Pietenpol-Archive.digest.vol-gw
July 31, 2008 - August 10, 2008
Subject: Re: Riblett install
Date: Jul 31, 2008
CG range of the Riblett is very close to the Piet, with a lighter engine up front I add a slight bungee pull on the forward side of the stick, when the Werner went on a little back pressure was added. except when full power was applyed on the Werner a forward pressure was applyed to keep from climbing over 2000 FPM. I kept the spar the same as Piet as all the fittings don't require a change. The cord line is higher on the 612, I suspect the angle of incident can be reduced. I have flown with 5 different engines on the same Piet and do-not change anything, just to test engines, Now that I am trying the 612 I retry engines . Don't be surprised to see a great improvement in flight, when using the 612. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195943#195943 ________________________________________________________________________________
Subject: Re: Homemade Turnbuckles
Date: Jul 31, 2008
Just back from EAA B & B Specialties is where I buy all my turnbuckles, all aircraft quality and with any type ends you want, the whole assembly costs about $10.00 each. Their prices are as little as 1/2 the price others in the same Fly Market are charging and their prices are the same all yr. around, not "Show Specials". They don't have a catalog but get part numbers out of AC/S, call them, order by part number and you'll get the best price anywhere. (913) 884-5930 I can't even begin to imagine anyone building a Piet, trying to save a couple bucks by buying hardware store stuff that they are going to trust their LIFE with?? Stick with aircraft quality but save by buying from reliable sources like B&B Specialties. Amen On Jul 31, 2008, at 9:13 PM, Oscar Zuniga wrote: > > > > > I got to thinking about "hardware store" turnbuckles as a possible > alternative to AN/MS hardware and paged over to McMaster-Carr to > snoop. Found some surprises. For example, let's take the typical > 1/8" 7x19 aircraft cable. It's rated at 2000 lbs. strength. For > that, let's pick an AN/MS turnbuckle with AN4 (1/4") threads, an eye > on one end and a fork on the other, roughly 4-1/2" long. It is > rated something a little over 2000 lbs. so it's a good match for > that cable. > > Searching "the hardware store", we start with open-body aluminum > "screen door" turnbuckles with 1/4" threaded eyes and find that it > might be rated a couple of hundred pounds, obviously due to the > aluminum body and the minimal number of threads on the eyes that > engage the body. Move on to galvanized steel and the strength > improves to a couple of hundred pounds, still very affordable. Now > on to the better stuff and we find stainless steel turnbuckles, > which are available in both open and closed body and seem to engage > maybe twice as many threads but are rated no more than 800 lbs. and > also have a caution that the working load should not be exceeded. > Can you say "fails rather sharply"? > > The cost of hardware store (or nautical/marine, I found) is a lot > more attractive but the strength is just not there without really > getting heavy. Is the aircraft hardware 'overkill' for the working > loads? I don't know. I have not run any sort of analysis to > determine the aerodynamic loadings on any of them, but when we go > from 2000 lbs. rating to a couple of hundred, someone had better do > some testing. Same goes for home-made tensioners. > > I'm all in favor of better mousetraps, but let's test these things > against their working stresses before we substitute. Those > stainless turnbuckles look great to me and are about 1/3 the price > of AN/MS hardware, but I would have to assure myself that they could > handle the flight loads with at least a 2x factor of safety because > my skinny a$$ is worth more than a $10 turnbuckle. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Subject: Re: Corvair hub on Piet. plans
Date: Jul 31, 2008
Michael: I have an older edition of WW's that had the drawing for the hub. There were some other drawings also, but I have filed them away and am unable to put my hands on them right now. It was always his thing that if you wanted to make your own he would go out of his way to assist you and many did and do now. If you are a person who doesn't have access to a machine shop or the time, he will sell you the parts, but he at least gives you the choice and nudges you in the direction of doing things yourself if you are wanting to try but not quite sure. Its not just the manual you are buying, but the help to the point of holding your hand if you need it. You probably won't, but it is good to know you have a plan B every now and then. dennis ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Wednesday, July 30, 2008 6:55 AM Subject: Re: Pietenpol-List: Corvair hub on Piet. plans Thanks Oscar, a very well written responce. IF I decide to do the Corvair, I will have to get these mentioned books. I see they are quite pricy, but what others are available? Machining either hub won't be an issue, I just wanted to get the best suited part that I could make that has already been proven. (Rather then make up my own fron scratch.) Mine will more then likely be 6061-T6 aluminum. Nothing has been decided...just gathering intel. and you have been of great help. --- On Tue, 7/29/08, Oscar Zuniga wrote: From: Oscar Zuniga <taildrags(at)hotmail.com> Subject: Pietenpol-List: Corvair hub on Piet. plans To: "Pietenpol List" Date: Tuesday, July 29, 2008, 10:39 PM Mike; Doesn't look to me like anybody actually answered your question about the differences between the two hubs (Pietenpol and Wynne) for the Corvair conversion, so I'll throw in my two cents' worth and see if I can add anything. I have the Pietenpol drawings and the hub sheets are dated November of 1972. The material indicated for the hub is "aluminum casting". The design pioneered the use of a "safety shaft" through the center of the hub into a threaded 3/4" deep bore in the center of the crankshaft end (nose). The safety shaft is called out to be a 5" long, 1" dia. 4130 or 4140 steel rod, or 1" dia. by .250" wall 4130 steel tube, threaded 18 threads to the inch. The hub is mounted to the crankshaft flange using standard Chevy 11/32" capscrews, 1" long. This requires that the holes in the hub be bored very deep into it and that a long, thinwall socket be used to tighten them. The flange itself has a standard bolt pattern and is .438" thick at the prop flange. Overall length is given as 2.875". I say all of this to contrast this hub to the Wynne hub, which is quite a bit beefier but is obviously an adaptation and improvement on Mr. Pietenpol's hub. It is 3.5" long with a 1.1" thick prop flange, and is machined from 2024 aluminum, but William says it could be made from 6061. William's design uses a safety shaft that is 6" long because the hub is a bit heavier, longer, and stouter- and the safety shaft threads 1" into the crank nose rather than 3/4" as in the Pietenpol. The threads are 14 threads per inch (coarser than the Pietenpol). While the Pietenpol hub body is slightly tapered, the Wynne design is straight, again making it beefier. William's preferred method of mounting to the crank flange is through the use of what William calls "hybrid studs", which are threaded with the Chevy 11/32" on one end and a more standard 3/8-24 thread on the nut end that holds the hub to the crank flange. Here's what William says about the Pietenpol hub in his manual, of which I have three different editions dating back more than 10 years: "This method was pioneered by Bernie [sic] Pietenpol in the early 1960s. Although I know of no failures of Bernie's way of doing it, my method is a little different and uses different materials, but the concept is the same." He also says, "The Pietenpol method is brought up for technical reference only. If you are building an exact replica of Bernie's engine, his son Don is the best source of information on it. Years ago, a number of cast aluminum hubs were made to Bernie's drawings. Some of these are still floating around for sale. These are light duty units suited only to the modest flying done by Pietenpols.". My take-away: make your hub using the Pietenpol or the Wynne drawings, but ALWAYS use a safety shaft and ALWAYS use at least 6061 aluminum, NOT any cast material. To my non-machinist's eye, the two hubs require about the same amount of machine work to produce but the Wynne hub has no tapers to cut and is stronger in some important areas, and is a little less than an inch or so longer. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Aug 01, 2008
Subject: Affordable Flying Center featured aircraft: Pietenpol
Air Camper Here is a link to Bill Rewey's Piet at Oshkosh. It was getting more attention than anything else in the Affordable Flying Center http://www.airventure.org/2008/4wed30/afc.html Ben Charvet Mims, Fl ________________________________________________________________________________
Date: Aug 01, 2008
I wonder about that exact subject...the loads on a control surface/turn buc kle/cable in a Piet. Say 90 MPH and a sharp "full deflection" pull of the e levator...what kind of load does that put on the-cables, etc? For that ma tter, the hindges, wood at the attaching points, etc. I have NO idea, but c urious. I would think a wood component would let go long before a steel cab le/tunbuckle...? --- On Thu, 7/31/08, Oscar Zuniga wrote: From: Oscar Zuniga <taildrags(at)hotmail.com> Subject: Pietenpol-List: Homemade Turnbuckles Date: Thursday, July 31, 2008, 10:13 PM I got to thinking about "hardware store" turnbuckles as a possible alternative to AN/MS hardware and paged over to McMaster-Carr to snoop. Fo und some surprises. For example, let's take the typical 1/8" 7x19 aircraft cable. It's rated at 2000 lbs. strength. For that, let's pick an AN/MS turnbuckle with AN4 (1/4") threads, an eye on one end and a fork on the other, roughly 4-1/2" long. It is rated something a little over 2000 lbs. so it's a good match for that cable. Searching "the hardware store", we start with open-body aluminum "screen door" turnbuckles with 1/4" threaded eyes and find that it might be rated a couple of hundred pounds, obviously due to the aluminum body and the minimal number of threads on the eyes that engage the body. Move o n to galvanized steel and the strength improves to a couple of hundred pounds, s till very affordable. Now on to the better stuff and we find stainless steel turnbuckles, which are available in both open and closed body and seem to e ngage maybe twice as many threads but are rated no more than 800 lbs. and also ha ve a caution that the working load should not be exceeded. Can you say "fails rather sharply"? The cost of hardware store (or nautical/marine, I found) is a lot more attractive but the strength is just not there without really getting heavy. Is the aircraft hardware 'overkill' for the working loads? I don't know. I have not run any sort of analysis to determine the aerodynamic loa dings on any of them, but when we go from 2000 lbs. rating to a couple of hundred , someone had better do some testing. Same goes for home-made tensioners. I'm all in favor of better mousetraps, but let's test these things against their working stresses before we substitute. Those stainless turnbuckles look great to me and are about 1/3 the price of AN/MS hardware, but I would have to assure myself that they could handle the flight loads with at least a 2x factor of safety because my skinny a$$ is worth more than a $10 turnbuckle. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 01, 2008
