Pietenpol-Archive.digest.vol-eh
January 04, 2005 - February 01, 2005
      > http://www.tools-for-woodworking.com/browseproducts/Winding-Sticks.html
      > Clif
      > .I have flattened one end of my
      > > rudder bar and I'm in doubt as to how to guarantee that when the other end
      > > is flattened, it will wind up in the same plane as the first. Any
      > > advice???....Carl Vought
      Rick Holland
Date: Jan 04, 2005
Subject: Joy stick question
Are the 2 fork bottom ends of the joysticks drilled 1/4" for the 1/4" bolt or 3/8" to go over the 3/8" rod which is welded inside the torque tube? Thanks -- Rick Holland ________________________________________________________________________________
Date: Jan 04, 2005
I drilled and reamed mine 1/4". If you welded the 3/8" tube to the torque tube, and had 3/8" holes in the stick fork, how would you get it over the ends of the tube? Jack Phillips -----Original Message----- Are the 2 fork bottom ends of the joysticks drilled 1/4" for the 1/4" bolt or 3/8" to go over the 3/8" rod which is welded inside the torque tube? Thanks -- Rick Holland ________________________________________________________________________________
Subject: Re: Torque Tube fit
Date: Jan 04, 2005
What if you install the torque tube before the seats are installed? Does this create some other problem? I noticed that in the original plans, an aileron horn is not mounted on the torque tube. Instead, the control cables attache to lugs welded to the stick. It looks like this installation can be completed after the seats are installed. Would appreciate any comments you folks have on these thoughts, so I'll know if I'm missing something. Thanks for all the great info passed along on this site. John S ----- Original Message ----- From: alexms1(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Sunday, January 02, 2005 10:05 PM Subject: Re: Pietenpol-List: Torque Tube fit Rick, Are you building the extended fuselage? That is what mine is and perhaps that has something to do with it. I have no problem installing my torque tube controls. Alex -------------- Original message -------------- Alex, The fit problem I had with my torque tube was due to its length. When I tried to fit the completed torque tube (Pulley supports and aileron horn welded in place) the aileron horn and front pulley support hit the front seat back before I could get the rear of the torque tube to clear the front of the rear seat. What I finally wound up doing is putting a 3/4" grove with a rotary sander in the front cross brace of the rear seat. Since the center of my rear seat is removable, I am going to just rebrace the seat and put a small cover over the hole. I think this is what others have done in the past that have had the same problem. The misfit was not off by much, so I am sure that on some Piet's the torque tube goes in fine. I spent today mounting my tailfeathers and trying to locate the ideal position for the elevator bellcrank to get rid of cable slack and rubbing of the cables on the horizontal stab. Rick ----- Original Message ----- From: To: pietenpol-list(at)matronics.com Sent: 12/31/04 9:44:44 PM Subject: Re: Pietenpol-List: Torque Tube fit Richard, When you say your torque tube does not fit just where does it not fit? I had no trouble placeing mine in for a temporary trial fit. I have not as yet placed the rudder bar as I am not sure as just what the distance from the seat front support it should be positioned. Other than that, Where is your problem? I may have a problem and not know it. Happy New Year. Alex S. -------------- Original message -------------- I just finished the rest of the welding on my torque tube and can't seem to get it to fit. From previous posts I new this was a problem so I mocked up the torque tube with wood and plastic. The fit was going to be tight but seemed to work out. Unfortunately the real thing wont fit. I know that Walt Evans and a couple of others have notched the rear seat to clear the rear pulley support, but I hate to do this if their is another solution. Has everyone else run into this same problem or is it just me? If you have what were the solutions? It looks like if I make the side leg openings in the front seat wider than the 6 inches shown on the plans, it may allow the aileron horn enough clearance to get the torque tube in, but I don't want to hog out more wood if it doesn't work. Richard Schreiber lmforge(at)earthlink.net ________________________________________________________________________________
Subject: Torque Tube fit
Date: Jan 04, 2005
That's what I did, John - installed the torque tube and then built the seats around it. No problems that way. Jack Phillips Fixing the other problems in NX899JP -----Original Message----- From: john s [mailto:smoyer98(at)snip.net] What if you install the torque tube before the seats are installed? Does this create some other problem? I noticed that in the original plans, an aileron horn is not mounted on the torque tube. Instead, the control cables attache to lugs welded to the stick. It looks like this installation can be completed after the seats are installed. Would appreciate any comments you folks have on these thoughts, so I'll know if I'm missing something. Thanks for all the great info passed along on this site. John S ________________________________________________________________________________
Date: Jan 04, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Piet Cont. motor mount on ebay
m> No bids yet on this guys. Don't know who has it up, but be super careful esp. that the firewall bolt hole pattern will line up with your fuselage mounting fittings. (or that he thinks it is for a Piet and it is really for a GN-1 or vice-versa) Mike C. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4515967655&category=26439&sspagename=WDVW ________________________________________________________________________________
Date: Jan 04, 2005
Subject: Re: Joy stick question
Bend the forks a bit. wrote: > > I drilled and reamed mine 1/4". If you welded the 3/8" tube to the > torque tube, and had 3/8" holes in the stick fork, how would you get it > over the ends of the tube? > > Jack Phillips > -----Original Message----- > > > Are the 2 fork bottom ends of the joysticks drilled 1/4" for the 1/4" > bolt or 3/8" to go over the 3/8" rod which is welded inside the torque > tube? > > Thanks > -- > Rick Holland > > > -- Rick Holland ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Jan 04, 2005
Alex, I am also building the long fuselage. As I said before, the torque tube came really close to fitting. If I had made the leg openings a little wider, or the triangle opening under the front set a little higher it would have probably fit just fine. The notch I put in the middle of the rear seat is only 1/2 inch deep. When I put the set bottom back on it is virtually invisible. Rick ________________________________________________________________________________
Date: Jan 05, 2005
Page 4 of the plans, top left, 1/4" bolt. Page 27, Flying and Glider, 1/4" bolt, admittedly a little hard to see, as per usual. :-) Clif > > Bend the forks a bit. > > > > > > I drilled and reamed mine 1/4". If you welded the 3/8" tube to the > > torque tube, and had 3/8" holes in the stick fork, how would you get it > > over the ends of the tube? > > > > Jack Phillips > > Are the 2 fork bottom ends of the joysticks drilled 1/4" for the 1/4" > > bolt or 3/8" to go over the 3/8" rod which is welded inside the torque > > tube? > > > > Thanks > > -- > > Rick Holland ________________________________________________________________________________
Date: Jan 05, 2005
Subject: Re: General metal working question
<004c01c4f157$27c44740$3f375142@Spot> One of the machinist tricks is to cut a block of material (wood would be fine here) so the block's edges have all the correct angles on them (square, hex, odd angles), then drill a hold through it, insert your material and clamp somehow. Don't remove the block until all your bending, drilling, jig boring or whatever is done. Figure out a way to reference the block's edges safely away from your working area. Jim Ash > >What alloy are you using? I used 4130 and Pressed it flat with a vice. I >didn't heat it for fear of hardening it to the point of being unable to >drill it for the fittings. 'Nuther question...I have flattened one end of my >rudder bar and I'm in doubt as to how to guarantee that when the other end >is flattened, it will wind up in the same plane as the first. Any >advice???....Carl Vought > > >----- Original Message ----- >From: "Catdesign" <catdesign(at)intergate.com> >To: >Sent: Monday, January 03, 2005 12:43 AM >Subject: Re: Pietenpol-List: General metal working question > > > > Rick > > > > No don't do it cold as this may cause cracking of the tubing. Also, don't > > just whack it with a hammer. Been there done that. Basically what you >want > > > > ________________________________________________________________________________
Subject: Looking for Dave Rowe
Date: Jan 05, 2005
Sorry to bother everyone else on the list, but Dave Rowe, if you're out there, please contact me off the list. Or if any of you have Dave's contact info, if you would please share it with me, I would like to talk to him about Yellow cedar. Thanks, Bill ________________________________________________________________________________
Date: Jan 05, 2005
From an archive (http://www.matronics.com/searching/search.html) search: Match: #7 Message: #25437 Date: Apr 20, 2004 From: dave rowe Subject: Re: aluminum parts <006901c426f5$4ece4340$1b02a8c0@WorkGroup> Roger that, things are pretty busy at the moment, but I will get them out by the end of the week. Thanks for the interest! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Subject: Pietenpol-List: Looking for Dave Rowe Sorry to bother everyone else on the list, but Dave Rowe, if you're out there, please contact me off the list. Or if any of you have Dave's contact info, if you would please share it with me, I would like to talk to him about Yellow cedar. Thanks, Bill ________________________________________________________________________________
Date: Jan 05, 2005
Thanks Jim, But I was in contact with Dave back in August, and he indicated that his e-mail address would be discontinued at the end of the August, and would be in touch. But no word yet. Bill -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jim Markle Subject: RE: Pietenpol-List: Looking for Dave Rowe >From an archive (http://www.matronics.com/searching/search.html) search: dave rowe -----Original Message----- Sorry to bother everyone else on the list, but Dave Rowe, if you're out there, please contact me off the list. Or if any of you have Dave's contact info, if you would please share it with me, I would like to talk to him about Yellow cedar. Thanks, Bill ________________________________________________________________________________
From: "tmbrant1(at)netzero.net" <tmbrant1(at)netzero.net>
Date: Jan 06, 2005
Subject: missing drawings - help!!
Can anyone help me? We've cleaned our basement and somehow have lost (misplaced I hope) 3 drawings. The tail section, 3 piece wing and regular wing dwg with the rib layout. I've found all the others. Anyone around MPLS that would be willing to let me make a copy of these??? I have my capstrip on order and I'm anxious to get going on the ribs as soon as it comes in. PS: Pietenpol Aircamper dwgs - not GN-1 Thanks! Tom B. ________________________________________________________________________________
Date: Jan 05, 2005
Subject: Re: Looking for Dave Rowe
I'm going to the Island ( Van Isle ) this weekend so I can get Dave's number in the local book and call him. I can also call his friend Paul if necessary Considering what he does for a living he could even be back in the middle east. If so I hope he's got a good supply of cantalopes and surgical tubing. Clif > > Thanks Jim, > > But I was in contact with Dave back in August, and he indicated that his > e-mail address would be discontinued at the end of the August, and would be > in touch. But no word yet. > > Bill ________________________________________________________________________________
Subject: quiet on the list/insurance
Date: Jan 07, 2005
Too quiet on this list, so I'll throw out a question and a comment. First the comment. My repaired/overhauled carb (from the nose-over incident) is on its way back to me from the rebuild shop in Corsicana as we speak. With the carb in hand, I should be able to put in some fuel and fire the engine to see if we can work on the carb heat situation. Airframe and landing gear repairs are still underway. Now the question. Sometime back, a kind soul posted information about Butler-Brown insurance being very reasonable. My insurance will be coming up for renewal this year and I was going to apply to Butler-Brown for a quote but they require that you be a member of Antique Aircraft Association. Not a big deal; $36 annual membership, which I should be able to afford if their premiums are better than what I'm paying now. My question is, AAA has "type clubs", one of which is a Pietenpol association, for additional annual membership fees. Anyone have any comments as to the value of belonging to AAA and/or its Pietenpol type club? Happy Friday-! Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 07, 2005
Subject: Re: missing drawings - help!!
Tom I'm out of town till about the 15th. If thats soon enough we can compare drawings and see whats missing. Dick N. > > > > Can anyone help me? We've cleaned our basement and somehow have lost > (misplaced I hope) 3 drawings. The tail section, 3 piece wing and regular > wing dwg with the rib layout. I've found all the others. Anyone around > MPLS that would be willing to let me make a copy of these??? I have my > capstrip on order and I'm anxious to get going on the ribs as soon as it > comes in. > > PS: Pietenpol Aircamper dwgs - not GN-1 > > Thanks! > > Tom B. > > ________________________________________________________________________________
Date: Jan 07, 2005
Subject: Alternate Woods, status report
I do believe that the wood construction phase of my Piet is now virtually complete. I began in earnest to build Feb. 1, 2002, almost three years ago. Ive tried to use good Douglas Fir, and Basswood plywood wherever possible.A year or so ago I compared fuselage weights with someone on the list here, and I came up with 71 pounds, vs 70 pounds for a spruce fuse. I think that both fuses were in about the same condition, but nothing definitve can be drawn from these figures. I began work on the wings a summer ago, laminating the spars from Fir, 7 layers. The ribs were of fir, with basswood gussets. Ive been working nearly every day(Im retired), so I have to agree with the year and a half estimate as a reasonable time to build the wings(and center section ). So 14 ribs(enough for one side of the wing), weighed very close to 5 pounds.I truly do not believe that it would make a big difference if the pile weighed 4 pounds, or 6. So strength of wood here is not a problem either because the capstrips are so large. Each laminated spar weighed 10 pounds at the start of construction, so I began with 25 pounds of ribs and spars for each wing. Now the ailerons are installed with piano hinges, and the metal fittings,etc. And the wing weighs in at ------- pounds(Ill weigh them soon and report). The wings have really been a pleasure to work on, even if there is a multitude of parts. I built the tailfeathers first, then the fuse, then the Center Section, finally the wings. Maybe if I built another Piet, I would do the wings at the beginning. We have a 35 Piet on the airport, which is non-flyable, but interesting. It has a two-piece wing, which I am beginning to think is superior to the Vi Kapler design, since the aileron control cables can be run directly to each wing. Im still a little bit perplexed about how one connects the control cables through the Center Section in such a way that they can be easily re-connected. Im amazed at the difference the drag and anti-drag wires make to the rigidity of the wing. I put in some temporary hardware store wires to stiffen the wing while finishing it. The fellow next to me is building a scaled Jenny, and has installed 3/32 cables for the drag and anti-drag braces. He uses Cable Bushings rather than turnbuckles, twisting the cable to achieve the correct tension, after pulling the cable tightly around the Bushing. It is easy to adjust the tension, each half twist tightening the cable by about five pounds. His spec. calls for 35# tension, a figure I think that I will use. I made a set of turnbuckles early on, so cost is not a factor, rather the weight saving and simpler hardware seems to me to be worthwhile. I bought the folded trailing edge at AS&S. Planning to clean the aluminum carefully, then to Epoxy the T.E. to the ends of the ribs with T-88. ________________________________________________________________________________
Subject: aileron control cables
Date: Jan 07, 2005
ANNCARLEK wrote- >Im still a little bit perplexed about how one connects the control cables >through the Center Section in such a way that they can be easily >re-connected. I can tell you how that works, having just disconnected the cables on my/Corky's Piet. Very clever. There are inspection covers on the wings just outboard of the gaps between center section and outboard wing panels, and you insert a removable link in the lower control cables going to each aileron. I believe these are like motorcycle master links but with a clevis pin at each end so you can remove them. The upper cable, which runs between wings, is accessed through a slot in the underside of the wing center section above the cockpit. Corky installed a removable metal (aluminum sheet) panel covering this slot. Up in the slot a turnbuckle joins the cable and also allows adjusting the tension in the connecting cable, and of course unscrewing the turnbuckle allows the cable to disconnect. I should take a picture, since it's far simpler to see than to explain, but the wings are 200 miles from the fuselage right now. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 07, 2005
Subject: [PLEASE READ NOW] - Addressing Upgrade At Matronics TONIGHT!
Dear Listers, Service Provider to upgrade to a larger IP subnet. I will be re-addressing all of the machines on the network including the Matronics Web Server and Matronics Email Server at that time. Name Service will be updated at that time as well and most things should work again pretty quick. There may be some bounced email for a few hours or even a day or so as the new name-to-ip-address resolutions propagate into the depths of the Internet. If you have problems posting a message to one of the Lists or get a bounced message back, please wait a couple of hours and try sending it again. Generally, access to the web site should work within 1-hour of Hopefully the transition will go smoothly and you'll hardly even notice! :-) Thanks for your patience! Matt Dralle List Administrator -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Horizontal and Vertical stab fittings
Date: Jan 07, 2005
I know this was asked on this list once before, but I never found any replies. I am in the process of attaching the fittings on the horizontal and vertical stabilizers. Specifically the rear stabilizer fittings that attach the vertical stab to the horizontal stab and to the rear of the fuselage. My question is if I drill all of the holes and put the fittings in place before covering, won't all of the holes drilled through the wood be off by the thickness of the fabric if the fittings are on the outside of the fabric after final assembly? I realize that Bernard originally had these fittings under the covering fabric where this would be a non-issue, but if the fittings are on the outside what do you do to insure proper alignment? Also how about the lower tail brace wire fitting. How has everyone mounted this fitting? Above or below the fabric? Richard Schreiber lmforge(at)earthlink.net ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Missing dwgs - found!! - other news.
Thanks to all for the offers on copying / emailing dwgs! This list is great.. I was somewhat embarrassed to ask (as if the piet dwgs were priceless works of art not to be misplaced). My wife had a revelation and looked in a box, and there they were - happy to be found. In other news, it seems I've gotten the bug again.. I'm planning to sell my flying club share (anyone interested) for $3500 or so and then to invest that in the Piet. Just not flying enough lately to make the club worth it, besides, I need to find a taildragger and get some lessons. I'd like to switch to taildraggers altogether. Anyone around KMIC who might know of a good deal on taildragger time / instruction?? Anyone interested in my Yankee flying club membership? Tom B. ________________________________________________________________________________
Date: Jan 07, 2005
Subject: Re: quiet on the list/insurance
Oscar, Don't waste your money on the type club. I was a member of the International Pietenpol Association until AAA took it over, and then saw no more newsletters for my multiple year membership. After numerous inquiries, Robert Taylor sent a "double" newsletter out and told everyone that their membership had been completed. It wasn't until the Buckeye Pietenpol Association, and then the Brodhead groups came along that we started getting regular news and information on the Pietenpol and owners. I had also joined the AAA to get the "great deal" from Butler and Brown, and also didn't receive the regular newsletters for that organization. After I let my AAA membership expire, Butler and Brown contacted me (I suspect Taylor ratted me out) and told me they were cancelling my policy. I found insurance through an independent agent who wrote my policy with the same underwriter for the same cost. I am now insured through the EAA Vintage Divison group policy with AUA, (800-727-3823). My recommendation would be to join EAA and the Vintage Division, even though you will pay more for the membership, but your money won't be going to support Taylor and his kids, and you will be sure to get a couple of great magazines, EVERY MONTH, no excuses and no lies. My two cents (from a happy EAA/VAA'er) Darrel Jones Pfiefer Sport N154JP Sonoma, CA Oscar Zuniga wrote: > > > Too quiet on this list, so I'll throw out a question and a comment. > > First the comment. My repaired/overhauled carb (from the nose-over > incident) is on its way back to me from the rebuild shop in Corsicana > as we speak. With the carb in hand, I should be able to put in some > fuel and fire the engine to see if we can work on the carb heat > situation. Airframe and landing gear repairs are still underway. > > Now the question. Sometime back, a kind soul posted information about > Butler-Brown insurance being very reasonable. My insurance will be > coming up for renewal this year and I was going to apply to > Butler-Brown for a quote but they require that you be a member of > Antique Aircraft Association. Not a big deal; $36 annual membership, > which I should be able to afford if their premiums are better than > what I'm paying now. My question is, AAA has "type clubs", one of > which is a Pietenpol association, for additional annual membership > fees. Anyone have any comments as to the value of belonging to AAA > and/or its Pietenpol type club? > > Happy Friday-! > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Re: Horizontal and Vertical stab fittings
Richard I asked the same question a couple months ago and didn't get an answer so I just put a single thin washer between each fitting and the fin when I measured to drill the hole in the horizontal stab. Won't know if it was necessary until after I cover it. I am mounting all my tail fittings on top of the fabric including the bottom tail wire fitting. Don't know if its the best way, just have seen a lot of Piets done that way. Rick H wrote: > > > > > I know this was asked on this list once before, but I never found any > replies. I am in the process of attaching the fittings on the horizontal and > vertical stabilizers. Specifically the rear stabilizer fittings that attach > the vertical stab to the horizontal stab and to the rear of the fuselage. > My question is if I drill all of the holes and put the fittings in place > before covering, won't all of the holes drilled through the wood be off by > the thickness of the fabric if the fittings are on the outside of the fabric > after final assembly? I realize that Bernard originally had these fittings > under the covering fabric where this would be a non-issue, but if the > fittings are on the outside what do you do to insure proper alignment? > > Also how about the lower tail brace wire fitting. How has everyone mounted > this fitting? Above or below the fabric? > > > Richard Schreiber > lmforge(at)earthlink.net > > > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 08, 2005
Due to the overlap of fabric along the edges and to the fabric tape which you will be placing over that overlap, the total thickness of the multiple layers of fabric is surprising. Fortunately, the only critical implication is the spacing of the bottom rudder hinge. The fin can be raised nearly 1/4 inch by the fabric between it and the stab and the stab and the fuselage. While one washer as a spacer is a good start, you might want to double that and/or make your rudder hinges adjustable. Jim Malley ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Re: Pietenpol-List: Horizontal and Vertical stab fittings > > Richard > > I asked the same question a couple months ago and didn't get an answer > so I just put a single thin washer between each fitting and the fin > when I measured to drill the hole in the horizontal stab. Won't know > if it was necessary until after I cover it. > > I am mounting all my tail fittings on top of the fabric including the > bottom tail wire fitting. Don't know if its the best way, just have > seen a lot of Piets done that way. > > Rick H > > > wrote: > > > > > > > > > > I know this was asked on this list once before, but I never found any > > replies. I am in the process of attaching the fittings on the horizontal and > > vertical stabilizers. Specifically the rear stabilizer fittings that attach > > the vertical stab to the horizontal stab and to the rear of the fuselage. > > My question is if I drill all of the holes and put the fittings in place > > before covering, won't all of the holes drilled through the wood be off by > > the thickness of the fabric if the fittings are on the outside of the fabric > > after final assembly? I realize that Bernard originally had these fittings > > under the covering fabric where this would be a non-issue, but if the > > fittings are on the outside what do you do to insure proper alignment? > > > > Also how about the lower tail brace wire fitting. How has everyone mounted > > this fitting? Above or below the fabric? > > > > > > Richard Schreiber > > lmforge(at)earthlink.net > > > > > > > > > > > > > -- > Rick Holland > > ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Re: Missing dwgs - found!! - other news.
Tom Try Dave at Osceola Aviation for the taildragger time. He has a Champ with a C-85. It's pretty close to how the Piet will feel, except for the wind on your face. Dick > > > > Thanks to all for the offers on copying / emailing dwgs! This list is > great.. I was somewhat embarrassed to ask (as if the piet dwgs were > priceless works of art not to be misplaced). My wife had a revelation and > looked in a box, and there they were - happy to be found. > > In other news, it seems I've gotten the bug again.. I'm planning to sell > my flying club share (anyone interested) for $3500 or so and then to > invest that in the Piet. Just not flying enough lately to make the club > worth it, besides, I need to find a taildragger and get some lessons. I'd > like to switch to taildraggers altogether. Anyone around KMIC who might > know of a good deal on taildragger time / instruction?? Anyone interested > in my Yankee flying club membership? > > Tom B. > > ________________________________________________________________________________
Date: Jan 08, 2005
Subject: good place to get engine hoist?
Curious if anyone has experience with Northern Tool and Equipment--got their catalog in the general junk mail a couple of days ago, but saw that they have a small engine hoist for $129. It's cheaper and smaller than even Harbor Freight's, but looks like it's probably enough for handling my Corvair block which I'd like to start working on. Worth the risk? Mark Hodgson ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Re: good place to get engine hoist?
