Pietenpol-Archive.digest.vol-fl
November 08, 2006 - November 27, 2006
      Sponsored Link
      Mortgage rates near historic lows: $150,000 loan as low as $579/mo. Intro-*Terms
Date: Nov 08, 2006
Subject: If You Got This Email, You Haven't Made A Contribution
Yet! :-) If you received this particular Matronics List Email message, its because you haven't yet made a Contribution to support your Lists! This is the first PBS-like funds drive message under the new distribution system. The new system selectively sends out the Contribution messages ONLY to those that forgot to whip out the 'ol credit card this year to support the continued operation and upgrade of the Matronics Email Lists! Don't you wish PBS worked that way? :-) You heard that right. Once you make your Contribution, these support requests messages during November will suddenly stop coming to your personal email inbox! Pardon me if I seem kind of excited about the new feature. I've wanted to implement something like this for a number of years now, but it was always such a daunting task to modify the back-end List processing code, that I just kept putting it off. Finally this year, I just decided to bite the bullet and put the code-pounding time it to make it work. A few days later, bam! A working system! Anyway, I'll stop gushing now. I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the Commercial-Grade Internet connection and to pay the rather huge electric bill to keep the computer gear running and the air conditioner powered up. Your personal Contribution matters because when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercialism that is so prevalent on the Internet these days and I particularly don't want to have it on my Email List site. I'm pretty sure you don't either. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution today to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 08, 2006
Subject: Re: engine mount jig
Ken, Look at the drawing, the offset is in there walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: KMHeide To: pietenpol-list(at)matronics.com Sent: Tuesday, November 07, 2006 10:54 PM Subject: Re: Pietenpol-List: engine mount jig Just a thought about the jig....Knowing the Ercoupe and its canted down and away engine mount to reduce p-factor...has anyone created an engine mount with this in mind as it works very well in the Ercoupe design? Do not know of the total amount of downward canting......Again...just a thought.. Ken H. Fargo, ND Oscar Zuniga wrote: I forgot to mention how I worked out the jig for the VW engine mount in my "Flying Squirrel" (not flying yet though). It was actually very enjoyable to build the jig because I knew goofs wouldn't matter much; I could re-drill or re-cut anything since it was just for the jig. It was a nice Saturday job to build the jig. I started out with a piece of scrap sheet metal (ductwork) measured and cut to the exact shape of the firewall, then mounted it to a piece of heavy plywood with some 2x4 back framing. Scrounge hardware mounted the sheet metal to the plywood, then I carefully located where the engine mount points would be. I had the four "spool" pieces that would form the four corners of the mount and I bolted those to the firewall jig with hardware store bolts. I mounted this firewall jig to a 2x4 frame that also supported the engine with some wood framing, in its desired relationship to the firewall. I also put this frame on casters to make it easy to move around, but that's just gravy. By the way, pictures of this are the first few at http://www.flysquirrel.net/engine/engine.html and the pictures will tell the whole story. I took this to my friend Jeff Sterling, who then welded the engine mount tubing together and it didn't matter if the plywood or ------------------------------------------------------------------------- --- Sponsored Link Get a free Motorola Razr! Today Only! Choose Cingular, Sprint, Verizon, Alltel, or T-Mobile. ________________________________________________________________________________
Date: Nov 08, 2006
Subject: Re: Motor mount question
While we are on the topic of CG range, their seems to be a difference of opinion on the forward max CG point, everybody seems to agree on the rear at 20" aft of the leading edge or 33%. I can't find a number on the plans for the forward CG but several posts in the archives mention 15" aft of LE or 25%. Going though the Bengelis books I have seen 16% (which would be 9.5") as a typical number, and most important in Bill Rewey's Piet guidelines on CG he mentions that 9.5" is the forward limit. Question is has anyone actually flow a Piet with the CG anywhere near 9.5" aft of LE? Rick On 11/7/06, Rcaprd(at)aol.com wrote: > > In a message dated 11/7/2006 9:14:52 AM Central Standard Time, > davea(at)symbolicdisplays.com writes: > > I am building the "standard" fuselage. I weigh 170 and 6'2 thus I made > mine a single seater so I have some legroom. People make it sound so > simple when they talk about "moving the wing back" but I was thinking it > couldn't be so simple unless they know something I don't. Thank you for > your explanation! Am I correct in thinking you can just move the engine > out farther to get the correct CG? (and leave the wing where it is) Of > course the nose might get to be a bit LOOOOOOOOONG! > > Dave, > Moving the wing back is a unique feature of the Pietenpol, and really > isn't that difficult to do, but requires a couple of new cables if you > already had the wing position nailed down. Moving the engine out farther > forward does the same thing as moving the wing back - as far as the C of G > is concerned. However, the farther forward the engine is, the more it > affects the handling of the plane coming out of a slip. > I built the 'Short' fuselage, now with a Continental A65 engine, and I > weight 210 lbs. I moved the engine forward a whopping 8" (increased the > wall thickness of the steel tubes), as well as moved the wing back from > vertical 3 1/2". It does give the plane a 'Long Nose' look, but with my > weight there is no way I can get too far aft on the C of G, even with Zero > Fuel the C of G is just at the aft limit. Us 'fat boys' just gotta do what > we gotta do !! With the rudder authority of the Piet, I have no > problem coming out of a slip. You can see lots of pictures of my plane on > my web site, as well as the entire C of G calculations under the 'Operations > Manual' page. > http://nx770cg.com/ > > Chuck G. > NX770CG > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: engine mount jig
Date: Nov 08, 2006
Yes, the A65 engine mount in 41CC is built per the Pietenpol plans with a bit of offset. If you have the supplemental engine mount drawing from Pietenpol, you'll note slight offset for it. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get FREE company branded e-mail accounts and business Web site from Microsoft Office Live ________________________________________________________________________________
Date: Nov 08, 2006
Subject: Clarification On New Contribution Module Operation...
Dear Listers, A number of Listers emailed and indicated that, even though they had made a Contribution this year, they still received the Contribution message yesterday. I looked into it and I found a slight anomaly (ok, bug) in the new code specifically as it related to Listers that had made their Contribution through PayPal AND have a DIFFERENT email address for their PayPal account and for their Matronics List subscription. If your PayPal account email address is DIFFERENT than the email address you are subscribed to the Matronics List(s) as, then my new code module couldn't tell that you had made a Contribution, since it was using the PayPal email address instead of the List email. I've fixed this issue for any new PayPal Contributions, but I don't have any easy way of resolving this for any of the previous Contribtuions. Again, this is ONLY an issue if your PayPal and Matronics List email addresses ARE NOT the same. Otherwise, everything works great. If you made a PayPal Contribution before 11/09/06 AND your email addresses don't match, please drop me an email at " info(at)matronics.com " (do not reply to this message!) and give me your Name, and both Email Addresses and I will manually update the records so that things will work as advertised. Sorry for the hassle! New code; new bugs... :-) To make a Contribution, please see: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administration ________________________________________________________________________________
Date: Nov 09, 2006
In a message dated 11/8/2006 8:10:20 AM Central Standard Time, at7000ft(at)gmail.com writes: Question is has anyone actually flow a Piet with the CG anywhere near 9.5" aft of LE? Rick, Bernard called out to maintain the C of G between 1/4 to 1/3 of the airfoil, which amounts to between 15" and 20" behind the Leading Edge. I seriously doubt that anyone anywhere in history of the Pietenpol has been able to have flown the plane with the CG that far forward. Chuck G. NX770CG ________________________________________________________________________________
Subject: smoke systems
Date: Nov 10, 2006
Boy, this list is quiet! Guess I'll ask a question for those of you who use the windshield washer pump approach on your smoke system. I think Chuck "Baby Oil" Gantzer uses a portable battery or a rechargeable battery to power the 12V setup on Seven Zero Charlie Golf. My question is, how long will the battery operate the windshield washer pump before requiring a recharge? Once per flight? Several flights (tankfuls)? And is the battery a motorcycle type or dry type? Smoke on! Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get today's hot entertainment gossip http://movies.msn.com/movies/hotgossip?icid=T002MSN03A07001 ________________________________________________________________________________
Date: Nov 10, 2006
Subject: Wiki...
Dear Listers, I added a new Wiki web site to the Matronics Email List features earlier this year. What's a Wiki, you ask? Well, here's the Wikipedia (http://en.wikipedia.org/wiki/Wiki) definition: A wiki (IPA: [ w .ki ] or [ wi .ki ] ) is a type of Web site that allows the visitors themselves to easily add, remove, and otherwise edit and change some available content, sometimes without the need for registration. This ease of interaction and operation makes a wiki an effective tool for collaborative authoring. The term wiki also can refer to the collaborative software itself (wiki engine) that facilitates the operation of such a Web site, or to certain specific wiki sites, including the computer science site (an original wiki), WikiWikiWeb, and on-line encyclopedias such as Wikipedia. Under the Matronics Email List Moniker, there is now a very nice List-specific Wiki available! It a place for Listers to put articles about any aviation topic that suits them. The purpose is to provide what the mailing lists do not: structure and persistence. The mailing lists are a fantastic resource to ask a question and get good (and bad and funny and annoying) answers. But once the question is asked and answered it is not in front of the List anymore. If a new person subscribes the next day, he/she does not see that information unless he/she goes to the trouble to search the archives, a hit or miss proposition. The result is that the same thread of conversation gets created and/or revisited. There are several things that happen as a result: 1. The person gets his or her question answered; 2. The information gets better as more people think about and answer the question; 3. The people who have seen the same question asked and answered get annoyed at seeing the same things over and over and over and ... So this is where the Wiki comes in. You know what questions you wanted answered. You may have asked or answered the question. You know the information is useful. So you put the information here, in the Matronics Email List Wiki! It doesn't matter that this information is 100% complete or correct. Just writing something creates a placeholder and makes useful information available immediately. It has the same immediacy as the mailing list but it has persistence and structure. But what if the information is incomplete or incorrect? No problem! Anyone else coming along can edit the article! If I write something and you discover something I have left out or stated incorrectly, you can fix it right then! So let's begin and make this the place for information about building, flying, maintaining, and understanding our airplanes. But what about whether something is "appropriate" or not? Don't worry. Write it down. Let the reader determine whether or not it is appropriate. If it is, he/she will read it. If it isn't, he/she won't. It's as simple as that. And when you do write that article you won't have to worry about whether some editor is going to decide whether or not to print it in a newsletter or whether the webmaster will have time to put it up on the web page. The last question I hear brewing out there is: if anyone can post anything, won't this just become a mass of garbage? Surprisingly, the answer is a resounding no. If you want proof, go visit the Wikipedia, a free-to-everyone encyclopedia written by whoever wants to write articles. The articles there are as good as anything I have read anywhere and anyone can add anything anytime they want to. So don't hesitate. Write it down. Put it here. It will never hurt anyone. The more information we get here, the more useful it will become to other people and the more information they will put here for YOU to use. Here's the URL to start (there are lots more bured under this starting place): http://www.matronics.com/wiki/index.php/Matronics:Community_Portal But please don't forget that this Wiki and all of the other Matronics Email List features are supported solely by YOUR Contributions!! November is List Fund Raiser month and there are lots of Free Gifts to be had with your qualifying Contribution. Please make a Contribution to support the continued operation and upgrade of these great services!!! Thank you! http://www.matronics.com/contribution Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: LONGER FUSELAGE
Date: Nov 11, 2006
A lurker joins the fray. We have just started on a Pietenpol. This in an education process for the son and a last airplane for the father. We have the table but are wondering where to put the blocks to hold the stringers and cross members. Our engine will be a Suzuki 1300 cc twin cam with a gear reduction. There is local experience with this engine and it is pretty. We assume about 75 horsepower with a weight of 175 pounds for the engine and 28 pounds for the gear reduction. This will be a bit less than the 250 or so for the Ford B or the Subaru. The propeller placement will put the engine high enough to show off its twin cams. I understand that Mr. Pietenpol's Corvair Air Camper was 6.5 inches longer than the original. The question I ask, "Where is the additional 6.5 inches put into the fuselage?" Any insight will be appreciated. Bill Weir > ________________________________________________________________________________
Subject: Re: smoke systems
Date: Nov 11, 2006
Oscar. Where can I get the plans for the a smoke system for my Piet? Thanks Gene ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Friday, November 10, 2006 4:48 PM Subject: Pietenpol-List: smoke systems > > > Boy, this list is quiet! Guess I'll ask a question for those of you who > use the windshield washer pump approach on your smoke system. I think > Chuck "Baby Oil" Gantzer uses a portable battery or a rechargeable battery > to power the 12V setup on Seven Zero Charlie Golf. > > My question is, how long will the battery operate the windshield washer > pump before requiring a recharge? Once per flight? Several flights > (tankfuls)? And is the battery a motorcycle type or dry type? > > Smoke on! > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > Get today's hot entertainment gossip > http://movies.msn.com/movies/hotgossip?icid=T002MSN03A07001 > > > ________________________________________________________________________________
Date: Nov 11, 2006
Hi Bill, Welcome to the list. The Piet is a great project. Pietenpol designed 3 different wood fuselages. From shortest to longest, they are the Flying & Glider, the Orrin Hoopman 1934 Improved, and the Corvair. The 1934 are the plans you buy from Don Pietenpol and is 13'7" long firewall to tailpost. The Corvair is a supplament plan you can also buy from Don Pietenpol, it is 14'4 3/8" long, 2 7/8" longer in the aft bay at the tailpost and 2 1/2" longer in the bay ahead of the aft bay, 2'' longer in the pilot pit and 2" longer in the first bay behind the firewall. The Flying & Glider is 2" shorter than the 1934, all in the first bay behind the firewall, making it 13'5" long. Skip > A lurker joins the fray. > I understand that Mr. Pietenpol's Corvair Air Camper was 6.5 inches longer > than the original. The question I ask, "Where is the additional 6.5 inches > put into the fuselage?" > Bill Weir ________________________________________________________________________________
Date: Nov 11, 2006
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Oscar-- Chuck has a great article on his web site about his smoker...... Mike C. ________________________________________________________________________________
Date: Nov 11, 2006
From: Tim Verthein <minoxphotographer(at)yahoo.com>
Subject: How to pronounce Pietenpol?
Howdy- Kind of a newbie/lurker here. Guess I have the first newbie question.... How do you pronounce Pietenpol? Tim in Bovey == You *can* repair a flip-flop with a capacitor! == Yahoo! Music Unlimited http://music.yahoo.com/unlimited ________________________________________________________________________________
Date: Nov 11, 2006
Subject: Re: How to pronounce Pietenpol?
Me too. I think it's pronounced pete in pole ________________________________________________________________________________
Date: Nov 11, 2006
>Hi Pete, Another lurker here. If you want to stir a little excitement, pronounce it G-r-e-g-a. Roger ________________________________________________________________________________
Date: Nov 11, 2006
Hey Oscar / Gene, et All, The smoke system I have has proved to be very reliable, and the only maintenance has been to recharge the battery about 4 or 5 times a summer...Oh yeah, every once in a while ya gotta fill 'er up with either Baby Oil, or your favorite white mineral oil. My smoke system consists of an after-market windshield washer pump and originally I had the aftermarket tank, plumbing to each exhaust pipe, and wiring to the switch on the power lever. I isolated / mounted the tank on the upper left motor mount tubing, with a couple layers of rubber strap. I routed the clear tubing to a Tee fitting secured in rubber, to the engine mount, then used 1/8" brass tubing to each of the fittings in the exhaust pipes. I laid out the route of the tubing, marked the pipes, and removed both exhaust pipes. I cut a 1/8" pipe coupler in half, radiused each half to the radius of the pipe, and oxy / accy welded them to the aft pipe of each side. After welded, I drilled one #60 hole through the exhaust pipes. I placed these holes toward the bottom edge of the fittings, theorizing that if oil would lay in there it would gum up. The switch is a push on / push off button, that is mounted right to the throttle handle. This location allows me to work the smoke without taking my hand off the throttle. I originally thought it would only smoke good at full power, but came to find I don't need much over 1/4 throttle to Smoke 'Em Up !! I can smoke 'em while taxiing, without any problem !! My exhaust pipes point down and away from the fuselage, and even when all the oil doesn't vaporize, the fuselage hardly gets anything on it. I had a couple of squawks on the original system, that I have taken care of. 1.) I mounted the tank at about the same level as the fittings on the exhaust pipes, and it always dribbles out the pipes, with a little bit of smoke as a result. Over a period of a couple of hours, it will drain the tank, but I usually 'Smoke em up' before that happens. 2.) When I ran the tank empty, and refill it, the pump would cavitate because of the way the line ran from the bottom of the tank to the pump, and I would always have to prime the pump, by blowing in the top of the tank. I got some strange looks from folks, while I performed this operation !! 3.) The tank was too small. It only was big enough to do about 3 smoke runs. I would like to put about a 5 gallon bucket up there on the firewall, but I don't have enough room !! 4.) I had to remove the top cowling to re-fill the tank. I built a new tank out of fiberglass / West System resin, with a fill tube out to the right side of the cowling. It is mounted lower on the firewall. This will take care of all the squawks. 5.) I now have been using the new smoke tank, but I have a small leak in the tank. I used West Systems resin for the fiberglass tank, and evidently I didn't get the seam sealed up good enough. I've never had that problem when I used polyester resin, but it kicks very quickly. The West System gives some time, but it is also quite a bit more expensive. I fixed the leak, and it has been trouble free ever since. I have some good pictures and explainations on my web site: http://nx770cg.com/SmokeSystem.html Chuck G. NX770CG ________________________________________________________________________________
Subject: Smoke system
Date: Nov 11, 2006
Chuck G. Thanks for taking time to explain your smoke system. Do you mind if I steal your idea? I just went to your site. A real 1st class site! Gene N502R ________________________________________________________________________________
Date: Nov 11, 2006
Chuck: you had me at the first sentence. All I asked was how long the battery lasted between charges-! All that other good stuff was, as Mikee pointed out, on both your website and your fun DVD. I reassembled my carb with the new venturi today, fired up the engine and it ran STRONG. What a joy to run the A65. Wings should be back on the airplane soon... Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Live Search! ________________________________________________________________________________
Subject: PS to engine run
Date: Nov 11, 2006
PS on today's engine run... I finally felt that I had the airplane tied down securely enough to try a full-power static runup. The tach needle was wiggling between 2200-2250 to me, so I think the firewall forward is about optimum! The EAA chapter has an optical tach and I'll be checking the mechanical tach against it, but you just can't argue with this setup for the A65. It sure is nice to hear it run. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ All-in-one security and maintenance for your PC. Get a free 90-day trial! ________________________________________________________________________________
Date: Nov 11, 2006
It is Pete-n-Paul, according to Don Pietenpol. ________________________________________________________________________________
Date: Nov 12, 2006
Subject: Re: Smoke system
In a message dated 11/11/2006 5:22:42 PM Central Standard Time, zharvey(at)bellsouth.net writes: Chuck G. Thanks for taking time to explain your smoke system. Do you mind if I steal your idea? I just went to your site. A real 1st class site! Gene N502R Gene, It's not stealing by any streach of the imagination !! I hope some great day will come, when we can fill the skies of Brodhead with Smokin' Pietenpols !! Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 12, 2006
In a message dated 11/12/2006 12:07:42 AM Central Standard Time, Rcaprd(at)aol.com writes: Gene, It's not stealing by any streach of the imagination !! I hope some great day will come, when we can fill the skies of Brodhead with Smokin' Pietenpols !! Just as sure you do will bring on a horde of beauros demanding; a tower w/operator, paved runway, landing lights, VOR and stuff, credentials officer on the ground checking driver license pilots who may have been rejected on a physical. All kinds of good stuff awaits you. Also, you may have a collision or two in all that smoke and TP. Before doing ANYTHING in aviation, especially something different, imagine how the feds can use it to further control your hobby and enhance their beauro and pockets. I promise this will be my last e-mail ever Nathan ________________________________________________________________________________
Date: Nov 12, 2006
I hope not, Corky. Al ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Sunday, November 12, 2006 11:01 AM Subject: Re: Pietenpol-List: Smoke system In a message dated 11/12/2006 12:07:42 AM Central Standard Time, Rcaprd(at)aol.com writes: Gene, It's not stealing by any streach of the imagination !! I hope some great day will come, when we can fill the skies of Brodhead with Smokin' Pietenpols !! Just as sure you do will bring on a horde of beauros demanding; a tower w/operator, paved runway, landing lights, VOR and stuff, credentials officer on the ground checking driver license pilots who may have been rejected on a physical. All kinds of good stuff awaits you. Also, you may have a collision or two in all that smoke and TP. Before doing ANYTHING in aviation, especially something different, imagine how the feds can use it to further control your hobby and enhance their beauro and pockets. I promise this will be my last e-mail ever Nathan ________________________________________________________________________________
Subject: Who's flying to Broadhead 07 from PA, WV, OH
Date: Nov 12, 2006
Who's planning on flying their Pietenpol to Broadhead next year. God willing I should have my Piet ready to go and would like to make the trip. This would be a first time for me and I would rather fly there with a wingman(s) John Pittsburgh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=73963#73963 ________________________________________________________________________________
Date: Nov 12, 2006
Well, it's my dream to fly 41CC to Brodhead (via Shreveport, LA) and if I don't have a goal or a dream to do so, it will never happen. So I'll say yes, I'm planning to fly to Brodhead in '07. Turns out that Paul Poberezny dissolved the SAA this past week, so there won't be another fly-in to Urbana, Illinois... the only other one that I'd have liked to have made. I don't think a NORDO, low/slow airplane like the Piet would be too welcome at OSH so that's out of the question. Plus, people might wonder about the integrity of an airplane that can be built for less than the cost of a new sedan and maintained by someone without a uniform and an FAA license of some sort. My wife still goes white as a sheet when I tell her that I should never need a radio to talk to anybody when I fly the Piet most places I want to take it. Most people assume that people flying airplanes have to be under Air Traffic Control or else! Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ ________________________________________________________________________________
Date: Nov 12, 2006
Subject: Brodhead accommodations
I sure this question was asked recently, but I was too dumb to pay attention. I am planning to attend Brodhead 2007. Where can I stay nearby? Jim, I am still interested in those Model A engines. Are you still out there? Ron ________________________________________________________________________________
Subject: Re: Who's flying to Broadhead 07 from PA, WV, OH
Date: Nov 12, 2006
John: I plan to fly MR. Hicks piet to Broadhead this year, but Missouir is a little out of your way. But that does not mean we can not fly there togeather. Chet Hartley N920Y ----- Original Message ----- From: "Rock-a-Wing" <john.rocca(at)us.army.mil> Sent: Sunday, November 12, 2006 6:36 PM Subject: Pietenpol-List: Who's flying to Broadhead 07 from PA, WV, OH > > > Who's planning on flying their Pietenpol to Broadhead next year. God > willing I should have my Piet ready to go and would like to make the trip. > This would be a first time for me and I would rather fly there with a > wingman(s) > John > Pittsburgh > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=73963#73963 > > > ________________________________________________________________________________
Date: Nov 12, 2006
In a message dated 11/12/2006 6:39:22 PM Central Standard Time, john.rocca(at)us.army.mil writes: Who's planning on flying their Pietenpol to Broadhead next year. I'm from W Va, but I fly out of Wichita KS. Be the good Lord willing, and the creeks don't rise...I'll be there !! Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 13, 2006
Subject: WLAS [Please Read]
Dear Listers, I sat down at the 'ol computer tonight to have a look at a few of the nice comments List Members have been including along with their Contributions this year. I was amazed at how many I found and even more amazed at some of the very nice things Listers have been saying about the Lists and how valuable the they are to them. I've included quite a few of these nice comments below. Please read over some of this great Lister feedback. No doubt you will find that you agree with at least one or two of those comments - maybe all of them! If you find that do, won't you please make a Contribution to support these Lists today!! Its fast and easy with the Matronics List Contribution Web Site: http://www.matronics.com/contribution Don't forget that I've now fully implemented the new *List Fund Raiser Squelch* feature that will automatically intercept any future iterations of my "Please Contribute" messages -- that is, *once you've made YOUR Contribution*! How cool is that? (Make sure the email address you enter along with your Contribution matches exactly your subscribed List email address. An exact match is how it works.) Thank you for your generous Contributions this year and for all the wonderful comments!! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying (WLAS) ================ Absolutely the best deal on the Internet!! -Owen B I love The Matronics... -Robeto B My wife has her soaps & I've got my lists! -Hal B These lists are, indeed, the lifeline of our hobby. -Bob R The best source of information for my a/c. -Tony C The Zenith list is the first thing I read in the morning. -Herbert H You do more good than you can imagine. I wish I'd known about you while I was building my Kitfox, but you are still an after-the-fact resource. -Ben B ..an excellent site. -Ashley M The "List" has been the ultimate help for my Zenith CH 701 project!! -Brian U I appreciate the list being here for me. -Geoff H ..a great service. -William C The List continues to be an interesting and useful facility. -David M Your list is a constant goad to keep me working on my project. -Thomas S ..a great service. -Robert W The Pietenpol list is a great resource. -Benjamin W The Yak-list is Awesome! -James S ..great service. -Robert S The features you have implemented recently have you poised to knock out yahoo groups... -Danny D I like how your forum looks/works and the list service... -Ken E ..great service. -David P Very useful web site. -Wayne E ..a very valuable service. -Chris D Great sites... -Randall R I used to look at [that other] site also but it's gotten so cluttered with advertising that I've stopped looking at it. -Wayne E Without your services, the build would be a grope in the dark... -Fergus K The information and help I've received greatly outweighs the donation... -Lee P ..great service! -Christopher D I really don't think I could be building my plane without the wisdom I find on this list. -William G It really makes building a pleasure. -James P ..great service. -Doug W I'm getting near the end of my build (Europa tri XS) don't think I could have done it with out the help of the forum. -Stanislaus S Marvelous service. Couldn't have done it without you. -Jim G Love the list, this is a wonderful way to help others... -Michael S ..good service. -Derek L The list is responsible for helping me complete this project and educating me in the process. -Jeff D Definitely worth the donation. -Ron L ..great service to the aviation community. -Tony P I have been flying my plane for 5 years (RV-6) but I still get valuable information from this service. -Don N A very helpful site. -Roland S It's a great community to be part of. -David L Great sites. -John C A great place to find and share not only information but to meet people across the country and make lasting relationships. -Uncle Craig Great facility. -Peter H Its a great source of information! -Michael W Great improvements to the List... -Edward A Great service!!! -Rich D ..great resource! -William C ..excellent lists! -Michael S Couldn't have built my RV4 without the list. -Warren M ..a great service... -James N I would not have missed [the list] for anything during the building of my Europa. -Svein J ..another great year. -Robert D ..this [is an] essential builder's resource. -David A ..excellent service. -Gregory B I've learned a huge amount of "stuff" over the past year and look forward to it every day! -Smith M ..a great communication tool... -Jon M Finished building 5 years ago, but still are lurking on your great list! -Lothar K ..a valuable service. At 11:00 pm Matronics is the goto place for my RV questions. -Mike D ================= What Listers Are Saying (WLAS) ================ ________________________________________________________________________________
Date: Nov 13, 2006
GREGA, I think, is pronounced, a i r p l a n e. By the way, if anyone out there has an set of plans for the longer Piet they do not have further use for and wishes to trade them for some other types of paper, the kind with small pics of Abraham Lincoln on them, why don't you contact me, for my archives. Gene -----Original Message----- >From: Roger & Barb <thoreson(at)earthlink.net> >Sent: Nov 11, 2006 11:13 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: How to pronounce Pietenpol? > > >>Hi Pete, >Another lurker here. If you want to stir a little excitement, pronounce it G-r-e-g-a. >Roger > > ________________________________________________________________________________
Date: Nov 13, 2006
Subject: Speaking of Brodhead '07
Exactly WHEN is Brodhead 07? Since we're just in the planning stages for eventually building, we won't be flying one down for a few years, but we'd like to show up and have a look! An internet search didn't turn up any details. When..and where to stay? Tim in Bovey == You *can* repair a flip-flop with a capacitor! == Cheap talk? ________________________________________________________________________________
Date: Nov 13, 2006
John, Cinda and I are hoping to make Brodhead 07, her in the motor home and me in the GN-1. We live at Hales Landing (2WV3) about 12 miles south of Parkersburg WV, and about 50 miles south of your direct line west from Pittsburgh to skim the south side of Chicago class B. We would hope to leave here the Tuesday or Wednesday before Brodhead. Haven't planned the trip yet, but looks like 2 days, or one real long day in a Piet. Skip > [Original Message] > > Who's planning on flying their Pietenpol to Brodhead next year. God willing I should have my Piet ready to go and would like to make the trip. This would be a first time for me and I would rather fly there with a wingman(s) > John > Pittsburgh > ________________________________________________________________________________
Date: Nov 13, 2006
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
