Pietenpol-Archive.digest.vol-fu
April 05, 2007 - April 18, 2007
      Alright! Lets carry this to it's obvious conclusion.
      A control wheel! Or, using that KISS principle,
      a bicycle handle cross stick for the maximum
      k-nee k-leerence. Have to be pretty small though.
      Kinda like those teeny weeny wheels some young
      guys put in their "hot rods". Hahahhahaha!
      Clif
      "If we knew what it was we were doing, it would not be called research,
      would it?" --Albert Einstein
      > Hey, I like the one about notching your leg enough to allow for more stick
      > travel!  Actually, a nice Rube Goldberg setup would be to have a handgrip
      > lever on the stick that would engage a reduction gear, say 2:1, to double
      > the cable travel per unit of stick travel when needed.  Or instead of
      > standard aileron cable pulleys, you could use some cam pulleys like the
      > ones used on compound bows to ratchet up the cable action as you near the
      > end of the pulley rotation.  Try getting those puppies past your DAR or
      > Tech Counselor-!
Date: Apr 05, 2007
Subject: Re: Squishing the ends
Once you have one end flattened clamp a length of straight wood to it. Line that up with the vise jaws by eye. I didn't just squeeze away with the vise itself. I rounded off one edge on each of two lengths of hard Ash. Stuck them in the vise and squeezed the tube between them. That way you get an easy transition from round to flat. This won't get you to perfect flatness. At this point I carefully hammered the rest of the way over the horn of my anvil. Clif > > I haven't had to do this yet but could you devise some kind of clamp that > makes it easy to square things up with respect to a side. If you used > blocks to raise the clamp up to the level of the vise, the clamp might > help keep your reference angle the same on both ends. I'm sure there are > other ways to do this but these problems with custom solutions are the > things I love about this project. Should be easy enough to make too. > > -------- > Glenn Thomas > N????? > http://www.flyingwood.com > ________________________________________________________________________________
Subject: Squishing the ends
Date: Apr 05, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
I had the same problem, Chris. The only way I found was trial and error (mostly error). I think I made 3 of each by the time I was through. As I recall, the second bend always tended to be about 10 degrees off where I thought it would be. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Catdesigns Sent: Wednesday, April 04, 2007 11:38 PM Subject: Pietenpol-List: Squishing the ends Anyone have a good method to ensure the squished ends of the spreader bars (wood gear), rudder bar, and tube connecting the sticks are in the same plane (or parallel or however you would describe it). I can squish them just fine. I just cant seem to get both end in the same plane. Any suggestions? Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com _________________________________________________ ________________________________________________________________________________
Date: Apr 05, 2007
Subject: Re: New question from and old brain
Tom, Personally I don't like the idea of wood screws holding on the horizontal stab. I used 3/16 bolts all the way through the longerons. No way those will pull out. I kid around about worshiping at the alter of BHP, but I do compromise on certain things. One of these is the Ford A engine. I am going to have two mags with 8 plugs, along with the Weber carb (recommended by Douwe from this list). I also had the Ford A modernized with the hardened valve seats, modern valves, pistons, counterweighted crank ,and modern bearings. I want a good reliable powerplant. My motivation is thinking ahead about giving my grandchildren rides. Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 05, 2007
Chris, On some occasions I reheated some parts and twisted them back into the same plane. Probably not the best thing to do. Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: New question from and old brain
Date: Apr 05, 2007
I did the same thing to mount the stabilizer, Dan. Used LONG AN3 bolts going through the top longerons and into nutplates. Besides, have you tried to find a #7 screw lately? Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of HelsperSew(at)aol.com Sent: Thursday, April 05, 2007 7:43 AM Subject: Re: Pietenpol-List: New question from and old brain Tom, Personally I don't like the idea of wood screws holding on the horizontal stab. I used 3/16 bolts all the way through the longerons. No way those will pull out. I kid around about worshiping at the alter of BHP, but I do compromise on certain things. One of these is the Ford A engine. I am going to have two mags with 8 plugs, along with the Weber carb (recommended by Douwe from this list). I also had the Ford A modernized with the hardened valve seats, modern valves, pistons, counterweighted crank ,and modern bearings. I want a good reliable powerplant. My motivation is thinking ahead about giving my grandchildren rides. Dan Helsper Poplar Grove, IL. _____ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Apr 05, 2007
Jack, I am so glad you responded to my post, because up till now I was going to use regular nuts on those horizontal stab bolts, until I asked myself "I wonder why Jack is using nut plates?" DUH!! Then I asked myself "How are you going to get TO the nuts or remove the stab if you have to dummy? !!" Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 05, 2007
Well, you could use regular nuts but you would need to have inspection ports on the side of the fuselage to be able to access the nuts for stabilizer installation. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of HelsperSew(at)aol.com Sent: Thursday, April 05, 2007 7:55 AM Subject: Re: Pietenpol-List: New question from and old brain Jack, I am so glad you responded to my post, because up till now I was going to use regular nuts on those horizontal stab bolts, until I asked myself "I wonder why Jack is using nut plates?" DUH!! Then I asked myself "How are you going to get TO the nuts or remove the stab if you have to dummy? !!" Dan Helsper Poplar Grove, IL. _____ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Subject: Re: Wing weight
Date: Apr 05, 2007
Hi Chuck, I've a lot to learn, but 110lbs seems like a very impressive number. Started thinking of numerous questions to ask, but did a google search of NX770CG first. Thanks for putting together an excellent website. The page showing wing construction was extremely informative. That did more to counter my "aluminum" musings than anything else. You have a beautiful plane, Gene BTW: Had some nice days in PA this week and had my motorcycle out for the first time this year. As I was riding I was thinking "OK, would an AirCamper be like the bike, and a Sonex, or 601 more like my car?" When not actually travelling anywhere, and the weather is nice, the car sits in the garage. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=105088#105088 ________________________________________________________________________________
Date: Apr 05, 2007
Subject: Squishing the Ends
My solution was easy -- I purchased those components from Ken Perkins! : ) Sorry to be a wise-guy, but I'm on vacation from work today! Fred B. La Crosse, WI ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: securing the LE of the Pietenpol stabilizer
Date: Apr 05, 2007
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Group, Here is a sketch of how I attached my LE stabilizer. Mike C. ________________________________________________________________________________
Date: Apr 05, 2007
Subject: Re: securing the LE of the Pietenpol stabilizer
What keeps this bolt from backing out from continued vibration, over time, from either a Tinneman nut or a "Home Depot speednut"? Do you put a lock or star washer on the bolt (at the top of the HStab), use Loc-tite on its threads, or what? Tim in central TX -----Original Message----- >From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov> >Sent: Apr 5, 2007 6:49 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: securing the LE of the Pietenpol stabilizer > > >Group, > >Here is a sketch of how I attached my LE stabilizer. > >Mike C. > > ________________________________________________________________________________
Date: Apr 05, 2007
I used a locking nutplate attached to the bottom of the top longeron. It's pretty easy to see if the bolts are getting loose (mine have never loosened in nearly 100 hours of flight), since it is right on top of the stabilizer and available for easy inspection during the preflight. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim Willis Sent: Thursday, April 05, 2007 9:12 AM Subject: Re: Pietenpol-List: securing the LE of the Pietenpol stabilizer What keeps this bolt from backing out from continued vibration, over time, from either a Tinneman nut or a "Home Depot speednut"? Do you put a lock or star washer on the bolt (at the top of the HStab), use Loc-tite on its threads, or what? Tim in central TX -----Original Message----- >From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov> >Sent: Apr 5, 2007 6:49 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: securing the LE of the Pietenpol stabilizer > > >Group, > >Here is a sketch of how I attached my LE stabilizer. > >Mike C. > > _________________________________________________ ________________________________________________________________________________
Date: Apr 05, 2007
And I also did the same as Jack on the stab. Rick On 4/5/07, Phillips, Jack wrote: > > I did the same thing to mount the stabilizer, Dan. Used LONG AN3 bolts > going through the top longerons and into nutplates. Besides, have you tried > to find a #7 screw lately? > > > Jack Phillips > > > -----Original Message----- > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of * > HelsperSew(at)aol.com > *Sent:* Thursday, April 05, 2007 7:43 AM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: New question from and old brain > > > Tom, > > Personally I don't like the idea of wood screws holding on the horizontal > stab. I used 3/16 bolts all the way through the longerons. No way those > will pull out. I kid around about worshiping at the alter of BHP, but I do > compromise on certain things. One of these is the Ford A engine. I am going > to have two mags with 8 plugs, along with the Weber carb (recommended by > Douwe from this list). I also had the Ford A modernized with the hardened > valve seats, modern valves, pistons, counterweighted crank ,and modern > bearings. I want a good reliable powerplant. My motivation is thinking > ahead about giving my grandchildren rides. > > > Dan Helsper > Poplar Grove, IL. > > > ------------------------------ > > See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503>. > > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > * * > > _________________________________________________ > > > Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 05, 2007
Subject: Alternative fabric paint
Hi All, I think it was last year there was a thread on this list addressing the testing of alternative paints other than the expensive aircraft finishes. There was an interesting article in this month's Brodhead Piet newsletter about this subject, where the writer suggested the use of KILZ primer and then water-based acrylic enamel I believe (I don't have the article in front of me). Does anyone have some current feedback on their test panels or currently flying airplanes? Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 05, 2007
Subject: Re: Alternative fabric paint
Whats wrong with high quality exterior gloss latex? Been lots of discussion (and experience) on the use of it on this and other homebuilder newsgroups, and have seen it on several Piets (and other aircraft) at Broadhead. Thats what I am going to use, no polybrush or polyspray or poly$$$$, just polytac it and latex it. Yes I know, its not going to look perfect 25 years from now, although if its hangered it's whole life it may not look that bad. Rick On 4/5/07, HelsperSew(at)aol.com wrote: > > Hi All, > > I think it was last year there was a thread on this list addressing the > testing of alternative paints other than the expensive aircraft finishes. > There was an interesting article in this month's Brodhead Piet newsletter > about this subject, where the writer suggested the use of KILZ primer and > then water-based acrylic enamel I believe (I don't have the article in front > of me). Does anyone have some current feedback on their test panels or > currently flying airplanes? > Dan Helsper > Poplar Grove, IL. > > > ------------------------------ > See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503>. > > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 05, 2007
I guess I'm just old fashioned. I plan to roll on coloured butyrate dope from the local aircraft supplier. First clear coats brushed in, roll silver then roll colour. Of course that's a long way away. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Rick Holland Sent: April 5, 2007 10:48 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Alternative fabric paint Whats wrong with high quality exterior gloss latex? Been lots of discussion (and experience) on the use of it on this and other homebuilder newsgroups, and have seen it on several Piets (and other aircraft) at Broadhead. Thats what I am going to use, no polybrush or polyspray or poly$$$$, just polytac it and latex it. Yes I know, its not going to look perfect 25 years from now, although if its hangered it's whole life it may not look that bad. Rick On 4/5/07, HelsperSew(at)aol.com wrote: Hi All, I think it was last year there was a thread on this list addressing the testing of alternative paints other than the expensive aircraft finishes. There was an interesting article in this month's Brodhead Piet newsletter about this subject, where the writer suggested the use of KILZ primer and then water-based acrylic enamel I believe (I don't have the article in front of me). Does anyone have some current feedback on their test panels or currently flying airplanes? Dan Helsper Poplar Grove, IL. ---------------------------------------------------------------------------- See what's free at AOL.com. -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 05, 2007
Heres a pic of my plane. Painted with Sherwin Williams house paint. Wing is Corn Yellow, satin finish and fuse is Gloss Blue. Still looks good after 4 years. I applied a coat of Poly Brush before painting. Dick N ----- Original Message ----- From: HelsperSew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Thursday, April 05, 2007 9:26 AM Subject: Pietenpol-List: Alternative fabric paint Hi All, I think it was last year there was a thread on this list addressing the testing of alternative paints other than the expensive aircraft finishes. There was an interesting article in this month's Brodhead Piet newsletter about this subject, where the writer suggested the use of KILZ primer and then water-based acrylic enamel I believe (I don't have the article in front of me). Does anyone have some current feedback on their test panels or currently flying airplanes? Dan Helsper Poplar Grove, IL. ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Apr 05, 2007
Dan, Thanks for the reminder. I made up a couple of test panels almost a year ago, coated only with latex primer and paint, and then promptly forgot to put one outside for weather testing. They're both sitting in my house. I've got to make up some kind of holder and put that thing outside. Here's a link to my test panels: http://www.mykitplane.com/Planes/buildLogReportDetail.cfm?BuildLogID=12 8 7&PlaneID=510&FName=Bill&LName=Church&PlaneName=Air%20Camper Bill C. ________________________________________________________________________________
From: "Scott Knowlton" <flyingscott_k(at)hotmail.com>
Date: Apr 05, 2007
Hey Bill: If you want to accelerate your weather testing I can bring your panel with me on my next layover to St John's Newfoundland and leave it stuck up in a tree along the coastline. If it survives a year there it'll be good for about ten years anywhere else! Scott Knowlton >From: "Bill Church" <eng(at)canadianrogers.com> >Reply-To: pietenpol-list(at)matronics.com >To: >Subject: RE: Pietenpol-List: Alternative fabric paint >Date: Thu, 5 Apr 2007 12:03:26 -0400 > >Dan, >Thanks for the reminder. >I made up a couple of test panels almost a year ago, coated only with >latex primer and paint, and then promptly forgot to put one outside for >weather testing. They're both sitting in my house. I've got to make up >some kind of holder and put that thing outside. Here's a link to my test >panels: > >http://www.mykitplane.com/Planes/buildLogReportDetail.cfm?BuildLogID=128 >7&PlaneID=510&FName=Bill&LName=Church&PlaneName=Air%20Camper > > >Bill C. > _________________________________________________________________ Your Space. Your Friends. Your Stories. Share your world with Windows Live Spaces. http://spaces.live.com/?mkt=en-ca ________________________________________________________________________________
Subject: Re: New Prop
Date: Apr 05, 2007
Gene, I think you'll really like how the prop does for you. Ed Sterba is a class act guy! Chris, I'm gonna try to escape out to the strip this evening to take some pictures. We just had our fourth baby on Monday, so things are a little hectic around here! Really enjoying it though!!! Mom and baby are healthy, so everything is good! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=105192#105192 ________________________________________________________________________________
Date: Apr 05, 2007
I like to call myself a strong Pietenpol follower too. But I know of a very popular Piet with screws holding the stabilizer down and they worked loose. I think the holes eventually stripped in the wood. The owner fixed the problem, and I don't think it's an issue anymore. I used through bolts on the stabilizer "spar" holes and placed an ispection hole and cover on the bottom side of the fuselage so I can reach up in there and hold the nut with my fingers. You have to lay on the ground to see the cover. Not much of a change, but lots more piece of mind!! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=105200#105200 ________________________________________________________________________________
Date: Apr 05, 2007
Subject: Sherwin Willams paint
Hello Dick N. What special metal preparation are needed to put S.W. paint on metal parts, cowl, gear etc. Leon S. in snowy ks. Going to have a white Easter. ________________________________________________________________________________
Date: Apr 05, 2007
Don, Congrats on the addition of your new crew member. Gene ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> Sent: Thursday, April 05, 2007 2:46 PM Subject: Pietenpol-List: Re: New Prop > > Gene, > I think you'll really like how the prop does for you. Ed Sterba is a > class act guy! Chris, I'm gonna try to escape out to the strip this > evening to take some pictures. We just had our fourth baby on Monday, so > things are a little hectic around here! Really enjoying it though!!! Mom > and baby are healthy, so everything is good! > > Don Emch > NX899DE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=105192#105192 > > > ________________________________________________________________________________
Subject: Re: Sherwin Willams paint
Date: Apr 05, 2007
Leon My engine cowling is done in Imron epoxy. The bridge decks are done in house paint. I first primed with Zinc Chromate primer, then 2 coats of paint. Dick ----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> Sent: Thursday, April 05, 2007 4:55 PM Subject: Pietenpol-List: Sherwin Willams paint > > Hello Dick N. What special metal preparation are needed to put S.W. > paint on metal parts, cowl, gear etc. Leon S. in snowy ks. Going to have > a white Easter. > > > ________________________________________________________________________________
Subject: Montana School Piet
Date: Apr 06, 2007
Thanks to all that have sent in a donation for the Montana kids. If anybody else has been thinking about it, there is still time to get it in before I send off the packet to their teacher, next Thur the 12 th. I will be sending along all of the notes guys have sent along. As a reminder Check to EAA Chapter 57 Dick Navratil 1415 Skiles Ln. Arden Hills, Mn. 55112 ________________________________________________________________________________
Date: Apr 07, 2007
Subject: Re: Montana School Piet
Dick, I mailed a check yesterday, but you may not get it in time. It takes our mail a while to get anywhere-- first it goes by mule to Waco, then heads farther north. Tim in central TX -----Original Message----- >From: Dick Navratil <horzpool(at)goldengate.net> >Sent: Apr 6, 2007 5:26 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Montana School Piet > >Thanks to all that have sent in a donation for the Montana kids. If anybody else has been thinking about it, there is still time to get it in before I send off the packet to their teacher, next Thur the 12 th. I will be sending along all of the notes guys have sent along. >As a reminder >Check to EAA Chapter 57 >Dick Navratil >1415 Skiles Ln. >Arden Hills, Mn. 55112 ________________________________________________________________________________
Date: Apr 07, 2007
I say use the heck out of it, Latex will probably last as long as poly woly big bucks. It will at least last as long as you will want it to. I would say recovering in 20-25 years is probably a smart thing to do, even if for none other than a very good inspection of the structure. For you folks who don't like the toxicity of MEK based poly tack, brush and what not, dad used a water based fabric cement called Ceco-Bond. You just mix with water and brush on. to seal the fabric you dilute it with more water and brush it over the whole surface. It is an approved product on some older airplanes like cubs and champs via STC. Don't get me wrong poly fiber is a GREAT system, it will work great. But if your building for GO and not SHOW and still want a good looking final product use the latex, and save that money for gas and hanger rent. Heck, I would bet Bernnie did not use top dollar aircraft dope on his. Probably used old barn paint or whatever he had. (maybe thats why they were red?) Just my 2 cents Shad --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. ________________________________________________________________________________
Date: Apr 07, 2007
Totally agree, the latex on my house has been exposed (unhangered) to direct Colorado sunlight at 6500 ft. for 11 years and it looks no different than the day we moved in (and it was not the higher quality latex either). If I fly my Piet 100 hours a year and hanger it the rest of the time it would take 482 years to get the same direct sunlight exposure time, and I don't plan on needing to repaint anytime soon. Rick On 4/7/07, shad bell wrote: > > > I say use the heck out of it, Latex will probably last as long as poly > woly big bucks. It will at least last as long as you will want it to. I > would say recovering in 20-25 years is probably a smart thing to do, even if > for none other than a very good inspection of the structure. > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 07, 2007
Subject: latex paint
I have had good results using latex on wooden boats. Here is an article you might find interesting _www.simplicityboats/latexcarnel.html_ (http://www.simplicityboats/latexcarnel.html) Ted Stone building a corvair powered Piet ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: latex paint
Date: Apr 07, 2007
I had to add .com to the www.simplicity link below (to make it www.simplicityboats.com/latexcarnel.html) but it was well worth it! VERY interesting article! Thanks Ted ----- Original Message ----- From: TGSTONE236(at)aol.com To: pietenpol-list(at)matronics.com Sent: Saturday, April 07, 2007 4:33 PM Subject: Pietenpol-List: latex paint I have had good results using latex on wooden boats. Here is an article you might find interesting www.simplicityboats/latexcarnel.html Ted Stone building a corvair powered Piet ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Apr 07, 2007
Tim Thanks for letting me know. I'll be watching for it. Dick ----- Original Message ----- From: "Tim Willis" <timothywillis(at)earthlink.net> Sent: Saturday, April 07, 2007 10:40 AM Subject: Re: Pietenpol-List: Montana School Piet > > > Dick, > > I mailed a check yesterday, but you may not get it in time. It takes our > mail a while to get anywhere-- first it goes by mule to Waco, then heads > farther north. > > Tim in central TX > > -----Original Message----- >>From: Dick Navratil <horzpool(at)goldengate.net> >>Sent: Apr 6, 2007 5:26 PM >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Montana School Piet >> >>Thanks to all that have sent in a donation for the Montana kids. If >>anybody else has been thinking about it, there is still time to get it in >>before I send off the packet to their teacher, next Thur the 12 th. I >>will be sending along all of the notes guys have sent along. >>As a reminder >>Check to EAA Chapter 57 >>Dick Navratil >>1415 Skiles Ln. >>Arden Hills, Mn. 55112 > > > ________________________________________________________________________________
Subject: Re: Squishing the Ends
Date: Apr 07, 2007
AMEN to that. Ken really knows what he is doing (and I don't - yet.) Ken has also come up with a bellcrank design that gets the elevator cable geometry right. i.e. you don't need a friction control device on top of the horizontal stab to keep the cables from rubbing a hole in the covering. It may not be the way BHP did it but I bet he would have used it had he seen it. < My solution was easy -- I purchased those components from Ken Perkins! : ) > Tom Stinemetze The Airplane Nut ____ | ____ \8/ / \ ________________________________________________________________________________
Subject: Re: Tachometer - where do you find one
Date: Apr 07, 2007
Listers: I am getting very close to having a panel to start designing my instrument layout. Consequently I need to find the sizes and spacing requirements for the final layout. I am having a little trouble trying to figure out where to find a tachometer that looks right for a Pietenpol but still operates electrically. I remember seeing one on DJ's website that has a max RPM of 3500 and receives it's signals from a tooth counter on the flywheel. (I'm also planning to use a Corvair engine.) The ones William Wynne recommends are digital which I suspect would get me laughed off the list. Any recommendations would be greatly appreciated. Tom Stinemetze The Airplane Nut ____ | ____ \8/ / \ ________________________________________________________________________________
Date: Apr 07, 2007
Messagemy analog tach was a Datcon. Datcon also makes the tooth counter which worked quite well. ----- Original Message ----- From: Tom Stinemetze To: pietenpol-list(at)matronics.com Sent: Saturday, April 07, 2007 8:04 PM Subject: Pietenpol-List: Re: Tachometer - where do you find one Listers: I am getting very close to having a panel to start designing my instrument layout. Consequently I need to find the sizes and spacing requirements for the final layout. I am having a little trouble trying to figure out where to find a tachometer that looks right for a Pietenpol but still operates electrically. I remember seeing one on DJ's website that has a max RPM of 3500 and receives it's signals from a tooth counter on the flywheel. (I'm also planning to use a Corvair engine.) The ones William Wynne recommends are digital which I suspect would get me laughed off the list. Any recommendations would be greatly appreciated. Tom Stinemetze The Airplane Nut ____ | ____ \8/ / \ ________________________________________________________________________________
Date: Apr 07, 2007
DJ - I thought you installed an EMS, why did you need a separate tach? Rick On 4/7/07, DJ Vegh wrote: > > my analog tach was a Datcon. Datcon also makes the tooth counter which > worked quite well. > > ----- Original Message ----- > *From:* Tom Stinemetze > *To:* pietenpol-list(at)matronics.com > *Sent:* Saturday, April 07, 2007 8:04 PM > *Subject:* Pietenpol-List: Re: Tachometer - where do you find one > > Listers: > > I am getting very close to having a panel to start designing my instrument > layout. Consequently I need to find the sizes and spacing requirements for > the final layout. I am having a little trouble trying to figure out where > to find a tachometer that looks right for a Pietenpol but still operates > electrically. I remember seeing one on DJ's website that has a max RPM of > 3500 and receives it's signals from a tooth counter on the flywheel. (I'm > also planning to use a Corvair engine.) The ones William Wynne recommends > are digital which I suspect would get me laughed off the list. Any > recommendations would be greatly appreciated. > > Tom Stinemetze > The Airplane Nut > > ____ | ____ > \8/ > / \ > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 07, 2007
I did install an EMS. but I wanted an analog tach in the panel. ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Saturday, April 07, 2007 9:20 PM Subject: Re: Pietenpol-List: Re: Tachometer - where do you find one DJ - I thought you installed an EMS, why did you need a separate tach? Rick On 4/7/07, DJ Vegh wrote: my analog tach was a Datcon. Datcon also makes the tooth counter which worked quite well. ----- Original Message ----- From: Tom Stinemetze To: pietenpol-list(at)matronics.com Sent: Saturday, April 07, 2007 8:04 PM Subject: Pietenpol-List: Re: Tachometer - where do you find one Listers: I am getting very close to having a panel to start designing my instrument layout. Consequently I need to find the sizes and spacing requirements for the final layout. I am having a little trouble trying to figure out where to find a tachometer that looks right for a Pietenpol but still operates electrically. I remember seeing one on DJ's website that has a max RPM of 3500 and receives it's signals from a tooth counter on the flywheel. (I'm also planning to use a Corvair engine.) The ones William Wynne recommends are digital which I suspect would get me laughed off the list. Any recommendations would be greatly appreciated. Tom Stinemetze The Airplane Nut ____ | ____ \8/ / \ -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
From: "GlennThomas(at)flyingwood.com" <glennthomas(at)flyingwood.com>
Date: Apr 08, 2007
Dick, I'm heading out and will drop mine in the mail. Don't know if it' Glenn W. Thomas Storrs, CT http://www.flyingwood.com ----- Original Message ----- From: "Dick Navratil" <horzpool(at)goldengate.net> Sent: Saturday, April 07, 2007 9:28 PM Subject: Re: Pietenpol-List: Montana School Piet > > > Tim > Thanks for letting me know. I'll be watching for it. > Dick > ----- Original Message ----- > From: "Tim Willis" <timothywillis(at)earthlink.net> > To: > Sent: Saturday, April 07, 2007 10:40 AM > Subject: Re: Pietenpol-List: Montana School Piet > > >> >> >> Dick, >> >> I mailed a check yesterday, but you may not get it in time. It takes our >> mail a while to get anywhere-- first it goes by mule to Waco, then heads >> farther north. >> >> Tim in central TX >> >> -----Original Message----- >>>From: Dick Navratil <horzpool(at)goldengate.net> >>>Sent: Apr 6, 2007 5:26 PM >>>To: pietenpol-list(at)matronics.com >>>Subject: Pietenpol-List: Montana School Piet >>> >>>Thanks to all that have sent in a donation for the Montana kids. If >>>anybody else has been thinking about it, there is still time to get it in >>>before I send off the packet to their teacher, next Thur the 12 th. I >>>will be sending along all of the notes guys have sent along. >>>As a reminder >>>Check to EAA Chapter 57 >>>Dick Navratil >>>1415 Skiles Ln. >>>Arden Hills, Mn. 55112 >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 08, 2007
Jim, Good article, not only does it makes good sense but sounds like a less expensive alternative to conventional treatments. John ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 08, 2007
Subject: door designs
I know that although its not part of the design and for purity sake probably not a proper modification which undoubtedly will bring tears to the eyes of the Piet purist, however. I know of no contortionist and therefor have to consider the possibility of passenger access and egress! Does anyone have a good structural design or drawing they would be willing to share for a passenger door? I would prefer a tried and true design that is designed to bolster the airframe rather than one that detracts from its structural integrity, so good engineering is key. I would appreciate hearing your thoughts and seeing any designs you the group may have. I figure that at the build stage I am at now planning and installing a door as part of the design is a lot easier and makes more sense than trying to cut one in after the fact. Thanks John ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Elect. tach
Tim. I bought an elect. tach. from Wicks. It has a small generator that requires a standard tach. mount thing. It looks more modern than I would like, but life is full of compromise. Some of these tachs have a sensor that you tie to a spark plug wire. Hows that for simplicity and not having worry about routing a heavy drive cable? Also eliminates the possibility (and expense) of up to 2 90 degree corner turner things. Leon S. Shivering in Ks. ________________________________________________________________________________
Date: Apr 08, 2007
From: Tim Verthein <minoxphotographer(at)yahoo.com>
It's a Corvar, right? Why not just visit your local auto parts shop and pick out a tach? Or snoop around online and track down a spiffy vintage reproduction tach? There are tons of them out there in a huge variety of sizes and styles. Connects to power, ground and coil. At last, that's how I connect them in my Corvairs...cars that is. tim in Bovey == You *can* repair a flip-flop with a capacitor! == No need to miss a message. Get email on-the-go with Yahoo! Mail for Mobile. Get started. http://mobile.yahoo.com/mail ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Travel to So Cal
It looks like Ill be in the greater LA area Ontario, Fontana and LA propper around the 16th of April or week of the 16th. I am again looking for builders and piets to visit. Anyone interested in getting together for show and tell or just a few beers! Please advise Contact off the list _Amsafetyc(at)aol.com_ (mailto:Amsafetyc(at)aol.com) Thanks John ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Cockpit door
I put the Price door in my front cockpit. It requires a 1''X5'' reinforcement plank that you could not bend enough for the taper that goes on threw the rear cockpit and continues to the tail post. (the taper, not the plank). The door is kind of a front cockpit thing only. Put on a step and learn to be a contortionest. Several years ago when Chuck and Doug Bryant had a Piet flyin at Benton Ks (Wichita) a man flew in with a Piet that had a right front door and a left door on the rear cockpit. It also had a Toyota engine. He only stayed a short time and left before I got to look at it. A year or so later the engine stopped on take off and he made a hard landing that destroyed the plane and put him in hospital for a long time. Leon S. ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Tachometer
I'm not a machinist and so am wondering what kind of electrical tach I can use rather than doing maching work on my Model A engine to accept a mechanical drive drive tach? Is there a tach available that will run off the magneto? Fred B. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Rib Drawing errors?
Group, I am plotting out my jig from the plans and there are a few areas that just can't be correct. Is there a revision sheet that I may be missing. Has anyone else had these same problems? I have been stuck on this for some time and need the help moving forward. I have checked and rechecked several times already. Any insight would be appreciated. Thank you, Ryan M. --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. ________________________________________________________________________________
Date: Apr 08, 2007
That's an understatement, based on the PolyFiber manual materials list to cover a J3 Cub (which would require maybe 10% more stuff than that for a Piet) and based on 2005 prices the cost comes to: Polyfiber Medium Fabric and Tape/Rings - $889 Paint (using polytone, the 'cheaper' stuff) - $2473 Total - $3362 (and 2007 prices are higher than this, e.g. PolyTak was $68 when I last added this up and its $86.80 now on the ACS wesite) versus - ACS homebuilders special 1.8 oz fabric & polyfiber tape - $600 1 gal. polytak - $87 3 gal. ext. latex gloss - $100 Total (very approximate) - $787 Rick On 4/8/07, AMsafetyC(at)aol.com wrote: > > Jim, > > Good article, not only does it makes good sense but sounds like a less > expensive alternative to conventional treatments. > > John > > > ------------------------------ > See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503>. > > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 08, 2007
WW recommends not wiring a tach to the coil as a short can kill the ignition. However Mark Langford hooks up his Grand Rapids this way and adds resistors to prevent a short (correct me if I am wrong guys, see Mark's website). Also only one of the two coils is connected so it would only shutdown one of the coils. WW uses a sensor that reads the teeth on the starter ring gear instead. Still debating which way I will go, really like the Grand Rapids EMS, does anyone know if it's tach input can be wired to a ring gear tooth sensor? Rick On 4/8/07, Tim Verthein wrote: > > minoxphotographer(at)yahoo.com> > > It's a Corvar, right? Why not just visit your local auto parts shop and > pick out a tach? Or snoop around online and track down a spiffy vintage > reproduction tach? There are tons of them out there in a huge variety > of sizes and styles. Connects to power, ground and coil. At last, > that's how I connect them in my Corvairs...cars that is. > > tim in Bovey > > == > You *can* repair a flip-flop with a capacitor! > == > > > No need to miss a message. Get email on-the-go > with Yahoo! Mail for Mobile. Get started. > http://mobile.yahoo.com/mail > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Clarification: Rib measurement
I have been through the archives and I only find slight reference to my problem. I have an "out of contour" (called a "kink" in the archive) condition in the upper of my airfoil, one forward and one aft. Please tell me you have seen this before. Thank you again, Ryan Ryan Michalkiewicz wrote: Group, I am plotting out my jig from the plans and there are a few areas that just can't be correct. Is there a revision sheet that I may be missing. Has anyone else had these same problems? I have been stuck on this for some time and need the help moving forward. I have checked and rechecked several times already. Any insight would be appreciated. Thank you, Ryan M. --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. --------------------------------- Bored stiff? Loosen up... Download and play hundreds of games for free on Yahoo! Games. ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Re: Rib Drawing errors?
Date: Apr 08, 2007
Ryan, As I recall, on the upper surface there are a few of the dimensions that just don't fit on the curve. The best way to deal with this is to take a long piece of wood, I used a cap strip, and use it to form a curve by holding on to both ends. Try to get it to line up with as many of the points as possible. Don't stress over missed points as this is one of the times where close is good enough. This airfoil is not supper critical to errors like a laminar flow airfoil. Remember, the finished wing will have some fabric sagging between the ribs thus changing the airfoil thickness. This is totally natural and occurs on many fabric covered airplanes and is part of the design of the wing. There are no supplemental plans or correction sheets on this. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Sunday, April 08, 2007 11:02 AM Subject: Pietenpol-List: Rib Drawing errors? Group, I am plotting out my jig from the plans and there are a few areas that just can't be correct. Is there a revision sheet that I may be missing. Has anyone else had these same problems? I have been stuck on this for some time and need the help moving forward. I have checked and rechecked several times already. Any insight would be appreciated. Thank you, Ryan M. ------------------------------------------------------------------------- ----- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. ________________________________________________________________________________
