Pietenpol-Archive.digest.vol-ej
March 01, 2005 - March 28, 2005
and wonder if this will do any good. I have had three different carbs on
and they all act the same.
Still looking for a counter clockwise tach. Has anyone used one of the new
electronic tach on a mag that they really like. Ken Conrad, Long Grove Iowa
Subject: | Lost Foam Gas Tank |
I'm going to build a gas tank for my center section using the lost foam
method. I'm savvy with fiberglass and epoxy but need some info about how to join
the foam parts. Is there a glue for joining the foam walls? And is it eaten away
when the foam is lost?
Roy
Stainless or galvanized steel works well. Aluminum is a no,no! Putting fibra-flax
between the steel and the wood is also recommended. You used to be able to
use asbestos to prevent the heat transfer from the steel to the wood but that
is not PC anymore.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
----- Original Message -----
To: pietenpol-list(at)matronics.com
Sent: Tuesday, March 01, 2005 6:05 PM
Subject: Pietenpol-List: Firewall
My Piet's basic fuselage structure is finished and I'm writing to ask about the
firewall. What do most Pieters cover their firewall with, i.e. I assume steel
or aluminum? Do you put some of that fireproof fabric in between the metal
and the plywood firewall bulkhead? I'm building a Model A powered Piet so mine
also has the "shelf" area behind the engine...would appreciate any advice.
Many thanks!
Fred B.
You can't use aluminum the FAA won't accept it. It has to low melting point.
I used stainless steel that I engin turned. It looks pretty good.
Gal steel wil work and the FAA will accept it.
Dale Mpls,
or aluminum? Do you put some of that fireproof fabric in between the metal and
the plywood firewall bulkhead? I'm building a Model A powered Piet so mine also
Many thanks!
Fred B.
DNA: do not archive
Its-Bogus: do not forward to list
--- MIME Errors ---
A message with no text/plain section was received.
The entire body of the message was removed. Please
resend the email using plaintext formatting.
NOTE! This error can also occur when the poster of the
message has a specific type of computer virus. This virus
WAS NOT forwarded on to the List. The poster should be
informed of the potential problem with their system as soon
as possible.
--- MIME Errors ---
DNA: do not archive
--- MIME Errors ---
as possible.
--- MIME Errors ---
Subject: | Re: cabane struts |
Cabanes are the talk of the group lately
I used Carlson Aircraft aluminum struts. www.sky-tek.com
About 75% cheaper than 4130 with only a small penalty in weight.
DJ Vegh
www.imagedv.com/aircamper
N74DV
Sent: Wednesday, March 02, 2005 8:14 AM
Subject: Pietenpol-List: cabane struts
How many guys have used the steel streamlined tubing from Aircraft Spruce (or
from Wicks) for the cabane struts? This is the stuff that is rather expensive
now.
Jeff in cool Texas
Forums. http://www.matronics.com/contribution
From: | "Phillips, Jack" <jphillip(at)alarismed.com> |
That's what I used, but I bought it from Dillsburg. Much cheaper and
much faster service.
Jack
-----Original Message-----
Spruce (or from Wicks) for the cabane struts? This is the stuff that is
rather expensive now.
Jeff in cool Texas
see
Matronics
Forums.
DNA: do not archive
--- MIME Errors ---
as possible.
--- MIME Errors ---
From: | "Jim Markle" <jim_markle(at)mindspring.com> |
Why not laminate your cabanes from wood (I used light maple and mahoghany) and
sandwich in some carbon fiber? Incredibly light (mine are around 12-15 ounces
each) and strong.
Someone once did the math and said each of the 4 cabanes on the typical Air Camper
(if there IS such a thing....) only had about 50 pounds of lift (tension)
to handle. I don't know how accurate that is, but a 1" X 2" wooden cabane (even
without the carbon fiber inlay) will easily handle that.....
Just a thought....
JM
(I have a set I made from black walnut/maple (doesn't everyone build 3 sets of
everything before they have the one they'll use????) that I'll probably take to
Brodhead this summer.......)
Sent: Wednesday, March 02, 2005 10:11 AM
Subject: RE: Pietenpol-List: cabane struts
That's what I used, but I bought it from Dillsburg. Much cheaper and much faster
service.
Jack
now.
Jeff in cool Texas
it's most certainly more than 50#. I did the calcs a while back when I bought
my aluminum struts. I came up to a few hundred pounds at 1G (remember they
are at about a 60=B0 angle)
If planning for a +5G load you're looking at over 1,000#
Still... wood works and looks cool too.... so long as they are built right... especially
the ends.
DJ
Sent: Wednesday, March 02, 2005 11:06 AM
Subject: Re: Pietenpol-List: cabane struts
each) and strong.
Just a thought....
JM
to Brodhead this summer.......)
faster service.
Jack
now.
Jeff in cool Texas
<001001c51f60$668411e0$0564a8c0@rdci.az.home.com>
Cabanes...not lift struts....yes, agreed, the lift struts are MUCH more than 50
pounds.....
Sent: Wednesday, March 02, 2005 1:45 PM
especially the ends.
DJ
and sandwich in some carbon fiber? Incredibly light (mine are around 12-15 ounces
each) and strong.
Camper (if there IS such a thing....) only had about 50 pounds of lift (tension)
(even without the carbon fiber inlay) will easily handle that.....
Just a thought....
JM
of everything before they have the one they'll use????) that I'll probably take
faster service.
Jack
(or from Wicks) for the cabane struts? This is the stuff that is rather expensive
now.
Jeff in cool Texas
DJ -
I think you are talking Lift struts, while Jim is talking Cabanes. The cabanes
see very little lift load in flight - essentially just whatever lift the centersection
develops because the lift struts attach at almost the center of the
main wing panels and carry virtually all the lift loads generated by the wings.
However, the roll wires put a considerable compression load on the cabanes,
and any rolling maneuvers put loads on them eiither tensile or compressive, depending
one which side of the airplane and which direction it is rolling.
I can also tell you from personal experience - when you are making a forced landing
and hit a dirt bank with the wingtip, the centersection and cabane struts
do feel some stress. My roll wires are now slack on one side from the fittings
at the top of the cabanes bending due to the load imposed on them. I'm going
to have to straighten those fittings as part of the rebuild of NX899JP. Having
finally assessed all the damage incurred, I can truthfully say, this is a
STOUT airframe. I would hate to think what this repair would have cost to a
Cessna. As it is, I'm getting it back in the air for somewhere around $1,000
and $475 of that is in heat treating the new axle.
Jack Phillips
Raleigh, NC
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of DJ Vegh
the ends.
DJ
From: Jim <mailto:jim_markle(at)mindspring.com> Markle
each) and strong.
Just a thought....
JM
From: Phillips, <mailto:jphillip(at)alarismed.com> Jack
service.
Jack
How many guys have used the steel streamlined tubing from Aircraft Spruce (or from
Wicks) for the cabane struts? This is the stuff that is rather expensive now.
Jeff in cool Texas
<000e01c51f61$ddba25a0$9202010a@FAMILY>
ooops my bad
DJ
Sent: Wednesday, March 02, 2005 12:56 PM
50 pounds.....
they are at about a 60=B0 angle)
DJ
ounces each) and strong.
Just a thought....
JM
take to Brodhead this summer.......)
faster service.
Jack
now.
Jeff in cool Texas
From: | "Dan Loegering" <danl(at)odayequipment.com> |
Getting ready to purchase some wood and start cutting. I have decided to start
on the wing ribs as my first project and was wondering if anyone out there has
a rough guestimate on how much T-88 I should start out with? Would a quart
kit suffice, or should I go for the 1/2 gallon right off the bat... Now just
waiting for the plans to show up!
Dan Loegering
Fargo, ND
Dan, I went for the smaller bottles, it makes it easier to handle and
keeps it fresh.
Jack Textor
Subject: | Re: Glue question |
Dan, I went with the quart bottles. The stuff goes
pretty quickly, but not so much on the ribs. They are
also easier to handle. I'm on my 4th set now. There
is a tip I found very helpful in dispensing the stuff.
I bought some 2 ton epoxy from Walmart ($1.97 each)
and when I used the glue and emptied the syringes the
stuff comes in, I cleaned the syringes out with
acetone real well and then dried them with a clean
cloth inside and then fill them with the T-88. I used
several of them at one time. This makes dispensing
the glue (1:1) real easy. I also used the blister
pack (and every blister pack I could get my hands on)
to mix the stuff. Hope this helps. I also made my
glue sticks out of short pieces of capstrip sanded
down on the bench sander to a chisel shape. This
worked real well in spreading the glue.
Doc
> should start out with? Would a quart kit suffice,
> bat...
> Dan Loegering
> Fargo, ND
> Contributions
> any other
> Forums.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
> http://www.matronics.com/photoshare
http://birthday.yahoo.com/netrospective/
From: | "gbowen(at)ptialaska.net" <gbowen(at)ptialaska.net> |
I use hot melt glue to hold the various foam blocks together. You can hot
wire cut or hand shape the blocks. The glue will dissolve just like the
polystryrene foam with a solvent wash after you've cut the mold apart, for
rebonding.
Gordon Bowen
Subject: | Fiberglass Gas Tank Question |
A good tight weave like 7781 will make a good tank, plus it's a satin weave
which makes the compound curves and corners more easily formed. I think
any epoxy will work, but Derakane (epoxy based vinyl ester) has a better
chemical resistance plus you work it just like polyester or bondo, (just
add a dab of mek peroxide to the resin) it kicks off fast. EZ-Poxy 10 plus
EZ-83 hardener has a track record of over 35 years usage as a glass/epoxy
gas tank in canard-pusher Rutan type aircraft.
Gordon Bowen
Dan,
I would go with the quart kit. T-88 does have a shelf life, in as much as
after awhile the clear (not amber) does start to thicken.
I only used 2 quart kits for my Piet.
I didn't like to waste (even though all my joints had a nice fillet at the
connecting pieces)
The best way to mix T-88 is on a saucer. Cut the nozzles with the same size
opening at the tip , and squeeze the same diameter bead , the same length
for both A&B. Guys waste alot by mixing in a cup. Only time I used a cup
was when I glued the ply to the fuse side or bottom, where you need lots of
glue.
Best application stick is a tongue depressor. Buy a package, or go to a
local pharmacy and get them for about a dime apiece.
Grab the round end in your teeth, about half way across, bite down , and
pull the other part away from your face. Now you have 2 applicater sticks.
Every time you're done using it, wipe off the tip. When it becomes "round"
on the end, throw it out.
(probably TMI, but I miss building)
walt evans
NX140DL
Subject: Pietenpol-List: Glue question
start on the wing ribs as my first project and was wondering if anyone out
there has a rough guestimate on how much T-88 I should start out with?
Would a quart kit suffice, or should I go for the 1/2 gallon right off the
bat... Now just waiting for the plans to show up!
> Dan Loegering
> Fargo, ND
In a message dated 3/1/2005 8:21:46 PM Central Standard Time,
ddjohn(at)earthlink.net writes:
FAA won't allow on a "certificated" airplane, but still a very bad idea on an
experimetal as well.
Subject: | Re: Fiberglass Gas Tank Question |
I'm using the West system and ordered my supplies from Aircraft Spruce. I'm
building one fuel tank (center section) using the lost foam method. A second
tank in the center section (smaller) will be used for baby oil so I can
out-smoke Chuck Gantzer. My fuselage tank will be built not from lost foam, but
from a
female (waxed) mold. I already had access to the gas tank mold and am too
lazy to build one from scratch for the center section tanks.
Subject: | Re: Lost Foam Gas Tank |
Gordon:
Many thanks for the tips on the tanks (not to be confused with tip tanks:)
Roy
Starting on the tanks tomorrow.
Dan,
I looked at prices and it was $25.00 for a quart or $75.00 for the gallon. That
seemed like a good saving so I went with the gallon.. Trouble was, it came
in two half gallon containers. Pouring from them to measure small quantities
was a pain. I have since ordered a quart and it comes in two pint containers.
Much better to pour and measure from.
Food for thought.
Alex Sloan
a
> rough guestimate on how much T-88 I should start out with? Would a quart kit
> Dan Loegering
> Fargo, ND
Dan,
That seemed like a good saving so I went with the gallon.. Trouble
was, it came in two half gallon containers. Pouring from them to measure
small quantities was a pain. I have since ordered a quart and it comes
in two pint containers. Much better to pour and measure from.
Food for thought.
Alex Sloan
One thing to keep in mind when using aluminum struts, is that aluminum is
much less forgiving than steel. Aluminum requires accurate holes, and NO nicks
or scratches. After put into service, nicks or scratches (stress risers) could
render the part unservicable, and un-airworthy. If a bolt should loosen up,
and woller out the hole slightly, the part is unservicable, and un-airworthy.
For these reasons, I strongly suggest the use of steel.
Chuck Gantzer
NX770CG
Smoke 'em, if ya got 'em !!
I have found that small plastic squeeze bottles (4 to 8 oz?) work very well.
The kind I use have a snap-on cap that is attached to the bottle so you
can't lose it.
I invested in a small digital scale (iBal 201) and mix the West System epoxy
by weight. These scales cost about $100, are used by ammo reloaders, and
weigh to .01 gram. They have a capacity of 200 grams. I typically only use 5
to 10 grams. Just put in the resin, get the weight, multiply by 1.2, and add
hardener up to that value. Its very accurate and repeatable for small
amounts. (I can't help it if I'm an engineer!)
BTW epoxy has a very long shelf life. Especially if you keep it sealed in
the can. By using the squeeze bottles, you don't have to open the can very
often.
Dan Hopper
Walton, IN
Subject: | Safety? Fiberglass gas tanks & Static Electricity |
I've successfully dissipated and prevented static electricity in photographic
labs for many years by mixing Downey Fabric Softener to water at a 50/50 mix,
and then spraying carpeted areas in and around the lab. Here in the
Southwest, on a cold-dry winter day, we can darned near arc weld with static after
walking around on a dry surface and many rolls of films have been ruined when
spooling film out of cassette in a darkroom. The static can bee seen on the film
after development. The Downey/water method nearly eliminates the ionic charge,
thus the reason your socks don't cling after coming out of the dryer when
treated with Downey. (Ask any woman who wears nylon stockings... Downey is a must
on man-made textiles.)
When fueling my Cherokee in the boondocks, I've also used my "formula" for
spraying down the surface of the wings, gas caps, my shoes and the area where I
stand when transferring the gas, prior to fueling an airplane with plastic
cans. (The cans are sprayed before fueling as well and allowed a minute or so to
dry... The back of the vehicle is also sprayed before loading a plastic can!
Try gassing an airplane at the landing strip in/at Wall Drug Store in South
Dakota... ain't gonna happen unless you go into town for mogas. Also, Custer's
Last Stand! No gas at the field, but a convenience store 1 mile away...
Sorry, but sometimes remote fueling is an evil necessity for us who live and
fly off of fields not having a fuel source, such as a ranch or in places in
the Dakotas That's why I always carried my small spray bottle of Downy/Water in
my airplane.
I'm more concerned about fiberglass gas tanks in my Pietenpol though.
Fiberglass makes for a great attractant for static electricity! I wonder if there
is
an additional way to enhance safety when adding gas to a wooden airplane
having fiberglass tanks? I'm about to build my fiberglass gas tank and I thought
of adding a small copper wire to the aluminum filler neck, then to the weldable
flange, running the wire down to a low spot on the fuselage where I could
connect to a ground source (probably a small copper shaft driven into the
ground...)
Obviously it's wise to AVOID using plastic cans for fueling an airplane, but
sometimes we don't have a choice.
Does anybody have any information about grounding tips and way to avoid
static when fueling a wooden airplane having a fiberglass tank in the boondocks?
Sterling Brooks
Knot-2-Shabby Airport & Texas Longhorn Cattle Ranch
I mixed on paper plates, but I've been collecting those polyethylene
lids that they use to cover oatmeal and other paper-cylinder containers
and I'm going to switch to them for the rest of the plane if they work
better, which I think they should. I would recommend some kind of
syringe for measuring (used plastic children's medicine type, one for
hardener and one for resin, which you can get at a Wal-Mart-type place);
with the equal-length-bead method you have to be careful that the beads
are exactly equal widths and I for one had a problem with that;
tongue-depressors or popsicle-sticks can be gotten at hobby shops, and
sand them down to get a pointed/straight edge for applying glue; Walt's
rip-with-the-teeth method sounds good too, with no sawdust residue
either. One mild caution: T-88 adheres a little bit to vinyl--I
covered my jig base with a clear vinyl sheet and some residue built up
over time at the sites with the heaviest glue, which needed a little
extra cleaning work when I removed the rib from the jig each time.
Mark Hodgson
From: | "Cory Emberson" <bootless(at)earthlink.net> |
Engines)
Subject: | Builder Feedback Requested for Kitplanes Magazine (Alternative |
Engines)
Hello everyone,
I've subscribed (quietly) to this list for a little more than a year, and
would like to hear from you if you're a builder who has successfully
installed and flown an alternative engine in your plane. I'm writing a
builder's roundup for Kitplanes magazine, and am looking for an installation
that's flown for a minimum of 150 hours, and is currently flying.
For the builders that we profile, the magazine will also be able to pay you
$100 for the write-up. We would also need at least 2-3 good photos,
including a close-up of the engine and an overall shot of the aircraft.
Additional photos would be great, and all photos will be returned. If you
have digital photos, it is very important that they be high-resolution, at
least 300 dpi.
I have a list of specific areas to address if you'd like to participate, but
we can handle that off-line.
Please feel free to contact me off-line at:
cory @ lightspeededit.com (remove the spaces - my anti-spam protection)
or reply offline to my list email address.
I have a rather short deadline, so if you're able to contact me as soon as
you're able, I would greatly appreciate it!
Thank you so much!
best,
Cory Emberson
Fiberglass/epoxy tanks have been used for over 30 yrs in Rutan type planes.
All the fuelers want to attach the grounding strap to any metal part of the
composite landing gear, (ain't gonna do a thing). So we canardians/aka
Pieties have exchanged 1000's of emails via the user group about how to
ground during fueling. The original plans for canard types calls for a
metal (like the kind you ground the engine with) woven strap, attached to
the fuel cap, dangled down into the fuel. You attach the ground wire from
the fueling station to it. It kinda sloshes around with the fuel while
you're in flight. Some builders have build into their laminates a ground
wire inside the tank surface that is in contact with the fuel, and also in
contact witht he filler ring/ and cap. I have a piece of Al cut about 3
in. on a side of triangle, connected to the fuel cap, with twisted wire.
This keeps contact with the fuel when the metal fuel nozzle keeps contact
with the filler ring on top of the tank. It is never recommended you fuel
a composite plane with plastic gas cans, but we've all done it. It's
recommended that you keep the fuel nozzle in contact with the fuel in the
tank. Incidentally, I've been around composite planes since Rutan flew his
first VariEze with our RAF epoxy system developed at Rezolin Chemical, I've
never heard of a composite plane catching fire during fueling due to
sparks, but coulda happened.
Gordon Bowen
From: | "John and Phyllis Smoyer" <jpsmoyer(at)verizon.net> |
Subject: | Installing elevator control horns |
The horns I'm talking about mount on the main and center beams of the elevators.
The plans seem to show the horn aligned parallel to the airplane center line.
However, because the horns are mounted some distance outboard of the airplane center
line, the control cables will connect to the horn at an angle of something
like (I'm guessing) 20 degrees or so. That means that the control force for
the elevator will exert a side load/bending moment on the horn, which will be
transferred into the bolts that hold the horn onto the elevator beams.