Load on the control cables cables is easy to calculate The control stick is nothing more than a lever, I do not have the drawings in front of me, but let us assume a 1: 10 ratio (it is lower) Stick forces in my Pietenpol are fairly light, never measured it but my guess would be between 1- 3 pounds. But again lets assume a worst case scenario of 10 Lbs. That would be 10 x 10 = 100 Lbs of force on a cable rated for 2000. (1/8") One reason why I have 3/32 cable on my controls (rated for 1000 Lbs) to save weight If you reverse the calculation I need to lean on the controls with more than 100 Lbs to break the cable. An air plane that needs 100+ Lbs at the stick to control it has something else wrong. Now why do we use cable that is rated 10 times load, simply because some unseen damage (corrosion or chafing) can reduce the cable strenght and you want enough left to save your butt. My 2 cents Hans -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Fri, 1 Aug 2008 6:28 am Subject: Re: Pietenpol-List: Homemade Turnbuckles I wonder about that exact subject...the loads on a control surface/turn buckle/cable in a Piet. Say 90 MPH and a sharp "full deflection" pull of the elevator...what kind of load does that put on thecables, etc? For that matter, the hindges, w ood at the attaching points, etc. I have NO idea, but curious. I would think a wood component would let go long before a steel cable/tunbuckle...? --- On Thu, 7/31/08, Oscar Zuniga wrote: From: Oscar Zuniga <taildrags(at)hotmail.com> Subject: Pietenpol-List: Homemade Turnbuckles Date: Thursday, July 31, 2008, 10:13 PM I got to thinking about "hardware store" turnbuckles as a possible alternative to AN/MS hardware and paged over to McMaster-Carr to snoop. Found some surprises. For example, let's take the typical 1/8" 7x19 aircraft cable. It's rated at 2000 lbs. strength. For that, let's pick an AN/MS turnbuckle with AN4 (1/4") threads, an eye on one end and a fork on the other, roughly 4-1/2" long. It is rated something a little over 2000 lbs. so it's a good match for that cable. Searching "the hardware store", we start with open-body aluminum "screen door" turnbuckles with 1/4" threaded eyes and find that it might be rated a couple of hundred pounds, obviously due to the aluminum body and the minimal number of threads on the eyes that engage the body. Move on to galvanized steel and the strength improves to a couple of hundred pounds, still very affordable. Now on to the better stuff and we find stainless steel turnbuckles, which are available in both open and closed body and seem to engage maybe twice as many threads but are rated no more than 800 lbs. and also have a caution that the working load should not be exceeded. Can you say "fails rather sharply"? The cost of hardware store (or nautical/marine, I found) is a lot more attractive but the strength is just not there without really getting heavy. Is the aircraft hardware 'overkill' for the working loads? I don't know. I have not run any sort of analysis to determine the aerodynamic loadings on any of them, but when we go from 2000 lbs. rating to a couple of hundred, someone had better do some testing. Same goes for home-made tensioners. I'm all in favor of better mousetraps, but let's test these things against their working stresses before we substitute. Those stainless turnbuckles look great to me and are about 1/3 the price of AN/MS hardware, but I would have to assure myself that they could handle the flight loads with at least a 2x factor of safety because my skinny a$$ is worth more than a $10 turnbuckle. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net D======================= ===== 3D===== D======================= =========== D======================= =========== D======================= =========== =0 A ************************************** ________________________________________________________________________________
Date: Aug 01, 2008
That all makes sense to me. I wonder,though, given your worse case scenerio , if a pully would break free from the wood long before a cable letting go? Just curious...things to ponder, I guess. --- On Fri, 8/1/08, hvandervoo(at)aol.com wrote: From: hvandervoo(at)aol.com <hvandervoo(at)aol.com> Subject: Re: Pietenpol-List: Homemade Turnbuckles Date: Friday, August 1, 2008, 9:21 AM Load on the control cables cables is easy to calculate The control stick is nothing more than a lever, I do not have the drawings in front of me, but let us assume a 1: 10 ratio (it is lower) Stick forces in my Pietenpol are fairly light, never measured it but my guess would be between 1- 3 pounds. But again lets assume a worst case scenario of 10 Lbs. That would be 10 x 10 = 100 Lbs of force on a cable rated for 2000. (1/8") One reason why I have 3/32 cable on my controls (rated for 1000 Lbs) to save weight If you reverse the calculation I need to lean on the controls with more than 100 Lbs to break the cable. An air plane that needs 100+ Lbs at the stick to control it has something else wrong. Now why do we use cable that is rated 10 times load, simply because some unseen damage (corrosion or chafing) can reduce the cable strenght and you want enough left to save your butt. My 2 cents Hans -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Fri, 1 Aug 2008 6:28 am Subject: Re: Pietenpol-List: Homemade Turnbuckles I wonder about that exact subject...the loads on a control surface/turn buckle/cable in a Piet. Say 90 MPH and a sharp "full deflection" pull of the elevator...what kind of load does that put on the-cables, etc? For that matter, the hindges, w ood at the attaching points, etc. I have NO idea, but curious. I would think a wood component would let go long before a steel cable/tunbuckle...? --- On Thu, 7/31/08, Oscar Zuniga wrote: From: Oscar Zuniga <taildrags(at)hotmail.com> Subject: Pietenpol-List: Homemade Turnbuckles Date: Thursday, July 31, 2008, 10:13 PM I got to thinking about "hardware store" turnbuckles as a possible alternative to AN/MS hardware and paged over to McMaster-Carr to snoop. Found some surprises. For example, let's take the typical 1/8" 7x19 aircraft cable. It's rated at 2000 lbs. strength. For that, let's pick an AN/MS turnbuckle with AN4 (1/4") threads, an eye on one end and a fork on the other, roughly 4-1/2" long. It is rated something a little over 2000 lbs. so it's a good match for that cable. Searching "the hardware store", we start with open-body aluminum "screen door" turnbuckles with 1/4" threaded eyes and find that it might be rated a couple of hundred pounds, obviously due to the aluminum body and the minimal number of threads on the eyes that engage the body. Move on to galvanized steel and the strength improves to a couple of hundred pounds, still very affordable. Now on to the better stuff and we find stainless steel turnbuckles, which are available in both open and closed body and seem to engage maybe twice as many threads but are rated no more than 800 lbs. and also have a caution that the working load should not be exceeded. Can you say "fails rather sharply"? The cost of hardware store (or nautical/marine, I found) is a lot more attractive but the strength is just not there without really getting heavy. Is the aircraft hardware 'overkill' for the working loads? I don't know. I have not run any sort of analysis to determine the aerodynamic loadings on any of them, but when we go from 2000 lbs. rating to a couple of hundred, someone had better do some testing. Same goes for home-made tensioners. I'm all in favor of better mousetraps, but let's test these things against their working stresses before we substitute. Those stainless turnbuckles look great to me and are about 1/3 the price of AN/MS hardware, but I would have to assure myself that they could handle the flight loads with at least a 2x factor of safety because my skinny a$$ is worth more than a $10 turnbuckle. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =0 A ************************************** ________________________________________________________________________________
Subject: Homemade Turnbuckles
Date: Aug 01, 2008
I like your logical approach, Hans. When talking about the strength of any system, we always go back to the old adage of "a chain is only as strong as it's weakest link". In the case of the control cables, as Oscar had pointed out, 1/8" aircraft cable is rated at 2000lb, and a 1/4" (AN4) turnbuckle has the same rating. Sounds plenty strong. However, are the sheet metal control horns the cables are tied to rated for 2000lb? Is the connection of that control horn to the wood rated for 2000 lb? Not even close! So, your choice of using 3/32" cables (and I would assume AN3 turnbuckles) makes sense to me. If the system is loaded anywhere near 1000 lb it will fail somewhere else other than the cable/turnbuckle . Even if you were to exert a 50 lb force at the stick (which would be 500 lb of tension on the cable and the control horns), your choice of cable still has a factor of safety of 2. Of course, regardless of what size cable is used, regular inspections are critical. This is the same type of logic I was applying when looking at the possibility of making the "homemade turnbuckles" that started this thread. It has always been my intention to do controlled, real world testing of any assembly that I come up with before I would even consider putting them in my plane. After the design is refined, I plan to build several sample assemblies which would be placed in tension, with the load incrementally increased to the point of failure. If the result is not satisfactory, the idea goes in the trash bin, and we move on. Regarding hardware store turnbuckles, these things are crudely made, and I would stay away from them. Regarding the actual cables, I would NOT buy my "aircraft" cables at the hardware store. The cable they sell is more likely "commercial" cable (although it might be referred to as aircraft cable) which is not lubricated, and will be far less resistant to fatigue failure. Just bite the bullet and buy the real thing. Also, if a cable is running over a pulley, be sure to use galvanized cable, rather than stainless steel, as the stainless steel cable will fail before the galvanized. If the cables do not change direction, stainless is okay (like tail bracing wires or landing gear bracing wires, etc.) Bill C. ________________________________________________________________________________
Subject: Re: Waldo Pepper
Date: Aug 01, 2008
QWxsIHRocmVlDQoNCg0KU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgQmxhY2tCZXJyeQ0K DQotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogIkJpbGwgQ2h1cmNoIiA8ZW5nQGNh bmFkaWFucm9nZXJzLmNvbT4NCg0KRGF0ZTogRnJpLCAxIEF1ZyAyMDA4IDA5OjM1OjMyIA0KVG86 IDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUkU6IFBpZXRlbnBvbC1M aXN0OiBXYWxkbyBQZXBwZXINCg0KDQpXaGF0IHdlIHJlYWxseSBuZWVkIGlzIHNvbWUgY29ubmVj dGlvbiBiZXR3ZWVuIHRoZSBtZXNzYWdlIGFuZCB0aGUgcmVwbHkuDQogDQpUYWxrIGFib3V0IGEg bm9uLXNlcXVpdHVyLg0KIA0KRG8gTm90IEFyY2hpdmUgdGhpcyBlaXRoZXIuDQoNCiAgX19fX18g IA0KDQpGcm9tOiBvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbQ0KW21h aWx0bzpvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxm IE9mIERhdmUNCkFicmFtc29uDQpTZW50OiBGcmlkYXksIEF1Z3VzdCAwMSwgMjAwOCA5OjE5IEFN DQpUbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IFBpZXRlbnBv bC1MaXN0OiBXYWxkbyBQZXBwZXINCg0KDQpXZSBuZWVkIHRoZSBjaGFyYWN0b3IgbmFtZXMgYmVm b3JlIHRoZWlyIGxpbmVzISEhISANCiANCkF4ZWwsIE1hcnktQmV0aCwgYW5kIFdhbGRvISEhDQog DQpEbyBub3QgQXJjaGl2ZQ0KIA0KIA0KDQotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KRnJv bTogb3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20NClttYWlsdG86b3du ZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dT24gQmVoYWxmIE9mDQpBTXNh ZmV0eUNAYW9sLmNvbQ0KU2VudDogVGh1cnNkYXksIEp1bHkgMzEsIDIwMDggNjo0OSBQTQ0KVG86 IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlz dDogV2FsZG8gUGVwcGVyDQoNCg0KDQogDQogDQpJbiBhIG1lc3NhZ2UgZGF0ZWQgNy8zMS8yMDA4 IDk6Mzg6NDUgUC5NLiBFYXN0ZXJuIERheWxpZ2h0IFRpbWUsDQptaW5veHBob3RvZ3JhcGhlckB5 YWhvby5jb20gd3JpdGVzOg0KDQpGb3IgdGhvc2Ugd2hvIG1pZ2h0IHRoaW5rIGEgV3lubmUgbWFu dWFsIGlzIGV4cGVuc2l2ZSwgYSAkNDAgbW92aWUgY2VydGFpbmx5DQp3b3VsZCBiZSEgDQoNCiAN CiANCg0KSSBkb3VidCB5b3UnbGwgZXZlciBoZWFyIGFueW9uZSBxdW90ZSBsaW5lcyBmb3IgdGhl IGhlYWQgdG9ycXVlIHBhdHRlcm4gb3INCnRpbWluZyBnZWFyIHNlY3Rpb25zIG9mIHRoZSBib29r DQoNCldoYXQgYXJlIHlvdSBkb2luZywgSSdtIGJvcnJvd2luZyB5b3VyIHBsYW5lIHNvbiwgaXRz IGFuIGluZmVyaW9yIG1vZGVsIGJ1dA0KaXQgaWxsIGRvLCBEaWxsaG9mZmVyIHByb21pc2VkIG1l IGEgam9iLCB5b3UgJ3JlIG5vdCBnb2luZyBhbnl3aGVyZSB3aXRoIG15DQpwbGFuZS4uLiBZb3Un cmUgYm90aCBzdGFydmluZyB3aHkgbm90IGhlbHAgZWFjaCBvdGhlcg0KV2hhdCB3b3VsZCB3ZSBk bz8geW91ciBwbGFuZSBpcyBkb3duIGZvciByZXBhaXIgYW5kIG15IGVuZ2luZSBpcyBnaXZpbmcg bWUNCmZpdHMuLi4uLiBBY3R1YWxseSBJIGhhdmUgc29tZSBpZGVhcyBvbiB0aGUgc3ViamVjdC4N CiANCkxldHMgZ2V0IHRoaXMgc3RyYWlnaHQsIHlvdSdyZSBqdXN0IGZseWluZywgc2hlJ3MganVz dCBkcml2aW5nLCBJJ20gdGhlIG9uZQ0KZG9pbmcgYSBncmVhdCBzdHVudCwgdGhhdCB3aHkgeW91 J3JlIGdldHRpbmcgYWxsIHRoZSBnbG9yeSBzb24NCiANCiANCiANCkpvaG4NCg0KDQogDQoNCg0K DQoNCg0KICBfX19fXyAgDQoNCkdldCBmYW50YXN5IGZvb3RiYWxsIHdpdGggZnJlZSBsaXZlIHNj b3JpbmcuIFNpZ24gdXAgZm9yIEZhbkhvdXNlIEZhbnRhc3kNCkZvb3RiYWxsIHRvZGF5DQo8aHR0 cDovL3d3dy5mYW5ob3VzZS5jb20vZmFudGFzeWFmZmFpcj9uY2lkPWFvbHNwcjAwMDUwMDAwMDAw MDIwPiAuDQoNCg0KDQoNCmhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ UGlldGVucG9sLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWMNCnMuY29tL05hdmlnYXRvcj9QaWV0 ZW5wb2wtTGlzdA0KDQpocmVmPSJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vYw0KDQoNCg0KDQoNCg0KDQoNCg0K DQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQo ________________________________________________________________________________
Date: Aug 01, 2008
