Pietenpol-Archive.digest.vol-gc
September 10, 2007 - September 23, 2007
      www.textors.com <http://www.textors.com/> , under Piet Project towards
      the bottom of the page.  Have a good week!
      Jack Textor
      Des Moines
      www.textors.com
Subject: Continental A-75 cruise rpm question
Date: Sep 10, 2007
Ken; I have acquired an A75 that is being gone through right now so I'm learning about them. As I understand it, the main difference between the A65 and the A75 is that the 75 has a hole drilled in the rod big ends to increase the oil flow, allowing the higher RPM needed to get the additional HP. There is some vagueness as to whether the venturi size in the Stromberg carb needs to change as well, because the Continental service letter does not mention it for the A75. They do clearly show the 1-5/16" venturi needed for the C75 but it has increased displacement (larger bore) and develops its rated HP back down in a lower RPM range than the A75. My assumption is that the A75 should use the same 1-1/4" venturi as the A65. I guess what I'm saying is that if you operate your A75 at its rated RPM (full power at 2600 RPM, cruise at 2350), you should be getting rated HP and still be OK on lubrication. I noted from the engine specs that the C75's max and cruise RPM are the same... 2275. There is no substitute for cubic inches ;o) Be sure you check your mechanical tach with an optical one though. I found that the tach on 41CC was reading about 200 RPM high at cruise RPM, meaning that I was leaving power on the table some of the time. Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get a FREE small business Web site and more from Microsoft Office Live! ________________________________________________________________________________
Subject: Re: ELT Location
Date: Sep 10, 2007
Gardiner, The ground plane is the three green looking strips in the picture attached to my original post. They are 1" X 23" 13 thousands aluminum used in the 'made on site' gutter industry. The ground plane, com antenna and ELT antenna are all in the fuse behind the pilot. I don't see why your alum foil plan should not work, you can use the same ground plane for the ELT. Skip > > skip, can you tell me more about your ground plane and location? I am almost > ready to start covering.thanks, gardiner mason. ps I plan on putting an ant. > on top of of the turtle back headrest for my icom handheld. I was told that > I could line the fibreglass headrest with alum foil for the groundplane. > ________________________________________________________________________________
Subject: Aileron piano hinge
Date: Sep 10, 2007
Stellex Bandy is one manufacturer. I sent them an email a few years ago asking for their recommendation for lubrication of the hinges, but never heard anything back. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Leon Stefan Sent: Monday, September 10, 2007 3:20 AM Subject: Pietenpol-List: Aileron piano hinge Speaking of the piano hinge, does any one know where a guy can find the straight wire in .90 in a length longer than the standard 6 ft. hinge length? I want to bend the wire as shown in the AS&S catalog (Cessna hinge ) with a loop to go under a screw to keep it in place. AS&S, and WIX sell the hinge wire separate, but only in the same length as the hinge. ( 6ft. ) I don't want to shorten the hinge to reveal enough wire to do what I want to do, and don;t have the patience, skill, or desire (or eye sight ) to drill a tiny hole ti install a nearly microscopic cotter pin. The exposed wire also is a nice place to grab the wire and pull it out for easy removal of an aileron. Does any one know who manufactures these hinges, so that I may go directly to the source? Leon Stefan in Ks. ________________________________________________________________________________
Subject: Re: funny spars
Date: Sep 10, 2007
Brian, I've not started on my Sky Scout wing yet, but if you have any questions about the Scout, feel free to email either in or out of the group. Did I read you live in Jacksonville? I was born in Fernandina Beach and my grandparents lived there for many, many years. Terry Hall Ada, OK ----- Original Message ----- From: "Brian Kraut" <brian.kraut(at)engalt.com> Sent: Sunday, September 09, 2007 10:00 PM Subject: Pietenpol-List: funny spars > > > I have a very interresting Sky Scout project. The wings and tail were > removed and used on an Aircamper. A new tail was made, but not covered > yet. > New ribs are made for the Grega GN-1 wing. I guess I will call it a > GN-1/2 > when I am done. > > I got all of the ribs and the spar material with the project. The > original > Scout plans show spars that are 1" wide and 4 3/4" tall. Front and aft > spars are the same. The plans show most of the spar routed out on the > inside to give an I beam section that is 1" wide at the top and bottom and > 1/2" wide in the webs. Makes a lot of sense since you want the strength > on > the caps of the spars. The GN-1 spar plans show them being 1" thick > without > the routed out section at all. The rear spar location is moved aft in the > GN-1 so the rear spar is only 4 1/4" tall. > > For some reason that I don't understand the spar material I got is not 1" > thick, it is 3/4" thick although the ribs are still made for 1" thick > spars. > > What I am thinking of doing is running the spars I have through a planer > and > getting them down to 1/2" thick then laminating 1/4" X 3/4" webs on the > top > and bottom on both sides. That will give me the same I beam section as > shown on the plans. I will glue on vertical pieces at each rib location > and > will glue in plywood sections between the webs where the wing attach > fittings and the strut attach fittings go. This will give me every bit of > the strength of the original Sky Scout routed spar sections and likely > more. > > A few things I am considering is maybe keeping the 3/4" and just > laminating > 1/4" strips on one side to make it easier to build and stronger, but > heavier. Also thought of doing that just on the aft spar since it is > shorter on the GN-1 wing and would not be as strong in the I beam > configuration with the 1/2" web as the original taller scout spars are. > Then again, the rear spar does not carry near the load of the front spar > and > the taller spar in the original scout plans is probably overkill anyway. > > I am also thinking that maybe the full thickness spars like the Grega > plans > show would be best. Who knows, might want to build an aircamper fuselage > and move these wings and tail to it someday. Already happened on this > plane > once. Are the regular Aircamper original spars routed like the Scout were > or are they the full 1" thick? > > Thoughts? Suggestions? > > Anyone have any idea how many Gs the original aircamper wings are designed > for? > > Brian Kraut > Engineering Alternatives, Inc. > www.engalt.com > > > ________________________________________________________________________________
Subject: EAA - Big Piet Display and Fly-In this Saturday
Date: Sep 10, 2007
Jack Phillips, PF Beck, Jeff Boatright, All Piet Pilots If you want to spend the night, we have plenty of room. Barry Subject: EAA - Wings & Wheels Poster Please Fwd this poster to as many people as you can. Pancake Breakfast - 9am Young Eagles Flights - 9 till Noon Airplane and Cars on Display 9 till 4pm Free Chow Car Registration Free Dash Plaque for Participants (Car & Airplane) Good Food Live Entertainment (George Britt and others) Thanks Barry ________________________________________________________________________________
Date: Sep 10, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Wish I could be there. Maybe next year. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Barry Davis Sent: Monday, September 10, 2007 11:22 AM Subject: Pietenpol-List: EAA - Big Piet Display and Fly-In this Saturday Jack Phillips, PF Beck, Jeff Boatright, All Piet Pilots If you want to spend the night, we have plenty of room. Barry Subject: EAA - Wings & Wheels Poster Please Fwd this poster to as many people as you can. Pancake Breakfast - 9am Young Eagles Flights - 9 till Noon Airplane and Cars on Display 9 till 4pm Free Chow Car Registration Free Dash Plaque for Participants (Car & Airplane) Good Food Live Entertainment (George Britt and others) Thanks Barry _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Sep 10, 2007
Subject: Re: EAA - Big Piet Display and Fly-In this Saturday
Barry, I plan to attend with Piet and with classic car. Now THERE'S a trick. Is there grass to land on, and if so, which side of which runway? Also, do I get a "dash plaque" for both vehicles? :) >Jack Phillips, PF Beck, Jeff Boatright, All Piet Pilots > >If you want to spend the night, we have plenty of room. >Barry > >Subject: EAA - Wings & Wheels Poster > >Please Fwd this poster to as many people as you can. > >Pancake Breakfast - 9am >Young Eagles Flights - 9 till Noon >Airplane and Cars on Display 9 till 4pm >Free Chow Car Registration >Free Dash Plaque for Participants (Car & Airplane) >Good Food >Live Entertainment (George Britt and others) > >Thanks Barry -- _____________________________________________________________ Jeffrey H. Boatright, PhD Associate Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Sep 10, 2007
I'm a little confused here. My understanding is that a ground plane was only needed in the air, and that on the ground, the earth functions as a ground plane. When flying, the ground plane is a "substitute" for earth. That is why you can use a handheld radio on the ground without attaching a 24" diameter sheet of aluminum to the bottom of the radio...that would tend to get in the way. I don't plan on using my ELT in the air. Does it really need a ground plane? Thoughts? Steve Ruse Norman, OK Quoting Skip Gadd : > > Gardiner, The ground plane is the three green looking strips in the picture > attached to my original post. They are 1" X 23" 13 thousands aluminum used > in the 'made on site' gutter industry. The ground plane, com antenna and > ELT antenna are all in the fuse behind the pilot. I don't see why your alum > foil plan should not work, you can use the same ground plane for the ELT. > Skip > > >> >> skip, can you tell me more about your ground plane and location? I am > almost >> ready to start covering.thanks, gardiner mason. ps I plan on putting an > ant. >> on top of of the turtle back headrest for my icom handheld. I was told > that >> I could line the fibreglass headrest with alum foil for the groundplane. >> > > ________________________________________________________________________________
Subject: A-65 Falcon prop for sale from Sky Gypsy
Date: Sep 10, 2007
From: "Cuy, Michael D. (GRC-RXC0)[ASRC]" <michael.d.cuy(at)nasa.gov>
If interested please respond to Frank's phone numbers in ad below: Falcon 72x42, A-65 bolt pattern, good condition $690. 64 spoke 19" diameter clincher wire wheels, refinished with new bushings $500. Call Frank Pavliga @ (330)325-9570 office or (330)418-0070. ________________________________________________________________________________
Subject: tail surface ribs
Date: Sep 10, 2007
I was noticing that the ribs on the tail surfaces behind the spars are pretty flexible when you push them. I was thinking of putting some 3/8" square spruce spacers in to stiffen them up a bit and make them less easy to damage from hanger rash or people that don't know any better leaning on them. Shouldn't add more than a couple of ounces to the weight. Any thoughts? Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Subject: tail fittings
Date: Sep 10, 2007
The places where you bolt on the fittings on the tail surfaces for the brace wires, attachment brackets, etc. are recessed in from the covering about 3/16" because the rib material goes over those surfaces. My first thought would be that you would put plywood on the surfaces that the fittings attach to so that they are full height and the fittings would go over the covering. On the uncovered tail surfaces I have they are already varnished and there are slight indentions in the wood where the fittings were obviously bolted on previously making me think that the builder had intended on having the fittings under the covering with the tabs sticking out of slots cut in the covering and I guess the bolt heads covered over giving you an ugly bump. Is this really how other people do it or should there be plywood building up those surfaces, not to mention reinforcing the areas. Sorry for all the newby questions. If someone could point me to a good builders site with lots of pictures I could probably answer most of my questions myself. Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Sep 10, 2007
Exactly what I did with mine, except I used 1/4" x 1/2" blocks Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Brian Kraut Sent: Monday, September 10, 2007 4:38 PM Subject: Pietenpol-List: tail surface ribs --> I was noticing that the ribs on the tail surfaces behind the spars are pretty flexible when you push them. I was thinking of putting some 3/8" square spruce spacers in to stiffen them up a bit and make them less easy to damage from hanger rash or people that don't know any better leaning on them. Shouldn't add more than a couple of ounces to the weight. Any thoughts? Brian Kraut Engineering Alternatives, Inc. www.engalt.com _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Sep 10, 2007
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Brian, To answer one of your questions, Chris Tracy's site http://www.westcoastpiet.com/ is an outstanding resource. Jack Textor www.textors.com ________________________________________________________________________________
Date: Sep 10, 2007
Subject: Re: tail surface ribs
From: "Glenn W. Thomas" <glennthomas(at)flyingwood.com>
Will the fabric add some stiffness? ...at least enough that you don't need to worry about it without straying off the plans design? On Mon, September 10, 2007 3:38 pm, Brian Kraut wrote: > > > > I was noticing that the ribs on the tail surfaces behind the spars are > pretty flexible when you push them. I was thinking of putting some 3/8" > square spruce spacers in to stiffen them up a bit and make them less easy > to damage from hanger rash or people that don't know any better leaning on > them. Shouldn't add more than a couple of ounces to the weight. Any > thoughts? > > Brian Kraut > Engineering Alternatives, Inc. > www.engalt.com > > ________________________________________________________________________________
Subject: Re: tail fittings
Date: Sep 10, 2007
Brian, There are many Pietenpol projects on www.mykitplane.com. Terry Hall ----- Original Message ----- From: "Brian Kraut" <brian.kraut(at)engalt.com> Sent: Monday, September 10, 2007 3:41 PM Subject: Pietenpol-List: tail fittings > > > The places where you bolt on the fittings on the tail surfaces for the > brace > wires, attachment brackets, etc. are recessed in from the covering about > 3/16" because the rib material goes over those surfaces. > > My first thought would be that you would put plywood on the surfaces that > the fittings attach to so that they are full height and the fittings would > go over the covering. On the uncovered tail surfaces I have they are > already varnished and there are slight indentions in the wood where the > fittings were obviously bolted on previously making me think that the > builder had intended on having the fittings under the covering with the > tabs > sticking out of slots cut in the covering and I guess the bolt heads > covered > over giving you an ugly bump. Is this really how other people do it or > should there be plywood building up those surfaces, not to mention > reinforcing the areas. > > Sorry for all the newby questions. If someone could point me to a good > builders site with lots of pictures I could probably answer most of my > questions myself. > > Brian Kraut > Engineering Alternatives, Inc. > www.engalt.com > > > ________________________________________________________________________________
Date: Sep 10, 2007
Subject: Re: Continental A-75 cruise rpm question
There are some other differences in the A65 and A75 engines. I don't understand why, but the piston pins (wrist pins) are a smaller diameter for the A75 than the A65. This spec, as well as ALL the specs for these two engines are called out in the Continental Motors 'Overhaul Manual and Parts Catalog'. If you have one of these engines, this is a MUST HAVE catalog. Chuck G. NX770CG ________________________________________________________________________________
Date: Sep 10, 2007
Brian, There is No need to add blocks to stiffen up the ribs in the tail. I put the fittings for the cables Under the Fabric. _http://nx770cg.com/Unique.html_ (http://nx770cg.com/Unique.html) Chuck G. NX770CG ________________________________________________________________________________
Date: Sep 10, 2007
Steve All radio work better with a ground plane in the air or on the ground. My car radio has a ground plane because it has a plastic body. With a ground plane you double the range of your ELT. Dale > [Original Message] > From: Steve Ruse <steve(at)wotelectronics.com> > To: > Date: 9/10/2007 12:39:55 PM > Subject: Re: Pietenpol-List: ELT Location > > > I'm a little confused here. > > My understanding is that a ground plane was only needed in the air, > and that on the ground, the earth functions as a ground plane. When > flying, the ground plane is a "substitute" for earth. > > That is why you can use a handheld radio on the ground without > attaching a 24" diameter sheet of aluminum to the bottom of the > radio...that would tend to get in the way. > > I don't plan on using my ELT in the air. Does it really need a ground plane? > > Thoughts? > > Steve Ruse > Norman, OK > > Quoting Skip Gadd : > > > > > Gardiner, The ground plane is the three green looking strips in the picture > > attached to my original post. They are 1" X 23" 13 thousands aluminum used > > in the 'made on site' gutter industry. The ground plane, com antenna and > > ELT antenna are all in the fuse behind the pilot. I don't see why your alum > > foil plan should not work, you can use the same ground plane for the ELT. > > Skip > > > > > >> > >> skip, can you tell me more about your ground plane and location? I am > > almost > >> ready to start covering.thanks, gardiner mason. ps I plan on putting an > > ant. > >> on top of of the turtle back headrest for my icom handheld. I was told > > that > >> I could line the fibreglass headrest with alum foil for the groundplane. > >> > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 10, 2007
Subject: Re: Interesting Aviation stuff near Virginia Beach???
In a message dated 9/10/2007 1:06:17 AM Central Daylight Time, jim_markle(at)mindspring.com writes: I'm in Virginia Beach VA until Friday evening and wonder if anyone knows of any interesting aviation related things to see in the area? I was on the beach there one time, and saw a bikini with a pair of propellers on 'em !! Even with sun glasses on, the wife still knew what I was looking at, and I still got slapped !! ________________________________________________________________________________
Date: Sep 10, 2007
Just up the road in Richmond (right next to the airport) is the Virginia Avation Museum. A great place to spend 3 or 4 hours. Howdy ________________________________________________________________________________
Subject: Re: A-75 improved rate of climb
Date: Sep 11, 2007
Well, I haven't actually done a proper empirical test, but my seat-of-the-pants ROC guage tells me it's significantly improved. Loaded to near gross weight on a 90F afternoon with high humidity, she climbs about like she used to solo, well worth the $$ for the prop in terms of get me over that tree at the end of the runway value. First chance we get, my buddy with his C-85 powered Cub and I will square off in a proper rate of climb comparison. I'll bet I can give him a run for his money now :-) BTW, she gets a diet of 100LL and the recommended Marvel Mystery Oil. 100LL because I've had problems with alcohol and water in the local mogas, and the MMO because it can't hurt, and lots of folks with more experience than I swear by it. Dave Mordecai in buggy Panacea, FL NX520SF > Dave, > > I suspect that you'll get a lot of answers. I think that that as long > as you use top oil, change it often, and keep temps in range, then > you'll do fine at anything under redline even for long runs. > > How's your climb rate with the new prop? ________________________________________________________________________________
Subject: cut steel parts
Date: Sep 10, 2007
I need to get some .065 4130 steel flat parts cut. I don't have a lot of free time and I get a good deal on my friend's CNC turret punch so I am going to just draw them in CAD and have him punch them out. I was thinking that I might be able to sell some other punched parts to offset my setup cost some. Is there anyone already selling pre cut steel parts? Is there much demand for it? It is a particularly good method of doing things like the wing attach fittings where you need a bunch of them and you want all of the bolt holes in exactly the same place on all of them. For things like the 90 degree bent tail attach fittings you are better off just starting with strip stock, radiusing the corners, bending, then drilling the holes in place than having them punched and trying to bend them exactly the same and having the holes come out the same on the left and right sides. Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Subject: Corvair intake manifold (Bernie's design)
Date: Sep 10, 2007
Hello all, Had a fantastic weekend at the MAAC fly-in at Brodhead. My wife had never flown in a light airplane before, and through a confluence of coincidences she was able to take her first flight in "The Last Original" with the woman who used to own the airplane years ago, who is a friend as well. This was particularly perfect, as last month we received our own set of Piet plans, and we are going to use the Corvair. And her opinion of the flight: she loved it! Needless to say, I'm ecstatic. She was enthusiastic about it beforehand, but now she knows she likes it, so she is even more gung ho about building and flying our own Piet. I'm a lucky man. :) Many thanks to Bill Knight, who was gracious enough to allow her to go flying in his airplane. Later on he also allowed me to climb into the airplane and see how it fit, and I must say that I was pleasantly surprised that I was not cramped. I'm not extra tall (5'11"), however I'm not small (220, 44" chest). Reading some of the postings about cockpit width had me worried, thankfully for no reason. Anywho, on to my question.... I've been reading through the builders manual, and thinking about how we will convert our Corvair. I rather like the idea of sticking to Bernie's conversion. It's relatively simple, has thousands of flight proven hours. Plenty of time before we completely make a call on that. One of the things in the process I was wondering about was the design of the intake manifold. Bernard indicates that the intake manifold is jacketed, and engine oil is circulated through it in order to heat the manifold, and cool the oil. If it's not an utter bear to construct, it would seem to be a good way to heat the manifold to reduce the susceptibility to carb ice. Unfortunately there is no picture or drawing of this that I have found, and I do not know exactly how one would go about fabricating such a setup. Might anyone have an eye-witness description in a bit more detail, or better yet some photos? I wish we had been able to pop the cowling on the "Last Original" at Brodhead, but we didn't ask at the time because we did not want to be a bother with everything else that was going on. Maybe on the next trip up. Have a good evening everyone, Ryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=133851#133851 ________________________________________________________________________________
Date: Sep 11, 2007
I have a 75 cont and a beech roby variable pitch prop and could not get it to turn up to static rpms until I drill the main jet out two numbers higher. I think .057 on a marvel schebler carb. Just a thought. Ken in Iowa waiting for the corn to dry down. ________________________________________________________________________________
Date: Sep 11, 2007
Dave, what prop did you have and what prop did you go to? Gene ----- Original Message ----- > , well worth the $$ for the prop in terms of get me over that tree at the end of the runway value. > >> > > > -- > 5:43 PM > > ________________________________________________________________________________
Subject: Re: Corvair intake manifold (Bernie's design)
Date: Sep 11, 2007
Of course I would post this question last night, and after a few minutes this morning poking around I run across a picture looking into the rear of 899H's cowling: http://www.builddiary.net/images/logs/21/fullsize/IMG_0387.JPG Ok, now that I can see that, can someone take a look and confirm what I think I am seeing? There is a vertical tube behind the engine. It runs directly behind the chafe tape w/ zip-tie that is on the angled engine mount member. This would appear to me to be part of the intake manifold. As I follow it down I see it steps down in size, and then I can just make out what appears to be the carb flange, mostly hidden behind the horizontal engine mount member. The manual instructions say that the manifold is made of 1 1/2" OD steel tubing, and the jacket is made from 2" tubing. After viewing this pic, and reading that description again, my initial conclusion would be that he slipped the 2" tubing over the 1 1/2" tubing, cut circular "caps" to enclose the ends of the 2" tubing, and welded this all together. I would then guess that he would run oil through a fitting into and out of the jacket. I can barely make out what appears to be an oil line attaching to the top of the jacket on the side facing the camera, and another line running behind the jacket in roughly the same location. This all raises another question: would he run warm oil into, and take cool oil out of fittings that are both located at the top of the jacket? After the jacket is filled with oil I would think this would not promote circulation of the oil through the jacket long enough to do any good. In addition, why would those three copper tubing lines, assuming they are oil lines, need to be run to the firewall like that? I hope I'm not missing something completely obvious here. Any thoughts on the matter would be appreciated. Thanks, and have a good day, Ryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=133884#133884 ________________________________________________________________________________
From: "MICHAEL SILVIUS" <M.Silvius(at)worldnet.att.net>
Date: Sep 11, 2007
Ryan: If you are going to use a corvair engine spend the money and buy William Wynne's conversion manual for the engine. Many improvements since Bernard first used one as well as a good guide to witch engine year/model and the specifics on how to accomplish it. www.flycorvair.com to catch on to many of the idiosyncrasies of the corvair you may also want to read up on and lurk on the Crovaircraft list at: http://www.krnet.org/corvaircraft_inst.html Michael ----- Original Message ----- From: "rmueller23" <rmueller23(at)gmail.com> Sent: Monday, September 10, 2007 10:45 PM Subject: Pietenpol-List: Corvair intake manifold (Bernie's design) > > Hello all, > > Had a fantastic weekend at the MAAC fly-in at Brodhead. My wife had never flown in a light airplane before, and through a confluence of coincidences she was able to take her first flight in "The Last Original" with the woman who used to own the airplane years ago, who is a friend as well. This was particularly perfect, as last month we received our own set of Piet plans, and we are going to use the Corvair. And her opinion of the flight: she loved it! Needless to say, I'm ecstatic. She was enthusiastic about it beforehand, but now she knows she likes it, so she is even more gung ho about building and flying our own Piet. I'm a lucky man. :) Many thanks to Bill Knight, who was gracious enough to allow her to go flying in his airplane. Later on he also allowed me to climb into the airplane and see how it fit, and I must say that I was pleasantly surprised that I was not cramped. I'm not extra tall (5'11"), however I'm not small (220, 44" chest). Reading some of the postings ! > about cockpit width had me worried, thankfully for no reason. Anywho, on to my question.... > > I've been reading through the builders manual, and thinking about how we will convert our Corvair. I rather like the idea of sticking to Bernie's conversion. It's relatively simple, has thousands of flight proven hours. Plenty of time before we completely make a call on that. One of the things in the process I was wondering about was the design of the intake manifold. Bernard indicates that the intake manifold is jacketed, and engine oil is circulated through it in order to heat the manifold, and cool the oil. If it's not an utter bear to construct, it would seem to be a good way to heat the manifold to reduce the susceptibility to carb ice. > > Unfortunately there is no picture or drawing of this that I have found, and I do not know exactly how one would go about fabricating such a setup. Might anyone have an eye-witness description in a bit more detail, or better yet some photos? I wish we had been able to pop the cowling on the "Last Original" at Brodhead, but we didn't ask at the time because we did not want to be a bother with everything else that was going on. Maybe on the next trip up. > > Have a good evening everyone, > > Ryan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=133851#133851 > > ________________________________________________________________________________
Date: Sep 11, 2007
Subject: Re: cut steel parts
Brian, For what its worth, I just had all my metal done in CAD. I sent them out for laser cutting, out of 4130 stock. It should be interesting to see what I get back. I believe my quantities may be excessive so I expect a bunch of extra parts also. According to my guy there is a good chance my parts may be cut this week, I remain hopeful and excited to see them arrive. Then its off to be coated/painted I am not certain about that part of the process yet but I am looking at the alternatives. Not sure if anyone may be interested but figured not to offer my excess parts for sale until I get all my metal bent and finished counted and verified. I am sure there may be others interested in speeding up the metal process. Since I have all the CAD drawings on CD in the 2 formats I was considering making them available for sale as to off set the development costs of getting them done if anyone is interested? I saw some for sale at Broadhead also, not sure if they sold but was curious as to the paint coating needed for all the metal parts as the typical treatment. I am also considering powder coating them not sure which direction I will go. Obviously paint weighs less than powder coating, what is the general conscious for metal parts coatings? John ________________________________________________________________________________
Subject: interesting stuff near Virginia Beach
Date: Sep 11, 2007
>saw a bikini with a pair of propellers on 'em !! >the wife still knew what I was looking at, and I still got slapped !! You got slapped for looking at propellers? Imagine what might have happened if you had been checking out the empennage as well... Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Discover sweet stuff waiting for you at the Messenger Cafe. Claim your treat today! http://www.cafemessenger.com/info/info_sweetstuff.html?ocid=TXT_TAGHM_SeptHMtagline2 ________________________________________________________________________________
Date: Sep 11, 2007
Michael, Thanks for the advice. I do have a copy of the manual (borrowed from a friend to thumb through before I take it back when I go to pick up my core from him in two weeks). I'll order my own copy (and see how long it takes to show up) before we order parts, as I'll need to send in the disclaimer from the manual. We will follow his minimum recommendations for many aspects of the rebuild (forged pistons, ARP rod bolts, etc). I imagine we will buy a few parts from him, such as the oil pan, maybe the safety shaft. We're building a hand-prop motor, so we won't need his starter setup. I plan on keeping the alternator in the rear, so we won't need the brackets. Because we won't be using a front alternator, we have no need for the gold hub w/ the pulley groove that he sells. If I'm not going to need use the front pulley, then I do not want the prop hub being any longer than necessary (no need adding extra stress on the crank), so we'll stick to the Pietenpol design there as well. We'll fab our own exhaust, so on an so forth. I have been lurking for a bit on the Corvaircraft mailing list, and it is a very active and interesting source of information and opinion. Thanks, and have a good one, Ryan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=133897#133897 ________________________________________________________________________________
Date: Sep 11, 2007
Remember the comments about making certain parts a bit longer than called for in the plans. Mike Cuy and Chuck Gantzer both mention this in their videos and point out various locations where it makes a big difference in being able to fit bolts through the fittings and to work with the nuts on them. Parts like the wing strut attach fittings that stick out the bottom of the wings, if made to plans, put the attachment hardware right up against the fabric covering with no room to work. Lengthen them a bit, like these: http://www.flysquirrel.net/piets/P6210018.JPG Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Get a FREE small business Web site and more from Microsoft Office Live! ________________________________________________________________________________
Date: Sep 11, 2007
I am avoiding laser since it heats the metal and hardens the edges. The turret punch leaves some slight scallops on some curved edges, but then can e sanded out easily and the holes come out perfect. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of AMsafetyC(at)aol.com Sent: Tuesday, September 11, 2007 9:14 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: cut steel parts Brian, For what its worth, I just had all my metal done in CAD. I sent them out for laser cutting, out of 4130 stock. It should be interesting to see what I get back. I believe my quantities may be excessive so I expect a bunch of extra parts also. According to my guy there is a good chance my parts may be cut this week, I remain hopeful and excited to see them arrive. Then its off to be coated/painted I am not certain about that part of the process yet but I am looking at the alternatives. Not sure if anyone may be interested but figured not to offer my excess parts for sale until I get all my metal bent and finished counted and verified. I am sure there may be others interested in speeding up the metal process. Since I have all the CAD drawings on CD in the 2 formats I was considering making them available for sale as to off set the development costs of getting them done if anyone is interested? I saw some for sale at Broadhead also, not sure if they sold but was curious as to the paint coating needed for all the metal parts as the typical treatment. I am also considering powder coating them not sure which direction I will go. Obviously paint weighs less than powder coating, what is the general conscious for metal parts coatings? John ---------------------------------------------------------------------------- -- See what'set="_blank">Make AOL Your Homepage. ________________________________________________________________________________
Date: Sep 11, 2007
How about a water jet cut part? I don't think there is any heat involved in that type of cut. Also would a punch introduce stress in the metal? ----- Original Message ----- From: Brian Kraut To: pietenpol-list(at)matronics.com Sent: Tuesday, September 11, 2007 9:15 AM Subject: RE: Pietenpol-List: cut steel parts I am avoiding laser since it heats the metal and hardens the edges. The turret punch leaves some slight scallops on some curved edges, but then can e sanded out easily and the holes come out perfect. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of AMsafetyC(at)aol.com Sent: Tuesday, September 11, 2007 9:14 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: cut steel parts Brian, For what its worth, I just had all my metal done in CAD. I sent them out for laser cutting, out of 4130 stock. It should be interesting to see what I get back. I believe my quantities may be excessive so I expect a bunch of extra parts also. According to my guy there is a good chance my parts may be cut this week, I remain hopeful and excited to see them arrive. Then its off to be coated/painted I am not certain about that part of the process yet but I am looking at the alternatives. Not sure if anyone may be interested but figured not to offer my excess parts for sale until I get all my metal bent and finished counted and verified. I am sure there may be others interested in speeding up the metal process. Since I have all the CAD drawings on CD in the 2 formats I was considering making them available for sale as to off set the development costs of getting them done if anyone is interested? I saw some for sale at Broadhead also, not sure if they sold but was curious as to the paint coating needed for all the metal parts as the typical treatment. I am also considering powder coating them not sure which direction I will go. Obviously paint weighs less than powder coating, what is the general conscious for metal parts coatings? John ------------------------------------------------------------------------- --- See what'set="_blank">Make AOL Your Homepage. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 11, 2007
Unless I am missing a critical piece of information, laser cutting heat is concentrated and localized to the edges of the material. That means edges are harder and less prone to wear at the edge which could be a positive note when considering holes would be treated to prevent wear. Areas where hardened edges are not wanted or warranted can always be ground or filed off as I suspect the heat would be concentrated and localized to a small area which can be ground or filed off as needed. Not unless I am missing some critical piece of information, in which case please advise, (Piet Builder in training and learning new things daily). I think, I would prefer to file a little than cut a bunch, just my uneducated opinion for today and subject to change based upon a more pragmatic and empirical approach. Thanks John ________________________________________________________________________________
Subject: Sky Scout Tailskid
Date: Sep 11, 2007
Good morning, everyone. I thought that I would share a photo of my Sky Scout tailskid, built per the 1932 plans with 4130 tubing and a spring from one of local farm supply stores. My dad (A and P) did the welding. Terry Hall ----- Original Message ----- From: Mark Bratcher Sent: Tuesday, September 11, 2007 9:27 AM Subject: Photo scan ________________________________________________________________________________
Date: Sep 11, 2007
Mine looks very similar but has a small hard rubber wheel attached instead of a skid. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Terry Hall Sent: September 11, 2007 11:43 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Sky Scout Tailskid Good morning, everyone. I thought that I would share a photo of my Sky Scout tailskid, built per the 1932 plans with 4130 tubing and a spring from one of local farm supply stores. My dad (A and P) did the welding. Terry Hall ----- Original Message ----- From: Mark Bratcher To: Terry Hall Sent: Tuesday, September 11, 2007 9:27 AM Subject: Photo scan ________________________________________________________________________________
Date: Sep 11, 2007
Looks good, but I have to ask the obvious question. Do you plan on never flying off of a paved runway? I guess that if you wanted to keep the original skid and occasionaly fly off of a runway you could make yourself a bolt on full swivel wheel that can be removed. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Terry Hall Sent: Tuesday, September 11, 2007 11:43 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Sky Scout Tailskid Good morning, everyone. I thought that I would share a photo of my Sky Scout tailskid, built per the 1932 plans with 4130 tubing and a spring from one of local farm supply stores. My dad (A and P) did the welding. Terry Hall ----- Original Message ----- From: Mark Bratcher To: Terry Hall Sent: Tuesday, September 11, 2007 9:27 AM Subject: Photo scan ________________________________________________________________________________
Subject: Re: Sky Scout Tailskid
Date: Sep 11, 2007
Brian, If I ever fly it, my plan is to keep it on a grass strip or tow it to the grass. And, yes, I had thought of the removable swivel tailwheel. Terry ----- Original Message ----- From: Brian Kraut To: pietenpol-list(at)matronics.com Sent: Tuesday, September 11, 2007 11:40 AM Subject: RE: Pietenpol-List: Sky Scout Tailskid Looks good, but I have to ask the obvious question. Do you plan on never flying off of a paved runway? I guess that if you wanted to keep the original skid and occasionaly fly off of a runway you could make yourself a bolt on full swivel wheel that can be removed. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Terry Hall Sent: Tuesday, September 11, 2007 11:43 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Sky Scout Tailskid Good morning, everyone. I thought that I would share a photo of my Sky Scout tailskid, built per the 1932 plans with 4130 tubing and a spring from one of local farm supply stores. My dad (A and P) did the welding. Terry Hall ----- Original Message ----- From: Mark Bratcher To: Terry Hall Sent: Tuesday, September 11, 2007 9:27 AM Subject: Photo scan ________________________________________________________________________________
Date: Sep 11, 2007
Guys, Here are some pics of my removable tail wheel set-up. Westcoastpiet.com, under the name Dan Helsper. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Hillsboro, IL airport being sold and closed
Date: Sep 11, 2007
The following came to me last night from Ray who lives in Hillsboro and has a Mustang II. This is a small grass field airport with about ten planes based there. Phil in Litchfield ................................. I am writing to ask you to help us keep the Hillsboro Airport (3K4) open. The city council has in the space of a few days announced that they agreed to negotiate the sale of the airport property to a coal company, and that they will take action on the sale at Tuesday's council meeting at 7:00 pm, all with no discussion with the Airport Board, the hangar renters/aircraft owners on the field, or the public. Please take a couple of minutes to go to this link to the local newspaper site and vote anonymously in their online poll..... http://www.thejournal-news.net/news/ scroll down near the bottom, left side of page. Please vote NO only once, but feel free to forward this to any other aviation fans you know. We may not be successful, but I would like them to HEAR US. Maybe we can lock up the website........ Thanks for your support. Ray Dorf, Hillsboro Airport Board member Sorry about the short notice, I just learned about the poll a short time ago. ________________________________________________________________________________
Date: Sep 11, 2007
Subject: Re: Hillsboro, IL airport being sold and closed
Ray Be sure to contact the FAA. If they have accepted Federal money they may be obligated to keep it open. ________________________________________________________________________________
Date: Sep 11, 2007
In a message dated 9/11/2007 11:43:08 AM Central Daylight Time, brian.kraut(at)engalt.com writes: Looks good, but I have to ask the obvious question. Do you plan on never flying off of a paved runway? Brian, I've got quite a few hours logged with a tail skid...around 50 or 60 hrs. Very noisy, though...sounds like you're dragging a pop machine across rough concrete !! Over half of those hours was without brakes. During the first half of '03 I installed brakes, and flew to Brodhead / Oshkosh with the hydraulic heel brakes, and a tailskid. Take off on hard surface isn't too difficult in light wind conditions, because the rudder becomes effective as soon as some prop wash flows over the rudder. Landing on a hard surface with a tail skid is a totally different story. Not much propwash during the landing phase. Difficult to control the roll out with the brakes, because it kept tending to lift the tail back up each time I stabbed one of the heel brakes, to keep it straight. Two times, I ran off of a runway while landing (missing the runway lights) during that cross country trip from Wichita KS to Brodhead / Oshkosh. One of those landings was a pretty stiff crosswind. Taxiing on hard surface with a tailskid is difficult, at best, with any wind at all. However, keep the tailskid on the grass, and it poses no problem at all during taxi, on take off, or landing...with or without brakes...just gotta stay ahead of the plane !! Chuck G. NX770CG ________________________________________________________________________________
Subject: Re: High Speed Taxi
Date: Sep 11, 2007
Ben, I have had both the lifting of the right wing and abmornal pull to the right. I found the right brake was draging. After correcting that the plane still goes to the left a little more than I think it should, and I have the right wing come up also. As the tail is lifted the aircraft seems to feel as if you are on ice with little control. Once the tail wheel is back on the ground you have very good contorl again. Chet ----- Original Message ----- From: "Ben Charvet" <bcharvet(at)bellsouth.net> Sent: Sunday, September 09, 2007 7:31 PM Subject: Re: Pietenpol-List: High Speed Taxi > > Is it trying to lift the right wing, or just veering to the left? More > than the normal amount that you would correct with right rudder? > > Ben > Chet's Mail wrote: > >> Question to the group I have Don Hicks piet N920Y with the model A eng. >> While working my way up to take off speed by doing several taxi test, I >> find the aircraft keeps trying to pull to the left. >> I have several thousand hours of flight time and have owned two trail >> drager aircraft. But this one has a funny feel. >> I have the stright axle, with wire wheels. >> Any thoughts??? >> Thank you for your time Chet. >> >>* >> >> >>* >> > > > ________________________________________________________________________________
Date: Sep 11, 2007
Vi Kapler used to sell those intake manifolds like Mr.Pietenpol used to make. If Kirk Huizenga is still on the list, I believe he had one for sale some time back, might still. It is wrapped with an oil system to heat the intake manifold while cooling the oil. I believe Wm. Wynne has tried them and was not too impressed with their functionality, but you should call and ask him about them because I might be mistaken. Those lines could be oil pressure to a guage, oil temperature to a guage and primer to a pump to the manifold. dennis ----- Original Message ----- From: "rmueller23" <rmueller23(at)gmail.com> Sent: Monday, September 10, 2007 10:45 PM Subject: Pietenpol-List: Corvair intake manifold (Bernie's design) > > Hello all, > > Had a fantastic weekend at the MAAC fly-in at Brodhead. My wife had never flown in a light airplane before, and through a confluence of coincidences she was able to take her first flight in "The Last Original" with the woman who used to own the airplane years ago, who is a friend as well. This was particularly perfect, as last month we received our own set of Piet plans, and we are going to use the Corvair. And her opinion of the flight: she loved it! Needless to say, I'm ecstatic. She was enthusiastic about it beforehand, but now she knows she likes it, so she is even more gung ho about building and flying our own Piet. I'm a lucky man. :) Many thanks to Bill Knight, who was gracious enough to allow her to go flying in his airplane. Later on he also allowed me to climb into the airplane and see how it fit, and I must say that I was pleasantly surprised that I was not cramped. I'm not extra tall (5'11"), however I'm not small (220, 44" chest). Reading some of the postings ! > about cockpit width had me worried, thankfully for no reason. Anywho, on to my question.... > > I've been reading through the builders manual, and thinking about how we will convert our Corvair. I rather like the idea of sticking to Bernie's conversion. It's relatively simple, has thousands of flight proven hours. Plenty of time before we completely make a call on that. One of the things in the process I was wondering about was the design of the intake manifold. Bernard indicates that the intake manifold is jacketed, and engine oil is circulated through it in order to heat the manifold, and cool the oil. If it's not an utter bear to construct, it would seem to be a good way to heat the manifold to reduce the susceptibility to carb ice. > > Unfortunately there is no picture or drawing of this that I have found, and I do not know exactly how one would go about fabricating such a setup. Might anyone have an eye-witness description in a bit more detail, or better yet some photos? I wish we had been able to pop the cowling on the "Last Original" at Brodhead, but we didn't ask at the time because we did not want to be a bother with everything else that was going on. Maybe on the next trip up. > > Have a good evening everyone, > > Ryan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=133851#133851 > > ________________________________________________________________________________
Date: Sep 11, 2007
Dick, I have the same setup as you discribe, so I'll look into this and make the proper adjustment. This make sence to me as what could be my problem. I also have the tail hook for securing the aircraft while starting with the release cable that is also conected to the left tail wheel cable. I might have a second problem there. I do thank you for your input. Chet ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: Sunday, September 09, 2007 8:25 PM Subject: Re: Pietenpol-List: High Speed Taxi Chet I had the same problem with mine, a straight axle, wire wheels, but a A-65 engine. But first, a basic rule with the Piet is that EVERYTHING makes a diffrence. I had rudder cables that went from the rudder bar to a point behind the seat where I had joined them to the tailwheel, a "Y". When I would taxi and lift the tail, the plane immediatly would veere to the left. This caused me to run off the runway a couple of times. I found that the tailwheel springs were storing energy and when the tail lifted, the rudder would shift. I replaced the cables with dual cables from the rudder bar, problem solved. Dick N. ----- Original Message ----- From: Chet's Mail To: pietenpol-list(at)matronics.com Sent: Sunday, September 09, 2007 6:18 PM Subject: Pietenpol-List: High Speed Taxi Question to the group I have Don Hicks piet N920Y with the model A eng. While working my way up to take off speed by doing several taxi test, I find the aircraft keeps trying to pull to the left. I have several thousand hours of flight time and have owned two trail drager aircraft. But this one has a funny feel. I have the stright axle, with wire wheels. Any thoughts??? Thank you for your time Chet. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 11, 2007
Gene, I did have the draging brake but have fixed that. Also thought of the heat issue and check both side, both were cool after over 30 mins of taxi time. ----- Original Message ----- From: Gene & Tammy To: pietenpol-list(at)matronics.com Sent: Sunday, September 09, 2007 8:35 PM Subject: Re: Pietenpol-List: High Speed Taxi Almost sounds like you have a brake dragging. Might also want to check your hub for heat after a run. Gene ----- Original Message ----- From: Chet's Mail To: pietenpol-list(at)matronics.com Sent: Sunday, September 09, 2007 6:18 PM Subject: Pietenpol-List: High Speed Taxi Question to the group I have Don Hicks piet N920Y with the model A eng. While working my way up to take off speed by doing several taxi test, I find the aircraft keeps trying to pull to the left. I have several thousand hours of flight time and have owned two trail drager aircraft. But this one has a funny feel. I have the stright axle, with wire wheels. Any thoughts??? Thank you for your time Chet. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- --- Release Date: 9/9/2007 10:17 AM ________________________________________________________________________________
Date: Sep 11, 2007
Chet There is one more thing now that you mension the lifting of the right wing. Do you have gap seals on your elevators? The wider the gap, the more the effect. When I first started flying mine, the tail was hard to get up and right wing wanted to raise as it was going off to the left. Try some duct tape on the elevator gaps, it may be a huge difference. I had a 3/4" gap. Dick N. ----- Original Message ----- From: Chet's Mail To: pietenpol-list(at)matronics.com Sent: Tuesday, September 11, 2007 7:58 PM Subject: Re: Pietenpol-List: High Speed Taxi Dick, I have the same setup as you discribe, so I'll look into this and make the proper adjustment. This make sence to me as what could be my problem. I also have the tail hook for securing the aircraft while starting with the release cable that is also conected to the left tail wheel cable. I might have a second problem there. I do thank you for your input. Chet ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: Sunday, September 09, 2007 8:25 PM Subject: Re: Pietenpol-List: High Speed Taxi Chet I had the same problem with mine, a straight axle, wire wheels, but a A-65 engine. But first, a basic rule with the Piet is that EVERYTHING makes a diffrence. I had rudder cables that went from the rudder bar to a point behind the seat where I had joined them to the tailwheel, a "Y". When I would taxi and lift the tail, the plane immediatly would veere to the left. This caused me to run off the runway a couple of times. I found that the tailwheel springs were storing energy and when the tail lifted, the rudder would shift. I replaced the cables with dual cables from the rudder bar, problem solved. Dick N. ----- Original Message ----- From: Chet's Mail To: pietenpol-list(at)matronics.com Sent: Sunday, September 09, 2007 6:18 PM Subject: Pietenpol-List: High Speed Taxi Question to the group I have Don Hicks piet N920Y with the model A eng. While working my way up to take off speed by doing several taxi test, I find the aircraft keeps trying to pull to the left. I have several thousand hours of flight time and have owned two trail drager aircraft. But this one has a funny feel. I have the stright axle, with wire wheels. Any thoughts??? Thank you for your time Chet. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: neat tool
Date: Sep 11, 2007
I have been wrestling with my new 3 piece wing, trying to get it correctly aligned and to put in the proper washout on the tips. Today I stopped in Sears and found a level with a digital read out to the tenth of a degree. It also has a laser. I was able to fine tune the wings and the $50 was well worth it. Also, I had final airworhyness inspection on friday and passed. I'm hoping for first flight this weekend. Dick N. ________________________________________________________________________________
Date: Sep 11, 2007
Are your bungee cords tight enough? Maybe Jack or Mike will chime in and tell you the proper tightness. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: "Chet's Mail" <Chethartley1(at)mchsi.com> Sent: Tuesday, September 11, 2007 5:48 PM Subject: Re: Pietenpol-List: High Speed Taxi > > > Ben, > > I have had both the lifting of the right wing and abmornal pull to the > right. I found the right brake was draging. After correcting that the > plane still goes to the left a little more than I think it should, and I > have the right wing come up also. > > As the tail is lifted the aircraft seems to feel as if you are on ice with > little control. Once the tail wheel is back on the ground you have very > good contorl again. > > Chet > ----- Original Message ----- > From: "Ben Charvet" <bcharvet(at)bellsouth.net> > To: > Sent: Sunday, September 09, 2007 7:31 PM > Subject: Re: Pietenpol-List: High Speed Taxi > > >> >> >> Is it trying to lift the right wing, or just veering to the left? More >> than the normal amount that you would correct with right rudder? >> >> Ben >> Chet's Mail wrote: >> >>> Question to the group I have Don Hicks piet N920Y with the model A eng. >>> While working my way up to take off speed by doing several taxi test, I >>> find the aircraft keeps trying to pull to the left. >>> I have several thousand hours of flight time and have owned two trail >>> drager aircraft. But this one has a funny feel. >>> I have the stright axle, with wire wheels. >>> Any thoughts??? >>> Thank you for your time Chet. >>> >>>* >>> >>> >>>* >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 12, 2007
Chet, Almost sounds like your lifting the tail off the ground before your have enough speed to put enough air over the tail for control. Gene ----- Original Message ----- From: "Chet's Mail" <Chethartley1(at)mchsi.com> Sent: Tuesday, September 11, 2007 7:48 PM Subject: Re: Pietenpol-List: High Speed Taxi > > > Ben, > > I have had both the lifting of the right wing and abmornal pull to the > right. I found the right brake was draging. After correcting that the > plane still goes to the left a little more than I think it should, and I > have the right wing come up also. > > As the tail is lifted the aircraft seems to feel as if you are on ice with > little control. Once the tail wheel is back on the ground you have very > good contorl again. > > Chet > ----- Original Message ----- > From: "Ben Charvet" <bcharvet(at)bellsouth.net> > To: > Sent: Sunday, September 09, 2007 7:31 PM > Subject: Re: Pietenpol-List: High Speed Taxi > > >> >> >> Is it trying to lift the right wing, or just veering to the left? More >> than the normal amount that you would correct with right rudder? >> >> Ben >> Chet's Mail wrote: >> >>> Question to the group I have Don Hicks piet N920Y with the model A eng. >>> While working my way up to take off speed by doing several taxi test, I >>> find the aircraft keeps trying to pull to the left. >>> I have several thousand hours of flight time and have owned two trail >>> drager aircraft. But this one has a funny feel. >>> I have the stright axle, with wire wheels. >>> Any thoughts??? >>> Thank you for your time Chet. >>> >>>* >>> >>> >>>* >>> >> >> >> >> >> >> >> > > > -- > 269.13.15/1002 - Release Date: 9/11/2007 5:46 PM > > ________________________________________________________________________________
Subject: neat tool
Date: Sep 12, 2007
Great news, Dick. Let us know when you've flown her. Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Tuesday, September 11, 2007 9:20 PM Subject: Pietenpol-List: neat tool I have been wrestling with my new 3 piece wing, trying to get it correctly aligned and to put in the proper washout on the tips. Today I stopped in Sears and found a level with a digital read out to the tenth of a degree. It also has a laser. I was able to fine tune the wings and the $50 was well worth it. Also, I had final airworhyness inspection on friday and passed. I'm hoping for first flight this weekend. Dick N. _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Sep 12, 2007
AOPA has a program to help community airports. Perhaps that is a resource. Terry Hall ----- Original Message ----- From: Phil Sisson To: pietenpol-list(at)matronics.com Sent: Tuesday, September 11, 2007 3:44 PM Subject: Pietenpol-List: Hillsboro, IL airport being sold and closed The following came to me last night from Ray who lives in Hillsboro and has a Mustang II. This is a small grass field airport with about ten planes based there. Phil in Litchfield ................................. I am writing to ask you to help us keep the Hillsboro Airport (3K4) open. The city council has in the space of a few days announced that they agreed to negotiate the sale of the airport property to a coal company, and that they will take action on the sale at Tuesday's council meeting at 7:00 pm, all with no discussion with the Airport Board, the hangar renters/aircraft owners on the field, or the public. Please take a couple of minutes to go to this link to the local newspaper site and vote anonymously in their online poll..... http://www.thejournal-news.net/news/ scroll down near the bottom, left side of page. Please vote NO only once, but feel free to forward this to any other aviation fans you know. We may not be successful, but I would like them to HEAR US. Maybe we can lock up the website........ Thanks for your support. Ray Dorf, Hillsboro Airport Board member Sorry about the short notice, I just learned about the poll a short time ago. ________________________________________________________________________________
Date: Sep 12, 2007
This might relate to the discussion on spinning. It sounds like your rudder isn't real effective. Is there a chance it's being blanketed somehow? Jim Ash -----Original Message----- >From: Gene & Tammy <zharvey(at)bellsouth.net> >Sent: Sep 12, 2007 6:25 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: High Speed Taxi > > >Chet, Almost sounds like your lifting the tail off the ground before your >have enough speed to put enough air over the tail for control. >Gene >----- Original Message ----- >From: "Chet's Mail" <Chethartley1(at)mchsi.com> >To: >Sent: Tuesday, September 11, 2007 7:48 PM >Subject: Re: Pietenpol-List: High Speed Taxi > > >> >> >> Ben, >> >> I have had both the lifting of the right wing and abmornal pull to the >> right. I found the right brake was draging. After correcting that the >> plane still goes to the left a little more than I think it should, and I >> have the right wing come up also. >> >> As the tail is lifted the aircraft seems to feel as if you are on ice with >> little control. Once the tail wheel is back on the ground you have very >> good contorl again. >> >> Chet >> ----- Original Message ----- >> From: "Ben Charvet" <bcharvet(at)bellsouth.net> >> To: >> Sent: Sunday, September 09, 2007 7:31 PM >> Subject: Re: Pietenpol-List: High Speed Taxi >> >> >>> >>> >>> Is it trying to lift the right wing, or just veering to the left? More >>> than the normal amount that you would correct with right rudder? >>> >>> Ben >>> Chet's Mail wrote: >>> >>>> Question to the group I have Don Hicks piet N920Y with the model A eng. >>>> While working my way up to take off speed by doing several taxi test, I >>>> find the aircraft keeps trying to pull to the left. >>>> I have several thousand hours of flight time and have owned two trail >>>> drager aircraft. But this one has a funny feel. >>>> I have the stright axle, with wire wheels. >>>> Any thoughts??? >>>> Thank you for your time Chet. >>>> >>>>* >>>> >>>> >>>>* >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> -- >> 269.13.15/1002 - Release Date: 9/11/2007 5:46 PM >> >> > > ________________________________________________________________________________
Date: Sep 12, 2007
John, You are correct in most aspects. Laser cutting (or just about any kind of cutting) produces a Heat Affected Zone (HAZ) adjacent to the cut, right around the perimeter of the part. Even waterjet-cutting produces a HAZ, but it is so small that it really isn't significant in this application. Some on the list have made mention of "friction-cutting" with the bandsaw, where bandsaw blade creates so much friction that the metal gets red hot, and then begins to cut through the sheet metal - this method will also produce a HAZ (bigger than by laser-cutting), but the edges will very likely all get cleaned up by grinding or filing before use, thus eliminating or reducing the HAZ. With laser-cutting, this zone is very narrow, usually in the range of approximately .010" for the gauges of metal used in the Piet. The result of the HAZ, is a change in the microstructure of the metal, and with it, changes in the mechanical properties of the metal. In 4130, the changes do produce edges that are harder, BUT, with this increased hardness comes increased brittleness - called Hydrogen embrittlement, which is not such a good thing. Since this area is so small, it can be fairly easily removed by grinding/filing (taking care not to overheat the metal with the grinder, and produce another, larger HAZ). On edges that will be welded, there isn't really any need to remove the HAZ, since you will be producing a new, much much larger HAZ by the welding process (especially with oxy-acetylene welding, less so with TIG welding). The key here is to make sure that your welding is done in an area that has still air (no drafts or fans) and let the welds cool slowly in the calm air. The result of this slow, controlled cooling is that it will normalize the 4130, eliminating the HAZ you just created by welding. Another point to consider is that the fittings as drawn by BHP were fabricated from 1020 steel (a low carbon mild steel). Having a low carbon content, this steel is less prone to hardening and embrittlement. Over the years, there have been many Air Campers built using 1020 steel fittings, without any problems (most of them even brazed rather than welded). "Upgrading" to stronger 4130 has its advantages and its disadvantages. In short, I wouldn't hesitate to get the parts laser-cut, especially if you don't have access to a metal-cutting bandsaw, or other appropriate tools. Just be aware of the harder, more brittle edges, and prepare them appropriately before bending them and putting them on the plane that will be carrying your (and possibly someone else's) butt(s). my 1.9293 cents ( = 2 cents Canadian) Bill C. ________________________________________________________________________________
Date: Sep 12, 2007
I have to jump in here and correct some mis-labeling. First, "hydrogen embrittlement" only happens in the presence of available free hydrogen, most commonly in the real world when arc welding in the rain. The arc electrolocizes the water, allowing free hydrogen to enter the molten metal. It also affects underwater welding in ship repair or steel construction. Hardening due to heat treatment is NOT hydrogen embrittlement. Second, 4130 is a relatively low carbon alloy. Its strength comes from the alloying effects of the Chrome, molybdenum and manganese in the mix. Its real beauty is that it achieves very good strength without careful heat treating. This makes it wonderful for Oxy-Acetylene welding, where the post-weld heat treatment cannot be carefully controlled. The local heating at a cut line in 4130 produces very minor mechanical changes in the metal, such as hardening. The source of the heat, whether laser, bandsaw blade, or plasma jet, doesn't change that. Laser cutting of a high-carbon alloy, such as a tool steel of some kind, does produce a very hard zone (HAZ) that is often ground off. In 4130, this really isn't much of a problem. Mike Hardaway PS: Don't arc weld in the rain. ---- Bill Church wrote: > John, > > You are correct in most aspects. > > Laser cutting (or just about any kind of cutting) produces a Heat > Affected Zone (HAZ) adjacent to the cut, right around the perimeter of > the part. Even waterjet-cutting produces a HAZ, but it is so small that > it really isn't significant in this application. Some on the list have > made mention of "friction-cutting" with the bandsaw, where bandsaw blade > creates so much friction that the metal gets red hot, and then begins to > cut through the sheet metal - this method will also produce a HAZ > (bigger than by laser-cutting), but the edges will very likely all get > cleaned up by grinding or filing before use, thus eliminating or > reducing the HAZ. With laser-cutting, this zone is very narrow, usually > in the range of approximately .010" for the gauges of metal used in the > Piet. The result of the HAZ, is a change in the microstructure of the > metal, and with it, changes in the mechanical properties of the metal. > In 4130, the changes do produce edges that are harder, BUT, with this > increased hardness comes increased brittleness - called Hydrogen > embrittlement, which is not such a good thing. Since this area is so > small, it can be fairly easily removed by grinding/filing (taking care > not to overheat the metal with the grinder, and produce another, larger > HAZ). On edges that will be welded, there isn't really any need to > remove the HAZ, since you will be producing a new, much much larger HAZ > by the welding process (especially with oxy-acetylene welding, less so > with TIG welding). The key here is to make sure that your welding is > done in an area that has still air (no drafts or fans) and let the welds > cool slowly in the calm air. The result of this slow, controlled cooling > is that it will normalize the 4130, eliminating the HAZ you just created > by welding. > Another point to consider is that the fittings as drawn by BHP were > fabricated from 1020 steel (a low carbon mild steel). Having a low > carbon content, this steel is less prone to hardening and embrittlement. > Over the years, there have been many Air Campers built using 1020 steel > fittings, without any problems (most of them even brazed rather than > welded). "Upgrading" to stronger 4130 has its advantages and its > disadvantages. > In short, I wouldn't hesitate to get the parts laser-cut, especially if > you don't have access to a metal-cutting bandsaw, or other appropriate > tools. Just be aware of the harder, more brittle edges, and prepare them > appropriately before bending them and putting them on the plane that > will be carrying your (and possibly someone else's) butt(s). > > > my 1.9293 cents ( = 2 cents Canadian) > > Bill C. > > ________________________________________________________________________________
Date: Sep 12, 2007
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Mike and Bill, Would appreciate your thoughts on mig welding 4130. Thanks! Jack Textor www.textors.com Subject: RE: Pietenpol-List: cut steel parts I have to jump in here and correct some mis-labeling. First, "hydrogen embrittlement" only happens in the presence of available free hydrogen, most commonly in the real world when arc welding in the rain. The arc electrolocizes the water, allowing free hydrogen to enter the molten metal. It also affects underwater welding in ship repair or steel construction. Hardening due to heat treatment is NOT hydrogen embrittlement. Second, 4130 is a relatively low carbon alloy. Its strength comes from the alloying effects of the Chrome, molybdenum and manganese in the mix. Its real beauty is that it achieves very good strength without careful heat treating. This makes it wonderful for Oxy-Acetylene welding, where the post-weld heat treatment cannot be carefully controlled. The local heating at a cut line in 4130 produces very minor mechanical changes in the metal, such as hardening. The source of the heat, whether laser, bandsaw blade, or plasma jet, doesn't change that. Laser cutting of a high-carbon alloy, such as a tool steel of some kind, does produce a very hard zone (HAZ) that is often ground off. In 4130, this really isn't much of a problem. Mike Hardaway PS: Don't arc weld in the rain. ---- Bill Church wrote: > John, > > You are correct in most aspects. > > Laser cutting (or just about any kind of cutting) produces a Heat > Affected Zone (HAZ) adjacent to the cut, right around the perimeter of > the part. Even waterjet-cutting produces a HAZ, but it is so small that > it really isn't significant in this application. Some on the list have > made mention of "friction-cutting" with the bandsaw, where bandsaw blade > creates so much friction that the metal gets red hot, and then begins to > cut through the sheet metal - this method will also produce a HAZ > (bigger than by laser-cutting), but the edges will very likely all get > cleaned up by grinding or filing before use, thus eliminating or > reducing the HAZ. With laser-cutting, this zone is very narrow, usually > in the range of approximately .010" for the gauges of metal used in the > Piet. The result of the HAZ, is a change in the microstructure of the > metal, and with it, changes in the mechanical properties of the metal. > In 4130, the changes do produce edges that are harder, BUT, with this > increased hardness comes increased brittleness - called Hydrogen > embrittlement, which is not such a good thing. Since this area is so > small, it can be fairly easily removed by grinding/filing (taking care > not to overheat the metal with the grinder, and produce another, larger > HAZ). On edges that will be welded, there isn't really any need to > remove the HAZ, since you will be producing a new, much much larger HAZ > by the welding process (especially with oxy-acetylene welding, less so > with TIG welding). The key here is to make sure that your welding is > done in an area that has still air (no drafts or fans) and let the welds > cool slowly in the calm air. The result of this slow, controlled cooling > is that it will normalize the 4130, eliminating the HAZ you just created > by welding. > Another point to consider is that the fittings as drawn by BHP were > fabricated from 1020 steel (a low carbon mild steel). Having a low > carbon content, this steel is less prone to hardening and embrittlement. > Over the years, there have been many Air Campers built using 1020 steel > fittings, without any problems (most of them even brazed rather than > welded). "Upgrading" to stronger 4130 has its advantages and its > disadvantages. > In short, I wouldn't hesitate to get the parts laser-cut, especially if > you don't have access to a metal-cutting bandsaw, or other appropriate > tools. Just be aware of the harder, more brittle edges, and prepare them > appropriately before bending them and putting them on the plane that > will be carrying your (and possibly someone else's) butt(s). > > > my 1.9293 cents ( = 2 cents Canadian) > > Bill C. > > ________________________________________________________________________________
Date: Sep 12, 2007
Subject: Service Bulletin
Would anyone like to share any airframe problems experienced during annual? Are there certain aeras prone to rot? Are there any weak areas? If there was a Piet service bulletin what would it be? Ryan ________________________________________________________________________________
Date: Sep 12, 2007
Subject: outside storage/parking
Anyone here leave there Pietenpol parked outside semi permanently, or permanently? Boyce ________________________________________________________________________________
Date: Sep 12, 2007
A couple of things I like to do to prevent problems are to raise the tail during down time. I put it up on one of those plastic chairs. During the winter I always go over the whole plane and where ever there is a hole I put one of those Downy cloths in the hole. Apparently the mice don't like the smell of this stuff. I haven't noticed any rot anywhere (touch wood) up to this point. I am in a non heated hanger with a gravel floor. It's been in there now for about 5 years and before that it was in a garage in Manotick for years and before that it was in Perth for years going back to 1977. So the guys who built this thing did it right. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Michals Sent: September 12, 2007 2:47 PM Subject: Pietenpol-List: Service Bulletin Would anyone like to share any airframe problems experienced during annual? Are there certain aeras prone to rot? Are there any weak areas? If there was a Piet service bulletin what would it be? Ryan ________________________________________________________________________________
Date: Sep 12, 2007
Subject: my Mentor is amazing
Hadn't talked to my Mentor in awile. Called him last night. He's somewhere around 87 and going strong. He's a few months into building a Flying Flea. With folding wing tips so he can tow it to the airport on the road. He's got a fresh 1/2 VW engine built,(that he's famous for) Complete with Eisemann Mag. I flew behind one of his engines for a few years,,,never burped. Think this is his tenth or so plane he built. May he live forever. Walt Evans NX140DL PS He builds a casting to mount a magneto directly to a Model A engine, if anyone is interested "No one ever learned anything by talking" ________________________________________________________________________________
Date: Sep 12, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Ryan, I can tell you the areas that have caused me problems are: 1. Exhaust pipes cracking 2. Bungee cords chafing (straight axle gear) 3. Chafe marks in the engine cooling shrouds (Continental A65) caused by vibration against the cylinder heads. 4. Rust on the tailwheel swing-arm caused by rocks chipping the paint off. That's about it in 2 years and 120 hours of operation. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Michals Sent: Wednesday, September 12, 2007 2:47 PM Subject: Pietenpol-List: Service Bulletin --> Would anyone like to share any airframe problems experienced during annual? Are there certain aeras prone to rot? Are there any weak areas? If there was a Piet service bulletin what would it be? Ryan _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Subject: cut steel parts
Date: Sep 12, 2007
Oops! You are right, Mike. That should have just been embrittlement, NOT Hydrogen embrittlement. My apologies. >From what I have read, 4130 is usually only succeptible to Hydrogen embrittlement if it is subjected to a high degree of heat treatment, or some plating processes. Not likely to be a concern in a typical Pietenpol project. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bike.mike(at)charter.net Sent: Wednesday, September 12, 2007 1:31 PM Subject: RE: Pietenpol-List: cut steel parts I have to jump in here and correct some mis-labeling. First, "hydrogen embrittlement" only happens in the presence of available free hydrogen, most commonly in the real world when arc welding in the rain. The arc electrolocizes the water, allowing free hydrogen to enter the molten metal. It also affects underwater welding in ship repair or steel construction. Hardening due to heat treatment is NOT hydrogen embrittlement. Mike Hardaway PS: Don't arc weld in the rain. ________________________________________________________________________________
Date: Sep 12, 2007
Jack, First let me say that I'm not a welder, and I'm no expert regarding welding. We do welding in the shop at work (MIG,TIG,and stick) but it is primarily stainless steel, mild steel and aluminum (not 4130). My experience is that MIG is a challenge to weld light gauges successfully. Our guys usually use TIG for light gauge metals, and MIG for heavier work. MIG is also a bit messier - more spatter, and relatively large weld beads. >From what I've read, one has to be more careful when welding 4130 with MIG. Proper filler wire selection is very important. The heat is not as controllable as with TIG or Oxy-Axetylene, resulting in a sudden application of heat. With Oxy-Acetylene or TIG, the basemetal is heated first and already at a molten state before filler is added. This is not the case with MIG, as starts are on cold material and the arc tranfer is too quick to allow the base metal and filler to properly join. I suppose one could MIG weld the joints, then normalize the welds afterward, using a torch, but it would be a lot simpler to just weld with the torch in the first place. I believe Chuck Gantzer is using MIG to tack his Tailwind fuselage together (for ease of use), then completing the final welds using a torch. Having said that, I have also read that several production aircraft have used MIG welded 4130 structures. Anyone else out there with more knowledge about this stuff? Bill C. -----Original Message----- --> Mike and Bill, Would appreciate your thoughts on mig welding 4130. Thanks! Jack Textor www.textors.com ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Date: Sep 12, 2007
Hello!!!! From what I have seen with 4130 aircraft fuselages.... They are tacked with MIG, and finished with Oxy-Acetylene. 4130 needs the pre heat and slow cool down that the larger heated area Oxy-Acetylene induces on the material. (should cool in STILL AIR, not by a fan or the wind) Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Bill Church Sent: Wednesday, September 12, 2007 3:19 PM Subject: RE: Pietenpol-List: cut steel parts Jack, First let me say that I'm not a welder, and I'm no expert regarding welding. We do welding in the shop at work (MIG,TIG,and stick) but it is primarily stainless steel, mild steel and aluminum (not 4130). My experience is that MIG is a challenge to weld light gauges successfully. Our guys usually use TIG for light gauge metals, and MIG for heavier work. MIG is also a bit messier - more spatter, and relatively large weld beads. >From what I've read, one has to be more careful when welding 4130 with MIG. Proper filler wire selection is very important. The heat is not as controllable as with TIG or Oxy-Axetylene, resulting in a sudden application of heat. With Oxy-Acetylene or TIG, the basemetal is heated first and already at a molten state before filler is added. This is not the case with MIG, as starts are on cold material and the arc tranfer is too quick to allow the base metal and filler to properly join. I suppose one could MIG weld the joints, then normalize the welds afterward, using a torch, but it would be a lot simpler to just weld with the torch in the first place. I believe Chuck Gantzer is using MIG to tack his Tailwind fuselage together (for ease of use), then completing the final welds using a torch. Having said that, I have also read that several production aircraft have used MIG welded 4130 structures. Anyone else out there with more knowledge about this stuff? Bill C. -----Original Message----- --> Mike and Bill, Would appreciate your thoughts on mig welding 4130. Thanks! Jack Textor www.textors.com ________________________________________________________________________________
Date: Sep 12, 2007
Subject: Re: Corvair intake manifold (Bernie's design)
Ryan, we used a pietenpol manifold built by Vi Kappler, the lines running out of the oil jacket are for oil pressure lines. We had no problems with this set up other than some joints cracked, (they were braized) The oil jacket did help cool the oil an average od 10-15 degrees in cruise. We are now using the same type of intake with out the oil jacket, and welded joints. Our primer line goes into the top of the manifold right before the "Y" splits to go to each head. Hope this helps. Shad --------------------------------- Moody friends. Drama queens. Your life? Nope! - their life, your story. ________________________________________________________________________________
Subject: High Speed taxi
Date: Sep 12, 2007
I would like to take this time to thank Dick Navratil, Catdesign, Gene & Tammy plus Jim Ash. As of today N920Y has flown once again. Mr. Hicks would be proud of his little airplane and she preformed well. After checking out every ones ideas as to my problem, I had asked a fellow pilot to come and taxi the aircraft and give me his thoughts. Before he was to show up I give a fellow pilot his Byannual flight review in his A model Cessna 170. After a couple of take off and landings and a great flight review.We started the Piet up for him to hear run. After a couple of minutes he said it is to nice of a evening to just stand here go do some taxi testing. So I did. After a couple of runs down the runway, I added a little more power and every thing just felt right. So we turned her around into the wind and added full power. Now that is a great felling when she lifts off the runway. On down wind the schroud around the radiatior came loose, so we had to cut the flight short. The biggest problem was I was just not getting up enough speed to have good airflow over the tail. Once again thanks to every one for your input. Chet ________________________________________________________________________________
Subject: Re: my Mentor is amazing
Date: Sep 12, 2007
Walt, Please send e-mail address and phone number. Chet ----- Original Message ----- From: walt evans To: piet list Sent: Wednesday, September 12, 2007 3:08 PM Subject: Pietenpol-List: my Mentor is amazing Hadn't talked to my Mentor in awile. Called him last night. He's somewhere around 87 and going strong. He's a few months into building a Flying Flea. With folding wing tips so he can tow it to the airport on the road. He's got a fresh 1/2 VW engine built,(that he's famous for) Complete with Eisemann Mag. I flew behind one of his engines for a few years,,,never burped. Think this is his tenth or so plane he built. May he live forever. Walt Evans NX140DL PS He builds a casting to mount a magneto directly to a Model A engine, if anyone is interested "No one ever learned anything by talking" ________________________________________________________________________________
Date: Sep 12, 2007
In a message dated 9/12/2007 5:20:24 PM Central Daylight Time, eng(at)canadianrogers.com writes: I believe Chuck Gantzer is using MIG to tack his Tailwind fuselage together (for ease of use), then completing the final welds using a torch. Having said that, I have also read that several production aircraft have used MIG welded 4130 structures. Anyone else out there with more knowledge about this stuff? Bill C. That is correct, Bill. Tack weld with Mig, then finish with Oxy / Accy is a common procedure, but keep in mind you must completely weld through the original tack weld. Using this method there is less stress induced into the steel tube structure. At the Rans Factory, in Hays KS, I understand the entire fuselage is welded up using Mig Welding. It is great for a high rate of production, but I wouldn't recommend it to the home builder. Keep in mind these guys do a LOT of welding, and I think that even with their expertise, there is still some undue stress induced into the airframe. Chuck G. NX770CG ________________________________________________________________________________
Date: Sep 12, 2007
Subject: Re: Engine question
Try this; http://www.mail2600.com/PropDesign/index.html Clif As this all sounds like a balancing act but then engine torque/rpm issues can be mitigated in some degree by matching up a propeller to that engine http://www.pponk.com/HTML%20PAGES/propcalc.html Like most things in this life, its not the end all but it certainly helps take much of the guess work out of the balancing act. John ________________________________________________________________________________
Date: Sep 13, 2007
Thanks to all for your thoughts. I plan to tack then have the welding instructor at a local school finish it up. Thanks, Jack Textor www.textors.com Subject: Re: Pietenpol-List: cut steel parts In a message dated 9/12/2007 5:20:24 PM Central Daylight Time, eng(at)canadianrogers.com writes: I believe Chuck Gantzer is using MIG to tack his Tailwind fuselage together (for ease of use), then completing the final welds using a torch. Having said that, I have also read that several production aircraft have used MIG welded 4130 structures. Anyone else out there with more knowledge about this stuff? Bill C. That is correct, Bill. Tack weld with Mig, then finish with Oxy / Accy is a common procedure, but keep in mind you must completely weld through the original tack weld. Using this method there is less stress induced into the steel tube structure. At the Rans Factory, in Hays KS, I understand the entire fuselage is welded up using Mig Welding. It is great for a high rate of production, but I wouldn't recommend it to the home builder. Keep in mind these guys do a LOT of welding, and I think that even with their expertise, there is still some undue stress induced into the airframe. Chuck G. NX770CG ________________________________ See what's new at Make AOL Your Homepage. ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Re: Pietenpol-List Digest: 20 Msgs - 09/12/07
Date: Sep 13, 2007
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Subject: Re: neat tool
Date: Sep 13, 2007
Dick, A very exciting time for you. Be careful and keep us advised. Gene ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: Tuesday, September 11, 2007 8:20 PM Subject: Pietenpol-List: neat tool I have been wrestling with my new 3 piece wing, trying to get it correctly aligned and to put in the proper washout on the tips. Today I stopped in Sears and found a level with a digital read out to the tenth of a degree. It also has a laser. I was able to fine tune the wings and the $50 was well worth it. Also, I had final airworhyness inspection on friday and passed. I'm hoping for first flight this weekend. Dick N. ------------------------------------------------------------------------- ----- 9/11/2007 5:46 PM ________________________________________________________________________________
Subject: Re: High Speed taxi
Date: Sep 13, 2007
Congratulations Chet! Gene . 9/12/2007 5:22 PM ________________________________________________________________________________
Date: Sep 13, 2007
It was just a matter of time b4 you figured it out.Sounds fantastic;congratulations,enjoy many more flights! ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Chet's Mail Sent: September 12, 2007 10:37 PM Subject: Pietenpol-List: High Speed taxi I would like to take this time to thank Dick Navratil, Catdesign, Gene & Tammy plus Jim Ash. As of today N920Y has flown once again. Mr. Hicks would be proud of his little airplane and she preformed well. After checking out every ones ideas as to my problem, I had asked a fellow pilot to come and taxi the aircraft and give me his thoughts. Before he was to show up I give a fellow pilot his Byannual flight review in his A model Cessna 170. After a couple of take off and landings and a great flight review.We started the Piet up for him to hear run. After a couple of minutes he said it is to nice of a evening to just stand here go do some taxi testing. So I did. After a couple of runs down the runway, I added a little more power and every thing just felt right. So we turned her around into the wind and added full power. Now that is a great felling when she lifts off the runway. On down wind the schroud around the radiatior came loose, so we had to cut the flight short. The biggest problem was I was just not getting up enough speed to have good airflow over the tail. Once again thanks to every one for your input. Chet ________________________________________________________________________________
Subject: re: power at low rpm
Date: Sep 13, 2007
I stole this from the physicsforum. The contributor is "Danger " [I always use my actual name for a username], but I believe "Danger" has got it right. The question came up here a few days ago: (On the matter of Undersquare/oversquare) Where they differ is in how that power is produced. As a general rule, a 'stroker' (undersquare) makes its maximum hp/torque at lower rpm's. An oversquare motor of equal displacement can make the same amount, but you might have to rev it three times faster to reach the power band. Since we're interested in prop efficiency, we -- of course -- want our muscle at low rpms. I.e., bigger bore, shorter stroke. BTW, For any gearhead, mathfan, physicsforum[dot]com might be worth signing up in. ________________________________________________________________________________
Subject: Re: re: power at low rpm
Date: Sep 13, 2007
Tom, I always thought a "stroker" was an engine with an increased stroke. And an engine that had been "bored and stroked" had been bored to larger diameter cylinders and a new crankshaft added to increase stroke. Either or both of these treatments are meant to increase the airflow. The result would add horsepower at the same rpm or provide the same horsepower at a reduced rpm. So I would think we would want bigger bore and/or longer stroke... Not a Physicist...:) Max ----- Original Message ----- From: Tom Winter To: pietenpol-list(at)matronics.com Sent: Thursday, September 13, 2007 1:38 PM Subject: Pietenpol-List: re: power at low rpm I stole this from the physicsforum. The contributor is "Danger " [I always use my actual name for a username], but I believe "Danger" has got it right. The question came up here a few days ago: (On the matter of Undersquare/oversquare) Where they differ is in how that power is produced. As a general rule, a 'stroker' (undersquare) makes its maximum hp/torque at lower rpm's. An oversquare motor of equal displacement can make the same amount, but you might have to rev it three times faster to reach the power band. Since we're interested in prop efficiency, we -- of course -- want our muscle at low rpms. I.e., bigger bore, shorter stroke. BTW, For any gearhead, mathfan, physicsforum[dot]com might be worth signing up in. ________________________________________________________________________________
Date: Sep 13, 2007
To get power at a lower RPM, we would want MORE stroke, not less...such as the Curtiss OX-5 which is 4 inch bore by 5 inch stroke and develops its 90 horsepower at 1400 RPM...at least that's the way I see it. Forrest Lovley Jordan MN ************************************** See what's new at ________________________________________________________________________________
From: "Patrick Panzera" <Panzera@experimental-aviation.com>
Date: Sep 13, 2007
For those who think that torque is king and direct-drive is the only way to go, I have several hundred hours in an SEL aircraft that has an engine capable of making the same maximum torque as an O-235. The plane is capable of hefting 10,495 gross to 26,000' with an initial climb rate of 1,575 ft/min and cruises at 270 kts. (true) up in the flight levels. The prop is driven through a geared redrive that knocks the output of the 23,000 RPM turbine engine down to a manageable 1,750, operating the 105" 4-blade CS prop at 76% of mach (while doing 270 kts). The HP rating at either the input or output of the PSRU is in the 1,000 range (actual HP is predicated on engine temperature), so for me, the 1,000 HP rating is WAY more relevant than the anemic 228 ft/lbs of torque the engine makes at 23,000 RPM. Torque x RPM 5250 = HP Pat ________________________________________________________________________________
Date: Sep 13, 2007
Ohhhh, Pat, that's so misleading. That redrive is also a torque multiplier. What's the torque value at the output side of that unit? Whatcha flying, a Caravan? For the record, 23k RPM is pretty enthusiastic and characteristic of a modern small turbine. Many Low to Mid bypass turbines max out at just shy of 11,000 RPM and are limited to these speeds by air temp, air press and inertial mass. Didja know that turbine inlets are designed to control 3 things? Temp, air pressure and air speed. The air speed in the inlet of a supersonic machine can't be allowed to go transonic, the temperature should be close to freezing and pressure shouldn't exceed 2 psi. I should be more modest, though. These were the design rules in place for equipment back when I was still working on them. Breaking one of those rules resulted in compressor stalls, flaming inlets, etc. For a conventional fire maker in an airplane, torque is indeed the key to maintaining inertia. The primary reasons folks avoid gear reduction in lighter aircraft with more modest powerplants are the same as they've always been: weight and reliability. They weigh a lot when they are properly strong enough to support the loads represented by a 7'-12' flywheel moving at speed. And it's easier to make a reliable gear drive for a turbine since there are no combustion pulses being transmitted to the input end of the unit, unlike a conventional IC engine. And for the record, I wish I could say I had several hundred hours in the machine you describe. It sounds interesting...and expensive. ;) Greg Chapman http://www.mousetrax.com http://www.layer1wireless.com "Don't start with me or I'll replace you with a small and efficient script!" > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner- > pietenpol-list-server(at)matronics.com] On Behalf Of Patrick Panzera > Sent: Thursday, September 13, 2007 4:36 PM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: re: power at low rpm > > <Panzera@Experimental-Aviation.com> > > For those who think that torque is king and direct-drive is the only > way to > go, I have several hundred hours in an SEL aircraft that has an engine > capable of making the same maximum torque as an O-235. > > The plane is capable of hefting 10,495 gross to 26,000' with an initial > climb rate of 1,575 ft/min and cruises at 270 kts. (true) up in the > flight > levels. > > The prop is driven through a geared redrive that knocks the output of > the > 23,000 RPM turbine engine down to a manageable 1,750, operating the > 105" > 4-blade CS prop at 76% of mach (while doing 270 kts). > > The HP rating at either the input or output of the PSRU is in the 1,000 > range (actual HP is predicated on engine temperature), so for me, the > 1,000 > HP rating is WAY more relevant than the anemic 228 ft/lbs of torque the > engine makes at 23,000 RPM. > > Torque x RPM 5250 = HP > > Pat > > ________________________________________________________________________________
Date: Sep 14, 2007
Lets take this one step further For the optimum performance in a perfect world what are the parameters for BEST PERFORMANCE BY: Prop lenght Pitch Engine RPM Torque Hp engine type: auto, industrial, Marine and other lets rule out AV engines in this to make it more interesting MFG Model engine weight aircraft weight total weight gross Giiven those parameters CG location Engine mount distance from firewall to back of engine length firewall to Prop John ________________________________________________________________________________
Date: Sep 14, 2007
Good Luck Dick! :D Patrick 601XL/Corvair EAA Chapter 25 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134505#134505 ________________________________________________________________________________
Subject: smoke on!