Is this a problem? Should I install the control horns at an angle, so that there
would be no side load? How have other builders installed this horn?
For sure, aligning the horns to eliminate the side load would turn them into the
airstream and create more drag than if the horn were aligned straight.
Thanks for your help.
John Smoyer
Subject: | Re: Installing elevator control horns |
I ran my horns at the same angle as the cables coming to them. I did not want
to be putting them in a side bending load.
DJ
Sent: Thursday, March 03, 2005 3:53 PM
Subject: Pietenpol-List: Installing elevator control horns
center line, the control cables will connect to the horn at an angle of something
for the elevator will exert a side load/bending moment on the horn, which will
be transferred into the bolts that hold the horn onto the elevator beams.
the airstream and create more drag than if the horn were aligned straight.
John Smoyer
From: | "Ben Charvet" <bcharvet(at)bellsouth.net> |
mock-ups for me).
Subject: | I've finally started building something that will fly |
(no more mock-ups for me).
Hi all,
I've been lurking in the background on this list for a few months now while studying
my plans, practicing my woodworking skills and getting my shop ready. Its
a long story but I built an entire fuselage mock-up with some lumber yard douglas
fir that I bought before I really knew what the recommendations were as
far as grain slope, etc. It didn't take all that long and I learned a lot of
things I'll do differently when I get the right materials.
I just started last weekend making wing ribs with wood (douglas fir) that meets
my expectations and I'm building a rib nearly every day. After cutting all the
parts out in advance I can now glue and nail one up in about an hour. I've
posted my progress so far at mykitplanes at the following link. I've posted
a few pictures there as well.
I've learned a lot just lurking in the background and from searching the archives.
There are three other Piets under construction within 40 miles of me so I
have lots of local sources of information too.
Here is my link
http://www.mykitplane.com/Planes/buildLogReport.cfm?PlaneID481&FNameBen&LNameCharvet&PlaneNameAir%20Camper
Ben
In a message dated 3/3/2005 4:55:10 PM Central Standard Time,
jpsmoyer(at)verizon.net writes:
Should I install the control horns at an angle, so that there would be no
John,
The horns should be installed at an angle, so there is no side load.
Chuck G.
temps in the mid 60's, and a SSW winds !!
Time to Kick the Tires, Twang the Wires, and Light the Fire !!
Subject: | Re: Safety? Fiberglass gas tanks & Static Electricity |
I'm carefully listening to this one...
I always wear safety glasses when re-fueling, and I always assume some static
discharge is going to occur, so I touch everything to ground, whenever
possible.
Gives me the Hiebie Jiebies every time !!
Chuck G.
Subject: | Re: flotation devices |
In a message dated 3/3/2005 9:26:36 AM Central Standard Time,
Michael.D.Cuy(at)grc.nasa.gov writes:
With my new drop tank and tip tanks I can carry 40 gallons which give me
about a 12
hour endurance time. About 800 air miles. I was thinking Houston to
Tampa direct,
non-stop, un-refueled.
Mike,
If you pull that one off, you will certainly win the 'Iron Butt' award !!
Chuck G.
I've done one 4hr leg, and three times I've done 3 1/2hr legs. After
landing, I had to sit there a few moments to allow all my bones to hook back up
Sent: Thursday, March 03, 2005 11:11 PM
Subject: Re: Pietenpol-List: Safety? Fiberglass gas tanks & Static Electricity
discharge is going to occur, so I touch everything to ground, whenever possible.
Chuck G.
The reason I posted this is from witnessing the aftermath of an actual fire.
When I was a news reporter for a TV station in El Paso, I saw a guy burned and
disfigured on one of the thousands of hard-news stories I covered in my
career. El Paso is a dry desert climate, great place for making static electricity
on a cool day. The fellow was a go-carter and he hauled gas in a plastic can
in the back of his pickup. To compound matters, his truck bed was lined in
Astro Turf. The fire investigator theorized that when the victim slid his plastic
gas can into and out of the pickup bed, it helped induce a static buildup in
the plastic gas can. (Kind of like when you rub a small rubber balloon on your
shirt, the resultant static makes it stick to you.) The go-cart was hauled on
a small trailer. He unloaded it, slid the plastic gas can on the Astro Turf
and during the fueling stage, KABOOM. Luckily, nobody else was hurt and he was
fueling in a sandy area where nothing else caught on fire, but the gocarter got
a new physical identity! No hair and 3rd degree burns to his hands, arms and
face.
I'm buying 15 feet of 1/8th inch copper grounding wire to install in both of
my fiberglass tanks, then running down to the bottom of the fuselage to the
juncture of the landing gear. Maybe this way, I can ground the airplane in a way
similar to how FBOs fuel spam cans.
One other lesson from my days as a news reporter. I saw a man who was killed
when shrapnel tore him to shreds. He was blown to bits from the explosion of
an air compressor tank. I suspect the tank had built up rust and was
compromised because someone was failing not to do a daily water drain of the tank
as
mandated by OSHA in work setting. I religiously drain the air tank on my air
compressors after using them, after seeing a dead man who looked like
hamburger--killed by an exploding air tank.
Sterling Brooks
Hi listers,
This doesn't apply to just fiberglass tanks, but to any use of plastic
around gasoline.
I'm one of those guys who uses plastic gas cans. I use them to fill my lawn
mowers in the summertime. I used them to refuel my C-150 with a plastic
funnel. I still would, except that I have sold it.
Now I happen to be an electrical engineer, also. I have worked a lot with
MOS devices which are very static sensitive. We had to work at a grounded
workbench with a wrist strap, etc. Working in a static sensitive environment
has instilled in me some ways to reduce the risks associated with static
electricity.
Static electricity takes some time to drain away because plastic is a very
poor conductor of electricity. So move slowly. Set your can of fuel on a
ladder, etc., near where you are going to pour it from, and wait a while. While
you are waiting, blow your breath across the can, funnel, and tank to drain
away the static electricity. The moist air makes the surface of the plastic
more conductive. When you are ready to refuel, use your body to bring the
fuel can to the same voltage as the plane before opening either fuel cap. That
is, touch both at the same time. If you have a metal ground system (like
the engine or landing gear), touch it too. If there is a spark, it should jump
during this time. After the spark jumps (or doesn't jump) the likelihood of
igniting a fire is very low. Now, without making any unnecessary movements,
open the caps and pour the gas.
For what its worth: gasoline is a non-conductor, and as far as I know
doesn't build up a static charge itself. The charge will be on the surface of
the
plastic pieces. I don't think its the gas you're trying to discharge, its
the tank, can and funnel. But, I'm not positive about this, so do what the
glass plane people have found that works -- which I've read in earlier posts.
The post about fabric anti-static spray was especially good. (Sorry, I don't
remember who that was.)
Dry climates are of course the worst. There have been numerous refueling
fires at gas stations. These are usually due to people sliding across the seat
of their car in cold dry weather which builds up a static charge on their
clothing. Its a good idea to touch the car body when you get out, and again
when you have the metal of the fuel nozzle in the other hand. This discharges
everything to ground potential. If the person stays statically charged, then
discharges at just the wrong time, the gas fumes can ignite. A Google
search will find some of these cases.
OK, now you know some ways to reduce the risk. Its pretty hard to be
perfectly safe around something with as much energy content as gasoline. All
in
all, its a pretty safe way to store energy. Look at the millions of cars on
the road, and every one of them has a bomb on board!
Dan Hopper
Walton, IN
John,
I'm built from the plan that is dated 3-23-33. and that drawing shows them on
an angle. It's kind of an optical illusion tho. lay a ruler thru the centerline
of the horn on the drawing and it will stand out.
walt evans
NX140DL
Sent: Thursday, March 03, 2005 5:53 PM
John Smoyer
will
fly (no more mock-ups for me).
Subject: | Re: I've finally started building something that will |
<000a01c5204d$c7aab030$0100a8c0@Desktop>
<009a01c52066$7ad10980$6501a8c0@benslaptop>
Ben,
Nice site and looks like a good start to a great project.
Good luck! You're gonna love it.
walt evans
NX140DL
Sent: Thursday, March 03, 2005 10:01 PM
Subject: Pietenpol-List: I've finally started building something that will fly
Hi all,
Its a long story but I built an entire fuselage mock-up with some lumber yard
douglas fir that I bought before I really knew what the recommendations were
as far as grain slope, etc. It didn't take all that long and I learned a lot
of things I'll do differently when I get the right materials.
the parts out in advance I can now glue and nail one up in about an hour. I've
I have lots of local sources of information too.
Here is my link
Ben
With Oshkosh opening on a Monday, July 25, will the Piet Gathering at
Brodhead be on the 22nd, 23rd and 24th of July?
And what are the dates for the Fall Fly-In?
Thanks, RF
Yep, July 22 and 23 will be the best days to be there.
Skip, still working on the hangar in WV
> Thanks, RF
Is there anyone on the list that has been doing spins in the Peitenpol?
I have let ours go around about 1/2 a turn and it seems to recover
almost by itself.
My CG is about 19".
Craig
Subject: | continental engine/carburetor |
A week or so ago someone posted about there continental engine seeming to
run out of fuel at full throttle. Yesterday I encountered the same thing I
think while doing full throttle tests tied down. The engine would rev up to
2150 rpm and after a few seconds would go lean and basically quit. If you
closed the throttle quickly you could catch it before it died. I have the
Stromberg carb with the new delrin needle and the fuel was set to about 3/8
to 1/2" below the edge of the bowl. Upon examination I noticed that the
back edge of the float was coming about 1/16 to 3/32" above the bowl and I
suspected that it was running into the float stop above it. I removed the
float and ground off 1/16" back by the new soldered on counter weight for
the Delrin needle. Reassembled the carb. Now the engine pulls to 2150rpm
static for 5 minutes with a 1/4 tank of fuel. Hope this helps someone else.
C-IDVW is now ready for taxi tests, soon for first flight.
Les
Subject: | Re: continental engine/carburetor |
Les, Thanks for your imput. I am going to open up the carb (stromberg)
today and look things over. I have had three different carbs on and they all
do
the same thing. I have plenty of fuel flow to the carb, When I frst start
it up it seems to get into the higher rpms which might be bowl gas but then
dies unless I just idle. I have parts ordered for a marvel Shebler
(venturi) but are slow in coming if they do. Thanks again Ken Conrad in warm
Iowa
(50)
Subject: | Re: Piets and spins |
I used to do spins in the Ford powered Piets all the time...I once spun down
from 5000 feet to 1000 feet over White Bear Lake...lost track of the turns.
Make sure the CG is not aft of 20 inches, and be carefull if the airplane is a
short fuselage model with a lighter engine up front...usually these ships have
the wing moved back, making the nose quite long, and usually the landing gear
is covered, compounding the problem of too much area out front. Bernard
never wanted us to cover the gear legs unless the airplane had a long fuselage,
for better spin recovery.
Forrest Lovley
The non-metal needle has been suspected of causing problems in the Stromberg
carb when auto-gas is used. The additives MTBE and TAME seem to affect (swell)
the needle. This has not seemed to be a problem when using aviation gasoline
(100LL) having a greater purity and far less additives.
I through away my plastic needle and went with steel.
Being into WW-I aircraft and guns as well as getting on the web on several other
topics (the kinds of things that draw engineers) you should be forewarned that
the ATF and FBI really DO watch for key words in e-mailed and when ordering
materials. One that draws attention really fast is precision scales (great for
mixing explosives and drugs). Don't be surprised or upset if you find yourself
answering a knock at the door from someone yelling "ATF!, open the door!"
and by all means remember, it is NOT a delivery! ;-)
Hank
Sent: Thursday, March 03, 2005 8:00 AM
Subject: Re: Pietenpol-List: Glue question
The kind I use have a snap-on cap that is attached to the bottle so you can't
lose it.
by weight. These scales cost about $100, are used by ammo reloaders, and weigh
to .01 gram. They have a capacity of 200 grams. I typically only use 5 to
10 grams. Just put in the resin, get the weight, multiply by 1.2, and add hardener
up to that value. Its very accurate and repeatable for small amounts.
BTW epoxy has a very long shelf life. Especially if you keep it sealed in the
can. By using the squeeze bottles, you don't have to open the can very often.
Dan Hopper
Walton, IN
Why not add a piece of stainless welding rod to your glass tank when you build
it running from the low point to a spot a couple of inches from the filler cap
so it would come through the covering? Label the end of the wire as the tank
ground and clip to the protruding wire when you refuel (BEFORE you remove the
cap!).
On the plastic fuel cans I designed a grounding kit a few years ago that used an
R/C model fuel stopper with a piece of stainless welding rod through it that
was put through a hole drilled in the plastic can and tightened. The rubber
stopper expands in the hole when you tighten the screw and the SS wire is submerged
in the fuel. If the wire is bent so it goes close to the outlet hole it
stays submerged when pouring. Just ground the can to the fuel tank ground and
on to "earth" and you should be all set.
Hank J
Sent: Thursday, March 03, 2005 9:19 AM
Subject: Pietenpol-List: Safety? Fiberglass gas tanks & Static Electricity
and then spraying carpeted areas in and around the lab. Here in the Southwest,
on a cold-dry winter day, we can darned near arc weld with static after walking
around on a dry surface and many rolls of films have been ruined when spooling
film out of cassette in a darkroom. The static can bee seen on the film after
thus the reason your socks don't cling after coming out of the dryer when treated
When fueling my Cherokee in the boondocks, I've also used my "formula" for spraying
stand when transferring the gas, prior to fueling an airplane with plastic cans.
dry... The back of the vehicle is also sprayed before loading a plastic can! Try
gassing an airplane at the landing strip in/at Wall Drug Store in South Dakota...
ain't gonna happen unless you go into town for mogas. Also, Custer's Last
fly off of fields not having a fuel source, such as a ranch or in places in the
my airplane.
I'm more concerned about fiberglass gas tanks in my Pietenpol though. Fiberglass
makes for a great attractant for static electricity! I wonder if there is
an additional way to enhance safety when adding gas to a wooden airplane having
fiberglass tanks? I'm about to build my fiberglass gas tank and I thought of
flange, running the wire down to a low spot on the fuselage where I could connect
to a ground source (probably a small copper shaft driven into the ground...)
Does anybody have any information about grounding tips and way to avoid static
Sterling Brooks
I dare not suggest a simple test like removing your tank filler cap and then
try reving up that 65. Might surprise you.
Corky in Louisiana enjoying the slower pace of life
Subject: | Re: Piets and spins, CG Stuff |
Oh soooo brave, to do spins in a Piete, it'd scare me to death.
On secondary subject of long fuselages and CG's. I just completed the CG
stuff on the rebuild of Piete N-1033B. This plane was built by Dick Greide
back in 1979 and crashed in a MO cornfield in 1996 on the way back from
Oshkosh, due to engine failure. Because the wings were off of an Aeronca
1300 payload, and Greide moved the wings back, longer 4130 fuselage, I
decided to utilize the full advantage of this planes payload abilities by
putting on an o-235 100 hp and shifting the CG as needed to fly my 280 lbs,
plus wife's 130 lbs. Had to move the pilot's rudder petals forward about 4"
due to 6'4" and long legs. It's a cozy fit by all measurement standards.
Here's how the numbers came out: LE of wing used as datum point.
1) gear axles 2"
2) empty CG 5.5" with wt of 680#
3) fuel at negative 12"
4) tail wheel at 161" (had wt of 14 lbs when longerons level, min fuel,
with full tank the bird will fall on nose without lead on tailwheel)
5) Passenger's front seat moment was 20"
6) Pilot's back seat moment was 53"
Using 20% of chord as forward CG min. limit or 12" back from datum, and 33%
of chord as aft loaded max. CG limit or 20". Trial (paper) loaded weight
and balance came out as follows: 1) 170# passenger, 300# pilot, 120 #
fuel. The initial takeoff CG was 17" behind LE, after burning off all but
about 2 gal of fuel, CG moved back to 19". Both in the operational window,
but wouldn't want to do a couple spins, pilot may wantta lose a couple Big
Macs too..
Minimum pilot weight without supplimental weights in tail or baggage rack
is about 150# with full fuel. This depends on the elevator's authority to
hold the nose up during flare
Max pilot weight with min. 2 fuel is about 305#. Moral of story, it is
possible to build a fat boy's Piete, hope this info is helpful for the
other couple non-FAA standard 170#'ers out there. Hope to be airborne next
week or two.
Gordon Bowen
In a message dated 3/6/2005 9:49:43 AM Central Standard Time,
gbowen(at)ptialaska.net writes:
Gordon,
If I read you e-mail correctly, you have wings off of an Aronca on your
Pietenpol. If this is true, then you CAN NOT use the 33% of chord as the aft
loaded max. The 33% aft limit (or as BHP listed it as 1/3 of the wing chord),
is
for the Pietenpol Airfoil...not the Aronca Airfoil. You MUST use the CG range
of the Aronca Airfoil, which probably has an aft limit of no more than 30%.
Loading in an aft CG range is where you will be in serious trouble if you enter
a spin. On several occasions I've seen Radio Controlled Model Planes spin
all the way to the ground, because they were intentionally loaded with an aft
CG, in an effort to attain a sensitive pitch control.
Chuck Gantzer
p.s. Arm X Weight = Moment
In a message dated 3/6/2005 9:44:50 AM Central Standard Time,
hjarrett(at)hroads.net writes:
Just DON'T make strafing runs at the local airport unless the FAA knows about
it first! Same goes for smoke systems in the exhaust.
True...Very True !!
On Friday evening, I was doing some 'Smoke Runs' around Cook Airfield, and
someone called the Fire Department, reporting a plane that was smoking, and
going to crash. Luckily, two airport guys were there when the Fire Department
showed up, and they pointed up at my plane as I flew past, and let them know
about my smoke system. I guess I'll have to let the Fire Department know when
I'll be 'Blowing Smoke' !!
Chuck G.
Subject: | Fuel cut-off valve |
Pieters,
Am to relocate my fuel valve from under tank, center. Does anyone know of any
rule, objection to locating this valve on the engine side of the firewall?
give me your thoughts on this subject, please
Corky
Subject: | Re: Fuel cut-off valve |
Normally, the fuel valve is NOT placed on the engine side. In case of fire, you
want to be able to turn is off. Fire will damage the valve and you might not
be able to turn it off so the tank continues to feed the fire.
Cy Galley
Always looking for ideas and articles for EAA Sport Pilot
Sent: Sunday, March 06, 2005 3:16 PM
Subject: Pietenpol-List: Fuel cut-off valve
Pieters,
rule, objection to locating this valve on the engine side of the firewall? give
Corky
Chuck,
I hope to never even approach within 2" of the aft limit on these wings,
for safety reason. But, the Aeronca has a straight constant chord of 60"
like most of the storebought tail draggers, and a lot of tricycle geared
planes. The limits of 33% of chord aft CG and 20% of chord forward CG
limit has nothing to do with Pietes or Aeroncas, these are standard
percentages used since the first Piper's and T-Crafts, due to the standard
shape of the wing. Look at any oldtime builders book, use to be available
from EAA bookstore, on how to build wooden homebuilt plane, these old books
always used the 33% and 20% rule of thumb numbers due to the shape and
chord of the wings they were building. Some designers recommended 32%,
like the Osprey, others like Rutan had other numbers due to the sweep of
wing and the constantly changing chord. For safety reasons, each
homebuilder (aka Test Pilot), has to understand CG limits and how to safely
experiment with their homebuilt wings and, if feasible, expand the safe CG
envelope.