I'll be there, just don't know which airplane. I'd like to bring the Pietenpol again, but my vacation schedule might dictate otherwise, in which case I'll arrive in a shameful spam-can and park away from the real airplanes (hey, being an RV-4 it is at least a taildragger, and a homebuilt). Brodhead is two days of hard flying from Raleigh in a Pietenpol, or 4 hours flat in an RV-4. Go figure. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Skip-Cinda Gadd Sent: Monday, November 13, 2006 8:47 AM Subject: RE: Pietenpol-List: Who's flying to Broadhead 07 from PA, WV, OH --> John, Cinda and I are hoping to make Brodhead 07, her in the motor home and me in the GN-1. We live at Hales Landing (2WV3) about 12 miles south of Parkersburg WV, and about 50 miles south of your direct line west from Pittsburgh to skim the south side of Chicago class B. We would hope to leave here the Tuesday or Wednesday before Brodhead. Haven't planned the trip yet, but looks like 2 days, or one real long day in a Piet. Skip > [Original Message] > > Who's planning on flying their Pietenpol to Brodhead next year. God willing I should have my Piet ready to go and would like to make the trip. This would be a first time for me and I would rather fly there with a wingman(s) > John > Pittsburgh > _________________________________________________ ________________________________________________________________________________
Date: Nov 13, 2006
Subject: Re: Speaking of Brodhead '07
In a message dated 11/13/2006 8:47:17 A.M. Eastern Standard Time, minoxphotographer(at)yahoo.com writes: Exactly WHEN is Brodhead 07? Since we're just in the planning stages for eventually building, we won't be flying one down for a few years, but we'd like to show up and have a look! An internet search didn't turn up any details. When..and where to stay? I do know the dates are July 20, 21 & 22. Still looking for a place to stay as well. Ron ________________________________________________________________________________
Date: Nov 13, 2006
Subject: wing strut attachment geometry
Hello group, I have a question regarding wing strut attachment (geometry) at the spars. I do not find any archived information on this subject. As we build our Piets with the wing leaning back a little, and the fact that by design, the lower wing strut attachment points are ahead of the upper wing strut attachment points, the struts will also need to lean back accordingly. As a result, the strut/s will not be aligned with the spar/s. Let's assume we use hollow streamline tubing for strut material (aluminum or steel), and let's assume we are fabricating an upper strut fitting with the hole perpendicular to the strut as shown in photos from previous "fitting" discussions. My question is "how do we assemble the strut/s to the wing at some required angle to attach the lower end of the strut/s to the fuselage without having some kind of capability for angular adjustment at the upper fitting?" I have looked at many Piets at Brodhead, and if I recall correctly, they all appear to have similar upper fittings where they get attached to the flat steel coming off the spars with a perpendiculr hole drilled through the fittings, and they all look like nice fabrications without any twisting. Thank you again everyone. It seems that I have been asking my share of questions lately and I appreciate the help. John --------------------------------- ________________________________________________________________________________
Subject: Brodhead & cross country in a Peteandpole
Date: Nov 13, 2006
That is one LONG trip you made in 2005 Jack to Brodhead and then your other stops. I can't blame you for wanting to fly the RV-4 up there. I've had way too much fun driving and then camping over by John Hofmann and Rob B. to bring the Piet again but still a possibility. (I've only got about 6 hours of flying to do to get to Brodhead from Ohio) You really have to be dedicated to take a Pietenpol cross country and it is very rare to find a Piet from more than a few states away--but we're getting them. John D. from Colorado, Iron Butt Chuck Gantzer from Kansas, and you from North Carolina. Steve E. and Duane W. still take the cake for flying in from Provo, Utah in 1999 though. Man, and 10,000 feet msl to cross those mountains ! Hats off to you all. Mike C. ________________________________________________________________________________
Date: Nov 13, 2006
Subject: Re: Brodhead accommodations
Couple hotels in Monroe, about 15 minutes away, just google for motels in Monroe, WS. Also a B&B in Broadhead, forget the name of it. On 11/12/06, Pietsrneat(at)aol.com wrote: > > * I sure this question was asked recently, but I was too dumb to pay > attention.* > * I am planning to attend Brodhead 2007. Where can I stay nearby?* > * * > *Jim,* > * I am still interested in those Model A engines. Are you still out > there?* > ** > *Ron* > * * > * * > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 13, 2006
Subject: Re: wing strut attachment geometry
John, The upper fitting , where the streamlined meets the flat strap, there is a single bolt that the strut pivots on. My Mentor had me put the end of the streamlined tubing in a vise and flatten it down to the thickness of the flat strap. This way there is no up/down wobble. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: John Egan To: pietenpol-list(at)matronics.com Sent: Monday, November 13, 2006 12:38 PM Subject: Pietenpol-List: wing strut attachment geometry Hello group, I have a question regarding wing strut attachment (geometry) at the spars. I do not find any archived information on this subject. As we build our Piets with the wing leaning back a little, and the fact that by design, the lower wing strut attachment points are ahead of the upper wing strut attachment points, the struts will also need to lean back accordingly. As a result, the strut/s will not be aligned with the spar/s. Let's assume we use hollow streamline tubing for strut material (aluminum or steel), and let's assume we are fabricating an upper strut fitting with the hole perpendicular to the strut as shown in photos from previous "fitting" discussions. My question is "how do we assemble the strut/s to the wing at some required angle to attach the lower end of the strut/s to the fuselage without having some kind of capability for angular adjustment at the upper fitting?" I have looked at many Piets at Brodhead, and if I recall correctly, they all appear to have similar upper fittings where they get attached to the flat steel coming off the spars with a perpendiculr hole drilled through the fittings, and they all look like nice fabrications without any twisting. Thank you again everyone. It seems that I have been asking my share of questions lately and I appreciate the help. John ________________________________________________________________________________
Date: Nov 13, 2006
Walt, I forgot, I'll have those diagonal flying wires in tension under the wing, so I feel better using a single bolt. Thanks again, John walt evans wrote: John, The upper fitting , where the streamlined meets the flat strap, there is a single bolt that the strut pivots on. My Mentor had me put the end of the streamlined tubing in a vise and flatten it down to the thickness of the flat strap. This way there is no up/down wobble. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: John Egan To: pietenpol-list(at)matronics.com Sent: Monday, November 13, 2006 12:38 PM Subject: Pietenpol-List: wing strut attachment geometry Hello group, I have a question regarding wing strut attachment (geometry) at the spars. I do not find any archived information on this subject. As we build our Piets with the wing leaning back a little, and the fact that by design, the lower wing strut attachment points are ahead of the upper wing strut attachment points, the struts will also need to lean back accordingly. As a result, the strut/s will not be aligned with the spar/s. Let's assume we use hollow streamline tubing for strut material (aluminum or steel), and let's assume we are fabricating an upper strut fitting with the hole perpendicular to the strut as shown in photos from previous "fitting" discussions. My question is "how do we assemble the strut/s to the wing at some required angle to attach the lower end of the strut/s to the fuselage without having some kind of capability for angular adjustment at the upper fitting?" I have looked at many Piets at Brodhead, and if I recall correctly, they all appear to have similar upper fittings where they get attached to the flat steel coming off the spars with a perpendiculr hole drilled through the fittings, and they all look like nice fabrications without any twisting. Thank you again everyone. It seems that I have been asking my share of questions lately and I appreciate the help. John href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List --------------------------------- ________________________________________________________________________________
Date: Nov 13, 2006
John, I thought I understood your question,,,but I know I don't understand your reply. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: John Egan To: pietenpol-list(at)matronics.com Sent: Monday, November 13, 2006 4:21 PM Subject: Re: Pietenpol-List: wing strut attachment geometry Walt, I forgot, I'll have those diagonal flying wires in tension under the wing, so I feel better using a single bolt. Thanks again, John walt evans wrote: John, The upper fitting , where the streamlined meets the flat strap, there is a single bolt that the strut pivots on. My Mentor had me put the end of the streamlined tubing in a vise and flatten it down to the thickness of the flat strap. This way there is no up/down wobble. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: John Egan To: pietenpol-list(at)matronics.com Sent: Monday, November 13, 2006 12:38 PM Subject: Pietenpol-List: wing strut attachment geometry Hello group, I have a question regarding wing strut attachment (geometry) at the spars. I do not find any archived information on this subject. As we build our Piets with the wing leaning back a little, and the fact that by design, the lower wing strut attachment points are ahead of the upper wing strut attachment points, the struts will also need to lean back accordingly. As a result, the strut/s will not be aligned with the spar/s. Let's assume we use hollow streamline tubing for strut material (aluminum or steel), and let's assume we are fabricating an upper strut fitting with the hole perpendicular to the strut as shown in photos from previous "fitting" discussions. My question is "how do we assemble the strut/s to the wing at some required angle to attach the lower end of the strut/s to the fuselage without having some kind of capability for angular adjustment at the upper fitting?" I have looked at many Piets at Brodhead, and if I recall correctly, they all appear to have similar upper fittings where they get attached to the flat steel coming off the spars with a perpendiculr hole drilled through the fittings, and they all look like nice fabrications without any twisting. Thank you again everyone. It seems that I have been asking my share of questions lately and I appreciate the help. John href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Nov 13, 2006
Here's the picture: http://www.flysquirrel.net/piets/P6210018.JPG There is a bolt (vertical) that holds the attach fitting (strap) into the end of the streamline tubing and another (fore-and-aft) that holds the attach fitting to the wing. In this picture (John Dilatush's "Mountain Piet") there is the added feature of a wing tiedown point, but you can see that the X-brace wires have tabs that the bolt through the wing attach fittings capture. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Find a local pizza place, music store, museum and morethen map the best route! http://local.live.com?FORM=MGA001 ________________________________________________________________________________
Date: Nov 13, 2006
In a message dated 11/13/2006 11:42:04 AM Central Standard Time, johnegan99(at)yahoo.com writes: My question is "how do we assemble the strut/s to the wing at some required angle to attach the lower end of the strut/s to the fuselage without having some kind of capability for angular adjustment at the upper fitting?" And remember to design the Jury Struts to be able to adjust for & aft, with the bolts in the lateral direction. I made my Lift Strut Attachments according to the plans...I call them 'Lollypop Fittings'. The two bolts running perpendicular to each other allows the wing to pivot. I have a good picture of how I did the lower Jury Strut Attachment at my web site, down toward the bottom of the page at: http://nx770cg.com/Wing.html It's best if you have a high speed connection, because I have so many pictures there to download. I now have some actual moving parts on my Tailwind, and I just recently updated the 'Next Project Tailwind' page too, at: http://nx770cg.com/NextProjectTailwind.html Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 13, 2006
In a message dated 11/13/2006 7:51:04 AM Central Standard Time, csfog(at)earthlink.net writes: Haven't planned the trip yet, but looks like 2 days, or one real long day in a Piet. Skip, Making it a two day trip is Much more enjoyable, because you don't have 'Git There Itis', and you can spend extra time when you're at the fuel stops to allow all the folks that come out of the woodwork to check out your plane...and answer all the most popular questions: "What is that ?" "Is it a kit ?" "Waddya mean you Scratch Built it ???" And, "Where are you going / coming from ?" Then, of course, they have to take your picture...so you simply have to plan for all this extra time spent at the stops. People will walk right past a $200,000 airplane to get a close up and personal look at your plane !! The Journey is the Reward !! Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 13, 2006
Chet, I live in Tennessee (half way between Nashville and Memphis) and plan on flying to Broadhead with my Piet. Where in Missouri are you? Any luck with the engine yet? Gene ----- Original Message ----- From: "Chet's Mail" <Chethartley1(at)mchsi.com> Sent: Sunday, November 12, 2006 9:35 PM Subject: Re: Pietenpol-List: Who's flying to Broadhead 07 from PA, WV, OH > > > John: > > I plan to fly MR. Hicks piet to Broadhead this year, but Missouir is a > little out of your way. But that does not mean we can not fly there > togeather. > > Chet Hartley > N920Y > ----- Original Message ----- > From: "Rock-a-Wing" <john.rocca(at)us.army.mil> > To: > Sent: Sunday, November 12, 2006 6:36 PM > Subject: Pietenpol-List: Who's flying to Broadhead 07 from PA, WV, OH > > >> >> >> Who's planning on flying their Pietenpol to Broadhead next year. God >> willing I should have my Piet ready to go and would like to make the >> trip. This would be a first time for me and I would rather fly there with >> a wingman(s) >> John >> Pittsburgh >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=73963#73963 >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Brodhead
Date: Nov 13, 2006
I will definetly be there, although I may not be flying down this year. I hope to have my new Piet done by then and hopefully will trailer it down as test flights will just be begining. Dick N. ________________________________________________________________________________
Subject: Tailwind (not Piet!)
Date: Nov 13, 2006
No, not GN-1, either! I will have to say that one of the very first issues of Sport Aviation that I ever had my hands on back in the 70s, and suddenly realized that it was possible for ordinary earthlings to build an airplane that could fly in the same airspace as certified aircraft, featured a Wittman Tailwind that was built by a gentleman with such talent and attention to detail as I had never before seen in my life. The project was described over many pages in the magazine and described how he improved a thing or two here and there, and it was a most astonishingly beautiful airplane to my little spam can eyes! I sure wish I could remember who wrote that article and built that Tailwind; I have the searchable Sport Aviation archive on CD and should just search for Tailwinds, but I remember sitting up late at night reading those first copies of Sport Aviation and marvelling at how, even just in a wishful dream, I might could... maybe... naw... me?... build and fly... a real airplane? And it could have real instruments just like real airplanes, and could fly hundreds and thousands of hours and the FAA would let you do it, here in the radio controlled states of America? Wow! Nobody ever told me! Carry on, Chuck. If I didn't dislike that oddball single/dual control yoke thing, I'd love Tailwinds all to pieces. Simple, efficient, fast, clean lines... and I did mention over on the Corvair list how I thought the Buttercup would be a marriage made in heaven with the Corvair on the nose. The Buttercup is just as nice as the Tailwind in many respects. Now back to your regularly scheduled programming. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ ________________________________________________________________________________
Subject: High Altitude Ford Performance.
Date: Nov 13, 2006
Hi, Do you seasoned Piet Pilots with Ford A power think an "A" can be modified enough to put out the power needed to fly a long fuselage Piet at it's max gross weight in the Summer out of an airport with 4,000 feet elevation? Lots of density altitude. Runway length will be plenty 5,500 feet. If so what engine and/or airframe modifications would you guys recommend? Thanks, Kevin ________________________________________________________________________________
Subject: Varnish
Date: Nov 13, 2006
Hey Chuck G. I noticed on your webpage you used ACE brand Spar Varnish. How did it hold up to the covering chemicals? Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ________________________________________________________________________________
Date: Nov 14, 2006
Subject: Re: Varnish
In a message dated 11/13/2006 10:55:35 PM Central Standard Time, catdesigns(at)comcast.net writes: I noticed on your webpage you used ACE brand Spar Varnish. How did it hold up to the covering chemicals? No problems, Chris. I included the part number there, too. Just allow it to cure 100%...maybe a couple of days. I use it exclusively to protect all the wood, even the prop. However, the last time I reworked my prop, I used West System Epoxy / Fiberglass, to protect the prop. Chuck G. NX770CG p.s. You've got a great web site there !! ________________________________________________________________________________
Date: Nov 14, 2006
Subject: Re: Tailwind (not Piet!)
In a message dated 11/13/2006 9:06:30 PM Central Standard Time, taildrags(at)hotmail.com writes: Carry on, Chuck. If I didn't dislike that oddball single/dual control yoke thing, I'd love Tailwinds all to pieces. Simple, efficient, fast, clean lines... and I did mention over on the Corvair list how I thought the Buttercup would be a marriage made in heaven with the Corvair on the nose. The Buttercup is just as nice as the Tailwind in many respects. C'mon Oscar !! That oddball single / duel control yoke speaks volumes about simplicity !! Another very interesting aspect of the Tailwind, is how the leading edge of the wing is designed. The inboard portion of the wing angles back in to the fuselage, and at high angle of attack, allows air to spill over, and accelerate, over the top of the fuselage, which then the fuselage actually becomes more of a lifting body, and reduces wing tip vortices. This is how he designed a high speed airplane, with very gentle stall characteristics. Just before his demise, Steve Wittman was working on incorporating that movable leading edge concept (ala Buttercup wing) to the Tailwind wing. Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 13, 2006
Subject: Re: High Altitude Ford Performance.
You need to see this; http://users.aol.com/gmaclaren/dyno.html Also understand that reliability is inversly propotional to any hotrodding one does. Clif ----- Original Message ----- From: Kevin Ross To: pietenpol-list(at)matronics.com Sent: Monday, November 13, 2006 7:11 PM Subject: Pietenpol-List: High Altitude Ford Performance. Hi, Do you seasoned Piet Pilots with Ford A power think an "A" can be modified enough to put out the power needed to fly a long fuselage Piet at it's max gross weight in the Summer out of an airport with 4,000 feet elevation? Lots of density altitude. Runway length will be plenty 5,500 feet. If so what engine and/or airframe modifications would you guys recommend? Thanks, Kevin ------------------------------------------------------------------------- ----- 11/13/2006 ________________________________________________________________________________
Subject: Chris Tracy's website
Date: Nov 14, 2006
>Chris Tracy >Sacramento, Ca >Website at http://www.Westcoastpiet.com Chuck wrote- >p.s. You've got a great web site there !! Man, it is a great site! Lots and lots of good pictures there. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Find a local pizza place, music store, museum and morethen map the best route! http://local.live.com?FORM=MGA001 ________________________________________________________________________________
Subject: Re: Chris Tracy's website
Date: Nov 14, 2006
We echo Oscar and Chuck's thoughts on this website. The pictures are worth a zillion words! No Piet builder should be without it! Don't archive Lynn & Kevin Knoll Wichita Piet/Vair in the works ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Tuesday, November 14, 2006 9:08 AM Subject: Pietenpol-List: Chris Tracy's website >Chris Tracy >Sacramento, Ca >Website at http://www.Westcoastpiet.com Chuck wrote- >p.s. You've got a great web site there !! Man, it is a great site! Lots and lots of good pictures there. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Find a local pizza place, music store, museum and more.then map the best route! http://local.live.com?FORM=MGA001 ________________________________________________________________________________
Date: Nov 14, 2006
I just have to add my "WOW" Gene N502R ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Tuesday, November 14, 2006 9:08 AM Subject: Pietenpol-List: Chris Tracy's website > > >>Chris Tracy >>Sacramento, Ca >>Website at http://www.Westcoastpiet.com > > Chuck wrote- >>p.s. You've got a great web site there !! > > Man, it is a great site! Lots and lots of good pictures there. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > Find a local pizza place, music store, museum and more.then map the best > route! http://local.live.com?FORM=MGA001 > > > ________________________________________________________________________________
Date: Nov 14, 2006
Thanks for all your comments on the website. Not having any other builders near by I have had to rely on the others to post pictures of their planes so I know how important they are. Now, all you builders and flyer of Pietenpol's, and even you Grega guys, send me your pictures and I will add them to the site as time allows, I am after all trying to build an airplane you know. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ________________________________________________________________________________
Date: Nov 14, 2006
One more thing about the website. Recently I added some pictures of the second Pietenpol I have ever seen. (Caution lots of thumbnail pictures and may load slow on dial-up) http://westcoastpiet.com/new_page_24.htm At first glance, due to the location of the landing gear, it looks like a Grega but it is not. It's a Piet. The builders used gear legs from a Tri Pacer turned around backwards and shortened. This necessitated the relocation of the rear landing gear mount. I think the wing struts are also from a Tri Pacer. They also rounded off the nose of the airfoil because an aerodynamicist friend told them it would stall better. They said it flew quite nicely. but have only 20hr on the plane so no details on the performance. http://westcoastpiet.com/images/O'Hara-Howe/IMG_3042.JPG They raised the wing a couple of inches which caused the angles of the lower strut attachment fittings to be off. As the plane was finished and covered before they discovered this they had to make up these metal wedges to compensate. http://westcoastpiet.com/images/O'Hara-Howe/IMG_3032.JPG I think it's a common mod to raise the wing a couple of inches so watch out for this if you still building. One of the things I thought was a good idea was this brace under the rudder bar . http://westcoastpiet.com/images/O'Hara-Howe/IMG_3105.JPG It is topped with some plastic so it slides easily. There is one on both side and really makes it feel nice an stable, no wobble at all. It also has a block on top to act as a rudder stop. In one of the pictures you will see a black tile, it's from the Space Shuttle. I guess it's there to remind them about the glide ration if you loose your engine. They also have a piece of spruce from the Spruce Goose but I cant remember where it's located. They also have this on the front of the cowling, http://westcoastpiet.com/images/O'Hara-Howe/IMG_3048.JPG and it struck me as quite appropriate for a Piet. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ________________________________________________________________________________
Date: Nov 15, 2006
Subject: LOC
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2006
Subject: Re: LOC
I have unsucessfully tried to unsuscribe to the list, I would appreciate you help. Sold the Pietenpol. Thanks Lou Wither ________________________________________________________________________________
Subject: FUSELAGE LENGTHS
Date: Nov 15, 2006
Thanks, Skip. Your describing the various Pietenpol fuselages is exactly what was wanted. Now to work. Bill Weir ________________________________________________________________________________
Date: Nov 15, 2006
Subject: need advise this is way off topic
Hello Piet'ers, Ben up here in St. Cloud, MN. First I want say that I committed a sin. I destroyed that fuselage that I had started in the name of building a cub replica. But I need some moral guidence and I thought I would turn to this list for help. Me and a friend by the name of Robb are trying to get started on a J-3 cub from Plans that I bought from Light Miniature aircraft. this past weekend we tried to align everything up and the plans would not match up. Yes these are full scale plans you build on top of. After trying to get help from a number of people my questions are not getting answered just more bewilderment. So right now me and my dad are in the process of redrawing everything. The other choice I have is to scrap this project and build the aircamper which I have a lot of knowledge of becuase since 1996 when me and dad got plans from Orrin Hoopman my dad has been trying to get something flying, but nothing comes of it. So I need help and a little guidence. I know this forum is less hostile. sorry for this off topic but I just don't know where else to go and ask! take Care, Ben Ramler Sponsored Link Mortgage rates near 39yr lows. $420k for $1,399/mo. Calculate new payment! www.LowerMyBills.com/lre ________________________________________________________________________________
Date: Nov 15, 2006
ben_ramler2002(at)yahoo.com wrote: >So I need help and a little guidence. I know this forum is less hostile. Yes, this forum is less hostile but it will not lead you to: -a glass cockpit with IFR capabilities and full electric system; -an airplane that cruises in the triple digits; -redundant systems; -an airplane with an enclosed cockpit and cabin heat; -an airplane with a $15,000 engine; -something you build from parts that you took out of a big box -paint jobs that cost more than the airplane. If any of your goals for building or flying include the above, you probably won't find it here. Ben, you need to go out to an airport on a nice Saturday and watch the airplanes fly, peek into hangars, look at airplanes that are sitting on the ramp, and find one that grabs you. One that you like, one that sounds nice, one that smells nice, one that you want to get into and fly. That's the one you want to work on because it has to grab you in the heart first. A roll of plans won't do it, and neither will an advertisement or a price tag or a pretty paint job. The airplane has to give you "the wink", like a pretty girl does, and not just one that's wearing a lot of makeup and a short skirt. When you get "the wink" and your heart skips, that's your girl... and your airplane. Since you're here on the Pietenpol list, I think an old wood-and-fabric airplane already gave you "the wink". I'll bet there are a good bunch of people in Minnesota who are building or flying Pietenpols that you can look at, smell, listen to, and maybe fly in. Maybe somebody here on the list will hook up with you to see if the Aircamper is "the girl next door" for you. If so, don't expect to do anything in a big hurry... building, flying, or anything else. We don't move too fast here but that's half the fun. Guys that are in a hurry tend to pass by the girl without even noticing "the wink" ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get free, personalized commercial-free online radio with MSN Radio powered by Pandora http://radio.msn.com/?icid=T002MSN03A07001 ________________________________________________________________________________
Subject: Re: need advise this is way off topic
Date: Nov 15, 2006
Hi Ben, Come to Stanton (SYN) next year when the flying weather returns. I will give you a ride in NX18235 (see attached pictures) to give you a taste of flying a Pietenpol. Forget the LMA Cub, no one will give it a second look on the flightline. If you come to Stanton on Father's Day for the annual fly-in you will see hundreds of people walking past Stearmans, Cubs, Waco's, Ercoupes, the usual throng of RV's, Pitts', Howards and many other types as they flock to the Pietenpol to look at it closely. Old men look at it with a gleam in their eyes, kids want to sit in it and woman think it is the "cutest plane ever". To most people big biplanes are intimidating and enclosed cabin airplanes are uninviting. The diminutive Pietenpol with it's open cockpits literally screams "Come and look at me!" People who know nothing about airplanes are drawn to it like moths to a flame. At the end of the day you will be hoarse from answering questions about your plane. Fly-in organizers will ask you to bring your Pietenpol to their airport fly-ins. Owners of private airstrips will literally beg you to land at their strip any time you want. Two weeks ago I took the plane up for the last flight of the season. 70 degrees, sunny and light winds. A perfect day. Lots of farmers in their fields with tractors and combines. With my leather helmet, goggles and silk scarf it was too easy to pretend the farmers and their machines were the mechanized division of the German Wehrmacht. Strafing runs were the order of the day. The crossed cabane cables made a perfect gunsight. Swooping in and out of the Cannon River ravines, dodging red-tailed hawks and just flying for the pure fun of it. I only landed because my gas was getting low. I had a silly grin on my face for two days. Build the Pietenpol. YOU WILL NOT REGRET THE DECISION! Greg Cardinal Minneapolis From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> > > Hello Piet'ers, > > Ben up here in St. Cloud, MN. First I want say that I committed a sin. I > destroyed that fuselage that I had started in the name of building a cub > replica. But I need some moral guidence and I thought I would turn to this > list for help. Me and a friend by the name of Robb are trying to get > started on a J-3 cub from Plans that I bought from Light Miniature > aircraft. this past weekend we tried to align everything up and the plans > would not match up. Yes these are full scale plans you build on top of. > After trying to get help from a number of people my questions are not > getting answered just more bewilderment. So right now me and my dad are in > the process of redrawing everything. The other choice I have is to scrap > this project and build the aircamper which I have a lot of knowledge of > becuase since 1996 when me and dad got plans from Orrin Hoopman my dad has > been trying to get something flying, but nothing comes of it. So I need > help and a little guidence. I know this forum is! > less hostile. > > sorry for this off topic but I just don't know where else to go and ask! > > > take Care, > > Ben Ramler > ________________________________________________________________________________
Subject: Oklahoma Fly-in
Date: Nov 15, 2006
I am having a fly-in this weekend at O44 (Oscar44) south of Norman, OK. Everyone is welcome...its a good 'ol grass strip where my plane is based. We'll have BBQ and a good time. More details here: http://www.wotelectronics.com/flyin/ Steve Ruse Norman, OK -- No virus found in this outgoing message. ________________________________________________________________________________
Subject: Piet & Vimy Ridge Documentary followup
Date: Nov 16, 2006
The film is a documentary on the 3 dimensions (air, ground, and undeground) that the Canadian Forces used at the Battle of Vimy Ridge on April 9 - 12, 1917. The documentary will focus on the underground tunnels that were used to house troops, move in supplies, and undermine with explosive the german trenches. The ground war of infantry and artillery. And the aerial war displaying how aircraft were used to spot and direct artillery fire by morse code back to the allied lines. The filming consisted of ground to air, air to air with a camera mounted on a helicopter. A camera in the front seat, and a camera mounted on the front cabane & wing struts shooting back toward both seat positions with the ground in the background. I have seen the raw footage taken, and with the very high quality equipment the filming is fantastic. I'm sure once the editors do there magic, the film will have some incredible flying sequences. Since it's a documentary, the producers were comfortable with using the Pietenpol. The likely original aircraft was a BE-2, of which there are none airworthy in the world anymore. Or a Sopwith 1/2 Strutter. And the only flying one in Canada had a recent engine failure. At least the Pietenpol does have the open cockpit, and speed range that the original types would have had. It was about -6C during the filming, and this would have been very similar to actual conditions on the days of the original battle. The film is a 90 minute special that will debut on the 'History Channel' in Canada on April 9th 2007. On the 90th anniversary of the battle. Unfortunately for you all south of the border, I have no idea if this film will be broadcasted in the USA. I will be getting a personal copy of the film. And either myself or someone else from my home field will take a copy to Broadhead with them. Shawn Wolk C-FRAZ 1933 Pietenpol Aircamper Winnipeg, MB ________________________________________________________________________________
Date: Nov 16, 2006