SSBkb24ndCBrbm93IG9mIGFueW9uZSBpbiB0aGUgbW92aWUgc2F5aW5nIHRoYXQNCj8/Pz8/Pz8N Cg0KU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgQmxhY2tCZXJyeQ0KDQotLS0tLU9yaWdp bmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogIkJpbGwgQ2h1cmNoIiA8ZW5nQGNhbmFkaWFucm9nZXJz LmNvbT4NCg0KRGF0ZTogRnJpLCAxIEF1ZyAyMDA4IDExOjMxOjUyIA0KVG86IDxwaWV0ZW5wb2wt bGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUkU6IFBpZXRlbnBvbC1MaXN0OiBXYWxkbyBQ ZXBwZXINCg0KDQo/Pz8/Pz8NCiANCihqdXN0IHNob290IG1lIG5vdykNCg0KX19fX18gIA0KDQpG cm9tOiBvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93 bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgSm9o biBSZWNpbmUNClNlbnQ6IEZyaWRheSwgQXVndXN0IDAxLCAyMDA4IDEwOjU0IEFNDQpUbzogcGll dGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBX YWxkbyBQZXBwZXINCg0KDQpBbGwgdGhyZWUNCg0KDQoNClNlbnQgZnJvbSBteSBWZXJpem9uIFdp cmVsZXNzIEJsYWNrQmVycnkNCg0KDQpfX19fXyAgDQoNCkZyb206ICJCaWxsIENodXJjaCIgPGVu Z0BjYW5hZGlhbnJvZ2Vycy5jb20+DQpEYXRlOiBGcmksIDEgQXVnIDIwMDggMDk6MzU6MzIgLTA0 MDANClRvOiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJFOiBQaWV0 ZW5wb2wtTGlzdDogV2FsZG8gUGVwcGVyDQoNCg0KV2hhdCB3ZSByZWFsbHkgbmVlZCBpcyBzb21l IGNvbm5lY3Rpb24gYmV0d2VlbiB0aGUgbWVzc2FnZSBhbmQgdGhlIHJlcGx5Lg0KIA0KVGFsayBh Ym91dCBhIG5vbi1zZXF1aXR1ci4NCiANCkRvIE5vdCBBcmNoaXZlIHRoaXMgZWl0aGVyLg0KDQpf X19fXyAgDQoNCkZyb206IG93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29t IFttYWlsdG86b3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJl aGFsZiBPZiBEYXZlIEFicmFtc29uDQpTZW50OiBGcmlkYXksIEF1Z3VzdCAwMSwgMjAwOCA5OjE5 IEFNDQpUbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IFBpZXRl bnBvbC1MaXN0OiBXYWxkbyBQZXBwZXINCg0KDQpXZSBuZWVkIHRoZSBjaGFyYWN0b3IgbmFtZXMg YmVmb3JlIHRoZWlyIGxpbmVzISEhISANCiANCkF4ZWwsIE1hcnktQmV0aCwgYW5kIFdhbGRvISEh DQogDQpEbyBub3QgQXJjaGl2ZQ0KIA0KIA0KDQotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0K RnJvbTogb3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpv d25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV1PbiBCZWhhbGYgT2YgQU1z YWZldHlDQGFvbC5jb20NClNlbnQ6IFRodXJzZGF5LCBKdWx5IDMxLCAyMDA4IDY6NDkgUE0NClRv OiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUGlldGVucG9sLUxp c3Q6IFdhbGRvIFBlcHBlcg0KDQoNCg0KIA0KIA0KSW4gYSBtZXNzYWdlIGRhdGVkIDcvMzEvMjAw OCA5OjM4OjQ1IFAuTS4gRWFzdGVybiBEYXlsaWdodCBUaW1lLCBtaW5veHBob3RvZ3JhcGhlckB5 YWhvby5jb20gd3JpdGVzOg0KDQpGb3IgdGhvc2Ugd2hvIG1pZ2h0IHRoaW5rIGEgV3lubmUgbWFu dWFsIGlzIGV4cGVuc2l2ZSwgYSAkNDAgbW92aWUgY2VydGFpbmx5IHdvdWxkIGJlISANCg0KIA0K IA0KDQpJIGRvdWJ0IHlvdSdsbCBldmVyIGhlYXIgYW55b25lIHF1b3RlIGxpbmVzIGZvciB0aGUg aGVhZCB0b3JxdWUgcGF0dGVybiBvciB0aW1pbmcgZ2VhciBzZWN0aW9ucyBvZiB0aGUgYm9vaw0K DQpXaGF0IGFyZSB5b3UgZG9pbmcsIEknbSBib3Jyb3dpbmcgeW91ciBwbGFuZSBzb24sIGl0cyBh biBpbmZlcmlvciBtb2RlbCBidXQgaXQgaWxsIGRvLCBEaWxsaG9mZmVyIHByb21pc2VkIG1lIGEg am9iLCB5b3UgJ3JlIG5vdCBnb2luZyBhbnl3aGVyZSB3aXRoIG15IHBsYW5lLi4uIFlvdSdyZSBi b3RoIHN0YXJ2aW5nIHdoeSBub3QgaGVscCBlYWNoIG90aGVyDQpXaGF0IHdvdWxkIHdlIGRvPyB5 b3VyIHBsYW5lIGlzIGRvd24gZm9yIHJlcGFpciBhbmQgbXkgZW5naW5lIGlzIGdpdmluZyBtZSBm aXRzLi4uLi4gQWN0dWFsbHkgSSBoYXZlIHNvbWUgaWRlYXMgb24gdGhlIHN1YmplY3QuDQogDQpM ZXRzIGdldCB0aGlzIHN0cmFpZ2h0LCB5b3UncmUganVzdCBmbHlpbmcsIHNoZSdzIGp1c3QgZHJp dmluZywgSSdtIHRoZSBvbmUgZG9pbmcgYSBncmVhdCBzdHVudCwgdGhhdCB3aHkgeW91J3JlIGdl dHRpbmcgYWxsIHRoZSBnbG9yeSBzb24NCiANCiANCiANCkpvaG4NCg0KDQogDQoNCg0KDQoNCg0K X19fX18gIA0KDQpHZXQgZmFudGFzeSBmb290YmFsbCB3aXRoIGZyZWUgbGl2ZSBzY29yaW5nLiBT aWduIHVwIGZvciBGYW5Ib3VzZSBGYW50YXN5IEZvb3RiYWxsIHRvZGF5IDxodHRwOi8vd3d3LmZh bmhvdXNlLmNvbS9mYW50YXN5YWZmYWlyP25jaWQ9YW9sc3ByMDAwNTAwMDAwMDAwMjA+IC4NCiAg aHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdCI+ aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdCBocmVmPSJo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbSBo cmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vYw0KDQogIGhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0 b3I/UGlldGVucG9sLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UGll dGVucG9sLUxpc3QgaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIj5odHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20gaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1 dGlvbiI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2MNCiAgaHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdCBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uID09PT09PT09PT09IA0K77+977+977+9fu+/ve+/ve+/vSzerumiou+/vVANCg0K ________________________________________________________________________________
Date: Aug 01, 2008
Subject: Re:The Great Waldo Pepper
Waldo Pepper (Robert Redford) feels he has missed out on the glory of aerial combat in World War I after being made a flight instructor. When the fighting ends, Waldo has taken up barnstorming to make a living. He soon tangles with rival barnstormer Axel Olsson (Bo Svenson). The two eventually wind up flying for the traveling air show owned by Dillhoefer (Philip Bruns). In an effort to attract bigger crowds, Dillhoefer introduces several young ladies into the show, including Mary Beth (Susan Sarandon) and Patsy (Kelly Jean Peters). As the show moves from town to town, and the crew practices new stunts, they experience problems, errors, and crashes. As a result of the death of Mary Beth during a wing walking stunt, Waldo is grounded by a federal aviation inspector, a man from Waldo's past named Newt (Geoffrey Lewis). Waldo ultimately loses his pilot's license, but this doesn't stop him from flying for very long. Under an alias, Waldo gets a job as a stunt pilot in a Hollywood film depicting the air battles of the Great War. Famous German air ace Ernst Kessler (Bo Brundin) has also been hired by the producers, as a consultant and to fly a Fokker Dr. I replica. The disillusioned, bitter and heavy drinking depiction of Kessler is based on the real German ace and stunt flier Ernst Udet. During filming of a famous wartime duel, though their fighters are unarmed, Waldo and Kessler begin dogfighting in deadly earnest, using their airplanes as weapons. ________________________________________________________________________________
Date: Aug 01, 2008
It certainly looses a bunch in the nutshell version In a message dated 8/1/2008 2:06:50 P.M. Eastern Daylight Time, davea(at)symbolicdisplays.com writes: That's it in a nutshell!!!!!!!!!!!! do not archive -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of H RULE Sent: Friday, August 01, 2008 10:09 AM Subject: Re: Pietenpol-List: Re:The Great Waldo Pepper Waldo Pepper (Robert Redford) feels he has missed out on the glory of aerial combat in _World War I_ (http://en.wikipedia.org/wiki/World_War_I) after being made a flight instructor. When the fighting ends, Waldo has taken up _barnstorming_ (http://en.wikipedia.org/wiki/Barnstorming) to make a living. He soon tangles with rival barnstormer Axel Olsson (_Bo Svenson_ (http://en.wikipedia.org/wiki/Bo_Svenson) ). The two eventually wind up flying for the traveling air show owned by Dillhoefer (_Philip Bruns_ (http://en.wikipedia.org/wiki/Philip_Bruns) ). In an effort to attract bigger crowds, Dillhoefer introduces several young ladies into the show, including Mary Beth (_Susan Sarandon_ (http://en.wikipedia.org/wiki/Susan_Sarandon) ) and Patsy (Kelly Jean Peters). As the show moves from town to town, and the crew practices new stunts, they experience problems, errors, and crashes. As a result of the death of Mary Beth during a _wing walking_ (http://en.wikipedia.org/wiki/Wing_walking) stunt, Waldo is grounded by a federal aviation inspector, a man from Waldo's past named Newt (_Geoffrey Lewis_ (http://en.wikipedia.org/wiki/Geoffrey_Lewis_(actor)) ). Waldo ultimately loses his pilot's license, but this doesn't stop him from flying for very long. Under an alias, Waldo gets a job as a stunt pilot in a _Hollywood_ (http://en.wikipedia.org/wiki/Hollywood) film depicting the air battles of the Great War. Famous German air ace Ernst Kessler (Bo Brundin) has also been hired by the producers, as a consultant and to fly a _Fokker Dr. I_ (http://en.wikipedia.org/wiki/Fokker_Triplane) replica. The disillusioned, bitter and heavy drinking depiction of Kessler is based on the real German ace and stunt flier _Ernst Udet_ (http://en.wikipedia.org/wiki/Ernst_Udet) . During filming of a famous wartime duel, though their fighters are unarmed, Waldo and Kessler begin _dogfighting_ (http://en.wikipedia.org/wiki/Dogfight) in deadly earnest, using their airplanes as weapons. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Subject: Brodhead Pictures
Date: Aug 01, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
OK, I'll try again to post some low resolution pictures (out of respect for those who suffer from dial-up modems) from last weekend's Brodhead Pietenpol Extravaganza: The grass was green, the mosquitos were plentiful and hungry, and the Pietenpols were in abundance (at least more so than the Hatz Biplanes). Here is a picture of the field: <> Here is what it looked like from my Pietenpol at 300' AGL: <> There was good food, and good camaraderie. And lots of Piet builders taking pictures and making notes from every flying Pietenpol on the field (I think there were a total of 14 Piets there): <> By the way, on the way home I went by Jackson, TN to visit my Mom. Coming out of there Monday morning, Flight Service forecast "a few clouds at 600' ". By the time I got to the Tennessee River at Clifton, this is what I found: <> Shortly after that picture was taken, it walled in all around me and I was suddenly in full IMC. If I didn't have a Turn & Bank indicator I don't know what I would have done. As it was, I did a 180 and went back to Jackson to wait for it to clear up. Made it back home Tuesday afternoon. In 5 days I put a little over 34 hours on the airplane and flew just over 1900 miles. Jack Phillips NX899JP Raleigh, NC _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Aug 01, 2008
Didn't know a Piet could go that high! That's encouraging...;<) Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (11 ribs down.) _____ <> Shortly after that picture was taken, it walled in all around me and I was suddenly in full IMC. If I didn't have a Turn & Bank indicator I don't know what I would have done. As it was, I did a 180 and went back to Jackson to wait for it to clear up. Made it back home Tuesday afternoon. In 5 days I put a little over 34 hours on the airplane and flew just over 1900 miles. Jack Phillips NX899JP Raleigh, NC _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Aug 01, 2008
Actually, I was at about 2,000' when that picture was made. Those clouds were really low (or I would have just gone under them when they started forming). I was near the Tennessee River and I suspect that over the river they went all the way down to the deck Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Friday, August 01, 2008 3:37 PM Subject: RE: Pietenpol-List: Brodhead Pictures Didn't know a Piet could go that high! That's encouraging.....;<) Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (11 ribs down...) _____ <> Shortly after that picture was taken, it walled in all around me and I was suddenly in full IMC. If I didn't have a Turn & Bank indicator I don't know what I would have done. As it was, I did a 180 and went back to Jackson to wait for it to clear up. Made it back home Tuesday afternoon. In 5 days I put a little over 34 hours on the airplane and flew just over 1900 miles. Jack Phillips NX899JP Raleigh, NC _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject:
Date: Aug 01, 2008
I've decided to "bump up" the top of my center section fuel tank, moth style, to get another hour. Now that the top will visible, I want it to look decent. My problem is that when I weld the cap flange to the top of the curved section, it distorts the top something fierce. I'm tig welding aluminum. I'm going to try again with the top flat on my welding table and the flange clamped down. I was thinking I'd cut the hole later which might help keep things in position. Any ideas on how to get a nice distortion free top? Douwe ________________________________________________________________________________
Subject: Re: No Title
Date: Aug 01, 2008
Douwe, Any chance you could snap a picture to show what kind of distortion you're getting, and what the application looks like? It would really help in terms of offering pertinent advise. Is the tank fully welded other than the filler, or is the top of the tank not yet attached to the rest of the tank? The usual way to deal with welding distortion is twofold, especially with aluminum, which requires more heat to weld than steel or stainless. First, you should expect that there will be some distortion. If you are expecting to have a perfect, smooth, distortion-free weld that requires no post-weld correction, you are likely to be disappointed every time. Knowing the ways that welds will act allows you to use methods that can minimize that distortion. Using TIG will help, because the weld is more concentrated. The first step is to tack-weld the two pieces together in as many places as possible, to minimize movement as you do the final seam welding. After the pieces are tacked together, check for positioning, and adjust with a small hammer as required. When you are happy with the positioning, you can weld off the entire joint. Since this weld's primary function is to be liquid-proof, rather than structural, make the welds as small as possible. Secondly, the most effective method of removing weld distortion is through the use of a sophisticated set of instruments called a hammer and a backing bar (or block). The extreme, localized heat of welding puts a lot of stresses into the metal in and around the weld. In the areas where the weld shrinks the metal, you need to stretch it back to it's pre-weld state. This is where the hammer and backing bar come in. Of course, the best approach might be to take an entirely different approach, and install a flanged filler neck, which would be attached with mechanical fasteners - eliminating the welding, and all the distortion that goes with it. Here's a link to the way Jim Markle did his. Looks good to me. http://www.mykitplane.com/Planes/buildLogReportDetail.cfm?BuildLogID=396&PlaneID=52 Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196081#196081 ________________________________________________________________________________
