Pietenpol-Archive.digest.vol-eq
August 16, 2005 - September 01, 2005
      appreciate if you would pass your secret around to those of us suffering from a
      bad case of the slows. Could be this 220 ft density altitude.
Subject: 65 hp props
Date: Aug 16, 2005
Hi Corky, I could be lying about it, I've had to repent of things I've said in ignorance before.... In any case I was flying at 74 mph with the sensenich, and now I'm indicating 80 in cruise with full throttle. I think I checked it with the GPS once. In either case, slow is slow, and 6 mph is usually chewed up with winds anyway. Autos on the freeway still pass me by. I am flying at 5-7000' regularly. Our field elevation is 4500'. Maybe my true airspeed is getting a boost being so close to the jet stream! /Silly Nonsense/-o Steve E ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Isablcorky(at)aol.com Subject: Re: Pietenpol-List: 65 hp props Mr. Steve, I had an A-65 Pietenpol and the only way I could have seen 80MPH was to have had someone pushing, flying straight down and just lieing about it. Would appreciate if you would pass your secret around to those of us suffering from a bad case of the slows. Could be this 220 ft density altitude. ________________________________________________________________________________
Date: Aug 16, 2005
Subject: Re: RE:
In a message dated 8/16/2005 7:13:59 AM Central Standard Time, harvey.rule(at)bell.ca writes: The word I have is 42 p and 72 length gives 2150 rpm 70 -71 mph at cruise 85-87 tops. That's about what I get from my homebuilt 72 X 42 prop, with Cont. A65 engine. I added aerodynamic fairings to the gear legs, and jury struts, and now I have to hold some forward stick pressure. I plan on removing the fixed trim tabs on the flippers. The fairings helped clean up the parasite drag, a little bit. Chuck G. NX770CG ________________________________________________________________________________
Date: Aug 16, 2005
Subject: Re: 65 hp props
Mike and everyone. For top speed, I've found that on the Piet the yaw is very critical. If the ball is a little off and you step on it, you can just feel a big change in speed. Also, at altitude if I push the stick forward slightly to get it "on step" (don't know if that's a real term , or we made it up) it really cranks. You'd swear it was diving/losing altitude but it's not. It flattens the low pressure arch over the wing and keeps you there. Anyone else do this? Going like a rocket in NJ : ) walt evans NX140DL ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: 65 hp props > > Chris- I use a wood 72-42 and it gives good climb performance and about a > 72 mph cruise speed at 2150 rpm. > > Mike C. > > > >What pitch prop are you running with an A65 ? I am leaning towards a 40 or > >42. Not sure which one will give me the RPM I desire. > >Chris Cummins > > > >__________________________________________________ > > ________________________________________________________________________________
Date: Aug 16, 2005
I had a Continental A 65 engine in my Pietenpol for the first few years and then installed a C 85 in order to have some reserve power on a hot day with a full load. The propeller used with the A 65 that gave the best results was a Sensenich 72CK42. I could get about 2150 rpm static and cruised at the same revs. At this power setting, it made about 74 mph in cruise and full throttle in level flight would give about 2250 rpm (short of the rated 2300 rpm of the A 65) and perhaps 78 mph tops. The Pietenpol is a bit draggy; a cleaner a/c like the Taylorcraft I once owned would top out at 95-100 mph at 2300 rpm with the same engine/propeller combination, and cruise almost 90 mph at 2150 rpm. Another propeller that gave similar results was a Flottorp 72A48 (the pitch numbers for different makes vary). A Flottorp 72A46 was pretty good, but the cruise dropped to about 70 mph at 2150 rpm. (If one cruised it at 2200 rpm, the cruise speed increased to that of the 72CK42, but fuel economy suffered.) A Sensenich 72CK44 was tried, but proved to be a bit too coarse pitch-wise and the climb rate suffered accordingly. With the A 65, the climb was never that good anyway, and in cruise with full load it was often necessary to add whatever excess power that was available to just maintain height! (The average elevation around here is about 2400' asl and the density altitude can get up there on a hot summer day.) Installing a C 85 made a huge difference to the overall performance of my Pietenpol--particularly in the climb, but it still is no speedster at about 80 mph with a 72x43 custom prop turning at 2300 rpm. However it is particularly nice to have power in reserve--a feature lacking with only 65 hp. A friend used a Warp Drive ground-adjustable propeller on his A 65-powered Pietenpol for several years and said he was able to optimize its performance rather easily. He broke the Warp Drive prop in a mishap and replaced it with a custom wooden one on the C 85 he has since installed. (I suspect he didn't like the appearance of the WD prop on the Piet, so didn't get new blades.) The Warp Drive propeller is a viable option. Shawn Wolk from Manitoba, Canada has one on his Pietenpol, and has reported his experience with it to this list. Has anyone else tried one? Graham Hansen (Pietenpol CF-AUN in cool, cloudy Alberta, Canada) ________________________________________________________________________________
Date: Aug 16, 2005
From: "Textor, Jack" <jtextor(at)thepalmergroup.com>
Walt, Your are right-on-step! It worked well in my 140, usually increasing the speed 5 mph. Sometimes when it wasn't stepping I could just deploy the flaps a smidge to get her going. Jack Textor ________________________________ Mike and everyone. For top speed, I've found that on the Piet the yaw is very critical. If the ball is a little off and you step on it, you can just feel a big change in speed. Also, at altitude if I push the stick forward slightly to get it "on step" (don't know if that's a real term , or we made it up) it really cranks. You'd swear it was diving/losing altitude but it's not. It flattens the low pressure arch over the wing and keeps you there. Anyone else do this? Going like a rocket in NJ : ) walt evans NX140DL ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: 65 hp props > > Chris- I use a wood 72-42 and it gives good climb performance and about a > 72 mph cruise speed at 2150 rpm. > > Mike C. > > > >What pitch prop are you running with an A65 ? I am leaning towards a 40 or > >42. Not sure which one will give me the RPM I desire. > >Chris Cummins > > > >__________________________________________________ > > ________________________________________________________________________________
Date: Aug 16, 2005
I've noticed that putting the nose down a little will increase speed without losing altitude. I've dropped the nose a little before, watched the speed go up and stay up (just a few MPH). I'll look at the altimeter after a few minutes, expecting to have lost a couple hundred feet, but I haven't lost any. I'll have to play with the yaw as well. I have to hold right rudder in climb, I need to add a little more trim tab to help keep my yaw down, I'm not always on top of it as much as I could be. Steve Ruse N6383J -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of walt evans Subject: Re: Pietenpol-List: 65 hp props Mike and everyone. For top speed, I've found that on the Piet the yaw is very critical. If the ball is a little off and you step on it, you can just feel a big change in speed. Also, at altitude if I push the stick forward slightly to get it "on step" (don't know if that's a real term , or we made it up) it really cranks. You'd swear it was diving/losing altitude but it's not. It flattens the low pressure arch over the wing and keeps you there. Anyone else do this? Going like a rocket in NJ : ) walt evans NX140DL ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: 65 hp props > > Chris- I use a wood 72-42 and it gives good climb performance and about a > 72 mph cruise speed at 2150 rpm. > > Mike C. > > > >What pitch prop are you running with an A65 ? I am leaning towards a 40 or > >42. Not sure which one will give me the RPM I desire. > >Chris Cummins > > > >__________________________________________________ > > -- -- ________________________________________________________________________________
Date: Aug 16, 2005
In a message dated 8/16/2005 7:52:20 PM Central Standard Time, wbeevans(at)verizon.net writes: Mike and everyone. For top speed, I've found that on the Piet the yaw is very critical. If the ball is a little off and you step on it, you can just feel a big change in speed. Also, at altitude if I push the stick forward slightly to get it "on step" (don't know if that's a real term , or we made it up) it really cranks. You'd swear it was diving/losing altitude but it's not. It flattens the low pressure arch over the wing and keeps you there. Anyone else do this? Going like a rocket in NJ : ) walt evans NX140DL Yes, I've found this to be true, too. Especially transitioning from climb to cruise. I always leave full power in until cruise speed is reached, then adjust power till no pressure is needed on the stick to maintain altitude. It planes out at about 63 mph indicated, which is actually about 72 or 73 mph. Some day I'll have to try to correct the ASI by adding an O-ring in front of the static port on the pitot / static probe. Chuck G. NX770CG ________________________________________________________________________________
Date: Aug 16, 2005
In a message dated 8/16/2005 10:29:12 AM Central Standard Time, steve(at)wotelectronics.com writes: I have two props for my A-75. One is a 68x38, the other is a 68x40. I get about 3,350rpm static with the 68x40, and about 50 more with the 68x38. The 68x40 gives me about 70mph in cruise (~2,500rpm), the 68x38 gives me about 65mph. Steve, Do you really get 3350 static rpm with those props ? That sounds very high for these small engines. I know they really crank 'em up to race with, but it shortens the life of the engine. Chuck G. NX770CG ________________________________________________________________________________
Date: Aug 17, 2005
So you would say that the 72X43 is my best choice for the 80 hp Franklin rather than the 72X42 right?(wood prop) ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham Hansen Subject: Re: Pietenpol-List: 65 hp props I had a Continental A 65 engine in my Pietenpol for the first few years and then installed a C 85 in order to have some reserve power on a hot day with a full load. The propeller used with the A 65 that gave the best results was a Sensenich 72CK42. I could get about 2150 rpm static and cruised at the same revs. At this power setting, it made about 74 mph in cruise and full throttle in level flight would give about 2250 rpm (short of the rated 2300 rpm of the A 65) and perhaps 78 mph tops. The Pietenpol is a bit draggy; a cleaner a/c like the Taylorcraft I once owned would top out at 95-100 mph at 2300 rpm with the same engine/propeller combination, and cruise almost 90 mph at 2150 rpm. Another propeller that gave similar results was a Flottorp 72A48 (the pitch numbers for different makes vary). A Flottorp 72A46 was pretty good, but the cruise dropped to about 70 mph at 2150 rpm. (If one cruised it at 2200 rpm, the cruise speed increased to that of the 72CK42, but fuel economy suffered.) A Sensenich 72CK44 was tried, but proved to be a bit too coarse pitch-wise and the climb rate suffered accordingly. With the A 65, the climb was never that good anyway, and in cruise with full load it was often necessary to add whatever excess power that was available to just maintain height! (The average elevation around here is about 2400' asl and the density altitude can get up there on a hot summer day.) Installing a C 85 made a huge difference to the overall performance of my Pietenpol--particularly in the climb, but it still is no speedster at about 80 mph with a 72x43 custom prop turning at 2300 rpm. However it is particularly nice to have power in reserve--a feature lacking with only 65 hp. A friend used a Warp Drive ground-adjustable propeller on his A 65-powered Pietenpol for several years and said he was able to optimize its performance rather easily. He broke the Warp Drive prop in a mishap and replaced it with a custom wooden one on the C 85 he has since installed. (I suspect he didn't like the appearance of the WD prop on the Piet, so didn't get new blades.) The Warp Drive propeller is a viable option. Shawn Wolk from Manitoba, Canada has one on his Pietenpol, and has reported his experience with it to this list. Has anyone else tried one? Graham Hansen (Pietenpol CF-AUN in cool, cloudy Alberta, Canada) ________________________________________________________________________________
Date: Aug 17, 2005
Work proceeding slowly but surely.Jury struts are now installed and braising wire lugs but I think I'll leave the braising wires till later since I have to move in that area quite a bit yet,they would just get in the way.I have to replace the plastic nylon tubing from the oil pressure gauge since the AME said that if it ever melted then I would have oil feeding a fire.Not a good situation.I have yet to reinstall the throttle /rich,lean control to the left side.I also have to replace the gas shut off valve and install an emergency shut off control.I have to cut that part of the wing off over the rear cockpit and install a hinge for flop over.I have to install a stirrup of some sort in order to get my stealthy little bod in the plane.I seen some good examples on this web and others.I havn't up my mind yet as to which method to use.I still have to put leather on the horizontal stab leading edge for the cable drag and I have to replace all the cones at the exit points for the rear control cables.I have to make one up for the underside of the wing on the right side as well since they are bigger than the other exit cones.I'm not using the same size all around.The ones that Spruce sent me where much smaller.I think they only have one size to fit all.Funny things they are too ;you have to cut out the part where the cable goes.I would have thought that part would already be cut out.I've gone around the whole plane and touched up the painting where it needed it so it looks real good now especially if your about 10 feet away from her.Even using exactly the same colour ,it's mighty hard to match especially since this plane has taken so long to build.Seat belts are all in and looking good.The instrument panel is still hanging loose till I can get that 1/8th copper tubing from Spruce.So as you can see,I'm making progress but I need time to get at her.I'm taking some days off this month and next hopefully I can finish before the snow flys.I don't have skiis for her so she will sit till spring .The N3 Pup has aquired a rebuilt 503 which has yet to be installed.I know what your thinking,the guys lost it ,regressing from 4 stroke to 2 stroke but that is the only solution I can see since the power to weight ratio is not condusive to my needs.You do what you have to do.I also have yet to repair the bent rods but the AME I'm working with seems to think that it's a piece of cake and the rod can be rose welded in order to make it worthy. Lots of work!I need to retire to get all this done but then I wouldn't have the money coming in to get it done either.Delemas,delemas.If I can ge the Peit done just before the snow flys then I may have time to get the N3 done and I'll fly that all winter since she is enclosed. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham Hansen Subject: Re: Pietenpol-List: 65 hp props I had a Continental A 65 engine in my Pietenpol for the first few years and then installed a C 85 in order to have some reserve power on a hot day with a full load. The propeller used with the A 65 that gave the best results was a Sensenich 72CK42. I could get about 2150 rpm static and cruised at the same revs. At this power setting, it made about 74 mph in cruise and full throttle in level flight would give about 2250 rpm (short of the rated 2300 rpm of the A 65) and perhaps 78 mph tops. The Pietenpol is a bit draggy; a cleaner a/c like the Taylorcraft I once owned would top out at 95-100 mph at 2300 rpm with the same engine/propeller combination, and cruise almost 90 mph at 2150 rpm. Another propeller that gave similar results was a Flottorp 72A48 (the pitch numbers for different makes vary). A Flottorp 72A46 was pretty good, but the cruise dropped to about 70 mph at 2150 rpm. (If one cruised it at 2200 rpm, the cruise speed increased to that of the 72CK42, but fuel economy suffered.) A Sensenich 72CK44 was tried, but proved to be a bit too coarse pitch-wise and the climb rate suffered accordingly. With the A 65, the climb was never that good anyway, and in cruise with full load it was often necessary to add whatever excess power that was available to just maintain height! (The average elevation around here is about 2400' asl and the density altitude can get up there on a hot summer day.) Installing a C 85 made a huge difference to the overall performance of my Pietenpol--particularly in the climb, but it still is no speedster at about 80 mph with a 72x43 custom prop turning at 2300 rpm. However it is particularly nice to have power in reserve--a feature lacking with only 65 hp. A friend used a Warp Drive ground-adjustable propeller on his A 65-powered Pietenpol for several years and said he was able to optimize its performance rather easily. He broke the Warp Drive prop in a mishap and replaced it with a custom wooden one on the C 85 he has since installed. (I suspect he didn't like the appearance of the WD prop on the Piet, so didn't get new blades.) The Warp Drive propeller is a viable option. Shawn Wolk from Manitoba, Canada has one on his Pietenpol, and has reported his experience with it to this list. Has anyone else tried one? Graham Hansen (Pietenpol CF-AUN in cool, cloudy Alberta, Canada) ________________________________________________________________________________
Date: Aug 17, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: Re: group photo at Brodhead with Javier
KEN ! So sorry for the ID difficulty> Glad to hear you surfaced. Great to meet you in person at Brodhead. Mike C. ________________________________________________________________________________
Date: Aug 17, 2005
Steve, You will need a little Right Rudder in a climb. Trim for the speed at which you will spend most of your time at--usually in cruise. Jim Dallas ----- Original Message ----- From: Steve Ruse<mailto:steve(at)wotelectronics.com> To: pietenpol-list(at)matronics.com Sent: Tuesday, August 16, 2005 9:47 PM Subject: RE: Pietenpol-List: 65 hp props I've noticed that putting the nose down a little will increase speed without losing altitude. I've dropped the nose a little before, watched the speed go up and stay up (just a few MPH). I'll look at the altimeter after a few minutes, expecting to have lost a couple hundred feet, but I haven't lost any. I'll have to play with the yaw as well. I have to hold right rudder in climb, I need to add a little more trim tab to help keep my yaw down, I'm not always on top of it as much as I could be. Steve Ruse N6383J -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com<mailto:owner-pietenpol-list-server(at)matronics.com> [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of walt evans Sent: Tuesday, August 16, 2005 7:51 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: 65 hp props Mike and everyone. For top speed, I've found that on the Piet the yaw is very critical. If the ball is a little off and you step on it, you can just feel a big change in speed. Also, at altitude if I push the stick forward slightly to get it "on step" (don't know if that's a real term , or we made it up) it really cranks. You'd swear it was diving/losing altitude but it's not. It flattens the low pressure arch over the wing and keeps you there. Anyone else do this? Going like a rocket in NJ : ) walt evans NX140DL ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov<mailto:Michael.D.Cuy(at)grc.nasa.gov>> To: > Sent: Tuesday, August 16, 2005 10:01 AM Subject: Pietenpol-List: 65 hp props > > > Chris- I use a wood 72-42 and it gives good climb performance and about a > 72 mph cruise speed at 2150 rpm. > > Mike C. > > > >What pitch prop are you running with an A65 ? I am leaning towards a 40 or > >42. Not sure which one will give me the RPM I desire. > >Chris Cummins > > > >__________________________________________________ > > > > > > > > > > > > > > -- -- ________________________________________________________________________________
Date: Aug 17, 2005
What rpm is the 80 hp franklin rated at? Chris > > From: harvey.rule(at)bell.ca > Date: 2005/08/17 Wed AM 07:43:49 EDT > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: 65 hp props > > So you would say that the 72X43 is my best choice for the 80 hp Franklin > rather than the 72X42 right?(wood prop) > > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham > Hansen > Sent: August 16, 2005 9:36 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: 65 hp props > > > > I had a Continental A 65 engine in my Pietenpol for the first few years > and then installed a C 85 in order to have some reserve power on a hot > day with a full load. > > > > The propeller used with the A 65 that gave the best results was a > Sensenich 72CK42. I could get about 2150 rpm static and cruised at the > same revs. At this power setting, it made about 74 mph in cruise and > full throttle in level flight would give about 2250 rpm (short of the > rated 2300 rpm of the A 65) and perhaps 78 mph tops. The Pietenpol is a > bit draggy; a cleaner a/c like the Taylorcraft I once owned would top > out at 95-100 mph at 2300 rpm with the same engine/propeller > combination, and cruise almost 90 mph at > > 2150 rpm. > > > > Another propeller that gave similar results was a Flottorp 72A48 (the > pitch numbers for different makes vary). A Flottorp 72A46 was pretty > good, but the cruise dropped to about 70 mph at 2150 rpm. (If one > cruised it at 2200 rpm, the cruise speed increased to that of the > 72CK42, but fuel economy suffered.) > > > > A Sensenich 72CK44 was tried, but proved to be a bit too coarse > pitch-wise and the climb rate suffered accordingly. > > With the A 65, the climb was never that good anyway, and in cruise with > full load it was often necessary to add whatever excess power that was > available to just maintain height! (The average elevation around here is > about 2400' asl and the density altitude can get up there on a hot > summer day.) > > > > Installing a C 85 made a huge difference to the overall performance of > my Pietenpol--particularly in the climb, but it still is no speedster at > about 80 mph with a 72x43 custom prop turning at 2300 rpm. However it is > particularly nice to have power in reserve--a feature lacking with only > 65 hp. > > > > A friend used a Warp Drive ground-adjustable propeller on his A > 65-powered Pietenpol for several years and said he was able to optimize > its performance rather easily. He broke the Warp Drive prop in a mishap > and replaced it with a custom wooden one on the C 85 he has since > installed. (I suspect he didn't like the appearance of the WD prop on > the Piet, so didn't get new blades.) > > > > The Warp Drive propeller is a viable option. Shawn Wolk from Manitoba, > Canada has one on his Pietenpol, and has reported his experience with it > to this list. Has anyone else tried one? > > > > Graham Hansen > > (Pietenpol CF-AUN in cool, cloudy Alberta, Canada) > > > ________________________________________________________________________________
Date: Aug 17, 2005
Franklin AC176s are 80 hp @ 2500 >From: <sbobka(at)charter.net> >Reply-To: pietenpol-list(at)matronics.com >To: >Subject: Re: RE: Pietenpol-List: 65 hp props >Date: Wed, 17 Aug 2005 11:44:10 -0400 > > >What rpm is the 80 hp franklin rated at? > >Chris > > > > From: harvey.rule(at)bell.ca > > Date: 2005/08/17 Wed AM 07:43:49 EDT > > To: pietenpol-list(at)matronics.com > > Subject: RE: Pietenpol-List: 65 hp props > > > > So you would say that the 72X43 is my best choice for the 80 hp Franklin > > rather than the 72X42 right?(wood prop) > > > > > > > > ________________________________ > > > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham > > Hansen > > Sent: August 16, 2005 9:36 PM > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: 65 hp props > > > > > > > > I had a Continental A 65 engine in my Pietenpol for the first few years > > and then installed a C 85 in order to have some reserve power on a hot > > day with a full load. > > > > > > > > The propeller used with the A 65 that gave the best results was a > > Sensenich 72CK42. I could get about 2150 rpm static and cruised at the > > same revs. At this power setting, it made about 74 mph in cruise and > > full throttle in level flight would give about 2250 rpm (short of the > > rated 2300 rpm of the A 65) and perhaps 78 mph tops. The Pietenpol is a > > bit draggy; a cleaner a/c like the Taylorcraft I once owned would top > > out at 95-100 mph at 2300 rpm with the same engine/propeller > > combination, and cruise almost 90 mph at > > > > 2150 rpm. > > > > > > > > Another propeller that gave similar results was a Flottorp 72A48 (the > > pitch numbers for different makes vary). A Flottorp 72A46 was pretty > > good, but the cruise dropped to about 70 mph at 2150 rpm. (If one > > cruised it at 2200 rpm, the cruise speed increased to that of the > > 72CK42, but fuel economy suffered.) > > > > > > > > A Sensenich 72CK44 was tried, but proved to be a bit too coarse > > pitch-wise and the climb rate suffered accordingly. > > > > With the A 65, the climb was never that good anyway, and in cruise with > > full load it was often necessary to add whatever excess power that was > > available to just maintain height! (The average elevation around here is > > about 2400' asl and the density altitude can get up there on a hot > > summer day.) > > > > > > > > Installing a C 85 made a huge difference to the overall performance of > > my Pietenpol--particularly in the climb, but it still is no speedster at > > about 80 mph with a 72x43 custom prop turning at 2300 rpm. However it is > > particularly nice to have power in reserve--a feature lacking with only > > 65 hp. > > > > > > > > A friend used a Warp Drive ground-adjustable propeller on his A > > 65-powered Pietenpol for several years and said he was able to optimize > > its performance rather easily. He broke the Warp Drive prop in a mishap > > and replaced it with a custom wooden one on the C 85 he has since > > installed. (I suspect he didn't like the appearance of the WD prop on > > the Piet, so didn't get new blades.) > > > > > > > > The Warp Drive propeller is a viable option. Shawn Wolk from Manitoba, > > Canada has one on his Pietenpol, and has reported his experience with it > > to this list. Has anyone else tried one? > > > > > > > > Graham Hansen > > > > (Pietenpol CF-AUN in cool, cloudy Alberta, Canada) > > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2005
Subject: Captain Gantzer Smoke Oil news
Guys--for give the slightly off-Piet post but the list has been dead anyway. For all of us smokers out there, I was just reading some posts on the International Coucil of Airshows discussion groups and there is a new oil out there that is cheaper and doesn't mess up the belly as bad as normal Texaco Canoupus #13. The link is here: http://www.noco.com/NOCO-MSDS/Prime_BL_Series.htm It is called NOCO BL50. They claim it burns whiter too than regular smoke oil. Another good post showed these oils as good smoke oils as alternatives: Quoted from a post on those lists: I like the Noco 50 but it's only up here in the NE USA usually. It's also a lot cheaper. Other types that you can use are: TELLUS 10 CASTROL Brayco 460 Shell Carnae-15, Vitrea 22, or Vitrea 13 Chevron ISO 15 Skywrite 19 Exxon Telura 612 and 613 G&G 853 Stay away from 1010 MIL-L-6081. This is only good for jets. It's not appropriate for civilian pilots and props. -David Schultz Airshows LLC ________________________________________________________________________________
Date: Aug 17, 2005
I don't have that info on me now,I'll have to get back to you with that one,thanks. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ed G. Subject: Re: RE: Pietenpol-List: 65 hp props Franklin AC176s are 80 hp @ 2500 >From: <sbobka(at)charter.net> >Reply-To: pietenpol-list(at)matronics.com >To: >Subject: Re: RE: Pietenpol-List: 65 hp props >Date: Wed, 17 Aug 2005 11:44:10 -0400 > > >What rpm is the 80 hp franklin rated at? > >Chris > > > > From: harvey.rule(at)bell.ca > > Date: 2005/08/17 Wed AM 07:43:49 EDT > > To: pietenpol-list(at)matronics.com > > Subject: RE: Pietenpol-List: 65 hp props > > > > So you would say that the 72X43 is my best choice for the 80 hp Franklin > > rather than the 72X42 right?(wood prop) > > > > > > > > ________________________________ > > > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham > > Hansen > > Sent: August 16, 2005 9:36 PM > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: 65 hp props > > > > > > > > I had a Continental A 65 engine in my Pietenpol for the first few years > > and then installed a C 85 in order to have some reserve power on a hot > > day with a full load. > > > > > > > > The propeller used with the A 65 that gave the best results was a > > Sensenich 72CK42. I could get about 2150 rpm static and cruised at the > > same revs. At this power setting, it made about 74 mph in cruise and > > full throttle in level flight would give about 2250 rpm (short of the > > rated 2300 rpm of the A 65) and perhaps 78 mph tops. The Pietenpol is a > > bit draggy; a cleaner a/c like the Taylorcraft I once owned would top > > out at 95-100 mph at 2300 rpm with the same engine/propeller > > combination, and cruise almost 90 mph at > > > > 2150 rpm. > > > > > > > > Another propeller that gave similar results was a Flottorp 72A48 (the > > pitch numbers for different makes vary). A Flottorp 72A46 was pretty > > good, but the cruise dropped to about 70 mph at 2150 rpm. (If one > > cruised it at 2200 rpm, the cruise speed increased to that of the > > 72CK42, but fuel economy suffered.) > > > > > > > > A Sensenich 72CK44 was tried, but proved to be a bit too coarse > > pitch-wise and the climb rate suffered accordingly. > > > > With the A 65, the climb was never that good anyway, and in cruise with > > full load it was often necessary to add whatever excess power that was > > available to just maintain height! (The average elevation around here is > > about 2400' asl and the density altitude can get up there on a hot > > summer day.) > > > > > > > > Installing a C 85 made a huge difference to the overall performance of > > my Pietenpol--particularly in the climb, but it still is no speedster at > > about 80 mph with a 72x43 custom prop turning at 2300 rpm. However it is > > particularly nice to have power in reserve--a feature lacking with only > > 65 hp. > > > > > > > > A friend used a Warp Drive ground-adjustable propeller on his A > > 65-powered Pietenpol for several years and said he was able to optimize > > its performance rather easily. He broke the Warp Drive prop in a mishap > > and replaced it with a custom wooden one on the C 85 he has since > > installed. (I suspect he didn't like the appearance of the WD prop on > > the Piet, so didn't get new blades.) > > > > > > > > The Warp Drive propeller is a viable option. Shawn Wolk from Manitoba, > > Canada has one on his Pietenpol, and has reported his experience with it > > to this list. Has anyone else tried one? > > > > > > > > Graham Hansen > > > > (Pietenpol CF-AUN in cool, cloudy Alberta, Canada) > > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2005