The purpose of my prior email was to let a few of the other Big Mac
challenged potential builders/lurkers know, it's possible to build a
quasi-plans Piete that will safely handle their weights, if adequate
attention is paid to placement of stuff that affect CG. Plus moving the
wings LE back to approx. 18" behind the firewall.
Gordon Bowen
P.S. I stand corrected, I provided the approx. ARMS of the moveable stuff,
not moment. Also N-1033B has a GM starter motor hanging out there by the
prop and a 20lb battery between the passengers legs.
Actually, if all of us self styled engineers want to get it right...as
Bernard said, we are moving the fuselage forward, not the wing back...the wing
stays
right where it is.
Forrest Lovley
In a message dated 3/6/2005 4:22:50 PM Central Standard Time,
cgalley(at)qcbc.org writes:
you want to be able to turn is off. Fire will damage the valve and you might
not be able to turn it off so the tank continues to feed the fire.
Cy Galley
Pieters,
Corky
Corky,
I located my cable operated, 3/8" fuel shut-off ball valve on the engine
side of the firewall, before I realized that certified aircraft must be
located behind the firewall, for reasons stated by Cy. My reasoning was that I
didn't want any fuel connections in the cockpit, where leaks could possibly
develop. I now have a plan in the works to retrofit a stainless steel box
enclosure, to capture the fuel shut-off valve, and carry a drain in the box overboard,
to the belly. I cannot relocate the valve behind the firewall, because I
built a blister in the tank outlet, to protrude thru the firewall, where the
weldable fitting is glassed in. Any ideas about this retrofit would be greatly
appreciated.
This brings up another question about fire hazards...How much heat is
required for Baby Oil to burn ? I have the fiberglass smoke tank located on the
engine side of the firewall, however my exhaust pipes go down & aft slightly,
totally outside the cowling.
Chuck G.
needing a great deal of restraint, to keep from pushing the 'Smoke Button'.
In a message dated 3/6/2005 4:55:39 PM Central Standard Time,
Chuck,
envelope.
Gordon,
I wasn't aware of those other airfoils with 33% aft CG limits. I thought the
Pietenpol's undercambered airfoil could get away with it, because of such a
high negative pitching moment. A flat bottom airfoil does not have as much
negative pitching moment (nose down) as an undercambered airfoil.
Chuck G.
p.s. the Wittman Tailwind has somewhat of a semi-semetrical airfoil, and has
an aft CG limit of 28%.
Subject: | Re: EAA website down?? |
Has anyone tried to log onto the EAA website this
weekend? I have tried all day Sat and all day today
(Sunday)...no luck.
Also, if anyone of you have the FAA N number query
page stored as a "favorite"...would you try to use
that. I have been "denied access"....
All other websites I visit work fine so I don't think
it is my computer......
thanks in advance
Larry Nelson
Springfield, MO
Beechcraft Bonanza V-35B N2980A
Pietenpol Air Camper N444MH
1963 GMC 4106-1618
SV/ Spirit of America
ARS WB0JOT
Larry,
The EAA site is working fine for me. It looks like the FAA redesigned
their site, this link should get you to the N number lookup.
http://162.58.35.241/acdatabase/acmain.htm
Jim Lathrop
> (Sunday)...no luck.
Aaahhh!!!!!!!!! The 30's, Golden Age of Aviation and those with memories
thereof, when fuselages were swept forward rather than wings swept backward.
Forrest, didn't you make a posting a while back that you saw Bernie cut the
top out of a dope can for making metal tabs? If so, maybe you can answer a
question about his history and plans for wings. Question: The National
Advisory Commission for Aeronautics (NACA) issued it's Tech Rept. #460 in
1933, advising future aviators and builders of planes on the pros and cons
of 78 different airfoils. NACA had been around since 1915. Did Bernie's
wing design come from this original NACA windtunnel work? Thanks.
Gordon Bowen
Chuck,
I believe test pilots/Designers like Steve Wittman set CG design limits
after a tad of flying trial and error and he assummed the future buyers of
his plans actually built the plan to plans, which many did not. The test
pilot who flew Nat Puffer's Cozy (one of the first serious modification of
Rutan's proven designs), used a 20# chunk of lead within a slotted plastic
pipe in the passenger seat. Nat may have learned this trick from Mike
Melvil, Rutan's longterm crash test dummy and space cadet. The test pilot
could slide the chunk of lead backward and forward, inside the plastic
pipe, as needed to recover from tail heavy stalls.
By default each Pietenpol builder is a test pilot, and has to set design
limits for his or her unique aircraft. I saw one the other day on E-Bay
that used a T-Craft wing.
The % of chord CG limit rule of thumbs comes from the original testing done
by NACA in the 1930's, with windtunneling of 78 different wing shapes,
aspects, chord and camber designs. I think just about every modern day
straight wing, constant chord wing is referred to as a NACA wing. The
funny thing is, NACA didn't issue it's report #460 until 1933, a year after
Bernie introduced his wing design.
Gordon Bowen
I've been using the West System epoxy. I buy it in the quart cans and use
thier mini-pumps which are sized for the correct 5:1 mixture. One full stroke
of
resin, plus one full stroke of hardener equals the right mixture. If you need
more,, two or three full strokes of each. The key is to make sure you've got
the right pump in the right can. I use the plastic lids off the "new" plastic
coffee cans for mixing. I've used almost exactly one full quart can of resin
and it appears that I have 4/5 of a can of hardener remaining. Also found out
that the local boating place carries the West system. Check their Web site for
dealers in your area if you're inclined to use this glue.
I made a test joint, of course, and after a day of curing, could not break it
no-how. Gave it to my weight-lifter son who can squat 500 pounds as easily as
I can manage 50 lbs -- he couldn't break the joint! I concluded that the
stuff is airworthy. Of course, builders have been using it for years, too!
Was 57 degrees this past weekend -- back to the 30s today. Spring is nigh!
Fred B.
Mr Bowen...In my posting I stated that Bernard, (I absolutely NEVER said
Bernie.!!) used the tops of dope cans to make aileron and elevator horns, not
"tabs". The information on how he developed his airfoil from a Gottengen 397 is
written in his "How to Build" series in Popular Aviation during the thirties.
He knew that a commercially produced airplane that he had previously owned with
an undercambered airfoil got off the ground good, so he merely went ahead and
built a wing that way to try it out. I have no idea on whether he ever saw
the NACA Tech report #460. I also never stated that we were "sweeping" the
fuselage forward or back...I merely pointed out that when a Pietenpol is adjusted
to get the CG in the proper place, we are moving the weight of the fuselage
forward, not moving the wing back, to compensate for a lighter engine than the
Ford Model A.
Quite possibly, it's time for me to quit reading the postings on this
list, and get back to building...I think my old friend Bernard would like the
idea.
Forrest Lovley
Subject: | Really GREAT aviation story on History Channel! |
The First Flight Around the World, will air one more time on the History
time zone. Set your TIVO and record it. You'll be glad you did!
I just watched this program and was amazed at the story of American aviators
who in 1924 flew around the world in their open cockpit airplanes. Four
American airplanes attempted the trip and only 2 made it, beating the French,
British, Italian pilots who were also competing in this event.
Original motion picture film of the trip along with a narrative from the
diaries of the aviators make for a really great. Computer graphics depicting the
airplanes also add to the drama of this show ... very well done.
If you like open cockpit flying (and I suspect you do) you'll really enjoy
watching this show. These guys (and airplanes) were amazing!
I wonder if Mr. Pietenpol followed this story when he was a young man and
became inspired by the success of the American pilots?
Below is a link to The History Channel website about this program. (Their
website runs slower than molasses following on a cold winter day, so be patient.)
http://www.historychannel.com/global/listings/series_showcase.jsp?EGrpType=Ser
ies&Id=14217115&NetwCode=THC
It's my understanding that Mr Pietenpol did not like " Bernie " at
all and insisted on Bernard. I can see his point. Anyone calling me
Cliffy gets ignored or an exceedingly dirty look ( occassionaly worse!)
The " Flying and Glider Manual" 1932, Available from the EAA as
a reprint, is a must to have. Bernard explains the airfoil on page 16.
He states,"Don Finke, a neighbour who flies as though he were born
in a plane, and myself sketched it out one night out of our heads."
And a little later," I am told by experts that the curve is practically an
Eiffel 36 with ordinates increased 25% all along the chord."
There is more, much more, in this publication. While you're at it, get
the entire set, great stuff.
The archives holds a vast store of information. Put "glue" in the search
engine box and up comes 2037 messages. Airfoil generates 571.
At the bottom of every message is a list of links. The fourth one is
" search engine". check it out.
Also go to http://www.mykitplane.com/index.cfm and look up the
articles scanned in by Jim Markle, in both the "files" and " picture
gallery" areas.
Forrest, I think many, if not all, on this list would like to hear more
on the flying characteristics of our favourite plane. Your comments
on spinning were an eye opener. Thank you.
A final word, don't use paper anything, plain or waxed, to mix glue
on or in. I use small graduated plastic cups to mix my 1 to 1 epoxy.
If I need 2 cc I fill 1 cc with part one and continue to the 2 cc level
with part two then mix. Nice and neat. Available at my local marine
supply.
Clif
not
397 is
thirties.
the
> idea.
> Forrest Lovley
Subject: | Orientation of Elevator Control Horns |
Many thanks to Walt Evans, Chuck G, Max Davis, and D. J. Vegh for your fast and
insightful responses. Walt, I looked in the original plans in the F&G manual,
and the horns are indeed drawn at an angle as you described. Max, your ship
looks beautiful on the mykitplane builders log, and the "tail grouping" photo
plainly shows the horns aligned with the cables. We will definitely be mounting
our control horns that way.
Thanks again for the help.
Best Regards,
John Smoyer
Subject: | Re: Torque Tube Rod |
John,
I am still studying your words of wisdom so when I get to my axle installation,
I will have good info to work from. Your comment about "next time using spreader
bars with thicker walls", what did you use and what would you go to?
Thanks so much.
Alex Sloan
Subject: Re: Pietenpol-List: Torque Tube Rod
Dave,
Pardon me for jumping into this discussion about how to keep the straight axle
from rotating when the brakes are applied.
May I suggest an alternative method of doing this so that the axle is free to move
in any direction without excessive strain on welded joints? I also believe
that the integrity of the axle is not compromised by cutting a hole through
it and I think this is a lighter solution to the problem.
I have attached a photo of the installation on my ex- "Mountain Piet". You just
weld a couple of 3" tabs on the top and bottom of the axle in the middle. Do
the same thing on the rear spreader bar. Now drill some 1/4" holes at the top
and bottom of the tabs to use Heim joints. Then connect the Heim joints with
a 1/2" round aluminum rod drilled and tapped for the 1/4-20 threads of the
Heim joints so that when when the whole thing is assembled you have a parallelogram
formed by the tabs and links.
The system works well. If I were to do it over again, the only change I would
make would be to use a rear spreader bar with a little thicker wall so that it
is not as apt to bend under loading.
Hope this is helpful in your decision.
Thanks Jack. Perhaps I will try to find two 8 inch pieces of pipe that can slip
tightly into my axle - position them so there's about 4 inches of pipe on either
side of the holes - and drill them through. This will double the thickness
of the axle in that critical area acting as reinforcement in case there is
a exceptionally hard landing.
Dave Paulsen
Subject: RE: Pietenpol-List: Torque Tube Rod
Dave,
The guide pins dont have to be welded. However, just putting a hole through the
axle causes a stress concentration. My axle broke at the guide pin, but my
axle was only .120 wall. My new axle will be .188 wall, and I will have it
heat treated after welding to raise the yield strength to 105,000 psi, which
will make it about 50% stronger (and 8 lbs lighter) than a .25 wall axle non-heat
treated. I am also going to change the design of the guide pins to allow
the holes through the axle to be on the neutral axis so any stress concentrations
caused by the holes will not matter.
Jack Phillips
Slowly beginning to repair NX899JP
Why does the bolt or rod that some of us have put though our straight though axles
have to be welded? I'm probably missing something obvious but I don't know
what. The rod can't jump out of the axle because there is a nut at the bottom
that will prevent it from coming up through the torque tube. Thanks. Dave
Paulsen
John,
using spreader bars with thicker walls", what did you use and what would you go
to?
Thanks so much.
Alex Sloan
Dave,
Pardon me for jumping into this discussionabout
how to keep the straight axle from rotating when the brakes are applied.
so that the axle is free to move in any directionwithoutexcessive
strain on welded joints?I also believe that the integrity of the
axle is not compromised by cutting a holethrough it and Ithink
ex- "Mountain Piet". You just weld a couple of3" tabs on the top
and bottom of the axle in the middle. Do the same thing on the rear spreader
bar. Now drill some 1/4" holes at the top and bottom of the tabs to
use Heim joints. Then connect the Heim joints with a 1/2" round aluminum
rod drilled and tapped for the 1/4-20 threads of the Heim joints so that when
when the whole thing is assembled you have a parallelogram formed by the tabs
and links.
again, the only change I would make would be to use a rear spreader bar with
a little thicker wall so that it is not as apt to bend under loading.
of pipe that can slip tightly into my axle - position them so there's about
4 inches of pipe on either side of the holes - and drill them through.
This will double the thickness of the axle in that critical area acting as reinforcement
in case there is a exceptionally hard landing.
Dave Paulsen
From: <A title=jphillip(at)alarismed.com ">Phillips, Jack
Dave,
However, just putting a hole through the axle causes a stress concentration.
My axle broke at the guide pin, but my axle was only .120 wall.
My new axle will be .188 wall, and I will have it heat treated after welding
to raise the yield strength to 105,000 psi, which will make it about 50% stronger
(and 8 lbs lighter) than a .25 wall axle non-heat treated. I am
also going to change the design of the guide pins to allow the holes through
the axle to be on the neutral axis so any stress concentrations caused by the
Jack Phillips
put though our straight though axles have to be welded? I'm probably missing
something obvious but I don't know what.The rodcan't jump
out of the axle because there is a nut at the bottom that will prevent it
from coming up through the torque tube. Thanks. Dave Paulsen
Date: Fri, 10 Dec 2004 18:53:53 +0000
--NextPart_Webmail_9m3u9jl4l_5435_1110316130_2
name="P1010024.jpg"
filename="P1010024.jpg"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--NextPart_Webmail_9m3u9jl4l_5435_1110316130_2--
Subject: | Re: Torque Tube Rod |
----- Original Message -----
To: pietenpol-list(at)matronics.com
Sent: Tuesday, March 08, 2005 2:08 PM
Subject: Re: Pietenpol-List: Torque Tube Rod
Alex,
I am not sure now since I sold Mountain Piet and can't measure the diameter of
the spreader bars on the plane.
I also sent the buyer, Greg Bacon, the plans for the plane. However, if my aging
memory is correct, I followed the sizes shown on the plans. I think if you
increased the diameter/wall thickness from that shown by maybe 25% you will
be ok. Even if you follow the sizes shown, there is no real problem, the spreader
bar simply bends a little more under a braking load
John,
I am still studying your words of wisdom so when I get to my axle installation,
I will have good info to work from. Your comment about "next time using spreader
bars with thicker walls", what did you use and what would you go to?
Thanks so much.
Alex Sloan
Sent: Thursday, December 09, 2004 5:06 PM
Dave,
Pardon me for jumping into this discussion about how to keep the straight
axle from rotating when the brakes are applied.
May I suggest an alternative method of doing this so that the axle is free
to move in any direction without excessive strain on welded joints? I also
believe that the integrity of the axle is not compromised by cutting a hole through
it and I think this is a lighter solution to the problem.
I have attached a photo of the installation on my ex- "Mountain Piet". You
just weld a couple of 3" tabs on the top and bottom of the axle in the middle.
Do the same thing on the rear spreader bar. Now drill some 1/4" holes at
the top and bottom of the tabs to use Heim joints. Then connect the Heim joints
with a 1/2" round aluminum rod drilled and tapped for the 1/4-20 threads of
the Heim joints so that when when the whole thing is assembled you have a parallelogram
formed by the tabs and links.
The system works well. If I were to do it over again, the only change I
would make would be to use a rear spreader bar with a little thicker wall so that
it is not as apt to bend under loading.
Hope this is helpful in your decision.
Thanks Jack. Perhaps I will try to find two 8 inch pieces of pipe that can
slip tightly into my axle - position them so there's about 4 inches of pipe
on either side of the holes - and drill them through. This will double the thickness
of the axle in that critical area acting as reinforcement in case there
is a exceptionally hard landing.
Dave Paulsen
To: 'pietenpol-list(at)matronics.com'
Sent: Thursday, December 09, 2004 7:10 AM
Subject: RE: Pietenpol-List: Torque Tube Rod
Dave,
The guide pins don't have to be welded. However, just putting a hole through
the axle causes a stress concentration. My axle broke at the guide pin,
but my axle was only .120" wall. My new axle will be .188" wall, and I will
have it heat treated after welding to raise the yield strength to 105,000 psi,
which will make it about 50% stronger (and 8 lbs lighter) than a .25" wall axle
non-heat treated. I am also going to change the design of the guide pins
to allow the holes through the axle to be on the neutral axis so any stress concentrations
caused by the holes will not matter.
Jack Phillips
Slowly beginning to repair NX899JP
-----Original Message-----
Why does the bolt or rod that some of us have put though our straight though
axles have to be welded? I'm probably missing something obvious but I don't
know what. The rod can't jump out of the axle because there is a nut at
the bottom that will prevent it from coming up through the torque tube. Thanks.
Dave Paulsen
From: | "Phillips, Jack" <jphillip(at)alarismed.com> |
Being somewhat interested in alternative ways to carry braking loads, I
just ran some numbers to see which would be of more benefit when using
John's design - thicker walls or larger diameter for the spreader bars.
I ran some quick calculations, assuming my memory is correct and the
plans call for 1" x .035" wall tubing for the spreader bars. I don't
have my plans here so I can't check them.
Anyway, if you started with 1" x .035 and wanted to go one step bigger,
you could either go to 1" x .049 or 1-1/8" x .035. The larger O.D.
would be preferable, for a couple of reasons:
1. The larger OD will give a higher section modulus (measure of
torsional stiffness) - about 44% more than the original size, whereas
the thicker wall will only give an increase of about 34%
2. The larger OD with .035" wall is lighter than the original OD
with .049" wall
3. The larger OD tubing with .035" wall is cheaper than the
original OD with .049" wall
4. The thinner wall section is easier to flatten on the ends
(which the spreader bars require) than the thicker material would be.
Jack Phillips
Raleigh, NC
Alex,
diameter of the spreader bars on the plane.
my aging memory is correct, I followed the sizes shown on the plans. I
think if you increased the diameter/wall thickness from that shown by
maybe 25% you will be ok. Even if you follow the sizes shown, there is
no real problem, the spreader bar simply bends a little more under a
braking load
John,
installation, I will have good info to work from. Your comment about
"next time using spreader bars with thicker walls", what did you use and
Thanks so much.
Alex Sloan
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Anybody have a set of left and right exhaust stacks for a Continental
A-65/Aeronca 7AC for sale? It turns out that both the right and left stacks
on 41CC got bent in the nose-over and I'll probably replace both. Repairs
coming along nicely...
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
Subject: | Some aerodynamic stuff |
Pieters,
As I build my engine mount jig some little questions have popped into this
ole brain. I remember from a long time ago, maybe flight school or somewhere,
that the downthrust angle on the engine is to force a more direct blast on the
lower surface of the wing.(High, single wing).