Be sure to check their shipping charges. Sometimes they are a little high. Otherwise I have had good luck with their products JIM ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Re: Pietenpol-List Digest: 8 Msgs - 01/07/05
In a message dated 1/7/05 11:08:29 PM, pietenpol-list-digest(at)matronics.com writes: << From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: aileron control cables >> Thanks, Oscar. I am just a poor retired space computer engineer, and would truly never think of something easy! But I'll do it like you say. It would be nice to see a picture! ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Deke Slayton Museum Pietenpol
According to the La Crosse Tribune newspaper (La Crosse, Wis.) the other day a Pietenpol Air Camper has been donated to the Deke Slayton Museum in Sparta, Wis. Sparta is 25 miles east of La Crosse on I-90. The Piet has been suspended from the ceiling of the museum. I don't know who donated the Piet but will check it out, get some pics and report later. For the younger Piet builders, Deke Slayton was one of the original Mercury program astronauts but did not fly due to a suspected heart murmur -- he did, however, fly later on one of the Apollo/Skylab/Soyuz (I believe that's correct) missions. Deke was originally from Sparta and flew P-51s in WW2. He died a few years ago after heading up a private space launch venture that was similar in vision to Burt Rutan's enterprise. FWIW -- I flipped my Piet fuselage right side up on the bench this past week. I am now in the process of adding the top cross braces and will add instrument panels, controls, seats and rear fairing in the coming weeks... BTW, has anyone considered using the solid aluminum disc wheels as installed on the Harley Davidson "Fat Boy" motorcycles in recent years. There are many of these wheels currently for sale on e-Bay at reasonable prices. They look 1920s period, at least they do to me (especially if they were painted to match the airplane). I don't know what the big Harleys weigh, but I suspect these=20are much stronger than a spoked motorcycle wheel =E2=80=94 and I would think also able to withstand a considerable side load. As they are aluminum, they must also be relatively light. I'd be interested in others' thoughts on this wheel possibility, especially if anyone has used them or seen them used. Regards to all, Fred B. ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Sat in my first Peit today
Well some things are just never what they seem. Im about 6ft or so and about 220, and shoe horned myself into a Peit this afternoon. I was simply too big to fit in the airplane. Knees hit the panel. Couldn't reach the heel brakes. Head was higher that it probably really needed to be for such an airplane and reaching the throttle required the same technique as driving with a window open and an arm hanging out the window in the breeze. Now building one of the stock ones is out of the question, but did anyone ever come up with plans based on the orginal that would be for a guy the size of Bernie? Mark > > ________________________________________________________________________________
Date: Jan 08, 2005
Subject: Re: Sat in my first Peit today
Contact me direct if you really want some suggested changes for size. Don't want the fury of the purists on my neck Corky ________________________________________________________________________________
Date: Jan 08, 2005
Mark, From my experience the most useful shop tool for tear down is a engine stand that enables the engine to be rotated. I have a Harbor Freight hoist also but it mostly takes up space but is a very handy and safe way to mount and demount the engine.I consider the Harbor Freight hoist a quality product. Lynn Knoll Wichita - Piet/Vair ----- Original Message ----- From: "Mark Hodgson" <mhodgson(at)bu.edu> Subject: Pietenpol-List: good place to get engine hoist? > > Curious if anyone has experience with Northern Tool and Equipment--got > their catalog in the general junk mail a couple of days ago, but saw that > they have a small engine hoist for $129. It's cheaper and smaller than > even > Harbor Freight's, but looks like it's probably enough for handling my > Corvair block which I'd like to start working on. Worth the risk? > > Mark Hodgson > > > ________________________________________________________________________________
Date: Jan 08, 2005
Almost any cheap hoist would handle a corvair engine. Most of them are made with long arms and legs for hoisting engines out of an auto engine bay and take quite a bit of room to store. If you only need something to lift a corvair engine onto a Piet, you could probably weld up something much more compact or just use a block and tackle from the rafters. At 200 lbs even a 2x4 truss would hold it. -Mike McCarty ----- Original Message ----- From: "Mark Hodgson" <mhodgson(at)bu.edu> Subject: Pietenpol-List: good place to get engine hoist? > > Curious if anyone has experience with Northern Tool and Equipment--got > their catalog in the general junk mail a couple of days ago, but saw that > they have a small engine hoist for $129. It's cheaper and smaller than even > Harbor Freight's, but looks like it's probably enough for handling my > Corvair block which I'd like to start working on. Worth the risk? > > Mark Hodgson > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 09, 2005
Subject: Bunji Struts
Piet Builders, I have a pair of bunji struts, that I replaced with spring struts. They are plans built, except I had to put a slight bend in them, where they criss cross, to eliminate any contact, because the lugs were not offset enough. They have the plans type plugs to retain the bunji's. Also a few extra bunji chords. If anyone needs 'em, they are yours for FREE - you pay shipping. e-mail me direct. Chuck Gantzer NX770CG Wichita, KS ________________________________________________________________________________
Date: Jan 09, 2005
Hi Mark, Many have widend the fuselage. I too had the same question. I widend the fuselage, raised the seats and instrument palnels. I will send pics off line if you want to see them. Doc > > > > > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://my.yahoo.com ________________________________________________________________________________
Subject: Re: Bunji Struts
Date: Jan 09, 2005
I would be very interested in your bunji struts. I live in Missouri so just let me know how and were you would like the check to be sent. I do thank you for your time. Chet Hartley ________________________________________________________________________________
Date: Jan 09, 2005
I installed a Lycoming 0-320 engine in my Cherokee using my tractor and a boom on a three point hitch. The boom was $89 at Tractor Supply. If you have a friend with a tractor having a 3 point hitch, this might work for you. It was a very easy installation and the conical engine mount on the Cherokee is probably harder to stab than plugging a Continental A-65 onto a Piet. ________________________________________________________________________________
Date: Jan 09, 2005
I'm going to be in Chuck's neck of the woods late this month. If someone along my route home (Wichita and or Kansas City, MO) to Central Texas) makes an agreement with Chuck for the gear legs, I can drop them off if not too far off my route home. I'll be heading back to the Dallas area, and then on to 5TA6, San Antonio Sectional. I'll be on the road back to Texas probably Jan. 31 or Feb 1. Sterling Brooks ________________________________________________________________________________
Date: Jan 09, 2005
I used a "come-along" suspended from the header beam above my hangar door. Just suspended the engine and rolled the airframe under neath it. ----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Sunday, January 09, 2005 9:39 AM Subject: Re: Pietenpol-List: good place to get engine hoist? I installed a Lycoming 0-320 engine in my Cherokee using my tractor and a boom on a three point hitch. The boom was $89 at Tractor Supply. If you have a friend with a tractor having a 3 point hitch, this might work for you. It was a very easy installation and the conical engine mount on the Cherokee is probably harder to stab than plugging a Continental A-65 onto a Piet. ________________________________________________________________________________
Date: Jan 09, 2005
You don't need a hoist at all. Just set the engine on a table and roll the fuselage up to it. prop up the tail to the right height, block the wheels, and shim up the engine till it lines up. use a pry bar to tilt the engine a little. Del Michael McCarty wrote: Almost any cheap hoist would handle a corvair engine. Most of them are made with long arms and legs for hoisting engines out of an auto engine bay and take quite a bit of room to store. If you only need something to lift a corvair engine onto a Piet, you could probably weld up something much more compact or just use a block and tackle from the rafters. At 200 lbs even a 2x4 truss would hold it. -Mike McCarty ----- Original Message ----- From: "Mark Hodgson" Subject: Pietenpol-List: good place to get engine hoist? > > Curious if anyone has experience with Northern Tool and Equipment--got > their catalog in the general junk mail a couple of days ago, but saw that > they have a small engine hoist for $129. It's cheaper and smaller than even > Harbor Freight's, but looks like it's probably enough for handling my > Corvair block which I'd like to start working on. Worth the risk? > > Mark Hodgson > > > > > > > > > > > > > Del-New Richmond, Wi "farmerdel(at)rocketmail.com" --------------------------------- ________________________________________________________________________________
Date: Jan 09, 2005
Chet, You were the first one to reply, so I guess you get the bunji struts. There is one other guy down in central Oklahoma that said he would like to have 'em, so if you think you won't use them, I hope you can send them on to someone else who would use them. I don't know what the shipping would be. I will pack them up this week, and send them off to you, then let you know what the shipping was. What is your address to send them to ?? Here is a picture of them, on the plane. I could never keep them tight enough, so I changed them out for the spring struts. I will also send out a copy of the details of how to tie the loops on the ends of the bunji chords. Chuck Gantzer ________________________________________________________________________________
Date: Jan 09, 2005
<007e01c4f3b8$aab0c4e0$4e705118@dawsonaviation> Well, I've just returned from Victoria with no joy on Dave. His friend Paul hasn't heard from him in some time either. After returning from the Gulf the last time he got out of his house and bought a $200,000 boat. He rented a corner of a hanger to store the Piet and Santa Anna. Paul thinks the boat purchase has stretched things for Dave as he wasn't his usual upbeat self the last time they met. He's going to see what more he can do and call me if successful. Clif > > I'm going to the Island ( Van Isle ) this weekend so I > can get Dave's number in the local book and call him. > I can also call his friend Paul if necessary. > Clif > > > > > > Thanks Jim, > > > > But I was in contact with Dave back in August, and he indicated that his > > e-mail address would be discontinued at the end of the August, and would > be > > in touch. But no word yet. > > > > Bill > > ________________________________________________________________________________
Date: Jan 10, 2005
Well, I don't get attachments since I'm on the list digest, but rather than wait for photoshare, I've attached some photos and hope they shows what I'm talking about. P1080012 shows the removable access panel on the underside of my wing center section that allows disconnecting the aileron control cable that runs between the two wings. Removing this panel opens up a "slot" in the aft underside of the center section. The turnbuckle is up inside this slot. The other cables are accessed via regular round access covers in the wing panels, where disconnect links are installed in the cables. You can see those in the second picture (PB130011), along with the dried blood on the underside of the center section "flop". The blood is from pilot Charlie's forehead, having snapped off the ignition key with his forehead when the plane stopped suddenly and went over on its back. A little tip for when you're laying out your instrument panel! Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 10, 2005
Per usual with this list, thanks to all for the good comments! Turns out that Bill Rewey, a Brodhead regular and the author of a number of useful Piet documents, actually has plans for an adequate wooden engine hoist that should cost a whole lot less and allow me to generate a little more sawdust in my basement as well. A list member clued me in to this; then I took a second look at the packet of materials I had actually gotten from Bill at Brodhead last summer, and voila--something I had overlooked completely last July! Got to organize my Piet literature better (maybe after I've built the beast). Or as they say in systems work, "Start coding; we'll get you the specs as soon as we know what they are..." Or as I might say: "Duhhhh..." Mark Hodgson ________________________________________________________________________________
Date: Jan 10, 2005
Chuck: Thank you so much this will be a great help on my piet as of right now all I have is the fusealodge and tail group. Question: We will be traveling back from a ski trip in Colorado this next week, the15th through the 22nd. I would like to stop and pick up the struts on Sunday the 23rd. If this would be possible. If not. My adddress is: Chet Hartley 200 Franklin St. Holts Summit, MO 65043-3504 Home Phone is 573-896-5405 Cell phone is 573-645-0534 ----- Original Message ----- ________________________________________________________________________________ <41E0A410.4000401(at)dp.net>
Date: Jan 10, 2005
Mark I built a fuselage at Sun n Fun acouple of years ago that might suit you. Take the basic long fuse plan and trty substituting the measurements for the forward bridge decks to the short fuselage plan. I also reclined my rear seat by 1" for comfort. You shold be able to get an additional 8-9" in this process. It made all the diffrence to me. 5'11" & 200 lb. Dick N. > > Well some things are just never what they seem. Im about 6ft or so and > about 220, and shoe horned myself into a Peit this afternoon. I was > simply too big to fit in the airplane. Knees hit the panel. Couldn't > reach the heel brakes. Head was higher that it probably really needed > to be for such an airplane and reaching the throttle required the same > technique as driving with a window open and an arm hanging out the > window in the breeze. > > Now building one of the stock ones is out of the question, but did > anyone ever come up with plans based on the orginal that would be for a > guy the size of Bernie? > > Mark > >> >> > > ________________________________________________________________________________
Date: Jan 10, 2005
Subject: Re: Deke Slayton Museum Pietenpol
Fred If you use those Harley wheels be sure to start with the newer models with the sealed bearings. I am out out of town now but check the archives on this under "Harley wheels" I have posted some pics and discussed this in the past. Or if you want further info e-mail me direct, I have lots on Harley parts. Dick N. > According to the La Crosse Tribune newspaper (La Crosse, Wis.) the other > day > a Pietenpol Air Camper has been donated to the Deke Slayton Museum in > Sparta, > Wis. Sparta is 25 miles east of La Crosse on I-90. The Piet has been > suspended > from the ceiling of the museum. I don't know who donated the Piet but will > check it out, get some pics and report later. > > For the younger Piet builders, Deke Slayton was one of the original > Mercury > program astronauts but did not fly due to a suspected heart murmur -- he > did, > however, fly later on one of the Apollo/Skylab/Soyuz (I believe that's > correct) > missions. Deke was originally from Sparta and flew P-51s in WW2. He died a > few years ago after heading up a private space launch venture that was > similar > in vision to Burt Rutan's enterprise. > > FWIW -- I flipped my Piet fuselage right side up on the bench this past > week. > I am now in the process of adding the top cross braces and will add > instrument panels, controls, seats and rear fairing in the coming weeks... > > BTW, has anyone considered using the solid aluminum disc wheels as > installed > on the Harley Davidson "Fat Boy" motorcycles in recent years. There are > many > of these wheels currently for sale on e-Bay at reasonable prices. They > look > 1920s period, at least they do to me (especially if they were painted to > match > the airplane). I don't know what the big Harleys weigh, but I suspect > these are > much stronger than a spoked motorcycle wheel and I would think also > able to > withstand a considerable side load. As they are aluminum, they must also > be > relatively light. I'd be interested in others' thoughts on this wheel > possibility, especially if anyone has used them or seen them used. > > Regards to all, > Fred B. > > ________________________________________________________________________________
Date: Jan 10, 2005
<000501c4f5b0$cc312ac0$0202a8c0@UPSTAIRS> How about finishing and mounting everything except the rudder Then you can mount the bottom hinge, rudder side, to fit the fuselage side. Clif > > Due to the overlap of fabric along the edges and to the fabric tape which > you will be placing over that overlap, the total thickness of the multiple > layers of fabric is surprising. Fortunately, the only critical implication > is the spacing of the bottom rudder hinge. The fin can be raised nearly 1/4 > inch by the fabric between it and the stab and the stab and the fuselage. > While one washer as a spacer is a good start, you might want to double that > and/or make your rudder hinges adjustable. > Jim Malley > ________________________________________________________________________________
Date: Jan 10, 2005
<2586.65.10.64.45.1105408777.squirrel(at)webmail.iphouse.com> Thanks for all those that have responded. I am sure you could modify the plans, but that really was not what I was looking for. Though it might work, when you modify plans you open up a whole can of worms and the proven nature of the design becomes something that is totally untested. I do not have the engineering expertise to be able to do that, and was hoping someone had. I would need more than just more cockpit room. The wing would need to be raised for me to see and getting in the front would be a physical impossiblity without some changes. I hoped someone had essentially a different set of plans that had been reviewed and used for some time in a number of airplanes. Though it looks like fun a Piet may not be the right airplane for me. horzpool(at)goldengate.net wrote: > >Mark >I built a fuselage at Sun n Fun acouple of years ago that might suit you. >Take the basic long fuse plan and trty substituting the measurements for >the forward bridge decks to the short fuselage plan. I also reclined my >rear seat by 1" for comfort. You shold be able to get an additional 8-9" >in this process. It made all the diffrence to me. 5'11" & 200 lb. >Dick N. > > > > >>> >>> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > > ________________________________________________________________________________
Subject: Fuel tank & parts
Date: Jan 11, 2005
Well, I need to clean the hangar out and I have a pile of Piet parts that needs to move. I have an aluminum center section gas tank (12.5 gal.), a 1 gallon header tank & shutoff valve, control stick assembly, and ALL the fabricated hardware for a piet. The hardware is all fabricated out of 4130 and has about 45 hours on it. The fuel tank has a built in sight gage and is built like an RV gas tank with rivets & pro-seal joints. The tank was built for a piet with a plans built 1 piece wing and I do not know if it will fit in the center section of a 3 piece wing. It all works just fine. It was taken off of my wind damaged (and ground looped) piet. I figure that $200 is a fair price for the many hours of labor that went into the stuff. (That probably amounts to about 50 cent an hour :-) The only problem is that the buyer has to pick it all up here near Austin, TX. The fuel tank has residual fuel in it making shipping out of the question. If anybody is interested, please contact me off list. Bob Seibert dsseibert(at)earthlink.net EarthLink Revolves Around You. ________________________________________________________________________________
Date: Jan 11, 2005
Mark, Don't give up on the Pietenpol just yet. I'm 6' 2-1/2" and over 200 lbs. I built the long fuselage version, which gives more legroom in both cockpits. I made the fuselage 1" wider, which helps a lot (I've flown standard width Piets and that extra inch really helps), and I raised the wing 2-3/4" higher than the plans indicate. The impact to the structure is minimal - just make the centersection 1" wider so the cabane struts will line up, and make the cabane struts enough longer to raise the centersection to where you want it. I also raised my turtledeck a couple of inches so you feel like you are riding in, rather than on, the airplane. Jack Phillips NX899JP -----Original Message----- ...I would need more than just more cockpit room. The wing would need to be raised for me to see and getting in the front would be a physical impossiblity without some changes. I hoped someone had essentially a different set of plans that had been reviewed and used for some time in a number of airplanes. Though it looks like fun a Piet may not be the right airplane for me. ________________________________________________________________________________
Date: Jan 11, 2005
Order the long fuselage plans and first build a mock cockpit out of scrap wood (as recommended by Bengelis). You can lean back the seat back, build the seat lower in the fuselage, some even build the fuselage a couple inches taller. People widen fuselages up to 4 inches and raise the turtle decks also. Think of the fuselage a big slab of clay you can mold to you needs (within limits). I am building to the long fuselage plans, added 6" to the length in front (as recommended by Bernie himself), lowered and leaned the rear seat back a bit, raised the rear turtle deck 3" and the front 1". Widened fuselage to 26" outside dimensions firewall to rear seat back. Of course it hasn't flown yet so take this info for what little it is worth. Rick Holland > > Well some things are just never what they seem. Im about 6ft or so and > about 220, and shoe horned myself into a Peit this afternoon. I was > simply too big to fit in the airplane. Knees hit the panel. Couldn't > reach the heel brakes. Head was higher that it probably really needed > to be for such an airplane and reaching the throttle required the same > technique as driving with a window open and an arm hanging out the > window in the breeze. > > Now building one of the stock ones is out of the question, but did > anyone ever come up with plans based on the orginal that would be for a > guy the size of Bernie? > > Mark > > > > > > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 11, 2005
Dang, didn't think about spacing for the bottom rudder hinge. Wish you were around Jim when I asked this question a couple months ago. My hinge position is adjustable but the holes I drilled for it in the fuselage are not. Will probably have to fill and redrill the holes after covering. Rick H > > Due to the overlap of fabric along the edges and to the fabric tape which > you will be placing over that overlap, the total thickness of the multiple > layers of fabric is surprising. Fortunately, the only critical implication > is the spacing of the bottom rudder hinge. The fin can be raised nearly 1/4 > inch by the fabric between it and the stab and the stab and the fuselage. > While one washer as a spacer is a good start, you might want to double that > and/or make your rudder hinges adjustable. > Jim Malley > > ----- Original Message ----- > From: "Rick Holland" <at7000ft(at)gmail.com> > To: > Sent: Saturday, January 08, 2005 12:04 PM > Subject: Re: Pietenpol-List: Horizontal and Vertical stab fittings > > > > > Richard > > > > I asked the same question a couple months ago and didn't get an answer > > so I just put a single thin washer between each fitting and the fin > > when I measured to drill the hole in the horizontal stab. Won't know > > if it was necessary until after I cover it. > > > > I am mounting all my tail fittings on top of the fabric including the > > bottom tail wire fitting. Don't know if its the best way, just have > > seen a lot of Piets done that way. > > > > Rick H > > > > > > wrote: > > > > > > > > > > > > > > > I know this was asked on this list once before, but I never found any > > > replies. I am in the process of attaching the fittings on the horizontal > and > > > vertical stabilizers. Specifically the rear stabilizer fittings that > attach > > > the vertical stab to the horizontal stab and to the rear of the > fuselage. > > > My question is if I drill all of the holes and put the fittings in place > > > before covering, won't all of the holes drilled through the wood be off > by > > > the thickness of the fabric if the fittings are on the outside of the > fabric > > > after final assembly? I realize that Bernard originally had these > fittings > > > under the covering fabric where this would be a non-issue, but if the > > > fittings are on the outside what do you do to insure proper alignment? > > > > > > Also how about the lower tail brace wire fitting. How has everyone > mounted > > > this fitting? Above or below the fabric? > > > > > > > > > Richard Schreiber > > > lmforge(at)earthlink.net > > > > > > > > > > > > > > > > > > > > > -- > > Rick Holland > > > > > > > > > > > > > > > > > > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 11, 2005
The fabric overlap on the fuselage should not be any more than on the vertical fin, so I don't understand why you would need to adjust for that. You just need to make sure all your hinges have a "fabric allowance" built into them Jack Phillips -----Original Message----- Dang, didn't think about spacing for the bottom rudder hinge. Wish you were around Jim when I asked this question a couple months ago. My hinge position is adjustable but the holes I drilled for it in the fuselage are not. Will probably have to fill and redrill the holes after covering. Rick H ________________________________________________________________________________
Subject: rear cockpit solo
Date: Jan 11, 2005
Howdy, folks; Working through the weight & balance on 41CC and looking at extreme forward and rearward C of G conditions in the spreadsheet (thanks, Bert and Nancy Conoly!), I've noticed a couple of things. 1. There doesn't appear to be any loading that will bring the plane to max gross without shifting out of the aft C of G allowable range. This is good insofar as it will be nearly impossible to overload the airplane, but does indicate some care is required to keep the aft C of G in range. With 170 lb. pilot and 210 lb. passenger, minimum fuel (2 gal.), and min. oil, it's at maximum aft limit but still 183 lbs. under gross. I've shifted loads around (in the spreadsheet) and this seems to be worst aft C of G case that will still allow me to approach max. gross. Obviously, I can go up on the passenger weight, but as an example- at my present weight of 150 lbs., the spreadsheet says I can fit a 413 lb. passenger in the airplane and be at gross and within aft C of G limit. Problem is, you can't physically shoehorn a 413 lb. person into the passenger cockpit. 2. Again checking aft C of G, at a "running on fumes" condition of minimum fuel and oil, the aft C of G is exceeded with a pilot any heavier than 175 lbs. unless there is a passenger aboard. This presents some operating limitations that have to be respected as well, such as at the end of a long 3. Checking maximum forward limit, with a full tank of fuel (16 gal.) and full oil, I need a minimum of a 107 lb. pilot to bring the C of G back to the forward limit. This would mean that the aircraft should be placarded "rear seat solo only" and should also have some sort of minimum pilot weight allowed when flying solo. Now, it would hardly make sense to try to solo the plane from the front hole anyway, since there are no instruments and no carb heat control up there. But just the same-! And as far as a minimum pilot weight, it is conceivable that a youngster, or a slightly built man or woman, might be too light to operate this aircraft within its forward C of G limit with full fuel. This would mean possibly running out of elevator in the flare or rotation... and a hard landing or an extended takeoff run. Anybody come up with similar loading cases in their W&B's? Mind you, the airplane still needs an official re-W&B after the rebuild is complete, but I'm looking at what-ifs. I guess if I forget all the mother hen stuff, this airplane can really handle a wide range of loading conditions and can safely carry a pilot and passenger, but there are some conditions to watch for. And I think I may just add a "rear seat solo only" placard to that lonely, bare front panel. Does anyone else have theirs placarded that way (not you Sky Scout guys)? Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 11, 2005
Subject: Re: rear cockpit solo
Oscar, What is the gross weight ? B.H.P. listed it at 1050 lbs. Chuck G. ________________________________________________________________________________
Date: Jan 11, 2005
Oscar. My DAR required a "solo rear seat only" placard. He suggested putting it on the REAR panel. Now, just think about that... If you are soloing the plane from the back then do you need to be warned not to solo from the front? no If some unknowing soul jumps in the FRONT seat to solo it, well, he's not going to see the placard and .. well you know the rest. So after I explained it, my DAR agreed it should be placarded in the front pit. So I think you're correct - it needs to be placarded and should be in the front pit Bert. ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: rear cockpit solo > > Howdy, folks; > > Working through the weight & balance on 41CC and looking at extreme forward > and rearward C of G conditions in the spreadsheet (thanks, Bert and Nancy > Conoly!), I've noticed a couple of things. > > 1. There doesn't appear to be any loading that will bring the plane to max > gross without shifting out of the aft C of G allowable range. This is good > insofar as it will be nearly impossible to overload the airplane, but does > indicate some care is required to keep the aft C of G in range. With 170 > lb. pilot and 210 lb. passenger, minimum fuel (2 gal.), and min. oil, it's > at maximum aft limit but still 183 lbs. under gross. I've shifted loads > around (in the spreadsheet) and this seems to be worst aft C of G case that > will still allow me to approach max. gross. Obviously, I can go up on the > passenger weight, but as an example- at my present weight of 150 lbs., the > spreadsheet says I can fit a 413 lb. passenger in the airplane and be at > gross and within aft C of G limit. Problem is, you can't physically > shoehorn a 413 lb. person into the passenger cockpit. > > 2. Again checking aft C of G, at a "running on fumes" condition of minimum > fuel and oil, the aft C of G is exceeded with a pilot any heavier than 175 > lbs. unless there is a passenger aboard. This presents some operating > limitations that have to be respected as well, such as at the end of a long > X-C flight. > > 3. Checking maximum forward limit, with a full tank of fuel (16 gal.) and > full oil, I need a minimum of a 107 lb. pilot to bring the C of G back to > the forward limit. This would mean that the aircraft should be placarded > "rear seat solo only" and should also have some sort of minimum pilot weight > allowed when flying solo. > > Now, it would hardly make sense to try to solo the plane from the front hole > anyway, since there are no instruments and no carb heat control up there. > But just the same-! And as far as a minimum pilot weight, it is conceivable > that a youngster, or a slightly built man or woman, might be too light to > operate this aircraft within its forward C of G limit with full fuel. This > would mean possibly running out of elevator in the flare or rotation... and > a hard landing or an extended takeoff run. > > Anybody come up with similar loading cases in their W&B's? Mind you, the > airplane still needs an official re-W&B after the rebuild is complete, but > I'm looking at what-ifs. I guess if I forget all the mother hen stuff, this > airplane can really handle a wide range of loading conditions and can safely > carry a pilot and passenger, but there are some conditions to watch for. > And I think I may just add a "rear seat solo only" placard to that lonely, > bare front panel. Does anyone else have theirs placarded that way (not you > Sky Scout guys)? > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Subject: Re: Fuel tank & parts
Date: Jan 11, 2005
Bob, does this mean your yellow piet is no longer flying? What happened, I thought you sold it? Chris Tracy Sacramento, Ca ----- Original Message ----- From: Bob Seibert To: pietenpol-list(at)matronics.com Sent: Tuesday, January 11, 2005 2:37 AM Subject: Pietenpol-List: Fuel tank & parts Well, I need to clean the hangar out and I have a pile of Piet parts that needs to move. I have an aluminum center section gas tank (12.5 gal.), a 1 gallon header tank & shutoff valve, control stick assembly, and ALL the fabricated hardware for a piet. The hardware is all fabricated out of 4130 and has about 45 hours on it. The fuel tank has a built in sight gage and is built like an RV gas tank with rivets & pro-seal joints. The tank was built for a piet with a plans built 1 piece wing and I do not know if it will fit in the center section of a 3 piece wing. It all works just fine. It was taken off of my wind damaged (and ground looped) piet. I figure that $200 is a fair price for the many hours of labor that went into the stuff. (That probably amounts to about 50 cent an hour :-) The only problem is that the buyer has to pick it all up here near Austin, TX. The fuel tank has residual fuel in it making shipping out of the question. If anybody is interested, please contact me off list. Bob Seibert dsseibert(at)earthlink.net EarthLink Revolves Around You. ________________________________________________________________________________
Date: Jan 12, 2005
Chuck "Baby Oil" G. asked- >What is the gross weight ? >B.H.P. listed it at 1050 lbs. Corky showed aircraft gross weight as 1,185 lbs. on the dataplate in the cockpit and all weight & balance calcs were based on that number. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 12, 2005
Because after covering the top and bottom of the horizontal stab, top of the fuselage under the stab, and the bottom of the fin the fin itself which has the top two rudder hinges in it is going to be sitting higher than it was when everything was bare wood. (By the thickness of four layers of fabric and fabric tape). So your bottom rudder hinge holes don't line up any more (unless you wait until after covering to drill them). wrote: > > The fabric overlap on the fuselage should not be any more than on the > vertical fin, so I don't understand why you would need to adjust for > that. You just need to make sure all your hinges have a "fabric > allowance" built into them > > Jack Phillips > > -----Original Message----- > Dang, didn't think about spacing for the bottom rudder hinge. Wish you > were around Jim when I asked this question a couple months ago. My > hinge position is adjustable but the holes I drilled for it in the > fuselage are not. Will probably have to fill and redrill the holes > after covering. > > Rick H > > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 12, 2005
Here we go again. I was in the same place about a year ago that you are Mark. I spent days going through the archieves and went to Broadhead last year and found two interesting things. First you continuously heard messages advicating 'build it to the plans, don't change a thing'. Then when you closely examine a lot of Piets you find that no two are built the same, in building materials or specifications or engines. You will find that a good percentage of builders make the same changes to their Piets like higher turtle decks, taller cabanes, wider/longer fuselage, etc. Plus even though the plans show no brakes or seat belts most people figure out a way to add those. So I suggested that a 'Twenty first century Piet' set of plans be created containing most of these changes you see people making. And if that wasn't bad enough I had the ordasity to suggest that these new plans be done in Auto-Cad or Turbo-Cad showing all dimensions, multiple perspective views, maybe even a parts list, etc. Well all hell broke loose, 'build it to the plans!', 'Bernie didn't have auto-cad, he didn't even have computers!', 'if God intended man to fly airplanes designed on a computer he would have given Bernie the insight to invent the computer before he invented the Piet' (actually, I make up that last snide comment). In closing Mark the only advice I can offer is 'Build It To The Plans' and don't change a thing like all the builders on this newsgroup. RIck H Fuselage, ribs, and tails feathers completed 'to the plans'. > > Thanks for all those that have responded. I am sure you could modify > the plans, but that really was not what I was looking for. Though it > might work, when you modify plans you open up a whole can of worms and > the proven nature of the design becomes something that is totally > untested. I do not have the engineering expertise to be able to do > that, and was hoping someone had. > > I would need more than just more cockpit room. The wing would need to > be raised for me to see and getting in the front would be a physical > impossiblity without some changes. I hoped someone had essentially a > different set of plans that had been reviewed and used for some time in > a number of airplanes. > > Though it looks like fun a Piet may not be the right airplane for me. > > horzpool(at)goldengate.net wrote: > > > > >Mark > >I built a fuselage at Sun n Fun acouple of years ago that might suit you. > >Take the basic long fuse plan and trty substituting the measurements for > >the forward bridge decks to the short fuselage plan. I also reclined my > >rear seat by 1" for comfort. You shold be able to get an additional 8-9" > >in this process. It made all the diffrence to me. 5'11" & 200 lb. > >Dick N. > > > > > > > > > > > >>> > >>> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 12, 2005
Rick is right - there are a lot of "purists" who will advocate building the plane exactly to the plans. However, I defy anyone to build it exactly to the plans in every detail becasue the plans themselves have some flaws (the detail showing the compression struts between the wing spars comes to mind). I have investigated a couple of Pietenpols built by BHP himself, and they are not at all alike. He designed at least three different fuselages and several different wing configurations. I suspect every plane he built was different in some respect from the others. To me, the things that make a plane "A Pietenpol" are the airfoil section of the wing, the basic layout of the structure, i.e., the location of the spars and the longerons, the lift struts and the cabane struts, and the basic planforms of the wings and control surfaces. There a number of changes that can be made (and some, like Jury Struts and the diagonal braces from the cabanes to the engine mount that SHOULD be made) without departing from the basic Pietenpol design. One of the things that makes this such a great design is the fact that it can be easily modified to suit a particular builder and still end up with a safe flying machine with good flying qualities. Just look at the variety of engines that have been used on Piets - many by BHP himself. I know of no other design so easily adaptable to different powerplants. As for making a 21st century plans set, I wouldn't know which configuration to choose to make "the new standard". Mine is the long fuselage, widened 1", with a taller turtledeck, a straight axle, wire wheels, 65 hp Continental, centersection 6" wider than plans to allow for a larger fuel tank (15 gallons in the centersection), piano hinge ailerons, trim system, electrical system, radio, intercom, and transponder with blind encoder, 3 piece windshields, and baggage compartment in the nose. To me it is ideal. To someone built differently than me, the extra length and width of the fuselage would be too much extra weight and cost. To someone who doesn't have to fly in Class B & Class C airspace, the radio and transponder are superfluous. Some would object to the extra weight and cost of the wire wheels. I think they "make" the look of the airplane. In other words, to each his own. Don't be afraid to modify the design as you need to fit your personal requirements. As long as it still uses the Pietenpol airfoil and general configuration, I wouldn't worry about the "purists". Jack Phillips -----Original Message----- Here we go again. I was in the same place about a year ago that you are Mark. I spent days going through the archieves and went to Broadhead last year and found two interesting things. First you continuously heard messages advicating 'build it to the plans, don't change a thing'. Then when you closely examine a lot of Piets you find that no two are built the same, in building materials or specifications or engines. You will find that a good percentage of builders make the same changes to their Piets like higher turtle decks, taller cabanes, wider/longer fuselage, etc. Plus even though the plans show no brakes or seat belts most people figure out a way to add those. So I suggested that a 'Twenty first century Piet' set of plans be created containing most of these changes you see people making. And if that wasn't bad enough I had the ordasity to suggest that these new plans be done in Auto-Cad or Turbo-Cad showing all dimensions, multiple perspective views, maybe even a parts list, etc. Well all hell broke loose, 'build it to the plans!', 'Bernie didn't have auto-cad, he didn't even have computers!', 'if God intended man to fly airplanes designed on a computer he would have given Bernie the insight to invent the computer before he invented the Piet' (actually, I make up that last snide comment). In closing Mark the only advice I can offer is 'Build It To The Plans' and don't change a thing like all the builders on this newsgroup. RIck H Fuselage, ribs, and tails feathers completed 'to the plans'. ________________________________________________________________________________
Date: Jan 12, 2005
Hello Oscar, > Working through the weight & balance on 41CC and looking at extreme forward > and rearward C of G conditions in the spreadsheet (thanks, Bert and Nancy > 2. Again checking aft C of G, at a "running on fumes" condition of minimum > fuel and oil, the aft C of G is exceeded with a pilot any heavier than 175 Since I'm the one who test flew N41CC and the succeeding 25 hours, I might comment on this. First, the 'tail heavy' aspect is the 'nature of the beast' and it's notorious aft-CG problem is well documented, so no surprise there. According to my notes, Corky and I used 1150 as gross weight figures. I built a special graphic W&B program as well as a separate spread sheet and did extensive looking at the problem and various situations. It all summarizes into what you have discovered. In this particular plane, before any rebuild, any pilot over 92 lbs with full fuel will place the plane within the forward CG limits. Any less fuel with that pilot will move the CG more toward the middle of the envelope. Now in all Piets with a front fuselage tank the problem is at the end of the trip when fuel level diminishes and CG moves backward. So if you wish to stay within the aft envelope, you must establish a rule as to how far down the fuel may be burned for the particular pilot weight. The heavier the pilot, naturally, the more fuel must remain in order to keep the plane within CG. Mike Cuy and I corresponded about this and he has spoken to this fact in this list. With my weight, feather weight as Corky put it , I had no problem. But with any pilot over 161 lbs, allowances must be figured. All of the above is assuming no passenger and I am speaking of N41CC as it is configured. Of course, there is nothing new in the email and all of this is well know and has been discussed. Incidentally, when we went from the heavier metal prop to the wooden prop (early in the test program) things changed dramatically since the empty CG shifted aft. The Piet, like the J3, should always be soloed from the rear. The use of a placard would probably be up to the builder and/or inspector. No new territory in this email, just thought I might comment how I approached the CG issue for flight planning/fuel burn purposes. ...Edwin ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~ Edwin Johnson .. elj(at)shreve.net .. www.shreve.net/~elj ~ ~ ~ ~ "Once you have flown, you will walk the earth with your~ ~ eyes turned skyward, for there you have been, there you~ ~ long to return." -- da Vinci ~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Jan 12, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Enjoy changing your Pietenpol to fit you !!!!!
