Pietenpol-Archive.digest.vol-ei
February 01, 2005 - March 01, 2005
      4. Can you buy a kit that includes the needed wood sizes?  5. Does anyone
      know if there are any builders, or Piets in Utah?  I am 210lb pilot, I would like
      to sit in one to get the feel if I am going to invest the time and money.
      I have read a lot regarding the plane and the different engines guys have used.
      Would a C-90 be to large with my weight, or would a Continental A-65 be be
      tter suited?  Are the Rotax engines too light for the plane and do they have
      enough torque at the lower RPMS?  I'm sure if I get started on this project I
      will have many questions. Any help would be greatly appreciated. Thanks.
        Brian Jardine
        Clinton, Utah
        801-499-6210
Date: Feb 01, 2005
Subject: A little something
Don't say I don't give you guys something. :-) :-) http://www.flightsongrecords.com/ Clif ________________________________________________________________________________
Subject: Peitenpol in Utah
Date: Feb 02, 2005
Hi Brian, Welcome to the wonderful world of Pietenpols. Your questions have already been pretty well answered, but there are a couple of extra pieces of advice that might be helpful: 1. Buy Mike Cuy's video on building and flying his beautiful Pietenpol, NX48MC. You can order it directly from Mike at: Michael.D.Cuy(at)grc.nasa.gov I think he charges $20 for it and it contains a wealth of information, and more importantly, a lot of INSPIRATION for those days when it seems you will never finish this project. In addition to his video, Mike is a regular contributor to this list and is a genuinely nice person, great builder and great pilot 2. If you don't already own them, buy the 4 Tony Bingelis Books from EAA (I just naturally assume you are a member of the EAA - if not, you should be). Those four books, The Sportplane Builder, Sportplane Construction Techniques, Firewall Forward, and Tony Bingelis on Engines cover 95% of what you will need to know to build this airplane. I also found helpful the EAA's book on Aircraft Welding, and Aircraft Construction Techniques: Wood 3. This is not a kitplane. There are good points and bad points about this. The good points include such things as being able to modify the design to fit your personal needs, and choose materials based on your own tastes and budget (there are many Piets flying built from aircraft grade materials and probably more flyig with lumber yard wood and hardware store fittings). The bad points are that you will probably make a lot of scrap pieces during the learning process. I know I did - I probably made enough parts for nearly 2 complete Pietenpols. However, remember that the FAA allows us to build our own planes for "Recreation and Education". The recreation part will become obvious - you will re-create the same part several times until you get it right :-). Because it is not a kit you will have to do a lot more thinking than you would to merely assemble parts made by a manufacturer. The plans have some mistakes in them, and even when the information is correct, it is sometimes presented in a way that requires a lot of head-scratching to understand. 4. Save all your jigs. You never know when you might need them again. I first flew my Pietenpol last October, and at the end of November had a partial engine failure which led to a forced landing. The off-airport landing resulted in some damage to the airframe which I'm now about halfway through repairing. I am in the process of making two new ribs for the right aileron and repairing one broken rib in the right wing. I'm very glad that I kept the jig that I used to make the original ribs so the new ribs will be identical to the originals. 5. Think through your choices carefully. As you begin to build your airplane there are a number of fundamental choices to be made (again, different form the typical kitplane): The basic choices every Piet builder faces are: a. What engine to use? If you buy the supplemental plans from Don Pietenpo, you will have enough information to use either a Ford Model A, a Corvair, or a Continental A-65. Any other choice will require more work to develop yoru own engine mount design (not that this is too difficult) b. Long fuselage or short? c. One-piece wing or 3-piece wing? d. Split axle gear or straight axle? e. Wire wheels or normal aircraft wheels f. Fuel tank in the nose or in the centersection? In addition to this forum, good information can be found by attending Sun'n'Fun or Oshkosh for basic woodworking, fabric work, welding, and metalworking skills., and certainly if possible try to attend the Pietenpol fly-in at Brodhead Wisconsin. There you will find a good array of Pietenpols displaying all the choices mentioned above (and more) and you can see first hand which choices appeal to you Good luck! Jack Phillips NX899JP Raleigh, NC -----Original Message----- Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale. 4. Can you buy a kit that includes the needed wood sizes? 5. Does anyone know if there are any builders, or Piets in Utah? I am 210lb pilot, I would like to sit in one to get the feel if I am going to invest the time and money. I have read a lot regarding the plane and the different engines guys have used. Would a C-90 be to large with my weight, or would a Continental A-65 be be tter suited? Are the Rotax engines too light for the plane and do they have enough torque at the lower RPMS? I'm sure if I get started on this project I will have many questions. Any help would be greatly appreciated. Thanks. Brian Jardine Clinton, Utah 801-499-6210 ________________________________________________________________________________
Date: Feb 02, 2005
I'm still here! I got behind in my reading and just had to cut 700 messages and start over. Brian, and others have a standing invitation to come to look at my airplane. It isn't the beauty queen some say it is, but it is airworthy and I fly it a lot during the summer, and on the warm days in winter. I have 300 hours on it now and have been flying it since 1997. There is no cheaper way in to the sky- and people dig the old time looks, and sound. Add smoke and you have got a head turner everywhere you go. (It just takes a while to get there!) I've still got lots of Piet caps if anyone wants one. Thinking of heading back to Brodhead this year again. Working on my Stinson 108-2. Both wings are covered. Fuse is next. We started an EAA chapter a year ago that has about 25 people attending every month. There is another piet project on the airport that has been sitting for a year or two since purchase from another party. Steve E Spanish Fork, UT ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bpjardine(at)comcast.net Subject: Pietenpol-List: Peitenpol in Utah Hi everyone, My name is Brian and I am new to this group. I live in Clinton, Utah and I was interested in a Peitenpol for a new project. I had a Challenger II several years ago and my brother and I finished a Sixchuter PPC last year. I like the looks, and construction of the Air camper. I have a few questions I hope you all could help me with. 1. Where is the best place to obtain full sets of plans and assembly instructions? 2. Would it be wise to buy a plane that someone else has started? 3. Does anyone know of any planes started/unfinished for sale. 4. Can you buy a kit that includes the needed wood sizes? 5. Does anyone know if there are any builders, or Piets in Utah? I am 210lb pilot, I would like to sit in one to get the feel if I am going to invest the time and money. I have read a lot regarding the plane and the different engines guys have used. Would a C-90 be to large with my weight, or would a Continental A-65 be be tter suited? Are the Rotax engines too light for the plane and do they have enough torque at the lower RPMS? I'm sure if I get started on this project I will have many questions. Any help would be greatly appreciated. Thanks. Brian Jardine Clinton, Utah 801-499-6210 ________________________________________________________________________________
Subject: Re: Japanese Pietenpol Air Camper
Date: Feb 02, 2005
EXCEPT that it cuts into your full-scale version's building time. I bought some beautiful plans for a 1/4 scale Piet model over a year ago, looked them over carefully, and decided to just start building the one I'll fly from inside. I'll keep those plans and the two R/Cs which are "flying" a few inches below the ceiling of my back porch, for the day I lose my ability to fly full-scale. OR maybe I'll come across a good R/C instructor distinct from the expert who wrecked my first plane! Mark Hodgson ________________________________________________________________________________
Date: Feb 02, 2005
ahhhh.... things are different here in AZ. when the temps in the shop during summer time reach 117 it's pretty much unbearable to be in there. sooooo.... it's the perfect time to build models inside. I wish our weather wasn't so severe that I COULD build for 12 mos. DJ ----- Original Message ----- From: "Hodgson, Mark O" <mhodgson(at)bu.edu> Subject: Re: Pietenpol-List: Japanese Pietenpol Air Camper > > EXCEPT that it cuts into your full-scale version's building time. I > bought some beautiful plans for a 1/4 scale Piet model over a year ago, > looked them over carefully, and decided to just start building the one > I'll fly from inside. I'll keep those plans and the two R/Cs which are > "flying" a few inches below the ceiling of my back porch, for the day I > lose my ability to fly full-scale. OR maybe I'll come across a good R/C > instructor distinct from the expert who wrecked my first plane! > > > Mark Hodgson > > ________________________________________________________________________________
Date: Feb 02, 2005
Subject: 2 Cyl. opposed Rotax
2004) There was a Mike Fisher who was involved in the tests of a two-cylinder opposed four stroke Rotax engine. Zat you? Carl, Thanks for your inquiry. I am not the Rotax Mike Fisher. There are quite a few of us around. One reason 2 Cyl. opposed engines are not more widely employed is the large change in crankcase volume caused by both pistons moving in and out at the same time. The large crankcases on successful versions of this design, such as the BMW motorcycle, are there for a reason. Some years ago, Franklin came out with a 60HP 2 Cyl, horizontally opposed, certified engine that would be okay for a Piet with a long mount. These unloved powerplants and parts are available at low cost. The Pietenpol likes a long, slow turning prop that moves a lot of air at low speed. The Model A Fords and A65 Continentals are better at this than the direct drive Corvairs, Franklins and various modern automobile engines. Cordially, Mike Fisher Talkeetna, Alaska ________________________________________________________________________________
Date: Feb 02, 2005
Subject: Re: Virus, Modern Ford Power
Hi Mike, This virus - whorms are kind of out of control, they use the address book of any e-mail and beguin "working" there are some ways to handle them: Once in a while (about every week) scan your drive to "clean" it from virus/whorms. Also have a spam filter and delete all the mails with a 21 to about 50 kb attachmentes. Never open any attachment that is not scaned or come from a secure email... Saludos Gary Gower. Michael Fisher wrote: Piet List Members, I keep getting lengthy, virus infected attachments from Michael D. Cuy to my personal mailbox. When I asked Mr. Cuy to disinfect the attachment of the "W32Beagle.AY@mm" virus to reassure my very picky Norton utility, he responded by advising me to seek assistance by clicking on the "HELP" button. Perhaps this is not the Michael D. Cuy who is a member of the Pietenpol List. Does anyone know anything about this? On a more interesting note, many Pieters are airframe guys; a smaller number are engine guys. A few like D. J. Vegh and Larry Harrison are both. I am primarily an engine guy who has a 116 cubic inch Ford Escort engine hanging, inverted, in a mockup Pietenpol Scout mount on my garage wall. It is currently belt-driven by a large electric motor to investigate the pressure and scavenge oiling and fuel injection systems. The truncated oil pan (now on top and no longer a sump) has a temporary Plexiglas cover through which oil flows can be observed. Interesting stuff, slow progress, not actively looking for an airframe yet. Sure would be fun to have it running at Brodhead next July. Happy landings, Mike Fisher Talkeetna, Alaska ________________________________________________________________________________
Subject: leading edge cover
Date: Feb 02, 2005
clamav-milter version 0.80j on elrond.itctel.com I am looking for some ideas on leading edge covers. 1/16 plywood is not available in my state and is very expensive to ship as well as buy from suppliers. I purchased some aluminum valley material to use but can't figure out how to attach it to the wood. I know there are people who have used aluminum. Could some one respond as to how the attachment was carried out. Has anyone used the 6 ply tag board mentioned by Bernard P. in some of the literature that is available? Would it hold its shape well enough to do what ever it is supposed to do. It will be hangered at my farm so it won't be getting wet and at the speed Pietenpols fly and the noise they make, I can't imagine bird strikes being a problem. Thanks for any information you are able to share with me. Ralph At Raymond ________________________________________________________________________________
Subject: BRS for Pietenpol
Date: Feb 03, 2005
Getting started with a Pietenpol project, I have lots of questions. Other light aircraft, and ultralight communities I have been involved with used BRS chutes on the planes. In fact most ultralights seem to have them now days. Has anyone ever installed one on a Piet? I'm sure it would take away from the nostalgic look, and I don't know if the airframe could take the stress of a chute deployment. If someone has used a chute, where was it attached? Since the plane has been around and flying for 75 years, needless to say it's an airworthy design. Has there been any documentation of structural failures or incidents? My wife has concerns about a plane being built out of wood and fabric. She didn't realize that until the mid 1900's most planes were wood and fabric. I have to resolve her concerns before I can dip into the "kitty" for some plane money. I am sure you all have been there once or twice. Thanks to all those who responded to my first posting. I received lots of valuabl e info. Brian Clinton, UT Getting started with a Pietenpol project, I have lots of questions.Other light aircraft, and ultralight communities I have been involved with usedBRS chutes onthe planes. In fact most ultralights seem to have them now days. Has anyone ever installed one on a Piet? I'm sure it would take away from the nostalgic look, and I don't know if the airframe could take thestress of a chute deployment. If someone has used a chute, where was it attached? Since the plane has been around and flying for 75 years, needless to say it's an airworthy design. Has there been any documentation of structural failures or incidents? My wife has concerns about a plane being built out of wood and fabric. She didn't realize that until the mid 1900'smost planes were wood and fabric. I have to resolve her concerns before I can dip into the "kitty" for some plane money. I am sure you all have been there once or twice. Thanks to all those who responded to my first posting. I received lots of valuable info. Brian Clinton, UT ________________________________________________________________________________
Date: Feb 02, 2005
Subject: Re: BRS for Pietenpol
0B9D0E069F0D(at)comcast.net> Brian I looked long and hard at this decision. BRS has a design worked out that has been used so if you contact them they can help you with quite a slick solution. The unit is mounted in the centre section of the wing so a centre section fuel tank can not be used and a cowl tank will probably be your choice. I ultimately did NOT buy one only because the freight companies decided to retire on my shipment. The problem is related to the "rocket" that launches it is considered hazardous goods. I live in Canada and had no problem getting the import permits. The freight companies wanted half as much as the system cost to haul it. So I made a cost benefit/decision and didn't go with it. Hopefully I will not regret it. The case for it is of course as ; 1. A broken propeller in flight and the engine parts company with the plane moving the C of G so far back the plane is un flyable, 2. Engine failure in a circumstance where a dead stick landing is not likely survivable. Both these circumstances are rare but people die every year from them. Structural failure of the plane I would place as a distant 3 rd risk and I personally feel that is a risk that I can live with but the first 2 are more probable but remote. Obviously good construction, and maintenance can improve your luck in this regard. Now I am sure some will ridicule the idea again as they did when I inquired about it because; 1. Bernie Pietenpol didn't use one, 2, Good pilots don't need these kind of things. Then again I think you will notice that there are so seat belt attachment points called out on the plans either. So what I am saying is; make the decision that makes you and your wife comfortable, it is your neck, not somebody else's on the forum Les >Getting started with a Pietenpol project, I have lots of questions. Other >light aircraft, and ultralight communities I have been involved with used >BRS chutes on the planes. In fact most ultralights seem to have them now >days. Has anyone ever installed one on a Piet? I'm sure it would take >away from the nostalgic look, and I don't know if the airframe could take >the stress of a chute deployment. If someone has used a chute, where was >it attached? Since the plane has been around and flying for 75 years, >needless to say it's an airworthy design. Has there been any documentation >of structural failures or incidents? My wife has concerns about a plane >being built out of wood and fabric. She didn't realize that until the mid >1900's most planes were wood and fabric. I have to resolve her concerns >before I can dip into the "kitty" for some plane money. I am sure you all >have been there once or twice. Thanks to all those who responded to my >first posting. I received lots of valuable info. >Brian >Clinton, UT ________________________________________________________________________________
Date: Feb 03, 2005
I also looked at this decision when I was starting to build my Piet. The deciding factor for me (apart from spending $3,000 for something I hope to never use) was adding 30 to 40 lbs to the empty weight of the airplane. I worked hard to save OUNCES from the structure, knowing that every pound counts. If I was going to add 30 lbs to the airframe, it was going to be in something that I could use more frequently (and with greater importance for safety) , like a radio and transponder. On my recent forced landing, I used the radio to let the plane I had been flying formation with know that I was going down. A BRS would have done me no good whatsoever - the damage the off-airport landing caused was certainly less than it would have been had I come down under a parachute. Yes, there are situations where a BRS might be the best way to save your life. A personal parachute is not a very good option for a Pietenpol - I tried to wear one for my first flight but couldn't get in (or out) of the cockpit with one on. It would be almost impossible for a passenger in the front cockpit to egress the airplane with a 'chute on. Besides, most Pietenpol flights are made at an altitude where a parachute probably would not be able to fully open before impact (I'm still talking about a backpack or seatpack 'chute - the BRS with its rocket deployment can open much faster). But what is the risk of such a situation occurring, and what other ways exist to mitigate that risk? Basically, a decision like this gets down to risk analysis. I work in product development for a medical device company, and we constantly use Failure Modes and Effects Analysis (FMEA) tools to identify and mitigate the risk of failure with our devices. In such an analysis, a failure mode is identified ("Engine falls off in flight"), and then every possible scenario that could cause such a failure is envisioned ("prop blade breaks, causing imbalance", "engine mount breaks"). The probability and severity of such a failure are assessed, along with the chance of detection prior to failure. Each of these are given a number rating, on a 0 to 5 scale, with 0 being "no problem" and 5 being "catastrophe", and the probability, severity and detection ratings are multiplied together to give an overall rating. Then you concentrate on figuring out ways to mitigate the ones with high ratings. For example, in the situation given below, to prevent the engine falling off due to prop blade breakage, a good pre-flight inspection should turn up any cracks. Pull on the blades and see if they deflect unusually. Thump them to see if they sound the same, etc. Flying ANY airplane is an exercise in risk management. I find it interesting that the Cirrus SR20 and SR22 (the only production aircraft with BRS parachutes) have a none too good safety record. A number of people have died in Cirrus airplanes, BRS or not. Probably more than have died in Pietenpols. Obviously, the safest airplane is one that has so much safety equipment on board that it is too heavy to get off the ground. According to the NTSB records, the Pietenpol has a pretty good safety record. It is sort of like a J-3 Cub - it is so safe it can just barely kill you. Jack Phillips -----Original Message----- Brian I looked long and hard at this decision. BRS has a design worked out that has been used so if you contact them they can help you with quite a slick solution. The unit is mounted in the centre section of the wing so a centre section fuel tank can not be used and a cowl tank will probably be your choice. I ultimately did NOT buy one only because the freight companies decided to retire on my shipment. The problem is related to the "rocket" that launches it is considered hazardous goods. I live in Canada and had no problem getting the import permits. The freight companies wanted half as much as the system cost to haul it. So I made a cost benefit/decision and didn't go with it. Hopefully I will not regret it. The case for it is of course as ; 1. A broken propeller in flight and the engine parts company with the plane moving the C of G so far back the plane is un flyable, 2. Engine failure in a circumstance where a dead stick landing is not likely survivable. Both these circumstances are rare but people die every year from them. Structural failure of the plane I would place as a distant 3 rd risk and I personally feel that is a risk that I can live with but the first 2 are more probable but remote. Obviously good construction, and maintenance can improve your luck in this regard. Now I am sure some will ridicule the idea again as they did when I inquired about it because; 1. Bernie Pietenpol didn't use one, 2, Good pilots don't need these kind of things. Then again I think you will notice that there are so seat belt attachment points called out on the plans either. So what I am saying is; make the decision that makes you and your wife comfortable, it is your neck, not somebody else's on the forum Les Getting started with a Pietenpol project, I have lots of questions. Other light aircraft, and ultralight communities I have been involved with used BRS chutes on the planes. In fact most ultralights seem to have them now days. Has anyone ever installed one on a Piet? I'm sure it would take away from the nostalgic look, and I don't know if the airframe could take the stress of a chute deployment. If someone has used a chute, where was it attached? Since the plane has been around and flying for 75 years, needless to say it's an airworthy design. Has there been any documentation of structural failures or incidents? My wife has concerns about a plane being built out of wood and fabric. She didn't realize that until the mid 1900's most planes were wood and fabric. I have to resolve her concerns before I can dip into the "kitty" for some plane money. I am sure you all have been there once or twice. Thanks to all those who responded to my first posting. I received lots of valuable info. Brian Clinton, UT ________________________________________________________________________________
Date: Feb 03, 2005
<020320050457.2512.4201AF34000E9D77000009D022069997350A02070B9D0E069F0D(at)comcast.net> Brian, I was told by an experienced and knowledgeable Piet builder that nobody has ever died in a Piet that crashed due to structural failure. He was emphasizing the fact that the plane is very well built with a large design safety factor. That's an awesome record for a design with over 70 years of history. This may relieve your wife's concerns about flying in a structure built of wood and fabric. Here's another interesting testament to wooden aircraft. The all wood Sterman biplane is rated at plus and minus 9 g's. Hope this helps. Greg Bacon Central Missouri ----- Original Message ----- From: bpjardine(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Wednesday, February 02, 2005 10:57 PM Subject: Pietenpol-List: BRS for Pietenpol Getting started with a Pietenpol project, I have lots of questions. Other light aircraft, and ultralight communities I have been involved with used BRS chutes on the planes. In fact most ultralights seem to have them now days. Has anyone ever installed one on a Piet? I'm sure it would take away from the nostalgic look, and I don't know if the airframe could take the stress of a chute deployment. If someone has used a chute, where was it attached? Since the plane has been around and flying for 75 years, needless to say it's an airworthy design. Has there been any documentation of structural failures or incidents? My wife has concerns about a plane being built out of wood and fabric. She didn't realize that until the mid 1900's most planes were wood and fabric. I have to resolve her concerns before I can dip into the "kitty" for some plane money. I am sure you all have been there once or twice. Thanks to all those who responded to my first posting. I received lots of valuable info. Brian Clinton, UT ________________________________________________________________________________
Date: Feb 03, 2005
Brian, Are you the same fellow that hangared at heber valley in John L. hanger with a Stinson? stevee ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bpjardine(at)comcast.net Subject: Pietenpol-List: BRS for Pietenpol Getting started with a Pietenpol project, I have lots of questions. Other light aircraft, and ultralight communities I have been involved with used BRS chutes on the planes. In fact most ultralights seem to have them now days. Has anyone ever installed one on a Piet? I'm sure it would take away from the nostalgic look, and I don't know if the airframe could take the stress of a chute deployment. If someone has used a chute, where was it attached? Since the plane has been around and flying for 75 years, needless to say it's an airworthy design. Has there been any documentation of structural failures or incidents? My wife has concerns about a plane being built out of wood and fabric. She didn't realize that until the mid 1900's most planes were wood and fabric. I have to resolve her concerns before I can dip into the "kitty" for some plane money. I am sure you all have been there once or twice. Thanks to all those who responded to my first posting. I received lots of valuable info. Brian Clinton, UT ________________________________________________________________________________
Subject: Re: leading edge cover
Date: Feb 03, 2005
Check out: http://www.boulterplywood.com/ Which claims to have Birch "aircraft grade" (they mean for model airplanes, but doubt if this makes a difference for the leading edge), 1/16" 50"X50" sheets. I'm planning to use that for my leading edge covers years from now when I get to that point, assuming the company is still in business (has been for a long, long time). Mark Hodgson ________________________________________________________________________________
<001301c50a03$916cbf50$9043040a@HPDesktop>
Date: Feb 03, 2005
while I have heard the same about no Piets going down due to structural failure, I do know of one case right here at my home field (Falcon Field - FFZ) where back in the 70's a Piet went down due to the elevator control system failing. The plane went into a nose dive on downwind and killed the pilot..... might as well have been a structural failure because at the point the control system failed it was all over except the screaming. A BRS woulda been nice (bot not yet in use in the 70's) I too have often thought about a BRS. I opted to not use one and just make sure that my plane is as safe as I can possibly make it.... but I sometimes still wonder if I shoulda put one in. DJ ----- Original Message ----- From: Greg Bacon To: pietenpol-list(at)matronics.com Sent: Thursday, February 03, 2005 8:17 AM Subject: Re: Pietenpol-List: BRS for Pietenpol Brian, I was told by an experienced and knowledgeable Piet builder that nobody has ever died in a Piet that crashed due to structural failure. He was emphasizing the fact that the plane is very well built with a large design safety factor. That's an awesome record for a design with over 70 years of history. This may relieve your wife's concerns about flying in a structure built of wood and fabric. Here's another interesting testament to wooden aircraft. The all wood Sterman biplane is rated at plus and minus 9 g's. Hope this helps. Greg Bacon Central Missouri ----- Original Message ----- From: bpjardine(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Wednesday, February 02, 2005 10:57 PM Subject: Pietenpol-List: BRS for Pietenpol Getting started with a Pietenpol project, I have lots of questions. Other light aircraft, and ultralight communities I have been involved with used BRS chutes on the planes. In fact most ultralights seem to have them now days. Has anyone ever installed one on a Piet? I'm sure it would take away from the nostalgic look, and I don't know if the airframe could take the stress of a chute deployment. If someone has used a chute, where was it attached? Since the plane has been around and flying for 75 years, needless to say it's an airworthy design. Has there been any documentation of structural failures or incidents? My wife has concerns about a plane being built out of wood and fabric. She didn't realize that until the mid 1900's most planes were wood and fabric. I have to resolve her concerns before I can dip into the "kitty" for some plane money. I am sure you all have been there once or twice. Thanks to all those who responded to my first posting. I received lots of valuable info. Brian Clinton, UT ________________________________________________________________________________
Date: Feb 03, 2005
I was able to buy "aircraft grade" 1/16" thick plywood in the 50"x50" sheets from stock at a local specialty building products company in western Canada called Windsor Plywood. It was in stock, I didn't ask what it was usually used for but I would assume for its bending properties. I also bought some clear straight fine grained fir to use in selected areas of construction (trailing edge, leading edge. As I was building it as a single seater due to my height I decided to tolerate the slight weight increase. I also added a radio, mode C transponder, alternator and battery and still came in at 650# with oil. I would assume that most better building supply stores (not Home Depot) could get it if they don't have it, at least in a bigger city > >Check out: > >http://www.boulterplywood.com/ > >Which claims to have Birch "aircraft grade" (they mean for model >airplanes, but doubt if this makes a difference for the leading edge), >1/16" 50"X50" sheets. I'm planning to use that for my leading edge >covers years from now when I get to that point, assuming the company is >still in business (has been for a long, long time). > >Mark Hodgson > > ________________________________________________________________________________
Date: Feb 03, 2005
There are a lot of things you can do to maybe ease your wife's concerns. Some may take some time though so be patient. First a BRS has some real advantages. The most likely advantage is a mid air. They do happen and it may be one of the biggest causes of an unflyable airplane. Number two on the list of reasons to have one is a stall spin on base to final. Its the only thing that can get you out of that situation with a chance to still be breathing. Far better to prevent that from happening in the first place but everyone that has been involved in one has figured it wouldn't happen to them. You should know that the airplanes on which it was certified and installed usually have a VERY high insurance rate. Often they are popped too quick and when the handle is pulled on many of these airplanes, the pilots handbook is quite clear in that it totals the airplane. You are ok, but it never was designed to get you an undamaged airplane at the end of it. The downside is the cost, weight and resourse allocation. Would you be reducing risk even more by spending available funds on something that might have a greater impact on safety? If money is no object, you don't have to worry about that, but then again if money is no object who would still be building a peit? Many would I am sure (no flames here) but one of the biggest advantages to the Piet has to be the fun per dollar ration. Other suggestions to help out. Take her to an airport that has a number of older airplanes. Ask the owners to show off their pride and joy to her and let her sit in one, touch the fabric, see that what you intend to do isn't so rare. Education is the key. Second get her involved. Let her see you are not doing something stupid. Let her see first hand your attitudes toward safety, your attention to detail and your dedication to learning to make this as safe as practical. Just like any pilot, you can not just talk to safety talk. You have to let her see you walk the walk as well and in time she will likely relax. Mark bpjardine(at)comcast.net wrote: > Getting started with a Pietenpol project, I have lots of > questions. Other light aircraft, and ultralight communities I have > been involved with used BRS chutes on the planes. In fact most > ultralights seem to have them now days. Has anyone ever installed one > on a Piet? I'm sure it would take away from the nostalgic look, and I > don't know if the airframe could take the stress of a chute > deployment. If someone has used a chute, where was it attached? Since > the plane has been around and flying for 75 years, needless to say > it's an airworthy design. Has there been any documentation of > structural failures or incidents? My wife has concerns about a plane > being built out of wood and fabric. She didn't realize that until the > mid 1900's most planes were wood and fabric. I have to resolve her > concerns before I can dip into the "kitty" for some plane money. I am > sure you all have been there once or twice. Thanks to all those who > responded to my first posting. I received lots of valuable info. > Brian > Clinton, UT ________________________________________________________________________________
Subject: Aluminum spars
Date: Feb 03, 2005
I'm just about ready ready to start on my wings (3 piece wing) for my piet. All my ribs are done (wood). I'm thinking about using possible aluminum spars.Is there anyone who has been building and now flying with such a set up? Thanks for the input. Bernie P. Lefebvre Val d'Or, Quebec ________________________________________________________________________________
Date: Feb 03, 2005
-Brian, If I may add my two cents (?) worth here as you have posted a very good question. I have no personal experience with the BRS, but I have had a lot of experience with parachutes both in the military and having owned and worn emergency chuts during years of acro. All parachutes can malfunction especially when the falling body is not stabilized before deploying the chute. If an airplane has a major airframe failure (ie. lose a wing), the plane will most likely spin or rotate or even tumble due to the much altered aerodynamics. Perhaps the BRS is designed to avoid complications from this scenerio. I know they have been used successfully on light aircraft, but this thing always concerned me. The Pietenpol is a very well designed small aircraft. It is well over built (if built correctly) and I can't think of any mishap (except for a mid-air or throwing a prop blade) that would cause a major failure. If the plane is built right and inspected frequently, it should be very safe to fly without much concern. The airplane does have a wonderful track record (much better than many factory built planes) and the fact that it is built out of wood should only increase your feelings of security. Wooden aircraft that are well built and maintained are far more durable aircraft than metal or composit aircraft. I have owned three antique airplanes (all three were much older than their pilot) and all three were just as sound now as they were when built. Most acro aircraft are built with wooden wings (both spars as well as the ribs) because they are much stronger and lighter than all other materials and do not suffer from fatigue like the others. One other point I would like to make is; you take a good sound airplane and a good experienced pilot who inspects his plane frequently, your risk of having a fatal accident on the highway far exceeds your risk of having a fatal accident flying. To make a long story short ( :) ), please reasure your wife that there are some wooden aircraft still flying after 80 years and all have survived most of their pilots. Best wishes, Doc > > > Getting started with a Pietenpol project, I have > lots of > > questions. Other light aircraft, and ultralight > communities I have > > been involved with used BRS chutes on the planes. > > > Brian > > Clinton, UT > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Date: Feb 03, 2005
Hello DJ, For what your message gives the idea, the problem was not about the design, was about the quality of the builders welding ability (and probably preflight and/or yearly inspection (sp?)) I have studied and bought countless of airplane plans and one thing I will positive believe is that the Piet is the most well built (maybe the word "overbuilt" will fit better here) I have put my eyes in... This is why, and also this great friends/family in this list, I am still here. Yes, I havent built one yet, but once I finish my 8th airplane I will do my best to beguin one, I am 52 years old, so probably I have time left to built at least 2 or 3 more projects, with God's permision, of course. Since the last time I flew my Hang Glider weekly, (about 12 years ago) and started in Ultralights, I havent used a chute since. Hope I will never need it (knock wood). I will rather invest that money in gasoline for emergency landing procedures practice (deadstick spot landing), and fully learn the stall behavoir, than in a chute. Probably I am completly wrong, so please dont follow my advise :-) Saludos Gary Gower. DJ Vegh wrote: while I have heard the same about no Piets going down due to structural failure, I do know of one case right here at my home field (Falcon Field - FFZ) where back in the 70's a Piet went down due to the elevator control system failing. The plane went into a nose dive on downwind and killed the pilot..... might as well have been a structural failure because at the point the control system failed it was all over except the screaming. A BRS woulda been nice (bot not yet in use in the 70's) I too have often thought about a BRS. I opted to not use one and just make sure that my plane is as safe as I can possibly make it.... but I sometimes still wonder if I shoulda put one in. DJ ----- Original Message ----- From: Greg Bacon Subject: Re: Pietenpol-List: BRS for Pietenpol Brian, I was told by an experienced and knowledgeable Piet builder that nobody has ever died in a Piet that crashed due to structural failure. He was emphasizing the fact that the plane is very well built with a large design safety factor. That's an awesome record for a design with over 70 years of history. This may relieve your wife's concerns about flying in a structure built of wood and fabric. Here's another interesting testament to wooden aircraft. The all wood Sterman biplane is rated at plus and minus 9 g's. Hope this helps. Greg Bacon Central Missouri ----- Original Message ----- From: bpjardine(at)comcast.net Subject: Pietenpol-List: BRS for Pietenpol Getting started with a Pietenpol project, I have lots of questions. Other light aircraft, and ultralight communities I have been involved with used BRS chutes on the planes. In fact most ultralights seem to have them now days. Has anyone ever installed one on a Piet? I'm sure it would take away from the nostalgic look, and I don't know if the airframe could take the stress of a chute deployment. If someone has used a chute, where was it attached? Since the plane has been around and flying for 75 years, needless to say it's an airworthy design. Has there been any documentation of structural failures or incidents? My wife has concerns about a plane being built out of wood and fabric. She didn't realize that until the mid 1900's most planes were wood and fabric. I have to resolve her concerns before I can dip into the "kitty" for some plane money. I am sure you all have been there once or twice. Thanks to all those who responded to my first posting. I received lots of valuabl e info. Brian Clinton, UT ________________________________________________________________________________
Date: Feb 03, 2005
In a message dated 2/3/05 10:25:31 AM Central Standard Time, djv(at)imagedv.com writes: << while I have heard the same about no Piets going down due to structural failure, I do know of one case right here at my home field (Falcon Field - FFZ) where back in the 70's a Piet went down due to the elevator control system failing. The plane went into a nose dive on downwind and killed the pilot..... might as well have been a structural failure because at the point the control system failed it was all over except the screaming. A BRS woulda been nice (bot not yet in use in the 70's) >> DJ, I looked up this incident that you referred to, in the data base that I have stored in my computer. I have done an extensive search of all accidents of Pietenpols from 1966 to the present. Now, referr to the last line in the report. The Pietenpol aircraft design Does NOT have a push pull rod in the control system, therefore this plane was NOT built to the plans. AMTRPL AIRCAMPER NNUM: 3586 LOCATION: MESA, AZ DATE: 07/08/79 ACFT HRS: 450 YEAR OF MFG: 0 FATALS: 1 INJURIES:0 WX AND WIND: UNKNOWN DAY CLER G10 0 0/ ENGINE: PILOT: TOTAL HRS.: 465 HRS IN MODEL: 125 LAST 90 DAYS: 30 CAUSES: ELEVATOR CONTROL SYSTEM TYPE EVENT: UNCONTROLLED COLL WITH GRND DMG: DEMOLISHED PHASE OF FLIGHT: IN TRAFFIC PATTERN-CIRCLING CATEGORY: INADEQUATE MAINTENANCE TYPE AIRCRAFT: MONOPLANE-HIGH/PARASOL WING REMARKS: ELEVATOR PUSH-PULL ROD FAILED DUE TO METAL FATIGUE. ________________________________________________________________________________
<001301c50a03$916cbf50$9043040a@HPDesktop> <003701c50a0c$cb31a1c0$0564a8c0@rdci.az.home.com>
Subject: BRS for Pietenpol/ regarding elevator control failure
Date: Feb 03, 2005
To D.J. Vegh: Do you know the location of the failure in the Pietenpol elevator control system at Falcon Field? I"m sure we Pietenpol jockeys would like to know any details. When I built my Pietenpol in 1970, I foolishly used aluminum pulleys in the forward elevator cable circuit. After 159 hours, I discovered the forward "up" elevator cable had frayed and I replaced it. Then, after 278 hours, the forward "down" cable frayed. The failures were at the twin pulleys on the torque tube just under the front of the rear seat. Probably dust combined with the aluminum pulleys caused excessive cable wear at this point. I then replaced both cables and substituted micarta pulleys for the aluminum ones. The airplane now has 741 hours on it and no further cable problems have surfaced. Needless to say, I keep a close watch on them. It is easy to check them by feeling the cable as it runs through your fingers when the stick is moved back and forth and this is a part of my pre-flight inspection. Should you snag a finger with a broken wire, it is much better than losing elevator control in flight! (But if one uses a piece of cloth instead of one's pinky for this procedure, it will catch on a broken wire alerting you that there is a problem, and the finger will be spared.) My Pietenpol, like many of them, has no elevator trim for backup. And it has always tended to be a bit nose-heavy in the air, solo or dual. An elevator control failure is something I would rather not think about. Even with a BRS, one must build and fly carefully, and practise diligent maintenance because the BRS may not be able to save you in some circumstances. The words of Major Hereward deHavilland (brother of Sir Geoffrey) come to mind: "The only way for a flying man to keep alive [is] to be apprehensive." (Quoted from THE LONELY SEA AND THE SKY by Sir Francis Chichester, 1964.) Graham Hansen (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Feb 03, 2005
Ralph, Your life is at stake here. Use 1/16" plywood for the top of the leading edge cover. Chuck Gantzer NX770CG Wichita KS ________________________________________________________________________________
Date: Feb 03, 2005
Subject: Re: Aluminum spars
Bernie, Like I said in my last post - Your life is at stake here...use the wood spars, and carry on with the construction of a Very Fine design. Chuck Gantzer NX770CG Wichita KS ________________________________________________________________________________
Date: Feb 04, 2005
may have been a GN-1 then. GN-1's have a push-pull rod connected to a walking beam. DJ ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: BRS for Pietenpol > > In a message dated 2/3/05 10:25:31 AM Central Standard Time, > djv(at)imagedv.com > writes: > > << while I have heard the same about no Piets going down due to structural > failure, I do know of one case right here at my home field (Falcon Field - > FFZ) > where back in the 70's a Piet went down due to the elevator control system > failing. The plane went into a nose dive on downwind and killed the > pilot..... > might as well have been a structural failure because at the point the > control > system failed it was all over except the screaming. A BRS woulda been > nice > (bot not yet in use in the 70's) >> > > DJ, > I looked up this incident that you referred to, in the data base that I > have stored in my computer. I have done an extensive search of all > accidents > of Pietenpols from 1966 to the present. > Now, referr to the last line in the report. The Pietenpol aircraft > design Does NOT have a push pull rod in the control system, therefore > this plane > was NOT built to the plans. > > > AMTRPL AIRCAMPER NNUM: 3586 LOCATION: MESA, AZ > DATE: 07/08/79 ACFT HRS: 450 > YEAR OF MFG: 0 FATALS: 1 INJURIES:0 > WX AND WIND: UNKNOWN DAY CLER G10 0 0/ > ENGINE: > PILOT: TOTAL HRS.: 465 HRS IN MODEL: 125 LAST 90 DAYS: 30 > CAUSES: ELEVATOR CONTROL SYSTEM > TYPE EVENT: UNCONTROLLED COLL WITH GRND DMG: DEMOLISHED > PHASE OF FLIGHT: IN TRAFFIC PATTERN-CIRCLING > CATEGORY: INADEQUATE MAINTENANCE > TYPE AIRCRAFT: MONOPLANE-HIGH/PARASOL WING > REMARKS: ELEVATOR PUSH-PULL ROD FAILED DUE TO METAL FATIGUE. > > > ________________________________________________________________________________
Date: Feb 04, 2005
All I can say is "Why?" -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Bernard Lefebvre Subject: Pietenpol-List: Aluminum spars I'm just about ready ready to start on my wings (3 piece wing) for my piet. All my ribs are done (wood). I'm thinking about using possible aluminum spars.Is there anyone who has been building and now flying with such a set up? Thanks for the input. Bernie P. Lefebvre Val d'Or, Quebec ________________________________________________________________________________ ETAsAhQlnOJNbe/EkgN61FvLKz+/OceHYwIURK/scwsEoJFWMKRclDavzksOUSw=
Date: Feb 04, 2005
Subject: Elevator failure
Several years ago the old IPA newsletter had a write up about a fatal crash because of elevator spar failure. The reason that it happened was the builder omitted the steel strap that tied the elev. horn to the middle beam. Leon S. ________________________________________________________________________________
Date: Feb 04, 2005
Subject: A65 carb issues
I rechecked the float level on my Stromberg NA-S3. It was about 1/2" high. Hopefully the black smoke will go away now, Obviously I will have to reset the idle. I need a good cap for a Case mag for a Continental if anybody has one. One of my caps is moisture sensitive. Les awaiting registration numbers so I can buy insurance and then test fly when the weather cooperates. ________________________________________________________________________________
Subject: project updates
Date: Feb 04, 2005
Howdy, Pieters; Well, I'm on a beanie-weenie and saltine cracker week (my wife is out of town, in Oregon for a week to visit our daughters) so I'm catching up on reading and emails, living on beer and microwave popcorn (the dog and I slurped down all the refrigerator leftovers in the first few hours my wife was gone). I notice quite a few builder updates about this time last year, probably due to most folks being snowed in or shut out of the shop due to wx., but not many updates yet this year. It's been somewhat quiet on the list. So... how about those who are building, posting a word or two on their latest progress? Pull away from the Super Bowl hype and let the rest of us know how your Aircampers are coming along. Me, my latest news is that a box arrived from Aircraft Spruce yesterday containing my new carburetor air box/filter to replace the one that got accordioned in the nose-over, plus a new carb heat knob and cable (sorry, Corky... I didn't like the dinky little brass knob unit). I was a bit surprised to find that the carb heat damper lever on the air box has detents on it (a series of notched "clicks" on the arm guide). Not sure what that's for since carb heat is usually all "on" or all "off" and not anything in between, but what the heck. All I need now is a short piece of aluminum tube, slip it into the bender, put on the nuts, flare the ends (EAA chapter 35 has an aircraft flare tool), and the fuel system on NX41CC is complete and ready to fire the engine again. This to replace the feed from the fuel tank to the gascolator, through the lower firewall, that got kinked in the nose-over. So, builders- how are y'all doing? Tom Brant? Jim Markle? Corky and "Repiet"? Anybody? I see that there were no Piets at Urbana, IL last year... if the Lord wills, maybe 41CC will be on the flightline this year... Bert Conoly? Anybody else planning to make the SAA event at Urbana? Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: project updates
Date: Feb 04, 2005
Bert Checking In! Still waiting on the weather - The darn winds have been up for three freakin weeks now. I HOPE to get a chance to fly N327BC tomorrow. Cross yer fingers. now. I got a nice E-mail back from Dwayne Obrien (of the group Little Texas) . Everybody go to this website- I'm telling you these guys are tremendous! I do music - have for 28 years. Trust Me! I will not steer you wrong! This is good , good stuff. http://www.flightsongrecords.com/ Thanks Cliff for finding his CD! Bert ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: project updates > > Howdy, Pieters; > > Well, I'm on a beanie-weenie and saltine cracker week (my wife is out of > town, in Oregon for a week to visit our daughters) so I'm catching up on > reading and emails, living on beer and microwave popcorn (the dog and I > slurped down all the refrigerator leftovers in the first few hours my wife > was gone). I notice quite a few builder updates about this time last year, > probably due to most folks being snowed in or shut out of the shop due to > wx., but not many updates yet this year. It's been somewhat quiet on the > list. > > So... how about those who are building, posting a word or two on their > latest progress? Pull away from the Super Bowl hype and let the rest of us > know how your Aircampers are coming along. > > Me, my latest news is that a box arrived from Aircraft Spruce yesterday > containing my new carburetor air box/filter to replace the one that got > accordioned in the nose-over, plus a new carb heat knob and cable (sorry, > Corky... I didn't like the dinky little brass knob unit). I was a bit > surprised to find that the carb heat damper lever on the air box has detents > on it (a series of notched "clicks" on the arm guide). Not sure what that's > for since carb heat is usually all "on" or all "off" and not anything in > between, but what the heck. > > All I need now is a short piece of aluminum tube, slip it into the bender, > put on the nuts, flare the ends (EAA chapter 35 has an aircraft flare tool), > and the fuel system on NX41CC is complete and ready to fire the engine > again. This to replace the feed from the fuel tank to the gascolator, > through the lower firewall, that got kinked in the nose-over. > > So, builders- how are y'all doing? Tom Brant? Jim Markle? Corky and > "Repiet"? Anybody? I see that there were no Piets at Urbana, IL last > year... if the Lord wills, maybe 41CC will be on the flightline this year... > Bert Conoly? Anybody else planning to make the SAA event at Urbana? > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Feb 04, 2005
Who's playing in the super bowl, anyway? Oh well, who cares.... Max Davis and I rolled it out into the driveway today and stuck the tail spinach on.....that was fun. VERY pleased with the "olde timey" look of the wheels.... Recently dissassembled and rebuilt the Stearman type fuel level guage I got from AS&S and it's gonna work nice......planed some mahoghany and maple pieces for the cabane laminations this evening..... Also completed cutting and tenoning all the Poplar wood stiles and rails for new kitchen cabinet doors (all 23 doors! aaarrgghh!). If you're married you'll know how making new things like kitchen cabinet doors helps you make progress with a Pietenpol project..... Life is good. Jim in Plano > > So... how about those who are building, posting a word or two on their > latest progress? Pull away from the Super Bowl hype and let the rest of > us know how your Aircampers are coming along. > ________________________________________________________________________________
Date: Feb 04, 2005
Dale Johnson and I are in the midst of paperwork hell. Third revision of the 8050-1 to OKC, second revision of an "Amendment to Affidavit of Ownership" (don't forget to notarize....) 2 1/2 hour meeting with the local MIDO, voicemails back and forth...... NX18235 is done, let's get on with the inspection!!!!!! Should have been flying last September. Still planning to fly to Brodhead this year. Small picture attached. Greg Cardinal Minneapolis ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: project updates > > So... how about those who are building, > posting a word or two on their latest > progress? Pull away from the Super Bowl > hype and let the rest of us know how your > Aircampers are coming along. > ________________________________________________________________________________
Date: Feb 05, 2005
How much does NX 18235 weigh empty..?? Forrest Lovley Jordan MN ________________________________________________________________________________
Date: Feb 05, 2005
Hi Forrest, NX18235 came in at 616 pounds empty. We were a bit surprised at the low weight. We knew the landing gear was heavy (60#) and all through the project we never made a conscious effort to keep the weight down. We just stuck close to the plans and we didn't add anything unnecessary. We used 2.7 oz. fabric and no more paint than necessary. Greg Cardinal ----- Original Message ----- From: <FTLovley(at)aol.com> Subject: Re: Pietenpol-List: project updates > FTLovley(at)aol.com > > How much does NX 18235 weigh empty..?? > > Forrest Lovley > Jordan MN > > > Forum - > through the Contributions > banner ads or any other > Matronics Forums. > pietenpol-list(at)matronics.com > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > ________________________________________________________________________________
Date: Feb 05, 2005
Subject: Project Update
I started building the fuselage in early November and have it all together including turtledeck and am finishing up work on seats. Floor is on, of course. I haven't put the plywood skins on front sides of fuselage yet as I followed somebody else's example of leaving it off until the seats and controls are all figured out and installed -- makes for easier access. Control stick assembly is next along with landing gear. Hope to cut out steel fitings this week and have it on gear before long. Will post some pics one of these days... Meanwhile it is supposed to be 54 degrees today here in the American Siberia (Wis.) and so I'm thinking about that Model A engine out in the garage. Needs to be totally rebuilt for aircraft use and warm weather makes it easy to mess around in the garage... By the way, the plans call for spruce for landing gear legs/struts (straight axle) -- is this what most use? Regards, Fred B. ________________________________________________________________________________ <000c01c50b8e$1e18a3c0$edf61e41@ATO>
Date: Feb 05, 2005
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Hi Oscar, Not much news here regarding my own project, but this is to let ya'll know that William Wynne will be doing a FREE 3-hr. program at EAA Chapter 82, Barber Airport (2D1), Alliance, OH next Saturday night (Feb. 12), 6-9pm Anyone who is in the area & interested in hearing Willian hold forth on the subject of Corvair engines, in the way only he can, is welcome to attend. Contact me off-list if you want more info. Kip Gardner -- North Canton, OH ________________________________________________________________________________
From: "Malcolm Morrison" <morrisons5(at)adelphia.net>
Date: Feb 05, 2005
I put a few more pictures on my web site, http://users.adelphia.net/~morrisons5/piet.html . I have the left wing just about done and have 11 ribs made for the right wing. The fuselage and tail are in pretty good shape. My motivation seems to come and go, so sometimes I make good progress, and sometimes weeks go by with no visible progress. I don't really like making all the brackets, it seems that there is no end to them. And many things, seat belts for example, require a lot of head scratching. But, it is great when you finally get past a stumbling block and complete another piece of the puzzle. Looking forward to meeting you guys at Brodhead. Malcolm Morrison ________________________________________________________________________________
Date: Feb 05, 2005
Wow, beautiful propellor Greg, did you make it yourself? Rick H wrote: > Dale Johnson and I are in the midst of > paperwork hell. > Third revision of the 8050-1 to OKC, second > revision of > an "Amendment to Affidavit of Ownership" > (don't forget to notarize....) > 2 1/2 hour meeting with the local MIDO, > voicemails back and forth...... > > NX18235 is done, let's get on with the > inspection!!!!!! > Should have been flying last September. > Still planning to fly to Brodhead this year. > Small picture attached. > > Greg Cardinal > Minneapolis > > ----- Original Message ----- > From: "Oscar Zuniga" <taildrags(at)hotmail.com> > Subject: Pietenpol-List: project updates > > > > > So... how about those who are building, > > posting a word or two on their latest > > progress? Pull away from the Super Bowl > > hype and let the rest of us know how your > > Aircampers are coming along. > > > > > -- Rick Holland ________________________________________________________________________________
Date: Feb 05, 2005
I read that someone was glueing the leading edge ply from spar to spar around the leading edge. This is what i know as a "D" tube, built right, very strong and rigid. You could not rig a wing like this. There would be lots of stress on the ply skin. And the but joints would have to part. Howdy ________________________________________________________________________________
Date: Feb 05, 2005
Credit for the prop goes to Dale. Everything he touches looks beautiful. And there is less than $50.00 invested in it, INCLUDING the prop duplicating machine. Greg ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Re: Pietenpol-List: project updates > Holland > > Wow, beautiful propellor Greg, did you make > it yourself? > ________________________________________________________________________________
Date: Feb 05, 2005
Picture of my Piet up on an Aero Lift at the Fed Ex Trade show last May. I am currently epoxy priming all of the metal pieces and getting ready to cover. Mike Luther NX1953M Anchorage Alaska ________________________________________________________________________________
Subject: started some covering
Date: Feb 05, 2005
today was such a beautiful day. blue sky, 75, slight breeze. All the rich dudes out at Falcon Field were flying thier T-6's, T-28's and Stearmans. I figured why should they have all the fun. I decided to get out of my "N74DV misery pit" and do something. Cleaned out the shop and tried my hand at covering the vertical stab. I can see this is going to be a bit of a learning curve, but it seems like I'll catch the hang of it. Vertical stab is covered but still needs to be stitched and tapes applied. I think I've conjured up a small burst of motivation so I need to ride the wave and go with it. Tomorrow I cover the horiz. stab. ohhh a question..... should I be covering the vert and horiz stabs with one piece or 2 pieces (one on each side) ? I started out doing it as one piece but screwed up so now the vert stab is in 2 pieces.... is this a no-no? DJ Vegh N74DV back in progress (for the time being) Mesa, AZ www.imagedv.com/aircamper ________________________________________________________________________________
Date: Feb 05, 2005
Subject: Re: started some covering
<001301c50b47$85d41720$edf61e41@ATO> DJ Good for you. I covered in two pieces, one each side. As far as I know rib stitching on the horizontals and vertical are optional at the speed of the Piet, check with the manufacturers instructions. > >today was such a beautiful day. blue sky, 75=B0, slight breeze. All the >rich dudes out at Falcon Field were flying thier T-6's, T-28's and >Stearmans. I figured why should they have all the fun. I decided to get >out of my "N74DV misery pit" and do something. Cleaned out the shop and >tried my hand at covering the vertical stab. > >I can see this is going to be a bit of a learning curve, but it seems like >I'll catch the hang of it. Vertical stab is covered but still needs to be >stitched and tapes applied. > >I think I've conjured up a small burst of motivation so I need to ride the >wave and go with it. Tomorrow I cover the horiz. stab. > >ohhh a question..... should I be covering the vert and horiz stabs with >one piece or 2 pieces (one on each side) ? I started out doing it as one >piece but screwed up so now the vert stab is in 2 pieces.... is this a no-no? > >DJ Vegh >N74DV back in progress (for the time being) >Mesa, AZ >www.imagedv.com/aircamper > > > > ________________________________________________________________________________
From: "gbowen(at)ptialaska.net" <gbowen(at)ptialaska.net>
Date: Feb 06, 2005
Mike, Finally got all of N-1033B recovered in Stits system after welding rebuild of wreck damage, looks great awaiting paint job and assembly. The guy who built this all metal quasi-Piete did a heck of a good job accounting for making potentially useful the payload available from the Aeronca wings (1300 lbs). He moved CG back 10" by extending the longerons to 168" and leaning the cabanes backward. CG 12"-20" of chord loaded envelope currently fall directly over the front seat passengers belt buckle. With O-235 we're currently welding up new motor mount, and hope to finish welding of new wing lift struts this week. Plane wreck back in 1996 had been due to nut coming off of one of the pistons on an C-85, knocking off the no. 4 cyc inflight, corn field landing. Maybe in a couple years,(after global warming makes AK as hot as FL, where it's 70F and sunny for superbowl sunday) I'll bring it back to Homer and see if it'll haul tundra tires and 1/4 of a moose. Gordon Bowen Original Message: ----------------- From: Mike Luther luther(at)gci.net Date: Sat, 05 Feb 2005 12:44:05 -0900 Subject: Pietenpol-List: project update Picture of my Piet up on an Aero Lift at the Fed Ex Trade show last May. I am currently epoxy priming all of the metal pieces and getting ready to cover. Mike Luther NX1953M Anchorage Alaska ________________________________________________________________________________
Date: Feb 06, 2005
Mike, what kind of wheels do you have on the landing gear of your piet? Bernie P. Lefebvre Vald'Or, Quebec ----- Original Message ----- From: "Mike Luther" <luther(at)gci.net> Subject: Pietenpol-List: project update > Picture of my Piet up on an Aero Lift at the Fed Ex Trade show last May. > > I am currently epoxy priming all of the metal pieces and getting ready > to cover. > > Mike Luther > NX1953M > Anchorage Alaska > > ________________________________________________________________________________
<5.1.0.14.0.20050205195137.0272a8d0(at)pop.telus.net>
Date: Feb 06, 2005
yeah... rib stitching is really not needed on the tail of the Piet, but I figure I'm gonna need to do it anyway on the wings so I may as well try it out. Plus I kinda like the look of the stitches and tapes. I'll pull out the Poly-Fiber video later today and will attempt to stitch this evening. DJ ----- Original Message ----- From: Les Schubert To: pietenpol-list(at)matronics.com Sent: Saturday, February 05, 2005 7:55 PM Subject: Re: Pietenpol-List: started some covering DJ Good for you. I covered in two pieces, one each side. As far as I know rib stitching on the horizontals and vertical are optional at the speed of the Piet, check with the manufacturers instructions. today was such a beautiful day. blue sky, 75=B0, slight breeze. All the rich dudes out at Falcon Field were flying thier T-6's, T-28's and Stearmans. I figured why should they have all the fun. I decided to get out of my "N74DV misery pit" and do something. Cleaned out the shop and tried my hand at covering the vertical stab. I can see this is going to be a bit of a learning curve, but it seems like I'll catch the hang of it. Vertical stab is covered but still needs to be stitched and tapes applied. I think I've conjured up a small burst of motivation so I need to ride the wave and go with it. Tomorrow I cover the horiz. stab. ohhh a question..... should I be covering the vert and horiz stabs with one piece or 2 pieces (one on each side) ? I started out doing it as one piece but screwed up so now the vert stab is in 2 pieces.... is this a no-no? DJ Vegh N74DV back in progress (for the time being) Mesa, AZ www.imagedv.com/aircamper ; - The Pietenpol-List Email Forum - http://www.matronics.com/subscription http://www.matronics.com/FAQ/Pietenpol-List.htm http://www.matronics.com/search http://www.matronics.com/browse/pietenpol-list http://www.matronics.com/digest/pietenpol-list http://www.matronics.com/archives http://www.matronics.com/photoshare http://www.matronics.com/pietenpol-list http://www.matronics.com/emaillists ________________________________________________________________________________
Date: Feb 06, 2005
Hi DJ, I did mine with two pieces each. I also found it useful to use the bias tapes when taping around the cureve on the top of the vertical stab. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of DJ Vegh Subject: Pietenpol-List: started some covering today was such a beautiful day. blue sky, 75, slight breeze. All the rich dudes out at Falcon Field were flying thier T-6's, T-28's and Stearmans. I figured why should they have all the fun. I decided to get out of my "N74DV misery pit" and do something. Cleaned out the shop and tried my hand at covering the vertical stab. I can see this is going to be a bit of a learning curve, but it seems like I'll catch the hang of it. Vertical stab is covered but still needs to be stitched and tapes applied. I think I've conjured up a small burst of motivation so I need to ride the wave and go with it. Tomorrow I cover the horiz. stab. ohhh a question..... should I be covering the vert and horiz stabs with one piece or 2 pieces (one on each side) ? I started out doing it as one piece but screwed up so now the vert stab is in 2 pieces.... is this a no-no? DJ Vegh N74DV back in progress (for the time being) Mesa, AZ www.imagedv.com/aircamper ________________________________________________________________________________
Date: Feb 06, 2005
Spruce is what I used, Fred. The spruce struts were the only part of the undercarriage that wasn't damaged during my recent forced landing. Mine are laminated of 1/4" thick pieces of spruce, bonded with resorcinol glue. One advantage of the laminations (in addition to greatly increased strength and resistance to splitting) is the laminations give you a handy guide to use when sanding down the airfoil shape on the struts. Jack Phillips Finishing the repairs to the right aileron today -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of TBYH(at)aol.com Subject: Pietenpol-List: Project Update I started building the fuselage in early November and have it all together including turtledeck and am finishing up work on seats. Floor is on, of course. I haven't put the plywood skins on front sides of fuselage yet as I followed somebody else's example of leaving it off until the seats and controls are all figured out and installed -- makes for easier access. Control stick assembly is next along with landing gear. Hope to cut out steel fitings this week and have it on gear before long. Will post some pics one of these days... Meanwhile it is supposed to be 54 degrees today here in the American Siberia (Wis.) and so I'm thinking about that Model A engine out in the garage. Needs to be totally rebuilt for aircraft use and warm weather makes it easy to mess around in the garage... By the way, the plans call for spruce for landing gear legs/struts (straight axle) -- is this what most use? Regards, Fred B. ________________________________________________________________________________
Date: Feb 06, 2005
I wonder where the rumor started that the tail of the Pietenpol does not need rib stitching. I believe it started 6 or 7 years ago. The empenage DOES need to be rib stitched. It is in the prop wash, and according to any manual, the spacing is even closer together, where stitches are in the prop wash. The tail takes quite a beating from the spirialing slipstream. We need to put a halt to this dangerous rumor. Chuck Gantzer NX770CG ________________________________________________________________________________
Date: Feb 06, 2005
Ditto Corky ________________________________________________________________________________
Subject: Re: started some covering - stitching
Date: Feb 06, 2005
no worries Chuck... I'm stitching. In fact I just finished stitching the vertical stab. I played my Polyfiber DVD, pausing and rewinding and playing as the knot was shown. After the 3rd time of watching the knot being tied I had it. I managed to do the remaining knots on my tail by memory. It's so funny how every one says you will easily remember how to do the knot once you actually do it. I thought for sure I was going to have a hard time with it, but it's true. It's a really easy knot to remember and complete. wooohooo! I just laid my tapes over the knots/ribs and am waiting for it to dry then I'll do the spanwise tapes.... and then the vertical is done. wow! this is a really big kick for my lack of motivation latley. I've got a good boost and it should maintain long enough for me to get the entire set of tail feathers covered and complete up to silver. DJ Vegh N74DV (with a covered vertical tail... yeehaw) Mesa, AZ www.imagedv.com/aircamper ________________________________________________________________________________
Subject: Der Faker Fokker is for sale!