Now as I plan to extend the mount a full 2 inches forward of the plans and
lengthen the cabanes another 2 inches over the plans.
It would seem to me that it would be necessary to drop the engine incidence
to compensate for these changes.
Now those of you in the know please advise. I'm laying out the jig for a 4
degree downthrust measured from the firewall and a wing incidence of 1 degree
30'.
Sure would appreciate some help on this one. I promise to leave the list
alone for the future.
Corky in La nursing Isabelle with a strep throat
Subject: | Re: Some aerodynamic stuff |
What you are referring to is called P factor. With airplane at cruise
attitude both blades generate about the same thrust, but with a higher
angle of attack the downward blade gets a bigger bite of air than the
upward blade and thus creates more thrust. For most airplanes that
means the airplane wants to turn left and one of the reasons you need
right rudder on take off.
Moving the engine from the design point would definately change the
impact of this on the airplane, but how much and how you compensate for
it is beyond my knowledge base
Mark
Isablcorky(at)aol.com wrote:
> Pieters,
> this ole brain. I remember from a long time ago, maybe flight school
> or somewhere, that the downthrust angle on the engine is to force a
> more direct blast on the lower surface of the wing.(High, single wing).
> and lengthen the cabanes another 2 inches over the plans.
> incidence to compensate for these changes.
> a 4 degree downthrust measured from the firewall and a wing incidence
> of 1 degree 30'.
> list alone for the future.
I'm thinking of putting a couple layers of Kevlar on the fuselage tank I'm
building to offer more safety over a simple fiberglass tank. I read in the Wicks
catalog that Kevlar is 2.5 times stronger than E glass, and 10 times stronger
than aluminum on a specific tensile strength basis.
The problem is I don't want to invest in a pair of $60 scissors that will
probably be used one time. Does anybody have any experience in cutting Kevlar
with a regular pair of scissors or is there an alternative to the $60 version?
Roy
From: | "Jim Markle" <jim_markle(at)mindspring.com> |
I have experience cutting Kevlar and the scissors are an absolute must.
But don't buy any. I have a pair sitting here collecting dust and would be glad
to loan them to you.
Send me an SASE (and promise that you'll return them!) and you're welcome to borrow
them.
If you decide to buy some for yourself, don't buy the $60 ones....get the $26 ones from ACP (http://www.acp-composites.com/acp-ta.htm)
Jim Markle
Plano, TX
214.505.6101
Sent: Friday, March 11, 2005 5:14 AM
Subject: Pietenpol-List: Kevlar
I'm thinking of putting a couple layers of Kevlar on the fuselage tank I'm building
The problem is I don't want to invest in a pair of $60 scissors that will probably
be used one time. Does anybody have any experience in cutting Kevlar with
Roy
Corky,
My take on the down thrust of the engine is since the plane wing normally flies
with some positive incidence, the engine/prop is flying with zero incidence.
walt evans
NX140DL
Sent: Thursday, March 10, 2005 7:57 PM
Subject: Pietenpol-List: Some aerodynamic stuff
Pieters,
As I build my engine mount jig some little questions have popped into this ole
brain. I remember from a long time ago, maybe flight school or somewhere, that
the downthrust angle on the engine is to force a more direct blast on the lower
Now as I plan to extend the mount a full 2 inches forward of the plans and lengthen
It would seem to me that it would be necessary to drop the engine incidence to
Now those of you in the know please advise. I'm laying out the jig for a 4 degree
downthrust measured from the firewall and a wing incidence of 1 degree 30'.
Sure would appreciate some help on this one. I promise to leave the list alone
for the future.
From: | "gbowen(at)ptialaska.net" <gbowen(at)ptialaska.net> |
I've worked a fair amount in the composites industry with Kevlar, so here's
my two cents worth. 1) Don't think Kevlar is gonna give you what you're
looking for in terms of accident damage to your tank over glass, especially
using only a couple plies over the glass core, 2) if you impact something,
that pokes a hole in your gas tank, you're gonna have a leak whether it's
covered with Kevlar or not, the resin system will shatter and leak at the
damage spot, 3) Kevlar is very hard to work with for two reasons, a: it
cuts very difficult therefore needing the special cutting tools, so you
gotta shell out the $60+ bucks, b: it has a lot more filaments per tow
bundle than glass so it consumes more resin per square foot to wet these
bundles out. 3) Kevlar has a tendency to separate from the glass plies.
The composites shop folks at Lufthansa used to get new 737/747 engine
cowlings from their supplier in the US that had a Kevlar inter-ply to
prevent jet engine vanes from shooting thru the cowling into the fuselage.
I watched them remove the Kevlar ply, just like peel ply, and toss it away,
because subsequent repairs to the cowling wouldn't stick. Kevlar has a
couple nice advantages, a) stronger than fiberglass or carbon, b) lighter
than either one.
Gordon Bowen
Original Message:
Date: Fri, 11 Mar 2005 06:14:17 EST
Wicks
stronger
Kevlar
version?
Roy
In a message dated 3/11/2005 5:15:56 AM Central Standard Time,
Pilots4ETW(at)wmconnect.com writes:
Roy & Sterling,
I agree with Gordon. I don't think the effort to use Kevlar in with the
lay-ups of Fiberglass is worth it. Kevlar is the most abrasion resistant
material of all the composite materials...that's why it's used in bullet proof
vests. It is a LOT more expensive, hard to cut, difficult to wet out. You're
trying to build 'Crashworthyness' into your plane...much better to build
'Airworthyness' into it. There are two types of Fiberglass: E-glass is used where
electrical resistance is the requirement, and S-glass is used when strength is
the requirement. Of all the composite materials, Carbon Fiber is the
strongest in compression, but offers poorest in abrasion resistance, therefore
each
type of material has it's place in a given design, in addition to the type of
resin.
I used Omni-direction Kevlar on the leading edge (about 1/2" wide), for
'tipping material', on the 3 props that I've built, because of it's abrasion
resistance. Then wrapped the entire blade with one layer of the light weight
fiberglass, all the way to the root. I used Polyester Resin (auto body stuff)
on the props. Epoxy Resin, such as the 'West System', is the preferred type of
resin for fuel, oil, and chemical resistant applications.
Chuck G.
So, 4 layers of Kevlar over two layers of fiberglass in a fuel tank build up
(in a Pietenpol having the fuel tank a few feet away from the pilot, in a
wooden airplane) does not add any safety? In looking at a search of Kevlar=20fuel
tanks on the internet, many folks riding pocket rockets (fast motorcycles) are
switching to Kevlar gas tanks so they don't cook their nuts over an open fire.
Also, the radio control airplane people are using Kevlar gas tanks so their
expensive RC airplanes don't cook upon hard landings. And, many law enforcement
groups using Ford Crown Victorias are now using Kevlar so their officers
don't burn if rear ended.
Here are some links.
https://commerce67.datapipe.com/eraaviation/hs_gc_as_aux_fuel.stm
Era's Enhanced
External Auxiliary Fuel System
for Bell 412/212/205/UH-1H/V/N
Two externally mounted "Kevlar=C2=AE" fuel tanks providing an additional 140
gallons of usable fuel, extending endurance by 1.5 hours meets FAR 29.952 NPRM
crashworthiness criteria.
http://www.f1technical.net/article19.html
Fuel tank F1 cars use fuel tanks made from puncture-proof Kevlar. This
dramatically reduces the risk of any fire during an accident. The tank reshapes
itself in the area where any pressure is being put.
http://www.benlovejoy.com/concorde/crash.html
Third, the fuel tanks. The bottom of several of the fuel tanks were lined
with rubber-kevlar shielding, both to reduce the risk of debris reaching the
fuel, and to dramatically reduce the rate at which fuel would flow out through
a
leak.
http://www.amerindustrial.com/article.htm
Amer Industrial Technologies Inc., has designed a fire-resistant fuel tank
system for the Long Island Railroad that will allow tank full of fuel without
risking the spill of fuel or fumes in an accident. Ahmad Amer=E2=80=99s=20=E2=80=9Cbullet-proof=E2=80=9D
rail-road car, lined by a puncture-resistant bladder made of Du Pont Co.=E2=80=99s
Kevlar, can carry 500 pounds of fuel and withstand a collision with a load of up
to 250,000 pounds. Kevlar is the same material used in making bullet-proof
vests.
http://www.mustang50magazine.com/roadtests/4288/
The cars were shipped from the DAP facility to Mascotech for installation of
the special custom HD cooling system and the special 20-gallon Kevlar fuel
cell. Those who raced the 1993 Cobra R complained of too small a fuel tank,
forcing extra fuel stops in endurance races that cost them time and position on
the
track compared to the Camaros.
http://www.autosafety.org/article.php?scid141&did813
On Friday, with the cooperation of Ford, Florida state troopers began
installing Kevlar-reinforced tubs in their trunks, which are designed to organize
equipment so items don't shoot forward in a crash and puncture the gas tank.
From: | "tmbrant1(at)netzero.com" <tmbrant1(at)netzero.com> |
test only - sorry
I received it.
walt evans
NX140DL
Subject: Pietenpol-List: email test
> test only - sorry
Subject: | Re: A-65 exhausts |
Oscar,
I made mine from "J.C. Whitneys" VW bypass exhaust pipes, for about $9.95
for two. The VW flange is the same as the continental, and by cutting up
the pipes, that are shaped like candy canes, with a little cutting/welding
and a little work you can have them for $10.00. You may have to add some
stock pipe from the auto store ( 1 1/4",,,I think)
walt evans
NX140DL
PS quite a few hours,,,and nothing flew off yet.
Subject: Pietenpol-List: A-65 exhausts
stacks
> Oscar Zuniga
> San Antonio, TX
Subject: | sanding glue joints |
In the advisory circular "acceptable methods.." section 1-6 "preparation of wood
surfaces for bonding" it states that sandpaper must never be used to smooth
softwood surfaces that are to be bonded. I built my fuselage by cutting the braces
on the table saw to a rough dimension and using a stationary disc sander
to get just the right fit. Does this mean that I'm building an expensive 2-seat
piece of firewood?
I did the same with the ribs I've been building.
Any thoughts on this?
Tom Brant
Brooklyn Park, MN
Subject: | Re: sanding glue joints |
Tom, you are doing fine. Some will not agree, but
glue two pieces of spruce (both sanded) as in a test
joint and then cut through the joint and see just how
far the glue absorbs into the wood. If you are using
T-88 or evuivalent, then you will get good penetration
whether you sand or not. I did mine both ways (sanded
or saw mitered) and found no difference in the
strength of the joints.
Doc
--- "tmbrant1(at)netzero.com"
> section 1-6 "preparation of wood surfaces for
> to smooth softwood surfaces that are to be bonded.
> I built my fuselage by cutting the braces on the
> stationary disc sander to get just the right fit.
> piece of firewood?
> Tom Brant
> Brooklyn Park, MN
> Contributions
> any other
> Forums.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/Pietenpol-List.htm
> http://www.matronics.com/photoshare
Subject: | Pietenpol Video Documentry |
To all you Pietenpol Enthusiasts,
I've started doing this video on the building and flying the Pietenpol
Aircamper, and I'm asking everyone to make suggestions as to what I should
include in the video. Sterling Brooks has been VERY helpful to me on this
project...Thank You Sterling !!
To introduce the video, I think I will go over some of the reasons that
folks have always had the urge to fly. I will also go into the history of the
Pietenpol, with information found on the Pietenpol Family Web Site. A part=20of
that history, is that the plans sold by the Pietenpol Family is the exact
plans drawn up by Orrin Hoopman, and designed by Bernard Harold Pietenpol. =20This
is the reason I am against updating the original plans. It's part of the rich
history of our beloved design. However, in my video, I am going to go over
each of the errors, and not so clear points on the plans, that need to be
clarified. I will also mention all the pertinent documents, and books, that the
builder needs to study, as well as all the hints & tips that I can think of. I
will include a method of tying the bunji chords. I will also include the need
to use the strap fittings on the belly, between the Landing Gear Lugs / Lift
Strut Fittings. Today, I carried the camera around with me, during a
pre-flight, and talked about each item I was inspecting...then the camera battery
went
dead. I'm also going to do quite a bit of aerial view points with the camera
with background music, and some ground based shots of take offs, and
landings...I hope I can grease a few landings for the camera !!
As far as the errors go, here are the ones that I know of :
Drawing No. 3 - lower left hand corner, the Bottom Fitting Plates show a
dashed line that says 'BEND UP 20=BA HERE.' It should read BEND UP 30=BA HERE,
or
Maintain alignment with the Lift Struts.
Drawing No. 4 - in the lower left corner, the drawing of the Center Strut
Fittings (to of the Cabane Struts) is unclear that there are but TWO pieces, that
overlap each other, kind of a U into a U. It is NOT three pieces.
Drawing No. 4 - Flying Strut Fittings 4 Req'd The angle of the strut
fittings should be installed in line with the lift struts, not at the sharp=20angle
called out in the plans.
Drawing No. 5 - the Measurements of Wing Rib Profile, there are a couple of
measurements that are a little short, and cause the top profile of the rib to
dip in. You should loft these points on your rib jig, then just blend the
crooked line on the top, so it is a smooth transition.
Drawing No. 5 - the Wing Beam Details (Main Spars) show an outdated method of
splicing the spars, and not recognized by AC43.13. The correct method of
scarf splice is called out in that AC.
Can anyone point out any other areas of the plans that are not clear ?
Any other suggestions on what I should include in the video ?
Should I include all the infomation I have about builders and flyers ?
How about an overview about building a prop ?
I hope to put together a useful, and enjoyable DVD, but I'm not going to
release it until it is 'Just Right'.
Chuck Gantzer
NX770CG
itching to burn some DVD's
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
As Doc says, the best thing to do is to make some test joints and then break
them. IF you get a clean break at the glue line, the joint is no good. If
you get a messy break with lots of wood fibers broken, indicating the wood
broke before the glue did, you can't ask for a stronger joint.
My Piet was built mostly with resorcinol, with T-88 in some places. A few
tips I learned along the way (through breaking test joints) are:
When properly made, a resorcinol joint is incredibly strong
When improperly made, a resorcinol joint is not very strong
T-88 is more forgiving than resorcinol, but cleanup is messier
T-88 is quite strong for butt joints. Resorcinol is not.
When making plywood doublers for use with either type of glue, you get a
better joint if you roughen the surface of the plywood with coarse
sandpaper. This is especially true for birch plywood, which has a very
smooth "sheen" that prevents good wetting by the glue.
Good tight fitting joints are essential with resorcinol. T-88 can stand
some (small) gap, but don't think it will let you get away with sloppy
construction
As for what the advisory circular says, I wonder if they were talking about
the hard sheen you sometimes see after using a belt sander on softwood? In
my experience, it is hard to get glue to penetrate such a sheen. I found
that roughing parts up, particularly for butt joints like the uprights in a
rib, gives a better joint.
Just my two cents, but after finishing up the structural repairs of my
Pietenpol from last fall's forced landing, I've had a lot of glue joints to
have to break. I've been very pleased with the results, and with the
overall structural integrity of the craft.
Jack Phillips
Raleigh, NC
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Galen
Hutcheson
Subject: Re: Pietenpol-List: sanding glue joints
T-88 or evuivalent, then you will get good penetration whether you sand or
not. I did mine both ways (sanded or saw mitered) and found no difference
in the strength of the joints.
Doc
> piece of firewood?
> Tom Brant
> Brooklyn Park, MN
> Contributions
> any other
> Forums.
advertising on the Matronics Forums.
Hi Tom,
Don't throw away anything you've already
built. I did test samples on both sanded and
unsanded joints, including some using birch
ply with the "manufacturing glaze" still
intact. Tests included both T-88 and
Aerolite. I even made some intentionally bad
joints that fit poorly and didn't have 100%
glue coverage.
Not one single glue joint broke.
Just follow "acceptable methods" for the rest
of the project.
Greg Cardinal
Minneapolis
Subject: Pietenpol-List: sanding glue joints
> using a stationary disc sander to get just
> building an expensive 2-seat piece of
> firewood?
> building.
> Tom Brant
> Brooklyn Park, MN
> Forum -
> through the Contributions
> banner ads or any other
> Matronics Forums.
> http://www.matronics.com/search
Subject: | Re: Pietenpol Video Documentry |
Chuck, all the things you mentioned are excellent.
One error I found was at the lower cross-member at the
firewall. How do you attach it? At the intended
attach points, there are the metal fittings for the
engine mount (Model A) which would hinder the
attchment. Also, methods on building a prop would be
great. I think this video would be real helpful.
Doc
> Family Web Site. A part of
> Bernard Harold Pietenpol. This
> with me, during a
> inspecting...then the camera battery went
> of take offs, and
> the camera !!
> know of :
> dashed line that says 'BEND UP 20 HERE.' It
> should read BEND UP 30 HERE, or
> NOT three pieces.
> angle of the strut
> struts, not at the sharp angle
> transition.
> the video ?
> Chuck Gantzer
> NX770CG
Great idea Chuck, I will certainly purchase one.
1) Since a good percentage of Piets are not built with Model A engines
several wood parts on the front of the fuselage are not needed. May
want to point this out.
2) Seat belt attachments, everybody does it different, still don't how
I will do mine, showing a couple proven ways to do this would be
great.
3) Flying struts - this is my biggest unknown, if using 4130 the plans
are fairly clear but it seems many do their ends attachments
differently. Many people are using Aluminum struts also because of the
high cost of steel streamline tubing and are also using different end
attachments. People may value your flight-proven opinions on this.
4) Brakes, everyone knows what an installed set of brakes and wheels
look like but a video segment of a wheel/rotor/caliper/etc being taken
apart and put back together would help a lot of people. Especially
since brakes are not on the plans.
I would say put it in, especially since you are going with a DVD media
if someone is not interested in a topic its simple to skip it unlike
a tape where you may have to fast forward for 5 minutes.
Yes
> Chuck Gantzer
> NX770CG
Rick Holland
In a message dated 3/13/2005 10:53:12 AM Central Standard Time,
wacopitts(at)yahoo.com writes:
attchment.
Doc,
The cross-member (3/4 X 3/4 Spruce) is shown on Drawing No. 1, in the
lower right portion. It goes between the inbd side of each of the lower
longerons, but is cut short, to access the inboard bolts of the engine mount fitting.
The 1/8" plywood firewall is also the gusset for this cross-member, as well
as the 7/32" plywood bottom, and will carry the load. There is also a gusset
on the inbd side of each lower longeron, with a cut out for this lower
cross-member, called out on Drawing No. 4 - in the upper left portion of the drawing.
I think this might be the error. There should NOT be a cut out for the
cross-member, because the cross-member doesn't extend all the way to the longerons.
Gussets like this one, and others like it on the lower longerons, should
have a filler piece installed, to prevent dirt or water from collecting between
the inboard gussets, and plywood sides, on each side of the lower longerons.
On Drawing 6 - lower left portion - shows the lower Model A engine mount.
This is a good point to clerify on the plans. The plans note - LOWER INSIDE
FITTING INSERTED THRU FRONT BULKHEAD. CUT OFF END OF CROSS STRUT. This
would be required to install one of the nuts on the inside of the fitting.
Good point, Doc !! Lets hear more like this.
Chuck G.
Tom,
Ref your message: "I built my fuselage by cutting the braces on the
table saw to a rough dimension and using a stationary disc sander to get
just the right fit."
