Pietenpol-Archive.digest.vol-fv
April 18, 2007 - May 17, 2007
      > _________________________________________________________________
      > Mortgage rates near historic lows. Refinance $200,000 loan for as low as
      > $771/month*
      > https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f8&disc=y&vers=689&s=4056&p=5117
Subject: Leading edge rap Riblett and oatmeal
Date: Apr 18, 2007
Because of the airfoil or because of the Warner? :0 Steve E. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Roman Bukolt Sent: Wednesday, April 18, 2007 11:47 AM Subject: Re: Pietenpol-List: Leading edge rap Riblett and oatmeal FYI This is Lowell Frank's blue Piet with the Riblett 612 airfoil. I does outperform the Piets with Piet airfoils. Roman Bukolt ----- Original Message ----- From: "Steve Glass" <redsglass(at)hotmail.com> Sent: Wednesday, April 18, 2007 10:36 AM Subject: Re: Pietenpol-List: Leading edge rap Riblett and oatmeal > > > Hi Guys > > Has a Riblett rib Pietenpol actually flown yet? Does anybody know of the > performance? > > The other thing I was thinking is that they must have had really "big" > boxes of oatmeal in the old days. > > Steve in Maine > > >>From: "Roman Bukolt" <conceptmodels(at)tds.net> >>Reply-To: pietenpol-list(at)matronics.com >>To: >>Subject: Re: Pietenpol-List: Leading edge rap >>Date: Wed, 18 Apr 2007 08:45:37 -0500 >> >> >> >>Reference Alum. flashing >>Sorry, I should have been more specific. Hardware store aluminum flashing >>is too soft. The aluminum from the aircraft catalogs is a stiffer alloy. >>It works just fine. That's what Bill Rewey used on the Piet he's been >>flying for the last 17 yrs. >>Keep in mind, that the front third of an airfoil is where all the >>performance comes from so the shape of the airfoil between the ribs can >>vary depending on the curve of that aluminum, or plywood, or oatmeal >>cardboard. >>No matter what you use, the plane will fly. Some better that others. The >>whole reason that the Riblett airfoil is so much better than the Pietenpol >>airfoil is the first 30%. Much deeper and more rounded leading edge >>yielding a softer, less critical stall and improved lift because of the >>airflow over and under the wing. >> >>Just my 50 cents worth (inflation,ya know!) >>Roman Bukolt NX20795 >>----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> >>To: >>Sent: Tuesday, April 17, 2007 10:53 PM >>Subject: Pietenpol-List: Leading edge rap >> >> >>> >>>I'm surprised al. flashing is too soft. I remember reading once that BHP >>>used cardboard about the consistency of Quaker oatmeal containers to >>>cover only the top of the leading edge. Leon S. in Ks. >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > _________________________________________________________________ > Mortgage rates near historic lows. Refinance $200,000 loan for as low as > $771/month* > https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&se arch=mortgage_text_links_88_h27f8&disc=y&vers=689&s=4056&p=5117 > > > ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Re: Riblett and performance
Roman, As you may recall, I am an advocate of the Riblett airfoil, at least for guys not already challenged by CG issues (fat boys, like me). I think anyone of moderate weight building anew should strongly consider the Riblett airfoil. The counterpoint is "pure Piet," stick to the design, build to the plans, etc. But I'd like to focus on performance. However, with this in mind, as Chuck G. pointed out (I think) doesn't Lowell's plane also have an over-100hp radial on it? I think the discussion I recall was comparative climbing rate or how much rollout on takeoff. Higher power, of course, would distort any comparative results. You can have another discussion, as well, about the apparent possible higher cruising speed with a Riblett, and/or the better controlability of the landing in a smoother stall. All these seem possible with a Riblett, as with the NACA 2412 or 4412 airfoils. Of course, plopping 'em down in really short fields, the BP-10 Piet should come out way ahead. (As Chuck says, it's like a notch of flaps all the time.) Is anyone aware of an apples-to-apples test, Piet vs. Riblett, with the same or comparable engines-- e.g., when each was equipped with an A-65 or a Corvair engine? Does anyone have a Riblett airfoil on an A-65? Please forgive me if I have my facts or past discussions wrong. Tim in central TX -----Original Message----- >From: Roman Bukolt <conceptmodels(at)tds.net> >Sent: Apr 18, 2007 11:47 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Leading edge rap Riblett and oatmeal > >FYI This is Lowell Frank's blue Piet with the Riblett 612 airfoil. It does >outperform the Piets with Piet airfoils. > >Roman Bukolt >----- Original Message ----- >From: "Steve Glass" <redsglass(at)hotmail.com> >To: >Sent: Wednesday, April 18, 2007 10:36 AM >Subject: Re: Pietenpol-List: Leading edge rap Riblett and oatmeal >> >> >> >> Hi Guys >> >> Has a Riblett rib Pietenpol actually flown yet? Does anybody know of the >> performance? Steve in Maine >> >> ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Date: Apr 18, 2007
I would say the WARNER!!!!! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Steve Eldredge Sent: Wednesday, April 18, 2007 11:02 AM Subject: RE: Pietenpol-List: Leading edge rap Riblett and oatmeal Because of the airfoil or because of the Warner? :0 Steve E. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Roman Bukolt Sent: Wednesday, April 18, 2007 11:47 AM Subject: Re: Pietenpol-List: Leading edge rap Riblett and oatmeal FYI This is Lowell Frank's blue Piet with the Riblett 612 airfoil. I does outperform the Piets with Piet airfoils. Roman Bukolt ----- Original Message ----- From: "Steve Glass" <redsglass(at)hotmail.com> Sent: Wednesday, April 18, 2007 10:36 AM Subject: Re: Pietenpol-List: Leading edge rap Riblett and oatmeal > > > Hi Guys > > Has a Riblett rib Pietenpol actually flown yet? Does anybody know of the > performance? > > The other thing I was thinking is that they must have had really "big" > boxes of oatmeal in the old days. > > Steve in Maine > > >>From: "Roman Bukolt" <conceptmodels(at)tds.net> >>Reply-To: pietenpol-list(at)matronics.com >>To: >>Subject: Re: Pietenpol-List: Leading edge rap >>Date: Wed, 18 Apr 2007 08:45:37 -0500 >> >> >> >>Reference Alum. flashing >>Sorry, I should have been more specific. Hardware store aluminum flashing >>is too soft. The aluminum from the aircraft catalogs is a stiffer alloy. >>It works just fine. That's what Bill Rewey used on the Piet he's been >>flying for the last 17 yrs. >>Keep in mind, that the front third of an airfoil is where all the >>performance comes from so the shape of the airfoil between the ribs can >>vary depending on the curve of that aluminum, or plywood, or oatmeal >>cardboard. >>No matter what you use, the plane will fly. Some better that others. The >>whole reason that the Riblett airfoil is so much better than the Pietenpol >>airfoil is the first 30%. Much deeper and more rounded leading edge >>yielding a softer, less critical stall and improved lift because of the >>airflow over and under the wing. >> >>Just my 50 cents worth (inflation,ya know!) >>Roman Bukolt NX20795 >>----- Original Message ----- From: "Leon Stefan" <lshutks(at)webtv.net> >>To: >>Sent: Tuesday, April 17, 2007 10:53 PM >>Subject: Pietenpol-List: Leading edge rap >> >> >>> >>>I'm surprised al. flashing is too soft. I remember reading once that BHP >>>used cardboard about the consistency of Quaker oatmeal containers to >>>cover only the top of the leading edge. Leon S. in Ks. >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > _________________________________________________________________ > Mortgage rates near historic lows. Refinance $200,000 loan for as low as > $771/month* > https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&se arch=mortgage_text_links_88_h27f8&disc=y&vers=689&s=4056&p=5117 > > ________________________________________________________________________________
Date: Apr 18, 2007
Roman, Thanks for the quick reply. His radial should be comparable in power to a Corvair, then, and that might allow a good comparison to a Corvair with a BP-10 foil. Of course, the torque curves could be quite different. Your project when finished will be a better metric. How about asking Lowell if he had a Piet airfoil on it first, and if he has any comparative data? Tim in central TX -----Original Message----- >From: Roman Bukolt <conceptmodels(at)tds.net> >Sent: Apr 18, 2007 1:09 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Riblett and performance > > >I'll have a Riblett on my corvair Piet when it's finished, one day in the >future. >The radial on Lowell's plane isn't a Warner. I don't recall what it is. I >do know that it is a 90hp. >I also know that when I saw it take off, the pilot didn't even go to full >throttle. >Other than that, If I remember right, Lowell did fly that same plane and >cengine with a Piet airfoil, but I may be mistaken. > >But as Chucky says, ya gotta admit, with the Piet you can drop'm in a pretty >small airpatch. Ever see films of a goony bird land? Its like that. PLOP! >I'd be fun to watch a Piet land with Tundra tires! Boing! Boing! boing! >etc. etc.etc. > >Roman Bukolt > ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Re: Mounting motor cycle tires on rims
Also John, Put a small dot of paint on the rim and right next to it on the rubber tire. This will show at a glance if the tire is sliding around the rim from the quick starting of the tire on landing. I had a valve stem get sheared off on a Fisher Biplane. Wasn't nice, had to have a friend fly back for another tube. Just look at the dots in preflight. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Ed G." <flyboy_120(at)hotmail.com> Sent: Wednesday, April 18, 2007 9:46 AM Subject: RE: Pietenpol-List: Mounting motor cycle tires on rims > > > Hi John...The tires can easily be mounted with hand tools . Just be really > careful not to pinch the tube under what ever you use for a tire lever. > The two nuts go on the outside of the rim. The second nut is a jam nut to > keep the retaining nut from vibrateing loose as the first nut is not > supposed to be very tight against the rim, just snug. You probably know > this but spoked rims need a rubber chafe strip between the rim and the > tube to keep the spoke nipples from punctureing the tube. Have fun. Ed > G. .... I'll be at Sun N Fun tomorrow...YeeeHaw..... > >>From: John Egan <johnegan99(at)yahoo.com> >>Reply-To: pietenpol-list(at)matronics.com >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Mounting motor cycle tires on rims >>Date: Wed, 18 Apr 2007 06:23:11 -0700 (PDT) >> >>Hello Group, >> >> Does anybody have experiance mounting motor cycle tires on motor cycle >> rims using typical "home tools"? I built my laced wheels, have tires and >> tubes, and need to mount them. I expect, I'll need to make a fixture to >> hold the wheel secure first. >> >> Also, I have "TR-6" type valve stems on the inner tube. This is the >> valve stem that has exterior threads on the entire length of the stem, >> and two nuts are supplied with the stem. When I look at motor cycle >> wheel assemblies, this type of stem is often used. Apparently the stem >> can be held in place on the rim with the two nuts. My question is >> "should the stem be positioned as far out of the rim as possible (if so, >> I'm not sure why I need a second nut located inside the rim), or should >> the stem be located so the inner tube stands away from the rim interior a >> little at the stem location (requiring the second nut)? " >> >> Thank you in advance for any experience you may offer. With your help, >> I will soon have a rolling fuselage. >> >> John E >> Greenville, Wisconsin >> >> >> >> >> >> >>--------------------------------- >>Ahhh...imagining that irresistible "new car" smell? >> Check outnew cars at Yahoo! Autos. > > > ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Re: Elevator bell crank construction....
5/16 seems way to large. I have 1/4 inch holes in mine simply because that was the size turnbuckles I had. Most light airplanes that I have looked at use 3/16 bolts through the turnbuckle at the terminal end. I made mine to the plans with the two thin sheets formed to an airfoil and then edge welded, with no sleeve. Ben Charvet Mims, Fl Got to meet Doc Mosher today at Sun-N-Fun! Dave Abramson wrote: > Hello Everyone!!!! > > I am building my Elv. Bellcrank, and was wondering what size clevises > are used (5/16)??? And should I sleeve where the clevises attach to > the bellcrank? > > (like on the rudder bar pivot bolt 3/8 o.d. tube w/ 5/16 bolt) > > Thanks in advance!!!!!! > > Dave > >* * > >* * > >* * > ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Re: latest
On NX92GB, we used AN eye bolts to hold the center section to the cabanes (rear cabanes). They are rated at the same sheer load as regular AN-4 bolts or AN-5's (I can't remember what size they are). These provide an easy way to attach passenger shoulder harness. The plan is to run a piece of cable from side to side with quick disconnect type fittings, then attatch the harness. I can't say we have it all figured out though, we have not hauled passengers yet, or installed the harness for flight. Just another Idea if any one wants to try it. Shad --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 18, 2007
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: Re: latest
Photos please..... Ken shad bell wrote: On NX92GB, we used AN eye bolts to hold the center section to the cabanes (rear cabanes). They are rated at the same sheer load as regular AN-4 bolts or AN-5's (I can't remember what size they are). These provide an easy way to attach passenger shoulder harness. The plan is to run a piece of cable from side to side with quick disconnect type fittings, then attatch the harness. I can't say we have it all figured out though, we have not hauled passengers yet, or installed the harness for flight. Just another Idea if any one wants to try it. Shad --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Mounting motor cycle tires on rims
Date: Apr 19, 2007
John, I have Motor cycle rims on my Piet. I must admit I cheat and let a motor cycle shop put the tyres on for me. Very cheap and I know it=92s done correctly. Other than that you need a couple of long tyre irons and plenty of soapy water. Advice I have had regarding the valve stem is to only use one nut. This is placed against the valve stem cap leaving the whole of the valve stem visible. The valve stem is therefore free to move a bit if the tyre/tube flexes a bit too much on landing. Hope that helps. Cheers Peter Wonthaggi Australia HYPERLINK "http://www.cpc-world.com/"http://www.cpc-world.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Egan Sent: Wednesday, 18 April 2007 11:23 PM Subject: Pietenpol-List: Mounting motor cycle tires on rims Hello Group, Does anybody have experiance mounting motor cycle tires on motor cycle rims using typical "home tools"? I built my laced wheels, have tires and tubes, and need to mount them. I expect, I'll need to make a fixture to hold the wheel secure first. Also, I have "TR-6" type valve stems on the inner tube. This is the valve stem that has exterior threads on the entire length of the stem, and two nuts are supplied with the stem. When I look at motor cycle wheel assemblies, this type of stem is often used. Apparently the stem can be held in place on the rim with the two nuts. My question is "should the stem be positioned as far out of the rim as possible (if so, I'm not sure why I need a second nut located inside the rim), or should the stem be located so the inner tube stands away from the rim interior a little at the stem location (requiring the second nut)? " Thank you in advance for any experience you may offer. With your help, I will soon have a rolling fuselage. John E Greenville, Wisconsin _____ Ahhh...imagining that irresistible "new car" smell? Check out HYPERLINK "http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html; _ylc X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-"new cars at Yahoo! Autos. "http://www.matronics.com/Navigator?Pietenpol-List"http://www.matronics.c om/ Navigator?Pietenpol-List "http://forums.matronics.com"http://forums.matronics.com -- 18/04/2007 7:39 AM -- 18/04/2007 7:39 AM ________________________________________________________________________________
Date: Apr 18, 2007
Subject: Re: Anyone want to talk about slipping a Piet
Go here; http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg You may have to use the Realplayer option to see it properly. Clif Roman, Good for you. Two basic things my instructor taught me........................ Say you're going to slip to the left...................... 1. Right rudder to the stops. (that's the standard, never let up on that) 2. left aileron to the left, use the left aileron as needed to get PROPER GROUND TRACK. 3. All the time watching the nose pitch. the airspeed indicator will read funky due to the air going over the pitot at an angle, and not reading correctly. You've got to keep the nose pitched down,,,,lots more that normal!!!! then when you get good over the field,, like 20 feet,,,relax everyting!!!! And land as normal Walt Evans NX140DL "No one ever learned anything by talking" ________________________________________________________________________________
From: "Scott Knowlton" <flyingscott_k(at)hotmail.com>
Date: Apr 19, 2007
Nice video. What an inspiration to get back to the shop and keep building (not to mention the inspiration to drive the 12 hours to go back to Broadhead this summer). Scott K (a slow piet builder in Ontario) >From: Clif Dawson <CDAWSON5854(at)shaw.ca> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet >Date: Wed, 18 Apr 2007 23:26:38 -0700 > >Go here; > >http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg > >You may have to use the Realplayer option to see it >properly. > >Clif > > Roman, > Good for you. > Two basic things my instructor taught me........................ > Say you're going to slip to the left...................... > 1. Right rudder to the stops. (that's the standard, never let up on >that) > 2. left aileron to the left, use the left aileron as needed to get >PROPER GROUND TRACK. > 3. All the time watching the nose pitch. the airspeed indicator will >read funky due to the air going over the pitot at an angle, and not reading >correctly. > You've got to keep the nose pitched down,,,,lots more that normal!!!! > then when you get good over the field,, like 20 feet,,,relax >everyting!!!! > And land as normal > Walt Evans > NX140DL > "No one ever learned anything by talking" _________________________________________________________________ Find the best places on campus to get take out, study & unwind http://www.liveu.ca/explore.aspx ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Lowell Frank's Piet
Date: Apr 19, 2007
I'm thinking that this was discussed here a while back, but maybe it's my memory. In any case, I spoke with Lowell at Brodhead the year he first flew with his new wings. All he did was build a new set of wings, nothing else was changed. So this gives a side by side exact comparison. If someone talks to him regularly, they should write down the specs and post them, if not I can call him. I do remember him saying that his cruise speed went up, his stall speed went down, the stall was gentler, his climb was quicker and I'm thinking his landing speed was slower. Other than that, nothing really changed. Douwe ________________________________________________________________________________
Date: Apr 19, 2007
Subject: Re: Lowell Frank's Piet
There could be no better test. We would all benefit from Lowell's expeience. Will someone volunteer to get his comparative data? Thanks, Tim in central TX -----Original Message----- >From: Douwe Blumberg <douweblumberg(at)earthlink.net> >Sent: Apr 19, 2007 7:53 AM >To: pietenpolgroup >Subject: Pietenpol-List: Lowell Frank's Piet > >I'm thinking that this was discussed here a while back, but maybe it's my memory. In any case, I spoke with Lowell at Brodhead the year he first flew with his new wings. All he did was build a new set of wings, nothing else was changed. So this gives a side by side exact comparison. > >If someone talks to him regularly, they should write down the specs and post them, if not I can call him. > >I do remember him saying that his cruise speed went up, his stall speed went down, the stall was gentler, his climb was quicker and I'm thinking his landing speed was slower. > >Other than that, nothing really changed. > >Douwe ________________________________________________________________________________
Subject: Anyone want to talk about slipping a Piet
Date: Apr 19, 2007
The only planes I flew for years were my T'craft or my Chief. When I checked out in a 172 I was completely confused by a slipless flapped approach. I couldn't get used to landing with the nose lined up with the runway. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Scott Knowlton Sent: April 19, 2007 9:52 AM Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet Nice video. What an inspiration to get back to the shop and keep building (not to mention the inspiration to drive the 12 hours to go back to Broadhead this summer). Scott K (a slow piet builder in Ontario) >From: Clif Dawson <CDAWSON5854(at)shaw.ca> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet >Date: Wed, 18 Apr 2007 23:26:38 -0700 > >Go here; > >http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg > >You may have to use the Realplayer option to see it >properly. > >Clif > > Roman, > Good for you. > Two basic things my instructor taught me........................ > Say you're going to slip to the left...................... > 1. Right rudder to the stops. (that's the standard, never let up on >that) > 2. left aileron to the left, use the left aileron as needed to get >PROPER GROUND TRACK. > 3. All the time watching the nose pitch. the airspeed indicator will >read funky due to the air going over the pitot at an angle, and not reading >correctly. > You've got to keep the nose pitched down,,,,lots more that normal!!!! > then when you get good over the field,, like 20 feet,,,relax >everyting!!!! > And land as normal > Walt Evans > NX140DL > "No one ever learned anything by talking" _________________________________________________________________ Find the best places on campus to get take out, study & unwind http://www.liveu.ca/explore.aspx ________________________________________________________________________________
Date: Apr 19, 2007
If you all really want to slip an airplane in any flying conditions to include high winds....try an Ercoupe! Now thats a modified slip looking over the passengers shoulders!....tee-hee-hee Ken Robert Gow wrote: The only planes I flew for years were my T'craft or my Chief. When I checked out in a 172 I was completely confused by a slipless flapped approach. I couldn't get used to landing with the nose lined up with the runway. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Scott Knowlton Sent: April 19, 2007 9:52 AM Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet Nice video. What an inspiration to get back to the shop and keep building (not to mention the inspiration to drive the 12 hours to go back to Broadhead this summer). Scott K (a slow piet builder in Ontario) >From: Clif Dawson >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet >Date: Wed, 18 Apr 2007 23:26:38 -0700 > >Go here; > >http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg > >You may have to use the Realplayer option to see it >properly. > >Clif > > Roman, > Good for you. > Two basic things my instructor taught me........................ > Say you're going to slip to the left...................... > 1. Right rudder to the stops. (that's the standard, never let up on >that) > 2. left aileron to the left, use the left aileron as needed to get >PROPER GROUND TRACK. > 3. All the time watching the nose pitch. the airspeed indicator will >read funky due to the air going over the pitot at an angle, and not reading >correctly. > You've got to keep the nose pitched down,,,,lots more that normal!!!! > then when you get good over the field,, like 20 feet,,,relax >everyting!!!! > And land as normal > Walt Evans > NX140DL > "No one ever learned anything by talking" _________________________________________________________________ Find the best places on campus to get take out, study & unwind http://www.liveu.ca/explore.aspx --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 19, 2007
exactly!!! I have that vid, but I love to watch it over and over Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Thursday, April 19, 2007 2:26 AM Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet Go here; http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg You may have to use the Realplayer option to see it properly. Clif Roman, Good for you. Two basic things my instructor taught me........................ Say you're going to slip to the left...................... 1. Right rudder to the stops. (that's the standard, never let up on that) 2. left aileron to the left, use the left aileron as needed to get PROPER GROUND TRACK. 3. All the time watching the nose pitch. the airspeed indicator will read funky due to the air going over the pitot at an angle, and not reading correctly. You've got to keep the nose pitched down,,,,lots more that normal!!!! then when you get good over the field,, like 20 feet,,,relax everyting!!!! And land as normal Walt Evans NX140DL "No one ever learned anything by talking" ________________________________________________________________________________
Date: Apr 19, 2007
Bob, I've said before that with the few planes over the years that I've checked out in, with flaps. I could get into alot tighter places while slipping my Piet. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Robert Gow" <rgow(at)avionicsdesign.ca> Sent: Thursday, April 19, 2007 10:43 AM Subject: RE: Pietenpol-List: Anyone want to talk about slipping a Piet > > > The only planes I flew for years were my T'craft or my Chief. When I > checked out in a 172 I was completely confused by a slipless flapped > approach. I couldn't get used to landing with the nose lined up with the > runway. > > Bob > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Scott > Knowlton > Sent: April 19, 2007 9:52 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet > > > > > Nice video. What an inspiration to get back to the shop and keep building > (not to mention the inspiration to drive the 12 hours to go back to > Broadhead this summer). > > Scott K (a slow piet builder in Ontario) > > >>From: Clif Dawson <CDAWSON5854(at)shaw.ca> >>Reply-To: pietenpol-list(at)matronics.com >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet >>Date: Wed, 18 Apr 2007 23:26:38 -0700 >> >>Go here; >> >>http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg >> >>You may have to use the Realplayer option to see it >>properly. >> >>Clif >> >> Roman, >> Good for you. >> Two basic things my instructor taught me........................ >> Say you're going to slip to the left...................... >> 1. Right rudder to the stops. (that's the standard, never let up on >>that) >> 2. left aileron to the left, use the left aileron as needed to get >>PROPER GROUND TRACK. >> 3. All the time watching the nose pitch. the airspeed indicator will >>read funky due to the air going over the pitot at an angle, and not >>reading >>correctly. >> You've got to keep the nose pitched down,,,,lots more that normal!!!! >> then when you get good over the field,, like 20 feet,,,relax >>everyting!!!! >> And land as normal >> Walt Evans >> NX140DL >> "No one ever learned anything by talking" > > _________________________________________________________________ > Find the best places on campus to get take out, study & unwind > http://www.liveu.ca/explore.aspx > > > ________________________________________________________________________________
Date: Apr 19, 2007
Subject: Is a CHT gauge necessary, or just nice?
OK, I've finally got a little money and I'm putting my instrument panel together. For the engine, I figure the oil pressure and temp gauges are essential. And of course the tach. But I'm wondering if you veteran A-65 pilots like to keep tabs on the cylinder head temp? My mentor (my Dad) says he never had much use for one, but it seems like it might come in handy. Also, anyone have experience cutting the holes with a common hole saw? Does that work, if you back up the plywood, or does it chew up the backside anyway? Maybe a fly cutter is the way to go? Thanks in advance Ken, making slow progress in Austin, Texas ________________________________________________________________________________
Subject: Re: Is a CHT gauge necessary, or just nice?