Date: Feb 06, 2005
Check it out! http://www.texasairmuseum.com/pietenpol/index.htm Matt ________________________________________________________________________________
Date: Feb 06, 2005
<001301c50b47$85d41720$edf61e41@ATO> <5.1.0.14.0.20050205195137.0272a8d0(at)pop.telus.net> I found that when it came to rib stitching the wings it went really quickly with a good helper/ assistant/ partner. I was fortunate in that I was able to recruit my wife . We set the wing up on edge with one of us on each side. Towards the end we were doing a rib in 15 minutes and we were still speaking to each other. Now the first rib took a lot longer (about an hour). I used the poly fiber system too. Les >yeah... rib stitching is really not needed on the tail of the Piet, but I >figure I'm gonna need to do it anyway on the wings so I may as well try it >out. Plus I kinda like the look of the stitches and tapes. > >I'll pull out the Poly-Fiber video later today and will attempt to stitch >this evening. > >DJ > >----- Original Message ----- >From: <mailto:leskarin(at)telus.net>Les Schubert >To: pietenpol-list(at)matronics.com >Sent: Saturday, February 05, 2005 7:55 PM >Subject: Re: Pietenpol-List: started some covering > >DJ >Good for you. I covered in two pieces, one each side. As far as I know rib >stitching on the horizontals and vertical are optional at the speed of the >Piet, check with the manufacturers instructions. > > >><djv(at)imagedv.com> >> >>today was such a beautiful day. blue sky, 75=B0, slight breeze. All the >>rich dudes out at Falcon Field were flying thier T-6's, T-28's and >>Stearmans. I figured why should they have all the fun. I decided to >>get out of my "N74DV misery pit" and do something. Cleaned out the shop >>and tried my hand at covering the vertical stab. >> >>I can see this is going to be a bit of a learning curve, but it seems >>like I'll catch the hang of it. Vertical stab is covered but still needs >>to be stitched and tapes applied. >> >>I think I've conjured up a small burst of motivation so I need to ride >>the wave and go with it. Tomorrow I cover the horiz. stab. >> >>ohhh a question..... should I be covering the vert and horiz stabs with >>one piece or 2 pieces (one on each side) ? I started out doing it as one >>piece but screwed up so now the vert stab is in 2 pieces.... is this a no-no? >> >>DJ Vegh >>N74DV back in progress (for the time being) >>Mesa, AZ >>www.imagedv.com/aircamper >> >> >> >> >> >> >> >> >>; - The Pietenpol-List Email Forum - >> >>http://www.matronics.com/subscription >>http://www.matronics.com/FAQ/Pietenpol-List.htm >>http://www.matronics.com/search >>http://www.matronics.com/browse/pietenpol-list >>http://www.matronics.com/digest/pietenpol-list >>http://www.matronics.com/archives >>http://www.matronics.com/photoshare >>http://www.matronics.com/pietenpol-list >>http://www.matronics.com/emaillists> ________________________________________________________________________________
Date: Feb 06, 2005
Save this in a secure place Chuck. That will save you having to do a new one a couple of years from now. It seems that we have gone through this before a few times over the years. Is it the knotting that's bothering folks? here's a little jig that can give you practice before the real thing; Clif ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: started some covering > > I wonder where the rumor started that the tail of the Pietenpol does not need > rib stitching. I believe it started 6 or 7 years ago. The empenage DOES > need to be rib stitched. It is in the prop wash, and according to any manual, > the spacing is even closer together, where stitches are in the prop wash. The > tail takes quite a beating from the spirialing slipstream. We need to put a > halt to this dangerous rumor. > > Chuck Gantzer > NX770CG > > ________________________________________________________________________________
Date: Feb 07, 2005
When I covered my wings, I did the rib-stitching by myself, with the wing laying flat on two sawhorses. Did the left wing in 12 hours of solid work, with breaks just for eating and nature calls. Next day I could hardly move, from all the ducking under the wing and maneuvering the needle. When it came time to do the right wing, I spaced the work out over a week and found it much more comfortable. It would have been great to have a helper and stand the wing up vertically. Jack -----Original Message----- I found that when it came to rib stitching the wings it went really quickly with a good helper/ assistant/ partner. I was fortunate in that I was able to recruit my wife . We set the wing up on edge with one of us on each side. Towards the end we were doing a rib in 15 minutes and we were still speaking to each other. Now the first rib took a lot longer (about an hour). I used the poly fiber system too. Les ________________________________________________________________________________
Date: Feb 07, 2005
The lack of tail ribstitching should not be classified as "a dangerous rumor", as Bernard Pietenpol never stitched the tail surfaces on any of his airplanes, and I never stitched any of them on my Pietenpol airplanes either. If the fabric is stuck properly to the ribs, this is more than sufficient. Forrest Lovley Jordan MN ________________________________________________________________________________
Date: Feb 07, 2005
The operative word in this statement is "IF". The question here is "why not rib-stitch the tail surfaces?" I can't believe anyone who would go to all the trouble to build their own airplane would then try to eliminate a couple hours extra work to avoid rib stitching the tail. If this corner is cut, it makes you wonder what other corners the builder would cut, possibly compromising safety. It is obviously safer to stitch it. And it is good practice before going on to stitching the wings. Jack Phillips -----Original Message----- The lack of tail ribstitching should not be classified as "a dangerous rumor", as Bernard Pietenpol never stitched the tail surfaces on any of his airplanes, and I never stitched any of them on my Pietenpol airplanes either. If the fabric is stuck properly to the ribs, this is more than sufficient. Forrest Lovley Jordan MN ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: building progress on NX799DB
Date: Feb 07, 2005
Hey guys, Somebody asked for updates, here's mine. Got my Model A back from my rebuilder and decided to mount it on a test stand so I can work all the kinks out with easy access. Got my prop and just have to plumb everything and start her up!! Built a "scooped out" rear seat out of Eglass so it comforms to my bottom, and drops me down about two inches into the cockpit. Was careful to leave clearence for elevator cables. Built a curved front seat out of carbon fiber just to see, and it is much more comfortable, in case I ever fly anybody. We're covered, have to rib stitch and tape the whole thing and finish. Do the sheet metal and all the hundreds of little things. Hoped to have her at Brodhead, but not this year. Douwe ________________________________________________________________________________
Date: Feb 07, 2005
Subject: UV blocking, Rustoleum Paint on fabric
I'm trying to find some info on the ability of Rustoleum oil based paint in regard to it's ability to protect fabric from UV damage. What level of protection does Rustoleum provide in UV absorption? (I can't find any info on this subject) and out here in the Southwest, we have very strong and harsh light (ask DJ...) I only have experience in doping a silver coat of butyrate (with silver added) over nitrate, and then using a focused Mag flashlight to check light penetration. Thanks, S.B. ________________________________________________________________________________
Date: Feb 07, 2005
d.com> Jack And while we are at it lets put extra nails and screws in all the joints because you know maybe the glue won't hold and I am sure there are plenty of other places we can overkill too. If Bernie Pietenpol, and the covering manufacturer, and books available on the subject provide guidelines why not listen to them. Sure if you have nothing better to do with your time go ahead. And if you think about it, what is the purpose of the stitching. It is to keep the fabric firmly in place where you can get a low pressure area on the outside (or high pressure on the inside). So you need it on the top of the wing and on the bottom because of Bernie's curved up area. Anyway my plane is a single place so the only neck I am risking is mine. Les > > >The operative word in this statement is "IF". The question here is "why >not rib-stitch the tail surfaces?" I can't believe anyone who would go >to all the trouble to build their own airplane would then try to >eliminate a couple hours extra work to avoid rib stitching the tail. If >this corner is cut, it makes you wonder what other corners the builder >would cut, possibly compromising safety. It is obviously safer to >stitch it. And it is good practice before going on to stitching the >wings. > >Jack Phillips > >-----Original Message----- > >The lack of tail ribstitching should not be classified as "a dangerous >rumor", as Bernard Pietenpol never stitched the tail surfaces on any of >his >airplanes, and I never stitched any of them on my Pietenpol airplanes >either. If the >fabric is stuck properly to the ribs, this is more than sufficient. >Forrest Lovley >Jordan MN > > ________________________________________________________________________________
Date: Feb 07, 2005
Under the "If Bernie didn't do it, it's overkill" philosophy, I guess you don't use seatbelts either. ----- Original Message ----- From: Les Schubert To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 8:42 AM Subject: RE: Pietenpol-List: started some covering ... I am sure there are plenty of other places we can overkill too. If Bernie Pietenpol, and the covering manufacturer, and books available on the subject provide guidelines why not listen to them. Sure if you have nothing better to do with your time go ahead. ________________________________________________________________________________
Date: Feb 07, 2005
Don't know about Rustoleum for fabric, but I just today bought the Dupont automotive paint needed to do the entire Piete N-1033B. Fabric is in Stits thru the silver coat, I can highly recommend this over normal dope. The Polybrush two coats filled the fabric, the Polyspray is already cut and filled with proper amount of al to silver it up and protect from UV. You just open the cans and use as is, after stirring. More expensive than dope but based on my experience, worth every penny. Bought a HVLP top filling spry gun from HD for $80, at 40 psi, no runs no drips and no errors. Took approx 2 gallons of polybrush, and 3 gallons of polyspry to do entire plane. Bought 1 gal. Dupont acrylic/polyurethane plus 1 qrt of the plasticizer needed (the stuff the pro painters add to automotive paints so they can be painted on plastic flexible parts like car bumpers, solvent reducer required to spry. The entire auto paint bill was $180. May need additional $50 in auto paint to do nifty trim. A little paint goes a long way if you've properly filled the fabric with Stits. Good luck. Gordon Bowen Original Message: ----------------- From: N321TX(at)wmconnect.com Date: Mon, 7 Feb 2005 11:06:57 EST Subject: Pietenpol-List: UV blocking, Rustoleum Paint on fabric I'm trying to find some info on the ability of Rustoleum oil based paint in regard to it's ability to protect fabric from UV damage. What level of protection does Rustoleum provide in UV absorption? (I can't find any info on this subject) and out here in the Southwest, we have very strong and harsh light (ask DJ...) I only have experience in doping a silver coat of butyrate (with silver added) over nitrate, and then using a focused Mag flashlight to check light penetration. Thanks, S.B. ________________________________________________________________________________
Date: Feb 07, 2005
Bernard Pietenpol DID use seat belts...I still have the original one I took out of Pietenpol Scout N-12942. Bernard Pietenpol DID NOT stitch the fabric on the tail surfaces or the ailerons...it wasn't needed if the fabric was stuck to the ribs of the tail surfaces properly. I still have the original fabric from the rudders of N-12937 and N-12942. The last airplane he built, N-899H, also still has its original fabric...with no stitching of the tail surfaces or ailerons. Forrest Lovley Jordan MN ________________________________________________________________________________
Date: Feb 07, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
I think to not stitch the tail surfaces is quite foolish, even if Bernie or others didn't. When you look back over your shoulders, the propwash buffets those surfaces and brace cables pretty good----I know the fabric glues are good but I chose not to glue the fabric to any ribs so that the heat taughtening process could be equal and complete before rib stitiching. I'm sure there are lots of things we would short-cut in building and still live many years to talk about it, but..... Mike C. 6 years and 300 hours ________________________________________________________________________________
Date: Feb 07, 2005
Guys, Rib stitching can be REALLY hard on the back, even when you put the wing vertical. There IS a trick that makes it MUCH faster and easier. First lay out where all the holes are going to be on each side of each rib by punching a hole with the needle (ALL the holes on both sides of the wing). You can get them really straight by snapping a line and they look REALLY professional that way. Next you get one needle for EACH RIB. Sit on a rolling chair and look through one hole to place the needle through the opposite side hole one rib after another. All you do is roll down the wing till you have the needles all through to the other side. Roll around to the other side and pull the needle through each one and pass it back the same way on the other side of the rib. Roll around the first side, tie the knot and pass the needles through for the next stitch. By repeating the needle motions over and over you save a TON of time walking around and your back stays comfortable in the chair. When you have done a few rows of stitches it is time to hoist the wing higher so the stitches are at eye level again (I hung my wing from pulleys from the hangar roof joist and moving it lets you stretch ever 10 minutes or so). Using this method (if I remembered all the steps) you will save DAYS and end up making you much nicer to your dog and wife when you get home. With a moderately bright light (a couple or three 40 watt bulbs spaced across each side) it is easy to pass the needle through and you don't need help from a second person. The cost of the extra needles is well worth it and I'm sure we could pass them on to the next guy to recover some cost if you are a Scott like me. Hank J ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 7:19 AM Subject: RE: Pietenpol-List: started some covering When I covered my wings, I did the rib-stitching by myself, with the wing laying flat on two sawhorses. Did the left wing in 12 hours of solid work, with breaks just for eating and nature calls. Next day I could hardly move, from all the ducking under the wing and maneuvering the needle. When it came time to do the right wing, I spaced the work out over a week and found it much more comfortable. It would have been great to have a helper and stand the wing up vertically. Jack -----Original Message----- I found that when it came to rib stitching the wings it went really quickly with a good helper/ assistant/ partner. I was fortunate in that I was able to recruit my wife . We set the wing up on edge with one of us on each side. Towards the end we were doing a rib in 15 minutes and we were still speaking to each other. Now the first rib took a lot longer (about an hour). I used the poly fiber system too. Les ________________________________________________________________________________
Date: Feb 07, 2005
I did something very similar. The wing was stood on its nose in a little rack made for the purpose (padded, same shape as the L/E). Next, I made 15 needles out of welding rod, punched all the holes. I ran all the needles through the holes on each rib and used a "starting knot" at each site (this is approved by Stitts). As each rib was finished, I moved on to the next one. I stitched the tail feathers simply because they are stitched on the J-3.....Carl Vought ----- Original Message ----- From: hjarrett To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 5:22 PM Subject: Re: Pietenpol-List: started some covering Guys, Rib stitching can be REALLY hard on the back, even when you put the wing vertical. There IS a trick that makes it MUCH faster and easier. First lay out where all the holes are going to be on each side of each rib by punching a hole with the needle (ALL the holes on both sides of the wing). You can get them really straight by snapping a line and they look REALLY professional that way. Next you get one needle for EACH RIB. Sit on a rolling chair and look through one hole to place the needle through the opposite side hole one rib after another. All you do is roll down the wing till you have the needles all through to the other side. Roll around to the other side and pull the needle through each one and pass it back the same way on the other side of the rib. Roll around the first side, tie the knot and pass the needles through for the next stitch. By repeating the needle motions over and over you save a TON of time walking around and your back stays comfortable in the chair. When you have done a few rows of stitches it is time to hoist the wing higher so the stitches are at eye level again (I hung my wing from pulleys from the hangar roof joist and moving it lets you stretch ever 10 minutes or so). Using this method (if I remembered all the steps) you will save DAYS and end up making you much nicer to your dog and wife when you get home. With a moderately bright light (a couple or three 40 watt bulbs spaced across each side) it is easy to pass the needle through and you don't need help from a second person. The cost of the extra needles is well worth it and I'm sure we could pass them on to the next guy to recover some cost if you are a Scott like me. Hank J ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 7:19 AM Subject: RE: Pietenpol-List: started some covering When I covered my wings, I did the rib-stitching by myself, with the wing laying flat on two sawhorses. Did the left wing in 12 hours of solid work, with breaks just for eating and nature calls. Next day I could hardly move, from all the ducking under the wing and maneuvering the needle. When it came time to do the right wing, I spaced the work out over a week and found it much more comfortable. It would have been great to have a helper and stand the wing up vertically. Jack -----Original Message----- I found that when it came to rib stitching the wings it went really quickly with a good helper/ assistant/ partner. I was fortunate in that I was able to recruit my wife . We set the wing up on edge with one of us on each side. Towards the end we were doing a rib in 15 minutes and we were still speaking to each other. Now the first rib took a lot longer (about an hour). I used the poly fiber system too. Les ________________________________________________________________________________
Date: Feb 07, 2005
I agree with Mike. All rag and tube airplanes I've owned had the tail feathers rib stitched. I, too, intend to heat shrink the fabric before I rib stitch and not to glue the fabric to the ribs. It will also make it easier when you have to re-cover the plane. The tail surfaces get a lot more beating than you would think. However, I'm sure there are many examples of planes out there flying with glued-only fabric on the tail feathers and are flying quite nicely. Doc --- Michael D Cuy wrote: > > > I think to not stitch the tail surfaces is quite > foolish > > > > > > Contributions > any other > Forums. > >
http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://mobile.yahoo.com/maildemo ________________________________________________________________________________
Date: Feb 07, 2005
Forrest Can you provide us with some idea of how/where Bernie attached the belts. This just a curiosity item for me, my plane is finished and I am happy with my attachments. Les > >Bernard Pietenpol DID use seat belts...I still have the original one I took >out of Pietenpol Scout N-12942. Bernard Pietenpol DID NOT stitch the >fabric on >the tail surfaces or the ailerons...it wasn't needed if the fabric was stuck >to the ribs of the tail surfaces properly. I still have the original fabric >from the rudders of N-12937 and N-12942. The last airplane he built, >N-899H, >also still has its original fabric...with no stitching of the tail >surfaces or >ailerons. >Forrest Lovley >Jordan MN > > ________________________________________________________________________________
Subject: Spruce or Fir?
Date: Feb 08, 2005
I had a question regarding Spruce or Fir for my Piet? From what I understand Spruce has the best strength to weight ratio, but it also has its price tag and shipping costs from Spruce Aircraft. Fir weighs a little more, but does not cost as much and I can get aircraft grade Fir here were I live, within an hours drive. Have many builders used Fir, and if so how much extra weight did it add to the airframe? I guess the question is $$ vs. pounds. Thanks. I had a question regarding Spruce or Fir for my Piet? From what I understand Spruce has the beststrength to weight ratio, but it also has its price tag and shipping costs from Spruce Aircraft. Fir weighs a little more, but does not cost as much and I can get aircraft grade Fir here were I live, within an hours drive. Have many builders used Fir, and if so how much extra weight did it add to the airframe? I guess the question is $$ vs. pounds. Thanks. ________________________________________________________________________________
Date: Feb 07, 2005
In a message dated 2/7/05 1:46:26 PM Central Standard Time, FTLovley(at)aol.com writes: << Bernard Pietenpol DID NOT stitch the fabric on the tail surfaces or the ailerons...it wasn't needed if the fabric was stuck to the ribs of the tail surfaces properly. >> I hadn't realized this. So, this is the source. However, I would still highly recomend stitching everything. It's not much work, and very good insurance. Chuck Gantzer ________________________________________________________________________________
Subject: Re:I FINALLY got to fly N327BC!!!!
Date: Feb 07, 2005
Well, I finally got to fly my plane today. I struggled since 1995. I wrestled with the FAA (and they turned out to be great, by the way) - I've wrestled with the wind and cold weather for over a month. I got to fly her twice this afternoon. No surprises. She flew hands off (but how would i know, I was pretty busy hanging on!) I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - AMAZING! - to break ground in a plane you built from sticks, plywood, fabric and pieces of metal. You and your family lived every single up and down for over 9 years. You worked almost every spare hour you could give up. You spent every single surplus dollar you had. You answered and explained and described and defended and discussed and cussed and dreamed and did without and prayed that that sucker would work - someday. Over and over and over and over and over again. And it did. It did! How TRULY amazing. You guys that are still building.... DO NOT QUIT! I promise you - it's a life altering event. I'll post some pictures in the next few days..... Now. Get back to the shop and get TO WORK!!!! bert in Florida! ________________________________________________________________________________
Date: Feb 08, 2005
Congratulations Bert, I can see your grin from here!! :) Mike Green Romsey AUSTRALIA ________________________________________________________________________________
Subject: HVLP reccomendations
Date: Feb 07, 2005
Since Poly-Spray and color coats are in my future I am trying to figure out what type of equipment to buy for spraying. My dad want's me to buy an $800 Accuspray HVLP unit but I've heard some of the locals out here at the field say that a cheap Home Depot unit does just fine. I'd REALLY love to save the money I'd spend on an Accuspray and use that towards a transponder. Would a cheap HVLP unit get the job done? I'm not looking for glass smooth paint but I do want it to look somewhat good. DJ ________________________________________________________________________________
Date: Feb 07, 2005
Subject: Re: Spruce or Fir?
<020820050314.20670.42082E8E000BEA26000050BE22070009530A02070B9D0E069F0D(at)comcast.net> Go to the chart at the bottom of this page and compare properties; http://clifdawson.ca/Tools_and_Tips.html Then to the Matronic search at the bottom of every email and punch in fir and spruce. This will keep you busy for a long time. :-) Clif ----- Original Message ----- From: bpjardine(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 7:14 PM Subject: Pietenpol-List: Spruce or Fir? I had a question regarding Spruce or Fir for my Piet? From what I understand Spruce has the best strength to weight ratio, but it also has its price tag and shipping costs from Spruce Aircraft. Fir weighs a little more, but does not cost as much and I can get aircraft grade Fir here were I live, within an hours drive. Have many builders used Fir, and if so how much extra weight did it add to the airframe? I guess the question is $$ vs. pounds. Thanks. ________________________________________________________________________________
Date: Feb 07, 2005
Subject: Re: Der Faker Fokker is for sale!
<004001c50d63$8ea182c0$284fd618@knology.net> And then there's Rotec...... http://www.rotecradialengines.com/ Clif > > Do you think you could get interested in a kit engine??? There is a kit of > castings for a 7-cylinder and a 5-cylinder available under the name of HCI, > which was designed by Jack Hereford of New Haven, MO. He advertises in > "machinist's Workshop" magazine.The cylinders and pistons are VW. There's at > least one at Brodhead..maybe more. You'd have to talk to Jack Hereford about > kit contents and cost.....Carl Vought----- Original Message ----- > From: "Steve Ruse" <steve(at)wotelectronics.com> > To: > Sent: Monday, February 07, 2005 12:57 AM > Subject: RE: Pietenpol-List: Der Faker Fokker is for sale! > > ________________________________________________________________________________
Date: Feb 08, 2005
Subject: don't send me this shit
SAVE_MONEY In a message dated 2/7/2005 9:32:34 PM Pacific Standard Time, djv(at)imagedv.com writes: Since Poly-Spray and color coats are in my future I am trying to figure out what type of equipment to buy for spraying. My dad want's me to buy an $800 Accuspray HVLP unit but I've heard some of the locals out here at the field say that a cheap Home Depot unit does just fine. I'd REALLY love to save the money I'd spend on an Accuspray and use that towards a transponder. Would a cheap HVLP unit get the job done? I'm not looking for glass smooth paint but I do want it to look somewhat good. DJ ________________________________________________________________________________
Date: Feb 07, 2005
I bought my spruce from the local lumber yard. Every square inch is not A/C grade so you have to cut it up to seperate out the good stuff. There is as lot of waste, but you still save well over half the cost of ordering ACS&S stuff. You need a table saw and a good blade. I bought 2"x6" of different lengths. Buy the vertical grain or what is called "quarter sawn" pieces. Doc --- bpjardine(at)comcast.net wrote: > I had a question regarding Spruce or Fir for my > Piet? From what I understand Spruce has the best > strength to weight ratio, but it also has its price > tag and shipping costs from Spruce Aircraft. Fir > weighs a little more, but does not cost as much and > I can get aircraft grade Fir here were I live, > within an hours drive. Have many builders used Fir, > and if so how much extra weight did it add to the > airframe? I guess the question is $$ vs. pounds. Thanks. __________________________________ http://my.yahoo.com ________________________________________________________________________________
<00c001c50da5$928f7fd0$d2705118@dawsonaviation>
Date: Feb 08, 2005
Anybody know how much those are? Matt ----- Original Message ----- From: "Clif Dawson" <CDAWSON5854(at)shaw.ca> Subject: Re: Pietenpol-List: Der Faker Fokker is for sale! > > And then there's Rotec...... > > http://www.rotecradialengines.com/ > > Clif > ________________________________________________________________________________
Date: Feb 08, 2005
WAY TO GO, BERT!!! There's no feeling quite like it, is there? Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Bert Conoly Subject: Pietenpol-List: Re:I FINALLY got to fly N327BC!!!! Well, I finally got to fly my plane today. I struggled since 1995. I wrestled with the FAA (and they turned out to be great, by the way) - I've wrestled with the wind and cold weather for over a month. I got to fly her twice this afternoon. No surprises. She flew hands off (but how would i know, I was pretty busy hanging on!) I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - AMAZING! - to break ground in a plane you built from sticks, plywood, fabric and pieces of metal. You and your family lived every single up and down for over 9 years. You worked almost every spare hour you could give up. You spent every single surplus dollar you had. You answered and explained and described and defended and discussed and cussed and dreamed and did without and prayed that that sucker would work - someday. Over and over and over and over and over again. And it did. It did! How TRULY amazing. You guys that are still building.... DO NOT QUIT! I promise you - it's a life altering event. I'll post some pictures in the next few days..... Now. Get back to the shop and get TO WORK!!!! bert in Florida! ________________________________________________________________________________
Date: Feb 08, 2005
I bought an axis HVLP system to spray the expensive Aerothane polyurethane paint. I wouldn't recommend it. By a cheap spray gun and use PolyTone, rather than Aerothane. Repairs are much easier and the Aerothane is difficult to spray (at least with the HVLP setup) Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh Subject: Pietenpol-List: HVLP reccomendations Since Poly-Spray and color coats are in my future I am trying to figure out what type of equipment to buy for spraying. My dad want's me to buy an $800 Accuspray HVLP unit but I've heard some of the locals out here at the field say that a cheap Home Depot unit does just fine. I'd REALLY love to save the money I'd spend on an Accuspray and use that towards a transponder. Would a cheap HVLP unit get the job done? I'm not looking for glass smooth paint but I do want it to look somewhat good. DJ ________________________________________________________________________________
Date: Feb 08, 2005
Usually Bernard just screwed a steel loop into the seat frame...later he attached that steel loop to the seat frame and then a steel strap from the loop to the bottom longeron under the seat. Forrest Lovley ________________________________________________________________________________
Date: Feb 08, 2005
For the record...I'm not recommending that anyone stitch or not stitch their tail surfaces on their airplanes. I'm just correcting the statements made by people on this list concerning "rumors" about how Bernard really built his airplanes. Forrest Lovley Jordan MN ________________________________________________________________________________
Date: Feb 08, 2005
0E069F0D(at)comcast.net> Bert-- THE fun has JUST begun !!!! Way to go !!!! Mike C. ________________________________________________________________________________
Date: Feb 08, 2005
<00c001c50da5$928f7fd0$d2705118@dawsonaviation> <001101c50db0$f1799750$eed1af18@hal> report For some reason I have $20k stuck in my head when I look at those. I can't tell you where I got it though. There are two or three companies making small radials that are usually at OshKosh, I've spoken to them before and I don't remember an exact price, but I know they weren't cheap. Isn't someone on this list working on a Rotec powered Aircamper? Is it you Clif? Steve Ruse Dallas, TX Quoting Matt Lansford : > > Anybody know how much those are? > > Matt > > ----- Original Message ----- > From: "Clif Dawson" <CDAWSON5854(at)shaw.ca> > To: > Sent: Tuesday, February 08, 2005 12:15 AM > Subject: Re: Pietenpol-List: Der Faker Fokker is for sale! > > > > > > And then there's Rotec...... > > > > http://www.rotecradialengines.com/ > > > > Clif > > > > ________________________________________________________________________________
Date: Feb 08, 2005
Nice work Bert, please post a picture of your masterpiece. I am now logging off and heading for the workshop too. Rick Holland > > > > Well, I finally got to fly my plane today. I struggled since 1995. I > wrestled with the FAA (and they turned out to be great, by the way) - I've > wrestled with the wind and cold weather for over a month. > > I got to fly her twice this afternoon. No surprises. She flew hands off > (but how would i know, I was pretty busy hanging on!) > > I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - > AMAZING! - to break ground in a plane you built from sticks, plywood, fabric > and pieces of metal. You and your family lived every single up and down for > over 9 years. You worked almost every spare hour you could give up. You > spent every single surplus dollar you had. You answered and explained and > described and defended and discussed and cussed and dreamed and did without > and prayed that that sucker would work - someday. Over and over and over and > over and over again. > > And it did. It did! > > How TRULY amazing. > > You guys that are still building.... DO NOT QUIT! I promise you - it's a > life altering event. > I'll post some pictures in the next few days..... > > Now. Get back to the shop and get TO WORK!!!! > > bert in Florida! > -- Rick Holland ________________________________________________________________________________
Date: Feb 08, 2005
Congratulations, Bert! If you can rack up 40 hours on it by April 12 you could fly it to Sun 'n Fun . . .just kidding! (although it would be great to see it) Mark Hodgson ________________________________________________________________________________
Date: Feb 08, 2005
Congratulations Bert. It is so good to read great reports. Alex Sloan -------------- Original message -------------- Well, I finally got to fly my plane today. I struggled since 1995. I wrestled with the FAA (and they turned out to be great, by the way) - I've wrestled with the wind and cold weather for over a month. I got to fly her twice this afternoon. No surprises. She flew hands off (but how would i know, I was pretty busy hanging on!) I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - AMAZING! - to break ground in a plane you built from sticks, plywood, fabric and pieces of metal. You and your family lived every single up and down for over 9 years. You worked almost every spare hour you could give up. You spent every single surplus dollar you had. You answered and explained and described and defended and discussed and cussed and dreamed and did without and prayed that that sucker would work - someday. Over and over and over and over and over again. And it did. It did! How TRULY amazing. You guys that are still building.... DO NOT QUIT! I promise you - it's a life altering event. I'll post some pictures in the next few days..... Now. Get back to the shop and get TO WORK!!!! bert in Florida! Congratulations Bert. It is so good to read great reports. Alex Sloan
Well, I finally got to fly my plane today. I struggled since 1995. I wrestled with the FAA (and they turned out to be great, by the way) -I've wrestled with the wind and cold weather for over a month. I got to fly her twice this afternoon. No surprises. She flew hands off (but how would i know, I was pretty busy hanging on!) I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - AMAZING! -to break ground in a plane you built from sticks, plywood,fabric and pieces of metal. You and your family lived every single up and down for over 9 years. You worked almost every spare hour you could give up. You spent every single surplus dollar you had. You answered and explained and described and defended and discussed and cussed and dreamed and did without and prayed that that sucker would work - someday. Over and over and over and over and over again. And it did. It did! How TRULY amazing. You guys that are still building.... DO NOT QUIT! I promise you - it's a life altering event. I'll post some pictures in the next few days..... Now. Get back to the shop and get TO WORK!!!! bert in Florida! ________________________________________________________________________________
Subject: Corvair College in New England
Date: Feb 08, 2005
Hi Corvair people, I'm interested in getting a Corvair College going at the EAA 106 hangar in Lawrence, Mass. (about 45 car-minutes north of Boston) sometime in September or October. Anyone interested in attending should send me an e-mail--I'd like to have enough possible attendees to persuade William Wynne that it would be worth it; he's never done one in the Northeast and has some interest in the idea but needs convincing. We have the facility and an active EAA chapter, and it's a great place to visit even if you're not a Sox or Pats fan! Mark Hodgson mhodgson(at)bu.edu P.S. Please keep "Corvair College" in the subject header to avoid spamicide. ________________________________________________________________________________
Date: Feb 08, 2005
I hauled mine into the living room. Set it on two chairs and suspended it with bungee cords from the ceiling fan and went at it. Two days with the help of my wife. Made for a cool conversation piece. Stevee ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Carl Vought Subject: Re: Pietenpol-List: started some covering I did something very similar. The wing was stood on its nose in a little rack made for the purpose (padded, same shape as the L/E). Next, I made 15 needles out of welding rod, punched all the holes. I ran all the needles through the holes on each rib and used a "starting knot" at each site (this is approved by Stitts). As each rib was finished, I moved on to the next one. I stitched the tail feathers simply because they are stitched on the J-3.....Carl Vought ----- Original Message ----- From: hjarrett <mailto:hjarrett(at)hroads.net> To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 5:22 PM Subject: Re: Pietenpol-List: started some covering Guys, Rib stitching can be REALLY hard on the back, even when you put the wing vertical. There IS a trick that makes it MUCH faster and easier. First lay out where all the holes are going to be on each side of each rib by punching a hole with the needle (ALL the holes on both sides of the wing). You can get them really straight by snapping a line and they look REALLY professional that way. Next you get one needle for EACH RIB. Sit on a rolling chair and look through one hole to place the needle through the opposite side hole one rib after another. All you do is roll down the wing till you have the needles all through to the other side. Roll around to the other side and pull the needle through each one and pass it back the same way on the other side of the rib. Roll around the first side, tie the knot and pass the needles through for the next stitch. By repeating the needle motions over and over you save a TON of time walking around and your back stays comfortable in the chair. When you have done a few rows of stitches it is time to hoist the wing higher so the stitches are at eye level again (I hung my wing from pulleys from the hangar roof joist and moving it lets you stretch ever 10 minutes or so). Using this method (if I remembered all the steps) you will save DAYS and end up making you much nicer to your dog and wife when you get home. With a moderately bright light (a couple or three 40 watt bulbs spaced across each side) it is easy to pass the needle through and you don't need help from a second person. The cost of the extra needles is well worth it and I'm sure we could pass them on to the next guy to recover some cost if you are a Scott like me. Hank J ----- Original Message ----- From: Phillips, Jack <mailto:jphillip(at)alarismed.com> To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 7:19 AM Subject: RE: Pietenpol-List: started some covering When I covered my wings, I did the rib-stitching by myself, with the wing laying flat on two sawhorses. Did the left wing in 12 hours of solid work, with breaks just for eating and nature calls. Next day I could hardly move, from all the ducking under the wing and maneuvering the needle. When it came time to do the right wing, I spaced the work out over a week and found it much more comfortable. It would have been great to have a helper and stand the wing up vertically. Jack -----Original Message----- I found that when it came to rib stitching the wings it went really quickly with a good helper/ assistant/ partner. I was fortunate in that I was able to recruit my wife . We set the wing up on edge with one of us on each side. Towards the end we were doing a rib in 15 minutes and we were still speaking to each other. Now the first rib took a lot longer (about an hour). I used the poly fiber system too. Les ________________________________________________________________________________
Date: Feb 08, 2005
I bought an off the shelf HVLP for $80 at Home Depot, sprayed at 35 psi at the compressor and expect got 10-15 psi after 30' of hose and letdown in pressure that comes with pulling the trigger. The sprayer has a top gravity feed (which I love, compared to siphon), very easy clean up. Just finished putting on the automotive paint (duPont), with plasticizer Bulldog added to keep it flexible. Polyurethane/acrylic paint with curative. Piete took exactly one gallon of paint, 1 qt of reducer solvent, 1 pt. of isocyanante curative, 1 pt. of Bulldog additive. Total $180, and I still have 3/4 gal of reducer plus 1/2 qrt bulldog left over. The Stits polyspry went on with a run and dryed quickly. The HVLP has very little overspray, and lost material when you set the pressure at 10 psi at the gun as recommended, if you use too much pressure it will overspray like the siphon types. I cannot see buying a sprayer costing 10x more. Good luck Gordon Bowen N-1033B Quasi-Piete Original Message: ----------------- From: DJ Vegh djv(at)imagedv.com Date: Mon, 7 Feb 2005 22:31:06 -0700 Subject: Pietenpol-List: HVLP reccomendations Since Poly-Spray and color coats are in my future I am trying to figure out what type of equipment to buy for spraying. My dad want's me to buy an $800 Accuspray HVLP unit but I've heard some of the locals out here at the field say that a cheap Home Depot unit does just fine. I'd REALLY love to save the money I'd spend on an Accuspray and use that towards a transponder. Would a cheap HVLP unit get the job done? I'm not looking for glass smooth paint but I do want it to look somewhat good. DJ ________________________________________________________________________________
<001901c50d95$fb2d10d0$6501a8c0@Nancy>
Date: Feb 08, 2005
Bert, Yeah, isn't it great!!! Something that you have to experience for yourself. Even though there is nothing like the very first flight, the next couple hundred will be a kick too. Good luck with it and safe flying. Ain't life grand! walt evans NX140DL ----- Original Message ----- From: Bert Conoly To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 11:23 PM Subject: Pietenpol-List: Re:I FINALLY got to fly N327BC!!!! Well, I finally got to fly my plane today. I struggled since 1995. I wrestled with the FAA (and they turned out to be great, by the way) - I've wrestled with the wind and cold weather for over a month. I got to fly her twice this afternoon. No surprises. She flew hands off (but how would i know, I was pretty busy hanging on!) I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - AMAZING! - to break ground in a plane you built from sticks, plywood, fabric and pieces of metal. You and your family lived every single up and down for over 9 years. You worked almost every spare hour you could give up. You spent every single surplus dollar you had. You answered and explained and described and defended and discussed and cussed and dreamed and did without and prayed that that sucker would work - someday. Over and over and over and over and over again. And it did. It did! How TRULY amazing. You guys that are still building.... DO NOT QUIT! I promise you - it's a life altering event. I'll post some pictures in the next few days..... Now. Get back to the shop and get TO WORK!!!! bert in Florida! ________________________________________________________________________________
Date: Feb 08, 2005
Bert, Just curious,,,do you have to fly off 25 hours or 40 hours? walt evans NX140DL ----- Original Message ----- From: Bert Conoly To: pietenpol-list(at)matronics.com Sent: Monday, February 07, 2005 11:23 PM Subject: Pietenpol-List: Re:I FINALLY got to fly N327BC!!!! Well, I finally got to fly my plane today. I struggled since 1995. I wrestled with the FAA (and they turned out to be great, by the way) - I've wrestled with the wind and cold weather for over a month. I got to fly her twice this afternoon. No surprises. She flew hands off (but how would i know, I was pretty busy hanging on!) I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - AMAZING! - to break ground in a plane you built from sticks, plywood, fabric and pieces of metal. You and your family lived every single up and down for over 9 years. You worked almost every spare hour you could give up. You spent every single surplus dollar you had. You answered and explained and described and defended and discussed and cussed and dreamed and did without and prayed that that sucker would work - someday. Over and over and over and over and over again. And it did. It did! How TRULY amazing. You guys that are still building.... DO NOT QUIT! I promise you - it's a life altering event. I'll post some pictures in the next few days..... Now. Get back to the shop and get TO WORK!!!! bert in Florida! ________________________________________________________________________________
Date: Feb 08, 2005
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: Corvair College in New England
, "Hodgson, Mark O" > >Hi Corvair people, > >I'm interested in getting a Corvair College going at the EAA 106 hangar >in Lawrence, Mass. (about 45 car-minutes north of Boston) sometime in >September or October. Anyone interested in attending should send me an >e-mail--I'd like to have enough possible attendees to persuade William >Wynne that it would be worth it; he's never done one in the Northeast >and has some interest in the idea but needs convincing. We have the >facility and an active EAA chapter, and it's a great place to visit even >if you're not a Sox or Pats fan! > >Mark Hodgson >mhodgson(at)bu.edu > >P.S. Please keep "Corvair College" in the subject header to avoid >spamicide. Hi Mark, I hope I'm not raining on your parade, but William & I will be finalizing plans for this year's Ohio Corvair College when he is here this weekend to do his "Night School". My EAA Chapter would prefer to have it in early summer, but my in my initial conversations with William last mnoth, he said that he would probably have to opt for late August or early Fall some time, since their big push over the next few months is going to be to get a backlog of parts built up & also finish the Corvair TriMotor project. I'm definitely not saying don't go for it, but you may have to convince him to work around what we're already planning. I'll be putting the word out about the OH Corvair College once we have the dates nailed down. Also, Congratulations BERT! It's great to hear that one more has taken to the skies. Hope to see you at Brodhead sometime. Cheers! Kip Gardner -- North Canton, OH ________________________________________________________________________________
Date: Feb 08, 2005
Subject: Re: HVLP reccomendations
Re: HVLP I used a $200 Campbell Hauschild HVLP rig with an extra 15' of hose per Stits reccomendation. It worked fine and was quie econamical on material. It is the kind with a suction feed and the hose is 1" flex hose like a vacuum cleaner. Can also check Harbor Freight for HVLP units at decent prices. Regards, Lou Larsen (still fussing with my A engine) ________________________________________________________________________________
Date: Feb 08, 2005
In a message dated 2/7/05 10:24:37 PM Central Standard Time, bconoly(at)earthlink.net writes: << I got to fly her twice this afternoon. No surprises. She flew hands off (but how would i know, I was pretty busy hanging on!) I'll admit it's a bit overwhelming. How truly amazing - I'll repeat it - AMAZING! - to break ground in a plane you built from sticks, plywood, fabric and pieces of metal. >> Bert, Allow me to offer my Congratulations...and a Big YEEEEE HAAAAAAWW !! Chuck G. ________________________________________________________________________________
Subject: Steve Eldredge's Piet
Date: Feb 08, 2005
Someone was asking about Piets in Utah the other day and Steve E. piped up since he's located in Utah. He also piped up (chimed in?) when the discussion turned to using latex house paint. In case anyone wants to know what Steve's plane looks like, it's the "poster child" that the host of our list (Matronics) uses, for example at: http://www.matronics.com/pietenpol-list/index.htm I've always liked the paint scheme that Steve used (British racing green fuselage, silver wings, nose, and fuselage top). And the "Aircamper" logo, and that big "E" on the tail... Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 08, 2005
<004001c50d63$8ea182c0$284fd618@knology.net> <00c001c50da5$928f7fd0$d2705118@dawsonaviation> <001101c50db0$f1799750$eed1af18@hal> <1107874208.4208d1a06421b(at)www.wotelectronics.com> Ain't me but I remember that rumour too. There was one around here that flew many years with a Jake on the nose. I'm not sure about the plane but the engine is now on Vancouver Island, well Saltspring Island to be more accurate. The owner is also newly flying a Piet with a model B on its nose. It resides under a pair of Stranraer tip floats. There's some great stories about THOSE planes around this coast. :-) :-) Clif > > Isn't someone on this list working on a Rotec powered Aircamper? Is it you > Clif? > > Steve Ruse > Dallas, TX > ________________________________________________________________________________
Date: Feb 09, 2005
Thanks for the plug Oscar! I'm piping (popping, chiming) in more now that I've caught up on a back-log of piet emails. Ready for warm weather! Steve E -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Subject: Pietenpol-List: Steve Eldredge's Piet Someone was asking about Piets in Utah the other day and Steve E. piped up since he's located in Utah. He also piped up (chimed in?) when the discussion turned to using latex house paint. In case anyone wants to know what Steve's plane looks like, it's the "poster child" that the host of our list (Matronics) uses, for example at: http://www.matronics.com/pietenpol-list/index.htm I've always liked the paint scheme that Steve used (British racing green fuselage, silver wings, nose, and fuselage top). And the "Aircamper" logo, and that big "E" on the tail... Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: CCW wood screws
Date: Feb 09, 2005
Here's a little puzzle for you antiquers, from a member of the KRNet: ==================== From: "Stephen Jacobs" <askies(at)microlink.zm> Subject: KR> CCW wood screws Date: Wed, 9 Feb 2005 18:28:07 +0200 Some time ago someone gave me a box of stuff that had belonged to someone that was no longer around. I understand that the old timer spent his time restoring old British airplanes - mainly wood (Tiger Moth and Chipmunk?). I was the only airplane guy they knew, so rather than toss it out, it came my way. There were some useful things in there, including a super tubing cutter for the smaller sizes (under 1/2") and turning tools for ferrels, flaring tools etc. Recently I needed some wood screws that were going to be covered with ply forever. I did not know if the moisture in the spruce (6%?) would ultimately corrode steel screws, so I decided to use brass just in case, but where to on a Sunday eve. I remembered seeing some brass wood screws in one of the little drawers in this box of treasures - they were the perfect size. Problem is, they would not do what screws are supposed to do. After a period of total perplexion, I finally realized that they had a left-hand "thread". I turned them backwards and in they went. I was reluctant to bury them under the ply, they may be unique and valuable. I cannot dredge up any logical reason why anyone would make a reverse thread wood screw - maybe to counter harmonic vibrations?? I doubt anyone else has any answers, but worth mentioning. Take care Steve J ====================== Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: severely OT - CCW wood screws & drain water
Date: Feb 09, 2005
I once asked my Earth Science/Physics teacher in high school this question... he was unable to answer it. I felt pretty macho at the time being able to stump the teacher in front of the class. "if our drain water swirls clockwise in the northern hemisphere and it goes ccw in southern hemisphere...... what happens at the equator? does it just go straight down???" I still haven't got a real answer on that.... 13 yrs later. DJ ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> > Oscar--they use LH threaded wood screws in Australia. Just like how their > water swirls > the opposite direction when toilets are flushed, they have winter when we > have summer, etc. > > Full of crap in Ohio, > > Mike C. > ________________________________________________________________________________
Date: Feb 09, 2005
water
water http://www.loc.gov/rr/scitech/mysteries/coriolis.html The Coriolis force is too weak to affect a sink or bathtub full of water... John John Ford john(at)indstate.edu 812-237-8542 >>> djv(at)imagedv.com Wednesday, February 09, 2005 1:38:00 PM >>> I once asked my Earth Science/Physics teacher in high school this question... he was unable to answer it. I felt pretty macho at the time being able to stump the teacher in front of the class. "if our drain water swirls clockwise in the northern hemisphere and it goes ccw in southern hemisphere...... what happens at the equator? does it just go straight down???" I still haven't got a real answer on that.... 13 yrs later. DJ ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> > Oscar--they use LH threaded wood screws in Australia. Just like how their > water swirls > the opposite direction when toilets are flushed, they have winter when we > have summer, etc. > > Full of crap in Ohio, > > Mike C. > ________________________________________________________________________________
From: "gbowen(at)ptialaska.net" <gbowen(at)ptialaska.net>
Date: Feb 09, 2005
How about the harmonics that could be generated by props/engines that turned clockwise? Some of the early British engines did have props that turned clockwise, perhaps those wise early adventurers of aviation discovered CCW screws were less likely to work their way out of the wood vs traditional screws? If so, those of you flying auto engines with CW turning props may have a screw lose and not know it. Gordon Bowen Original Message: ----------------- From: Oscar Zuniga taildrags(at)hotmail.com Date: Wed, 09 Feb 2005 10:43:16 -0600 Subject: Pietenpol-List: CCW wood screws ________________________________________________________________________________
Date: Feb 09, 2005
I bough one of the Harbor Freight HVLP spray units for under $100 and painted my whole Taylorcraft with it using the old time method of nitrate dope, aluminum filled clear and color byuterate. It never missed a beat, uses half the dope I expected and produced a show finish (where I did the prep properly). The whole thing looks GREAT and I will NEVER go back. It was fantastic using a piece of 2" tape on the open window openings with no paper in the holes and NO overspray in the plane (practice first, there IS a technique to getting no overspray). I shot the whole plane with my car sitting 10' away from the open hangar door and there isn't a fleck of paint on my car the factory didn't put there. Hank J. ----- Original Message ----- From: DJ Vegh To: pietenpol-list(at)matronics.com Sent: Tuesday, February 08, 2005 12:31 AM Subject: Pietenpol-List: HVLP reccomendations Since Poly-Spray and color coats are in my future I am trying to figure out what type of equipment to buy for spraying. My dad want's me to buy an $800 Accuspray HVLP unit but I've heard some of the locals out here at the field say that a cheap Home Depot unit does just fine. I'd REALLY love to save the money I'd spend on an Accuspray and use that towards a transponder. Would a cheap HVLP unit get the job done? I'm not looking for glass smooth paint but I do want it to look somewhat good. DJ ________________________________________________________________________________
Date: Feb 09, 2005
Ask any sailor who has "Crossed the Line". It swirls the same way it did in the northern hemisphere. In fact we went all the way to Rio and none of the drains I looked at EVER changed directions. From what a physics major on board said there are so many forces acting on the water that are so much more powerful than choriolis (SP?) he would have been shocked to see one change direction. Didn't explain why the majority started out one direction (not all, but most) but I would imagine in a brand new clean drain choriolis is a bigger % of the total force in effect. Once crud starts accumulating in the pipe with a swirl pattern established there isn't enough "push" from the Earth rotation to overcome it. Hank J ----- Original Message ----- From: "DJ Vegh" <djv(at)imagedv.com> Subject: Re: Pietenpol-List: severely OT - CCW wood screws & drain water > > I once asked my Earth Science/Physics teacher in high school this > question... he was unable to answer it. I felt pretty macho at the time > being able to stump the teacher in front of the class. > > "if our drain water swirls clockwise in the northern hemisphere and it goes > ccw in southern hemisphere...... what happens at the equator? does it just > go straight down???" > > I still haven't got a real answer on that.... 13 yrs later. > > DJ > > ----- Original Message ----- > From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> > > Oscar--they use LH threaded wood screws in Australia. Just like how > their > > water swirls > > the opposite direction when toilets are flushed, they have winter when we > > have summer, etc. > > > > Full of crap in Ohio, > > > > Mike C. > > > > ________________________________________________________________________________
Subject: Re: fabric work
Date: Feb 09, 2005
I bought some of the oil based Rust-oleum to try on the steel parts of my plane and it seemed to work really well. It thins easily and covers well with a small sprayer. I got some on the edges of some fabric areas and it seemed to stick pretty well to the dope (I was using an air-brush trying to get some small steel parts coming through the fabric that the dope didn't want to stick to at all). Question is, how well does the Rust-oleum stick to fabric with dope already on it? I haven't done the trim colors yet and the custom mixed Rust-oleum is MUCH cheaper than dope and has a good finish. Will it last? Anybody tried markings in an oil based paint on a dope finish? Hank J ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: fabric work > > Oscar, > I have oil based enamel Aluminum Rust-oleum on my plane, for the UV > protection, and oil based Red Devil Red, for the trim. The paint is holding up very > well. For the repairs I have done, I have been fairly successful by using duct > tape to remove most of the paint, down to the fabric. Carefully test small > areas. Experiment using the duct tape right on unsanded paint, or use fine sand > paper to remove the gloss, clean the dust off and press the duct tape on, and > RIP off the paint, leaving reletively clean fabric. This probably wouldn't > work with Dope. I finished up cleaning the fabric with plenty of clean rags, > and MEK wearing rubber gloves. Remove the paint, and clean the fabric before > you cut the fabric, or the loose edges are much more difficult to clean. Like > Terry said, be very carefull not to sand into any fibers. 1" to 2" overlap > for the patch, using poly tac, and even blend the edges away with you fingers > and the glue. Finish blending the edges with an iron at temperatures toward the > lower end of the range. You should be able to blend in paint right up to the > patch, and make the patch almost disappear. To save weight on the empenage, I > used 1.8 oz fabric. It's also easier to use the lighter fabric, however, > your patch should be the same weight as what it is covered with. Fabric repair > is not very difficult. Matching the paint will probably be your biggest > challenge, however, repairs give 'er some character !! > > Chuck G. > > ________________________________________________________________________________
Date: Feb 10, 2005
Subject: Re: CCW wood screws
Mike, > > Oscar--they use LH threaded wood screws in Australia. Just like how their > water swirls > the opposite direction when toilets are flushed, they have winter when we > have summer, etc. > > Full of crap in Ohio, And, according to my friend, the compasses all point south down there. Full of more crap in Louisiana. ...Edwin "Once you have flown, you will walk the earth with your eyes turned skyward, for there you have been, there you long to return."-- da Vinci ... www.shreve.net/~elj ________________________________________________________________________________
Date: Feb 10, 2005
In parts of Alaska the compasses point East... Full o' crap in Indiana... John Ford john(at)indstate.edu 812-237-8542 >>> elj(at)shreve.net Thursday, February 10, 2005 11:03:39 AM >>> Mike, > > Oscar--they use LH threaded wood screws in Australia. Just like how their > water swirls > the opposite direction when toilets are flushed, they have winter when we > have summer, etc. > > Full of crap in Ohio, And, according to my friend, the compasses all point south down there. Full of more crap in Louisiana. ...Edwin "Once you have flown, you will walk the earth with your eyes turned skyward, for there you have been, there you long to return."-- da Vinci ... www.shreve.net/~elj ________________________________________________________________________________
Date: Feb 10, 2005
This airplane has T-craft Wings. -- Terry L. Bowden ________________________________________________________________________________
Date: Feb 10, 2005
Subject: any Piets near Atlanda or Brunswick, GA ?