Date: Sep 15, 2007
Well, 41CC may have a new habit soon. Smoking. I got the test apparatus hooked up securely enough to allow ground testing. Consisted of an automotive windshield washer reservoir and pump bungee'd to the side of the airplane with a small 12V motorcycle battery sitting on that and also lashed on. Flex hose to the exhaust stack with the last few inches a piece of copper tubing, to a brass fitting threaded into a boss welded to the stack just where Mike Cuy said to put it. Two small holes drilled through the stack wall, again as per Mike's specs for size and location. One large bottle of baby oil went in the reservoir, engine was started and warmed up (tail tied to my car's trailer hitch and wheels chocked), then 1500 RPM and I gave it a blip of smoke. Wowza!!!!! She makee smokee! Let that one waft past the hangar behind me and blipped it again. And again. And againnnnnn!!!!!!!! Looked back and the hangar was full of smoke, and a nice trail downwind about an eighth of a mile in the light breeze. Decided to call it good before the volunteer fire department showed up, since my apparatus had proven itself. Couple of things I noticed right away. One: the grass beneath and behind my airplane was all oily, so was my car parked downwind (tail of the airplane was tied to it, remember?). So were the gear legs. Maybe when the smoke is on with the airplane is flying it doesn't oil everything up so bad, but it consumed 3/4 of the bottle of baby oil and it looked like a good deal of it was unburned or maybe the smoke condenses. Second, when I would apply smoke the engine would start to stutter a bit on that side. It was definitely the smoke doing it. Not sure why, but again- maybe with higher power settings such as used in flight, it won't do that. Kind of strange. It will be nice to get the system complete and operational, but at least I know that my components will work and the smoke volume should be about right when the airplane is in flight. I don't know how Chuck "the master of baby oil" Gantzer does it, pirouetting his airplane in a cloud of smoke. He must get out of the airplane covered in oil! Took my brother up for a flight after that and made a pretty decent x-wind landing. Pietenpols forever! Oscar Zuniga NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Share your special parenting moments! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us ________________________________________________________________________________
Subject: Stitts covering
Date: Sep 15, 2007
Looks like I am going stitts for my covering. I have some great folks who will help me learn the job. Can anyone here give me an approximate idea of what I need to order for fabric, adheasive etc. ? -Scott Schreiber ________________________________________________________________________________
Date: Sep 15, 2007
Subject: Re: smoke on!
Hey Oscar, I figured you would be picking up the habit of Smoking !! Caution: It is very habit forming !! The way I originally set up my system, was with an automotive after-market windshield washer tank & pump. Here are the original problems & solution that I came up with: 1) The location I placed the plastic tank on the left side of the engine mount was a little too high - just a little above the point where it enters the exhaust stack. Gravity caused the oil to dribble out into the exhaust when the pump was NOT on. 2) Another problem I had originally, was that I ran the line down, then back up to the 'Tee' in the center, where it split and goes to each side, and when the tank would run dry, and I would refill the tank with Baby Oil, the pump would cavitate, and I would have give the system 'Mouth to Mouth Resuscitation', by blowing into the filler hole with the pump on, in order to bleed the air out of the pump. 3) The tank was not big enough, which limited the 'Smoke On' time. I cured all three problems by building a larger fiberglass tank (holds about a gallon) with a nipple glassed in the bottom of the tank, and locating the tank down low in the center of the firewall, and located the pump separately at the lowest point in the system. The lines going to the exhaust should be long enough so heat will not travel down the metal, and affect the plastic tubing attached to it. I ran the two brass (should have been copper) lines from the exhaust pipes all the way to the Tee, using compression fittings, then a clear tygon tubing from the pump to the Tee. I cut a steel union in half, radiused them to the exhaust pipe, welded one on each of the aft pipes about 1 1/2" down from the flange, and drilled ONE # 60 hole down low through the exhaust pipe after it was welded. I located the hole down low in the fitting, so it would drain all the oil out into the exhaust and would not collect and harden up in the fitting, after the pump was turned off. The system has been trouble free ever since, and even when I do the 'Smoke Dance' on the ground, I only get a little oily dirt on the landing gear legs, and maybe a little bit on the leading edge of the stabilizer. I've never had any engine stutter with the smoke on, even at the lower power settings. Here is the page on my web site: _http://nx770cg.com/SmokeSystem.html_ (http://nx770cg.com/SmokeSystem.html) Chuck 'Baby Oil' Gantzer NX770CG SMOKE 'EM IF YA GOT 'EM !!! ________________________________________________________________________________
Subject: smoke on!
Date: Sep 16, 2007
From: "Cuy, Michael D. (GRC-RXC0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Oscar, >Congratulations on making smoke and not to fear, at cruise RPM >you will burn more oil that you belch overboard. The hotter >your EGT the better and for your ground test you would have >seen a marked >difference if your engine was warmed up and you were at 2150 >rpm. You'll be fine. Way to go. > >The Thunderbirds parked at our NASA hangar over Labor Day >Weekend (as they do every other year) for our local airshow >and Friday we had an open house so I snapped this photo of the >smoke injection probe that simply sticks into the GEF110 >engine exhaust. The tip looks very much like a spray wand end >(but all stainless) >of a bug sprayer. Imagine that ? I asked a ground support >crewmember how much smoke oil each Thunderbird goes >thru during a typical performance and he said "about 20 >gallons". There were 16 55 gallon drums of Shell >Carnea E Oil 22 sitting on pallets nearby the planes (that >would be 880 gallons of fun in a drum) and I coveted every one >of them. In September of 2005 the Thunderbirds were using >Shell Vitrea Oil 22. Must do the same >thing but for some reason they were using this Carnea E Oil 22 >this year. > >Smoke on, > >Mike C. > > > ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Sep 16, 2007
Hey Scott, Stitts has a number of fabric packages for homebuilts and they do have one for the Pietenpol. It includes all of the fabric, stitching and tapes as w ell as the chemicals to silver. Check out their website or give them a cal l. They are in Ohio. Shipping is a little bit costly because of the nature of the dangerous goods. We have a supplier agent in Toronto so I'm sure t here must be a network throughout the USA. My guy quoted me $5200.00 Cdn l ast year which included a single colour. Best of luck. Scott Knowlton Slow builder in Burlington Ontario From: got22b(at)subarubrat.comTo: pietenpol-list(at)matronics.comSubject: Pietenp ol-List: Stitts coveringDate: Sat, 15 Sep 2007 20:08:24 -0400 Looks like I am going stitts for my covering. I have some great folks who w ill help me learn the job. Can anyone here give me an approximate idea of w hat I need to order for fabric, adheasive etc. ? -Scott Schreiber _________________________________________________________________ News, entertainment and everything you care about at Live.com. Get it now! http://www.live.com/getstarted.aspx ________________________________________________________________________________
Subject: audible changes in engine noise with smoke on
Date: Sep 16, 2007
Oscar, I failed to mention that when I am smoking there is a muffled sound to the engine or at least from the right side where the smoke exits. I don't see a loss of rpm that I can detect but the pitch of the engine certainly changes somewhat and I think that is normal. Again in cruise flight (or preferably a lower pass down the runway "to scare the deer away") you will know the results of your handiwork better. PS-- Never admit to doing a buzz job but merely couch it in the terms mentioned above and if you have no deer in your area just substitute whatever animal is native to your area: groundhog, prairie dog, Elk, Moose, Canadian Geese, or penguins. For those down under, slow Koala bears looking for a tree, Tasmanian Devils, or a pack of hyenas or kangaroo. Mike C. ________________________________________________________________________________
Date: Sep 16, 2007
Yes, I can just hear it now. I taxi up to my hangar and shut down after making a couple of smoking runs. Airport manager comes up to me and asks what the heck I think I'm doing? "Fumigating for elephants" I'll tell him. "Elephants? There ain't no elephants around here!" To which I reply, "Well then, I guess it's working!" Har, har. Sorry for that bad one. I know what you mean about the muffled sound when there is smoke in the pipe, but this was an actual missing/stuttering sound, almost as if smoke was getting drawn back into the chamber and causing a miss. Regardless, I think you and Chuck are right and when I operate it at normal flight RPM with the engine warm, I'll have no problem. I will flight-test it at altitude before trying it near the ground though. We have plenty of buzzards around here and I can do an aerial application of "buzzard dispersant" when the time comes. Oscar Zuniga NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Test your celebrity IQ. Play Red Carpet Reveal and earn great prizes! http://club.live.com/red_carpet_reveal.aspx?icid=redcarpet_hotmailtextlink2 ________________________________________________________________________________
Date: Sep 16, 2007
> I will flight-test it at > altitude before trying it near the ground though. We have plenty of > buzzards around here and I can do an aerial application of "buzzard > dispersant" when the time comes. Around here our "buzzards" have a fancy name http://www.scienceviews.com/animals/condor.html ...and are "protected" in such a way that we can't even fly over where they might live, let alone actually fly over them and spray them with "dispersant". Elephants are fair game however. Pat ________________________________________________________________________________
Subject: Re: Stitts covering
Date: Sep 16, 2007
Great, thanks! -Scott ----- Original Message ----- From: Scott Knowlton To: pietenpol-list(at)matronics.com Sent: Sunday, September 16, 2007 11:41 AM Subject: RE: Pietenpol-List: Stitts covering Hey Scott, Stitts has a number of fabric packages for homebuilts and they do have one for the Pietenpol. It includes all of the fabric, stitching and tapes as well as the chemicals to silver. Check out their website or give them a call. They are in Ohio. Shipping is a little bit costly because of the nature of the dangerous goods. We have a supplier agent in Toronto so I'm sure there must be a network throughout the USA. My guy quoted me $5200.00 Cdn last year which included a single colour. Best of luck. Scott Knowlton Slow builder in Burlington Ontario ------------------------------------------------------------------------- --- From: got22b(at)subarubrat.com To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Stitts covering Date: Sat, 15 Sep 2007 20:08:24 -0400 Looks like I am going stitts for my covering. I have some great folks who will help me learn the job. Can anyone here give me an approximate idea of what I need to order for fabric, adheasive etc. ? -Scott Schreiber " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List p://forums.matronics.com ------------------------------------------------------------------------- ----- Get news, entertainment and everything you care about at Live.com. Check it out! ________________________________________________________________________________
Date: Sep 16, 2007
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Congratulations....Chief Oscar "Oil your grass" Zungia..... or how about Chief Oscar "Baby your wood" Zungia..... tee-hee-hee Oscar Zuniga wrote: Well, 41CC may have a new habit soon. Smoking. I got the test apparatus hooked up securely enough to allow ground testing. Consisted of an automotive windshield washer reservoir and pump bungee'd to the side of the airplane with a small 12V motorcycle battery sitting on that and also lashed on. Flex hose to the exhaust stack with the last few inches a piece of copper tubing, to a brass fitting threaded into a boss welded to the stack just where Mike Cuy said to put it. Two small holes drilled through the stack wall, again as per Mike's specs for size and location. One large bottle of baby oil went in the reservoir, engine was started and warmed up (tail tied to my car's trailer hitch and wheels chocked), then 1500 RPM and I gave it a blip of smoke. Wowza!!!!! She makee smokee! Let that one waft past the hangar behind me and blipped it again. And again. And againnnnnn!!!!!!!! Looked back and the hangar was full of smoke, and a nice trail downwind about an eighth of a mile in the light breeze. Decided to call it good before the volunteer fire department showed up, since my apparatus had proven itself. Couple of things I noticed right away. One: the grass beneath and behind my airplane was all oily, so was my car parked downwind (tail of the airplane was tied to it, remember?). So were the gear legs. Maybe when the smoke is on with the airplane is flying it doesn't oil everything up so bad, but it consumed 3/4 of the bottle of baby oil and it looked like a good deal of it was unburned or maybe the smoke condenses. Second, when I would apply smoke the engine would start to stutter a bit on that side. It was definitely the smoke doing it. Not sure why, but again- maybe with higher power settings such as used in flight, it won't do that. Kind of strange. It will be nice to get the system complete and operational, but at least I know that my components will work and the smoke volume should be about right when the airplane is in flight. I don't know how Chuck "the master of baby oil" Gantzer does it, pirouetting his airplane in a cloud of smoke. He must get out of the airplane covered in oil! Took my brother up for a flight after that and made a pretty decent x-wind landing. Pietenpols forever! Oscar Zuniga NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Share your special parenting moments! http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us --------------------------------- Catch up on fall's hot new shows on Yahoo! TV. Watch previews, get listings, and more! ________________________________________________________________________________
Subject: last word on baby oil
Date: Sep 17, 2007
I promise I'll drop the subject after this post. Check out this link and see if it works for you: http://www.flysquirrel.net/piets/smoke/babyoil.html Oscar Zuniga NX41CC "El Taco Flaco" San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net/piets/CorkyPiet.html _________________________________________________________________ Discover sweet stuff waiting for you at the Messenger Cafe. Claim your treat today! http://www.cafemessenger.com/info/info_sweetstuff.html?ocid=TXT_TAGHM_SeptHMtagline2 ________________________________________________________________________________
Date: Sep 17, 2007
HAHAHAHA!Oscar that was hilarious, ya just made my day! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: September 17, 2007 9:22 AM Subject: Pietenpol-List: last word on baby oil I promise I'll drop the subject after this post. Check out this link and see if it works for you: http://www.flysquirrel.net/piets/smoke/babyoil.html Oscar Zuniga NX41CC "El Taco Flaco" San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net/piets/CorkyPiet.html _________________________________________________________________ Discover sweet stuff waiting for you at the Messenger Cafe. Claim your treat today! http://www.cafemessenger.com/info/info_sweetstuff.html?ocid=TXT_TAGHM_SeptHMtagline2 ________________________________________________________________________________
Subject: Question for Walt Evans and Don Emch
Date: Sep 17, 2007
Walt and Don : I am using the same drum brakes you have and need some advice. What kind of material did you use for a spacer between the inner wheel bushing and the brake backing plate? I was thinking of just slipping on a 1-inch long bronze sleeve. Any problem with running bronze against bronze? Anyone else using these brakes care to comment? Thanks Chris -------- Chris Tracy WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134883#134883 ________________________________________________________________________________
Date: Sep 17, 2007
Subject: Re: Question for Walt Evans and Don Emch
Chris, I've been going thru my old pics trying to find the right shot, but can't. these are the best I can do. BUT,,, The brake back plate, with shoes, is solid mounted to the axle, then whatever spacer I needed so the drum would position correctly over the shoes was used. It was also a bronze sleeve. And with the bronze sleeves in the wheel, it was bronze to bronze. I drilled small oil holes over each bronze sleeve bearing in the wheel hubs. I oil them annually. These are one of the things that I worried about when building/designing. Would the oil get on the shoes and ruin them? Don't really know what's going on inside the brakes,,,but they don't grab to get me into the horror situations of nosing over,,,and when I mash them during run-up, they hold. And since I was taught by a geat WW11 P-51 pilot, who always said, don't count on the brakes, fly like they're not there,,,,,,I only use them to slow down for fun. A newer instructor in the 90's (who used to drop cargo into an opening in the forrest, with a DC-3, while spiriling, with the load on a long rope) taught me that,,,when braking with a taildragger, if you use one brake and the opposite rudder, you may ground loop, but you'll never nose over. Sorry to ramble on Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Catdesigns" <Catdesigns(at)comcast.net> Sent: Monday, September 17, 2007 3:57 PM Subject: Pietenpol-List: Question for Walt Evans and Don Emch > > > Walt and Don : > > I am using the same drum brakes you have and need some advice. What kind > of material did you use for a spacer between the inner wheel bushing and > the brake backing plate? I was thinking of just slipping on a 1-inch long > bronze sleeve. Any problem with running bronze against bronze? > > Anyone else using these brakes care to comment? > > Thanks > > Chris > > -------- > Chris Tracy > WestCoastPiet.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134883#134883 > > > ________________________________________________________________________________
Date: Sep 17, 2007
What sort of wheel/brake set up are you running? -----Original Message----- From: "walt evans" <waltdak(at)verizon.net> Sent: 9/17/2007 6:58 PM Subject: Re: Pietenpol-List: Question for Walt Evans and Don Emch Chris, I've been going thru my old pics trying to find the right shot, but can't. these are the best I can do. BUT,,, The brake back plate, with shoes, is solid mounted to the axle, then whatever spacer I needed so the drum would position correctly over the shoes was used. It was also a bronze sleeve. And with the bronze sleeves in the wheel, it was bronze to bronze. I drilled small oil holes over each bronze sleeve bearing in the wheel hubs. I oil them annually. These are one of the things that I worried about when building/designing. Would the oil get on the shoes and ruin them? Don't really know what's going on inside the brakes,,,but they don't grab to get me into the horror situations of nosing over,,,and when I mash them during run-up, they hold. And since I was taught by a geat WW11 P-51 pilot, who always said, don't count on the brakes, fly like they're not there,,,,,,I only use them to slow down for fun. A newer instructor in the 90's (who used to drop cargo into an opening in the forrest, with a DC-3, while spiriling, with the load on a long rope) taught me that,,,when braking with a taildragger, if you use one brake and the opposite rudder, you may ground loop, but you'll never nose over. Sorry to ramble on Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Catdesigns" <Catdesigns(at)comcast.net> Sent: Monday, September 17, 2007 3:57 PM Subject: Pietenpol-List: Question for Walt Evans and Don Emch > > > Walt and Don : > > I am using the same drum brakes you have and need some advice. What kind > of material did you use for a spacer between the inner wheel bushing and > the brake backing plate? I was thinking of just slipping on a 1-inch long > bronze sleeve. Any problem with running bronze against bronze? > > Anyone else using these brakes care to comment? > > Thanks > > Chris > > -------- > Chris Tracy > WestCoastPiet.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134883#134883 > > > ________________________________________________________________________________
Subject: Re: Service Bulletin
Date: Sep 17, 2007
Ryan, Sorry it has taken so long to get back with you. I'm in the process of moving everything around in my house and I can't find what I'm looking for. Sometime back someone on this list posted a list they use when they do a conditional inspection on their Piet. It was really outstanding and I copied it to use but as I said I can't find it now. I think it would be just what you're looking for to use as you inspect the Piet. Hope someone comes forward to help you out. Gene ----- Original Message ----- From: "Ryan Michals" <aircamperace(at)yahoo.com> Sent: Wednesday, September 12, 2007 1:46 PM Subject: Pietenpol-List: Service Bulletin > > > Would anyone like to share any airframe problems experienced during > annual? Are there certain aeras prone to rot? Are there any weak areas? If > there was a Piet service bulletin what would it be? > > Ryan > > > -- > 9/11/2007 5:46 PM > > ________________________________________________________________________________
Date: Sep 17, 2007
Subject: good ole brew & view
Hi all, I am on the road next week going south to Greenville South Carolina a little into Georgia on I85 and then to Memphis TN. Any builders/owners in those areas willing to share a brew and or view of their project? Please let me know if you're interested I sure would like to get together for some good old piet talking Thanks John ________________________________________________________________________________
Date: Sep 17, 2007
4.5-inch Azusa drum brakes. Mine have aluminum backing plate but Walt must have steel. Wish I had steel ones. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: "Ryan Michals" <aircamperace(at)yahoo.com> Sent: Monday, September 17, 2007 4:28 PM Subject: RE: Pietenpol-List: Question for Walt Evans and Don Emch > > > What sort of wheel/brake set up are you running? > > > -----Original Message----- > From: "walt evans" <waltdak(at)verizon.net> > To: > Sent: 9/17/2007 6:58 PM > Subject: Re: Pietenpol-List: Question for Walt Evans and Don Emch > > Chris, > I've been going thru my old pics trying to find the right shot, but can't. > these are the best I can do. > BUT,,, > The brake back plate, with shoes, is solid mounted to the axle, then > whatever spacer I needed so the drum would position correctly over the > shoes > was used. It was also a bronze sleeve. And with the bronze sleeves in > the > wheel, it was bronze to bronze. > I drilled small oil holes over each bronze sleeve bearing in the wheel > hubs. > I oil them annually. > These are one of the things that I worried about when building/designing. > Would the oil get on the shoes and ruin them? > Don't really know what's going on inside the brakes,,,but they don't grab > to > get me into the horror situations of nosing over,,,and when I mash them > during run-up, they hold. > And since I was taught by a geat WW11 P-51 pilot, who always said, don't > count on the brakes, fly like they're not there,,,,,,I only use them to > slow > down for fun. > A newer instructor in the 90's (who used to drop cargo into an opening in > the forrest, with a DC-3, while spiriling, with the load on a long rope) > taught me that,,,when braking with a taildragger, if you use one brake and > the opposite rudder, you may ground loop, but you'll never nose over. > Sorry to ramble on > Walt Evans > NX140DL > "No one ever learned anything by talking" > ----- Original Message ----- > From: "Catdesigns" <Catdesigns(at)comcast.net> > To: > Sent: Monday, September 17, 2007 3:57 PM > Subject: Pietenpol-List: Question for Walt Evans and Don Emch > > >> >> >> Walt and Don : >> >> I am using the same drum brakes you have and need some advice. What kind >> of material did you use for a spacer between the inner wheel bushing and >> the brake backing plate? I was thinking of just slipping on a 1-inch >> long >> bronze sleeve. Any problem with running bronze against bronze? >> >> Anyone else using these brakes care to comment? >> >> Thanks >> >> Chris >> >> -------- >> Chris Tracy >> WestCoastPiet.com >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=134883#134883 >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 17, 2007
Hi Chris, What I did is very similar to Walt's. It's funny how similar our ships are! I do have basically the same wheels and brakes. In looking at his pictures I really only see one main difference. The piece of tubing that makes up my hub is longer. It comes all the way out to the edge of the brake drum. Instead of that tubing being about 6 1/2" it is about 8". So I guess while it's on the airplane you wouldn't be able to see the difference in Walt's and mine. I think a bronze bushing would be just fine to make up the difference, just keep them well greased. Eventually I want to get a hold of some 6" wheels and get some 8.50 X 6 tires and try them out. When I do I plan to just make up the difference with bronze bushings. Greasing them is very important. I made Larry Williams' hubs for his plane. When I made them he assured me over the phone that his axle was 1.500". I made them with the bushings at about 1.504". He said they were a little tight when he put them on. The axle must have been a little larger. I thought maybe we should open them up a little, but we never did. He went ahead and flew up to Brodhead and Oshkosh. The morning after the EAA guys interviewed him for the magazine article they wanted him to go up and do some air to air shots. He started down the runway on takeoff and the plane started to pull to one side. He stopped, taxied back and tried again. Same thing, and almost ground looped. This time he taxied to the repair tent. They had to beat the wheel off with a hammer. The bushings were so tight and so dry they practically welded themselves on to the axle. After filing, sanding and regreasing they were ready to go again. And the photoshoot was completed. Lesson learned: have at least a few thousandths clearance fit, and file grooves in the bushings to hold the grease. Then don't be afraid to grease them up! If it's too tight, once the axle starts to warm up it grows and of course that just makes it worse. Anyway, I really like the brakes. I really only use them for run up and for taxiing on pavement around other airplanes and fuel pumps. With the high pressure wheels on pavement it just likes to roll and roll. Just another reason to stay away from pavement! Which by the way, on our Brodhead/Barnstorming trip this year, I think we stopped at something like 16 airports and never once had to land on pavement. No radio either. Is that just great or what!! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134944#134944 ________________________________________________________________________________
Subject: Routine Maintenance
Date: Sep 17, 2007
Here is Jack Philips list, I didn't think it would be a problem to re-send it since he has posted it here before. Steve Ruse Norman, OK -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, September 17, 2007 6:31 PM Subject: Re: Pietenpol-List: Service Bulletin Ryan, Sorry it has taken so long to get back with you. I'm in the process of moving everything around in my house and I can't find what I'm looking for. Sometime back someone on this list posted a list they use when they do a conditional inspection on their Piet. It was really outstanding and I copied it to use but as I said I can't find it now. I think it would be just what you're looking for to use as you inspect the Piet. Hope someone comes forward to help you out. Gene ----- Original Message ----- From: "Ryan Michals" <aircamperace(at)yahoo.com> Sent: Wednesday, September 12, 2007 1:46 PM Subject: Pietenpol-List: Service Bulletin > > > Would anyone like to share any airframe problems experienced during > annual? Are there certain aeras prone to rot? Are there any weak areas? If > there was a Piet service bulletin what would it be? > > Ryan > > > -- > 9/11/2007 5:46 PM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phillips, Jack Sent: Wednesday, February 21, 2007 9:19 AM Subject: RE: Pietenpol-List: Routine Maintenance I've got a pretty similar checklist I use for my annual "Condition Inspections", suitable for Pietenpols with straight axle landing gear Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Hans Vander Voort Sent: Wednesday, February 21, 2007 8:43 AM Subject: Re: Pietenpol-List: Routine Maintenance Chuck Just did my annual inspection before the winter and decided to make a checklist for this (see attached) (See attached file: Pietenpol Air Camper anual inspection.doc) As the weather has been pretty bad lately, I have decided to replace some engine components and to enlarge the wind screens. Termotec is pretty good stuff, I have it on my exhaust tubes, to keep heat out from under the cowling. Termotec is not flammable but can soak up oil. You might smoke from unwanted places Hans NX15KV _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N ________________________________________________________________________________
Subject: Re: Routine Maintenance
Date: Sep 18, 2007
That's the one I've been looking for! Thank you Steve. Gene ----- Original Message ----- From: "Steve Ruse" <steve(at)wotelectronics.com> Sent: Monday, September 17, 2007 10:23 PM Subject: RE: Pietenpol-List: Routine Maintenance > > Here is Jack Philips list, I didn't think it would be a problem to re-send > it since he has posted it here before. > > Steve Ruse > Norman, OK > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & > Tammy > Sent: Monday, September 17, 2007 6:31 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Service Bulletin > > > > Ryan, > Sorry it has taken so long to get back with you. I'm in the process of > moving everything around in my house and I can't find what I'm looking > for. > Sometime back someone on this list posted a list they use when they do a > conditional inspection on their Piet. It was really outstanding and I > copied it to use but as I said I can't find it now. I think it would be > just what you're looking for to use as you inspect the Piet. > Hope someone comes forward to help you out. > Gene > ----- Original Message ----- > From: "Ryan Michals" <aircamperace(at)yahoo.com> > To: > Sent: Wednesday, September 12, 2007 1:46 PM > Subject: Pietenpol-List: Service Bulletin > > >> >> >> Would anyone like to share any airframe problems experienced during >> annual? Are there certain aeras prone to rot? Are there any weak areas? >> If > >> there was a Piet service bulletin what would it be? >> >> Ryan >> >> >> >> >> >> >> -- >> 9/11/2007 5:46 PM > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phillips, > Jack > Sent: Wednesday, February 21, 2007 9:19 AM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Routine Maintenance > > I've got a pretty similar checklist I use for my annual "Condition > Inspections", suitable for Pietenpols with straight axle landing gear > > > Jack Phillips > NX899JP > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Hans > Vander Voort > Sent: Wednesday, February 21, 2007 8:43 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Routine Maintenance > > Chuck > > Just did my annual inspection before the winter and decided to make a > checklist for this (see attached) > > (See attached file: Pietenpol Air Camper anual inspection.doc) > > As the weather has been pretty bad lately, I have decided to replace > some > engine components and to enlarge the wind screens. > > Termotec is pretty good stuff, I have it on my exhaust tubes, to keep > heat > out from under the cowling. > Termotec is not flammable but can soak up oil. > You might smoke from unwanted places > > > Hans > > NX15KV > > _________________________________________________ > > This message is for the designated recipient only and may contain > privileged, proprietary, or otherwise private information. If you have > received it in error, please notify the sender immediately and delete the > > Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - > N > -------------------------------------------------------------------------------- 1:29 PM ________________________________________________________________________________
Date: Sep 18, 2007
Thanks for sending that, Steve. It saved me having to dig through my files to look for it. Bear in mind this list is specific to my Pietenpol (Continental A65, straight axle landing gear) and will need to be modified for your individual airplane's design. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Steve Ruse Sent: Monday, September 17, 2007 11:23 PM Subject: RE: Pietenpol-List: Routine Maintenance Here is Jack Philips list, I didn't think it would be a problem to re-send it since he has posted it here before. Steve Ruse Norman, OK _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Subject: smoking issues
Date: Sep 18, 2007
The most common thing people tell you after seeing your Piet smoking is "boy, you've got some bad rings in that engine son, or you really need to have your engine checked." The most fun thing about the smoke is when putting around the countryside if you see a little league game or some backyard picnic going on you circle with some smoke on and they get quite an enjoyable time out of it. On a more serious use of the smoke system, this past Memorial Day a local VFW dedicated a gorgeous granite and stone monument to all the services and wars. They had a big ceremony with a fast T-34 doing a low fly-over for the opening and then just after the conclusion of the Star Spangled Banner they had me fly over the monument and do a 360 degree turn with full smoke on. In talking with others after the event they said there was not dry eye in the house. Made me feel somewhat useful in lifting up a big THANK YOU to any veteran, past or present, alive or not, who helped serve to give us all the freedom we so much take for granted today. End of speech. Mike C. ________________________________________________________________________________
Subject: Piet biplane
Date: Sep 18, 2007
I was just looking at the GN-1 biplane project for sale on Barnstormers (looks like a good deal, by the way) and a crazy idea went through my head. Anyone ever built a biplane Scout before? I would have assumed that the wings would have been shorter, but they look pretty long in the pictures for this one. What is the normal span for the biplane? How hard is it to do a biplane conversion if you already have a completed and covered fusalage? Have people done conversions to already finished planes before? Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Sep 18, 2007
Subject: wheel camber
Guys, I'm finishing the landing gear (J3 clone with springs) for my GN-1 -- does anybody have a suggested amount of camber to use? Thanks in advance, Tom Bernie Gloucester Mass ________________________________________________________________________________
Date: Sep 18, 2007
Mikee wrote- >do a 360 degree turn with full smoke on. >they said there was not a dry eye in the house. Nope. All of 'em had oil mist in their eyes from looking up ;o) Sorry... couldn't resist... diving for cover now... Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Can you find the hidden words? Take a break and play Seekadoo! http://club.live.com/seekadoo.aspx?icid=seek_hotmailtextlink1 ________________________________________________________________________________
Date: Sep 18, 2007
Ryan, They are GoKart brakes. I can post particulars, if you need. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Ryan Michals" <aircamperace(at)yahoo.com> Sent: Monday, September 17, 2007 7:28 PM Subject: RE: Pietenpol-List: Question for Walt Evans and Don Emch > > > What sort of wheel/brake set up are you running? > > > -----Original Message----- > From: "walt evans" <waltdak(at)verizon.net> > To: > Sent: 9/17/2007 6:58 PM > Subject: Re: Pietenpol-List: Question for Walt Evans and Don Emch > > Chris, > I've been going thru my old pics trying to find the right shot, but can't. > these are the best I can do. > BUT,,, > The brake back plate, with shoes, is solid mounted to the axle, then > whatever spacer I needed so the drum would position correctly over the > shoes > was used. It was also a bronze sleeve. And with the bronze sleeves in > the > wheel, it was bronze to bronze. > I drilled small oil holes over each bronze sleeve bearing in the wheel > hubs. > I oil them annually. > These are one of the things that I worried about when building/designing. > Would the oil get on the shoes and ruin them? > Don't really know what's going on inside the brakes,,,but they don't grab > to > get me into the horror situations of nosing over,,,and when I mash them > during run-up, they hold. > And since I was taught by a geat WW11 P-51 pilot, who always said, don't > count on the brakes, fly like they're not there,,,,,,I only use them to > slow > down for fun. > A newer instructor in the 90's (who used to drop cargo into an opening in > the forrest, with a DC-3, while spiriling, with the load on a long rope) > taught me that,,,when braking with a taildragger, if you use one brake and > the opposite rudder, you may ground loop, but you'll never nose over. > Sorry to ramble on > Walt Evans > NX140DL > "No one ever learned anything by talking" > ----- Original Message ----- > From: "Catdesigns" <Catdesigns(at)comcast.net> > To: > Sent: Monday, September 17, 2007 3:57 PM > Subject: Pietenpol-List: Question for Walt Evans and Don Emch > > >> >> >> Walt and Don : >> >> I am using the same drum brakes you have and need some advice. What kind >> of material did you use for a spacer between the inner wheel bushing and >> the brake backing plate? I was thinking of just slipping on a 1-inch >> long >> bronze sleeve. Any problem with running bronze against bronze? >> >> Anyone else using these brakes care to comment? >> >> Thanks >> >> Chris >> >> -------- >> Chris Tracy >> WestCoastPiet.com >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=134883#134883 >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 18, 2007
Yeah, mine were all steel Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Catdesigns" <catdesigns(at)comcast.net> Sent: Monday, September 17, 2007 8:10 PM Subject: Re: Pietenpol-List: Question for Walt Evans and Don Emch > > > 4.5-inch Azusa drum brakes. Mine have aluminum backing plate but Walt > must have steel. Wish I had steel ones. > > Chris Tracy > Sacramento, Ca > Website at http://www.WestCoastPiet.com > > > ----- Original Message ----- > From: "Ryan Michals" <aircamperace(at)yahoo.com> > To: > Sent: Monday, September 17, 2007 4:28 PM > Subject: RE: Pietenpol-List: Question for Walt Evans and Don Emch > > >> >> >> What sort of wheel/brake set up are you running? >> >> >> -----Original Message----- >> From: "walt evans" <waltdak(at)verizon.net> >> To: >> Sent: 9/17/2007 6:58 PM >> Subject: Re: Pietenpol-List: Question for Walt Evans and Don Emch >> >> Chris, >> I've been going thru my old pics trying to find the right shot, but >> can't. >> these are the best I can do. >> BUT,,, >> The brake back plate, with shoes, is solid mounted to the axle, then >> whatever spacer I needed so the drum would position correctly over the >> shoes >> was used. It was also a bronze sleeve. And with the bronze sleeves in >> the >> wheel, it was bronze to bronze. >> I drilled small oil holes over each bronze sleeve bearing in the wheel >> hubs. >> I oil them annually. >> These are one of the things that I worried about when building/designing. >> Would the oil get on the shoes and ruin them? >> Don't really know what's going on inside the brakes,,,but they don't grab >> to >> get me into the horror situations of nosing over,,,and when I mash them >> during run-up, they hold. >> And since I was taught by a geat WW11 P-51 pilot, who always said, don't >> count on the brakes, fly like they're not there,,,,,,I only use them to >> slow >> down for fun. >> A newer instructor in the 90's (who used to drop cargo into an opening in >> the forrest, with a DC-3, while spiriling, with the load on a long rope) >> taught me that,,,when braking with a taildragger, if you use one brake >> and >> the opposite rudder, you may ground loop, but you'll never nose over. >> Sorry to ramble on >> Walt Evans >> NX140DL >> "No one ever learned anything by talking" >> ----- Original Message ----- >> From: "Catdesigns" <Catdesigns(at)comcast.net> >> To: >> Sent: Monday, September 17, 2007 3:57 PM >> Subject: Pietenpol-List: Question for Walt Evans and Don Emch >> >> >>> >>> >>> Walt and Don : >>> >>> I am using the same drum brakes you have and need some advice. What >>> kind >>> of material did you use for a spacer between the inner wheel bushing and >>> the brake backing plate? I was thinking of just slipping on a 1-inch >>> long >>> bronze sleeve. Any problem with running bronze against bronze? >>> >>> Anyone else using these brakes care to comment? >>> >>> Thanks >>> >>> Chris >>> >>> -------- >>> Chris Tracy >>> WestCoastPiet.com >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=134883#134883 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 18, 2007
That's absolutely great!! Ain't Life Grand. Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> Sent: Monday, September 17, 2007 9:18 PM Subject: Pietenpol-List: Re: Question for Walt Evans and Don Emch > > Hi Chris, > > What I did is very similar to Walt's. It's funny how similar our ships > are! I do have basically the same wheels and brakes. In looking at his > pictures I really only see one main difference. The piece of tubing that > makes up my hub is longer. It comes all the way out to the edge of the > brake drum. Instead of that tubing being about 6 1/2" it is about 8". > So I guess while it's on the airplane you wouldn't be able to see the > difference in Walt's and mine. I think a bronze bushing would be just > fine to make up the difference, just keep them well greased. Eventually I > want to get a hold of some 6" wheels and get some 8.50 X 6 tires and try > them out. When I do I plan to just make up the difference with bronze > bushings. > > Greasing them is very important. I made Larry Williams' hubs for his > plane. When I made them he assured me over the phone that his axle was > 1.500". I made them with the bushings at about 1.504". He said they were > a little tight when he put them on. The axle must have been a little > larger. I thought maybe we should open them up a little, but we never > did. He went ahead and flew up to Brodhead and Oshkosh. The morning > after the EAA guys interviewed him for the magazine article they wanted > him to go up and do some air to air shots. He started down the runway on > takeoff and the plane started to pull to one side. He stopped, taxied > back and tried again. Same thing, and almost ground looped. This time he > taxied to the repair tent. They had to beat the wheel off with a hammer. > The bushings were so tight and so dry they practically welded themselves > on to the axle. After filing, sanding and regreasing they were ready to > go again. And the photoshoot was completed. Le! > sson learned: have at least a few thousandths clearance fit, and file > grooves in the bushings to hold the grease. Then don't be afraid to > grease them up! If it's too tight, once the axle starts to warm up it > grows and of course that just makes it worse. > > Anyway, I really like the brakes. I really only use them for run up and > for taxiing on pavement around other airplanes and fuel pumps. With the > high pressure wheels on pavement it just likes to roll and roll. Just > another reason to stay away from pavement! Which by the way, on our > Brodhead/Barnstorming trip this year, I think we stopped at something > like 16 airports and never once had to land on pavement. No radio either. > Is that just great or what!! > > Don Emch > NX899DE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134944#134944 > > > ________________________________________________________________________________
Subject: Re: Piet biplane
Date: Sep 18, 2007
Brian, I'm not sure about the biplane conversion, but are you the guy I just read about in General Aviation News? Don Emch Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135135#135135 ________________________________________________________________________________
Subject: Extra Pietenpol project for sale...
Date: Sep 18, 2007
I just wanted to let everyone know I have an extra Pietenpol project for sale. It belonged to a friend that passed away and I bought it and now my wife says one has to go. It is fairly complete, but has no engine or instruments (compass is included and installed). For detailed description and photos please email me off list: MaxHegler(at)msn.com Thanks, Max ________________________________________________________________________________
Date: Sep 18, 2007
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
For what it's worth, I had a wife once that made me sell my J-3 Cub. She said "Either the airplane goes, or I go." I made a mistake and sold the airplane. Should have divorced her on the spot and saved myself 12 years of misery, as well as a good airplane. Now I've got a GOOD wife, one that actually enjoys flying, and even goes to Oshkosh with me. They are out there, but are not easy to find. This one even helps by bucking rivets on the RV10 project. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Max Hegler Sent: Tuesday, September 18, 2007 5:50 PM Subject: Pietenpol-List: Extra Pietenpol project for sale... I just wanted to let everyone know I have an extra Pietenpol project for sale. It belonged to a friend that passed away and I bought it and now my wife says one has to go. It is fairly complete, but has no engine or instruments (compass is included and installed). For detailed description and photos please email me off list: MaxHegler(at)msn.com Thanks, Max _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Sep 18, 2007
That would be me. http://www.generalaviationnews.com/editorial/articledetail.lasso?-token.key 14878&-token.src=index&-nothing Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Don Emch Sent: Tuesday, September 18, 2007 5:31 PM Subject: Pietenpol-List: Re: Piet biplane Brian, I'm not sure about the biplane conversion, but are you the guy I just read about in General Aviation News? Don Emch Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135135#135135 ________________________________________________________________________________
Subject: Re: Extra Pietenpol project for sale...
Date: Sep 18, 2007
YEP! Can't argue wisdom gained thru years of hard earned experience. "Wanted----- companion, co-pilot, rivet bucking and other aircraft building tools an asset, preference given to woman who owns airplane" Gordon ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Tuesday, September 18, 2007 3:05 PM Subject: RE: Pietenpol-List: Extra Pietenpol project for sale... For what it's worth, I had a wife once that made me sell my J-3 Cub. She said "Either the airplane goes, or I go." I made a mistake and sold the airplane. Should have divorced her on the spot and saved myself 12 years of misery, as well as a good airplane. Now I've got a GOOD wife, one that actually enjoys flying, and even goes to Oshkosh with me. They are out there, but are not easy to find. This one even helps by bucking rivets on the RV10 project. Jack Phillips NX899JP Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Max Hegler Sent: Tuesday, September 18, 2007 5:50 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Extra Pietenpol project for sale... I just wanted to let everyone know I have an extra Pietenpol project for sale. It belonged to a friend that passed away and I bought it and now my wife says one has to go. It is fairly complete, but has no engine or instruments (compass is included and installed). For detailed description and photos please email me off list: MaxHegler(at)msn.com Thanks, Max ">http://www.matronics.com/Navigator?Pietenpol-List ics.com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Sep 18, 2007
Well, I can't complain about the wife...she loves to fly and supports almost everything I do. The problem is my hanger/garage has 2 Pietenpols, 1 RV-7 project, 1 RV-10 project and an ultralight project...but only four of them are mine. Since I have 2 Pietenpols, she thought someone else might enjoy the build process... Max ----- Original Message ----- From: Phillips, Jack To: pietenpol-list(at)matronics.com Sent: Tuesday, September 18, 2007 6:05 PM Subject: RE: Pietenpol-List: Extra Pietenpol project for sale... For what it's worth, I had a wife once that made me sell my J-3 Cub. She said "Either the airplane goes, or I go." I made a mistake and sold the airplane. Should have divorced her on the spot and saved myself 12 years of misery, as well as a good airplane. Now I've got a GOOD wife, one that actually enjoys flying, and even goes to Oshkosh with me. They are out there, but are not easy to find. This one even helps by bucking rivets on the RV10 project. Jack Phillips NX899JP Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Max Hegler Sent: Tuesday, September 18, 2007 5:50 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Extra Pietenpol project for sale... I just wanted to let everyone know I have an extra Pietenpol project for sale. It belonged to a friend that passed away and I bought it and now my wife says one has to go. It is fairly complete, but has no engine or instruments (compass is included and installed). For detailed description and photos please email me off list: MaxHegler(at)msn.com Thanks, Max ">http://www.matronics.com/Navigator?Pietenpol-List ics.com _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
From: "Patrick Panzera" <Panzera@experimental-aviation.com>
Subject: The perfect t-shirt
Date: Sep 18, 2007
YEP! Can't argue wisdom gained thru years of hard earned experience. "Wanted----- companion, co-pilot, rivet bucking and other aircraft building tools an asset, preference given to woman who owns airplane" http://www.flycorvair.com/tshirt.html Pat ________________________________________________________________________________
Subject: Everett Law/JAX Law
Date: Sep 18, 2007
Brian, I was reading this today and could hardly believe it. It's really strange that I checked out the Matronics site this evening and you were on it! For those of you not familiar with this you need to check it out. In Jacksonville, FL you can work on your motorcycle, build furniture, build a dragster, or even a boat, but it is illegal to build an airplane in your home or garage!! Absolutely absurd!! AAAhhh!!! http://www.generalaviationnews.com/editorial/articledetail.lasso?-token.key=14878&-token.src=news&-nothing Brian, if there is anything I can do to help out your cause, let me know. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135174#135174 ________________________________________________________________________________
Date: Sep 18, 2007
From: "Glenn Thomas" <glennthomas(at)flyingwood.com>
Subject: Re: Everett Law/JAX Law
Some ideas... - How "enforced" is a fairly ridiculous law like that? (akin to "against the law in Storrs, Connecticut to wear your T-shirt inside out on Thursdays") - I would look at the consequences and probably press on with the project if there are no public canings involved. I can just see it on COPS when they raid the poor guy's house, find the cabane fittings on his work bench ("A-ha, what are these??") and then kick their way into the secret room in his basement that the spruce sniffing dogs lead them to, to find that he's been secretly building a fuselage and then they haul him out in cuffs making typical COPS self-congratulatory comments. - Who could tell what it is when it's uncovered? - According to my EAA chapter, an Air Camper isn't really a plane anyway. Sorry, I'll behave now. On 9/18/07, Don Emch wrote: > > Brian, > > I was reading this today and could hardly believe it. It's really strange > that I checked out the Matronics site this evening and you were on it! For > those of you not familiar with this you need to check it out. In > Jacksonville, FL you can work on your motorcycle, build furniture, build a > dragster, or even a boat, but it is illegal to build an airplane in your > home or garage!! Absolutely absurd!! AAAhhh!!! > > > http://www.generalaviationnews.com/editorial/articledetail.lasso?-token.key=14878&-token.src=news&-nothing > > Brian, if there is anything I can do to help out your cause, let me know. > > Don Emch > NX899DE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=135174#135174 > > -- Glenn Thomas Storrs, CT http://www.flyingwood.com ________________________________________________________________________________
Date: Sep 18, 2007
Tom, My GN-1 has Cub gear and Cub wheels and tires. It has 1 degree out at the top camber. That is at rest no pilot or passenger aboard. Skip > I'm finishing the landing gear (J3 clone with springs) for my GN-1 -- does anybody have a suggested amount of camber to use? > > Thanks in advance, > > Tom Bernie > Gloucester Mass ________________________________________________________________________________
Subject: Re: Everett Law/JAX Law - LARGE model plane
Date: Sep 18, 2007
I have built very large scale model airplanes before. My largest was a 40% scale Giles. Who's to say you decide not to make a 1:1 scale model of the Aircamper? And then maybe the day after you finish it you decide that you might want to ride in it afterall? I guess my question is... what is the legal definition of airplane according to that ordinance? does it exempt radio control model airplane builders? DJ Vegh former GN-1 builder www.azchoppercam.com ----- Original Message ----- From: Glenn Thomas To: pietenpol-list(at)matronics.com Sent: Tuesday, September 18, 2007 6:57 PM Subject: Re: Pietenpol-List: Everett Law/JAX Law Some ideas... a.. How "enforced" is a fairly ridiculous law like that? (akin to "against the law in Storrs, Connecticut to wear your T-shirt inside out on Thursdays") b.. I would look at the consequences and probably press on with the project if there are no public canings involved. I can just see it on COPS when they raid the poor guy's house, find the cabane fittings on his work bench ("A-ha, what are these??") and then kick their way into the secret room in his basement that the spruce sniffing dogs lead them to, to find that he's been secretly building a fuselage and then they haul him out in cuffs making typical COPS self-congratulatory comments. c.. Who could tell what it is when it's uncovered? d.. According to my EAA chapter, an Air Camper isn't really a plane anyway. Sorry, I'll behave now. On 9/18/07, Don Emch wrote: Brian, I was reading this today and could hardly believe it. It's really strange that I checked out the Matronics site this evening and you were on it! For those of you not familiar with this you need to check it out. In Jacksonville, FL you can work on your motorcycle, build furniture, build a dragster, or even a boat, but it is illegal to build an airplane in your home or garage!! Absolutely absurd!! AAAhhh!!! http://www.generalaviationnews.com/editorial/articledetail.lasso?-token.k ey=14878&-token.src=news&-nothing Brian, if there is anything I can do to help out your cause, let me know. Don Emch NX899DE Read this topic online here: Storrs, CT http://www.flyingwood.com ________________________________________________________________________________
Date: Sep 18, 2007
Subject: Piet
We had a hard landing in the Piet. For those of you following the drama, I can't lay claim to that particular landing (but my previous landings caused the tail gear to collapse). I have attached some photos of the damage. Basically, the front left gear strut was forced up into the fuselage, putting a twist in the longeron (cracked it slightly) and pretty much breaking the surrounding plywood floor and gusset. It may be that we can splice the longeron and replace the floorboard plywood. We plan to take this opportunity to rethink the gear and wing attach points. Maybe we will use a channel piece between the gear legs like Grega calls for, and maybe even use Grega wing attach fittings rather than the Piet tang like at DJ Vegh's websites: http://www.imagedv.com/aircamper/Log/image-pages/04-22-02.htm http://www.imagedv.com/aircamper/Log/image-pages/04-30-02.htm http://www.imagedv.com/aircamper/Log/image-pages/05-04-02.htm http://www.imagedv.com/aircamper/Log/image-pages/05-30-02.htm http://www.imagedv.com/aircamper/Log/image-pages/06-05-02.htm In the UK, they seem to use a gear that is a hybrid of Piet, Grega, and Piper. Here's the best photo I could find of the UK landing gear: http://www.pietenpolclub.co.uk/gallery/displayimage.php?pid=707&fullsize=1 Several of the UK Piet's are built this way, but I couldn't find good photos. This one even uses the Grega front pieces for landing gear AND wing attach points: http://www.pietenpolclub.co.uk/gallery/displayimage.php?pid=330&fullsize=1 I'm reading AC 43.13 for acceptable methods for spar splicing. I can't find anything for longeron splicing. My concern with this guideline is that the Piet longeron takes a pounding with landing loads right at this spot (obviously), so I don't know if AC 43.13 is sufficient to this specific need. Any thoughts appreciated. Jeff ________________________________________________________________________________
Date: Sep 18, 2007
Jack, Can I order one wife to go from the orginial stock you found your wife from??? Last one walked away after 5 years! Then... she found herself a nice attorney and cleaned out both my pockets! Plenty of baby oil in my eyes! Sincerely, KM Heide Fargo, ND "Phillips, Jack" wrote: For what it's worth, I had a wife once that made me sell my J-3 Cub. She said "Either the airplane goes, or I go." I made a mistake and sold the airplane. Should have divorced her on the spot and saved myself 12 years of misery, as well as a good airplane. Now I've got a GOOD wife, one that actually enjoys flying, and even goes to Oshkosh with me. They are out there, but are not easy to find. This one even helps by bucking rivets on the RV10 project. Jack Phillips NX899JP Raleigh, NC --------------------------------- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Max Hegler Sent: Tuesday, September 18, 2007 5:50 PM Subject: Pietenpol-List: Extra Pietenpol project for sale... I just wanted to let everyone know I have an extra Pietenpol project for sale. It belonged to a friend that passed away and I bought it and now my wife says one has to go. It is fairly complete, but has no engine or instruments (compass is included and installed). For detailed description and photos please email me off list: MaxHegler(at)msn.com Thanks, Max ">http://www.matronics.com/Navigator?Pietenpol-List ics.com Kenneth M. Heide, BA,CPO,FAAOP --------------------------------- Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase. ________________________________________________________________________________
Date: Sep 18, 2007
Brian........ STAY THE COURSE!!!! My father owns a piece of commercial property along the bay in Duluth, MN. It has been zoned C-4 for many years. He can build up to an 800 foot ore boat if he wishes. Yes, the neighbors complained when he would work on his 50 foot cruiser. Complaint were flying in all directions. His good friend "Mr. Attorney" reminded all the neighbors at a community gathering of the C-4 zoning and all "legal cost" if his client were to seek damages. Amazing.....never heard another peep in all these years..... KM Heide Brian Kraut wrote: That would be me. http://www.generalaviationnews.com/editorial/articledetail.lasso?-token.key 14878&-token.src=index&-nothing Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Don Emch Sent: Tuesday, September 18, 2007 5:31 PM Subject: Pietenpol-List: Re: Piet biplane Brian, I'm not sure about the biplane conversion, but are you the guy I just read about in General Aviation News? Don Emch Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135135#135135 Kenneth M. Heide, BA,CPO,FAAOP --------------------------------- Yahoo! oneSearch: Finally, mobile search that gives answers, not web links. ________________________________________________________________________________
Date: Sep 19, 2007
Skip, I need to drill holes in the tubes that goes through the center of the compression springs to pin the tubes to the collars that slide above the springs. The location of the holes will determine the camber of the wheels. What I'm lookin for is the starting camber angle to establish with zero weight on the gear so as to arrive at something like 1 degree empty. Maby I can figure it backwards (if you use springs) what increase in camber do you think you experience with a full load? Thanks for the response, Tom Bernie Gloucester, Mass -----Original Message----- >From: Skip Gadd <skipgadd(at)earthlink.net> >Sent: Sep 18, 2007 10:19 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: wheel camber > > >Tom, >My GN-1 has Cub gear and Cub wheels and tires. It has 1 degree out at the >top camber. That is at rest no pilot or passenger aboard. >Skip > > > >> I'm finishing the landing gear (J3 clone with springs) for my GN-1 -- >does anybody have a suggested amount of camber to use? >> >> Thanks in advance, >> >> Tom Bernie >> Gloucester Mass > > ________________________________________________________________________________
From: "Richard and Kathryn Davis" <kbrooks(at)aptalaska.net>
Subject: re Extra Pietenpol Project for Sale
Date: Sep 19, 2007
Guess I am one of the lucky ones as well my wife is building her own Pietenpol alongside of my Aerial.She is a very talented woman she can stitch ribs faster and straighter than anyone I know,she can gas weld airframes do tin work and event isn't afraid to jump in when we have an engine to overhaul for the business. Too bad she couldn't be Cloned so those who have the wives that aren't receptive to our passions of flight and building could be replaced. Anyhow that's my 3 cents worth,wishing all the group safe flying and soft landings ________________________________________________________________________________
Date: Sep 19, 2007
Must be nice. ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard and Kathryn Davis Sent: September 19, 2007 11:25 AM Subject: Pietenpol-List: re Extra Pietenpol Project for Sale Guess I am one of the lucky ones as well my wife is building her own Pietenpol alongside of my Aerial.She is a very talented woman she can stitch ribs faster and straighter than anyone I know,she can gas weld airframes do tin work and event isn't afraid to jump in when we have an engine to overhaul for the business. Too bad she couldn't be Cloned so those who have the wives that aren't receptive to our passions of flight and building could be replaced. Anyhow that's my 3 cents worth,wishing all the group safe flying and soft landings ________________________________________________________________________________
Subject: Piet
Date: Sep 20, 2007
Jeff, I build my undercarriage from the UK plans. It has survived quite well with my landings, although I did buckle it on a ground loop (side ways into an earth bank). Check out http://www.cpc-world.com for some pictures, Page 5 of the Build pictures has the construction. The U/C and wing strut fittings are combined. A steel strap underneath the fuse keeps both fittings together in a hard landing (I put one on the rear fitting as well). Cheers Peter Wonthaggi Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Sent: Wednesday, 19 September 2007 1:59 PM Subject: Pietenpol-List: Piet We had a hard landing in the Piet. For those of you following the drama, I can't lay claim to that particular landing (but my previous landings caused the tail gear to collapse). I have attached some photos of the damage. Basically, the front left gear strut was forced up into the fuselage, putting a twist in the longeron (cracked it slightly) and pretty much breaking the surrounding plywood floor and gusset. It may be that we can splice the longeron and replace the floorboard plywood. We plan to take this opportunity to rethink the gear and wing attach points. Maybe we will use a channel piece between the gear legs like Grega calls for, and maybe even use Grega wing attach fittings rather than the Piet tang like at DJ Vegh's websites: http://www.imagedv.com/aircamper/Log/image-pages/04-22-02.htm http://www.imagedv.com/aircamper/Log/image-pages/04-30-02.htm http://www.imagedv.com/aircamper/Log/image-pages/05-04-02.htm http://www.imagedv.com/aircamper/Log/image-pages/05-30-02.htm http://www.imagedv.com/aircamper/Log/image-pages/06-05-02.htm In the UK, they seem to use a gear that is a hybrid of Piet, Grega, and Piper. Here's the best photo I could find of the UK landing gear: http://www.pietenpolclub.co.uk/gallery/displayimage.php?pid=707&fullsize=1 Several of the UK Piet's are built this way, but I couldn't find good photos. This one even uses the Grega front pieces for landing gear AND wing attach points: http://www.pietenpolclub.co.uk/gallery/displayimage.php?pid=330&fullsize=1 I'm reading AC 43.13 for acceptable methods for spar splicing. I can't find anything for longeron splicing. My concern with this guideline is that the Piet longeron takes a pounding with landing loads right at this spot (obviously), so I don't know if AC 43.13 is sufficient to this specific need. Any thoughts appreciated. Jeff ________________________________________________________________________________
Subject: Re: Piet
Date: Sep 19, 2007
OK I wondered what happened to you on Saturday. I guess you are forgiven. Sorry about the mishap. Barry PS: We had 3600 in attendance at Wings & Wheels, and a lot of fun. ________________________________________________________________________________
Date: Sep 19, 2007
Glenn, That was great!!! Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135349#135349 ________________________________________________________________________________
Date: Sep 19, 2007
How enforced is an interresting question. They passed the law over a year ago and I have been the only one ever cited on it. So far it is to the tune of over $12,000 in legal fees and $1,000 in fines. The law has two parts, one for storage not in an enclosed structure, and one for working on an aircraft even in your enclosed garage. Obviously, they have only cited me on the storage part of the law and they know that they would never win in court if they tried citing anyone for working on one inside because it is completely unconstitutional and they could never prove it anyway. See www.jaxairplane.com for more information. There are a few things you can do to help. After fighting this for a long time we have finally gotten a council member to sponsor a repeal. It goes through several steps. The planning department looks at it and makes a recommendation. Then the Planning Commission has a public hearing and makes a recommendation to the Land Use and Zoning Board (6 members of the City Council). They have another hearing and make a recommendation to the Full City council (19 members). So far the planning department recommended denial, the planning commission unanimously recommended approval. Yesterday the LUZ comittiee voted approval. Next step is on next Tuesday when the council votes on it. You can help by emailing them and asking them to approve bill 2007-0955 which will repeal the law. Their addresses are here: http://www.coj.net/City+Council/City+Council+Members.htm You can also help by donating to EAA Chapter 193 to help with the legal expenses that we have had so far by clicking here: http://www.jaxairplane.com/contribute.htm. We have had about $4,000 in donations so far, but $12,000 in legal fees. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Glenn Thomas Sent: Tuesday, September 18, 2007 9:58 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Everett Law/JAX Law Some ideas... a.. How "enforced" is a fairly ridiculous law like that? (akin to "against the law in Storrs, Connecticut to wear your T-shirt inside out on Thursdays") b.. I would look at the consequences and probably press on with the project if there are no public canings involved. I can just see it on COPS when they raid the poor guy's house, find the cabane fittings on his work bench ("A-ha, what are these??") and then kick their way into the secret room in his basement that the spruce sniffing dogs lead them to, to find that he's been secretly building a fuselage and then they haul him out in cuffs making typical COPS self-congratulatory comments. c.. Who could tell what it is when it's uncovered? d.. According to my EAA chapter, an Air Camper isn't really a plane anyway. Sorry, I'll behave now. On 9/18/07, Don Emch wrote: Brian, I was reading this today and could hardly believe it. It's really strange that I checked out the Matronics site this evening and you were on it! For those of you not familiar with this you need to check it out. In Jacksonville, FL you can work on your motorcycle, build furniture, build a dragster, or even a boat, but it is illegal to build an airplane in your home or garage!! Absolutely absurd!! AAAhhh!!! http://www.generalaviationnews.com/editorial/articledetail.lasso?-token. key=14878&-token.src=news&-nothing Brian, if there is anything I can do to help out your cause, let me know. Don Emch NX899DE Read this topic online here: Storrs, CT http://www.flyingwood.com ________________________________________________________________________________
Date: Sep 19, 2007
I just an email to all council members asking to approve the bill. I also made sure I commented on my opinion of this mess. DJ ----- Original Message ----- From: Brian Kraut To: pietenpol-list(at)matronics.com Sent: Wednesday, September 19, 2007 3:03 PM Subject: RE: Pietenpol-List: Everett Law/JAX Law How enforced is an interresting question. They passed the law over a year ago and I have been the only one ever cited on it. So far it is to the tune of over $12,000 in legal fees and $1,000 in fines. The law has two parts, one for storage not in an enclosed structure, and one for working on an aircraft even in your enclosed garage. Obviously, they have only cited me on the storage part of the law and they know that they would never win in court if they tried citing anyone for working on one inside because it is completely unconstitutional and they could never prove it anyway. See www.jaxairplane.com for more information. There are a few things you can do to help. After fighting this for a long time we have finally gotten a council member to sponsor a repeal. It goes through several steps. The planning department looks at it and makes a recommendation. Then the Planning Commission has a public hearing and makes a recommendation to the Land Use and Zoning Board (6 members of the City Council). They have another hearing and make a recommendation to the Full City council (19 members). So far the planning department recommended denial, the planning commission unanimously recommended approval. Yesterday the LUZ comittiee voted approval. Next step is on next Tuesday when the council votes on it. You can help by emailing them and asking them to approve bill 2007-0955 which will repeal the law. Their addresses are here: http://www.coj.net/City+Council/City+Council+Members.htm You can also help by donating to EAA Chapter 193 to help with the legal expenses that we have had so far by clicking here: http://www.jaxairplane.com/contribute.htm. We have had about $4,000 in donations so far, but $12,000 in legal fees. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Glenn Thomas Sent: Tuesday, September 18, 2007 9:58 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Everett Law/JAX Law Some ideas... a.. How "enforced" is a fairly ridiculous law like that? (akin to "against the law in Storrs, Connecticut to wear your T-shirt inside out on Thursdays") b.. I would look at the consequences and probably press on with the project if there are no public canings involved. I can just see it on COPS when they raid the poor guy's house, find the cabane fittings on his work bench ("A-ha, what are these??") and then kick their way into the secret room in his basement that the spruce sniffing dogs lead them to, to find that he's been secretly building a fuselage and then they haul him out in cuffs making typical COPS self-congratulatory comments. c.. Who could tell what it is when it's uncovered? d.. According to my EAA chapter, an Air Camper isn't really a plane anyway. Sorry, I'll behave now. On 9/18/07, Don Emch wrote: > Brian, I was reading this today and could hardly believe it. It's really strange that I checked out the Matronics site this evening and you were on it! For those of you not familiar with this you need to check it out. In Jacksonville, FL you can work on your motorcycle, build furniture, build a dragster, or even a boat, but it is illegal to build an airplane in your home or garage!! Absolutely absurd!! AAAhhh!!! http://www.generalaviationnews.com/editorial/articledetail.lasso?-token.k ey=14878&-token.src=news&-nothing Brian, if there is anything I can do to help out your cause, let me know. Don Emch NX899DE Read this topic online here: Storrs, CT http://www.flyingwood.com href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Sep 19, 2007
Tom, My GN-1 has bungees. The Piet I am building does has springs. I am planning to adjust the spring legs so the wheels have 0 degrees camber at gross. Skip > Maby I can figure it backwards (if you use springs) what increase in camber do you think you experience with a full load? > Thanks for the response, > Tom Bernie > Gloucester, Mass ________________________________________________________________________________
Date: Sep 20, 2007
Skip, Guess I'll initially rig my gear for 5 degrees negative camber, then pin them at the correct point when the plane is finished. Thanks for the input. Tom Bernie Gloucester, Mass -----Original Message----- >From: Skip Gadd <skipgadd(at)earthlink.net> >Sent: Sep 19, 2007 10:04 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: wheel camber > > >Tom, >My GN-1 has bungees. The Piet I am building does has springs. I am planning >to adjust the spring legs so the wheels have 0 degrees camber at gross. >Skip > > >> Maby I can figure it backwards (if you use springs) what increase in >camber do you think you experience with a full load? >> Thanks for the response, >> Tom Bernie >> Gloucester, Mass > > ________________________________________________________________________________
From: "MICHAEL SILVIUS" <M.Silvius(at)worldnet.att.net>
Subject: Re: Potential Auto engine for Pietes
Date: Sep 20, 2007
Some further research in to the rotary engine reveals a distinct possibility for a Piet. http://www.atkinsrotary.com/index.php?pag=50-19 Michael ________________________________________________________________________________
Subject: Sanding ribs
Date: Sep 20, 2007
The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am finding that it is very easy to sand into the spruce sticks, especially on the undercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Sep 20, 2007
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: Re: Sanding ribs
Brian, A router works fast and very well... Brian Kraut wrote: The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am finding that it is very easy to sand into the spruce sticks, especially on the undercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com Kenneth M. Heide, BA,CPO,FAAOP --------------------------------- Building a website is a piece of cake. ________________________________________________________________________________
Date: Sep 20, 2007
That's how I did mine...1" belt sander with a fine, slightly worn belt and held the rib at an angle to the belt so it just knocks off the gusset material. A new belt would be way too hard to control. I used the unsupported part of the belt. I did lightly tick the corner of the spruce once in a while, not a biggie. Just have to take it slow and careful. That was the only efficient way I could think of to do it but there are probably others......Ed G. Fl. West coast ----- Original Message ----- From: Brian Kraut<mailto:brian.kraut(at)engalt.com> To: pietenpol-list(at)matronics.com Sent: Thursday, September 20, 2007 5:19 PM Subject: Pietenpol-List: Sanding ribs The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am finding that it is very easy to sand into the spruce sticks, especially on the undercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> ________________________________________________________________________________
Subject: Cabane strut and fitting question
Date: Sep 20, 2007
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Help guys, Checked pictures and archives and could use your input. My cabane fittings are about =BE in wide ID (where the strut connects). My aluminum (Barry Davis) struts are a little over an inch wide OD. Is it better to have the strut fit OVER the fitting, inside the fitting or attach to the fitting via internal block that extends out past the strut. That's about clear as mud, sorry! And thanks! Jack Textor ________________________________________________________________________________
Date: Sep 20, 2007
Brian, I first used a router to trim, and then beveled the edges on my 12" disk sander. Jack Textor ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Brian Kraut Sent: Thursday, September 20, 2007 4:19 PM Subject: Pietenpol-List: Sanding ribs The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am finding that it is very easy to sand into the spruce sticks, especially on the undercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Sep 20, 2007
Router with a laminate cut-off bit. Jim Lathrop On 9/20/07, Brian Kraut wrote: > > The fastest way to sand the little overlaps where the plywood gussets > hang past the spruce sticks on the ribs is to use a belt sander, but I am > finding that it is very easy to sand into the spruce sticks, especially on > the undercambered bottoms of the ribs. How have the rest of you sanded > them? > > > Brian Kraut > Engineering Alternatives, Inc. > www.engalt.com > > ** > > * > > > * > > ________________________________________________________________________________
Date: Sep 20, 2007
My Dremel tool came with a router attachment. It took awhile to set up, but then it was guaranteed to cut the ply off at 45 degrees and not touch the spruce. Skip ----- Original Message ----- From: Brian Kraut Sent: 9/20/2007 5:24:03 PM Subject: Pietenpol-List: Sanding ribs The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am finding that it is very easy to sand into the spruce sticks, especially on the undercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Sep 20, 2007
Router, with a flush cut bit on a router table. Steve e From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Brian Kraut Sent: Thursday, September 20, 2007 3:19 PM Subject: Pietenpol-List: Sanding ribs The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am findin g that it is very easy to sand into the spruce sticks, especially on the un dercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Subject: Re: Cabane strut and fitting question
Date: Sep 20, 2007
Use an internal block inside the strut then go down to 3/4" outside. Check out a Cessna 150 for ideas. BED ----- Original Message ----- From: Jack T. Textor To: pietenpol-list(at)matronics.com Sent: Thursday, September 20, 2007 5:53 PM Subject: Pietenpol-List: Cabane strut and fitting question Help guys, Checked pictures and archives and could use your input. My cabane fittings are about =BE in wide ID (where the strut connects). My aluminum (Barry Davis) struts are a little over an inch wide OD. Is it better to have the strut fit OVER the fitting, inside the fitting or attach to the fitting via internal block that extends out past the strut. That's about clear as mud, sorry! And thanks! Jack Textor ________________________________________________________________________________
Date: Sep 20, 2007
Brian, I used my beloved Dremmel tool. Fitted with the small drum sander. Utilizes the hand techneque, but you can blend them down nicely. then when you get them like the pics, you can go over them with a piece of 1X2 covered in sandpaper to get anything sticking up. Ain't Life Grand Walt Evans NX140DL "No one ever learned anything by talking" ----- Original Message ----- From: Brian Kraut To: pietenpol-list(at)matronics.com Sent: Thursday, September 20, 2007 5:19 PM Subject: Pietenpol-List: Sanding ribs The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am finding that it is very easy to sand into the spruce sticks, especially on the undercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com ________________________________________________________________________________
Date: Sep 20, 2007
I will give that a try. I had actually thought of that a while after I posted the question. The fact that I went to the store today to get some laminate cut-off bits and a router table to cut some aluminum ribs for a BD-4 with a thick aluminum template I have for them should have made me think of it a little sooner. Duh. Then I will just hand sand them at a slight angle after they are routed. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jim Lathrop Sent: Thursday, September 20, 2007 5:52 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Sanding ribs Router with a laminate cut-off bit. Jim Lathrop On 9/20/07, Brian Kraut wrote: The fastest way to sand the little overlaps where the plywood gussets hang past the spruce sticks on the ribs is to use a belt sander, but I am finding that it is very easy to sand into the spruce sticks, especially on the undercambered bottoms of the ribs. How have the rest of you sanded them? Brian Kraut Engineering Alternatives, Inc. www.engalt.com
http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com ________________________________________________________________________________
Date: Sep 20, 2007
Here's a link to a picture of the router option. The router with the laminate bit really takes all the risk out of the process and it comes out perfectly every time. http://www.flyingwood.com/index.asp?page=13&filter=0 -------- Glenn Thomas N????? http://www.flyingwood.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135582#135582 ________________________________________________________________________________
Date: Sep 20, 2007
Another option, just for the record. I've also used a standard block plane with a sharp blade. You can knock off the edges and give it a chamfer with just a few strokes. Steve e -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Glenn Thomas Sent: Thursday, September 20, 2007 7:01 PM Subject: Pietenpol-List: Re: Sanding ribs Here's a link to a picture of the router option. The router with the laminate bit really takes all the risk out of the process and it comes out perfectly every time. http://www.flyingwood.com/index.asp?page=13&filter=0 -------- Glenn Thomas N????? http://www.flyingwood.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=135582#135582 ________________________________________________________________________________
Date: Sep 21, 2007
Subject: Corvair running grrrrrrreat!
Hello group, 20 +hrs and counting on the new rebuilt corvair. I have flown over 20hrs in the last 30 days, thats insane!! I just keep putting gas in and pushing the throttle in and going up. Took my wife up as the first crash test dummy, (after using dead weight of course), and she flies good. We flew 20 miles to a pankake breakfast last sat am when it was 44 degrees F, and had fun. Only problem was my frozzen fore head, she never complained. I also took a 6ft 4in fellow I work with flying last weekend and he enjoyed the hell out of it, except getting in the front hole. We have about 25 hrs on it in the last month and I must say, It eats Cubs for dinner, on climb and cruise. I am still coming in a bit hot with 2 pepole aboard to ease the weight on to the mains (wheel landings) as we need at least 1 more wrap on our bungees to stiffen up the gear for the increased weight. Dad came up and stold the wheels to put on some 8.00-6 tires, so she is up on blocks for the time being, but he should be up tommorow and take Mom up for her 1st open cockpit ride with dad since she was in her early 20's. I hope I am home to see it. Hoping to make at least a few more fly ins this fall before the snow starts flying. Shad NX92GB --------------------------------- Building a website is a piece of cake. ________________________________________________________________________________
Subject: Model A eng Hot
Date: Sep 22, 2007
Gentelman: While flying 920Y today after working on a radiator pin hole. We top off the coolant, and filled the gas tank with 100 LL. The first take off everything was good untill downwind when the water temp rose to about 200 degrees. On base and final the temp droped to 170 degrees. So after the second take off the temp went to 200 again. So we cut the pattern short and landed, while taxi in I started to get some white smoke from the #4 exhaust pipe. After shut down I was only able to add about one cup of coolent. Pulled the # 4 plug and found some water in the cylinder. What are your thoughts? As to jump in temp and smoke. Chet ________________________________________________________________________________
Subject: first flight
Date: Sep 22, 2007
Hey all I finally got to fly the new Piet today. That radial engine really has some kick. The tail comes up quickly and it is very smooth in flight. A special thanks to all who helped in the building process, especially the crew at Sun n Fun where the components were build, Skip, P.F. and all the others. Dick N. ________________________________________________________________________________
Date: Sep 22, 2007
That is beautifull. Is that one of the Rotec radials? I love the external elevator horn. Gives it a great antique look. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Dick Navratil Sent: Saturday, September 22, 2007 10:43 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: first flight Hey all I finally got to fly the new Piet today. That radial engine really has some kick. The tail comes up quickly and it is very smooth in flight. A special thanks to all who helped in the building process, especially the crew at Sun n Fun where the components were build, Skip, P.F. and all the others. Dick N. ________________________________________________________________________________
Date: Sep 22, 2007
Blown head gasket or a cracked block. If you start it up with the radiator cap off you should be able to feel exhaust pulses coming out the radiator. Brian Kraut Engineering Alternatives, Inc. www.engalt.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Chet's Mail Sent: Saturday, September 22, 2007 10:32 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Model A eng Hot Gentelman: While flying 920Y today after working on a radiator pin hole. We top off the coolant, and filled the gas tank with 100 LL. The first take off everything was good untill downwind when the water temp rose to about 200 degrees. On base and final the temp droped to 170 degrees. So after the second take off the temp went to 200 again. So we cut the pattern short and landed, while taxi in I started to get some white smoke from the #4 exhaust pipe. After shut down I was only able to add about one cup of coolent. Pulled the # 4 plug and found some water in the cylinder. What are your thoughts? As to jump in temp and smoke. Chet ________________________________________________________________________________
Subject: Re: first flight
Date: Sep 22, 2007
Dick, Congratulations! My wife really liked the looks of your Piet and wants me to switch from the Model A to the Rotec...says it might be my Christmas present. I may be seeking you out for guidance... Take Care, Max ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: Saturday, September 22, 2007 9:42 PM Subject: Pietenpol-List: first flight Hey all I finally got to fly the new Piet today. That radial engine really has some kick. The tail comes up quickly and it is very smooth in flight. A special thanks to all who helped in the building process, especially the crew at Sun n Fun where the components were build, Skip, P.F. and all the others. Dick N. ________________________________________________________________________________
Date: Sep 23, 2007
Very good, Dick! Can you provide some details like climb rate, cg location, weight, how it handles, etc... Greg C. ----- Original Message ----- From: Dick Navratil To: pietenpol-list(at)matronics.com Sent: Saturday, September 22, 2007 9:42 PM Subject: Pietenpol-List: first flight Hey all I finally got to fly the new Piet today. That radial engine really has some kick. The tail comes up quickly and it is very smooth in flight. A special thanks to all who helped in the building process, especially the crew at Sun n Fun where the components were build, Skip, P.F. and all the others. Dick N. ________________________________________________________________________________
Date: Sep 23, 2007
Congrats Dick, really like the all wood look. When are you getting started on Piet number three? Rick On 9/22/07, Dick Navratil wrote: > > Hey all > I finally got to fly the new Piet today. That radial engine really has > some kick. The tail comes up quickly and it is very smooth in flight. > A special thanks to all who helped in the building process, especially the > crew at Sun n Fun where the components were build, Skip, P.F. and all the > others. > Dick N. > > -- Rick Holland ObjectAge Ltd. Castle Rock, Colorado ________________________________________________________________________________
Date: Sep 23, 2007
Subject: cockpit cowl attachment
Piet Group, My question is regarding how to attach the aluminum cockpit cowl to the longerons. I am referring to the cowls that the windshields will set on. Have you guys found that it is better to attach another piece of wood or aluminum to the top of the longeron, so not to screw into the longerons or to simply screw into the longerons? Is a small wood screw the suggested hardware to use if attaching to the longerons? My concern is that the hole may open up after the screw is turned in and out a few times during the building process. Thank you for your thoughts and congratulations to the folks with recent first flights and successes. John Greenville, Wisconsin --------------------------------- Need a vacation? Get great deals to amazing places on Yahoo! Travel. ________________________________________________________________________________
Date: Sep 23, 2007
Subject: Re: cockpit cowl attachment
In a message dated 9/23/2007 3:08:32 PM Central Daylight Time, johnegan99(at)yahoo.com writes: My question is regarding how to attach the aluminum cockpit cowl to the longerons. John, I glued a small 1/4" strip along the otbd edge of the longerons, and used small screws through the cockpit cowl (spaced about 3" apart) that go into the 1/4" strip, so as not to interfere with the integrity of the longerons. Chuck G. NX770CG ________________________________________________________________________________
Date: Sep 23, 2007
In a message dated 9/22/2007 9:47:06 PM Central Daylight Time, horzpool(at)goldengate.net writes: I finally got to fly the new Piet today. That radial engine really has some kick. The tail comes up quickly and it is very smooth in flight. Hey, that's some great news, Dick !! Sure is a beautiful job you did there. You're going to get a lot of attention with that one. Hummmmm...I wonder how much smoke you can make with all those cylinders... Chuck G. NX770CG ________________________________________________________________________________
Date: Sep 23, 2007
I used machine screw inserts. They have machine threads on the inside, and wood screw threads on the outside. You drill a 1/4" hole in the wood, the n thread the insert into the wood using a hex allen wrench. More surface a rea, and it doesn't wallow with repeated use. Steve E. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Rcaprd(at)aol.com Sent: Sunday, September 23, 2007 2:30 PM Subject: Re: Pietenpol-List: cockpit cowl attachment In a message dated 9/23/2007 3:08:32 PM Central Daylight Time, johnegan99@y ahoo.com writes: My question is regarding how to attach the aluminum cockpit cowl to the lon gerons. John, I glued a small 1/4" strip along the otbd edge of the longerons, and used s mall screws through the cockpit cowl (spaced about 3" apart) that go into t he 1/4" strip, so as not to interfere with the integrity of the longerons. Chuck G. NX770CG ________________________________ See what's new at Make AOL Your Homepage. ________________________________________________________________________________
Date: Sep 23, 2007
Subject: Re: Fwd: Re: Wood grain?
List, I am a little confused by AC 41.13's explanation of wood grain. I thought I had a pretty good idea of what to look for, and trusted A/S's quality, but after gluing up both sides, I've read Glenn's posts and have taken another look at my wood. We wanted everyone else's opinion. Thank you, Ryan Note: forwarded message attached. --------------------------------- X-Apparently-To: aircamperace(at)yahoo.com via 68.180.197.120; Sun, 23 Sep 2007 15:07:01 -0700 X-Originating-IP: [209.85.146.179] Authentication-Results: mta508.mail.mud.yahoo.com from=flyingwood.com; domainkeys=neutral (no sig) Received: from 209.85.146.179 (EHLO wa-out-1112.google.com) (209.85.146.179) Received: by wa-out-1112.google.com with SMTP id j32so1750452waf Received: by 10.114.79.1 with SMTP id c1mr2708456wab.1190585217858; Date: Sun, 23 Sep 2007 18:06:57 -0400 From: "Glenn Thomas" <glennthomas(at)flyingwood.com> Subject: Re: Wood grain? In-Reply-To: <46f6a4ee.1d35640a.1f02.fffff370SMTPIN_ADDED(at)mx.google.com> MIME-Version: 1.0 Content-Type: multipart/mixed; boundary="----=_Part_46216_11624287.1190585217822" References: <46f6a4ee.1d35640a.1f02.fffff370SMTPIN_ADDED(at)mx.google.com> Content-Length: 186455 ------=_Part_46216_11624287.1190585217822 Content-Type: multipart/alternative; boundary="----=_Part_46217_15210446.1190585217822" ------=_Part_46217_15210446.1190585217822 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 7bit Content-Disposition: inline Hi Ryan, Isn't this fun? (Figuring out what is what in the process of building an airplane) I learned a lot from questioning what I received from A/S and then getting 43.13 to help me. I learned quite a bit but I am in now way an authority. What I learned makes sense to me now and I will explain what I have come to understand in terms of grain and slope. >From the pictures you sent it would seem to me that the wood would be OK if the end of the longeron had a pretty near vertical grain. That is to say that the lines in the wood go almost perfectly perpendicular to the sides of the cut. (Grain2.jpg) It's hard to describe in words so I drew a few pictures that are attached. If you think about how the tree grows if those lines are up and down, the lines should be pretty straight on the plane that cuts perpendicular to the vertical grain. The other 2 sides are insignificant. The tree grows straight but not as straight as a measurement instrument. So as the grain lines on Side A wave in and out of the cut line you will see a very inconsistent grain display on Side B which I think is what you would expect. If you think about it, you would not see any grain lines on side B if the grain was perfect. Right? It looks very erratic but side A is what you are focusing your attention on with 43.13. On the other hand, if the grain on the end of the longeron is at an angle (45 degrees) you would see grain lines on all sides. (Grain3.jpg) I would like to post this to the forum if you don't mind since there are people that are much more knowledgeable than I. I just happen to be one of the many builders that made a website (and I am very fussy about everything but not a Pietenpol or homebuilt airplane guru). This is a very good question that a lot of people probabaly don't question enough. If my explanation doesn't make sense, call me. It took me a while to become comfortable with the grain slope dilemma. (860) 487-4860 any time If you don't mind please post this to the forum. I would like to hear what others have to say on this regarding what I have learned. Good luck. Glenn On 9/23/07, Ryan Michals wrote: > > Glenn, you must be the authority on wood after your ordeal with A/S. I > haven't fully deciphered 43.13 yet. Could I get your opinion of my > longeron grain? Attached are a few photos. > > > Thank you, > > > Ryan Michals > > NXxxxCC > > Clover Clipper > > > *This message sent from a hand-held wireless device. > -- Glenn Thomas Storrs, CT http://www.flyingwood.com ------=_Part_46217_15210446.1190585217822 Content-Type: text/html; charset=ISO-8859-1 Content-Transfer-Encoding: 7bit Content-Disposition: inline
Hi Ryan,
<div>From the pictures you sent it would seem to me that the wood would be OK if the end of the longeron had a pretty near vertical grain.  That is to say that the lines in the wood go almost perfectly perpendicular to the sides of the cut. ( Grain2.jpg)
Good luck.
Glenn
On 9/23/07, Ryan Michals <aircamperace(at)yahoo.com> wrote:
Glenn, you must be the authority on wood after your ordeal with A/S. I haven't fully deciphered 43.13 yet. Could I get your opinion of my longeron grain? Attached are a few photos.