Hi Oscar, Greg, and Group, my main to goal is to go flying! IFR and all that other stuff is so over rated it's not even funny. A simple airplane is all I need. and my friend to. I have done a lot of sitting at airports lately. Plus I've been to broadhead with my dad back in 1996 or 1997 don't remember which. ----- Original Message ---- From: Oscar Zuniga <taildrags(at)hotmail.com> Sent: Wednesday, November 15, 2006 9:35:45 PM Subject: Pietenpol-List: need advise this is way off topic ben_ramler2002(at)yahoo.com wrote: >So I need help and a little guidence. I know this forum is less hostile. Yes, this forum is less hostile but it will not lead you to: -a glass cockpit with IFR capabilities and full electric system; -an airplane that cruises in the triple digits; -redundant systems; -an airplane with an enclosed cockpit and cabin heat; -an airplane with a $15,000 engine; -something you build from parts that you took out of a big box -paint jobs that cost more than the airplane. If any of your goals for building or flying include the above, you probably won't find it here. Ben, you need to go out to an airport on a nice Saturday and watch the airplanes fly, peek into hangars, look at airplanes that are sitting on the ramp, and find one that grabs you. One that you like, one that sounds nice, one that smells nice, one that you want to get into and fly. That's the one you want to work on because it has to grab you in the heart first. A roll of plans won't do it, and neither will an advertisement or a price tag or a pretty paint job. The airplane has to give you "the wink", like a pretty girl does, and not just one that's wearing a lot of makeup and a short skirt. When you get "the wink" and your heart skips, that's your girl... and your airplane. Since you're here on the Pietenpol list, I think an old wood-and-fabric airplane already gave you "the wink". I'll bet there are a good bunch of people in Minnesota who are building or flying Pietenpols that you can look at, smell, listen to, and maybe fly in. Maybe somebody here on the list will hook up with you to see if the Aircamper is "the girl next door" for you. If so, don't expect to do anything in a big hurry... building, flying, or anything else. We don't move too fast here but that's half the fun. Guys that are in a hurry tend to pass by the girl without even noticing "the wink" ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get free, personalized commercial-free online radio with MSN Radio powered by Pandora http://radio.msn.com/?icid=T002MSN03A07001 Sponsored Link Mortgage rates near 39yr lows. $420k for $1,399/mo. Calculate new payment! www.LowerMyBills.com/lre ________________________________________________________________________________
Date: Nov 16, 2006
Well, not to mess things up too much...but if all you want to do is go flying, a homebuilt like a Piet may only frustrate you. Consider what a lot of other homebuilders have done: Buy an old Champ, Cessna 120, 150 or similar so you can "go flying".....while you make sawdust building that Air Camper! I wouldn't dream of trying to change your focus.....but "plans built" homebuilding projects won't scratch that itch for you....for a LONG time! Actually, as I sit here looking out the window at a beautiful clear blue sky....all I want to do is go flying!!!! Jim in (kinda) cold NE Oklahoma..... -----Original Message----- >From: Ben Ramler <ben_ramler2002(at)yahoo.com> >Sent: Nov 16, 2006 10:19 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: need advise this is way off topic > > >Hi Oscar, Greg, and Group, > > my main to goal is to go flying! IFR and all that other stuff is so over rated it's not even funny. A simple airplane is all I need. and my friend to. I have done a lot of sitting at airports lately. Plus I've been to broadhead with my dad back in 1996 or 1997 don't remember which. ________________________________________________________________________________
Date: Nov 16, 2006
but jim do realize how much a 150 or a champ goes for..........way to much! Its easier for me to build then go flying! Besides sawdust is fun! Ben R St. Cloud, MN ----- Original Message ---- From: Jim Markle <jim_markle(at)mindspring.com> Sent: Thursday, November 16, 2006 10:50:05 AM Subject: Re: Pietenpol-List: need advise this is way off topic Well, not to mess things up too much...but if all you want to do is go flying, a homebuilt like a Piet may only frustrate you. Consider what a lot of other homebuilders have done: Buy an old Champ, Cessna 120, 150 or similar so you can "go flying".....while you make sawdust building that Air Camper! I wouldn't dream of trying to change your focus.....but "plans built" homebuilding projects won't scratch that itch for you....for a LONG time! Actually, as I sit here looking out the window at a beautiful clear blue sky....all I want to do is go flying!!!! Jim in (kinda) cold NE Oklahoma..... -----Original Message----- >From: Ben Ramler <ben_ramler2002(at)yahoo.com> >Sent: Nov 16, 2006 10:19 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: need advise this is way off topic > > >Hi Oscar, Greg, and Group, > > my main to goal is to go flying! IFR and all that other stuff is so over rated it's not even funny. A simple airplane is all I need. and my friend to. I have done a lot of sitting at airports lately. Plus I've been to broadhead with my dad back in 1996 or 1997 don't remember which. ________________________________________________________________________________
Date: Nov 16, 2006
Some of us are builders and some are flyers and some are both.I come under the second category.I bought a Piet that was just about finished hoping I could get airborn ASAP.As it turned out it took longer than I figured and I almost gave up on the project.I kept going because of this web page.It gave me what I needed and I'm not just talking about information.There is a spirit here you can't explain.I love to fly my Piet now but Jim has a point here;if your not a builder then stay away from it because it will drive you nuts.Good luck in what ever you do. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: November 16, 2006 11:50 AM Subject: Re: Pietenpol-List: need advise this is way off topic Well, not to mess things up too much...but if all you want to do is go flying, a homebuilt like a Piet may only frustrate you. Consider what a lot of other homebuilders have done: Buy an old Champ, Cessna 120, 150 or similar so you can "go flying".....while you make sawdust building that Air Camper! I wouldn't dream of trying to change your focus.....but "plans built" homebuilding projects won't scratch that itch for you....for a LONG time! Actually, as I sit here looking out the window at a beautiful clear blue sky....all I want to do is go flying!!!! Jim in (kinda) cold NE Oklahoma..... -----Original Message----- >From: Ben Ramler <ben_ramler2002(at)yahoo.com> >Sent: Nov 16, 2006 10:19 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: need advise this is way off topic > > >Hi Oscar, Greg, and Group, > > my main to goal is to go flying! IFR and all that other stuff is so over rated it's not even funny. A simple airplane is all I need. and my friend to. I have done a lot of sitting at airports lately. Plus I've been to broadhead with my dad back in 1996 or 1997 don't remember which. ________________________________________________________________________________
Date: Nov 16, 2006
Ben, here's an idea for you. Pietenpoler Carl Vought died recently and left two very nice Piet projects uncompleted, both for sale. Buy one and you're 75% on the way to flying but can still enjoy completing the construction process on an above-average workmanship project. There is info available on the person who is handling inquiries on the projects and materials for Carl's widow, Barbara. The projects are in northern Alabama. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get FREE company branded e-mail accounts and business Web site from Microsoft Office Live ________________________________________________________________________________
Date: Nov 16, 2006
Ben, There's a really nice O-200 piet currently up for sale on Barnstormers. http://www.barnstormers.com/cat.php?PHPSESSID=b57446cc465a6aeefe8ef51821bb0929 Get a partner to share the cost of the bird and the hangar rent. You could be flying RIGHT away! Greg Bacon Mtn. Piet Repairman Prairie Home, MO ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Thursday, November 16, 2006 11:19 AM Subject: Re: Pietenpol-List: need advise this is way off topic > > > but jim do realize how much a 150 or a champ goes for..........way to > much! Its easier for me to build then go flying! Besides sawdust is fun! > > Ben R > > St. Cloud, MN > > ----- Original Message ---- > From: Jim Markle <jim_markle(at)mindspring.com> > To: pietenpol-list(at)matronics.com > Sent: Thursday, November 16, 2006 10:50:05 AM > Subject: Re: Pietenpol-List: need advise this is way off topic > > > > > Well, not to mess things up too much...but if all you want to do is go > flying, a homebuilt like a Piet may only frustrate you. > > Consider what a lot of other homebuilders have done: Buy an old Champ, > Cessna 120, 150 or similar so you can "go flying".....while you make > sawdust building that Air Camper! > > I wouldn't dream of trying to change your focus.....but "plans built" > homebuilding projects won't scratch that itch for you....for a LONG time! > > Actually, as I sit here looking out the window at a beautiful clear blue > sky....all I want to do is go flying!!!! > > Jim in (kinda) cold NE Oklahoma..... > > > -----Original Message----- >>From: Ben Ramler <ben_ramler2002(at)yahoo.com> >>Sent: Nov 16, 2006 10:19 AM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: need advise this is way off topic >> >> >> >>Hi Oscar, Greg, and Group, >> >> my main to goal is to go flying! IFR and all that other stuff is so over >> rated it's not even funny. A simple airplane is all I need. and my friend >> to. I have done a lot of sitting at airports lately. Plus I've been to >> broadhead with my dad back in 1996 or 1997 don't remember which. > > > ________________________________________________________________________________
Date: Nov 17, 2006
Subject: List Value...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least 0 or 0 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that same amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... Won't you please take a minute to make your Contribution today and support YOUR Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 17, 2006
Nice but neither me or Robb have the money, besides I have corvair enigne already! ----- Original Message ---- From: Greg Bacon <gbacon67(at)hughes.net> Sent: Thursday, November 16, 2006 8:42:49 PM Subject: Re: Pietenpol-List: need advise this is way off topic Ben, There's a really nice O-200 piet currently up for sale on Barnstormers. http://www.barnstormers.com/cat.php?PHPSESSID=b57446cc465a6aeefe8ef51821bb0929 Get a partner to share the cost of the bird and the hangar rent. You could be flying RIGHT away! Greg Bacon Mtn. Piet Repairman Prairie Home, MO ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Thursday, November 16, 2006 11:19 AM Subject: Re: Pietenpol-List: need advise this is way off topic > > > but jim do realize how much a 150 or a champ goes for..........way to > much! Its easier for me to build then go flying! Besides sawdust is fun! > > Ben R > > St. Cloud, MN > > ----- Original Message ---- > From: Jim Markle <jim_markle(at)mindspring.com> > To: pietenpol-list(at)matronics.com > Sent: Thursday, November 16, 2006 10:50:05 AM > Subject: Re: Pietenpol-List: need advise this is way off topic > > > > > Well, not to mess things up too much...but if all you want to do is go > flying, a homebuilt like a Piet may only frustrate you. > > Consider what a lot of other homebuilders have done: Buy an old Champ, > Cessna 120, 150 or similar so you can "go flying".....while you make > sawdust building that Air Camper! > > I wouldn't dream of trying to change your focus.....but "plans built" > homebuilding projects won't scratch that itch for you....for a LONG time! > > Actually, as I sit here looking out the window at a beautiful clear blue > sky....all I want to do is go flying!!!! > > Jim in (kinda) cold NE Oklahoma..... > > > -----Original Message----- >>From: Ben Ramler <ben_ramler2002(at)yahoo.com> >>Sent: Nov 16, 2006 10:19 AM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: need advise this is way off topic >> >> >> >>Hi Oscar, Greg, and Group, >> >> my main to goal is to go flying! IFR and all that other stuff is so over >> rated it's not even funny. A simple airplane is all I need. and my friend >> to. I have done a lot of sitting at airports lately. Plus I've been to >> broadhead with my dad back in 1996 or 1997 don't remember which. > > > ________________________________________________________________________________
Date: Nov 17, 2006
yeah! how much! remember niether robb or me don't have alot of money. ----- Original Message ---- From: Oscar Zuniga <taildrags(at)hotmail.com> Sent: Thursday, November 16, 2006 8:00:23 PM Subject: Pietenpol-List: need advise this is way off topic Ben, here's an idea for you. Pietenpoler Carl Vought died recently and left two very nice Piet projects uncompleted, both for sale. Buy one and you're 75% on the way to flying but can still enjoy completing the construction process on an above-average workmanship project. There is info available on the person who is handling inquiries on the projects and materials for Carl's widow, Barbara. The projects are in northern Alabama. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get FREE company branded e-mail accounts and business Web site from Microsoft Office Live http://new.mail.yahoo.com ________________________________________________________________________________
Subject: The correct spelling is advice.....
Date: Nov 17, 2006
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Well I had to say something......plus hopefully start some controversy to get the list talking again ! :))) Ben says that he wants to fly right now and I think we can all relate to that. Many of us can relate to that desire from when we were very young---in my case around 6 years old. I flew kites, rubber band models, control line Cox models, Estes rockets, our parents large patio umbrella off the roof of our garage when they weren't home and of course blowing up old airplane models with firecrackers......but it took me until I was 29 years old before I had enough money to put down $ 3,500 on 1/2 ownership in an Aeronca Champ. Now 1/2 ownership in a Champ is about $ 12,500 so I can understand where Ben is coming from so do the decent thing and BEG for a ride or hunt around and find a CFI that will let you ride with him in the back seat while he is giving lessons in a 172. There are ways to fly now, cheap..but you have to be a scrapper and be resourceful---just like when you build a non-kit airplane like a Pietenpol. Mike C. ________________________________________________________________________________
Date: Nov 17, 2006
I bought a Lazair ultralight back in the mid 80's for 5000$.Put a 77 Impala up for collateral.My wife was pissed.Still is.I'm sorry but I have to fly!I had to sell the Lazair in the mid 90's to pay of some debt but in 2000 I bought an N3 pup for 9000$ then the Piet came up for sale for 10,000$.I told my wife,listen it's too good a deal to pass up.She's still mad.I have two planes and she's still pissed.I wish I'd kept the Lazair too and then I'd have three planes and then everybody could be mad at me but I'd still be flyin!If you really want to fly ,you'll find a way even if it means getting everybody mad at you.Put the house up for collateral,the car,the wife, what ever! ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC] Sent: November 17, 2006 1:23 PM Subject: Pietenpol-List: The correct spelling is advice..... Well I had to say something......plus hopefully start some controversy to get the list talking again ! :))) Ben says that he wants to fly right now and I think we can all relate to that. Many of us can relate to that desire from when we were very young---in my case around 6 years old. I flew kites, rubber band models, control line Cox models, Estes rockets, our parents large patio umbrella off the roof of our garage when they weren't home and of course blowing up old airplane models with firecrackers......but it took me until I was 29 years old before I had enough money to put down $ 3,500 on 1/2 ownership in an Aeronca Champ. Now 1/2 ownership in a Champ is about $ 12,500 so I can understand where Ben is coming from so do the decent thing and BEG for a ride or hunt around and find a CFI that will let you ride with him in the back seat while he is giving lessons in a 172. There are ways to fly now, cheap..but you have to be a scrapper and be resourceful---just like when you build a non-kit airplane like a Pietenpol. Mike C. ________________________________________________________________________________
Date: Nov 17, 2006
Subject: Re:More advice on cheap flying
Cuy, Michael D. (GRC-RXD0)[ASRC] wrote: > Well I had to say something......plus hopefully start some controversy > to get the list talking again ! :))) > Hi all, There is a guy in our local EAA chapter that just finished a beautiful Pietenpol. He hadn't flown in a long time and is now taking some lessons with another club member in a J-3. His plane has flown a couple of times, but not with him at the controls. I'm still a few years away from that moment, but I decided that I didn't want to have to stand on the side of the runway while a friend of mine did the first flight. Another club member is retiring from flying and had an old Corben Baby Ace for sale at a great price. Another club member is in the process of getting me a taildragger endorsement and some currency so I can get some liability insurance. I have a Private ticket, and am going to fly sport pilot. If all goes well, I should have the airplane in my posession in a few weeks, and be ready to fly the Fly Baby in January of February. It has a Continental A75 with about 100 hours SMOH, 78/80 compression on all 4 cylinders and a fresh annual. It isn't much to look at, but its open cockpit and probably will fly very similar to a Piet. Maybe I just got lucky, but I would suggest joining your local EAA chapter, hang out at the local airport as much as you have time, andget all the building advice you can from all the members and the EAA Tech counselors ( my tech advisor was the one that knew about the plane for sale) Building a Pietenpol is a lot of fun, but not the cheapest or fastest way to get in the air, although you can spread the payments out over 5-10 years if you need to! Ben Charvet Mims, Fl ________________________________________________________________________________
Subject: Re: The correct spelling is advice.....
Date: Nov 17, 2006
I guess I just don't understand.... How about getting the money to fly the old fashion way? Get a second job and save til you have the money. Question. If you don't have the money (or can't earn it) how are you going to pay for the Hanger, the gas and up keep? I don't want to be negative but let's be honest. It costs a lot to fly and the money has to come from some where. Buying the plane is only one part of ownership. My wife and my motto is "If you don't dream, dreams can't come true." We've done a lot of crazy things, such as cruising and living on a sail boat for 12 years in the Pacific. A dream come true? Yes, but not without one hell of a lot of work, doing a whole bunch of job I didn't want to do. It sure was worth it. I'm retired now but still work one day a week, just so I can keep flying. Ain't no one else going to do it for me. Gene N502R --- Original Message ----- From: harvey.rule(at)bell.ca To: pietenpol-list(at)matronics.com Sent: Friday, November 17, 2006 12:37 PM Subject: RE: Pietenpol-List: The correct spelling is advice..... I bought a Lazair ultralight back in the mid 80's for 5000$.Put a 77 Impala up for collateral.My wife was pissed.Still is.I'm sorry but I have to fly!I had to sell the Lazair in the mid 90's to pay of some debt but in 2000 I bought an N3 pup for 9000$ then the Piet came up for sale for 10,000$.I told my wife,listen it's too good a deal to pass up.She's still mad.I have two planes and she's still pissed.I wish I'd kept the Lazair too and then I'd have three planes and then everybody could be mad at me but I'd still be flyin!If you really want to fly ,you'll find a way even if it means getting everybody mad at you.Put the house up for collateral,the car,the wife, what ever! ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC] Sent: November 17, 2006 1:23 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: The correct spelling is advice..... Well I had to say something......plus hopefully start some controversy to get the list talking again ! :))) Ben says that he wants to fly right now and I think we can all relate to that. Many of us can relate to that desire from when we were very young---in my case around 6 years old. I flew kites, rubber band models, control line Cox models, Estes rockets, our parents large patio umbrella off the roof of our garage when they weren't home and of course blowing up old airplane models with firecrackers......but it took me until I was 29 years old before I had enough money to put down $ 3,500 on 1/2 ownership in an Aeronca Champ. Now 1/2 ownership in a Champ is about $ 12,500 so I can understand where Ben is coming from so do the decent thing and BEG for a ride or hunt around and find a CFI that will let you ride with him in the back seat while he is giving lessons in a 172. There are ways to fly now, cheap..but you have to be a scrapper and be resourceful---just like when you build a non-kit airplane like a Pietenpol. Mike C. www.aeroelectric.comwww.kitlog.comhttp://www.matronics.com/Navigator?Piet enpol-List ________________________________________________________________________________
Subject: sounds like
Date: Nov 17, 2006
you need to get rid of your wife, Harvey:)) Mike C. ________________________________________________________________________________
Date: Nov 17, 2006
________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Friday, November 17, 2006 2:18 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: The correct spelling is advice..... I guess I just don't understand.... How about getting the money to fly the old fashion way? Get a second job and save til you have the money. Question. If you don't have the money (or can't earn it) how are you going to pay for the Hanger, the gas and up keep? I don't want to be negative but let's be honest. It costs a lot to fly and the money has to come from some where. Buying the plane is only one part of ownership. My wife and my motto is "If you don't dream, dreams can't come true." We've done a lot of crazy things, such as cruising and living on a sail boat for 12 years in the Pacific. A dream come true? Yes, but not without one hell of a lot of work, doing a whole bunch of job I didn't want to do. It sure was worth it. I'm retired now but still work one day a week, just so I can keep flying. Ain't no one else going to do it for me. Gene N502R --- Original Message ----- From: harvey.rule(at)bell.ca To: pietenpol-list(at)matronics.com Sent: Friday, November 17, 2006 12:37 PM Subject: RE: Pietenpol-List: The correct spelling is advice..... I bought a Lazair ultralight back in the mid 80's for 5000$.Put a 77 Impala up for collateral.My wife was pissed.Still is.I'm sorry but I have to fly!I had to sell the Lazair in the mid 90's to pay of some debt but in 2000 I bought an N3 pup for 9000$ then the Piet came up for sale for 10,000$.I told my wife,listen it's too good a deal to pass up.She's still mad.I have two planes and she's still pissed.I wish I'd kept the Lazair too and then I'd have three planes and then everybody could be mad at me but I'd still be flyin!If you really want to fly ,you'll find a way even if it means getting everybody mad at you.Put the house up for collateral,the car,the wife, what ever! ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC] Sent: November 17, 2006 1:23 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: The correct spelling is advice..... Well I had to say something......plus hopefully start some controversy to get the list talking again ! :))) Ben says that he wants to fly right now and I think we can all relate to that. Many of us can relate to that desire from when we were very young---in my case around 6 years old. I flew kites, rubber band models, control line Cox models, Estes rockets, our parents large patio umbrella off the roof of our garage when they weren't home and of course blowing up old airplane models with firecrackers......but it took me until I was 29 years old before I had enough money to put down $ 3,500 on 1/2 ownership in an Aeronca Champ. Now 1/2 ownership in a Champ is about $ 12,500 so I can understand where Ben is coming from so do the decent thing and BEG for a ride or hunt around and find a CFI that will let you ride with him in the back seat while he is giving lessons in a 172. There are ways to fly now, cheap..but you have to be a scrapper and be resourceful---just like when you build a non-kit airplane like a Pietenpol. Mike C. www.aeroelectric.com www.kitlog.com http://www.matronics.com/Navigator?Pietenpol-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c h ref="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr o nics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Nov 17, 2006
Here is my little insignificant story. I started a Piet about 10 or 12 years ago at my home in PA. When I opened a shop in SC, I left the Piet parts in PA and started a miniMAX at my new place in Myrtle Beach. I picked that design because it was wood, easy to build and would give me some building experience. I even milled all my own wood for it. I was about 95% done when I had to sell the Max. Meanwhile, I moved back to PA and started right in with procuring stuff for the Piet. But in the mean time, I really wanted to get in the air...cheaply. Almost by accident, while checking out Barnstormers, I hit on the powered parachute section. I saw one for $4,900.00, and bought it. I learned to fly it in about an hour and am having a blast. Sure, it is limited on what it can do, but what the heck...I'm in the air! Ron ________________________________________________________________________________
Date: Nov 17, 2006
I was going to make a similar suggestion, you don't have to buy an old certified aircraft to fly. If I wanted to have something to fly ASAP and as cheap as possible while I built my Piet I would buy a used PPC as you mentioned. No hanger rent (fits in the back of a pickup truck), maintainence as cheap as it gets, and a couple hundred bucks to learn to fly the thing versus $3500 for a Sport Pilot or $7000 for a Private Pilot license. True its not a 'real' airplane but it still get you off the ground. If I wanted something closer to a 'real' airplane and could afford more I would look for a used single place ultralight like a CGS Hawk or a Kolb (with folding wings so it will fit in my garage, wait a minute, theirs no room in my garage, I'm building my Piet in there, never mind, have to rent a hanger), no stinkin license required. Rick On 11/17/06, Pietsrneat(at)aol.com wrote: > > *Here is my little insignificant story. * > *I started a Piet about 10 or 12 years ago at my home in PA. When I opened > a shop in SC, I left the Piet parts in PA and started a miniMAX at my new > place in Myrtle Beach. I picked that design because it was wood, easy to > build and would give me some building experience. I even milled all my own > wood for it. I was about 95% done when I had to sell the Max.* > * Meanwhile, I moved back to PA and started right in with procuring > stuff for the Piet. But in the mean time, I really wanted to get in the > air...cheaply. Almost by accident, while checking out Barnstormers, I hit on > the powered parachute section. I saw one for $4,900.00, and bought it. I > learned to fly it in about an hour and am having a blast. Sure, it is > limited on what it can do, but what the heck...I'm in the air!* > *Ron* > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 17, 2006
We have a thing up here in Canada called the Quebec garage.It doesn't cost much.Its made out of an aluminum frame and covered in plastic or tarp.Just right for a small plane with fold up wings.If you took the wings off a Piet it would fit right in there and you could put the wings on either side leaning up against the walls.A lot of guys up here use them right outside their garage because,yes the garage is filled with other goodies like snow blowers and rv's and planes being built and on it goes. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: November 17, 2006 6:10 PM Subject: Re: Pietenpol-List: The correct spelling is advice..... I was going to make a similar suggestion, you don't have to buy an old certified aircraft to fly. If I wanted to have something to fly ASAP and as cheap as possible while I built my Piet I would buy a used PPC as you mentioned. No hanger rent (fits in the back of a pickup truck), maintainence as cheap as it gets, and a couple hundred bucks to learn to fly the thing versus $3500 for a Sport Pilot or $7000 for a Private Pilot license. True its not a 'real' airplane but it still get you off the ground. If I wanted something closer to a 'real' airplane and could afford more I would look for a used single place ultralight like a CGS Hawk or a Kolb (with folding wings so it will fit in my garage, wait a minute, theirs no room in my garage, I'm building my Piet in there, never mind, have to rent a hanger), no stinkin license required. Rick On 11/17/06, Pietsrneat(at)aol.com wrote: Here is my little insignificant story. I started a Piet about 10 or 12 years ago at my home in PA. When I opened a shop in SC, I left the Piet parts in PA and started a miniMAX at my new place in Myrtle Beach. I picked that design because it was wood, easy to build and would give me some building experience. I even milled all my own wood for it. I was about 95% done when I had to sell the Max. Meanwhile, I moved back to PA and started right in with procuring stuff for the Piet. But in the mean time, I really wanted to get in the air...cheaply. Almost by accident, while checking out Barnstormers, I hit on the powered parachute section. I saw one for $4,900.00, and bought it. I learned to fly it in about an hour and am having a blast. Sure, it is limited on what it can do, but what the heck...I'm in the air! Ron www.aeroelectric.com http://www.matronics.com/Navigator?Pietenpol-List -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 17, 2006
And you can put it in the trunk of a car and take it anywhere you like.You can even put in on the plane as baggage and go flyin anywhere you like.Florida,California,you name it. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Pietsrneat(at)aol.com Sent: November 17, 2006 4:53 PM Subject: Re: Pietenpol-List: The correct spelling is advice..... Here is my little insignificant story. I started a Piet about 10 or 12 years ago at my home in PA. When I opened a shop in SC, I left the Piet parts in PA and started a miniMAX at my new place in Myrtle Beach. I picked that design because it was wood, easy to build and would give me some building experience. I even milled all my own wood for it. I was about 95% done when I had to sell the Max. Meanwhile, I moved back to PA and started right in with procuring stuff for the Piet. But in the mean time, I really wanted to get in the air...cheaply. Almost by accident, while checking out Barnstormers, I hit on the powered parachute section. I saw one for $4,900.00, and bought it. I learned to fly it in about an hour and am having a blast. Sure, it is limited on what it can do, but what the heck...I'm in the air! Ron ________________________________________________________________________________
Date: Nov 17, 2006
In a message dated 11/17/2006 7:24:20 P.M. Eastern Standard Time, harvey.rule(at)bell.ca writes: And you can put it in the trunk of a car and take it anywhere you like.You can even put in on the plane as baggage and go flyin anywhere you like.Florida,California,you name it. Mine is on a 3 wheeled cart, with a steering bar, instrument panel and other little bells and whistles. Even came with 2 helmets, GPS, bazillion channel transceiver, intercom and a trailer to haul it! Ron Do not archive ________________________________________________________________________________
Date: Nov 17, 2006
Ron, Your the kinda of guy I have a great respect for. You do what what you have to do. I think flying a powered parachute would be a blast. As long as your flying,, who cares what your flying? I flew ultralights for many years and had a blast and as soon as I can afford it I will buy another one to put next to my Piet (and it just might be a powered parachute) Gene N502R ----- ( ________________________________________________________________________________
Subject: Re: Who's flying to Broadhead 07 from PA, WV, OH
Date: Nov 17, 2006
John: We are about 100 miles west of St. Louis on the Missouri river at Jefferson City, the capital of MO. As to the engine I have found that a also have a mag problem. The mag is one of the old 4000 series that they just through way. There was never any repair parts made for them. But we have modified the housing to make it bigger for the new style condenser, and have just completed that so we should be able to install the mag with in a couple of weeks and start taxi tests. Chet ----- Original Message ----- From: "Gene & Tammy" <zharvey(at)bellsouth.net> Sent: Monday, November 13, 2006 6:17 PM Subject: Re: Pietenpol-List: Who's flying to Broadhead 07 from PA, WV, OH > > > Chet, > I live in Tennessee (half way between Nashville and Memphis) and plan on > flying to Broadhead with my Piet. Where in Missouri are you? Any luck > with the engine yet? > Gene > ----- Original Message ----- > From: "Chet's Mail" <Chethartley1(at)mchsi.com> > To: > Sent: Sunday, November 12, 2006 9:35 PM > Subject: Re: Pietenpol-List: Who's flying to Broadhead 07 from PA, WV, OH > > >> >> >> John: >> >> I plan to fly MR. Hicks piet to Broadhead this year, but Missouir is a >> little out of your way. But that does not mean we can not fly there >> togeather. >> >> Chet Hartley >> N920Y >> ----- Original Message ----- >> From: "Rock-a-Wing" <john.rocca(at)us.army.mil> >> To: >> Sent: Sunday, November 12, 2006 6:36 PM >> Subject: Pietenpol-List: Who's flying to Broadhead 07 from PA, WV, OH >> >> >>> >>> >>> Who's planning on flying their Pietenpol to Broadhead next year. God >>> willing I should have my Piet ready to go and would like to make the >>> trip. This would be a first time for me and I would rather fly there >>> with a wingman(s) >>> John >>> Pittsburgh >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=73963#73963 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 18, 2006
John, Dad and I will more than likely be flying to Brodhead in 07. We fly out of OH71 wich is a private airport community in Central Ohio. It is on the Detroit Sectional chart under the name "Chapman Memorial". It is about 20-30 miles north of columbus. We would Love to join up and fly out togeather. From here it would be a 1 day all day flight. About 6-8 hrs flight time with fuel stops. On our last attempt we had about 7 hrs of flying but weather and meccanical trouble grounded us in Poplar Grove ILL.. I believe Mike C. will be flying out this year as well. Van Wert OH , in north western Oh would be a good rondevous point from our 3 home airports. It is easy to find too, Just follow US rt 30 west all the way, then continue to Chicago. Hope to join up with all you Ohio area pietenpol'ers Shad >> Who's planning on flying their Pietenpol to Broadhead next year. God >> willing I should have my Piet ready to go and would like to make the >> trip. This would be a first time for me and I would rather fly there with >> a wingman(s) >> John >> Pittsburgh , --------------------------------- ________________________________________________________________________________
Date: Nov 18, 2006
Date: Nov 18, 2006
Subject: Fuse questions...