dumb answer since if I had just read the letter correctly I would have noticed the answer is right there! > >I don't have that info on me now,I'll have to get back to you with that >one,thanks. > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ed G. >Sent: August 17, 2005 12:21 PM >To: pietenpol-list(at)matronics.com >Subject: Re: RE: Pietenpol-List: 65 hp props > > >Franklin AC176s are 80 hp @ 2500 > > > > >>From: <sbobka(at)charter.net> >>Reply-To: pietenpol-list(at)matronics.com >>To: >>Subject: Re: RE: Pietenpol-List: 65 hp props >>Date: Wed, 17 Aug 2005 11:44:10 -0400 >> >> >>What rpm is the 80 hp franklin rated at? >> >>Chris >> >> >>>From: harvey.rule(at)bell.ca >>>Date: 2005/08/17 Wed AM 07:43:49 EDT >>>To: pietenpol-list(at)matronics.com >>>Subject: RE: Pietenpol-List: 65 hp props >>> >>>So you would say that the 72X43 is my best choice for the 80 hp >>> >>> >Franklin > > >>>rather than the 72X42 right?(wood prop) >>> >>> >>> >>>________________________________ >>> >>>From: owner-pietenpol-list-server(at)matronics.com >>>[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of >>> >>> >Graham > > >>>Hansen >>>Sent: August 16, 2005 9:36 PM >>>To: pietenpol-list(at)matronics.com >>>Subject: Re: Pietenpol-List: 65 hp props >>> >>> >>> >>>I had a Continental A 65 engine in my Pietenpol for the first few >>> >>> >years > > >>>and then installed a C 85 in order to have some reserve power on a >>> >>> >hot > > >>>day with a full load. >>> >>> >>> >>>The propeller used with the A 65 that gave the best results was a >>>Sensenich 72CK42. I could get about 2150 rpm static and cruised at >>> >>> >the > > >>>same revs. At this power setting, it made about 74 mph in cruise and >>>full throttle in level flight would give about 2250 rpm (short of >>> >>> >the > > >>>rated 2300 rpm of the A 65) and perhaps 78 mph tops. The Pietenpol >>> >>> >is a > > >>>bit draggy; a cleaner a/c like the Taylorcraft I once owned would >>> >>> >top > > >>>out at 95-100 mph at 2300 rpm with the same engine/propeller >>>combination, and cruise almost 90 mph at >>> >>>2150 rpm. >>> >>> >>> >>>Another propeller that gave similar results was a Flottorp 72A48 >>> >>> >(the > > >>>pitch numbers for different makes vary). A Flottorp 72A46 was pretty >>>good, but the cruise dropped to about 70 mph at 2150 rpm. (If one >>>cruised it at 2200 rpm, the cruise speed increased to that of the >>>72CK42, but fuel economy suffered.) >>> >>> >>> >>>A Sensenich 72CK44 was tried, but proved to be a bit too coarse >>>pitch-wise and the climb rate suffered accordingly. >>> >>>With the A 65, the climb was never that good anyway, and in cruise >>> >>> >with > > >>>full load it was often necessary to add whatever excess power that >>> >>> >was > > >>>available to just maintain height! (The average elevation around >>> >>> >here is > > >>>about 2400' asl and the density altitude can get up there on a hot >>>summer day.) >>> >>> >>> >>>Installing a C 85 made a huge difference to the overall performance >>> >>> >of > > >>>my Pietenpol--particularly in the climb, but it still is no >>> >>> >speedster at > > >>>about 80 mph with a 72x43 custom prop turning at 2300 rpm. However >>> >>> >it is > > >>>particularly nice to have power in reserve--a feature lacking with >>> >>> >only > > >>>65 hp. >>> >>> >>> >>>A friend used a Warp Drive ground-adjustable propeller on his A >>>65-powered Pietenpol for several years and said he was able to >>> >>> >optimize > > >>>its performance rather easily. He broke the Warp Drive prop in a >>> >>> >mishap > > >>>and replaced it with a custom wooden one on the C 85 he has since >>>installed. (I suspect he didn't like the appearance of the WD prop >>> >>> >on > > >>>the Piet, so didn't get new blades.) >>> >>> >>> >>>The Warp Drive propeller is a viable option. Shawn Wolk from >>> >>> >Manitoba, > > >>>Canada has one on his Pietenpol, and has reported his experience >>> >>> >with it > > >>>to this list. Has anyone else tried one? >>> >>> >>> >>>Graham Hansen >>> >>>(Pietenpol CF-AUN in cool, cloudy Alberta, Canada) >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Pietenpol Propellers
Date: Aug 17, 2005
Harvey, It seems your Franklin engine is rated 80 hp at 2500 rpm. My Continental C 85 is rated 85 hp at 2575 rpm, which makes them reasonably close. I get about 2450 rpm full throttle static and about 2550 rpm in level flight, full throttle. If the airplane were cleaner aerodynamically, I would exceed the rated rpm of 2575 quite easily. The propeller I am currently using is a Colin Walker 72x43 wooden prop. Unfortunately, Colin Walker (of Surrey, British Columbia) has retired. However, there is a rumour that somebody on Vancouver Island is going to take over his business. Colin made excellent propellers for many years and, if this is true, it is good news. I suspect that a 72x44 CW propeller would be just right for my airplane, but the 72x43 I have is OK. (Remember, a "43 inch pitch" number on one propeller may not match the same number on another make!) Getting the optimum fixed pitch wooden propeller for your airplane is a gamble. An aeronautical engineer friend said that usually a lot of different propellers need to be tested to find the best one, but this isn't an option for most of us. He also told me that Pietenpols don't do as well with certified production props as with custom-built ones. Metal props can be re-pitched; wooden props don't lend themselves to this kind of "tweaking". A ground-adjustable prop (eg. Warp Drive) pretty-well eliminates the gamble factor, but some don't like their appearance on a Pietenpol. You could go that route, as others have. If you can borrow a Sensenich 72CK 42 or 72CK44 for trials, you would then get an idea what prop you need for your particular airplane/engine combination. Either of these should be reasonably close to your requirement--at least for testing. Graham (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Aug 17, 2005
Borrowing a prop for a Franklin will probably be difficult. The AC 176 series Franklin's prop flange has a 4" X 6 X 3/8" bolt pattern..It is fairly unique to this engine. Believe it or not they were in production before Continental or Lycombing ( That's what I read anyway) so they don't use a SAE pattern..I guess they just made one up that looked good on paper...Ed Grentzer >From: "Graham Hansen" <grhans@cable-lynx.net> >Reply-To: pietenpol-list(at)matronics.com >To: >Subject: Re: Pietenpol-List: Pietenpol Propellers >Date: Wed, 17 Aug 2005 15:57:23 -0600 > >Harvey, > >It seems your Franklin engine is rated 80 hp at 2500 rpm. My Continental C >85 is rated 85 hp at 2575 rpm, which makes them reasonably close. > >I get about 2450 rpm full throttle static and about 2550 rpm in level >flight, full throttle. If the airplane were cleaner aerodynamically, I >would exceed the rated rpm of 2575 quite easily. > >The propeller I am currently using is a Colin Walker 72x43 wooden prop. >Unfortunately, Colin Walker (of Surrey, British Columbia) has retired. >However, there is a rumour that somebody on Vancouver Island is going to >take over his business. Colin made excellent propellers for many years and, >if this is true, it is good news. I suspect that a 72x44 CW propeller would >be just right for my airplane, but the 72x43 I have is OK. (Remember, a "43 >inch pitch" number on one propeller may not match the same number on >another make!) > >Getting the optimum fixed pitch wooden propeller for your airplane is a >gamble. An aeronautical engineer friend said that usually a lot of >different propellers need to be tested to find the best one, but this isn't >an option for most of us. He also told me that Pietenpols don't do as well >with certified production props as with custom-built ones. Metal props can >be re-pitched; wooden props don't lend themselves to this kind of >"tweaking". A ground-adjustable prop (eg. Warp Drive) pretty-well >eliminates the gamble factor, but some don't like their appearance on a >Pietenpol. You could go that route, as others have. > >If you can borrow a Sensenich 72CK 42 or 72CK44 for trials, you would then >get an idea what prop you need for your particular airplane/engine >combination. Either of these should be reasonably close to your >requirement--at least for testing. > >Graham (Pietenpol CF-AUN) > ________________________________________________________________________________
Date: Aug 17, 2005
Graham, The franklin will have a different bolt circle diameter so the props you mention will not fit. if he is doing a sensenich, it needs to be a W72F42 Chris > > From: "Graham Hansen" <grhans@cable-lynx.net> > Date: 2005/08/17 Wed PM 05:57:23 EDT > To: > Subject: Re: Pietenpol-List: Pietenpol Propellers > > Harvey, > > It seems your Franklin engine is rated 80 hp at 2500 rpm. My Continental C 85 is rated 85 hp at 2575 rpm, which makes them reasonably close. > > I get about 2450 rpm full throttle static and about 2550 rpm in level flight, full throttle. If the airplane were cleaner aerodynamically, I would exceed the rated rpm of 2575 quite easily. > > The propeller I am currently using is a Colin Walker 72x43 wooden prop. Unfortunately, Colin Walker (of Surrey, British Columbia) has retired. However, there is a rumour that somebody on Vancouver Island is going to take over his business. Colin made excellent propellers for many years and, if this is true, it is good news. I suspect that a 72x44 CW propeller would be just right for my airplane, but the 72x43 I have is OK. (Remember, a "43 inch pitch" number on one propeller may not match the same number on another make!) > > Getting the optimum fixed pitch wooden propeller for your airplane is a gamble. An aeronautical engineer friend said that usually a lot of different propellers need to be tested to find the best one, but this isn't an option for most of us. He also told me that Pietenpols don't do as well with certified production props as with custom-built ones. Metal props can be re-pitched; wooden props don't lend themselves to this kind of "tweaking". A ground-adjustable prop (eg. Warp Drive) pretty-well eliminates the gamble factor, but some don't like their appearance on a Pietenpol. You could go that route, as others have. > > If you can borrow a Sensenich 72CK 42 or 72CK44 for trials, you would then get an idea what prop you need for your particular airplane/engine combination. Either of these should be reasonably close to your requirement--at least for testing. > > Graham (Pietenpol CF-AUN) > > > ________________________________________________________________________________
Date: Aug 17, 2005
Chris and Ed, Harvey has an adapter on the Franklin which allows him to use the Continental props. It had been machined for that purpose. I saw it in May when I was at Ottawa and, at that time, a McCauley metal prop (for a Continental) was fitted. His friend, an Aircraft Maintenance Engineer (as I am), told him a wooden prop would be safer with that adapter. I agree with his engineer. Harvey bought his GN 1 in an advanced state of construction and all this stuff was done by the builder. It would be better if he could find a wooden Sensenich for the Franklin, but I think that is not too likely. A custom-built prop to fit the Franklin would, if he decides to go that route, allow him to ditch the adapter. Graham ________________________________________________________________________________
Date: Aug 18, 2005
That's correct;the man I bought it from told me that he didn't think the adaptor set up was all that safe and he felt that it was too heavy with the metal prop.So much so,that he felt there was a danger of tipping over easily.He suggested that I switch to a wooden prop and the AME that is helping me said that a wooden prop would also be smoother.So I'm in the market for a wood prop with either a 72X42 or 72X43 for the 80hp.I have sent out letters to both Sensenich and Tennessee and have received no info back.I believe that they want all the particulars with regards to bolt pattern etc.before they will get back to me.In one situation you have to fill out an order form first.So I have to wait till I can get back to the aircraft to glean all that info.I will be selling that McCauley prop if anyone is interested.And the adaptor as well.With a wood prop on I may be able to reinstall the starter.That ,however may just put me right back where I started with the danger of tipping.With the starter,the metal prop and adaptor on it will tip over unless I tie a rock to the rear,HAHAHA!I'd probably land up in the Redeau River eh guys! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham Hansen Subject: Re: Re: Pietenpol-List: Pietenpol Propellers <grhans@cable-lynx.net> Chris and Ed, Harvey has an adapter on the Franklin which allows him to use the Continental props. It had been machined for that purpose. I saw it in May when I was at Ottawa and, at that time, a McCauley metal prop (for a Continental) was fitted. His friend, an Aircraft Maintenance Engineer (as I am), told him a wooden prop would be safer with that adapter. I agree with his engineer. Harvey bought his GN 1 in an advanced state of construction and all this stuff was done by the builder. It would be better if he could find a wooden Sensenich for the Franklin, but I think that is not too likely. A custom-built prop to fit the Franklin would, if he decides to go that route, allow him to ditch the adapter. Graham ________________________________________________________________________________
Subject: Pietenpol Propellers
Date: Aug 18, 2005
I would opt for the ground adjustable only I found out from Perceptor during my engine exchange on the N3 Pup that direct drive likes to destroy ground adjustibles.It has something to do with the torgue.The blades will work loose and try to leave at the connection point.All good info I'm receiving noe with the present letters coming out.I should be able to get a pretty good handle on what to go after,thanks a million to everyone. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham Hansen Subject: Re: Pietenpol-List: Pietenpol Propellers Harvey, It seems your Franklin engine is rated 80 hp at 2500 rpm. My Continental C 85 is rated 85 hp at 2575 rpm, which makes them reasonably close. I get about 2450 rpm full throttle static and about 2550 rpm in level flight, full throttle. If the airplane were cleaner aerodynamically, I would exceed the rated rpm of 2575 quite easily. The propeller I am currently using is a Colin Walker 72x43 wooden prop. Unfortunately, Colin Walker (of Surrey, British Columbia) has retired. However, there is a rumour that somebody on Vancouver Island is going to take over his business. Colin made excellent propellers for many years and, if this is true, it is good news. I suspect that a 72x44 CW propeller would be just right for my airplane, but the 72x43 I have is OK. (Remember, a "43 inch pitch" number on one propeller may not match the same number on another make!) Getting the optimum fixed pitch wooden propeller for your airplane is a gamble. An aeronautical engineer friend said that usually a lot of different propellers need to be tested to find the best one, but this isn't an option for most of us. He also told me that Pietenpols don't do as well with certified production props as with custom-built ones. Metal props can be re-pitched; wooden props don't lend themselves to this kind of "tweaking". A ground-adjustable prop (eg. Warp Drive) pretty-well eliminates the gamble factor, but some don't like their appearance on a Pietenpol. You could go that route, as others have. If you can borrow a Sensenich 72CK 42 or 72CK44 for trials, you would then get an idea what prop you need for your particular airplane/engine combination. Either of these should be reasonably close to your requirement--at least for testing. Graham (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Aug 18, 2005
Harvey ..They both have on line order forms on their web sites at; www.sensenich.com and www.tn-prop.com..I bought from Tennessee because their price was half the price of a Sensenich uncertified prop without the brass leading edge..I set out to buy a Culver prop and found that Tennessee had bought them out...They have the template for the older Franklin hub..Which ever way you go make sure you stress your bolt pattern to them..The PLZ Franklins use an SAE pattern and when you say Franklin that's what they seem to think you need. I got mine several months ago and the workmanship in it is top notch and it has a nice classic shape to it...Ed Grentzer >From: harvey.rule(at)bell.ca >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: RE: Re: Pietenpol-List: Pietenpol Propellers >Date: Thu, 18 Aug 2005 07:19:39 -0400 > > >That's correct;the man I bought it from told me that he didn't think the >adaptor set up was all that safe and he felt that it was too heavy with >the metal prop.So much so,that he felt there was a danger of tipping >over easily.He suggested that I switch to a wooden prop and the AME that >is helping me said that a wooden prop would also be smoother.So I'm in >the market for a wood prop with either a 72X42 or 72X43 for the 80hp.I >have sent out letters to both Sensenich and Tennessee and have received >no info back.I believe that they want all the particulars with regards >to bolt pattern etc.before they will get back to me.In one situation you >have to fill out an order form first.So I have to wait till I can get >back to the aircraft to glean all that info.I will be selling that >McCauley prop if anyone is interested.And the adaptor as well.With a >wood prop on I may be able to reinstall the starter.That ,however may >just put me right back where I started with the danger of tipping.With >the starter,the metal prop and adaptor on it will tip over unless I tie >a rock to the rear,HAHAHA!I'd probably land up in the Redeau River eh >guys! > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham >Hansen >Sent: August 17, 2005 9:38 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Re: Pietenpol-List: Pietenpol Propellers > ><grhans@cable-lynx.net> > >Chris and Ed, > >Harvey has an adapter on the Franklin which allows him to use the >Continental props. It had been machined for that purpose. > >I saw it in May when I was at Ottawa and, at that time, a McCauley metal > >prop (for a Continental) was fitted. His friend, an Aircraft Maintenance > >Engineer (as I am), told him a wooden prop would be safer with that >adapter. >I agree with his engineer. > >Harvey bought his GN 1 in an advanced state of construction and all this > >stuff was done by the builder. > >It would be better if he could find a wooden Sensenich for the Franklin, >but >I think that is not too likely. A custom-built prop to fit the Franklin >would, if he decides to go that route, allow him to ditch the adapter. > >Graham > > ________________________________________________________________________________
Date: Aug 18, 2005
Since the engine is aimed downwards to about 3 degrees then if you are looking at your engine and it appears level then your plane would be down by about 3 degrees.Bringing the fusy up means now the plane is level while the engine is in it's normal configuration of down by 3 degrees and I believe that is why you are not loosing altitude.Your plane is now level.Don't look at the engine to see if your level because it's not.I believe I could be off a degree or two but this is what my plans indicate for motor mount.Correct? ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rcaprd(at)aol.com Subject: Re: Pietenpol-List: 65 hp props In a message dated 8/16/2005 7:52:20 PM Central Standard Time, wbeevans(at)verizon.net writes: Mike and everyone. critical. If the ball is a little off and you step on it, you can just feel a big change in speed. Also, at altitude if I push the stick forward slightly to get it "on step" (don't know if that's a real term , or we made it up) it really cranks. You'd swear it was diving/losing altitude but it's not. It flattens the low pressure arch over the wing and keeps you there. Anyone else do this? Going like a rocket in NJ : ) walt evans NX140DL Yes, I've found this to be true, too. Especially transitioning from climb to cruise. I always leave full power in until cruise speed is reached, then adjust power till no pressure is needed on the stick to maintain altitude. It planes out at about 63 mph indicated, which is actually about 72 or 73 mph. Some day I'll have to try to correct the ASI by adding an O-ring in front of the static port on the pitot / static probe. Chuck G. NX770CG ________________________________________________________________________________
Date: Aug 18, 2005
Excellent;thankyou very much.I will order from Tennessee then using the info Provided. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ed G. Subject: RE: Re: Pietenpol-List: Pietenpol Propellers Harvey ..They both have on line order forms on their web sites at; www.sensenich.com and www.tn-prop.com..I bought from Tennessee because their price was half the price of a Sensenich uncertified prop without the brass leading edge..I set out to buy a Culver prop and found that Tennessee had bought them out...They have the template for the older Franklin hub..Which ever way you go make sure you stress your bolt pattern to them..The PLZ Franklins use an SAE pattern and when you say Franklin that's what they seem to think you need. I got mine several months ago and the workmanship in it is top notch and it has a nice classic shape to it...Ed Grentzer >From: harvey.rule(at)bell.ca >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: RE: Re: Pietenpol-List: Pietenpol Propellers >Date: Thu, 18 Aug 2005 07:19:39 -0400 > > >That's correct;the man I bought it from told me that he didn't think the >adaptor set up was all that safe and he felt that it was too heavy with >the metal prop.So much so,that he felt there was a danger of tipping >over easily.He suggested that I switch to a wooden prop and the AME that >is helping me said that a wooden prop would also be smoother.So I'm in >the market for a wood prop with either a 72X42 or 72X43 for the 80hp.I >have sent out letters to both Sensenich and Tennessee and have received >no info back.I believe that they want all the particulars with regards >to bolt pattern etc.before they will get back to me.In one situation you >have to fill out an order form first.So I have to wait till I can get >back to the aircraft to glean all that info.I will be selling that >McCauley prop if anyone is interested.And the adaptor as well.With a >wood prop on I may be able to reinstall the starter.That ,however may >just put me right back where I started with the danger of tipping.With >the starter,the metal prop and adaptor on it will tip over unless I tie >a rock to the rear,HAHAHA!I'd probably land up in the Redeau River eh >guys! > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham >Hansen >Sent: August 17, 2005 9:38 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Re: Pietenpol-List: Pietenpol Propellers > ><grhans@cable-lynx.net> > >Chris and Ed, > >Harvey has an adapter on the Franklin which allows him to use the >Continental props. It had been machined for that purpose. > >I saw it in May when I was at Ottawa and, at that time, a McCauley metal > >prop (for a Continental) was fitted. His friend, an Aircraft Maintenance > >Engineer (as I am), told him a wooden prop would be safer with that >adapter. >I agree with his engineer. > >Harvey bought his GN 1 in an advanced state of construction and all this > >stuff was done by the builder. > >It would be better if he could find a wooden Sensenich for the Franklin, >but >I think that is not too likely. A custom-built prop to fit the Franklin >would, if he decides to go that route, allow him to ditch the adapter. > >Graham > > ________________________________________________________________________________
Date: Aug 18, 2005
Subject: Piet builders in North Dakota/Minnesota
Members of the list: I recently purchased a set of plans to build a Pietenpol. Anyone interested in assisting me in and or around the Detroit Lakes, Minnesota area? Would enjoy working with others to make this plane come to life. I am a native of Albany, Wisconsin just 7 miles to the west of Brodhead, WI They are some fantastic builders at that airport and well worth the time to visit. Anyone interested please contact me at 218-486-1963 Home or Work 701-364-9100 Ken Heide ________________________________________________________________________________ <002c01c5a0e1$9a1f3770$6401a8c0@FAMILY>
Date: Aug 18, 2005
Subject: New Piet(?) owner with questions
Dear Pietenpolers, My dad and a friend and I just bought a Pietenpol built in the late 70s. The plane had been regularly flown by the seller right up to the day that we bought it. He had purchased the plane from the widow of the builder, who died a few years ago. Hence, we cannot ask him some of the questions that I'm going to be asking on this list. Though the plane is registered as a Pietenpol Air Camper (two separate words), after trucking it home 1000 miles and upon close inspection, it appears to be a combination of Pietenpol and Grega designs - would that be a Griegenpol or a Priega? :) The only plans we have for it are Grega, but it's a plans set from the 80s, well after the plane had been flying, so this is not the plans that the plane was built from. The landing gear appears to be Pietenpol, with the fuselage lift strut fittings doing double duty as landing gear strut fittings. These fittings are connected with one another by a metal strap that runs under the fuselage directly under the cross-member that is visible from inside the cockpit. The strap is simply bolted to each fitting by two AN3 bolts running vertically through the wooden cross-member and floorboard. Our front strap is bowed/bent on the left side, halfway between the centerline and the left strut bracket. There are absolutely no other signs of damage or stress to the wooden or metal members attached to or surrounding this assembly, nor are there obvious signs of repair. We're not sure how this could be unless a hard landing years ago caused the strap to bend, and a bunch of repairs were made so expertly that they are not detectable. I guess it could have happened during the truck drive home, but if so, it was the only damage to anything on the plane. I've check with the seller, who was very up-front about other issues, and he says that the plane never had a damaging landing in the last three years, nor had he seen the bulge of the bent strap through the fabric (which is what we noticed once we got the plane home). Note that it's not easy to see - the plane is all white. Is there a consensus in the on the use of a steel strap running across and under the fuselage between strut fittings? Should we replace with another strap or maybe use angle, channel, or square tubing to prevent another bend? All thoughts are welcome and thanks for reading this far. Jeff ________________________________________________________________________________
Date: Aug 18, 2005
Subject: Re: Captain Gantzer Smoke Oil news
Hey Mikee, Thanks for the info !! Now I have to find out if it is available in town. Chuck G. ________________________________________________________________________________
Date: Aug 18, 2005
I have seen this once. In this case the bend was caused during a ground loop that put the gear in compression on one side. Normal flight loads have the bar in tension. In our case the other repairs needed solved the problem, but there was no wood damage. Probably worth investigating, but it may turn out to be minor. Steve e ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Subject: Pietenpol-List: New Piet(?) owner with questions Dear Pietenpolers, My dad and a friend and I just bought a Pietenpol built in the late 70s. The plane had been regularly flown by the seller right up to the day that we bought it. He had purchased the plane from the widow of the builder, who died a few years ago. Hence, we cannot ask him some of the questions that I'm going to be asking on this list. Though the plane is registered as a Pietenpol Air Camper (two separate words), after trucking it home 1000 miles and upon close inspection, it appears to be a combination of Pietenpol and Grega designs - would that be a Griegenpol or a Priega? :) The only plans we have for it are Grega, but it's a plans set from the 80s, well after the plane had been flying, so this is not the plans that the plane was built from. The landing gear appears to be Pietenpol, with the fuselage lift strut fittings doing double duty as landing gear strut fittings. These fittings are connected with one another by a metal strap that runs under the fuselage directly under the cross-member that is visible from inside the cockpit. The strap is simply bolted to each fitting by two AN3 bolts running vertically through the wooden cross-member and floorboard. Our front strap is bowed/bent on the left side, halfway between the centerline and the left strut bracket. There are absolutely no other signs of damage or stress to the wooden or metal members attached to or surrounding this assembly, nor are there obvious signs of repair. We're not sure how this could be unless a hard landing years ago caused the strap to bend, and a bunch of repairs were made so expertly that they are not detectable. I guess it could have happened during the truck drive home, but if so, it was the only damage to anything on the plane. I've check with the seller, who was very up-front about other issues, and he says that the plane never had a damaging landing in the last three years, nor had he seen the bulge of the bent strap through the fabric (which is what we noticed once we got the plane home). Note that it's not easy to see - the plane is all white. Is there a consensus in the on the use of a steel strap running across and under the fuselage between strut fittings? Should we replace with another strap or maybe use angle, channel, or square tubing to prevent another bend? All thoughts are welcome and thanks for reading this far. Jeff ________________________________________________________________________________
Date: Aug 18, 2005
Subject: Re: New Piet(?) owner with questions
In a message dated 8/18/2005 4:37:35 PM Central Standard Time, jboatri(at)emory.edu writes: Our front strap is bowed/bent on the left side, halfway between the centerline and the left strut bracket. Jeff, I had the same thing happen on my plane. I've seen it on other Pietenpol's, too. My strap is one piece, from lift strut fitting to lift strut fitting. I originally built it without any bolts down through the cross strap. I believe it is caused by hard landings, causing the wing panels to load the lift struts, and cross strap in compression, causing the slight buckle. Even though it isn't very much, it caused the incidence of the left wing to decrease, causing a slight left wing heavy condition. I repaired it by using three #10 bolts / washers (3/16" bolts) down through the Ash cross member and cross strap - one in the center, and the other two spaced evenly to the outboard. The left wing heavy went away, and I've had no problems ever since. The aft strap has plenty of hardware going through it to keep it from bowing down. The brake cylinders, front seat belt, and rudder bar support all have hardware going down through the aft Ash cross piece and cross strap. Chuck Gantzer NX770CG ________________________________________________________________________________
Date: Aug 18, 2005
Harvey, It is possible that Preceptor discouraged you from using a Warp Drive propeller on your N3 Pup because it had a direct drive two cylinder 4-stroke engine. With only two cylinders, the power impulses are going to be widely spaced. A friend has an N3 Pup with the two cylinder 40 hp Mosler which has relatively high compression and lots of "snap". I have never heard of such a restriction on a four cylinder direct drive engine and know of quite a few four cylinder Continentals (A 65, C 85, C90 & O200) that seem to be successfully mated to the Warp Drive props. I was thinking of getting a Warp Drive prop for my 65 hp Wag-A-Bond and you are instilling some doubts in my mind. Has anyone on the list any information on this? Graham (Pietenpol CF-AUN) ________________________________________________________________________________
Subject: Cruising "on the step".