Group-- Gardiner Mason writes below---if any of you can help him please don't reply to the group but rather to the e-mail provided here----susan....... susanandgardiner(at)bellsouth.net >"I am interested in building a pietenpol. Are there any in the Atlanta or >Brunswick Ga. area? I sure would like to see one,or possibly get a demo >ride. I currently have a C140 > > that I keep in Brunswick, Ga., and I want a good woodworking project. I > have the building space and tools and time." > > >Gardiner Mason. ________________________________________________________________________________
Subject: The Fisherman
Date: Feb 10, 2005
Howdy, Pieters; Well, "The Fisherman" is alive and well. He has some pictures on a website that he asked be given to the list, so here it is: http://falconview0.tripod.com/pietenpolhomebuiltairplaneproject I'm just the messenger... Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 12, 2005
Subject: wing setup and trammeling
A nice article with description and photos -but for a stearman is at http://www.bigskystearman.com/AssemblyManual.html Henry Williams ________________________________________________________________________________
From: "Dick and Marge Gillespie" <margdick(at)peoplepc.com>
Subject: Rib-lacing Cord
Date: Feb 12, 2005
Pieters, Don't bitch a whole lot, but I really gotta get this one out for venting and warning others. This is my second time around using Poly Fiber system and am well pleased except for the following: I ran out of cord (500 yds) from the first time and had to re-order (from AS & S) to finish this second project. I was rocking right along almost enjoying the lacing until I received the re-order of cord. It was ordered under the same part number at AS & S but when received it was much heavier cord and much waxier and only 296 yards. P/N 09-03800. Talk about difficult. It was twice as hard to use and took at least twice as long to lace. I was so pissed I called PolyFiber and ask them about it. The tech I talked to said that he was aware of the cord being heavier and said that it was all that was available. So, does anyone know of any other source of cord that I might replace what I am going to dispose of? I have finished with this project but will be doing more lacing in the future, I hope. DickG. Ft. Myers, FL ________________________________________________________________________________
Date: Feb 12, 2005
Don't know about a new source of cord, But I just saved a ton of money on insurance..... Only kidding, but I did by chance just land in your fair city about 2 hours ago (ala Delta 767, not the piet....) Is this the flat cord or the round cord we are talking about? Steve E (at the pink shell) ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick and Marge Gillespie Subject: Pietenpol-List: Rib-lacing Cord Pieters, Don't bitch a whole lot, but I really gotta get this one out for venting and warning others. This is my second time around using Poly Fiber system and am well pleased except for the following: I ran out of cord (500 yds) from the first time and had to re-order (from AS & S) to finish this second project. I was rocking right along almost enjoying the lacing until I received the re-order of cord. It was ordered under the same part number at AS & S but when received it was much heavier cord and much waxier and only 296 yards. P/N 09-03800. Talk about difficult. It was twice as hard to use and took at least twice as long to lace. I was so pissed I called PolyFiber and ask them about it. The tech I talked to said that he was aware of the cord being heavier and said that it was all that was available. So, does anyone know of any other source of cord that I might replace what I am going to dispose of? I have finished with this project but will be doing more lacing in the future, I hope. DickG. Ft. Myers, FL ________________________________________________________________________________
Subject: Re: Rib-lacing Cord
Date: Feb 13, 2005
Steve, It's the round cord. You arrived in Ft.Myers on one of the coldest days of the year. If you'd like to discuss it, call me at 936-2774. DickG. ----- Original Message ----- From: Steve Eldredge To: pietenpol-list(at)matronics.com Sent: Saturday, February 12, 2005 10:29 PM Subject: RE: Pietenpol-List: Rib-lacing Cord Don't know about a new source of cord, But I just saved a ton of money on insurance... Only kidding, but I did by chance just land in your fair city about 2 hours ago (ala Delta 767, not the piet..) Is this the flat cord or the round cord we are talking about? Steve E (at the pink shell) From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick and Marge Gillespie Sent: Saturday, February 12, 2005 8:52 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Rib-lacing Cord Pieters, Don't bitch a whole lot, but I really gotta get this one out for venting and warning others. This is my second time around using Poly Fiber system and am well pleased except for the following: I ran out of cord (500 yds) from the first time and had to re-order (from AS & S) to finish this second project. I was rocking right along almost enjoying the lacing until I received the re-order of cord. It was ordered under the same part number at AS & S but when received it was much heavier cord and much waxier and only 296 yards. P/N 09-03800. Talk about difficult. It was twice as hard to use and took at least twice as long to lace. I was so pissed I called PolyFiber and ask them about it. The tech I talked to said that he was aware of the cord being heavier and said that it was all that was available. So, does anyone know of any other source of cord that I might replace what I am going to dispose of? I have finished with this project but will be doing more lacing in the future, I hope. DickG. Ft. Myers, FL ________________________________________________________________________________
Date: Feb 13, 2005
Subject: Painting control system metal parts
What have you guys used to paint your control system parts (after zinc chromate primer)? Was thinking of using rustoleum spray paint. Lighter colors are better at showing weld cracks correct? -- Rick Holland ________________________________________________________________________________
Date: Feb 13, 2005
Subject: Powdercoating control system parts
You guys that powdercoated your control system parts, how did you deal with the ends of your torque tube and bellcrank tube which fits tightly and rotates in a bearing tube. Can those ends be masked off before coating? And the insides of the bearing tubes as well. -- Rick Holland ________________________________________________________________________________
Date: Feb 13, 2005
Subject: Firewall/crossbrace question
This will seem like a dumb question (I know, I know -- there are no dumb questions, but this one may qualify). On the 1-1/2 by 1-1/4-inch white ash horizontal crossbrace that is shaped to fit around the vertical uprights behind the firewall...and is held in place with 5/16 bolts...should there also be glue between the ash crosspiece and the back of the plywood firewall? This is the piece that the Model A engine "cradle" rests on... I assume there should be glue here, in addition to the bolts...and I assume the plywood "box" (where the mag and radiator will reside) above is also glued to that crosspiece.... Fred B. . ________________________________________________________________________________
Date: Feb 13, 2005
Subject: Re: Painting control system metal parts
Hi Rick: I am really sold on the Poly-Fiber two part white Epoxy primer for all of my metal parts. After seven days of cure time it is a really durable finish. Paint stripper won't touch it and I can't scratch it off with my finger nail and I can polish the primer to a nice sheen for a final finish. I did read that Epoxy primer will get a little chalky after a few years of UV. Zinc chromate as a primer for steel works just fine, but I ran into durability issues when I tried to topcoat the primer with spray enamel. Mike Luther Rick Holland wrote: > > What have you guys used to paint your control system parts (after zinc > chromate primer)? Was thinking of using rustoleum spray paint. > Lighter colors are better at showing weld cracks correct? > > -- > Rick Holland > > ________________________________________________________________________________
Subject: Re: Powdercoating control system parts
Date: Feb 13, 2005
all my stuff was powdercoated. thermal tape is used to mask off areas where powdercoat should not get to. DJ ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Pietenpol-List: Powdercoating control system parts > > You guys that powdercoated your control system parts, how did you deal > with the ends of your torque tube and bellcrank tube which fits > tightly and rotates in a bearing tube. Can those ends be masked off > before coating? And the insides of the bearing tubes as well. > > -- > Rick Holland > > > ________________________________________________________________________________
Date: Feb 13, 2005
Most of the Fabric "glues" will lift the zinc chromate as well. Then there goes your rust protection. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: Mike Luther To: pietenpol-list(at)matronics.com Sent: Sunday, February 13, 2005 3:18 PM Subject: Re: Pietenpol-List: Painting control system metal parts Hi Rick: I am really sold on the Poly-Fiber two part white Epoxy primer for all of my metal parts. After seven days of cure time it is a really durable finish. Paint stripper won't touch it and I can't scratch it off with my finger nail and I can polish the primer to a nice sheen for a final finish. I did read that Epoxy primer will get a little chalky after a few years of UV. Zinc chromate as a primer for steel works just fine, but I ran into durability issues when I tried to topcoat the primer with spray enamel. Mike Luther Rick Holland wrote: What have you guys used to paint your control system parts (after zinc chromate primer)? Was thinking of using rustoleum spray paint. Lighter colors are better at showing weld cracks correct? -- Rick Holland - The Pietenpol-List Email Forum - ________________________________________________________________________________
Date: Feb 13, 2005
Rick, I finally settled on Rust-o-leam appliance epoxy spray paint. In the hardware store with a picture of a fridge or stove on it. Not too many choices for color,,,black,white or almond. Cause I made all the controls black, it worked out. Since most parts can fit into an oven, I sprayed and baked at 250 F for about 1/2 hour. When it cools, it seems to be bullet proof, even MEK wont touch it. I was put onto this by my Mentor AP. walt evans NX140DL ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Pietenpol-List: Painting control system metal parts > > What have you guys used to paint your control system parts (after zinc > chromate primer)? Was thinking of using rustoleum spray paint. > Lighter colors are better at showing weld cracks correct? > > -- > Rick Holland > > ________________________________________________________________________________
Subject: engine available
Date: Feb 13, 2005
I just heard about an engine /prop combo that is available. This is a Chevy (GM) 2.5 Liter - 4 cylinder engine with a wooden prop. A retired Doctor (or dentist) built this engine up for a Corben Baby Ace and it was completed and flew. It was very satisfatory however evidently some family members "encouraged" him to convert to a continental. Auto engine Phobia, I guess. He told me it had a special cam put in to make the max power 92 hp at a lower RPM than what the engine is rated at. I think it also of course comes with carb, prop hub, stacks, etc. This is the same type engine that Larry Harrison flew with for years - I flew that plane several times and it was a sweet engine. It also LOOKS very much like a Model A. Dr Wicker is known here locally as a VERY capable builder and pilot having built and flown a Marquart Charger for years. Anyway - I have no interest in this at all - diont get a thing out of it -I just wanted to pass it along. If anybody wants his telephone number, e-mail me off line. Bert ________________________________________________________________________________ ETAtAhQjeL0f0My6LzBe+kaZaZGxE3VyOAIVAJWiL+ExnS/wn4EWPTZLviU7NfEJ
Date: Feb 14, 2005
Subject: 2.5 Chevy engine
Hi Burt: Did Larry Harrison ( or any one else ) ever do a "how to convert" article for that engine? I was wanting to use the Chevy. 2.5 originally, but knew nothing about what was needed to convert one for ac. use. I now have a fortune invested in a Model A, but may still like to know more about it for a future project. Thanks Leon Stefan in Kansas ________________________________________________________________________________
Date: Feb 14, 2005
Walt Did you use any primer before applying that? That must be a big oven you have to fit a torque tube. Rick H > Rick, > I finally settled on Rust-o-leam appliance epoxy spray paint. In the > hardware store with a picture of a fridge or stove on it. Not too many > choices for color,,,black,white or almond. Cause I made all the controls > black, it worked out. Since most parts can fit into an oven, I sprayed > and baked at 250 F for about 1/2 hour. When it cools, it seems to be bullet > proof, even MEK wont touch it. > I was put onto this by my Mentor AP. > walt evans > NX140DL > ----- Original Message ----- > From: "Rick Holland" <at7000ft(at)gmail.com> > To: > Sent: Sunday, February 13, 2005 11:05 AM > Subject: Pietenpol-List: Painting control system metal parts > > > > > What have you guys used to paint your control system parts (after zinc > > chromate primer)? Was thinking of using rustoleum spray paint. > > Lighter colors are better at showing weld cracks correct? > > > > -- > > Rick Holland > > > > > > > > > > > > > > > > > > > -- Rick Holland ________________________________________________________________________________
Subject: Aileron Horn Question
Date: Feb 14, 2005
From: "Textor, Jack" <jtextor(at)thepalmergroup.com>
Hi all, It' 50 and sunny here in Des Moines, can't wait for spring. What's the consensuses regarding aileron horn construction? The manual says 20 gauge and bend without heat while the plans say 22 guage, all welded with no bend. 4130 only? Anybody just use flat aluminum? Thanks for all the help! Jack Textor Still building ribs ________________________________________________________________________________
Date: Feb 14, 2005
I used .032" 4130, bent and welded. Makes a nice lightweight and very stiff and strong unit. The edge welding is very easy to do and requires little or no filler rod. Makes a nice "antique" touch to the airplane (looks just like the control horns on the Spirit of St. Louis). Drill all holes after welding. Jack Phillips Raleigh, NC (48 F and rain today, but 67 tomorrow) -----Original Message----- Hi all, It' 50 and sunny here in Des Moines, can't wait for spring. What's the consensuses regarding aileron horn construction? The manual says 20 gauge and bend without heat while the plans say 22 guage, all welded with no bend. 4130 only? Anybody just use flat aluminum? Thanks for all the help! Jack Textor Still building ribs ________________________________________________________________________________
Date: Feb 14, 2005
Rick, The cans instructions specifically said not to use primer, so I didn't. The instructions were odd cause it said to apply second coat within 1/2 hour OR after like two weeks. I top coated one piece after one hour, and the second coat attacks the first, and you have a wrinkley mess. Get around this by baking between coats. Yeah, think that the torque tube was the only thing that I let air dry between coats. Try this paint on some scrap. Cut some coat hanger into like 3" pieces and bend a hook on each end. I had a string between two trees in the yard that I would hang the stuff onto while painting. Hold the top of the hook with your fingers on each piece so you can look at and spin the piece around while painting, then hang it. and the next piece etc. then heat the oven to 250 F and pull out the top rack. Two by two carry the pieces inside and hang them from the rack. After about half hour take out and cool by hanging somewhere. You won't be disappointed in the durability. All you've got to lose is about $5.00 for one can walt evans NX140DL PS if you're married, you may want to do this when the wife is out shopping for the day ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Re: Pietenpol-List: Painting control system metal parts > > Walt > > Did you use any primer before applying that? That must be a big oven > you have to fit a torque tube. > > Rick H > > wrote: > > Rick, > > I finally settled on Rust-o-leam appliance epoxy spray paint. In the > > hardware store with a picture of a fridge or stove on it. Not too many > > choices for color,,,black,white or almond. Cause I made all the controls > > black, it worked out. Since most parts can fit into an oven, I sprayed > > and baked at 250 F for about 1/2 hour. When it cools, it seems to be bullet > > proof, even MEK wont touch it. > > I was put onto this by my Mentor AP. > > walt evans > > NX140DL > > ----- Original Message ----- > > From: "Rick Holland" <at7000ft(at)gmail.com> > > To: > > Sent: Sunday, February 13, 2005 11:05 AM > > Subject: Pietenpol-List: Painting control system metal parts > > > > > > > > What have you guys used to paint your control system parts (after zinc > > > chromate primer)? Was thinking of using rustoleum spray paint. > > > Lighter colors are better at showing weld cracks correct? > > > > > > -- > > > Rick Holland > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > Rick Holland > > ________________________________________________________________________________
Subject: Re: Aileron Horn Question
Date: Feb 14, 2005
Jack, My 1934 plans say welded WITH a bend with 22 ga steel. That's what I did. seems very whispy before bending and welding, but after the welding, it's very impressive how strong the horns are. none of them flew off yet! walt evans NX140DL ----- Original Message ----- From: Textor, Jack To: pietenpol-list(at)matronics.com Sent: Monday, February 14, 2005 2:46 PM Subject: Pietenpol-List: Aileron Horn Question Hi all, It' 50 and sunny here in Des Moines, can't wait for spring. What's the consensuses regarding aileron horn construction? The manual says 20 gauge and bend without heat while the plans say 22 guage, all welded with no bend. 4130 only? Anybody just use flat aluminum? Thanks for all the help! Jack Textor Still building ribs ________________________________________________________________________________
Date: Feb 14, 2005
I don't know how thick it is...but I watched Bernard make those aileron horns and elevator horns from the mild steel tops from 5 gallon dope cans. They didn't have an actual bend in them...he just formed them so that after brazing they were airfoil shaped with the thick section near the front. Forrest Lovley Jordan MN ________________________________________________________________________________
Date: Feb 14, 2005
Thanks Forrest, Every once in a while I need a letter like yours to set me back on track. Aileron horns from dope cans, leading edge ply from Quaker Oats containers, and split gear from water pipe. We still have to make it good, but Bernard made them from pretty basic stuff, so what we use today should hold together pretty darn good. Ain't life grand!! walt evans NX140DL ----- Original Message ----- From: <FTLovley(at)aol.com> Subject: Re: Pietenpol-List: Aileron Horn Question > > I don't know how thick it is...but I watched Bernard make those aileron horns > and elevator horns from the mild steel tops from 5 gallon dope cans. They > didn't have an actual bend in them...he just formed them so that after brazing > they were airfoil shaped with the thick section near the front. > Forrest Lovley > Jordan MN > > ________________________________________________________________________________
Subject: OT - Quad City Challenger II
Date: Feb 14, 2005
has anyone on the list ever flown a Challenger II?? If so do you know if the wings are easily foldable for storage/transportation? I ask because I have an opportunity to go in a partnership with one. My uncle wants to build a plane and he's decided on the Challenger II. Build time is about 200 hrs and with the both of us tackling the project we could be flying inside of 4 months. for those who don't know what it is here's the site.... it's a low and slow 2 seat plane. www.http://www.quadcitychallenger.com/ DJ ________________________________________________________________________________
Date: Feb 14, 2005
.028 is the thickness I used. Seemed pretty flimsy until the halves were formed and welded. They were then incredibly strong. And light. They aren't all that difficult to make and are quite satisfying to complete. I've seen many that were simply made from a single piece of .090 steel, it works but is heavy. I have not seen any aluminum horns. Greg Cardinal Minneapolis ----- Original Message ----- From: Textor, Jack To: pietenpol-list(at)matronics.com Sent: Monday, February 14, 2005 1:46 PM Subject: Pietenpol-List: Aileron Horn Question Hi all, It' 50 and sunny here in Des Moines, can't wait for spring. What's the consensuses regarding aileron horn construction? The manual says 20 gauge and bend without heat while the plans say 22 guage, all welded with no bend. 4130 only? Anybody just use flat aluminum? Thanks for all the help! Jack Textor Still building ribs ________________________________________________________________________________
Date: Feb 14, 2005
Subject: Re: OT - Quad City Challenger II
DJ, I had a Challenger II for a while. The wings attach in the standard form; 4 bolts on top of the fuse, and several bolts for the wing struts. You would also disconnect the flaperon linkage connections. You could assemble and disassemble each time you wanted to fly but it would become a pain. Mine took several hundred hours to assemble, it was fun and it went together nicely. The challenger is a nice flying plane. Good luck. Brian Clinton, UT DJ Vegh wrote: has anyone on the list ever flown a Challenger II?? If so do you know if the wings are easily foldable for storage/transportation? I ask because I have an opportunity to go in a partnership with one. My uncle wants to build a plane and he's decided on the Challenger II. Build time is about 200 hrs and with the both of us tackling the project we could be flying inside of 4 months. for those who don't know what it is here's the site.... it's a low and slow 2 seat plane. www.http://www.quadcitychallenger.com/ DJ ________________________________________________________________________________
Date: Feb 14, 2005
In a message dated 2/14/05 1:48:03 PM Central Standard Time, jtextor(at)thepalmergroup.com writes: << What's the consensuses regarding aileron horn construction? >> Jack, Plans type horns are much more than adequate, three dimensional making them very strong, easy to build, and well proven. Aluminum horns are Risky Business !! Chuck G. ________________________________________________________________________________
Date: Feb 14, 2005
DJ, I've never flown, and I don't think I've ever seen a Challenger II, but I've heard of it somewhere...probably in one of the magazines. I'm always interested in anything that flys, but the link you listed didn't work for me. Oh, well....kit planes are for Sissy's !! :) He he he !! Chuck G. ________________________________________________________________________________
Date: Feb 14, 2005
DJ, I met a Challenger II owner at the Brodhead fly-in last year. He mentioned that he was selling his Challenger because it was "the most boring thing he ever flew". You may want to get a ride in one before diving in. BTW, I did a little tail dragger training in a Kitfox with a 582 Rotax. The noise and vibration of that two stroke was annoying and disconcerting. It took a lot of enjoyment out of the flight experience for me. Greg Bacon Prairie Home, MO > > ________________________________________________________________________________
Date: Feb 15, 2005
DJ,,, I flew a challengerII for several years and really enjoyed it. Fly great. But as far as pulling the wings everytime,,, you really might think about that one. I don't believe you'll enjoy doing that everytime you fly. But it's a real nice bird. Carl L. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh Subject: Pietenpol-List: OT - Quad City Challenger II has anyone on the list ever flown a Challenger II?? If so do you know if the wings are easily foldable for storage/transportation? I ask because I have an opportunity to go in a partnership with one. My uncle wants to build a plane and he's decided on the Challenger II. Build time is about 200 hrs and with the both of us tackling the project we could be flying inside of 4 months. for those who don't know what it is here's the site.... it's a low and slow 2 seat plane. www.http://www.quadcitychallenger.com/ DJ ________________________________________________________________________________
Subject: Challenger II
Date: Feb 14, 2005
DJ, I also have no experience with the challenger but I do fly a Kolb Firestar II that my uncle built. I absolutely love it. I compare it to riding a motocycle with wings. The Kolb is somewhat like the Challenger. Very well designed and rugged. Feels and flys like a conventional airplane. The Kolbs wings fold very easily, a one-man job, no problem. It uses a Rotax 503, dual carb. Plenty of power even with my 200 lbs and another 130 in the rear seat. The firestar is definately a "bugs in the teeth" airplane. Chasing coyotes, turkeys or just enjoying the view, its a great way to blow off the sawdust from piet building!! Good luck. Chad Johnson ________________________________________________________________________________
Date: Feb 15, 2005
Too many www's, Chuck. Check the addy when it comes up in the address line and remove the extra http's and www's. There is apparently an issue with vertical tail effectiveness when the cockpit is fully enclosed. Most of the ones I've seen have plexy fins added at the ends of the stab, about a square foot each, just like the ones you see on float Beavers. I think in Britain you're required to install an addition to the vertical fin. There are a lot flying though. Clif > > DJ, > I've never flown, and I don't think I've ever seen a Challenger II, but I've > heard of it somewhere...probably in one of the magazines. I'm always > interested in anything that flys, but the link you listed didn't work for me. Oh, > well....kit planes are for Sissy's !! :) He he he !! > > Chuck G. > ________________________________________________________________________________
From: "Kevin Holcomb" <ksholcomb(at)mindspring.com>
Date: Feb 15, 2005
That Rotax may be loud, but trust me that is a good noise. I was gave a friend a BFR in the really nice Kitfox that he had built himself last year. That Rotax suddenly stopped making noise. It was shortly after takeoff with approx 250 feet to work with. We landed straight ahead, or rather right where we were because the airplane just doesn't glide very far. All we had to work with was Citrus grove so into the trees we went. After a real quick review of the situation, which with a Rotax does not take long, there just is not much to look at (fuel, ignition, throttle, and you are out of levers/buttons). The good news is that we demonstrated that if you keep her under control, get her slow and do your best flare you have a great chance of living. We did, I was unscratched, but rather bruised from the seatbelts and from a tube from the landing gear that buckled and drove itself up through the seat, thankfully the seat cushion was thick. My friend needed surgery for a destroyed ankle; he is just now getting back to walking. And of course the airplane is trash. There was fuel onboard, in fact the left wing tank split open so there was fuel everywhere. Only one prop blade was damaged so it wasn't turning at the time of impact. The engine, a Rotax 532 had 71 hours since new and about 2 hours since a teardown/inspection by Lockwood (the presumed experts.) The teardown was not inspired by any particular event, it was just the sort of careful over the top maintenance that my friend did on the airplane he built. Needless to say I am not impressed with Rotax. It did change the way I think while flying; where I would land is never far from my mind. Reliability seems a lot more important than it ever did before, and for myself I no longer have any interest in airplane engines without a long, happy and established history in the field. Friends don't let friends fly a Rotax, Kevin www.airminded.net > [Original Message] > From: Greg Bacon <gbacon67(at)direcway.com> > To: > Date: 2/14/2005 11:51:20 PM > Subject: Re: Pietenpol-List: OT - Quad City Challenger II > > > DJ, > > I met a Challenger II owner at the Brodhead fly-in last year. He mentioned > that he was selling his Challenger because it was "the most boring thing he > ever flew". You may want to get a ride in one before diving in. > > BTW, I did a little tail dragger training in a Kitfox with a 582 Rotax. The > noise and vibration of that two stroke was annoying and disconcerting. It > took a lot of enjoyment out of the flight experience for me. > > Greg Bacon > Prairie Home, MO > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 15, 2005
Forrest is right - you don't actually bend the steel in a crease. You want to make the leading edge rounded. I hammered the thin steel sheet around a 1/2" steel rod to form the curve, then edge welded the two halves together. One of the most fun parts to make on the whole project. I can't understand why anyone would put up with the increased weight of solid .090" thick steel horns when these are so light and so much fun to make. Jack Phillips -----Original Message----- I don't know how thick it is...but I watched Bernard make those aileron horns and elevator horns from the mild steel tops from 5 gallon dope cans. They didn't have an actual bend in them...he just formed them so that after brazing they were airfoil shaped with the thick section near the front. Forrest Lovley Jordan MN ________________________________________________________________________________
Date: Feb 15, 2005
Gary...actually, I believe that the dope cans back in the 30"s were probably lighter material than today...I have some old ones from Berry Brothers and they are pretty thin...no OSHA, hazardous shipping regulations, etc, etc...also, they didn't have to be strong enough for uncaring shippers to mistreat. The material is very ductile mild steel that is easy to form, and not prone to cracks. And if you use them to build your airplane, it won't cost you anything to get rid of them...:>) Forrest Lovley ________________________________________________________________________________
Date: Feb 15, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: a useful FAA web site !
Hey guys-- I was stumbling around looking for something on the web and found this site----VERY good for bookmarking. http://www.faa.gov/fsdo/phl/IAREF.HTM Mike C. ________________________________________________________________________________
Subject: Re: a useful FAA web site !
Date: Feb 15, 2005
Wow! nice find. I just went there and downloaded the safety belt attachment AC. 47 pages of kick arse info! tons of other goodies too! DJ ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: a useful FAA web site ! > > Hey guys-- I was stumbling around looking for something on the web and > found this site----VERY good for > bookmarking. http://www.faa.gov/fsdo/phl/IAREF.HTM > > > Mike C. > > ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: walking beam attachment
Date: Feb 15, 2005
I'm ready to attach my walking beam for the elevator controls in my Aircamper and I like to see how others have done it. The original plans and the 1932 Glider manual show the bearings just attached the the vertical fuselage struts with 3/16" bolts. The Skyscout plans in the 1933 glider manual show the bearings attached to 2'' x 5" spruce blocks bolted and glued to the inside of the vertical struts. I have seen photos on the web with the spruce blocks, but they were only glued an no additional bolts. I've also seen examples of the original attacment method. I am a little reluctant to drill the two 3/16" holes through the strut since if the strut collapses I'll be in a heap of hurt. I'm assuming thats why Bernie changed it on the '33 skyscout plans. What have most others done? Thanks, Rick Richard Schreiber lmforge(at)earthlink.net ________________________________________________________________________________
Subject: Re: walking beam attachment
Date: Feb 15, 2005
Drill the holes and don't worry about it. I doubt if one of those uprights has ever broken because of the holes drilled through it. Greg Cardinal ----- Original Message ----- From: Richard Schreiber To: pietenpol list Sent: Tuesday, February 15, 2005 7:25 PM Subject: Pietenpol-List: walking beam attachment I'm ready to attach my walking beam for the elevator controls in my Aircamper and I like to see how others have done it. The original plans and the 1932 Glider manual show the bearings just attached the the vertical fuselage struts with 3/16" bolts. The Skyscout plans in the 1933 glider manual show the bearings attached to 2'' x 5" spruce blocks bolted and glued to the inside of the vertical struts. I have seen photos on the web with the spruce blocks, but they were only glued an no additional bolts. I've also seen examples of the original attacment method. I am a little reluctant to drill the two 3/16" holes through the strut since if the strut collapses I'll be in a heap of hurt. I'm assuming thats why Bernie changed it on the '33 skyscout plans. What have most others done? Thanks, Rick Richard Schreiber lmforge(at)earthlink.net ________________________________________________________________________________
Date: Feb 16, 2005
Subject: 4130 cutting with PLASMA?
Has anyone had good results cutting 4130 sheet with a plasma cutter? Gas (the old cutting torch method) renders sloppy results and I'd like a better way to cut 4130. ________________________________________________________________________________
From: "Richard Navratil" <horzpool(at)goldengate.net>
Subject: Re: 4130 cutting with PLASMA?
Date: Feb 16, 2005
I had a chance to try out a plasma cutter. It's a great tool. You can cut any shape quickly and neatly. I havent seen on for less than about $1000. I keep looking and wishing. Dick N. ----- Original Message ----- From: Pilots4ETW(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Wednesday, February 16, 2005 9:02 AM Subject: Pietenpol-List: 4130 cutting with PLASMA? Has anyone had good results cutting 4130 sheet with a plasma cutter? Gas (the old cutting torch method) renders sloppy results and I'd like a better way to cut 4130. ________________________________________________________________________________
Date: Feb 16, 2005
in a perfect world I'd have a TIG welder, MIG welder, Gas welder/Torch AND a plasma cutter. You could do some awesome metalwork with that setup. Of course a Flowjet water cutter, 8' shear, 8' brake, metal roller, English Wheel, power hammer, mandrel pipe bender would be nice too. DJ ----- Original Message ----- From: Richard Navratil To: pietenpol-list(at)matronics.com Sent: Wednesday, February 16, 2005 9:56 AM Subject: Re: Pietenpol-List: 4130 cutting with PLASMA? I had a chance to try out a plasma cutter. It's a great tool. You can cut any shape quickly and neatly. I havent seen on for less than about $1000. I keep looking and wishing. Dick N. ----- Original Message ----- From: Pilots4ETW(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Wednesday, February 16, 2005 9:02 AM Subject: Pietenpol-List: 4130 cutting with PLASMA? Has anyone had good results cutting 4130 sheet with a plasma cutter? Gas (the old cutting torch method) renders sloppy results and I'd like a better way to cut 4130. ________________________________________________________________________________
Date: Feb 16, 2005
Friction sawing on a band saw works very well. I see no reason why a plasma cutter would not work. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: Pilots4ETW(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Wednesday, February 16, 2005 9:02 AM Subject: Pietenpol-List: 4130 cutting with PLASMA? Has anyone had good results cutting 4130 sheet with a plasma cutter? Gas (the old cutting torch method) renders sloppy results and I'd like a better way to cut 4130. ________________________________________________________________________________
Date: Feb 16, 2005
Subject: Cuby for Sale
Pieters Went to the airport this afternoon for a part and in this hangar was a Cuby, wingless. I asked about it. It was built as a EAA project and finished out by an individual member. He flew it for a short time and it got away from him as he propped it w/o chocks, hit a hangar and damaged the wings. One new spar in one wing and a few small dinkies and leading edge on the other. No prop or engine damage. Operator who bought it says he doesn't have the time to finish it. Both wings need covering and a few places need covering on the fuse. Otherwise should be a good flyer with the minimum of work. Located at Downtown Airport, Shreveport, La. Contact Lee Gunter 318 226 1512 or Leedonna(at)shreve.net. I told him I would list this on the net for him. Oh, it has an A-80 Continental. Corky in Louisiana ________________________________________________________________________________
Date: Feb 16, 2005
Subject: Cuby price
Forgot the most important part. He wants $ 7500. ________________________________________________________________________________
Date: Feb 16, 2005
Unless there's some hardening in the immediate area of the flame.....that may not always be desirable. Northern Tool and Harbor both have an outstanding metal cutting band saw (cuts horiz and vert) for around $170.....EASILY worth the money..... jm ----- Original Message ----- From: cgalley To: pietenpol-list(at)matronics.com Sent: Wednesday, February 16, 2005 12:02 PM Subject: Re: Pietenpol-List: 4130 cutting with PLASMA? Friction sawing on a band saw works very well. I see no reason why a plasma cutter would not work. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: Pilots4ETW(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Wednesday, February 16, 2005 9:02 AM Subject: Pietenpol-List: 4130 cutting with PLASMA? Has anyone had good results cutting 4130 sheet with a plasma cutter? Gas (the old cutting torch method) renders sloppy results and I'd like a better way to cut 4130. ________________________________________________________________________________
Date: Feb 16, 2005
I'd add to your list ---a metal cutting band saw- in fact I'd list it first. Henry Williams ________________________________________________________________________________
Date: Feb 17, 2005
In a message dated 2/15/05 7:28:36 PM Central Standard Time, lmforge(at)earthlink.net writes: << I am a little reluctant to drill the two 3/16" holes through the strut since if the strut collapses I'll be in a heap of hurt. I'm assuming thats why Bernie changed it on the '33 skyscout plans. What have most others done? >> Rick, I drilled for the 3/16" bolts, acording to the plans. Just use care to make nice clean straight holes. I also drilled a #40 hole in the top of each of the bellcrank bearings, so I could oil them at each yearly 'Condition Inspection'. Chuck Gantzer NX770CG ________________________________________________________________________________
Date: Feb 17, 2005
In a message dated 2/16/05 6:15:56 PM Central Standard Time, jim_markle(at)mindspring.com writes: << Northern Tool and Harbor both have an outstanding metal cutting band saw (cuts horiz and vert) for around $170.....EASILY worth the money..... >> That's what I use to cut all my 4130, both tubing and sheet steel. When I raise it up to verticle, I use it to cut sheet steel over.090" thick. I bought mine used for $30. Chuck G. ________________________________________________________________________________
Subject: hydraulic disc brakes / wheels on ebay
Date: Feb 16, 2005
these may appeal to someone on the list. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd1&item4527917146&category26439 DJ ________________________________________________________________________________
Date: Feb 17, 2005
I just use a bandsaw. Nothing you will be cutting for a Pietenpol is thick enough to worry with torch methods. Some can be cut with shears. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Pilots4ETW(at)wmconnect.com Subject: Pietenpol-List: 4130 cutting with PLASMA? Has anyone had good results cutting 4130 sheet with a plasma cutter? Gas (the old cutting torch method) renders sloppy results and I'd like a better way to cut 4130. ________________________________________________________________________________
Date: Feb 17, 2005
Subject: Cutting 4130
I have the Jet horizontal/verticle bandsaw and really like it so far. About all I have cut with it is 4130 making pratice pieces for TIG welding. Those welds do get hard I found out. If you saw too close to the weld to use the pieces over again you'll destroy the blade in only a couple cuts. I wonder if anyone has found a good set of hole saws to use with a Joint Jigger. I have gone through a few bi-metal saws by Dewalt. They have course teeth and tend to break on the hard chrome moly tubing. Anyone know if a finer tooth hole saw would last longer. What about grinding the fish mouth to shape or cutting with snips and filing to finsh it off. Thanks for listening. Leroy Brandt ________________________________________________________________________________
Date: Feb 17, 2005
Subject: Cabane bottom attachment
I am planning on using the smaller (2.4") streamline aluminum struts from Carlson for my cabanes, mostly based on info from this newsgroup. On the plans the cabane lower attachment bolt that goes through the two .090 fittings is about 3/8" above the longeron. This means that the 1/4" hole in the bottom end of the cabane is 3/8" (or a little less) from the end. Question is, does this put the hole too close to the end of the cabane? From what I have read any hole center should be 2 x hole diameter from the edge of the material. Thanks -- Rick Holland ________________________________________________________________________________
Date: Feb 17, 2005
As usual, in this area BHP made his fittings too short. Lengthen the fittings to get proper edge distance on the holes. In nearly every fitting on the airplane, Bernard was a little stingy with material. Makes for a light airplane, but some of those fittings are pretty critical and will ruin your day if they fail Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Subject: Pietenpol-List: Cabane bottom attachment I am planning on using the smaller (2.4") streamline aluminum struts from Carlson for my cabanes, mostly based on info from this newsgroup. On the plans the cabane lower attachment bolt that goes through the two .090 fittings is about 3/8" above the longeron. This means that the 1/4" hole in the bottom end of the cabane is 3/8" (or a little less) from the end. Question is, does this put the hole too close to the end of the cabane? From what I have read any hole center should be 2 x hole diameter from the edge of the material. Thanks -- Rick Holland ________________________________________________________________________________
Subject: Re: Cabane bottom attachment
Date: Feb 17, 2005
lengthen the fittings and insert a 4" piece of 2024-T351 Square bar into the bottom end of the cabane. Place a bolt through the cabane and bar above the fitting.... this helps put some load further up on the cabane. I used Carlson (Sky-Tek) struts and that's how I did mine. see these pics. http://imagedv.com/aircamper/log/image-pages/03-30-03.htm DJ Vegh www.imagedv.com/aircamper N74DV Mesa, AZ ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Pietenpol-List: Cabane bottom attachment > > I am planning on using the smaller (2.4") streamline aluminum struts > from Carlson for my cabanes, mostly based on info from this newsgroup. > On the plans the cabane lower attachment bolt that goes through the > two .090 fittings is about 3/8" above the longeron. This means that > the 1/4" hole in the bottom end of the cabane is 3/8" (or a little > less) from the end. Question is, does this put the hole too close to > the end of the cabane? From what I have read any hole center should be > 2 x hole diameter from the edge of the material. > > Thanks > -- > Rick Holland > > ________________________________________________________________________________
Date: Feb 17, 2005
Hi Chuck: I got a Harbor Freight metal cutting bandsaw but I am not real pleased with it. I doesn't cut straight in the horizontal position, the blade veers off to one side. In the vertical position the blade jumps off the wheels. Is there any way to correct this? My buddy has a King brand, but the same saw and his is great. Dennis ----- Original Message ----- From: <Rcaprd(at)aol.com> Subject: Re: Pietenpol-List: 4130 cutting with PLASMA? > > In a message dated 2/16/05 6:15:56 PM Central Standard Time, > jim_markle(at)mindspring.com writes: > > << Northern Tool and Harbor both have an outstanding metal cutting band saw > (cuts horiz and vert) for around $170.....EASILY worth the money..... >> > > That's what I use to cut all my 4130, both tubing and sheet steel. When I > raise it up to verticle, I use it to cut sheet steel over.090" thick. I bought > mine used for $30. > > Chuck G. > > ________________________________________________________________________________
Date: Feb 17, 2005
Subject: Harbor Freight bandsaws / was: 4130 cutting with PLASMA?