Fellow Pieters: Question.....If you are going to build a wider fuselage would you build it 3" or 4" wider? Also, are they going to be any major changes is the structural integrity, rigging etc.... Lastly, for a guy who is 6'0 and 254lbs....is the current size of the plane comfortable? what modification if any have you made to improve function and comfort of this plane design. Ken H. Fargo, ND --------------------------------- Mortgage rates as low as 4.625% - $150,000 loan for $579 a month. Intro-*Terms ________________________________________________________________________________
Date: Nov 18, 2006
Subject: Re: Fuse questions...
Would highly recommend building a mock cockpit out of scrap wood first as discussed in the Bengelis books. Will answer all these questions and you will learn a lot which will make your fuselage go together easier with less mistakes. I ended up making mine two inches wider, leaned the seat back two inches, and raised the turtle decks a couple also. Also helps you figure the best places for controls, cables, and etc. Rick On 11/18/06, KMHeide wrote: > > Fellow Pieters: > > Question.....If you are going to build a wider fuselage would you build it > 3" or 4" wider? Also, are they going to be any major changes is the > structural integrity, rigging etc.... Lastly, for a guy who is 6'0 and > 254lbs....is the current size of the plane comfortable? what modification if > any have you made to improve function and comfort of this plane design. > > Ken H. > Fargo, ND > > Mortgage rates as low as 4.625% - $150,000 loan for $579 a month. > Intro-*Terms > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 18, 2006
Absolutely no one that is much bigger than I can get into my cockpit and be at all comfortable.I did not build the plane and I am happy to say that I lucked out on it because I just fit in comfortably and I didn't even try to get in until long after I had bought the aircraft.Something for buyers to be wary of when looking out there.By the way I am 5'4" and weigh 207 lbs at this time.Heavy, yes and fully aware of that point and loosing weight since October when I weighed 222 lbs.The hard or impossible part for anyone taller than I is to get the knees past the instrument panel.It is built like a fighter plane and very compact.I have noticed that I will have to tilt my instrument panel back or pull the bottom out about an inch or two in order to see the instruments properly.I am too high in the torso to see it the way I should.Part of a project for next spring as well as adding a temperature gauge to one of my cylinder heads.I also found out that my altimeter gauge is busted so I have to replace that as well.I also have acquired an electrical clock for an aircraft which I will install with a switch to the battery .I think it would also be a good idea to install a secondary switch under the instrument panel out of sight in order to defeat the starter button.You know how people are at flyins.They like to push buttons and throw switch and if the right switches are thrown and the proper button is pushed and someone is near the prop then someone may loose a head or some other part of their anatomy and that would be tragic.Not to mention the law suit that would incure. One of the problems of having an electric start in an open cockpit.No door to lock. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide Sent: November 18, 2006 4:42 PM Subject: Pietenpol-List: Fuse questions... Fellow Pieters: Question.....If you are going to build a wider fuselage would you build it 3" or 4" wider? Also, are they going to be any major changes is the structural integrity, rigging etc.... Lastly, for a guy who is 6'0 and 254lbs....is the current size of the plane comfortable? what modification if any have you made to improve function and comfort of this plane design. Ken H. Fargo, ND Mortgage rates as low as 4.625% - $150,000 loan for $579 a month. Intro-*Terms ________________________________________________________________________________
Subject: Rotec piet
Date: Nov 18, 2006
As things are a bit slow on the list, here is an update on my new Piet. The tail is finished with the special batch of Poly Tone that Stits made for me. I wanted it to look like leather stretched over a lamp shade and I am happy with the result, it is transluscent. I fit the wing center section on last week with temp fittings. Yesterday, I built the bellcrank assy and it will be installed this week. I am going with external rigging on the bellcrank. The wings are almost ready for covering, just some minor puttering left. Rotec e-mailed me last week. They say there are 3 other Piets now under construction. I know of 1 in N. Florida who is on the list here. Has anyone heard of anyone else? I'm still hoping mine is done for Brodhead. Dick N. ________________________________________________________________________________
Date: Nov 18, 2006
Subject: Movie
As Dick says, since things are slow on the list, here's a video I made this morning of a circuit of my home airport, Lenora (2GA9). I haven't figured out how to have YouTube videos come out top quality (the original looks much better), but you'll get the idea: http://www.youtube.com/watch?v=aHOGRtOpHMs Just a bit of fluff for those who didn't get to go Pieting today. Jeff ________________________________________________________________________________
Subject: Re: Movie
Date: Nov 18, 2006
The video is inspiring; it's the soundtrack that needs a little work. Couldn't hear the engine music over the wind blast. ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Saturday, November 18, 2006 5:30 PM Subject: Pietenpol-List: Movie > > As Dick says, since things are slow on the list, here's a video I > made this morning of a circuit of my home airport, Lenora (2GA9). I > haven't figured out how to have YouTube videos come out top quality > (the original looks much better), but you'll get the idea: > > http://www.youtube.com/watch?v=aHOGRtOpHMs > > Just a bit of fluff for those who didn't get to go Pieting today. > > Jeff > > ________________________________________________________________________________
Subject: looking for Matco brakes
Date: Nov 18, 2006
I'm looking for a pair of new (or like new) Matco MC-5 brake masters. If you have a pair for sale, email me off-list please. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ View Athletes Collections with Live Search http://sportmaps.live.com/index.html?source=hmemailtaglinenov06&FORM=MGAC01 ________________________________________________________________________________
Subject: Re: Movie
Date: Nov 18, 2006
Nice flight, Jeff. Send me you movies on CD and I can post them on my website if you want. I just found this good one by Grant Maclaren http://www.youtube.com/watch?v=-2Ch9QhwyBY&mode=related&search Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Saturday, November 18, 2006 5:30 PM Subject: Pietenpol-List: Movie > > As Dick says, since things are slow on the list, here's a video I made > this morning of a circuit of my home airport, Lenora (2GA9). I haven't > figured out how to have YouTube videos come out top quality (the original > looks much better), but you'll get the idea: > > http://www.youtube.com/watch?v=aHOGRtOpHMs > > Just a bit of fluff for those who didn't get to go Pieting today. > > Jeff > > > ________________________________________________________________________________
Subject: Progress and problems
Date: Nov 18, 2006
The good news is I am making some progress. I got a decent jumpstart when I bought a tailfeathers set and some ribs for next to nothing from a great builder. I also started on the fuselage sides, I have one just about complete. Giant scale R/C experience is helping me a great deal more than I thought. I have a few pics up at my site: http://www.subarubrat.com/Pietenpol.htm The problems, well they all come from Aircraft Spruce (the company). I had to go around and around with them on various issus. Some of them being all items other than one being reported as in stock and shipping from the East coast when that last item came off back order. Later it was all going to ship from West at a higher rate. They finally shipped it as promised but when the order arrived they had forgotten the capstrip. They found where they had messed up and shipped it, however they shipped the wrong size and I have 500ft of useless capstrip coming. The spruce kit advertised as being complete (other than having to order the capstrip seperatly) does not include the leading or trailing edge stock as well as some other stock. The fuse kit does not include enough of one size and I have about 6 pieces that don't match any size called for in the plans or on their cut sheet they sent with the kit. I suppose I have to call them back Monday and try to get the missing pieces and capstrip re-done, but honestly I am tired of calling them for problem after problem. And one last Aircraft Spruce problem, they substitute 3/4 spars for the 1in spars in the plans saying that some company told them it was OK. Even if this is true, and I don't trust this much, all the measurements and clearances (rib spar slots, metal fittings etc.) are intended for the spar thickness called for in the plans. I am not sure I like the idea of all those changes to the plans because of some hearsay source. Anyone else been through this? -Scott ________________________________________________________________________________
Subject: Re: Movie
Date: Nov 18, 2006
Inspirational! ----- Original Message ----- From: "Catdesigns" <catdesigns(at)comcast.net> Sent: Saturday, November 18, 2006 9:20 PM Subject: Re: Pietenpol-List: Movie > > > Nice flight, Jeff. Send me you movies on CD and I can post them on my > website if you want. > > I just found this good one by Grant Maclaren > http://www.youtube.com/watch?v=-2Ch9QhwyBY&mode=related&search > > Chris Tracy > Sacramento, Ca > Website at http://www.Westcoastpiet.com > > > ----- Original Message ----- > From: "Jeff Boatright" <jboatri(at)emory.edu> > To: > Sent: Saturday, November 18, 2006 5:30 PM > Subject: Pietenpol-List: Movie > > >> >> As Dick says, since things are slow on the list, here's a video I made >> this morning of a circuit of my home airport, Lenora (2GA9). I haven't >> figured out how to have YouTube videos come out top quality (the original >> looks much better), but you'll get the idea: >> >> http://www.youtube.com/watch?v=aHOGRtOpHMs >> >> Just a bit of fluff for those who didn't get to go Pieting today. >> >> Jeff >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Progress and problems
Date: Nov 18, 2006
Scott, 3/4 inch solid spars are perfectly acceptable substitutions for the routed 1 inch spars. Use them without worries. Greg Cardinal ----- Original Message ----- From: Scott Schreiber And one last Aircraft Spruce problem, they substitute 3/4 spars for the 1in spars in the plans saying that some company told them it was OK. Even if this is true, and I don't trust this much, all the measurements and clearances (rib spar slots, metal fittings etc.) are intended for the spar thickness called for in the plans. I am not sure I like the idea of all those changes to the plans because of some hearsay source. Anyone else been through this? -Scott ________________________________________________________________________________
Date: Nov 19, 2006
I'll second that. I'm certainly not that big but I still widened my fuselage by two inches, much more comfortable to sit in and make engine noises! Here's a couple of pics of my mockup; http://clifdawson.ca/Pientenpol.html Clif ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Saturday, November 18, 2006 3:32 PM Subject: Re: Pietenpol-List: Fuse questions... Would highly recommend building a mock cockpit out of scrap wood first as discussed in the Bengelis books. Will answer all these questions and you will learn a lot which will make your fuselage go together easier with less mistakes. I ended up making mine two inches wider, leaned the seat back two inches, and raised the turtle decks a couple also. Also helps you figure the best places for controls, cables, and etc. Rick ________________________________________________________________________________
Date: Nov 19, 2006
Subject: Re: Rotec piet
Nice work Dick, how did you do your logo and stripes? They look great. Rick On 11/18/06, Dick Navratil wrote: > > As things are a bit slow on the list, here is an update on my new Piet. > The tail is finished with the special batch of Poly Tone that Stits made > for me. I wanted it to look like leather stretched over a lamp shade and I > am happy with the result, it is transluscent. I fit the wing center section > on last week with temp fittings. Yesterday, I built the bellcrank assy and > it will be installed this week. I am going with external rigging on the > bellcrank. The wings are almost ready for covering, just some minor > puttering left. > Rotec e-mailed me last week. They say there are 3 other Piets now under > construction. I know of 1 in N. Florida who is on the list here. Has > anyone heard of anyone else? > I'm still hoping mine is done for Brodhead. > Dick N. > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 19, 2006
I purchased the Piet wood set from ACS. Most people use 3/4" spars, build the ribs to the plans and add 1/8" ply spacers to the spars at the rib positions when building your wing. Possibly they don't include cap strip because some people use 1/4" x 1/4". Yes no leading or trailing edge either. Many people use cut down Home Depot stair railing for leading edges, I used Douglas fir for mine and I ripped a single Douglas fir 1/x2 for both trailing edges. May want to try Wicks as an alternative for ACS. Rick On 11/18/06, Scott Schreiber wrote: > > The good news is I am making some progress. I got a decent jumpstart when > I bought a tailfeathers set and some ribs for next to nothing from a great > builder. I also started on the fuselage sides, I have one just about > complete. Giant scale R/C experience is helping me a great deal more than I > thought. I have a few pics up at my site: > http://www.subarubrat.com/Pietenpol.htm > > The problems, well they all come from Aircraft Spruce (the company). I had > to go around and around with them on various issus. Some of them being all > items other than one being reported as in stock and shipping from the East > coast when that last item came off back order. Later it was all going to > ship from West at a higher rate. They finally shipped it as promised but > when the order arrived they had forgotten the capstrip. They found > where they had messed up and shipped it, however they shipped the wrong size > and I have 500ft of useless capstrip coming. The spruce kit advertised as > being complete (other than having to order the capstrip seperatly) does not > include the leading or trailing edge stock as well as some other stock. The > fuse kit does not include enough of one size and I have about 6 pieces that > don't match any size called for in the plans or on their cut sheet they sent > with the kit. I suppose I have to call them back Monday and try to get the > missing pieces and capstrip re-done, but honestly I am tired of calling them > for problem after problem. > > And one last Aircraft Spruce problem, they substitute 3/4 spars for the > 1in spars in the plans saying that some company told them it was OK. Even if > this is true, and I don't trust this much, all the measurements and > clearances (rib spar slots, metal fittings etc.) are intended for the spar > thickness called for in the plans. I am not sure I like the idea of all > those changes to the plans because of some hearsay source. Anyone else been > through this? > > -Scott > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 19, 2006
Subject: Gap Seal Tape
I'd like to some opinions on using gap seal tape on the rudder and elevator, is it really that necessary. Thanks. Tim ________________________________________________________________________________
Subject: Re: Gap Seal Tape
Date: Nov 19, 2006
NX18235 has no gap seals on either the elevator or rudder. I have never noticed a situation where I felt the rudder or elevator need more authority. Greg Cardinal ----- Original Message ----- From: "Tim" <twilliams(at)mailmt.com> Sent: Sunday, November 19, 2006 9:07 AM Subject: Pietenpol-List: Gap Seal Tape > > I'd like to some opinions on using gap seal tape on the rudder and > elevator, is it really that necessary. > Thanks. > Tim > > > ________________________________________________________________________________
Date: Nov 19, 2006
In a message dated 11/19/2006 9:08:55 AM Central Standard Time, twilliams(at)mailmt.com writes: I'd like to some opinions on using gap seal tape on the rudder and elevator, is it really that necessary. Thanks. Tim Tim, The gap seals on the empenage may not be needed, and Bernard never used them. However, theoretically, it will reduce drag, add a bit of redundency to the hinges, and when taking off from some fields, may prevent any sticks or stones from getting in the hinge area. I chose to seal the gaps during the covering stage, using the dacron material, prior to paint. I have some good pictures on my web site, as to how I sealed the gaps: http://nx770cg.com/Unique.html Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 19, 2006
Subject: Re: Movie
In a message dated 11/18/2006 7:32:08 PM Central Standard Time, jboatri(at)emory.edu writes: As Dick says, since things are slow on the list, here's a video I made this morning of a circuit of my home airport, Lenora (2GA9). I haven't figured out how to have YouTube videos come out top quality (the original looks much better), but you'll get the idea: http://www.youtube.com/watch?v=aHOGRtOpHMs Jeff, I would like to copy your idea about putting some video footage on youtube, but I don't know how to do it, or what format to use. I've been editing down my 1hr 42min video to as short as possible, to get it on there. It's kinda difficult to decide what to use, and what to leave out...got any suggestions ? What format do you use ? What's the longest video you can put up there ? How much GB or MB can be used ? Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 19, 2006
The answer to that depends on how wide the gap is. On the Piet I presently fly, I neglected to route out the tail hinges, so there is a 1" gap. When I installed the gap seals there was a major difference in the amount of effort needed to lift the tail on take off run and the plane is now about 2 mph faster. It's an easy test to try, just apply a strip of duct tape to the underside to elevators. Dick N. ----- Original Message ----- From: "Tim" <twilliams(at)mailmt.com> Sent: Sunday, November 19, 2006 9:07 AM Subject: Pietenpol-List: Gap Seal Tape > > I'd like to some opinions on using gap seal tape on the rudder and > elevator, is it really that necessary. > Thanks. > Tim > > > ________________________________________________________________________________
Date: Nov 19, 2006
Rick The logo wings are thin pieces of cherry. The circle is birch and stripes and lettering are vinyl. Dick ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Sunday, November 19, 2006 8:19 AM Subject: Re: Pietenpol-List: Rotec piet Nice work Dick, how did you do your logo and stripes? They look great. Rick On 11/18/06, Dick Navratil < horzpool(at)goldengate.net> wrote: As things are a bit slow on the list, here is an update on my new Piet. The tail is finished with the special batch of Poly Tone that Stits made for me. I wanted it to look like leather stretched over a lamp shade and I am happy with the result, it is transluscent. I fit the wing center section on last week with temp fittings. Yesterday, I built the bellcrank assy and it will be installed this week. I am going with external rigging on the bellcrank. The wings are almost ready for covering, just some minor puttering left. Rotec e-mailed me last week. They say there are 3 other Piets now under construction. I know of 1 in N. Florida who is on the list here. Has anyone heard of anyone else? I'm still hoping mine is done for Brodhead. Dick N. -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Movie
Date: Nov 19, 2006
Nice movie. That's a fun little dogleg in the trees as you head out. Must be a one-way strip, judging by the departure and approach from the same end. We had some good little one-way strips where I used to fly up in Oregon. Thanks for sharing. The only thing missing was a smoke trail headed out that little alley of trees ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Talk now to your Hotmail contacts with Windows Live Messenger. ________________________________________________________________________________
Date: Nov 19, 2006
Don't leave the duct tape on there too long.It can be messy getting it off later.I used tape that they used for the gaps on the Chinook ultralight for my airlerones and vertical gap in my rudder but for the elevator I used ceconite material.I wanted to see how each worked out.I may land up later replacing the tape with ceconite from what I've been told.With the tape, because it was sticky only on one side I did both sides leaving enough tape for movement but with the ceconite ,because I was gluing it on,I went from the top of the horizontal stab to the bottom of the elevator.I'm not sure if there is a wrong way to do that or not,like for instance taking it from the bottom of the horizontal stab to the top of the elevator.Either way there is a situation there that could cause eddy currents to materialize hindering flight.It might if I was flying an F86 but so far from the way I did it I havn't noticed any problems but then I'm not a test pilot although I did fly my plane for the first time myself on her maiden fight.Couldn't find any test pilots. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: November 19, 2006 11:44 AM Subject: Re: Pietenpol-List: Gap Seal Tape The answer to that depends on how wide the gap is. On the Piet I presently fly, I neglected to route out the tail hinges, so there is a 1" gap. When I installed the gap seals there was a major difference in the amount of effort needed to lift the tail on take off run and the plane is now about 2 mph faster. It's an easy test to try, just apply a strip of duct tape to the underside to elevators. Dick N. ----- Original Message ----- From: "Tim" <twilliams(at)mailmt.com> Sent: Sunday, November 19, 2006 9:07 AM Subject: Pietenpol-List: Gap Seal Tape > > I'd like to some opinions on using gap seal tape on the rudder and > elevator, is it really that necessary. > Thanks. > Tim > > > ________________________________________________________________________________
Date: Nov 19, 2006
Subject: Re: Movie
Oscar (and others), Thanks for the comments. The strip is sort of one-way in that there are a couple of reasons to land heading west and take off heading east. There is a church, quickmart, and concentration of new housing developments on the west end. There are cow pastures and other open spaces to the east. Another consideration is that our hangar is on the west end, so it's a lot easier to taxi out to that end for take off and taxi in from landing the other other way. Jeff > >Nice movie. That's a fun little dogleg in the trees as you head >out. Must be a one-way strip, judging by the departure and approach >from the same end. We had some good little one-way strips where I >used to fly up in Oregon. > >Thanks for sharing. The only thing missing was a smoke trail headed >out that little alley of trees ;o) > >Oscar Zuniga >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Clif's website
Date: Nov 19, 2006
Clif's website- http://clifdawson.ca/Pientenpol.html If you haven't taken the time to look at it, at the very least scroll to the bottom of the homepage for the cartoon. Classic! Classic! But just looking at the work on the handmade throttle quadrant is worth visiting the site. Thanks, Clif. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ View Athletes Collections with Live Search http://sportmaps.live.com/index.html?source=hmemailtaglinenov06&FORM=MGAC01 ________________________________________________________________________________
Date: Nov 19, 2006
Subject: Re: Clif's website
Perfect sentiment for our strip! (Though dogs and deer are more often the problem). > >Clif's website- > >http://clifdawson.ca/Pientenpol.html > >If you haven't taken the time to look at it, at the very least >scroll to the bottom of the homepage for the cartoon. Classic! >Classic! But just looking at the work on the handmade throttle >quadrant is worth visiting the site. Thanks, Clif. > >Oscar Zuniga >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net -- Jeffrey H. Boatright, Ph.D. Associate Professor Department of Ophthalmology Emory University School of Medicine Atlanta, GA 30322 Editor-in-Chief Molecular Vision http://www.molvis.org/ ________________________________________________________________________________
Date: Nov 19, 2006
Sealing the aileron gaps with tape made a huge difference in the handling of our Piet. Without tape, the effect of aileron input was delayed and when it did happen, resulted in sudden changes in roll. > >I'd like to some opinions on using gap seal tape on the rudder and >elevator, is it really that necessary. > Thanks. >Tim -- Jeffrey H. Boatright, Ph.D. Associate Professor Department of Ophthalmology Emory University School of Medicine Atlanta, GA 30322 Editor-in-Chief Molecular Vision http://www.molvis.org/ ________________________________________________________________________________
Date: Nov 19, 2006
Subject: Re: Movie
Chuck, YouTube is very easy to use. It's free to sign up at http://www.youtube.com and I don't recall that they want any more than a username and password from you. As to formats, sizes, etc., from their website: * Videos are limited to 10 minutes (unless you're a Director) and 100 MB. * Videos saved with the following settings convert the best: * MPEG4 (Divx, Xvid) format * 320x240 resolution * MP3 audio * 30 frames per second framerate Right now, I use Quicktime (.mov) and in Mac iMovies export at CD quality, but apparently that's not the best format. YouTube is going to convert (trim down) anyway, so I upload at as high a quality as possible while staying within the 100 MB limit. Actually, the largest I've uploaded was 18 MB. I'm still getting used to the camera and haven't even tried real editing. I'm also starting to play with Google movies, but I don't know if it's any better than YouTube. WARNING: You can spend a lot of time at YouTube. There' a lot there and it's addictive!! :) Jeff >In a message dated 11/18/2006 7:32:08 PM Central Standard Time, >jboatri(at)emory.edu writes: > >As Dick says, since things are slow on the list, here's a video I >made this morning of a circuit of my home airport, Lenora (2GA9). I >haven't figured out how to have YouTube videos come out top quality >(the original looks much better), but you'll get the idea: > >http://www.youtube.com/watch?v=aHOGRtOpHMs > >Jeff, >I would like to copy your idea about putting some video footage on >youtube, but I don't know how to do it, or what format to use. I've >been editing down my 1hr 42min video to as short as possible, to get >it on there. It's kinda difficult to decide what to use, and what >to leave out...got any suggestions ? >What format do you use ? What's the longest video you can put up >there ? How much GB or MB can be used ? > >Chuck G. >NX770CG > > -- Jeffrey H. Boatright, Ph.D. Associate Professor Department of Ophthalmology Emory University School of Medicine Atlanta, GA 30322 Editor-in-Chief Molecular Vision http://www.molvis.org/ ________________________________________________________________________________
Date: Nov 19, 2006
Tim, only way your going to know for sure is to try it both ways. I like using gap seal tape made out of vinyl. I buy mine from a sign company (it's what they make letters out of and comes in many colors). I cuts strips, then take the paper backing off half of the width of the strips and stick two strips togeather. That way you end up with sticky side on both sides of one/half of the width of the tape. Peel off one/half of the backing and apply to the top, route the other half down thru the gap and fix to the other side. Done. I've been able to find colors that will match my paint and it really looks nice. Gene ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Sunday, November 19, 2006 3:10 PM Subject: Re: Pietenpol-List: Gap Seal Tape > > Sealing the aileron gaps with tape made a huge difference in the handling > of our Piet. Without tape, the effect of aileron input was delayed and > when it did happen, resulted in sudden changes in roll. > >> >>I'd like to some opinions on using gap seal tape on the rudder and >>elevator, is it really that necessary. >> Thanks. >>Tim > > > -- > Jeffrey H. Boatright, Ph.D. > Associate Professor > Department of Ophthalmology > Emory University School of Medicine > Atlanta, GA 30322 > Editor-in-Chief > Molecular Vision > http://www.molvis.org/ > > > ________________________________________________________________________________
Subject: PS- Clif's website (watch out for Mike!)
Date: Nov 19, 2006
Clif- you'd better watch out for Mike "The Spelling Cop" Cuy in case he notices that "Pietenpol" is misspelled in the link to your page- http://clifdawson.ca/Pientenpol.html He's been a little tough on misspellings here lately ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Stay up-to-date with your friends through the Windows Live Spaces friends list. ________________________________________________________________________________
Date: Nov 19, 2006
In a message dated 11/17/2006 8:15:15 P.M. Eastern Standard Time, zharvey(at)bellsouth.net writes: Ron, Your the kinda of guy I have a great respect for. You do what you have to do. I think flying a powered parachute would be a blast. As long as your flying,, who cares what your flying? I flew ultralights for many years and had a blast and as soon as I can afford it I will buy another one to put next to my Piet (and it just might be a powered parachute) Gene N502R Gene, I appreciate the kind comment. However, I do want to say that nothing, in my mind, will take the place of the Piet. I have been captivated by the plane for many years. I first saw it in an aviation publication, with the Model A engine and thought, "Wow, that is the coolest thing I have ever seen." So I sent for the plans. When they arrived, I strolled out to my workshop, about 100 feet from my house, to check them out for an hour or so. As I started my walk back to the house, I heard the sound of an aircraft, obviously low and slow, over my head. I looked up (like I always do when any aircraft flies by) and what do you think it was?Yes, a Pietenpol! To this day, that is still the ONLY Piet I have ever seen "in person". So I sort of knew it was meant to be that I chose this design. And what a great bunch of fellow Piet fanatics to associate with. Good mentors, fun to talk to and brimming with info to share. It doesn't get any better. Ron ________________________________________________________________________________
Date: Nov 19, 2006
Subject: varnish
Hi Fellow Piet'ers, I have a question for everyone, what type of varnish is everyone using? What I would like to know is also, why can't regular thompson wood sealer be used if a person was going to apply 3 coats or so? thanks and just an update on my project I will be meeting my dad out at Robb's place (building partner) to draw the plans up to full scale tomorrow (11/20/06). I will also be putting a website together to so where I am at with the project. take care, Ben St. Cloud, MN ________________________________________________________________________________
Subject: varnish
Date: Nov 19, 2006
Ben; Like Chuck Gantzer, I have used Ace spar varnish (from your Ace hardware store) on wood repairs to NX41CC. It's quite thin so needs several coats but I love the smell of the hangar after I varnish something so I don't mind. I found that if you shake the can the varnish sometimes has tiny bubbles when you apply it, but it's thin enough that the bubbles disappear as it dries. Purists say "stirred, not shaken", but I'm too impatient so I shake the can. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get FREE company branded e-mail accounts and business Web site from Microsoft Office Live ________________________________________________________________________________
Subject: Oklahoma Fly-in
Date: Nov 19, 2006
A few pictures from the fly-in. You local guys have to make the next one, this was really a lot of fun. http://www.wotelectronics.com/flying/061119flyin/Pb180078.jpg http://www.wotelectronics.com/flying/061119flyin/Dsc02871.jpg http://www.wotelectronics.com/flying/061119flyin/YellaFellas.jpg http://www.wotelectronics.com/flying/061119flyin/Pb1800671.jpg Steve Ruse Norman, OK -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Steve Ruse Sent: Wednesday, November 15, 2006 11:43 PM Subject: Pietenpol-List: Oklahoma Fly-in I am having a fly-in this weekend at O44 (Oscar44) south of Norman, OK. Everyone is welcome...its a good 'ol grass strip where my plane is based. We'll have BBQ and a good time. More details here: http://www.wotelectronics.com/flyin/ Steve Ruse Norman, OK -- -- -- ________________________________________________________________________________
Date: Nov 19, 2006
Those are great air-to-air shots. Looks like you guys had a severe clear day! What were the temps? > >A few pictures from the fly-in. You local guys have to make the next one, >this was really a lot of fun. > -- Jeffrey H. Boatright, Ph.D. Associate Professor Department of Ophthalmology Emory University School of Medicine Atlanta, GA 30322 Editor-in-Chief Molecular Vision http://www.molvis.org/ ________________________________________________________________________________
Date: Nov 19, 2006
Subject: Re: PS- Clif's website (watch out for Mike!)