Date: Apr 19, 2007
If you can't change it, it doesn't do you any good. I'd chuck it. Also, for thin plywood, I like using a flycutter, just back it up with a piece of soft pine or something. Gene ----- Original Message ----- From: Ken Chambers<mailto:ken.riffic(at)gmail.com> To: pietenpol-list(at)matronics.com Sent: Thursday, April 19, 2007 5:26 PM Subject: Pietenpol-List: Is a CHT gauge necessary, or just nice? OK, I've finally got a little money and I'm putting my instrument panel together. For the engine, I figure the oil pressure and temp gauges are essential. And of course the tach. But I'm wondering if you veteran A-65 pilots like to keep tabs on the cylinder head temp? My mentor (my Dad) says he never had much use for one, but it seems like it might come in handy. Also, anyone have experience cutting the holes with a common hole saw? Does that work, if you back up the plywood, or does it chew up the backside anyway? Maybe a fly cutter is the way to go? Thanks in advance Ken, making slow progress in Austin, Texas http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> ________________________________________________________________________________
Date: Apr 19, 2007
Cylinder temp? Naw, only watched that when flying 2 strokes Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Ken Chambers To: pietenpol-list(at)matronics.com Sent: Thursday, April 19, 2007 5:26 PM Subject: Pietenpol-List: Is a CHT gauge necessary, or just nice? OK, I've finally got a little money and I'm putting my instrument panel together. For the engine, I figure the oil pressure and temp gauges are essential. And of course the tach. But I'm wondering if you veteran A-65 pilots like to keep tabs on the cylinder head temp? My mentor (my Dad) says he never had much use for one, but it seems like it might come in handy. Also, anyone have experience cutting the holes with a common hole saw? Does that work, if you back up the plywood, or does it chew up the backside anyway? Maybe a fly cutter is the way to go? Thanks in advance Ken, making slow progress in Austin, Texas ________________________________________________________________________________
Date: Apr 19, 2007
I had reason, sometime back before the dynasaurs were extinct, to slip an F-4 into an approch for which I was poorly set up (too high, too fast). My back-seater, having never been in a real airplane*, screamed bloody murder all the way to our safe landing. I was able later to make him realize that a slip is an excellent way to get down in a hurry, even in 15 tons of military brick. Mike Hardaway PS: *A real airplane has one engine in front and the tail wheel is on the correct end. ---- walt evans wrote: > > Bob, > I've said before that with the few planes over the years that I've checked > out in, with flaps. I could get into alot tighter places while slipping my > Piet. > Walt Evans > NX140DL > "No one ever learned anything by talking" > ----- Original Message ----- > From: "Robert Gow" <rgow(at)avionicsdesign.ca> > To: > Sent: Thursday, April 19, 2007 10:43 AM > Subject: RE: Pietenpol-List: Anyone want to talk about slipping a Piet > > > > > > > > The only planes I flew for years were my T'craft or my Chief. When I > > checked out in a 172 I was completely confused by a slipless flapped > > approach. I couldn't get used to landing with the nose lined up with the > > runway. > > > > Bob > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Scott > > Knowlton > > Sent: April 19, 2007 9:52 AM > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet > > > > > > > > > > Nice video. What an inspiration to get back to the shop and keep building > > (not to mention the inspiration to drive the 12 hours to go back to > > Broadhead this summer). > > > > Scott K (a slow piet builder in Ontario) > > > > > >>From: Clif Dawson <CDAWSON5854(at)shaw.ca> > >>Reply-To: pietenpol-list(at)matronics.com > >>To: pietenpol-list(at)matronics.com > >>Subject: Re: Pietenpol-List: Anyone want to talk about slipping a Piet > >>Date: Wed, 18 Apr 2007 23:26:38 -0700 > >> > >>Go here; > >> > >>
http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg > >> > >>You may have to use the Realplayer option to see it > >>properly. > >> > >>Clif > >> > >> Roman, > >> Good for you. > >> Two basic things my instructor taught me........................ > >> Say you're going to slip to the left...................... > >> 1. Right rudder to the stops. (that's the standard, never let up on > >>that) > >> 2. left aileron to the left, use the left aileron as needed to get > >>PROPER GROUND TRACK. > >> 3. All the time watching the nose pitch. the airspeed indicator will > >>read funky due to the air going over the pitot at an angle, and not > >>reading > >>correctly. > >> You've got to keep the nose pitched down,,,,lots more that normal!!!! > >> then when you get good over the field,, like 20 feet,,,relax > >>everyting!!!! > >> And land as normal > >> Walt Evans > >> NX140DL > >> "No one ever learned anything by talking" > > > > _________________________________________________________________ > > Find the best places on campus to get take out, study & unwind > > http://www.liveu.ca/explore.aspx > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2007
Lowell Frank used to have an inverted Funk engine ( Ford Model B actually turned upright, does that make sense?), then he went to a 145 HP Warner ( that's right, a 145), he sold that a few years ago and put a Lambert on it about 2 or so years ago. I think that is the 90 horse. I flew with him when it had the 145 on it. It was all engine! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=108006#108006 ________________________________________________________________________________
Date: Apr 19, 2007
Clif, That was a very nice slip and landing......wish I was at the controls. Ken Heide Fargo, ND Clif Dawson wrote: Go here; http://westcoastpiet.com/Videos/AirCamper-Slip.mpeg You may have to use the Realplayer option to see it properly. Clif Roman, Good for you. Two basic things my instructor taught me........................ Say you're going to slip to the left...................... 1. Right rudder to the stops. (that's the standard, never let up on that) 2. left aileron to the left, use the left aileron as needed to get PROPER GROUND TRACK. 3. All the time watching the nose pitch. the airspeed indicator will read funky due to the air going over the pitot at an angle, and not reading correctly. You've got to keep the nose pitched down,,,,lots more that normal!!!! then when you get good over the field,, like 20 feet,,,relax everyting!!!! And land as normal Walt Evans NX140DL "No one ever learned anything by talking" --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 20, 2007
I'm putting one on my Franklin soon but I'm not sure which cylinder to put it on.I'm only using one temperature gauge. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ken Chambers Sent: April 19, 2007 5:26 PM Subject: Pietenpol-List: Is a CHT gauge necessary, or just nice? OK, I've finally got a little money and I'm putting my instrument panel together. For the engine, I figure the oil pressure and temp gauges are essential. And of course the tach. But I'm wondering if you veteran A-65 pilots like to keep tabs on the cylinder head temp? My mentor (my Dad) says he never had much use for one, but it seems like it might come in handy. Also, anyone have experience cutting the holes with a common hole saw? Does that work, if you back up the plywood, or does it chew up the backside anyway? Maybe a fly cutter is the way to go? Thanks in advance Ken, making slow progress in Austin, Texas ________________________________________________________________________________
Date: Apr 20, 2007
Subject: Hoe saw
I've had good luck with a hole saw by backing the work with a wood block. Also you can start your hole from one side, then finish it from the other side. that works well when free hading with a hand drill. Fly cutters are great but only in a drill press. Leon S. In Ks. wishing I were in Fl. ________________________________________________________________________________
From: "Graham and Robyn" <grhewitt(at)globaldial.com>
Subject: Re Rudder/TaFor riggingilwheel cables
Date: Apr 20, 2007
For rigging tail wheel steering cables, what are your views, to avoid excess weight; instead of running cables all the way from the rear rudder pedals to the tail wheel, what about splicing by Nico Press the tail wheel cables to the rudder cables just before they exit the side of the fuse? Would this cause any side loads on the rudder cable with possible lost motion? Thanks Graham Hewitt ________________________________________________________________________________
Date: Apr 20, 2007
I don't think so if you include the springs with the connection at the back on the tail wheel butterfly connection. It may make it feel heavier in flight to move the rudder but still doable as long as the springs aren't too tight or heavy duty.. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham and Robyn Sent: April 20, 2007 7:06 AM Subject: Pietenpol-List: Re Rudder/TaFor riggingilwheel cables For rigging tail wheel steering cables, what are your views, to avoid excess weight; instead of running cables all the way from the rear rudder pedals to the tail wheel, what about splicing by Nico Press the tail wheel cables to the rudder cables just before they exit the side of the fuse? Would this cause any side loads on the rudder cable with possible lost motion? Thanks Graham Hewitt ________________________________________________________________________________
Date: Apr 20, 2007
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Subject: Tail attachment
I have seen in the archives a question about the attachment of the horizontal stab to the fuselage (from Rick Holland) that intererst me, and since it doesn't have an answer I will post it again. The two bottom fittings are attached to each other with two horizontal bolts through the fuselage tailpost, however the fuselage sides are angled. Did you guys makes 4 wedged shaped washers out of something so the bolt head and nut seat flat or add 2 wood wedges for the fittings to sit on? I will use bolts, no rivets. Another question, I have seen Piets with the horizontal stab bolted at the leading edge, main spar or both. I plan to bolt it trough the main beam. What would be recommendable? Thanks Saludos Santiago --------------------------------- Pregunt. Respond. Descubr. Todo lo que queras saber, y lo que ni imaginabas, est en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: Apr 20, 2007
just try to pick the cyl with least airflow. Typically a rear one! Often found on number 3. harvey.rule(at)bell.ca wrote: v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} st1\:*{behavior:url(#default#ieooui) } Im putting one on my Franklin soon but Im not sure which cylinder to put it on.Im only using one temperature gauge. --------------------------------- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ken Chambers Sent: April 19, 2007 5:26 PM Subject: Pietenpol-List: Is a CHT gauge necessary, or just nice? OK, I've finally got a little money and I'm putting my instrument panel together. For the engine, I figure the oil pressure and temp gauges are essential. And of course the tach. But I'm wondering if you veteran A-65 pilots like to keep tabs on the cylinder head temp? My mentor (my Dad) says he never had much use for one, but it seems like it might come in handy. Also, anyone have experience cutting the holes with a common hole saw? Does that work, if you back up the plywood, or does it chew up the backside anyway? Maybe a fly cutter is the way to go? Thanks in advance Ken, making slow progress in Austin, Texas http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com ________________________________________________________________________________
Date: Apr 20, 2007
Thanks,I'll try that one. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jonathan Scholl Sent: April 20, 2007 11:30 AM Subject: RE: Pietenpol-List: Is a CHT gauge necessary, or just nice? just try to pick the cyl with least airflow. Typically a rear one! Often found on number 3. ________________________________________________________________________________
Subject: Hoe saw
Date: Apr 20, 2007
I to would rather cut with a hole saw than a flycutter. The hole is not as crisp but the cut is safer and more controllable. "HOE saw" careful look what happened to Imus. Steve in Maine >From: lshutks(at)webtv.net (Leon Stefan) >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Hoe saw >Date: Fri, 20 Apr 2007 06:21:25 -0500 > > >I've had good luck with a hole saw by backing the work with a wood >block. Also you can start your hole from one side, then finish it from >the other side. that works well when free hading with a hand drill. Fly >cutters are great but only in a drill press. Leon S. In Ks. wishing I >were in Fl. > > _________________________________________________________________ Download Messenger. Join the im Initiative. Help make a difference today. http://im.live.com/messenger/im/home/?source=TAGHM_APR07 ________________________________________________________________________________
Subject: lowell frank's stats
Date: Apr 20, 2007
Spoke with Lowell Frank today, and he gave me his best estimates of the differences between his plane with the Piet wing and the same plane now with the Ribblett 612. His plane is exactly the same, except the new wing is two feet shorter. He did this because the new wing has more lift. He says he recommends people leave the original length now to get extra lift and he doesn't think it'll slow things down much at all. Most of you know, but his plane has a 90hp Lambert on it, which it did with the Piet wing too. He's also had a model B on it, a Funk engine, a 145 Warner and now the lambert. He says the most noticible difference is in the top speed, which he says increased 15 mph Stall dropped about 5 mph He claims the climb almost doubled it is much more responsive to throttle changes now. Hope this helps. I'd like to purchase some Ribblett drawings, can someone get me his contact info? Thanks Douwe ________________________________________________________________________________
Date: Apr 20, 2007
Subject: Re: lowell frank's stats
Douwe, Those are impressive differences. I would think that with an A-65 there might not be that much difference in cruising speed. Re the drawing, Roman Bukolt has scaled out the Riblett 613.5, which Riblett himself says is the best for the Piet. (It has a taller camber on the upper surface than the 612.) IMHO, the 613.5 should accentuate the benefits that Lowell found of the Riblett 612 over the BP-10. Roman sells the full scale drawings of the 613.5 for $10 or $15-- I forget which-- postage paid. You might contact him. I found it to be a very workable drawing. (I am not building that airfoil now, however.) Roman also has the plots for the 613.5, which are NOT included in Riblett's last edition of his "GA Airfoils." I don't recall if he has the plots for the 612, but I do, if you need them, as I got them from my copy of Riblett's book. Tim in central TX -----Original Message----- >From: Douwe Blumberg <douweblumberg(at)earthlink.net> >Sent: Apr 20, 2007 1:51 PM >To: pietenpolgroup >Subject: Pietenpol-List: lowell frank's stats > >Spoke with Lowell Frank today, and he gave me his best estimates of the differences between his plane with the Piet wing and the same plane now with the Ribblett 612. > >His plane is exactly the same, except the new wing is two feet shorter. He did this because the new wing has more lift. He says he recommends people leave the original length now to get extra lift and he doesn't think it'll slow things down much at all. > >Most of you know, but his plane has a 90hp Lambert on it, which it did with the Piet wing too. He's also had a model B on it, a Funk engine, a 145 Warner and now the lambert. > >He says the most noticible difference is in the top speed, which he says increased 15 mph > >Stall dropped about 5 mph > >He claims the climb almost doubled > >it is much more responsive to throttle changes now. > >Hope this helps. I'd like to purchase some Ribblett drawings, can someone get me his contact info? > >Thanks > >Douwe ________________________________________________________________________________
Date: Apr 20, 2007
From: Charles Tracy <charlestracy2635(at)yahoo.com>
I ran across this link while looking at the Airplane PDQ web site. They have a long list of airfoils that you can download for free in autocad. I believe the Ribblett 612 is one of them. This might help in developing a rib. Of coarse it would be easier if someone has a layout with rib framing already. Download the zip file at this address: http://www.davincitechnologies.com/AirfoilOptimizerStdAirfoils.htm Charlie Douwe Blumberg wrote: Spoke with Lowell Frank today, and he gave me his best estimates of the differences between his plane with the Piet wing and the same plane now with the Ribblett 612. His plane is exactly the same, except the new wing is two feet shorter. He did this because the new wing has more lift. He says he recommends people leave the original length now to get extra lift and he doesn't think it'll slow things down much at all. Most of you know, but his plane has a 90hp Lambert on it, which it did with the Piet wing too. He's also had a model B on it, a Funk engine, a 145 Warner and now the lambert. He says the most noticible difference is in the top speed, which he says increased 15 mph Stall dropped about 5 mph He claims the climb almost doubled it is much more responsive to throttle changes now. Hope this helps. I'd like to purchase some Ribblett drawings, can someone get me his contact info? Thanks Douwe --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 20, 2007
FYI I have the full size drawings of both the Riblett 612 and the Riblett 613.5 available. They are $10.00 each including shipping and handling. BTW 24 Piet people so far have ordered the 612 and two ordered both the 612 anf the 613.5. Roman Bukolt (Not Roman Gukolt) 6505 Urich Terr. Madison, Wi. 53719 ----- Original Message ----- From: "Tim Willis" <timothywillis(at)earthlink.net> Sent: Friday, April 20, 2007 3:56 PM Subject: Re: Pietenpol-List: lowell frank's stats > > > Douwe, > > Those are impressive differences. I would think that with an A-65 there > might not be that much difference in cruising speed. > > Re the drawing, Roman Bukolt has scaled out the Riblett 613.5, which > Riblett himself says is the best for the Piet. (It has a taller camber on > the upper surface than the 612.) IMHO, the 613.5 should accentuate the > benefits that Lowell found of the Riblett 612 over the BP-10. > > Roman sells the full scale drawings of the 613.5 for $10 or $15-- I forget > which-- postage paid. You might contact him. I found it to be a very > workable drawing. (I am not building that airfoil now, however.) > > Roman also has the plots for the 613.5, which are NOT included in > Riblett's last edition of his "GA Airfoils." I don't recall if he has the > plots for the 612, but I do, if you need them, as I got them from my copy > of Riblett's book. > > Tim in central TX > > > -----Original Message----- >>From: Douwe Blumberg <douweblumberg(at)earthlink.net> >>Sent: Apr 20, 2007 1:51 PM >>To: pietenpolgroup >>Subject: Pietenpol-List: lowell frank's stats >> >>Spoke with Lowell Frank today, and he gave me his best estimates of the >>differences between his plane with the Piet wing and the same plane now >>with the Ribblett 612. >> >>His plane is exactly the same, except the new wing is two feet shorter. >>He did this because the new wing has more lift. He says he recommends >>people leave the original length now to get extra lift and he doesn't >>think it'll slow things down much at all. >> >>Most of you know, but his plane has a 90hp Lambert on it, which it did >>with the Piet wing too. He's also had a model B on it, a Funk engine, a >>145 Warner and now the lambert. >> >>He says the most noticible difference is in the top speed, which he says >>increased 15 mph >> >>Stall dropped about 5 mph >> >>He claims the climb almost doubled >> >>it is much more responsive to throttle changes now. >> >>Hope this helps. I'd like to purchase some Ribblett drawings, can someone >>get me his contact info? >> >>Thanks >> >>Douwe > > > ________________________________________________________________________________
Subject: Re: Tail attachment
Date: Apr 21, 2007
Hi Santiago...There are probably several ways to do the tailpost fittings but I just made a couple of small 1/8" plywood wedges and glued them to the tailpost so that the fittings would sit square to the centerline of the fuselage. It worked out fine. For the front of the stabilizer most builders are replaceing the #7 wood screws with 8-32 an bolts through the main beam. I put self locking nut plates on the bottom of the longeron but again, there are different ways to do that too. I haven't decided how I will fasten down the leading edge yet. Ed G. ----- Original Message ----- From: santiago morete<mailto:moretesantiago(at)yahoo.com.ar> To: pietenpol-list(at)matronics.com Sent: Friday, April 20, 2007 11:00 AM Subject: Pietenpol-List: Tail attachment I have seen in the archives a question about the attachment of the horizontal stab to the fuselage (from Rick Holland) that intererst me, and since it doesn't have an answer I will post it again. The two bottom fittings are attached to each other with two horizontal bolts through the fuselage tailpost, however the fuselage sides are angled. Did you guys makes 4 wedged shaped washers out of something so the bolt head and nut seat flat or add 2 wood wedges for the fittings to sit on? I will use bolts, no rivets. Another question, I have seen Piets with the horizontal stab bolted at the leading edge, main spar or both. I plan to bolt it trough the main beam. What would be recommendable? Thanks Saludos Santiago ------------------------------------------------------------------------- ----- Pregunt=E1. Respond=E9. Descubr=ED. Todo lo que quer=EDas saber, y lo que ni imaginabas, est=E1 en Yahoo! Respuestas (Beta). http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> ________________________________________________________________________________
Date: Apr 21, 2007
Subject: GN-1 Roll call
I am just wondering how may Grega fliers are on the list. What stage is your project in? What fuselage? What engine? Any other mods? Myself, I have ordered "Complete" plans from a "guy" in Oregon. We will see what arrives at my door if anything. I have been practicing my welds, I was getting a little worried, but I am feeling better about them. I have a Corvair core, ready for tear down. Thanks all, -Ryan --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Re: GN-1 Roll call
Date: Apr 21, 2007
Mike King GN-1 77MK Ponder, Texas (Dallas/Ft. Worth area) Built in 1985 A-80 Cont. Several hundred hours of flying time Dual controls / instruments ELT, radio antenna, digital tach, slide bar to step into rear cockpit (will install smoke system and gap seals in 2007) ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Saturday, April 21, 2007 1:18 PM Subject: Pietenpol-List: GN-1 Roll call I am just wondering how may Grega fliers are on the list. What stage is your project in? What fuselage? What engine? Any other mods? Myself, I have ordered "Complete" plans from a "guy" in Oregon. We will see what arrives at my door if anything. I have been practicing my welds, I was getting a little worried, but I am feeling better about them. I have a Corvair core, ready for tear down. Thanks all, -Ryan ------------------------------------------------------------------------- ----- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 21, 2007
Subject: Re: lowell frank's stats-- Roman's Drawings
BTW, Roman's Riblett airfoil drawings are rib plots, which really help. I believe that I recall that Roman took pains to make sure that his drawing dimensions are true to the numerical plots. In other words, his drawings are not just a cheap copy job, but a blueprint quality copy. I have only seen the 613.5 drawing myself, but was glad to get it. This is an unpaid testimonial. FYI, I believe the full names of the two Riblett airfoils are the Riblett GA30A612 and the Riblett GA30u613.5, but I have been told that Riblett may have dropped the letters in the middle of his former nomenclature. A likely "almost right" explanation follows: -- The "GA" stands for "general aviation," -- the "30" stands for how far back on the chord (as a percent of the chord, from the LE) the thickest part of the camber fits, and --the "12" or "13.5" is the maximum thickness of the camber, expressed as a percent thickness of the chord. Laid against a Piet rib, the Riblett 13.5 is about an inch taller in the upper surface and an inch lower in the lower surface. The Riblett nose is much more rounded until after the first 30 percent of the chord. There is a VERY slight undercamber on the lower airfoil surface, like the Piet, but only toward the tail of the airfoil. Overall, the airfoil looks quite a bit like a Clark Y that is taller (thicker). However, the Riblett's lower surface drops lower below the chordline than the Clark Y in the first third of the chord, and thus looks more like a NACA 2412 or 4412 below. It's more laminar below than a Piet or Clark Y. The spars can be at least two inches taller than the Piet's, and thus both heavier and stronger. This might be a good application for a built-up spar, like "Peter's Piet" Down Under. These numbers and comparisons are all somewhat inexact, but good overall impressions. Tim in central TX -----Original Message----- >From: Roman Bukolt <conceptmodels(at)tds.net> >Sent: Apr 20, 2007 3:19 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: lowell frank's stats > > >FYI >I have the full size drawings of both the Riblett 612 and the Riblett 613.5 >available. They are $10.00 each including shipping and handling. >BTW 24 Piet people so far have ordered the 612 and two ordered both the 612 >anf the 613.5. > >Roman Bukolt (Not Roman Gukolt) >6505 Urich Terr. >Madison, Wi. 53719 ________________________________________________________________________________
Date: Apr 21, 2007
Harvey Rule GN-1 C-IOVC Ottawa,Ontario,Canada Finished in 2006 Franklin 80 hp 2hrs.flight time so far Single seat;front seat used for battery Old style step and flop door on center section wing. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mike King Sent: April 21, 2007 3:02 PM Subject: Re: Pietenpol-List: GN-1 Roll call Mike King GN-1 77MK Ponder, Texas (Dallas/Ft. Worth area) Built in 1985 A-80 Cont. Several hundred hours of flying time Dual controls / instruments ELT, radio antenna, digital tach, slide bar to step into rear cockpit (will install smoke system and gap seals in 2007) ----- Original Message ----- From: Ryan Michalkiewicz <mailto:mskybolt(at)yahoo.com> To: pietenpol-list(at)matronics.com Sent: Saturday, April 21, 2007 1:18 PM Subject: Pietenpol-List: GN-1 Roll call I am just wondering how may Grega fliers are on the list. What stage is your project in? What fuselage? What engine? Any other mods? Myself, I have ordered "Complete" plans from a "guy" in Oregon. We will see what arrives at my door if anything. I have been practicing my welds, I was getting a little worried, but I am feeling better about them. I have a Corvair core, ready for tear down. Thanks all, -Ryan ________________________________ Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. <
http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html; _ ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM - > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat r onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
From: "skellytownflyer" <hanover(at)centramedia.net>
Date: Apr 21, 2007
Got DJ Vegh's GN-1 project-working on wings now-close to ready to cover.fuselage about same.finishing up a lot of details that take 10 times the amount of time you think they should as allways but it is fun.Raymond Hanover.Skellytown TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=108380#108380 ________________________________________________________________________________
Subject: Re: GN-1 roll call
Date: Apr 22, 2007
My GN-1is almost ready to cover. All that's left is some wiring and hooking up some Bowden cables. It has a Continental 0-200 and it's located in Denham Springs, Louisiana. Wayne Poole dxechkn(at)earthlink.net EarthLink Revolves Around You. ________________________________________________________________________________
Date: Apr 22, 2007
Subject: Continental engings ARE amazing
Went to the airport today to fly for the first time since November. Primed the A-65 twice, with switch off, pulled 6 blades thru, Left mag (impulse) on, flipped it the first time and it was running. Oil pressure came right up, too. Amazing!!!! Walt Evans NX140DL "No one ever learned anything by talking" ________________________________________________________________________________
Date: Apr 22, 2007
Mine used to start like that every time. Lately though, it takes 10-45 blades before starting. Any tips on how to troubleshoot it would be appreciated. It has dual impulse mags (Slick, with maybe 400 hours?). I don't have a primer and I know that will make it take a little longer to start, but it used to take ~6-7 blades, which is a long ways for 10-45. Warm it will generally start on the first pull. Steve Ruse Norman, OK _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt evans Sent: Sunday, April 22, 2007 10:00 AM Subject: Pietenpol-List: Continental engings ARE amazing Went to the airport today to fly for the first time since November. Primed the A-65 twice, with switch off, pulled 6 blades thru, Left mag (impulse) on, flipped it the first time and it was running. Oil pressure came right up, too. Amazing!!!! Walt Evans NX140DL "No one ever learned anything by talking" ________________________________________________________________________________
Date: Apr 22, 2007
Mine is a GN-1, however I'm not the builder. I've been flying it for a little over two years now.well over 200 hours since I bought it, and I have no complaints. Steve Ruse Norman, OK _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Michalkiewicz Sent: Saturday, April 21, 2007 1:18 PM Subject: Pietenpol-List: GN-1 Roll call I am just wondering how may Grega fliers are on the list. What stage is your project in? What fuselage? What engine? Any other mods? Myself, I have ordered "Complete" plans from a "guy" in Oregon. We will see what arrives at my door if anything. I have been practicing my welds, I was getting a little worried, but I am feeling better about them. I have a Corvair core, ready for tear down. Thanks all, -Ryan _____ Ahhh...imagining that irresistible "new car" smell? Check out new <http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html;_ylc X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-> cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 22, 2007
Al Lyscars here in Portland, Maine. Building ribs over this winter. My old pal, Paul, fabricating 4130 fittings for me in Brunswick (just up the road from me). Am using the Riblet airfoil. I have a Corvair core which I intend to use on this ship. Al ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Saturday, April 21, 2007 2:18 PM Subject: Pietenpol-List: GN-1 Roll call I am just wondering how may Grega fliers are on the list. What stage is your project in? What fuselage? What engine? Any other mods? Myself, I have ordered "Complete" plans from a "guy" in Oregon. We will see what arrives at my door if anything. I have been practicing my welds, I was getting a little worried, but I am feeling better about them. I have a Corvair core, ready for tear down. Thanks all, -Ryan ------------------------------------------------------------------------- ----- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 22, 2007
Ryan, I started my GN-1 project 14 months ago. I have milled all the wood (Doug Fir) and fabricated all the fittings, so this is a true "scratch build" and I'm proud of it. The wings and tail feathers are covered using Stewart Systems' Eco Bond and Eco Fill -- great stuff. So far my wing panels seem kind of heavy at 67 lbs uncovered, but I have 1" Fir Spars and the 25% weight penalty is coming home to roost. The fuselage and all controls and cables are complete and tested. The landing gear legs, fuel system, wheels and brakes, and FWF remain. Looking for O-200 or C90. Regards, Tom Bernie Gloucester, Mass. ________________________________________________________________________________
Date: Apr 23, 2007
Subject: Re: Continental engings ARE amazing
In a message dated 4/22/2007 5:20:38 PM Central Daylight Time, steve(at)wotelectronics.com writes: Mine used to start like that every time. Lately though, it takes 10-45 blades before starting. Any tips on how to troubleshoot it would be appreci ated. It has dual impulse mags (Slick, with maybe 400 hours?). I don=99t ha ve a primer and I know that will make it take a little longer to start, but it us ed to take ~6-7 blades, which is a long ways for 10-45. Warm it will generally start on the first pull. Steve Ruse Norman, OK Steve, Walt is right on about these Continental A65's. I don't have a primer o n mine, either. I finally did my first flight of the year, this evening. Haven't flown since mid December. One of the many many things I did to prep are for the flying season, with about 300 hrs on the engine and slick mags, I pu lled both mags off and set the e-gap. They were both off by several degrees. I had to buy a T-150 tool to set the e-gap. I then timed both mags to the eng ine at 30=C2=BA BTDC. Mags off, cold engine, throttle idle, stick back in the s eat belt, in the chocks, I pull 8 blades through. Walk back to the cockpit and say it out loud "fuel on, engine idle, stick's back, in the chocks, Contact". S he fired right up on the first blade, and idled nicely...and that was with 1 gallon of old fuel. I think it was due to adjusting the e-gap. I drained a ll the old fuel (put it in my car), and taxiied over to the pumps with 1gal in the tank. I could meet you at the Breakfast Fly-In at Ponca City on May 5, and let ya borrow my T-150 e-gap gauge, if you like. Or, you could mail order one to keep in your tool box...they don't cost much. All day long the wind had the sock out straight, but it was down the runway. By the time I was at the pumps, the winds had changed, and there wa s over a half sock full of direct crosswind, but I've been there before. Mag drop showed less than 50 rpm. Everything looked good, and felt good. Take off from the hard surface so I had time to see if the ASI was working, but spent the rest of the time on the grass runway. I did several slips to landings, a couple of fly by's, then went off for a full power level flight, followed by a couple of power off stalls. With the insulated exhaust pipes, the EGT was v ery noticeably higher, and the Smoke was Thicker !! Sure is great to be flying again !! Chuck G. NX770CG ************************************** See what's free at http://www.aol.com . ________________________________________________________________________________
Subject: GN-1 Roll Call
Date: Apr 23, 2007
My partner, Tom Schildt, and I have been working on our GN-1, purchased from South Lakeland Sport Aviation in Florida about 5 years ago. Included in the purchase were the wings & tail feathers (uncovered), 4130 steel fuselage, and landing gear. Also purchased separately a C-85 engine. Our shop is north of Abbeville, Louisiana. Have met with Corky in Shreveport and his wonderful wife, Isabelle several times. They are a true inspiration. Look forward to meeting Wayne Poole in Denham Springs, Louisiana, who I see from the list is also building a GN-1, and any other nearby builders. Jim Cooper blugoos1(at)hughes.net ________________________________________________________________________________
Subject: front cockpit shoulder harness attach
Date: Apr 23, 2007
OK, I took a few pictures of my shoulder harness attach setup and put them on a webpage, at http://www.flysquirrel.net/piets/harness.html Once again, note that this idea is not original with me... I took it from an idea that was in the BPA Newsletter. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ MSN is giving away a trip to Vegas to see Elton John. Enter to win today. http://msnconcertcontest.com?icid-nceltontagline ________________________________________________________________________________
Date: Apr 23, 2007
Subject: Re: front cockpit shoulder harness attach
Oscar, Elegant solution. Really nifty. BTW, if that notch in the top of the ash block is the rear sight, is the "brazing rod fuel gauge" the front sight? ;) Tim in central TX -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: Apr 23, 2007 9:48 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: front cockpit shoulder harness attach > > >OK, I took a few pictures of my shoulder harness attach setup and put them >on a webpage, at >http://www.flysquirrel.net/piets/harness.html > >Once again, note that this idea is not original with me... I took it from an >idea that was in the BPA Newsletter. > >Oscar Zuniga >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > >_________________________________________________________________ >MSN is giving away a trip to Vegas to see Elton John. Enter to win today. >http://msnconcertcontest.com?icid-nceltontagline > > ________________________________________________________________________________
Subject: moving to San Antonio
Date: Apr 23, 2007
Steve wrote- >It looks like I will be moving to the west side of San Antonio Welcome to the neighborhood! Come by and see me some Saturday... last hangar (I think it's the beige one), next to last hangar facing south. If the door is open, stop by. If you can fit in the Piet, we'll go up! >Castroville, San Geronimo and Boerne stage Airports. >Do you have any opinions on these three? I am based at San Geronimo and it's where the EAA Chapter 35 hangar and clubhouse are located. Lots of building activity on the field and hangars are occasionally available, or you can sub-rent or share one. Lots of builder support and lots of friendly folks. The Chapter has a large assortment of tools and services available for builders. There is no fuel on the field and no runway lighting. Castroville is where most pilots out of San Geronimo get fuel and it, too, is very flying friendly but I don't have any details about what's available there. It is 10-15 minutes away from San Geronimo by Pietenpol, depending on headwind ;o) Boerne Stage is a nifty place, lots of sailplane activity, but I don't have much info on that one either. >I own a 1948 Bonanza People routinely fly Bo's and Mooneys out of San Geronimo, along with just about everything else. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Download Messenger. Join the im Initiative. Help make a difference today. http://im.live.com/messenger/im/home/?source=TAGHM_APR07 ________________________________________________________________________________