Date: Apr 08, 2007
You are not going nuts, except from frustration. Everyone has this problem. There is no official revision sheet, and no unofficial one, either, for instance, showing which parts need to be made longer or bolt-holes moved to allow better alignment or assembly. I have seen at least one corrected plot on a "Glider & Flying" reprint, but cannot lay my hands on it right now. Perhaps someone else can point out the one or two errors in the upper surface of the airfoil. I believe the full scale drawing corrects this/these. Tim in central TX -----Original Message----- >From: Ryan Michalkiewicz <mskybolt(at)yahoo.com> >Sent: Apr 8, 2007 1:02 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Rib Drawing errors? > > Group, I am plotting out my jig from the plans and there are a few areas that just can't be correct. Is there a revision sheet that I may be missing. Has anyone else had these same problems? I have been stuck on this for some time and need the help moving forward. I have checked and rechecked several times already. Any insight would be appreciated. > > Thank you, > > Ryan M. > > >--------------------------------- >TV dinner still cooling? >Check out "Tonight's Picks" on Yahoo! TV. ________________________________________________________________________________
Date: Apr 08, 2007
Thank you for the quick response. I figured I could do something like that. I just wanted to be sure I wasn't something I did. -Ryan Catdesigns wrote: Ryan, As I recall, on the upper surface there are a few of the dimensions that just don't fit on the curve. The best way to deal with this is to take a long piece of wood, I used a cap strip, and use it to form a curve by holding on to both ends. Try to get it to line up with as many of the points as possible. Don't stress over missed points as this is one of the times where close is good enough. This airfoil is not supper critical to errors like a laminar flow airfoil. Remember, the finished wing will have some fabric sagging between the ribs thus changing the airfoil thickness. This is totally natural and occurs on many fabric covered airplanes and is part of the design of the wing. There are no supplemental plans or correction sheets on this. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Sunday, April 08, 2007 11:02 AM Subject: Pietenpol-List: Rib Drawing errors? Group, I am plotting out my jig from the plans and there are a few areas that just can't be correct. Is there a revision sheet that I may be missing. Has anyone else had these same problems? I have been stuck on this for some time and need the help moving forward. I have checked and rechecked several times already. Any insight would be appreciated. Thank you, Ryan M. --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com --------------------------------- No need to miss a message. Get email on-the-go with Yahoo! Mail for Mobile. Get started. ________________________________________________________________________________
Date: Apr 08, 2007
Date: Apr 08, 2007
Subject: Re: Clarification: Rib measurement
When I recieved my plans , I got a full sized rib print. This is the one that I put on the rib board, and made the ribs to. My Piet flies great with this wing. Didn't you guys get this?? And as far as the metal fittings,,,just make them 1/4" longer , to stick out of the layers of fabric, so you can hook a fitting to it. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Sunday, April 08, 2007 4:13 PM Subject: Pietenpol-List: Clarification: Rib measurement I have been through the archives and I only find slight reference to my problem. I have an "out of contour" (called a "kink" in the archive) condition in the upper of my airfoil, one forward and one aft. Please tell me you have seen this before. Thank you again, Ryan Ryan Michalkiewicz wrote: Group, I am plotting out my jig from the plans and there are a few areas that just can't be correct. Is there a revision sheet that I may be missing. Has anyone else had these same problems? I have been stuck on this for some time and need the help moving forward. I have checked and rechecked several times already. Any insight would be ------------------------------------------------------------------------- --- Bored stiff? Loosen up... Download and play hundreds of games for free on Yahoo! Games. ________________________________________________________________________________
Date: Apr 08, 2007
Subject: Re: Just a few quick rib questions
>>Hello everyone; Just a few quick rib questions. First, let me say I took the advice of the list and threw out my full size rib print << Why would you do that?? Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Sunday, April 01, 2007 6:01 PM Subject: Pietenpol-List: Just a few quick rib questions Hello everyone; Just a few quick rib questions. First, let me say I took the advice of the list and threw out my full size rib print and am manually laying out my jig, thank you. I have not recived my full plans yet and I am working out of my builders manual, page 30. I have started with the "chord line" as illustrated, and plotted out the bottom side of the rib. I am confused whether the top mesurements are from the top of the rib to the chord line, or only to the bottom of the rib? Second, what are the first and last mesurements on the underside of the rib? There are arrows only, with no mesurements. Third, what is the lower mesurement opposite "4 1/2", 18" from the rear. it is between 7/32"and 1/16" Thank you, Ryan Ryan Michalkiewicz Skybolt Project ------------------------------------------------------------------------- ----- Never miss an email again! Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. ________________________________________________________________________________
Date: Apr 08, 2007
I didn't really throw it out, I still take a look at it every so often to confuse myself. Seriously though, It contains details that the drawing doesn't show. There is an 1/8" difference in the amount of upward curve between the drawing and the plans. From what I've read here in the archives, there is not a noticeable difference in the way they fly. walt evans wrote: >>Hello everyone; Just a few quick rib questions. First, let me say I took the advice of the list and threw out my full size rib print << Why would you do that?? Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Sunday, April 01, 2007 6:01 PM Subject: Pietenpol-List: Just a few quick rib questions Hello everyone; Just a few quick rib questions. First, let me say I took the advice of the list and threw out my full size rib print and am manually laying out my jig, thank you. I have not recived my full plans yet and I am working out of my builders manual, page 30. I have started with the "chord line" as illustrated, and plotted out the bottom side of the rib. I am confused whether the top mesurements are from the top of the rib to the chord line, or only to the bottom of the rib? Second, what are the first and last mesurements on the underside of the rib? There are arrows only, with no mesurements. Third, what is the lower mesurement opposite "4 1/2", 18" from the rear. it is between 7/32"and 1/16" Thank you, Ryan Ryan Michalkiewicz Skybolt Project --------------------------------- Never miss an email again! Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com --------------------------------- Bored stiff? Loosen up... Download and play hundreds of games for free on Yahoo! Games. ________________________________________________________________________________
Date: Apr 08, 2007
I remember after I covered and stitched my wing there were slight flat spots on the ribs from the covering pulling them in. I thought "oh no!", but it flies and probably doesn't know the difference! Like Chris said this is an area that you want to be as close as you can, and that's good enough. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=105779#105779 ________________________________________________________________________________
Date: Apr 08, 2007
Sorry to answer your question with another question but have you read the archive threads and BPA newsletter article concerning the Riblett 612 airfoil for the Pietenpol? If I was were you are in the building process I would order the excellent full size 612 airfoil plans from Roman ($10) or get the coordinates from Bill Rewey for a couple bucks. Just an interesting alternative. Rick On 4/8/07, walt evans wrote: > > When I recieved my plans , I got a full sized rib print. This is the one > that I put on the rib board, and made the ribs to. > My Piet flies great with this wing. > Didn't you guys get this?? > And as far as the metal fittings,,,just make them 1/4" longer , to stick > out of the layers of fabric, so you can hook a fitting to it. > Walt Evans > NX140DL > "No one ever learned anything by talking" > > ----- Original Message ----- > *From:* Ryan Michalkiewicz > *To:* pietenpol-list(at)matronics.com > *Sent:* Sunday, April 08, 2007 4:13 PM > *Subject:* Pietenpol-List: Clarification: Rib measurement > > I have been through the archives and I only find slight reference to > my problem. I have an "out of contour" (called a "kink" in the archive) > condition in the upper of my airfoil, one forward and one aft. Please tell > me you have seen this before. > > Thank you again, > Ryan > > *Ryan Michalkiewicz * wrote: > > Group, I am plotting out my jig from the plans and there are a > few areas that just can't be correct. Is there a revision sheet that I may > be missing. Has anyone else had these same problems? I have been stuck on > this for some time and need the help moving forward. I have checked and > rechecked several times already. Any insight would be > ------------------------------ > Bored stiff? <http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>Loosen up... > Download and play hundreds of games for free<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>on Yahoo! Games. > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 09, 2007
Tom, I ended up, after trying a number of different types, with the Stewart Warner analog tach that WW recommends Stewart Warner part no: 82636 & Stewart Warner sender 82646 I scuffed the chrome bezel with scotch-brite and painted it mat black. I then mounted it from the rear in to the panel secured with a home made nut plate. The automotive gauge is 3 3/8 diameter, much large than the 3 1/8 Aviation gauges. But by using the recessed rim and mounting it from the back the difference is less than 1/8" and hardly noticeable. Hans -----Original Message----- From: tstinemetze(at)cox.net Sent: Sat, 7 Apr 2007 10:04 PM Subject: Pietenpol-List: Re: Tachometer - where do you find one Listers: I am getting very close to having a panel to start designing my instrument layout. Consequently I need to find the sizes and spacing requirements for the final layout. I am having a little trouble trying to figure out where to find a tachometer that looks right for a Pietenpol but still operates electrically. I remember seeing one on DJ's website that has a max RPM of 3500 and receives it's signals from a tooth counter on the flywheel. (I'm also planning to use a Corvair engine.) The ones William Wynne recommends are digital which I suspect would get me laughed off the list. Any recommendations would be greatly appreciated. Tom Stinemetze The Airplane Nut ____ | ____ \8/ / \ ________________________________________________________________________ ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: mag powered tach for Model A
Date: Apr 09, 2007
I am using a Westach tach which runs off a lead to the mag. Larry Williams has been using one for a long time with no problems, and mine has worked well on the test stand. There theoretically is the potential of a short causing problems in the mag. Tony Bingilis recommends installing a small fuse between the mag and tach just in case. This is what Larry did, and I will do once it's in the plane. You can find them in the ACS catalog. Douwe ________________________________________________________________________________
Date: Apr 09, 2007
That same tach has a small wire inside that if you have the wrong rpm and you cut that wire it will give you the proper rpm.I believe it cuts the rpm in half when you cut the wire.It does come with a fuse.I haave the same one.I use it in my N3 Pup.My Piet uses another type of tach.Can't remember at this time what type that is. ________________________________ I am using a Westach tach which runs off a lead to the mag. Larry Williams has been using one for a long time with no problems, and mine has worked well on the test stand. ________________________________________________________________________________
Date: Apr 09, 2007
I have read about it and I am interested. Will there be a flying Riblett at SNF? ------Original Message------ From: Rick Holland <at7000ft(at)gmail.com> Date: Sun, Apr 8, 2007 08:31 PM Subject: Re: Pietenpol-List: Clarification: Rib measurement Sorry to answer your question with another question but have you read the archive threads and BPA newsletter article concerning the Riblett 612 airfoil for the Pietenpol? If I was were you are in the building process I would order the excellent full size 612 airfoil plans from Roman ($10) or get the coordinates from Bill Rewey for a couple bucks. Just an interesting alternative. Rick On 4/8/07, walt evans wrote: > > When I recieved my plans , I got a full sized rib print. This is the one > that I put on the rib board, and made the ribs to. > My Piet flies great with this wing. > Didn't you guys get this?? > And as far as the metal fittings,,,just make them 1/4" longer , to stick > out of the layers of fabric, so you can hook a fitting to it. > Walt Evans > NX140DL > "No one ever learned anything by talking" > > ----- Original Message ----- > *From:* Ryan Michalkiewicz > *To:* pietenpol-list(at)matronics.com > *Sent:* Sunday, April 08, 2007 4:13 PM > *Subject:* Pietenpol-List: Clarification: Rib measurement > > I have been through the archives and I only find slight reference to > my problem. I have an "out of contour" (called a "kink" in the archive) > condition in the upper of my airfoil, one forward and one aft. Please tell > me you have seen this before. > > Thank you again, > Ryan > > *Ryan Michalkiewicz * wrote: > > Group, I am plotting out my jig from the plans and there are a > few areas that just can't be correct. Is there a revision sheet that I may > be missing. Has anyone else had these same problems? I have been stuck on > this for some time and need the help moving forward. I have checked and > rechecked several times already. Any insight would be > ------------------------------ > Bored stiff? <http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>Loosen up... > Download and play hundreds of games for free<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>on Yahoo! Games. > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 09, 2007
Ryan I don't know about the 612, but I will be bringing along a NACA 4412 rib jig and I have a overlay for the regular Piet rib. The 4412 is used on the Champ and also has been used on the Piet. It, like the 612 has better stall habits and is a bit faster thean the Piet airfoil. I will have cap strips there and if you want, you can build a rib or 2. Dick N. ----- Original Message ----- From: "Ryan Michalkiewicz" <mskybolt(at)yahoo.com> Sent: Monday, April 09, 2007 8:59 AM Subject: Re:Re: Pietenpol-List: Clarification: Rib measurement I have read about it and I am interested. Will there be a flying Riblett at SNF? ------Original Message------ From: Rick Holland <at7000ft(at)gmail.com> Date: Sun, Apr 8, 2007 08:31 PM Subject: Re: Pietenpol-List: Clarification: Rib measurement Sorry to answer your question with another question but have you read the archive threads and BPA newsletter article concerning the Riblett 612 airfoil for the Pietenpol? If I was were you are in the building process I would order the excellent full size 612 airfoil plans from Roman ($10) or get the coordinates from Bill Rewey for a couple bucks. Just an interesting alternative. Rick On 4/8/07, walt evans wrote: > > When I recieved my plans , I got a full sized rib print. This is the one > that I put on the rib board, and made the ribs to. > My Piet flies great with this wing. > Didn't you guys get this?? > And as far as the metal fittings,,,just make them 1/4" longer , to stick > out of the layers of fabric, so you can hook a fitting to it. > Walt Evans > NX140DL > "No one ever learned anything by talking" > > ----- Original Message ----- > *From:* Ryan Michalkiewicz > *To:* pietenpol-list(at)matronics.com > *Sent:* Sunday, April 08, 2007 4:13 PM > *Subject:* Pietenpol-List: Clarification: Rib measurement > > I have been through the archives and I only find slight reference to > my problem. I have an "out of contour" (called a "kink" in the archive) > condition in the upper of my airfoil, one forward and one aft. Please tell > me you have seen this before. > > Thank you again, > Ryan > > *Ryan Michalkiewicz * wrote: > > Group, I am plotting out my jig from the plans and there are a > few areas that just can't be correct. Is there a revision sheet that I may > be missing. Has anyone else had these same problems? I have been stuck on > this for some time and need the help moving forward. I have checked and > rechecked several times already. Any insight would be > ------------------------------ > Bored stiff? > <http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>Loosen up... > Download and play hundreds of games for > free<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>on Yahoo! > Games. > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 09, 2007
FYI I believe the Kitfox uses the the Riblett 30A- 612 airfoil Roman Bukolt NX20795 ----- Original Message ----- From: "Dick Navratil" <horzpool(at)goldengate.net> Sent: Monday, April 09, 2007 11:10 AM Subject: Re: Re:Re: Pietenpol-List: Clarification: Rib measurement > > > Ryan > I don't know about the 612, but I will be bringing along a NACA 4412 rib > jig and I have a overlay for the regular Piet rib. The 4412 is used on > the Champ and also has been used on the Piet. It, like the 612 has better > stall habits and is a bit faster thean the Piet airfoil. I will have cap > strips there and if you want, you can build a rib or 2. > Dick N. > ----- Original Message ----- > From: "Ryan Michalkiewicz" <mskybolt(at)yahoo.com> > To: > Sent: Monday, April 09, 2007 8:59 AM > Subject: Re:Re: Pietenpol-List: Clarification: Rib measurement > > > > > I have read about it and I am interested. Will there be a flying Riblett > at SNF? > > ------Original Message------ > From: Rick Holland <at7000ft(at)gmail.com> > To: > Date: Sun, Apr 8, 2007 08:31 PM > Subject: Re: Pietenpol-List: Clarification: Rib measurement > > Sorry to answer your question with another question but have you read the > archive threads and BPA newsletter article concerning the Riblett 612 > airfoil for the Pietenpol? If I was were you are in the building process I > would order the excellent full size 612 airfoil plans from Roman ($10) or > get the coordinates from Bill Rewey for a couple bucks. Just an > interesting > alternative. > > Rick > > On 4/8/07, walt evans wrote: >> >> When I recieved my plans , I got a full sized rib print. This is the one >> that I put on the rib board, and made the ribs to. >> My Piet flies great with this wing. >> Didn't you guys get this?? >> And as far as the metal fittings,,,just make them 1/4" longer , to stick >> out of the layers of fabric, so you can hook a fitting to it. >> Walt Evans >> NX140DL >> "No one ever learned anything by talking" >> >> ----- Original Message ----- >> *From:* Ryan Michalkiewicz >> *To:* pietenpol-list(at)matronics.com >> *Sent:* Sunday, April 08, 2007 4:13 PM >> *Subject:* Pietenpol-List: Clarification: Rib measurement >> >> I have been through the archives and I only find slight reference >> to >> my problem. I have an "out of contour" (called a "kink" in the archive) >> condition in the upper of my airfoil, one forward and one aft. Please >> tell >> me you have seen this before. >> >> Thank you again, >> Ryan >> >> *Ryan Michalkiewicz * wrote: >> >> Group, I am plotting out my jig from the plans and there are a >> few areas that just can't be correct. Is there a revision sheet that I >> may >> be missing. Has anyone else had these same problems? I have been stuck on >> this for some time and need the help moving forward. I have checked and >> rechecked several times already. Any insight would be >> ------------------------------ >> Bored stiff? >> <http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>Loosen up... >> Download and play hundreds of games for >> free<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>on Yahoo! >> Games. >> >> * >> >> href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List >> href="http://forums.matronics.com">http://forums.matronics.com >> * >> >> * >> >> >> * >> >> > > > -- > Rick Holland > > "Logic is a wreath of pretty flowers, that smell bad" > > > ________________________________________________________________________________
Date: Apr 09, 2007
Where will you be? I will be at SNF Tuesday through Friday and would like to see the 612 and anything else concerning the Pietenpols. Thanks! Max ----- Original Message ----- From: "Dick Navratil" <horzpool(at)goldengate.net> Sent: Monday, April 09, 2007 11:10 AM Subject: Re: Re:Re: Pietenpol-List: Clarification: Rib measurement > > > Ryan > I don't know about the 612, but I will be bringing along a NACA 4412 rib > jig and I have a overlay for the regular Piet rib. The 4412 is used on > the Champ and also has been used on the Piet. It, like the 612 has better > stall habits and is a bit faster thean the Piet airfoil. I will have cap > strips there and if you want, you can build a rib or 2. > Dick N. > ----- Original Message ----- > From: "Ryan Michalkiewicz" <mskybolt(at)yahoo.com> > To: > Sent: Monday, April 09, 2007 8:59 AM > Subject: Re:Re: Pietenpol-List: Clarification: Rib measurement > > > > > I have read about it and I am interested. Will there be a flying Riblett > at SNF? > > ------Original Message------ > From: Rick Holland <at7000ft(at)gmail.com> > To: > Date: Sun, Apr 8, 2007 08:31 PM > Subject: Re: Pietenpol-List: Clarification: Rib measurement > > Sorry to answer your question with another question but have you read the > archive threads and BPA newsletter article concerning the Riblett 612 > airfoil for the Pietenpol? If I was were you are in the building process I > would order the excellent full size 612 airfoil plans from Roman ($10) or > get the coordinates from Bill Rewey for a couple bucks. Just an > interesting > alternative. > > Rick > > On 4/8/07, walt evans wrote: >> >> When I recieved my plans , I got a full sized rib print. This is the one >> that I put on the rib board, and made the ribs to. >> My Piet flies great with this wing. >> Didn't you guys get this?? >> And as far as the metal fittings,,,just make them 1/4" longer , to stick >> out of the layers of fabric, so you can hook a fitting to it. >> Walt Evans >> NX140DL >> "No one ever learned anything by talking" >> >> ----- Original Message ----- >> *From:* Ryan Michalkiewicz >> *To:* pietenpol-list(at)matronics.com >> *Sent:* Sunday, April 08, 2007 4:13 PM >> *Subject:* Pietenpol-List: Clarification: Rib measurement >> >> I have been through the archives and I only find slight reference >> to >> my problem. I have an "out of contour" (called a "kink" in the archive) >> condition in the upper of my airfoil, one forward and one aft. Please >> tell >> me you have seen this before. >> >> Thank you again, >> Ryan >> >> *Ryan Michalkiewicz * wrote: >> >> Group, I am plotting out my jig from the plans and there are a >> few areas that just can't be correct. Is there a revision sheet that I >> may >> be missing. Has anyone else had these same problems? I have been stuck on >> this for some time and need the help moving forward. I have checked and >> rechecked several times already. Any insight would be >> ------------------------------ >> Bored stiff? >> <http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>Loosen up... >> Download and play hundreds of games for >> free<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>on Yahoo! >> Games. >> >> * >> >> href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List >> href="http://forums.matronics.com">http://forums.matronics.com >> * >> >> * >> >> >> * >> >> > > > -- > Rick Holland > > "Logic is a wreath of pretty flowers, that smell bad" > > > ________________________________________________________________________________
Subject: Brodhead 2007
Date: Apr 09, 2007
Looking ahead a few months... As I just read in the most recent BPA newsletter, at this year's Pietenpol Reunion (July 20, 21, 22) the BPA News is planning to sponsor forums all day on Saturday. The last couple of years have not had much in the way of forums - but this year looks like there should be a good selection. Here's a link to the newsletter website: http://pietenpols.tripod.com/id1.html Bill C. ________________________________________________________________________________
Date: Apr 09, 2007
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: paint information
Ultraviolet Absorption of Latex Paints by Kirk Huizenga For many years there has been discussions on the Pietenpol mail list as to the suitability of exterior latex paint as a system for covering an aircraft. A number of builders have completed their projects and have used latex paint to cover the fabric with claimed success. One issue that had not been tested is the ability of latex paint to protect Dacron fabric from damaging UV light. In standard systems, there is a barrier layer of paint applied prior to color coats. In the Poly-fiber system this is called Poly-spray. In the past, builders that have used latex paint to cover their fabric have sealed the fabric with black latex paint with the idea that black paint would absorb the most visible light and, hopefully, UV light. This, in turn, would protect the fabric from degradation. I have considered using latex paint on my Pietenpol rebuild, but wanted to be certain that it would, in-fact protect the fabric from UV degradation. There are builder that have had latex covered fabric for over 10 years without incident, but better safe than sorry. One should not assume that because visible light is being blocked that UV light is also being blocked. Methodology: I contacted a friend of mine, Dr. Tom Varberg, a Professor of Chemistry at Macalester College in St Paul, MN and asked him about testing the paints. Tom agreed to help me in the testing by using a Beckman DU7400 Spectrometer. The spectrometer can record Transmittance, the amount of visible and ultraviolet light lost (or conversely, absorbed) by a material. Transmittance is the ratio of radiant power (p/o ) that makes it through the substance (paint) to the radiant power (P ) sent into the substance. Transmittance can then be converted to Absorption (A) with the formula. Tom also supplied me with a small disk of quartz to use as a base for testing the paint at an appropriate thickness - similar to that expected when covering fabric. Quartz does not absorb or restrict UV light in the wavelengths we were PO P T = PO P A = −logT Ultraviolet Absorption of Latex Paints by Kirk Huizengatesting (400-200nm) and therefore would not introduce error in the absorption readings. I applied 4 different paints 1. Kilz Latex White 2. Glidden Exterior Latex-Wooland Green 3. Behr Exterior Flat Black 4. Poly-Fiber Poly-Brush) to the quartz with a small brush. After shooting a blank to calibrate the spectrometer, one of the painted areas on the disk was placed between the light source and the sensor. The light source flashes on (2 seconds for our test) and the sensor picks-up any energy that makes it through the paint. The DU7400 gives a graphic representation of Absorbance at each wavelength (in nanometers). In the charts below, I averaged the Absorption of every block of 10 nanometer since there were 600 data points for each sample (from 800 to 200 nanometers). As a curiosity, I also prepared some lightweight Poly- Fiber fabric generously given to me by Gil Leiter of St Paul, MN and tested it. I heat shrunk the fabric and tested it with and without paint and Poly-Brush (generously given by Pietenpoler, Robert Haines). The results are shown in Chart #2. Limitations: The Beckman DU7400 Spectrometer is limited to an absorption of 4.5 (but we will consider that to be sufficient at T=.0031%) The DU7400 is likely to show erroneous data or noise when at either extreme of its measurement (0 or 4.5). Some data for specific wavelengths may not be accurate, but a trend is obvious The testing we did does not account for reflection. Any light reflected by the paint would show up as being absorbed. This doesnt really change the applicability of the test results, but does raise a question of what color paint is the best to use on sealing and protecting the fabric. This is only a test of the UV blocking ability of latex (Continued on page 6) F or many years there has been discussions on the Pietenpol mail list as to the suitability of exterior latex paint as a system for covering an aircraft. A number of builders have completed their projects and have used latex paint to cover the fabric with claimed success. One issue that had not been tested is the ability of latex paint to protect Dacron fabric from damaging UV light. In standard systems, there is a barrier layer of paint applied prior to color coats. In the Poly-fiber system this is called Poly-spray. In the past, builders that have used latex paint to cover their fabric have sealed the fabric with black latex paint with the idea that black paint would absorb the most visible light and, hopefully, UV light. This, in turn, would protect the fabric from degradation. I have considered using latex paint on my Pietenpol rebuild, but wanted to be certain that it would, in-fact protect the fabric from UV degradation. There are builder that have had latex covered fabric for over 10 years without incident, but better safe than sorry. One should not assume that because visible light is being blocked that UV light is also being blocked. Methodology: I contacted a friend of mine, Dr. Tom Varberg, a Professor of Chemistry at Macalester College in St Paul, MN and asked him about testing the paints. Tom agreed to help me in the testing by using a Beckman DU7400 Spectrometer. The spectrometer can record Transmittance, the amount of visible and ultraviolet light lost (or conversely, absorbed) by a material. Transmittance is the ratio of radiant power that makes it through the substance (paint) to the radiant power sent into the substance. Transmittance can then be converted to Absorption with the formula. Tom also supplied me with a small disk of quartz to use as a base for testing the paint at an appropriate thickness - similar to that expected when covering fabric. Quartz does not absorb or restrict UV light in the wavelengths we were Ultraviolet paints. It does not deal with any other issues of using non-certified methods of covering and painting ones experimental aircraft like longevity, ability to seal the weave, adhesion, or flexibility/brittleness of latex paint. The Poly-Spray was tested with two layers one on the front of the disk and one on the back. We found that this introduced some errors. Some of the energy that makes it through the first layer of paint gets bounced around between the two layers and gives odd readings. Conclusions Latex paint can sufficiently blocks UV radiation and therefore protect Dacron fabric. Color does not seem to matter as far as level of absorption differences are extremely minor (in the range of thousands of a percent) This is a matter open for discussion, but the practice of using black paint as the base/sealing coat on fabric to block UV light may not be the best practice. White, in theory, would be a better paint for that. White paint has a high amount of Titanium Dioxide, which is highly reflective. Black paint, on the other hand, gets its color from Carbon Black primarily. Black paints have much less reflectivity and more absorption of light. Now, as I mentioned above, color does not seem to matter much in terms of protecting the fabric, but paint that is more reflective should last longer than paint that is more absorbing of light. It is not an issue of black or white being better at protecting the fabric, but rather the longevity and protection of the paint itself from breakdown. Brand of paint shouldnt make much difference in terms of UV protection, but could make a difference in durability and longevity of your paint job. The above courtesy of http://www.eaa54.org 54NewsletterMarch2003.pdf --------------------------------- Be a PS3 game guru. Get your game face on with the latest PS3 news and previews at Yahoo! Games. ________________________________________________________________________________
Date: Apr 09, 2007
Just make sure you have room for the spars. :-) Clif Thank you for the quick response. I figured I could do something like that. I just wanted to be sure I wasn't something I did. -Ryan ________________________________________________________________________________
Date: Apr 09, 2007
I believe that was in the later Sky Scout article in the 1933 issue. There are some changes in that. Clif > > I have seen at least one corrected plot on a "Glider & Flying" reprint, > but cannot lay my hands on it right now. Perhaps someone else can point > out the one or two errors in the upper surface of the airfoil. I believe > the full scale drawing corrects this/these. > > Tim in central TX > ________________________________________________________________________________
Date: Apr 09, 2007
Subject: Re: securing the LE of the Pietenpol stabilizer
Drilled head bolts and safety wire. http://www.wicksaircraft.com/catalog/product_cat.php/subid=850/index.html Clif > What keeps this bolt from backing out from continued vibration, over time, > from either a Tinneman nut or a "Home Depot speednut"? > > Do you put a lock or star washer on the bolt (at the top of the HStab), > use Loc-tite on its threads, or what? > > Tim in central TX > ________________________________________________________________________________
Date: Apr 09, 2007
< It's a Corvar, right? Why not just visit your local auto parts shop and pick out a tach? Or snoop around online and track down a spiffy vintage reproduction tach? There are tons of them out there in a huge variety of sizes and styles. Connects to power, ground and coil. At last, that's how I connect them in my Corvairs...cars that is. > Yes, I know, tachs are a dime a dozen, but it's pretty difficult to find an auto tach at someplace like Autozone which registers less than 8-10 thou. DJ Veigh e-mailed me with a suggestion to Google "Datcon" which is what he used on his Corvair. I tried that simple solution and found a raft of usable tachs, the majority of which use some form of electric signal. I really appreciate the ease of installation of an electric wire over a mechanical linkage. Tom Stinemetze ____ | ____ \8/ / \ ________________________________________________________________________________
Date: Apr 09, 2007
MessageA few guys experienced some issues with "standard" tachs when hooking up to coil. Myself included. I tried 2 tachs before the Datcon with tooth counter and both of them were erratic and way off. Tried all the normal methods of getting it to steady to no avail. Only the Grand Rapids EIS ach and my tooth counter worked with any sort of accuracy. DJ ----- Original Message ----- From: Tom Stinemetze To: pietenpol-list(at)matronics.com Sent: Monday, April 09, 2007 5:59 PM Subject: Re: Pietenpol-List: Tachometer - where do you find one < It's a Corvar, right? Why not just visit your local auto parts shop and pick out a tach? Or snoop around online and track down a spiffy vintage reproduction tach? There are tons of them out there in a huge variety of sizes and styles. Connects to power, ground and coil. At last, that's how I connect them in my Corvairs...cars that is. >Yes, I know, tachs are a dime a dozen, but it's pretty difficult to find an auto tach at someplace like Autozone which registers less than 8-10 thou. DJ Veigh e-mailed me with a suggestion to Google "Datcon" which is what he used on his Corvair. I tried that simple solution and found a raft of usable tachs, the majority of which use some form of electric signal. I really appreciate the ease of installation of an electric wire over a mechanical linkage. Tom Stinemetze ____ | ____ \8/ / \ ________________________________________________________________________________
Date: Apr 09, 2007
I will be working in the Wood Workshop. It is up near the main entry. For anyne else who wants to stop by and help out we will be assemblying a Volmer VJ 22 fuselage this year. If anyone wants some fast progress on a Piet project next near, let us know. We can fit in another project for the future. The wood workshop is kind of Pietenpol central at the show. Dick N. ----- Original Message ----- From: "Max Hegler" <MaxHegler(at)msn.com> Sent: Monday, April 09, 2007 12:24 PM Subject: Re: Re:Re: Pietenpol-List: Clarification: Rib measurement > > Where will you be? I will be at SNF Tuesday through Friday and would like > to see the 612 and anything else concerning the Pietenpols. > > Thanks! > Max > > ----- Original Message ----- > From: "Dick Navratil" <horzpool(at)goldengate.net> > To: > Sent: Monday, April 09, 2007 11:10 AM > Subject: Re: Re:Re: Pietenpol-List: Clarification: Rib measurement > > >> >> >> Ryan >> I don't know about the 612, but I will be bringing along a NACA 4412 rib >> jig and I have a overlay for the regular Piet rib. The 4412 is used on >> the Champ and also has been used on the Piet. It, like the 612 has >> better stall habits and is a bit faster thean the Piet airfoil. I will >> have cap strips there and if you want, you can build a rib or 2. >> Dick N. >> ----- Original Message ----- >> From: "Ryan Michalkiewicz" <mskybolt(at)yahoo.com> >> To: >> Sent: Monday, April 09, 2007 8:59 AM >> Subject: Re:Re: Pietenpol-List: Clarification: Rib measurement >> >> >> >> >> I have read about it and I am interested. Will there be a flying Riblett >> at SNF? >> >> ------Original Message------ >> From: Rick Holland <at7000ft(at)gmail.com> >> To: >> Date: Sun, Apr 8, 2007 08:31 PM >> Subject: Re: Pietenpol-List: Clarification: Rib measurement >> >> Sorry to answer your question with another question but have you read the >> archive threads and BPA newsletter article concerning the Riblett 612 >> airfoil for the Pietenpol? If I was were you are in the building process >> I >> would order the excellent full size 612 airfoil plans from Roman ($10) or >> get the coordinates from Bill Rewey for a couple bucks. Just an >> interesting >> alternative. >> >> Rick >> >> On 4/8/07, walt evans wrote: >>> >>> When I recieved my plans , I got a full sized rib print. This is the >>> one >>> that I put on the rib board, and made the ribs to. >>> My Piet flies great with this wing. >>> Didn't you guys get this?? >>> And as far as the metal fittings,,,just make them 1/4" longer , to stick >>> out of the layers of fabric, so you can hook a fitting to it. >>> Walt Evans >>> NX140DL >>> "No one ever learned anything by talking" >>> >>> ----- Original Message ----- >>> *From:* Ryan Michalkiewicz >>> *To:* pietenpol-list(at)matronics.com >>> *Sent:* Sunday, April 08, 2007 4:13 PM >>> *Subject:* Pietenpol-List: Clarification: Rib measurement >>> >>> I have been through the archives and I only find slight reference >>> to >>> my problem. I have an "out of contour" (called a "kink" in the archive) >>> condition in the upper of my airfoil, one forward and one aft. Please >>> tell >>> me you have seen this before. >>> >>> Thank you again, >>> Ryan >>> >>> *Ryan Michalkiewicz * wrote: >>> >>> Group, I am plotting out my jig from the plans and there are a >>> few areas that just can't be correct. Is there a revision sheet that I >>> may >>> be missing. Has anyone else had these same problems? I have been stuck >>> on >>> this for some time and need the help moving forward. I have checked and >>> rechecked several times already. Any insight would be >>> ------------------------------ >>> Bored stiff? >>> <http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>Loosen up... >>> Download and play hundreds of games for >>> free<http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>on Yahoo! >>> Games. >>> >>> * >>> >>> href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List >>> href="http://forums.matronics.com">http://forums.matronics.com >>> * >>> >>> * >>> >>> >>> * >>> >>> >> >> >> -- >> Rick Holland >> >> "Logic is a wreath of pretty flowers, that smell bad" >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 09, 2007