I assume that you are sanding the ends of the pieces to get the correct
angle. That is OK--most builders do it. The strength of these joints
comes from the gussets. End grain joints are notoriously weak. It is
even perfectly acceptable to build ribs with all of the bracing cut at a
90 degree angle, thus getting 100% of the strength from the gusset. By
the way, be sure to scuff your plywood lightly with sandpaper before
gluing.
Dick Hartwig
Waunakee, WI
rhartwig11(at)juno.com
I think I understand the sanding the plywood... I've made several ribs and on
a few occasions, had some extra glue. So I made test pieces. As you mentioned,
I made one with the braces at 90 deg. cuts and the other were tight joints.
The one without any end grain contact (gussets only) actually broke free of
the gussets quite easily. I have not tried it with sanding the plywood.
All of the ribs I've made do not have plywood that is sanded. Should I scrap them
(8 ribs)? The other test I did had tight fitting joints and the wood broke
first on that one. Then tonight I put a lot of pressure just outside the gussets
and the brace came free of the top capstrip. IT had wood fibres in it but
it broke at the glue line...
Tom B.
Well I keep looking for an all wood construction airplane that I can fit
in at 6ft 1 and about 220. I recently sat in a Piet that I think was
built using Bernards plans and I simply didn't fit. I saw some plans
from St. Croix Aircraft including some interesting plans for a bi plane
version.
Are these any larger? Id be interested to know if anyone had flown the
biplane version.
Mark
Subject: | Re: Different Piets |
<4235007F.1080500(at)dp.net>
Mark,
I built the long fuse from the 1934 plans ( with the long fuse added prints)
and I'm 6' 3" 220#. It fits for me!
walt evans
NX140DL
Subject: Pietenpol-List: Different Piets
> version.
> biplane version.
> Mark
Mark, many (including myself) have modified the width
of the fuse to make the cockpit more user friendly. I
am building a biplane version (my own design) using
the Piet fuse and ribs. The great thing about the
Piet is it's versitility. You should find many
discussions on this topic via the search engine. The
Piet is a great plane in it's own right, but it is
easy to use it as a spring board for other designs.
Doc
> Contributions
> any other
> Forums.
Thanks Chuck, that was a little confusing on the
plans. The cross member is only going to act as a
stiffner for the ply attached to it since it isn't
directly attached to the longerones. You could run 45
degree angle braces from the verticals at the bulkhead
down to the cross member and this would allow it to
have some structural integrity, may not be needed,
however. I enclosed all my gussetts with balsa strips
creating a sealed box to keep dirt and water from
collecting near the joints.
Doc
> Standard Time,
> the
> attchment.
> Doc,
> out for this lower
> Chuck G.
Subject: | painting metal parts |
Group;
I've had problems painting metal parts, both steel and aluminum. Some parts
will take the paint perfectly, but other times it's as if there is something
on the metal that repels the paint and I get little voids and imperfections.
Cleaning with hot soapy water, MEK, alcohol, or degreaser don't seem to
make any difference... there are little areas that just won't take the
paint.
Is this maybe some silicone from a cleaning rag, or something in the pores
of the metal? Any ideas?
Oscar Zuniga
San Antonio, TX
Oscar,
I had good results using the PolyFiber products. The procedures are
different depending on the metal. For steel:
a. Beadblast the parts to get all welding scale and any rust off. even
clean metal can benefit from beadblasting as it gives a little more "tooth"
for the primer
b. Clean with PloyFiber's Met-L-Sol
c. Prime with PolyFiber's Epoxy Primer. I find the green works better than
the white. Once cured, this stuff is bulletproof
d. Paint with whatever top coat you want. If you use their Aerothane
polyurethane, you will find it produces an extremtly hard, durable finish
For aluminum:
a. Clean the parts with PolyFiber's Alkaline Cleaner
b. Etch with PolyFiber's Phosphoric Acid etch
c. Apply an Alodine coating. I didn't use PolyFiber's coating because
their's is a clear alodine and I prefer the gold alodine so you can see
where you have missed.
d. Epoxy Prime as above. The acid etch and alodine provides a finely
toothed surface and the primer just about jumps on the aluminum.
e. Top Coat as above. Once the primer is on, you can use any paint you wish
PolyFiber's products are very expensive (that epoxy primer is about $65 for
a quart kit, which makes about 1-1/2 qts), but this is the part of your
project that will really show. If you did a world class job on the woodwork
and then the paintjob looks like crap, the whole airplane will look like
crap.
Jack
Finally finished with structural repairs on NX899JP and starting to do
fabric work.
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar
Zuniga
Subject: Pietenpol-List: painting metal parts
Group;
paint.
Oscar Zuniga
San Antonio, TX
Interesting Doc, a Piet biplane. I looked at the Aerial biplane plans
(and I assume you have also) but heard nothing but bad things about
it. I originally purchased FlyBaby plans and the FlyBaby biplane
supplemental plans which included a modified set of wing plans (both
wings) that bolted to the original fuselage with very little
modifications. Peter Bower claimed you could interchange the wings to
go from biplane to monoplane any time you wanted.
I originally wanted to build a biplane but couldn't find anything else
to beat the price/builder support/track record of the Piet. From what
I have heard the problem with the Aerial Piet biplane was too much
wing area because it kept the original wing and added a lower wing of
about the same size. The FlyBaby biplane used two different smaller
wings which were swept back like a Pitts, looks really good.
Sorry if you know all of this already, I think it would be incredible
if some industrious
person (like yourself) came up with a good biplane Piet design which
could be retro-fitted to existing Piets (like the FlyBaby biplane).
The best of both worlds. The FlyBaby plans also included additions for
adding floats. I know at least one person has successfully added
floats to their Piet, make those plans available as a supplement also
and you have a seriously versatile design.
I wish you the best of luck.
> Doc
Rick Holland
Subject: | Re: painting metal parts |
Oscar:
When I built my Avid Flyer, I had to paint many aluminum and 4130 parts, not
to mention fiberglass. I used a 2 part epoxy primer. Everything went great.
I'd try the two part epoxy and stay away from Krylon or other primers in a
can.
One other problem, you have fairly high humidity in your area. You might
need to install a moisture guard on your airline. Here at Knot-2-Shabby we
have humidity too but not as bad as San Antonio. Here is a trick I learned
from an old-timer... I use a filter out of the compressor at 10 feet, then I
go out 25 feet, and installed a moisture guard I bought as Sears. Then I run
another 25 feet from the mositure guard to my gun (HLVP) and it helped the
moisture problem. (Don't ask me why the 25 feet-moisture guard-25 feet thing
works, I learned this trick from the paint shop here when I was spraying a
custom pickup I built in the 80s... Didn't have this problema in El Paso,
since there is no humidity there, but in Central Texas, wow.
Are you draining the sump daily on your compressor? (A great safety measure,
not to mention a way to keep excess water out oif the line.)
Also, I almost always add a fish-eye additive to my paint (in addition to a
hardener... in the color coat, not the primer) and the fish-eye additive is
VERY GOOD for the problem you described. I've never tried these additives in
anything other than enamels by the way.
Last, have you used any air tools needing oil? You might have a contaminated
oil line.
PLATA
> Group;
parts
something
imperfections.
> paint.
> Oscar Zuniga
> San Antonio, TX
Subject: | Glue and Sanding |
Perhaps I missed it, but if not it may be worth mentioning.
Whenever I sand wood, especially plywood I go over the areas to be joined
first with the shop vac, then with either a tack cloth or the sticky side
of duct tape. The purpose being to remove any wood dust from the area of
the glue joint. This is standard practice whenever I assemble wood in my
shop. Disclaimer: I'm not a expert and I'm not suggesting the joint is any
stronger. I just do it for my own piece of mind.
Jack wrote-
>T-88 can stand some (small) gap, but don't think it will let you get away
>with sloppy construction.
In fact, T-88 requires a small gap. If you over-clamp a joint made with
T-88 you'll squeeze out too much of the glue and will not get a good joint.
One of the big plusses of working with T-88 is that it is much more
forgiving than resorcinol or some of the other glues. Joints should be
nice, but even if you have slight discrepancies the T-88 will fill the gap
and give you good strength.
Although I haven't tried it myself, it is said that wood joints can be made
with T-88 on wood that is moist (such as from steaming, to bend capstrips).
It has also been said, and my experience bears it out, that T-88 will soften
at elevated temperatures. Icarus would have had a problem with T-88,
although we know that Piets would take an eternity to climb close enough to
the sun to make a difference ;o)
Oscar Zuniga
San Antonio, TX
Subject: | LSA regs and tailwheell endorsements |
My uncle is currently a Student Pilot with about 12 hours.
He wants to stop training for a Private Pilot certificate, buy a LSA and
get a Sport Pilot certificate. We were talking and I told him that I am
seriously looking into getting my Sport Pilot Instructors certificate. If I
did I'd teach him in his aircraft.... BUT,
I'm wondering.... if he gets a taildragger (like a Kolb or Kitfox, etc.)
will he need a tailwheel endorsement?? and if so, would I (being a Sport
Pilot Instructor) be able to endorse him for tailwheel flight in his
airplane?
I'll give 1 minute of free advice (estimated value $.02) to anyone who can
answer my question ;)
DJ
www.imagedv.com/aircamper
N74DV
Subject: | Re: LSA regs and tailwheell endorsements |
DJ Just a piece of advice. Help him. Help him pick a CFI. Encourage
him. Fly with him. Answer his questions, but do not take the
responsibility of teaching him. Relatives are just too close for an
instructor to do their job properly. More often than not a CFI that is
not objective is either way too tough to be fair or too easy for the
students on good no matter how hard they try to be completely fair. It
can cause very hard feelings that can easily last.
>airplane?
>DJ
>N74DV
Possible sources
1) Oil from your compressor (rings and cylinder bore getting worn)
2) Are you using paper towels? Lots of brands are contaminated with Si.
3) Finger prints. You wouldn't believe how much contaminant is on your
fingers!
4) Contaminated shop rags
Possible solutions
1) Eliminate the above
2) Wipe with Prep Sol (Get it at a GOOD paint store. It's what they use in
auto paint shops)
3) Don't throw rocks at this one. I know it sounds totally STUPID but use
the paint you will be using on the part to clean the surface. I found this
out by accident after what you described happened several times in a row and
the finish was doing it AGAIN! I was so frustrated I literally wiped the
wet paint off with a clean rag and just blasted it with another coat. (Like
I said, I was really mad). The residual paint from the wiping was wetted
out by the new paint and leveled into a beautiful finish. I have pulled
this little trick several times since then when I couldn't get the surface
clean by any normal method and darned if it didn't work every time. I don't
know why it works and I sure don't let anybody see me do it but it has
worked. It's just embarrassing to admit I have done it. If it works for
you let me know. Heck let me know either way. It has yet to fail me when
nothing else works.
Hank J
> Group;
parts
something
imperfections.
> paint.
> Oscar Zuniga
> San Antonio, TX
In a message dated 3/14/2005 6:15:07 P.M. Central Standard Time,
aerialphotos(at)dp.net writes:
Sometimes that can be true but not always. I taught my daughter to fly and
it's something we've enjoyed together for years. We still get on pretty well
even though she's a professional pilot and I'm her chief pilot. I must admit
when we went through recurrent training last week and her V1 cuts were better
than mine it was hard to take.
It all depends on your relationship with your uncle. If neither of you have
your egos wrapped up in it you can have lots of good safe fun.
<423628CC.4050200(at)dp.net>
typically I can see that.... but my dad was my CFI and all went well.
We're a close family and we're good with stuff like this.
DJ
Subject: Re: Pietenpol-List: LSA regs and tailwheell endorsements
>>I
>>airplane?
>>DJ
>>N74DV
<423628CC.4050200(at)dp.net> <000601c528fb$beeecab0$0100a8c0@Desktop>
My old man taught me when I was 14 (39 years ago) and I'm still learning
tricks from pop! And I don't even dread having my 85 year old father
teaching me in an open cockpit airplane (when this Piet project is ready :)
At the rate I'm going, he'll be 86 before this puppy flys.
> DJ
> From: "Mark Blackwell" <aerialphotos(at)dp.net>
> To:
> Sent: Monday, March 14, 2005 5:14 PM
and
If
> >>I
Sport
> >>airplane?
can
> >>DJ
> >>N74DV
My opinion: Remember that when tranning the Instructor has to be VERY firm in
his corrections, and clases. The student life (in the future) could depends
on that trainning.
If you cant be firm enough without hurting feelings, dont do it.
But flights, with advice, once he got his ticket, are always welcome. This from
all pilots Newbes or "good" ones.
Saludos
Gary Gower
(Just do what you decide, maybe not a good opinion :-)
TomTravis(at)aol.com wrote:
In a message dated 3/14/2005 6:15:07 P.M. Central Standard Time, aerialphotos(at)dp.net
writes:
Sometimes that can be true but not always. I taught my daughter to fly and it's
something we've enjoyed together for years. We still get on pretty well even
though she's a professional pilot and I'm her chief pilot. I must admit when we
went through recurrent training last week and her V1 cuts were better than mine
It all depends on your relationship with your uncle. If neither of you have your
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Subject: | Scary GN-1 on ebay now......in Texas. |
d2$2c7c8b50$0564a8c0@rdci.az.home.com><423628CC.4050200(at)dp.net>
I like how the seller calls this a Pietenpol Air Camper when it is
not....and the fact that he says "easily repaired"
and "light wing damage". Oh right-----take a look at the photos. I
would steer way clear of this baby.
Mike C.
Subject: | here is the link....... |
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4534270000&category=63677&sspagename=WDVW
Subject: | Re: Scary GN-1 on ebay now......in Texas. |
Yo Mike,
Looks like an Aircamper to me... I thought the major difference was that
the GN-1 had a steel tube fuselage. This one's wood. I'm no expert, though,
so I readily admit ignorance if I a wrong. ;)
Anyway, I agree that this thing is crazy scary. Definitely NOT worth the
$6,500 buy-it-now price, or the current bid price of $4,000!!! Some people are
just suckers for a "good deal", and don't do their homework before they open
their wallets. Too bad...
-Wayne
In a message dated 3/15/2005 8:00:09 AM Central Standard Time,
Michael.D.Cuy(at)grc.nasa.gov writes:
Mike C.
GN-1s can be built with steel or wood fuselages, just like Pietenpols.
This one is definitely a GN-1. I wouldn't touch this one with a 10'
pole. If the lift strut fittings borke, the spars are definitely
suspect. With a broken prop, I would always wonder about the engine
(even though wood props supposedly take the strain that a metal prop
would impart to the crankshaft).
Jack Phillips
N925WB1(at)aol.com
Subject: Re: Pietenpol-List: Scary GN-1 on ebay now......in Texas.
Yo Mike,
that the GN-1 had a steel tube fuselage. This one's wood. I'm no
expert, though, so I readily admit ignorance if I a wrong. ;)
the $6,500 buy-it-now price, or the current bid price of $4,000!!! Some
people are just suckers for a "good deal", and don't do their homework
before they open their wallets. Too bad...
-Wayne
Mike C.
the easiest way to tell a GN-1 from a Piet is the landing gear. On the Piet the
front and rear tubes of the gear meet up at the lift struts. On a GN-1 the
rear tube meets the fuselage in front of the rear lift strut. Thats because
GN-1's use a J-3 landing gear.
And yes... this one look spretty scary indeed. I'd give about $3000 for it.
Sent: Tuesday, March 15, 2005 7:13 AM
Yo Mike,
Looks like an Aircamper to me... I thought the major difference was that the
GN-1 had a steel tube fuselage. This one's wood. I'm no expert, though, so
Anyway, I agree that this thing is crazy scary. Definitely NOT worth the $6,500
buy-it-now price, or the current bid price of $4,000!!! Some people are just
suckers for a "good deal", and don't do their homework before they open their
wallets. Too bad...
-Wayne
In a message dated 3/15/2005 8:00:09 AM Central Standard Time, Michael.D.Cuy(at)grc.nasa.gov
writes:
Mike C.
Subject: | Aeropoxy over West System? Compatibility? |
Does anyone have any experience in using Aeropoxy OVER West System? I need to
add a couple of layers of fiberglass cloth on a fuel tank and I've run
bone-dry on West System epoxy resin and hardener but I have a fresh supply of
Aeropoxy PR2032 resin and PH3660 hardener (originally intended for something
else...)
S.B.
DJ,
Thanks for clearing that up for me. I learn something new all the time from
this list, even if I am just a casual observer!
BTW - I would assume then that the Pietenpol rear LG strut arrangement would
be stonger than that of the GN-1, as the landing loads would be trasmitted
throught the attach fittings, into the wing struts, through the wings, and
then back down on the other side, thereby creating a box (similar to a biplane
wing configuration) ; whereas the GN-1 loads would be completely absorbed by
the lower longeron, putting in it shear between the rear LG attach fitting,
and the rear strut attach point. Just a thought.
-Wayne
In a message dated 3/15/2005 8:56:09 AM Central Standard Time,
djv(at)imagedv.com writes:
Piet the front and rear tubes of the gear meet up at the lift struts. On a
GN-1 the rear tube meets the fuselage in front of the rear lift strut. Thats
because GN-1's use a J-3 landing gear.
From: | "Frank Metcalfe" <fmetcalf(at)bellsouth.net> |
Yes he will have to have and endorsement and if you have a tailwheel
endorement with your CFI you will be able to sgin him off...But only in LSP
aircraft
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of DJ Vegh
Subject: Pietenpol-List: LSA regs and tailwheell endorsements
airplane?
DJ
N74DV
thanks that's what I was thinking. I do have my endorsement so it looks
like all will be good.
DJ
Subject: RE: Pietenpol-List: LSA regs and tailwheell endorsements
LSP
> aircraft
> From: owner-pietenpol-list-server(at)matronics.com
> Sent: Monday, March 14, 2005 3:13 PM
I
> airplane?
> DJ
> N74DV
I've used both these systems over the years plus analyzed them as
competitors for composites applications. There would not be any problem of
using either of these two systems. Aeropoxy was one of the two systems
approved by Rutan for integral fuel tanks on his canard-pusher designed
homebuilts, and has functioned for close to 15 years. West is used mainly
in the marine industry and is used for fuel tanks. One tip- if the
epoxy/glass laminate you're trying to bond something to is shiny, you gotta
sand the surface to about 80 grit to get the next layer of epoxy/glass to
bond properly.
Gordon Bowen
Original Message:
Date: Tue, 15 Mar 2005 13:19:15 EST
Subject: Pietenpol-List: Aeropoxy over West System? Compatibility?
to
of
something
else...)
S.B.
Another thing that I do when gluing joints, using West System epoxy, is to
make a series of little indentations on each side of the joint using the corner
edge of my wood chisel. This gives the joint some more surface area and
"teeth." Seems to work very well.
When I started building my Piet I made a test joint of 1-inch by 1-inch
spruce in a typical longeron and upright joint with 1/8-inch ply gusset on=20both
sides. After only 24 hours I could not break the joint and so gave it to my
powerlifter son. Understand that he can squat or dead lift 500 pounds seemingly
easier than I can lift 50 pounds! He could not separate the joint. I then took
a
hammer to the joint and only succeeded in breaking away the unsupported
gusset material. I have determined that this glue and method is airworthy --- not
to mention that thousands of homebuilders have been using West System for years
under all kinds of conditions. But I've found that with all things having to
do with airplanes, it doesn't hurt to be a little nervous...
I started making the landing gear struts out of white ash the other day. What
made it special is that I'm using my great-grandfather's 1882 drawknife to
rough shape the leading and trailing edges of the white ash=E2=80=94basically just
rounding off the corners but with a little more taper to the rear. (Wonder what
great-gramps would think of building an airplane=E2=80=94or airplanes in general!)