Don't even consider using the blade Harbor Freight sends you with the bandsaw; go get a real blade from somewhere reputable. Better yet, buy your blade by the foot, get some silver solder and make them to length yourself. Jim Ash > > >Hi Chuck: > I got a Harbor Freight metal cutting bandsaw but I am not real pleased >with it. I doesn't cut straight in the horizontal position, the blade veers >off to one side. In the vertical position the blade jumps off the wheels. Is >there any way to correct this? My buddy has a King brand, but the same saw >and his is great. >Dennis >----- Original Message ----- >From: <Rcaprd(at)aol.com> >To: >Sent: Wednesday, February 16, 2005 9:08 PM >Subject: Re: Pietenpol-List: 4130 cutting with PLASMA? > > > > > > In a message dated 2/16/05 6:15:56 PM Central Standard Time, > > jim_markle(at)mindspring.com writes: > > > > << Northern Tool and Harbor both have an outstanding metal cutting band >saw > > (cuts horiz and vert) for around $170.....EASILY worth the money..... >> > > ________________________________________________________________________________
Date: Feb 17, 2005
Funny, I have over 500 hours behind/in front of Rotax two-strokes and 700 hours behind the 912/914 series. Zero failures with the exception of the carb falling out of the boot on my Fisher 303 with a little Rotax 277 single lunger. I have had one failure with a Continental and one with a Lycoming though. Jim T. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Kevin Holcomb Subject: Re: Pietenpol-List: OT - Quad City Challenger II "Kevin Holcomb" Friends don't let friends fly a Rotax, Kevin www.airminded.net > [Original Message] > From: Greg Bacon <gbacon67(at)direcway.com> > To: > Date: 2/14/2005 11:51:20 PM > Subject: Re: Pietenpol-List: OT - Quad City Challenger II > > > DJ, > > I met a Challenger II owner at the Brodhead fly-in last year. He mentioned > that he was selling his Challenger because it was "the most boring thing he > ever flew". You may want to get a ride in one before diving in. > > BTW, I did a little tail dragger training in a Kitfox with a 582 Rotax. The > noise and vibration of that two stroke was annoying and disconcerting. It > took a lot of enjoyment out of the flight experience for me. > > Greg Bacon > Prairie Home, MO > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 19, 2005
Subject: Band Saw Adjustments
In a message dated 2/17/05 7:03:37 PM Central Standard Time, wingding(at)usmo.com writes: << Hi Chuck: I got a Harbor Freight metal cutting bandsaw but I am not real pleased with it. I doesn't cut straight in the horizontal position, the blade veers off to one side. In the vertical position the blade jumps off the wheels. Is there any way to correct this? My buddy has a King brand, but the same saw and his is great. Dennis >> Dennis, I had the exact same problem with mine, but it only jumped off every once in a while, mostly when the teeth caught and stalled the movement of the blade, then it would jump off. It seems to be a fairly common problem with these saws. I used it like that for quite a while, before attempting to figure out the problem. Here is what I did to correct it : Just remember...Safety First !! Always make a Visual Disconnect, when working on any piece of equipment, which means UNPLUG THE CHORD !! The saw is designed to twist the blade at the portion where it does the cutting. It seemed that it didn't twist the blade quite far enough to make a 90 cut, and it would make a crooked cut. There is a sliding portion of the blade guides, where the roller bearings are, and at each of these locations I made a small shim to go under there on one side of the lock bolt, to make it twist the blade just a little bit more. The shim is about .015" thick, and 1/4" wide, and about 3" or 4" long. I placed the shim on the side of the threaded locking bolt, so it would twist the blade a little bit more. Presto !! Makes straight 90 cuts !! There is also adjustments on the idler pulley, for blade tension, and blade track. These adjustments have to be done to keep the blade on course. For the blade tension, loosen the two bolts that lock the sliding idler pulley, I think it takes a 12mm wrench, and tighten the blade with the 3" black knob, till the blade on the back side is tight enough to twang maybe a B flat note (nice and tight, but not too tight). Then rotate the motor by hand, to see how the blade tracks. You will have to remove the belt guard to do this. If it creeps off the pulley, adjust the other bolt that makes the idler pulley angle in a little, and you can actually watch the blade go back on the pulley. Do this by hand, with the saw unplugged, to get the blade on track. Make the blade come back on the pulleys, but not so much as to make the blade ride on the little ridge on the back side of the pulley. If you over adjust, it would probably wear out that ridge. When satisfied, plug the saw back in, and with the blade cover still swung out of the way, just bump the switch on, and right back off, a couple of times. If the blade still looks like it is on track, turn it on, and watch to see what the blade does. If it stays in place on the pulleys, turn it off, close and secure the blade cover, and have at it. If it does not track on the pulleys, and tends to creep off the pulley, stop and unplug the plug, and re-adjust the blade guide on the idler pulley - the one that makes the idler pulley angle in and out. When the blade jumps off, I unplug the saw, raise it to the verticle position, open the blade cover, get the blade on the top idler pulley, and part way around the driven pulley. Then with a stick of wood, I hold the blade in place on the driven pulley, while I rotate the motor by hand, until the blade goes all the way around the driven pulley. Chuck Gantzer in the rain soaked Land of Oz ________________________________________________________________________________
Date: Feb 19, 2005
Subject: (no subject)
l4grasshopper(at)cox.net ________________________________________________________________________________
Date: Feb 19, 2005
Subject: Fwd: (no subject)
In a message dated 2/19/2005 1:21:05 PM Central Standard Time, JimNikls writes: -52 UAV Unbelievable that someone would make this - all real turbines! Check out the movie link below. Could be a UAV contender? From: JimNikls(at)aol.com Date: Sat, 19 Feb 2005 14:21:05 EST Subject: (no subject) Isablcorky(at)aol.com, dick(at)dethloffinsurance.com, ENHEND(at)aol.com, awferg(at)kingwoodcable.net, jimgraham(at)iopener.net, JMOORES(at)WebTV.net, pwpeavy(at)bellsouth.net, JLQ1(at)COX.NET, rhlehew(at)shaw.ca, Horizon(at)hcm3.com, hvaughan(at)sport.rr.com, jwwright3(at)sbcglobal.net --65.3f5f0fa6_alt_bound B-52 UAV Unbelievable that someone would make this - all real turbines! Check out the movie link below. Could be a UAV contender? _http://www.mcgirt.net/RC/VIDEOS/Giant_B52/B52_flight2.wmv_ (http://www.mcgirt.net/RC/VIDEOS/Giant_B52/B52_flight2.wmv) --65.3f5f0fa6_alt_bound B-52 UAV Unbelievable that someone would make this - all real turbines! Check out the movie link below. Could be a UAV contender? http://www.mcgirt.net/RC/VIDEOS/Giant_B52/B52_flight2.wmv ">http://www.mcgirt.net/RC/VIDEOS/Giant_B52/B52_flight2.wmv --65.3f5f0fa6_alt_bound-- /9j/4AAQSkZJRgABAgAAZABkAAD/7AARRHVja3kAAQAEAAAAPAAA/+4ADkFkb2JlAGTAAAAA Af/bAIQABgQEBAUEBgUFBgkGBQYJCwgGBggLDAoKCwoKDBAMDAwMDAwQDA4PEA8ODBMTFBQT ExwbGxscHx8fHx8fHx8fHwEHBwcNDA0YEBAYGhURFRofHx8fHx8fHx8fHx8fHx8fHx8fHx8f Hx8fHx8fHx8fHx8fHx8fHx8fHx8fHx8fHx8f/8AAEQgBqQLQAwERAAIRAQMRAf/EALkAAAID AQEBAQAAAAAAAAAAAAIDAAEEBQYHCAEBAQEBAQEBAAAAAAAAAAAAAAECAwQFBhAAAgECBAMF AwkEBgcGBAUFAQIRAAMhMRIEQVEFYXEiEwaBkTKhscHRQlIjFAdicjMV8OGCktJD8aLCU4OT JLI0RBYXCGNzVDXThEVVJuKjw2QlEQEBAAIBBAIBAwIFAwQDAQAAARECEiExAxNBUQRhcRQi BfCBkaEywdFCseFiI/FSBjP/2gAMAwEAAhEDEQA/APOGyASUItk9nCvh8niyK0m5BUlhpGYi JpbDKtwm6uoEtkW85LY5cpprhYBLW9trqHlNzaIJ7DFW2UNtJdIAunEYnRJxqXHwUxCkSrGe OonOs0CwJUAEwDzxmrkEEJMk/DmBTIuNILFnM9tQV4iYIJHCc6A9WkAwDjgcxRFC7KnAeE4d 9FGX8JYqFEZ50TABpH+XKjjAyq9VgCLJHisQTmAAaZv2KcbRJ/BjSAT4eB5U/qMKG72wkeR4 gCBhVxftcDO7toy/hYFZOQg+6nGmFHeWiTCEAZYzx4040wB98DchV7y2FWag33jW4PlggnPK YpNQob647H/p1cHMCZg1eP6mBvuSANW3AnhnhUx+pgp93Y0gHbgcgeIHPCrNb9mEO5JuEHaI x4Grx/UwvTZeWewLYAPh0gk+006/YXotQ3lW1B/cUHup1F2xMknxKIjSvy0tFK6aAdK6zwhc eyadRCGYFhZtKSYyExzq5UDXwHCFLJxknTw7auAW2FlrrXHW2UjC2qZY4Gam2StJs9JZsUXT xwieys52TqW6dHZygWABjEwD31f6msUP5fpYxCmUzMzn31c7JiljZbMkReIUmT4fmxq3a/Rm rbZbEiRDMDyInuxqcqZoWtbS2NQs5duRHtq5plRu7Qnxo2oxjqNMVepltdgNVzQykYAhiJ9x qXJc/bVb31oAyjaV9uNZ4VLC797a31HmWnw4AkAVZLFwx3LnRlkkOCOGoxW5yMVE6j0UAag6 kcJYinHYxRLuuj3BHmMs/DiYrONoYrSn5EW1KvcIPwwZIPICpcpmnWX21kkpdZWEM2rDtqYt Ja1L1fdMpP5wlZwBM54E41JLGvZsJ+s9QBTy95pzCzw51ZKvt2Z7m7LIBedI1TOkCWPGRV6s 3e0u5ZtXgAW1LmQDE+6s5ZyK29tJVThlGkQMIrWa1N7FubbW4kgMSZVZM05UuwGtIwjWw5xn jTlU5gFmwzJrLMi5JLLJ7SKvK/TU3J3HTkeSt42104gHjOdXn+hdwfywNpCXSQAASSQSZzqc ozyabWy2qMNTsdMamLAk1dd8Uyedt09rRa3uXLTjbIOI76nJrp9st/abZpNu5EKSLZU6ywyA Mxia3No10+2AbTeaQzWQuMYsZpyZys2t0I0WTzMmThToh+3IuMLYW7bbI5hflrNK129tbuuE F5rbzpZcSaLNcn3enbm0yot64xciIPiOMCtSS/sba2FPZFq45e6/mqYdSxwJ5xWbWbKtgLmH mvpj7JPz0yzldyxeSU8+4uA7SKZLS180AD8xcPbQG53n2L2PDVEnvpMGUa9vVSHKBxxGR7cQ aHRVq5cMPcaTEMFWVPzUydDfNaSJVu9SPZRKs3LpHgKzwwOdECj3VEXdLNnIBFVeiOXJBCKQ OGIpkWCWM+Wsd5n5qZC7vnGPKt2tM+KSfkIpKdFKtzHVbVlPb9Ypk6IMAPwc8CCeB9mNMrlT omoqLIKEYmRVmyZWbVpR/ChTmBApyMgYNbxsWCD+9AiOw1ZWoGyjAguhtv8AZKNkBiKcjky9 S6PsN6qfmbVy9onSpcgD5Rzrpr5bDlfty/8AyT6ddAx2bK7fEocwPlrf8nY5U3b+kekbSUtW 7gt3P4isSy88jUvntORm79K9O3pU3jf02zKxAGIjARTXz2ErGnpTYWbNy2lu/ouYsSFYgjlI wq+65XkUPQXTltQNzfUAgwyqxwns7av8i/RzemuLcLhgwjhlXz5tGRWdYEs2HDmTNS2CiQ5I LKWOAk41Mi2e1bt/iMPDgWJ+imUwo7vZFgBdBAzEwa1JfprCfm9qdUMoCZsD89SymA/mdqVA F5QuRJJz7adUwq6+yEEbgBicBOFWW/SmncbdFwujAajqaRWTAF33TpP44IieJAmr1CG3eydm 8q4JOKEEnHmRhNWZCbPUds2u07HzyJCgwCR31q6rxb7LWGtq5uAE/EonDswrFSwEB9R0M0CV bIdnGtGDNvcOgO1tgzGACMqm06lhqxD+E4CSSJJ7qzhMCbyRanS2rTOkAzHKp1CFTbMRNiBG Bac63mqeVsW4UhSSMsTllWc1BMLThCoXDMup91M0UfyzMIEkGYGAk0zVS61tWBKLE5kGR7qS 1Etmz9kDnIB44Y1LaD8pWUBYGqJJEEVrXO1kMhNpUUwwIWM+Mdprt+Vtr7LNe06f6Jr26hdL DkKxBnM6hhynGuEtaENttLTSrhS0BtRJnsxNTlaF3LXS1LK7gMcANWnvrU2oq3s+meWoWCPs 4/KKXeifk9kwbRdxU5lsqeymQXOnbUKG8wlRhIIxq+wyv+X2XhvMYqBBgrgc+FPYZU/SEfCS QR4WIkD209pmkfyl1DMzmDIUQAe/urXti8iE2emDcRnUYsCOJ7q1zOTW+127oVtBxqxYEEAx yrPOmaXas7W1c8rxSowkHTB+el2pk7yrKuU1AOMSSOffU5Iu1tVKs3hgnAkYGl3MnW9sgSWK gGYSJis3Yyg2y68AAhwIGEngTNORkLbIhwNODfEFOECtTYQdO2rMA1kFTmxAgEd9TnfsyXe6 VY1YbZbg4aRj/QVZvfsVb6Dt21arKgmSDIGNX2VcitdKtJcwtaR2NhUu9Qs7Aq76V/vHP31q bBH5bcphcthxIghTIrWVUm3vIGc2SJkGQcZygHlTIj2766T5bRhHhkACmQvzLpk6HmTD6Yq4 XBSgvq0l1H3jIx40wNCXXFoC2znTzGIis4TCk3G41xqwQ4nGZq8YYG993XRec45riMe+pJgw td5cWyAijDABpJjKnHqmFDqDQVAOsGdRGAGVOC4Rt84cFgCSJB04d1WamETe3WwKwuEEKc88 zTimD1vkqS4hjhpE4HPOs2Iobiw0SzKSMR21eO0+FX5tjxkMVgDEfFU6phAytoBuEhcNLfEa nWKjflx4S0A8cse+rmpMm2zbCCHYY5wc+dS5XNWy2yxZXJJ+KOPaaZpmrtOttsC4HE4RTK5o b/lXbpHmamYeOMD8lJUtS1ZS1BCkCOOPz05E2wz3Le3DkeN2GHh+qtS0tOaxbeyBc/EQfCG/ qqc6vI4m3bKTbCW5HhUkAYRxqci7Z+DrO62aMxex5vAA3IFMrLr9F37tlVC27ZViZBkHCkuW bikqR4mIIY5k8a1tvlniv7IhsTxxgis8jCDUFGMk8qZMDL2R4ijkDhIzplvGpZvrqwBHZTLG BLdORUMw5YRVzGsQlty6v/DYt90dlVOIfzzkan27YGNJPy0OK13ZGLIozzIAHacKv+a4UNwG KE2tTH4iIgYVf81mrPd6gVdFNgleI51vXtUuvVo23ULILFrDLbBCqZyxxwrPy1NYLz0uMTM4 kEA1LUuob25t2nFtpHKicaG/fZAn2tYkJBJj2VYcQm3vb7fhXFtj4Yzg9s0zFwzDq21KAgtj wC1w4nExOoWXIKKXMkAwIml1wvGqbebf4lI1HMYUONU282evT5kyJhhhjSa36X11n/MdMZgE uajiFAGffW8bT4LrYYLGytFrjqV156mwM9g4YVj2XsyyXtxYN7yrCi2k8p1Ed+FamVUovXiw DAknFhkB7cquUy1WymryL1xWgToAEGZOfsqZTITc2lnxXLaqgMhNM4c5q8quTvM6YF8xbKyD wUTHKmaGoNpdXzVsq+iYBAxPGs3ezoZV57Wm0MgU56Rkq8IomVJ1C476A0KSFwyn20wDu9Su 2VJZWfUBpEZY1JrnsFHeXXuqodrbsMVjCRW8Klq5vLbg7hwAD4xMlZyg1nMUTdSFpXUE4qRJ EkTxojELr3fxVYm3lbYnMjM1vKhT+ZXDBuMqZW8eHOkwZjpWl6oFVNIuCYZ8BHbnWeUMwd29 1DQyW4eDoDARDDvzwpMJmAs7+6lxbTOpYsVkY4qONWyUrVd3hWCF1lQJkCCSc6vh3um02nwx ZmYH5jvaPkhYGCkQe+ud7tZhAW/izMjGRLxgR205QyG6965bWQrPOq3GXKR21Z3XMZ74vhwL lu3jMXGGYPPurUsIZYbaC3oYLKE6swAOFKC3H5ZF1siy/wAIkgGswgrf5F3FhtuF0D4STEca XMQy3dG3vkWLH4enVmQDwyNTjkGvVbpuLqWEMjSOGHGp6xo/NwocqYzhT2SeHKpNDCfzQIGd kCoOHxYHuyqXQwBurbdk1a4b7AE8cMcMKvAwu9vPDot2w7KJZiYHvpNQA6k/m+W+2MkeE8CY wE049M5ADqiKgubqybGI0jL56cfowO3v7d24XtoWRMWMfDTiYMO+saAdLz93IVZ46YXa6htz edAsgdnvqXSmBDe7QIWMrykGl0pgm51rb23KCWC4kgYAVZ47TBNzr9lrmnRKLgWk4cOFWeJe JrdWsIPtGRhkBjlUnjqYJTqq6yq2/NWAYODA9tX1rgVzqzpBbb6mIyBJpPGmAN1tyoLWdIJx 1YyvIVfW1ga9Xt6yr2xbIB7QeVL46mFP1SyBq8uSCNRXme6k0phTdY2pBLWMsYjOr66YOtdT 2GLKIgDDTPxf6KxdNjBdze9NAZxbIOqCAI9oq8NjBf8AMOmiGv29DiYBByGXvrXC/Coep7E3 FARlx8Ry7sKeuqobvYkybpWIIGmM+NONQ+doo1i9IicZGeWFTNRzd11tkuBLaE6cWLAwZrrP Gsh+z6+126LdyzpJMBlIYCKxt46lh77va6nJxJMAcZivR5ZtPHpP0t/3c9e9Bd6htwPwzqII mBhPtrzzTb5dMM93q21IdQDIOM/P2VrjVwQeqbVLhuEl1kEBxgDyEVeNwYax1HY3D+HdCuRq EfRhWMVOI7u7QWzDlmHJc2GNWSmCl6rYRAL1k27pxIIwPbNLpVurLd6xsA2m0jaiOEg95rU1 vymG+x1Lb+WrOGU5RBJ7ONYulTiy/wAzS7f8G20qMDceQScMx7a1xsizU+31PZKVtujq2cK0 xUutOJ639rdQQ0iftnEcazipgLXOn+Y2tdTAjh8uVOpijvXdppEOQgxHMAUmfokV5lllBNwk nFR2DOn+Rgdq/syfj0lcAFjjzwqWHGjTcWDcKrdJYY4wARTCYGj2myheWRnnAoYRjZYDEE5Y rh89BU2lwAIIEx9RpgCTCkompjGZ58DVkhhWtdJ8GR7acQi5d248vWxKn4+wcJrUhhera5h9 IJMSMvdlUsqmottwTgQDBnOazULDKzkW4OAMExFawKCoZDEKB9qnEVeSwpBLBnGKg4mklXJL 3kCCWIP3eOFXiFWd0qt+N+GWbAThHPCrdBTPt2tLcWyQRCthpAMfVXOd8NcqVFi4mi2TbIM+ CMe/21q0m5tvZ7QobdxiC3PCO6pd7l055c1L+yW86XR5hECMsFNdb5Ljo3d617f+XsxFhAgO LD5sa5b3a96522k7i3ZLeUl2LYx7cTUkYol6eoVblpz5esjVGJFaymTbm3twVRyCY0zgIqc/ syo9LugKweATnnh/pqeyIG90pluYXZEfC2ZJqzeBqdO29hh5zEtmFnGO/hV5tSxVtbFtxa21 nQoj4cQTnjWbbUtyN9lfe7rZgwYSSRiCeFMxKpOnkMrG5DmdKCQDHOeNMtTDQV6jcA8s21Aw KkyRGE1joyxizuVU+bLuCSWMA48gK3n6b1iDbbk2mZwVUHToJliOBPsrMi8Sm6fuPM8xyVAy IEnDGtz9Uti7+yvNZDWAxux9rACasvVibdVWNrfvlg19bbjBtOIkcBwpcTqrXpuWlBW+zNgF twYwzy7axjKGBry2zN0liuopyPKrg7sx2k3PBcCXB8IGctWstcTLdtbNi8LsuxbUcZBIww9t TJhNjfe3cW0oCXCJxOB7BSzKWNd+1cs3ReUamcais4ExWabMVldwpnVCwZUYmSfbFb6Ie20v i0isAFQfaONTMRgIvtuFPltIXGFPv5Vu9mnStJtltA7pWPi1eLKMq5W34TqZutw5dWsWtKiG YHDwg5VJKuGZr/UHS4dGnQuY5T9NbzGcKTZXrbLeS4bly6h024jQDzPzmtXbLTWwW3ZWGxnB Z8Q0rBANc53Zyy37TNZN1Ei43iZR4sBlJFbkw1SttevldGlVt4alIxgcabRlo83dyqW1Ohhn AAIFYwh639xbE+U7BQNKAZHmZqcQC3rd9Sm58QIMACSMuVOs7Klq2bSubQNtHJ8PZkJmali9 DntXChstdDBgI4MO6amOqZcx13lu6dEeXbeQv2iJ413mMNyxtuazaILDWF1Kv7Rx4VnVllXy 71vy7r6FIhlPby41bcFpO42+wt3E03jrAjTMz2n3VZauazAbl2VV1LYDgKwBOPecIrv4/Ftt 2i5bruyu2tFsMCwx8zVAYkThE4e2s+Tx7a/8phMmh96r3FQcCJ1eGeUcDXK4E2ty66gXQZxL BsSMOFZ2vUtA6WmUjN0kAsJBDQa3yTLAL7LuXCXSbcgqi4QMvdzrWcxqOht1e9t7guAq8yOc cMqxnDNB+RuJd1i6LKP8aNjq5e6nI5H6d0lpjgV1QhPIDt4UlhkG4tADWGJYAREkdomkplLK WdwPxCEuEeAycRxqXaxVNbsI0KQUA1M06pXjnWteq5ClixffShZreGkzBg92WVS7YTJz7eyF dHUhwDAHvmpNuplltXbO1Ph25kx5jET3HsrW3VWhNuty21x7eJfwKDDETXp/J8kxpJ8af9a5 eP5/cJ2o/MKviKoJAYxjx768l36OhT2AS9s3cWOAVZMcs61y+QD9OFrS38QucFKwBhyEmcK1 N1lAu1ltR8ByLYEspGXZNXJktF0ahYOq2xIYucRMz8XCpaZVcSLYbzbbOp1KrTABy9s0lM1m tLuRqe7uLeiSGB5TzArVRX5bd62Nm4LqEArBIJYNkfZlUli5WvnINN1rhVs5zBqcpb0DdtaL K1mWZw2piRIhjgFPfxpbgy1jbWrBiCTPxLxOWPdUzlUtJuArodeok6WIwz+qnQyprG5ezAUs MvFI4UzDI7ablgB5cEBsSezKBRLQPtHPxKVYgSQxj2UlMqG2vaoFt3eCVgkGBzpmKBN5u1Qq bTAqCfFxxyq4RDud21q1ptOFIGC4Z99MBu36hurWKq4uTEP4lIHGpdBY3N5nNwgnxBgYiR2V LA8b+9CaElC0MTOHcKzxjOGv8wDbLOo1RMcwPlrOOphmTebwalFpSGHgEZE8yK3ZBD1HfeYP ChKiWRQMqcYYgH6ruFKu6gKcdMY41eMMKTqhI1XBDFZUjIxzmrwXBX813JDSqiDKhZ1RPbV4 wxB3OpXWDfhlVy1HgYzpNU4xlO83b2otujEfexy5dta4xrEdC0b8hG0hBiAcQTyM157i9SbC 8myl1/LwVm8LEAGOGAqTa4690tmegW26Bi7sJOMYye81cpkj+Ube4fMuqqACNYM8avPByp/5 bbLZ0htRBxKjIcqzb1XLJes2rbFVCFWGLHGDzqzZehw3dq0gUTAGkAZYjOs9Msrt3dVzU9sF j9qMwK3bBqDOx1wERciMSc8AAKmIZLvBncFLZkEEsc4nhToUttjdLMQwk4wMyOU8KiCs7S4h YHPAoeIEVLBFtE3rmncSyL8ImJzpjotmB2V3jMpZQ4I+OcMTwqccIci7rCVCiYLk/EKcQDt5 bFWdREN4s8KTVZVPcQMGXQWuDDxEg1ZqdVO+7W2fLt+MwSeYq4Qu/wDnGQh5Wf8AKGZHfVmq yMFrpe/e7kbVhh9ojB+M861ezdw6aWby6bIvKWAGJEzlh7qnROgz0/y1Gh2Z2JLkicKzbGck r09/PW95gB+wBl4eJ5Velbmxn5W09wlrpNsfE4HhniBzqTolpi2SCLaku0wJUAgjEHGqzq1G 3Ya3bGtWXVN0E4iThwHCs8s1rafLK23shvwwWMmdRgSZrU2jGTbu3R0LF2AChmMduAHsrM7t dCrhuhgVfBhqeRx4CtTWJC7lvd3lJUYcVOAiYpJI3ykHb2DKxm54hIKySADjBrVsZuxg29wD U7qLQzPAgVjEZinv2Vm0jorwQmkyWAxk8q1WqVuLO60BNagHFnEZe2pGYbsdozO7NeOsYhVH VNtmGjVGCgwSefKZrWCtL7vbhlS2AwQfwzllhSRkhrt032YqC4jIcJnCpVx0K3Lm47KyggkB QAQZBzn20mSRmu7q6NKlTbEEhyIInPCrjAu5a2+5QhHOofCcu3PtirL9krDcbbbeyRfQMSQF EMzEk6QIzJJNejwacvJI1Hv9h6O3VzpCW7/RN75zKrDcW08UzkEeIwzmvrWbzbMs4/T2TXXj +rz/AFzZ3umb9dvea8WdAujcWzaZTj4VBZpjMEGu919muNo47aSMKKGtsSZIxM8eFfnN+lw4 WpblLYS0cRik8pxFYrKriXLytbuDy1GdycJ4UmIuGSzs3t7jy7pBtAYtkSDjWrv06NZ6Olt9 xZTWhJnV4T+yMK51isG8YvuHBu+F4NvD4a6RqNVhr9u2qbhtYPAYyMIrF79ENLlCQuNtjLq0 ZHhV/UIvWl3Ftjty1u5aBAaAIita1ZWK50jfAarsqtzJlOYnEwODGuvs1+G7YO10uzbhTuCs zjPEDDCsbbZ+Gctm38zWbSXtbgYucMjgKxiIbtbPUdxfG2sA37lw6YEESe004xZrlkvbTqtr c6btpl0zKHHEGIq3T4pZhtt3VYENbJJSAGzmcqxYyPqPRTt7O0ubXwm/bW7fwHxEkRPdW5Zj q6WCt7Lcbnpz71br2b23AdFUeEhdQPi7ZprrLmVrXXplyupdN6ndsWtwUcYSzDwgBTgW5zXT XsxZgr+X7i3ackaku4gGTMycKzy6s5Zbe1L21tPAZiQUJxGJIJPdWuUnVbQXOnXrgdFXSA3i IAh6c0y07HYXttuyw/EERn4DHzVNrlqxpG+S4CtxBIkMpEjCuG041LGiy63G/BnyyIC5BQP9 NWbfbK7W4RToKYrMavoq0UN6jXGRSNYIdVPGtqsb4kFI0uoAdgcJqWphn21+x5pNy6dJOA7S cMqtXDYj3jaJBDspY6REwPlq46klc+/uN0t6CurTpaZgHn7qvTC5Da3V17ouXLalgoIVoJA5 +2omWi/uHs2juEII1YjCCTAEVklDb3N4vbYBSpOlkBxnnWsxcmveS04skKZggDLuipyItLw8 t7jeWqhoziPZWeVyHLcXQvjDBjiRnl21OQA6Q5KwFJ8Piz7DFOSCS5tVLFiEJwmPkwpyoxbs Wr1wkXBa0qIGJnhNdJt0ORjLsLirJgrhOWoxFTnYmURdlYQrqHmT8Mc+FJcgHtraQXFRGk8T Gda5GWdrygeYLVtR+zOLEzlVzarsi2bjoi2/EBBgRJHE1w1W1Py6LaVoPmDxMsEaZ+yZjvrR jobc2rnyiFBaCHxnxT9VZ7d14/RSWvw2HlzqHe2fAVMnGq0bgIQEI5eETWmcKbbXGcKqMpIB XWBJwxy7cqz27tY+kG1vKizbOljg2mBhnBqs4U9i9MlFYiQCJilhgy3trzIWRYCAlgJ4Z99S 4kWa5ALVtmkqdcQM4xpgwjWVKELIC/ERTCYMWy3km5j5YOmcYmMhNSmEPT7YuMttQWUYuswR n2YVdbbFutWsJa1q8SdIQHGM5yyqfODj0LRDpPjbEyGY4CrlJE/Kbd0ZrlwBziAUlTlgTM0t WQNjYWrDhwvxSzBScSONXNB/igviFU5ACCPbUkRR215AQXZQQMCDGXClhhE6a1zTcNxiZLDH Ne6rLFwba6Rat3NVzX5Q/wAvETOHfWd7cdF1k+RWunxcbXcupdjwQQIx4UrUwda6XtbWzvWb q3RduEm3dbSCGBwkkTETgM657S8pfr4bzriwpekXFC6LpOqdTNiI7uEVvOXLjDLFi0jXlvu1 xWQBXA0sGykau/Km2cdO66Y+QflbYuOVcXdsWWQDpuED3iprvemYu2s++gdxbuW75BZWsz4N Mnw5gTAx4U16zLG2vU3cWzurDGyRtgqYW/EWxJxkiDGFWdO/drEvZkvbVlsOLe5BOGJHNcY5 Y1ZtnuWQSW915CWxdBaRDmZjuGdLYx0Uw3viRCjOcdWI+SpmLxKu9P37C6m5JtXkhQDIAngy nGtTfWyWdVuuL1Szsr9sFUYAlpLEcOAxrV2S9RPs7iAvcueYBiOGWMVvx2comD7PVraAB9um gZBBB+WvsTbT511ZvjvxXY6Z0zadR2O6fas6XLNtr6WgcG0EFwZ1fZk4cqz+R+J47pdtJipr LOlccNuQ7aiiqw+EYY85FfEsjWABG0OxAI5yZzop63lgL5a+WBxzHvpclirm329wDy5QSNS4 D2A1JbEV+WVHXS+ok8MxHbVyNittzLRBxz7O+s21cAFvaudbBHuFo0sRxxnKrmpgu7dtpeV4 V4b4FWARyBikyjNa3b9KYdUtW7W43di95m1DqQqtiAWgy2mZr1fjbXm7+KZrL0z9RP1QsdVf e3epbjcaAbr2SittwgOTWlGlV4Th317br+tfU18X3H0LqnrDqHrn0Y9m30Vtpvrmi3b3F0B1 O41j/u5ImBmScsqnu21uDX8W3rXj7/QOnpuL1pNwzlSQGBGY/dzr5u/kzbXyfLrJtZOwT0vZ jblRdbWsE4gMf2TyE1jlGJBPsbBV1TAOx0h2EwMpq8plehLdPtW1CwG0mAwOod9TJ0Atnp9x QRbJcYMMjnwrPKoO70+LurboDa06WBPiP1VuXosoG2t1Y/DIKjATgT39lQzEKCSxAI0me08I 7qsq5jF5eJS69xLDNLYR4RjpnvrfQkES168ZvspYnyywwgQFUDlUqXUg9O3rnxYwRBHEDvFa 12kOgvyiq4aLnmqTKkYaowyqd1w7fp7qp6XcZ3QXLq3lu2m4aVUqynvmanLDp495qVub97f7 /cbuRaXcNKrMgA9/Km3kjnvc0va+bb80QW0o4DPAE8CKksyzMGJufMsJbvXFuKi6QBmpyH11 ctt/S/UvT9rZO1uW2W0LfliBiSGkseczj21ZMO2u0kwRvOtqelXtt5DC7cRRbdiD4JxaBkfo q69Gdt5jDjnq5ChLtohEARTGHEz8tOOXKzJFy/tb0O1okYHUBxOFONTiZa3Vjbl9J8JggHHK mEuqjvfMTTawWfEi4GnEkoV3Fpg3m24g44DGRhlxplZbD2tp5dk2jAAiGM4RWGc0F+7tbgFo S95JgxAmIxityVZGZVtWjrGoXCIMTgTiCKWKFre3K621FrmEjAD2VI1ky7ttqbCsDBMTjjIw /rqTaxii2e5fZXXcnwNphsScc63nLppvg387s93dcCNa+LDtwmsbfq52g/KbVNYdiyNb8I+7 zINan6M2rsbfZCyqfZEnS3bjlSxchs9PtW4a3cOhGnGBiMalTK16cWRTcu2yXP4ZBk4zyqcl ssGenbK9ZFliQw8RYYS0xkaTfCZotxtruFu44iYBQCcBTVcsf5KytwOxcJcAwwAwxzFbthkV vpm3LPqdwLjToLSASP66lsOQTsFtSdZVcjxMDnVWUNzY7e4pC3mDkFvKAxHYDWuU+iWMtvYX WuRduG22YDcuOXGs2yJlokWG8tCXsz41MudXOTUwRZ2aMrMCHRmE/ZIjKryTLpJuHtr4J1ag QYy9tc3SHp1DdFmfUzO6lGLDUYMc55UTNB5j6TrEEmZIxM1MGR+YxtKBpiSBGDA4YnjRZS9T qZxMcCeFRDLzqVQBofHAZAZjjnSrb0HuN6zlbYhLaCERdWmYgtBJxNO6Wqs2r10OiXVBgnQ7 aZABY4nDhlV6BZusrsASSMCwJiD21myEybcLaLb69TMMMwVA4GrVL852KqYBGEjM4zjzqSYM 2jNyQVaSrHUMcBwOFMK0G+DanyAi3CFR1Jx0cADzOdS34az07F+dYVPFalVUgAtB1H7WHAcq sz1TlPoCMl52KqikLrOGEDkKrLTe3Vu4iL+WVLAEIYJWSoBjUc+NZt64lXPTsT5tzV5qXtHx BYgHEQQABgCDFWVMEu4dmYjE+JtOHYTVyYPNzYNdsqS3k6dVxT4SDnp1QZ5TFLVklWm6t2lD A6oIKLgQDj8XPkKQ6OgeqWb9uX817jWvJgaZGOotJ9uFc99q6TFK2fU7Vq0ymwLxuEaTcJ1J jCqDzOddIzmR0tz6i2ly2lttt5bFQLtoMSXIOWWGK5zVu63Y64tq5p3Vi0bVq40MWBAFsYBi oJYDX81O/WGHSs7AXNuLT7K1fIjyrhEhiYMCDnhzzreunzhu/ThdR6dbG4ZDtmsrbZhcBBOl hmCQBPiNc9r+jntr1Zbez2pdfMuAp4S3hZiCTGkAcs6kwyWyW7d5HKupUa4aIIHyc6xmWL2L dNd1rcg6p0GIJjIAmtSltq/y7mFtuowwLDETgecVcs5AdluLOlyjS0aWGEk4AzWenZq5C1u/ dJuXJJJ0nzGElpz9lJJrOnZLm1dv7vhFyNBWCTgRjIBFdM5iYG22a5YZ7NtrkqQzAYCIxmrr 3g88xhGPITX1mtbi5en/AE46rYtdVVGnRqi9MQbdwaHGHY1ev8ef02J5/Lys/QPU9l/L99uN o1txd21y5auM0aToMKVx4ivz3k0213svZnDKLYvaVug2rZ+2ykjlhGNYtsjU1yb5T2tChZDa tFwg6SVzAJBrUl71MMpvsX0FtJUjSYkT3xjTinY43ot6jJUQCQMATwy41JDCC9bZFIt+JZxk 4jhhwrPG56lwK0La3dVtfMcoddthgpMyRnkONa7EgblmxaZdbBiQT5qklccoyqS2xq6xk6nf 2222KtuINp7i28J1EschPdnXq/H8W222Z8N+KY2j0/p7Z9Y3m7vbjp+9Vum73aJt3G5TU9wI 3islgIC9sZduNd70n1X6Lx52656On1Pe9cs7K3stg67i5sVa3NlAFs2oKwoPxHTOOfGuV1u0 tjz/AJnnuuv9Lw9u2UUTfKSpkNjJHdXmfAMs6VDTc1LcwiMKlZZt2dFw23ssAjEYYyQa1Co1 y4UVLKeWumZJMgmpiGEFu8ElGVWHhLRqJqYB6twiDU4KjiMMaYVp2u+IcG6POUjFdUYZcKOk 2nzF37+z1r5QdLZWCOIY9vIUn7F4/AHW1cXSL2hB/vCMQI+WkkJNaTuVu27kKlq+gHhIP9Qr Sba/qpbl9pDWYWBDg1LIxYaj3Qq6VlgJE4VDBjPubYDC2iocAuE5Z+2mGuFRNzqdgVXSQPDE AUsYLu3bLqVLSigqTiBU7DLYv9MsMQ1rUwOBUnT8taq9a2XjtbhS4BiRMGMJ7azNjNKD7VSS 6BZEaMz8lXqltoH3G3EncINI8KH4sMqdfgC1rphdSbhAYzoGRjIRVm1XqRd6Z5jf9MNaESG0 5Y1vkcjD0E2LROswATpAkjjHtNPY1NssFxdzYAUWWuKZMRgpHOrLEzGjYbfwat3bZFOILcIF Z22vwl2yeq7QufJeFwiB8pms8mba0vZRWHjGjMsRjj3VORmsg6fZFxnLroaGE4iRwrXNqbtD Da3lm6NLAaVYDAaRkO4VL5Kl3ZLwcWiAqXSxA1sJ0hfrmtzeNZVbtWRcYeYPHGplElfZlUuy d0d3tbbzNJdCcT2V0lSwFrcLeYxbKzMniDwqWiX+nncbZrTuyK4DCOznHCprYZFY2tqNpakM 9osXaCdSkTlwiKzXSbS4yrebff6rT2tNzXAuAfZAmIJqya4al0yV1K11R0bQC4UDSFiSIBIM /tVZhjeTPRlXa9SW95bEi06ghWMY5YVL9sNdva7y0xF28nmMJwOIwgVnidDb213GIFwKhnUp OMHAT89WQwy2tludQCXFYzOeIAwxOVWwOO33LBcJK+ElsNRpmGIlza7p0LbbSW4g4GnQpFra 9YwF8wMTIxzyFXEMR0w5VvDpxEEHlyrGG8jS5dGry2CswEac4XH6JqYMqJZk0u5ZFH4a5jHO aYMrjwsFAEwdXEdxpgyMWLr2TdtqXRMLjRGnlx5CrYAFx0GQxwOGYPA1MIppYloEk48I7oqY DNxYvWgPNVSWjSQQxiBmBlnxouKHQzoCpLlmC+WMWJOWEUwNi7bZpbf8x5y31Yr5S6ZGnDxg gRjUqyEW02fksbjMt8AlFwKnER2jj8lEwvzdNvyVcjbliZjmIM+w5TRTmt7U+Wu23Vy5fKiL egiGGJCwZq2Sr/mDbWTuL6Kts3bzsBoDaZmYAJwx7akhjJ97Y7mzbZNxt1sT4/iBbHACZbCs 3Wy5y10xjDEzML4VLrEKNIAYxjnlwNWYZtEh2kOGtYzNsh28A44caXt0M/a5UKw0q+IKNMRH PnnSdkz9CtX7gtvbLoEcQ2oTEGcMJz5VLcQhbLbUjHlBXnnSUwff3Nm9pcJpuRFyIALTmBwr GutzcrtZcYZwVMzJ7a6MDBUMNLQOHPHtqLD9rZ3946tqt684cAqgLEHNcR3VrXS3sdV2OoXt uza2uscdKklRJM8ROdTjgmzRZ65vXvvfeyl8aQrC4CVk8Tjn21erU3z3Mt9R2rhbT7ZfMuyF cXXTQdUgmABHYKuc/C5dfYXOh7lLJ3F3ynRiq2rrGI4As2BA44D20k0jpOvdrXa+n3O4Y3Ld 4W/ixaypnBgvxHBcgDVl0/cusC/RujXbm8fbqguC0k2QMEeJwEZtU231z2X1S9mcdJ2Qs7az t31XCYe3Opi3xEaeJjw9lS3XP6Jwz27kdW9P3rD7ktYumGm0gLTDZxqXGO+szlf/ABs/c28W O9ctdrpDuuy3UYllGpSoEgDI6sYrE8fks6VmzWXtVQlux5xtpaLsbaW7rHUZGkkofukzNa43 5qT7w84VGWYr7kYb+gm3t9+pUadfhNerwXq5+SPaerNxt/8Ap9y9iX6nZR/zEmBdtHy3nGPs ycONfK/uXi2nllmMOuu+vDrOrhL1TYi4zBLhADLb1KGxIwjVqiDyrw9cLymWnY+odmgui/Ze 413xa2RT4hzy8PZV57Tsuu0+Sbt7ZaGube4FcmTiwYEQVCpyzrFzds56GZgA6zvmt3xevMWt eOWkwwwXDDPtq9JYZtlV51pduLFlLbsVJuloIkoMQx4jHD6amLb17JbJCF8qyFVLZ80DFySQ GxMwOyus1tuJHPOGK51zp+2LW2e3daBBtrEGBMsBwr7X439q1v8A/rtj9J/3Y232x/TM/u09 O9Tfp/1Ho259O9fbdbHddR3CuvW7yr+U293bK1za3AVBYKzHy3XTiDJNeny+LTx3Hjn9H+7t +PmT+r/k6vprY+qEu/yjYb+wm13im4m5sXVu7Z1PhuNYvR4u0DxDjFfN8vjx17x9nw+TlMS4 fQ+m9P8ASvpvbbe/1PqVvaWttcNxr166F85kU+YpQn8TMQoBNZ8Ocp+RdZrh8t6he9KXN4D0 bfO/T74W7ZF+0Ld4BifA6EggrW/P/b95rz1/0z1fEtk2x1ZhYsQztcDmPCgwjHOvmW4BCwnn BWeQfhu8hwIAxipNjB1zbJbtll03UC+I4SCewcq1ksYypYEQBGEjhUTBy7RrdpXuKBbY5EjV jxgYx7KzN+uG7pcZKe3ZRzEsYHiUZn21pjAF2l24zG258JLMHI+ECYExVkMB03T8RBkYThxr JgT7e4VBBwIwIMZYVZRPIv8AhBIMmMDJx9lOgjWriuVODjMNjVsAvbcDGcY4Z0MKt9PuXr1t FhLjZFm0iInxE4CpVwD8ruUZkuh7fZIB5VbAL7VPLlkOmYnGZzAqERB5RwthlIHhM1ZAZvoF YNt5U5aQZ7adcitwNu0+VaYtAjXwPeIqdVohubqZWU1jkonvxqXLIX3e9VTo0jDJRpbH3UwW LsdRv2ySbj6z9kiVApdUsLfqG9e88EaGyMRBGNXiYBavSCF1ayZIeWUk1aYDaWxg99QHY/Yk LAwyq0wJvzgIui2UsjDWASsd9MRrj8oVDMH14FiQMIipYzYJntKpZn4xHbU4obZe09vWrDRx NSRcG3QqKAjq1sZiMZzONbkGOxt2DNDg2iZAJyPcaVcLK3FdiVJBPxLGVFwluyHdlueZYgfH hBOYqY6k1hgNm2AFco6/ESBj9NWtbTX4A25CsZdWESZwmphzwYu7AsKypiw+JZIFLDBV7dy2 pVDQMVbhVhhnXeWrilHtSZxZRJzEZVrBgy3uhbV1NoMNJUqWMspHEVzsWdCrZGuPLNtSsEAz 28ONaStNtVbbxZdm0AZmIxxmedSpgy3cYGFBXAageJnCs0wptxduFgVe3KwrLwMY1qIVd2dw orBlCkkATJyzjOk2mcPRdOhy9PuDY3N35yW0RxbCEMXuMRJCxhgMSTWrjDOGUC5iOECJ4zWe iHi3uSrHTp0CTiPh7j38KGAanggCCAMzxJpiC/LvT4mJ1HDgMThSLgxEdtQmXxJkwYAxoh+1 T81fb8xfuIukvccIbrTIGIkc86cYLvtu7dq2HJt2VY+USIBaAWxj4oIn2VKYFf3G53F1r167 ra4dRJgn5MqVq3JfhIcHSY+Eycx3ZzWUht1dmoHk3GuYfiAjQFYngMZwp+ypdRbDrcTSGuIX C29Q0AyMD2jOpJZ07tZi7WzvNt23enTtUONwhyhIYDT4RHy0zrnF7rNbjPwKxsdVpnSzea7j cUKn4Ztr8ZLH7vdWL5Nde9WaW/Ar1m1qU2dpcUYAeZcDKZk/EAuMfNXXjWFKPLsXNbr5wujT tArS2GLh1GmIMRNJJP3ZtIZ3s3GLILTAStsYwD4lBPceNOsTKrjXLz+ZcYG4x1lsMdRJpkUV DNxK44LUVRdmtC2FwDFgxEMSYgE8QKvVka2ywCu3lkzLkTlkCBUWQ6709A6Km8S4urS9xQwC xHihwuGNMxqambTcdf6NeV9puGsm94luWnBDQSob54mr26rMxlv7je7kW1vXGuCypSzKgEKC SYOBiTNT5S22FIl9DqOOkjFhmD2HOaWM4ORnIuAW9YxLXCMUHZpwAk1OF++zUv6BZtyxhkBd YVVAhoGMnDGedTXTCW09L++tvqtHTZVidahjbnjnx8XGnDrlZa6Wy6turO3W5be1avEBLrrP mA6tWoRh7ezGmbj/ALO12k7Dvbnd7TdEslyxctjw3XLamAWVJkkagCCDUslnZM2VtHUuq7ud rc3Gl9Hn7oyxBS0uoFiDjMZZTU18kuv9PXDW2c4vdm2m437Fd0l1dO8ueBXfElIfS6iFIy4V 1nTqxLmldT2duWRgu5YeI7tTJCkLKtpw0g/D3+ypdp8Js8vdUpcZWEFWII5Qa+vrekcjLDFL qsMwZr0eO9U2j37p/MvS6kW/NfYXfNVM/wAO+hV+WTKpqf3Dx8tMz4Y8fXo87ujsHDXLGz/D UhFW2zjFQWaQwJaVgmIivh3q7YjGOn7m8raAHUAnwEHSIniZ99ZicaXuLN3bpoUFpJ0/CzeE wctVMxbLBWT1Oz4lQNbstrueEMJEASSMjMQcKs1mcxc3sdtdv5bbi9ubtrbtYUXLdm9rBcsc k0gxGeMVZizLN1s7vOeoOvyLmzssWtq2q5dGbmYOJGqONfe/t/4811zf+V7fszcgtdGuNM3V GAIgE4H3V+i1/tnTrs8W39wmekPToO3ZdN1y/ZAj5Zrvp/btJ3trjt+fte0j6J6Ovendt6K6 pt+q7FN7b2V1LnT7Lsys1++GGmVI0hdM6l4TXj/J/Bx5NZp05d/8np8H5n9Fu3w8R1naXerb 4bzeXV8y2otba0iBbVi0MrdlfsqPecySa9Ov9r0k71xv9x2z1kc650G7qbRcUwMCQRWb/bL8 bNT+4z6a9jf3O3KbTdmdqP4d8AeHVzJgxhxr4v8Acv7RvjlPh6PH+Vpv27u5c262nK2/L3SF QRcXVgOXDnjX5i9Howqxt7N2+FvObOsjxKsqsnGQDMAY4VjbbEtkzWtdZb16Ds2Nm5ewHS4x Gtdyxa0FgiZVvizgAVqWpiKFq3tV0C2ty7cg+abgYLBwiBxxzJrFltznp/ju3jExgK2b9609 xF0paWQsqSRMGRIJqc5nDPC4yBbNp3RLxay8j4sFggEHLAdta2uJ2ymsze4rdpkZh4LlpwVF wqXjj4YiCYprvL+hdcFsLoDWhOAmANQ9/KtM4LTzPNgESSAJwzwqUwa+23aWb2oFbVlxbdgD ALZYkRGFakzMwsrKyXRqAYAFZhiVJBwgYZ1cJgVjb7y66qgJBOhdIzPIE045XA3t3kCHcW7i KPhLA4SJHvqXSxFJuQlzUDpdSIOOBqBlt8VbWqkmVJAzB+sUULbhXDF1U3H+K4BB5cKW21Ae Vb8zT5iqgn8QEnLLDtoBHhx148v6Z1QJRh4hdJUHFZBn/RS1RBxpCl1Pbl76kRUHVJYAc4qg gjBmxXLA5ezCmTAbguMM1JigW63QBJUqfsyYBmqLt25ttrVFJIIIzjHKgry0EgAEZEDM0Ftt UI1AFcpE9tBR2QLCSxXnOMmmSg/li6yYc6sSpOAq2iv5Xt3zLIBPOBhUB2tvbtoUVzjjjz76 mOphaWts6MLruxAhMdMHtwM1Z0IXd2dp9JDauBJEeykEXaKqYsWIOLTjHspCVY29zyzbDgW4 wUgGNXGTTK8qFOnWkedHiAzTCeU0tRV7YIxBMB/vRJqoEbWyoKviScDkBUwKS0FbQtw6Z8QG Z7KuFPttcSCbnmBSfCcKmIHXbgF5gpS7aEDUJWCRyOPZVDmdNxrvm2m3cqAlq2fCYGljiSQT gcPkrNrpbGNUVShdfMtkyU1RMZ5ZTUlZHZ29y45W0NdwRA/pnUg0L069bRr16zc8pSykmQNa EBx7MqXouCLVt7lxEUMdEglVkxzMYmKuvVDNza21p0tPt7gsa5tu+pLjqpIPEqM4McqrWS23 DBRbs2kFtSwyxIYz4mOdM5wnLDVuuvb+6S102kaAvgs20ChRgF0qIHZS7W/JyZHa/dtJcvOG 0jTbVpJgYSJwOVEqi1pEZW1eYYgEQQczRMHfmrzWz+JjgFthYkTM+ERgaiyl22FtQxHxgw0T DcRiImKIcdzbKC7bAQsHRQUEQx8WPt9lLVyoXmWy1osQuoarckA4z7KnTOVluHSvbvbNbLI3 /SkaPy633LKxBcaQ4+DVWZrrLbidW+fTuw2Btbyuu4F38NWY2wx8TwdLadJ0hB8XZWsszqXt rOy3W+PlW3TbABmQ3BrgQDpLxJ7KcpnrCa5qbjZ2rL6VvJcVkLhl1QMcExUeKInhSs2YFtNr e3U20DQivd0KuqSo5CM8qTTPWd0jftumbm5d24ubcJauudszZw4EPcKuRJVZOGAjhW5rc4rU lH1Hol61stqdKLcIuvZGnTrtjGWuEkF4+xmKzdMd+/8Aj/dq69GezsdqzWk89kW4W1teTQFI WV8WrGpMZZmo7/TLFvbjeJuGbaaU81MTcDQPMAkBTBPClx3OPTJF9Spe2tz+ESUF15ITDQuA K6oPCs1IFmv2ToXTcVlEahqADYkKSBBniKztrLhqbYG+9e/uBdvhcBDeFSAo4KuWArWWbc9y 03htr5SLo1yLjDEspMgaaWSrNrAbncKt63dDl7reJj4tSMuABJ7sIqplq23V9ztr3mKCD8Kl 0wyAywxgR21bPtrXezqC5vgb739wFW6z6b1u0gtg24hhpA0DLDCplORP5q24S2rMliQdLHUe 8wBnUTk272/b3SXtxYVduoJwSCwACoNQw/DA4ARS7ZrXLLPbv7yzaQ+eW27AhNMMNK+GAAYW MhSwzYXduX1dZVgGhgOBUYD5qzxTLlblj5twt8Wokx219jxf8IiI2INd9e6V770RdO4tvsJ/ 