Date: Aug 01, 2008
Subject: test
test walt evans NX140DL ________________________________________________________________________________
Date: Aug 01, 2008
Subject: my project
Evening Everyone, I want to apologize and take back the statement when I said that we were shortening the wing. That indeed was a misstep on my part and I wanted to clarify. What I am going is that after the 14th rib is made dad and I would look at what is the best to proceed in the rib construction. My dad would would like to modify the jig and build the ribs where the aileron will be place. Alternatively we could do what Ben C and Hans have suggested and just take a saw to it we will just have to wait and see. On another note who what the great waldo pepper. I gather that its a movie but thats all I know I have never seen it. take care & Happy Building or flying, Ben in MN ________________________________________________________________________________
Subject: project progress
Date: Aug 01, 2008
Everyone: Had a wonderful time at Brodhead, but didn't get to talk to everyone, always a disappointment. It is amazing that no matter how many times you go and look at often the same Piets, depending on what point you are in on your own project, you see new details that you never noticed before. I learned a LOT this trip! After returning, I blasted, primed, and painted all of my steel parts (well, almost all). Today, I started bolting things on PERMANENTLY!! Before I did, though, I weighed my fuselage. Mine is a short fuselage, with only minor modifications. No fittings whatsoever, only wood and varnish, my completed fuselage weighs 33.6 lbs. according to my digital bathroom scale. I know there have been postings on here with fuselage weights, but I am too lazy to look them up right now. How does this compare to others??? My biggest problem is that I will not have another day off until next Thursday to go out and work again, bummer!! Gene ________________________________________________________________________________
From: "mr-fix-all" <jb.spiegel(at)us.schneider-electric.com>
Date: Aug 01, 2008
I was reading you post about the aluminum warping when you weld it, a friend of mine works for LifeLine ambulance where they scratch build ambulances. they had the same problem when welding the window and door frames in the large panels of aluminum. The solution was surprisingly low tech. They have large pieces of 2x6 rectangular aluminum tubing that they have capped on both ends which they filled with water then freeze them they clamp the frozen tubes about 1 inch away from the seam and weld. works like a charm. Jake -------- "Be who you are and say what you think, those that mind don't matter, and those that matter don't mind" Dr. Seuss Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196111#196111 ________________________________________________________________________________
Subject: welding
Date: Aug 02, 2008
Thanks for the welding tips. Bill, I am welding the flange on the top before attaching to the tank. I think I may have gotten sloppy and let the flange move away from the sheet as I tacked it. Jake, great tip!! i had thought something like that might soak up the heat but hadn't thought of such a clean solution. Love this forum!! Douwe ________________________________________________________________________________
Subject: Re: my project
Date: Aug 02, 2008
Ben, Why do you need to modify the wing rib jig? I thought the recommended method of construction was to build the ailerons in-place and then cut them free. As I understand it this helps the ailerons line up perfectly with the rest of the wing. This would mean all the ribs are built the same. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ________________________________________________________________________________
Date: Aug 02, 2008
I wish I had an answer for you chris. This is just what my dad wants to do. Maybe in his mind it might be easier not sure on that! ----- Original Message ---- From: "catdesigns(at)att.net" <catdesigns(at)att.net> Sent: Saturday, August 2, 2008 10:26:11 AM Subject: Re: Pietenpol-List: my project Ben, Why do you need to modify the wing rib jig? I thought the recommended method of construction was to build the ailerons in-place and then cut them free. As I understand it this helps the ailerons line up perfectly with the rest of the wing. This would mean all the ribs are built the same. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ________________________________________________________________________________
Subject: Re: welding
Date: Aug 02, 2008
Douwe, I would also avoid cutting the hole till your finished. Jake "Douwe Blumberg" Sent by: owner-pietenpol-list-server(at)matronics.com 08/02/2008 09:54 AM Please respond to pietenpol-list(at)matronics.com To "pietenpolgroup" cc Subject Pietenpol-List: welding Thanks for the welding tips. Bill, I am welding the flange on the top before attaching to the tank. I think I may have gotten sloppy and let the flange move away from the sheet as I tacked it. Jake, great tip!! i had thought something like that might soak up the heat but hadn't thought of such a clean solution. Love this forum!! Douwe ________________________________________________________________________ This email has been scanned for SPAM content and Viruses by the MessageL abs Email Security System. ________________________________________________________________________ ________________________________________________________________________________
Date: Aug 02, 2008
Correct, you build the ailerons as part of the wing and saw it out later, makes aileron construction very easy. Rick On Sat, Aug 2, 2008 at 9:26 AM, wrote: > > Ben, > > Why do you need to modify the wing rib jig? I thought the recommended > method of construction was to build the ailerons in-place and then cut them > free. As I understand it this helps the ailerons line up perfectly with the > rest of the wing. This would mean all the ribs are built the same. > > Chris Tracy > Sacramento, Ca > Website at http://www.WestCoastPiet.com > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 02, 2008
Ben, Yeah, you build the whole wing, in one piece,,,then you glue in the airleron spars, and when done, cut out the airleron. Works great. PS I would trammel the wing before glueing in the airleron stuff and cutting. This makes sure all is parallel. walt evans NX140DL ----- Original Message ----- From: <catdesigns(at)att.net> Sent: Saturday, August 02, 2008 11:26 AM Subject: Re: Pietenpol-List: my project > > Ben, > > Why do you need to modify the wing rib jig? I thought the recommended > method of construction was to build the ailerons in-place and then cut > them free. As I understand it this helps the ailerons line up perfectly > with the rest of the wing. This would mean all the ribs are built the > same. > > Chris Tracy > Sacramento, Ca > Website at http://www.WestCoastPiet.com > > > ________________________________________________________________________________
Date: Aug 02, 2008
what do you mean by trammel the wing? Ben in MN ----- Original Message ---- From: walt <waltdak(at)verizon.net> Sent: Saturday, August 2, 2008 11:05:27 AM Subject: Re: Pietenpol-List: my project Ben, Yeah, you build the whole wing, in one piece,,,then you glue in the airleron spars, and when done, cut out the airleron. Works great. PS I would trammel the wing before glueing in the airleron stuff and cutting. This makes sure all is parallel. walt evans NX140DL ----- Original Message ----- From: <catdesigns(at)att.net> Sent: Saturday, August 02, 2008 11:26 AM Subject: Re: Pietenpol-List: my project > > Ben, > > Why do you need to modify the wing rib jig? I thought the recommended > method of construction was to build the ailerons in-place and then cut > them free. As I understand it this helps the ailerons line up perfectly > with the rest of the wing. This would mean all the ribs are built the > same. > > Chris Tracy > Sacramento, Ca > Website at http://www.WestCoastPiet.com > > > ________________________________________________________________________________
Date: Aug 02, 2008
Ben, You can check the archives, and I'm sure others will jump in. But it's a process, that has to be done on all wings, where, using a long device that you can make yourself. consisting of a rod with 2 pins at right angles. You pick points near both ends of the spar where the ribs cross. By taking diagonal comparisons of each, you can tell if the "rectangle" is square. This means pushing or pulling each spar slightly till the criss-cross readings are equal. Usually done when the flying and drag wires are installed. This way when you glue in the aierleron spars are glued in,,,all will be square walt evans NX140DL ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Saturday, August 02, 2008 1:36 PM Subject: Re: Pietenpol-List: my project > > > what do you mean by trammel the wing? > Ben in MN > > > ----- Original Message ---- > From: walt <waltdak(at)verizon.net> > To: pietenpol-list(at)matronics.com > Sent: Saturday, August 2, 2008 11:05:27 AM > Subject: Re: Pietenpol-List: my project > > > Ben, > Yeah, you build the whole wing, in one piece,,,then you glue in the > airleron > spars, and when done, cut out the airleron. Works great. > PS I would trammel the wing before glueing in the airleron stuff and > cutting. This makes sure all is parallel. > walt evans > NX140DL > > > ----- Original Message ----- > From: <catdesigns(at)att.net> > To: > Sent: Saturday, August 02, 2008 11:26 AM > Subject: Re: Pietenpol-List: my project > > >> >> Ben, >> >> Why do you need to modify the wing rib jig? I thought the recommended >> method of construction was to build the ailerons in-place and then cut >> them free. As I understand it this helps the ailerons line up perfectly >> with the rest of the wing. This would mean all the ribs are built the >> same. >> >> Chris Tracy >> Sacramento, Ca >> Website at http://www.WestCoastPiet.com >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 02, 2008
Subject: Piets in Hawaii
Just back form a 10 day business trip that included Brodhead and I am out again on Tuesday for Hawaii on business, I may be there for about a week. Any Piets on the big island or any of the islands for that matter? Ill be there soon enough and would love to visit a Piet Hawaiian style. John **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Date: Aug 02, 2008
Subject: Re: Inspection holes (wing)
"Wait till you get to the part about the empty oatmeal cardboard containers ;o)" Oscar, oh great, that will be the one thing we obsess about till we know =) On the road from Osh down to Brodhead right now, I don't expect to post this till returning to Scholler. Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ============================== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 5/27/2008 12:56:22 P.M. Central Daylight Time, taildrags(at)hotmail.com writes: Wait till you get to the part about the empty oatmeal cardboard containers ;o) **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Date: Aug 02, 2008
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: Re: Piets in Hawaii
John, - With all the travel you do..... I want your job! What is it that you do aga in?.....airplane security agent inspecting flight attendant demeanors?..... .lol Kenneth M. Heide, BA, CPO, FAAOP - --- On Sat, 8/2/08, AMsafetyC(at)aol.com wrote: From: AMsafetyC(at)aol.com <AMsafetyC(at)aol.com> Subject: Pietenpol-List: Piets in Hawaii Date: Saturday, August 2, 2008, 8:04 PM Just back form a 10 day business trip that included Brodhead and I am out a gain on Tuesday for Hawaii on business, I may be there for about a week. - Any Piets on the big island or any of the islands for that matter? - Ill be there soon enough and would love to visit a Piet Hawaiian style. - John Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. =0A=0A=0A ________________________________________________________________________________
Date: Aug 03, 2008