A drawknife works very well for this task as long as it is sharp and you work
with the grain. (White ash will tell you very quickly if you're going against
the grain.) I really felt a connection with the "old timers" using this method
=E2=80=94no shrieking, growling power tools. Just a quiet swish, swish of sharp
steel. Very relaxing. But don't relax with a drawknife -- you wouldn't want=20to
cut
off an important body part -- or stain that beautiful wood by bleeding all
over it!
Just think! Only four months, one week and a day or so to Brodhead '05! "Git
'er done!"
Fred B.
Wayne,
You have hit on another way you can tell a GN1 from a Piet.
Use the ebay link below and check out the picture of the inside of the cockpit.
You will see an extra upright about 6 or 8 inches from another upright. Grega
had to put the extra upright in so there would be an upright intersecting the
lower longeron at both L/G and lift strut locations.
GN1s also have 2 fairing strips down the side of the fuselage where Piets only
have one.
Skip
BTW - I would assume then that the Pietenpol rear LG strut arrangement would be
stonger than that of the GN-1, as the landing loads would be trasmitted throught
the attach fittings, into the wing struts, through the wings, and then back
down on the other side, thereby creating a box (similar to a biplane wing configuration)
; whereas the GN-1 loads would be completely absorbed by the lower
longeron, putting in it shear between the rear LG attach fitting, and the rear
-Wayne
The landing strut loads go into the fuselage. When the wing stops lifting it
becomes a dead weight pressing downwards. That load goes down the strut
to the fuselage as well. " All roads lead to Rome." as the saying goes.
Sent: Tuesday, March 15, 2005 12:50 PM
DJ,
be stonger than that of the GN-1, as the landing loads would be trasmitted throught
configuration) ; whereas the GN-1 loads would be completely absorbed by the lower
-Wayne
In a message dated 3/15/2005 8:56:09 AM Central Standard Time, djv(at)imagedv.com
writes:
the front and rear tubes of the gear meet up at the lift struts. On a GN-1
the rear tube meets the fuselage in front of the rear lift strut. Thats because
Subject: | Prop carving machine on Ebay |
Ebay item number 4534710618 http://pics.ebaystatic.com/aw/pics/s.gif" WIDTH="12" HEIGHT="1" BORDER="0" DATASIZE="49">
Does anyone have experience with making this device? Pros - cons?
Sterling
Subject: | Prop carving machine |
> From: N321TX(at)wmconnect.com
> Subject: Pietenpol-List: Prop carving machine on Ebay
> Thanks,
> Sterling
I don't have experience but I have been gathering info on a propeller
duplcator. Check out this website. More pics and their store if you
click on the link at the bottom. It will give you a good look at what
is in the prop carving plans;
http://www.wood-carver.com/oshkosh.html
Anyone with a bit of talent could eyeball engineer the same thing
without a set of plans. That's probably why you can't tell anything by
looking at the picture on ebay.
DocFont
Subject: | Re: Prop carving machine |
The plans on e-bay are the ones I used to make my carver.
I have used it for more than 10 years and done lots of props, for my planes and
friends.
I carve the basic cut, then they do the final sanding and balance, I just watch
them, all this for free, because I dont have the time to build their props
and they need to learn and work on them.
Works great, yuo just need to make a good flat table...
Very easy to build and inexpensive. Each router is good for about 3 to 5 props
(depends on the brand and quality) I use cheap home duty little routers, they
weight less.
Saludos
Gary Gower.
> Thanks,
> Sterling
DocFont
Subject: | Re: Prop carving machine on Ebay |
Found it! Finally! I knew I had plans for this somewhere.
I haven't made or used this thing yet but it looks pretty
simple. Below is the source;
Gary McGill & Associates
PO Box 2566
Glendale, AZ 85311-2566
gemcsr(at)juno.com
VW two cylinder engine conversion plans and parts.
Here's some other stuff;
http://users.lmi.net/~ryoung/Sonerai/Carve_Prop.html
http://www.flyingflea.org/docs/WoodenProps.htm
http://members.tripod.com/moasiaircraft/simple_propeller_design.htm
http://users.lmi.net/~ryoung/Sonerai/Glue_for_Props.html
http://www.kenfern.btinternet.co.uk/frame.htm
http://www.wood-carver.com/articles.html
And finally, my favourite;
http://www.woodenpropeller.com/index.html
Clif
Sterling
Subject: | Fw: Kitfox-List: West Epoxy System Warning |
I read the RV, Tailwind and KitFox lists just to see what the other guys are
up to. One poster added this comment about epoxy. He specifically names West
Epoxy, but West isn't the culprit, it's just the components in epoxy.
For what it's worth, it makes an interesting read. (I ALWAYS use gloves when
working around epoxy, MEK and acetone.)
Subject: RE: Kitfox-List: West Epoxy System Warning
> --> Kitfox-List message posted by: "Don Pearsall"
> Don, I have to echo your warnings to everyone. I built a KR-1 over 28
years
> ago, then a KR-2. Both are built using epoxy as the resin for fiberglass
> cloth (more flexible than polyester.) During construction, I did not wear
> gloves at all, and often had my hands and arms dripping with the stuff. It
> even got into my hair. I sensitized my hands after the KR-1. Every time I
> was exposed to the epoxy, or even its fumes, it was like someone poured
> scalding water over my skin. My skin would just act exactly like it was
> badly burned, and hurt as bad too. Luckily, the sensitized areas were just
> my hands and arms, but not ALL areas. There were patches of my skin that
> were not affected.
> Needless to say, after the KR-2, I said bye-bye to building composite
> planes.
> To this day, many years later, I still get burned by just being near epoxy
> fumes. And I sure do not work with it.
> So I sympathize with you Don! I hope your face heals quickly. Did you go
to
> a Dr yet? Maybe there is something they can do to make it heal faster.
> Don Pearsall
> From: owner-kitfox-list-server(at)matronics.com
> [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of
> AlbertaIV(at)aol.com
> To: kitfox-list(at)matronics.com
> Subject: Kitfox-List: West Epoxy System Warning
> --> Kitfox-List message posted by: AlbertaIV(at)aol.com
> I posted a few days back that I had another episode with West Epoxy.
Once
> a
> person becomes sensitized to epoxy, it is for life (that is per West
> Epoxy).
> A couple weeks ago, my Son wanted to fill a small crack on his boat and
I
> offered to help. He mixed it up while I watched close by. Even that
> close
> and it nailed me good. I have lost at least two layers of skin around my
> nose
> and mouth. Tonight, it had stopped peeling and starting to itch. I
gently
> rubbed my face to make it feel better and all of a sudden, I had two
> palmfuls
> of blood. There isn't enough skin left on my face to hold back the
blood.
> We've talked about MEK and other chemical we use and how bad they can
> be
> to an airplane builder. Trust me folks, you don't want to become
> sensitized
> to epoxy. West says that it will get worse and worse at each exposure.
> They are telling the truth.
> When you use this stuff, you better get into full dress with an
> external
> air source. I'm having a hard time understanding how they can even sell
> this stuff.
> BTW, I've used West Epoxy rarely on and off for years and it never
> bothered me until I built the Fox. I put out this warning tonight
because,
> quite
> frankly, I'm a bit worried this time. All you tough guys that might say,
> "stuff don't bother me". STAND-BY
> Don Smythe
Subject: | Re: Prop carving |
Clif,
Great post. I changed the title line for the archives.
Dan Hopper
Walton, IN
In a message dated 3/18/05 3:19:06 A.M. US Eastern Standard Time,
CDAWSON5854(at)shaw.ca writes:
PO Box 2566
_gemcsr(at)juno.com_ (mailto:gemcsr(at)juno.com)
_http://users.lmi.net/~ryoung/Sonerai/Carve_Prop.html_
(http://users.lmi.net/~ryoung/Sonerai/Carve_Prop.html)
_http://www.flyingflea.org/docs/WoodenProps.htm_
(http://www.flyingflea.org/docs/WoodenProps.htm)
_http://members.tripod.com/moasiaircraft/simple_propeller_design.htm_
(http://members.tripod.com/moasiaircraft/simple_propeller_design.htm)
_http://users.lmi.net/~ryoung/Sonerai/Glue_for_Props.html_
(http://users.lmi.net/~ryoung/Sonerai/Glue_for_Props.html)
_http://www.kenfern.btinternet.co.uk/frame.htm_
(http://www.kenfern.btinternet.co.uk/frame.htm)
_http://www.wood-carver.com/articles.html_
(http://www.wood-carver.com/articles.html)
_http://www.woodenpropeller.com/index.html_
(http://www.woodenpropeller.com/index.html)
Clif
Sterling,
I can't tell much from the poor photo on Ebay. I have a duplicator
(don't know if it is the same one)which is like a wooden box with 4 sides
made of 3/4 inch ply. The sides are hinged together and hinged to a
trolley. The trolley runs on 4 wheels made of pulleys that ride on
tracks made of 1/2 inch angle iron. The side opposite the side that is
attached to the trolley has a bullnose 1/2 inch probe attached to one
corner and a router with 1/2 inch core box bit attached to the other
corner. My description is probably as clear as mud, but this tool has
been used to make several good props and is as good as the operator. I
obviously was not the operator. I could bring it to Brodhead if you are
going to be there this year
Dick Hartwig
Waunakee, WI
From: | "Dick Navratil" <horzpool(at)goldengate.net> |
Subject: | A good day at the hangar |
I uncrated my new engine and did a first test fitting today. This is the Rotec
R-2800. I have attached a pic. It's starting to look like an airplane of sorts.
This is the fuselage that we built at Sun n Fun.
Dick N.
Subject: | Re: A good day at the hangar |
Dick,
my dad was considering that engine for his Fisher Celebrity project but ended up
opting for a Corvair. I sure am fond of those Rotec R-2800's They look
great!
DJ
Sent: Friday, March 18, 2005 3:15 PM
Subject: Pietenpol-List: A good day at the hangar
sorts. This is the fuselage that we built at Sun n Fun.
Dick N.
Very cool !! Good looking engine cant wait to see that on fly !!
[mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Dick Navratil
Sent: Friday, March 18, 2005 5:16 PM
Rotec R-2800. I have attached a pic. It's starting to look like an
airplane of sorts. This is the fuselage that we built at Sun n Fun.
Dick N.
Subject: | Well gone an did it today |
Well my day started off a bit differently. I picked up the phone before
making a final decision and talked to Don Peitenpol. I haven't started
a day in a better way in a very long time. Super guy that seems to love
aviation with a true appreciation of avation history. He should, he did
have a rather unique view of it. His willingness to answer questions
and his just generally being a nice man told me this really is the
airplane for me and I ordered the plans.
Ive never tackled a project like this, but Don was very encouraging. It
will be a while before I finally start cutting wood, but the first step
was taken today and would welcome any advise and recomendations on any
special tools I might need to make life easier.
Mark
Subject: | Re: Well gone an did it today |
Mark, congratulations, but don't wait too long after
getting the plans to start work on the project. Best
to get started as soon as possible. A small workshop
is helpful. I use my garage. A work bench. I use a
table saw frequently as well as a small band saw and a
miter saw. I also use a Dremel tool often. A tack
hamer and I use tweesers for holding the very small
nails for securing the gussetts on while the glue
dries. I also have a larger band saw with a metal
cutting blade for the metal work. I have an
acetylene/oxy torch with an "O" size welding tip to
make the welds with. I also use a Stanley
forming/shaping tool and a good wood rasp. Lots of
sand paper and a disc and belt sander are very
helpful. Lots of glue clamps for sure. These items
don't all have to be bought at one time, you can
acquire them over several weeks as you progress on the
project. You will love working on the plane and this
is coming from a guy who spent 32 years of flying and
had never built before in his life. It is a lot of
fun to build and does take a lot of time, but it is
far more fun than watching tv and much more rewarding
too. You will save big bucks if you go to the lumber
yard and purchase your wood there and cut the pieces
you need. Baltic birch is a great plywood. You can
get good A/C grade 1/16th inch birch ply from a good
hobby store. It takes more work this way, but you
will save a lot of money. Everyone on this list is
very helpful and will answer all your questions for
you, just ask. Best wishes and happy building.
Doc
It
> but the first step
> Mark
> Contributions
> any other
> Forums.
Thanks Dan. I'll be carving a prop soon. I just acquired a half VW
with about 10 hrs on it for $175. Guy smucked his plane ( Hummel )
left the engine with the fields owner in leu of money owed. Things
happened to it while sitting around so I've had it apart and back
together again, virtually no wear in the cylinders. Seems like a
good practice project for prop building.
----- Original Message -----
To: pietenpol-list(at)matronics.com
Sent: Friday, March 18, 2005 6:17 AM
Subject: Re: Pietenpol-List: Prop carving
Clif,
Dan Hopper
Walton, IN
In a message dated 3/18/05 3:19:06 A.M. US Eastern Standard Time, CDAWSON5854(at)shaw.ca
writes:
PO Box 2566
gemcsr(at)juno.com
Clif
Beautiful, Dick!
Jack
Dick N.
resources for learning what to keep and what not to? What is the
difference between aircraft grade ply and regular ply?
I have most of the tools you mentioned except the bandsaws and the
welder. I have soldered copper pipes to musical instruments, but never
welded. Like you Ive been a pilot for over 20 years but building is
something that the wife made me do around the house.
>Doc
> It
>>but the first step
>>Mark
>>Contributions
>>any other
>>Forums.
Mark,
Get a copy of EAA's Aircraft Building Techniques - Wood. While you're at
it, get all four of Tony Bingelis' books: The Sportplane Builder,
Sportplane Construction Techniques, Firewall Forward, and Tony Bingelis on
Engines. Other books I would recommend are the FAA's bible on aircraft
repair (which has a lot of information that can be applied to construction),
AC-43.13. The EAA's book on aircraft welding is useful (there is a
surprising amount of welding to be done on a wooden airplane), as is
PolyFiber's book on how to cover an aircraft.
If you can afford it, I would recommend two bandsaws - one for wood (and
aluminum) and one for steel. I already had a Sears 12" bandsaw which served
me well for the woodworking. I bought a cheap Grizzly metalcutting bandsaw
for about $200 and it did a fine job on all the steel parts. A good
beltsander with an abrasive disc is a "nice to have" tool for dressing the
edges of the steel parts, as well as finishing the wooden parts.
Good Luck to you! You are about to embark on an adventure few have known.
I can tell you that there is no better feeling in the world than feeling the
plane you have built with your own hands lifting off the runway and
responding to your control, just as you have imagined it.
Jack Phillips
Raleigh, NC
Covering the new stabilizer for NX899JP this morning
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark
Blackwell
Subject: Re: Pietenpol-List: Well gone an did it today
>Doc
> It
>>but the first step
>>Mark
>>Contributions
>>any other
>>Forums.
M ark
If you can make it to Sun n Fun, we will be building a Fuselage and tail
feathers for Gardiner Mason at the show. Come by and look or help. There
will also be demo's of building wing ribs or you can buy a completed set
from Chrlie at the show if you want.
Dick N.
Subject: Pietenpol-List: Well gone an did it today
> Mark
Mark, I found fairly good spruce at our lumber yard.
You will need to pick through the stack to find the
right pieces. Look for "quarter-sawn" lumber. That
is, lumber, from the end view point, has the rings
running across the end of the board like a ladder.
Often you will see the center of the tree on one end
of the board (again looking at one end of the board).
Count the rings and you should have at least 8 rings
per inch and they should run all the way to the other
end of the board without running off the edge of the
board. As few knots as possible (you will discard a
lot of board because of knots and pitch pockets, but
it is still cheaper this way). You are allowed small
knots (less than 3/8" diameter no closer than 3/8"
from the edge of the piece). Save the discarded
pieces as you can use smaller pieces for cross-members
in the project. I bought my small band saw off ebay,
but I had to do some work on it after I got it.
I used the pattern of the rib that comes with the
plans to form my rib jig, though some think the
pattern my not be accurate. I compared mine with the
coordinates and found it very close. Remember, it is
still an airfoil and will fly. You be the judge. You
will spend a lot of time building jigs, but that is
part of the fun. Just take your time and make it as
accurate as you can. I try to think ahead on the
project to prevent doing something that will have to
be changed later. So I spend more time thinking about
the project than I do in actually doing the work.
Before I started my project, I went through all my old
issues of Sport Aviation and ripped out all of the
articles on building tips and put them in a ring
binder for reference. I bought Bengelis book "Sport
Plane Builder" and find it helpful. The more you
read, the easier it will be to build
There is a lot of debate over the plywood issue. I
find that plain old baltic birch (from the lumber
yard, usually in 5' X 5' X 1/8" sheets, are plenty
strong for the large gussetts. A/C grade plywood will
say it is A/C grade on the label and I bought Midwest
brand at the hobby store. That is the 1/16" size for
the rib gussetts just to save on shipping. I bought
1/8" mahagony ply for the side panels again from the
lumber yard. I used 1/4" 5 ply baltic birch bought
from the lumber yard for the floor.
The EAA website has some great articles on gas welding
and with practice you will have no trouble welding.
Pratice is very impportant. You can go to the local
scrap metal yard and buy pratice material. I do
recommend you buy 4130 steel for the metal parts on
the plane however.
Hope this helps and good luck. If you would like some
building pics, I will be happy to email you some.
Doc
--- Mark Blackwell wrote:
> Id heard the local lumber yard was the place to go,
> but any good
> What is the
> ply?
> bandsaws and the
> but building is
> >>Contributions
> >>any other
> >>Forums.
> protection around
> Contributions
> any other
> Forums.
http://mobile.yahoo.com/maildemo
Mark, a few more hints if you wish to use them. I
bought 2 X 6 boards as base material. This gives you
plenty of board to cut your material from. I have a
used 10" table saw with a Diabalo finish cutting blade
to cut everything with and it works very well.
Remember to sand the plywood before gluing because
glue penetration is critical for a strong joint. The
plywood has a glaze that needs to be sanded off. A
few stroks with good sand paper is all it takes. Hope
this helps.
Doc
> but any good
> What is the
> ply?
> >>Contributions
> >>any other
> >>Forums.
> protection around
> Contributions
> any other
> Forums.
Salivated on unpainted 4130. Just as bad I suppose.
Subject: | BALTIC BIRCH--be careful |
I would suggest using caution if you are buying Baltic Birch for aircraft
building. The only Baltic Birch I have seen is interior grade and I use
a lot of Baltic Birch for cabinet making. I am not saying that there is
no such thing as Baltic Birch glued with waterproof glue, but any that I
have soaked in water has peeled apart. Just to make sure I was not
blowing smoke on this subject, I took a break from writing this and
sliced off a 1/16 inch strip from the edge of a beautiful sheet of 5/8
inch Baltic Birch. I placed it in a pan of boiling water. Within 3
minutes the laminations started popping apart. You can boil aircraft or
marine ply like this for an hour and it will not come apart. The only
non-aircraft plywood that I would recommend is 1088 spec. marine ply. or
good modeling ply such as Sig brand which is used in the model airplane
business. There are probably other good plys, but I would not use them
unless I performed boiling water tests on them.
The difference between aircraft/marine plywoods and other plywoods is not
only in the glues used to laminate them, but in the defects, patches and
voids that are allowed in the face veneers and interior laminations. I
am assuming when Doc said "A/C" plywood he meant "aircraft" plywood. If
you ask for "A/C" plywood at the lumberyard it just means that the
plywood has a face veneer on one side this is "A" (relatively defect
free/or plugged) and a lesser "C" quality veneer on the other side--not
the sort of ply you would want to use for primary aircraft structure.