73bfbf2mE2z7HAr2bazfSyuWtxs4O5e7at3VvXWS4bul7enUQWnU2oDDHMV+Wtstj0fBaht3 fbzLvmX4J1sGKsF4yBIEDlWNcazEjV63NAoCX3NvQ6PNu27rBHCVVpiMhXWbRkQ3LF9Nzb22 HmM7WjcZXYlY8RB1EKV1AE51ZQjc3HGyufieFmwUROuCNWIr3/2v8T3+ea3t3v7OHn8vDS14 je7E6z5TatRKw2c1+y839sx10rw+L+5S3G8aNj1q81mw9rAmzbV9ePiUQYrlv/cNpJNemHXT 8HW23brlr/m+8I+MDuArjfzfLfl3n4fjnwL+Y7zTBvuFOJAYgSOyud8++c5rpPDpjtAjqu8V jF3UP2gDW9fy/JPljb8Xx34Pt9c3AfxojLGMSDXfT+47zviuO34GnxmOfueptu7/AJFpTAEs nbw91PyPyNvPjXWJ4Px54c7bV6np9/cW9rtrsjzdILahqAgAZHA1+P8Az/x74vLddul7vV4/ JrtOWpjveR28wYg+LHL2V4q2vXbKhdRnEFs5B76GIryb9zUbT/BiwYgQAY4mrDCIty6HLKFB 4pMZVFG1okr5bJqgAt2Tw4YVrMTC7lrSyFrhdmDMycBMgNqBxJ44CpLFw1DbbdBq3W51ap0m yxJA4Ezn+7VmFmpW421lbo8o3guJR3CmSBIyw74OFTaTLNho27Wtpce84137QezirEtriIGo rGOcGnGTq1hXUuidX2aJc3Fv8FtIFwMjLJnwrpZtWVbulS6VhlxbCFsjKKThiYk8jWKYpo39 /a+Z+IPMZ1VXVifhM4EYQYpLmFmC9zvd5ubtx734jZu0DKdWMDmatv3UxaQxRnwAUHASMO6i G2n26AkqLj5KrfCD288KqhVXZotorM0kgclE8OykiLS6UmLaXNQKkkAwMjHKmAnzPLkGwdMZ jKlgsBLjCLLMDkAs8zjTqYUX0iChVT8OBj2UMDC3VaPLgCJOk5HKaYMCW4oVjOKmOOJ7KmFk KDB18zUcSRE5jnFVMKS4mo5NykmguRqgSJ4jsqpg9twpDG5bUkrp4qFI+0Apzw41FKFy2big uVWYJGJjsnOliCuG8GJQHRwOGNToqvOdhpbM5TlVJCluTEcs+E0W4EL6DCceIEwTRMJ5p1AT GOGBOJqphfmwCo4yDhNBasMEwYHCAD8gxqW4XBjPZANtU8QMFiIYGIKkd9JczoUoMoUtqAaY 0HE4jMVcEAcAxGs5EjEyKYFreXSQoiROONMIrzAWUA5Y8Pkqiw3iJEHHDIRQwaisVC6TOJNw /dA4DvNcctYRNvuQFuWkdlDDRd0yob4hlhMCYpJUZnN7zDBZWEgyIOr6Kkgdcv3GgsNZGAJJ 7yKkM1aX9xYvC9am22Gi8pKkcxI76vYlo7jdT3Fy7uLitdEO7XTEGI1kD2iYq9l60H5a87XQ z2rZALqJ8L8SqaZFWUxk27sN9dNzcKhNtGS2l1V8DMR4FEDMgTTqYNt9K3d1UdjosaWe0z5E AyypHGTMVLnvVkKXZXLqF/MQQB5hZgCCZjPEk9lQwrb7ZS+nG40oEtzAbHxeI5Vcww2Dpibq 2yLuEsst78PbM4YMLhBItiQAQnxFjjgKSfqYB+Qs3d1btbRLp3Ya551oqAngGqFRsV0gGZpL nsuBvsrm23Opr6NpuMdbKtw60mNU4MvPgak2wlhTWrNhmWUe8VMa18HiUGUg4tqmDlTIUvTm PmtcZIQSGDTLMRlGedOUhg+/0w20J2pa4hEsJAIBllDYAElZitXaGGXb2epXW8i1PmtkkRIn Ae2Ks6irQvWkLLddb7sbYtW9WoFSCMhBBOUGpMXsdY0Pv7953sbzcX7rKWkZMHUBRr1CcNIB GdMrmlrur4R7Jti6lptY1fZYkSQcDjpAxqZTBg3d0XmvEEO06ipiRhwNZydWh+o9V2yNs1uP YXT47QBtyGOoaxxmR8lSb56yrbZ0L2t/bK4XcqbyhgWUNpJxlgT+1jWpcEVuN7szqUhiiSLW q5qFsapAE4xpwxqRbEFvpz2Va2rLfIhrjH8PEyCRBIMcvdVz+icYvc7DZbZy1q8l9UCvrI0h tWk6QucicZ5UtW6gbf7QX3KWtaAGHJgw0rDQTjBqS1LE3e66Y5GhwRCzc8WYB1YNxyGBjCtW lkJXc7bxAModMUOeZgZ9tZt6JNTFZbYD3ZawdWGQ1FctXPCpFwSd3aAttaXyiq6bhmQxMgsZ 58q3i9jF+idpuLNk2gWVkDSWBnUp4YcamLlMZb7nUts10utlLTB9aBSzgKRivjkn2nCmLWsO ZeRXvO06g2OqvtfjT/64cSGXSZGVdrqlj0fpfePY3YKmGUh1Papr1eKvPuZ612lnZ+ot1c13 Ut75RvLKofCRfAcx/akV8P8AN8c18l6d3p021x1jkWL1pdTmcV0w8jDiJrx2TCWz4jdY3brt 9AuQAVBtHxA4s2rGQILcKmSVV25cvgK2pmYkloAck83zIwrM165+159MPP8AX91uNsba238B BYoQIkQK+7/ZvJfHdtte/Zy8njm8xs4H8wtPZBuLoYOW1jEc6/VeL+5yzG0fM8n9tx11rH06 ERVUa9KqrSYUNmfdxrHg/H0ubZlvz/kbzEnR6LYujJ4VUOuYCx7a92musnSSPLd9r3tdl7CP aDFFYxj4Qa3iU5bRna1ZW2rvaUqZkaRhjFS+OWdoTybT5rnb21tUuR5WhjOAMThnXHf8Tx7f GG5+Zvr85c3aN+X315WYKBqNxpGMiFq+C6eGcdrIx5+fm2zrLXpel7+xf23lq0vagExEjhX5 X/8AoNtPJvN9frD6H4vi200xs1xde4QrEYiFIkfJX57L1G2715Eu22S2xYAqzDFCCMR7OFMg bA3FwOwQOqxqA4k5VMLMmDd+X4ltcQRaPwgCDjj4pq4Mpb3ARGdSVJ8QEYTy9gqd1lGd1tbp drloeJTEYAMcZFRYAC1cZmBW26jwiMMOHETVuULulmaC2vS0ouantz7KLUId0MITdJ06MDOo 8udaQ4/zK0rJctXbaoPIuagQqyZKGcp01cVc2K3N+24t/grbCgaVb7pxHAE5zJqci7VSJs7l sQfLuhWZ7kmJOKqFiasrOSrIS0LjPcuK5OhgqgymbSdXZU2kveNS2Bt27YXXftF1VhjqVTpP LjWspKYE2LWVf/MRiotTwK+FpEEwc6ZazFBhbViX1M6xqAKwSIy7jU+UySqr5YAMIvibnhhJ NJUuFoNbk/5bYjExlSmRaVVmKmSIOJiewVF6LvXbhW0ly2zWbYItrqBChjJjljSFEd1uAlwB oV1AdRgTGUnOaubAlVs+SCpOszPKOec1JTCWyVeRpYKY0nIme3MVowuC5DIig8YUGZw41Lau AOLpZWI4xGdIzgEs0+E6ssQauFwJLF4qHOkEzEtgIpKYDoveXqgiIkCTjNOiLJGnS+pTEqOB 7J50JC3uKCquxBOUiP6qs6rxyvUhBZICHCO2mE4lvKtpYyOEcJFFofzCjSoBYcWkRPZHZTDO FrfcZT2mB8hFSxqCW4XuE3GaTiQSMZpOiVRtW2Utq7iD2RVykMNy5ftr5ksbaLbS4TiAuAXC s66TXs3d8gAggGcMfBniJFbZARegHTisY50gU4uEgqdIJxBiTWl6DG+vm0pIIw8IPDmMK8s1 XFpqdY6haUWbIdVhvCDKkkCcMZkVua1ONJXdbosXuWWDElgNJx9gEU9d+k40e23W9W5rS3cN 5TKjQQoHtFa9W30s0rR+d6j+Fo2v4VudSaD4pzkdsZ1fTv8AS3WnNd6uzaxtVJJkJ9leyCTU n4u/0cKhtdddgz4xLElgTLGSR7c61PxN14VQ2/WCrIFGkkNGqFJGAkVr+JuXSrXadaxCrAgg AXIXxDxYdta/h7Xvg4UKdM621wsVtWif8wvq+SDS/h7L6/1NHTepjByjAk5HThPDOp/D2L4l 2ukbhl0+aouTMA5Ce3Gn8Pb7anijQvTesahN5Q+IL6iTpPCn8Lb7XgzXOhdab/NtLjIEmAPd xrc/C/U9cFa6V1dAfMv25nwKCxAHZhVv4X6nrgk6VvCD515GaPDAMDGp/C/VfXDbHS71oz54 PIwZHy1b+FPtPXDbnT9w7hjuoPEhYOUcDSfhT7PXCB0O8XV/z10MpkAAAdmFbn4eq8IJujzq F2/cYtiW4k8yaT8PWHrgD0Gw7+Yb90H7q4L7q3/F0T1wVnou1RipvXXnGTEDsqfxNFmkaU2N tQ4S7dC3BD+MmRM4z3VL+H4/rs3IWej7Ivrlw3MQPorf8bT6C/5B04Zaz3mavo0+lNXpFlV0 i7d0n7Oqn8fT6QbdP25AlZgQIwmOdX0afSgHTdmpDCwAQMyTV9Ov0J/LtmFjy0A4Ymnp0+iB PTdhq1eWJiILGPdT1a/QJdltgZ8tccIzEdxp6tfoyP8AJ7ZgAbSEDCCMKvr1+ltqJstqkhLN tQcwAKvCGVi1aBJNpGkEQRlPGrNYmXM36BdyYAAKgwMBlXbTs4792IgVpitfSrvl7lCTgDBr fjuK4eSPb9d21nqHRenbu4oZttr2bucwv8S3j/aas/leOXrY6/j7dMPM3+iWmtkWrmkjKTI+ aa8G34+t7PViMi9K3loeB1IA+wccOxorjt+L9F0l/QFvf3Nve1X7dwNBElPCJwzhhXDb8faM epzfUO4tb++NsNLXfIN0XGUIQ7PkSoGFfpP/AOf/AB9dtN+fzXzfzfJtptrh4rdLurCuLijw AkqrK5wzjTnXr8/gmt/psv8Am6eLzXadYy9Fu3r3T1dAUhmIgxIJJ+c159fLvju7Xx657OxZ a8RBLewn5qW7X7Maz6bwm4W3KBwvGJFJNvjK26/oS+4vWVOo3FBzOMVZd9ftLNb9Aubvd3La gvr0mbZJmOyc67afleSfLlv+N49vhwtld3dzc39dy2brXXBa40HwE8BU18W/l2zmdTbyaeLX H09P6Zu3BvVDAtaYFS6ggTwImp+Z/a974dtrZ/TMvP8AztLtNZL1euWxe1gIskDHP2dlfjcv bgCLdL6WU6hxOHsoQGJP2VLYcgI7qtsAKWmc1Hy1Uwf5i6mLAs2IbVlj3VPlroiubbjyyGbA yVEHI6SpkZ1rJVG0FJDgpOXZVQOhlVBMmZA7KyLLvoZYZkdgxA5jCec0OzRc6jur9ty9wm8Q AzkmdCiFGPLs9ta5Vq1luPefQoVYWYCgQNWdMs1SWHuLoXCMVE8c47zFRQ3LbWbVu5cCHzwS oBJIj7w4VcHZDea+yI9zzAI0szHCe/KiRNBDskDVbaDpYRPfxpYuKayj4S41ASWxIB+72mnE wBXBt6LruttQTaRctZjEycsOFTihbtpHmMzGMFHHEY4d9MAQ6zqVyMMYGM+2hk23cbUGgE6Y xPZUBMJJRhJSMM86uADW7Ph1YSMJHDKmRcoIYqDEQDj7anVRbgbifxFNt1OkqBBgcK1YFp4T LF9BwkHLlEiogbl4qgjxkzgRHuqyKF7hCBYYFgCMiMYPDspIKW4wJXFUOPikH24VcIpdSMCW WCcBwA9tRTRafSrAgIxjAgmQJy+mhkDlxAUjXGeQNChvK7KCCSWJnLhGfDGkEtraFxRdtHQc W0ETHHOiCUIVM2/DBAGQkZSedAN9EQqYUMIYDODmOdM5Um6We4XYhGZjqKgLiewQBSiIdN1S gDEMG8s5Yc8eNVmiKuWMqQZ8UYQDy7aLEQLqxZkUkRqMxTJku6ALiwy6RiCc57K1kej8uyqx AwyAAr6WI9WVi5aU4IwI4j+qqg1dTkpBzJNBR8uftD30FL5U5MedAWlCfiMcooLYWwJ1BVGZ PAUBKiR8VFWEnIz7aBi24GOI5Z1UGVJPDuigB9vqxgSMiM6LHb6F6Q651ax5myv7W6VnVZa7 purHNIq8f1TLkdQt73Ybp9rvNubV+2Ya2xg1lYyncNmEj20VQuXCcRI7aAwMAT7hQELyrgON AZv3MIAoYCbl5sIFAJNw8Me+goI+ZAigjTEAUAS4yw5CgnmX4+zQD+JPi0zQQsw4e6ip5zHA QJ5CiA8eozMcW50UYQxgffQWdXb76CiBxx9tBXlhslxoDFozx+SiOX1MRfTtX6a66OfkYCa2 wZZMMDV+XLePoXRZ6h0Df7AYvcsDc2hx8zb+Ix3pqrt5JnVz8W2K82DHEivA+iNbzHABicuF AUswhlMDnQeH9bdPvWOr7XfKhO03Kfl7pXJbkypMfeyr2fj7ZnGPP5dcXlXLHRdotk/mrYKH HSCVjliMZr7nj/C8fj05eV8nf8zfffj4w+n7Nra2/IW4zpa+AMIUKZ4Y/PWfxt9bnHaNfkab S5vy9EnlBZlVGeYFei+TWfLlNNr8NNu/aH+asfvCk8un3F4bfQzcsureNWAicRFanl1+4zfH t9MO86fszYuOzLatqNWsQNJH2gfore/ruvXGGNecvTLzv8te1cF5FS47mSAJVjnkfiPfXm3/ AB/JrJt47LHfT8jTa8d+ld70xvL1zqKreRWRVYsICkYRhHfXyP7l/cPJPBtrt89Hp0/E8cs2 1eplRaKWiFdR/FLGQMiI7K/IR613DtwES3FyCJaDJMccTHbUylKa1tnIZyWvmZAkZ4gRlUzV RVtqhMfHCiBhjjxqs4S5t1uLaYNaPmYaUMEaTA1CM2q5wuBbiygXTaJNoFvwnzV4CkwMiSuH ZTkMXlmYM4Y4yMD21vKAd3UrJAkRzqSFaZ2YsugcvedlKMMECRLggiZ1YAg0lwWF6zb1Kjso YEP+7nB7KsoeN61hQLXmWbhteWxgQysdUER8BGNaXJdzdG42tQgV1Gm38QULAAk44RSirty4 VC3V1D7BOI4ZHswp1QhLSBvxBqXDCYwn20yZatsqLfuttNuu4EA+Vck6QPFGBHAY1qXr0XLL fRHuattqtwqgozl5ePEZgRJxjhUMhFskjW2uBnmB7aZVBbt6lgMUX4mBAaOMA4Gs5pYtdvuG s3byWma1bCm48SFDmAW5SRWp1MLZWCpKQCJGRkEYUkPhZI8kKUC3I1BjqOoScxkPZRKp2uDQ TcS6GWcCSRhke4UwgGYgDAREz38KYMGm8XCHQFKYYTJx+JpnGoLVQSQ2pHXBsJxFDBRS0wVm JJBkH/RVFGyMlMAGTjj7KsqYV5i6S0wZ44zQFcb8MhbyMHKg29OMASDqjt50XJGhFcSuJHhx wmiZMS2pDC4JBESTGE45Z0BLtR4maUV1LW5zcatJgE/LSxS2CaiCcogHA++mAQ80KAHkHGJw 92VLDJTrdUqrgXVybSQpOfHspgyttq+oXEIJBk5EYcueFUyD8m48apBGOrAY5/JUF3BbcSWJ JxcOSfEczQ7lPZTQWgDGVaTjwoYWtraqVa87kah4FK4iMfi+qrKTD0YuA5iBX1HpEHI+FYmg stdOBMcpAoKJuffEcooBKuYJcY8DhFFXLAYRyzogZcgggY+2gIdpAqgwbcYnLtoL1pGB9lBa vwJPcaihFx/MIIHlj4GBMnvoHbbdX9pfF/bXns3kxW4jEMPaKI63XfWvUer7O3Y3+z2m5uWh pXd6GW8O0ENHyUuSR59LisJCijTQioRioHcYog/LQYz8tBURlj24UyoTq5kDvFABF3EqSaCl /MRMT20F67nFfloAa6fugUFC5cJEAe6gNlLcfcBQQJpzY91FWAeZHKgqTz9wFBajVMz8lARs 2yQTJK5dk51ALWbUZGRxqgRZs/eg0yGC0D9ugLybSjEmoOV1lEV7JXjINdfG5+VyicYrbmJD Farns9r6J6j+X3di4fhtuA45o2DD3E13166uHaq6vsrXT+o7rZ3FJNi4yDtWZU+1Yrw7zFfR 0uYxqbZ+FI76y0skfd91AneWdvuttc2960Wt3RpP0EdoOIrWm11ss+E21lmK8F6mt7vaG3au jTbLQl0/C33ZPAnlX2fP+d7tJ/u+Z4fxPVtf9i+hLd3f5Ta7RPM3G90iDzJOHsrPm888fjk1 +etdfD4L5fJ1/aPqW2/QHqu42d25t92Durai4bRSLeMnQGkmcOVfK0/I5Xs+r5PxZpOt6vB9 W9Ieo+mHcPuen30223vnbtuHtsiFxJhS2chTFet4mPZ9A6/vd0Npten37l9iV0hCMQJhi0Bf bV3nGZvY01u9xr1or/Q9xYFzZ9RsPt900FVuAiOWHGa9P4u3j3ll+flw/K08mlz9fDNYd7V5 tqfEdWlRyYHCDXs/F898e/C3o8X5Xhnk05ydXf6Pc6Zt7l266anuKVKqwXxcMSrV+Z/vf5ev m8v9P/Gf737d/wAXx3TXFbrF+w10u0ksBoAOHDP3V8Ox6s/bWlgLbZ1YOFJXVjjMYkYHPjU6 r+x73CLCfho7gmLgXxEtAx/d51JtSwDtaS2iPN4iRDGVIA+yR351SWCtrYZ0XcW/KtsAC9lY ZQcZE58MK1mHQCIhu2rdklrl7B15MDIxM8ccKzhF3dk1u0hvlbjXdWpcQUK5DkZrXaFjGNHm gMCH+yoXUCWEiDzqWpgdzbW7dqSzNfBl0IACwYIq24LFrbshbwXV5uUCNJWDMzTIXds3Wgi5 qMCGEkQFEDuAwpktA+1vh0lGkiQFWDp7u6tQwHRf8uJwQ4SCc844VZ3KUGeQoUgAeIcT7qrJ jTcUOyOiKwU3IzaOZGccKq5Ff2tq1aVhdGpyCtsoVYoftHCB2VZV6C2u31uNt5cu0aIYLCwS wAMCTMgk0l6kkpYRLaAsztJJFuBISeLczU6UEpW6zzdSyNJItwYaMAhCjEwczToZZ9d4W4AM QCiZLAOZkYzVwZFouDb+bqUam0aZGoQJmM4xooBHGCwyw4mh0XflLhDR5YJEkFSCDljVwoLd yyWIkzmXP9BQONwoIZgNJK6GBDRzOFMBatAKg4N8MiINKHzgq2lZW0gXwTIeDJIgDDsqGGe6 /jJ8saZmOQNVmxQ8vnJ4R2/1UZXIZWuKZ0wNJwOPEDM0WwSNpTUWJIBBEYnDCphMKBEyYDR4 ZzqmFAgsNSRjFALpZ0iFKZ4gz7YqgHCqq6G7pGE5UyZPk3rSqXVHTSlpVtgBhJLMzDHjgSKZ +F6Mt/TbuMLj3DbBIVgniIGRjIA99WmEXzPJ1oCUAJZ4PHAmoiyF8ssTgB25nsoFWl0vLjUq QQGyzyNMnV2R8QJnCvq4eo0XSIiY7KgvWWIhSTxJMUBlVgT7hVgry0OP11AYsIZGftoIbAEA KPfQDiD8PyzQVOOIw4VRevHKQMqgMPIyAoog2HADOqL1pUCy6iPHhxqhbqoOu2Zbj21Bp2+6 2zwrgK/3Tx7qK0m5t4wE0QJe3wwNFX+CR4iPkoKL7dRE1BR3NoYfRVC23K/ZU49lBYuA/wCX QRixBhAKZFeKPhx7KiqOs4GTyoILTzynCTVB+U4HAjtqCKn3gB3UBr5aDsNFwsGy4kGmTCvI Qj4wO+oKARTGtZOWNMqp2QiC4miOX1ZJtowyBNdPG5+WOS6412clLgYrUYruen7xTcBeeHur r464bx6z1UhvPsepHLdbcW7rcPM2/wCGZ7dOk15vPrivX+PtmOIHxwInlNcHoMHmRlhRAtcZ YkD5ao4XrK/bX0z1A6FJNvSpImCzBZx5TXXwf85ljy3GteB9D+oE6V6gsbh2EWbbDajUBpux CHHOOVej8zWXXpU/t+/Hf+qPs/T/ANYNz0T1Dc6hs7f5rpnUbdm51DavcZXt3lUK4tapVRxw r5vj/pn6vp/k687LHr/UH6n9X3t5Nj0roF/c9Pu3AXvbC9tN4XtIJuBbdt3jUWwOB9uFevX7 6f6vm7bO71j9Rv092m2s7jfo+26tv7RFnp16xes7g3IAFplCjHUwBOPfWN+3WOvi2uf6Xx79 eOtbPab/AKMgdEuNaveci4lHOjw9sGan4PevT/c+mseY9J7PZbuynVt1+JfckKi/CGTwl8eL Zxwr2fmebO2I+X+N48a9Xc3HTelXxgrW2GIZTAnur5m3i1r0bSXuyDpHl3Ga1uC0iFBHHtrh t+LL2Z9UWlnrIt6NQuWw2pgCJJywUxlArlfxaenp3Htt7o847qy63MRbt5LqbDUxg4Lnprhf DZ3YvjwYkqr2yyAsgIbAiBgPEcRNY49MMYwrcb3wIC/4qkao55fKIrPFLDTeN3b24tqTYV3v XkmWLEwWOX2op1s/ZbE21tHRxipU/FhBkZd5ipKXUJ0qFFkaiCRqbKTngDyirKGXN3cv3bVq 6PEqlCygDVGHwqIwAptc4TBYHmY4LrkasBmSI91SoEK1m5bAcoE1AspwORjA+LEVMIZb3d5b hZb7C8oJ1z9k4kDiM6qnDdeG6Nykvey1GAAcNRxz5VrPyyzNuEvizr0obahEVFCyoJMnAaiT xNTkuQpZYm8rEroGqOGrhnW8mQlLegBCfMVSLrNlpMQBhMik2wW9BqUtm1cWPMtBg3mItxWw hfCf3uNalMlG7fQXrasxS6RrECGCYrzOdS1OuEKN5QuNbAtE6Q5mdQEx7qsWUBtW3PxsMAFh pEDhBqt9BXLS5pJkQdWBn2UKzsBIXSyg5GOPsqs5CNOoEnVBnSfFP+mnUhd3bM4F5QPKxgkE Akcucca1lrqK5f3N+4PPvC86qFD6clHAkZxNMpQo5XwtbJzAYGMYqLgfmWlCi2XUgeMmRJIk gYnjhVwYAb7YMjBlZQdIIkcIPI9lGc0JJNskkzGC4Y+2kOorL7i3cDIxJiAY4EQaGDFu2lAR 0BaSxMwdJGGEYVS64AQjAlzMHDtrJ2TzEgDSCmIyIPbVTJ825EvricFyIHfjQ5Fm3bBGpl0u CRPDvNEL1XbZy1AfCVx76nQUt99MHMGZIPuqooXmXSFJVhjPCKYBI6sSScTGfbQEbXmAoiqZ XDTSK6RcsM/lr6r1JqLDCJ4ioKi5mAKCme6pwGPKgpTeJk6u/CKAyboYAEzE++iqZrozJmiK 1MRnjRVgOew9lBPKunDUR7auAQtwcWM99QENPKffQEDAnTQHE8AeVUCbYIxwoAuWVudhGR40 HpfTvpNur7ZvyXUbNzeoJbZXFNu57GMq3fVwnJg6h0vc9P3LbbeWDZvLmrjHvms1qMem2DlP ZRRKBnBI7qIIgcFMd1BArjJeOM0BRcMwoFAJ1gQYoA/EORoqA3QcaInmPMEmirBwHjgcpqC/ DME/LRUZbBzfLKhlDbskfxKASLQwBk0A+GZAhhkwGPvoFm4yiABNBl31xzZ8WWUd4rfj7seT s5zxxru4wsjGqzW7p10276MOBBrWtxXHePoRU770tuLQEvsLq7pOflv+Hcj3qavn16Zb8G3V 55UcYwuGUkV4XuMLuIDOqseOBwpkwB23DGEgjnH10Hn/AFkHfoG6svibui2BhMlgfort4Nbt tiOfl2k16vkvVelb61d827bi05hGBGSjjyr6N/F3x2eL+Tp9k/m+pi35X5l/LiNOsxFc/wCH c9nX+b0xmhsvubAHlX2twQYQlYIMg4Vu/hy93H+V+j1HSvWHrK91Cxf2bfmt9thp2+4vFrhs jmpuFgnsrlr/AGvn0lenX+68Ph0N50vq++Zd11Nl3u9I/EuE6sCSYUNkJPCvVP7bt45jXDht /cJ5bnavX9As+R0iwj/hsJJtxlJPKvmfka3XeyvX4tpdcx0WdChU3cM9On664OhflpPgbV2i BRVMApyYHjjUFtaS4ukgOD9lv66WSjPc6TYDEqr2Tx0NKmOwyK5beDWs8YT/ACxgxZbwgnFW HD31w2/F+qs01+Qttt0twMyg2o8ZUEHL2g159/BYxfDb2Gt61IS2yzOTeGWIwJNceLHG/IEd bNxkMQ8aTMmJk5DCaztMMWNaKr3/ACl0WbukgG84UF5yU/Zw5mrJElodzZs+cArMyEhII0mV iTGOEmM6nbsti027ut03LlsFDCWz8TGI9wNOrM7BuC0iqGKlo1BkwKqMdPtzotWt7zUtKpGs kROQ9p7qTZkk7XzAxV/wgVUAdmVMKavmF2tC8TqQEgkgYydE9tX9kwin8uXVQWuMrC9I+Gcl gjMcaS4Xj1KG6dr6kDUwI0iASWImP6qzd8RMUyyt13Or8NpIcHB10mCADyq8zB1wWLr228vy Ciqtx8Wyb4mxjHLCry6YXottptdxulu3Lp29ss3nOB5gU4k6EGnDIAT7a1zOjKyPetC0Fti4 rHQ4K25EZOSRwXCrygPeWl215UPl6WRLoCOX0eaNWlnMSy8RW8zpfsx1N6t0+1ah9reXeTL3 ja0gW2Kg6RpZpAJiYAnKtXF7VbHLDrpUuDoyKZ/J21gyo4jSh0gyAF5GrktLt2biYMdeBE0y zlGRWKnUuMxbjHDlNMihbseafw9LEy/djhFay3KHW6sU0lbeJ04MI+emTlVLGoMGP7sx81OR kd+9e/L2rPmEqpZjaYgqGcjEQOIFWU6lBYxMB4OuTPdFEqg1oIC2pcMwJHbUMQ9bS+Tcueag FvT4T8bajHhXjHGndOKW1tsuA1LwPM9xqQxBW9VtmVDpR1i6ow1CZx7JFUwUB5ikyTBGGANE Hct2MVtv5i4SzeA+7GmULNpXclRCERpmY5GauYols3CCGGNuYCmDJ45RTosjoMLoA8Oqc4gR X1HoGLLHiQe/Kgs2YzmRxnCoBv2mTbrctBWuM2nyixDCOJEVPlRoZBynjjVRZLEwFmORoCUj 7SHtk0VCyEwoAPD2UFTyYUBFHOCkknljQD5N1uZ99Aa7a8I8IE8zQNTbOeKgccaoYm2VT8QM eygJra5QO/OgBhbGMMO4UFWr5s3VuWXuW7qGUuL4SD2EGhh7Kx686duulfkvUexub90/h7i1 pV+zOIbupdv0Ti8nc3Wzv3n/ACqPatajoS8QXA4aoqNLEzmT2CgNfN5EjkaBkPGKVQJKDNag WXRuGPaYpkQqvAcM5FFA9smAR4ePOgX5IgalEjjNABtGfDB9tAthdBwEfLQD+KM1JFAQuEDI 0FC8+QwoCSJGpiFmGMnKa1rJbhnfbEtM8u95wt+XrBPg0519C/j6YeDX8jfJHUbIO3ZlcOFg sF8Ue7P2Vw9GK7e/McdirKGVgwIzUzjWbFlLOFUp1hoYGqxtH0T0fuFvOm3uGLe7RtrcnldG ke4wa7bTOrlpcVwdw++s3blh4W7aYo6wJlTB+avn3XFfRlzGZrl3VJicsBjUVR3F2QC4HfQc n1C+5v7a3Zto1xS0xbAJkDAGeFe78HbXXa293k/Mlus+gdM9H9a3gBFlVX4gLzqB7QA1fY/n az7fL/j2uT1r0hvLTNtd9srttbl4st6wPMJVTjoAifBXPf8AL5TpGp4sOl0H0f6fZltzuNrt xqus+9FpBc0wAowJ45Vxv5O2rfqlK6v6V3PS+rk+mdmd3sNxbViFDOA8nUuc91PH+Tvr1mDb xy3Fbum+nPVl9QX6Q+3n7dy6qL/dc6q7T+4//tGL+L9NibfdbUvY3KG3dRiGQkN8oMRyr5X5 /k133zPp9P8AE1uumKMspwjGvE9QSqnIT3UBBrkQGg8jJoAY35yx50Bpub64HLlFTANr9xhD BT2xVMlkg8Mf2SRTC5BcRLilHUMhEAMJrnfFqvO9mYdJQDVYvNbcxgQHXDHsNcdvxZWeOtJ3 S7/buC//AFAgHzba4TmdXGa8+349jG/jx85D/M1ujSCyMB41AxB4mPZXDbTaON1F5zbrcAWi WOlsMzpicB2Bazis0tbOu9BVtAAa4xBGBy5YRWbLhWq6L9lyb6aQdQthSpJwk6lmRnUmtwWJ t2RLI0yWIMLykY4k4xUtprqlncorhrhDMqDVqAlgB9JqZ7GFXnNwm432kBPCATiY+Stcjrk7 yUvKUAGtAW1A6ZY8Y7BU7mcFWNvuLe7F03A9tFHh1ZYYzVusS0OogDTLHCVU54gceypxMmW9 y1trdoT4SdTsIyxhZpjHVOIBdZ7FqJJYsRqnmSeGNWLg+6mlUJU+UwGlSJYjPhWgY/BtCFBU kKuGRnVwj2zSbU7GCwu5U7o6VtJc03bAlRLCdAOMDDAk1u23qG7WztW2pY7dLhRzdbQ58/yU UEypPwAMMRnW9Z0as6Me82ptvpsXFvWGZlTc29QR9IBbTqAbDVjNS4YrGwvIdWq2yj7cnjxA islgblwkLFsuoPxcY9tayZwO55LqqRouiSzhj4/uyDgIGGFOS3YC2QzKjswQTqgAtl9ngO2t coss+Rbbp67i6ieem3BDE3bk6fApbGATjEDCrLKSst4IBqSRcw1yIkkdh4VcktLAIxI8MZEk 9+ApG8xdttuLh1rcbWrFUUhdLGdOYYECrIuZgLpt4VrepCANak6iWAxIIjM8KMWREbcL8GBu CHZgGgZ4A0wsRjeVsE1CJAEgTkamGctGhRbR5Zbp/iqD4cMFjPhUXoiG3phQ2eJnn30Lg3Vc W0bIGpS4fTpBbAEfFnHZVidG/Wx+wfaBX1HcQuHLSedQTUTgVPdQXq4FPaTVEkYYH2UFalGE e+oLW633ZHsoLa5hkBQEjYTA91UGLzSdJjuwoqjebKogPzLB8VEiijF+6fhXHvoK826cwJ+W qCFy4JyI5VAdu6ftQJ7Kob5vHDuqAXvqfs+yqM15Q/iTwsMiKirs71rZ03hp5XOB7+VQdC3e LCQQQeRqgy4GOJqCgEYToy4mqI1tBB0jsoFkxhpHbjQUbsYQKKU915J0zFAprznJYoILjkTh RMoTzOFFLaIwE0AG7pIECgl645s3MAPD7cKuvdnbsDp3VXsWbouSyELbzxCtOqPdXs08ljx7 +LPZqNi1dTzdq8jiPrFezXabPJc6sN20hBRrYGMyBBnnWd/FlvXysV3bXFBI8S8x9Iry7eOx 6dfJKG1NSFeq9M7orgDDIQy981107ONdD1rt9HW23irpt9QtJu0IwBZ1h/8AXBrx+XXFe7xX McHxHJsa5OqvJJ7+2qMfUd820CzirA4TB8JBwr0fj97Xl/KziR6v09urepED4gAspyx7RXfa vLHU6pYs7rS9l/x7U6ICMwJzjWePGrrU2j516yRdfSdkw0XX3VwggAHToBMAM4GMV2slc9bZ K9X6ce3b3HlEsWRcG1OvZlFN007vWvc1bYTh25nCvPh6M9HgeqO93qF+42MtGfLCvJ5f+Ve7 xT+mMpViIgduNc3VFW+BpFuFGURUBanyKg8waAvGGwQRwiqKfzSf4ZB40QE3F+yfdFAJu3dQ m34RxPGghMwFTSOAmgv8TARpbnUEIvZMMqKTd2lu5qa4oLRAfGR3HCs7aS90c9+nbhW/CcMn 3Wyj3V5t/wAb6LrKUv52wuhrYAY6JAJYIMc+VcNvDYzfFZ8mi54LY1LdcDDTAInPhNcuCXxW itstzC20kCArDgxmYPGsbaud8dhoXbNb0GLl0CdRIGecQcqki4wbb8pmtjcubVpGCvfClyLZ wJKAjVFJGMkbhnN8XzcLEwBzxGB5f6aY6J3Azg6A0B2LE4ySe7sip1hgVm9cZQDmHkqM/opU w0XHUKqAagQdTRBBBxqGLCb1s3bFtwCitiFxiAY48TWoHqRa1CZBDQc5JXlRZGdPNtsrOWOJ dmyBxiPZUwi9tvIItm2SzvqAhtJKwRPvONSzoH9S3t+7fTWQzIv4bzGkTML2DEVq+S3uXKrd zb3bV53ZoEqmAWAcMsu8LS7ZqSJfGztbYN5muYBKmPFMDA4kiPlpkPaztF1Ay8g6BMAHDE8x nV12CNzY29t0WyfNtaQTdClSTExBx8OXbVtnwuCPK0kjXpKAmW49gpKjVc6be/I4vYZLJ1Lc tOhueIAkQYdwMhyrci8ejPfR7WtXAY2yJK4wGGVWM4ZWYl1aVOEYiM8sRQNFizjqUiASpU6p MYAyRApkyTd2dvT5m2YNpORGnlOB7TWpWpszNauhouIGBUYk4VVgWuXNQV9RVZjSxiYq0qPZ dFKeaxAnTBIDc4JE0wBYbiAzM4DAEEEERzFMRfg0G4ttXLHOC3HKYpJKjvAOeEc6+m7rZGnM UAF2GBNBa3BzNAeiRIfEjCggtCPiHaaii0BSYg++qhbFlyAqCILjZLlVFlLgE6TJqKieYRGj 5DQXoMyFaeOFUOCtMaY76A9IzgnmBQTSCfhjsJigoqdWGE86gmh8cp49tBQRozjmKqoQ0+GK AbW2uanLuGQnwoRiOeNBf5a5ZxssdJ+wTh7Kgba3IYRMXBgVNA43hEEzQD+ZMfD3VRYvg4Eg UAuwJ5ioAYj6oqgDEQZoK0LiJn2VAJVT38aoHTwJnlUENuqqCwbp8oPGuRjjnWtZmsb3Ec+9 tbu3R0uLBBX6cq7OOQWb92w4e20H5DWpbGdtZe7p293t90oFwC3d5/ZNevTzfbx7+GzsXf2z 2zI9hFdelYlwxuqzJXHmMDXPbxSuuvkrX0vqNra7gFiQhwYEY/JXKaWVq3L0/V+r9J6r0Pp6 JuAN7srty0EYMCbNwaxjH2Wn31y8vju3Z28Xkms6uAwuq0eWTyIgz3V5b47Ho92pbXL6tHlM O8RWp4dqnv1cf1Ltr1/bWLrKFWxeVmM/ZYx89ejw+O63q8/m8s2j0fpNp6rcUSVVcsxh/prv u8+r0G7ti7uFuMoIxEyRHdiKaps+d+unuXvU3TBbJK7VblvSPhBOknCtXvKSdMO76M3iN1S/ aZtBCiAcMTjU3qaR73c7h7exuT4WRSZGURXL9XX9HhT5TiYK3iZ1EjTEY9s18+19OTBchTDH 3Y1FWLlvPUaGUVkZiFcZ8ZAoBKsciPZVFFWB+LHhUAl2Bw+WaqBLMRy7RM1FVpPFj2zNAy2W X7U9lAeoHMRQLecsccIzoBKlTpZCG5EEGgsIwMiRyoLOytv8SqWPGs3WVepN3pll8Wz7DETh XO+HWtTb7Z22m6sibYRra4RBmDwwrhv+N9G2L26Mp6h1G1bZL9iUIKsACYHMdtee+LDlfHfg /b9S2dvSl5FdWK/FIYnHiMq5yWOU1xepu3ubDzkfcp+ZtCQyJcFo6tJ0eKGiGgnDGpO+al1w XuNsBYsAaPNJe6Sp1soYlQrMMoiYNNrPhnBoewUe2NWsCZPATM5ZscajdADc/L3FcywbSuML P9ONSRnGS9yl0uXDAsyydInLDh31eSYCLu4tWfKYq0FSxGZAw91SpxOuX7SbQJcsudxeuoLT hxoVft6licZEYjKrMYqYuFW0TcEjhkp44HOp8J1E1sPqDkm2oGpecjIciaT9DJZlWQ6GNpSS QYgSYiedJEy1SLYBB8xypXSwlSCDpy7KSYasJUX0IKhmQOdL6SwJjAADjVRLU/ji+Nd4geWR 8OosJM9la1vVMHXd0vm2Lu3ChhbHmKFZWkDT4pPHPCBU+MqYyoHANu5uHtkvufFCeWQAXBUF pDTPZXTPT9T5J3CWrw02LSqlsnxSSzhmJTUThIB4AZUyUu8LNxQm2tMgtqfNJYsCZzAAwAkC pyQrc2UtPcDOLgT4tBwPKOya0YKPmeWGVHkkrIGEnEAUMDuoNNsFBLCWkZFScZpKdSru0sk6 9DraM6dR1DLEA863VlJFm6C2J0mCocThlxqy4ayA2fLJCLg2ZMZTj7KmS16MWrjGNUTyr6ju tLIDY4xQRggGVABVWEEAUEWzOIMRyoG2rFuZLEj2Cg0IlsCNJntoL1WlMQCTkaCjuLAYLznK pkD+atCYwIyFMqpt0WGBx7DjQUL75kgAY0BDcoVBLCeQoCG5IEKJHaM6AGvvjKzy4UA+eZAi DQEFvXB4B20wovI3MYxlVRa2r0iIEcKKFtYMkyaAC92TOI4VA7YDp3523c6lauPtgfH5JCvH 7JNamEtfQd76Z9AXemK3T+qWttuHE2bt26SSYnTcQwV761df0Y5/q8BuLDWtxctvcW4VJBe2 2pTHJuIqTx7fS+zX7ABaEzjyrXq2+k9uv2IGyD8WPeKvp2+k92qzdtAYED2ir6dk9+oDcs8S J7xT0bJ/IgdVrhcQfL9FX+PU/kT6CwsEybyDuBq/x6n8j9FH8px3A9gNX+Mn8gJbZjHzp7gf rq/xk/kVXn7VSGF0yMjFan48jO3ntZ9zf/MCLt/WAZA0gQa6eqOfOsxS196avqhzpZKDIGac Icq07Tftb8DjXbP2D9FNc69mdpK1vtrG4Qvt2nmhzFejXeVw21sc+7tipxFauqzYKgr9dc7q 3Nmi1vL1vIkj5KlmWpWltza3Kabso3314e+syY7F6uN1OwV1WgHuglSr5gjUOFau1+U4x6P9 Oxru7u/dkEZYcDArls1Hd3W4sm95TYvJPEAKuJ7612mWO9w8D6is2l6j066oAN25e8yAMSya vF7q8v49za9v5Mk1iuleZb3Fy9bMMWDe7hXs2jxR9Du71H9Om5ONwAA9pwrzb74lejxaZsea VEOBaeVeF9BYtIeNRU8tBgQJoqCzbxjMURXkpGWdVU/LI32SfbUTAzbsrg1v2zVFeXt4nTnz NQWFtZFYPMGioNIwQCDmImgguLjqtqwqonmbcD+EvvNDAWu2zOlADzFRC2uNJEtEYzRQDUeF ASq8YA9tFwYiRmIoCeyjz4ViMQcazYsuHP3nSLdy22hQHxI0wBj2GuW3iz2a5Ob/ACvcoU/B YBY0hdJnlEGuG3iv0xjJ9vdXQ5UK/mYjBeM4YZV574k9FvZLW7spuHdpYNjcPI5wV7al0rG3 g2ncYubZrRtKdIBLQYAwz+TCsWWOWKG2MQtu4CQRK4ECZw+WrhDDZUy9uyWeyBqMEhVwwYDg S3Gpx+Fobm2t3b4vMGCAqDHFp5dlKWCTUg0KVtFQVAUSTGMn2xWZDjF39L2dJcLfa4pMA6tK LBxyimuqbawvqO2v7e3bDELb3dsXLQME4MVJwkjxA/FW8YjndWq9uFv2bW1s7e2jhEZroksW UBSBqynjGdM9MNXVmvDe27Ny04vWksXQSkEKt4qV8Y4EBT21cXF/x+zOMRSBgbji61y2MVR8 TAw+iamIWgOoW7jEMpuDQrGJBEEzhjVkZPbczba46kBfAogajOAx+WquOhP5s7e4llz+M7EK czHcPbUz/oNKbl320oyi5buku6/FBAEnlBFTqLQ2vKZhd03GVQ2qSXnEMAMxOFM9MmSGO5uu qm4AyBmcYKC7TGkCAK1lMrv3D+XtQwPhl1AMlpJP0UlUkXDoK6Sogzq+9OP0VrkloXW61kOQ Shkgkzp0nKOGLVYzaNHIS5o067i6WJUEQRBjUDj3VJvirlvCXxiTPCvrvWvRdwnhVEhuR7ed QQEScCO2qGLcEQGGPGgYhbmDNBCjHMkjjUFBEkqwYUVI26wIMUBRtJwBEUEPkRAEE+ygXcQM IEe+gu1t1VdRYDsFA2LSrOueyih820G+GT20DRc28c55DjTKL80CQuWfKKCG8SIU49tFCPMJ jCcuNBBauscSaIYtpwA0yOZqqI22I4fXQAu2NuVAVxmNaq4HYJ4V0nl2kcr4ta9L6Z2nozfR tus2ztNwTpW+nliy3aZWUPyVv37M+nUr1B6Q2OxZrux6h07d7YnwqGt+co/aVWx7xU/kbfZ6 dXnX2aTASwf7Bx9z0/kbHo1CdlhIt2B/wn//ABKv8jY9Gpb7RwD4NtH/AMq7/wDi0/kbH8fU H5V8wu09tu8P/wDNT+Rsfx9VHa3+FnZnt03/AP8AFp/J2P48JuJulRiu02lxgJCxfBJ5A+ZV /k7J/Hjg7P1dttxvDs7nT7G2vzpi815RqmNPxmK17dv0Z9WrtTuZx6ftiOy7eHzms/ya1/Hg g96RPSrR7V3FwfOKv8ip/HU++2loBrvSTpPFNyT/ALBp/Ip6AJ170/8Ab6ZfB7NwPpt1f5F+ k9Bv859KPbZX2G8BYHTpvWyQ3A42xke2nv8A0J4XNtb24jhrYKxl4sa1PKxfE7O16jttwIug JcgiTkeFejTzZ7vPv4rAX9kVxGI5iu/dxzhlZGTuqWOk2UCSQqgljgFGJJ7BWMNZMa21qBuH VSRPljxuO8Awp7zUsUdjr13p7f8ARh4Px+YR8wFc7q1G8+rxf2V3b3bXlvdWNawJxBz9lZ8n WYa8evHbLz3XLB3u0s7nbXxZba3PMOrA6SpUiD315/Frddur0+azbXo63S+jbfeWku7TdqGc LILSJIxmK99xh83PV1H2O+6b0ptnuLq3rLXlay4nUuB1KTlHKvF5+z3fj92EiDAxx4V5HsXp vADIg8R/VUwuVrcYDTge050wZFbgkyYGWFMGTCqpm89gNFDqQ9vYaYCWupwwOVMGQm+QM5Bq Ki3icwQahkWYMgzxxpgyO3oWYBBOdVVwDiBhRFqkjAYc6CaUBxNETSnv+agngzIPeKKsKhxA wFAPlgZYUUQJBBie+oILgGQx40BC+pPigxjkMKxdcta72Iv5fEeVbZW5qK53wyus89jLuOkb G6G8sG07DhlJrnfDV567d2A+nN2hN3b6coZA0zjOTE1y31vyxfxtbP6avcXOqhLPnbUK1hPL vtZXSHDMYa4RPjxAPcKxdOmHDb8Xdju7u/5/lkN5lsmbcQQRnKmpwcNvHZcLs37JYICFYnwE 4HDKaztGOOGjb74Ei5ccQPCtvLE4YfPhjWbMB9y5tTIZgbgBJucZ7ZzNT5ycg3J3V3EizfWN JVQtuAoEgAwCQMauC0veb5rl29f1KqsQxRFAUwAAdIOedEtYtzedDpTwISPHxhsfER2VWWi6 u58va7fwhWUshBBYa4+PHPw5VPhKG+8sllm1aWi4RkCDgB2VLt0MUd+1t7m6fc2lIZoVWJDF Yxxy7aWraO5ttV02Nu6JbQtcML/EwIxIkwTkK1L8Nchbplu2nuiDdYKltApghR3TnxqSJ3Z7 92zZW0xUCFDKhBZjBw+eKTOEVZ0vaZ2kuIW0hxy4+yasWQLJcFny3eFVW1OcSDJAmcqkuGMG vcSzsUPjuFzDDhiCYHyU1mVp9+1aNuwdvcF8toPnKpCglNRTSwGIxB7q1np/joVrN61pjAEc zX2npLN4TAb2VAHmTxxPLGgrW7EQpPZRVgvOCR2mqhieeBMgDjRRM7n7XtBqIEeaGwc9k0wq eU/2mI58qYBJaH3pPIUBm2pzaKAlQcfbllQMi1E6ZPeaAWNsYaBnlNAXm2wYCRPEUVPzCZAC efZQWt22eE9nKgIPZSZz450FHcIASM+OFBY3DmSEkigg3T5ae2gLzn5RQTzColj7KCmuoRJM g/ZpRmuJZPPXOBwoGJea0IuDVwBHLtqjSl4MM+FQwMpK4nPh2UAmyhUhngxI9nDCpapfw4CO +qBbWDn3ig8p6v8AT1jfKd1YZbW/QYqSB5gHDE51003w5765cj0961vbMjYdV1NaQ6Fun4rc YQ3MVrbTPWJrv8V7qy637S3LLB7T4q6mQR2VxdVvZssCriQcCp5VRwuq9PWwfMQkoTGo8DyP 11YxejAgx51YjQpitxijDEYg1qVLHR2XVntgW7njt/dPDurvp5bHn8nhldFUsboDyDLn/L+1 Xq08kry7aWJfT8ohtbf+KQRf3IzMiCls5qvM5t3VrGWrtJOndzGtEcKWJKWyA4ETWcNSlG1G WI4g1i6Omu49ulkk27tw2lOUqHT2jOs4sXMrd07pu12r/mdtaRCrHVc2zZ9ptE/NTkXx57Ol Z3l/dbbeeZu/MtYNZtxADLHZMnka8/kz1mOjr4pJZ9sq7jGTJjnXje0fnPiVlRx5UUBe5GRI y550QPjIgyDnHGgsMwkjE8Zzoo1vXIMnvFQyLzGaMAcIgqKCE2woGkDgTFBVs2xhqEn7woD8 5QI1A+zCmDKfmY+1jEZCmFyE7ntOHZTCZCN1xJnjFMGRfm3Mkz7QKGV+cDiSeyMKGUFxCZMk cBypgytbi5KuA440wZELxjEnuphcgZzPDtqYXIS5yMCiZQFMT3TTC5OS6hOOAqJkQe0v2u8Q aYXIi6HBIJqYJUW7fABBkcjBE86xfHK6a+Swi9ttpujO52yNcP21wNc/T9Ovu+4z7jolq7cR rG4ewQCPENeeE5+ysXxUt027uLuei7vbXHJUNqPmK6Hw6lzOkmAcOArG3j6dXDbxSdYZuN10 /wDKqAb5vkIboYoLbOCRcwGIERBzzrndOjz7xnHUd0l6HVQjKcVgwrYHPsNc7r9ON6n2yu42 7GMAZtjKVy0zh31ueHbbtGMnFdu1ry2Xwyx7cRAr0a/h7fcTmZbu7cOHcFXVCqsAGggQufDn Vn4W2DmTY6XuL1zzLNprijwlliBMAsZrP8Dy/WT2Q3+W761bQXNs5JeZjGJyJXurHk/E8s/8 bhddtQtcVbjyuhiCrgkySQCcu/OvLLdb1a1hW1uOt0Bit1REIcMhlVlTB43yDebrzICXLL2l VVBAkTAJIKjtFa126rKUu0W2rG1cZrxUM1swpTT8WoE5DhWendYv+Xbh9vcVVuG6hQ3i6sBa DmFLnISSM86s8dXEIJO3unSAfK8UjxLCnxzHCanH4SYLsXrbPZh9YZnCjIAiTnVq2TPR1jbA JnT7Ma+26iRRnI7hhQMLRkKAHuOTORqBZd4AGfbRVO9zs76EMbb3bdu1dYrpvglAGUnwmDqU GR7aC1W4ePfQELZYibh7RQGLRUTqwFBFZMiJ7RQH4AB4TIzoALGc4FBWtiYkyOdBZYARMA5U Fo1od4oq/wAwonnxoKbdWwDgZMTNBYvGMCI4zQEt58QMs6AWusxxz5ZUDVOOLZZY0FMuoEli eM0FeQIkn30EFoEyYjlRTdFqILR3VUK8m3bYtau/2TzqLKu3vBq0khWHCget1TiHFARZSDGB oFENjAJxzmpgeJ9demdxuCeqbUNcuKoF+yMTpXJl7uIrr49sdHPfV4AzJk413cHW6D6n6h0i 4AjebtSfHt2JjvXkaztpK1rvh9H6X1zpvVNsL9i+qgfGjkK6nkwJrz3XD0TbMHud90lUZb26 2+giGDXExHvp1Ojzd7d7BdybWz3VvdAiUVHDNAzB7a6yZcrcKXqVuYOB/pnVwmRjqNvI4cqu EyL82MGUzzFXCWt2z391LiOhIYGVI4GtZZsy7G163buKF3KyPvDOu+nnvy8+/g+ms7azeTXY YMK9Ou8rz3WxjvbR1OVawmWdrRFSxuUsrWbGpQEEGRhWcNZXbvXrVzzLbFX4nn31MNZy3Wuo be7huFNp/vpl7RXHfwa7N6+XbU47dmGu0RdXmpx91eXf8faPTp+Rrf0J8eojUw5jGuGMO+RY zJOoDKgnmtjDR3igMNaCyzknjAFRVG8oyJjjVRTXgRkZ54UyKF22cp9ooCOuMgRzFBczHA9t AJuCDiSR3UBAOY8MUFM5HbGEDGgEXG4iKYBC4yiCKC1vdsdnOgL8w2Q+UUUJvt3VEV5pjIHt ouUNwxGAb30E14wB30RRukCNMmimWxdbFUPfjWppb2jF3karW33E+JtI4AY130/E2vdy3/K1 nY7yyq+M6+3AV2n4U+3Hb82/EDqC4L4e6vRr+PpPh59vyN78lX7QurDzB4HI1nzfi67/ALte H8rbXv1jk73Z2CfLZCnIrhPLvr5Xk/G43Fj138rlOjMNvtbZlUGHEiT76mvj1nw47b290ZyT h7eJrrIwbY2G63DfCQvNgQK7aeK1m2O5s+hbW2Fe4PNfkcvdXo18cjOa6ipZtLCqEH3Rh81d Jql2kZLnUFcsu2PmsB4mmLa/vP8AQK6TXHdzu+ezjdZ3W1ubZ18oXboEPuEUhQSQIBGPir5H 5v5PiudZJtfv6enw+PbvXOS9tS6M4CG4CBEYEdnPw18KT5en4Ub3/U/mrltXVDDMAQjsPvDt nEVqop1t3X/NeaQVVmLR49RmZHaa5/o1r0Iv328y4PMa4bw1AliDcOBGqMDxwrpL16s9TbG4 tWtsURtO68oM5OGokg4YTxg1NcRMYDt7VpgdRKuplQAIlwYbhS3rkdMm0IM4nD319p3WbluM seONBcZEe6qJiOzlUFQIzBPCqKKoucc5qAdJjAYDGaKhkSZIoILgHGgs3xAnExh3UEW/cGQH cOVBf525E4mfbQX5xkticMopkWrsc/bRRSS3ZQVbXsBONBMB4lUdndQVGoABYOcUEa0OeJzi ggSI8RBFAekgGWg0GPf9b6T050Td3xaZ11KIJkZcAasmUtkY29cemkE/mmY5aVR/pAq8KnOM 939QvTwHgW/cjkoHzmr66eyM7fqR0pfh2l48pKD6TV9VT2Rnu/qXYJldi3ZNwD5lq+pPYRc/ U2/iLexQYRLOT9Aq+s9jHuP1F6ncH/d7C9viP0inqT2VlP6g9eB8JsryIT6yaeqHOoP1C9SR IvIO62tX1w50Dev/AFRM/nCo5BEH0U9cTnS7vrf1BcErvryE/FBA90Crwhd65O6377ljcuwb 5M3LowLTxbt7a1OjN6sxudtUwrVNBJ7KIK3du27i3LbFXUyGGYNFet6RvE6yvliE6kg+DLzQ MyO2omDvKuh9DKQwMEGhhq29ljmDAoYdHbW4YchPzVMrg4GkGixvL1htVtiprU2wzdJXW23W 7VwBNwsH74+qvRr5vt59/B9Nbba1eXXaYMOyvRrvK891sY720ZMxWkyyva7KljUpZWs2N5UQ ONZsalHYc2nDIxXmKzlcZdRNyl4fiAXPkYe2sbaa7d41rttr2oX2auZsPM/YODDury7/AI9+ Ho0/J+yLlllwLQwzBwrz2Wd3p12l7E+XAznnFZaMt3hAHlieJxohnm2WWSsAZY5VQP4Bjx6Z 544UE0qPhuCggB+/J5nKggBnxQ6gcMKADdCkgAheEUE/MRiMPZQD+Y1EziOygL8xBAjAdk0B C8I4e6qJrVokgHkBUEJXg8GgvWvFvdQEpsjJqAi1sZEGg27N9qy6T4bwy5MD28DXp8G2ucWP N55t3jVIHDLnX0JJHgttWvicCQgY4ngPdWmQMPixlRmeEVUJPkxIuA/sjE/VUyYKv761ZQaz qIEKpMx7Kxt5JGpqxJu7u83KB7TXNuh1eSpCy3CW0nCvJ5Lt5P2d9JNe7t2bO3tG3ct7Sxbu 28fNdS7auxdS2x/dJ7aaeCfLW3kmcyYiXbLXrq3G06UmEVQFGrEwMc6766SOe/ku1zRMyJnj 8ldZq47bSM17qihzasqbt8f5VvhOWpsl9tammO7F8lpV1XYN+fuawcV2drAEftHAt7YHZXPy +bXSOnh8G3kuHJ6hut5eC29AtWYDLYQ46Tllx9lfC/K/L38nTtq+z4vwtNJ/8mNbu+G1Ki0C iNrZ2IEfZB04YxXg4fTW34+wLV21fZ1uiPCw8Y0oYyImIJFZ21s7OO2lULinajxKLQY3AogN j9tpOWGBpn4Zxj4RPFejRcAfBTOrVlB1ZVzZtFu9mBdVrqLbfbSHR/iCkAZfXW72wSs15rF9 hcOpXMIsTAIbVBMcalnRrpY0bc2b94izcUqq6PMI8eq2oViTjqyhe+pjDP7HgbiO0DKvtOwl F+OIB4UBBbwMl4NBNTkxqk8jhQExZZxgcfbQUVV821D6qAjbMZk0E8gkYtnw7KUUbajMzOGG NFWNMwcIoi1CDEkntoqw1vKiGLEFkwA7KokzENjyioqS/Hh75oDBcjHllQQQRiDnA4UBAKY+ uhENvlGPHGgEoQBj8lBYt2/vT20GTqnQum9S2x226JKyCjDBlPNW4UlwlmXAu/pr0pm/D3V5 OQ8DfQK6TyVngzv+mNv7HUGA4akBPyEU9p62R/013w/h76yw/aVl+aavtT1st39O+tL8N7bt /aYfOtX2xPXWW56C9RKCQlpo5XR9MVfZDhSH9GepR/4Itx8Lofpq+yJwrJd9O9dtfHsL8diE j5Jq8ocaxX+n721Ouxct89SMPnFMmCJOTYEcDVymBCDlTJhNB4igmipkURjVMKFS0FJ5Vcgr V+7ZurdtMbd1CGRlwII5VB9J6B1ja+oNt4tNvq1kfipkLgGGsfTUGlrRQlSIIzFRVpANVBrt txfVk27W1uwAnmtpUszBV+VqLIj2NxZuXLG4Q279l2t3FIjFSRI7DnVwgcRRDrG9v2WlGIIr U2wzdJXX2vXbbgJuF/tD6a76eb7effw/TX+XsX11WWB7q9Ou8rz3WxkvbRl4VolZWtGcqzY1 KoW+eVZsalWCy4gwazxa5HW95wfhxqYXLYm6DrBi4vJs/Yc6ztrL3WWzsjWNvcjQ3lsfstl7 Grz7fjS9nfX8izuRd2t218akcmGI99ebbx2PTr5NaSyzwnn7KxhsGlgJigMMhA1Eg8cKAxiJ TPgKCi5ESJnjQRWXJhA50EFoMPDB74BoYUbTLjpmcyKCtH+iKAJgQB7KAWZRAIx50BAMVlcR QDD/AGhFBvCg9EBgFvzWLaRqC+VkWiY4xWp8ox21djCBmPARHymBTFTka38zs9M3Wi1HnPat aldIIGq4QTMYFVq6/LltvfgXR9/1LFOoqptQdFxDLggYKZjUPmr1/jbXtOsePySd62XOowTG lF5nExXstw4TqzNuPzDELc8w8AZH9VY9s+GuF+UO36kwhFVF/ZI+msW7VqSNG36HaaH3Ds7c QYrPD7ay6dnbbfbjTbUIOwY1uapaj3FBwM99dJq5bbsl7qFtLgsqTcvHKzbEt/a4L/arc1jn d6m32HU9xuBdOlVIjyAZAH3mcxiOzCs+SyRvxS3o09Y6P1HZbU2+nizYvXtLW9ww124eCzAr mYrlNrtrmV24SXrHLJFtijTqBxY5ntr5m+tz1fS0sx0QMuGMEca53SV1m9g2KMrB0S7qEeJR XK+CO0/IrBuOl7G6SWDW4ghUxBI+aud8Nb9ut7xhv9N8sOLSl2aIOo6cTMRpxFcr47PhjbTS 9nOfzUL6DpYNjbMgCcdUCKxdHlviuTn6idyFF62Ef4rl7Vq1dsEnKsXTDlZgy3+VvjwFkGnS yTg3Gc4zqdYksyVZ21207AWz44lRAOjPEDnUrXZ1C1wEeEgmvsNrDPMhfbQGrTOoiOIoLKsR IWRxNBPKwEgnsq4EFkhTpAw/plUVTW3zyjlQQWyRiT3CgFrRjHCOVADWRwPHPOixFskk6ie6 oGW7ESCxg8c4q4QelFwBPfQGLigTz94oBO4TKCT81FwsXlMiMs6CLdAERwwM0EV1M4YZGKCC 8oMgZUEN9ZjDHLvoohfB5COHGiK89SOB7KirN2MjE5UAkhwTqMjlQVogyBgRlQXpHLOKC9KT pMczFAUGIWOXbQWBoIE5cBQMLsRicDwIworFe2G1vH8WymgZNpBmmUZm6L01hF7aWLoGEm0k /NTlTEUvpb0xeEnp9nvTUvzEVedThC//ACD6TunGw9ufuXHw95NX2U4Rl3n6XdDAm1c3Cg5M GUgd8ik8tT1x4P1B6Y3vRtxpujzdu38LcKDpPYeTdldddsud1w5GiBWxWmiG7Td7nZbhNztb