Date: Apr 23, 2007
Subject: Garmin 196 on eBay
I just listed my pristine Garmin 196 on eBay. I used it in my Cessna but upgraded to a 296 a couple of months ago. My 196 is available for inspection at Bruce Field in Central Texas (E30, San Antonio Sectional) should anyone like a preview. Ebay auction #260110714726. It comes with a 64 megabyte card and the original boxes and manuals. Thanks, Sterling Knot-2-Shabby Airport 5TA6, San Antonio Sectional __________________________________________________ ________________________________________________________________________________
Date: Apr 23, 2007
I mean no offence Oscar, but does anyone else see problems with this setup? I would be worried that in the even to sudden deceleration (crash) the wing along with the cross wires the harness is attached to would go forward. Correct me if I am wrong here Oscar, but I believe this is what happened to 41CC when it crashed. These pictures Oscar took show it what I am talking about. Alternatively, they might have failed due to compression when the plane flipped over. http://www.flysquirrel.net/piets/incident/PB130005.JPG http://www.flysquirrel.net/piets/incident/PB130010.JPG To avoid this the front diagonal down tubes (not on the drawings) would need to be large diameter and the connection between these and the front wing supports would have to be very strong. In Oscars case the front connection on the right brace broke at the Heim joint. The other problem I see is cable stretch. There isn't a lot of room between your face and the instrument panel. If the cables stretch the harness isn't going to help much. Nothing wrong with using cables but the pull needs to be aligned with the cable not 90 degrees to it. Only the tension in the cable will resist the forward pull from the harness and I doubt anyone will put in enough tension into the cross braces to make them not flex. Adding a shoulder harness to the front cockpit is very difficult. I sure wish I had a suggestion or a solution better but nothing I can come up with is ideal. I haven't decided how I am going to do mine yet but I think anything we try is better then nothing. Good for Oscar to at least try something. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Monday, April 23, 2007 6:48 AM Subject: Pietenpol-List: front cockpit shoulder harness attach > > > OK, I took a few pictures of my shoulder harness attach setup and put them > on a webpage, at > http://www.flysquirrel.net/piets/harness.html > > Once again, note that this idea is not original with me... I took it from > an idea that was in the BPA Newsletter. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > MSN is giving away a trip to Vegas to see Elton John. Enter to win today. > http://msnconcertcontest.com?icid-nceltontagline > > > ________________________________________________________________________________
Date: Apr 24, 2007
Hey Santiago Attached a couple pictures of the ply wedges I added to mine to get two parallel surfaces for the two bolts. Rick On 4/20/07, santiago morete wrote: > > I have seen in the archives a question about the attachment of the > horizontal stab to the fuselage (from Rick Holland) that intererst me, an d > since it doesn't have an answer I will post it again. > The two bottom fittings are attached to each other with two > horizontal bolts through the fuselage tailpost, however the fuselage > sides are angled. Did you guys makes 4 wedged shaped washers out of > something so the bolt head and nut seat flat or add 2 wood wedges for > the fittings to sit on? > I will use bolts, no rivets. > Another question, I have seen Piets with the horizontal stab bolted at th e > leading edge, main spar or both. I plan to bolt it trough the main beam. > What would be recommendable? Thanks > Saludos > > Santiago > > ------------------------------ > *Pregunt=E1. Respond=E9. Descubr=ED.* > Todo lo que quer=EDas saber, y lo que ni imaginabas, > est=E1 en *Yahoo! Respuestas* (Beta). > > * > =========== =========== =========== > > * > > -- Rick Holland "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 24, 2007
Subject: Re: GN-1 Roll Call
Jim, I am not near buy, but feel we "GN-1 builders" need to hang together. I have come to the conclusion that there are those "purist" out there, (not all) who don't see "the advance variation" of the "father and fore runner" of home built aircraft as "true". Still, GN-1 builders have needs, interests and a willingness and desire to build a good safe project. Anyway, i am 80% done and as the ole saying goes, 80% to go. Still, my wood frame fuselage is pretty well done, the Corvair needs to be built and my wing are done. everything needs to be covered. mine sets on a cub type gear, with brakes and tail wheel. Where are you, with your project? Gene -----Original Message----- >From: Jim Cooper <blugoos1(at)hughes.net> >Sent: Apr 23, 2007 8:27 AM >To: Pietenpol-List Digest Server >Subject: Pietenpol-List: GN-1 Roll Call > >My partner, Tom Schildt, and I have been working on our GN-1, purchased from South Lakeland Sport Aviation in Florida about 5 years ago. Included in the purchase were the wings & tail feathers (uncovered), 4130 steel fuselage, and landing gear. Also purchased separately a C-85 engine. Our shop is north of Abbeville, Louisiana. Have met with Corky in Shreveport and his wonderful wife, Isabelle several times. They are a true inspiration. Look forward to meeting Wayne Poole in Denham Springs, Louisiana, who I see from the list is also building a GN-1, and any other nearby builders. > > >Jim Cooper >blugoos1(at)hughes.net ________________________________________________________________________________
Date: Apr 24, 2007
All of the points that Chris raises are valid. My feeling was that the new setup is an improvement over what was there before, not that it was an ideal solution. I will note, however, than in the nose-over the rear cabanes remained intact and it is the X-braces for those cabanes that the attach point is anchored to. The cables are 1/8" and are tensioned pretty well, but if something bends or buckles they could go slack, yes. The best solution that I've seen is the wishbone-style welded tube fitting that the UK Pietenpolers pioneered. It installs inside the boot cowl that encloses the flight instruments and is a really sturdy piece of work. One example is G-BYZY, one photo example is http://www.pietenpolclub.co.uk/gallery/displayimage.php?album=31&pos=6 Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Exercise your brain! Try Flexicon. http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07 ________________________________________________________________________________
Date: Apr 24, 2007
Gene, Thanks for your good input. Oscar has answered your questions about damage in the hard landing, indicating that his "imoroved BPA shoulder harness assembly" would likely have worked quite well in his hard landing. (We all agree some things might well have been stretched.) He has also provided the pix of an alternative, the more robust UK shoulder harness attachments. But you have raised a question about the survivability of the cabanes and the front cabane-to-firewall connection. I'd like to add to that. Oscar's plane had a hard landing, but William Wynne's had a crash landing (steeply from 70 feet up), and the Heim connectors or whatever he had, designed to resist PULL in flight, would not and could not resist COMPRESSION in a crash. Wynne has suggested building the assembly with tubing and stout connections to prevent BOTH push and pull. This is more important, as he has pointed out, when the gas tank is in the wing, as things can move, leak, and flame, as they did to him. As you may know, he had several surgeries as a result of burns. Ideally we might go with something more adustable and less permanent-- Heim and lighter tubing-- to TEST the final location of the wing for CG purposes, and then install a more permanent and stouter final assembly. Both this tubing forward and the tubing of the two shoulder harnesses' attachments add weight that BP did not have. Of course, as others have pointed out, we are supposed to make the planes both light and strong enough to fly well, not strong and heavy enough to crash well. To me, though, these few pounds seem like good ones. These are the last safety measures you have in a crash. I might have enough appropriate tubing on hand to estimate the total weight. Maybe someone else already knows. In any event, I'd like to hear both data and opinions of more established Piet builders/fliers. Thanks already to you and Oscar for this discussion. Regards, Tim in central TX -----Original Message----- >From: Catdesigns <catdesigns(at)comcast.net> >Sent: Apr 23, 2007 9:37 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: front cockpit shoulder harness attach > > >I mean no offence Oscar, but does anyone else see problems with this setup? >I would be worried that in the even to sudden deceleration (crash) the wing >along with the cross wires the harness is attached to would go forward. >Correct me if I am wrong here Oscar, but I believe this is what happened to >41CC when it crashed. These pictures Oscar took show it what I am talking >about. Alternatively, they might have failed due to compression when the >plane flipped over. > >http://www.flysquirrel.net/piets/incident/PB130005.JPG > >http://www.flysquirrel.net/piets/incident/PB130010.JPG > >To avoid this the front diagonal down tubes (not on the drawings) would need >to be large diameter and the connection between these and the front wing >supports would have to be very strong. In Oscars case the front connection >on the right brace broke at the Heim joint. ><<<< MORE TEXT FOLLOWED IN ORIGINAL>>> ________________________________________________________________________________
Subject: wire wheels
Date: Apr 24, 2007
I know there has been a lot of discussion in the past about where to purchase parts for wire wheels and such. I am just wondering what is an average cost per wheel ready to roll if you went the route of buying motorcycle rims, making a hub, buying spokes, buying tubes and tires, etc... I am leaning towards getting the kit from here... http://www.airdromeaeroplanes.com/Default.asp?page=76 and am just wondering if their price tag is in the ball park. ($495.00 for both) Thanks! Dan Loegering Fargo, ND ________________________________________________________________________________
Date: Apr 24, 2007
Subject: Re: wire wheels
Invoices for tires/tubes/rims/spokes/etc Those invoices are for 2 sets, (enough for 2 projects) so divide all the costs by 1/2: http://mykitplane.com/Planes/filesList2.cfm?AlbumID=67 on mykitplane.com...in the files section. jm -----Original Message----- >From: Dan Loegering <danl(at)odayequipment.com> >Sent: Apr 24, 2007 4:39 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: wire wheels > > >I know there has been a lot of discussion in the past about where to purchase parts for wire wheels and such. I am just wondering what is an average cost per wheel ready to roll if you went the route of buying motorcycle rims, making a hub, buying spokes, buying tubes and tires, etc... > >I am leaning towards getting the kit from here... http://www.airdromeaeroplanes.com/Default.asp?page=76 and am just wondering if their price tag is in the ball park. ($495.00 for both) > >Thanks! > >Dan Loegering >Fargo, ND > > ________________________________________________________________________________
Date: Apr 24, 2007
Another question might be what is the weight difference? The Airdromeaeroplanes.com kit is 36 pounds for two complete wheels with tires and tubes. What do some of the other complete wire wheels weigh? Dan Loegering wrote: I know there has been a lot of discussion in the past about where to purchase parts for wire wheels and such. I am just wondering what is an average cost per wheel ready to roll if you went the route of buying motorcycle rims, making a hub, buying spokes, buying tubes and tires, etc... I am leaning towards getting the kit from here... http://www.airdromeaeroplanes.com/Default.asp?page=76 and am just wondering if their price tag is in the ball park. ($495.00 for both) Thanks! Dan Loegering Fargo, ND --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 24, 2007
Dan, I recently finished my wheels. Here is my information on them. 2.50" wide x 19" Drop Center Chrome Rim, 40 hole $65 each Chrome Spokes $40 per set 4130 Tubing for Hubs 2" o.d. x 0.120" wall $7 per foot 4130 Flat Steel for flanges 0.090" x 9"x9" $5 Oil Impregnated Bearings $20 Total for two wheels ~ $225 Tires, tubes and rim bands $45 each Paint for hubs $05 Total cost of completed wheels w/ tires (for both) ~ $320 disclaimer: These have not flown (or landed) yet. I also considered the Aerodrome wheels. When I inquired, I learned that the hubs were made for a slightly smaller diameter axle, and an 18" internal sleeve is inserted inside each axle end to increase the strength or stiffness. I am not questioning the design, only sharing information in the event you already have the axle. I made the phone call and they were very kind. I simply chose to fabricate my own. john in Wisconsin Dan Loegering wrote: I know there has been a lot of discussion in the past about where to purchase parts for wire wheels and such. I am just wondering what is an average cost per wheel ready to roll if you went the route of buying motorcycle rims, making a hub, buying spokes, buying tubes and tires, etc... I am leaning towards getting the kit from here... http://www.airdromeaeroplanes.com/Default.asp?page=76 and am just wondering if their price tag is in the ball park. ($495.00 for both) Thanks! Dan Loegering Fargo, ND --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Sun N Fun pictures
Date: Apr 24, 2007
Just got back from Sun N Fun and wanted to share some pics. The only Piet i saw was the one in the museum. http://sportplanes.tv/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=109108#109108 ________________________________________________________________________________
Date: Apr 25, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
Dan, I think that price is pretty reasonable. I believe I paid about that much for my hubs alone. I think the rims were close to $100, and having them laced with custom spokes by Buchanons was another $100 or so. I don't have the exact figures at hand, but they weren't cheap. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Loegering Sent: Tuesday, April 24, 2007 5:40 PM Subject: Pietenpol-List: wire wheels --> I know there has been a lot of discussion in the past about where to purchase parts for wire wheels and such. I am just wondering what is an average cost per wheel ready to roll if you went the route of buying motorcycle rims, making a hub, buying spokes, buying tubes and tires, etc... I am leaning towards getting the kit from here... http://www.airdromeaeroplanes.com/Default.asp?page=76 and am just wondering if their price tag is in the ball park. ($495.00 for both) Thanks! Dan Loegering Fargo, ND _________________________________________________ ________________________________________________________________________________
Date: Apr 25, 2007
Subject: Trying to reply to DOUWE about my Garmin 196 (sorry list)
Piet List: SORRY FOR THIS E-MAIL, BUT DOUWE SENT ME A REQUEST ABOUT MY GARMMIN 196 ON EBAY AND MY REPLAY CAN'T GET THROUGH HIS CONTROLS ON EARTHLINK. PLEASE DISREGARD... Hey Douwe: No Problema, as we say here in Texas. My Garmin is pristine, works great and you'll love it. I though I had died and gone to heaven when I first took it out of the box and outside. My dad about fell oever backwards, He retired flying corporate jets all over the world and despite having inertial nav in a G-ll that he flew, he wished he would have had one of these back in the "olden days." Sorry to be such a hard-nose on Ebay, but my account was hijacked a couple of years ago and I no longer trust Nigerians, Russians, Ethipoians... the list of crooks goes on and on. PS... take a look at this link... It is a first flight in an airplane I built and flew (On YouTube) http://www.youtube.com/watch?v=HWJUdhAmfvQ. Now, I have to decide if I am going to finish my Aircamper or sell that too... Decisions, decisions. Sterling Brooks Knot-2-Shabby Airport __________________________________________________ ________________________________________________________________________________
Subject: Airdrome wire wheels
Date: Apr 25, 2007
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
http://www.eaa1279.org/Pietenpol.htm Dan--- go see EAA Chapter 1279's web site as they purchased the wire wheel kit from Airdrome Airplanes and were quite pleased. I don't see how you can go wrong at that price--- making my own hubs and ordering everything thru a local motorcycle shop here in Cleveland I spent $600 on my pair of 19" wheels (but I have aluminum rims not steel) and that was back in 1993. Mike C. >>http://www.airdromeaeroplanes.com/Default.asp?page=76 <http://www.airdromeaeroplanes.com/Default.asp?page=76> and am just >>wondering if their price tag is in the ball park. ($495.00 for both) ________________________________________________________________________________
Date: Apr 25, 2007
Subject: Re: Airdrome wire wheels
Do you know the weight difference between the aluminum and steel rims? What did your complete wheels end up weighing? "Cuy, Michael D. (GRC-RXD0)[ASRC]" wrote: http://www.eaa1279.org/Pietenpol.htm Dan--- go see EAA Chapter 1279's web site as they purchased the wire wheel kit from Airdrome Airplanes and were quite pleased. I don't see how you can go wrong at that price--- making my own hubs and ordering everything thru a local motorcycle shop here in Cleveland I spent $600 on my pair of 19" wheels (but I have aluminum rims not steel) and that was back in 1993. Mike C. >>http://www.airdromeaeroplanes.com/Default.asp?page=76 and am just >>wondering if their price tag is in the ball park. ($495.00 for both) --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: wheel weights
Date: Apr 25, 2007
Michael, Aluminum is roughly 1/3 the weight of steel so whatever steel rims weigh mine weigh about 66% less. Say that two steel rims are 5 pounds each (just as an example....I have no clue what some of them actually weigh) then you have 10 pounds of steel rims vs. 3.33 pounds of alum. rims. Mike C. PS--- disclaimer: I don't know what alloy my aluminum rims are....there may be other alloys in there like magnesium but I have nada clue so your rim density may vary:) ________________________________________________________________________________
Subject: Re: wheel weights
Date: Apr 25, 2007
Well that may be true-but I would expect they use thicker aluminum than the steel to gain the same strength and I'd really be surrised if there is that much difference.it would sure depend on if both wheels were designed for the same load,Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=109257#109257 ________________________________________________________________________________
Date: Apr 25, 2007
Subject: Wheel weights
Guys, I just went out to the hangar and weighed one of my wire wheels (alum), complete with band-type brake drum. 20 lbs. This includes the bearings, tires and everything. I'm not sure what the drum weighs separately. Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 25, 2007
Yes but it isn't as strong so those rims would have to be thicker for adequate strength. They will be lighter but not by that much. The majority of the weight is in the tire anyway. Aluminum block engines, for instance, are not necessarily lighter than iron and in a few cases are actually heavier. Clif Michael, Aluminum is roughly 1/3 the weight of steel so whatever steel rims weigh mine weigh about 66% less. Say that two steel rims are 5 pounds each (just as an example....I have no clue what some of them actually weigh) then you have 10 pounds of steel rims vs. 3.33 pounds of alum. rims. Mike C. ________________________________________________________________________________
Date: Apr 25, 2007
Purchased my wheel building supplies in October . I'll give you the cost per wheel. Buchannon's 1 21" x 1.85 Sun Aluminum rims ----- $179 1-set Rim Pins (to help stop tire rotation)---- $6 40 9ga stainless steel spokes ---- $51.60 40 9ga .281x.900 Stainless steel nipple----- $41.60 Shipping----- $8 (remember this is only half the cost) If your building them your self you will need a spoke wrench--- $19 I had Buchanan's loose lace one so I knew the spokes would fit---- $22 I built and trued the wheels my self.---- $0 Wheel hub with brake spacer from Ken Perkins----- $95 (includes shipping) Had to have the bushings reamed because the ones Mr. Perkins supplies are for ground axels and my axel is a non-ground 4130 tube --- $20 (strait axel gear) JC Whitney Tire--- $27 Inner tube 80/100x21--- $8 Rim Strip--- $2 (actually $4 because JC Whitney charged me for them but didn't send them. So I called and told them they were not in the shipment. They sent me new ones and charged me for the new ones too. At his point I was to depressed to care about $4) Now for the weight (as weighed on my bathroom scale, so its +/- 1/2 pound) No brakes Rim--- 6 lb wheel hub--- 2 lb 40 SS Spokes --- 2 lb 40 SS Nipples --- 1 lb Tube --- 1 lb Tire--- 6 lb Total weight is about 18 pounds. Did I forget anything? Now for the true cost Including the cost above trying to get wheels on my plane also cost: $100 Very early on in my building I bought a set of wire wheels that turned out to be to narrow and not up to the quality I would use on a plane. $200 for motorcycle wheels from a junk yard oops salvage yard. What's the difference between junk yard and salvage yard? Salvage yards charge more for the same old junk. One rim turned out to have a cracked rim and I never figured out how to get them to work with the strait axel. Also, no one who used them with the strain axel replied to my emails asking for help. So I didn't use them. Total cost? You do the math I don't want to know. I makes me too depressed. This has been one of the most frustrating and depressing experiences of building this plane. What's worse, is after I spent all this money and I had built the wheels, I discovered the spoke flanges have bent in. As of now, I have taken the wheels apart, removed powder coat and bent the flanges back strait(ish). I will then weld the outside joint where the spoke flange attaches to the 2-inch tube, that was NOT welded by Mr. Perkins, and rebuild them. On the bright side I'll be good at building wheels. I'm so sick and tired of this type of thing happening that I find it difficult to work on the plane and be happy right now. As you can tell I'm in a deep funk about this. So the cost of the wheels also includes the wasted time building, unbuilding and the weeks (months) it will take to get over the utter frustration of the whole experience and return to building. For now I'm going to go watch lots of TV instead of building. That should drive me crazy and get me back out there soon I hope. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: "Dan Loegering" <danl(at)odayequipment.com> Sent: Tuesday, April 24, 2007 2:39 PM Subject: Pietenpol-List: wire wheels > > > I know there has been a lot of discussion in the past about where to > purchase parts for wire wheels and such. I am just wondering what is an > average cost per wheel ready to roll if you went the route of buying > motorcycle rims, making a hub, buying spokes, buying tubes and tires, > etc... > > I am leaning towards getting the kit from here... > http://www.airdromeaeroplanes.com/Default.asp?page=76 and am just > wondering if their price tag is in the ball park. ($495.00 for both) > > Thanks! > > Dan Loegering > Fargo, ND > > > ________________________________________________________________________________
Date: Apr 26, 2007
Chris, What are "rim pins" and how do they work? Of course I am sure I won't need them, as all my landings will be like a bird's feather dropping to the ground. :) Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 26, 2007
Subject: Max Davis
Max. Would youi please contact me direct. I have a problem. Many problems but you can help solve one of them Corky Isablcorky(at)aol.com ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 26, 2007
I was checking out the wheel kits on the Airdrome Aeroplanes website. They look really good. Since they do not list any specifications, it's kind of hard to tell exactly what they are offering. Don't know what size axel they are made to fit. From the photos it looks like the hubs are 6" wide, and the overall diameter of the tires is 25" (maybe 19" rims?), which sounds good for a Pietenpol. Do any of you guys have any more detailed specifications? Regarding pricing, the website says "Two welded hubs sell for $195 per pair" and "Wheel kits ready to be laced with 2 tires, 2 tubes and 2 bearing sets sell for $495. This also includes a step-by-step detailed video." I assume that they also include the rims, spokes, etc. Does anyone know if the wheel kits include the hubs, or do you have to buy both (which would make the price actually $690 a pair). If the wheel kits include the hubs, would they sell the kit minus the hubs ($300?) Bill C. ________________________________________________________________________________
Date: Apr 26, 2007
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Bill, Enjoyed your post....regardless of Axel size.....their wheels are utilized on a good many of their planes which are much heavier than the pietenpol. To me the overall set and cost make them very competitive and I am tending to lean their way.....As for axel size....I am sure their axel size has been tested and I'll bet it is very close to what we are useing. Ken Bill Church wrote: I was checking out the wheel kits on the Airdrome Aeroplanes website. They look really good. Since they do not list any specifications, it's kind of hard to tell exactly what they are offering. Don't know what size axel they are made to fit. From the photos it looks like the hubs are 6" wide, and the overall diameter of the tires is 25" (maybe 19" rims?), which sounds good for a Pietenpol. Do any of you guys have any more detailed specifications? Regarding pricing, the website says "Two welded hubs sell for $195 per pair" and "Wheel kits ready to be laced with 2 tires, 2 tubes and 2 bearing sets sell for $495. This also includes a step-by-step detailed video." I assume that they also include the rims, spokes, etc. Does anyone know if the wheel kits include the hubs, or do you have to buy both (which would make the price actually $690 a pair). If the wheel kits include the hubs, would they sell the kit minus the hubs ($300?) Bill C. --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 26, 2007
Rim pins are pins that project into the bead of the tire to hold it to prevent rotation of the tire and tube. If this happen it will shear off the valve stem and your tire will go flat. See attached picture. Chris, What are "rim pins" and how do they work? Of course I am sure I won't need them, as all my landings will be like a bird's feather dropping to the ground. :) ________________________________________________________________________________
Date: Apr 27, 2007
Subject: Wing Strut Forks
Hello group, I would like to learn more about "Wing Strut Forks". I have searched the archives and have not found this specific information. I plan to use the Sky-Tek Aluminum struts with an aluminum insert at the lower strut end, and a "fork end". I find three fork end options in Aircraft Spruce. Would people like to share thier knowledge to determine which fork may be best suited for this appliation (lower wing strut ends)? 1. Wing Strut fork #13370-00 p/n05-06000 $82 7/16-20 thread 2. Wing Strut fork #14481-00 p/n05-08575 $86 7/16-20 thread 3. Aeronca Wing Strut fork p/n 05-08575 $60 4. Others? Is there a standard gap width of the fork, so we know it'll fit nicely over the flat tab fitting at the fuselage? Thank you for any information. john --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: RE: wire wheels
Date: Apr 27, 2007
I have posted some of the questions to Robert on the wheels, but here was a preliminary response to some questions that I had on them... I'll let the group know what the reply is on the remaining questions. Dan L Fargo, ND Dan Our wheel shouldn't have any problems at that wt. our hub has 1.25" ID oil lite bushings with a 7.25" wide hub it's also drilled to attach a break if required. Robert -----Original Message----- >From: Dan Loegering <danl(at)odayequipment.com> >Sent: Apr 2, 2007 1:46 PM >To: rbaslee(at)peoplepc.com >Subject: Wheel kits > >Hello, > >I ran across your web site while searching for wheels for my project. They look like they would fit the bill nicely, but wanted to run it by you to get your thoughts before purchasing them. > >I am building a Pietenpol air camper with straight axle gear (Jenny style). Gross weight with two aboard should be around 1,150 - 1,200 lbs. Will the wheels you have be okay in that weight range? What axle dia. fits with the bearings you supply? Are any of your builders using breaks with their setups? > >Thank you for the info! > >Dan Loegering >O'Day Equipment, LLC >(701)282-9260 >800-654-6329 ________________________________________________________________________________
Date: Apr 27, 2007
Some pics;not sure if this is what you want. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Egan Sent: April 27, 2007 8:25 AM Subject: Pietenpol-List: Wing Strut Forks Hello group, I would like to learn more about "Wing Strut Forks". I have searched the archives and have not found this specific information. I plan to use the Sky-Tek Aluminum struts with an aluminum insert at the lower strut end, and a "fork end". I find three fork end options in Aircraft Spruce. Would people like to share thier knowledge to determine which fork may be best suited for this appliation (lower wing strut ends)? 1. Wing Strut fork #13370-00 p/n05-06000 $82 7/16-20 thread 2. Wing Strut fork #14481-00 p/n05-08575 $86 7/16-20 thread 3. Aeronca Wing Strut fork p/n 05-08575 $60 4. Others? Is there a standard gap width of the fork, so we know it'll fit nicely over the flat tab fitting at the fuselage? Thank you for any information. john ________________________________ Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. <http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html; _ ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM - > ________________________________________________________________________________
Date: Apr 27, 2007
A few more pics ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Egan Sent: April 27, 2007 8:25 AM Subject: Pietenpol-List: Wing Strut Forks Hello group, I would like to learn more about "Wing Strut Forks". I have searched the archives and have not found this specific information. I plan to use the Sky-Tek Aluminum struts with an aluminum insert at the lower strut end, and a "fork end". I find three fork end options in Aircraft Spruce. Would people like to share thier knowledge to determine which fork may be best suited for this appliation (lower wing strut ends)? 1. Wing Strut fork #13370-00 p/n05-06000 $82 7/16-20 thread 2. Wing Strut fork #14481-00 p/n05-08575 $86 7/16-20 thread 3. Aeronca Wing Strut fork p/n 05-08575 $60 4. Others? Is there a standard gap width of the fork, so we know it'll fit nicely over the flat tab fitting at the fuselage? Thank you for any information. john ________________________________ Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. <http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html; _ ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM - > ________________________________________________________________________________
Date: Apr 27, 2007
A few more ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Egan Sent: April 27, 2007 8:25 AM Subject: Pietenpol-List: Wing Strut Forks Hello group, I would like to learn more about "Wing Strut Forks". I have searched the archives and have not found this specific information. I plan to use the Sky-Tek Aluminum struts with an aluminum insert at the lower strut end, and a "fork end". I find three fork end options in Aircraft Spruce. Would people like to share thier knowledge to determine which fork may be best suited for this appliation (lower wing strut ends)? 1. Wing Strut fork #13370-00 p/n05-06000 $82 7/16-20 thread 2. Wing Strut fork #14481-00 p/n05-08575 $86 7/16-20 thread 3. Aeronca Wing Strut fork p/n 05-08575 $60 4. Others? Is there a standard gap width of the fork, so we know it'll fit nicely over the flat tab fitting at the fuselage? Thank you for any information. john ________________________________ Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. <http://us.rd.yahoo.com/evt=48245/*http:/autos.yahoo.com/new_cars.html; _ ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM - > ________________________________________________________________________________
Subject: Re: Wing Strut Forks
Date: Apr 27, 2007
John, I used : 05-06000WING STRUT FORK # 13370-00 The fork is the right dimension for the sheet metal fitting at the fuselage. One comment: you mentioned aluminum inserts, I would not recommend aluminum as the Fork has a fine UNF thread. you can easily strip the threads, you need course thread forks (do not know where you can get those) for aluminum. You should use Steel inserts with this UNF thread. I did not use Aluminum Sky-Tek struts but opted for the traditional steel with the welded insert Hans -----Original Message----- From: johnegan99(at)yahoo.com Sent: Fri, 27 Apr 2007 7:24 AM Subject: Pietenpol-List: Wing Strut Forks Hello group, I would like to learn more about "Wing Strut Forks". I have searched the archives and have not found this specific information. I plan to use the Sky-Tek Aluminum struts with an aluminum insert at the lower strut end, and a "fork end". I find three fork end options in Aircraft Spruce. Would people like to share thier knowledge to determine which fork may be best suited for this appliation (lower wing strut ends)? 1. Wing Strut fork #13370-00 p/n05-06000 $82 7/16-20 thread 2. Wing Strut fork #14481-00 p/n05-08575 $86 7/16-20 thread 3. Aeronca Wing Strut fork p/n 05-08575 $60 4. Others? Is there a standard gap width of the fork, so we know it'll fit nicely over the flat tab fitting at the fuselage? Thank you for any information. john Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________ ________________________________________________________________________________
Date: Apr 27, 2007
Thanks all. Yes Hans, I meant "steel" insert in the "aluminum" strut, good catch. I believe I made my fuselage fitting out of 0.090" flat steel doubled up, but I'll have to measure to be sure. That's why I am looking for the fork gap dimension. Thank you guys. hvandervoo(at)aol.com wrote: John, I used : 05-06000 WING STRUT FORK # 13370-00 The fork is the right dimension for the sheet metal fitting at the fuselage. One comment: you mentioned aluminum inserts, I would not recommend aluminum as the Fork has a fine UNF thread. you can easily strip the threads, you need course thread forks (do not know where you can get those) for aluminum. You should use Steel inserts with this UNF thread. I did not use Aluminum Sky-Tek struts but opted for the traditional steel with the welded insert Hans -----Original Message----- From: johnegan99(at)yahoo.com Sent: Fri, 27 Apr 2007 7:24 AM Subject: Pietenpol-List: Wing Strut Forks .AOLPlainTextBody { margin: 0px; font-family: Tahoma, Verdana, Arial, Sans-Serif; font-size: 12px; color: #000; background-color: #fff; } .AOLPlainTextBody pre { font-size: 9pt; } .AOLInlineAttachment { margin: 10px; } .AOLAttachmentHeader { font: 11px arial; border: 1px solid #7DA8D4; background: #F9F9F9; } .AOLAttachmentHeader .Title { font: 11px arial; background: #B5DDFA; padding: 3px 3px 3px 3px; } .AOLAttachmentHeader .FieldLabel { font: 11px arial; color: #000000; padding: 1px 10px 1px 9px; background: #F9F9F9; } .AOLAttachmentHeader .FieldValue { font: 11px arial; color: #000000; background: #F9F9F9; } .AOLAttachmentHeader a, .AOLImage a { color: #2864B4; text-decoration: none; } .AOLAttachmentHeader a:hover, .AOLImage a:hover { color: #2864B4; text-decoration: underline; } .AOLWebSuiteCompose .AOLPicturesFullSizeLink, .AOLWebSuite .AOLPicturesFullSizeLink { height: 1px; width: 1px; overflow: hidden; } body { background-color: white; font-family: "Verdana"; font-size: 10pt; border: 0px; } .AOLWebSuiteCompose p { margin: 0px; padding: 0px; } img.managedImg { width: 0px; height: 0px; } img.placeholder { width: 275px; height: 206px; background: #F4F4F4 center center no-repeat; border: 1px solid #DADAD6 !important; } Hello group, I would like to learn more about "Wing Strut Forks". I have searched the archives and have not found this specific information. I plan to use the Sky-Tek Aluminum struts with an aluminum insert at the lower strut end, and a "fork end". I find three fork end options in Aircraft Spruce. Would people like to share thier knowledge to determine which fork may be best suited for this appliation (lower wing strut ends)? 1. Wing Strut fork #13370-00 p/n05-06000 $82 7/16-20 thread 2. Wing Strut fork #14481-00 p/n05-08575 $86 7/16-20 thread 3. Aeronca Wing Strut fork p/n 05-08575 $60 4. Others? Is there a standard gap width of the fork, so we know it'll fit nicely over the flat tab fitting at the fuselage? Thank you for any information. john --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. --------------------------------- --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 27, 2007
Subject: Strut forks.