Thank you,
Ryan Michals
NXxxxCC
Clover Clipper
Glenn Thomas
Storrs, CT
http://www.flyingwood.com ------=_Part_46217_15210446.1190585217822-- ------=_Part_46216_11624287.1190585217822 Content-Type: image/jpeg; name="grain1.JPG" Content-Transfer-Encoding: base64 Content-Disposition: attachment; filename="grain1.JPG" X-Attachment-Id: f_f6y3nfl6 /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0a HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCALRA7MDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAprhyyFXCgNlgVzuGDx7c4P4U6igAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKAA9OKKKKAPn3XVz4k1bp/x/T9v+mjUVLrJZfEGqgSAD7dccc/89Wo oA99ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAoopAQehBxxQAtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFAHz7rvPiPVv+v6f/ANGNRS66AfEerH/p+n/9GNRQB9A0UUUAFFFFABRR RQAUUUUAFFFFABRmsDUdW1SPVv7PtLKElxuieaQgSALk46cg8Y6457iswa34hkYeTpthd/MFYW9z nBPc4JCjg9f8aAOyzRWFbXPiCV1Eul28Chjktc5yPwz9a2YPO8oefsEncISQPzoAkoopCwHUj86A FopC6gZLACjcp/iH50ALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeAa6rDxHq3Of8ATp+2 f+WjUUuvZPiPVd3X7bP1H/TRqKAPfqKKKACiiigAooooAKKKKACiiigDn/Fnz22nW5leJbm/jgaS M4ZQwboex7fjW1bW0NnAsNvCkUY/hQYH1rJ8V6dPqGin7KGNzbuJogqgksAR3/3ifwxWrZXkGoWU N3ayCSCZQ6MO4P8AI+1AEd9qMGntbLNvLXMywRhVz8x9fQcdajv9a03TJI472+t4Hk+6sjgEj1+l UPEttHI2lXLoP9HvomMhH3FJ6+2SFH41as9Pglmv7qeGOR7qYqwYbgVT5AMHj+HP+RQA7UNUjs9P a7/16HasaxEEyMTgBex//XWbBrF/aXljb6vaRwm+YiE25ZxEwx8shIAyc8Y9D25rL8TeFdGs0t9T jjuLSOGdPOa0k2mNScbwME5BI+7+Va8fhiOWS1mn1fULyK3kSaBJZFZQynIOcfNx3P4UAWNf1A6R pb3IG6QkRxjP8R7/AEHJwOwrH1q9u/DEcGo3WsGWNSBJYhEBlGfmMfAJIB6cD5cnHObfju0N34cZ UlMciyBowPvO21gFGO/OfwpfCdho8ml2upWkaSTunzysPmD87hjsQS350AdGMjANOpskiRRtJIwV EBZmJwAB1NNgmjuYI54XDxSKHRh0YHkGgCSiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiimvIkSF5GCqoyWY4AH1oAdRUVvcwXUQlt5o5Yz0eNgwP4ipaACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooA8E11XfxFqpYbj9tnGenHmNiim6+6L4k1UBQ3+mzc4772 ooA99ooooAKKKKACiikJx6/lQAtFGR60UAFFFFABWVb6Db2d4Z7We5giL72tY3AiJ9cYyOcHgj06 ZFatFAFXUrGPUtNubKUDZPGUJIzjI4P4Hmq3h+G7g0WCK+z9qVnEhPVjvbn8ev41p1jvrTXU8trp UC3MiYzOzjyV/EEkkenHf0oA1Li3huoGhuIklibqjjIPcfrXPReF76ykdNO8QXdtaYCxwOglEYHQ AsTgDtjHAGc1Fe3N5patNq3iQQEnctvbQIzEegBUsR+Hbr1qzb69ealbKuladM0h4M94PLjH+1x9 76DH4UAaGnaV9kRHubiS9uVLETTEnbnrtGTt9OP5cVjT+Dvs99Jc6VrN3pcUjbpIIjmPdwOFJwOg 7e3TAFuDTvETuftWtRqh5IhgXP0GRxx9albwvp0/N79ovHwBunnY447c8UAZthpmlW0pGp+IP7Sl R87Lq6yqtzyULEZ69uPSt3+2NMVTtvYCqj+Bg38qZBoek2MY8uzhREHG/wCYAfjVO41fwxaShXms TJnOIkEhHudoOOnWgCzH4k0mZWZLvhTglo3UfqKemuadJyt7DgHGScZ/OqMnivw5JlHulfGPlNu7 HnGMDb9Klh1Hw3eSqiTae033QjhVf0xg80AWH1zS05Op2Yyf+e6DJ6dzSw61p08nlw6laSyE8LHO rH8gc1LJpOnTKA1nDgdNq4/lVWTwvo0vDWK49A7D+RoA0vMwQpHPpT94zg8Gufl8PXtnEV0XVZ7d SeYp281QPRdwO2mtrOo6PEx1mx8xFOFuLM7g/plTjb6devQUAdJkUVVsb221C1S5tJlmhYcMv8j3 B9jzVkNmgBaKKKACiiigAooooAKKKKACiiigAoorItJ9Qk8S6hC7obCJE2qRhlYgEbcDkH585PGF x3oA16QsoYKSMnoM0tUJ9GsLm7e6lg3TumzfuIIHqCDwfcc0AX6KbGgjjWNSxCgAFmLH8SeT9TTH uYI5o4XmjWWUkRoWAZ8DJwO/AJoAloozVdL+1kvZLJLiM3Ua7niz8wHHOPxH5j1oAsUVDc3cFlbv cXUyQwpy0kjAAfjUOn6pY6rC8tjcpOiNsYr2OM4P50AXKKKKACiiigAqnqd62n2JuEh8598capu2 gl3CjJ7Absn6VcrH8U5/sCXCbz5sPy+v71KANaIu0SGVVSQqCyq24A9wDgZ+uKdRRQAUUUUAFFFF ABRRRQBkTm4u9fSGC7aGKzjDyqvIkLk4Uj6KT+Na9YtvOkXjK8tmQiSezjmVh0KqxU598t+VbVAB RRRQAUUUUAFZGqQwanf2mmyuwVP9LdVJG8IQAp9QSeR7Vr1zenh7jx5rMryAi1ghhRcdA43Hn6rn uOfrQBZhSPSvEf2aGFIbW+i3qqAgecn3sDoMrj67a26yNRh83xHozCJmMXnuXHRBsC8/UsP89deg AooooAKKKKACqGrai+m2qSRQefNLMkMURfYGZjjk4OOMnp2q/WB4nkRX0ZWViTqUJXBHByRzn60A byEsisVKkjJU4yPbiloooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPAdcdB4j1UHaD9un6n/po1FJrw/4q TVuAP9Nn9/8Alo1FAHv9FFFABRRRQBR1S9ezt08qHzriZxHFHnGWPc+wAJP07day7rQ4J0FzrUsl xIWBWJM7EP8AdRRye/PXv2q1axSXXiO8u5HDQ2yi3hTHRiFZm+vOM/Udq1yqsVJUEqcgkdD0/qaA Me21KzsIvIZbuGOM4RZYW+UDoBgH5QOma07W6hvLaO4t5BJFIMqw/wA8VQ8NSPL4etDI+9grIT5Y T7rEY2jgYxjApsdv/Z2ur5cuy0u42UQAYVZVwRt7DK7ycAZxzmgDXooooAKZLNHDG0krqiIMsWOA BVTUNUg09QriSWZvuQQjdI/uF9PfpXNx2t140kSa8d7fRkO02atn7QwJ5LDGRnb6jII680AR33iF NZuJLW2lcW4GI4YjiS7b+7n+Bf8Aexx2PbUtrLWb21WC5MelWyt/q7RsyleeN3Qdc5HOfStey06x 06NY7S2ihULtG0c4HbPWm6jHLPBhLxrRFbdI6Abio6jJ+79aAKdppOjeHYPOxDCF6TTFQRxjAPGP wpV8SadIHSzM1zIg4jhhbn2BIA/Wsi4MV4622mWUeoSD5Wvr3dLHEehwSCGIGeAep+taum2kOj2s ubx2UnzJHlYKqnuQBwo9ug+lAFdr7xNcXH7jTrO1g9bmQu3T/ZPHP9PwJ9IvL45v9auVQDmKyIiX 8T1NOm1qaSZI9O0+e8Un/XA7IiPZ8EE/p15p09hrV8nzajbWQIPywQeY3/fTH+QoAitfDOjWkgkE BkfOQ0h5BH0xn61qQRW1uNsNug+Xb8idR+FczY+G7m5E8tz4g1JDFM8bIsrx7cMcH72ACMMOOhHJ HV8+j6bv2t4uvY26kf2jj09+n+NAHVrODwRg+hNRT2Njef8AHxawyH1ZATz71x7aPHDIktt47mjC fNtnuFlU5z1DNj9K2Yp9ct7Qv5FnqmMnzbaUxbsex3DJ9BQBJL4R015/Pga4tZefntn8s/mB2qFn 8T6XIi+XFqtsn3nAEcrDp6gZHB6HPtni5aeILaQbbuKbT5Qu4rdoUXH+/wDdP559q1opY54llhkW SNhlXRgQR7EUAUNN1yy1NzFEzpcqu6SCVSrp2IPY4PXGa0qzdT0Oz1MiR1aK5Q5S4hOyRTjGcjnp xWbBfXfh+4isdSMtzZNtSK/PJDEfdcZJxnv19cjJoAs3nh2NrxtR0+VrS+C4Xbjy3P8AtDB69P16 02z12SO6Sx1iD7Hdu22JgCYpv91ugPTgnqQASTituOWOaJZYnV43G5XU5DD1BqC9sLa/i8u4jDEA 7Hx8yH1U9jQBY/Clrn7O7uNGuTYanIXtgMw38zH5zjO1icgHhuSRwBxXQUAFFFFABRRRQAUUUUAF FZGreIbTTG8hM3V+3CWkHzSE4zyBkgY746djU+ltqUqST6iscPmEGO2UZMI9C4OGJ4PQYoA0KwtL QDxZr7g/eFtn8ENbtZmmYbVNZbAyLpEz9IYz/wCzUAadYeqxLceJdFikQvGFml4JG1l2FTwff9fw OhFqthcXIt4LqKaU5ysR34x1zjp+NVb7K+JdJby9ymO4TcR90kIR+OFP60AU01hLDVtea+uNlpbm F0y2du5ACAPc4496yNY06a30f/hItWZU1GC6gumRDlY41cARA+mGJJHU46gVevtClvvGSvL5rae0 STygr+7Zk3KI/wAdwJBzwCO/G1r2mf2xol1YbsGVRtPuCCM+2QKAJ9RukstOuLmSZIVjjLeY4JVT jgkDk89h1rmPDEF1H4gljlt9gtrQLM5xuaWQrIcn+I44J9Qc9qq6jrC3PgZdPkS5n1PyxBNGR84k jALs3bHyk9Tn88dH4YhWPQIJBNFNJcFp5ZYwPndiScnuR93P+z26UAUvE1ozahpl/PC9zp1qzm4g VQcZGA5U/eAOD7AH3rU0zVtL1VpX0+5illGPNUDbIvXG5Thh3xkVaa+tEYq91CrDqDIARXM60lle T40qwuzqT71W+s0Maxscffk4DA9e/Q9M0AdbRUNqs6WcC3UiyXAjUSuowGbHJA7DNTUAZ+r6mum2 yhNrXc7eVbRH+OQ9M+g9T/UisXWNOksbRdZmvbk3sLRmWSFlVdgbkbTjK4YjGefzzrNELvxHmQRM lnArICoLB3Y5Oe2Ag/P2qvrMSazdRaOs+1FInulUnmMcBD9SQevGM0AX7rVbOzuUt55WEzqXCrGz fKO/ANc9rvibSLvT3tIrqQT+ZG+1oJUxtlUnJ28dP8K09AuGntIINSj26paKYiZgN8gGAZF7lW4y RxnPWrWvwifQL9Ds/wBQ5BdQQPlNAF6KWOeNZIpEkjboyHIP40+oba0trOMx2tvFAhOSsSBQT64F TUAFZWo6lNHew6fp6pLeON7hxlY4+m48jvgdf/r6pzjjrXE2OgXWs6tqd1qt2BiY20sEMWxZECrj ksTtOQSDn+VAGv4avbi9FyWvGvrSMqI7qSIRs78lwAAPlHygZGevJq3ZX02oaneLH8lnauIQ2Pmk kH3voBwOnOTzWjDDFbxLFBEkUa/dRFCgfQCuegu1sdPkhtVzfXt/cpGBzh/Mf5z7KoBPHQUAS6n4 iNrrNnp1rCJWe5SG5ZsgR7lyAPcjn0wpHXprX9/b6baPc3L7UXoO7H0A7msW90iWw0a2NrvuLq2u lu5Nq7WuXOQ2SOmd3U54HOetCG11bxekyXaTRWlqskUaSBlLlmBYAHsOCfXbQBkXl1q0fiTS9Skh gs3uo5bVBIrH5SVMauBnB3lRxjqc4xXYabLdzafC99CkV0QRIiHK5BxkfXrjJxnqetVNbsvtgsCM b4L2KYDGSQGwcfgSfwrVoAKKKKACsfWLtUuoYI4Gu7raWS0JCo+eNzMRjgBuOevTuNisfRm8291V 5hmeO7aNWbqI8KQBnkDr7Eg0AUdJ1y207S7qPUpFgFjIVZFVm8pCSUTuWKgYyB0FU9M8R6VFr+t3 Ml0wjneERsbeT7qxDPO3gZz1/rzpaTZWl9cahf8AlROk12rxvH0Jj4Dg/nn8R0q3pgYazrWQdhnj IYnv5KZGPwH50AXrdoZlF1FIkolUbZIzlWXJxjnHfrU9IAASQACTk+9LQAVj23iawvL2OC1E08Lu Yxdxx5h3jOV3dz8vbI5HNO8QTXQso7WykEd1dSCJGDYZRgkkY54xyewOatWumW9lHDDaosFtEP8A UxooDHjDHjJIx/jnigCyssbyPGsimRMblByVz0yO1OJxWF4fCjUNaSWNBcpeM2RGFPlsAV575x3/ AJYqPxnfT2miCK1eRbi5mSJDC+2Tk5O3HPOAOP71AFqfxTolszLLqlmrKSCDMuRjg9/WuO8TeJtH v9e0AW+pW7eRdhpWWQAIN8Z55xjg8+xrujoekkYOmWZGc4MCkD6ccdBXOeINF0yLWNDii0uxWKS4 bzFEKgNyvBGOeufw+tAHWW13b3cYkt545kP8Ubhh+YqaqdvpOnWc3m21hawSf3oolU9Mdh6VcoAQ kKMkgD1NLVe+sodQtHtrgExtg/KxBBByCD7ECsIahqnh8xwalDLqFmMk6hCpLIvo6DJ49c8j1IOQ DpaKhtrqC8hE1tMksZ43Ic8+h9D7VNQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHgWuYHiLVcoM/bZ+n/AF0aik10N/wk eq5/5/Z+n/XRqKAPfqKKKACiiigDK0QqDqUYGGS+k3892ww/RhWrXOahb3Oj63JrdpDJcwXKpHeQ qfmULwrqO+O4+v4XbfxPodym+PVLYdeJH2NwcdGwe1AEuiNu09/Rbq4UfQTOB/Ki6mil1mxs1dfP i3XTKeoTa0efqS4/ANVRvEcF2jw6Iv2276ABSsaZBIZmOBt+mSePrV7TLBrOKSSdxJeTt5k8g6M2 MAD2AAA/+vQBepkrMkTsib2Ckqucbj6U+obu4FrZz3DAssUbOQDjOBmgDmr21nN0LG0uI/7Yul3X lwVPywfdO0ev3Rx6ZOM5rpoIIrW3jghQJFGoVFUcADpWZ4et5ls3vrqMJeXredNlcHHRF6ngLtwD 057mrOqX0lrCIbURyX8wP2eGQ4Dkcn8hzQAahqdrp0SvPKSz58uJRl3P91R3PIH4j1rPl0+71mUG /wB8Gnj5ltlk2u5B4MhHbHOAfToRVzS9HSwkluZZWuL2fBmmfHX0UY4X0Hpj0o1jUZ7ONILG2+1X 8+fKi7ADq7HjCjjvySB3zQBBf6lbaWYLOCNZbuQYt7OEbSR6/wCyvvjjn3qO30Sa9Cy6663LBt0d uvEcXOccY39hzngd8k0sEVt4dhJmmlvdSuWLEkAyzNgZCjsvGcdBTjpd3qyq+rSmGMMGW0t3wuPR 2/iP0wKAFfXrZbv7DZW813KgAK2ygpH7FiQBSG38QXF3mS7tLS2GcCBS7n2O4fyxU66rZRO9jp8Z uJrcYNvbqAF/E4UfnQlvqd9Fm8uPsaliRFbfe29gXOefpigBjaBZFN9/LPdFRkvPMcKcckAEBaxZ rvQbK4kjsLO2nkiYBjJcHZnAPGNxPXnit+10DTbUAi2WWTHMs/7x29yT396srBOmdkscYydqLH8u O2e9AHP2mpWtwuZdHtdjkbRDKrljnHAYL3x09afbXeixXLtHFLpl3wMzqyBvTdztI5xye/GK0TNq EZCXtjFdRbhmSAdPT5GJzjjnPfpUljqGm3bPZW0gLIDuhkVlIGTnhh07eg49qALzRrLFslRWBHII yKym0CG2V30qR7Gc9NjkxknuUJ2k++KcdFFrO9zpkptpGHMPHkt9Vxx25HPalsdZ8y4Sxv4fsmoM CVhJ3BwBnIYcevGc8HrigBbfVTHdJY6hGYLluEk/5Zzf7p7H2PrjmtKSNJozHIiujdVYZBqK9s4b +zltZ1zHKpU9Mj3Ge9ZunXNxZXx0m9Z5Pl3Wty55lUYypOclh69SBk+pAKTJP4VuVeMtJokjfvEP zNbMe69yue3fJPX73SRyRzRJLE6vG6hldTkMD0IPcUOiSxtG6hkYEMrDIIPY1zdozeGtVGnyLK2m 3sv+iOAWELnrGepwTk5+vvgA6G5tobuEwzxiSM4OD6+tZFhNPpV5HpN3JNOspJtpyBhUA4Rjxk8d eevbjO5VLV7L7fpdxAoBlKExHOMPjgg9vqOaALtFVNNne40+F5jmcLtm4Aw44bgE45q3+NACZB70 tcreCXXvE9tbwSO2nabMHuSgABmX5lGT97BC8Adzk9Kuap4iSCSSw0yF77U8bVijUlEb1duAAMjP OeR0zmgDWvL220+2e5u5khhUcsx/Qep9hzWEmoat4hUHTEbTrL7sk9zGPNY/7ABIx7n146VJY+G1 mvY9X1ki41ErzGeYYj2CKc4x9evPXmuhoAztL0Sx0gSG1jbzZcebLI7O0hHcknqTkmtGiigArCuv DSXc10rXk0dldSebNbRfKGbaAfm64OORW7RQBnadpMGjxeRYRRRwM+5lwd2MevfnH4VojOOetFFA BRRRQBE1rbu0jPBEzSLsclASy+h9R7VlDwzZbghluTaDlbUynYp9Qfvdcnr1NbVFAFODStPtkVYb OBQvT5BxVyiigAooooApXOntNdLcw3c9tLs8tthBVlzkZVgRkc89eTS6fpsGnRusTSSPI26SWZy7 ufcn+VXKKAIZLS2mmjmlt4nljOUdkBZfoe1RapEbjSrq3VwjzRNErMMgMw2jP4kVbooAKKKKACse XTr221qTUNPNuy3KKtzFMxXJUEKVIBwecf41sUUAQQfai8jXAiVcgRpGS2B6knH5Y496qWGjxWN7 dXW8ySTuxXI/1alixUfUnP5elaVFABWTfaIst0L6wlFnfDgyqgIdc8hh3/xx6DGtRQBVtLR4Qslx O1xc7dplZQMdMhQAMAkZ9emScCrVFFABRRVe4vre1lijmZw8udgWNmzjHoDjqOtAFisy90DTr+6a 5lidZ3XY7xStGXX0baQGH1rTooAZFEkEKRRjaiKFUZ6AcCkjgSKSZ0B3TPvfJ77Qv8lFSUUAFFFF AGLrytbzafqiwyzCylcvHGMkoyFSfqOP/rdRIviPTJniitbgXU8pASGHlumTkHG3ABJzjp68VrUU AY2o6dqP2lLzSJ7eG5YgXAmUlZVHQHA7ZOCMH3qqPDEl5aXLapevNfzjAmQ/LEoYFVVeBjKqT649 ea6OigBkRkMSGZESQj5lRiwB9iQM/kKzdQsZbrW9JuFVTFbNK0hOOMrge/X/ADxWrRQAUVBMlxK+ yOUQx7SCwUF8noVJ4GPcHOalRdkaqWZioA3N1PuaAHUUUUAYV1oclk0l5oRFtcuweaLqtwAc7Pmy F7jIx1PTqL2lapHqluzeW0NxGds1vJ96NvQ+o9D3/MVfrA8QwT2QOu6ciG7toyJVb7ssPVgenIxk c9u/SgDfooByMjpRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUHmigD591448SatwB/p0/Q/8ATRqKk1w58Rat1/4/p/8A0Y1FAHv1 FFFABRRRQAVUk0vT5XZ5LG2d2OWZoVJP14q3RQBHDBDbpshiSNfRFAH6VJRRQAVz/iO6m+2aVpsU ZZLy4/e+jRqV3IR3BUknthSO9dBWRA8d14ouhuffY26R7SwxmQliQPooHPPXt1ANV3WNC7sFUDJJ OAKzNLilumfUr2AJcSHESMDmJBkAcgEE5Yn6/hS6vD9uktNO34jlcyTr/eiTqAe3zGP8M1qUAVdQ vU0+zedxuYcRxjrI/ZR7k1jbzpEX9oXVv9p1u9O1Ik+9jqI1wDhVGMnkZ5J6UqSW2r61c3dwriz0 glIy3CGYHLvjvtAUD6n14k02aN0n8RXzNCkilYRLlfLgyMZGerEBvxAHfIBLbWkGjwte6pdLcXjE 5uJFAPQnYg7AfNwPeniG81YpLO0tnZ9Rbj5ZJAf75B+X6D1OeejbCwmubr+09SBE+c28Ic7YEx0I 4yxzyTnoMdBWs7rHGzucKoJJxngUAMgt4bWFYoI1jjUYCqKqSaoshVbCP7azfxRt+7X6vyAfbrUM Rk1tUmbdHprxnERJV5DnGWx0XA4APOefSrV3dW+lWseISQziOKGEAMzE9FGQPU/QGgCnfadqN4Hc 6jLCvlnbBbDYd3UfPnJ5x6A47ZpsfhmzaJRey3V5L/FJJcSDJznoGwOn5U+KxvLtGbVJ3IYki3gb YFUnOGIILcYH59c1lXFjpemW4S5muIJmb5Ira4kYgcgYA5IwOSwxkdaANBvDyRTI1re3sMXPmRC4 fDAjHBzwe+fYVSvNIuVLypefbGUfu451UOn+5L1VvQn8c0mj6Vpl5ZrLEFZ0dlEtvcyAH3xkbTg9 CPz61nQ217eSatB9rup9MiuSjOtwwngZTzsbPKgAZX647igC/oevyo0NhflUkbKoZpv3m/jEbA8k ndkHuMdzWrqVtHqlo0TERyj/AFc6r88TZByCCCOnYiua8ReFLaCyjvxf30qROgd3uWZlQ8Aqc5yG 2sOR0NXdM0VtV0y0voda1NFlQMVed8j1H3vXjv0oA2dK1Np7dobl1N3bMIpsH7zAfe6Dg/QDOR2o 1eyXVbFrdZTbzg74Zhy0TjoR+eOvesiLw28Ot3Ih1S8SSSGOQyFiS2GYYY5GcDHfv9Ktjw9qKYCa /c4H95Sx/VqANDSNWj1fS4L2MYEi5ZQc7T0Iz9RUmoWkeo2M9pIF/eRsoJXOwkEbgPUZrmdK0HV7 Vr6G01bylS6bKvCjAkqrZHy55B6Z4rSfwzcXeVv9ZvZozkNHGfKVge2Afw/P14ADRtchgsmstVvY Yr60ZopfOkClgOj/ADckEY5rUtda0u9k8u11Kznk/uxTqx6Z6A+lcxqXhXQ9M1DTJo7BFgnn+zTq C5Z9w+TvwAwGfard/wCHNJtrzSY7O1SO4+1q6ne+QqZdsHP0+ucUAWPDMh+261Fu3KL13zkHkswx 69FWpvFevHw9orXUcXnXEjCKFOxYgnJ9gAT74xUHhxY4b3X5DtQC9bczEccbuT6c556ZNZMOnzeM dbTV7lmTRIGZbWJsK74wGbjkAsDznOAOBQBU8Om8vdOOjaNmK2BLXer/ADYaXuIxkE9FG7PTPAyu e40/TLXTIdlvGN7cySsAXlbk7nbuckn8a59Ne+3KdK8JW0LeUuDcyIVt4RntgfMTzjt35wa3tLt7 +3tf+Jje/arhjltsaoif7K4GSPc5P0oAvUUUUAFFFFABRWZqHiHSdLuEt77ULe3nkxsSV9pOc4+g ODz7GoYtXkn8TtpsaqYY7fe5PXdwRg9CMEfmfTkA2aKKyxrcC2N7eygLFazPCdrZLFTtxyAMk8Y5 HTmgDUorMsNctNQuJbZBLFdRHDwTJtYdDn0PBB4PGRnBqprWp3Auo9JsG8vULlC0Ujj5EwCcnr/d PGD6+xAN6iud0yTVbLW49Ov9SS/ElsZSREEeNgQMnGBtJzjv+RroqACiiigAoorHutQuofE1nZCS 2W1nhYhH4ldxk/LzzgAZGO/WgDYorL03XbHV5J0tJdzwHDqQQepGR6jg8ik1rUzplmjxwmeeaUQw x5wGdumfbigDUzk0tcpcvrmiRjUb/UI7m0jkAlt441UhCdoKnAyckccDA6mulmmjtbd552CRxqWd jzgAc/WgCaiovPiMImDr5RXcHyMYxnOaal3bTOFinhkf0VwTj/JFACX1yLOwuLo4IhiaTB74BPb6 VDpEtzNpVtLdukkzpuLoCAQeRwQO2OwqHX5vI8O6lMVc7LWQ4HJ+6aZBe6ZpOn2lrJf28flRJEoa VQThQOnXtQBpyzRQBDLIqB2CLuOMsegHvUlc1qfiPS5LYRwX0LzCRHUAMQdrbsHaCedpHfrW7aXE d5axzwvujkUMDjsRmgCxRWPda2I9RfTrO0lurtF3Mq4RUGM8sfw7dxWnHI7oC0TRt3B5/lQBLRWN f+JLOwvksiks9y3/ACzhAJXPTPI5PoMnHOMVKupXi4abSbgITgGNlcj0JHGPwzQBqVg6XP8AaPFO uZYMIRBGnqo2kkD2z29c1u9RXMaBG8Xi/wATqx48y3IOPVCf6gfhQB1FFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAVma9cvb6RMkKF7icGCFAM5dgQOvHHJ59K0Jpo7eCSaVgscal3Y9gBk ms3ThJfXJ1SXzFiZdttDIgDRqcbicepGR14784ABq0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFNQ5jU+woA8C15R/wkerZ2/8 fs/Xj/lo1FP13B8R6rhs/wCmz+3/AC0aigD3yiiigAooooAKKKKACiiigArm/C8YbUPEF0XdpH1B 4juxgBBxj8G/z36TpWP4dj22t8/TzNQuWx9JWXr3+7n9O1AEccpm8byxq+UtrAKV9Gd8n9FX/IrQ 1W/TTNLuL1wSIkJACk5PQDA55JFZek4Pi7xCcDcPsw6dvL/z+X1q7rcUd1b21lIEK3F1EMOMghD5 pBHfIjIoAy7zz49I0rSSiLd6nIFul3bWCkF52Xtnr+daN7Fa3uqWWmyICsCm7KAEAbSFQfTluP8A Z9KS6RZvFWmg7D5FtcS8/eBJjUY9sFqrgxjx+VJbzW0zIGDjb5gz7dcfnQBv1nXaG91GC0EhWOEC 4mCnk84RSD1UkOf+AjpWjWNYSs/inWYy+QkVtgYPygh6ANmsm1ggvdaudQ3FmtibWMA8DABY/XLE fQVrVkaFFJFPrCydDqDsvGPlKIf60AWtVuJbXTZZIMmZsRxdPvuQqk57ZYZ9qhtNEtbeGASDzpo5 POadgA0knPzNjGev6D0q9cwLdW0kDllDrjchwynsQexHUHsRWMNF1cqIn8RztBnBAgVXK+m8cg9O aAJbSJT4mvpbbaIfJVJyo6zZJ9OoU+v8XIqp4Vh3HX/NUssmqTja3IK8D/Gt21s7exh8m2iWNM5O OrH1J6k+55rjrzRdYtpZbeDWHtkv9Qkm8qzgLSFHIBZnJ+UKMHIA5PU5FAD5LwSfC+aZpHn3I8av wS370qCOenQ/QVteGm22+oW/y7bfUJ0UDjALbwP/AB+sD/hB3hFppx16+lhc5khNwyjYo5ZULEff MfY43VPovhwTnUJBrOrpi7kj+S5K7yuFLNxy3HX0AoA6G2uoJvEF/BG2ZbeCASdeCxkIH5YP4itK uN0zwdkTX39t6n5tzIWEsV2x3xDIjJP8R24Ppz0q0fB82W2+JNaAPrdMT/OgDZ08r9s1Qg9bofn5 UYq/n0rhtC8OzXgvLka3q8cRu22MtwcTKoAD55znGPwx2rXfwdZThftN7qVwR3luST/KgBPHNtHc eFriSQlTbssyMDjBBx/ImotU1KKLxvpsDzKggtpJ5A2QAhVuc4/6Z+vQHjkGsnxb4c07TtCd43v5 JZGWKOLz2YO3XGOmcKf6dqh1rwfp51awsbe/ufttzkFpZslIhkueMHkZXHQ8+9AFnzL1dCgFpbSO +t3Ml1OIyMiJiOFPQZQpyc9T0PS+nh691u3SDXQlvZQMPJsrcgjgYBLcnGM+h5zxiuphhjt4I4Il 2xxqEVfQAYAp9ADIoYoIlihjSONeiIoAH4Cn0UUAFFFFABUVzMLe1mnKlhGjPgdTgZqWkZVdGR1D KwwQRkEUAczpmkW1l4bM5SOa7uYN2+Zs7mZcKu49M5x75NZuhRRWvi6G4ScPZXFm1raSFs+cyMpY j06Nj2A9q1ofDd7HAto+tzPZKw/c+Xg7OPk3ZzjA/XjHSta60mzu7NbVoVSNHEkflgL5bg5DL6EG gC7Xn9gH1HxNJpqTkR2+rT3syKADhdmzkjpuJBHUg/jXWafpd3bypJearPdmIFY1x5a4IGSwH3jx 1PTPTvU1tpVraald30SBZbkLv47jOSPrxn3FAE19YWupWrW13CJYWIJUkjp7jmuStdLu7HxXd2sG qOrvbR/Z5bkGWQRA/MATxncO/Y/iO1rF1rRJL66tNRsZo4NRtCfLeRNyup6o3cA8jI5AJx1yACzp ejw6WbiRZZpp7hw8ssrZJPsBwByfzrRrJs73WZpRHcaTFAoxuk+05H4AL+OM+2a1RnAyQT3xQAtF FFABWF4iVIJ9O1N2ZfssjpnjA8xCoJPb5toz71u1XvbK31G0ktbqMSQyY3KT1wcj9RQBjNoen+Jd A06S7jdX+zxvHLE2x48qCMfT3zisTWYNW8O3FhfNqKXttDJIkcl5GWeLcvQ7fmfoeRz7HpXdRxpD EkUSKkaKFVVGAoHQAUksMU8RjmjSSM4yrqCDjnoaAMWDStSvLuG51q7gZYDlLS1UiIt2Zi3LEdh0 GAfWo/EV3Jd6JqUOnn54Y3MkzLxGyDdgZ6tx26Y57ZtReHLOJtvnXjWwGFtWuGMQA6Db6exq/LZw SWMlkEEcEkbRlYwFwCMHH50AY1lYW2o69f38qRywxBbWBGUFQuxWbgjj72Pz9a2ry1jvbVreQkIx BO3GeCD3B9Ki0ux/s3TYbQymXy8/ORgnJJ/rVygDnNY8OaPFo99OtkiypbSFXySRhDjv7f5zWta6 Tp9oq+RY28bKMZVBke2etPv7Nr2DyRO0SN8soAB3oeCvtkdx0q1QBh+KLWS/s7SyjeRPtF0sbFCA du1i3XrwCce1X71hp2iXD2yrGLa3YxqBwu1TgY9OKlntmmurWUS7VgdnKY+/lSv4danZVdSrAMpG CCMgigDJ8M2y2+g2z53S3C+fK5wSztySSOp7fhUniHUJtL0O4vLdVaWPaFDDI5YL0yM9ahsrDUNI DW1r9nuLLJMSSExvESSSCwB3D8M81qGMzxFLiOJkZcPGRuGe/J6j8KAMHSrnS9I0yCQ3Hn3d4qyS Oi75Z3Iz0Ue5x2/Eml0vXb288UXemXMMMMcMHmCMZMi8rjc2ccg5wBxke9bEGm2NswaCzgjYHIKR gEH2qlqANjqkOqLDPOrJ9nlSFC5RSd2/aOuMYPfB49CAa9YDSPYeN1QhVt9StcA92mj5/wDQD+lb UM6zhiqyAKcfOhXPAPGRz1rG8RWskl3o91E0gMN4isV4AViMkn8Me+7HegDeooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKa7pFG0kjqiKMszHAA9Saxi9xrsmyPzLfTFPzuQVe59Avoh6579OOa AJX265KoTd9ghkV/MGNs7qx4A/uggHPQ9vWtamxxpFGscaKkaAKqqMBQOgAp1ABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU2P/ AFa/QU6mx/6tfpQB4Lr+P+Ek1XIIP2yb2/jNFGuMv/CRaruPP22ft/00aigD3yiiigAooooAKKKK ACiiigArE8NTF4dTiJP7nUrhMHtl9/qf79bdc9pFuNO8U6zbFzi5Ed3EuSeCWDn2O79CvoaADTCI /Gmuo27dLHA6+mFXB/U1d1QE6lovHAvHOfT9xL/jVBIfL+IcjqFAk03cxxyT5igfoP5VpaqCJdNn yFWK7UsSf7yNGP1cD8aAK91OsHi3TUZlH2i0uEUY5ZlaNhz9N1Ra3cxaVqOn6q6kxlzaTOP4EfBD EnoAyjJ9CetHiWzUfYdYDbH0ubznbPSE4Ep454TJx7dD0rWuraC+tJLedFeGVcMPX/PXNAE4NZVx dQ2XiW1jaNt+oQtEJAvG6LLqufcPIf8AgJqvot/dRyf2XrDwjUUyYyh/4+IhwJPTJIOR1HXAzV3V bD+0LBo49i3CES27uMhJl5RvpnGfUZoA0axb8XOmam2qxfvLJogt1AiEyZB+V19cA8+w78YXR9ZN 2Psd6IoNWhQNc2qEkLnuD0I5U8E43AE+uvu6e/SgCvY6ha6lbJPazLIjKGwDyuexHY+1TTzw20TS zypFGvV5GCgfiaqXmjadqBJubOJ2PJcDax4x1HNMtNB0mxYNb6dboynIbYCVPXgnpQBBHrb6pHMu iwmVlwBczoVgye3Zmx7DqeoqzDBDpdvPfXc5aXyg11cMxwQgOSF6KOpwPWrdzcw2lvJPPKkUSDLO xwBWPEJtcuVurlZLfS4GSe1XeAbk43CRx1VRwQpwcjJ7AAEunoks1xr1wskbSx7Y1kGDFCvPQdyc t+IHaoVsp7XQLbS2vNl5dOQ8vAYlmMkuPfbvwfXFaQzezI+3/RYzuQ5IMjDocf3R1GepAI6AmOyA u7uTUWR1BURW5Y4DRkBt2O2T69lHA7gFyCGO2t44IV2RRIERR2AGAKh1K/i0zTp7yZWZIlztUZLH oAPqcVazWDbztr2rLKkUbaTZOWinPWacbkJX/ZXLDOOWwQSBQBo6Rp66XpNrZLg+TGFYgkgt1J59 TmrtHNYOveJrfSIZo4MXF6gGYlIxHkcF+eO3HU5HrmgDJ8UeILSDXbSCfzmt9PcXE6RqCZJCP3ag 5GCN285wMDv0rY0DS7yANqGsOs2qzDazqeI4+D5YHQAEZ4/M9Tm+EvDUttJ/beql31W4DMQ+D5Yb Htnd19AAxGBXXUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAVDdWsN5bvb3EYkifG5T3wcj9RU1FABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFV7u+tbCLzbqdIlPA3Hkn0A6k/SgCxVa+v4NPtzNO+P7qD7zn0UdzVEand6gEbS7 YfZ3PF1cDCEeyZDH0zx+VTafpEdnPJcyzSXV3J96aYDK+y4HyryeKAKf2G71qcy6moj00qDFYnhy 3PMhH/oIOOmeRzu0UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU1PuL9KceBTY8GNSOhGaAPAtdI/wCEj1bAH/H7P/6M ail1wlfEWqgqv/H9Of8AyI1FAHv1FFFABRRRQAUUUUAFFFFABXPeIvNs9R0nVo3CRW8xhuCeF8qT AJY9lXGeeMgV0NQXlrHfWU9pLny5o2jbHXBGOKAKUkezxRBMzqBJaPGq45JDKevfgnj2/KLxUl03 hq7ayXdcw7J4x6mN1f8A9l6VjWV3PZxaVFqEshu7C+NhPyDvWRSI29wcx8nng+9dlQBXje31PTUk CiS2uoQ2GHDIw7/gaw9DmfRrweHLtbhkRS1leTNkXC8tszn76jIx3Vc4Aq1oNxNHPfaPcRlWsHHk MPuvbvnysE9SApU9fu9Sc1e1PS7XV7QW92jMgYOjI5VkYdGBHQigCDWNGj1WJXR/s19EcwXarl4j 3x0yCMgjODmqkeuS2VxJba1bm0VOI70ZMMw/vEgYjPGdpPHqahTV7/QLYDxCr3Ee8j7fbR5RV7eY owVPbgEcgVvQXFvfWqTQSJNBKuVZTkMDQBSnstO1uFLiOVWcArHd2suHX1Cup6e3Sqa/29pVsEKQ 6sAP9YG8hx7FcMG+uQf51MnhfSoLp7q0geznfq9rK0YPttB249sUk+lasQfs/iGdOOPNton/AJKK AI4/Eg4WbSdXiPRiLNnAP1UHP1p8muXMr+Xp+kXs78ZadDboM+78/kDSJpmuhwW8QKV6YFmg/Hr1 /T2q6unuyMt1fXM4Y5wCIgPoUAP5k0AZ08ccl1I+p3IvHRRjTrcFlxngtHk7zz1IAHXHArSNvJfC N7sGOLBzbA5B543kdeP4enJ68U+G3sdKttkKRwRdTjv/AFJpCj3yjzQ0ds6ENCw+Z88Yb0GOw59f SgCKTOpv5KF1s1I3SxuAJuOUGOdvqeORj1q5PcQ2sDzzyxwxIMvJIwVVHuT0qvdXtvYLDEEZnkO2 KCFQWYAc4HTAFVotPub5nk1cRmPIMdpG26NcY5Y4G459eKAK0r3PiCR4YcwaSrASSvHuN4vUqnPE ZHG7nIPGOtaM9xpuh2CtI9vZWqZCLwi55OFUdTwTgcnmquo6/Ba3S6daq1zqEgISOMbhGccGTn5R 39cZNU00VSg1PxRcQXE0GWGTtggHsDwe3JHp1xmgCvcX2q63p8ksbjQtOG4yXVwcSlMZDL0Cjnk5 9cHiqukaPDquqi4NvJFYWExeN95Jv5gT++ds/MFxkDn7x56gXY4rrxZOlxcpJBoRQf6HMMPM2Mhj joASMYYj5Pfjp440hiSKNQkaKFVR0AHQUAOooooAKKKKACiiigAooooAKKKKACiiigAooqrNqdjb lhNeQIV6gyDI/CgC1RWaut2suPs0dxcg94oiR9ecVZjupZf+XK4QerlB/wCzZoAs0VSkfU2C+VBa Jkcl5WOPwC/17+3MbW+rS/ev4IeP+WUGfr940AaNFUVs7zJMmpynJJwkSKBycYyD/kVObbeAHnmY D0bb/wCg4oAnpCwUZJA+tUJdFspzmVZ3/wB65kP/ALNQmh6YmMWiMB0DksP1NAFk3torhGuoQx6K ZBmojq2nL11C1H1mX/GgaVp65xY23IwcxDmp47eCEARwxoB0CqBQBENSsWUMt7bFSMgiVcfzp/2y 1xkXER5xw46+lT0UAQ/aoeoZiOOVQkc/QUz7dDvK7Z8jP/LB+34VZooAqHUYBn5bg4xnFtIev0Wk Op24OCl1/wCAkv8A8TVyigCn/advtJK3IHvbSD/2Wnf2jbZwTIvu0LgfqKtUUAV2vrVBl5ljH+38 v86b/aVgGCm9tsk4A81evT1q1SMisMMoI9xQBSOs6WDg6lZ/9/1/xpyavpshxHqFo5/2ZlP9ane1 t5AQ8ETA8HKA5qJtNsXYs1lbMT1JiU/0oAE1KwkbCXtsx9FlU/1qdJopBlJEYZx8rA1UbRtNbrYW /p/qx7f4CozoGkttzp9v8pBHyenSgDRDKejA/jS5HrWX/wAI5pHH+hKCvQhmBH600eGdGAIFimCc /eb/ABoA1qKyv+Eb0oKFFqQoGAolfH5ZpT4d0ooU+y8EY4kb/GgDUpGZUGWYKPUnFZQ8NaQBxaY+ XbxI4459/c08eHdIGc2ETgnOJAXGfUZzigCeTVtNiYrJqFojDqGmUH+dNXWtKY4XU7Mn0E6n+tKu kaYmNunWi46YhUY/SrUcUcKhYo0RRxhVAFAFK41i3gBxDeTHdtAhtZHyfqBjHvnFU49Y1W5dTbaB KsRz813OIiP+A4Y/5H4blFAGVPa6xdcf2hBaITgiGEu2P95iMH/gNTW+j2kIRpFa6lTGJbljIwx0 wT0/D69av0UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACGmx/6pMf3RQy5yT6UqDaij0FAHg+vlP+Ek1X/r 8m+6f9s0VFrny+ItWGSf9On7/wDTRqKAPf6KKKACiiigAooooAKKKKACiiigDjPGWhRlpNYihZy8 QgutigskeQfNX3XaAeuR/d5NdFomsW+uact3AGXkLIjAja+ASASBkcjkcVoEBlKsAQRgg968/vbO 78FasL6wWabTG3s8bS7Y1zwEYnP8RBDYB5x3bIB1msWVxJLa6hZMxurMsRDuwsyNjcp98Dj3A/C7 Y3sGo2aXVszNE+QNylSCCQQQeQQQRVPS/EFhqscYSZIrph81rI22RTjJGDyceo4qO6sJ7G7m1LTF MjOCZ7JpSqStx868Ha/GOmD355oA2KydQ8N6ZqMomeEwzht/nW7eVITx1ZeT0FXbS/t71SYZPnUA vE42yJnsynlT9as0AZkGk3Fsm2PWb9gOgl8t/wBSmf1qUxaoPuXlqR/t2zZ/MOP5VeooApRR6nvz Nc2hT0S3YH89/wBKm8md0XfdFWHUxIFDfg27+dPnuIbWJpbiaOKNeryMFA/E1g3XjCyW5Ftp0Uup TY3H7KN6gdzkZzQBtt9nsoWmlkCIoJaSV+n4noKpveXF0A9qVhs9u57iZcZHH3AenGeWGOnBFYdl Hr+rws08K224lWkvMvgdtkOAv4tk89TWlB4ajkdn1W7l1JvNEiLMSEQj0TOO/wBOnFAFW21zSbGO S30v7Tql1nLeUpkZ8gkMZMYK9sgnr61KLHXNYRk1O5/s+3JOYbJsO4x0L84wcHK4zyCK3be1t7VC lvBFCpOSsaBR+lZ9/rQt7r7DZWz3t9gFokYARKe7sen05PTtzQBHJNpPhWxiiC7C/wAkUSKXlnYd gByT09hkdBUNtpt7qsyXmuLGixkmGxjbci/7Tn+JscemPqRU+m6KYZWu9RmF5eO28bxuSA9SI88g f4D3rYoAKKKKACiiigAooqOaeK3TfNKkaZxudgB+tAElFZtzrEcaA2tvPeMenkRll/766U5H1O7t 8mOGxc5HzHzmx2PYD9aANCoprmC3XM0yRj/aYCqaabM5DXWo3MpHaM+Uv5Lz+tTLpdgrh/scJcHO 9kDN6dTzQBHFrFncA/Z2km/65xMc++cYx70kt1qLuFt9OCg/xzyqB+S5NX1UKoVQAAMADtS0AVIV 1E8zy2y89I42PH1J/pTZtPefAa/vAB/cdU/kBV2igClHpNhE25bWMt6uNxH51cVVRQqqFUcAAYAp aKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACijI9aMigAopMijIzjIzQAtFI GB6EUueM0AFFFGc9KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKDRRQAhPsaF +6PpRgelC/dH0oA8B1v/AJGLVsD/AJfrj/0Y1FLrh/4qLVs4z9un/wDRjUUAe/UUUUAFFFFABRRR QAUUUUAFFFFABUVxbw3du8FxEssUgwyMMgipaKAOL1DRI7CUSahZm70yAYt5bdtklko4HTBYAY5J JG3PfAtW1rrn7u60bXYL7T3X93Heru4/31G4nOevTpj06qsS68MWU18b61knsLwg5ltWC7j/ALQx gjvjoe+eKAKl1DqU19Hc3GhRtcRrtS5tL/DKOeMELnr0ORzUAuvFMLgwWclwhH3bnygVHPdSuew5 H86u3B8U2kqC3+wX8AGDuQxyscdzu2jn0B+lSDxBPa5/tXSLq0TGfOQiaMDj7xXkHn0/GgCquq+K JkAj0GFGKgkyXIAB/Ln9OlMe18Z3UoLX+m2UY7QxmQn67h/h/Srg8ZaAZfLOoBG/6aROg/MqB3q0 fEeiADOr2IyQBm4Xr+dAFAeEoLva+tXlzqcoGMSPsQc5yFXGDnv7AVt2llbWMXlWsKRJ/sjr9T3q hJ4o0KJdx1a0bjOI5A5/JcnvUcHivSbtpEtZZ55YxkxpbSbj7DKigDaqC7vLexgM91MkUY/ic4yf Qep9qxjeeI765UWmnRWFsUyZL0hnz7KjHHbrViz8OWsF6b67lmv7w4xLckMEIOfkUDC8/lQBTS+1 fxDFHJpqHTbFid09woMrjkfKnIHPcn0/HX03SbHSIXisYPKR23t8xYk+uSSf8n1q7RQAUUUUAFFF Vb6/gsIt8zEseEjUZdz6KO5oAtVQ1DV7XTiqSF5J3+5BCu52/D/Gq3k6lqpkW4LWFmcbFjOJzwOr ZIA9sZ7fXQsrG2062FvaQrFECTgdye5PegDPkGs6gY2hkTTrc88qHlYZ7gjCnH1xU39hWMkyTXCP czKCN87ls/8AAfu/pWlRQAgAUAAAAcACloooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACijNNLcUAOpM00ue4wewNRT3UNtGZZ5o4ox1aRgo/M0ATFvY0hfHTH51gjxbpc k3kW9091MCR5UEDsxPBx0x39ajmv/EMsiG30qG2tzy017Mvyr6lVORx1FAG3cXUdtA808kaxKMsz nAUe5rnm8ZWgy/2e9Nvxi48sFGB9Oc46ckd6ztS/s7XAtnqmsNcsjh/semRNgttIxu5LdT37DpUC +CIhexm08PwomPmuL65LMRj+6jcH+fegDtkuI2i8wOpQgMG3jGOx9qq3etWNjGr3F/aQo2du6VeT 6AdSfpXN3ngrwzbMJtVvY4W6mNZBEjDIONrZJ6euauWOl+EpUY6ZoaXZU48xbY4JBz/rHwDz70AS 2PjXSL6aSNL1VRFyZJysSnnG0bjnP4fnWkNd0tk3jVLIp/fFxHj+fsfyrGl01pAGm0LRNLtVPzPc QpM554wFwOeOpqWNtDgsjLb2VvetFkmc20caBvQMQB1z0z/KgC5J4s0KM4fVLU9PuNu6jg8A+ufx qJfG3h47sapCQBkkK/8A8T7VjW+q6nqPyaHp9oirzuit8ADIyNzYXPU8ela1m99pXlXHiLXYQUi2 /ZYkAD5/ibqzHqOOOPrQAr+OtAXONQ3YHJEErD9FqJPHuiyFj9qlCr1P2Z/rjp71ebxTaSJjTre7 v5OywQkAZ6ZLYAHvUdnqOp6rLJCstlYkAnYkqzyqAcZ4OMfUdeO3IBH/AMJxoCoSdQACjJ3QSLjH b7vX2rU0zW7DWFd7C5E6xkBsKRjPTqBUl5rGn2ORcXAB/uopc9+ygnsaxNd1TWj9iTToYrKG4uo4 mubpcvhj/CgOc/Xt6dQAdQDmlqpp2nxabaCCJmbLF2dzksx6k+//AOs5OTVugAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigBCcUL90fSlpF+6MelAHgWtj/iotW5P/AB/T/wDoxqKNbB/4SLVsZx9u n7/9NGooA9+ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAK9xYWd2wa5tIJiBgGSMNgfi KgXRNJUELpdkMnJxbpyfyq/RQBQXRNJT7ul2Q+lun+FXIoo4IxHFGkaDoqDAH4U+igAooooAKKKK ACiikJABJOAOpNAFLUtSSwiAVfOunOIrdWw8h74HPAHJPaorDTXWQ3d84mu3IYBvmWD1VM8gc9e+ BVbRYn1Jhrd7AizPuFoASfLgP3eOm48nPoccdK3KACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiikJx3A96AFoJxUZk4BBGD3zTWlKqWYYUdT0AoAkLfXrjpSbwSQD7VzeoeONF0 +XyFuTdzkkCK0Xec+mc7c+2abPr+oz2wltrBbFCflfUiVdh/sxpluvr25oA6Xfjqar3WoWlmqtd3 UFuGOAZZAgY+gz1rjoJtVvZPs83iSSfLkGPTo0EjAHGVYLwuTjcxA61XuNL0uHWbWSwtpHIultbu e4fzXmlI+6d5IOMEtxxkFc9wDpLjxVZKWWzjvdRkTG4WFuZFH/A8bcfQmo49Y8QTWrTf2Etoo/in mMjdccRouSfy9ea3fsxWNUhmeJVGAqquPyx/KsiDVNUsY3bU7CZrdOlxuiDnnGSqtjHPY59j1IBh y/29qk5Hnasq45SC2W0QnOeHZi2OMZ68j3FaNn4f8xC95o9tLM3V9Qu2um/IrgfgRW1cS6s3FpbW YUjh5p2yP+AquD/31TUt7iNTJqGqEgn7karEg+h5b/x6gDOl057Z/Lm1q3sbY8+Tawrbn6g7ifb8 O1NuI7OHZENOv9XmVSFa4VnXn/af5efUccfSrNjJpvnb9Ospbl9wU3B+bbxj77nPA7D8uauSLq0s wCva28PUsAZHPtg4A/WgCvb29+ttsgtLDShjJKfvSOem0BR05zk/SqcNnH5hkutevb6RPm8q2cqN uOhRMk9asatPpNnbhdVvJJSGGF3kPntxHj+XeqNt4gkuojbaDpPktjcPtChEXnk4Q8g46575+oBY jtoGlVoPDUAWNeLi72ocdDk4Zs+5/OotR1TdbqsOqbpCTmLTUEhAB9c8DoCTxzVKCDUdXV4LzUmv SOGS1GyJCcZDMMbgOemeAR1znTsPDEdvCqTzHYOTFESFz356kUAZTn7bb7JRHBITkLI3225b6L/B wD06c0afp08wCS6TcXzIBsuNVfhCeOIiOBxnA59+mdWTWtB0FVtLX95MeFgtFMrsc9M+v1NUdX8W XkEbrBDb2smzKpcOXmOf+mcYbaf944yfY0AXzoWpTsvmawbeBT/x72UXlKOf7wOelZE0ui6XezW4 0xr2aMkNPdYOSRnGcEn649akVry/0bztTlmQuQqLfMLaMk+ixtuc8cA4yKqaZBp2nSwi5mIt488S wGInuCFXJIzj72O3XnIBK+q61rEK2WmaYlpbOPLkLR7lCN78AcHpg/StLT/CksADXOpShjy62hMQ Jz0znOMYHbOBmuljEYiQRBRGFG3b0x2x7U6gCtFp9nBKJorWFZcY8wIN2MY+916Vh+Id83ibw3ae YVieaWZgO5jUMP6j8a3L26WztnmcMVXHC4zyQO5HrXDaj4gmu/Fem/YRagwRTgSSuWQbigOTwMDH bcP0oA9CopqjHbFOoAKKKKACiiqtvfR3N3c28aSZt9oZyPlYnPAPcjHPpQBaooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAD04psf+qT/dFKcd6SP/AFSf7ooA8G1sk+IdVJOf9NnHc/8ALRqKNbgRvEOqnf1vZ+rH /no1FAHvdFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUE460UAFFFFABRRRQAUUUUAF YXihZrq0s9MhJVdQuVt5mU4YRbWd8H6JjnPXGOa3ax5bmOXxhbWZUM0NlJPk84LOijHvgN+BoA2K KKKACiiigAooooAKKKKACiiigAooooAKKKKACijOOtJkUALRmmFxnHvWTe+JNIs2eOXUIGmVgv2e Nw8pbsAg5zQBsZ9qaXx6/gK5FvFWpySyhNE+xWw4W71S4+zqCc8lSMn1wD37Vny2+v61qQIvNQkh CgkWwNjb5wD8sjBmkB5/h79RgZAOq1TxBpekYGoXscDHHycs/wBdqgnHvWDqXjq1hREsbKe7klGY nkTyo3zjGMjJ/Ac1G/hPSbLUYvtd/bQDO+K0tYvLmY+ofc0rcjsf61sWUfm3LS6focVrtGFvbtNs jccnbjeffcVz60AY0d14x1Szgf7Klskh5e1CpIB25kY8HPYduvNZWj6GLu7kuZnXVbqMfMrmSdgR 0XzSyxjrnk++PTuIdEBkkm1K9mvmf70ch2wD0xHnHQDrnue5oOo29vbwQ6PZi7RiRGtrgQoAecuP lXHp19qAMq38Paneqq3twtjZA8WVqAMr6NtwPQfxDj65qnw/oaammkL5pxhp5HblieUiA4GSAzEg ZAU8jOa3L6C9uYkkvNTXTrULmaKFsHpk/vSQRjnkAVSs7m2tXkl0vSZr67kkcPOGzuUEAEzOeflV MDPp6UAT67rE9jdQ2NnNZwyOg/1/G0M20MOQMKA5OeuAOpGYdXt0tLPw/a27l41v4AHJBMmMncSM ZJ5JPc1NZWtvrl7c6jeW8UsSk28MUsathQQSxJ9T09OeTniO90fS4dY0mGDT7eMvM8jBIwBtVD2H bJX259+QDpKrXzMtnJtjjcFSG8yTYoXByScEgfhU2I4IuAscaDtwFArn9QuRqwa2tIFntFCmW5Vs iTByY1PfPGTk8FuDQBNZAt4dsZLrUGt0NujbYgqcbQccgnp6Y+g6VXXV9B0yMTwmWaQ5USMrsx4y fmf6dj2qK90yOVIXubq306P73lxxqWAByArnoQMfdHHaom1XS7cSpFbxRx2wwbi5jaSRc4x8pG7B LDBJA6ewoAmk1vXJ7driCwhtrYZzJOTlffB25B46Dv3xg52oKbyyiuLzU7h45cY2kwxjoen3n6dF Hf6VTl1WS+snVDJf3ORIEhU3DKCcZwvyR8A92Iz2rTtNL1q8tVH2WDS2RcJNcv8AbLjOAMgkgL0z gY5x0oAdBoy2VsiQW8MduuHkuLk+WnTkAZ39+5Ap0WoaFcXQiimm1e5i+VII4R5aZznAVQmOe5PQ HtVmz8KxKyyaveXOrTBiwFyxMSt6rHkgdff2rYiS002ArBbxWsQ5IjUIv14xQBmRTeKL25ZTaWWm WvQM7edL9QAQv59Pej/hDdPmuftF/Pd37lQCLmXK8Y5woHp34rWN/CJRGZEV26KWGT9BU4lye34U AZH9px24ltdG0mWdoSwKRoIYwwOCuWwM/p71iw6oLczW95c2VldTn5LfSoC85YZypcgqWGcYxwc8 1taxZpcTJcXGpy21milZYiyiNx7546nHOc+1UFvGt5mg0HQctgg3cq+Sh7Ag4y/QntwBjqKAM+20 ie3upLl9PhtoSuZ7/WZ/tEkgwMjYGAX8T2xjpja0yxeTVTfSySXUQiBimuIzGyseyLgYXHqOp69a x7i4guLdlF6mpaizbnigxeeWV4yqkhI8ZAJ29T3zW7puk3kN1Hc3F7cBQCTbm4eUFiMcseCMdgow RnmgDbqOZZGiZYZFjkPRmXcB+GRTiyopZiAo5JJ4FYd/4ptIEQWLQ30ruqLsmCxDP96X7qng4HU9 hQBHdaFo9sy32sTzXzIdqNevvUE9ggAU+vTjGeMVk3zXeo+MLSC0t1hhWzdRuYfvYg8ZIZRyqH5R g4JBPGM5vS38utap5el6egaP5DqdxFnye52qRyfu45HXOMCotsHhvXNDS8vUeSa3uY57y4IVpWzG 4JOe2CBnOBxQB1VvHLFAqTTGaQEkuVC55z0Hp0/Cpaw7jxHuKrpmn3WoM/3ZI0KxHr/y0Ix1GKdP a65qMOGvIdMBx8kK+a+OD987cHqOAaANae4htojJPKkSDqzsAKzI9fhvI3OlwTX5Q4JjGxM9xvbA yPTrToPD1iiYuhJfvjG+9fzj+APA/ACtRVCqFUAADAA7UAYy2ur6lARfzx2UTD/U2wzJ+LnIB9gD 9fTRsrC106ExWsKxqx3MRyWPqT1J+tWaKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigBM+lJH/q0+gpcUkYx Go9hQB4LrhK+ItVG3P8Aps/Jb/po3tRRrqk+ItVIXI+2z8/9tGooA98ooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArnYXP/CwLlJAN39nqYzkfd3jPH1roq53W ZotF1621y54tGgNnNJg/ustuVjgEkEjHtkUAdFRRRQBz114x0y0v5bSX7SHjYqWW3dlJHUAgc9/y q7p/iDTNUANlfQTZ/hDYf/vk4P6VZvtOttQiZJk5ZSvmLwwB9D/TpXOal4N823kCOl8doWMX2WdP XDggkcD5en50AdWHzTwc15zY2Gl6PeW1oNX1PQ9SvJDHFASDbySADIUFShHIABOTxjtnp9L1TUBr 0+i6nDC8scAniuoTgOmQuCp5U5J/I9OMgG/RRRQAUUUUAFFFZ2pa1Y6TD5t7dRQKTgF2+8fQDqT9 KANAnFNLgdc4965SfxbNfQH/AIR7TLjUGI4uHTyYEPuz4JIHOB+YzWfdatvt408ReJLbTWfg2+lN +9DdQGYbj0I6DHvigDqdU13T9FthNf3ccIb7i5y78/wqOTWbBr+o6xa7tG0mbDAhbm/Iji9mABLO PpisHT7zSdNlSLw9Bp0ecmTUdRuVVgTkn5MhyDjttGfoataje+HLyRV1bxM18yks1payAxAjnGEB IGDjJbpnnrQA+5V7WBv+Er8RhgzZ+x2OY/fBK/Owx646/SrWm6U8Fr/xTukw6SkjZae/UtMPcJkn GOzMOp4HeCHWxbMLPSItI02zjHEtzcI5IwP4I2znr1Pb34Zfax4Xnkhk1XxDPcAciBN6RPjnOxBl h0PJPT2oA0JpNLt9QtxOLjW9XiIG2MBzE2R82zISPnHJwfetCSDXL25GbmHT7PriECSZuOhLDav4 A/WsC68e6datBY6ZCsSt8kck0LrGuADgIo3dD0wKWfXtF1FQl54guX5BMFpA8SH/AMdLd+7Y78Yo A3mXQvDzvPK8ME0pyZJpC8r9BwWJYj2HAp8Op3Wo25k0+xdFP+rmvD5aMD0YKMsR0OCFyD1rndO8 SaTazNa2P2LTLdQG8t4HZ3Hr8nHfpknvU/8Aa+hSTvdSXWo6iyHcqPC4SMjpgbVXk9znp1oAneW3 u1+xX00+sXasGlt7IhY4/TOCowfR2NajW+rTShFnt7G1XAAgHmSY/wCBDavbse/4Yp8axPci3SMW MYwN9zEzkZyFG1OO2fvdPrRcX3hyZxd6jqk94ifdjmjOxT/uqgz1PBzweegwAaFw+krfIpgm1O9R wMKDMY2B6nJ2x8/TH4VVuNO8Rtqc17p01rZxz7TNBJIX3lRgNnaQpIAGR2x/dwY4fF9g8zw/bYrW AYSMC2kYgezY2DH44/Dln9o+F5JS8+oNqMzHcqTtuA4PGMBV49cdqALUGuWukRw6Zb6RfsY1ASO3 WOTPqch+uck5x1z3qeefXbueOS002C0CA/vLyRS5B6rhc7RkDOCegrLbxdA52vfW1jbhgFNtGblj zg4ZAUXnjkHrXO3mpg3z3FnpN1fyIcrc6nMWA6ciNcAZ98dh7UAdBd3tqVFvrV4+qS7smC0TEcZw OuCC3pyT1rK1vx29pcCCBo4mAIQQoJi2OB7YyMce9c/qg1K9uvP1ydovMDNHDbHsv9wEnbkj7xA5 B64qxp+i3C77CCzkilaMSCzgeSNp8ZAkd2ysZ4B5x2wvzDIBBLqWrarfM0drNazAbmkumG9E4yWB HyKOSW4A7Ywa67w54a0fUrB5Lhrm/G/BlYtFFIw6tGFwSASRk9SDioVsraxOm2wtRqOo258uKOCI x2kMw2ne3d2HBJ5+6ThK0Znie9t31u4nudRjbzoNMtF+WNhgqcDOXHXLNjk9qAOotbO2sofItbeK CLrsjQKPrxU33h3H6VhWGqXs2qLa3zQWsrfOLNEMkgXB5d1O1Rnp0zj3rSutWsbK7gtbi5VJ7hgs UfJZiTjoOg9zxQBPIFClt2AOuK8i1ltdu9Qhl1C8iS3mha5hjiQsqRn7g2jqcjOeeozgDj1fVYmu NJu7dDiSaF40/wB5lIH864iG70/XPENpI17LaKmmGJ3VvLaOUHLL8w4wpbkfnQBHo3gK9Msc91dL DaMI5GthAA7EMSVJHKZyMgf0roVNzomqxWtxI82m3LCO2diWaJ+MIx7g5OOpGOuAcc/FJpmi+J7e 50zV3S0ZWF8ZpQyTE527VGCzZB5HTK9iQZPEeu2/iJ/7Fhile0dlZ2iBMsmOcInbPTLY/wAQC6fF rau7Weh6fLdTlsb5wBEmMHccHtwcHaelU4rDWtdu2tNR1iCa0Zw0sFudiMgI3oGADP1weSPcHite 10rV9RhW3v44NM0+PIW1t9rs3QgknK9SeoOSOnerNvc+H/DxFrBKpnYkFYlMshPoQoOPpxQBp2Gl 2WmR7LK2jhzwdvJbvyTyfxqE6sJrlraxia7dTtaReIkPoz+vsATWbfzaxqEq/YdJk8lh96+kVEHv 5Y+f88H2q3Nol1qMOzUNTmVSeYbMCJMY5U5BLc55yPpQBn62rxaVctq2s28Uky/uoWkMcSc8/d+e TjseCe1V9GuxNBGlrpt3qDoWdZ2jENtnPJUsecHjnJ44wOnRaZoWmaOG+w2ccTN958ZZvqTzWjQB z0GneIZZwLnUrWys1G0QWEIJxj+84OPwH+NUtW8L2lvqWm6rb2xnliuVFw1xI0mUbgsQxIGM54Hv 2466igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooARs4460if6tfoKU8c5pE/1a9Og6UA eC60x/4SHVef+X6ftn/lo1FLroC+ItVBXn7bOf8AyI1FAHvdFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFRzQRXMLQzxJLE4wyOoZSPcGpKKAObTw/qmmSltF1 jZbDGyyvIzNGO2A27co9APTnNWxbeIpR8+p2EB44itGf6/ef/P61s0UAc03hrVLqZXvfE98VHVbR RBn8iR+lWZNI0qxjDXl7cgsNnmT38gZvYHcOfpWvc/aPs0n2QRfaNp8vzSduffHOP88Vj2Ph5WdL zWWW91EceYfuoOOFGAMcZ6daAMWTRl1z93p9vd2lujLsvZbmTJUHnYhPHqD/AC4rptJ0a30qBQrP PckYkup2LyyfVjkkdABnoB6VogAAADAFFABRRRQAUUUUAZHiRY5dINrJ0upo4BzjlnHf/P51y6fD qxmu5oLy71NzGP3M7ThjIp5OcrwwPHXsDgV0HiksE0jDED+1LfIHf5q36APMtC8NC7vbrTNYu72e CBnt03XG2OQjB2quST8pOR2GeueNzVPh1oU+nsLDT4YLpG82NgOGYc4PbBP+ccVqaaoHirXELBh/ o8yjb9wlGU8/8Bzx61u0Acdomh6JrtvBq32K2VMbfsyKrKrLwd7dXOeQTjjFdAmgaNEMR6RYIPRb ZB/SqGg2yaZrWs6bFBHDbF47uEKeSHXa35NGf0roKAOT/sfTdO1+eOXTbKK2vVHkTtEpVZT/AAYI xknLe/Qck1vJo2lo5ddPtd5GC3krk/pUWvaSNY0t7cNtmU+ZA5YgLIOhOOf8Oo5AqbSNSTV9Jt7+ NdglXJXdu2sDgjPfBB/+tQBgeILezttb0SMaZZuk8zKztEp2ncmOMcnr9OtdUsUasWVFDHqQOTXJ +Ldo8QeGWYdLsgevVPb1x3/+t11AGL4i02W40+5urAtHqUcQMLqNxO0lguPfLDHfdg8Ve0m/TU9J tbxGjbzYwW8tsqG6MAfYgj8KtmuY8GSRJb6np9uCsFhqM0MSYOFXdnAPfkt60Aa+u2r3ejXMcWfO VC8WBklxyB+PT6GpNIv11XSLS9G3M0Suyqc7WxyPwOR+FWz1HSub8Blj4M0/dw37wkHqP3jGgCLx dpwgWDXLaBS9lKJblIoQ0k8eRuHvxng/XsK2k0nRblFuE0+wlSUb1kWFGDgjqDjnI71YvIUvbGe0 kyqzxtESOeCMH+dY3geQt4N04uTnYw65wA7AAewHH0FAFHTdDtT4p1dEzbxW7xPHFbARcMnPzAbs Eg8A446DmtnVLSytLV7tdLjuJgy8Lb+YxJYAsQBliOvrx1FVkmdPH8kS5EUulq74XqyykDJ+jH/I roKAODj8I3Z09rvdNc30zKzC6CrIe2Sckrgdg2cADI5B1Lu3k0OwFyibHlcCRIiGQSNnMsjHYXyc DLFRyOldRUU8C3EYRmZcMGBXHUHI60AcgGuVtl8yZtOVVAeZf3k05PGAB91dxIGPlyRjPFV5IIRa F43OlxRMFk8pgt3ITk/vJCV2AnkZ4P0xXR/8I+j6s13LOXhB3RQBANrY5YvyxbJJB4IzxUM+gzS3 oQNAtijCWJWXcUfGD8mMEknO5iSOgHOQAZqCWWXy45Y9GsMFmjRDFJLKOpXIVnGNvOBngYPNPt9R t4JUTTLKG2W5ZlW9ueHmOfmIXG5yTyBnJPar2rWWkWrG7vb37MXI813fc8g7KCclRwThcd6xHnfW JpP+Eb06YI4MU9xc5jjdDjAUkltoGcqu09PagC7pup3qvdMouL0hgslxcOIUVhwdsf8ABx1yRn8q oazYWMOoC81eO3uzKco3lJbwgnjaZOXc89s9sgAHF/T/AA5riywrd6jb29rAP3cVpGG5OeQHXAbv u5PJrVj8K6Ml19pe0M8/d7iV5d3uQxI/SgDi5wuoIF03ThDCki5Sw0/e7kHo0xwF6feHvkEdeo0z T79LZPsun2WkuVIaV/38pyc9tvXryeOBj06RVVFCqoVQMAAYAFLQBg2/housn9q6nd6jvOTG7lIu ufuA46/h7Vq2un2Vju+yWkEG4AN5UYXOOmcfU1ZooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKADtTU+4ufSnUi/dH9KAPBNcKnxFqvyt/x+z/8AoxqKTXlm/wCEj1XC jH22fGf+ujUUAe+0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBz/iuNZItILAHbqtswzjruroKxtdntitvAbu3jnjuI bgxvKqtsVwWIBPoG/I1BceMdLgk2RpeXDbgv7q2bBJ6AFgA34E0AWLGV5/E+rkxsqQRwQK3ZjhnP /oYrYrzzQfFV9NJetBot/PJdXjXCuU+7FwqAnpzsK5zgYOM4OOhGta/IpMXhhsc7fMvUQkdu3H0o AmDE+O3UbsDTFJ445lOPx4P+c1uVwula5rd3qmp6hb6DJdRvItsAt1Eoi8scgEn5gWdjnHfrWtJr uvooK+FZScZP+lpx+QzQB0THjHPPpXL+AM/8I1tVt0azyBM+mc/qST25JqC88Z3tt+4Ph6+F86kx Q/e3Y6n5eSB9OasaFf2+l6Zb6culasnlKAzNYthmPJPBPrnqcdO1AEXi/nW/DQDnP20EqAeRuT27 fUfjXXVx+s6jbt4k0G4ZJBDbtO0rSwtH5eUABO4D1P1roI9b0qRdy6jaEe8qj+dAF9iQM1zXhG1e GbXZ2yBLqc23IIBAbqPxJH4VNr3iKK004rptxBPfTnyoAkikKxH3j2AAGeeKt6feadY6ba2z6paS OkaqZPNUeY2OW69zk/jQBp4+lYXgy1+y+D9Mi5x5W8E9wxLD+dLr2v6db6BfyR39u0ggbaI5l3Zb 5QevqRzV60u9Os7KG2W+tdsMaoP3oHAAHrQBdIwAx4x1zXP+B2Evg+wdeARJxkn/AJaN681Z13VL RNBvfLv4llkhaOIpIC29hhcAck5I6VH4cFlo3h6ysHvLZXij+cCVeGJLMOvqTQBQuZGh+KNngnE2 mmMjt952/wDZa62uN1W4sT4/0G7W7gIEUyyMsgwAEbbk5wBy3X0rXu/FFlFlLGO41OYDOyyjMoHp uYcD86ANuq19qFpp1uZ7ydIYx3c4z9PWsoN4g1a0BAi0YMuckefLn6HAA/X6VZtfD9lCpNyGvpTj Mt4RK30Geg5PSgCvNrl5dxj+w9OkutwH+kT5hiXPf5sM34D8eaeNN1a+hxqOqfZ89Y9OXZ34+dsn p6YrZVVRQqqFVRgADAApaAMzS9A03SIwtrbqHBLea/zOSRgnPb8MVp0UUAFFFFABRRSAbVAGcAY5 OaAFooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEJxSJ9wU40 1OEFAHhOvZPiPVMrz9sm9P75opniDP8Awkmq7mbP2ybrz/GaKAPe6KKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooApf2a i6i96kjB5MeYhVSrYxt7ZGOcc9+/Aqa6s7a+h8m6gjmjznbIoYZ9eanooAo6RpUGjaclnbl2RSSS 5yST1+n0FXqKKAK9lY22nWy29pCsUS9FH+easUUUAQCzgF614I/9IZBGXJP3Qc4/M1PRRQAUx4Yp DmSNHOMfMoNPooAqyaZYSgiSxtnBGDuiU55z6etRnRtLLFjptmSTknyF5P5e5q9RQBl3XhzRr2MR z6bblQwf5U2cgEDOMZ6mntoWlu+77FGG4wVyuMemOnStGigDAm8H6VNqCXLxkRxkOkCfIquMYYFc Ht0z/M50E0TTE24sYTtGBuXdgfj9av0UAY994W0TURCLjT48QsXTyiYsMcc/KRzwOa1Yoo4U2RIq L6KMU+igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKRen4mlpqfd/E/zoA8I1/J8SaocE/6ZNzn/bNFHiHd/wAJLqmTj/S5 f/QzRQB7zRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUgOc0tNU5ZvY/0FAHhPiISL4l1QbgP9LlONn+0aKm8TXA/4SfUxlji4cfd96KA PcqKKKACimlu2CfpWDfeIdtxHb6ZZvqM7EbxEcIgJ43PyB+o45xQBv7h60ZGa4//AIq7Vb+eNLiH S4oQjJutfMEm4dMseSvfGOoqzb6xqFhqMdhrdukauhK30RIhYgEkEE/LwD3/AAGaAOoopBnHNLQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUZzQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRVW91 G2sPL89mBkYhQiFycDJ4AJxQBaopkU0U6b4ZEkTpuRgR+lPoAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKiiuoJ5JI4ZkkeI4cK2dp54P5H8qAJaKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKav3n/3v6CnU1fvP/vf 0FAHhfiNVPibVD0/0qToP9o0VP4mhuH8T6k0UDFPtD4O3357UUAe30UUUAc3dfaPEWoXFjBKYtLg byrlguGlccsoPOR90Hgd+SOKz4tA1zTruaG01NLa0uJGECQWsbCPAJXzCy7j8oAzk84HStHwJHGn hCzZOWcyM7FcEtvI5+mAPoBWxqUl7Fp8r6fAk92APLjdsA8jOT7DJ/CgDjbzUPFnhia3lvby01aK eURLbLHsmb1K7QB+nUgd66rxBDDcaJcRzZGdoQqMsJNw2YHruxXL2dt4ss9Skuk0m2muJ+Jri4uF XPQYUL0AwOuenGK2ryWXSbJNV1q6E08ORHbWy7I2kbgBQcszdeSemTgUAXtBupbnTdk6gTW0j20h AwGKHbuHscCtOs/RrR7TTwZkVLmd2nnC9nc5I/DgfhWhQAUVmarfz2tzp1tarG811cBWVx/yyAy5 HI5Ax6/Q1p0AFFFU5bCOXVIL0lg8SMoxjHPr3PU/kKALlFFRyzww7fNlSMMwVd7AZY8AfU0ASUUZ ooAKKQkAZNV7nUbKzK/abuCDdnHmyBc464yaALNFIjq6K6MGVhkEHIIpaACiiigAooooAKKKKACi ikyKAFooooAKKKKACikLADJNQT3kFtE0s80cManBaRgB+v1oAsUVXtLyC/t1uLaQSQtna6nIOCQf 1Bps+oWttdW1tNLsluSRECDhiO2egoAtUUUUAZWk3aanPeXUczskVw0CgN8hAC9vrk5689cVq1he DlC+FrJgCN4Z+e+WJB9uMcVu0AFFFFABSMcUtc/4gmlvbiLQbR/Lnu0LTS4P7uEcE8evT8e2QaAG XutXF3dS6dosZluUfy5J2XCQHnJyQckEY9M+uCAo8NC6Al1m8uLybHQOUjT6KuBnk88ZrY0/T7fT LNLW2Tai9TgZY9ycd/8AI4rkdfgm1nxjHpSzMITbhZRHwUjLBn57E7UH/fP4gD9LvbSS0uLzQdRm jt7SYJJb3cgMTKMHILfMgIOATjkcjvW9pev2Oqxobe6heUrlokkDMp7jHU4IPIHNYV3Y28PxJ0+N rZPss1kVRMDaHXOOMdlXGOg9s87V54W0u9+1eZAFFwQWKAAggYJH1GBj+poA2FbPanVieHzcQG80 y6m86SzkASVuWeJhlNx7twR9AK26ACiiigAoqveXkFjbtPcSCONSATjOSTjAA5JqhYeIbXUL1rSC K5LiMyBmjwpHoe6nngMBQBaGpxHWW0za3mrAJyxxtwWxjrnNXa5e0ld/iLdRMiDy7AbnUY3kshrq KACikBJ7YpaACiiigArMm1u3h1u30popjNOhdXAGwDDHk5z/AAnoO4rTrkr9pv8AhZFikYyPsYYg 9CNzg/o2fwoA6zORWJqDFfFmiIDhWiucj3wn/wBetyud1XZ/wm3h8sMtsuQvHQ7B3+mf85oA6EAK MAAD2paKKACq9vew3U9zDGfnt3CODjuAc/Tkj6g1YrmvCr/abzWbxlw73bRA9iqcgj2+f/6woA6W iiigAoqCa9tbd0Sa4ijeQ4RXcAsfbPXqKnByKACiiigAooqtfX9tpto91dyiKFCAWIJ6nA4HJ5NA Fmims4RSzsoAGSTwAKSORJokljZXRwGVlOQQehBoAfWeJ5P7fkt97eWbVXC4G0HewJ9c9Py9qLrU xa6zp9gYgReiXD7sbSgBxjHORn8qrRtjxpcIVHzafGQ2OeJHyM/iKANmiqOp6vY6REkt9P5SO21f lZifwUE/jV6gAoqvNf2lvcQwTXMMc0xIiRnALkYBwO/JH5j1qcsFUkkADqaAFrF8M7JdNmvUBxd3 U0wyMHbvIX68Af8A6sVd1K+Frol7fQujeTbySq2cqSqk/lxUegQpB4e09I/u/Z0b8SMn9TQBo0UU UAFFVr+/ttMs3u7uTy4I8bm2lsZIA4HPUip9/GTxQA6imh1OQDkjr7UueMigBaKTcKqvqNrHfx2L SEXMilkTaeRzznGOxoAt0UmaAQehB7UALRRTXdUBZuABkn0oAdRUNvdwXcbPBIsgVip2nOD6VN2o AKKKQnFAC0Um4AZPFAYHoaAFooooAKKKKACiiigAooooAKKKKACiiigApqfef/e/oKcOB1zTEOS/ GPm/oKAPDPEbSf8ACS6nhyB9qk4H+8aKZ4lkUeJ9UGMYupOuB/EaKAPeaKKKAOW+z33ha7uJLGzk vtMupPMFtAoD27kc49VPHHQe2PmuDxdpifLcreW0o+9HLaSZU/UKR+tbtFAHOS+JryWeNNN0C+uU Yj97MpgUj1G4Z/PFTWfh5zqK6nq92b28QkwqBtigzjhV9eByeuAcZFbtFABRRRQBympSM/xG0WHL FY4ZJAMnAysgJ9OePy7d+rrk7/MXxL0t3UbZbRo0Yk/eHmMcfhXWUAFZ9rdGXW9Qt/tAdYUi/djH 