One other thing about the 612 drawing, it assumes 3/4" wide spars as most people use now days. Using the original plans I, like many people, built the ribs with 1" gaps and then added 1/8" ply spacers on both sides when assembling. Rick On 4/9/07, Ryan Michalkiewicz wrote: > > mskybolt(at)yahoo.com> > > I have read about it and I am interested. Will there be a flying Riblett > at SNF? > > ------Original Message------ > From: Rick Holland <at7000ft(at)gmail.com> > To: > Date: Sun, Apr 8, 2007 08:31 PM > Subject: Re: Pietenpol-List: Clarification: Rib measurement > > Sorry to answer your question with another question but have you read the > archive threads and BPA newsletter article concerning the Riblett 612 > airfoil for the Pietenpol? If I was were you are in the building process I > would order the excellent full size 612 airfoil plans from Roman ($10) or > get the coordinates from Bill Rewey for a couple bucks. Just an > interesting > alternative. > > Rick > > On 4/8/07, walt evans wrote: > > > > When I recieved my plans , I got a full sized rib print. This is the > one > > that I put on the rib board, and made the ribs to. > > My Piet flies great with this wing. > > Didn't you guys get this?? > > And as far as the metal fittings,,,just make them 1/4" longer , to stick > > out of the layers of fabric, so you can hook a fitting to it. > > Walt Evans > > NX140DL > > "No one ever learned anything by talking" > > > > ----- Original Message ----- > > *From:* Ryan Michalkiewicz > > *To:* pietenpol-list(at)matronics.com > > *Sent:* Sunday, April 08, 2007 4:13 PM > > *Subject:* Pietenpol-List: Clarification: Rib measurement > > > > I have been through the archives and I only find slight reference > to > > my problem. I have an "out of contour" (called a "kink" in the archive) > > condition in the upper of my airfoil, one forward and one aft. Please > tell > > me you have seen this before. > > > > Thank you again, > > Ryan > > > > *Ryan Michalkiewicz * wrote: > > > > Group, I am plotting out my jig from the plans and there are a > > few areas that just can't be correct. Is there a revision sheet that I > may > > be missing. Has anyone else had these same problems? I have been stuck > on > > this for some time and need the help moving forward. I have checked and > > rechecked several times already. Any insight would be > > ------------------------------ > > Bored stiff? <http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>Loosen > up... > > Download and play hundreds of games for free< > http://us.rd.yahoo.com/evt=49935/*http://games.yahoo.com>on Yahoo! Games. > > > > * > > > > href="http://www.matronics.com/Navigator?Pietenpol-List"> > http://www.matronics.com/Navigator?Pietenpol-List > > href="http://forums.matronics.com">http://forums.matronics.com > > * > > > > * > > > > > > * > > > > > > > -- > Rick Holland > > "Logic is a wreath of pretty flowers, that smell bad" > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Fw: piet kids
Date: Apr 10, 2007
Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick ------------------------------------------------------------------------- ------- See what's free at AOL.com. /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcHBw8LCwkMEQ8SEhEP ERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcGBw4ICA4eFBEUHh4eHh4e Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh7/wAARCAEZAeADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD0SNlA wRy3IIpd2XKtyPYY5qNTuXYAenOPXgf5+lPXaWI9+PTnNYmhImAxLDOV+mM//qpcgFnZsnHcYGM9 PemJjKgkHt049P8AJp3GPvEc5PzdDzQA6Mbuu4bOvBNO25PfBHU0xTnIyOe56f8A66f8zRkkAZPp 65OPbpTAceDggE55PUn/ADilzgkADA60xc7ztAXHOAemeufzqUDccZyCenSgYu4HG0jpSrw/UYAy WHIP/wBbpRlgOpAPpxRGMnJBJzkg/wA6BDjg9GGOo456UuB0U5Dc5A600krnIzuHOfrTlI28A++e f8/54pCHLjpjpyQaUhlbaDgjrgfnSZyCc57jFITkdenUimA5cbOOuOtKAQemPakOTyM5pBgLgk4H U96AHYwDnoeelAHQnkj8KCx6A+546UY3A88UAKDkkY5x1pQBwCvI6U3PXJ/WgjryT2OeaAHEjqOv qKQHJ7Ht16UrFRk54+n9PwpAu1cEhsZzgYFMQp5Y8du4o5GduKQYGMjr7cUuR1OCfT0oAUFsgccj k9RQBhiwycfpQWzwOB7UwZIyR0PODnikMeCTwAOB+VC5OCuMdOaMBcFs/MM88ZpCOOp+lMBc7hz6 8/SjsR+We1KCDgHGMU0jg/NwKQACwG4Lkj060uRzjue9IeF+baPfPApRjJ/iOTnFADBgZ9zngUAf NjkjsKcvIwAcj3zSEZJz/OgBMkHgACmnj5iBt7E9qcQGwSucd8e1I5I4Cn5hx6f56UAIoXAypP1o 7EqQOcjPNBxvODkdzSADHynGOOeabAQjjJHIwQDQ/AwM5HTHalGc84yewNNyN3CgZ7A0DEYnb90I eM45H/16ZnLDc+T2J9aVtyKR8xCkMOwx/LNNU5KtvXceR/tCgBccHGRkcnFRvwThSRwBzyPX8Klk y2SSc1G2ASqqQufxB70ARoDhS+4Y5G1e1ITlRgAnoe5yOf8AOKcQQ27LHnOPwphXBDEKBg8njAoE hCeSfunHHX1oOPlBYYzjgd/SgJ8hOAWzjPPv1FN/jOBuPYetMY11xvBXnHP9OnNMfAbeCSfc9/60 5yWOD07g01+QQSeD3PSgQxsg4GNx549D7U0Hjrkg56c8/wCTTyGWTKsuei84H5/1/wAhhUFgD25A HQf5/pQA0HaCQep/PrTHJB5znGRgdfTmnyFeVORuzyB0P9KY21lVM7unTsaBESlmGc4IGcZ/DkUx j8xIU9c9O3+c1L82M8c9fl71Fksxxu5B4P68mgAJUxqDwcHBXuM+35U18E4DcHgEjqafwrcrg/T8 KYSVcoxy/senQUwIivboOh2gHNRscqQRnHT8elTSdy3UnOc8/rUc2WO11JUnI44oA3MJ97pg4GfT rSYJk3PwSAMZBzx1/X9KQ9BjGe5xT1Yjg/lWZQ7Dh+uc4OPSpFwTt7gc47D/ACKZERsIU4AAGTT9 qhvmC7W6kcn8B1oAc4wQDk4x6GjdtBXkZJJ/P1/KmkMdq4AUE8A98dR+FPHHIYjjPSgY9Ccbs5Ld QBnvSpnb+AI600HHy9T6EcE09QGUBjzntzk+1ADn3KQGyfXHSgDPKjP0PT8qbuBcgkg4yMf5+tBA DH5tpA6n8v8AGgQ9ehZkzxwcDP1P+f1p+4g9dwAP4d6jPQ5I496euchdo/EcfjQAEfdxhcdu1ObB wOfTJo3ZGNwGeSaXjdxwe3GP1oADndtPUdf/ANdGGyMEAbSMDgD6UAgbsevBU4/H9aUZI+bPHHBp iFTc+S4UHrgHoaXnrkYpueevqAc05eMcDjpz+VAA2M4yOO9BVgSCpGDg8UZOMnJ29yeB7fzpAduC 3JJ7/wCf8/zAAZbkgEg9RzkUo+96nGSaUHbnPWlALDAwc+1AAc7j/SgKzHAUk96ADuDZyfrzxQME YY8dc+2eaAALvb5ecH0/zxSJv2gjj26YNIpbkjJx1Pr69KcO/JOaAEBYde3fNPbKDB5yemOKQEjn ac9aUegU47nH86AGlW5OMDqO3+etITgnPY4J96cVBAG4E4poGRngMcHA7e1AAOAcAjnP1oPAIA59 j3oGDjtSgH6Y64oAQYJxkE0MDznkgfXFBxg9cDvnOPrQASPl6bsYz3oAbgdM/rRyV6Dj8/xoGc7s E7Rngc0c+uOKAG4QZwAMnOMYBNAYDHI78Up+7nd+NKDkHIBPSmAwnJX5tpPHXrTWPB/hA7+mBnNK eCTjGT0xkj0FJuZmIwW+bOSBx7e9AxAxXBbJOR27e2aaTl8kAKTyeRTsZz0z1GBgfh7U0OARkcA8 jPAoAGXLDAGR7Yx/nFRt1yCckc5GMYp+Dk7yWUevc96M7T0xjpkcjI9frQBGW4ZiuAvX/P0zTRjD OQVPBx296VN27a3C8Anvk+9IwHHVj9OD/kUAN6SEfLj0A6df8/lUTgkcEAkdPXNSAZz1wePrSbDk YIb3zQAxVJUnBwoxnrUTfL3PXGP0/rUsgBY/Lyo6c/MPSmP987l4HXaep46j0oERs74MrIc842Dj jn6CgBgw3AAA9c5xz1pxOAGOcMPSkKgtyOMc4Gf/ANdAETKHyASSRnOSCaaxIIzwD2PXJP8A9epc Z/PHJ4+nPNREEEkjIPXHA96AG7QSSQccdP51GcnDMSpxgFev5CpJ9+cLtxnHqM8f40xhye+enFAW GjAbaOM8n/8AV+VRNtEpwRg9WB4Pb8akbDnaucEcDP8AOmqrNu3HnG3Hv149v6mmIYwJUMc7T/n/ AAqHeCm5jyTw2QP8/WrExbllJIx0ye2Ov+T/AFqFVbjd2Pzenr/T+dAGwMAdMhh37/07U8AYCKwB wO350xQxJDkcAgcZ/L9KkXfv3YYL7cj/AD/hUFjlUdxyvpjinHORnP0xjmmrlckso64xz60qqCTl d2eufrQIcw3x7Tknr0zjj8M9qcSVXBAyAOB3pG6ZXAJPb+VL85DAMAcHGc8A/SgZIqfNkMeBkDPf 8PengKEDBc9s4/nUQJUYyfx6/X+dPUZUYK4zwR3/AB60ALjagGecHOB+VO7Ek7e+MZ5pueytnnp0 pwzj5cnP60CHfx4HTtx3x1/WnKDyhAyOB7+lMJcouCTg49CevalRSHDBflPHfj0zQBIAv3s/40qA nKnGT7UA4PLZOeB6Uhyy/wAXHU859u9ACkH+FsfhkEUDse4OfpxSg546g9utMldYImkkdFVVLM7k BVAGSSSeBQBICWGD04I460Z3HaWGSTwe/wDnNZtlrug3txHaWWtadczuzhYorpHclfvDAOcr39O9 XhJuhEio7gnAUrtP/j2PSmIlbIzjt+dGRuJ9h1NZGr6pcWOsaPZrbxPHf3/2XzN53KPstxMeMYBz CoHJ4Y5xxnUD4A3HYDjhgBz1wPX8KAJCTxgAdsY70inK4A56dvrVc3doGIku7dX4wDIM8/WnwXFv OSILmOXaT91s/wCe1ICfHOOMdqB69ODinssg+YqRkg+hpjL8uHzjqen+etAAPu+h70nAX7wHPTrU DXcSkErdEkHpBIfX0FTW7iYBwrLk87xtI/PFNDH9B6emDjFGQDwPwqQw7ZArtEoOOQ4IGfpWPba7 p0+l2N9dSf2b9tgSeG3vnjjmCMMjcocjPPIBOOh5FAGo3UnFAP8ACCDVSO8E67raGS4GeDE8bDH/ AH1/nNSo9wzAHTrqMd2bYQPrhqAJecD5MY4GAKOQQzHnsc96SSWxt4vNv9Rt7EHgCc47/l+tU9S1 rRbYbhq1pMGOB5ZL+/O0EjjHJwPfpRZiLoAxyfpSHliSvPpXMW/imeW9aARaMIiT5Un26Ybhzywa 3AU+2TW4uraWI98+pWSkfK225RlU+mSRRYC169csOc0Dk88nNVv7S09wNmoWJz0LTIQT+dc5rXiC 1R4m/wCEpWyFrcRyTRw6U85u1IIEG7JCBiynzO20c4JIdmwOr57kD6d6Tkc9P5Vz8XjPRSql4r0E gjBEYAP/AH1TY/GelM2z7NcoOm/CfNz/AL3fNPlYXN9sBsdQKTII6ccHHtXOT+KNO5KT3yj0RI/T 3pE8XaYi5dNQJGcK0UfX04NLlYXOicK+Pm/HP9aTPLA/KBwD/P61yh8bPJnGkpHg/Kwm3DHuMDHb v61BL4rglbK2MoznAF44H6Dr060+RhdHYhW6lSM9AfwoI5Oe/p39v51y0fi6CJN5s5c9CGm3Y9OW pt142Z3y+mbl56ygH/0GjlYXR07fMuNowDzgfqKZg52CMbmPP4VxFz4ol+05t9LsQpX5VkiLEE56 kYz+Q75qmniHV4pgn2kKRgttijJHcdFHHT6e9UoNhc7PW9a0jQ4DdatqFpZKYnlUTSBXkVcFtife cjI4UE5IGMkZNF1rR9cill0jVrHUViKh/s86v5e4ZXdgnBPvj9K838b6v4i1zwxeaXZpYR3U0Xlp dyJlogxCvtPIUlSQGAyDgjBAI1bXxdqUFpBaQ2mmRW1rGsUMX71giqMKgy5JAAHWlyMdzuppPJOW EvPHyIW/kKrQ3trPdPbRu32hLeO4eNomQpHI0ioxyB1MUgx1G3nGRXF3fi7UJQGFxbWrLkgRgNn0 wG3dKzLjXJ57h5p9SwzoAwWbYCq5IBA7DLcf7R9TRyiueoZUYGMlj1B6/wCeKYcg4brjIwfpXlk/ iOUR/vNckhVRnAuyAOMf3ucCoD42gtOG8Qwg52jfMOucY5zj7wocfMFfsesBiApDLx1UY9f8/nTc 7VYnDdzn69a8kk8fWJHlN4ijPAYbJNpGeOo6/wCfesPxP8RvI024TTtXku7naNqGZ9vJ5Y+2O3qB UtpLcai30Pcj5salnR9mcszc49M5qNmAPykjOCAQcZ6dPwr5Vm8Rx3BkeawtpyQ7FxEwkbgFAHLf Kc8EjG0dPQdV4Y+LWtafqyWd0H1HTHmzJ9puA80ALHJWU4JXoArgnjGR3SlFlOnJI+gXBYZVlZdu Tg+n+BpudwYq2P6/rVPRb+11fTLXUrN99tcxLLGcg8Ed8cZHQj1Bq2SnO4DP8qozY1tuGIJwRjIP tUT4IXgEjknPT6/mKlJwrY+bA459P8moX4z8uOo69M+nt0oDqaqtyMoRhjjgcc8dKkjGBnbhivuQ OmBUaE4AC59809skEglehwP88VBZJ1T5NoXPpnHPT/PvTkOWIBGc9D+NJnOCRx+ppEJ34ITByDuH +f1pASrzkAjHTr2pSECsVKgsBnBPX/PNIjbk2DIXPb/9dIGIG3oB/n+lMCRQRjeVwGwFOM89Mmnq w2sqrnaOOgzmo0Lc8A98etPypX5u/HTp/nmgB54YBu3f+f8AOuf1rxZZ6fdmziiN5MhAchwqg85X POWGORj15yMVuzq8sUsXnSIJFK74yFZcggkH19Pwrh/Gnhux0fwJr+pWcs4urHTbm4t2IBClY2Iy MYIBFCt1E7lseN2jUZ0yNnwFXExHHv8AKfU/5NWYfGcPJfT2QscnEuQP0GaoaT4d0fxD4Ys72CXV tNe6gSdZAwEpDoGVsMGTBDAjjtg8hhUc/wAN0MIFp4w8RQzgYDu1s659SoiHtnkd8Y6irx7Cs+5p yeNAM+VpxfHA3T4BPT+6abP40lZBHFp6RzHjc029fx4H8xXJeCfA11e6dNJq/jXVrmSO9vLb/Qoo YSqwTywAlGSQ8mLd9XC4wpY7r/C+wmRZE8WeKFI7rcW5B6f9MCO2c9+fwLq+w7eYj+MNVJWQJbbR yUSMkOPzJ/I03UPFN3f2z2l5pGk3ED48yGa3MsZ6EZVmIIGO49PSnQ/CnTV+aTxT4olZuCXu4hjB 5A2xDH1HP61Yu/hfoVzEsY1HXreXcGM8N8fMI5BHzBlwc88ZyBgijmXYLeZxHw/gTw5Zie48J+GI 9ae4nuZr60t+jyux2xggGNFQqgRCqgKeOST27+M9YVSPKslUg7Cqt8uepHzc/l2qroPwn0bT7lpd U1XXdaVvMVIZr94oowz5VgIyrFgvBJcg84UcAaw+Gfgp2J/s69ZlwMf2xeHbwDjHm9eRx1pprsHz OdvtZ1G6eza5nH+izme38sbTHIyOhYN1+7I4PJzuNWIvEurwQiP7fvXHBZVc4x3JBPUevauZ+LPg vw9pNn4UtNEsruwkvPFdnp87yahcyJJDKGLLgzbipIGSCpyvBHU+l2vgzwxHGbibw/pySYCtvXzF VicYBYcgk4zgZ4GOMA5uqQreZzUXivVkYB72IDktu2YAwPp/hnPFKfF2ptkLqlvEqnJ/1ZBXOM8j p/n6UfjX4Z8HaN4KPiN9His2067tSBaRAPPEbmNZYyvCsCnTJB4wCoLZ6yz8BeB3twr+B/D6SoMM JdOikZsdDuK5bPXJ59QDkA5vILHMXHia/mjill11UVM4McqpnjOTsxx6Z/pVU64I5zMurJFI5+aR Z9pJHJOc89QefWvSbXw74etEVLXQdJtgn3fKso1A9Og+laQtrdkG6GIqvQbBx+lHO+wuVHkk/jFN rGTxKqDbv3NekDafxqo3j7TljWb/AITCFVI4P9o5DHoRndz/AJ717EIIfMJEEPTB+UZP+eawPGHg jQ/E7xXF0J7TUIY/LivrOTy5kTeG2HIKuuQflcMBubGNxoU2NJHnN14t0/UVXzfEK3kR6KZt4ycY /wA96o2Wu6FBEbayvkIhXOxQzOBnBOME8nqT1JPU5r0WT4c+FPs4gvba91eds83d64385BaOPZEN uR8wjz06k85E3hbRNB8b+F9PgRhHc22oiUSCSZWw1mUjQFiIlAUgHB4Byd58wPnaHZHPyazZeR5i JeFQOkVlIT0PQBcnoRx6VSvvFmk2jqLpruD92JMyWUqkrkLnlemSB9SB3FeyQ6ToiKUXTrDeqqSG iVyBztPPJBI4PfFYcvhzz/ibZyajpWkS6G+hX/l2yWqhiRPYpJ5gK4OQ64IPcgrwWkXOybI8p1Dx voFmI1nk1GJyN2yexeMhQcfxAHrn9fSqcnxA8K2+0/aLmTfkkqFJX5iAG5+U8dDg47cjPoHjX4Ka Br0lncabf3WiPFuWUANciRSWO0B3/dkE8bTtxn5TnNU9Z+Aejz6NZWmlaw9re2UXlS3ctosv2oeY 77nClDuy+0MWYhFVeSqsJ55l8sDDg8SRSwXFzFZXrwRMwMzNGiHH3mBZ8MoORuHHGM8HDLjxBeRp I48P3sxRSx2zwlmAPUDfz9BmvW/DHgTwloWn2Wn2ug2FwltgCW7gSaWX5txZ3YZJJJPYDoABgDRu vDfhtp2/4p3RxyQAtlHjH5VXOybI8GtPFl5exGe18L3kiK7I5N1ApDA4ZSC2QwPYjNRWnjPULpLt zoXk/Z5FSRpbxFJJVXUg8/KwZSG6HORXtcHg3wcdSm1CLw5pckjwm1lH2ceS69CTF/q2f+Hdt3Yy ucAirujxmLVvFSRXDBZ9VjZVHQH+zdP3Hp13dc5zge9LnY9Oh47p+oeIr63xp+mafdfLuRUnkYsQ Dwu1COfr2/KvoN3481/S4tXsPC0P2d3kj2uJmIKSNGQSqEcFT0Ne73MSz6fNHdzvAoQieW3kMRRc ckODuTI9DuHYg4asH4b6NBofh240+zaVoYNU1OCMysMyBL+4WN22gDcVAyQBnuOAA+Z9w0tseOy3 vjmLWIdJudJs7K5uATbRzxyhrnaPn8oY+baNpI4IByQBitO7sfGsKf6RYzJkdU0eeXHPPAYevt0r 28MsqiQoyMOSGxuVsEY+vJGR2PoaV3OFkHzMPugjv7dxxn/PFK7A8HGi/FC6lItobII7fI0kEkJ5 53MGB56nGT6Uk/hb4sfawxti4I4FuLXYPXl7hSOg6j9c17y3bOSP8/5/GkDLjGc+maNe40/I+cPH Fl4/0HSfNd9QaeJDLc7dPM0aRKMs/mRB40wMk7m4BJzxzlW1r40uLdJ5vEoVZEBjS0iDmRsZ77Rk 565HUcivqJmKbSp+b+EY6nivF4Phj4ki1C/0wXGn/wDCPRTkWaGVxK0JG4Rl8MWRd2wg7S23kleC uuoJnnujW/iLUrq7QeKy0FtKIzdJDuVm8tC6qCwyoZmG44BwpHBO12paZ4kiuy0uuTtauR+9hiLy r03ExeYPlA3Z2ljgcAdvVtN8F28N3q0J1GKFotRSJIUtCd7fY7ZgF+cAADPA4wCcjBqw/wAO70Qy pNq9tcRONrxDTicIeMf63kDOT6gfQB2THzNHiPhbSrjWNNtJx4o1C+Ztr3K+c6mHcjMNy7ju5wo6 ZGTxjBveHtAW6t5VutU1oXltM8U8SXW1Q+chkLrnaU2kZ4O7tXo/hj4a2ureCvD10NX2Sf2ZC0co tissO6JchXV1YYBI7A9xRa/CbXLXxB9rbxmJrS5GL4f2ckUzFEAjCsvXPzZYFGAAAJ6hWQ1JrqeZ XHhXT7u7ktNM1K/ee1ZVmlmZHjjbOcYCDc/Q4BGBySOA0Wl+BLC6sp5Ptl4ZpZpfJdpVZTHvYRsQ AOCm08EH5uo4r3yL4e6BFZRWkU+oWoj53WskcZz1BAZGA555znnORwauj/D210vT7S0XVbm5kgtY YpPOiRVLIirkKu0qPlBxuJ9zRyxJ55Hja6Hp9m+/UNBknAO43NrczuCcgDMYIcHgYVQ4AP3uMipr ukeHFt7fU7SJGs4rgJeCK7fYEYYJPzEgrlTtGOM5HSvoiHwroIRRJpaSuOrCaVc/k9Y3iz4YeEfE cO2Swm0+UkFrmzkIlIHQFnDAjHYjHftkFl2GpvqeO6p4e8OaejGLSZ7u7kyIrZZ3JcjjPLYC5I3M eBkZ7Zy9K0WOy8efZryytb1JdM8xkW2DQJL5nKqrDk4GAx+Y9T1r27wt8L/Ceg6SlhFZyyTlt89z 58kTzNk43CMgYAJAHYepJJrz6Dotj8R4XNtHFbf2HIH81BIDi5hP8Wd2d20depxyaPdT2ErvqeYa j4a0qV5Lmy0+1F02R5bWyvGccLuRh8qjqdu04PfgVneH4tPhsVuptDilT7RcEXEFiCT++kABjGZF YYGB8wVcc9QPoK40DQWaS5/sWyuZcAgPbJxtyQAMfL1P51keENK0S4sL4f2VpzNHql/GCLaPp9ql IHToAQBT8iTnfgrrlpOdT8PxXUMscTfbrMRyq/7mQneuFHGyQk4JziVfoPSZGBVgAAwboO/T8xWb B4f0W31qPV7fTLa3vY42jEsC+WWQ4+VwuN4+UEbgcdsc503YblIbk5JA9Mk/5+lUgbI5mUA7gR2w Tk/54/ComZdpY5B4IOP8+v8AnFLLwoR9nynjPJLY6/59KZHgkeYccEFiMkccj27HHHWmiTVwBg5H 4DipVUnI5PP51GmAuXOOmAw5pRjkkbSPlyPcf/W/SsTQmztAXjLcHHegKeFBHfJHX1pvzKMBevB9 +n+fxFS5UE4Yk59cGgBygjCkckDr0PTgUR5Zz0HzEDH/ANamY+Y5HytwQKWPJYop3hQc8/5z2/Wg CSNsYzjjg09WHzDOU64P5cYqJHLIuF4B6E88/wAqc0gU44PGelMCU42lHJwDkY/Tr/OszxdZJqHh HWLKVNyXNjNGwzgsGjKnB+hrRQ7uSCpI45z+v1qKdfOt2iyP3ileB0z/APrFNLUTMj4bpGPh94fh Rgvl6VahQhywBhTk59Tn64roFMgVgqKzjOPmwp/w/mK5/wACmT/hCfDe+VtzaTa7ht5OYUIPt3/O tyQEkK0QZN4Jy+CuOQR68gfnUx2B7nHfCKKEaX4hsowkUFn4l1GG2SJAghTzS2xAOABuOMcY7Yrt SoJ+XarkfN8vDcYzg9RwPeuG+EKC3/4S+N2LE+KL5mJH97Y39cV3UwHTbgjrj/63fiiKdhy3HNIF bDZGD944wfb6809TgEHAxnjnNV0k42StvB4DY4z7+n8vzpWZokZ1kAUDJDnAUZyeeT0J46fSqETA qULOVAA5OeBinREn5jHsJBCc4IB6n2J/MfXpVtpWusyyIyRjBSJxhvZmHbkcD8TzwtrdyPm5OfpQ I5/x1po1DT7NXEUoj1jTnRZId+HN7Eo6EZHz4I9Cea30jSSMsSDkkFonzgg8gE9ACMEY7cg81neJ 5ja6Mtw6ZRNS06RmPYC/tzxnNaXmFpCrPkjBHy4AB6DPfof0pdQ6HAftAWr3nwe1y0EsO5Ehd1JO 4hZ43yDnIBCN689+Oe/lV1kxiQqSV4x8vfP549e3vnnfiTatqHw71+BUil3WMzoAOvlqWw3PBBU+ mK6e9AhuXhdSxDMjOQAM7sY/H6f0ph0I4S+z94vI6lTw3uPT6dvfgl3IJyB6D3pFIXEYVtijqST7 dev5/wCNJCXAKPyRnDAckf0P/wCv2AIUHIwwI/8ArU9RkFzghe3f6VEW/ebc9CCeeg/zmnOWbnaO OlAwUL5pkVACwHzdeOw/n+Zrz7x68w+MPw3ijuDB5n9qruVhkD7KOxGDzg4OeQODXoAZVAbac/3e hye31/wrgfHKM3xk+G8o3YjGqhu+SbZcD26GhlR3O7lRbjy5Y1KODujd4yrAEdGU884GVOPzGayF vIo/HFnbyxLbTy6Nfb4ywJZxcWOG/wBoFEOD6DBwQQNcSeWJHYTuI2JJKfMeM/KAPmxnAxk8YOTk 15/47luIPjD8N7a2mkVZI9UiZ3y+VWCNhuJ6nKDnqeeQaTJR6FKrMmEkZWU5U9efcdx+XfoeRjaf dfbvCOnXc2oxabuWylkmnKhSDJGdmWIH7zlB3JbgZ4rYhl3qQ42SIcOmenXBHqDjrj8jkDxb4n/F SLwRZjwZpdleT6rZ6ZGl1dQssaWu9YwiYkidZQytlhgDDKA245Rhc9lt7qF9ROl/bLWfUUj814Ip U8wJuILeUGLhRwCxGMnGc8BbZLZtNSK3vluYggRZoZM+Yu0YYMp7gggjsePWvj0+JV1n4u3njvRN Ht9I3nzYLKTEwinMHl+fnywrOsn7/BUZbHOTur6M+GHj6w8RytoBS4TU7O3EzzNCqRXce7aZU2Eh SSVLIfumTALgbi7Owro7xUVEWNVVEVQqhRgDHYf57Vk2crm51pIJGgJ1tfObaG3A2FkowMHnOPTG MnI4bQnlYZSLBk25yRkKPU4/l1P5kcx4bvZJ/HnjSyWcoYpbSVfk+4XtVXOOh/1Y/lU9UUjqTGRC UgQDdycsVIBIycjnd159Tms7wuETQg0kuWbUdRBO4Ak/b7kAnHrj88Vd328skX3mypljwjYx0JJx j+IDB556cHHO/D2/j1LTdYt2UFLXXNRtyG5GDcO56+vmVVtQ6HTSb9rrG2xyAV46Y9R6c/z+tNyS mWjwzcEZ4B7/AOP+FNlcQxjIYqowzkkkc8E98dBn8T60kwVxjBHcEDlTzyPzP69jQK47cS4Hy/lS HAHmA49TyQPqfwqG5nSGSOF/nnmO2MDgMwxuPsBnP06ZPFTs5B+6QAMEYweaBXGOQflAAUDAJ6n3 o+facdh2/QD8aRWO4AbhkDJ+n+FIHPzqOELA9c0Acn4enkPjPxhHI7J5E9s5aNS7BWt48rjBPPlg ccnHbjHTyNudWWYJ32cfOB1/DJH5e9cZ4Rf/AIup46TIO0adjPp5B/wrr2EgOZYxuRR+9TgMSfmA GcjkA4Pt6HAkVI5H4OSI3w70TyuZ4LUWs6buhjOMY6BgMn/gWD2I7CUK4CFcqeeB78fSsbwZEtvo 91bIiosOq6jEqqcjAvZ8denH9fStZlzJuB2bTjkcMPT9f885FtcHo2Nlfa67iQrHgnv0GP8AI/8A roC+N5zkAHr/AJ44pjyKZJEkCE4wQR1Hr9CM/kabJvLMVKglcLlScN788j/PfIZLY24ldR5VttMh wMsPljz1Zu+OuBnn25IWNAiiPeznH3jySc5/z+nGAE+VAVBQMT8yk9+mf5flQ6sUdlOzAxlhuHbr iiwrjlYCVQMnIyfXH+f89axLmNj40s2dU2nS7tVUckjzrXOT+I6e/wBK0zHG8JVXZhuy2D98jg7j 3HGMD0x0GKpXHHizT27jTr3kD/prZ96mXQpF1syKpdkiZtuSvQnIJA9Rwa5L4bS+ZF4j2nPleIL1 Dgk4+fPf6/54rpwVDiIQ7MMzqwPUnqfrlj+tcf8AC/zI5fFqyooP/CTXjIcY4YRsP51a3/ryDodk SgB389Me3H/6qZKuQBjjHTjjFOZjuAJPrwcc/wCc1Gx+XjgkfMRyAKdibkUgSVdjD5e3cEdD17Z/ lTGfEQJUDJyORwKex2jhi2eQw6nv/n+tRSN0zwRyDj/61OwrmzGUUcKFGc5wf8/59KemBJkFihwO v15NQKemcjHXrjvTt2eenvnkViaXLAxvIzzjBwen+cihRz8vzNznB4NV0bI4zgn6U7PB6YJAB6j1 /A//AFqLBcnL45OeRxz29OKV/u7RjBGTg9vT+VQM8hXceVA2nqc+o57Dg07dgrkH3GOtVYVywSCy glSMAcc+/J/z/KnKAVGWJOeM5P51BvJGe39KEKnGf4SAAMZppBcndvlJVeR65/Lip7Zz9oiLEbS4 OPx/yKqln6oC38XBAqa2LG5jwwzu5z37d+3XmhLUVzJ8Hkv4H8P4jlQf2TaOApwx/cocZz0PGa1y Q1w0nlybkT+H7pyeRjPXK9xxn3NY3gt/M8HaKw+7/ZtuM/7sSj39K1LRlSMhE8vazDYWztA4H0yA Dj3qYaxTHLcxPA1qbO88Vrx+812SVex+a2t24/OukUsi7CSy4ODxn6H/AD/9fJ0FWj1HXyNozqil QR2+xWn4d61pZR5bMQQi9fU+3HXt+dCBsdGpcbdgYk4KgZHT09MVG6qEUuW2R4IHQexPqB/9c8jN ChYQQCgRjnGfud8D2+nTnt0eXI5DYxzVbiuSDkFW3KBzwT1/yTSr8pJch/L+8QOeB6A9fp6jiqju QAkeNoGGP9we3B56cen4A2IioVdpbGBgg5/Xv9aLBc5z4r3Bh+H+oT7hhJrQ5PQEXcJ6/UV05JEq D94eSAo5X6n8sfjXFfG9U/4VbrDMm7/j3znkHFxEfX2rrrqTNs8b20swYbTHE4UuCcEAkjjnkE8g kc1n9t/L9Rt+6UPF5aPwF4jG2EudGvQyJypYwSZwcDqTW3clZ5pHLB1kLHkcHJ/lWF48O3wP4hIO M6VdZB/64t/h61b8NXf23w/pd7nd9ptIpQQck7kB4NP7VhdC7Iq7MMCQpHzE8j0Of6//AF6RpX5U Lsk6YbovOM+4Pb16cc4HY8KqrvPXPbtk/wCefzxEwFqjSxxb5G5lLZLsPUY6kdh6cLjirFclgR0Z o8l1OWDdT05B/wA9OOwySSALgg8nC7TyTj+f+Gaa8yLGJFJZXYYCOPn57ev54xntTIo5VuXmmk8w ucjOMRdPlXgcHGSTzk+mAqGWAxChGyWA65J7/wAqwfEunmbxL4TvtgJttQnjYk9N9jcn/wBkreJP 8OOnOf8APtVLUQst3oSltoXVGOBznGn33H60mOOhZllVJY0Ny0bSnEY2fKcckAkdSO2egJA+Umua 8XaYtx438E6vhd1rfXUHIyf3lnMT/wCihXTO1yuHjBeInlV4Y5x68bRySOvAxnoc/W0LX3h+Egs3 9rSPknByNPvQSPzPSlJXBGhcwLcQPEzyIHRk3I7I654OGUgj6ggjggggEfMXxo8B+JLTxTqI0/TN c1jTruCFYWKSXVw1yqRb/mcb23KjPuXKfwjlGVfpm5lZIy0S736KMcA+p9ucn6cc8VV1K0ae6gKg MYpmmL4OASGGAPQ5yc9fc8irIV+h8Mf2Rrulm6uLiy1HS5LEot4kkckUkCyY2lgcFc/LjPXI616x +zRo2qah46tPEM0LnT7G3nEc8+ZN7vlCImyPuk4ZuQMgH5nXPeeItR07RPG2uLqFzZWCTWlsYo51 FvJNh7p5Sqs2ZBvYnIC53j5WyHOZ4X+Kmj3uqX1jbrI9qRi3uIdQit7mRyEChVmMe377rkMTleRh i1StWOx7suASAoAXlhnn615/4Ncn4x/EMDPyrpXJbPBgfOB2rsrW6E13cWjSKLi1YLMEjZMZyA4D gEoxVgCMjKMAzbSa4fwMHHxj+JDclWOlheemLZv/AK3eqfQcdmeghpBlWkjYLxkRkHd1yfwK9PQ1 wnwYMnkeNFYEbPF2obfcEq39a7aPaJWLI6GTOVODnHy7sj1G3AyOB9awPBliun6l4qiXgy62Zj7+ Za2z/wAmovZ2EtmdI7c5OA2cfnUF3PJHbxtb20lzlwhSNgDtLAbiWOAq5ye+AcAnCmbcoJkYhRnA wRyT04PU8U1myGCgorLxxnj8faqsSQ29sg/ezos0z8ySEYDY5AAzwB2A6deSSaZdXiw3EcP2dy9w dsQTJG4DJ3HB2jAHPTJA6lQ0kzyYVwSW/uE8EfXtjP8AT0w2IbCTkeYTgsOuB0x6AZ//AF80WAI0 aNNskpaQ8swXGTz0A6Adv8ku3rjPTjjr3FR4dZWO9iGO4ZHIPpn0P6fyVwoIYDjrjg/560WEcT4Q DL8V/HhZeHGm4yeeYG/TiuvtBGDMYSHhMrbRvUgH+IKB33bs5yc57YA5/QYBF498TSRoy/abaxZj j72BMuP/AB0e3StyZ7pUMsUQN0Yuhk/d7wOFJPOMk846DntUw2+/8y5PX7vyKHhHzDpU8lwoimbU 9QaSNWyEY3kxIzxkZyK1QF2njHX5TwDz16Vk+GGzo7bRnOoagSSMc/bZ6vXDSFSkX7tj1f8AuD1A 7nHTP1OehcF7qE9xWlElz5Klt4xk/dAB7Anucj6dT2y0yYUgqMDng5BHrj+lIipFbhEACIckE847 kk9SfzzUNw6OGjZAMk8g8qegOB39Pz7YqrEi+btujEASMfM4bhehHXkk56egyeoDOM3mKGBZkIPU keoP0+nbFQoViQxhl3c7Sc89OT3zk8/UetCEqnyvufqWY9T74/DtxxRYVyZNsaBEQKF/hVR8oAwA Pasm+lK+K9LTAO6wvVA5znzLU8flWgrtgMv7s4xyeR7H9K57XJjH400DOE3216u85/6YnpSkhxep vecxuACzeW8YYMOVAHXPYfeH1x7VzvhO0WC88RLswJNYZ2XPB3W9ucZ9M/StzzRGu+R/IXzCWDd2 +6OvTJweKoaUFF7rYwpDaguR7fY7bPt6jFJr3kNbM1ASWIPAHPPb2/z6VEWJUHORnjuRTcnnnGRj nt/+vn8PSkJGVXhdxHB5HX17CtCRrsM7WwdwGR/n6VEwJdigySMk4HPTNKWKthWbDAd+Bj6c/wD6 qRsKuQNuVzkdOOfSgDTEjbQw2gnP09MDmpCSrnO7I/Nag3KVwAMDHIxgCnK5KcgZXgE9PTp+H86z LJUwxLe/JBz9AaXOF59cgnt60za3C/MDyBkc0hTJLD2xnnsaegiaNgWzjJYkk8cj/HFKZFztUY4+ Y9cdKjUfJtGB7gYxTxwvJHy8jJ4I69+DQCJk3ZLYG09cjj8B6fSnIVYAbsHoQB2pkZJlZZACwwCQ eT9aCR/EApA7np6/0oAlT5sMQcdifrU0bFJl9c46HFVzlRkgEnjOOB/9enhwWjf5uORQBh/DSVpv AekSJ87LaqoBYcleOvPpXQIGR1UBgm35VxkDHHJPPp19K4/4STyT/DvQ/PjjkkZZNytgNhZWAO32 O38+tdcGbKsd3D9FI5zxg/nn6frlS+BehU/iZV0qRP7R17Lcf2lGScdP9BtBj+mK0I18yTfLncRh I/7vufU8/h09Sef8OyiTxZ4kgCHMV1A49t1rEOvrla6JHwvB55HWqg7q/r+YpaC7lUAqwCnBPHPt SMTuxHkAjkZ+6fb39vx+rc5GEBDevXaPoaXbtQNsLEkDG3kZ7/nVkkkJHlKqDI3YB5JPr/n86XLB /MTaR1IHGRn+f+feoyF3O0RI34JU4+btn0H9R+j87ZCyYBGd2T92gZxPx7fZ8ItZcKW4tzjOOftM XH+c/Su4mKmZV2MRkkMDhfTHXnqfy+lcX8bIln+F+tLhsbI3AH+zKh5/L+X0rsGCCeU/vVZjsIZu McnOM47kE+3tUr438v1G/hX9djF+IWIvh14jAztTSroYaUnIELgc9s8f/rp/w5JXwD4bRiNw0u23 LnniFM/XqBUPjWP7f4S1/TIdga50+4Rz6ExlcHHGSCuB279gZPALbvAfh1t4ZTpNrhh0/wBSvT/P f3ot71wt7p0TsMkgEE8kgfl2+n5UiNu7ZGPTjHvVWaaVMqCWY5G38ev0Gev06nipPMzg5BwOnp9f erIB1AffFEmwtkr0O4nJx2ySM/X1zkPSQMokA4I4BBGPrnpzTGKsSGVGBUgqRkc/p/8ArqFpnj81 AIzKwLRqWK7jx7HnJwTyOh9grDLK/I7gNwxzyc9v5f8A6/rV1F9upaCfMwBqEuSO/wDxL7wY/M0+ KQyR8xsoHLbuoPp6Z/yKztckMWq+H2HPm6iytt6f8edyM47env8AgKUloVE1nCPJKwgKtwrSKdrO vUYZTkAEnHIwc49azNZvBBqugS3KyQD7bKCpYZUmxuhg4479c475xVyG4UxNLvlZd2WDqVcZPCkE AjrgDHTFcd8Q7uKwvPCE08aQ+Z4hiiRi2/PmRTAjkYXJbp37HgADQk7MteNPHug+E4NNu9csdYFp qkmwXaWzMtsg2czKSGTIJbaFLEIQVyuKZqnxc8CWdjc3kXiCy1CV4TLFawTDfK3VUzg7C3TLdM89 K3tY02w1uyfT9VsLW9tZMhorhAwzj7wz0IycMOQcEEGvHfi78MfB3hnwFrOv6H4XtDPaLGrNcapd YgEkgj8xAHIdwXHDHbjJOdpVm0I8h+KXilPFfjG5u4YmaxhUWtjHLK7yiBMiMl2+YuSS2X3NliCc deUZTbTq6ASqcFJGXDDHTPPykYzjnp6EGpZLqz+0QutikMShfNWKRy7kE5bLlsM35DH3etU2l2ll kBdgwPytgYx05HB5P05qbMo+o/gtrujWlx4a0vSPPt7XXtKl+0W32oNE+oWuzzMRKzmJ2j82RnfA dfJ5DK4Pd6PFb2/jnxBfKG8u70+xnkIXdyrXMZ4AyTiMDueMdeK+Yvgh4O/4Tvx5Y6fdzFdLiAln KSeWxAOFRcA4Ys2TjacByD9019K2Vzcv4luo5rO10zUo9Oh8nfcIxnVby9AdVVt2xwVLZ5VmGQ2F NEldr1/RjT0Z1Bbyoole4yu4K7SNkvzgc8DcTjnH4dMU9Nk3a54g2k7jfwL16AWFmP5547/niSSa UbIoz5Ny0eeULrHkY+bBGRnIxkFsHpyRS8OyRu+sSQSiUHUl+ctncPsVqQc9xzn9BVNbCWzNd23F fmGQCAW69c0qgkh8EJ9R/KqplCzLEmGJGWXso9T+uPX8yHtIcDAG3pyen+eKqxJJI6PkLtBxj+f/ ANekyA5cFix4YKOo96jJJXPzcHIG7OD3P5U0cDLFh169M0rAOjmBZlGdyn5gRj6H6f8A6uuaYVWL eAwQHJ2/3TjPA9//AK/rSByrswVSRlcEev8AkUyN5CroyjKkfcPDD1Hp/Tnr1JYRno8DeJL9/MK7 9Mswzqdp3efeKMZzzxj61cnM7BfIjVpBIuATjjPzen8O7H9elUIlb/hKNUaIIXOnWBky3Yy3oXGO 52N9MfSrM8Mr26N5j26vnzFPDhTkbVYfdOccj0OOoNKCsrev5lN3ZkeCbgzWGoIc7INWvoy23BP+ kynb37kc/wBem/vZmLfMcd+4rjfhmpt4vEEHltGE166KxtwVVyrqMduHHTiurm3OQudoHU98Dt7f Xr/RrZBLdiiTMuAoYAHn+8c8qPy/z2juZ0jQh1dyxACBc7ie3/1+OPSlcrGFUAAIMBVGQAOwA/lT EeUqxZVTJB27QxwOOvr9OP50yRFjXDuDvLn5i+Pfj02/575LJCY2UMCVxknupz1+nv2/kp4LAYAU 4XPGeOtMR3fJcLuBGNv4c/SmASnhVOQynsT159f8/iK5TxLN5fxD8K/eJaK+xgE5xGh49SPT3rpy 20qCo28kgnBHuP0rjfF80o+I/ghUQgNJe7nBzgrBnGO+QD9MUmVHRnYDcqCBJQ0gQqN43fMOhPrz WVo07vrviGF2bal3DhTjHNrACc++39K1eeVOdoPGT1+vvn+lcn4YvFbx94u0xbdojZtZsQ2NvzQA Db+Cg8+tD3BI6jJ/izjkHAJ/z/n1pNz5K7iFY56e3HHp/hSojICxbOTw3A/z/wDW7Ux/vKUX0OQe nuPXpVJiY6QFxgFOB0XuP5f/AFqgkYsoPJC44Kjr19PalY4TGVxnHr26fypr7QMBQSO3XH0pIRsI uc5G4kY57DPt/nrTn3bcIo+UdvXj+eKesRK5K4Hcj1pyoFxyBkYOMcj0rDmNuUj2nBPzYB5GeTTl H+zwf0p4iOB1Y7sD1/zzUioXckg5Ykk5AGKFIXKRAEcFACDznqP88U8biR8mFUZwMcf56U5ISc7Q RgZAHOcD/wCt3p4Qhec9OMU+YOUYo37WVflHt689DT+VBOOSepPSlAwMkHGMYHOP8P8A69Crjdg5 7nOKaYcoEfNlSfYU5SAq4XGRxTiANql8E8E/3vQfpWXrWuWekbFuGdpJBujiQZYgHAY+g7fnjOKL 3YmjmfgVfRXnwu0eQS28+BKpZEAdWMrllPpgbePx9K7rYWhMbggleQDgDp7/AEryH4Ralc+GPA9h pd1pkrTRb1fdMBgF2IGFBHcEnJPIGcKoHbJ4zhbCrpbHjgGcY6f7v+c0RjZJA3d3K/gu7M3xI8bw fIDBNYk4AIBa2HHv0xXY58zKIfl9Qe/oP8fr3zjzbSrtbHxb4g12JJEGsyWrNCrAeUIYihAYg/e+ XJxnAbnJDLuXHjNtm2KwEeAQCzlgAO2MDk0KLigbudoW56DB5HtSRjbvRiRk+oxn/P8AOuBvPF+q lEaNLSI4yQIyxPTrub0znj0693p4y1NMAQWrEDqyNk/XBqkLQ7wMobOMDHOPTrx+dPOC28DGTz9K 4T/hL9SMS+Xa2nTBJVz6f7Wef8+7ZfGGp+XuFvbKScKdpyPfkkf/AKqLAanxZkC/DXxAxXzPLsnJ UnHAGffGOua6a8jZppI4xNC28tukHzJk5wQe/t2/AV5J4u1fXtc0LUbBJ7WP7ZayW2WgVvlcAN1G dp/mARyOLia3rtvIwW/uMFyxaY+YxJzyS2eSeec+9FhPc9QtYGZkt40YsZAnlb+GLHBJJ6jncT1+ p4OD4Fkx4A8ObE/fS6RaOqMfmY+QhOT6DIycd/XArkL/AF/VL2MwXcsM0X90wxjtg8he4JB9QSDw SKZousXukWsNvZyLFFFbRW8S+UshWKNdqICwJIC9OepJ6sSQD1CEbFO4kuw5YHr9B6c9P65JRVBb ABDcDKj6/wD1/wA68zvfEmuXKNEb0pIuDlBs5xg/d/D6VWbVL4t+9v7mVyCFZ5WZvpyfTPHP+AFj 1PJXl8DH8WO2P07/AONLMjuCMhZAOGZeFPPbj19q83tfEGqWuJotROSScyMJR1/2s+v+cU8eKdaG RHeptzyBFHgH2447e1A0j0dWEgLPg9c4PQ4HUcHHPfFcR8TdTlsR4alFxNasniGGK5kWEylQ1tcE 7FCkyZGcBQSTkdQRWVdeJdTnBMupbQSRlCqMTnjp09MfWsLWUbUryKe+vZZprZgV3SklRtIAPXgh u/cA9QKBpHq0V3HkT389nbu7ERR+eoITPAY5wzdTxwuSoJ5ZuA+LNzDdt4Tns3s55IfFVjJdPDJv eKBTJhzhQRGAxJLfdLkd6wJJ9HtEie5uoLcOCF8yVULYxnGR2yP0zTlv9MEcXl39s8crCIMJUPzH 7q8Hkk/XpRcSR6nc67pENyn2rX9MgAGET7bGoJ755/IfU+mON+Mz6d4k8A69Bpd74cvrr7HELQw3 8ZuuJklmjx0AKRKVUHLMOnC5pnSdSkQzppWoT4BYCK1dt3HAGBknp0rP0HTNY1fTI9Qbw5q0S3LN JGj6bJG7R7jsJUZ52hfmB5GD34L6ahZHzomj63ICV0jUDtIVgYGO4gE85Ge3+eacnhzxBMCYtGvA oHP+jkHr1yeeo/zmvpCbS7uBQzaNq3GANunTSbeOcBVP+TVSeUQQlp9K12FQPlL6TcKuR7lAB165 /OlcFExP2aLX/hFTqmoa2iadftNbNp8syySBSnmM29Y+SpJTI6kA4x1rvtV13TtX8S3m+EQRz6ba xi6G9ZbeZbq9JliPl4KshGScFgUR0KtKI+W0TULPV5lt9OmeZ0Yoy7GBU8Aq5bHPbOfr0rctvC+p T6q8NvpplnWCF53Xb8schmMW9ieMmKbAJ4PUAsuWmmPlaNXQfFVxKtxpV3PHHNbshTV4oz5N62Pm Z4iA8e4BQQuRndtICrmXwZrl1PqWu3N/5doL/UBPbrczKojRbeGNix3YzujxgYLE5AC5K05PCniF OlhlgBwLuI7sY4+9XO6VfTaxqWraZpGnXd9eaRN5GoRQyRp5MgLLtJkZQ3KNypI+X3GXcLHrCajp 4BH9pWznqT5qlifXr9KJdSsEVib2D5ByokB9+gOa87ttH8TSOYH8M38bISRI9xbMBxnJxLnHA5xn +kVzpfieKGST/hF71kiG4lbiBmcYydqiQk4/M0nKwuU7a68WaPCkYiknuS3UJGQR253Y9O1RL4u0 0ozGC8wowAqKRx/wL39MV5JqPia40rTG1HUfCniXT7Tobm7sDFGW/u5Yg59Pp0p+k+JbjWYhc6J4 f1m+gZyglis2eMOMEqZFyqkAg9c8jsRS5kVyM9W/4THTVdf9GvSdu7BEZ/8AZ8496ik8Y6WEbdDd D5TnhOnfo/078Vx8mjeN3hee38J4GcIHvoFJHUZUvkfj0qLTtP8AGVw1xbXPhOe3uItvPnxsm05w Q+8K3AOQMkZXON1HOhcpu6Z4k06HxPfX10L+5k/sqztoJ/I2hws10zE4YJu+ePPu2QFB21LceL5p VkEdtJH8rGP95vBf+FmXaM9CCN3IPXOK5awt9Q1DVxpvl21ndLaxXUX2l1/epJI8eVAOSN8YG4ZV t6YPzLu2V8G+Kt77b3RAu05Qo5KnBOCfxFPmDlDwbqK6FLrcksUlx/aepS6jkYBhLqoEYAA3YC5B 464wep6H/hKNP3bjBcDdwTsAwMfWuS0vw74km17UdMudS0eOayn8vyQsiO6+RDMWGc5AFxGpx0JG cbhUmp+GPFsOy408adfwxsEkt4ZNsrtnDEM4CEDOccY2kZJ4oUlYfLdm7deLI1m3RWxljEeMM4Un 36H0xjtg9e1ebxXO0sa29kinJLeYS+SODjGPX9apXXgrX1mDxanab1Py4LdfXIj4xz+FU4fBXion 9/qVrCzf88pN65yMnmIe/wCeaGxWRpyeKb8R7ntbVm3cZT7uexwfapk8VyRoqyWAd1GGZZSAexyM Ht/nmoLbwJfMSLnxFNj/AGYA2P5c8VNJ4EJj8tPEFxGSu3ctouR7jLkZH0Io5hco+TxS5YfZ9PbL f3335+nyj+prl9Wvbu58QaZrJSzi/s5pZmURkhy0Tx5Y7hjAbqMZ2gHIVcaNl8ONYfzrfUfECMqv +4mi81WkBJJDoHUKQMAYZs89DyaOs/DaK3uNGtL7xDeXNtfXzWcyIZkG029xIB/rWzlowOw+YHtU 85XKc1e/EnUJpBJDqUsVvK7CNUtEZW+YqeSpOMqRz79apeC/iJbad4h1HUri2kvhqKwrdXDMFlKx Dy1YKWwwCbs5CEkDrzXoo+DPgeKMvMmofKAd/wBrwFx/FyCOhI/PNcz4U+F2hT+MtesZLnXUtLe3 tXto5ZYixE3m7iyvEQM+UCo6gHB5yqwpPuaWj2PS9F1Gw1nThfafMssBJBI4KEHDKR1BypGO4HHH NTzxkgZwR6dq43Tfhrqej+Il1jSfFrQ7Ayss2nh2mjP8EhV0Vh0wQgIwD2rujETwFyBkFiMAHuf1 rRSRm4lOTbyUOcqGx3J6VE/LAgAHGV46j1FWZ4ihwCckAhVHQjvnj86YIm+U42nptHT/AD0quYnl OjSI9mbpycY6+tSmINkcgY4z257VIiZBGc88EdOPpUhiVeeMAkY64/rj8K4eY6rFfygpzg1IIjyo O4E8D1PSp9pyQd2CTnPfpQYwzHgkcHIGOlHOKyIGVSPuAE8Ej+lI8RVGaQYx3Izzx+fP0q0F53Yb n27/AFpzKdxGQOpOaakFioyc5AIB6j1xxTkQZOM5P8qsiP5zhGHAPI4H+cVIIgFGQCMcmnzi5Sgi YkJOOMk8dRWBe+ELa+uXu7jULzzZGLuUEY28YC8oTgds5xgV1bwFhtdSAPQ09IW7A+v+TT9pYXLc 8s8DeHYdc0H7TqGsTm9jvLm2uI7QRiNGiuJIxhWQsMqgbk/xZ47bw8BWA5XV9XwT03wnvx/yyre8 K2+3RrgKpRf7U1XaNvKkajc5JYkjnI4rYVWIVWxnrlRx6etN1bt2FyWR5QnhuK58Va7oMGv3yfZb Wz8mQRxv5U8xnIEuEHGIk2jIzuI3ZZcQ2Pw48Z3E9xFqHiLTII43/czpaGZpVz3TKeWcdRubk45x mvR9OjDeOdWDSCUS6Np5AK4BUXF+R+jAf5xW28XljLglRyeen1pOrrowUTzCL4a6ly8vjG4mzn5Z LBSM/wDAWB6+uavR/D2VMO+uyN/u22B+HzZr0Rom2gAsMdOe5pQuHBJwM4zjin7VhyHAr4Ahzj+1 bs7uvyAZxj3NU1+G1wdXSVvEVzLp3R7d4FWQEA42upAxyPvKT155GPS1jJ+6ODjouKEjMgbacqOC R3Pp/if8hOoHKeU+N/A1lYeC9a1O21TVo30/Tbm5iLXAKl44WZQRt+7lRn8uvI0NF+HugXdrBfm+ 1aZJ1E8JF6djxtyhGFUjgjjnGSOQcnp/iTGI/hv4mIQbRot2MYHTyXyPypPhtbNN8O/DW9JDnSrV gxI4zChJHsM4GR2x0odUfKZ9t4E8L27Ca4tL+eNTvZRdSs5A5wADyT/nNc34U8A6frfgXw1fNeal Z30ul2Vy1zbXbN5xe3jZ9yybl3Els/KcYUg8so9bSCVWiUl924DKIfr+A4x+OO9c38IrQf8ACrfC ewvg6PakZyf+WSHqe3+eKTq3DlKZ8FeGi4/4lhIB5JuJSex6lqhk8BeFH2h9L7jBFzLyR6ndXbiz kDElcgfdz1/H/H/9Zb9kbcAVJH6U1V8xchwLfDbwc0bBtIJGd2DdzdR/wPjpUL/CzwNNEYW0JSjq QR9pmHUYJ4frz1655r0ZrJ8dD7Z5oFkQpd1YDvxR7awch5OvwZ+HlvJNLPpdzKpkLoHvpgIwcfu1 CMMgHpu3Mc8k8VwfxT+E/hnSZfDs9hpl0I9S8SWNi9vbzOzRW7h1dVLuVDMdvzcAFVAI5LfS66U7 v5jqc4OxfQf4/wAunrnK8Y6N5+iReZldmraU6kdM/wBo2wx9OTSVVXHynL+BvBGjeDrKe30m3CG6 kV5pACNzKgQqpcs+zhmCsz4MjYODWZ8XNI/tGz8OMt59nlsfEmm3AAUM8o+0LDgZ4G3zgxJDdAMc 16Ra6bN8okEi7F2x7s72XP3mPfOBx+JGcAUfGmnSJ4cZTGFRtU0jYw+8c6ra5GPpjp1OeKPbIHBm HrSeIm8P3NrpZsoddKhYJJS3k4LBTMAOQQpLbfmw2B845bo5vnuXlckEryx65Ix1/wA9K1ZNFEqD K8ghlZeCp9QfxP4Gq09pLHABKuJfOjXA+66mRVyPz5HUfkTHt0HIzLaHLAgEY5bkc9azfEdh9p0p 4ii4IxjHX/Jrsv7LYE4GOMA4pl7pDm2ZFj3NjIH9TTddDUGfL8OiS6N4ymvLePy1l27iBkZ/vH6e ldf4WkuB8bJo0nu1hm8JospDblaT7U5VnXkZALbSRheQOoFdjqHg9jqBkI3SNyTtwM9sDPA/xrnd I0q7svj+kTCVI5PCe4Mij5jHeDIGQc8MM45545qYYmNy3SbR6B9mf7Pucx78BdxGOeOcd/8A6+M9 68g+CmgfZ/iB45u50vEnN/54llRojLm6vkJ6BZEKqucAruHHzINvvi6T5UcjSy5Zhl5Gbbj6eijt zxyc55rmfDumG2+JHiOzcpI1rpmmKZVTb5jSNdzEkdB80h4HH8q0+sIz9mWWgbJ242nkY56UCEtw +VGRxt6f4Vt3GkGRAgLKc7lYdVPqP889DwatQ6bt8tHYB2XGQuMnHP8AXj0+lS8QrAqZzv2dwc7R xxx+f9afJDJIq+YXPbBOePSuqTRweAO3XFObRsLnA9Kj6yi/ZnIPbEqcAjJyfes6WB7pQMf6Pxxn iXn6fd9v4vp17i80XcoVvmU/fXHX2P8An+uajaURnIOT3POKaxCF7M8XmtZW/aMX5I5YX8IPG4kJ 6faznsc9QCPQ+2K7mzHnTCW2geK2LFCzAb5WHyiTvlMAYbqflOAvJsX/AIetn+IWk3xSRmfR79SI wf3qxT2bAYHJG6Q8fxdOQeeml0a4ktGjaG3mdhtcNkRnPDcHJI64HfgEjqF9YHydjgfDdnFFqviK NrDZJHrYnZsl1SVtPsgwDHnJ3P0A4OMDIzrCNlJRo1VF+5g9R6Y7Ef8A6u4Fvw9YSnXPFEQk3iLV 49wbjbnT7LB469OnoeMVrfYWjYlQBjPTjpTVdC5DlpItzYGRkjsePahbcna3boQD79f1/nXRwaU5 LiUhk6qCOQPQ+v19PfrKmjtuAUc4xmqeJQlTObS0Yg89+3bP60GEKCZCAirlienTv+Fdemj4UbuA OvbpUltoSzyBpUxEpzGhHUjncfx6D8Tz93J4pIpUzj7ezeZTIVwpHyKRg/U8ZH09/wAsPxpZf6d4 XRtwaTXAEIcgB/slztBwQSM4yM/WvXv7ISKNnIx+FeffF63NlN4JmZTH5viq1hYdcB45kGf++h68 9PeFibySLVK424sQ8i7hvjB3J3BPUMfXHb3APpjLs7V/+Ex1VmlV2/srT8AYGFM9/t9c+mfr68ek HS9qEmHARTtVRnIH/wBauctLBU+KOp6ciFE/sCwkQAALxcXgwMdMZH50vrIuQzJYGAUbcZAzjj/J qvJbkEHHA9/Su4uNGVRwgx7Cs+TSSOSCcn+tWsSgcDjHsyG2iPLE4OQe3+TUQsyCSFwW6Z64zXZS aMS3CfTuKiGiMuQQcHqKr60ifZj7fTXwSBt6nj19anGlu2Btzg8cmu5XTUX+HtT105Mfdri+sNmv IcQNMf8Au56HkU46ZIWyVA+gxXcf2ev90E09bFBxjjGKPrDHyI+Vf2kvF/iPwzqlloGhXC2DTWgu ri5bAbaXZQqk/wDXNs45+YciuS+F/wAU/EUHi7StKvr2TVrTUruG1k8/79uXYLvDdSMsTjp1xjgV 3P7c2itb3XhbXILKR1ZLi1ln2FkQ5jKJnpuYNJgdwjH+HjzL9mDQ9K1/4w6Rb3l3BbQWB+3xxyyB Wnljwyovqd3zY7rG9daqL2POyeXoj66TSJDk7cN27VL/AGQcDAyfYda7RLRF6LTxarn7orj9ux8q OJXR35JXGeTUkekHuOvauz+zKewoFsgGdufaj28hWieU/Du0N9peqKu9ja+INThKrgc/bJjznqPm B/xrp5NEO3kAEjAJXOD24+uKxf2fQLmx8crIv+q8b6vFyOo87P8AWvTFiU7SGUHnIHOccH9alVZK 6fd/mN8p5BbWij4232nE4Z/DVrL09Lq5H4fertTpOOduMHsK52Fj/wANUXNmcbP+EHhkA9/t0oNe mvCF4IyPWn7WSbv/AFogfLocXLppXopZR6Dke4oOnswUgBj6/wCetde9smcY6VC9oMkIMDv/APWN X7ZoXKjlI9PkkYqoPlj7xPX6D+p/r0tRaUoUKqBQPToK6RLdAo2gY7D0qQRADCrk/wAqXtmPlR59 4+8Oy6n4H1/S4U3SXml3MCj3aJlH86PhdpIX4b+FSEY79CsmLZyM/Z4z3789fb6V6RawIsqcZO4E kjkmub+F8SH4YeEXAVtuiWOGIx/y7oM/lmm6j5Lk3V7E8Wmq0gX5gFH3ccHP9eP1rjfgHbJdfBfw bIcYfRrfBHIJEYBH1yK9QjTqc5GeBjp2x+deb/stt537P3g9nA4sNnH+y7L/AErL2juHMjsjpicd PyqEaSqtgL8nYen/ANb/AD06b+315puwbqfOw5kY401AuQvAHYU9NOQkfL9PatTy8Nx93uP6/wCf /wBbwuOePrRzsOZGd9gj6bfpXNfENIrDQLa7kVhGmtaTkKhY/wDIStucDk/Su4C/gK81/ac1CbR/ gtq+rQKTJZ3WnzgDr8t9bn+lCnK+glLmdjrRpy7mKxlOc7vU/wD6gK5T4pXuj6R4btZNSvLXTvN1 zS2AuZkjLiLULaSQjJ52xoXOOijNehNFmRWCKT0JJ5Ud8cc9BXw3rN1B8U9Z1Lxdrt1cNGb57e1V ZsmztkVXUKQ3lthWywBAL792M83Bu9zSK9o+VH194e1Tw/4ihkuNA1ew1ER4837NOshjJzjeAcqT tPBwTio7Gxtp9JZYMFBqchzn+Jbxt35EEV8k/DXXL/wF8XtE1Jr+zNheTixv7h5AkBtpGQO5dvuh ColPIx5fXacV9c+BZrjVvDNzNOQkkWu6lGMRqvyQalOqjCAAkrGOcZOckkkkxKMlHmCXuNpmyLSM Y+UE9gO9SR2gKYfBJ5wOg9quRxnYONvcL6fjTztVcscdqXMZuoYU+ixPIZCAM9McmuVvdDt4fip4 fufLX7Q2haorYORgT6fjGfQk8+9ejgFlyV2n0zXM6nHn4n6Fx00PVO3/AE30/wDwp00rth7S5P8A YcrzF5g6ESY5HQn06c+9cd4Zt47j4z/ECEhHEdhoqMOvWK5yCPpivSBCvmfxg53ff4Y4xjGenTjp yO9eX/DQvL+0F8Yo2YlI30IKM/8ATix/rW1P3oyG5K5h/FT4j3fgrx1Z6NaWNjqFh9jWS6Du6zRy lyAN/I27MEnaTzknGSKNt8cbdruKO68HtHak/vHTURI649FMagkEf3hXG/GuW1n+MGt3NnJC+0Rx NKrZw6xRK4PuCpUj1HtXHSlVliEqKWUODuHr3P584+vNd1PD05QTfUwdWSeh7tP8fvCFpILdtB8U zFVUlxDagHPXrOOmOeMeldV8O/id4c8carcaTp9jqthfxW/2kRX0CDfGGVWYNG7qMF0GGIPzcA4b Hyy4D30SuwKMjEqBx/Dyfz9/wruPg3qqeH/iXpd7NOYrW4LWFxJ5YcskoAVScfKvmrCxYYwF54zW dXCRjByQ1VldXPqR7UHHFUbixErEFCEHBH972+n8/p13MDb05PWmOoCk+n415l2bqZxl9a58f6Km 5o2/sXVArqMlSZ9Px17/AOFbi6eFZTNGJH++ZAPlVsY+UEkjIJx7Zz15z9QXd8S9CV04OiakdpGe ftGnkH2xiugRFDOEIABxsXGAepPHc55z7HvVSeiGmea+BSJfin8R9PPAgvLCYc8YexiXpj/pn612 baYpcsBjjkY4Pp+P+ewrgvhmHP7QvxeUj5R/YpU49bR/8K9XCe1EnZlysjCi09QTgY5wRU0Gnxxg jado6D09hWpIERWdgOnXGfpTLdZWTzJo/LY8bM52/j3NQ5NiuiL7LFsG3DdDkUqQKMdvSpZSIIpH WN5GwSsakZZuuBkgZPuQPXHJp0XzLvJyT+ntSbC40wpx8uQOma8y/aAsPtFl4LlUHFt400mQ4959 n/s9epcYNcv8TYVm8O2m4KSuvaOwz2P9pW1CvdW7ocZ2NZLUh28tQrEhixGQfUfkP1rzxHK/tQzW eMq3giKQ8f3b6Qf+zf5zXpz+V50Stv387NqnbnHU9unTNeWsT/w15GmOP+EBYg46/wDEwXv+VOGt xpno0lqCTwMemKh+xKX5UevStMjjHamMMGouxme1kmR8ophsgWztH5VpYppKg+n1pcwWLIUZ4pQv HQ/lS0q4zRczbADvWP4x8TaD4Q0V9X8QX6WdoriNWILNI5+6iKMlmPPABPB9K2hnH86+Df2xviA/ iD4wzaJDeM2keHdlsiwXAZXucZlfbjh1ZvLIJOPKOMZIrehRdaXKjOU+Uwf2i/izrPxF8ReVOr2n hy3mcWFg/wDCQMebKBw0h6dSF5Cn7xPm2jyyPq8CqzrCNznaSOAD07/j69hTtaurC/W3lsyymMbW idcMAenOfX69qoW0627PIYvMkwnlszfKCQck8817kKUYR5Ujncm2emeF/jj8VPCN9Hbx+L7y7iQq xi1Ai6R1X+E78sPTAYH3FfcvwN+INr8S/AFt4iihW3ulc297bgkiKZQpOCeoKsrD2bHavzNu7h7m 7ZpFiViwbapzu7Z6ken+RX0z+wB4rFn4z1nwjc3GRqdmlzCDJ8qzQ5yqj1KOx+kVcGMw8Ix54K1u xpGTbsz7Tpce9NyDS+lebco4r4WabHpWpeObVAQr+KJbnr3mtbaY/rIa7ROXYA5xjjGMfjXPeESD 4i8adeNciH/lNsa6JOdr/Mc9OMcHnkVdRKMrIVzzP7K6ftVi8A/dy+BjHn3S/B/9qV6cRz0rjru1 KfG7Sr3b/rfDV9Fu/wBy6tDj/wAfrstu7k/d/nSk7WFciK8jHK9KNnHSnMwGcCohKC+1TyPvHsP/ AK/+fSki1cdt/ugZ96fGvHA57g05CpztOcHmnY7jrTuS5Agw6nPeuI+BN8uo/Bzwxc7QEXT0hAJ6 CPMeP/Ha7ZW554IPIzXmH7KzPJ8APC7SbXZ0nLZzg5uZc+vbtS3aDoenQ7jGu5ldgMMyjAJ749Oa 4T9nuwbS/hNpWmOAGtJ72Agdil3MuP0rvVPzkZPr04/OuX+GO1PDFyo5C65q6gDnpqVyMfpRZ7iv odQevSmBSM7iMetPA53N1/lSkgDOadxXEwFHpSBSSWPGf4fT/wCvSKMAHHA6DPSnk0XABznpXlH7 VWpadH8JtQ8O3abrjXIzBb7uEj2MrNKxPACcED+JsDgZZe/8b60PDfgzXPEotvtZ0nTbi98jzNnn eVGz7N2DtztxnBxnoa+I/wBpD4j3fjHVrK8+zzaZFPY2jJbxvvLlkMiRhwAW5kkycAYPQ7VJ2owc pIumk3d7I+idF+P+m6zfXtjY+B/F99Lb3flrJpemG/SOPcQsk23b5bZVjtG4cAhmrwfxd4d0Twxb 6edLu9O8UQrePcafdXEhtriLaohP2iFyro24RAt0cFZApxtHkuh+ONd07TNa0rQ7/wCyQeIIoYdV jg2v5yJu2puIJCYdw3IJ3YbcMitfwbrEN9Jc+HpH8myvIv8ARLppNr21xtLIwIcYB+YfLnJO3+Ni 3VPDumm+hpRrxjPY7DwR8OH8fazY+E7D7HpMcge/kmfcWWAA7pSm8Hd88a7FfA83IJVWx9qfDe3u bbw4bW5uHkkTUb/a7L8zJ9smKA5JJ+TaCzEsepO4k1+d+m+L7a0s9RNvplxdXN0Atw7EHH7tssAS SDgEgbgcKcV7H8Gf2hNc8MQQ6f4jTUPE2lOJZ/tOd+oQbnJPzuQJApDna4B+fO8KoQEsPUfvPoGI qRm/ddz7OJUAndx603Kk85rI0jUrfV9MtdUsJxPZXcKT27gEB0YBlbBAIyCDggEd+elouc45/wAa 4uUlUy4H5wOa5vUpF/4WnoK9joOqHp/08afx+ta6vg5Brg/Fmprb/GzwNamR1a90zV4Rt6ZH2STB /BM/hTimnoHs7s9DJT7WsrRg7VKK46jJBb8PlX8RXknw0vVj/aV+MFoSSZv7GlT/AIBZKD/6Gtem syoruY3i53NsUFmxjnAznIA98eh4HzroOtnRP2yfijfSxyTWtr4ajvpYo/vuIbeyOFzxkgkc+ta0 o6SS7DcEmcZ4gurLVPF2saxpkyGxvdRuLmJ3BXKOxIODjGQM+2fWsgxRzahDI6qrNE5VXUkkhlwT zwO4B/H0EluqKEMZZQeUQ9s/NVl0UXAdnYHaV24wDkgnjH+cCvbSsrHE9WZ858vUrcoPlKsMMcAD 5c/r6fp2uSoCUljlmjMZDo6SFGVweGDLgqw6gg5BGeuKytegkvNT0oQTvbNHcNMDGik/cKkcggfe 9+n41JcaVJL5e68uDsdHwGAGVYEE4GOo6dOeR6Ftxn2p4K1tfEHg/StbjEJa5t1NwkAbZHKPlkVd 3JVXDL7gcZ77OTuyCCpHGP8AGvEf2Xddk/sbVfDNzI7NZTi4hMtzuJST5WREPIVWTcSOCZugJOfZ nuDjIwSOoPUivArU3CbR1QXMrnIeJtSWy+M3gu0bAN/pmrW6+pINpL1+kZ/yK7MB95ZkTJBBIY8D Py8fjz/WvOPiFBcv8WvhpqKgeRFfX9uTjkGSxmbB9j5Q/I13hkXCKihihG0ux47Zzyc4J+tZb/I2 lDRf11OF8C6fLa/Hf4lXMgwl5a6NNHnuBFcRk/mhH4GvSB646Vx1lKIfiVrr8kyaLpeFHUnz9QGB +Arqo3fHPTqaLPqKXvO5JjccnHB4oIBUruIz3HakYnBKjJxwCcAn601AwXk7mPU+v/1qkmwrEZG4 qG6fX/P+elI+QDsC7uvPehwpUhuRTHlVSoJ4PGe2ew/z/hSKSHIxKg7Suex61z/xEBOgWowP+Q5p HX/sJW1dA4YoQp2t2OM1zXxJlEPhy1kdtqrrWks230Go2xNOnJc6Bq+iOjkLjLGRUQAHOPfnPtj+ teZzW7D9qm3uCrYfwPKgPri+jJ/9CFemQeX8zgk5Y55PUcf0rkL8Rr8atFu2jCyt4b1FGIPGFubE 4/8AHjWak+ZJef5M0j1OxIAHzelV5JVU884p80vmcjpTTtxwKSfccU+oyN3uG2qCB3NRyIFc5Y+3 NTxMyg+WvX2ppVzliKXNZjW+pZBzg/lT19BUdOBHWncxsZPjjW/+Ea8Fa54iEAuTpWnXF6IS+wSm KNnC7sHGduM4PWvys1W9ur+/mvb+5muLq6laa4nkbLySsSWZj1JJOTz396/Q79sG5a3/AGdvE+yd oZJPssalX2lgbqLcufQruz7Zr861bEgzIFPLZK9cjn8+1exlsVyORzVX71hIUJYnpwBuxxn04z6f pUoYxT5kACns3Iz7e3HUetNiQq4dSrIAWIAGGAx2PX3HpnOKSYRqBg5Oeo5yf8etenYxvqJFJIyb iqYJzu4znOfr/ke1df8ABvxS3gz4n+HvEHmeRDZXaPcEIGzATtlA9SY2cZ9TXIQg7zyIwTjknH+e 350sUjJJ8q4YA/L3X3Has6sPaRcX1LTs0z9dQwZQynIPII707PNea/sza7L4h+BfhW/nYGaKzNm5 znPkO0IJz3IQH8a9MiAxzXzbfLuby0OZ8HlW8Q+NgH5GuRA4GSpOnWWP6GuoZflPAY9Rn17Vx3gK +t5PHHxCsFkXz7fWreSRe4V9Ns9pP12n8q6151yR2/nU87kS4u9jmdSlB+JuguOV/sTVOQOCPP06 ukabcvFcpqUoPxL0MZyf7E1Xtj/l407p+YreMjfdH54ronG9vQ0jBMkaQklQee59KQHpg8dqjDYw BRuoRqkTK5DBgcY/WrCXAIx39KpA+9LjODnnFJpMTgmWHkJOc4ry79kxmj/Z98JxSxkNHFcAk9iL mUfrzXpKt8xU43Yz9a4D9nprY/CyyitklVIb3UIQr8fdvZ8Y7Hr1HfjqMU7e6S4rY9M80bgRuPbA xXO/DRFXw/eEc513WDz2zqVyT+tbK5HVcnqMnGTXO/DW4Evhi6cYwde1kD3xqd0P6U18D+RnKGqR 1jyhR1qEzMTkjHoKaB3PWmMecVKSLUES+a1M3tvB3EDGCOxqPd8tG4e9VZFcqPJf2qPGVzoXw5ud Hs4ZhLrVndxSy+RvRIURVkTOeHbzUxwQVEnKnaa+JPFo1Ty9LOqn9zPaWrQxlg6hFjC7uy7jjleo CgEk4Y/cv7RHwuPxP8N2dvZajFpuq2EjmCaZWeOSFwPMhYA4AZkibcVYjy8ADcTXjni39m5fD3w4 1W+1jx9NrFtounz3kNo1m0DJGNpl8tvNfOADhSuCxXJXcTXbQlCKT6mU1fQ+XZXilGxEjVDGPNwo QoATwQOSPpjnqB36TwBaW41qPU206M2tnDJcS+egxENpWPk553kYGPpzwMe9s9KfVbmKK5vbezeY TpA0YldLd0V4yzrtBOHVCcLkkHttqxaaurW9vpunxzxW8t0HebeHlkboN7bc4XOQVHy8HBOMdkrz jyrqYxtF83YIIUtooY2YXKudskayq2Iz0UDABYgtjsN3rmnWdzbRysgeIbA7Tzxpy+4IWUf3cbT3 53HqazZXmSyZYJZU3qzHIJ3r1OB9CT36Ht0bYXkq3zNLKTlcZA25wQAR6kdO3Hfit3a2pN3fQ+tv 2LPiCjC5+HWoSiLy1a60iJzgqOWmhBLZPeUKFyMTFjwtfTh5r8xtM1aayvYtRg1CS1uLF1msihLS QOhyp3EZGGAODzx3wCftzwp8e/AN94H0XWtc8R6dp+o3tsTc2aBneGVDskJiQyPGjPym8gspXvnH m4mi4vnWxvRndWPWt3O09e/0rzj4h2FyPi98MNXgDraW1zqdtPtyf9bZO4yByeYTVqy+LXw1vlJh 8ZaYFBP7yWQxc45ILgD+nasvxv488HS6p4Pu7Pxt4dKWmtPc3DLeRTBIhpt8CSqtkElgq/7TDAbp XJH3tjZvlPTlbbiMuzMByzdT7k+p/wAa+XPFhvdD+OnxP8RWEHn+foj6cfOUjI8rR0kY46nFwWHT J5r3mz8beDry38+Hxd4dk55CavbybDjlW2uRnHvjsDXz18cNZitfGsupaRrFre2OrLcSXscAidY5 FOnxLG0qytkN9jikB2xhRkEnDhOjDwlzpMmUlYxT8skKouPnAYHJ/hPAHtgfl61NJGjOAf4Rxnsc Y5/z0rJj1XT5XiY3kT4lxmF8kfLkjr7j68+laK38LCFlnG5W9QDt5Ofrxngn+tevc4bEF4xbVrFk VljO/AY/Mfl68/5+lWnVY4N5mi2Ku9tzZ2gk89OB71Q1G7jimieKF55Q6gBIztGQerYwOnJP9Rn0 /wCEsXgS01C0v9f1yG41uORZI4J0cQW0mQQxkZdjyKehDbFP3c7Ves6lT2auXGDkbXwR8C6/puuf 8JVqss+lQ/Z2ghswAJJ0baT5ysCY0BVSAMOWHJVVw/tJbDAe2RnuKwJfFPhhSA3inRBuBA2ajCc/ TDHmua8Faj4Z07XPGV3JqOi2sF9ryXEEwuokEifYLQM+QeQZfOye7FyepNePVlKcnKR1wjZWRveM IDNrPhJXfej644K4wVX+zL4FQRz6nJ6ZroptojIkj8wOMbMA7s9vSuC8T+IPDknivwlayeIdIuII dee4FwNSgZdp0zUOuGBXYxVeRggp8xJYLNq3xX8A2aFo9UnvZkfb5dtbPux3O5wqkcY+96fWk6cm lZf1cakru5v6CHk+IWryzGNmGiacCYzlQ32nUcqD144B6Zx+A6vKhtvU4yR6V5Ho3xK8IR+PNa1m 81h4rG70fTLe1H2Gbeskct4ZI22hslfPjO4YXDADO1jXVwfEnwK0ZdPEMHq26N1Y++Cuf0rOrTmm rpkxd7nYs3b+lVZJ9pIHWuNvPit4EiJUa5uIGTss529fRD6Vmax8WfBdlCskF5c6k7H5o7W1YMnu fM2D8jSjRm+jLuo7nfySlvpTUY7gMk+gryiP42+HzfSLNpepJZBQUlUI0rE9MoWAHf8AiNWbb40+ FDcbWs9YhjB5keBCB+CuT79O9aPDVUvhEqkb7nraF9y5GVPB9j/h/n6efftK6lFo3wc1fVpDtFnc WM24ckYvITmrUfxW8BrCHfxAo/2fsk+f/QMV5Z+0H8R/DHif4Y634dsk1m4S+SEbYLNSfluYnLp8 27oGyCpB4OV5zhTo1VVjeL37FwlHnTuj6GaYZUMNjMOh9e4rlL/b/wALQ0NAhT/iSaq2P73+kadk /ma8/wDFH7Qej2Fwi6X4dv8AUCw3MtxOlsRz7B+Pc9+K5HTf2gPDNz8VbDWNf0u50G3g0e5sJJBe tdqplmt5VcxBVKKBbuGdUJJdAeAMXHC1Y+813/IXPHSx9KoQeAelDsF4zzWfpupWep2Ud/p17BeW ku7ypoJA6PhipwwODhgQfQgipi/zda5eU3LkD8EE06ViFNU0JHOTSmZtmOo96hx1Fy63L2eetLmu An+J2hRSbPP547Hv09u4qRfiZoJcobgZXGTjgVv7Cr/K/uMeaL6nif8AwUC8W2K6HoXgaMub+S6X VpiAwWOFVkiTJxg7mZjx08vnqM/LkHhS8b4ZzeP2mEdrHrUWjW8CJlpHaB5XbdngKFUdDu3npjn2 L9sTUbXxp8SNHPh+za5vY9MEMzo5JkHmuyIFxgbcsSe4celekWj+E/Df7K+q+CpY47i6bQrm5uVn RWzetE0m4cYykgXaeo2Ke2a9Wk50aUFGLu3qc7ipSd2fGcu1CqMeihunXcAec+/+elDunIwzEtw2 Ow9u/wBajkw8mXJC7sDkHj3PenOZJHLOTtPOSd20GvTSOfYcAPuJwWGQxJweP/rn/PNdFq/hm803 wTo/iS6s7u3TVby5hhadwqzRxJAySRrgMwBkcFxlflAyDmucZihPl5jxxgN6euB1r2TU9Tfxd8Fv CcEwYt4QF5aMSA4laa4tjEgHbCEjvkoB3rKamnGy06/caws73Z9Y/sY6DNo3wG02WedpDqdxNfon URIzBFUH3EYb6uR2r0jxT4i07wzpkmparcCGBSFUDlpHIOEUdycE+gAJOACR4n8MfH0vhj4d6HoD aayzWdosbIG2hTySPwziua+IWr6p4x1eK9uLuGCC2UpbRfZ2YoDgsSd4ySwGSABgKOoyfIpYCvUq N1FZM1nUpxvZ3JtD+KN5pPxQ8c+ILPRnNrrs9k8QnnGMQ2wiHyqeDxkn3xzgGuyX46s2C3hlWzwS L/Hf/rmfSvIv7EupcKl9DtDZYGzbPGfST6GrVj4dW5aOOTXobSFuWb+zTJn6Hzhj8RivSeApJXcf x/4JhGu29Gd7efFtpvF1jr40IqbXT7qxFv8Ab9yt50ttIXB8vgj7OBjvu9sHRf44S7HEXhtFYDIz dlgf/HB/OuPtPBWkMpE/jASE9CunbOD25kOfr9PSq8Hgq0GsO03jG0/s/I+VNOPnSLySpYy4Xr1w c+grJ0qD+y/xNFKa6m/L8bPFMkpWDTdJVG4D+TIxB9M78H8qZbfGbxbCmJYNLnxxve2cZOf9lx+X 09ani8IfDtATJruqnPHyyxDnr3jPPNLJ4M+GwQ7df10YYfKLmDj/AMgmko0f5H9zHef8w2P42eKy 3/HhoPHbyZh/OSnS/GzxQH+Ww0TA6gwSk/8AoziqUngz4elg0fivxOOc5We1IOe5zbmql74H8IbI Bp/i3XkUTq1z58UE2+Lncq7Y02OeMOdwGD8hqlCk/sP7g5pfzGje/GvxVNbNFDZ6Tbu/SZIZN8Q9 cM5GfqCPYiuM8DePvHeg6FFYQaraIFubiaRILOPZulnklYAsmQNzscdATxxiu60/wn8MoXBub/WL rrxNNGB/46g/ya67SvBHwuuoy0WnyTAnJL3kv9GFRKdGCd6b+4XLKW0ji4fjb4thh8p7XRLhlHLz QSAn3IV1/LAqn4b+K/iPRNPktLGw0loXurm6USxyMS1xcSXEijEgG0PIyjjOAMknmvTZfAnw1WIk 6EhAB5F5cA9COokz3rmbvR/hSl75T6HJlTtDJf3XH0/eYPalCVGV1GDYOMk/eZlt8cvFWwg6dog3 DgpBLkH8ZPrxXOXvxN8cXr7pPEEsa7MiOGGKNVPflQGI6dWNdS3hn4N29vFEdO1a7lWIB5Tq14hk I6sVSRUBJ5IVVHPAAwKrSaB8JDtA8PansGMZ1i9z/wCjqqMYPVUn9wWa+2jEi+KfjyLy0/ttnXjA a1hYn6krn9a1bb40+KoQFkt9LuudpLwOGxjOflYCus8M+CPhRqkKpb6NJ8vQSahckj85K6y0+HHg W1O6DQbUkHOXkeQ/mzGs51qKdnCxapzaupHkGpfG/wAUrbO3l6RbBR99IGyP++nIJ9v0rzD4lfHL xzqPh7+z7XVL17C8cefKLEW6SJtOYt4RS29T93uBjnPHvfx+8I6LafCTXrrRNAs4r1BbYkhiVXC/ aI9xBxx8pOfUcVxH7R3hnwi1zpfh3Sbaxs7HTLOWM3NhL86zedEu2QLgFljgljLSbiDcj5Sc1rQ5 KkrQgTO8V7zPlO9nnW5kkdcGFRbRJFEMoojG8DI4JLAsRnq3Jzk00vYMMpELSABzLKpYglslQBxn LcYHAz34r0a28K6DDJfyvp7362981pDIXMbhFiiwSQQrtukwd2OB6nFWLPQLTWJl0jT9NsTZwYke WQz+cC0e3qHydrLnaTt+/wAAls+rHCSaT0OOVaJ5mRauwCS27YkbyjJJ5RU8Z4LADqDz6HjjFXfD