Hi John: I bought 4 large turnbuckle forks from B & B aircraft for about 2 bucks each. I don't have them in front of me but I'm sure the shank is 3/8" They probably worked a control for a B-52 so ought to be strong enough for a Piet wing strut. Leon S. in Ks. ________________________________________________________________________________
Date: Apr 27, 2007
Subject: Re: Strut forks.
Leon, What is "B & B Aircraft"? Ron ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: Wing Strut ForksWing Strut Forks
Date: Apr 27, 2007
Some thoughts of wheels. I have a couple of 18 inch rear wheels off of old dirt bikes. The hubs are spaced at 4 inches. They originally had drum brakes but disks could be attached to the sprocket drive side. I paid $5 for one and $20 for the other. For tires I visited a motorcycle shop and went through the discarded tire pile. I found a couple or 3.25 X 18 high mileage but sound tire casings. (free because it costs the business to get rid of them) The main expense was taking the rims to the local blacksmith shop to have the centers reamed out and brass bearings inserted. ($70). The wheels weigh in at 22 lbs each with tire mounted, but no brakes. I will be flying off of private grass field so do not plan on having brakes. I am not done, but feel confident my wheels will not be one of the problems I'll face. Ralph ________________________________________________________________________________
Date: Apr 28, 2007
Subject: Re: Pietenpol Rip Off, Beware
These are not original plans. He is making photo copies and selling them as original plans. I had already purchased real Pietenpol plans from the Pietenpol family. I was buying his set of Piet and GN-1 drawings mainly for the GN-1. They are photocopies he ran off at Staples with no serial numbers. Gordon Bowen wrote: A lot of the old plans from the 30's to the 50's were just 10-15 sheets of crude drawings and no instruction/construction detailed manual. Paul P's Pixie plans are just a few pages of drawings. Don't think any of these actually cost $125 but who knows what they're worth today. Recently a unused serial numbered set of plans went up on ebay for Rutan's Longeze and they fetched $1500 bidding war, Burt's too big into other projects to support the homebuilt stuff anymore, but it's a heck of a set of complete plans and drawings, if you got the old newsletter updates. If you want good detailed drawing and instruction manual you gotta pay $500 for a Cozy etc. I paid $350 for a set of plans for Osprey couple years ago that were riddled with errors, designer still selling plans that he knows have errors and has not updated plans since early 70's. As far as plans go, it's hard to find them that you can actually build the plane from start to finish without errors and corrections, you gotta have lots and lots of help from local EAA guys or tech advisors. I'd recommend finding someone in EAA somewhere near you who's actually built a Piete like plane and go over them with him, find out what else you need to know before tossing together any parts, even if the plans were detailed. Gordon N-1033B SuperPiete (whatta great flying fun plane, Bernard would be proud of the mods) --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: Apr 28, 2007
Ryan, I have a set of the old 8 1/2 x 11size GN-1 drawings I bought from Mr. Grega for the large sum of $25. I will never build a GN-1 so you can have them. As long as your serious about building something. Feel free to email me off list. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Saturday, April 28, 2007 6:09 AM Subject: Re: Pietenpol-List: Pietenpol Rip Off, Beware These are not original plans. He is making photo copies and selling them as original plans. I had already purchased real Pietenpol plans from the Pietenpol family. I was buying his set of Piet and GN-1 drawings mainly for the GN-1. They are photocopies he ran off at Staples with no serial numbers. Gordon Bowen wrote: A lot of the old plans from the 30's to the 50's were just 10-15 sheets of crude drawings and no instruction/construction detailed manual. Paul P's Pixie plans are just a few pages of drawings. Don't think any of these actually cost $125 but who knows what they're worth today. Recently a unused serial numbered set of plans went up on ebay for Rutan's Longeze and they fetched $1500 bidding war, Burt's too big into other projects to support the homebuilt stuff anymore, but it's a heck of a set of complete plans and drawings, if you got the old newsletter updates. If you want good detailed drawing and instruction manual you gotta pay $500 for a Cozy etc. I paid $350 for a set of plans for Osprey couple years ago that were riddled with errors, designer still selling plans that he knows have errors and has not updated plans since early 70's. As far as plans go, it's hard to find them that you can actually build the plane from start to finish without errors and corrections, you gotta have lots and lots of help from local EAA guys or tech advisors. I'd recommend finding someone in EAA somewhere near you who's actually built a Piete like plane and go over them with him, find out what else you need to know before tossing together any parts, even if the plans were detailed. Gordon N-1033B SuperPiete (whatta great flying fun plane, Bernard would be proud of the mods) ------------------------------------------------------------------------- ----- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
From: "MICHAEL SILVIUS" <M.Silvius(at)worldnet.att.net>
Date: Apr 28, 2007
Ryan: Be aware that the original GN1 drawings are quite basic as well. They are about 19 pages of 11x17" size. it was not until just last year that new full size ones were printed with corrections. The originals were selling for 25 $ till about 2 yrs ago. The new full size ones sold for 75$ if I am not mistaken. Be aware that there is also a fellow on ebay that has a collection similar to what your seller there shows, but I do not know if it is the same clown. If you are diligent and keep an eye on ebay they do pop up occasionally. As for Long EZ plans they are in high demand as they are not available any longer from Rutan. They are a large package and quite comprehensive and detailed. They have often been cited as what plans should be like. I am fortunate in that I have a set of unused ones including the Roncz canard and new rudders in pristine condition (minus the engine install book, section 2) The valuable part in these is the full size templates for the bulkheads and airfoil all the rest of the detailing can be obtained via regular EZ community channels in the form of a CD. For the right amount I could be convinced to part with them as I do not think I'd ever build it at this point and it would be nice if someone actually did use them. I definitely would not want them going to a speculator who would intend to make copies from them. Michael ----- Original Message ----- From: Ryan Michalkiewicz These are not original plans. He is making photo copies and selling them as original plans. I had already purchased real Pietenpol plans from the Pietenpol family. I was buying his set of Piet and GN-1 drawings mainly for the GN-1. They are photocopies he ran off at Staples with no serial numbers. Gordon Bowen wrote: A lot of the old plans from the 30's to the 50's were just 10-15 sheets of crude drawings and no instruction/construction detailed manual. Paul P's Pixie plans are just a few pages of drawings. Don't think any of these actually cost $125 but who knows what they're worth today. Recently a unused serial numbered set of plans went up on ebay for Rutan's Longeze and they fetched $1500 bidding war, ________________________________________________________________________________
Date: Apr 28, 2007
From: "Wayne E. Bressler Jr." <wayne(at)taildraggersinc.com>
Subject: Fiesta Fly-In, Cinco de Mayo, at W66 -Warrenton, VA
/All, I'm sharing this with the group as an open invite for any EAA-types and sport aviation enthusiasts to stop in at W66 for some free grub and good times. There will be plenty of local aircraft on the field, and I will be there with my trusty camera to document all the planes and good times. The community at W66 is very open and warm. There aren't enough airports like this one with people like these! You won't be disappointed./* Fiesta Fly-In, Cinco de Mayo, at W66* That's May 5, 2007! To celebrate Mike Anderson and Chrissy Kirby taking over the FBO at W66, we'll have a free cookout for everyone on Saturday, May 5th, in front of the FBO. Food and fun start at noon. We'll feature the usual Bubba Burgers, sodas (pre-flight), beer (post-flight), chips and famous W66 camaraderie. Because it's Cinco de Mayo, there will also be some Mexican flare in the form of Margaritas (both virgin and otherwise), salsa, etc. Lastly, Mike and Chrissy need to sell some fuel. If you're able, please do them a favor and don't top off this weekend. Mike and Chrissy want plenty of air in those tanks when they come to fill them up on May 5. Mike and Chrissy are hoping for 1,000 gallons on Saturday the 5th. Let's make it happen! Please pass this along to pilots based at other airports who want to soak up the fun at W66. Also, feel free to bring kids and friends who want airplane rides. See you at the airport................ FMI and post-event photos visit: http://www.ganation.com/forum/showthread.php?t=7 -Wayne Bressler wayne(at)taildraggersinc.com www.ganation.com www.taildraggersinc.com* * ________________________________________________________________________________
Subject: Piet kids update
Date: Apr 28, 2007
I made it back from Sun n Fun the other night and have been getting upacked and re-organized. I opened the envelopes with donatioins that arrived while I was gone and added checks I received at SNF which in all totalled $210. That gives us a grand total of $615, 2 Piet videos and a brass data plate for them. This is a very nice thing we all have done for them and I know they appreciate it very much. Thank you Dick N. ________________________________________________________________________________
Subject: Fw: piet kids
Date: Apr 28, 2007
Date: Apr 28, 2007
Subject: B & B Aircraft
Ron: B&B Aircraft is located in Gardner Ks. (Kansas City) They didn't use to have a web sight, but may now. They always have a large tent at Osh. and S and F.. I don't have their number in front of me, but you should be able to get it from Information. AS&S sells the same forks for around $25 ea. and I will lay odds that they buy them from B & B. Leon S. ________________________________________________________________________________
Date: Apr 28, 2007
Michael, Re Rutan's Long plans, go to the canard pusher user group at yahoo and most a message you have some plans, you'd get a nice price out of them. I'm a member of that group and we have about 650 members of all flavors who have or are building canard aircraft. You're right, the Rutan Aircraft Factory is the gold standard for all build from scratch type plans. Nat Puffer's Cozy plans are almost word for word what Burt and Mike Melvil put together 10 years earlier. Still love the Piete's flying fun much better, ears flappin' in the wind and all. Gordon ----- Original Message ----- From: MICHAEL SILVIUS To: pietenpol-list(at)matronics.com Sent: Saturday, April 28, 2007 8:05 AM Subject: Re: Pietenpol-List: Pietenpol Rip Off, Beware Ryan: Be aware that the original GN1 drawings are quite basic as well. They are about 19 pages of 11x17" size. it was not until just last year that new full size ones were printed with corrections. The originals were selling for 25 $ till about 2 yrs ago. The new full size ones sold for 75$ if I am not mistaken. Be aware that there is also a fellow on ebay that has a collection similar to what your seller there shows, but I do not know if it is the same clown. If you are diligent and keep an eye on ebay they do pop up occasionally. As for Long EZ plans they are in high demand as they are not available any longer from Rutan. They are a large package and quite comprehensive and detailed. They have often been cited as what plans should be like. I am fortunate in that I have a set of unused ones including the Roncz canard and new rudders in pristine condition (minus the engine install book, section 2) The valuable part in these is the full size templates for the bulkheads and airfoil all the rest of the detailing can be obtained via regular EZ community channels in the form of a CD. For the right amount I could be convinced to part with them as I do not think I'd ever build it at this point and it would be nice if someone actually did use them. I definitely would not want them going to a speculator who would intend to make copies from them. Michael ----- Original Message ----- From: Ryan Michalkiewicz These are not original plans. He is making photo copies and selling them as original plans. I had already purchased real Pietenpol plans from the Pietenpol family. I was buying his set of Piet and GN-1 drawings mainly for the GN-1. They are photocopies he ran off at Staples with no serial numbers. Gordon Bowen wrote: A lot of the old plans from the 30's to the 50's were just 10-15 sheets of crude drawings and no instruction/construction detailed manual. Paul P's Pixie plans are just a few pages of drawings. Don't think any of these actually cost $125 but who knows what they're worth today. Recently a unused serial numbered set of plans went up on ebay for Rutan's Longeze and they fetched $1500 bidding war, ________________________________________________________________________________
Date: Apr 28, 2007
Subject: Re: B & B Aircraft-- Some info
I just found this online. Sounds good. "B&B Aircraft Supplies - This is a mom and pop shop with a whole warehouse full of new aircraft parts. Super nice people and great prices. Check here before you go elsewhere. No website, so... call or fax your order. Phone - 913-884-5930. Fax 913-84-6533. " Tim in central TX -----Original Message----- >From: Leon Stefan <lshutks(at)webtv.net> >Sent: Apr 28, 2007 5:16 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: B & B Aircraft > > >Ron: B&B Aircraft is located in Gardner Ks. (Kansas City) They didn't >use to have a web sight, but may now. They always have a large tent at >Osh. and S and F.. I don't have their number in front of me, but you >should be able to get it from Information. AS&S sells the same forks for >around $25 ea. and I will lay odds that they buy them from B & B. Leon S. > > ________________________________________________________________________________
Date: Apr 28, 2007
In a message dated 4/28/2007 7:17:59 P.M. Eastern Daylight Time, lshutks(at)webtv.net writes: Ron: B&B Aircraft is located in Gardner Ks. (Kansas City) They didn't use to have a web sight, but may now. They always have a large tent at Osh. and S and F.. I don't have their number in front of me, but you should be able to get it from Information. AS&S sells the same forks for around $25 ea. and I will lay odds that they buy them from B & B. Leon S. Thank you Leon and Tim for the info. Ron Do Not Archive ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 29, 2007
Subject: Plans
If you wnat some well drawn scratch build tube & rag plans, try one of Ed Fisher's designs. I anyone wants to build a Zippy Sport, I have a set of those. Larry the micro Mong guy -- ________________________________________________________________________________
Date: Apr 29, 2007
Here is the one I have information on : B & C Specialty Products Inc 123 East 4th PO Box B Newton, KS 67114 US 316-283-8000 Fax: 316-283-7400 _sales(at)bandcspecialty.com_ (mailto:sales(at)bandcspecialty.com) ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: airplane plans & carb ice
Date: Apr 29, 2007
Seeing the various posts here about the Piet, EZ, and GN plans, I guess my take is a little different from some. I buy or acquire plans for the sheer enjoyment of reading and studying them and I have maybe a dozen or more different sets of plans. I learn from each and every detail, every view, every section, every parts list. I don't expect them to be perfect and I don't expect them to be complete. I feel that I have enough interest and support to build one of whatever the plans are describing if I understand the designer's intent and spend enough time studying, examining, and dry-fitting things together. And it's what I most enjoy about scratch-building. I don't want a kit. What I don't appreciate are plans that are put out by theoreticians and marketed as "real". If I know that the designer actually built what he drew up, that's good enough for me- I can fill in the blanks, smooth out the curves, and spot the "you can't get there from here" stuff. It might cost me a scrapped piece of wood or metal, or the wrong length AN bolt, but that's OK. I don't mind following in the footsteps of somebody who has already built the part (or assembly) that I'm trying to build or understand from his drawings. I'm just grateful that he left me a trail of bread crumbs to follow on the way to my own dreams, part-way up a trail with someone else's footsteps on it. I know I'm not a kit builder and I'm not a "connect the dots" builder. And I don't think there are too many of that type of folks on this list. We build for the enjoyment, the challenge, the reward of working out the fine points and finding a slightly better way to do things. We build on the strong foundations but put our own touches on the finish. Might as well pass along my hard luck story for today. I went out to the airport, pulled the cowlings off the airplane, and set the idle speed and mixture on the carb (one of those "I'll get around to it" tasks that I'd been putting off). Set it at 550 RPM, as per Gorden Bowen's and others' recommendations for summer operations on the A65. Replaced the cowlings, preflighted, taxied to the active, and ran up the engine. Perfect. Lined up on the numbers, throttle in, tail up, and about 100' down the runway she started to stumble. Back on the power, the engine RPM smoothed out, but I was concerned. Back-taxied to the numbers, set the brakes, and full power runup this time. Clean. Full RPM, nice drop on mags and carb heat, no hesitation, no stumble. Rolled it back out onto the numbers, power in, tail up, stumble! Power back and that cleaned up the roughness, but I decided it wasn't my day to fly. Taxied to the hangar and looked under the cowling. Frost on the carb body and manifold, and lots of condensation on the carb and manifold areas. Carb ice. I didn't have a lot of time to give it another shot and had other tasks to do so I did them and put the airplane away. Thirty-five minutes after shutting down the engine, there was still condensation on the carb. My Tech Counselor up in Oregon, a Piet flyer with a Franklin on his airplane, advised me to use carb heat while taxiing and anytime the throttle came back to less than 1500 RPM. I think I'll take his advice from now on. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Exercise your brain! Try Flexicon. http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07 ________________________________________________________________________________
Subject: Re: airplane plans & carb ice
Date: Apr 29, 2007
Wow, we almost lost Oscar. Glad it happened on the ground and safe. The last time I had a hack hack cough the damn plane was 200' in the air, still had 5000' of runway to slip it back on with idle power. I had put an electric (Facet) boost pump in the fuel line to help with fuel head pressure on takeoffs. Forgot the pump switch, and the little ball inside pump kinda got stuck so fuel couldn't completely free flow from tank to carb. Facet claims the pump is completely non-restrictive when switch is off. Took pump back out of system, never had another problem. Electric fuel pump booster is recommended on some midwing homebuilts like the Longeze or Cozy. Figured couldn't hurt Piete's system due to low tank but was surprised to learn this little pump can get stuck closed and has happened to other builders in canard group. Agree 100% with comments about scratch built plans, it's always good to expand idears. Got lots of good ideas just looking at others projects via EAA meets. Gordon ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Sunday, April 29, 2007 6:44 PM Subject: Pietenpol-List: airplane plans & carb ice > > > Seeing the various posts here about the Piet, EZ, and GN plans, I guess my > take is a little different from some. I buy or acquire plans for the > sheer enjoyment of reading and studying them and I have maybe a dozen or > more different sets of plans. I learn from each and every detail, every > view, every section, every parts list. I don't expect them to be perfect > and I don't expect them to be complete. I feel that I have enough > interest and support to build one of whatever the plans are describing if > I understand the designer's intent and spend enough time studying, > examining, and dry-fitting things together. And it's what I most enjoy > about scratch-building. I don't want a kit. > > What I don't appreciate are plans that are put out by theoreticians and > marketed as "real". If I know that the designer actually built what he > drew up, that's good enough for me- I can fill in the blanks, smooth out > the curves, and spot the "you can't get there from here" stuff. It might > cost me a scrapped piece of wood or metal, or the wrong length AN bolt, > but that's OK. I don't mind following in the footsteps of somebody who > has already built the part (or assembly) that I'm trying to build or > understand from his drawings. I'm just grateful that he left me a trail > of bread crumbs to follow on the way to my own dreams, part-way up a trail > with someone else's footsteps on it. > > I know I'm not a kit builder and I'm not a "connect the dots" builder. > And I don't think there are too many of that type of folks on this list. > We build for the enjoyment, the challenge, the reward of working out the > fine points and finding a slightly better way to do things. We build on > the strong foundations but put our own touches on the finish. > > Might as well pass along my hard luck story for today. I went out to the > airport, pulled the cowlings off the airplane, and set the idle speed and > mixture on the carb (one of those "I'll get around to it" tasks that I'd > been putting off). Set it at 550 RPM, as per Gorden Bowen's and others' > recommendations for summer operations on the A65. Replaced the cowlings, > preflighted, taxied to the active, and ran up the engine. Perfect. Lined > up on the numbers, throttle in, tail up, and about 100' down the runway > she started to stumble. Back on the power, the engine RPM smoothed out, > but I was concerned. > > Back-taxied to the numbers, set the brakes, and full power runup this > time. Clean. Full RPM, nice drop on mags and carb heat, no hesitation, > no stumble. Rolled it back out onto the numbers, power in, tail up, > stumble! Power back and that cleaned up the roughness, but I decided it > wasn't my day to fly. > > Taxied to the hangar and looked under the cowling. Frost on the carb body > and manifold, and lots of condensation on the carb and manifold areas. > Carb ice. I didn't have a lot of time to give it another shot and had > other tasks to do so I did them and put the airplane away. Thirty-five > minutes after shutting down the engine, there was still condensation on > the carb. > > My Tech Counselor up in Oregon, a Piet flyer with a Franklin on his > airplane, advised me to use carb heat while taxiing and anytime the > throttle came back to less than 1500 RPM. I think I'll take his advice > from now on. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > Exercise your brain! Try Flexicon. > http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07 > > > ________________________________________________________________________________
Date: Apr 30, 2007
Ahh Oscar - you've discovered the Dark Side of the A65. When I had a J-3 Cub, on more than one occasion when the humidity was high and the day was cool, I had the engine actaully quit while taxiing out for takeoff on a long taxiway. When you do your runup, leave the carb heat on for more time than just to see if you get an RPM drop. About 30 seconds should be long enough. Likewise, in flight when you are about to reduce power, pull the carb heat "on" a good 10 to 30 seconds before you actually pull the throttle back, so you've got plenty of heat to warm up the carburetor body before cutting the throttle. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Sunday, April 29, 2007 10:45 PM Subject: Pietenpol-List: airplane plans & carb ice --> Seeing the various posts here about the Piet, EZ, and GN plans, I guess my take is a little different from some. I buy or acquire plans for the sheer enjoyment of reading and studying them and I have maybe a dozen or more different sets of plans. I learn from each and every detail, every view, every section, every parts list. I don't expect them to be perfect and I don't expect them to be complete. I feel that I have enough interest and support to build one of whatever the plans are describing if I understand the designer's intent and spend enough time studying, examining, and dry-fitting things together. And it's what I most enjoy about scratch-building. I don't want a kit. What I don't appreciate are plans that are put out by theoreticians and marketed as "real". If I know that the designer actually built what he drew up, that's good enough for me- I can fill in the blanks, smooth out the curves, and spot the "you can't get there from here" stuff. It might cost me a scrapped piece of wood or metal, or the wrong length AN bolt, but that's OK. I don't mind following in the footsteps of somebody who has already built the part (or assembly) that I'm trying to build or understand from his drawings. I'm just grateful that he left me a trail of bread crumbs to follow on the way to my own dreams, part-way up a trail with someone else's footsteps on it. I know I'm not a kit builder and I'm not a "connect the dots" builder. And I don't think there are too many of that type of folks on this list. We build for the enjoyment, the challenge, the reward of working out the fine points and finding a slightly better way to do things. We build on the strong foundations but put our own touches on the finish. Might as well pass along my hard luck story for today. I went out to the airport, pulled the cowlings off the airplane, and set the idle speed and mixture on the carb (one of those "I'll get around to it" tasks that I'd been putting off). Set it at 550 RPM, as per Gorden Bowen's and others' recommendations for summer operations on the A65. Replaced the cowlings, preflighted, taxied to the active, and ran up the engine. Perfect. Lined up on the numbers, throttle in, tail up, and about 100' down the runway she started to stumble. Back on the power, the engine RPM smoothed out, but I was concerned. Back-taxied to the numbers, set the brakes, and full power runup this time. Clean. Full RPM, nice drop on mags and carb heat, no hesitation, no stumble. Rolled it back out onto the numbers, power in, tail up, stumble! Power back and that cleaned up the roughness, but I decided it wasn't my day to fly. Taxied to the hangar and looked under the cowling. Frost on the carb body and manifold, and lots of condensation on the carb and manifold areas. Carb ice. I didn't have a lot of time to give it another shot and had other tasks to do so I did them and put the airplane away. Thirty-five minutes after shutting down the engine, there was still condensation on the carb. My Tech Counselor up in Oregon, a Piet flyer with a Franklin on his airplane, advised me to use carb heat while taxiing and anytime the throttle came back to less than 1500 RPM. I think I'll take his advice from now on. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Exercise your brain! Try Flexicon. http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglin eapril07 _________________________________________________ ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: wheels
Date: Apr 30, 2007
Hey guys, My plans for being able to use a grass strip might be changing, which might mean that my brakeless wire wheels might need replacing. I've ordered some gokart brake drums from which I'm going to build up a new hub. I can then either dismantle the brakelss wheels and send it all back to Buchannans, OR I can sell the brakeless set for enough to make a new set. If anyone is interested in purchasing the brakeless set, contact me and I can send pics. They've never been used and are totally unique and authentic in that I used old style smooth clincher WW1 style wheels and tires. They are use 28 X 3 tires. 38 Stainless steel spokes and laced at Buchannans. Bronze bushings, grease fitting and they weigh 18 lbs. IF I decide to proceed, I'd probably just want to start over rather than taking these wheels apart, so selling them would be best. my spam will catch your emails, but I'll find the message and add you to my address book. Douwe douweblumberg(at)earthlink.net ________________________________________________________________________________
Subject: carb ice, triangle installed ?
Date: Apr 30, 2007
Oscar-- you have the same setup as I do with Aeronca stacks and carb heat muff. Inside the muff where your front and rear pipes Y together there should be a steel triangle that fits in that Y with about 1/8 inch space between it and the pipes to slow the air down and get better heat transfer to the hot side of your carb air scat hose. My pipes did not come with this triangle so I had to add it. As I recall there is a tab (or you can weld one in) to nut and bolt the steel triangle to. Mike C. ________________________________________________________________________________
Date: Apr 30, 2007
Hello Oscar, > From: "Oscar Zuniga" <taildrags(at)hotmail.com> > My Tech Counselor up in Oregon, a Piet flyer with a Franklin on his > airplane, advised me to use carb heat while taxiing and anytime the > throttle came back to less than 1500 RPM. I think I'll take his advice > from now on. Actually, the prime RPM for ice is probably from around 1200 to 1600 or 1700 and 'theoretically' doesn't produce ice at idle or full power. However, after owning a 65 hp Luscumbe 8A for 17 years, I became very aware of ice, especially on chilly mornings in the fall and spring seasons with our high humidity. _But_, you need to consider operating environment (taxiways and runways) for your above rule. Remember that the air with the carburetor heat ON is _unfiltered_, bypassing the air filter and any sand, dust, etc. from the runway and taxiway can go directly into your engine. ...Edwin ____________________________________________________________ "Once you have flown, you will walk the earth with your eyes turned skyward, for there you have been, there you long to return."-da Vinci http://bellsouthpwp2.net/e/d/edwinljohnson ________________________________________________________________________________
Date: Apr 30, 2007
Subject: Pietenpol Vs. Flybaby cockpit
Has anyone ever sat in a Bowers Flybaby cockpit and how does it compare in size to the Piet? I remember it being a little tight. I'd hate to add the extra weight just for 2". Thanks, -Ryan --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: May 01, 2007
Mikeee wrote- >Inside the muff where your front and rear pipes Y together >there should be a steel triangle that fits in that Y Got it. I had my welder add a tab to each down-pipe and then bolted a triangular piece of flat steel plate onto the tabs to force the incoming air to flow around the plate and pipes instead of just shooting past them into the carb air box. It works great. I can open up the heat muff and take a photo if anyone cares to see it (should have done that prior to reinstalling the assembly anyway) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Exercise your brain! Try Flexicon. http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07 ________________________________________________________________________________
Date: May 01, 2007
Subject: Re: carb ice, triangle installed ?