m> Amen, Rick Holland and Jack Phillips----there is nothing wrong with deviating from the plans. Nothing at all, provided you just think things thru and figure out what else will have to change, if anything of the 'fallout' of those changes. There is nothing sacred about building to the plans. There are no two Piets alike and besides there is no such thing as an originally-built Pietenpol. All 26 of the ones that BHP built were different so there are 26 original Pietenpol designs out there--we only see what he put down on the plans at the time they were drawn up by W. Hoopman is all. I won't repeat the insightful comments by Jack, but re-read them. He's right on too. Mike C. PS-- in other countries like Great Britain they are not allowed to deviate from plans and if you do, you must go thru hell for the PFA to approve it. Be thankful and be creative and customize !!!!! Don't get crazy, but have fun. ________________________________________________________________________________
Date: Jan 12, 2005
Subject: 1150 gross
241(at)matronics.com> Edwin-- thru the cob webs of my memory I can't recall where I came up with the 1150 gross weight either but it was a Pietenpol source, not heresay. I can say that I've taken off at 1100 lbs. on about an 80 F day and it didn't do too terribly bad. Not the greatest but still climbed out fairly well. (Elev was 810 msl) Mike C. ________________________________________________________________________________
Date: Jan 12, 2005
Subject: long x-countries and thin pilots w/ the nose tank
241(at)matronics.com> What you have Oscar is a plane that you will trim by changing your fuel load for a particular flight. Most of you flying I suspect will be 1/2 hour round the airport type flying so you'll fly with 10 gallons instead of 16 so she's in a nice meaty part of the CG envelope. When you go x-country solo you'll have enough baggage in the front seat to help you out on the full tank condition and if you have enough bladder control to fly the three solid hours that it would take for you to get 41CC down to where the fuel level makes you too far forward on the CG then you are quite a guy. I fly two hour legs on long x-countries with my nose tank and then land. That is plenty of time in the saddle plus it leaves you with a nice balanced situation. If you get into the too far forward and too far aft CG ranges then either you couldn't find gas at your last airport or didn't drain off enough for featherweight pilots to fly it. Mike C. ________________________________________________________________________________
<5.1.1.5.2.20050112120337.01b15670(at)popserve.grc.nasa.gov>
Subject: update on N74DV
Date: Jan 12, 2005
well.... here's the story. It's quite depressing really. N74DV is about 90% complete. Just needs a cowling, ailerone cables run and covering. EVERYTHING else is complete. Really this thing could be done in a few months time.... BUT (and this is a very big BUT) There is no point in me finishing this bird right now. Once it's done I have no where to keep it. All the local airports around here have 7+ year waiting lists for hangars. I'm 5 yrs into the list at one airport and have moved from #150 in the list to #40. Still several years away on that. So I've reached a point where I have lost all motivation to get this damn thing finished.... I'm so frustrated. I've canvassed the airports talking with hangar tenants in the past couple months and I really thought I'd find something... even someone to let me share hangar space... but nope. Nothing... zilch... nada. So it looks like N74DV is gonna be sitting for a while.... and it could be a long while. I know this will comeas a shock to most of you but I've even mildly entertained selling the project and getting a spam can as there's plenty of ramp space available. Although that would likely never happen as my father would absolutley kill me if I sold this project.... ha! 30yrs old and still afraid of dad. :) Anyhow... I just had to vent off some frustration..... I'm off to Ireland for a week beginning tomorrow... maybe that'll cheer me up. DJ Vegh ________________________________________________________________________________
Date: Jan 12, 2005
DJ, I know it's painful to have a fabric covered plane (particularly a wooden one) sitting out in the sun, tied down instead of secure in a nice dark hangar, but with today's fabrics and paints it really isn't as bad as you might think. Use the Stits PolyFiber Process, with a good solid coat of silver (polyspray) and their Aerothane polyurethane paint and it should be no problem at all to have it outside for a couple of years while you move up the hangar list. I don't know how latex house paint would hold up under such conditions, but I know a number of Stits covered planes that have sat outside for years with no noticeable effects. Besides, saying it "just needs covering" means you are at least a year away from having to worry about a place to keep it. It took me well over a year to cover and paint mine (granted, I lost a couple of months waiting for weather warm enough to spray paint in my unheated garage). Don't give up yet! Jack Phillips -----Original Message----- well.... here's the story. It's quite depressing really. N74DV is about 90% complete. Just needs a cowling, ailerone cables run and covering. EVERYTHING else is complete. Really this thing could be done in a few months time.... BUT (and this is a very big BUT) There is no point in me finishing this bird right now. Once it's done I have no where to keep it... ________________________________________________________________________________
Subject: filling the tank/was long x-c
Date: Jan 12, 2005
Mike wrote- >you'll fly with 10 gallons instead of 16 so she's in a nice meaty part of >the CG envelope. Dagnab it, my mother always told me never to go outside barefoot when it's cold, and my instructor always told me never to put the airplane away without topping off the tanks. My mother is dead now, God rest her soul, but I still have this thing about topping off with fuel at the end of the day. But I understand (as Edwin, Mike, and the rest of you have most helpfully pointed out)- that we have all of these things as tools that we use to load and operate our machines properly and even as an older dog I can still be taught new tricks. Thanks for the fine discussions. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: filling the tank/was long x-c
Date: Jan 12, 2005
Oscar, The thing about filling the tanks is to keep condensation out of the fuel. But if you sump your tanks before fight like your supposed to it shouldn't be a problem....as long as the sumps are at the lowest point. The small amounts that you may not get are caught in the gaskolator (not sure about the proper spelling)before it goes to the carb. A lot of airplanes manufactured today may have four to six seats but if you top them off may only be able to legally take off with one person on board. Me personally, I would rather take off with partial fuel, light load and go play. Jim Dallas ----- Original Message ----- From: Oscar Zuniga To: pietenpol-list(at)matronics.com Sent: Wednesday, January 12, 2005 12:28 PM Subject: Pietenpol-List: filling the tank/was long x-c Mike wrote- >you'll fly with 10 gallons instead of 16 so she's in a nice meaty part of >the CG envelope. Dagnab it, my mother always told me never to go outside barefoot when it's cold, and my instructor always told me never to put the airplane away without topping off the tanks. My mother is dead now, God rest her soul, but I still have this thing about topping off with fuel at the end of the day. But I understand (as Edwin, Mike, and the rest of you have most helpfully pointed out)- that we have all of these things as tools that we use to load and operate our machines properly and even as an older dog I can still be taught new tricks. Thanks for the fine discussions. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 12, 2005
Pieters, This recent discussion of fuel tanks and CG has activated my old wheels to turn. No doubt that a Piet type aircraft is difficult to trim, CG, with a forward fuse tank from full to 3 gallons, never let it get below that. NX311CC, Repiet, is sitting in the shop with a completed fuse and center section. Has an 18 gal alum fuel tank forward to firewall. So, if I takeoff from Shreveport to Brodhead will full tank and 190 lb Corky in the rear pit it should fly great with a slight back pressure needed on the stick for the first hour. By the time I land in Arkadelphia I will probably be healing the stick with forward pressure. These assumptions are based upon experience of Nathan Moss flying NX41CC. So, the WB can be controlled with the amount of fuel in the tank relative to the weight of the rear pit pilot. So, if I were to build a center section alum tank of 14.8 gal capacity it would be very simple and convenient and pleasant flying on any given situation knowing how much fuel to have in forward tank for balance AND extended cruise. No elaborate plumbing required just a Y at the gascolator and another line cutoff within pilot reach for the wing tank. When I add fuel in Arkadelphia and all points nawth to Brodhead just merely top off the wing tank. Now, in addition with 32+ gals there is no limit except the lower back to where you might go. Might even make Beliese and stay with the fisherman. Gad!!!!!!! imagine an 8hr leg in a Piet Corky, dreaming in La with his bride ________________________________________________________________________________
Subject: Horizontal and Vertical stab fittings
Date: Jan 12, 2005
Of course. I was thinking in the fore and aft direction - not vertically. I guess it wasn't much of a problem - I had no problem assembling mine, with no allowances made for fabric thickness there. Jack Phillips -----Original Message----- Because after covering the top and bottom of the horizontal stab, top of the fuselage under the stab, and the bottom of the fin the fin itself which has the top two rudder hinges in it is going to be sitting higher than it was when everything was bare wood. (By the thickness of four layers of fabric and fabric tape). So your bottom rudder hinge holes don't line up any more (unless you wait until after covering to drill them). ________________________________________________________________________________
<5.1.1.5.2.20050112120337.01b15670(at)popserve.grc.nasa.gov> <000501c4f8cd$88e6d5b0$0564a8c0@rdci.az.home.com>
Subject: Re: update on N74DV
Date: Jan 12, 2005
----- Original Message ----- From: "DJ Vegh" <djv(at)imagedv.com> Subject: Pietenpol-List: update on N74DV > > well.... here's the story. It's quite depressing really. N74DV is > about 90% complete. Just needs a cowling, ailerone cables run and covering. > EVERYTHING else is complete. > DJ you've hit a nerve. This is the first time I've verbalized this outside of my immediate family, but I'm afraid I waited too late to start my Piet. It's very close to being finished and now I'm in a race with my health. I'm planning to complete the plane then see if I can still declare myself "airworthy". I have a second Piet which is in storage which I have decided to sell. You're right, it is depressing.......Good luck........Carl Vought ________________________________________________________________________________
Date: Jan 12, 2005
Hey, not only would your old man raise hell, but a whole mess of us TACOs and a bunch of them Damned Yankess would be pissed as well. I'd look into renting a hanger 150 miles away in some obscure town. I had a hanger in a small town about 3 hours away that cost me $35 a month! This was in Childress, Texas and the rates have sky-rocketed to $45 a month now (13 years later.) NO WAY IN HELL ARE YOU SELLING THAT AIRPLANE! You won't be living in Mesa all your life and some day you'll be in a part of the country that isn't growing so darned fast... then you would kick yourself for getting rid of your airplane. Seriously, if you had to park the airplane 300 miles away, you could make this work. If you were so darned far away, I'd let you park it here at my place. Something will give, just KEEP THE AIRPLANE. Isn't there an airport in Florence, AZ? If not, try Payson... but don't give up. Maybe I'll build a storage building at Knot-2-Shabby and you can park it here for free. Sterling ________________________________________________________________________________
Date: Jan 12, 2005
Oscar This is a piddly point, but the min fuel spec if you are using an A-65 is about 5 gal. Dick N.> > insofar as it will be nearly impossible to overload the airplane, but does > indicate some care is required to keep the aft C of G in range. With 170 > lb. pilot and 210 lb. passenger, minimum fuel (2 gal.), and min. oil, it's > at maximum aft limit but still 183 lbs. under gross. > > ________________________________________________________________________________
Date: Jan 12, 2005
<200501120756.j0C7uev32241(at)matronics.com> <5.1.1.5.2.20050112120337.01b15670(at)popserve.grc.nasa.gov> <000501c4f8cd$88e6d5b0$0564a8c0@rdci.az.home.com> DJ, Do what I did when I bought the Taylorcraft. Get out the sectional and draw a circle at the longest distance that you feel like driving to go flying. Then call the owner of every farm strip that is in the circle. I made it about 4 before the guy said yes, I could use his old hangar. Also ask the old CFIs about strips that aren't on the sectional. There are a huge number of them here in upstate NY. Dave N36078 '41 BC-12-65 At 12:38 PM 1/12/2005, DJ Vegh wrote: > >well.... here's the story. It's quite depressing really. N74DV is >about 90% complete. Just needs a cowling, ailerone cables run and covering. >EVERYTHING else is complete. > >Really this thing could be done in a few months time.... BUT (and this is a >very big BUT) > >There is no point in me finishing this bird right now. Once it's done I >have no where to keep it. All the local airports around here have 7+ year >waiting lists for hangars. I'm 5 yrs into the list at one airport and have >moved from #150 in the list to #40. Still several years away on that. > >So I've reached a point where I have lost all motivation to get this damn >thing finished.... I'm so frustrated. I've canvassed the airports talking >with hangar tenants in the past couple months and I really thought I'd find >something... even someone to let me share hangar space... but nope. >Nothing... zilch... nada. > >So it looks like N74DV is gonna be sitting for a while.... and it could be a >long while. I know this will comeas a shock to most of you but I've even >mildly entertained selling the project and getting a spam can as there's >plenty of ramp space available. > >Although that would likely never happen as my father would absolutley kill >me if I sold this project.... ha! 30yrs old and still afraid of dad. :) > >Anyhow... I just had to vent off some frustration..... > >I'm off to Ireland for a week beginning tomo rrow...maybethat'llcheerme >up. > >DJ Vegh ________________________________________________________________________________
Date: Jan 12, 2005
Arizona Pieter, In my short lifetime I've hitch hiked, railroaded, motored and flown over your fair state. In most places there is nothing, I mean nothing. Now is that flat desert so expensive that those 150 waiters couldn't find a little spot somewhere like 10 acres for sale or lease, post flags for a runway, build a few pole sheds and you could build your own waiting list? Maybe America has passed me up but I'll be damned if I would give up because of no hangar space in Mesa and other close places. Anyone with enough guts to drive a Piet through their neighborhood should be able to find it a home in the desert. A Piet doesn't need hay or water. Talk to some dusters for advice. Corky, flying near the bayou in La ________________________________________________________________________________
Date: Jan 12, 2005
DJ, a hanger is really just a luxury. When I was barnstorming (first in the WACO-see attchment-and then in the Bird) I would be away from home base for as much a three months at a time, always moving from one town to another, and rarely ever saw a hanger. Instead, I covered the cockpits and engine with old Army ponchos, all tied down nice and tight and made sure I had plenty of tie-down ropes in place. I carried a set of home-made tiedown anchors for when there was only grass for the plane to sit upon. We weathered out many storms and generally bad weather together, me with a small tent pitched near the plane. The plane got wiped down a lot and flown even more. Rocker box grease, fresh thrown from the engine, makes a great protective layer over the paint to help shed rain-drops off the drum taught fabric. I never really saw any worse for wear and weather by doing this. Folks get used to having a nice warm and dry hanger to keep their pride and joys in, but more planes have sat outside than they have inside a hanger. Don't get me wrong, a hanger is very nice if you have one, but don't get rid of your airplane (and I'm not sure I would drive three hours just to fly) just go to the nearest Army/Navy Surplus store and buy you some "portable hangers." Good luck and hang(er) in there, something will come up sooner or later...it always does. Doc > __________________________________ ________________________________________________________________________________
Date: Jan 12, 2005
Subject: elevator & rudder hinge brackets
I have just started rebuilding a Grega Piet that needs new hinge brackets for the elevators and rudder. Are these available to purchase somewhere or do they have to be built from scratch. Thanks Jerry Engel rvjengel(at)aol.com ________________________________________________________________________________
Date: Jan 12, 2005
Subject: Re: Sat in my first Peit today
My point was that I knew it could be modified, but I do not pretend to know even close to enough to know what can and can not be changed from plans and still be safe. I would need some fairly significant changes. Raising the height of the wing from the fuselage would be one Id want to have at least some forward vis and that opens the door to many potential problems. So does adding length an width potentially to a fuselage. If a revised set of plans for a big guy were available Id buy them. I didn't mean to start the purist debate. If a set of plans were available that had the alterations made and been reviewed by someone more versed in these matters than myself, Id go that route. Im a pilot not a designer. I just might mistake something that is a big deal for something that isn't and I want to be here to complain when I do not get my social security checks. Any airplane, even an aircraft as simple as a Piet can and will bite if not treated with respect. For that matter any airplane that has survived and thrived as long as a Piet deserves that anyway. Mark Mark > > ________________________________________________________________________________
Date: Jan 12, 2005
Jack Do you happen to remember your turtledeck dimensions? You mentioned that you raised it a couple of inches - was that across the board for all the turtledecks or did you use some other method of smoothing it out? I ask because I'm about your height - and because I'm crazy about the looks of your airplane. Ken in Austin, who's putting off mountains of work on the hold house to squeeze in a little Piet time. ________________________________________________________________________________
Date: Jan 12, 2005
To follwo up on Dave's suggestion to look for every little unknown airport possible, here's a great site with a bunch of places you may have never heard of, updated frequently: Abandoned & Little-Known Airfields Website http://members.tripod.com/airfields_freeman/ Keep the faith... the waiting list here in Melbourne FL (MLB) is about 150+ people long from what I've heard and the idiots running the local airport are working hard to REMOVE half the (now full) T-Hangars and our crosswind runway. That has me considering whether the Piet or Zodiac is the more practical plane... at least a metal plane won't be quite as bad outside here. Of course, with our daily thunderstorms, frequent tornadoes and microbursts, small hail, intense lightning, and the occasional hurricanes don't kill the wooden planes left sitting outside, then the wood rot probably will. Just my opinion, I know some have done this with few problems but it seems like a big gamble for something you've poured years of your life into. There's a Fly Baby bipe down at Valkaria that has been sitting outside, it looks ROUGH. Dunno what it looked like before, but it sure looks like a plane that's been stored outside for a long time. Arizona is probably at least better for outside storage. I know of a wooden-winged biplane that came apart in mid air recently, nearly killing the pilot, due to being stored outdoors for only two years in the Miami area... the whole spar was rotted through from moisture that had condensed or collected inside the wing... it wasn't found when the new owner bought the plane (which had been built by an Oshkosh-winning craftsman, the original construction was excellent and the design was not an issue... it was all from improper storage.) and after 11 months and 250 hours of acro, it finally let go. High price to pay for not having a hangar available. The other side of the coin is that apparently, the companies that build and operate T-Hangars have to make their money back in about 7 years for it to be economically viable for them to do (something to do with the duration of their construction loans or taxes I suppose.) Since the construction boom has doubled the price of steel lately, they would have to charge something like $900 a month to make any money, so therefore, they don't have any incentive to build since nobody would sign up. At least that's what our EAA chapter was told by a guy who had spent considerable time researching our situation here. Mike Whaley merlin@ov-10bronco.net Webmaster, OV-10 Bronco Association http://www.ov-10bronco.net/ ----- Original Message ----- From: DJ Vegh <djv(at)imagedv.com> Subject: [piet] Pietenpol-List: update on N74DV > > well.... here's the story. It's quite depressing really. N74DV is > about 90% complete. Just needs a cowling, ailerone cables run and covering. > EVERYTHING else is complete. > > Really this thing could be done in a few months time.... BUT (and this is a > very big BUT) > > There is no point in me finishing this bird right now. Once it's done I > have no where to keep it. All the local airports around here have 7+ year > waiting lists for hangars. I'm 5 yrs into the list at one airport and have > moved from #150 in the list to #40. Still several years away on that. > > So I've reached a point where I have lost all motivation to get this damn > thing finished.... I'm so frustrated. I've canvassed the airports talking > with hangar tenants in the past couple months and I really thought I'd find > something... even someone to let me share hangar space... but nope. > Nothing... zilch... nada. > > So it looks like N74DV is gonna be sitting for a while.... and it could be a > long while. I know this will comeas a shock to most of you but I've even > mildly entertained selling the project and getting a spam can as there's > plenty of ramp space available. > > Although that would likely never happen as my father would absolutley kill > me if I sold this project.... ha! 30yrs old and still afraid of dad. :) > > Anyhow... I just had to vent off some frustration..... > > I'm off to Ireland for a week beginning tomorrow... maybe that'll cheer me > up. > > DJ Vegh > > ________________________________________________________________________________
From: "Todd & Sarah Baslee" <twbaslee(at)sbcglobal.net>
Date: Jan 12, 2005
Clear DayHi guys, I sat in a Pietenpol for the first time in Brodhead and found it at first quite interesting. I am 6' 4.5" and weighed 240 lbs. Getting into the Piet for the first time was a challenge. However, I made it. Bill Rewey was kind enough to give me my first ride in a Piet and later explained that he made some modifications to the original (longer & wider). He has documented all of his work and, I believe, he has some of his documentation and recommendations for sale - not at a very high price. My friend, Greg Bacon, recently purchased Mountain Piet. I found getting into it quite easy. I also fit quite well. The only problem that I have encountered with the Piet and my largeness, is the windscreen. While flying, my face is above the windscreen which can cause communication problems and the such (a few bugs in the teeth). DJ, When I read your posting I was very surprised. Seeing your website and reading your posts on this site has really encouraged me. Just because there is no space available now doesn't mean that something, somewhere is not going to open up soon. Just keep up the work and encouraging us newbie's with your posts and your website updates. Todd Baslee ________________________________________________________________________________
Subject: minimum fuel
Date: Jan 13, 2005
Dick wrote- >This is a piddly point, but the min fuel spec if you are using an A-65 is >about 5 gal. I used the weight & balance numbers that Corky used in his paperwork when he got the plane inspected, and he showed 2 gal. The engine really does burn about 4 gal./hr., so a 30 min. reserve is 2 gal. and that creates a worse case than 5 unless you're using a fuel tank in the wing center section (which this plane doesn't have). We're splitting hairs here, since we know that on occasion some pilots will even burn the last drop of fuel in the tank and still not make it safely back to an airport (accident statistics show that). The condition we're examining for would be one of those "boy, I sure should have stopped at that last airport for fuel" deals, the little wire isn't sticking out of the fuel cap very much at all, it's the end of the day, you're tired, and in unfamiliar territory. To then have to land the airplane with an aft CG condition is to create a scenario for a problem. Thanks for all the help, guys! PS- it looks like the welding work should be all done by next week, when we'll move to the wood and fabric repairs. It depends on how quickly we can get streamline tubing for the wing cabanes... Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Sat in my first Peit today
Date: Jan 13, 2005
Ken, I think I made the turtledeck 1-1/2" taller at the rear of the rear cockpit, and tapered the height down to plans height at the tail. I made my formers circular arcs (layed them out on AutoCAD) and spaced the stringers an even distance around the arcs, with the stringers perpendicular to the arc at each former. This results in each stringer being curved except the center stringer, but the curves are very gentle (and look nice, to my eye). Of course, after the stringers are located, the formers get cut down a bit so they won't touch the fabric. I've attached a photo that shows the stringers and their formers, as well as the small spruce strips placed in between the stringers in the midsection between each former to prevent the fabric shrinking from warping the stringers (a little trick advised by Mike Cuy). I apologize for the long download, for those with dial-up modems - I don't have a low resolution copy of the picture. I don't remember what radius I used for my formers, but as I recall, the radii decrease as you move towrd the tail, in such a way that they describe a cone, whose axis is parallel to the upper longerons (does that make sense? Perhaps I can draw a sketch and send it to you). Jack Phillips Halfway through building the new stabilizer for NX899JP -----Original Message----- Jack Do you happen to remember your turtledeck dimensions? You mentioned that you raised it a couple of inches - was that across the board for all the turtledecks or did you use some other method of smoothing it out? I ask because I'm about your height - and because I'm crazy about the looks of your airplane. Ken in Austin, who's putting off mountains of work on the hold house to squeeze in a little Piet time. ________________________________________________________________________________
Date: Jan 13, 2005
Jack, What a beautiful airplane. Do you have a web site? Jack Textor Des Moines ________________________________________________________________________________
Date: Jan 13, 2005
DJ, This plays to one of my worst fears, projected maybe 4 years in the future, BUT when I got on my EAA chapter's hangar waiting list, I had some interesting discussions. One member tied down his Aeronca Champ for something like 8 years before selling it, and it was airworthy and regularly flown right up until then. Granted, the Champ is tube and fabric, but isn't its spar wood? He claimed it wasn't a problem AND we're talking New England, which gets a tad more precip and cold than Arizona. Second, it may be undignified, but you could tie down with a Cover-It hangar depending on the airport manager or their policies (http://www.coverit.com/). I hope you find a solution because I could easily be in a similar boat when I complete my labor of love. I can either have faith that this can be solved or make lawn furniture, I suppose, and lawn furniture is a lot more boring. Mark Hodgson ________________________________________________________________________________
Date: Jan 13, 2005
Thanks, Jack. I do have a website, at: http://home.bellsouth.net/p/s/community.dll?ep16 <http://home.bellsouth.net/p/s/community.dll?ep16&groupid130718&ck> &groupid130718&ck , but I haven't updated it in quite a while. I need to post the pictures of my first flight, and probably the pictures of my recent crash (my fault, not the airplane's). I'm currently hard at work rebuilding the Piet and hope to have it at Brodhead this summer. Jack Phillips -----Original Message----- Jack, What a beautiful airplane. Do you have a web site? Jack Textor Des Moines ________________________________________________________________________________
Date: Jan 13, 2005
Hi Joe, Good to see you on the list - haven't heard from you in a while. Yes, I saw spacers liek that on a Pietenpol under construction at Brodhead in 2000 and they looked like a good idea so I copied them. Helps to keep the ribs in shape when ribstitching. Jack -----Original Message----- Jack, Thanks for the picture. I noticed small spacers in the tail ribs. Were these also added to prevent the fabric from warping/distorting the tail ribs? Joe ________________________________________________________________________________
Date: Jan 13, 2005
Good points Mark. Few current and past Piet builders have professional aircraft design experience. I sure don't. And along the same lines I never welded a thing before starting my Piet but I took a TIG class and bought a TIG machine and am welding my controls now. When I first started this thing I assumed no one flew any aircraft that wasn't welded by a professional, licensed, bonded, and insured genuine aircraft welder (in some countries that is a requirement). I redesign based on what has been proven to work in flying Piets built by the great people on this newsgroup and every other Piet builder I can find (Broadhead is an oasis in that regard). This is an aspect of homebuilding that kit-plane builders may never understand, the detailed learning aspects of Piet building, learning the whys and why nots and alternatives. With a complete kit you certainly learn a lot but may never have to weld, cut, or bend metal or figure out what AN bolt to use, lay up fiberglass, etc. , thats all provided for you (insert bolt 12A in hole T3 and screw on nut n7). For Piet builders its like that saying 'getting there is half the fun'. For me building and learning is most of the fun, some builders have even said that finally flying their Piet was anti-climatic after the building process. Rick H. > > My point was that I knew it could be modified, but I do not pretend to > know even close to enough to know what can and can not be changed from > plans and still be safe. > > I would need some fairly significant changes. Raising the height of the > wing from the fuselage would be one Id want to have at least some > forward vis and that opens the door to many potential problems. So does > adding length an width potentially to a fuselage. If a revised set of > plans for a big guy were available Id buy them. > > I didn't mean to start the purist debate. If a set of plans were > available that had the alterations made and been reviewed by someone > more versed in these matters than myself, Id go that route. Im a pilot > not a designer. I just might mistake something that is a big deal for > something that isn't and I want to be here to complain when I do not get > my social security checks. Any airplane, even an aircraft as simple as > a Piet can and will bite if not treated with respect. For that matter > any airplane that has survived and thrived as long as a Piet deserves > that anyway. > > Mark > > Mark > > > > > > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Old Airports and lack of hangers
http://members.tripod.com/airfields_freeman/ I visited the above website as recommended by Mike Whaley in regard to DJ and other folks having a lack of hanger space and affordable shelter at their respective airfields. It's a really neat website, especially for anyone having an interest in old airfields. Worth a looksie. Buying a piece of land and establishing your own "legal" landing strip is getting more difficult these days, especially along border states, because of 9-11 and people running drugs from Mexico. (My "airport" is not too far from Crawford, Texas and I bet it's impossible to establish a landing site near the President's ranch. And even if you did, you'd have to keep your airplane grounded a lot of the time.) I'm happy that I built my airport in 1995 when there wasn't a lot of hoops and hurdles to go through, but for many people, building you own grass strip and hanger and such isn't an option. I think AOPA and EAA might be a resource for aviators in need of a shelter for their airplanes. Here in Texas, we have a few airport managers (Abilene ABI is an example) where the local airport manager doesn't give a flip about the "little guy" who owns an airplane having something less than two engines and especially something as humble as a Pietenpol. Too many airport managers have tunnel vision on big iron and they want to run-off tube and fabric flyers and old wooden airplanes from their fields. In the past, ABI had a supportive airport manager, but the trend is for new managers only to support corporate and commercial aviation. In Texas, if an airport is getting money from the state, our Texas Department of Transportation (TxDOT Aviation Division) has been very helpful in letting bozo airport managers and FBOs know they ARE NOT supposed to be renting hangers to people who want to shelter their motorhomes, boats or other non-aviation related items, if an aviator is in need of a space. I also think that AOPA is aggressive in this regard but I haven't seen EAA taking a lead on this, although they might be, I'm just not aware of EAA efforts to help out in this problem. Sterling Brooks EAA 695308 AOPA 01014359 ________________________________________________________________________________
Date: Jan 13, 2005
DNA: do not archive Its-Bogus: do not forward to list --- MIME Errors --- A message with no text/plain section was received. The entire body of the message was removed. Please resend the email using plaintext formatting. NOTE! This error can also occur when the poster of the message has a specific type of computer virus. This virus WAS NOT forwarded on to the List. The poster should be informed of the potential problem with their system as soon as possible. --- MIME Errors --- ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Turnbuckles and A/C Cable
Hello Gang, Here is a website that carries A/C cable and turnbuckles. http://www.blairwirerope.com/ Has anyone on the list had any experience with them? I don't know of the pricing as yet as I just emailed them for a catalog. Any response is appreciated. Thaks, Doc __________________________________ http://my.yahoo.com ________________________________________________________________________________
Date: Jan 13, 2005
Subject: Corvair Piet on ebay
Guys-- I just noticed that Carl Loar has his Corvair powered Air Camper on ebay. Mike C. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4518186263&category=63679&sspagename=WDVW ________________________________________________________________________________
Date: Jan 13, 2005
Those metal "boxes" are the comm radio and intercom (on the right) and transponder and blind encoder (on the left). That was the only place I could think of to mount them, and it actually works very well - they are easily seen and accessed from the rear cockpit, but they don't even show up to most onlookers unless they are pointed out, so they don't detract from the antique look of the airplane. Jack -----Original Message----- From: greg menoche [mailto:gnwac(at)earthlink.net] Subject: RE: Pietenpol-List: Sat in my first Peit today Jack, what are the metal boxes under the wing tank? Your plane looks great too! Greg Menoche Delaware _- see Matronics Forums. _- http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 13, 2005
I'm sure Bernard is looking down at us and chortling away. What did he design this thing for anyway? Get it done. Get it in the air. go flying! And yet here am I turning it into some piece of Louie the Fourteenth furniture. You should see these fantastic burl veneers I lucked into for my cockpit panels. Jaguar eat your heart out! But you know what? I have known right from the first stick that I would never be able to afford a hanger. Everywhere I look there's planes out in the sun and rain year round for their entire life. And think of those youngsters that might hang out at the local strip. They're gonna develop some love for what? dead closed up industrial buildings or the real live, in your face, honest to god flying machines that can be touched and smelt. We need them! Those future aviators. For what it's worth, there's wood and fabric airplanes around here that have been out in the weather for 30 years that fly regularly. Average rainfall? 72 inches. Average temps? -5 to 90F. Clif, on the Wetcoast of North America. > > DJ, > > This plays to one of my worst fears, projected maybe 4 years in the > future, BUT when I got on my EAA chapter's hangar waiting list, I had > some interesting discussions. One member tied down his Aeronca Champ > for something like 8 years before selling it, and it was airworthy and > regularly flown right up until then. Granted, the Champ is tube and > fabric, but isn't its spar wood? He claimed it wasn't a problem AND > we're talking New England, which gets a tad more precip and cold than > Arizona. Second, it may be undignified, but you could tie down with a > Cover-It hangar depending on the airport manager or their policies > (http://www.coverit.com/). I hope you find a solution because I could > easily be in a similar boat when I complete my labor of love. I can > either have faith that this can be solved or make lawn furniture, I > suppose, and lawn furniture is a lot more boring. > > Mark Hodgson > ________________________________________________________________________________