Date: Aug 18, 2005
Walt & everyone, All four short fuselage Pietenpols I have flown were very sensitive in both pitch and yaw and, as you stated, concentration is required to get maximum cruise speed. With my Pietenpol, it is easy to fly "cockeyed" merely by having the ball only slightly off center.This costs some speed. At the end of a full throttle climb, I don't reduce power until I have established the cruising attitude, using as reference the position of the nose on the horizon and the relationship of the underside of the wing to the horizon. Speed is allowed to build up and power is gradually reduced to the desired level to avoid disturbing this somewhat delicate situation. The feel of the aircraft, as well as the ASI and altimeter readings (I don't have a VSI, but having one would help), will tell you when you are "on the step". Over fifty years ago, a bush pilot (I was his mechanic) showed me how to get a bit more speed in cruise by trimming the A/C (DeHavilland Beaver, in this case) slightly tail heavy, requiring a slight forward pressure on the yoke. I don't have elevator trim on my Piet, so this isn't an option--but I have tried it on Taylorcrafts, Aeroncas, etc. In any case, these techniques work well only when the air is smooth. When it is turbulent, all bets are off. With my Pietenpol, in rough air I'm lucky to keep it pointed in the intended direction! Graham Hansen (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Aug 18, 2005
Hi Graham, The advise has been that nobody should use this type of propellers in any VW engine. Only the wooden two blades type. The "Legend" (I use this word when I have no first hand info on something) says that this props will not act as a flywheel like the wooden propelers. This make the crankshaft to break. I dont mention the brand of propellers that where the first ones to fail because was not "that" brand of props in specific, were all of them. Off course I have not tested personally this failure, or used any ground ajustable one, in my past VW engines. Mainly because loosing a blade or a propeller in flight is a SERIOUS CG problem... I just use(d) wooden props in the VW conversions I built. Not the case for the Piet, because averyone is advised not to use the VW in the Piet... Not even with the Valley Reduction ;-) Saludos Gary Gower. Graham Hansen <grhans@cable-lynx.net> wrote: Harvey, It is possible that Preceptor discouraged you from using a Warp Drive propeller on your N3 Pup because it had a direct drive two cylinder 4-stroke engine. With only two cylinders, the power impulses are going to be widely spaced. A friend has an N3 Pup with the two cylinder 40 hp Mosler which has relatively high compression and lots of "snap". I have never heard of such a restriction on a four cylinder direct drive engine and know of quite a few four cylinder Continentals (A 65, C 85, C90 & O200) that seem to be successfully mated to the Warp Drive props. I was thinking of getting a Warp Drive prop for my 65 hp Wag-A-Bond and you are instilling some doubts in my mind. Has anyone on the list any information on this? Graham (Pietenpol CF-AUN) --------------------------------- ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: lift strut strap buckling
Date: Aug 19, 2005
Jeff, I too have seen this on many Piets, typically in the front strap. It must be hard landings where not only is the lift strut loading that strap in compression, but the gear bungee attachment is pulling that strut fitting down at the same time. I think this introduces a kind of downward "rolling" motion in that fitting which wants to buckle that belly strap. Most people just add more bolts. Interesting note, I've never seen it on a axle-geared Piet. Good luck Douwe ________________________________________________________________________________
Date: Aug 19, 2005
Subject: belly strap bowing
Jeff- congratulations on buying a Pietenpol. I've seen those straps do the same on my plane BEFORE it ever left my house. I suspect that as humidity levels in the air change that the wood fuselage expands and contracts accordingly (you can see this on the plywood of planes like the Spruce Goose.) and so the strap either bows or tightens in different conditions. My advice is not to worry about it and it really is only a backup in cases of severe turbulence or hard landings to prevent the bolts from ripping thru the ash cross members. Mike C. ________________________________________________________________________________
Date: Aug 19, 2005
There was a notice that came out a while back that the warp drive ground adjustable props where fracturing at the roots.That's what happened to Dave Stroud ,the guy who fly's the Christavia at our field.He now has a solid piece of lumber on the front. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham Hansen Subject: Re: Pietenpol-List: Pietenpol Propellers Harvey, It is possible that Preceptor discouraged you from using a Warp Drive propeller on your N3 Pup because it had a direct drive two cylinder 4-stroke engine. With only two cylinders, the power impulses are going to be widely spaced. A friend has an N3 Pup with the two cylinder 40 hp Mosler which has relatively high compression and lots of "snap". I have never heard of such a restriction on a four cylinder direct drive engine and know of quite a few four cylinder Continentals (A 65, C 85, C90 & O200) that seem to be successfully mated to the Warp Drive props. I was thinking of getting a Warp Drive prop for my 65 hp Wag-A-Bond and you are instilling some doubts in my mind. Has anyone on the list any information on this? Graham (Pietenpol CF-AUN) ________________________________________________________________________________
Subject: Builders in North Dakota / Minnesota
Date: Aug 19, 2005
Hi Ken, I would be very interested in sharing ideas with you as your project progresses, and maybe you could teach me a thing or two as well! I am in Fargo, ND and am only slightly farther along than you at this point - purchased plans about 4 months ago and have been working on getting the basement ready for the project and researching all that I can on building practices and Piet specific items. Just purchased the Tony Bengalis series while at Oshkosh and have been reading these the last few weeks. My rib jig is nearly complete and I was literally going to place the order for capstrip and ply for the ribs today. (I'll hold off now though until we can talk) I started this venture with another individual with the intent on building two aircraft side by side, and this may still happen once work slows down a bit this winter (he manages outside construction crews). Our intent was to be able to purchase materials together and ease the shipping charges. Neither of us are in a hurry to get them flying though and I am planning on about a 5 year project - wing ribs through this winter - tail surfaces next spring, fuse next fall, etc... The plan was that we would each work on a different jig and then swap jigs around as we completed phases. In talking with the local EAA chapter, I believe there is another Piet project in the area, but he is inactive on it (doesn't want to sell though...). Drop me an email at "danl(at)odayequipment.com" so we can chat - I'll be driving through tonight on my way to Ottertail - can't stop tonight, but I'll swing over some time with my Cardinal. Sure will be a blast to cruise the lakes with a flight of Piet's though! Dan Loegering From: Kenneth Heide <km> Subject: Pietenpol-List: Piet builders in North Dakota/Minnesota Members of the list: I recently purchased a set of plans to build a Pietenpol. Anyone interested in assisting me in and or around the Detroit Lakes, Minnesota area? Would enjoy working with others to make this plane come to life. I am a native of Albany, Wisconsin just 7 miles to the west of Brodhead, WI They are some fantastic builders at that airport and well worth the time to visit. Anyone interested please contact me at 218-486-1963 Home or Work 701-364-9100 Ken Heide _ ________________________________________________________________________________
Date: Aug 19, 2005
Subject: Re: lift strut strap buckling
Thanks to all those who responded. I think we'll replace the strap since we've already cut the fabric to assess damage. To avoid bends in the future, we'll probably replace the strap with angle or channel. -- Jeffrey H. Boatright, PhD Assistant Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Aug 19, 2005
<a06010228bf2bd47fe240@[163.246.59.196]> Jeff, My Piet has been flying for about 3 years now. I noticed that my straps, especially the front one, was bellied down before I ever took it to the airport. Think it's from a common mistake where you have the fuse upside down and making all the parts , and not realizing that when you finally tighten the brackets that support the wing struts,the landing gear, and connects the strap,,,that a little bit of compression that was not there before, bows that strap out a bit. You could remove the strap and open the holes, but that would defeat the purpose. The strap is made to take the load from the wing struts in an emergency. The wing load wants to pull the ash strip ,on the floor, apart. Incase the bolts let go you still have a continious "strap". If you want to repair, I would replace the flat strap with simular from the print. To use angle or channel would cause drag, look bad, blah blah. And since it's in tension (when needed) angle or channel won't add anything. walt evans NX140DL ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Subject: Re: Pietenpol-List: lift strut strap buckling > > Thanks to all those who responded. I think we'll replace the strap > since we've already cut the fabric to assess damage. To avoid bends > in the future, we'll probably replace the strap with angle or channel. > -- > > _____________________________________________________________ > Jeffrey H. Boatright, PhD > Assistant Professor, Emory Eye Center, Atlanta, GA, USA > Senior Editor, Molecular Vision, http://www.molvis.org/molvis > mailto:jboatri(at)emory.edu > > ________________________________________________________________________________
Date: Aug 19, 2005
Subject: Deep rambling thoughts
Anybody get to thinking ,,after you take people for a ride,, maybe during the drive home,, "They asked the same old questions, "you really built this by hand? From these prints? It's just glued together? How high can you go? What if the engine quits?"""" And you realize that you actually created each and every piece of this plane!!! Some build clocks, some boats, some jewlery boxes,,,but rarely is the builders "arse" accountable for the result. And I look at the plane and say to myself,,,"I actually fabricated each and every part of this plane". I'm proud of the way my plane came out. And I wish it was as good as others I've seen. but all through my building process, my Mentor's words rattled in my head every time I held the piece up and gave it a final look. " In building airplanes,,,there's no such thing as ""That's good enough"" (Dick Lawson EAA#272) walt evans NX140DL PS think about things like this when it's a rainy day, and know that winter's comming. Ain't life grand! ________________________________________________________________________________
Date: Aug 19, 2005
<a06010228bf2bd47fe240@[163.246.59.196]> Jeff, If the strap is bending because the wood is moving as some have suggested - maybe Mike C? - I would be careful about putting in a piece of metal that cannot bend. When the wood moves, and it will, if the metal won't move too then the wood is going to move something else. Dave At 02:26 PM 8/19/2005, you wrote: > >Thanks to all those who responded. I think we'll replace the strap since >we've already cut the fabric to assess damage. To avoid bends in the >future, we'll probably replace the strap with angle or channel. >-- > >_____________________________________________________________ >Jeffrey H. Boatright, PhD >Assistant Professor, Emory Eye Center, Atlanta, GA, USA >Senior Editor, Molecular Vision, http://www.molvis.org/molvis >mailto:jboatri(at)emory.edu > > >-- > > >-- incoming mail is certified Virus Free. ________________________________________________________________________________
Subject: gap seals
Date: Aug 19, 2005
I know that gap seals hve been discussed before, but I just want to ad a bit more to it. At Broadhead I had discussed my takeoff problems with a few of you. If I wasn't careful and didn't add power slowly, while pinning the stick foward, the plane would want to fly before it had the speed. This would cause the plane to want to stall at the ground. I thought this might be the way a Piet flew. After telling my story to the old timers sitting around after all had left, they told me not to look at moving the gear aft as I was thinking but to gap seal the elevators. I have piano hinge on the ailerions so I hadn't thought much about the elevators. After locating some duct tape at Brodhead I taped up the elevators. Right away it flew like a completely diffrent plane. It is much easier to handle on takeoff, tail comes right up and the stick is much lighter. On landing it is more responsive. In cruise it adds about 2 mph. My only question in all of this is, what to replace the duct tape with for a permanent addition? My first thought is a closed cell foam that we use at work as an expansion joint in concrete. Next might be strips of leather or a mylar tape. Any suggestions? Dick N. ________________________________________________________________________________
Date: Aug 19, 2005
Subject: Re: Deep rambling thoughts
In a message dated 8/19/2005 3:41:09 PM Central Standard Time, wbeevans(at)verizon.net writes: Anybody get to thinking ,,after you take people for a ride,, maybe during the drive home,, "They asked the same old questions, "you really built this by hand? From these prints? It's just glued together? How high can you go? What if the engine quits?"""" And you realize that you actually created each and every piece of this plane!!! Some build clocks, some boats, some jewlery boxes,,,but rarely is the builders "arse" accountable for the result. And I look at the plane and say to myself,,,"I actually fabricated each and every part of this plane". I'm proud of the way my plane came out. And I wish it was as good as others I've seen. but all through my building process, my Mentor's words rattled in my head every time I held the piece up and gave it a final look. " In building airplanes,,,there's no such thing as ""That's good enough"" (Dick Lawson EAA#272) walt evans NX140DL PS think about things like this when it's a rainy day, and know that winter's comming. Ain't life grand! Walt, I'm pretty sure that everyone who has completed and fly an airplane, has had these thoughts and questions posed to them. Some other popular questions are "How fast does it go ?", or "How far can you go ?" I think the general public views airplanes as methods to go farther and faster, and probably believe it is rather risky, too. Their beliefs are with merit. One thing John Q. Public seems to have difficulty comprehending, is the sheer joy of flight...until we take them up for a ride in a Pietenpol !! The sights, sounds, and feelings are truly one of a kind. As far as completing and flying a homebuilt airplane, Mr. Lawson offers some very good advise. I think for most of us it is a major lifetime accomplishment, second only to raising a family. It will be one of the legacy's we will be remembered for when we are gone. It is a Very unique accomplishment, due in large part to the EAA, that is not even possible in most other parts of the world. The Freedom we have here in America is one to be cherished. Yes, Life is Grand !! Chuck Gantzer NX770CG ________________________________________________________________________________
Date: Aug 19, 2005
Subject: Re: gap seals
Dick, I made empenage gap seals for my plane while in the construction phase, therefore I can't compare the performance to being without the empenage gap seals. Here is an area where I varied from the plans just a little, but I didn't want to endorse the change till I had some flight time on the plane. Curse me all you purists !! We all know how important it is to seal the gaps at the ailerons. I used the plans barn door hinges, and sealed the aileron gaps with a strip of 3" fabric tape, centering it over the gap, before painting. Now, I just didn't like the big gaps at the hinges of the elevators (flippers) and rudder. I used the same method I used when building model planes, I call it a 'Double Monocoat Hinge'. I used Vi Kappler aluminum hinges, and after building and fitting the control surfaces, before covering, I glued a triangle piece of bulsa wood to the trailing edge of the horiz & vert stabs, and the leading edge of the flippers and rudder, leaving a gap of 1/4" between the tips of these triangle pieces, in line with and the same diameter as the hinge pins. I then covered all the flight surfaces in the conventional manner, assembled the flight surfaces with the pins, then glued a fabric strip down each slope of the triangle piece, across the gap, then up the other triangle piece, and trimmed it. I did this on the top and the bottom, so two layers of fabric bridge the 1/4" gap, right on the hinge line. Advantages: 1) It seals any air from leaking at the hinge, when the flight surface is deflected, therefore less deflection is needed, thus reducing drag. 2) It is a secondary attachment of the flight surfaces, in the event of a hinge failure, and keeps the hinge pins from working out, even if the cotter key is gone. 3) It prevents any sticks or stuff from becoming lodged in the hinge area, when operating out of unimproved strips. 4) Hawks don't have any gaps in their tail. 5) I included a picture. Chuck G. NX770CG ________________________________________________________________________________
Date: Aug 19, 2005
Rcaprd(at)aol.com wrote:In a message dated 8/19/2005 3:41:09 PM Central Standard Time, wbeevans(at)verizon.net writes: Anybody get to thinking ,,after you take people for a ride,, maybe during the drive home,, "They asked the same old questions, "you really built this by hand? From these prints? It's just glued together? How high can you go? What if the engine quits?"""" And you realize that you actually created each and every piece of this plane!!! Some build clocks, some boats, some jewlery boxes,,,but rarely is the builders "arse" accountable for the result. And I look at the plane and say to myself,,,"I actually fabricated each and every part of this plane". I'm proud of the way my plane came out. And I wish it was as good as others I've seen. but all through my building process, my Mentor's words rattled in my head every time I held the piece up and gave it a final look. " In building airplanes,,,there's no such thing as ""That's good enough"" (Dick Lawson EAA#272) walt evans NX140DL PS think about things like this when it's a rainy day, and know that winter's comming. Ain't life grand! Walt, I'm pretty sure that everyone who has completed and fly an airplane, has had these thoughts and questions posed to them. Some other popular questions are "How fast does it go ?", or "How far can you go ?" I think the general public views airplanes as methods to go farther and faster, and probably believe it is rather risky, too. Their beliefs are with merit. One thing John Q. Public seems to have difficulty comprehending, is the sheer joy of flight...until we take them up for a ride in a Pietenpol !! The sights, sounds, and feelings are truly one of a kind. As far as completing and flying a homebuilt airplane, Mr. Lawson offers some very good advise. I think for most of us it is a major lifetime accomplishment, second only to raising a family. It will be one of the legacy's we will be remembered for when we are gone. It is a Very unique accomplishment, due in large part to the EAA, that is not even possible in most other parts of the world. The Freedom we have here in America is one to be cherished. Yes, Life is Grand !! Chuck Gantzer NX770CG ******************************************* Yes Chuck and Walt, Same Questions Worldwide! Is amazing... Also I think that the "risky" feeling to airplanes is caused by the Movies... Almost 98% of the movies where a GA airplanes flyes... yes, will crash! then the movie's trama beguins... Also how many cars have been lost, because everytime (in the movies) a car gets fire.... It expodes as it was full of dinamite!!! When a car beguins to burn, just a simple coke (shaking to pressurise) will stop the fire. They dont explode. Well, flying is great, sharing the flight its greater... Saludos Gary Gower. ________________________________________________________________________________
Date: Aug 19, 2005
Subject: Continental 65 or 85 eyebrow patterns
If anyone needs the eyebrow patterns for a 65 or 85 Continental engine, please contact Tom Schildt at 337/989-8148. I have them and will be out of town until Sept. 20. Thank you, Jim Cooper ________________________________________________________________________________
Date: Aug 20, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Walt--- great story. You're absolutely right. You know all the 'stick time' that we accumulate during the building process ? Well in all the times I was sitting there moving the stick around on the ground I it never once crossed my mind that something should break......but on climb-out during my first flight I suddenly got this unwarranted sense of caution that those wing struts are holding the entire weight of me, my fuel, my engine, my fuselage, and my landing gear...and if they should fail now, I'm going down. After rationalizing to myself that I knew that I knew that every part of the plane was made to the best possible standards out of the best possible materials and inspected by several very knowledgeable people, that I was fine and should just enjoy the ride and the first flight. (and all the following flights:) The older guys at our airport are really good (like your Dick Lawson) and do everything the right way on maintenance and restorations, but the one guy will finish a job, show it to me, and say "it's good enough for who it's for." and of course he's joking--but its still funny. Mike C. ________________________________________________________________________________
Date: Aug 20, 2005
Subject: do you have to talk with air traffic controllers ??
Another common question is this one and my answer always surprises people. I tell them that you can legally fly a plane like our from coast to coast without ever having to talk with anyone at anytime. My first two times to Oshkosh I went 100% non-radio in 1998 and 1999. Since then they have really tightened up the rules on NORDO approaches to Oshkosh, but it still can be done. Since then I bought myself a nice Icom handheld and really find between that and a puff or two of smoke in the pattern increases my safety and of those in the air around me. Mike C. ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Piet model vid
Found a neat R/C piet vid, some on floats. But it is in German. http://paf-flugmodelle.de/Video/mpg/Pietenpol.mpg Something for a rainy day! walt evans NX140DL ________________________________________________________________________________
Date: Aug 20, 2005
Just the kind of responses I get also Walt whenever I take someone out to the garage. Funny when you fly in a plane someone else built (including a factory) you don't think about welds failing and bolts falling out (at least I don't). You just assume that anyone that builds something as complex as an airplane must know what they are doing, that is unless I built it. I am sure that when I get this thing in the air some day and I hit some good turbulence I will immediately flash back to the welds on the flying struts and fittings, the T-88 holding the floor on the plane and keeping me from falling out the bottom, etc. Rick On 8/19/05, walt evans wrote: > > Anybody get to thinking ,,after you take people for a ride,, maybe during > the drive home,, "They asked the same old questions, "you really built this > by hand? From these prints? It's just glued together? How high can you go? > What if the engine quits?"""" > And you realize that you actually created each and every piece of this > plane!!! > Some build clocks, some boats, some jewlery boxes,,,but rarely is the > builders "arse" accountable for the result. > And I look at the plane and say to myself,,,"I actually fabricated each > and every part of this plane". > I'm proud of the way my plane came out. And I wish it was as good as > others I've seen. but all through my building process, my Mentor's words > rattled in my head every time I held the piece up and gave it a final look. > " In building airplanes,,,there's no such thing as ""That's good enough"" > (Dick Lawson EAA#272) > walt evans > NX140DL > PS think about things like this when it's a rainy day, and know that > winter's comming. > *Ain't life grand!* > -- Rick Holland ________________________________________________________________________________
Subject: gap seals
Date: Aug 20, 2005
Hi Dick Our gliders use a stiff milar taped to the hor stab & vert stab. My glider has closed cell foan glued to both surfaces with contact cement. Dale ----- Original Message ----- From: Dick Navratil Subject: Pietenpol-List: gap seals I know that gap seals hve been discussed before, but I just want to ad a bit more to it. At Broadhead I had discussed my takeoff problems with a few of you. If I wasn't careful and didn't add power slowly, while pinning the stick foward, the plane would want to fly before it had the speed. This would cause the plane to want to stall at the ground. I thought this might be the way a Piet flew. After telling my story to the old timers sitting around after all had left, they told me not to look at moving the gear aft as I was thinking but to gap seal the elevators. I have piano hinge on the ailerions so I hadn't thought much about the elevators. After locating some duct tape at Brodhead I taped up the elevators. Right away it flew like a completely diffrent plane. It is much easier to handle on takeoff, tail comes right up and the stick is much lighter. On landing it is more responsive. In cruise it adds about 2 mph. My only question in all of this is, what to replace the duct tape with for a permanent addition? My first thought is a closed cell foam that we use at work as an expansion joint in concrete. Next might be strips of leather or a mylar tape. Any suggestions? Dick N. ________________________________________________________________________________
Date: Aug 20, 2005
controllers ??
Subject: Re: do you have to talk with air traffic
controllers ?? Years back some friends came to me after reading about a recent plane crash at a local grass strip in the Orlando Sentinel. The writer had volunteered a comment in the article that there was no control tower at the airport (no relevance to the accident, obviously). The article implied that airports without control towers were unsafe. My friends were shocked to read this 'news'. I asked them why they weren't shocked that there weren't traffic lights at every intersection of two roads, and how they managed to survive 4-way stop signs every day. Jim Ash -----Original Message----- From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov> Subject: Pietenpol-List: do you have to talk with air traffic controllers ?? Another common question is this one and my answer always surprises people. I tell them that you can legally fly a plane like our from coast to coast without ever having to talk with anyone at anytime. My first two times to Oshkosh I went 100% non-radio in 1998 and 1999. Since then they have really tightened up the rules on NORDO approaches to Oshkosh, but it still can be done. Since then I bought myself a nice Icom handheld and really find between that and a puff or two of smoke in the pattern increases my safety and of those in the air around me. Mike C. ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Options decisions
I just got two of Tony Bingelis' books. I promised myself I was going to read them before I started an airplane, and I'm glad I have so far. I I read, I've had some questions about options specific to the Piet. I've got the plans, including the supplementals and 3-piece wing drawings. I'm just trying to decide what makes sense for me. I'm 6'2" and 200lb, so I expect the long fuselage and the seat setback will be in order. I haven't put together a mockup, but it's coming. I was planning on building the 3-piece wing, but then I read that the typical three-piece wing adds significantly more weight to the plane. Now I'm wondering if this holds true specifically for the Piet. I've also seen comments that the Piet tube-and-fabric fuselage is significantly lighter than the wood one. I'm comfortable welding 4130 tubing, so I can go either way. I currently own a J-3, but if I take my wife for a ride, I'm about 70 lb over gross, so useful load in an airplane is one of my hot buttons. I'm not going to set myself up again for this problem, certainly not from the start, anyhow. Jim Ash ________________________________________________________________________________
Date: Aug 20, 2005
If it is the strap between the gear fittings on each side that you are talking off, Greg and Dale have them on their pietenpol. The strap takes the tensile loads and the ash takes the compressive loads. chris Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: Douwe Blumberg To: pietenpolgroup Sent: Friday, August 19, 2005 6:54 AM Subject: Pietenpol-List: lift strut strap buckling Jeff, I too have seen this on many Piets, typically in the front strap. It must be hard landings where not only is the lift strut loading that strap in compression, but the gear bungee attachment is pulling that strut fitting down at the same time. I think this introduces a kind of downward "rolling" motion in that fitting which wants to buckle that belly strap. Most people just add more bolts. Interesting note, I've never seen it on a axle-geared Piet. Good luck Douwe ________________________________________________________________________________
Subject: Re: RE:
Date: Aug 20, 2005
that is what greg and dale get from their 72 42 homebuilt prop copied from an old sensenich blade. Chris Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: Rcaprd(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, August 16, 2005 4:57 PM Subject: Re: Pietenpol-List: RE: In a message dated 8/16/2005 7:13:59 AM Central Standard Time, harvey.rule(at)bell.ca writes: The word I have is 42 p and 72 length gives 2150 rpm 70 -71 mph at cruise 85-87 tops. That's about what I get from my homebuilt 72 X 42 prop, with Cont. A65 engine. I added aerodynamic fairings to the gear legs, and jury struts, and now I have to hold some forward stick pressure. I plan on removing the fixed trim tabs on the flippers. The fairings helped clean up the parasite drag, a little bit. Chuck G. NX770CG ________________________________________________________________________________
"Pietenpol" , "Corvair"
Subject: NEed a pdf file
Date: Aug 20, 2005
Does anybody know where I can download, in pdf format, the entire FAR part 23 on light airplane certification. It normally goes by "14 CFR Part 23" and I am looking to download it once in its entirety instead of the 500 subparts, one at a time... Chris ________________________________________________________________________________
Subject: Re: Piet model vid
Date: Aug 21, 2005
Hi Walt, Thanks for sharing the Piet vid site with us. As a modeler myself, it is good to see that the model Piet's are being built & flown in many parts of the world, just like the real thing! Currently working on the end spinach with some spruce that Arthur Johnson donated to me (Thanks again Arthur!!) on his way to Brodhead/Osh this last month. My wing ribs are completed. Regards Mark S Japan, Typhoon #'s 11 & 12 have just come to life to the south of Japan, could get wet this week ! ________________________________________________________________________________ <007b01c5a5f4$45a76a10$0301a8c0@north>
Date: Aug 21, 2005
Chris and everyone else who responded- Wow! Thanks for all of the information. The list consensus seems to be that, as stated in the plans, the strap is optional, but a good idea. In what may be an abundance of caution, we replaced the strap this weekend. Thanks again, Jeff >If it is the strap between the gear fittings on each side that you >are talking off, Greg and Dale have them on their pietenpol. The >strap takes the tensile loads and the ash takes the compressive >loads. > >chris >Braumeister und Inspektor der Flitzer und Flitzermotoren > >----- Original Message ----- >From: <mailto:douweblumberg(at)earthlink.net>Douwe Blumberg >To: pietenpolgroup >Sent: Friday, August 19, 2005 6:54 AM >Subject: Pietenpol-List: lift strut strap buckling > >Jeff, > >I too have seen this on many Piets, typically in the front strap. > >It must be hard landings where not only is the lift strut loading >that strap in compression, but the gear bungee attachment is pulling >that strut fitting down at the same time. I think this introduces a >kind of downward "rolling" motion in that fitting which wants to >buckle that belly strap. > >Most people just add more bolts. > >Interesting note, I've never seen it on a axle-geared Piet. > >Good luck > >Douwe ________________________________________________________________________________
Date: Aug 21, 2005
Subject: Re: NEed a pdf file
Christian, Do you have a link to the webpage of FAR part 23?I can convert web to pdf --- Christian Bobka wrote: > Does anybody know where I can download, in pdf > format, the entire FAR part 23 on light airplane > certification. It normally goes by "14 CFR Part 23" > and I am looking to download it once in its entirety > instead of the 500 subparts, one at a time... > > Chris > > ________________________________________________________________________________
Date: Aug 21, 2005
Mitty, yes. It is on this page and it appears UNDER all the links on this page in its entirety. I can take care of the few graphs and charts that are otherwise unreadable. Thanks! Cheers, Chris http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=3dcd582f14ee6e6d12c2bc1c9102e5e6&rgn=div5&view=text&node=14:1.0.1.3.9&idno=14#14:1.0.1.3.9.0.59 Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: "Mitty" <benny_bee_01(at)yahoo.com> Subject: Re: Pietenpol-List: NEed a pdf file > > Christian, > Do you have a link to the webpage of FAR part 23?I can > convert web to pdf > > --- Christian Bobka wrote: > > > Does anybody know where I can download, in pdf > > format, the entire FAR part 23 on light airplane > > certification. It normally goes by "14 CFR Part 23" > > and I am looking to download it once in its entirety > > instead of the 500 subparts, one at a time... > > > > Chris > > > > > > > ____________________________________________________ > > ________________________________________________________________________________
Date: Aug 21, 2005
In a message dated 8/21/2005 11:14:39 AM Central Standard Time, sbobka(at)charter.net writes: Mitty, yes. It is on this page and it appears UNDER all the links on this page in its entirety. I can take care of the few graphs and charts that are otherwise unreadable. Thanks! Cheers, Chris http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=3dcd582f14ee6e6d12c2b c1c9102e5e6&rgn=div5&view=text&node=14:1.0.1.3.9&idno=14#14:1.0.1.3.9.0.59 Chris, I just checked out that site, and yes, there seems to be the whole thing there. I'm just curious...Why couldn't you just hit 'print', and have a hard copy? It would be many pages. Chuck G. ________________________________________________________________________________
Date: Aug 21, 2005
Chuck, I need to be able to take it with me when I fly around the world on long trips. I already have a bag that weighs about 75 pounds with all my crap that I normally have to carry. Putting it in PDF and reducing the weight down to the weight of a CD or putting it on the hard disk is really the best option. I have copies of the reg right here. It is just not in a form that is most useable. I am doing the strenth substatiation of the Z-3 Flitzer Falke. I need to refer to the reg from time to time to keep the work moving along... Cheers, Chris Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: Rcaprd(at)aol.com To: pietenpol-list(at)matronics.com Sent: Sunday, August 21, 2005 12:20 PM Subject: Re: Pietenpol-List: NEed a pdf file In a message dated 8/21/2005 11:14:39 AM Central Standard Time, sbobka(at)charter.net writes: Mitty, yes. It is on this page and it appears UNDER all the links on this page in its entirety. I can take care of the few graphs and charts that are otherwise unreadable. Thanks! Cheers, Chris http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?cecfr&sid3dcd582f14ee6e6d12c2bc1c9102e5e6&rgndiv5&viewtext&node14:1.0.1.3.9&idno14#14:1.0.1.3.9.0.59 Chris, I just checked out that site, and yes, there seems to be the whole thing there. I'm just curious...Why couldn't you just hit 'print', and have a hard copy? It would be many pages. Chuck G. ________________________________________________________________________________
Date: Aug 21, 2005
Subject: gap seals
Hello Group, I was wondering.....how about using piano hinges for elevators? The only real drawback I can see is that it wouldn't look "authentic". Maybe function dictates form? I plan using piano hinges for the ailerons, so this seems not too out of line. Comments? BTW, I just returned from the NWAAC Fly-in at McMinnville, Oregon. There was not a single Piet at this fairly prestigious event. Mine is still probably several years from attending. Will it be the first? Where are all the Left Coast Piets? The world awaits an answer! Keep the sawdust flyin'! Don Cooley ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: left coast piets
They're all on Vancouver Island. :-) The oldest continuously registered aircraft in Canada, CF-AOG, is flying off a private strip, one is flying out of Naniamo and the other is completed and in flight testing, again, at Naniamo. I almost forgot! It appears Dave Rowe has been posted to the far Atlantic Coast somewhere. I don't know the status of both his planes but some time ago they were under tarps in the corner of a hanger at Pat Bay ( Victoria International ). The attached photo is the one currently testing, built by Dean Sevold. Powered by a Ford "B" Clif ----- Original Message ----- From: DONALD COOLEY To: pietenpol-list(at)matronics.com Sent: Sunday, August 21, 2005 10:38 PM Subject: Pietenpol-List: gap seals Hello Group, I was wondering.....how about using piano hinges for elevators? The only real drawback I can see is that it wouldn't look "authentic". Maybe function dictates form? I plan using piano hinges for the ailerons, so this seems not too out of line. Comments? BTW, I just returned from the NWAAC Fly-in at McMinnville, Oregon. There was not a single Piet at this fairly prestigious event. Mine is still probably several years from attending. Will it be the first? Where are all the Left Coast Piets? The world awaits an answer! Keep the sawdust flyin'! Don Cooley ________________________________________________________________________________
Date: Aug 22, 2005
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
Jim, One thing to conisder (and you already seem to be considering weight) is that the long fuselage adds considerable weight to the airplane. Somewhere on the list archives is a thread about weight and CG as surveyed at Brodhead a few years ago. Invariably, the long fuselage Piets weighed well over 700 lbs empty, wheras the short fuselage versions usually come in somewhere in the low 600's. Mine is not only a long fuselage, but is 1" wider than plans (I'm also 6'2" and 200 lbs). Empty weight is 745 lbs, and it really suffers poor climb performance on a hot day. I flew formation with Mike Cuy to Brodhead and his plane consistently outclimbed mine (not that his climb performance was spectacular). I still have yet to take a passenger up in mine - I'm waiting for the weather to cool off so the density altitudes come down a bit. Having said that, I still think I would build a long fuselage if I had it to do over again. It is more comfortable, and if you are going to fly it any distance, comfort becomes pretty important. But I would put a more powerful engine than a Continental A65 in it. I'd go with a Corvair or a C85 or O-200. Jack Phillips NX899JP -----Original Message----- I just got two of Tony Bingelis' books. I promised myself I was going to read them before I started an airplane, and I'm glad I have so far. I I read, I've had some questions about options specific to the Piet. I've got the plans, including the supplementals and 3-piece wing drawings. I'm just trying to decide what makes sense for me. I'm 6'2" and 200lb, so I expect the long fuselage and the seat setback will be in order. I haven't put together a mockup, but it's coming. I was planning on building the 3-piece wing, but then I read that the typical three-piece wing adds significantly more weight to the plane. Now I'm wondering if this holds true specifically for the Piet. I've also seen comments that the Piet tube-and-fabric fuselage is significantly lighter than the wood one. I'm comfortable welding 4130 tubing, so I can go either way. I currently own a J-3, but if I take my wife for a ride, I'm about 70 lb over gross, so useful load in an airplane is one of my hot buttons. I'm not going to set myself up again for this problem, certainly not from the start, anyhow. Jim Ash ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Arthur Johnson from Australia visits Brodhead, 2005
Guys-- (especially Mark Stanley), Had the pleasure of meeting Piet builder Arthur Johnson at Brodhead. Here is a photo of him in front of my Air Camper. Arthur just got in from Japan where he stopped to see Piet builder and fellow bloke Mark Stanley from the list. What a whirlwind of travel. Arthur showed me a set of photos showing his beautiful workmanship on his Air Camper back home. It is going to be a beauty. Mike C. ________________________________________________________________________________
Date: Aug 22, 2005
Jim-- Jack is correct in generalizing that the long fuselage Piets are usually heavier than the shorter version but that is not always the case. Frank Pavliga's Sky Gypsy is a long fuselage, Cont. 65 powered plane with no brakes and a tailskid and his empty weight is a few pounds lighter than my 632 pounder. You can keep the weight down. Douwe was talking with me at Brodhead and he is very weight-concious while building which you have to be if you want the plane to perform decently. It is marginal enough without saddling the wings with more than they really need to be lifting. I feel for guys like Jack who, out of necessity, by the airspace they fly in and around have to add things like encoding altimeters and electrical systems. Mike C. ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Charlie Rubecks
Has anybody heard how Charlie is doing of late? I visited with him at Brodhead and got an update on his condition -- he was going in for surgery the following week. Just wondering if anyone has heard latest...hope he's doing well. As for my Piet project I'm getting ready to place an order for nuts and bolts so I can start bolting pieces to the fuselage, i.e. landing gear fittings, struts, control sticks, etc. Beautiful day here in La Crosse, WI -- and I took a vacation day! A bad day Piet building (no such thing) beats a good day at work anytime! Great stuff on this list lately -- many thanks to all the experts! ! Fred B. ________________________________________________________________________________
Subject: Re: Arthur Johnson from Australia visits Brodhead, 2005