Oscar, Now........ you know better then to lead a horse to water!.....Of course we can use a photo! A picture is worth a thousand words.....tee-hee-hee Ken H Fargo, ND Oscar Zuniga wrote: Mikeee wrote- >Inside the muff where your front and rear pipes Y together >there should be a steel triangle that fits in that Y Got it. I had my welder add a tab to each down-pipe and then bolted a triangular piece of flat steel plate onto the tabs to force the incoming air to flow around the plate and pipes instead of just shooting past them into the carb air box. It works great. I can open up the heat muff and take a photo if anyone cares to see it (should have done that prior to reinstalling the assembly anyway) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Exercise your brain! Try Flexicon. http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07 --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: wood gear question
Date: May 01, 2007
Getting close to cutting the wood for the gear and just have a couple of questions. First - it is spruce that is used for the legs correct? And just ash for the bottom block... Second - what is the purpose for angling the bottom ash blocks back so they intersect at the tail wheel (if you were to extend them all the way back...)? I understand the reasoning for angling them for clearance when the plane is in 3-point attitude, but would there be any reason to not keep the ash block in line with the wheels (not angled inward towards the tail wheel)? It would make the bottom cuts much easier to make without the inward cant. Third - do you glue the bottom joints from the legs to the ash, or do you rely on the metal side plates to attach these pieces? Thanks! Dan Loegering Fargo, ND ________________________________________________________________________________
Date: May 01, 2007
Subject: Re: Pietenpol Vs. Flybaby cockpit
Just happen to have the FlyBaby plans in front of me Ryan. Outside width is 24 1/4". The longerons are 3/4x3/4" so the inside width is actually 1/4 to 1/2" wider than the Piet. Was fairly simple making mine 2" wider than plans, just cost a little weight and an extra sheet of 1/8" ply. Rick On 4/30/07, Ryan Michalkiewicz wrote: > > Has anyone ever sat in a Bowers Flybaby cockpit and how does it compare in > size to the Piet? I remember it being a little tight. I'd hate to add the > extra weight just for 2". > > Thanks, > > -Ryan > > ------------------------------ > Ahhh...imagining that irresistible "new car" smell? > Check out new cars at Yahoo! Autos.<http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-> > > * > > > * > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Date: May 01, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
Hi Dan, I don't know what others have done, but I can answer for what I did on my landing gear. The plans call for spruce, and there is no need to use anything heavier. I made mine of 1/4" planks of spruce laminated together, partly for strength and partly becasue I wanted to run a channel down the middle of the strut to hide my hydraulic brake lines (a plane of this type didn't have haydraulic lines hanging out everywhere in 1929). I found a side benefit of having the glue lines was it made it much easier to sand the struts to a uniform airfoil shape - the glue lines were straight when the surface was uniform. The "V-Blocks" are ash, because they take a pounding from the axle and ash absorbs shock better than any other wood (which is why they make baseball bats out of it). The purpose for angling the blocks toward the tail will become apparent if you try to make them parallel. I didn't realize they needed to be angled and went through several board feet of wood (fortunately, it was pine - I recommend making practice pieces first before committing to expensive spruce). I could never get the fit right at both the fuselage and the V-blocks. Finally I made a jig with strings representing the struts and realized I need to angle the V-blocks to make everything line up. It is just a coincidence that the angle required is very close to pointing toward the tailwheel. You can probably glue the V-blocks to the struts. I chose not to, to make it easier to thread my brake lines through. The steel plates are strong enough and glue is not necessary. The landing gear geometry is the single most difficult part of building this airplane, if you are using the straight axle gear. I don't know if the split type gear is any easier, but I know that once you get through this part, the rest will be easy. Good luck! Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Loegering Sent: Tuesday, May 01, 2007 9:59 AM Subject: Pietenpol-List: wood gear question --> Getting close to cutting the wood for the gear and just have a couple of questions. First - it is spruce that is used for the legs correct? And just ash for the bottom block... Second - what is the purpose for angling the bottom ash blocks back so they intersect at the tail wheel (if you were to extend them all the way back...)? I understand the reasoning for angling them for clearance when the plane is in 3-point attitude, but would there be any reason to not keep the ash block in line with the wheels (not angled inward towards the tail wheel)? It would make the bottom cuts much easier to make without the inward cant. Third - do you glue the bottom joints from the legs to the ash, or do you rely on the metal side plates to attach these pieces? Thanks! Dan Loegering Fargo, ND _________________________________________________ ________________________________________________________________________________
Date: May 01, 2007
Subject: Wood gear
Dan, I don't think it is physically possible to make those ash blocks in line with the line-of-flight. If it is I sure could not figure it out. The reason is that the fuselage starts to taper back before you get to the back leg attach point. I suppose it really could be done, but the result would be misalignment of the back leg with the ash block. In other words the back leg would end up sitting "crooked" on top of the ash block. It would take a better man than I to figure it out if it can be done. Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
From: "Steve Singleton" <slsingleton(at)cvalley.net>
Subject: Douglas Fir longerons
Date: May 01, 2007
Hi everyone- I bought a 16ft 2x6 douglas fir that i thought might work for longerons but it only has 5 to 6 growth rings pr in. It's a very nice looking board but am wondering if the 5-6 rings an in. is enough. Thanks for the help. Steve Singleton ----- ________________________________________________________________________________
Subject: Re: Douglas Fir longerons
Date: May 01, 2007
I believe 8 rings/inch is the minimum standard, sorry. Ben > > From: "Steve Singleton" <slsingleton(at)cvalley.net> > Date: 2007/05/01 Tue AM 10:25:16 EST > To: > Subject: Pietenpol-List: Douglas Fir longerons > > Hi everyone- I bought a 16ft 2x6 douglas fir that i thought might work for longerons but it only has 5 to 6 growth rings pr in. It's a very nice looking board but am wondering if the 5-6 rings an in. is enough. Thanks for the help. Steve Singleton > ----- > ________________________________________________________________________________
Date: May 01, 2007
Although the ring count doesn't quite come up to spec, I would not reject the idea out of hand. The longerons on a Piet are not dainty pieces (they're 1x1) and Doug Fir is stronger than spruce, so if it were me I think I'd look to see how straight and clear the planks are before discarding the idea and the planks. The thing about the wood between the rings is that it is softer as the ring spacing increases (wetter season?). If it were wing spars, no. Not even if I were The Fisherman II. And my opinion on this subject is worth as much as the thin air that the internet is made of ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Interest Rates NEAR 39yr LOWS! $430,000 Mortgage for $1,299/mo - Calculate new payment ________________________________________________________________________________
Date: May 01, 2007
Dan Question #1 The drawing calles for spruce. But we used ash for the whole landing gear.If you make perfect landings use spruce Question #2 I don't know. Question #3 Rely on the metal side plates.Glue won't hold on the end grain. Dale > [Original Message] > From: Dan Loegering <danl(at)odayequipment.com> > To: > Date: 5/1/2007 9:03:27 AM > Subject: Pietenpol-List: wood gear question > > > Getting close to cutting the wood for the gear and just have a couple of questions. > > First - it is spruce that is used for the legs correct? And just ash for the bottom block... > > Second - what is the purpose for angling the bottom ash blocks back so they intersect at the tail wheel (if you were to extend them all the way back...)? I understand the reasoning for angling them for clearance when the plane is in 3-point attitude, but would there be any reason to not keep the ash block in line with the wheels (not angled inward towards the tail wheel)? It would make the bottom cuts much easier to make without the inward cant. > > Third - do you glue the bottom joints from the legs to the ash, or do you rely on the metal side plates to attach these pieces? > > Thanks! > > Dan Loegering > Fargo, ND > > ________________________________________________________________________________
Date: May 01, 2007
You could satisfy your concerns with a strength test. Hang a weight from a piece of spruce and then from your fir. One test is worth 100 engineers. Howdy ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: perfect landings
Date: May 01, 2007
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Good post, Dale. I can vouch for good clean spruce gear legs and ash bottom pieces as I have made some real ground-smasher landings with no damage. On the gluing of the ash pieces---I roughed them up good with 100 grit or so paper and glued them with T-88 to the spruce legs and they have held beautifully. Don't clamp so tight as to squeeze the glue all out though. Mike C. ________________________________________________________________________________
Date: May 01, 2007
One engineer to set up your test right is worth 10,000 tests that give answers to questions you didn't know you asked. ---- VAHOWDY(at)aol.com wrote: > You could satisfy your concerns with a strength test. Hang a weight from a > piece of spruce and then from your fir. One test is worth 100 engineers. > Howdy > > > > ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 01, 2007
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Subject: Tail attachment
Ed and Rick, thanks for the past answers. We glue two small plywood wedges as suggested. Today we bolt the empenage to the fuselage, no problems. Attached a couple of pictures, the second one is the elevator stop (1/8 aluminum plate), not a new design but I like the simplicity and light weight of this device. Saludos Santiago --------------------------------- Pregunt. Respond. Descubr. Todo lo que queras saber, y lo que ni imaginabas, est en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: May 01, 2007
Subject: Finger faster than brain
Yep, I forgot the pictures --------------------------------- Pregunt. Respond. Descubr. Todo lo que queras saber, y lo que ni imaginabas, est en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Subject: Re: Carb Ice
Date: May 02, 2007
Pieters, I ran into serious carb icing a while back while climbing out. This is an A-75 with Stromberg carb & Aeronca stacks. The weather was cool and humid, worst case icing conditions. Yes, they're not supposed to do that at WOT, I know, but immediate application of carb heat cleared it up. Climbed on up to a safe altitude over the field at full throttle, turned carb heat off while at WOT, and the problem recurred in less than 30 seconds. Not the slow loss of power described in the textbooks, but roughness followed by loss of several hundred rpm within seconds. Once again, carb heat cleared it up almost instantly. The real root cause of the problem? I believe it was Mogas containing ethanol, saturated with water. I had noticed a loss of static rpm during runup, maybe 75-100 rpm, but it was smooth and sounded good, so I blamed it on cold oil. After being seriously spooked by the carb icing at WOT, I landed & rechecked the gascolator, but no free water was present. Went to the EAA website and followed the instructions on how to make an ethanol tester with a tall skinny bottle, and found that the local BP/Amoco 87 octane did indeed contain ethanol. Since the gasoline/ethanol absorbed only a small quantity of the test water initially put in the bottle, I'm assuming that it was already saturated with water. Drained the tank, refilled with 100LL, and gained over 100 rpm static. No icing at WOT or cruise since then, but the weather has warmed up as well. The Mogas went into the lawn mower............... I'm sticking with Avgas from now on. It has it's own issues, but at least it's consistent from batch to batch, unlike the local gas stations. Dave Mordecai NX520SF Panacea, FL Oscar wrote: > Taxied to the hangar and looked under the cowling. Frost on the carb > body and manifold, and lots of condensation on the carb and manifold > areas. Carb ice. I didn't have a lot of time to give it another shot > and had other tasks to do so I did them and put the airplane away. > Thirty-five minutes after shutting down the engine, there was still > condensation on the carb. >
Pieters,
Dave Mordecai
NX520SF
Panacea, FL
Date: May 01, 2007
Subject: Re: wood gear question
In a message dated 5/1/2007 10:34:56 A.M. Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes: Hi Dan, I don't know what others have done, but I can answer for what I did on my landing gear. The plans call for spruce, and there is no need to use anything heavier. I made mine of 1/4" planks of spruce laminated together, partly for strength and partly becasue I wanted to run a channel down the middle of the strut to hide my hydraulic brake lines (a plane of this type didn't have haydraulic lines hanging out everywhere in 1929). Is this your gear, Jack. Looks great, whoever it belongs to. Ron do not archive ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 01, 2007
Steve My opinion is that I wouldn't use it, but don't discard it either. There are plenty of places where it's not structurally as important where it can be used. Keep shopping the lumber bins and check the 1x4 t&g flooring at the lumber yards. Dick N. ----- Original Message ----- From: Steve Singleton To: pietenpol-list(at)matronics.com Sent: Tuesday, May 01, 2007 10:25 AM Subject: Pietenpol-List: Douglas Fir longerons Hi everyone- I bought a 16ft 2x6 douglas fir that i thought might work for longerons but it only has 5 to 6 growth rings pr in. It's a very nice looking board but am wondering if the 5-6 rings an in. is enough. Thanks for the help. Steve Singleton ----- ________________________________________________________________________________
Date: May 01, 2007
Subject: Re: Tail attachment
Didn't get any pictures Santiago. On 5/1/07, santiago morete wrote: > > Ed and Rick, thanks for the past answers. We glue two small plywood > wedges as suggested. Today we bolt the empenage to the fuselage, no > problems. > Attached a couple of pictures, the second one is the elevator stop (1/8 > aluminum plate), not a new design but I like the simplicity and light wei ght > of this device. > Saludos > > Santiago > > > ------------------------------ > *Pregunt=E1. Respond=E9. Descubr=ED.* > Todo lo que quer=EDas saber, y lo que ni imaginabas, > est=E1 en *Yahoo! Respuestas* (Beta). > > * > =========== =========== =========== > > * > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Subject: Re: Finger faster than brain
Date: May 01, 2007
I absolutely love the elevator travel stop! VERY nice! ________________________________________________________________________________
Date: May 01, 2007
Dan Q: First - it is spruce that is used for the legs correct? And just ash for the bottom block... A: Yes, and it's what I used. Q: Second - what is the purpose for angling the bottom ash blocks back so they intersect at the tail wheel A: By angling the ask blocks inward it allows the front gear leg to lie within the plane of the rear gear leg. If you do not angle the ash block in ward the rear gear leg will not sit squarely on the block no matter how you cut it. Don't assume that angling it towards the tail wheel will be the correct angle. You need to adjust so it aligns with the rear gear leg and the front gear leg. It just so happens this is about an angle to the tail wheel. The attached pictures shows my landing gear, upside down, the front gear leg is toward you. The vertical block the string is against in the inside edge of the ash block location. As you can see, to get the gear legs to line up in the same plane, the ash block needed to be angled inwards. However, the top view shows that on my setup the angle isn't quite pointing at the tail wheel (the string points at the tail wheel). Q: Third - do you glue the bottom joints from the legs to the ash, or do you rely on the metal side plates to attach these pieces? A: I don't plan on it and do not think you need to. If you can wait, soon I will post how I built my wood gear to my web site (still writing it up). It worked well for me and, although time consuming, it was rather simple to cut the gear legs accurately. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ________________________________________________________________________________
Date: May 01, 2007
Thanks for the opinions fellows. I'll do a load test on a 4ft 1x1in of the spruce and of the 5 ring pr in fir and let you know what happens. Looks like i go back and try to find a better board. Steve Singleton ----- ________________________________________________________________________________
Date: May 01, 2007
Make a mockpit! That will answer all your questions. http://clifdawson.ca/Pientenpol.html Clif Was fairly simple making mine 2" wider than plans, just cost a little weight and an extra sheet of 1/8" ply. Rick On 4/30/07, Ryan Michalkiewicz wrote: Has anyone ever sat in a Bowers Flybaby cockpit and how does it compare in size to the Piet? I remember it being a little tight. I'd hate to add the extra weight just for 2". Thanks, -Ryan ________________________________________________________________________________
Date: May 01, 2007
I've used fir as it is readily available to me. The grain count is more than 36 because the tighter the grain the easier it is to carve smooth rounded shapes and deal with the end grain trimming that is neccessary to have a good fit at the fuselage end. Don't fight the angle of the Ash block. Just make it fit the ends of the legs firmly and smoothly. Don't forget, an awful lot of it is going to be hidden behind and under bungee cords and axle tube. The bottom cuts are much easier than the fuselage ends. :-) No glue on the leg/block joint. I stuck a gyproc through there into each leg just to hold the assembly together while fitting the plates. http://clifdawson.ca/Pietenpol3.html Clif > First - it is spruce that is used for the legs correct? And just ash for > the bottom block... > > Second - what is the purpose for angling the bottom ash blocks back so > they intersect at the tail wheel (if you were to extend them all the way > back...)? It would make the bottom cuts much easier to make without the inward cant. > > Third - do you glue the bottom joints from the legs to the ash, or do you > rely on the metal side plates to attach these pieces? > > Thanks! > > Dan Loegering > Fargo, ND > > > -- > 2:57 PM > > ________________________________________________________________________________
Date: May 02, 2007
Not only is 100 LL Avgas more consistent and reliable, it is alos not much more expensive right now. I just filled my car with premium at $3.19 per gallon. Avgas on our field right now is $3.50 per gallon. After dissolving a needle valve with mogas 25 years ago, before they put much alcohol in it, I think I'll stick with avgas. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kmordecai001(at)comcast.net Sent: Tuesday, May 01, 2007 10:08 PM Subject: Pietenpol-List: Re: Carb Ice Pieters, I ran into serious carb icing a while back while climbing out. This is an A-75 with Stromberg carb & Aeronca stacks. The weather was cool and humid, worst case icing conditions. Yes, they're not supposed to do that at WOT, I know, but immediate application of carb heat cleared it up. Climbed on up to a safe altitude over the field at full throttle, turned carb heat off while at WOT, and the problem recurred in less than 30 seconds. Not the slow loss of power described in the textbooks, but roughness followed by loss of several hundred rpm within seconds. Once again, carb heat cleared it up almost instantly. The real root cause of the problem? I believe it was Mogas containing ethanol, saturated with water. I had noticed a loss of static rpm during runup, maybe 75-100 rpm, but it was smooth and sounded good, so I blamed it on cold oil. After being seriously spooked by the carb icing at WOT, I landed & rechecked the gascolator, but no free water was present. Went to the EAA website and followed the instructions on how to make an ethanol tester with a tall skinny bottle, and found that the local BP/Amoco 87 octane did indeed contain ethanol. Since the gasoline/ethanol absorbed only a small quantity of the test water initially put in the bottle, I'm assuming that it was already saturated with water. Drained the tank, refilled with 100LL, and gained over 100 rpm static. No icing at WOT or cruise since then, but the weather has warmed up as well. The Mogas went into the lawn mower............... I'm sticking with Avgas from now on. It has it's own issues, but at least it's consistent from batch to batch, unlike the local gas stations. Dave Mordecai NX520SF Panacea, FL Oscar wrote: > Taxied to the hangar and looked under the cowling. Frost on the carb > body and manifold, and lots of condensation on the carb and manifold > areas. Carb ice. I didn't have a lot of time to give it another shot > and had other tasks to do so I did them and put the airplane away. > Thirty-five minutes after shutting down the engine, there was still > condensation on the carb. > _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: May 02, 2007
Jack, Have you tried your new prop yet? Gene ________________________________________________________________________________
Date: May 02, 2007
Nope. When I do, I'll post some info to the group. Planning to fly it to Burlington, NC this weekend to a Vintage Aircraft Fly-in. Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Wednesday, May 02, 2007 7:53 AM Subject: Re: Pietenpol-List: Re: Carb Ice Jack, Have you tried your new prop yet? Gene http://www.matp; available via href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: May 02, 2007
Santiago I like your craftsmanship, very nice. But why the elevator stop ? None is called for in the plans, None is needed to fly. Antoine de Saint Exup=C3=A9ry said it so well. "Perfection is finally attain ed not when there is no longer anything to add, but when there is no longer anything to take away." And we all know the Pietenpol Air Camper is perfection Hans, -----Original Message----- From: moretesantiago(at)yahoo.com.ar Sent: Tue, 1 May 2007 9:07 PM Subject: Pietenpol-List: Finger faster than brain ________________________________________________________________________ AOL at AOL.com. ________________________________________________________________________________
Date: May 02, 2007
Good point, thats with I did using lumber from an old deck I tore out. You will learn a lot about the design before cutting the expensive wood and you will know for sure if you really need to widen. Rick On 5/1/07, Clif Dawson wrote: > > Make a mockpit! That will answer all your questions. > > http://clifdawson.ca/Pientenpol.html > > Clif > > > Was fairly simple making mine 2" wider than plans, just cost a little > weight and an extra sheet of 1/8" ply. > > Rick > > On 4/30/07, Ryan Michalkiewicz wrote: > > > > Has anyone ever sat in a Bowers Flybaby cockpit and how does it compare > > in size to the Piet? I remember it being a little tight. I'd hate to add the > > extra weight just for 2". > > > > Thanks, > > > > -Ryan > > > > * > > > * > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Subject: Airdrome Aeroplanes Wire Wheel kits
Date: May 02, 2007
Just got off the phone with Robert Baslee at Airdrome Aeroplanes. Very nice to talk with. He says he has built over 50 sets of wheels and feels quite satisfied with the present arrangement which he offers for sale. Here's the low-down on the wheel kits they sell: The standard hub is 6" inside the flanges (about 6 1/4" outside) - They CAN make a wider hub (about 7 1/4") if absolutely necessary, but have had the best success with the standard hub. The standard hub is fabricated from chromoly steel, and prime painted. Standard hub is supplied with oilite bushings with I.D. of 1.25". Standard hub has a larger inside flange, with a bolt pattern to attach brakes. Spokes are heavy duty, chrome plated. (I didn't ask what gauge) The rims are 19" diameter, chrome plated steel. The tires are approx 3 1/4", resulting in overall diameter of about 25 1/2" for the wheel. The wheel kit includes the hubs with bushings, spokes, rims, tubes and tires (and a video). The price listed on the website ($495 per pair) typically is for customers who have purchased their landing gear from him. The price for wheel kits alone is $595. Lacing and truing is typically another $100. But Robert kind of hinted that they could probably include the lacing and truing in the $595 price. (nudge, nudge, wink, wink). He said that they will sell the hubs alone for $195, because they are a difficult part to make. If you want to make your own hubs, he said he COULD sell the rims, spokes, tires & tubes, but anyone could do that. >From recent posts we see that John Egan has built his wheels for about $340 (doing all the work himself), and Chris Tracy has invested about $800 (with purchased hubs and 21" aluminum rims). Overall the wheel kits sound like good value for the money. Especially if you don't feel like building your own hubs. Bill C. ________________________________________________________________________________
Subject: Fir-spruce test
Date: May 02, 2007
Hi everyone- I just completed my highly scientific stress test on a 48in 1x1of spruce and douglas fir. Both had about a 30degree slope(i know thats a lot of slope). Both were bowed down about 1/16 when i started. With a 5gal bucket with 3gal H20 the spruce bowed apprx. 435 thousandths - firwas at 400 thou. At 5gal water fir. was at 550 down and spruce had bowed down aapprx. 665 thous. Then removed bucket and put my 200lbs slowly onto the fir and after just a bit I did hear a crack. Put my weight on the spruce and it had a catastrophic failure instantly. The spruce had many rings per in. and the fir had only 5. Moral of the story is i know its not rocket science and i need to just build. Yes everyone knows that fir is stronger but weighs a bit more. I agree with someones else comment that the 5 or 6 ring fir is probably just fine but i'm sure more rings would be even better. After doing all these very detailed xperiments a feel i have become an xpert in the weight stess analysis field so i feel i can speak up and give one more opinion hear. Make sure you do this test over your floor drain! Have a great day. Steve S ________________________________________________________________________________
Subject: Re: Fir-spruce test
Date: May 02, 2007
Steve Still worried about the fir. This is what I did with mine. Make your longerons 1x1 but rip them to a little over 1/2 inch and glue them back together. Take one of the pieces and swap ends. Than plane them to 1x1. Works great. jas ----- Original Message ----- From: Steve Singleton To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 5:15 PM Subject: Pietenpol-List: Fir-spruce test Hi everyone- I just completed my highly scientific stress test on a 48in 1x1of spruce and douglas fir. Both had about a 30degree slope(i know thats a lot of slope). Both were bowed down about 1/16 when i started. With a 5gal bucket with 3gal H20 the spruce bowed apprx. 435 thousandths - firwas at 400 thou. At 5gal water fir. was at 550 down and spruce had bowed down aapprx. 665 thous. Then removed bucket and put my 200lbs slowly onto the fir and after just a bit I did hear a crack. Put my weight on the spruce and it had a catastrophic failure instantly. The spruce had many rings per in. and the fir had only 5. Moral of the story is i know its not rocket science and i need to just build. Yes everyone knows that fir is stronger but weighs a bit more. I agree with someones else comment that the 5 or 6 ring fir is probably just fine but i'm sure more rings would be even better. After doing all these very detailed xperiments a feel i have become an xpert in the weight stess analysis field so i feel i can speak up and give one more opinion hear. Make sure you do this test over your floor drain! Have a great day. Steve S ________________________________________________________________________________
Date: May 02, 2007
Jim-dumb question but did you have the pieces for botttom long. preshaped in jig when you glued them up or just straight. Steve S ----- Original Message ----- From: Jim Sury To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 7:18 PM Subject: Re: Pietenpol-List: Fir-spruce test Steve Still worried about the fir. This is what I did with mine. Make your longerons 1x1 but rip them to a little over 1/2 inch and glue them back together. Take one of the pieces and swap ends. Than plane them to 1x1. Works great. jas ________________________________________________________________________________
Date: May 02, 2007
Do you have video of this experiment, it sound highly entertaining, lol. Steve Singleton wrote: Hi everyone- I just completed my highly scientific stress test on a 48in 1x1of spruce and douglas fir. Both had about a 30degree slope(i know thats a lot of slope). Both were bowed down about 1/16 when i started. With a 5gal bucket with 3gal H20 the spruce bowed apprx. 435 thousandths - firwas at 400 thou. At 5gal water fir. was at 550 down and spruce had bowed down aapprx. 665 thous. Then removed bucket and put my 200lbs slowly onto the fir and after just a bit I did hear a crack. Put my weight on the spruce and it had a catastrophic failure instantly. The spruce had many rings per in. and the fir had only 5. Moral of the story is i know its not rocket science and i need to just build. Yes everyone knows that fir is stronger but weighs a bit more. I agree with someones else comment that the 5 or 6 ring fir is probably just fine but i'm sure more rings would be even better. After doing all these very detailed xperiments a feel i have become an xpert in the weight stess analysis field so i feel i can speak up and give one more opinion hear. Make sure you do this test over your floor drain! Have a great day. Steve S --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: May 02, 2007
Subject: Wood specs
I have found a lumber yard that is willing to special order some spruce. What should I ask for, i.e growth rings, quality, free and clear etc...? I am thinking 4 2x4x16's to get started. -Ryan --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: May 02, 2007
No but my wife thought it funny when the lab tech put his weight on the spruce and it collasped. She said i'm not rideing in that thing. She has no since of adventure. Steve S ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 7:46 PM Subject: Re: Pietenpol-List: Fir-spruce test Do you have video of this experiment, it sound highly entertaining, lol. Steve Singleton wrote: Hi everyone- I just completed my highly scientific stress test on a 48in 1x1of spruce and douglas fir. Both had about a 30degree slope(i know thats a lot of slope). Both were bowed down about 1/16 when i started. With a 5gal bucket with 3gal H20 the spruce bowed apprx. 435 thousandths - firwas at 400 thou. At 5gal water fir. was at 550 down and spruce had bowed down aapprx. 665 thous. Then removed bucket and put my 200lbs slowly onto the fir and after just a bit I did hear a crack. Put my weight on the spruce and it had a catastrophic failure instantly. The spruce had many rings per in. and the fir had only 5. ------------------------------------------------------------------------- --- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
Date: May 02, 2007
Straight worked just great. You could preshape but it isn't necessary. What's great about my process is that you can buy 1x6 lumber and make 1x1 longerons. jas ----- Original Message ----- From: Steve Singleton To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 7:38 PM Subject: Re: Pietenpol-List: Fir-spruce test Jim-dumb question but did you have the pieces for botttom long. preshaped in jig when you glued them up or just straight. Steve S ----- Original Message ----- From: Jim Sury To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 7:18 PM Subject: Re: Pietenpol-List: Fir-spruce test Steve Still worried about the fir. This is what I did with mine. Make your longerons 1x1 but rip them to a little over 1/2 inch and glue them back together. Take one of the pieces and swap ends. Than plane them to 1x1. Works great. jas ________________________________________________________________________________
Date: May 02, 2007
Subject: Re: Airdrome Aeroplanes Wire Wheel kits
Group, I have attached a photo of the wheels I made with 19" rims. I would build wheels again now that I learned how to do it, however it took me a very long time to learn and complete this portion of my project. I agree that the $495 price of a complete set is a very reasonable price. john e. Bill Church wrote: Just got off the phone with Robert Baslee at Airdrome Aeroplanes. Very nice to talk with. He says he has built over 50 sets of wheels and feels quite satisfied with the present arrangement which he offers for sale. Here's the low-down on the wheel kits they sell: The standard hub is 6" inside the flanges (about 6 1/4" outside) - They CAN make a wider hub (about 7 1/4") if absolutely necessary, but have had the best success with the standard hub. The standard hub is fabricated from chromoly steel, and prime painted. Standard hub is supplied with oilite bushings with I.D. of 1.25". Standard hub has a larger inside flange, with a bolt pattern to attach brakes. Spokes are heavy duty, chrome plated. (I didn't ask what gauge) The rims are 19" diameter, chrome plated steel. The tires are approx 3 1/4", resulting in overall diameter of about 25 1/2" for the wheel. The wheel kit includes the hubs with bushings, spokes, rims, tubes and tires (and a video). The price listed on the website ($495 per pair) typically is for customers who have purchased their landing gear from him. The price for wheel kits alone is $595. Lacing and truing is typically another $100. But Robert kind of hinted that they could probably include the lacing and truing in the $595 price. (nudge, nudge, wink, wink). He said that they will sell the hubs alone for $195, because they are a difficult part to make. If you want to make your own hubs, he said he COULD sell the rims, spokes, tires & tubes, but anyone could do that. From recent posts we see that John Egan has built his wheels for about $340 (doing all the work himself), and Chris Tracy has invested about $800 (with purchased hubs and 21" aluminum rims). Overall the wheel kits sound like good value for the money. Especially if you don't feel like building your own hubs. Bill C. --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: May 02, 2007
Subject: Re: Wood specs
I'd go with 2X6's instead if you could get 4 of those you'd have plenty for the fuselage and tail.. Special order it may be tough to get the specifications on growth rings. You want at least 8 per inch. EAA has a good book on building with wood, and if you are a member of EAA they have a bunch of articles in the homebuilders section of their website that would help you grade the wood. Good Luck Ben Ryan Michalkiewicz wrote: > I have found a lumber yard that is willing to special order some > spruce. What should I ask for, i.e growth rings, quality, free and > clear etc...? I am thinking 4 2x4x16's to get started. > > -Ryan > > ------------------------------------------------------------------------ > Ahhh...imagining that irresistible "new car" smell? > Check out new cars at Yahoo! Autos. > <http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-> > > >* > > >* > ________________________________________________________________________________
Date: May 02, 2007
Subject: Carb Ice
The 'ol Continental 0-200 is bad for ice, too. I think it's because the carb's not mounted on the sump like a Lyc. This should give more HP/cubic inch, at least in theory, due to the cooler charge. Larry the microMong guy -- ________________________________________________________________________________
Subject: Tail wires
Date: May 02, 2007
Can any one give me a direction to go where I can find the tension required for the tail brace wires. Also what is the tension of the alerion control cables? Just a update for everone on N970Y Mr. Don Hicks piet, I have been working on the starting problems of the model A. Due to poor spark, bad wires, dirty fuel and a bad mag we think we have things going our way. I hope to fly with in the month. Chet Hartley ________________________________________________________________________________
Subject: Re: Tail wires
Date: May 02, 2007
Chet On your first two questions, not much and not much. You definetly don't want the wires to ping or fwang when you pluck them on the tail. More importantly, make sure the wires leave the tail perfectly balanced. A half turn off here or there changes the way it flys. On the ailereons, The tighter they are the more friction on the pulleys and fittings. Align using the top cable and just snug up the bottoms. Good luck Dick N. ----- Original Message ----- From: Chet's Mail To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 9:00 PM Subject: Pietenpol-List: Tail wires Can any one give me a direction to go where I can find the tension required for the tail brace wires. Also what is the tension of the alerion control cables? Just a update for everone on N970Y Mr. Don Hicks piet, I have been working on the starting problems of the model A. Due to poor spark, bad wires, dirty fuel and a bad mag we think we have things going our way. I hope to fly with in the month. Chet Hartley ________________________________________________________________________________
Date: May 02, 2007
Thanks Hans. Well, we just like the stops in the controls, in fact we will add stops for the rudder and aileron (small, very small wood blocks) it adds no complexity or weight and that's my main concern. I agree 100% with your Piet philosophy. We will have a one piece wing, wood gear, Ford A, but also will have safety belts, brakes and a steerable tail wheel (I already feel shame for that). Yes, as a Piet purist I'm a sinner. Saludos Santiago --------------------------------- Pregunt. Respond. Descubr. Todo lo que queras saber, y lo que ni imaginabas, est en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: May 02, 2007
Take a look at these http://www.bowersflybaby.com/tech/testing_wood.pdf and http://www.sportair.org/articles/Aircraft%20Wood%20-%20Part%20One.html and a good overview of wood. http://www.auf.asn.au/scratchbuilder/contents.html Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: Ryan Michalkiewicz To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 5:58 PM Subject: Pietenpol-List: Wood specs I have found a lumber yard that is willing to special order some spruce. What should I ask for, i.e growth rings, quality, free and clear etc...? I am thinking 4 2x4x16's to get started. -Ryan ------------------------------------------------------------------------- ----- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
Date: May 03, 2007
Subject: Off Topic - Ya can't do that in a Piet !!