7ssGPPfJ4P0xjvU9zcmOWO3iAa4lyVB6Ko6sfYcD6kDjqMu2dbfxpfQO5aS6s4po1H8KozKc/i4/ X8QDXublLZEZ2UbnVBk4yScf/X/CuB8Ww3Or6PquqFg+nwr5drG67hlThpcA4z98A9cN2xzreMpT /aOkWojR2uhPCu8fKGYKgzxnGWB/D6Vc17SYoPA17YWoURxW7EeYeuPmYn3PJ+p7UAdD0HTiud17 X7rTpJFsooZBbQNcXJl3BVUfdQEfxNggDk9OOa3bS5ivrKC7hJMM8ayISOqsMj9DXCQJqt74/wBU tEIFv9ogmuiOixoDsXn+9weB2NAHX6zcXdpotzc2cLTXKR5SMDPzHjOBycdcd8dqzdB0rSpbETtd R6zN/FdTqJHXjIXnJXAPQ8810lYU/g/RZZzcRW72tzjCz20zxsg9Bg4A68YxzQBtQxRwRLFFGsca jCoi4AHsKfXOhtV0XUYhc6hHe6dPIsSrKFSaIk4XGAN4yQDnnofWuioAKKKKACiiigDA15ZdRvbX SIrwW6SAyzqv35FBGF6g7Ths45OPTNN07T30fxH9ktpGGmzWjPHAWLCN0ZQduc4+/wA+uR6ZqxPf QWPicJdMIlurVRFK7hULI5ynJ64dSPoafaXn9o628trJHJZ20TQs6nO6UlSQD0IAXB569qAK1/qB j8WWNqZ/Lgjt5JpgX2rg8At2wNp6+tYOrz6xLYTeJFupYLS1lR7W0RmRZYhIMvJ0zuXnnIx+Z2dU 0GfU/EsczhP7Oa1EVxkjc+GLbR3HOOR6cEd9bUNMhvNDuNMSONIngMUa7flTjC8e3H5UAXhwKKra et2lhCl+8b3SriR4+jEd+g6jk8das0AFFFFAGHq2o339oppOnW2Z5Yw7XUnKQgkjp3OFPXAzjr0q he+EreeJWv7x55I28xru6O7yl/iEYJwhIAyentzxsajoVnqVwtzI1xFcqmxZredo2C5Jxwfeqc3g 3RrsH7bFcXh65nuZG7Y6bsevPuaAJ4NZ8P2MCW8WqadDGgwqfakGB+dR6wlrdXehO4jnhkuztJ+Z TmGQgjseQMfn2rnbjw3a6kv2Tw3Z29pAjlZb+ZPM3LjBWLdnn/aGPunB5Brp59PjtjoltaxusFtc YUBidqiGQDJ79uvrQBPJNNp0GZg01ugOZUzujUdCwJJbjqRz7VgSeMpAkk0Wmk24nESs8xR3Qqp3 rGVyfvDgenbnG7r9jLqOhXlpAzCWSP5MHGSOcZ9DjH41Qs/EP2txp8Glzw36R8wzLtjiIA6sOdvT BxzxwM0AJ4OlW48IacYyflh8tgSfvAkGsK61fXI75dWivMaY96tnbWPlKTNyQW3Yzk7Tgdjx2Obd jc2vgjz9HnhuXtpJDNZmJSw2tgeXyeG3ZPYHOeCecfT9Qn0G7gXW7O+aygLvYqkO47nJYySZI+f5 iMcgZ7EZIB6YKKxdP1y41eBJrLS5kiLYLXcixgAYzjbuJ/8ArHkVtUAFc14QkbUba71eeHbNdXD+ WzEsREMAKCegBB6cZH5dLXLeAllg0O5spgoezvJISVbO48MT0HdiPwoA6mvPpLzUbP4h6xd21u2o iCCOFoU3K0YcKy4wCD90+nNeg1zvh1Fn1nxFqKgBpbxbfjuIkVc5+pb8qAMeW+1XVvFXh+WTTW04 Rm4Km4YMSxiP8HBIGR0POe2K7dcxwKZpFJVfnfG0HA5PtWHqLo3ijSEaQedFI5Vc4yjxP+fMZ+nH rUN9fz6/dSaTpTqLeNzHqE7EAhCdpRAQTk4b5sY+XAPUgAs6Cour/VNWTHlXcojj77liym7PoTnj 275rcqG0tLewtIrW1iWKCJdqIvQD/PepqACszXdY/sayjmFu9xJLKsMcanGWOSPU9j0BOccVp1l6 /Y2d/pTreztbxxkSLOrlDGw4ByCPUj8eMHBoAyo/Dc91KJtWna5u5EO58bUtgRjbGAOvUZz7nnk9 BZ2NvYxBII1U7QGfA3Pjux7nr+dcK2r+IrVw0fiCwvCyhxDJb5P0JjXAOePvfjWpoHifWdTuBFPo 6NGsvlSzQuVEZH3sg5HHpu/XggFeG8hsviTrE13OsUK2YbczcAYhH554wOvFXbTxVfXGvWFjPpD2 kN4ZRG07kSHYm4nbjpyB179eKlvfCVvqHisapcrG9t5Cgx5IZpQcAn/Z2449RVzV4ETVtJ1OZ1jg tHlEjs2AodMAn2yAPxFAF3VL+PTbF7iXoOgHU9z+QBJ9ga5u21fxAumtrNxaiSAoGFqm0fIed4YZ Pp1B4P1rV1s2+paBfyQATtFBL5bLnG4oynaR1OCRxnrWZeeJrC80hdO0uOSa8mHkLaKvzIvQ7iDg DGec479MkAG9qt89hDAY1DSTTpCobuSf8Af59sVed0ijaSRlREBZmY4AA6kmszX7OS7sYZIY2lmt bmK5jjBxvKtyPyz/APX6VWf+0NckRPJmsLBSPOWXAkmHdcDlR7gjr+QA7RdcbWdV1FIQn2G22LG+ 0hnY5yc56celVmRT8S42xkjSD+H74f4mtHT9Nk07ULryVgWwm2ssa5DIyoiADtjCn9PXim7LH8QI y5VfN00ohJxvYSZwPXAyaALGq68tjOtpZ2zX18SMwRH7inHLEA7RyOtYlxHrR8WeHrvUGhRC86GK JSBGGj4DNk7iSOOg/PjVe21LTteu721tlvLe9C7180I0RRQBjPBB5pt9Yavqs9jK62trHb3CTbdx eTAyGGcYzjp/TnIB0FFIqhVCjoPeloAK4nwbe/YrO/tjbzSXJ1Bx5MafcARASxPCAbWxuIztwOwr tq87ufD+o3Ws6jZWDPbPLNLLc3TSMEeKTaVQDHJzuB9Md+RQBt3fi+Z52i0TSJtUERIllRyiKfRW 2nd39O2M5q7b+JBcaXa3w0vUcTblKJEGaNlYqQwzxyDz6eh4pbRNXsrWKzh02wSNBsV452VR152F Sfwzn371e0qzksbBYZpBJMWZ5HAxuZmJJ6D19KAPOU1KDXrC8nl0m71O/u5WSErHlIEDfKA2OMAk 8DvzjJr0fSoriDR7KK6LG5S3jWUu+4lwozk9znPNYtz4f1Kzmz4ev0srdm3yW7qCrNgDIJViMgCt Ky0y8HlyajqU1zKmCFjPlIDxnIXG7p349qANSiiigArm/GiKdNtJZV3QQXazSgnjaqOefbOK6Sor m3iu7aS3nQPFIpVlPGRQBj6jdyyaElmroup3cSx+Tu2vyQrsBjOFBJzjt+NS+HblDYvp2VE+nP8A ZnQDHyrwjYyTgqAfrn0qSy0Cysrpbv8Ae3F0q7FnuZDI6rzwCeg5P5mi80SOe++3208tneFdryRY xIO25Tw2P89sAGfck3/jqwjhb5NNikkmOMgM6hQnscFW+n1pt3eRaf40nuZwoiXSQ27jcSJSNoz1 JLAAepHtWzpumQ6ZC6o8kskjb5JZXLM5+p6D0H+JqO90W0v9TtL6YP5ltnaFYgMcgjPrgjNAHL6n p1ze+H7/AFy/hkS8ljVorU8/ZkDLkDd3IXJ4HUjFdtLKkMTyyMFjRSzMegA6mm3NvHd2sttMN0Uq FHGcZBGDWNFcXGqaLPpd3HLBqT27QyF4jsLFSN4YDbtJzQBkNOltpC6vexx3eo3snmWNtM28Rhm+ XZkZAAIJOF7Ditzw/cyaz4Zhlv8Ay5mmWRJcJtVwGZenuBUeh6Nc2kUJ1OWGea2Tybfys7Y48AdO Mk4547CrWnaVJpgNvBdYsQ5eKHYNyZOSu7uM56jPPXigDJ8SaPp1h4cvp7a28mQQ7A0Tlepxzg4P XvWh4esYotC01g0wb7NE23z3Kj5BwBnGPbGKb4vOPC92cgHMeM/9dFrWtoFtbWG3QkpEiopPXAGK AJaKKKAKOs2n27Rby2ESyu8LBEbGC2Mr146gVzs3inUoLTfL4fuEKg+ZLISiZ6DGRznI4OOuM8V2 Fc54uQ3sOn6VHOElvLkApj7yKCzH8PlPUdKAJfCel3Gm6Li8lkkubiUzys+d2SAOc85wBmqek6Ud Tvr3U7x5ipneGECXh4lY8NjsDkBe2M5Oa6qsf+wQHuFW/uktp5GleFCBlmOW+bGQD6DFAEVic+JL iO0eU2cERjkXeWjWbKnA7A7T0Hv07ppV4k9xrF/ePHHHBdtbIZGG2NUAHU9NxJJ/LnFa1jY22m2a WlnEIoEztQEnGSSevuTVFvDemPcyzNFIRK5kaPzW2FyclsZ6nj8qAMrWdWub/T74aTuit4oyZL7a fm46QkdT23dsfQ1t6Jpo0jR7ezB3MgJdvVicsfzJq01pA1kbMxjyDH5ez/ZxjFSqCqgFix9TjJ/K gBa5iMy+KL+Q7pIdMtXMYCOSt3zgkkHBXA9/vevTobuJ57OeKJ/LkeNlV/7pIwDWDa6Rq62EGmyS 2ltYxxeS4tyWd14BOSowTz0x97PagBdKvbS21p9B0+3R1hDS3U+FQbuOAFUAkZUdsAAdRXR1ycNp B4Z8RzXMimPT7qPZE43P5bfLkE89SCcn/Gt+LVbW5kCWzPOSRkxoSqg9y3Tpz15HTNAFTWNb/s3K QQC5lUDcgk2nJIAUcHk56VT03WtTfWTZatZxWqTR+dbuH2k9P3eD958ZJx0x071naLpC6j4k1HUL h5mWG8ZsEkAurEIP+AgZ/FR0znqNU0mz1i1+z3sW9AdykEgq3YigCpquoNayR2doyNfzj91G3OOc FiPQZz+B9KzbGz1TS9etIp9VmvmuhK86uCERQByoydvzEdMDtxWP9h1+DxhDFJqVnPeLakwSTLj5 dzDoBy2N3r1PtXX6VptxatJc3939qvZVVWfaAqgdlHYZPtnigDTooooAKKKKACiiigAooooAKKKK ACiiigApqD5n92/oKdSDq31oA8N8TxA+KNTO3P8ApD+nrRR4pdYvFOpqVIP2hj0z1OaKAPc6KKKA CiiigAooooAKKKKAMbXrG6ka11LT41mv7FmMULthZA+FYE5GDjof0NEmsXU9qo0/TZ3u3wCs6+Wk JPUsTjOPRc5x261s0UAZ+maYLFp55ZBNeXLBp5tgXdgYAA7ADoPc1JPplrcala6g8f8ApNsGEbjj hhgg+vU/mauUUAIVBIJAJByPaloooA5a20bW9EX7Do9xbPYMzODdIS8Wey4IGM8/d6k+tWLLwnBY yw3cV7c/2ipYzXRIJn3EFg4xjbxwBjHrnmuhooAjjSQENLLubGCFXav5cn9azbnwxol2wabTYCRw Nq7f5YqeW/uLe7dZbCU2owFniPmEkjugGQOozz2/C/QBlWXhrRtPuPtFvYQrMMAORuIx0xn0rVoo oAKKKKACiiigCK4tbe7QJcwRTKDkLIgYA/jTooYreJYoY0jjXoiKAB+Ap9FABRRRQAUUUUAFFFFA BRRRQAgAUAAAAdAKWiigAooooAKKKKACiiigArntVs9QstaXWtMhNzuiENzaK4TzACSGGeCwzx9M dyR0NFAHP/8ACaaIgUTzzQS/xwyW7l4yOobAIGPrjg0J4w0aVWWyae6kzxFBbPlyTzgkAe/Wtmay tbiRZJraGV16M8YYj8TTobaC2XbBDHEvoiBR+lAHMy6VqPilkfVoBptpHuCQptadwy4OX52j2A56 GumtraGzto7e3QJFGMKo/wA8n3qWigAooooAKKKKACiiigAooooAKTABJxyaWigAooooAKQgEgkD jp7UtFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAQ3VrHdwiKX lN6PjA5KsGHX3FTUUUAFFFFABXPR3BuPHssWCUtbHbyRgOzKSQOvIxz7V0NY1jbtD4j1Wd0fNwYg h8s42qgyd3TktjHXj8gDZooooAKKKKACiiigAooooAKKKKACiiigDK1fS5LqWG/smWPUbbPks4yr A9VbuRjI7Yyan0y4v5oduoWX2eZQMsjqyP7jkkeuD6jk1eooAKKKjknihGZZUT/eYCgCSiqf9rac WKjULXI4I85eP1qxFPDMCYpY5AOpRgcUASUUUUAFFFFABRRRQAUUUUAFIOp+tLRQB4n4oyPE+pYH /LdqKPFcf/FU6j2/fHrRQB7ZRRRQAUUUUAFFFFABRRUF5dw2FpJdXBZYoxliqFzj2Cgk/gKAJiwU EsQAOpNLXK63rejar4fuo4r+2YlBKqs+CSmHAx1z8ta2gMv/AAjml7OE+yRYOMcbBjtQBqUU0MMf 41HLcRwoXlkVEXGWZgAPxNAE1FMEik4yMjqM9KcD+tAC0UmaM0ALRSZBPWgZxyRn2oAWikyPWkZw iliQAOSSaAHUViaf4ge/uIwdPnt7ed2S3nkZGEu0ZzhSSoOGxn0Hc4rboAKKKKACimySLFE8j52o pY4BJwPYcms+117Tby5FvBcZlJIVWRkLY5ONwGePSgCS41JbW/tbV4JcXJZVlGNoIGcHnPPbjrir 1YXidJ/stlJAEDrewoWcZCq7Bc478la3BQAtFUp9X062vVs5ryGO5YAiNmAODwPzwau0AFFFFABR RUF3cx2lrJcSttRFyTjP5DufQUAT0VkaVqWoahcu81gILJow8Mm4lm5xzkDr1x9PWtJrmBJ1geaM TMMiMsAxHsKAJaKry3sEFzDbyvtkm+4CDhjgnGfwqfPegBaKaHH4DrQGFADqKjimjnjWSJ1kRuVd GBBHsaJJliRnf5VUZLMcAD1J7CgCSis2z1rTtRkkjstQtp3TlhDIHIHrx29+lW5LqKCIyzyJFGv3 ndsKPxNAE9FFFABRRRmgAopCyr1IH1qOC5guk3280cqZxujYMM+mRQBLRRRQAUUUUAFFFFABRRRQ AVFbTpdW0c6AgOM7TjKnuDjuDwfcVLVRbZ4pppbeQb5HUyI+SvHXHPBIIGfYcUAW6hguY7nzDESR HIYySMZI64/Hj8KmrB8NBRJrYUgj+1Jc4GOdqE/rQBvUVW1Gae30u7mtUV7iOF3iRgcM4UkA47Zo 0+aa4sYpLlFSflZFXoGBIOPbIoAs0UUUAFFFFABRRWVZ3F/Nrd8jGF9PQARMowyuAMgnvzn6YoA0 bieO2t5J5SRHGpZiAScD2HJ+gpYZkngjmQ/JIoZSRjg+1YfjWaSDwhqLx5zsVePQsAf0JrW062+x 6XaWvP7mFI+evCgUAWcj1oyM1iuniXzpPLn0zygx2+ZC+SO3Rv8AP6mtYX+tX08LQSafPaeYBLKk bfKOCQMsDnHTg9R70AdHRRRQAUVk6lrBs76CxtYRc3kg8wwBwreXzyCeM8H8qtakdQFmW0xbdrkE HbPnaR3HHQ0AXKK5D7Z44RiH0nT5QM/NHPsz6HBJ71EfFGvafPDFqegoDKwVI7e7V3OeOF78+pAo A7SigdKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKiuLmG0t3uLiVYoYxlnY4A FAEtZ+p61p+kR7ry5VCfuxj5nY+yjms4Tapr7t9nLWGkugKXH/LedTnJQfwDHQkbuh+mjpWjWWjw eXaxfMfvyvy7nrye9AEX23U721EljYC3Ld75tpH/AAFc9vUimW1jrbFXvdYVT3jtoFC9+7An0/Kt iigDNk0S1nUC4kupj6tcyD9FIH6VFF4X0WIYWwQ/77M2frknNa9RGCNv9YPMP+3z+nSgDNn0jQYd nnWNkhz8g8sAk+w71Wl0vR2KtHock5ByNsWzHb+Mr7flW+AFAVQAAMADtQSB1IFAHOW17a2eoIBq CWlqqssttdXgkff2AyW249m9OO9bsF7a3RIt7mGUrywSQNj64qbcB3zVS70uwv1Zbi1ik3cFtvzf n1oAtgg0Ag1kQ6E9kP8AQNTuoVB4ik2yRgegUjj8DSQ3+p2TSnVrWI26/MLi1yQB6FMlvxHrQBs0 VXtL22v4RLazJKnfaeR7EdQfY1YoAKKKKACiiigDxLxfIV8WaiAUx5vc+woqXxgGHizUPmB+cdf9 0UUAe0UUUUAFFFFABRRRQAUhAIIIBB6g0tFAGVd+GtFvYXjm0qyO4EbvIUEfQgZrnPD/AIchv/D1 jcW+o6tYMFKSRQ3DIm9SVb5O3Kn/AOtXcVz/AIZlEdzrOnn5Tb3ryJH/AHY5DuH5tvNAEUPha7jU rJ4i1KRT/wBNCD09ck/r/TGPbJ9u8SzaM8t9e2KShZvPl8xSI0JJJ5HLlQRx0HoRXe1h6RoH9na3 qmoSGNjdSZj25yqk5YHtknH5UAZzPd+EruNJZJLvSbmYIrMNq6euQBljn5TkDkgDHA7VsanrFvYa Yt7zcJLtECwtuM5boEx1yOfpWjcQR3VtLbzLuilQo65IyCMHkc1j6f4U0zTbpJ4hPIYs+Qk0pZYB zwg7fePJyaAKvgua/k028gv7l55bW8eAO/UgBSck8nkkfTFT+J757X+yYIncPc6hDGwRipKbhu5H bp+dQ+D3WRNbZXVwdVmOVORyqHiofFIz4i8NEoGAuW9fVPw9/wAPrQBp6i4stZ0+7eUiOcmzaPcc MzfMjfUFWH/Azz2MGoahe3V4ul6SAHZCZb0AOlvg4wVPVuCMHocHnmneKtOvdQsLX7AM3Fvdx3Cj IH3c468cEg49qu6NpMGi6clpBlj96SQ9ZHwAWP1xQBkeFJr9ZdU0vUJprh7KYbJ5ThnVs446gcZH J4bHap/GM8tp4ZuZII2foH2nkJnkfjjb+NT6gzaXqa6kkDvbyR+Xd+UuSMH5Hx3xlgfb6CpBc3Gr xgWyTWttv+aaRF3SL6IpzwfVgOO3oAZTa7bm/ivIrVpdKgbyPtakBI2Y7Sw9VGACcjHPHTPVdqzt V01LrQLmwgiVQYiIo1+Rdw5UcdBkCjw/Ks3h3TmVy4+zopYkkkhQDyevINAGjRRRQAVTutJ069Rl urG2mDEk74gTk98+tXKKAOH8V+HRZeHZ5rDUL+FYTGywi5fZw69s8ev4VreRr+k2jzy6zaXccSbn +1wiEAAc/ODx35IrW1SxGo2DWrYKO8ZcE9VDgkfiARU13aQX1q9tcx+ZC+NyEkA4Oe30oA423uYP F19LAukpABIDPfIA6yxjHyhyoPJC8eg9K7ioLOzt7C2S2tYhHCnCqOcfnU9ABRRRQAVzniOE32s6 Jp8h3Ws0kjzRsu5H2bWG4Hr0I/HPaujrM1jRk1QQTJM1veWrF7ededhPUEdwcDj2oA065rS1tE1z UYtSWH+0DeGS1M/LtEVBXyy3UDDcL0wau29vrzKkV3fWyKuC00EeZGPphhtGfpU2o6DperKov7RZ 9ucFmOcHPGQckcnjpQBm63NFqt7ZabZ/v3W43TzQPzaheuSPuEjIHfjjnkQ/27caXZGwMb6nqtvL 5JiUEPImMrIQASBggE9M55re0/SrDSoTFY2scCscttHJ+p6mli0yyg1GfUI4FW7nAWSXJywAAA9v ujp6UAcrqmhT2WmS6rqN/PfX8dxDKpU7I4QHUEImcAcnnv8AmTbmFx4nneG2eS20iF2DXMbEPckf KVXp8v3hnnOB+HR3tlb6haPa3UfmQvjcuSM4II5HPUCpIYYreFYYY0jjQYVEGAB7CgDF8G2v2Pwj pseFG6LzcKMD5yX/APZqr3R/4SHXks4Lhxp1om+6MTDZOzYKx+4wCTjI5x1wQsdpqOk+ErmC5uoA La0kSJolJIAX5SScdPQDtnPaqfhtNSg0bfZ2IM14DObieX5fm+56lgFIz64PtkAl16207SZdPuLO KCzminDy+QuwtAOXBC9QdowD3oj0i68QRR3etBbe3Zt5sWU/KoyRk54OcZOM49Ogj1bwbPqdlJJJ eebqbyhvNclU2Aj5AAPlHAPQ8j8a04NK1K93f25eRSRbsrb2gKJ/wI/ePPOM0ATrrML6pa2NpC00 cyuxnT/VqFA6HowyQOOhIq5qF0LHTbq7IyIIXlI9doJ/pVa6tLlL22nso4CIbeSELK5UDcUI6A5H ye1PvoLiXQrqB3Etw8DrlE2hiQeAOcDt3oAz5NRvBDYafbSpLqdzD5jTON6RqAMudoAPJwOACfyN We717QGBuYzrFo7j97BHsliH8W5QMEenI6cnmrfhYSXFjJqU4HmXTDacYIRRtCnHHBDEexGea3qA OSbUbPxPq9vplrc5tVh+1zeW2Gkw23ymHUep/Dpwa1LURW3iWSztIQkP2USTBD8ivuwvy9iRu57g DrjjnfFGkaLp+vxa1qdi0lncKIXaJjmOXOfMwCD90HOOeDxnr0WlR+H9LjddOms0EpDOyzBi/HGS Tk9f196ANmiqq6lYu4RLy3Zm6BZQSf1qwjq6hlIKnoRQA6iiigArP0jUZ9Ss1nnsmtSwDKPMWRWB Gchl61oVyuj69BZ+C7a5ZC0kR+zCBMb2kDYCgdzjDeuMnFAGkmqNL4uk0xJozHFZ+a8YHzbyw6n2 XHH+19K2K4y50q+0O3s9agPmXMTvPqagfNMr7S4UZx8oXgZA4znrnfbxBp40b+1ElLwHhVVcOzdN gU4+bIxg/wAuaAG+HtTudU05pLyFYriKQxvtUqrcA5APIGGHc1Lp98t5fX8YAVoHCFN2c9fm6cZx +lQeGNNm0rQ4oLkg3DM0khB7sSRn3AwD9KTTYGg8Sa0WRVWUQSIR1I2sCT+IagCTWLqTTHh1AyMb ZSIposEjDMBv4zjbz25zjis3wSzyWurSOcs+pytnOc8Lz7V0skaSxtHIiujAhlYZBHoRXKeE9MaG 1v47a5ltYlvJF8qNQQCMcjeCRxgY9vXJoA1PFlwLXwtqDkZ3R+WADg/MQvH51sDA4xisPXdKhOha k6+Y8zQly7yMx+U7sD+6CR0UCoIrm58Vp+4E9lpQbDSN8ks+M5C4PC9Mnv09aAN21vbS+jMlpdQ3 CA4LRSBwD6ZH1FT1z+h2kekazqWmRBI7dhHc28e/LbSNrHnnqo/MetdBQAUUUUAISQCQMn09a4zw 9r8GlaSttqNteJqG95LlRbOxLsxOenORiu0ooA4PxHr91qWnixTw9fpFPNEga6Ty8tvBC4wRyQB1 /pnr7L+0JCJr3yoQV4to/m2k4+8/cjHYAcnrwaq+JGWLSlun3Fba5hmIUZJCyLnH4ZrXoAytcsLv UraK3t5IlhZ/36uWG9P7uVPQ9CPQ9qrga5YQLJJNo628SfOmx4VRR6NkgD8O1btc4LO48T2+7UXR dMkbItYufMUH5SXHIOQDxjkYwMZIBq6bqQvtIjv5kW3VlZmBkDKoBIzuHBXjIPpV6ue8YKtt4MvU iTESIibEyMJuUEcdsZ9vXiuhoA520jjv/HN/dtCA2nwR2yOQDuLZckHsRkr+J962dQunsrCa4itp LmRFysMYyznoB/8AX7Csrw5GIL7XoScv/aDSHp0dFI/rW9QBxUus6teTM95Dd6XYjBAS0kkJwR95 kIOCemMe+R139HTR5d1xYeXLNyzyuP3o3dc55GSOnA46cVNf61YadlJZ1aYdIIyDIfw7fU8VlaJb zX2u3GuSWaWkDReVbpsAeQEgs7kdScDj/wDWQDpaKKKACucv/FiJctaaVY3Gp3KHD+TxGvrl8Hp7 A+nWujrHuvD8LSvcafO9hdOxZ5YuQxPXcpOD0oAg0nxBd3l19m1DR7jT5mcqm9t6vhcnDYHH0B98 Vv1yV1oPicyRTQ6/BLLDu2Ca0RRk/QHHHH51esdYv7bULfS9cgiS5nB8i4t2zHMVGWyDypxj65+m QCzqd5dtqFtpmnSwRXEqPNJJKm/y41IGQoI5JYYzxwaTQLu+urW4TUAv2i2uHgLqhUSAYw4B9Qah tAP+Eo1e8uXQJEkNvCzMBtG3ew/EkHn/APXRs9f0u38Qa00mow+UzQFMcgnZg4I6ngZHbj1oA6kt j8KoTa7pVtMYbjUbSKRThlknVSDjPQmuY8Q+L4J5IbHSr1vmJ+0SRwlmVeAAARznJ6eg5Gc021sL XUtM+z6RoTKzIVF3qSDbtJJLKRuyS3oB6noBQB3AYEdqhuL61tADc3MMKscKZJAoP51H+50nR/nZ mhtIPmY8kqi9frgVhaRpX9tx/wBraxGswuAHtYWYkRRnJHTAOQR2zgDJyeADpo5o5oxJFIkiHkMr Ag/jWTrOutpsiW1tZT3t7Iu5YYgcBc43MwB2j8DWhY2FtpsH2e0jEUAOViX7q+uPqeazdc0Wa8lj 1DTZlt9VgG2KV+VK85BGD2Y9uuPwAFstZvZJ4Y73SZrZJSVWQPvUH/a4BGeg4Oa2qxNH1/7bdSab fRG21OBQXQ8LL1BaME5I4/UYJ61t0AFFFFAASAMngVz8EQ8SXS30plGmRbkjtZU+S56ESMDwV6bQ RwRn2qzrsEuorb6XDMYlnYtcEHBMC43KPcllH0zWsqqihVUKoGAAMACgBaKKQjIIzj3FAGTo0j3F 1q0jlgq3pRFyeiogJ/E5rXrA8LmQjWTIST/as+CfTjH6VuySJDE8sjBY0UszHoAOpoAztAFx/ZET 3ZkNw7Oz72LH7xA69OAOBxWkelV9PvrbUrGO7tHLwSZ2kgjoSDwfcGk1O5az0m8ukGXhgeRc+oUn +lAFPRria7kvpnuPOgM5EGF+UKOMqe/v7iq0o1S8v7ubTrm3Cwt5EYmLNH0UscKeWByM54wRVnS9 1n4StGggZ3jsldYu7Nszj6k1i6Zo2oaroPl6hOY1ZWlhIVllWYsW8xuhGCeADyOevQAuTWfit87L 7TFPr5DD+pq1p9lrsdwr32pWjxKTmKK2I3DHqTwfzp+gas+pWjx3MbRX1swiuI2wDux94Adj/j1x mtegAooooAyb3RQ7m402b7BdE5Zo0G2U/wC2v8Xfn3NS2mplrtrG9jEF2PujOVlH95T+fHUVo1Vv 9Pg1G3EU+8bW3o6MVZGAOGBHcZ4oAtUVladfTRz/ANmalJGb5V3q68CZOcHoPm4ORjtkcVq0AFFF HegDxTxvP5XjHUE2ZwyHOf8AYWio/HkSnxrqJJwcx8Af9M1ooA9vooooAKKKKACiiigAooooAKqQ 2KQandXqYBuUjVwB1Kbuc/Qgf8Bq3RQAUUUUAFFFFAHN+DbcWtrqkKncE1KZc8DOAo7dOlaeqaWN RlsZQ6o9pcLMCVzkDqvXjPH5VdhgigVlhjVAzl22jGWJySfcmpKACiiigAooooAKxfCgRfDsCx7P LWSZU2Z24ErgYzzjFXtV1BdL0u4vXVnES5Cr1JPAH5mofD0PkeHrBdjoWhV2V+qsw3EfgSaANKii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAMzxHIkXhvUmkYKpt3XcexIwP1IpPDIA 8K6OAQQLGHkdPuCpdbs31DRbu1iAMkkeFBx16jrx2/8A1VJpVq1jo9laPjdBbxxHacjKqBx+VAFu iiigAooooAaiLGioihUUYVVGAB6CnUUUAMlhjniaKaNJI2GGR1BB+oNU/wCxNJ2lf7Lstp6j7OnP 6e9X+9FAEFvZWtoCLa2hhB6iOML/ACqeiigAooooAKz4tE02G9+1x2kay5JGBwpO3JA6AnavPtWh RQAhAIIIyD1BrNXw5oq3QuRpdp5wGA3lDjp0HQdBWnRQAUUUUAFUdOsfsT32FULPctMMEnO5Vz9O QavUUAI6LIjI6hlYYKkZBHpSRxpEgSNFRB0VRgCnUUARNbwPOk7wxtNGCEkKgsoPXB6ipaKKACii igAooooAiubaG8t3guIlkif7ysOD3H6806KJIYwkYwo9Tkn3JPJPuafRQAUAAAADAFFFAEF5aQ31 pLa3CB4pF2sCAfx57jrS21slrEEVnc93kbczfU96mooApDTgmqvfRytH5iqJY0UYkIBALHGeAfbo Knnto7kASb8DPCyMoOfXB5/GpqKAM610HSbMsbfTraMs24kRjr6/WtEAAAAYA7UUUAFFFFABRRRQ Bzg8MXmNzeINQaQsCSZGC/goYe/tToPCkcE5uhqF1JegsUuJyJTGT/dDg7R9McDFdDUVxOttayzv nbEhc49AM0Ac7Z2l1qclzeJdJG63UsZWSHfHIFVY920ng/JnI9TV7SvD0FjHcNdiC7uLiUyvK0Cj rj5e/AxTfCLPJ4YtJJDmRzI7nGPmMjE8fUn/AOvW3QBzEiWvh7xP9qkijisr9BGJFiwIZF6AkcKp Gfx9hxurqenvH5i31syYB3CVSMHpzmrEkaSxtHIiujDDKwyCPcVmp4c0eNyw0+BiezruH5HigCxc pDq+lXMEFyhjuIni82MhwMjGfQ9aydE1uC3shp2pf6Bc2KLE/wBocKsgAIDKx6ghc+3610QAAwBg VFNbwXAAmhjkA6b1Bx+dAEVvqVhdvstr22mb+7HKrH9DVokAZJwKjight12wxRxr6IoA/Ss668P2 OoTvLfK9zk8K7sFUYHGAcY49P15oAp+IU0i9iG/ULW21GEF7ebz1SRSPc87eRn61c8N6lLq/h6zv Z12zSKQ46ZZWKk47ZIzjt0qFvCHh92DNpcBZfuk5yPoc8VsoiRoqIqqijAVRgAUAVtRu5LG3E6QC WNW/fEvt8tMElunOOOPerEUsc8SSxOHR1DKw6EEZBpXUOjKehGOgP86hsbG302yjtLVCkMedqkk9 Tk9fcmgDIs/9J8b6lKT/AMedrHbqPZ/nJ/TH4Vv1gWaS23jbUlcKUu7eOZCD0CfLg++SenQfXjfo AKKKKAKdpaNaXV2VVPKnl87IOCGKqCMY/wBnOferhAIIIyD1FFR3EpgtpZVjaVkQsI0+8xAzge5o AjtrO3s94gUxq38AY7F6n5V6DqelF9bm80+5tQ/lmaJow+M7cgjOO/WuFh13VtQlnNxqdvp5DY+z y/uxHjjG7G4nuee/bkDq9CtFggeRNWk1AOcFzLvUEdccnH50AXIYHsdKjtomV5IYRGhb5AxAwPXH aq39tBFHnWF9G/ceQW/IrnNQawRc6vpOnlpMNIblgv3T5ZVhu/HGPf8ATTvL23sIPOuZVjTO0E9z 6UAc5eTDUtVtbjS7G/jvEkCm6aAxxFONyvuwSMfjwPaurrDTxZpjSxoftCpIeJXgZUGemSRxWvcX EdtbSXEh/dRoXYgZ+UDJNAEtFVrS+gv7SO5tpA8MgyjAEZ/OpWcgUASUVg3HizSradoXucmN9shS NiIz7nGK17a7hvLdJ7aRZI3GVYdD/n0oAh1GyN3CHhYR3cR3Qygcqe4+h6HtUtjc/a7OOUjbJjEi YwUfuCO2DVisvT4zb6zqcIIEbeXOqg5wW3An8StAGpR3opP4jQB4942Ut4vvydn/ACz6/wDXNaKk 8a3Cx+Lr5SFJHl9cf8819qKAPXqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKh ubS3vIvKuYUlTOcOM4PqPQ+9TUUAZUHh3TYLuO5EO+SP/V7zkJz2H+fzzWrRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFVJ7iRb+2tYjGDIryOWBJ2rtHAHuw5/Q0AW6KKKACiiigAoooo AKMj1qlqOqWumQ77iT5iDsiQbnkI7Ko5PUfTPNZsNz4g1CESRWdtYAtwLsmRtueu1duDjt70Ab9F YY1W50+4ji1lLaJHHF3G+2Ld/dO77v585GO+LtrrOm30hjtNRtLhx1WGdHI/I0AX6KRWDDIIINLQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRWLp91OPE+sWdxIwjxDLbI7feUphyo64BHPbP1oAta8M+Ht T/69Jf8A0A0aFK0/h7TZmd3Z7WNi7tlmyo5J7k9ab4hYr4a1Vh1FnMemf4DVXwc/meEtObJ5jPXt 8x4/zz680AblFFFABRRRQAUVkavc3y39hZWMqQvceYxkeIyAbFBAIyPlJPPIPQAjNaNrJNLAGnh8 mXJDIG3dCQDn0I5/GgCaiiigAooooAKKKKACiiigAooooAKKKKACiiigAqlrEMtzol/BACZpLaRI 8Y+8VIHXjr61dooAyvDVpLY+HLK3mjMcqpl0PVSSSR+tatFFABRRRQAUUUUAFFFUtVvzpunvcrC0 8gKrHEpwXYkAAfn+WaALtFU9NF79jR79wbh1DOiqAIyRyox1APGauUAFFFFAGTrtvemKC901Fe8t X3KhP30Iwy9e/B/4DxzWhaXcF9bJc20gkhcZVhxn86mrnLiyuPD08t9pMHm2Um3ztOiTkHpvjx0O MZGOcfkAdHRVWy1C11CPfbyhiAC8Z4eMnsy9VPB4PoatUAFFFFAFHUjelI4rO2gl3kh2nb5EHuOp rMs/C0UWtxavNIi3EWQkNtGI4uQV5HJJwfUdB6V0NFAGTP5UPie3mllCeZaPEgYgBjvQ4+vI/WqO taa0uu2t/Lbz3NosPlskOCVYNuyVP3geAcV0TIjlSyqSpyCR0NOoAwLhtV1dVs/sjWtlMuJ7iQKH 291VNxwTjGT69Kh8SXc0NvBotgqB7iJlYspOyMDbx7nOBn+tdLXFXTf2j46msZbcPsaAI7JvCxqp kf6AkhSf90c0ARau7eGbp9W0yDKOBFNBLKmzbxhlCnduGD1z94ntTfFF54kGh3H2iwtYLU7VlkWT cwUsAe/4dDwTXYJpOnRsGTT7VWDbsiFQc+vTrU13aQX1rJbXMayQyDDKe/8A9f3oA53T7LxFFYpb AaXBHt2lgjMx4xuPOGP161uaXp66Xp0NmkjSLGD8zYBOST2+tVNO0e50940/tOWa0iJKRSL8w4IA 3Z5HPTGOBjFa9ABWPpU7XetavOvMCOlup/2kB3fq1WtR1AWiCKALNeOQI4M8nJ6nHQAAnPTjGals LQWVnHDnc/3pH7u55Zj9TmgCzSfxH6ClpP4j9KAPI/GtsZPF18wWQ58voeP9WvtRSeNWceLr7DgD 93xz/wA81ooA9eooooAKKKKACiiigAooooATODilrm9UmRPG2hxYUsyTAZ7HYSCPf5WH410lABRR VC41JI9Ut9NjBa4lUyNwcJGOpJ+uBj3oAv0gIPSqMcpTV54DJlXiWVE64IJVse33Pz96z9QvNRvb +bTdIlWF4Yi09w6Z2sR8iqCME5654A9xigDezS5rM0TUDqukW16uMSr8wXICsDhgM8nDAjtUuo3P 2GwnuShcxoTsU43nsM9sn8qAL2aTcM4zzXLaLq2r3GuNp+pJZh0t2lZYVYMp3LtByx/hbOPcdOQL Ou39zFqGn6XbTLbNelt9ww+4qjJ29sn17ZHrkAHQZpaxNI0CDRrqae3lnY3CgTCVw29h0boCDyR7 1tjkUAFHUUUh6UALRXO33iC9W6lttO0me5MWQ8wK7cggEAEgtjIzj8M1Y0XWHvpJLW7Ecd5H82xF Ybk4w3zAY5JGOvGe9AG1RUN3cJZ2c1zJxHDG0jH2Ayf5UW063dpDcx7gkqB1DDBwRkZ96AJs0Vi6 /wCIYdEtpCcPc+WZEjOQCB1JPYDB/Kr+l3T3uk2d3IEDzwJI3lnK5ZQTj25oAt0UUUAFAHXn/wCt RVHVNRt9LtGubo/IMhQoyzHBOB78HrgUAXdwo3D1rmf7N1rXYWTVLhtPtWH+qtHxI3QjLHnjp2z3 WpvDWgS6NPqUjvhLif8AdR7y21FLYJPq2c4HA475oA27qSSO0meEKZFjZkDdCccZpLS6ivbZJ4s7 W6qwwVI6gjsQeKz/ABRdy2Phu8uYSA6KuMnAOWAI/I1PHBNHtu4ZPMZ40EkWQFcj+IH+92z0IAHH UAGhWGZM+OY489NNZsY/6ar3pNU1a4+1RaZpsaSX8qln3HKwKAOW9+R+ffgGhZWF9a+PN9zcvcJJ phAlaMLyJVyowBwM55yfmHSgDrKKaQACWPArz3U9P/t+G41syz3UVy6W+m2pfEYG7BcD+EnBOW5y MdMCgD0SiiigAqrqV/Fpeny3kwYxxAEhRzycD9TVqsLXitzqGkaVISIrqdpJBtBDiIb9pz2Jx+VA EGm6VNfQtq97Mn264iDW7L86WwIJXAOASN2eR2+pNbTrjxWlrHd5tdSibKtDMRDKpDEEgqu09OmO fWurdVdGR1DKwwVIyCPSuI0vXr628L6Y8VnhJhIXuCpdU/eMMYHOcckn0PB5wAas2oWE19bDVNGu I5pyIBLLGGjDEkKAc55LHkDvzgVaufCmi3LbzZLFKDuSSJihRsYyMcZH0rF0jUvDC6ulw+rST6lK m1ZrvzIwQM8KGAUfeIwPX3rtM5oA5tLy90TU4rfVJRPY3LrFbT45jk6BWycnPqckE9SMlekrE8Xx iXwrfgjOEBHscitugAooooAKKKKAI554raFppnWONRlmY4ArI0bxTY65cyW9tHcI6KWBlQAOoIBK 4J45Hp1qs6Sax4rltrhCbHTgGChhteRlUjcO/Bbj8+vOvbwb9QubySLY+BDG2fvRjnP4sW/ACgCz PPHbQSTyttjjUu5xnAAyTVbTdVstWhMtnMHC/eUgqy/VTyKoapCdW1i1sAQ1rbnz7tOME/wKcg5y QePTn0qp4luhe3lho9vJIsj3iee0blCigb+vcngj3AoA6eoILyG5edYmYmF/LfKkDd7E9evap64z StSki0K00nTj5mpSFw2MH7OC7Zd+TjjOM98cc4oA6/zoxKIjIvmEEhNwyR64qC40yzur23vJYc3F ucxSBypXr6HnqRz6n1Nc22hW2k+INBm815rhp5hLcTYLyMYmxk46dcDI6966+gDmNbbxKbDUIltN OmtpY5EVknaN0QggFsggnBzx6GqPhifxIfDVnHaWemeWqERzS3TncAx7BM+3XtXUauSui37KGJFv IQFGSflPQU3Q7R7HQrG2kQJLHAokUdA+Pm/XNABZtq3m4vYrIRkZ3QyOSD6YK8/XI+lX6KKACiii gDGv3YeK9GUZ2tDc5x/2z5/z6/gdmsHU0ZvGGgEbsLHdE4PH3UHP51XvLe/8Q3VwsV9Laadbg+RL bsY3kmHBySOVGD04Oe+OADpqhuruGytpbm4kEcMSF3c9Ao6muc03xzpMmkwT391HbXJGJIgrHnpl QATg9e+M4POaztS8Q6bq3iPSI7IXF28TO8SRqU3y4BAO8DAAUkkdu2CaAOr0rWLLWrY3FjL5iA7W BUqQfcHnnqD3FX6wtH0+/fUptY1RIYLqSPyUgh5CpnOWPduO3GPrgbtABRRRQAUhIVSScAdTS1ge IriWS803SEBEd+7ee4OMRptLDPbOQPxoAsQa79vdv7OspbiFWKm4LKkZ46gk5I7dK0LS6W7h8wRy RNkho5BhlPocfgfxrM1a4CQf2Xp7BNQlTZCFXaEGOpYcLwD054yAcVm+FJzpdzdeHbvEc0EjSWzP wbiNiSWA6H8Oxx1U0AdZRRRQAVHNPDbpvmlSJMhdzsFGT0HNSVz/AIqihm/sVJ+UOqRfLnAY7XwP egDQ1m5uYLAix2G8lYRwK/Qt1P5KGPpxzS6Rf/2lpNvd/LvdQJAo+644YY7YIIqCztP+Jgo+0TTp ZR+WskjZO45JBPchduSfbnOazbyw1HRNUm1LRoPtcV0wa8gdssMEnMeSOuW455PQ9gDpS23qahs9 QtNQjaS0uI50RyjNG24Bh1GfxrmtX1qDU/stj9kvQrys08Rjw5CDhQM4JLFe/bNbGh2dxAlxcXdv FbTTMAIITlY0UYUcfifxHSgDVLbRk1lv4j0pNUXTTdD7UzbAuxsBvQtjGfbNZ/jC/wDIt7PTi2yL UJhDO4GSIsgPj3OQOh4z9RDpYtr2aTRrONBpEFurAkfvPMLBlYhunIbgjqv4UAdXRVS5uJYbyzjT YUmkZXDA5wEZsj8QPzpup6nb6VaGe4bGeEXu7dlHuelAF2sXW8SaloluSQWvDL1xnZG5/mR+VWdC v5tU0W3vbiNY5JdxKp0A3ED9AKg8RSJa2ltfufktLqN3/wB1jsPT0DZ+oFAGweKzL7xFpOmz+ReX 0UUmQCpJJXPTOOme2etQ+Kr6bT/Dd3PblllICK6qSU3EAtxyCATj3x16Vj2NwLW3tdL8PWv2gbWd 57uPAeMk5P8ACfvHqew6HINAHY0VHbwi3tooVOVjQKD9Bis/UtSmtdS02ygh3tdu25twG1VwW6+x J/DHUigDUzijPOKw9UQazerpKySJBHl7plGCeBtUEjB5YE/Sq6eD4bKVptJ1C7sJCclUIaM+uUIw fx/DFAF670G3mne7tJZLG9bkzwHhj/tL0YdOvpVaG71zS7c/2najUEUnbNZcykZ43RkAdPQ9ulPh k8Q21wiT29tdwDgyRNsYj15OCfbAHuK2wcjPP4igDDs/F+jXb+U9z9lm7xXQ8sj6np+tbiurqGVg ynoRyDTZYo542jljWSNuCrjIP4Vh3fg3RbpldLdrV1OQ1s2zH07CgDfJx1orBh8MtbLiDXNYTAwN 1wJAP++lNTrp2rIAF1stj/npaqe3sRQBr0VmLa6wrDOpW7rznNrg+3Rv84pDa6yyYOqWyN6raE/z egDUqCOzt4rqa6jiVZ5gokcdW28CqZstVP8AzFlHGPltVx9eTTDpN7ICJtbvDnr5Sxp+WFoA1qRn VFLMwVR1JOAKwj4WjfaJdX1aVQc7XueD+lWLbwzpFqQyWSO2MbpSXP60AOuPEWlwDAu0lboFhO/J 9MjjP1NMF5qWpQn7HavZIekt0AH/AATn9a1UjSNdqIqr6KMCnUAU7PTorRnkLvNcOcvNLgsfb2Ht VyiigApP4j9KWmLu3Hd1/wDrmgDyLxuqnxhfZx/yz/8ARa0VP4zgkfxZesqsQfL6f7i0UAes0UUU AFFZl9Hqy38VxZTRSWoXbLaOAu48/MGwTnkccDj3q9BK8gbzInjYcENgj8COooAlooooAKKKKAOT 1eBh8RPD0+84eOZdoH92N88/8DWusrC8Tt9jtbbWEjLy2E6tgDJMbEI4H/ATn6gVsW1xHd2sNzCx aKZFkQkEZUjI4PSgCWubvJ4LPx1byzDaZrBo1YnAO1i+PwAP51vyXEUcqRFsyOflQcnHr9PeqGp6 Hbapf6fdzMwayl81QvG7uM/QgH8x3oAzPE99Np2p6fLAjPLLBcwRKBkGRghQHtyygc1s6Tp39mWC 27S+dKWZ5Ziu0yMTncevPQde1Tz2VrdTQSzwRySQNviZhkofb9PxAPYVPQBy3giN7CyvtInmDSWd 3IsUbcP5XG1tvUBjuI7c8UzxLflNesbPe4WCI3nlKxBuHVhsjHHJLAcc9SccCtfUtEW8vY9QtrqW 01CKMxJOnzDYezKeCM8/UD0rEvtKOkaxY6zdG51EAlbqZ8t5Q/hZUHAAJJPHAzjnFAG1oVnJFbPe 3cKpf3bGWbuV6ALnqAABx25q7e2FpqMJiu7eOZMEAOORkYOD1Bx3FVLXXrO/mjjsRNch+WeOMhUH HLFsevQZPtV+Z5I1Vkj3jPzgHnGO3rzj8M/SgDAn8NX0FwtxpOt3cBTlbe4dpoj6Lgnhe3HOOhrR 0vUpLmSSzvYPs19AAWjzlXXtIh7qfzB4Pui6xK0rRjSb9cdHdF2n8mJx74qHTrbUrjVBqmoxW1vi 3MMdvExcjLAks5UZ+6OMcZ/EgG1RRRQBh+E5Wm0FPNYG4SeZZhuyVfzG4b3xj9Ku3lsj6np1yBiS ORlyO6lG4P44rPvNF1C3uZbrQ71bd7iTzLiGZQY2OMbhxkHjn1/ACrGn6VdrNFd6rftdXMW7y1RQ kaZGMgAZJwT19fxoAn17/kXdT/69Jf8A0A1z2leIGj8N6bZ6bEL7U/IVPJD8RgDG5z2HA4z3rr3R JI2jkVWRgQysMgg9iKp6bo9hpEbJYWywq2N2GJzj3JNAGPqWgQW3hfVSzma7e3dnun/1jbRlRnk4 G1Rj8eprV8PgDw3pYC7QLOLC4xj5BWgQGUqwBBGCD3qlptjNp6SW5ufOtVP+jqy/NEvPyls/MBwB 3x1JoAvUUUUAFZ+saTFrNj9mld4yrrIkiEgow6EfrWhRQBz8ej6/Gip/wkxYA5+ayQk+2c1iX91r thcwQWOuXGqXkz8RRWCGIAEA+Y44Qc+uf5jtbq2ivLZ7eYExPgMASMjPTiktbO2sohFbQpEnoo6/ U96AM7xDZ3GoeFby2AU3LQbtqLuDMuG2gH1Ix+NP8N3X2zQbaYyF2IIJbrwTjPocYrVqlpOmx6Rp sVlFI8iRliHfG45Ytzj60AYvhyaCLV9bgncpfNeO4WU4Zos/KRnqBz0zgFfUU7xJcsPsuo6fC9zP p83mOYwSPLI2umemSCPpjPatTUdB0vVpEkvrNJmUEAkkZHocHn8auwW8NrAkEEaxxIMKijAFAFTU f+JhoF4LN0m8+2cRMhDBiVOMdjXMeFL+C5SzsrmSCOWwjk3wPIA/m+YVDFeDkDk5GQX55rpbbRLS yiMNq1xDATnylnfGc5OOcj8CP1qk/gzw9JJ5kmmRu/8AeZ2J/n9fzNAGrFqFlPMIobu3klILBEkB OBwTgGrNV7OwtNPjMdpbRQKxywjUDcfU+pqxQAVg+KN9paW+sQwiWXTpRKRjLGI/LIB74Of+Ait6 kdFkRkdQysMFSMgj0oAZb3EV1bx3EDiSKRQyMOhBrkPCusfZNDkspNM1LfaXEkQXyCWcE7gSOxww yP6VY/4RvVdJnB8O6kkFnuLtZ3C70zjoDgkA+xBz1Jzwy1bxRBeSXj6JbGaaNFnRL/EbsP4wCpK8 cdeePTNAC3c1zqbOB4NSXeMb710jJ+uA2Op75rV0WybQtJkW9vFMYcyDcxCQJgAICxOFGPWqUy+M byN1jOl6cDwrAtK49+Rt/TtUi+GWv0hOv3smoNFyE4jTd64UDPb8vegCtqEjeKrr+y7ZXXTEYSS3 qMSkwA5RcDBOWHOf4ScHFdVUVtbQ2lulvbxrHEgwqKMAVLQAUUUUAFFFFAGJp04j8T6zaND5bSeV cI/eUbFQn6AqBn/Ctuqd7psF9LBM7SRzwEmKWJtrLnqPQg+hqW2glgUiW7luCe8ioMf98gUAZt1Y 31vqk95pqxE3saxzbzgxsudrjseCRjHYVX1HRLz+yUNpcLLqcMy3HnOm0zsudqtz0wcYz044zmuh ooAq2N8l9FvWC5hIA3JPC0ZB9OeuPUZHvS2unWllJPJbW6RyTuXlYDlifU/0qzRQBg+KY7sWtjd2 Vs9xLaXaTFEGWKYIIHfnOOPXNbNtN9ogWXypIt2fklXDDnuKlooAKKKKACiiigAooooA5Pxja6lP d6bJp32hMLNFLPbpueFX2ZYD1wD0wfQ5xRbx+H7GJNPEWo3ropkEUkM8oZuckgjYrE5POOTnjNdZ RQBznhrw7bWOm+bc2FotzcP57KIAPLyBheR2x+ZNXNY0CHVIrcxTSWdzaktbzQ8eWSMHjoRwPy9M g69FAGPb6frkKbJNcimwOGeyAb8cMAe3YdPxrWjDrGodg7AcsBjP4U6igAooooAKydX0aXUrm0uI L57SW3DqGRAxKvt3DrxwOv49q1qKAKWn6ZDYqX/1tyw/eXD8u/tk5OOBgZ7U6+0y01FV+0RAunMc qna8Z9VYcg1booAjgi8iBIvMkk2jG+RssfqakoooAKwvFenXeoaZC1i3+k2tylzGv94rkfpnPfOM d63aKAM3Q9Nk0rS0t55zPcMxkmlOfncnk8/gPw7VpUUUAZ2saW+pxW5hu2tLi3mEscyKGI4II+hB /wAc9KtxC5G0TNEcD5igIyfYE8d/WpqCQMe9AEc0ENwqrNFHIFOQHUHBxjPPsT+dYulN/wAVXr8Y QKqC2wR3+Q1vVg6VGy+LPEDn7rfZsc55CHP07UAXdVtrib7JcWoDTWs4kCE43gqyEZ7cNnPtUMOj NcNJLq7xXcjqQi7MLCD1C8/TnGeOprXooAw9AWfTbYaRPFNI1sxCXAQ7JEJyDk8AjOCMnpxnnGhq mnpqmmT2UjsglXG5eqkHIP5gVcooAq20FzDZxwTTpMyIEMjIcvgYyeetU7rT54tYTVLKOKSQQfZn ikcoNmSwIIB5z2x071rUUAQxG5bDSrFH6opL/rx/Kue1W/XS/FRu7jd5a6W/kBnAWSQOCUXP8ZAX pnPHpXT1Vu9OtL6WCS5hEjQNujyTweO3foOtAEekwyJp8Ulxk3Mi7pHZcMckkA/TOMdqvUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU0ABiAMDAp1IOpoA8e8cFR4wv8yEf6vjP/TN aKm8aJEfFt8WBz+7/h/6ZrRQB65RRRQAUUUUAFFFFABRRRQAVhXXhDSLq7e6EUkMshzIYXwH+o7f hit2igCrYadaaZbC3s4VijHJ2jqferVFFABRRRQAUUUUAIGDZwQcHBxS1geDZDP4Xtrl1USzvLLI QoXcxkbJOO5qxrl59jfS8Luaa/jiHz7cbgwJ9+M8UAa9FGaKACiiigAooooAKKKKACiiigAooooA KKKKACiq97dfYrKW58iefy1yIoE3u57BR6/p64FY1v4r+0HP9h6wke4qWa2BIIJB4Uk8YNAHQ0U1 HEkauoYBgCNylT+IPI+hp1ABRRRQAUUUUAFFFFABRRRQAUUhYDGT1OB70tABRRRQAUUUUAFFFFAB RRSF1DBSwBPQE9aAFopGYKpZiAoGSSegrlPCOk3FnYRail/c3C3gErwz4xhjw2c/exgk9/ywAdZR WbrV89lBaiNwklxdwwKTyOXG7/x0MK0qACiiigAooooAKKKKACiiigAooooAKKKKACiiigAqpLqV pDfJZSS7Z3AKqVOOc45xgE7WwM84q3UN1aw3lu0My5U9COCpHIIPYggEH2oAmoqK3iaC1ihaV5Wj QKZH+85Axk+5qWgAooooAKKKKACiuf8AF013HYWMFnLJC11fRW8kkRwyo2ckHIxyB/LvXQUAVor+ 2mvp7JJD9ogCs6FSOCOCM9R7jPpVmqlxYrNeW12jmOaEkEgf6xCCCjeo5yPQgGrdABRRRQAVWvvt AtxJaxiSeNgyxs+0MOhGfoTjPGcVZooAoW2s2F006JOFkt1DTJJ8rRgg9c/Q89ODVHwvK95a3uoO vy3d5JJE5GC8QwqHHUcL3+ver9zo2m3kqSXFjBI6EkFkHfrn1z71agghtoVhgiSKJfupGoVR9AKA JKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkB+Y/ SlpB94/SgDyTxpj/AIS2+4P/ACz7f9M1op/jNlHiy9zn/ln/AOi1ooA9ZooooAKKKKACiiigAooo oAKytbsZZ0hvbZnF1ZFpI1Un94McocdjgflWrWLo2q399qurWt3apDFayhbd1OfMU7hk89flz0HB HXrQBY0fWLfVrITxHa44kiLAtGfQ4/StHOBnBrG1Xw+l9cjULO4kstSRdqzxnhvQOvRh/nsKXSdW nklXT9VjjttT2lxEhysiD+IHnHfjJPBNAGuXAOMGslfEunPqjWCyOXXgyKhaPd3XcOhGec8Dp1qp r8095qMGh2siRxzQtLfOflZIMgZUnjn5h3PToOazdYaGLwrc2ulh4dLto9rSxuMy5PKKeTgk8nv0 HWgDs45ElRXRgyMMqynII9QabMW8mTadp2nBJxzSW9vHa20VvCu2KJAiDOcADAqO5S6Z42tmgAGd 6yoSW44wwPGD7HPt1oAw/AzgeC9N2n5dr4/77ak8Vbg2huFU7dWt8lgeh3DjH1HWs7RLfxLa6FBb 2a6a8cJeNS6uWYBiD/GOcg1T10+Lnso3vrbTUjguYZkkiRjtkDjb1k5ySB09fY0Ad+pIAH9KbHdQ SyyRRyo7xYEiq4JQnpkA8Vx80fiDWbqXSpLuyiRNq3/2VCpRGAO3LZOSueh7jmug0fw5p+iF3tUd pXAVpJW3MQO2aANbNFZ2rXxsooCrKC9zDG5OOFZwP16VFp9uuoONUukV95zaoyjEUf8ACQOcM3BJ 69BxigDWprusUbSSMFRQWZicAAd6rHToRcm4hLQSs26RoiB5nGMMDkH+fv1rKsJpPESwvcrtt4Aj SRrkCWbGcEHnYAVYA9SRnpQBJZ+KrC91VdPjjuFZ93lSugEcu3rtOc9ATyB+ozuA5GRXI+L1jOt+ GlKnf9uBDA4wAy5H4nH6111ABRRRQAUUEZGDWX4jkvYvD922nbvtW0BCoJIyQCRjuBmgBuqeILTS 5ooGDz3Mp2pBCNzE+/p+PXtmqNjP4guPEZS5aCK0iG6WCMbgAQcAuRkvna3GBgnrVPRda8KaPE0M V8YpZW/eyXSsrM3X5mIAyN3+etdXbzw3MInt50nhk5R0YMpHTgjrQAXM621u8zKzBR91Bkk9gP8A 6/FSKwdFYAgEZ5GD+VYnioq+mW9ox+W8vYID8xX5TIC3I6cKf/14FblABRVK5upU1GztYlz5m+SU 9dqKP6sV/WsSTxhE2oWi2cQn06S6W1kvA3y+a2QFUd+cc9MEeooA6iiisXxNqN1p9hCtjGj3lzMt vDu6KTnn9PpkjPFAG1mjIrM0fQbHQ4XjskZRIdzknqeecdB1xx2Apuv6rBomltdzE5LBEUAksx9u +ACcZHTqKANQHNLXn8vhy0l1aOF52ufEMpSS5ulY/wCjIDng49MAA+oOFyK9AoAKKKKAE2jIJ5I6 UHOOCPxpawvFEtzJa2+mWLqtzfyGLJH3YwCXbr24+ucCgCrNrup6jNIugW8EtvBkyXVwxEchH8CY 654+bOMfUGt+xuRe2FvdBdoniWQDOcbhn+tZ+qQWVh4auLZg8dpHBhliGWK9x9W6ZPqTWjZSxz2F vNFE0UbxKyxsoBQEZAIHAxQBV1jWbbRLNbm5WVw8ixRxxLuZ3PQAZHpUum6jHqdu0yQzwlH2NHPH sdTgHkfQisvxNb6gsunappdr9rurKVswM4VWjZcOef4sDAIzjceD0q5pfiLTNXkaG1uR9oUZaCQb XH4Hrj1GRQBqUUUUAFZWt6P/AGnHFPCwjv7Ul7aRvuhuOD7HA9xj8Dq0UAcZqPisR6dqOlatb/Yt UFnLgkjyJW2tt2MT3HOCPUckV1dhbLZ6da2qDCwxJGBz0AA789qr69brdaBfxMiuTbvtDAcNtODz wCD3rHt/B2mNag2d3f29vOgby4ZdisCO645z6H/61AB4ilW6vtNEUhxa6hAJMZwSzjAyPTac59et dRWJr1q9p4XddPjUNYiOaJGyQREwfB9chamvNct4tIgvbX9+12qm0QAgylgNvHUDkZz0+vFAGrTX dY0Z3YKqjJYnAA9ayfDWrS6xpTS3Kqt1DM8M6qjIFZTwMHn7pXPvmrerxQzaLfx3BxC9tIshxnCl Tnj6UAO0/UrTVIGms5fMRXKE4IwR9fYg/Qirdcv4LxLaTXcZRopo7fBRs/MIV3A++Sc//WrqKACi iigAooqC+kmi0+5ktl3TrEzRrjOWAOBjvzQBh3d7fapq72OlTeVb2v8Ax9TqQSzf881yCM+vfI5x /FLos95pwi03XL+Ke/nkka2CZJMagH5jtHI55P61H4LmU+DbKd2CqRIzMzf9NG5Jqpp1zb+IPG0t 9bSMYNPtljBwV3u+7kggHABb+nfIB1jMqIzsQqqMknsKWqOt/wDIB1Hhj/o0n3ev3T0rCs7mbxaB HIZYdPjjQyvBJtMsxUFkJ7qNxyPUdaAOrpMgd6yf+EX0bYVWyC57rIwP5g/5yfWuaTSLXVre4ub2 5vLfQ4CRGFu5SJ1DY+YMxJ+70wPvDHIyQDtYby2uXdILiKVozhxG4bafQ46VJLKkMTyysEjRSzMe gA5JNcpooth4hSPToTHbNbmYzTMzyzJnaOXJKruPfBOzuK0vGPm/8InqHk537F4BxkbhkflmgDXt riO7tYrmElopUEiEgjKkZHB5FSkgDJOKrWscVnDBYxFm8mJVAPJCgYBP5fjzXMXgvtU8W32lW8rw 2/lwm5nQbWWMBiEU46sWbnPHOOhFAG/Pr2lW1+lhPfwRXbYxE7gHnpn0z79a0c5rl9U8NaTp3hHU Yre0VfLt3lEnVyyruHPXqOg9T61r+HwF8N6WFBAFpEAD1+4KANGiiigDE8Rje2joM5bUojx7Bm/p W3WZqoB1DRSx4F43Hv5EtadAGfbaossN3cTotvBbyyIHZ87lQ4ZjxwMg+vSsa98Uz29omsR26Poo kKMyndNIORvAyABkdCc/Sue1TWJT4Rvk02WKTEk0t2gUkqkkzBByRjdhuOv0FdhqmlxL4PudNiTK RWZjjAXui/LwPdRQBtUhOKp6RdNfaLYXchBee3jkYgYGWUE/zrM8Qa/YQabqFtFd7737PIFjtzud WwR26EdefSgBs/i21hv2tRaXUqrOLfzkC7C564yRwMEH/dbjAyd6WaOGJ5ZZFjjQFmdyAAB1JPYV yng3Rt+labqV6wkdIR9miIBEIPf6nJ+mcHkcbPiXTp9V8P3VnbbPOcKUDnAJDA9fwoAyX17VNdil Xw7BsjBaM3lyoADdAUHf+9yPqueDZ8OweJVlebWNQimhPCRiIKfr91SOfXt2HYttS162tVjl8NDE ahQLe4QDaB2XPHTgZNJL4whslQ6lpmoWe4gbnjDLk56EH+lAHSUUikMoYZwRnkYpaACiiigAJxSb hkD1rF1q8vTfWul6cUEs4Zp3zl4Yvu7wMgdT1Pp0PaleeGbSHSZbO306S8kfIWSSVQQT/ExJGSMn sc8A0AdODkZpayNWnvdK0BTZsk96phhja4BIkYsq5OO5yfxqo2n/ANvXBivZZns7NtmA2zz5f4iy j+EcYHueoxkA6Kisvyk0Owklk1GY28S8eeocJzxjaAx64AyfQVUt5fEWoOzGO2063IVozJGZJSCT kEbgAcAdehOMcUAb9FYI8Qw28IjuWZrlppLeJFj+a4ZGAOAMgckDkilhj16+DifydMjPTyiJZR7Z Py++ce1AG7RVSzsnsy4N3cTo3IEzBip56HGfT8qkvZpLewuJoYjNLHEzpEOrsBkL+PSgCSSRY0LM eB1NCSpICUdWxwcHOK47Sbe28TxrfalfSTXOfns4iRHHxgZQ569c+9bljodtBcwXSWy23kb/AC4k OfvcEse5xn86ANiiiigAooooAKKKKACiiigAooooAKT+M/QUtNH3yc9hx+dAHlHjOMN4svT/ANc/ /QFopvjQxf8ACW327r+7/wDRa0UAet0UUUAFFFFABRRRQAUUUUAFc5ci6i8R3/2K4hiZ7SGaTzI9 5IUyDgAjPQcn2ro6x9QtLxtbs7i0QbGjMU8hK4VRIjYwRk5AccevbrQAn9n647bm1yNAf4Y7JcDj 3Yn/AD2pmleHnsrqO9v9Rn1C9jQxrNIAo2nH8I4B4PTHX8a3KKAKF9o2n6lPHNd2qSvGMAsOozkA +uCM0zU9IgvdDuNNijiijdfkUKAobO4cD35rSooAoadqkV9bxsyNFcHiW3OS0bdweOnvxV+iigDK 0oXsN1e288AFuLh3il3cENhgAMc9Wyex457J4kgS70Z7RmVWnlijTJ771PHqRgn8K1qgezgku47p 0Jmj+6dxwOCOmcHhm/OgDCumudC127vodPnvotRCb/s4y0TIu3kdwQfUdDx3q/b3Oq38Uv8Aoiae pH7qSVvMc8dSgwBg+56dOa1aKAMLxRYzTeFLq2tEkmnwmwHLs2HB+vr9K1rOIW9jbwhSgjjVNpOc YGMVPRQBXvrdruwuLZJDG0sbJvHVcjGR70WFlDp1jDaQA+XEoUE4yfUnHc9asUUAc74k0+S71bQJ 0jLCC75Iz8vRu3bCH/JroqKKACiiigAooooAxb2wuLt3RNN0wAMxD3Mfmh898DGD60zQvDp0e5uL l7syS3HLxQx+VAp4yVjBxngcnJ/Mk7tFAGVrLGO40iUBiFvlDbf9qN159ssP881q1BeWcN9b+TOp KhlcEHBVlIZSD2IIFOt7eK1i8qFdqbmbkk5JJJOT6kk0AclqGl6tq/jWXbLPZ6fFbrE0yZ/fISGK qeMEk4zz938K1vEWnyN4Ynt9Lt0SaLbJAkagbCrBsqB369Oa3KKAK2n30Wpafb3kJBSZA4AOcZHI PuOlY3iqK6jOmalZ2kl3NZ3O4wryCjKQSQM89MHBxmtyO0toZnmit4klk5d1QAt9T3qagDm/+Env piotfDepFjgH7QvlAHvzzWF4203X9X8PtczpBDHbSidLSJTJIOCuWYcHG4scdq9BooAytDi0eDTh LpLwtBK2WlVsl3P949d2T0Pc9K1axbbwnodndJcwWCrMjBgxkY8jkEgnBIPTNbVABRRRQAVg61JP YazYajHp1zfRLFLC6wAM0RO0hgp9dpB6f0O9RQByl3pd/wCK7LzbuNtPUKRHay/PluznGMdSORkY yMd9HSdUupEhs7jSr6O4iRVlkaNViyMAkHdyM56Z6fStqigCte3TWkSuttNcFmC7YtuRweTuIGOM fUiuM1iXV9Xm/wBA8MTWt8oWSLUGlWN0IyCDwM8HGCcEMfSu8ooAZF5nkp523zdo37Pu574z2p9F FABRRRQAjAMpBAIIwQe9V9Ot3tNMtLaTbvihSNtpyMhQDirNFAEc8MdxBJBKu6ORSjrnqCMEVgeH vCUWhzGeW7kvZlBSFpBgQqeSFGT1P8zjGTno6KAOf1TQ7pNWXWtHlWO7AUT2x+VLsDIAYj+IBmwT nHHHFVhrHiC8drNvDUcfmBkMk1wWjHbLDZgj2B57V1NFAHGaZaaz4OtWsLbT49TsQ++N4iIpFz1U qAd3Pc4479h1Vjefbbfzfs1xb842XCbW/KrNFABRRRQAUUVHOzLbyMgJcISoHUnFAGQ/hPSnklzE 4t5X8x7VXxEX4+baO/AqHRfKTxR4ghiyojNsBGBhVHlcY/w+ldDXP6On/FWeI5RjBa3TrzkRZ/8A Zh+VAG+yhlKsAVIwQRwRWL4U0htF0GO0kjCTeZI8hAA3EscHg4+6FrbooACARgjINZlvoNhbhQUe ZUG2NJ3LrGuBhVB7cCtOigDNvbWePUYtStIVmmEZgkjL7NyFgQc+oIPHuam1SwGp6Xc2TybPOQqH AztPY474OKuUUAUtN05dPgKmWSed8GWeU5Zz/QDsO35mm6XpUOlpNsYySzytLJK4+ZySSAT7A4q/ RQBl+IrO41DQ57S0YrNKUCkdMBgTn2wDV61to7OzgtYs+XDGsaZOTgDA/lU1FABRRRQBR1Owe/S3 MVy1vLBMJkcLu5AIwR6EMauqCFALFiO570tFAHPXnh+0tdKlt7S2LG4u4GmO0MzL5yk5/wBlVJ+g yeuTXQkAjBGQaKKAOU0rwU9hCIbjW7+4gClfJWRo0wc5+UEjua6CDS7C2gaGGzgSNk8tlCD5l9D6 jnvVuigDnrXw3daaZU0zWJre1ZsxwPEJFjyckDJ9c/1ycmtSNL63t2Mky3cxYbQFESgEge/Tk1do oAwG0G+u5xNea1dAnkx2zNEq+y4PP1IJNXIvD+lxsHezimlAx5kyh2P4mtOigAooooAKKKKAMF7i PTfFk73kixw3lsghlkOFVkLbkyT33A9vzraininXdDKki+qMCP0pZYYp4zHNGkiHna6gj8jSQwRW 0KxQRJFEv3URQoH0AoAxfFk0lrpcF2gytvdRyyAnjAPGfbJU/h+FaWkxzRaRaLcxeVceUpmTduxI Rlue/wAxPPerMsMc8flzRpImQdrqCMg5HB9CAafQBznjCS3jtdM+1sq27ahEJSxAXbhs7s8bcZz7 ZrQvtbtrZfLt2S6u2ICW0TguxP0zgYyc+gq5eWVvf2zW91EssTdVP+eKisNLstMjKWdusQPuSfpk 849qAMqfw0brT4ALya0vkZ5TPB8p8yQ5fIB59OvQd6V5L6x+STX7KSVcbknjCfXoc810BGQR61Th 0qyhYuIQ7nkvId5J9cnvQBn6Nr8mpXUltNYyRtGSPPiy8LEAZG4gEHnoR2rUuL60tWCz3UETHtJI FP61Yqq+mWMkjSPaQs7nLMUGSfX60AYeq3Ph+WEul2Y55X4n03JlZvTcgPX345HtWn4fm1CfRYH1 OIx3XIYEYJAPBI7HH+PGcVditLa3OYbeKM+qIB/KpqACiiigAooooAKKKKACiiigAooooAKaPvnn sP606mj/AFjfQf1oA8s8YQl/FV629hnZwAf7i0VL4ujDeJ7w8/wdz/cWigD1CiiigAooooAM0UUU AFFFFABRRVXUppLfTLqaIkPHC7qQAcEKSOtAFqisrw3fzan4ftLueRXldSHdVwGKsVzj3xmp9W1B tM02W7SHz2jKgR7iu7LAdcHnn/8AV1oAvUUyGVJ4UljbcjqGU+oPIp9ABRRRQAUUUUAFFFFABRRR QAUUUUAFFRSXMMU8MDuBLNny1/vYGTUtABRRRQAUUUUAFFFFABRRRQAUVEl1byXEluk8TTxgF41c FlB6ZHUZqWgAooooAKKKKACiiigAooooAKKKKACiiigAopCQoJJwByTVPSr2bUNOiu5rdYPNUOqr JvypGQc4H8qALtFFFABRRRQAUUUUAFFVNOv49StDcxfc82SMc5zsdkz+O3P40un3bXtp5zw+S3mS IU3Zxtcr6DrjP40AWqKKKACiiigAooooAKgvLf7VZTwbmQyRsgdSAy5GMgkHn8KnooAx9O16GaRb G/aO11QD57d8ru68qTw3Az8pbGeveq3hK4+2xarejcY7jUJGibaVDIFVVIB9hz75rYutOsr0f6Va wze7oCfzqaKGOCJYoY0jjUYVEUAD6AUAPooooAKKKKACisnTgq6zqMX2i6Z42DeXLKWQq4DZUHpg 5HHAq3ql+ml6Xc3rgMIYywUtjeey59ScD8aALdFVNMvH1DTobp4DCZVDBCc8HkHP0qj4bdrqxl1A zPILueR0DOzBEDEKACcDgdqANmiiigAoorKtbt5PEV7aqd0UUUYIB4jbrjHTJDf+O9+wBq0UUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFB9qKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigApo/1h+g/rTqT+I/SgDzXxWhPiW7IP9zt/sLRUnimMt4juztB+52/2FooA9Ho oooAKKKKACiiigAooooAKpavcR2mi39xKu6OG3kkdcZyApJFJqWny3yR+Tf3Nm8bbg0JGG6feBHI xnj3+lY95pviSWze0S+sZ4nAVmljKMQOowuBz0PrntQBY8FqF8HaXgkkwhiT6kkn9SaTxpdGz8K3 c6/fRoiv18xcH8Ov4Vl+ELLX7bRxafadOhtYnlRcQu8qt5jbgctjrnHXt1qbxH4eRfC+sOZbi9uZ YtzSXLgkIrBiqgABRwTgD+lAHUwqUgjRgNwUA7enTtWNrPia20e8tbVo2mlndVIVgBGpIG4k/jx7 HkVKurmPw1Z3shjS5uYYxEpGVaZ1+VeD3bjr+Ncx4n0ieLwXPeXShr+Sdbm6PXHBUIDnooYAY9yO tAHfDOOvNZF54ht7eaS2hQzXKzx24jztBdwSMnnAwDnvx0rW3r5mzcN+M474rg7PTjN8SbxGjAig k+1EkZ3EqMYPsSD2/LNAHUNr9vb3DQX0M9kQcCSdQI3P+y4JB/Q+1SXmv6VY2L3k17F5CnBKNvJP oAMkn/8AX0rSrldSWCXx7Y/abkRrbWTTwrJjZvLFc89TjnjBG360Abem6vbarEZLfzBgK210Knaw yp/EDNR2mu2l7q93psG95LZQXkAHlnPYHPUd/wAfQ4y1Nl4j8QL5c/2m2s4GWbY21C7Mu1cDllOw nqVOB1qPSpLe08deIY22QhoLZk5wpVEIPsMbl/yKAOmlnjghklmYRxxqWZ24AA5J/Km2t3BfW0V1 bvvhkXcjDPI+lcrr2qyeItCurXw+klzEVZZrlAQAByVXONxPqM8HjNa+m3lu/hS2e0u4kxZqEkZg 2whQOcdcEjIoAdeeIYLTU109ba7uJtu9/IjDBBx94kjHUfnWsjLIgZGBVhkEHIIrktBtNestKgsY La0hQAs1xLkliScnAwc8jqO3Wtvw/qc+qaZ5l3CsN3DI8FxGvQOpwccngjB6nGcZOKAKmqS+V4t0 BcA+YtymT2+RW49/l/nW2Zo1dULAM2dqk8n6DvXKeL7q5tNf8PSWsKyzb5wiMRgsVVQOSP7xqnrF k2mWul6vqsqSag2pQvcS7QRHH8x8tDjhVz1PJx9AADu6KKKACiiigCvdX1rY+V9quI4fNfYm9gNz Yzj9Km3ZAI5+hokjSVCkiK6HqrDINYB8OTWFy11ouoTQOzZa2mcvA/HTHUcgcjmgC7pOr/2mj7rd 4XUkYJyCQeQDgcjvxWmeh/rXEaJd6/pt9qlvJpUF25uPtM/kTBGUuoxhWzkEL65rej8QllPmaPqs bAdGgGD9DnHXjnH5UAZ9hL5nxG1SMD5Y7VM8DkkJ369Pw4PXt1VcXohuJfiJqd1cW8tsLmzVoopc btoKruODxnHT2NWrrXGuPE+lfZblDpYmeGWVSQrTFGATPQ9Vx9fpQB1VJvXdtyNxGce1KRkYrjNM jtbrxfczQtm8S9lefbgYRIhEAfxZf++fbkA7OiiigAooooAKKKqanqEWl6bPezBikS5woyWJOAB9 SQKALeeaK52w0vWJYhfXWr3EV1I3mi3CgxRr1EZBAJHY9D2znmktbe61bWLldUaKS2sWjRIo1xG8 pRXLEEknG4Yzx+IOQDo6KhuruCxtnuLmQRwpjcx7ZOB+pxVDw5qza3oUGoOiI8hcFU6Da5X+lADv EV0LPw7fzFipELKpHZm+UH8yKuWUC2tjb2yggQxLGAe2ABXJeMvDVo+l3uoCW7STKsUS4cK2X5yM 9Oc+2PbFXbbwHokV0LmZLi8kHQ3UpcfiOMj2PFAHT0U2ONIY1jiRUjQBVVRgADsBTqACiiigDHGs XFxqM9nZ2cbPb58wXE/lt1ABVQrEg/NycdB61r846c+grL1nw/Y64sX2oSJLCwaOaFtrrj0NQpbe IrZljjv7K6iycyXMJEmPT5CAcfSgBvh2Vrfw0Z5Q0j+dcyMqLksTM5wo79cDHXjFS+HZZHt76OY/ vYb6ZXG/djLbwO3ZhVfw5p6nT7e5nlkmkUyFEcAJGS7ZKjrk+pJPpjmo7fU7LR77XxdzCNEuo5jk ZP7yNQBgD1RvwGT60Aa82q2cGq2+mySkXdwpaNApOQMnk9B0P5VdrmbvTNTl0mPUFWMa9HIs6hEU L6eU2STt2k5w2c5wegrT0zXbHUoJWSQRS26g3MMmVaAkZIbOOnIz04NAEWt+I7bQjGLiC4lLo7jy gvAXbnJJHJ3cDvg1sVwDY8TeO7qzFwX06OBS20EB1XHyhu4LMfwBxXW+ILS4vtBvLW1CtLLHtCsc Bxnlc+4yPxoA0s5qKe4gtYTNcTRwxLjLyMFUZOByfc1zdnqN9baJbWOm6LdG8WLaRMCsUTY5yzNk jJ4APTjisnxPouo3tvYPqN0r3Vzdpbi3hJEMSsrAkDqW7knPUjBwKAO/ooooAKKKxor0WnimfTpZ M/bIxcw5PQqAjKPwXd+dAGwSB1OO1LXPeJZ1/wBHJbdDZTR3d0F+ZlUMNuVHJz8x6fw10NAEYnia 5e3Dgyoiuy+isSAfxKt+VPJAGSQB61y89g2s6tPq+mXvlXVmwtYmH3H25Lq2QcgliOPT15rP1u78 ZRabqHmWeni1SCQtIgOQm05I/eZzjnpQBs6Pruma7qry2trcLNGkka3DoAskauAcEHkbhxkZHPTP J43O3wbqLhyhjVZFYHBBV1I/UVl/D3Tg2jWmsSXEjzvC8ATIKKokP45ypPXv+NanjGOSbR4IY13L LeQRuCOMFwP5kUAaVzs0vQ5vIAjS1tm8sAfdCrx/Ks3wT/yKNmA27a0q59cSsK1dUjM2kXsSgsXg dQBjnKn14rI8Cgr4OsQQBhpRxnH+tf1oA6KiiigArm9BnW48VeInVSBvhXp12hkPP1U/5NdJXCaM dQGp6zBpYhMsmpSi4nc58iPPykLwGOTJ+K8jnNAHd5pCQOSQBXOP4SEcrXlpql+NQAGyWWcspI7M Mcg/1rOufFeqnweNWg02IeZCMTeeNqOW2fdIz15A56j3oA2rvxHHBNcJb20lytqrPO6nCoF+8M85 I5446EdjjUsrpL6xgu41ZUmjWRVfGQCM844rjtA0C51XRLNdRxDp2BOsEZO65LbWDSkk5/n6bcCu 4AAAAGAOgoAKKKKACq8N5HPdXECK+bdgjsR8pJUNgfgw/P2NWKxrGZo/EeswSFVjxBMmSMkspUn/ AMcAx/jQBFruqS6bf2k4kC2kJAuwxwoSRgqsTjHGGP4Y71vVhaZCdT/tW5uctbXjGBFyRmNNy5Hc ZyfTnJ75qtFpWtaDa/ZtFuIbq0Qfu4btfnTqTgrtBGT36fhyASP4kk/to2sdr/oUdwtpLcseszDI VR6DKgk+p9s9F9a4XwXpd09mqXV0DDZXbkxDIczAD7xz0GenGcnIruqAIZ7qC18rz5Uj82QRR7jj c56Ae/FV9W1a20axN1c7iuQqomC7k9lBIye/0Bqh4llEX9jgoreZqcKZI5X7xyPyx9Caj0WFtWvD rt5EVcFo7NQRtEXZuP4jlhnP0GKAHx+K7U3VrBcWV9aG6IETXEaqGJ6DhiepA/EVvZqlrFv9r0S+ t9m8yQOoXGcnaccfWuZ8O+MNNj8OWSX1zJ9pRfKKiGSRuCQuSFOTtCnPfPvQB2dJkHvXP3WrapeK BommmVGIAurohI155+TIc/p+lY+h6fHqfi+6vLu8N7Pp52ncTtjkOQQgxwoKuP8AgIPegDuaKOlF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJ/EaWigDgfEisdfuSM4+T/0EUVPr8St rdwT1+Xt/siigDt6KKKACiiigAooooAKKKKACkCgEkZ59STS0UAVLa1lt728kMiG3mZXRAuCjYw3 1BwD9SatkAggjIPaiigDndN8KrZXyTT3011BbMzWdvIMLBuJOf8AaIBwM9PyxvywxXETRTRpJGww yOoII9wafRQBWs7C2sIhHbR7FAC8sWOB0GSScDsO1RrpkC602qAuJ2gEBUY2kZzn69Bn0FXaKACq V5pGm6i4kvLG3ncAANJGCcemfTk8VdooAit7W3tIvLtoIoY852xoFGfoKq6homl6qVa/sILhlxtd 0G4Yzxnrjk8e9X6KAIre1t7SMx20EUKElisaBRk9TgVANJ00XIuRp9oJw28S+Su4N65xnNXKTcpc oGG4AEjPIB6fyNAC1hxXC2njGayUBUu7Zbgj/poCVP5qB/3zW5XPasV/4THw8Mpuxc9/m/1fp6de