Date: Aug 22, 2005
G'day Blokes, Thanks Mike for the Great shot of Arthur Johnson & your Piet. Arthur showed me the photos of his Piet in OZ, (OZ = Australia for those who don't know). I have to agree with Mike, the Piet will be a beauty. Arthur is a great bloke and I hope lot's of you got to meet him at Brodhead. I have attached a shot of Arthur Johnson, Takamichi Mita & myself with Mr. Mita's Piet during Arthur's visit to Japan during July on his way to Brodhead/Osh. Mark S Japan > Had the pleasure of meeting Piet builder Arthur Johnson at Brodhead. > Arthur just got in from Japan > Mike C. > ________________________________________________________________________________
Date: Aug 22, 2005
Subject: First flights
I would like to take a minute to thank all of those on this list that have unknowingly contributed to the successful building and eventual first flights of N799LJ. I have been a lurker on this list for the last 3-1/2 years while building this ship. I must say that all of the information needed to support a builder is available on this site. Saturday, I was able to get in the first flight of about 1/2 hour around the pattern in fairly rough air, not proving much other than the plane would fly. Last night, however, I was able to get another flight of close to 1 hour in smooth beautiful air, just prior to sundown, what a trip. Plane flew fine, there is no requirements for rigging adjustment, plane essentially flys hands off. All engine temperatures and pressures were normal. Plane flies at 175 MPH @ 2250 RPM behind a C-85-12 turning a Sturba 72-44 wooden prop. I obviously have not gotten a chance to check climb performance but it is significantly better than the Cub that I have been flying. Fifty MPH on final sets up for 3 point landings that are a piece of cake. Lou Wither ________________________________________________________________________________
Date: Aug 22, 2005
CONGRATULATIONS LOU!!! Great feeling, isn't it? Jack Phillips, PE Sr. Manager, Disposables Product Development Clinical Technologies and Services Cardinal Health Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Nav8799h(at)aol.com Subject: Pietenpol-List: First flights I would like to take a minute to thank all of those on this list that have unknowingly contributed to the successful building and eventual first flights of N799LJ. I have been a lurker on this list for the last 3-1/2 years while building this ship. I must say that all of the information needed to support a builder is available on this site. Saturday, I was able to get in the first flight of about 1/2 hour around the pattern in fairly rough air, not proving much other than the plane would fly. Last night, however, I was able to get another flight of close to 1 hour in smooth beautiful air, just prior to sundown, what a trip. Plane flew fine, there is no requirements for rigging adjustment, plane essentially flys hands off. All engine temperatures and pressures were normal. Plane flies at 175 MPH @ 2250 RPM behind a C-85-12 turning a Sturba 72-44 wooden prop. I obviously have not gotten a chance to check climb performance but it is significantly better than the Cub that I have been flying. Fifty MPH on final sets up for 3 point landings that are a piece of cake. Lou Wither ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: First flights
From a fellow lurker, CONGRATULATIONS!! on your first flights. It's great to hear another wonderful airplane takes to the air (of course I am quite impressed with the 175 MPH at 2250 RPM and behind a C-85 none the less. :) Best wishes and many happy flying hours to you and your new plane. Doc H --- Nav8799h(at)aol.com wrote: > I would like to take a minute to thank all of those > on this list that have > unknowingly contributed to the successful building > and eventual first flights > of N799LJ. I have been a lurker on this list for > the last 3-1/2 years while > building this ship. I must say that all of the > information needed to support > a builder is available on this site. Saturday, I > was able to get in the > first flight of about 1/2 hour around the pattern in > fairly rough air, not > proving much other than the plane would fly. Last > night, however, I was able to > get another flight of close to 1 hour in smooth > beautiful air, just prior to > sundown, what a trip. > > Plane flew fine, there is no requirements for > rigging adjustment, plane > essentially flys hands off. All engine temperatures > and pressures were normal. > Plane flies at 175 MPH @ 2250 RPM behind a C-85-12 > turning a Sturba 72-44 > wooden prop. I obviously have not gotten a chance > to check climb performance > but it is significantly better than the Cub that I > have been flying. Fifty MPH > on final sets up for 3 point landings that are a > piece of cake. > > Lou Wither > > > ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: Builders in North Dakota / Minnesota
Dan, Sound great! I just finished a 16' by 32 inch rolling table with adjustable casters for the project. I am on board with you in this project! I currently have a hangar at Hawley Airport. I am finishing up with a Aircoupe (complete restoration)! So I have lots of room also. I have planned on using the corvair engine and have purchased two of them. I look forward to this set-up as I have read many good things about that particular motor. I am very excited to get started with this project and look forward to working together. My skills are i the artificial limb and brace business as I work in Fargo, ND. I have plenty of finishing equipment and metal bending jigs that could be very useful. My lab is large enough to work in creating some of the parts. My home phone is 218-486-1963 and cell phone 701-793-3030. Look forward to a meeting and discussion as to our next move. Sincerely, Ken Heide Dan Loegering wrote: Hi Ken, I would be very interested in sharing ideas with you as your project progresses, and maybe you could teach me a thing or two as well! I am in Fargo, ND and am only slightly farther along than you at this point - purchased plans about 4 months ago and have been working on getting the basement ready for the project and researching all that I can on building practices and Piet specific items. Just purchased the Tony Bengalis series while at Oshkosh and have been reading these the last few weeks. My rib jig is nearly complete and I was literally going to place the order for capstrip and ply for the ribs today. (I'll hold off now though until we can talk) I started this venture with another individual with the intent on building two aircraft side by side, and this may still happen once work slows down a bit this winter (he manages outside construction crews). Our intent was to be able to purchase materials together and ease the shipping charges. Neither of us are in a hurry to get them flying though and I am planning on about a 5 year project - wing ribs through this winter - tail surfaces next spring, fuse next fall, etc... The plan was that we would each work on a different jig and then swap jigs around as we completed phases. In talking with the local EAA chapter, I believe there is another Piet project in the area, but he is inactive on it (doesn't want to sell though...). Drop me an email at "danl(at)odayequipment.com" so we can chat - I'll be driving through tonight on my way to Ottertail - can't stop tonight, but I'll swing over some time with my Cardinal. Sure will be a blast to cruise the lakes with a flight of Piet's though! Dan Loegering From: Kenneth Heide Subject: Pietenpol-List: Piet builders in North Dakota/Minnesota Members of the list: I recently purchased a set of plans to build a Pietenpol. Anyone interested in assisting me in and or around the Detroit Lakes, Minnesota area? Would enjoy working with others to make this plane come to life. I am a native of Albany, Wisconsin just 7 miles to the west of Brodhead, WI They are some fantastic builders at that airport and well worth the time to visit. Anyone interested please contact me at 218-486-1963 Home or Work 701-364-9100 Ken Heide _ ________________________________________________________________________________
Date: Aug 22, 2005
Thanks for the replies. I expected the long fuselage would be heavier, but I didn't know how much. I spent some time yesterday looking at the plans with a calculator. I didn't realize how long the 'long' fuselage really is. I also noticed that the tubular fuselage drawing is actually the shortest of the lot, at 161", if memory serves (I'm at work and nowhere near the drawings). It's also got one less station in the rear than the short woodies. Although the top part of the pilot's seat area is a bit longer between stations, the bottom part is shorter. I haven't looked at the angles, but I suspect this would put me in a more prone and knees-folded-up position. If I look at all three drawings concurrently, the long woody is roughly the same as the short, with an inch or two extra added to select stations. If I want to make a long fuselage of 4130 tubing, I'll have to come up with a similar lengthening process. Having a seriously aft CG scares me; I plan on exiting every spin I might enter. As I babble, I guess I'm looking to find out: 1. Is there anybody here who built or owns a tube-and-fabric fuselage, and waddayathink? 2. What are the relative strengths between the short woody and the as-drawn tube-and-fabric fuselage? 3. Of those who 'adjusted' their dimensions be it for personal comfort or whatever, what were the changes and how were they derived (and why)? 4. The tube-and-fabric drawing specifies diagonal bracing at three stations, but the wooden ones don't. I suspect it's because there's a sheet of wood across these stations on the woodies, but is this true? 5. Has anybody done a weight comparison of the one-piece vs the three-piece wing? 6. Does somebody here have the tube-and-fabric fuselage drawing handy? Some of the fine print (tubing sizes) is blurry on mine towards the front, and I could use the numbers clarified. I got mine straight fron Don Pietenpol, so they're not copies, but the printer must have had an off day. On a different note, Tony Bingelis mentioned something that pulley sizes should be a larger diameter when going around tighter angles. I see this isn't the case for most of the aileron pulleys on the Piet. Is this because of the space being too tight for larger pulleys? Has anybody used larger pulleys? Jim Ash -----Original Message----- From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com> Subject: RE: Pietenpol-List: Options decisions Jim, One thing to conisder (and you already seem to be considering weight) is that the long fuselage adds considerable weight to the airplane. ... ________________________________________________________________________________
Date: Aug 22, 2005
HI Jim, I tried to answer some of your questions below. You are asking good questions! I guess if you are comfortable with welding, the steel fuselage could be built longer and would be lighter than wood. Making it wider would not be as much of a problem with tubing. I must admit though that I like the look of my wooden interior. One change you might want to make is to provide more slant to the rear seatback. I suggest you build a cockpit mockup and see if it is comfortable for you. I wish I had done so - I would have then changed the seatback angle to be more comfortable. Jack Phillips NX899JP -----Original Message----- Jim Ash wrote: ...As I babble, I guess I'm looking to find out: 3. Of those who 'adjusted' their dimensions be it for personal comfort or whatever, what were the changes and how were they derived (and why)? Jim - I can say that the mods I made to mine were a 1" wider fuselage and a 6" wider centersection in the wing. The fuselage was made wider to give more room in the cockpit and I think it was a good change, except for 2 issues - it added weight and it added cost. The weight was due to more plywood and slightly more spruce, the cost was due to the fact that I had to buy more than one sheet of plywood (not possible to get 2, 25" widths out of a sheet of 4'x8' plywood). The centersection was made wider to give more fuel capacity. My fuel is all in the centersection and by making it wider I have a 15.5 gallon tank. 4. The tube-and-fabric drawing specifies diagonal bracing at three stations, but the wooden ones don't. I suspect it's because there's a sheet of wood across these stations on the woodies, but is this true? I wondered about the lack of diagonal bracing in the wooden fuselage but it doesn't seem to be a problem. Even a serious ground loop that wrenched the tailwheel off the fuselage didn't cause any twisting of the fuselage structure 5. Has anybody done a weight comparison of the one-piece vs the three-piece wing? I haven't done a comparison, but I can tell you the one piece is lighter. The fittings that hold the 3 piece wings together and the bolts, metal fairings, sheetmetal screws, etc all add up to several pounds of weight. However, the 3 piece wing is A LOT easier to handle during construction and transport to the airport. I know how heavy my centersection was and I remember how difficult it was to hold it up while installing it on the cabane struts and riging the roll wires. I can't imagine having to do that with the entire wing 6. Does somebody here have the tube-and-fabric fuselage drawing handy? Some of the fine print (tubing sizes) is blurry on mine towards the front, and I could use the numbers clarified. I got mine straight fron Don Pietenpol, so they're not copies, but the printer must have had an off day. On a different note, Tony Bingelis mentioned something that pulley sizes should be a larger diameter when going around tighter angles. I see this isn't the case for most of the aileron pulleys on the Piet. Is this because of the space being too tight for larger pulleys? Has anybody used larger pulleys? I don't know on this one. I used the size called out in the plans (or the closest larger size) and they seem to work fine. ________________________________________________________________________________
Date: Aug 22, 2005
Subject: A-65
Pieters: I need a lot of help. Can't start engine without pouring raw fuel in the top plug holes. Have started twice. First time it ran for about 10 seconds. Next day, same priming procedure, it ran for about 15 seconds. Has anyone experienced this behavior with your 65? I've overhauled the carb daily, new steel needle and seat, gaskets. I took the brass revolving plate, mixture, out. Read the A-65 manual until the print is fading also the Stromberg NA-S3A1 manual. The only thing I can't comply with from the manual is the 18 inch head of fuel above the carb. I only have 8 inches from tank bottom to carb bottom. Will one of you engine know-hows please come to my rescue? Mags are very hot from rebuild. Engine has new bearings, guides, rings etc. Thanks in advance Corky In La trying to start this d--- thing in 102 temp. ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: A-65
Corky, My first thought and then I'll think more later,,, Remember the first time that I put fuel in my tank, and I had just rebuilt the carb to the book,,,I thought the carb would just fill up when I opened the gas shut off. But it didn't. Forget how I vented the bowl to get gas into it, but it was strange. Sound like the bowl is strangly empty. walt evans NX140DL ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, August 22, 2005 6:13 PM Subject: Pietenpol-List: A-65 Pieters: I need a lot of help. Can't start engine without pouring raw fuel in the top plug holes. Have started twice. First time it ran for about 10 seconds. Next day, same priming procedure, it ran for about 15 seconds. Has anyone experienced this behavior with your 65? I've overhauled the carb daily, new steel needle and seat, gaskets. I took the brass revolving plate, mixture, out. Read the A-65 manual until the print is fading also the Stromberg NA-S3A1 manual. The only thing I can't comply with from the manual is the 18 inch head of fuel above the carb. I only have 8 inches from tank bottom to carb bottom. Will one of you engine know-hows please come to my rescue? Mags are very hot from rebuild. Engine has new bearings, guides, rings etc. Thanks in advance Corky In La trying to start this d--- thing in 102 temp. ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: A-65
Walt, The bowl is full each time I remove it to "try something else". Tomorrow I will set the fuel level a bit higher, if I can find a washer thin enough. As I said ,I installed a new needle and seat valve so it may be needing a slightly higher fuel level. Corky ________________________________________________________________________________
Date: Aug 22, 2005
You could do piano hinge on the elevators. You would have to change the dimensions on the rear of the stab and the front of the elev to be able to trim off material, so it would get full up and down motion. Other than that it would probably be fine. Dick N. ----- Original Message ----- From: DONALD COOLEY To: pietenpol-list(at)matronics.com Sent: Monday, August 22, 2005 12:38 AM Subject: Pietenpol-List: gap seals Hello Group, I was wondering.....how about using piano hinges for elevators? The only real drawback I can see is that it wouldn't look "authentic". Maybe function dictates form? I plan using piano hinges for the ailerons, so this seems not too out of line. Comments? BTW, I just returned from the NWAAC Fly-in at McMinnville, Oregon. There was not a single Piet at this fairly prestigious event. Mine is still probably several years from attending. Will it be the first? Where are all the Left Coast Piets? The world awaits an answer! Keep the sawdust flyin'! Don Cooley ________________________________________________________________________________
Subject: Garmin GPS196 for dummies
Date: Aug 22, 2005
Okay, I'll admit it. I'm a dummy. I just talked myself into a Garmin GPS196 (black & white) and it comes with a free download of the database update. However... nowhere in the manual can I find how to go about downloading the update and installing it to the GPS. I know there is an interface cable for my PC, but beyond that I'm clueless as to how to snag and download the update. GPS196 users who can help me, please email off-list at taildrags(at)hotmail.com or point me to some instructions somewhere. Thanks. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Mods to Model A engine mount....
Date: Aug 22, 2005
My fuse is 1" wider than plans and I have a Model A mount that is built to plans....so when I bolt on the 3/4" tubing braces, the holes that the ash sits on are spaced 1" too far apart. I considered adding a 1/2" piece of ash to each side of each of the bearers (to move them toward each other 1/2" each tomake up the 1") but that adds a bit of a moment arm.....probably not an issue but I would rather keep the engine as close to the center line of the tubing holes as possible. I can notch the tubing per the attached picture and weld the gap shut. The bend works out to approximately 3 degrees, which means I'll notch out a .04" gap (not much more than the width of my saw blade) and then weld that back together. (My preference is to do NO cutting and welding......) Since I only need a 3 degree bend over a 19" distance (for a change in the hole location of 1/2" on each side of the engine mount) I'm considering heating the tubing up and bending it in 1/2". Maybe heating up a 12" length (rather than a short distance) would not compromise the strength of the tubing......would that work? I'm obviously going to run this by my EAA Tech Counselor but these solutions seem more than adequate....but I sure would like a sanity check from anyone who cares to help me out here. Suggestions? Notch/weld or heat/bend? I welcome all input! Thanks! Jim in Plano ________________________________________________________________________________
Subject: Re: Mods to Model A engine mount....
Date: Aug 22, 2005
I like the heat and bend option. Greg ----- Original Message ----- From: Jim Markle To: pietenpol-list(at)matronics.com Sent: Monday, August 22, 2005 9:19 PM Subject: Pietenpol-List: Mods to Model A engine mount.... My fuse is 1" wider than plans and I have a Model A mount that is built to plans....so when I bolt on the 3/4" tubing braces, the holes that the ash sits on are spaced 1" too far apart. I considered adding a 1/2" piece of ash to each side of each of the bearers (to move them toward each other 1/2" each tomake up the 1") but that adds a bit of a moment arm.....probably not an issue but I would rather keep the engine as close to the center line of the tubing holes as possible. I can notch the tubing per the attached picture and weld the gap shut. The bend works out to approximately 3 degrees, which means I'll notch out a .04" gap (not much more than the width of my saw blade) and then weld that back together. (My preference is to do NO cutting and welding......) Since I only need a 3 degree bend over a 19" distance (for a change in the hole location of 1/2" on each side of the engine mount) I'm considering heating the tubing up and bending it in 1/2". Maybe heating up a 12" length (rather than a short distance) would not compromise the strength of the tubing......would that work? I'm obviously going to run this by my EAA Tech Counselor but these solutions seem more than adequate....but I sure would like a sanity check from anyone who cares to help me out here. Suggestions? Notch/weld or heat/bend? I welcome all input! Thanks! Jim in Plano ________________________________________________________________________________
Date: Aug 23, 2005
The welding at the bolt tube joint has already eliminated the heat treating of the metal for a couple of inches up the tube, so heating and bending a short length next to the bolt bracket would probably be OK. Come to think about it, that bit of the tube is already softened and may just bend the 3=B0 you need. If you're planning on 12", that's a significant percentage of the tube length, well over half. The whole idea of that brace is that the line of force lines up with the center of the tube. If you bend it at all, especially with strength destroying heat, you're compromising the structure, a lot. Would you do that to your wing struts? You might get away with it if you tied them together in the middle. If you're going to bend the things only 1/2" over 19" you might as well just pull them in and then put a small dia brace strut between them, as on the wing struts. That way the 4130 heat treated strength will still be there. That engine is pretty heavy and gets a lot "heavier" when maneuvering. Myself, I would reheat the already softened area within a couple of inches of the bolt tube and gently push the other end over a bit, check it, do it again, etc. If at a degree or so it appeared to be flattening then stop and ponder. Are you sure it's 3=B0? I just drew it out and it looks more like two. Not much of a bend. By working close to the bolt tube if you do get into trouble it would then be easy to add a gusset. Clif Subject: Pietenpol-List: Mods to Model A engine mount.... Since I only need a 3 degree bend over a 19" distance (for a change in the hole location of 1/2" on each side of the engine mount) I'm considering heating the tubing up and bending it in 1/2". Maybe heating up a 12" length (rather than a short distance) would not compromise the strength of the tubing......would that work? I'm obviously going to run this by my EAA Tech Counselor but these solutions seem more than adequate....but I sure would like a sanity check from anyone who cares to help me out here. Suggestions? Notch/weld or heat/bend? I welcome all input! Thanks! Jim in Plano ________________________________________________________________________________
Date: Aug 23, 2005
Subject: Re: A-65
I had the exact same problem on the C-85 with that carb. Try venting the fuel from the float bowl. I pulled the carb off the engine and found no fuel in the bowl, reassembled and vented the bowl and we were able to get the thing running. Haven't had a problem since. I have about 10" from bottom to tank to bowl, engine runs fine in the normal attitude with just a small amount, less than 1 gallon in the tank. Lou ________________________________________________________________________________
Subject: A-65
Date: Aug 23, 2005
Corky, Eight inches is not much (unless you're talking about something dirtier than airplane engines). Of course, what the carburetor sees is not the height to the bottom of the fuel tank, but to the top of the fuel. Is your tank full when you are trying to start it? Have you tried a fuel flow test to see what flow rate you get from the tank if you have the fuel line disconnected from the carb (but at the same height as the connector going into the float chamber)? You should see at least 7 gallons per hour through the fuel line in this test. Is the 8" you mentioned with the plane in a 3 point position or level flight? If that is the level flight position, you might have even less in the 3 point position. One thing I found when I was first getting my engine to run was that a slight leak in the intake system causes a severe drop in fuel mixture, making it run very lean (which makes it hard to start). The other thing I found was that Slick had made my ignition harness incorrectly (brand new mags and harness), and two of my cylinders were firing in the wrong sequence. Once I figured out which ones were off and swapped the leads around to get the right firing order, it started right up. Before then, it was very difficult to start, and ran very rough - just running on two cylinders. When yours runs on the primer, does it run smoothly for the 10 or 15 seconds that it runs, or is it rough? Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Isablcorky(at)aol.com Subject: Pietenpol-List: A-65 Pieters: I need a lot of help. Can't start engine without pouring raw fuel in the top plug holes. Have started twice. First time it ran for about 10 seconds. Next day, same priming procedure, it ran for about 15 seconds. Has anyone experienced this behavior with your 65? I've overhauled the carb daily, new steel needle and seat, gaskets. I took the brass revolving plate, mixture, out. Read the A-65 manual until the print is fading also the Stromberg NA-S3A1 manual. The only thing I can't comply with from the manual is the 18 inch head of fuel above the carb. I only have 8 inches from tank bottom to carb bottom. Will one of you engine know-hows please come to my rescue? Mags are very hot from rebuild. Engine has new bearings, guides, rings etc. Thanks in advance Corky In La trying to start this d--- thing in 102 temp. ________________________________________________________________________________
Subject: Re: Garmin GPS196 for dummies
Date: Aug 23, 2005
>Sometimes you can get downloads off the google site.Ask for the company that the gps is made from and they may have a download page. Maybe! > From: "Oscar Zuniga" <taildrags(at)hotmail.com> > Date: 2005/08/22 Mon PM 10:04:19 EST > To: krnet(at)mylist.net, pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Garmin GPS196 for dummies > > > Okay, I'll admit it. I'm a dummy. I just talked myself into a Garmin > GPS196 (black & white) and it comes with a free download of the database > update. However... nowhere in the manual can I find how to go about > downloading the update and installing it to the GPS. I know there is an > interface cable for my PC, but beyond that I'm clueless as to how to snag > and download the update. > > GPS196 users who can help me, please email off-list at taildrags(at)hotmail.com > or point me to some instructions somewhere. Thanks. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Tape to use on airlerons and elevator
Date: Aug 23, 2005
I'd like to know what is the best tape to use in these places for gap cover?I will order the one you guys say is best.Thanks in advance for any advice. ________________________________ ________________________________________________________________________________
Date: Aug 23, 2005
Subject: Re: Tape to use on airlerons and elevator
In a message dated 8/23/2005 11:59:59 AM Central Standard Time, harvey.rule(at)bell.ca writes: I=E2=80=99d like to know what is the best tape to use in these places for gap cover?I will order the one you guys say is best.Thanks in advance for any advice. I used covering material process, applied to both sides, before paint. Chuck G. ________________________________________________________________________________
Date: Aug 23, 2005
In a message dated 8/22/2005 12:40:09 AM Central Standard Time, adonjr(at)sbcglobal.net writes: I was wondering.....how about using piano hinges for elevators? The only real drawback I can see is that it wouldn't look "authentic". Maybe function dictates form? I plan using piano hinges for the ailerons, so this seems not too out of line. Comments? Don, I've never seen piano hinges used on the empenage. I suggest you contact Vi Kappler, and purchase his cast aluminum hinges. Many Pietenpols out there, including mine, use his empenage hinges. He worked with Bernard Pietenpol for years. If you give him a call, have a bunch of other questions ready to ask him, while you have him on the phone. Vitalis Kapler 1033 Forest Hill Dr. WS Rochester, MN 55902 phone: 507-288-3322 ________________________________________________________________________________
Date: Aug 23, 2005
Subject: A-65 Oil Pressure
Pieters, We have the engine running, finally. Had to cut it off as there is no oil pressure. I filled the oil outlet to the gauge with oil but nothing happened. Any comments. Corky in only 100 degrees today ________________________________________________________________________________
Date: Aug 23, 2005
Subject: Re: A-65 Oil Pressure
Corky, Sounds like your oil pump is not primed. Try raising the tail above your head for a few seconds. I used to fly a Champ that required this if it sat for awhile. TakeCare, -john- > Pieters, > > We have the engine running, finally. Had to cut it off as there is no oil > pressure. I filled the oil outlet to the gauge with oil but nothing happened. > Any comments. > > Corky in only 100 degrees today > ________________________________________________________________________________
Date: Aug 23, 2005
In a message dated 8/23/2005 6:51:37 PM Central Standard Time, jhofmann(at)reesgroupinc.com writes: Corky, Sounds like your oil pump is not primed. Try raising the tail above your head for a few seconds. I used to fly a Champ that required this if it sat for awhile. TakeCare, -john- I've used this method too, and it was successful. On a previous occassion, after having had the fuselage in a level position for doing gear mod, I tried filling a dry oil pump by filling it through the oil pressure line. It took a least a half hour for the oil in the homemade funnel to slowly make it's way in. That was also successful. It's just much easier to just raise the tail, and allow the oil in the screen filter to prime the pump. Chuck G. ________________________________________________________________________________
Date: Aug 23, 2005
Corky, Try this method to prime the oil pump: 1. Remove the oil temperature bulb from the oil screen. 2. Shoot some fresh oil into the oil screen with an oil squirt can. Be generous! 3. Re-install oil temperature bulb. 4. Start engine and you should get an oil pressure indication within 30 seconds. If not, try connecting an oil pressure gauge to the O/P outlet with a short line (sometimes there is an indication lag with a long line). I have used this method for over fifty years on small Continentals when raising the tail didn't produce results. Let me know how it works for you. Cheers, Graham (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Aug 23, 2005
Thanks Clif! Bending near the bolt bracket sounds like the ticket! Am I sure it's 3=B0? Well, a 1" rise on a triangle with a base (or slope) of 19" works out to about 3 degrees.....so...hey wait.....oops....it should have been a 1/2" rise (duh, I suppose there's no reason to make up the ENTIRE 1" difference on one side!!!).....uhhh, a 1/2" rise across 19" is actually 1.51 degrees...so yeah, about 2 degrees.....even better! I'm gonna heat and bend...... I saw somewhere that you can take a tubing bend out by heating one side of the tubing to make it draw the tubing in a particular direction. I'm gonna try that. I'm feeling a LOT better about this now... thanks again. (I LOVE this process!!!) Jim in Plano.....looking forward to having some pockata-pockata sounds in my driveway in a few weeks.... ________________________________________________________________________________
Date: Aug 24, 2005
What did you have to do to get it running, Corky? And how long did you let it run before shutting it down? Mine often takes the full 30 seconds to get any indication on the oil pressure gage, as it is a long way from the engine to the rear cockpit Jack Phillips, PE Sr. Manager, Disposables Product Development Clinical Technologies and Services Cardinal Health Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Isablcorky(at)aol.com Subject: Pietenpol-List: A-65 Oil Pressure Pieters, We have the engine running, finally. Had to cut it off as there is no oil pressure. I filled the oil outlet to the gauge with oil but nothing happened. Any comments. Corky in only 100 degrees today ________________________________________________________________________________
Date: Aug 24, 2005
>Thanks for the reply Chuck;that was one of the methods I had thought of but I figured you guys had some preference to a particular type of tape.When you think of it though,you don't really want a sticky surface in the middle anyway.I will use 5 inch ceconite tape on the airlerones and I think the three inch should be plenty on the tail. > From: Rcaprd(at)aol.com > Date: 2005/08/23 Tue PM 05:17:03 EST > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Tape to use on airlerons and elevator > > In a message dated 8/23/2005 11:59:59 AM Central Standard Time, > harvey.rule(at)bell.ca writes: > I?d like to know what is the best tape to use in these places for gap cover?I > will order the one you guys say is best.Thanks in advance for any advice. > I used covering material process, applied to both sides, before paint. > > Chuck G. > > ________________________________________________________________________________
Date: Aug 24, 2005
Corky, Have you purged the air from the oil pressure gauge line? Oil pressure on ours took a LOOOOONG time to register on the gauge until we purged all of the air from the gauge line. Greg Cardinal ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, August 23, 2005 6:28 PM Subject: Pietenpol-List: A-65 Oil Pressure Pieters, We have the engine running, finally. Had to cut it off as there is no oil pressure. I filled the oil outlet to the gauge with oil but nothing happened. Any comments. Corky in only 100 degrees today ________________________________________________________________________________
Date: Aug 24, 2005
I'm working on that today.....Thanks It's been so damn hot here I can only stand a few hours a day and I have to wait for my prop-er to show up. Corky ________________________________________________________________________________
Subject: First Flights
Date: Aug 24, 2005
27, 2005) at 08/24/2005 08:28:37 AM Congratulations Lou, I know how you must feel, you where not alone. Saturday, August 20th @ 4 PM, my Pietenpol Air Camper Miss Banshee made her first flight also. The weather was great, a slight breeze form the south, Heat index of 105 F and a density altitude of 2400 Ft. The Airplane flies hands-off straight and the Corvair engine performs flawless. I must thank all of you Pietenpol listers for all the questions and answers that have been posted, this list is truly a great resource for all builders. Every time a question arose during the construction phase, I was always able to find answers on the list or in the archives. Thank you All, I will have to repay the favor by sharing my experience in the future. I will start with this; My Pietenpol is the improved long fuselage Air Camper. Empty weight 680 Lbs Split Landing gear with 6 x 6.00 wheels, Matco wheels and brakes The main deviations from plans are: 1) Wheels are 3 forward of plans. (changed the landing gear V slightly) 2) Bungies replaced with coil springs. 3) Engine mount extended by to give Corvair more clearance to Firewall. Engine O-164 Corvair, William Wynne conversion with front starter Propeller: Tennessee prop. 64 x 34 Carburetor: Zenith 1821 I started this Pietenpol project in March of 2004 and build a little every day. I took me around 1780 Hours to complete it, (yes, thats right in a year and a half and holding a day job) Now its off to flying again, Yee-Haw!! Hans van der Voort Proud Owner/Builder/flyer of Pietenpol NX 15 KV Miss Banshee Waller, 3XS7 Houston Sectional ________________________________________________________________________________
Date: Aug 24, 2005
Subject: Re: First Flights
That is interesting that two had their first flight on the same day and at nearly the same time. I was at 2:00 PM eastern time. I wonder how many of these Pietenpols are completed and flown in a year. That might be an interesting statistic. I was 3-1/2 years of construction, however I was only working during the winter season, generally from November through March. I never kept track of the hours, I just used it as a hobby. My problem is; what am I going to do for winter entertainment now? Again congratulations on your first flight. Lou ________________________________________________________________________________
Date: Aug 24, 2005
I know a Pete Vander Voort who lives in Manitick just outside of Ottawa are you any relation to him.Your computer puts out some strange symbols;I don't know if your aware of it.I should be ready to fly within the next month if all goes well.Just in time to put her away for the winter.By the way what do you guys do to winterize your plane,engine and everything.I use Downy fabric softener clothes all over the plane wherever there is an opening to make sure the mice don't get in.They don't like the smell of Downy.I'm not quite sure if there is anything that can be sprayed in the cylinders.I heard that just squirting some oil in is all that it really takes.I was given these things that look like they go into the spark plug holes and they have what appears to be a crystal inside the glass case.I'm not sure but I think they are for soaking up moisture.Anybody else ever seen these things? -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of hans.vander.voort(at)alfalaval.com Subject: Pietenpol-List: First Flights Congratulations Lou, I know how you must feel, you where not alone. Saturday, August 20th @ 4 PM, my Pietenpol Air Camper Miss Banshee made her first flight also. The weather was great, a slight breeze form the south, Heat index of 105 F and a density altitude of 2400 Ft. The Airplane flies hands-off straight and the Corvair engine performs flawless. I must thank all of you Pietenpol listers for all the questions and answers that have been posted, this list is truly a great resource for all builders. Every time a question arose during the construction phase, I was always able to find answers on the list or in the archives. Thank you All, I will have to repay the favor by sharing my experience in the future. I will start with this; My Pietenpol is the improved long fuselage Air Camper. Empty weight 680 Lbs Split Landing gear with 6 x 6.00 wheels, Matco wheels and brakes The main deviations from plans are: 1) Wheels are 3 forward of plans. (changed the landing gear V slightly) 2) Bungies replaced with coil springs. 3) Engine mount extended by to give Corvair more clearance to Firewall. Engine O-164 Corvair, William Wynne conversion with front starter Propeller: Tennessee prop. 64 x 34 Carburetor: Zenith 1821 I started this Pietenpol project in March of 2004 and build a little every day. I took me around 1780 Hours to complete it, (yes, thats right in a year and a half and holding a day job) Now its off to flying again, Yee-Haw!! Hans van der Voort Proud Owner/Builder/flyer of Pietenpol NX 15 KV Miss Banshee Waller, 3XS7 Houston Sectional ________________________________________________________________________________
Date: Aug 24, 2005
27, 2005) at 08/24/2005 09:02:34 AM Lou, Thanks, for my next project I lean towards a Culver Cadet. Again wood build, 100 Hp but little faster. Just need to find some costruction plans. Hans Nav8799h(at)aol.com Sent by: owner-pietenpol-l To ist-server@matron pietenpol-list(at)matronics.com ics.com cc Subject 08/24/2005 07:50 Re: Pietenpol-List: First Flights AM Please respond to pietenpol-list@ma tronics.com That is interesting that two had their first flight on the same day and at nearly the same time. I was at 2:00 PM eastern time. I wonder how many of these Pietenpols are completed and flown in a year. That might be an interesting statistic. I was 3-1/2 years of construction, however I was only working during the winter season, generally from November through March. I never kept track of the hours, I just used it as a hobby. My problem is; what am I going to do for winter entertainment now? Again congratulations on your first flight. Lou ________________________________________________________________________________
Date: Aug 24, 2005
27, 2005) at 08/24/2005 09:08:58 AM Harvey, Could be, a few of my father's cousins moved from Holland to Canada in the 50's. Myself I am a fresh import. I do not plan to winterize the Pietepol, Texas weather does not know Canadian winters. Winter here looks like your summer. For your engine I would use fogging oil, you get it at a boat supply store. You use it to winterize boat engines. Hans harvey.rule@bell. ca Sent by: To owner-pietenpol-l pietenpol-list(at)matronics.com ist-server@matron cc ics.com Subject RE: Pietenpol-List: First Flights 08/24/2005 07:51 AM Please respond to pietenpol-list@ma tronics.com I know a Pete Vander Voort who lives in Manitick just outside of Ottawa are you any relation to him.Your computer puts out some strange symbols;I don't know if your aware of it.I should be ready to fly within the next month if all goes well.Just in time to put her away for the winter.By the way what do you guys do to winterize your plane,engine and everything.I use Downy fabric softener clothes all over the plane wherever there is an opening to make sure the mice don't get in.They don't like the smell of Downy.I'm not quite sure if there is anything that can be sprayed in the cylinders.I heard that just squirting some oil in is all that it really takes.I was given these things that look like they go into the spark plug holes and they have what appears to be a crystal inside the glass case.I'm not sure but I think they are for soaking up moisture.Anybody else ever seen these things? -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of hans.vander.voort(at)alfalaval.com Subject: Pietenpol-List: First Flights Congratulations Lou, I know how you must feel, you where not alone. Saturday, August 20th @ 4 PM, my Pietenpol Air Camper Miss Banshee made her first flight also. The weather was great, a slight breeze form the south, Heat index of 105 F and a density altitude of 2400 Ft. The Airplane flies hands-off straight and the Corvair engine performs flawless. I must thank all of you Pietenpol listers for all the questions and answers that have been posted, this list is truly a great resource for all builders. Every time a question arose during the construction phase, I was always able to find answers on the list or in the archives. Thank you All, I will have to repay the favor by sharing my experience in the future. I will start with this; My Pietenpol is the improved long fuselage Air Camper. Empty weight 680 Lbs Split Landing gear with 6 x 6.00 wheels, Matco wheels and brakes The main deviations from plans are: 1) Wheels are 3 forward of plans. (changed the landing gear V slightly) 2) Bungies replaced with coil springs. 3) Engine mount extended by to give Corvair more clearance to Firewall. Engine O-164 Corvair, William Wynne conversion with front starter Propeller: Tennessee prop. 64 x 34 Carburetor: Zenith 1821 I started this Pietenpol project in March of 2004 and build a little every day. I took me around 1780 Hours to complete it, (yes, thats right in a year and a half and holding a day job) Now its off to flying again, Yee-Haw!! Hans van der Voort Proud Owner/Builder/flyer of Pietenpol NX 15 KV Miss Banshee Waller, 3XS7 Houston Sectional ________________________________________________________________________________