ht37Z8DjhQfU/TXV9l6p2gsiLHXbQ8VuQFvAcVHOpU7Lbb3bd82rilXWQVPYDQGlm6UDW/Dc UhrbkBtLqZVoOcETSC9G5Kk3213Hd7txgIBuXW1Ofaaq3bPQDLVZLIqADIM0DrG8v2WDIxEV qbM7ayu1s+uWrkJuRj94V308328+/h+m07WxeXXaYEHlXpm8rz3XDPd2TrVMstyxGLVMNZIY DgKmFlACVxBg1Lqsp9vd3V7e+s3VqVqs9RiV+EHMZg+w1nCtA/LXRIGhua4j3GuO/g1v6Ouv m2hT7a5JYRcUYkrmPZnXm38G0ejTzyl+YimNIx4kVysd5VfhtxUdtSCmTh4SOYNAPlDGMe40 BeTAmDHCmBSM6eJGIjCgMbg4ktwiTjQTzxmNMdq0BjzriApYDL9+MPf7K1NbUtkCyWmxKEYZ TNXgnIuEt5k+00xGeTSL3/8AymAw/wCpWeGdtqTbvhi+SOfcv443MOQrPG1yvkamuXD07aWb Vkvre7fMcyRbEn/hmu3j8PTr9uW2y02O9uL+I62V5ASa9mutkxOjlcHW+l7dSCQbjcWY1eE+ TlW61tQizARa0gjcRMFxPbWuLN2A99mGOHdW9dWNtiL+9t2Codybjz5dpZZ3j7qjE1rEYzRW Nr1DeuDdP5WxGNtDNw/vuMF7l99S7YamuWHrfqL0/wClrRs3NL7j7G1skFmP3if9o1x38uHb x+C15F/X3Uuo3w/mi1aB/D2yYKB+1949prxb+W7Pbr45Hreg/qAWsLsuoDXZyWeHdU03utZ2 0y7V61tN0nmbdtSHERmK9f8ATvOrjLdL0cu9t7lkwRK868fk8F1/Z6/H5Zt+5BuEGBM1xw7K /MXFyJE4HjUwShO44tnzyphck31F3JtJMeLM4e2sbeKU51k3XTDcZ3ttr1/EtzE8MJ9lcr4O hbL3c+907cgEWxdQ4HywBcWZ54wa43xWfDF0+l2V3DrN1wLgMK0FSVJybgYjjXPbX9GLrtXc 8xj9mvpNiVzPwnvigZiclMd2dBCzAYKc8cqQCWJyz4jhQWLwCnAQM8aKE7uGEJIOEY0MKF9S ZKcKUV+YUk+EDnzoB1LMZdooq9fiETyyoggzQDBAjjhFBBdJwiSeygvOMO2KVVgoARGHEUAl 0iNEn5qAW04Rhy9lABBxE1BBhjPvqqsgxhE9mVQGpBUQuIzafooIWGUQeEURYgjGQoopixmO HCKCw5xwgg4UFAycDQUUPaedBWkEAKeeNBeoRlPf9VAWtmAnECirQ2xgIEcqAgQcM88aI6Hp vo/R+p9QXa9Q6g/ThcgWbgQOjMeDksunsqyFr2PV/wBJ99stsb/T9yN8qCWTToeM8BJmliTZ 49i9hjZuIQRg6sMueBrLUY+o9O22527o9oXdu4h7TiQaQr5d6p9HX+mFtztA13Yz4uLW/wB7 mvbXfTfPdy21w8sRjXRgENRHb9HdF9RdY9Q7TYenrTXerXGmyFIQKFEs7scFRRmTSj9XbT9F m33TrB691Nf5qLYF67s7fg1RzcgtHOBNZ5GEv/o5s9ntdH5i5dIGG4UKBPauMe+kqWV4br3o vfdOckIblnhcUfPW2XmNxtWSZFRrLE6gHGqpTCoAoJPGqljVteobjbt4WMVqbWOd0ldzadcs XoW+IPMV318rhv4mq5tLV9ddtgQeIr0a7xwutjDe2NxOFaSVle0RwqYayWViphZVVMNZEl1l xBrNjWWq31BgRqE9swazhWlb23vCGAJPHJvfWNvHrt3jWu9nagubCTNp5P3WwP1GvNt+Nfh6 NfyftmdHRocFY4RXnutnd6JtL2DJ4GJ41lpDcIEa4Meygi3XPwke6rhLTtCEEtdlgMAq4Ezz MVuaM3cAt2wPFjV4xLsPzYAUYgZDhS7MXeQu5fIzaO6s5tc9vIzncgnwjU1WePLldmqzY3e4 6dcUDT/1Fsz3o4rtp4erN2PsdDtgg3LhfsA+uu+vikZuzt7zbLauWbFm3pWzZtoZ+8V1t/rO a3r0ibQr8vA1OT3DGtJgP5iynhCMpPExPuq4TJLviTJ7Sa3IxayP1HbKwQP5lw5JaBuN7QoM e2t4wxkVhN1urJXx7a9OJKqW081EkA9/urHPFb4StY23SOkbVt1uboURNy/caXbvY1jbdvXx 5fPPVP6svcL7Toa6LfwndNn/AGV+k1w38j06eH7ef6H6e3XW2ubvqG5J1Z4h7xbmwPwjvrx7 79Xp01B1b07vuk3FdW87buYS6og6uRFJcrY0bc71FUtaueLMFWHuwrcjm9L0jre/2RVhqKcV M1vW4c9tZXrdj1nZ79YwS6c0ORr06eSXpXn20s6xe52f+7EH7p+iufk/G+dXfx/kfGznMrg/ HiMxFeKyx6+5DtfBIgSTgagLU6/EoHfQTz1HHPtoJ560FP5VwwwBxkEzM9lS6ymcNgcSAq48 6qGC8/ECKAhdY5mMImgA3E7PbzoIbloAkxMcDyqLhXnbcASoygHPGghvWYJjEZiKoJAHRnRN a2wCx5TVkt6xLZO6ltMXA8szExhlzq8L9M859rKalEJGowvbT11ecKZLgUkA+EwY5mnr2OcG 1rcSQQfCMeMCrfHsns1ANteMDSRqEinq2Pbqo2bgEhCcY4zU9W3dfZr9oiXA5QKVaJYZYU9e 2cHsmMhe20KccThGdPXsvOBKOCcCecVPXfonkiirkgaYIxyq+vb6PZr9q8i5pVwMHwA4+2nr 2+i+SDFq7JEfDxp69vpPZPsYsuTiMxhV9Wye3Va7cgGcveaerb6X2a/ZhtHVnE4U9O2U9uqm sssDUBj8cGKm2lk6ta7y3AdLfeDMc4Fc2xaCJBBPGmBShzMqQRmKomhmIgjnH01BNDArEds4 zQFAiJwoCt2lgQ0jhRRTpcRmDkcvdREIJxKyDgSOdFtep9N/qD1voart3je7BcBYuEhl/cuY +4yK1KzY+hWLXpD1vsDuVthN0uF0CFv22OWuMx8lXDPZ4vr/AKB6n0nXdsA7ra4nWokj94Vm xqbPIX9vccsDbCgjEHEH2VmNvnfqv0OwNzedLtxmb20HPibf+Gu2vk+3HbT6eEYFSQwIIzBw iK7Ob9a/oP6Isel/SNre37enrPWUTcbtmHit2jjZsjlCnU3aeys1MvqVvdxnUwuWy1uFIxM9 lZWUjd9E2m+B0Lpc5wMKspdcvAeq/wBObDK7sq7ZjJF7AIe+cKvJnjXyfrHpfqGzLuui/ZU/ xLLBx8hqyjz7ggwRFVQGgqgomqig5BqpW3adSv2WBViK1NsMbaSu3teuWrg03xB5iu2vlcNv E2Gzt9wuu2Qw7K7675cbrhjv7BhkJrbJCdO3F3+GhYkwo4k8hUsalZrll0dkcQymGHIili5D FZw1KmIyNZsXJlvdXUyYxyOIqYVqt9RVl03VkduNZusvclx2NW3s7plTA+7OH96JHurz7/jS 9no0/Is7k3dtpxFqFnAg6gfblXLbxY+HXXzS/JLHThpg1i9Fu+FajEnDlUzXK+Sl3Lyjs5Um lrFtordvc3v4S4c66a+Jm1qtdJ+1eaT93/RXfXws3ZvsdPtgQluI4muskjHWulZ2qrsruswB ct4DAfC9M9WpqAX7C3EtWxqZ2CgLiZYxTFMwnqHWF/N3rhK20Z20liBIkxHsrXHCXasb9Re4 QES5c7QPLT+80fIDVkZtKYb65Gl0268dA8x/7zQP9WtyMXZadKs3HD3Q19hkbrFh/dwX5K0y 6u26fCgBQicFAj5BWLu3NG3bbnop3VnatdV7ruFuaIK2knxs7TnGAUSZry+Ty4enTxuL+on6 f7frG0Nlbum4kts90pJTHg6gwQfkrrLNokt1r5v0r0WnR7xbfqLu+XKRNtf3Ac++vn+WbS4r 2+PFmTt96fa9dG42e6bbXxioiU7hEMvvrPLpitXVzH6pu7l4Dd6b4ssVBGK6lME4gY1qTDG7 0Gx6ps7ygXVx4EmuuuzhdXTt29u0G2fca9OvGuNzDFtBTIAnnArp64xzbbG63AGkspAyDT89 akwnc57O33RHnpBH20bGsb6Tbu1p5Lr2Z7vS7KyLdx1nLUJ+quN/EnxXTX8u/ML/AC24SPgv KMCMjHtrjt+NtOzvr+Rrf0JuJtJ/ER7LciJFcbLO7tLL2S3t9u2IvjPANIqBi7U/ZdSRljQC usnPE1AUXCInDnQDHiMmOXGoJrOQE86Ko3XjAR82NBAWJwHsoKhpGQ50Muts08qxBUEudRzH dXv8euI8Pl2zs0ah9wfL9ddHNJnJB7J+ugkxhoWRzBqiwcPhX3VBeqfsqPZQSeYAHExQZ3vh mJ0rHDCpI1aDzv2E91VFebj8Ce6gK2Lt1itu0rMAWICjJRJPsFBVwXLVw27iKrrgylRINAPm n7q4fsj6qplXmNyHuFBfmv2e4fVQV5z9nuH1UE3JvOqqxAEA5AZ48BXh8+2dsPb4NcTJQtuM AJPGuLqIPdwwke6ioFJk5dnOgJVZYIEqeBP0UBAmMVB4Yigjq0rmeAA+aooURgwwjgaIbp0k Y6s5MZVQLFViGxjDD5KiqUoRiJ4d1EaNlvN1s7y39jffbXxk9slW7sM+6kqvpno/9TbO6a30 /rgW1fchLW8Ai25OH4g+yTzyrcrndXd9Qfp/0/qitf2oG23REyo/DY9sVLCV8v696U6n028b e7sFHGT5qRzDVnDXJ85696K2283tveWdNrdJcRrowCXAGEhuRjjW9d7E21y/SlveKxlfYByr vl5mu1uAeyhlqtbqzbV7t66LW3tK1y9cOOlEEsYGJw5VmtR+X/1M/V39RvU/Vb1rpFvqXSPT 1klNptdsl+y91ATF6+6hWLOMdMwMu2rNXTrHI9Heo/V1l71jqrdQ3O0ugKqbo37irEk6RckY 8asmGPJcvT2tKXhuthdO3fN9u0i2wOYg5Vu6uUpPVLFln8y2QA2OgEGDyrGK6SuUUeciaYMh 0XPuk1cGYnl3fun3VcVMwQs3PumnGpbBLYufdNamtTlDVs3h9k1ZrWeUabFzeWWDWyVPeK3J WdrrXV23VnMDcKP3pFdNbs47az4bbXULUkWLkXHXSsZrP3ThBrrljFcm7c2skLqwwyrXKJNa UShOAY+ys8o1xoYB4H3GmYYqvLPAH3Gp0VDaccDUwuVq123BEiorTZ37pgwicyPpFDB5bb3h gdJ5r/hrlt4pf0a5WKXbLHiBdfvKcu8RNY9eO8OWTz0nZOoLMMcoM/NW5459JyNS3YsqEQwv GK6TTDF2PS/tEHNu6nGrmM+561ZtCJCtwGJb2KJPyU4maibjf39jeKWmAN2zjdOgRpu4wNTf NTPVcdB9LtXbe+tbi7fLfl9V/wAu0oUE20LCSdTZjsq2Z6JLIz2drZRtVu0oeINw+J/7zSa3 iMZp6WSzRn21csttnYGRqrN2bmjP1j1D0XodjXu7qh/s2xixPYK47b4dddLez571j9Qeq9VY 2tsTs9piIQ/iOO1uA7BXn28uez0a+ORl6d1jcbd1IJAXKuOG85fRvT/rFb9kbfcnUjYQa6ab Yrntq19U6btd3az1IcbdwZqa9Nk3jlrtdK8jvdlf2l427gwPwuMmFeHyeO617dN5tOjhdQ6Y FZ9xbUsrEtcWJjtA5VmVbMsy7fZW9jut9e3A26bdbZkywPmOEERjhONdNblzurRtvznlLe27 ruLTQQ1lg+B5gYj3VrXZi6t9jq24tnTdUyMwwg1218ljnt446m16ptbpi54DXbXzfblfE6tr bhxqQh14EV1llcusdno/p/qnUGNvbWzcCiWkjSqjMknACue2/FrXTkwW06fuNzcsbPe2tzct lgy2TqEqYbSYhgOazS7TOPlrhY6V3onTtt0a91brG4Ta9NswDcYFmZ2wVLaDF3PIfNWP+Vw3 pL8PGbi70q5dD9OuXHtHxBL6hHAmJ8LOI9s15PJNfh6tNr8hlIwEHvrk6NJBIH4bCOyt+quf t1VoUY+OeI0/109VPbFaGJwDRwMY/PT0092q/JvH7Le7+unpp7tV/lr8zpOPd9dPTT3ajG3v jHQY45fXT07Hu1CNNu+nnzbsSDchdRgZxjWtPFZerO3mmOjR/wCYejEsln8xfYGF8u0CoE/a YtAr1cnm4i3HX+l7aw16/wCcgER4VxPLPGrbhJGfa+r+m3revb2t07sSNKICSsYzBw9ppleL Ueu7XQ13cWr1uSPE+gYnniaJgl/VPS1wt2b179pHswOebTUtWagHq/pmrQNlvLjt8Pli24z4 6S1MnE/c+pek7e2Fv7e/5jxptIylyDw0gGlpIlnqNi6hc9Pv2ljDzLqBh3qFqzJcM465tXvm ztenX9wcPxPNVEXvYp8wqS2riNKbglTq2kMcouzH+qKrIvzGB/6YTwPm/wBVUyn5j/8A10xG ZuNgfZTBlQuvB/BtY82fD3GgrzXx8FnLiX+uhla3XBB02DzB1n6aYMrDvn/0/dDn5zQyoliM bluezV81cL4Jbl2nnuF6yM3X+6T89P48X+RVB1H+Z/qfXT+PE/kbJrT77+xRV/jw9+yzctnO 4+HYKfx9T37KZ7DRL3MMogU9Gqe/ZA+3BnXdJ7xV9Gp79kNza/euYZYino1PfsovteLXD/aq +jVPdsEXNqDIL4ZeKr6dU9u32hvbfM6v75+ir6dT27faDc2Fy1/32+ur6dU9uxV+8jxpkc5Y mnq1T2bfYDvN3EefdgZDzH+ur64c6Vcd7uF0s4H32ZvnNOEOd+wrt9txVfdV4ROVabdyymU+ xiPmq8YnKmfmLR4Me9m+unEzVefaP2J7y311cRM1T35+FVnjqLH6aYi5Zri3nyKL3T9M1MLk sWL/ABZT7qYMjt2SGlgrjkWI+amDJ6vYRlLbS24GYL3IPfDA1MLLFXbqXBCbe1a7VNwn/WZq Ren6Efl3LT5gX5q1KzWhWvj/ADrf90fVRDk3EDxOhP7o+qgs7hfvL/dH1VcphX5n9tf7g+qm TCfmTwf/AFRTKYV57cXP92mTCjuozuH3UyuAHeWRnej2gfTV5JxCd9tBnfE/vL9dTkvEP8w2 E43UP9tfrpypxX/MOnsdKOhblqBPz05HEDdSsY+UrXSOFtCR/eML8tTK4C+43dxcLaqedxp+ RQfnoKQOFGsgtxIED2CTVQ5NzdXjPfn76DQm9DArcEg4NwJ9oomBDbbC4s21lvus7A/PFazW cINjtj4WSD90lvrqclarVtFTRatW7ccUGknvis4wuctNuBsL8vP4lnD2XK1L1SzoZsrQ/L7u 6ATptBPbcdV+aavzEnZdnaM5xwHKrnDOMtN99nsrJe+621USZONc7s6TV879W/qzas69p0cC 5cyN37APfxNcN/I9Onh+3zW7vt/1be69xr3W5uHw6ZJ9i1599svRrG270vq2xhrltlTmcV94 wrEq2HbXqR+FsDyNajGHZ2O+ZWBVo5Vpl7PoXqZ0i3eOpDgZretw57avS3re23m2gw9lsQRm pr0zG8cZbrXm97029tLvO0fhucO414fL4br+z3ePyzZwuqenjuttdXbOLbXBLWySEJzGWWNc 5W3jV9M+o13Giztnt3QY81WCr36wamMFtr2fR9j1/aWgOob2zvYIJtXbRuaRBBi5qRp0kgVZ tWLpHoF6f6Y3n8J7m1dhwbUAe5p+eu8rixbn8x0bqCWbO5F9CodXUEYEnAgk8q1yxMs8cux6 l9U9bv8AoG50vpGzv326luEt9YubUeNdogL6AR8PmPAPYIrt4vNxzt/5Sf0/5/Jrp8PK9Gsd STr+1t9JW8p/MK+1tXgpuoqNqHmaPDKqPHGFeXaSt2vZ/qrv9n6nbpq9Es2Lm06c9y71Lb3b rJZ8+6gWbHlnWdOJzr0ezGl1v/K4/wBvtmTq8l0To920u43D6vIsqtpWOTXXIOkTyUFjXnsd Nb1dAWlgANwxxrk65Zx12x94/wBx/wDDX0sx87jU/nljmf7j/wCGmYcar+e2B9s/8t/8NMw4 1f8APdvxuf6lz6qZi8ar+eWDk/8AqP8A4aZhxrMd5spk3rpJzk36nRcUD7rprKVd2ZTgQ3mk H31P6TFPtdY2Vq2Ldu6LaLkoRgP+zWuUTjQX+p9Lv6RuLlu4FxXWDAnvFS3Uko065060gRNz ZRBkoIAHsq8ocKI9c6e40turLBsNJKkGe+mZTjW7c9MG02/5i9YsIirqfwJKrzOFLiJLWNfU GxQQu6tKoyAgD5BU5ReNT/zFsJn81bnn/QVcxeNWPUew/wDqk+X6qcocaL/zLs8vzSkdzfVU zExU/wDMe0P/AIke5vqpmGKv+fbb/wCoH91/8NMxeNX/ADqwcrxP9h/8NXMONX/ONv8A70/3 H/w0zE41X8423+9P9y5/hpmLxq/5ttv98f7lz/DTMONT+abX/et/cuf4acocas9X2y4i80/u XP8ADU5Q40L9asuArbhiBiBof/DSWHGhHUtr/vm/uXP8NXlDjU/mW1/3rf8ALu/4acocKn8y 2n+8f/lXf8FMnCp/Mtn99/8AlXf8FXJwqDqOy++//Ku/4KZOFT+Y7L77/wDJu/4KnI4VY6hs uFx/+Vd/wUycKIb7amAHuGeAs3f8NXJxrfttld3O3F+zJtsSolWUyMDgwBFMphkuXVR2QpeL LgYtXDiO3TU5HEIvzlY3B/4TD54q5OK/OuRI2u4P9lR87Cpkwnm7j/6O97TbH+3VyYUbm8nD Zue0vaH+0aZMQJfqc+HZLHNryj5lapmmItf5sTjtrSjtvMfmt1criDW31I5pZX+25/2RTNTo vyOpf/BHsc/SKdTonkdR4taH9h/8dOp0T8tv/wDe2x3Wz9L0OijtOoH/AMSo7rQ+ljQ6Fnp/ UDnv3HdbtD51NOpmCXp+6Hxby83stD5kouYMbG5GN+8fao+ZRRMp+QP++vf3yPmpgysdPH+8 unvuP9dDKfy5OJuHvuP9dUyv+W2vusf7b/4qhlX8sscbc97MfpqmU/lm2OdkHvx+ehmq/lWy yO1tnvQH6KmDNEOlbIZbSyP+Gn1UM0wbGyMFsoO5R9VVBjaxkgHcBRTbYv20a2hKo/xrGdZs l7ktimsXrhk4mr2SlGywMEQeNUTyTQC9oqsmrEJmrhMiDEZGKin293cEBvGoynh3VbMo22t0 j8ceR+up2SuhYVH2O4x0sblmJ44XONM9UdTbbO5Z6W5uRbt3rqM7H7ttSRHtel2mVmtw8z6k 9ddJ6LZYBwbuSgYsT2CuO/kdtPFa+O+pPW3V+t3GV3aztjP4QOJH7Rrhd8vVrpJ2YOj9C33V LmmyuiyDD32+BfrPZXHbfDcmXv8Ao/RNj0u0F266rxEXL5Hib6hXO21uTDdfuWbdktejy8mU 5GeEcakWvMr6ZO83r3bR8nbsZRfCWHZH9dd5HDbZ1Nt6Ue2Ia8/sUH6a6TVzuzWvRr9sfh3g x5MCv11rizydTpW/6nsHAdS9k/EAdQ+SrJYzcV6ixe2u+skLBBHitnMV3m027uWLrejyPqW7 1PoJbdHafnulE+K/aOm7Zng64gj9r315/J+N86/6PV4/PnpWDZer+g70hbW48q4f8u74DPKc q8l1seiV0jeBxXEEew1Fc67Z3KXS9gakOOmQCPfW+TndGTqNzqBC3dDlkEEdla5M8W3091fq N0XbSWg6aR5qG4ttiOY1cqsvVnaGdR3fWk21y10q2Ns24U29zfVwbzWzg1tW8IVG+1GJ5xhW 55ePadVmn2V0Db76xtn8+6LRJg2LltnDDgQysKxrt1NtXVfcXntrbuEaLc6LagKomNRAHExi c6ztvb0dJrIX4YMNjwrKuodzuVxPTNie574+mu38ivP/AB4H+Y3J/wDtG0Pdeu1f5NP44v5g +f8AJtse7cXB89P5H6H8cu91hLFvXd6Hb05Ql9yxPIDtp/JT+Om065tdztre6tdDDWby6kJ3 DKYPYcq1fPgngO/me0GfQWP7u4JqfyD+Oh6t09fi6BuO9bxP0Gn8g9FQdZ6KMX6HvRPK5P8A s1f5CeiiHWvTZwbpO/U/vj/DV/kw9FEvUvSrHxbDfD+0v0rT+RE9FN/mHotD47W6R41KjPa1 ETGAOdWfkQvhrobm5av7W3dtgFH4kSYyiu0ccC3a+gttuW2t/dbxNwgGsC2pWSAcDqyrl7nX 1rTY+i7qC4m83IU5SiAn2aqe+HqUenekgf8Av1+P3F+hqe+J66sbH0ePi394d9v+unvh6qs7 T0SDj1G8P+Eae+HrC9v0Khj+Z3/+Sx+ir7oeugn0Ip8XVL3/ACWp7j1rFz0CDj1W6e+0w+in ti+qmLe/TzM9Vf223H0U9sPXTRe/TqP/ALuR3q31VPaesxG/Txs+s4futT2Q9Z17pvojUzL1 b8OToJH2eHyUnkL42c7X0Mpx60o71Jq+09YfK9Bg/wD3xP7jfVT2Hrq9HoP/APek/uv9VPYn rQJ6E/8A3q3/AHX+qnsX1p5foYnDrNv3P9VPYetZseiv/wB6tjvV/qp7D1rG19FH/wDXbX91 qew9Yh0/0ccuu2ADz1fVT2HrHb6P6Tb4ev7YHvP1U9h6xtsek2HG32e/tb9bql3Ns/ARhj31 eWUuuE6X6d2PUd6+3v7hNqwQuly6YU6cwSeMUu2Ca5dJ/QnSR8PVtkf+Mn11PYvrCvobp5y6 ntD3XVq+w9a//ImyJw6htj/xBU9h6xj9Ptrl+e2/sensPWYv6cbQ57+x/ep7D1jH6c7Ef+Ps /wB6nsX1qP6ebQZb2ye9xT2J60/9Pdth/wBZt/8AmCnsPWr/ANPdv/8AV7Y/8UU9h61H9PbG Q3O39l1aew4IP04Q5biwf+KtX2HrX/6Zscr1n/mLT2HrWP0wu/7217Li09h60/8ATDccGQ8v GtPYetP/AEw3fDQf7Qp7D1rH6Xb04+D+8Prqew9af+l++/ZPcwq+w9av/THqHC2I7xT2HrWP 0w6gf8up7D1of0w6hwSr7IeurH6X9Qw8HyVPYeup/wCl3Uf93T2w9dWP0v6h/ujT2nroh+mP UP8AcmnsX1i/9LuonHyiKnth6qFv0t6kMrdPbD10i7+lnVGyt+LgcavtieqsF39PN9ZBNxdI UEsYMAASSa1N2bpXiOpG015ksY2kMBj9ojjXpmuHC7MJU1UysLUw1k21Ze4627al7jnSiKCW YngAMTWb0WPb9E/SD1P1C2l7dG30yy4kC/LXY/8Alrl/aIrht+RJ26u2vhte66V+k3R9psr+ 03W6vbxNwbLs4C2mVrOvBSNXhbXjNcb57nLpPDMNG/8A0z6Hu+kWum+buLNuy1027lq54/xY z1hstPdUnkvX9V9cfCfXP/th9VWL13e9B6gvWbeLDb7kizuYzgN/Cb/VqXFdMvn2x/TjqG1v /wD8g29zaOMRsnBRz+9PDurjvbHTWZeptbS1atCzbUJaQQqrgBFc216SCDERQcf1JZv3U2zJ haR28wYzqIhT89b1qbdmDZbvd7a4A8kcCONdI4WPTbDrKsBrOFdNdmLq6SXrN0SpFd9d5XDb WwRQTXWasWjtPdRpVyp50wmXRtbzduCHe3cBwIYYmrBy+p+nfTvUsd3020bhzZB5b/3k0n31 eEvcm+0vSuLc9EnaCei9SvbQ5+RuIv2T8zCuG34+t7O2vn2ndlu7nrnTMeq7I3LAz3uym6kc 2Q+Ja82/4207dXo08+ta9nv9lv7XmbW+t1TnpOI7xmK4XMdp1P06fFGIoLVgcDjPKgJbg4ZD h2UQSXFLEk4jI1QRZGiPfVHzhfXXqYD/AL4ceaIforrwjnyo19fepB/4hT320+gVOEOVOT9R evD4vJbt0R8xp64c6a/6k9VuWilzb2GBzIDA+zxVPVF5nt+om+sBFG2tPqRXLEsMWEnAUvjh NxL+qG7Bk7K3PY7D6KeqHMY/VK+MG2KnuuH/AA1PX+pzNH6prGPTyO0XMf8As09a82C7+pPU muXjbsoEaPIVs7faYjVNPVDmYv6lb8a/+lSCoFsajg3EkjMdgp605svVfWb9RubZ1seRdsZX g0sSfiH7uFa10xU22zH1H0f1MdR6W1tjLgBvaRj8terXs8u86g9T9at9J2lnfX7ZuWWIs3mX FlIBCmOM5V5vNp/V+7v4N+jzFr9SejlbXmWriG45FxYkIv3iY8U8hXP1V25xoPr7061u67My qjaba6AWuDLUBwH72NT11ZtBn1l6XLXB+YQ+Wmsykg/srhianDZeUEvqL0xcYD8zYDFPMkgA AcjhE9mdOFMw2x1b05cKBL23c3QWtgwDAzJBGHtqXWnRLW96Be8vTdsMLzFLMAeNhmBTFOgh c6Qw1hrHlrc8pmkQH+7M51Oq9Gldn0wG4GFv8M/iw3wk5TjhTqYgj0vpxJm2MMdOpsRzzoYX /Junkj8MgHk7YT7aZMRX8l6eG+3HZcb66WnFY6H07UTDgcB5jfXTJhD0XpsgA3BOX4jUyYhd 3o+yWdLXgMI8ZPz0ycYX/KdtAIe8OzVj81TJxi06RZmDevDuYH6KuU4wZ6PaGW6vf6h/2acl 4CXpJAw3dwHkVtn/AGavJOMeb9QdT690S/qKW9xsWIFvcaAMT9l+Rq63LO0wVt/1A3xtm3+W sknJiikg88q1xZdH0z6ovL1INdIGvAgACfdXfTo5bzL6eLi3ra30hsJjMEHgeyu1mXCV5ve7 HcbbeEjyX2zy9oNaBIX7pP7OVePe3W4evTWbQwb97aADZbORx0Y/NWOdb9cWOpX5/wC6bQN+ 7H+zTnT1KbqN84jabU9w/wD6avOp6yPzu4c4bPbr/aI+insp6yn3e84bO37LhFPYnrZm3fUC cNn7r39dPYvrCl7qbg6doe0eaPpantPUBtx1ETOyJ/4n1PT2HrKfqO5QEtsWgCcHYn5Hq+w4 OQ3rzogYq7aWBggtdBB/vVrNZ4rHr7oQzv8A/wDcvD5mpypxMX1/0Xhuivdfuj5zTlV4mr6+ 6Yfh6gw//MP9JpyqcTE9cbM/D1O4P/zDU504tFv1mpgp1O92RfJ+ipzpxNHq26x1fzTcey9/ VT2U4nJ6t3f2erbsd14fVV9lOLXY9U9Ub4Os7wf8Zfpqew4taeoOunFetb3H/wCKv11fYnFo TrnqU5da3o/4iH/apzMNCdb9WD4et77+8h/26czB69d9aASvWd8B/Z/x05mBD1b6ztZ9e3QI +8qn/apzMIf1B9Y2/wD9fvdxtinMwg/VH1on/wCtsR+1bX6qc4uKlz9ZPVFhddzq6sVxCeUJ McMqsqdSF/VH1L1jaXdnvN2BtNwukrbCglSZILATjXo8XfLh5bcYcy5sVfFD7K9s2eOxjfaO DBFVG7ofprqPWuoJsNiga62Lu2CW0GbseQrn5NprM1001u1xH2/0j6F6J6ctK9pRuepR+Jv7 g8ePC2MdC92POvneTyXbu92njmr0wIrDplKKhFECUmhhz+renel9VseT1DaW9zb4C4oJHapz Hsq5TD51179E9qzPd6NuTZJx/LX5ZP7LjxD2zWbrK1N7O75t1r0r1zob6eo7J7CMdKXhD22P Y6yKxdLHSbSuQbSsCD4gc1NZWuFu9l+WvBWAa25lJyP7J5Gukrntqb1Gz0L81bsbLeDa7pbV s3rF4nQz3F1eBonCY410m3SOfGk3f5lsWJdW8tY/FEFTIngTWmejbsuvyIczzrprvYxtpK7O 16htb/HSTXo18s+XDbxuktmVkYjnXTpeznmw+xbukwo1fskTWbcLiVrudN3WjzBYYDiINTlK uLCrHT711/ADPCKluFkywepf0r2g2a9Ye/b6FumbTZ3xZbK3Hz0lCVD9sY1zsm/eO2t21cN9 tf25W1eZblzQp822Q1u5h8aEYEGvDtpdXs12lmQMGicO+sqoBiJme6gsYzIk8TQSWwM+yqj4 5qMCu7mmsijKtR9vOmVi9ZAoWG3r6OLZAMrbVWnmKEKD+6mRYI50RJxoolPbQEGERVRcdtB9 M/TfqJtnbaj+Fcmyx5OvD+6Zrr471cvJOj1/qnpY3/S95sWH8VfMtdjCp5ten7MeO4r4O4ZG KOIdSVIPAjA1zleiALf0FBQftoC1AcZPKhFG5n8tMixdHtplRec0QGPOO2iDG5u6WHmNDfGJ MGOfOij/AJjvASw3FwM66HIdpK/dOOVDLRs/UHVNpube4t3y1y0pS2bnjCqeADYVLIs2rXvP WnqDd2gj7sosz+EPLJ7yuNZ4RbtWMeoesrlv9x/zG+utcYmaYvqnr6xp6jfBH7ZNTjDlTV9Z epEGG/uGMp0n5xS6Q50+3689SLGrdlhOMok+/TThF513Lf6oNpC3OngwBiLkTHH4ax6o17E3 P6nFkAsbBVuTiblwsI44KBV9R7Bp+pdgKC+xfVHj0uInskVL4j2Jc/UXpd+w9jc9PuXbNwaX QspBBqeo5x5Rt5s/zLflA6bcmbS3CCwHIkZ1rFndm10NnfIvKQYOYrcrG0fWPRfXhfsjbXW8 QwE130uXDeYd7qG2Nyw9tcXHjtcyQMVHfWPNpmN+LfFfP39f+n7dxrbm9bdCVZWtGQRmCJry +uvVzik9eemScbzqTx8pvoqeqrzho9cemc/zhB5+W/1U9dOcW/rn0wty2PzZbX9pUYhT+0SB T105RoX1X6WbLqFmf2tQ+cU4VeUMHqT06xGnf2D3uB88VOFOUH/OOjtDW99tyeQuqD89S61c tCdU6fdBVtxaJyDq6nDtxrOK1mM9/wAgXAguqzHFArCSDjgKI8l6i2Ppfqav5u7tbbqC4Ld1 KpnlcBjVXTXlGdsV876jsbmzvmy1y3dXNbllg6MOcj5jXVyswyGasgEijKUD9vur1lpVu8cD Uw07fT+soxCsdL8QcjUR2NO33aAPgeBBgjuNQYtz0ze2QXtO1y2OROoeyi5ZF3F8H+I4/tGh K0Ju90Mr1wf2j9dFabW/3wy3Fz+8aFbLXVOoD/xNz+8aYRrXrHUo/wC83PaaYTIT1fqn/wBQ 3uB+inFZVjq3VnBU34BzbSs+zCmIWs26e4bN247sxCMdTGcga1GWfpHUt7sel9JXbtjee2jh sfC0lq1NsTKXXNe76f6p8pY3WCDNyYj2mvRp5Hn28X09JtN9tN4oNtw05DjXfXeOF1s7vsfo zpG36N0tUAB3W4i5uX4yRgncteHy78rl6/FrNY9Il6TE1zdWhbgioog1Aa44nAUWDDcBh89F UaASAaBF/a2byNbuIrowhkYAgjuNXLNjw/qH9I/T3US17aKen7kzBs/wyeZt5e6KlkpNrHzH 1J+l/qPpttzc2w320M6ru3BcgcynxD2Vm6X4dJvL3fJvUnpjqXnte2wN/SAr2z/EEZSDFRrO OxXQT62210LYVjZEApvCfLAnIY6h7KnLDF0y9xe2/Qt9trA3e3O03jKLd19uBoU6i5ZSQOJ4 qO+umu/2xtrYyv6R6pY/E2V5N5bGICnQ8funA+w10lc6PZdX3mzvjb7lGtsI1W7gIPuNdNd7 GNtMvonQfUPp/o/St76j6mnmbTptg3W24jVcukhLdsT952ArtP8A7LNc4/7Maa4r5Z1f1h63 6zvbXWur379lN5NzZ2tq5TapbVtOmyiEBdJwM4864+byS/8ACY0/x3/V6JPt9f8A0re16j6Y d2WU9S6fc07q03h8+zwuj9ofarnr5Lf6b/k53x9cx8c9R+rt/wCq/VXUeq3d7bLWdw+12XTR qmztrZZVNsQV0eHx4yWNej8r+m8J0mv+9+W9ftt6aHu7J7pGlRc0qOE6QW0/JXi2jppTzbEN 25CsOgPLK5HDjNBCAuBz7KouFnHKiPlr+l+v251bC9HYJ+Y1vnGcVkvdL6jZP4u1vJH3kYfR V5RnBBRl+JSO8RVyYDgThjGBpkUQYzqiAGoJGOVMiSfZVMKk0yYXr93OmTD0XTfQ/qLf2kvJ bt2LTgFWvuEJB46cW+SqzbH0H096D3PTulOq9St392Ly7nyUQ6AUUrCuYaW44VrlZj9GbY9c 1wX9lZ3I+KAHXiDkwr03q83avC9S9L9Ibfbg3NsjO76mfxSScZzw9leTi9E36OR1H0Lsbqat oW29zliynvBM+6llam7xW/2G62G5NjcpocYjirLzU8RUmzcZjPKmSRU41MmAE44SKuVwvW0T lUMILhIitZTAtZnlFTJhNTHPCmTCGTVEywqZMJIwmrCr1Y4nAUF68KZTAg2FBWvHOrlVazwN ECXMRUyKDNOdB0djviLiK5x4Gp2Ht+jbvcbW4u5SdCxqPMVuXFYsy+r9N3qdQ2CXVPjA+WvR 3efs+Wfqv6ZO33I67tUizuW07xQMFuxg/c/z159pivRptl861k1MtKNygguGKmVwhunuq5E1 kETUENw4Y++mRQuMPhMRlFFiPu93AAuvHLUamDJDXHZiXMnmcaAJoIzEqATgOwUUJHuogYoI RHGirU41Eb9l1W/tiATrTkc/ZTCvUdN6xY3C+FvEM1OYrKWNd/p+13mMabvB1GPtHGg5t/pe 6sPBXUvBxlRcou3uriVw50S1rsWSRlQrUNvhlQMTacTjFAa7cHGgz9Tslen7kjhaf5jWoYYf KFs9Ds5Ygkfu2qk7Kf6gQ3rW12xfTbv31S4eyDWrejOrb6Xbd9G3r24Z7O3uJe2zt8LDMrhl iKszOjO0z1fbvT36t9PuKqdRYbW4SFDXGAQkmBD5YnnVwy+i9O67t74BVw01mxZXYt7pWGB9 lRrLVZuiJPsFRTxc7aiiDihleqi5XNDKRQwmmhgLWgaGHn+v+g/TvWwW3uzU34hdwnguD+0P pq5ynWdnzH1B+jHVtkrXuj3xvbYx8i5Fu7HY3wn5KzdJ8NTyfb5/v+m7zaO+13tm5ttwv+Xd Gkz9VZxZW+8c7bdU3G2crqKsuamuk2cboydc6k+43qbhzJKKs/u1q7dCR0ek7jp3WNs/Ruop 52z3JUta8xrcsh1LDLjM5Um9nZMYDZ9K7HbvcsdM2/k2sWv3bzsVRFza47/Cq0mnVLurc+td p07T0voF5l2toadxv8UbcMT4mVTiiH7IOMZ1vbGnSdaTW/LbcfpPULgbbPtLC3oLFdFsycyy oNRPsrM+0uTd55CWrO12Yja7YNF0jS124xl7rjGJgBRwUDjNY8m0xiO2muIx+MYwM8K5NhOA jIHjQCAQxHyCqIWEEyTFEaglxSIjv7K5tCIfixCnKgBturKQwBMZsAfnBoEXOmbC4Cbu0sP2 tbT6qDJe9NdCuzPTrOOWkFfmirypiMjehvTrAarDoT9x2A+UmnOpxjPd/TzoLD8O7fQk/eB+ davOpxjM/wCmmwY/h726sfeRD9VX2VeLJuP0yvg/9Pv0aP8AeIV+Ymr7E4q6X6B3W16ttLu9 uWbu1W5LqpaSQCwkERwrp4981jeYj3tq0bjFomvTNXltaLYuWG1IYPGtzRi7N+y31sC5bvLo FzNh8M84rc16M2kb2xat3dWpXN0AypDQAIGVYmrWWQ2rbUuhycX1F6csdQ2bIwxEm1cGaNz7 uYrh5PG7aeR8o3e1v7Tc3NvfXTdttpYcO8dhrlK9BWmaCiPfQTSaIuBQSBnNUVEfVTJhdMiE R3UAsYNMipoYViBTJhNZpkVqPGrkST9VTIgY8aqLBJOGJOQFMmHV2Hp3rm7u2xb2rorEfiuN CgTmZjKpkfQ9v0zc2LKWvDeKDSSuEx2GtcWbtHf9LdROy3QsXJW1cwIb7Jrt478Vx3nzHqer dO2u+217a7hNe13SFLi9h4jtFa31zGNbivjfVv003O2vPb2u51NbJAS6IkcPEv1V5sV6ZtHk updK6j0675e8stbnJ80Pcwwo0xaoPKgrUeNMmFh6ZVNZqCaj/XVMKLUyYCwBxoFkle6pkTVQ SaCpxoJNBUjhRVhjQdT090vd9T6na223Y2j8Vy8PsIMz9VSpej6907o9mzbWxt0LsBy1O3aY q4crXZtehevb1Zs9K3VxTkRZePeRUth1Zd3+kXrEAvZ6Nuhx0+XhUzF6q2X6XepDt2ubjY3d q6TNu8pRjHIEVMtdXO3PQL21uG3dtlGGBBFUZW2JRcqKSdtGVFwVf2y3LT23HhcFSOwiKSjh 7TpXUbW8tNubivttoreSRmdQj5BRbTN7+Q6ps7Nhna3+a8e3cCGDJj763lkPQru6W3uNnumN y7s7mgXjjqUiVONWd8JtGL1jvns7KzYXxNcfWy/s2xJPy1duxr3eu2vrzrPQvyJ2d0Mm4vW7 TWbksmlhJjEEHuqf+OWePV9M9L/rZ0Pd71unbu8NnvbbaIvEC25/YuTHsMUvRMXu+rbDru2v gBXBAyM51nDU2dS3uAw8JqKel4caBoudtAxWmopqmiwVBKIvTQCUBzFBzOr+nOldVsGzvtsl 9IMalBInkcx7KuTD5P6t/RQ2wdx0j/qLayTtrp8YH7Dj5jS6y9lm32+V9S9Nqjvt7y3NvdWZ tv8AEp7jjWLmN4lc/aenRZ3AuXHN2zjKqxtODwIwIpyZurtnb2jZ8t3uXkOdq/ca4MO8x8lW 7/S664c5vTnSjfW9bVrVxSGGkgrIPJpFZyuHVZ0yW3bHMoipP90VbtlJrgtnM5YRWWii0mY7 6ogGPsoBxMgEjgTxohZUnId+NB0yccIiubQWuEEA5xyyoIbngxgjgeFABugYYUFyuoCceXM0 UBAPhBJJzogtBVp1ArGXEH30VYV2+yOePGoKa2zAAgwMxNAF/btpW6FxtsGCnMxw91dPFcVj yTo6OwtKy3GXFYDL3GvpePs+d5OlVcEGt1mBCE1lReSOIplRflpwgzRBLsb0YpKHMVLZVjzP WPS3Tdxvwd5ttZddKXNTKYBkDAia8Xm1s6x7PDtL0Yrn6fenXU6bd5Gz8Nwn55rhzrvxjM36 ZdJceDdX7Z4TpP0A1fZThCH/AEtt5p1Ejj4rYPzMKeypwZrn6X7wDwb+yf3kYT7iavt/Q4MV 39OOtqNVu5YuLwhiv/aFX2JwZLvoT1KuB2yt2rcT66s8kONZ39I+pFien3DP3SrfMac4nGkP 6c68k6thfkcPLJj3VecONZrnS+pW8bm1vL2m2w+iryiYrO1t1+NSD2gj56sqAw540VRUHKgg U8aASpk8hQUBRHq/QO22j7y7dvIHvov4AOQPE98VrWZTavpm22yFAYntrvNXnuxp2wGMVeLO VG1baNa64yPEe2tTVOT0HS+p7c2Py+5uwVwRn5dpreGQdZ2IvKm5tw5XwuVgyvA+yuN16us2 6OFuumWdzaa1fti5bYQysJBqXQm2HhfUH6csmrcdKnmdsxw/sk/TXLbSx118mXhr23u2LrWr yNbuIYZGEEGsOgIAoqRhlQQjgaCooKM5URX9DQAUzg+yqoD2iDQQzQVQQZUBDPlRH6b/AEZ/ Sfo229K7Xq/V0e/v+qKu5NiSiW7J/hK0eIkr4jjxrnLUsfaOj7XpvTrYt7La2tsnK2gU+05m mCO9Z3IYCTUaa7d1Rwntqh12ztd3b8u+gYcOBHcaK8f6n/T3a722zC35y4kMoi4vsGdGbHyn rvoPd7WWtJ51rmueFXKPLX+hXkklCI51i7Ok1cncbVkOIrUpYxXUia1Ky5fU+lpu9utq23kP aYPZdR8JHdWkYtpt7nSts9zcudxf3N5fMZebHSDjSdM2perk+p79n+Y3UuTC7RrVuBIFy5jj 7K1bjBrG7ft5l3oK/fuq/wDdtzU/8WfmsVja9L3lvrT3rgTfJuHaw+qCEURiJxE1uzO3Vc4j 3/o/1v1rZ9O2lxbxAe2pay2K5R7J7Kzr2Y2nV9E9J/rr0Debptlvrw2W6Rzai8QEcgxKXPh9 jRSzrgxY+q7LrW23CA27gbCY7DUwcnSsbnUc++pWpWy3cwqKelyop64iiioi6CxQiRRQtbBo jz3qb0R0Tr9nTvbEXlB8rcp4biE8jx7jVydnxn1b+mnXuieZetqd7sBj+YtiWVf/AIiDLvGF Zun03N3jSuMhhHCsNh1sJKjUBwihUJcifk+miKJZjEQe+hVhWgTwzmgLSGWftDmKqKggTII4 zTAirOBwnI0D9WkgEauGE4msNIFdmyhuWZ9lEQ2SMBIknw5++oqltjiIPEHsoLFsgah8vKgL QQNQw7BQEoMgsIMRPDuqKcGtgYmTkY51UEmgGQJoo1C3AbcKC4hXOAXEeI90VZUsynRz5e6u WH8IMrB4NOXvr6Hg2eDzauxZ9P73e7pbO2tF3fJRXXbbo5a6kbhPTe03x2G59RdMTfrg+3G5 Vyp5MyakU97Vzm2ezrfFW/cel97ZFu55eu1dGq1etkPbcc1dZVvYavJm62OrZ9NbHpfSNz1/ 1BdOz6NsVD7i9Gp2JwW3bTNnY4AVjfy4jpp4svknVf8A3A+o7u8a10DpHT+mdIViqLuLI3e5 ZZgNduXPCG7FWBXLn1d+Ew6aep951my216lt7K7/AE+dtN1tl8tSyjUVZJIxAwIq7WbRzkxc xr1C6isPDIkAZ14nsDow1RJ+7hQDLqZJ7gaBfmrIkGeETwzxqKGHjHL3Yc6AICgkjAYicpoI LjSSYgYjh8s1UGLpP73HHhQVIGJJ7cchnRajpZYDWgJ4yAcPbRAHpvTLsg7WywjElFJ9piqY Kb076fvY/krBUYSLajH3VM0xGS56M9OuIu7FFP7Er8xq8qmIy3P0/wDTLAkWbiYZi62Hvmrz pwjwPqH05uujbvy7n4m3fGxfGTDkeTCuuu2XOzDoehyn5zcW1w3IUXbDfuYOp7CGrcuGbMvp nTd0pAwiM1OY/qr0a7PNtq7n5Zbi61MqcjXdwIbaweQrNaWu1QntqZawNUdAVUkA5iYogfJo J5B76Ulee9U+iNr1iwbluLW8QSlwDPsbmK47+P6ddPJh8h3+w3Wy3Vza7pDbvWzDL9XZXB6J cs5XGiqINBVBCMKCgBnQTTQCbYNAsoR20EgHGgrTVBWiq3Fa4JQEFweQOIqUfuTpu729zZ7d 7AC7drSGyq4AIVBUAcornOzNdO1fjjhWkb9vupGdFdCxu+BNFy32b8xGJOQqK6llXCjVnyFG pHhfU3q30wPVVroSOlzfJauPviglUbwaEcjDXBJIzFXeYn7mC+tdD9M7zp3mq6eaVwVRBnlI rzYrtmPj/qv0+u0LXbPisDM8R31vVi14i+ACa7RzrIwrcZAVBEGqyyX+mbe4m68AZ90PFqxG oLCkTlVx1yOeNrdTd9GtXR4tvbcvxGpUC51n4k/Vb8uC/Qttes2d67sjX96yXnGPgZyBA5yK u170j2Viylm0lpBpS0oVFzwWtyMV5vo/TOl9T2N5rjAbo37rF0I1gM2GpTmO+pZ1rVtj1e1/ UDqfozYbLbbZ23Nz4Ldt9RQhTLHMkZ4RSTEZ45r676A/Wvo/XbUXtW03CELcS5iuo8nHDvis 90ssfVNl1axfQOjhgwnCphZXV29wXCINRpuUwKjUEGoYXqFEXNBYNAVFXpJoYC20DggjPMGm TD5161/SHpO+S5vunOnT96cdJITb3GOQYZKTzFa6bEuHxXq/Suo9I6jd2PUds233Fv4kYZjg ykYMp4EVz21sdJcsGpdeGBOJJrIvUAoIAkSPb89URXjLPjQWzyM8eeVECrjEAYcJmgqRJnCq jf5iCAw1cRzwrm0IPbOJUgjACaCzMgZA4j/TQUFEAE+I4r/XUVBpOoacefLtoLCnEmFGZoRc LoLKSeYHKlIpljM4/ZwoBR9KkGI4k5UUreXWTYXroMFbTkY5kKYqXsOT6V6xc3fRdr1AtN22 RY3OOOtMm/tCK9ucbfu820zHc/UPqvqHd+mh0roPnBd3Za/1VtuCXewrBfK1DEITi3PAVPNv /ox4tcPlfpb0s+63/ShtL1o7je7sbQ7RSWvqDGq4yDHSAT7qa65rta/RvpPb9Z/Tfqd3ZdQv 2996e3F1Ld7agsQGZSTeRGH4bKPi51dPJN5x2/yv+Phm9Gn9T+p9K9Zb/pXp7pm809FtMbu7 YDAvByHEhcBXO6/Zb9PkO+/Te90vfb3Y7LeWbux3cLuVaybt1UDBpsXIgE5asORqa7fbT6H1 jqHSbR2zbfaIqdP2S2WODXNNtAltNfEliB7allttTLySIwtBRJZVEmPkrhXohqIYkZHnnRQi 4QIJHs50QDhyIjEjFuIoKeYMwRhjzoALQSAdRz7AJoAKKZ+8cZGHsoCt2wzGFAMHGijS3CwV kKcMJNVDlQFIIgZDDGaCvy4WG0wv9O2oBlQCJnTkJxwoqJcJEMfixj6TRCmaCNM8wTRWTqO1 23Udnd2u6Ae0/GIKkZMO0USvmwtbn0z6isvcBZbLhleIFy0cG+Q16dNsuNmH0rbX9lvrl+/0 y4b6WLlxbkfEoBwaM9LDHurUuGLq7HR+qqraLuCH4h9Ir06bvNto7l7bLcQPbMgiQRyrq5sX kNqwBqWLK1LsdxpDFCVOfCsZjWCztL2qDhVyjf0/oW53FxURCzMcKl2Wam+o+regvSV/+W9X 3/5nrZWbnStkovXrMiQbpLW0Q/slp7K55vfs7evEeP3W59J9eL39ihXcWxNzbby0gd7fFkgu pK99cfLrNpmd2/HbrcfDl3/T/QGUz0+weBOgA/JFeTL1cWdvR/pq5A/IKGPIsvzGryqcYTc9 BemTIO2dSIkrcbP2k1eVOMZ3/Tv06SQp3Cn7MPPzg1edOMZbn6Z9OPwbu9bB+EsFPvypPJU4 Et+mCxK9QIzwa0Poar7DgS/6W7z/AC9/bP7yMsfKaew4Mt39MOuKmpL+3uTl4mH+zV9kThXO 3X6fep7OK7dbg/YdTPvIq84nGvP7nbbja7i5t9wht3rZ03EMSDyreWS4k48aD9Z/p11c730Z 0Xc6pY7S2j/vWh5Z/wCzWIzXr7W6k4GDWkbtvu4MHA/PTA6VjcA8air61629Nej+mJ1Tr24a 2dwWTYbWyjXr99kEuLVtRjE5mAOdXXXP7NR8R/UH/wB2fWrtq9030x0u50UmVbf74A7oA/ct RotntJatzjP/AJf+i9XzXoHW9/0npWz9S3fMexc3d1nuOQzXRqAvHVmTLTjXOy722l2x0fU9 j602fUrI3Owvl7TCZBy74yqazBtctb7peoWHtNegupHiyxrV1jE2seG6p03dbS6wur4Z8NwY qe41MYaly5jqasKWRWss1XCqiiKo5+86UG6cdttQFNthdthjhqVtcT21MGWu80WHc4EIx+St as1wPTXQtpatbXqSlhuHtuLgmVbUTB7IqTrctbX4at0PM9U7BYkWbF253E4Crv2n7szsmxnb +o+q3bfgtjbI9xRkXiZirf8AlD4O9JevfXnpnYWN/tr53HSGaX2t061UaoMT4lnhBisW3q1Z L+79Gejf1d6LvLVtt7cG0DIHF24w8rScZ18PbUxnsxnD6ltN5Z3Ni3fsuty1cUNbuIQyspxB BGBFZbfP/wBevXPW/SPom1ueiv5G+3+6XaLu4DGyhRnZkBkazpgE5V6fxtNbbduuIz5NrJ0f B/QP6o/rH1D1RsekdL65e3m56heFtbW+jc2ROLuwcFgqqCx0kVPNiTOGNdrX2nr3/uL9J9A9 VbnoO82+43VjZlbV/qu10OhvgfiqLRIMK2GDHGpfx7JM3rfhv2TL3/pX1r6Z9VbR930DfJvr Voqt4KGR7bOJVXVwpBNcbMXFbly9DaEmOIqK8V+pnqX9Q9htvyHoj09e3+/ur4+quLfkWP3L bsPMfv8ACO2u3injnXe5/T/ulz8Or+mW89Xbr0fsv/Nu0u7Xr9rXa3nnaNV0q3gujyyVhlI9 tcLetajq9e616W2G2uWevdQ2W1sXlK3LW8u20DqRBBVyJrp49N711lTaz5fHfXFr0TvfTOyT 07uU6h06zu7u3TqovteTZO4DLtyxki20iAcBnXTaXG3Lv06f9XPXbjjHZ8ruWGtXGt3AUuIS rocwRgQe6vLZivRKAKIwJzoLKnT4TkcYxoBJMy2PbQVHZkMqIpTiQYjM86DcGWc8QM8s6wq0 fLUJBnvNAxHJISAVjGgJWIjV4uZB+ugsMQAW8OBkA0VZJViQCQ3PEQKgpnYMcIXD+goKa4uo g55xz99ACspH7PZwNFU7h5tADSRpaeR+sVKPm2x6g/p3rW96buNX5K45Vv2SDNu4PZnXp0vL VyvSvsP6c+t9ls7W52N+zZ3F3dWxbtG5Gm7bJk2tXInEdtas5Ri9DWsbbb9eHVumdKOx3pkv c21hlcifvRGP2jFTWY7M8nmvXnr5LIvWru6/M9QuNpukP5lu0BmqspIdyfiIwHOp26RrFvd4 Pp3rzc7LdC9ZuMrDmsgjtGNWXC2R9C6H6pvdY2P5qxs0ZFJV2XepZAPajo7CtYjNjm7r1UNz 6j2/R2NhNvoLG3tHd1/MCdPm3GxuPpmOC8BXLfNjppJl2UZlUgnViYJ4CvO7IGYHIMBgeNUW zgEQILHPlQRyRKgQZ95NAli5aAQpnvFADK2MDhn20FaIUZyMSe3tzoD0qBAwJnv+WgsNJMk4 c6sDBcVQCchOHGgvz10MA2B9sUCmuqZIUEHI8agVMHwj20VLgbEgEnLHP6KDw/qD1n1DZdSv 7LaW0TyDpNy4CzExwEwBXXTSYc9tnl+r9c33Vbtu9vGVmtLoXSNIiZy5mukkjN2yb0T1BvOl 7tNzYeHACXFPw3E+44+arO7L6lsOo7Pr2z/P9L/i2sd3txhctsSYIAwiBGA4VrOGLPt3PT/W ocbe8cJ48K7675cN9MPV9T696d9LdDveourWTuUtkW9nsUwbcbhgSlvV9lfDLtwHbTfZfFrm vkW7/V/9Tetb5t0N6emdNuuLdrZ9OtrZ29kt8CaoLMTzdiTXG+T6j0WPo/6bepn6tdHS/VMM GOnb9aVQtxbhMBL4EK6/tASKs8mf3Yvjj6Z6tO49D+i9/vthaS71p18jpNwwVF25gLg/dHir PLrm9mprh+RumdI3m86tudv1C3vT1+62vbKtprj3dyzgk3WJBCkEsXxrF3l62t4fRm6Rb6F1 RLdhhu7rOEVinMxAEnMms65SnbpLSO6LkrlfYDXG93eASdIkkEGJ+XjUUeggEEzxWiDVUM6+ OOE0Foiu4KqQQYP+mimPZ8ShZjImfooKO3bR98H3UFlXWFOJPAiI7KBWYGROWNB4H9QPSjXH fq+0SXA/6u2JkgYeYPprppt8MbavnkMuddWH3H9DevavT9/pzvL7O+WRSf8ALujVh2ag1ZYr 6zt94Hgg+LkKqOD6p/V70l6ZDbfdX23nUUGGy2kO6nlcYnQntM9lbmn2Yec9Hf8AuS6du+pt tvUW0Xpe0uuBtt3ZLXUtqcIv4au3Uo9lZsnwvF4P9fv1A2vq316x6Puzueh9Ls29p0t0LBGg Brt1AY+O4c+MCt7dJNWo4HS9l663Fjztt1BmVfhs3dwbns0vrX2GuV2i93qvV931Bvf0f6b1 Dq9xhudt1G7087fy7aKttLaskaFESV7jNb8d6WMWdXzHpnWepdLvC9s7z2TxAJ0nvFRp9J9L fqXsb5FnqTHbbiPA4Eozcpnw1EsfQdn1Db721Cab6ES1swWjs4NVyxhh33pvb7hDe6e4DcbL ZdwPD21eKzf7eb3O1vbe4bd5DbccCKjTORViBIqoi8e6qKe0roUYSrAhh2ERVZL221t7bb27 FqRbtiFnHDvpJgtczd3be09Q2b+4ISxdsG0lw5Bg0wam3ws6xnS8j3ev7m2wZPLCKwxBhCKs /wCS2dI5v836jt+jr0u5tBF+2BtrgmSjmZgTJrGu2OrV1mcul1Oxux07ovRlc2W3HgvicMAJ DRnE1dbZozO9r0Ho31L6o9BepdhZ23VL93om8Y2228sbIZvCs2zqUMGIypZjr8M7XM6d31n1 b+sHoTq2yf0p612V25tN5aFxt7tFDNt7kkW7gUnUrjEgrPKMa9HDh/Vre/w56756Vl/Tb0T0 foW0696i9D9X23qrrj7X8v6dtMV296wbv8Rr1u4yw+UcwI41jEu8u3/GNTpLju+E9Y6F6p6Z 1UdO6z0zdbff3roRbe4tsrXLtxsNLHwuWY8DXTyeTNu1OPw+r/qWbvoP0J0L9Punv5PUt0P5 l6kv2TDPekFLWtcfC3yKtZ8HTS73vt0n6T/HT/Vb3kdv/wBvn6i9b65uOq+ius9V3Ny5vdnc bo++uXWN+w6KVdUuHxYKwdcfs1wt47S46NS5fO/VPrn9ROmD+U9Q671Gx1rpt69t9+F3V4Fi hAVpDYzwrvtLrtcdvgt6fq736KfrJ1TYeqx031X1Xc7/AKD1pPyl9t3euXvIuPhbuBmJKgk6 WjgZ4Vy8lvTb6TSvKfq56G33ov1huumbl33G2ufj9N3tyWa7t3JiWObofC3bjxr1+TyXeTaX pf8AasXXFwv9LfWWz6P1Pc9K63dZfTHXbf5XqmkavJb/ACN2ox8Vl8/2Sa81t1vKfH+8Wdej 2vXOmb7a7jcbXqJB6r05ls7wiGW9YYD8vukb7SuhAPs7a476yXE7d5+3/s6+Pb4rlhbOnFhP EnATXN0qabQkhwRzFUMs7Fm2N/eW4K7ZrauMBGuYbnmKSZMsVw63ktiZkcKgDUAIA8XaMKDp C0pUYYz4v66yqC26jIEcBxqCzaMjxZcDzjsoJEGNWQxootRHizOAHccKC2AAhmJOedQUHTA8 +3jVDHPHSY5H6DUAC4PhjTxkY8aiqhzlCqZnlNUeI/UToh8qz1S3iRFrcYZD7DfRW/HcXDG8 +Xidvvt1tj+FcIX7p+H3V3c3r7Xr/o67FLV7pu4v3wIZH3TmwSOOifoq2/qmHjeo767vt7d3 VxVQ3Wny0EKoyCqOQrMmGiMYoDViuUgcY40yNfTGvLvtu23Ba95qG0FzLahApFfbVUyHIzGM HP3V5XaUROnkO/jQDg2AM+2ghIVM8eEiTQRYYCBGMhjE0AsQcVxnLhjVFG4ywQZjAxRChcUE 6QcOOZ+Wihe5IBDRBxoKtscscThI/pwoLRZ+IaRwHYe6gJtcaMSeIyyMTjQV5JnCJnAjKgEp cGZxnBY+aiV88/UDpb2OqLvFH4W6USwM/iIIIPsiuvj2+GNo8pFdGFRjNEeo/T3ro6V1o23b Ta3gFsuTADqZSfmqw2mX0PrW+Vd5Y3SKE1rpu6cJcHM94NJcMyPVbPo3S/WPpzyN44/6C5rK k46LiwxUcxprPltXSYc30l+n/Q+k9Tu7ncdU3O76NtLo3O36Zct+Vbu7i3/Be5LePy5kQKzN rZhq4HfuLuOpbjeQu36dsh5t5xCqsnwqIjxO2Va11wzblZ/U9uobnZbbf3he2GzaLdm4ZWIj Gt7dZg6u+vVOp3bDPsje3QvAqGsqGTSQABKAnLnXL1/a3d5vdIm1vG/fuK/URIsbVGDNaaML