S2VuDQoNCkl0cyBhIG5hc3R5IGpvYiBidXQgc29tZW9uZXMgZ290IHRvIGRvIGl0ISBTaG91bGQg SSBzZW5kIHlvdSBzb21lIHBpY3Mgb2YgbWUgYXQgd29yaz8gDQoNClN1eCBiZWluZyBtZQ0KDQpK b2huDQpTZW50IGZyb20gbXkgVmVyaXpvbiBXaXJlbGVzcyBCbGFja0JlcnJ5DQoNCi0tLS0tT3Jp Z2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAiS01IZWlkZSwgQkEsIENQTywgRkFBT1AiIDxrbWhl aWRlY3BvQHlhaG9vLmNvbT4NCg0KRGF0ZTogU2F0LCAyIEF1ZyAyMDA4IDIxOjM2OjEzIA0KVG86 IDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUmU6IFBpZXRlbnBvbC1M aXN0OiBQaWV0cyBpbiBIYXdhaWkNCg0KDQpKb2huLCANCqANCldpdGggYWxsIHRoZSB0cmF2ZWwg eW91IGRvLi4uLi4gSSB3YW50IHlvdXIgam9iISBXaGF0IGlzIGl0IHRoYXQgeW91IGRvIGFnYWlu Py4uLi4uYWlycGxhbmUgc2VjdXJpdHkgYWdlbnQgaW5zcGVjdGluZyBmbGlnaHQgYXR0ZW5kYW50 IGRlbWVhbm9ycz8uLi4uLi5sb2wNCg0KDQpLZW5uZXRoIE0uIEhlaWRlLCBCQSwgQ1BPLCBGQUFP UCANCg0KoA0KDQoNCg0KLS0tIE9uIFNhdCwgOC8yLzA4LCBBTXNhZmV0eUNAYW9sLmNvbSA8QU1z YWZldHlDQGFvbC5jb20+IHdyb3RlOg0KDQpGcm9tOiBBTXNhZmV0eUNAYW9sLmNvbSA8QU1zYWZl dHlDQGFvbC5jb20+DQpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlzdDogUGlldHMgaW4gSGF3YWlpDQpU bzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbQ0KRGF0ZTogU2F0dXJkYXksIEF1Z3VzdCAy LCAyMDA4LCA4OjA0IFBNDQoNCg0KDQpKdXN0IGJhY2sgZm9ybSBhIDEwIGRheSBidXNpbmVzcyB0 cmlwIHRoYXQgaW5jbHVkZWQgQnJvZGhlYWQgYW5kIEkgYW0gb3V0IGFnYWluIG9uIFR1ZXNkYXkg Zm9yIEhhd2FpaSBvbiBidXNpbmVzcywgSSBtYXkgYmUgdGhlcmUgZm9yIGFib3V0IGEgd2Vlay4N CqANCkFueSBQaWV0cyBvbiB0aGUgYmlnIGlzbGFuZCBvciBhbnkgb2YgdGhlIGlzbGFuZHMgZm9y IHRoYXQgbWF0dGVyPw0KoA0KSWxsIGJlIHRoZXJlIHNvb24gZW5vdWdoIGFuZCB3b3VsZCBsb3Zl IHRvIHZpc2l0IGEgUGlldCBIYXdhaWlhbiBzdHlsZS4NCqANCkpvaG4NCg0KDQoNCg0KDQpMb29r aW5nIGZvciBhIGNhciB0aGF0J3Mgc3BvcnR5LCBmdW4gYW5kIGZpdHMgaW4geW91ciBidWRnZXQ/ IFJlYWQgcmV2aWV3cyBvbiBBT0wgQXV0b3MuDQoNCg0KDQoNCg0KICAgICAgDQoNCg= ________________________________________________________________________________
Subject: empty oatmeal cardboard containers
Date: Aug 03, 2008
Girrrlz- Legend has it (actually, this has been verified by old-timers) that Bernard Pietenpol used empty Quaker Oatmeal cardboard cartons to make the top surface covers of the leading edges on his wings. Find THAT in your AC 43.13-! Search the archives and you'll also find remarks indicating that he used the tops of 55 gal drums for the material for control horns, empty dope cans for various metal bits, and the like. Welcome to low 'n' slow homebuilding. A new age it ain't, but it sure is fun. I can attest to that with just about an even 1.0 hrs. in yesterday's logbook with 41CC, after Hurricane Dolly's rains really greened up the countryside. Purrrfect Pietenpoling, and made me go back to the hangar and work on my smoke system some more. I hope to be making smoke with it by the time this year's "Wings 'n' Wheels" event rolls around in September on our our field. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Not-A-Tri-Pacer
Date: Aug 03, 2008
Hey, now! Here's a name I recognize, Jim Hamilton: http://www.airventure.org/2008/7sat2/around_field.html One of my very best friends in Oregon is Jim's brother, Jack. A true low-and-slow flier. They have a place up on Graves Creek, a tributary of the Rogue River, and I flew Jack in to their dirt strip in a Super Cub one beautiful and cool morning for one of my most memorable flights in Oregon. They don't make too many of 'em like Jim and Jack Hamilton anymore... Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 03, 2008
Douwe, Since you are welding the cap to the top before welding the top to the tank, it should make it much easier for you to do some of the straightening. You should be able to set the welded assembly on to a hard, solid surface (like an anvil, or a piece of steel plate) to act as the backing bar, when you gently use a hammer to stretch the metal back to the shape you want. Of course, if, as you say, the two components were not correctly positioned when tacking, that will be a big contributing factor to your distortion. Usually, it is possible to tap with a hammer to close small gaps before welding off the joints. Good luck. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196360#196360 ________________________________________________________________________________
Subject: Building, then learning to fly it - how feasible is it?
Date: Aug 04, 2008
Just how feasible is it for an amateur pilot to build a Pietenpol and then learning to fly in it? I know it's doable, but is it actually a realistic, smart endeavor? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196398#196398 ________________________________________________________________________________
Subject: Any Piets in N.C.?
Date: Aug 04, 2008
Does anyone know of any Piets, particularly already flying, in NC? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196399#196399 ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Re: Building, then learning to fly it - how feasible is
it? what is eastern NC?East of Raleigh or east of I-95? North eastern or south eastern NC a little more specific to area. In a message dated 8/4/2008 9:59:08 A.M. Eastern Daylight Time, tomanderson_nc(at)yahoo.com writes: --> Pietenpol-List message posted by: "Tom Anderson" Just how feasible is it for an amateur pilot to build a Pietenpol and then learning to fly in it? I know it's doable, but is it actually a realistic, smart endeavor? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196398#196398 **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Subject: AN machine screw questions
Date: Aug 04, 2008
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Hi All, Back from OSH and Brodhead, great time, good to see all my friends! Planning to use 10-32 screws for attaching tail hinges and ailerons. Would the 60k tensile strength be ok or should I go with the 125k? Thanks! Jack www.textors.com ________________________________________________________________________________
Date: Aug 04, 2008
is it? Tom, Only you can answer that one with confidence. Many guys who have come before us, I suspect, have done it. Their assessment of the personal risk was just that: personal. So it is yours. Al in NH ----- Original Message ----- From: "Tom Anderson" <tomanderson_nc(at)yahoo.com> Sent: Monday, August 04, 2008 9:55 AM Subject: Pietenpol-List: Building, then learning to fly it - how feasible is it? > > > Just how feasible is it for an amateur pilot to build a Pietenpol and then > learning to fly in it? > I know it's doable, but is it actually a realistic, smart endeavor? > > -------- > Location: Eastern N.C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196398#196398 > > > ________________________________________________________________________________
Date: Aug 04, 2008
Tom; I'd say learning to fly in your own Piet would be great, with a couple of caveats. First, have an experienced test pilot fly off the hours and complete all the necessary tweaking so it will fly right. The last thing a student needs is to be learning in an out-of-rig airplane. Second, make sure there is some sort of intercom. While that was not an option back in the days when Piets were first flown, it sure helps when instructing. Last, but not least, it might take quite a bit of courage for an instructor to ride in that front cockpit and not have brakes or carb heat control. He or she can "save" a botched maneuver with power and flight controls but it would sure be nice to have brakes up front and absolutely essential to safety of flight to have proper operation of carb heat control. Ignition switch and fuel cutoff would also be nice to have in both cockpits but a lot of people have learned to fly in airplanes without access to them for both student and instructor. If you can find an instructor willing to teach you in your Piet, go for it. The airplane is certainly going to be a good teacher. And if I misunderstood your question and you are already a pilot, then it's a no-brainer. Definitely doable. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 04, 2008
is it? I suppose it's do-able, but one of the tricks is to find a flight instructor who knows taildraggers and is willing to do it in your plane. The instructor is going to have to learn the characteristics of your plane at the same time as they're teaching you, unless you let them fly it first. If you're really lucky, you might be able to find a test pilot / instructor that could do both your flight tests and your instruction for you. As a non-pilot you absolutely do not want to do your own flight testing; this is one of those times where experience is worth a lot. Also keep in mind you'd probably be receiving your instruction while seated in the back, which means your instructor is going to be crammed into the front hole. So besides the above criteria, they might have to be pretty flexible also. You'd also need a full set of controls and gauges both front and back. Jim -----Original Message----- >From: Tom Anderson <tomanderson_nc(at)yahoo.com> >Sent: Aug 4, 2008 9:55 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Building, then learning to fly it - how feasible is it? > > >Just how feasible is it for an amateur pilot to build a Pietenpol and then learning to fly in it? >I know it's doable, but is it actually a realistic, smart endeavor? > >-------- >Location: Eastern N.C. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=196398#196398 > > ________________________________________________________________________________
Date: Aug 04, 2008
is it? >Just how feasible is it for an amateur pilot to build a Pietenpol and then learning to fly in it? >I know it's doable, but is it actually a realistic, smart endeavor? Tom Speaking from my own personal experience, it's certainly doable to build your own Pietenpol, even if you'r not already a pilot and have no experience building airplanes. You just need to be willing to learn as you go and be willing to junk parts that are not "up-to-snuff" (whatever that means.) Learning to fly in that homebuilt Pietenpol - that's going to be a LOT more difficult. First you have to find a licensed instructor with a tailwheel rating who is willing to risk his own neck in a homebuilt that he didn't build. Then, you have to find someone who will take your creation and herd it through it's 40-hour testing phase to the final FAA approval stage before you would be allowed to have a second person (you) in the airplane. After that, the rest would be a piece of cake. It's not like the old days when Bernard P. designed his own plane and then taught himself to fly in it. BUT, don't let that stop you! Learn to fly in a Spam can - one with a tailwheel if you can manage it - and then you will be ready on that glorious day when your Piet is ready to "...slip the surly bonds of earth..." I'm beginning to see that perticular light at the end of the tunnel but it's still mighty dim. Tom Stinemetze McPherson, KS ________________________________________________________________________________
it?
Date: Aug 04, 2008
Oscar, Thanks for the response and no, you didn't misunderstand at all. I've got several ( -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196424#196424 ________________________________________________________________________________
Date: Aug 04, 2008
Jim is right... if your instructor has no experience in a Piet, then he or she had better learn the airplane first. Duh. My instructor had flown 41CC quite a bit before he ever started my checkout, plus he is an old taildragger pilot from way back, so he didn't bat an eye about flying it from the front seat or instructing me in it. Matter of fact, to demonstrate different maneuvers he would set it up and then ask me what the airspeed indicator was showing. Without fail, he could nail it by sound and feel without benefit of the ASI but I would at least provide a vane-type airspeed indicator hung out on the strut so the front-seater has an idea of what the airspeed is. But now we're picking nits. The question was, "how feasible is it?" and I'm of the opinion that it is quite feasible. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 04, 2008
Well, I know of at least one. Mine. I'm based at Cox Field (NC81) in Apex, NC. As for learning in your Pietenpol, the tough thing is going to be getting an instructor who is interested in teaching you in a Pietenpol. I'm not sure how he (or she) could get paid since it is not legal to fly commercially in an experimental aircraft other than for "tranisition training". I don't think primary flight instruction would qualify as transition training. But if you can find a flight instructor who doesn't mind flying from the front cockpit of a Pietenpol, for free, then I suppose you can do it. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tom Anderson Sent: Monday, August 04, 2008 9:59 AM Subject: Pietenpol-List: Any Piets in N.C.? Does anyone know of any Piets, particularly already flying, in NC? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196399#196399 ________________________________________________________________________________
it?