Weird! Well I'll just have to go in and fix it. I haven't updated the thing for a while, just too busy, I've got a bunch more stuff to add to a number of pages and a couple new ones to create. Time! time! time! Thanks for the compliments. You guys can download those nasty cows if you want. I made it for the rest of you Pieters. Clif Yoohoo! Hi Miky! :-) :0) > Clif- you'd better watch out for Mike "The Spelling Cop" Cuy in case he > notices that "Pietenpol" is misspelled in the link to your page- > http://clifdawson.ca/Pientenpol.html > > He's been a little tough on misspellings here lately ;o) > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > Stay up-to-date with your friends through the Windows Live Spaces friends > list. > > > -- > > ________________________________________________________________________________
Date: Nov 20, 2006
Subject: Re: Oklahoma Fly-in
In a message dated 11/19/2006 9:14:02 PM Central Standard Time, steve(at)wotelectronics.com writes: A few pictures from the fly-in. You local guys have to make the next one, this was really a lot of fun. Hey Steve, I'm going to make it down there one of these days. I had to work this weekend...kinda chilly for that flight anyways. Great pictures !! Is that a big long com antenna sticking down in front of the landing gear ? Chuck G. ________________________________________________________________________________
Date: Nov 20, 2006
Subject: Why? [Please Read]
Dear Listers, Each year I like to explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a superior experience over the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell little-blue-pills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year during November to encourage members to support the Lists. I believe that the Lists services that I provide here offer many benefits over the commercial equivalents in a number of ways. The first feature I believe to be significant is that you cannot receive a computer v*rus from any of these Lists directly. Each incoming message is filtered and dangerous attachments stripped off prior to posting. I also provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. Safe and simple. Another very important feature of this system in my opinion is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the very fast Search Engine, the huge size of some of the Archives is a non-issue in quickly finding the data you're looking for. And added just this year is the new Email List Forum that allows members who prefer the Web BBS-style of List interaction. The beauty of the new List Forums is that they contain the exact same content that is distributed via email. Messages posted via email are cross-posted to the respective Forum and vice versa. The Forums also allow for another convenient method of sharing pictures and other files. Additionally added this year is the new List Wiki that allows members to build their own "Online List Encyclopedia" of sorts, documenting various aspects of their project for all to share. I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys I knew and who where also building RVs. It has grown into nearly 70 different aviation-related Email Lists and an associated web site that receives over 23,000,000 hits each year!! Additionally, the List Email system forwarded well over 87,000 postings last year, accounting for an unbelievable 39,000,000 (yes, that's 39 MILLION) email messages delivered to Matronics List subscribers! I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service all _without any advertising budget_! I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, use the List Browser, or surf the Forums and Wiki sites. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! List Contribution Web Site: http://www.matronics.com/contribution Thank you, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2006
Subject: Re: The correct spelling is advice.....
In a message dated 11/19/2006 7:31:51 P.M. Eastern Standard Time, Pietsrneat(at)aol.com writes: I looked up (like I always do when any aircraft flies by) and what do you think it was?Yes, a Pietenpol! "Flies" by? Sometimes I crack myself up. do not archive ________________________________________________________________________________
Subject: You Tube and Google Video
Date: Nov 20, 2006
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Man guys, Jeff Boatright is absolutely right about You Tube and Google Video being addictive. There is just about anything that might interest you on there. I like to type in things that I have not been able to try to do yet---things like hang gliding, parasailing, ski jumping, and more. I've never driven the 7 mile bridge in the Keys so whala, there's a couple who posted a view of driving that stretch. A fun one to type in in r/c crash or r/c accident. Some of the footage these r/c guys (like our own DJ Vegh) shoot from their aerial platforms is just great----with side to side pan capabilities and all. You like Model A's ? Type in Model a running or Model A start up. Same for Corvair's, Subaru's, you name it. You can spend mucho amounts of time on those two web sites ! Mike C. ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Subject: Rotec piet
Date: Nov 20, 2006
Hi Dick! Do you have any photos of your engine install? I am thinking to use a Rotec Radial on my Piet too! Best Regards, Dave Abramson -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Dick Navratil Sent: Saturday, November 18, 2006 5:07 PM Subject: Pietenpol-List: Rotec piet As things are a bit slow on the list, here is an update on my new Piet. The tail is finished with the special batch of Poly Tone that Stits made for me. I wanted it to look like leather stretched over a lamp shade and I am happy with the result, it is transluscent. I fit the wing center section on last week with temp fittings. Yesterday, I built the bellcrank assy and it will be installed this week. I am going with external rigging on the bellcrank. The wings are almost ready for covering, just some minor puttering left. Rotec e-mailed me last week. They say there are 3 other Piets now under construction. I know of 1 in N. Florida who is on the list here. Has anyone heard of anyone else? I'm still hoping mine is done for Brodhead. Dick N. ________________________________________________________________________________
Date: Nov 20, 2006
I hope you can make the next one, we are looking at February as a possibility. We desperately need a smoking Piet here! Yes, that is a comm antenna that I installed on the bottom of the nose. I wanted it inside the fuse, and may do that eventually, but it works great in that location as there was already sheet metal for a ground plane there. I have transmitted up to 90 miles air to air using my 5 watt handheld! I can regularly transmit 40 miles air to air. I made it with some brass brazing rod and nylon insulators from Home Depot, and a pre-terminated RG-58 cable from the local electronics shop. Total cost was under $10! Steve Quoting Rcaprd(at)aol.com: > In a message dated 11/19/2006 9:14:02 PM Central Standard Time, > steve(at)wotelectronics.com writes: > A few pictures from the fly-in. You local guys have to make the next one, > this was really a lot of fun. > Hey Steve, > I'm going to make it down there one of these days. I had to work this > weekend...kinda chilly for that flight anyways. > Great pictures !! > Is that a big long com antenna sticking down in front of the landing gear ? > > Chuck G. > ________________________________________________________________________________
Date: Nov 20, 2006
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
A couple of concerns, Ken, I made my Pietenpol 1" wider than plans, and used the long fuselage plans. The result is a pretty heavy Pietenpol (empty weight 745 lbs), which climbs even worse than usual for a Piet. There are a couple of problems with the long, wide fuselage. The first is weight. SOme years ago, someone on this list compiled a list of Pietenpols at Brodhead, comparing their empty weights and CG locations. Every one of the long fuselage Piets came in at over 700 lbs, and a couple were over 800 lbs. You wouldn't think that adding 9" or so would add 50 to 100 lbs, but it seems to do so. Making it wider adds substantial weight as well. The other problem with a wider fuselage is in expense. With a 24" wide fuselage, you can use a single sheet of plywood ripped lengthwise for the floorboards and firewall. If you make it wider, you will use a lot more plywood, with substantial waste. The Pietenpol is supposed to have a gross weight of about 1050 lbs. If you weigh 254 lbs, and carry 10 gallons of gas, your airplane can only weigh 736 lbs EMPTY, and you'd probably better not plan on carrying any passengers. I have flown mine with myself and a 205 lb passenger, and 15 gallons of fuel on board, for a gross weight of 1,240 lbs. It flew, but I was glad we were flying off a 6,000' paved runway. Climb rate was a shade under 100 feet per minute. If I were to build another one, I would build the short fuselage and keep it standard width. I'm 6'2 and 200 lbs, and I've flown Mike Cuy's standard width, short fuse Piet and found it nearly as comfortable as my own, with a better climb rate. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide Sent: Saturday, November 18, 2006 4:42 PM To: Pietenpol Subject: Pietenpol-List: Fuse questions... Fellow Pieters: Question.....If you are going to build a wider fuselage would you build it 3" or 4" wider? Also, are they going to be any major changes is the structural integrity, rigging etc.... Lastly, for a guy who is 6'0 and 254lbs....is the current size of the plane comfortable? what modification if any have you made to improve function and comfort of this plane design. Ken H. Fargo, ND _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Nov 20, 2006
Subject: website
Hello everyone, I was just wondering if anyone would object to using 2 pictures from the pictures gallery to put on my website! I will give the URL here on the forum when I am ready! thanks, Ben R. St. Cloud, MN ________________________________________________________________________________
Date: Nov 20, 2006
Their our to many possible errors in are language two go too. People should remember there education when they go they're. ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Monday, November 20, 2006 9:19 AM Subject: RE: Pietenpol-List: The correct spelling is advice..... Sorry Harvey, but flys just isn't proper English (in the U.S., nor in Canada). (here's a link to a quick explanation) [snip] ________________________________________________________________________________
Date: Nov 20, 2006
MessageJack, I don't agree. I built the long fuse with an A-65 and 99.9% to plans. My empty weight was 595#. I was lucky to have a Mentor that was a stickler for not adding anything. I can't believe that 1" of 1/4 plywood and various fuse sticks account for 100#. Think you must have beefed here and there, and added one too many goodies. You know the old saying,,,"thinking of adding something that's not on the plans? Throw it up,,,if it comes back down,,,leave it off" Our strip is 2,550ft of asphalt. The Regs say that you have to be 400' and to the end of the runway before you make your turn climbing out. With just me (6'3" 210#) and 1/2 gas load I'll pass 400' before reaching the end of the runway. Now put my friend Bob in the front and it climbs kind of like a cub. Hard to imagine a Piet built 200# heavy, and that would be a climbout with just me. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Monday, November 20, 2006 11:28 AM Subject: RE: Pietenpol-List: Fuse questions... A couple of concerns, Ken, I made my Pietenpol 1" wider than plans, and used the long fuselage plans. The result is a pretty heavy Pietenpol (empty weight 745 lbs), which climbs even worse than usual for a Piet. There are a couple of problems with the long, wide fuselage. The first is weight. SOme years ago, someone on this list compiled a list of Pietenpols at Brodhead, comparing their empty weights and CG locations. Every one of the long fuselage Piets came in at over 700 lbs, and a couple were over 800 lbs. You wouldn't think that adding 9" or so would add 50 to 100 lbs, but it seems to do so. Making it wider adds substantial weight as well. The other problem with a wider fuselage is in expense. With a 24" wide fuselage, you can use a single sheet of plywood ripped lengthwise for the floorboards and firewall. If you make it wider, you will use a lot more plywood, with substantial waste. The Pietenpol is supposed to have a gross weight of about 1050 lbs. If you weigh 254 lbs, and carry 10 gallons of gas, your airplane can only weigh 736 lbs EMPTY, and you'd probably better not plan on carrying any passengers. I have flown mine with myself and a 205 lb passenger, and 15 gallons of fuel on board, for a gross weight of 1,240 lbs. It flew, but I was glad we were flying off a 6,000' paved runway. Climb rate was a shade under 100 feet per minute. If I were to build another one, I would build the short fuselage and keep it standard width. I'm 6'2 and 200 lbs, and I've flown Mike Cuy's standard width, short fuse Piet and found it nearly as comfortable as my own, with a better climb rate. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide Sent: Saturday, November 18, 2006 4:42 PM To: Pietenpol Subject: Pietenpol-List: Fuse questions... Fellow Pieters: Question.....If you are going to build a wider fuselage would you build it 3" or 4" wider? Also, are they going to be any major changes is the structural integrity, rigging etc.... Lastly, for a guy who is 6'0 and 254lbs....is the current size of the plane comfortable? what modification if any have you made to improve function and comfort of this plane design. Ken H. Fargo, ND _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Nov 20, 2006
In a message dated 11/20/2006 10:06:37 AM Central Standard Time, steve(at)wotelectronics.com writes: I hope you can make the next one, we are looking at February as a possibility. We desperately need a smoking Piet here! Yes, that is a comm antenna that I installed on the bottom of the nose. I wanted it inside the fuse, and may do that eventually, but it works great in that location as there was already sheet metal for a ground plane there. I have transmitted up to 90 miles air to air using my 5 watt handheld! I can regularly transmit 40 miles air to air. I made it with some brass brazing rod and nylon insulators from Home Depot, and a pre-terminated RG-58 cable from the local electronics shop. Total cost was under $10! Steve February !! Holy Crap !! That would be a very chilly flight !! I would have to be bundled up so much, it would cause a lot of extra drag, if I could even fit in my plans width, 632 lb. short fuselage. At least there wouldn't be any flys..or is it flies...or is it fly's out buzzing around :) I made an antenna from coax cable, that I separated the two leads, and stretched them apart under the turtle deck, totaling 42". I have an ICOM -5 Handheld, but I don't think it will broadcast 40 miles, but it does well in any local flying area...with a typical south wind I would call: "Norman Field, Zero Charlie Golf is Forty miles north, inbound for landing...in about an hour" Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 20, 2006
Rick, As far as I am concerned I would rather deal with Wicks than A.S.S. (WOW! thats a appropriate abriviation). I usually deal with Wicks on lumber and usually recieve it in a couple of weeks. Although I am building a Jungster 1 not a Piet, it is all wood and all my spruce has been purchased from Wicks. I don't know whats been going on with A.S.S. lately but I have heard a lot of complaints about them as far as lumber orders, from screwed up orders to lack of customer service. On a side note 3/4 in spars are more than enough, Take a look at a Taylorcraft spar. They are longer and only 1/2 in thick, and the root end spar plates for wing attatch fittings are beveled down even more to keep the 1/8 in ply flush with the rest of the spar. My 2 cents Shad --------------------------------- Mortgage rates as low as 4.625% - $150,000 loan for $579 a month. Intro-*Terms ________________________________________________________________________________
Date: Nov 20, 2006
Subject: Ohio area pietenpol gathering
Helo Group, Dad and I were talking the other day about possibly organizing an a gathering of Pietenpols from the Ohio area. We thought this would be a fun event for people who would love to fly to Brodhead but can't find the time to make the trip due to occupational or logistical reasons, as Brodhead can be a long long trip if weather takes an unexpected turn. I was just wondering how many of you would be interested in attending an Ohio Piet fly-in. I was thinking of one easy way to do this would be to keep touch next spring and meet up close to another sceduled fly in in the area fly in as a group. This would be a fun alternate to those who can't make it to Brodhead, and an added bonus to those who do make it to Brodhead. A few of the area fly-ins that come to mind are the Taylorcraft fly-in At Barber Field in Alliance, The WACO fly-in at Wyncoop in Mt Vernon Ohio, or any other grass airport fly-ins you all may know of. These airports would all be within 2-3 hrs flight time from almost anywhere in Ohio, and you could even sleep in your own bed that night. --------------------------------- ________________________________________________________________________________
Date: Nov 20, 2006
Gene, What a great idea! I'm in the sign business...I should have thought of that. The crappiest vinyl I carry is guaranteed for five years (under normal circumstances). It is very durable. Also, the adhesive is quite tenacious and should hold 'till the cows come home. Ron ________________________________________________________________________________
Date: Nov 20, 2006
You are right, Bill. It just didn't look right to me after I posted it. I should have more confidence in myself. Ron Doo nut arkive do not archive ________________________________________________________________________________
Date: Nov 20, 2006
Dave Go to www.rotecradialengines.com Look for the tab on the left side of their site titled "Dicks Pietenpol" They have pics there. Dick ----- Original Message ----- From: Dave Abramson To: pietenpol-list(at)matronics.com Sent: Monday, November 20, 2006 9:24 AM Subject: RE: Pietenpol-List: Rotec piet Hi Dick! Do you have any photos of your engine install? I am thinking to use a Rotec Radial on my Piet too! Best Regards, Dave Abramson -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Dick Navratil Sent: Saturday, November 18, 2006 5:07 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Rotec piet As things are a bit slow on the list, here is an update on my new Piet. The tail is finished with the special batch of Poly Tone that Stits made for me. I wanted it to look like leather stretched over a lamp shade and I am happy with the result, it is transluscent. I fit the wing center section on last week with temp fittings. Yesterday, I built the bellcrank assy and it will be installed this week. I am going with external rigging on the bellcrank. The wings are almost ready for covering, just some minor puttering left. Rotec e-mailed me last week. They say there are 3 other Piets now under construction. I know of 1 in N. Florida who is on the list here. Has anyone heard of anyone else? I'm still hoping mine is done for Brodhead. Dick N. ________________________________________________________________________________
Subject: Re: Ohio area pietenpol gathering
Date: Nov 20, 2006
I was just thinking the same thing lately. I'd really like to help try to organize some kind of gathering in Ohio. There are several active Piet pilots in Ohio and I think we could make a decent showing. A few would include Will Graff, Mike Cuy, Frank Pavliga, Virgil Phillips, you and me, and I'm sure there's more. I'm sure the Barbers would accomodate us and their EAA chapter at the field would always like to sell more pancakes. I could talk to Forrest and get his opinion. They may be interested in hosting us. Or we could just plan to gather at another. The Taylorcraft and Aeronca fly-ins at Barber may work. Wynkoop field is a beautiful one and would be a good one to meet at for the Waco fly-in too. I think both of those have hosted Pietenpol Fly-ins in the past. Both are grass an' gas. Any other Buckeyes out there have any other suggestions? Let us know. Don Emch Read this topic online here: http://forums.matronics.com/viewtopic.php?p=76006#76006 ________________________________________________________________________________
Date: Nov 21, 2006
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Hi Everyone, I've pretty much been off-list and not building for quite a while, but forced unemployment has gotten me motivated to get back to work on my project, and since I had all the materials at hand to build ribs, I'm finishing up my jig & back at it. Anyway, I'd like to say that EAA Chapter 82 would be more than happy to host a gaggle of Piets, and any of the Fly-ins at Barber would be appropriate. Personally, I'd like to see that coordinated with our Corvair Fly-In, a new event a Barber that we started this year (due to bad weather, we had lots of Corvairs in cars, only one on an airplane, but I hope we'll do better next year). I'm advocating a change of date to some to time later in the summer, as weather in NE Ohio is always iffy in June. Anyway, This is just to let you all know that we have an event at Barber that would LOVE to have the presence of Pietenpols (especially ones with Corvairs, but we won't be choosy :). If the consensus of regional folks is that Barber would be a good choice, let me know & I'll bring it up at a chapter meeting. > >I was just thinking the same thing lately. I'd really like to help >try to organize some kind of gathering in Ohio. There are several >active Piet pilots in Ohio and I think we could make a decent >showing. A few would include Will Graff, Mike Cuy, Frank Pavliga, >Virgil Phillips, you and me, and I'm sure there's more. I'm sure >the Barbers would accomodate us and their EAA chapter at the field >would always like to sell more pancakes. I could talk to Forrest >and get his opinion. They may be interested in hosting us. Or we >could just plan to gather at another. The Taylorcraft and Aeronca >fly-ins at Barber may work. Wynkoop field is a beautiful one and >would be a good one to meet at for the Waco fly-in too. I think >both of those have hosted Pietenpol Fly-ins in the past. Both are >grass an' gas. Any other Buckeyes out there have any other >suggestions? Let us know. >Don Emch > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=76006#76006 > > -- North Canton, OH ________________________________________________________________________________
Subject: fly-ins
Date: Nov 21, 2006
There is one less fly-in now, as many of you know. The SAA (Sport Aviation Association) has ceased to be, per e-newsletter to members from Paul Poberezny a week or two ago. The SAA fly-in at Frasca Field will no longer be held. So... something else should step up and replace it, right? Something off a grass strip, family-friendly, no airshow, no commercial advertisements or bizjets. Oscar Zuniga (SAA #1001) San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Talk now to your Hotmail contacts with Windows Live Messenger. ________________________________________________________________________________
Date: Nov 21, 2006
You can count me in. I am one state away in PA. Ron ________________________________________________________________________________
Date: Nov 21, 2006
In a message dated 11/20/2006 10:20:49 P.M. Eastern Standard Time, horzpool(at)goldengate.net writes: Dave Go to _www.rotecradialengines.com_ (http://www.rotecradialengines.com/) Look for the tab on the left side of their site titled "Dicks Pietenpol" They have pics there. Dick That is a SHARP Piet! That engine looks great. Ron do not archive ________________________________________________________________________________
Subject: heavy piet
Date: Nov 21, 2006
What kind of engine did Jack phillips use to get that poor performance? I am building the long f uselage and 2 inches wider with a corvair engine. I don't expect it to be a rocket, but it should do better than he described. I have a cessna 140 with a C90 and with 1450 max gross it climbs at 600fpm. Gardiner Mason ________________________________________________________________________________
Subject: Re: High density altitude airport
Date: Nov 21, 2006
I live at an airport with an elevation of 3125' elevation and in the summer it gets very hot. What if any are the options of operating a Pietenpol in and out of a strip with high density altitudes. Do I turbo the c-85, or stick a bigger engine on, or change props or even move to a lower elevation (no really an option)? Thanks Bruce Kirk ________________________________________________________________________________
Subject: High Altitude Performance.
Date: Nov 21, 2006
I am suprised the following post did not elict more responses from the Ford A fliers on the list. After all the correct spelling of advice had almost thirty relies. Kevin Hi, Do you seasoned Piet Pilots with Ford A power think an "A" can be modified enough to put out the power needed to fly a long fuselage Piet at it's max gross weight in the Summer out of an airport with 4,000 feet elevation? Lots of density altitude. Runway length will be plenty 5,500 feet. If so what engine and/or airframe modifications would you guys recommend? Thanks, Kevin ________________________________________________________________________________
Subject: Carl Vought's projects for sale
Date: Nov 21, 2006
OK, I'm just the messenger. Contact information on Carl's projects follows ===================================== For sale in Huntsville, Alabama (must pick up in the next few weeks). One Pietenpol on gear, maybe 75% complete, but lacking engine and instruments (the red one shown at http://www.krnet.org/piet ). Built by Ray Loritz??? of Chicago. Carl wouldn't have bought it had it not been nice. Price is what Carl paid for it (not counting airline tickets and moving it from Chicago)...$4800. Another white one (unpainted) that's at least 90% done built by mechanical engineer Carl Vought of Huntsville, Alabama (who recently passed away). It's also shown at http://www.krnet.org/piet . The workmanship on Carl's plane is impressive. The Model A engine goes with it. C arl knew as much about aircraft engines as anybody on this planet, and designed and built the "Buddy Twin" two cylinder ultralight engine a few years back. You can rest assured that this engine was meticulously rebuilt, and is all back together except that the head (which appears to be new) isn't bolted on yet. Finishing up the engine was the last hurdle before Carl could fly the airplane, and he had every intention of doing that before pneumonia unexpectedly cut his life short. The price for this one is $8000, which is only the price of parts for which receipts could be found. Everything that looks like it's part of this plane is included. We all know that this is a bargain, so these prices are pretty firm. Please contact Bob Luther at 256-881-2245, or at cell phone 256-508-8533. We would like to sell these planes in their entirety to one or two buyers and call it done, so please don't ask to buy parts and pieces. ---------------------------------------------------- your messenger, Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ View Athletes Collections with Live Search http://sportmaps.live.com/index.html?source=hmemailtaglinenov06&FORM=MGAC01 ________________________________________________________________________________
Date: Nov 21, 2006
My airport is at 6840, over 10,000 density altitude on a hot day. Am going with a Corvair (100 HP), will let you know if it's enough. I have flown 150s (also 100 HP and 1000lbs empty weight) many times with a passenger from similiar altitude airports and did ok so it should be enough. Rick On 11/21/06, Kirk, Bruce wrote: > > > I live at an airport with an elevation of 3125' elevation > and in the summer it gets very hot. > What if any are the options of operating a Pietenpol in > and out of a strip with high density > altitudes. Do I turbo the c-85, or stick a bigger engine > on, or change props or even move to a lower elevation (no > really an option)? > Thanks > Bruce Kirk > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 21, 2006
It sounds like Barber could work. Making it a Pietenpol/Corvair Fly-in might be a good idea. I'll bet we could get a showing of Ford, Corvair, and Continental powered ships without too much arm twisting. If we advertise we might get more than just Buckeyes there too. With the nice weather forecast this week I may try to fly over and see Forrest and see what he thinks and if others like the idea, maybe you could bring it up at a chapter meeting Kip. What do you think Shad? Don E. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=76246#76246 ________________________________________________________________________________
Date: Nov 21, 2006
Don't forget the difference in wing area. And don't forget, that 100 hp Lyc or Continental started out life at the factory door with only 80 true horsepower. Put those two together and what do you get? Clif Subject: Re: Pietenpol-List: Re: High density altitude airport My airport is at 6840, over 10,000 density altitude on a hot day. Am going with a Corvair (100 HP), will let you know if it's enough. I have flown 150s (also 100 HP and 1000lbs empty weight) many times with a passenger from similiar altitude airports and did ok so it should be enough. Rick ________________________________________________________________________________
Date: Nov 21, 2006
Count me in too [Laughing] John Pittsburgh Read this topic online here: http://forums.matronics.com/viewtopic.php?p=76265#76265 ________________________________________________________________________________
Date: Nov 22, 2006
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Weight & Balance
Date: Nov 22, 2006
Hi Guys, This may be a dumb question but which way does the C of G move if you move the wing BACK! Does it follow the wing movement, i.e. move the wing back CG moves aft, move the wing forward CG moves forward? Cheers Peter Wonthaggi, Australia http://www.cpc-world.com -- 10:36 PM ________________________________________________________________________________
Subject: Re: Weight & Balance
Date: Nov 22, 2006
The reason for moving the wing is to change the location of the airfoil's center of lift in relation to the aircraft's center of gravity. To answer your question, the aircraft cg will move aft when you move the wing aft but the airfoil center of lift will move aft much more than the cg. Greg C. ----- Original Message ----- From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> Sent: Wednesday, November 22, 2006 6:32 AM Subject: Pietenpol-List: Weight & Balance > > > Hi Guys, > > This may be a dumb question but which way does the C of G move if you move > the wing BACK! Does it follow the wing movement, i.e. move the wing back > CG > moves aft, move the wing forward CG moves forward? > > Cheers > > Peter > Wonthaggi, Australia > http://www.cpc-world.com > > > -- > 10:36 PM > > > ________________________________________________________________________________
Date: Nov 22, 2006
Subject: High at. performance
.......do you seasoned Model A fliers......? I think the question didn't elicit much response is because there are very few (if any ) Model A fliers on the list. I think there are a lot of Model A builders here, but few (if any ) fliers . The one thing that gets repeated often is that the reliability of the A is in direct proportion to the amount of hop up you do. Some of A guys have good success with this engine. Others don't and throw in the towel and go with a Cont. or something. Ken Perkins does well with his hopped up A, but has his share of forced landings. I don't know what to tell you since I haven't flown yet, except keep it LIGHT. Remember the stock A is only about 40 hp. It seams to fly a lot of Piets ok, but with little margin. My field alt. is 1500 ft and I am getting religion praying that my A will work good, Leon S. in Ks. with a Cont. 65 in the corner gathering dust..just in case. ________________________________________________________________________________
Subject: Fuselage taper point
Date: Nov 22, 2006
Ken Heide and I were discussing the "wide fuselage" options last night while gluing up the last of four fuse sides. Has anyone ever moved the taper start point to the back of the rear seat instead of at the station ahead of it? What would the issue be of keeping the 24" dimension all the way back to that point? We are building the long fuselage version and tested one side last night to be sure that it would pull in with the shorter distance. This change would be a very minimal structural change but would effectively widen the rear cockpit by 2" at the pilot's shoulders. Let the discussion begin! We are looking for pro's and con's about this possible solution. Dan Loegering Fargo, ND ________________________________________________________________________________
Date: Nov 22, 2006
Rick, Dad's corvair was putting out somewhere in the 90-100hp range with a marvel scebler ma3spa carb and no blower fan. We are located at about 1000msl in central Ohio and even on a hot day (90 +) with full fuel and me (180lbs, empty wt 732lbs with batt and starter), I can get an initial climb of 600 -700ft/min. That would put the gross wt at about....990lbs. On a 90 deg day during the test phase I climbed to 8000msl and had no problems and was still getting 200 ft/min est. as alt increased. It may have got better if we had a mixture control but that is too high out here in Ohio for practical flights,I was up there just to see if It would do it, and to cool off. Besides airliners coming in to Port Columbus Airport (20 miles south) get a little to big in the windscreen for my taste. I would guess with a single person and 10 gal of "go juice" It will climb like a heavy 150. The other good thing is at 50-55mph your not covering as much ground as you would in a 150 climbing at 75-80mph, so that runway is still below you for just a little longer if you need it. My 2 cents worth, Shad Clif Dawson wrote: Subject: Re: Pietenpol-List: Re: High density altitude airport My airport is at 6840, over 10,000 density altitude on a hot day. Am going with a Corvair (100 HP), will let you know if it's enough. I have flown 150s (also 100 HP and 1000lbs empty weight) many times with a passenger from similiar altitude airports and did ok so it should be enough. Rick --------------------------------- Rates near 39yr lows. $510,000 Loan for $1698/mo - Calculate new house payment ________________________________________________________________________________
Date: Nov 22, 2006
Don, That sounds good. I usually fly over to Wyncoop (12miles away) to get fuel,as I live on a private strip/ community in Centerburg (Chpman Memorial), and we dont have fuel here. If Barber doesn't work out I can ask Wyncoop about having it co-inside with the Waco fllys'ziz-in (ha ha). I even thought about asking the airport owner here at Chapman if we could have it here. I have about 1 acre behind my hanger to park piets. But I am guessing Bill See the airport owner won't like the idea (insurance reasons I suppose). But if any of you would like to fly into chapman I AM allowed to invite you, and piets are always welcome, and there is plenty of grass, 3100ft 28/10 runways and it is pretty smooth. By the way if Barber doesn't host it or we all want to meet at the waco fly-in also, bring a check or cash for the fuel at Wyncoop, as they don't accept plastic. However they have the best price on 100LL I saw all last summer. I believe it was only $2.20/ Gal, compared to an average of 3.00-3.50/ gal. Well group I am glad you all share the interest of a more local piet gathering. We might just have to meet up and do high speed (80mph)fly -by's in tandem at the local fly-in's one after the other like the RV guys. ( "Aircamper Overcast"). BOY, they would get mad! It would steal all there thunder to see a "Rag Bag" mock them there fast aeroplanes. Sorry to get so excited, haven't flown the Piet for a few months, Shad Don Emch wrote: It sounds like Barber could work. Making it a Pietenpol/Corvair Fly-in might be a good idea. I'll bet we could get a showing of Ford, Corvair, and Continental powered ships without too much arm twisting. If we advertise we might get more than just Buckeyes there too. With the nice weather forecast this week I may try to fly over and see Forrest and see what he thinks and if others like the idea, maybe you could bring it up at a chapter meeting Kip. What do you think Shad? Don E. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=76246#76246 --------------------------------- Mortgage rates near historic lows: $150,000 loan as low as $579/mo. Intro-*Terms ________________________________________________________________________________