Date: Jan 14, 2005
Here is a picture of the inside tailcone of a "new" Pietenpol that had never flown, and sat in a carport with "protection" from the rain on 3 sides and covered by a tarp. The wood rot in this "new" and never flown Pietenpol is sickening. I doubt I would like to park a handmade wooden airplane outside, even if I lived in Arizona. I've seen DJs airplane at his house and it is a masterpiece and it deserves being sheltered in a hanger, if not a 40 X 30 trophy case when not being flown. They might not get a lot of rain in Arizona, but they get violent chinook winds that states east of the Pecos River don't get. ________________________________________________________________________________
Date: Jan 14, 2005
I think what people mean to say is that with proper varnishing/epoxy coatings and drain holes, wood will last outside just fine. Your example did not display signs of having either done to it. FWIW I parked my Fisher FP303 outside on a grass strip in Massachusetts for three years without a problem. Jim -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of N321TX(at)wmconnect.com Sent: Friday, January 14, 2005 7:15 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: update on N74DV Here is a picture of the inside tailcone of a "new" Pietenpol that had never flown, and sat in a carport with "protection" from the rain on 3 sides and covered by a tarp. The wood rot in this "new" and never flown Pietenpol is sickening. I doubt I would like to park a handmade wooden airplane outside, even if I lived in Arizona. I've seen DJs airplane at his house and it is a masterpiece and it deserves being sheltered in a hanger, if not a 40 X 30 trophy case when not being flown. They might not get a lot of rain in Arizona, but they get violent chinook winds that states east of the Pecos River don't get. ________________________________________________________________________________
Date: Jan 14, 2005
Subject: Re: Old Airports and lack of hangers
May be part of the reason that powered parachutes are so popular. Don't need airports or hangers. wrote: > http://members.tripod.com/airfields_freeman/ > > I visited the above website as recommended by Mike Whaley in regard to DJ > and other folks having a lack of hanger space and affordable shelter at > their respective airfields. It's a really neat website, especially for > anyone having an interest in old airfields. Worth a looksie. > > Buying a piece of land and establishing your own "legal" landing strip is > getting more difficult these days, especially along border states, because > of 9-11 and people running drugs from Mexico. (My "airport" is not too far > from Crawford, Texas and I bet it's impossible to establish a landing site > near the President's ranch. And even if you did, you'd have to keep your > airplane grounded a lot of the time.) I'm happy that I built my airport in > 1995 when there wasn't a lot of hoops and hurdles to go through, but for > many people, building you own grass strip and hanger and such isn't an > option. > > I think AOPA and EAA might be a resource for aviators in need of a shelter > for their airplanes. Here in Texas, we have a few airport managers (Abilene > ABI is an example) where the local airport manager doesn't give a flip about > the "little guy" who owns an airplane having something less than two engines > and especially something as humble as a Pietenpol. Too many airport managers > have tunnel vision on big iron and they want to run-off tube and fabric > flyers and old wooden airplanes from their fields. In the past, ABI had a > supportive airport manager, but the trend is for new managers only to > support corporate and commercial aviation. > > In Texas, if an airport is getting money from the state, our Texas > Department of Transportation (TxDOT Aviation Division) has been very helpful > in letting bozo airport managers and FBOs know they ARE NOT supposed to be > renting hangers to people who want to shelter their motorhomes, boats or > other non-aviation related items, if an aviator is in need of a space. I > also think that AOPA is aggressive in this regard but I haven't seen EAA > taking a lead on this, although they might be, I'm just not aware of EAA > efforts to help out in this problem. > > Sterling Brooks > EAA 695308 > AOPA 01014359 > > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 14, 2005
<00c601c4fa0d$5f7e2d40$4e705118@dawsonaviation> DJ, If you can't find a reasonably close hangar, park it outside, fly it, enjoy life. Seize the day. I was just about to give up my dream of aircraft ownership because I just couldn't justify the cost. My good friend, Greg Cardinal, pointed out the fact that you can never "justify the cost" of owning an aircraft that you don't really need. You become an airplane owner because it's your dream. Greg's words changed my mind and my life. I've had a Cherokee 140, a Corben Jr. Ace, and I'm now the proud owner of the wounded Mountain Piet. Consequently, after moving home to Missouri, I couldn't find hangar space close by for my 140. I kept it hangared 1.5 hours away in Macon, MO for about a year. I decided to find land suitable for a grass strip. I now live on 75 acres with an 1850 ft grass strip and a pole barn for a hangar. I can't quantify how much aviation has enriched my life and the people I share it with. Enrich your life! Fly it. Fly it. Fly it. Even if it suffers minor wear and tear from being in the elements, your life will be way better than if you never fly YOUR homebuilt aircraft! Greg Bacon Missouri ----- Original Message ----- From: "Clif Dawson" <CDAWSON5854(at)shaw.ca> Subject: Re: Pietenpol-List: update on N74DV > > I'm sure Bernard is looking down at us and chortling away. > What did he design this thing for anyway? Get it done. Get > it in the air. go flying! And yet here am I turning it into some > piece of Louie the Fourteenth furniture. You should see these > fantastic burl veneers I lucked into for my cockpit panels. > Jaguar eat your heart out! But you know what? I have known > right from the first stick that I would never be able to afford a > hanger. Everywhere I look there's planes out in the sun and > rain year round for their entire life. And think of those youngsters > that might hang out at the local strip. They're gonna develop > some love for what? dead closed up industrial buildings or the > real live, in your face, honest to god flying machines that can be > touched and smelt. We need them! Those future aviators. > For what it's worth, there's wood and fabric airplanes around > here that have been out in the weather for 30 years that fly regularly. > Average rainfall? 72 inches. Average temps? -5 to 90F. > > Clif, on the Wetcoast of North America. > > > > > DJ, > > > > This plays to one of my worst fears, projected maybe 4 years in the > > future, BUT when I got on my EAA chapter's hangar waiting list, I had > > some interesting discussions. One member tied down his Aeronca Champ > > for something like 8 years before selling it, and it was airworthy and > > regularly flown right up until then. Granted, the Champ is tube and > > fabric, but isn't its spar wood? He claimed it wasn't a problem AND > > we're talking New England, which gets a tad more precip and cold than > > Arizona. Second, it may be undignified, but you could tie down with a > > Cover-It hangar depending on the airport manager or their policies > > (http://www.coverit.com/). I hope you find a solution because I could > > easily be in a similar boat when I complete my labor of love. I can > > either have faith that this can be solved or make lawn furniture, I > > suppose, and lawn furniture is a lot more boring. > > > > Mark Hodgson > > > > ________________________________________________________________________________
Date: Jan 14, 2005
I like what you said there Greg - quite inspirational actually. With regard to DJ's plane being outside, what about some sort of wing covers. I saw a picture somewhere (I think on the Sonex Yahoo site) of a plane with some kind of wing covers on it. I guess it would protect from the UV degradation effects from the sun and maybe even provide some level of protection from hail etc. You could probably have something custom made at a boat cover shop for a few hundred bucks (notice that if you say "bucks" it doesn't sounds quite so bad). At any rate DJ, I think we've all been looking forward to your beautiful airplane taking flight and for you to sell it would probably require some of us to seek counciling from the despair. Don't do it man... don't do it. Eric W. >From: Greg Bacon <gbacon67(at)direcway.com> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: update on N74DV >Date: Fri, 14 Jan 2005 09:45:07 -0600 > > >DJ, > >If you can't find a reasonably close hangar, park it outside, fly it, enjoy >life. Seize the day. > >I was just about to give up my dream of aircraft ownership because I just >couldn't justify the cost. My good friend, Greg Cardinal, pointed out the >fact that you can never "justify the cost" of owning an aircraft that you >don't really need. You become an airplane owner because it's your dream. >Greg's words changed my mind and my life. I've had a Cherokee 140, a >Corben >Jr. Ace, and I'm now the proud owner of the wounded Mountain Piet. >Consequently, after moving home to Missouri, I couldn't find hangar space >close by for my 140. I kept it hangared 1.5 hours away in Macon, MO for >about a year. I decided to find land suitable for a grass strip. I now >live on 75 acres with an 1850 ft grass strip and a pole barn for a hangar. >I can't quantify how much aviation has enriched my life and the people I >share it with. > >Enrich your life! Fly it. Fly it. Fly it. Even if it suffers minor wear >and tear from being in the elements, your life will be way better than if >you never fly YOUR homebuilt aircraft! > >Greg Bacon >Missouri > ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Seat belt/shoulder harness attachments
One thing that I forgot to pay special attention to while at Brodhead last summer was how most folks anchor their Piet's seat belt/shoulder harnesses....What's the recommended method and where to attach them? Anyone have drawings? I've got my fuselage all framed up to where I can add controls, landing gear, instruments, etc., etc. Seat belts would be nice, too. ; ) Enjoyed Greg Bacon's post about Wicks -- I also enjoyed the pipe organ factory tour when I was there three weeks ago. Don't forget to take an airplane picture/poster to Buzzie's Diner in Highland (half a block or so from Wick's) if you stop there for breakfast or lunch...good food, reasonable prices... Still below zero this sunny but cold Saturday morning up here in Western Wisconsin (I'm building the Piet fuselage in the basement)...15 below or so again tonight and tomorrow night. Reminds me of my old history professor at Winona State U on mornings like this...he'd come staggering into class with icicles hanging from his beard, and muttering about "the American Siberia." Well, as Garrison Keillor says, "Up here Mother Nature tries to kill us about six months out of the year." Builds character...! I imagine I'll here from somebody up around Fargo ND where it's really cold... Stay warm -- won't be long until July/Brodhead once again! Fred B. ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Burl wood for panel
Can anyone recommend a good source for burl wood for the instrument panel? I saw a great example of this at Oshkosh last summer and it really made the cockpit standout. Also, sometime ago I recall seeing a sample of something I think was called monkeywood. I'd like to know a good vendor for such veneer. Thanks, Sterling ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: Turnbuckles and A/C Cable
looks like aircraft quality cable. But not aircraft quality hardware. ________________________________________________________________________________
Subject: Re: Seat belt/shoulder harness attachments
Date: Jan 15, 2005
On NX18235 we attached the pilots seat belt to the fuselage frame that supports the pilot's seat back. The pilots shoulder harness is attached to the vertical fin's forward fuselage attach point with cables running along the turtledeck stringers (the turtledeck was raised about 4 inches). Passenger seat belt is attached to brackets which are bolted through the ash cross member and floorboard. Passenger shoulder harness is attached to a bracket welded to the aft right cabane strut (a single, diagonal strap is used for the passenger shoulder harness). Greg Cardinal Minneapolis (-18 F this morning) ----- Original Message ----- From: TBYH(at)aol.com To: pietenpol-list(at)matronics.com Sent: Saturday, January 15, 2005 9:20 AM Subject: Pietenpol-List: Seat belt/shoulder harness attachments One thing that I forgot to pay special attention to while at Brodhead last summer was how most folks anchor their Piet's seat belt/shoulder harnesses....What's the recommended method and where to attach them? Anyone have drawings? I've got my fuselage all framed up to where I can add controls, landing gear, instruments, etc., etc. Seat belts would be nice, too. ; ) Stay warm -- won't be long until July/Brodhead once again! Fred B. ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Hanger space in the Phoenix Area
DJ, I have not yet started my project, haven't even ordered the plans yet but am getting closer. Part of what keeps delaying me is the thought of building something more complicated than a door stop. I have spent my life as a computer programmer and as a flight instructor. Never really built anything. I currently have a hanger at the Goodyear Airport (GYR) and work at Glendale Airport (GEU) with a little work rearranging my hanger we could possibly store your pietenpol in my hanger until you bubbled to the top of the Falcon Field (FFZ) hanger list. I can be reached at 602-819-8359 if you want to talk. Mike PS Have the hanger to store a bag of parts that will someday be an Auster J1. __________________________________ http://info.mail.yahoo.com/mail_250 ________________________________________________________________________________
Subject: Re: Burl wood for panel
Date: Jan 15, 2005
Rockler, e-bay, or do a Google search on "Wood Veneer". I've attached a small photo (65KB) of ours. Burled black walnut, bookmatched. Front and rear panels are successive veneers so the burls match. Greg Cardinal ----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Saturday, January 15, 2005 12:00 PM Subject: Pietenpol-List: Burl wood for panel Can anyone recommend a good source for burl wood for the instrument panel? I saw a great example of this at Oshkosh last summer and it really made the cockpit standout. Also, sometime ago I recall seeing a sample of something I think was called monkeywood. I'd like to know a good vendor for such veneer. Thanks, Sterling ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Tig question
TIG welders, any problem welding 4130 to stainless? Figured I would weld a stainless bolt to the top of the rudder bar post instead of a Cadmiumplated AN bolt (Heard Cadmiumis bad stuff to breathe). Would you use stainless or ER80 filler rod? Thanks -- Rick Holland ________________________________________________________________________________
Date: Jan 15, 2005
Try: www.constantines.com ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Burl panel
Clif and Greg and List: Clif, I am not familiar with Ferris Bueller, so you lost me on that one. But I will research it until I know what you mean. Or as my carpenter friends say " I can't smell what you are stepping in." Greg, I could not resist sending a picture of my cockpit panel. Yours is awesome looking. Your picture turned out a lot better than mine. I did notice the machine turning, the caning and the walnut stick grip. You can see my burl thru the "too" many instruments, but just for fun can you spot the garden hose, the British caulking gun parts or the K-Mart freezer bump rail. List: From now on I will try not to be a Piet repieter and will start a new message. Mike Luther Anchorage (Banana belt) Alaska NX1953M ________________________________________________________________________________
Date: Jan 15, 2005
Try Certainly Wood in East Aurora, NY. http://www.certainlywood.com/index.htm My wife has dropped some cash there for marquetry supplies. Neat place to visit. Dave N36078 '41 BC-12-65 At 01:00 PM 1/15/2005, N321TX(at)wmconnect.com wrote: >Can anyone recommend a good source for burl wood for the instrument panel? >I saw a great example of this at Oshkosh last summer and it really made >the cockpit standout. > >Also, sometime ago I recall seeing a sample of something I think was >called monkeywood. > >I'd like to know a good vendor for such veneer. > >Thanks, > >Sterling >-- incoming mail is certified Virus Free. >Checked by AVG Anti-Virus. ________________________________________________________________________________
From: "Richard Navratil" <horzpool(at)goldengate.net>
Date: Jan 15, 2005
On a really cold day all you can do is putter with Piet parts, throw in Mike Cuys video and dream of summer. Dick N. ----- Original Message ----- From: TBYH(at)aol.com To: pietenpol-list(at)matronics.com Sent: Saturday, January 15, 2005 9:20 AM Subject: Pietenpol-List: Seat belt/shoulder harness attachments One thing that I forgot to pay special attention to while at Brodhead last summer was how most folks anchor their Piet's seat belt/shoulder harnesses....What's the recommended method and where to attach them? Anyone have drawings? I've got my fuselage all framed up to where I can add controls, landing gear, instruments, etc., etc. Seat belts would be nice, too. ; ) Enjoyed Greg Bacon's post about Wicks -- I also enjoyed the pipe organ factory tour when I was there three weeks ago. Don't forget to take an airplane picture/poster to Buzzie's Diner in Highland (half a block or so from Wick's) if you stop there for breakfast or lunch...good food, reasonable prices... Still below zero this sunny but cold Saturday morning up here in Western Wisconsin (I'm building the Piet fuselage in the basement)...15 below or so again tonight and tomorrow night. Reminds me of my old history professor at Winona State U on mornings like this...he'd come staggering into class with icicles hanging from his beard, and muttering about "the American Siberia." Well, as Garrison Keillor says, "Up here Mother Nature tries to kill us about six months out of the year." Builds character...! I imagine I'll here from somebody up around Fargo ND where it's really cold... Stay warm -- won't be long until July/Brodhead once again! Fred B. ________________________________________________________________________________
From: "John and Phyllis Smoyer" <jpsmoyer(at)verizon.net>
Subject: Need help finding a master cylinder
Date: Jan 15, 2005
Can anyone advise me on a good source for a brake master cylinder suitable for a Piet? Thanks to everyone for the informative postings and images. I really enjoy this group. Best Regards, John Smoyer ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: Need help finding a master cylinder
Hi John and Phyllis: Mine is a Matco MC-5 vertically mounted master cylinder with built in reservoir from Aircraft Spruce. Price was $73.95 each. I am using this with the rudder bar set-up. My brakes are activated by the balls of each foot pushing down on a protruding rod that is connected to a lever that attaches to the top of the master cylinder. I tried to show you my setup in the 2 attached pictures. The view of the picture is from the front with the firewall removed and the camera pointing into the passenger compartment. I liked the Scott heal brake idea and I tried to find some that I could rebuild or buy inexpensively on E-Bay but had no luck . Otherwise they are $654.00 a pair at Aircraft Spruce. I am sure that there are atleast 10 different ways to go with the Piet brake design, but I like mine cause the passenger and pilot can use the brakes, also I have a set of parking brakes that I use all of the time back and forth into the garage. Mike Luther NX1953M Anchorage John and Phyllis Smoyer wrote: > Can anyone advise me on a good source for a brake master cylinder > suitable for a Piet? Thanks to everyone for the informative postings > and images. I really enjoy this group.Best Regards,John Smoyer ________________________________________________________________________________
Date: Jan 15, 2005
Fred, Take a look at the International Stinson Club Technical Manual. Gary Murdock had made up sketches of the bolt-on brackets needed to put harnesses in the Stinson. Check the club web site if you don't have the manual. It is available from Joe Dexter on CD. A must have for 108- owners. Darrel Jones Sonoma, CA N6982M TBYH(at)aol.com wrote: > One thing that I forgot to pay special attention to while at Brodhead > last summer was how most folks anchor their Piet's seat belt/shoulder > harnesses....What's the recommended method and where to attach them? > Anyone have drawings? I've got my fuselage all framed up to where I > can add controls, landing gear, instruments, etc., etc. Seat belts > would be nice, too. ; ) > > Enjoyed Greg Bacon's post about Wicks -- I also enjoyed the pipe organ > factory tour when I was there three weeks ago. Don't forget to take an > airplane picture/poster to Buzzie's Diner in Highland (half a block or > so from Wick's) if you stop there for breakfast or lunch...good food, > reasonable prices... > > Still below zero this sunny but cold Saturday morning up here in > Western Wisconsin (I'm building the Piet fuselage in the > basement)...15 below or so again tonight and tomorrow night. Reminds > me of my old history professor at Winona State U on mornings like > this...he'd come staggering into class with icicles hanging from his > beard, and muttering about "the American Siberia." Well, as Garrison > Keillor says, "Up here Mother Nature tries to kill us about six months > out of the year." Builds character...! I imagine I'll here from > somebody up around Fargo ND where it's _really_ cold... > > Stay warm -- won't be long until July/Brodhead once again! > Fred B. ________________________________________________________________________________
Date: Jan 15, 2005
Subject: Re: Seat belt/shoulder harness attachments, oops!
It must be too late in the evening. I just posted a reply about harnesses on my Stinson. I also installed harnesses in my Pietenpol-like Pfiefer Sport, but it is tube fuselage and all I had to do was wrap the ends around the cross tubes behind each seat position. A great tutorial on installing shoulder harnesses is in Tony Bingles's book on Sport Plane Construction techniques, I think. Flat brackets with through bolts in shear as high as possible will work best. Try to borrow a copy of Tony's books if possible. If not, they are available through EAA and would be my recommendation for first books for a homebuilder's library. Good luck on the Piet. Darrel Jones Pfiefer Sport, Ser.#2 N154JP TBYH(at)aol.com wrote: > One thing that I forgot to pay special attention to while at Brodhead > last summer was how most folks anchor their Piet's seat belt/shoulder > harnesses....What's the recommended method and where to attach them? > Anyone have drawings? I've got my fuselage all framed up to where I > can add controls, landing gear, instruments, etc., etc. Seat belts > would be nice, too. ; ) > > Enjoyed Greg Bacon's post about Wicks -- I also enjoyed the pipe organ > factory tour when I was there three weeks ago. Don't forget to take an > airplane picture/poster to Buzzie's Diner in Highland (half a block or > so from Wick's) if you stop there for breakfast or lunch...good food, > reasonable prices... > > Still below zero this sunny but cold Saturday morning up here in > Western Wisconsin (I'm building the Piet fuselage in the > basement)...15 below or so again tonight and tomorrow night. Reminds > me of my old history professor at Winona State U on mornings like > this...he'd come staggering into class with icicles hanging from his > beard, and muttering about "the American Siberia." Well, as Garrison > Keillor says, "Up here Mother Nature tries to kill us about six months > out of the year." Builds character...! I imagine I'll here from > somebody up around Fargo ND where it's _really_ cold... > > Stay warm -- won't be long until July/Brodhead once again! > Fred B. ________________________________________________________________________________
Date: Jan 15, 2005
Subject: [ Bill Sayre ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Bill Sayre Lists: Pietenpol-List Subject: Brodhead Fun http://www.matronics.com/photoshare/bannerbill@att.net.01.15.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: Burl panel
It's a movie, "Ferris Buellers's Day Off". Subject: Pietenpol-List: Burl panel > Clif and Greg and List: > > Clif, I am not familiar with Ferris Bueller, so you lost me on that > one. But I will research it until I know what you mean. Or as my > carpenter friends say " I can't smell what you are stepping in."> > Mike Luther > Anchorage (Banana belt) Alaska > NX1953M > ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Seat belts/harnesses/Deke Slayton Museum Piet
Thanks for excellent tips, Greg C. The Bingelis books are excellent, of course (I wouldn't try to build an airplane without them), and you provided tips very specific to the Piet -- many thanks again! Here's an update on the Piet recently put on display at the Deke Slayton Museum in Sparta, Wis.: According to a follow-up article in today's La Crosse Tribune newspaper it was built by Raymond Schwarz of Glenview, IL. Took him seven years to finish in the 1980s. The article also lists nine other people from Monroe County, Wis., who had built Piets over the years. My only complaint is that, like too many museums, they hung it from the ceiling -- how can young people (or other builders) get up close and really see it if it's hanging from a 20 or 30-foot ceiling? Perhaps they have a floor space issue, but I would feel bad if they hung it up to "get it away from the kids." BHP would feel bad, too. My 2 cents... Have a great day! Fred B. ________________________________________________________________________________
Date: Jan 16, 2005
Mike, that is one of the nicest instrument panels I have ever seen in any airplane. Would be interested in knowing where you got that wood also. I assume it doesn't grow locally up there in the Banana Belt. RIck H. > Clif and Greg and List: > > Clif, I am not familiar with Ferris Bueller, so you lost me on that > one. But I will research it until I know what you mean. Or as my > carpenter friends say " I can't smell what you are stepping in." > > Greg, I could not resist sending a picture of my cockpit panel. Yours > is awesome looking. Your picture turned out a lot better than mine. I > did notice the machine turning, the caning and the walnut stick grip. > You can see my burl thru the "too" many instruments, but just for fun > can you spot the garden hose, the British caulking gun parts or the > K-Mart freezer bump rail. > > List: From now on I will try not to be a Piet repieter and will start a > new message. > > Mike Luther > Anchorage (Banana belt) Alaska > NX1953M > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: Hanger space in the Phoenix Area
I am a computer programmer/geek and ex-flight instructor and thought the same as you at one time. Now I am TIG welding my controls. Just order the plans and start easy by making a rib jib and just build some ribs, will only cost you $100 to $200 bucks. You will know after the 4th or 5th rib whether you are cutout to move up to the elite ranks of Piet Builder. If you decide its not something you want to do you can hang the ribs you do complete in your office wall at the airport and impress your flight students. Rick H wrote: > > DJ, > > I have not yet started my project, haven't even > ordered the plans yet but am getting closer. Part of > what keeps delaying me is the thought of building > something more complicated than a door stop. I have > spent my life as a computer programmer and as a flight > instructor. Never really built anything. > > I currently have a hanger at the Goodyear Airport > (GYR) and work at Glendale Airport (GEU) with a little > work rearranging my hanger we could possibly store > your pietenpol in my hanger until you bubbled to the > top of the Falcon Field (FFZ) hanger list. I can be > reached at 602-819-8359 if you want to talk. > > Mike > > PS Have the hanger to store a bag of parts that will > someday be an Auster J1. > > __________________________________ > http://info.mail.yahoo.com/mail_250 > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Safety strap
What is the purpose of the safety strap that goes over the torque tube? To keep the torque from bending up or sideways too much? Can't find a thing on it in the archieves. -- Rick Holland ________________________________________________________________________________
Subject: center section radios
Date: Jan 16, 2005
This question directed to Jack Phillips. I dont have your e_mail address or would have sent this off line. A few days ago you posted a pic of your wing center section with the boxes containing transponder and such. I am very curious about this. Could you post more detail? Do you leave the transponder in the On position and have another power switch on the panel? What about VHF? Channging chanels? This is a great use of space. Dick N. ________________________________________________________________________________
Date: Jan 16, 2005
I used a Piper Cherokee emergency brake master cyl. The assy has a hand lever. One cyl controlls both wheels. With a steerable tailwheel I havent had the need for individual brakes. Dick N. ----- Original Message ----- From: John and Phyllis Smoyer To: pietenpol-list(at)matronics.com Sent: Saturday, January 15, 2005 7:24 PM Subject: Pietenpol-List: Need help finding a master cylinder Can anyone advise me on a good source for a brake master cylinder suitable for a Piet? Thanks to everyone for the informative postings and images. I really enjoy this group. Best Regards, John Smoyer ________________________________________________________________________________
Subject: Wing rib brace location
Date: Jan 16, 2005
A simple question- <> When you build your ribs, does the diagonal brace at the rear go from the bottom chord to the top of the rear strut (aswn in the plans and the full size rib sheet), or from low on the rear spar to the top rib capstrip (as shown on the Sky Scout rib plan, the BPA newletter sample, & the picture of the three piece wing)? I have found pictures of ribs on assorted web sites in each position. Regards- Norm Muzzy ________________________________________________________________________________
Subject: Re: Safety strap
Date: Jan 16, 2005
Rick, Guess it's for if the front guy fights you for the controls, and the torque tube breaks,,,OR the torque tube just breaks! It keeps the tube in allignment (kind of) and you can get the plane down. walt evans NX140DL ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Pietenpol-List: Safety strap > > What is the purpose of the safety strap that goes over the torque > tube? To keep the torque from bending up or sideways too much? Can't > find a thing on it in the archieves. > > -- > Rick Holland > > ________________________________________________________________________________
Subject: Re: Safety strap (Aileron torque tube)
Date: Jan 16, 2005
Rick, The earlier F&G Manual plans do not include the safety strap, likely because the aileron drive cables were attached to the rear control stick about 6" above the torque tube and ran down to the lower longerons, and out along the rear lift struts. This imposed a downward load on the torque tube, tending to keep it in position. The later drawings by Orrin Hoopman show the aileron drive cables attached to a vee-type crank welded to the torque tube about halfway along its length. Since these cables travel upward to the center section, they impose an upward force on the torque tube. A failure of the front torque tube attachment could allow the torque tube to swing upward, slackening the aileron drive cables. Presumably, the safety strap would hold the torque tube down enough to maintain some aileron control. When I built my Air Camper 35 years ago, I installed the "safety strap" according to the Hoopman plans. I had, and still have,a suspicion that there was a good reason for it being shown on the later plans, and would recommend using it. Graham Hansen (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: Wing rib brace location
The 1933 plans have it going from the top of the rear spar to the rib bottom. > > A simple question- > > < some > ribs, will only cost you $100 to $200 bucks. You will know after the > 4th or 5th rib whether you are cutout to move up to the elite ranks of > Piet Builder.>> > > When you build your ribs, does the diagonal brace at the rear go from the > bottom chord to the top of the rear strut (aswn in the plans and the full > size rib sheet), or from low on the rear spar to the top rib capstrip (as > shown on the Sky Scout rib plan, the BPA newletter sample, & the picture of > the three piece wing)? I have found pictures of ribs on assorted web sites > in each position. > > Regards- > Norm Muzzy > > > -- Rick Holland ________________________________________________________________________________
Date: Jan 16, 2005
Subject: Re: center section radios
Jim Malley has had his radios up there for some time. His plane appears in Mike's video. Clif Subject: Pietenpol-List: center section radios This question directed to Jack Phillips. I dont have your e_mail address or would have sent this off line. A few days ago you posted a pic of your wing center section with the boxes containing transponder and such. Dick N. ________________________________________________________________________________
Date: Jan 16, 2005
It goes from the TOP of the rear spar downwards and rearwards to the BOTTOM cap strip. That's the way it's shown in my 1933 Flying Manual. On p31 is an expanation of why the change was made. Clif > > > When you build your ribs, does the diagonal brace at the rear go from the > bottom chord to the top of the rear strut (aswn in the plans and the full > size rib sheet), or from low on the rear spar to the top rib capstrip (as > shown on the Sky Scout rib plan, the BPA newletter sample, & the picture of > the three piece wing)? I have found pictures of ribs on assorted web sites > in each position. > > Regards- > Norm Muzzy > ________________________________________________________________________________
Date: Jan 17, 2005
----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Saturday, January 15, 2005 1:00 PM Subject: Pietenpol-List: Burl wood for panel There's an outfit that goes by the name of CONSTANTINES that I bought some burhl from to rework the dash of an old Jaguar. I was very satisfied with what I got...paper thin but sufficient. If you have trouble getting to them with what little I've given you, contact me off line...You have my email address...Carl Vought Can anyone recommend a good source for burl wood for the instrument panel? I saw a great example of this at Oshkosh last summer and it really made the cockpit standout. ________________________________________________________________________________
Date: Jan 17, 2005
John: I used go-cart master cylinders. I added a page to my website- pics on there.. If you want better pics I can send them to you this weekend. Bert http://bconoly.tripod.com/id17.html ----- Original Message ----- From: John and Phyllis Smoyer To: pietenpol-list(at)matronics.com Sent: Saturday, January 15, 2005 8:24 PM Subject: Pietenpol-List: Need help finding a master cylinder Can anyone advise me on a good source for a brake master cylinder suitable for a Piet? Thanks to everyone for the informative postings and images. I really enjoy this group. Best Regards, John Smoyer ________________________________________________________________________________
Date: Jan 17, 2005
Bert: thanks very much. I'm a volunteer for an air museum, working on constructing an Air Camper. I'll review these pics with the boss on Wednesday. We never thought of go-cart brakes, but it sounds like a great idea. Thanks very much for your input, and for yourr great web-site. Your plane sure looks like a beauty. I clicked on the "what's a GN-1" link, but didn't look like any info came up. So, what is a GN-1, as compared to an Air Camper, anyway? Thanks, and best regards, John Smoyer ----- Original Message ----- From: Bert Conoly To: pietenpol-list(at)matronics.com Sent: Monday, January 17, 2005 7:54 PM Subject: Re: Pietenpol-List: Need help finding a master cylinder John: I used go-cart master cylinders. I added a page to my website- pics on there.. If you want better pics I can send them to you this weekend. Bert http://bconoly.tripod.com/id17.html ----- Original Message ----- From: John and Phyllis Smoyer To: pietenpol-list(at)matronics.com Sent: Saturday, January 15, 2005 8:24 PM Subject: Pietenpol-List: Need help finding a master cylinder Can anyone advise me on a good source for a brake master cylinder suitable for a Piet? Thanks to everyone for the informative postings and images. I really enjoy this group. Best Regards, John Smoyer ________________________________________________________________________________
Date: Jan 17, 2005
Subject: burl
I think I've figured out what my wood is. It has all the characteristics of the catalpa that I have used for carving in the past. I've still got a fair bit left. The reddish veneer I'm not sure of still. ________________________________________________________________________________ ETAsAhRT3qeHnLY7YxqvF+8FRhONxVT3PQIUVaLVOuQWPctdgwtQSqxvTyVbgWg=
Date: Jan 17, 2005
Subject: safety strap-torque tube
7.50 BARRACUDA_HEADER_FP56 RBL: Blacklist bl.spamcop [Blocked - see <http://www.spamcop.net/bl.shtml?209.240.207.249>] Ditto what G. Hansen said, but also if you brazed the mounting strap on to the torque tube bearing tubing as shown on the plans it's probably a good idea to have the safety strap. Remember the discussions about brazing 4130 a year or so ago? I left all of my brazed parts on the plane. I figure since hundreds of Piets have been flown with brazed parts(since Don Piet. is still selling old plans without corrections - even safety notations, like "don't braze 4130"- ( mild steel ok to braze) I think brazed parts are ok, but still, install the safety strap. Leon S. Hutchinson Ks. ________________________________________________________________________________
Subject: burl
Date: Jan 18, 2005
Whatever it is, it sure is pretty! Jack -----Original Message----- From: Clif Dawson [mailto:CDAWSON5854(at)shaw.ca] Subject: Pietenpol-List: burl I think I've figured out what my wood is. It has all the characteristics of the catalpa that I have used for carving in the past. I've still got a fair bit left. The reddish veneer I'm not sure of still. ________________________________________________________________________________
Date: Jan 18, 2005
Subject: Re: burl
The larger piece appears to be a high quality honduras cut mahogany ________________________________________________________________________________
Date: Jan 18, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Avai lable!