Date: Aug 04, 2008
I agree. It would be too hard to communicate for primary training in a Piet. Try a Champ or a 172. Dick N. ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Monday, August 04, 2008 10:48 AM Subject: Pietenpol-List: Building, then learning to fly it - how feasible is it? Jim is right... if your instructor has no experience in a Piet, then he or she had better learn the airplane first. Duh. My instructor had flown 41CC quite a bit before he ever started my checkout, plus he is an old taildragger pilot from way back, so he didn't bat an eye about flying it from the front seat or instructing me in it. Matter of fact, to demonstrate different maneuvers he would set it up and then ask me what the airspeed indicator was showing. Without fail, he could nail it by sound and feel without benefit of the ASI but I would at least provide a vane-type airspeed indicator hung out on the strut so the front-seater has an idea of what the airspeed is. But now we're picking nits. The question was, "how feasible is it?" and I'm of the opinion that it is quite feasible. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Waldo Pepper Movie
Gentleman, I bought a copy of the Waldo Pepper DVD while at Oshkosh for $32.00 (New). The vendor imports the DVD's from Germany. The DVD cover is in German, but the movie is in English. The movie is titled "Tollkuhne Flieger" with Robert Redford. If anyone is interested go to www.warshows.com or call at 1-973-328-8488. Take care, David ________________________________________________________________________________
Subject: Re: Any Piets in N.C.?
Date: Aug 04, 2008
Thanks for the response, Jack. BTW, is there any chance I could come by sometime and take a look at your Piet...possibly even take a ride in it to see if I'd even like it? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196438#196438 ________________________________________________________________________________
is it?
Date: Aug 04, 2008
When I was a kid in the mid 1930s on a farm in Michigan, a neighbor bought one of the first, if not the first version of an Air Camper plan. First he built the wing and tail, grafted them onto a wooden frame making a glider out of it and had a friend tow him aloft with a Ford truck. Thus he taught himself the rudiments of flying, then he completed the Air Camper in his barn and just took off in it. He flew it a lot for several years. Every summer evening after the chores were done, he was up puttering around overhead. The Piet self- destructed in his barn where it was stored during WWII because he was grounded by the government. After the war he bought a Funk and continued to fly until he was in his eighties., He never bothered to get a pilots license. His Piet wasn't much different from the modern ones, but he sure had the desire to learn to fly. On Aug 4, 2008, at 7:22 AM, ALAN LYSCARS wrote: > > > Tom, > > Only you can answer that one with confidence. Many guys who have > come before us, I suspect, have done it. Their assessment of the > personal risk was just that: personal. > > So it is yours. > > Al in NH > ----- Original Message ----- From: "Tom Anderson" > > To: > Sent: Monday, August 04, 2008 9:55 AM > Subject: Pietenpol-List: Building, then learning to fly it - how > feasible is it? > > >> >> >> Just how feasible is it for an amateur pilot to build a Pietenpol >> and then learning to fly in it? >> I know it's doable, but is it actually a realistic, smart endeavor? >> >> -------- >> Location: Eastern N.C. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=196398#196398 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: paying for flight instruction
Date: Aug 04, 2008
I had no trouble with my instructor. I was keeping 41CC in his hangar for the duration, so I paid him hangar rent that was appropriate to the services rendered and that was that. And since he and I are both rated in category and class, and I learned in conventional gear years ago when I first started flying (no taildragger endorsement required), his checking me out in the Piet was nothing more than transition training. I can see now that it could be a bigger issue than just finding an instructor who is willing to instruct you in your own experimental aircraft. However, I would bet that some suitable arrangement could be worked out without violating any FARs. The intent is that experimental aircraft be constructed and operated for recreational and educational purposes, not commercial ones, so it would have to be in keeping with the spirit and intent of the $@%&* law. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 04, 2008
Sure. Where are you located? I don't give rides out of Cox - runway is too short to clear the trees with a passenger, but I can meet you in Sanford (TTA, 6,000' runway). Right now the Piet is down for maintenance after 34 hours of flying to and from Brodhead. I need to do an oil change as well as repair the cooling shrouds on the engine. Both shrouds developed cracks in the attach brackets. I've ordered some steel to replace the aluminum brackets and hope to have the repairs made by next weekend. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tom Anderson Sent: Monday, August 04, 2008 12:37 PM Subject: Pietenpol-List: Re: Any Piets in N.C.? Thanks for the response, Jack. BTW, is there any chance I could come by sometime and take a look at your Piet...possibly even take a ride in it to see if I'd even like it? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196438#196438 ________________________________________________________________________________
Date: Aug 04, 2008
Jack, I live in Wilson and work in Raleigh. -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196455#196455 ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Taking instruction in your homebuilt
Jack et al., I certainly could be wrong about this, but I'm pretty sure that an instructor can be paid for instructing in a homebuilt airplane. Rental cannot be charged on the plane (that is, the owner of the plane cannot be paid for its use). There are several other considerations (noted in the sources below), but I don't think that the FARs disallow an instructor being paid. I am planning to take instruction in my Piet. I had an instructor lined up who was quite excited about providing instruction and had done so in other amateur-built experimental planes, but our schedules never jibed (his "day job" expanded right when we were getting going). BTW, The EAA has a list of sport pilot instructors, and one of the column headers is: Willing to Instruct in Experimental Aircraft? It's divvied up by state, and the URL for N.C. is: http://www.sportpilot.org/instructors/north%20carolina_1.html This link requires logging in as an EAA member. ---------------------------------------- Sources that suggest an instructor can be paid for instructing in a homebuilt (AOPA, EAA, etc.): From Ron Wanttaja's website, a reprint of the old rec.aviation.homebuilt FAQ Q334: Can I take lessons/get my license in my homebuilt? A. Like so many things in aviation, the answer is, "Yes, but..." There is no regulations to prevent your taking lessons or your flight test in a homebuilt aircraft. Your ability to do so will depend on finding an instructor willing to instruct in a homebuilt, as well as an Examiner willing to administer the test in the aircraft. Neither is automatic, and you'll have little recourse if they refuse. If you would like to take lessons in your homebuilt, ask around at your local EAA chapter. Many EAA members are instructors, and would probably be more willing. My local chapters, for instance, include several CFIs who administer BFRs in members' homebuilts. http://www.wanttaja.com/avlinks/FAQ.HTM ---------------------------------- From AOPA Online: Homebuilts can't be used in a commercial operation. (An instructor may be paid for services provided in an experimental airplane, but charges can't be levied for use of the airplane.) You or your student cannot rent a homebuilt for the purpose of training. http://www.aopa.org/asf/publications/inst_reports2.cfm?article=198 ---------------------------------- A fuller discussion is provided at EAA's website, but doesn't directly bear on this question (I provide it here because it lists useful considerations): * Flight Instruction in an Experimental/Amateur-Built Aircraft * Am I allowed to receive flight Instruction in an Experimental /Amateur -Built aircraft? The short answer is yes, you can receive flight training in an amateur-built aircraft. However, there are some issues that may limit this opportunity. First, the aircraft in question must have already completed it's flight test phase (called "phase one operations"). Phase one is usually either the first 25 or 40 hours of operation, depending on what engine/prop combination is installed. During phase one operations, only the pilot can be in the aircraft, so no dual flight instruction could take place in the aircraft during this time.Assuming that the aircraft has completed phase one operations and has been moved into phase two (normal) operations, flight training in the aircraft would be allowed. The next issue is finding a CFI (certified flight instructor) who is willing to provide primary training in the homebuilt aircraft in question. Not all CFI's are willing to give instruction in homebuilt aircraft. Another issue is whether the aircraft in question meets all the requirements of training for the license or rating sought. For private pilot certificates and above, there are requirements for night and instrument training, as well as radio navigation, so the aircraft used for training must be equipped for these operations. If the amateur-built aircraft does not have the appropriate equipment, a second aircraft will have to be used for those portions of the training. Splitting your training between two aircraft will certainly add additional hours to the flight training but will provide the added benefit of experiencing more than one aircraft's flight characteristics. The next thing to consider is the practical test (checkride). This is governed by 14 CFR 61.45, which states that the applicant must present a standard, limited, or primary category aircraft for the practical test. However, this regulation also allows the Designated Pilot Examiner (DPE) the discretion to administer the test in an Experimental-Amateur Built aircraft. Some DPE's are not willing to give a practical test in an amateur-built aircraft, so you may have to find an aircraft acceptable to the DPE in which to take your checkride. Also, the aircraft used for the checkride must be equipped to perform all the tasks listed in the Practical Test Standards for the license or rating sought. Depending on the level of equipment in your homebuilt, you may end up taking your checkride in the aircraft in which you did your night and instrument training As a practical matter, you will only be able to do your primary training in a homebuilt that you own. This is due to the fact that the operating limitations (which are issued as a part of the aircraft's airworthiness certificate) for a homebuilt prohibit the carriage of persons or property for compensation or hire. This means that the owner of a homebuilt aircraft cannot rent the aircraft to you, as that would constitute carrying a person for compensation or hire. Finally, you need to make sure you can properly insure the aircraft for primary training (including solo). Depending on the aircraft, insurance may not be available for an owner that is not yet a certificated pilot. Even if you can acquire aircraft insurance as a student pilot, this may or may not be cost-effective. You'll have to balance the cost of this insurance against the cost of renting an available training aircraft from your local FBO (Fixed Base Operator). Note that even if you rent an aircraft from an FBO it is strongly recommend that you carry non-owner insurance (often called "renter's insurance") to protect you in the event of an accident. The insurance premium for your homebuilt will probably drop considerably once you get your pilot certificate and a few hours of experience in your logbook. http://members.eaa.org/home/homebuilders/faq/Flight%20Instruction%20in%20an%20Experimental_Amateur-Built%20Aircraft.html? > > >... >As for learning in your Pietenpol, the tough thing is going to be >getting an instructor who is interested in teaching you in a Pietenpol. >I'm not sure how he (or she) could get paid since it is not legal to fly >commercially in an experimental aircraft other than for "tranisition >training". I don't think primary flight instruction would qualify as >transition training. But if you can find a flight instructor who >doesn't mind flying from the front cockpit of a Pietenpol, for free, >then I suppose you can do it. > >Jack Phillips >NX899JP > -- _____________________________________________________________ Jeffrey H. Boatright, PhD Associate Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Re: project
Did that include oil? Rick On Fri, Jul 25, 2008 at 4:43 PM, skellytown flyer wrote: > > i have been off the list as far as posting after changing e-mail servers > but maybe this will work.I am trying to get moving again on the project I > bought from D.J. last year.I just pulled the Corvair engine from the mount > this afternoon and decided to weigh it before moving it out of the way while > I work on the fuselage.if I was seeing the scales right-( they were pretty > well covered up with the base I set it on) but including the 15# for the > wood base I made to sit it on it looked like 240# so that would be about > 225# without it.and that didn't include the carb and tubing left hanging on > the firewall,the starter or the exhaust stacks i removed,prop and bolts etc. > does this sound reasonable? I sure would like to get this plane flying in > the next year.but I am not real fond of the EIS unit in the panel.I know > they are not cheap but seems to me that a couple of steam gages would look a > lot more natural in a Piet.-well a GN-1 anyway.Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=194962#194962 > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Ribs and sanding
Afternoon Group, A quick question. How well should I be sanding the joints on the opposite side before gluing? take care, Ben in MN ________________________________________________________________________________
Date: Aug 04, 2008
From: "Glenn Thomas" <glennthomas(at)flyingwood.com>
Subject: Re: Ribs and sanding
I scored with #60 grit. Just a couple of passes with the sandpaper at 2 angles and only enough to give the glue something to grab. I vacuumed away all the dust with a shop vac. All glued surfaces including gussets and capstrip got with the 60 grit. On 8/4/08, Ben Ramler wrote: > > > > > Afternoon Group, > A quick question. How well should I be sanding the joints on the > opposite side before gluing? > take care, > Ben in MN > > -- Glenn Thomas Storrs, CT http://www.flyingwood.com ________________________________________________________________________________
Date: Aug 04, 2008