Date: Nov 22, 2006
Guys, The Koch chart gives a pretty good idea of how performance is affected at higher altitude airports. A quick look at the chart show an aircraft that climbs at 500 fpm from a 50 degree sea level airport will climb at about 200 fpm from a 50 degree 6000' airport. (At 100 degrees it will drop to around 100 fpm.) Tom Bernie > Rick, Dad's corvair was putting out somewhere in the 90-100hp range > with a marvel scebler ma3spa carb and no blower fan. We are located > at about 1000msl in central Ohio and even on a hot day (90 +) with > full fuel and me (180lbs, empty wt 732lbs with batt and starter), I > can get an initial climb of 600 -700ft/min. That would put the gross > wt at about....990lbs. On a 90 deg day during the test phase I > climbed to 8000msl and had no problems and was still getting 200 > ft/min est. as alt increased. It may have got better if we had a > mixture control but that is too high out here in Ohio for practical > flights,I was up there just to see if It would do it, and to cool off. > Besides airliners coming in to Port Columbus Airport (20 miles south) > get a little to big in the windscreen for my taste. I would guess > with a single person and 10 gal of "go juice" It will climb like a > heavy 150. The other good thing is at 50-55mph your not covering as > much ground as you would in a 150 climbing at 75-80mph, so that runway > is still below you for just a little longer if you need it. > My 2 cents worth, > Shad > > Clif Dawson wrote: > Subject: Re: Pietenpol-List: Re: High density altitude > airport > > > My airport is at 6840, over 10,000 density altitude on > a hot day. Am going with a Corvair (100 HP), will let > you know if it's enough. I have flown 150s (also 100 > HP and 1000lbs empty weight) many times with a > passenger from similiar altitude airports and did ok > so it should be enough. > > Rick > > > > ________________________________________________________________________________
Date: Nov 22, 2006
Greg, Nah, forward. Peter, Don't think of it as moving the wing back, but rather moving the fuselage forward. So the imaginary point , on the wing, that the whole plane would teeter on, before moving, would be in an exact spot. After you moved the fuselage forward, now you'd have to pick a spot further forward to balance everything. hope this makes sense. If you have Windows Excel I can send you a small program, given to me, where you can just plug in all the numbers and see the final result to any plane walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: "gcardinal" <gcardinal(at)comcast.net> Sent: Wednesday, November 22, 2006 8:15 AM Subject: Re: Pietenpol-List: Weight & Balance > > The reason for moving the wing is to change the location of the airfoil's > center of lift in relation to the aircraft's center of gravity. > To answer your question, the aircraft cg will move aft when you move the > wing aft but the airfoil center of lift will move aft much more than the > cg. > > Greg C. > > ----- Original Message ----- > From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> > To: > Sent: Wednesday, November 22, 2006 6:32 AM > Subject: Pietenpol-List: Weight & Balance > > >> >> >> Hi Guys, >> >> This may be a dumb question but which way does the C of G move if you >> move >> the wing BACK! Does it follow the wing movement, i.e. move the wing back >> CG >> moves aft, move the wing forward CG moves forward? >> >> Cheers >> >> Peter >> Wonthaggi, Australia >> http://www.cpc-world.com >> >> >> -- >> 10:36 PM >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 22, 2006
We used the hub on the prop as our datum point.AME said mathematically that's the best because then it's just a matter of adding .(if my memory serves me right) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans Sent: November 22, 2006 1:48 PM Subject: Re: Pietenpol-List: Weight & Balance Greg, Nah, forward. Peter, Don't think of it as moving the wing back, but rather moving the fuselage forward. So the imaginary point , on the wing, that the whole plane would teeter on, before moving, would be in an exact spot. After you moved the fuselage forward, now you'd have to pick a spot further forward to balance everything. hope this makes sense. If you have Windows Excel I can send you a small program, given to me, where you can just plug in all the numbers and see the final result to any plane walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: "gcardinal" <gcardinal(at)comcast.net> Sent: Wednesday, November 22, 2006 8:15 AM Subject: Re: Pietenpol-List: Weight & Balance > > The reason for moving the wing is to change the location of the airfoil's > center of lift in relation to the aircraft's center of gravity. > To answer your question, the aircraft cg will move aft when you move the > wing aft but the airfoil center of lift will move aft much more than the > cg. > > Greg C. > > ----- Original Message ----- > From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> > To: > Sent: Wednesday, November 22, 2006 6:32 AM > Subject: Pietenpol-List: Weight & Balance > > >> >> >> Hi Guys, >> >> This may be a dumb question but which way does the C of G move if you >> move >> the wing BACK! Does it follow the wing movement, i.e. move the wing back >> CG >> moves aft, move the wing forward CG moves forward? >> >> Cheers >> >> Peter >> Wonthaggi, Australia >> http://www.cpc-world.com >> >> >> -- >> 10:36 PM >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 23, 2006
Walt, Thats what I am hoping. I would appreciate a copy of your spreadsheet. I have made one myself but would be good to see how you have done it. Thanks Peter. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans Sent: Thursday, 23 November 2006 5:48 AM Subject: Re: Pietenpol-List: Weight & Balance Greg, Nah, forward. Peter, Don't think of it as moving the wing back, but rather moving the fuselage forward. So the imaginary point , on the wing, that the whole plane would teeter on, before moving, would be in an exact spot. After you moved the fuselage forward, now you'd have to pick a spot further forward to balance everything. hope this makes sense. If you have Windows Excel I can send you a small program, given to me, where you can just plug in all the numbers and see the final result to any plane walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: "gcardinal" <gcardinal(at)comcast.net> Sent: Wednesday, November 22, 2006 8:15 AM Subject: Re: Pietenpol-List: Weight & Balance > > The reason for moving the wing is to change the location of the airfoil's > center of lift in relation to the aircraft's center of gravity. > To answer your question, the aircraft cg will move aft when you move the > wing aft but the airfoil center of lift will move aft much more than the > cg. > > Greg C. > > ----- Original Message ----- > From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> > To: > Sent: Wednesday, November 22, 2006 6:32 AM > Subject: Pietenpol-List: Weight & Balance > > >> >> >> Hi Guys, >> >> This may be a dumb question but which way does the C of G move if you >> move >> the wing BACK! Does it follow the wing movement, i.e. move the wing back >> CG >> moves aft, move the wing forward CG moves forward? >> >> Cheers >> >> Peter >> Wonthaggi, Australia >> http://www.cpc-world.com >> >> >> -- >> 10:36 PM >> >> >> >> >> >> >> > > > -- 10:36 PM -- 10:36 PM ________________________________________________________________________________
Date: Nov 22, 2006
Peter, Sure, I guess I can put on this reply. I didn't make it up. Someone in this group or the Fisher Flying Products group shared it with me. See if it downloads all four. I did four different setups, for all possible modes. Everything from max plane, to light pilot with heavy fuel, to heavy pilot with low fuel. It's a great little program, just highlite the square and change the value. Hit enter and the bottom line changes. I used the prop hub tip as the datum. So the distance from there to the leading edge plus the "window" on the wing , gave the final result. Say you want to add an instrument,,,,you can "add" it on paper and see the result, before you put it on. If you're designing a new plane, you put the people in the seats measuring at where the navel is in the seat. (actually they call out something else, but this is a family group) :^) Have fun walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> Sent: Wednesday, November 22, 2006 4:34 PM Subject: RE: Pietenpol-List: Weight & Balance > > > Walt, > > Thats what I am hoping. I would appreciate a copy of your spreadsheet. I > have made one myself but would be good to see how you have done it. > > Thanks > > Peter. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans > Sent: Thursday, 23 November 2006 5:48 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Weight & Balance > > > Greg, > Nah, forward. > > Peter, > Don't think of it as moving the wing back, but rather moving the fuselage > forward. > So the imaginary point , on the wing, that the whole plane would teeter > on, before moving, would be in an exact spot. > After you moved the fuselage forward, now you'd have to pick a spot > further > > forward to balance everything. > hope this makes sense. > If you have Windows Excel I can send you a small program, given to me, > where you can just plug in all the numbers and see the final result to any > plane > walt evans > NX140DL > > "Put your wealth in knowledge, and no one can ever take it from you" > Ben Franklin > ----- Original Message ----- > From: "gcardinal" <gcardinal(at)comcast.net> > To: > Sent: Wednesday, November 22, 2006 8:15 AM > Subject: Re: Pietenpol-List: Weight & Balance > > >> >> The reason for moving the wing is to change the location of the airfoil's >> center of lift in relation to the aircraft's center of gravity. >> To answer your question, the aircraft cg will move aft when you move the >> wing aft but the airfoil center of lift will move aft much more than the >> cg. >> >> Greg C. >> >> ----- Original Message ----- >> From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> >> To: >> Sent: Wednesday, November 22, 2006 6:32 AM >> Subject: Pietenpol-List: Weight & Balance >> >> >>> >>> >>> Hi Guys, >>> >>> This may be a dumb question but which way does the C of G move if you >>> move >>> the wing BACK! Does it follow the wing movement, i.e. move the wing back >>> CG >>> moves aft, move the wing forward CG moves forward? >>> >>> Cheers >>> >>> Peter >>> Wonthaggi, Australia >>> http://www.cpc-world.com >>> >>> >>> -- >>> 10:36 PM >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > -- > 10:36 PM > > > -- > 10:36 PM > > > ________________________________________________________________________________
Date: Nov 23, 2006
Walt, Thanks very much, I'll give them a try. Cheers Peter. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans Sent: Thursday, 23 November 2006 9:22 AM Subject: Re: Pietenpol-List: Weight & Balance Peter, Sure, I guess I can put on this reply. I didn't make it up. Someone in this group or the Fisher Flying Products group shared it with me. See if it downloads all four. I did four different setups, for all possible modes. Everything from max plane, to light pilot with heavy fuel, to heavy pilot with low fuel. It's a great little program, just highlite the square and change the value. Hit enter and the bottom line changes. I used the prop hub tip as the datum. So the distance from there to the leading edge plus the "window" on the wing , gave the final result. Say you want to add an instrument,,,,you can "add" it on paper and see the result, before you put it on. If you're designing a new plane, you put the people in the seats measuring at where the navel is in the seat. (actually they call out something else, but this is a family group) :^) Have fun walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> Sent: Wednesday, November 22, 2006 4:34 PM Subject: RE: Pietenpol-List: Weight & Balance > > > Walt, > > Thats what I am hoping. I would appreciate a copy of your spreadsheet. I > have made one myself but would be good to see how you have done it. > > Thanks > > Peter. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans > Sent: Thursday, 23 November 2006 5:48 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Weight & Balance > > > Greg, > Nah, forward. > > Peter, > Don't think of it as moving the wing back, but rather moving the fuselage > forward. > So the imaginary point , on the wing, that the whole plane would teeter > on, before moving, would be in an exact spot. > After you moved the fuselage forward, now you'd have to pick a spot > further > > forward to balance everything. > hope this makes sense. > If you have Windows Excel I can send you a small program, given to me, > where you can just plug in all the numbers and see the final result to any > plane > walt evans > NX140DL > > "Put your wealth in knowledge, and no one can ever take it from you" > Ben Franklin > ----- Original Message ----- > From: "gcardinal" <gcardinal(at)comcast.net> > To: > Sent: Wednesday, November 22, 2006 8:15 AM > Subject: Re: Pietenpol-List: Weight & Balance > > >> >> The reason for moving the wing is to change the location of the airfoil's >> center of lift in relation to the aircraft's center of gravity. >> To answer your question, the aircraft cg will move aft when you move the >> wing aft but the airfoil center of lift will move aft much more than the >> cg. >> >> Greg C. >> >> ----- Original Message ----- >> From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> >> To: >> Sent: Wednesday, November 22, 2006 6:32 AM >> Subject: Pietenpol-List: Weight & Balance >> >> >>> >>> >>> Hi Guys, >>> >>> This may be a dumb question but which way does the C of G move if you >>> move >>> the wing BACK! Does it follow the wing movement, i.e. move the wing back >>> CG >>> moves aft, move the wing forward CG moves forward? >>> >>> Cheers >>> >>> Peter >>> Wonthaggi, Australia >>> http://www.cpc-world.com >>> >>> >>> -- >>> 10:36 PM >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > -- > 10:36 PM > > > -- > 10:36 PM > > > -- 10:36 PM -- 10:36 PM ________________________________________________________________________________
Date: Nov 22, 2006
Peter, Before all this fancy computer stuff (but still using a calculator), I did the weight & balance like I show on this web page: http://nx770cg.com/OperationsManual.html Scroll down to the bottom of the page, and see all possible loading configurations. I use the firewall as the datum (per plans), so there will be some negative numbers when doing the calculations. The reason, by today's standards, they put the datum ahead of the prop, is that there will be no negative numbers. Walt always has the good explanation of what happens when you move the wing: You're not actually moving the wing aft...what you are really doing is moving the fuselage forward. Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 22, 2006
Subject: Re: Fuselage taper point
In a message dated 11/22/2006 9:55:44 AM Central Standard Time, danl(at)odayequipment.com writes: Ken Heide and I were discussing the "wide fuselage" options last night while gluing up the last of four fuse sides. Has anyone ever moved the taper start point to the back of the rear seat instead of at the station ahead of it? What would the issue be of keeping the 24" dimension all the way back to that point? We are building the long fuselage version and tested one side last night to be sure that it would pull in with the shorter distance. This change would be a very minimal structural change but would effectively widen the rear cockpit by 2" at the pilot's shoulders. Let the discussion begin! We are looking for pro's and con's about this possible solution. Dan Loegering Fargo, ND Dan, I don't know why anybody would even want to widen the fuselage. That shouldn't even be an option. The plans dimensions get the job done, and keeps it as light as possible. I have the short fuse, plans width, and I am 6' tall, and go about 215 lbs. Once I'm snuggled down in the cockpit, it's plenty roomy enough. I even have enough room to keep a fire extinguisher, fuel sump tool, and E.L.T. by my left hip, and four rolls of T.P. and a bottle of water by my right hip. If you move the taper starting point to the back of the rear seat, the radius of the sides curving in will be much more dramatic, look odd, and not to mention how it Will Affect the aerodynamics...most likely by blanking out some of the inboard horizontal tail with turbulence. Also, it doesn't seem the longerons could handle that radius, unless you steamed them. Moist Heat is what is required to make curved wood. If you go that route, you better be mighty careful...or you're gonna hear a loud 'CRACK' !! All right...I'll say it again - "Build it to the plans !!" Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 22, 2006
Chuck, Nah, Just passing along the explanation that someone else told me , and my simple brain could pick it up. Just kind of makes sense. Chuck, If I didn't tell you before, let me tell you now,,,that your video was great. Lots of great stuff on building, and a must for the new builders. Those TP drops were a blast. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: Rcaprd(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, November 22, 2006 6:08 PM Subject: Re: Pietenpol-List: Weight & Balance Peter, Before all this fancy computer stuff (but still using a calculator), I did the weight & balance like I show on this web page: http://nx770cg.com/OperationsManual.html Scroll down to the bottom of the page, and see all possible loading configurations. I use the firewall as the datum (per plans), so there will be some negative numbers when doing the calculations. The reason, by today's standards, they put the datum ahead of the prop, is that there will be no negative numbers. Walt always has the good explanation of what happens when you move the wing: You're not actually moving the wing aft...what you are really doing is moving the fuselage forward. Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 22, 2006
I pretty much agree with Chuck and I remember a past comment from Mike Cuy that "It fits me like a glove". I don't see much reason to go wider, it just adds weight. The exception is that the long fuse with the A-65 would have been better for W/B. Dick N. I don't know why anybody would even want to widen the fuselage. That shouldn't even be an option. The plans dimensions get the job done, and keeps it as light as possible. I have the short fuse, plans width, and I am 6' tall, and go about 215 lbs. Once I'm snuggled down in the cockpit, it's plenty roomy enough. I even have enough room to keep a fire extinguisher, fuel sump tool, and E.L.T. by my left hip, and four rolls of T.P. and a bottle of water by my right hip. If you move the taper starting point to the back of the rear seat, the radius of the sides curving in will be much more dramatic, look odd, and not to mention how it Will Affect the aerodynamics...most likely by blanking out some of the inboard horizontal tail with turbulence. Also, it doesn't seem the longerons could handle that radius, unless you steamed them. Moist Heat is what is required to make curved wood. If you go that route, you better be mighty careful...or you're gonna hear a loud 'CRACK' !! All right...I'll say it again - "Build it to the plans !!" Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 22, 2006
Don't know, what is the wing area diff? On 11/21/06, Clif Dawson wrote: > > Don't forget the difference in wing area. > > And don't forget, that 100 hp Lyc or Continental > started out life at the factory door with only 80 > true horsepower. > > Put those two together and what do you get? > > Clif > > *Subject:* Re: Pietenpol-List: Re: High density altitude airport > > My airport is at 6840, over 10,000 density altitude on a hot day. Am going > with a Corvair (100 HP), will let you know if it's enough. I have flown 150s > (also 100 HP and 1000lbs empty weight) many times with a passenger from > similiar altitude airports and did ok so it should be enough. > > Rick > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 22, 2006
Consider yourself a catylist. Isn't that what makes things happen? Clif :-) ----- Original Message ----- From: harvey.rule(at)bell.ca To: pietenpol-list(at)matronics.com Sent: Wednesday, November 22, 2006 3:59 AM Subject: RE: Pietenpol-List: The correct spelling is advice..... You'll learn nothing from me but lots from those who pick up on my mistakes and I like to jump right in there with both feet and I make a lot of em.Glad to be of service in an inverse way.Keep em flizing. ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Nov 23, 2006
In a message dated 11/22/2006 5:43:26 PM Central Standard Time, waltdak(at)verizon.net writes: Chuck, If I didn't tell you before, let me tell you now,,,that your video was great. Lots of great stuff on building, and a must for the new builders. Those TP drops were a blast. Thanks, Walt. I'm still working on a trailer for 'Flying NX770CG' to put up on YouTube or Google video, to try to drum up some sales...which dropped off to almost nothing. I guess just about everyone on the list has it, so now it's time to branch out to the general population, and show them the thrills of flying a Pietenpol - Low & Slow !! Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 23, 2006
Walt/Greg, I moved the wing back about three inches today. It made a difference (forward) of about five inches. I can now make up my front cabane struts and be happy. I'll do another complete W&B after the struts are fitted. Many thanks Peter. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans Sent: Thursday, 23 November 2006 9:22 AM Subject: Re: Pietenpol-List: Weight & Balance Peter, Sure, I guess I can put on this reply. I didn't make it up. Someone in this group or the Fisher Flying Products group shared it with me. See if it downloads all four. I did four different setups, for all possible modes. Everything from max plane, to light pilot with heavy fuel, to heavy pilot with low fuel. It's a great little program, just highlite the square and change the value. Hit enter and the bottom line changes. I used the prop hub tip as the datum. So the distance from there to the leading edge plus the "window" on the wing , gave the final result. Say you want to add an instrument,,,,you can "add" it on paper and see the result, before you put it on. If you're designing a new plane, you put the people in the seats measuring at where the navel is in the seat. (actually they call out something else, but this is a family group) :^) Have fun walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> Sent: Wednesday, November 22, 2006 4:34 PM Subject: RE: Pietenpol-List: Weight & Balance > > > Walt, > > Thats what I am hoping. I would appreciate a copy of your spreadsheet. I > have made one myself but would be good to see how you have done it. > > Thanks > > Peter. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans > Sent: Thursday, 23 November 2006 5:48 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Weight & Balance > > > Greg, > Nah, forward. > > Peter, > Don't think of it as moving the wing back, but rather moving the fuselage > forward. > So the imaginary point , on the wing, that the whole plane would teeter > on, before moving, would be in an exact spot. > After you moved the fuselage forward, now you'd have to pick a spot > further > > forward to balance everything. > hope this makes sense. > If you have Windows Excel I can send you a small program, given to me, > where you can just plug in all the numbers and see the final result to any > plane > walt evans > NX140DL > > "Put your wealth in knowledge, and no one can ever take it from you" > Ben Franklin > ----- Original Message ----- > From: "gcardinal" <gcardinal(at)comcast.net> > To: > Sent: Wednesday, November 22, 2006 8:15 AM > Subject: Re: Pietenpol-List: Weight & Balance > > >> >> The reason for moving the wing is to change the location of the airfoil's >> center of lift in relation to the aircraft's center of gravity. >> To answer your question, the aircraft cg will move aft when you move the >> wing aft but the airfoil center of lift will move aft much more than the >> cg. >> >> Greg C. >> >> ----- Original Message ----- >> From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> >> To: >> Sent: Wednesday, November 22, 2006 6:32 AM >> Subject: Pietenpol-List: Weight & Balance >> >> >>> >>> >>> Hi Guys, >>> >>> This may be a dumb question but which way does the C of G move if you >>> move >>> the wing BACK! Does it follow the wing movement, i.e. move the wing back >>> CG >>> moves aft, move the wing forward CG moves forward? >>> >>> Cheers >>> >>> Peter >>> Wonthaggi, Australia >>> http://www.cpc-world.com >>> >>> >>> -- >>> 10:36 PM >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > -- > 10:36 PM > > > -- > 10:36 PM > > > -- 10:36 PM -- 5:41 PM ________________________________________________________________________________
Date: Nov 23, 2006
Would think that wing loading would be more relevent than wing area. Rick On 11/21/06, Clif Dawson wrote: > > Don't forget the difference in wing area. > > And don't forget, that 100 hp Lyc or Continental > started out life at the factory door with only 80 > true horsepower. > > Put those two together and what do you get? > > Clif > > *Subject:* Re: Pietenpol-List: Re: High density altitude airport > > My airport is at 6840, over 10,000 density altitude on a hot day. Am going > with a Corvair (100 HP), will let you know if it's enough. I have flown 150s > (also 100 HP and 1000lbs empty weight) many times with a passenger from > similiar altitude airports and did ok so it should be enough. > > Rick > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: control cables
Date: Nov 23, 2006
I am at the "bolt it together and string the cables before covering" stage. When I remove the wings, how do I disassemble the aileron cables through the pulleys in the center section after I have installed the ends for fastening to the control stick? Carol and Ralph Raymond ________________________________________________________________________________
Date: Nov 23, 2006
Subject: Re: control cables
In a message dated 11/23/2006 9:34:41 AM Central Standard Time, ralphhsd(at)itctel.com writes: When I remove the wings, how do I disassemble the aileron cables through the pulleys in the center section after I have installed the ends for fastening to the control stick? Ralph, Don't terminate the ends of the cables, till final assembly. Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 23, 2006
Another alternative is to remove the pully wheel but that is a pain in the ass.it can be done but harder to put back together especially after covering.Where my pullies are located at an inspection hole made in the fabric using half a cover cap to cover half the hole.If you blow up the second pic you can see the half hole covers.You have to have small hands to take it apart and put it back together but it can be done.Ya just snag some kid that's runnin around the field and bribe him to help ya out. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rcaprd(at)aol.com Sent: November 23, 2006 10:50 AM Subject: Re: Pietenpol-List: control cables In a message dated 11/23/2006 9:34:41 AM Central Standard Time, ralphhsd(at)itctel.com writes: When I remove the wings, how do I disassemble the aileron cables through the pulleys in the center section after I have installed the ends for fastening to the control stick? Ralph, Don't terminate the ends of the cables, till final assembly. Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 23, 2006
From: Tim Verthein <minoxphotographer(at)yahoo.com>
Subject: Long Newguy Introduction
Hi All! Been lurking for some time now, figured I should stick my hand out and say Howdy! I tend to get winded, so better grab some more food and relax.... Tim is the name, my wife is Ronna, and we're in Bovey Minnesota, just 7 miles up the Iron Range from Grand Rapids, and about 70 miles NW of Duluth. I always sign off as "Tim in Bovey" on the various lists I belong to to avoid confusion with the plethora of other Tims out there. Our aviation interests go back a long ways. Dad was a PP, hasn't flown for years now, he's 78. Ronna grew up in Roundup, MT, with a close family friend who owned/operated the airport there and they used to fly a lot. I spent tons of time as a kid thru teen years flying with Dad in 120, 140, 172, a Mooney and a T-Craft (those are the ones I can remember anyway). I have always wanted to get my PP but due to many things, mostly time, money and medical issues, never did more than a few hours of dual for the fun of it. I'd been watching the LSP develop over the past few years and did a big YIPEEE! when it went thru. So, we are both intending on getting LSP tickets in the near future. In the meantime.... We've deicded to build airplanes. Attracted by the greatly reduced cost compared to buying a certified plane, the fact that we can do our own repairs/maintenence, and that we can spread the cost over time, buying what we need as we build, no financing is going to be necessary. All in all, a good deal! We decided to build a Zenith CH-701, all aluminum STOL plane, after researching tons and tons of planes/kits. We went to the Zenith workshop in October, got some demo flights in, and built the rudder, and we're ready to proceed. I figured minimum 2+ years to completion. Haven't decided yet, but leaning toward Jabiru power, as I like the concept better than the Rotax, and don't want to go Corvair with this plane for several reasons. Anyway.... Somewhere along the way in the past couple months I discovered the Pietenpol, and it's really grabbed me by the..well..you know the phrase....ordered the info pack from Don, read a ton of magazine articles, AND about 70% of the digests for this list (just a year to go and I'm all caught up with you guys). So, anyway, we've decided to build a Piet too, at the same time. When we're saving up cash, or hiding indoors because it's 40 below zero out in the garage and we don't want to be working on the Zenith, we can be in the basement making ribs and tail feathers. I built a lot of R/C and C/L models in my day, and it will be nice to work in 1:1 scale! I'm already thinking Corvair power for the Piet because.... I also happen to be a Corvair driver. My Son is too. I have a '64, he has 2 65's. I drive mine as a daily driver except in the worst of winter and also autocross it. I'm thinking along the lines of a complete, ready to run Corvair from flycorvair, simply because they, to me, are a heck of a good deal, and I have complete faith in the powerplant, and am familier with repair/upkeep for them. So, that's my story. I'm sure we'll have lots of questions as time goes on. It appears there are some grey areas in the plans, and I'm sure I'll make a tweak here or there myself as I bet most of you do. We're regular Oshkosh attendees, and excited about the Brodhead event too. We have a local EAA chapter that's pretty active. I haven't been able to hook up with them yet....busy busy busy...but will soon. I figure I better get on the waiting list for a hanger over in Grand Rapids, too, since it's about a 2 year wait and we'll need some serious space by then! Can anyone recommend some good books about the Pietenpol, and wood plane building in general? I have a few already, but I bet there's more out there. We're prepared for projects that will take time, but be a great husband/wife adventure! And we'll be able to get Dad's trusty Shopsmith out of mothballs (anyone else remember the Shopsmith?) BTW, I too was concerned about fiting in a Piet, as I was about a 701 for that matter. I'm 6'2". A year ago I weighed 290. When I decided it was time to fly, get healthy, get my BP under control, and stop being pooped out by the time I got to the top of the stairs....I've got myself down to 185! Best way to improve several things, health, autocross handling in a Corvair, and flight charasterics! Most fun I've ever had flying, was riding with the Red Baron Squadron (yes, the Pizza guys) in their Stearman. They were here for a promotional event (I spose I should mention...I'm the morning radio show host in Grand Rapids..so I get all the media perks..I've been on the air somewhere for 31 years now....in GR for 19...check us out at http://www.kozyradio.com you can listen to some morning show podcasts if you're up to it) Anyway, when I got to the airport to fly with them..the pilot took one look at me and said "Not till this afternoon" They had just arrived after about a 60 mile flight, and their tanks were almost full. With me at about 290 back then...they wouldn't stunt with that much weight! So had to come back 4 hours later after they had done a bunch of rides for kids and whatnot..so the planes were lighter....but got the full treatment....hammerhead stall, loops, rolls, wingover..it was GREAT! I knew it would be interesting before we took off, as he was fitting the parachute to my butt and explaing how to work it..he said "If I say 'bailout! bailout! bailout!' 3 times like that, I mean it". What a thrill THAT was! If you're *really* got time to kill, have a look at my web page at: http://www.edselmotors.com (yes, we also own an Edsel) There a bunch of Corvair stuff there, and lots of other time killing stuff. I plan on adding a flying section eventually. I have a teensey weensey bit of flying stuff still posted at my ancient old web page at: http://www.uslink.net/~hepcats/planes.html Tim in Bovey == You *can* repair a flip-flop with a capacitor! == Cheap talk? ________________________________________________________________________________
Date: Nov 23, 2006
Subject: Re: Long Newguy Introduction
In a message dated 11/23/2006 5:42:53 P.M. Eastern Standard Time, minoxphotographer(at)yahoo.com writes: http://www.edselmotors.com Hi Tim, Like you I been watching and reading about the Piet since I first saw it on a TV special, cant remember which , but like you it grabbed me and I was captivated by it. Funny thing is that I look at the 172 but my interests always go back to the Piet. I finally bit the bullet and got a set of plans in May of this year and have been deeply involved in research, really enjoying visiting other builders and owners across the country, taking pics and asking questions. Although I have not begun my build as of yet I am doing the reading got Tony's books real informative and full of great build tips. Chucks DVD is also a good resource. The good news is that there is a bunch of support and help here. Best of luck in your build! John Hey really loved the Edsel. Thanks ________________________________________________________________________________
Subject: 41CC is headed south
Date: Nov 23, 2006
Well, tomorrow (Friday) is the big day. The airplane is outside on the trailer, hitched up and ready to go down to Zapata County Airport where the wings have been quietly resting in a hangar for a bit over two years now (yes, two years!). I have all the tools, hardware, wing struts, everything ready to roll. Tomorrow I'll trailer the airplane down and reattach the wings and try to get them re-rigged in preparation for a new W&B and annual. Everything is ready. Something to give thanks for, you can be sure! Also want to give thanks for Corky, Mikee, Chuck, Walt, Shad, Dick, Doc, Tim, Jack, Sterling, and everybody else who has coaxed me along for two years during the repair and rebuild. You guys are great, and so is this list. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ View Athletes Collections with Live Search http://sportmaps.live.com/index.html?source=hmemailtaglinenov06&FORM=MGAC01 ________________________________________________________________________________
Subject: Cutout at tailpost, any great tips?