Subject: tape to use on ailerons and elevator
Date: Aug 24, 2005
Harvey wrote- >I'd like to know what is the best tape to use in these places for >gap cover? I will order the one you guys say is best. Well, I have not used this myself (yet), but one of the guys over on the KRNet suggested "gaffers tape" for use on the wing gap seals on KRs. This is tape that is used in movie sets to tape wiring down onto the floor, so it doesn't have adhesive down the middle part of the tape... the part that would be over the gap between the wing and the control surface. It's available in an assortment of colors. Here's one example: http://www34.pair.com/harrison/thetapeworks.com/progaff.htm Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 24, 2005
Lou, if you're like me, you will want to relax and take it easy for a month or so, then start wanting to build another airplane. I got hooked on the RV-10 at OSH this year and am already cleaning up the workshop in anticipation of starting on it. I want to see just how easy a kit is compared to a REAL airplane project. I had to promise my fiancee that I would not start working on it until next winter, but I figure if I spend enough time drooling over the plans and info package this fall (as well as remind her everytime we take a trip in the car, "Gee honey, if we had the RV-10 we would have been there 4 hours ago") she might relent and suggest that I get started on it this winter. I'm already working that angle. We've got to go visit a friend of hers in Northern Virginia over Labor Day, and it will be a 5-1/2 hour drive from Raleigh. The RV could make the same trip in 51 minutes. Even the Pietenpol could do it in 2-1/2 hours (the roads don't go straight). I miss having an airplane in the basement. Jack Phillips NX899JP "Icarus Plummet" -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Nav8799h(at)aol.com Subject: Re: Pietenpol-List: First Flights That is interesting that two had their first flight on the same day and at nearly the same time. I was at 2:00 PM eastern time. I wonder how many of these Pietenpols are completed and flown in a year. That might be an interesting statistic. I was 3-1/2 years of construction, however I was only working during the winter season, generally from November through March. I never kept track of the hours, I just used it as a hobby. My problem is; what am I going to do for winter entertainment now? Again congratulations on your first flight. Lou ________________________________________________________________________________
Date: Aug 24, 2005
Well as far as the wife situation goes, we have a Navion as the other airplane and she is pretty happy going places in that. In the short/long run retirement is getting closer and I would like to find something to replace the Navion with that is a little less expensive to own and operate. Requirements are the gear has to be down all of the time and the prop does move in any other direction other than around and around. I cannot get to excited about the RV's, there are just too many of them around, nothing exciting. Have been doing some research on the Barracuda (wheels go up, and the prop moves) or the Glastar. I really don't know if putting a kit together would be the same thing. It might be a little like the Barbie houses when my daughter was small. My basement is now clean and definitely needs something for this winter. Maybe I'll go back to putting RC's together, use to do that years ago. Not cheap, but less than the real thing. Lou ________________________________________________________________________________
Date: Aug 24, 2005
Thanks a million Hans. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of hans.vander.voort(at)alfalaval.com Subject: RE: Pietenpol-List: First Flights Harvey, Could be, a few of my father's cousins moved from Holland to Canada in the 50's. Myself I am a fresh import. I do not plan to winterize the Pietepol, Texas weather does not know Canadian winters. Winter here looks like your summer. For your engine I would use fogging oil, you get it at a boat supply store. You use it to winterize boat engines. Hans harvey.rule@bell. ca Sent by: To owner-pietenpol-l pietenpol-list(at)matronics.com ist-server@matron cc ics.com Subject RE: Pietenpol-List: First Flights 08/24/2005 07:51 AM Please respond to pietenpol-list@ma tronics.com I know a Pete Vander Voort who lives in Manitick just outside of Ottawa are you any relation to him.Your computer puts out some strange symbols;I don't know if your aware of it.I should be ready to fly within the next month if all goes well.Just in time to put her away for the winter.By the way what do you guys do to winterize your plane,engine and everything.I use Downy fabric softener clothes all over the plane wherever there is an opening to make sure the mice don't get in.They don't like the smell of Downy.I'm not quite sure if there is anything that can be sprayed in the cylinders.I heard that just squirting some oil in is all that it really takes.I was given these things that look like they go into the spark plug holes and they have what appears to be a crystal inside the glass case.I'm not sure but I think they are for soaking up moisture.Anybody else ever seen these things? -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of hans.vander.voort(at)alfalaval.com Subject: Pietenpol-List: First Flights Congratulations Lou, I know how you must feel, you where not alone. Saturday, August 20th @ 4 PM, my Pietenpol Air Camper Miss Banshee made her first flight also. The weather was great, a slight breeze form the south, Heat index of 105 F and a density altitude of 2400 Ft. The Airplane flies hands-off straight and the Corvair engine performs flawless. I must thank all of you Pietenpol listers for all the questions and answers that have been posted, this list is truly a great resource for all builders. Every time a question arose during the construction phase, I was always able to find answers on the list or in the archives. Thank you All, I will have to repay the favor by sharing my experience in the future. I will start with this; My Pietenpol is the improved long fuselage Air Camper. Empty weight 680 Lbs Split Landing gear with 6 x 6.00 wheels, Matco wheels and brakes The main deviations from plans are: 1) Wheels are 3 forward of plans. (changed the landing gear V slightly) 2) Bungies replaced with coil springs. 3) Engine mount extended by to give Corvair more clearance to Firewall. Engine O-164 Corvair, William Wynne conversion with front starter Propeller: Tennessee prop. 64 x 34 Carburetor: Zenith 1821 I started this Pietenpol project in March of 2004 and build a little every day. I took me around 1780 Hours to complete it, (yes, thats right in a year and a half and holding a day job) Now its off to flying again, Yee-Haw!! Hans van der Voort Proud Owner/Builder/flyer of Pietenpol NX 15 KV Miss Banshee Waller, 3XS7 Houston Sectional ________________________________________________________________________________
Date: Aug 24, 2005
Congrats to both of you on first flights. On the question of winterizing- I just turn my engine over a couple of times every few weeks and start it up on an occasional nice day. I'm in Minnesota so a nice day can be 30+. Dick N. ----- Original Message ----- From: <harvey.rule(at)bell.ca> Subject: RE: Pietenpol-List: First Flights > > I know a Pete Vander Voort who lives in Manitick just outside of Ottawa > are you any relation to him.Your computer puts out some strange symbols;I > don't know if your aware of it.I should be ready to fly within the next > month if all goes well.Just in time to put her away for the winter.By the > way what do you guys do to winterize your plane,engine and everything.I > use Downy fabric softener clothes all over the plane wherever there is an > opening to make sure the mice don't get in.They don't like the smell of > Downy.I'm not quite sure if there is anything that can be sprayed in the > cylinders.I heard that just squirting some oil in is all that it really > takes.I was given these things that look like they go into the spark plug > holes and they have what appears to be a crystal inside the glass case.I'm > not sure but I think they are for soaking up moisture.Anybody else ever > seen these things? > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > hans.vander.voort(at)alfalaval.com > Sent: August 24, 2005 8:29 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: First Flights > > > Congratulations Lou, I know how you must feel, you where not alone. > > Saturday, August 20th @ 4 PM, my Pietenpol Air Camper Miss Banshee > made > her first flight also. > > The weather was great, a slight breeze form the south, Heat index of 105 F > and a density altitude of 2400 Ft. > > The Airplane flies hands-off straight and the Corvair engine performs > flawless. > > I must thank all of you Pietenpol listers for all the questions and > answers > that have been posted, this list is truly a great resource for all > builders. > Every time a question arose during the construction phase, I was always > able to find answers on the list or in the archives. > > Thank you All, > > I will have to repay the favor by sharing my experience in the future. > > I will start with this; > My Pietenpol is the improved long fuselage Air Camper. > Empty weight 680 Lbs > Split Landing gear with 6 x 6.00 wheels, Matco wheels and brakes > The main deviations from plans are: > 1) Wheels are 3 forward of plans. (changed the landing gear V > slightly) > 2) Bungies replaced with coil springs. > 3) Engine mount extended by to give Corvair more clearance to > Firewall. > > Engine O-164 Corvair, William Wynne conversion with front starter > Propeller: Tennessee prop. 64 x 34 > Carburetor: Zenith 1821 > > I started this Pietenpol project in March of 2004 and build a little > every day. > I took me around 1780 Hours to complete it, (yes, thats right in a year > and a half and holding a day job) > > Now its off to flying again, Yee-Haw!! > > Hans van der Voort > Proud Owner/Builder/flyer of Pietenpol NX 15 KV Miss Banshee > Waller, 3XS7 Houston Sectional > > > ________________________________________________________________________________
Date: Aug 24, 2005
Subject: A-65
Pieters, Thanks for all the helpful comments. I used most of them. This morning before it reached 90 my man was proping after we had primed each cyl through the top plugs. He pulled it through about 4 times and nothing. On the next prop I moved the throttle to about 1/3 open. She fired. I had an oil pressure guage fitted next to the case. Oil pressure began to show after 20 or so seconds finally up to 30 @ 1200 rpm. I would reduce the throttle below 1000 and it would begin to stop so kept it at 1200 for about 5 minutes but each time I lowered it below 1000 it tried to die. Soooooooooooooooooooooooooooo something tells me that I must have a problem in the idle system somewhere. But where? I had taken the carb apart several times to clean and check everything according to the manuals EXCEPT that little brass tube sticking up out of the lower body. I have another old carb body so I put that little tube in the vise and carefully turned the body until it loosened. I removed and examined. Studying the manual this was the idle metering tube. The lower end being the idle metering jet. It was blocked with no light to be seen through it. With some brass safety wire I began to clean and sure enough there was a jet hole there. I removed the carb on the engine, took it apart again and removed the idle metering tube and guess what I found. Yep, no hole and it took quite awhile to finally clean the gook out. It's clean now and all reassembled. When my prop-er comes back we will see if it works. Sorry this has been so drawn out but I wanted it in the archives in case someone in the future is faced with identical problems. Had to stop as the temp just jumped to 100 and as we say down here, you talk about, man it's hot. Corky ________________________________________________________________________________
Subject: Re: A-65
Date: Aug 24, 2005
I am sure glad to live up nawth where it is a cool 75. Chris Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, August 24, 2005 2:32 PM Subject: Pietenpol-List: A-65 Pieters, Thanks for all the helpful comments. I used most of them. This morning before it reached 90 my man was proping after we had primed each cyl through the top plugs. He pulled it through about 4 times and nothing. On the next prop I moved the throttle to about 1/3 open. She fired. I had an oil pressure guage fitted next to the case. Oil pressure began to show after 20 or so seconds finally up to 30 @ 1200 rpm. I would reduce the throttle below 1000 and it would begin to stop so kept it at 1200 for about 5 minutes but each time I lowered it below 1000 it tried to die. Soooooooooooooooooooooooooooo something tells me that I must have a problem in the idle system somewhere. But where? I had taken the carb apart several times to clean and check everything according to the manuals EXCEPT that little brass tube sticking up out of the lower body. I have another old carb body so I put that little tube in the vise and carefully turned the body until it loosened. I removed and examined. Studying the manual this was the idle metering tube. The lower end being the idle metering jet. It was blocked with no light to be seen through it. With some brass safety wire I began to clean and sure enough there was a jet hole there. I removed the carb on the engine, took it apart again and removed the idle metering tube and guess what I found. Yep, no hole and it took quite awhile to finally clean the gook out. It's clean now and all reassembled. When my prop-er comes back we will see if it works. Sorry this has been so drawn out but I wanted it in the archives in case someone in the future is faced with identical problems. Had to stop as the temp just jumped to 100 and as we say down here, you talk about, man it's hot. Corky ________________________________________________________________________________
Subject: Gas tank size
Date: Aug 24, 2005
As I approach the completion of my wings (wooden completion), I will next work on the center section. I recall some Pieters recommending to build the center section 36" wide to accommodate a larger fuel tank. I thought I heard that a 36" section will hold about 14 gallons, which makes sense (25" x26" x 5" x 0.0043 = 13.975 gallons). At 6.25 lbs per gallon, that's 87 pounds of fuel. Is 87 pounds of fuel a lot for a Pietenpol to lift with a couple a people in it? Let's assume a Corvair engine, extended fuselage, limited avionics, and let's assume 90% of the flying time carries only one person in the plane (for those who enjoy to compromise). Any thoughts, or better yet, experience? This e-mail is intended for the use of the addressee(s) only and may contain privileged, confidential, or proprietary information that is exempt from disclosure under law. If you have received this message in error, please inform us promptly by reply e-mail, then delete the e-mail and destroy any printed copy. Thank you. ============================================================================== ________________________________________________________________________________
Date: Aug 24, 2005
In a message dated 8/24/2005 6:19:34 AM Central Standard Time, Jack.Phillips(at)cardinal.com writes: Mine often takes the full 30 seconds to get any indication on the oil pressure gage, as it is a long way from the engine to the rear cockpit I've purged the air from my oil line before I ever started the engine for the first time, and it still takes maybe 20 seconds for the gage to read, especially after it sits for a few weeks. It seems like an eternity staring at the gage thinking...c'mon...c'mon...gimmee a reading... If I run the engine on a daily basis, it has a reading before I can even get from the spinning prop to the left side of the cockpit. It seems to me, that the oil drains down past the pump gears, and empties some of the oil from the screen area, which has to fill up before getting a gage reading. By raising the tail, you dump the residual oil from the screen area that can't drain out, and prime the pump with it. If the plane sits level for a period of time, you loose the oil in the screen area, and and another means to prime the pump is required. Chuck G. ________________________________________________________________________________
Subject: Re: tape to use on ailerons and elevator
Date: Aug 24, 2005
----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: tape to use on ailerons and elevator =================================== Oscar, Look at the tape used to seal the wing root gaps on sailplanes after assembly. I used it, works well. May be able to find it on the internet, my friend, a sailplane owner/pilot gave me a roll to use. Drop your control surface all the way down then apply tape to the gap, will form only a very small hump when surface is at neutral position. Hope this helps, John ================================== > > > Harvey wrote- > >>I'd like to know what is the best tape to use in these places for >>gap cover? I will order the one you guys say is best. > > Well, I have not used this myself (yet), but one of the guys over on the > KRNet suggested "gaffers tape" for use on the wing gap seals on KRs. This > is tape that is used in movie sets to tape wiring down onto the floor, so > it doesn't have adhesive down the middle part of the tape... the part that > would be over the gap between the wing and the control surface. It's > available in an assortment of colors. Here's one example: > http://www34.pair.com/harrison/thetapeworks.com/progaff.htm > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Date: Aug 24, 2005
Lou and Hans, A hearty CONGRATULATIONS to you on your first flights !! Quite a milestone !! In a message dated 8/24/2005 8:30:05 AM Central Standard Time, Jack.Phillips(at)cardinal.com writes: I got hooked on the RV-10 at OSH this year and am already cleaning up the workshop in anticipation of starting on it. Jack and all, Have you considered a Wittman Tailwind W10 ? Did you also notice that one of them won First Place 'Formula FX' race this year at Osh, beating out all similar horsepower RV's, canards, and other glass planes, with an average speed of 218 mph ? Yeah, I know it's a two place, but it is a scratch built plane, well under half the price of an RV, and it sure is FAAAAAST !! Not that I'm prejudiced or anything, but a Wittman W10 is my current project. Chuck Gantzer NX770CG looking forward to passing up all those RV's when the Tailwind is done !! ________________________________________________________________________________
Subject: Re: Gas tank size
Date: Aug 24, 2005
Hi John, NX18235 has a center section built to the Keri-Ann Price plans. A 15 gallon tank was built to fit this center section. This aircraft has an empty weight of 616 # and has flown at weights in excess of 1125# on 85 deg. F. days. Greg Cardinal ----- Original Message ----- From: "Egan, John" <jegan(at)kcc.com> Subject: Pietenpol-List: Gas tank size > "Egan, John" > > As I approach the completion of my wings > (wooden completion), I will > next work on the center section. I recall > some Pieters recommending to > build the center section 36" wide to > accommodate a larger fuel tank. I > thought I heard that a 36" section will > hold about 14 gallons, which > makes sense (25" x26" x 5" x 0.0043 = > 13.975 gallons). At 6.25 lbs per > gallon, that's 87 pounds of fuel. Is 87 > pounds of fuel a lot for a > Pietenpol to lift with a couple a people in > it? Let's assume a Corvair > engine, extended fuselage, limited > avionics, and let's assume 90% of the > flying time carries only one person in the > plane (for those who enjoy to > compromise). Any thoughts, or better yet, > experience? > > > This e-mail is intended for the use of the > addressee(s) only and may contain > privileged, confidential, or proprietary > information that is exempt from disclosure > under law. If you have received this > message in error, please inform us promptly > by reply e-mail, then delete the e-mail and > destroy any printed copy. Thank you. > ============================================================================== > > > Forum - > Subscriptions page, > Browse, Chat, FAQ, > > > ________________________________________________________________________________
Subject: Re: Pietenpol-List Digest: 22 Msgs - 08/22/05
Date: Aug 25, 2005
From: Isablcorky(at)aol.com Subject: Pietenpol-List: A-65 Pieters: I need a lot of help. Can't start engine without pouring raw fuel in the top plug holes. Have started twice. First time it ran for about 10 seconds. Next day, same priming procedure, it ran for about 15 seconds. Has anyone experienced this behavior with your 65? I've overhauled the carb daily, new steel needle and seat, gaskets. I took the brass revolving plate, mixture, out. Read the A-65 manual until the print is fading also the Stromberg NA-S3A1 manual. The only thing I can't comply with from the manual is the 18 inch head of fuel above the carb. I only have 8 inches from tank bottom to carb bottom. Will one of you engine know-hows please come to my rescue? Mags are very hot from rebuild. Engine has new bearings, guides, rings etc. Thanks in advance Corky In La trying to start this d--- thing in 102 temp. Corky, I'm new to the list and new to A-65's, only had mine for a couple of weeks now, but I've learned a little about the Stromberg NA-S3A1 in my brief ownership: Set the fuel level by the book (and you're right to use the steel needle, a swollen neoprene tip started my Stromberg lessons). I set mine up on the bench in a pie tin to contain any leaks, leveled it , and used a clean gear lube container hung from overhead & tygon tubing to simulate the actual head of 1/2 tank fuel in the plane. (figured that was "average" head) Took about 6-8 attempts to get it right, but the color of the plugs is perfect now. Get this right because if the level is just slightly high she'll run fuel out of the atomizer as soon as you turn on the fuel shutoff valve. Normal level is just under the atomizer ports. If you have the idle mixture screw about 1.5 turns out from seated and the idle ports are clear, she should take about 4-6 blades to get fuel into the cylinders and then start right up. Others will tell you otherwise, but I don't think you can adjust the idle mixture on this or any other carb/engine without the engine running. Yes, it's dangerous, but the screw is pointed aft & you're well away from the prop with a long screwdriver. Just be careful and have the plane tied/chocked and a safety man with a hand on the mag switch. (Can't imagine trying to adjust the idle on my old BMW motorcycle by repeated starts/stops/adjustments...what a pain) Other Stuff to check: Has the idle speed screw been moved since the engine last ran? Having the throttle plate just slightly open too far will result in no fuel being drawn from the idle mixture port(s). Check for intake leaks at the intake elbow to head flanges, will result in the same thing. Ignition timing: The A&P who built my engine was a stickler on this. Both impulse mags click simultaneously, timing is dead on. (New Slicks & harnesses) On the oil pressure issue: My engine will fail to develop oil pressure after an oil change or sitting for several weeks unless I remove the oil pressure sending line and pump about 1/2 a squirt can of oil into it. Just keep a big pump oil can around with about 2 feet of 1/4 tygon tubing clamped on it's spout. There are a couple of old Cub pilots around here who turned me onto this trick. It takes several ounces to fill the pump cavity. Be generous. Dave Mordecai in Panacea, Fl (heat index of 105 today, too &#*$ # hot to fly) From: Isablcorky(at)aol.com Subject: Pietenpol-List: A-65 Pieters: I need a lot of help. Can't start engine without pouring raw fuel in the top plug holes. Have started twice. First time it ran for about 10 seconds. Next day, same priming procedure, it ran for about 15 seconds. Has anyone experienced this behavior with your 65? I've overhauled the carb daily, new steel needle and seat, gaskets. I took the brass revolving plate, mixture, out. Read the A-65 manual until the print is fading also the Stromberg NA-S3A1 manual. The only thing I can't comply with from the manual is the 18 inch head of fuel above the carb. I only have 8 inches from tank bot tom to carb bottom. Will one of you engine know-hows please come to my rescue? Mags are very hot from rebuild. Engine has new bearings, guides, rings etc. Thanks in advance Corky In La trying to start this d--- thing in 102 temp. Corky, I'm new to the list and new to A-65's, only had mine for a couple of weeks now, but I've learned a little about the Stromberg NA-S3A1 in my brief ownership: Set the fuel level by the book (and you're right to use the steel needle, a swollen neoprene tip started my Stromberg lessons). I set mine up on the bench in a pie tin to contain any leaks, leveled it ,and used a clean gear lube container hung from overhead tygon tubing to simulate the actual head of 1/2 tank fuel in the plane. (figured that was "average" head) Took about6-8 attempts to get it right, but the color of the plugs is perfect now. Get this right because if the level is just slightly high she'll run fuel out of the atomizer as soon as you turn on the fuel shutoff valve. Normal level is just under the atomizer ports. If you have the idle mixture screw about 1.5 turns out from seated and the idle ports are clear, she should take about 4-6 blades to get fuel into the cylinders and then start right up. Otherswill tell you otherwise, but I don't think you can adjust the idle mixture on this or any other carb/engine without the engine running. Yes, it's dangerous, but the screw is pointed aft you're well away from the prop with a long screwdriver. Just be careful and have the plane tied/chocked and a safety man witha hand on the mag switch.(Can't imagine trying to adjust the idle on my old BMW motorcycle by repeated starts/stops/adjustments...what a pain) Other Stuff to check: Has the idle speed screw been moved since the engine last ran? Having the throttle plate just slightly open too far will result in no fuel being drawn from the idle mixture port(s).Check for intake leaks at the intake elbow to head flanges, will result in the same thing. Ignition timing: The AP who built my engine was a stickler on this. Both impulse mags click simultaneously, timing is dead on. (New Slicks harnesses) On the oil pressure issue: My engine will fail to develop oil pressure after an oil change or sitting for several weeks unless I remove the oil pressure sending line and pump about 1/2 a squirt canof oil into it.Just keep a big pump oil can around with about 2 feet of 1/4 tygon tubing clamped on it's spout. There are a couple of oldCub pilots aroundhere who turnedme onto this trick.It takes several ounces to fill the pump cavity. Be generous. Dave Mordecai in Panacea, Fl (heat index of 105 today, too #*$ # hot to fly) ________________________________________________________________________________
Date: Aug 25, 2005
Subject: left coast piets
----- Original Message ----- From: Clif Dawson Subject: Re: Pietenpol-List: left coast piets They're all on Vancouver Island. :-) The oldest continuously registered aircraft in Canada, CF-AOG, is flying off a private strip, one is flying out of Naniamo and the other is completed and in flight testing, again, at Naniamo. I almost forgot! It appears Dave Rowe has been posted to the far Atlantic Coast somewhere. I don't know the status of both his planes but some time ago they were under tarps in the corner of a hanger at Pat Bay ( Victoria International ). The attached photo is the one currently testing, built by Dean Sevold. Powered by a Ford "B" Clif ----- Original Message ----- From: DONALD COOLEY To: pietenpol-list(at)matronics.com Sent: Sunday, August 21, 2005 10:38 PM Subject: Pietenpol-List: gap seals Hello Group, I was wondering.....how about using piano hinges for elevators? The only real drawback I can see is that it wouldn't look "authentic". Maybe function dictates form? I plan using piano hinges for the ailerons, so this seems not too out of line. Comments? BTW, I just returned from the NWAAC Fly-in at McMinnville, Oregon. There was not a single Piet at this fairly prestigious event. Mine is still probably several years from attending. Will it be the first? Where are all the Left Coast Piets? The world awaits an answer! Keep the sawdust flyin'! Don Cooley ________________________________________________________________________________
Subject: A-65
Date: Aug 25, 2005
Don't wory ,Texan's get their fair share of snow and rotten weather from what I've seen.It just doesn't last as long. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Christian Bobka Subject: Re: Pietenpol-List: A-65 I am sure glad to live up nawth where it is a cool 75. Chris Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, August 24, 2005 2:32 PM Subject: Pietenpol-List: A-65 Pieters, Thanks for all the helpful comments. I used most of them. This morning before it reached 90 my man was proping after we had primed each cyl through the top plugs. He pulled it through about 4 times and nothing. On the next prop I moved the throttle to about 1/3 open. She fired. I had an oil pressure guage fitted next to the case. Oil pressure began to show after 20 or so seconds finally up to 30 @ 1200 rpm. I would reduce the throttle below 1000 and it would begin to stop so kept it at 1200 for about 5 minutes but each time I lowered it below 1000 it tried to die. Soooooooooooooooooooooooooooo something tells me that I must have a problem in the idle system somewhere. But where? I had taken the carb apart several times to clean and check everything according to the manuals EXCEPT that little brass tube sticking up out of the lower body. I have another old carb body so I put that little tube in the vise and carefully turned the body until it loosened. I removed and examined. Studying the manual this was the idle metering tube. The lower end being the idle metering jet. It was blocked with no light to be seen through it. With some brass safety wire I began to clean and sure enough there was a jet hole there. I removed the carb on the engine, took it apart again and removed the idle metering tube and guess what I found. Yep, no hole and it took quite awhile to finally clean the gook out. It's clean now and all reassembled. When my prop-er comes back we will see if it works. Sorry this has been so drawn out but I wanted it in the archives in case someone in the future is faced with identical problems. Had to stop as the temp just jumped to 100 and as we say down here, you talk about, man it's hot. Corky ________________________________________________________________________________
Date: Aug 25, 2005
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
You always have the option to keep the tank less than full. With a smaller tank you don't have the option to carry more fuel. With a Pietenpol's limited ability to battle headwinds, I would think anything less than 3 hours of fuel capacity is pretty limiting. I find that a leg longer than 2 hours is pretty uncomfortable, but it is nice to be able to handle a 3 hour leg if necessary. Jack -----Original Message----- As I approach the completion of my wings (wooden completion), I will next work on the center section. I recall some Pieters recommending to build the center section 36" wide to accommodate a larger fuel tank. I thought I heard that a 36" section will hold about 14 gallons, which makes sense (25" x26" x 5" x 0.0043 = 13.975 gallons). At 6.25 lbs per gallon, that's 87 pounds of fuel. Is 87 pounds of fuel a lot for a Pietenpol to lift with a couple a people in it? Let's assume a Corvair engine, extended fuselage, limited avionics, and let's assume 90% of the flying time carries only one person in the plane (for those who enjoy to compromise). Any thoughts, or better yet, experience? ________________________________________________________________________________
Date: Aug 25, 2005
I would consider a Tailwind if I were building a 2 place travelling airplane. I admire Wittman's designs from a functionality standpoint. I don't think his designs are particularly pretty, but they certainly are efficient. But I want a 4 place plane that is fast with good short field characteristics. I am considering an RV-10, a Murphy Moose, and a Bearhawk. So far, the RV-10 looks like it has the most bang for the buck. Ran across a deal on an RV-4 yesterday, but I don't think I can swing the cash for the deal without selling the Pietenpol which I refuse to even consider. Jack -----Original Message----- =09 =09 Jack and all, Have you considered a Wittman Tailwind W10 ? Did you also notice that one of them won First Place 'Formula FX' race this year at Osh, beating out all similar horsepower RV's, canards, and other glass planes, with an average speed of 218 mph ? Yeah, I know it's a two place, but it is a scratch built plane, well under half the price of an RV, and it sure is FAAAAAST !! Not that I'm prejudiced or anything, but a Wittman W10 is my current project. Chuck Gantzer NX770CG looking forward to passing up all those RV's when the Tailwind is done !! ________________________________________________________________________________
Date: Aug 25, 2005
I won't be using the front seat at any time for passengers so I can always drop a tank of gas in that area provided I tie her down well.I guess since I'm not carrying passengers then theoretically I could take as much gas as a passenger would weigh.Always an option. -----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phillips, Jack Subject: RE: Pietenpol-List: Gas tank size You always have the option to keep the tank less than full. With a smaller tank you don't have the option to carry more fuel. With a Pietenpol's limited ability to battle headwinds, I would think anything less than 3 hours of fuel capacity is pretty limiting. I find that a leg longer than 2 hours is pretty uncomfortable, but it is nice to be able to handle a 3 hour leg if necessary. Jack -----Original Message----- As I approach the completion of my wings (wooden completion), I will next work on the center section. I recall some Pieters recommending to build the center section 36" wide to accommodate a larger fuel tank. I thought I heard that a 36" section will hold about 14 gallons, which makes sense (25" x26" x 5" x 0.0043 = 13.975 gallons). At 6.25 lbs per gallon, that's 87 pounds of fuel. Is 87 pounds of fuel a lot for a Pietenpol to lift with a couple a people in it? Let's assume a Corvair engine, extended fuselage, limited avionics, and let's assume 90% of the flying time carries only one person in the plane (for those who enjoy to compromise). Any thoughts, or better yet, experience? ________________________________________________________________________________
Date: Aug 25, 2005
27, 2005) at 08/25/2005 08:35:47 AM John, I use standard center section, 3 piece wing. And made a aluminum fuel tank that holds 14 gallon plus I have a 2 gallon Header tank in the front. The Corvair, according to WW conversion manual, should burn 3.5 GPH. That gives a long range for a Pietenpol. I have been test flying my Piet every evening since Saturday and 45 minutes is a long time on a wooden bench. You will need a good seat cushion to get use out of a larger fuel tank. Hans "Egan, John" Sent by: To owner-pietenpol-l pietenpol-list(at)matronics.com ist-server@matron cc ics.com Subject Pietenpol-List: Gas tank size 08/24/2005 04:05 PM Please respond to pietenpol-list@ma tronics.com As I approach the completion of my wings (wooden completion), I will next work on the center section. I recall some Pieters recommending to build the center section 36" wide to accommodate a larger fuel tank. I thought I heard that a 36" section will hold about 14 gallons, which makes sense (25" x26" x 5" x 0.0043 = 13.975 gallons). At 6.25 lbs per gallon, that's 87 pounds of fuel. Is 87 pounds of fuel a lot for a Pietenpol to lift with a couple a people in it? Let's assume a Corvair engine, extended fuselage, limited avionics, and let's assume 90% of the flying time carries only one person in the plane (for those who enjoy to compromise). Any thoughts, or better yet, experience? This e-mail is intended for the use of the addressee(s) only and may contain privileged, confidential, or proprietary information that is exempt from disclosure under law. If you have received this message in error, please inform us promptly by reply e-mail, then delete the e-mail and destroy any printed copy. Thank you. ============================================================================== ________________________________________________________________________________
Date: Aug 25, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
I agree with Jack P. that you can always off load fuel if you want to take a passenger on a warmer day or get out of a shorter strip, but should you land on a x-country like I did coming back from Brodhead (remember Bryan, Ohio Jack ?) on a Sunday and find there is nobody around to help you with fuel---you can always soldier on to the next airport. I do like the automated pumps at my home airport. Mike C. ________________________________________________________________________________
Date: Aug 25, 2005
Congratulations Hans, finishing in only a year and a half (including building your Corvair) is incredible. I am also building a long fuselage Corvair Piet, (Matco wheels and brakes also) one question, did you extend the front of your fuselage or engine mounts to get the CG to the point where you didn't have to move your wing back? (vertical cabanes?) Rick H. > > > Thank you All, > > I will have to repay the favor by sharing my experience in the future. > > I will start with this; > My Pietenpol is the improved long fuselage Air Camper. > Empty weight 680 Lbs > Split Landing gear with 6 x 6.00 wheels, Matco wheels and brakes > The main deviations from plans are: > 1) Wheels are 3" forward of plans. (changed the landing gear "V" slightly) > 2) Bungies replaced with coil springs. > 3) Engine mount extended by =BD" to give Corvair more clearance to Firewall. > > Engine O-164 Corvair, William Wynne conversion with front starter > Propeller: Tennessee prop. 64 x 34 > Carburetor: Zenith 1821 > > I started this Pietenpol project in March of 2004 and build a "little" > every day. > I took me around 1780 Hours to complete it, (yes, that's right in a year > and a half and holding a day job) > > Now it's off to flying again, Yee-Haw!! > > Hans van der Voort > Proud Owner/Builder/flyer of Pietenpol NX 15 KV "Miss Banshee" > Waller, 3XS7 Houston Sectional > > > > -- Rick Holland ________________________________________________________________________________
Date: Aug 25, 2005
27, 2005) at 08/25/2005 09:47:44 AM Thanks Rick, I have my Hangar behind my house (Airpark) which makes it very easy to work on the plane and keep a good pace. I did not extend the fuselage other than the 1/2 inch on the motor mount. The reason for this was that the standard Corvair oil filter would almost hit the Firewall. And with a layer of Fiberfrax and stainless sheet would be impossible to mount. The other option would have been a remote oil filter but this would increase component count and weight. Or yet another option would have been to make a recess in the firewall but I was to far along to do that. If I build a Air Camper again I would build the Firewall 2" back and extend the Motor mount the same. My Cabanes are not vertical, they lean about 1 1/2" back. Please note, that with the above setup (CG at 18" from Leading Edge) and with Landing gear V as per drawing, I only had 1 Lbs on my Tail wheel during W&B, top longeron level. I decided to move wheels forward by 3 " tail wheel pressure is now 15 Lbs. I did some wheel landings last night and it seems very stable. Hans ________________________________________________________________________________
Subject: hard seat
Date: Aug 25, 2005
I don't remember who to credit for this. At Broadhead, as I was complaining about my sore butt from the 4.7 hr trip down, somone commented that he used his sleeping bag pad as a cushion. I tried this on the way home. I have a self inflating pad and folded it over three times and left the valve up at the seat top. I am able to let air out to get the right height. This has made an extremely comfortable seat. These are available at Gander Mtn stores for about $80. Also they have a cover available to hold this pad into the seat shape for $39. Dick N. ________________________________________________________________________________
Date: Aug 25, 2005
27, 2005) at 08/25/2005 12:18:43 PM Bill, Started a web site yesterday www.hometown.aol.com/hvandervoo/indexfront.html Have a look ! Hans "Bill Church" To Sent by: owner-pietenpol-l cc ist-server@matron ics.com Subject Re: Pietenpol-List: First Flights 08/25/2005 10:23 AM Please respond to pietenpol-list@ma tronics.com Lou and Hans, How about some pictures of your finished planes? Do Not Archive ________________________________________________________________________________
Date: Aug 25, 2005
Subject: Re: Hans new web site
Try this link: _http://hometown.aol.com/hvandervoo/indexfront.html_ (http://hometown.aol.com/hvandervoo/indexfront.html) ________________________________________________________________________________
Subject: fixed landing gear
Date: Aug 25, 2005
I did an inspection of my plane tonight and found that my fixed gear axle is bent. There is about a 1" deflection in the axle,with the stbd wheel showing the bend. I had a bit of a discussion at Brodhead, with Jack Phillips on axle sizing and Jack, you are right, the 1 1/4" x .125 wall is not heavy enough for the fixed gear. I have a spare axle of the same size and will install that but will also sleeve the inside with a 1" oak dowel. I will then order a new 1 1/2" and install in down time this winter. Also, one of my cross brace cables is showing the stress threads. I just replaced the cables before Brodhead. I will up size these cables to 5/32". I belive the axle bent last Saturday when I made a full stall landing in a 15-18 kt cross wind. I should have done a wheel landing, I guess. It wasn't a horrible touchdown but there were some pretty good side loads in settling in. The Harley wheels held up very well though. This was one of those days when the wind was varied and gusting thru 50 degrees. Dick N. ________________________________________________________________________________
Date: Aug 25, 2005
Very nice Hans. I've posted your website to the Corvair list. I think they will all be quite appreciative of your efforts. > www.hometown.aol.com/hvandervoo/indexfront.html > > Have a look ! > > Hans > ________________________________________________________________________________
Date: Aug 25, 2005
Subject: Re: Gas tank size Gas transfer.