Here is the high energy promo clip for Skip Stewert Airshow. His show is coming to Wichita in the fall. _http://youtube.com/watch?v=UWAbbV4ZB_k_ (http://youtube.com/watch?v=UWAbbV4ZB_k) Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Tail wires
Date: May 03, 2007
Good answers, Dick. I don't want the wires to "ping". I prefer a very low "Thummmm". Important thing is to make them all sound and feel about the same Jack P. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Wednesday, May 02, 2007 10:15 PM Subject: Re: Pietenpol-List: Tail wires Chet On your first two questions, not much and not much. You definetly don't want the wires to ping or fwang when you pluck them on the tail. More importantly, make sure the wires leave the tail perfectly balanced. A half turn off here or there changes the way it flys. On the ailereons, The tighter they are the more friction on the pulleys and fittings. Align using the top cable and just snug up the bottoms. Good luck Dick N. ----- Original Message ----- From: Chet's Mail <mailto:Chethartley1(at)mchsi.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 9:00 PM Subject: Pietenpol-List: Tail wires Can any one give me a direction to go where I can find the tension required for the tail brace wires. Also what is the tension of the alerion control cables? Just a update for everone on N970Y Mr. Don Hicks piet, I have been working on the starting problems of the model A. Due to poor spark, bad wires, dirty fuel and a bad mag we think we have things going our way. I hope to fly with in the month. Chet Hartley href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Subject: Tail wires
Date: May 03, 2007
I don't understand how you can do that when the elevator is at center position you have the top cables holding it up and if you loosen those off it will drop the elevator .I tried to get them looser but it was out of position??????????????? ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phillips, Jack Sent: May 3, 2007 9:02 AM Subject: RE: Pietenpol-List: Tail wires Good answers, Dick. I don't want the wires to "ping". I prefer a very low "Thummmm". Important thing is to make them all sound and feel about the same Jack P. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Wednesday, May 02, 2007 10:15 PM Subject: Re: Pietenpol-List: Tail wires Chet On your first two questions, not much and not much. You definetly don't want the wires to ping or fwang when you pluck them on the tail. More importantly, make sure the wires leave the tail perfectly balanced. A half turn off here or there changes the way it flys. On the ailereons, The tighter they are the more friction on the pulleys and fittings. Align using the top cable and just snug up the bottoms. Good luck Dick N. ----- Original Message ----- From: Chet's Mail <mailto:Chethartley1(at)mchsi.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 9:00 PM Subject: Pietenpol-List: Tail wires Can any one give me a direction to go where I can find the tension required for the tail brace wires. Also what is the tension of the alerion control cables? Just a update for everone on N970Y Mr. Don Hicks piet, I have been working on the starting problems of the model A. Due to poor spark, bad wires, dirty fuel and a bad mag we think we have things going our way. I hope to fly with in the month. Chet Hartley href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat r onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ">http://www.matronics.com/Navigator?Pietenpol-List ics.com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Subject: Tail wires
Date: May 03, 2007
Discussion here is tail BRACE wires. Not the elevator control cables. That's a whole different issue, and one that I don't think ol' BHP thought out too well. Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of harvey.rule(at)bell.ca Sent: Thursday, May 03, 2007 9:40 AM Subject: RE: Pietenpol-List: Tail wires I don't understand how you can do that when the elevator is at center position you have the top cables holding it up and if you loosen those off it will drop the elevator .I tried to get them looser but it was out of position??????????????? _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phillips, Jack Sent: May 3, 2007 9:02 AM Subject: RE: Pietenpol-List: Tail wires Good answers, Dick. I don't want the wires to "ping". I prefer a very low "Thummmm". Important thing is to make them all sound and feel about the same Jack P. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Wednesday, May 02, 2007 10:15 PM Subject: Re: Pietenpol-List: Tail wires Chet On your first two questions, not much and not much. You definetly don't want the wires to ping or fwang when you pluck them on the tail. More importantly, make sure the wires leave the tail perfectly balanced. A half turn off here or there changes the way it flys. On the ailereons, The tighter they are the more friction on the pulleys and fittings. Align using the top cable and just snug up the bottoms. Good luck Dick N. ----- Original Message ----- From: Chet's Mail <mailto:Chethartley1(at)mchsi.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 9:00 PM Subject: Pietenpol-List: Tail wires Can any one give me a direction to go where I can find the tension required for the tail brace wires. Also what is the tension of the alerion control cables? Just a update for everone on N970Y Mr. Don Hicks piet, I have been working on the starting problems of the model A. Due to poor spark, bad wires, dirty fuel and a bad mag we think we have things going our way. I hope to fly with in the month. Chet Hartley href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ">http://www.matronics.com/Navigator?Pietenpol-List ics.com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: May 02, 2007
I'll try there 1x6's next. Thanks for the tip. Steve S ----- Original Message ----- From: Jim Sury To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 8:14 PM Subject: Re: Pietenpol-List: Fir-spruce test Straight worked just great. You could preshape but it isn't necessary. What's great about my process is that you can buy 1x6 lumber and make 1x1 longerons. jas ----- Original Message ----- From: Steve Singleton To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 7:38 PM Subject: Re: Pietenpol-List: Fir-spruce test Jim-dumb question but did you have the pieces for botttom long. preshaped in jig when you glued them up or just straight. Steve S ----- Original Message ----- From: Jim Sury To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 7:18 PM Subject: Re: Pietenpol-List: Fir-spruce test Steve Still worried about the fir. This is what I did with mine. Make your longerons 1x1 but rip them to a little over 1/2 inch and glue them back together. Take one of the pieces and swap ends. Than plane them to 1x1. Works great. jas href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: May 03, 2007
Jack, OK let's not be hasty and loose with the assumption that BHP actually made any unintentional mistakes with those elevator control cables. I prefer to think that BHP, being the visionary we all know he was, intentionally made those cables that way because he knew that it would be one of the "distinguishing characteristics" of his quaint design, and he knew we would all be talking about it all these years later. Maybe he thought that the cable rubbing on the L.E. of the horizontal stab would eliminate the weight and complexity of an additional fairlead. Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Tail wires
Date: May 03, 2007
Thanks for straightening me out on that.By the way my bracing is done by rods that are adjustable.See insert. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phillips, Jack Sent: May 3, 2007 9:49 AM Subject: RE: Pietenpol-List: Tail wires Discussion here is tail BRACE wires. Not the elevator control cables. That's a whole different issue, and one that I don't think ol' BHP thought out too well. Jack ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of harvey.rule(at)bell.ca Sent: Thursday, May 03, 2007 9:40 AM Subject: RE: Pietenpol-List: Tail wires I don't understand how you can do that when the elevator is at center position you have the top cables holding it up and if you loosen those off it will drop the elevator .I tried to get them looser but it was out of position??????????????? ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phillips, Jack Sent: May 3, 2007 9:02 AM Subject: RE: Pietenpol-List: Tail wires Good answers, Dick. I don't want the wires to "ping". I prefer a very low "Thummmm". Important thing is to make them all sound and feel about the same Jack P. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Wednesday, May 02, 2007 10:15 PM Subject: Re: Pietenpol-List: Tail wires Chet On your first two questions, not much and not much. You definetly don't want the wires to ping or fwang when you pluck them on the tail. More importantly, make sure the wires leave the tail perfectly balanced. A half turn off here or there changes the way it flys. On the ailereons, The tighter they are the more friction on the pulleys and fittings. Align using the top cable and just snug up the bottoms. Good luck Dick N. ----- Original Message ----- From: Chet's Mail <mailto:Chethartley1(at)mchsi.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 9:00 PM Subject: Pietenpol-List: Tail wires Can any one give me a direction to go where I can find the tension required for the tail brace wires. Also what is the tension of the alerion control cables? Just a update for everone on N970Y Mr. Don Hicks piet, I have been working on the starting problems of the model A. Due to poor spark, bad wires, dirty fuel and a bad mag we think we have things going our way. I hope to fly with in the month. Chet Hartley href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat r onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ">http://www.matronics.com/Navigator?Pietenpol-List ics.com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ">http://www.matronics.com/Navigator?Pietenpol-List ics.com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: May 03, 2007
Subject: Tail wires
Harvey, Your tail bracing rods are pretty standard fare for old taildraggers. My 7AC Champ was so equipped and was tuned to a low A#, very much like Jack Phillips' "thummm"...very pleasant music until one of my "thumm"s became a "thud." It was a tiny fracture in a rod at one rod end fitting. "Thummming" is an excellent preflight check. Mike Hardaway ---- harvey.rule(at)bell.ca wrote: > Thanks for straightening me out on that.By the way my bracing is done by > rods that are adjustable.See insert. > > [snip] ________________________________________________________________________________
Date: May 03, 2007
Your look lots like mine, I've had good luck with them, so I think you'll be satisfied. I think that everyone should try to make their own. It's fun and very rewarding. In my picture # 188, you can see the "mini lathe" that I used to make them. Always wanted one, so this was a good reason to buy it. Notice the scratch on the bottom where the hub mets the flange. Thats to line up the spoke holes from one flange to the other so the spokes will lace right. PS the white bearings are just PVC temporary bearings used to true up the spokes on an axle mandrel. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: John Egan To: pietenpol-list(at)matronics.com Sent: Wednesday, May 02, 2007 9:19 PM Subject: Re: Pietenpol-List: Airdrome Aeroplanes Wire Wheel kits Group, I have attached a photo of the wheels I made with 19" rims. I would build wheels again now that I learned how to do it, however it took me a very long time to learn and complete this portion of my project. I agree that the $495 price of a complete set is a very reasonable price. john e. Bill Church wrote: Just got off the phone with Robert Baslee at Airdrome Aeroplanes. Very nice to talk with. He says he has built over 50 sets of wheels and feels quite satisfied with the present arrangement which he offers for sale. Here's the low-down on the wheel kits they sell: The standard hub is 6" inside the flanges (about 6 1/4" outside) - They CAN make a wider hub (about 7 1/4") if absolutely necessary, but have had the best success with the standard hub. The standard hub is fabricated from chromoly steel, and prime painted. Standard hub is supplied with oilite bushings with I.D. of 1.25". Standard hub has a larger inside flange, with a bolt pattern to attach brakes. Spokes are heavy duty, chrome plated. (I didn't ask what gauge) The rims are 19" diameter, chrome plated steel. The tires are approx 3 1/4", resulting in overall diameter of about 25 1/2" for the wheel. The wheel kit includes the hubs with bushings, spokes, rims, tubes and tires (and a video). The price listed on the website ($495 per pair) typically is for customers who have purchased their landing gear from him. The price for wheel kits alone is $595. Lacing and truing is typically another $100. But Robert kind of hinted that they could probably include the lacing and truing in the $595 price. (nudge, nudge, wink, wink). He said that they will sell the hubs alone for $195, because they are a difficult part to make. If you want to make your own hubs, he said he COULD sell the rims, spokes, tires & tubes, but anyone could do that. From recent posts we see that John Egan has built his wheels for about $340 (doing all the work himself), and Chris Tracy has invested about $800 (with purchased hubs and 21" aluminum rims). Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ------------------------------------------------------------------------- --- ________________________________________________________________________________
Date: May 03, 2007
Subject: Going South again
Hi all, On the road again to the Carolinas from Charlotte NC to the GA line on I 85. During my travels I would like to meet up with other Piet owners and or builders to check out projects flying and non. Anyone in that area willing to share some Piet time please let me know, I would appreciate a meet and greet evening if and where possible. Please let me know if you're interested! Thanks John ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Hem fir
Date: May 03, 2007
Has anyone used Hem Fir? My local lumber yard has some and they told me it was very clear and sraight grained but i have not heard of it being used on a Homebuilt before. I ran a search on the internet and it is used in makeing a lot of trim lumber. Steve S ________________________________________________________________________________
Date: May 04, 2007
I know when I drove my MGB car I wanted wire wheels but a few of the guys told me that one drive over a bumpy road and these babies would be out of round. The spokes would loosen up and there are all kinds of trouble with tightening them again. Do you guys who have used wire wheels on your Piet in the past find this to be a problem? ________________________________ ________________________________________________________________________________
Date: May 04, 2007
I abuse the wire wheels on NX18235 pretty regularly with less than graceful landings. No problems. Greg C. ----- Original Message ----- From: harvey.rule(at)bell.ca To: pietenpol-list(at)matronics.com Sent: Friday, May 04, 2007 6:02 AM Subject: RE: Pietenpol-List: Airdrome Aeroplanes Wire Wheel kits I know when I drove my MGB car I wanted wire wheels but a few of the guys told me that one drive over a bumpy road and these babies would be out of round. The spokes would loosen up and there are all kinds of trouble with tightening them again. Do you guys who have used wire wheels on your Piet in the past find this to be a problem? ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: May 04, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
If you get to the Raleigh, NC area, give me a call Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com Sent: Thursday, May 03, 2007 7:32 PM Subject: Pietenpol-List: Going South again Hi all, On the road again to the Carolinas from Charlotte NC to the GA line on I 85. During my travels I would like to meet up with other Piet owners and or builders to check out projects flying and non. Anyone in that area willing to share some Piet time please let me know, I would appreciate a meet and greet evening if and where possible. Please let me know if you're interested! Thanks John _____ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: May 04, 2007
Not at all. Anyone who has flown with me can tell you that many of my landings are not kind to the undercarriage. Even after a forced landing where I hit hard enough to break the axle, the wheels are still true (and no touch up was required to the wheels after that landing). Wire wheels are actually among the strongest of wheels (which is why sports cars used them to begin with). Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of harvey.rule(at)bell.ca Sent: Friday, May 04, 2007 7:03 AM Subject: RE: Pietenpol-List: Airdrome Aeroplanes Wire Wheel kits I know when I drove my MGB car I wanted wire wheels but a few of the guys told me that one drive over a bumpy road and these babies would be out of round. The spokes would loosen up and there are all kinds of trouble with tightening them again. Do you guys who have used wire wheels on your Piet in the past find this to be a problem? _____ _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: May 04, 2007
Subject: Re: Going South again
In a message dated 5/4/2007 7:21:51 A.M. Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes: you get to the Raleigh, NC area, give me a call Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 Jack, Thanks for the invite, how far are you from Charlotte. I arrive Monday May 14 Charlotte NC, at this point I am available to drive to Raleigh if its not too much of a trip. I arrive Charlotte around 5:00 pm so it is a possible if not too far of a drive. Please advise on distance and your availability. Thanks John Recine ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 04, 2007
Charlotte is about a 3 hour drive from Raleigh _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com Sent: Friday, May 04, 2007 8:34 AM Subject: Re: Pietenpol-List: Going South again In a message dated 5/4/2007 7:21:51 A.M. Eastern Daylight Time, Jack.Phillips(at)cardinal.com writes: you get to the Raleigh, NC area, give me a call Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 Jack, Thanks for the invite, how far are you from Charlotte. I arrive Monday May 14 Charlotte NC, at this point I am available to drive to Raleigh if its not too much of a trip. I arrive Charlotte around 5:00 pm so it is a possible if not too far of a drive. Please advise on distance and your availability. Thanks John Recine _____ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Subject: Hem fir
Date: May 04, 2007
Steve, Not sure, when you say 'Hem Fir", if you are referring to Western Hemlock. If that's what you mean, then it can be a suitable substitute for Sitka Spruce (almost identical density, with higher strength). Ask the lumberyard exactly what species they have on hand. Check the weblinks that Chris Tracy posted yesterday, and you'll see Western Hemlock listed in the charts. Go to the Matronics Archives, http://www.matronics.com/search/ and do a search in the Pietenpol Archive, using the word "hemlock". You should find enough reading to keep you busy for a couple of hours. As you read through, you'll see that at least one builder (Clif Dawson) has built almost his entire airframe using CAREFULLY SELECTED Western Hemlock. I can't recall the source, but I definitely remember reading that BHP built laminated spars from carefully selected lumberyard Hemlock. Bill C. ________________________________________________________________________________
Date: May 04, 2007
Subject: Re: Hem fir
I couldn't resist googling the hem-fir, Here is a clip form the site and th e link. FYI the official word on Hem-Fir from: (http://www.weyerhaeuser.com/default.asp) Hem-fir is the name given to a combination of hemlocks or firs that share similar characteristics. These include western hemlock and the true firs (noble, California red, grand, pacific silver and white fir)=94specie s primarily found commercially in the Northwest states and British Columbia. Hem-fir design values are nearly as strong as Douglas fir, resulting in an economical and excellent structural product. High ratios for strength and stiffness make it a good choice for framing, and the color of its wood is a mong the lightest of the western softwoods. Hem-fir is a species with excellent preservative treatment characteristics, which makes it an economical option to naturally durable species like western cedars and redwoods. Hem-fir products are available in structural, appearance and remanufacturin g grades. _Weyerhaeuser > Softwood Lumber > Softwood Lumber Species > Hem-Fir_ (http://www.weyerhaeuser.com/ourbusinesses/buildingproducts/softwoodlumber/s pecies/hem fir.asp) ************************************** See what's free at http://www.aol.com . ________________________________________________________________________________
Subject: washing the airplane
Date: May 04, 2007
Howdy, Pieters; My airplane's wings sat in a hangar for two years while I repaired the fuselage. Dust, bat droppings, rat droppings, bug stuff, rust drips from the hangar framing, you name it. I have not bothered to clean it up yet but will be doing so before the Hondo fly-in (SWRFI, June 1-2). The Poly-Fiber care instructions say just use gentle detergent to clean the surfaces and a good paste wax to protect them. However... one of the recent Sport Aviation magazines carried an interesting article about newer products that do a better job, so I'm going to give them a shot and will report back on how they work. First product is "Extreme Simple Green", which is supposed to be used to remove spots and stains before giving the whole thing a washing. My airplane has plenty of spots and stains so this will be a good test. The second product is "RejeX", a polymeric coating that goes on after the surfaces are clean and dry, instead of the wax job. Does NOT contain silicones that cause so many problems with painting later on (such as Lemon Pledge, Armor All, etc. contain). Supposed to make it much easier to remove bugs and droppings and lasts a couple of months. The Texas weather will provide a good test for this. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Download Messenger. Join the im Initiative. Help make a difference today. http://im.live.com/messenger/im/home/?source=TAGHM_APR07 ________________________________________________________________________________
Date: May 04, 2007
All I ever use is dish washing detergent with some water mixed in and spray that on .Let it sit for a while and wipe it off.Works to get bugs off the prop too after a flight.My prop always looks like new.I don't know how this will work on bat droppings though.I've only had to deal with bird droppings and it works fine. ________________________________________________________________________________
Date: May 04, 2007
Subject: Update!!!! Pietenpol Rip Off, Beware
Well I have to say the Baroness is awesome, she brought the photocopier to his knees! I received my original plans, with serial number in the mail today. The seller maintains it was an honest mistake. Barnstormers is great and the Baroness provides a great service to the aviation community. -Ryan Ryan Michalkiewicz wrote: These are not original plans. He is making photo copies and selling them as original plans. I had already purchased real Pietenpol plans from the Pietenpol family. I was buying his set of Piet and GN-1 drawings mainly for the GN-1. They are photocopies he ran off at Staples with no serial numbers. --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Date: May 04, 2007
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Subject: Tailwheel bracket
Guys, how do you attach the tailwheel bracket to the fuselage? Each bracket has four bolts, two going sideways an the other two from bottom to top of longeron interfering with the truss members. We are building the long fuselage and we would like to keep the original tube lenght (less arm, stiffer and ligthter), mount it behind the gusset plates and put the 4 bolts. Can this weaken the longerons to much? Gracias! Santiago --------------------------------- Pregunt. Respond. Descubr. Todo lo que queras saber, y lo que ni imaginabas, est en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: May 04, 2007
More pics ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of santiago morete Sent: May 4, 2007 8:57 PM Subject: Pietenpol-List: Tailwheel bracket Guys, how do you attach the tailwheel bracket to the fuselage? Each bracket has four bolts, two going sideways an the other two from bottom to top of longeron interfering with the truss members. We are building the long fuselage and we would like to keep the original tube lenght (less arm, stiffer and ligthter), mount it behind the gusset plates and put the 4 bolts. Can this weaken the longerons to much? Gracias! Santiago ________________________________ Pregunt=E1. Respond=E9. Descubr=ED. Todo lo que quer=EDas saber, y lo que ni imaginabas, est=E1 en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: May 04, 2007
Still more ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of santiago morete Sent: May 4, 2007 8:57 PM Subject: Pietenpol-List: Tailwheel bracket Guys, how do you attach the tailwheel bracket to the fuselage? Each bracket has four bolts, two going sideways an the other two from bottom to top of longeron interfering with the truss members. We are building the long fuselage and we would like to keep the original tube lenght (less arm, stiffer and ligthter), mount it behind the gusset plates and put the 4 bolts. Can this weaken the longerons to much? Gracias! Santiago ________________________________ Pregunt=E1. Respond=E9. Descubr=ED. Todo lo que quer=EDas saber, y lo que ni imaginabas, est=E1 en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Subject: While You're Making Flying Weather Plans
Date: May 04, 2007
For those of you close enough to McPherson, Kansas to think about flying here, don't forget the annual When Pigs Fly nationally rated BBQ contest and Fly in. This year the event will be on August 24-25 and it would sure be great to have a few Air Campers and/or Sky Scout's here on the ramp. The food is great, lots of other activities will be going on (weather permitting) and I, for one, will ensure that any Pietenpol birds get prime space on the ramp. More info at: http://www.eaa1344.com/ Tom Stinemetze The Airplane Nut ____ | ____ \8/ / \ ________________________________________________________________________________
Date: May 04, 2007
One more ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of santiago morete Sent: May 4, 2007 8:57 PM Subject: Pietenpol-List: Tailwheel bracket Guys, how do you attach the tailwheel bracket to the fuselage? Each bracket has four bolts, two going sideways an the other two from bottom to top of longeron interfering with the truss members. We are building the long fuselage and we would like to keep the original tube lenght (less arm, stiffer and ligthter), mount it behind the gusset plates and put the 4 bolts. Can this weaken the longerons to much? Gracias! Santiago ________________________________ Pregunt=E1. Respond=E9. Descubr=ED. Todo lo que quer=EDas saber, y lo que ni imaginabas, est=E1 en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: May 04, 2007
I've had two cars with wire wheels, a TR-2/3 and a 56 Healey. One was driven fast over many miles of moutanous gravel roads on Vancouver Island and the other saw some of the same but not as much. The TR was built like a truck but the Healey was too low. Since they were sports cars I certainly wasn't about to limit my speed now was I? Never was there any indication of out of round and there definitely would have been at speed on flat smooth pavement after all that rough usage. Clif ----- Original Message ----- From: harvey.rule(at)bell.ca To: pietenpol-list(at)matronics.com Sent: Friday, May 04, 2007 4:02 AM Subject: RE: Pietenpol-List: Airdrome Aeroplanes Wire Wheel kits I know when I drove my MGB car I wanted wire wheels but a few of the guys told me that one drive over a bumpy road and these babies would be out of round. The spokes would loosen up and there are all kinds of trouble with tightening them again. Do you guys who have used wire wheels on your Piet in the past find this to be a problem? ________________________________________________________________________________
Date: May 05, 2007
What it means is that in any given pile of material there will be some pieces that are Hemlock and some each of a few of the firs. In the firs used some are weaker than Spruce and some a little stronger. It will be difficult to tell which is which with a lot of it. I've encountered it here and gone through a few piles. None of it met my personal criteria. Framing material is fine for framing a house but is never graded to meet the needs we have. Knots, for instance, are quite acceptable in framing. As are many other defects. So choose carefully. Do you want one spar to be Pacific Silver at 6200 lb/in=C2=B2 and another of California Red at 7200 or Hemlock at 6800? Spruce in this same chart is 6700 lb/in=C2=B2 as a reference. Clif ----- Original Message ----- From: AMsafetyC(at)aol.com Subject: Re: Pietenpol-List: Hem fir Hem-fir is the name given to a combination of hemlocks or firs that share similar characteristics. These include western hemlock and the true firs (noble, California red, grand, pacific silver and white fir)=94species primarily found commercially in the Northwest states and British Columbia. Hem-fir design values are nearly as strong as Douglas fir, resulting in an economical and excellent structural product. High ratios for strength and stiffness make it a good choice for framing, and the color of its wood is among the lightest of the western softwoods. Hem-fir is a species with excellent preservative treatment characteristics, which makes it an economical option to naturally durable species like western cedars and redwoods. Hem-fir products are available in structural, appearance and remanufacturing grades. Weyerhaeuser > Softwood Lumber > Softwood Lumber Species > Hem-Fir ________________________________________________________________________________
Date: May 05, 2007
What I don't understand about all this debate re various woods is, WHY! The FAA's or EAA's Acceptable methods and materials booklets lets you know what's what about wood for aeroplanes. Your choice, but when you get right down to it, the cost of the wood is the absolute least of your cost in building a homebuilt. Why sweat it, get some sika spruce and start building or you'll never get flying. You'll make lots of mistakes, waste maybe 1/2 of your wood, but's still the least cost way of getting airborne. Gordon ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Friday, May 04, 2007 11:33 PM Subject: Re: Pietenpol-List: Hem fir What it means is that in any given pile of material there will be some pieces that are Hemlock and some each of a few of the firs. In the firs used some are weaker than Spruce and some a little stronger. It will be difficult to tell which is which with a lot of it. I've encountered it here and gone through a few piles. None of it met my personal criteria. Framing material is fine for framing a house but is never graded to meet the needs we have. Knots, for instance, are quite acceptable in framing. As are many other defects. So choose carefully. Do you want one spar to be Pacific Silver at 6200 lb/in=C2=B2 and another of California Red at 7200 or Hemlock at 6800? Spruce in this same chart is 6700 lb/in=C2=B2 as a reference. Clif ----- Original Message ----- From: AMsafetyC(at)aol.com Subject: Re: Pietenpol-List: Hem fir Hem-fir is the name given to a combination of hemlocks or firs that share similar characteristics. These include western hemlock and the true firs (noble, California red, grand, pacific silver and white fir)=94species primarily found commercially in the Northwest states and British Columbia. Hem-fir design values are nearly as strong as Douglas fir, resulting in an economical and excellent structural product. High ratios for strength and stiffness make it a good choice for framing, and the color of its wood is among the lightest of the western softwoods. Hem-fir is a species with excellent preservative treatment characteristics, which makes it an economical option to naturally durable species like western cedars and redwoods. Hem-fir products are available in structural, appearance and remanufacturing grades. Weyerhaeuser > Softwood Lumber > Softwood Lumber Species > Hem-Fir ________________________________________________________________________________
Date: May 05, 2007
Subject: Re: While You're Making Flying Weather Plans
In a message dated 5/4/2007 9:29:29 PM Central Daylight Time, tstinemetze(at)cox.net writes: When Pigs Fly nationally rated BBQ contest and Fly in. This year the event will be on August 24-25 Hey Tom, I just put it down on my calender . See ya there (if not sooner). Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 05, 2007