l4qToj7K/ETiYFb2/pnU11tc8E2wCOOXHsryvSNHuGAYkjODHfRBm5pyg9sT2UUVtpE/FwPO gZaceZgIM4UDUdBJOLcuPfQMDWiSWWCcSZPdlRIguKTpkBeIjiKoRcQEFZHYRlUUoqzg6IOM EHlQfPvVPol9tuG6j0+wL9gMW3GzAPh5lOY7OFddN/ty20+mHpO+vW7ybnpk2b9vPy8CDyI+ iu/Rx7Oz6i9W+tepbAbSw7bRdMbj8urI9zgZbNR2LSWTsT9Xzt9luvONrQxvSZQAliaxb9uk drdegut2+m2t7bUXbhUve2yGXQfThmKxN43xcnpNgG695hIsge8mK1WXsNslzY29tvlBtG4A SuALW5xYqDwzBrMK9J6us9S3fph9ht7vl7XdXbO5vW2EqzWtQRhxX4jlV1245/VL1fKt7srl i5ctXBDJga1Ey57nS3y0V2/T/qnrHTbiiw5u2VP8Fj/2TwoV9Y9NfqB0nq0WdyzbbqCiCxgP h95cmHbSXDF1em3Qs3rKrvUW/t2+DcW8R781NbllY6xwuoem7ig3ti3n2s9H2wPpqcWpu4To VJBEEZg0VSjBjyH00EVhVLFyKrNhO82G03tnytwmtQZU5EHmDROzn7jo9vZ9C3e32SNcu3Fx 4sxn6BU1mGuWaXurX5Z+h3iINtlsNPDWkfOKz/4k+R76bnqjpluf4Nu5cI9hFa37T9zXtXor dwT3cDzrTDh9Ks9O6v6z6sd+i37Vu2tm3bZoMiASsEHDSa1tf6p+ybTGvR6HY/p1s7XWNrv+ m7+7Z21u4r39sWIuaQZKpdQg49tdeOezhd78vr2x9UdW26ogujcWUYOtjcqLyKwMgrqkqRwg 1vbxa1nXy2OV6r9H+kPWu7O/3l3d9H6w8k7m235raktnqsuQyj9xq57abY+3fXzS93hG/Sb9 RPSHXNj6k6Alv1BZ6deXcrf6Wxe4AhlluWGi6NaSDANcN9czDrLns2f+5noFh+o9J9cdP/8A tvqHbqt2VKldxaUEB5yZrfA8VNdfHeXj/XX/ANDbu+IoyzGc4QKjD9EdFLfrH+lTdA3T/wD8 49JL52wu3IDbnbxpCmMfEoCN+0FPGs+Hbhtdb/x2/wAf4/Ru/wBU/V8Xuel9zt20338q59x1 IPuMVraWXFYj7j+mXQuseqei9P2PUdvfTqHRALSdSuW7gtbrpFxtL7VrpEG5Z1arePw4cK4X p0/zn7/+7U6vC3DYNx9B1orMqvzCsRPyU82nHe6/TvptmZJE45nhPtrkq4ZZDYRnOfdRVawR hlwIog2dDicMIx4mg6bFoEf1VhVJdLZeHOZz5UUIusZDEdmXyUQDuJJBkjM0VRfEScONAckk 6pIyCiMuJoKAlTAI+7zHDhUBhFNsayNX2ufyVQSkKDhgMGwiJxqKGJY4Quc86BW4tW79trV5 Q9l1KsjZEciKYHzrr3obe7S6z7AHdbbMKMbi9hHH2V118n253XDzb7W/buG1ctslwf5ZBDe6 tys4eg6J6F6p1BFv3v8ApNu3ws4Jc48Ew95rO2+GtdXobf6X7ArH5u9rHxQE+aseytcGfcfp iBcAs78eXEstxPEP7pg09icHe9P+lem9FU3EA3O8nw33XSVBHwouMd9TbfLWuuHcLEEhlYFc AY+isNAZmjgTOI5eyqALPENgRhqHLOaIsO4MiTIz+qiha4wkmI+egjXbeiCJPzTRE3O2ujb2 N4ha3YvE+Wwe2zSsgq6jxDLioooPEDBxJxJyoKCEroGBGInGaGRrOWGGWFAaMNJlcBlnQGhw IIA4EjEzxFAIdFZgExzjhyyoCEFfCCOMGgw9Z6JZ6psH2t/wz4rTASVeMCKS4SzL5J1Lp246 fvLm03C6Ltox2EcCOw16NblxvRl0zHzVoCYERnUHoum+rb9vaHZ7/VuLQjynnxqR2nMRSwel 9Metb2w3U7ZvNtXRpe0Tp1DlT90sfQ7u+3e6UXr3St7OkE+ZespbAA/3jAkCP2a1MMV8z6x+ odzfdTTbPYtp0KxcK/lLRYqx+FrxYmXf9pvZAwqbXPSOmskd49A6Hvtut7bKUFwBrd60YEH9 nKvNmx14yuj03p2x2e30XNuL7Lgb/m3UDD9pFMV0nlYvjalt2ltkWrFuymYFsALiK57bZ6um uuEkCHOMxxx91ZaLZyB8JUHNvbVF6oYaTifiJ7aILU45GeHYKiiQ3DnkeGUVUMCEEY+L6KAc JbUcBwFBSMwYRJ76BmtiSDnzOVBQvFp0wOZYUHV6X0az1DZ3d5f6t0/YC3qAtbq4y3W0iZCB Tg32SJ7qSWmXlb3Q+ibjd/mjtCt8mWe0zWwxU5kKQPkq8rPlLrH0Hp289P8AVLFnZ7nbpbvr pVVusfLf/iHFT30jF1fTeoegfS256Wdptum7baKyDRf29tFdTz8wCW7znVwZfm/9ZfR3rf0n dt7u0A/RDgdzatqwVyTHmSGIkeytaYW1826ZeTfWNwx29u1eseU142hpDpqKyUyBE8K1e7L1 HqDpDbfrj2NlcO56daXQ25UyjqbYKkKMRhHCm2uMfqkuXY6d1W9vfTuzVgDe2ttkVsidGU+6 mCPnXqbq1zqHUBduIquqabmlQsMMxAAyyrUSvObj4hFKsJxGWdRVrduI4uKxDjJgSCO41R7P 0z+pvU+mutndFr+3wDOcWj9pcmqM2Pp/SPUnTOqW1v7K8tm432J/DJ+dTW5s57aN282uy3p0 bu35O4+zeWJPtyYVvErGbHB6j0TebNbjhfN2+A81cY7xwrN1w3NpXMFRpdUEpolg1NVkrebK xvLS27wPgdbiMpghlMg0vYnRyuuWN0b+36r0xRfv7csl1FIOpOIwOMcqm3ZrX6q+gdc6j1Ld XVu7UWtvbGL4yr4eEznPyVOXXBdZI43S+gHqt3d71Nw23vJuW8txkcZOUEVd+u1XOI+l7Lf3 LREEkCMeNdNdrHDbSV6ro/VLd+9aS7MMwDRgYJxrpt5Ma2uU06yM+w/UK5vfUq9Ft9DW/YW0 967f2bOt20igkFtXmI+Gcx31y/8AsmLNs2/F/wCmP/dJ5NbLbr27YdVvXvTR0bf9a9LXn6jc 6YT+bsGdrdtAGC5mfMRcJ8sn2V28Pkm2/DyTjf8AWX/P/u1tMTlpc9M/VcTqv6reterb7pPS +i9T2/U9z1C2jbvpfVNhtlsbbdGZti7uMWgfbY+3GvXt+LrNLbMf525n+TGv5Vu0k65/2ebH 6w9dS8y7r076cvXbZKtr6ZZzBg+JCK8Hk8fC42mP83r03m0zHS6P+uHUem79eobP0t0Dbb5Q yrudttrli5pb4llLmIPI1zvG/f8Aq1jDF1j9bPVlzcXNx0/pnR+k377G5d3m22KPuC7GSfMv m7n2Cuk31+s/vUxXmOqfqJ+oXVAR1D1J1C/bJk2xfe3b7tFsovyVZ5b8ST/JLq0dG3q3Pw2P xYp38R7a4+WW9V8W2OjpEmWxwn2Vwd1wzSF1EH6KAPFnhGZb5KAQxzjPnlQdlbblS2ER4jlA 5xWFAAwIEYcvppgyjWxrxA99DIgFHwEkdtFLGknxNI4GMaRKLVAmSGOeOdUR2XQVBEkZd/Co oCYOAyzM8qADcJdTmcTPAdlARZgpIlrh4HD5aiigmMTIxIz75ogghJ8TCIk5H/RQRjbVscTG YAmOU0Udu6SMRJ48aYFi4wnMMvsHvoLW9iZgg5cT3UF+a0YYAcIE0pAFrh1SJGQAymghVz4n XxGM8x20FAMzYgrGJIPKqIUJmSQIxH+igpbLM5iROIJioAdNABZvHOYM1Qlmlm0EFhgx41Fw tC0gzIyoGqzCfFMGAwNBMTM4nIzxPsoLRSsFRgwwPz0Mi0wSAMDIiY4UgO2bYw1RkJ7qoa24 VMjFvtz+SiLN+2B8RMnAf0FB571L0Lb9YsQALe8t/wAG8e3HS0cDV1uKlmXy/ebXcbTcPt9x b8u9bMMpw93ZXeXLkz8cqoILMmoglJGIwjI0VsvdX6pesDb3d7fewo0i0bjFI5RNa5VMMo0g 45VhXq/RPqG9td0nTrzE7S+0WwfsOco7DWd5lrSvoDxqjXMjHtFcXYu9dSyjOxJRcW0jE+zj RDbd628aUzEgQQfbNCmECcpAwYETQRCNQEYnn2fVQM12yfASf2hlNBJABGogAZ8uNBCwAmZO ZjA0EDgzPxcKIseZqEP4Y+Ejj89FEGYzq9lBRaQWIAGPd7KCmbAA88DQD5hEE5R8lBPPUHBY jAe2iva+jv1F3vRjb2e+nd9NBxUmXtj9gnMdlWVm65fWbbdK63043tq9vebLcqVuWmAdSpEF WU/KDWnN+fP1B/Qs9B6pc6/6UsNe6Q4ZOqdFXU921bb4n2+bOi4NpzHCa3nKW4eD2+wu7Fru 5N9bm2NtktOPungfZS3JGUX/AMp0G65BOlSIAJxJkn3mmeqyPDbi5b/LEggs74QZwGZrSVzG lmnhQTRVFFDOVMC9EcKYGjZb3dbK6L21uG24zIyPeKYHv/Tn6lNpG16kBpP2j8H1rRm6voXS +r2b9qNowvJcIItkywgHLmK3NnG6r3fRemb+Wsf9LueI+yT2rw9lXBysee3/AEvd7K4Vv2yB 9m4MVPcaljc2yyVGhA0ZwIGQYzjCqjgWLu72XT9KW2sObiW3vvbIACgT4RIkk6Q/GpfmtYb7 XWbZu7oXAAtliAbWq40aynjUCQcJ7qvymHFPSuudLLbno+4/M7a54zZIBJBxnScD7Maze+W8 z5ei9OdW3HUNq9zcWDt71p/LdMcSADIBxGdWbMbTD6h6M6BsNz0x+r7q4fwr2hbQPh0qvi19 +rCK8X9x82+vi249+3+ddvxfHLt1ath6L2vTd11LqPpPfN0vqfULB295NyDdRVdIRVDeO2zE BsST2V8jw/3P8nw7S+TWeXWfXfp3v6ydsvRv+F49pjS8Hkum+kesemrG39NW91tNv17rAvKm 7v3Au2Ww1v8AHfWw+JgRbTUM54xX3fwfzNPzLzkvHW5sx1z8T/q+X5/xtvDt1s5Xpr9Y+f8A s8ctrc+o7969eG96r6pvbtTfYaHsPt1WGL3cw+oAA/DFfp9rw6XEknR8uf1dbm7Pp+2/SPoP VOqt1Hfbdel7J0ti30XY3XdUZUCsX3FzxElhPhFeDy+fOk17/rXs08cm3KdP0eW9Z/pH1joe vedL19T6UCSdKzuLKgT+Ii/EP2l9oFeK6fT2Tf7ea9M+mes+qeqWukdI2x3O6u5nJLajO5cf 7KjnXDa8XR9x6B/7Ueg2rSv6g6zud3fOL2dkFsWh2BnFxz34VOdXi7+7/wDbd+nq7JrXTzvN luo/C3Xnm7pbgWRxDD3VvXf7ZukfHPVHpHqnpvqrdO6gFZ41WrtufLuocNSz83Csb646zs66 3LjsmkQvwgSBwHZWFLIkSeHKgsYDGYIoOrq1W1YrDd849uVZihlpgmSvGONBYBCnAERnUEYu CMAuOJoIFFwaWBx+1RVAgAjCFBURxPbNVBFPMVQInMv2VKAcKE/Z46sP6qKWVBGD5YE8fkpS L4YCVzk/RQMRzmfATMLFMBgsvGEaSMcMYqBgtKROgscxiJn2TVFDbNENiOAHzUE8lTgxJgye UUDQtuQRxwBwnHHOiiI05AGSYMwDRMga2mAmDwjP20FEJpK4CeM40wKAUAzLEzJPzTRQhFka W0kjHKOVAyIUaiSQccJiO6gyva8UESMTJw7qgUbcScsMhQEtksYAJGeUAUDBtgGh/hWCTQXo tEAAYnLCMOFUUAFYTgQfh/0Cgs6dQwExgczQR0IgqxGcmedFyptIUErHGeJqBZOPhgjMnKgi i2ULfDjgR/XQcn1D6b2XV7E3D5W6t/BfgFuxWHEVZtjslmXzjqfR+odNu6N1bKg/DczRu413 m2XGzDErYdlaQVu3cd1S2hd2ICqokn2CplZHbsei/Ud5Aw2oQHhcdVb3E1j2ReNK3Hpfr+2A NzZOyk4FIuY/2Jq+yLxrqemPSu/vb1NzvbT7bbWSHUuNJdxiBjj31jbafC66/b3xW6CcIU5c prm6JBaFwggEHEigNZIFsCe0HGZ7aBkQhDsQDmOOeFA221tVAJKvnAqimKwW95+ugBmUsQuO GAJqCsGIjLI9/KgZmpHAY6coIogtZcac+ziYoGAiInGqKxJCzpP3uFAvNjJBHOooLjwMTIYY CgCcSwXhgc4qotWJB5xiBxoruemvVPV+hb0bjZ3B5bYXbB+Fv6c6SpZl9o9M+tOieoLShXFj fqPxNu5AbV+yY8XsrTFjz3q79HfSPqC49wWL3T93dYu262RKK7E4m5aIa2zHnE1eTL591b9L t56asBChvbYSF3THUz9/KsWN67PA9f8AQnS+opK2V2u5X4b1pQB3Ooias2wtmXzfrPprqPSb 2jdWxoJi3eTFG7j9FddbK52Ycs2sa0gCnGrAJU0FQaipHblQdTpHXupdMuK23uEoDPlkmPZy olj6V0T9RNn1BFt7uBuYwZjpcf2uNWXDG2r09rrVu7b8u8Bdst94TPfXSXLldWPc9E2m5m5s bgR8/Jc+H2Gl1Wb/AG4+42e62rab9spyJyPccqzhuWUANQRgHXSw1LIMHsMiqjn3djuLFvcP tXa490aVtSLZVZZiEcDOXkTU+ctZa9nbNna2bRENbRVYZ4gY1IlZ+qde2/T00qPN3TCUsj52 iu3j8ef2Y22w9Z+nPq7bbHq296Lu+r7fd2r160/T9wA6Lea8gD2VkaUgqoEn4u+sfl/i6+Tx 3Xaf07Tr+i+HzXXbMvV9bt7a1eCuF+EsbdzBWUtg5EnwvEgkYivw9/E/N/H8l011vk0n+lnx /wDh9uebxb6y28XE/Uf0z6Z6v6atXNx5Y6ja3Fu3t9yhJuiypLPaRsVgzLZ1+n/sXh8/h122 8v8Az36/9ny/7ht4/J0naOf6fHT+n7ZdptLCbe0PuDFjzY5se+vtc7bmvmzSTs9LtN1EQcK1 3WXDu9MvtdvotsarrEBAOZrlvMR01r2fp70x0bon5m7sNnZ22637C7v7tpApuuBgTHKfprx7 XNzXq1mHaBqNqZZolj51+snpE9Y9N3N5t0nf9Nm/bI+JrYH4ie7H2V1069PtPl+cgcp45mM6 4WOq10EagccqIGGiCACcO+g6xS2GxJg/e9+E1hQSgIIBwPDL3VUTzNNt1H8PDDLEcuNRVSNU DVBGfCqLDD4cRJnVwqC2tpHhwxkYfRQUoeBiVBlYIzoZQ7dnBkFkjAHHHuqmS/LXBSCqjEEZ ZHjUUaqpJOEDInKfdQWYmeZ8MiQJxohvnxxlfZieVFGbiYsFJ4kScJ5RQCLyuDMhlxM8caCj d0g6SccUOVFQKCjE4GPh40RNTFfEZI4kjCoKYwwg6ogyffxqqEydLaecf0FEUzmBI8I4jH2Y UUbbhbIBFrUMNSjxHHsoL89ro1DV5bDkVK9hFCq/FuI0Az3/ANPmqCW9vpeCQAcoiSxz7Koe ulTl4lwGYz40gl2xrWZLH7uRigzFbiCLgzyYzgOyKCyqNgRLTI/roLhdBIWgWxYqRAkjCeFF il+E6iC3EDnRFXChVhOOQExQAX8sEnIjBe6gWSRJ4nMAGoFXEW7bKPbVkIOpXErjznCg4299 F9E3RDW7Z2xOLm0Y/wBUyKvOpdY19G9M9O6Tda7tdTX2EeY5DHTnAgACl2t7muuHbtlXGkiT xkxj31GhBguDCAMiKYBBVIgEkTiCPkog9BU8TGJjH3UVYtDUMAVnEx9VBfkIfhOU+EUKPyU1 YjEZLx7yaADaGqF+Gfi7aCabYiMScJFELvYEgLJJx7aKWC2okCBkI+rhVEFy5IgQRIPKpEX+ YfSVMD2R7ZqilvFWHEk4DnzqKN7yBcTicAJ91VC/PUCCIPAnCirNzWAxAnnjgPZRMrDGJERk AcT/AKKAQ4V4wk5dtDItcMQ3xE4jLKgZZ3V21cDhipnUGU4jljRX0j0d+rL23TZ9ah7SgJb3 YwZY++Z4xnWpWLr9Ppn5rpfVtqfLdd5trk6kGlkacDOE4cKuGcvmHrP9Pb9q7d3HSgWsIJNk 55T4cMc4qWEr5fv9qbi3dturQKHB7TjPhBmstvBdd9D37c7jpvjtkFm2pM3F/dP2q6Tf7Zur yL22VirAqwwIIgg10jBZWqiiuFFVHsoKGdAYYCCOGVRHa6V6r6nsCq6vOsD7DZx2GhY9r0n1 h0/dwNfk3vuPh7q1mxm6PSWOrNphouIc1OINa5Od1MG36Fuidds2HP2rZge7EUxEzYo+mLNy Ttt4I+7cX6VP0U4rNlJ6Q3txoG5sDlJb6qziryjUPQW5ayxO+ti5HhCqxE95+qkOTxXVfRvq Lpt/bvbKW2tXnu/zZQzOA4AhyoMhYwwnGu88k+WcZ7PPbDc3dqemJubadSs2r15n6NdDWype AxZxBh4BBBwiul26Xr8scX03ofrf1DZ2Fi1uru3u3rNtba3DZV30rlqd9RZubca4XeZ/p6R1 mt+Wrc+od/1C4j7u/wCZ5Y020gKig4kKqgKKcksatr1ECJNWbOV1d7YdWWAC09tdJszY+lfp 7txeN3qDCVT8Oyf2vtH2Vx82+ejr4dfl7224Irg9JymosHFQJ3NpbltkYSrAgg8Qa1Klfk31 p0P+SeqOodOQabVq6fJn/dONSe4GK15u+ftdezgNpDyTqGWH0VyaUGMREjIz9FEdi4jNBXHs OFYaBGhYbDmM/dwoA0lXOtcJnmT7qC0GknxRM58h20BgEYkY8SeANUU5iWLEkn31BQuCREt+ 9lQHbuMmLEzOUZVQwKGQKQSxOJOWOUVAtwIEmF+zh76KsSyAEFR9jjJ+egEGGJjTOfdQXIEY mRgytiDVFalDG4owiDjUEXcBTOnUCMT/AFUE1BoOkHiV5cooCHlqJUThJxkRQCHkSBPLsNAS mcBiOAGHfRTPJ0jAZ8eFMmE8nwkFdIGGOXvoE7iyGZdNw2yoghRMzljnhWdplZcD21vyBquM XdhBYmSeXdV1mDa5OBDC34ssiYnOrEoiPGWkEz4R20AMzGfsgYkA8sqAHgkl8DkTkP66BFxS HgEkYR20DgvhKhcMpnifmoL0gsCFkAZ/PQU1rmAwJxM4CoEXhpMFTBxUzOPdVC/MExgZEmgB n1MZwkZA86AbjlBoVcScCon3zUU22sEAA3F5RPbNAWhh4NOknxaSYbPLGhgRsvYc27ko7Q0R jjRIO2g0hOJOJIynhNFGHYXcwFGM8cKBnmNIUHESSOyqLW6VAhySxmOU0QQuEOC0gdvfhlQO YMtsXYkH4TNAk3AGCsMjPH56iqJLGSBIMHlHCqhbeWzPGYwxyJoFlQ2CrIGcGTQUzHSxIiOO RM8aAZcqRMkcMIigmg6Wk45UXIWTVA1CBgfoqIEqCMSASYEj6qoij4QJDcPZQW2knUDBwwyo L0rgcM8+VAJZQuQYk48PloDUavEscNPKgLQ0yTjjJj5KDqdE9Tda6JuRd2O6ZAI12TBRgDip B51ZcFkfU+h/qN0/rW3Fi/e/JbwwHVgGEAcCQAR31qVzsscn1p0XpfUOqttEsptupeSt22Bc Z9aO2hQ3hAHiwkthUuCZnV886r6e3+wv+XubDWLwnVbaD24HKs4bly8r130r07qam46eRu+G 4QQSeAZftfPWtdrCzL551foHUel3dG5t/hsYS8uKN3H6DXXXaVzssc02xHKtIEqKCtJ5USpF BRBzGdCrBOfy0V1um+pOq7Jgq3Dctj7D4/LnUwj1Ow9bbG6ANwDYftxX3iiYd/adYtOA1m6C DxBq8mbo6Nrq10R4prU3ZujfY9QXVwLEirmM8a2W+uBvtZ5g0MMG96T0Xfkv5QsX/wDe2gAf dlUsJtY4m59N9R25LbZhuLfCPC3uNZurpN4xi9uLTlLqtbcZqwg1GmyzvLgHxVcs4btv1R1I 8RFamzN1ff8A9O90LfpTp+PiuIbrntdifmrjnNta1mI9ntt2rccaNt9u6DRTlYGi5EyiKLY/ Pf6/dOSx6j2e7RPHvLBR37bTQPkauu3XT9qzr3fLHgLEYjlXBtACRqwE5YmcOYoOsQScRhz5 VkWF4ZGMxhl76iobbKSzNIz7KoA48MQJNQQhmOAw4mM6C2DEAwAIiDMj3UAMjAmGg4SMeVAf lafDkePH3RVhRLpkYlf3eNAY0Iq21A09mcHgKioqIGliIBkDlQiNbAVg+WeGeHLnQJNskHTJ nDDMURbeWig8Jx7fdRVIhJYiDmcvnoAKNpgmCeIwNAYUhVbH5x76B9u0wTETqwI76UW9vQsK /lqAJPARRRhZU4iSIk4YmgoqwUKSMACcONCgRSJZfEZ8XH+qgG4LrgLp0qMwJzAoAuW8ANI0 jEk9tBcBczOcCYE86ERrbspkEacOOPvqCX0Z1VpIOAYnEf3edUUwVDi2K4ZSSDjQo/OVUnTp WRPMcqChdw0jifiJ4UXKaoIA4SCQMPbjTCEsXuA6rmImZwmMBUWq0WmMsR2qO7lVQpySAZBA ngJqAbZZvDDaZiTGJ7xRTLTtrDISC0nA4Z4fNQb9t1bdbaHRhrWChe3buFYM461aqhV7cXNw 7XLlzXcPxTxnHIRFCFyYGSrlBPy0DGuXIUjSrRjA+qgo3FUKzKTiASudAfgIOBDNjyHbQCCd RYkknECchwooWu3F1KRCzmRhMcIqQQPcYDU4wyIxqobbdHnVMx3R7aCBwohYLzlx9poCBUjS eWAGEmrAsAKSpnsJM+6oKLaGAGB+igpiky2BnACgBhOI44tPPsoKPhOIBjjlQL1PqBwniMqC wSx4HtPGgowiEmJzHLuoBL3D+6YM5UGnYrtjvbf513s7Rj+LdtKLjAQYKqSAcalVfVF2Vnc6 djuTutuyzruIbTAzkVPHtrSM0qTqAw5jHEZxUMmbe6VfUmoEYSDGH00H0r0l+pm129m10/q9 uVkBt0CYg4jXGI+atd2OL6LueienusdJW8Tr2t1BctXSwbQpyKuJgc6rL5b6u9EWdihv7bcW b1nHTDgthlK91OKzZ4LdbS1dttavKty04hkYSpHcay28R130EV1X+lmeJ2znHP7DH5jW5v8A bO2rxt6xdtXGt3UKXFMMjCCK6xgozQCRRFEYc6FVNUXjUBCcuFFhlm/fstNm4yH9kkUR2dh6 o6hZZRdbWgzMeKpgey2O+ubrbi/tym4tnPQYdexlOVY5LxPHUAphw1s8mEfPWpszdWm1vwcV b5as2ZurZb6k4zNa5M8T/wA9YurpuotxeTAH56oSen9Kuz5btt3OUHUvuNZsM0luk7hMUuJe XhpMH3GjXJ9Q9GeoLVjomz2rsUvWU0MpwyYxWJEy9z0/ryNHimlald/bdXtkDxZ1Fy6VjqKN xmjWWn86mmZouX52/Wz1FY6v6oTbbZw9npieWzKcDcbxPlygCu2/TST5qR87DkxqHhk49ted tJwzkgzjhQdlWDkxBkGceXfWFQ2zBIYQcS1AxQIhvETwP0UwigiAyIgiDPyYUwoCxyBjgBwm qCIAQ6RqIz5f0FSkLAKHU55kNxqg1soYckkRh2++hFhFGGk4HLLOoCKKRIUyMAaYUI8JGA0g ZnjRFM5IGBZWwLZYfPRYjuyrzI9h99BYt6T94DxRhGXCqivLhpW3HEnKoo0tlWwPgzYHHPHG qGjTiTHIzl76gJFbUWIMRHL3UFuiMwhSQBLa4gd3ZQVqLQQ3h5RQBcIYeETAzoATVkWCg48s fZQUGAga9IjAZzRQhMVMA54HiOIoLY6TkdAmYjD3zQgLt2AxRfNfEkTE8zJoBcgiSYnLiMON ADF41Ajkwzg/RQUdU85zOGPsoFLcQgCNMk4Z4d9BZugGEEknhB99AMEuJwLSRP3RUFY6hpJ7 ceJ4VQ22toLjC6cdQwxjKaGUDW1jGCcsJOedAq1uTc3JVbbMlsYvHhE4VMq0NqLh9MBvCMBE VUGQsRpyGYxHtigiGBIyAjsoGIusgNKiMuc1BDaOgAgQ2Ok4ZUBaCRM4DAVRbEpMiZynlQCU DjInM/10FQMvtcIGHyUERIg6pHE8ceFBZtt9kxxPbhQQK1tcW1E54ce2gE32lQBiAYiIxoVQ CkhgAW4cSBxoBZABjjOJwOIoFm2VHw44RlFUVDkyBGnPkKgXJALMSSDAAAoKVgVk4ajGHZjQ FctqVEeJshAoDgKDrgkmDhwoBN1MAMYxIGA7KAC0iCRjnhl2UEtyVIJxAg8qC2LahJnHPsoD F8MdKHwnDPH5qDq7L1P6g6btn2e1311dky6BYkOig4EBSMj2Vub4ZxHJv9S3hJl3KDAIWIHL Cs8quCU3KlmBnCADPH21FMDAmRMAfazoMHVug9O6ohO4t/iAYXlEOO48fbWptYlkrw/WvR3U dhN20DudrGrzEHiUftL9IrpN8ud1efKTW2VeXgDNCqKnKqJB/rqC4w7aCCgsqwx+Sg19O6lu +n3xe2r6T9peDDkwqWSrLh9C6L1za9WsQiqt5R+LZbEjt7RXHbXDpLlvbp21InywDzEr81TN MRS9OYfBdYTkphqvKpxghtr4+Fg3CYirzZ4IyblM19xFam7PBPOurmCKvNOA0315DKuymryT g6uw9X9S2pEXSyjgaZOL020/UtlUayZ5UTFdBP1ca0vgtu54cKnRqSuT1r9WPUO/2z2dvcG0 RvCzqfHGUA8Ks2kamrwbXX1a5YuZ8UxM51i7W3NbwBCwOBgcJrIhMmDnMACg7iXIbTpIYDji IqZFG+NGIAB5c6RTFMrM8on+mFEQt4Sy4cDPfQKDS4ILMVxxEVFMW6wB0GAeOVXIWxOos2oi cCowEVAWOggHEnCcoHZVDUJCzqkxmYzoKHliDJxz7+NBcCQWgziFPbUUKuuAOET2TQCxxGoa oPOqIwXVIIJGPhMwcs6gtbrRHAyZicqC7d2/ph7emWIBBnDnQOLdpBGMTANADaYgFtQxw5dl BPMRV0qWMHI1QF9mKgkyeOGEVAILKNBaNWQyJiihMkC5EIeHdRMGLkkkScQezlRQm4yM2jI9 px9hoig66xqxOEDhjyoqFhq0qcVzbA40wZKuMv2h4ZCgAxQUQ1tQ8AoSdUYyRwk+ygWzkgNI kDAMIGPOgWuhUlAFTVBk4T2UXKiXDhkgsZbsJyM0RdkEyVkyINsDL30BqraBcYAE4QZAA7qC 2R4CQIY8sfbQU1ltc4BsxzkYUBrYBSGYTjMHGeUVAxgvlggEnnnlyoCQ3FwYzM6QZEHsqg7V wH4jh93OR9dTArzzqGEEcOMVYVYdmJYHxcKC9eliDgftGgI3S88BHDCgltlcsJ7TPAUEkNIA lxmKABMlSf3jQLdgtwlZ8RiP6qGRM7QCIJgiBAmgXbu3BhAMYTQMS5B+EBjgZPCeVBHuQJwi MIGI76oVcYSoIkkiScCQMagrXacxHizI4UAogg4QeM4YUEWCRBABMCaoNQ7DGInE8Z76Cmtq ZDYFfloFEfdUgcT/AKKgDAyQcDmTQTS2qCABlA40DAIYSfhGQ5DnQGLasJQwe3lzoKC6AOIy HAe+gWSY0XCVBIKiiKv2VIDgRqwB5RlRWUXdwmpLjAkkQyyABQaUZThrJxgGcPbVQ+2U0YEH s+qaiuV1P0r0jqBY3bflbg5XrXgPtHwtWptYzdZXjur+iOq7HVctL+asDJkB1x2p9VdJvGLo 88ylWKsCrZEMMR766MhioKHP3UF5meNBYB/0VRYXnRGja7m/tL6bjbuUupiGH9MqWZMvpHp7 rVnq201YJuUMXrIzn7wn7Jrz7TDtrXVC+KD7Sf6Z1ARmTIgRxzoIwkQDj97KgFnOnPVHHnVC yQWEmQeNEKYgKww1ZkUUIkAwPETn2UE1kxDHmKIAOoHhHE901REGoZwfpHaagM5ZGJ7KoEoc dWBHZxoOswKmSJAIGJEYjKsKov4fHKnH+k0FFgEhgYbI4mZoIWLKBbQrpiZiIoEDcPcQMjo1 qMAM+WFKGLICEwBwE5xQE10sunV4FPwE5E8qAyyhOURj9FUQ3PwwDqRoy0zA7TQCGMQxlRm3 blnUF60DQrSpiOFFQyzyYEfCOyiCUHSAcNRz7eEUFENPhEsTxkDCopuvUSAcRmoP01QpC6rh OOanMczjTIfquRqtkHnA8WNLVJDKVNxVIUYf1zzqCAowGocMWGZqoJrqIC0EA5kmSaDObgMs SSGH2uXfQWLowLQATCjE9mdFM16CWxBzDkHnyNIYLbch2OUkQDQU1wlAABLZjtmgHW4KgglZ ldOMcJoKBW4WJ8SmInhHHvoIFLSoXSGxJgYxw76A/wAupMlpJWTOGIPbQM0W7ixEggaScCDR FiwyRgc54E/VRVFY06VnHjAj3UELoZ8GGUESJ4TRBKiSACRAx40UQWNJ0guDIOUDlQA5B1QA hBnDl31AA1oB4jkYJiqJLO4zjM5cKA3sMELiCoyE0CwqkS0q3DHsyNAVspIhSAMifkoLLAkk GIGJyzoBUvjrIKgwk0A3rhUF3ZWAjEcKAxdckkuAYBCn7XZTJgAJcETDA/N3UFgM5OKiBC86 AlARlkktpz7OVBHtrGo42ychOf0UCDYdyygmcwMMIyPKgZfFwgaiAAPiHA+6KAHVCYxhZJHO gYltVI05/LQCdOOkQZOM5/VVDAurEDxHiYwqCBCDLtAAiB2cMKCnWTAkZfFQDpWShErx+qgr QG8KgmPsigt7DAjUskHjI+eiZLZyDlPsyoqB3DYfAcROA+SgpidPhhmB+EmJ9sVUWQIKkSx7 eNFLLhMGYsTgrHLL6qIqFgqyScCW5d9RSjZRpdcB91YAEcKCw4BAyXLv/pFBptOhBJcREBRE 0FubofAagMzMkURz+odD6b1BNW7sK7YgXBgwPDFcasv0YeV6j6B3CS2xveavC3c8Ld05V0nk Yurzu96Xvtk2nc2XtE5Fhge45GuksrGGXQfYKqKAP9VBaye6gMQRRG3pPUbvTt9a3NvEKYuJ 95TmKm0zGpcPq223djcbe1uLba7d1dS48xXndJTTb8EhTIwknnRS9GYYGDkR9IoL02mQgfGB 4pqjObUwSZC5AcaiFmSYGJz7qqqMTOPeKCjaJy/szkPdQAB4WOksQRiMhP11UQlkaOeZmgNG 8MASZyoLuajIk6ueeFB12CMTHfOMVkqIlsJJkzM8/wCugWxXxEY8NJI7KBTo5YjEKwEkcu8V FgEswAWEKMIBDEDvNBd62khxygLPtwoAtqxDtpZeADRHeONFCCysA3iBbIzMmgeSgY4kNIwP z50AeYWB1YA5NEYcoNRF29TSSIAyx+erlTFAkk6iQRJnDuohgS0MExIxAGYJzzpgGfLUYCYO Y+ntosC99UgEYjIyIoKDsGIkKSIw4DlQWhaTPiyxmgtiMAI0xPCKAXUnxKDJMwTEH6qCri23 K6hIzYUCLtvV4kYcwMsDzmoA8wkaBjcQRMY/1VQJfWVckrzBke8VFMS02ZltUiI0gRAoG+U4 EFsBJOHLhTIEreuAkuXiBbDEwFy0+zlQyLyo0tqlBmCOOZx+iqjRctXtvc8ncWmtXUAcowgw cRhnlUVSqJBCwOB5++rgXpAXAkg5g4USl+YdMAaT9VFUpM5YZycJxoBnUDnrzzgeygK3cCEs +MmRhONVDLl21cgBtI5jCDUGdnA8U+HKJxxoqvMUeKNJ4iJgfTQLZmgHgCMu/soZMN3ShOYI MHiOeAoA1FlDAyIwMcDQRbgAaCojwnh20ETMyfhw1HEmgsXX1HGbfAHOe+gotCklYGWGXtoD tWVaZGogS092PKgJrSAhs54cMqAgJPiWDx93CiIr2hc0MIbNBB+eirtv5ghlBM45iO7CgYQI 1GQM8Rw7aBTJpMfaYzp4YUEW3IKkcMCTn2RyoF+WYBOccOygIIDpEAGZ1eyiDAtkQoyyB41V EzhIBkk4QBAiKIE21YBhjGJighUALxHHu4Y1BA4W4Qh0twOVFDdv7k6mY5nwTiKuUwU9xmQj LkeM+6gVN8NJyGR7D2VA1TeKzgTzyoAMvK/cx4jKqBKlgBkSJBGNAALhdBxxwOPHOgPSdDYy DE6RnQJu2S0Rh4c8jQJD3LTgspFvi4yHsqK07fcq1skEyIiOdEaFZdOpcNRmeIOdARdyCJl/ s8u2qKe1au29F1FKMviVgCPccKmTDg7/ANE9K3Oq5atNt2IxNn4ZjMqZHDhW5vYzxjzm99Cd Vst/07ruB9lZ0t8uHy1ueRm6uFuum7/aMU3Nh7R7QY9+Vbm0ZsrOFIMZ8qtQY+eg+geg7t+5 0t7bibdm5Fo4nMSR764b929ez02qGIY6SOHfWWxF01EZ8VFBmZgTh4Z41RUBQcc4g8fkqBZK ggz4uI5GqAdSZCjUpwBwBzogWDKmmOPGTQQ6yZ0gHiOFAMEk6gJIgcaBgU+HEA4DDPlViCCg qVmfopkdJVtkEeEsMAOUcIrKl6LsiMQPiPGKCBRqJaPLIADSZntqCi/g0AyWyX5s6CriEAg4 sOHCO6igVWLSjaiBgtFOZAzYQQc+OFESCVliNSnBoqhbKNXhHiXj2GoKCNpGqHJwPD5KKtfE NEYrBJn5KgMlSAW8MGSsYcs8ImqF62III455wBzqAmuO6gqdMHI5VRSzEZGcMB89B0dj6c9R 9QNi5sunX9za3TFLFy2hZGKnSQWyHi51LVZ3tXdruL20v2zbv2XNu9aMEq6nFTEiR2UgFUWW g6RmFiO/KqgsGZ5JOHhOQP8AVRS2tArq4jDROfbUCzqBbwDmSY7oqoLSrCSNX7Ry7qCFUW4F IhoyJn2CitFnT5ZUIJ1albGR2DhBoBjXOWvLPCTQUbfgAAn5B20FlVUz4iCPYKIIvdN3W7k3 GEFpk6YiMeymSBdwGY8Zy5UVTlRcH2UPETjhnRAz4lUCNRiTRRkWwx1KQB8JWiEgg/EABjiM cKALjLq5DjxNFVrtDHJiIAnTjQCSrt97CYjPtnsqCG8pfMAg4pn2QaoGEybw5iCcJJoBZMCQ 2Xsy4UBuXgEkALlhyNAJYEBT4iThqwx+mgvy2icguI45UEtlsCvhIzGU91AQDE+PHScj9IoG wdMoZBwgUEGp5AGvSPdw91BYYrpYmIyGPyxQG7aQXbPCMcqC3KlfgjHM91BIZ1EyeWMUFi2F ICLLKIjOMKCwWhWKgQIJNALBiAS+AOQET3UQOsEgRqjOYM0VLajUcAOMiqhkhhI8QORGJ9tA HhxAGIxwjGgWdAElsDk2Z7sKEUzAA5ds8I76AVafEQFB7YnlQDcZSYU+HjM4A0EQpIEAgcf6 6Kmq5rgYj7Q7OdEC1xXcHHTl76CE8ZjhHGgFgXI1Yj7JBzHsoKBOsqTBiAaBj20ELqmRBGMz 7aBRtrAB54wMKBDWxbJKk5zieXKKgO3dGkDMjMTETVGy2VYlolRhI/pjQPCgLCkFuXYO+iKd XlQkrpx+SiggESSzHGI+eghtI6PbujXbjBDEY85qDmXvT3QNwx8zaLqyDICpP90itZsZshA9 J+nFb/u0RmWZz7xNXlftOMdPa7e3ZteTtlFuyPgVRAw5VloYQlZbGPtHCKC9LCMmj399BCke InMzjzqhYQRK4yciaCNbLCAC2MRx76gF7JUTmBxI41YgBbAETLHswmgIKpWeJGfI0CzbMnEM p+zQCQAIyXjxqiw5WVVpHM4SKI6mkCI7yMBPfWVCznBgwxIEiMZ76AjJUAA44T3d9Bmt+BRa WSZlSxJ7SSaijcXJkZKYZRjNAQUYKAvcJ95og0t6QBIgYACiq8ljMAkZgnGgMo4AwwOPycaC iii2SygznOMmgtQcAqgCOzjhQTRdCFMPEDMUC2I1FVkEjMjAfTRVHTEcMwwpgRERAFxZiYXt OfCg2bTqfUdlZeztN3uNsrMLjrauOgZxgDCkY1rlRiZlU61GOsl2IzJzxrMVYJEKxgmdRHDl RFhgIGMYzl8tRUUk4z4RhGU1UCrLOjEEfDJ4EcaC7Z0qJYalAMcD20DVgLJEscRxoCQGdX2p gjhjRVsBLQY7ufKgHiPFl2T8+NBWBYgk4glTMe2iLuO5wUye09kUAOSqsMPMBgkYweWFFhTO pAiZiAZ7aIIkESsxhxkE/RRQtqKxGWPbyoIA5OqIVZIcx7qIq4qwFK4kYscOVALIwKkqDEAE Yxyz40IXb0hySLg8BHhwIJ7TPtHEVFD5drT5k6V55Nge3hQNKo3iUk8pPPM1QozbSSThxOHZ woDGomI8AHxfVQHbBIJjGBqgGgYq6l1NCoRhGcigoWjBc9x491A63ZgMSARGeZoLW1MiMuYH yUFsigDAxyXMUCgVLQPs5zl/XQEiMSXmJJJJ+gUKO4AFBGYz7BRFhwUE+JpggY51RZkSF8OO A5VFC1skSTx5/RRABWyJBAy5x20AgKDnAOXCiglWAK+JeVVBeYoQLJ4EjKKqKlz8Jw4nuoA4 SQQQcuANRQBtQ1NmDgo/roKZ+DDu7KCLpBknPgOPKgvSACwM8CDhhQUzcpM50AldQ0iQ3GKC 0Q4yBGUUFhWMMMdOEHA9lALE62JwwgnjPOgEQQ2sSRmccTzoIBpkSOcEGgWyCVk5ZqZOFAN+ wcHTwsMQce+pgyljdsrG3cVlP2XGR/p21RoTegKCMTOkEnP2cKB4vkmLYIIMicPZRC2JIMmC MwI+agUWMtqJJoqgupWUSoc4xIPsoibe2UthWuPdAmGcyR8lKGC60EqJAwjKgmvwkcM4oGpB QEFVYk4cYGVA0IYYkyojUKIDSAZICjOgDUAC2ZOAAqiDExMAfFPCgoqCYmcMaBTnGIjlxoBu FT7OQ40gDTIJJnH3VRNLaR8rUHUuZL3/AEVhSrv8Wz3j5qMiOZ/tfNVUHFvZ89IC/wAX0GoU 3iP3vpqrFr8R7voqItP4q/uH5qrSfaeqys/Ae76Ky0Wmb94pEPtfx3qpAbf+P7R89Rond/wT 30RLHwe00aKHxt+99NVIsfwz7fmqUXazoKX+IP3WqRaYv8P2CiEN/DHs+iqkVdyHcKkVqP8A EXuP0VVS3/C9lAW2yf8AeNEpX/ifZ9BqKI/EP3fpqgXzP7oqJShk3fWhSfQKlIM/Aaoq78D/ ALv10gaPgpQr/c//ADG/7JqHwYP4yfvClCx8J/eNRou//EX/AOX/ALVCLsZL+5/tGrEo+o/G n7yfOKiwVj4Lff8AXRDW4+z6KsSlvknt+ekU2z9fzmqgrf0VFNOb/wBOFEJf4R3j56KBP4S9 9CDHwjvFCqv8O4UEs/FVFXs0/eNRDdv8K95oG3P4Kd5oMd7P30CrX2O8/wDaNUReH9OdEEPh ailbj/L7vooFn4m7hUU25/DogRkf3R85qwpJ+H+781A3bfEO76DQ+F7f+K3dUoW38R/6casK j5j2fNQS99ruoAP/AHpe76KFRf4D+2hFW/itd5ohy5n976aUhW8yNRWXb8f3h81WjcPjP7v0 0QP+ae40KpvhH71FUfjT20QbZnuPzUBDNO6kQFr4V7/opVM2/wAKdxoH3M2/e+qrERv4Q/eq UgFzf2UA2viud311Qs/TUAnOqBvZj20F2/4Z/d+mhEt8KD//2Q== ________________________________________________________________________________
Subject: covering is FUN!
Date: Feb 20, 2005
well... the tail feathers are nearing completion. All covered except one elevator and the H.stab. I like covering! and you know what's even more disgusting?? I REALLY like stitching! It's so fun to tie those damn knots! am I crazy or what?! I am hoping to shoot Poly-Spray on them in the next week, maybe two DJ Vegh www.imagedv.com/aircamper N74DV ________________________________________________________________________________
Date: Feb 21, 2005
Subject: Weldable flange (fiberglass fuel tank)
I'm getting close to building my fuel tanks out of fiberglass. In looking at the book, Sportplane Construction Techniques by Tony Bingelis (page 83) I see the flange but don't have any idea which flange size to order for my specific needs. Both AS&S and Wicks show flanges using 1/8", 1/4", 3/8", 1/2", 3/4" female pipe thread in which to insert the finger strainer. I'm guessing a 3/8" would be OK for a Contienetal A-65 or a Corvair engine's thirst? Or should I go with 1/2"? Thanks, Roy ________________________________________________________________________________
Subject: Plans ordering trouble
Date: Feb 21, 2005
Hi all, Have finally decided to take the plunge and order plans (wife said OK) and am running into difficulty trying to make this happen. Is the information on the Pietenpol web site still accurate? I attempted to email Don and Andrew with the addresses listed and they bounced back undeliverable. Any thoughts on how I can obtain a set of plans so I can start construction? Dan Loegering Fargo ND ________________________________________________________________________________
Date: Feb 21, 2005
Subject: Airfoils
Pieters, Anyone know whether the GN is the same airfoil as the B H Pietenpol? Corky ________________________________________________________________________________
Subject: Re: Airfoils
Date: Feb 21, 2005
it is with the exception of the radius of the leading edge. the GN1 has a larger radius for a more blunt leading edge. Other than that it's the same. also the spars are placed on 31" centers on the GN1. DJ ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, February 21, 2005 10:54 AM Subject: Pietenpol-List: Airfoils Pieters, Anyone know whether the GN is the same airfoil as the B H Pietenpol? Corky ________________________________________________________________________________
Subject: Re: Plans ordering trouble
Date: Feb 21, 2005
I ordered my plans in November and used the Paypal option for payment. They were delivered within 2 weeks and even included a letter from Don Pietenpol suggesting that I make at least one part every day. I never received any e-mails from them though. Ben Charvet Just getting started too ________________________________________________________________________________
Date: Feb 21, 2005
In a message dated 2/21/05 12:18:52 PM Central Standard Time, djv(at)imagedv.com writes: << it is with the exception of the radius of the leading edge. the GN1 has a larger radius for a more blunt leading edge. Other than that it's the same. also the spars are placed on 31" centers on the GN1. DJ >> DJ is correct about the leading edge, and although I've never seen the GN1 and the Pietenpol 'FC 10' overlaid on each other, I'd be willing to bet there are other small differences. I do understand that a larger radius on the leading edge helps keep the wing flying at a higher 'Critical Angle of Attack' (AOA when the wing begins to stall). Have you ever noticed how large the radius is on aerobatic planes? It's Huge !! It allows them to fly at a higher angle of attack, and use the enormous amount of thrust to maintain altitude, when they are behind the power curve. The official name for behind the power curve is the 'Region of Reversed Command'. The drawback to a larger radius leading edge is in cruise flight, where drag is increased significantly...that's why the aerobatic planes don't make a very efficient cross country plane. Nothing is for Free in aircraft design !! Chuck G. Hey...I've been reading a book by Berry Schiff called '1001 Things You Though You Knew About Aviation'. Why was it decided in the 18th Century that the territorial limit of the United States (and other countries) should extend three miles beyond shore ? This was the maximum range of a shore based cannon. ________________________________________________________________________________
Date: Feb 21, 2005
Subject: Re: Weldable flange (fiberglass fuel tank)
In a message dated 2/21/05 8:20:19 AM Central Standard Time, Pilots4ETW(at)wmconnect.com writes: << I'm getting close to building my fuel tanks out of fiberglass. In looking at the book, Sportplane Construction Techniques by Tony Bingelis (page 83) I see the flange but don't have any idea which flange size to order for my specific needs. Both AS&S and Wicks show flanges using 1/8", 1/4", 3/8", 1/2", 3/4" female pipe thread in which to insert the finger strainer. I'm guessing a 3/8" would be OK for a Contienetal A-65 or a Corvair engine's thirst? Or should I go with 1/2"? Thanks, Roy >> Roy, I believe 3/8" is the chosen pipe thread for the small Continentals. That is what I used, however I did some rework to the finger strainer. The only finger strainer I could find had 3/8" male pipe threads, and reduced to 1/4" female threads, with a hex to tighten the finger strainer into the weldable fitting. I was afraid 1/4" is too small, and would restrict fuel flow. I reworked the finger strainer by using a die to cut the male threads of the finger strainer down to the point where it would go in the female threads of the weldable fitting enough to allow an AN822 ELBOW with 3/8" male pipe thread on one end, to go into the weldable fitting, and 3/8" Flair fitting on the other end of the elbow. I left the hex on the finger strainer till I got the threads cut down enough, then cut the hex off, and used a square easy out to install and seat the finger strainer down in the weldable fitting, then installed the elbow on top of it. I ruined the first finger strainer, by cutting too much threads off, and it just threaded right through the weldable fitting. I now have 3/8" plumbing all the way from the tank, through the gascolator, to the carb. Oh yeah, before glassing it in, I also cut the ridge down around the radius of the weldable fitting, so the fiberglass layers would lay right up around it. Chuck G. the word 'Aileron' is derived from a French word referring to a 'Small Wing'. (sheesh.......I feel like Cliff Claven from Cheers !! ) ________________________________________________________________________________
Date: Feb 22, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: GN-1 project on ebay
This looks pretty nice........ http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4529984847&category=63679&sspagename=WDVW ________________________________________________________________________________
Subject: Re: GN-1 project on ebay
Date: Feb 22, 2005
that's the same one that was for sale last year. Not sure why it's listed again cause I thought it sold last time. It does look nice though. I like the aluminum combing work. DJ ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: GN-1 project on ebay > > > This looks pretty nice........ > > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4529984847&category=63679&sspagename=WDVW > > > ________________________________________________________________________________
Date: Feb 22, 2005
Subject: Why buy plans?
Listers, I was wondering if it is really necessary to purchase plans for the Pietenpol Air Camper, or the GN-1, when the plans in the 1932 Flying and Glider Manual (available from EAA) seem to be good enough to build from? Isn't that why they were published originally? Dan Hopper Walton, IN ________________________________________________________________________________
Subject: Re: Why buy plans?