aAN14IpJI5HiRpI87GZQSueuD2qprGlw6xpz2kx25IZHwCUYcgj+R9QSO9X6KAK9mt0lqiXjpJMo 2mRON/8AtEdifQVYoooAKKKKACiiigDEwy+ODgsEbTvmAPBIk4J98Hj8a26jEEYuDcbf3pQJuz2B Jx7df5egqSgDP1LRrXVHt5Zd8c9uxaKeE7ZEyCCA2MgHPI71BceGtLm0RtJS1jitTggKoJDDvz1P GOeo4rXooA5iGx8WWtuLJNTspo/updzQsZUXHU/Nhm9Mj6k8mqlp4dvvDN3davbOdXurhSJ0cCIn JBLAgMe33R1z7DHZUUAVLC+N/EXNpdWxB+7cR7SevTn2/wA5q3RRQAUUUUAFYfijC2FrNKrPaQ3c T3KDndHnHK/xAEqce1blIQGBBAIPBB70AUDrVg+BbXEd3Ifux2zCRj+R4HucCsH7bq2h6rd3M2jX NzbXwSUR2R80wuF2tngZzhf6Z5x1MVtBbsxhgijL8uUUAsffHWpaAOctbfUdfkgu9UiaytE4Omsd wlP95jxkZx8pGPl96bpqy+H9S1O2lt7iSzuJzdQSwwNIFLfeQhc4wRxxjv3rpaKAMbUbl7vw7fyP ayxI8Mixo/Dn5TjcD93n69jWpayme0hlIILorEHtkZpLq2ivLWW2mBMcqlWAODg+lSRxrFGsaDCI Aqj0AoAdRRRQAUUUUAFFFFAENrbi2hMYbcN7uOOm5i2Pwzj8KzpfDtnNr41WUb2Cg+UwypkAwr/U KWA9NxPXNa9FABWXeeHNGv5hLdabbSSBi27Zgkk55x15HetSigDIvPD9tLHB9hdtNmgyscloAmFJ yVKjgrnnHrz61etbNbYHdLNO5bdvmcsQenHYcelWaKACuXeQal8Q44HSTytMtWkQ4+UyvtB/8dYf 5znqK53QoRN4i1/UwCEkmS2UN1zGoDH6E4x9O1AHRUUUUAFZeq6Ob+e0u7acWt7auWjn8sP8pBBU gkZGCfp+dalFAGVbaFDDp15bSzSTS3ob7TcHAdywxx6ADgDtVJNL1+PThpkeqQLGAVF6Y2MwXHTB brnjOeAB35roqKAILO0isbSO2hXCRqAOBk+5x3NQa3BJdaDqNvEpeSW1lRFHUkqQBV6igDnPAtvc 2nhO2t7qAwvHJKApyCR5jHJBAxyTx7e9XfEkc0miv9nieSZJoJFVF3N8sqHIH0Fa1FAEcMq3EQcI 4Vu0iFSfwPI/GqGi2z2FtLYvGQsMrtHJjCursXGPpuwfp71p0UAFFFFAFTU455dPkW2XdLlWCbym 8BgSu4dMgEZ96y7LWLC0t/n0u405mPzRi0bDH1BUcj64PqBW/RQBiTazc3SmHTLC6MrfL508Rjjj ODyd3JwQOg79+lTLoNqvhsaKQDD5Wzdj+Lruxn+9zitWigDA0q013SraKxd7O8toVEcUmDG4UcAN 1HA44/XqdmBrgr/pEcSnH/LNy38wKmooAKKKKACsDVvDk2qar9qXUpbeB7cW80CJ/rFDFvvZ9wOn rnIJFb9FADYo1hiSJMhEUKuSScD3PWnUUUAYbaBNb6vLf6Xf/ZFny01sY98Ukh6vjIwx4yRyce5q 5DZXzTiS81EyKpBWKCPykz78lj24yB6g1oUUAZPiDRBrunpa/aDbskqyrIE3EEZ9x61qIiRRrHGq oigKqqMAAdABTqKACqsWm2EL74rK2jf+8kSg/wAqtUUAVdRvU03Tbm9kG5YI2faCAWIHCjPcnge5 rL8JWRg0YXkyp9rv2N1MydDuORj2wfzJ9ai8btv8OGyUEzXtxFbw84G8uCMnsPlNblnax2Njb2kW fLgjWJM9cKMD+VAE9FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJ/F+FLSZ+YD 2oA4zXsf21ccD+Ht/siim6+W/tq4wrEfL0/3RRQB21FFFABRRRQAUUUUAFFFFABRRWa2pXMOrtbX Fg6WjbRDdI28MSBkMMfJycDk59qANKiiigAooooAKKKKACiiigAooooAKpXsd0ri4shEZcBXSQff UHI57Yyf++icHpV2igDKbV7iKMNNo99uyQREEcf+hf0FUtOsLrUNdOuajbG1McYitYCwJ24OXb3+ Yjt9O9dFWZ4huzY+H764U4KxEA+meM/hnNAGhFNFPEJYZEkjboyMCD+Ip9Z+hAf8I/pxVAgNtGdo 7ZUGtCgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAGSTRQgGWREDHA3MBk+n6U+sbUF S58R6baSrG8RgnlZJBkNgoAMd/vZ/CtmgAooooAKKKKACisFdbun8Q3+nRQwzC2VWEYba5BVTnOS CMkjGB2+tal5dvayWirA0onnETFTygKsd2O4yBnpwSe2CAWqKKKACiimRyxy7vLkV9rFW2nOCOoP vQA+qVndy3V5fKVVYbeURIecudisT+bEfhV3P6VjeHnkcap5hB26jMFx6cYoA2aKKKACiiigAoor Ov3v7WY3cGbi3VFVrREG8ndyyt3OD93260AaNQWlrFZW4ghBEYZmAPbLE4+nNQf2xYpbpNczraBh nbdHymH4NjucelY7+K5Lme4j0axTUVtziRhOUJx1KDadwB449R2OaAOmooooAKKKKACimySJDE8s rqkaAszMcBQOpJ7CqEevaVLFJIL+BEjfYxlbZg84+9jg4JB6HHGaANGiikJCgkkADkk9qAFoqnaa pbX0pW2LyJt3LMsZMTjvtfGD17H19Dh95qFpp6K11ME3MFVcEsxJA4Ucnkjp0oAs0UiOsiK6MGVh kEHIIrN1HXbLTp47d2ea6kOEt4BvkPBOdvYYB5NAGnRUcE8dzAk8Tbo3UMp9RUlABRSKysMqQR7G mTyrBbyTOQEjUsxJwAAM0AQadObmCSc9GmkC8nG1WKgj6hc/jVusPwhn/hFrIHORvU59nYVuUAFF RJcwSTNCk0bSqMsisCQPcVLQBl3OoTDX7PTLdRho2nuGI5WMcDHuWwD7fmNSslVU+LpWJO4WCBR7 eY2f5CtagAqnpV7/AGjpdvebdvmrnH9atswVST2GazvD0axeHdOVNuDbo3yjAJIyf1NAGlRTJJoo iokkRC5woZgNx9B60+gAooooAKKKKACiiigChcacbrVra6lceTaqTHGP4nPBLfQAYx3Jq/RRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUn8QPtS0n8X4UAcN4hlK67cjIH3fX+ 6KKg8SuB4guhkfwf+gCigD0GiiigAooooAKKKKACiiigAqC9eGKxuJLhS0KRszqBklQMnAHWp6oa 3gaBqJPT7LLnjP8ACfWgC1ahRaxBHd02ja0hyxHbJPJ/Hn1pBcxNdPahx5yIshXuFYkA/mp/Kqfh 8IvhzTVjRUUWsYCr0X5RxWNrt3Pp3imC4hh+aXT5olkK7huXLgfgVH/fX4gAvQ63qF7d3AstJZ7S 2maGSWaUI0jKxVvLABBAx3Iz7VND4k09sLdNJp8pz+7vV8o/meDn2P8AI1Y0SOGLQ7Fbc7ojAjK2 3aWyM7iMDBOcnjvV+gDlv+E+0gRxOY7z94m8jyDlPUN7jj8xW3p2sWGrQ+bZXUcwwGKg/Mmf7y9R 361heAYJbTSb+2nGJIr+VWH4L/j71pav4X0rWiHubfbMDuE0Xyvnjk9j0HUHHagCrf6jqt7rjaXp JFuLaMSz3EiBlJONqY54IJ9+DyMc7Gm38WqafFeQ/wCrkzjnPIJB/UGuV0S11uyvtWtLS7glMd2S y3wLPsZQUbcuM5A798+tdHoOiwaBpcdjA7uqncWbjk9cDsP889aAGapqs1rc21lZWwuLy5DMqs+1 URcbmY4JA5445PGeRWhbvLJEDPEIpP4lDbh+B4z+QrH1KG+tfEFvqdpZteRG2aCeNWRWQBgwZc4J J54z2/Otpl/q83iyS3vYRb2rWZlSAlWKncoBJH1bvQB0E9zHbvAjhszSeWmBnnaW59BhTU1Y3iKR oLO0dFGft1uCfQeYM/4fjTPEeqjTrFoomP265RktUHGXOADnoMFh9c0Ablc/42k8vwffsM9EHBx1 daXwW80nhSyaeSWST94C0rlmIEjAZJ56Yq9rtgup6FeWhQuZIjsUY5Ycr19wKAJNJOdGscYI+zx8 jgfdHrzTNT1zTdHjR9Qu0gDnagbJZj7Acn8qraXcpZ+DbW6kJZbexVnxwTsTkc/Q1W8L2n2i3OvX SE39+u5iVACpn5Qo7DAX1JwKANiTUbZdMfUUkE1ssRmDxEMHUDOQehq0CCMjoa5G4vT4f1R7awSM 2rXKXF9JIMrAshCBVwwweM4weowDzjrqACs+HVoH0c6lMyRRKGLYkDAYJGMjqcjHHfjmtCvP9IaP UfC+kaC0uwTyyRSlR8yiP95jOMBsFf5+1AF8v4t19o7uwnt9IsGYlA6B5nTsWBUj34x16ng1t6fp +rW9wr3mtm6jG7MX2VEBz05HPFaqqqIERQqqMAAYAFLQAUUUUAFFFFACEgDJIA96ht720uywtrqG YrgsI5A2M9M4rF1mObW79dIt5WjtYiHv3Xg4IyqA5zk9T+HXkG3oNxYXtmbiyt4oRG7wYTGQqn5c /VdrYPTNAF3ULr7Dpt1d7Q3kRNJtJxnAJ6/hS3t7Dp9jLeXThIol3Oc/oPU54FV9djEvh/UoyAd1 rIMEZ/hNYttfW/iy4tLYrvitY4ry4IHAlOdqc9Rw2cccYz1FAG7pWpw6vp6XkCOiMWUpJjcpBIOc Ejt60/UdQt9LsZbu5bEcY6DGWPZRnuTwKyvDVqumzatYfdZbszqnPEbqNpyfUq34g0y6thqPja2S dcw2Fr9oj458xnx19PlHHXI9OoBnPearJ4o8P3V/BBbW80lxHGqsSwVkJUPnHzHYp49SO3PZ1zPj aKWbSEa1lVbuykW/RCRkrGeTz6bgffpXRwyx3EMc0Th45FDoy9GBGQRQA+iiigChrE1/b2XnWESy OjhpEKlmKc52gdT0/DPfFN0nW7DWoC9ncI7oB5sWcPGT0DL26H2OOCa0ayNX8NadrLpLOjxXCMGW 4gbZICOnzfh+HagDJsxNF8T79GGIpbESryOcGNc4+oYfh9K1delMM+jPyB/aCKT/ALyOP61lNp13 pfiiwlTUjPLdwyWqvdRbiFU+YAdpXJ+96fT0l8U2iWumDWJnluLmymhlQE4UASLkBegHJ55PA54o A6C+vI7CzluZQzLGM7UGWY9gB6k8VHpeox6rp8d5FFLEjlgElADDaxXnBI7etZFk0XiXVV1FomNj YuRZuSNsz5Ks2O+Cowff1BAk0eQWWv6rpLbgHf7bBuHLK/3+emA5/XvzgAdrt39ouIdBt5Atxeqf NY4/dw87jznJIDAcdjkjitHTrbT7e2D6dHAsMoDh4cESDHByOv1rnL2G/wBQ126jggElveRRRR3Z XMcduNxk5B5LHgDocjtWv4Z2x6S1mJmlNncS25Zjk/K5wDwP4StAEWo6DPuubnRb06fez43PtDoT kknaQRk5HPt2yazvDn9uwtqIaDTZc3kjSlZ5E/eEAnblW+X/ADxiuurK0O6t70X91akGGW6JU7SM 4RAT+YNAChtdeYZh06KLPOJXkbH/AHytXIo7rGZ513HtGgAH0zn/AD+tiigBFBAwWLe5paKKACq9 /c/YtPuboJv8mJpNucZwCcfpViormIT2s0JziRGXjGeRjvxQBnaRFc3GmCS9vWu4rqFWVXiVGQMv IJXAPX0FZEd8/gqzSzvbN5dNVyILm3+YqCScSKcHI55Gc+nFbeiyNN4dszHIvmfZ1QOy5G4DBOBj IyPb8KJY9aGTDcWDdeHhcfTkMaALdpeW1/bLcWk8c8LdHjYMKnrE0nQ5LLU7jUppkE1wgWSG3TbF nOc46k9efc+tbdABRRRQBg+Kr8QWMOnxyBLnUpltkJGQFZgHP/fJI+pFU7zRLB9asNNgiRYdv2i4 jcltyxAImM55y/Pt16jNnxFa6q2o6Zf6VbJcSWonBR5Aoy6ALnJGQDz68e9RNpmqWyx6tBHHLqzS lrmIuFV4yAPLB7YAXHJwcn5u4B01YXia7eOC0sEbZ/aE627vx8qEgNjPcg4/GtaG6SZygjmRwoYh 4mUDPvjBPsDTNQsItRtTBKXX5ldXjOGRgcgqexoAfZ2dvp9pHa2kSxQRjCovQc5P61z/AIaxrVzP 4guUYTF2htgfl8uDqAQDgnk5znkcVrR6QnmK9zd3V5tGAs7Lt9MlVABOM9fWsSXTdf0OWdfD6Wc9 pcTed5dwp3RMQAQDuUbeOO/bHegDrK5Sy1G0ge/1Z7dmv57uS2ihTO9guFC4/wCAgk84z+FXI7Tx Hexqt9f21mhHz/Y4zvYHtli2047gn/Cgnh7U9Cv5brQ5Ibn7UV8832XcEZ+YMCM57/QfUAHSabZL p2m29ohJESBSxOSx7n8Tk1gSXMnibWbnTbe78rTrJ9l6igq8x7KG7LlWBxjp1IPG1Ba3ssUZ1C7U yKSStqpjQ8cZySxxz3H0rlPCkOrqNRurNbEw32oTTNK6tnrjAHHAwcdevOOaANKws4/DviaLTbLc mnXkLOkAJby5Vxk5POCB+Z/KfV9PuLnR9Rmu7y5BWKfZDFIEQKN23OACcrtyCSOvvV2w0ZbXUJ9S uJ3ub6YFDI3ComeFVew4H1Iz3puuWt1fQx2UMW62uHC3MgkClEBBOB3yMj8vwAM618J6ZBpNu160 6vFAvnubuRV4ALE/NwOv0zWTZ+F7bXJUuY7KSx0ojCo07ebKOu7HIAzx1PTPoa6DxXpt3qmmQQWg dsXKPLGsgTzIxnIJPGOh/Cmppmq6tBCNauY4UGDJbWY2hz7sSSO3Q/qAaAMQ3Wk+HJLo6BpCyTWy CO4uGcqi5bGO5JLAdBz74OO6rN1PT45PD9xYwRYVYCsSL2KjKgfiBUljqS6jo8d/bRly8ZYRZwd4 yCmTjkMCKAMuecQ+P7ZTz59gYx7YZmJ/8d7etbV3fWthCZbu4jhQDOXbH/6653VzYaje2d2b6606 7tlYZ+zsG2uMEEkcHrg54ycetMsrZ7BW/sfSrm5mkbd9uv3Q8nqeoYj1xjOe9AHSWV9aana+faTL NESVJX19CO3/ANeuXs/FEGkaBJaXoKalYJ5X2eX5d/OIznkYIxk89CRkcno9J07+zbIxNJ5s0kjS zSkYLuxyT/T6AVJqNhFqdhLZz/ckA/Ag5H6igDjJ7fR9WsIluZG1LV7pcookbZFLjIBAOAFOMg5I x04rt7OF7ext4JJDI8caozk5LEDBNYOnawujW0Oma1m3lhxDFNsYxzIOA2ecYGNxOACe2cDZXVdO bG2/tTnpiZef1oAtk4GazdN1q31Sa4jgjmAhcp5jqArkEj5SDz0z9K0gQRkciue8OJc2ep6zps0K JBHOLi3KLgFJSxx+BU/nj0oA6GiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACk/i/ClpM/Nj2oA848Ugf8ACR3eSP4P/QFopfFAH/CR3fz4+5xj/YWigD0eiiig AooooAKKKKACiiigAqjrau+g6isYJc2soUDqTtOKvUUAZ2gKq+HtOVTkLbRj/wAdFZvjLTri80pJ 7FC15bt8gVdxZX+Vhj6H8hXR0UAQWduLOxt7YNuEMax5xjOBip6KKAGJFHEzlECmRtz4HU4Az+QF PoooAx7/AEeZ9QXUtNuUtbwKVffGXSYY4DDI9uRzwKsvDqU6BWuYbYZ+byULtj2ZuB2/hPf61foo Aai7EVdxbAAy3U/WsfUnSy8RaVeOsarMJLJpGIBBbDIPfJTH41rQOrx7lkMgLNycccnjj06evHPN c34+DL4a+1xs6yWk6ToyYJVuVBGf96gDY1vTDq+kzWKzmBpNuJQMlcMDxyPTHWoNL0V7OaW5vbxr +5dsrJIgHldchBklR8x4zjHH116KAOb0+abQLq40t7G5fT1ZpbWeGJpBhjnyyFB5BLcnHGPrW9ay yz2yST25t5GGTEzBiv1I4zU1FAHPwRSrbalo88csSyvKLeWOFmQJJkjkDAwSeuP61RsT4ptLGLSI 7G3V4R5a37y7kKjoduAc4x6/T066igDHh8OWi6JLptw8k/nj9/M5+d267snPfkDn8eaWyg1m0t1s 5JbedUQql47Nvx23J/EffdzjtWvRQBDawtBbqkkplkxl5SAC7euBXJaf4fubDxqpjj26fGJblJAC QS3y7PQEZ465APrXZ0UAFFFFABRRRQAUUUUAc5d6FqQ1TUbixvLdYdSVEnEyMWiCrtyhB6kE+nam DTLvw7fSXmmpLeWc4RZrJNqlWAA81exbAORxnPXgY6aigBEJZFYqVJGSpxke3FQWlja2CMlpbxwq 7F2CLjJJyTViigDOvtKF3dw3kN1Na3UY2+ZFg7k5+Uqcg9c9OuKralodxd3Vrd2epSWl3AhjeYRB jKvYMOAecnpjk4xW1RQBQ0/TBaRMbmUXd1Ju8y4dAGYE/dx2HTjpTtJsZNM02Kze4NwIRtjcrg7O wPJyR0zx9Ku0UAFFFFABRRRQBz3i+drOysL4eZttb6OR9gz8uGUg+mQ2PxFb0sUc8TRSxrJGwwyO Mgj3FV9U06HVtOlsbhnWKXG4oQDwQe/0q3QAyGGO3gSGFFSKNQqqowABUVxY2d26PcWsEzp91pIw xX6ZqxRQAiqFUKoAAGAB2rGl0F49TlvtNvmsWuAPtCLErq5B+8AejYLc8jJzjrnaooAbGhSNULs5 UAFmxlvc4pVVVGFAAyTgDueTS0UAFFFFABRRRQAUUUUANjijhjEcSKiL0VRgD8KdRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAVgeDGWXwzBOsfl+dLNIVB4GZG/pit+oLKyt9OtI7W1j8uCPO1Mk4 yc9/c0AT0UUUAFFFFABUMVpbW8kkkNvFHJKd0jIgBc+pI61NRQAUUUUAFFFFAEcsEU6bJokkX+66 gj9ajisLOCTzIbSCN/7yRgH8wKsUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABSfxH6UtHegDzbxU4HiS7BA/g/wDQFoo8VBT4ku85z8n/AKAtFAHp NFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAZL6dPYXF1d6X5Za4cSTW8g+ViBzs IICs3cnPQVka6uta7ph0xdJMAnOJZXmUqgDD8euD06A4zXW0UAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUd6KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACk70tN/jH0oA8x8XBz4ovMA4+Tv8A7C0UeLmx4ovOP7nb/YWigD1CiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApP4h9DS00/fH0P9 KAPM/Fv/ACM958ufuf8AoC+1FP8AFcyJ4lu1MeSNnOf9haKAPS6KKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKAAZxz1ooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAppHzg+x/pTqTnPtQ B5v4qlZfEl2BGhHycn/cWik8VOw8S3YBH8H/AKAtFAHpVFFFABRRRQAUUUUAFFFGecUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFHeigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKQbudwA57HPFLRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUncUtNJw6j1z QB5b4wlK+Kb0c/wf+gLRS+L1z4pvTuA+51B/uLRQB6nRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUh+8OPxpaQ9RQB5Z4w/5Gm9+cD7n Bb/YWineL3YeKbwBFI+Tkk/3FooA9SooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKQjpzj+tLQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFHpxRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUh6ilpD98DPY0AeU+Mdv/CV3uWYH5Og/ 2FopvjNseLL3k/8ALP8A9FrRQB6zRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAg++foP60tFFABRRRQAUUUUAFNP+sH0P9KKKAPJvGn/I233/AGz/APRa0UUU Af/Z ------=_Part_46216_11624287.1190585217822 Content-Type: image/jpeg; name="grain2.JPG" Content-Transfer-Encoding: base64 Content-Disposition: attachment; filename="grain2.JPG" X-Attachment-Id: f_f6y3ntrl /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0a HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCALVA+UDASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigApCTjpmgkCm9fQ+maAEdwODx9e9N2ZwWHA6Y4qQKB7n1pTk96AImPHBwB6Vz2p6u8t5 /ZGlMZdQfO9lXCwqOpLcgHn8PrgGbV9TnmnGk6X893IdskoyBCvc5/TPb64FaGj6La6La+Vbrl2A 8yU/efAwPwHYf1JJAItG0WDRbQxxkPcSHdNcMPmkYnP1x6DP5nJNi6nhtYHmuJY4Y0Xc7McYFSX9 /babatcXUgRBwO5Y9gB3JrFt9NuddnW+1YNHarhray3cDjh2x1PPQ9PbnIBTEN74sUjEljo5Jyf+ WtwM/wDjq+3WuhFvb2Fpsijjt7aFScDAVR6//XNWp54LO2aWZ1iijXJJ6AAVz4huPE9xvuUlg0qN spGTtaYg9++Py/qACjJJeeK53tbCQ22jqSs92B88xGcqn49//rCugjtrPSNNMcMaW9pCCxBP3fcn r/OrFzc2mk2AeVlhgjUKqj2HAA78CsCOyvfFDrPqStbaaDmO1ViDJ0+9wOOo/HjsxAKzzXfitntr FJLbSlYrLdnIaXGOFGeh5H6+x1pDpnhfSFTi2tI+FUY3O3t6n+WPQVZ1bWbXRYYo9u6eT5ILeMcs eg4A4HT+QycCs7TfD89zfLq2uSm4udv7q3YDZD07evH+OTggAzotO1LxZIlzqebbSAQYbVWO+Ydm c+/r6dMcNXVLFHBbhVRYoYlwABtVVA/IDFLqWo2mlWMl3ezLDCnViMkn0A6k+wrlktNS8ZXPm36S WWgrzHbZAe5GeCx7Dj6YIxn71ACT3934puJNP0WUwadGwW51Acb+OUj56kYOffPAxu6TTdMtdJsY 7SziVIkHJwMucAbmI6kgdat2tpb2VtHb20KRQxjCogwBWHqusSS3Z0nRwJL9uHl27kgHck9iP88k CgB2r68LKRLOxiF3qkn3IF7e7Y6fmPcgAkN0Tw6bGeTUdRk+1apL96YE4QdMLn8s4HXtV3SNBttJ MkoJlupf9ZM/JPsPQcD6457VpNhRnOAKAG9OgP5Gud1LxA8l+NH0ZVuNRckPL1jtwDyWPPI/nx14 MF7qlzr15JpWgzFEQ4udQU5WP2X1J9vz71uaZpNrpFr5FnHgH77HlnPuf8igCro2hW2kK8u9rq+l GJ7qT7z85OOeBnt9M5qfU9as9IgWS5chnO2OJeXkPoo/qePes7Utfla5bTtGhjvL7ozgZjg92I7+ 2fTpU+l+HY7W5N/fSfbtSfkzygHyuc7UHYD2x06DNAFWOxvtfmW61gtbWasGisE6t6M5/pxXSwxx wwpFEixxoNqoowFA7Ck6deT7mmNIEQsx+VerGgCxWPdX819dPYaXIgdMefOTkRA+3djzge2T2znz X934hke201nt7JD++uyM7v8AZT1Pv2/EVt2FtbadaLb20YVB+bHpknueOtAEtlZQ2FsIIAcdWZjl nbuzHuT61V1LVBan7PbJ5963CQj19z06c4z056c1W1TXTbzCxsovPvnHCKQQg9/f68DuRUukacmn I0txKJryQZlmzwOc4Ht6nvgZ7AAD9O0o20rXd3L594/V+y+w/wA/lk1X1DVbqe7fTNGVHuguZbhx mK3+uOre1UrnVp/ENxJp2hzMkC8XGoKuVXr8qHu3H65rZ0zT7LRrJbS0j8uIfMSTlnbuzE8k0ALp mlxaZCwVmlnlO6adzlpW9T7eg6Cn6hqVtpkAluXxuOEReWc+ijqT7Cqmq65DYCOGEG5v5srb2qH5 pG/HoB3PYcniotO0l4rn+0dSlF1qJHBB/dwdfljGPcgnGTz0zigB9nZXl7crfaqBHtwYbJWysZ67 nPRm4HsMZHPTXLBetRNIwHT8cisXW9bGnRiGFHmvpeIoEUkk+4HPrgdeOwBIAN3zFPTJ7cVHJdRw 7fNdELEKu5sZJ6DnufSqun211b6dEuoXZmuFBMshAA9ccY6evtWTaRL4h1Y3csYNhZv+4BGN79dx /n+IH97IB0quGHQ06m7BggEilUbVAyT7mgBaKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKTNLRQA3qBg07FFFABXOanql1fXR0vRADL/y3uQflhXvg +v8AkZ7O1DUZNTvTo+mO27kXNyvSFfT3J6fmPUjW07TbbS7Rbe2TCjlmONznuTjvQBHpOk2+kWgi iy8jAebK33pCBjPsPboKNS1WPT1CLG0904/dW8f3m+voPf8AmeKjv9WMNytjZxG4vXxlQDsiB/ic jp346n2607TdJSy3TTObi8kO6SdxyT049ABxj6+poAp6fo8092up6wRJeDPlwg/u4e3yjPP1rWu7 uCxt2nuHCIv6+wqPUNQg06382YnJO1EVSxY+gABNZ9nps99PHqGrAGRRmK2wNsfPU+p4H0PPpgAZ b2lzrUy3WqQCK1Q5htSc7vQuPy4PcfnpahqVvpsKvM2Xc4jjB+Zz7VX1fWY9OCwxL517KP3UI/mf b26nt3xBpmjS/aP7S1WQz3zcqpA2wjsoA9P5+vUgEVhpNzfXf9payMyZPk2oOUjHuO5/z9L2q6ob IJBbRfaL6UHyoR6f3m9FFJq+sJpqJHHG015NxFCozz0yfRc4/kOaTS9Ka2ke8upDLezZ3t2HoAPo B645x1OQBmmaKLW5kv7x1uL+XG6XYBt4xhfbkj6fiS/WdetdGjRX/e3cvEFsh+eRu3HXGe+Pz6VX 1nXmtZxp2mQ/a9UkHyxAjEQx958np3x9OmRRonh0WEhv7+Y3mqyD97cN0XPUIOw7dB7ADgAFTTvD 91f366t4iZZZ1z9ntF/1UAPqO5/+sTkgY6ckAEk4A6mmySJFG0kjqiKMszHAA9TXPyy3viQtDZsb bSiSklwQN8w6EIOcDtk9/oQQBb7U7rVXaw0KVQd2ya9GGWEd8c8n0/pyRp6XpVvpVsIoAWY/flfG 9+vU/ifzqe0tILG2W3toxHEvQDn8STyT7mlu7u3sbdri6mSKJerucAUASO6RRtJIyoiglmY4AHqT XITS3/jC4a3s3ltNERtstwOHuMdQh/T0+vQTpHf+LDFPMfsuhsd6RA/vbhR03einrx26ZyGG9d3d no+n+ZMyQwRKFRenQcKB+HQUAEUNjo2nCOMR21rEOpbge5J5JPqeTWBI194tBW2aay0gja0rDbJO O+0cEL7/AP6qsJpVzr8sd3rIMdqBuhsB8pB9ZCO/Q47V0QAVQAAAOAB2oAq6dptppVottZwiOMcn 1Y+pPc1aI9KWs/VNXt9KiUyBpJnOIoI+XkPQAD6/zFAD768t9Pt2nupRHGvfv+Hr9K59LK+8Syrc X6SWulg/JanIecerdNo6cdSPwNXbfRJtRvPt+uKrMjfubQENHGPU+p/T863pHSONnkZVRRlix4Ao AqpGIYlSKMKijARRgKPwrnr3VbnU7mTTtE2vIoxNdK+FiGcce/598DjNOuri58TyTWOnAwWKnEt2 y53eqge47e/OOh2bbTrLRtO8mBfLhXLux5Z27sx7n/PQUAUrGwtdCs5NpVSRumnYAM/68Adh/Pkn O2XfiWV1dZbXRkOCQ+2S6+nonv37dci0NPl8QurXAeDS1OVh6Nce59F/n9MV0BhVQAOMDACjgUAU ooIbWBYoI0hhT7scahVHfoKzNS1F45RY2K/adSkUlIVbCoP77nso/wA8kAy395NLdnTtJRZb7AMs jEbLZT0LepPOF749OavaPosOkWzKsjzXEp3T3D/elb+gHOAOmT1JJIBV0vRo9N8yZ5PtF/OP390w 5bp8qj+FeOme3NaOCDgnHP0q0V475+tYN/qU91ctpmkEPOOJbjjbD/8AX4PPbpyegA2/1WQTHTtM jFxqBHOCMQj1J6Z56dPXsDe0jR49NDzSHzb2bmaY8k+w9un1wPYCXStKh0q3MaMZJXO6WVurn+g9 v/r1S1nUbhrhdK04E3coy7qceUvHOccdevYdOSKAK+qzya3dvo1k48tcC7mXogz0/Tp3PHQNWpdX mm+HtMWS4dba1jwigKSST2AGST1Pc9TUEa2HhbSN0zhVyN7hPmlc+gH0/ADk8E1iaVpM3iPUE13V kYW4ybW2c5GD3Ptj2+bHpncAdiDkAjoaWiigAopCcCqt3qdnYgG6uYoQRkb2AyB7UAW6KitrmG8t o7m3kEkMqh0cdCDUtABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUjMEUsxCqBkknAAoAWudv9SudUvTpejuAB/wAfF1tO2NfQEEc/Tk54xgkR3d1e+Ip2sdNZ rexQ4nvCOW/2U/z068YDbtjY2+nWq29tHsjX8Sx9Se596AE07TrbS7Nba2TCDksfvOfUnuf/ANQ4 FUL7VZpbxtL0sBrvH72YjKW49T6t6Ci9up9RnfTtOlaPYcXNyv8AyzH91T/e5/Cr9hYQadarDAgH dm7se5NAEem6XBpsJCZeZ+ZZnOWkbuSaZqurxaZEFCma6k4hgTlnP+H+HFRanrH2WZbO0j+030hG 2JRkIP7zeg/L8OtO0zSjZ7rm6l+0X8g/eTHt/sj0HT6+gGAACPTdLmM/9o6o3m3rD5EyCkA54Ueu Dgn8upJNT1l4pxY6dGLi/bGU/hjHqx/pn3qndarc6veNpujOAqHFxeY+VBjop9e2fy6EjU03SrXS bcpboS7cvIxyzn1z/Tp+dAEWj6MunBpp5GuL2XmWVznn0Ht/ngcB+r6sNNiVY4WuLqTiKBBkn3OO QoqPV9WFjGsUUZnvJhiKFep/2j6Acf0zUek6Q9k8t5ezeffTHLuf4RjoPb+WT+IAukaQ8ErX1+/n ahJyWPPl+w/X6ZIHUlq2p6zd3d02laAUa7BxNdMu6O3GcH2LcEY7EY9QK13qN34ku307R5Gjso2C 3d90Df7EZ6k46n6cgEGt/TNNtNJsltbSMKg5JwMscdTj6D2AAAwABQBHpOj22kxSeVmSeZt8878v I2SeT6DJwO2T3JJtXd3BY2z3FxII4kGSxqHUtUtdKtvOuXPJwiKMs59AKyrTTbrWZkv9bjAiU77e yPRPRnHdsdvr64ABFHBc+KZBcXXmW2kDmGAHD3HP3mI6L6DvnPoT0iIkUaxxqqIoCqqjAAHQAU6s zWNZh0qEDiS6k+WGEdWY8Dj0z+fQZJAoAk1fV7XRrNri4YZx8kYPLn2/qe1ZFrotxrV5HqmuD5V5 t7D+CMcct6nr6e/oLWl6PMbs6nqkgmu2/wBWuABEvUDHr/nk5JvajqIslSOKMz3Up2xQqQCx9eeg HUmgBdT1KHTbcPISZZDshjUZaRz0AHeqdno8st2uoatIs9yCDFEB+7t+uMerc/e/wFP03SPJuP7Q vmWfUXBzJjiMH+FR2+vetagAopCQoJJAA5JNY0t7cau7W+lyBLdTtmuyuR34TPU+/ofcUAS32qMJ xZaeomvG5P8AdjHqx7D9eR60/T9HjtJWurhzdXz/AHp3HIHoo/hH0qzZ2NvYReXAmMnLOeWc9ck9 zyar6vrNtpEG6XMkzcRwpyznoOPTP+SeKALV5eQWNu087bVHAA5LH0A9awlt73xJKsl0HtdLBDJD 0eYYzknPA/yPWp7TSJr27XUNXIdxzDb4+WP6+p5/TJycY2Li5htIGmnkEca9WNADf9G0+0AAjgt4 lwAo2qoHYCsyKKTXXE90jR6erZit2H+ux0Z/9nuB36mpYbaXU5Vur5WSAYaG0YdP9px3PoO31rVo AKydQu7q4n/s/TVHmn/XXDDKQj+rei/njrUl5cTXM5sLF9sgI8+Uf8slPp/tEdPzq5aWkNlbrDAu 1BzycknuSe5oAj0/T4NNtRBAGPJZ5HOXkY9WY9yf/rdKtUVjSTyaxcm3tSPsKHE0wP3/APZHqP55 z0ADgDbi5uNWna1sGKWqttmuQcE+oX/PP05OlY2Ntp1sLe1jWOMHJwOp9TU0MMcESxRKFRRgCqeo 6mtlshiTzruXiOEHk9sn25/zgkADNW1VbCNYox5l5L8sUQ5JJ6HHp/n1xlG6tvC9sxuXW61e7bd5 MZ+ZyTwB32gnrjk5wMkLVeS/XSpvL8s6h4inGPLjO4QkjIBPRR3+novTU0fw+LKU319L9r1JyWaZ udmc8LxxwSPoSAAOKAKWm6Fc6ldjVfEADzD/AFFrk7IhkHOM8E4HHsCcnG3qKKQsAKAFoqvd3kFl ayXNzKkUMYJd3OABXJf21rXiiR4NCiNnYA7Xv51Ic+u1e38/92gDa1vxLZ6IoSQma7cZjtoz8x9M /wB0cHk9cHANZUOgX/iGf7Xrm23tGAZbKEbWP/XQ9egHcnn+EjFa+i+GdP0QtLChkuX5eeQ5Ynvj 0/me5NbNADIoo4IkiijWONFCqiDAUDoAOwp9FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRUdxcQ2sDTTyLHGvVm/SgBzukUbPIwVFGSxOABXPF5fFDlYy8OkI5Bk 43XBHHy/7Pv1yB3+6iwXPiWbzbgtDo4OYolOHnI7sf7vXGOvBHqehRI4IlRFWONFwqqMBQOw9BQA 23t4bWBIII1jiQYVVGAKyLm5uNaZ7XTJvLtR8s12M8n+6h78dSPwIPIDNLr8jwRK0emAlXmyVaf1 C9ML1Ge+PTrsxRRwxLHGoRFGAo6CgCO0tIbG1S3gXbGgwMnJPuT61nXurSS3badpi+ZddJJSPkh9 z6n2/wD1GO4vJ9ZkNpprtHbhts14PYZwnrnjn0ORxV+1tbPRdPKR4jhjG6SRurHHLMe54oAbp2nQ 6XbuzSb5n+eed+C5HU8nge38zknKe4m8STmCxkMWmKR51xtIMv8Asqc9PWpQJfErneDHpKnAXkPc EevHC/Q/kem5DDHbwrDCipGgwqqMAUAMtbWCyt1gtowkS9FBJ/nVDVtXWwaK2hQz31wcQwqCf+BN joowfrj2OF1bVTZbbe2iNxeyj93EO3oW9v8AA5IALCHS9Lj0mKbUNQuBJduC9xcyvkIOpAJAwo+g 6dAAAABNM0sWRk1G/k33sq75HcgrFxyAegAGR9B+JzJJrrxfI9taM9vogbbJcj79xjqqg/w59c55 z6Fy+b4ykY/vrfQ43KlSCj3ZH8k+n8/udTHHHDGscaqiKMBRwBQAy2tYLK2S3t4xHEg+VV/Mn3JO ST3JqpqurR6bGoCGa4kO2KBT8zn/AA6c1X1nW2sGS0s4fteozcRQDgD3Y9h/hRo+itZu19qEgutU lH7ybHyoP7ieijJ56n9AAM0vRpWuBqmrlZb9sFEA+S3H90DJBPv+XcncppYeorn9W12f7U2l6Qqz aicbyfuwKf4m7cfpkdehALWsa9Hp0iWkEbXOoS8RwIM/ifbgn6A1Ho+hG2uX1K/cT6hLzuI/1Yxj A/X2GSBjJzJo+jQ6SrzO5nvZv9dcMckn0HoP89hg1bV3tGS1s4ftF9KcRx54X/ab0Hf/ACAQCbVN V+whIbeFri9lO2KBf4j15PQDjkmjStOa2Buboh7+ZR5r9Qv+wp9B+vWo9K0r+zzJcXMxnvZv9ZKc kAf3V9Bn8609wXOTg/WgB9RXFxFawtLK4VVGeap6jq1vpsBlmYbsHYinLP8AQVmxabdarKl3rRCw jmOyA465Bf8Aw9hnuKAJdk/iFsybotK5wuSrTjsfUL0P4e5rcREjRUjVURRgKowAKQMcYGB26f0r m9Q1yfUbo6VoTxyTld0k4b5UXpkH+vPsDg4ALur68bSdLGwiF1fuQBH2X64/xHHJIo0rQjbXJv7+ X7TqDD7/APDHkc7f5ZwOOABk5l0nRoNJRmDebdSf624Yct3wBk4Ge350mqa0LGSO1t4vtF/McRQK efq3YKPWgC1qGpW2mwh53G5jhIwRuc+gHeqttYzXlyl/qIIZfmhtc5WLjqfVv0H1osNKMM/2+/kF xqBHL4ISMHqEHb0z1OK094Iz29qAH1n3l5JJMbGwZftRXc8hG5YF/vMO59B3wewJqpqGpS3F0NN0 xla5I3SORlYlzjcx/PjqTxwMkaFlaxWFv5cW5mZt8kjn5pGPVmPr+gGAMAAAAks7SKytxFHk93ds bnbuzHuTUzusaM7sFVRksTgAVXur+3soGmuJVjjXu3c+g9TXOwyX3ieQTyb7TSFf5UIw82D39vf2 4z1oAmkmuPE07W8Akg0xPvzdGlPoB6ex/Edq6C3t4rS3SCBAkSDCqP8AP60kflwxrHGgRVGFQDoK wdU164mujpeix+deHh5f4IfUk9OMj+mTxQBa1nXfsUsdjZRm41GbiOJe3uf168cc++NdXX/CNKGk YX3iLUPlRACVXn8wg/DcR27WpWs/BumNO2+81C6YL1w88noM52qOST29zT/D2j3Udw+tawwk1W4X GAMCJDj5VHYDHufXkmgC14e0RNHtzJcSGfUZvmuJmJOWPJA9s/ngegA2jIPf8qiJyB6e9Vb29ttP t2uLy4EECnBd2wM9gPU+1AFzzM9x+BrnNY8Ura3Q07TIW1DVCceSn3Y/dj7Z5A/Eisn+0tZ8ZOYd DaSw0rcUmvH4kccfd7j6Dnpkr0rqdD8PWGgWvlWkfztzJK33nP8AQcdBQBh2nhC71SeO98T3r3Tg 71s0OIo+Ohxxx7fiWrsFVUUKoCqBgADAApaKACiiigAooooAKKKKACiiigBKDn0paQjNACE98Gjd 6/nTJGWNGZm2qASTnGPeuee9vdX1FYNJfyoYWBmuHUEfTHcn049/SgDphRSBcdMYoJwKAFopiuxf G04/vdqfQAUUUUAFFFFABRRRQAUUUUAFFIRkYo2+5oAWikA980tABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFVb+/h0+2MsuSf4UXksfQfp+dAD7y8gsLZr i4kCRr3PesaCxm12ZbzU42WzBzBZuOv+04/p7nPHFSWem3F/drqOroNyH/R7QkFYuQdx7FsgEenX rjG2SFUsxAAGST2oAUnAyelYzFtfdkG5dKX7zcg3PsP9j3/i+nUJfXnKqWj0tThj0NyR2Hon8+R0 66NxcWum2hlmdIYIxjngewHv7UASs0VvCWYpHEg6nAVQP5CsSQXPiCRo1aS30tSVc4w8+Dgj2Xt/ jn5XrbTa3MLi78yGxU5it/ul/dvb2/py2ndXNvptk00pCQxjACj8gBQA13tNJsMsVht4hx/nuSfx JrNjtptcnFxexmKxjbMEB6yf7Tj09P8ADkyQWEupXEd/qKlVUfubQ5wnP3m9WI/IcetbFACABVAA AA4AHasjV9Za2cWVgqz6jJwqdRH05YD6g449SQOaNS1WZpTp+lr5t4flZ/4Yfcn1H449CSFZ1va2 fh6wmuriXLnDT3DAlnPQcck+w5Jz3NACafZxaJZS3eoXQe4f57i4kPfpgfp/QAYUZsUF14smFxex yW2jowaG2YYa5/2n9B6D3+hqa2trjxFMt7qUQTTQQ1tZuM7xjhpB0Oc5x/TJbo6AEVVRAiKFVRgA DAArC1XW5ftw0jSY/P1FhlnxmO3H95/wOcf4jK6jqlxeXjaTo/NwP+Pm6Iylsv8AVj0AH49Kv6Zp NppNuYrZPmY7pJW5eRu5Y9+SfzoAi0jRYNJR3DvPdzcz3MvLSH+g9BWi2Mdf1pJZY4ImlldUjQZZ mOABXMyTX3imYxWbvaaSrFZZiuHmweQoI6cY9PXPK0ALc6tdazePpmhuVjHFxf7crGMdF9T0/P8A EbGm6ZbaTa+Tbk88s7nLMf8APap7SygsLdLe2jWOJBgKP1J9T71m6lqchuP7O0zbLfuDliuUhH95 jzj/ACKADVdXkglWx09DNqMoO1OMIP7zE/55HqMzaXpEemb5GZ57yX/Wzuck+wPYe1S6ZpMOnQty ZLiUhppm+87fXrgdh2q7sAHyhR+FADdy49aytT1cWrJa2yGe9lOEhQZ/E+g9zgAc+gKajqcxuBYa comvG64PyxDuzHHH8/Tk1Y0zR49ODyGVp7qXmSd+p9h6D/AcmgCCx0nyp2vL8/ab0nKueRCMdF9P rWg7qiNIzhUUbmZmwFHckmnTyJbxNNNIqogyWI6VyrLd+MJCirJbaODzIcbpiD0A6dR16D3OcAEs 19e+ILh7TTd1tYof314Tyf8AZC9effHv6HZsrSDT7ZLa3jCKoGd2Nznpljjk1ZtrKCxtI7a3TZBE MKu7OB7k8k+pNY1xcXOtzvY6YxhgQkT3w+ZVP9yPszep7D3IoAW91a6ubt9M0Uo92o/fXBGYrYHu 3q3oo/lzVnS9Kg0mOQrvmuJjumuX+9Kf5Aewq1ZaZa6ZaJa2kOyMHJPVmY9WY9z71Y8sA5bnB69h QAwEtyVPXvWRd6lPe3I0/Tf9cwzJP1jhXn5j6njgdyOoGSEubyTVrp9P0x1woBnuDnbGD29yR279 8DrqWOnQabaiC3D9dzu3LyN3Zjjkn9BgDAFAEdhZW+nW/lQhizHLyPy8jerHH/1gMAcVFqWrW+mQ qZpCZX/1cK8u/wCHYep6fyqDVtZ+zSGzsI/tepNwkCkYX3Y9vpkfgOafpehtaXL397Mbm+k6uTxG PRf/ANQ49O4Bn2mmXepzR6hruCFw1vYgYWMEDlx3PbB/H0G+F6BAMgYAHb6VK7CJDJJIqovJL4AA 9Sa5ee7uvFM8lnphMWmghbi86Fx3VPy/UHpgEALzUptavm0nSHBRebm8Vsqi56ZB78j3we2TVmd9 M8KaNJIkRCjGASTJcSY4GR1P04AzgYrTitbDQ9MKrstrSEbnkchQTj7zH17fkBWFpVlJ4l1WPXb2 EpYQcadA+cn/AKat7nt7evBoANC0W8mvhr2vFZNRZf3EAHy2yHsPf8e5zk9OoDE9QPfPrUmzryTn rmuZ1rxOYLk6XosP23VSQhVVJSH3Yjg4444A7kUAXNf8QWugWqSXGXnkyIoFbDOf6D3/ACBNZVho GoeIruPU/EqhLdR/o+mjhVHq49emR1PGcDK1e8PeEzp1zJqeq3P2/VpfvTNysfThffjrgegA5z01 ACKqogRFCqowABgAUtFFABRRRQAUUUUAFFFFAACDnB6daKKKACiiigApk00dvC80zqkaDLMxwAKp 6prFppMBedyz4+WJOXc+gFZEej3WvTrda4pjtVwY7ANwevMmD7j5fYZzQBGZbvxVNi3L2+kg/NMR hpev3Pp0z0GeMkcdJa2sFjax21tEsUMYwqL2/wDr+9SqqooVQFUDAAGABS0AFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR2oooAKKB065ooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKy9T1cWbrbW0LXV7IdqwoR8vu3oO9AE+o6nDp0alwzyucRxICWc/hVew06R5Y 9Q1ElrwjIjz8sOR0GOCRnGf/AK5LtM0o2zG6vJPtN+/LSnon+ynoOTz39hgDQmmit4XmmkWONBlm Y4AFACu6RozyMqooyzMcAD3rK8t9cIeTKaYCCsZBDXHfLei9OO/ehI5NacSzrt04Z2QN96Ug43N7 cZA6+vpT9Q1QWjCysoDcXxA2woOEXpuY9AP58fUAE99qFtpVum8HJwkUMa5Zu2AB+H/6yBVW106e 6uEvtV2mVeYrdTlIs/oW9/X8AJdO0o20huruU3F8+d0hJwoP8KjsBz+Z9al1HU4dOiUt880h2xQg /NI3Ye31/rgUASX1/DYQh5SSzHaiL95z6AVStLCS7ni1HUfmlX5oYcYEQPsed3+eww/T7GdnF7qQ Rrw/cQAFYR6D355P4c9Tp0AFYt5fXF/cfYNKkCkEie6xkRfTsT2+oI6glYri+m1q6aw092W1X/X3 SNjI7qp/rke3c1cmlsvD+nBY4j2WOKMZeVuAAPU9B7cUAMSPTfDGms/KJkAsTueRuwHqevH1Pqag tLG71S5XUNWUJCObexK58vj7z+rdeO350tnpM17eR6prChrhDm3twcpb/wCLe57gegA23dY0Z3YK qjJYnAA9aAFrAnv59clmsdJkMduh23F8O3+zH6tjv2z7imC4n8TTNHbs8OiqSskw4N2e6oeoT1bv 09a3oIIraBIYY1jiQYVVGABQBDp+nWml2i2tnCIogScAkkk9yTyTTr6+g060e5uX2xp+ZPoKrapr EGmBIyrTXUg/dW8f3n/wH+QDVaz0ma5uI9Q1grJcqAY4FP7uE9enQnPftx1wDQBUSzu/Esi3GorJ a6chzFahtrSn+859PTGDz2/i6OONIYkiiRUjQBVVRgKB0AHYU6sm5vZr2drLTXAI4nuMEiL2Hq3P +ewAt7fy3Fw2naaQbgAGWU/dhUnHX168e34izpunQ6bbeVGWd2O6SRzlnPqafY2Nvp1sILZNqA5O Tkse5PvVhnVELuwVVGSScACgBaw7nUJ9TuWsdJlVdhxNcYyEHI4568fj+tTPLNrG+CESQ2mcPNyG fHUL6fX/APVWjb20NpCIoIwiDsKAINN02DTLXyYdzEnc8jnLOfUmpLy+t7C3aa5kVFA7nk/Sm39/ DYQh5Dl2yI4x1c+1ULXT5r64S/1Ldxh4LZsYjPByeAcjsDnHXr0AKUFnc+I5VvL8PBYKcw2/QydP vZH3ePx9h16RESGJY41VI0AVVUYCgdAB2FKzKilmIVQMkk4AFZe19awzAppucqucNce59E9u/wBO oBBI82vsY7aUw6YG2vMoIacY5CH+7/td+3rWxBbw2sCQQRrHEgwqKMACnqqooVVCqowABgAUMyop ZiAB1JoACVRSzEAAZJPYVg3Fxca7M1pp8rQ2iHE10FB5B+6uep/DA689DIzS6+4SMvDpyH55FbDT n+6pB4A7n8ueV1kSCzttqBIYY1z2VVFADbS0gsbdYLaMRxr2HUn1J6k+5rFu9XuNRum07RlLP/y2 uzwkS+3ue3r24+YJJNfeIZZILbFvpYJR5yMtMOhCg8evqPXJyo27Szt7G3EFtEscY5wO59SepPua AKuk6PBpUGFPm3Dj99OygNIf6D2/mcmrs80VvC80zhI0GWY9qWWWOCJpZXCIoyWPasAQzeJZQ9zG 8OmI3yRk8zYPcdvx6dueQAReVceKZS7O9vpUb4QLw0zA8+2Oo+v0roYIILK1WGCNIoYxwq8ACpER I41RFCooAVVGAAOwrlLyWfxfdS2FjcPDo8TbLi5jA/fsOqqT1XtnHUdx1AInaXxrqYjRWXw/bP8A OxyPtbgnof7oIBGODnJ7V14EVvAANscUa49AqgfyquzWej6cWO2C2hXp+PQepJP1JNcqiar40kLT +bp2hZDKgGJbgds+3Q55HYbvvAAkuddvvEl+2l+H/MitlOLjUcYCjuEyOpHTuc5GAM1uaH4fsNAt PJs4hvb/AFkpHzP36+nJwPc9yTV60s7ewtY7a1iWKGMYVV/n7k9STyanoAKKKKACiiigAooooAKK KKACiiigAooqOeeK2haaZwqKMkk0ASVg32vSvdnT9HtzdXYOJHPEcX+83b/63Q1AJr/xMWWDfZaV kZmIxJOP9nPQe/uMZwcb1nZW2n2y29rEI4l6Ac/mTyT9aAM3TPD8NpcfbrtjdaiwG6ZzkIcYwg7D rz15PritmiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo70UAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRR1oAKKKKACiiigAoooNABSZFN3kccE96wrrVJ9Tun03SCMrkXF2RlIvYd Mt/n1IAJ7/VpXuTp2mxmW8I+duNsIPdv8+vXGKtaXpaabb48wzXLgedcMMNIfX6f5JJyS6wsLfTb UW9upxnLu3LSN3LH1/8ArUt7fwWFs1zdHyol4yeST2AA6k+lAE9xcw2kDTTyLHGvVmOPw+tZMMEu uSx3d5G0VmjEw2z9XPZ3wfrgdP50yCzk1W5jv9QBWNDvtrQ4wnH3m9Tg/h/OOW+utdlNrpUgjs1Y rPeqeuOqx+vbn8uxIBavdTuJ7ltP0lVe4HEs7DMcP+LcHj/AirWm6ZDp0RwfMnfmWdvvOfr6e38z k0tjaQabapa28YWNABuA5bHGTwBmoNU1cWHlwQxtNeznbDCv/oTegH+fUAEmp6oliFijXzryT/VQ L1PufaoNK0maCVr3UZVuL5zkMBgRj0H5kZ9OPUl+k6W1mZLm7fzr+b/Wy84HT5Vz0H4fyGNCWeK3 heaZ1jiQFndyFCgdSSe1AD2ZUUsxCqBkknAArn5bmbxDKbawkkhsI2/fXIBBkI/hX29fX6EboFmu PFUv7ovBoytgt915yPT29u314XRv9Ts9Bso4Y4x5rZS2tU5aRvwycZ6n37kgEAdfX9l4esY41Ql2 +S3t0OXlYDoO57c/TuQCzTtJc3X9qamEk1BxgAcrAvovofU+59yW6TpEsdy2qamwm1KQdvuwLj7i /rz7nrkk3dR1S10u1ae5kCgcKvdj6CgCxc3UFnbvcXMqxxJ1Zj/nJ9qw0iuPEpE1yrQaTkGKAjD3 A/vP6L6DvjPpSW2lXGs3KahrS4iU7rewI+WP0Z/VvbtyO+K6HcKAERFjRURQqKAFVRgAegrG1LW3 +0nTdJRbnUD1OfkhHcuecY/yCcA1LjV7vW7yTT9FLJCmVmvtvyqemF9fw5PbA+atrTNLttJs1t7Z Tgfekbl3Pqx7mgCvpOjrp5kuZ5PtF/P/AK6cjr7Adh/gOwAGoSACScAdTUc88VtA888ixxINzOxw AKxMSeJR8waLSeeCCGuPz/h/DmgCWW4m1qRrazZo7EHEt0pIL4PKp+WCa1oIIraFYokCoPTv7n3p 0caRRrGihUUYAHYVV1DU7fTkQzNl5DtjjHVj06fUj86ALE08dvE0srBUHU1lRpc6xJ5s2YtPzlIs cyjsT6f5x60Wljc30i3eqcAHdFajon+96np+vXOBs0AIqqihVAVQMAAYAFUdR1aCwKxYMt1JxFCg JLHtnHQe/sfSqmo65tnNhpq/adQPGAMpHyASx7AZ/wA9DZ03Slsy1xOwmvZMmSXnAz2UHoOn1wM9 sADbLT3af7dffPcsBsjbBEI9u273HToO5bQlljhiaWV1SNAWZmOAAO5NNuLiK1t3mmcKiDJJOKyr eGbW3FzfQGKzU5htnyC5B+9IPTgEKfqecAAEqI2tbJpQyaeDujiYYNwMcM3ovovfAJ9K1aKoanq9 rpUatcFiXO1VQZJPYfjQBbnnitojLM4RB1JrLjEutlZ2Lxafw0a/daXnr6gfzB9OSltYTalKt7qk ZUA5htSeEGc5fsT0OO2B1PS5qmqW+k2jXE5JwDhR1NAE800FlbbnKxxIMAdAPYVnRxy6zIJp1aKx B+SJhgy+5HYfz9h95tnZXGoSR3uqxBWUh4bfOfLPYn39s4+pAxs0ANjjSKNY40VEQBVVRgADoAKS aaO3haWVtqKMk/560y7u4bK3M0zYUcAd2PYD3rNgtpNWcXV8hW2zmG2b+bDHJ/EjBoAIYpdYlW5u kaOzQ5hhPBf/AGm/XH+c66qqKFUAKBgADgClrndR1K61SaXTNFYjaxjubsHHl8HKof7w7nt0GT0A INRvJvEl1LpGly7bWMgXlyM4Yd0Uj9fXkccmtS6u9M8L6QGf91BGuEjQZZyOwHr05PA7kCoZp9N8 I6MkaKqgfLHHuAaVuB1P4ZPYVV0jSbm/u11nWgTMW3W1s3SFf4SQf4vbseTzjaAQ2em6h4juVvde hSKyjffb2BXknnBkyM9+nf2HB6uiigAooooAKKKKACiiigAooooAKKKKACimM+0j/DNZWr62unbY Y0ee7lO2KGMZJP8Ann+eKALt/qMGnwlpGzIR8ka8s5PAAA9TWXBpl1q863msLshVg0FkDwADwX9T nBx+foJtL0iSGf7fqE5uL4r0z8kORyF9T23Ht0ABIOxkUAKBgYHSimlsY4Jz6U6gAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACkBzS0UAFFFHagBOgxS/jRRig AopMenFFABn05o70bfr+dGPU8UAIDk8GlznpR2oAOef50ALRTdvPFG31AoAXPNNZh05+gpGbYjMz BQoJLHgAe9c9NJe+I5HtbZnttOB2zTNGN0o7hQfX3H1/ukAdPeTa/K9np0rRWanE94O/P3E9/wBM EHoQG2La0gsrVYIE2xL7nJPcnuTU0EEVtAkMKBIoxtVV9KqalqEWnxBmVpJZMiOJM7nPsPT1PagB NQvoNPt/OnJ9FjQZZz6KO9ZdvavK51bWtkYUZit3HyW6nOS2erEEZJ/IdKd9misQ2t69MhnX7gwS sI7KoHU/nzz6YbDZXGvTLd6nGYLFSWisHUZb0ZyCfXp9PxAIi9x4mbKyvb6L/eXIkuiM8A9kyPTk fU43IYYba3jt7eFI4YxtSNQVCipzEOMMFUDAA4wPT6VkanqTQTrYWKCfUJOi87Yh/eY9gOuP8eQB dU1V7Rha2UQn1CVf3cWeFH95+mF/z70/SNLFh5lzcMsmoz8zz9cdPlUnsMD8voAaXpK6YrytJJc3 k3M1wxJLew9B9P8AAB+qara6VZPc3bkIvACjliew7UAWLu7gs7d57mVY4wMbi3U+gHUnjoP1rAji ufEsqXF4stppaMGhty2Gm9GJHbn/AA/vU+30ufVrpNR1pU2AD7PYsDiMerZ7+xHPGcfdFzV9a+xS paWsZutSmGYbdG4A/vN0wOv1wewJAA/UtXg0iKC0t4RLdSAJbWkAGcdBwOiDHX2pul6W0Ep1HUGE +qSg75OcRD+4oyQAPb355JLdI0U6eZbqeaS51C4wbictkH/ZUdgOnb8BgCDUtalW7XTNLh+06i3L blBjgH95z7Z6f14IBf1bWotMCRIv2i+l4gtY2+Zz/Qep/wAKr6bos5u/7T1qRLnUOkSKv7q3XPRf U9OTz6dyXaVo8emySXUshudQlH764f8AVV9Fz/nAGJ9U1S20i0a5uXG0Z2qDyxx0H+PGKALtzew2 ltJcXEnlQoMs7dB7ev5Vzam88XSbmD2nh/GVIbEl0c9T6IR/jzkFXQaRd6xdpf66yiFMNb2IzhOc guPX279/Suk3EKME8cdOKAEt4YLWFLe3jSKKMYVFGAPwpl9f2+n2kl1cyCOJBknrk+gqnqWqw6dA Gdd8rnEUC4LSt2AGP1NU7TSZLi9XUtZ2NdL/AKi3Q5jgGeo9W9/c/QACWttd69Ml9qe6KyU7oLLH Ug8M579Mj610KsFUAKAo4AXoBVd5UVWd32gAlmJGAPftWJPqV5rE72mku0USHEl44IGeOF/D8T6j qQC/qWtGCYWdlH9pvX4CL0T3b/I+op2naSttcNe3kxuL5+S5+6meyD6cZ6/QcUun2FtpcDRW28lz ukkYgu59ScAfhwBU895FbQPNPIkaIMs7nAFAFsyIBksMDqc9K5661q41W5Nhoo3KpAuLsHCxg9gf XHTHJyMccim9xd+J5Hitne00lH2POFw83HIX0wfwHfJ4G5bw2tjbra20axwrwFznJ7knOSe+TyTQ BJp1hb6ZbhYoyZWUebKVG6QjufxJOOgzwKfealb2Ns88xYKvAx3PoPeqV/fwafatcTnEYOAApBY9 gMDk1TtLKe9uhf6mkYcD9xbMMiHnO4nu3APt9egBYgtJdUu1vNTUqitm2tDnC/7Tjue4H584xtGT AyTnjoBVTdnhW69RjvWPe391cXp0zTMefjdNMfuwjOBzjqefy45yVAL+pa39llFpaQtdXz8rApxg epPYe/bvRp+nC2mN5fSrc3z5JcD5Ysj7q59uM9T7Dim6bpkGlwsisZJ5MGWZ+GkI9uw9AOPqSTVa /wBUmF0NP06Fbi/YElWf5Yl9WOPUjj9OgIBb1PXIrF47dAZruY7Y4UwTz0JGen+emTUOm6W0cw1H VGE+pMOg+ZIeTgJx1wcZ+uMAmpNM0kadvlkf7Reyj99cN1PfC+i/4DPbF47jwM9O/egCUygDOfyN UdR1WDS7Y3N0flJwiA/M5/E4/HpUGp6kmnRqzo000h/dwxrlmP4c459/TFV9O0e5N0NT1dllvAP3 cY5WEdfpkceoHXJ4NACWVhPqVx9v1rGf+WNmeURT3II6nI688DPoOiEgIzx7Y5qq0hGTk49ScCuT uNevdfu20/w+WSBGAuNTZTtQYz8hPXOMccnPGBhqANHWNbmv9QOgaM5NywP2meNseQvQgHs3PXt2 +bpbubvTvCGjRQgDdysMKjBkbr7nHqefxJ5yZbmy8HadHaafG1xf3DAIGUs8zk4DMR254Hf8yLGk 6NKl0mra1N9p1PZ9zGEgJ6gepGcZHHpQBPo2iXU11/a2uskt6TmKID5YRnI49R29OvJya6SoFmHG Qw/OniVSMg5+lAElFRiTLYAA9cnn8qduzQA6ik3e1G4UALRSZHqKXIoAKKKTIIyDxQAtFGaYc+tA D6Qmqk93BblRNOkW/OzzHA3YHPftXN3OqX3iC9k0/QXaKKMhbm/ZflTP8K8gk4HbnkdBjIBa1bxE y3Z0rS0+1amRyif8sx3J5wMZGTkemc9IfC2m39hq+qf2mDJdMsTLcYzGwbcSqHGeCOR9Cc9TtaRo 1polqYrdSXc7pZn5eVvVj+P61og/WgBpDEUHd060oHPGfxp3SgBAMCloooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACijPtRQAUUUUAFFFFABRRRQAUUUUAFFFFABRQDntiigAooooAKKK KACiiigApksiQxPJLII41BZmJ4A9aSaaO3haaZwkajJY9qxI0n8QyJPIWi0sHdGgOGmx0b6dwfoR 2NAEZNx4llZEMkGlIcF8Yacg9s9hj6c9znbvwwxW8SxQxrHGvRVGAKciJFGscaqiKAqqowAB0AFZ 9/qEwm+xaeiy3hxuLfchHXLe/oKADU9WSyeO2hia5vZv9XAvp/eY9hVFYYtGVtU1KV7nUZhtVVTL E9o41H5f/rJLitv4diaUh73U7puFGPMmb0Hoo7noPyFWNO0uUXH9o6m4lv2XCqPuQA/wqPwGT/ic gENjptxfXY1LV0TzFObe1GCsP+0fVjx9MD8Ns8ilrI1C/nuJm07TDm4I/ezggrAM45/2uuB7UARa pqcou/7M0qJJb9sFySNsC/3m9/Qe+fQGzpejw6TC/ls8s8rbpp5OXkPuf8/1qfTtOg023EUIyx5k kPLOfUk/U/nWbq2uyC5bS9HjF1qhXJHGyAf3nOffp/8AWBAHa5rkOk+VEsZub6fiG1j5Zvcjrjg/ r7kQaTo108q6jrTxzXx5SBR+7t+QcKPXgc9AR3OWNvRtBj01nu7mT7Xqc3+uunUAn/ZX0X/AegxD q+s3JuhpOjRiW/f78rf6u2XuzHu3I49wT2DACavq8sVwmm6eizanMOAeUhX+++O3oO9TaRoqaYjT Sv5+oT/NPcn7zn0HoPpjp24xPpek22jwSMHMk0h3z3Mp+Zz15PYDnA7fUknHnuJ/FUzWmnvJBpIX E14Mgzf7Ke3HP/6sgBeaheavdPYaGQkaHFxfsMrH6qmD8zc9j/iNbTdKtNItfKtU2qxy7MctI3qT +uPrVuzsLWwtI7W0hWGCMYVE4/E+p9SetZer601vcjTtMhNzqTj7o+7EOOWPTPIOPzxxkANX1ddM CQwQNc30o/c20f3mHqR2H+fUiHS9BlS7fU9VkFzqTk7cMWjgXsFHH5446DuTd0jRRp7SXNxM1zfz nMs74JH+yvAwP5/QADUIPPWgCHB6YJP161kajq5gnFlYwi61B/uxoeIx6v2HUcHrUVxqd1rE8ljo ci4RgJ71uUQeiAHJJ5Gegx37ael6Na6TbeVbglmJaSV+XkJOck0AVNO0lbSZry7kNxfvw0r4wvso 7f57VaurqCzt2nuZQkY7njJ6/iaNR1GPTgqhHmuX4igjGWc/lwOvPsfSqNnoc95cLfa0UklABjtw cxx855HcjjjnpnJ4wAVIYrvxFGs10j22lN8yQ5+eYdmJ7A//AKuxrbijjgiWGJVjjQYVE4wKu7Oe prO1TU49PCQxqJ7uY7YYAMlj6nGSB7//AFzQBHfX1rp9s1xdSiONRznr6dP89ayINM1XxDL9o1Qm 1sFP7qyBKtJ2y/cD26n26VoafoLTzrqOtBZ7wHdFBu3RW/sB0Le+Pp6nfoAopYsiIg8tEQbVRAAF HYDj9KrahcxaZb+bPJyeEjC5eQ/3QByat6jqMWnQqWVpJpDthhT70jeg/wAaq6fpkjT/ANoakRLe t9xOCtuP7q++Op/yQCnp+j3VzdDUtUI80MTb238MI7E/7XX6Z9ea2mUqpLZAHJOePryanZgqlmIC gZJPaufklufENwYbcyW+moSHnVsNKQcFR6d/p7EYABDcXd3rVw9hpTSLBGwW4vDlQvcovqcY6fiR 32LDToNMtRb2wYDO5mblnbuWPr29gABgDFWoIIbS3WGCNYokGAqjAFYlxd3OuXEllpxaK0Q7Z7vs 3H3U6Z69f6dQBl5qdxe3TaZpDZmVts1xtJSEc9/X9OCPXGhpWj2+kWfkQKXduZJZDl5D6k/j+FW7 Kxt9OtVt7aMJGOfcnuT6mpz1HpQBEVzgdPfFZWrakLJRb2yfab+TiODP1wWxjjj2/DrTtV1dopRp +noLjUJAcKBkRjuW7d+hI/UZm0jSF09Wmlbzr2XmWUnP4DPb374HsAAQ6VohtZHvr2X7RqMoBeUj hOvyr6AZI+laFxLFa28k88gSGNS7ueNoHUmrDMqKWZgqqMkk4AFciyyeNLwApJH4fhbIO4obpwfT rtBx9MHvjaAUw1145nkjgee10BG2vKQA930yMEZC9eD+IycLe1O/g0T7Po+kWazX0h/d26HhPV35 GT35PuSBzVrUta8u4XQ9Eh8y9ACN5aYjtUx1PGBx0H/1gbmh+H7fRY3cMZ7yX/XXLj5nP9B/k5oA zdI8PLpjm9u2FzqkpLSznsSACF9OABnA4HGBxWrzjgc1omKM9UH5U37PDnIjAPqKAKSqeynJ/P8A nUpVuc7sd8H39RVkwpjGKPLAPGB6cUAV+c9W+pxinByBndkY6L3qYpx0z+lJsHJ8sA/zoAi34/ve vJP+RThJzwQPxp5UjkYx6bahmljhiaWaXy40GWd2wBQA8OccHcMdc0hlYN1P5VUvtSsrGz+13Vyq W+NyuDncOOnt0/MU61uobrTU1Bt8Nu6BwJl2MB2yD0oAsifPc/8AfJp3mj1HPuRXG6xrt7La7tIt 2ijkykMhjzNcHj/VoR90ZGWPHI5zxUcOv/2LaHTHvjqetZ8yZSx2Rs3RQQMkA/rnpwoAO4Ei8DJX IJAx2qjqmqx2EWF+edhhE9D6nn/9f5muMs7mS0vJtSuLiKbU3RgXL/JaqewJ+XPBOOn61r6Po8uq OL29E0dsedkgKvcH1ZTyq9scE49OoBmW2hXnivVG1C6vZorEYAMQ27yByEJ/h5PzD6DPJrurKxtt Os47SzhSGCMYVF6D/E+9WKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooozQAUUmaMgUALRSdqMj1FAC9 6KQY6igZ6HFAC0hz60ZHrRQAdu9LRRQAUUnPqKWgAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACoLu7hsrdp5mwi/mT6CmX9/Fp9v5knLniOMfeduwA61Qs7C4vbhL/AFQfMhzBbfwx88MR /e/l9egAwafNrVwtxqSbbJDuitGB+Y9mcf8Asv5+lbmMDAorKurqe/mex06TZtIE1zjIX1Vf9r37 fXOABb2/mlujp2nYNztzJOeUgHv6t3C/ie2YgYdFjjsbNGuL6ck5Y5LHkl5D6Zz9e3epJJI9MjTT 9PhEl3J8wQ9snmSQ+mfxJ4HtY07TxZRs8khmu5cGedurn09lHYdqAI9O0w25NzeS/ab5/vzEcLx9 1B/CvX6960aQkKCSQAOSTWO162sTta2EhFshxPcoSB/uoe59+w+oyAPvLu5u7r7Bp3GP9fcnpH7D 1b/PXkXLCwg061WCAE92djlnPck9zTra2t9PtRFEAkSDJJP6k1kTST+InaC3Yx6XkrLLjBnGDwuf 4c49j3yMggC3Wo3WqzyWGjOERTtnve0fXhPVvfp+pGlp2mWul2/lW6ctzJK3LyH1Y9zViC3htYVh gjWONeiqKxr69uNTum0zSnKICVurwA4jGPuoeMtyOR0+vKgC32pT3t6+laQ6+cvFzc9Rbj27FuvH /wBfFuxsLLQNObD7URd01xMw3P1JZm79T+dSWdlZaLYGKFUhhTLuxwMnux/z7dKy4opfEkqXVwrx aXG26GBhg3HH33/2fQfie1AEciXPiiby2EltoqH5xjD3f+z7J6kfTr06KKKOCJIokVI0AVVUYAA7 CnKqxoFUBVUYAAwAK56a/u9cvGtNKZo7KNilxeqcZOPup6/UfmBjIBPe6nc3d4+maRgzLxPdMMpA Of8Avpsjp/gcXNK0m30m38uHc8jf6yeTl5OSeT36n8/c1PZWNvp1sLe1jCRjn3J9T+n5CnXN1BZw NNcSrHGvUn+nqaAHyyxwRNLK4SNRlmPQCsCX7V4l/dwSPbaTnEjlcPOQRwvovUZ/nzU0Nvc63IJ7 9HgsVOYrQnDMQeGk/LIGcdOuAa21VUUKoCqBgADAAoAjtraGzgWC3jEca5wo9+apX+pvFcLZWURn vHGcfwxj+8x/H/PGY7y9uLqdrHTNvmDiWc/di9vc/wCfUi3YadBp8TLEMyOcySMPmc8nJ/M/mfU0 AQaXpIsme4uJBcX0ufMnK44znao7D/PoBpUVi3F/c6jctZ6WF8tCBPdt91O+F/vNjt+fBGQB9/q7 i5Nhp0QuL09cnCRj1Y/5/PipdM0hbFmuJpTc3sgxJcOMHHoo7DgfkPQYs2NjBp9uIoQx7u7nLOfV j3P8ugwBVmgAqjqOpJYqiKhmupTiGBDy5+vYepNJqOpCz2QQx+fezf6mAHGfUk9lHc0zTdLNo8l1 cy+ffTf6yU9AP7qjsB+v5AABYadLHO17fSLPeuCAwHyxL/dT29T1PGa0WZUUsxwBTZZo4IjJK6og 6sxxWQkc+szCaU7NO/gQE5lHqfY+vcdOCSQAYza5LtjJi05GBL95/Ye3v+XPK6wENrbgAJDBEmAB hVRQPyAApJJIbS3MjlY4Y15PQAVixibxFK0jSPFpaSYRF4NxjvnqBnHT07HmgBXkn8QlooDJb6aD iSRk2tP6quTkD1JHt1zjaggitYEggjWOJBhUUYAp0caRRrHGipGgCqqjAUDoAKdQAVi6hqVxcXD6 bpIDXO355z9yH6nnnrjj+RFLfX095dNpumsRIpAnuB0iHt79R9fxK6NnZwWMAhgTaucse7HuSe5o Ai0zTIdMt9iEyStzJMwG5zyefzP5nuSTdorntf1S6klGi6OA+oTL+8kDYFsh/iJHIPPH/wBcZAKm rTP4n1R9Bs5tlnbsDqEqgkn0jB7E+vqp9MF91qc0s3/CP+G4k3wqI57g5EdsvIwD3bg/j68lcmwU XEB0DwrcqsMRzf6iqnlzkHHPOSp+6fbIHNdPZf2R4e+yaPDIscs7HYh+aSVsElmx7KeTxxjsKAJt E0W30Sy8iFmkkdt80znLSP3J/wAP5nJOlWVrmvWuhWvmSh5p3B8i2iGXlI7Af1/+tXI/8Jhqu+GI zQkyTF5ZY4crGoGREmT854PPfJPygZAB6HVDVtYtNHthLdSAFjhEzyx/w9/6kCuSg1jUL3Uhqlws ptYyy2dlC5DTTEdMAcqFJJY8c/gM27u7jULyPypzPqJJ86YBfLiUbgVT05+UZJGMnkyCgDsdE8QD UElF0Y4p1DSmNQw8mPjAkJ4DYOcemDgVnXmu3+tTpYaErQCU5+1SDB8sHDMqnnAyME9Tx6kZg0+C OxVtsjW0zLshDMW1Cfu7njMQzwDgMST1YZW4uftUb2NmTHDNuFzdI4UTsoO4K2B8i85Ixn0CnNAG /Z+I4Z9Yt9GsRJeeWh8+5kYDCqMbunzZbA7DnIyK1YNUsrm/msYZxJcQjMiqCQvsW6Z9s5rh4hO9 slloivAlyC7XKbUefk4YH+GMfw9N3P8AtEyxywabZzQ6bLJbaZA2Lm/VQHupB0ih9ADkZx6nOcsQ Df13xdYaITFte4uc4EUYPLf3d2MZ5HHXkVjXYu/EEqfb8i3PMdhE+4T8A8sOgHALHAx0xu4zYoYb S/VpLeM6i33LUfM1srAlEBOSZW6sx5APYbcb03mxziwV1N3LHvvLp3Gy2iGMKAeBkH7vvzwc0AA0 2O6QXepTQpZQk/cbCFQoGxR/c64PBI7ANWV4t1PUJUtAYLJXmcGG0vXIWFAcmeZRgkcEbc8Z53HK jUivLWSxOsaohh0e3w9lFKCWkOM+ay9WYnOM/XHQnkpbm/16++26nG0UEso+xwAAyGPPVgDnJyCB 1JYDgDgAm1nWbm8866snaLagE9+0ZLEnjZCpzsB6dyenJyTBomnSadYiadJYfOcCKFMmWXHTYOwP QN1wM4bPHSaZFb2+y1s4/tOo5yI2QeXbKTy3YE9Pm5BP3ffpdO0aKzc3U5+0Xz8tO/JXjovoP1Pe gDL0zwysssd7qkCqyYMVmrZSPA43f3m69yPqea6bAzmlooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACikN GR0oATPYntSHJ5B9qUnHr+RoznufyoAbuI68UuTkH1o+nB9cYoJAxluPWgAYHHHrS574PvxSYOOW Bx7d6UhgeB+tAAOvUYoPA9aBu79aX+VAADnqKWm5xkE0uee2PrQAtFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFUtR1GPT4l43zyHbFEOrmm6nqS2CIiRtPdTHbDCnVz/QDrk+hqLT dJe2nN7ezm4vnXDN/CnqF/x/QUAJp+mSm4/tDUtkl6RhVXlIVycBffnr/wDXJ1CQASTgDqTSO6xo zuwVFBLMxwAPU1jq02vPlS8OmqQQcYac9fqoBxx36HuKAA3UutTmC03JYLxLcg4Mn+ynHT/a/Lgg mS5u1sjHpelxRteMuUjJ+WJf7745A9PU8Ut5fiykg0zT4UkvJBlI84WNB1dj6fqatafYJYRON5ln lbfNMww0jevsOwHYUAFhYJZI5LtLcStvmmb70jf0A6AdAKtMwVSzEBQMkntTJ54rWB5p5AkaDLMe 1Y0cM/iBvNuleHTeDFCGw0uD94kHp6fmOxoAeWn118IXh0sEhmBw1xg4x6heDnuR9eNKSS206zZ3 KQ28QyT2H/1/5mkvLy10uzM1w6xQoAAAOvoAB1PsKzYLS61acXWpKEtl5htOfzfnk+2PbpncAIiT 6+yS3EUkGnqdyQtgNKezNg9PQfj1wV2kRY0VEUKigBVUYAHoKHdIo2kkZURQWZmOAAOpJrn2mm8T ForZmh0kHbJLghrgY6Kf7vT6/oQCSS7n125NrYM0enof392uQZP9mM+/94H9MbtOOO00fTlQFYba BAMk9AOPzpf9C0fT/wDlnbWsI+gHP6kk/Uk1lQ20uv3Ed7eo0dgnMFo4wXP99/w7f0zkASKCXxFN Hd3alNLU7obZh/r+OHcenPCn0rcnnitoHnmcJEg3Mx7Cm3V3BZWzT3EgSNepPc9gPUmsWK1n8QTC 6v42hsI3zBbHrJjGHb9ePpj1YAHE/iOR0BaHSANpOCHuD3Hsvb8x1+7vRxrFGsaDCqMAUqIsaKiK FRRhVUYAHoKo6hqa2ZWCJDNdyA7Ik5PTqfQUATXl9BYxhpSS7cRxoMvIfRR3NU7bT5bu5W+1NE81 DmGEHcIeeue56c//AFsLY6W63BvdRdLm9PCsF+WJc5wgPT69enpmtNmCqWYgADJJ7UABIUEkgAck msaS7l1mRrewk2WqnE1yOvTovGCen+eC4y3GsTMkDGLT1I3SFCGmPcL0wPf+fONaONIkCIoVR0Ao AjtraG0hEUCBUHPHc+p96kkkSKNpJGCooySe1QX1/b6fbNPcOFUDgd29hWTHZXGvtHcarB5NkpDR 2TDl/eTP57cfXuKADdc+IX/dyPBpfd1G15vYHPKnn5vyyeRtwQRW0CQwRrHEgwqqMAU8AKAAAAOA BS0AFZ19qTJKbKxVZr8rkKx+WP8A2nI6D26/mKj1LU5RP/Z2m7JNQZQx3crCuR8zenXIHfB69DZ0 7To9PhYBjJNId0szD5pG68+3PA7UAJp+mpYq7s5mupTumncfM5/oPQdBVi4uIrWEyzSKiDuTTLy8 gsLV7i4cKij8/YVnwWlxqUq3V+xW3zuitCmMehf/AA68nPXaABtvHPrcq3N0pjsFbMMJ4Mvozc9O vHf6fe1bi4itYHnncJEgyWNNvLyCwtmuLmRUjXuT1PoPesa2tZ9dnS+1KNo7RGzb2bjqR0d/X6f5 