Ben, AC 43.13, Section 1, Paragraph 5, quote, "...Sandpaper must never be used to smooth softwood surfaces that are to be glued. Sawed surfaces must approach well-planed surfaces in uniformity, smoothness, and freedom from crushed fibers..." Fortunately, though, almost all the strength in our ribs comes from the gussets. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (11 ribs down) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Monday, August 04, 2008 2:49 PM Subject: Pietenpol-List: Ribs and sanding Afternoon Group, A quick question. How well should I be sanding the joints on the opposite side before gluing? take care, Ben in MN ________________________________________________________________________________
Date: Aug 04, 2008
hmm. I wonder what sandpaper I'm using. Maybe I sanded to much away then be caus I sanded until there was not dried up glue left from the other side is this over kill?=0A=0A=0A=0A----- Original Message ----=0AFrom: Glenn Thoma s =0ATo: pietenpol-list(at)matronics.com=0ASent: M onday, August 4, 2008 6:06:56 PM=0ASubject: Re: Pietenpol-List: Ribs and sa nding=0A=0A=0AI scored with #60 grit.- Just a couple of passes with the s andpaper at 2 angles and only enough to give the glue something to grab.- I vacuumed away all the dust with a shop vac.- All glued surfaces includ ing gussets and capstrip got with the- 60 grit.=0A=0A-=0AOn 8/4/08, Ben Ramler wrote: =0A--> Pietenpol-List message pos =0A=0A=0A ________________________________________________________________________________
Date: Aug 04, 2008
so why did you tell me that Gary? so you trying to tell not sand ok I can do that. Ben in MN ----- Original Message ---- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Monday, August 4, 2008 6:15:55 PM Subject: RE: Pietenpol-List: Ribs and sanding Ben, AC 43.13, Section 1, Paragraph 5, quote, "...Sandpaper must never be used to smooth softwood surfaces that are to be glued. Sawed surfaces must approach well-planed surfaces in uniformity, smoothness, and freedom from crushed fibers..." Fortunately, though, almost all the strength in our ribs comes from the gussets. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (11 ribs down) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Monday, August 04, 2008 2:49 PM Subject: Pietenpol-List: Ribs and sanding Afternoon Group, A quick question. How well should I be sanding the joints on the opposite side before gluing? take care, Ben in MN ________________________________________________________________________________
Date: Aug 04, 2008
yes the weight did include oil in the case.,but not the carb or the exhaust stacks except the cast iron headers. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196521#196521 ________________________________________________________________________________
Date: Aug 04, 2008
Not sure if I should step into this one, since it looks like there is some confusion, but here goes anyway. I'm going to assume that Ben's question has to do with sanding the bonding surface of the plywood gussets for his wing ribs. If that's right, then Glenn's reply is what you're looking for. Just scuff up the surface, since plywood can have a "glazed" surface as it is received. This glazed surface just needs to be scratched a bit to permit the epoxy to penetrate the plywood and make a decent bond. You shouldn't really be removing material from the plywood, just making it more bond-able. Gary's comments refer more to glue joints for end-grain spruce (or whatever softwood you are building with). When spruce is sawn, the end grain has open pores which will absorb the adhesive. If the end is sanded (and especially if the wood gets burned in sanding), the pores tend to get clogged, which impedes the absorption of the adhesive. If the epoxy doesn't "bite" into the wood, the joint will not achieve the strength that is needed. That is a bad thing. So, Ben, if you are asking about sanding the "gluing side" of the plywood gussets, then, yes you should sand them, like Glenn said. If that's not what you're asking, then maybe you need to re-state your question more clearly. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196540#196540 ________________________________________________________________________________
Date: Aug 04, 2008
Sorry Everyone, Yep that is what I was asking. just dealing with sanding then gluing. I am building with douglas fir so spruce is of no concern to me. Another question I am unsure of what grit of sandpaper I am using, and my dad is unsure to. If I can describe it by its color the sandpaper I am using is a grey color. take care, Ben ----- Original Message ---- From: Bill Church <billspiet(at)sympatico.ca> Sent: Monday, August 4, 2008 9:30:56 PM Subject: Pietenpol-List: Re: Ribs and sanding Not sure if I should step into this one, since it looks like there is some confusion, but here goes anyway. I'm going to assume that Ben's question has to do with sanding the bonding surface of the plywood gussets for his wing ribs. If that's right, then Glenn's reply is what you're looking for. Just scuff up the surface, since plywood can have a "glazed" surface as it is received. This glazed surface just needs to be scratched a bit to permit the epoxy to penetrate the plywood and make a decent bond. You shouldn't really be removing material from the plywood, just making it more bond-able. Gary's comments refer more to glue joints for end-grain spruce (or whatever softwood you are building with). When spruce is sawn, the end grain has open pores which will absorb the adhesive. If the end is sanded (and especially if the wood gets burned in sanding), the pores tend to get clogged, which impedes the absorption of the adhesive. If the epoxy doesn't "bite" into the wood, the joint will not achieve the strength that is needed. That is a bad thing. So, Ben, if you are asking about sanding the "gluing side" of the plywood gussets, then, yes you should sand them, like Glenn said. If that's not what you're asking, then maybe you need to re-state your question more clearly. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196540#196540 ________________________________________________________________________________
Date: Aug 05, 2008
Subject: How hard is it to get into the front seat
I think I remember seeing a video showing that it was pretty difficult. The reason I ask is because my misses is not the most flexible person and she has a bad back. I really wish to build a Pietenpol with a Model A engine, but I also want to take her flying and show her why there is nothing else like it. Charley ________________________________________________________________________________
Subject: Re: How hard is it to get into the front seat
Date: Aug 05, 2008
Charley, Keri-Ann Price sells plans for a modification to add a door to the passenger seat. Her website is: http://www.geocities.com/keriannprice/Pietenpol_Plan_Packages.html Greg ----- Original Message ----- From: "charles loomis" <rameses32(at)yahoo.com> Sent: Tuesday, August 05, 2008 3:48 AM Subject: Pietenpol-List: How hard is it to get into the front seat > > I think I remember seeing a video showing that it was pretty difficult. > The reason I ask is because my misses is not the most flexible person and > she has a bad back. I really wish to build a Pietenpol with a Model A > engine, but I also want to take her flying and show her why there is > nothing else like it. > Charley > > > ________________________________________________________________________________
Subject: Re: Homemade Turnbuckles
Date: Aug 05, 2008
Bill, Dale Johnson built a pull tester for testing the cables on NX18235. We also used it to test some homemade turnbuckle barrels. Dale would be happy to do a test on one or more of your turnbuckles. Let me know if you are interested. Greg Cardinal ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Thursday, July 31, 2008 12:34 PM Subject: RE: Pietenpol-List: Homemade Turnbuckles Ken, I kind of got sidetracked away from the homemade turnbuckles for a while, and I've actually been building my tailfeathers. So, the short answer to your question is "No, I haven't". Having said that, here's the long answer. I didn't do any strength calculations, but I have a strong feeling that the turnbuckles as I made them will be sufficient in strength, but I have yet to do some real-world pull testing to see what they can safely handle. Before I do the pull test I wanted to refine the design a bit to make them a bit more user friendly. That way I'll be testing the proper part, not just something similar. I still plan to do it, just not right now. If you need an answer right now, I think just about anyone could make up a set of these in a short period of time, and then do their own testing using a simple apparatus (lever and pivot). When I do get around to revising the design and doing the pull-testing, I'll share the results with the list. If you want more details about how I made the prototype, let me know. Bill C. ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide, BA, CPO, FAAOP Sent: Thursday, July 31, 2008 12:37 PM To: pietenpol-list(at)matronics.com Subject: RE: Pietenpol-List: Homemade Turnbuckles Bill, Have you nailed down the materials (thickness, width, length, rod size, etc) to manufacture the turnbuckles for the tail section? After seeing the price for the turnbuckles on Aircraft Spruce and others, I think making my own would be a great idea... any assistance? Kenneth M. Heide, BA, CPO, FAAOP ________________________________________________________________________________
Date: Aug 05, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Look on the back. Most quality sandpaper will have the grit size printed on the back. It will be a number ranging from 60 (very coarse) to 600 (extremely fine). Do you have the Tony Bingelis books? If not, you should buy them. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Monday, August 04, 2008 11:25 PM Subject: Re: Pietenpol-List: Re: Ribs and sanding Sorry Everyone, Yep that is what I was asking. just dealing with sanding then gluing. I am building with douglas fir so spruce is of no concern to me. Another question I am unsure of what grit of sandpaper I am using, and my dad is unsure to. If I can describe it by its color the sandpaper I am using is a grey color. take care, Ben ----- Original Message ---- From: Bill Church <billspiet(at)sympatico.ca> Sent: Monday, August 4, 2008 9:30:56 PM Subject: Pietenpol-List: Re: Ribs and sanding Not sure if I should step into this one, since it looks like there is some confusion, but here goes anyway. I'm going to assume that Ben's question has to do with sanding the bonding surface of the plywood gussets for his wing ribs. If that's right, then Glenn's reply is what you're looking for. Just scuff up the surface, since plywood can have a "glazed" surface as it is received. This glazed surface just needs to be scratched a bit to permit the epoxy to penetrate the plywood and make a decent bond. You shouldn't really be removing material from the plywood, just making it more bond-able. Gary's comments refer more to glue joints for end-grain spruce (or whatever softwood you are building with). When spruce is sawn, the end grain has open pores which will absorb the adhesive. If the end is sanded (and especially if the wood gets burned in sanding), the pores tend to get clogged, which impedes the absorption of the adhesive. If the epoxy doesn't "bite" into the wood, the joint will not achieve the strength that is needed. That is a bad thing. So, Ben, if you are asking about sanding the "gluing side" of the plywood gussets, then, yes you should sand them, like Glenn said. If that's not what you're asking, then maybe you need to re-state your question more clearly. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196540#196540 ________________________________________________________________________________
Date: Aug 05, 2008
Charley For what its worth I was considering the door also. I was just really concerned reluctant to cut the upper longeron weakening the structure for an occasional rider. That thought was reaffirmed by my tech councelor. You may want to reconsider that also John ------Original Message------ From: gcardinal Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Sent: Aug 5, 2008 7:10 AM Subject: Re: Pietenpol-List: How hard is it to get into the front seat Charley, Keri-Ann Price sells plans for a modification to add a door to the passenger seat. Her website is: http://www.geocities.com/keriannprice/Pietenpol_Plan_Packages.html Greg ----- Original Message ----- From: "charles loomis" <rameses32(at)yahoo.com> Sent: Tuesday, August 05, 2008 3:48 AM Subject: Pietenpol-List: How hard is it to get into the front seat > > I think I remember seeing a video showing that it was pretty difficult. > The reason I ask is because my misses is not the most flexible person and > she has a bad back. I really wish to build a Pietenpol with a Model A > engine, but I also want to take her flying and show her why there is > nothing else like it. > Charley > > > Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Aug 05, 2008
Charley, I've found that if a person really wants to get in they will. I added a step on the rear gear leg that really helps. Good friend of mine of 35 years, was the last of the people not to get polio shots. His legs are shriveled and only 50% there. But he wanted to get in and he did. Had a great time. But then he couldn't get out! Me and a friend, grabbed him and lifted him out. A fun time was had by all. Big thing about the Piet that no one had discussed, is the tight room for your feet on the rudder with a big butt sitting there. Once had to make up a feeble excuse about the winds aloft, cause I couldn't take a big-butted lady, who would have loved a ride walt evans NX140DL ----- Original Message ----- From: "charles loomis" <rameses32(at)yahoo.com> Sent: Tuesday, August 05, 2008 4:48 AM Subject: Pietenpol-List: How hard is it to get into the front seat > > I think I remember seeing a video showing that it was pretty difficult. > The reason I ask is because my misses is not the most flexible person and > she has a bad back. I really wish to build a Pietenpol with a Model A > engine, but I also want to take her flying and show her why there is > nothing else like it. > Charley > > > ________________________________________________________________________________
Date: Aug 05, 2008
Has anyone talked with Frank Pavliga ? His Piet used 3/32 cable to cross angle support the cabanes, and had to keep tightening because of stretch, and replaced them after a few hours of flight. Do other applications of 3/32 cable experience the same problem ? Don't chance it. Allen Rudolf's piet still flys with 1/8 Th" cables and the plane weights under 640 Lbs. And will fly two people on a 90 Deg. day with a standard Ford A just turning 1950 RPM. Pieti Lowell[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196610#196610 ________________________________________________________________________________
Date: Aug 05, 2008