Subject: Wire Wheel kits and old cars
In a message dated 5/5/2007 1:11:21 AM Central Daylight Time, CDAWSON5854(at)shaw.ca writes: I've had two cars with wire wheels, a TR-2/3 Hey Clif, I had a TR3 when I was 17 - 19 yrs old. Man, was that a fun car to drive. I always had 2 or 3 passengers with me, in case we had to push the car somewhere. Never had to open the door...just hop over and into the seat. Plenty of power, too. That was the first engine I rebuilt from start to finish. I won $100 dollars in a twisting road race with an Opel Cadet...blew 'im away. I was always racing somebody. That was the only car I know of, that in a hard corner, the front wheels would slide before the back ones...ya just had to get used to that. I put close to 10,000 miles on it while I had it. It did have some problems, though. Things kept falling off of it...Like one time the grill fell out, and I ran over it, another time one of the front brake pads fell off, and I didn't have brakes, another time the slave cylinder stopped working so I had to shut the engine off at any stop lights, and use the starter button go get going then shift without the clutch, another time the generator quit working (at night of course) and I had to drive home with no headlights because when I turned the headlight on (one of them worked) the engine stopped running, but sometimes if I pounded on the dashboard the generator would start working again. Then, of course, the windshield wipers never did work, so I carried a long wiper arm and blade off of a big chevy, and just used my left hand out over the windshield to wipe the windscreen off. This was a Lucas Electrical System. The steering box was kinda stiff, so I had to turn the steering wheel back to center. Never did have to worry about getting wet when it rained, because the ol' rag top couldn't keep much rain off of the occupants anyway (no side curtains). There was no heater core, so sometimes I had to scrape the windshield inside and out. I discovered it had a POSITIVE ground, after I put an Eight Track Tape Player in it, and it gobbled up three of my favorite tapes, before I realized it was playing them backwards, and had to pull about 100 feet of tape out of the player each time. Ah, yesss...that sure was a Fun car to drive !! Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 05, 2007
Subject: Re: Wire Wheel kits and old cars
Chuck, Next week I'll tell you the story about how my daughter came home from La Tech one week end and told me about the bargain she found in a drainage ditch for $100. Yep, an MG Midget w/ wire wheels. Corky ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 05, 2007
Don't you wish you still had the TR-3? I had one also in the early 70's, paid $600 for it. Have you seen the prices now for them. Fun car to drive but I never knew when something like the generator would just fall out. Once the oil plug came out of the pan, talk about smokin. Dick N. ----- Original Message ----- From: Rcaprd(at)aol.com To: pietenpol-list(at)matronics.com Sent: Saturday, May 05, 2007 3:38 PM Subject: Pietenpol-List: Wire Wheel kits and old cars In a message dated 5/5/2007 1:11:21 AM Central Daylight Time, CDAWSON5854(at)shaw.ca writes: I've had two cars with wire wheels, a TR-2/3 Hey Clif, I had a TR3 when I was 17 - 19 yrs old. Man, was that a fun car to drive. I always had 2 or 3 passengers with me, in case we had to push the car somewhere. Never had to open the door...just hop over and into the seat. Plenty of power, too. That was the first engine I rebuilt from start to finish. I won $100 dollars in a twisting road race with an Opel Cadet...blew 'im away. I was always racing somebody. That was the only car I know of, that in a hard corner, the front wheels would slide before the back ones...ya just had to get used to that. I put close to 10,000 miles on it while I had it. It did have some problems, though. Things kept falling off of it...Like one time the grill fell out, and I ran over it, another time one of the front brake pads fell off, and I didn't have brakes, another time the slave cylinder stopped working so I had to shut the engine off at any stop lights, and use the starter button go get going then shift without the clutch, another time the generator quit working (at night of course) and I had to drive home with no headlights because when I turned the headlight on (one of them worked) the engine stopped running, but sometimes if I pounded on the dashboard the generator would start working again. Then, of course, the windshield wipers never did work, so I carried a long wiper arm and blade off of a big chevy, and just used my left hand out over the windshield to wipe the windscreen off. This was a Lucas Electrical System. The steering box was kinda stiff, so I had to turn the steering wheel back to center. Never did have to worry about getting wet when it rained, because the ol' rag top couldn't keep much rain off of the occupants anyway (no side curtains). There was no heater core, so sometimes I had to scrape the windshield inside and out. I discovered it had a POSITIVE ground, after I put an Eight Track Tape Player in it, and it gobbled up three of my favorite tapes, before I realized it was playing them backwards, and had to pull about 100 feet of tape out of the player each time. Ah, yesss...that sure was a Fun car to drive !! Chuck G. NX770CG ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Subject: Blaine Aviation Weekend
Date: May 05, 2007
This is coming very soon but it should be a great fly-in. EAA Chapter 237 is having a fly-in pancake breakfast and lunch at Anoka County Airport in Blaine, MN on May 19th and 20th Chapter 237's Famous Pancake Breakfast with sausage and beverage runs from 7a.m. to noon and lunch of hamburgers, hot dogs and chili runs until 4p.m. There are two really great aviation museums on the airport. Golden Wings Museum has a collection of beautifully restored vintage airplanes that includes five trimotors. American Wings Air Museum has a collection of warbirds from WWII to Dessert Storm. They also have a Wright Flyer replica, an original 1911 Steco biplane plus many other exhibits. There was a Swift, an Ercoupe, a Luscombe T8-F plus a lot of other vintage airplanes, warbirds and the usual later model airplanes at last year's event. There will be a Hangar Dance Saturday evening with the Sights and Sounds of Dave Andrews Big Band. This has been a lot of fun for everyone that attended in past years. More can be found at www.eaachapter237.org Thank you, Lyle Peterson President, EAA Chapter 237 ________________________________________________________________________________
Date: May 05, 2007
Boy! I never had anything like that! Mine ran like a trooper. Maybe it was because it was the transition car between the two and the three. Also the steering was great on mine. I could drift it like there was no tomorrow. The Healey was the one to break loose on the front. I hated that! It just felt wrong. Only two things marred our comanionship. The battery went bad and one day. I had to start the thing with the crank in order to get to work. Then the head gasket blew. It required two gasket sets to repair it as that engine was half the old two and half the new three! ( 1956 I think) It was still going strong when I had to sell it. By the way,you know that the entire windshield assembly was removable for racing by backing off two large screws, right? I wonder if that's the appeal of the Piet? There's a lot of similarities. Both built like a brick you-know-what, both require attention to drive/fly, same fun- factor. After all this time I finally acquired a 3" micrometer and checked my best looking Corvair crank. The bearings are right in the middle of specs for a brand new one! Smooth too. That's made me a happy camper. :-) Clif I've had two cars with wire wheels, a TR-2/3 Hey Clif, I had a TR3 when I was 17 - 19 yrs old. Man, was that a fun car to drive. I always had 2 or 3 passengers with me, in case we had to push the car somewhere. Never had to open the door...just hop over and into the seat. Plenty of power, too. That was the first engine I rebuilt from start to finish. I won $100 dollars in a twisting road race with an Opel Cadet...blew 'im away. I was always racing somebody. That was the only car I know of, that in a hard corner, the front wheels would slide before the back ones Chuck G. NX770CG ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: May 06, 2007
Hot Dog! At least we'll have one flying Piet and another that is recognizable parts. Tom > When Pigs Fly nationally rated BBQ contest and Fly in. This year the event > will be on August 24-25 > Hey Tom, > I just put it down on my calender . See ya there (if not sooner). > Chuck G. > NX770CG ____ | ____ \8/ / \ ________________________________________________________________________________
Date: May 07, 2007
Subject: Throttle control question
I plan on making the standard "swinging pendulum" type throttle levers in my Piet that most people use. Figure that will connect the back lever to the front with a rod threaded on both ends with screwed on fork ends. My question is what is the best way to go from the front lever to the carb? After going through three years of Broadhead pictures I realized I have taken no front cockpit pictures including front throttle linkage, its so unexciting normally compared to the average rear cockpit. Thanks Rick -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Date: May 07, 2007
I ran a standard Bowden cable from my front throttle to the throttle on the carburetor. Not entirely satisfactory - there is a LOT of friction due to the major bends in the cable, going from the extreme left side of the airplane to the carb close to the airplane centerline. As I recall, I had a couple of near 90 degree bends, I would recommend as gentle a bend as possible to reduce friction. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, May 07, 2007 10:23 AM Subject: Pietenpol-List: Throttle control question I plan on making the standard "swinging pendulum" type throttle levers in my Piet that most people use. Figure that will connect the back lever to the front with a rod threaded on both ends with screwed on fork ends. My question is what is the best way to go from the front lever to the carb? After going through three years of Broadhead pictures I realized I have taken no front cockpit pictures including front throttle linkage, its so unexciting normally compared to the average rear cockpit. Thanks Rick -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Date: May 07, 2007
Subject: Re: Throttle control question
Good question Rick, as I am also interested in learning this. If I may expand on your topic. I wonder if fastening the levers to the longeron (or another block below the longeron) using wood screws is the standard method for fastening? 1. type of cable or linkage to the carb and how to fasten it 2. how to safely attach the throttle levers to the fuselage john -still kind of chilly in Wisconsin- Rick Holland wrote: I plan on making the standard "swinging pendulum" type throttle levers in my Piet that most people use. Figure that will connect the back lever to the front with a rod threaded on both ends with screwed on fork ends. My question is what is the best way to go from the front lever to the carb? After going through three years of Broadhead pictures I realized I have taken no front cockpit pictures including front throttle linkage, its so unexciting normally compared to the average rear cockpit. Thanks Rick -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado --------------------------------- Don't be flakey. Get Yahoo! Mail for Mobile and always stay connected to friends. ________________________________________________________________________________
Date: May 07, 2007
Thanks for the pics Harvey!! Jack Phillips, I read that you put the brackets on the longerons behind the gussets. Is that correct? do you use the horizontal and vertical bolts? Dan Helsper, I can't see the vertical bolts in those brackets. You will put them later? Thanks! Santiago --------------------------------- Pregunt. Respond. Descubr. Todo lo que queras saber, y lo que ni imaginabas, est en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: May 07, 2007
Subject: Re: Tailwheel bracket
Santiago, I must have missed seeing vertical bolts in that bracket. I don't remember seeing them on my 1933 plans. Are they there? Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 07, 2007
41CC uses a single run of Bowden cable all the way... the center wire is continuous from pilot's control all the way to the carb, but the outside jacket/sleeve is interrupted for the front cockpit throttle "lever" (actually just a spool knob secured to the center wire). Simple and effective. If I were to redo the setup I would change the position of the knob in the front cockpit since it's a bit too far aft to get to comfortably, but then again it's only rarely used up there and you really don't want passengers fiddling with it anyway. There is friction drag on the setup but I like it that way... the throttle does not creep in cruise flight and it requires thought and action to move the throttle without resorting to a friction clamping screw or a vernier setup. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Download Messenger. Join the im Initiative. Help make a difference today. http://im.live.com/messenger/im/home/?source=TAGHM_APR07 ________________________________________________________________________________
Date: May 07, 2007
Tim, I think in your pictures from last year, the 'Pitts' is a Skybolt and your 'stinson' is a luscombe silvaire. Steve E Low and Slow Since 1929 Pietenpol Aircamper steve(at)byu.edu From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tom Stinemetze Sent: Friday, May 04, 2007 8:25 PM Subject: Pietenpol-List: While You're Making Flying Weather Plans For those of you close enough to McPherson, Kansas to think about flying here, don't forget the annual When Pigs Fly nationally rated BBQ contest and Fly in. This year the event will be on August 24-25 and it would sure be great to have a few Air Campers and/or Sky Scout's here on the ramp. The food is great, lots of other activities will be going on (weather permitting) and I, for one, will ensure that any Pietenpol birds get prime space on the ramp. More info at: http://www.eaa1344.com/ Tom Stinemetze The Airplane Nut ____ | ____ \8/ / \ ________________________________________________________________________________
Date: May 07, 2007
Santiago, On my Pietenpol, I used only two AN3 (3/16") bolts, placed horizontally in the lower longeron, for each bracket. I did not use vertical bolts in order to avoid having too many holes through the longeron. The lower tabs simply rest against the lower longeron surface and serve to stabilize the fitting. Instead of separate bolts for the forward end of the vee-type yoke, I used a single long 1/4" pivot bolt made from steel drill rod. And the yoke vee has a 1/2" x .035' tube crosspiece located about 2" back from the pivot bolt. This crosspiece was an early modification that really stiiffened the yoke and enabled me to use the single long bolt without a spacer. This setup has been entirely satisfactory during literally thousands of flights from rough fields. I wouldn't change it if I were to build another Pietenpol. Graham Hansen Pietenpol CF-AUN Camrose, Alberta, Canada ________________________________________________________________________________
Date: May 07, 2007
Subject: [ Dan Helsper ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Dan Helsper Lists: Pietenpol-List Subject: Interchangeable Tail Skit/Tailwheel - No Tools Required... http://www.matronics.com/photoshare/HelsperSew@aol.com.05.07.2007/index.html ---------------------------------------------------------- o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ---------------------------------------------------------- ________________________________________________________________________________
Date: May 07, 2007
Hi you, I am building a Piet in Lagrange, Ga., and would be more than willing to share info with you. Gardiner Mason ----- Original Message ----- From: AMsafetyC(at)aol.com To: pietenpol-list(at)matronics.com Sent: Thursday, May 03, 2007 7:32 PM Subject: Pietenpol-List: Going South again Hi all, On the road again to the Carolinas from Charlotte NC to the GA line on I 85. During my travels I would like to meet up with other Piet owners and or builders to check out projects flying and non. Anyone in that area willing to share some Piet time please let me know, I would appreciate a meet and greet evening if and where possible. Please let me know if you're interested! Thanks John ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: May 07, 2007
Looks like I'm going to have to sell my Piet Graham.With the high cost of the hanger rent at 250.00/mo., the cost of gas and repairs to my Malibou car I've run up against a wall.I figure she's worth $19500.00 cnd.So if any body on this list is interested contact me by personal email Harvey.rule(at)bell.ca thanks.I hate to sell her but I can't see the light at the end of the tunnel anymore. I figure I'll keep the N3 Pup since it can sit it outside and I won't need a hanger and she is also great for winter flying which as you know,the Piet, isn't so great.If I don't see a response from you guys then I'll put her up for sale in the COPA and Barnstormers.I figured I'd give you guys first shot at it. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham Hansen Sent: May 7, 2007 1:20 PM Subject: Re: Pietenpol-List: Tailwheel bracket Santiago, On my Pietenpol, I used only two AN3 (3/16") bolts, placed horizontally in the lower longeron, for each bracket. I did not use vertical bolts in order to avoid having too many holes through the longeron. The lower tabs simply rest against the lower longeron surface and serve to stabilize the fitting. Instead of separate bolts for the forward end of the vee-type yoke, I used a single long 1/4" pivot bolt made from steel drill rod. And the yoke vee has a 1/2" x .035' tube crosspiece located about 2" back from the pivot bolt. This crosspiece was an early modification that really stiiffened the yoke and enabled me to use the single long bolt without a spacer. This setup has been entirely satisfactory during literally thousands of flights from rough fields. I wouldn't change it if I were to build another Pietenpol. Graham Hansen Pietenpol CF-AUN Camrose, Alberta, Canada ________________________________________________________________________________
Date: May 07, 2007
In a message dated 5/7/2007 9:24:32 AM Central Daylight Time, at7000ft(at)gmail.com writes: I plan on making the standard "swinging pendulum" type throttle levers in my Piet that most people use. Figure that will connect the back lever to the front with a rod threaded on both ends with screwed on fork ends. My question is what is the best way to go from the front lever to the carb? After going through three years of Broadhead pictures I realized I have taken no front cockpit pictures including front throttle linkage, its so unexciting normally compared to the average rear cockpit. Thanks Rick It took me three tries, before I found a suitable method to mount the power lever in the aft cockpit. Doug B. mounted it 'per plans', and it was just too uncomfortably hard for me to manage, because my for arm was too long, and I had to bend my wrist a lot just to get to it. You guys have never met a 'Purist' till you met Doug. He said "Well, you're just going to have to have surgery to your left for arm, and have it shortened by about 4". Having found out the surgery was going to cost more than the whole Pietenpol project, he agreed we should move the throttle handle, and moved it forward several inches. That still didn't feel right. I finally found the best way was to mount it horizontally, under the instrument panel, so the handle was in a similar location close to the left longeron. I use a bolt / castle nut / washer to adjust friction. I bought a used J3 cub throttle cable to go from the carb, and conveniently ended under the front panel. I use a 3/8" X .035" tube, flattened at both ends, to connect the J3 throttle cable to the throttle handle. The 3/8" tube slides through an oversized Adel clamp that is mounted to the bottom of the front panel. I have another pair of Adel clamps mounted tight on the 3/8 tube, for the throttle handle for the front cockpit. Works good, no problems, and I saved about $35,000 dollars not having the surgery. Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 07, 2007
Thanks Chuck, do you have and pictures? I know I have taken pictures of your Piet at Broadhead but nothing with your throttle controls. Rick On 5/7/07, Rcaprd(at)aol.com wrote: > > In a message dated 5/7/2007 9:24:32 AM Central Daylight Time, > at7000ft(at)gmail.com writes: > > I plan on making the standard "swinging pendulum" type throttle levers in > my Piet that most people use. Figure that will connect the back lever to the > front with a rod threaded on both ends with screwed on fork ends. My > question is what is the best way to go from the front lever to the carb? > After going through three years of Broadhead pictures I realized I have > taken no front cockpit pictures including front throttle linkage, its so > unexciting normally compared to the average rear cockpit. > > Thanks > > Rick > > It took me three tries, before I found a suitable method to mount the > power lever in the aft cockpit. Doug B. mounted it 'per plans', and it was > just too uncomfortably hard for me to manage, because my for arm was too > long, and I had to bend my wrist a lot just to get to it. You guys have > never met a 'Purist' till you met Doug. He said "Well, you're just going to > have to have surgery to your left for arm, and have it shortened by about > 4". Having found out the surgery was going to cost more than the whole > Pietenpol project, he agreed we should move the throttle handle, and moved > it forward several inches. That still didn't feel right. I finally found > the best way was to mount it horizontally, under the instrument panel, so > the handle was in a similar location close to the left longeron. I use a > bolt / castle nut / washer to adjust friction. I bought a used J3 cub > throttle cable to go from the carb, and conveniently ended under the front > panel. I use a 3/8" X .035" tube, flattened at both ends, to connect the J3 > throttle cable to the throttle handle. The 3/8" tube slides through an > oversized Adel clamp that is mounted to the bottom of the front panel. I > have another pair of Adel clamps mounted tight on the 3/8 tube, for the > throttle handle for the front cockpit. Works good, no problems, and I saved > about $35,000 dollars not having the surgery. > > Chuck G. > NX770CG > > > ------------------------------ > See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503>. > > > * > > > * > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Date: May 07, 2007
That's about as simple a solution as I can imagine Oscar (which usually means its a good solution), I assume you clamped the cable housing under the front and rear cockpits? Rick On 5/7/07, Oscar Zuniga wrote: > > taildrags(at)hotmail.com> > > 41CC uses a single run of Bowden cable all the way... the center wire is > continuous from pilot's control all the way to the carb, but the outside > jacket/sleeve is interrupted for the front cockpit throttle "lever" > (actually just a spool knob secured to the center wire). Simple and > effective. If I were to redo the setup I would change the position of the > knob in the front cockpit since it's a bit too far aft to get to > comfortably, but then again it's only rarely used up there and you really > don't want passengers fiddling with it anyway. > > There is friction drag on the setup but I like it that way... the throttle > does not creep in cruise flight and it requires thought and action to move > the throttle without resorting to a friction clamping screw or a vernier > setup. > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > Download Messenger. Join the i'm Initiative. Help make a difference today. > http://im.live.com/messenger/im/home/?source=TAGHM_APR07 > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Date: May 08, 2007
Rick asked- >I assume you clamped the cable housing under the front and rear cockpits? Yes, it's clamped in both locations, with more than one clamp. I've left it exactly as Corky set it up but may rework it next winter when things get slow again. For a setup that uses rods and bellcranks all the way from throttle to carb, completely 'hard' linkages all the way from end to end, there are pictures of Ernie Moreno's Piet setup here: http://www.flysquirrel.net/piets/piets2.html showing the linkages as the rod passes through the firewall, and then the 'cockpits' page showing how the quadrants are set up and connected together, http://www.flysquirrel.net/piets/piets3.html Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Catch suspicious messages before you open themwith Windows Live Hotmail. ________________________________________________________________________________
Date: May 08, 2007
Oscar Question about your front rudder petals, looking at your pictures, do you have a cable or a solid rod running between your front and back rudder petals? If a cable is that a spring running from the front petal to the firewall? I am asking because I was thinking of using springs. Rick On 5/8/07, Oscar Zuniga wrote: > > taildrags(at)hotmail.com> > > Rick asked- > > >I assume you clamped the cable housing under the front and rear cockpits ? > > Yes, it's clamped in both locations, with more than one clamp. I've left > it > exactly as Corky set it up but may rework it next winter when things get > slow again. > > For a setup that uses rods and bellcranks all the way from throttle to > carb, > completely 'hard' linkages all the way from end to end, there are picture s > > of Ernie Moreno's Piet setup here: > > http://www.flysquirrel.net/piets/piets2.html showing the linkages as the > rod > passes through the firewall, and then the 'cockpits' page showing how the > quadrants are set up and connected together, > http://www.flysquirrel.net/piets/piets3.html > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > _________________________________________________________________ > Catch suspicious messages before you open them=97with Windows Live Hotmai l. > > =========== =========== =========== > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Subject: pedal return springs
Date: May 08, 2007
Rick- The pictures on my website that you're referring to are of Ernie Moreno's Piet, not mine, but to answer your question- it sure looks like there are pedal return springs on the pilot's pedals but I don't see any for the passenger pedals. Surely there are some there because the link between the front and rear pedals are 1/8" cables (the Nicopress sleeves are clearly visible). Without something to hold up the front pedals, they will simply flop over backwards the first time you steer them past the tip-over point. Dan Horton had a really clean and nifty pedal return spring setup on his replica Canuck/Jenny (Geo Metro power, I believe). I have some pictures of his setup somewhere; I'll try to dig them up because it was a very nice arrangement. He used circular springs rather than coil springs but it's hard to describe in words. Let me find the pix and scan them. On 41CC, the linkages between pilot's rudder bar and passenger's pedals are 4130 steel tubing (small diameter) with fork ends. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Now you can see troublebefore he arrives http://newlivehotmail.com/?ocid=TXT_TAGHM_migration_HM_viral_protection_0507 ________________________________________________________________________________
Date: May 08, 2007
In a message dated 5/7/2007 7:56:31 PM Central Daylight Time, at7000ft(at)gmail.com writes: Thanks Chuck, do you have and pictures? I know I have taken pictures of your Piet at Broadhead but nothing with your throttle controls. Rick Rick, I'll get some good pictures of the set up on Thursday of Friday. TFR in Wichita on Wednesday for Air Force One, so Bush can see the devistation in Greensburg KS. Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 09, 2007
Thanks Graham!! I don't like the idea of drilling cross holes in the longeron. Your experience is more than enough for me. Yes Dan, those bolts are on the 1933 plans, but for me it's not very clear. Don't worry, we can blame the young Hoopman : ) Saludos Santiago --------------------------------- Pregunt. Respond. Descubr. Todo lo que queras saber, y lo que ni imaginabas, est en Yahoo! Respuestas (Beta). ________________________________________________________________________________
Date: May 09, 2007
Santiago, Yes, I went home yesterday and saw those bolts on my plans. It seems like a lot of holes and bolts for the application. At most I might put a couple of wood screws in there. Dan Helsper Poplar Grove, IL. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 09, 2007
Oscar, On Ernie Moren's Piet, do you know why the cowl and the motor mount are both so long, and after the tail has been lightened, the plane is still tailheavy? Is Ernie himself quite heavy? As you know these CG issues are quite germane for me. Thanks, Tim in central TX -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: May 8, 2007 7:03 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Throttle control question > > >Rick asked- > >>I assume you clamped the cable housing under the front and rear cockpits? > >Yes, it's clamped in both locations, with more than one clamp. I've left it >exactly as Corky set it up but may rework it next winter when things get >slow again. > >For a setup that uses rods and bellcranks all the way from throttle to carb, >completely 'hard' linkages all the way from end to end, there are pictures >of Ernie Moreno's Piet setup here: > >http://www.flysquirrel.net/piets/piets2.html showing the linkages as the rod >passes through the firewall, and then the 'cockpits' page showing how the >quadrants are set up and connected together, >http://www.flysquirrel.net/piets/piets3.html > >Oscar Zuniga >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > >_________________________________________________________________ >Catch suspicious messages before you open themwith Windows Live Hotmail. > > ________________________________________________________________________________
From: "Richard and Kathryn Davis" <kbrooks(at)aptalaska.net>
Subject: Aileron control horns
Date: May 09, 2007
I am looking for a set of aileron horns would anyone have a extra set for sale. ________________________________________________________________________________
Date: May 10, 2007
I've scanned and uploaded a photo of Dan Horton's pedal return spring setup, at http://www.flysquirrel.net/piets/pedalspring.jpg You can see the spiral-type spring that holds the pedals in place and maintains tension on the rudder cables. I thought it was clean and clever. Also visible in the photo is Dan's heel brake setup. It isn't real clear in the photo but what he has are small heel brake arms that he fabricated from aluminum stock, with the braking force transferred from the brake arm to the actuator arm via a rod or tube that is concentric (inside) the rudder pedal pivot tube. That puts the brake cables all the way outboard, out of the way against the inside of the cockpit wall, with a straight shot down to the mechanical drum brakes. Not only did Dan's airplane win awards in its "Canuck/Jenny" configuration after he completed it, but it was again a show winner last year (I believe), also appearing in a feature story in Sport Aviation after Dan sold it and it was repainted and marked as a different airplane. Was it a Navy paint scheme? I'm over the hill now and don't remember too well ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Like the way Microsoft Office Outlook works? Youll love Windows Live Hotmail. ________________________________________________________________________________
Date: May 10, 2007
One other throttle control questions for anyone that has used the standard throttle lever hanging from the top longeron. Is it necessary to secure the bracket to the longeron with bolts and nuts or will two wood screws (maybe with a little epoxy on the threads) be enough? Thanks Rick On 5/7/07, Rick Holland wrote: > > I plan on making the standard "swinging pendulum" type throttle levers in > my Piet that most people use. Figure that will connect the back lever to the > front with a rod threaded on both ends with screwed on fork ends. My > question is what is the best way to go from the front lever to the carb? > After going through three years of Broadhead pictures I realized I have > taken no front cockpit pictures including front throttle linkage, its so > unexciting normally compared to the average rear cockpit. > > Thanks > > Rick > > -- > Rick Holland > ObjectAge Ltd. > Castle Rock, Colorado -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Date: May 10, 2007
Subject: Wing flying drag wires?