Date: Nov 23, 2006
I have my fuse sides done! http://www.subarubrat.com/misc/pietfuse3.jpg And I was wondering if there is any great trick to use to cut the "wedge" out at the tail post where they join? -Scott ________________________________________________________________________________
Date: Nov 23, 2006
Subject: Re: 41CC is headed south
Oscar, Good for you. Keep us posted on the progress. Us "nawtherners" are in awe of you guys down South for two things,,,warm weather,,,and Corky's Shrimp Gumbo. Hope this post finds all members of the group and their families well and happy after their Dinner. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Thursday, November 23, 2006 7:01 PM Subject: Pietenpol-List: 41CC is headed south > > > Well, tomorrow (Friday) is the big day. The airplane is outside on the > trailer, hitched up and ready to go down to Zapata County Airport where > the wings have been quietly resting in a hangar for a bit over two years > now (yes, two years!). I have all the tools, hardware, wing struts, > everything ready to roll. Tomorrow I'll trailer the airplane down and > reattach the wings and try to get them re-rigged in preparation for a new > W&B and annual. Everything is ready. > > Something to give thanks for, you can be sure! Also want to give thanks > for Corky, Mikee, Chuck, Walt, Shad, Dick, Doc, Tim, Jack, Sterling, and > everybody else who has coaxed me along for two years during the repair and > rebuild. You guys are great, and so is this list. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > View Athlete's Collections with Live Search > http://sportmaps.live.com/index.html?source=hmemailtaglinenov06&FORM=MGAC01 > > > ________________________________________________________________________________
Date: Nov 23, 2006
Subject: Re: Cutout at tailpost, any great tips?
Nice shot Scott! Wow is the only thing I can say! How roughly did that take you? just curious?=0A=0ABen=0A=0A=0A----- Original Message ----=0AFrom: Sc ott Schreiber =0ATo: pietenpol-list(at)matronics.com=0A Sent: Thursday, November 23, 2006 6:02:52 PM=0ASubject: Pietenpol-List: Cut out at tailpost, any great tips?=0A=0A=0AI have my fuse sides done! http:// www.subarubrat.com/misc/pietfuse3.jpg And I was wondering if there is any g reat trick to use to cut the "wedge" out at the tail post where they join? -======================== =============0A=0A=0A =0A__________________________ .yahoo.com ________________________________________________________________________________
Date: Nov 23, 2006
Scott Thats a job that seems simple, but it's one of those technical things that has to be done right. You will need to make a straight line on your jig and block the fuse in place. Find the center line of all the cross members that you have installed so far. Make sure each member and the tail post falls exactly on the centerline. Then there are a couple of ways to proceed. with the halves together, make a mark on each half to rough cut with a hand plane or use a small saw. Re-fit the halves and if they are somewhat close, use a belt from a belt sander, cut open, 80 grit and pull it back and forth to final fit. Others may have diffrent methods of sanding or cutting but there is no shortcut on getting your fuse trued up straight. Dick N. ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Thursday, November 23, 2006 6:02 PM Subject: Pietenpol-List: Cutout at tailpost, any great tips? I have my fuse sides done! http://www.subarubrat.com/misc/pietfuse3.jpg And I was wondering if there is any great trick to use to cut the "wedge" out at the tail post where they join? -Scott ________________________________________________________________________________
Date: Nov 23, 2006
Ralph wrote- >When I remove the wings, how do I disassemble the aileron cables >through the pulleys in the center section after I have installed the ends >for fastening to the control stick? Not sure what you're asking, but I will tell you that the wings are presently removed from 41CC and it was very convenient that Corky provided access covers and cable links just at the wing roots to allow the aileron cables to be disconnected and the wings removed without pulling the cables through the pulleys. Harder to describe than to do, but I can take pictures if it would help and if we're talking about the same thing. To disconnect the wings, I cut the safety wires from the turnbuckles at the bellcranks down at the joystick in the cockpit, backed the tension off the aileron cables, removed the inspection covers on the undersides of the wings, disconnected the aileron cable connector links (like motorcycle chain links), and voila-! that, plus the pitot tube line, and the wings came right off. There are links connecting the two aileron cables plus the cable that connects the port and starboard ailerons across the top. FWIW, Corky cautioned me about not removing one wing at a time. He recommended that I lower both wingtips to the ground first, then remove one wing and the other. If you remove one wing at a time you may end up with the airplane tipping over onto one wingtip. Fortunately, we had lots of cardboard boxes full of stored stuff to stack up under the wings to support them while we worked. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ MSN Shopping has everything on your holiday list. Get expert picks by style, age, and price. Try it! http://shopping.msn.com/content/shp/?ctId00,ptnrid=176,ptnrdata 0601&tcode=wlmtagline ________________________________________________________________________________
Date: Nov 23, 2006
The same is true with giant scale R/C, I am fine with the process, what I was reffering to in specific is the actual cutting of the tail post area. When you talking about 1/2x1/4 spruce and 1/4 by 1/4 balsa it is a simple matter of a razor saw. I was wondering if some great method had been worked out. -Scott ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: Thursday, November 23, 2006 9:20 PM Subject: Re: Pietenpol-List: Cutout at tailpost, any great tips? Scott Thats a job that seems simple, but it's one of those technical things that has to be done right. You will need to make a straight line on your jig and block the fuse in place. Find the center line of all the cross members that you have installed so far. Make sure each member and the tail post falls exactly on the centerline. Then there are a couple of ways to proceed. with the halves together, make a mark on each half to rough cut with a hand plane or use a small saw. Re-fit the halves and if they are somewhat close, use a belt from a belt sander, cut open, 80 grit and pull it back and forth to final fit. Others may have diffrent methods of sanding or cutting but there is no shortcut on getting your fuse trued up straight. Dick N. ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Thursday, November 23, 2006 6:02 PM Subject: Pietenpol-List: Cutout at tailpost, any great tips? I have my fuse sides done! http://www.subarubrat.com/misc/pietfuse3.jpg And I was wondering if there is any great trick to use to cut the "wedge" out at the tail post where they join? -Scott href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Nov 23, 2006
Subject: Re: High density altitude airport
Of course it would. You need the two plane's areas before you can calculate loadings. And loading depends on the gross weight of each aircraft. Notice I did not say maximum gross. Since you've got access to a 150 why not measure the wing next time you're out and go from there? At this point we know that we have a heavier AC with 80 HP minus age and density factors against a lighter one with 100 HP minus the same factors. We have a pretty good idea of the wing size of the Piet, depending on any changes you might or might not decide to make. Now we need the wing area of the 150 after which we can begin making comparisons. Clif ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, November 23, 2006 7:19 AM Subject: Re: Pietenpol-List: Re: High density altitude airport Would think that wing loading would be more relevent than wing area. Rick On 11/21/06, Clif Dawson wrote: Don't forget the difference in wing area. And don't forget, that 100 hp Lyc or Continental started out life at the factory door with only 80 true horsepower. Put those two together and what do you get? Clif Subject: Re: Pietenpol-List: Re: High density altitude airport My airport is at 6840, over 10,000 density altitude on a hot day. Am going with a Corvair (100 HP), will let you know if it's enough. I have flown 150s (also 100 HP and 1000lbs empty weight) many times with a passenger from similiar altitude airports and did ok so it should be enough. Rick www.aeroelectric.com http://www.matronics.com/Navigator?Pietenpol-List -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ------------------------------------------------------------------------- ----- 11/23/2006 3:22 PM ________________________________________________________________________________
Date: Nov 24, 2006
Subject: More Great List Comments - Please Make A Contribution!
Dear Listers, There's a little less than one week left for this year's List Fund Raiser. I thought it would a great time to share a few more of the great comments I've been receiving from Contributors regarding what the Lists mean to them. There are some particularly poignant ones in this batch and I encourage you to have a look at some of them. Don't forget that once you make your Contribution, the Contribution Squelch kicks in and you won't receive any future messages from me regarding the Fund Raiser this year! This holds true for the Realtime and Digest distributions and now also the HTML and TXT links included with the Digest! (Note that for technical reasons, if someone replies to one of my contribution messages, the Squelch will _not_ be activated, and you will still receive it. Contribution messages will also still be found on the Forums site and the List Browse). Please make your Contribution today to support these List services! Pick up a great Gift too! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ============================= WLAS #2 ============================ Tackling my project without the List would be like building on a deserted island. The List has made me part of a learning (and laughing) community. -Larry W Thank you for providing such a fantastic resource for us Kolbers. I'm very happy to contribute towards keeping such a wonderful resource available. -Geoff T ..you do a great service for the flying community by providing this service. -John L ..solidly administered. -James C A great source of information. -Ralph S The Lists have likely saved a numbers of lives... -James F ..exceptional user service. -Larry W Better than a magazine! -Aaron G Thanks to your List I will be able to finish and fly my project. Without the help of the great people on your List I doubt it would have happened. -Ed G I learn something on a too regular basis thanks to these lists! -Ralph C ..valuable service. -John F ..a well administered service. -Stewart C Great forum! -Ronald C A great service! -Andy H Been reading the lists since my first RV in 1999. Good work and as necessary to me as a rivet. -Albert G The lists are a great help. -Gary S This resource has been critical to my building success so far. -Timothy F Great system and support! -Richard P Very helpful in the building my CH 701. -Ralph S Another year of entertainment and pleasure! -Larry B A great resource for all of us. -Larry W Another year of great service! Once again, the information is worth more than I can ever contribute. Thank you also for the "community" that the List fosters. I cannot tell you the number of times that seeing an friend's name come up has caused so many awesome memories to come flooding back - along with the eager desire to gather with these great guys again. I love hearing the beginner's enthusiasm, the builder's progress, and the flyer's success... -Robert B Our list has great info and I love reading the "Flame Posts! " -Stephen M Great service! -James B Excellent source of information. -David P You provide a very valuable service to the aviation community. -David H The RV related lists have been a tremendous help in the construction of my RV-7... -Norman R Awesome list!! -John E Great bunch of guys and very knowledgeable! -Herbert G Thank you for making it so easy to stay in touch with my fellow RV-10 builders. -David J I love the list and have been a reader for a long time. -James V Continues to be a great service! -George A Awesome List server. -Deke M Many of us would never finish our airplanes without [the List]. With it, I'm getting close! -Ronald C An excellent source of both information and inspiration! -William R Forums and format are easy to use. -Jack B Great help with my kit building. -Ralph H Super service. -Richard N Still loving it. -Jared S You have a fantastic web! -Harvey R ..a great service. -James M Glad you are there... -David A I get some great information on your list. -John P Fantastic service. Couldn't have made it as far as I have without it. -Stephen T A great learning experience with my RV-6A. -Ron B Great resources! -Jason H Well done. Very valuable. -Jeffrey D Great resource for the experimental aircraft community. -Chris H This List has been one of the most helpful tools in building my RV-10, since I build alone, and do not have any help readily available. Without the List, I could not have embarked on building my RV-10. -Jim H You run a great list there. -James H Really like the Kolb List. -Don W ============================= WLAS #2 ============================ ________________________________________________________________________________
Date: Nov 24, 2006
Welcome aboard! ________________________________________________________________________________
From: "Joseph Czaplicki" <fishin3(at)earthlink.net>
Subject: 41CC headed south
Date: Nov 24, 2006
Glad to hear 41CC is getting ready for flight again. Then looking forward to seeing her at Brodhead in 07. Back north to the land of her birth. She may have been raised in the south but she was born in the cold north JoeC N94634 N22498 From: "Oscar Zuniga" <taildrags(at)hotmail.com> Subject: Pietenpol-List: 41CC is headed south Well, tomorrow (Friday) is the big day. The airplane is outside on the > trailer, hitched up and ready to go down to Zapata County Airport where the > wings have been quietly resting in a hangar for a bit over two years now > (yes, two years!). I have all the tools, hardware, wing struts, everything > ready to roll. Tomorrow I'll trailer the airplane down and reattach the > wings and try to get them re-rigged in preparation for a new W&B and annual. > Everything is ready. > > Something to give thanks for, you can be sure! Also want to give thanks for > Corky, Mikee, Chuck, Walt, Shad, Dick, Doc, Tim, Jack, Sterling, and > everybody else who has coaxed me along for two years during the repair and > rebuild. You guys are great, and so is this list. > > Oscar Zuniga San Antonio, TX ________________________________________________________________________________
Date: Nov 24, 2006
Subject: Long intro. new guy
Welcome: I too planned on 2 years to build my Piet. I'm in year 8 now. I am collecting parts for a next project now but I am not building 2 airplanes at one time. Unless you have NO other responsibilities, family, or job you might be able to assemble a turnkey 701 kit in a short period of time. There is no quick build turnkey Piet kit out there that I know of. Double your build time guess and you may be on the ball park. The books by Tony Bengilis are a must have. EAA also has other books on wood and aircraft construction that are good. Good luck, Welcome and happy building. Leon S. Ks. PS the Piet plans are lousy ________________________________________________________________________________
Date: Nov 24, 2006
Hello Tim You must be retired to have the time to take on two airplane projects at once (or very disiplined). Anyhow I think you will have an ideal combination (especially for Minnesota), open cockpit Piet for fun on the warmer days (thats anything above 0 in MN), and the 701 for the rest of the time. Looks like a Covair engine is a natural for someone as interested in Covair cars as you are. I am building a long fuselage Piet with a Corvair conversion using most of the parts that William Wynne sells. You probably know about William Wynne's 601 Corvair, did you know he has a 701 kit that he is about to start on which is of course going to use Corvair power. He is also going to develop a firewall forward kit for it as he has for the 601 (including mount, engine shrouding, a separate manual, and other stuff). Dick Navratil is a regular on this newsgroup and is currently working on his second Piet with a Rotec engine and I believes he lives near Minneapolis. You may want to look him up if he is not too far from you. As far as good reference material get all four of the Bengelis books, the new Pietenpol Story book by Chet Peek (his email is in the archives), and Mike Cuy's and Chuck Gantzer's videos. Congradulations, you have chosen two excellent to aircraft to build. Rick On 11/23/06, Tim Verthein wrote: > > minoxphotographer(at)yahoo.com> > > Hi All! > Been lurking for some time now, figured I should stick my hand out and > say Howdy! I tend to get winded, so better grab some more food and > relax.... > > Tim is the name, my wife is Ronna, and we're in Bovey Minnesota, just 7 > miles up the Iron Range from Grand Rapids, and about 70 miles NW of > Duluth. I always sign off as "Tim in Bovey" on the various lists I > belong to to avoid confusion with the plethora of other Tims out there. > > Our aviation interests go back a long ways. Dad was a PP, hasn't flown > for years now, he's 78. Ronna grew up in Roundup, MT, with a close > family friend who owned/operated the airport there and they used to fly > a lot. I spent tons of time as a kid thru teen years flying with Dad > in 120, 140, 172, a Mooney and a T-Craft (those are the ones I can > remember anyway). I have always wanted to get my PP but due to many > things, mostly time, money and medical issues, never did more than a > few hours of dual for the fun of it. I'd been watching the LSP develop > over the past few years and did a big YIPEEE! when it went thru. So, > we are both intending on getting LSP tickets in the near future. In > the meantime.... > > We've deicded to build airplanes. Attracted by the greatly reduced > cost compared to buying a certified plane, the fact that we can do our > own repairs/maintenence, and that we can spread the cost over time, > buying what we need as we build, no financing is going to be necessary. > All in all, a good deal! We decided to build a Zenith CH-701, all > aluminum STOL plane, after researching tons and tons of planes/kits. > We went to the Zenith workshop in October, got some demo flights in, > and built the rudder, and we're ready to proceed. I figured minimum 2+ > years to completion. Haven't decided yet, but leaning toward Jabiru > power, as I like the concept better than the Rotax, and don't want to > go Corvair with this plane for several reasons. Anyway.... > > Somewhere along the way in the past couple months I discovered the > Pietenpol, and it's really grabbed me by the..well..you know the > phrase....ordered the info pack from Don, read a ton of magazine > articles, AND about 70% of the digests for this list (just a year to go > and I'm all caught up with you guys). So, anyway, we've decided to > build a Piet too, at the same time. When we're saving up cash, or > hiding indoors because it's 40 below zero out in the garage and we > don't want to be working on the Zenith, we can be in the basement > making ribs and tail feathers. I built a lot of R/C and C/L models in > my day, and it will be nice to work in 1:1 scale! I'm already thinking > Corvair power for the Piet because.... > > I also happen to be a Corvair driver. My Son is too. I have a '64, he > has 2 65's. I drive mine as a daily driver except in the worst of > winter and also autocross it. I'm thinking along the lines of a > complete, ready to run Corvair from flycorvair, simply because they, to > me, are a heck of a good deal, and I have complete faith in the > powerplant, and am familier with repair/upkeep for them. > > So, that's my story. I'm sure we'll have lots of questions as time > goes on. It appears there are some grey areas in the plans, and I'm > sure I'll make a tweak here or there myself as I bet most of you do. > We're regular Oshkosh attendees, and excited about the Brodhead event > too. We have a local EAA chapter that's pretty active. I haven't been > able to hook up with them yet....busy busy busy...but will soon. I > figure I better get on the waiting list for a hanger over in Grand > Rapids, too, since it's about a 2 year wait and we'll need some serious > space by then! > > Can anyone recommend some good books about the Pietenpol, and wood > plane building in general? I have a few already, but I bet there's > more out there. We're prepared for projects that will take time, but > be a great husband/wife adventure! And we'll be able to get Dad's > trusty Shopsmith out of mothballs (anyone else remember the Shopsmith?) > > BTW, I too was concerned about fiting in a Piet, as I was about a 701 > for that matter. I'm 6'2". A year ago I weighed 290. When I decided > it was time to fly, get healthy, get my BP under control, and stop > being pooped out by the time I got to the top of the stairs....I've got > myself down to 185! Best way to improve several things, health, > autocross handling in a Corvair, and flight charasterics! > > Most fun I've ever had flying, was riding with the Red Baron Squadron > (yes, the Pizza guys) in their Stearman. They were here for a > promotional event (I spose I should mention...I'm the morning radio > show host in Grand Rapids..so I get all the media perks..I've been on > the air somewhere for 31 years now....in GR for 19...check us out at > http://www.kozyradio.com you can listen to some morning show podcasts > if you're up to it) Anyway, when I got to the airport to fly with > them..the pilot took one look at me and said "Not till this afternoon" > They had just arrived after about a 60 mile flight, and their tanks > were almost full. With me at about 290 back then...they wouldn't stunt > with that much weight! So had to come back 4 hours later after they had > done a bunch of rides for kids and whatnot..so the planes were > lighter....but got the full treatment....hammerhead stall, loops, > rolls, wingover..it was GREAT! I knew it would be interesting before we > took off, as he was fitting the parachute to my butt and explaing how > to work it..he said "If I say 'bailout! bailout! bailout!' 3 times like > that, I mean it". What a thrill THAT was! > > If you're *really* got time to kill, have a look at my web page at: > http://www.edselmotors.com > (yes, we also own an Edsel) > There a bunch of Corvair stuff there, and lots of other time killing > stuff. I plan on adding a flying section eventually. I have a teensey > weensey bit of flying stuff still posted at my ancient old web page at: > http://www.uslink.net/~hepcats/planes.html > > Tim in Bovey > > == > You *can* repair a flip-flop with a capacitor! > == > > > Cheap talk? > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 24, 2006
Here some pictures showing how I did it. Since I didn't have a 12' wide belt sander I clamped a couple of pieces of steel at the tail post and just ahead of where I was going to cut and cut the wedge out with a rigid back hand saw. Then made a two sided sanding block out of 1/4" ply which I put between the two cuts and pulled it up and down until the sides matched. Rick On 11/23/06, Scott Schreiber wrote: > > I have my fuse sides done! http://www.subarubrat.com/misc/pietfuse3.jpg And > I was wondering if there is any great trick to use to cut the "wedge" out at > the tail post where they join? > > -Scott > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 24, 2006
Scott: I brought the tail post sides together until they touched. Then I cut two 1" wide stiff paper strips ( a couple of feet long I guess ) to simulate the longerons and laid them on top of the longerons, then brought the paper strips together at the rear end over lapping them to get the shape and with of the finished end. I then glued the paper strips as they set. This formed a paper triangle. then I split the triangle in two vertically to show the cut need on each side. This became the template I marked the wood with to show my cut lines. I used a small handsaw to cut, then a palm sander to hone the shape. It worked great. Epoxy glue pays off here because it has gap filling qualities. but don,t be sloppy. Leon S. Ks. ________________________________________________________________________________
Date: Nov 24, 2006
Rick, Nice pictures. I like your work. walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Friday, November 24, 2006 12:05 PM Subject: Re: Pietenpol-List: Cutout at tailpost, any great tips? Here some pictures showing how I did it. Since I didn't have a 12' wide belt sander I clamped a couple of pieces of steel at the tail post and just ahead of where I was going to cut and cut the wedge out with a rigid back hand saw. Then made a two sided sanding block out of 1/4" ply which I put between the two cuts and pulled it up and down until the sides matched. Rick On 11/23/06, Scott Schreiber wrote: I have my fuse sides done! http://www.subarubrat.com/misc/pietfuse3.jpg And I was wondering if there is any great trick to use to cut the "wedge" out at the tail post where they join? -Scott www.aeroelectric.com http://www.matronics.com/Navigator?Pietenpol-List -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 24, 2006
About 3 days total, first day was one side plus outer gussets. 2nd day was inner gussets on that first side and framing up of the 2nd side with it's outer gussets. 3rd day was inner gussets on the 2nd side and clearing the building board. -Scott ----- Original Message ----- From: Ben Ramler To: pietenpol-list(at)matronics.com Sent: Thursday, November 23, 2006 8:16 PM Subject: Re: Pietenpol-List: Cutout at tailpost, any great tips? Nice shot Scott! Wow is the only thing I can say! How roughly did that take you? just curious? Ben ----- Original Message ---- From: Scott Schreiber <got22b(at)SubaruBrat.com> To: pietenpol-list(at)matronics.com Sent: Thursday, November 23, 2006 6:02:52 PM Subject: Pietenpol-List: Cutout at tailpost, any great tips? I have my fuse sides done! http://www.subarubrat.com/misc/pietfuse3.jpg And I was wondering if there is any great trick to use to cut the "wedge" out at the tail post where they join? -Scott Electric www.buil* HomebuiltHELP http://www.matronics.com/contributist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?Piet======= ========= ------------------------------------------------------------------------- ----- Everyone is raving about =========== ________________________________________________________________________________
Date: Nov 24, 2006
I ended up using a mixture of your pics and an idea that popped in my head thanks to your pics. I "masked off" the area not to be cut with 1/8 sheet metal and used that as a guide for the handsaw and it came out smooth and straight. I just need to run some 80 grit over it to get a nice surface for the epoxy. -Scott ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Friday, November 24, 2006 12:05 PM Subject: Re: Pietenpol-List: Cutout at tailpost, any great tips? Here some pictures showing how I did it. Since I didn't have a 12' wide belt sander I clamped a couple of pieces of steel at the tail post and just ahead of where I was going to cut and cut the wedge out with a rigid back hand saw. Then made a two sided sanding block out of 1/4" ply which I put between the two cuts and pulled it up and down until the sides matched. Rick On 11/23/06, Scott Schreiber wrote: I have my fuse sides done! http://www.subarubrat.com/misc/pietfuse3.jpg And I was wondering if there is any great trick to use to cut the "wedge" out at the tail post where they join? -Scott www.aeroelectric.com http://www.matronics.com/Navigator?Pietenpol-List -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 24, 2006
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
That is great news, Oscar-- pretty exciting stuff. It is hard to imagine that 2 years has passed since you took possession of your Illinois-Born and Gumbo-Grown Piet. Who says the nawth and south kant git along ? Mike C. ________________________________________________________________________________
Date: Nov 24, 2006
Subject: Video shots......
Fellow Pieter's: For some of us this Christmas holiday, we often ponder of a "great" gift we could use. Therefore, I have found the "great" gift you can run out and purchase...... wrapping it with care..... and applying the gift tag to simply say,...from Santa Claus! What is this gift you ask?....... At Shopko, your will find a Oregon Scientific Water-Resistant Hands Free "Helmet Cam" with Flash Memory Video Recorder. (See where I am going with this fellow pilots!) You can capture all the flying action with the ultimate all terrain digital video camera compact all-in-one design. Playback is either on PC or Television. Mounts easily on helmets, bikes, and a wide array (planes) of other sporting gear. There,...my good deed for those of us who would like to video our flying experiences at a low low price of $129.00 which includes all mounting hardware and PC windows XP or Windows 2000 compatible. Merry Christmas! Ken H. Fargo, ND --------------------------------- ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Re: Video shots......
In a message dated 11/25/2006 12:18:22 AM Central Standard Time, kmheidecpo(at)yahoo.com writes: At Shopko, your will find a Oregon Scientific Water-Resistant Hands Free "Helmet Cam" with Flash Memory Video Recorder. Ken, I've been looking for this type helmet cam for a long time, but they are all over $300. I searched the Shopko web site, but couldn't find it. Where did you see it ? Chuck G. NX770CG ________________________________________________________________________________
Date: Nov 24, 2006
Chuck, What a great camera and very tough! I walked into my local Shopko store and found three of them hanging for $129.00. each. If you like I will go and buy one for you in the morning and ship UPS. Just say the word.... Ken PS...they were not on clearance either for that price! Rcaprd(at)aol.com wrote: In a message dated 11/25/2006 12:18:22 AM Central Standard Time, kmheidecpo(at)yahoo.com writes: At Shopko, your will find a Oregon Scientific Water-Resistant Hands Free "Helmet Cam" with Flash Memory Video Recorder. Ken, I've been looking for this type helmet cam for a long time, but they are all over $300. I searched the Shopko web site, but couldn't find it. Where did you see it ? Chuck G. NX770CG --------------------------------- ________________________________________________________________________________
Date: Nov 25, 2006
In a message dated 11/25/2006 1:07:35 AM Central Standard Time, kmheidecpo(at)yahoo.com writes: Chuck, What a great camera and very tough! I walked into my local Shopko store and found three of them hanging for $129.00. each. If you like I will go and buy one for you in the morning and ship UPS. Just say the word.... Ken PS...they were not on clearance either for that price! Ken, 'The Word' !! That would be fantastic if you could do that for me !! Send it to: Chuck Gantzer 626 Pattie Wichita, KS 67211 Let me know the total cost, and I'll get a check right off in the mail to you. Thank you very much. ________________________________________________________________________________
Date: Nov 25, 2006
Subject: High alt. performance
Hi Tim: I have that article in one of the old newsletters. I'd forgot how anemic the stock A was. Those old racers use to get a lot of power out of them but "what price speed"? The A was a great engine during the automotive "stone age", but getting modern (or just decent) performance out of it seams to take the life out of it in a hurry. I'm going to do a minimal amt. of boosting mine, only with insert bearings so as to handle 6 or 7 to one compression, than a Stromberg carb. as from an A-65. I am based at 1500 ft. so all I'm really looking for is a little extra margin for a little extra alt. when I pass over the trees or wires at the end of the runway. I think the only real way to get a good original looking inline engine set up for the Piet is o use a modern engine like Larry Harrison did in his Poplar Piet. Right out of the box you have higher stock hp. reliable full pressure oiling and years and millions of dollars of R and D behind it. I just wish one of those smart guys who have already done it would do a conversion article on it. Leon S. in Ks. ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Re: Long intro. new guy
Eight year? No problem Leon, remember the journey is the destination as they say (unless you like flying more than building I guess). Rick > > > Welcome: I too planned on 2 years to build my Piet. I'm in year 8 now. > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 25, 2006
Subject: longeron question
Hey Fellow Piet'ers, I have question on the longerons. Would 3/4" wide by 5/8" be strong enough to use for the longerons? Just thought I would ask before it was to late. thanks, Ben Ramler ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Re: longeron question
NO ________________________________________________________________________________
Date: Nov 25, 2006
Subject: any body see this?