Subject: Re: [ Bill Sayre ] : New Email List PhotoShare Avai
lable! Bill Sayre ---- Your Brodhead Fun video and music on the photo share was GREAT !!!! Thank you ! For those who missed it, click on the link below, scroll down a bit and then and double click on the .wmv file. Mike C. > >http://www.matronics.com/photoshare/bannerbill@att.net.01.15.2005/index.html ________________________________________________________________________________
Date: Jan 18, 2005
Subject: Re: burl
Sometimes wonderful things happen when you least expect it. :-) Corky, I lean in that direction also but not Honduras. True Honduras was logged to extinction by the early part of the last century. There are some very similiar mahogany's from the same general region though. Clif Whatever it is, it sure is pretty! Jack ________________________________________________________________________________
Subject: update on N74DV
Date: Jan 18, 2005
DJ- You might put an ad in the paper 'wanted to share hanger'. My plane is in the hanger with another one. I know a person with a hanger at the Chandler airport, and they are huge hangers. It would be no problem to put a second plane in there. -Norm ________________________________________________________________________________
Subject: Re: safety strap-torque tube
Date: Jan 18, 2005
>since Don Piet. is still selling old plans without corrections - even >safety notations, like "don't >braze 4130"- mild steel ok to braze The plans do not need to have the warning because the plans do not call for 4130 steel. They actually call for mild steel. I think the only piece called out as chro-molly is the rudder bar but I'd have to check on that. Most people, my self included, choose to use 4130 but I welded mine because I thought that was the best way to do it. However, I'd bet there are a bunch of Piets out there with brazed 4130 (as well as millions of bike frames). I do wish Don would put some kind of a notice on the plans that says, if you choose to use 4130 steel check as to the appropriate welding or brazing process. I think it would help a of people. On a side note, did anyone else read the articles in Sport Aviation (I think November and December 2004?) where the authors tested Oxy-Acetylene, TIG and MIG welding processes with 4130. Read them at my Dads house and now he can't find them again. As I recall they felt all three processes can be used but MIG requires a bit more talent to get a good weld. They also recommended and welding rod RS-80 I think it was. Any one else remember this? Chris Tracy Sacramento, Ca ________________________________________________________________________________
<41E85EB5.2B3E9A96(at)gci.net> <00b901c4fac7$59d31c60$4e705118@dawsonaviation> <013801c4fddc$1ff949c0$0100a8c0@Desktop>
Subject: Re: update on N74DV
Date: Jan 19, 2005
----- Original Message ----- From: "DJ Vegh" <djv(at)imagedv.com> Subject: Re: Pietenpol-List: update on N74DV For some time, I've been interested in putting up my own, small, hanger, just big enough for one Piet. So far, I've been unable to get the owner of the airfield to assign me a space for it. The vendor that looks best to me sells a Quansit type building, (which is available in a 30'X22' size) is U.S. BUILDINGS in Boone, NC. They can be reached at 800/405-7501 and www.usbuildingsdirect.com. Prices appear reasonable, especially when you consider the resale value...Carl Vought > > hey guys.... been in Ireland all week just got back and am trying to catch > up to about 200 emails...... > > ________________________________________________________________________________
Date: Jan 19, 2005
<41E85EB5.2B3E9A96(at)gci.net> <00b901c4fac7$59d31c60$4e705118@dawsonaviation> <013801c4fddc$1ff949c0$0100a8c0@Desktop> <001801c4fe4d$b7511de0$a170d618@knology.net> report I'm curious, what prices have you seen from usbuildingsdirct.com? I filled out the form for a price list on their website, and even called them. They sent me a brochure, but no prices. Thanks! Steve Ruse Dallas, TX Quoting Carl Vought : > > > ----- Original Message ----- > From: "DJ Vegh" <djv(at)imagedv.com> > To: > Sent: Tuesday, January 18, 2005 11:05 PM > Subject: Re: Pietenpol-List: update on N74DV > > For some time, I've been interested in putting up my own, small, hanger, > just big enough for one Piet. So far, I've been unable to get the owner of > the airfield to assign me a space for it. The vendor that looks best to me > sells a Quansit type building, (which is available in a 30'X22' size) is > U.S. BUILDINGS in Boone, NC. They can be reached at 800/405-7501 and > www.usbuildingsdirect.com. Prices appear reasonable, especially when you > consider the resale value...Carl Vought > > > > > > hey guys.... been in Ireland all week just got back and am trying to > catch > > up to about 200 emails...... > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 19, 2005
My Piet is the second project that I've housed in a fabric hanger. The Piet has lived for the last couple of years in a "Cover-It" hanger. (20X30) Just have to find a airfield that will let you put one up. Both hangers have been through hurricanes, (or the part of the storm that we got hit with) without damage. walt evans NX140DL ----- Original Message ----- From: "Carl Vought" <carbarvo(at)knology.net> Subject: Re: Pietenpol-List: update on N74DV > > > ----- Original Message ----- > From: "DJ Vegh" <djv(at)imagedv.com> > To: > Sent: Tuesday, January 18, 2005 11:05 PM > Subject: Re: Pietenpol-List: update on N74DV > > For some time, I've been interested in putting up my own, small, hanger, > just big enough for one Piet. So far, I've been unable to get the owner of > the airfield to assign me a space for it. The vendor that looks best to me > sells a Quansit type building, (which is available in a 30'X22' size) is > U.S. BUILDINGS in Boone, NC. They can be reached at 800/405-7501 and > www.usbuildingsdirect.com. Prices appear reasonable, especially when you > consider the resale value...Carl Vought > > > > > > hey guys.... been in Ireland all week just got back and am trying to > catch > > up to about 200 emails...... > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Okoume BS-1088 Plywood Source Des Moines plus capstrip
steamer
Date: Jan 19, 2005
I just purchased some Okoume plywood from the folks at CedarTree in Des Moines. This is a family shop, basically selling the materials out of their garage. They are about a mile from the intersection of I35 and I80. Give them a call to check inventory, and to make sure they will be around. They indicated they would also cut sheets of material down to ship UPS, if that was a need. I bought some 1/16 inch and 1/8 inch from them just to get started. http://www.cedartreeinc.com/ I also got the tip to use an electric teapot to make a steamer for the cap strips. I bought a GE electric Teapot from Walmart, about $29. A piece of 1 inch PVC tubing fits the spout with just a bit of sanding, and I can steam 3 strips at one time. I pinched the steam switch tube shut (and TIGd it, just because I can!) to keep the steam switch from turning the pot off. The overtemp switch will trip after about 20 minutes, so you need to reset the switch after letting it cool for a few minutes. One hour of steaming and the douglas fir capstrips bent very easily over a forming block. This amount of time matches quite nicely with the time required to pull a rib out of the jig, put the new strips in, glue all the joints and splice plates. -Norm ________________________________________________________________________________ capstrip steamer
steamer
Date: Jan 20, 2005
steamer
From: "Textor, Jack" <jtextor(at)thepalmergroup.com>
Norm thanks for the heads-up. They are about 10 miles from my house. Jack Textor ________________________________________________________________________________
Date: Jan 20, 2005
Subject: More on the plane in the Deke Slayton Museum
Thank you to Grant MacLaren for forwarding this article to me, http://www.lacrossetribune.com/articles/2005/01/16/news/z2plane_16.txt Mike C. ________________________________________________________________________________
Date: Jan 20, 2005
Subject: Pientenpol-List: update on N74DV
Hello Carl, > Subject: Re: Pietenpol-List: > > the airfield to assign me a space for it. The vendor that looks best to me > sells a Quansit type building, (which is available in a 30'X22' size) is > U.S. BUILDINGS in Boone, NC. They can be reached at 800/405-7501 and > www.usbuildingsdirect.com. Prices appear reasonable, especially when you > consider the resale value...Carl Vought I have a friend who has a building like this, either by the same vendor or very similar, as a hanger at Page Airport just west of OK City. He built a Hatz Biplane there and also has a PA-17 in the hanger. He has a regular entrance door in the rear of the hanger and blocked off a portion there for the workshop with standard sliding doors for the front entrance for the planes. There are quite a few of these buildings on that airport. I was extremely impressed with the building. One thing about that location, the building will withstand the strong winds they get. The concrete pad is poured with footing bolts installed. They actually put a small scaffold on a pickup truck bed to construct it. You simply bolt it together like an Erector set. :) ...Edwin ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "Once you have flown, you will walk the earth with your eyes turned skyward, for there you have been, there you long to return."-- da Vinci ... www.shreve.net/~elj ________________________________________________________________________________
Subject: prop size
Date: Jan 21, 2005
I have been reading a book on making propellers. Just for comparisons, what size prop do those flying with the Corvair engine use? Does the Corvair run at about 100 hp? What is max rpm? What is the cruise speed you get? I have a Rotec radial engine on order. According to this book, I may have ordered a much too aggresive prop. The factory recommended a 72x55. I told them I wanted a climb prop, but I'm not going to be towing banners or gliders. Thanks Dick N. ________________________________________________________________________________
Subject: Re: prop size
Date: Jan 21, 2005
my Corvair has a 66x29 on it, which for a Corvair is considered a climb prop. I'm not looking for fast cruise so I propped it for great climb. The Corvair puts out anywhere from about 90-110hp depending on how you build it. Max rpm in the Corvair is limited by the size of prop you use.... but I'm going to redlinemine at about 3300. DJ ----- Original Message ----- From: Richard Navratil To: pietenpol-list(at)matronics.com Sent: Friday, January 21, 2005 9:03 AM Subject: Pietenpol-List: prop size I have been reading a book on making propellers. Just for comparisons, what size prop do those flying with the Corvair engine use? Does the Corvair run at about 100 hp? What is max rpm? What is the cruise speed you get? I have a Rotec radial engine on order. According to this book, I may have ordered a much too aggresive prop. The factory recommended a 72x55. I told them I wanted a climb prop, but I'm not going to be towing banners or gliders. Thanks Dick N. ________________________________________________________________________________
Date: Jan 21, 2005
Looking at the Rotec website I suspect that your prop will be close to correct. Also remember it is way easier to cut a little off of the blades if you have too much prop, impossible to add a little on if you don't have enough. Also the corvair typically has the prop running at crankshaft speed where as the Rotec has a 2-3 gear box. I suspect the factory has made a good recomendation. Looks like a really nice engine. Les >I have been reading a book on making propellers. Just for comparisons, >what size prop do those flying with the Corvair engine use? Does the >Corvair run at about 100 hp? What is max rpm? What is the cruise speed >you get? >I have a Rotec radial engine on order. According to this book, I may have >ordered a much too aggresive prop. The factory recommended a 72x55. I >told them I wanted a climb prop, but I'm not going to be towing banners >or gliders. >Thanks >Dick N. ________________________________________________________________________________
Date: Jan 21, 2005
Thanks les &DJ I'm trying to just get an idea if the guide in the book I have is accurate. It indicates that a 72x55 will give me 107 mph at 2450 rpm prop speed. Yes, I can throttle back for cruise and use the power for climb. Dick ----- Original Message ----- From: Les Schubert To: pietenpol-list(at)matronics.com Sent: Friday, January 21, 2005 7:23 PM Subject: Re: Pietenpol-List: prop size Looking at the Rotec website I suspect that your prop will be close to correct. Also remember it is way easier to cut a little off of the blades if you have too much prop, impossible to add a little on if you don't have enough. Also the corvair typically has the prop running at crankshaft speed where as the Rotec has a 2-3 gear box. I suspect the factory has made a good recomendation. Looks like a really nice engine. Les I have been reading a book on making propellers. Just for comparisons, what size prop do those flying with the Corvair engine use? Does the Corvair run at about 100 hp? What is max rpm? What is the cruise speed you get? I have a Rotec radial engine on order. According to this book, I may have ordered a much too aggresive prop. The factory recommended a 72x55. I told them I wanted a climb prop, but I'm not going to be towing banners or gliders. Thanks Dick N. ________________________________________________________________________________
Subject: Saw dust is Flying
Date: Jan 21, 2005
Just a note to say that after years of dreaming and "saying" I am going to start building a piet, I actually built my table today. I know it is not an "actual" part of the airplane but I have to start some where. I am just happy to see some physical progress. I will be ready to order wood for the fin and rudder as soon as I get a quote back from the supplier. My questions for all those "experienced" builders is this. What tool or tools would you say was the most handy to have around during your building process? Any opinions on Aeropoxy glue? Any and all sugestions would be very much appreciated. Thank you. Chad Johnson, McPherson Kansas. ________________________________________________________________________________
Date: Jan 21, 2005
<000e01c5002c$d0c52830$0600a8c0@laptop> Which book? Here's an interesting little program to play with; http://www.nicon.org/chapter328/PropDesign/ Clif Subject: Re: Pietenpol-List: prop size Thanks les &DJ I'm trying to just get an idea if the guide in the book I have is accurate. It indicates that a 72x55 will give me 107 mph at 2450 rpm prop speed. Yes, I can throttle back for cruise and use the power for climb. Dick ________________________________________________________________________________
Date: Jan 22, 2005
Subject: Re: Ohio Weather Prediction
Blame the Ruskies, we just wave what we don't need on through. They couldn't get us with ICBM's....... :-) :-) Clif > >> We have a special shippment coming to ya'll on Sunday direct from our > neighbors in Canada to Louisianna so don't get too comfortable. ________________________________________________________________________________
Date: Jan 22, 2005
Subject: Pietenpol Tools
Hi Chad! I started building my Piet back in November and have the fuselage pretty well framed up and am working on the turtledeck stringers. One of the most useful tools for me have been the electric, laser-guided miter saw that my wife got me for Christmas a couple years ago -- I told her I wanted to do some cove molding around the house, which I did. Of course, I was also thinking a little more long term, if you get my drift! It has been very useful in accurately cutting all the fuselage uprights and crossbraces with all those different angles. Obviously you can make all those cuts with a good sharp hand saw, too, but if you can get an electric laser-guided miter saw, you won't be disappointed. (Hey, if laser-guided is good enough for Al Queda, it's good enough for us Piet builders, too!) A bench vise is good too for when you do need/want to make hand saw cuts. I also have a hand-me-down table saw that I've been using to cut my spruce into the various dimension strips -- I bought my spruce in 20-foot long 6-inch wide, 1-inch thick planks from McCormick's Lumber in Madison, WI. Amazingly I still have all my fingers -- as originally attached. The docs can do miracles now and reattach all kinds of various body parts, but I'd just as soon not go through that exercise -- besides, it would set back the building schedule! I also went to an auction last summer and picked up a like-new combination belt sander/disc sander for about $40. That has been very useful for smoothing parts and taking off just a little to get a perfect fit. At the same auction and for about the same money I picked up an also like-new Craftsman table router -- I haven't used it yet but am thinking I will use it for forming my own vertical and horizontal stabilizer leading edge material. Other than that, a large T-square and carpenters chalk line for keeping everything square and for laying down straight when drawing out the fuselage sides on the bench. The top longeron has to be perfectly straight. I also picked up a neat little wood chisel -- it's not only a chisel but on one side it is a flat rasp and the opposite side is a rounded rasp -- handy for trimming off little blobs of epoxy that may drip here and there and that you may miss when wiping up excess. (My wife told me I should just leave that big C-clamp that accidentally got glued to the fuse top a week ago!) Also lots of sandpaper and various blocks of wood to use as sanding blocks. Lots of light -- I had a couple fluorescent shop lights in the basement where I'm building the fuse. These were up by the firewall end, with a regular light bulb down by the tail. But I picked up another shop light at Home Depot for about $10 and hung that one over the tail end -- what a difference! My feeling is that you can't have too much light (especially at my age-- I didn't used to need reading glasses until I built that darn ship model a couple years ago!) A handheld sabre/jig saw for cutting out large plywood pieces. I find that a blade for cutting sheet metal works well for cutting aircraft ply without splintering the backside all to heck. I also have a small bench jig saw which come in handy. I don't have a band saw, but that would serve very well in a wide variety of uses -- that's probably the one saw I really should have...but I've done okay without so far... Have fun building! And stay tuned to this list -- I've learned a lot from the real experts on this list! Great bunch of folks! Anyway, I hope this helps. Fred B. La Crosse, WI PS -- Still snowing here this fine Saturday morning -- not a good day to go out but that's okay 'cause I'm building my Piet in the basement! ________________________________________________________________________________
Date: Jan 22, 2005
Subject: Re: Saw dust is Flying
Re: 'handy' tools, A sander, bench mount, nice to have a belt/disc model A band saw A drill press and a hand type electric drill Note, these are not absolute requirements, but sure do make life easier and more enjoyable micrometer (1" is fine); and an inside/outside caliper,(plastic one is OK). These are what I call 'tools of precision' are usefull in setting up a saw and other tools. Have at it, the fun ( and tears) are yet to come). Lou Larsen Sill going on a 9+ year Piet project ________________________________________________________________________________
Subject: sawdust
Date: Jan 22, 2005
Chad, > There will always be naysayers in anything you or anyone else does. That does not matter. What matters is that you follow your dream at your pace. I have also been "at it" for about four years. Since I started I have moved, my wife has had many health issues ect. Today I am finishing up the drywall hanging in the garage at our new place. I have all the fuse wood, all the rib wood, all the tail group wood, and I have my Corvair engine all tore down. Part of my plan hasalways been a clean place to work and a place for everything. If you build clean, it just seems to me you will end up with a safer plane. Not to say a dirty/unkept shop is going to produce an unsafe plane, but for me I want it all to be organized. I've always been that way. Good Luck, and congratulations on getting started. 909-790-0530 > > Doug Blackburn > Doug & Elizabeth Blackburn > Yucaipa California > www.inlandsloperebels.com > W W's Conversion Manual 3202, 5782 > www.flycorvair.com 20 > after years of dreaming and "saying" I am going to start building a piet, I actually built my table today. Chad Johnson, McPherson Kansas. Doug & Elizabeth Blackburn Yucaipa California www.inlandsloperebels.com W W's Conversion Manual 3202, 5782 www.flycorvair.com ________________________________________________________________________________
Date: Jan 22, 2005
When it comes time to make your metal parts I would add a good bench vice (bending metal fittings and squishing metal tubing) and an angle grinder (around $40 to $50) for cutting metal sheet and tubing (unless you want to spend the money on a metal cutting band saw). wrote: > > Re: 'handy' tools, > > A sander, bench mount, nice to have a > belt/disc model > A band saw > A drill press and a hand type electric > drill > > Note, these are not absolute requirements, but sure do make life easier > and more enjoyable > > micrometer (1" is fine); and an inside/outside caliper,(plastic one is OK). > These are what I call 'tools of precision' are usefull in setting up a > saw and other tools. > > Have at it, the fun ( and tears) are yet to come). > > Lou Larsen Sill going on a 9+ year Piet project -- Rick Holland ________________________________________________________________________________
Subject: Tool Advice and Aeropoxy
Date: Jan 22, 2005
Thanks for all the advice on tools and building. So far I have most of the tools needed with exception of a band saw. Any opinions or experience with Aeropoxy glue? My wood supplier uses Aeropoxy for his own work, he has it in stock and the cost seems to be the same as T88. Chad ________________________________________________________________________________
Date: Jan 22, 2005
Mike, just saw this message.... (still trying to catch up from my vacation) I'll certainly keep it in mind! I'm going to try another round of hangar searching at CHD and FFZ in a few weeks. DJ ----- Original Message ----- From: "Mike Volckmann" <mike_cfi(at)yahoo.com> Subject: Pietenpol-List: Hanger space in the Phoenix Area > DJ, > I currently have a hanger at the Goodyear Airport > (GYR) and work at Glendale Airport (GEU) with a little > work rearranging my hanger we could possibly store > your pietenpol in my hanger until you bubbled to the > top of the Falcon Field (FFZ) hanger list. I can be > reached at 602-819-8359 if you want to talk. > > Mike ________________________________________________________________________________
<00d001c50057$003c3e30$4e705118@dawsonaviation>
Date: Jan 22, 2005
Cliff I have "Propeller Making For The Amateur" by Eric Clutton. Thanks, I'll take a look at that web site. Dick N. ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Saturday, January 22, 2005 1:50 AM Subject: Re: Pietenpol-List: prop size Which book? Here's an interesting little program to play with; http://www.nicon.org/chapter328/PropDesign/ Clif ________________________________________________________________________________
Date: Jan 22, 2005
Chad, The others told you most of the tools you will need to build with. You will also need to buy a gas welding rig (I bought one at auction real cheap) to build your metal parts with. The most useful tools I have used were the table saw for cutting out my wood pieces (I bought spruce from the local lumber yard, 2 X 6 planks in different length, to save tons of money, the band saw, the drill press, the miter saw, and the bench sander. The other tools are all hand tools that most everyone owns. Once you get your jigs set up, things will go quickly and you will see progress. Best luck and have fun. Doc ________________________________________________________________________________
Subject: cruise speed and fabric work
Date: Jan 22, 2005
To answer one of Dick Navratil's questions that didn't seem to get answered, the Corvair-powered Piets (well, the ones with the William Wynne conversion and no blower motor) seem to cruise a bit faster than the A-65 and Ford powered ones. Not to say that they are comfortable cruising at those higher speeds, but that they can do so with the extra horsepower. William's plane would climb out at the airspeed that my A-65 Aircamper cruises at (65 MPH), and would cruise at 100 MPH if you firewalled it and didn't care about the ride or the fuel consumption. I think he normally cruised it at 70-75 MPH which was comfortably throttled back. Certainly the climb in the Corvair Aircampers far exceeds the 100 feet per hour stated for that vintage Pietenpol in the museum-! And as long as everybody is hunkered down, snowed in, blown out, frozen in place, mudslidden, flooded, or otherwise grounded- I'd like to know how big a deal fabric covering is. I've watched the Stits video (years ago) and it doesn't seem too difficult, but have never done it. I don't have the Poly-Tak, the dopes, iron, or the other stuff (but can scrounge or borrow what I need)... just want to make sure it's not too difficult to do myself. I need to re-cover the vertical stabilizer and also patch a few spots in the fuselage here and there. Thanks for any comments. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 22, 2005
DJ, I understand GYR is a long way from the east valley. My mother lives just north of IWA. Currently I am considering starting either a Fokker Dr-1 replica or a Pietenpol. Probably end up being the Dr-1 replica. Mike --- DJ Vegh wrote: > > > Mike, > > just saw this message.... (still trying to catch up > from my vacation) I'll > certainly keep it in mind! I'm going to try another > round of hangar > searching at CHD and FFZ in a few weeks. > > DJ > > ----- Original Message ----- > From: "Mike Volckmann" <mike_cfi(at)yahoo.com> > To: > Sent: Saturday, January 15, 2005 12:01 PM > Subject: Pietenpol-List: Hanger space in the Phoenix > Area > > > > DJ, > > I currently have a hanger at the Goodyear Airport > > (GYR) and work at Glendale Airport (GEU) with a > little > > work rearranging my hanger we could possibly store > > your pietenpol in my hanger until you bubbled to > the > > top of the Falcon Field (FFZ) hanger list. I can > be > > reached at 602-819-8359 if you want to talk. > > > > Mike > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://my.yahoo.com ________________________________________________________________________________
Subject: Re: cruise speed and fabric work
Date: Jan 22, 2005
Thanks Oscar for that input, that's exactly what was looking for. I'll have 115 hp but I dont want to cruise too fast, but after having flown the Piet on some hot days, I need to climb at better than 100 feet per hour. I have received some warnings from guys in my EAA chapter that the stall characteristics will drastically change with more hp and stol prop. Now for your question. I really enjoyed to covering. It isn't hard at all. Do the tail feathers first of course. It goes so fast that it's almost a let down, You spent so much time getting to that point and in no time it's done. The rib stitching is the biggest chore. Fabric stretching and applying the tapes are really easy. Dick ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: cruise speed and fabric work > > > To answer one of Dick Navratil's questions that didn't seem to get > answered, the Corvair-powered Piets (well, the ones with the William Wynne > conversion and no blower motor) seem to cruise a bit faster than the A-65 > and Ford powered ones. Not to say that they are comfortable cruising at > those higher speeds, but that they can do so with the extra horsepower. > William's plane would climb out at the airspeed that my A-65 Aircamper > cruises at (65 MPH), and would cruise at 100 MPH if you firewalled it and > didn't care about the ride or the fuel consumption. I think he normally > cruised it at 70-75 MPH which was comfortably throttled back. > > Certainly the climb in the Corvair Aircampers far exceeds the 100 feet per > hour stated for that vintage Pietenpol in the museum-! > > And as long as everybody is hunkered down, snowed in, blown out, frozen in > place, mudslidden, flooded, or otherwise grounded- I'd like to know how > big a deal fabric covering is. I've watched the Stits video (years ago) > and it doesn't seem too difficult, but have never done it. I don't have > the Poly-Tak, the dopes, iron, or the other stuff (but can scrounge or > borrow what I need)... just want to make sure it's not too difficult to do > myself. I need to re-cover the vertical stabilizer and also patch a few > spots in the fuselage here and there. > > Thanks for any comments. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Date: Jan 23, 2005
Subject: Tools/glue
I've been using the West System T-88 epoxy. Very easy to work with. One thing I found is that the plastic lids from the plastic coffee "cans" are ideal for mixing epoxy -- will hold up to three squirts of resin and hardener at a time. Hardened waste epoxy will simply snap right out and you can use the lid again -- or if it gets too old and grungy just throw it away. I keep several in the shop...and the rest of the coffee containers are handy, too. I suppose one of these days nice tin coffee cans will show up in the antique shops, just like the old tin and even cardboard motor oil cans... Working on aft fuselage turtledeck today... Fred B. ________________________________________________________________________________
Date: Jan 23, 2005
As for tools, the ones that I used a lot were a good 6" belt sander and a cheap metal cutting bandsaw (about $200 from Grizzly). Don't know anything about Aeropoxy. I mostly used Resorcinol, with a little bit of T-88 in places that would show. In my recent forced landing, none of the glue joints broke - the wood fractured outside of the joint. Resorcinol is a pain in the winter, though, due to its required bonding and curing temperatire of 70 F +. I'm waiting right now for the heaters to bring the temperature in my basement up to 70 so I can glue together my new stabilizer. It was 14 F last night and has warmed up to a balmy 25 F so far today. Jack Phillips Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Chad Johnson Subject: Pietenpol-List: Saw dust is Flying Just a note to say that after years of dreaming and "saying" I am going to start building a piet, I actually built my table today. I know it is not an "actual" part of the airplane but I have to start some where. I am just happy to see some physical progress. I will be ready to order wood for the fin and rudder as soon as I get a quote back from the supplier. My questions for all those "experienced" builders is this. What tool or tools would you say was the most handy to have around during your building process? Any opinions on Aeropoxy glue? Any and all sugestions would be very much appreciated. Thank you. Chad Johnson, McPherson Kansas. ________________________________________________________________________________
Subject: fabric work
Date: Jan 23, 2005
Dick wrote- >Do the tail feathers first of course. It goes so fast that it's almost a >let down, You spent so much time getting to that point and in no time >it's done. The rib stitching is the biggest chore. Fabric stretching and >applying the tapes are really easy. Thanks, but- all I'm doing are repairs! As you'll recall, this is the repair of NX41CC after its ignominious nose-over incident on Veterans Day. There is the vertical stabilizer to re-cover, plus several areas where the fabric has had to be opened up to access various fittings. Sad to say, unless I re-cover the whole airframe, this bird is going to look like it has some experience in theater (of war), with field repairs! I'm going to try to do a good job on the paint matching, but patches will show upon close examination. My thought it to apply round patches to the areas we've had to open up, and to use pinked edges on the round patches. As I understand it, I'll need to sand back the paint on the underlying fabric to get to bare fabric, then Poly-Tak the patch in place and go from there. If this is the wrong approach or if there are easier ways to do spot repairs, please advise. I also assume everything will be the standard weight fabric (2.7 oz.), although some have used the lightweight fabric for the tail surfaces. I believe Ernie Moreno told me he used the old HS90X fabric to re-cover the tail surfaces on his airplane to shave a bit of weight off the tail. Oscar Zuniga San Antonio, TX ________________________________________________________________________________
Date: Jan 24, 2005
Oscar, I'm doing the same thing to my Pietenpol after its forced landing. A couple of questions come to mind: 1. What paint was used on it originally? If a polyurethane paint was used (like I did on mine), the old paint will have to be sanded off - and that is a major pain. If PolyTone was used, MEK will remove it easily. I suspect MEK would take butyrate dope off as well, but I have no experience with that. 2. How long are the cuts in the original fabric? If the cut is 8" or less, the overlap only needs to be 1" when you glue the new fabric down with PolyTak. If more than 8", you need a 2" overlap. I cover the overlap with 2" pinked tape as well. 3. On the vertical stab, you will probably have to use bias tapes to tape around the curve at the top. Just follow the directions in the polyfiber manual. If you have questions, contact the folks at PolyFiber. They are very good about answering technical questions. http://www.polyfiber.com/ Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Subject: Pietenpol-List: fabric work Dick wrote- >Do the tail feathers first of course. It goes so fast that it's almost a >let down, You spent so much time getting to that point and in no time >it's done. The rib stitching is the biggest chore. Fabric stretching and >applying the tapes are really easy. Thanks, but- all I'm doing are repairs! As you'll recall, this is the repair of NX41CC after its ignominious nose-over incident on Veterans Day. There is the vertical stabilizer to re-cover, plus several areas where the fabric has had to be opened up to access various fittings. Sad to say, unless I re-cover the whole airframe, this bird is going to look like it has some experience in theater (of war), with field repairs! I'm going to try to do a good job on the paint matching, but patches will show upon close examination. My thought it to apply round patches to the areas we've had to open up, and to use pinked edges on the round patches. As I understand it, I'll need to sand back the paint on the underlying fabric to get to bare fabric, then Poly-Tak the patch in place and go from there. If this is the wrong approach or if there are easier ways to do spot repairs, please advise. I also assume everything will be the standard weight fabric (2.7 oz.), although some have used the lightweight fabric for the tail surfaces. I believe Ernie Moreno told me he used the old HS90X fabric to re-cover the tail surfaces on his airplane to shave a bit of weight off the tail. Oscar Zuniga San Antonio, TX ________________________________________________________________________________
Date: Jan 24, 2005
Subject: Re: fabric work
You don't want to let your sandpaper get into the fabric at all. Once those fibers are cut with sandpaper, they have lost strength. Also, the place will never seem to fill with your finishing materials. This is the reason for using dope on fabric. If it was dope to begin with, there is no need to sand thru the dope. Just lightly sand to scuff the surface. The dope will soften again with application of new dope and thus blend in. If the original finish is polyurethane or enamel, its not that simple. Lightly sand and then mask off the area to be painted using the same type of paint. The trouble is, you can't get a blending effect and you end up with a mask line. Also...watch out for sanding over rib stitches abd structure. It doesn't take much pressure and your sandpaper will get into the fabric. -- Terry L. Bowden ph 254-715-4773 fax 254-853-3805 ________________________________________________________________________________
Subject: Piet for sale
Date: Jan 24, 2005
Hey Piet listers, I'm back on the list as we have our computer set up in the motor home parked in the hangar. Have about 1/2 my Piet parts in the hangar, the rest should be here soon. Will be back to work on the Piet after some electric and allot of plumbing in the hangar and building the apartment, so maybe next fall. Dick, Jack and Bert congratulations on your projects becoming aircraft. Oscar and Jack sorry to read about the off field landings, glad only airplanes were hurt. A guy on the field here is building a Bearhawk and he told me Bob Barrows the designer of that aircraft is selling his A model Peit. Short fuselage(don't know if he means flyer and gilder or 1934 plans), red and silver, no breaks, tail skid, wire wheels with straight axle, empty weight 630, the A has pressure lube and aluminum head. Aircraft has 80 hours. Barrows says it flys straight and good, my contact here whos judgment I trust says it looks like good workmanship. Barrows will deliver within 500 miles from Fincastle VA. $12,000.00 Telephone for Barrows 540 473-3661. Hales Landing the airpark I live at is now on the Cincinnati sectional, 12 miles south on Parkersburg WV. Once the Wx gets better Piet listers please stop by. Skip Cinda + Skip Gadd csfog(at)earthlink.net ________________________________________________________________________________
Subject: Re: Piet for sale
Date: Jan 24, 2005
Is that "breaks" or "brakes"? Might make a difference. ----- Original Message ----- [...] selling his A model Peit. Short fuselage(don't know if he means flyer and gilder or 1934 plans), red and silver, no breaks, tail skid, wire wheels with straight axle, empty weight 630, the A has pressure lube and aluminum head. Aircraft has 80 hours. [...] ________________________________________________________________________________
Date: Jan 24, 2005
Subject: Another Piet, actually a GN-1 for sale
0.37 FORGED_QUALCOMM_TAGS QUALCOMM mailers can't send HTML in this format 1.15 OBFUSCATING_COMMENT HTML comments which obfuscate text 0.29 HG_HORMONE Talks about hormones for human growth Can be seen if you search "Pietenpol" under barnstormers.com Photo enclosed. Mike C. PIETENPOL =95 $10,000 =95 COME AND GET IT =95 Pietenpol GN1-Aircamper Expermential class, built in 1981 flown regularly except the past year, only flown twice in past 12 month, That't the reason for the sale, Have to many airplanes. Wife says 2 is enough. C-85 continantial engine less that 600 TTA&E. Needs annual, but it is airworthy. Have all log books and records since new Price $10,000 without annual Jan. 18, 2005 call 731-225-5475 or 731-693-4041 West Tennessee. =95 Contact James Fairchild - located Pinson, TN Usa =95 Telephone: 731-988-5288 or 731-424-5426 =95 Posted January 20, 2005 =95 Show all Ads posted by this Advertiser =95 Recommend This Ad to a Friend =95 Send a Message ________________________________________________________________________________
Date: Jan 24, 2005
The Piet has no brakes. No breaks as far as I know. Skip Is that "breaks" or "brakes"? Might make a difference. ________________________________________________________________________________
Date: Jan 24, 2005
Subject: Re: Another Piet, actually a GN-1 for sale
report I called and spoke to the owner of this one for about 30 minutes on Saturday. Sounds like it is a good airplane. However, he e-mailed me this morning and said that someone came out and looked at the plane Sunday, walked around it once, and said he'd take it pending a pre-buy. Still, no cash has traded hands as far as I know, but it might already be spoken for. Steve Ruse Dallas, TX Quoting Michael D Cuy : > Can be seen if you search "Pietenpol" under barnstormers.com > > Photo enclosed. > > Mike C. > > > PIETENPOL $10,000 COME AND GET IT Pietenpol GN1-Aircamper > Expermential class, built in 1981 flown regularly except the past year, > only flown twice in past 12 month, That't the reason for the sale, Have to > many airplanes. Wife says 2 is enough. C-85 continantial engine less that > 600 TTA&E. Needs annual, but it is airworthy. Have all log books and > records since new Price $10,000 without annual Jan. 18, 2005 call > 731-225-5475 or 731-693-4041 West Tennessee. Contact James Fairchild - > located Pinson, TN Usa Telephone: 731-988-5288 or 731-424-5426 Posted > January 20, 2005 Show all Ads posted by this Advertiser Recommend This > Ad to a Friend Send a Message > ________________________________________________________________________________
Date: Jan 24, 2005
Subject: New owner...