ug3msyxXiRtND88bNBKpdZSucKnVuq5CjqQMruzXqtz8O/D9rbXMMdnM5lDbJ0CnyTt2qMkjAPrt bGMn38+giudBnkhBjuftcxiXy5VYJKAd27gLnLLyB0xnutZ4mlKlG5rh3CpKz2My3s7VnmFz5kN0 h2PbP8hRhnjGFOSd2QBznoea7rwTa2UnhqSyu7a1mT7Q7L50WVztiXflh8wyCSSO3rWX4O8Ez+LN RuJb/wAZ+EPDenSTLK1xq2q20MrA7d3lW6sCxUZ25CIdpG5TnH1/pvxF+F3gDwDa6VoviywvdO02 3S3t7TTLqK5urmQ52qEhIBllbJJwoLMWO0ZI5amIULWV2y1BM+aIbDw0LnyV0vRmcjiMwRAj3AA9 gfwFRWc3hyS4tzp8+kxywuWT7M6KwJQoeE56MR3/AEyPS3m8T/Gr4s6Bp/jMmw8O6PEdVvtBRi8c G44tY7mXBD3MvzExMECwZ2nzHkA+mM7wS8kQLOSrIeQffk5Ycj8KyqYvktpqyqdK58jafoevXqLJ ZaVqN4WX5fJtpHDDAwflHr7/AP12Gwvo7TUNRayufsenXLWd9cGNhHbTgqpikbojgsgKkg8juRn6 a8c315JpEOh6FPJFrOtF7W0vIVDCyTb+8vPvDAjDALyMyvCmR5gYcZ8avD+i+C/2YtU8PQXVhZWl jZW8cRAWA3UkU0TAkIjBpJCnzfLhmblkGWExx17XW43R3PBJNd0qyYGfWLKLC7sPKoJGTngn3FMk 1rTJUjlS/jOD8pifcrgHqSM5/D09BXlPiGCa80K61a/h23LKohjB+WCPevbH3uTk+/bpXSTqnnRh Tg7yCN3XhgQR3I46eldjkzJJM62XxJoqMFa9Kl/mAKkZyD26546f5HeaT4I8W6jZQ3dlod3PbTok kEqABJEYAq6knkEHOemD+NeFXls89xaSRozBpiVPBL4Vhx6nPP0z+PsPwY+LOpfDuQ6TfR3Oo+Gw XP2RCBJbOXJdod2OCcnYSFJJbIJYnCpUnGN4K7LUYvc6eD4V+Pnww0Ajd83N3bjj/gT/AFP/AOuq cfw+8ZP4pfQP7FY6hFaC9kUSRtGsTuyLmXd5asWRsJu3EITjAJr6f0HVtK1/RrbWtHu47yxu0EkM 0eRuHTkEAhgQQVYAqQQQCCBRstDltvGWqeIWv1Zb7T7SxSBYMNGsD3D7i5YhizXLfwjAUdc5rhWY zV7o09iuh87T/CDx4WjdvDULeUf3eb62O04K5X97wcN29x35jf4V/EXa5TwsxPAAW/tfx6yj6f5x X1NuG44wT/LNLkgDpj27VP8AaNTokWqCsfKh+GfxIH3vBl3Iccn+0LPk+mPP9KrXHgD4jW1vJdT+ BdUEUMZkkK3NnK2FUk4SOYu7YGAqgsTgAZr6xL4PLCo5byBBtaUDt1pLMar6If1eJ8y6d8KPH14k hm0WOzV02j7VcxfMCTydjMR17/lWpD8EPF0qNvu9EhfBwWnkzk47hD3Fe8T3oZjtkUL9ah+3KB/r lx9apY2t5B7KB4g3wR8SqONY8Phs9pZ/p/zyqrcfBbxjG2INQ8OSqeu+6nXP4CA9q92+1RFRmZee OtL9oi7SL09aHja3cSowPna4+EnxC/tJLG3sdDkjNuZZL1tRZbcNuI8ofuzKXxhs+Xsx/FnitCw+ CvjKUlNRuPD1vETkCC7mm5Pf5oVFe9m4jQAlgB7msjWPF+kadcCG4uEVyOmaX1yvLSJSpU1qzw64 /ZavNRuHuL/x8ke9i21NKZymQBgN5yngAY+nuax9Y/ZW1azRX0TxdZ38obJW6ge0U/TBm/LGPavo NfHGiNEX+1qBj1pbTxXo97KyRXaEjjG8Hn8Kz9tiFq1+BfLT6HkHw0+G3xd8BzwSaNrfhcWauDd6 fdandSQ3Q2BC2BajZLhUw64+6NwYcV7zZTzvbQvdxRQ3BRTNHFKZER8fMquVUsAehKrkdh0rMOs2 JBzcIcZ6Hr/nmg6xYKhf7VGFBxnNZVJSqO7Wo4rl0OiidSvAPvTJcZIA5rHtNaspB8lxH68Ec1cm 1G3C7g6nHvXG4tPY3TVj5jKfL5mAWJI2j+IAgn+ePqRTfPL/ADgFAegBzjjoccVlx6rbSRI7sQSR uyMc459qnOpWzLkyHvuyRj8elfbXR4Bmarod8PGFjr9lLbhUiMN1HKnzFOeQfXkDH/16ueOpjH4K 1rcAy/2fMo5wOYyKnTU7YbsuuQSOVwBxWV421CBvB2sIkwMr2kwTnbj5SOB/wL9KaSC7ufN7gMM4 A4zjbjHNaenaTeajbalPYwE29jGZpzxnAIGATzxyfoO/GaC75XDJIfM6Kehz2I9OnrnmvXPgVbQx +HtSvZkQC4uPKKsOWVFzj6fPj86yVm7M021R5HHiMEYUjJCsBk++O3brXuX7PkSnwldvJGJFOoEA gZwwjjI+nXivIPF2l/2N4p1DT4ciGOUmLkj5D8y9euAf0r0j4J+IYYfD17ppiBkW484/RkA498r+ GRVR0eontoewKVK/fzg8ckUpc9Rxzkjtx/KsGXxBAm07mVimPm4HTJHr2P5VFa+I/MYLJznjfuxk DqP/AK2PTFVzK5m4s6VTGBuZWVUJUfNx06/yqSN1IDcklSQ2MD16+v8AhXPf2zbMVQdMdjwOMdan /tW2V0GCB2A+YcU+ZdxWZt7yznLqrZIyQfb8vSmb0IGxR8xz0GayptTg2AhlIXooI/z/APrqF9ch 8oMq7ww4PGcYJ6dcf/Wp3QWbNsCQhdrYByQcj15+lJG6BA7MWVl3cYzjPPfnH61l/wBr2yxF237j li5Pp/kZ/Cqp8RW38OV/hGXAo5kJRZ0CyqwACIm1QMDkA9wD3/yalWQkD5kLkZP/ANb/AD3rCOt2 oG9SwVxksR6jOeacuvW+xnVQmSRgnPvx/n/GnzIfKzXDtGSrkk9B7f5zVm3u5IyCkzRj1U9fQ1hT 6tarGbgtJkZIB/xz9RxTItbSQKwA+cHkdQOnT6Urxe4WaOkm1S6lj2m5mbuSGwDgjI/nUHmq5JKn I9uOAM88DPNZceoW+cLyWxhR1OevvRHqMHzP5qkpg/4ihcq2BqT3NUTPlQzb8Abc9gP85prS4UZI K9j/AJ/Csk6rCyKQxYBsHcdoB9jyOw60v22GUREzlWY8Ko9DnA/KndC5Wb1nevaT+bC7I46EN0/z iumsfHuq2yeVMyyEJnLZXPoMd+CK8/N9bpcoqSYJITao6n/9Sn9fxT7fb4x9o3HP1+v+f8nGpSpV NZI0hOcdmdr4w+Ieo3+mf2LbCW1EuyS4byQwlTf8qq54HKEkYz93B6g+P32rSXE8dydQuLaRRtEU JfMhDgFSu3BBAHXjuc1t307TTSmJi0Axt2EnnYMdM98/rXknjM3lxetdQtFLZwIY5ZSwwrGOVo4s ZBYH7MzYwec5OWGeyjCGHpXSIk3Un7xXsPEtxpg1O1JuGmk1SZjbOpDOWwg5J3E/KQRjt9Mdv8J9 XN/c6pIkJjlE4BKqGXaVwFJzkfKrDGMAqcfewPNdK0n+1rSFFsJLie8uCpR7lEYFIzKxKhxsUKxK bgAfmwW2kL3nwr0i50q/uoL6wmiQKkcMu6ORQyFpDgBuD+9yNx5ztycHPPRxM6tVR6f15mtWnGMO ZbnW+MLiJLiKyu5JvJuDneixiOSNfvI38XDZG5Ru6/MmAa8Y8VXNtLrT2lm3k26Xw8l7OMALJuRM hhwWKx78k9TyeAT6145vZX0qQ2cvk3bSRRx+aAQGdgqnODxu2DJ9OmK8K0bTtXk8Rw6bZ3BgvZX2 OPNMflmNyzK54zjYH+XPQY54q8bbSPzM6CSTZ6h8P/EWmaLq13pNlolr4mvbu1gNrJHDG8ccwyzR JuX93HiTJY4CiLkf3eoNvB4Wj1Lx14mntr/VYYW8pbeMxQWqE7VggABK7mIXzCM4bn+MtxPhzwQt usv26+O11VWS3ly5ZAp3CUqpUFtx24GAq5ZsGkh0eG68eItpczzWmkqlxKZLiST/AEjJMa5Z/wCE fPkA45B64rjhKMDWScj1H4X2d/4d0x7m8usa5qcrXepSbRlnb+DgY2rkDGSAS2MA11Op/EG5tYTa 390IY2tZ7qWRQWVIovLMpKqMnPm5zznaeOu7ze9vtU+Q211GYgAHWSF3J9dpEijjOdvfHHoeX1rW J73xJp6XpgZbSRom8sShZHbEuxv3vzBTEjnng7Rj0cnSnq4glUjomek2vjSfw9eS+MvE15HZalqM Igge4tGSW1tlzJHbDAJP3mdxx85VcfKlVPDvi698ba/a694uigGlWoVtE0m6UeVIdpBupIjkF8Ni PJIQMSuSRI3FtqC+MtXhSSO3OiWLiVxsyL66C4LEHOY0yR6NjJ3DO3butQmjmDPJ8xLbicA5wP1y TUWpPXlN0pwlvf8AI8y8VRTweD57e4jEUsDiGSM8spWQKR+BGPTitq5jZbmEDI2SkcDrwR/hzUPi ywhuYtetRJmfzXuZGLZIJRZSOmQCc8fyrPj8S6bqOojEP2eEzbIHcDnI28jGB989/wAqlojqaV5H GzWrG43FnTOxTh12/ey3bkYrSUNvYRMC27Kl/mwOgB456dvxrG12GVoLVbaQK7TptO/jg57diMjH 0q5HZXzRN5eqSq4B2kRKCxyOvUc56fX6hpBc9F+DPijX/DnjSAaZqTDTZQ8uo2jnckqBcBwuRh9x j+YcjjquVr3Of4rtyFtWHH94HnvXzT4SlmtLq7njkQuzCNT1YdCR9OU/EVtLqrowYFpNxyWz8x6n J/w/SsZYehN3ktS1OolaLPcm+KF8qsqWYVex35/E/wCOaz3+JmrsBhYwp6YJ57cH614//b1yB5Rj dQAvys3TJ5G7uRk0DXJQSxwQBjP8utXHDYZfZJdSs+p6jd+OtcuYwyXQjzxlcHn/ACQfyrKm8R6t Lnzb+XOCQQ3vx2+v+TXEJrOSqZG5hwBjJ45/DnrUMurTI5Ei5DfKFIGD6Yx/nGK2hGhHaKJftXuz vz4r1ZYfLW/Lcde/6f54qufEurMMG9kXk5ycV59caxM/7tUj2srA5Gcd8/kKr/2pOS8UcwVkzsPU 449PTtj1/J/uv5SbT/mPQ4/EuqSbSt9MVwAfmBXJz0PU9/y6UL4m1NSV/tGTcpJxnkj1/T19a86F 1cyYJlAZe459qC07E75iP9onIODScqf8qHyT7npU3jTVLmERNegALuBQ8emc/jWNPqAuXMksm9yM H8Pc1xOWZmJlyOmCc8Hrn2GabJOxJQlmDHlXI5H+HJ/L8KIThD4YicJS3Z2DXkZHztgEY+9ntSwX x3nyZlDfKcqegOPQjsK4WS7uS5UMxAGWbPI9/TH+e1Qtczq+xnLZLZzxnntjt/jWntvIn2fmegya j8zP9qYgMw6kHqO3+eozT21J0zGt0RzxhskmvO3lud5YszDOQgHXjp7UjXVwzIrhwcHBXnGOB9T/ AJ7Ue0XVD5PM7wazdI+Y7uVT6K/QeuM1fg8VapGPl1EjacnJyMZ/+tivM/tFwrgKSWXBxuGeeCfX j/OajEshO8tt+QbDtJz3B/Qc+uKhyhLeI1GS2ZYAGFO9iGP7tTwOh56c1YEzLuQLt7EBvu9eDx/I Vj+coOUVW5GSrHP4Y69u+KmivIVQl2TIIX5X5HHGRjjrj8fxrF3NU7s0jJskTklgOewI7D+v+eaG vJ9t0a9tFHzSQsQAcHOMgY9Mj9femtdhSMF0blmbv64P5/8A6uKhe7DLtDfLuGEXAAGecA/j9fTp hptaidmeRvPI0rEfdxyA2B7kenU/nXqPw+E1n4ajEjuizSNIfmHQ8dfcDNeYXbJ9qfy4zGA52Y6g Z4HH416b4d1GNtGsZM/ukhCPKwIU7QF5PbkdyM1rUuZwsYHxUt1/tG0uVbBkRk+YZ3bTkcevzfyq r8PNQkt9b8hkO26UhhjkY5HTseRj3rd+IBtrjw0XCoxikUgpwQeRjHXA5/GuS8FTw23iO0nuWZVD EH8QRk+2aE7xHsz1vZILiP8AfkEHJzgZIHv06DvT0t/LKqjCPJ4w2c9TkfXvVEXcSnzYyCdw+Zug wen/AOr/ABp63duNpMwXdnuDkfl/niudtl6E26QEZAUAZX1Axxkj/PepXkkmjVTBuK8ZJ6556f57 VVF5C8ioHXeqg43DjnHTPHTn8OtOe+jwxDgADBIPUHtz+Bo5gtYupdzBFjIcoXxznpznpz/PpSs5 TCEkcABWHPBzx3z06VnNdJDEzvMAgB3c5wPx+p/yKe91CAAZCA3CpuyAc8ngdOoxRzCWxoTqjLhQ WZR0yQenQj09ue1V96vnBXHQZ49QBnrz/TPtVSW7hAVVVcZzlWwc8/4+lKlzAEO+RASThQcAZ7/r TUhl5HAOz5cggEZ9+5HQdqI5ZSm5SR23fhVCa8i3uHkBZDy2eB1B7fUUhvo/LeQzB16k7Dk5Pc8+ lPmA0RPnCeUjgj7pYDJ5GehH+fWhLhhJsKpvP3ufu+49+n9Ky/tKSyFvOwFXOwe3T9D2qOO/yTtE ZYnBJ4J6fMMfl68GkI2UvCVEhfacYypJHHfr9fzpY9QCbhu6nOQcAd+5x2rnJbzzJAXO1C3loG4G 4YHHsMZ6dPalW53DyzIigrhsHHrz/IfiKdhXOjbUgw3bweMDtjHb8h/Kmx3qkhY7liVA2gEY+v1/ +v1rDWZI1+/heGXa2Ryfy9siqwvMgbx5gXJ9B2wBz7n17ehy7LuF+50cV66zLIJZNw4XIGPT/Dmm XWoWMDD7Vew26vnHmSqhbpnGfqDnsKxPtw8pQiNk/eYZ2jnt79K4bVgNa8RPEJUAj4R2IUBAw38d 8ZcjByQPahLme4Xtse0yXUdp4fmeScKyFpF3EfKSAG54wMHpnrj1FcpqR0y88Lz2VlDG5lkkvLma E4MLRpmKNiHwgIa7wjckqp4ByfNXv7y1gm0a8mkjt/tCmfLOc7SRwpIB4C9cH5F6YqRVisXt5I7+ GGa5tyJWkRx5BbkAbSdxKY5PZxkAjI6q1WU6ailsRRiozvI6rwlfi3uIPEnmK++7jtnEhJRAINk0 rFjycTbuTwd33gK9is7KbRneG8sCkckBjlKouAHZQcqfQquCRxu+U5wa+dtHbUdZLWsU6CWOPzY/ PvIokXaUVQDMwGAuAMEnC9MAmuh0HVNa8N38Wmaxfq8MsBuAIb+1mVDg7WLr5mD+7+6MNnbj7wzl hnyVryY67546I6f4hXSGGJJJrmO2e4ika7tyR5EQkGHU+mVXBGRkggHgVyukxx2yXvibQZxFaabN HawxlQftEYx5jSAYJ3FlZTn+HHGARa8Uai7faLSMect5iCBXCq3I+9IMbhtBJ6/KQuc9Rkabp2mD T9S0RvKS+SbK3JjBcxfKVYDORnHQH+LB686YufNNk0VaJ1lx47tZrN5bO2lnu9giWBbdmUTtwilg 2GJIOAOSAcY6VQ0vW7bRNFhs7rSdeN3czNLM8lrv86dh8x+YgnIIH05IJyDhQQCbV4rvSbezI0uO OIhovLF1MuQcjoGAJ+Y85wcnqOntdb02e3F5MsXkxkeYJ48CGToQePvDIB+vHFctkjRO5JeeK3hP 7rw9rxuWDC1imsWVMEdCA/PRjkDOBj1J5bxFex6lbQ2mlW+oQWdsSLqa7+WZ5m3B16nkhiWz/exw MZlk12+1OZm025NuZMxBw5xaxE/Mw7bnPbqu3ggc1pR+RHbRWMOAqJtEQbOcn+eTyTzkmq2Ki1fU u+ATGLJIygAhUgFemAAfXJOfy74rpQsUkis2QSDhiCB7/wCcfyribXUYNMmjElzBGGH3XIB7nB5x 0OfQ59xV9fEmmoomu7+0ZCSD5cwZgep4B3fj9O9Iqck3dFX4iTiyN2FcwPPZRojquA58wh09jtHP tge1cxLYBfCcV0YmjbA8wODghnOTj+8cxEYwMAnmrHjnX7HVrWFLafeY5WbGxhuDAHJyBgggjg88 H2Ghc3dlceGYI5L87RZJEQH+YusfAJI4AY44yPkHrimttTPdmtp90b7R9Nu1ZmkaSLeGAAZhlW4H oc4/lW0cIqs6kd1y3TtnOOvqffvXH+G5J7rSLSOSRIfst6ZNvGZFZGf35+c9M+ldDq91AunsOAZH QMwYA7dwyc+uOnr09aoL6G7psU62iyeYCZBuIKbcBssAR7A4p2V8wF5EYDocHA9j6kfj1HcVhJrC lVbzNruc/ORx+v8AnipX1aF2UedlsYBz+efc57c8VjcpWN25ZWYMFCcqBgEDdxzz3OMfjVdiADvZ iwJ4PQD36+tYq6vamYOzhjtJBGMLzwOv49O34UDV7fBCOVVkyDzhh14HTtTuNG95uFDj7vKlgMlc 8Z9+5/Sq/wBpBUsGJJ6H/OaxTrS3C/KWAONvBxg8Y9QSD3pP7VjUAIQzHAGTz0p3A1pbmNUMhKlu PvMAMHgk/j3oDbcqcCM4JYqRnpgD6A+h9OK51tWkaQM0iBQQCwIJ3njHB46086pEqELOGcKTkR/d B6jPB7n8j9aXNqTrc3/OIC443EsQRg46fh/+ql8z5gVk+VeuccHjjHGR/wDWrn11hJoWnaVmBGcq uCcd8E5A+Ynn69OQ/wDtuBmO9kGVyGC9eOv5f5xRdBqbJue3mYUH+HvnHP6ZqKS7lVSqpvVwQHBA 2+57/p61jf2gm4Bp0C7jgkcYzgE/kf8APWGTVI2hMcTLk9CpIII447jp2pqSJuzbhLRw7QQoHBPT b2GPyx/+qlm85MM7qqkbm7kd+KxU1GPzGw6O7AhxGmCPbHbgD69aik1dFYZKlXwvy5JU8nOBxnJ9 eOv1fN2KuzfLHyUbajENzgYJ9gP/AK9LDLI0XDRndjew6ZwB+XT/ADxWB/bMaRqu5cD7yAfdH+JN TJrcaod7qeg3A4HXr37/AJUroFc15C5cqSYyRjknn8fyP4/jTZVBZY8Da6n6dsj05GT9M1zravCi nMke0bXUJyDz09uB79fxqa61qAbJXcqpVflds4IHQ9s9uKLonVGF9vZkQQyMgZh8wbKknAJx0J/D Pr3qebVZkeOKW5OQqnk5GCATxz3JBHOOn0oorAYkwykcqxyWPQ9+mP50h3tKcKzSkZHQ7s9ffHf3 xWftPd5bF263LsWoycMcyYyAW6sexAHTpntU41JpCYy23K/eAPBwegBP5ms+RHI3cEAcgMCTwDjg 9vrg02SGaS4RQoGxSZOVJC49Oc/dI6D8e0Xk2GuxgTEpLJktktkgjnvnI/pXSaTdtDpiIULqp2qr HvuJB4wR9D7Z61j3WkXkdulxNGCH6FGLHAGSTgH8/X1q7a28kWnW4MZypO4txtyen6j8q6qzfLoR Bsv6hqH2rTLlduSVJw/THBBXH5YPvXP6UVjv41d9qqSTwG246H0J7/8A660ngmmi8tJHjQ84Jz04 GT06D/6xqla6PdzSON8QZQcKW5bH17f59qVJ2jZsbTepv/2m4aTE5BLfeXncOw46cfhxUf8AacoU ADaVPzkA556fiDmo9W0W4s3WVGfY6Z+6X9sHtxz1/wDrmNoJZpIxjnH+sD5298EgnpjBz657YrCV xNli5v7hGYF2WJxkjKkD5hx6Hn+VRtqbKufOnhTDdfmDZIbk56emO1RtbM5UMiuCMBR0HH06dalS 1kklRlT94MfPycYHBP8AL/69TqCuTPfTRwlYiSgU5IIXrzn8cZ79TUb6nMzgStIuxiCR269ccd/y NLHbjYS6bdq/NuJHoc8cjqOf506S1A3HIQnkmNckAAn9eB68+lSkykRPfXBKhmdmAA+7gnk4Pt61 NBeTZLyS7wfkCqQTu24O7BGBkD69ec5qKC3KOfOilKYAI4yMnB4GOMZ688+opWtJlRI0ypHAbGAB noRg9vT9aq0hajLe9uXnLLMS3LtnJKsef6Hipmv5FlRvn8vJA656dwemB15pzQTFSGjxjaCV744O T+Z79aPskhBZoNwbuW746Ee35c9cUWl2Ghr3lzHGQjSqw3bVGOWHbj/a70h1CZZM7kdduQ7fXn8h 26cUsts4K+Y6KGwUXZjO3A59uSMZAPH1oSAllCIxiRlzsUKzZGSPyP5D8KOWRLFfUCI1P2pvM3Zy 5GV4PGBngf4ng0HUg8IjWOMtuy3lHbu7569ef54zTktZROHRQGIBb17dfxwcH3potJQikjDdR0xy c/0H0x3oakwYk1622MsZQ7YyQMHp68HgkfmelO+1XGd0bja/VQOgB4/EjHAphsrhS0W4E7QQrAkL +Gfc8dORU8VlcsFXfHCScZI4zngnP1PPTpS5JDsipFdSOhXDfMcKvG09sH3zjisy0Nql3fvOCCG2 RmGQHLE4OM9QcNyBwCfYVuGzlDuSvlq3GABhc+hz16Zz6n8cXTbdrjXbm2aHe7SE4f5tx3EDjHOS w5/GtqcWr2GnZpkMtzJJqxmEyZJZgrsqrnBxnoOcDr+Jqe6toVt3uTvlkMn71kmV1w2Aq7hkb/vn qeMZ75ueLLaCTx5NDbWa21nJcC2iEeAMbEUN7EhgxB6FsGnXsNvFpUsryDD39vCiNjlVRyx3HqF3 J+fcCujVaEaX0MKAQ+dEZlOFwvyAAq2AFIHQnIyfXnvzTLeaeO5ja0ASZPujjgjn88iuhvNEhNmN QUSQySXPkb2B2eYdhX13bsyE9ANnU9KlbSBFcxhkWN2J+XgbvY45AzgdR6ms22tbDSuzNsrkSyQX KTSRJaqEDPAhBbBBO3Ixxz1zkk5zST3sqzm6t5y0yqx5i4ILAlRyQQOvT17gVpR6dBEpQjy426gE gA85PfsKH0iOWLLHcuMkGQHC559MHjJPWocm3exSUbeZm2b3nkpbxXjQqOyQKdoPJOSc9c//AFhU Gom4CXBN3M4lA8wNF5e/bjGQDyPc+lbn9mxbAI1RlZBtKucepwSO3H/66W40lJk8t5mwwI3LIBg8 ct6qef8AEURbvew/dtsc/ZQTs0kAu5Y9wBO0nDA475/zgfSrKabYSyDzWvFY7Tnep4LYPYYwO3c9 OtWbZo7WZI9SKwKkSbJAuBJtYk5xn5sN6HoPWry2yy2aPGgzIM5BBAzxjPr0qZuaZNroyo9MszPI PKkMYOATJnn3AA4zxx+lT31hp7OotbARlxnHmuSD3HX0rQjs5AQyZLou1VHQ8Hpzx39e3ale0dnB OQGAU85BGMHtx0HPAz9BSU6lrJlci3OdvYIUtC8UaK4K7yGJxkdB1PcflWn4TtbG+1HSra9gAtri 4jhnZ5Cqqu9QWP0Az+PHSrN7ZiWzcKyyl1ASNsjLKT044yWHPqQPrB4LsI9WinsGnWFo0aQEsDu+ QsqYBBClhtZ+Qu4ZHaripNW6k2syNiIibe3kXGIPqQY0OD1Ge31z07SgrHORCsqgEtgYwT1Jx+Of xqxFa28j3c1mz/ZZZnaAHgrGDhFIPso+lTm2wAZpXBXou7/V9+ueOmP0rOpGV3YaTKEsry5Rm3bg cfMVB3Yx9KGaZJWB2uc9S2BnkjBH09+KupZK7OTI6gYbavDNyMcY46jPtmlawnb94zRYYc72LE4O eB2//WM8VHJLsMoSzyH+Jhk4yP4x6devPP8AOllkmyv7siYPgb8cglsAD/8AX1q5/ZZjEksvmRxu wEalTtJOScZGB7YPtwerprX7RMzMSOVVQoJAwMZz64/nVcjsH2in512sqbRKIww2dFLdc8evXA+v rSM1x5YKyyeWRmQA8+y4HOeQOvb3qf7M2T+8mDuM8KenTPAOBx/OpZbSIIjETOqk5CDnk9Rnqegx RyS7DM7fIxJJ81SScdc/Ujp/WpH3k5YjBc8FSQPp7YqZrYo4eNpg6ocgxMQccbdvueO/9ainsHZV 2C4hRPmJaFgMjqAQOvQdxx+NLkYmJPLKLfOChBY7lkGVXAP8+/HU5HamTNIrQqolhlMZBUj7/v8A p2yP6W4LJnVjAlzy2clMZ/P16fgPSnJaP5iuILph8rOvlspYDBweh6DFHIxpXKCzXCRMhLJnOc4K 9xjpx19OP5jSFlBdGYL/AA7e3U/X/wDXVmVI4l23DNGWB3bjgHk/nz0pptf3TbS8nXaQSynjOMAc 9uB70ckhJFd2IZm2lZMZCEdVzkHP0/n9KnvxZJZwOXY3UmZZQzKUjI+6QSMcg+pz7HpM9jMsPmSJ cbCCVbyDyw6beOeR057Z65qMWPlOVe1KZLfORnjn/P5mqSa0sJxbdzOD3EckkR87ZtAJPTk8+nfI x2/DNPYyFfk+XcPyXryf8B26Vc+xPHkrEVjY4wSRk5P59c8/TtTPscn3IklVSwJ3k4Lex/H17jin ytjcSlMJmKmVY2crgZHIBGfz9/y7U2ZGdR1w2QW656/rx69q1JbU/Z1DiWNmLMzYyu1QAc59yDjJ A3DkZqt5E6hozHMzPG2WMTKBye54ByOuSP6nK+gmjUMA3khvmJwVbHzdcH05ODj6CrFjZecWKKih XABYEHbg4IHHr+OOOK1HS3yVijjdgNoUoMrx69+n8+adGYCHdlhLHBCgBT+v5fhRJtrQ2Vk9TO+x oso8+aI/NkeWh3cdPmzyMZ6/rUzLHEwKRMy43qjvnHsR68Z6ematBxGEIOUBxuZcBs+mPb+Yp73K K6EKcpwozuGepwOB68/5EqL6sLpbIwpbq5lWWH7QVRxlo87iOmcAn1A6encUrKpi3LLmROFyvA9M 8gf4YrSRo4pHElmh8sYALAMpzyM5xwOKc0yiHd5MpjP3vQk5A6njP4VvsiEZssUjByjo3yBiCuM+ vOOn4elVQkhn3KyZIb7wJwOnPPTt7YPrXQTsJE3bMq/Lg4XPrx2HufXvSwy28UZUxqrHGMrySccZ HvxRey2AyZJLqWUAzIij5ziJsE9iTnHHpxSRxsmxEaPCsSXWPk8HbxnIOT6Ct1pjGF8tEVmPzllH ORkH9Onv+FTNdEgMlvGu0DjaM5x9Mdef8iocn2BpGE0TAFmdVwMlmzyBjPfGfb8u9Pj2ysrRygAl WOFYk/Q55+nPX89xblvL8uS3j8sDAO0EH8Px7/jUVwxMcc8dtD5ZBCnZnv0z3/z+K5mFlYxI081/ 3txGQp3/AC5IxkdRnnBP51HHDGAzG8h8zaPnwxAYd8F8HGOe/TmtvFqSQlrFtALf6peDk8Dj69/f 3pjhEAZY7dCON4j5685PH+TzT1FZGO0oIRGvFYgYKhPlOCcMBux2PI9vbA7hBvknweXIJO1ccdz7 Hpjv3rWYJMQpSFgQBvaPJI7cfjTQ0SxD93CEjUrt2LxweO231p6hboZW6UZY3MPLDh2PTOOcnnsM VGjQlk23yK+3JAk+6eCQeevH8/WtzZaM5WOCNerIrwjIPfHX/JFO22QVE8iBsANnYOB+PA+n0qgs jFkhE1uYZr6MoqYKyEkHoB7E9vYkU+2QJb5hvLeN0XGUYZBxk55x3yP8DWtLBaxqwS1iCsBnZEuF 9ecY6/57VGbaxBbZZ2hVxjmJfUkjOOnU57/zkVkZLOzsu26iwmNsZG7Htx1qeOMPJta4QEEoNvPz DPGCeP8AEVoQwWDqJ0tLYqQQXCKw9xuPftipHTTUZXeGFR1BkUA9Tk88Y4P50agZZt4Nq7Wi9mUf cPTqG5+mf5UrlzNIUXDMVJYx7ie2c59Qec5H6HQMVn5iq1rCQgIACjgYHAP+e3tUP2ezKLCY1Cj5 sE4y2MA4B4zjH4Ua7k6FBbeUS+aELNu+fbbE4G7HXPfjI4B/GsLVbqfSPEi3VqHV5IQXQoUHt/6C reuR7V1sdjaHKtbAqOT75PKjB54x9KZFpljHI0v2ZGkkQkMCWC4I5GTjqvUYPB55qo6PUcldHIao lw2iWeqqfLkM5xOgKFnOSTnPUBVHtj1PMF/I+oaU1zLN5YhfMcSg7WZz8/TgEgA9uF6V1s2kacH8 poGUI4fZvbBJz159z+uM0t1ptjKMyxLsX0ZsevOD1ySPbP56JhynN6FPd3zxtcSs/wBmTbBujYj3 xjjIBP3uufxreW6kVTuiiHynYHtD1xjgDGAPf9RUr6dYsyiG2L7IvLz5pVhjoDgj8/rTvsIRP3Ej AnBABHynsfwPapkr7CWhWFw0kZ8kIACAE8kE5B9APp/jVgO0iOzSJtDEZFqcHOcdeew4x61Zjggu JIwIt5UHJGScFR6cYx+H5U6G3gOHKhtvABJ4Jx0H5j8fymzKRWdpJNv3QSOMQHpnGfbr9OajgNzE 2+IKuFwAIQGyDnAU5Hp2/PrWgtvE+V8uTG0gMSeh6+/QHr9O1KkULgBQADjlmxz/AFpagjJvbUXA LvEkkwyMopBBx0z7gnrx+WaqSWk6jZ5M42YG3y24yAen+eMVvMuQEdY9oPUZXc3GD6/h/wDqp0Zt 0kIZYwMeoz36Yzk4zTQ+hzUR1iGEAWzQ7cbd8DEEdzgqc8j9cY61bjGqMiCXykj4bIh5+pIQj+lb CujMSx2ZUZAyCcDoenf6Hkd+aZLHIyLEJSE3AEFm3Dr/APWp/IEUPPuoi+EDhjhSsI3c9+F+ncjP Xoawb3Ti1xcXMttdxyFjvwerEbmIGwZAJ/zxXVsrROr5lOSRksSSccAZxzz1FIkOAHUybxkgIBgj 17enTpTT1E0jOs9RltRsKSW6wIAheIkYwOuO+AeRnPr1q5b6nGznZcW5RyQOS2MYznA68/z/ABfc YEmHXerEfKDwD2IHVecDt0HtVDUEjkeZGkkyzFMg4JJ7E/QDvzStcDcg82aXZHdWr5UAorDr+Xp0 44GPWnm01LP/AB9WfC7mMmOODx078nr1rm1sgi7YmkBkmXL4DN0x1/IdfWpVmvY13NqkrdTggkIC MYPp1PT6dKVhp9zpZtO1JJAY762U4BVlJwWxzxtAx/8AqqAaXqBSdnubTkHaefm+pKj0NYsV/cxR DMhYIpw5clmG0Hpz+vXHenWWqzuzhpBIqsUVyhXaxzg5zgZH+FKzRSNtLK6aLi5hOAMJyRkDnt9f 6U5raaWMky2Qbgs3zqB3zyp5/IfhWfYT26ylQUAbgYYkk8dSe2ee36Vo+daPGNw3S7dx9vU5Hv60 XYFCXS7kKYmvrPew3E7CdrjODjHPXr04qT7FfwyAJfIyAYOQSQAPXaQDyM4GevtWjFJarEnzjAOS Qc4/M+1K62siqXwzAHPJ3Y4/i/LtxxSEymYV3qouckDJ2MCQOwwV6Y/n+FSG0vI723KagjQqCsgA IPQEEZGM5HXt+ORNHLDKrFmyhJOSWzj5ug656/XtT2hQj/WD5QQ+Om48jp7dKAIXjVTukndiSq7t yjPoOUPXP8sGmSQx5G24lXgLh5VAAzzglSOcgduvXgVajZQMFUYqw2hiRj04pgeMEhYYyRhvnGMN +XPPekAyCCNmZmuS4ICnMhww+u3J+7+Ge/d6RW5jCpeuxOSrAjafUdPr2PT3pyhTvbKkNjG5QOfy 56dPr7VHPu3jyzgFhtLfeAyc/hmgoje1hkLLksoBLFWHPGMYAHYD9enFSwoihmdmZQDkEEgjPQen bpg8daVXBAIb7pICnoTkr/PP61HOZ0jZA33iCdp5A/D8efpR0sArCxwQ8OQDkE7s9R6HvgflVd7K 0EnmW9uuSAMfMBgE/LznOMkj39qfI88kZjkcvHt3cjB4xxn8B9M/k17i4Ep2kYP3s85xkZ575yfr +VKzBsz/AC3MyRs9yMKCyOm1MZb5gcf4jv1pzzXEIjiLRbtuMEDr1BTB9/T/AOu2y/1a/wC5J/OO kv8A/VRf57mnYVxrSybiMMArZVSRySe/X14+noaSOQFUVWTjAymSSR2zn8eKdd/68f8AXNv5tQ3/ AB+Wf/XL+lWkJEazBDtL7GDgZZeeuc/j9KdmSVU2OwBGcbM7VGMZOepJAz7darj/AF83/XNv/QzT dF+6n/XvJV+YnoW45xt8sIQ/KsxO4sCc9sjt0H/6nZCqFkIZF4yDngE855NVn+4f+uy/+gvS/wDL 1c/9fLf+y0h2940PtG6RlDDeRyOSScgnH+fSnGR1jVQg7bsdQaoL/wAhWT/eWra/6pP95qhuzAll mQytCm9SABuROAT0yD7Z5PHB70yDZ8yRjeIsFm2gcYA6j+Xfr2qkfuj/ALa/+y1taf8A8gtP+vlv 60A9CqilXRt4B3behGc9Rj8R/nNNuNwyxIZccsRyMj1/PFOl/wBdJ+H/AKC1RW/+sP0/9malclO4 5mYD5QQcggdTwPzHr/8AWqCV3R8ZlCq+4mM844O3pjjI55PBA9p4vuWv/XVv/ZKzbn/kHS/9cX/9 mrSwnoaEMhKqY0HlgFVc8cNjO09cdD9R78qjSN85EYIIA3ckfie3HWqfa0/7a/8AslWtR6r9Yv8A 0JaOti7Di7bzgnGMMcgbucn/ACaDvxhopeeuW659D9Sfy4qaH/j4T/rmv9KZbfcH4f1otdEW1Iow sYcphpWBMYkAI6nI4Jxnse3frgPEZ2qQ6om4qFDABeOOB2+vvUE//HrcfT+slR6R/q4Pqv8A6CaB pXLUaHZgwZYt8jL6cE89h3xTyVLfKB823/eGe/B6f/Wpif6mT/rof5inp1l/3R/Wl0uJDvmRv3ix 7gfugj8Oe3SmNOtwXhOVkRefk5OB9R1yevr3wAVk/wBZJ/ur/wCgmnn/AI/Jf+ucf/oD0DuQS7dr OYmPJZQSSOTkkEjrznj+WKc4J+QMWIIBJHU8Z78VJd/8tP8Agf8AKpYf+P8Ag+kX/oRpxAqOFDbc AFuFx27YGDx/+uo3ztDMemcDHGMcc8/pT3++Px/nUs/+pn/3KHuS9CNXRgzKYyu7LAyFcKOcD0JO OvQ5NIyGIKpUlVUBVYZCgYGQP606y/1EX/XH+hoj/wCQgfoP5UDtoG/ziu9HRl+6SQM/r09/fvmn uxyJCEYk8kEkDFSw/wCph/3l/mKrp/rpPoP5Ul3FsK8TOd7bTj5SWOcdKaISQUCu0YUO3AONvPTP OGA9TkUsf+pn/wBw/wBak1D/AJCVx/12P/oNLmKW5Cx2vvMaKSMNl8kE44xnr2/D1p0zNMdjQkA/ MWIwM44A79SR/hTNT/5afX+gp+kf8gkfRatK4LUR/wB2wQs2PQnqfx7Zyce9QXO+NMr8jlgQwOQD /jz+tPX/AI9F/Gkuv9TD+FSNoz7ua6YvEkgmQSbcFeVyRgAnqAO3Q4p0F20kiurl1XBH8QYnI9eg 59O3vUNz/wAed7/13j/klM/5ZX//AF8D/wBBqkhW0LEOoJIuwOWcjBBb7p45GT6j9aglaOfoj438 hsNzjg8c9MflUVh/q3/3z/Op5vvP9R/7JUpiTuyE2pkhEiliODkMAeo6HP6/yxUcsSLcIG2xykhm YAZJC9/UDJ7c1I3/AB9D6H+QqWx+8P8Afm/9DNUHcreY8SyGNYlVmGMcZHvxgnHvyKe0l55jN5qm IqVztHHPA74P8+nHSopv+Psf9fTf+jZKv3f/ACET/wBdx/6CaHoV0RBDd3gcKFYqARlQCD35x9Pr UsM9ysTDLuFAJypOOR/9b9KhT7z/AO5/7IasQf64/wCexpNCTbJV1GTBWfIVB8gYFW6jPOeRxkEc cfnZk1rCIsf7wKVyTIDtPOMLnOMEe9Y97/x6P/12H8zT5ei/7z/+gCpt1FfWxrPqjDy1VwuWyWAJ zjrj1yBQdYXlROj/AMXJJGPf9P5/Xn36N+P81qHWP+Q5H/vf+yinYo6ZNbVdw4cqCc+o+nUfTrUk GrCMsjbDxzsBDBsDAGOeg9P5Vz8H+ol+h/kKtW//AB6Tf8A/k9DSC9lc2hqDSsZYjllXLEsCc4/P rmpDcuAmEOT/AHRnbj1Gf85rE07/AF0/+6n8qvW/3R/10X/0KlLRjTuTTXEweMAs+75iuOB0oN1L 8hbBZjtB6D8fy/8A11Fb/wDIQ/Af+hCq46mla4+p/9k /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcHBw8LCwkMEQ8SEhEP ERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcGBw4ICA4eFBEUHh4eHh4e Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh7/wAARCAEhAd8DASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDy+/4y O30rN2kEjJPetW4AxyAT1rPIz0GeetfMw2PVmRjn2x2NRXVolwgV1H1qyi5bkZ9AKsBQyjArS9iD jtQspLeQkrlMcN2qk0eMd+T0rup40liKyKWXGOma5zU9KeEmSIMydR6itYTvowuZKyNG4ZGYMpyD 3BrrNE8QQ3arZ6owDdI5v6GuTmUjgg5A71EdynoeOatxUkDPR54ZbdyMsNw4ZehB9DVY5PTA9sda x/DviXyolsdUBktuit/FGfUV0VzblVWaJhPA4yki9KwcWtxXKYU9BQhwQ24ZHaptp5yBz1qMqOc4 9qQDpCSxYnJPvUkcZMW8EYzjGeaZyc8AdKf0AUMPXNIBUQlsgn8e1TyRKrgl1KgjkUyMqQMHB6E1 IUUEHGSOSTRYLl1nRbYxwxBefmOepz+tULjeyqGbJB6YxirH2hvICEnaGJxnuf8A9VVjvZjnnJos JEEhdmBJ/WnqiDGBkiopCQx3A4zUtsTnOOOhoHctQRgc9asCNdq4ABpLUNj5Fxk96vRWuUDH1wQK diWyuiBmUt1HAq0bZpHGFwAeTn+lWoLdBHnAAz1qfZEmCzE45+op8orlc2q+ScHtzzVZ7R+cJtFX 2uSFZY1AJGAT2qF553QLI+QD6UWQFMwALyS3sBSPG2BtRR9eSKnyw6VJBHkfMfakkMqxwuW3cjPX NXYk4+VSTjFWoIY+4z25q9DbecdqrgH0FUokuRkFXDD+H3qVVDIRyTnOKs6lFHA6CRh1wcdatx28 JKGKNjkZyaajqHMZyg42heR19qmhBCtvwQAc9zWtHZw53yEAjrToUXEm2Paj4yMdfTNX7MjnMuK3 E3ls0SghQvYE/XHerqWqxjDMFGcjFTeQzjAfavUcYqeK0hxuZskHvVKAnI8j8dQrb+KZtnCyKsi8 deMH+RrvtJTzbOx1goCJbVFkcY7DbyPqrVzPxgtRDf2F4q4DxtGePQ5/9mNdP8N5Eu/B0ULncVaW DnBwAQ4P5yn8qXJ71im/dTOp0q2G/DdB17VbntE8shJCB7DpU2mANHE8ka7ioyexPQ1du4S1mHQg 5bBAPSumMPdOeUtTnTp+fmLf/Xqve2JS3AVgFXJAI5reeJsBVy3uBVW40y4us5cIh65bmpdPyKUz O+GF55fj6xgYgsS6nH+4a95z+VfNUULaH8UtJWKRvJF1bnfnHDttP9a+kxnGa9DKm0pwfRnNjN1J Du3oK5P4lQiXT7d8DIkIBPuDXVjiua+JCsfDjSKwXy5FYkjPqP616GJV6UvQ5qXxo8tvY0TQnZvu LdTKytwTlUx/WuYszEYDCwUsrEjFbet6iLjRdRXao8u5hbGOmVcN/wCgrXHLN5bb1JDdx7V8vVa0 sexBaM9A8PCKPVbRjtDoytk9Bg10/wAT/Dz2V8PF2lR/MmPtkSjhgOj/AND+B9a4TQr1pkjlzg7t uAPTFe0aZqsV5b+ROgMciYweQQRyDXfg1TqQlCXU5a7lCSkiLwHrK6tYb4wfkAD9wDjpn1roixdi oyMHk153o9rregaqNBtFSPSZpTLFdKMkIWxsyf4uR+AzXokahECgk4HUmvUwjly8kt0clZJO62Yu McEmlzzSfWkxzu7n3rqMh2eMDvSEnOKO1NyAcCkApNBbtxSE9qaTSGOzz0+lTQSYbnFVd3OO4pXD lSEfafXrihOwj47u8eUvGDjPFZ+M/wAXP0rVuUjA+YZPQ1nyRDcQoIr4uKsfRSdxirt5LcfXpUwK 7eetRmMDrkfWpTBuGUIYHpVCGEkjqQKV1DEoQCPcdamWBWP0HenPFgjOT7U7COa1nSPMBkt+GHVf 8K5yaFkZlfINejrHkE8n0xVLU9AS9jaSFMSjkdga0jO2jC55+y8cZ9uK3PDmvz6Y3ky5ltH4eMnj 6iqF9ZzW0ximjKc9xiqmNrYHP1rZ2kgPSRFHc2y3dpIskD9+6/UVC6dhzXGaHq93pU26Ehkz8yH7 pFd/avZavaC605iHA/ewZ5U+o9qwlBxEZ5APc1JDFkgKST6in7BuOTzVi0CjBO0HdkEdakLjo7WX gY4xR9nkC7iDjHpWgJ2jf92cKPlOO/XmglpSxJwD0HpSFcz9gGMj605UTluntVtrZncbBkZ5NTrZ FYTsAVj1zTsFzEvU2qcfXpUek/PcbG59B6Vq3enlbeWWQOfLQttXvgVzOm6jJPq8KxRokUD7ZXGF yD0JHXg55pqIXO9srSNoztcFhjj/AOvVkQRRx4DBsEdOgpNPTy9rYBXHXrVlsTHDADJ6DjFUkRcg JUpgDaDz0qtK43kZDbRirItFbhXPHbNILaJDzgn2HWk0NMpKsjE4BGe+KkMGGIfIx+Faawr5Q2pj I44qM2cm3g9O56UcormcyqvCinQJ83uTxxnrU0sKx8Mc5/Wn2jc5Ren4UWGXLKyeQ527R6nvWosD RRbFYZxzj1qhbb8gksR/s9K1LVpGHl8hexx0reCRnJs53xRb3Vvpk96sQYRKG2jvz/KtLw9OLvQ7 W5K/M659fyrWudLttQh+zXhYxP8AeBOOe1VPClsLOwuNPGBNb3Dwgcfc4wwHYEEH6k0+S0rk890S DErLuU7B1x3PpU4hZ/lAC/hVry7aKPDbYwPU1k3XiLRbObyluRPMeAkI8xifouavRbk3b2L0Vook +bJ9BVqO0UKSQPeuebWdYmkJ0/QbjB6PcusY/LrSofFty+2e/sbCMf8APJDI305wKSkuwOL6syfj LZq3hmCdVyYLhSxxyAQR/PFJ8DJlmsNSsioLRyRzfRSGU/rsqbxjomoT+F76S61m6uFjiMnlFEVW K89h04rlvg7PE2v3OnSzSQx3tk8ZdHKsNuJMg9vuVL+NOxotabR7ISttNGXYeUzYI9D2/OtSURrE CF3DOcVy/wDwiVqWLG71CQdRm6c8+tWbDw0Z7dWg1TULd0OGxcE4I68HNdCU72sc75e5tvdbGMYK qDjIFRB41OCcA965+5u5fDMudeuVubFm2pdrHhkPo4H8xWHqXj2OeY2Hhyya8uH+VJWG1Mn0B5NT Koo/EUoN7GR49nuU8UWOrJzEl0FiJ4B8sg/+hb/yr6jRgUFfOXxI0iW38DW0cm157KZGlkToxJKk /iSK978PW9o2nWl/CuXmt1bzGYsSCAcZJJxXZl11Uku6TMsVZwj5Gmcg4rH8Zru8NXnBO1Q3Bx0I NbOOMVQ16IS6PdxsSAYmPH0r1pxvFo4ouzTPnmaFmtNUAIbfCkwweMiXaf8A0KufWJwrBsdOK6yf aE1ME7WNk4jU/wDXZDgZ+v8A+uuYWV2X51x2zjj2r5Goj24MfpN0bebYzMoDg8dK9n8Ozm80+KWE HawK8HPIrkfhXNpDGe21iS1jgmtzGFmwFdiR698ZrY8LpcabOdLGr/YTDdZDFA3mxHBGM+ue1dWG jy2lfcwrPm0OvZb+3+xNKpkhadOCcFeetdX261T1BY5LLdI4VBhg3pg1YhkSWNXjYMrDIOa9+nBQ drnmylcf2yBUcwkYARyBPXIzUh6+lGcVq0SNYEptyQcdRUFrZwW5LJvJYkks5bP51ZGDikfJXA4p OKGmJTexz1oXIUAnJ9cUHGaQDejlh0qReaZnnFSLkcg0ID4/lD+g5HeofLHGW69xWtsCbiqhyRgE HpVVUXHzkhSeeOlfGI+gbKaQgvnOcdQasCOIfMRu471JHHE5/dzIwHvirxt+MBQwHOQOKolsq2ik PlRkdcEfyp81mVkJ24VuQMZ4NWlgYHCsoX261bKqIwdwbHGKpIm5mrp4JAUEj1zVmO0OwbjtHrU6 uQmwIMUwnIKMSB0osBlaxotpf25SVcsPuyA85rzzWtIuLCco6krnhgOG5r1WNI0yF3E9BUV1pqX0 LRsiMvcHqKabQ0zxqSPnI/WrGnX1zptytxauyMDnjv7V0XiLw1cWLNIg3Reo7fWuaeJgRnkjsK2T TGejaTqVl4ijG0JBqAHzxjgSe496kjaS3uNjxDKkhkZemRivNbeWW3nSWFyjqchl4INeieGPEdnr QWx1bbFfZxFcDgP7NWcoW1QmrF6Jd3JA/wAK0EhjCjc4P48VHNDJbOY3Qq/b0I9aRDvbDKc1mIsB o4wfLwT6Z600yMSPm78elWba18xOwq7LpiIQd4PGeRVJMTaMhi7bkLsQe1eQFZbe+MT7laOQjjtg 17q1nGPuqTj2rx7xlbm08U3sRX+PeP8AgQDf1q4Kw4s9E0uzleNpdMuZLaRCRLbS/MgYdRjt+FbN peQqRHeQtb3JPflD9G/GqWi2k76fp2uQ/OstugvVPG4Y+97kH9K6drK1kULKscyHkKRkURgyJSRA 0e6IuowMY6darNGVwEjLMB3q21vNAzGzc7D/AMsnPA57Ht34qSOTDjehjkPGG5H4Gq5SbkULT7AH iC+5FNeCbkOMA9CavRktlmyGzjpxT0gJctIzMw4wD61XKLmOduInjDFhxn61FYs7ygD5RmtzVISk DE7VAHrzXFwajJDqQO390HC88ZycVlJcrNI6o76yiCIBsJPGTWiiO0RKjb6H8aj0vzZERmi2pjni tY4jt23AA5rrhHQ5pPUzAjxhyTuPbtk1De+HRqBFxM8sFwAQJYZChA/DtV9NzSeeEOBwnoPU4qWO Oebgc8/hVcqejDmaOXl8J6SHP2me6v3Bz++nZh+XT9KuW1pa2ilbS2ihXttUA/pW6bMu5yASM7go oW2t4v8AWDJPYCl7Owc9zGPnyvtY8e45IqeGzlLq2QMcfStbbGZP3aKvPDEVDdq2/JcnHYcU+TqH MQXljFPYzQySFlkRlZfUEV4T8PZ303x1pqT/AClboQyA+jHY2fwJr3VbiUK0aFhnqB3rwXxcj6Z4 1vgoIZbgTA+hYBv61lW2ujWl1TPb7rxcVuGt7LTtQvZIztkMUGEDDgjccZwapR+N/wCzrsrfWVzb CcDEYUMwPToOvHp6Vpzabcaz/pKarc29vcgSqsIVSFYbgM/Q1Pa+GtFs1Jgt1M5585vndm6jLHnr WtqkndMyvBLVHNwmbxtNILk+VpkLjNuSDJKw5Bf+6PbrWroHgXStPKBLdJmSYzK0gy69MAH0zjit uWygvYEubOI2t2FISRcBlPQhuxGexq/4cu7i6eWG8SOO8tiEkRRkHqQw9j/SrhSTfva3JlUaXu6F LxnpIvfBWqxqmXFuzDHUsvzDr7iuw+Flyb34eaHOWBP2REODnlflP8qhWMOjRkKwYEHPSofgqjW3 gSLTmHzWN1cW7f8AAZW/oRXfh4ctZPya/JnPUlem15nYkY7VHOA0TL2IqfH51FL37V6bWhypnz1r MLR6hcr5HD21yoHoQoY59xiuRvyLfSLo8SFRlCSQQa9H8W2Xla9iNyoe7kg47tIjLjv7dfXpXn+q pjSnZSdu4c474/z/APWr5GvHlm15nt0ndIwNT1KaLSrSWKVkznkDoeMfyrS8MatrusapDbW01xeX z4jTzHyVHTgnhRVW0sYL3Qnea5SN7UK8aPz5rFgu38mJ/Cug+EehaR4g1PULGYSB0g3RyRuUZDuw elYwi5NJdTSbSTZ7xqrbPAUaXs8SzpBGJSHyC4xnnvzVvwHdx3nhyBkfftyp/OvIPEXw1uNOsZL+ x125jtbdGlliuW3ZCjJxjHPFehfBlk/4RwRqDnOeete3Rqz9vGMo20sebOEfZtp31O7K5Oc9vWmk 89KceBn+Vc9pni/RL69u7QXSwzWs7wyJL8vKkjI9uK9KdSMLcztc5Yxb2OgXilJrI1XxFo2lwxzX uo28SysFj+cEsT6YrVBDDIOQRxTU4ydkwaa1Yi5KBiu0kcg9qT/OKceO9IfTFOwDcc09eoHWmcjA NZ2vazFo9uk8kE05dtoWJcn8alyUVdjSbdkYup/DDwndRusVrLaMf4oZj/JsiuW1L4NRtn+z9adQ Bws8Ib9QR/KvXWPX61HXPPBUJ7xNY4ioup4NefCjxFa5eGO0u8do5cE/99AVkXfhjxDYHE+iXcYH 8SIXA/FcivpEClK9+tc8sqpP4W0arGTW58tt+73KytnuCPSpbdFkOWQqCO1fSd5pWm3wxeafa3Hp 5kKtj8xWJe+AvDNwSwsDbtnrC5XH4dP0rnllVRfC0zRYyPVHhn2dASAxAPqKiNtIxyFJGevrXsF7 8MrOTmz1GaMn/nqgf+WK5TxJ4E8Q2G37Fi7QjlooySPw61zVMFWpq7j9xrDEQlpc4vyZU4LBR7Dm mLNJb7mHzMRj3xWrc6df23y3MLwk9nUg/rVc27EMFjLADkt1rlcWja6Ma8NxdKVZFSMjGOtcfr+g BVMtsmT3UD+Vd9cRDO0n681TktWIwAc9qnVFJnkU9uYzyrA55zUOSrKRkEHrXo+t+HFuUMkIAl64 9a4u+sZYJDDKjKy+taRncq51XhHxiixJpuuHzIOkU2Pnj/8ArV2nkxwASxkT274aORcEH8a8WMbK TxnHoK6zwL4uudEYWl4gubCQ/PG3JX3X0NFkyWux6NbSQs4G5o8+1alrBasQHuV56ZbrUca2F7Yp qGnFbiBsc55TPYjtSQrbiVd0W0DGADxVJWMm7l+a2giB2OrEDoK8a+Lto0XihJ9m3z7dWOBwSCV/ oK9a8neC0M4Q45ByPX8P/wBdeY/Fu1vw1ndXRRkUvGjLzkcHn9abHDc7b4YZu/BVopYN5ZaMrn/a JA/Iiui0+wezmFswC27f6kg9P9k56cdK4b4ITh9JvLRm5jkVwc9Nwxj/AMdrv7m1unAQvjJyPw6V UVpciekmi01rbxvl5ATjofWoJ0tpGEflqwPUZzTrTTJpyPOP70HDBun1HtWkLKO1chRkgnlec+9a KLfQzbsZsdq8QBgVtmOVkPT6HtT45EYiGXcrngBhj9e9arzqoCLEckDJPaqc2Zco0KlSc4A6VXKl sK99yvNYWM6FXDPnggGvCvG1xHaeMbsWLhohMAoPVNpHf6qfzr2TVZb6wtWNqGaV22RIwyQzcDHr jr+Bryb4saX/AGbqtl5MMqRfY0RmZerqTkn3ORWNSz6G9Lc9ysC9zZwzQbVikjVwB6EZ/rU4ikuH EJ+bacu3972rG8AX63HgbSHiG+VoBGN3Rdnyk+/St+zljRM+a42kjaR156/j1reFmkYS0bJYrY4c spI9h3qwTFGcAYz3zSPPGRlJQueue/tTWa2RzjLLgnOOBWystjMjMxEmV5GO3FMaVnjwUCk9Djk1 Y8rzMBQxB5J6VJDYZwzffzkgCjlbC6RWgi3BRvYjqQeKiitJj945B461qixlQHofoOamS3bGCnt0 qlTuJzMqW2jST5wxPXI6mvDPjlZ/ZvF0Vwse0T2ysTn+IEg/pivow2ofCkDrya8i/aM0jy7HS9RR cpFI8LNjruAI/wDQTUV6XuNmlGfvpHUfDphqfgvSbhhk/ZQhPuhKfyUV06W4C8ISR3rhP2db5Lvw xLYyOc2dwwAHo4DD9VevWP3KgbUAIHJq8NBTppmdZuM2jCtYJLa6dXOI5v3i7ugYDkflz+BrO1JP 7A1O18QTCQ2sieTfgdYsnKOfUKWYH/e9q3NcQ3NmkcKZkaQFeeOOTn2IBH41cWGDUrHE0W+KVMMr 9weoIrX2afuohTtqy3C9u8SyRkMCuQRyCDTPAkQtrvXbcFQrX/nog6gPEmT+LB/1rjZr258CgQyu l9ogbCAyj7RbL6YJ+dR27getdJ8PvEWieINb1SbRrs3ASGFZSEIUHMmOvXr29K1pVU6kVLRomcGo trY7bGKhuOR14qU81E/XmvUZyo8W+K6yWmsTzxDaUkinXH8JB6n05+n41ykGhya5qWp6fbyrFCmX 3YyME/KOO5FetfFfRFvNEuLyFoVuFiKYkcKGHXAJ78e3WqXgXw6f+ERsZ9qC4uo1nmJP3iyjGfoA P1r57EYVyxDXfU9KnXSpJnnGl/C3X2txGs1o437hl8EjPpXQ/C74d+IvC3iu61K7+ztbSxugWJyz ckEdsdvWvVtOtPsoUNjd3NaQYV0Usvpqze5nPFTd0edfF2x8QXfgq5tNH02a6uLlkRlQjKpnJPX2 x+NYnwgh8T6TMIdS0y9t4TkEPEdor2ANnkZNKAfSt6mDjOoqnM7ozjXcYOFtzjfEnjq20hm3WV84 XIb/AEZ8fUHGMV4preqaT4v8dwNb2jWkZYmXbFtaQk5y3qa+m2jVyVZAR71g3fhDQbmdp2sljkJy XQkE1nisLVrKykXRrQpu9jz34hW+geHtO0u5s7GOee3cSLbg7ixHqKgtPitr88xi/s22tztGBKGy PwHP6V3k3gTQZ5A4SdZNpAbd0yOvIrP8LeHfDPgi4d7y7k+2zZ/0u+cASeynpn261zyw9eMrxaij RVKbjZq7JtIn8b2pXU9Ta21K1kjG22tlKSKSRg/MB712ozty3BxXNav478L6daXM8mpwubcDciHJ JJwMevWsm4+I2kXeu6bpGkzNdyXcih3hTeEBH6ckZPYZrrjVpUVrO/4mDhOevLYX4reOrfwlYpDH skv513RoT90Z5Y4rkvhd8Q9W1jUbh9TUy2+3g7Pu+lcR4z0PW/E3xZOmtdLqhikWOSaHJRI92cN/ dIGcj2r3Ww8I6bY2gitIFtj32VxTlXr1nyaKJ08tOlTSerZ17nmkA4zQ3WkBAODXsI4BxGKB2xRn rRwM8c1Yhy9DSEnrSg8ig8d6YDQe1BFKPpQfTmgRFJFG6FZEV1PZhkVk3nhbQbo7pNNhVvWPKf8A oOK2+KQdOtRKEZfErjUmtmcXe/DrSJi5glmiLdA2HA/r+tYd58MZlJNtcQTezbkP9a9Q70uecVzy wNCX2TVYioup4neeAtWgJJ0+RwD95GDfoDmuc8SeBkvIwt3G1tKvRipDD8K928SeKNB8Pxb9X1KG 3J6Jyzn6KMmsrS/iD4I1mb7LBrloztxsnUx59hvABringsOnyqdmdEcRVtfl0PkrXfD11pdwUnUm NidjD+L/AD6ViTwlAxGDkdRX29rXg3wzrdsYb3Srd1PIKDYR7grXg/xR+DOpaJDPqmgSS6jYgbpI yv76IepA+8Pcc+3euWtgKtJc26OilioT0ejPMPCfia/8PXhlt3MkTYEkL/dcdxivWNOvLPxHbfbd Hf5wAZrYn50Pt6ivErmEoSCOnbFXNC1S90a/S7sppIpE6bWxn61yJm8o31Pb7S2ujIEMWT9azfH3 h+5v/DrxuMlX3IpP8RBC8/XA/GtLwV4ttfE9ssfmJbaqow8R4EvuprT8TWt9Ho9w0kZURKJSM/3S G6/hWvInG6MOZqVmeX/AmXy9XvrR9uGh3Nu9VYY/ma9fJt3wEiYH1UYry/w5ZDSPi5eWkSrHFMTI voFZScD8WH5V6tLbhU/1g3n0PSqp3sFXe5UnJUho52Eq9FI6j0p0T3Mnz27llxlg3p/n2q0mnMzA Sc5Hc4/lUq2Edo+4gujkAheACe9a8jMuZFOK5eaTa8ZXkjgZ/wA/lVyQIigiFycYGelWgqxrtghV STy2aiuos27SOQyg8BDyT2H1J4qlFom5TZxcXeHIQQDA7/Mev5D/ANCNec/HWwkFppt9A5BinaNn bhQGXcc+3y16VbaTOqqBAJGP3yWwGJ5Jx9a5z4yWM+peAryYlVEWx44oxwQCASfwz/k1E4Nxdy4S SkjL+C07XnhV0iCCO3uGjA6N0Bz7ZyeK7+GwknbMYAAwSrfKR715p+zJcxGXWLGQ87Y5UB69wT+o r3CS3ilACopbsT1H0q8NT54XFXlyzaMRNLLMB5ZPqe1OfTyJBudEPsM1riC7iAUN5qA/d/iH+NS2 8Ecm5QnzdSCMH8a6lRT0MOdmPBEVYncxx3Papxau5DK5GOea1hZp0HSsnxN4k0XwxaGbUJ0Dt/q4 kG6SQ+gUf/qqnTUVeT0FzOTsi7awSKF3n8TU081rEw+0XcMQPTewX+deJeKPiT4h1fKaey6NY5wG XBmYe5PA/Dp61xYv2kneaaR7qXJJmlfczfUnNck8fCGkFc6I4WT1k7H1RCbZ4y0BSQeoYHmuA+O1 qbvwFdbowxgkjkGB052k/kxry7SfFl9pahrORY3zlnzwfbjr+Oabr/jHWNYspoby/kkjlGCv3Ux9 KmePjODi1qOOFlGSdyz8AL+PTtc1W1uWVY/IEpJ7FG2k/k5r1O9+IHh22BKztcNnGI1/xrx7w7aC PxXpzK2ItZspYMjtIY2jx/31g/jXKz3bRu2R83celc8MROnC0TaVGNSV2ezax8Vo43VtPsUyoK/v HJ645xx6VxmofEDXr9XhS6aGJiWZIhtHJyf1NcJLLIxHJA+lOR3Bzz3GB3rOdepPdlxowjsjYvLs 3SZuZpJATzuORXrH7M072uranauFSG4hVkYjG9kPIHqcPnHuK8UhBkk56HtXoHwumittRl1CSMul jazzsfMKn/VkYDDkZyBmjDzcK0ZeYq0eam0fSmqazpWmKDqGoW9vnkK8gBP0HU1m2vi3Qb27gtrK +WaWYnaqjBAAJJOcelfN/wDbv2lp5SgDu7MmckgE5wSeT+Na3hy5nk1W2nXcqodw2HngV6Us2m5e 6tDkWCSWrPbvHccOq+HrrTlmiHmDBLcgD8KoWHiO1sdMis7ewuJPs6LGFQcYAx1PWug0K7j1CxSV lUtj5unWtFLaFR8sSA/Su/klUaqRZy8yiuVo5RfFE0khRtKkjx/efH9K6DT7ie6hDG18vPqeKuND E4IeNWHcECnqoVVCgADoPStIUpxd5SuTKcXsgRT3Ap3ajrwaWt7WIG5HWk7e9DHg4NNdwD0z6c0g FYntUNzDFOm2aNHX0YZpxfoc1FJJyAMnI7VLaKRyWrfDnwxe3JuTbvBIxLOYmwGz1659aseF/B2h +HLya6sEkeSUYPmMDt+nFbcs+FYc5/nVcu+0Miv78VyOlSUuZRVzXnm1Zsl0610zTt4sbSG3DnLe WgXJ96nluo16ms1mmPLFEHXlsGq1w8QBaW8RRnoP8abqcq0Fy33OrNJjnP69adnFAHaupGYDpSZw cE8mnGkHXtmqEOHalOaF6e1B47UxCDpQ2fSlHNJk5oAQ96MU6g0wGjGKy/FP286PONNmjguNpPmv 0RR1P5VqkDGMV5b8T/FXiLSJrqOxigSLlI2mOd2QM4X06jn37Vy4qrGlTbl1NKUHOVkeEeJru4v9 TlZjcXTBiDITuLVkTGK18tmU7n5PzDK847Vcv7rXtVmlkJiVWfLFAFjJ+g4/SoG0O9dd000Tk9SS c18se30PTvhX461LwzeRW2rSXU2jy/LgrvWPPQofr1H14zX0VazxXVtHcQOskMqB0YchlI4NfGdr HrFkgUMJYF5wshBUf4V9X/DYaj/whunDU1gWQwr5YiOQI8Dbn3xXtZVXm703qkefjKaVpo4P4t/C G21zzNY8ORx22oEEy24wqTH1HZW/Q+3JPzfq2mXdheS2l3A8E8TFXSQbWUjsc194Ee/FcP8AFD4d aX4zsWfalrqaL+6uVX73+y/qP1HbuDrjMuUrzpb9iKGLcfdnsfH1rPLazLNbyNHKrAqy8EEGvf8A 4XfEHRvE9ifDfixIYrx0MUdz9wTAjG1iOje/Q/Xr454v8M6p4Z1d7DVbVoZU5DfwuvOGU9xWGCYX 3jIYdMHpXkU6kqUtvVM7pwVRHuWo6ZL/AMJ34Qa8haKWaNbS4de+0huvr1r2Y+GrWP5rchcd3UEn 8a+c/AvjaK5Wy0zxFM3l20wltrsffhYZHPqMHFfUljdQ3drFcwSLJHIoZWU5BFepl6p1Oa5xYrnj YwX0a73/ADIrr6hhVSfSbglvMQ7SORjiuyo7dMmvQeFgzlVRnDwaa5IhmOcD5e+Rn+lMksd1/HEi iOGIeYwCnkk8D07E/gK7Z4o3OXRSfUjpVd7K1XzHH7tnOWbPU4x3qHhEtivanOLF5lwIoUyqn96T /If56fWqPinTvtvh3ULDYC09rIigDuVOK6uDT4UQLHIG7k9yfXipWswF+VQTjFT9XbWoe0sz5j+A Z+yfEV4lTat3asACeDgg/wAxivo2KAg7pNq/j2r540+A6D8S7eAiSJ7DWWtgGGD5Um4of8PrX0W1 tLIoyDj61w5f8MovdM6cV8Skuo79yF+Xt3JxUVyUdeV5HRh1FSraBeXJAryz4jeMluzcaNoV75dm mEvb+JssSc/uovViBywPArsr1VSjeRhTg5uyJPGHj1oLm50fQbqKe9jBV7mRcxwN6H+83sM8jmvL NXnS3ddR1OVri9lYl5pH3NI3oOcY/QVS8Q6zBp1vCltEsewYihQ/d45JPc+prlF1C7aV5Z5fN3n5 o3G5SPoeK8CrWlVd3senTpqC0LF7qUt5IS7bY85VV6U1bgsgQYGB600rZ3AxC/2STI+R8tG30PVf xz9asWunuI7iWZSphi8zAYYOWVQQe/LA1loa7DEkcYUnjufWleV3+Vc47n1oiClOh3Y9KkgtnMhZ yAoBP0qRnT6Tfquh2F0Uf7Ro+oxzrjoIywLZ/EetY/jmx/s/xhq1mmNqXMmwHspOV/Qit74cW6Xl zf6TJxHfWkkSsR/EBkEe4Iqj4+ikudT02/AZze6XBJIR/wA9FHluD+KVqtad/wCv61M72nY5dIXJ 6dOmKmhiUoScjFSuoj+6GBOAMj1HNMJJxtP8Jz7Vnc0JoRtxsXn+9ntXSWWqRWPhXVbVDiS7EcKh c9N4djn/AIDj8a5y0b58OM8VsXN1p9v4Qmt2gjlvri6XZIc7o0UZYjnjJKjp03fg4fETLYzLVscD qTk5rf0m+lVkQtgGuXiuAJPmzz6nPNXYbk+YBEdwBAH1qdhtHt3w/wDFkNhdfZbyZRbk8sexr1y3 nhnhSWCRXjYZDKcgivk2DUIYwizSBtp59vavTvhx4usrSwniN+WdRujhKNggdcYFergcc6b5JbHB iMPdcyPahzxSHHUYrK8P6jHe6RHe+fvWUswLLtwNxwMewwPfFSXWqafa5N3fW0GP+ekqrx+Jr3VV i4qVzz+V3saGaazACsVvFGjHAt7h7s9jawvMPzUEVWl8R6g7FbHw9eSAniSeRIV/HksP++aiVeC6 lKnLsdCdxBPPtUJ3E4LcVzV5d+KZgP3+m2CZ+YIjTuB7MSo/Ss6azup1Y3muapcNn7iOsI/8hgH9 awniF0TLjT8zsJZ7e3XfPcIidyzY/nWLL4p8PRzBI9QS5lx922zMfxCA4rEXSdPQid7GGR1/juP3 r/m2TVmW/t4xtCInHGxcCsJV5eSNFTRan8RSlWNlot5J2DShYh+O45/SqjXviG6fEkmnWUZPbdKw H/jo/SqkmrBgykgAVQudRYLlcj8KwlWb3ZooeRPdR33m77nWJZF/55xAIPzHNULsadbqXjt1eQnk vl2P4mqV3dsASrZGeecVmS3EjSZ3AjrXHOorm8YM9/8Aype9NA5pw56V9EjzWB7nApcD2oP15xRz jFWIB2oPJ6VgeG4/E9te3NvrUtreWu8m2uY/kkx2DJjH457V0FTCXPG9rDkrOwYx07Ume1O+lJjt VCDoKWk5o7mmID9a8C+PWpGXxEmkQsxZinmY7BiFA/z61759TXgPxfsPsfjae7nG7zp7aYE9Nm9R /NTXmZpf2S9Trwf8Q5PxLbW2i2cUMyAsVBCI2MD3rEsb61mQkeYmOxHUV0/xE0KKLUhIVVnmHmBm JOOc1SHhaax0Ca/uFliL425jwpB7j/61eBKDu1bY9KMlZMp6Td2k96iKk7qWCk44+ma+oPAgYeDN FDZyLGEHPX7gr5Z0LToY9RiXhizjB7g19Y+HIxb6Bp0PGI7WNRg5HCgV62Tr3pM48dsjQ+lI3Xg0 y6uILaB7i5mSGGNSzu7BVUDqST0FeWeLvjNpVmDHokQvGOR5z5VOOOB1P6V69bEU6KvNnDTpSqO0 Ud14y8MaN4r0hrHWLZXTrHKOHib+8p7H9D3r5K+Jvg6XwhrpsReQ30DrvimiI5How7N7V1GrfELx HrU5Rrq4bJ/1attQD6Dj86wtTBmjJ1G7AUjhQc4r5/GYunXd4xs+56eHozpbvQ4ZN0bblJzXpvwr +Kmo+FZ4rO6LXemM3zxE8pnutcHe2OHfycuo6Y7j3rOeOSM7tp9a5oVJRfNF2ZvKKkrSR9vWnjLw 5c6NFrEeootrIOCQcg+hHY1i6h8VvC1qGAkuJyOnlx4B/Mivlrwp4pv9CmMa4mtZfllgk5Vh/jW5 rFjHe2DavoMr3FsBmW16vAT6juvvXfLM61vdsciwUE9T1bV/jXf3F5HZeHdDjaWV9qGdixYeu0Yx +dcH478VebPJca3rM2r38UhRLCMMttGQwDbsEDoOi/ma46+1WbwzZxFVQa1cx72duTbREcYHZzyf UDBrl/7XumBD+UwPGCtctSvVqr33c6IUYR+FHaWfxFvrK8aWHTrSKNgEEaBkKAZ4DKQ3fua9M+G/ xvRXj07W7bZBwscvmu7An1LknH8q+fBPbzfK+Ymz25FBEsZ4bcp5DA0qdadJ3g7FToxmrSR7v8Sb y2l8fyazZnzbe+tILgNj7kkTDj0J+T3+9X0XbOktvHIuCrKGH0NfD3h3xZqWllYDILmyYktby5Kn Ockeh9xX0lL8TNOj+HOn3ekyp/aFzbBI4mOfIK/KzOfQEcZ6+nXHfgcTGM5ym7X1OPE0ZWjGI/40 +K2tLc+H9LuDFcSLm+mj5aGI/wAC+jtn8Bz3BrwrVtSFnAYSqwxxgrBbocjJHU+p9T1q9rmokxfa ppWdS5ky3LTSNkl2Oev9K43UZXuZmnmb7w4HYewrz8TiHXqcz2OqjSVONijcvLcSPPOSWY5+n4Uy JtmRjk+tTLljt4OOeT1puzJAOfXGaxNRI8bgVzW7o93JbaXPs2sJpEDxOMqyjJOR9QPesmNVAwME 1qEgW48sDGckge1JgbdnBoGtRwxWzLoWo5C5lcvbSN6knLIfzH0qe98LatpIaG/spVfb5vm8NGQe hDLwa56BwJU3gcNuwRxXffDrxDewa1Y2TQW2oQtIYY1mDZRZOGVTnoc/dIIz0AJJqo8snaREuaOq Oe0GOXSvEFnMznHmhCw6e/8AOtHxTbWq6NHcGTEljLd2cJHO4NLHIuSecbZG/GtLxJrejWeuW+re D47i3eBSrLcDzNrHuu4t6n8RWP4hurrWrV/NZI5J5lndfKCjcVxuGD3HXjsDV+7C8b3FrKzOSndH fdwBjuetRRuuxjj5jjr0xWlJpywhhJKrEHblen51XFsiz7Cwx1UZ4xWBrcrfaMOflwM9qdfANawX Akj2OzoEz86lcHJHod3H0Na4e0eyWAWaLJkneP4vQfz/ADpdOuEs3E6RxidD+7zGrj3yCMU1uJmH bW8cjjzLh1z22/1zWzpQfSdSgvrExyPGTjzwGXpg5BGD1qG5EIlASFQc44570rxl15DEZ+7nApXA lt5Wv1nt2t4TMzBjcBMFME5AwQCTkdRT9OfUreWVbTzxBFGQ8iFgUUnkYBxjJH5CptLEkJk8hzEX jZMgDkEYIP4GjR9T17Trmaawnht1kQRygqGVxn0IPOeelNO+4n5FnRl1F7i2s7q/uBBjZBudggzy B7A5+nNeqeCbC00lWa5ttPL54dYwW/E9a82mvDc21u8roZY1EWASOAfToPwxW7YalPsAklJG4Gtq U1GVzKpFyVj2NNQt9vyYBI7UG7i3YaFjJjgluOe9cVYa1a+ShmcKi9q0TqKSqPLw2e9enHEXRxOl ZnTXd2sQ2kDJAYcdiM1myayYJm8qPaW7lMCqRukLKZJAfb2omaFo+vCjjmnKq3sCgluIJvOmYs3f PpVS5QfMScEdKJp41QYkX6VRmn2nefn4yea55S7mqQpKJlipOD+FQalchQVXGDzgCm7hMNxIXJ45 zVW7jwNwGeOw61k3poaJalGd3djGOh5/GoplaLA3YGOaW5kYMVHHoPSq1zKSmCT+JrnbNUj3LRfE unahYG8MyxIGKnecVfj1ewmaMQXUUnmEhSrVUksNMiQKbWPYTyB0zT4tH0tyDHbxjb0x2r6GDqrT RnmSUNzVWWN2AWRSfQGoob22mupbWKZWlhx5i55GaopZWOnzrNDEytyDjJ4qTTrGxtrqe7gRlmnO XY5+atozm2loRZGnjNBOOvApob/9dMlUyRPGSfmBFbNkEoo+vrVe3VreJImbco4Vj1/Gp8gkj0pJ 3AXucijimHfu424pwJx2pgLgGvPPj1o/2/wNdXkUIee0RnDAchQCf54/Wu41bUbfTLQ3NycLkCi7 gj1XSJreQYiuoWQ/7rDH9awrwVaEqfUunJwkpHyRqviGXW9PtZPNkMm0JKB1BHalv9bvf7Njskvd QWCNQPJYfIMc8Dpnk/ma0PF3w88SeEc6obNL6xMjb5LXL7ACfvAjIOPwrjtT1TT7lBsYmQA5DcYr 5acZxdpKx7UXGS0N/wAORS6hrUawSyRLHE880jDIVI1LM35D8yK+moPEun6D8PtO1jW2+xr9iiJi zudm2D5FHc/5NeBfCu90PTfCPi271WQx+fZLZxOgBlYyh/kQHvwD+Fc14q8Tajqd+tzqNwzzxxhI U/gt0xgKo6Zrtw9f6rDmjq5f5mFWn7aVnsjd+KHj/V/Fc7Cd3s9OX/U2aOQMf3pPU/5+uL4Ah0zW 9ajsLyV0Hl5RNxXewwSM4PG3d71zJjnuQOG2jnHr9asWVtJFKZRlCQQCBXJKo5S5p6s2UFFcsdDt fiJcaLYLBa6AYvPTIby16L/tHuRjvzzXn13dTMwZ5TIwHUmtiSElflALAZJbvWZLAryHcy5+tTzJ u40rF7wdcf8AE3Tz8Mm9dwPIIzg8VP4xsksNamgjXbGXYgHovPA/Ig1R0RQt8AAMYwfbn/61dD8U YRcSQX6oB522Vgp7vGo/nE350aBszj5I+Txz1q34e1q+0TUUu7VipU/MM5Vh3BHcVc0PRbjUtNu7 pXVIbNC8kkhwvsAe7E8Ae/pWXd2zqCGUr9aY9GdF4i0ez8YxzazoIKaqqb7uwJ4bH8Uf4Y+WvPpI mjkaOQFXU4KnqDW1Z3d1YXcdzbs8ckbBlZT0Irq5otJ8dxHzWh03xAowr52xXWB0Po3vVpi+H0PO kjO4EHvwatK7iIyAZiJ+dP7pqzdaNqNldta3VrJFNGxBUjp71astGvWmCGF8MMEYxkHnvSbRRX06 ylu7gRRY2MMlj2Heu+s4bax0uOJoE8uP5jIzHDYPQgf5zWJotjdaV5lqiiaWV1ZlHIAGfTnv2rak ttQ1RI7UmFEVsg7x/TPFZN3YM57UbuS6mLv80aHEa54AqrITJLgR4A6jFdyvg14I1murqMoSBtiX POM9TV7TPDultYPczDdEjEANJg8DvwP09aaixc6R5wseOfLPXqBVj+zruQCSK1mkDDJKoTiusYaS mRHCispP8WcVbsb/AEu2QyuxlmbGFTIwORzke36j3pCbOLt9F1Fzv+zSKnfIrds9IZ4IRcTxxQCT a0hztVmHQ4BOPl9KuajqFxKz+Q3lqxPHU81Rtru6s5FmilIkRgQ2AenOeaG9Q1ILyyjh8uWBWYEc gnoau+HtRl02+hu4o4/MiYOpYHAIPB/Os+WaVznjnnHWhSwQHO3JpXHbQuzsvnTSKSELkqCMHHOK htrvyFYMgdWGAGzxULyKEIHPPHvUXyDuRQ3d3BBcXcjvnGB7DFM3OVUdBjnFNJBcDqAR0qSP7uDy KBjUDb8HJB9KlCAAy7gGDABec9+enbA/P64dEFJxggDqKlVU78nPc0CG+WxYuQcnk8dKljjO/nae 31qcLkgnBzgdaeqqrHPQDigCG2DCVc8845p0MTfaph84VW474/Gpoh+8yAPWprm4MNyUIXbIgY59 aBEOnrmSUOoIDcE8mtmBwQJNp681RsT5jyqhTmMMCT3FXbcbWw2AfrTQmali1uylboFhjoG71o28 2V2xuYgOhPIFYsE4GcgAkdanScK2TnjrWsZWIaN2K5dFG87yO/QfWrC3UknVh+dYH21B80gLcYwO KsRXSFflJH1NaKZDiaDSdtw59ahnmQqNzng4PHUVWd0IwDkdQc02Rl2Z75ocgSLkcqEg4I96rXN4 sRYDB3DAyM96rzSfuhjdntVGV92cn86hzsUojrjfJL5u4n1qpcXO7AIDfWiR2AIDHFUZ2weWJ9vS sWzRI9+8QeHdRv0As9VeAD+HFQ+HPDOu2E+651xpkxyu3qa6sSDJHpUN9fJbqvdmOBivpPYUlLnf 5nle0nblHw28yD95JvPfipRG3ByMfSnxnKgjuKcOvWuuMUkYtkR81QSME+lOjMh+8mKeGBYr6Uo6 9c1SQrikblwQD9aiBMcm1h8p6H+lTDmggEHI69adguJ3680oAzmol/cqfMYFeik9fpVez1GK8vrm 3txvS2YJLIDxvxkqPcAjP1H4HMk7BZi6rplnqcax3kQlVTkAk9atxKsUKxxrhVGFHtTunWoJ7mOA 4lO1TxuPSi0Y6iu3oY3he4ju4tYtD8/2bUZkIbn72JMfT58V5F8ZPBmj3/ioSyRW+mWaWAmuLqOI L5ZDsMkcbi3AA7/ga9QvWv8ATZtSu7i8t/7NmfzvMX920CBACc/xcqT+IFeH/FDXr7x3NDD4evob i1thxZO2ydmGfnIPDnrgDOM9K8fGTj7NQktUd+Hi+fmWx5/qmsRTN9msIzBZwMRbRZzsHdmP8Tnu fy4xXa+BfhRrGvaeuramfs8EiloImB3v6E+grZ+C3wtku7pdZ8S2bxQxNmK2lG0s4PVwe3tX0JFH GsQjCBVUYAHGKxwmB9queexrXxPJ7sD5tuvB0+kNMs9sG2fdI5Ge1cpLZTKSpRhyRg9a+sbrS7S6 LLJCuBxyOtcT4l8F2UFrPcwRruVWdRjPIHSor5dKGsdhU8Wnoz5zu45RK4LbQMKD1qjc2jo4BxXr WofDbV/LVre33yE5+UgAfnVZfh1qpmZLt7SF/wC68o4HckDNcPsai+ydPtYdzzG0jZb6MIiklsYz kk4r0O/0C68U6boujacim9dQLobceQELYJJwD8sjd+2PSjTfCljDetnUoprvafLRVIUluMknGAAc 9O1aPkS6XfarcWeqky+SY5rlZCRKcYKjHPHT8OO1XCNvi2FOV9jm/EMGmw2kml6PcPFYwzfunEOF uWztZzyScAfmx6dK5zUdPmuNUj86WG0iEQCjqNpYkEgZOea67SdP1LUrBJoYYlAhcZfhcBuF/Men bPU8pL4Wu4JTNdzbW2hUERwduO57/pUNSethppaXPO7y0EbspYHDbR8p5HqKz23xuHDFeeD0r1C8 8P2rIAyPIT1Zm6H8MVx+s6LPZM4CF4s8MG/mKS03LTua3h/xTBqVkuj+I5HGBtgux95D6N6irl3p NzbDmOPY4ykgYkOD0IPNebzK6E4GO9dR4T8Vy2Ua2GoD7RY55BGWj91PbvVSVxWa2NuG0lVyHuDs BztAIXPr1q5aSyRR78qCoAXn+VTeRE8Ec9tMs1vIMo45/A+hpmwAYIyOuaytYLliW/vJY/KaWUqD uIDYycetZ05ckBnYgY/iq3lSmwZBzUU65bBx+FO7AzWWQTYIIqOVP3pwOB0rRdMANVWZPmJzwT2p ARJzxjBxjNJKjA45496lVdpBA5p7Ae+etIZSeJsZXj61KsbBcNzzwKmlRlKMFOCOpprhlHTAHXnp QBCUGcbRj0zTJEAUHHX3q4qCRuOp6HpTZECKcKGPt1oApLCSSU6UqJIMjcdp5NSgkZwGO7rxSS78 jbkAetACBOygDHXBqXGOh4HWmgPnpgexqWND82SemDQAsWS3ofpTxMxcjaTU9vboeRy3WpHhCtk5 zjjIxTsIrhpN+QOKmuR5scZYBcccjmlRdz/Lgr/KlvF/0c784z2oAQfZ7e/hW0md96jO5QME9R1r RiRnEjmRE2rkqzcn2HrXOAr9oQqc4Yd+ldAq7ZeCSSvOaEwaJYpCNoIAGM5q1uVe2M9M9azZXA+7 jNP3nHJ7UwNKOQDqQc/pTmmAb5cgYqhG+Rj9Kez4HJGe/emmKxeS5BG30pyTsQVzwO1ZqNyeSBUn nABchhjrRzC5S28p8rGeB05pjTA24jaKNTu3bwPm6Yx9KqSXGDkcH6VBPOykEAYNFx2H3MqgnOW/ HrVCSQk4z09abPcDPLDI9TULPvGfT3qGUkfUFvMzrEzHa38QrC8c30dpNZqJD5kkowB69q0onjCD BPztwRUKWX2m+aRrVp2AO1mGRn+lfQTblDlR5cbJ3Zp211JDFDG8nmSMueB1qexvmnkIYBG9M5qr a6Tdb0eSZYgoICqMkZ9607bT7eA7lQlsYLMc1101Ue+hlLlJkPJI709Qepp3eiulIyAcdPSg/lSn FUtVuBFGI94RnBy5IARR1Y5/zyKUnyq7BK7OA+LHjebStKFlpK+ZqN/MbS0A556M4Hc5OB712vhL TBovh20sHcPKqAyvjG+Q8sfxJNeINo3ifXvjLZarcWU50Sxuw6XMmEhWNMldpONwJA5Ga9W134i+ ENI3Q3WrwSygcxxNvJ/KvOw1ZOUqtR26K511adoqENerOuPArK8QxXUmnyfYkWWT/nmx6jvj3rzG 6+NlmVePTtKuLggZTzTtLD1rCl+MHiiaQ/YdMsoFP3EZWkLemCMfnTq5hQatcmGFq3vY5/41eNbt bWLwhbTyKUbfeLyCrHkIfoMZ981lfBnwTPrOrw6pfRyLZQyBoywx5jA1T1SDU/Eurz6jq0Ek97Mu HmaPy+hzhenGOOfSvRvCdzq1vDFFby7FjXasaDhR7KK8eM1OpeWp6DThC0T2u3IgjSNiMAY5NLNe W0fyG5jRs4wWHJ9K83itNUnvPtrSTSDbgpINvzevXP6VrnTJ7qPEzRwggccnnseoHc17EcVJrSJ5 zpJbs6SbXIYt2+GZGHQOpGecZFcz4w8V3UOnu+nxoCqliXIHfoM8Vf020awQxeeZoX/5ZSY2D3Ax xQ+laLPLv8tYZcEfNyD+J5FKcqs42TsOKhF3aucTod5c3yXN5qF9cTr5xChJP4RwDgfyHvT7XTWn vZbmC3uWEwC4Z8AAZP154/KuuksRAgjjtVRSeHUZBHrmrtrEkJG1GbHtXLHDt2Umaur1Rz2l+GVk KGWBICEKsynJwT64GO35VF4k0C2jtmSNlAPZVH6nvXUuXMxblRnIAqpqETT5DcD3HH41rKjBRskZ qpK9zzPQLJbO6J2ZVTkbq3LsNIPMWFF45IWp5LL/AEhtkZAzn2qV4ndVVto455rjjDlVjocru5yO qW7b3fcz4/Os42cZHzoCGHII610OpRf6WFGP5ZqnOhT5c9O5/lWEo6msXoeb+KfCzReZdWIaSPkl Mcr9K4e4hKg7eCOK9ylViSN3HXNct4k8Mw3Ye5tAsUuPmU9H9fxrPY1jI4Tw54hvNImADb4GPzxt 0P8Aga9DsLy11SI3Fk+5AAWXvGfQj+teZ6hYyQyOjxlHU9x0pNH1C70y9WW3l2YznJ4YDnB9c46U NXKtc9RdcnNMaMgEMDnrjFU9C1611gfIiw3GPnjzwfdf8K2DGJMAfePX3rOwjNcEk8YHv6VXKhXY 845x71pzQ/OQSTjpxVSWFBlAc5PegCnnJCEEkihUIPv9am2DI9BStGrbj0A9O9ICL58jJY9qSQ5z wB+FSlWBAA749KfJEVRWZM49aBlVGxHnv2wO1DDd2565qUYDE7cHpx/OldgSWXGO2O1ICGZWHYdS AR2quQy4BHXvV1ZV2neRgHkmq0lwmW2jp0oAaqkjJ/nVi2jMkiptznGcdqpmdQWGBzSfa5ItpeNx uHy7uAeSP6H8qYG82Ybj7uQRxtPap1mhkKq4U4XG0jH61gW9/MzKNqgEYHNWYjdNK37v8cU7isaE bqrkiPA9ugp0+JbaRAOR93nvTDFIwD7to7g81bs0WCZZQQ+QeCnA/A5zQhHM26lbnbJlSM9Oa6NL gXOnKyD54xgkd6wpwFuZAFZWBJB7VreG7+3jyl4CIQfm2jJpLcb2IUUtO28bQP7y0OkgVAq/Keha tXUo7eSIy27gc8VjXO5QMtkAdc0NWBO5NCXVgrbuuRgYqZmEYw2Oazo5TG+CTyOKk+3O8hRI1bIx