On Youtube. lots of them http://www.youtube.com/watch?v=-2Ch9QhwyBY cool! walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ________________________________________________________________________________
Date: Nov 25, 2006
That would be a huge decrease in cross section... .625x.75=0.468= less than 1/2 the cross section area of 1 that you get with the 1X1 called for in the plans. I've heard of folks using 7/8x7/8 with Douglas Fir, but I decided to use the full dimension as called for on the plans. Don't start compromising so early in the project, or you'll never have the guts to fly it. (or let anyone else) Just my $.02 Ben Ben Ramler wrote: > >Hey Fellow Piet'ers, > > I have question on the longerons. Would 3/4" wide by 5/8" be strong enough to use for the longerons? Just thought I would ask before it was to late. > >thanks, > >Ben Ramler > > > > > > > ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Band Saw?
First off, thanks all for the nice welcome! Lots of notes on and off the list. I'm in no hurry to finish either plane, but we'll stay on task! I'm semi-retired, kids all grown, wife still works full-time. Although I do enough sideline work on my own to make me still working full time! But I work 5-11 AM leaving the day to build and tinker and what not. Also, thanks for the good book suggestions. Really helped fill out my letter to Santa. Question: I figure I'm gonna need a bandsaw for this sort of work. I haven't used one since high school shop class (and no, it wasn't steam powered!). How big of a saw am I going to want to look for? All I have now is a small jigsaw that worked find for models 20 years ago, but that's not gonna do it! I plan on taking my Dad's Shopsmith out of mothballs when I need it. For those not familier, it's a combination table saw, lathe, drillpress, horizontal sander, and I think cheese grater too! VAriable speed, Dad's got all the attachments, so that will be good for ripping long parts, etc. but I think bandsaw is gonna be the key. Besides, it's good to have another reason to buy another tool! Tim in Bovey == You *can* repair a flip-flop with a capacitor! == Want to start your own business? http://smallbusiness.yahoo.com/r-index ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Re: Band Saw?
Actually the jig saw works really well if you buy the hollow ground blades for it. the blade is thicker on the front than the back, instead of blades with set in the teeth. A bandsaw will be used if you have it, but I would rather have a nice miter saw for precision cutting, it leaves the end grain open for good glue penetration, rather than bandsawing the cuts and sanding to the line which closes in the pores. besides wasting huge amounts of time cutting and fitting. Just set your fuselage side pieces on top of the longerons, mark with a sharp pencil and cut it to the line...and your done fitting. Or if you have a lot of repetitive pieces like the rib pieces. set a stop and cut them all at once. good for plus or minus .005. Del Tim Verthein wrote: First off, thanks all for the nice welcome! Lots of notes on and off the list. I'm in no hurry to finish either plane, but we'll stay on task! I'm semi-retired, kids all grown, wife still works full-time. Although I do enough sideline work on my own to make me still working full time! But I work 5-11 AM leaving the day to build and tinker and what not. Also, thanks for the good book suggestions. Really helped fill out my letter to Santa. Question: I figure I'm gonna need a bandsaw for this sort of work. I haven't used one since high school shop class (and no, it wasn't steam powered!). How big of a saw am I going to want to look for? All I have now is a small jigsaw that worked find for models 20 years ago, but that's not gonna do it! I plan on taking my Dad's Shopsmith out of mothballs when I need it. For those not familier, it's a combination table saw, lathe, drillpress, horizontal sander, and I think cheese grater too! VAriable speed, Dad's got all the attachments, so that will be good for ripping long parts, etc. but I think bandsaw is gonna be the key. Besides, it's good to have another reason to buy another tool! Tim in Bovey == You *can* repair a flip-flop with a capacitor! == Want to start your own business? http://smallbusiness.yahoo.com/r-index Del-New Richmond, Wi "farmerdel(at)rocketmail.com" --------------------------------- ________________________________________________________________________________
Date: Nov 25, 2006
Tim For most things, a 11" tabletop from Sears will do just fine. Get one with variable speed so you can cut some metal fittings also. Alo, welcome to the list. Dick N. Arden Hills, MN. ----- Original Message ----- From: "Tim Verthein" <minoxphotographer(at)yahoo.com> Sent: Saturday, November 25, 2006 3:56 PM Subject: Pietenpol-List: Band Saw? First off, thanks all for the nice welcome! Lots of notes on and off the list. I'm in no hurry to finish either plane, but we'll stay on task! I'm semi-retired, kids all grown, wife still works full-time. Although I do enough sideline work on my own to make me still working full time! But I work 5-11 AM leaving the day to build and tinker and what not. Also, thanks for the good book suggestions. Really helped fill out my letter to Santa. Question: I figure I'm gonna need a bandsaw for this sort of work. I haven't used one since high school shop class (and no, it wasn't steam powered!). How big of a saw am I going to want to look for? All I have now is a small jigsaw that worked find for models 20 years ago, but that's not gonna do it! I plan on taking my Dad's Shopsmith out of mothballs when I need it. For those not familier, it's a combination table saw, lathe, drillpress, horizontal sander, and I think cheese grater too! VAriable speed, Dad's got all the attachments, so that will be good for ripping long parts, etc. but I think bandsaw is gonna be the key. Besides, it's good to have another reason to buy another tool! Tim in Bovey == You *can* repair a flip-flop with a capacitor! == Want to start your own business? http://smallbusiness.yahoo.com/r-index ________________________________________________________________________________
Date: Nov 25, 2006
Let me add on to what Corky said: NO NO NO NO, Stick to the plan Dick N. ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Saturday, November 25, 2006 11:47 AM Subject: Pietenpol-List: longeron question Hey Fellow Piet'ers, I have question on the longerons. Would 3/4" wide by 5/8" be strong enough to use for the longerons? Just thought I would ask before it was to late. thanks, Ben Ramler ________________________________________________________________________________
Date: Nov 25, 2006
Tim, Since I have used a bandsaw almost every day of my life for 21 years, my opinion may be of some value. I have owned or worked with almost every type of bandsaw there is. My favorite is still the 12" Sears freestanding model. It is cheap, reliable and you can find the blades anywhere there is a Sears. It has 2 wheels (preferable), takes a wide variety of blades and has power enough to cut "pack-ups", or stacked pieces. They are also very easy to rebuild, should you ever put that many hours on it like I do. It is light enough for me to load on a stock truck by myself when going on the road with my business. And no, I do not work for Sears. But I sure recommend the saw. Ron ________________________________________________________________________________
Subject: White Ash substitution check
Date: Nov 26, 2006
Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott ________________________________________________________________________________
Date: Nov 26, 2006
Subject: Re: White Ash substitution check
Scott, I'm no wood expert, but I do know that ash is tough as hell (axe handles baseball bats) and poplar is a very soft wood. I used a scrap piece of ash as tool to bend my fittings over a mandrel. Hitting the piece with a hammer, the top only mushroomed, never split. I would think that oak, red/white, or maple would (no pun) be better walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:01 AM Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott ________________________________________________________________________________
Date: Nov 26, 2006
Oak is available here as well, and I looked at it but it seemed prone to breaking, a blade like effect. Poplar did seem softer than Aspen. -Scott ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:26 AM Subject: Re: Pietenpol-List: White Ash substitution check Scott, I'm no wood expert, but I do know that ash is tough as hell (axe handles baseball bats) and poplar is a very soft wood. I used a scrap piece of ash as tool to bend my fittings over a mandrel. Hitting the piece with a hammer, the top only mushroomed, never split. I would think that oak, red/white, or maple would (no pun) be better walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:01 AM Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Nov 26, 2006
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Scott, Neither Aspen or Poplar are suitable substitutes for Ash, they are far weaker, and in spite of being from deciduous trees (as opposed to evergreens), they are considered softwoods by the timber industry. Mature Aspen, particularly, has very little tensile strength & is prone to sudden failure (I know this from bitter experience, having nearly been killed when I was 8 from climbing a large aspen & having a branch break suddenly). Aspen is not really considered a structural wood at all, although it has a very pleasant "clear", light, and smooth apperarance that makes it good for cabinets, etc. If I had to choose between oak and maple as a substitute, I'd go with the maple, it's more uniform in density & grain & tougher. Just be sure you get ROCK maple, which comes from a harder/denser species of maple - there are also soft maples like Red Maple & Silver Maple that would NOT be suitable. Some tropical hardwoods may have similar properties of strength and toughness as Ash, but I'm no expert on those. It occurs to me that one place you might check is YUKON LUMBER CO. in Norfolk, VA. Sorry, I don't have a number, but when I lived there, they were they experts on various types of lumber from around the world & stocked an amazing variety of common & exotic woods. All that said however, I think you should look around more for ash - there is really no GOOD substitute & I'm sure you can find it on line, if nowhere else. Everyone on the list should also be aware that ash is going to become increasingly scarce in the future. There is a nasty insect that came here from Asia about 8-10 years ago (most likely in a load of Chinese-made pallets sent to Detroit) called the Emerald Ash Borer. It has infected huge numbers of trees in Michigan & is now spreading into Ohio. No known pesticide can kill it & it is 100% fatal to Ash trees. Here in Ohio, a friend of mine at the Ag Research Center is in charge of the State effort to find a control & so far his team is batting zero. Privately, he says that there is no hope for controlling this pest & that eventually Ash trees will go the way of the chestnuts & dutch elms, probably in 10-15 years. In the meantime, there MAY be a glut of Ash on the market in the next couple of years as timber folks selectively cut ash as salvage lumber to get ahead of the borers. Once an area is infected, the current tactic is total quarantine, with no shipment of young trees, firewood or lumber allowed out of that area, so there is some incentive to cut before an area goes that way. So get it while you can. Just a little more wonderful news to make everyone's day.... Kip Gardner >Oak is available here as well, and I looked at it but it seemed >prone to breaking, a blade like effect. Poplar did seem softer than >Aspen. > > -Scott > >----- Original Message ----- >From: <mailto:waltdak(at)verizon.net>walt evans >To: pietenpol-list(at)matronics.com >Sent: Sunday, November 26, 2006 9:26 AM >Subject: Re: Pietenpol-List: White Ash substitution check > >Scott, >I'm no wood expert, but I do know that ash is tough as hell (axe >handles baseball bats) and poplar is a very soft wood. >I used a scrap piece of ash as tool to bend my fittings over a >mandrel. Hitting the piece with a hammer, the top only mushroomed, >never split. >I would think that oak, red/white, or maple would (no pun) be better >walt evans >NX140DL -- North Canton, OH ________________________________________________________________________________
Date: Nov 26, 2006
I bought my ash from Wicks. It isn't listed in the aircraft supply catalog. Had to call the Wicks Organ company, their sister company and they had it and cut to the thickness in the plans. Wasn't expensive. Don't know if they still carry it, but don't know why not. Dennis ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:34 AM Subject: Re: Pietenpol-List: White Ash substitution check Oak is available here as well, and I looked at it but it seemed prone to breaking, a blade like effect. Poplar did seem softer than Aspen. -Scott ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:26 AM Subject: Re: Pietenpol-List: White Ash substitution check Scott, I'm no wood expert, but I do know that ash is tough as hell (axe handles baseball bats) and poplar is a very soft wood. I used a scrap piece of ash as tool to bend my fittings over a mandrel. Hitting the piece with a hammer, the top only mushroomed, never split. I would think that oak, red/white, or maple would (no pun) be better walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:01 AM Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Nov 26, 2006
I can get you the ash pieces needed for the plans pietenpol. Will cut a bit longer for surety. Give me a full name, address and phone. Nathan (Corky's buddy) ________________________________________________________________________________
Date: Nov 26, 2006
And remember, guys, ash was used for the frame on many a Morgan production sports car. Al ----- Original Message ----- From: Dennis Engelkenjohn To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 11:22 AM Subject: Re: Pietenpol-List: White Ash substitution check I bought my ash from Wicks. It isn't listed in the aircraft supply catalog. Had to call the Wicks Organ company, their sister company and they had it and cut to the thickness in the plans. Wasn't expensive. Don't know if they still carry it, but don't know why not. Dennis ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:34 AM Subject: Re: Pietenpol-List: White Ash substitution check Oak is available here as well, and I looked at it but it seemed prone to breaking, a blade like effect. Poplar did seem softer than Aspen. -Scott ----- Original Message ----- From: walt evans To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:26 AM Subject: Re: Pietenpol-List: White Ash substitution check Scott, I'm no wood expert, but I do know that ash is tough as hell (axe handles baseball bats) and poplar is a very soft wood. I used a scrap piece of ash as tool to bend my fittings over a mandrel. Hitting the piece with a hammer, the top only mushroomed, never split. I would think that oak, red/white, or maple would (no pun) be better walt evans NX140DL "Put your wealth in knowledge, and no one can ever take it from you" Ben Franklin ----- Original Message ----- From: Scott Schreiber To: pietenpol-list(at)matronics.com Sent: Sunday, November 26, 2006 9:01 AM Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Nov 26, 2006
When I built my Pietenpol, I couldn't find White Ash of the quality and size I needed. My fellow teacher, who was a real expert on woods, suggested either Birch or Oak as suitable substitutes. I opted for Oak because it was less prone to rotting. Birch tends to stain and rot rather easily, but is really strong (illustrated by its use in wooden propellers). Oak was used for centuries in wooden ships and it is strong! The two Oak cross pieces on the floor of my Pietenpol are as sound as they were when I installed them over 36 years ago. Of course, they were well-protected by several coats of urethane varnish and the a/c has been hangared most of its life. My ol' Piet has literally thousands of takeoffs and landings from really rough fields, and I think a steel fitting would have broken long before the Oak crosspieces suffered any damage. White Ash is the preferred wood for this application, but in my experience Oak is a reasonable substitute. Do not, however, use Poplar or Aspen for these members (I have used it for violin backs and it is nice to carve, but it cannot compete with Ash, Oak or Birch for strength). Whatever wood you use, always use the selection criteria for aircraft quality wood. Graham Hansen (Pietenpol CF-AUN in chilly Alberta) ________________________________________________________________________________
Subject: heavy piet
Date: Nov 26, 2006
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
A brand new 65 hp Continental. It's not the engine, it's the weight. 745 is too heavy for a Piet. Some of that is in the straight axle (21 lbs), some in the wire wheels, (probably 20 lbs apiece), a lot is in the polyurethane paint (probably 60 lbs), but some is in the wider fuselage. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gardiner Mason Sent: Tuesday, November 21, 2006 6:39 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: heavy piet What kind of engine did Jack phillips use to get that poor performance? I am building the long f uselage and 2 inches wider with a corvair engine. I don't expect it to be a rocket, but it should do better than he described. I have a cessna 140 with a C90 and with 1450 max gross it climbs at 600fpm. Gardiner Mason _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Nov 26, 2006
I haven't used this Company, so I can't vouch for their service...but it appears you can order small quantities. It's worth a shot. Here's the link...http://www.bristolvalley.com/catalog.asp?prodid=293392&showprevnext=1 Steve Schofield Vero Beach, Florida ________________________________________________________________________________
Date: Nov 27, 2006
Subject: List of Contributors Coming Soon - Make Sure You're Listed!
Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, the List seems at least as valuable of a building/flying/recreating tool as a typical your magazine subscription! And how interactive is a magazine, after all? :-) Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by droping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2006
Subject: White Ash availability
I purchased white ash "baseball bat blanks" sold by Woodcraft. They have a mail order catalog and an extensive website. Your saw will have to be able to handle the piece which I believe was about 3 1/2" x 3 1/2" x 42" long if memory serves. The cost was about $35.00. I have a planer too which helps immeasurably when buiding a wood airplane. Dan Helsper Poplar Grove, IL ________________________________________________________________________________
Date: Nov 27, 2006
Subject: Re: heavy piet
Jack, What wall thickness was your straight axle? You mentioned a weight of 20 lbs, so I went out to my hangar and weighed mine (a full 72" long at this point before trimming) and it was only about 10 lbs. The thickness on mine is .120 I believe. Dan Helsper Poplar Grove, IL ________________________________________________________________________________
From: "Graham and Robyn" <grhewitt(at)globaldial.com>
Subject: Re addresses
Date: Nov 27, 2006
Hi Bo here are the addresses, Phil is Chapter 24 Pres & Joe is Sect Hope to see you Wednesday Regards Graham ________________________________________________________________________________
Date: Nov 27, 2006
Scott, Ash has a number of interesting characteristics that make it the right material for the landing gear (and the engine mounts for the model A). I found this on the web: "...Because white ash wood is tough, strong, and highly resistant to shock, it is particularly sought for handles, oars, and baseball bats." In addition to absorbing shock well, ash is relatively light, and has the unique property that it does not splinter, which is why it is used to make gymnastics parallel bars. I don't know of any other wood with those characteristics. It is worth going to some trouble to find the correct wood. That is one of the joys of building a plans-built airplane, and one of the things I'm missing while building my RV-10. It's just not the same to go look in the crate that the kit came in to find a part, as it was to have to search for the correct material and then fabricate the part (in my case I usually had to fabricate several parts to get one good one) when I was building my Pietenpol. Enjoy the building process. In this age of kit-built airplanes, you are a member of a dying breed. An Elite group. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Scott Schreiber Sent: Sunday, November 26, 2006 9:02 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Nov 27, 2006
MessageWell, I have a solution thanks to the great and generous Nathan who has already offered up the piece. And of course now some of those other sources that came after are here on record for others. For me it is learning the balance of new and old used in this plane. Nobody suggests using the glues from the 1930's, and yet the metal fittings are considered very servicable, and struts are as varied as it gets.... it is an interesting process. -Scott ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Monday, November 27, 2006 8:07 AM Subject: RE: Pietenpol-List: White Ash substitution check Scott, Ash has a number of interesting characteristics that make it the right material for the landing gear (and the engine mounts for the model A). I found this on the web: "...Because white ash wood is tough, strong, and highly resistant to shock, it is particularly sought for handles, oars, and baseball bats." In addition to absorbing shock well, ash is relatively light, and has the unique property that it does not splinter, which is why it is used to make gymnastics parallel bars. I don't know of any other wood with those characteristics. It is worth going to some trouble to find the correct wood. That is one of the joys of building a plans-built airplane, and one of the things I'm missing while building my RV-10. It's just not the same to go look in the crate that the kit came in to find a part, as it was to have to search for the correct material and then fabricate the part (in my case I usually had to fabricate several parts to get one good one) when I was building my Pietenpol. Enjoy the building process. In this age of kit-built airplanes, you are a member of a dying breed. An Elite group. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Scott Schreiber Sent: Sunday, November 26, 2006 9:02 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Nov 27, 2006
MessageI read with interest your comparison of the Pietenpol project vs. the RV-10. You can't get much greater contrast in homebuilts then that. It just so happens that I am simultaneously building both, the Piet and the RV-10. I started my Piet in Jan.2004 and have the tremendous benefit of having Bill Rewey as my close friend, advisor, and DAR. I have all my ribs done, the fuselage about 90% complete and have finished welding up the landing gear. Then last Jan. my son ordered the tail kit of an RV-10. When I told him "you don't have the time or the passion to tackle a project of this size", he replied, " I know. I'm not going to build it, you are." So, in the evenings a couple days each week I get over to his home to work on the RV, and during the day, I go to my basement and work on my Piet. Meanwhile, he started taking flying lessons. He hasn't soloed yet. I convinced him to own his trainer rather than rent, so he and I bought a really nice 1972 Cessna 150 with low engine time and an IFR panel. Then he had built a beautiful 50 x 60ft hangar, complete with office, bath with shower, fully insulated, heated, well lit, and big enough to hold three planes. Since my special issuance med ran out last Aug. and I can't re apply for several months (cancer) I went and bought a really well built Piet from a guy in Baxter, Ia. to fly under the Sport Pilot rules while continuing to build my Piet. So, I have the best of all worlds: building two very different aircraft, have two very differnt planes to fly, and the luxury of housing them in a very nice hangar at a totally new rebuilt airport in Middleton, Wi. Who said you have to die to be in paradise? Roman Bukolt NX 20795 N 1765Q ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Monday, November 27, 2006 7:07 AM Subject: RE: Pietenpol-List: White Ash substitution check Scott, Ash has a number of interesting characteristics that make it the right material for the landing gear (and the engine mounts for the model A). I found this on the web: "...Because white ash wood is tough, strong, and highly resistant to shock, it is particularly sought for handles, oars, and baseball bats." In addition to absorbing shock well, ash is relatively light, and has the unique property that it does not splinter, which is why it is used to make gymnastics parallel bars. I don't know of any other wood with those characteristics. It is worth going to some trouble to find the correct wood. That is one of the joys of building a plans-built airplane, and one of the things I'm missing while building my RV-10. It's just not the same to go look in the crate that the kit came in to find a part, as it was to have to search for the correct material and then fabricate the part (in my case I usually had to fabricate several parts to get one good one) when I was building my Pietenpol. Enjoy the building process. In this age of kit-built airplanes, you are a member of a dying breed. An Elite group. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Scott Schreiber Sent: Sunday, November 26, 2006 9:02 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Nov 27, 2006
Actually I do suggest the glues from the 1930's. I used Resorcinol throughout my Pietenpol. It is the only glue approved by the FAA, and it was used in the 1930's. Pain in the but to work with, but once cured it will withstand 24 hours immersion in boiling water. Try that with T-88. I like T-88 for repairs and non-structural areas. Much easier to use than Resorcinol, and plenty strong enough, but I just don't know how well it will hold up after years of service. There's a lot of data on resorcinol. Let the flamers begin... Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Scott Schreiber Sent: Monday, November 27, 2006 8:35 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: White Ash substitution check Well, I have a solution thanks to the great and generous Nathan who has already offered up the piece. And of course now some of those other sources that came after are here on record for others. For me it is learning the balance of new and old used in this plane. Nobody suggests using the glues from the 1930's, and yet the metal fittings are considered very servicable, and struts are as varied as it gets.... it is an interesting process. -Scott ----- Original Message ----- From: Phillips, Jack <mailto:Jack.Phillips(at)cardinal.com> To: pietenpol-list(at)matronics.com Sent: Monday, November 27, 2006 8:07 AM Subject: RE: Pietenpol-List: White Ash substitution check Scott, Ash has a number of interesting characteristics that make it the right material for the landing gear (and the engine mounts for the model A). I found this on the web: "...Because white ash wood is tough, strong, and highly resistant to shock, it is particularly sought for handles, oars, and baseball bats." In addition to absorbing shock well, ash is relatively light, and has the unique property that it does not splinter, which is why it is used to make gymnastics parallel bars. I don't know of any other wood with those characteristics. It is worth going to some trouble to find the correct wood. That is one of the joys of building a plans-built airplane, and one of the things I'm missing while building my RV-10. It's just not the same to go look in the crate that the kit came in to find a part, as it was to have to search for the correct material and then fabricate the part (in my case I usually had to fabricate several parts to get one good one) when I was building my Pietenpol. Enjoy the building process. In this age of kit-built airplanes, you are a member of a dying breed. An Elite group. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Scott Schreiber Sent: Sunday, November 26, 2006 9:02 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/ch ref="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Date: Nov 27, 2006
Hi Scott, I got my White Ash from The Wood & Shop Inc. 314-731-2761 or www.woodnshop.com <http://www.woodnshop.com/> ! They will ship it to you too!!!!!!! Cheers, Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Scott Schreiber Sent: Sunday, November 26, 2006 6:02 AM Subject: Pietenpol-List: White Ash substitution check Failing to find white ash for the two xmembers I checked with a few wood working friends and they suggested Poplar and Aspen as equivalent woods. I was able to find both 3/4 x 3 and 1/4 x 3 Aspen locally and it is clean knot free quality wood. I am inclined to laminate 3 1/4x3 lengths to get a nice strong piece, probably overkill but not allot of effort. Does anyone know of a compelling reason not to use Aspen, laminated or single piece? And let me say again, this group is great. -Scott <http://www.buildersbooks.com> <http://www.homebuilthelp.com> ________________________________________________________________________________
Subject: T-88 vs. resorcinol
Date: Nov 27, 2006
Good grief, Jack-! Are you planning to fly your Piet through 24 hours of boiling water? Icarus will certainly plummet! This is one discussion that will never end, as long as there are taverns, hangars, and pilots. Less filling or more taste? T-88 or resorcinol? I'll settle for T-88, having used it and found that its qualities are very endearing... workable in temps down into the 50s, not fussy about proportioning, nice gap filling, dries clear, readily available, quick curing, will bond dissimilar materials, and well documented in aviation use for a long time. But, I do not plan to fly through boiling water, ever ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Talk now to your Hotmail contacts with Windows Live Messenger. ________________________________________________________________________________
Date: Nov 27, 2006
With all this global warming you just never know when it might start raining boiling water. The list has been kind of quiet lately - just thought I'd stir things up with a re-hash of the old glue discussion. So here goes. I used both, T-88 and Resorcinol on my Pietenpol. Both are good glues, and have their pros and cons. I happen to like Resorcinol better, but I sure used a lot of T-88. Resorcinol Pros Very strong (if properly applied) Long history in aircraft construction FAA approved. Totally weatherproof (the Mil Spec requires withstanding immersion in boiling water for 24 hours) Impervious to salt and fresh water, temperature extremes, solvents, oil, acids and alkalis Highly resistant to molds, fungi, bacteria and insects Purple/Brownish color (looks good in laminations) Easy to apply with a brush Cleans up with water (before cured) Resorcinol Cons Joints must be tight (no gap-filling capability) Temperature must be at least 70 F or joint strength may suffer Joint must be clamped with a pressure of 25 - 75 psi Purple Brownish color doesn't look nice for some applications 4:3 mix ratio is difficult to mix in small volumes T-88 Pros Very strong Clear - nearly invisible when finished Can be worked down to 35 F temperatures Unaffected by water, oil, kerosene and many other chemicals when fully cured 1:1 mix ratio (easy to mix small amounts) Good gap-filling properties (joints can be messy) Little or no clamping pressure required T-88 Cons Sticky - messy to work with Difficult to apply with a brush Long term exposure to weather results less clear than resorcinol Not FAA approved (can't be used on certificated aircraft) Basically I used Resorcinol everywhere I could, except in the cockpit area where I didn't want the purple glue lines. Other than the cockpit, the only places I used T-88 were joints that were not perfect, or places where I couldn't get good clamping pressure. When repairing my plane after the forced landing, I found no glue joints broken, either resorcinol or T-88. I think both are excellent glues. Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Monday, November 27, 2006 10:42 AM Subject: Pietenpol-List: T-88 vs. resorcinol --> Good grief, Jack-! Are you planning to fly your Piet through 24 hours of boiling water? Icarus will certainly plummet! This is one discussion that will never end, as long as there are taverns, hangars, and pilots. Less filling or more taste? T-88 or resorcinol? I'll settle for T-88, having used it and found that its qualities are very endearing... workable in temps down into the 50s, not fussy about proportioning, nice gap filling, dries clear, readily available, quick curing, will bond dissimilar materials, and well documented in aviation use for a long time. But, I do not plan to fly through boiling water, ever ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Talk now to your Hotmail contacts with Windows Live Messenger. _________________________________________________ ________________________________________________________________________________
Date: Nov 27, 2006
Subject: Re: T-88 vs. resorcinol
On 11/27/06, Phillips, Jack wrote: > > Jack.Phillips(at)cardinal.com> > > Other than the cockpit, the only places I used T-88 were > joints that were not perfect, or > places where I couldn't get good clamping pressure. > ... > > Jack What's this not perfect stuff? Jack, you surprise me, I thought if it's not perfect you do it all over again? Rick -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Nov 27, 2006
A really interesting article on poly glues 9like gurilla glue) Vs rescorcinal. ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Monday, November 27, 2006 1:36 PM Subject: Re: Pietenpol-List: T-88 vs. resorcinol On 11/27/06, Phillips, Jack wrote: Other than the cockpit, the only places I used T-88 were joints that were not perfect, or places where I couldn't get good clamping pressure. ... Jack What's this not perfect stuff? Jack, you surprise me, I thought if it's not perfect you do it all over again? Rick -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: T-88 vs. urethane (Gorilla Glue)
Date: Nov 27, 2006
>From the KRNet archives (not posted by me): >I just called the Gorilla Glue folks at the phone number on the bottle. >Tensile strength on Douglas Fir is 1700 psi. T-88 is 7000 psi (although >it's not given as to what kind of wood was tested). Spruce has a >tensile strength of something like 10,000 psi parallel to the grain and >130 perpendicular to the grain, and there are other factors involved >as well, but you might could argue for most applications that either >would do. But T-88 is stronger than Gorilla Glue, and I personally >would use T-88. > >One other deciding factor might be shelf life. The bottle of GG that I >picked up is less than a year old and has only been opened once, and >very little was used, but it's solid as a rock. T-88 lasts for years with >no >perceptible change. I've never seen it go bad. For airplane use, I would >simply use the best. There was also mention made of the fact that urethane glues will foam up in the joint, causing some widening of the joint with resultant loss of tolerance even if clamped up tight. What you end up with is hardened foam in the joint and the strength of the joint becomes the strength of the foam. Based on what I've heard about Gorilla Glue and other similar products, they have their place but not on aircraft structures. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Talk now to your Hotmail contacts with Windows Live Messenger. ________________________________________________________________________________
Date: Nov 27, 2006
Subject: Chuck G
Chuck, Please send me your address so I can send out your new christmas present UPS. I'll send santa's invoice later... Ken H. Fargo,ND --------------------------------- ________________________________________________________________________________
Subject: Re: Chuck G
Date: Nov 27, 2006
My address is 840 Woodley Dr., Atlanta,Ga, 30318. Gardiner Mason ----- Original Message ----- From: KMHeide To: Pietenpol Sent: Monday, November 27, 2006 5:59 PM Subject: Pietenpol-List: Chuck G
November 08, 2006 - November 27, 2006
Pietenpol-Archive.digest.vol-fl