report A few months ago I posted asking people for leads on GN-1s for sale. Several people e-mailed me, and DJ sent me some information on a Pietenpol he had seen in Indiana. I called and spoke with the owner in December, scheduled a pre-buy inspection, and then went to see the plane for myself when I was on Christmas vacation. I just got off the phone with the owner, and agreed to purchase the plane! Now as soon as the weather warms up in Indiana, I'll be going to get it. Hopefully it won't be late March before I get a decent weekend...I'm waiting for a few days of forty degree temps in Indiana to make the trip home in my first airplane. Needless to say, sitting at work every day waiting for spring is torture... Steve Ruse Future owner of N6383J Dallas, TX ________________________________________________________________________________
Date: Jan 24, 2005
Subject: Re: New owner...
In a message dated 1/24/2005 6:32:06 P.M. Central Standard Time, steve(at)wotelectronics.com writes: ...I'm waiting for a few days of forty degree temps in Indiana to make the trip home in my first airplane. Steve, This is good news, and good luck with your new acquisition. It appears that you fall under TACO jurisdiction, being located in the Dallas, TX. area. You will need to talk to Sterling about that. We should plan a get together sometime soon, I'm sure we need to have a TACO meeting for the occasion...in the past we have met at the Purple Cow, and some other undisclosed locations. Let us know if you need any assistance with this endeavor. Max Davis Arlington, TX. 817.516.1116 (H) 817.229.9136 (M) ________________________________________________________________________________
Date: Jan 24, 2005
glad to hear you bought that plane. It's a great little plane that the owner took good care of. Did you happen to notice the white/green T-craft in the hangar when you went to see the GN-1? Thats the T-craft my cousin owns and I get to fly every August. DJ ----- Original Message ----- From: "Steve Ruse" <steve(at)wotelectronics.com> Subject: Pietenpol-List: New owner... > > > A few months ago I posted asking people for leads on GN-1s for sale. > Several > people e-mailed me, and DJ sent me some information on a Pietenpol he had > seen > in Indiana. I called and spoke with the owner in December, scheduled a > pre-buy > inspection, and then went to see the plane for myself when I was on > Christmas > vacation. I just got off the phone with the owner, and agreed to purchase > the > plane! Now as soon as the weather warms up in Indiana, I'll be going to > get > it. Hopefully it won't be late March before I get a decent weekend...I'm > waiting for a few days of forty degree temps in Indiana to make the trip > home > in my first airplane. Needless to say, sitting at work every day waiting > for > spring is torture... > > Steve Ruse > Future owner of N6383J > Dallas, TX > > > ________________________________________________________________________________
Date: Jan 24, 2005
Steve, Congratulations! Best of luck with your new bird. I hope to see it and meet you sometime soon. Max is right. We need to plan a TACO meeting soon. I need to come up anyway so I can retrieve my dad's nicopress swaging tool from Jim Markle. Also, we plan to have another Tick Hill TACO gathering this spring sometime. So maybe you can bring your plane down then. In the mean time....Happy Low and Slow flying. Terry Bowden ________________________________________________________________________________
Date: Jan 24, 2005
Date: Jan 24, 2005
Subject: Next TACO meeting to honor Steve Ruse
Actually the subject line should read... Next TACO meeting to honor and induct Steve Ruse and gawk at his new Texas Air Camper... As soon as Steve has an idea of when he will have his Air Camper in Texas, and at a time convenient to him, let's have a meeting. Maybe we can tie this into Mike Cuy's visit. Maybe Corky can swing by? Maybe Oscar will have his repairs done and can meet us at a location between San Antonio and Dallas if there isn't a Presidential TFR. Maybe some other Yankees other than Mike can visit? Just a thought. Sterling 5TA6 NOTAMS. Fresh cow chips on runway, land at your own risk. ________________________________________________________________________________
Date: Jan 25, 2005
Subject: Hales Landing
In a message dated 1/24/05 11:13:57 AM Central Standard Time, csfog(at)earthlink.net writes: Hales Landing the airpark I live at is now on the Cincinnati sectional, 12 miles south on Parkersburg WV. Once the Wx gets better Piet listers please stop by. Skip Skip, Great to hear you're back on the list. While I was at Marshall Co. Airport during August '04, in W Va, I got to the point of flight planning a day trip with the position and cooridnates you gave me at Brodhead, and with my 26 yr old son in the front pit. Had everything set to go. I don't remember if you weren't there, or it was weather that kept us from setting off. I was really looking forward to making that flight...We'll make it next time through !! Chuck G. ________________________________________________________________________________
Date: Jan 25, 2005
Oscar, I have oil based enamel Aluminum Rust-oleum on my plane, for the UV protection, and oil based Red Devil Red, for the trim. The paint is holding up very well. For the repairs I have done, I have been fairly successful by using duct tape to remove most of the paint, down to the fabric. Carefully test small areas. Experiment using the duct tape right on unsanded paint, or use fine sand paper to remove the gloss, clean the dust off and press the duct tape on, and RIP off the paint, leaving reletively clean fabric. This probably wouldn't work with Dope. I finished up cleaning the fabric with plenty of clean rags, and MEK wearing rubber gloves. Remove the paint, and clean the fabric before you cut the fabric, or the loose edges are much more difficult to clean. Like Terry said, be very carefull not to sand into any fibers. 1" to 2" overlap for the patch, using poly tac, and even blend the edges away with you fingers and the glue. Finish blending the edges with an iron at temperatures toward the lower end of the range. You should be able to blend in paint right up to the patch, and make the patch almost disappear. To save weight on the empenage, I used 1.8 oz fabric. It's also easier to use the lighter fabric, however, your patch should be the same weight as what it is covered with. Fabric repair is not very difficult. Matching the paint will probably be your biggest challenge, however, repairs give 'er some character !! Chuck G. ________________________________________________________________________________
Date: Jan 25, 2005
Hey DJ, Thanks a lot for helping me out, I wouldn't have found it without your help! I've been meaning to e-mail you since your post about your hangar issues. I sure hope you can find a solution, I want to see you fly your plane one day. I'd hate to see you get rid of it. I've spent the last six months looking over your site, trying to learn as much as I can, it is packed with good information and a lot of great pictures. I didn't get to look at the Tcraft when I was there. We all night from Minneapolis, got to South Bend at about 8AM, spent an hour looking at the plane, and then headed out. I was dog tired and it was about 3*F, way too cold for me! Once I got done looking at the plane there wasn't much else on my mind. If you ever make it out this way, be sure to send me an e-mail or something, I'd be glad to take you up for a while! Steve -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh Subject: Re: Pietenpol-List: New owner... glad to hear you bought that plane. It's a great little plane that the owner took good care of. Did you happen to notice the white/green T-craft in the hangar when you went to see the GN-1? Thats the T-craft my cousin owns and I get to fly every August. DJ ----- Original Message ----- From: "Steve Ruse" <steve(at)wotelectronics.com> Subject: Pietenpol-List: New owner... > > > A few months ago I posted asking people for leads on GN-1s for sale. > Several > people e-mailed me, and DJ sent me some information on a Pietenpol he had > seen > in Indiana. I called and spoke with the owner in December, scheduled a > pre-buy > inspection, and then went to see the plane for myself when I was on > Christmas > vacation. I just got off the phone with the owner, and agreed to purchase > the > plane! Now as soon as the weather warms up in Indiana, I'll be going to > get > it. Hopefully it won't be late March before I get a decent weekend...I'm > waiting for a few days of forty degree temps in Indiana to make the trip > home > in my first airplane. Needless to say, sitting at work every day waiting > for > spring is torture... > > Steve Ruse > Future owner of N6383J > Dallas, TX > > -- Checked by AVG Anti-Virus. -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Date: Jan 25, 2005
That sounds like fun Sterling, I can't wait to get it back here and spend spring, summer, and fall burning Avgas. I'll have the plane here ASAWA (As Soon As Weather Allows). I'd be glad to drop down into the hill country once I get it here, there is some great barbeque to be had down there. Thanks for the welcome everyone...I can't wait to meet more of you. Seems like a great group. Later this spring I plan on buying some wood and fabric and re-creating the vertical and horizontal stabs for a Pietenpol, just to learn more about their construction. Who knows, maybe one day I'll find time to build an entire Piet. Steve Dallas, TX -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of N321TX(at)wmconnect.com Sent: Monday, January 24, 2005 8:19 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Next TACO meeting to honor Steve Ruse Actually the subject line should read... Next TACO meeting to honor and induct Steve Ruse and gawk at his new Texas Air Camper... As soon as Steve has an idea of when he will have his Air Camper in Texas, and at a time convenient to him, let's have a meeting. Maybe we can tie this into Mike Cuy's visit. Maybe Corky can swing by? Maybe Oscar will have his repairs done and can meet us at a location between San Antonio and Dallas if there isn't a Presidential TFR. Maybe some other Yankees other than Mike can visit? Just a thought. Sterling 5TA6 NOTAMS. Fresh cow chips on runway, land at your own risk. -- Checked by AVG Anti-Virus. ________________________________________________________________________________
From: "Richard Navratil" <horzpool(at)goldengate.net>
Date: Jan 25, 2005
Hey Skip Great to hear from you again. Hope to se you at SNF again. Dick ----- Original Message ----- From: Cinda Gadd To: Pietenpol Sent: Monday, January 24, 2005 11:12 AM Subject: Pietenpol-List: Piet for sale Hey Piet listers, I'm back on the list as we have our computer set up in the motor home parked in the hangar. Have about 1/2 my Piet parts in the hangar, the rest should be here soon. Will be back to work on the Piet after some electric and allot of plumbing in the hangar and building the apartment, so maybe next fall. Dick, Jack and Bert congratulations on your projects becoming aircraft. Oscar and Jack sorry to read about the off field landings, glad only airplanes were hurt. A guy on the field here is building a Bearhawk and he told me Bob Barrows the designer of that aircraft is selling his A model Peit. Short fuselage(don't know if he means flyer and gilder or 1934 plans), red and silver, no breaks, tail skid, wire wheels with straight axle, empty weight 630, the A has pressure lube and aluminum head. Aircraft has 80 hours. Barrows says it flys straight and good, my contact here whos judgment I trust says it looks like good workmanship. Barrows will deliver within 500 miles from Fincastle VA. $12,000.00 Telephone for Barrows 540 473-3661. Hales Landing the airpark I live at is now on the Cincinnati sectional, 12 miles south on Parkersburg WV. Once the Wx gets better Piet listers please stop by. Skip Cinda + Skip Gadd csfog(at)earthlink.net ________________________________________________________________________________
Subject: TACO induction gathering
Date: Jan 25, 2005
Well, I hardly qualify for anything since I haven't yet gotten my Piet in the air, but here's an idea. There is a place at the Gillespie County Airport in Fredricksburg (the Hill Country of Texas) where they have renovated an old hangar and turned it into a hotel and somewhat of a museum. It's called the "Hangar Hotel", info at http://www.swaviator.com/html/issueMJ04/HangarHotel.html , and could perhaps be persuaded to provide a special rate if a half-dozen or more TACOs were to book in an event with planes flying in. I believe they are trying to attract the "classic" crowd such as Piets anyway. It may warrant a field trip to investigate what they have in the beer cooler. I might have to persuade Sterling to help me investigate. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 25, 2005
Sign me up. We might organize a group from North Texas to go to the Hill Country. Mike King TACO Squadron GN-1 77MK Dallas -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Subject: Pietenpol-List: TACO induction gathering Well, I hardly qualify for anything since I haven't yet gotten my Piet in the air, but here's an idea. There is a place at the Gillespie County Airport in Fredricksburg (the Hill Country of Texas) where they have renovated an old hangar and turned it into a hotel and somewhat of a museum. It's called the "Hangar Hotel", info at http://www.swaviator.com/html/issueMJ04/HangarHotel.html , and could perhaps be persuaded to provide a special rate if a half-dozen or more TACOs were to book in an event with planes flying in. I believe they are trying to attract the "classic" crowd such as Piets anyway. It may warrant a field trip to investigate what they have in the beer cooler. I might have to persuade Sterling to help me investigate. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ====== ====== http://www.matronics.com/FAQ/Pietenpol-List.htm http://www.matronics.com/browse/pietenpol-list http://www.matronics.com/digest/pietenpol-list ====== ________________________________________________________________________________
Date: Jan 25, 2005
Subject: Re: TACO induction gathering
Deal me in. Tom Travis ________________________________________________________________________________
Subject: N327BC First Flight Today
Date: Jan 25, 2005
N327BC flew for the first time today. No surprises. The 20 minute trip around the pattern several times only a netted a couple of small adjustments. My friend Don Sirmons from Quincy, Florida had the honors. Don's got 1000's of hours in taildraggers and has test flown countless airplanes after build or re-build including another Aircamper last year. I know - it's like kissing your sister in a way BUT I feel better about doing it this way because he was able to make some observations that I would have probably been unable to process due to the high "pucker factor". He said it flies great, it's in trim, makes good power, and the CG is just right so I have just lowered my workload for the first time I fly it by having these things worked out. It's quite rewarding to complete it and see it fly. I'm sure I'll fly it this weekend after I make a few minor adjustments. To you guys building.... keep it up. It took me 9 years, 6 months and a couple of days to get here! Once it's done it's really cool to see it fly. I'll post some pictures to my website as soon as I can. Bert ________________________________________________________________________________
Date: Jan 25, 2005
Mike, Were you at the Hillsboro airport last Friday. I saw a Piet while I was doing a couple of touch and goes. Jon b -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mike King Subject: RE: Pietenpol-List: TACO induction gathering Sign me up. We might organize a group from North Texas to go to the Hill Country. Mike King TACO Squadron GN-1 77MK Dallas -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Subject: Pietenpol-List: TACO induction gathering Well, I hardly qualify for anything since I haven't yet gotten my Piet in the air, but here's an idea. There is a place at the Gillespie County Airport in Fredricksburg (the Hill Country of Texas) where they have renovated an old hangar and turned it into a hotel and somewhat of a museum. It's called the "Hangar Hotel", info at http://www.swaviator.com/html/issueMJ04/HangarHotel.html , and could perhaps be persuaded to provide a special rate if a half-dozen or more TACOs were to book in an event with planes flying in. I believe they are trying to attract the "classic" crowd such as Piets anyway. It may warrant a field trip to investigate what they have in the beer cooler. I might have to persuade Sterling to help me investigate. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ====== ====== http://www.matronics.com/FAQ/Pietenpol-List.htm http://www.matronics.com/browse/pietenpol-list http://www.matronics.com/digest/pietenpol-list ====== ________________________________________________________________________________
<001e01c50345$9df4f3b0$6601a8c0@Nancy>
Subject: Re: N327BC First Flight Today
Date: Jan 25, 2005
AWESOME!!!!!! so glad to hear it Bert! I'm jealous! how about some pics of the finished project?! DJ ----- Original Message ----- From: Bert Conoly To: pietenpol-list(at)matronics.com Sent: Tuesday, January 25, 2005 6:23 PM Subject: Pietenpol-List: N327BC First Flight Today N327BC flew for the first time today. No surprises. The 20 minute trip around the pattern several times only a netted a couple of small adjustments. My friend Don Sirmons from Quincy, Florida had the honors. Don's got 1000's of hours in taildraggers and has test flown countless airplanes after build or re-build including another Aircamper last year. I know - it's like kissing your sister in a way BUT I feel better about doing it this way because he was able to make some observations that I would have probably been unable to process due to the high "pucker factor". He said it flies great, it's in trim, makes good power, and the CG is just right so I have just lowered my workload for the first time I fly it by having these things worked out. It's quite rewarding to complete it and see it fly. I'm sure I'll fly it this weekend after I make a few minor adjustments. To you guys building.... keep it up. It took me 9 years, 6 months and a couple of days to get here! Once it's done it's really cool to see it fly. I'll post some pictures to my website as soon as I can. Bert ________________________________________________________________________________
Date: Jan 25, 2005
No, it was not me. I was at the Dallas Shrine all day Saturday. You lucky dog. I would like to fly over to Hillsboro. Looks like a neat airport. Mike -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jon Botsford Subject: RE: Pietenpol-List: TACO induction gathering Mike, Were you at the Hillsboro airport last Friday. I saw a Piet while I was doing a couple of touch and goes. Jon b -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mike King Subject: RE: Pietenpol-List: TACO induction gathering Sign me up. We might organize a group from North Texas to go to the Hill Country. Mike King TACO Squadron GN-1 77MK Dallas -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Subject: Pietenpol-List: TACO induction gathering Well, I hardly qualify for anything since I haven't yet gotten my Piet in the air, but here's an idea. There is a place at the Gillespie County Airport in Fredricksburg (the Hill Country of Texas) where they have renovated an old hangar and turned it into a hotel and somewhat of a museum. It's called the "Hangar Hotel", info at http://www.swaviator.com/html/issueMJ04/HangarHotel.html , and could perhaps be persuaded to provide a special rate if a half-dozen or more TACOs were to book in an event with planes flying in. I believe they are trying to attract the "classic" crowd such as Piets anyway. It may warrant a field trip to investigate what they have in the beer cooler. I might have to persuade Sterling to help me investigate. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ====== ====== http://www.matronics.com/FAQ/Pietenpol-List.htm http://www.matronics.com/browse/pietenpol-list http://www.matronics.com/digest/pietenpol-list ====== ====== ====== http://www.matronics.com/FAQ/Pietenpol-List.htm http://www.matronics.com/browse/pietenpol-list http://www.matronics.com/digest/pietenpol-list ====== ________________________________________________________________________________
Date: Jan 26, 2005
Congratulations Bert.. Peter Wonthaggi Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bert Conoly Subject: Pietenpol-List: N327BC First Flight Today N327BC flew for the first time today. No surprises. The 20 minute trip around the pattern several times only a netted a couple of small adjustments. My friend Don Sirmons from Quincy, Florida had the honors. Don's got 1000's of hours in taildraggers and has test flown countless airplanes after build or re-build including another Aircamper last year. I know - it's like kissing your sister in a way BUT I feel better about doing it this way because he was able to make some observations that I would have probably been unable to process due to the high "pucker factor". He said it flies great, it's in trim, makes good power, and the CG is just right so I have just lowered my workload for the first time I fly it by having these things worked out. It's quite rewarding to complete it and see it fly. I'm sure I'll fly it this weekend after I make a few minor adjustments. To you guys building.... keep it up. It took me 9 years, 6 months and a couple of days to get here! Once it's done it's really cool to see it fly. I'll post some pictures to my website as soon as I can. Bert ________________________________________________________________________________
Subject: Berts first flight
Date: Jan 25, 2005
Good goin Bert. Now for the really fun part. Dick ________________________________________________________________________________
Date: Jan 25, 2005
Way to go, Bert!!! There's no feeling like it, is there? Jack Phillips ________________________________________________________________________________
Date: Jan 25, 2005
Bert, Way to go, man that must be exciting. Skip ----- Original Message ----- From: Bert Conoly Subject: Pietenpol-List: N327BC First Flight Today N327BC flew for the first time today. No surprises. The 20 minute trip around the pattern several times only a netted a couple of small adjustments. My friend Don Sirmons from Quincy, Florida had the honors. Don's got 1000's of hours in taildraggers and has test flown countless airplanes after build or re-build including another Aircamper last year. I know - it's like kissing your sister in a way BUT I feel better about doing it this way because he was able to make some observations that I would have probably been unable to process due to the high "pucker factor". He said it flies great, it's in trim, makes good power, and the CG is just right so I have just lowered my workload for the first time I fly it by having these things worked out. It's quite rewarding to complete it and see it fly. I'm sure I'll fly it this weekend after I make a few minor adjustments. To you guys building.... keep it up. It took me 9 years, 6 months and a couple of days to get here! Once it's done it's really cool to see it fly. I'll post some pictures to my website as soon as I can. Bert ________________________________________________________________________________
Date: Jan 25, 2005
Dick, Thanks. Yes I am planning to be at SNF this spring. Skip Great to hear from you again. Hope to se you at SNF again. Dick ________________________________________________________________________________
Date: Jan 25, 2005
Bert, A big CONGRATULATIONS to you !! Well Done !! You did the right thing having Don do the first flight. Seeing your ship in the air will pale by comparison, when you are at the controls. Best of Luck !! Chuck G. ________________________________________________________________________________
Date: Jan 25, 2005
I heard from the owner of this one again this morning. The guy who said he would take it "couldn't secure financing" so the plane is on the market again. Here are the other pictures the owner sent me: http://pg.photos.yahoo.com/ph/wb0tmc/album?.dir=/1827&.src=ph&.tok=pha_vaCBx j7VZ7QS Steve Ruse Dallas, TX -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Steve Ruse Subject: Re: Pietenpol-List: Another Piet, actually a GN-1 for sale I called and spoke to the owner of this one for about 30 minutes on Saturday. Sounds like it is a good airplane. However, he e-mailed me this morning and said that someone came out and looked at the plane Sunday, walked around it once, and said he'd take it pending a pre-buy. Still, no cash has traded hands as far as I know, but it might already be spoken for. Steve Ruse Dallas, TX Quoting Michael D Cuy : > Can be seen if you search "Pietenpol" under barnstormers.com > > Photo enclosed. > > Mike C. > > > PIETENPOL $10,000 COME AND GET IT Pietenpol GN1-Aircamper > Expermential class, built in 1981 flown regularly except the past year, > only flown twice in past 12 month, That't the reason for the sale, Have to > many airplanes. Wife says 2 is enough. C-85 continantial engine less that > 600 TTA&E. Needs annual, but it is airworthy. Have all log books and > records since new Price $10,000 without annual Jan. 18, 2005 call > 731-225-5475 or 731-693-4041 West Tennessee. Contact James Fairchild - > located Pinson, TN Usa Telephone: 731-988-5288 or 731-424-5426 Posted > January 20, 2005 Show all Ads posted by this Advertiser Recommend This > Ad to a Friend Send a Message -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Subject: Lift strut angle
Date: Jan 26, 2005
Group, I am starting to make the fuselage brackets for the landing gear (split axle) and have a question regarding the tab that the wing lift strut attaches to. The plans say bend the tab up 20 degrees. I drew a diagram on some graph paper with a vertical measurement of 46" (fuselage 24" plus cabanes 22") and a horizontal measuremaent of 80" (from the cabane out to the spar bracket). This gives me an angle of 30 degrees. Am I measuring something wrong, and is the angle of the tab critical ? Only want to make these things once :-) Congratulations Bert, Rod Wooller Chidlow Australia ( Three and a half years in ) ________________________________________________________________________________
Date: Jan 26, 2005
Rod, My Jim Wills plans show 28 degrees. Cheers Peter. Wonthaggi, Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of rod wooller Subject: Pietenpol-List: Lift strut angle Group, I am starting to make the fuselage brackets for the landing gear (split axle) and have a question regarding the tab that the wing lift strut attaches to. The plans say bend the tab up 20 degrees. I drew a diagram on some graph paper with a vertical measurement of 46" (fuselage 24" plus cabanes 22") and a horizontal measuremaent of 80" (from the cabane out to the spar bracket). This gives me an angle of 30 degrees. Am I measuring something wrong, and is the angle of the tab critical ? Only want to make these things once :-) Congratulations Bert, Rod Wooller Chidlow Australia ( Three and a half years in ) ________________________________________________________________________________
Subject: Re: Lift strut angle
Date: Jan 26, 2005
I made mine right to the plans and after final assy , my tabs weren't right on the centerline of the strut. The plans also say that you need some play in the holes to avoid side stresses on the bolt and "chrystalizing" walt evans NX140DL ----- Original Message ----- From: "rod wooller" <rodwooller(at)hotmail.com> Subject: Pietenpol-List: Lift strut angle > > Group, > > I am starting to make the fuselage brackets for the landing gear (split > axle) and have a question regarding the tab that the wing lift strut > attaches to. The plans say bend the tab up 20 degrees. > I drew a diagram on some graph paper with a vertical measurement of 46" > (fuselage 24" plus cabanes 22") and a horizontal measuremaent of 80" (from > the cabane out to the spar bracket). > This gives me an angle of 30 degrees. > Am I measuring something wrong, and is the angle of the tab critical ? Only > want to make these things once :-) > > Congratulations Bert, > > Rod Wooller > Chidlow > Australia ( Three and a half years in ) > > ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: torque values
Date: Jan 26, 2005
Can someone please give me the torque values for 7/16 fine and 3/8 fine aircraft grade bolts? thanks!! Douwe douweblumberg(at)earthlink.net ________________________________________________________________________________
Date: Jan 26, 2005
Subject: Re: Raising the wing
I was going to post this on the "lift strut angle" thread but decided not to hijack that thread. I am trying to determine all of the ramifications of raising the wing on N444MH, Howard Henderson's plane which I own. It appears that when I raise the wing 2" (is that not a common "raise" for the wing?) I will need to redo the fuel line, the cabane struts, and the cabane strut wires, unless I go with the forward hard braces. I will need to lengthen the aileron cables, or effectively lengthen them with some sort of "link" at the controls. Now, when you raise the wing, does not the angle of the lift struts change? Or does the raising of the wing also require different lift struts? Anyone on the list raise the wing of a completed plane? Should I just live with crunching myself up to enter the cockpit? Should I have surgery and change MY geometry? (Too many questions....) ===== Larry Nelson Springfield, MO Beechcraft Bonanza V-35B N2980A Pietenpol Air Camper N444MH 1963 GMC 4106-1618 SV/ Spirit of America ARS WB0JOT ________________________________________________________________________________
Date: Jan 26, 2005
Rod, The angle is fairly critical and should be in line with the centerline of the strut, otherwise it imparts bending moments that can jack up the stresses unnecessarily. I didn't build that type of gear on mine (I used the straight axle undercarriage with wire wheels), but I wouldn't be surprised for this to be a mistake in the plans - there are plenty of mistakes. Go with your own geometry - make measuremetns of the parts you have and align the angle with your struts. Any variations you have made in fuselage width, cabane strut length, or position of the lift strut attach points on the wing will affect the angle. For what it's worth, on mine, with cabanes 2-1/2" longer than plans, my angle was right at 30 degrees. Jack Phillips, PE Sr. Manager, Disposables Product Development Clinical Technologies and Services Cardinal Health Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of rod wooller Subject: Pietenpol-List: Lift strut angle Group, I am starting to make the fuselage brackets for the landing gear (split axle) and have a question regarding the tab that the wing lift strut attaches to. The plans say bend the tab up 20 degrees. I drew a diagram on some graph paper with a vertical measurement of 46" (fuselage 24" plus cabanes 22") and a horizontal measuremaent of 80" (from the cabane out to the spar bracket). This gives me an angle of 30 degrees. Am I measuring something wrong, and is the angle of the tab critical ? Only want to make these things once :-) Congratulations Bert, Rod Wooller Chidlow Australia ( Three and a half years in ) ________________________________________________________________________________