yOTSuOxegmXd1wtOaQsNqsBn1qvCPl/eJgj0p4EbjCvgn1OKYhJDjjPAqrO2Actz2p1yQcpvBHrn rWfcllY7GDKOh9aTGh8mWIw2MdTUIkYE5P6VHuOGIyeMiqhnHQ/KR3xSKPUvhj8cdFmMVl4otvs0 o4F0i7kz7r2+o/IV71peoWGo2iXWn3UNzA3KvE4ZT+VfBvibwvrfhy+a01axntZAeNy4DD1B6EVp eBfHfiPwfeCbTL+VYyRvgY7o2x6qf59fevZw+OcNJar8TjrYRT1ifdgPfH4UoHqOleNeCvjzoGrW yw6pbtZagB0DDy3PsT0/H866y48aXLqDbW8ESnoXYsf0r0vrlG17nE6FROzR3R454qG4ure3QvPP HEB3ZgK87n1vVbk5a6kGeyjaB+VY91HcSXDSz3DOxPO5i386xnj0vhQ1h77s9D1TxhoWnjEt55hP QRKWz+PSvKfif4tt9anjjh+1CEKALdgFWRs5y235mHT5cgVfms4JSGkLHA7cVastG0stHLJGHkQh lwelcVevVrrl0SN6cIU3c89vNI8a+KCpv9QuRa7txR3KRnnoF4IFS6b8OLGEbru8zIW+YKuQR6An tXp7TgylPLzGemeKesEErriNUwOcfWsFQT3dzT2zW2hxNp4V02zJdbdj6Ek4/LpWtp1nbWsqRJCs UZwQVXH4GukNkhQ8cDgLmiOwjIbzVBGMYI4q40LbIh1b7lN9N0+SWPcqvjkgrnmtawsI7dt3yBO2 KpW4SyZFn+eJjhH7g+h/xrWjKgE4+U8j2ropxjvYzm2T27RRRnBXce5pQY3hYHLn2qv8g5xgdqjM qqrkPgjn0rfmsZ2GTXPk9V4Jxz2pJDGYcsdzE5z7VX8wTSkM/wAo/WrBSLG1jnnt2FZXbKtYTT7q 4hkIDYQn7p5B/OtP7baTT4ZTEwXqoyv5VQCBXXAQjtz0qOWMPIrqwGAV4PH41cZSirEtJs050KoX 4ZP76nIqi10nzDcNucFj1p9uk0Um5JCO/pmoLtYLpStxC0LZ/wBZEOPqVPFVJ9gSM2eeJnLBmXnJ zjGPeq93cWbcEhTjkrzj8KtzaJJtaSB/tUf95OoHuOorGmtt6rIqMFYZ+YEH8c8iuSfMt0bRsytN HZtPwzMeuQOBVe9sGAG0ZUnGc9asi22fOfu/Wp2lzGAeVQ8DuKxsnuaXtsc7cL5ZK+VjB+v+fwql dDeSWzkcf0rpJvs0qlXQBhwCBWJe2p3MUyUHIArGUbGkZXOY1vRrPU4CGQJKBxIOv/16891rRrjT 59s0SsM5VsZV69b+zjO+T5eelUtTsYLu1MUyB42HfqPpWOqNYs8Wikns7gSwuVIPBHau88K+LopQ sN2ds/8AfPRvrWT4l8Ny2OZosywH+LHK+x/xrmJIpI2LJnIp6SNNz16WcOR3PWq8j98g4/OuL8Pe JWRktrs5UcBzyR9fWuwG2VFKDcpGQR3rNprcVrDGlUnkgemack6kkjGBjtUckTluF/Ok8ltjZ6Ht SEOlnVZc9T39Ka94hYEsc54xUU0JYnJwR05qNYkxvyPzoGWDdq/Rc4/WoLiZvMPBAPoKastvbtln jJHOMgcVXnvoGIKyB/bFIEJKZSuQSQOwPFVnDkqobnHHtSz6jFjAjO0+4H41Sluzu3BVxngHJNOz Ga0VpFJtZpGJ7gmraQWkPz7lyx6s1c291M55lOMdAccVCGB5J3DPc5p8omdQ0+nxuxN0AfRfSpoN f02IBCZpivov+NckSmzcoOfTFLCzF8hOPWnYDsz4pgaMJDpbbv7zSf0xU9rqM87guiR57AVyEBdW HUVpWruJQclffNJti5UbOo6hLp2oMYnXDKVbgEEEH9MVm20zuXdclQOi9RUetsWeJtwKsCOfameH pCLySNnCB0IyfpSZSWhrW+oM0W0Etjg4zxTJbjc20LvBJ4A5qKN/leJFUDPO3ufWnSxNDGu1/nPP B6UhDZUkGCqOcdttJaXLrISrbWxnI4IpX+0M6Bp3PQgBuBU0d35dqbcpCxzkyFBv/OkMuwXkixso ALMOTzmq0saGItI+z0HOaiFyV4VeNuc1XkuRIMNwcfWncViN0UqF2OjcnJ71GiqmTubIPcfpUyuH UMwA59c0XBGzzU67sYBpFFcH5jgjnnGKrXJjQ9FZvSm3FyiSMwJJwcY6VHDby3UgcDHFAHq/iLU5 /F0DW2rzLPEDkRhAoU/lkV5t4i+HkgRp9LfzAOfKY/N+BruOH5BZfRhwcVLHcTRACTEi+o6/lWvM 5O7epmvd0R4PeWN3YzlZYnhkVu4wQa6Twl4+1nQWWEyLcWgPMUnI/A9R/nivU7/TtN1m38u8gjkB 6Mv3h+Nee+Jvh3dW2+fTCbmLk7MfOv8AjVqTRXNGWjPUvCXjnRvECxxx3K21wf8AljKwBJ9j0P8A P2rqQFY4IBx1NfJjw3VjMyFXikB+YEYNdn4P+Juq6SyW95m7tl4AdjlR7H/Gt4zvuZSo/wAp9DAL 9wqcetaulWCkM+c5PpnFcH4V8YaV4gUfY7sLL1ML4DD/AB/Cu406+eBCGww64J610UnFvU5ZprQf eQ+RGJdhAZiBnjB9aj+0IqkgbiBVO8uZZZGWRvl3ZUZ6fSovO25AHtxTctdBKPc0VvGEeQBk9Ktp P5seGwKwI5bl3Cxws3+FSK8+8DBAHoaFUsDibWYnRo5QHUjoearxXLWTCGfLwMcJIeo9j/jTLRiC CY2x7mrM7JMpiZFcMMEEZGKtPqiSyru4xjAx0qteH92xHBNVIZGsW8q4bdbkYSVjyvs39D/k3Xy+ Aq5OeOKd7oLWKcau7Zw3HepovMXKjOPU9anhSTcQSSR61eWz8xA2Sv4U4wb2E5WMotIXx02nHPer doFbDDdx2zS/2e5d+WK5qwLUKAVLKRxVRjITkgccY7d+elR4SQYwc9cmrawKOGPWnosaPhnGOg4r XlIuZhWaEl4yUbIwQcUXhW4Ui9gD5H+sj+Vx9exrRmntY1K7ie/Ss64vYWJEcbFR0zUySS3Gm2Zt zokkkYltpPOXGdgGJB9R/hVKGweNWVkO7OCD2q9cXxD4BEZ4wRVS416G3Bjv54XjzjfLKEYfRv8A Irnap3NVzGfc2RidgcDPc1nyBQWU4cYwMc1p3Oo+H72RoLHW7SWbtC0g3n2Ujhj7Dn2rh9X8X2Nl etYyWV+Z0ONrQ+WT/wB9EEflXPUtE2gmzbnQcgJkYHU8CqNxEATk5IPBz0rkbrx1cSbhFYquem+T OB9AKy7vxTq8rlQYYD6rHz+pNc8po2UWdlJE0gZSAQQcj1rhvFPhtYw11Ykdy0ZI4+h/pUM2q6hL kyahOG/2H2/yqhKwLbncv6ljmsrmqTRz8kKlty4D+9bOg+ILmwkEN1vkgPBGckD2ptzBHIu5Vww/ Ks+WIkkSKeBwQM4qrp7jPQr7VcqstsGuIH53lhwTzg4zg1nyarcvnbEiDGRwTXK6Rf3FjJ8jAxk/ MrdCPQiuhAS6Q3NnlQRlos8r7+4qGrCsI1/cl9rzfoBionfcPvFj2ySaiCkt8zHFIQwIGGHuaQxW zjhCQB1zUBDMcL19Kt7AkeWkXJGAq5P59qfBHlAFJV/XPGPpRcDOC5YlscdATUbq2M4wepNaM9sA 7HOTn0qsy4yzEnnGKpMRUkXDZHT+lTsmMMq8YxnFOkXOGxkewpylsbc5U9qLgMWElNwIx3pyJ8wA OQepHarEUannAPoaQLgElgOePalcY7HzDcelXIHRGXceehGarY/dbuopU6DHUdcmpYi9qQ86x+Q4 2uD9Aaq2Lol1C0ybkBw/PLA9asxgkSISCCp/Gqa+QLGRSWE2cgdsAfnQBtzm2UJ9nLISeSTTZnIA V3Pyj16VTgdHgX5gzLkEdfxFSylnbjP3ccHrzSAe0gypGc5znNWXWOdPkz5mO/es9n5QYI56GniY pMzEZX1AwKQ7CDIDq3B6Yo8rD/w4x16irrNBdp+7ULJ1znGapXcph4ZeoyKBjJswrtDjNZFzeO2V B47/AP1qW9unmbaeMdhV/RtHad1mmACnoPWnsBX0ywnunDupCjnPrXYWdhFBEGMZcn7qf1NWtM0q QkJFHhePxr0bwl4UdgryRM8jLkAj9aunSlUdkZ1KiijgIWxgYqzGevH0rPjclgMn8a0ICCwDA4pR GyaNAxypKN/eHf61L5k8TfvkLD+8o4/H0p0cRABU8EZBqxjamNxJxWqRm2ZOt6FpetxZubdGYjiV OGH415r4p+HmpWG6exQ3duOcp95fqK9fFum/dE2xu+Oh+oq/ZzGEn7SAid3HKn/CqULvsCm4nzJb i7sbgPEzxSqc5HGCK9G8H/Fa+s5I7bW1N1COBID84H9fx/OvR/EHgvQtfgad41huj0ljUA/j2NeP eNvAGr6HI8saG6tf+esQyB9R1FP3oPUtSjU0Z7r4e17RtdgWfTruOYlcsmfmX6jqK29vOeDn0FfI Vjfahpd1HPa3EsMqHIKnBr1bwP8AF54ilr4jiMi/8/MY+YfVe/4flW0ai6mM6LWqPbII3aUgtsHv xRArGXhe/rTNH1HS9YsVurC9huIG4DI2f07Vdi2BhtBIFdCjsczY6NSDyvOOlLkgntgdqkLYHAyf WobieKDL3EyRr6uwAH41drCGSp5iNEV3hgcqabpsk+nk290xMDkCKVjnaf7rH+RrKvPGfhfT1P2n XrLdnkJIJCPwXNYOofFnwrBDJCi3eo7hggRbVI992KjmjF3uUoSeiR6bFAhdQzjBHOOprRhCoOAe O7V4FD8ZruC2eGw0VJNpzGbmclgv4DnH16evWse/+L/jK74ils7NTxiKAE4+rE1axlKIfVqjPpSd gc4IH65rH1DVrGwVjf6jbWy9f3sypx+NfMWpeMfE2oEi716/kU8MqSlFx9FwKxHlMjl2BdyeWY5P 61lPHp7IuOEfVn0hqHxG8JQSsJNdgbaeBFukz/3yDWBqHxc8PxylrZL+5GMLsiCj82I/lXhMhYsW 2cn1FCGY9O/SueWLmzZYaCPU9U+Ll/I7HT9JhiUjA+0SFj+QxXO6h8Q/FVwxxexWy+kMSj9Tk/rX IhHK5Zix9KlWA7eFPJ71jKtN7s0VKK6Ghfa9q98xe51W8k3dVMzBR9AOKoRSb5STl2Pc96PLIOCg HoBUixlANq4OeprNu5a0LSyvt3BcH1Iq5b69fx24tbtINQtQOIbtd4Uf7DD5k/4CRVJHXyGDMARg gVCzHjIyR0qU2tgaTNWXTNHvwv8AZ141hO3Jtr1sp/wCUcY6feC/U1Q1LSLzTZvLvoJIiwyuRw49 QRwR7iqzktwccVr6TrN9YwtBHIkls5zJbzqJIm+qnofcYPvVXT3CzRjGIZyq/rT0Izjapx+ldIsH hzVSR8+hXYz3aa2Y9h3dP/H/AMKzdS0PUbGFJZod1s5wlzCwkic+zqSM+2c0nHqCl0M2QAqNxPoe KgaJHypBxjrjGKnK4Yjt6etD/fYjsaRRj3lmVfcpOPbvSWM8scgMRZZFOQQelak7Hy8HvxVGe23E lAcHp7VaYjXguo70qNiRzhcELwHPqPeoWYs4DkkqMAE9OvFYEqSRN8rNle1a2malFc+VBeTFHHAl Izt56HnpSatsIvFdrbc4Y4wDSpJs69OcfWlnUR5VmLn+Fh0P09aHEexAhDY6tjrUDHrlxuLZ9faq rp2yBip9xK4xz2xSsXVDt8v3yATRcCFiWiWPI2g8Z7UqKSAuxVxkFu5oB4GQAc1MAMkkjpQDGpGV AOcLjOPSnpGpfDfL160pyxAySBxx2p/8I4G4++TQAjKBHlfmIH+TTCQFXa2S3Jx25pzElDg4PQj2 qtI+G5GQBxQBdtJMSgsTzxzVeZVDzxuxGRwFGc+lG5kO4YJXkZNRTPIu8rkBx83uaEA2waSJv3qk jkdOa1EfeoK/3e5xWT5krxYl4OMgkc4q/p9ySq+YAcDBOKGMsdAGxnsc9BSkARnLjHUgelPOGmwx XGPlAGaq3jKinLDPfHepAkW4jhwIWYH+LJ4qKdmvJmCEE9TzVWIG7kKwjaB1J712XhrQyCrSJk5y Rjp9aPJA2lqZmj+H94Rnj+bqAa7bS9EACLHGXkbr6LWrp2mcfcJzXb+GdA+1MgjjKRIcNJ/hXXRw 0puxzVa9kVvB/hwCUExs0gHJ7L9a9F06xhsYgsfLH7zHvUlnaw2luIYF2qO/rU5r6TC4SNGOu55V Ws5s+UoSCQAMAeh61ZEg3gbe/AzWZGXUKRwKspJuIHOfcda+STPbZuRy7CEYHcKlL75QPWsP7bBb kGa4iiGMZdhUUvivQ4Qd+oLIwHSNS1aJkOJ1cXBJ38n+dTwlAOW3cfdPevPZ/iJpluMwWtzP6ZIQ VmXfxMv2Uiz063i93Yuf6VqpIXIz123t3UF7RjEe64yh/D/ClN8RKsV5brFk43E5Rvx/oa8Pu/Hn im4iIGp/Zl6bYUC4/HrWJdatqN6p+1aldzZPO+UkU+e2weyb3PWPHnhnwTexPPNqNnpd0TwUdcE+ 65rxbV9Mjtrp47e5iuo1PyyRg4Ye2akLiV/nXcc4J7//AF6njjYANGwce3aobs7rQ1imtLlbQde1 nQLz7Tpl5NbyA8qvRvqDwa9Bh+MfiS4tVjiSwgmVcO5Tlj64JxXBzxxyf6wDoenBzVGWxkHKEkc1 SqNLR2E4xk9TtdQ8feLrxdsmuXUYJwRCRGP/AB3FYkl7c3LeZdXE87E8mRyx/WsSOaS365IB5BrS tbmGQAZCvxwamTk92NJLYnXc/POCKUGRgB6dOKkIXyuHp8Q2rnHOOmKzGRojjGGKsOhHUVK6LNGX QfvQMsPX3FPba8e4DBpjq0cgKPzgH8aAGhPlzjsOOtOGQ3HQd6tqwlXaAocckD+L3qKLAbZjJ6cC lcLDWGYiM9OpqWFI9w3A49QKjABViWOeuevNOhPyAlj6YxQIsNCQcKu72708Qjkkge2elNaZI0GT k4o88bDkc9+eM1IxzKq/OSCP0qISqpYKOTjntSPKGVgMAdelVDJk7eh7kHpTSAneTexwBgdKU7go BxkCooEZm3KrMF5JHOKsjGMnGcjB60MCPaxIwOQKtqAIsY59elVXfB3DI5qVJAyEHnA9aGBYVVAU kZx1qzp97f6e7SWd08G4bXXqrjrhlPDD2NUt4YKBkDAx7etTRONwHQfTrS1QaF2S50m+Ym+szYzn pLZD5GOOrRk45/2SAPQ0y+0O6hie6tmivrRRkz2zbwoz/GOqf8CAqjJ/reB349qSzuZrW7FzbTyw yoxKvExVh9CKd77it2KcwBGSOvXNIq4ckEj0x3rcl1KzvVzqlirSjj7TbARvk/3l+635An1qnNpT TMW0u4W+UjPlqu2VR7p1P/Acj3p2C/cyniEj4GA2eQRWZqNqqSkoOR/Ftx+lbT+bnDhgwyAG4qJw ZflYY+tCdhlDTtUZCtreljFzt4zg+39a08gkOpDL2xWTeWTbsqCR0BptjdzWUjbtzRngjNU1fYZs FkVs85wKC7EcfTgVIqR3du9xbOHCkblz8wH9ahk+TARiGHU1AEyoWwu1mI5zTlIQhiuQe+arrMzJ tLNn09aQsABgEnPrRYRclmBGVAXJxjJ4pBKmMbTkd6pA5J46UGQBiD24osBoJ5cqg/MDt5A5yaju FG/IHTjpVdLtVYYXtgDGKlW8WUHChcn60WYDh1PJxnp61et7aGaQsxGFQEg1TDJszvJOfSpooVuo hE5KqwOWHBHXH60gNq/0uB5Vgtkt59wBV4JWZdp/hG4ZBBzxiquoaY2mrtlTyw65HHXjp9RTtB1w +GnSaOxM7xSKd7kAE8496m8R+JodVgWWPT44rhz8+0jG7PUA+o9+1VZNXJV0zGM7h1VMljgACoCu +UtdMY1Bxknv71oaNp11fTqR8qg/eH8NdNd6BZxaeYJEj82QYVnGSuf4sVKVym0ixpWhWtg0SGaK V5EVyy84DANge4zXZaXYJhZJAVjA+VQOvvWD4YS2gurnZCZpRYrIyJyd0eFJA56g/pXVeGNG8U+I tUhaeym0vS4ziR5V2uw9FB5yfXGK6aML7K7OepK27Ok8OaNLqMo8weXbJ12jr7V6FbQRW8KxQoFR egFNs7aK0t0ggQJGgwAKmHAr6bDYZUVrueTUqOb8hcc0D0o5xRz9a6jM+DX8W6m4CxCGNeei5P61 Tn1XVrknzr+UZP3Vbb/Ks6BSfYrVqKMDIwORnGa+JdkfTJIhlZ5EzIzMw4JJzxSQfLKMAEd+Ku+U uM45/wD11G0O1eMZFJSG0QvGwbGcYzxjpT0jDKWyc1Jc84deh4IqOPIY8nqeKpbEMGACYwBTMYQj 1NP25wCRx1pxUleR39aYiBVIfPQ/TvVuJSmG6NjqKjKYGSe1SIOCeM/zpNgxxVHceauOeq/4Unls gLDBA4DCpcfIB360zeYzleCf1pCK7QxTkh1w3qBUEtgy5dCsnHGO3vWgfJc5c+WT1IHBP060+SPy QAGDhupU8U7tAZkF1LANsill75rRtbqCUEKdpI6GopoIZRhh83qOxqjNYzxgyIrcHG5aejGbqZx9 7aevBprthhkEk1kwX0sYUSjd2NX4ZY5yNh5A5z1qbWETxMytwrZqVZPNICgBx1A7/SotgBIUsT6C lijJk3AgAc56UgBSRkY61KpXJIGB0H1psiiQkqMMRk57/So4+C29sMD070AWJwDF985BwR/WoUUt 6nAyfahV3Z5GfrT0DFs8jtQA0qFTIPNQttAJOc1aaLcCM8ioCpD9gB1zQmIIztJ/nUhYlQTyMYpm O4Gc/wAqlVCVChenPWgY0EEAjBz7cVLF8p6Zzx/9ehI96j0J+lImepU8cE+lK4EpDq4QdQCMcetT xudw69ORVdyrEt0OOadA+CTnOBzSAsPt3bgu3BBKnpVcD5tx/SjzMyHnPXn9achypyd2OaAI/L6E n8M010w+9SQeMYPIqVTjbleO+Kc+zy26h+MY6dOf6frRcC5bagJ2C6rEl4uCDIx2yrwf4x17feBq OWztpxusLkFjx5UuFf8AA/dP559qoDhMYAOc5z1pyEeWRjqQc07isNukaEmCeKRXGdyOuCDWfcW2 clOG681sLfXAhW3k2XFuudsU3O3/AHSOR+BFTRWej38QW31B9NujnEd0N0LewkXlc/7S49WqorsF 7HH20k9jITE20jqPX2rasLiC+j2k+VcDPyno3+FWNW0O7tI1N/ZvEr/6udQGjf3Dj5W/A1z80U1t OHA+Ze5703qM2JCY22HKkdQRyKYz7W2g0WV9FqCLbXreVMB8koH6H1pb2yls5gJk+9yrc4b3zSsI OTlgCR6jpURRnfCEZIyR0xj60OXwE7ds8VEOHPK8nHBoAFIJxnIPTip5EaJwDg7lBBDZHPNRADJ5 DfTpT4dxYkkKooGXLVmLAEAqeSDV+4lj8qIRyFtvBTbgdf16msuK4WMgoGmY+nT86pXl7JHIySAo 69V28gfj/wDWpWuwN6HWbSW3NleacoUtuWZSN3TGOe3SnRCBdscrllXA2oMsawIrjF0ig8tgFyfu 57frX118OdD8D6ZYWT2Fnai+aBWeWUbpCSoycnp+FbUMO68+RNIyrVVSV9zyPwp4V8ZarGh0vRpb aA42z3OI1x6gHr+tekeH/hHChWfxFqkl7MfvJCNq/TJ5P6V6kjIwyjAj2NP74r3KOU0oL33f8jza mNnLbQw9N8LaBpoh+w6bBbvEwZXRfnJwRy3U8E9a3BwMAUYxzS/SvSp0oQ0irHLKTluwpf5UjEYo HIqyRckikyKM8Ypp5NIZ+e9pu3bee9XACqKMHI71DbjDA8AdOBVnkAu2MHvmviJPU+oS0HBBkjH3 Tnnil2FU+bGMUgbAHtU5AaLBIB+tZjK9zHtRBjqDVdFq1ek7RkbmH8qq7jk4+XPTmtYbGctxhxuJ 5+uafnAyKaAQDuzgn0pH54Ug8flVEkpYNHjuKX5mX0qGF8HGPwqfIIySc9uOlIRKCBH8xHTjJqN8 kArxxmiXPUHqPSlUZXDcDr0oAjkUN15Ip0ReI7lOCT+dKoUlhnvk0KrMc8kAZzTGWrd4GlDugB/u n7p/wqNvOWQnYF3Ht0xTYj+6ZSVwcfNjkU6LehO05B6g9KQhstvbznDp5b9MrUTWLRRsYJCTjHA7 VoLFE5Gcqf0offC2BkZP4YpXApfbAJ2YAGNeMdDn0HtVqKRJgSDjHODxTZltipSRTFIR97sfrVWS 3lhdWRwUx97P8sU9wLj/AO9lu2D0pNpk3MABJjp2b/69U0mkADSKD6VaDHG7eT07UAOiLcgAcD86 VZSGGSeDnrU/ksygqArHOeevHSoZIXVtpHTg0tAJBKSTtAB+lNdHbc3A7AUzaVY8/KPWnGRj8hI2 9c4oABj5huOR2qS3Y7cc5xULHcM8n0OKIF5PPPvQBYd9sag4z3FLn5cg8Z5FMC84Y9umetSsFH3i OKQFcsRkZHPHPbmpoM4kBOBj+tNYIzMMg0RkgMF5wMfrQBKyJvOM4we/sadGoKMCO3TNGdyjPTGO vSk53MN3GKQx20BeCc9qRl3OTggdDipFUYB3ccU5ggIAJ5pAVwDgN2HemMQDwAO/WpnZdpG45JwK hDbhgDPPTFMBhBLbQDnOCKhlJUAA4HX61NIhbOPlyOeajERZRnJ+gpoC7pHiTVtKc/ZLyXyH/wBZ CzZjkHup4NN1LUdI1KUudPNhKeD5J3RngDO3qCTk8cc9KptCAMYyfTNSQ6XeX8ixWlpJMx+6kalj +nNVzaaisr3KculyuGe0CyjAw0Kl8H6dR+Iqex1RoYm0vUo2aJuCRwyEcZHoa7nwh8NPHTahHc2m kz2oHHmXB8pcd8gkMQfpT/E3w7vvCviXRm1Y2+om/lkka1twSMIQWGTjs36Vp7OfK5Wdl5Ee0hfl ucpoXhqxvp55bvXkhs47d5EndDId46IyjkZ9fyzVDR9BvNb1OKw0m0knupm+RE9+eT249a6PxDq2 iap42hudBsBpGjRokcgWPDP/AHsqDg+n+NelfC640fQNV0mW4ltg0zzIJQcDCo2D79h+NOMLzUL9 dyZTcY81vkY+gfAXXJYRPr2qWmlxqASqDzXA9+Qo/M1Q1/R/hv4YdrSH7drd2oOZZpQsYPsFAq/8 WPipd6vdzafpcjQ2cbFQVON59TXk807yMWZi7nktnJrev7Cm+Skr+b/qxFNVZazdvI6K78QBBjTt PtLNB0MaYP59a5vXAJpft1yS0s+AQew/vf0FQwv96SdzsjG6TntngD61WnunuUO5SVxwPT0rjOiK SEtVt1uQXLmLPPvXon9panp39nSNqkjl7RGR8kEDlcfhtrzqELj5s+tdf4gkkn8JaHeRKGEXmWzE exDAfqaNb6DkloegeGPiXqumyqJbgXMK9Yy9es+EviRpGrlkuXSzYYKiRx81fI6XhX+Iow/vCt3T tUMYjDPnPf0+tdNHHVqOzujnq4WE+h9o2tzBdQiWCVJEPRlORU3QZr518D/EW/0nyoGcS2KHlCvI B54P1r2vwr4lsNd08XEE67ujITyK93C5hTr6bM8ythpU9ehvj8KDxzTEOVGH3fjTz9K7k7nOJuDc mmkiklYIN2ePSmlwygkVLfQdj4FDDdtGMd8VYjjLJ97p2xUCwlHVsnIPPFWvLIAbgfSviGfUEewC U49aeisXwxxzintGR8wAyfekDAHOAdvSgGTIiMymTJRTyB3FU5jC1zIWAUE7kUdB6VbiLvIiIwIL c56YqHV4UivWjDKcfcI6VUTORD5okzGdoGc8DoagkQKzBVPpUnl4zzyBn6U3MjHJByeOKtEoau1H PJPH5VOq5iDZ/CiS0byBLG4I/iApkZIByCfUUCH4wM9fxpqAnqTz6U98bA2MYHHNEDqI+AcfWgVx gXbIRkYB/Oph6Y+mKYH3Ek9/egnDt1BA4xQO5KCoYZXP0pYichR3qGEgyfKcHHWpgQUJXqelICZX c4XIA9KYZ3VSvBHcHmmwhxkgZxxUUueeoGc0AP8AknmAX5W67SePzq/DbrENo2ICOVY/e49DWYpK yqegPFXIYoWYxXtxLACSd6oGwMcAA4/nQ0A26toJCTjymPT+7/8AWqtJ9qtMq0RYZ475/GrAINsy oWeNW+Qt1xmnwMw4xlDwVIyKNgEs9QiEYMg+bpjPI9634YLDVdJjhth5GpwhmZi/yXCct/wFh09+ O/Xn7nTkdTJGDG+fusfX+VVo57ywkwhKsDkAnofWhWEyxeRyQs8bqUZW2srDBFVHYlSd2T0rUnuZ dcuxc3LmSeU4eTqzNnq2ep7fgKhGneYZtjSN5Q+YbOmD9e39KewFWKR2XH5HFWrcjlifaoFtXj+8 ST1GKnWIbC3PBpMYNIdhz26Uock5PGOlAC7QnftzVm3tLi4Tba2k0pPQJGWP6Ck2kFiBQpXgjPfI qaJBsY9Titiy8GeL7xh9n8O6odxAB+zMo/Mium0z4PeOrwES2UFoOMNPcAZ/BcmqjTnP4U38iJVI x3ZwcYYZ4PTnPFOcZIPAJHJzXq9r8CfE8h/0nVNMgGOql5D/ACFZMnwa8ay6Ob21l095ld1a1JKv lWK8EjBzjI+tafVK63g/uJ9vTf2jgFA2EnPUduBTjHGYy+4D6nvXWab8FfiPqIzOLLTk6fvp+cfR Qa6HT/2fvEcbK914j03IOceS0g/XFOOErSV1F/cDr01vJHmKW0t3KI7SBpnI5EcZY5z7VvaZ8P8A xlqGPI8PX5U95E8oH8WxX0B4U8M+MNBto7aPX9Mu4Ixjy5LMrx6Ag5rubM3Pkj7UsSyDqI2LL+oF d+Hyp1PjbXy/W5y1Mby/Ckz5v0b4IeK7qQG9ax0+Pvvk8xx+C8frXZ6N8BNJh2nVNcvLn1WCNYx+ u6vZB+lL2r0aeUYeO936v/KxyyxtV7aHG6R8L/BGm7Wi0OGdx/FcMZc++GOP0rqbWxs7KMRWlpBA ijhY4wo/IVY3j1qIzqNofgnpXbChRpfDFI55VJz+J3EOAD2NfOf7S1+0/i+zsY5m/wBGt+djfdZj kj8QBX0VP5aAuwxgEk+1fIXi7UJtd8aXt8BuSS4bYCOi5wo/IAV52bVOSjy92deBhed+xc8A6Vbz apCrW6nkAF19OSc034qX0EOuRW9o22W3TCkHAQk5JHv0rrPCFuLd5bh08oQQAnHOGY/4CvGPEepP qGuXV5uyZZmZc9lzx+leFFWp+p6PxTH3268MlzHw/JnjXp/vD2/lWWbmQZiiGW6HAzT5Lw2rxtbP tuM5DdhV61MFvF/atsieamcwkZCyf3h6r3x2PFSa2IL39xsssAupDzn1k9Pw6fXNVQAJGzxnjmoo 2LOWJyzHJJPJJqbhs4GeAD60NDRFas2xgRXWabKJfA97CWb/AEa5jmx6ZypP6iuPdgkrjk88c10v g6YTx6jYll23FnJhf9pfmH6ik1rcHsUFJcYYA59e1Ny0Tnym5PODSxoShLA4x1NCbMg8Z71Fii7b 6lKh8s5VuMg113hXX7qyeO5tbllIPIzj/wDXXBOqzHaWxnofSp9Nme3uRFIxGTkEd6W2qE0nufV3 w38aHVJDbXZVTjhh0J9K9GUhlBByK+SND1OaxkiminO9R0B5Br6H+HXiaPWNNSN2JmUfNXvZbjub 93M8nFYfl96J1M43nj9arYkzlXOKsOHDYxkUq7eAR+lepJXZxo8Wm8F+ELqUCPSIwTxhSRj9akX4 Z+FJEZTp2HU8hZmq3NJmVZVlECDHCn9K0VW18+S4SefAjwdz9Wr5uFOm94nquc11ZzS/DHwfG+bm O6j3/dCSknH5Vem+CPhK4YeRcX8RI3AeYD/StaxgeAiRlLA9NrZKg+tb9tftHGzFvlQfeJ4AralQ ov4okSq1FtI87m+BOjlP3Op3yEAkjaGrNuPgK92FMOvksvA3xDIX8K9ojvY/JWX7QNrdQvP4ZqvN q1vGpMCvvJwVA7etbvBYZf8ADkfWK3c8QuvgLexHEevRu/PWE/41Su/gXrka74NYspFPUeWwxXuR 1S8OrCCO2kkRhneBgKK0BJuWRXmywxgY6VKwdGV7Ng8TVW586j4MeKooma3vLCY45TcQSfxFZcnw g8eQ/dsLZ8kH/j4WvpuKJI5PMmBdc5BB/pU0Ucq3DScYYfLkcCl/Z8H1f4f5D+uTXRHzMvwb8cSx Lm2sVLdmuACKX/hS/jtWCCytGGOouRivpch45zJdAGNVzkjoPwo07U7W6R3tg4VWwcjFNZfSvZyf 4f5C+tz7I+aF+C3j8nYLC2x6/aVxT4/gr4/L4Nja49TcrX1F5shjDRuOmVB71FBqKys0Y+V8Yzjj NX/ZtK+sn+H+QvrlTsj5mtfgj48fO62so8c/Ncj+gq6vwN8bYyP7N6cA3B/+Jr6StnkRMXEqsw9B irJKyLgEj39atZXRa+J/h/kS8bU7I+Vbv4RePbQZOkLcj/pjOjfzIqtJ8MvGzRqo8N3II75T/Gvr ZQxUDOTSeVg7lJBpPJ4dJP8AAax8uqR8jn4UePWiz/YMwxzkyJ/LNWNP+Fvjq+RY30IoAeskyLn8 M19YxiQZ34I7YFKoA5Cg5p/2RB/aYfX59kfMg+C3jaVVC29nAo7NcD+lW7b4F+LQfnuNMHPeZj/7 LX0l82Bx+tALAnK8fWrWUUVvJ/h/kQ8dU7I+frb4Ea4VPm6tp0Weu0O39BWgvwDEiqtzrkJHfbbE nPsd1e55H403pySce9aLKcOt7/eS8bVfU+Srr4fQ+Hddupdavpo7O0djFJCMSb1PycEHqOa4pLe6 vbu8u0mYWyyDG4qrksem0YB69hX2P448LWfibTDA5WOdWDI/Zsdm9RXhXjLwOdNvJIY7JbVh8wUH O4f3lPcfyryMXhJ4d6arud1DEKotdzz/AEzS2GsWqyX8DwSSKjPchljTLc7ihyB1H417xo/ge3s1 imuvAek6jbsm4NZXhk3Z6HEpGR+NeP6dprQ5WeNmjk5w3WvQPAnjTVPCES2tzv1DSM8Juy8A/wBk +ntUYSVLmtV++yf5oqvzte4emaHF4YhukgPgs6VLjhpNNXaAP9tcj9a6+3NoEVYDCBjgLgcVW0TV NP1mxi1DT7iK5gkUFWQ/ofQ+1WrhYpEOYlfb6ivpaNNQV1b5Kx5E5OT1Je2QajY4JZ8L756VSiEE RaZ2MW08qJTgD3HSvPfGnii6vbqW3sXYW6nABGM8d/1orYmNKPNIcKTm7I7u+8RaVZB1e5RnjOGA PfGa5q/+IMMExjSOJkIyCGyemf54Feaag1yXWUzb2c5Kr/WqskoimeGUjJ7nrz3H5V5NXM6jfu6H ZDCwW+p2994/vzCuxREwzznjNVm8farcRiNpRH3yABmuQjeO7DQxyMxAIxjBDE1HbxTxSssdwknJ PlucYA9DXI8ZWf2jZUIdj0K28a3UTRCSQSBBuZQOuRxk1pWXxADKWnRVwchcda8yW6XKtKyqVOCC 2AfbHerlrElw/mEBFGcFT96tIY2stmS6EHuj27TPEFlfAeWxBPrWrFKkme4zjNeB2811aSJtmKhh +6G/5ia6/QfFMllcxQXyyKmQSXfOAe9ejQzK+kzlqYW2sT1AoT0xmq5IMu04DDtmsy38SWMzp5TM yMOHPr9K0p4re8i2Pn2Kkqw+hHIr0eeM/hZzcrjuc58TNT/sjwbqFzuIZo/KjwcHLcf1z+FfNmnQ F5lYDAz8w+pr1/416N4nXQMRSvqGmQyCVmC/vo8A/ex1A9RXlekHf5MG353YL36E4r5zNKjlVUWr WPUwcUqd0ze1u4bSfhxe3jFjJejCHOCMjaP05rw2Mja8jE9zXrvxyuXi03T9HtgwhUbmAHA2jAB/ M15DdjNpsU4PANcs9LROmls33GadBLe3ccUabpZWwPbnv7Vf1C4hjvwLA5t4PkQkf6z1Yj3P6YqS CNtI0f7QQour9CkQzykPRm+rH5R7BqywAMA9O9RvqaF+6tY3g+22jARcCWPvG3p/unsfwqqgIwQQ R25p9pcPbyhk+YHh1bow7g+1W7y3iCLc2gLRNwV7xn0PtSAyb3cHBIzkVqeELjytatmyRubae2Qe P61n3K7yjEHIOMGptKjaO7ik3KAGB3Z6US2BF6WNonkjPJRipBHoaVF2/KeKv63EF1aZ1YBZH3g+ zDP9aqKd5ZFwGJ4OKlgRyRt1QADH605Ylmwpyrfwn3qRlPlKDznmnKB5ilc4qbjLWn3XkOkbDqMN jr1716X4A8Qz6Nfo0ZZVYjIJ4I968xm5kSRf4vlbHY+tdboakGN2kVW25GevFKMnGScdyZpNWZ9U 6JerqOnxXA6svNXcYHT8a4v4baj5lnDDNMjSPGGCjjiu4OAM19bhqntaSk9zw6keSTR4KvT/AIGK 0rf/AI9JP99qKK+cgeq9jesP9S34Uaz/AMgiaiiu1/Ccy+IoW3/IIh+jUtn/AMfAooqFsi31Ow0z /W/9sxTIP+QlP/1yoorvWyOV7svW/Wp5vuJ9aKK6I7GfUo6p1H+6f5U3Tf8Aj2/4CaKKzl/EKXwk sX3bf/darB/i+n+FFFWIst9wfQVIn3Y6KK2Rn0Hab/qD9atN94/Q0UVrHZEsSPq31NHcUUVaJFP3 zQOlFFADT98U1+gooo6AiGfp+Arh/ix/x66Z/wBdX/8AQaKK4Mf/AAJfL80dGH/iL+uh5XqH+vH1 aqa/8e6/57UUV811PUR6H+zj/wAe2r/9d1/9Br1l/uv9DRRX1GA/3aB5mL/is4TxL/yELn/cP/st cbc/6mX6t/6CaKK83GfEdFDYyLz/AFcn/XX/ABrIvP8AkIRf9dqKK82Z1xJ9H/18v/XdP5Gq97/x /j/rj/SiioXwob3M/Tv9RL/12NdLpH+uT/eNFFOG457FvXvuaf8A7x/pV3WfuW//AFyX/wBCaiit 1uzLsX/DP8X/AF0P8xXrWndv90UUV62XnDidyxP/AKl/of5V8v6R/wAjnF/18j+dFFYZ18UP67Gu B2kavxI/49bz6n+VeCX3Rfqf5miivKn/ABGehR+FGx4q/wCP20/68IP/AEGsiT73/AaKKlbL0Rot ho+6fwrovDv3b3/rkP50UVM9hdTD1D/j6l/3j/OiH7v4/wBKKKpAjo9c/wCPmL/r3T+QqhD9w/7/ APQ0UVHQRNL1h/3f61E/3x9RRRUl9CWf/U/9tF/mK6XRv+Pu3/3aKKRLPYfhl/yFYv8AgP8AWvYn +7+FFFfR5Z/DZ5GK+M//2Q= /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcHBw8LCwkMEQ8SEhEP ERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcGBw4ICA4eFBEUHh4eHh4e Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh7/wAARCAFoAeADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDwqPOT 3A7Gpl6DHrUS9OKlTJz05rsOF6smVQSMZxUvG7jjPaok6kfhUsf3RQSSKBkY5qVc5460yMEAYqVf r+tINx0YyPmPapUAwMdKYMkdxxUqgEEdcelArWRw/j6TGqIBn5Yh1+prmcg9UFeia34dXUbtrgz7 WIAww4FZE/g+6B+TynHs2D+tYShK52U6keVanKARkcgj8c0uxeocflW1ceHL6HJa3kI9QMj9Kz3s Joyd6kH0PH86hpm10yrsOeDke1OXeFxyKka3lQH5Cab8yr3zSGhNx7qv4ijCk4xj6Uu5s84NLlSv Ix9DSAQKvrj2IqRAwPUfgaYApJwetOC44Bz+NAFiC7uoG3QzyxnsQxFa1r4r1qAAfbXkA7SfN/Os EZ56804H2FO7RLhGW6O1sfH12m0XVpDKO5U7Sf6fpWzZeOdMlIFxBPBk9sP/AIV5lxn696uaNaPe 6hDbJ1kcLn0q41JbGMqEGe0WdzBeW6XEDbo3GVJGKmFQ2cMdvbRQRjEaKFWph04rpRwvfQXj1oPH ajjAApQOD0oJQv0FJxjHegDtxg0oBoHqBB/GjnHWgfhRjg9/xpivcQ8/Wjr356UvXt+tL3pDG8Zp MemKXGDRQAn60hHHNO5GCOaQj0pBa43H400jPfpT/wCfakJyBxQUMbPFIQM05uh7fWmn0xSDcYe9 MPA5/KpDnrimdAPSgojYAeuBTD0PFSMPx9s0xh1GM0x2uRH2xTG4z+tSkdPSmsMjAFIFtYiZT3zi oSParBBB9qiPUZxxSH6kTDg88VGwHHSpWHGTx9KibrgAcdaYyFhkYPWoj6AcVOxqEjvigNSJs45x /hUTY7flip5MdvxqJsCi4nqQP0xwDUbjnpke1St1PeoXGScHH40ARMBng8ion6Yx+VTNyffuM1C5 +bjH0pFJkLrxwMZ/Co3AHvmpjg5/pUbep/M0iy0h7Z/H0qUHBGcYI9KhXGAOnPPFTp0z2A61oZtk kXCjnNTKD2AqFPvZOfyqZMk9ulIglTOMHP5VMnU4qBOckVMrYGOPxoDclTOQOaeoXOQB9KjXqSCO PWpR6cUASL61Ip6Y5qMcdakXOOOlAtiUYPUnA55oaKNxh1VvqKRM8gf/AFqevUdqEK5Tl0XTpv8A WWceccEDB/SqM/hPTZDlXnj9gwI/UVvITgZp469Bj3FLlT6FqpJbM4+48FBlzDOhPoyY/lWZceDt RRTshDj/AGHH8jivRVxkE/yp6kE59al04mixEkjyW50C/t+Ht5gvqYz/AEqk9lMpIKZPsR/Kvagq n3qGaxtJ1Pm28Mmf7yA1Dpdi1ie6PFzHKp5VgfcUAsevB7161P4c0uYc2wjz/wA8yV/QVmjwZZ3c 7RW13tCHEjSRgonTqeOeRxnPNRKHKrm0a8Z6I82J6jnPrXd/DPTTvlv5FOFGyM+/f8uPzq7e/D3T 7YD7R4gsoHIyvynDfqa6DRI9I02xjtE1rTsIPvBj8x7npRTavcKzfK0jQHpzT1yeajF5ooYb9esg vquT+lW9Nm8LzahFb3XiiO3idvmkFsX2j6bhW3tInD7KZB60ozisnxBr+l6frh0+xu11CEyKqXQX YhBONxySQBwa37ZNFliUy+LdIhkwMo6S5/RTT5kHspFcdOtGcetacGnaRKRjxp4dGexaUEfgUqym hae4IXxn4abjk/aGX+a0+ZB7JmIPT86OnHNbv/CPQ8eX4j0CbJ6i/jXI/wCBMKYPDV6x/cX+iy/T VrYfzejmQnSkjFHXntQcY/zxWy/hjVVGVk0hj2xq1sf5PTH8Oa0nWG1cjtFexP8AyY0cy6B7ORkZ 5/nQeK1o/DXiGUfudEvZR6xxFv5VIvhLxa4+Twrrjj2sJD/Si4ezl2MTtmg/St7/AIQ3xeB83hPX V9zYyj+lUbzQ9ZssC70m/tyRx5luy/zFF0w9nNdDOPfj8aTr06ipXhlT70Uqn0KkVH5chHCOf+Am i4+SXVDCeck0zHrUrRSAZKMB6kGozgZB60E2YxsdsflTG5IJIIPQU8jHpTT7Hr3oHYY3v+VNxwDw eae1I2cZwKCkRt93BPvTCSDn+dSN15/Wo3x1NA+hHIQcnAzUfQkEZp7kZFRu3HI5pAmRv6nFROAT kGpD7nAqNumSe1AyNuv41E4BOADzUhGB1FRt90kZ696BXuRtz7YNQsPU1K+elROOcZ4/lQDfQifg cH9KiYjHNSNyfw7VG5A4H1oAdDaXFx/qk3c4AyMk+3rVSZWVyrZDL1BHStbTLmCKN45uCejZ4qtr EsUsyuh3NsxIfU5P9MVNyou5mtgLz+NRPjrn61Kwx0xmoZCQenPqadi0yygz+FSjA564qJD6+n51 KvQdSKszaRMuCp7n609Dkdu1MG3aBk4qRT19vWgmxKmO4qVevJ+lQrkDNSoT3PX0pB8icEZ7/nUo IA681AhIHP8AKpFbuOe1AmidPvAn9alUcdOagR+akV/zP5UxK5ODyKeKhVxk9qerjPBpAS9MHNPT 0BqLnA56U5SPQ4FMXUmXODg96VeWwKYvNOBA4HSmD03JVGAc5pw456VGDk8mng5HXj6UgSuP4HOe 9cJ40ivtIvDfWk8iWd0w85VPAfsa7r1/nVbUrOG/sJbS4G6N1wf8amS5lYunPkkeZ3Wo3Nzt8yUk KMKM1D5rHPNNmtZrC/k0+6YI8fRj/EvY8U0bc5znHHBrld0eorNXRMJCepx+NPWRgMZIHaoMjHXO acOBn+tIGkSTOxw2SSOp9KmjnZoVO4t2Jznmq4O5SCOe1MhY7ivY9B70xW1LXnu3IY5py3M3Teev rUHPBOQcZ6UhznPP496LhZMsi5mB++w49aljv5V4LMD3INURJjkj9KGcdWX3ouKyNAajcb8iaQcd d1PXVb1SCtxJx6MRWaD26k+tOyVXjmi4ml2NqHX9TjbK3txgejkVcj8Wa3FyNSuQD6SEVzSuVHHf rS7z0AHPqKrmYvZx7HZ2vxA8Wx/6rXr+MYxxMRWhF8WvHluQYvE+oKR0xO1eebuB0/KlLdhzRzMX sodj1GD43fEOL73ie9b0DPu/nV8/HXx1KgSbUoZ19JbSJ8/mtePg4xyOtG47uKOZh7NHrR+M+uOC biw0KZj/AHtItif/AEChfi5OQBN4e8POO/8AxKoFP6IK8mLAYwpyRSs+eQeMUczHyI9a/wCFm6a5 3XPg7RpcnOArx/8AoDCrEHxF8Gs4Nx8P9OPrtvbkf+1K8d3DPJI44pxcAhuRT52T7NM9uj8f/DGQ bZvAEqEjkxanKMfmxqxH4p+Dk5Zp/D/iG0U8jyb5WwfQbh/OvB2fLZyc+tK8hI2k0KbF7FdGe7vr PwWmACf8JXAx75if8eoqhft8MpoG/s3xNq9vNtJUXNipUnHAJV8jJ74OK8VU/MR2qXzR0K4I4FCm xOkr6nfagkcE7CC9tb6HP+shY5x7g8jrUDEZPSub8PRCS98wHIQdzXRMcN14+lawd0YVYpOyGsV6 Y61G2SMkdae3vUZ9O+aoi1xjHr09Oe9Rvwc596kcjHHT+VROcjsTQA05zx/OoHHripHP0qJz7flQ KyInByQetRuMHjgVIcEeuajc9vTjNDBIi5GRnrUT7Tj9McVK5IOBTVimkcLHGzE4+6KLlryKzAHq eKibA9KtSwMg/eMic4ILc/l1qNlgXOZHf02J/MnFFy7MemccDHrUqgZ7j3qBDgE54NTRtg98/Wnc h9icHn0+lPXn2PWolwTyTx0qQYAAzj8aCbXJlIBGKlTrkt3qBc55qVCc+3oKCLdyYHPU4NSIQBk4 qFMipFP59jRvuNkqk+nvTwce/wBajVvc/QmnK3PINMCcdwP0pwwaiX3NPUnsOlIXkSg4OPepVOOM 1ACccHGacDn0oDcnRux4HapA/fGBUAIAzg/nTgeOKdwe5OG45HWnA9ieagQk9jmpF9zigWxKDnPN OBzx+lRqyjtn60okJAAPGO1AtTnPH2iteWYv7dM3NuOgHLr3FcBGylQwxyPyr2IncCDjng15r4v0 saVqvmRLi1uSWT0Vu4rCrDqdmGq/ZZmq3rye2KeuMVBgjaSOCOM04NjI6D2rnO65NnGD+NNkODvX pn/9dN3Z6Y/OnqdyEdcc4qkTJdiQyFuXJbjAyaQScZyKhToRg5HSnKcAYGD0o2GtSUMeBxS7/YVG p9OPQUoIAHSgTsSllOAFA54xRlcHIHTpTOAR2pwOSB2+tFxDiU7AU4bQevH0pF55B6H1pBk9hTEh 4KnoaT5QcZxQB3HAzxQF57c9SaLhYBtx1A9aNv8Ad4A9KCpz14x096UL2DE0Awwc/hTSGBwcYxT9 rEgU7BwOhoGR7WI5BoyR1qyFbZnHA9Ks6bY3moStFZ27zuiF2VVycAEn68A/lSEZYY/h9KRnIPJ/ KrLvEDho13EdPSoJWUkjbigdiMyEd+aC/wAo56U1yDyMj8e9LCvmusa5yxA6e9AWOv8ADaAaYjFe TknIx3/wxWl0zUNpGIbZIwfurjrTnPOOldEFZWOCcryYjMMdzjrimFsEDH6U9UlfISN2+gPFNZNv 35YlPcbskfgOaq5CRE2OcN2pjEAAjn6dqezxAkHe/wBBgfmf8KjaQZGyNRjqSSc0DtYjJOfX2prR NnLKY1zjLfKM/jTnmlPG8qP9kY/lVdsZz/PrTHZD5I4lHzTpnHSPLH/D9aiLQg8Ru492C/pzTGI5 PT14qJyc5BPJpWEl1JPPJIKLCnGM7M9frmoJJXIKvK5B7FiQf6U2ToTkj61Gw9unrQ9SlqIx9ABU THrxk05qiYHuQffNCKRYQEjvj6VMvUnt061BH8yg59xUqdOecjFMmSJlPHAxzUi+nWoUPIx+NSD0 9OaZOxYHbHXGaepwSQTzUIJ4x17VIrd8UMmyJ8nIOeakByf8KgVvc1Ihz6D2x0oETZ9eKkUcc1Cv epAT049qVwWxKp45p46dTio1B65xUi8dW68cd6aC47J44qRctwASKiDAdBjNODEZG4nvQKzJVAHU gcfWpQwB6Z9M1XBxmnofXH4mgLk+84AJ4x0o3epzUIx14p4x6fWmLQkVuM9acrL61F0H9acG496N waJQx61R16wj1XTZbSQYJGUP91h0NWlYk/8A16VT70PUa02PJJUuLed7acbZIzhgaaGz25Jrr/Hm lAqNVgX51+WYKOq/3vwrj9pxuxxmuWceVnpUp88bkgYDkAcGnCQgjjmoeMcHnpSkjgGoNCViEmBO dp/rU7bCw2gqMDjOe3WqzjdEGHValhYNEMduKGNabj8AADNIPTqKM/xEU5ePp2oFoKAR7g1Pb2zz MUiG4jnioRn7vHA9Oas2lxJASYvw4o9SWyJRg475p4CkYyPypoBJLd+pNLtGMdutMBw2k8YxmnOF GRkH3FRbe+c0Knp+FAywkBddwxx3zRsKnABqIRsSOTnHOacqyhchvyoFaxIVKnPP1pmSB2A9qfmY nlmNWYILiUbkt3lQcEhTgfjQDdio0hA25/D1oS7mhLeVIybxg4OMj0rQGnxtjzpYYAec7934fKCa R9NsOGW8lc45HlhR7YOT/KkF0Y8j9T+NR7iWGASa3PsUaLuh+zbh/FKSx/Lp+lZ81xeQyPsuPLLD BEPyAjHoMChj3IvsN2OZIjF/10ITP/fRGfwrR8PWUL3iPJcIdnzFI1JPHbnA/WsYnJJZiTXReEoi IZZmH3iAOKpK7Jm+WLZ0TSRYASNyf7zsMfkB/WmedIDlBHH/ALq5/nk0w8dT+Gajc49jW5wXsErv JgO7vgcbmziomwO1O3HHToPWo36e1MGNZufYVG556ZpXHocfjUZJ56Yz0xQK9xr5x8wx70xsdvSn M3TnmoycjgH+eKAsNfBHp71ExKjA9PrTmOOSR+FR7sfn6UFLQY/4DJqNjxkcn3p7cjJIPXFRP0yR RcpWGucdSSaicjp3PtT35B4zz3qJz6nFIaViwhwM/wBalQDbyf16VAv4dOM1MpIB469jVCuTJnPV akjIzjoRUCt3/lUoIYflQS12ZMuTgnk+vSpEx2IzntUKn+6CBUynBBznnJoIJFKnjuO1SxA8dQKi Ujt29ak3H15oEyYYB5P4U9WwDjGagUjFSKc+tAtCUNjk807dz3x3qINkcHOaeD/D+dMehMuemMU4 YAziolPGRn8Kdk/TFAWJQfTinDP+RUak04EYGMZNAnaxIpBx+VKDyPT2qPJ/HPenAjOf8mi4EgOB Sg1FuPQHFKp560BsS5wfSnBj2qIE54696dkcE0AhZVWWIxyIGVhgj1FeZ65pz6ZqD22d0Z+aI+q+ lemE8dKyPFWmjUdOJQYuIvni9/UfjUTjdGlCpyyPPlOeCM04Yx06U0L04II4II6H0pQDjg+1cx6V xyEA5wMd/eltmEcwVhkZzjOM03OO/wCNNc7lLDqp54/KiwPuiyMdmxmnDO7rnNMUBgGAyODmpowf b6UAOUMcncM+9SheMEqfei3hknbZDFJI+OiKSeOelWvsMiokkskMSuSPmkG4fVRlh+VMm5XXAH3q dsBPbHXrirq21mmfMnklKnkRJgEf7zcj/vml328ZfZZhgfu+axYr/wB84B/KgNCrDbmZtqbfc54H 1rUOg3yqkhjjWN/uyM4RT+LYqGG/uFdtriEOACIlCKceoXA7Uk0haFolyWfAP86LKxN3cng05DtB mjYfxeXlmH5gA/nUq29jFx5UsrhurPtUj/dHP61lraysMZOKsQQTRn5WP88UDLhk8rd5VvBCG/h8 oNtPsWyR+dQXdxNcSb57t5XAxmRiSBTwLrPzSMV9DThbluHUfUUB5lBjgEMVz7GoHlPqPwNa7aTB Ly0jI1VbjQ9pxHeBifVSP60hqyM4zOAQD+FVZXJY59Olad1olzDFuMsTDrgE1lvCy5DMAf5UaMaI eS2B3rt9MiFvZRRgEMFyfrXJaXEZ7+OMYYbsn6V2Rbrz9K0pK+phiHshzkVGSDyc/gaCy8dc9c1G z/Wtjl8xWbANRFsH1PXpQSOSCAKiZvmz0BoAVmIz0GOtMbI5Jz7UjN83B/Go3YleAM9cUgAtnvjn 2xURz3JPpSsQAOajLHOQ3HqO9MewNnrkA+nrTCVIpGOD6UxmycE8DpmgYjMM/wCQKiZvWlY8dh34 FMYkj2pDtcYxBPA/KmHnv+NPU/l61GfpgUFbvQsMjRvtdCjdwaehOfemTTyzt5khBPTGc4pEY457 0J6DcbMsIwzz+NTIeOmfU/jVVWOSOfyqQHqSelO5Fiyrc4PPtUinHXHXODVZT7E1IjHdg5oIcS0r 4yc808N078VWUjPoDUqtx/PFO5NmTIQeT3NShuh/Wq6HPfOKeGxzRcUtSwHBHUYNPU+2TVdZMng/ Snq3ORz6GgCcN0608Hge/vVfOO4NSAgcd8dqA6kytnoPrTw3c/jUSNxjNLu5/wA80wJ8jNOcYY5P bNV1bkAHjvTi5bGTz0oBXJQy+ozjNOB+g+tRA5yT/KnBvXr09KBEinHSlJ78VHuHtjqKM5HQUA10 RNntQCc88frUO9R1bA9zQsoz8u4+9K4/I43xfpws78XcQAhuCdwA+63/ANesUrjrXouo26XtpLbS orK44JJ69jxXAuZraWSF1WKWN8Ngcg+x64rCcbM7KFTmVhIreZk81YmMeQC235c+maQyXEIawupr JIWfKbYlMj5/21XkD0JpXLyMWdiSeSSc0hhV2VmHK8qfSoN3qS2LWSSSxETzxgfITiM59x81aKzq p/c2lvGdu0/Jvz7/ADZwfpisV2ME6sSCr/eOOa1Uj3D5fu4Gee9AiVpbiWNIHmkMSfdjL4C/QVBd ROF3RS4ODwFJJNTxwORxt/OrEULjGFHt04pD2IrVQI027jwCdx6NgZH55qck7egxU9rEo3Bl75pJ zCikkN60xXKjtkfdHWprfbkYiJPcimW4DHrjngZxmtmyswV3MUUHjk0rCuJAbdY/njcjHYZqxGLd ugwPcVet7BHHG0596nFgAduAfYUwM5ooGGY5Vb2xUMsbLyFz9K1Gs1QZK4/xoCKvJFAHPT3Bj5YF ee4qk98NwO8YrrZ2t9mHhjb6isaWDT5Z9zW0aoOqqMUrFmPNfAx4D9Rmsydw7ZB569a6bUNO0ryy Ybfy3xnO8kVzt3AiEgfnSbKSZd8Nwje9wcEr8oNbbMDwDxmqWkwiCyRTjLfMfxqwTXRBWicNaV5s ex/Coi3zYJ9qGbjPr3NRsR25z2zVGVxS/TGelMJJ4PYY6U1mXI9aj3Z6H2oAcxxxn60zIAyOTjjm kdjj2z0FMJ6jp6U9wWoMwIHQY/Co2GMd8H86UseBjrxTGJ7HgDpQUkDEZ2nH41GSMHgCgsOOpxUb YK9P6UD0QpOSecio+OmO1OLZx3qN+ef60h3GMc8DoOaYfUU84znNRnPI3H8aBrccrHHBOTUiE55O BUAJI7c09c545pFbk6thuD+lSKefl7VAhzxxT0bnr+tMm2pYVwB/WpIzu6DvVdThakBPrx6elO4m uxYckMRmnhiD1ODVaNuvP5mnq2TgjB68UybXLStjgscU9XII5/SqyHuP1p0ZwQC3XqfSkKxayOCC M04P3yagYqDiMlhjg9KcGI9PWmTZ3LSNyBzT9+AATVRW6L078mniQAcEfjQLbQtBz1z+lOV+Mk/W qglTjac+uKerkkbUP1PFIaRbVuAM08Ng9elVBvIPzjHsKeuCfmJb60yehOZQDyetG9s8Kx54zTFK 9hj6U4MCecCgQ9TJ32rn0pdp7sWH6UzeTz2o30D1Jl2gYAAz29acDgdOB+lQhgfT6UbgTigomz9D XM+MrEBl1KMEsMLKAO3Y/wBK6Hcf6UkqpLE0ciKysMEEdamSuhwlyPmRwCLkD5sc+lSqDweCa2NL 0zQ0W4t9V1i9s7qKTESx2Syq6Y4JJkX37Hp1rVbQPDLQmSHxlCW7JNYyRn9CQPzrDlZ38yschPCZ otoGD1FXdLYmDaxOV4+tbj+G8RhrfW9Gm4BC/agh6/7WK3dU0PQx4RfVLa4tba+hKZt1uo5HlyQG wAxOBknPoKLE8yOSEeRndgGp0DAZXGeoOaEddpCsp/GpYV3jDYIpALASJfmxgjg56mqOpTZm8lOS D25q1rbmCx8xOSpGAB+NZ+h2k12ZbmYFFyNuRyfWgaXU0bS2+QZ61r2lgH2kgkDoSKoKoDbc1sWx YxhdzL9DQhFtLEmPblsHqKnS2kjXCsw/HmmK0uzAmYe+easwyvjmQMfUrQHQgQsG/ePJinGKJyN0 hX1xVuNWcEtHER7cU2eDI4jXjp81IaMi+0xHjZo7zaeuCua51LOd7sxxzocdGbgZre1Pzo4yFjfH rXO6fK11cOEHQ845/lQy+hYu7W+SM7mjbA/gbNYrxPLcrG55zXTSBkhKquSfXise3VzdF3TbgelQ leSRWkYtl8uPw9qYzD8/500uMenfpUe70+ldh5jdyR2A47ioy/I5ppOeRio+ex6+1AbscxAOMdaa W5FNLA555J60wtge3fmmVsKxxgZOKY5GeeaRmz3z9DSE8c+x5oQdbg2ducimEkkAD60ORtzkdaYx zz15oGrdBCeaYSCSPzpTjbjpTCQM8HPWgfUVzk5B6/yqLPGOv0pdwDdsH8jUZYAYpAwY8dOntTWb HIPXikGWJCgn6VKlqcAuce1OwXS0Ih0+Xr1pwwMEggVGMfe9qevH4cipLuSrwMf/AF6d2AINMBGc ZApyk/5NMErkuc9en1p8eCB1/Go15x+op6PtXJxkn1ouLoSHoD6d89akUkgcn6EVCHHoc4pUeQ4A GO3PrRcgnVvUDgetPDbcEt+feoOSeWP0AxVAyuznDNjPAobsNR5jXMgGR1+g4ponVcDI/E81lbiW 6nNPBz16+9TzFezRoC4XcC0hP0FTRSxlgGAznncazRjeq+pzx7c1bCjOckc0czB0zRDYAxkenNOD fn/KoYjlBg9eD609T71dzB72Jg56/nTlc9s9ahBJ56mn9QOQKEwsSiT5sDOfpThIS3TrUI4HBGPr Qpbg4HPegPUn3ZNODd/f86gDdv1pQ2ST7UXB2RNkbs54/kKUP744qHceOR+NO3c4NFwdiUOfX9ac D2JNQFuoo3nGe9K41psZviS2DxC9UZaEfP7r/wDW6/nWMOcEHtXVkggqeR0NcvfwGzuWiIHlnLRH 1Gen4VnOPU6KUrqwwkqvAOe/NOjmbPB/DNU5ZMLxn696jWY9f1qDdGwkxwPm5xVu2mzjJH5VgJPj BBHFW4LhTgluB1OaQWLHiuZf7FkYFgAyglTzgnn61J4KuvM0WTczssc7JFuPITAIH6msvxJMG0iZ Rg5Kn9areD7gx2E0e7jfnGPYUBY6wXaeecng9DWpb3sG3aXYe+a5drtMAsg/Knx3NnnBjwPQHFAW 1OwjvISpxOefXmrNnNwB56t9RiuMSayPVnA9mq9ZvblgY7qQZ7Eii4JHewMSuSikdiDTLmWOPIYE D2FYlrdyxRDLJIMelF3qdqVHmExse2DUjsGpzxPE4EmSRgAGuf8ABsIju7o/aIpEDY3RtuAIz36H 8Kb4ru7YaLdPBcDdswMHHXiqvwqSJoby9k8qGJmWMDPOVXk4JzzuBPbP5UnsVY6u+lg8ohnzxjNY zELAcghy2R64/wA4qfWbmHcyR4+bjIHQetZ0jnjA4qqOsrk15OMLLqOaQDkD8BUe8biD+PNDMSTy KYWIH8q6TiHOc9CTjjJqMtng/nSM2Pf3pGPsMe9AlEUk+gFMzz83akJ9cfjTGODgUDuOJwRkmmE9 s556UFs//rpu4A5I49qY7IQk9OtNPU0hJyTTWbtnjGaBAT7c+tMbk9cfjQXz05PSnRQMw3NgCiwa dSI/McAGpEtnY7mIAq0kaIMKB7k0/BOe31qkiee5CsYRQFUfjTypJ4Az70//AHce9IVPVuv86aJu Y6k+1P3DH86iAODkn3FPAFZ2N79yQNj+HP04pwLEDgAUwYPHGR0qRcdPyxTsK4uQAQX5PQE4qRQu M4HtUTxpIuHGfxqPbNAfkJkX0PUUh7ovIVOCScehFOBAySOPrVSC4R+BwfpzVjdkcdetCYmnaw6d 9sLEc+9UAOnqKmvH+RUz3zx3rMju5gDvTaxOADnn/PNRJ6l01oXwMAckVNGT3FUftRWQIYxtJIyG q9aOkkfmbSBgjrSKtYcEL3StuICDOOxz/wDqq8Oear2oDKzDPzN+QHH881aXGcDoBQhMnQ4BHpUi MC3TJxxzVdCeh6Af41IGA5xx71a2MZLUlBycEH64pynHGetRIQc9BzTwwHGc0yWShuOuPrTlJzx+ FQr09R7U4kA9ePWlcOhKCf8AIpcl23HAJ7YAH6VEDxk9OvtTg3T+VO47Dxz049qUYOegpivx2PPF G4c+uaQuVjxjHGcUDkcAUzdxg0b/AEI/OgNhw4H3unSqWsWv2uzIXmWP5kOO/p+NWicnHTNISTnI ye9D1Q1pqcRKxxgnBz6YxUYY45APpzWn4ktDDc+emNkh5HoayMkHBPXvWLVtDsi7q5JuyffvVmJx 5We9Ujkf/XqZWPlbeMVJa3E1CQPYyj/Z71U8PSFYphuGdwNTXIY27nHG01T0Y4WXn0x+tN7D6m0Z iI+vemC4YDsahBJh4Peq4kIPJpJisaaXGByo6elW7e5hwN0eD6hsVipIexqxFMyjGePTNAHVQaii KNjMwx0LU6XU4ZABJAenY5rnVnPpk4HIp5nk4+6fbFKw1oP8WXEEmjv5asvIwDgZOatfDme1i0mT z8lhMxC/VV5/SsLxFLu0xOgJkGQPoam8MP5Vh0PLk5/z9KTWg1udPdTJJdMYyQg9/X/JqMnjrzUE JBTcSdx53Uu4Y61tRVo37nPiHeWnQl3DpkZ70hfJOPrUYLAnt/hTC2TWhz76EhPOccmkzyTjvUe8 jkdvekL8dDTHbUfntjHFNJPemMxzk03dnjmgB556n61GSDj+tI0mBg5z06Uqxyy9OFPenYNtxjPj jOT7U5IJGOSML61ZjhRBuxuJ9TxUoU4zz1/KmlYiT7EUNukYwBk+p4qQLj5s5NPwBxjjvRjjjrVd TO+o07gRxkeppDkDnp6dqewPTJFIeM8e9MpbDOMA9/QUEclffr6U7pzn1xTQD1HOO9F7DVigLKT/ AGfXGaX7HNkDaCfrV9Rlf6VKgySOppcqE5szBaTk48o4pDBL1MbA1sR5xjv/AEqRevv70WE6sjF8 twPuMPoKNuPWt0DP8IPNOVEPGxfoaLIPaHPTW6ycsGDdiOtROZYlwylwOpHOfw/Oun8mE9Y1/Kg2 9vs5iSocEUqzRyX2iJn3M2DjHNLHJC3V1+nSpZYYZkclAuWJHHI5/wAKzLuF1uUiRSSR09ef/rVi zrVmjXWBJAAURh9KkdorRxBKhTb95Sp+UentWMY5EPO4dhTxPMm93cvn7248nNK5XL5nQQPviDA9 uRjoe9SIAc5BAzWTa6jDNwwCMcd+tacTKygg7vU9qpMh3JPugE4xnHr/AJ6U8Nnj14zT1iadAIly +crUiWN0wH7pvTgVaMJsiB4HA9PpTt35etSGzucj90w/4DR9nlA5RvyoJ06jMnAAwKfnHAIPPNNE behP4UbDjO0c0BpYcGIOAD04pckY6HNNKsDzRj1HFBTWo/ceeuM0bufQfSmkdsGkGQxBBxigNyTf 0o3Djmos4Xr255pTjHuDSGh5cA9AR70GQnJGOaiJ6tke2KNxI5GKA2GXsKXVs8T4x0H1rkJreWKZ omXDL1/xrsCTkehrJ1yDcFuFbO35X45x61Eo31NKbs7GO9tNG20qjnOBskVufwNNdZEU7onUD1Wp DGp7r61DMjBMZ46jBrPQ31IpHAhfOelUtNO1pM4AOMVbc7l7YIqlYEh3H86Y9jSeTFsMgZOe3vVd SCcZFSy3CzwxFE2bYwr4ORnJ5/KoNoz1FId2Sr07VLGR171XwemacrEUiki+hyPvUjNnGBz64qus 20DinC49wO1Jj0I9fythbK4+8SwPqOataIdtmgzx1IqDxfbtaTWkDq4Jt0kw6lfvDPGe3PUcHtWh pB2WaBl2/Ko6e1D1WgtndmoD8mG6+1BbAxgVBDOkkKujdRyMdKduGPqa6YtW0OOSd9dyQsP6ZpNx B6VGG9+M0E8deMUyR5JwAD9aYD1wPrimk4OM89OtBVypKKXI/wA9aewATtODSqskoBUYHqakghG0 M/Oeq9hVoDoCAB6U0iHPsQxQIhBOGP6VMASRk4HpinAYIGAc+tKFGMnA7DNUQ2hvXHc04YPUZ4pe QepPtSYH3uPYUyWC4Hv25FKc5JHTJNCgj5vr2o5wSKNgSsJwM+tNPfBANObGevakxwB3/pSuPUac 57/lSZHX2pxz+v4U04HBxg0DTFQ/KB1qRCOdwHIpiHsefT3qRcH1z65qidEPTkcYqVTzzxkVEpzj gYqQfXii5A8YxnvUgO0j5R17VGAO/UVIDlTnp7CkHmhQD3A596besy2crKDnaelSLxjjP4U/tzzS 1COjOaSB3TcNoPX3qJrUtLvB2yKMBvb0rqbi3hlQsgMchGCQOPyrEuLe4tm3SoCpP3h0NZSjY7YV U9CvFAXBEqAjvj/Cq2p2cOUWKQANk49CP/1/pV9SSdyYz0I9ap6m6y3PH8KgEdPf+tQzUzZLBgAU ZSfTNPgN5A4C5bv1p7ZHQk00MwyM8+1Iq5uaTqqKyRMrRyKdzEjg/wCFdDbavZs+DIEJ4IPQGuGh Zgc5z71YDkgA4x9KpSZlOkpanoEd9ZkEC6h6f3xUwmhblZYiP94V56NpXkc1OkDNFv8ALbZ0J7VX OR7E77ajLkBSKDBCw5iQ574riYtPlaA3AyEU4znnmgRTIcJcOPTDGjmJdJ9TtDZWvRoFz7Ux7C0A P7kf99GuRU6ghytzL17OalE2qAD/AEufAPA3UcwnB7I6YaZaFM7WGevzUxtHtz0dgPr0rnxfatGf +PmTjpkf405dX1QDIuBwenlg/wBPpRfQfs33NptGQthZvzFRvosg/wCWiHnHIrK/t7VV5Plt9UqR PEeoJ8zQwAeu0/40roapy6Fx9EmHR48/jUT6TcjqqHHPDVG/ia7YYFvbk/j/AI0w+JJ0ieSS3jwi kkgntRzISpzvcc2lXQBzHnHcEVXn0+4ZWDQNtIwRt61p6Drceo6M9/NthEbssnPAxj+hFY/iLxQn kbNJky5bJkK449s0NpasFTk3Y5u9je2uWgeLBQ8deRUDPAygNC+7PJDgD8sVb0jTb/WbvyrKF7qc kNJzjGWAyST6kU/xBot1o1wttePAZSuSsb5Kex965+bU7+VpGS0TeU0gB2Zxz2rLtvlml+hPSuit IZ4lDmPKOOh7+2KwWXF5cBV2j5uPTmmmJrQuFPKjEQQcqjbgeeUBx+tRxjnOQavavGkFxJCrBjHK 65xjhSFH/oJqjbHINMWiH4BPakwCOKfgj198ikYgdx+NNgMYehxTASGG0jI709vzBqG4P7sgd6Qy TxGSbyFWcvi3hzu/65r/AJ/CtRzbCDbHvOAADuOR+HSsjWkkTVfJcEOm1MH2AFbcFv5ls5b7u7qA aUmVGLbsLp4iRpfNuVQKhZNzYHHJH1qeOVXXcrZA96ZYW8komCJuUNtNRRQPBqTQgEAruC+hz/8A rq4XirmNTllJrqi2Ceo5pyI7EbRzU0UAHL9c8AdKmGAuOMA+lbpHK5dhkcCj7+G9wKn2jAA4AHT0 poJPIGaeFz15GKexm7iLycrTtvy7qXp0Bx7UueNuDxVCbYLwMgc49KXI+g9DR9OD9aQjuQaCReg6 80i9ecfSlI6DJI+tJgBtuBmgfKGfegHjjj8OlGSQBzigdgMZoHYTHAIFGGzwDz3FKQcjnntQ4G7q OnpR6DtroNIzznP0o5x7mlII64oPPYfhSHZjRjI7fhTx0Hp9ajXn0I6/WpVGByMZq9jNscvBB71J g46dfeoxjipF3YHUjvmgjceoBPGKeuc4ORTOAMk/nUg6dBQK2o4HPpUoOc/zzUY9P609SMECkx3t sSAAfSlZd6lDggg8HuKYvbnJNOGR7fWgcZGNdi3eby7JSJwpZ414AA68euSKxI4rjUIJbq0tpmVX KMMckj269CK6+a0hnbe6/OP41bBH4iq1no4tTiC+ukjySVDDHP4Vm4XN41uVWOXaGaNR5kLR57Mp FIFYryDk9M1182lQzoyzz3MobsZSB+lRHw9YiPZH5qEZIbfux6DmpdN9DRV49TlkHfB5qRcjp+RN atxoV5Fkx7JVHZTg/kaznR4nKyRtG3cMMVDi0axmpbMch5Hr/OrUbvgpu+RuozwarpnHp71cspRD KkhjVyDkBhkfjSVxsniLlSpZgvXGeKcFzgD60jSb3YhQC3OAOBzUiHJ+YjHamSPRee30qxEnIH86 ii5YDqParaKBzihAWI1AwMA8dxUyW8JyGt4mJxyUB/nSwxDapwcYq1BHkjIHvTAhOmWcvL2oB/2e P5UJ4bsJOss0WfbP9K1YgSMAdelXbZe+OPSgGYi+DIif3eoRke8WMfrWT4n8IajFoV4bKNLxgFys Ks0hBYA4AGSfX2zXf26bjz+OKuRoVJ2HnpxS3EpM+do3vdN0m50u5hmgkkmRgkileMHOQef7tU4l U8Z6819U2duXj2SDfGR91uQfwNJ/wi3h6dg8vh/SmJzz9jQH9BUuFzSNTl6Hzv4Oubiwvp5raC5l maIxoEkMaqT0diOflOCAMcgHIxV24066nuPtWp3DXVxgAkjI4r6Kt/DGgtFHC2lRCJOUVGZQv0AI 49ulRXHw88P3DGQR3MIP8KSDb+oz+tLkK9rd3sfOZCrM3mIfrj2rlEiE3iMwAfLLcBD9C4r6lT4T 6Vdvcqt1IhDARnbgA7VJz1yOvpXh2qeEJLP40jwqZQJWuo40kQnAd0VkP3cnBYdufUdRPJYrnTOX 1SZLryWEYDLGQ5/vEuzZ/wDHsfhVKzTEeCo69q7jVPhh4305cXXhnUlXqWjgaRB/wJMj9a52TSry CTy3gYOOoxkj61STFdPYz2UFehGOBTBGzHao3H0rasNEv72fy44G4GWODwPU+1bNloUcGTMocjrg HB/Hv+lRKVi4w5tznofDlzPbCZZI1Y8hWyM/jVG60TU4YhNJbMY+u5HDgDjrgnH4138kTHBTnHY8 8elZeqI7WzeWCqtKiSdcAlh/9esvaTuaOETlPEvmSeLrjzFKsJgCCMYwAK3bO3IsFkBADE5IPNRa vFBd/FG+jcF4ftcgAJPQA4/lXUvodvJbstrKYeOhyy/rzUynZJPsXGF5O3c5rTb63tgYZSAzOSWP QccD9DTDcwrq958scpDDa47YGDg96tX3hySK2uJLpFkVcFWjJOSMnkdcciudtm/eTffCJ1ZFxk1s 6jcVYxVFc7b6nQJNC4BDgZ6bjg1KEXI3HPGcVhxzu6AOZGwBgHnAPI6/n+NTwSyRMkiOjKh+4+QC PQ4I/wAar6w1uhPBxfws2VyTjt9aco7ZxVC1u5Hjjt1gEkpc4ZZCS2egwauwMJIFkGQGUEZrenVj PY46tCVJ+8PAGOKU88E/KO9BwASep71XjuY5L57VCWdF3Mc8DpxWt0YpX2LPQ4zz3xSDBXIGSPSl Az3x3pO3bmgVrC4J7Zz7UYPPrSocAr0BzSNjuQc0XJsJ1IBz9aM/Nx+VB4x0zSH36CgeyF79cmgn PAwKGA3c9aD2wOvSgdkGcA4/+vRkdvXpSr2A7+1G3Hr659KLlryIhjnB/pUg6g96jGAu4dKeMgDn Oe1WZNEqdMcY9qcnUAYpgPcj/wCvT1xjjHSkZkg/Ak1IMgd8VGucAg4qRSCPUenagLokHXHXtThz 1Hemg9OOlSA5HOR7elAtLCpk9f504DJyaT2xSrk85NA2h49xzThnGB/OmDpz1AqVODnGM96BLVij nGM0vbnHvnFPUZ6jFL+IpXK3E4I4NJJGkilWRXU9QRT06+mKftPpk0NhYx59Bs5W3xeZA2eiEY/K qlxpF5H80Xlzjpwdp/InH610hUD8+M0mPb8TU8qZaqTjpc5Bw8MhS4jkiOTgMDz/AI1Ojg8qQO2R XUOiupV1DA9iM1Tn0m0mYMimF/WPj9OlQ4Gka6fxIz4DzjtV+3AKjgVBNpV5CubaWObn7r/Kceme ajtrmeByL20lgCtyxOVP4jrUbbmyaexuwqNgJ7d81YhXjOeKoQXKSKNroSxyADjj6Vpx444xntRu UWIAowAc8cYq5FkfSqsWMcdasJuzQJl+E7WB7+9algpEe4jdk81lQglM1v6bmGPsTx1HtTEXrWGd 2GUwCO9bVnDjC5H4VkWxuZuEVjzyfaty2BhjzKdu3Bx3oAtJtXA29O9Whhl4HNZc04LogbjGeDVr 7QywgRsRIeM9xSGWbFxvbaRlmPf04/pXhmtYtf2u7WaVcrNNAFJ5+9aqgP517l4Z08xwM0rOW86T Gf8Aro1eO/Fa2+yftO+EJFUA3L2JPv8Avyn8loKj1Pou1iUsCPSrjxK8e2Ugp1O88D8+Kr2sLxRB pHBY9h2q8kMjbVeMGMgl8559B/PPXgYI5pCI7Syit2M8KeTK4GWQbSAM7ewOeT17k+1Q6vZJfCP7 ekV9GpYMl5Es4AYAZ+cHoQvPYZrR2EnNNcZBVlDAjBB6EUikcR4k+GfhTV2Mi6NZafLtCh7RGjA6 8hFYLn3INecfEP4P6Tpvh671Gzlurh4XjaKM/Mxy6jG0Y3dfUfhXvCO3llZDudTtJx19/wARg8VB OqthjggHODWcoo1jJ7Hxj8PvBb638YfEGlwO8yacbkhjjLhJRHk+53V7T4j+E2nx6JJfaNqd3DdW 6bp7a9iG09yUkGMjnGApOR2rkf2Rt998RPE2sOcebasGLDq0kyv1/wCAmvpaUHPBA9MCocUa8zUj 5QuvD2t2Ble70+XywxDSQkSxjAGfmQkfrWNfaBpOob2u7NBKwwXUbX/P/Gvp6G4tdN8dPdGSJY0j /fJMf3b5ABXaB3X6jP5V1t14e8G63pSHWNIs7UTyb4/LiCGMEsAwBHyggcnAB4PPFeHVxPs6jjtY 9BaRTa3PiaXwvpUEcsdtK6l0wDKN4HT0246etcrqGkTRxO8MlvPFGGKywndvx/CRnj8DX2Hqvgr4 UMJLiM6pNAoJUINn8JbA37c5A7D057V83+LdX8A29y0fhW11mODcd4ukiUk9z8nHOK1w2KdWTUbu xU6aUdrfgec6JdXVtONSW1Rzbv0J24Y8D9f5Vv2qMlvHG2QVQA/gKim1OyucoYSCGDAnHJHSop75 DpRuo2G51wo9DXs0NLyaszysSnLljF3ItT1AgPBacvyHb+79Pejw3blLVrls75T1PoDWbpqNcXAj 3csee+RXULGkSKqjaqjA+laUpOTcmZ14RpQUY/MCCAOnvSDJxTyue3fpSFSM8/WuhM4nF9BozgZ9 6TNL8q9D68U1nXd3GfandC5Gw3fL6cUHk5wcmmtIScAc49aG80jIjf8AKp50WqUmOJwOh69hQSOF PT+VZM+sWkXD3C/ReTWdPr8eT5EBc+rHFS6iNI0JdTpvNQHlhjmoZ9Rs7ckyzD6d64+fU7yfOZSg /upxUMeXYEnJ96xlWfQ6IYddWdu8qxDc7Y7c+tVv7Z077R5P2kBxx7fTNZOspqpsmQKzIeuBnj8K 5ZldG5VlOe4rf2nY5o0ejPUUIOP1qTIHBH1rm/CV2q6d5dxIwbecbgcY4roI5kcEpIrDPatVJSRz zg07MnH4fjT05HP481Eo496lTpnqKdjK1yRCBxUo5X1qJCB1P44qRTxyelIVh5OD0+lPU4zgDHf2 qPpweg9qep556d80FXQ5eSP1p+cj0pinODkU8DoTnPWgFoTLgDrUhBwemDUAPAA7VMCTkdcUhqw5 eT/9enrnqRn6Uife9jUqjnjpUtlxXUaR2yKFA3AE/XnpSzDp1poyD1waYnuWREvGCDUv2ZME56VX ilKjDHpVpJRsPORUO5pFRHRW6NFnp9aHtV+U4zntVi3x5HB4p7DLKDU8xo4poyrrQdPmT/UbD6xn bg+vHFVJdK1K1ANhqTMo/guBnH/AgP6V0MvCGop+g2jPFTa5fM0tDAGsahp6/wDEy02RkHWW3O4c dyO1aGl+IdHviFjvY0f+7J8h/XrUt0MRZPU1kXlhaXYP2m2ikPqRhvzHNWotq5HtEnqjudPjZ7mG MAESNjk8V0sK/JsZgcHFeMxaTLZTeZpWqXlnITkgPlB+HH61vW/iXxzpiIXttN1aLOWYDy5CO44I GfwNTqtzRcsvhZ7BayiONEiGD16dTUN61w8m1T05NcHpvxR0mCZRr2lalpEp6uU82If8CGD+ldho Pi3wrrblNL12xmlkOAjP5ch+iNhj+VFxOLNezsnkZNzfMBk4PNb1hpqCQFySKraZCsU4djn0rcWW M7VUFg/GAOaBFiC2IyV2gFiR9Cc/1rw742wSR/tE/D65OAHezjGD1K3bH/2YV7po7Sy2EAK7ZfLU HPGCFFeNftECSy+I3w21CUAFdSJz7JLA39aC4s94sLSVv38x+Rew6n6eprWjQrH+8A8w8uVHGcAf 0x+FQWrSR5G0nZwR6sRx36YPv1HpU/mq3Dn60gRHJg8oSAOtVbiVk44FaDCFl757c1Se1LzEiTIH brSGZ7SP5ytg7WG088e3X8R75HpVHX78WGjX96+QttbSTE+yqT/StuW2XYY3OAR1HBHuPeuY+KK7 /ht4lbjcNFvA2OORC+evvUyNIbnjP7Glvt0/xLdNwXmt0U/QSE/zFfQpB28dK8e/ZEtHj+Gd1OFI E2qS846gRxgf1r2Z4yADUsd9TE8ItpUviXVf7S0b7e6SqqOwQ+UQWySHYZBGOmfujjpWzr+pJcWs ccV5IjIgSOFVAUYK8swww+7ng9q4KGed7rUZoLYSN9rLiXftEWScZI65x/47TLq+jmhFrb3O+dhl 2X7q4+8CTjjtnuenrXxuNqSlUcen9bnvUKMdJFDxLpOs3+w2ctqbdVWNGmBDuQuGYDp3AGTxgda8 q8c+AZpYZ5jocJcFQLi0kUKD9B1z9O1dV4s8YxWZ+zW9wtw6IABj5VBHfNeXeJPFUlzMWub5pGI2 qkeSAPSrwlKrFpwOirKNveOD1nTZ7F3xlljUklkKkYz/AIVgRxL9kQiSQymRsqfugYXB+vX8q6/U jPfp+8QxWwGSP4j7fU1uw+DxpphtL2GynuztnbyZGdotwyIm525HBI5IzgkEFR9HGc1FKe55MlBy 5o7GRommQx2ULR2xE7qGkckliT29AP8AJzWrHpF3IMrDIfcjFdEbXUfMCKZYojgIgwoA+graTwJ4 hl0OXVF025ksjjdOUJCnPr9cD8qv6zGFlc55Ydzd2jg3010+WWe3hOOjSZ/lVd4LOP792Gbv5aE/ zxTvEDW+lymK4fY/oAc/pXIal4iKsRaQ+vMh/wAK6oyi1uc86Uo6JHWM+mqfuXMv1YKD/Os+81vS rPObeFWHYsXP5Vw17qd9dZEk5Cn+FeBVA5yT1qm49CeV9WddeeNJgCLGBE7btij/AOv+tYOo63qd 8xNxdyMG6gHArONC9ckYpNlJWF5zmlU44pvHPINODegpMpMkjJzVq3UBudvXseapqSTzzU8LED+d ZzWhrB66ncKYycggH1BrNury3GrLZSQo+V4Z1Dc+n+TXJiabH+tcf8CNKHkLrIZG3jo27kV0ykmt jjhTcXud4bO2YHMS5P8Ac+U1G2nLjMUzL9RnH5Vxq3d2p4uZf++zV3TZNTvLxLeG6lDO2Ad1JuA1 Ce17nRiG+iJEVykmOo38/kaet7fQgedbFh64IpviDTtTsNOtzC8jMpPmOpycYGM/jmuaOp6nH8v2 qT8aSnK2jD2UZfEjrotZgOfMRk/UVah1aybrKFP+0MVwL3l1K+55RnHZQKes9wf4/wAxVe2fUl4W L2PRoLmGQDZKjj2apkYc9uK82W6uFO4OQaswa5qdu3y3BYYxhxkVSrIylgp30Z6Gr8889aer9AMV 5+PFGp8fNEcHulPHivUx1EH4r/8AXqvaxIeEqdD0BXO7nHNSrKR/COteeL4u1EdY7Y/8BP8AjUg8 Z34Ofs9v+uP50e0iwWGqHoQnwPuinLOSOnFefJ41u+hs4Tn/AGjT/wDhN5wozYRn6SEf0o54B7Cq d/5ucfL9aBKCRwfzrgl8dSDrpyn/ALbf/Wp3/Cd8/wDIN4/67/8A2NHPEXsKh3nmEcY61JHMQCOx HSuC/wCE8Tdk6awP/Xb/AOtT18eQ99Pk/wC/g/wo54h7Gouh6VbTqiBasNPHwcjivMv+E/ty/wA1 jMPYOKmHj6ybhrS6xjnG05/Wo919TVRnbY9De8jkG0HHvih54ioU15+PH2l4wba89vkX/wCKpx8e 6T/z733X/nmn/wAVSvEXLU7Hb3jqYxtIOfSqJIBABPBrlf8AhPNJ7wXo/wCAL/8AFU0+OtJ/5433 /fC//FVakl1JlSm9bHZYCsgz3zV+4YBY1HPtXnr+PNNU5S3uyf8AaVR/U0h+IMBYbLeRceoz/Wpb XcqMJ7WPSyiuhVwGU9QRnNZN/wCHdFuwfM0+FWP8Ua7D+YxXFP8AEA5JVpVAGMCJf5k0Dx6rPzcT DPBzEuBWd0jZQlfQ7CG117SRH/YXi/WLKGH/AFcDzmSJfbYTtx+Brb034l/EjSERruPRtZRST5kq GGTH1QqP0Neey+KdKR8y65JMG/54wuf/AEILSDxN4YZcSXd9KT1Ij2AfoaOZFcrW57Jp/wC0OIJF TUPBF3aQgfNJbXQkx9FKKMfjXJfHr4n6J47m8J3Ogfb1m02ed5UuYNrR7jDsxhiD/q24B7VyEPiz wpGvERcjvIJCf0xWZ4g1nw5qUAaIxQ3CHKHyX59iealSlYpKNz7f0Hxv4M1GytRbeM9GlJjX5Zr+ FJ2PUlkyMMTknAAyeBXVWsUNzB5tvKskZ6OhDKfxBr85dPmsL0h50JUDBCvtZef1/Gti31K00a6M uk+KdS0ydR1iMisP+BLg0QqKXqXVw7p26ruffrwzI+1VkbHoKt6fA0kw3nafQ18O6T8Y/iLpUUg0 34g3V76LdRfaG/DzkbH4GteH4/8AxNjgMM+vW0k8n3X+wQ+Yv0Cpt/MVbdjJQZ9u3Wmo0WOM/wC7 XlHx/Y6H8LvEdwwZo57J7fcBwryYjAP1DHk/3QO4r59g+OnxStplnutW82NTkrcaREiMPcpGD+RF P+I3x21Txh8P7zwzf6HYwte+WJby1mbb8kiuMRtkjlR/FUuSZcYtM9t/ZktPL+C2hvFtDTm4lYZ6 nz3X+Siu81m/g0iwlvdSniht4tu5yc8lgqjjnJJAHua+ZPhn8bNR0DwfYeFdK8NW181grJ9oluyo Yu7Pyo6csR15x2rH8Z/HHVNan+x6hpmj25tJt4WMz4EiHKscS7WIIyMgjOOKzlNbIuNKV7s72/8A GE2hC5toLlYhdqBcHG07eflx64JH51z97rOu63ZiHRLaSCz3YM8kqxxk4PG5sKDweM5OK8p1TWUv 9VnuNY1VWuGlYyRr8oBzyPb8K9w8AfHTwlpHwmvfBer2X2geRKlm8IUqWbJG/cQRhyCGGSOOOK8m pl95c8up6UcVZcsEeN67aawI0a8mWCNz/qkbLfif/wBdZ0EMcR4X5v7x5P50/wAQ+JrCWR3aZpmP aNeg/GuXvPEc7ki3iWMercn/AAr1qUIU42SPOrSqVJavQ6hn3XSo2BGnzOT0PoP616n8EItF1nxn