Garden sprayer is one name. They come in various sizes and are used for fertilizer, bug sprays and other things. If you're flying behind a Corvair you'll have a battery anyway. The electric pump won't take much to run. Let's see, the average official passenger wt here in Canada is now 187 imperial pounds, 31 gallons!. That's going to be one calloused butt! And a lot of bug spray out the pilot tube! :-) Clif Yes, but what is the name (in english) of that plastic poisoner bottle? Not important just that I think that has an specific name... Just curious... Saludos Gary Gower. > What has worked great for us, is to make the extra tank airtight and pressurize with a cheap 2 quarts (ups! my english) bottle to aply poison on the gardens :-) Just give about 5 pumps and the gasoline will transfer. No electricity needed. Not much preassure either. > > Saludos > Gary Gower.> > > HAHAHA!I can well imagine it would cause a commotion.I've seen > ultralight pilots do the same thing.What some guys do is hook up a small > pump to thar spare tank and with the flick of a switch they pump gas > from there to the main tank.It does require carrying a battery sourse > though in order to run the small pump.The whole thing isn't exactly the > safest way to fly but it works. > > guess since I'm not carrying passengers then theoretically I could take > as much gas as a passenger would ________________________________________________________________________________
Date: Aug 25, 2005
I don't think you need a specific poison pump bottle. Any air pump, such as used to inflate air mattresses and even a bicycle pump would work. You're pressurizing the sealed fuel tank and forcing the fuel out into the main tank. I like both this and the electric pump options. With the electric pump you could probably strap in a couple of 5 gal jerry cans with tubing securely fitted into them. This would give you two carryable, handled containers to go to a gas station with as well. Also here's a gap seal option from another RAA member; "The SeaRey guys use the 3M tape that protects the bottom rocker panels of cars from stone chips. Canadian Light Amphibians , seareycanada.com I've seen it used as prop leading edge tape too." Clif ----- Original Message ----- From: Gary Gower To: pietenpol-list(at)matronics.com Sent: Thursday, August 25, 2005 6:19 PM Subject: Re: RE: Pietenpol-List: Gas tank size Gas transfer. Yes, but what is the name (in english) of that plastic poisoner bottle? Not important just that I think that has an specific name... Just curious... Saludos Gary Gower. sbobka(at)charter.net wrote: good idea, Gary. Chris > > From: Gary Gower > Date: 2005/08/25 Thu AM 11:06:23 EDT > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Gas tank size Gas transfer. > > Here we dont have enough airstrips here and is dificult to get gasoline on a XCountry flight (on ultralights), legs of more than 4 hours are common among us (at 60-70 mph) so we always fly with our extra gas tank in the passenger seat. > > What has worked great for us, is to make the extra tank airtight and pressurize with a cheap 2 quarts (ups! my english) bottle to aply poison on the gardens :-) Just give about 5 pumps and the gasoline will transfer. No electricity needed. Not much preassure either. > > Saludos > Gary Gower.> ________________________________________________________________________________
Date: Aug 25, 2005
Thanks Cliff, just learning, We only uswd to carry about 2 hrs estimated of extra fuel, for safety. Plus the normal 3 -4 hrs in the main tank. Two stroke engines use lots of gas. Right now I fly with a 912S (Rotax), so no extra tank needed. No, not a Piet, but a CH 701 by Zenith, that I co-own with my brother.. Saludos Gary Gower Clif Dawson wrote: Garden sprayer is one name. They come in various sizes and are used for fertilizer, bug sprays and other things. If you're flying behind a Corvair you'll have a battery anyway. The electric pump won't take much to run. Let's see, the average official passenger wt here in Canada is now 187 imperial pounds, 31 gallons!. That's going to be one calloused butt! And a lot of bug spray out the pilot tube! :-) Clif Yes, but what is the name (in english) of that plastic poisoner bottle? Not important just that I think that has an specific name... Just curious... Saludos Gary Gower. > What has worked great for us, is to make the extra tank airtight and pressurize with a cheap 2 quarts (ups! my english) bottle to aply poison on the gardens :-) Just give about 5 pumps and the gasoline will transfer. No electricity needed. Not much preassure either. > > Saludos > Gary Gower.> > > HAHAHA!I can well imagine it would cause a commotion.I've seen > ultralight pilots do the same thing.What some guys do is hook up a small > pump to thar spare tank and with the flick of a switch they pump gas > from there to the main tank.It does require carrying a battery sourse > though in order to run the small pump.The whole thing isn't exactly the > safest way to fly but it works. > > guess since I'm not carrying passengers then theoretically I could take > as much gas as a passenger would ________________________________________________________________________________
Date: Aug 26, 2005
Sorry to hear that, Dick. It does confirm the stress analysis I did (unfortunately AFTER my own axle broke). The loading of this axle is somewhat peculiar in that the stress due to bending moments is constant in the area between the bungees. In other words, just sleeving the area around the bungees won't improve things, it will just move the failure point to the place where the sleeve stops. What I found when doing some research after my accident was that the gear should be sized to fail at something between 3 and 5 G's. If you make it too strong and have a very hard landing, the gear will survive but will pass the stress on to some less robust part of the airframe, causing even more expensive damage. For a steel axle to be good to 3 G's (assuming a gross weight of 1100 lbs) with no heat treating (in other words, normalized 4130 steel), a 1-1/2" axle needs to be .218" thick. To be good for 4.5 G's (3 G's plus a 150% safety factor), an un-heat treated axle would need to be solid steel, 1-1/2" diameter and still would fall somewhat short. This is why I chose to heat treat my new axle to 130,000 psi tensile strength (105,000 psi yield strength), allowing me to use the considerably lighter wall thickness of .188" and still be good to almost 5 G's. I've attached an Excel spreadsheet that calculates the axle stress. The variables you can play around with in the spreadsheet are the material yield strength (60,000 psi for normalized 4130), the distance between the center of your tire and the center of the bungee attach point, which determines the bending moment, and the axle diameter and wall thickness. You can also plug in your actual gross weight. Once again, this shows the Bernard knew what he was doing when he designed the "Improved" Air Camper with the split axle gear. The straight axle can be made very strong (the undercarriage is extremely rugged), but the axle itself is pretty heavy. The split axle gear can be equally strong with much less weight. Jack Phillips, PE Sr. Manager, Disposables Product Development Clinical Technologies and Services Cardinal Health Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Subject: Pietenpol-List: fixed landing gear I did an inspection of my plane tonight and found that my fixed gear axle is bent. There is about a 1" deflection in the axle,with the stbd wheel showing the bend. I had a bit of a discussion at Brodhead, with Jack Phillips on axle sizing and Jack, you are right, the 1 1/4" x .125 wall is not heavy enough for the fixed gear. I have a spare axle of the same size and will install that but will also sleeve the inside with a 1" oak dowel. I will then order a new 1 1/2" and install in down time this winter. Also, one of my cross brace cables is showing the stress threads. I just replaced the cables before Brodhead. I will up size these cables to 5/32". I belive the axle bent last Saturday when I made a full stall landing in a 15-18 kt cross wind. I should have done a wheel landing, I guess. It wasn't a horrible touchdown but there were some pretty good side loads in settling in. The Harley wheels held up very well though. This was one of those days when the wind was varied and gusting thru 50 degrees. Dick N. ________________________________________________________________________________
Subject: Re: Pietenpol Aircraft
Date: Aug 26, 2005
27, 2005) at 08/26/2005 09:07:57 AM Thanks Robert, No, I do not have any patterns or plans of the cowling yet. I just build it, I started off with some foam and shaped a nose bowl. This foam nose bowl became the male plug/mold for the fiberglass/ epoxy bowl I did not make a traditional female mold. This nose bowl I then mounted on the Prop hub and rest is made from Aluminum .02- 2024 Same for the Eye brows. I did not know how big to make them to get good cooling. So expected to have to remake them, either smaller or bigger. They seem however spot-on Temperature on full power climb is about 420 F At 75 Mph cruise it is around 375. And that is in Texas heat of 100 F. They might be to big for winter. The Picture gives the cowling more credit than its due, close up there are a few imperfections. But it is good enough for flight. I do intend to redo some of the Cowling, I want to make a aluminum nose bowl an redo some of the top parts. I might make some pattern drawings this winter. Hans "Robert B. Holton" cc 08/25/2005 04:46 PM Subject Pietenpol Aircraft Hans, Your Airplane is beatiful to say the least! I am in the beginning stages of building a GN-1 Aircamper, and I too want to use a William Wynne Corvair Conversion. One of the only reasons I have considered not using the Corvair is because all the Pietenpols I have seen before with this engine did not have cowlings that I thought were very attractive. Then you posted the picture of your plane. Once again what a piece of art! I immediatley focused on the way you cowled your aircraft. It appears that you have put eye brows on the plane. I love that look, but have only seen them on Pietenpols with Continentals or Lycomings. Did you design you own cowl and eye brows to fit the Covrvair Motor? If so do you have patterns left over that you may be willing to sell to other builders. Let me know I would be interested. Robert B. Holton ________________________________________________________________________________
Subject: Re: fixed landing gear
Date: Aug 26, 2005
Thanks for all of that, Jack. I was planning on going to a 1.5 x .188 axle. Heat treating sounds like a very good idea. I have done that with small parts but how do you dp that on something this large? Also , did you up size your cross brace cables? Dick ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Friday, August 26, 2005 7:04 AM Subject: RE: Pietenpol-List: fixed landing gear Sorry to hear that, Dick. It does confirm the stress analysis I did (unfortunately AFTER my own axle broke). The loading of this axle is somewhat peculiar in that the stress due to bending moments is constant in the area between the bungees. In other words, just sleeving the area around the bungees won't improve things, it will just move the failure point to the place where the sleeve stops. What I found when doing some research after my accident was that the gear should be sized to fail at something between 3 and 5 G's. If you make it too strong and have a very hard landing, the gear will survive but will pass the stress on to some less robust part of the airframe, causing even more expensive damage. For a steel axle to be good to 3 G's (assuming a gross weight of 1100 lbs) with no heat treating (in other words, normalized 4130 steel), a 1-1/2" axle needs to be .218" thick. To be good for 4.5 G's (3 G's plus a 150% safety factor), an un-heat treated axle would need to be solid steel, 1-1/2" diameter and still would fall somewhat short. This is why I chose to heat treat my new axle to 130,000 psi tensile strength (105,000 psi yield strength), allowing me to use the considerably lighter wall thickness of .188" and still be good to almost 5 G's. I've attached an Excel spreadsheet that calculates the axle stress. The variables you can play around with in the spreadsheet are the material yield strength (60,000 psi for normalized 4130), the distance between the center of your tire and the center of the bungee attach point, which determines the bending moment, and the axle diameter and wall thickness. You can also plug in your actual gross weight. Once again, this shows the Bernard knew what he was doing when he designed the "Improved" Air Camper with the split axle gear. The straight axle can be made very strong (the undercarriage is extremely rugged), but the axle itself is pretty heavy. The split axle gear can be equally strong with much less weight. Jack Phillips, PE Sr. Manager, Disposables Product Development Clinical Technologies and Services Cardinal Health Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Thursday, August 25, 2005 10:43 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: fixed landing gear I did an inspection of my plane tonight and found that my fixed gear axle is bent. There is about a 1" deflection in the axle,with the stbd wheel showing the bend. I had a bit of a discussion at Brodhead, with Jack Phillips on axle sizing and Jack, you are right, the 1 1/4" x .125 wall is not heavy enough for the fixed gear. I have a spare axle of the same size and will install that but will also sleeve the inside with a 1" oak dowel. I will then order a new 1 1/2" and install in down time this winter. Also, one of my cross brace cables is showing the stress threads. I just replaced the cables before Brodhead. I will up size these cables to 5/32". I belive the axle bent last Saturday when I made a full stall landing in a 15-18 kt cross wind. I should have done a wheel landing, I guess. It wasn't a horrible touchdown but there were some pretty good side loads in settling in. The Harley wheels held up very well though. This was one of those days when the wind was varied and gusting thru 50 degrees. Dick N. ________________________________________________________________________________
Date: Aug 26, 2005
I didn't upsize the cables, but I used the very stiff 1x19 cable which is stronger than the 7x19. The only place I found that could heat treat an axle that long without warping is Rex Heat Treatment in Lansdale, PA. They do a lot of aerospace parts and have a vertical oven so the part doesn't lay down and warp. It was not cheap - $475 to do my axle, and it took about 6 weeks. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Subject: Re: Pietenpol-List: fixed landing gear Thanks for all of that, Jack. I was planning on going to a 1.5 x .188 axle. Heat treating sounds like a very good idea. I have done that with small parts but how do you dp that on something this large? Also , did you up size your cross brace cables? Dick N. ________________________________________________________________________________
Date: Aug 26, 2005
Dick-- my axle is about .20" thick and has survived some pretty rough landings and a groud loop when my tailwheel shoe failed. Mike C. PS-- the straight axle and wire wheels just look so go to me..I couldn't even consider the split axle version with donut tires. ________________________________________________________________________________
Date: Aug 26, 2005
Subject: Rims and Tires
Members of the list serve: I am seeking information on locating a supplier of aluminum rims and hubs. Also can you recommemd rims size and tires width. Along with that what about hub size and dimensions. Just seeking imput for the best possible selection. Sincerely, Kenneth M. Heide Fargo, ND ________________________________________________________________________________
Date: Aug 26, 2005
What kind of wheels? Spoked "Motorcycle" type, or more traditional aircraft type wheels? Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kenneth Heide Subject: Pietenpol-List: Rims and Tires Members of the list serve: I am seeking information on locating a supplier of aluminum rims and hubs. Also can you recommemd rims size and tires width. Along with that what about hub size and dimensions. Just seeking imput for the best possible selection. Sincerely, Kenneth M. Heide Fargo, ND ________________________________________________________________________________
Subject: Re: Rims and Tires
Date: Aug 26, 2005
27, 2005) at 08/26/2005 03:21:01 PM Ken, What landing gear? Split landingear is what I have, and I used Matco W62 wheels & brakes, 6 x 6.00 tires. Or straight axle gear with spoked motor cycle wheels, aerodrome aeroplanes make a nice set. Hans Kenneth Heide To Sent by: pietenpol-list(at)matronics.com owner-pietenpol-l cc ist-server@matron ics.com Subject Pietenpol-List: Rims and Tires 08/26/2005 02:07 PM Please respond to pietenpol-list@ma tronics.com Members of the list serve: I am seeking information on locating a supplier of aluminum rims and hubs. Also can you recommemd rimssize and tires width. Along with that what about hub size and dimensions. Just seeking imput for the best possible selection. Sincerely, Kenneth M. Heide Fargo, ND ________________________________________________________________________________ ETAsAhQXE4C0AvTEpp46yD6DX9tL2YmsKQIULhtztyOxcDzu51uYD+2aBBDBjlc=
Date: Aug 26, 2005
Subject: wheels and rims
Hi Ken: I am using Hager hubs and brakes. My wheels are al. atv whels 8" by 6 wide. nice and light, but not really cheap. Leon S. Ks. ________________________________________________________________________________
Date: Aug 26, 2005
Members of the list: I am interested in aluminum spoked rims and the width of the motorcycle tire. This also include suppliers of such, along with size of wheels, etc.....Sorry for the confusion! Ken Heide ________________________________________________________________________________
Date: Aug 26, 2005
OUCH ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Friday, August 26, 2005 9:52 AM Subject: RE: Pietenpol-List: fixed landing gear I didn't upsize the cables, but I used the very stiff 1x19 cable which is stronger than the 7x19. The only place I found that could heat treat an axle that long without warping is Rex Heat Treatment in Lansdale, PA. They do a lot of aerospace parts and have a vertical oven so the part doesn't lay down and warp. It was not cheap - $475 to do my axle, and it took about 6 weeks. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Friday, August 26, 2005 10:44 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: fixed landing gear Thanks for all of that, Jack. I was planning on going to a 1.5 x .188 axle. Heat treating sounds like a very good idea. I have done that with small parts but how do you dp that on something this large? Also , did you up size your cross brace cables? Dick N. ________________________________________________________________________________
Date: Aug 26, 2005
Ditto here on the wheels. Dont get me wrong here guys on this bent axle. This was not a near disaster or anything. I just noticed more deflection than previous and one of the cables had stressed. Dick ----- Original Message ----- From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> Subject: RE: Pietenpol-List: fixed landing gear > > > Dick-- my axle is about .20" thick and has survived some pretty rough > landings and a groud loop when my tailwheel shoe > failed. > > Mike C. > > PS-- the straight axle and wire wheels just look so go to me..I couldn't > even consider the split axle version with donut tires. > > > ________________________________________________________________________________
Date: Aug 27, 2005
Ken, Dale and I used 3.50 X 19 Chen Shin motorcycle tires mounted on 40 spoke DID rims which were located at a local motorcycle salvage yard. Spokes are custom from Buchanan Spoke and Rim in California. Hubs are 6" wide and were made to Howard Henderson's plans. Small picture attached. Greg Cardinal Minneapolis ----- Original Message ----- From: Kenneth Heide To: pietenpol-list(at)matronics.com Sent: Friday, August 26, 2005 5:18 PM Subject: Pietenpol-List: Rims and Tires Members of the list: I am interested in aluminum spoked rims and the width of the motorcycle tire. This also include suppliers of such, along with size of wheels, etc.....Sorry for the confusion! Ken Heide __________________________________________________ ________________________________________________________________________________
Date: Aug 27, 2005
I didn't do this on the already semi-completed Piete I bought and rebuilt, but for those of you out there in Pieteland that have yet to install a gear, you may want to consider picking up a fiberglass bow gear that is used on the Varieze and Longeze. It's made from strands of S-glass and epoxy wound over a mandrel, shaped like a hunting bow. Would support a Piet even with hard bounce. Very simple and tough. Not very traditional looking but you could always paint it with faux-wood paint to get the desired affect. Probably look on ebay and find one for less than a couple 100 bucks. They're made by Featherlite in Ukiah CA., think they still sell new for about $600. I've bounced my Cozy sized gear with a 2100 lb gross quite a few times without evidence of any damage. The gear could be attached to the existing tabs on the Piete's lower longerons with 7/16" bolts run thru the entire length of the front and back tabs and the gear attached with a 7/16" further ideas, chk out someone in your area that has a Rutanesque type canard-pusher's gear installation. Gordon Bowen -Homer Alaska Cozy IV N64CY Osprey II N64SY Pietenpol N-1033B " There are no passengers on spaceship Earth, we are all crew", McLuhan ----- Original Message ----- From: "Dick Navratil" <horzpool(at)goldengate.net> Subject: Re: Pietenpol-List: fixed landing gear > > Ditto here on the wheels. > Dont get me wrong here guys on this bent axle. This was not a near disaster > or anything. I just noticed more deflection than previous and one of the > cables had stressed. > Dick > ----- Original Message ----- > From: "Michael D Cuy" <Michael.D.Cuy(at)grc.nasa.gov> > To: > Sent: Friday, August 26, 2005 1:22 PM > Subject: RE: Pietenpol-List: fixed landing gear > > > > > > > > Dick-- my axle is about .20" thick and has survived some pretty rough > > landings and a groud loop when my tailwheel shoe > > failed. > > > > Mike C. > > > > PS-- the straight axle and wire wheels just look so go to me..I couldn't > > even consider the split axle version with donut tires. > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 27, 2005
Subject: Fwd: FW: pete
Heres the address to a neat free-flight Piet model. > http://smallflyingarts.com/Current_Content/Spotlight/aircamper.htm > > Subject: FW: pete Date: Wed, 24 Aug 2005 11:35:35 -0500 From: "Terry Bowden" <tbowden(at)ramaircraft.com> Terry L. Bowden Chief Engineer / D.E.R. Powerplant & Engines RAM Aircraft, Ltd. Partnership Office: (254) 752-8381 ext. 333 / Fax: (254) 752-3307 email: tbowden(at)ramaircraft.com website: www.ramaircraft.com -----Original Message----- From: Robert Toliver Subject: pete Check this out: http://smallflyingarts.com/Current_Content/Spotlight/aircamper.htm http://www.w3.org/TR/REC-html40"> Terry L. Bowden ChiefEngineer / D.E.R. Powerplant Engines RAM Aircraft, Ltd. Partnership Office: (254) 752-8381 ext. 333 / Fax: (254) 752-3307 email:=20tbowden(at)ramaircraft.com website: www.ramaircraft.com -----Original Message----- From: Robert Toliver Subject: pete Check this out: http://smallflyingarts.com/Current_Content/Spotlight/aircamper.htm ________________________________________________________________________________
From: "Philip Miller" <philip_miller_3(at)earthlink.net>
Date: Aug 27, 2005
Is it possible to use split landing gear with spoked wheels? If so, are there any special considerations about that (wheel dimensions limits, side loads, etc.) I like the look of the spoked wheels, but the impact absorbtion, strength and utility of the split axle sure looks more attractive. I'd miss those beautiful ash struts though. Phil Miller PietenVair Altadena,CA ________________________________________________________________________________
Date: Aug 27, 2005
Phil, Look up the 1929-30 Travelair 2000 landing gear for how it could be done -- the Travelair used 28 x 4 wheels with the shock cords attached to the center "vee" (like a J-3 Cub). It will take some drafting time to figure axle placement and landing gear angles for the right deck angle. Concerning the straight axle Piets -- if I remember correctly, aren't Part 23 landing gear (only) stressed for about 3g's ?? Mike C. Pretty Prairie, KS ----- Original Message ----- From: Philip Miller To: pietenpol-list(at)matronics.com Sent: Saturday, August 27, 2005 4:43 PM Subject: Fw: Pietenpol-List: Rims and Tires Is it possible to use split landing gear with spoked wheels? If so, are there any special considerations about that (wheel dimensions limits, side loads, etc.) I like the look of the spoked wheels, but the impact absorbtion, strength and utility of the split axle sure looks more attractive. I'd miss those beautiful ash struts though. Phil Miller PietenVair Altadena,CA ________________________________________________________________________________
Date: Aug 27, 2005
Subject: Re: (Maybe) First Flight?