IAqWk+v3C3N8jRaejAw2rcGX/acent0P0+9v0UjMqIXdgqqMkk4AFAAzBVLMQABkk9qwri7udbla 00x2itVOJrzHX/ZT1P8Ah9N0gnl15mS3LxacrFXl6NMRkFV9AD1J9Meta0EEdtAkMKBY0GAP89aA I7Kxt9OtVtrWMJGvbOST6k9zViisbXtfi0eERxqs99IMxQbwuB3dyfuoACST6UAN8Q66NKiW2tlE 2pTq3kRdlwOXb0Ud/wD9ZHl17f3M8NzY6ZcMElZptQvSv+vI6k55Ea4xjqxPTnaYdW1uXUZLgef5 4uW2z3hDKrRg42LjGIgeexYgeozlRPc3twmnWCSq8+DiNRuY+hPYYzxwFyD24AO70jVv7H0aTSdF P2maNVmvNSf/AI94JGAG1c8k8Kqrj6jginR3Fv4LtpNZ1J3m1q+QrDFNJyqcEs/JxkgE45wAAM7s w2F19j06zFtapMUJWwtLd2Iu7gZDSlyc+WMFQTjIU9FJUc5qDRG/utRvJI7m+DM4mB4uZVAxt9YY 8EA4+YjkYNAF86hHdTS3N87vJKf3zht0jA/8sUA4JIOD0Cg4PQtW7Ha22kzg3JijnEW9rfO8WsXA Ccn77EjPrz0yGGT4d0pND0//AISzVwZb6RCunWk2V2DPMjZ5/wBr2HPUgCtcLd3tqby6ndY3k3gk MXuH4DT8gbIwG2qOnHAGWIAF1zxC85ntdLWNJXiZJJo/mWBAD+6jBxk7iNzdySBmpPDkdvY2Jn1O 9uDayNiVNxdrgjkAcnHGAx4GML3GMqw0W4e5hs7aBJbu4JICnhAADk9sLzzxlie2K177SpJLldGt JFkdflvL4ybFDDkxrxgKvVjyxPpgAgANeuvEGq3V9dSLaadCogVYnDOobpHER/y0bDAt6Z5wKv2c Qn2zOlu25vKtrBG+UlMnZ/sxpnLN0Y4PU84pjkvNltp7mHTbUEQ4I8yeRxywHIyRnLc7VzwcZrW0 i1+xQy2OnJHPcCPF3elvLigA6gkdAuB0POOPu5oA05pbQRmbVLsxWO8/apnYg3zjA8qNOvl5wG9c BccfLTkumkuBqEts1uLZNumaeMBIAAf30g44yOB1JQ9gSKNnZPqmotrNyz3Om2OGgeVAjM2NqgKO F+Y/L6ADpgA7vh61XXNSma4tQ0EQHmzImxHcEbYlU9EVRwB6jPYkAfZxvoWmDVZle41C5YrZxSfM dzn7x5HzNxnGM/KOtFvYRtHL/aEymzhcT6ldEYW6kByEA/uqcn3JJCjINUtW1/7brd1JZuTLEhit 2aQKsKDIeU4IPOdq455OeQKe3h6/bSEkB8u3km811mcKvQDzJAMZGBwg4GFGMFqAKskGqeIvEcV7 fW4TTU+aztGK4AVtuXxuAUAMTnrnAzg42Rpdtq15Fb6erBLRNr3ZQiMEkZVF4GQBjjpnn/asadp8 upn91Mw09sedc42vc44CqBjYoHGQOw6nkdTbW0Npbx29vGscUY2qi9AKAItP0+30y1W3t1OByzud zOe5Y9zVqiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEIz3xSFMnO4j2FOooAbsA6E59aCvvz9Kd RQBGIgOgX/vmlCHn5jT6KAGbD68fTml2nOc/rTqKAG4boSMUbfWnUUAN2L6UbF/uj8qdRQAAYooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACsvU9WNrNHZ2kRnvZfuoOijuzen5io9U1WZJx p2mRibUJB3Pywj+8/tz/APr6Gxpekw6YjlWaWeU7pZpOWY+mewz296AG6Vpf2IPcXDia/mH72YDj /dXPQD9etXbi4itYWmncJGvUn/PNMvr2DT7R7m4YhF7AZLHsAO5rPhsZtSuVvdQDLEufJsyBgDJ+ ZvUnjjt09aAGwwz63ItzdrssAQ8Nser9wz/4dKm1DUXgkWw0+IS3rKMKPuxLnG5vQfzxS6lqUsU8 VhYqsl/MNwDfdiTu7e3oO5NTabpyadbld5lnkO6adgA0jep/oO1AC2GnRWKu2TJcSkGaZvvOe3Po OgHb86ffXtvp9o9zcvtRRnjqx64HqeKj1PU4dMtxJIGeR8iKJFJaRvQYFULHTrq9uU1HWNpdcNBa gfLAfUnu3T6EZ9MADbe0utZmF1qSNFaqcx2bL193/wAOPfjIOnqOpW+l2pnuCxydqIgyzt6AetM1 TU4dMtw75eZzthgU/NK/ZR/j0HWqemaXLLdf2tqgBvnGFiBysC54Uevr9aACy06e7uhqOrKhlAxB bjO2AHkjrgnpz7dsgDWnuIrWB555FjijG5nY4AFMvLy3sLWS5upVihjGWZv0HuT0AHJrAis7jxRK t1qKNDpanMFmesv+25/oPwOOWAF8u58UTBpVkt9HQn902VecjufQenPHpuwV3J7i00uy8yVkgt4l CgAYAHQAAfkAKLu8ttNsXuJ2EcES88fkAP5AVh2Fre67dpqeqxiK0jbda2RAPbh29+/5dOcgDrO2 vdduxfakhhsEOba0Ocv6M/8Ah7+n3tbU9UttJtDcXLHHRUQZZz6Af5A71X1rXYNHiQFGnupTiG2j 5dz+GSB74qLTdJmkuV1PV9kl+VwiL9yAdcKMnn1Pt9SQCOwsbnVJV1HV0CjIa3tDnEXPDHIB3Y/r nqFXeorAu9QudWupNM0vKIp23F4f+WfqFHc4/wA9SACxe6rJJcnT9NAku8He5HyRDjJJ7nkcf/qN rT9OSxV2LGW4lOZZmHLn/D2p9hp9tp0HlW6YBOWY8sx9Se5qW5uIrSB55nCRoMlj2oAdLKkMbSSO ERRksT0rFUyeI/vK0Wlq3Gcq05HQ9iB0/L8mxRTeImS4uk8rTVO6GIH5puuGJ/u47d8ntgtvABVC qAABgAdqABVVFCqoVQMAAYAFZ+q6xb6VCN533D8RQLy0jdgB7niodW1r7FNHZ2kJuL+b/VxDoPdv b/PHFP03Sfs0hu7yT7RfPnMhJ2oD2UHp9ep+mAACLTtLuXuDf6u8c10f9VGo+SAe3v79ugJ5J2aQ nFAOenNAC1jXupTXlxJpukkGdRia4I+SDtwehf2/Oqlzq0+tXLadospWMf6++TBCD0Trk/5HqNmw sYNOthBbIQudzFurN3J96AE03TYNLtfJiLMzHfJK5y0jHqSaTUtTg02DfJueRiAkSDLOScAAf5/P iotU1VbBESNGmuZTsijUZyx6Z/z2J4AJEOm6ZJHN9v1FvNv3HrlYQey9OcdT9cYBoAbY6dc3NyL/ AFVg0qkGK3H3YvcjJye+MnHqSAav6jqNvpdm1zcMdo4VVGWdj0VQOpNV9V1SHTLXzZFeR3O2OBAS 0regH49f64qhpmmXM86arq77rvkxQAnZbA9sZ5bpz2Pr1oAfYadc6pcDUtZjUcZt7M5KxD1YHq31 H64C79QqcjOBn144qpqOr22l2puLiVcYO1QQS59B+n50AW7m6gs7dp7iQRxqMkn/ADyfasOJbjxM RLcRSW2lDmNC217jjgnHIXr9eo7Gks7C61W6j1HVi8arh4LPlQnTG/39vz9B0WfagBI40ijWONFR EAVVUYAA6ACnUVznivxfaeF7dA0ZuLuUExwK4U46biT0GcCgCz4j8QQ6DZbiUNxID5SucKP9pj6D P49PceRXl5dax50gmMdnI4+0TuMSXhHduCAi7CdnAIx1xlJDFqfivXJLjUCUB2yydkjh528Htz05 PHqQG3dQsbPSoI9SnyiLFt0+BgDyBn7RIOhbONq9OB2GQAcjdqlviGO2yqAJGhAJJXuQP94YHbjq eT09hato6yWbxzy6hdqvmwqr72yMiLjlQerN/dzggtTvDWjyW6Lqv2R57o/8eNq/BdweHduyhiPm 7knoFJOxZ6fJokr+fcpPr1ype4uNxKWsbHkgdSxOBxjkjGOAwBS1iQ6TZGATRS3903kXlxGMLEgH /HvCOwGOR/8AWAi8M6FBepLrWtCNbC1+8HyYyEAwoHdVwOeh6DIJpradf6l4hGlpF5NraRiSeWYg i2RhnOe8jDP69BgLuX+l3fiXTbWHTvLtNGglARZdw85AM+YehIHUDuc5PegCmsZ8VXs+taq7QaHb 5PlsGBeMDIUjsc4Jxz244zk3TXGqXCXaxRvcXJK2lupOI0HyhyADj0Ucc7iDkVr3CrqsEelWcch0 mEmO3XI3XsikZkP+wGPPbPpyVSVtO8FTyTuY7zXJkUQQrGQkGRgjIwMcYHAOMD5QTQBYupF8GaMb WzQSa1fcz3CKCImPAJGeFAyFHC/Kc478/Y2hu5rWz8jfbO5DRK3z3b9Tlsfd9fzz0IpalJdywHUL tpZGL7ykf+tnJ+ZVQjGQAQScjAYYxlQ294Ss7y/geGQhJDlLm8i/gTHEUWONx5yewxkcigDQg0KW /vYbKxmENlAjfabuAAEu2dyRnvwRzjA2jGOh0dTs7G40g2NsyWOkQSLvkUHE7AkFABy2O55yQBzg 0y71O2leXStPZLXTLID7VcJwOudiHuxP5nOffm5vEM0mp2llp9sglz5VrblSVgGM7j6sMZyfyzyo Bu3miTa5dWlisX2bT4HZ5Yg2SnTaWOeZDg+u0Hnk1s31xZ6BpaabZEQSvGywlQPk4/1jE8cdST1q lp9t/YuyMM13q92uHnbG2JBzjHZQc47k5qG/l0vTNTjl8uXUdZkXEdugBLPnO8gcLjP4AZ96AF0L QdN8P6Ut7fNg7g7ST8HcPlHAJz3wf9o++daKGXW51ubpHisY2DQQHgydDub29v6da9lpU9xdrqGu FJrgfNFbpkxQenX7zdOcADnr1reWTccAfrQBJ0ooozmgAooooAKKKKACiiigAopDnBwcGloAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKxtT1aX7Sum6Vsmv35Y5BWBc4Lt69+KTUNUlmujpmlgPdniSQ/dgHqfX0GO/Hri5pelW2kWx igGWY7pJWA3OfU4oAXS9Nj0222BjLO53TTsMNK/cn/CnajqMOmWpmlDueiRRjLyH0A/yPWm6lqUO m24kkVpJHO2KKMZaRvQf49KqWGn3EtyNR1MK10R+7iU5SEeg4BP1P+AAAlhZT3Vwuo6oF87rBBk7 YBj0P8XXnGfp0E+qajJb7LSxRZtRnH7qNj8qDu7+ij9TwKj1jVvsLR2lrELjUp/9RAGxx3Zj2Uc/ XHHs7StL/s1JXlka4vbht885HLHsB6KM4AoAl0vTU06Bhvaa4kbfPO45kb+g7AdgKj1XV1sdlvAo mv5gfJtweSfU+w/zxkirqWrzm5/s7SY/OvX6yEZjhGSCWPqMEY9ffirOl6RDpcbnzGnupTmW4lwW bnpn09qAItN0t0nGpaoyTagy4GB8sI/uqPxPPufU5n1bWINItlkkBklkbZDAn35X9FH8z2o1XVIN MgEkhLyucQxK4DSn0GT+J9qp6RpU4uW1XVSsuoSKNi9rdcfcX8zz1NADtK026kn/ALT1Yq963McY PywKf4QPX1P+RoahqNtpdobm8mEUY4BJGWY9APeoNX1i20ayNzc554SNMF5D6KP69B3rM0rTry/v RrGtKPMAItrTHywqe5B53EY689z2VAB1lZXutXUepasrQ26fNb2JwQMgjL+pwR/9YZzuXl7BY2z3 FxIEjX17n0HrUN7qNrp9o91dy7IUAyepJ7ADuTWLp1rPrl3Fq+pRFIE5tLOTHyH++fU8DH6AdwCS zsZ9cuo9U1aFo4YyTa2bE4X/AG3HQtg9/X859b1/7DMun6fH9q1aYfu4ACQg/vOR0H4j8BzVbUdd urq/bStCQTXiHbPcf8srf2Jx14P09yMVf0bRbfRrd1TMlxMd887cNK34knHJ4JPXJJJyQCPSPD6W U7397ILvVJeXuHA+TjG1PQfz9hwNlmCIWZgFAySewqGeeG1t3nmkWGJBlnY4AFYAW58TTAyq1vpE bnCH790Qe/8As+w//UALLNc+JphDYztDpA/1twgIac5IKocdOOT71v2trBZWywW8KxRKOFUVL8qq ABgAYAA4qC4uI7a3eaXiNBuY47f1NADri6jtYGmmcIijk4J/QVh2lvPr86ahfgx2C829qw+//tt9 fT+nUtbabXLhb69XZYr/AMe9u38f+03HT+f0+9vEj+9z7YoAdnA4x6dKxtT1ef7T/Zulqs2oMMnP CxL/AHiT2z9fpniq9/qNxqly+l6IwMmP393n5IV6cYOSeO3p1HJGrp2m22l25jt1O5jukkON0jdy x/p0HQADigBum6VDpoZ8ma6k/wBbcPjc3OcZ7AZPH48nJq8cYyRj601mXocfiaR3WJDJKQiKCSSR gD3NACsVRWZiqqBktnAA+tc3Ld3PiaZrXT5PK0tDia6HWUf3V+v8ufTKnzvFcu3MsWixt95W2tds Dgj1Cj+fuOOgjiSCJIoo0REG1EXgAelAEdtbQWNqlvaxCOGMYVV4GP6/U1S1LVGtmFrbQfaL2TPl wrzjgcsc8Dkcn/DMd/q8z3J0/S0Wa8P3nHKQjPVj0Hfj2OMkYqzp2nw6dG21hLcSndNO3WQ/rgDs P5kkkAj0/SzaObq7kM984+eUnhf9lc9B798fQB2qavBpUCtIrPNIdsMKjLyN2AH49f6nFQ6trcOm GOEB7i9n4ht0GS3ucdB/n6R6TozQXH9p6mfP1V0wzZykAPVU/ln+lABpWlTm6/tXU9smoOP3cecr br/dHv6+mSMnqdokgbj19RijGOv3vrzWRqmsm3mWw0+IXWoyg7Is/Inu5HQf54zQBJq2swaVGnme ZJPIQsVvGMu5J4wBzj3qtp2lTtcjU9YkSa+IBSLAKW3PQep7Z9upOSbOk6Mtg0l1cSi51CYky3Dd h/dX0H0xnH0A0iAOgagBvmY6HP05oE4z8obnuB3qO5uIbWFp7mWOGFeskrhFH4mvOvEPjC81PUF0 jQIpDJKxj8xVy7nnpz8i+p4PXO3jIB03ifxlbaLH9ltV+16vJ8kNtH821iDguB/LryOmc1y1p4Yv VW88QeIYmvr4tlbaUBlJOApIAwVBxwB0Xjjrr+GPA8nh64try4ljub2dWW4OB+6BBbahPUZ69z9A Qe0VSOTnP160Ac7o2kyzKt3qjblZhMEcFWLYPLjoAOy/wjjjkVwRlm8ZeKftF3HIYVZTBb5PKhuF wDkDnluMcngkV6drWmSaxp5s0upLRJXXznjX5nj/AIlB/hJ4559MHNSWuk2enSyy2VpFbyS4DGMd QAAAPTp/k0AZ80o8OaPcX0j+fd7dkScBFJwFjVRwFGAeOwPvXOxzSQaYL5t893M7LbeYQpupuQZS OgjUE4zgYPO3Jz2V/p1rqSRRXsAuEik81VkHyhgCOex4YjHI5rK1bw2NX1qG7urgfZI4PKa2HVvm JPOflByAcDOBjPoAVNDsjd2BgIc6aJC8lw5O6+lJJdz32bsYz2Hqcq3xpqd1FZWmk2ETtPfMyCOF cnylxuA7AcryeAM54rpgu1VRBEqqAFUdgPYfhXJeKvEotRJpunSM9+4Ku0XJTsVU/wB4kAen48gA yNR1ZPDdkWZopNWkTygITkQKBxEmM4PQFuerHknnmgsNpK97rDbr1ZBtt1YFw+OIu5BGVz/dGQTk g1raroUuk2tvc3N3G2tSSLK0a5LRIBuUgY+XDA9T1APbAND8A6ldar5l3A0MICN50rZwMZ+UHOXJ znPA79AKAG+H9AvNXu/7R1E4CZQYQYTP93Ixnn0PJOc8g9HrGqJp8A0fTmWxggj3XV0pDfZYzzwe pkYknnJJOe5I1tS1LStF0C4uYJ7fbCGit40bfmUDhAB15K55+pryuO3u9bmMkweKxWTfMinJaSTj HvK2OBzgYPY5ANC91SS/aDSNIjkhtUYCLBDGRs4PX7zcdf6AAdfoulR+HIFijVLjW503MD8yxKep J7KOMnPzHFR6Zp0fhe2eRo4/7VeLJGSYrGM4yXI6nPpkn6ZNX9O0K41kK7Ge20pzulMmBPfHqGbH 3V9PbPruoASOWe5nks9CYS3DNi71OUEKp46ep6YUcfTrW5pej22kQEQjzZ3H725kwXkP9B3x0/U1 qW9nBZW0VvbQrFDHwiIvC9ef16+9TiMZy3JoAqrAzcnhfyNTAYUgcevvU2B6UbRjGBigCNcgcgnH qOakHJzxS4HpRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRSE8d6AFNYOoajcX102laSf3w4uLjtbg8fifbIJxw RyVbf6jPqFy2laOwDji4uwMpbjHQcjLHpx6HkYJGpp2nw6ZaC3gDEZ3M7nLyN0yx7nAA+gA6CgBu l6Va6PaeRbL1O6SRvvSN3Yn/ADjtTNU1SLTYN2GlnfiGCMHfK3oPb1OOKZq2rrpqRokRuLuY4gt0 OC59z0ABPJ/LJ4qPTNKkguG1C/YT6jKMM4GFjX+6o9On+eoA3T9JlFz/AGnqbLNqBGF2/cgU/wAK j+vepdV1VrRktbWH7TqEwJhgzjj+8x7KP16Ck1XVjZeXbWyCfUJ8iCAdv9puRhR3/wA4NPsE0yOa 5uZhJdzANc3L8ZwPyCjsOKAF0rSjYCWaecz3853TTsP/AB1R2UdqzbnVLrW5nsNFIEIylxfkfKnH 8Azyeev/AOuklN14oby7WSW20lWIkn2kPOQR8qgj7vXnkcYweRW/a2lvZ2sdtbQiKKMbVUen17n6 5z3oAisNPttMtvItIiEzuc5yztjBJPc8D8vpTNS1SHTYUZ1d5JG2RQoCWkb0Ax09T/MkCo9W1aHS 41B/e3EpCwW4b5pGyB9cZIyf0J4qDS9KmjnbUtTcTajIOmMrAOyoO35+vJySQBNL02cS/wBpao4k 1B0GFCgLAP7q8n+fv71Nq+rQaXbLJJmWdztht0I3SsSBge2SBn3A5JAJrGsx6TCv7pprqU4gt1+9 IfwyQOnOD1A5JAqro+jT+edV1fZLqcgHyA5SAdlUdMjn1xkgE5ZmAIdL0aW5u01fWQHvsfuYRkJA O2F5APc5Jwe/TGxfXkOn2slzdOsUK9WPf0A9yeBU080cEMk0zhIkG5mZTwK521tG8TXCanqMTLpy c2dpIOHHaRx7jt6HHTOQAtLKXXbqHVdTiWO1Xm0tGbgDrvb3Ppj9OrLzVLjXbyXS9CZTGp23eoZy sQ/upg8kj09fxD5L248T3T2elzyQ6ahIub1AMy/7EZP45OOmD0wG3bDTbfS7GOzs41jgjHAA5Y+p 9T70AQ6VpNpotklpZJtRfvM2N0jf3mPc/p6YGKmu7yGxtmuJ5BHEvViep7Aep9qZqOoRabAkk7jL NtREXLSMT0FZ9npd1fXcepawAJF5t7RG+WIHuemWOeev1xxQBHFZT6/LHd6ipjsQd1vZkjLDsz46 k88Zxz+J31VVCqqqFHACjGBSnO7rnj86hup4rW3knnkWOFBlmPp6e+emKAEuruC0geaeUJGnU5/p 61kWltJr80d9exstinNvauPvHpvb/OD245Ztrby+IbiO/u0aLT4yfItm/wCWpz99vb27/T729I0c UTSPIsaKMszMFAHrzQA4nBO5sfQ8Vz095c69O9lpTNHaLlbi9Prx8qc8kjP8+ON0Ty3XiiRrezMl tpSNiW5A+aYg8qgPbgg+n1BWukgt4baBYIECRIMKo/z196AIbGwt9PtVt7WPy4hz05Zu5PvVg7sb QRn6U7bxx0/Kqt/fWul2b3V1MsUS92PJPoPU0ASXE0VpbyTzyqkaLlnc4ArnYoJ/FM3nXcUkOkId 0EW7a07f3mxyB14+lSW9nP4mkjvtQj8rTV+e2tT1l9Gk7dO39OvR4SOPGAiKv0CgfyFADNm0ABcY 6ADoPasa4vLnUJpLLSyoCHbcXZxtXI6Ljq2D6jGR04prXM2vzNb6eTFYK22e6xgvj+FP68Y/lW1b WkNhapb26COCMYVc5x75PJ78mgCGysYNPt1igBxnLuzZZz6k9/5enFUNX1oWciWNpGLnUpvligBy F4+8+B0GQfp+dRaxrc8d0NJ0iFbnU3ALdNtsp/if068D/wDUbujaFb6Ojvva4vJf9ddSD55Oc/lz QBDo+gJZM15estzqUuTJPtxtz/Cg7DGB746DpWwVCAnPHvRLLHBE0srqiKMlmOAK5qWS98Us0VnK 9ppH3XuNpV5/ULntjv09c8qACS61WfVZ307Q3DSLxPdnBSEHpj1J7Y646jO4amlaNaaRAUt0zI/+ slb779ep9OTgdBmrVraW9jbrb20SxRL0VR+vufepqAExxWP4j8RWXhywW4uyzM5KxRJndIQMnp2A /p61nXvi2S7upNO8OWpvrtSFadgRBFz1J7jjt+GelcudKvtf1Y27X39pXSNi5uwSLe3X+6mMbm6H AxyfYkAGTf3et+N9aNvaxvsBPlISQkS4+8fTv82STwAOw9F8M+D7Hwzb/uB5t24AluHABOB0HoPY Vp6Ro1notoILWP5mwZZW5eRvVj9SfpmtCgBm1vXH4k00rnjn+tS0mAOnfrQBFtGeAf1pmwNnAIHf FWMDPTmj8KAKzR9Pm6etRmPdx8p9yauY57CsXxBrDWCR2dmC9/ccIFAJRe7fXg465I6HGKAMXxX4 nOlY07TR5upSkIAg3FM9AF7scjA/yMawtF8MWb3lwYp9YAzJJI29LbPq2OWzn246HbiodFt5TDNq 8gNuhDM142dsSHjbGBy7tlueNoxjH8Wppemm4uVub9VttJsx5yxzAggdQ7seC7YyRjgYHHGACbwt 4almujr+softMnzQxSNu2jrvbqN3AwO2AepAXP8AFfj+BVex08GVQCDJkYbtxnqPyH6is/xX41l1 UCC2EkNg/wAohdcPcc/eOOdvTC9TyT0GaWm6FJBPAfMaTVJ9pjiUj9yCRnqOX2gDHAXacjAIABl2 9leX5D3c0y+SPnkOHSBOpWPOdznJOPXGT2rsbSOPRhExhP8AaDIUs7fJb7MSB1B5eVhySRnoOAAB Nd6QdNfTtK0yZJL8ZeSOIZKtxhzn05+Y85Oe4FdVoXhyDSR9omP2i/fl53JYjPULn1PJPU/TAABQ 0nwoGlW81f8AeyZ3i3Zty78D53/vNx05A7Z4I6qiuT8YrLqV1pugxSyRreOzyvG2CAuMAjIyvJOP 9gUAdZRXDeGtbvdH1NvDfiFtsu/bZXBHyyqfuqT0ycYHrgg/N97uaACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiikJwMk8UALWDe3s+qXjaXpj4VR/pN2pyIh/dHqx/z6VHe3Fxr076dpzNFaA7bq82/mig9SeM /X8Ds2FhbabarbWsQSMcn1Y9yT3J9aAG6dpttpdmttbJhRyzty0jYwWY9ycdar6rqjWZW2tIftOo Sg+VDnAH+0x7Lx+P8odS1aX7UdL0tUl1Erli3KW4/vPjvzkDv+IzY0vSI9OEkjSNcXcxzNcSAbn/ ACHA9qAI9J0g2bNdXki3OpSgebcFcf8AAV9F9qXVdUNkUt7WE3OoTD91Avp/eY9lHrSavrP2B47S 1iNzqU4/dQL2H99/Rffv+ZFZEtPDVnLqOp3BmvZv9bMR80hAztQdhgdOBxk9OAB9pa2+g2k19qV1 5l1Llp7mQ9e+1R2UdgPSq0Ntc+JZBc3qyQaUGDR2brgz46NJ7f7J6/gCZbPTbrVLoajrClQrZtrP Pyxr6uO7Hg+36DfoAakaRRLHGoREACqowAB0AFZusavHpqCNImuLyXiK3Q4Lnpyew9/50mr6x9he OztI/tGoz/6qEdFH95vQcH64PTBITSdG+ws1zdTG6v5Pvzvyep4HoOT0x+A4oAj0fR5YJDqOpSC4 1KVcM2MLEP7qDnAHTr/Mkv1nWYtLjWNYvtF5L/qbZOrHpk4zge/5A03XNdXS/KtbeL7TqVxxBbr3 5xub0XP9ewJEeiaB9jmbU78ibVpxmWXJITj7q9uOmQBxQAzQtClhf+09WIn1WXBJPKw8Y2p2HGen qRk8k756dBnHSlOccdawNa1OV5JLCxlSEou+7u3OFt4++D/f9B/kADdQuLfUNRNq7KLGy/e3ryjC E4+VMng+/bBI71QP23xfchIxJa+HkPzMcq957eqr/nrkLFpmlHXEjRYXtNAiO5Itx33ZODuYjkD/ APUOldnHGkMaRxoqRoAqqowFA6AD0oAbBbxWsCQQRrHEg2qq9AKz9X1qLSlVBHJcXcn+qt4xlm9z xwPf8snim6prJtJlsrKH7XqEnIhDcIvTc3oP5+wyQaRoi2LveXUpudRm5lnY5x7L6CgCHTNFk+0f 2lqxE+oH7i5JS3HHCA8A8ckf/XrbxS1HcTxWsDzzuEjQZZjQBHczwWsEk9xKI4kGWZu3/wCusOC1 k8Szrd3kZTTI2Jt4Dx53o7AjoRnj+nUht5PE8qXd4jJpSHdb27Afv/8AbYenXHr9OW3L6+g06zku rl9kSDJNADrm4itLd555FSNByx/zyfaucSC78WOs1xvttGzujiBw9wOzEj7o75H4HuZLawuvEM0d 9q8RislO+3sWPX0Z/wAOx9cEDkHpaAGRxJFEkUSKiIoVVUYCgdAB6U7H5UtU9S1S10q28+5cgE7U VRlnb0AoANT1K10mxe7u5Nka+gyWPYAeprItNKudXuo9T1hcIPmt7Bh8sXu3q3sRwefQCXT9LuL2 6TVtZX9/w0FoSClt6fV/ftn6Y25ZY4YzJI4RB1JNAA8ixxl3dQoHJPArAUz+JJgVd4tHU53ocG5I 7Ag/d9/y55CoJPEsnmNvj0pW+VSuDOQff+H+fbua3v3cMX8McaL9AoH8hQARRRQRLFDGscaDCqgw APYVz+oatc39zJpeiOHuV4mugAY7fnp3y3t/9fDZry+8RzNbaXKbXTlYrNfL99+Puxgjjt83+Tt6 fp9rpdmlraRCOJOgHegCLSdJh0m08qMmSVzummflpW7kk81PfX1tp1o9zdSrHEgySTiq2razb6VE u8NJPJxFDGNzMfoOfy59KqWGjzXNyupayRJc5DQ25AKW/p06sPXt2zjcQCvHp934imW41aN7ewXP lWW4gye8n5Zx15wcchujVVRQqgKoGAAMAClrG1rxDFpbJawRNealKMxWkf3j7n0HH+cHABpXd5b2 Fs1xdTJFCvVmOPw9z7d65S4lu/FsMjmY6b4fVf3kjjbJNg5PXgLgY5yPr0WU6KHA1jxZeJKYv3i2 x4gg74xzuPT64HXrQLe88XTB5/Os9EjbiDG1roe5zwvT+h70AVYrdtdi/srQw2n6ChxcXUfElwe4 UnnJ4yx5Oee4PXWGn2umWaWlnCsUKDhV/mT3PuamiijghSKJAkaDCqOgFPoAKKKKACiiigAooooA KqTrZWby6nOsUbrHtedhyFznGfrj68e1W65PUdStdQmubu7kA0LTD+8IJxcy9AvowBOMdyR1zQBT vLtr9k1bUkWG1GTp9vcsAh4z50g7KBg/j34ride8RzXtvDHGCLBWaRSy5e6kHHmuB0yc4XqBj2p2 va5eazOtxcRLFFKwWGDOX6fKG4+77Y5Jz6Z6HwR4Xs4dVXUNRCvfOpmt7Yjd5S5G1264boR0xnpn FAFzwV4KktzHq+uRB74/NDC4yIR6n/a9u316XUigh1W6tNAH2jVJH/0u+lO77OrHJXd6+3XgZzji 7dalc6/cS6dozbLVflub/sM9Vj9Wwevp0PQ1uWFjBp1mltbqQi9WPVj3Y+5oAg0nR7bR4GWEF5pC DNO/35COmT6DsO351oUUUAFcF4n1F7fxHdtagi6i08RowBJBLZJGOc7WYj3XvXe15des194x16SJ 5FaGJsMMgR+WvPQ8/d/8eHvQB0dzoqeKvC8KXgiXU0iwrlidrH15zg475wRkcimeEvEk7y/2Brav DqsGURpf+W4Az17sByfUfMOtS+BYvM8P6fd+bJkLPGUJwG/enkjuRs4/3jUnjPww+uWiXNi3lanb 4McitsZwDnbu7EHBB7H0yTQB1FFc34P8RNr+mH7TtW/gbZOqDCt6OPY46diCK6SgAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKbJIkUbSOwVFGST2oAVmVFLsQqqMkk4AFczLd3fiW4Ntpk8trYRPie7UYZ+Pup79O319C5mu PFM+yMvBoiEF5OVe7OAcL6J6nv0HPToooo4IlihjSONBhURcAD2AoAZaWkFjax21tGI4YxhVHP6n knuSeTWZdajPe3h07Smw6nFxdbcrCPQZ4Zuox2wc9Khe7m8QymDT5PL0wHEt2jEGXnlY8dv9r347 E7NpaQWNulvbRLHEgwFUUAQ6bpkGl23lQgljzJIxJaRu5JPOT1/E1X1LVmgnSwsUW41GUZWMtgRr kAu57KMj3PApuo6pIl0um6eqy38i5OT8sC/32/w/yazfZfDNoSqPeajcE5xzLcPj8wvHbOB60ABN v4YsHubp3u7+5fDOEJeeQ9FAAOF7AdBxTtO0q4ubpNU1ja90OYYB9yAdfxb3/wAM1LpmkyC6Op6m RLqDDCjgrAvPCehweTz1PPJJ2KACsXUdYke5bTNJCzX/AEkcg7IBjqx6Z9v/AKwZuoX9zf3h0rSX 2sP+Pq6HSBfRfVzz9P5X9M0u10m1FvbKQP4mb7zfWgCHStDtdJMskZeW4mYtLPKcuxPv/noPQVX1 zXhp5Wyso/tWqz8QwKC23P8AE+Oi/UjPqACQavq86XA0zSkSbUZFJOWG2AY+835j/JAabR9Di0zf PLI1xfzD99cv1PTIHoOB+Q9BgAi0PQ20/fd30/2rUpstLMei5xlV9uB2HQcAAAbVFYes60YGazs3 UT7SZZ2xttk7uc8cent+FAEeu628DvYWDqlyE3zXDjMdqnHzN6nnheprJ0XRhrH7yWOVNIVgyLIC sl4/ILydyOmB7/XJo2jjWQTPHIujo5ZI5QRJdSZyZHPpnOB24HrXbAAAADAHQCgBFUKoVQAAMADt WJqGqzXFy2maQQ910lm/hg6Z5xgnnpRd38+qXLafpUgCKdt1dqeIx3VD/f8Aft/LSsNPt9NtVt7V NqDk5OSx9TQBFpOkw6VbsiM0s0jbpp35eRvUmr9FV729t9PtWuLmVY417k4yfQUAPubqCzt3nuJV jiQZLMaw4bG51y6F3qYkjs0OYLM8B/8AacdT24Pvxjq+0sLnVbmPUdVVohGwa3tM/KvcFh65wex4 GfQaGqarb6VAHmO6VztihXlpG4GAByeSOg7juQKAJNQ1CHTrYzSkk9ERfvOegAH1I/Osux0y51C8 Gp6zGA6kG2tN+5Ycdz2Lfn0B9As+nadO866nqRBvWUbYwBtgHPA684Jzyep69Tr0AFFFZmq6sLAx 20Ef2i/n4hgX/wBCb0UetADtX1iDSYV3Ay3Mp2wW6H55WPp7ep/mcA1tO0mWS4/tLVj5l62CkW7K W4/ugdCfU+oGPUu0jRns5ZL2+nN1qM3DyngKvZVGBxWpPPFa28k8zqkUalmZjgAUALNNHbwvLM4S NBlmPQVjJDPrswnuN0WmqQYoujTe7f7Pt3+n3nxWs2rXAudQh8u2jIMFuc/Mf7zA/oOPer+oahba ZaNc3UgRBwBkZY+g96AH3Nzb2Fo89xIkMEQ5Y8AD0/8ArVgxx3fikia4EtppAIKW5XD3A9WPZTxx +Oc4xPb6dc6vMt5rMarEpDQWWQyrwQS+Ryef89K3qAGxxxwxrHEioijCqowAPYVl6nrP2eUWVjH9 q1BukK87Bxy3oOR1x1HqMsv9Qubi5bTtK2m4APmzOCUiHP65BHfkEdjts6VpFvpMLrGWkmlO6aZ+ WkPufxP5k8kkkAi0rSPsjteXkguNRlA8ybsvH3V9B/P2GANWkd1jRndgqKMszHAA9TXJtqd14tuX s9JZ4NKQlbm+wQZD/dj/AMfz44YAs6lr9xc3r6ToCpNegfvbhhuit/r6nr+I78iltbPS/B9jLe3l y0lzL/rbmZt0kp7KP8+5qa4udL8HaPFDFESSdkEEa7pJ3+gGT27ccAdhUGmaHcXl+NZ13ZJddbe2 2/JbDqOv8Xf2NAEVppV34huU1LXY2it1ObbTySAB2aT1J/ukexHaupAAAAGAOgoooAKKKKACiiig AooooAKKKQkKpZiAAMkntQBn6/PcW2g3s1qP3yRkg91H8RHuBkj6V5Bf30+rWtpbJE8elQAR2lpy WuJSOWJPfk+oAPHc103ivWzrlwdPjk8vTlOGDDBuG6j6jjAHQlgT7ZCs9vclbJzLqDqAZYkDCziJ ztjzjMpJPPABJ5GAFALNpokdrMsUkyy38KF7guxNvZKfu7yfvOTnCDOSDkYznpNN019Zt5bePz49 Hm5nupSBPet6cDAT145B9SSE8N+DhHYWw1DP2eNjKloR99jzvlJGWbqMHoMD1FdrQBFbW0NpbpBb xrHEgwqj/PX3qWiigAooooAK4LwvYfa/FHiG4bZ5bPLHuVich3P4Hhc/jXe1yngOEjTLy5dWEk92 7Hcc8DH9SaAIfhq7HwzJGwGIrp1U4HQhX7e7Guxrj/BH+jXviDTQhUQ3plBPUhsqP0jB/GuwoA4X xRplxoerReJtJRQd5F3EOA24AEntg4XOe4U4NdRoGojVdFguxuO7cmW6ttYruI7E4zjtnFaEkaSx tHIiujgqysMgg9QRUVnZwWFqltbIViTO0Fix5OepJPegCeiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiio7ieK1geeeRY4kG5mY8A UALNNHbwvNM6pGgyzMeAK59UuPE8oeQyQaOrZCAbWuSD3Ofucfjn2yXwRt4lZLu5jK6Up3QQOObj j77DP3euB3+nXbuLiGztnnncRwxrlmPYf57UAKzRW0BZikUMS5JOFVFA/IACsVvtHiGV0+eDRwCp 7Pcn+ifz6dKcILjX3SW58y301TlLf7rz8/ek9F6YX3yewG2AqKFUBVAwAOABQA2OJIYljiQIijCq owAKyrzUbm6uZNO0rb5yDE1ywysGRxx/E3t09agnv7jXd9ppEpjtslJr9T93jpH6k/3geB06g1JJ PbaDbQaVp0O+6ZcQxKuef779OO5/zgAYv2Xw5ClnZxG61C5bcwLDzJm5Jdz19f8A6wBIuaZpf2V3 urpxPfyj95Lj7o/ur7fz+gAC6Xpf2EPPPIZ72bmWYn9B6D8ug6AADRoAKwrnUZ9UvH07SnKohxc3 eDhAc/Kh6FuOT26dclW3M0niFns7CbZYqds9wucv/sqfT1PcH0Izs2trDZWqW8CBIoxgAUANsrG3 0+2EFtGEQcn1Y+p9TWTqWq3V1dnS9GAafpPck/LAM4OPVuv0I9iKr3OrXOuXTafou9bdW2XN8PlV RzkIep6dR68EfeG1pmmWuk2SWtom1F5J4y59TjvwPYYAGAAKAItH0eDR7UxxsZZnO6ad/vyt6n9f zJOSSTo0Vz2qaw06XEFjOIIYB/pV8w+WIdcL/eOO3uPqAB2r62waa1sZ4Y/IUtdXT8rbj6d2z27k Y9cUtK0ZdTiSadGTTs744mGJLk54klOBzxkDHGRTdH0gagYZGtTb6RC3mW8En3p26b5B6+noMACu tJCqSSAAMkntQAAAAAAADoBWJdzza3ObLT5iloh/0m6Q9f8ApmhHf1I6D60ya4m8QytbWMhj0wcT XaHmX/ZjPp/tfX8dq2torSBYYVCov6+5oAS1tYLK3WC3jWONeiipqKpajqcOnRAuGklc4jhQZZz7 D+tAD77ULfT4DLO4HGQuQC3IHGfqKo2dhNe3K6jqcYDqd0FvnIi9CfVv5fUDEthYzvN9v1Ehrphh Ih92FfT3bnk/gO5LtU1M2SCG3QT30vEMGeT7n26/l1HJAAup6tDpqIpVpbiQ4igT7znp+A96h03S 5Y7hr/UJfPvX6D+GEf3V/UZ9PxJfpultDI17elZb+XlmByEHOFX6AkZwM/pWnQAUUVhX2p3F9dNp mjOvnr/x8XJXKQD+reg9j6HABNqerSRzjT9ORZ9QcE4P3Yhxyx/Ece49RUmlaQLAvc3Epub+b/W3 DDn/AHV9F4HHsPbD9J0e20i3ZIVDSyHdNMR80h5PPtycD3PUkkzX9/Fp8IeQM7udscaDLO3oBQBJ dXUNlA0077UHHuT2AHc1nW1rPqcy3mox7IVbdb2jfw+jv/teg7fXpJaWMs8yX2ogG4A/dwZBWDPP 4t0y3tx3JsahqVvpsStOx3udscaglnb0AHPcfnQAmp6jFplp50is7MdscaAku3YCs3TtJuLm7XVN aKyXS/6iEH5IBweB/ez356D0GJtP0t5bw6rqcMf25wPLjB3i3X+6D6+pHGenU52KACsO9vp9RvP7 N012UD/j4uUIwg9AfXn9COOSEuLu51mc2mmS+XbIStxdj6D5U9znr6c8ZXdqWFhb6baJbW0YSNfz Y+p9TQAlhp9vptqILdMLnczH7zt6k+vA+gAAwABUl3dwWNrJc3MgjhjG5mPb/E+3eq+q6rb6RZNc XBJJ+WONeWkbsqj1rFt9Fu9duo9R15SkSHdDp2cqnoX5wx/ycDigBiwXfi90muTJa6Ir7kt/uyXG MEFiP4c9MHt9CL2qavb6HFb6bp1qkt9NlbaziAUepJx0Hf8A+tkiLWtfmF2NH0RFudVfG/8AuWyd 3Y4xkenuODkBrWhaBFo6PLJK91fzcz3Uhyzn0HoPagCHR/Dn2S9bVNRnN5qki4Mh+7GO4QenXn06 Yyc71FFABRRRQAUUUUAFFFFABRRRQAVheJWvJIY7O2VY4JVd7m4kOEjjUDIY9s5/IHgjONe5uoLO 3e4uJVjiQZZj/nn6V5xrOpal4z1BdLsIJUss5ZS20MAy/M57Ac/Lz1BGSOADMW1e9vJW0a3vDbKu FlKNuxk/NwOCTyP4ueOma7Xwr4XGnAXd1CEl/wCWURIYp7sRxu/l69AN/TNOh0uzW3hVQc7pGAI3 t3PJJ/U4AA7VcoAKKKKACiiigAooooACMjB6VDa2sNlbrb26bIlyQuSepyevuamooA5DTX8n4mav Am4LNarIwyMZXZ2/4GfzNdfXEak0kHxX0ho9oSe2ZZB64WXn8wn5V2wYEdge9AC0UhOKWgAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiigHIoAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooqtfX9tptq9xdSqkajPJ5PsPU0ALe3ttp9s1zdzLFCvVmrGgtrnxBcJe3oaHTVO6C0YENIecNJ7 YP3e/fjgy2dlcarML/VoAiKc21m3Pljs7jpu9u314GhqOpQabCHky0j8RQry0jegH9e1AEl5eQ2F s087EKOAAMlj2AHc1n21pc6nNHfakhijRt1vZ9dnoznu3t0HTrkl1np81zcrqOqKpuFJ8mANlIF7 fVvU/lVu/wBRt9OiVpmJdztjiQZeRvRR36j6UAS3V1BZW0lzcyrFDGMs7dBWMouPEbB90ltpanhR w9zx1z2Tpjrn27Pg0u51K4S81kKNhDQ2anckX+8f4m9/b3xVnU9TNvKlnaJ519KPlQdEXpvb0FAE V9dppscWl6ZADdOoEcUeB5Skkbz7Zz9TVjTNLSwM0rO0tzO2+SRjn8B7f5+jtN0yOwEkhYy3U2Gm mbq5/oParkkscMTSyuqRqMszHAA9SaAFZlRGd2CqoyWJwAK52aWXxQz21s0kOlAgTSlSrT9cquR9 3pn1+nDRkTeLJgcvDokbdCMNdMD3HZQR0/Pn7u7cXNnpNiZZmSC3jGBx+gHc+1AD0S206xCLsgto E6scKqjuSf51zLz33jBmitDJZ6KG2yzMuHuQDyF/2eMfjg55UJBDdeMJku7sT2ujoQ8EAODccghm 7447cc8E/ePWIiRxqiKFRQAqqMAAdhQBHaWkFjax21tGI4YxhVHP4knkk9STyTzUrMFUsxAUDJJP AFNmmit4WlmkWONRlmY4ArmPPuPE0jySbrPQoSSzudrXG0889l459PqfkAHahqEmtGe2tpTa6TCr fbL8sBwOqp+Gck/4BoNO0qPWzGWtXtdEtmJt7U8NcP8A89JD1I645yTkk9qLK1XxH5KW8TWvh22I EMYXYbgjv67evXnv97letREjjVI1VUUBVVRgADsKAF+VFwMKqj6ACuekeXxNK8EEhi0mNtssi/en IP3VOeFx3/yG3Vy/iS8fTbGQrp8RIu7lG+8ePkQg/XJ9vz37a2hs7WK2t0EcMShEUdgOlADoYYre FYoY1jjXgKowBT6KxdV1mSOcadpiJcak4J2Z4iX+8344/P6AgFjU9VFmyW1vGbi+l4jhXGf948jA /H+pDNP0l47k39/KLi9b7px8sQxjCj8+ev65fpOlLp6GWaTzr2QfvZmJOe+BnoP54pmrao9sVs7F BNqEo+ROoT/ab0FAC6trAsdltbKs+oTcQwZ6n1Pt/ngAkO0rSzZB7i5kM99NzLMf/QR6Dp2GcduA DStIXTw80shnvJSWlnYc84+Uei8dK0qACkd1jRndgqKMsxOAB61HcXENpbvPcSLHEgyzN0Fc6Rde KJVL+ZbaKCHXBAa69O/C988dsc8qASPf3HiKZrXTJWhsEYrPeLwW4Hypx7/pz2DbVjYW2m2iW1rG EjX06k+pqaKKOCJYoY0jjUYVEGAB7AVn6jqbRTCysYxcXzAHYGAEan+JvQf59AQCXUNSjsykMY82 8l4igXqx9T6D39jTbLTmjmN5eOs164wWA+WNf7qe3qep9uACw0uKxd7iRzNdygCSd+p9h6D2/PNQ 6vrP2Jls7NFuNSmH7mDP6t6CgCbVdXh0uJQymW4k4hgTlpD9PT3qDTdJkS7bUtRk86/cYABykAx9 1B/X/EkrpeipZyG9u3W51KT/AFlyRjH+yo7AdK1JJEijaSR1SNASzMcBQOpJoAdXNz3U/iS6eysJ PL0+JsXFyOrn+6vbBBzn6EjBAZk1zdeJ5vs1kWh0kMVuLgghpcHBRR6dc/r3U9DbW8NnbJBAgjiQ cD+ZJPU55JPJ60ALbW0NnbpbwIEiQYAzn8STySepJ5JrK1rxFBpbraQqbnUZf9VbJyfqcdB/npkj Pv8AxFealejTfDSrMwP7++IzFD7A9Cfz9gecaejaDa6LG8u8zXcgzPdSn5nPcn06UAVNJ0Cdr8az rUiz6iQfLRQNkAPRR7jpn3PU81BqOuXerX0mjeHmHmpxc35XdHAPQEdW/wD1epWC61G88WXMmnaQ zQ6Yjbbq+wRv6HbGe/GfwIOQMbul03TbXSbJLSziEcS8+7HuSe5oAg0bQ7PQ7QwWqHc3MkrHLSH1 J/z1PcmtKjNFABRSUHPagBaM4pKPwoAWik5z0poB7j8aAHFgOpxSFqT5geKjkbaGZiFVcksTwB1o AcZMHGQPrXI3ni4LJ9ujmWLSINwDYG++kHG2PP8ABknLDuBiqGveKorxzZ2zF7fBLRqwVrkAZILE fJH1yxxwOOtZOj+H7nxjdx3l+cadEoVNilI9vaOJemztu64AoAda3l5451xUff8AZI2VpNrAx26c 9M4O44IyRzweQDXpdnb29haRW1tGkcMahUUEnA989T7nrUdrYRWFv5NrGkMXUhRjJ9T78VMFcDng d+f/AK/FAE4bI6U6q5JDd/c/1pw5AwRz2J/woAmz7UgIPSmZ9waUPnrigB9FMB68nrSE89enfHFA ElGaYQCOg59qdjHagAyKaTzzj86djFIRnjNAHFeMUMHiXwxdoyrJ9rEOd2GIZ0U49eGb867MAgfM a4j4nxSjQrSaEnzYrnKN3B2Mev8AwGu2ikE0ayxkFHAZT6g8igB/IHqfal59aMe9AFAB0HJoGaWi gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoorP1b VotKtw7I8s0jBIoYxlnY9MCgB2qapBpVsJZdzO52xxICWdj0AA98fn6kCqNlpU95eJqmsJGbhcGC 3A3Lb/j3b37ZPXg0mkaTcPcrrGsBTqTLiOJW3Jaqf4V7FsHBYfQdyyXWsT311Lp2jDdKnEt2RlIv Yep/T/ewQAC1qWsLbSfY7RRcai/CQjOEz0LkdB+p+gJDdM0l4Jzf38v2jUXXaXP3Yx/dQfwj/PPU zaZo9tpUZEW95W5klkcszknJPJ7nr+FU7zWJrm9bTNHAkuF4muDgxwex9W9sY/HigCfVNajsZY7O 3T7RqExxHAvUf7Teg6/l9SGaXozQ3H9o6lItzqbqAXA+WLrwg7Dk/r6nM+maVb6XESo825cZmuGH zyHuSf6ZqHVtXa1ljsbPbLqE+AkeM7B/eYDt/noDQAmr6u9vIthYBZdRl+6vURg/xNjp3xnHQ+lT 6TpKaZEzM3m3Up3TTEcsT/So9H0kaXE8sz/aL6fDXFwRyx9B7DtVq8v4LC1kurqRYoYxlmJ/QDqS egA5J4FAEtzdQWdtJcXEqxwxjLMe1c8sVx4puI5rmOa10qFtyQlsNcH1bHb2/r91lrDceJZYtR1F Gg05fmtrQvgv6M+Ov8uwyOWt634hh0aNLaNBNfSL/o9pGOW64yBnA4PucHHQ4ALurazp/h+yEt06 xoFxHEuASB6DgYHHtyPUVhWWjah4g1FdT8QAx2qHNvppHyjjgv69+DyfYfLUujeHrh7wa1r0nn6k +GWE4Mdt3AUeo9jjIzycselL46jj68/yoAk4Ax29qq32o2+nWr3N0/lxp69SewHqap6xrdrotoJr nczscRxIMtI3oP8AH+pAOVZaTcaxcpqeuxjj5rawK7liU93GOW6HB6EZPOAoBHHa3Hit0vtQ3Wuj p80FrypmH99z2H4fQ45ZHL+MLo28LGLw/bsA5T5WuHGCFH+wOPT9Bl+oySeJ72XR7V3FhA4W/uFb G8gjMSn+fvx610FvBHa28cFtEscMahFQdAP8/nQBYTZFGqIoRFGFUcADtisG/wBQn1bUJNH02V4f Kw13dYGEXP3F/wBo/wBKdqeoTSXi6Pp7YvpFDSOBkW8fOWPI59P/ANVX9P0630yxjtLdcquSzY5d j1Yn1JzzQBYtLa3sbVLa3QLGgwMdfr9aseYPUE+1QE4yR6etc7eXl7r11LpmmXHk2iEpc3gwe3Kr xjPt/IdQCe/1mbVLx9J0aRd4H+k3itlYFzggH+96f/WyNHSNMtdHtTFCWaRzvmmYfNI2c5P5nA7U 60sodNtUtrZSsS89csx7liep96q6nqJs1ihhQTXsxCwRE55P8TD+6MH64PvgAk1XWBaPHaWq+ffz 8RQ7SRnHVj2H/wCvpzTtG0tdOiMs8izX0o/fTDv7D29+559hDpGlnT4nmuZRcahNzPOF6/7IHoP8 8cVo9ByMAdAeKALG8f5PWqOqata6VaNcXTEDB2ooyzn0AqhrWvR6TGsaKbi9k4htYjlmJzg4Hbj+ dVdM0K4kvBqWsyrcX64MUYOYrb/dHQtnv2I7nkgDYdMu/EN1He61DstFO+309hyfeT9flxkg4OBl T06/IAPlHYAdAPaoHkESl3cKijLM5AAHqT6VzzXdx4lzDpzyW2lq5Wa9XhpsHBWP26/N/wDXFAF+ 61ea7uHsdJYPMvE1zgGOHpxk8FvYZq3pmmwaXaiGIM0hH7yZ/vyn1P59O3YU6ys7XTbVba1jSKJe ijJOfUnqT9ao6trUltKthYRC51GUZSID5YwejP6DOPSgCTWNaktHWxsI/P1OZSY4scIOm5vQf56A 0uj6LDpIlmaV7i9uCDPcv95vYegzn/8AVgBuj6QulxyST3DXV7KczXL9T7Adh7f/AFqtXt7Bp1pJ dXMyQwoMlifQZwPU8dKALM1zHbxPLJIscaDLMxwBXMhrnxfJ8wa20FWPOcSXWMjAx0X3/LnlWW9n d+KpUvdQjaDSEbdb2jHmf0d/b8eeg4+Z9+8u7bTbJ7q5kjt7eJevGAOwA/kKAJ98Fla4HlW9tBHj AO1Y1A/IAAe1cu17feMna308yW2iZKz3bJhpxyCqhh07Hj691qOCyu/GcqXepJLaaJGwMFmWIa4P B3P7f5GMZbp7m6s9LsDLO0VvawgADaNoHQBQPyAHWgBYY7LRdN2Jst7SBCzMxxgdyT61y7S3fj2U JbtJa+HUch5SNsl2QcEAdl69e+O4ICQW9340uFu9QSS20FCHgtclXmYd3I7fp0xzzXZRRxwxJFEi xxRqFREGFUDgADsKACys7bT7SO1tIVhgjGERRwO9T0zOPugH1pQSaAHUU3P1o3D3/KgB1FJR9TQA tFIc9j+lLQAlGKWmyOkUbSSOqRoCzMxwAB1JNAEdxcR28LzSPtRBknBP5Dv+HWuD8Sa7LqETQxyQ 29njcxm6IuNyyPweuPkQZJyCe2Jr7Vl1ZP7SuX2aREQVTOM5GRwfvOeODgAH6k0rDTJNeu4r7UoU /s4SmSysI+XlcHl3PGcHbknofwAAGeG/Ch1dYb3UEK6e3IjZMSXbA5DvgkBByAv/ANYn0pEVFVVU KqjAA4AFMgh8pRnGcYAUYCjsAOwqWgBMD0ppTIOOKfRQA1UC9OtKB65paKAGkEjikKnBByc0+igB u3vgfjSgY4AwBS0UAJjmgdKWigAooooA5b4hReZ4RnJICrLEWyexcL/7NWv4dlM/hnSpmbcz2cLE +pKA1V8YWf27wjqcIGSITKB6lCHA/wDHaPB04uPCGluAQFgEYB6/L8v9KANyiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiijNABSbgDTSf/r+1ZGs6yum JDFFDJdX1wdsFvGPmc+p9FHcntmgB+s65HpcKJGnn3sxC29uvLOT3x6dfyPQZIp2dlDpjTazrdzE 95k/vZGBWBTnCJ6E55x16VDHBBoKnV9YmafU5srhTu5PPlxKcdh1PQZOVXo6HTp9ZuEvtaVVgQ7o LEjAT0LE9T1zx7cDIIA0SX3iiR8+ZZ6KCQCPlkuMcc5/hPpj65yQN22htdMsxBCEhghTkk4wAOpP 07mmXl5b2Ns9xczLFBGOWYH8hjqT0wOT2rnxBc+KCst2JLPRhykOdslwQeGb0X29/XkAElxfX/iS R7TS3kttPU4mvsFC/UbYz19ORjvyOM7ljZ22mWSW1nGsUSAAYxyemSR1PvUiRxxRLFGFjjUYVV6Y rO1TVGs5orO2UzahOD5UeM7R/ebnp7cZx6AkACazrT2e2zsh5+pTcRQqN23/AGm7AY9f5ZNP0jSh pqPLNL599NkzTk9STnA9vwGeO2AG6PpH9mJJLNObm+n5nmfkn0A9vw59hgB2ravbaTbGSeTc7g+T Ap+eVh2A+pHPvQBNqeqWul2bXN5L5cQ+UcZZ29FHUn/656Vi2um3et3kWp60nlwxnfaWQY/KCOr+ p/XtwMhprDRZ729XV9ZAadebe1ySluO3fBPTPGc8noApq+tzLdnSdJT7Rqjjkn7kAPVmJ745xz79 QCAP1rX/ALA6WFkhu9Vn+WK3jwdvGdzc4AHXBx69Mmn6FoA0wyXd5M11qsxLTXL87c/wp6DAAOBz gdgAJdB8OwaLbs7N9ovpf9fctyzknpk84z+J71rnGcAfjigBhJ25GPyrF1jxB9gmSxs0+2anLxHb o3I4zlvQYIOOODngc1X1DWry/uZdM8PRpLcjia8LZig9845Pb654ODjT0fQ7bSI3dS013LzPdSHL yHqeewz2/maAKWk6D5N4dV1OQXOpvjax+7AMfdTt3PP5d8t1i+uby7/sPSZtl04zc3CnP2ZPw/iO eBnIznuMza7q81vImm6Ztl1afhARuEKn+Nh6en+ANW9E0SDRLD7PEzSSyMZJ53+9NIeSx/woAmsd OttKs0tLSJkijGByST7k9zx+npVPVdRmgljsrFBJqEw+RTyIl7u3tzVjVNQ/sy2VkUzXErCOGEHl 29vp1P0pmjaS9mJLy8YSalc8zSf3R2RfRRQAukaSmmWZjDGW4lw9zOwGZXx17ceg/wDr5uvtjRmd tqqNzM3QD1NSTSRwxPJNIqIoyzMcAD3rm3WbxbIUUNBoiPkvyr3JBzx6Ln+Xr90AR5ZPFLSW9nK0 WlqSJbpfvSkHlVJxjvz/APqrdtrO3s7aO1tYUihiXaqKMAf4/WrEVvHbxJFDGscSDCogwBUGoX1t pts1xcvhQcKo6sT0AHcmgCnq9/HpVqJSvm3EjBYLfPzSOSAAP6//AFxUGj6RLbKb/UCsuqTAeY4x +7GPuDHp3x/KpdJsZ57ltV1NMXb/AOpiJyIEx0HHU9/w6VskhVJOAAOT6UAVwMdWJ7fSsLUtcka/ /srRY1udQP8ArCT+6gHct7g4GPf2xUdzqd3r9y9jochWBSBPfFCqqCB8qH+I9+McY5wcnb0rR7PR 7MW1qhx1d35aRv7zH1/QdgBQBT0jw/Dphed5Hub2XmW5l5c+wz90e3tz0q7eXUNhavPO4SJBk5qa 8uobG0kuZ2xHGpY5IGfbmsa10+51m8XUNWj22yc21m2eP9tx/e9vz9AAVI7W78QzLc6hDLDpindD ZH5Wn/23wc7emFPX0x16VUCqAq8AABQuMD29KnrntX1udr4aPo6iXUG5kc/dt19W4PP4frgEAXV9 VuEuV0vSoxLqUgBYnlbdD/G359P59Db0rRINLjd8+ZdSndcXLD5pD9euPanaJosWi2ZiVzLPId09 w33pG/w5OB/Mkku1jV7XRbE3Vyx67Y4lxukbsqj1oATU9QtdJsXu7uRUjXgZOCx64H6/Qc9BWNY6 HJrFwura+hcFc2+nyL+7hHqynqcY4P1PIUJY07SrnUr2PWNaQLIhJtbTtCM8Fv8Aa6HHryeQNt3X tfs9BtFkuCWmlO2CBPvyt6D0GSMnoMj1AoAXV9Xs9Fszd3jkAnCIPvyH+6ozyaxLLR7nxDerqniG EJFHxbaax3Ko/vuDjJPpge/oJtF0K6vNQGva8Fa7K/6Pa7flth9Dn5uB9PrzWtrut2mhWJuLklpG +WGFT88regH1I56DNABq2s2eiae93fTeXGvCqpyztj7qjuf6ZJwATXO6dpN14puo9Z1+Ly7NDus9 PbIAHq/rnuD976cVa0fQbrUb+PX/ABCqteLg2tqM7LdevQ/xZ557gHrgL1W3rzQA0DAwvAHAA7U6 gj6k0h/GgBecnGfxpMADml59D+NA56UAGB60AHsfzpcUtACY45o69qWigAxRRRQAVma/Jpq6RMmq APbSDBiycyHOQBjnOcVNqep2+lWhuJ29kQfec+gHrWfp+mXN5fpq+qsfMUH7PakDbACep9Wx+Xv2 AMyLwzJrdj5moxpaALiytEjwtsuepUYG4+nGM+vTpNP0+PT4Ais0jkANI2MkAcAAdAOcAcDJ9auU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAEF6jyWNxHGMu0TBfqRxWX4RtJrHwzbW08TROj y/IwIIHmMR19sVt0UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAITims2PqfU0E8dM1i65rElgUsrGBrnUp1PlRqOnozegz36AdewIA7V9cXTzHbwxtca hOQsNsh5YnuT0AABJ9hms1Fj8PJ9qvGXUPEV7kIqdX/2Ez92McZbAzgd9q0sUCeHpcvJ/aXiK/BV SRjjrgD+CMHknufoMa+k6R9iZ7u7k+0ajNzLMei+iqOyjoPz70AV9O0WYXZ1PVXS4v2GFAU7IFyD tUE+oBz6+vWreqanaaTaG5u5dq52oowWkbso9/09aZret2+iWqySq0txK3l29ugJeZ+ygf17fpVP StFmuLlNY1rEmoEfuof+WdqucgKP73TJ9h6ZoAh07Tr7V7lNU1klFUlrWwRmCxA9DJ/ebHr0yfoO hIJO4g59M1KRz07VlavqYsDFBDC895cHbBDGASTjlm5Hyj6/kMkAFfWdUNiyWtrD9o1CfAjgxkKC cb2GeF6+mcHkAEh+j6MuneZc3Li41GcZnuPf+6vAwv8AgOwAD9G0QWAe6uWM+pTZM07nJ7DCnsvA 9Og4AAAm1jVodItFeRWlmlcRwQJ96RzwAPb1PagCLWNXi0i3Rnjaa4lJWC3RctK3oPbnk/zJANbS dDmS4/tXVXE+pyAcYASBeyqB6fj35ySxfouiyw3Emq6owm1SfqQcrCvZEGeMc/n1PJMOu6vdPdf2 LouG1KQAySAjFuhxyeDg4OfbI7lQQCLWtZuZtQGi6Gqy6gxxPKc7LZSBkk9N2CD+XUkCtTRNDttE tGiiJkmkO6ed/vSt6n0+nuTySSX6No1rotoYbdQXdi8spHzSMSTkn8T/AJ5q5cXENpbvPcSrFEgy zscAUAOkKRRtI7BVVSWZjgAepNcnLd3Xiud7PSnaDS1bbc3gyGk/2E/r+uOhciXPjP55S9voW7KK jEPc4z1PYf5B7jqYIIraBIYI0jiQbVRBgKPQCgCtpelWej2S2llFsjB3MerO3dmPc9PyHYVS17XB pax21rGtxqlxxb2/r/tN6KP1/MiXXdZXSLRdiiW8nJS2g5JdvwBOBkfmB1IqHQNDbT/Nvr2Tz9Vu gDcTH/0FfQD09qAHeH9EbS4XuLyX7Tqdx81zOe5/ur6KPSr+oX8Om2jXM5O0EABRksT2HvS399b6 bZvdXL7I0/Ek9gB3NZthp899eLquqoBIufstt2gU9z6uf0/kAO0qwuJbk6tqYH2pxiCHHFsh/hH+ 0e5rYZlRGZmCqoySTgAUtc/NMfEGoC1t2b+zrds3Ei5AlYfwZ7jnP6+mQBm2bxLd5EjR6PC+CACG uGHBGf7oOQfy69OiVVRQqqFVRgADAApI40ijWONFSNAFVVGAAOgAqK7u4LG1e5uH2RIMk4zQAl7e wafavc3DhUX8yfQe9ZthZXF9dLqepptdc/ZrbORCP7x9WPHPb+TbHT7i/vk1bUwyMufs1qTxCPVh 3b+X6DVvLy3sLV7m6lWKFOrN/L3PtQA65uYbO3e4uJViiQZZ2OAK5YPd+M5GCF7bQAcb1yr3fHQf 7H+eT911pZXnim8XUNWieDS42za2Jb/W/wC3IBwR6Dv9M7urVVRQqgKoGAAMACgCK1tLextY7a1i SKGMYVEGAP8AJ5pbi4htLd553CRICzMewouLiG1gaaeRY41GSzGsexim1uVL+9TFmp3W1sw4Y9pG Hf2HTv6YAGWdvNr1zHqN6CljGxa0tiCu/wD25AevsOnfvx0FFc9qeo3V/qH9jaScMDi8uxn/AEdT 2U/3yM49PQ84AFv9Vn1C+k0jRnAnT/j5uiuUgHoPV/8AA9wcaemaXbaTbeTbhiSSzyOcvIxOSWPf qaXS9LtNHsUtLOPZGvUnqx9Se5pNV1W20ewkvLotsUcIgyznGdqjueDQAmrata6NYvdXTHAB2ovL OfRR3rM0rSpr66XWtZjBu85tYe1uhHTBAO7qTn9OgXTNIuLu+bVtbRWuSR9nts7ktlHp2LZwc+w6 dBd13W4NC09rmUeZK3ywQKfmmfso6/yP49KAItf16PRrdVjie5v5vltrWMZaRv6AdzVXQtBnjuP7 Y1p/P1eQccgpbryAiAcDg8nnqeTySvh/SLlZn1nWNr6rcDGAOLePtGP6/lk8kyeIPEkWkeXZ20Zu 9WuBi3tIxuJ/2m9F+pGcH0JABLr+vxaJboFia5vJjiC1j+859eATj3wapaL4enN9/bmvOlxqrDEa hQEtU/urjv75Pfk8ky6D4caxnfUtTnN7q0xy0z9Ix0CoOgGM9PU9jXQUAFFFFABRRRQAUUUUAFFF FABRRRQAVS1TVINJszPNkseI41+9I3ZRRqWpwaZAJJdzu5CxxRjLux6ACqOm6RJJdjVtWVXv2UBI 87kth6L2z6kfh3JAI9L0q5uLz+1tZybrOYLfdlLZcY4xwW681v0UUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRSZFJvGcY/GgB1FNDilyKAFoqhrd09loeoXUUnlyQW0kisRnaVUkHGD6VmeE tXudT00C7Z5Jo+k+wBZlz1BHGR0OOOM96AOiopC2O1YSeMNGk1UafHcM7lxGJFQmPeTgLu789xxz 1oA3qKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAQ9OKQ9e4oJx9fesLWNYm F0NJ0qIzalKvJIISBePnc+nPHqRgc0ASarq7wTpp+nqbjU5RlI8/LEvTzHODgD9fSqENsPDsPlxE X2v32d0jA/MfVu4jX9fzNSOtr4R047C95ql6+1S/MlzJ2Hsq56dAPc86Oi6XJZxvdXsvn6jcfNPK ei+iL6KKAF0nRl05prmaVrm/uDma4fr7Kvoo7CpdW1W30i08+YO5ZgkcUa5eVz0VR6/ypusava6L Z+dNueRzthgTl5mx91R/nFZ+kaLcy3q61rbb9RIIigVv3dqh/hHq3qe+B6UATaRpU32p9Y1VVbUp lAVBytsn/PNffkknuT6Vt0Vn6rqi6dCFRfNu5OIYBklz+HYdzQAmsap/ZlsDFC1xcyZEMKdXP+FR aRpL2by3l5IJr+f/AFkgzhR/dHt/9b0puj6O9tLJf37JNqM33pAPuL2VfQY/z66k80dtBJPM4SKN S7seigDJNAEWoX8GmWEt5csRFEMnAySewA7kngCsjRLG5vLptc1SIJcyj/R7dufs0eOn1PU+5/AJ aW82u6iuo30UkVlBkWttIMbj/wA9GHrjgD0P1zZ1jUrhJo9N00Br+fq5GRAndz7+g/HBxggFbV9a uXu/7I0RBLft/rZjjZbL6kngtyOOcdSDwDoaPo8Gj2vlxkyTvzNO+S8jcnkkk45OASevUkkldJ0i 30i1MUWXkc7pZWJLO3qSfx/Mk5JJNu5uYbS3eeeRY4kGWZjgUAJd3UNjayXNw+yKMZY4J/IDkntg da5qG0n8WXCXeoxGLSI2329scZlPQOxHVcE9ODnjK8tJa2U/iW4j1HU0aLT0bdbWTfx9MO/r04H9 CQenoAOlZusazBo9ujOrTXEp2QW6felbIH4DJGT7jqSAV1jV4dItVkdTLPK2yCBfvSv2A/x/mcA1 NG0aaK5k1XVH87Up+3BWBecIntyfzPqSQBdI0aSO6bVdUdZtTlXGQPlhX+6g5xjJHX19WJ0729g0 +1e5uX2Rr7ZJPoB3NPubmGztpLi4lWKGMZZ2PAFYumwz61PHq1+pSFGLWdt0AHGJG9WPOPQfWgCS ytJ9Tuk1LU4tip81ratn931+Zh3b+X15rborM1S/miZLKwUSX0wO0ZGIx/fbrge+PzOAQCrq1zNq Nw2i2JKsy5uZ8HESHt9Tzj1xj+9jWs7SCwtUtrdAkSZIHuTkn8SSfxqLTdOi0y0EMeGcndJJjBkY 9Sf89KtsyojO7BVUZJJwAKAGzTRwQtLK4SNBlmPasm3hbWLpL+5Qi2hYm1hbox/56Hnn2+v40iZ1 +ZJWUjTImyqOuPtDDoxz/COw71sSSJFG8kjBEQFmZjgADqTQAy5uYbS3kuLiQJFGMsx/zyfauftr CTxHdJqOpxFLJGza2bjrjOHbnnOenTgdRyxHA/ie8W6uFA0iF91vHni4PTcw9PY9iRjrXS0AFRzT RW0LzTOEjQZZm6CkubmGzt3uLiRY4oxlnboKybeGbWrgXd5GyWKHNvayJgsw/jcfngfj7kAVIJtc mE92kkOno2YrZhtM3+1IP7vovfHPpW1RXP3F/da3NLY6SzRW6NsuL0cfVYz6+/vxjINADdQ1WfU7 6TRdGlCyp/x93YGVt15GBzy5wR7YPocaulaVbaPYJaWobYpyWc5Zj6k0/TtNtNKtBa2UCxRAlsDq Se5Pc1W1vW7fRLQSyhpZ5Dsgt05eVz0AH1I59/UgEAfq+s2ei2onu3OWO2ONF3PI391QOprL0/SL rU9RTWtcUCRDm0suq247E+rcA+x+i7Z9J0adrv8AtfWGWXUXH7uMD5LVSPuL6nrlv/rkya/r8WkR LDEFm1GYYt7Yclj0yQOcfzwffABLrmu22hWgklVpp5Dtgto+ZJWyBgD0yRk+47kA5uh6DcSX517X NsmpuCIo8fLbJ2UdeevI9T1OSX6DoN1HctrOtyrPq0y42qBst1/uLjrj19z7kv13XJ47pNG0dVl1 acdSMpbpjl2PTjjj3HqAQA13xE9pcLpWlRLdaxKMpET8sY/vP6cc4yM4p/h3w2mjJJcXMxvNTuDu nunHJ/2V9Bx+P5AS6B4ft9Dt2O97i9mw1zdSnLyt3+g9v59a2KACiiigAooooAKKKKACiiigAooo oAKy9Z1210WFPMBluZTtgt4+Xlb0A/z7ZOBSa3rcWjwoBG893MdsNvGCzOfXA7VX0TR54pW1TVmE upzc4zlbcEfcTkgfUe/uSALo+kXC3LatqziTUpVwEX7luv8AdUevqf8A65O5RRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFAGVrusRaJpxuZFMrkhIol6u/bnsO5Pp6nAPONYazqJSTWNW XTxOQkNsknlbiewwck9Bg5NaF95Fx42g+27Vt9OtGuojJjAbOHbr0AZOexU1n6bYXfio3us3UhgS QGKwjeMZiVW4J9ckc/Vh0AoAnXw3rWnwG4stSke4+XdAZWZD643kgnPsufbNbujag+oWrefCILmJ iksakkZBIJHfGQw/D8al0ma5ks/KvLZoLiAmJvm3LIBwHU+jDnnkdD0rP0qV38Wa7HlfLiEGAP8A aUn+ef8APUA0NZdotD1CWNd0iW0jKMdSFOKx/h8d3gjTyWDEeaAwOeBKw/oK1tfUv4c1NQcFrSUA 5/2DXI+H21O2+F1vcaW8KXMLXEh85TgoJpCeOcGgDS8UXdzqN/b+GrCfypbkF7mTGdkeDwceuM9R ngfxVuW+h2FrZWtpDCFhtnWRB3LDoSfXOD+HpXm3hrxnaWOq3V5rtvPFeXz4N0o3xxoSSBjJZV7f RV44Jr1C3vIbmJJoJUlicbkeNtysPUEZBFAFqimhs9OlOoAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKQ0ALSZxxnJpCTg9sVz13qdzq1y+m6JOAyEi5vMZSDttHHL85A9ueOoBJqmp3dzdf2V oxU3ZGZp2GVtlJIye2cg4HU47ckSW1tZeFNId2d5pnYGWZ+ZbmUnj6kk8DoB7VKq6b4V0ZiWZYlY szMd0k0h7k9WY/5wBxX02xvNQvk1jVl8tkz9jsxyIFIxub1cj8ADj1oAk0jSpluX1XVNsmoy/dUc rbJjhF/M5PfJq5qurWuj2f2i6fG5gkcY5aVz0VR3J/8Ar0zWNYt9GtBLMHklkbZDBGMvK/ZVFU9L 0m5nul1fWtj320iGBQNlqhwdo9W45b8B05AE0fSbqS6/tjWgjakwxFEpylqh/hX/AGuTlupzjpW9 RWXqmsJZFbW2An1GUYhgAJ59Wx0H1x/MgAdq2qiwVIYEE9/NxBbg4LH1PoPeo9H0lrUG7vWM2oy8 yyFshf8AZXjgY/rT9K0prMvc3c32m/lGJJiBwP7q8DC/z/IC7dXUFlayXNzKsUMa7ndugFAC3FxD aW73FxIscUYyzN2rmoopvF8qz3cUkOiLhoYWO1rg9mYf3fQfj1xgtrW48WXUV/qMBi0iIlrazfOZ /R5FPGPQe/p97Y1bWItMVIwpmu5SBFAv3m5Az9OaAGaxqw02OK2toxLf3HyW1uB1PqfRQOT06U/S NL+wRNLcOJr6b5p5uOWwMgcDjj/9QAAh0jRmtZ5NRvnE2pTg+Y4PyoDj5F9hgf5NbFACEhVLMQAB kk9q5+3C+Jb8Xciv/Ztq5ECMMCaQHBYj0GMY9yD/ABLTdQuZNd1FtGsZMWkeRfzrzjnHlg+pwQfT vnBB6CKJIYkijULGihVUdAB0FAD6oarqkOl24ZgZJ5DtggU/NK/YD/GodY1630gxw7HuLybPlW0Q yzcH8hwf19DSaZpcqzHUdSKS6jIOMDiBcfcX6ZPPfNAEWkaTcC5bVNXMcupMCqbeVgQ/wr6e5/U9 Tq3V1BZWz3FzKsUSDLMx4FR6hqFvplm91dSBI19wCx9Bn/P4VkwWFxrV4l/qkXl2iAm2snznkY3S D1Iz8vYHnnIoAjs4ZPEtzHqN9CU06Mh7O3c/6w9pGH8u3J7YLdJRWNqmu/Zrkafp8Qu9SbpCGwE4 zlj245x6Y9RkAk1jVzZKLazQXGpSjEMAOcf7TegGR/8AWGSJNI017GKSW5mM95Od80hx1/ujgfKO cf06A0vTPsQee4k8+9m5mmI6+w9h/T6ATX+pW2mwiS4fBbhIxy0h9AP8j1oAnnnitoWmmkWONRks x4FZMSXGtyLPMGh04ENHCy4aX3f/AGfQf/WNMh0+fWJYr3VUMcSkNDZHovoz+re3GB16kVuMwVSz EBQMknoKABmWNCzEKqjJJ4AFc2rTeKrkja0WiRnvw10wP6KMf5P3WC4uPFkrR25aHQwMNNjD3Jz0 X0HFdMiLGioihVUYAHQCgARFjRURQqKMKqjAA9BVXUtTt9LgEk292Y7Y4oxueRumFHc8j86qaprg tbldPso/tOpyglIR91Bx8znsBkH1PanafoywTC+vWF1qJyfOYZEQP8Mf90dvfn1oAbaafc3dwl9q pHmKQ0NorZjgPYns7e/btWncXENpA89xIscSDLOxwBVXVdXs9HtDcXcm0dERRlnPoo7msy00671m SK+1yJEjUl4LDGQnTBc/xN1+ntkigCM/bfE7gFHtdEZc5JKyXQI6Y42r9eox1zx0FtbQ2lvHb28a xxRjCqvYVLWDea5Jd3sulaKplu0O2e5K5itvUkn7zeijuDnoRQBY1jWTYMlpaQNd6jMMxW6HoP7z n+Ffr1/Mhmk6I1tMNR1KUXerOu1psfLGp/gjHZf1PJ4zgWdJ0e30iB1iLSTStvmnkOXkb1J/pWdq msT3N+2iaQGN2Ria5AylsD1+rYOce4oAm1bWZVnGmaSgn1KQZzwUgGRkvzwcHIH+IBdougR6Yz3V xIbrUZjma4c5P0XPQAcf5AFnSNHtdGtTFbgtI53SzOcvK3qx6nqazbrVZ9Zun03RZNqKcXN71VB0 Kp/tcHn249VAG6vq1/eXr6PoKZuAMXF4w/d24PYere3P44OL+h6Da6FaskOZLiU757lx88rHkkn0 yTgf1yTa03TrfSrJLW2U7RyzsctI3dmPcn1q3QAUUUUAFFFFABRRRQAUUUUAFFFFABWTretrpipb wRG51GfiC2TGWODyeRxwfyPoSDWNbGnFLa2ga6v5jtigT1PdvQdfyPQAkM0TRDYPLfXsi3GqXH+u nxwo/uLnovA+uBwAAAAR6HoElncSalqU/wBr1Ob7zkDEQ/ur/j/Kt2iigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigDgfH8ci6pp/2d5CbyJra5jQBsQhlcvtPXHJPPIB7ZrtNOaz NjElhIj28aiNNj7sAcYJ65GO/Nc9Kqz/ABPg3hlMGnM8eRwTuAyD9JCMe1dKlrbrK0iQRq5I3EJg k9j70AS55OeAO9c34SLXbarqzFmF5dZicgjfEqjYQPocevHPoJdf1FZbiLQrYiS7uf8AWR9hHjnc c8A9/VQwHJWtu1t0tLaOBCSqDG5sZY9ycdyeT7mgCvrG/wDsPUPLzv8As0m3b1ztPSuE0qR3+Gem 6ZbEefeyTxqMn7okkJ/MhV5/vCvRpEEsbRt91gVP0Neb+A4zeTWELjCaZ9oYYORudgcfT5sj/dGO 9AHZ3fhrTL3S4LCeAFIIhFDIOJIwBjhvw6dD3FcNPpeseAb2S70v99pjtukibmNyePmHVH6AN0OB 67a9QooA5rQPGOna8/2dGe1v1GXtJ8B+OpXsw9x+Qrowx7g1zGveB9P1bE0AFtcJgoV4UEdMY+6e ByPyJrJg8Ra/4YZbPWtOuL+1QhI7qNh5pAHfs/bnIPqM0Ad8CD/+qlrnbDxlpmp31rZ2ZmaeZ2Vk kiZDGAjNySMHp6/j2PRUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR0oAKa7BFLMQFHJJPSmXFzDaW7z 3EgjiQZZm6CubiN34uYtIklroeRtGdsl0P6L05HPXHXIAHSXt54kufsumtLb6YpIuL5TtMnJBSL8 sFu3PcVqSy6b4Y0YfKILWEbUjXlnY84GeWYnJyevJJ6mjUtUs9DtYk2Au/yW9rFgM+OyjsBxz2/E A1NM0y8u7xdW1kg3AH+j2y/ctwR6d29T/LgAANP0ye/vk1nV1PnAf6NaN922Hr7ueuf8OL+r6pHp Fg1wyNLISEhhT70rngKP89KdqurWejWTXV7KEjHAHUsfQDuazNH024ur065q0e27cEW8Dc/ZkPb/ AHiOtAC6No0/2r+2dZ2SarICEUcraof4E9/U/X3J36bJIkUbSSOqIoyzMcAD1Jrn2vLjxBM1tZ5i 005WS57y9QVX/wCv+PcUAWbjU5766FlpPOGxPdYysQ44GeC3PuP1Il0jQ7fSQ8gZp7uXBmuJOWc4 GfoOOn5k1ftraG0gWC3jEca9FH+eT71S1nWYNGtPMdHmnf5YLeMZeVvQD+v9SAQCbU9Us9HsnvL6 dYoV4yerHsAO5rAs9PvvEl6mpa3E0FjEc2unEnBP9+Udz7Hj9S1nStHvri7/ALU19o3u8Yht4mJj gXgke5zjPUZUHnAIfrGuzC4Ol6Ki3Gpt1J+5CueSx9R+nHXgEAm1rX009ks7SP7XqcxCxWyHJBIP zP6Lx/kAkJpGivbTtqOoy/adTkGGfOVjXJwqDsBk84GefU1LouhQaREzlvPvJcma5cfM5PJ65IHt mtOSRIYnlkYKiKWZj2A6mgB1c7q2o3eo3X9j6NJslyPtd0pyLdM8gcj5jyOOeDjBBKw3+r3esX50 fRvMi2ki7vMYEIzghT/e6+/bjkrs6Zpdlolj9ntU2oPmeRzlnP8AeY9zxQA/TNMtdIsUtLRNqL1Y 9XOAMn3wB9AABgACsjVfEbtf/wBjaIi3WpMSsjg/u7YY+8555HHHuOpIBz7vXNR8S3kmn+GnEdmj bLnUWVsdcMIzxyB3HXtjAJ6DR9Hs9DsVtbKIqOC7nlpG7sx9/Tt7UAM0jQodNdrmV2ub+TPmXMnL