Yafqd9AEml+Ys4OeCeT7/wBa+dJb25uXBmmZu+M4H5dK0tI1aeylDwyMhHcGuXGRlUg1E6sNFLdn 3J+0B4Z8NeGNCs9V09IrWdphEId2fMGCSwHXjAB7cjp3k0v45eCLH4cx2txGxvo7UwGxWPKSNtIy W6BT1OeeTwa+OtT8Z6tqkcX2+/ubgRrtj82UttX0Ge1VLaS/u4fOjbehfZhTyDjP5V58KVb2jnH3 U1ax2OnS5Eqju0X/AB9qMepXVxOAAx5BHbmvP7k5PGeK29SuoxbTwzLJHcqygBu47/0rnppCxz2r 0sPS9nGxzYiop6kbj1IFRkgE8ZFSwx+bJgtge/pS3cCwspQ5BHTPQiutbHC2QMx7cfSmk+pyKXnJ 45pDnHWmSIM55FOBxzTR+H404fSgEOXtg5qRXI71CPbpT1OPapaKTEDpThIhHPWottAHPAq7GdyY SrntVzS9Ul0+4863YKx4ORkdazwoPril2Z6c0WuO7PQLHxzC9q63USmUL8uOjGuMnn82ZnZ1YsSz EHqaqrHu6Kx+lAi77HI+lJId+pcgeL+Jhnr1FTedDjCkfnWaIiTnY35U7yhj5vWocTWNWytYsySL 1B/Wm5Lj1H8qgMKjJGaQxAcg/jinbzFzN7osMoGMZz6U0/e56+4qHYDSbfw/CnYkmI5yAfy6Uhz7 561Dj3xRj0NOwrkpyDwDSHp0xUXc84oy3HJoswuPAz0B+tBBHqBTc4/Hmkye/T1zQK48Hr6UE0wZ B4PtShm9T+dAXHZ+tAyaaCxbALZzxitOx0PWLxsRWkg6HMriMfmxFF7BczhwDzTk5YKOrHAHvXea D8NLjUtn2zxd4V0zd/Ddaku8exC5re1v4U6Rp0kc8nxD8ORquDsjaaXJ68HYBS9AUvI811vRdQ0d oRfQ7POQOpByDlQ2M+uGX8xWepPHWvSPFVhb6xJbW1v4k0b92S2VWZAzFUUn7nOdgP1Jqj45+Ffi fwfocWsasYFtpZWhA3PHJuU4b5JFUnB4OAcHrisY1bWU92auHWOxwrHkYpF6jjj0pp3DqW/CkBb+ 8fzrczbJc5B46U3d6fjTQzA8E/nTQx45/WiwXJNxFKD25zUe4+ppQWxyTmgCQHPFODcenFRZfONx pMsDnJosFy1bTvDIskbYath7uDULMiUbZE9Oo+ntXO7j2JrR0cZlLtz2/rWcqabTNIVnGLj0ZrW6 pDAdxKxqAGYdSf7q+57nt/Nst/KzfZ4iIIGcERoSAfQkdc8kZJzSXcqrbw24IUFAxYA4LN83fjPI H4CqiwNIUTDeYGDBlBOfYAU7it2JIZ3LkpKSRjJUkEcYrZjlF1a+ZdyZuGY4kxggdgTn5hnOc+gw eabfeGNYstL/ALTnsZ47O4kMcc+MoSDgjI71ReVRD5S9htHHB46e1Zzk7pI2pU4NNyI79biAu8Dt A33WVHx1+nUHrWIXPGe1dBKVmso5ACzDMZ9f7yn+dc/IjtIwQMa0RjqBkZiWY5J5JNOEp6A9Kr5I 4JNCtjoTQ4gpE43OcYJz7UjKyjkYrQ8LxG41qzhWURs8yhXPQHNe7/tE/Blfh14O0/WItWt9QhvX 8uQeUImjkK7htG47hw3PGMD1rCVVRnymsY8x877gOnPvTllYYHA+lQyDGelJnjFbWM+ZplyOZiRu YgZ65r2bVPDGkeFfh5p/iiy1q31C2vTscBGWRZCCQMdCPlPfI9O9eHZ96me9ujaiza5mNuG3iIud gbGM7emeetYzpTck4vTqaxqRt7xNqt89/ePPJgE9AOw9KpNSE5PWkJHX863SMXIFYqdy9RRNK8rA seQMDHGBTTyMYpMZHBqjNsTtk0E09IXf7sbH6CrMWl3knSFh7kU7oClmgZz/AErZh0Gc48yRVBHb rV2DQ7dSN7s/sBilzILHNjJPA/IVYitbmQ4WInNdVFYW0YwsC/iM1OsajgKB247VHOUonBj6/rQP Y0nOOKcOw71qZig+9OXkj5sfjTBnJ7elOBI5I/SgCRGIB+Y09JCq4POaYHO0jHX2p6P8p/wpDHKW 28/zpynA5bP1pqnjj+VOyOQRUs0S0ELYOOaRj6k/hRkZ6Uq8jFFwtcjyDxk0EcjB4qcIDweKd5QI z/SlzIpQbK2CRTcetWfLX8aaU+h/CmpIXs2V+1B4H61KUwetM207kcoznA70nGafgUmO2adxcrEH t9DRz0/nSkHP1pcdABQAkcjwzrIhAIPBxXYLpl2mmQ6jLA8kMhYby277uCfp94fnXHNkjHFev6c7 /wDCAQx7xhorj/0XEf6Vw4ys6Thbqzqw0VK9zkbS9tIZfmtgQfQZrpfGd/DHaWsUdnHva3SQtnqM D6+lcMuQxYgNg981319pkOpWti5bZtshkqM54reGm5lXsmnaxxEV5Kb6NHVBllPA9ea7/wCNV7rN 34T0v+0tQurlBfXRHmyMw8xnLOwz3JOTXAajaS2WutazLgwyBOeMgHGf0r0T4xBH+H+mNGSQurXI HOTgrGwz/wB9Vx1pNYimb0/4crHjLU0/U/jUjjr3ptekjkYh+vfFNWn4IT05puPXpTFqHGeBTlx2 5poHHqaUcDk8UAhT1PBoJ65H60nGev4UEcdcUhikg+1XtIP7zaehP8xxVAgVJbybJAc4HQn0piN/ VbrbYxxRRD96qku7DIKqAcfjmjw1MH1i1jnnKoz4+U4Kn64qON47m1MTv1OUfHCv7+xqmIJra8jW QFXLDaTj161D2aL3PTviF4v1O88N2WjXrxiGGNVXy02qWB5Y+pxgfhXnAMklxGSyMoORzgj9KLvU LrUH3zSlyFSNP9lQDgfzp1nbsFYMEUjlnPG0dwe2eelQk+u5crLRFlS0WmqsiuN77xnjgKf/AIoV lWt2kEzltwHTKqD/ADqzqNwOVQYUDCjHIXr+fesoqzc4OevFaJ2M2roW5YT3MsqIEV3LBAemTnFR DPf86k2N2U80nlPn7p49qLhYdDK0TB0OCOhFbeveLfEWvWVra6xrd/fwWa7LaO4nZ1hXAGFBPHAH 5D0rAMbDqpFPhikkcKsZZs8YFRKnGTUmtilOS0TGucnrSD1rQi0e7b/WbYx7nNWk0aIYZ5Wb6DFP miPlkYgB/HNKFLcDk9gBXRx6daoB+63EDgtzVhVVQFQAD0ApcyDkZziWF2/IiYe54qzZaLc3TMAy JtxnJrcwCOverOjIpuwsjOu4Ywo70OegONjMg8NR5/ezA+wFXYtEsoTzEWPqTXRfZrYSlcyHnGSR /hTTAg+VQQM9c5/pWfOw5UZMdrHFwioo9hTzEDwfqK1Vtos8qWP1P9KlFvChwYMHPOT/APXo57Ds Yvl57f0pRFjtzWyYY88RKAf9kUgtumAB+AouS0Y7JjuM0BPQc+2TWu0QUbmdQOv3sVXuLrTouZL2 H6b8kflVIW55v9hl6ebF+v8AhSiwfjE0Wfx/wqcMST3p2+trkKJALJ8n99EPz/wp4sHA/wBfEPXg /wCFTK2KcCT2ouPlRCNPJH+viH4Gnpp5x/x8J067TUueenSnBsHgdPWldjUURrpxAB+0KfbaaeNP znNxH/3yakD46nrUiliOFJ+lTdl2IBpoI5uk4P8AcNSJpox/x9IR/ump1VwRkAfU9KeCveVfw5pN uw4oiXTQP+XlP++D/jUw0xSf+PtOe/ln/GlVox1eT3HA/rSpLArqJEbZnBJb9anc05mkMOlRtx9r QZ5/1Z/xp39jQFci/Tr/AM8v/r1pWNlcXCPNAkflo35j8e9LZi6vLoxQHChj82AMDPHSpat1DmuZ 8Xh1ZiAl4Dk44hJ/rR/wjMOSDqOMf9Men/j1dF4htoLHTUY3DfaBjALFt34VgC6PByc96m8nrFlL lfxIYfC8BGTqRPoPI/8AsqU+FrUA/wDE0bP/AF7/AP2VPN257mmm7c9CaF7XuNxp9hh8L2nbVH6/ 8+w/+LpG8MWYHGqSn/t3H/xdTC4c5IPuaUXBJ6iq/edzNqmULzw/bw25dL93I7GEAfnurt9HhMnh tIEbokgye+5FH9K5C/uD9mOc546dK7rwXA0+j4ChiwGCScgnHT8OK4cwbjGLb6nThYxlK0UVPAXh 2yu/FdrZ30SXELSAMjAgH8jmu28R6fbWEwt4UCRRwuqqF5A+vWq/hLRza6/ZXGSf36hs8GtvxpGy zvIDg4ZW445Bz/KtcHW9rT5rmGPpclWy7Hi/ieBn8STsSDundlbbg43Hj9K6DxSZLvwnZ2d0GMC3 bPlWwdxjUY6H+6KyNatZv7UabDshkyWA4BPr+FbGrO48OSRkEhbhWz/wGlU/iQYQfuNHHnSNJUnM d6c9P36//EU9NG0qSKVg0sTIuVDzA7j6ABKkbJJJb3NRlvmOTxjivQ6HKnrYlTR9PMMe+HJIH8Z/ xoGiaaD/AMex/wC+z/jWlFGWgjwO2KnjtWPLY56Cp57FcrbMY6JpwOBbjkYxubj9aDodiBza/mT/ AI1urCinIHI4FDY6cH2Ipe0K5O5gtotip+a1A+pOf50i6RYdfsy4Hua2XODg9+eO9MIHOFPPvTU2 LlKCaZp+MG0iyO5FKdNsB/y5w4/3BVs5wcGkY5GBx+NK7DlMa/0po2MlmvHdAP096pRzPCwSZSgH 8Mibl/xH4V06nmmTRxSf62MNjpkZo57aMpwvqjnlvI1HS0GRyAjZ/nREtzeyAQRs3OPMZdqL9AOK 2ha2ytkQR5+nSrEGMgAd8cDpQ522BQu9WT6Fo1vDH+8VZ5GOWd1FdPZaVbHBFtFn1EYrM01hlQM1 2WgRCUjivJxNWSu7no0acTJl0ZNgK26AeyCsm90rYCPKA9SBXrMGlCSPO3tWfrGh4jJ2/pXBDGa2 Ol0EeOXmnoW3PCpI7lc1V+yBRlUABGOBgV2usacYi3y/jWDLBxjbzmvTp17xOSVFJmLJFtHAHWoG XHNadxFjt+lUJAAM/rXTCV0ZThYhYfTp+VMPTpTzjrgcGmtjGQRk9q3Ri0Mb0A5rd8CaJeeIPElr o+nqGu7uRY4gSBuYkcZPT0rBwd3oDToL24sJRdW00kMsfzK6HBBHcGlJNpqItOp7L4h+FfjHQ9ct tKu9Fka7uU8y2SErKZgv3tuwnJHGR16HuK47UUXTLqeDUoHtp43+eOZSjKemCDyO9clrHj3xDr00 X9razqWpTIuyNridpSo9AWNUbiSabBmkZiPU9KmEJrcmXL0OkuvEVhBJ/o8bPIPuspwM/jWafE7t Jva1QnsF+UZxj0rH2KB0Gaaw9hWvIjNvSxqzeJr8nEccUQ6dM1Tn1bU5iN13IP8AdO3+VVhH0Lda D3+XjvVKKQakLiRjl3OT1JPWm+WM9cn0qUqWPHOOnFOROeRTJRSMTLjI+maXYR2p0DBnCuzAdODT piY32DoOhNIsYFIPapBjIOcj0xUYmxjIX8hVmSJ0gEhCsPYdKW40l0GBwOitQZWzkIB9aZ5if3Of Y07zEzkAj1zQMUyS9sD0wKQySFsMSaXfGe5z15WlQqx+VgSe3rRdiVrjQx4OaXcQelKcY6AfiKbj PTn6UBcd5mO/NOR1LAMcLnmoTxzj8hSZGeadhqR2moX1nY+HI4bWVHklUL8p6DHNY+ka5Jp3m7VW QMPl3dm9awgwI60m4etR7JWsyvatbGhdX011cGWZzIx7mo/NOcD69KpeYMYzSiTJGO1XyohzbZbM ufQZ9sVPDeNAm1UhJJ+8y5IrOAkIyFJ/CgZJ5ZB9WHFPlQuY1H1K5lXY0x2ngquAD+VNTBJx/KqK 7A4BmQnI4Gef0rTsoJLidY4h8xOAccD3pWUULVjJ7eSa0kKoMLjcfTmvUPhdavLZxR7DkbRyMd68 u1DUfPvFs9Od47SA8unWRv7xPvjivcPg9DK4t3uS7SSRq5LkksGwc5PXqD+NeHnVRqkevllP373P R08Mx2fgybUnjYPDJblWOMHdKikfkTXNeN41Fjdtgj/Sdqg9P4+1e7eI/C9vqfwrBMhiazK3i4HD FAflP4E/iBXj/j7T9+h6hdRRBo4rvJKjIUZwPw+YfpSyOElhlzddTlzKqqlVyXTQ870exlk06eGd B9nuEV1II6lcMMduQK5rXLb7PpN7C7KgjZdxboBjg11XhhNyzTi4jcSKivEOsZUED8xj8qyPHNqT Z3wLKFnixk8BeMZ+lelVWkZdjhw7/eSj3PPTbyM2zgLxz2NQXsYgABGPlPHr0q14Xa5kim0qe2k8 yEloZCpBXj7pz2ODj3+tVfEDbEDEdFI6Y9K6Iz5nY1lT5Vc6PS8GwibAzz1+tTOcA49Kp6LIX02M 46dKssfoSax6moyUjHTPNRPyT6+lPfPTGT0qFuvGOKpIl6iOBycc9+eKiY4JxxTpGwD1/KomckHJ 4/lVogTI29MGkJJ4P1NNJ5BFJnI5x9aokcGOAOTilJwDyQajHscUjEkcDoeopMq9kKxySSeKVHIY cj8ajYkdAefXvSI3IyTQ0CbubOnzEOOa7nwvcBXUZrzm1kwwJrpNFvQkqnd3rzMXSckd9CVme5aB NE8ag4Iq9q9vFJCSorhfD2sKEXLj866ZNVSWLG4fnXzs4OMj1IyTRxfiW0UbhiuIu4Apbjoa9B8R urbiOc1w17gF8de1ejh5O1jmqrUwLwAcYA57mse5XBPHTvWtqLYz6Vj3BJY98169DY4qhA5wehxU bHHQjPFPc9sVEc55H05rsRzNge/H41DPkoR1qRj3Heo5OR2qkZSZR0O2Kl529SoH8zWg3JPGaswx rHGFwB/j1oAB6fzp3uSlZFQRsR0NKIznGc1Yc/xcg0IM9M0XGyAxOz4HFIIBk7mP5VYxj+XFNPTJ 5pkkXlqD696FUZ6HHvTyfl5H60AYGaBamBayoLqIzbxEHHmbBltuece9dP491jwldi2g8KaNeWkM KjzLi7kzJMcd1BKj8P0rkgMEdcU4px3odJOSk3sCqNRaKzXb5wMVv+FdU0mORxr7XDWyIWWOBQWk PZc5GAfWuY9x+NB6d6qcFNW2FGbi7l+/vxNeyy20K28LuWjiBLbB2GTyfrVf7RLn72KjSJ3BKrkD qaFQu4RQcmmkkJuTJRczY+/+lKlxOzbVf5vUVCyMrFW4I4IpB7U7CTPQtb8D+Krb4fweMZtMkh0h toS4dlBYMcAhc7sEng4xXBtcS54fn6VfvNd1/UdNt9Mu9X1G6sbYAQW0lw7xxDttUnA/CqkWn3cg ysD498D+dZUueMf3jVzSdm/dI/tM4/5aMPxoF1OeshP1q2mkXhHzBF+p/wAKsJoUhHzyj6Bavmih ckjKM0hyC55o8yT++351vJoCkAs8hyPYVZtvDcch+6/4tS9pEPZyOYLsf4z+dOWaVRhZGX1w2K7E eHLaJh+7DHvyTU6aLCBtW2QjjHyCl7WJSptnClnPJY+mc0ZYDv8AnXoA0aAY3WkXv8gqVdItxwtv Go9Nope2Q1S8zgLMn7XFn++O/vXUyz/YNHkuAT5lw/krg8gdSf5VrjSoA3FvGD64FTNpqMFEqKyr 91SQQPpUSqplKnY4mEfZ7fJDgc5BPBP+cH8K9z+Dmoubeyd3yxCJn8AP6V5/d6LZm1kIjRSoyPlF dP8ADdhEltHwAs6gce9ebmMFXp2W56OCn7OXkfXOo+IoG+FeoW4fLm2x97GAWA/rXC+ILaRvh54m lY7ikyLnvzLGf6Vwj+IXGnzWJdQGOw9c9R/hXpuqQq3wv8YhJC+y7gO4g/3h61OR05xouM3tovQw zWMYVFyddT5702/is1lMW4Tq22ZSPlYAnGPfGPT6Go/E98l5G0YG3puDdMEVXvPIt1cTFA8wdVOC SBn0yOfr61S1dYo5mjEpcNBG2dmMAoPfr/hW0ZSvKL6Mz9nFqM7HnWr3sKzIdPluVlVtrSO2S44I PB45zwK1/E7vd6Tb6lkn7VDvY4wN/R//AB4Nj8Ktz6P4EtUKHWNSuG7jMUX9WrN1+90ZdFisNMac JEWx506yE7uwwq4AP8666c1JrlTFVpzim5afM3PDx3aVER12r/KrzEdePes7w0Q2jQMT/CP5Cr5I /DrUtasXQa/Q4IJ7VXfBHP1qdzg8Hn1NQMcHAbn61aE9CJ+5JqM5HI7+1PZuPbPHFROR29KohsYx /nSZAOTjJoOPr68VGcFexFUibinI5oJNNDe+KQkdqBisSDz6cUhJppPHIGBTS4yPrTEWY5GDZPSt C1nKYIOKx1YAD+tTxTEKM8ZrGcLm8JpHa6TqbRlct9K6O11nKLh+orzKG62kc4rQg1F1UZYYFeXV wd3dHdCtY7q/1DzU+9XOXsuXbBHQ1nnUSy4LVVmuyxJJBB46VFPDuJUqiaINQbLnoay5SC1WLqUk npVNm9DXpU1ZHLUd2NPJP9KjbHbOalHU5HHWmkf/AKq2TMXEhfI7fhTE5dQeBnFSSDaCKjT/AFyE Y+8KtWaMmX2B9elMb0PpUrgk+opm0Z74oERknIx+FOBIXgGjaACRwBR8u3BBqguMY9QMHnNMJqUh cnOKQ9eB1HPFBKIh05IzSkggUp4wMD6UAcHtimK5zOeg7UpztOTxija3pTtrOCFGc8DNaGSMwDt3 pQDjpXofw4+H2leIlnn8QeNdK8NQwsFCXMM0ssme6qikY6/xA+1aeqfD/wAC22sJa23xGF3Zbcvd Q6TLwfQKxUn60N2HZ3OU8GWMM9lPNPCjjftywzjAH+Nbh0ywGStlbjjP+rFdbZeFfhrpduVi+KWs SRg7jHF4aGWPtvnxXP8AimfwpboE0XxV4iuZefM8/RoIFA9Btmas3d6mifkea3sZbUZ44o8/vGCg DPeuj0rT9loiy2qs+Pmyme9Uofs0Ejvb3N0WkPLFFBP88VI5hmQb5bqVs8h5Dj9KUnccEt2ajRpF wwhgBP8AEwX+dKDaL96+tAf+uwP8jXOtZob+KML8jZOCfatJtNiRA/lRj8P8azfKupsnKS0iakcm m551K1BOcfPipln0pcMdQtvwbNZllZwrd20TRIQ0gDcdRXSvpVorjZAoQdqI0+bVMlzcXZoqLc6W AGF5C2OwB/wp76vpkAw10qjpwjH+lW20632cRJ9fSmx6fbHh4I2AORlQafsbbsTqXILXVYriQxWt tczsOc7AP5kVbE9ycf8AEulGRnBkT/Gpo7aMFjHCoOMfKKkhgw33B05qXSGpsq7rsuMxWqL33TEn 8sU4QXjkGO7t19hEW/8AZqvKnONv6VYiGQKlxSKTZmfYppAN17MCf+ecagfqDT001iwDT3b8dCcf +ggVroOh71KnHpxWdkjTlucrr407TR5VxcTxvJGSgM0hz+tanw6ljdbdllOz7RH82fVhXE/ES6iu /EDeRIX8mMRtzxuBJIH510Hw9uVh0iOQsB5c8ZPGejitJ07xVyVUtJo6eXUvL1+S2MmWS5K8tnvX 1MhtZfh34zcxsN0Vq7IyggZRcHn8f6V8Y6rcR/8ACf3flS7of7SJB7EbzivrLSZ3m+HHjGOYlXm0 21cFh12n+XIrTDU1TbSMcZUdRRb7Hyl48KRak7RNklzuA/h5qS92t5Eir8smnRsTjv0P6isvx68X 9rz5KiQNkn15q/Nch9O0k+XJH/xKyCWx8xEzjI9ug59KXLo7BzaRPPy1uJCGizj1enCa24/0dfxc 1RuSfPccdTTI1LyBeMk1tyXJVSx6J4YdX0qMgAAg4UHIHP8A9atAnjkda5rwxHdSaXGY71ol+bCr GD3Pc1elt5jkz6rcBe+0Kn8hXPy62R0JtpOxpMwAA4FQTyIgJaRRj1PFYJj08opn1e4c85VrgetQ NLocLgo7ED7xV36fhVqJm5G1Je2mcfaYfoHFRvdQ9pVIA7HNc/c6hpTSxkRXLhScgsTkY9z9Ka2p aSudlgSD/eA/xq1Ezcl3NibUbVOGkI/4Cf8ACoW1S1P3H3+gAx/Osr+1rXPyadH046f4VHLqbTOH SBUKjgE+/wD9arUSeY2jfd1tp3BGchRQl1JIMrbPgHByQP0rI/tW9ZuBCuc9jSx3V67Eo+Cxydqj +tJlJ9jaZ5ivMaj6v0/SmrJvGTgEEg4OelVUF2P+PiZF+rrn8gKQTCBsNIrhm5Izx+lQpRexo4SS vYvB88nv60bsnHaowcjrSBvrTZKepZSXHp+dSrOcdTwfWqO7H4e9O3kDBNQ4JlqTL/nlR9400zHv /OqYcHHOfpTWkwfSp5C+csSy5znFQeZ7mms+c8nHvTQcjmmo2VhORZhckjIAz2LCnu3OSU/77rPZ R5uSz5wOh9qmECsACWyBzk1zuTTvc9Snh4yWwk8pAO3Y2OgBqKGQSMj9MEZpjwqkikFuPU5qO2BV pFB6Guim7o4MVS5GtDbLdxnmmk43YPP1pgfK5J7UrEjv7VaRyitjA6dMUbgMkUxiSAaaD6H8qdge 44nvmmN+Z9aCTzz+tRsSD14pokcxOe1JnPPv2pCxOKbuIJpiMPPTOcGpbfmaMf7QzRRVEo3EkAHB oe4jjXLNRRU2uzTmaRm3l6ZDgHj0qgZCT0oopkXbFjJ9KvWauegFFFZzehpTWpbjhc6lbfKS2Dwf oa07+MxQDPBB59qKK4pO80ehCKUWVbUldQtnUAkS5wTx3qe+8Ust8YoI08pSQWYdfeiiu6lscFb4 kdRbSpcQo6spyoOAc9aeYwOtFFMzFjXbjrUqHEmQc59qKKUti0h7HIGDzUiKNuDnPTmiisZdzdIl QnHH4Vma3r9hpCFZpQ0+PliXlj/hRRURXNJJlSdlc8pBZ5A0hB3kknua6rw5eLZ6cBtPEiH64OaK K6p9DmhqN1W9N74znvYkwk14ZOegy2a+pYdZksvCmv286nMmhRsox05jHP5miinHcyrLRHy7403X V5KyKWIPysvIPPTNOt5dRuLHT4ltfltbU2/HfMjPk/8AfVFFctatKmtDro0YzaTOP1S2mtbuSG4i eKTOSrDBFVo87gRnIxRRXVCTcUznqwUZuKNOyuoYLdY5JLskfwpLtXGT6VFPNbPnZbKPcuxP86KK aXUnm6FchPRaPlGPlGPpRRTJELKDkAD8KQuuOP5UUUwE8wCnojthiPk7k8UUVM3YqKvuaYa2z5dj bsxGMyzjLdOyjgfjmnmCWbImuc8cLnp+HaiiuOo3GVkevh6EJ0+aSJVk06FSQJrhwO7bVP5c1WS5 WS4VVtoYlzkbQSfzJNFFbRpKOpxzxEpaJJLyX9M0d3fnHrQxGO/0oorU5luNZ/qaTcT34oooGhA1 G/jnFFFIGNZhgZNSQtkeuaKKTHEPmaRcemP1q9DGcAsePrRRXn1nZ2PosJ8KKc4hLhUmjL9gCCar AFb2QeoziiiumkrP5HDjrSjfsy9CxMYHpSluvPBoord6HlvRiFs9cdaRSSaKKHoOyBnGcEZphb5u 2aKKaI6iEnp/Sm9GNFFMbR//2Q= ________________________________________________________________________________
Subject: Fw: piet kids and Sun & Fun
Date: Apr 10, 2007
Hi Dick, I sent a check for the kids in Montana, mailed yesterday. We plan to arrive Sun & Fun Sunday before dark. Plan to camp in the same area, cow pasture up against the fence. Have you talked to Aircraft Spruce about wood and glue? See you there, Skip ----- Original Message ----- From: Dick Navratil Sent: 4/10/2007 4:13:24 PM Subject: Pietenpol-List: Fw: piet kids Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick See what's free at AOL.com. ________________________________________________________________________________
Subject: Re: Fw: piet kids and Sun & Fun
Date: Apr 10, 2007
I will hopefully arrive at SNF Sat night. I hope to find a spot in the same place. For anyone else coming to SNF, we are camping along the fence line at the end of RWY 9. If anyone else is coming, we can try to save space. Also, the Matronics server didn't allow the pics to post from Mont. I will try that another way. Dick ----- Original Message ----- From: Skip Gadd To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 4:13 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun Hi Dick, I sent a check for the kids in Montana, mailed yesterday. We plan to arrive Sun & Fun Sunday before dark. Plan to camp in the same area, cow pasture up against the fence. Have you talked to Aircraft Spruce about wood and glue? See you there, Skip ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: 4/10/2007 4:13:24 PM Subject: Pietenpol-List: Fw: piet kids Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com To: horzpool(at)goldengate.net Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick ------------------------------------------------------------------------- --- See what's free at AOL.com. ________________________________________________________________________________
Date: Apr 10, 2007
Dick, I got 3 pictures on your "piet kids" post. Skip Also, the Matronics server didn't allow the pics to post from Mont. I will try that another way. Dick ________________________________________________________________________________
Date: Apr 10, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
I'll see you there, Dick. I plan to fly from Raleigh to St. Augustine on Sunday, and then fly into Lakeland on Monday morning. I'll look for you in the woodworking tent. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Tuesday, April 10, 2007 7:53 PM Subject: Re: Pietenpol-List: Fw: piet kids and Sun & Fun I will hopefully arrive at SNF Sat night. I hope to find a spot in the same place. For anyone else coming to SNF, we are camping along the fence line at the end of RWY 9. If anyone else is coming, we can try to save space. Also, the Matronics server didn't allow the pics to post from Mont. I will try that another way. Dick ----- Original Message ----- From: Skip Gadd <mailto:skipgadd(at)earthlink.net> To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 4:13 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun Hi Dick, I sent a check for the kids in Montana, mailed yesterday. We plan to arrive Sun & Fun Sunday before dark. Plan to camp in the same area, cow pasture up against the fence. Have you talked to Aircraft Spruce about wood and glue? See you there, Skip ----- Original Message ----- From: Dick Navratil <mailto:horzpool(at)goldengate.net> To: pietenpol-list(at)matronics.com Sent: 4/10/2007 4:13:24 PM Subject: Pietenpol-List: Fw: piet kids Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com To: horzpool(at)goldengate.net Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick _____ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Apr 10, 2007
Jack, we haven't met yet, but I am building a piet in Lagrange, Ga. I will be camping out under my cessna 140 in the vintage campground. I have a silver grey 140 with a rubber chicken hanging on the prop. N3533V. Stop by and lets talk. Gardiner Mason. I plan to be there Friday or Saturday. ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 8:36 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun I'll see you there, Dick. I plan to fly from Raleigh to St. Augustine on Sunday, and then fly into Lakeland on Monday morning. I'll look for you in the woodworking tent. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Tuesday, April 10, 2007 7:53 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Fw: piet kids and Sun & Fun I will hopefully arrive at SNF Sat night. I hope to find a spot in the same place. For anyone else coming to SNF, we are camping along the fence line at the end of RWY 9. If anyone else is coming, we can try to save space. Also, the Matronics server didn't allow the pics to post from Mont. I will try that another way. Dick ----- Original Message ----- From: Skip Gadd To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 4:13 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun Hi Dick, I sent a check for the kids in Montana, mailed yesterday. We plan to arrive Sun & Fun Sunday before dark. Plan to camp in the same area, cow pasture up against the fence. Have you talked to Aircraft Spruce about wood and glue? See you there, Skip ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: 4/10/2007 4:13:24 PM Subject: Pietenpol-List: Fw: piet kids Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com To: horzpool(at)goldengate.net Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick ------------------------------------------------------------------------- - See what's free at AOL.com. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-Listhref="http://forums.matronics.com">h ttp://forums.matronics.com http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Subject: wing covering
Date: Apr 10, 2007
Guys, The screws I used to secure my aluminum leading edge look kind of nasty underneath the fabric. Any suggestions (other than covering them with anti-chafe tape prior to covering)? How about pulling them out and covering the line with a tape? Anything. Thanks, Tom Bernie Gloucester Mass ________________________________________________________________________________
Date: Apr 10, 2007
In a message dated 4/10/2007 7:38:34 PM Central Daylight Time, skipgadd(at)earthlink.net writes: Dick, I got 3 pictures on your "piet kids" post. Skip Dick, I got the pictures, too. That is a great idea you had about helping these kids with their aviation endevors. It also helps them realize what 'Airplane People' are all about !! Chuck G. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 10, 2007
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: Re: Pietenpol-List Photos
Say Dick, Can you send me your photos on the seat belt set-up in your Piet? I can't find them and would like to see the attachment points of the cables and it complete design.... Thank You Ken Heide Fargo, ND --------------------------------- Don't get soaked. Take a quick peak at the forecast with theYahoo! Search weather shortcut. ________________________________________________________________________________
Date: Apr 11, 2007
From: Grover Summers <oldaeroplaneworks(at)yahoo.com>
Subject: Re: wing covering
Try a thin felt-like material. Grover Thomas Bernie wrote: Guys, The screws I used to secure my aluminum leading edge look kind of nasty underneath the fabric. Any suggestions (other than covering them with anti-chafe tape prior to covering)? How about pulling them out and covering the line with a tape? Anything. Thanks, Tom Bernie Gloucester Mass ________________________________________________________________________________
Date: Apr 11, 2007
Subject: No piets in so cal
There are no piets and no builders in the Southern California, LA area? Although I find that hard to believe that such a popular design and build that no one has responded to my visit request, or no one is interested in a visit. Either way, with no response or willingness to host, I guess its just gonna be Jim Markle and I talking piets over beer in some obscure watering hole Monday night. Sorry no one responded , would have loved learning and sharing build info with our Southern California Brethren. John ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Tachometer - where do you find one
Date: Apr 11, 2007
I have a Westach tach for the 1835 VW on my "Flying Squirrel" that runs off the magento P-lead (single mag on the VW). Mine includes an hour meter and also has range markings on it. A picture is at http://www.flysquirrel.net/panel/pnl02.JPG . While I realize that this particular tach won't work on a Corvair with points ignition, the point I'd like to get across is that Westach made my tach for me as a "special" but at no additional cost over what Aircraft Spruce wanted for a similar unit. I gave them the RPM range that I wanted, where I wanted the green/yellow/red markings and they did that for me. You can tell Westach what you want, what it runs off of, and they will make you a tach to your specs. There are several different dial sizes to pick from, too. Website is at http://www.westach.com My tach does have a fuse in it in the line from the magneto P-lead but I believe it's there to protect the tach from spikes from the magneto, not to protect the magneto from problems in the tach. The P-lead is essentially a ground wire to kill the magneto; not sure about the exact function of the fuse though. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Cant afford to quit your job? Earn your AS, BS, or MS degree online in 1 year. http://www.classesusa.com/clickcount.cfm?id=866145&goto=http%3A%2F%2Fwww.classesusa.com%2Ffeaturedschools%2Fonlinedegreesmp%2Fform-dyn1.html%3Fsplovr%3D866143 ________________________________________________________________________________
Date: Apr 11, 2007
Hi Gardiner, Unfortunately, my plans at this point are to arrive at SNF on Monday morning (possibly Tuesday morning, depending on wx) and then depart on Thursday morning. It's possible I might depart on Friday but it would be pretty early Friday morning, as I've got a 10 hour trip ahead of me to get it back to North Carolina. Any chance you can get there by Wednesday? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gardiner Mason Sent: Tuesday, April 10, 2007 9:20 PM Subject: Re: Pietenpol-List: Fw: piet kids and Sun & Fun Jack, we haven't met yet, but I am building a piet in Lagrange, Ga. I will be camping out under my cessna 140 in the vintage campground. I have a silver grey 140 with a rubber chicken hanging on the prop. N3533V. Stop by and lets talk. Gardiner Mason. I plan to be there Friday or Saturday. ----- Original Message ----- From: Phillips, Jack <mailto:Jack.Phillips(at)cardinal.com> To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 8:36 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun I'll see you there, Dick. I plan to fly from Raleigh to St. Augustine on Sunday, and then fly into Lakeland on Monday morning. I'll look for you in the woodworking tent. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Tuesday, April 10, 2007 7:53 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Fw: piet kids and Sun & Fun I will hopefully arrive at SNF Sat night. I hope to find a spot in the same place. For anyone else coming to SNF, we are camping along the fence line at the end of RWY 9. If anyone else is coming, we can try to save space. Also, the Matronics server didn't allow the pics to post from Mont. I will try that another way. Dick ----- Original Message ----- From: Skip Gadd <mailto:skipgadd(at)earthlink.net> To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 4:13 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun Hi Dick, I sent a check for the kids in Montana, mailed yesterday. We plan to arrive Sun & Fun Sunday before dark. Plan to camp in the same area, cow pasture up against the fence. Have you talked to Aircraft Spruce about wood and glue? See you there, Skip ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: 4/10/2007 4:13:24 PM Subject: Pietenpol-List: Fw: piet kids Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com To: horzpool(at)goldengate.net Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick _____ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: Apr 11, 2007
Hi Dick, Do you know how many kids/adults are involved? I'd like to donate a few piet hats to the cause. Steve E. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Tuesday, April 10, 2007 5:53 PM Subject: Re: Pietenpol-List: Fw: piet kids and Sun & Fun I will hopefully arrive at SNF Sat night. I hope to find a spot in the same place. For anyone else coming to SNF, we are camping along the fence line at the end of RWY 9. If anyone else is coming, we can try to save space. Also, the Matronics server didn't allow the pics to post from Mont. I will try that another way. Dick ----- Original Message ----- From: Skip Gadd <mailto:skipgadd(at)earthlink.net> To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 4:13 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun Hi Dick, I sent a check for the kids in Montana, mailed yesterday. We plan to arrive Sun & Fun Sunday before dark. Plan to camp in the same area, cow pasture up against the fence. Have you talked to Aircraft Spruce about wood and glue? See you there, Skip ----- Original Message ----- From: Dick Navratil <mailto:horzpool(at)goldengate.net> To: pietenpol-list(at)matronics.com Sent: 4/10/2007 4:13:24 PM Subject: Pietenpol-List: Fw: piet kids Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com To: horzpool(at)goldengate.net Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick ________________________________ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat r onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Apr 11, 2007
Subject: Re: No piets in so cal
John, Go here http://www.frappr.com/pietenpol There are a few in So Cal. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: AMsafetyC(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, April 11, 2007 10:29 AM Subject: Pietenpol-List: No piets in so cal There are no piets and no builders in the Southern California, LA area? Although I find that hard to believe that such a popular design and build that no one has responded to my visit request, or no one is interested in a visit. Either way, with no response or willingness to host, I guess its just gonna be Jim Markle and I talking piets over beer in some obscure watering hole Monday night. Sorry no one responded , would have loved learning and sharing build info with our Southern California Brethren. John ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Subject: 60 miles SW of LA.....EAA Pietenpol Project
Date: Apr 11, 2007
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
This project was featured in the Feb. or March issue of Sport Aviation. A really good group. http://www.eaa1279.org/ Mike C. ________________________________________________________________________________
Date: Apr 11, 2007
Tom, Possibly you could carefully cut away the fabric close to the screw heads. Then remove the screws, dimple the aluminum sheet around the holes, and install countersunk screws. A "dollar" fabric patch over each screw head should finish the job, and it should come out reasonsbly smooth. Good luck! Graham Hansen (Pietenpol CF-AUN) ________________________________________________________________________________
Date: Apr 11, 2007
Hi Steve There is the teacher, Patrick Kenney and six girls, his main volunteers. I'm sure there there are a few others I havent heard about, but that is the core group. I'm sure the hats will be most appreciated. I can send them with the second mailing after Sun n Fun. I will be hitting up some people for donations at SNF who have some $ and not on the list. Dick ----- Original Message ----- From: Steve Eldredge To: pietenpol-list(at)matronics.com Sent: Wednesday, April 11, 2007 1:18 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun Hi Dick, Do you know how many kids/adults are involved? I'd like to donate a few piet hats to the cause. Steve E. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Tuesday, April 10, 2007 5:53 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Fw: piet kids and Sun & Fun I will hopefully arrive at SNF Sat night. I hope to find a spot in the same place. For anyone else coming to SNF, we are camping along the fence line at the end of RWY 9. If anyone else is coming, we can try to save space. Also, the Matronics server didn't allow the pics to post from Mont. I will try that another way. Dick ----- Original Message ----- From: Skip Gadd To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 4:13 PM Subject: RE: Pietenpol-List: Fw: piet kids and Sun & Fun Hi Dick, I sent a check for the kids in Montana, mailed yesterday. We plan to arrive Sun & Fun Sunday before dark. Plan to camp in the same area, cow pasture up against the fence. Have you talked to Aircraft Spruce about wood and glue? See you there, Skip ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: 4/10/2007 4:13:24 PM Subject: Pietenpol-List: Fw: piet kids Hey all I talked with Patrick Kenney last night. He is the teacher that is restoring the Piet with the Montana kids. I called him to find where to send the donations and to let him know what we are doing. I have enclosed his e mail to me after our discussion. He is doing a great thing and if anyone else would like to get in, I will be mailing him some Piet info when I get back from Sun n Fun. I'm sure a second suprise would greatly appreciated. After things are settled, I will post a total of $ raised but no donor list. I figure this is about his kids. Dick N. ----- Original Message ----- From: Kenney285(at)aol.com To: horzpool(at)goldengate.net Sent: Monday, April 09, 2007 11:11 PM Subject: Re: piet kids Dick, What a great surprise-thank you! Sabrina and I were covering tonight and she was very excited to hear of your donation. We'll be splitting up the money based on their hours-Sabrina just went over three hundred tonight. I did not mention it in the article but three of our kids are very much at risk with extremely limited resources. In fact, we usually feed them at the hangar when they come up and I drive them home due to gas prices. Accordingly, your money will be used to buy savings Bonds for the kids. Enclosed are several pictures: Last class project 1896 Chanute, Comstock in 1932, Bozeman Piet. Patrick ------------------------------------------------------------------------- - See what's free at AOL.com. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-Listhref="http://forums.matronics.com">h ttp://forums.matronics.com http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. com ________________________________________________________________________________
Date: Apr 11, 2007
Chuck You are right. It doesn't take much to make a difference in kids lives, especially if you see they are starting that way themselves. Someday they will see one of the great things that got them there is that teacher and that experience. Showing them that others care also adds to it. They will remember what they did and that it affected others. I had a High School shop teacher that I put on the same level as that. How many kids now get to learn to run a lathe, pour cast aluminum, fabricate sheet metal and other things that can be used to make things. Dick N. Dick, I got the pictures, too. That is a great idea you had about helping these kids with their aviation endevors. It also helps them realize what 'Airplane People' are all about !! Chuck G. ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Apr 11, 2007
Or go to a Truss Head screw, which is very low. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Graham Hansen" <ghans@cable-lynx.net> Sent: Wednesday, April 11, 2007 3:40 PM Subject: Re: Pietenpol-List: wing covering > <ghans@cable-lynx.net> > > Tom, > > Possibly you could carefully cut away the fabric close to the screw heads. > Then remove the screws, dimple the aluminum sheet around the holes, and > install countersunk screws. A "dollar" fabric patch over each screw head > should finish the job, and it should come out reasonsbly smooth. > > Good luck! > > Graham Hansen (Pietenpol CF-AUN) > > > ________________________________________________________________________________
Date: Apr 11, 2007
Subject: Latex paint class
After a high tech class on latex paint..........OK OK it was a show on the History Channel "Modern Marvels", They were talking about how they make, and used to make paints. I don't see any reason Poly spray would block any more light than latex. Poly spray uses aluminum oxide as a UV block, Most modern paints use Titanium oxide for uv protection. The old house paints used lead as a UV block, (although you might need an 0-470 in a piet if you want to use lead paint ha ha). Any way, watching that show taught me a little bit about the How's and why's of paint. If you are using latex you may even be able to stop by a Home Depot parking lot at 7 am and find a couple guys to paint it for cheap. Shad --------------------------------- It's here! Your new message! Get new email alerts with the free Yahoo! Toolbar. ________________________________________________________________________________
Date: Apr 11, 2007
I don't know if your underside covering is on or if you are stretched all the was tight, if not, there is a padding that is made to fair out things like that. It is in ACS cataolog. Dick N. ----- Original Message ----- From: "walt evans" <waltdak(at)verizon.net> Sent: Wednesday, April 11, 2007 3:42 PM Subject: Re: Pietenpol-List: wing covering > > Or go to a Truss Head screw, which is very low. > Walt Evans > NX140DL > "No one ever learned anything by talking" > ----- Original Message ----- > From: "Graham Hansen" <ghans@cable-lynx.net> > To: > Sent: Wednesday, April 11, 2007 3:40 PM > Subject: Re: Pietenpol-List: wing covering > > >> <ghans@cable-lynx.net> >> >> Tom, >> >> Possibly you could carefully cut away the fabric close to the screw >> heads. Then remove the screws, dimple the aluminum sheet around the >> holes, and install countersunk screws. A "dollar" fabric patch over each >> screw head should finish the job, and it should come out reasonsbly >> smooth. >> >> Good luck! >> >> Graham Hansen (Pietenpol CF-AUN) >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 11, 2007
Subject: Re: Latex paint class-- aluminum PolySpray no oxide
I think there might be a big difference here. The PolySpray has aluminum PARTICLES in it (a suspension), so you are putting (I think) 3 coats of aluminum under the finish paint, with the sole purpose of blocking UV. Relative to sunlight, it is almost like having an aluminum wing. OTOH, the latex paint with Titanium oxide is a wonderful white pigment which also blocks UV to a degree, as does all paint. All this said, I'd love to save money on paint. Tim in central TX -----Original Message----- >From: shad bell <aviatorbell(at)yahoo.com> >Sent: Apr 11, 2007 3:29 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Latex paint class > >After a high tech class on latex paint..........OK OK it was a show on the History Channel "Modern Marvels", They were talking about how they make, and used to make paints. I don't see any reason Poly spray would block any more light than latex. Poly spray uses aluminum oxide as a UV block, Most modern paints use Titanium oxide for uv protection. The old house paints used lead as a UV block, (although you might need an 0-470 in a piet if you want to use lead paint ha ha). Any way, watching that show taught me a little bit about the How's and why's of paint. If you are using latex you may even be able to stop by a Home Depot parking lot at 7 am and find a couple guys to paint it for cheap. > Shad > > > >--------------------------------- >It's here! Your new message! >Get new email alerts with the free Yahoo! Toolbar. ________________________________________________________________________________
Date: Apr 11, 2007
Ken I can't find a pic of that set up. I am going to the hangar tomorrow, I'll make a note to take a pic. Dick ----- Original Message ----- From: KMHeide, BA, CPO, FAAOP To: pietenpol-list(at)matronics.com Sent: Tuesday, April 10, 2007 10:12 PM Subject: Pietenpol-List: Re: Pietenpol-List Photos Say Dick, Can you send me your photos on the seat belt set-up in your Piet? I can't find them and would like to see the attachment points of the cables and it complete design.... Thank You Ken Heide Fargo, ND ------------------------------------------------------------------------- ----- Don't get soaked. Take a quick peak at the forecast with theYahoo! Search weather shortcut. ________________________________________________________________________________
From: "skellytownflyer" <hanover(at)centramedia.net>
Date: Apr 12, 2007
I do plan on using Poly brush and some Polyspray on my fuselage after being sure I have adequate finish on my wings and tail surfaces with what I have on hand.But part of the Stitts process is using the polybrush to both seal the weave,plus it has an additive to kill mildew or fungus that might start working on it and strengthen the material with a plastic type film it builds up-I remember some tests a long time ago on another list that told how much the strength increased by using ( I think) something like a layer of pantyhose over a frame and painting it with several layers of polybrush and putting a load on it.-anyway I'm not going to suggest painting my wife's or anybody else's wife's pantyhose to help em hold the load here! I may be dumb but not stupid. but I do plan on doing at least 3 coats of Stits product on my fuselage and then possibly paint with some other type of finish.but if the cost difference ins't too huge and I doubt it will be by then. probably just use Polytone. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=106461#106461 ________________________________________________________________________________
Date: Apr 12, 2007
Thanks for the replies. The wing is covered both sides (stitching now) the screws under the fabric are #4 truss heads. I didn't think they would be so noticeable. Think I will finish as-is -- at any sign of chafing through I'll remove them all and patch the holes. Thanks, Tom Bernie Gloucester Mass > > I don't know if your underside covering is on or if you are stretched all > the was tight, if not, there is a padding that is made to fair out things > like that. It is in ACS cataolog. > Dick N. > ----- Original Message ----- > From: "walt evans" <waltdak(at)verizon.net> > To: > Sent: Wednesday, April 11, 2007 3:42 PM > Subject: Re: Pietenpol-List: wing covering > > > > > > Or go to a Truss Head screw, which is very low. > > Walt Evans > > NX140DL > > "No one ever learned anything by talking" > > ----- Original Message ----- > > From: "Graham Hansen" <ghans@cable-lynx.net> > > To: > > Sent: Wednesday, April 11, 2007 3:40 PM > > Subject: Re: Pietenpol-List: wing covering > > > > > >> <ghans@cable-lynx.net> > >> > >> Tom, > >> > >> Possibly you could carefully cut away the fabric close to the screw > >> heads. Then remove the screws, dimple the aluminum sheet around the > >> holes, and install countersunk screws. A "dollar" fabric patch over each > >> screw head should finish the job, and it should come out reasonsbly > >> smooth. > >> > >> Good luck! > >> > >> Graham Hansen (Pietenpol CF-AUN) > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Just a few quick rib questions
Date: Apr 13, 2007
Date: Apr 12, 2007
Subject: Piet List vs Other Lists
Nah, he's a friend of friends back up in NC. "Phillips, Jack" wrote: I dont think so not even sure he has email. I can get you his phone number if you need it, though. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Michalkiewicz Sent: Friday, March 30, 2007 7:12 PM Subject: RE: Pietenpol-List: Piet List vs Other Lists Is Jimmy Dean on this list!? "Phillips, Jack" wrote: Corky, I would like to do a project like Jimmy Dean, down in Sanford, NC is doing. Jimmy (who owns a beautiful Ford Model A powered Pietenpol, that sadly needs a new fabric job) is building an essentially new Waco Ten. He bought a junk Waco and is using the old parts to make patterns for all new components. He has finished the fuselage framework, all welded up of brand new 4130 tubing, much better than the mild steel of the original. He is using the original ribs to make a jig to build all new ribs. By the time he is finished about the only original components will be the centerline and the nameplate and serial number, but that is enough in the FAAs eyes to make it a certificated airplane. Id like to do something similar, as my retirement project. Then take it and go barnstorming. You cant go barnstorming in a Pietenpol and charge for rides, since it is Experimental. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Isablcorky(at)aol.com Sent: Thursday, March 29, 2007 10:04 AM Subject: Re: Pietenpol-List: Piet List vs Other Lists In a message dated 3/29/2007 11:04:47 AM Central Daylight Time, Jack.Phillips(at)cardinal.com writes: or rebuild an antique like a Travellaire or a Waco Jack, This is a thought provoking statement. IF a builder so decided he wanted to undertake such a project, to actually build one of the above, where would he or she obtain plans, drawings, spec or whatever. I've often wondered how long it would take to build the ribs for a Waco Taperwing. Mindbogling. It would be a worthy retirement project, if one lived long enough Back in '52 I observed a lonely UPF-7 parked on the far end of Ft Smith airport. I inquired and the FBO said I could buy it for $ 186. Some jerk came in, ground looped, damaged the lower left wing tip. Repairs were $186. The guy had never come back. Just thinking Corky --------------------------------- See what's free at AOL.com. http://www.matronics.com/Navigator?Pietenpol-List --------------------------------- The fish are biting. Get more visitors on your site using Yahoo! Search Marketing. http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Piet kids