N444MH, Howard Henderson's old plane, has it's wing moved 3" aft of it's plans built location, to accomodate my 222# vs Howards and Joe Santana's 175#. Yesterday, I finished the work, safetied the turnbuckles, and had two friend help. I did some more high speed taxi's and raised the tail, when she promptly lifted off, and I put her back down. I did that on two more runs. It was the middle of the hot afternoon, with wind rustling the tree tops above me. I am at a one way in, opposite way out airstrip. The "A" was purring. (I loved the water spashing on my face from the overflow.) While I was being encouraged to go fly that darn thing, I decided to wait until the cool of a quiet morning, zero wind preferably. It was never my intention to fly her yesterday. I went flying in my Cessna 195 today (newly acquired 2 months and 30 hours ago) and wondered to myself if I am just chicken. Got to shake it off. The Cub I flew back in the Spring was a piece of cake. It's just a plane. Right? (Somebody say "yes".) Any clever advice, snide remarks, (yes, get that nose down), encouragement, etc will be appreciated. Larry Nelson Springfield, MO Beechcraft Bonanza V-35B N2980A Pietenpol Air Camper N444MH 1963 GMC 4106-1618 SV/ Spirit of America ARS WB0JOT ________________________________________________________________________________
Date: Aug 28, 2005
Just a follow up on my landing gear problem. I spent the day at the hangar, removing the wheels and axle. I was shocked to find that my port side bungee had almost completely chaffed thru, not from this incident but from rubbing on a bolt head on the gear leg. For anyone who hasn't checked you bungees in a while, it may be worth unwrapping and checking. I will make a chafe guard out of 2" SCH 40 pvc pipe to cover the bolts. Dick N. ________________________________________________________________________________
Date: Aug 28, 2005
I would say follow your instincts.If the winds are high and you don't feel confortable then do as you said ,wait for a nice calm morning or evening, as long as it's calm.It's one less thing to have to worry about.Test flying your own aircraft is quite a big step even if you are a seasoned pilot on other aircraft. Take your time and enjoy unless of caorse you have to be somewhere in a hurry! > > >N444MH, Howard Henderson's old plane, has it's wing >moved 3" aft of it's plans built location, to >accomodate my 222# vs Howards and Joe Santana's 175#. > >Yesterday, I finished the work, safetied the >turnbuckles, and had two friend help. I did some more >high speed taxi's and raised the tail, when she >promptly lifted off, and I put her back down. > >I did that on two more runs. It was the middle of the >hot afternoon, with wind rustling the tree tops above >me. I am at a one way in, opposite way out airstrip. >The "A" was purring. (I loved the water spashing on my >face from the overflow.) > >While I was being encouraged to go fly that darn >thing, I decided to wait until the cool of a quiet >morning, zero wind preferably. It was never my >intention to fly her yesterday. > >I went flying in my Cessna 195 today (newly acquired 2 >months and 30 hours ago) and wondered to myself if I >am just chicken. Got to shake it off. The Cub I flew >back in the Spring was a piece of cake. > >It's just a plane. Right? (Somebody say "yes".) Any >clever advice, snide remarks, (yes, get that nose >down), encouragement, etc will be appreciated. > >Larry Nelson >Springfield, MO >Beechcraft Bonanza V-35B N2980A >Pietenpol Air Camper N444MH >1963 GMC 4106-1618 >SV/ Spirit of America >ARS WB0JOT > > > >____________________________________________________ > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Fwd: pete
Date: Aug 28, 2005
Hi BARNSTMR,and the list members, A great looking model of the Piet. The aircraft that the builder modeled is Simon McCormack's Piet in Tasmania. For anyone that is interested, there is a neat video of the model in flight and you can also download the plans (using Adobe) for free. There are 2 sections, one is the basic plans and the other is of full size parts etc. A very well built little Piet ! Mark S Japan From: BARNSTMR(at)aol.com Subject: Pietenpol-List: Fwd: FW: pete Heres the address to a neat free-flight Piet model. http://smallflyingarts.com/Current_Content/Spotlight/aircamper.htm ________________________________________________________________________________
Date: Aug 28, 2005
Larry, Making the transition from experimental airplane builder to TEST PILOT puts a little stress on the pucker: a) have someone else who's been an experimental test pilot go thru the plane from front to back looking for things you may have forgotten, b) you go thru the plane one more time and then go flying, c) take his or her (safety chker) car keys with you on the first flight, this will give your safety checker a little incentive to do a good job for you. Good Luck. Gordon Bowen -Homer Alaska Cozy IV N64CY Osprey II N64SY Pietenpol N-1033B " There are no passengers on spaceship Earth, we are all crew", McLuhan ----- Original Message ----- From: "Larry Nelson" <lnelson208(at)yahoo.com> Subject: Re: Pietenpol-List: (Maybe) First Flight? > > > N444MH, Howard Henderson's old plane, has it's wing > moved 3" aft of it's plans built location, to > accomodate my 222# vs Howards and Joe Santana's 175#. > > Yesterday, I finished the work, safetied the > turnbuckles, and had two friend help. I did some more > high speed taxi's and raised the tail, when she > promptly lifted off, and I put her back down. > > I did that on two more runs. It was the middle of the > hot afternoon, with wind rustling the tree tops above > me. I am at a one way in, opposite way out airstrip. > The "A" was purring. (I loved the water spashing on my > face from the overflow.) > > While I was being encouraged to go fly that darn > thing, I decided to wait until the cool of a quiet > morning, zero wind preferably. It was never my > intention to fly her yesterday. > > I went flying in my Cessna 195 today (newly acquired 2 > months and 30 hours ago) and wondered to myself if I > am just chicken. Got to shake it off. The Cub I flew > back in the Spring was a piece of cake. > > It's just a plane. Right? (Somebody say "yes".) Any > clever advice, snide remarks, (yes, get that nose > down), encouragement, etc will be appreciated. > > Larry Nelson > Springfield, MO > Beechcraft Bonanza V-35B N2980A > Pietenpol Air Camper N444MH > 1963 GMC 4106-1618 > SV/ Spirit of America > ARS WB0JOT > > > ____________________________________________________ > > ________________________________________________________________________________
Date: Aug 28, 2005
Gordon, I wish I could claim to be the builder. It flew the day before I loaded it on a trailer and hauled it to MO. I merely moved the wing back. The work I did to accomplish that was redoing the cabane X brace wires, and redoing the lift strut wires and Dremelling some of the metal work to allow the aileron wires clearance at the cowling, since they were at a different location with the wing moved back. I have rebuilt factory aircraft in my younger days, and flew them off the nearest highway to get them to the airport. Once, with a Tripacer that I had installed the tailfeather bellcrank UPSIDEDOWN, creating a desire to go into a steep climb until I fixed that problem. I have climbed into ultralights when someone says, "hey, just go flight it"...then wishing I was on the ground as soon as I flew it "higher than I wanted to fall". Kissing the ground upon my return.....(only to do it again a few weeks later). I just need to go over it, and fly it. --- Gordon Bowen wrote: > > > Larry, > Making the transition from experimental airplane > builder to TEST PILOT puts > a little stress on the pucker: a) have someone else > who's been an > experimental test pilot go thru the plane from front > to back looking for > things you may have forgotten, b) you go thru the > plane one more time and > then go flying, c) take his or her (safety chker) > car keys with you on the > first flight, this will give your safety checker a > little incentive to do a > good job for you. Good Luck. > Gordon Bowen -Homer Alaska > Cozy IV N64CY > Osprey II N64SY > Pietenpol N-1033B > " There are no passengers on spaceship Earth, we are > all crew", McLuhan > > ----- Original Message ----- > From: "Larry Nelson" <lnelson208(at)yahoo.com> > To: > Sent: Saturday, August 27, 2005 4:29 PM > Subject: Re: Pietenpol-List: (Maybe) First Flight? > > > > > > > > > > > N444MH, Howard Henderson's old plane, has it's > wing > > moved 3" aft of it's plans built location, to > > accomodate my 222# vs Howards and Joe Santana's > 175#. > > > > Yesterday, I finished the work, safetied the > > turnbuckles, and had two friend help. I did some > more > > high speed taxi's and raised the tail, when she > > promptly lifted off, and I put her back down. > > > > I did that on two more runs. It was the middle of > the > > hot afternoon, with wind rustling the tree tops > above > > me. I am at a one way in, opposite way out > airstrip. > > The "A" was purring. (I loved the water spashing > on my > > face from the overflow.) > > > > While I was being encouraged to go fly that darn > > thing, I decided to wait until the cool of a quiet > > morning, zero wind preferably. It was never my > > intention to fly her yesterday. > > > > I went flying in my Cessna 195 today (newly > acquired 2 > > months and 30 hours ago) and wondered to myself if > I > > am just chicken. Got to shake it off. The Cub I > flew > > back in the Spring was a piece of cake. > > > > It's just a plane. Right? (Somebody say "yes".) > Any > > clever advice, snide remarks, (yes, get that nose > > down), encouragement, etc will be appreciated. > > > > Larry Nelson > > Springfield, MO > > Beechcraft Bonanza V-35B N2980A > > Pietenpol Air Camper N444MH > > 1963 GMC 4106-1618 > > SV/ Spirit of America > > ARS WB0JOT > > > > > > > > > ____________________________________________________ > page > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > > > > > > > > Larry Nelson Springfield, MO Beechcraft Bonanza V-35B N2980A Pietenpol Air Camper N444MH 1963 GMC 4106-1618 SV/ Spirit of America ARS WB0JOT ________________________________________________________________________________
Date: Aug 28, 2005
Larry, Good luck. See if you can take the car keys of a safety checker anyway. If they're serious about your safe return, you'll get a good second opinion of the plane's safe condition. Test Pilots at Lockheed Skunk Works used to take the car keys of the chief AP mechanic and chief design engineer with them on first flights like the SR-71. Gordon ----- Original Message ----- From: "Larry Nelson" <lnelson208(at)yahoo.com> Subject: Re: Pietenpol-List: (Maybe) First Flight? > > Gordon, I wish I could claim to be the builder. It > flew the day before I loaded it on a trailer and > hauled it to MO. I merely moved the wing back. The > work I did to accomplish that was redoing the cabane X > brace wires, and redoing the lift strut wires and > Dremelling some of the metal work to allow the aileron > wires clearance at the cowling, since they were at a > different location with the wing moved back. I have > rebuilt factory aircraft in my younger days, and flew > them off the nearest highway to get them to the > airport. Once, with a Tripacer that I had installed > the tailfeather bellcrank UPSIDEDOWN, creating a > desire to go into a steep climb until I fixed that > problem. I have climbed into ultralights when someone > says, "hey, just go flight it"...then wishing I was on > the ground as soon as I flew it "higher than I wanted > to fall". Kissing the ground upon my return.....(only > to do it again a few weeks later). > > I just need to go over it, and fly it. > > > --- Gordon Bowen wrote: > > > > > > > Larry, > > Making the transition from experimental airplane > > builder to TEST PILOT puts > > a little stress on the pucker: a) have someone else > > who's been an > > experimental test pilot go thru the plane from front > > to back looking for > > things you may have forgotten, b) you go thru the > > plane one more time and > > then go flying, c) take his or her (safety chker) > > car keys with you on the > > first flight, this will give your safety checker a > > little incentive to do a > > good job for you. Good Luck. > > Gordon Bowen -Homer Alaska > > Cozy IV N64CY > > Osprey II N64SY > > Pietenpol N-1033B > > " There are no passengers on spaceship Earth, we are > > all crew", McLuhan > > > > ----- Original Message ----- > > From: "Larry Nelson" <lnelson208(at)yahoo.com> > > To: > > Sent: Saturday, August 27, 2005 4:29 PM > > Subject: Re: Pietenpol-List: (Maybe) First Flight? > > > > > > > > > > > > > > > > > > N444MH, Howard Henderson's old plane, has it's > > wing > > > moved 3" aft of it's plans built location, to > > > accomodate my 222# vs Howards and Joe Santana's > > 175#. > > > > > > Yesterday, I finished the work, safetied the > > > turnbuckles, and had two friend help. I did some > > more > > > high speed taxi's and raised the tail, when she > > > promptly lifted off, and I put her back down. > > > > > > I did that on two more runs. It was the middle of > > the > > > hot afternoon, with wind rustling the tree tops > > above > > > me. I am at a one way in, opposite way out > > airstrip. > > > The "A" was purring. (I loved the water spashing > > on my > > > face from the overflow.) > > > > > > While I was being encouraged to go fly that darn > > > thing, I decided to wait until the cool of a quiet > > > morning, zero wind preferably. It was never my > > > intention to fly her yesterday. > > > > > > I went flying in my Cessna 195 today (newly > > acquired 2 > > > months and 30 hours ago) and wondered to myself if > > I > > > am just chicken. Got to shake it off. The Cub I > > flew > > > back in the Spring was a piece of cake. > > > > > > It's just a plane. Right? (Somebody say "yes".) > > Any > > > clever advice, snide remarks, (yes, get that nose > > > down), encouragement, etc will be appreciated. > > > > > > Larry Nelson > > > Springfield, MO > > > Beechcraft Bonanza V-35B N2980A > > > Pietenpol Air Camper N444MH > > > 1963 GMC 4106-1618 > > > SV/ Spirit of America > > > ARS WB0JOT > > > > > > > > > > > > > > ____________________________________________________ > > page > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > > Subscriptions page, > > FAQ, > > > > > > > > > > > > > > > > > > > > > > > Larry Nelson > Springfield, MO > Beechcraft Bonanza V-35B N2980A > Pietenpol Air Camper N444MH > 1963 GMC 4106-1618 > SV/ Spirit of America > ARS WB0JOT > > __________________________________________________ > > ________________________________________________________________________________
Date: Aug 29, 2005
Thanks for the heads up, Dick. I'll check mine tonight. I always check the bungees before each flight to ensure that they are still clamped in place and haven't slipped, but I'm not as thorough about checking for chafing. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Subject: Pietenpol-List: fixed landing gear Just a follow up on my landing gear problem. I spent the day at the hangar, removing the wheels and axle. I was shocked to find that my port side bungee had almost completely chaffed thru, not from this incident but from rubbing on a bolt head on the gear leg. For anyone who hasn't checked you bungees in a while, it may be worth unwrapping and checking. I will make a chafe guard out of 2" SCH 40 pvc pipe to cover the bolts. Dick N. ________________________________________________________________________________
Subject: First off-Field
Date: Aug 29, 2005
27, 2005) at 08/29/2005 09:23:58 AM Made my first off-field landing this Saturday evening, due to my own mistake I created a vapor lock between main and header tank. Flew for 25 minutes until my header tank was empty and she went into Glider "mode" Luckily I was at 2000 ft and over lot of flat farm land. Had to land a mile short of the home strip in a freshly harvested corn field, it was rough. But no damage, other than my own pride, sure like that split landing gear with the fat tires ;) I am making some small changes to the fuel lines trying to eliminate of this ever happening again. Hans ________________________________________________________________________________ ETAuAhUAw6q/92Fi5fWGqeZW1qnmp6Kg+rICFQCAS0yXCJ3ZmvEJZR1kStbqnEbkxw==
Date: Aug 29, 2005
Subject: Re: First off-Field
Hans: What caused the vapor lock? I have been thinking about fuel problems lately. My fuel line runs along the outside of the fus. just above the stringer. In 3 point or climb it runs uphill. In level attitude it runs flat horizontally. I'm thinking I need to change it so everything runs down hill from the tank to the gascolator so any air bubbles flow up hill to the tank. Glad to heare your landing went well. Leon S. In kansas corn country, also with split gear and fat tires. ________________________________________________________________________________
Date: Aug 29, 2005
Hans, Congratulations on the successful outcome. When you have time, please tell us what about your current plumbing, how do you think it contributed to the failure, and how do you intend to improve it. Again, only when you have time. Thanks, Jeff > > >Made my first off-field landing this Saturday evening, due to my own >mistake I created a vapor lock between main and header tank. >Flew for 25 minutes until my header tank was empty and she went into Glider >"mode" >Luckily I was at 2000 ft and over lot of flat farm land. >Had to land a mile short of the home strip in a freshly harvested corn >field, it was rough. > >But no damage, other than my own pride, sure like that split landing gear >with the fat tires ;) > >I am making some small changes to the fuel lines trying to eliminate of >this ever happening again. > >Hans > -- Jeffrey H. Boatright, PhD Assistant Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Aug 29, 2005
Also, were you running Avgas or auto gas? My airport is out of avgas, with no prospects to get any for the next several weeks, so I'm about ot bite the bullet and run mogas in my Pietenpol. I know avgas has additives to prevent vapor lock and just wondered if you were running mogas and think that might have contributed to the problem? Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Subject: Re: Pietenpol-List: First off-Field Hans, Congratulations on the successful outcome. When you have time, please tell us what about your current plumbing, how do you think it contributed to the failure, and how do you intend to improve it. Again, only when you have time. Thanks, Jeff ________________________________________________________________________________
Date: Aug 29, 2005
27, 2005) at 08/29/2005 11:43:56 AM Leon, Yes, all fuel lines must run downhill, I ignored that in a 1 inch section (and Murphy's law ruled) My fuel line runs from the left rear end of the center section (rear spar) through a shut off valve to the front left cabane. Where it goes down in to a 2 Gallon Header tank. I tried to keep the fuel line as high up as possible for passenger access this causes a 1 inch curve back up right after the finger strainer and T for the fuel drain valve. This normally ought not be a problem as long as the line is full it will syphon out continuously and there is no heat source to create gas bubbles. But during taxi and run up I left the shut of valve closed, (I did open it before take off as part of my check list). The period during taxi and run up caused air in to enter the Header tank, Header tank has its own vent line. And his vent line gets Ram air during flight and the main tank has a normal vented cap ( no ram air) During flight it thus possible that the air pressure in header tank is higher than in the main tank creating the air blockage or reverse flow. The following I is what I am changing now, The 1 inch curve section is removed by using a short street Tee at the tank. And the line will slope down about an inch (1 : 24 slope) My Air Camper seems to fly a little Tail high so in flight this increases to about 1 : 12 slope, the only time I do not have this slope is during climb out and landing flare, that is why I have a header tank. A check valve will be place in the header tank vent line, air is allowed out but not in. A ram air intake on the main tank to create a slight pressure. And a change in my check list, the main tank shut off valve is to remain open at all times and only to be closed during emergency and maintenance The reason I am certain that this caused the engine shut down is that when I came to standstill after landing, I could hear the fuel run in to the header tank again as there was no more Ram air pressure on the header tank ventline. Although my next flight will be with some nervousness, I do have great confidence in the Pietenpol, It does not have a great glide ratio but with engine out and full stall landing flare you can put it down on postage stamp. Hans ________________________________________________________________________________
Date: Aug 29, 2005
27, 2005) at 08/29/2005 11:53:05 AM Jack, I run autogas in my Corvair engine. At the low altitudes that I intend to fly I do not believe the vapor pressure difference between Avgas and autogas have a effect. A local flies a Beech18 on the field on autogas and he flies a lot higher than I do, it is used sometimes as jump plane climbing to 14000 ft. Also the vapor lock occurred due to my own fault (operator error) and was not created by a heat source. My Gascolator and fuel lines on the firewall are all insulated and sloping down to the carburetor. Hans ________________________________________________________________________________
Date: Aug 29, 2005
In a message dated 8/29/2005 9:57:26 AM Central Standard Time, hans.vander.voort(at)alfalaval.com writes: At the low altitudes that I intend to fly I do not believe the vapor pressure difference between Avgas and autogas have a effect. Autogas, regardless of altitude, is more prone to icing the carb than 100LL. Crop dusters (in the old days) had a difficult time keeping ice out when flying at low altitudes, especially in humid conditions and when flying over irrigated fields. I'd double check your carb heat box and make certain it is working well. ________________________________________________________________________________
Date: Aug 29, 2005
27, 2005) at 08/29/2005 01:01:07 PM Thanks, I agree auto gas could be prone to icing quicker. However, I made a 45 minute flight that morning without any problems (Total flying time is now 5 hours). Did get some trouble with carb heat cable sticking and re-lubricated and checked proper operation before the last flight. None the less everything gets checked after every flight hour, I take the cowling off and check for chaffing, anything coming loose or any cracks developing, or anything else out of the ordinary. Hans Tuu2Tango(at)aol.com Sent by: owner-pietenpol-l To ist-server@matron pietenpol-list(at)matronics.com ics.com cc Subject 08/29/2005 11:27 Re: Pietenpol-List: First off-Field AM Please respond to pietenpol-list@ma tronics.com In a message dated 8/29/2005 9:57:26 AM Central Standard Time, hans.vander.voort(at)alfalaval.com writes: At the low altitudes that I intend to fly I do not believe the vapor pressure difference between Avgas and autogas have a effect. Autogas, regardless of altitude, is more prone to icing the carb than 100LL. Crop dusters (in the old days) had a difficult time keeping ice out when flying at low altitudes, especially in humid conditions and when flying over irrigated fields. I'd double check your carb heat box and make certain it is working well. ________________________________________________________________________________
Date: Aug 29, 2005
SpamAssassin (score=-2.552, required 3, autolearn=not spam, AWL 0.05, BAYES_00 -2.60) Tuu2Tango(at)aol.com wrote: > In a message dated 8/29/2005 9:57:26 AM Central Standard Time, > hans.vander.voort(at)alfalaval.com writes: > > /At the low altitudes that I intend to fly I do not believe the vapor > pressure difference between Avgas and autogas have a effect. > / > > Autogas, regardless of altitude, is more prone to icing the carb than > 100LL. Crop dusters (in the old days) had a difficult time keeping ice > out when flying at low altitudes, especially in humid conditions and > when flying over irrigated fields. > > I'd double check your carb heat box and make certain it is working well. The I think its called the Reid Vapor Pressure isn't going to be the issue, especially if its used in a Piet. Auto gas now often has alchol in it that can degrade fuel lines and seals in some systems. It also isn't the same in different parts of the country. The other thing that is a big watch it is contamination during transport. It's easy to pick up all sorts of nasty things from water to trash that if you don't plan for it can wind up in you tank. ________________________________________________________________________________
Date: Aug 29, 2005
Subject: Re: First off-Field..
I dont think is a vapor lock problem,.. If the header tank is pressurized (ram "L") and the wing tank is normally vented, then the air from the header was pushing back the gasoline up to the wing tank. No gasoline could come down by gravity The header should be free vented and the wing tank with the inverted "L" ram pressure, so the gasoline can be transfered with a little of preassure.. The shut off valve should be open only to transfer from the wing tank to the header, or the gasoline will be overflown through the gas cap of the header. Depending in the capacity of both tanks is the amount of gas tranfer each time. Is more simple to do it than to explain it (at least for me) Hope this helps Saludos Gary Gower. Tuu2Tango(at)aol.com wrote: In a message dated 8/29/2005 9:57:26 AM Central Standard Time, hans.vander.voort(at)alfalaval.com writes: At the low altitudes that I intend to fly I do not believe the vapor pressure difference between Avgas and autogas have a effect. Autogas, regardless of altitude, is more prone to icing the carb than 100LL. Crop dusters (in the old days) had a difficult time keeping ice out when flying at low altitudes, especially in humid conditions and when flying over irrigated fields. I'd double check your carb heat box and make certain it is working well. --------------------------------- ________________________________________________________________________________
Date: Aug 29, 2005
27, 2005) at 08/29/2005 03:19:37 PM Gary, My ram air "L" of the header tank is placed above main tank level. Tubing is run all the way to top of wing this to avoid overflowing of the headertank. I would like to avoid a manual operation of filling the tank. Come to think of it, the vented gas cap (on top of center section) could be in a low pressure area agrivating the problem I believe a check valve in the header vent line and a Ram "L" on the maintank will do the trick. Thanks Hans ________________________________________________________________________________
Date: Aug 29, 2005
Hans, I will tell you what we have done is similar gasoline systems: Here (in Mexico) Landing strips or places to land ad refuel (even with auto gas) are few, dificult to find and problem makers, So we have Big experience in gasoline transfer in our ultralights, when we go for XCountry.... Some have worked, some make great glider practice :-) Remember also we4ed killer bottle preassure system) Gasoline transfer in several events sure is dangerous, because is easy to forget (to open or to close the valve) same final gas shortage results. The best system that worked for us (as automatic system) is to handle both tanks as a unit (gravity and pressure talking) Hope can explain clear: As I read you have a 2 galon header, well you have to make the cap of the header airtight (and wire safety closed). This is why: You will always have the system in tranfer. right? The vent of the header will go to the upper part of the main tank, so gasoline will no be pushed back. The (lower) exit of the main tank will go to the upper part of the header.... There will always be fuel in both tanks and hoses. Venting of both tanks will be though the main gas cap. (safety later let me finish) The filler cap of the main tank will be ram pressured. so this preasure will be in both tanks at the same time, is phisics not me, you will always haved to refill though the main tank and the header will always be full.. Now safety: both thanks need a drain plug for water, both need a shut valve, the main tank one should be open in flight always (we safety the valve open position in flight with a simple girl ponytail ruberband), If you need to close this valve in an emergency just pull the ruber band with the finger and close the valve. This way vibration will not close the valve and in an emergency the main suply can be closed. The other safety will be the main shut off valve in the lower header and the gascolator in the lower part of the system. Hope is clear enough... There is another (automatic) fool proof system when a single wing tank is used as reserve... Higher than the main tank. Could explain later, if needed. Hope this helps, 15 years experience with ultralights, 4 hrs plus legs. in XCountry, Several weekends a year with no gas shortage... Lots of fun with less of worry. Saludos Gary Gower. hans.vander.voort(at)alfalaval.com wrote: Gary, My ram air "L" of the header tank is placed above main tank level. Tubing is run all the way to top of wing this to avoid overflowing of the headertank. I would like to avoid a manual operation of filling the tank. Come to think of it, the vented gas cap (on top of center section) could be in a low pressure area agrivating the problem I believe a check valve in the header vent line and a Ram "L" on the maintank will do the trick. Thanks Hans --------------------------------- ________________________________________________________________________________
Date: Aug 29, 2005
Subject: Anyone Know The Story Behind This Crash?
Hi Listers, Does anyone know the story behind this aircraft and the crash? Almost looks like an RC model especially given the cameraman's rather unemotional comment following the crash. Kind of looks like the elevator may have been hooked up backwards following a rebuild. http://media4.big-boys.com/content/oldplanecrash.wmv Any information on this video would be intersting. Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re: Anyone Know The Story Behind This Crash?
Date: Aug 30, 2005
Matt, Quit the footage. Looks like a turbine conversion to a Caribou that took off with the gust lock engaged. Chris Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Subject: Pietenpol-List: Anyone Know The Story Behind This Crash? > > > Hi Listers, > > Does anyone know the story behind this aircraft and the crash? Almost > looks like an RC model especially given the cameraman's rather > unemotional comment following the crash. Kind of looks like the > elevator may have been hooked up backwards following a rebuild. > > http://media4.big-boys.com/content/oldplanecrash.wmv > > Any information on this video would be intersting. > > Matt > > > -- > > > Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 > 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email > http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft > > ________________________________________________________________________________
Date: Aug 30, 2005
I think this is the crash that occured at Gimli Industrial Airpark in Manitoba, Canada. The aircraft is a highly modified Caribou, converted to turbine power and operated under the Experimental catagory of CAR 4b. It had flown the year prior to the crash. . The complete report can be found starting on page 6 of a PDF file at this website... _http://www.asasi.org/papers/2001/Four%20Unrelated%20Accidents.pdf_ (http://www.asasi.org/papers/2001/Four%20Unrelated%20Accidents.pdf) ________________________________________________________________________________
Date: Aug 30, 2005
>You have to try landing in corn when it's not harvested.You talk about gettin beaten up.This was done with an ultralight not enclosed. > From: hans.vander.voort(at)alfalaval.com > Date: 2005/08/29 Mon AM 09:23:56 EST > To: > Subject: Pietenpol-List: First off-Field > > > > Made my first off-field landing this Saturday evening, due to my own > mistake I created a vapor lock between main and header tank. > Flew for 25 minutes until my header tank was empty and she went into Glider > "mode" > Luckily I was at 2000 ft and over lot of flat farm land. > Had to land a mile short of the home strip in a freshly harvested corn > field, it was rough. > > But no damage, other than my own pride, sure like that split landing gear > with the fat tires ;) > > I am making some small changes to the fuel lines trying to eliminate of > this ever happening again. > > Hans > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 30, 2005
From: Michael D Cuy <Michael.D.Cuy(at)grc.nasa.gov>
Subject: light, simple, mindless fuel tank installations
laval.com> Hans-- I'm glad you landed safely and have determined the cause of your fuel starvation problem. Excuse my continual endorsement of the four-book series written by Tony Bingelis, but he shows all types of fuel flow installations and knows the do's and don't that are easily done without doing some valuable reading first. I can't help but recommend a nose-tank only for any kind of Pietenpol with any kind of powerplant. You have the most simple of designs with very short tubing/flexible tubing runs, a single shutoff valve, a gascolator, and vented cap. You can fit 17 gallons there too if you design it to fit the curved upper portion, just under your aluminum cockpit cowling area. With the nose tank you free up the entire center section for camping or any other kind of gear. In my center section I can fit my tent, sleeping air pad, cloth folding chair, tie downs, spare oil, Marvel oil, and rags. It also makes for an excellent way to easily inspect your aileron balance cable, turnbuckle, and two aileron pullies. With most Piets having tail-heavy syndrome, if you put your fuel just behind the firewall instead of the cc, you help yoursefl in the CG department. The nose tank is easier to fill too....and if you spill some it doesn't run down and drip on the pilot seat like a cc tank fill job can do. Just some thoughts ! Simpler= lighter. Lighter= better performance and the ability to fly passengers without a pucker factor in the high 9's. Mike C. ________________________________________________________________________________
Date: Aug 30, 2005
From: "Textor, Jack" <jtextor(at)thepalmergroup.com>
Good thoughts Mike. How did you baffle your tank? If I recall, it was welded aluminum.....? Jack Textor Des Moines -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael D Cuy Subject: Pietenpol-List: light, simple, mindless fuel tank installations Hans-- I'm glad you landed safely and have determined the cause of your fuel starvation problem. Excuse my continual endorsement of the four-book series written by Tony Bingelis, but he shows all types of fuel flow installations and knows the do's and don't that are easily done without doing some valuable reading first. I can't help but recommend a nose-tank only for any kind of Pietenpol with any kind of powerplant. You have the most simple of designs with very short tubing/flexible tubing runs, a single shutoff valve, a gascolator, and vented cap. You can fit 17 gallons there too if you design it to fit the curved upper portion, just under your aluminum cockpit cowling area. With the nose tank you free up the entire center section for camping or any other kind of gear. In my center section I can fit my tent, sleeping air pad, cloth folding chair, tie downs, spare oil, Marvel oil, and rags. It also makes for an excellent way to easily inspect your aileron balance cable, turnbuckle, and two aileron pullies. With most Piets having tail-heavy syndrome, if you put your fuel just behind the firewall instead of the cc, you help yoursefl in the CG department. The nose tank is easier to fill too....and if you spill some it doesn't run down and drip on the pilot seat like a cc tank fill job can do. Just some thoughts ! Simpler= lighter. Lighter= better performance and the ability to fly passengers without a pucker factor in the high 9's. Mike C. ________________________________________________________________________________
Date: Aug 30, 2005
That's a real video of the crash of the first prototype Turbo Caribou. I think it was Winnipeg, but I don't remember anymore. The control locks were never removed before take-off. I didn't know them personally but they were friends-of friends that died in that crash. the project was picked up later and I was privileged to work on it. The STC to convert the Caribou to turbines is now held by Pen Turbo in the States. DECA Aviation in Toronto with some minor assistance form our company (Avionics Design Services) finished off the program. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Matt Dralle Subject: Pietenpol-List: Anyone Know The Story Behind This Crash? Hi Listers, Does anyone know the story behind this aircraft and the crash? Almost looks like an RC model especially given the cameraman's rather unemotional comment following the crash. Kind of looks like the elevator may have been hooked up backwards following a rebuild. http://media4.big-boys.com/content/oldplanecrash.wmv Any information on this video would be intersting. Matt -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re: light, simple, mindless fuel tank installations
Date: Aug 30, 2005
27, 2005) at 08/30/2005 09:30:34 AM Thanks Mike, I came so close to doing exactly that during building but decided to stay with the BHP design. Now after this and a few times having to fill to CC tank I am considering it again. It still can easily be done although it would be more work as CG will change forward. Filling the CC tank is real pain and spillage risk is high, did not happen to me yet but I am sure Murphy's law will rule on this to. Plus that Tank sitting above you during a more damaging emergency landing is potential for being soaked in gas Hans ________________________________________________________________________________ ETAtAhQFEmWpUe9psACImwhWG9x/d4lwawIVAK/5V4nao7KD/vQvGG9vBd3S4QvK
Date: Aug 30, 2005
Subject: Fus. fuel tank.
Good thoughts Mike. Unfortunately Model A builders like me are stuck with the wing tank because of the high location of the Model A"s carb. My carb. sets at the same height as the top of the fus. cowl. eliminating gravity flow. Leon S. In hurricane free Kansas. ________________________________________________________________________________
Date: Aug 30, 2005
The Travel Air uses 30x5 wheels. The shock cord attaches to the axle and center vee, unlike a Cub where the shock cord is entirely on the axle "spreader bar." I could come up with measurements for the Travel Air if anyone thought it would be useful, but I doubt it. Gene ----- Original Message ----- From: Michael Conkling<mailto:hpvs(at)southwind.net> To: pietenpol-list(at)matronics.com Sent: Saturday, August 27, 2005 6:40 PM Subject: Re: Pietenpol-List: Rims and Tires Phil, Look up the 1929-30 Travelair 2000 landing gear for how it could be done -- the Travelair used 28 x 4 wheels with the shock cords attached to the center "vee" (like a J-3 Cub). It will take some drafting time to figure axle placement and landing gear angles for the right deck angle. Concerning the straight axle Piets -- if I remember correctly, aren't Part 23 landing gear (only) stressed for about 3g's ?? Mike C. Pretty Prairie, KS ----- Original Message ----- From: Philip Miller<mailto:philip_miller_3(at)earthlink.net> To: pietenpol-list(at)matronics.com Sent: Saturday, August 27, 2005 4:43 PM Subject: Fw: Pietenpol-List: Rims and Tires Is it possible to use split landing gear with spoked wheels? If so, are there any special considerations about that (wheel dimensions limits, side loads, etc.) I like the look of the spoked wheels, but the impact absorbtion, strength and utility of the split axle sure looks more attractive. I'd miss those beautiful ash struts though. Phil Miller PietenVair Altadena,CA ________________________________________________________________________________
Date: Aug 30, 2005
laval.com> Jack-- I have no baffles in my tank. There are enough bends in that back piece that it doesn't oil can and the bottom is supported by two pieces of spruce running side to side with s/s fuel tank straps w/ felt glued to them cradling in the whole thing. Good thoughts on the fuel above you during an accident, Hans. William Wynne had a really neat idea of making his cc out of fiberglass and using it as a structural member if I'm not mistaken....but that was also the cause of his burns after he had some carb ice and a forced landing. A really great guy---hated to see that happen. Lesson learned from all of these stories. Some have asked if I get enough head pressure with my tank being all in the nose and I performed flow testing ala the Bingelis HP/min-flow-in-a-climb angle at the carb and I had the required flow all the way down to just under 2 gallons. So to fly safely full power in a climb, I need at least two gallons of fuel in the tank or more. Not bad to have a useful load of 15 gallons on board in a Piet. Mike C. ________________________________________________________________________________
Subject: Re: Fus. fuel tank.
Date: Aug 30, 2005
Yeah, I know JUST what you mean, same here, I can relate, that's been my experience..... Ok, I'll admit it, I don't actually know what the heck we're talking about here....but since I'm picking up MY (ready to "bolt on and fly") Model A this weekend, I'm just kinda excited about being able to include myself in the "Model A builders like me" group, along with Leon, Larry, Ken, Jeff, Kip, Douwe, et al..... Jim in Plano.....making PockaTa PockaTa sounds....all the time now..... ----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> Subject: Pietenpol-List: Fus. fuel tank. > > Good thoughts Mike. Unfortunately Model A builders like me are stuck > with the wing tank because of the high location of the Model A"s carb. > My carb. sets at the same height as the top of the fus. cowl. > eliminating gravity flow. Leon S. In hurricane free Kansas. > > > ________________________________________________________________________________
Date: Aug 30, 2005
Subject: nose tank sketch-installation: the correct attachment
! Guys--here is what my setup looks like. Mike C. ________________________________________________________________________________ attachment !
attachment !
Date: Aug 30, 2005
attachment !