When grading boards it is easy to see the lines caused by the annular
rings and to determine if they run from end to end (or 1" in 15"). There
is also grain running at 90 degrees to the annular rings. The only way
you can check that for run out is to cut a few inches off each end of
the board and split it with a chisel 90 degrees to the annular rings and
then measure for run out. I believe (without checking the book) run out
should be no more than one inch in 15 inches. Get a good book on grading
aircraft wood if you are not using certified woods.
Dick Hartwig
Subject: | Re: BALTIC BIRCH--be careful |
I did mean A/C to stand for "Aircraft." I do know of
several airplanes flying successfully with baltic
birch plywood for gussetts. I think the best test to
see if a material is adequate would be one designed to
simulate actual conditions under which it will be
used. I have subjected baltic birch test pieces under
rather high heat and high humidity with no major
problems. I protected the wood with polyurethane
varnish and allowed it to cure for at least one week
before the tests. I tried to simulate a test that
would be more likely to reflect actual conditions.
Sunlight is another stressor that needs to be tested,
which I did. Of course, my tests may not pass those of
professional engineers, but I am satisified with the
results. I'm sure that different manufacturing
companies produce different qualities of plywood, so
it would be difficult to make generalized statements.
The safest bet, of course, would be to buy certified
aircraft quality products...provided you have the
budget to do so. Safety is the key point, so any
non-certified materials must be tested (under
realistic condidions) to see if they are safe
materials to use.
Doc
> sure I was not
> writing this and
> water. Within 3
> the model airplane
> would not use them
> means that the
> (relatively defect
> the other side--not
> aircraft structure.
> rings. The only way
> Dick Hartwig
Subject: | "convert" program |
A year or so ago I offered a program to any one who wanted it. It's called "convert"
and it converts anything to anything. Any volume amounts, any weight amounts,
angles,speed, temp, torque, force, blah, blah, blah. Simple to use, even
the engineers got a kick out of it.
Any body that doesn't have it wants it, just post to the group, and I'll send it
to you directly.
It's about 1/2 meg, and don't want to clog up the group.
walt evans
NX140DL
I just ran up my engine for the first time today. C-90 with a 72CK42
Sensenich prop. Got 2200 rpm with the plane tied down. Is this about
what some of the rest of you are getting with a C-90? Got the engine
from Don's Dream Machines. Runs real smooth. They recommend a 72WGK42.
Do any of you know the difference? If both are about the same there is
no point in buying another prop.
Craig
NX899CL
From: | "Doyle Combs" <doylecombskeith(at)earthlink.net> |
Subject: | Re: "convert" program |
Walt, I would appreciate the convert program.
Doyle Combs
Sent: Sunday, March 20, 2005 4:41 PM
Subject: Pietenpol-List: "convert" program
amounts, angles,speed, temp, torque, force, blah, blah, blah. Simple to use,
even the engineers got a kick out of it.
it to you directly.
walt evans
NX140DL
Piet listers-
My 4 year old Pietenpol Air Camper (NX 899LW) is officially for sale!!
Last Thursday night I had a heart attack. Since my employment is now in question
and any chance of even being allowed to have a Sport Pilot license in the future
is pretty remote, I have decided that now would be a good time to find the
Piet a new home.
For those of you who don't know me or haven't been to Brodhead the past 3 years,
my Air Camper was featured in the Jan 2004 issue of Sport Aviation and the E.A.A.
is still using it's images in their subscription advertisements. It's the
one with the subtle yellow-with-red-scallops paint job!!
I will do my spring Condition Inspection within the next few weeks and it'll be
ready for the summer. I also have an extra prop, spare engine, rib jig, prop
duplicator and some other spares that are part of the package.
My asking price is $16,000 which seems to be reasonable for an insurance replacement
figure.
Since participating on this list indicates a more than casual interest in The Air
Camper, I'm hoping that one of you will pick up on this or pass the info along
to a friend. You're a great group of guys and I hope you can help me out.
Larry
Larry,
I'm extremely sorry to hear of your plight. You gave my daughter,
Sarah, a ride in your immaculate airplane last summer at Brodhead which
she will never forget. It is a phenomenal example of fine craftsmanship
rendered by a truly first-class individual, and I'm certain folks are
going to jump at the opportunity to own it. It is an absolutely
wonderful airplane.
John Ford
john(at)indstate.edu
812-237-8542
>>> lnawms(at)msn.com Monday, March 21, 2005 9:55:02 AM >>>
Piet listers-
question and any chance of even being allowed to have a Sport Pilot
license in the future is pretty remote, I have decided that now would be
a good time to find the Piet a new home.
3 years, my Air Camper was featured in the Jan 2004 issue of Sport
Aviation and the E.A.A. is still using it's images in their subscription
advertisements. It's the one with the subtle yellow-with-red-scallops
paint job!!
it'll be ready for the summer. I also have an extra prop, spare engine,
rib jig, prop duplicator and some other spares that are part of the
package.
insurance replacement figure.
in The Air Camper, I'm hoping that one of you will pick up on this or
pass the info along to a friend. You're a great group of guys and I hope
Larry
Subject: | VW based aircraft engine installation video on Ebay |
I just listed a Mosler Motors installation video on Ebay for $1.00. It shows the
installation of a Mosler 82X on an Avid Sportster.
I was hired to produce this video for Mosler Motors in 1990.
For anyone interested in VW based engines, this would be a good "educational" video,
even though Mosler is no longer in business. I also DO NOT RECOMMEND installing
a VW engine in a Pietenpol or a GN-1. You really need something with more
power.
See it on Ebay by typing in item number 4537719007.
Sterling Brooks
Knot-2-Shabby Airport & Texas Longhorn Cattle Ranch
5TA6, San Antonio Sectional
From: | "Dennis Engelkenjohn" <wingding(at)usmo.com> |
Damn Larry! That'll be enough of that stuff!!!
Did you ask our permission to have a heart attack? Well did you ? I think not!
Seriously though, I hate to hear that. From you or from anyone. An older person
I could handle, but Larry, you're relatively a young man. I hope you are doing
all right and feel bad you will have to give up flying. Was it so serious
you would give up flying altogether, including ultralights? This is devastating
news, cause if it happened to you, it could happen to me.
I really, really hope you will be alright.
Dennis Engelkenjohn
To: Pietenpol-List Digest Server
Sent: Monday, March 21, 2005 6:55 AM
Subject: Pietenpol-List: For sale
Piet listers-
future is pretty remote, I have decided that now would be a good time to find
E.A.A. is still using it's images in their subscription advertisements. It's
the one with the subtle yellow-with-red-scallops paint job!!
be ready for the summer. I also have an extra prop, spare engine, rib jig, prop
figure.
Air Camper, I'm hoping that one of you will pick up on this or pass the info
along to a friend. You're a great group of guys and I hope you can help me out.
Larry
I am also sorry to hear of your heart attack but as far as flying an
LSA (including any Piet), as long as you have not failed or been
denied an FAA physical all you need is a drivers license. Doesn't
matter if you have had a dozen heart attacks.
> Larry,
> wonderful airplane.
> John
> John Ford
> 812-237-8542
> Piet listers-
> paint job!!
> package.
> Larry
Rick Holland
"'Pietenpol-List Digest Server'"
Do you have any pictures posted anywhere?
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of LAWRENCE
WILLIAMS
Piet listers-
paint job!!
package.
replacement figure.
Larry
From: | mark thomson <buccaneer7(at)bellsouth.net> |
Netscape/7.2 (ax)
> called "convert" and it converts anything to anything. Any volume
> amounts, any weight amounts, angles,speed, temp, torque, force, blah,
> blah, blah. Simple to use, even the engineers got a kick out of it.
> I'll send it to you directly.
> walt evans
> NX140DL
Hi Walt ,LET me know all the proven weights and balanaces and airfoil
designs,that you have studied,I am very interaested in your knowledge
for the piet n pal...aircamper.
thanks so much...Mark
Look in the matronics photoshare. There are plenty! Try this [
http://www.matronics.com/photoshare/pietenpol-list.html#Top ] and
look into any of the Brodhead 2003 or 2004 posts. It'll be the really,
really nice red and yellow Piet with the tennis ball spinner...
John Ford
812-237-8542
>>> kgoff(at)arkansasusa.com Monday, March 21, 2005 8:36:08 PM >>>
LAWRENCE
WILLIAMS
Piet listers-
in
be
past
subscription
paint job!!
engine,
package.
insurance
replacement figure.
hope
Larry
I agree with Rick. This is the most common sense
legislation ever to come out of the FAA. You
sefl-certify that you are physically able to fly the
airplane and, with a valid drivers's lic., you can fly
under the rules of the Sporsman ticket. Do the
cardiac rehab and keep your risk factors in line and
you should be able to fly for a long time.
Doc
> far as flying an
> failed or been
> license. Doesn't
> wrote:
> > Larry,
> gave my daughter,
> an absolutely
> > wonderful airplane.
> > John
> > John Ford
> > 812-237-8542
> AM >>>
> > Piet listers-
> have a Sport Pilot
> 2004 issue of Sport
> > paint job!!
> > package.
> reasonable for an
> pick up on this or
> > Larry
> Rick Holland
> browse the many List
> Archive Search & Download,
> much more:
http://www.matronics.com/ListFeaturesNavigator?Pietenpol-List
http://info.mail.yahoo.com/mail_250
Larry,
Sorry to hear about your heart condition, but it's WAY too soon to sell your
plane !! Just do all the stuff the Doc says, and have a quick recovery. I
think the best way this list can help you out, is to encourage you to keep
NX899LW, and fly 'er under the new LSA rules...they are taylored to folks like
you.
It just seems to me, you would regret selling the ol' Piet...especially on
those beautiful calm evenings !!
Chuck G.
ETAsAhRXUsBxreHgvIpd3U+3l60qJiujcQIUC0DuCQOv4wJpqyP7btcxWYerOl4=
Hello Larry: Chuck is right. It is too early to think about selling. (
the other posts are right also) I had a heart attack 11 months ago. ( at
age 52!!) I thought it was the end of the world for me, but it was not.
I don't know what you do for a living, but I'm sure you can work that
out with your employer. Since I go barrelling down the road in an 80,000
lb monster, I figured no one wanted me out on the highway mixing with
school buses etc, but after being released, they tossed me the keys and
said go for it. I don't think any one works for a more cold heartless
company then I. Good luck. Leon Stefan the "cardiac cowboy" We are now
part of an elite pietenpol fraternity.
From: | "Jim Markle" <jim_markle(at)mindspring.com> |
Subject: | Cabane mounting help.... |
Ok, so my center section was already built when I inherited a fuse that was 1"
wider than plans.....so to keep the cabanes vertically straight, I had to add
a some space to the cabane attach fittings along the top longerons on each side.
So does anyone have an idea what's the best way to fill that space? I'm thinking
a round bushing (sort of like a REALLY thick washer). Or (and this is my preference...),
making a thick piece of Ash shaped kinda like the .040" fittings
I've embedded to the ends of the cabanes....basically "building out" the bottoms
of the cabanes to the "full" thickness...
I typically think about this sort of stuff for months before figuring it out but
my brain is tired and I want to finish this up....someone help me here.....
(I made the attached picture small so hopefully it won't cause any download issues
for anyone...)
Thanks!
Jim Markle
Plano, TX
214.505.6101
Subject: | Re: Cabane mounting help.... |
In a message dated 3/22/2005 5:41:49 PM Central Standard Time,
jim_markle(at)mindspring.com writes:
1" wider than plans.....so to keep the cabanes vertically straight, I had to
add a some space to the cabane attach fittings along the top longerons on each
side.
thinking a round bushing (sort of like a REALLY thick washer). Or (and this is
my
preference...), making a thick piece of Ash shaped kinda like the .040"
fittings I've embedded to the ends of the cabanes....basically "building out" the
bottoms of the cabanes to the "full" thickness...
but my brain is tired and I want to finish this up....someone help me here.....
issues for anyone...)
Thanks!
Jim Markle
Plano, TX
214.505.6101
Jim,
I've been studying your picture, and I see your dilemma. The picture
appears to be the front left lower cabane strut, with a hardware store bolt (used
for pre-fit). Why did you cut the end off the wood that forms the arch ?
I think the first thing to do, is consider all the possible remedies.
Here is the ones I thought of, in the order of their preference:
1) Slant the top of the cabanes inboard, while keeping the bolts in the
horizontal plane - so the wing will still move for & aft. The angle would be
maybe a quarter of a degree. This was my first thought, but I see you already
have the holes drilled in the cabanes. Although, you could use the next size
larger bolt, and file the holes top & bottom, (keeping them round) to maintain
a
horizontal hole....aw, scratch that thought...
2) Offset the upper end of the cabane struts outboard 1/4", and the lower
ends inboard 1/4", thus keeping the cabane struts vertical. This option would
be inline with the old carpenters adage - "Split the Difference". It may
require building new cabane fittings top and bottom.
3) Offset the lower end of the cabanes 1/2" to the inboard, such as your
picture indicates. I don't really like this option, because it seems it would
impart a bending moment on the lower fitting. I take it this would require a
1/2" joggle in the inboard strap fitting ? If you use the piece of Ash wood to
fill the 1/2" outboard difference, I think the Ash should glued into the
outboard sides of the cabanes, and be much longer up the cabane, maybe 4 or 5
inches, and blend into the cabane strut. Also, if you go with this option, I think
you should use the next thicker size inboard strap fitting, with the joggle
in it. The cabanes & fittings should be kept in shear, and with a joggle on
one side, and a bushing on the other side, it just doesn't seem like a good
shear fitting.
4) Build 4 new cabane struts, with the offset built in.
5) Build a new center section.
6) Build a new fuselage.
7) Go get another beer, and sit and look at it for a couple more hours...
Chuck G.
p.s. Jim, I know these parts were already built when you got them, but, OK,
I'm going to say it...This is the reason you hear so often - "Build it to the
Plans". Changes have a ripple effect on everything. One inch wider cockpit
will not make any difference in comfort.
not the answer you want to hear buit if it were me I'd either build a new center
section or make new cabanes that are thicker at the bottom and taper up towards
the top.
The latter option would be easiest and with the different types of wood used for
laminations it'd give a really cool look as the thicker laminations on the bottom
were tapered up at the top.. kinda like the look of a prop.
or.... maybe put your center section in one of those "wood stretchers" and pull
to the desired width ;)
DJ
Sent: Tuesday, March 22, 2005 4:40 PM
Subject: Pietenpol-List: Cabane mounting help....
preference...), making a thick piece of Ash shaped kinda like the .040" fittings
for anyone...)
Thanks!
Jim Markle
Plano, TX
214.505.6101
Thanks DJ and Chuck.......
I love getting these new ideas!!!....whether I use them or not, this gets me thinking
out of the box.....
I like the idea of building new cabanes with the offset built in and also the idea
of making the ash "spacer" taper up 4 or 5 inches....I'm thinking new cabanes
is the better of the two.....
Thanks guys!
And Chuck, that hole in the arch piece is where the arch piece cracked when the
plane was ground looped....seems both arches took more stress than they could
handle.....I've left them on while I build everything else just to keep as much
of "the look" as possible (I'll rebuild the front arch pieces). Having a hole
there did turn out nice for the picture though!
As I type this I'm implementing option 7 below.....I'll work out the others later....
Thanks again guys!
jm
Jim,
I've been studying your picture, and I see your dilemma. The picture appears
I think the first thing to do, is consider all the possible remedies. Here
1) Slant the top of the cabanes inboard, while keeping the bolts in the horizontal
plane - so the wing will still move for & aft. The angle would be maybe
a quarter of a degree. This was my first thought, but I see you already have
the holes drilled in the cabanes. Although, you could use the next size larger
bolt, and file the holes top & bottom, (keeping them round) to maintain a
2) Offset the upper end of the cabane struts outboard 1/4", and the lower ends
inboard 1/4", thus keeping the cabane struts vertical. This option would be
inline with the old carpenters adage - "Split the Difference". It may require
3) Offset the lower end of the cabanes 1/2" to the inboard, such as your picture
indicates. I don't really like this option, because it seems it would impart
a bending moment on the lower fitting. I take it this would require a 1/2"
fill the 1/2" outboard difference, I think the Ash should glued into the outboard
sides of the cabanes, and be much longer up the cabane, maybe 4 or 5 inches,
you should use the next thicker size inboard strap fitting, with the joggle in
it. The cabanes & fittings should be kept in shear, and with a joggle on one
side, and a bushing on the other side, it just doesn't seem like a good shear
fitting.
Chuck G.
Plans". Changes have a ripple effect on everything. One inch wider cockpit will
Chuck should have stated for option 7... "Go get a Guiness Stout and have a
Corona chaser...
<002801c52f5a$ff21e260$6401a8c0@FAMILY>
Don't forget that there's very little stress on that joint, 150 lb or so.
You do have to multiply that by any G you might pull, of course.
Most of the wing forces are taken by the outer spar/strut joint.
Your concern with that long bolt is bending of the bolt. If you check
the plans you will see that a 1/4" bolt is specified at that location.
You will also see that the strut is considerably narrower than the
space between the brackets and a bushing tube is specified all the
way across from bracket to bracket. The tube takes the bending
loads and the bolt, at the bracket/tube joint takes the shear stress
that bolts are supposed to handle, a division of labour if you will.
Even on a plans built fuselage you have 1 1/4" between the brackets.
The metal struts in the plans aren't even half that distance. Thus
the bushing tube.
The shear strength of that 1/4" AC grade bolt is 6133 lb. You have
two shear locations on that joint. with equal stress on each it can
handle 12266 lb.
Now the brackets themselves are 3/4" wide by 3/32" thick with a
1/4" hole. this means that the load bearing metal is 0.047 square
inches. The tensile strength of 4130 is 90,000 lb/sq in. Thus the at
bracket will handle 4218 lb. There are two of them per strut. There
are eight of them per airplane.
When the bolt is longer than a simple shear joint then bending is
introduced. That would throw all the carefull alignment effort out the
window maybe affecting the flying characteristics adversely and
causing other joints to bear more load than normal. Thus the
aforementioned bushing.
So, if you introduce that taper piece and carefully drill and bush it
with 1/4" ID tube you're away to the races ( haha).
Even if you make new cabanes you can't just center the things on
the bolts. You have to span the bracket space in such a way as to
have only shear loads on the bolts.
If you're interested in a graphic of the spanwise lift distribution of a
hersheybar wing it's half way down this page;
http://clifdawson.ca/Tools_and_Tips.html
#7 is good. I spent the afternoon with #7 and my favourite accountant,
who has reduced my tax load much closer to zero than I would have
thought possible.
Clif
thinking out of the box.....
idea of making the ash "spacer" taper up 4 or 5 inches....I'm thinking new cabanes
Thanks guys!
Subject: | Re: marvel shebler venturi |
Pieters: Does anyone have any experience in putting a new one piece venturi
in a marvel Schebler carb.I just got one and I suppose you must take out the
throttle shaft and press out the old one and press in the new one. Any
advice would help
Ken Conrad in cool Iowa with a little snow this morning
Jim,
I wouldn't go with a simple bushing or fat washer, cause any side "lever" forces
would put pressure on the center of the bolt where it's weakest.
better to bore the hole to the bushing OD , and have a long bushing go clear thru
the strut catching both plates on the side of the wood strut. Then to keep
the bottom of the strut in position, use a thin wall bushing over the exposed
part of the long bushing.