Date: Apr 12, 2007
Hey all I sent off the packet tonight with the checks still in all of your original envelopes. To date we raised $405. There are still a few more checks to come in and if you happen to stop by the Wood Shop I would be glad to take checks there too. I have attached a copy of the letter that I enclosed with the checks. After I respond to a couple of e mails I'm packing the computer for the morning drive to Sun n Fun. Thanks much Dick ________________________________________________________________________________
Subject: Yes, there are Piets in Southern California
Date: Apr 13, 2007
John---did you not see my posting about EAA Chapter 1279 about 60 miles SW of LA who have a very nice Piet project going ? For more info go here: There was an article in Sport Aviation written by Steve Williamson (EAA 1279's President) about the project in the March issue as well. "If you would like to get involved, by all means, come out and join us any Saturday morning from 8 to noon at the French Valley Airport - Bldg. 95, Hangar 15. See you there." Steve Williamson, Pres. http://www.eaa1279.org/Pietenpol.htm >From Doc Mosher's Piet directory you might want to check on these guys too: Walt Bowe San Ramon, CA Milestones of Flight Museum, Lancaster CA Bill VAnHorn, Blythe, CA Hiller Aviation Museum, San Carlos, CA John Watson, Chico, CA Dan Benner, Cedarville, CA Paul Sherman, Riverside, CA Leslie Deline, San Diego, CA Joann Painter, Mojave, CA Ray Martin, Fort Jones, CA Dave Cleveland, Rancho Palos Verde, CA Henry Hayes, Blythe, CA Martin Vandenbroek, Lompac, CA Jim Kearns, Placerville, CA Dennis Heiny, Escalon, CA Robert Miller, Novato, CA Dan Patterson, Auburn, CA Malcom Muir, Quincy, CA Dave Wheatley, Escondido, CA Larry Robbins, Burson, CA Dave Thompson, Fortuna, CA ________________________________________________________________________________
Subject: make that 60 miles SE of LA
Date: Apr 13, 2007
Date: Apr 13, 2007
Subject: Re: Piet kids
Dick, Great note. Thanks. I am sure the kids will gain an appreciation that they are part of something bigger than they thought, and far bigger than all of us-- the continuation of the venerable heritage of this pluckly little aeroplane. A quest for all of us, as a matter of fact. What a great bunch of kids they are, too. Tim in central TX -----Original Message----- >From: Dick Navratil <horzpool(at)goldengate.net> >Sent: Apr 12, 2007 9:01 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Piet kids > >Hey all >I sent off the packet tonight with the checks still in all of your original envelopes. To date we raised $405. There are still a few more checks to come in and if you happen to stop by the Wood Shop I would be glad to take checks there too. >I have attached a copy of the letter that I enclosed with the checks. >After I respond to a couple of e mails I'm packing the computer for the morning drive to Sun n Fun. >Thanks much >Dick ________________________________________________________________________________
Subject: PFA type acceptance
Date: Apr 13, 2007
Hi I found this document from England with some interesting points. I'm trying to get a drawing of the English built up spar. Best regards Steve in Maine _________________________________________________________________ Get a FREE Web site, company branded e-mail and more from Microsoft Office ________________________________________________________________________________
Subject: Re: Yes, there are Piets in Southern California
Date: Apr 13, 2007
John, I live in Torrance Ca. and would love to show you my Piet project, but unfortunately, I will be leaving for Sun n Fun the same day you arrive. You might want to check out the EAA chapter at Corona airport. They have a Piet project that they have been working on. Here are a few pics that i took while out there one Saturday morning. http://www.gomerair.com/Photos/Eaachapter494/ I can get you a contact name and number of one of the members if you like. Just let me know. Also, for the rest of you in So Cal, on April 28th and 29th, Flabob airport is having a pietenpol gathering. Check here for details. http://www.eaach1.org/images/pietenpol.gif Chris Gomez Read this topic online here: http://forums.matronics.com/viewtopic.php?p=106723#106723 ________________________________________________________________________________
Date: Apr 13, 2007
Hey Chris Thanks for getting back to to me on this, I think I got something pretty well set up for Monday evening, thanks! I do travel to So Cal on occasion so if not this trip , maybe next we can get togehther. Thanks for contacting me and enjoy the Sun and Fun. I am hoping to get to Broadhead this year to meet other Pieters. Happy flying John -----Original Message----- From: cgomez(at)sportplanes.tv Sent: Fri, 13 Apr 2007 1:12 PM Subject: Pietenpol-List: Re: Yes, there are Piets in Southern California John, I live in Torrance Ca. and would love to show you my Piet project, but unfortunately, I will be leaving for Sun n Fun the same day you arrive. You might want to check out the EAA chapter at Corona airport. They have a Piet project that they have been working on. Here are a few pics that i took while out there one Saturday morning. http://www.gomerair.com/Photos/Eaachapter494/ I can get you a contact name and number of one of the members if you like. Just let me know. Also, for the rest of you in So Cal, on April 28th and 29th, Flabob airport is having a pietenpol gathering. Check here for details. http://www.eaach1.org/images/pietenpol.gif Chris Gomez Read this topic online here: http://forums.matronics.com/viewtopic.php?p=106723#106723 ________________________________________________________________________ ________________________________________________________________________________
Date: Apr 13, 2007
In a message dated 4/12/2007 11:07:05 P.M. Eastern Daylight Time, horzpool(at)goldengate.net writes: Hey all I sent off the packet tonight with the checks still in all of your original envelopes. To date we raised $405. There are still a few more checks to come in and if you happen to stop by the Wood Shop I would be glad to take checks there too. I have attached a copy of the letter that I enclosed with the checks. After I respond to a couple of e mails I'm packing the computer for the morning drive to Sun n Fun. Thanks much Dick , Just wanted to thank you personally for taking the time to do all that for the kids...and us. Ron ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: PFA type acceptance
Date: Apr 13, 2007
Best of luck on that one, I tried for 3 months and got no response whatever. Also I got no response from the Pietenpol family when I tried to contact them about it. At one time there was a web site showing construction of the spar. I believe it was in Autralia. Bob B. ----- Original Message ----- From: Steve Glass To: pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 12:08 PM Subject: Pietenpol-List: PFA type acceptance Hi I found this document from England with some interesting points. I'm trying to get a drawing of the English built up spar. Best regards Steve in Maine _________________________________________________________________ Get a FREE Web site, company branded e-mail and more from Microsoft Office ________________________________________________________________________________
Date: Apr 13, 2007
Here is the web site http://www.cpc-world.com/ There is even a u-tube video at the bottom of the home page. Nice pictures of the entire construction process. Bob B. ----- Original Message ----- From: baileys To: pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 2:53 PM Subject: Re: Pietenpol-List: PFA type acceptance Best of luck on that one, I tried for 3 months and got no response whatever. Also I got no response from the Pietenpol family when I tried to contact them about it. At one time there was a web site showing construction of the spar. I believe it was in Autralia. Bob B. ----- Original Message ----- From: Steve Glass To: pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 12:08 PM Subject: Pietenpol-List: PFA type acceptance Hi I found this document from England with some interesting points. I'm trying to get a drawing of the English built up spar. Best regards Steve in Maine _________________________________________________________________ Get a FREE Web site, company branded e-mail and more from Microsoft Office ________________________________________________________________________________
Subject: Piet with a canopy
Date: Apr 13, 2007
Every now and then someone asks if a Pietenpol can be fitted with a canopy. Well, I just stumbled across a photo of one (as well as a bunch of other Pietenpol photos I hadn't found before). Before you open the link, brace yourself. This machine looks quite different - it has a reeeeeeeallllly looooooooonnnnnnngg motor mount extension. While the canopy idea makes sense for those of us up in the Great White North, with it's short open cockpit flying season, I find the appearance of this canopy really detracting. Maybe if it was easily removable - only to be used when it's too cold out for anyone to be watching... Okay, take a look: http://www.abpic.co.uk/photo/1031240/ Bill C. ________________________________________________________________________________
From: "MICHAEL SILVIUS" <M.Silvius(at)worldnet.att.net>
Date: Apr 13, 2007
for some straneg reason I am unable to access Peter's page. I keep getting a mesage that the page can not be displayed. any idea whats up with that? been that way for a while. michael in maine ----- Original Message ----- From: baileys To: pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 3:18 PM Subject: Re: Pietenpol-List: PFA type acceptance Here is the web site http://www.cpc-world.com/ There is even a u-tube video at the bottom of the home page. Nice pictures of the entire construction process. Bob B. ________________________________________________________________________________
Date: Apr 13, 2007
Subject: Re: Piet with a canopy
Bill, Thanks for the warning. My heart might not have stood it otherwise. Then I started looking for the bugspray nozzles- the Piper Agrothingie has a canopy like that. I suspect that the pilot weighed mucho, and with the canopy, needed that kind of engine extension. I wooooooooooooonder how it handled. If it did, what a forgiving basic design!!! Wisconsin seems too warm a spot to require butchering a Piet like that. Besides, open cockpit is what it's about, IMO. Easy to say here, though, where we have only "Summer" and a few months of "Other." Tim in central TX -----Original Message----- >From: Bill Church <eng(at)canadianrogers.com> >Sent: Apr 13, 2007 4:35 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Piet with a canopy > >Every now and then someone asks if a Pietenpol can be fitted with a >canopy. Well, I just stumbled across a photo of one (as well as a bunch >of other Pietenpol photos I hadn't found before). Before you open the >link, brace yourself. This machine looks quite different - it has a >reeeeeeeallllly looooooooonnnnnnngg motor mount extension. While the >canopy idea makes sense for those of us up in the Great White North, >with it's short open cockpit flying season, I find the appearance of >this canopy really detracting. Maybe if it was easily removable - only >to be used when it's too cold out for anyone to be watching... > >Okay, take a look: > > >http://www.abpic.co.uk/photo/1031240/ > > >Bill C. ________________________________________________________________________________
Date: Apr 13, 2007
I tried it again and it worked for me, however this address was at the top. http://www.cpc-world.com:80/ Let me know if this doesn't work. Bob B. ----- Original Message ----- From: MICHAEL SILVIUS To: pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 4:43 PM Subject: Re: Pietenpol-List: PFA type acceptance for some straneg reason I am unable to access Peter's page. I keep getting a mesage that the page can not be displayed. any idea whats up with that? been that way for a while. michael in maine ----- Original Message ----- From: baileys To: pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 3:18 PM Subject: Re: Pietenpol-List: PFA type acceptance Here is the web site http://www.cpc-world.com/ There is even a u-tube video at the bottom of the home page. Nice pictures of the entire construction process. Bob B. ________________________________________________________________________________
Date: Apr 13, 2007
Uuum isn't Brodhead in Wisconsin? ----- Original Message ----- From: Tim Willis To: pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 3:56 PM Subject: Re: Pietenpol-List: Piet with a canopy Bill, Thanks for the warning. My heart might not have stood it otherwise. Then I started looking for the bugspray nozzles- the Piper Agrothingie has a canopy like that. I suspect that the pilot weighed mucho, and with the canopy, needed that kind of engine extension. I wooooooooooooonder how it handled. If it did, what a forgiving basic design!!! Wisconsin seems too warm a spot to require butchering a Piet like that. Besides, open cockpit is what it's about, IMO. Easy to say here, though, where we have only "Summer" and a few months of "Other." Tim in central TX -----Original Message----- >From: Bill Church <eng(at)canadianrogers.com> >Sent: Apr 13, 2007 4:35 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Piet with a canopy > >Every now and then someone asks if a Pietenpol can be fitted with a >canopy. Well, I just stumbled across a photo of one (as well as a bunch >of other Pietenpol photos I hadn't found before). Before you open the >link, brace yourself. This machine looks quite different - it has a >reeeeeeeallllly looooooooonnnnnnngg motor mount extension. While the >canopy idea makes sense for those of us up in the Great White North, >with it's short open cockpit flying season, I find the appearance of >this canopy really detracting. Maybe if it was easily removable - only >to be used when it's too cold out for anyone to be watching... > >Okay, take a look: > > >http://www.abpic.co.uk/photo/1031240/ > > >Bill C. ________________________________________________________________________________
Date: Apr 13, 2007
wow looks like a high wing AG cat. but while on the subject, check out the photo on page 41 of the latest EEA magazine, the one with the article on the rebuid of the Comstock Piet. Did anyone notice the grey tube structure sloping back from the top of the cabanes behind the heads of the project participants? any ideas as to what that may be? or am I just imagineering things here? also doesn't that center section look rather small? michael in maine ----- Original Message ----- From: Bill Church Every now and then someone asks if a Pietenpol can be fitted with a canopy. Well, I just stumbled across a photo of one http://www.abpic.co.uk/photo/1031240/ Bill C. ________________________________________________________________________________
Date: Apr 14, 2007
Hi Guys, There shouldn=92t be any problem accessing the site. Anybody else have any problems? Cheers Peter Wonthaggi Australia HYPERLINK "http://www.cpc-world.com/"http://www.cpc-world.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MICHAEL SILVIUS Sent: Saturday, 14 April 2007 7:44 AM Subject: Re: Pietenpol-List: PFA type acceptance for some straneg reason I am unable to access Peter's page. I keep getting a mesage that the page can not be displayed. any idea whats up with that? been that way for a while. michael in maine ----- Original Message ----- From: HYPERLINK "mailto:baileys(at)ktis.net"baileys "mailto:pietenpol-list(at)matronics.com"pietenpol-list(at)matronics.com Sent: Friday, April 13, 2007 3:18 PM Subject: Re: Pietenpol-List: PFA type acceptance Here is the web site HYPERLINK "http://www.cpc-world.com/"http://www.cpc-world.com/ There is even a u-tube video at the bottom of the home page. Nice pictures of the entire construction process. Bob B. "http://www.matronics.com/Navigator?Pietenpol-List"http://www.matronics.c om/ Navigator?Pietenpol-List "http://forums.matronics.com"http://forums.matronics.com 12/04/2007 7:58 PM -- 12/04/2007 7:58 PM ________________________________________________________________________________
Date: Apr 13, 2007
Peter: Still the same problem as before. Almost a year ago I use to be able to see your page though it took a long time to load up, as I am on a phone line. But now I get this odd behavior and cant seem to get on it. I use both Internet Explorer and Mozila and both behave the same. Dont know if it is my browser settings or ATT (my isp) sure would like to see your progress. I am at a loss as I am a dummy whan it comes to these machines so if anyone has any sugestions you can email me backchanel at m.silvius(at)att.net so we dont eat up band with with this. thanks michael in maine ----- Original Message ----- From: Peter W Johnson Hi Guys, There shouldn=92t be any problem accessing the site. Anybody else have any problems? Cheers Peter Wonthaggi Australia http://www.cpc-world.com ________________________________________________________________________________
Date: Apr 13, 2007
Hahahaha! That's another plane behind the Piet! Clif Did anyone notice the grey tube structure sloping back from the top of the cabanes behind the heads of the project participants? any ideas as to what that may be? or am I just imagineering things here? also doesn't that center section look rather small? michael in maine ________________________________________________________________________________
Date: Apr 13, 2007
Works fine. Clif Hi Guys, There shouldn=92t be any problem accessing the site. Anybody else have any problems? Cheers Peter Wonthaggi Australia http://www.cpc-world.com ________________________________________________________________________________
Date: Apr 14, 2007
Subject: Re: paint information -- COMBINATIONS?
Ken, I am not sure I followed what was tested. I was able to view the pdf file, but saw no comparative data table. It looks like four samples were tested-- one with PolySpray alone, and three different tests of various coats of latex. Did any of the surfaces that were tested have three coats of Poly-Spray under the latex paint? Is that a possible combination? Some background first. I just looked up the Poly-Fiber process in my Poly-Fiber manual, "How to Cover an Aircraft using the Poly-Fiber System," revision no. 20, 7-01. I bought the manual as the current issue at Oshkosh last year. The Poly-Fiber people seem to indicate in their system that virtually ALL of the UV blocking comes from the undercoat of vinyl filled with aluminum powder-- what they call Poly-Spray. In fact, they recommend three coats of this Poly-spray. I am quite interested in prepping with Poly-Spray silver(aluminum powder)undercoat, followed by a couple of coats of latex finish paint. I know that generally one does not mix oil based primers and latex finish paints, but is this possible in this case? Let me tell you of my interest and position. Being as "tight as the bark on trees," I would love to finish with LATEX paint if it will last. I have enough aluminum PolySpray on hand to get the fabric prepped, but have NO finish paint yet. In fact, I have not even decided what colors to use. I will likely use a light color because I want to keep the heat down in and on the plane here in central TX. I am talking avoiding absorption of infrared and visible light, not UV radiation. I am trying to avoid heat buildup with the light shaded finish paint, and avoid fabric-damaging UV with the Polyspray underneath. It seems to me the ideal paints would be the silver (aluminum) PolySpray underneath and a white or silver finish latex paint[to save money]. Here are the questions: -- Will this work? -- Do people ordinarily spray latex paint over latex primer? -- In this case, can I successfully spray a latex finish paint over the PolySpray? -- Will it adhere and not craze, curdle, etc.? -- If not directly, will an intermediate thin latex primer over the PolySpray work? Has anyone ever tried this? Tim in central TX -----Original Message----- >From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com> >Sent: Apr 9, 2007 1:36 PM >To: Pietenpol >Subject: Pietenpol-List: paint information > > Ultraviolet Absorption of Latex Paints by Kirk Huizenga For many years there has been discussions on the Pietenpol mail list as to the suitability of exterior latex paint as a system for covering an aircraft. A number of builders have completed their projects and have used latex paint to cover the fabric with claimed success. > One issue that had not been tested is the ability of latex paint to protect Dacron fabric from damaging UV light. In standard systems, there is a barrier layer of paint applied prior to color coats. > In the Poly-fiber system this is called Poly-spray. In the past, builders that have used latex paint to cover their fabric have sealed the fabric with black latex paint with the idea that black paint would absorb the most visible light and, hopefully, UV light. This, in turn, would protect the fabric from degradation. > > I have considered using latex paint on my Pietenpol rebuild, but wanted to be certain that it would, in-fact protect the fabric from UV degradation. There are builder that have had latex covered fabric for over 10 years without incident, but better safe than sorry. One should not assume that because visible light is being blocked that UV light is also being blocked. > Methodology: I contacted a friend of mine, Dr. Tom Varberg, a Professor of Chemistry at Macalester College in St Paul, MN and asked him about testing the paints. Tom agreed to help me in the testing by using a Beckman DU7400 Spectrometer. The spectrometer can record Transmittance, the amount of visible and ultraviolet light lost (or conversely, absorbed) by a material. Transmittance is the ratio of radiant power (p/o ) that makes it through the substance (paint) to the radiant power (P ) sent into the substance. > Transmittance can then be converted to Absorption (A) with the formula. Tom also supplied me with a small disk of quartz to use as a base for testing the paint at an appropriate thickness - similar to that expected when covering fabric. Quartz does not absorb or restrict UV light in the wavelengths we were PO P T = PO P A = logT Ultraviolet Absorption of Latex Paints by Kirk Huizengatesting (400-200nm) and therefore would not introduce error in the absorption readings. > I applied 4 different paints >1. Kilz Latex White >2. Glidden Exterior Latex-Wooland Green >3. Behr Exterior Flat Black >4. Poly-Fiber Poly-Brush) to the quartz with a small brush. > >After shooting a blank to calibrate the spectrometer, one of the painted areas on the disk was placed between the light source and the sensor. The light source flashes on (2 seconds for our test) and the sensor picks-up any energy that makes it through the paint. > >The DU7400 gives a graphic representation of Absorbance at each wavelength (in nanometers). In the charts below, I averaged the Absorption of every block of 10 nanometer since there were 600 data points for each sample (from 800 to 200 nanometers). > >As a curiosity, I also prepared some lightweight Poly- Fiber fabric generously given to me by Gil Leiter of St Paul, MN and tested it. I heat shrunk the fabric and tested it with and without paint and Poly-Brush (generously given by Pietenpoler, Robert Haines). > >The results are shown in Chart #2. Limitations: The Beckman DU7400 Spectrometer is limited to an absorption of 4.5 (but we will consider that to be sufficient at T=.0031%) The DU7400 is likely to show erroneous data or noise when at either extreme of its measurement (0 or 4.5). Some data for specific wavelengths may not be accurate, but a trend is obvious > >The testing we did does not account for reflection. Any light reflected by the paint would show up as being absorbed. This doesnt really change the applicability of the test results, but does raise a question of what color paint is the best to use on sealing and protecting the fabric. This is only a test of the UV blocking ability of latex (Continued on page 6) F or many years there has been discussions on the Pietenpol mail list as to the suitability of exterior latex paint as a system for covering an aircraft. > >A number of builders have completed their projects and have used latex paint to cover the fabric with claimed success. One issue that had not been tested is the ability of latex paint to protect Dacron fabric from damaging UV light. In standard systems, there is a barrier layer of paint applied prior to color coats. In the Poly-fiber system this is called Poly-spray. In the past, builders that have used latex paint to cover their fabric have sealed the fabric with black latex paint with the idea that black paint would absorb the most visible light and, hopefully, UV light. This, in turn, would protect the fabric from degradation. I have considered using latex paint on my Pietenpol rebuild, but wanted to be certain that it would, in-fact protect the fabric from UV degradation. > >There are builder that have had latex covered fabric for over 10 years without incident, but better safe than sorry. One should not assume that because visible light is being blocked that UV light is also being blocked. Methodology: I contacted a friend of mine, Dr. Tom Varberg, a Professor of Chemistry at Macalester College in St Paul, MN and asked him about testing the paints. Tom agreed to help me in the testing by using a Beckman DU7400 Spectrometer. > >The spectrometer can record Transmittance, the amount of visible and ultraviolet light lost (or conversely, absorbed) by a material. Transmittance is the ratio of radiant power that makes it through the substance (paint) to the radiant power sent into the substance. Transmittance can then be converted to Absorption with the formula. Tom also supplied me with a small disk of quartz to use as a base for testing the paint at an appropriate thickness - similar to that expected when covering fabric. Quartz does not absorb or restrict UV light in the wavelengths we were Ultraviolet paints. > >It does not deal with any other issues of using non-certified methods of covering and painting ones experimental aircraft like longevity, ability to seal the weave, adhesion, or flexibility/brittleness of latex paint. The Poly-Spray was tested with two layers one on the front of the disk and one on the back. We found that this introduced some errors. Some of the energy that makes it through the first layer of paint gets bounced around between the two layers and gives odd readings. > >Conclusions Latex paint can sufficiently blocks UV radiation and therefore protect Dacron fabric. Color does not seem to matter as far as level of absorption differences are extremely minor (in the range of thousands of a percent) > >This is a matter open for discussion, but the practice of using black paint as the base/sealing coat on fabric to block UV light may not be the best practice. > >White, in theory, would be a better paint for that. White paint has a high amount of Titanium Dioxide, which is highly reflective. > >Black paint, on the other hand, gets its color from Carbon Black primarily. Black paints have much less reflectivity and more absorption of light. > >Now, as I mentioned above, color does not seem to matter much in terms of protecting the fabric, but paint that is more reflective should last longer than paint that is more absorbing of light. > >It is not an issue of black or white being better at protecting the fabric, but rather the longevity and protection of the paint itself from breakdown. Brand of paint shouldnt make much difference in terms of UV protection, but could make a difference in durability and longevity of your paint job. >The above courtesy of http://www.eaa54.org >54NewsletterMarch2003.pdf > >--------------------------------- >Be a PS3 game guru. >Get your game face on with the latest PS3 news and previews at Yahoo! Games. ________________________________________________________________________________
Date: Apr 14, 2007
Subject: Piet Project For Sale (in a few weeks)
I haven't been on the Pietenpol list for more than a year and am returning to say hello to a few friends here and announce that I plan on putting my project up for sale in early June. I'll make a video of what I have and put it on YouTube when the Aircamper goes up for sale. The engine will be sold seperate from the Aircamper. The instrument panels will also be sold seperate. They are so good looking, they look like they belong in classic 1930s Rolls Royce. I bought Premium Carpathian Burl Elm that came from England and laminated my own plywood, Then sprayed about 9 coats of clear-coat on the finish and mounted all new goodies in the panel (another small fortune spent here!) The pilot-panel is finished and the passenger panel is simply laminated and has nothing mounted in it. These are not attached to the cockpit, but are ready for installation. The passenger cockpit is "tubed" for an airspeed indicator and can be flown from the front. The engine is a Continental A-80. (Looks just like an A-65 but has a few more ponies.) I spent a small fortune in rebuilding this engine. It has Cermanil cyclinders, a brand-spankin-new camshaft, Slick mags with dual impulse and they have about 5 hours TTSN, new wiring harness, a reman crankshaft, the case was rebuilt at DIVCO. The valve covers are powder coated in Continental Gold with new silicon valve cover gaskkets. The intake tubes are powder coated in Candy Apple Blue. The engine also has a new data plate, with info gleaned off the old data plate. New bearings, and a reman yellow-tag carb. I also have a motormount for this engine in matching Continental Gold (powder coated) that will be sold under a third listing. This engine looks brand new. It is the best looking small Continental "A" series I have ever laid eyes on! My father re-built this engine (he had an A&P license) and I'd like to keep it due to senamental reasons as he passed away shortly after the engine was rebuilt and his signature in in the logbook. I wish to limit my liability and will only sell this engine by having the buyer sign a statement that he/she knows the engine is being sold for parts only, and must be disassembled and rebuilt by someone else. I'll be making photo-copies of all my engine receipts and can provide a CD of the invoices for everything done to anyone sending me a pre-paid SASE for mailing a CD. I suspect the cost for postage would be in the neighborhood of $2.00, so please send a pre-paid envelope large enought to accomodate a CD. I just wanted to give everyone a heads-up about this and you can keep an eye out on my YouTube postings by going to YouTube and typing in my moniker, "TUUTUUTANGO" to see a list of my videos. I'll probably post the airplane under a heading of PIETENPOL and the engine will be under CONTINENAL AIRCRAFT ENGINE. The Piet and Contienetal videos will probably be on YouTube by the end of this month or in early May. I won't be able to give anybody a "sneak-preview" until the video is on YouTube because I will be in Washington state until further notice. The Aircamper and engine are in Central Texas inside a hanger. Wings are covered and painted in a light gray with Rustoleum. New cables will need to be installed because I had to cut the cables when I bought ths project in order to trailer the Aircamper from Kansas to Texas about 4 years ago. I found one small problem on the center-section. Everything looks great, BUT I believe the metal spar-plates need to have a doubler or washers welded onto them. My father caught this. I think it is a very easy process to remove these plates and weld on the doublers (or washers). The center section will need to be recovered. I had planned on building in a small strobe light into the leading edge of the center section using a small Lexan plate, but whoever buys this project can re-skin and re-build as they wish. This should be easy and I have new plywood I'll toss in as well as new fabric for this process. The fuselage is covered but I pulled fabric away from the firewall and it will need to be re-done. This project was originally built by an A&P/IA having a degree in an aviation dicipline... The fuselage is painted purple. I planned on sanding down the finish (it was painted in Rustoleum using a roller) and I had planned on using a red-white and blue Texas flag paint scheme desgined for me by DJ Vegh. The wheels are VERY NEAT looking they came from a Honda CB350 and I have them bead-blasted and powder-coated in red, to go along with the Texas flag design. They could easily be spray-painted in any color of your choice, and I think they would also look very authentic to the time period if they were painted black. Thanks, Sterling __________________________________________________ ________________________________________________________________________________
Date: Apr 14, 2007
Subject: Re: Piet Project For Sale (in a few weeks)
Sterling, I am looking for an old-looking Airspeed indicator. What type do you have, how much $ and when will it go up for sale? Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 14, 2007
Dan: Everything I have is new. I've seen what you are looking for and was told Ebay is a good place to look. Sorry, but good luck. Sterling --- HelsperSew(at)aol.com wrote: > Sterling, > > I am looking for an old-looking Airspeed indicator. > What type do you have, > how much $ and when will it go up for sale? > > Dan Helsper > Poplar Grove, IL. > > > > > ************************************** See what's > free at http://www.aol.com. > __________________________________________________ ________________________________________________________________________________
Subject: Old fashion Johnson air speed indicator
Date: Apr 14, 2007
I found this on one of my old letter.It may be the type of air speed indicator your after. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Sayre, William G Sent: July 14, 2006 2:00 PM Subject: Pietenpol-List: Old fashion Johnson air speed indicator For a store-bought source see... http://www.science-city.com/jodewest.html ________________________________________________________________________________
Subject: Johnson airspeed indicator
Date: Apr 14, 2007
Here is another letter I found -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Conkling Sent: July 15, 2006 8:52 PM Subject: Re: Pietenpol-List: Johnson airspeed indicator Add this with Oscar's info on the Johnson A/S & you should be able to make it! Now, to find the drawing for that Mach meter for Chuck G.!! Mike C. Pretty Prairie, KS ----- Original Message ----- Sent: Thursday, July 13, 2006 8:13 AM > > Rogers asked- > > >Does anyone know where I can find some info to build an old fashion > >Johnson airspeed indicator? > > Nobody really answered his question. I asked the same question a while back > and someone very promptly sent me two close-up photos of their Johnson setup > (one static, one in flight) but I don't remember who it was (black wing > struts, yellow wings). Probably Chuck "Baby Oil" Gantzer or Ed Grentzer. I > would be glad to send out those photos to anyone who wants them; you could > easily build one just like it by eyeball, along with this narrative info > found in the archives: > ============= > >It uses a .047" music wire, with 2 1/2 coils, and has a leg that is bent > >perpendicular to > >lock the coil from rotating, and is inserted into the back plate. The coil > >is 3/4" in diameter > >and is spaced off the backing plate with a threaded thru bushing that is > >3/8" long. > >From the center of the coil, to the tip of the pointer, is 7". The bushing > >that is in the > >center of the coil is 3/8" diameter and is about 3/32" long. The bolt is > >about a #6, > >and on each side of the coil is a plastic washer that is 7/8" O.D. The > >coil and pivot point > >is covered with a molded plastic teardrop shape fairing, and has a slot cut > >for the pointer > >to travel in. The sweep of the arc is 70. The backing plate with the > >indicator markings > >is .040 aluminum, probably 2024. The numbers are 20 thru 90 mph. The > >angle plate > >that the relative wind pushes against is 1 1/4" X 2 1/8" X .030" thick, > >with the pointer > >is on the 3/8" leg of this angle, which is next to the backing plate. To > >attach the > >music wire to the angle plate, it has a small aluminum block that measures > >1/4" X 1/4" > >X 3/4". The .040" wire is drilled thru length wise, and has two #2 (or > >smaller) set screws > >to secure the plate, wire, and block. > ================ > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Apr 14, 2007
On the last letter the attachment never followed.Here is the attachment. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rule, Harvey G (N092740) Sent: April 14, 2007 2:38 PM Subject: RE: Pietenpol-List: Johnson airspeed indicator Here is another letter I found -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Conkling Sent: July 15, 2006 8:52 PM Subject: Re: Pietenpol-List: Johnson airspeed indicator Add this with Oscar's info on the Johnson A/S & you should be able to make it! Now, to find the drawing for that Mach meter for Chuck G.!! Mike C. Pretty Prairie, KS ----- Original Message ----- Sent: Thursday, July 13, 2006 8:13 AM > > Rogers asked- > > >Does anyone know where I can find some info to build an old fashion > >Johnson airspeed indicator? > > Nobody really answered his question. I asked the same question a while back > and someone very promptly sent me two close-up photos of their Johnson setup > (one static, one in flight) but I don't remember who it was (black wing > struts, yellow wings). Probably Chuck "Baby Oil" Gantzer or Ed Grentzer. I > would be glad to send out those photos to anyone who wants them; you could > easily build one just like it by eyeball, along with this narrative info > found in the archives: > ============= > >It uses a .047" music wire, with 2 1/2 coils, and has a leg that is bent > >perpendicular to > >lock the coil from rotating, and is inserted into the back plate. The coil > >is 3/4" in diameter > >and is spaced off the backing plate with a threaded thru bushing that is > >3/8" long. > >From the center of the coil, to the tip of the pointer, is 7". The bushing > >that is in the > >center of the coil is 3/8" diameter and is about 3/32" long. The bolt is > >about a #6, > >and on each side of the coil is a plastic washer that is 7/8" O.D. The > >coil and pivot point > >is covered with a molded plastic teardrop shape fairing, and has a slot cut > >for the pointer > >to travel in. The sweep of the arc is 70. The backing plate with the > >indicator markings > >is .040 aluminum, probably 2024. The numbers are 20 thru 90 mph. The > >angle plate > >that the relative wind pushes against is 1 1/4" X 2 1/8" X .030" thick, > >with the pointer > >is on the 3/8" leg of this angle, which is next to the backing plate. To > >attach the > >music wire to the angle plate, it has a small aluminum block that measures > >1/4" X 1/4" > >X 3/4". The .040" wire is drilled thru length wise, and has two #2 (or > >smaller) set screws > >to secure the plate, wire, and block. > ================ > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Apr 14, 2007
The last time I went to this web site you could buy one of those Johnson airspeed indicators.I don't see them there now.Maybe they ran out.You could make one of your own if your handy.You would have to experiment with the spring till you got it right however. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Sayre, William G Sent: July 14, 2006 2:00 PM Subject: Pietenpol-List: Old fashion Johnson air speed indicator For a store-bought source see... http://www.science-city.com/jodewest.html ________________________________________________________________________________
Subject: Johnson airspeed indicator CAD?