You see that flex tube and connection at the bottom of your tank,well turn it around so it goes directly out to the fire wall instead of having that loop in it. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael D Cuy Subject: Pietenpol-List: nose tank sketch-installation: the correct attachment ! Guys--here is what my setup looks like. Mike C. ________________________________________________________________________________
Date: Aug 30, 2005
Subject: flex hose under tank
ce.ca> Harvey-- if I turned that fitting around I'd not have had room for my shutoff valve and a flex hose works to dampen vibration if in a loop or semi-loop as I have it installed. Has worked perfectly as drawn for 7 years and close to 400 hours of flying time. Mike C. ________________________________________________________________________________
Date: Aug 30, 2005
Ok ,I stand corrected.In my situation I have the shut of valve directly below the tank with the connection going out to the gascolator with no flex tube in it as per an AME and I have yet to test mine.I am also having more of a problem trying to connect up the shut off cable because the valve is facing 90 degrees from where yours is and I have to find somewhere on the side to mount that cable and high enough so it can still shut off the valve. It does give me an idea though,I can still turn my valve around 90 degrees and still have the lower connection connected up the same.Thanks for the picture.I may still land up putting the flex tube it yet.I have a short piece going from the gascolator to the carb as it stands right now. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael D Cuy Subject: Pietenpol-List: flex hose under tank Harvey-- if I turned that fitting around I'd not have had room for my shutoff valve and a flex hose works to dampen vibration if in a loop or semi-loop as I have it installed. Has worked perfectly as drawn for 7 years and close to 400 hours of flying time. Mike C. ________________________________________________________________________________
Date: Aug 30, 2005
ce.ca> Harvey-- you know I had the exact same setup as you describe on your tank and the reason I switched to the flex line is that I could not for the life of me make up that little line of alum. tubing with flares to match both my fuel valve and my firewall fitting !!! It was such a short run that I couldn't get it right-- could not get the tube in the flaring tool after I did one end. I hear you on the actuator problem too on your valve orientation. You can do it though ! ;You know my IA was watching me toil with that short tubing connection and HE was the one who suggested I turn that blasted fitting around and run/purchase a s/s braided flex hose to complete the run--and boy am I glad I did. I can't take credit for that installation idea, but it has worked like a charm. Don't forget to use fuel lube on all your threads/connections. It feels like thick bees wax....and if I'm not mistaken it just might be. I have some if you need it and can ship it to you via mail. You won't need more than a shot glass full for three airplanes worth. Mike C. ________________________________________________________________________________
Date: Aug 30, 2005
I can't take credit for that flared alluminum pipe either because it was already done when I got the plane.Yes sir I used fuel lube on all my connections even the ones at the flex hose and the AME said I didn't need to. He informed me on how sticky it is because he supplied me with some and your right it doesn't take much.He was very enfatic on the point of not getting it in the line too.If I can get that whole connection to move 90 degrees then I will fix my problem tonight after work.I figure I'll have to disconnect that alluminum tube first though.Oh boy another trip upside down and backwards while hanging on with my knees and one hand.I have bruises all up and down my one side from doing this acrobatic feat and I'm not amused.The guys at the field keep telling me I'm having fun!This plane building is interesting especially when most of its been done already and I have to go in and fix it or modify it after the fact.I have had to cut holes in the side of the aircraft just to install seat belts because they were not put in.Interesting way to build.I see now why the guy at the government office (when I went to apply for my registration) told me that I would have to dismantle the plane and start over again;maybe he had something there.I thought he was nuts at the time but I'm beginning to think maybe he was right.Having fun here in cold Canada;I use that term loosely! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael D Cuy Subject: RE: Pietenpol-List: flex hose under tank Harvey-- you know I had the exact same setup as you describe on your tank and the reason I switched to the flex line is that I could not for the life of me make up that little line of alum. tubing with flares to match both my fuel valve and my firewall fitting !!! It was such a short run that I couldn't get it right-- could not get the tube in the flaring tool after I did one end. I hear you on the actuator problem too on your valve orientation. You can do it though ! ;You know my IA was watching me toil with that short tubing connection and HE was the one who suggested I turn that blasted fitting around and run/purchase a s/s braided flex hose to complete the run--and boy am I glad I did. I can't take credit for that installation idea, but it has worked like a charm. Don't forget to use fuel lube on all your threads/connections. It feels like thick bees wax....and if I'm not mistaken it just might be. I have some if you need it and can ship it to you via mail. You won't need more than a shot glass full for three airplanes worth. Mike C. ________________________________________________________________________________
Subject: fuel prices and gas tanks
Date: Aug 30, 2005
27, 2005) at 08/30/2005 02:16:48 PM Some inside info: Gasoline wholesale price (automobil) just hit 2.40 , forty cents up from yesterday! Fill up your gas tanks, retail price will be 3 + by the end of the week Hans ________________________________________________________________________________
Date: Aug 30, 2005
Up here we are paying 1.03$ per litre which translates to 4X's that much for a gallon.So we pay 4.12/gallon but then again our gallon is slightly bigger than yours and our dollar is lower as well.Sooooo I think we are about on par with you.But because our dollar is lower it seems like we are paying twice as much.I am looking forward to the day when we can stick it to them and fly on water for fuel! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of hans.vander.voort(at)alfalaval.com Subject: Pietenpol-List: fuel prices and gas tanks Some inside info: Gasoline wholesale price (automobil) just hit 2.40 , forty cents up from yesterday! Fill up your gas tanks, retail price will be 3 + by the end of the week Hans ________________________________________________________________________________ ETAtAhUAghB5HmEawieVTA59fIlm5UGzn+ICFC2plCl21uvX99rnCm/duzYFkCVU
Date: Aug 30, 2005
Subject: Fus. Fuel tank idea
The man who had the Corvair project fuselage at Brodhead had a great idea for his nose tank. It was a 12 gal. race car fuel cell from Jeggs. They even have the foam inside. He said W. Wynn gave him the suggestion. Leon S. ________________________________________________________________________________
Date: Aug 30, 2005
Hi Matt, I asked on one of the flight sim boards I frequent. Appears to be a full size De Havilland DHC-4T Caribou: Some people linked to this document (page 7 - page 6 in PDF), starting fourth paragraph) http://www.asasi.org/papers/2001/Four%20Unrelated%20Accidents.pdf The final example I?d like to bring before you today also deals with a modified aircraft. Like the first event I described, it?s unusual because virtually the entire accident sequence is captured on videotape. The accident occurred in August 1992 at the Gimli Industrial Park in Manitoba?a famous site in Canadian aviation history, where an Air Canada Boeing 767 known as the Gimli Glider was dead-sticked onto a drag racing strip, following fuel exhaustion. The accident aircraft is a highly modified de Havilland aircraft. In this case a Caribou had been converted to turbine power and was operated under the EXPERIMENTAL category of CAR 4b. The conversion was accomplished at Gimli, and the aircraft first flew in mid-November 1991, before accumulating about 23 hours on 12 flights by month end. These preliminary tests revealed the need for the replacement of the aircraft?s mechanical vacuum pumps with a Bendix suction system, the addition of in-line fuel boost pumps and the installation of a newly designed hydraulic pump. The accident occurred on August 27, 1992 on the first of several planned trips to flightcheck the fuel and hydraulic systems. The aircraft had been hangared in a partially disassembled state over the winter, and had only recently been re-assembled, including the re-installation of the complete tail section. I?ll let the video show you what happened?and I will caution you right now that this footage is extremely graphic? [Video?] The accident investigation used this videotape and some 35mm photographs as a key resource in determining what went wrong at Gimli. With the exception of a slightly higher-than-normal nose attitude at lift-off, the aircraft?s initial climb appeared normal. At about 35 feet AGL, the aircraft made a noticeable pitchup movement. When I tell you that the photography revealed that the elevator control surfaces were observed to pitch trailing-edge-up for rotation, neutralize and then remain in the neutral position through the balance of that short flight, I expect most of you will come to the same conclusion as the Transportation Safety Board of Canada. The aircraft?s control gust locks were at least partly engaged. A very close examination of the video does indicate rudder movement and minimal elevator movement, during the start of the takeoff roll. On the standard Caribou, the gust lock control handle is located forward of the power quadrant, and it has two positions?forward for Unlocked, and aft for Locked. If the control surfaces are not in the neutral position when the lock is engaged, any movement of the surfaces through the neutral position will cause the lock to engage. In addition, on the factory-standard Caribou, the control handle is designed so that when it is in the aft-Locked position, the power levers cannot be fully advanced. This is intended to prevent power application and takeoff when the gust lock system is engaged. The accident investigation further revealed that the aircraft?s takeoff distance was approximately 20 per cent longer than anticipated for the conditions. This may provide further evidence that the gust locks played a part in this event. Analysis of the recovered debris indicated that, although the aileron and elevator locking mechanisms were in their respective Disengaged positions, the rudder locking mechanism was found to have been in the fully engaged position at impact. Further investigation revealed that in fact, it had been jammed there by the forces of the impact. In addition, the analysis determined from the damage evidence that the aileron control lock had been dis-engaged at the time of impact. In its synopsis of the accident, the Transportation Safety Board concluded that the control gust lock system had not been fully disengaged prior to flight and that one or more of the locking pins had become re-engaged after lift-off. See also: http://aviation-safety.net/database/record.php?id=19920827-1 Narrative: The aircraft took off for a test flight for a turbine-engine conversion programme. It climbed steeply, rolled to the right and crashed in a nose-down, rightwing-low attitude. 3 fatalities Tuesday, August 30, 2005, 12:44:20 AM, dralle(at)matronics.com wrote: MD> Hi Listers, MD> Does anyone know the story behind this aircraft and the crash? Almost MD> looks like an RC model especially given the cameraman's rather MD> unemotional comment following the crash. Kind of looks like the MD> elevator may have been hooked up backwards following a rebuild. MD> http://media4.big-boys.com/content/oldplanecrash.wmv MD> Any information on this video would be intersting. MD> Matt ________________________________________________________________________________
Date: Aug 30, 2005
Subject: Re: Fus. Fuel tank idea
I have always wondered why more homebuilders don't use these kind of fuel tanks. As some people on the newsgroup have mentioned before, if a NASCAR offical inspected the typical homebuild fuel system for safety he would laugh his butt off. WW is very sensitive to the issue of crash-worthy fuel systems after his burn injuries after a Piet crash. I know that few if any prebuilt tanks would fit in the center section but fitting one behind the firewall shouldn't be a problem. On 8/30/05, Leon Stefan wrote: > > > The man who had the Corvair project fuselage at Brodhead had a great > idea for his nose tank. It was a 12 gal. race car fuel cell from Jeggs. > They even have the foam inside. He said W. Wynn gave him the suggestion. > Leon S. > > > > -- Rick Holland ________________________________________________________________________________
Date: Aug 30, 2005
Subject: Re: fuel prices and gas tanks
$2.40? Ha! Thats peanuts, I am in San Diego on a business trip and regular is already $2.99 before any increase. By the way had the afternoon off and visited the San Diego Aerospace Museam, it is excellent. They have the original wing rib jig used to make the Spirt of St. Louis wing down the road at Lindberg field and it used 1/2" x 1/4" cap strips just like the Piet except they are rotated 90 degrees so the entire rib is 1/4" thick. On 8/30/05, hans.vander.voort(at)alfalaval.com wrote: > > > Some inside info: Gasoline wholesale price (automobil) just hit 2.40 , > forty cents up from yesterday! > Fill up your gas tanks, retail price will be 3 + by the end of the week > > > Hans > > > > -- Rick Holland ________________________________________________________________________________ <984E798CE7C4D4419A6D99DF385597A896154C(at)toroondc511.bell.corp.bc e.ca>
Date: Aug 31, 2005
That's $2.40 WHOLESALE. I missed it, too, the first time I read it. -- In other news, the city of New Orleans disappeared today. My personal favorite for help in natural disasters is the Mennonite Disaster Service. They come early, stay late; way, way after the TV cameras leave: http://www.mds.mennonite.net/ >$2.40? Ha! Thats peanuts, I am in San Diego on a business trip and >regular is already $2.99 before any increase. > >... >-- >Rick Holland ________________________________________________________________________________
Date: Aug 31, 2005
Gas prices this morning in Ottawa Canada jumped to 120.09 which translates to 4.90/gal. I may not be able to afford to fly when I get the Piet finished! New Orleans is under 6 meters of water which translates to 18 feet of wet.Ya I'd say it disappeared. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Subject: Re: Pietenpol-List: fuel prices and gas tanks That's $2.40 WHOLESALE. I missed it, too, the first time I read it. -- In other news, the city of New Orleans disappeared today. My personal favorite for help in natural disasters is the Mennonite Disaster Service. They come early, stay late; way, way after the TV cameras leave: http://www.mds.mennonite.net/ >$2.40? Ha! Thats peanuts, I am in San Diego on a business trip and >regular is already $2.99 before any increase. > >... >-- >Rick Holland ________________________________________________________________________________
Date: Aug 31, 2005
Subject: HAPI powered Pietenpol for sale on Barnstormers.com
9-4967@storefull-3317.bay.webtv.net> Guys-- this is wild. PIETENPOL =95 $9,500 =95 FOR SALE =95 Piet. aircamper, 29tt, o time Hapi v/w conversion elect. start, dual controls. Call 618-565-2053 =95 Contact Gordon W. Glodo - located Grand Tower, IL USA =95 Telephone: 618-565-2053 =95 Posted July 13, 2005 =95 Show all Ads posted by this Advertiser =95 Recommend This Ad to a Friend =95 Send a Message ________________________________________________________________________________
Date: Aug 31, 2005
Here in Jackson ms yesterday some clown were selling 5 gal jugs for $100.Damn bastards!! :(It's pretty bad here at the moment.No gas,no drinking water...We got power but my internet still dont work...SUX --- Rick Holland wrote: > $2.40? Ha! Thats peanuts, I am in San Diego on a > business trip and regular > is already $2.99 before any increase. By the way had > the afternoon off and > visited the San Diego Aerospace Museam, it is > excellent. They have the > original wing rib jig used to make the Spirt of St. > Louis wing down the road > at Lindberg field and it used 1/2" x 1/4" cap strips > just like the Piet > except they are rotated 90 degrees so the entire rib > is 1/4" thick. > > > On 8/30/05, hans.vander.voort(at)alfalaval.com > > wrote: > > > hans.vander.voort(at)alfalaval.com > > > > > > Some inside info: Gasoline wholesale price > (automobil) just hit 2.40 , > > forty cents up from yesterday! > > Fill up your gas tanks, retail price will be 3 + > by the end of the week > > > > > > Hans > > > > > > > > > ===================================== > ===================================== > > > > > > > > > > > > > > > > > > > > > -- > Rick Holland > ________________________________________________________________________________
Date: Aug 31, 2005
We have been watching you hard luck on the news.Many people never made it through the storm. Our heart goes out to you and yours at this time.It appears as though there may not be a solution soon to everyone's problems.We heard another Levey broke and that's not good,not good at all. > >Here in Jackson ms yesterday some clown were selling 5 >gal jugs for $100.Damn bastards!! :(It's pretty bad >here at the moment.No gas,no drinking water...We got >power but my internet still dont work...SUX > >--- Rick Holland wrote: > > > >>$2.40? Ha! Thats peanuts, I am in San Diego on a >>business trip and regular >>is already $2.99 before any increase. By the way had >>the afternoon off and >>visited the San Diego Aerospace Museam, it is >>excellent. They have the >>original wing rib jig used to make the Spirt of St. >>Louis wing down the road >>at Lindberg field and it used 1/2" x 1/4" cap strips >>just like the Piet >>except they are rotated 90 degrees so the entire rib >>is 1/4" thick. >> >> >>On 8/30/05, hans.vander.voort(at)alfalaval.com >> >>wrote: >> >> >>> >>> >>hans.vander.voort(at)alfalaval.com >> >> >>>Some inside info: Gasoline wholesale price >>> >>> >>(automobil) just hit 2.40 , >> >> >>>forty cents up from yesterday! >>>Fill up your gas tanks, retail price will be 3 + >>> >>> >>by the end of the week >> >> >>>Hans >>> >>> >>> >>> >>> >>> >>===================================== >>===================================== >> >> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>-- >>Rick Holland >> >> >> > > >__________________________________________________ > > > > > > > > > ________________________________________________________________________________
Date: Aug 31, 2005
SpamAssassin (score=-2.256, required 3, AWL -0.26, BAYES_00 -2.60, J_CHICKENPOX_32 0.60) I got my commercial CFI and CFII at Jackson. Times like this bring out the best in people and the worst in people. I hope you told the guy what he could do with the hundred that someone would eventually pay even if you didn't. Yet with the jerks you don't hear about the good stories. My dad after Camile picked up a camp stove for my aunt in Gulfport at the time. He took it to the counter to check out. The owner looked at him and asked, "Is this going to someone on the Gulf Coast?" He told him it was for his sister in the Gulfport area. He just said, "No charge, and wish her my best." I was on the coast about 2 weeks after Camile. This has many simularities. Its almost like you combine the flooding of Virginia, but put it in worst terrain (New Orleans) and the other destruction and you have damage that will last for decades. The last time I was there only a few years ago you could still see some signs of Camile and that was decades later. This one will be no different and likely worse in some ways. Hopefully those that had airplanes in the area got them out and can go fly them occasionally to get away from the rest of the mess. Mitty wrote: > >Here in Jackson ms yesterday some clown were selling 5 >gal jugs for $100.Damn bastards!! :(It's pretty bad >here at the moment.No gas,no drinking water...We got >power but my internet still dont work...SUX > >--- Rick Holland wrote: > > > >>$2.40? Ha! Thats peanuts, I am in San Diego on a >>business trip and regular >>is already $2.99 before any increase. By the way had >>the afternoon off and >>visited the San Diego Aerospace Museam, it is >>excellent. They have the >>original wing rib jig used to make the Spirt of St. >>Louis wing down the road >>at Lindberg field and it used 1/2" x 1/4" cap strips >>just like the Piet >>except they are rotated 90 degrees so the entire rib >>is 1/4" thick. >> >> >>On 8/30/05, hans.vander.voort(at)alfalaval.com >> >>wrote: >> >> >>> >>> >>hans.vander.voort(at)alfalaval.com >> >> >>>Some inside info: Gasoline wholesale price >>> >>> >>(automobil) just hit 2.40 , >> >> >>>forty cents up from yesterday! >>>Fill up your gas tanks, retail price will be 3 + >>> >>> >>by the end of the week >> >> >>>Hans >>> >>> >>> >>> >>> >>> >>===================================== >>===================================== >> >> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>-- >>Rick Holland >> >> >> > > >__________________________________________________ > > > > > > > > > ________________________________________________________________________________
Date: Sep 01, 2005
I went to the New Orleans web page yesterday and they have bigger problems than anyone could imagine.There are now sharks and alligators wondering around in those waters.Boy ,that's scary! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Subject: Re: Pietenpol-List: fuel prices and gas tanks I got my commercial CFI and CFII at Jackson. Times like this bring out the best in people and the worst in people. I hope you told the guy what he could do with the hundred that someone would eventually pay even if you didn't. Yet with the jerks you don't hear about the good stories. My dad after Camile picked up a camp stove for my aunt in Gulfport at the time. He took it to the counter to check out. The owner looked at him and asked, "Is this going to someone on the Gulf Coast?" He told him it was for his sister in the Gulfport area. He just said, "No charge, and wish her my best." I was on the coast about 2 weeks after Camile. This has many simularities. Its almost like you combine the flooding of Virginia, but put it in worst terrain (New Orleans) and the other destruction and you have damage that will last for decades. The last time I was there only a few years ago you could still see some signs of Camile and that was decades later. This one will be no different and likely worse in some ways. Hopefully those that had airplanes in the area got them out and can go fly them occasionally to get away from the rest of the mess. Mitty wrote: > >Here in Jackson ms yesterday some clown were selling 5 >gal jugs for $100.Damn bastards!! :(It's pretty bad >here at the moment.No gas,no drinking water...We got >power but my internet still dont work...SUX > >--- Rick Holland wrote: > > > >>$2.40? Ha! Thats peanuts, I am in San Diego on a >>business trip and regular >>is already $2.99 before any increase. By the way had >>the afternoon off and >>visited the San Diego Aerospace Museam, it is >>excellent. They have the >>original wing rib jig used to make the Spirt of St. >>Louis wing down the road >>at Lindberg field and it used 1/2" x 1/4" cap strips >>just like the Piet >>except they are rotated 90 degrees so the entire rib >>is 1/4" thick. >> >> >>On 8/30/05, hans.vander.voort(at)alfalaval.com >> >>wrote: >> >> >>> >>> >>hans.vander.voort(at)alfalaval.com >> >> >>>Some inside info: Gasoline wholesale price >>> >>> >>(automobil) just hit 2.40 , >> >> >>>forty cents up from yesterday! >>>Fill up your gas tanks, retail price will be 3 + >>> >>> >>by the end of the week >> >> >>>Hans >>> >>> >>> >>> >>> >>> >>===================================== >>===================================== >> >> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>-- >>Rick Holland >> >> >> > > >__________________________________________________ > > > > > > > > > ________________________________________________________________________________ <984E798CE7C4D4419A6D99DF385597A8961557(at)toroondc511.bell.corp.bce.ca> <984E798CE7C4D4419A6D99DF385597A8961557(at)toroondc511.bell.corp.bce.ca>
Date: Sep 01, 2005
http://www.mds.mennonite.net/ http://www.redcross.org/ http://www.aspca.org/ > >I went to the New Orleans web page yesterday and they have bigger >problems than anyone could imagine.There are now sharks and alligators >wondering around in those waters.Boy ,that's scary! -- Jeffrey H. Boatright, PhD Assistant Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Sep 01, 2005
Subject: Try to wipe that smile off my face!
Howard Hendersons Pietenpol, N444MH (for MacLaren / Henderson I guess) flew this morning. I made three flights and everything went GREAT. She is a bit "right wing low" hand off, BUT she does has a broken left wing tip rib, that might be the cause of that, although it is hardly noticable. My little strip is just east of metro Springfield, MIssouri, the Flying Bar H. She is banana shaped in plan view and I didn't realize that till this morning when I looked DOWN on it. She is "take off to the SW and land to the NE" kind of strip, due to obstructions. Immediately upon departure you fly over a deep railroad "trench" with trees on both sides. Not a good place to have to put her back down, and on my mind, you can be sure. I just LOVE flying this plane. My first landing was the best. My last as just sort of flaring too high and she just settled in without complaint. Anyway, since Chuck wouldn't let me ride in HIS plane at Brodhead '04 (said I was way too fat, but he did take my friend Wes up).....I thought I need to join the fun. Try to wipe my smile off....I dare ya. Larry Nelson Springfield, MO Beechcraft Bonanza V-35B N2980A Pietenpol Air Camper N444MH 1963 GMC 4106-1618 SV/ Spirit of America ARS WB0JOT __________________________________ Stay connected, organized, and protected. Take the tour: http://tour.mail.yahoo.com/mailtour.html ________________________________________________________________________________
Subject: Seat Belts
Date: Sep 01, 2005
What is the best practice for seat and shoulder belts for a new Piet and does anybody have any purchase sourcing suggestions? Thanks all. This e-mail is intended for the use of the addressee(s) only and may contain privileged, confidential, or proprietary information that is exempt from disclosure under law. If you have received this message in error, please inform us promptly by reply e-mail, then delete the e-mail and destroy any printed copy. Thank you. ============================================================================== ________________________________________________________________________________
Date: Sep 01, 2005
Larry-- way to go. Congratulations on logging your 1st few flights in a Pietenpol !!! On the broken wingtip bow....is that the bow that is broken ? If so--that is a compression member and I'd not fly it like that. If it is a rib--less worry. Mike C. ________________________________________________________________________________
Date: Sep 01, 2005
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
Way to go, Larry! Great feeling, isn't it? Depending on how the rib is broken, you might be able to repair it without having to do much fabric work. I had to repair one broken rib after my forced landing last fall and was able to do the repair in place by working through one inspection hole and a 6" slit in the fabric which was easily patched with tape. How did the rib get broken? Jack Phillips Raleigh, NC ________________________________________________________________________________
Date: Sep 01, 2005
Mike, it is a rib that was actually broken, I believe, by HH hisself. Previous owner never repaired but I am planning on doing so this winter. --- Michael D Cuy wrote: > > > Larry-- way to go. Congratulations on logging your > 1st few flights in a > Pietenpol !!! > > On the broken wingtip bow....is that the bow that is > broken ? If so--that > is a compression > member and I'd not fly it like that. If it is a > rib--less worry. > > Mike C. > > > > > > browse > Subscriptions page, > FAQ, > > > > > > > > > > Larry Nelson Springfield, MO Beechcraft Bonanza V-35B N2980A Cessna 195 N9883A Pietenpol Air Camper N444MH 1963 GMC 4106-1618 SV/ Spirit of America ARS WB0JOT ________________________________________________________________________________
Subject: Seat Belts
Date: Sep 01, 2005
I used the military type from Aircraft Spruce.I havn't flown with them yet but just sitting in the seat and making motor noises;they feel just fine. I bought the lap belt and two shoulder strap type that has a long single belt on the shoulder for feeding back behind the seat and around the cable and through the special wrap back on itself piece.It looks like a square piece of metal with slots in it.This piece comes with the order.I cut a slot in the wood that my back rests on,as high as I could get it without running into too much wood from the turtle deck.Seems to work OK. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Egan, John Subject: Pietenpol-List: Seat Belts What is the best practice for seat and shoulder belts for a new Piet and does anybody have any purchase sourcing suggestions? Thanks all. ------ This e-mail is intended for the use of the addressee(s) only and may contain privileged, confidential, or proprietary information that is exempt from disclosure under law. If you have received this message in error, please inform us promptly by reply e-mail, then delete the e-mail and destroy any printed copy. Thank you. ======================================================================== ====== ________________________________________________________________________________
Date: Sep 01, 2005
Jack, HH kept meticulous logs and so did Joe Santana. I believe it was HH that ground looped her. And thanks for the advice. --- "Phillips, Jack" wrote: > Jack" > > Way to go, Larry! Great feeling, isn't it? > > Depending on how the rib is broken, you might be > able to repair it > without having to do much fabric work. I had to > repair one broken rib > after my forced landing last fall and was able to do > the repair in place > by working through one inspection hole and a 6" slit > in the fabric which > was easily patched with tape. How did the rib get > broken? > > Jack Phillips > Raleigh, NC > > > > > > browse > Subscriptions page, > FAQ, > > > > > > > > > > Larry Nelson Springfield, MO Beechcraft Bonanza V-35B N2980A Cessna 195 N9883A Pietenpol Air Camper N444MH 1963 GMC 4106-1618 SV/ Spirit of America ARS WB0JOT __________________________________ Stay connected, organized, and protected. Take the tour: http://tour.mail.yahoo.com/mailtour.html ________________________________________________________________________________
Date: Sep 01, 2005
Subject: Re: HAPI powered Pietenpol for sale on Barnstormers.com
This might be worth exploring except for the VW engine. Been there, done that and VERY disappointed in VW based "airplane" engines.. Won't fly in an aircamper very well, that I can promise. ________________________________________________________________________________
Date: Sep 01, 2005
Subject: Re: Try to wipe that smile off my face!
Hey Larry !! A big CONGRATULATIONS on your first flight !! You're gonna have a blast flying that little ol' plane around. It's both challenging and forgiving. When you land at various airports, folks come out of the woodwork to check out your plane !! They don't even glance at a half million dollor plane, just to check your plane in detail. It's great to have N444MH back in the air, where she belongs !! Chuck G. ps I'm glad you took my wise crack in jest...the way it was meant. ________________________________________________________________________________
Date: Sep 01, 2005
Chuck is right. The best airplane to own is the one where they push the Learjet out of the hangar to put yours in. Chris Braumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message ----- From: Rcaprd(at)aol.com To: pietenpol-list(at)matronics.com Sent: Thursday, September 01, 2005 5:09 PM Subject: Re: Pietenpol-List: Try to wipe that smile off my face! Hey Larry !! A big CONGRATULATIONS on your first flight !! You're gonna have a blast flying that little ol' plane around. It's both challenging and forgiving. When you land at various airports, folks come out of the woodwork to check out your plane !! They don't even glance at a half million dollor plane, just to check your plane in detail. It's great to have N444MH back in the air, where she belongs !! Chuck G. ps I'm glad you took my wise crack in jest...the way it was meant. ________________________________________________________________________________
Date: Sep 01, 2005
True,Mark. I just got home from gas hunting..No luck.I have about 1.5 - 2 gallons left in my bike.That will be enough for two more trips to work and back .Then i'll buy me a shwinn bike. Now there is a NUMBER of great folks.Everyone except those few bastards luders(spell) are holding up together.Helping out each other.Companies open doors for people.Distributing ice and drinking water for free..The only problem is that we have no gas around here to drive and take chance for it.However we are here are high spirited.We got through the storm with minimal damage here .Got power back so we re cool.No water or gas is ok...Hopefully soon we'll get some. Now In new orleans few folks (watching here on TV) are screaming "take us out,WE WANT OUT" Then walmart burgluries.Heared on radio they were breaking in hospitals looking for drugs.Hell here on CNN i saw a dude running with about three dozens of fishing poles.Those assholes(excuse my french) were warned and asked to move out.Instread they chosen to ride it out.Then they chose to break in the stores and steal stuff even if they don't really need 6 pairs of jeans or riding lawnmower(sae on CNN boy pushing it out of store) Then they choose to shoot up the helicopter that was rescuing folks. Then they acuse government because it's easier to blame uncle sam then do something for your own good. It's just a type of people.Makes me sick and disgusted.Let me tell you,I saw a tramendous help from government and other folks.People helping each other and this is a bottom line.We'll get through it only working together.Now acusing sam or each other. Peace out.:) Mitty --- Mark wrote: > > > I got my commercial CFI and CFII at Jackson. Times > like this bring out > the best in people and the worst in people. I hope > you told the guy > what he could do with the hundred that someone would > eventually pay even > if you didn't. Yet with the jerks you don't hear > about the good > stories. My dad after Camile picked up a camp stove > for my aunt in > Gulfport at the time. He took it to the counter to > check out. The > owner looked at him and asked, "Is this going to > someone on the Gulf > Coast?" He told him it was for his sister in the > Gulfport area. He > just said, "No charge, and wish her my best." > > I was on the coast about 2 weeks after Camile. This > has many > simularities. Its almost like you combine the > flooding of Virginia, but > put it in worst terrain (New Orleans) and the other > destruction and you > have damage that will last for decades. The last > time I was there only > a few years ago you could still see some signs of > Camile and that was > decades later. This one will be no different and > likely worse in some > ways. > > Hopefully those that had airplanes in the area got > them out and can go > fly them occasionally to get away from the rest of > the mess. > > > > Mitty wrote: > > > > > >Here in Jackson ms yesterday some clown were > selling 5 > >gal jugs for $100.Damn bastards!! :(It's pretty bad > >here at the moment.No gas,no drinking water...We > got > >power but my internet still dont work...SUX > > > >--- Rick Holland wrote: > > > > > > > >>$2.40? Ha! Thats peanuts, I am in San Diego on a > >>business trip and regular > >>is already $2.99 before any increase. By the way > had > >>the afternoon off and > >>visited the San Diego Aerospace Museam, it is > >>excellent. They have the > >>original wing rib jig used to make the Spirt of > St. > >>Louis wing down the road > >>at Lindberg field and it used 1/2" x 1/4" cap > strips > >>just like the Piet > >>except they are rotated 90 degrees so the entire > rib > >>is 1/4" thick. > >> > >> > >>On 8/30/05, hans.vander.voort(at)alfalaval.com > >> > >>wrote: > >> > >> > >>> > >>> > >>hans.vander.voort(at)alfalaval.com > >> > >> > >>>Some inside info: Gasoline wholesale price > >>> > >>> > >>(automobil) just hit 2.40 , > >> > >> > >>>forty cents up from yesterday! > >>>Fill up your gas tanks, retail price will be 3 + > >>> > >>> > >>by the end of the week > >> > >> > >>>Hans > >>> > >>> > >>> > >>> > >>> > >>> > >>===================================== > >>===================================== > >> > >> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>-- > >>Rick Holland > >> > >> > >> > > > > > >__________________________________________________ > protection around > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
August 16, 2005 - September 01, 2005
Pietenpol-Archive.digest.vol-eq