Date: Feb 22, 2005
Dan, The plans include changes/improvements to several areas including cable routings, landing gear, spar fittings, rib construction, etc... Greg Cardinal FAA paperwork is DONE and approved! Final inspection to be scheduled in MARCH! ----- Original Message ----- From: Hopperdhh(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, February 22, 2005 6:56 PM Subject: Pietenpol-List: Why buy plans? Listers, I was wondering if it is really necessary to purchase plans for the Pietenpol Air Camper, or the GN-1, when the plans in the 1932 Flying and Glider Manual (available from EAA) seem to be good enough to build from? Isn't that why they were published originally? Dan Hopper Walton, IN ________________________________________________________________________________
Date: Feb 22, 2005
Dan, You could build from the F&G plans. The 1934 plans, from Don Pietenpol, are called improved and most seem to think they are. They are also bigger and there is more detail. The 34 plans are 2 1/2 inches longer and the Corvair fuselage is about 14 inches longer, you may want the longer fuse if you are larger than about 5'8" and 180 lbs. or just want more space. If you use the F&G plans check out the diagonal brace in the pilot pit, it goes the same way all the other diagonals go, opposite from the 34 plans. The F&G are also missing the long gusset on the lower longeron aft of the pilot seat and the large gusset on the tail post. The 34 plans also have larger and harder wood braces across the floor at the lift strut attach points. Hope this helps. Skip Hales Landing WV ________________________________________________________________________________
Date: Feb 22, 2005
Dan, I think you could easily use the F&G plans. There seem to be about three types of Piet builders: those who stick religiously to the plans and don't stray at all, those who stray just a little from the plans, and those who stray a lot. There are even a few who use the plans only as an educational resource and from them build an entirely different airplane. All of the above builders are correct in that they are building airplanes and are having fun. For my project, I could have easily just used the F&G plans and my plane would have turned out just the same. If you are the purist builder, then the 1934 plans may be more helpful to you. Either way, you will have fun building this little airplane (and it's variations). Doc > > ----- Original Message ----- > From: Hopperdhh(at)aol.com > To: pietenpol-list(at)matronics.com > Sent: Tuesday, February 22, 2005 6:56 PM > Subject: Pietenpol-List: Why buy plans? > > > Listers, > > I was wondering if it is really necessary to > purchase plans for the Pietenpol Air Camper, or the > GN-1, when the plans in the 1932 Flying and Glider > Manual (available from EAA) seem to be good enough > to build from? Isn't that why they were published > originally? > > Dan Hopper > Walton, IN __________________________________ ________________________________________________________________________________
Date: Feb 23, 2005
Netscape/7.2 (ax)
Subject: Re: 4130 cutting with PLASMA?
I have one from Grizzly--it's probably from the same factory in China. On mine, it was impossible to adjust the blade tension tight enough to keep the blade on the wheel. I used the cutting attachment on my welding torch to elongate the adjustment hole and get a bit more travel. Since then it's worked OK. I agree with you that it's not a great tool, but it gets my job done--usually. I only use it in the vertical position, and made a new table without the big hold that the stock one comes with. Gene Hubbard San Diego Dennis Engelkenjohn wrote: > >Hi Chuck: > I got a Harbor Freight metal cutting bandsaw but I am not real pleased >with it. I doesn't cut straight in the horizontal position, the blade veers >off to one side. In the vertical position the blade jumps off the wheels. Is >there any way to correct this? My buddy has a King brand, but the same saw >and his is great. >Dennis >----- Original Message ----- >From: <Rcaprd(at)aol.com> >To: >Sent: Wednesday, February 16, 2005 9:08 PM >Subject: Re: Pietenpol-List: 4130 cutting with PLASMA? > > > > >> >>In a message dated 2/16/05 6:15:56 PM Central Standard Time, >>jim_markle(at)mindspring.com writes: >> >><< Northern Tool and Harbor both have an outstanding metal cutting band >> >> >saw > > >>(cuts horiz and vert) for around $170.....EASILY worth the money..... >> >> >>That's what I use to cut all my 4130, both tubing and sheet steel. When I >>raise it up to verticle, I use it to cut sheet steel over.090" thick. I >> >> >bought > > >>mine used for $30. >> >>Chuck G. >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 23, 2005
Netscape/7.2 (ax) with PLASMA?
Subject: Re: Harbor Freight bandsaws / was: 4130 cutting with
PLASMA? I've had OK luck with the bi-matellic blades from Grizzly. One breaks every few months. Gene Jim Ash wrote: > > Don't even consider using the blade Harbor Freight sends you with the > bandsaw; go get a real blade from somewhere reputable. Better yet, buy > your blade by the foot, get some silver solder and make them to length > yourself. > > Jim Ash > > > >> >> >> Hi Chuck: >> I got a Harbor Freight metal cutting bandsaw but I am not real >> pleased >> with it. I doesn't cut straight in the horizontal position, the blade >> veers >> off to one side. In the vertical position the blade jumps off the >> wheels. Is >> there any way to correct this? My buddy has a King brand, but the >> same saw >> and his is great. >> Dennis >> ----- Original Message ----- >> From: <Rcaprd(at)aol.com> >> To: >> Sent: Wednesday, February 16, 2005 9:08 PM >> Subject: Re: Pietenpol-List: 4130 cutting with PLASMA? >> >> >> > >> > In a message dated 2/16/05 6:15:56 PM Central Standard Time, >> > jim_markle(at)mindspring.com writes: >> > >> > << Northern Tool and Harbor both have an outstanding metal cutting >> band >> saw >> > (cuts horiz and vert) for around $170.....EASILY worth the >> money..... >> >> > > > ________________________________________________________________________________
Date: Feb 23, 2005
<004f01c51565$d09a9900$8442fea9@karen> <421D5831.9070906(at)sbcglobal.net> I have a question about these things. Are the wheels flat faced or crowned? clif I have one from Grizzly--it's probably from the same factory in China. On mine, it was impossible to adjust the blade tension tight enough to keep the blade on the wheel. I used the cutting attachment on my welding torch to elongate the adjustment hole and get a bit more travel. Since then it's worked OK. I agree with you that it's not a great tool, but it gets my job done--usually. I only use it in the vertical position, and made a new table without the big hold that the stock one comes with. Gene Hubbard San Diego ________________________________________________________________________________
Subject: RE: Testing a rib
Date: Feb 24, 2005
What is an appropriate method to break a wing rib? I built one tonight using stables to hold the gussets on. When I removed it from the jig, I found that there was not enough strength in the stapled joints to keep the rib in shape. Basically, things were shifting and twisting. From here on out I will go back to letting the rib cure in the jig. The rib tonight will be scrap, and I would like to bust it. I have had the best results from gluing all of the rib and gussets together at one time. Basically, putting a set of gussets into the jig, then all the rib sticks, then the other set of gussets. When I put one of the 3 inch split PVC clamps on each gusset everything is held firmly. After cure, the rib is removed, and everything looks really good. If I don't use that much pressure, sometimes a stick will not be seated fully, and the gusset will not have good contact with all of the mating sticks. I am concerned that I might be putting too much pressure on the T88 and be starving the joint. I tried a rib with Resorcinol so as to not have the pressure concern. It worked OK, but the T88 made a better looking rib (gap filling). Any insight would be appreciated. Regards- Norm Muzzy ________________________________________________________________________________
Date: Feb 24, 2005
Subject: Re: RE: Testing a rib
>What is an appropriate method to break a wing rib? Do not install the wing tip bow and attempt to tighten your drag and anti drag wires in the outer bay. I did this and when the end rib failed it did so with such a force that the noise it generated made me think that someone had fired a cannon in my living room. Mike C. ________________________________________________________________________________
Date: Feb 24, 2005
Look at the loads imposed on a rib in flight. Generally, most of the loading is applied to the lower capstrip, through air pressure on the fabric on the bottom of the wing and the partial vacuum (reduced pressure) from the air flowing over the top of the airfoil, transmitted to the lower capstrip through the rib lacing (some load is carried by the top capstrips, through the glue attaching the fabric to the top capstrips). If you assume the worst case, a 3.2 G pullout from a dive at max gross weight (say, 1100 lbs), with a 50% safety factor thrown in for good measure, the total load seen by the wing is 1100 x 3.2 x 1.5 or 5,280 lbs. If you assume that this load is evenly distributed over the 30 ribs, each rib is carrying a total load of 176 lbs. Further assuming that the load is evenly distributed along the 60" length of each rib, this works out to a loading of just under 3 lbs per inch of rib length. If you can suspend your rib to hang upside down, supported on two stubs of spars secured to your workbench and then press down with a flat piece of plywood 12" wide bearing down on a flat section of the rib and load it with 36 lbs of whatever you want, this would be a reasonable approximation of the actual loading. Having said all that, the main thing you want to check with glue joints is that the wood around the joint fails before the joint does. Any method you can apply to a joint to break it (except trying peel the doublers off - glue is not very strong in "peel strength") should demonstrate that the wood breaks first. If the glue joint breaks and the wood is intact, there's something wrong with your gluing technique. Jack Phillips, PE Sr. Manager, Disposables Product Development Clinical Technologies and Services Cardinal Health Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of NEMuzzy Subject: Pietenpol-List: RE: Testing a rib What is an appropriate method to break a wing rib? I built one tonight using stables to hold the gussets on. When I removed it from the jig, I found that there was not enough strength in the stapled joints to keep the rib in shape. Basically, things were shifting and twisting. From here on out I will go back to letting the rib cure in the jig. The rib tonight will be scrap, and I would like to bust it. I have had the best results from gluing all of the rib and gussets together at one time. Basically, putting a set of gussets into the jig, then all the rib sticks, then the other set of gussets. When I put one of the 3 inch split PVC clamps on each gusset everything is held firmly. After cure, the rib is removed, and everything looks really good. If I don't use that much pressure, sometimes a stick will not be seated fully, and the gusset will not have good contact with all of the mating sticks. I am concerned that I might be putting too much pressure on the T88 and be starving the joint. I tried a rib with Resorcinol so as to not have the pressure concern. It worked OK, but the T88 made a better looking rib (gap filling). Any insight would be appreciated. Regards- Norm Muzzy ________________________________________________________________________________
Date: Feb 24, 2005
Subject: Aircraft Spruce & Specialty $HIPPING
I called AS&S early this morning thinking I would order some 1/16th inch thick plywood, 48 inches by 48 inches. The plywood was reasonable, just $24 but the lady quoted me a price of $120.00 to ship it. I then called Wicks. They wanted somewhere around $50 for the same piece of plywood, but this time the lady on the phone said "I can't tell you about shipping, the guys downstairs to that.." Is this reasonable, sales (at Wicks) not knowing what the left hand is doing and AS&S getting $120 for shipping a thin piece of 48 inch by 48 inch plywood a couple of states away? S.B. ________________________________________________________________________________
Date: Feb 24, 2005
Subject: Re: Aircraft Spruce & Specialty $HIPPING
Sterling--- I went to UPS and it varied for a 50"x50"x2" 5 lb. package from 110 to 150 $$$$$$ !!!! Try the FedEx ground web site. Both of these sites have calculators to see how much things cost to ship------I certainly don't recall it being sooeee outrageous ! Mike http://www.ups.com/ http://www.fedex.com/us/services/us/ground.html ________________________________________________________________________________
Date: Feb 24, 2005
The problem is that when you get big pieces like that (beyond the sizes UPS can ship), it has to go by truck and that gets expensive quickly. I tried to have all my big stuff (spars, longerons, plywood sheets) shipped at once so I only had to eat such a cost once. Actually, I did do it twice - I got my spars from Wicks and my longerons and plywood from ASS a couple of years later. As I recall it was about $100 each time for shipping - and that was just to the trucking companiy's terminal. I still had to manage to get the stuff from the trucking company to my house. Jack Phillips Finishing the structural repairs to NX899JP this weekend, then on to fabric repairs -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of N321TX(at)wmconnect.com Subject: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING I called AS&S early this morning thinking I would order some 1/16th inch thick plywood, 48 inches by 48 inches. The plywood was reasonable, just $24 but the lady quoted me a price of $120.00 to ship it. I then called Wicks. They wanted somewhere around $50 for the same piece of plywood, but this time the lady on the phone said "I can't tell you about shipping, the guys downstairs to that.." Is this reasonable, sales (at Wicks) not knowing what the left hand is doing and AS&S getting $120 for shipping a thin piece of 48 inch by 48 inch plywood a couple of states away? S.B. ________________________________________________________________________________
Date: Feb 24, 2005
Airborne Express is the cheapest when it comes to this stuff... and they'll deliver it to your house. That's how my big 4x8 sheets of ply came and it was reasonably priced DJ ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Thursday, February 24, 2005 1:50 PM Subject: RE: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING The problem is that when you get big pieces like that (beyond the sizes UPS can ship), it has to go by truck and that gets expensive quickly. I tried to have all my big stuff (spars, longerons, plywood sheets) shipped at once so I only had to eat such a cost once. Actually, I did do it twice - I got my spars from Wicks and my longerons and plywood from ASS a couple of years later. As I recall it was about $100 each time for shipping - and that was just to the trucking companiy's terminal. I still had to manage to get the stuff from the trucking company to my house. Jack Phillips Finishing the structural repairs to NX899JP this weekend, then on to fabric repairs -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of N321TX(at)wmconnect.com Sent: Thursday, February 24, 2005 3:24 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING I called AS&S early this morning thinking I would order some 1/16th inch thick plywood, 48 inches by 48 inches. The plywood was reasonable, just $24 but the lady quoted me a price of $120.00 to ship it. I then called Wicks. They wanted somewhere around $50 for the same piece of plywood, but this time the lady on the phone said "I can't tell you about shipping, the guys downstairs to that.." Is this reasonable, sales (at Wicks) not knowing what the left hand is doing and AS&S getting $120 for shipping a thin piece of 48 inch by 48 inch plywood a couple of states away? S.B. ________________________________________________________________________________
Date: Feb 24, 2005
S.B. You wrote it like AS&S has a shipping company. They are just passing along the rates from the shipping people. Due to the size it's probably going by truck. When I was doing my leading edge, they were nice enough to rip it into 4 pieces 12' X 96" which is leagel UPS size. walt evans NX140DL ----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Thursday, February 24, 2005 3:23 PM Subject: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING and AS&S getting $120 for shipping a thin piece of S.B. ________________________________________________________________________________
Date: Feb 24, 2005
I got my plywood (1 4x8 sheet of 1/4" BS1088 and 3 sheets of 1/8" 4x8 BS1088 Okoume) from Noah's Marine for about $300 and that included freight (which was about $100 as I recall) DJ ----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Thursday, February 24, 2005 1:23 PM Subject: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING I called AS&S early this morning thinking I would order some 1/16th inch thick plywood, 48 inches by 48 inches. The plywood was reasonable, just $24 but the lady quoted me a price of $120.00 to ship it. I then called Wicks. They wanted somewhere around $50 for the same piece of plywood, but this time the lady on the phone said "I can't tell you about shipping, the guys downstairs to that.." Is this reasonable, sales (at Wicks) not knowing what the left hand is doing and AS&S getting $120 for shipping a thin piece of 48 inch by 48 inch plywood a couple of states away? S.B. ________________________________________________________________________________
Date: Feb 24, 2005
FYI on shipping light stuff - When I worked for Fedex, shipping cost rate was based on package weight. But there was also an internal calculation they did called 'dimensional weight', which is what they would end up charging if you shipped a large box of air. I don't remember the calculations, but the net result was to generate a 'weight' based on dimensions for oversized packages. I don't remember when they applied it versus just the normal package weight. Jim Ash > > >Sterling--- I went to UPS and it varied for a 50"x50"x2" 5 lb. package >from 110 to 150 $$$$$$ !!!! > >Try the FedEx ground web site. Both of these sites have calculators to >see how much things cost to ship------I certainly don't recall it being >sooeee outrageous ! > >Mike > >http://www.ups.com/ > > >http://www.fedex.com/us/services/us/ground.html > > ________________________________________________________________________________
Date: Feb 24, 2005
I get all my ply from Alpha Aviation in Greenville (about a 30 minute drive East (sort of) from Dallas).....same price as AS&S, only costs driving out to see Russ and is a LOT more fun to deal with (he's a really nice guy)...... Or how about I "ship" it to Plano for $100 (that's a $40 savings!!!) and you "stop by" and pick it up???? Isn't that a win-win????? jm ----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Thursday, February 24, 2005 2:23 PM Subject: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING I called AS&S early this morning thinking I would order some 1/16th inch thick plywood, 48 inches by 48 inches. The plywood was reasonable, just $24 but the lady quoted me a price of $120.00 to ship it. I then called Wicks. They wanted somewhere around $50 for the same piece of plywood, but this time the lady on the phone said "I can't tell you about shipping, the guys downstairs to that.." Is this reasonable, sales (at Wicks) not knowing what the left hand is doing and AS&S getting $120 for shipping a thin piece of 48 inch by 48 inch plywood a couple of states away? S.B. ________________________________________________________________________________
Date: Feb 24, 2005
Problem solved! I'm heading to Alpha Aviation in Greenville. Long drive from Central Texas, but worth the trip to see this place. Jim. Do I drop off a taco and Corona on the way, or FedEx it to Plano? Thanks for the tip. S.B. ________________________________________________________________________________ ETAsAhQKoFnlqgqD5i+i17eeRql5/3g4kwIUX2SPUuxbWcxYLReo+aBlUIXyCzs=
Date: Feb 24, 2005
Subject: Shipping cost
....."the supplier is passing the shipping cost along to you...." True, but I guarantee the shipping is the cheapest part of "shipping and handling" I recently bought a small item with $8 S&H only to find postage was just $1.25. The important thing is to do a lot of figuring and buy all of your ply at once. Also perhaps order extra 1/4 sheet so so. You will use it. Leon Stefan in Ks. Building his Peit from his meager UPS wage. ________________________________________________________________________________
Date: Feb 24, 2005
Drop it off on the way....and pick up those welding flanges.... I typically call Russ first (903.455.3113) just to make sure.... JM ----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Thursday, February 24, 2005 4:57 PM Subject: Re: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING Problem solved! I'm heading to Alpha Aviation in Greenville. Long drive from Central Texas, but worth the trip to see this place. Jim. Do I drop off a taco and Corona on the way, or FedEx it to Plano? Thanks for the tip. S.B. ________________________________________________________________________________
Date: Feb 24, 2005
I dunno about that.... have you checked what shipping for a taco and a beer bottle would cost?? ;) ----- Original Message ----- From: N321TX(at)wmconnect.com To: pietenpol-list(at)matronics.com Sent: Thursday, February 24, 2005 3:57 PM Subject: Re: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING Problem solved! I'm heading to Alpha Aviation in Greenville. Long drive from Central Texas, but worth the trip to see this place. Jim. Do I drop off a taco and Corona on the way, or FedEx it to Plano? Thanks for the tip. S.B. ________________________________________________________________________________
Date: Feb 24, 2005
I guess an appology is due to AS&S. My mindset on the shipping issue was probably from my buying things on Ebay where some (not all) vendors charge $30 to send something and when it arrives in the mail, the postage was $6. I'm off to Alpha Aviation Supply Company in Greenville, TX next week for my plywood needs. AS&S had the best price for the actual purchase of the plywood I am in need of, BTW. S.B. ________________________________________________________________________________
From: "Jake Crause" <admin(at)homebuiltairplanes.com>
Subject: Upstate NY / Cold Conditions
Date: Feb 25, 2005
Hey folks, Anyone on the list building a Piet in Upstate NY? I just moved to Croghan (near Watertown) and am setting up shop to start building very soon. I'd love to meet with / converse with local builders if possible. On another note; my detached rough lumber 3.5 car garage is not insulated and as you can imagine it gets VERY cold in there. I kicked the snow off my boots inside the threshold of the door on the day I moved in and the same clumps of snow are right were I left them 2 weeks later. What are some ways I can deal with the cold and still make progress on the structure? I thought of building a thermostatically controlled heat box made of Styrofoam insulation to set over the work table and whatever part I'm working on while it cures. Not difficult to build and I imagine much easier than trying to heat the entire space. How long would the glue joints need to be maintained in the room temp range before they can be allowed to be returned to the sub-zero temps? Is it a bad Idea to let finished parts of the structure be exposed to such temps? FYI right now my plans are to use either T-88 or the West system. Is there a better glue for these cold conditions? Thanks in advance! Jake Crause www.homebuiltairplanes.com ________________________________________________________________________________
Date: Feb 25, 2005
Regarding the shipping of plywood, I have run into many problems with shipping. I have shipped plywood with fedex, airborne, ups and a number of truck lines. anywhere from a few sheets of 1/8" to 20,000 lbs. When shipping by truck, you are paying for the labor at the dock( to a point) . It doesn't seem to matter much whether you ship 20 to 200 lbs, the price doesn't change all that much. When shipping full size sheets via the overnight operations, my loss ratio was as high as 50 % The problem there was how to package light weight ( they DO charge by the pound) to prevent bending the panel in half. Lately, UPS has been accepting larger packages...I just shipped a sheet of 3/4" teak ply that I cut in half lengthwise so the package was 24"x 96" x 3" thick. The cost of shipping was $105 including insurance. It was classified as an oversize 3 package and was charged at a 90 lb rate, even though it only weighed 70lb. If anyone on the Piet list needs plywood shipped, let me know via PM or phone, not over the list. I will cut panels to rough size for you to save on shipping. Cheers Wayne Midwest Marine Plywood 651-882-9704 >From: N321TX(at)wmconnect.com >Subject: Re: Pietenpol-List: Aircraft Spruce & Specialty $HIPPING > >I guess an appology is due to AS&S. My mindset on the shipping issue was >probably from my buying things on Ebay where some (not all) vendors charge $30 >to >send something and when it arrives in the mail, the postage was $6. > >I'm off to Alpha Aviation Supply Company in Greenville, TX next week for my >plywood needs. > >AS&S had the best price for the actual purchase of the plywood I am in need >of, BTW. > >S.B. > > > > ________________________________________________________________________________
Subject: Excellent Pietenpol article....
Date: Feb 25, 2005
on eBay.... This is about 10 pages of some of the best Pietenpol info available..... It's an article by Joe Christy called: "The Pasture Pilot's Pride and Joy" I got a copy of it about a year ago or I wouldn't be tellin' you guys about it!!! :-) It's great. <http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item6948497168&ssPageNameADME:B:SS:US:1> Jim Markle Plano, TX 214.505.6101 ________________________________________________________________________________
Subject: Re: Excellent Pietenpol article....
Date: Feb 25, 2005
Ok, the link fails (why do I bother????) If you're interested, go to eBay and look up item #6948497168 Jim Markle Plano, TX 214.505.6101 ----- Original Message ----- From: Jim Markle To: pietenpol-list(at)matronics.com Sent: Friday, February 25, 2005 9:03 AM Subject: Pietenpol-List: Excellent Pietenpol article.... on eBay.... This is about 10 pages of some of the best Pietenpol info available..... It's an article by Joe Christy called: "The Pasture Pilot's Pride and Joy" I got a copy of it about a year ago or I wouldn't be tellin' you guys about it!!! :-) It's great. <http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item6948497168&ssPageNameADME:B:SS:US:1> Jim Markle Plano, TX 214.505.6101 ________________________________________________________________________________
Subject: Re: Testing a rib
Date: Feb 25, 2005
Norm, I recently finished a set of ribs, using T-88, and didn't encounter your problem. I measured the T-88 using two children's medicine-measuring syringes I got at CVS. Did the last because I had had one bad curing experience using the "equal length beads on the paper plate" method, in which it took about a week rather than 24 hours for the tackiness in one rib to go away. My sequence was a) install and glue ribs and braces in the jig, b) glue gussets on one side, c) staple gussets in place, d) pull out assembly, inspect for squeeze-out on all joints, turn jig upside down and place rib on back of jig and glue gussets to other side, e) staple gussets on other side, f) finish by inspecting for squeeze-out and labelling the date on the rib and the test pieces. I applied glue to both surfaces always, because early on it looked like that seemed to ensure good squeeze-out. At first I placed a thin plastic strip between the prongs of the staple when stapling, then pulled it out after driving the staple; theory being that that would allow for more T-88 in the joint. However, I found that that seemed to actually interfere with good squeeze-out, so I quit doing it, used more pressure on the standard 1/4" staples, and still had satisfactory breaking results with all of the test joints (one for each little batch of glue which amounts to 2 per regular rib, 3 on end ribs). HAVING SAID THAT, no one but me has inspected the ribs, which haven't been assembled into a wing, which has never flown. Take it for what it's worth. It's just that Resorcinol seems like a huge pain in the butt, kind of like using nails rather than staples, and the staples seemed to hold the rib together even during the 30 to 45 minutes when they were only on one side. Mark Hodgson ________________________________________________________________________________
Subject: Testing a rib
Date: Feb 25, 2005
From: "Textor, Jack" <jtextor(at)thepalmergroup.com>
Sounds like a good system Norm. You do a "test" with each rib? Is that something the feds want? Jack Textor ________________________________________________________________________________
Subject: Re: Upstate NY / Cold Conditions
Date: Feb 25, 2005
Jake The answer to that question has a direct relationship to the tolerance level of the wife. Winter is a great time for making wing ribs or the tail feathers. You can make the jig for either and set it up on a dining room table or a washing machine while working and prop it up in the corner when not working. Winter is also good for making controll horns and other steel parts. T-88 will cure at 50 deg. so you can work in the basement also. Also, check out the local EAA chapter, they may let you set up a work area in the chapter hangar. Dick N. ----- Original Message ----- From: Jake Crause To: pietenpol-list(at)matronics.com Sent: Friday, February 25, 2005 12:38 AM Subject: Pietenpol-List: Upstate NY / Cold Conditions Hey folks, Anyone on the list building a Piet in Upstate NY? I just moved to Croghan (near Watertown) and am setting up shop to start building very soon. I'd love to meet with / converse with local builders if possible. On another note; my detached rough lumber 3.5 car garage is not insulated and as you can imagine it gets VERY cold in there. I kicked the snow off my boots inside the threshold of the door on the day I moved in and the same clumps of snow are right were I left them 2 weeks later. What are some ways I can deal with the cold and still make progress on the structure? I thought of building a thermostatically controlled heat box made of Styrofoam insulation to set over the work table and whatever part I'm working on while it cures. Not difficult to build and I imagine much easier than trying to heat the entire space. How long would the glue joints need to be maintained in the room temp range before they can be allowed to be returned to the sub-zero temps? Is it a bad Idea to let finished parts of the structure be exposed to such temps? FYI right now my plans are to use either T-88 or the West system. Is there a better glue for these cold conditions? Thanks in advance! Jake Crause www.homebuiltairplanes.com ________________________________________________________________________________
Date: Feb 25, 2005
Jake-- don't know if you are near Brockport but Tom Bowdler is a nice guy (dentist by profession) who owns an 0-200 Canadian built Piet and is pretty close to finishing another. There are also TWO guys who have Ford powered Piets near there too---a father-in-law, son-in-law combination. I can't recall their names anymore but they came thru Ohio in 1998 or 99 and after we had flown a three ship for a while towards Indiana I pulled away from them and heard later that the one lost his prop and flipped in a bean field (he and his son were okay) and the father-in-law landed nearby safely. Last I heard the damaged Piet was either flying or close to flying again. Mike C. >Hey folks, > > >Anyone on the list building a Piet in Upstate NY? I just moved to Croghan >(near Watertown) and am setting up shop to start building very soon. I d >love to meet with / converse with local builders if possible. > > >On another note; my detached rough lumber 3.5 car garage is not insulated >and as you can imagine it gets VERY cold in there. I kicked the snow off >my boots inside the threshold of the door on the day I moved in and the >same clumps of snow are right were I left them 2 weeks later. What are >some ways I can deal with the cold and still make progress on the >structure? I thought of building a thermostatically controlled heat box >made of Styrofoam insulation to set over the work table and whatever part >I m working on while it cures. Not difficult to build and I imagine much >easier than trying to heat the entire space. How long would the glue >joints need to be maintained in the room temp range before they can be >allowed to be returned to the sub-zero temps? Is it a bad Idea to let >finished parts of the structure be exposed to such temps? FYI right now >my plans are to use either T-88 or the West system. Is there a better >glue for these cold conditions? Thanks in advance! > > >Jake Crause > >www.homebuiltairplanes.com ________________________________________________________________________________
Date: Feb 25, 2005
Jake I am in cambridge about 1 hour n of albany, but the real expert is Ed Snyder hes maybe 1/2 hour n of albany, in Clifton Park. He has a for sale ad in the current newsletter Henry Williams ________________________________________________________________________________
Date: Feb 25, 2005
Norm, these are all good techniques, but I found that the old fashioned way was the best way for me. I simply mitered in my caps and diagonals, guled (T-88) the joints. Layed a gussett over a joint and marked around it, spread on a good thick layer of glue, nailed the gussett on with one nail (3/8", 20 guage A/C) in each diagonal and usually two in each cap. Just as soon as I had all the gussetts on, I pulled (gently) the rib out of the jig and layed it on a sheet of wax paper on the work bench and did the back gussetts the same way as I did the first side. I like the nailing, it is quick and easy and doesn't add enough weight to even be concerened about. I could build two ribs easily in an evening after work. I have had my ribs inspected by several tech inspecters and they all approved them. I even cut all my caps out of spruce I bought at the local lumber yard, just like the old days. Hope this helps. Doc > > > > > > > > Contributions > any other > Forums. > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/Pietenpol-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ http://mobile.yahoo.com/maildemo ________________________________________________________________________________
Date: Feb 25, 2005
Dan, I bought my plans just over a year ago. Here is the public information that I had acquired and used to contact Mr. Pietenpol. I hope that this information is of use to you. Donald Pietenpol 1604 Meadow Circle S.E. Rochester, MN 55904 Home Number (507) 289-2436 Home Fax: (507) 289-1279 Happy winds!!!! Jim Courtney jbciii5656(at)yahoo.com --------------------------------- ________________________________________________________________________________
Subject: cabane struts
Date: Feb 25, 2005
DNA: do not archive Its-Bogus: do not forward to list --- MIME Errors --- A message with no text/plain section was received. The entire body of the message was removed. Please resend the email using plaintext formatting. NOTE! This error can also occur when the poster of the message has a specific type of computer virus. This virus WAS NOT forwarded on to the List. The poster should be informed of the potential problem with their system as soon as possible. --- MIME Errors --- ________________________________________________________________________________
Date: Feb 25, 2005
Dick: Thanks for the reply. I have given some thought to building the ribs in the house because it would be very convenient to do so. However, the reason I'm holding off on building the ribs is kind of a strange one. I know that being an Army Helicopter Pilot I will be deployed to the Middle East very soon. Probably within a year or so. Because of this I have been trying to come up with ways to maintain progress on the aircraft even though I'll be out of the country. One way to do that will be to become the first Pietenpol builder (I assume) to finish all of the wing ribs and metal fittings for the aircraft while deployed to a war zone. I'll definitely spend some money in shipping the completed ribs back, but it would give me something to enjoy and distress with. Don't laugh, having deployed numerous times, I really think it can be done :D. Mike: Brockport is quite a hike but not an unrealistic day trip. Thanks for the tip. **Mr. Bowdler, are you on the list?** Henry: Cambridge is a bit of hike as well but, if you don't mind, I'd love to swing over and say hello. How far along are you? Does anyone know the affects of storing completed parts in very cold temps will have on the integrity of the wood and glue? Will the moisture freeze and damage the fibers somehow? Thanks. Jake ________________________________________________________________________________
Date: Feb 25, 2005
Jake, Wooden airplanes are stored in unheated hangars everywhere. I've never heard of a problem. Greg Cardinal Minneapolis (my hangar is unheated.....) ----- Original Message ----- From: Jake Crause To: pietenpol-list(at)matronics.com Sent: Friday, February 25, 2005 9:57 PM Subject: RE: Pietenpol-List: Upstate NY / Cold Conditions Does anyone know the affects of storing completed parts in very cold temps will have on the integrity of the wood and glue? Will the moisture freeze and damage the fibers somehow? Thanks. Jake ________________________________________________________________________________
Date: Feb 25, 2005
Jake, Wooden airplanes were flying to the north and south poles during the late 20's and 30's and, other than freeze their pilots and passengers, held up very well. Sometimes the engines were a little cranky though. Wood is one of the best materials to build airplanes out of. It is durable, strong for it's weight and doesn't suffer from fatigue like metal does. You will find a way to work on your plane in spite of the cold and some have fun. Doc (an "Old, Bold pilot...who is still alive :) --- gcardinal(at)mn.rr.com wrote: > Jake, > Wooden airplanes are stored in unheated hangars > everywhere. > I've never heard of a problem. > > Greg Cardinal > Minneapolis (my hangar is unheated.....) > ----- Original Message ----- > From: Jake Crause > To: pietenpol-list(at)matronics.com > Sent: Friday, February 25, 2005 9:57 PM > Subject: RE: Pietenpol-List: Upstate NY / Cold > Conditions > > Does anyone know the affects of storing > completed parts in very cold temps will have on the > integrity of the wood and glue? Will the moisture > freeze and damage the fibers somehow? Thanks. > > > > Jake > __________________________________ http://baseball.fantasysports.yahoo.com/ ________________________________________________________________________________
Date: Feb 26, 2005
Jake: More power to you as to being deployed and building at the same time. I'm on my way to Kuwait to fly the C-12 there so if you are passing through stop by ops and say Hi. I'm trying to finish a project someone else started. But that will have to wait a few months. Chet. ________________________________________________________________________________
Date: Feb 26, 2005
Subject: Re: cabane struts
Jeff I have been pondering the same question for months. Finally got a chance to talk to my TA about it (who is an A&P and competition Pitts builder and pilot), and he approved the use of the Carlson aluminum struts with the solid aluminum inserts. (Just like DJ Vegh has documented on his excellent website). http://www.sky-tek.com/struts.html I am using the smaller size struts for the cabanes and they have 3/4 x 1" solid inserts which will fit into these so you can use 1/4" bolts and still be 2 diameters from the edges where the ends attach. Will use the large ones for the wing struts with 1 x 1" inserts. > Hi guys, what is the most common size of cabane struts and what different > choices are there? > > Jeff in Texas -- Rick Holland ________________________________________________________________________________
Date: Feb 26, 2005
Subject: Cutting and grinding aluminum
Guys What are the best tools to use to cut and grind/shape aluminum struts? I have been using an angle grinder with an .040 blade to cut all my 4130 tubing (which works great). Thanks -- Rick Holland ________________________________________________________________________________
Subject: Re: Cutting and grinding aluminum
Date: Feb 26, 2005
a bandsaw cuts aluminum struts just fine. for grinding I use my 12" bench disc sander or an angle grinder. be careful though.... aluminum is VERY efficient and heat transfer. it'll get real hot real quick when grinding on it. DJ Vegh www.imagedv.com/aircamper N74DV Mesa, AZ ----- Original Message ----- From: "Rick Holland" <at7000ft(at)gmail.com> Subject: Pietenpol-List: Cutting and grinding aluminum > > Guys > > What are the best tools to use to cut and grind/shape aluminum struts? > I have been using an angle grinder with an .040 blade to cut all my > 4130 tubing (which works great). > > Thanks > -- > Rick Holland > > > ________________________________________________________________________________
Date: Feb 26, 2005
Subject: Tachs
Pieters: I am looking to trade 3 clockwise tachs for 1 counterclockwise tach. Or will buy your counterclockwise tach. Mine are used tachs but think they should work. Ken Conrad in sunny Iowa 563 285 4073 ________________________________________________________________________________
Date: Feb 26, 2005
Subject: Re: Tachs
You CAN change the rotation of a tach by adding a right angle drive, if that's the SNAFU walt evans NX140DL ----- Original Message ----- From: Wizzard187(at)aol.com To: pietenpol-list(at)matronics.com Sent: Saturday, February 26, 2005 2:25 PM Subject: Pietenpol-List: Tachs Pieters: I am looking to trade 3 clockwise tachs for 1 counterclockwise tach. Or will buy your counterclockwise tach. Mine are used tachs but think they should work. Ken Conrad in sunny Iowa 563 285 4073 ________________________________________________________________________________
Date: Feb 26, 2005
Subject: Re: Pietenpol-brake fluid
Pieters, What is the best brake fluid to use. The aircraft red stuff or the silicone that is out now. I am using aircraft parts that are now empty. Ken again in not so warm Iowa but good for Feb. ________________________________________________________________________________
Date: Feb 26, 2005
Jake I am on LI for a bit, I wont get up to Cambridge probably till the end of March, If that works for you I will call Ed and its only another hour to see him. My body is nearly done, working on controls. ribs done , tail done( on LI on the winter). Many Pieters in the past have made the observation, that some of the metal tabs need to be made 1/4 inch longer or so, If you try to make these ahead of time ( rather then fitting them on the job ) it would be nice to know which brackets and how much-- I'm not there yet so cant help with this Henry Williams ( L I 631 423 1813, Cambridge 518 677 5485 ) ( in Cambridge no internet ) ________________________________________________________________________________
Date: Feb 26, 2005
Subject: Re: Tachs
Be carefull...not ALL right angle drives change the rotation. Forrest Lovley ________________________________________________________________________________
Date: Feb 26, 2005
Subject: Another building level reached
christinedigsjazz(at)shaw.ca, wayfollower(at)cox.net, T_FIN(at)Compuserve.com, glevy1(at)cox.net, IFlyTigers(at)aol.com, LCJELKS(at)aol.com, JimNikls(at)aol.com Pieters and friends, Ole Corky hasn't been too idle these winter months. Today I completed assembley of the major parts following a major overhaul of the Continental A-65 engine which will power Repiet NX311CC sometime in 05. An engine mechanic EARNS every nickel he charges. Corky and Isabelle livin the good life in warm Louisiana ________________________________________________________________________________
Date: Feb 26, 2005
My landlord came over today and we came up with a plan to insulate the garage and set up an oil furnace. He already has the furnace and he will pay for all the materials. Henry: Thanks for the invite. You can be sure I will take you up on it. Expect an email in early April :). Chet: It's good to know there are other Army Aviators out there building. I've run into a couple on my website at www.homebuiltairplanes.com but I'm surprised to find that most people who fly for the Army don't seem to have a big interest in recreational flying, let alone building. Best of luck on your trip and be safe! DOC and Greg: Thanks for the input. I guess it makes sense that wooden airplanes are subjected to the same climates as other aircraft and fair just as well. I'm going to stop worrying about it too much. Thanks for your help. Time to get building! Jake ________________________________________________________________________________
Date: Feb 27, 2005
Ken, Use aircraft grade brake fluid in aircraft brakes. Do NOT use automotive brake fluid. I buy mine from A.C.S.& S.C. Alex Sloan -------------- Original message -------------- Pieters, What is the best brake fluid to use. The aircraft red stuff or the silicone that is out now. I am using aircraft parts that are now empty. Ken again in not so warm Iowa but good for Feb. Ken, Use aircraft grade brake fluid in aircraft brakes. Do NOT use automotive brake fluid. I buy mine from A.C.S. S.C. Alex Sloan
-------------- Original message -------------- Pieters, What is the best brake fluid to use. The aircraft red stuff or the silicone that is out now. I am using aircraft parts that are now empty. Ken again in not so warm Iowa but good for Feb. ________________________________________________________________________________
Date: Feb 26, 2005
Jack- I will test a couple ribs, basically the ones that don't match up with the others, or that I don't want to use for whatever reason. The inspectors don't care about testing or anything like that. It doesn't hurt anything, but they are really only interested in making sure that you meet the minimum requirements, that the workmanship looks adequate, and that the paperwork is correct. This is my 2nd plane, so I have been thorugh the inspection process once (a couple times if you count helping others with their inspections). So long as the Des Moines FSDO is doing it, no big deal. Just make sure the plane is safe. Put 1.3 hours on the Cozy this afternoon. Seems strange to be building a plane that tops out at about the same speed where my first plane rotates. How far along are you? Des Moines, right? I have a source for wire wheels here that looks interesting. They make their own hobs and lace them up with moped rims. I don't know if the rims are heavy enough or not, but my guess is that they will probably work fine. -Norm Sounds like a good system Norm. You do a "test" with each rib? Is that something the feds want? Jack Textor ________________________________________________________________________________
Date: Feb 26, 2005
In a message dated 2/26/05 4:35:49 PM Central Standard Time, Wizzard187(at)aol.com writes: << Pieters, What is the best brake fluid to use. The aircraft red stuff or the silicone that is out now. I am using aircraft parts that are now empty. Ken again in not so warm Iowa but good for Feb. >> I use 5606 (the red stuff). Chuck Gantzer NX770CG p.s. I flew today for the first time in months !! It was 55 with winds 180 @ 15 to 20. Stayed in the 'condensed' pattern and shot a bunch of landings. Sure feels great to get back in the air. ________________________________________________________________________________
Date: Feb 27, 2005
Subject: Re: Tachs
Pieters. I have a right angle that does not change the direction. Lucky I didn't buy it , it was in some junk I acquried. Boy is it heavy. Ken Conrad ________________________________________________________________________________
From: "gbowen(at)ptialaska.net" <gbowen(at)ptialaska.net>
Date: Feb 27, 2005
On an ole low and slow Piete I'm not sure if it makes a lot of difference between clear silicone or red, but I can tell you from real experience that when you don't use the red stuff in a fast taxi or landing plane, you're in for a real sad surprise. During high speed ground testing of controls and brakes on my Cozy IV, I had the plane to 80 knts and return to stopped on a 5200' runway. The disc brakes put out a lot of heat when you're stopping a 1000 lb airplane on 1/2 of the runway. I managed to "boil-out" the clear autostore bought brake fluid from the disc brake calipers after the second run, ergo the brake failed with multiple boiling bubbles in the line. Luckily got stopped on the grass. The red aircraft grade brake fluid is higher in viscosity and apparently higher in temp boiling point. Replaced the clear fluid with aircraft red, haven't boil-out the fluid since. Good luck, ole Quasi-Piete N-1033B (which just this week got it's niffty 0-235 cranking hope to have flying next month) has motorcycle brake handles and go-cart sized compression brakes, think they'll hold ok. Gordon Bowen Original Message: ----------------- From: Wizzard187(at)aol.com Date: Sat, 26 Feb 2005 17:34:50 EST Subject: Pietenpol-List: Re: Pietenpol-brake fluid Pieters, What is the best brake fluid to use. The aircraft red stuff or the silicone that is out now. I am using aircraft parts that are now empty. Ken again in not so warm Iowa but good for Feb. ________________________________________________________________________________
Date: Feb 27, 2005
Sure looks purty, Corky Jack Finishing the last of the structural repairs to NX899JP today - then on to fabric work -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Isablcorky(at)aol.com christinedigsjazz(at)shaw.ca; wayfollower(at)cox.net; T_FIN(at)Compuserve.com; glevy1(at)cox.net; IFlyTigers(at)aol.com; LCJELKS(at)aol.com; JimNikls(at)aol.com Subject: Pietenpol-List: Another building level reached Pieters and friends, Ole Corky hasn't been too idle these winter months. Today I completed assembley of the major parts following a major overhaul of the Continental A-65 engine which will power Repiet NX311CC sometime in 05. An engine mechanic EARNS every nickel he charges. Corky and Isabelle livin the good life in warm Louisiana ________________________________________________________________________________
Date: Feb 28, 2005
Subject: Rib-testing
Hey guys, It's been a while since I posted, but I just wanted to exit lurking mode and chime in on my highly unscientific version of rib-testing. I made up a test rib, and let it cure for a few days. Next, I propped the rib up between the workbench and my step stool. I then lifted myself up on my hands holding onto the bench and ladder and placed one foot onto the rib. I gradually let the rib take my weight until I had probably 70 - 80% of my weight on that rib!! Now, I'm about 230 on the hoof, so I figure that rib was holding up a ballpark of between 160 to 185 pounds!!! I was amazed at how strong those things are!! Anyway, I then did the math - 30 ribs * 170# and came up with around 5000# - good enough for me!! Even if I guessed way wrong, that rib was still holding an incredible amount of weight when compared to how much IT weighs. Kinda like an ant!! To do a more accurate test, I guess I could have place the rib on a board on a bathroom scale, but all it was for was to bolster my confidence in the rib design, material and my own building technique and it worked!!! By the way, I made one rib per night and let the one side cure, then the next day, glued on the opposite side gussetts and made a new on in the jig. It was slow, but I was working tail feathers too, so it was fine. I also had trouble with the ribs not holding their shape out of the jig. I suspect my capstrip bending wasn't thourough enough. Now, I'll go back into stealth mode and get back to work, waiting to get home and into the garage to get back to work on the Piet!! Gary Meadows Spring, TX ________________________________________________________________________________
Date: Feb 28, 2005
Subject: Throttle quadrant plans
Hello to all in the group: Does anyone have plans for a throttle quadrant like these? I don't want/need anything fancy. I can build one from scratch from these pictures, but, I don't know how long to make the "throw & pivot points". These two examples seem to be very different in their geometry. I don't know what would be best with a continental 75 engine/carburetor. This is just a shot in the dark, but I thought I would ask anyhow. Thanks in advance, and happy building/flying, Max Davis Arlington, TX. NX101XW (We now have an official N number, very exciting!) (http://mykitplane.com/Planes/photoDisplay.cfm?PhotoName=DSCF0007a.JPG&PhotoID=2291) ________________________________________________________________________________
Date: Feb 28, 2005
Subject: Re: Throttle quadrant plans
Max, I remember a comment by my DAR. He said to make the throw on the quad larger than the needed movement of the throttle arm. Corky who can't remember too much lately ________________________________________________________________________________
Date: Feb 28, 2005
Good to see you back on the list Gary...It has been a long time..I made my ribs the same way, let the top gussets cure overnight then pulled the rib out of the jig and put the gussetts on the flip side and do the first side of a new rib each day. They came out great and there is no detectable difference between any of them.I lined my rib jig with plastic grocery bags cut down each side..They protected the rib jig and most of the plastic would peel off the T-88..the rest I just sanded off .. I would lay up a rib then go work on some other part of my Piet...If you're patient it works great...Ed G. >From: Gary W Meadows <garymead(at)swbell.net> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Rib-testing >Date: Mon, 28 Feb 2005 06:41:56 -0800 (PST) > >Hey guys, > > It's been a while since I posted, but I just wanted to exit lurking mode >and chime in on my highly unscientific version of rib-testing. I made up a >test rib, and let it cure for a few days. Next, I propped the rib up >between the workbench and my step stool. I then lifted myself up on my >hands holding onto the bench and ladder and placed one foot onto the rib. I >gradually let the rib take my weight until I had probably 70 - 80% of my >weight on that rib!! Now, I'm about 230 on the hoof, so I figure that rib >was holding up a ballpark of between 160 to 185 pounds!!! I was amazed at >how strong those things are!! Anyway, I then did the math - 30 ribs * 170# >and came up with around 5000# - good enough for me!! Even if I guessed way >wrong, that rib was still holding an incredible amount of weight when >compared to how much IT weighs. Kinda like an ant!! > > To do a more accurate test, I guess I could have place the rib on a board >on a bathroom scale, but all it was for was to bolster my confidence in the >rib design, material and my own building technique and it worked!!! > > By the way, I made one rib per night and let the one side cure, then the >next day, glued on the opposite side gussetts and made a new on in the jig. >It was slow, but I was working tail feathers too, so it was fine. I also >had trouble with the ribs not holding their shape out of the jig. I suspect >my capstrip bending wasn't thourough enough. > > Now, I'll go back into stealth mode and get back to work, waiting to get >home and into the garage to get back to work on the Piet!! > > Gary Meadows > Spring, TX ________________________________________________________________________________
Date: Feb 28, 2005
I=A1=AFll look tonight and thry to make some measurements off mine. I have an A65 Continental. It=A1=AFs basic geometry to design your own. You need to know the circmferential distance you need the cable to provide at the carburetor. Measure the distance from the pivot point of the thrrottle arm on the carb to the point where your bugnut will be attached (call this dimentions =A1=B0r=A1=B1 for radius. Now measure the number of degrees the throttle arm needs to move to go from idle stop to full throttle (use your kid=A1=AFs elementary school protracter). Now divide this number (it=A1=AFll be somewhere around 45 =A2=AA) by 57.30 to convert it to radians (don=A1=AFt worry about what that means, just do it) and multiply that number by what you got for =A1=B0r=A1=B1 above. This is the linear distance the throttle cable needs to provide. Now for the cockpit end. Your throttle quadrant needs to produce this amount of linear travel, plus a little bit more, as Corky so wisely suggested. The reason for this is to make the stops at the carburetor, not in your quadrant. Otherwise you will not be able to quite get full throttle (increases pucker factor on takeoff) or quite get down to idle (which can cause some high speed taxiing, especially downhill and downwind). Here you=A1=AFve got a little discretion. I suggest you go sit in some other airplanes and see how they feel, then measure their quadrants. I copied mine from a J-3 Cub, because I used to own one and thought its throttle felt fine. You=A1=AFve got two paraemters you can play with - the radius (length) of your throttle lever, and its throw, or angular sweep. The longer the radius, the less angle it needs to sweep through to get the same cable movement. The formula is Radius x Angle (in degrees, divided by 57.30 to convert to radians) linear cable movement, which should be maybe =A8=F9=A1=B1 more than the cable movement required by the carburetor. As to how long to make your throttle quadrant lever, that is a matter of personal preference. Obviously, it needs to be at least as long as the Radius you just determined, but how much longer is up to you. One other thing to watch out for - your cable needs to be solidly attached to structure near the attach points for both the quadrant and the carburetor. Otherwise, some of your quadrant movement will just go into bending the entire cable, housing and all. Good luck, Jack Still working to repair NX899JP in time to fly it to Brodhead this summer -----Original Message----- Does anyone have plans for a throttle quadrant like these? I don't want/need anything fancy. I can build one from scratch from these pictures, but, I don't know how long to make the "throw & pivot points". These two examples seem to be very different in their geometry. I don't know what would be best with a continental 75 engine/carburetor. This is just a shot in the dark, but I thought I would ask anyhow. Thanks in advance, and happy building/flying, Max Davis ________________________________________________________________________________
Date: Mar 01, 2005
I obviously didn't make the quadrant that's on 41CC (Corky did), but I've made others. I found that if I played around at the workbench with some junk materials like plywood and scrap metal to make a mock-up, it's easier and more satisfying to work out the stroke, travel, and proportions of the lever than if you sat down and worked out the trigonometry or drew it up in CAD. If you don't like the throw or travel, you just punch a new pivot point and try that, or cut out a longer handle and try that. Grab whatever is handy and start experimenting. I have a box of miscellaneous hardware that I've picked up from jobsites and parking lots over many years, and I'm sure all of you do too- so I work out of that and my scrap bin to do test fits of things, then fabricate the final item using "real" stuff. We don't need no stinkin' plans (and I'm an engineer!!) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 01, 2005
Max Hey man. I must apologize for not getting back to you about the throttle plans. I have been covered up at work and home projects and barely get time to check my email lately. excuses...excuses... Lon built the throttle pictured for our pietenpol. It is straight from the Hatz plans. I will try to scan it soon if I can get his plans from him. There are some phenolic washers used for a friction adjustment. Anyway... keep after me and I will get it for you. Terry -- Terry L. Bowden ph 254-715-4773 fax 254-853-3805 ________________________________________________________________________________
Date: Mar 01, 2005
Subject: Re: tenpol-List:fuel pressure
Pieters: I have a J3 cub gas tank in the front of my piet with a 75 hp cont engine and have been running the engine but it craps out when I add throttle. The books say you should have 1/2 lbs of pressure (19 inches) of head. I can't see how a j3 cub has ever had this much. With just two gal of gas I have about 6 inches when sitting with the tail wheel down and my motor cycle wheels on. I am going to put a 90 degree tube in my gas cap to get some prop blast and wonder if this will do any good. I have had three different carbs on and they all act the same. Still looking for a counter clockwise tach. Has anyone used one of the new electronic tach on a mag that they really like. Ken Conrad, Long Grove Iowa ________________________________________________________________________________
Subject: tenpol-List:fuel pressure
Date: Mar 01, 2005
Hi Ken, The J-3 had the tank sitting a little higher than a Piet does, in relation to the carburetor. Still, you should be all right. Have you measured the fuel flow by taking the fuel line off at the carburetor and time running the fuel into a bucket? I don't know what an A75 burns, probably a little over 4 gals per hour. You need at least 150% of that available, so you should be getting at least 6 gals per hour, or a gallon every ten minutes through your fuel system. Before going to the trouble of putting the 90 degree tube on your fuel cap, just try it with the fuel cap off - that will tell you if you have a venting problem. If it craps out immediately when you add throttle, it is not a fuel flow problem because the float chamber (if full) will provide enough fuel for at least 5 - 10 seconds of full throttle operation. Might be a mixture problem. Do you know for sure you have the correct jet in the carburetor? Do you know if the float level is set crrectly? This critical (assuming you have a Stromberg). Jack Phillips, PE Sr. Manager, Disposables Product Development Clinical Technologies and Services Cardinal Health Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Wizzard187(at)aol.com Subject: Re: Pietenpol-List:fuel pressure Pieters: I have a J3 cub gas tank in the front of my piet with a 75 hp cont engine and have been running the engine but it craps out when I add throttle. The books say you should have 1/2 lbs of pressure (19 inches) of head. I can't see how a j3 cub has ever had this much. With just two gal of gas I have about 6 inches when sitting with the tail wheel down and my motor cycle wheels on. I am going to put a 90 degree tube in my gas cap to get some prop blast and wonder if this will do any good. I have had three different carbs on and they all act the same. Still looking for a counter clockwise tach. Has anyone used one of the new electronic tach on a mag that they really like. Ken Conrad, Long Grove Iowa ________________________________________________________________________________
Date: Mar 01, 2005
Ken, Sound like the problem I had when first setting up the idle mixture screw on my Stromberg (assuming that's what you have.) Since the carb doesn't have an accelerator pump . (65 year old equiptment) Had to keep messing with the screw till I got way to the rich end of idling good. Even now it may stumble if the throttle is pushed forward too fast. walt evans NX140DL ----- Original Message ----- From: Wizzard187(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, March 01, 2005 4:09 PM Subject: Re: Pietenpol-List:fuel pressure Pieters: I have a J3 cub gas tank in the front of my piet with a 75 hp cont engine and have been running the engine but it craps out when I add throttle. The books say you should have 1/2 lbs of pressure (19 inches) of head. I can't see how a j3 cub has ever had this much. With just two gal of gas I have about 6 inches when sitting with the tail wheel down and my motor cycle wheels on. I am going to put a 90 degree tube in my gas cap to get some prop blast and wonder if this will do any good. I have had three different carbs on and they all act the same. Still looking for a counter clockwise tach. Has anyone used one of the new electronic tach on a mag that they really like. Ken Conrad, Long Grove Iowa ________________________________________________________________________________
Date: Mar 01, 2005
Subject: Firewall
My Piet's basic fuselage structure is finished and I'm writing to ask about the firewall. What do most Pieters cover their firewall with, i.e. I assume steel or aluminum? Do you put some of that fireproof fabric in between the metal and the plywood firewall bulkhead? I'm building a Model A powered Piet so mine also has the "shelf" area behind the engine...would appreciate any advice. Many thanks! Fred B. ________________________________________________________________________________
Date: Mar 01, 2005
Does it change when you raise the tail? Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: Wizzard187(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, March 01, 2005 3:09 PM Subject: Re: Pietenpol-List:fuel pressure Pieters: I have a J3 cub gas tank in the front of my piet with a 75 hp cont engine and have been running the engine but it craps out when I add throttle. The books say you should have 1/2 lbs of pressure (19 inches) of head. I can't see how a j3 cub has ever had this much. With just two gal of gas I have about 6 inches when sitting with the tail wheel down and my motor cycle wheels on. I am going to put a 90 degree tube in my gas cap to get some prop blast
February 01, 2005 - March 01, 2005
Pietenpol-Archive.digest.vol-ei