Kind of what was designed in the original plans offsetting the streamlined tube
to one side.
walt evans
NX140DL
Sent: Tuesday, March 22, 2005 6:40 PM
for anyone...)
Thanks!
Jim Markle
Plano, TX
214.505.6101
Be careful with that one. They had some problems and several AD's came
out because people were finding out first hand why the prop is on the
airplane. (Hint Its to keep the pilot cool. Let it stop and see if
they do not start sweating.) Might not be a legal requirement on a
homebuilt, but this one makes good sense.
> venturi in a marvel Schebler carb.I just got one and I suppose you
> must take out the throttle shaft and press out the old one and press
> in the new one. Any advice would help
Hey Walt
I'de like to have it
Barry
bed(at)mindspring.com
Sent: Sunday, March 20, 2005 5:41 PM
it to you directly.
walt evans
NX140DL
Hi Walt, I would like a copy if it's not too much
trouble. Thanks.
Doc
--- Barry Davis wrote:
> Hey Walt
> Barry
> From: walt evans
> who wanted it. It's called "convert" and it
> force, blah, blah, blah. Simple to use, even the
> to the group, and I'll send it to you directly.
> group.
> walt evans
> NX140DL
Netscape/7.2
Subject: | Conversion program |
Walt:
I'd appreciate a copy of it.
Dick Carden
Walt,
I'd like a copy also.
Brian
saddleguys(at)yahoo.com
Barry Davis wrote:
Hey Walt
Barry
to you directly.
walt evans
NX140DL
report
Walt,
If you'll send it to me I'd be glad to host it, then you can just
e-mail a link.
Steve Ruse
Dallas, TX
Very soon to be owner of N6383J
Quoting brian jardine :
> Walt,
> Brian
> Barry Davis wrote:
> Hey Walt
> Barry
> From: walt evans
> walt evans
> NX140DL
I upgraded my C-65 Piet to a C-90 from Don's Dream Machine's in
Georgia. Flew it with the new engine installed today. I haven't carried
a passenger yet, but the performance is improved dramatically. It's
getting of the ground in the length of the turnaround at the end the
runway. Might be 150ft. I'm not sure about the rate of climb, but I'm
flying of a 1,200ft strip and the angle of climb improved a bunch too.
I should be just fine with a normal sized passenger now. Should have
done this a long time ago.
Craig Lawler
<1f24e07859cc74e7ab2a3a948c56ec4a(at)ptd.net>
Craig,
I see by your email that you have prolog. Are you in eastern PA.?
walt evans
NX140DL
Subject: Pietenpol-List: C-90 Piet
> Craig Lawler
Subject: | Stromberg needles for Continental engines |
Here is a very good link in regard to arguments for stainless steel or Derlin or
Neoprene tipped needles in Stromberg carbs. The link mentions fuel additives
in auto gas is not specific to what additive except with a brief mention of alcohol.
I'm still trying to locate the info I found on the additives MTBE and
TAME and how is affects plastic and neoprene.
http://www.bowersflybaby.com/tech/stromberg%20needles1.pdf
Subject: | Elevator/rudder horns |
From: | "Textor, Jack" <jtextor(at)thepalmergroup.com> |
Happy Easter all,
Do the full size plans for the horns include the bend allowance to form the front
edge?
Thanks!
Jack Textor
well i may have the youngest piet builder around hes 15, and he wants to
build a piet.do you guys think its to big a job for a teen tom
Subject: | Re: teen builder |
Tom,
There are teens and then there are teens. You alone will have to judge the
ability of yours. I will say that I knew of a kid (pre teen ) who built a Model
T Ford Sporter from parts and had to wait 3 years before being legally old
enough to drive it (on the streets). Age really has nothing to do with it. If
he can imagine it he can build it.
Corky, the ole school teacher down on the bayou
In a message dated 3/27/05 12:24:24 P.M. Central Standard Time,
Isablcorky(at)aol.com writes:
Tom,
Model T Ford Sporter from parts and had to wait 3 years before being legally old
thanks corky the kid is pretty good with cars him and his brother built a
jaguar xj6 drag car with a 500 hp chevy sroker its pretty quick
but you cant pull over to the urb at 3000 ft
Tom,
I think building a homebuilt can be a great character builder for any young man
and the original wooden Piete is a great place to start. Starting a big project,
having the character to stick with the work no matter what the problems and
lastly seeing the end product of one's labors is an invaluable life learning
experience. Couple $100 worth of Sitka spruce, good wood working tools, plans
are all that's needed. If you're anywhere near Satsuma FL, I'll give the
young Eagle enough rough cut Sitka spruce to get started, if he's got the wood
working tools and desire to buy a set of plans. The wood's in hanger #8 at
Palatka Airport FL., so's my metal Piete. Building a plane can start a lifetime
of love of aviation, even if it takes a lifetime getting done. As I think
most of the fellow members of these web-user homebuilder groups would agree,
being an aviator is more than just being a pilot. Building a plane is as rewarding
on a daily basis as actually taking it for a spin around the pattern.
Gordon Bowen -Homer Alaska
Cozy IV N64CY
Osprey II N64SY
Pietenpol N-1033B Flew again on 3/12/2005
"Fanaticism consists of redoubling your efforts when you have forgotten your aim"
Sent: Sunday, March 27, 2005 9:11 AM
Subject: Pietenpol-List: teen builder
well i may have the youngest piet builder around hes 15, and he wants to build
Tom, I don't think age is as important as maturity.
If he is motivated and dedicated to the project, there
is no reason he couldn't build an award winning Piet.
Put him to building a few ribs and see how motivated
he is. It wouldn't cost much and he could get spruce
at the lumber yard that will do well for ribs. The
hobby store will have 1/16" Aircraft birch. I'd say
full steam ahead. It will be the young people who
will carry aviation into the future, not us old guys.
Doc
> 15, and he wants to
> a teen tom
He'll need a lot of perseverance to see it through to completion. I had the skills
to do something
like this as a teen, but I think it would have been hard for me to see a project
of this size through
to the final product.
I have a 14 year old whose only interest right now is to get this Corvair engine
together and see it run.
We put a long block together and then the Air Force sent me off to Flight Engineer
school last week
for the next six weeks. He's just itching for me to get back so we can wrench
on it. Somewhere along
the way I realized that we didn't orient the pistons properly and that we need
to take it apart and flip half
the pistons over. I was going to help him do it when I got back home. After reading
your post and thinking
about the things I was doing by myself when I was a young teen (building motors,
doing bodywork,
doing carpentry, plumbing and electrical work) I realized that I don't give him
enough leeway to let him
go and learn some of these things on his own. I'm always there supervising him
and if he runs into
trouble doing something I do it for him. As a result he doesn't have a lot of
confidence in being able
to accomplish anything on his own After thinking it over I called him and told
him to go ahead and
disassemble the motor and turn the pistons over. I know he can do it, it's just
the matter of letting
him do it on his own...
-Mike McCarty
Sent: Sunday, March 27, 2005 12:11 PM
Subject: | Re: teen builder (Go for it!) |
Not at all! He just need guidance and supervison from other builders, parents
and teachers:
Is something great to encourage, the best idea is to finish the proyect when they
are old enough (16 or more) to fly it.
In France there is a school and Assn. that promotes aviation betwen (very) young
boys:
http://www.chez.com/airetespace/
"Click" several pages in "Air et Space" until you find in the left side in "constructuin
colective" a two seater by several of the students and also in "constructions
Individuelles" you can see projects of Flying Fleas with builders
from 12 years old up, teached and helped by adults, but the project is all theirs,
imagine the potential of learning in this boys!!.....
Needs lots of cooperation from the Teachers and the Parents and support from the
Government(s).
In Europe in general Aviation Education with young boys and girls beguin very
early, including Soaring classes. Just like Music and Atheltic or Sports classes.
Saludos
Gary Gower
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
Yes, just cut them out per the plans, roll the edges (I hammered them over a
1/2" diameter steel rod), bend up the flanges and edge weld them, then drill
the holes. They are fun to make, very light and very strong. I don't
understand why anyone would use flat steel plate horns - too heavy.
Jack
Raleigh, NC
Covering the last aileron and getting ready to start re-painting NX899JP
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Textor,
Jack
Subject: Pietenpol-List: Elevator/rudder horns
Happy Easter all,
front edge?
Thanks!
Jack Textor
Subject: | Re: Pietenpol-List Digest: 2 Msgs - 03/26/05 |
Walt,
We have a 1,200ft strip located just east of Milton Pa.
Craig Lawler
As a former flight instructor I ran into this once in a while. I'd
never discourage a kid from wanting to reach for his dreams, but I'd
never turn a kid loose on something like this unless you or someone you
trust completely is helping him along the way.
Something like this reminds me of why I used to like fishing so much.
When I was in my teens, I spent many wonderful hours on a lake. I never
caught much, but I learned a lot about boating, water safety, and some
life saving techniques along the way. When I was 16, I got to take the
boat and go to the lake by myself under certain conditions. Man that
was something. Yet he didn't just turn me loose. He had taught me. He
controlled where I went and when. He checked up behind me and once in a
while he would, "just happen by the lake" and have his rod in the trunk
of the car to make sure I was where I said I was and following the rules
he had set. Id see the car, bring the boat in to pick him up and
usually there would be an hour of fishing left.
It was not till I hit my thirties that I realized the most important
part about fishing and boating was the time I got to spend with my dad
at a key time in my life. One of the tricks he showed me about life
saving on the lake, saved the life a young boy off the coast of South
Carolina. Looking back Id bet you find that building the airplane would
only be a fringe benefit.
> to build a piet.do you guys think its to big a job for a teen tom
Two good friends of mine have now "gone west". Their names were Maurice Fry
and John Davids, and both had impressive careers in aviation.
They grew up in Hartney, Manitoba, Canada and Maurice travelled to
Minneapolis, Minnesota where he took his flying training at Wold Chamberlin
airport during the summer of 1930. When he returned to Hartney with a
Private Pilot Licence, he and his friend, John, decided to build a Pietenpol
Air Camper. I'm not sure when they started construction, but Maurice made
the first three test flights on November 7, 1931. At that time the airplane
was unregistered and unlicenced. A local Royal Canadian Mounted Police
member told Maurice he would have register it and have it inspected by the
Department of Transport. This was done and the registration markings CF-ARH
were assigned. As far as we can determine, this Pietenpol was the first of
the type officially registered in Canada. It was powered by a Ford A engine
which, according to Maurice, gave somewhat marginal performance.
Building an airplane is an undertaking relatively few people carry through
to completion. Maurice and John's accomplishment is especially remarkable
because Maurice was only seventeen years old when he test flew his
creation--and John was just sixteen!
If a kid is fifteen years old and wants to build a Pietenpol, let him or her
do it. It has been done before.
Graham Hansen (Pietenpol CF-AUN)
Subject: | OT Giant RC B-52 has crashed - video |
remember the huge 25' wingspan 8 turbine powered radio controlled B-52? well
it has crashed.
what a shame
here's the video
http://www.warrixflyinggroup.co.uk/Video/August%2004/Broadband/b52.wmv
also a 20' span Cessna Caravan with turboprop power crashed on takeoff due to reversed
ailerons check it out
http://www.blinddumbanddeaf.com/Videos/ravencrash.mpg
DJ
Subject: | Re: Teen Builder |
> From: "Gordon Bowen" <gbowen(at)ptialaska.net>
> Subject: Re: Pietenpol-List: teen builder
> Tom,
young man
the wood
> working tools and desire to buy a set of plans. Building a plane
Greetings Gordon and the rest of the list
My Son is 10 and we are starting on a homebuilt. Plan is to build it on
the low budget system over the next mumble mumble years so it should be
ready to get him a sport pilot license when he is old enough. Low budget
because I am back in the poor college student phase of my life again
adding an RN degree to what I already have. Secondary plan is to use it
to show how all of this homeschool book learning stuff works in real
life. Tertiary plan is to use it as a way to teach him to use all the
fun toys in my harp, spinning wheel and medievil armor building shop.
Matthew is now 10 and has been helping me in the shop for years. At
first it was just, "Hand me that phillips screwdriver" type things but
he learned the names off all the tools. At 8 it was drill press,
catching boards coming out of the planer and power hand tools like the
router. Last year at age 9 he got to turn some simple pieces on the
metal lathe and started on the band saw. This year I will start on some
of the other saws and let him make some things he can sell on ebay and
at renassaince faires.
I've been involved with the renassaince faire/SCA market for 25 years.
That's me mentioned on the Argent Fox Harps webpage; www.argentfox.com/
We have lots of tools to play with. I noticed he's picked up 2 quotes
from time spent together in the shop. "I do good work." and "Uh, don't
tell mom." I noticed him using those expressions I normally use last
spring while we were building a big carved wooden sign and a 2'
illuminated clock that went with it.
Our plane project is a Woodys Pusher not a Pietenpol. Similar in terms
of speed and performance. The Woodys Pusher was designed in a time when
a lot of builders did not have a shop full of tools so many of the parts
were simplified. The Pietenpol is better designed in some ways so I am
using bits of pieces, like truss wing ribs in my project.
Gordon, can I buy a bit of that spruce next month? Woulda started buying
wood this month but my tuition was due last week. Next year Matthew will
be 12 by July and we planned to send him to EAA's aviation camp for a
week. I know a great kid who can use a few of those Young Eagle points
to help pay his tuition to camp if you know anyone with EAA Young Eagle
points.
DocFont, EAA 77755
yep, I think a 5 digit EAA number puts me in old timer, but not quite
geezer status
From: | Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> |
Subject: | San Fran Piet Project....guy needs assistance selling...... |
tlc1(at)well.com writes
>I am the executor of an estate of an elderly friend here in San Francisco.
>The estate includes a partially-built Pietenpol. I am seeking advice on
>how I might sell the Piet and what it might be worth. I think it is an Air
>Camper. The fuselage is complete, as is one wing and (I think) the
>elevators and rudder. There are wheels, too, but no engine. The components
>are located in San Francisco. I would appreciate any advice you might give
>me on how best to dispose of it. Are there any Pietenpol afficianados or
>experts here in the Bay Area that might be able to take a look at the Piet?
>Best regards,
>Tom Chester
>Thomas L. Chester
>1972 Tenth Avenue
>San Francisco, CA 94116
>(415) 665-7520, Cell (415) 806-3517
Subject: | Cabane diagonal struts |
What size round 4130 tubing would be adequate for the cabane diagonal
struts (to the top engine mount fitting)? I have some 3/4" .058 and
some 1" .049 laying around. Also, is their a tubing strength
comparison chart on line somewhere showing the different diameter/wall
thickness sizes?
Rick Holland
I want to do this too. Been thinking of the 0-200.
Stevee
clawler(at)ptd.net
Craig Lawler
To support any Young Eagles or well motivated "teenbuilder" who has adequate
motivation and supervision, I'll donate the wood currently in FL. It's
all excellent 2 yr dryed Kachemak Bay AK Sika spruce. But- rough cut 8.5'
max length (that's the length of my pickup bed), most 3/4" and some 1 1/2"
thick, varies from 4" to 8" wide. Mostly knot free but some small tight
knots. The problem for anyone interested is: 3-400 bf is in the hanger
Palatka FL, you gotta get it yourself somehow. My co-builder of Piete
N-1033B is at the airport everyday, contact Floyd at 386-325-3208, if you'd
like to come and pickup some wood, just put it to the good use of building
tomorrow's aviators.
Each year around Nov. I come south from Homer AK and bring down some wood
for friends that ask for it. It's all rough cut directly from the sawmill,
but hand selected by one of the most environmentally smart and wood savey
sawmillers I've ever had the pleasure go getting to know. It's excellent
wood for homebuilders who what to make something meaningful. So, if any of
you have good Young Eagles projects afoot and need wood, contact me prior to
Nov. each year and I'll see what I can do to get it to you for least cost or
free.
Cozy IV N64CY
Osprey II N64SY
Pietenpol N-1033B
aim"
Subject: Pietenpol-List: Re: Teen Builder
> > Tom,
> young man
the
> the wood
> points.
> DocFont, EAA 77755
> geezer status
From: | "Oscar Zuniga" <taildrags(at)hotmail.com> |
Howdy, Pieters;
I'm working on a smoke system for 41CC but in the meantime, for you smoke
fanatics who can handle video clips, you can take a look at a different type
of smoke system here (it's about a 1MB file):
http://www.flysquirrel.net/Babypowder.mpeg
If you've ever been around infants, you'll understand this (I'm from a
family of 10 kids myself).
Oscar Zuniga
San Antonio, TX
mailto: taildrags(at)hotmail.com
website at http://www.flysquirrel.net
Subject: | Re: smoke systems |
My neighbors are wondering what all the laughing is about....
This is great.....
Reminds me of some of the other not so pleasent "oops" occurances I've
experienced during "the process".....this is MUCH more tolerable.....
jm
Subject: Pietenpol-List: smoke systems
> Howdy, Pieters;
> type of smoke system here (it's about a 1MB file):
> Oscar Zuniga
> San Antonio, TX
Subject: | Ben Charvet's Piet/Douglas fir |
Ben wrote-
>I built an entire fuselage mock-up with some lumber yard douglas fir
>that I bought before I really knew what the recommendations were
>as far as grain slope, etc.
I looked at Ben's construction photos and everything looks real nice to me.
But beyond that, I am going to stick my neck waaaay out and ask why in the
world build that nice fuselage mock-up only to discard it due to some of the
wood grain slope being "out of spec"? It's fine to build a mock-up out of
scrap for trying out different configurations of things, and it's fine to do
it for the sheer practice and learning to build, but I don't believe I've
every read anything that says the grain slope is critical for any reason
other than to control twist/warpage due to changes in moisture content of
the wood UNLESS we're talking about wing spars. For a truss structure like
the fuselage, with short spans and everything cross-braced, grain slope as a
factor leading to twist or warpage would not only be insignificant, it would
have to all even itself out unless you intentionally aligned all the pieces
with the grain in the same direction... not very likely with that many small
pieces.
There are differences in bending strength when comparing loading parallel or
perpendicular to the grain, but for the fuselage structure where the loads
are tension/compression, I don't see that it would make a bit of difference.
If the stock is clear, knot-free, and has tight grain, I'd like to hear
(for the purpose of my own education) why it wouldn't be suitable for the
fuselage truss structure or even for the tail feathers (braced structures).
I will say this about Douglas fir though... it's a pain to make holes in it
when you're not drilling counter to the grain ("through the layers"). The
layers of grain differ significantly in hardness and the "hard layers" grab
your drill bit and offset the hole you're trying to drill if you don't use a
guide or a short, stiff bit with the work held securely. Having built the
entire structure of my "Flying Squirrel" out of 3/4" square stock fir, I've
made my share of slightly offset holes!
>There are three other Piets under construction within 40 miles of me
I must have missed it in your post. Where are you located?
Oscar Zuniga
San Antonio, TX
From: | "Ben Charvet" <bcharvet(at)bellsouth.net> |
Subject: | Re: Ben Charvet's Piet/Douglas fir |
Well, the mock-up looks real good in person too....and you're not the first
person to ask why the wood wasn't good enough. The grain run-out problems
were within a foot of the end of the longerons on 2 or 3 of them. If it had
been in the middle I might have been willing to take the chance. I figured
I had a chance of breaking off the tail in a hard landing, or losing the
engine and having a severe out of balance problem :). It probably would
have been fine, but at that stage of the project I wasn't sure if it was
March 01, 2005 - March 28, 2005
Pietenpol-Archive.digest.vol-ej