Subject: Raising the wing
Date: Jan 26, 2005
If you raise the wing, you will need to make new lift struts as well as new cabanes. All the other things you mentioned must be changed as well (fuel lines, aileron cables, roll wires). The roll wire fittings should also be changed if the angle of the wires changes significantly, but I doubt you will be changing it that much. The diagonal struts that run from the forward cabanes down to the engine mount must be changed as well (unless N444MH uses the bracing wires on the right side of the cockpit for fore and aft bracing. Jack Phillips -----Original Message----- I was going to post this on the "lift strut angle" thread but decided not to hijack that thread. I am trying to determine all of the ramifications of raising the wing on N444MH, Howard Henderson's plane which I own. It appears that when I raise the wing 2" (is that not a common "raise" for the wing?) I will need to redo the fuel line, the cabane struts, and the cabane strut wires, unless I go with the forward hard braces. I will need to lengthen the aileron cables, or effectively lengthen them with some sort of "link" at the controls. Now, when you raise the wing, does not the angle of the lift struts change? Or does the raising of the wing also require different lift struts? Anyone on the list raise the wing of a completed plane? Should I just live with crunching myself up to enter the cockpit? Should I have surgery and change MY geometry? (Too many questions....) ===== Larry Nelson ________________________________________________________________________________
Date: Jan 26, 2005
Subject: Bellcrank question
Yes, I know I need to just shutup and build it to the plans but I would just like everyone's opinion on this one. On the plans the bellcrank is made with two holes on the top and two holes on the bottom with four shackles (at $8.00 each) directly connecting all front and back elevator control cables. In the archives people complain about their elevator cables going slack. In addition to saying this is normal people claim that the solution is to have the cables connect to the bellcrank in the middle, even with the center of rotation. But no one offers a method of accomplishing this. Well here is one way to do it and simplify the design as well. Just dill one hole at the top and bottom in the center. Most Piet belllcranks I have seen do not follow the plans and use short metal straps with clevis pins to connect the bellbrank holes to the control cables with maybe a shackle or two in between. Just use four short metal straps at each end connected by a single clevis pin, two pointing forward and two pointing back. Cheap, easy, simplier, don't see how it would offer less strength. Sorry for the long post and tell me where I am thinking wrong here. -- Rick Holland ________________________________________________________________________________
Date: Jan 26, 2005
Larry I can understand your problem I think! I am 6'4" tall and could NOT get into the cockpit without the wing in place. Looking at the access issue I simply left off the tail end of the centre section behind the rear spar. I know some people have put this part on a hinge so they can swing it up out of the way. If you have the 3 piece wing this might be a simpler solution. I also built mine as a single place as I had to move the instrument panel ahead 4 inches. If I had been starting from scratch I would have stretched to front part of the fuselage about 6 inches and left it as a 2 place but I had bought a partly built project from a estate so removing the front cockpit was way easier, and with only 65 hp this way I don't have to consider the extra weight of a passenger. Anyway "BLACK PIET" will hopefully fly in a month. It is mostly Black with white trim and wing top accents. 65 hp Continental Narco radio, C transponder, registered as a ultralight so controlled airspace is easier Les in Calgary > > >I was going to post this on the "lift strut angle" >thread but decided not to hijack that thread. > >I am trying to determine all of the ramifications of >raising the wing on N444MH, Howard Henderson's plane >which I own. > >It appears that when I raise the wing 2" (is that not >a common "raise" for the wing?) I will need to redo >the fuel line, the cabane struts, and the cabane strut >wires, unless I go with the forward hard braces. I >will need to lengthen the aileron cables, or >effectively lengthen them with some sort of "link" at >the controls. > >Now, when you raise the wing, does not the angle of >the lift struts change? Or does the raising of the >wing also require different lift struts? > >Anyone on the list raise the wing of a completed >plane? Should I just live with crunching myself up to >enter the cockpit? Should I have surgery and change MY >geometry? (Too many questions....) > >===== >Larry Nelson >Springfield, MO >Beechcraft Bonanza V-35B N2980A >Pietenpol Air Camper N444MH >1963 GMC 4106-1618 >SV/ Spirit of America >ARS WB0JOT > >__________________________________________________ > > ________________________________________________________________________________
Subject: Accurate Wood List
Date: Jan 26, 2005
I've just received my plans and need to order the wood for a long bodied three piece wing aircamper. I'll be ordering from Aircraft Spruce and shipping to Europe so I want to avoid any mistakes. I've seen a wood list mentioned in the archives (Sep 04) and would appreciate it if someone would e-mail me a copy. Regards Derek Doyle ________________________________________________________________________________
Date: Jan 26, 2005
Subject: Varnished Wings
Hello Gang, I'm sure this has come up in the past, though I can't get a hit on the search engine. Has anyone had experience with varnished wings? I just figured up the paint cost for the plane I am building and nearly had heart failure! A friend of mine knew of a Piet that had varnished wings and that it was flying and holding up well. Does anyone know of this plane and how I can contact the builder? I think the varnishing would be much cheaper than the painting process. The Helsman Spar Urethane I am using on the wood has some UV protection, but is it enough? Has anyone added alumn. powder to the varnish to improve the UV protection? I know, questions, questions... Thanks and best wishes to all. Doc __________________________________ http://info.mail.yahoo.com/mail_250 ________________________________________________________________________________
Date: Jan 26, 2005
Ok it's just piling on at this point, but here's my congrats also! There can't be too much reinforcement when it comes to a first flight. Mark Hodgson ________________________________________________________________________________ ETAsAhQIOZzt8HtZ00kvZzWaLLbd6FRH+AIUT5tQtiqUBFhzMQEbJo+4ikKAyE0=
Date: Jan 26, 2005
Subject: Brodhead
Hello: We have to pick our summer vacation in the next week or so (where I work) The last B.Head newsletter didn't have any dates for the fly in. Is it the weekend before Oshkosh as usual? Does any ine know? Thanks. ________________________________________________________________________________
From: "Doyle Combs" <doylecombskeith(at)earthlink.net>
Date: Jan 26, 2005
Galen, you might want to check out latex paint. I clearcoated the latex and it looks pretty good and not soft as it was before. > [Original Message] > From: Galen Hutcheson <wacopitts(at)yahoo.com> > To: > Date: 1/26/2005 11:50:44 AM > Subject: Pietenpol-List: Varnished Wings > > > Hello Gang, > > I'm sure this has come up in the past, though I can't > get a hit on the search engine. Has anyone had > experience with varnished wings? I just figured up > the paint cost for the plane I am building and nearly > had heart failure! A friend of mine knew of a Piet > that had varnished wings and that it was flying and > holding up well. Does anyone know of this plane and > how I can contact the builder? I think the varnishing > would be much cheaper than the painting process. The > Helsman Spar Urethane I am using on the wood has some > UV protection, but is it enough? Has anyone added > alumn. powder to the varnish to improve the UV > protection? I know, questions, questions... > > Thanks and best wishes to all. > > Doc > > > > __________________________________ > http://info.mail.yahoo.com/mail_250 > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2005
Hi Doyle, I've been following the discussions on latex paint and am impressed. The varnishing interests me because the finished product would have a very old appearing finish. I thought it would go very well with the plane's antique history. I am definately going to look at the latex paint before I pay outlandish prices for A/C grade paint. It seems like anything aviation has to cost 3 times as much as non-aviation materials. Thank goodness we have the experimental class to do just that, EXPERIMENT! Thanks. Galen (aka Doc) --- Doyle Combs wrote: Galen, you might want to check out latex paint. I > clearcoated the latex and > it looks pretty good and not soft as it was before. > > > > > > > > > > > __________________________________ > more. > > http://info.mail.yahoo.com/mail_250 > > > > > > > > > > > > > > > > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://info.mail.yahoo.com/mail_250 ________________________________________________________________________________
Date: Jan 26, 2005
Let me add my straw to the bundle and congrats on the first flight. Even though you didn't make that first flight yourself (and each pilot has to know his limitations and to know when it is wise to let someone else make the first flight) it has to be a rush to see an airplane that you built with your own hands fly so successfully. It makes us all (those who still labor over dreams of someday flying our creations) envious and yet proud that you have accomplished what you set out to do 9 years ago. Best wishes and always "fly safe." Doc --- "Hodgson, Mark O" wrote: > O" > > Ok it's just piling on at this point, but here's my > congrats also! > There can't be too much reinforcement when it comes > to a first flight. > > Mark Hodgson > > > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > ________________________________________________________________________________
Subject: Re: Varnished Wings
Date: Jan 26, 2005
About 20 years ago, I made up some samples of fabric coverings to test for durability, ease of fabrication, cost of the project, etc. One of the samples was varnished with a brand that claimed some built-in UV protection. The samples were left in the backyard for a couple of years; the sun, the rain and a few of the neighbors' pets had a go at them. All held up well. The varnished sample was relatively inexpensive, but 2 coats of it weighed more than 9 coats of dope; also, I couldn't get the tapes to look right (and I tried both gluing them on and varnishing them on). Partial to the aesthetics of the "varnished look," I finally went with clear dope, mixing in a little color on the 8th coat. There's no UV protection, but the combination of a hangar, the Northeast's numerous sunless days, and everyday nightfall have combined to keep the fabric in pretty good shape at the 15 year mark. Jim Malley ----- Original Message ----- From: "Galen Hutcheson" <wacopitts(at)yahoo.com> Subject: Pietenpol-List: Varnished Wings > > Hello Gang, > > I'm sure this has come up in the past, though I can't > get a hit on the search engine. Has anyone had > experience with varnished wings? I just figured up > the paint cost for the plane I am building and nearly > had heart failure! A friend of mine knew of a Piet > that had varnished wings and that it was flying and > holding up well. Does anyone know of this plane and > how I can contact the builder? I think the varnishing > would be much cheaper than the painting process. The > Helsman Spar Urethane I am using on the wood has some > UV protection, but is it enough? Has anyone added > alumn. powder to the varnish to improve the UV > protection? I know, questions, questions... > > Thanks and best wishes to all. > > Doc > > > __________________________________ > http://info.mail.yahoo.com/mail_250 > > ________________________________________________________________________________
Subject: Brodhead
Date: Jan 26, 2005
Leon, The EAA chapter website says July 22 and 23 2005. Skip Is it the weekend before Oshkosh as usual? Does any ine know? > Thanks. > > > > > ________________________________________________________________________________
Subject: Helicopter perfection (off-topic)
Date: Jan 26, 2005
I don't fly RC models and I don't fly choppers, but I just watched a video clip of an RC chopper doing things I didn't think possible. I think DJ would appreciate this one since he's an RC guy. It's several minutes of video so it takes a bit to download (I have cable modem and it took about a minute): http://www.compfused.com/directlink/557/ Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Helicopter perfection (off-topic)
Date: Jan 26, 2005
ahhhh yeas... Alan Szabo. he flies a Raptor 90. I have a Raptor 50. I've flown with him at that field in Vegas a couple years ago. We put night blades (LED's in the tips) on and flew our helicopters at night... loops rools, inverted hovering... even flew through the sprinklers that night. He's a great pilot. DJ ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: Helicopter perfection (off-topic) > > > I don't fly RC models and I don't fly choppers, but I just watched a video > clip of an RC chopper doing things I didn't think possible. I think DJ > would appreciate this one since he's an RC guy. It's several minutes of > video so it takes a bit to download (I have cable modem and it took about > a minute): > > http://www.compfused.com/directlink/557/ > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Date: Jan 27, 2005
DNA: do not archive Its-Bogus: do not forward to list --- MIME Errors --- A message with no text/plain section was received. The entire body of the message was removed. Please resend the email using plaintext formatting. NOTE! This error can also occur when the poster of the message has a specific type of computer virus. This virus WAS NOT forwarded on to the List. The poster should be informed of the potential problem with their system as soon as possible. --- MIME Errors --- ________________________________________________________________________________
Date: Jan 26, 2005
Rod, The angle of the tab is critical, and should be parallel to the lift struts, and have nice clean round holes in them, to attach the lift struts. As for the holes, I much prefer pilot holes, then match drill the finished holes when the lift struts are fitted. I suggest you triple check all your measurements (especially if you change the cabane strut length, or the fuselage width), and use the angle you come up with. The angle is much closer to 30 than it is to 20. While we're on this subject, the 90 angle fittings on the inside calls out for 20 ga. (.035"). Last summer, I changed all four of those angle fittings inside, because they were .035" 1020 steel, and they dimpled into the wood. I replaced them with .063" 4130 steel. On the front cross strap, I also added a 3/16" (#10) bolt up through the 2" cross piece strap, through the White Ash cross strut, because the 2" strap bowed away from the bottom of the fuselage. It was probably caused by the negative G's imposed on the lift struts, as a result of a hard landing. This is somewhat of a common anomaly of the design. I only installed one bolt up through the centerline, but now the 2" strap is showing a gap on the left side. I will add two more 3/16" (#10) bolts for a total of three bolts up through the Ash Cross Strut. I'm talking about the front strap. For the rear cross strap, there is already plenty of bolts going up through the strap into the ash cross piece, with the rudder bar brace, and it is where I mounted the master cylinders pivot points, a couple of inches to each side of the centerline. While flying, I use the 30 angle of the lift struts to attain a 30 bank angle, by keeping them parallel to the ground. Chuck G. NX770CG Wichita KS wishing you Texas Boys could shove some of that 70 weather up this way !! ________________________________________________________________________________
Date: Jan 26, 2005
Second that. The angle shown on your plans will be for a specific case which assumes following the plans to the letter. As Jack says, as soon as you make any change, longer cabanes, positive dihedral, deeper fuselage, wider fuselage, all of the above, that angle will change. There is a Piet for sale here, built some years ago by a pair of airline mechanics, with a 6" wider fuselage among other things. It has flown for some years with an unmodified corvair except for the removal of the cooling fan. Jim Wills plans? Clif Landing gear sitting on fuselage, in jig, waiting for bolts from Wicks. I'm having trouble waiting to turn it over so I can sit in it and make engine noises again! > Rod, > > The angle is fairly critical and should be in line with the centerline > of the strut, otherwise it imparts bending moments that can jack up the > stresses unnecessarily. > I didn't build that type of gear on mine (I used the straight axle > undercarriage with wire wheels), but I wouldn't be surprised for this to > be a mistake in the plans - there are plenty of mistakes. Go with your > own geometry - make measuremetns of the parts you have and align the > angle with your struts. Any variations you have made in fuselage width, > cabane strut length, or position of the lift strut attach points on the > wing will affect the angle. > > For what it's worth, on mine, with cabanes 2-1/2" longer than plans, my > angle was right at 30 degrees. > > Jack Phillips, PE ________________________________________________________________________________
Date: Jan 26, 2005
Subject: Re: Bellcrank question
Rick, I believe the purpose of two holes on top, and two holes on the lower end of the bellcrank, is to offer redundency, in the event of a pin failure. Chuck G. ________________________________________________________________________________
Date: Jan 27, 2005
Thanks guys for all the replies and helpful hints. I'll re-measure everything accurately and make the angle to suit. Thanks again, Rod >From: "rod wooller" <rodwooller(at)hotmail.com> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Lift strut angle >Date: Wed, 26 Jan 2005 16:44:12 +0800 > > > >Group, > >I am starting to make the fuselage brackets for the landing >gear............. > Rod Wooller >Chidlow >Australia ( Three and a half years in ) > > ________________________________________________________________________________
Date: Jan 26, 2005
Thanks for the info Jim, I wonder how one good coat of spar urethane varnish would work. It would cut down on the weight. Perhaps with some alumn. powder mixed in. I haven't priced the clear dope as yet, it may be cheaper than the Poly Stitts stuff I priced. Doc > > > > > > > > __________________________________ > more. > > http://info.mail.yahoo.com/mail_250 > > > > > > > > > > > > > > > > > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > ________________________________________________________________________________
Date: Jan 26, 2005
I don't think any redundancy is gained by the use of four pins. If any one of the four bellcrank pins breaks, elevator control is lost...you can't push a cable. Counter-intuitively, having only two pins would reduce the theoretical probability of failure. Mike Hardaway ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: Bellcrank question > > Rick, > I believe the purpose of two holes on top, and two holes on the lower end of > the bellcrank, is to offer redundancy, in the event of a pin failure. > > Chuck G. > > ________________________________________________________________________________
Date: Jan 26, 2005
<003201c5042f$4f3710b0$6401a8c0@the48194bd3804> If all else fails, use you arms :-) Clif Subject: Re: Pietenpol-List: Bellcrank question > I don't think any redundancy is gained by the use of four pins. If any one > of the four bellcrank pins breaks, elevator control is lost...you can't push > a cable. > Counter-intuitively, having only two pins would reduce the theoretical > probability of failure. > > Mike Hardaway ________________________________________________________________________________
Date: Jan 27, 2005
Subject: Varnished wings--Pietenpol Fly-In
The plane with the varnished wings is owned by Tom Brown. To get his address, email the Brodhead Chapter webmaster by clicking on the link at the bottom of their website. Brodhead Chapter website is: http://www.eaa431.org The Piet Fly-in is July 22-23, 2005. Dick H. ________________________________________________________________________________
Subject: lift strut angle
Date: Jan 27, 2005
Just to add one more data point to the growing pile, the wing lift struts on NX41CC are right at 30 degrees from horizontal, and I believe the wing cabanes are lengthened a bit to raise the wing. But I looked at the geometry in CAD and tried moving the wing back down to stock location and it only reduces the angle a degree or two. Twenty degrees wouldn't seem to be correct in any case that I looked at. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 27, 2005
Subject: Re: Accurate Wood List
Derek I bought a Piet wood kit from Aircraft Spruce. Just before it was ready to ship they called me to say that the rib cap strip was not included in that price and was extra. About this time I found a partly built Piet project so I have never opened the boxes to inventory it, figured it was safer in the crates as it came. I didn't buy the cap strip as I knew I wouldn't need it at that time. Hope this helps. Les >I've just received my plans and need to order the wood for a long bodied >three piece wing aircamper. I'll be ordering from Aircraft Spruce and >shipping to Europe so I want to avoid any mistakes. I've seen a wood list >mentioned in the archives (Sep 04) and would appreciate it if someone >would e-mail me a copy. > >Regards > >Derek Doyle ________________________________________________________________________________
Date: Jan 27, 2005
Subject: Re: Varnished wings--Pietenpol Fly-In
Dick, thanks for that info. I will contact them soon. I hope to make it to Broadhead this year, if all goes well, but I doubt my plane will be ready. Doc > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://mobile.yahoo.com/maildemo ________________________________________________________________________________
Date: Jan 27, 2005
Subject: Re: Pietenpol-List: Lift strut angle Clif wrote: Jim Wills plans? Clif, I believe Rod was referring to the Pietenpol plans modified by Jim Wills, for PFA (UK) approval . I understand those plans have a few modifications including a quick-disconnect for aileron connections (since the majority of UK Piets will only be flown in summer and stored for the winter) and built-up spars (because spar stock is scarce in the UK). There are likely other modifications/corrections, and I believe that variation from any details on those plans must be granted a concession by the PFA (correct me if I'm wrong, anyone who knows better). Bill ________________________________________________________________________________
Subject: Static port
Date: Jan 27, 2005
Hello Fellow Piet pilots Thought I'd pass this one out there, went flying in my plane with the instructor, only to find that the air speed and VSI react as the power setting is changed, it seems I have a problem with the static port. I am currently using a pitot/ static tube, the static tube sits about 4" below the wing with the pitot tube another 2"lower. The front cockpit also has a ASI and Altimeter, these however are not connected to the pilots static system, the front Altimeter reads 100' higher than the rear cockpit, the ASI reads 10mph higher than the rear instruments. My thoughts are to plumb all the instruments to the static system, and then to use an alternate static port, my question is this where would the best place to pick up a reliable static position. To date we have flown 2hrs since the rebuild and everything else seems in order. Thanks Norman Stapelberg South Africa ZS-VJA (121hrs) ________________________________________________________________________________
Date: Jan 27, 2005
Hi Norman, The first question that comes to mind is where are your pitot tube and static tube in relation to the leading edge of the wing? If they are behind the leading edge, 4" is probably not far enough away from the wing to truly read "Free-stream" air. If you look at other similar speed airplanes, such as a J-3 Cub, you will find that the pitot tube is located considerably lower than that - about 12" as I recall from my old Cub. It is a good idea to use a static port, rather than just leaving the instruments open to the air behind the instrument panel. Rarely does the cockpit ambient pressure match the actual static pressure, with the results that the instruments don't read accurately. But the location of this port must be carefully chosen to make sure it is not influenced by the airflow around the airplane. Putting the port out ahead of the lead edge of the wing, and well outboard of the propwash is usually a good choice. In the book "Flight Testing Homebuilt Aircraft" by Vaughan Askue (http://www.amazon.com/exec/obidos/tg/detail/-/0813813085/qid=1106857699 /sr=1-1/ref=sr_1_1/102-2003434-0024117?v=glance&s=books ) there is a whole chapter on selecting a location for the pitot-static system, and methods to calibrate it. Most pitot tubes don't read accurately at high angles of attack, generating airspeed readings considerably slower than the true airspeed. One of the tips he gives in the book is to chamfer the edges of the pitot tube, creating a slight funnel shape which tends to promote much more acurate indications. When I test flew my Pietenpol (with a chamfered pitot tube), I got an indicated airspeed at stall of about 42 mph. I was disturbed by comparing this to the speeds others were quoting (stall speeds as low as 29 mph), until I started running some calculations. For my plane to stall at 42 mph requires a maximum lift coefficient of about 1.8, whcih is quite reasonable for an airfoil made up by an amateur designer like BHP. For even a light weight Pietenpol to stall at 29 mph would require a lift coefficient of over 3.2, which is totally unrealistic without leading edge slats and double-slotted flaps. The only conclusion is that the airspeed indications are faulty and the actual airspeeds at stall are closer to 40 mph. Jack Phillips NX899JP -----Original Message----- Hello Fellow Piet pilots Thought I'd pass this one out there, went flying in my plane with the instructor, only to find that the air speed and VSI react as the power setting is changed, it seems I have a problem with the static port. I am currently using a pitot/ static tube, the static tube sits about 4" below the wing with the pitot tube another 2"lower. The front cockpit also has a ASI and Altimeter, these however are not connected to the pilots static system, the front Altimeter reads 100' higher than the rear cockpit, the ASI reads 10mph higher than the rear instruments. My thoughts are to plumb all the instruments to the static system, and then to use an alternate static port, my question is this where would the best place to pick up a reliable static position. To date we have flown 2hrs since the rebuild and everything else seems in order. Thanks Norman Stapelberg South Africa ZS-VJA (121hrs) ________________________________________________________________________________
Subject: Re: Static port
Date: Jan 27, 2005
I took a shot at it, and guess got lucky. On the bottom of the rear instrument panel, made a fitting with a small hole in it, to put the static tube thru the ply, kind of down pointing at my right shin. No real variations, and airspeed checks with GPS. easy installation too, 12"of plastic tubing. Added a front ASI later and didn't add to the static system, and it has some variations. walt evans NX140DL ----- Original Message ----- From: "Norman Stapelberg" <norshel(at)mweb.co.za> Subject: Pietenpol-List: Static port > > Hello Fellow Piet pilots > > Thought I'd pass this one out there, went flying in my plane with the > instructor, only to find that the air speed and VSI react as the power > setting is changed, it seems I have a problem with the static port. > > I am currently using a pitot/ static tube, the static tube sits about 4" > below the wing with the pitot tube another 2"lower. The front cockpit > also has a ASI and Altimeter, these however are not connected to the > pilots static system, the front Altimeter reads 100' higher than the > rear cockpit, the ASI reads 10mph higher than the rear instruments. > > My thoughts are to plumb all the instruments to the static system, and > then to use an alternate static port, my question is this where would > the best place to pick up a reliable static position. > > To date we have flown 2hrs since the rebuild and everything else seems > in order. > > Thanks > > Norman Stapelberg > South Africa > ZS-VJA (121hrs) > > ________________________________________________________________________________
Date: Jan 28, 2005
In a message dated 1/26/05 11:29:50 PM Central Standard Time, bike.mike(at)verizon.net writes: << I don't think any redundancy is gained by the use of four pins. If any one of the four bellcrank pins breaks, elevator control is lost...you can't push a cable. Counter-intuitively, having only two pins would reduce the theoretical probability of failure. Mike Hardaway >> Mike, Bernard Pietenpol was a master of design. If he put four pins in there, then there was some very good reason for it. Sometimes, the purpose of a design is not readily evident. The plane can certainly be flown if only one half of the elevators (flippers) is operational. Power setting can also be used for pitch control. Chuck G. ________________________________________________________________________________
Date: Jan 28, 2005
If we think a moment: there are 4 cables going back as the elevators are separate each side so 2 for the top and 2 for the bottom, then of course there are 2 cables going forward to the stick, and then you might have 2 cables going forward for trim if you have it. I don't have the plans right in front of me, they are in the shop; but that might total to 6 holes (or 8 holes with trim) for all the clevis that you might need, or maybe just 4 holes if you double up the cables going back onto the same clevis. > >In a message dated 1/26/05 11:29:50 PM Central Standard Time, >bike.mike(at)verizon.net writes: > ><< I don't think any redundancy is gained by the use of four pins. If any one > of the four bellcrank pins breaks, elevator control is lost...you can't push > a cable. > Counter-intuitively, having only two pins would reduce the theoretical > probability of failure. > > Mike Hardaway >> > >Mike, >Bernard Pietenpol was a master of design. If he put four pins in there, then >there was some very good reason for it. Sometimes, the purpose of a design >is not readily evident. The plane can certainly be flown if only one half of >the elevators (flippers) is operational. Power setting can also be used for >pitch control. > >Chuck G. > > ________________________________________________________________________________
Subject: Pietenpol Projects in the Nashville area?