c4yB6DgfkPQU/XNds9AsDdXb9eI4x96Q+gFR61rK6VbqRA9xdSkJBbp1dj6+grP0XQbiS6TWNfdb jVCg2RYBS1Gc4Xtnpk+3HckAdpWlXmo3keta4CJh81rZH7tsMdT6t/L6gY6UnFRl8A+vsP8ACsnW bu7cLp+m7ftU33nckCFO7EgcH0/P0BAIda12ZL2PR9IQS6nMMliMpAnd2+n+HUkK17R9Gt9HtyqH zLiT5p7hvvytyck8nGScDJ6nqSSYdI0ez0W0MdtGDI+GnnPDSt6k9cdcelVfEGuyaTAkUFs9zqFx 8tvboC3P949OB6ZB+gyQAWdf8Qw6JbxhU+0Xs7BILVD80hP9Kj0fRrgSf2hrMyXeoPjbgfJAP7qj pn3/APrk1PD+hS2U0up6mRcavc/M79REOm1Tj0wCRx0A4roN7nGwD8TQBJPPFbwPNNIscaKWZ2OA o9TXHEXnjmcZMtp4dQkEAlZLts4IOOi/y/3v9Xa1a3bxFqEGns7LpESefOw4EzhiAmfQFcn8PUEb /n28UO2KWCOOMYADAKgHt2AFAE0UcdvBHDDGqoihUReAABwK53Utfvbu8OleH0SW5AP2i8f/AFNs PX/ab2/+vijqesyardPY2uow2GnJj7TevOqO467U9OO/v+B1rDUvDWkWcdpaalp0MQIXaLhMsx/H k8fyx2oAuaPpcGjWrRqzyTSNumuJTlpW9SfQdh2/M1HrXiCHSFjj8tpryYhYbePlmJOAT6DP/wBb NUL7xpoFnAZBqdpNJwqRpLySen0HUk9gCe1Z+i3eixStql5rVhPqE/J8ydcRD0UZ44IH44oA0tI0 Bxe/2vrTi61Vx8oxmO3HOFUdAQD1+uOSxbf84HgEE+grFXxFoC7Yxq1gozgKJlx+HOOuaxvEGr2u qNHpsWuWVvYS5W7nS5QyMMgbApJwDzk4x6/LnIBNfa3c+JNVfRdDuGitIv8Aj+1KIg7R/cjOfvE8 Z9j6c9DpWnWej2K2dkhWNDlizZZ2PVmPcn/DsKyoNW8O6PpaJDf6fHaxYCiGUSdT6AlmPcnr1J71 FqfivTrfTTLY3lpd3UiA20KTA7yemcHIHqeP5UASeI/Ek9k0Om6UguNXu8iGLghR3c/TBxnjgnti tLQdHg0Wy8tXEtzId1xcN96V+TnnnHJwM/mSSczwzocmm27X167XGr3g3Tz8HaDjCKegAwM49B2V QKd1qFz4plew0a4MenI2Lq+TGJAMgpGcHPPX1+nUAsXt/deKbp9M0aYJpyfLd3q/xZBwsfqPccHI 5x97pbGwttNtEtbSIRQoMBQc/mTyTUFha2+nWcVparshiXCgk8+5J6k9SauqxPagB1FJkZxkUtAB RRRQAUUUUAFFFFABRRRQAVia1rUlvMmm6ann6nMPlQdIlxks3Yfj6j6FNS1pjef2Vpima+YfMRws Q9S2CB6Z5wccE8G5pWkxaXA2G825kO6edh80jf0HXA9+5JJAItI0OHTDJcSP9ovpsmW4YcnPJA9B kD8h6DGrRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAct4o0a+k1Gy 17Sgkl7ZKymBxxKhB+h4yTjP05AqNtY8R6pH5FhozafMwAe4umyqcn7oI+b8vwrraKAMvSNDg0oy TGR7i8mA864lOWbHQewrUoooAKxNA0AaLPqUvmbvtdwZFVT8qJklR9eSPTgVt0UAFFFFABSEBgQQ CDwQaWigCGG0trdmaC3iiZhglECk/lU1FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAHpxWXc69p1pZ3N3 LcoIbeQwyHurjqvuef8AIrQuJvs9tLN5cknloX2RruZsDOAO5ry431tc3c+p31heTJZyuLPSIzgm RGXc78gE7mA78cc45AOjtoL7xhPFfX8RttERg8Fqx+a6GOGcdNp9DwR04OW2dY1saXHHBZ2r3d5I wiit4sfKcdW9FH+HQc1zt38R5LMQtL4a1NFfBbzBt2LkDJ4x1/kfQ4ktfEGsxecIPBt2JZJHbc8w GWPJySo+XPA9qAN7RtHlt917qci3OpS8vIQMRjsq+gH+fU3dQ1GHT4Sz/PMQTHCvLyY9AOT26CuO 1HxT4tsoPPfQLW3VpBHGZZs5Y9AeRxgdcVBJ4U8VX3iqDxHLeafaXscH2cBAzBUyTwpyM/MeCSM4 NAHQ6boNzPqI1fXJVnuxzBbgfu7fnPA7twOfbv1rZv8AU7HS7c3F/dw20Q/ilcLn2HqfYVzcmg+J HiMt54qkAVdzLBbBcdzjaQSOP85OeOvvh7d+KNciuf8AhIhdWyxpzO7+fEp4ZVU5HvnPXAI/ioA7 G2uJfGgM8E08Gj/dj2fK0/X5vUDtj1BHXJHVQ28NuqrDEkYVFjGxQMKvQcdhk4HvXJWXw6sbCEQw arq0cSkbUjudo4AGTgcnCrz7dKyfE3hOysYbaR7/AFCdTKuUnnL8ZA4PXOW689aAOm1PxGxtYR4f ji1O5uHKRtG+6IAfeJYHBx0xkc9SKdovh82c51LVZUu9WcZaY5xEMfdTPYZbnA6ngZxVCH4c6Jbx iOOS8WPkBFlCgZ+gFEvgDR0s3jiSeRwpKI8xClscZC4wM46c0Aaet30s9o9ppl1CtxIRG0wlX91n HPXg4OfywDmm6PFoWi2jR217abmOZpTKuXPXnngcnA6DJ9TWH4e8JeH9Q0qOWWy8xwSrNuIDdweD j7u3gcfjmtuPwX4dhP7vTEX1AdsH3IzQBbfxFosWfM1WyX2M65P4Z9j+Vch4p8ZxXU6aXo+oQJG0 fmS3qSE+WwZcAbTngZYkZ4wMckjb1HSND0W3t5I9EtJFkuY4m3AfKGON3Oc4wOK149D0mJt0elWS N/eW3QH88UAczpPijwvommx2VpfSzttLswgfLnkEnIwo+XjJAAx2rE8VeJm8QQ20Wg3eoxKH8u5M UG5WRsAjb/Ew6jkDqM88emC3hU5WGMEHIIUVj6BH5Wo64pDhmvS5Lc5BUYxx0/8Ar0AYml63Jpel W9rYeGNaeBOFaVMMxJOWIGcZJJ7d6mm8V63FDLOvhS4EUeSWmuBGMAZPG2uyqhrao+g6gsjFYzbS BiOoG05oA4rRj4rht/tEejR3TXH75bm5vQWI2/LkdQSCBjIAx9MacTeNyAsVlo9sm5mIkd365PGD 3Yn6cj0re8POsnh+xKoUAiCbfTb8uP061pHHT+VAHGTDxokkMUmpaDbvM22NdrFnI5IXI9B6HFKn h/xSL25uf7etY3mAy8dqC3HC/pj8fStDxHbxy6rojs+1o7gYPUn50OOfoPy7V0IXHf8AHFAHJHw3 4kfPneLZSuc/u7YAj24YZ/z+GbbeDb66upLpvEeoRsrFY5A5Ziu7nktwCAMDtwTmur8SXN3ZaDdX Vk+2eIBwdm7IBGePp3qXR7P7JpkMRxvxulIAGXP3uOwB4A7AAdBQBz6+B5HbdP4k1iTOCx88jPPG OeKwvGHg+Ky0LdbahqE9zLKkS+dPnccZHbr8v0xnPevTMAdAOOmKwPGUjx+FL+VOCioynJ6h19O3 +eelAGTafD7w9KEuDDcypKFkCvPlR3GOAeM1S8SeEtF0vSIbqLT2mignXzw0xDPFgjZz2LFenPfN d1Yo4062WQEsIkDZGOdozxWL4zVW8KX4LMozGCV7Zdevtzz7UAO/4Q7w+HG7SomxwN8jMPxBPIqY eGNDBJXSLTng/JxjJ7en+e1asRWWJJAOHUNjp1FS7fU5oA4XxXo2mWP9m3dvZW6eVcqHQIArp1Kn PsD710LeF9EkYk6XbHjA+Xg1n+L3xqXh6IgFXv1JU9DyB07/AHv16GupC4GO2KAMG78P6HaWNzON ItmWKJ2KbcbgBkj8doqhoPhfw9d6XFqP9hwQyXipMybi+3AwNp7A4B46966LV5BFot9IwBCW8jEH ODhT6c1T8LBj4bs3dQpcM4A7KzEj9CKAMrXfC2jwaZNJbaRCJNuMrxtXljgE4xx29axdK8FadqXh CKaK1tH1GeLCXE5dkUg4+6CMjAOO57967nWkQ6LqDMMj7LIDk8fdP5daz/BbK/hCwKqVXa4AYY6O w/z/AEoA4640iy8Happ1hDFc3tzrEMsEgiISMKuwsQhzkncMAkjGRyeT2+h2Qs9LihG7PLBWi2Fc 87SCTyO57nJ71keM4N+r+GZxhWi1BAGwM4ZkBXPXnr+FdhigCAcH3PrSjpwfyOalK8euabgY5AP4 UANBJ7A+9PDdM459Dmm455xTSxzyw9s5oAmoqIZPQAj1zUmPWgBaKKKACiiigArntS1ie8vH0jRc PdAfv7jny4Bkg5YfxZBGBzwRxyVg1LV7zVNR/sbQ2UEH/S7zJxCvt6k8jg5yCBjBZdvStKttIslt rYMR1d3OWkbGCx/LoOB0AA4oANL0uHS7byo2eR25klkOWc+5/kO1XaKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAopMc5yfpS0AFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFJj3oxnua AFopMe5ox7mgBaKKTH1oAWijFFABRRRQAUUUUAFFFFABXJ+F7CG807URdQxsxv5sFTnaSFBKnryc nP0NdZXM+Asv4Tt7h8GSeSSR2H8R3Fc/ko//AFYoAZpVpcTeMtUluNQknjsxFHFEcYG6MHJwOud3 v8x6A89TWFpEUUHiTXY4iCGaGVgFxtZlOR79A2f9r1zW7QBzvi1PMTR0x9/U4V3f3RyT/LH410Vc /wCKApk0PcxGNUhIx3OGH9a6CgArmPCemwDwnaRpK08kZkWO5lO6TiVtuW6nHHH4dK6eud8EsD4a jUE/JLKuD2+ckfoR15zQB0Vcx4vVZbjRICkbmW+VSrHB298HPbg/h+B6euX8Zbll8PyL/wBBeBSC 2Mgk9u/TP4UAdRRRRQBg+GR5f9rW658uG/dI1zwi7VIAHb198571vVy/hjK6/wCJUMgb/S1bGwDG Qe/fjA/D3rqKAMTxI6JFp28ble/hjK84O4kdvz/CtusHxUAYNLBJGdTtxwM5+bGOo7Z/DNb1ABXP 6OSvivxBESf+XeTB91Yf+yiugrn9MJTxlrkZyA0Vuy5zzw2cfn/OgDoKo6yypoeoM2Nq20hOfTaa vVT1dtui37EgYt5Dk9PumgDP8HoyeFrIOOm/bznC722/pitysXwltPhex2gj5Wz/AL245/XNbVAG DrClvE3h8ADiSYk4GR+77ZH4f5Fb1YGsPt8U+HV5CtJPk54/1RAH61v0ARzp5tvJHhTuQrhhkHI7 1ieC7h7nwtavJIXkDSAkj/bbA9eBjrW/XL+BZWfSLxGABjvZVxs24yFb+tAHTkBhggEe9c748OPB OpHJHyL0Gf41ro65rx+A3gjUVPcIMY6/OtAHQ2+77NFuBDbBkHqDisPxwqN4N1ESEhdq5I6/fWt9 c7RuwDjnBzWH4yCnwjqAcAgoBz/vDmgDU092k021dyxZoUJLdScDrwP5VZqppZY6TZF0CMYEyoOQ p2jirdAHJeLFU+IvDLHGVujjK56sg/DrXW1yni9kGq+HUYHJvkIIByMMn6c/y59eroAo60pfQdQU dWtpB/46ar+F0KeFtLDAg/ZkOCfUZqTxBx4fviQTiI8Ac/h70eHRjwzpI+Xizh+6cj7g6UAT6qu/ R71fW3kHXH8J79qyvBKsnhKzV/vhpd318xs1q6owXSb1mGQIHJGcfwmsnwOwbwhZFSSMy8kdf3jU AV/G+PJ0MEkD+1oM7RyRhuB+ldTXJfESWS30C2uYl3PBeRyAZA5AbHX3wPxrraACkIzS0UAN2D/6 1LtAzgc0tFACE035iOMD8eKfR0oAaBjv+NLuA6kUE/XNIWxyaAHVyuoX9x4jupNJ0a4CWycXd6mG A/2Bz355FRXmoXXii5l0vR5tlkmBd3y4III+4g75H9CeCN3S6fY2+m2UdraptiQcZJJPuSepoANO 0620uzW1tU2xrySeSx7kn1/z0q1RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRQc9qACiiigAo zRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFAFLV5Gi0a+kVgrJbyMGPYhTzWd4NjaPwnYjaqlg7kAYA3Ox/rU/iiRovC+pMgGTAy8tt68Hn8f xqTw7/yLGk/9ecPUY/gHagCpZrJB411MNgpc2sMqHPTYWUjH45/HntW9WFIdnjqEs5Al051VSeGI kB/PB/z23aAOa8Yt5cejTMRsj1SBmzjpzXSjp15rmfHqO3hO5ljYCSBllUepHbPb/PrXTUAFc14J wNKvEDq2y+mX5ei8jiulrm/BhY2GoBmZiuoSjnPHTge30oA6Sue8XNttNLYvtC6pbEkruGA+Tn0+ vriuhrmPHrND4a+0jAEFxFISeg+bA478kUAdPRRRQByvhok+KfEgIwRJGMAcfekP9c/jXVVzmk4X xx4iUKF3R2rH/a+Vhn/PtXR0Ac54wcR22lyMCVGp2/AGcHeDn2PGPxro65jx1uGiW0iruMd7C+3O M4bvyK6egArmoV2fEW5KnAfTwWUZ5IdQD6Zwce/HpXS1zzuB8Q4lyMnS3OB1/wBavJ/KgDoarahE s+m3UT52vC6nHoQRVmmyLuidcZypGPWgDD8GEnwpaZ67pQefSRq3q5zwKc+ELT/rpN2x/wAtXro6 AOW8VM0Wu+GplJBW8K5AyfmwpH4gn/PI6mub8YsYodJuO0WpQEkddu7kD147Y/LGa6SgArl/BaLC NcgXrHqkoI3ZA4UDA7cAcV1Fcp4Vf/iovE0WRhbpWGD67u3Y5B+v6kA6uub8eru8E6kCM/KnH/A1 /wA89K6SsDxtGJPB2oqSR8inI65DqePegDeUhlDDoRkVg+NVL+Eb9V6kJ2z/ABrWlpE5utFsLhus tvG54x1UGs/xlEJvCl7GSAG8vOSQMeYvcc0AbFqFW0hVPuiNQOc8Y9e9S1S0csdD08scsbaPJ9Tt FXaAOW8Xr/p/h+TGQuoxqR06uveuprmPG3yW2k3H/PHUoXPGTgZPH5CunoAztf2/2BfbmKr5LZYH GOKNAwPDml4II+yRYx0+4KfrQJ0O/A/595P/AEE1V8KMX8KaWSzMRbqCWGDkcUAaN6A1hcAnaDEw JzjHBrE8Ctu8HWJyh+aUEocgkSuOK6IjIwa5bwA//FOvbnBNvcNGWB+9wrc/99Y/CgCTx4G/4RG6 dSBsZGJIJ/iA7fWujRxJGrgEBgDg1heNYhN4P1BDjBVScnHAdTWrpsxuNLtJ227pIUc7emSoPHtQ BaooooAKKKKACiimu6RxtJIyqiglmY4AA7k0ADEKCSQABkn0rkbi9ufFd01jphKaUp23V3jl++1f XIxx6HJ4wHWa5n8YXUlnYzeXo0TBbicKcznui8YI4wf1yCAeotLO3sbWO2tohHDGMKo5/Ek8knqS eTQAyxsbbTbOG0tY1jgjG1B39SST1JPJPcmrPTmlAx0pCKADPrS0d6KACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACigDAA9KKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKAOc8d5PgzUACASEHJx/Guf0zW5YxmGwtoyu0pEqlSc4wBxX P/EAj/hDL1CpbeUA+YDncCOvuMfjXT0AYGpqyeMNElViu+K4jZccMNobr2II/nW/WBrRZPEvh18D Z50yscDjMRA/X0rfoAwfGPPhLUVB5MYH5sBWxbS+fbRTA8SIG5x3Ge1Z/iWPzfDt6MgAIHJPYKQc /kKk0A58OaZwB/okXAPT5BQBoHp9K5zwm679eAYkLq8w+ZskfKmf8f8A61dHnAPP9a53w0wGp+II 0PS/LEZzglR/P0+vXOaAOjH0rnfHcQm8EaohI/1YIJ9mB/pXRZ46Vl+I7cXfh3UIyRjyGcfVfmH8 qANC2nW5t4plPEiBwPYgGpayfDDb/CukNv35socsTnJ2DvWtQBzFkyr8RtTUhdzWUTA4OQAeR06c j/Oa6euYjAX4lS7VcBtNJc44J3oBz9AePrXT0Acr8QuPCcsmR+7kVsZIJ6jgjp1z9Aa6quc8dxCX wbqCkD7q4zjj5gO/1rft5luLaKdDlJEDqfYjNAElcrqDtH8SNJw+BJaumMnBwHOPrwD+HtXVVy/i ST7N4l8NXIXcRcvFjH99Qmc+27P/ANbNAHUUUUUAcr4CVo9Fu4n3bo72RSzEndwvPPSuqrm/Ce2O 51+ABVK6pI+0dQCq4P44NdJQBynxD3DwuZEzujmV1I6qQDgj3zjHviurrB8aRmXwfqSDqYx/Du/i HatTTJ2utKs7hzl5YEdiBjJKg0AWq5jRMx+NPEcZ+4wt3TjgnDbv5iunrmdKYr4+8QoT96G2ZeOw VhQB01ZfiOPzfDt8pGcRFuuMY5z+GM1qVQ1sBtB1EHobWUf+OmgCPw4MeF9JBxn7FD06fcFQeLY1 l8LX6scLsBJwTjDA9BTfBzFvCWnFsZEZB/BiP8jtVvX0Enh3UlP/AD7SEexCkg/nQAaA5k8OaW7H LNaRE8/7ArRrI8LTef4V0uTdu/0ZFJznoMde/StegDkPiMdnh2CTO3y7pW3FtoX5X5NdfXLfEOFp fBl4UdlZCrZH1wf0P+eldLBKtxbxzJ92RQ45zwRmgCtrLbdDv2wTi2kOAcE/Ke9Z3gvP/CI2A5wF cLnqF3tjue2K172Lz7G4h/56RMvTPUY6VieB3aTwnbM4wxlmJHpmVyB+RFAHRVyng9hDqHiHT9m0 xX7SjByNr8L06HCdPp+PV1ylhJJb/EbU7d2Hl3FqkqDuNu0Y/Nnx+NAGn4rgNx4W1FBk4hLkA9Qv zEfpUnhuUT+GdLkUAZtYwQOgIUAj8xU2tQ/aNC1CEjPmW0i9M9VNZ/gyUz+D9NYknbGU/wC+WK4/ SgDeooooAKKKRmVFLMwVVGSScACgBJJEijaSR1REBZmY4AA6kmuQkuLjxneG2tVeLQom/fTtkfaT /dA64+v168VNcCbxhKYY3lt9HifEjDAa4I7DjgDAPtn1Hy9Nb28NpbR29vGscMahURRwAKAFt7eK 1t47eCMRxRqFRV6ACpKKKACiiigAooooAKKTnPejoOT+JoAWij60UAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQBy3xCkaPwfdbTtJKjcDgr3z09u3NdTXMeP03eEbkiPeyspUY6HP1HGMg+xNdPQBz vioYl0KQeXvXVIgockA5VhjPrXRVheJnCf2NkNzqcIypxg89fbtW7QBQ1z/kA6ic4xay98fwmovD e7/hGdMDDaVtY1x6YUD+lWdViM+j3sS4y9vIoycdVI61R8KOsnhixK78KrJ8/XKsQfw4/KgDZrmt BH/FWeJTtON8Ayf91v8AGulxXP6WNnjHxAoYfOts+P8AgDD+g/SgDf468fWo7iIT20sJ6SIyc+4x Ugz3NHvigDm/Ak/neD7Ms2WRpUYdCCJG6jtxiukz64rmfBoaCDWLU5222pyxqCMfLtQ8e3J57103 egDmtQcwePtGfYxFxbTQ7l4xgb8H1Hy/gQPx6UHNc14lZrbWvDl6FJCXxgbnoJUK9Prj/wDVXSg/ SgDJ8URLN4X1FGBIMBOB1OOcCptAff4c0tt27daRHPr8gqTV4zLo97GGAZ7eRQc4wdprO8GzvP4R 013HzLF5eMYwFYqB+AAoA3q5nxoyQ2ul3cmNlvqEMjbjgBQSST9AM59q6aua8eQibwdfEkAoFZfr kD+tAHS0VBZXKXtjb3UZBSaJZFI7gjI/nU9AHLeH4/s/jHxLCMYZoZeFxywcnnPPUV1NcrbM8fxL u4y3yTWG8Dcf4WQdOn8RrqqAM/XYhNoGoRkAg279R/sn07+9QeF5vP8AC+mtjBWBYyPQr8pH5ir9 7CtzYXEDEBZYmQn0BBFYPgScSeD7Tr8skyYbtiVsD8BgUAdNXH26m2+Kt3kqEutODDn+JSgx9cZP 0rrS/ArkNVdoPiPok43qs1tLExGeQAxwe3UqeaAOwLfn9Kr3Qae2mh4w6Femeo+oNPDMOpGO5pQT kc9/T/CgDnPAErHwdaq5BaOSZGPQZ81j/Wt7UkE2lXkXXfA64HuprlPA0rw2moafKCJLbUHjC+il Qevpw36V2PORk/hn/GgDA8Bv5ng6zO7cQ8wPGOfNftXSVx/gLdDpl5ZMyb7a8kQrnkcKf55Gfb8u uGcdePagDG8XwvP4U1CNM58sE4OMAMCf0Bqz4ek87w3pkhwCbWLIBzg7RkfnU+oQm7065thtJliZ FyeMkEDNYXgO7E3hC0TcheBnidQT8hDEgf8AfJWgDqK5TwBtXRbuJC22K9kUKc/LwpIwenJJx7+t dSXA61yfhJjb694l09gAI7tZV4A4cHA+mAvtzxQB11cnrRNl470K93MEuFe1fB46HA/FnH/fNdZX NeOLdn0KO7jIEtlcx3CfLnkHA9+pB49KAOlrmPADMPCkNu2S1vLJESRj+IntwevUV0dvMlzbRTxn KSIHU5zwRkVzHgtVtZdcsFbIh1B2AzkgEYHv/D/9c0AdXRRSMyopZmCqoySTgAUAI7rGjO7BUUZZ mOAB6muWaS58XzmOI+ToSMA78h7nB6DjgcD8D68KyZ7jxjeNbwOYtBiOJJkJDXDA9FI/h9/Yd+nV xRRwQpDEixxooVEUYCgcAAelACQwRW0KQwxrHEgwqqMACpKKKACiiigAooooAKKKKACk6UtFACDF LRRQAUUlAOe9AC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAc547DHwffBVLHAI4zyCD07/Sujrm/Hkav 4Nvy2fkCt1/2gP5E10lAGL4jUmLTSuCRqNucHP8Ae5/TNbVY3iRA9rYkkgJqFu+R7SA81s0AVtRB OmXYVdzeS+FxnPyniqPhgqfDlmU2bSrHKdD8x5rRu4luLKeFvuyRsp4B4Ix34rL8JyrN4bt3XGC8 o4GBxI3T/OfXmgDarmtPbZ4+1mPH+st4XB3HHAwePxFdLXMEpafER2Ztq3OnqPvcFhIAOPXGfyoA 6eiiigDmfD5aHxR4ltC2VWaKcA9RvU/p8orpea5i0naD4j6jbMHxc2Ucyk9PkO3j/vs8+x9K6igD mfHO6HwzJeIoLWc0VwpPONrjn/PaujBB5Ugg+n9KoeILRb7w9qFuyby9u+FHdgCR+uKqeErv7d4c s5SXLpGkTmQYO5VAOfxzQBtPGJEKN91gVIyen1rmfA0uPD8dqXDyW8s0bH3D5598MPzrpioHPGfp XDeHpXsPGep6TlRF5skyhf8AbCkA/gn6H2oA7onjv/KqOtRJNol9EyqVMD/e6ZAJH6gVbVwRxz9K R0SVSjLkONrc9jQBkeELv7X4T0yTbykPlHJGSYyUJ/HbW0Wx3HTvXLeCblpdFmtZOHtLqSIjOeCd 3Xp3P4AV0xJOQAf60AczrGIPHehXZk2eZDPCzdiNpIB/HH6V0kcheJHJIJUGuX8bObeDS78O4a3v 487eMqfvDp6Ct/SWZtHsi53M1vGTkdyozQBcySQDjB9DXIeCJ3hs7qykyskd/Kmw9MbFbgc8ZJ9e 9dftyTkdetcNZlbD4lXVi6hTdTfa4QFPP7lw557nI/759qAO6C8Zzz7VxnjdfI1bw1fMSqx3yIzb cgAunX8N3+Rx2gXjpzXKfEeF5PCvmRlg8FwkgYKTt6jP60AdVsOcgc+tLgkEY70+igDhtKU2PxE1 exLqI7gi7QbfmY7TnHYcsfrge+e12t/e/M5rlLq3EXxRsZVRgJbJyzBiASMj6HAA/OuvoA4vw+Db eMtdsmA8xpGnHGcBiCOfXDf07CuwKjHIPFcg8RtvishXaftViXbIGQBgYH/fArssfnQBEVGcnset cd4LVbfVPEemiPasF4ZFO7+FiwGcdDhB2HBHWu2wPauX0ew8nxt4jkW3aOKVbc7yOGbDEkdupOfo M0AdEQAMcfliuI1aCaz+Ilt5MeV1aFI2b2R1LjjnhV/8e9q7vYMYyQPrTXt4mkjkMUbSRZ8tioym Rg4PbNAD1G3OKhv7Vb6wuLVjgSxlM+mR1qbd2OAfSlGKAOc8D373fhqKGVSJrNjbODjoACv/AI6Q PqDUOkXKxeP9fs8gGWOGZRz2QAkcf7XJz6fgmnL/AGb8QNRs8/ur23F0gx0IODkn3L4A7fhV+C1t f+Eq1DVCGjeC3S3d2OFORvYknjgbO/rQBtkhVLMQAOST2rj5pbrxnc/Z7YtBoUb/AL2bkNc47Dnp n27c/wB2o3urvxtctb2iyW+gxuUnmdcNcYOCqg9j/LOeeK7C3t4bS3jt7eNY4oxtVFGABQAsEEVr AkEEaxxRjaqKMACpKKKACiiigAooooAKKKKACiiigAooooAKKKKAEx60f0paKACiiigAooooAKKK KACiiigAopOfSjPtQAtFFFABRRRQAUUUUAFFFFABSZGcZ5o57UYoAM0tJgZpaACiikByAelAC0UU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAc546dV8I3kbFgJtse5eoyR/h+ddBDu8iPecttG SBjnHp2rC8aoH8JXpPBUxsD6EOvNaulyNLpNlI2NzwIxwR1Kj04oApeJ0D6DMD1DxlTzwd4weM/y I9eK2KxPFztF4XvpUUs0aBwucZwRW0CCoIOR6+tAC1zfghw3h7ZlS0c8ittOQDnP9R9c5710lct4 NRbafXbRQSI9QZgx7gqq/wDshoA6muR8RM1v4w0OcNt8wiEEk4OXGeh9CcZ659sjrWZUUszBVHUk 4Fch4lfTL3UtIujrFhGlhceZKGuF3cMrYAHOcrj8aAOworm5/HWgxEpHcTXEoBIjht3Jb6EgD9ai TxvBcKPsmj6tO56AQALz0yxOMfTNABqEiw/EXSSdi+ZaSRlicHrkD36cfj7Z6muFluNU1TxHYatD 4dukazjddlwQhO4YyCR7+vr0rTN74wlP7vSbCAY482XfzjuQw7+3t70AdPXI/D15joM0EkYX7PdS Rk7ySWzk/wAx+OeOOZ/sfjCcgtqdlbggZ8uLcR0zwQc9+4/oI08H3YR0fxBdokjmR1tkEO5ick8H 1/w6cUAdNK6RrvkdUXpljgV57qWo6fp/xLtLwXsZgnhP2h1cMqHYyrnGfT8M+5rfj8A6N5gkuWu7 thxm4m3ZHpwBV618JaFaY8rTojj/AJ6EuPyJIoAoyeOvD8YP/EwaQjskEh9P9n3FVZPH+ijKxRX0 5wWwlvtOB1OGI9a6aHStOt23Q6faxNnOUhVT+g9h+VXAABgDAoA8w0PxD9l1zX5odJ1G4+1PHMkM cXzLncfm64J3Y99v57beLtVGNnhDUm6/fDDjH+4eT09q7ERRrI0iookcAMwHLAdMn8TT6APOPEGq 65rei3FkPC13E7BZEcFmxgjtsHPPTrx7VfsNZ12xsbTT4vClywt4Vh3yXH3tqgDnZg5x3I/Gu4oo A48eIPFhXMfhMYxkb7zBPpxt/wD1Vnyf8JPPr8Gst4WQz28JiVPtqqCTjLc+24e/HoK9AooA486p 44lHyeH7KE+slwHHv0Yf5FS7vG84H7rSIARyHDMQevZjz+Pr7V1dFAHKfYvG0rjzNV06FeMmCMk9 efvKe3+eeFGj+LSFLeKEU55C2cZGPxWuqooA5g6B4iZOfFcglxgOLKPgd+OlRnwxrzNufxfdk5z8 tuq9sdAcV1dFAHG/8IPdtdreSeJL5rtEaNJgCCqtjIHzH0/WrR8I3jSfN4l1Ux5+6JSDjHTOa6ii gDkW8G6h5gaPxXqqjOcNIzf+zY/SnDwrrS7Sni293DPLR7s+nG7HpXWUUAcuPDmuqQw8WXRcEn5r dcc+2fb36msm9/4TK11GDT7PW4bq5ZPMZZLZQAnTJwo6kHv/ADFd9UENt5d1cXBO5pSoHJ4UDgdf UseMdaAOPuF+IFnIfLfT71WwTmIYXHUDDKf0JpieJvGFtL/pXhyOdf7sAkQg+m7DA/XjrXdUUAeV aj4h1eXxbpep/wBgTwywhofszTcTEggY+QNxvPY9RU9pda7qd6ba80W6/s29uz54SRsAMdpywX+H HTj7vUHOfTGRGZWZVJQ5UkdDjHH4E1DZLItt+9Qo5d2KlgcZYkcj60ASQQRWsEcEEaxxRqFREGAo HYCpKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo/CiigApDj8/el ooATjpn9aMfSlooAKKKKACj60UUAITjsTSZ65yMdzTqAMUANweec0oHOeM0tFABRRRQAUE4oooAK KKKACiiigAooooAKKKKACiiigAooooAKKPrRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUARXKhrWUGFZ/lJ8pujn0rjYvEfii5v 5rO00SxiCpvgDzsdyKdrdQvcrxjgEdciu3qKW3imeJ3RS0TbkbHIOMcHt1oA46/j8ZavpNxY3Wna aiTLtYrIQcZHbcf51et38bMqiWPRkA4JcSEn8mxXUUUAcyun+Lbh90+tWdqOBstrcODxyfnGfTv6 1Ha+DHgkmkk1q8LzkGZov3ZkOSeccdWJ6d+9dVRQBzSeBNC3h5oJbhx1aaUkn6kY9vyq/b+GdFtV Kx6dAVJJw4L9QQfvZ456VrUUARwwQ26bIYo4l9EUKP0qSiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKQMGLAZypwePbP8AWgBaKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKQHI7/iKAFooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKqandtY6Xd3SKGeCB5FDdCQpIB/Ksjwlca7d6XFdaw0TCdfMTamxlB6 AjHpn9OuTgA6KiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiigdKAC iiigAooooAKKKKACiikBoAWiiigAooooAKTP1/Kg9OaTPfNACk4FHek9eD+NGMnNADs0U3tS9R/h QAuaSmk/T60vGe2eooAXPNGffBppLCkJB64/E5oAGkCgnIwOST0FRW17b3lulxbTpLDIMrIhyCOn H4j9DVfV/OfSrtbZY3neNlRZG4OeD+hPH8qxfBJUaC6B2ZI7uZYyRj5d2R9Rzn8aAOoDjuffgU7N Q7gegY+mVPFBzyAjN+HagCUsAeo/GjcPUfnUW2U9Mr9cGjypCfvLj1/+tQBIScdeaN+PU/SmCFh/ GPwX/wCvS+U/aTH4UAO356dqQygfjTfJY9ZWNL5HB+dufpQBWi1W2nv57GOT/SIFVpFKno3Qg9D+ HTv1q4GBrhrWNrX4l3xE/wAs2FdSOdrRphs4x95VH/AhxnJrthDhgQ7ZHY9PyoAlopAAOlGeehoA WigdKKACiiigAooooAKKKKAMXxY5TwtqJBwfJOOM55FM8HSCTwhpjAEDyQPukdCRxntxVjxOCfCu rFcbhZysMjPIUkVR8CSiXwXpzAEAB0OcdRIwPTtkUAdHRRRQAUUUd6ACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKQkDuKUgHqM0mAOgFABnHUijcPUUtFADS4BwT+lG/nofyNOooATcPQ/lSZP900 6igBBn0xR83oPzpaKAG/NjoPzo+f/ZH606igBuH/ALw/KgqccEZ+lOooAbg+tKAe5zS0UAFJtP8A eNLRQAmOetG0GlooATaCMYpNg7Ej8adRQA3ywfX86AgHc/nTqKAGmNT29utJ5Sen60+igBnlJ3Gf qaPLTOdvNZXiDWZ9HtopLaxN3LI+NnmbBgcnnByewGK0LG9g1KwgvbVi9vcRiSNipXcpGQcHnpQB NsQc7VGO+K57wIiL4QtCiqu55WO3oT5rc/j1rW1iQw6JfyqdpS3kYHOMYU1S8IwG38J6ajKFZoRI wHTLEsf1NAG1RRRQAUUUUAFFFFABRRRQBx7xLbfFAHYGF5Y85HQggg+/+rAx9DXYVxmrQOvxR0K5 I/dtA8eenISY/j1rs6AKeqXp07TLi8ETTGFCwjUgFj2GT0+van2N2t7p9tdoCFnjWQKeSMjOOKfd qrWc6spZTGwIHcYrG8LXLR6Va6fdErcJArR7uDJERwR9OhHXjJ60AbhJByV/IUoYYHHFOrI17WbX QdPa7uDuLNsjiT70jnoo/r6AUAaobJpea5RNS8S2uoQyX9raDTZ7lbdUQkTJuOFbqQR3559hXV4w MYzQAtFQzSCKNpHYKijLMxwFA6kn0rlV8XXN9dMmjaPJfQIcGdnKLnjp8px+PPHSgDsKKw9N1HWL i58q90M2kf8Az1W5Vx+WBW4KAK2o2xvNNurYBSZoXjw3Q5BHPtXLfDe6SXw01vghradl2nqAwDjj 0yxH1Brsq4TSSdH+Jmoac4Cw6hEZouPvsDuHHbGZRnpwO9AHd0UUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUlLQAUUUUAFFFHXpQAUUg6UtABRRRQAUUUUAFFFFACYFLRRQAUUUUAFFFFABRRRQAUUUUA Jz1oxx1paKAGbX/vD8qcM9zS0UAFFFFABRRRQAUUUmaAFopM84paACiiigAoo5ooAKKKKACijNFA BRRRQAUUh6daM+9AC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFXUbGPUtOuLOUsqzRtHvX7yblIyPf muf+HlzNceFUS55uIJnikbcWz0I5PPCsq8/3a6quJ8Hu1n4t8UaY6qmJ1uI0U/wsW5x2+Ux0Aa3j ecQeEL9iNxYKgXOC2WAwPwzWxY2q2Wn21opysESxg+oUAf0rm/HmZ9KsrMKxNzfxQcZB5B5Hrj/P OK6ygArmtc1C5u9Ti0PTZJY5mw9xNERmNcj5c9sg8nrgjHJFdFNKkEEk0hwkalmPoAMmuP8ADE62 +k6r4nvywWeSWUBm3FI1Jyq556jGP9laALHgua4E2s2EtxNcQ2V2YonnYs3TkZPbIzjtn0IrZ8QX 8mmaDeXkIJkjj+XGOCTgHnjAzn8O9ZngW0lg8Oi5uARPeyvcvuGD8x4/PGe3XpTfFxe+tLjTIhuC Wkl3MoJBIX7i/icn/gNAEWq6hqGl+F9HitrhDqN20FqJpsvl2XlvqSOuO9TJF4ztnbNxpV5HngOr IxGfUcD8j0FZ00w1K18KBJAVWVHfAHLxMiED6MT07A+grt6AME6prlvbPLd6RbqsYyXS77f7u08+ 2TzVZfF04txNJ4c1UqVyPKRHGfT7wrc1Oz+36bcWvy5kQgbs4z2zjnGfSrMZZo1Z12MQCVznB9M0 Aeda/wCI7htZ0PUodF1OAQzFH82FQXVyowMtjON3fv711Ues6vdS4tfD0qwH7s11OsX5pgsPyqv4 1ma202xuFXd5N9HJ1AxgMep6fXt79K6WgDGa2125hdbi7s4FKkFLeIuTx/efj/x01mW3lalrdxos 9xNdxWttFIZHCxyW0vBG1kAIJUqfw9yK6mVd0LrnGVIzgHH58VynhKYXWv8AiG84LTPCSV6YAbA/ LHbuOtAHQxR6hAQjSw3MecbnBRwM98ZDHHsOa5jRIn8T6/Pr07q9nbv5VjEeV4Od5HHzcg89CR/d FdH4gdo/Dmpuv3hayYPp8p5qp4PQR+FbEBs8OT14Jdjjn06fhQBqpaoJVmkzJMoIDt2z1wOgqeii gDk/EEza1r9t4ahYrFt+03rq3IQHhf5ZB/vKa3LqW20XSwkEccYUFIYxwC2Ccep6E+px3Nc1PeJ4 f8c6lfagsiWlzAvkuil8sFUEYAJ524/D3409LS4128i1m9i8mCNStrb5JBBwfMPTJ4GOOwI9SAWP CupXOq6DFc3jK1zvkVyi4HDHAx7DA/CtquT8IyCz1DV9GdNjRXDTRBjyyH5eB6DCnPfePqesoAK4 3x3FPZPpev2gYy2FxhwDgFGHOc+vK/8AA/pXY7hu255xmob20jvrKa1mAMcqFDkZ60APgmjubeOe Ft0Uih0b1BGQakrm/Bkrx6ZPpU3E2nTNCRuJ+QnK8+nJA9lrpKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooATApCpPfH0p1FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABSYFLRQAUUUUAFFFFABRRRQAwhugNKFPUnB9qdRQAgGBQTjnBNLRQAgye 2KWiigBCM0AAdAKWigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACuIKDT/AIwK+4Eajp5UA9mHP8of 1rt65DxajWviDw5qq8LFdeQzk8KHwOn+7voAf4pWSfxJ4YtUkALXTzbduQwTaT+mfxrrK5e+tZbj 4haZMMGK2t2boTgsJFP06p/nFdNJIsUbSOcKoJJ9BQBjeL52tvCWpur7WaAxg+hb5R/OuSIlu9C8 O+GLK4Alu41ub4j7yI37w+w+Ziev8PvXQeNr+wfwvdWrXEby3EYMMavkyEEEdO2R1PH8qqfDvT41 0ltTmWNr+U+U5zlokUBQmewO0Nj0Kj+EUAdfHHFa26RoqxwxIFUDgKoH8sVkaFEt5FeapNGSdQfC h8/6hcqgxnGCCW467u9M1u7e9uU0KzcebcKftTgZ8qLHPI6MQeM/pkVuRxpFGscahEQBVVRgADoB QB5ppdpNaeI7DRZS7DTL+WSPDDDRyLuGRn1+b/gWK9NrntW8OSX3iXTdWt7hYGtuJTjJZQc4A9+h JPHvXQ0AFFFFAHP+NbdbjwpdqVUsChUsM4O4DP6mugrL1WyuNSktrcrGLNZlllbzDlgvIXbjnJx3 7fhWpQAVyvgmJEg1Fk2kG52gjnIAAGTgAn6f/WHVVR0zSrbSIZobUMElmaYhjnBOOB7cCgC5JGk0 TxSorxupVlYZBB6g1xujaovha6fQNXYxQKS9pdMMRspOSpOOOTnJyMkjIwM9pUc0ENzHsniSRM52 uoIzQBSfXtJRN/8AaNs4IJAjkDlsegXJP4Vdhl86IP5bx56Bxg/lUVtp9nZkm1tIISeCY4wpPOe3 vVmgBkkMUwAljRwpyAyg4PrT6KKAOY8T6TeG6t9b0hA2oWvWMjPmJ3H5ZHHJyO6ipoPF1rdQbYLO 8N8eBaNCc592AKgepzx6Z4roaMc570AUtNt7mGAyXsiyXkp3SlR8q+iL/sj9eT3q7RRQBXWwtl1B 79YgLl4xEzgkblByAR0OPXrViiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKO9ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFYHjOwS/8LXgY fNAvnqR22/e+uV3D8a36CMjBoA47wpe3Gs63cajKylEtI1wBgb2A3Yz/ALUbfgVrsay9E0G10KKa O2Z2819xZ+oHQD8K1KAKNto2nWd1LcwWkaTSnczYzz7en4VzTeEdV0y9nfw5qq2VrcHc8DKCFOMA KCpH48HAA5xXZ0UAY2geH49EilZ7iS7u5jmW4l5Y+w9BnJ+pPsBs0UUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFGecUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUjMFBLEAAZJJpa5bx3Nu8Pz2KQ+YZ9pfOdqJvUFmx7kDHU8+hoA6jOaWq2nQm 3021hZizRwopZupIUDJqzQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFJg7w244xjbxj60tFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAJ16UtIc9gM+9RM0gyQp/AUATZorl9W8SPBM lnptsb6+l+VBuARfUtjk468DseRzWf4a1XxHquuOZp7OSwhJW4EMeFB2kqEbqTkj2xn2yAdxRQKK AEJIHAzXJeOo2h8J3JRSXeWMu+ASTngn8cD8q66sDxsceEL5tu4DyyRtyMb15PsOpPYZoA1NMdX0 mzZAQpgQj6bRVus/QWLeHdMYkkm0iOT1PyCr0kiRRtJI6oijLMxwAPUmgB1FQ213bXkZktriKZFb aWjcMAfTjvU1ABRRSFgOefwFAC0hIHJ4FIDnpSkE9qAE3jPt9ab5q5HI596gvZo7S0mup22xRIZH wCSAAegHU+1cikXiPxM7XdreLplkpYRBRlpD2J9e4PUeg70AduJFIBHOfSlyPWua8KancX8Nxaak iDULN/LmAH3hyA3AxnIYHHHGe4rpNqgZ6D60AOopMjsc0tABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU YoAKTkE559OKWigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAK4rVNbvfEGonRfDzgxLhrm+DjaozyB+n1z6AmrvjK9vSlno unqPtGpMyM5YjagxkccjOevoGrS03QLbStJGn2pKKw/fSrkO5I5OQcg+mOnagDnLLSYtRe40/S32 2Kny9Q1I/NLdOD80Sk9Fxxnp2+vZWdnb2FrHa2sSxQxjCqP88n3qSGGOCFIYUVI0UKqqMAAdqfQA UUUUAFZPiaCO48M6iku7asDSfKecr8w/UCtaobuAXVnPbt92WNkP0IxQBR8NSiXwzpjhs/6Mi5xj kAD+lZ3imd5b3SNIXd5d7OfPAbbujA+ZT35BJ/4D260eBLjzvC8URGHt5Hicdwd27B9Dhh/+qodR d2+I+kRjlBbuxAHTKyDnnjtj8aAOht7S109StpaxQxsclYY1UZ+g61ZDZ7EfWuaj0b/hIYWu9Ru5 mSRyYYoXKLGvIA+vqcZyPTAEcsV14WurSRLuS40ySUQyJPL/AKrP8eT6EdsDk8d6AOq61yni1p7+ +0zQLafyReuzXDq5VhGozgEeuDx3x1rq65aOaG8+JU0fyM1nYgcqMqxIOQf91z6de+aAKWj32oeG 9cTQdYuDPaT/APHjdytlgc/cYnrntnkHjkFcdtWV4g0O317S5bWZE3lT5bsPun/A9DWf4f8AEcR0 Vl1eZba8sj5Nx5zYLEA4bnrkA59w3pQAeOr9rHw0+xSWmkEYIOCpwWDA9iCuRWxPcWWh6WHlcQ20 CBVGMk4HAA6k+w5rhfGviqx1LSjBp0c9yLdxLNKIyscakMvJI65OO31rasPDx11oNY16VLouokgt 4z+6RDyAfXtx7clqAH+E4Zb7UNT8RTxhBfsqwLjkRrwD364H1IJ6YrqqRVVFCqoVQMAAYAFLQAUU UzzY/O8oMDIBuKjnA9/T/wCsaAH0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA YHiXQrjU1t7zT7j7PqNoSYXPQ5xx+g9jyD14zIvFut2mYtV8M3TSLwZLMbkPHv0/Mj3rsqKAOKPx JsCcf2Vq6nOM+Shx7/f6UjfEmxUZOkavg5wRFGfT/b9x+Y9a7aigDjo/iToTsocXsWepe2Jx/wB8 k/pXVWV7bahZxXdpMk0Egyjocg9vzzxjsaxPFes22l2fkraR3l/cfLBbsgcZ7M4/u5AHucAe0/hT RjomhR27grLIxlkXOQrN2H0AA+uaANuiiigDntCzY6nrdrMUSNJ/tCtkBcMMn34G3NUvFcslpeaL 4giR3trR2M2I8tscAdDgj5S344FdFcaVY3d3HdT2yPOg2hjnp6H1H1qa7tYr2zmtZ1zFKhRvx9Pe gBttCkZd4ZS0Mp3heCozySpHY9e/tWJ4yukj0mOzURPdXkyxQwyE/OSQDwOSOQD9fpVGHw/4m0mN bfStbie1Q/LFdJu2r6A4JAAwAM49qu6V4WaHUF1TV72TUdQUDaz8JGcdVHQd+gA56Z5oA6MjIxk/ hXn2m6vp1h468VXdx8sqmCGJUId5TtO4AD/cHXpzz1r0KvOPCn2zTfEviGRrRtSka52vcROu8fM5 xtOAM4HGQOB6UAbz3PinWFBs4ItItzg77gbpiD7cge4I69+KwB4YtNN8badDdg6h/aMT+dLOWyXV S2f0GMk9TXVz+I3iIRdG1IyNwgaNVB/HJP6VX07T7zUfEA17UYjbiKIxW1ueoyTlj+B6e/sKANS/ 0a1vdIudPSOOBJh1jXADZyGwMZwQD71y3hjW5tEvx4X1vMUiEJZTOfldeyZ/9BPflTgjB7qs/VdF 0/W7cQ39ssqjO0nqv+fTpQBoZrOv9e0nTCRe6hbwuBnY0g3/APfI5P5VgN8PNPMawLe3otgcmIyc Hknp0647dq0bPwV4fsSDHp8bEdn5B/4D0/SgCrHrOq+I8Lo1u9lZH797dJhj/uL3PXr+hrd07Tbf TICkO5nchpZpDueVsY3Me5/T0xVyigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAEByM4I5xzS0 UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQBXa9t0ecPKqrbqGmdjhUyM4J6A459gQe4rAfxJJqt59i0WOR0I+e72dB6oG 4/4E3HoG6F6+EVllZr+/muYzJ5pixtUvnrjJ+mevoQOK37e2gtYhFbxJFGOdqDAz6/WgDG0TwzDp kv2y5kNzqDKA0zEnHXoTyTyRk849K3qKKACiiigAopM+1L3oAKKQnHp+dJnHGD+dADq43wcG/wCE l8VM3/P2B+TSc/r+n4V1rPkf1z/hXG6I5tviN4gt0wqyxRz7F7nC8/X5j+f0oA7eimK3HOfxFODA 9OaAFoppcAdQPrxS7vxFAC0Umf8AOKQnPSgB1FJt/H60tABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR24ooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooOe1FABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABSZ60tGKAEz7UZGM5FIVJPpQV5BHWgBS2Pek3c4H6ijZnqTTqADN FFFADdv69aNvPGKdRQA3G0fLgD0xTQgY8gAemOtSUUAN8tQcjisUaA0fi9tbimCpJB5csZySx6ce g4X16dO43KKAG7evpQVPJ706igBgjA4xx9adj/8AUKWigBO+KB70tFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUmM9aWigBAoByM/nS0UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUVW1AXjWMo094kusDY0qkqOecge2fxrIsNQ8QQTxxatpiSRSOEFxan7hPdkyTjPcHjPTvQB0FFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRSEkEYGe eeelAC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAcNeXV14g8WyaS9w1vaWz4CRE/vDjJL8/N0OB0GeQcV02k6XHpLTQwyO0RClVbt1yeOMk9 TgdvSiigDTooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKAP//Z ------=_Part_46216_11624287.1190585217822 Content-Type: image/jpeg; name="grain3.JPG" Content-Transfer-Encoding: base64 Content-Disposition: attachment; filename="grain3.JPG" X-Attachment-Id: f_f6y3ny0s /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0a HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAKAA5ADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAO+KKK KACiiigAooooAKKPxpCQOSeKAA57D8zS8496QHr160c+mBQAtJkDrikI9Sf5UcE+4oAAQcYxR1pc e1GKAEzzRg+tOooAToDRz6/pS0UAJzS5opGYIhZmCqBkknAAoAXrWDrPiSOxuBp1hEbzVpMbLdOd g4+Z+eAAc/l0zmqNxrN94hlez8PMiWoJSbUmyQp9EGRng9QfyyGrR03SNP8ADlnJIrHcVLTXdwwM knfLN7cn06/WgChp3hyV71dY124S6v1O5Ez+5tsdlHcj17EZxnmrU17dapO9npcsYiVitxeAHCEY +VR0ZvxwO/8AdK759fIEZe30kjPnLIVkuRxjb3VCM/NwT24O6tqG3ighSGGNY4kAVUQYCgdgOwoA rWOnw2EHlQLgFt7MSWZ2PViepJ9f5AYq2E4xxS7F9Kzr7VPKnFlZoZ71xkICAEXn5mPYZ47+wPSg B+o6lHYqqIPNu5flhhUZZ2/zzzj1yACahs9Lle4F5qUvnXKktEgPyQZGOOm49fmI+gFTadpa2Yaa Z/PvJB+8mI/8dX0Xjp+Jyea0KAEAxS02SRIY2kkcIijJZjgCufE914lLpbNPZ6YrFGlK7ZJ8cELn ovv+XsATXWrT3l21ho6h5EOJ7hgfLhHcA929qv6dpkOnJIVZ5Z5m3zTyHLyH39AOwHAqe1tLext1 t7WFIol6KgwPr7n3qagAqtfX9tptsbi6kCJnA4yWJ6ADuT6VBqerRaeEiVTPezZEFsn3pG/oPUng DJqvp+kS/av7R1WVbm+xiNQP3duPRB6+rHk+woArx6fda5Il1qytFZg74tPIH4GX19dvT19K6Cik LAAkkADkk0ALWHdapcajcTado5HmRsEmu2GUh9R/tN7fy4NVpLu78SOYtPdoNKVsSXqkBpcdRHnq M8E9PqcgbtnaW1hZx21pEsUEYwqr0HOfxOckmgCPTtNt9NhZYMs8h3yzOcvK395jVyisq+1jy7o2 FlGLi+IyULYWIf3nPYcjjqaALOoalBp0QaTc8rnEUMY3PIfQAVWtrGe6lS71UIZFIaK2U5SE8YJ/ vN79u3rT7HS0t5Xup5GnvZBhpm42j+6g/hX2HXvWiSB/9agBarX1/babavc3UojjXue59B71Uv8A WorWVbaCJ7q9bpBF1A9WPRQPUmq9lpU7XSXupyrcXanKKB+7hPP3M8k47n8BQBF9lvdffdfBrXTD jFqD88vf5z2Ht1PtznfjRI41SNQqKAAqjAAHYDtSdBgcfSsO/wBdlku5NO0iNLi7TiWZziK2PT5j 3P8AsjnrQBd1PWYNOaOEK095McQ28fLMfX2A7mqtjpTTXi6lqria9BPlRjmO3HovqfVu5/Cn6dpU Wnl5mLT3UvMtzKRuY+g9BwOB6DrWoMnpigCQHPp+FQ3V3FZ28k80iRxRjLux4AqnqerW2l2okmdy SQEjjXLuScDA+prJg0u71e5W91ldkK4aHTxyqdeX9T0+mPwoASWa+8UZih32ekdHkx+8uB6KCOB0 5/DnkVvWlrBZWkdvbwpFBGMIijGPz5zT9u0ZOc9stRgAbiQABnJP3R/hQA4MxwSVPpjisrVNcWzm FlaKLjUZMhIFbOzABy/PA5HXHXtVSfVrrVZZbPQ9u1fllv2+4h9FHdsYP5dMgjR0zSbbS4SkK75X w0kz4Lyn1J9PbpQBT0/RXS9/tPUpvtV7/DtJ8uEeijHJ9zj2A5zsbnP3h9O1OwxPJyfSsW91h3ne z0aH7VeAgOx/1UWe7Hp+XPHc8UAXdS1my0iHzLyTaW+5Go+dz04A59qyha32tzeZq262tFP7uxjc 7nx0LsOmeu3r06cirlho8dg73lzMbm+YEyXUo27R6KP4Rx/npVGbWZr+drPQkMr52zXjf6uLIzkA /eOOR1z+ZABoahqtloNssW35wgEFrCnzEZwAABgDPH4cVlx6XqOuTLc63K0VsMbLCJzj6uevPPHo e3IOlp2irYu1w7vPeycvPIMt9B6D2H49qq32tSC8+waRGLu+x88j/wCqhHQlj6j09vwoAv3eo6do FpGJdkSgbYYI8ZI6YAHb/GqC6Vf+IJVm1oPb2iklLFGwGyBy5HXv78ds1Lp+hxaez6jqU/2i9I3S 3Mh4UDsvoAB16nHboOW1rxXqHiDUZND8Jx+c+MTXJxsUZ53H09vfueKANPxN4xs9Chj0vSkE13hU jhgH3R0VQB64xxz6c9Kvh/wJcXs66t4qLS3JJZLUyZCd/mIODzz3znn+6Nfwl4NtPD6G5mJu9Scs XupOo3dQvoPfqfbpXWdKAECKqhVUBVGAAOgpCoIPbPpTqRmCqWYgADJJ7UAIEAHQUEYya5O78Q3u uXj6X4bQlVO241Fx+6h9hzkt/s9fdRg11USMkSLI7SOqgF2wCxHc4459qAEwxOSAcdOOlDMVXnqe mDmpMUmM9fyoAaAcdCT6+tPFHSm5LdOnrQAhlBOEG73zQo6tjB9qcFA6CnUAIBjuaWiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiijvQAUnfOT9KWigBvrxkelKMY4GKWjrQAnSloooAKKKKACiiig AooooAKKKydY1+30oLCim5vpDiO1i5dvfAyQMUAWtT1S00ewkvL2URxIPxY+gHc8Vzf9n6l4wYS6 n5tjo4YFLIErJOBg5k9BkdPy7Mb2naDc3F6mq69KtxeLgxW6/wCpt+c8DuwOOfUDqQDWze30FhD5 kzck7UQcs7HoFHUn2FAEUjWWiaaMLHb20K/KiDAH0A9/zz71nxadNrbpdarF5VurBoLP1A6NJ68j IXt3yeFt2tjLcTpf6io88AGKAYKwf/FN156DoO5OnQAgUD1/OloJA6nFYslxca0zQ2LmKxDbZLtT y+Ooj459N3Qe56AEk9/NezvZ6ay7lIEtweVizz+Le3ocnAxm3Yabb6dGywrl3OZJGxuc+pP8h0Hb FS21rBZwLBbxrHGvRR/M+p9+9TUAFVdQ1C20uze6u5Nka8dMliegA7k+lRanqsOmxLlXmuJDtit4 +Xkbnt2HB5qrYaVcS3SalqzrJdrnyoVJ8u3B7DsW7bsdvxoAjis7rW3hudTj8i0Q747LuxxwZD+f y/n6VugAAADAHQUUUAFYt7rTvetpmlKs96B+9c8x249XPr6L1P51DLqF3rcrW2kExWgOJb89yDys Y7n36DmtXT9OttMtVt7ZNq5LMT1dj1ZvUmgCDStHj01Wd5XubyX/AF9zL96Q/wDsq+ijgVpUVU1H UrbS7Uz3L7VyFVRyzseiqO5NAE1xcQ2sDzzyLHEgyzMegrBWG48UKJbnfb6TuzHEOGulI6t6L6dC c9uCX2+mXGr3AvtZQCEHMFieVQesnq3t0HfPG3oKAGRxJEioihUUAKqjAUewFPxUc9xDawPPPKsU SDLO5wAKxc3fiEHBa20lhjPIkuB/NV/U49DQBJNf3GqzSWmlMEiRts171VT3VB/E3v0H6G9Yaba6 dCyQRgFzud25Zz6se56/nViCCK2gSGGNY40GFVRgAU25uoLK3ae5lSKJerMcCgCQ/KOv4msGfVLn UbhrPRwDhts126HZFwPu/wB5sY4/lijbd+I1DHzLTSyc7CpWWcdv91T/AJ7Gtq3torWBIII0jiQY VEXAH4UAU9O0uHT0by90sznMs8nzSSH3Pp7VcZ0iiZ3cJGgyzPwAB1P0qO/1C10y1a5vJliiBABP Uk9AB3PtWL/Z934jlE2qJJbaavMVjnDSc8NIeo6ZAB789OQBHu77xDL5Wmu9ppg/1l5j55/9mL0H qx/xrYsbC3020jtbWIRxIOAOST6k96txxrGiooAVQAABgAD0HalJCgkkADkk9qAG4AzwB+GKxtS1 porg2NhA11fMMhFxtT1LHoMf4eoBZdX91rMsllo7hIlOy4vSDheOVT1bkcjt3HBOlpulWulW/k26 scnLyOdzOfUmgDP0vQBBctqF9KbvUHAzK44j46IMcdcZ6n26VtCMDOOvvT6oalqkenqqiN57iTiO CIZZjz+Q460AS3dzBY27XFzIkcadSePwA7msGOO/8Tuk0ytZ6RkMkWcST8dSR91ef047NV220ia7 u47/AFgrJMhDQ2658uE+vXBYevr64GNugCCC1itYUht41jjQYVFGAKLmeCzt3nuZVjiXlnbgCodQ 1OHT0AZXmnfiOCIbnc+w9ODz7VSh0mXUJ0vNZ2yOvMVoOY4fr2dvfp6dAaAKzfbfEfyxCSx0o8+b wJLkH+7z8q98kHPGKtzzaT4a04J+7t4F+7Gg+ZiePqfqfzpt7rUjym00eD7XdZ2s+cRQnBwXb6jo OevfinafoEdvc/br2X7bqDcmZ0AC9cbF/h4OPX+VAFH+ztR1992oh7HTwwKWsb4eTHQuR09cdfYE ZrbWO00yy4EdvBEvYYVRTdR1O30u3Ek25mbiONQSzt0AHvzWVFpNzrM8V7rJKwq2+KxA+UDjG/1P cg+3uKAI/OvvE25LQyWGl9DOR+9m5529guB156j0Iqe9vtH8HaXgmOIdVjLYLn1J+vft2Has/wAU eN7PQYDb2zCW5wQNgBWMAc98cfkO/Q1zuh+EdS8U3I1bxHIy2ko3C3yQ8n1yMquDjPX029WAKq3X iL4kTGGNPseiKSskgB+bqCPx9O2ecdK9E0Pw/YaDZLa2NskcfVmIy7n1Y9Sf5VpwQRW0KwwRpHEg wqIMAfhUlAB0oorI1bxDbaa32aJXur9x+6tYV3Mx/oODnPYGgDQvLy3sLZri5lWONerMcVzBGp+M CjAy6doh+dZFIE1zzwV/urwTk9eCB0ardvoE2pXn9oeIGSZh/qbFeYoh23f32/8AHc9jgGujoAr2 Nha6baR2tlBHBBGMKiDA/wDrn371YoooAKKKKAAgHrRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUc0AFFJznpS0AFFJQQO9AC0 UUUAGecd6KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKiuLmC0t3nuZo4YUGWk kYKo+pNcu15qPi4mHT99lo+8rJeZxJMB1VARxzkZ5HHOeVoAs6h4guLy6fS/Dyx3F2B+9uW5ht+Q OT3bGcD274NXtF8P2ujIXDNcXsmfOu5uZHJxkZPRcgce3OTzVvTdMs9JtBa2MCwxA7iASSx9STyT wOT6Ckvr77KEjijM11KcRRDv0ySeyjIyfcdyAQBb6+SyVFCNLPKdsUKfec/j0A6k9hTbSydJ2u7p xJdOAPlzsjHPyqD9eT1P5AN0/TjbO9zcym4vZRh5TwFH91R/Cv8APGTV+gApHdY0LuwVRySTgCmz TRwRGSVwqDqTVBbd9T2zXkZW24aO1cdfRpB6+i9up56AEe19b2sSyaYy5Azhrj+oTn6n2H3tVVVF CqoVVGAAMAClooAKytR1SRZvsOmos9+wyQT8sS8fMx7deB3pk97cak8lrpTqqqdst5wVQ+ij+Juf oK0LKyhsYPLhBJJy8jnLyN3LHuaAKunaPDZTyXcjG4vpv9ZcP1x6KP4RwOB6DPStKiq95ewWNuZp 2IHRVAyzH0A7mgCSeeK1geeeRY4kGWdjgAVg7brxMwZ1kttG/unKyXQ4wT3VCO3U/kRPFp1xqsyX eq5WFTuhsQflX3k/vN7dB71t0ANjjSGJIokVI0AVVUYCgdAB2FOorKu9Vd7r7Bpsfn3X/LST/lnA PVj6+g/woAl1LVFsWigjiae7myIoU749T2Huf6EiDTtHkS8OpalIlxqBBVSo+SFf7qf1P16ZObOn 6XFYs8xZpruX/W3Dn5m9h/dHoB6Dr1q9QAVUv9Rt9NiV5ixZ22RxxrueRvQCo7zUGjnFpaR+deHB K87Ywc/M57Djp1Paiy07yZBc3MhuL0rhpW6L7KOgH60AQQWFzezJdaqQNrborRDlI/8AeP8AEw9e g7VrUVmS3094zwaYASCFe6Yfu09dv95gO3TkZNAEuoapHYtHCqNPdzcRQJ95j7+g9zVe20qSeaO8 1Z1nuFO6OJQRFF6YGTk89T+AFW7HTobEMVLyzOcvPKd0j+xPoOw6VboAKoahqsVk6W6I097KD5Nu nVvcn+FfUmorrUZprh7HTI/MuFOJJnBEUXrk929APxqfT9NisQ8m5pbmXBmnf7zn+g9AOBQBXs9J droX+qOlxeKT5W0fJAp7L+Q5PNatFU9Q1KDTod0hLSH/AFcKAs7n0AHJoAnuLiK1geeeQJGvVj/n r2xWGYbvxGyPI72ulBsiIAiS4APc9lP68+xFi30y5vZ1vNYdWI5jtE/1ceQR83PzNg49OvtjZoAZ FFHBEsUUaxxqMKqDAA9hT6ZNNHBE0krhEXqTWSJbjXGIhYw6bnBkBw847hfQZ79x0oAfdanPcTvZ 6SiSzqPnmY/u4s56nueO2eo464n0/SoLBnl3NNcyffnk5YjOcD0H+AyTirNrawWVulvbRLHEgwFX /PJ96Lq7gsoDNcyrFGP4mNAE1Zkt/NeSPb6XsZlJWW4cZSI+gH8Td8fTJGahCXWtqfOSaysc8Jkr LMO+7ug9uv0wDU15qNppCRWkMW+dxiC1hXk/gOg4PPsfSgBYrWx0eKS6mkBlP+suZTl2z2+nA+UV Xf7ZrgMYElnp5HLHiSYHsP7o6Hvkcdzh9vpcl3Ol7qxEko5jtv8AlnD6cd29+n1wDWvQBDbWsFnA IbeJY4x2UdT6n1PvVW81MRXAs7VPPvXBwo+6n+057D9enqKrSahPqsr22ksFiUlZr0jKqf7qD+Jv foPriiW40vwvp+HkCljn5mzJKxPLHufr0H6UAFlpMNi7anqUq3F/gl7hxxGMYwg7cEjPU59MAcr4 l8ZXNzK2maPDIxYkFx96QAchRjJb0HfjPWq2o6hrXibUvsVrEqOoDC3JYeVno0rD7hAJyPvdRgHg 9hoHhi00SJHbbc3wTY10yAHGc7VHO1c9h+OaAMbw34HS2nj1TWP314cOtuxDJE3ByxxhmB9PlB6D gGu1oooAKRmCjLEADuTVXUNSs9LtzPezpFGAfvdTj0HesZrG+8SNv1DzbLSyAUtF+WWbPXzD/CPY c+uOhAEk1e81y4ez0IGOCMlZ9QkHyof7qD+JvUcY6HHStfTdItNKjYQKWlkx5s8nMkhHTcf5DoOw q3DDFbwpDDGkcSDCoigBR6ADpT6ACiiigAqCa9toJ44JZ0SWQgKpPJzwP14rG1HxE5vDpmjQi7vz wzZ/dQ+pY+3/ANbrwWaZ4aeLVF1PUrg3N0nzL/dWQggsP+AttGR6nA4CgHR0UUUAFFFMlmihCmWR UDMFXccZPpQA+iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKAA/WkP1paKAEowfWlpMZFACZI9Pypc0tJjvmgBaT86WigAooooAKKCcDJ4FFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVHVdXstGtGub2UIuDtUfecgdAP8j1qnq/iKDT5hY2ym 71WQfurSPqfdj0UdOT+g5qDS/D0v206rrksd5qRP7tVyYrcdggOMn/aIz+OSwBVg0u+8TSi716Mw aeG3W+nHgsMcGX/4ng9QeCVPVKqooVVCqBgADAApay7vUJJbs6dp21roAGWQjKwKT1PqTg4HqOwy QAPvtRdJ1srJFlvXBODnZGPVyOnsO+DipNP06OwR2LtNcynM07/ec9h7KMnA7Z9SSZLKxhsIWSLc Wdi8kjnLSMepJ7/06DirNABVa9vYbCESTEkswSNFGWkY9FUdz/8AXPQVHf6ilntiRGmupDiKFOre 59FHcngfiKbZWDxym7vJRNeMCMjhIx/dQflk9Tj8AAFvaSzTLd34UyjmKEHKw/4t/tfgMZOb9FVd Q1C30y1M9wWwTtREUszt2VQOpNAE800VvC800ixxoMs7HAA+tYh+0+I1xh7bSW5DZ2yXAxxx/Ch5 68nA9eFt7C71hhc6zGEg3Zi0/gqoHQyHu3t0H51u0ARwQRW0KwwRrHGv3VUYAqSisnUNXdLkafps aXOoHqhfCQj+85GcfTqaALGoanFY7IlRp7uXiG3jxuc/yA9SeKistMdbv7ffyrPelcKFHyQjuEH9 Tyfan6dpMdjI9zI5uL6Ufvblxgnpwo/hXgcD0HXrWhQAUEgDJOAKZNNFbwtNNIscaDLMxwBWEDd+ I2Bw1tox54JWW6H4fdQ8e5GfXNAExv59WuJLbTXaO3TiS9CgjP8AdTPU+/QflnSsrG20+38m1iEa Z3Njqx9Se54HNSwwxW8KQwxpHEgwqIoAUegA6VFe31tp1s1xdSrFGOMnufQepoAnZlRSzEKoGSSc ACsw3c2pO0NiSkAO17vjt1CDuffp1qCOG91qQS3atbaf/DakEPJ7uQeB7fnWyiLGgRFCqowFUYAo AitLSKygEMIOMkszHLMT1JJ6k0+eeK2geaeRY40GWZjwKrahqkGnIA+ZJ3/1UCcvIfYf1qC20+a4 nS81Mq0qndFApOyE/wAmb3xx29aAGBbrWhmVXtdPJ/1ecSTj/a/ur7dTz2NakUUcEYjiRUQdAoxT 6q6hqFvptqbi4Yhc4VVG5nPYAdzQBZd1jRndgqqMlicAD1rGNxda4Wjs2e20/o1z0eb2j9Bj+L8u lJFZXWrsJ9UHl2u4NHYgdQOQZD3Pfb0GBnuK2wAAABgCgCK3t4rS3SCBAkSDCqOwqWkZgqlmICgZ JPQVhPqc+tXElnpJK2y8TX+MqD/dTkZPuOg57gkAtX2rMlyLGwiFzenqM/JEPVz2+nX9Myafpa2c stzNK1xeS/fmYYwPRR/CP5/gMS6dplrpdsILWPaDy7nlnb1Y9zVokKCSQAOSTQAtZ2paxb6aViO6 W6kB8q3jBLOfoO3/ANf0NVJdXuNQuWtNFVHCHbNeOMxxn0H949/y6A5FvTNGt9NLygtNdyD97cSc u3t7D2/PJ5oArJpMuozC51jY4HMdovKIMYw3948nI6fXAxtUjMFUsxAUDJJ6CsOfUrzVJDbaLsWM HE17Kh2J7ION7fjgd+ooAu3+qx2kgt4Ua5vH+5BH1+rf3RyOT61Ha6UWuBe6kyXF3/CMfu4ec/ID 39zz9KfbWdjolrLKZCN2DNczvudz2yx9ycAcZPA5rN8y98S4MDy2WksP9YBiSce2ein17g96AJrz Wbi7uWsNEjWWYDEty3+rgz3/ANo98fz5xf07TI7BCzSNPcvzLcSfec/0Ht7d+tWLW0t7K3WC2iWO NRgKv9fU+5qvqmq22k24knJLudsUaAlpG9ABQBZuLiG1haaeRY416kmsLbeeJSrNutNHzkL0luh9 c/Kh/MjkdQafDpk2pzC/1wBY4yWhsmKlIx6ue7Y7ZwPfjGTrXiuS7kls9HnjhhiYLdahJ9yEdSBy CWx0UcnPYfNQBf1fxPbaWw03TIRcXiocRR4CRKByWPRQO5JAHeuTsrPUvE+pSm3nYyRv/pGpEFUh J6xwggEtgKd/BAwBtB+afQfDsutKrwmez0GTDu0hBuL7nK7mAGFGeMcDJxyS1ei2trb2NtHbWsKQ wRjCxoMAUAVdG0Wx0LT0s7GLYg5Zzy0jYxuY9z/+oYHFaFFVNR1Oy0m0a6v7mO3hXjc56n0HqaAL dYt94hjW5k0/TIzfakvBiT7kR9ZG6KP1OOATWep1jxSVcedpGjNng/LdXA+hH7tTz/tcds5re03S 7LSLRbaygWKMdeSWY+pJ5J+tAFHT9Df7SuoavKt3fj7mB+6g9kH/ALMeevTJztUUUAFFBOBWJrXi W20orbRI11qEh2xWseSST03YBwPwJxk44NAGrc3UFnbtPcyrFEvVmP8AnmuX+26j4t+SwEtjo5ID 3Lr88w7hRnoenoO+eUp1toV7rFwt74ik3gHMdguAiDJ+/gkMenGe2CWrqVChQFXCqOAOB+AoArab plppVottaRhVHLNgbnb1Yjqf89KuUCigAooqveXsFhbtPO4VQOBkAsfQZ70APuLmG0gaaeQJGvUn +Q9T7Vj2kcus30WpXClLSIk20RH3/R2/p/nNe3trjXrpb6+Vlshkw22MbwRwW56cn68fw/e6NeBw eBQA6ijOaKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKMUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFQ3V1BY2sl zcyrFDGMs7dqAJulcvea9c6xePpXhxlZ0JW6vjylv6Af3mJH/wCsciCSTUfGLFLUvY6H91pzjzLn 12jsOoyeO+G6Dp7GwtdNtEtbOFYYU6Kv8yepPueaAKOiaBa6JEzITPeTc3F1J9+Vs5/AZPT88nJO tRWVJcSatI9vYymO2Q7ZrpRnce6Rnpn1bnHTr0AFuLya9ney019pU7ZrsAMID12gHhnPp0GcnsDa sNPt9NthBbJgZ3OxOWkbuzHqScdTUttbRWlvHbwJsijGFGc/qeSfc9aloAKzb7UmSb7FYxie+cE7 c4SIY+857D0HU9u+Ip9Rlvp3stLwzIwE1yfuRDuBjq+O34nAxm9Y2EOn24hhBJ6vI/LSN/eY9z/k YFAEen6clirOztNcyYMtw/3nPp7Adh2+pJN2isfUNVnad9P0iNJr4D53cHyoM/3yO/t1oAn1LV4r B47eONri9l/1VtGRub3Oeg9z6VDp2kOlz/aOoyeffsuAM/JCP7qD9M/yyczaZo8Onb5SzT3kv+uu ZPvOf6D2+laNABRTJZY4IXlmdY40BZnY4AA7k1z3n3ficlLYva6P0acHbJceyei+/egB95qV7q87 2GhMiop2T37crEe4QfxN09q1tO0220u2EFsp55d2OXkbuzHuamt7eG0t0gt41jiQYVVGAKloAKp6 nqlppFm11eSbIwQoABZnY9FUDkk0zVNWg0uJN/7y4lbZBbqRvlbIGAPQZ5PYVT07SbiW6/tPWGEl 4eYoFctFbD/ZB4LerfgO5IBHb6fda1Kl5rMQjt1O6DTzggejSere3QfXpv0Vg3GsTajctYaKQzqc T3ZXKQj2/vNzwP8A65ABa1TWorGRLWBGub+U4it0659WPYdz7e1MstGc3Qv9UlW5vcDYACI4fZR6 +/sOAc5n0zSINNQsGaa5f/W3Ehyzn+g9v5nmrskscMbSSuscagszMcAAdSTQA+sm61d5LhrHSo1u bsf6xy2I4O2WPc8fdHPHaqslxeeIcw2DSWmmnKyXZG2STpxGD0HX5j+HStex0+00y2FvZwLDFkth e5PUk9Sfc0AQ6fpUVi7Tu7XF5IMS3MgG5vYY6DjoKv0VhXep3OpSPY6IRuAxJesMxRew/vN9OP6A FjUtYFrcJY2cYuNQlBKRZICj+8xHQdPzpNP0YxXI1DUJftWolfvn7kXHIjHYdRnqefU1Y07SbbTE bylLTScyzvy8h9Sf6VeoAKr3t9badatc3UojiXuepPoB3NVNV1u30oJGVae6k/1VtFy7/h6cH8j1 xVSx0W5uriLUdblEtygPl2ycRQ5Pp/Efrx06kA0AQpFe+JgklyJbLTA2VhB2yTDj7x7Dr0+o/hYd BBBFbQpDBGscaDCqowBUlYmo6/5d0dP0uH7ZqIwWjHCRr6u3Qf56nggGhqOp2ul2xnupNowdqgZZ j6Af5FY4sr/xERJqHmWenHayWgOJJMHOX7r246/7pHNnTdDaOb7dqk4vL8gYJH7uHvhAf5/kBkit qgBkMMdvCkMKLHGg2qqjAAqvqGpWumW/nXUgUdFUcsx9AO5qtqmtRWLrawobnUJVJitk6nA6k9AO nJ9fxqLT9IZLk6hqUy3N+c7cfcgz2QfTAz1PtkigCBbK+11hNqYezs85js45CHcZ6yEdOx2j8+oq 9qOp2ujW0a+WWkb5ILaFfmc9gAOgqtqetPHcHTtKjW41ArkgEbIQf4nPbrnHp+AK6Xo4s5Wu7mRr q/kGHnf+Ef3V9F/z7UAV7bSLzU7hLzXWB2kNFZRn93H/AL3Pzn9Oe/GOipmexOKy9T1gwzfYLCMX Gouu5YweEX+857D/AOtwc4IBNqerJYbIo4nuLuXiKCMZLH1J6Ae59z0BqgLa20pZNZ1q5SS8x98f diH92MfpnjPPTJqld31j4Sh+03ri61q7AVUTLPISeFQdcZIHHX8OOevppH1KG61mJr3VZWX7Jo8T ZSI9mkI+8R1x0AyTnGQALreo32qxJeahI1nobhvs1vC4FxdcYBXPAU/3j2PA+YNWhofg9r/yLzWr ZILaED7JpKA+XGN24NJz8zkgE55OBu54GzoWg3EVy2qa5cC61SQ8AH93AM8BR03Y6n8u5PSUAIKW q97fWunWz3N3MsMKDJZq5N7nVvF7YtJJtK0TIBnZMTXPP8AP3VwOG9+M4oA0dS8VKl22naNavqWo jAKxnEcXu79qTTfDWbxNU1y5/tDUVOUzxDB7Rr+XJ54yMVpaZpdhpFqLWxt0hiHOE6sfVj1J9zV4 ttByfp6mgB/Yc596bv3HAqMkO3Dc+gOKODxwf1zQBLnFNeZY0LMQAAST2A9SfSqOpatZaPaPc3so jjU4UcZc+i+v9MZOADXOfZtR8XhZtR87T9JyClqrYecZzlvQcf1AHDEAku/EN7r00ll4bC+WPkmv 3yoXIzhOM+nucggYO8aGiaDa6OjyIzy3Mg/e3Ei/Mx74H8IJ7ck9yTzWla2kFpbx21tGsUKDCouT +Z7n1JyTVgjB53fU0AIDjoD7nFPDufT8OaACOeT7ZzSj6fSgBwLelLkUwDuBk/Wuf1HxC8tyNO0Z fPu2GS4+6i5xuyQRj3wfYMeKAL+r67b6Wvl/626YDZCvJJJwOnqewyT2FU7LSLi8uhf6x88oO6O2 