Date: Apr 14, 2007
Where are the Autocad guys? This would be a perfect thing to arcive! Steve in Maine >From: <harvey.rule(at)bell.ca> >Reply-To: pietenpol-list(at)matronics.com >To: >Subject: RE: Pietenpol-List: Johnson airspeed indicator >Date: Sat, 14 Apr 2007 14:38:23 -0400 > > >Here is another letter I found > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael >Conkling >Sent: July 15, 2006 8:52 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Johnson airspeed indicator > >Add this with Oscar's info on the Johnson A/S & you should be able to >make >it! Now, to find the drawing for that Mach meter for Chuck G.!! > >Mike C. >Pretty Prairie, KS > >----- Original Message ----- >Sent: Thursday, July 13, 2006 8:13 AM > > > > > > > Rogers asked- > > > > >Does anyone know where I can find some info to build an old fashion > > >Johnson airspeed indicator? > > > > Nobody really answered his question. I asked the same question a >while >back > > and someone very promptly sent me two close-up photos of their Johnson >setup > > (one static, one in flight) but I don't remember who it was (black >wing > > struts, yellow wings). Probably Chuck "Baby Oil" Gantzer or Ed >Grentzer. >I > > would be glad to send out those photos to anyone who wants them; you >could > > easily build one just like it by eyeball, along with this narrative >info > > found in the archives: > > ============= > > >It uses a .047" music wire, with 2 1/2 coils, and has a leg that is >bent > > >perpendicular to > > >lock the coil from rotating, and is inserted into the back plate. >The >coil > > >is 3/4" in diameter > > >and is spaced off the backing plate with a threaded thru bushing that >is > > >3/8" long. > > >From the center of the coil, to the tip of the pointer, is 7". The >bushing > > >that is in the > > >center of the coil is 3/8" diameter and is about 3/32" long. The >bolt is > > >about a #6, > > >and on each side of the coil is a plastic washer that is 7/8" O.D. >The > > >coil and pivot point > > >is covered with a molded plastic teardrop shape fairing, and has a >slot >cut > > >for the pointer > > >to travel in. The sweep of the arc is 70. The backing plate with >the > > >indicator markings > > >is .040 aluminum, probably 2024. The numbers are 20 thru 90 mph. >The > > >angle plate > > >that the relative wind pushes against is 1 1/4" X 2 1/8" X .030" >thick, > > >with the pointer > > >is on the 3/8" leg of this angle, which is next to the backing plate. >To > > >attach the > > >music wire to the angle plate, it has a small aluminum block that >measures > > >1/4" X 1/4" > > >X 3/4". The .040" wire is drilled thru length wise, and has two #2 >(or > > >smaller) set screws > > >to secure the plate, wire, and block. > > ================ > > > > Oscar Zuniga > > San Antonio, TX > > mailto: taildrags(at)hotmail.com > > website at http://www.flysquirrel.net > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _________________________________________________________________ Exercise your brain! Try Flexicon. http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07 ________________________________________________________________________________
Subject: trouble viewing Peters' site
Date: Apr 14, 2007
I can get to the site just fine and it's a wonderful treasure of details and photos. However, I have cable modem and it still takes a while to load. I suspect that those of you with slower connections will time-out while trying to load the pages and your browser will thus give you the 'unable to access' error message. I believe it's due to the wallpaper (background) that Peter has on his pages. It's perfectly in keeping with this airplane, but it does make for slower loading. Too windy to fly today but there was a pancake breakfast at the EAA35 chapter clubhouse so I taxied the Piet down and parked it in the grass outside. People magnet! We were there maybe 30-45 minutes answering questions and listening to old-timers tell about their fabric airplanes, their wood props, their taildraggers, their A65s, their grass fields. I let a couple of kids sit in the cockpits and stir the stick around... their poppa was worried about them being too rough but I assured him that there was nothing they could hurt in the airplane and they had a great time. Hope to fly a bit tomorrow. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ MSN is giving away a trip to Vegas to see Elton John. Enter to win today. http://msnconcertcontest.com?icid-nceltontagline ________________________________________________________________________________
Date: Apr 15, 2007
Oscar, Thanks for the info. I will try and make the images smaller to allow a speedier load time. Mark Langford commented on the images size sometime ago and I made them a little smaller. I will try again to reduce the size. Thanks Peter Wonthaggi Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Sunday, 15 April 2007 11:20 AM Subject: Pietenpol-List: trouble viewing Peters' site I can get to the site just fine and it's a wonderful treasure of details and photos. However, I have cable modem and it still takes a while to load. I suspect that those of you with slower connections will time-out while trying to load the pages and your browser will thus give you the 'unable to access' error message. I believe it's due to the wallpaper (background) that Peter has on his pages. It's perfectly in keeping with this airplane, but it does make for slower loading. Too windy to fly today but there was a pancake breakfast at the EAA35 chapter clubhouse so I taxied the Piet down and parked it in the grass outside. People magnet! We were there maybe 30-45 minutes answering questions and listening to old-timers tell about their fabric airplanes, their wood props, their taildraggers, their A65s, their grass fields. I let a couple of kids sit in the cockpits and stir the stick around... their poppa was worried about them being too rough but I assured him that there was nothing they could hurt in the airplane and they had a great time. Hope to fly a bit tomorrow. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ MSN is giving away a trip to Vegas to see Elton John. Enter to win today. http://msnconcertcontest.com?icid-nceltontagline -- 9:36 PM -- 9:36 PM ________________________________________________________________________________
Date: Apr 14, 2007
Subject: Want to buy your piet!
I am in the middle of a piet project I bought, but running out of time and steam. Thinking of selling yours? Let me know.... ________________________________________________________________________________
Date: Apr 14, 2007
Subject: Re: Want to buy your piet!
Hey, didn't you buy the Pietenpol I originally bought from DJ? You live north of Dallas? Sterling Brooks Winters, TX I can send you some still pictures, but won't be able to show the plane until I get home... --- Jonathan Scholl wrote: > I am in the middle of a piet project I bought, but > running out of time and steam. Thinking of selling > yours? Let me know.... __________________________________________________ ________________________________________________________________________________
Date: Apr 15, 2007
Jonathan, Check out the one for sale at barnstormers.com Looks like a very nice bird. Gene ________________________________________________________________________________
Date: Apr 15, 2007
Subject: Latex Paint
Some links on latex paint: http://www.questiongravity.com/airbike/latex1.htm http://www.questiongravity.com/airbike/latex2.htm http://www.ultralightnews.ca/articles/housepaint.htm http://www.ultralightnews.com/features/paintinguls.htm I hope this is helpful. Larry the microMong guy -- ________________________________________________________________________________
Date: Apr 15, 2007
Yes, Sterling, I bought the fuse that you got from DJ.....Also have aquired lots of other Piet stuff, including several engine projects, etc. Just running out of gas....my wife wants me to reduce the inventory, so I am looking for one that is done....and done well. Happy to pay the right price for an excellent Piet or GN-1 Jon Mike Kerley wrote: Hey, didn't you buy the Pietenpol I originally bought from DJ? You live north of Dallas? Sterling Brooks Winters, TX I can send you some still pictures, but won't be able to show the plane until I get home... --- Jonathan Scholl wrote: > I am in the middle of a piet project I bought, but > running out of time and steam. Thinking of selling > yours? Let me know.... __________________________________________________ ________________________________________________________________________________
Date: Apr 15, 2007
Subject: GN-1 Support
Group, I regret to admit I am leaning toward a metal fuselage and the Riblett wing. The next logical step is the Grega. The whole point of my choice was price, open cockpit and the ability to use Corvair power. Does anyone know of any builders support or mailing lists? Could someone talk some sense into me? Thanks -Ryan --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Re: GN-1 Support
Date: Apr 15, 2007
The GN-1 mailing list on Grega's site is down as is many of the links and such. I fear the GN-1 is going to whither away with time. The late designer's son has ceased distribution of the plans and there appears to be no indication when or even if he will start up again. If you already have plans go for it, but getting plans isn't possible now unless someone sells thiers. DJ Vegh former GN-1 builder ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Sunday, April 15, 2007 9:51 AM Subject: Pietenpol-List: GN-1 Support Group, I regret to admit I am leaning toward a metal fuselage and the Riblett wing. The next logical step is the Grega. The whole point of my choice was price, open cockpit and the ability to use Corvair power. Does anyone know of any builders support or mailing lists? Could someone talk some sense into me? Thanks -Ryan ------------------------------------------------------------------------- ----- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 15, 2007
Ryan Don't regret building the plane YOU want. What you will regret is wasting a lot of money and time building, and probably not finishing, the plane someone else wanted you to build. As DJ can attest, builders of the GN-1 are welcome on this list. Just remember to remind people your building a modified Grega and don't take everything you here personal. The thing that gets people all riled up is to call it a Pietenpol just call it by the right name and all will be good (mostly). We should all remember to call them Aircampers and GN-1's. I just pulled out my copy of the GN-1 plans and if your looking to build a steel fuselage these are the way to go. Much more detail then on the Aircamper drawings. As to talking some sense into you, it seems to me you already have enough sense to know what you want. The Aircamper is a fine plane, the GN-1 is a fine plane and your Ryan-Camper 1 will be a fine plane too. Just start building and stop worrying what others will say. It's your money, your time and your dream. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Sunday, April 15, 2007 8:51 AM Subject: Pietenpol-List: GN-1 Support Group, I regret to admit I am leaning toward a metal fuselage and the Riblett wing. The next logical step is the Grega. The whole point of my choice was price, open cockpit and the ability to use Corvair power. Does anyone know of any builders support or mailing lists? Could someone talk some sense into me? Thanks -Ryan ------------------------------------------------------------------------- ----- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 15, 2007
Chris, Great advice! John Sent from my Verizon Wireless BlackBerry -----Original Message----- From: "Catdesigns" <catdesigns(at)comcast.net> Date: Sun, 15 Apr 2007 13:42:54 To: Subject: Re: Pietenpol-List: GN-1 Support Ryan Don't regret building the planeYOU want. What you will regret is wasting a lot of money and time building, and probably not finishing, the plane someone else wanted you to build. As DJ can attest, builders of theGN-1 are welcome on this list. Just remember to remind people your building a modified Grega and don't take everything you here personal. The thing that gets people all riled up is to call it a Pietenpol just call it by the right name and all will be good (mostly). We should all remember to call them Aircampers and GN-1's. I just pulledout my copy of the GN-1 plans andif your looking to build a steel fuselage these are the way to go. Much more detail then on the Aircamper drawings. As to talking some sense into you, it seems to me you already have enough sense to know what you want. The Aircamper is a fine plane, the GN-1 is a fine plane and your Ryan-Camper 1 will be a fine plane too. Just start buildingand stop worrying what others will say. It's your money, your time and your dream. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com: ----- Original Message ----- From: Ryan Michalkiewicz: Sent: Sunday, April 15, 2007 8:51 AM Subject: Pietenpol-List: GN-1 Support Group, I regret to admit I am leaning toward a metal fuselage and the Riblett wing. The next logical step is the Grega. The whole point of my choice wasprice,open cockpitand the ability to use Corvair power.Does anyone know of any builders support or mailing lists? Could someone talk some sense into me? Thanks -Ryan ---------------- Ahhh...imagining that irresistible "new car" smell? Check out new ________________________________________________________________________________
Date: Apr 15, 2007
Ya came to da right place.Look into the archives and I'm sure you'll find a lot of stuff there.There are a lot of links to go to with a whole lot of pictures and instructions for what you are after.Just take your time and graze. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Catdesigns Sent: April 15, 2007 5:43 PM Subject: Re: Pietenpol-List: GN-1 Support Ryan Don't regret building the plane YOU want. What you will regret is wasting a lot of money and time building, and probably not finishing, the plane someone else wanted you to build. As DJ can attest, builders of the GN-1 are welcome on this list. Just remember to remind people your building a modified Grega and don't take everything you here personal. The thing that gets people all riled up is to call it a Pietenpol just call it by the right name and all will be good (mostly). We should all remember to call them Aircampers and GN-1's. I just pulled out my copy of the GN-1 plans and if your looking to build a steel fuselage these are the way to go. Much more detail then on the Aircamper drawings. As to talking some sense into you, it seems to me you already have enough sense to know what you want. The Aircamper is a fine plane, the GN-1 is a fine plane and your Ryan-Camper 1 will be a fine plane too. Just start building and stop worrying what others will say. It's your money, your time and your dream. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: Ryan Michalkiewicz <mailto:mskybolt(at)yahoo.com> To: pietenpol-list(at)matronics.com Sent: Sunday, April 15, 2007 8:51 AM Subject: Pietenpol-List: GN-1 Support Group, I regret to admit I am leaning toward a metal fuselage and the Riblett wing. The next logical step is the Grega. The whole point of my choice was price, open cockpit and the ability to use Corvair power. Does anyone know of any builders support or mailing lists? Could someone talk some sense into me? Thanks -Ryan ________________________________ Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. <http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html; _ ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM - > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat r onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Apr 15, 2007
Thank you Chris. They are both such great aircraft. I am an ex Champ pilot, and that may be what's pulling me in this direction. It was at the Ohio Aeronca Aviator fly-in, when I saw my first Pietenpol (I think it was Michael's) and have just admired the design ever since. Chris, Great advice! John Sent from my Verizon Wireless BlackBerry -----Original Message----- From: "Catdesigns" Date: Sun, 15 Apr 2007 13:42:54 To: Subject: Re: Pietenpol-List: GN-1 Support Ryan Don't regret building the plane YOU want. What you will regret is wasting a lot of money and time building, and probably not finishing, the plane someone else wanted you to build. As DJ can attest, builders of the GN-1 are welcome on this list. Just remember to remind people your building a modified Grega and don't take everything you here personal. The thing that gets people all riled up is to call it a Pietenpol just call it by the right name and all will be good (mostly). We should all remember to call them Aircampers and GN-1's. I just pulled out my copy of the GN-1 plans and if your looking to build a steel fuselage these are the way to go. Much more detail then on the Aircamper drawings. As to talking some sense into you, it seems to me you already have enough sense to know what you want. The Aircamper is a fine plane, the GN-1 is a fine plane and your Ryan-Camper 1 will be a fine plane too. Just start building and stop worrying what others will say. It's your money, your time and your dream. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com: ----- Original Message ----- From: Ryan Michalkiewicz: Sent: Sunday, April 15, 2007 8:51 AM Subject: Pietenpol-List: GN-1 Support Group, I regret to admit I am leaning toward a metal fuselage and the Riblett wing. The next logical step is the Grega. The whole point of my choice was price, open cockpit and the ability to use Corvair power. Does anyone know of any builders support or mailing lists? Could someone talk some sense into me? Thanks -Ryan ---------------- Ahhh...imagining that irresistible "new car" smell? Check out new --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 15, 2007
Amen Chris, the best sentences I've read on this list for the past few years. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 15, 2007
Subject: Tube squishing tool.
Hi Guys, Here are some pics of my tube squishing tool. This is the way Tony Bingelis says to do it. Works great and very cheap. Two pieces of angle iron in your vice. Dan Helsper ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Sun 'n' Fun
Date: Apr 16, 2007
S29kYWsgSFRNTCBFbWFpbERlY2lkZWQgZGlzY3JldGlvbiB3YXMgdGhlIGJldHRlciBwYXJ0IG9m IHZhbG9yLCBvciBzb21ldGhpbmcgbGlrZSB0aGF0LiAgSSBlbGVjdGVkIHRvIGdpdmUgdXAgb24g Zmx5aW5nIHRoZSBQaWV0ZW5wb2wgdG8gU3VuICduJyBGdW4uICANCg0KWWVzdGVyZGF5IHdhcyBo b3JyaWJsZSwgd2l0aCBtdWx0aXBsZSB0b3JuYWRvIHdhcm5pbmdzIGhlcmUgaW4gTm9ydGggQ2Fy b2xpbmEgYW5kIGJhZCB3eCBhbGwgdXAgYW5kIGRvd24gdGhlIGNvYXN0IGJldHdlZW4gaGVyZSBh bmQgRmxvcmlkYS4gIFRvZGF5IHRoZSBza3kgaXMgbW9zdGx5IGNsZWFyLCBidXQgdGhlIHdpbmRz IGFyZSBmb3JlY2FzdCB0byBiZSBzdHJhaWdodCBvdXQgb2YgdGhlIHdlc3QgYXQgMjUga25vdHMg d2l0aCBndXN0cyB0byA0NSBrbm90cyEgIEV2ZW4gaW4gRmxvcmlkYSB0aGUgd2luZHMgYXJlIGZv cmVjYXN0IGF0IDE4IGtub3RzIHdpdGggZ3VzdHMgdG8gMjgga25vdHMsIGFnYWluIGZyb20gdGhl IHdlc3QuICBFeGNlcHQgZm9yIExha2VsYW5kLCBldmVyeSBhaXJwb3J0IEknbSBwbGFubmluZyB0 byBsYW5kIGF0IGhhcyBub3J0aC1zb3V0aCBydW53YXlzLiAgTW9kZXJhdGUgdHVyYnVsZW5jZSBh bGwgYWxvbmcgbXkgcm91dGUsIGFuZCBldmVuIHRob3VnaCB0aGUgd2luZHMgYWxvZnQgYXJlIGlu IHRoZSA0MCBrbm90IHJhbmdlLCB0aGV5IGFyZSBibG93aW5nIGFjcm9zcyBteSBjb3Vyc2UgYW5k IG9mZmVyIG5vIGJlbmVmaXQuICBCeSB0b21vcnJvdyBldmVuaW5nIGEgd2FybSBmcm9udCB3aXRo IHNob3dlcnMgYW5kIFQtc3Rvcm1zIGlzIGZvcmVjYXN0IHRvIGJlIHN0cmV0Y2hpbmcgYWNyb3Nz IG5vcnRoIEZsb3JpZGEsIHNvIEkgcHJvYmFibHkgY291bGRuJ3QgZ28gdG9tb3Jyb3cgZWl0aGVy Lg0KDQpBbnl3YXksIEkgYm9va2VkIGEgZmxpZ2h0IG9uIFNvdXRod2VzdCBBaXJsaW5lcyBhbmQg d2lsbCBmbHkgZG93biB0b25pZ2h0IHdpdGggS2FyZW4uICBJIGhvcGUgc29tZSBQaWV0cyB3aWxs IG1ha2UgaXQgdGhlcmUuDQoNCkphY2sgUGhpbGxpcHMNCk5YODk5SlAgIA0K ________________________________________________________________________________
Date: Apr 16, 2007
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
I'm glad to hear you're going to keep your airplane safe and sound in your hangar, Jack. I kept watching the weather all weekend hoping that front would move out to sea but the stubborn NE'aster kept it hugging the shoreline. You just saved yourself two days of total aggravation that would have seemed like 20 days. Mike C. ________________________________________________________________________________
Subject: rolling into the grass on 9-27 at Oshkosh ?
Date: Apr 16, 2007
Does anyone have personal experience with how smooth or rough the grassy areas are off the sides of 9-27 at Oshkosh by chance ? If someone were to land a small-wheeled taildragger and then be directed to turn off into the grass, do you think that there might be rough areas enough to catch a main and cause some trouble ? Thank you, Mike C. ________________________________________________________________________________
Date: Apr 16, 2007
Subject: Re: rolling into the grass on 9-27 at Oshkosh ?
Mike, I have landed on 36/18 at OSH and taxied off to the grass on the west side with my Aeronca Sedan. I don't remember having any issues there. Can't say for the other runway. Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 16, 2007
Hi Mike; The grass on the south side of 9-27 is fairly smooth (smooth enough to taxi a Mooney without any problem, and then have the nose wheel fail and come apart (not from the grass) and still not hit the prop. I couldn't tell you about the North side. Cheers jon ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 16, 2007
To add to what Chris wrote and Corky "amen'd", I'd like to say- "just do it!" No matter which design or refinements you want to go with, get started. You'll never regret it. The icing on the cake is flying the airplane, and I got to take my oldest daughter up in 41CC yesterday for her first flight in an open cockpit airplane. It was great. Photo of us at http://www.flysquirrel.net/piets/Janna_Pop.jpg . My next victim, -er, passenger- was my next door neighbor Kyle "Itchy" Rash, who is a Marine aviator (EA-6B Prowler) and private pilot. Despite the lack of knee space up in the front cockpit, he had a great time and is eager to get his tailwheel endorsement so he can graduate to the roomy rear cockpit of the Piet ;o) Unroll those plans and start building! Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ The average US Credit Score is 675. The cost to see yours: $0 by Experian. http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE ________________________________________________________________________________
Date: Apr 16, 2007
Ok. I am on the hunt for plans now. In the mean time I will be practicing my welds. Cheers Oscar Zuniga wrote: To add to what Chris wrote and Corky "amen'd", I'd like to say- "just do it!" No matter which design or refinements you want to go with, get started. You'll never regret it. The icing on the cake is flying the airplane, and I got to take my oldest daughter up in 41CC yesterday for her first flight in an open cockpit airplane. It was great. Photo of us at http://www.flysquirrel.net/piets/Janna_Pop.jpg . My next victim, -er, passenger- was my next door neighbor Kyle "Itchy" Rash, who is a Marine aviator (EA-6B Prowler) and private pilot. Despite the lack of knee space up in the front cockpit, he had a great time and is eager to get his tailwheel endorsement so he can graduate to the roomy rear cockpit of the Piet ;o) Unroll those plans and start building! Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ The average US Credit Score is 675. The cost to see yours: $0 by Experian. http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Oil Cooling Success (I hope)
Date: Apr 17, 2007
Hi Guys, With some great help from William Wynne (thanks William) I installed a remote oil cooler underneath the Corvair engine and rebuilt the engine baffling to provide more efficient engine cooling. I carried out probably two hours of ground runs at varying times and rpm settings and have now achieved normal (I think) oil and cylinder head temps. Over the last couple of days I have had two reasonably short flights (30 minutes each) and temps have been normal. The last flight was three circuits around the pattern through full power climbs to near idle descents with all temps in the normal range. I need to do a flight of an hour or so to confirm that all is well but things are feeling pretty good. Check out the web site for some pictures. Look under "Engine Construction" > "Engine Cooling". Thanks to William for his time and advice. Cheers Peter Wonthaggi Australia http://www.cpc-world.com -- 5:53 PM ________________________________________________________________________________
Subject: EBAy peit with flaps.
Date: Apr 17, 2007
There is an engineless piet for sale on ebay item number 200100505599 Interestingly it has flaps... that would be interesting to try out. Steve e ________________________________________________________________________________
Date: Apr 17, 2007
Subject: Re: EBAy peit with flaps.
If it has the traditional BP-10 airfoil and flaps, "interesting" might be as in the Chinese curse-- "May you live in interesting times." The combined pitching moment of the Piet airfoil's undercamber and the added flaps would likely cause considrable instability. Maybe its builder moved the CG forward more (closer to 25% from wing LE than 33%) to accommodate. In any event, IMHO, someone needed to add "test pilot" to their logbook as they lowered the flaps. I'd love to hear what some very experienced Piet fliers will say about this. Perhaps it is another airfoil altogether. Tim in central TX -----Original Message----- >From: Steve Eldredge <steve(at)byu.edu> >Sent: Apr 17, 2007 8:48 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: EBAy peit with flaps. > > > >There is an engineless piet for sale on ebay item number 200100505599 > > > >Interestingly it has flaps... that would be interesting to try out. > > > >Steve e > ________________________________________________________________________________
Date: Apr 17, 2007
Yea it could be very interesting. I wonder what would happen as you slowed down... Sounds like the best be would be to try it with the XPlane program first, then at altitude with a ballistic chute. On 4/17/07, Tim Willis wrote: > > timothywillis(at)earthlink.net> > > If it has the traditional BP-10 airfoil and flaps, "interesting" might be > as in the Chinese curse-- "May you live in interesting times." The combined > pitching moment of the Piet airfoil's undercamber and the added flaps would > likely cause considrable instability. Maybe its builder moved the CG > forward more (closer to 25% from wing LE than 33%) to accommodate. In any > event, IMHO, someone needed to add "test pilot" to their logbook as they > lowered the flaps. > > I'd love to hear what some very experienced Piet fliers will say about > this. > > Perhaps it is another airfoil altogether. > > Tim in central TX > > -----Original Message----- > >From: Steve Eldredge <steve(at)byu.edu> > >Sent: Apr 17, 2007 8:48 AM > >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: EBAy peit with flaps. > > > > > > > >There is an engineless piet for sale on ebay item number 200100505599 > > > > > > > >Interestingly it has flaps... that would be interesting to try out. > > > > > > > >Steve e > > > > ________________________________________________________________________________
Date: Apr 17, 2007
would be fun to build a 33% scale RC Piet and play around with things like this. One day I plan to scale up my 1/8 scale RC Piet and do such things. When I retire in about 20 years check back with me then.... :) DJ Vegh veghdesign.com Mesa, AZ 602.743.5768 "Where there's a will there's a Vegh" - ----- Original Message ----- From: LWATCDR To: pietenpol-list(at)matronics.com Sent: Tuesday, April 17, 2007 2:02 PM Subject: Re: Pietenpol-List: EBAy peit with flaps. Yea it could be very interesting. I wonder what would happen as you slowed down... Sounds like the best be would be to try it with the XPlane program first, then at altitude with a ballistic chute. On 4/17/07, Tim Willis wrote: If it has the traditional BP-10 airfoil and flaps, "interesting" might be as in the Chinese curse-- "May you live in interesting times." The combined pitching moment of the Piet airfoil's undercamber and the added flaps would likely cause considrable instability. Maybe its builder moved the CG forward more (closer to 25% from wing LE than 33%) to accommodate. In any event, IMHO, someone needed to add "test pilot" to their logbook as they lowered the flaps. I'd love to hear what some very experienced Piet fliers will say about this. Perhaps it is another airfoil altogether. Tim in central TX -----Original Message----- >From: Steve Eldredge < steve(at)byu.edu> >Sent: Apr 17, 2007 8:48 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: EBAy peit with flaps. > > > >There is an engineless piet for sale on ebay item number 200100505599 > > > >Interestingly it has flaps... that would be interesting to try out. > > ________________________________________________________________________________
Date: Apr 17, 2007
If I kick my Piet into a slip,,,there is no place I coldn't get into. It's alot tighter than a 150 with 40 deg of flaps. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Steve Eldredge To: pietenpol-list(at)matronics.com Sent: Tuesday, April 17, 2007 10:48 AM Subject: Pietenpol-List: EBAy peit with flaps. There is an engineless piet for sale on ebay item number 200100505599 Interestingly it has flaps. that would be interesting to try out. Steve e ________________________________________________________________________________
Date: Apr 17, 2007
In a message dated 4/17/2007 11:47:34 AM Central Daylight Time, timothywillis(at)earthlink.net writes: I'd love to hear what some very experienced Piet fliers will say about this. Perhaps it is another airfoil altogether. Putting flaps on a Pietenpol airfoil, is like putting windshield wipers on a duck's ass !! Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 17, 2007
Subject: Anyone want to talk about slipping a Piet
I was taught by an ex P-51 pilot in the 60's, and he taught me slips. Maybe I got some great information, or maybe I don't know crap, But just thought of having a discussion about slipping . Maybe the new guys are not sure , or have never really been taught the art of slipping an airplane. (Wow, they don't even teach steep turns anymore. like 45 deg's is the max). Remember going thru your own wake. And the instructor said "good" at a 60 deg steep turn? Walt Evans NX140DL "No one ever learned anything by talking" ________________________________________________________________________________
Date: Apr 17, 2007
Chuck, Good one! Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Rcaprd(at)aol.com To: pietenpol-list(at)matronics.com Sent: Tuesday, April 17, 2007 5:42 PM Subject: Re: Pietenpol-List: EBAy peit with flaps. In a message dated 4/17/2007 11:47:34 AM Central Daylight Time, timothywillis(at)earthlink.net writes: I'd love to hear what some very experienced Piet fliers will say about this. Perhaps it is another airfoil altogether. Putting flaps on a Pietenpol airfoil, is like putting windshield wipers on a duck's ass !! Chuck G. NX770CG ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Apr 17, 2007
Good way to put it Chuck. I don't recall ever being too fast when landing my Piet. EVER. Even landing on a 1,000' strip is not a challenge. I once landed in field about 400' across. There was a long north/south runway, and a very short field that could be used for east/west landings in crosswinds. The wind was about 15mph from the east, I had no problem taking off to the south, but preferred to try landing in 400' than to land with a 15mph direct crosswind. I stopped in WAY under 400'. I can't see that you would gain anything with flaps, and you'd lose a fair amount of useful load. Interesting concept though. Steve Ruse Quoting Rcaprd(at)aol.com: > > Putting flaps on a Pietenpol airfoil, is like putting windshield wipers on a > duck's ass !! > > Chuck G. > NX770CG ________________________________________________________________________________
Date: Apr 17, 2007
Subject: Re: Anyone want to talk about slipping a Piet
The Piet is great for aggressive slips...I don't know exactly what angle I can come down at, but it must be darn near 45 degrees in an agressive slip. OK, it probably feels steeper than it is, but it is steeper than I've done in most other planes. This plane is so draggy, it must be about like flying a Cessna with a 3' parachute tied to the tail. I probably do a moderate slip on at least half of my landings. It helps keep the runway in sight. After probably 100 consecutive hours in my plane with no time in others, I tried to fly a buddies 150hp Citabria. Great machine, but when I tried to land, I was way, way too fast. Had to go around. I got into ground effect, and the stupid thing wouldn't slow down. Never had that happen in the Piet. I must've had a good instructor too...I remember the first time I felt that slight bump in smooth air after circling back through my own wake. I was surprised that it was still there enough to feel it. Kind of neat. Steve Ruse Norman, OK Quoting walt evans : > I was taught by an ex P-51 pilot in the 60's, and he taught me > slips. Maybe I got some great information, or maybe I don't know > crap, But just thought of having a discussion about slipping . > Maybe the new guys are not sure , or have never really been taught > the art of slipping an airplane. > (Wow, they don't even teach steep turns anymore. like 45 deg's is > the max). Remember going thru your own wake. And the instructor > said "good" at a 60 deg steep turn? > Walt Evans > NX140DL > "No one ever learned anything by talking" ________________________________________________________________________________
Date: Apr 17, 2007
Subject: Re: Anyone want to talk about slipping (or spinning)a
Piet Slips are quite fun in a piet, just like the champ. I think the piet slips a little better than a champ. It is more like a Cub I think. The piet has plenty of rudder to drag the side of the fuselage. Just be careful not to get too slow, Or she could swap ends real quick. (Never happened to me, but I don't want to spin a pietenpol) As "draggy" as a piet is it will slow down in a hurry. Don't be scared to try it but DO respect the fact that is a different airplane, and the first time you try it in a piet you will probably be solo, So as you say, Stay 3 mistakes high to get the feel of it, then work your way down. The good news is more than likely unless you are 30mph fast, or 500 ft high on final on a runway shorter than 3000ft long, you won't even need extra drag to settle her in and stop. By the way, Has anyone on this list ever done a spin in a Piet, on purpose or by accident? ......Wonder how fast it recovers? Shad --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: leading edge wrap
From: "skellytownflyer" <hanover(at)centramedia.net>
Date: Apr 17, 2007
Have any of you found that the hardware store flashing is a satisfactory quality for the leading edge wrap. my plans call for .013 thickness and say it will work. (GN-1 plans.) but haven't checked yet to see what they have to offer.but last time I lookd at flashing it seems like it was awfully soft. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=107661#107661 ________________________________________________________________________________
Subject: Re: leading edge wrap
Date: Apr 17, 2007
Bill Rewey tried it (hardware Store or lumber yard aluminum flashing ) on his first Pietenpol and said it was too soft. When the fabric was tightened it pulled the aluminum down. He recommends you don't use it. Roman Bukolt ----- Original Message ----- From: "skellytownflyer" <hanover(at)centramedia.net> Sent: Tuesday, April 17, 2007 8:16 PM Subject: Pietenpol-List: leading edge wrap > > > Have any of you found that the hardware store flashing is a satisfactory > quality for the leading edge wrap. my plans call for .013 thickness and > say it will work. (GN-1 plans.) but haven't checked yet to see what they > have to offer.but last time I lookd at flashing it seems like it was > awfully soft. Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=107661#107661 > > > ________________________________________________________________________________
Date: Apr 17, 2007
Subject: Leading edge rap
I'm surprised al. flashing is too soft. I remember reading once that BHP used cardboard about the consistency of Quaker oatmeal containers to cover only the top of the leading edge. Leon S. in Ks. ________________________________________________________________________________
Subject: latest "BPA News"
Date: Apr 18, 2007
I just got my BPA News in yesterday's mail (the publication that Doc and Dee Mosher put out). Some of it seems to be a little late, like DJ's classified ad offering his project for sale (long gone now). Plenty of good pictures, including the classic photo of Corky with 41CC, Walt Evans, Mike Cuy and Chuck Gantzer "smokin' em", Don Emch's Piet, and a bunch of others. A short bit by Paul Poberezny on jury struts. We do need to send material to Doc. Little tech tips, construction progress updates, you name it. And Mary Jones has promised to run a short bit on the repairs to 41CC in the June issue of either Sport Aviation or Sport Pilot, I'm not sure which. I dropped my subscription to Sport Pilot as it had a lot of duplication of what was in Sport Aviation. I installed a modified attach point for the front cockpit shoulder harness on 41CC, based on an idea in the last issue of the BPA newsletter. I'll take some photos and send them to Doc but will also put them on my website for you other guys to see and critique. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ The average US Credit Score is 675. The cost to see yours: $0 by Experian. http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE ________________________________________________________________________________
Date: Apr 18, 2007
I guess this was an engineering exercise to determine "can it be done" without common sense asking "why?" There must be a huge side load on that wing if you slip with flaps extended. Hans -----Original Message----- From: timothywillis(at)earthlink.net Sent: Tue, 17 Apr 2007 11:34 AM Subject: Re: Pietenpol-List: EBAy peit with flaps. If it has the traditional BP-10 airfoil and flaps, "interesting" might be as in the Chinese curse-- "May you live in interesting times." The combined pitching moment of the Piet airfoil's undercamber and the added flaps would likely cause considrable instability. Maybe its builder moved the CG forward more (closer to 25% from wing LE than 33%) to accommodate. In any event, IMHO, someone needed to add "test pilot" to their logbook as they lowered the flaps. I'd love to hear what some very experienced Piet fliers will say about this. Perhaps it is another airfoil altogether. Tim in central TX -----Original Message----- >From: Steve Eldredge <steve(at)byu.edu> >Sent: Apr 17, 2007 8:48 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: EBAy peit with flaps. > > > >There is an engineless piet for sale on ebay item number 200100505599 > > > >Interestingly it has flaps... that would be interesting to try out. > > > >Steve e > ________________________________________________________________________ ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Mounting motor cycle tires on rims
Hello Group, Does anybody have experiance mounting motor cycle tires on motor cycle rims using typical "home tools"? I built my laced wheels, have tires and tubes, and need to mount them. I expect, I'll need to make a fixture to hold the wheel secure first. Also, I have "TR-6" type valve stems on the inner tube. This is the valve stem that has exterior threads on the entire length of the stem, and two nuts are supplied with the stem. When I look at motor cycle wheel assemblies, this type of stem is often used. Apparently the stem can be held in place on the rim with the two nuts. My question is "should the stem be positioned as far out of the rim as possible (if so, I'm not sure why I need a second nut located inside the rim), or should the stem be located so the inner tube stands away from the rim interior a little at the stem location (requiring the second nut)? " Thank you in advance for any experience you may offer. With your help, I will soon have a rolling fuselage. John E Greenville, Wisconsin --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Re: latest
Oscar, I'd love to see your attach points. I have either seen a pic or the actual plane where the builder had run a cable across between the attachments on the rear cabanes. He had his shoulder harness attach points on that cable. This got the attach points up high so that spinal compression in a crash would not be an issue. This looked very workable, but a little "clanky". However, if the shoulder harness attach points were welded onto a piece of slightly bent rigid tube with the proper spacing (10-11" apart?) for the attachments, and that cable design were run through the tube, that would be a pretty good solution. Flexible tube over the cable on each end of the rigid tube assembly would center the rigid tube assembly and its shoulder harness attach points. With removable chain links on both ends, the cable and harness could be taken down quickly and stowed, when no passenger is on board. That's a little crude, but my plan until I see your design. I am looking for something better. Tim in central TX ==================================== >I installed a modified attach point for the front cockpit shoulder harness >on 41CC, based on an idea in the last issue of the BPA newsletter. I'll >take some photos and send them to Doc but will also put them on my website >for you other guys to see and critique. > >Oscar Zuniga >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Subject: Elevator bell crank construction....
Date: Apr 18, 2007
Hello Everyone!!!! I am building my Elv. Bellcrank, and was wondering what size clevises are used (5/16)??? And should I "sleeve" where the clevises attach to the bellcrank? (like on the rudder bar pivot bolt 3/8" o.d. tube w/ 5/16 bolt) Thanks in advance!!!!!! Dave http://forums.matronics.com This message, including any attachments, may contain confidential information and is transmitted for the sole use of the intended recipient. If you are not the intended recipient, you may not use, disseminate, copy or retain this e-mail or the information contained in it. If you have received this e-mail in error, please immediately notify the sender by telephone or reply e-mail, and permanently delete this e-mail from your computer system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message. Finally, the recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email. AION Diagnostics, Level 2, 40-48 Subiaco Square Road, Subiaco 6008, Australia, Phone: +61 (8) 6461 9400, Fax: +61 (8) 6461 9499This message, including any attachments, may contain confidential information and is transmitted for the sole use of the intended recipient. If you are not the intended recipient, you may not use, disseminate, copy or retain this e-mail or the information contained in it. If you have received this e-mail in error, please immediately notify the sender by telephone or reply e-mail, and permanently delete this e-mail from your computer system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message. Finally, the recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email. AION Diagnostics, Level 2, 40-48 Subiaco Square Road, Subiaco 6008, Australia, Phone: +61 (8) 6461 9400, Fax: +61 (8) 6461 9499 ________________________________________________________________________________
Subject: Re: Leading edge rap
Date: Apr 18, 2007
Reference Alum. flashing Sorry, I should have been more specific. Hardware store aluminum flashing is too soft. The aluminum from the aircraft catalogs is a stiffer alloy. It works just fine. That's what Bill Rewey used on the Piet he's been flying for the last 17 yrs. Keep in mind, that the front third of an airfoil is where all the performance comes from so the shape of the airfoil between the ribs can vary depending on the curve of that aluminum, or plywood, or oatmeal cardboard. No matter what you use, the plane will fly. Some better that others. The whole reason that the Riblett airfoil is so much better than the Pietenpol airfoil is the first 30%. Much deeper and more rounded leading edge yielding a softer, less critical stall and improved lift because of the airflow over and under the wing. Just my 50 cents worth (inflation,ya know!) Roman Bukolt NX20795 ----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> Sent: Tuesday, April 17, 2007 10:53 PM Subject: Pietenpol-List: Leading edge rap > > I'm surprised al. flashing is too soft. I remember reading once that BHP > used cardboard about the consistency of Quaker oatmeal containers to > cover only the top of the leading edge. Leon S. in Ks. > > > ________________________________________________________________________________
Date: Apr 18, 2007
Hi John...The tires can easily be mounted with hand tools . Just be really careful not to pinch the tube under what ever you use for a tire lever. The two nuts go on the outside of the rim. The second nut is a jam nut to keep the retaining nut from vibrateing loose as the first nut is not supposed to be very tight against the rim, just snug. You probably know this but spoked rims need a rubber chafe strip between the rim and the tube to keep the spoke nipples from punctureing the tube. Have fun. Ed G. .... I'll be at Sun N Fun tomorrow...YeeeHaw..... >From: John Egan <johnegan99(at)yahoo.com> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Mounting motor cycle tires on rims >Date: Wed, 18 Apr 2007 06:23:11 -0700 (PDT) > >Hello Group, > > Does anybody have experiance mounting motor cycle tires on motor cycle >rims using typical "home tools"? I built my laced wheels, have tires and >tubes, and need to mount them. I expect, I'll need to make a fixture to >hold the wheel secure first. > > Also, I have "TR-6" type valve stems on the inner tube. This is the >valve stem that has exterior threads on the entire length of the stem, and >two nuts are supplied with the stem. When I look at motor cycle wheel >assemblies, this type of stem is often used. Apparently the stem can be >held in place on the rim with the two nuts. My question is "should the >stem be positioned as far out of the rim as possible (if so, I'm not sure >why I need a second nut located inside the rim), or should the stem be >located so the inner tube stands away from the rim interior a little at the >stem location (requiring the second nut)? " > > Thank you in advance for any experience you may offer. With your help, I >will soon have a rolling fuselage. > > John E > Greenville, Wisconsin > > >--------------------------------- >Ahhh...imagining that irresistible "new car" smell? > Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Doc Mosher's "BPA News"
Date: Apr 18, 2007
I am really happy to see a true Pietenpol enthusiast running the newsletter again. Doc Mosher is a good guy and he has done a fine job in resurrecting a pretty lame newsletter. (no slam against the Independent Register in Brodhead since they merely compiled things send to them) Do we have any contact info Oscar, others, to subscribe ? I have it at home but not with me here at work. Mike C. ________________________________________________________________________________
Subject: Re: Leading edge rap Riblett and oatmeal
Date: Apr 18, 2007
Hi Guys Has a Riblett rib Pietenpol actually flown yet? Does anybody know of the performance? The other thing I was thinking is that they must have had really "big" boxes of oatmeal in the old days. Steve in Maine >From: "Roman Bukolt" <conceptmodels(at)tds.net> >Reply-To: pietenpol-list(at)matronics.com >To: >Subject: Re: Pietenpol-List: Leading edge rap >Date: Wed, 18 Apr 2007 08:45:37 -0500 > > > >Reference Alum. flashing >Sorry, I should have been more specific. Hardware store aluminum flashing >is too soft. The aluminum from the aircraft catalogs is a stiffer alloy. >It works just fine. That's what Bill Rewey used on the Piet he's been >flying for the last 17 yrs. >Keep in mind, that the front third of an airfoil is where all the >performance comes from so the shape of the airfoil between the ribs can >vary depending on the curve of that aluminum, or plywood, or oatmeal >cardboard. >No matter what you use, the plane will fly. Some better that others. The >whole reason that the Riblett airfoil is so much better than the Pietenpol >airfoil is the first 30%. Much deeper and more rounded leading edge >yielding a softer, less critical stall and improved lift because of the >airflow over and under the wing. > >Just my 50 cents worth (inflation,ya know!) >Roman Bukolt NX20795 >----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> >To: >Sent: Tuesday, April 17, 2007 10:53 PM >Subject: Pietenpol-List: Leading edge rap > > >> >>I'm surprised al. flashing is too soft. I remember reading once that BHP >>used cardboard about the consistency of Quaker oatmeal containers to >>cover only the top of the leading edge. Leon S. in Ks. >> >> >> >> >> >> > > _________________________________________________________________ Mortgage rates near historic lows. Refinance $200,000 loan for as low as $771/month* https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f8&disc=y&vers=689&s=4056&p=5117 ________________________________________________________________________________
Subject: Subscription info Pietenpol Newsletter
Date: Apr 18, 2007
Thanks to a strong Pietenpol enthusiast (Dick from Chapter 1279) from French Valley, California---here is the Piet Newsletter subscription info. Mike - BPA, c/o Independent - Register, PO Box 255, Broadhead, WI 53529-0255 $16 one yr, $30 two yr. Material for publication: BPA, PO Box 3501, Oshkosh, WI 54901 email: bpan(at)tds.net, web: www.pietenpols.org <http://www.pietenpols.org/> Cheers, Dick ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Re: Subscription info Pietenpol Newsletter
Thanks Mike! I just sent some pictures to the BPA newsletter! Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: latest "BPA News"
Date: Apr 18, 2007
wonder why yours took so long? Got my issue almost a month ago. Gene ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Wednesday, April 18, 2007 8:00 AM Subject: Pietenpol-List: latest "BPA News" > > > I just got my BPA News in yesterday's mail (the publication that Doc and > Dee Mosher put out). Some of it seems to be a little late, like DJ's > classified ad offering his project for sale (long gone now). Plenty of > good pictures, including the classic photo of Corky with 41CC, Walt Evans, > Mike Cuy and Chuck Gantzer "smokin' em", Don Emch's Piet, and a bunch of > others. A short bit by Paul Poberezny on jury struts. > > We do need to send material to Doc. Little tech tips, construction > progress updates, you name it. And Mary Jones has promised to run a short > bit on the repairs to 41CC in the June issue of either Sport Aviation or > Sport Pilot, I'm not sure which. I dropped my subscription to Sport Pilot > as it had a lot of duplication of what was in Sport Aviation. > > I installed a modified attach point for the front cockpit shoulder harness > on 41CC, based on an idea in the last issue of the BPA newsletter. I'll > take some photos and send them to Doc but will also put them on my website > for you other guys to see and critique. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > The average US Credit Score is 675. The cost to see yours: $0 by Experian. > http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE > > > ________________________________________________________________________________
Date: Apr 18, 2007
Oscar I miss spoke. It's only been about three weeks, not a month. Looking forward to your photos of the modified attach point. Gene ----- Original Message ----- http://www.flysquirrel.net > > _________________________________________________________________ > The average US Credit Score is 675. The cost to see yours: $0 by Experian. > http://www.freecreditreport.com/pm/default.aspx?sc=660600&bcd=EMAILFOOTERAVERAGE > > > ________________________________________________________________________________
Subject: A little off topic but I'm sure you've all flown major
airlines before
Date: Apr 18, 2007
West jet is a Canadian western airline out of Calgary;enjoy! > > > >West Jet is an Airline with head office situated in Calgary, Alberta. > > > >West Jet airline attendants make an effort to make the in-flight > > > >"safety lecture" and announcements a bit more entertaining. > > > > > > > >Here are some real examples that have been heard or reported: > > > > > > > > > > > >On a West Jet flight. There is no assigned seating, you just sit > > > >where you want. Passengers were apparently having a hard time > > > >choosing, when a flight attendant announced, "People, people > > > >we're not picking out furniture here, > > > >find a seat and get in it!" > > > >------------ --------- -- > > > >On another West Jet Flight with a very "senior" flight attendant > > > >crew, the pilot said, "Ladies and gentlemen, we've reached cruising > > > >altitude and will > > > >be turning down the cabin lights. This is for your comfort and to > > > >enhance the appearance of your flight attendants." > > > >------------ --------- --- > > > >On landing, the stewardess said, "Please be sure to take all of your > > > >belongings. If you're going to leave anything, please make sure it's > > > >something we'd like to have." > > > >------------ --------- --- > > > >"There may be 50 ways to leave your lover, but there are only 4 ways > > > >out of this airplane." > > > >------------ --------- -- > > > >"Thank you for flying West Jet Express. We hope you enjoyed giving us > > > >the business as much as we enjoyed taking you for a ride" > > > >------------ --------- ------ > > > >As the plane landed and was coming to a stop at the Vancouver > > > >airport, a lone voice came over the loudspeaker: "Whoa, big fella. > > > >WHOA!" > > > >------------ --------- ---- > > > >After a particularly rough landing during thunderstorms in Ontario, a > > > >flight attendant on a West Jet flight announced, "Please take care > > > >when opening the overhead compartments because, after a landing like > > > >that, sure as hell everything has shifted." > > > >------------ --------- -- > > > >From a West Jet Airlines employee: "Welcome aboard West Jet Flight > > > >245 to Calgary. To operate your seat belt, insert the metal tab into > > > >the buckle, and pull tight. It works just like every other seat belt; > > > >and, if you don't know how to operate one, you probably shouldn't be > > > >out in public unsupervised. " > > > >------------ --------- > > > >"In the event of a sudden loss of cabin pressure, masks will descend > > > >from the ceiling, stop screaming, grab the mask, and pull it over > > > >your face. > > > >If you have a small child traveling with you, secure your mask before > > > >assisting with theirs. If you are traveling with more than one small > > > >child, pick your favorite." > > > >------------ --------- -- > > > >"Weather at our destination is 50 degrees with some broken clouds, > > > >but we'll try to have them fixed before we arrive. Thank you, and > > > >remember, nobody loves you, or your money, more than West Jet > > > >Airlines." > > > >------------ --------- --- > > > >"Your seat cushions can be used for flotation; and in the event of an > > > >emergency water landing, please paddle to shore and take them with > > > >our compliments. " > > > >------------ --------- -- > > > >"As you exit the plane, make sure to gather all of your belongings. > > > >Anything left behind will be distributed evenly among the flight > > > >attendants. Please do not leave children or spouses." > > > >------------ --------- ------ > > > >And from the pilot during his welcome message: "West Jet Airlines is > > > >pleased to announce that we have some of the best flight attendants > > > >in the industry. Unfortunately, none of them are on this flight!" > > > >------------ --------- -------- > > > >Heard on West Jet Airlines just after a very hard landing in > > > >Edmonton; The flight attendant came on the intercom and said, > > > >"That was quite a bump, and > > > >I know what y'all are thinking. I'm here to tell you it wasn't the > > > >airline's fault, it wasn't the pilot's fault, it wasn't the flight > > > >attendant's fault, it was the asphalt." > > > >------------ --------- --------- > > > >Overheard on a West Jet Airlines flight into Regina on a particularly > > > >windy and bumpy day: During the final approach, the Captain was > > > >really having to fight it. After an extremely hard landing, the > > > >Flight Attendant said, "Ladies and Gentlemen, welcome to Regina. > > > >Please remain in your seats with > > > >your seat belts fastened while the Captain taxis what's left of our > > > >airplane to the gate!" > > > >------------ --------- --------- > > > >Another flight attendant's comment on a less than perfect landing: > > > >"We ask you to please remain seated as Captain Kangaroo bounces us > > > >to the terminal." > > > >------------ --------- > > > >An airline pilot wrote that on this particular flight he had hammered > > > >his ship into the runway really hard. The airline had a policy which > > > >required the first officer to stand at the door while the Passengers > > > >exited, smile, and give them a "Thanks for flying our airline." > > > >He said that, in light of > > > >his bad landing, he had a hard time looking the passengers in the > > > >eye, thinking that someone would have a smart comment. Finally > > > >everyone had gotten off except for a little old lady walking with a > > > >cane. She said, "Sir, do you mind if I ask you a question?" > > > >"Why, no, Ma'am," said the pilot. "What is it?" > > > >The little old lady said, "Did we land, or were we shot down?" > > > >------------ ------- > > > >After a real crusher of a landing in Halifax, the attendant came on > > > >with, "Ladies and Gentlemen, please remain in your seats until > > > >Captain Crash and the Crew have brought the aircraft to a screeching > > > >halt against the gate. > > > >And, once the tire smoke has cleared and the warning bells are > > > >silenced, we > > > >will open the door and you can pick your way through the wreckage to > > > >the terminal." > > > >------------ --------- -- > > > >Part of a flight attendant's arrival announcement: "We'd like to > > > >thank you folks for flying with us today. And, the next time you get > > > >the insane urge > > > >to go blasting through the skies in a pressurized metal tube, we hope > > > >you'll think of West Jet Airways." > > > >------------ --------- -- > > > >Heard on a West Jet Airline flight. "Ladies and gentlemen, if you > > > >wish to smoke, the smoking section on this airplane is on the wing. > > > >If you can light 'em, you can smoke 'em." > > > >------------ --------- -- > > > >A plane was taking off from the Winnipeg airport. After it reached a > > > >comfortable cruising altitude, the captain made an announcement over > > > >the intercom, "Ladies and gentlemen, this is your captain speaking. > > > >Welcome to Flight Number 293, nonstop from Winnipeg to Montreal. > > > >The weather ahead is good and, therefore, we should have a smooth and > > > >uneventful flight. Now sit back and relax.. OH, MY GOD!" > > > >Silence followed, and after a few minutes, the captain came back on > > > >the intercom and said, "Ladies and Gentlemen, I am so sorry if I > > > >scared you earlier. While I was talking to you, the flight attendant > > > >accidentally spilled a cup of hot coffee on my lap. You should see > > > >the front of my pants!" A passenger yelled: "That's nothing. You > > > >should see the back of mine!" ________________________________________________________________________________
Date: Apr 18, 2007
FYI This is Lowell Frank's blue Piet with the Riblett 612 airfoil. I does outperform the Piets with Piet airfoils. Roman Bukolt ----- Original Message ----- From: "Steve Glass" <redsglass(at)hotmail.com> Sent: Wednesday, April 18, 2007 10:36 AM Subject: Re: Pietenpol-List: Leading edge rap Riblett and oatmeal > > > Hi Guys > > Has a Riblett rib Pietenpol actually flown yet? Does anybody know of the > performance? > > The other thing I was thinking is that they must have had really "big" > boxes of oatmeal in the old days. > > Steve in Maine > > >>From: "Roman Bukolt" <conceptmodels(at)tds.net> >>Reply-To: pietenpol-list(at)matronics.com >>To: >>Subject: Re: Pietenpol-List: Leading edge rap >>Date: Wed, 18 Apr 2007 08:45:37 -0500 >> >> >> >>Reference Alum. flashing >>Sorry, I should have been more specific. Hardware store aluminum flashing >>is too soft. The aluminum from the aircraft catalogs is a stiffer alloy. >>It works just fine. That's what Bill Rewey used on the Piet he's been >>flying for the last 17 yrs. >>Keep in mind, that the front third of an airfoil is where all the >>performance comes from so the shape of the airfoil between the ribs can >>vary depending on the curve of that aluminum, or plywood, or oatmeal >>cardboard. >>No matter what you use, the plane will fly. Some better that others. The >>whole reason that the Riblett airfoil is so much better than the Pietenpol >>airfoil is the first 30%. Much deeper and more rounded leading edge >>yielding a softer, less critical stall and improved lift because of the >>airflow over and under the wing. >> >>Just my 50 cents worth (inflation,ya know!) >>Roman Bukolt NX20795 >>----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> >>To: >>Sent: Tuesday, April 17, 2007 10:53 PM >>Subject: Pietenpol-List: Leading edge rap >> >> >>> >>>I'm surprised al. flashing is too soft. I remember reading once that BHP >>>used cardboard about the consistency of Quaker oatmeal containers to >>>cover only the top of the leading edge. Leon S. in Ks. >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >
April 05, 2007 - April 18, 2007
Pietenpol-Archive.digest.vol-fu