Date: Jan 28, 2005
I'll be in Nashville next week on business and wondered if there are any Piets or Pietenpol projects in the Nashville TN area? Thanks, Jim in Plano (where there's a Piet project ON THE GEAR!!!! woohoo!!!!) ________________________________________________________________________________
Subject: How to License your Homebuilt Aircraft
Date: Jan 28, 2005
This is an announcement that www.HomebuiltHELP.com has just completed production, and is proud to announce the release of their latest DVD video presentation: "How to License Your Homebuilt Aircraft". (for the U.S.) To the best of my knowledge, this is the first comprehensive DVD video that explains in detail the complete licensing process for experimental amateur built aircraft - showing what/how to fill out the forms, and also demonstrating new capabilities such as reserving an N number by going online and using the FAA website. I'll leave it at that, as full details are available at the www.HomebuiltHELP.com website. In keeping with the list's guidelines, this will be the ONLY post on this matter, and I hope it was valuable to some Pietenpol builders. Thanks! Jon ________________________________________________________________________________
Date: Jan 28, 2005
In a message dated 1/25/2005 7:26:23 PM Central Standard Time, bconoly(at)earthlink.net writes: To you guys building.... keep it up. It took me 9 years, 6 months and a couple of days to get here! Once it's done it's really cool to see it fly. I'll post some pictures to my website as soon as I can. Bert Congratulations Bert, it's got to be a great day and a wonderful sense of accomplishment. Mine is not far behind. Taxi tests revealed some problems that are just about corrected. They involved wheel bearings and bad geometry between the tailwheel control arms and the rudder conrols arms. Look forward to the photos. Don H. ________________________________________________________________________________
Date: Jan 29, 2005
Each pin and clevis has it's own job to do distinct from all the others. Any one breaks and it's doo-doo time. The rear cables are doubled on one clevis on the plans thus 4 holes. Using two would mean opening up two of the clevis( clevie?) to go outside the others. This would mean a longer pin, increasing bending loads on it. This in turn leads to the necessity of a larger pin which means a larger clevis which might be too big for the cable loop, heavier also. Clif ----- Original Message ----- From: Les Schubert To: pietenpol-list(at)matronics.com Sent: Friday, January 28, 2005 6:48 AM Subject: Re: Pietenpol-List: Bellcrank question If we think a moment: there are 4 cables going back as the elevators are separate each side so 2 for the top and 2 for the bottom, then of course there are 2 cables going forward to the stick, and then you might have 2 cables going forward for trim if you have it. I don't have the plans right in front of me, they are in the shop; but that might total to 6 holes (or 8 holes with trim) for all the clevis that you might need, or maybe just 4 holes if you double up the cables going back onto the same clevis. ________________________________________________________________________________
Date: Jan 29, 2005
Mike, Hillsboro is a nice, small airport. Gives extra discount on already low priced fuel on Saturdays. Later this spring come down to PWG (McGregor) and have breakfast with Chapter 59. We do it on the first Saturday of each month. Next week is the first Saturday in February. Jon b -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mike King Subject: RE: Pietenpol-List: TACO induction gathering No, it was not me. I was at the Dallas Shrine all day Saturday. You lucky dog. I would like to fly over to Hillsboro. Looks like a neat airport. Mike -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jon Botsford Subject: RE: Pietenpol-List: TACO induction gathering Mike, Were you at the Hillsboro airport last Friday. I saw a Piet while I was doing a couple of touch and goes. Jon b -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mike King Subject: RE: Pietenpol-List: TACO induction gathering Sign me up. We might organize a group from North Texas to go to the Hill Country. Mike King TACO Squadron GN-1 77MK Dallas -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Subject: Pietenpol-List: TACO induction gathering Well, I hardly qualify for anything since I haven't yet gotten my Piet in the air, but here's an idea. There is a place at the Gillespie County Airport in Fredricksburg (the Hill Country of Texas) where they have renovated an old hangar and turned it into a hotel and somewhat of a museum. It's called the "Hangar Hotel", info at http://www.swaviator.com/html/issueMJ04/HangarHotel.html , and could perhaps be persuaded to provide a special rate if a half-dozen or more TACOs were to book in an event with planes flying in. I believe they are trying to attract the "classic" crowd such as Piets anyway. It may warrant a field trip to investigate what they have in the beer cooler. I might have to persuade Sterling to help me investigate. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ====== ====== http://www.matronics.com/FAQ/Pietenpol-List.htm http://www.matronics.com/browse/pietenpol-list http://www.matronics.com/digest/pietenpol-list ====== ====== ====== http://www.matronics.com/FAQ/Pietenpol-List.htm http://www.matronics.com/browse/pietenpol-list http://www.matronics.com/digest/pietenpol-list ====== ________________________________________________________________________________
Date: Jan 29, 2005
Hi Jack Yep static is about 4" below the leading edge and in line, the pitot pipe is another 2" lower than the static pipe and is about a 1/2"forward of the leading edge. I copied the pitot/ static system that was given in the KR manual. Well it don't seem to work for me, will have to try another system, I pulled in a tube to the front instruments static's now just need a reliable source for the static. The current position is well clear of the prop wash as it is close to the wing attachment. I'll let you know how things progress, I am going to make a new system of tubes but longer. Thanks Norman ________________________________________________________________________________
Date: Jan 29, 2005
WEIGHT10, WEIGHT15 [15] You are quite correct that the Aircraft Spruce Piet wood kid does not include the cap strip material for the wings. (although cap strip material for the tail group is included.) I found this out the hard way. When my wood kit arrived (minus any 1/2 inch by =BC inch cap strips), I called and got connected with a nice young lady who looked up the pull sheet (which I had not received with the order) and informed me that cap strip was extra at $8 per foot. (Turns out she was wrong on the $8 per foot part.) When I got over my shock I checked out the catalogue which states that rib and spar stock is supplied S2S and are to be run through a table saw and ripped to the appropriate widths. When I called back to check this out, the phone rep checked with the shop guys and came back with =93we think the 3 inch by 1/2 inch by 7 foot boards are to be ripped for the cap strips.=94 Shortly after ripping these boards for cap strips, I received the pull sheet and found out that these newly deceased boards are the aileron spars. Oh well! Good lesson to pass on I guess. Tom Stinemetze McPherson, Kansas ____ | ____ \8/ / \ =93I bought a Piet wood kit from Aircraft Spruce. Just before it was ready to ship they called me to say that the rib cap strip was not included in that price and was extra.=94 ________________________________________________________________________________
From: "Malcolm Morrison" <morrisons5(at)adelphia.net>
Subject: Updates on my web site
Date: Jan 29, 2005
Hi all Just posted a couple of updates on my web site showing brake pedals, wings, engine, and carbs. http://users.adelphia.net/~morrisons5/piet.html Malcolm ________________________________________________________________________________
Subject: Off topic
Date: Jan 31, 2005
Hi All, Check this out. I might ditch the Piet and get one of these ! :) http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category26442&item4522969691&rd1&ssPageNameWDVW You might note he already has 2 bids on it . Mike Green Romsey Victoria AUSTRALIA ________________________________________________________________________________
Subject: Piet in museum
Date: Jan 31, 2005
There is a Piet in the air museum in Liberal, Kansas. Interesting white paint scheme. Pictures at http://www.cityofliberal.com/airmuseum/aircraft/homebuilt/index.html Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 31, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Japanese Pietenpol Air Camper
Thru another builder who contacted me, I learned that a glider pilot/mechanic named Mita San near Tokyo built an Air Camper years ago and never finished it. He intends to someday but for now has built this yellow electric r/c Piet which he has flown off the sand beaches of Tokyo bay ! Tora Tora Pietenpol Air Camper ! Mike ________________________________________________________________________________
Subject: Leading Edge Ply
Date: Feb 01, 2005
Hi Guys, I have just had my first major woodworking cock up. I have been trying to glue the leading edge ply to one of the outer wing sections of a three piece wing. I started by making up the whole length from four pieces of ply scarfe jointed together. I loosely attached the top of the ply to the upper spar of the wing and applied many wet towels along the leading edge bend line. I thought of gluing it all at one time but decided to do the top first, let that dry and then do the bottom. I glued the top part, let it dry and I got as far as applying the glue to the bottom part yesterday afternoon but could not get the ply to fit around the LE properly. I presume I had not bent it enough. It was becoming a real mess so I removed the ply totally from top and bottom and will have to start again. The glue works well. I will have a lot of cleaning up to do on the wing rib leading edges! How did you guys do yours? did you glue it all as one piece? or one top and another on the bottom? or in pieces to butt joint at the ribs?...... Any tips or a blow by blow account of how you managed it would be gratefully received? Many thanks Peter Wonthaggi Australia http://www.cpc-world.com ________________________________________________________________________________
Subject: Re: Leading Edge Ply
Date: Jan 31, 2005
Peter, I borrowed someone elses idea with cutting a plastic jug (either Chlorox or a white jug from cat litter) into strips about 3/4" wide on the band saw. After glueing with T-88 simply stapled through the strips into the ply, into the rib. Next day , the glue doesn't stick to the plastic, and mainly the plastic stops the staples from making a dent in the ply. When using the light staples only 1/4' long, the strips could be grabbed at the end and pulled in a long strip to remove the staples. didn't scarff the joint, just cut the length to center on a rib center where necessary. walt evans NX140DL ----- Original Message ----- From: Peter W Johnson To: pietenpol-list(at)matronics.com Sent: Monday, January 31, 2005 8:28 PM Subject: Pietenpol-List: Leading Edge Ply Hi Guys, I have just had my first major woodworking cock up. I have been trying to glue the leading edge ply to one of the outer wing sections of a three piece wing. I started by making up the whole length from four pieces of ply scarfe jointed together. I loosely attached the top of the ply to the upper spar of the wing and applied many wet towels along the leading edge bend line. I thought of gluing it all at one time but decided to do the top first, let that dry and then do the bottom. I glued the top part, let it dry and I got as far as applying the glue to the bottom part yesterday afternoon but could not get the ply to fit around the LE properly. I presume I had not bent it enough. It was becoming a real mess so I removed the ply totally from top and bottom and will have to start again. The glue works well. I will have a lot of cleaning up to do on the wing rib leading edges! How did you guys do yours? did you glue it all as one piece? or one top and another on the bottom? or in pieces to butt joint at the ribs?...... Any tips or a blow by blow account of how you managed it would be gratefully received? Many thanks Peter Wonthaggi Australia http://www.cpc-world.com ________________________________________________________________________________
Date: Jan 31, 2005
Subject: continental A65in "Black Piet"
I was sitting in my almost completed Piet today running the engine and observed that the engine seems to go rich as you come off idle up to about 1100 rpm, over that it then revs up nicely. idles fine at about 600-700 rpm with no indication of overrichness. Starts quite nicely with the throttle closed with one shot of prime. The engine was at about 60 F and the outside air temp was about 35 F when it started. I assume that this flat spot and slight black smoke as you speed it up is a indication of incorrect float level. I have installed the new delrin needle with the recommended float weight change. I would appreciate any sage advice from someone with more experience than I. I should be ready to test fly in a week or so if I don't have huge issues to deal with. Just need to final fit the wings, do the weight and balance final, and take it to the airport. I have a experience tail dragger pilot lined up for the first flights ________________________________________________________________________________
Subject: Re: continental A65in "Black Piet"
Date: Jan 31, 2005
Les. I've seen this too. It seems to be a function of temperature. It doesn't do it if the ambient temp is over 50 F. I've heard some folks say this is common with A-65s. I'm interested in responses here , too. I'm still waiting on some reasonable winds. All dressed up with no where to go! BC http://bconoly.tripod.com/ ----- Original Message ----- From: "Les Schubert" <leskarin(at)telus.net> Subject: Pietenpol-List: continental A65in "Black Piet" > > I was sitting in my almost completed Piet today running the engine and > observed that the engine seems to go rich as you come off idle up to about > 1100 rpm, over that it then revs up nicely. idles fine at about 600-700 rpm > with no indication of overrichness. Starts quite nicely with the throttle > closed with one shot of prime. The engine was at about 60 F and the outside > air temp was about 35 F when it started. I assume that this flat spot and > slight black smoke as you speed it up is a indication of incorrect float > level. I have installed the new delrin needle with the recommended float > weight change. I would appreciate any sage advice from someone with more > experience than I. I should be ready to test fly in a week or so if I don't > have huge issues to deal with. Just need to final fit the wings, do the > weight and balance final, and take it to the airport. I have a experience > tail dragger pilot lined up for the first flights > > ________________________________________________________________________________
Subject: COntinental A65's on a cold morning
Date: Feb 01, 2005
Bert and Les, I think what you are seeing is pretty common. Continental A65's don't have an "acceleration pump" on the throttle to help atomize extra fuel for acceleration. When the engine is cold, a sudden opening of the throttle tends to suck liquid fuel into the throat of the carburetor, with the result that the engine sort of chokes and gasps before beginning to accelerate. It can be quite disconcerting particularly if you suddenly need a burst of power, to shove the throttle in and have the engine sit there spluttering for a second or two before beginning to speed up. It definitely occurs on my Pietenpol and I remember the same thing happening with my old J-3 Cub. You just need to learn to advance the throttle very slowly on a cold day. I've never had the engine quit from this, but it sounds like it is about to quit. Jack Phillips ________________________________________________________________________________
Subject: Re: COntinental A65's on a cold morning
Date: Feb 01, 2005
COntinental A65's on a cold morningIt is more serious than you think. Lee Hilbert, Buck's #3 son, had his A-65 quit because he went from idle to power about 2 weeks ago. Temp was about 5=B0F. He landed, dead stick on Lake Delavan only to sink thru a weak spot in the ice. Ruined his entire day and the WIS DNR finded him $440 for polluting the lake. Cy Galley - Aeronca Aviators Club Newsletter Editor & EAA TC www.aeronca.org Actively supporting Aeroncas every day ----- Original Message ----- From: Phillips, Jack To: Pietenpol-List Sent: Tuesday, February 01, 2005 8:12 AM Subject: Pietenpol-List: COntinental A65's on a cold morning Bert and Les, I think what you are seeing is pretty common. Continental A65's don't have an "acceleration pump" on the throttle to help atomize extra fuel for acceleration. When the engine is cold, a sudden opening of the throttle tends to suck liquid fuel into the throat of the carburetor, with the result that the engine sort of chokes and gasps before beginning to accelerate. It can be quite disconcerting particularly if you suddenly need a burst of power, to shove the throttle in and have the engine sit there spluttering for a second or two before beginning to speed up. It definitely occurs on my Pietenpol and I remember the same thing happening with my old J-3 Cub. You just need to learn to advance the throttle very slowly on a cold day. I've never had the engine quit from this, but it sounds like it is about to quit. Jack Phillips ________________________________________________________________________________
Date: Feb 01, 2005
Man! That=A1=AFs terrible! What kind of plane was it? Probably not a Pietenpol at 5=A2=AAF, but anything with a 65 Continental is a cool airplane Jack -----Original Message----- It is more serious than you think. Lee Hilbert, Buck's #3 son, had his A-65 quit because he went from idle to power about 2 weeks ago. Temp was about 5=A1=C6F. He landed, dead stick on Lake Delavan only to sink thru a weak spot in the ice. Ruined his entire day and the WIS DNR finded him $440 for polluting the lake. Cy Galley - Aeronca Aviators Club ________________________________________________________________________________
Subject: Re: Japanese Pietenpol Air Camper
Date: Feb 01, 2005
looks good! I think everyone who builds a real Aircamper should build a model too! DJ ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: Japanese Pietenpol Air Camper > Thru another builder who contacted me, I learned that a glider > pilot/mechanic named Mita San > near Tokyo built an Air Camper years ago and never finished it. He > intends to someday but for > now has built this yellow electric r/c Piet which he has flown off the sand > beaches of Tokyo bay ! > > Tora Tora Pietenpol Air Camper ! > > Mike ---- > ________________________________________________________________________________
Date: Feb 01, 2005
COntinental A65's on a cold morningIt was an Aeronca 7AC ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Tuesday, February 01, 2005 9:27 AM Subject: RE: Pietenpol-List: COntinental A65's on a cold morning Man! That=A1=AFs terrible! What kind of plane was it? Probably not a Pietenpol at 5=A2=AAF, but anything with a 65 Continental is a cool airplane Jack -----Original Message----- It is more serious than you think. Lee Hilbert, Buck's #3 son, had his A-65 quit because he went from idle to power about 2 weeks ago. Temp was about 5=A1=C6F. He landed, dead stick on Lake Delavan only to sink thru a weak spot in the ice. Ruined his entire day and the WIS DNR finded him $440 for polluting the lake. Cy Galley - Aeronca Aviators Club ________________________________________________________________________________
Date: Feb 01, 2005
Jack is right, you slowly advance the throttle or advance it in small increments to allow the engine to catch up. You can flood the carb. enough to kill the engine. This is especially true on a very cold engine. Another reason to allow the engine to warm up before flight on cold days. Doc --- "Phillips, Jack" wrote: > Bert and Les, > > You just need to learn to advance > the throttle very slowly on a cold day. > > Jack Phillips > > __________________________________ http://my.yahoo.com ________________________________________________________________________________
Subject: Continental A-65 in "Black Piet"
Date: Feb 01, 2005
Les asks- >I assume that this flat spot and slight black smoke as you speed it up >is a indication of incorrect float level. I have installed the new delrin >needle >with the recommended float weight change. Not sure if it's a float level issue because you didn't say which carburetor you're using, but if it's a Stromberg NA-S3 series, it could possibly be. There is a bit of fussiness about setting the float level but it's been perfect on mine since Corky set it up and since I changed the carb to one overhauled by Deanie Montgomery. Deanie puts them on a flow bench to set them up, but if you want to fool with it there is detailed information in some articles authored by Neal Wright at http://www.bowersflybaby.com/tech/engines.htm (under "Technical Help- Neal Wright on the Stromberg Carburetor"). It has to do with fiddling with the combination of various thicknesses of float bowl gaskets that come with an overhaul kit. You can email Neal at COUGARNFW(at)aol.com if you want to discuss this specific problem to see if it's related to the float level. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 01, 2005
Subject: Virus, Modern Ford Power
2004) Piet List Members, I keep getting lengthy, virus infected attachments from Michael D. Cuy to my personal mailbox. When I asked Mr. Cuy to disinfect the attachment of the "W32Beagle.AY@mm" virus to reassure my very picky Norton utility, he responded by advising me to seek assistance by clicking on the "HELP" button. Perhaps this is not the Michael D. Cuy who is a member of the Pietenpol List. Does anyone know anything about this? On a more interesting note, many Pieters are airframe guys; a smaller number are engine guys. A few like D. J. Vegh and Larry Harrison are both. I am primarily an engine guy who has a 116 cubic inch Ford Escort engine hanging, inverted, in a mockup Pietenpol Scout mount on my garage wall. It is currently belt-driven by a large electric motor to investigate the pressure and scavenge oiling and fuel injection systems. The truncated oil pan (now on top and no longer a sump) has a temporary Plexiglas cover through which oil flows can be observed. Interesting stuff, slow progress, not actively looking for an airframe yet. Sure would be fun to have it running at Brodhead next July. Happy landings, Mike Fisher Talkeetna, Alaska ________________________________________________________________________________
Subject: Re: Next TACO meeting to honor Steve Ruse
Date: Feb 01, 2005
Steve...Sorry for the delay in answering your inquiry about the price quote from US Buildings. We've been out of town for the last ten days. The price I was quoted on 4/6/04 for a model Q33'-16' which is 33 feet wide and 20 feet long with max height of 16 feet was $5750.00 delivered to Huntsville, Alabama.. The person who made the quote was Andrea C. Gimin. You might want to talk to Karen Smith (factory consultant) first. Do you know they have a free video which they will send upon request? ...Carl Vought----- Original Message ----- From: Steve Ruse To: pietenpol-list(at)matronics.com Sent: Tuesday, January 25, 2005 1:55 AM Subject: RE: Pietenpol-List: Next TACO meeting to honor Steve Ruse That sounds like fun Sterling, I can't wait to get it back here and spend spring, summer, and fall burning Avgas. I'll have the plane here ASAWA (As Soon As Weather Allows). I'd be glad to drop down into the hill country once I get it here, there is some great barbeque to be had down there. Thanks for the welcome everyone...I can't wait to meet more of you. Seems like a great group. Later this spring I plan on buying some wood and fabric and re-creating the vertical and horizontal stabs for a Pietenpol, just to learn more about their construction. Who knows, maybe one day I'll find time to build an entire Piet. Steve Dallas, TX -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of N321TX(at)wmconnect.com Sent: Monday, January 24, 2005 8:19 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Next TACO meeting to honor Steve Ruse Actually the subject line should read... Next TACO meeting to honor and induct Steve Ruse and gawk at his new Texas Air Camper... As soon as Steve has an idea of when he will have his Air Camper in Texas, and at a time convenient to him, let's have a meeting. Maybe we can tie this into Mike Cuy's visit. Maybe Corky can swing by? Maybe Oscar will have his repairs done and can meet us at a location between San Antonio and Dallas if there isn't a Presidential TFR. Maybe some other Yankees other than Mike can visit? Just a thought. Sterling 5TA6 NOTAMS. Fresh cow chips on runway, land at your own risk. ________________________________________________________________________________
Subject: Re: Virus, Modern Ford Power
Date: Feb 01, 2005
There was a Mike Fisher who was involved in the tests of a two-cylinder opposed four stroke Rotax engine. Zat you? The tests apparently didn't go well or Rotax decided the market wasn't there. I'd like to find out more about it...Carl Vought ----- Original Message ----- From: "Michael Fisher" <mfisher(at)gci.net> Subject: Pietenpol-List: Virus, Modern Ford Power > > Piet List Members, > I keep getting lengthy, virus infected attachments from Michael D. Cuy to my personal mailbox. When I asked Mr. Cuy to disinfect the attachment of the "W32Beagle.AY@mm" virus to reassure my very picky Norton utility, he responded by advising me to seek assistance by clicking on the "HELP" button. > > Perhaps this is not the Michael D. Cuy who is a member of the Pietenpol List. Does anyone know anything about this? > > On a more interesting note, many Pieters are airframe guys; a smaller number are engine guys. A few like D. J. Vegh and Larry Harrison are both. I am primarily an engine guy who has a 116 cubic inch Ford Escort engine hanging, inverted, in a mockup Pietenpol Scout mount on my garage wall. It is currently belt-driven by a large electric motor to investigate the pressure and scavenge oiling and fuel injection systems. The truncated oil pan (now on top and no longer a sump) has a temporary Plexiglas cover through which oil flows can be observed. Interesting stuff, slow progress, not actively looking for an airframe yet. Sure would be fun to have it running at Brodhead next July. > > Happy landings, > Mike Fisher > Talkeetna, Alaska > > ________________________________________________________________________________
Date: Feb 01, 2005
Les, Yeah, I went thru this with my Mentor on a 65 idle setup. First you have to set up the carb to the manual. Then , as I was told, you have to find the happy medium on the idle mixture. The main thing is that the Stromberg carb doesn't have an acelerator pump like all the cars do, so you have to set it up so that it will stumble the least on acceration. and work the throttle accordingly. (remember, it's 1930's technology) walt evans NX140DL ----- Original Message ----- From: "Les Schubert" <leskarin(at)telus.net> Subject: Pietenpol-List: continental A65in "Black Piet" > > I was sitting in my almost completed Piet today running the engine and > observed that the engine seems to go rich as you come off idle up to about > 1100 rpm, over that it then revs up nicely. idles fine at about 600-700 rpm > with no indication of overrichness. Starts quite nicely with the throttle > closed with one shot of prime. The engine was at about 60 F and the outside > air temp was about 35 F when it started. I assume that this flat spot and > slight black smoke as you speed it up is a indication of incorrect float > level. I have installed the new delrin needle with the recommended float > weight change. I would appreciate any sage advice from someone with more > experience than I. I should be ready to test fly in a week or so if I don't > have huge issues to deal with. Just need to final fit the wings, do the > weight and balance final, and take it to the airport. I have a experience > tail dragger pilot lined up for the first flights > > ________________________________________________________________________________
Subject: Peitenpol in Utah
Date: Feb 02, 2005
Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale. 4. Can you buy a kit that includes the needed wood sizes? 5. Does anyone know if there are any builders, or Piets in Utah? I am 210lb pilot, I would like to sit in one to get the feel if I am going to invest the time and money. I have read a lot regarding the plane and the different engines guys have used. Would a C-90 be to large with my weight, or would a Continental A-65 be better suited? Are the Rotax engines too light for the p lane and do they have enough torque at the lower RPMS? I'm sure if I get started on this project I will have many questions. Any help would be greatly appreciated. Thanks. Brian Jardine Clinton, Utah 801-499-6210 Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale. 4. Can you buy a kit that includes the needed wood sizes? 5. Does anyone know if there are any builders, or Piets in Utah? I am 210lb pilot, I would like to sit in one to get the feel if I am going to invest the time and money.I have read a lot regarding the plane andthe different engines guys have used. Would a C-90 be to large with my weight, or would a Continental A-65 be be tter suited? Are the Rotax engines too light for the plane and do they have enough torque at the lower RPMS? I'm sure if I get started on this project I will have many questions. Any help would be greatly appreciated. Thanks. Brian Jardine Clinton, Utah 801-499-6210 ________________________________________________________________________________
Date: Feb 01, 2005
Brian, there is a Piet fuselage, ribs, and tailfeathers on ebay right now. It is located in Texas City. Good luck in your venture. ----- Original Message ----- From: Subject: Pietenpol-List: Peitenpol in Utah Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale. 4. Can you buy a kit that includes the needed wood sizes? 5. Does anyone know if there are any builders, or Piets in Utah? I am 210lb pilot, I would like to sit in one to get the feel if I am going to invest the time and money. I have read a lot regarding the plane and the different engines guys have used. Would a C-90 be to large with my weight, or would a Continental A-65 be be tter suited? Are the Rotax engines too light for the plane and do they have enough torque at the lower RPMS? I'm sure if I get started on this project I will have many questions. Any help would be greatly appreciated. Thanks. Brian Jardine Clinton, Utah 801-499-6210 ________________________________________________________________________________
Subject: Re: Peitenpol in Utah
Date: Feb 01, 2005
Brian, Go to: http://www.pressenter.com/~apietenp/ for the plans. The best place for "assembly instructions" is right here on the Pietenpol list. Aircraft Spruce sells a wood kit but there have been mixed reviews on it. I don't have any first hand knowledge. Steve Eldridge is a well known Pietenpoler who lives in Utah and has built a beautiful A-65 powered Air Camper. He pops up on the list occasionally. People MUCH larger than 210 pounds have built Pietenpols. They are quite roomy. Engine choice might be more dependant on your field elevation than your body weight. A Rotax would be too light. Greg Cardinal Minneapolis ----- Original Message ----- From: bpjardine(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Tuesday, February 01, 2005 6:32 PM Subject: Pietenpol-List: Peitenpol in Utah Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale. 4. Can you buy a kit that includes the needed wood sizes? 5. Does anyone know if there are any builders, or Piets in Utah? I am 210lb pilot, I would like to sit in one to get the feel if I am going to invest the time and money. I have read a lot regarding the plane and the different engines guys have used. Would a C-90 be to large with my weight, or would a Continental A-65 be be tter suited? Are the Rotax engines too light for the plane and do they have enough torque at the lower RPMS? I'm sure if I get started on this project I will have many questions. Any help would be greatly appreciated. Thanks. Brian Jardine Clinton, Utah 801-499-6210 ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Feb 01, 2005
Brian: You can order the plans direct from Don Pietenpol, the son of Bernard Pietenpol who designed the original AirCamper. Here is a link to his web site ==>http://www.pressenter.com/~apietenp/. Buying a plane that someone else started would certainly save time, but look at all of the fun of building you would miss. I currently into my second year of building and I enjoy it even more now than when I first started. Aircraft Spruce in California has a wood kit available for the aircamper. There is also a wood list on MYKITPLANE.com which is what I used. If you need the link let me know and I will dig it up for you. I would definitely get a copy of the 1932 flying and glider manual from the E.A.A. (about $6 or $7), that has the reprint of the original 1932 series of articles on building the aircamper. If you haven't already seen the publication, it has all of the plans and building information. It will definitely give you a good overview of what the Pietenpol is all about. Good Luck, Rick Schreiber ----- Original Message ----- From: Subject: Pietenpol-List: Peitenpol in Utah Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale. 4. Can you buy a kit that includes the needed wood sizes? 5. Does anyone know if there are any builders, or Piets in Utah? I am 210lb pilot, I would like to sit in one to get the feel if I am going to invest the time and money. I have read a lot regarding the plane and the different engines guys have used. Would a C-90 be to large with my weight, or would a Continental A-65 be be tter suited? Are the Rotax engines too light for the plane and do they have enough torque at the lower RPMS? I'm sure if I get started on this project I will have many questions. Any help would be greatly appreciated. Thanks. Brian Jardine Clinton, Utah 801-499-6210 ________________________________________________________________________________
Date: Feb 01, 2005
Peter, The 1/16" plywood goes on the Top Only. It does not go around the leading edge, and it does not go on the bottom of the wing. It does not get glued to the top of the front spar, either. The plywood overlaps the leading about 3/4", then after the adhesive is set, bevel the forward edge of the plywood, and blend it in. You could scarf splice the edges of each of the four pieces above a rib, but I made butt joints. The only place it is glued is along the leading edge, and up each of the ribs. The aft edge of the plywood, just above the spar, will kind of warp up a little bit. Bevel the aft edge of the plywood slightly, and when the fabric is installed and shrunk, it pulls the aft edge of the plywood down very nicely. There is no need to wet the plywood, because it is a very large radius along that portion of the airfoil, and it is no problem at all to bend the plywood along the ribs. I used T88 on mine, and did not use any nails, or staples. I used quite a few clamps, but not too much clamp pressure, so you don't squeeze all the adhesive out. I also used the black rubber bunji chords around the leading edge, and the spar, between each rib, but use temporary blocks to space the plywood up off the spar, so you don't get slack in the plywood there. Chuck G. ________________________________________________________________________________
Date: Feb 02, 2005
Chuck/Walt. Thanks for the reply's. I am using the Jim Wills version of the plans which call for the complete leading edge to be covered with ply. I will combine the two ideas and see how it goes. I'll butt joint the ply pieces at the ribs. That will make it easier to bend the smaller pieces rather than try to bend the whole length. Ain't life fun. Cheers Peter. Wonthaggi, Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rcaprd(at)aol.com Subject: Re: Pietenpol-List: Leading Edge Ply Peter, The 1/16" plywood goes on the Top Only. It does not go around the leading edge, and it does not go on the bottom of the wing. It does not get glued to the top of the front spar, either. The plywood overlaps the leading about 3/4", then after the adhesive is set, bevel the forward edge of the plywood, and blend it in. You could scarf splice the edges of each of the four pieces above a rib, but I made butt joints. The only place it is glued is along the leading edge, and up each of the ribs. The aft edge of the plywood, just above the spar, will kind of warp up a little bit. Bevel the aft edge of the plywood slightly, and when the fabric is installed and shrunk, it pulls the aft edge of the plywood down very nicely. There is no need to wet the plywood, because it is a very large radius along that portion of the airfoil, and it is no problem at all to bend the plywood along the ribs. I used T88 on mine, and did not use any nails, or staples. I used quite a few clamps, but not too much clamp pressure, so you don't squeeze all the adhesive out. I also used the black rubber bunji chords around the leading edge, and the spar, between each rib, but use temporary blocks to space the plywood up off the spar, so you don't get slack in the plywood there. Chuck G. ________________________________________________________________________________
Date: Feb 01, 2005
Brian, You really need to go talk to Steve Eldrige in Prove, actually he works in Prove and lives in Spanish Fork, I think. He is about 210lb too. He's a great guy and I'd bet he would show you his plane. Try his email address at steve(at)byu.edu. A Rotax is to light for a Piet. You may want to try upgrading to a C-90 or O-200. I hear they fly very good on a C-90 and at your weight it might have better climb, Steve runs a C-65 and seems to fly all over the place in his. Keep asking questions on the list but see if you go see Steve's plane. Chris Tracy Sacramento, Ca ----- Original Message ----- From: bpjardine(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Tuesday, February 01, 2005 4:32 PM Subject: Pietenpol-List: Peitenpol in Utah Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale.
January 04, 2005 - February 01, 2005
Pietenpol-Archive.digest.vol-eh