yCsfpnkgkegyM88kAhNL0SCzb7TOWnvnBLysM7c8kLnkD1PU9zgADZXA4G4c9qAJ8qqnJwB1Jpwr kNf1m41K5bw7oo33cg/0i46x2ydyT6/Tvx6kb+lWp0/TIbJrhrhYF8tWcANsBO0HHUhcDPfGe9AG hRTd3HXP0pRn8e9AC0UmcUZzQAtFITilH1oAKKKKACko9cn8qWgAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKwtW8QGC7TS9LjW71SQHEY5WEcfNJg8Dn2/MgEAt6zrVtoln58+53Y4jhTlpD6Af5/MgVkWek XuvXK6lr42W+c2+mn7qLjrIOhPt+fXaLWjeHDaTjUdVuPt+qsOZWHyxEjkRjt6Z4z7Dit+gBAAqh VAAAwAO1KTgZPSmTTRW8LzTSLHEgLM7HAA9TWPGsviAiSZXi0r+GF12tc+7A8hPbgt3+XhgBXe51 u48uFjDpIH7yZThrn/ZQ9VX1bv0HqNeKKOCJIokVI0AVVUYAA7U5VVFCqoVVGAAMACo7i4htIGnu JUiiQZZ3OAKAJSQASTgDvWO80uuborSRobDJWS5QjdJ6hPQep/AezVin10+Zco8GnZBSBgVkmwc5 b0U/3ep7477CIsaKiKFRQAqqMAD0FADLa2htLdILeNY4k6Kv5n8c85qQkKCSQAOSTVe+v7XTbVrm 8nSGFerN/nmseOG/8QTGS8Sex0xThLYttkn9TJjovsCO+eMUAPkv59cmktNKkMVqh2zXwHU/3Y/U /wC10HvxWrY2Ftp1uIbaPYvUknLMfUk8k1NFFHBEsUSKkajCqowAPpT6ACq99f22m2j3V3MkUKDl mOPwHvUepanbaVbefcs3J2pGi7nkbsqjuaz7PS7i/uU1LWkAmX/UWgbckH1xwze/SgCCG2n8Sul1 qMLQ6WMNDZP1lIOQ8g9OmF/OuiVVRQqqFUDAAGABS0UAFZOqaw1vOthYItxqUgJWM/djGM7nPZf8 RjqKiu9VuL28fTdGZDMg/f3bLujgz2/2n9vzq5pek22lQsIQXmkO6a4k5klb1Y/ieOnJoAh0rRhZ Sy3l1ILnUZ+ZJyMYH91B/Co/Xv2xozTx20LzTOEjQZZj2FV9Q1KDTolaQO8jnEcMY3O59h+XPTms +LTJ9UmF1rA+RXzFZZ+RcdC394/49ugAIVkufE4PlmS10oNgsRh7n1H+yv5+h7gbttbQ2dtHb28Y jijGFUf55+tSKoVQqgAAYAHasnUdZaOb7DpsP2u/IztBwkQ5+Z27dOnU+lAFvUdTt9Mg82bczMQq RoMs7HoAO/NZsWl3WrTpd6yAsaNmGxVsoo9XP8R9ulWrDR1t7j7bdSG61BgQZn/gB/hQfwr/AJNa lACABRgAAe1Nmmit4XmmkWONBlnY4AH1qvqOo22l2jXF1IFXOFUfeduyqO5NZNvYXWuSC71mIpag hoLA5wPeT+8fboKABzdeJWKwyPbaRyrOBiS55xx/dXrz3rbtLS3sLSO1tYlihjGFRe3+J7k9SalG FAUYAA6U2WaOCJpZXVI1GSzHAFAD6wNQ1yWa9fStGQTXw4llP+rtx6sfXrjrz64Iqm99f+KZBHpz S2ekBsSXmCskwHUJ3A9/58rW/Y2FpptqtvaQiOJecDufU+p+vpQBW0rQrfTJHuXka6vpf9ZdS/eO ew/ujgcD0Gc4FX7m6gs4GnuJVjjUcsx/zz7Vn6trtvpYWFUe4vZB+5tYhl3P07D3PvVGz0a7v51v 9elLyYylkh/cxfX++R+X+9gGgBhuNR8T8Wcr6fpeSrT4/ezYP8HYD35B9CDxt6fp9tpdqttZwrFE DnA6k+pPUn3NTg49TxUV1e29lbPNPKkca9ST+n1oAsFsYB6msG71i6vrlrHRFRmTie9k/wBXD9B/ G3sPzHWqomvvEeX/AH1npTD5QPlmnHv/AHVP5+nGGrYjS20+z2qsdtbxLkkgKqj1JP8AM0AR6XpV vpscm3dLcyndNcSAF5D7+3t/UknPutUvNTuWsdGdYvLOJ71lyqeyg8E9+v5ZzVczXXiRnWF3tdJx gvjD3IxyBnovY/lyem7a2sVnbx29tbiKGMYRR2H9T3z370AQ6Zptpptt5VqjZbl3c7nkb1Zu5/Qd sVeJGeRn8TTCCRgAgjt61halq11Lff2TpDKbw482cqSlsp7n1b0XufocAE+q63cRXC6dpcIm1F+W DthIF4+Zz/wIHHPXoeBWJqOrp4ZQ2OnLJqGv3zYZyQzk8nnsoXkgHhRkk9c07/WF0otovh51m1CU GS5vpjhYxnBkd+gAJ5IHGcDJJrL0DTJtUluIdKdxC5aO/wBYmT95Lnqka9h0O3tgFs8CgCaz8+LV TBp0w1HxHMf9IvZGJislJwQufQZG4jJz7kV2eg+HrTQ1aVCbi/m/193IMu2eSF64XPbnoM5xVzS9 HsdFsVtLC3ESDlyWJaRsYyzdzxj+VXdmDgBSehH+eaAJAwXGOBnvWVrXiO30ZY4lje5v5zthtIiC 7n6DoPfpWfqPiKWa9OjaEiXGonIllJzFbL3ZiO/oO5xVzSNBh0tpLh3e51Cb/XXc33z6qv8AdXPb 8yaAKFt4fuNWlS98Tsl1ODuislB8iD2Iz859zweOO9dQA3OBk+oFNAGMYUfWn4I5HPpigBoYAdMc 8bj1puGbkKDjp0wB+dPALEZGaUgAEkcD3xigBpzjByfQYNYes+I49OmFjaJ9r1KQhUgjXdsJGcvj 0HOOOOpUfMKN54gvdbuZdN8MhXAO2a+Y4RBjJwR09j1OeBj5xs6P4es9HixErSzMuHuJTl2ycn6A nnA6nk5OTQBmaboMktymp66y3V4QGSFsMkB4JUeuD+HGRzzXRLmQ5985FS+WC2do4pxTPt9KAIwp HG0U4LgnAHT8ak2ijaKAGgHqBUc80VtC007rFGoyzMelVtV1iz0a2M10+DglUXq2MZ68DqOSQOay I9MvPEEq3Oq+ZDZg7orYEox4wCe6dz/e55K8qQCCe6vvErtDZsbXTkOJJyAS5HBHofTHQd8421s6 fpNpp8HlQRNknLyE5aRvVj1J/QDgYGBWjDBFbxJFDGkcaAKiKoAUDoAB0pl1c21jbSXNxLHDEgyz twBQA3aqg5BAAyM9K5W61q98QX8ml6AxjtU+W61HkbCR0j9T/wDX6cEtK6j42ldQZtP8PAgq6nEl 6CO391Oev5eo66zs7ewtIrW1hjhgiG1I41woH0oAoaTotro9n9ntUIyd0kjnc0jf3m/w6DoMCtJU PTt+dSUUAJ0pCPTrTqKAGcjrnA7mmFjjChsdCTUxGaTaM5wKAIwduT+fQY+tPHJzzil79aQgnsMf SgBdwo/ChQQAOPwGKWgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAopCM/wD6 6WgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApGYKpZiAAMkntUdzcw2lu9xc SrFEgyzscAVyga98bE4L2fh091yst3z2P8Kf56n5QCW51y91+aWw8N4ESMEn1NhmOPg5CD+I9Onr 2yGrY0TQbLQbVorVS0kh3TTucvK3qx/E8dOT61etrWCzt1t7aFIYUztSNQAMnJ4+pJqWgAqveXtv YW5nuZAiAgDjJYngAAckk9hTNQ1GLT40LK8ssrbIoYxl5G64A+nJPQDk1Ws9NlkuFv8AVCkl2P8A VRpkxwA9lz1b/aP4Y7gDIbOfUrmK+1FNkUZ3W9meQh7O/q/oOi+55GvRWdqGpm1ljtraE3N5JysS nGB3Zj/COetAE2oajBp1v5kpJZiFjjXlnY9AB3NVLewnvJ473VAN6ENDbA5WI8ctyQzZH0HbPUus NIEFx9uvZTdX7D/WN92LPVYx/CPfqe9alABWbqetW+mlYgklxdv/AKu2hUs7d8nHQd8/zqjf61c3 N62l6Giy3Kj99cuCYrf0zx8x9vY+hq7pei2+ms8++S4vJR+9uZTl3749h6D6dcUAU7LRri8vI9T1 spJcJhre2X7lv/Qt784PQnAxv0UUAFZOs65Hpmy3hhkutQmB8i1iALE+rcjC56n0z6VBqOuytenS 9GiW5v8A/lo758q3Hq5Hf/Z61Z0jRLfSg8xY3F7LzPdOPnkPHT0XgcD07nmgCHSdFlhuf7S1Sf7V qTKVDYwkKnqqD+vX9c7VIDVTUdTtNLtvOupdik4UAZLH0A79qALUkiQxtJI6oijLMxwAPc1zz3dz 4lAi053t9LJIkvAMNLg9I89vUkY7c8imxWN94hcTayhtrEcx2Cscvz1lPft8v510DvFbQM7skcSL kknCgD+QoAbZWVtp9olraQrDAn3UX8z+Oe9Zd9rcslw9jo0S3N4pAd2/1UX+8f049+pBFVHuL3xN vjs2e00rlTcdJJx/sgj5Rnv7Y9RW3ZWcFhb+VbQBEyWOOSxPcnqTQBV0vRUtJWvLp1utRfl7grjH so5wP89MAahIUEkgAckntVW91G1061e5upVhhTqzHqfQeprHMd3r65vUe008kMtt/wAtJB1/een+ 6Ox60AS3F9eaxM9npJMMCkrNfEcA8cR/3j79K0bDT7bTbcQWysBySzMSzE9SSep/yKkhKRRJFDEs cajaqKuAo9Mdqk3HGeD7UASdPWszU9aisZUtYY2ub+QZjt4zzjpuY/wr7n+hqlea3cXc7WGioJJg ds12wzFb9ef9punA45+uLel6Rb6bvfc01zKd0txKBvc+mccD0H48nmgCHT9Ik+1DUdUZJ9QyShXO yFf7qg/jz1/mdrePw9ajL84/OsPU/EywXv8AZumw/btSPVF5SAZxukbtjk446dsigDT1TV7LR7dZ ruQjcdscaDc8jeijuef1rBTSr7xDcxXmujybFDug00ep7ynv/u++OOQbGlaEY7salqcwvdUZceYQ SkQ9EHGOvXAPXGMnOtd6jbadbma6lWKPOMtxk9MAfjQBYAVEAG1VUdMYAA/lXP3PiG51G4ey8PxJ MyMUlvXOIYiMdD/Eee3p+Ih8jUvFKMb3zbDR2I2wj5Zrhf8AaP8ACufofYYDHoLWzt7K3jtrWJIo YxtRIxgAZ9P5nvQBS0jR4NNEku8z3c3M9w/LOfb0XgYHPuSea0wBkgYz7mlCgjHP5dKxtU1iRbj+ zdMhNxfsuST9yAZxuY+3PHfHGelAFrU9Xg0tEEgaS4lOI4Ixudz7D+v86zrTSru9u01HWjHJKB+6 tRho4vfpy34kD1PBq7pejLZySXdxKbq+mAElwygcf3VA+6v8+54AFjUNTt9MjDS5aZ/9XAnLyH0A +pAz7gdSKAFvby3061a5u5RFGgyWPU+w9ax4bK68Qzx3WpQvBp6cw2LDBc/35P8A4n8Omd1ix0a5 vbqLUtbk8ydDuhtQB5cB+mTlvfnHvgEb4UDGOP60ARpGFAAXAHanbMAdSfXinkgAknArDmuZ9bla 2sneGyRts10OC+Oqp/j9fxAIb67udTum03RyFC/LcXuPlh77VOOWwRwCOvUda5zXdTt9Nszomiyr F943V02Tt45Py8sxIAx34AwOi+IfEsVnCNI0FQkSsEeSFd5JbPCjncxOcd2Pt96fwz4G5S/1yJdw PmQ2WcqjEDc8h/icnt90e+AFAMzw94On1RVeUPa6M2GIZv319x95yOg54xwATjk769Ht7KC1to7a 3iSKCNQqIgwFHoKs02SRIo2kkYKijJJ7UANKoiktgKBkk8ACuVuNRvfFFxLp2hymDToyUutRK9T3 SIdz6k8D36Fub3xrKUw1r4eVsOeRJe9DhT2j9WHXBwe46u3t4bS3jt7eJYoY1CoiDAUDsKAKul6P ZaPYpZ2cIWNeWY/ekbuzHuT3NXguPSlooAQDGaMfnS1l6zrtto8YDAzXUmBFbp95yTgfQZ/E9gTx QBbvb21062a5u5lijH8R7n0AHJPsOa5Vo9R8bKQS9hoZIII/1lwPwOMfmvP8XUXbPQ7nVbpNS187 iOYbEHMcQI6MP4j7evc8AdNQBBaWVtYWy29rEscS5IUdyeSSTySTySeTU9FFABRRSEhQSxAA6k0A LWPqOupBMbOyRrq+/wCeUYyR0z7Z5HUgDIyRkZhfUbzV5vI0oGKAZ8y7kHy+gAAOTznIyCMclcqT oabpVtpcbLDueR8eZLIQWfHTOAAAMngADk8cmgChpmhSJcG/1aRLm9JBQDJSL6ZA3HrzgAZ+ULk5 3aKwdS19he/2VpEa3WpN97OfLgHdnI6fTv068UAW9Z1y00W3DzbpJ3IWG3iG6SVj0AA+nX+uBWZb aFeavdR6h4iZT5bBoNPjb91Hx/H/AHm/MfXjF/StAisZjeXU73upPnfdS8Yz2RckIPYfnWvQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFHOfaiigAooooAKKKKACiiigAooooAKz9X1my0S0Nxey7Rg7UXlnx6 D/OKr67rq6TEkNvEbrUZyEgtkPJJzyfReCfwPYEino/h2b7Yusa7Kt3qhA2Lj93bD0UevXn9M5JA IINHvfEd1HqGumSGzXJg0xWIUg9Gl9Tj+E/Q4yVrqgAoAAAA4AFLRQAVn32peTKLS0QT38gyseeE H99z/Cv6noMmoL3Urie7Om6UFa5GPOuHGY7dT6/3m9F/Ekd7lhptvp0bCEM0kh3SzSHc8rerHv8A yHYAUARadpn2SR7m5m+030vDzlcYXOQqjnao9O/U5NaFMllSCJ5ZWCIgyzHoBWI813rx2Wrva6dk q838c3bCZHC/7X5etAD7rVJr24NhpJVnBxNdHmOEf+zMewH4kcGr+n6bBp0biPc8shDSzPgvK3TL H+nQdqktrWG0t0gt0CRRjaoBzioNU1W30q282bLMSFSNBlnYnAAFAFu4uIbWB57iVYokGWdzgAVz Qu77xUsi2jPY6MTt+0Dia45wdgP3V68nk/mKkTTrrWpY7nW0CxI26LTkIKj0Mh/iPPTOP1roAp6b RwOlAEFhY2um2wtrKFIoRztU9/UnqT9at03J9DUF1eQWVs9xcyLDDGMu7cD/AOuc9qALBYKDkjA5 JPGK5yfUL3xAz2ujS/Z7MNtl1DBy2Ooi9T/tdO4qEC78WBJJg9tomeIc4luuo+bsEPp3/Kujhhig hSOKNY0UYVFXAUew7UAQadplppFmttaReXGp3HA5Y92PqT61aZm75AppweW5P5VgzardapcvZaFt CIcTX7DckZ7qo/ib+X5GgC1qevLZXCafaIt1qcv3LdD/AKsY+/J/dUcdevaoLDS2W5GoanJFdaic YfGEhH92MHp169Sc9KuaTo1vpNs8cReSWQhpp5Tullb1Zu/0qDUtVFlcJZWkDXV/JwsS4Cpnu57D 9fpmgC3f6rb6Zbia5c/MdqIvLSN2VR3NZUVnea1cpdasDFbIcwWIJ/76k9T7fX1xUunaJJHOt/qU /wBr1Ds/ISIf3UBwMdecZ/rtLHgZ7Y4AHWgAQhRjcABjjGKoahrMVm6W0cbXF7L/AKu3Q8kf3mP8 K+596iu9RlnuDY6aiyXKj95Kw/dwDODn1b2//VU2n6VBYBn3NLPJzLPJyznvn0Ht9KAK9npUs1ym oao4nu1yY0AxHB/ujucHBJ5+lauRngDg/T/9dGAT0P8AjVDVdXt9LWNHBluZjiC3jOXkPsPT3/nQ Banuo7a3ee5lWKFPvMTx6D8fasAm98TqQVmsNKYdiFluQf8A0FDn8fftYg0a41OZLzXFRyrbobIH dFF/vf3m9+n17b4iPUnBPrzQBVtbWC0hWG2jSOEEkLGuPqfzoluI4YXklkSKFOXdyAoHuT0qDWNU s9HthLduVLHEcSfflb0Ufj+FZK6Nf6/JHc6+RFZg7odOj6exkPUnpwPTtytAET6hfeI28nRy1npg bD6ichpMEgrGOoOR1/Ppg7WmaVaaZbCC0iEY6scZZznOS3fqfYZ4wKuLFFbxAYSKKNcAD5VRQPyA rn21W8164ks9EIitVGJNRkGef7sYGMtjnOeM9jwQCxqOvx21z/Z+nw/btUcH9ymCIgOrSHsBnufQ dTSWGgFblNQ1aYXuog7k4PlQdvkX9Mnn0Aya0NK0Wz0aAxWkbbnIMsr8vKfVjxk/oOwFX1XjgA98 +tADRnqTg07ICks2AOpJ4/8ArVHc3MFlCZriURRqMlmbj1rD8m88SsGlD2mkBwQgYrLcAdz/AHVz jBB+mOGoAWbUbvXWa30eQRWgOJr0jGRjpHzyeRzwO/oDr6bplrplv5NtGFLNvkY8s7HqzHuf5dBg CrMNvHDCsUaBEUYVVGABWPf6zJJetpWjqst6CPNkI/d26+p9TxwPX6GgCfVta+xutpZwG71GT/Vw Keg/vMeyjIz9R65o0zRjbSfbL6UXOovy8p+6nGNqDsMcZ6nnoOBJpWkQ6XGxDNLcyndNcSffkb39 B6D+Zya0qACmySJDG0kjBUUZJPamXFxDaW7zzyLHEgyzN0ArDjgm8RMt1fKYdLUh4bckZmH96Ttt 9B+fHUAa0sviP94JGt9EUbmkzta4GOxzwnXnj2/2eZ8QeKbnULsaB4ZhMgC+WREmAMduwAA9cAd6 XXNdvfFepN4e8OD9whAubsY2Rjsc+uRwPY+ny9b4c8M2XhuxENvulnYfvbhx8znOfwGScD37nJoA o+FfBdtoKpd3RF1qhX5p25EZI5CcD6FsZPsOB1NFVdQ1C10uye7vJRHCmMnGSSeAAO5oAluLiG0t 3uLiVIoYxud3bAUe5rm0gm8XSrNdxSwaIuGihbhrv3YZ4TpweufTqQadc+J5oNQ1mIw2Ebb7fTic 7jxh5Ox74XHpnuK6mgBERY0VEUKqjAUDAA9KWiigAopGZUUsxCqBkknAArnZr681+VrXSXaC0QlZ rwggk56J+GfT14GNwBNf63JJcvp2kILi9Bw7Z+SLkZyfz9cEHqRtM2k6FFYN9puHNzfvgvO/ODjG Fz/Pr26YAuafptppdv5NpEEU8sf4mPqT344HoAAMAAVboAKKKKACiisrU9aS0k+y2qfaL5uFiTnB 4xkfiD2GOSVHNAFy+1C206AzXMqovbJ5P+e56AcnArI+xXWvyCa+MlvYYBjt1JV25zlu44x7+m3G WksNDle6XUNXkE94GyiK2Y48fd7DcR6kYGeBnLHcoAbHHHDEsUSKkaAKqKMBQOgAokkSGJ5ZXVI0 UszscBQOpJ7Cqup6pZ6PYveX0yxQr3Pc+g9TXPLp1/4ubz9XE1lo+QYtO+7JNg/elPUD/ZHt0xyA SvqV94mmFvo7S2umBis+okbWfHVYe+eo3EcEH0wdzS9Ks9HsltLGFYoxyT3dv7zHueOtWYoo4IUh hjSOKNQqIigKqjgAAdBT6ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACu f13XpYJxpWjxrc6vKPuZ+WAY++56DGRx7jrwDW1DXLvV7t9J8OFWkH/HzfN/q4F9Fx1b/HI7ka+i 6JbaJaGKEtJM53TXEnLytknJP1J49z70AQaJ4fi0ppbqeZrvUp+ZrqQfMenyr/dXgcew9BjZopks scELyyuEjRSzMxwAB1NAD6xJLy41qUwaZKYrEZWa9UEFj02xZGD/ALw4HbJppWbxGEYNJBo55xyk l2Oxz1VP1b2HXcRFjRURQqqMBQMAD0oAitLSCxt1gtoxHGuTgc5J5JJPJJPJJ5NMv7+2021a4uZV RBwM9WJ6AepNRajqkdgEjVGnu5ciG2jI3ufx6AdyeBUNnpkpvDqGpOst1jEUanMduO+zPUnuxGcc cc5AK6WFxrEvn6opS0BzDYnoRxgy+p4+70Gec1tKoAxx+FDusaF5GVVUZLE4AFc++qXOvFrfRH8q 3BxNeuh4/wBlBxk+/b2yDQBY1XWJIpfsGmQtdag3GFHyQg/xOc/p/KnWGhrbzm9vJDd6g/3p242j nCoP4QMn8z64q1pml2ulQGG1i2g4LueWc46k1e/CgCMDAHp70YxyOtPwPSsbVNdW2uRp2nxLd6o4 +SEH5Y/9pz2HU46nH40AWNU1a20m3ElwzF3O2KGMZklboFUfUgfjWZaaTdapOuoa6ods7reyP+rg HYlf4m9znH8rWk6FJbSm+1O4F5qcn3pSvyxdfljHYckZ6mtnGB0zQA3BHJyTUF1cW9nbSXV1KI4Y xlnckAVBqerQaYERg011LkQW0f35T7c8D3PAqja6HNf3S6hrjLM6kNBZg7orcjofRm9+3bPWgCBU vfEp3zrJZaMfuwkYkuh6t/cX26n2HJ3YYIbS2WGGJIYYxhVUBQopbu8t7CAzXMixpuwM9SfQDuev 5VjLDeeIiJJw9npe7KwgYlmA7t6L6d+h44NADbjVbnVppLLRmKxqdst8OVX2Ud+P8emDWlpekWum I3kxuZnH7yaU7pH+rfrgcZJOKvQQRW8KxRIEjUYVR2qG+v7bTbVri5kCIOg7sfQUATSOkMbySOiI o3MzHAA9Sa543V34hfZp5kt9Mz8930af/Zj5yB7+31BmXT7rXJY7jUwYbJfnjslyCxzwZM89MfL+ fet1UCKFUYUDAAGAKAILWygtIFigiWOMdFH+efxqXafp+ApZZI4YmlmdEjQbmdzgKB1JJ6VzzXN5 4kYxWIls9MDYe6dcPN6hFPQe5HXtxggEmo63Ibr+zdIiW5vc4kkJxFbe7tgjPt+h6G1pmiRWEklx K7XF9L/rLmTljnqF/ur04HoM5q7Yafa6ZaJbWkSxxL2A6n1Pqas0AAGOBWLrOuizkFjYxC71SUfu 7dedn+2/ov8A9bkdRWvtZudUu30vQGUyq225vSMpbjuAM/M3XAH6dRoaNolvots6RM0s8rb57iTl 5W9Sf5Dt+tAFbSdAa3uBqOqXDXuqsDmRvuQjn5YxgYABIz1OT0yRWne3ltp9s9zcyLHGo5JOM+wq tq2sw6UiL5bz3Up2w28Qy8h/oPeqVloct1ex6prZSa7Q7obccx2/pj1boc9j0zjNAFaK3uvFLme8 SW10fOYrfJR7j/abByF9BwTx079JFBFBEsUMaxxqu1VQYAHoMVJRQAmAO1UNS1SHTwiYMtxIcRQp yzH6fgfyPoaqXOrzXdybPRlSaVf9bOx/dxD69888D+WSLWmaRFpwaVnae7k/1tw/U5xkDOcLwOPY ZJPNAFO00ea9ljv9Zw9xu3R22cxwjjAIzgsOuemfUgNW7SEhVLMQABkk9qwprm512RrawfyrBXKz XYPL4OCqfljP/wCpgAu9QutUuWsdJYrEpxcXq9E9VT1b+XqOtaenafb6ZaLb26bVByzE5Z27knuf /wBXQVLbWsFnbpBbxrHEg4Ue5yT7knknuamoAKqahqNvpdlJdXT7UUcAdWOOgHc03UtUg0yANJl5 n4ihQZeQ+gA5rMi09/N/tnXZ0EkYzFCSPLth/wCzP059emcZIA2G2l1A/wBq63tito18yG1l+VIV GSXkz3x69MZ68Dm9Q1a98cak2l6PLLZ6NA227vgMNK39xPUkc89M5YdAUuZNX8e3htYEltPDsMuJ Zv47ojsuD0z3PAxzuOAO503SrXTLOK1toUihiUKkaZ2qP65PJJ5JOTQBHo2j2WjWK2ljbrBCpJ2r nlj1JPUk+v8A9atKkAA6CsvWNaXTjFbQR/aNRuCFgt1PJ/2m9FHJJ9qAJNY1m30e2DyK808h2w28 Qy8rdgB/Ws7TNFuLu7XV9e2yXobMFsOY7Udserdy3vxU+kaC1tdvqepTLd6pJwZduFiX+7GOoGOp 7+3StugAooooAKiurqGztnuLiQRxIMsx/QAdyTwAOSag1PU7XSLJru7k2oOAO7tjOB78H26k4AzW FZ6dd+IrpdS1hWjshzbWDdCMcM498ngjPY4GQQB0cV54okWaffbaPkMkQOHnwQQSR0B/+uOzV0kU UcESxQxrHGowqIMAD2Ap9FABRRRQAUdKiubmG0gaeeQJGvUn+g7n2rmd+o+K2zA72WlBgVlGC049 hjH4nK9OG52gE97rF1qd22naHtYgfvbog7E6H7w9jxjk54wPmGnpOj2+kQssZaSaQ5lnf7z8k49g MnA9yeSSTatLSCxtkt7aMRxJ0A5ye5JPJJ6knknk1PQAVj654jtdEEcJVrm/m/1FnDzJIfp2HvVD VvE0z37aNoEAu9TI+eQ58m3B/idsfp/M8G5oPh2PSGluridr3Up/9ddSDnGc7VHZf1OBnoMAFLSv Dtzd3kWs+JHS4v1+eG2AzFaeyjJBbgc9j3OAa6iiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiimTTR28LyzOscaDLMxwAKAHMyopZiAoGSSeAK5O5vrzxXcPYaTK1tpiErc36g 5k/2I8jB75P5+jANz4yuSMS23h+JsZyUe8YY6eidf/1/d6qGGK3hSGGNY40G1VUYAFAFfTdMtNJs ltLKIRxLye5Y92Y9yfWrdFZuqaxHpzJbxxPdX8wzDaxn5m5AyT0VRnlj+tAFm+v7fTrVrm5fag4A AyzHsqjuT2ArKj0+41xxc6xEY7UMGg089sHIaXBwzcA7eg9zU+naVKJ/t+pzLdX5zt2/6uAH+GMf puPJ9ula/agBM46msy/1R1mNjpwjmvyMkMfkhGfvOR09h1P54ilv59Tla20pwIl+Wa9A3Kp7qn95 vfoPrV6xsIdPtxDAp6lmZjlpGPVmPcmgCHT9NWzZ5pJZLi7l/wBbO/VvQAZ+VR2A/HJ5qa+1G202 2M91KETsD1Y+gHeqGo6xJHdf2fpluLq/Yck58uEern+g/TIyzTfD/lTi91Sb7fqB581xhYvQIO31 9c4xnFAEBs73xCwfUd9rp/VLNSQ0nvIeoGeQBjr7ZPQRxJHGqIoVFGAqjAFPx7UYHpQAYpaiuLiG 0t3nuJFiiQZZ2OABXO+ZfeKW2xGWy0U/ekHyy3Q9F/uoeCT1/M4AJr7V7vUbqTTdC2eYoIuL1wfL gz/d/vP3Hb171o6XpFtpUUgi3SSyndNPKcvKfVjVm0s4LG2S3toljhQAKo/qepPueald0jQvIyqo 5LMcAUAOrFvdZlluZNP0eJbi9Xh5G/1UHux7npwOefY4qSzXvijzILKSS00nOGvEO17gdxH3A7bv yzzjdsrG2062W3tIVijHOB3PqT3PuaAKel6LFp0ktzLM91fTHMt1L94+igdFUdgKk1PVotPTYqNc XbD91bR/fcnp9BkdTxwfSql9q8s1w2n6Ogmu/uyTZHl249T6ken+GKs6Zo8OnPJO0klxeS/6y4lO Wb2HoOnA9B6CgCva6RPc3K32sPHNOvMUCD93D9M9T7/4A1tUVkXuqzSzPYaSiz3Y4kkJ/dwdeWPc 5HT2PpigCxqOqJYhYo4zcXcnEVupwWOD1PYcHmq9hpcrXA1DVXWa9/5Zqo/dwD0Uevuee31n03SY dP3ylmnvJQPOuZOWc/0HoO1aFABVXUNRtdMtTc3cqxxg4GTyxPQD1NVdU1lbJvstrEbvUHH7u2Q/ qx6KPrUOnaLILv8AtLVZludQIwmBiO3Hog/9m6/rkArR6feeIJEudXRreyUhobANyfRpD69Djtx0 5z0McaRRrHGioiAKqqMAAdABTqrX+oWmmWzXF5OsUS9Sf6AcmgCd3WNGd2CooJZicAD1rmZbi88V EwWDy2mkhtst2Plknx/DH6D3/DsQUis73xVItzqkctppatmKwcYaYesnt7f0GW6hVVECqoVVGAAM ACgCGzs7ewtUtrWFYoU6Kv8AM+p9zWZqmttDcrp2mxC61FxnZnCxLnG5z2H+eTgGC91afU7ptL0R gX6XF5glIBjsejNyMAHP06jU03SrXSrcxW6sWY7pJXO55G9WPr+noBQBW0jQ10+aW8up2vNSm4ku XGMD+6o/hX2HXj0GNaiq17fQWEDSzvgAEhRyW+goAnkkjhjMkrqiDqzHAFc+Li78SHbaM9rpX8Vw OJJvZPb1PTtzztfHp1zrcwudVUrZ53Q2LcZ95B3z/dPrzjJWt8AAYAxQBDa2kFlbrBbRCONew5JP qSeSfc8mpHdI0Z3ZVRRksxwAKSWVIInllYJGgyzHoBWBCsvid0uJo5ItJXDwITta4PZj3C/zz6ck AFll8TsyxNJBpCsVd/uvc4PRTnKrngnr6c/d34oo4IkiiRUjQYVVGABSoiRxqiKFRQAqqMAD0FOo AKzdR1X7K4tbSI3N8/3IV6L/ALTHsBkfmPWqN3rNxqFybDQyjMp2z3jDMcPTgdmbnIH+OQl1eaZ4 R04yyM8txOeC5LS3D9snHTn6DPvyATeVbaNC+q6vciW6AI81/wCDP8EY7fh168Dgc4gv/HOolJ1a 30mBv3iIx6/3c93IPPZeg55NG1j1bxrfmaW5aOxjkKsUHCdCVQYwW9WOdvucCvRLKyttOsorS0hS GCJcKidB/iSecnkmgB9tbQWdtHb20SRQxjaiIMBR9KlorntV16Z706PoirPqR4kkYZjtR/ef1PoP /wBRALOsaxJayrp+nRC41SZNyRk/LEuceY/oufxP5kSaRoy6cZbiaVrnULg5nuX6n/ZUfwqOwp2j aPFpNu4EjT3MxDXFzIPnlb1PsOw7fnWlQAUUUUAFZusa3a6Nbq8x3zSHbDAv35DnHHtkgZ9wOpAN bXPEKacRZ2cf2vVJcCK2U9Ce7eg79uATwAWEGi+HWtrk6pqkgu9Wk5LnlYuvC8dcEjPYEgYBOQBu maPdahdx6troRp1Gbe22DbDznJ7k9MenU8429JTcH60vpzQAtFFFABVHVNWtNItTPdSADnauQC35 9vc8Cq2r62tj/o1ogudRc7Y4F52kjOW9u+O/sMkV9L0JzdDU9VJmvyBhScrF6Y9/0HOOpJAKtvpF z4huPt+uRvHbgFYbLOBtPUt356YOCR1wCVrqelFV76/tdNtHuryeOCBOrucD/wDXQBM7pHG0kjKq KCWZjgADuTXHTaxqHi24ksvD7tbadG2251IggsQcMkYI6+/8uMpFFqPjjbNeLJZeHS26KAErLeLx gv3Ve/GM546Bj2Fvbw2tukFvEkUMY2oiLgKPQCgCrpOj2WiWK2ljFsQHLMTlnbGNzHueB+QAwBir 1FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUnWgBaKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKo6tq9notk11eSbV6Ko+8 7dgo7mgCW/v7bTLR7q7lEcS9T1J9gO5rmksbrxfdJe6iklvoqcwWT8Ncf7cg7D29PY/NLZaPc69c pqviCHbGCTa6c4BWJezP6sfT8/QdTQA1EVEVEUKqgAKBgAelOpskiQxPLK6pGgLM7HAUDqSawjLe +IG22ryWelHBNyAVluP9zI+Vf9rqe3rQBPd6tLcXUmnaQElu4zieZwTFbfX+83oo/HFWNL0iHTEd gzTXUx3T3MmPMlPbJ9B0A6AVYsrK2060jtbOFIYIxhUQcfX3PueTTNQ1GDToQ8xZnbIjhjG55SBn Cr3NAE1zcwWdu9xcyrFCgyzucAVkYudfOW32ulZBC9JLoe/9xOnHU+3eSDTZb+VbzV0VmGDFaZ3J DwevZ2569PSrWparaaVCr3DEySHbHEnLyNwMKPxHtzQBP/o1hakny4IIl9lVFFYZv73xAzRaYGtb DA3XkilXfrkIvB9iTgjnpjlItIu9auIr3WiUgU74rBT8q+hc9z3x/LkHo1RUUKoAUDAAGABQBT03 S7TSbbyLSPaCdzMeWdvUmrtFFABVHVdWttJt1kn3NJI2yGGNSzyvjhVA71X1HWhb3H2Gxi+2aiR/ qEYDyxj7znsOR+Y9RSaTorWj/bL+c3mpODumfpGD1SMfwr/P9KAKlvo97qt4l/ruwRoSYdPXDIno XPRm/wA+1dEAAMAYFFVNQ1K20yBZLhmJdtscaDc8jHoqjuaAJLy8t7C2ae5kCRj16k+gHc+1YwsL rXrlLjUkMOnJhobI5zIf70uQP++Pz7irVrp811cpqGqBTMADFbfeS37/AIv6t7cdK0Lq6gsrdp7i QJGvc9SfQDufagB7NHBCWZkjiRckk4CgfyFYTXF54iOyyaS00zOHuekk3/XMEcL6k9c+1PS0utcm 87UEkg09SQlkww0hB4aTHbuF+n47iqFUKoAUDAA7UAQWNjbabaJa2kQjhToo5/WrBOBk0yaaO3he aZ1SKNSzsxwAB1NZXlz624aUPDpeDiJgVkn92B5VfQcH19KAEkurnWT5OnO0NnuKyXo6uB1Efr6b unBxnvo2Vha6dbLb2kKRRDso6npknueOtToixoqIoVVGAoGABTZZUhjaSRwiKMlicAUAPrFutRut Qk+yaKyg/wDLW9ZdyRewH8R/Tp60wfaPEJ5SS30rJBVwVkuRx1BHCH35I7DPGzBBFbQrDBGsca9F Ucep/XmgCppekW2lRMsPmSSOxaSaZt0jk+p/z69Sav0VjXmqXF1dNp2kBWnX/XXDcpAOfzbjgc8/ jgAm1XWotOeK3jje5vpuIbaPq3uT/COvJ7AnscVNO0KV9Q/tbWZEuL7H7qIDMduP9kH+Ljr+HPJN 3S9GttMUuMzXcg/e3MnLue/J6DjpWjQAEgDJ4Fc9cT3HiKVrSxkaHTlbbcXQH+tHIKIfwwT/APqM 8sj65cNbW8jJp8ZxPMv/AC2JH3UPp6n8PetaCCK2gjghQJFGoVVHYUANtbaGztkt7dAkSDCgfzJ7 k9Se5qaiqF9qJglW1tYvPu3BKoDwo45b0AyP/wBZGQBNU1aHS4l3K0s8hxFDGMs59AKp2OjyXFyu pawFlvAQ0UQOUg9Mere/bjHOWNvT9M+yu9zcuJ72Q5eXGAo/uqD0H8/oABo0AFMmljgheWVgqIMs TRNNHbwtLK4RFGSTWKlrJr063N4pXTo2zDb5I87n7zjHTpgd/p94Ait4p/Essd5dI8WlKQ0FswwZ z2d/9npgd/p16Kiorm5hs7d57iVY4kGWZjwBQA6WRIYmlkcRogyzMcACuce4u/EheOAPa6QCA07/ ACvcDJyqqei+59e/IEyWtz4hlWe/R4NMGGitGHzSnqGk9B7f4cw+INeGnJ9g0oRNfAAEk4jtk4+Z 8DAxxx7jgkqrAC6prFh4Zso7S1t1aYg+TaRfL/wJvQe55PPua47RtIvvFupSX99Nvtt22WaPjz8E 5iQ9VUdGb22jkkifSvDlxr08h86RrDeReXrt+8vmDcqv91ARg44yDjJGR6La2MVpCkUahURQiqvA AHQAUAR2dlDZ28cMCRpHGoVVXgKo7AdgKtBtuR1PtSsAqElgqgZJ9K5K4mu/F87WmnSm30VWK3F4 jfNcYOCiY7H1/HkcEAlvtX1DXb2TS/D7eXDGdt1qfVYzjO1Bn5m6c9vUda29J0i00WxW0soykYOW ZuWkbuzHuT+XpxU1nY29haR2trEscEQwiL0H9ST1J7nmrABHuPTNADqTNJ16rS+xWgArn9V1+Vro 6Vo0RudQY7HcfctuPvMTxkenOPc4Vqmpa3d6xdS6N4fJDL8tzfHO2Edwp7n3/LuV19H0W20e08i3 XLNgySPy0hAxk+n0HAoAr6F4eh0jfO8huNQlH766f7xB5wPbPPqSBnoMbY446mjHYDAHpShQOMcU AIARjLU7mikZlRSzEBQMkk4AFAC1z+pa1cT3B07RFEt0Qd82fki5HsffnBHB6kbar3Oo3PiGV7PS WeO0HEt2Mr74HQ+hwME+oBBO1pml2mlWwhtYggP3mONzfU/yHQdBgUAV9I0GDS98pd57uQfvJ5GJ J7nGScAkD3OBknAxrUVg654j/s+dNP0+2a/1aX/V2yH7gx99z/Cv1IoAta3rtpoVn51wWklchYbe Pl5WJwAB9SP88VjWOgXet366x4lUHbzaabnMcA9XH8T/AKD8sXND8NfY7ttV1WZb3WJR80xHyRDn 5YwegwSM9+emcV0NABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRSd6WgAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiisn Xddh0WBAI2uLyY7YLZPvSH/CgCXWtZt9EsftEyvJIx2xQxjLSt2A/wA/qQDn6Xos89+NZ1nDX3Ih gyCluvYDHBbrzzjPHcldH0Kf7UNX1pxPqjD5UUny7YY+6gz156/l1JPQUAFVdQ1C30y1NxcuVXIV VUZZ2PRVA6k+lR6hqsGnmOIh5rqY4ht4hl3P9AO5OAKr2Olym6XUdUkWa+CkRqvMduDnIQepHBY8 nHYcUAV49OuNbmS71iLyreNt0GnkggY/ilPIZu4A4Huem9RWTealNPdPpullWulAM0zDKW6n19WP ZfxPA5AJdS1UWki2ltF9p1CRd0dupxgdNzH+Ffc9e2TS2GmmCVry7cT38gw0uOEX+4g7L+pxz2xJ p+mw6dG+wtJPKQZp5OXlI7k/yHQdqj1bVF02BRHGZ7uU7be3U/NI39AOpJ4AoAbqurDTxHBDC1zf TcQ26Hlvcnso7mo9M0Y2s7Xt7N9q1CQYaU9FH91R2HP+cmpNM0v7JLLeXLifUJwPNmxgKOyJ6KPz PetKgAoopskiRRtJI6oijLMxwAPUmgB1YF3qN1q7yWOivsUZSa/K5WM9MJ03N/L8ciBJrvxVIfJe S10MHBkXiS79hx8qe/UjjjPHRW9vFawJBAgSNBhVHagCrpek2uk25it1Ys5LSSucvKxJJLHuck1e oqjqWpx6dEmUaa4lO2C3jxvlb0HsOpPQDmgB+o6jDptr50qu7EhY4oxl5GJwAo7mqmm6fO8/9pao sZvW/wBXGvK268jCn+8QTk++Bx1XT9LlWf7fqUqz35zjb/q4Af4UB9jjd1PtnFWdS1KHTLbzZcs7 HZFEv3pHPRR7mgB2oahBptr58245YIkaDLyMeiqO5qpaWE9xcJqGp4M4GYrdTlIP8W9T+VGnadOZ xqOplXvSCERTlLdT/Cvv6t3+latABTJZY4InllcJGg3MzHAAolljgieWaRY40G5nY4AHqTWZFHJr EsdzOrJYIQ8MDDBlPZ3Hp3Cn2JwRgACx2smqXCXd4pW1Q7re1YdT2kf39B26nnpq0VV1DUINNtTc T7iuQqoi7mdj0CjufagB17fQafbme4fauQqjuzHooHcms+Kym1WZLvU4zHEhzBZEghePvSdQWznA 6Ae+adY6fNNdLqmqAfbNpEUCtlLZT2Hq3q34DitagApGYKpZiAoGST0FMnuIrWB555FjiQZZm7Vz ka3Pi3Ekyy22i8FYj8r3YPOSQeEx278+1AE7XU/iQGKwd4NNDAPd4w0uG+ZUHpxgk8ckc4IO1a2k Flbrb20SxxL0UfqT6k9yeTUkcaQxpHGipGgCqqjAUDoAPSnUAFZFxM+q3UlhbMRbJlbmZOOf7gOO vTOOnfHGU1C9nub06Tpz7Z9u6ecc+Qp6cep7f/rI0rS1isrWO3gXbGgwO5PqT6knnNAD4YY7eFIY kCRoNqqOwp9FY0t1Pq121rYSmO1jOJ7lecn+6nv7/Tt1AJri9nupWtNOA3g4knYfLGMdvU+3/wCu rNlp8FgjCJcyPjzJWxvkI7k/06DsBU0MMdvCsUS7UXoM5/EnufepKACo7i4itbd555FjiQZZm6AU TzxWsDzzyLHEgyzN0ArLt4JNYmjvb6Fo7eNt1tbPwf8AfcevoO1ACwwzatKt1doY7MHdDbnq3oz/ AOH/ANfOvRVTUL+LTrYyyBnbokaDLOemAO/UUAPvb6Cwg82d8Z4RByzt2VR3J9Kz7ewm1C4S91Re EO6C0PKxnszerdPYHnrjDrCznaQalqpAudvyQ7gUtl5zjsWwTlvTgHGScDVvEy6jHOlvdPZaXAxW 4vABvlOAfLiBOdxz6cDBPoQDQ1nXnaeWw06VY/KH+l3pUlLceg9X54Hrx6lcfS9EGvHISS30dZWL ljiS9PqfRTkj6ZA6k1JoWiS6zDDLPEbHRYvns7NOGkY/8tHyORzxnrnPA4PcABVCqAABgAdqAGxR RwRJFEixxooVEQYCgcAAdhTycDJprusaM7sFRQSzMcAD1Nc5vn8VTssZlt9FjbDMAVe7I7DuE9+/ T1wAJNJJ4qumtITImixEi4mUlTcnH3FI5C88kdema6SONIo1jjRURQAqqMAAdgKbBBFbQRwQoEij UKijoAOgqSgAoopskiRRtJI6oigszMcAAdSTQArEKpLHAHJJOMVyF/qd34nvW0nRmMdiOLq9xwR/ dH19OpHPC4LyStc+MZDFA0ttoiOVeUcNckcFQCPu5/DrnngdNa2sFlbJb20SxxJ0UfmSfUk8knkk 5oAi07TbbS7KO0tYwkafmT6n3q3RRQAUUVFc3MNpbvPO4SNerGgB0sscELzSuEjjUszHoAOSa5pm vPFFw6xnyNIRsBiCHkYHnI4/AHIGOQT8qrEl74lvPMuI3t9KjfMa5w0pB4PB9RnPbIxzyOljjSKN Y40VEUYVVGAB7CgCO3to7WFYYl2xr0A59ySTySScknqeampskiQxPLK6pGilmdjgKB1JPYVyUmpX /i6ZrXRZmtNJRylzqG355R0KRen+92/QgE2pa/eahfHSPDYWS5X/AI+LxxmK2Bzj6k9uv48409C8 P2uhWrLEWmupTuuLqXmSZvUn09B/Mkk2tL0uz0exSzsohHGvJP8AE5xjcx7k461coAKKKKACiiky M4yKAFopM0tABRRRQAUUUUAFFFMAO5stnPb0oAfRRRQA1hnvimKkinh9y+h7fjUtFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUc85/CiigAooooAK KKKACiisXWddazuI9OsIftWqTDKRDoi/3nPYf59KAH69rqaPAscUTXN/MdtvbR8s7HOCfQcdfr6H EGhaFJaSNqWpuLjV5x+8l6iMf3E9AP1qXRdCXT2e8u3Fzqk/M1yRz/ur6DgdMZx9ANmgArI1LV5U uDp+lRJdajxuDNiOAH+KQjpx0A5P61FPqM2rzTWGjybUjJS4vgMrEcfdT+8/T2HfnArS0/TrbS7R ba2QhASzMzFmdj1ZieSTQBBpmkR6fumlla6vpR++upB8z+wH8K+ijgfrWjSMwVSzEAAZJPasF7uf xEWh06V4dNDFZb1Os2OCsR9M8F+npnqACW6up9Wnew0ycxRI2y6vE6p/sR9t/v8Aw/XFadpaQWNu sFvGEjXt1JPck9z7mnW1tBZ20dvbRJFDGMKiDAAqHUdRttMtTPcPgE7UQY3Ox6Ko7mgBmq6rb6Ta iabc7uQkUKcvK56Ko7mq2jadcRs+o6mUfUrgDcF5WBe0aew7nueabpmnzzXp1jU1H2xl2wQ5yttG ew9WPdvw46Vs0AFFFUdU1WDSrdXkDySyHbDBGMvK3oB/XtQBLf39rplq1zeTLFEvGWPU9gPU+1ZK WFzrs8d1qaPDYqQ8NgwALHqGl9/9n8D3zNZ6RJcXq6nq22W7XJgh6x2oOPu+rHAy34DHfZoAKKKx tS1iUXn9l6XCLjUCAXLZEVup6M5x35wOpx2oAm1fWE00RwRRPc38+Rb20YyWPqf7qjuT0puk6Q1m 73l7N9q1KYYkmI4Vf7iDsv8AM8nsBJpWkR6b5kryyXN5NjzriU5Z8dAPRR2AqfUdRt9Ls2ublmCg hVVFLM7E4CqByST0FACalqVvpdp9ouCxBYIiIu55HPRVHcmqOl6bPJdf2tqgBvXGIoQcrbIf4R2L ere5A4ySml2N1cTrqurrtu8HybYMGS1U9ge7kdW/AcddqgApk00VvC800ixxICzOxwAPUmm3NzDa QNPPIsca9WY/p9fasqK2l1qeO8vUKWSfNb2rHO85OJHH0wQvb60AEMMut3AurtCmnJzb2zrgyn++ 4Pb0U/U84xtUVWvr+302ze6upAkSfmT2AHcn0oAdeXkFhaSXVy4SKMZYn+Q9SemKytMtbm/vP7Y1 GNo2x/odq45gQ/xMP75HX0HHrRZ2dzqt2mparD5UcbbrOybny/SR/wDpp1wP4R75NblABTJpo7eF 5pnWOKNSzuxwFA6k0TTRW8LzTSLHEgyzscACuahWTxdOJriN49EikDRRONpuyO7D+4DyB379KAJI YH8VSi6vInj0mNwbe3fj7Tj+Nx/dz0HfHPB56SgAAAAYA7UUAFY2pas5u10rTQst/IMu2flt1/vP j9B1qO+1W4u746Xo+DcKf9IuSMxwDuM927Y/wJW/pelW+k2phhLu7HdLNIcvK3qx70AO0zTYtMtT DGSzOxklkY8yOerH8h+VXKR3WNGd2CqoyWJwAPWueme68SF4bWR7bS9zJJOAN8uDghQe2QQcjHY5 5AAJJ7mXXZns7CXZZIStxcgAhv8AYXPXr16euRw2zbW0NnbR29ugSJBhVzn8yeSfUnk0W1tFaW6Q QIEiQYVR/nk+9S0AFQXd1BY273Fw4RFHJ9fYVBqeq22lQq87EySHbFEgy8jegA+o/MetVLXS5rm7 XUNUYvMpzDb8GOAf+zNwOeg7dM0AJbWk2rXEd/qMZjhjbfa2hPT0kkH970H8P16bVGeaydW1n7E6 WlpF9p1CYERRA8A/3n9FGc0AWb/UorIpEFaa5k/1cEfLN7+w96qW9olpv1fV5YvtSqS0hPyQLj7q k/jz7n1OUsNPh0W2lv8AUboS3bLuuLqQ8D2X0H068e1ef3Wq6t8QNYez02LbYQn+M/JGOQHkI6se cKM/oxoA0fEHiJ9fuxp1okstqWKJbQvtkunGPvHqqg5z7DP+7taL4RY3MOp62yS3SHdDaxKFgt+c jCjqR19MnPJG46ug+GrDQYB5KLJdMu2W5Zfmf2HovAwvsM5PNbNABTJpo7eF5ppFjjQbmdjgAepN E00VvC800iRxINzO7YCj1JNcpCsvjO8S6lR49AhbMcMq4N24wQ5H9wdh3/kAP8q58YTiSRng8Po/ yxHh7zaerAjiMntnJx05BHVKoVQqgBQMADoKAAoAAAA4AFLQAUUVT1PUrbSbF7u6fCLwAOrH0Gf6 8AZJIAJoAsXFxDa27zzyLHEgyzMeAK53yrnxTKGl3waMrZEeCrXGOhz6ZwQR+HOCq22mXuuzx32s jy7ZSWhsRkAg/wDPQH27cE5IOAStdLQA2OOOGJIokVI0UKqKMBQOgA7CnUUUAFFFZ+qavb6WihwZ J5P9XCn3m5A/mR6k9gTxQBPf6hbabbGe5kCr2GeWOM4H4ZPoACTgAmsaHTbnW7lbzVU2Wyj91ac4 5HOenqQcgE9OBkNNY6VPcXS6hqzb5lOYoSBiPp6Z9AQM9cEkkAjcoARVVECIoVVGAAMACoru7t7G 1kubqVYoIxl3Y4Aqrq2s2mjwK9y5Mkh2wwIMyTN/dVepPI/OsW10K71y7XUvEgGxWDW2mq5MUXoX 4G5v069eAoBDHDqHjOVJ7oS2fh8/PFAGCyXY7F8dEPXGeePrXWxRRwQpDDGkcSAKqIoAUDoAB0p9 FABRRRQAUUUUAFJzn2paKACiiigAooooAKKKKAA0UUUAFFBGaKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoorn9d12SC5j0jS gsurTjgHlYF/vt+ecfj7EATXfEMttcf2Vo8S3eryLkR5G2IcfM/PHBz/APrANvQtFGkWztNKbi/n Ia5uX5Mjenso7D/E03w/4ettBtHCnzrydt9zcsPmlbOec5456fUnJJJ0rq6gs7d7i4kEcSDLMaAH yyxwQvLK6pGgLMzHAAHc1hLNceJsrA0tto+RmZTtkux6Keqp/tdT2x1qCKyn8VPHdapHJFpatvgs W483ByrSj06EL+fv09AEdvbw2lukFvEkUSDCogwAKg1HU7XSrU3F05AJCoigs8jHoqqOST6CoNS1 dLJhb28f2q/fGy2RsHH95j/Co9TVbTdDMd2up6pKl3qpBHmhcJCp/gjHYe/U8564oAgbTb7xAwfV wbWw3ZXT0bLOB0MrA/8AjoyOnJroVUIoVQAoGAB0AoVlZcqwYeoOaytZ1tdM8u2giNzqE4Jht16k AgFj6KMj/OcAEusaxBo9qHdWluJDtgt0+/K3AwPbJHPuO5ANTTNJnmnTVNZ2yX+MxxD7luPQc8nn k+o9slNG0aZLk6rqzCbU3GB3WFeflUfiefcjnJLbtABRRWXq+qyWUXk2Vubq/k+WKFexP8Teijv/ APXoAXVtYTTVjijiNzfTnbb2qMAzn3PZeOSelR6XpEsNy2palIlxqUg27lHyQr/cQHkD3PJpNE0V rAPeX0outUnH764xwBnOxPRRx9cD2A2KACimSyxwQvNLIscSKWd3OAoHJJPYVzLXN94rkaGyaWy0 YcSXWNslz7R56L1yx6/nQBZutTudWu5NO0clY0YpdX4xtiI6ovq+D+Ga1dO0210q1FvaRBFyWZjy zserMe5PrUlpZ29hax2trEsUEYwqL0Aou7y3sLWS5uZBHFGMsT78DjuSeAO5oAS+vrbTbOS7u5Vj hjGSxP6D1PtWTpllcalejWdUiMbDP2K1bP7hD/Ew7SEdfTp61HZadcaxdR6prCbFRt1pZZ4iHPzP 6uc/h09a6KgAqjqeq2+lxI0pLyyHbDAgy8regH5c+9UdV12WKVrHSbc3l+DtZQcLFkdWPT8P/wBR k0vRvsszXt7J9p1GRcPMeij+6o7D+fPTOKAIoNIuNQvUv9ZZX2cwWS8xxZHU/wB5vf6/hu0VQ1fV YtJtBIUaaeQ7ILdPvSv2A/qewoAXVNVttJtxJPuaRztihjGXlbsqjuf8az7DSbi8vRqutCJ5xg21 sBlLYcHuPv56n24xwA/SNJmW5bVdWZZdSkGAB9y3X+4n9T35/HaBz60ALVeO9t5LNrsSqLcbj5jH C4BwTk9uOvQjmq+rXAiSCB28uO5kMby5wEUKzNyOmQpGeMZz2AOJHDL4tuvMm/d6FbykRwYI+1lT wzAj7meg749CCQByW83i25W4ufMi0OM5hgYFWujz8zjqE9B3611AAAAAwBwAKqvqmnxMVkvrZCOz TKP6+x/KqFx4u0C2BL6tbNg4xG+8/wDjuaANknAyegrnLrUbnWrk6foz+Xbq224vgMqv+yhB+9z/ AF+uDq3jnSdUmWzS7li07gzzIpBlB/gHIIB5yeePqKtQ/EXwvY2yW9qJRGgARI0UDnt97Geec0Ad Zpum2uk2a2tou1QcszHLOx6sx7n/AD0FWZJFijaSR1RFGWYnAArhJvirpEcLSx2d1IinG4bcZxkD Oevf8/Ss/UfHo1m3ktho9ybXIDqC2Ze4GQvAPH5EcUAdL+/8VzqQzw6LGfTDXLA/oo/zz93pI0S3 hSKKMIiKFREXAUDsB6VwI+IFwkaxweF70MFARNsgCjHGf3fTGOBTh4t8VSkm38LzKSRgTROuePUk AduTgfXkgA78N7H6Vkazr8emyR2lvH9pv5TiOBTyOPvH0A/rXDXXivxpLdxwRaZBbkyrBsKqSWbg Aksc7epIGB3PakstH8d28806PZpcTsPMnldWYjnhQAwHbnGTgelAHaaVorw3P9palMbrUW4V3+7C MYwgxgZ7nAzk9BxW4GODXnv9keOZkVZdbt4gCDujkP8ARBn86guPD/iSOxkmn8VyADkKhlJJ67R8 478fTntQB3mp3stpbP8AZoWmuWGI41x1JwCfbPf9QMkULK2i0S0utS1K48y6KmW6uSD8qgZ2qMZw MdAOfToBwujeH/FGorJff269vHIcROxk+ZRwSV3Ag8Y57Y/DsNX0m+vvC66fb3Ikv4Y0EU0xO15F AG5+pwecgknn15oA5eWe/wDibqQitZHsvD9qw80n/WyNj7uMkA4PcED3yRXo2n6fZ6VZpaWUCQwo MBV/mSeSfc8muB8A6VZwaabvToJrY7zE4EjbX+RCTjPJz0z0yR0rtoywx8xJ/wBkmgDT61Fc3UFn bSXNzKsUMY3O7nAArPuNTh021ku72VIrdB8zOe/oPUnpisGGC48W3KX+pxtDosZ32tm45n6Ykk9v Qe/4kAlihuPGcqz3sU1vocbhobZ/lN2QchnHXZnoM8/ka61VCKFUAKOAAOAKjVlAABHToBT92T8u DQA6ikH0xWbrOt22i2fnz7nkY7YokGWdvT/E9vyyAS6tq9roti11dvhRwqD7zn0FZWmaVc6jeprW tpiYD/RrNsFbcZBz7twDng+vQBWaTpVxfXaa1rig3e0eRbkfLbjr07NkD8h3Ax0u4frigBaKKKAC ikd1jRndgqKMszHAA9TXM3WrXmtXYstEYJApxPdMCNv06Efhye20fNQBb1LXikv2LTIzc3pfYdoy I8YyT64yM9AM8kHAM+naOLaUXl5J9p1A5zKei57AfTjPX6DAE2laRbaRbeVDuZyAHlf7zY6dOABk 4AwBk8cmr9ABWJrniFdMkisrSBrzVLjiC2T/ANCY9lGDzVPV/Es7aidF8Pwrd6mf9bIT+6tR6ufX jp/Pob+heHbXQ0llBNxfTndcXcg+eQ9fwX0GfqSeaAItH8PNbXZ1TVJlvNWcYMu0bIR3WPjIHbPU +3St2iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoopk0YmgkiJIDqV yOoyKAOT8W+INd0vUbK00rTPOjuQALlgCnmEkBM5AU9CM8HPsRXM6RbeOdOmuLiDRk+0XTBpp7ma MscZ4Hzcdc/X24rT8GW9zfeG7y1ZvJaCUNawFtxgkU7uWx3bqB/tetd5GfNijlZHjLAMVJwVyOho A4eS18duWuLjVbC1Q4ygJPl88A4X146n8awrLTvF/iG5ldtXVY7ZvLcu0m1nz/CQApxjnHIPB9+0 1VzqWu22kQ8RwYurn5TjjG1PTnPI7gn0rdSLYqKpLADqWoA4kj4g2gGJLa7Knojx/N7fMBge+c9a q3XiTx1G7WiabbtcJGGPlbWbkgDPzEZ+9ge2cYrtdVv4dJ0ue9uc+XEuQpJAYngL36kgVU0HTJrS 0ae8Aa+u5DcXJzna7AAqPZQAv4E98UAcjpVj4309pZYbezEt04eaWSRC7Hrk+wJOB+laRm+II4Ed oTtH8cZ5xz6f5NdiEGMEAn35rN1S0vLxoLa3uHtbcEtPJEcO/YIDjgckk+wHOTQBw82o+OtKurhX SFFlZ5Vw8TAkL90cnB4wB646kmrGmL46jmkvzp0EtxeqrPJI8eVXGVQAkEAZ6Y6luvFTaB4W08eJ rjUraAGysn8uBndnMswA3SktkcZwMcA9srXen5h8wGT6nrQBxi6h8Qk27tJtpAvXEkeWJ9fmHAwf Q8jr1p/9ueOol/eeHoGySAQ69e3G/wDzmux2AnG0jv8AezSeWV5oA41vE/jGNwJPDfH+whbngdm9 cnPpise18Satot9cB9Ed7ueT5ml3syZJKqeTxgg+uO3AruNZ1FdKtVKAG5nfyraFv4nPTgdu/wCQ zzUCaDARG08jSSi4Fw7luWcZ79gDjAHp7nIBkHxb4nAJ/wCEYmzjgeW/XHtn2/r61HL4u8UwJLNL 4e8uBCSxdCNg9yW/UDv0re1/V20my/0aPzr+UiO2h3DDOxwCfQZP58CnWuhJHp1ra3UjXDRS+fNI /PnSkHJb2yxI9ML6UAcVfXXjHXJI5rvQpBZZDrZcbTwNpb5gTzg4OMegI41V13xvDEEHhmHHTG5R gY9BIfau0KYB2569ff25o8vBwCR+FAHG/wBr+PJiGGgW8WCRkug46dC/1PWsmSPxrcX63d3osU5S bzURnQqrAAKx+fjGOg4zzgHBrsL64vZNRjtNLVd0bK1zOxBCDOdo9TgHj+Va3lgncTg9c46UAcd/ bvjkbgvh23xwM71A4POPn5/+tjtVK517x9OZLWLSYYpSmWZCuUzwMZc8nkiuu1y7fTNEurq3/wBe E2Q5HJc8AgHrjrjviptOtbiCxt1u28y88lFnc87mA5ycYPJxnvQBxWn3Hjiwg8u30C25Ys254yT7 ZD/4896snX/HRQhvD0JXpgKOfXI8z/P8+42A8ED61BeXUNnZzXNwwSCFCzZbGQP/AK/60AcaPFHj aa5NnFoNslz5fmBXdQccDOfMx1I/wqnFa+OhqpvpLW1luTHsEzyRYjGT93uOp7envXSeH9HS3E+r nd9q1FzcS7juyrYIUE/wgYwO3TnFbZjJIYgHHZlNAHHmH4h3AZHvbCBDgbiw3DHX7qH9P0qNPDHi x2Hn+K2UHG4RmRvy5H9PpXbEEHhR7c8Y/nWTr+qNp1pHDbrnULtxDaoME7j1P4ZHXjJGcDJoA4Ee G9Y1HxCdMj1u6vbW2lK3dyQwSJioPQvknIxhTx9DXQL8NLR1KTateOG6gBFA46AEHH+faum0vT4t J09LWH52JLyOwGZHP3mJ/wA8AelaMTNImcDPQ7TnFAHLwfDfQYgBILy55yRLOVH/AI6B+VYsvhu1 fVbmTTNLs2022QqGmVpmllZQM/Nn5VB7exAODXUeI9RuLVLfTbJSb+/fy4yM4jX+JjjpxnkY4BPb B0bCyisbKG3Qu4jG3cTyx7k/U84HrQBXs9E0i0hSAadaZVQMtbpk49SBz61ais7SJgYra1RsdUiU H+VPaIPg8ZBzzmqWsX/9mac0qoTO5EcComWaQ8DjPPPr3wKAK915es61DaHdJBYuJpgMbfMyQo9S QQeO2056itttwPBbcP0FZ+h6Y2maWkEjCW5cmSebruc9ee+AAufQDNaipgY+ZfagCMBsYJb8TWdr d6dK0ia5RWaX7kKA/ec9OD1PfHfGK2MAjqfzrmkMmueLnPH9n6WNuCPvznB9Oi4/MKRwaALulaY1 pp9vHcZecDdIS+4hz1we+Ome+0VeEWVwARz61aK7lwf5UvAoAqGPA5AJz2P+Nc3cA63rkluufsdg 3Py4Dzc/mB09ip/vVsa/qDadppMKh7udxDbqo53McZHB6DJ/DHeptE0pNJ0qG1AAcDdIRg5Y9eQB n0zjnGTzQA62tzDbRxHaSigcDAPvz05qbYcjkn1NWCowR29qjlZIY2ldtqIpYnk4H9aAOI+Hccje FxIZNw+0NnbyG4Vcj8vbvXR6nqFppFi97eSoka8KB9525+VfU/8A1+wNcV4c8QSaN4Rs7a30+W+1 C4upIreEKF+YKGJb2xk8cepHWuk0rwxc3GoRaz4jnS71BMNDCq4htj1wo7kHufQHkgNQBTs9Hu/E V5HqmvJsto/mtNLZAQmejyg9Wx2P5DpXUpCVGQCO+ckVa8tQM9MUxoycDccduKAItxA4xtx1B/rT 1bBwPrQUbn5iPfNY+sa1/ZgjtoImub+clYLZB95uDlsdAMjPT69wAT6zr9tpNsAQZbiX5YLdPvSt 2A9s8Z/IE8VS0jRHe8Gsau3m6mwBVDytuOcKvbIyRkccnGSSzLoehvayvqGoS/atUnGXlOMRDH3U 9B2/kAK2wc8DBH97PWgB+4gYUjp1zz+tOUsAORxTAMDJ3fln9cUYODj9RQBNnA+Y/jVe91CDT7Y3 Fy4VB0GeWPoB61n6prcGnN5Shpbth8kCAk5PTOOfwHPt3rLtdDuNRuFv9cIknxhLXAKIM5w3JB7c DjPUscGgBcX3imbfI8lppAb92qEBpsH73I6cdenPGThh0tpBDZ2yW9vGscKDCqo4H+NMXJJyOTz0 60k08dtC80ziONBuZ24AA/GgC3uwOeK4691658TXbaT4dmKWy/8AH1qqYZEH92P+8x6cdOT6Gqjz 33jZjFbNLZeHw215NpEt0ASGAHYdsnjr94ghessbG20+zjtLKCOCBM7UQYH1+p9TzQAzRdIsdB09 bSxjKxjl3Y5eVu7Me5/QdsCtPcDzmogrc8/kaQKf8TmgCbcM4yDS5qPJ7cDPpR269qAJaTcM4qAv ngHj370vIyQrH6k0ATZHqKNwqIDPRR+VOJwOQOPwFAEn1opobjI/xo3cdPyoAdRSbhS0AFFFFABR RRQAUUUUAFFFFADc4JGPelz7GkY4+bGcelKGB6GgBetFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFBoA5bwhs+061GuS0d/ICxbOecf+ y/579DfXkOnWM95cOEhhQu5x2H8zXMeEJGbX/E6MMMLzP3sjBaQDjt0/z0q3rbDVNe07RcExRt9s u1GQCi5CA9iC2Mqe1AE3huyuEs3v75Qt/fv582Byo6ImeuFXHHOCWrbKkDrn8aVVwOmOc1U1fUY9 J0m5v5Su2FCwDHAJ6AZ7ZJAoAxblm1jxVHZKrG10tRcTOCMNOceWuOvA3N9Rg9eehxgcAn6k1meH NOk03SFN0MXdwxubonH+tbk5xxxgDj0rZoAh2Z4xj6CsPxFdz29rBY2eDf3z+VFjPyjHzueDgAfz zziuhJCKWZgFAySTwK5nw9G+rate+IpirRuTbWQHOIkYgt9Sc9emD1BoA19N0yHS9PhsrcfuoU2j sSepJ9ySSfcmrYBz3yfrUuM0UARgYPFMdkjRpHKqqglmY4CgdST6VPXNa4W1vUotBtpGESkSagyD 7qdVQn/awffoegNAFbSIm8Q6v/b8wH2SENFpsZZumSGkYHueg/kcKa6WRhFGzsgbA+6vVj6D+VTx xpDEkUaKkaAKqKMBQOgA7CsPxPfSwW0FjZAnUL5/JhKkgoD958jkYB6jkDJHQ0AZPh+0fWNbudYu nEyQHyoWRm8svj5jGDgbV6KR1yT1FdcF6Eg49jTLCxg06xhs7cERQqFGepPcn1JOST3JJqzgUAR7 Rn7vPfBrI1zUn0+OG2tEVr+8fy7dccD+859hkfmK155ora3lnmcJFGhd2PRVAyTXOeHoZNX1GfxH dxbdxaGxRh92EH7/AF6nn9cHDCgDZsbFbK3ESlixJZmP8TE5JqyYx1A/ICpMe1Z+u6omjaNc3p27 0Q+WpGdz44HUUAZLztrHisWkZzaaavmTlSCHkP3V4PYg/irA9RnpAuD2J7+9ZPhnS30vRkW43G8u GNxcl2yTI3XPbIGBxwSCe9bBGaAGMpPcgegrndZhbWdXg0cAm1iAnu2H/jq57Hj9cj7tbOrahHpW lz3sg3CJflX+8x4VR9SQKpeG9Ll0+weW7Je/u3865kYgsWPQdBwB26Ak44oA0xGWyW5J/Cn+UuOf 0qSigCJxGqFm2qFXJLcAD3rl/DqtrmoXPiGVcRHMFgpGcRA4LfUnPvywyRip/EU8l/eweHrRysl0 N906nlIR976ZHGexK8EMcdHDDHbwRwQoEijUIijoABgCgCNoQQeAD6+v1qpcW8cUbzyStCiAl3BG APetKuZ1tpNc1ePw/EsgtVVZr6VeMLnKpnPU4/qD8pFAFXw1Yy39zN4iudwe4BitEY58uEHqD33Y Bz0PUfeNdSI88lOcdBmpURIo1jjVURQFVVGAAOgAp1AEQjIPFcxDH/wkPiv7SZd+n6UdsagfLJMR 97OO3UYPZD351PEGpPZ2sdtbc3t4xigUZznoW49MjJ7DntVzStOi0rTILKLBWNeWxjcx5Zsdskk4 96ALKpjvk59aULjsPenUUAZHiDVG0zSZJIs/aZcRW6AZJduBgeo6474A71JoOlJo+kxWo2mU5eZ1 H35D1Oep9ATzgCsuHbr/AIta4BLWelZRe6vMfwwcdxnghDXT0AFFFYXifUJbWyis7TP2y9fyo8Z4 Hc57dQByPvZ7UARWZGu6898QHsbImK3JAIeTIy4Oeen6KRXRVW0+yj06whtIvuxKFzzz+ZP5dqs0 AIRntXO+JXnuwmmWJUzyEEqc46jk45wuVJ+orW1bUo9J02a8lUsIx8qA4LMeAM9ue/br2ql4ds5o bM3V4GN5cnzHLZyAeQMH7vXOOxJHQCgDA+GdlBHolzOobzWn8os5JOxUTCj/AD1rucCuP+HMnmaH eEEFReMFIPX92n9c12FABSEA9QDS1z+t+IzaXK6ZpcYu9VkGREvIjHq3IH4EjqMkZGQB/iDWn05E tbKIXWpznbBbhS3POGbHQcdyOh54NSaNoQ04y3dzMbjUbj/Xzkk8Z4VfQAYHvgewCaFoX9mmS8vJ ftOqXHM9we3T5V9BwPrgdAFA2qAGFMnpgZ/Ok2EE8LipKZNNFbxNNNIscaDLO5wAPc0ANK88Hk+l c5qGtT3UxsdDRp7nOGn6qg9QTwP94gjg4DEEB73V14juJLezMttYR5WSZlwXbJBABHPTofX5hxtb asdNtdOthBbR7Fzkt1Zj6k9zQBk6N4fi0zMrl5r2T780nOO5C5JOM9zlj3J4xsbAuCQF7A7sVZxW Vrmu2mhWolmDSzuQsNvEMySsegA/z+ZAIA6/v7XTLN7y+lEUCfebOcn0A7muagsrzxi63erWxttF DB7WydsSTDH35fQc9P6ctb07w7darfDV/EqrJKvFtZDmOEf3iOhb8/fJxt6zAFAFaO3jiiSNI0SN FCqgXhQOgAHAHHQU/GBkgEeoapscUbR6c0ARAADIDfnmkycfe/IZ/lUuxc5xz60u0UARdMHI/Gms wJAPHtnrUxTPXke9JsHTbkfWgCIkZ5I+h4pwUnoV474qQJ9Pyo2DOcc+tADAreuT9Tg0fMP4+3fA p+3mgKB3/CgBo5GeM+ooyR9aXZnnJoPGev1oAUHA560v484powB15x1PNHT73HHrQA7I9aWkHOe1 GPagBaKKKACiiigAooooAKZGuFywO7oc98d6fSAAEkADPJ96AFooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA4bwzcraax4puJXKwR 3LSySMDhFDSE/wBffj343PDUE0trNqt0CtxqLecVJ+5H0jXj0Xn15rkIYjfa/q2ijebe/wBQJuCe vlIXZxnsCdoGOxx3r0vAxjHFAC1zuqKdX8SWOmAn7Naf6XdccMRgRr+JJOOhAIrcurmOztZbmY7Y 4lLsSccCsfwvayCyl1O6B+2ak3nyZHKp/Ag5JAA5wem4igDeo6UUyWVIYnlkYLGilmY9gOpoAwvE k81y9roloSJb5iJZFP8Aqohyx/HoM8Hp3rbtraKztYraBdkMKCONck7VAwBk81geGI21CS48Q3A/ fXZMcKkYMUKtgLz6kZPY4BrpKACiimySJFG0kjqiICzMxwAB1JNAGfreqjSrEOiGW5lcRW8Q6u7c Af8A68fWk0LTJNMsMXMomvJmMtxLjG5z2+g6fr3qhpMB1jVG124DeXEWjsozxsAyrOR6nJHX1roq AGySJFG0kjBEQFmZjgADqTXP+H0OqX1z4hmQr537q0VjysIxyeepIJ9ucdaNfeXU7630C2dkEo82 7kUjKQg9PqTxx0yOMZrfhhjt4I4IY1jijUIiKMBVAwAB6UAPooqhrWqxaLpU99KN3lj5Uzy7HoP8 9s0AZ+qyNq+pLokO77Oo8y9kXHyj+FAfXPPHI4963lVUQIihVUYAAwAKzNC0xtPsme4bzLy5bzrh yoB3Hnbx2H+PTNalABXNXKDXfFEEA5stMPmynnDy5+UcMOhGeh+6wPWtPX9UGjaLcXoAZ0XEanux 6f4/hRoemnTNMSOU7rmQmW4fdndI33jn9PwoA0qKKqalerp2nT3TDcUX5E7u3RVHuTgfjQBmTv8A 2v4jSzAza6cRNMccNKR8gz7Dn8a3qzNB0xtM0xUmIa6mZp7lx/FIxyfy6fhWnQAVT1TUYdK06a8n KhYxwCwXcx4AyemT37Vcrl5t3iTxCLfaG0mwbc7g5WaXpt/DkHrwGBGGBoAt+G9OnhSfU74k318Q 7Agjy07Lg8jqTg8jIU525O7RTXdY0Z3YKqjJJPAFAGfrmrpo2nmfYZZnYRwQqMtI56ADv/nvUXh3 SX0rTv8ASG8y+uG825kLbiWP8Oe4HT35OOTVHSwfEGrtrMgf7FbExWUZPDt/FIQOvPA988ZUGulo AKCcDJ6UVheILuSZodFtGxdXnDnaCI4udzEHg9Dx3AI9KAIdLV9X8QXGsSKBbW4NtZ9fn/vSfXkr n3YHpz0dQWVpDYWUNpACIokCLk5Jx3J7k9Se5qegArL8QX8thpjfZlZrqdhDABj77dOvT/HFalYV sg1bxDLet81rY/uoPQyHlm/AY9jkd1oAu6JpaaPpUNmrb3UZkk7u56n+g9AAO1aFFFADXdY0Z3YK ijLMxwAPU1zuix/2vqs2vTw4UDyrPeoyF5yRxkdSOvdh0xVrXZZLl4tHtnVZbkZlbk7I+5xkdcEf mO9a8USQQpDGMJGoVQSTgDgcmgB9FFV767SwsZrqT7sak4zjJ7D8TxQBg37/ANteKoNLAY21iouZ yR8pY5CjlSDxkY6Hc3dRXTVkeHrA2tgbiX5rq7YzzORgnJJAPHYHp2JOK16AOQ+Hkc0ej34nUq5v 3YhsZ5ROuO//AOrtXXMyohd2CqoySTgAVzPg1BbWurQliFj1KVBvPTAWoXku/GTvHazyWmhKdkk8 fEl0wJBVD2T3+o9doAXevXuvXL6b4a27F4udQkyqRj0T1b0P/wCsbGh6BZ6DbMluC80hLS3EnLyH 3Pp6Cr1nZ2+n2cVpaxCKCJdqKO34nkn1J5NT0AFFFZ2qavFp0WADJOx2pGiliWPQYHU+348AEgAs Xl9b2MXmTyBeCVXu2OuB7dz0A5OBWKtreeIZBPd77awVgY4huR5Bjk9iOe5AOOgX7zT22ivd3X27 V9skvHlwDlU6H5v73IBx0B55PzVuUAMhhit4UhhjSOJBtVEUAKPQAU+iue1rX50ul0jRI0utVk4Y k/u7Yf35D2+n9cAgE2ueIF0x4rKzgN5qs5AhtUYA45+Zj2UYP/1hkiLRfDslrePquq3H2zVJOjkf JAMfdQdu/PucYyc29F0KDR0kk3vcXs/NxdSffkOc/QDnoK1aACiiigAooooAKKKKACiiigAooooA KKKKACkIB60tFACYH/66MAdhS0UAFFFFAB3ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKQ57UtUtWvPsGk3V 1uAaOMlc/wB7ov64oA5HwSsV3r/iPUVIk33GyFwMfuy7ng+/y5+gruh0riPhxE8dlqCuMFbjYRuy N4yW6cdT612zMqIWdgqqMlicAD1NAHP+Is6jqGn6EFLR3DGe7AOP3CY+U+zNtB/+vXRVzvh0Pqdx da/LkC5Pl2ysPuQqSM+248kdDgGuioAK5vxNI+oXNn4ft2cPdnzLhkOPLhU8nODjJ4Hvgd66GaWO CGSaVgscalmY9gBkmuf8MRNeSXevzph75v3AZcMkA4UexPU+uFoA6CKKOCFIYkVI41CoqjAUDgAU +iigArm9Xdtd1IaFbTFbePD37pnOz/nnntu56HPB9DV/W9VewhSC1QS6jckpbQ+p7k+gHU1NpGlR 6TaGISNLNI5kmmbrI5OSfb6fzOSQC7HGkUaxxoqIgCqqjAAHQAVX1K/i0zTp7yb7kS5x6noB+JxV qucXOv8AiEtk/wBnaa+AMkCSbrn3A/w6hqALug2M9tavc3pZr67bzJt3VR/CnH90HHfnOOMVrUUU AFc2Ma94pJYFrHSWwAc7XuMdcYwdo98g+zVa8RapLZwRWVjhtTvSY7df7v8Aec+yjnv+WauaRpcO j6bFZwchMlmPVmPJP+egwO1AF6iisvxBqg0rSZZUJ+0ONkKqMkse4HfHXHfGO9AGTJv8Q+MFi2/8 S3STuY4P72fIIGf9kjPHdeeGFdVWboOmf2TpENs2DNjfO453yHqc9/TPoBWlQAVgrKuua9tjIew0 5vnOOHn6ge4Uc/UrjOeLWvX8ljpxW3XfeXB8m3jyRucj25wOue3fA5qxpNgumaXBaBgzIuZHAxvc 8s2O2WJP40AXKKKjnmjtreSeZtsUal3bHQAZJoAzNdvpYoo7GydRf3R2R5ONo7t0PQZPQ9Cexqzp Glw6Rp0dpDg7eXfGC7ev6AAdgAOgrP0GGW8urjXLgMpuRsgjJzsjHf05wOmRxuB+cit6gArDv5m1 XUhpFuf3CYku5MHG3P8AqwR3P1GOSORirmr37WNoBCoe6mPlwJnqx6H6D/OKk0uwGnWKwlzJKSXl kPV3PJP+ewFAFqKKOGJIokWONFCoijAUDoAOwp1FFADJpUgheWQ4RBknGax9Bhe5kn1mcZku8CEH +CIdMcDGT+YCnrUeqltY1RNFjDfZkAlvHHTGQRGf94f4g5FbyqFUKoAUDAA7UALRRSMyojO7BVUZ LE4AFAGT4gvpba0S1tAWvbxvKhVSQR6tkcgAdSOnWr9jZRafZRWsAxHGMdOp6kn3JJP41jaKf7a1 ObXWQiAA29mGXB2g/M/4njtwD1BFdDQAVFcXEVrbyTzOEjjG5ialrndXc6vq0OiQysscf728ZOCo GCozkY6g9+o9DQBZ0OB5vN1W5XFxdH5Rx8kYPAHA64HrnANbNIoCqFUAADAA7UtABXN30ia14mh0 nYWt7IC5uMg4ZsYVemO/TuNw7Vs6lfxaZp095LysSEhf7x7D8TgVn+FrOa30gXN1zd3rG4mPoW6D oO2PxJoA26q6lqFvpWnzXtyxEUS5OOp9APcnirVclqFvH4o8QpbMC+m2CsZ/SSQnG3Hf7p/I+oyA ZnhqyTxDe6rLdpstGmZ2tlc5LOT1IxjAHUdc+nB72KKOCFIoo1jiRQqIgwFA4AA7CuU8HbjrPiVu TH9uYAjpkM4IHfpjPb0FddQAUUEgDJOBWFcajcapcNZ6av7ngSXJ+6BgHr9CMAcnP8IIYgD7/V5H ul0/TV824bO5wcBB0Jz7euCBjHJ+WrWnaTFYkysRNdsCHnK4POCQvXAyM4ySepJPNTWNhBp9usMC ngAM7febHHP9AOAOAAOKtUAFFNd1jRndgqKCWZjgAeprlri7n8XSyWOmytDpCMY7q8XhpfWNM9Pc /wCSASX+s3msXb6V4dlRWRgLm+KhkhUjPy8/Me3+SRs6XpFno9t5Nqhycb5HOXkPqx79/b0qWw0+ 10yzjtLOBIYUGAqjr7n1PqTyas0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFIRnvj6UhYL94496AHUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFUtW01NW06SykmliRypLxEBhgg8Zz6Vd
September 10, 2007 - September 23, 2007
Pietenpol-Archive.digest.vol-gc