Hello All, Are the 1/8 X wires really needed inbetween the wing struts? Thanks --------------------------------- We won't tell. Get more on shows you hate to love (and love to hate): Yahoo! TV's Guilty Pleasures list. ________________________________________________________________________________
Date: May 10, 2007
Subject: Info needed on the 1/8 flying wires in between the wing
struts. Hello All, I need some info on the 1/8 flying wires. I need to know are they adjestable, and how are they attached? Thanks --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. ________________________________________________________________________________
Subject: aileron horns
Date: May 10, 2007
Would anyone have a spare set they would like to sell?? I am in desperate need of a pair ASAP Thanks ________________________________________________________________________________
Subject: Double posting
Date: May 10, 2007
Sorry for the double posting folks our postings kept coming back saying we couldn't post now here they are . Anyhow wishing all a great Thursday and all the moms out there a Happy Day Sunday Richard & Kathryn ________________________________________________________________________________
Subject: Re: Info needed on the 1/8 flying wires in between the
wing struts.
Date: May 10, 2007
Hi Gus, The 1/8" cables between the lift struts are adjustable with turnbuckles. On NX18235 the outboard ends are attached to the lift strut attach bolts using a cable pull. The inboard ends are attached to an eyebolt that also serves as one of the gear leg mounting bolts. Greg Cardinal Minneapolis ----- Original Message ----- From: gus notti To: pietenpol-list(at)matronics.com Sent: Thursday, May 10, 2007 2:47 PM Subject: Pietenpol-List: Info needed on the 1/8 flying wires in between the wing struts. Hello All, I need some info on the 1/8 flying wires. I need to know are they adjestable, and how are they attached? Thanks ------------------------------------------------------------------------- ----- Ahhh...imagining that irresistible "new car" smell? Check out new cars at Yahoo! Autos. ________________________________________________________________________________
From: "Steve Singleton" <slsingleton(at)cvalley.net>
Date: May 10, 2007
Sorry i'm so late saying thanks for the info on Hem fir. My email went down after i asked that question and i've been gone since Tuesday with my work. My little world was just shattered today when my daughter called and told me she had heard that the road was closed a few miles south of the airport at Carrollton MO where we keep our Champ. I thought no big deal because we are quite a ways from it. I got with the Opts manager at our office where i work out of and told them i needed to get home to check on my plane (I truck for a living) and they got me in this evening. I work in Kansas so it was about 9:30 this evening when i got to Carrollton. I could not believe it-I could'nt even get to the airport because of the high water. I'm guessing that there is 2 to 3 feet of water in the hanger. Words can not even begin to express the feelings i have now-disbelief to anger (at myself). This happened in 93 but was only supposed to happen every 500 years. I'm a half hour north of the airport but will go back tomorrow and try to find someone with a boat to take me out to the airport. Hopefully i can get it up on a makeshift stand to get the water out of it if it is that deep. I'm so emotionally down now that i have to taslk to someone and i know this group is the one to go to even if its only for moral support. Steve Singleton ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Friday, May 04, 2007 9:13 AM Subject: RE: Pietenpol-List: Hem fir Steve, Not sure, when you say 'Hem Fir", if you are referring to Western Hemlock. If that's what you mean, then it can be a suitable substitute for Sitka Spruce (almost identical density, with higher strength). Ask the lumberyard exactly what species they have on hand. Check the weblinks that Chris Tracy posted yesterday, and you'll see Western Hemlock listed in the charts. Go to the Matronics Archives, http://www.matronics.com/search/ and do a search in the Pietenpol Archive, using the word "hemlock". You should find enough reading to keep you busy for a couple of hours. As you read through, you'll see that at least one builder (Clif Dawson) has built almost his entire airframe using CAREFULLY SELECTED Western Hemlock. I can't recall the source, but I definitely remember reading that BHP built laminated spars from carefully selected lumberyard Hemlock. Bill C. ________________________________________________________________________________
Subject: Re: Wing flying drag wires?
Date: May 10, 2007
Gus Yes, the wires are VERY important. The vertical loads on the wing are supported by the two struts. The struts on a Pietenpol are parallel to each other. This configuration does not resist for and aft loads very well. The wires take the for and aft loads keeping the struts and wing from rotating front and back. They are only loaded in tension so wire works quite well and are lighter then tubing. See attached drawing for a pictorial description. The same explanation works for the cabain struts as well as the wing struts. Some designs, like a cub, angle the rear strut forward to do away with the wires and take the for and aft loads. This requires a very strong fitting where all the wing loads are concentrated. Mr. Pietenpol chose to divide the load into two thus making it safer for the light weight structure to carry the loads. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: gus notti To: pietenpol-list(at)matronics.com Sent: Thursday, May 10, 2007 10:51 AM Subject: Pietenpol-List: Wing flying drag wires? Hello All, Are the 1/8 X wires really needed inbetween the wing struts? Thanks ------------------------------------------------------------------------- ----- We won't tell. Get more on shows you hate to love (and love to hate): Yahoo! TV's Guilty Pleasures list. ________________________________________________________________________________
Date: May 11, 2007
Steve, Sorry to hear about flood. Really hope your plane is ok. I live in Tennessee and could be there in a day if you need help. Gene 731-584-3443 ________________________________________________________________________________
Subject: Another British Piet Takes Flight
Date: May 11, 2007
Looks like another Pietenpol showpiece has taken flight in the UK. I was just checking out the UK Pietenpol Club website, and saw this photo. http://www.pietenpolclub.co.uk/gallery/displayimage.php?album=56&pos= 4 Check out the workmanship on this plane - outstanding! For those on the list that put off building because they think they need to have a perfectly equipped shop before they can begin construction, check out this page that shows the progress of this plane six years ago: http://www.pietenpolclub.co.uk/builders/chrisandfransprogress.htm That looks even tighter than Chuck Gantzer's "in-house" building as seen in his DVD. I believe this plane was built by a husband/wife team (Chris and Fran Barley) over a 14 year period... that would make it a lot easier getting spousal approval for having a plane in the house. Bill C. ________________________________________________________________________________
Date: May 11, 2007
The wires also provide a safety factor in case a strut or strut fitting comes loose correct? Rick On 5/10/07, Catdesigns wrote: > > Gus > > Yes, the wires are VERY important. The vertical loads on the wing are > supported by the two struts. The struts on a Pietenpol are parallel to each > other. This configuration does not resist for and aft loads very > well. The wires take the for and aft loads keeping the struts and wing from > rotating front and back. They are only loaded in tension so wire works > quite well and are lighter then tubing. See attached drawing for a > pictorial description. The same explanation works for the cabain struts as > well as the wing struts. > > Some designs, like a cub, angle the rear strut forward to do away with the > wires and take the for and aft loads. This requires a very strong fitting > where all the wing loads are concentrated. Mr. Pietenpol chose to divide > the load into two thus making it safer for the light weight structure to > carry the loads. > > Chris Tracy > Sacramento, Ca > Website at http://www.Westcoastpiet.com > > ----- Original Message ----- > > *From:* gus notti > *To:* pietenpol-list(at)matronics.com > *Sent:* Thursday, May 10, 2007 10:51 AM > *Subject:* Pietenpol-List: Wing flying drag wires? > > Hello All, > > Are the 1/8 X wires really needed inbetween the wing struts? > > Thanks > > > ------------------------------ > We won't tell. Get more on shows you hate to love<http://us.rd.yahoo.com/evt=49980/*http://tv.yahoo.com/collections/265> > (and love to hate): Yahoo! TV's Guilty Pleasures list.<http://us.rd.yahoo.com/evt=49980/*http://tv.yahoo.com/collections/265> > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Date: May 11, 2007
Chris thank you very much, Do you know how tight they are supposrt to be? I'm thinking then need to be tight. Thanks Catdesigns wrote: Gus Yes, the wires are VERY important. The vertical loads on the wing are supported by the two struts. The struts on a Pietenpol are parallel to each other. This configuration does not resist for and aft loads very well. The wires take the for and aft loads keeping the struts and wing from rotating front and back. They are only loaded in tension so wire works quite well and are lighter then tubing. See attached drawing for a pictorial description. The same explanation works for the cabain struts as well as the wing struts. Some designs, like a cub, angle the rear strut forward to do away with the wires and take the for and aft loads. This requires a very strong fitting where all the wing loads are concentrated. Mr. Pietenpol chose to divide the load into two thus making it safer for the light weight structure to carry the loads. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: gus notti To: pietenpol-list(at)matronics.com Sent: Thursday, May 10, 2007 10:51 AM Subject: Pietenpol-List: Wing flying drag wires? Hello All, Are the 1/8 X wires really needed inbetween the wing struts? Thanks --------------------------------- We won't tell. Get more on shows you hate to love (and love to hate): Yahoo! TV's Guilty Pleasures list. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com --------------------------------- Finding fabulous fares is fun. Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains. ________________________________________________________________________________
Date: May 11, 2007
I'm sorry I do not know how tight as I have yet to finish my plane. Being in tension the wire should not need to be that tight. Just tight enough to take out the stretch. I believe that others have said they should have a dull twang sound when plucked. Not a sharp high tone. Mike Cuy Chuck G. and Jack P. will know better, as they have flying planes. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: gus notti To: pietenpol-list(at)matronics.com Sent: Friday, May 11, 2007 8:34 AM Subject: Re: Pietenpol-List: Wing flying drag wires? Chris thank you very much, Do you know how tight they are supposrt to be? I'm thinking then need to be tight. Thanks Catdesigns wrote: Gus Yes, the wires are VERY important. The vertical loads on the wing are supported by the two struts. The struts on a Pietenpol are parallel to each other. This configuration does not resist for and aft loads very well. The wires take the for and aft loads keeping the struts and wing from rotating front and back. They are only loaded in tension so wire works quite well and are lighter then tubing. See attached drawing for a pictorial description. The same explanation works for the cabain struts as well as the wing struts. Some designs, like a cub, angle the rear strut forward to do away with the wires and take the for and aft loads. This requires a very strong fitting where all the wing loads are concentrated. Mr. Pietenpol chose to divide the load into two thus making it safer for the light weight structure to carry the loads. Chris Tracy Sacramento, Ca Website at http://www.Westcoastpiet.com ----- Original Message ----- From: gus notti To: pietenpol-list(at)matronics.com Sent: Thursday, May 10, 2007 10:51 AM Subject: Pietenpol-List: Wing flying drag wires? Hello All, Are the 1/8 X wires really needed inbetween the wing struts? Thanks ------------------------------------------------------------------------- - We won't tell. Get more on shows you hate to love (and love to hate): Yahoo! TV's Guilty Pleasures list. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- ----- Finding fabulous fares is fun. Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains. ________________________________________________________________________________
Date: May 12, 2007
Subject: Where do I go?
My PPSEL license had been resting comfortably in my wallet for 41 years. Just today a friend showed me his new Sport Pilot card, which looks like my new digitalized drivers license. Where to go to get an up to date copy? Thanks Walt Evans NX140DL "No one ever learned anything by talking" ________________________________________________________________________________
Date: May 12, 2007
Subject: Re: Where do I go?
To replace your paper certificate with a plastic certificate, go to _http://www.faa.gov/licenses_certificates/airmen_certification/certificate_rep lacement/_ (http://www.faa.gov/licenses_certificates/airmen_certification/certificate_replacement/) and select the option to replace paper certificate. The FAA was charging two dollars for the plastic replacement but was free if the new certificate was issued based on the satisfactory completion of FAA practical test for a new license or rating, which would result in the issuance of a new certificate. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 12, 2007
In a message dated 5/12/2007 1:16:55 AM Central Daylight Time, catdesigns(at)comcast.net writes: I'm sorry I do not know how tight as I have yet to finish my plane. Being in tension the wire should not need to be that tight. Just tight enough to take out the stretch. I believe that others have said they should have a dull twang sound when plucked. Not a sharp high tone. Mike Cuy Chuck G. and Jack P. will know better, as they have flying planes. Chris Tracy That's right, Chris...a dull twang is what I end up with. Take all the slack out, then a little tighter (maybe a turn or two) with the turnbuckle. To a lesser extent, these cables can also be used for adjusting the washout....back one off, and tighten the other one up the same amount, then re-check the wing alignment - just don't forget to re-safety the turnbuckles. I also use nylon zip ties to seperate and secure the cables where they criss cross. A failure in any of the struts, or cables on the Piet, would most likely be catastrophic. Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 12, 2007
This is how I got mine replaced as well. Walt, they did not charge me as I was having my SS number replaced at the same time. I did this last Auguts. They gave me the nice plastic card for Pilot and another one for my A&P. -john- > To replace your paper certificate with a plastic certificate, go to > http://www.faa.gov/licenses_certificates/airmen_certification/certificate_repl > acement/ and select the option to replace paper certificate. The FAA was > charging two dollars for the plastic replacement but was free if the new > certificate was issued based on the satisfactory completion of FAA practical > test for a new license or rating, which would result in the issuance of a new > certificate. > > > > > See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . > > > > ________________________________________________________________________________
Subject: Felix back flying
Date: May 12, 2007
Well, about 9 months after I bought it I FINELY got to fly Felix the GN-1. The first flight this morning went great. Second flight this evening got windy as I was climbing out. Flew around for awhile and made a few approaches, one didn't seem too bad so I landed, really got lucky and the landing went fine. Skip skipgadd(at)earthlink.net EarthLink Revolves Around You. ________________________________________________________________________________
Subject: Re: Felix back flying
Date: May 12, 2007
Good goin, Skip. Nice to have you back among the flying. Dick N. ----- Original Message ----- From: Skip Gadd To: pietenpol-list Sent: Saturday, May 12, 2007 9:07 PM Subject: Pietenpol-List: Felix back flying Well, about 9 months after I bought it I FINELY got to fly Felix the GN-1. The first flight this morning went great. Second flight this evening got windy as I was climbing out. Flew around for awhile and made a few approaches, one didn't seem too bad so I landed, really got lucky and the landing went fine. Skip skipgadd(at)earthlink.net EarthLink Revolves Around You. ________________________________________________________________________________
Date: May 12, 2007
Walt, Just wait and it will come. The FAA is in the process of updating all licenses to the new format. Mike ----- Original Message ---- From: walt evans <waltdak(at)verizon.net> Sent: Saturday, May 12, 2007 12:07:27 PM Subject: Pietenpol-List: Where do I go? My PPSEL license had been resting comfortably in my wallet for 41 years. Just today a friend showed me his new Sport Pilot card, which looks like my new digitalized drivers license. Where to go to get an up to date copy? Thanks Walt Evans NX140DL "No one ever learned anything by talking" ________________________________________________________________________________
Date: May 13, 2007
Congratulations Skip! What all did you need to do to be flying again? I'm almost ready myself. Bought 502R in July and by December decided to to a complete rebuild of the A 65. It's been slow but hope to be airborn by the 20th of this month (my birthday). Gene By the way, that's a great photo. Very inspiring! ----- Original Message ----- From: Skip Gadd To: pietenpol-list Sent: Saturday, May 12, 2007 9:07 PM Subject: Pietenpol-List: Felix back flying Well, about 9 months after I bought it I FINELY got to fly Felix the GN-1. The first flight this morning went great. Second flight this evening got windy as I was climbing out. Flew around for awhile and made a few approaches, one didn't seem too bad so I landed, really got lucky and the landing went fine. Skip skipgadd(at)earthlink.net EarthLink Revolves Around You. ________________________________________________________________________________
Date: May 13, 2007
Congratulations, Skip !! Great news. Do you think you might make it to Brodhead this summer ? Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 13, 2007
Subject: Alcohol Anyone ?
I have been using about a 50 / 50 mix of AvGas and MoGas, but I always check for alcohol before I put the MoGas in the tank. Yesterday was the first time I found alcohol in the 91 octane Quick Trip gas. Here in Kansas, there is no requirement for the gas stations to state there is alcohol in the fuel. I guess Gov. Sebelius got her way. I'll be checking the other stations, but being in Kansas, I would suppose all the fuel out here has some corn in it...bummer. The way I check for alcohol is simple - I use the fuel sump tool. I measured the depth of fuel it will hold, and painted a mark at the 10% mark and 100% mark. Put water in it exactly to the 10% mark, then fill with fuel to the 100% mark. Put my thumb over it and shake it vigorously. If the water line increases, ya got alcohol. It didn't take much time before the alcohol reared it's ugly head, in fact there showed 3 distinct layers in the sump tool - most of the water in the bottom, then a milky layer about 1/4" thick was the alcohol and water mix, then the fuel on top the rest of the way up. Chuck G. NX770CG ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 13, 2007
Dick, Gene and Chuck, Thank you, It is good to be flying the Aircamper. I hope to fly it to Brodhead, if the weather is good and I get enough time in the plane before then. Gene, It is a long story involving living quarters, the plane itself didn't need much. I changed the tires, removed the smoke system and reinstalled the front controls and put in a fuel shut-off valve and the scat tube that pushes the air for carb heat. I got an impulse mag on ebay, but using the same procedure each time it starts ok, and may wait for the annual to install the new mag. Good luck on flying yours next weekend. I will tell Cinda you liked the picture. Skip ________________________________________________________________________________
Date: May 13, 2007
Skip, Great news! I was just wondering a few days ago how you made out with Felix. I hope you enjoy it! I really hope to see you at Brodhead with it. I plan to fly mine up. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=112671#112671 ________________________________________________________________________________
Date: May 13, 2007
Rick, I used the plans underhung lever. I mounted it just like the plans with screws into the longeron. Very secure. I ran a 3/16" steel rod from the lever forward to the front of the front cockpit. The rear end of the rod is threaded and a 10-32 fork is threaded onto it to attach to the lever. The forward end is also threaded and has a turnbuckle barrel threaded onto it. That has an eye terminal at the other end of the barrel that attaches to a flexible throttle cable that runs to the carb. The cable is an A-920 throttle cable I bought from Aircraft Spruce. A little pricy but worth it. This has solid ends that swivel a few degrees. Really a great thing when it comes to fitting the throttle. The front cockpit can control the throttle by sliding that steel rod. The turnbuckle allows some adjustment to get the "feel" right for the pilot's lever. The lever results in a natural feeling. I have long gangly arms so I did have to move it forward slightly more than whats shown on the plans. Seems to be very smooth operation. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=112674#112674 ________________________________________________________________________________
Date: May 13, 2007
Jolly good show, Skip! Glad to hear that you're back in the air. After a workday at the hangar on Saturday (with all the rains we've had, the grass and weeds are growing like crazy), I took care of some chores, sopped up some of the sweat and dust, and then took 41CC for a short hop. Not much of that rod showing out of the top of my fuel cap, so I didn't want to go very far, but the breeze was fair and the time was right. On rollout for takeoff, I had the same roughness and loss of power as last time but it went away as soon as I pulled carb heat so I backed off, taxied back to the numbers, pulled carb heat, and off we went at full power. Beautiful afternoon to be up, and the airplane was in top form. Made one of my best landings ever, and it was a good thing, too... the EAA Chapter 35 executive committee was scheduled to meet in just a few minutes so they were all outside the clubhouse, judging my landing. I didn't give 'em anything to deduct points for this time and the airplane sure did its part ;o) Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ PC Magazines 2007 editors choice for best Web mailaward-winning Windows Live Hotmail. ________________________________________________________________________________
Date: May 13, 2007
Don, Great, can't wait to see your ship in person, and you of course too. ;^) Skip > [Original Message] > From: Don Emch I plan to fly mine up. ________________________________________________________________________________
Date: May 13, 2007
Oscar, Thanks. On your carb heat, do you see any drop in rpm? On Felix and the Cheif in the next hangar with the same engine, we don't seem to get any drop on the ground. Only when the engine warms up after flying awhile, than we will see a slight drop. Skip > [Original Message] > From: Oscar Zuniga <taildrags(at)hotmail.com> > , pulled carb heat, and off we went at full power. ________________________________________________________________________________
Date: May 14, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinal.com>
Way to go, Skip! Great feeling, isn't it? Jack Phillips _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Skip Gadd Sent: Saturday, May 12, 2007 10:07 PM Subject: Pietenpol-List: Felix back flying Well, about 9 months after I bought it I FINELY got to fly Felix the GN-1. The first flight this morning went great. Second flight this evening got windy as I was climbing out. Flew around for awhile and made a few approaches, one didn't seem too bad so I landed, really got lucky and the landing went fine. Skip skipgadd(at)earthlink.net EarthLink Revolves Around You. _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary, or otherwise private information. If you have received it i n error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Subject: carb heat on 41CC
Date: May 14, 2007
To answer Skip's question (and a few other folks who asked), I've uploaded a couple of photos of the modified Aeronca heat muff setup that I have on 41CC, to my website- http://www.flysquirrel.net/piets/engine/carbheat.html It works well, giving me 100-150 RPM drop on application of heat. I suppose I could instrument the carb air inlet and measure temperatures before and after application of carb heat, but we're living in the 1930s here and I wouldn't want to offend Mr. Pietenpol's sensibilities by throwing digital electronics into the mix ;o) The setup works. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ More photos, more messages, more storageget 2GB with Windows Live Hotmail. ________________________________________________________________________________
Date: May 14, 2007
Jack, Thanks. The first flight was really great. The second flight, it was really great to get back on the ground. ;) Skip ----- Original Message ----- From: Phillips, Jack Sent: 5/14/2007 7:27:35 AM Subject: RE: Pietenpol-List: Felix back flying Way to go, Skip! Great feeling, isn't it? Jack Phillips ________________________________________________________________________________
Date: May 14, 2007
Subject: MID-ATLANTIC FLY-IN
I HOPE THAT ALL WHO ARE CLOSE BY COME TO LUMBERTON NC ON I-95. FLY OR DRIVE TO THE MID-ATLANTIC FLY-IN MAY 18,19 & 20. SURE WOULD LOVE TO SEE A COUPLE OF PIETENPOLS THERE. IT WOULD MAKE MY GOING WORTHWHILE AS I'M SURE OTHERS WOULD LOVE TO SEE A REAL AIRPLANE FOR A CHANGE. HOPE TO SEE YOU THERE TED STONE PIET BUILDER, I NEED ALL THE INSPIRATION I CAN GET ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 15, 2007
Rick, I was out flying last night and realized my throttle "rod" is not 3/16" like I said. It's actually 1/4" with forks at each end. The forward end attaches to the turnbuckle. As it passes through the front cockpit I have a hardwood block that it goes through as a guide. I have a leather washer at the mounting point of the under slung throttle. This allows for smoother operation. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=113013#113013 ________________________________________________________________________________
Subject: Chet Peek's book "The Pietenpol Story"
Date: May 15, 2007
I just thought I would let everyone know there is now an "official" website for all of Chet Peek's books, including "The Pietenpol Story". In case you haven't heard of it, it is a great book, anyone remotely interested in AirCampers should read it. The address is: http://www.threepeakspub.com Steve Ruse Norman, OK -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Steve Ruse Sent: Wednesday, October 11, 2006 10:51 PM Subject: Pietenpol-List: Chet Peek's book "The Pietenpol Story" Chet has received his book from the publisher, and is ready to start selling copies. Until the end of the year, he will be distributing the book himself, so the only way to get one is to e-mail him directly to order it. I will get my copy Thursday afternoon and can't wait. I'll be sure to post some thoughts on the book soon, I bet I'll have it read cover to cover in two to three days. His e-mail address is RBaron18(at)aol.com. I asked him today and he said he will be taking orders for the book by e-mail, so don't hesitate to send him an e-mail if you are interested. There are even a couple of pictures of my plane in the book, and a little bit of information on my plane and how I obtained it, so I'm particularly excited about the book. If you don't know who Chet Peek is, he is an "Aviation Historian", who knows plenty about aviation. He was in B-17s in WWII, and has plenty of hands-on restoration and flying experience. He restored and flew a Curtis Jenny which was actually for sale on Barnstormers recently. I'm sure he has forgotten more about airplanes than I will ever learn. His most well known book is "The Taylorcraft Story". He is currently building a Model A Pietenpol, he has the fuselage built and is nearly ready to run the engine. I've seen it in his garage, and the work he does is great. I can't wait to see the finished product, I'm sure it will be one of the nicest around. I hope to fly chase on its first flight. Steve Ruse Norman, OK -- -- ________________________________________________________________________________
Subject: Bartlesville Biplane Expo - Bartlesville, OK - June 1st
& 2nd
Date: May 15, 2007
I'm going to try to make it, I'm planning on heading up late Friday afternoon and returning late Saturday. Not sure where I'll stay yet, I may camp on-field if possible. The website says there are "limited bathing facilities on the airport". I'm still trying to figure out what "limited bathing facilities are". Is anyone else planning on going? Chuck G.? Jim M.? Jim, I hope you can make it, I feel like I've known you for a couple of years now, and we've never even met! http://www.biplaneexpo.com/ Steve Ruse Norman, OK ________________________________________________________________________________
Subject: Re: Bartlesville Biplane Expo - Bartlesville, OK - June
1st & 2nd
Date: May 16, 2007
Where is Bartlesville? I am just a few miles south of the Oklahoma border on I-35. Mike King GN-1 77MK Ponder, Texas ----- Original Message ----- From: Steve Ruse To: pietenpol-list(at)matronics.com Sent: Tuesday, May 15, 2007 9:40 PM Subject: Pietenpol-List: Bartlesville Biplane Expo - Bartlesville, OK - June 1st & 2nd I'm going to try to make it, I'm planning on heading up late Friday afternoon and returning late Saturday. Not sure where I'll stay yet, I may camp on-field if possible. The website says there are "limited bathing facilities on the airport". I'm still trying to figure out what "limited bathing facilities are". Is anyone else planning on going? Chuck G.? Jim M.? Jim, I hope you can make it, I feel like I've known you for a couple of years now, and we've never even met! http://www.biplaneexpo.com/ Steve Ruse Norman, OK ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: tailwheel
Date: May 16, 2007
Hi guys, What is the lightest tailwheel you have or have seen or can think of that would stand up to this application? Douwe ________________________________________________________________________________
Subject: Re: tailwheel
Date: May 16, 2007
Hi Douwe, How about a rollerblade wheel? Another option would be an idler roller from a clothes dryer. The rollers in a Sears / Kenmore dryer appear to be fairly stout. Greg C. ----- Original Message ----- From: Douwe Blumberg To: pietenpolgroup Sent: Wednesday, May 16, 2007 4:59 AM Subject: Pietenpol-List: tailwheel Hi guys, What is the lightest tailwheel you have or have seen or can think of that would stand up to this application? Douwe ________________________________________________________________________________
Date: May 16, 2007
No, I don't think I would use that but a journal bearinged Speed Queen/Huebsch drier rear drum roller may be strong enough or possibly the Maytag one. By the way, Maytag no longer exists as such. They've been bought by Whirlpool ( Inglis ). ----- Original Message ----- From: gcardinal To: pietenpol-list(at)matronics.com Sent: Wednesday, May 16, 2007 4:01 AM Subject: Re: Pietenpol-List: tailwheel Hi Douwe, How about a rollerblade wheel? Another option would be an idler roller from a clothes dryer. The rollers in a Sears / Kenmore dryer appear to be fairly stout. Greg C. ----- Original Message ----- From: Douwe Blumberg To: pietenpolgroup Sent: Wednesday, May 16, 2007 4:59 AM Subject: Pietenpol-List: tailwheel Hi guys, What is the lightest tailwheel you have or have seen or can think of that would stand up to this application? Douwe href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- ----- 5/16/2007 6:05 PM ________________________________________________________________________________
Subject: tailwheel
Date: May 17, 2007
Several years ago I saw hockey puck drilled out and set up as a tailwheel. It was in the Smith/Karner, Pietenpol hangar at Brodhead. It was on one of the Sky Scout projects there. Don't think ether project has flown yet. Skip ----- Original Message ----- From: Douwe Blumberg Sent: 5/16/2007 6:05:31 AM Subject: Pietenpol-List: tailwheel Hi guys, What is the lightest tailwheel you have or have seen or can think of that would stand up to this application? Douwe ________________________________________________________________________________
Date: May 17, 2007
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: N-number assistance.........
Members of the list: I recently logged onto the FAA's inquiry web page to research an N-number I would like to have on my Pietenpol. The n-number is 1963K. Upon further searching.....it comes back: This aircraft's registration status may not be suitable for operation. Please contact the Aircraft Registration Branch at 1-866-762-9434 for additional information. Upon further research I find this number registered to this company: --------------------------------- N1963K is Assigned Assigned/Registered Aircraft --> Aircraft Description Serial Number 4690 Type Registration Corporation Manufacturer Name LUSCOMBE Certificate Issue Date None Model 8A Status Revoked Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating Pending Number Change None Dealer No Date Change Authorized None Mode S Code 50300500 MFR Year 1947 Fractional Owner NO --------------------------------- Registered Owner Name INDEPENDENT DRILLING CO Street 1114 INSUROMEDIC City
April 18, 2007 - May 17, 2007
Pietenpol-Archive.digest.vol-fv