In theory, we should be able to build stronger turnbuckles than standard aircraft ones. The A/C turnbuckles are made of brass. Their male threads are rolled, making them stronger than the cut threads we would make. However, I believe the female (tapped) threads are cut. That would likely be the wekaer link, and more likely to strip in tension. Moreover, brass is has less tensile and shering strength than either steel or stainless steel. Building our own turnbuckles out of stainless steel (female) and a cap bolt (male) might be the best of all worlds. The high quality steel cap bolt (socket head) has rolled threads and is case hardened, as well. The mating female part (homemade) has cut threads, but the S.S. material is much stronger than the brass. Moreover, the builder might experiment with slightly undersize tap drills to achieve nearly interference fit (more thread-to-thread surface). This last step might not be practical, and a real tap-breaker, but perhaps a worthy experiment. Also, as in the demontrated design, the homebuilder can make the straps that carry the loads on the ends of the entire turnbuckle assembly as thick and wide as needed. Of course, as stated first in this note... this is only THEORY, and that is why testing is so important. If it works, the proper homemade turnbuckle would be not only cheaper, but better than store-bought aircraft quality. It would also be more in keeping with the barndoor hinge, baling wire, and oatmeal carton LE heritage of the Piet itself. Note, though, that this is definitely NOT an appeal for Home Depot turnbuckles. Tim in central Texas -----Original Message----- >From: gcardinal <gcardinal(at)comcast.net> >Sent: Aug 5, 2008 6:22 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Homemade Turnbuckles > >Bill, > >Dale Johnson built a pull tester for testing the cables on NX18235. We also used it to test some homemade turnbuckle barrels. >Dale would be happy to do a test on one or more of your turnbuckles. >Let me know if you are interested. > >Greg Cardinal > ----- Original Message ----- > From: Bill Church > To: pietenpol-list(at)matronics.com > Sent: Thursday, July 31, 2008 12:34 PM > Subject: RE: Pietenpol-List: Homemade Turnbuckles > > > Ken, > > I kind of got sidetracked away from the homemade turnbuckles for a while, and I've actually been building my tailfeathers. So, the short answer to your question is "No, I haven't". > Having said that, here's the long answer. > I didn't do any strength calculations, but I have a strong feeling that the turnbuckles as I made them will be sufficient in strength, but I have yet to do some real-world pull testing to see what they can safely handle. Before I do the pull test I wanted to refine the design a bit to make them a bit more user friendly. That way I'll be testing the proper part, not just something similar. I still plan to do it, just not right now. If you need an answer right now, I think just about anyone could make up a set of these in a short period of time, and then do their own testing using a simple apparatus (lever and pivot). When I do get around to revising the design and doing the pull-testing, I'll share the results with the list. > If you want more details about how I made the prototype, let me know. > > Bill C. > > >------------------------------------------------------------------------------ > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide, BA, CPO, FAAOP > Sent: Thursday, July 31, 2008 12:37 PM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Homemade Turnbuckles > > > Bill, > > Have you nailed down the materials (thickness, width, length, rod size, etc) to manufacture the turnbuckles for the tail section? After seeing the price for the turnbuckles on Aircraft Spruce and others, I think making my own would be a great idea... any assistance? > > > Kenneth M. Heide, BA, CPO, FAAOP > > > ________________________________________________________________________________
Subject: Homemade Turnbuckles
Date: Aug 05, 2008
Maybe this would be an area for the CozyGirrrls to make some parts. There are several dozen turnbuckles required to build a Pietenpol, and they could offer a turnbuckle kit. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim Willis Sent: Tuesday, August 05, 2008 10:22 AM Subject: Re: Pietenpol-List: Homemade Turnbuckles In theory, we should be able to build stronger turnbuckles than standard aircraft ones. The A/C turnbuckles are made of brass. Their male threads are rolled, making them stronger than the cut threads we would make. However, I believe the female (tapped) threads are cut. That would likely be the wekaer link, and more likely to strip in tension. Moreover, brass is has less tensile and shering strength than either steel or stainless steel. Building our own turnbuckles out of stainless steel (female) and a cap bolt (male) might be the best of all worlds. The high quality steel cap bolt (socket head) has rolled threads and is case hardened, as well. The mating female part (homemade) has cut threads, but the S.S. material is much stronger than the brass. Moreover, the builder might experiment with slightly undersize tap drills to achieve nearly interference fit (more thread-to-thread surface). This last step might not be practical, and a real tap-breaker, but perhaps a worthy experiment. Also, as in the demontrated design, the homebuilder can make the straps that carry the loads on the ends of the entire turnbuckle assembly as thick and wide as needed. Of course, as stated first in this note... this is only THEORY, and that is why testing is so important. If it works, the proper homemade turnbuckle would be not only cheaper, but better than store-bought aircraft quality. It would also be more in keeping with the barndoor hinge, baling wire, and oatmeal carton LE heritage of the Piet itself. Note, though, that this is definitely NOT an appeal for Home Depot turnbuckles. Tim in central Texas -----Original Message----- >From: gcardinal <gcardinal(at)comcast.net> >Sent: Aug 5, 2008 6:22 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Homemade Turnbuckles > >Bill, > >Dale Johnson built a pull tester for testing the cables on NX18235. We also used it to test some homemade turnbuckle barrels. >Dale would be happy to do a test on one or more of your turnbuckles. >Let me know if you are interested. > >Greg Cardinal > ----- Original Message ----- > From: Bill Church > To: pietenpol-list(at)matronics.com > Sent: Thursday, July 31, 2008 12:34 PM > Subject: RE: Pietenpol-List: Homemade Turnbuckles > > > Ken, > > I kind of got sidetracked away from the homemade turnbuckles for a while, and I've actually been building my tailfeathers. So, the short answer to your question is "No, I haven't". > Having said that, here's the long answer. > I didn't do any strength calculations, but I have a strong feeling that the turnbuckles as I made them will be sufficient in strength, but I have yet to do some real-world pull testing to see what they can safely handle. Before I do the pull test I wanted to refine the design a bit to make them a bit more user friendly. That way I'll be testing the proper part, not just something similar. I still plan to do it, just not right now. If you need an answer right now, I think just about anyone could make up a set of these in a short period of time, and then do their own testing using a simple apparatus (lever and pivot). When I do get around to revising the design and doing the pull-testing, I'll share the results with the list. > If you want more details about how I made the prototype, let me know. > > Bill C. > > >----------------------------------------------------------------------- ------- > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide, BA, CPO, FAAOP > Sent: Thursday, July 31, 2008 12:37 PM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Homemade Turnbuckles > > > Bill, > > Have you nailed down the materials (thickness, width, length, rod size, etc) to manufacture the turnbuckles for the tail section? After seeing the price for the turnbuckles on Aircraft Spruce and others, I think making my own would be a great idea... any assistance? > > > Kenneth M. Heide, BA, CPO, FAAOP > > > ________________________________________________________________________________
Subject: Re: fuel drain locations
Date: Aug 05, 2008
Hi Douwe, I have placed fuel outlets in most locations and finally just use the rear right, because a boarding passenger will hit the left rear with his shoulder, and if you fly with the ball in the center either rear locations will work. The center location, "Allen Rudolf's " will get tagged very often by a passenger boarding. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196620#196620 ________________________________________________________________________________
Subject: Re: best movie scenes
Date: Aug 05, 2008
If you want to see some neat Piet flying, take a gander at " Red Betsy ", Ted Davis did the flights in this movie. Type the title in the search web. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196625#196625 ________________________________________________________________________________
Subject: Re: Frued table saw blades
Date: Aug 05, 2008
You are quite right, I use a 80 tooth carbide to saw my spars from a 6"X 2-1/2" X 14 Ft. Lg. Sitkus, when I flipped the beam over and reversed ends the surface never needed a plane job. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196627#196627 ________________________________________________________________________________
Date: Aug 05, 2008
Tim, Now you've got me re-energized and ready to get back to work on the turnbuckle prototyping, with a new twist. I'm going to try making one from oatmeal cartons and stove bolts! Or not. Actually there's no need to make them stronger than A/C turnbuckles, just equal. But the use of higher strength materials (st.st. vs brass) could allow for some weight savings, based on a strength to weight basis. Stainless steel will provide necessary corrosion resistance, like brass, since most of the turnbuckles are exposed to the elements. Using smaller tap drills will definitely become a source of extreme frustration for anyone working with stainless steel, and the cost of broken taps will very quickly exceed the cost of buying A/C turnbuckles. One feature that I have not yet figured out is a method to safety wire such a homemade turnbuckle. I don't actually anticipate doing any further development on my prototypes until sometime later in the fall, when it gets too cold out in the garage for epoxy to cure. When I have some results, I'll share them with the list. But that doesn't mean someone else can't go ahead with their own ideas / prototypes / testing. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim Willis Sent: Tuesday, August 05, 2008 10:22 AM Subject: Re: Pietenpol-List: Homemade Turnbuckles --> In theory, we should be able to build stronger turnbuckles than standard aircraft ones. The A/C turnbuckles are made of brass. Their male threads are rolled, making them stronger than the cut threads we would make. However, I believe the female (tapped) threads are cut. That would likely be the wekaer link, and more likely to strip in tension. Moreover, brass is has less tensile and shering strength than either steel or stainless steel. Building our own turnbuckles out of stainless steel (female) and a cap bolt (male) might be the best of all worlds. The high quality steel cap bolt (socket head) has rolled threads and is case hardened, as well. The mating female part (homemade) has cut threads, but the S.S. material is much stronger than the brass. Moreover, the builder might experiment with slightly undersize tap drills to achieve nearly interference fit (more thread-to-thread surface). This last step might not be practical, and a real tap-breaker, but perhaps a worthy experiment. Also, as in the demontrated design, the homebuilder can make the straps that carry the loads on the ends of the entire turnbuckle assembly as thick and wide as needed. Of course, as stated first in this note... this is only THEORY, and that is why testing is so important. If it works, the proper homemade turnbuckle would be not only cheaper, but better than store-bought aircraft quality. It would also be more in keeping with the barndoor hinge, baling wire, and oatmeal carton LE heritage of the Piet itself. Note, though, that this is definitely NOT an appeal for Home Depot turnbuckles. Tim in central Texas ________________________________________________________________________________
Subject: Re: Roll Call
Date: Aug 05, 2008
Chet, Have you: Set timing at 28 Deg ? Cleaned the casting out from the water inlet with a stiff wire ? Use a Ford T water pump in place of the A pump ? Check head gasket and H2O openings.in castings ? Radiator clean and large enough ? Auto fuel ? I run a Ford B supped- up to 90 HP and when it ran hot,In the water pump I found one impeller of two broke off, welded it on, solved problem, I use a Funk pump, externally mounted, like the "T" pump, which I have used in the past with success. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196633#196633 ________________________________________________________________________________
Date: Aug 05, 2008
Subject: ribs and ailerons
Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: ribs and ailerons
Date: Aug 05, 2008
Ben, Check the plans, the ailerons are built integral with the wing and cut out after you have completed building & trammeling the wing. I'm not there yet, but maybe someone else on the list can expain the process. Kip Gardner On Aug 5, 2008, at 12:20 PM, Ben Ramler wrote: > > > Afternoon Group, > Here's a question... Once all 31 ribs are made how many of the > ribs need to be set aside for the ailerons? > 73, > Ben in MN > > ________________________________________________________________________________
Date: Aug 05, 2008
-----Original Message----- >From: Tim Willis <timothywillis(at)earthlink.net> >Sent: Aug 5, 2008 9:21 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Homemade Turnbuckles > > >In theory, we should be able to build stronger turnbuckles than standard aircraft ones. The A/C turnbuckles are made of brass. Their male threads are rolled, making them stronger than the cut threads we would make. However, I believe the female (tapped) threads are cut. That would likely be the wekaer link, and more likely to strip in tension. Moreover, brass is has less tensile and shering strength than either steel or stainless steel. Tim, I also thought this was the case regarding the SS turnbuckles, but check out the ones that McMaster-Carr sells: http://www.mcmaster.com/ p/n 3082T21 These are SS turnbuckles comparable to the AN130-16S that AS&S sells, but they are longer. For some reason the SS turnbuckles at McMaster are rated at 400lbs whereas the AN130-16S are rated at 1600lbs. I don't understand how the brass turnbuckles could be 4X as strong as the SS but perhaps some of the mechanical gurus can enlighten us. It may be the type of SS that is used, or perhaps the eyelet is not welded. That said, I would think 400lbs would be plenty strong for a low & slow Aircamper. BTW, the AN130-16S sells for about $27 and the McMaster SS one is just over $17. Regards, John F. Richmond, TX (Eduordo was a bust!) GN-1 Aircamper Corvair 164cid ________________________________________ ________________________________________________________________________________
Date: Aug 05, 2008
Subject: Model A mag timing
Lowell, I have my mags set to 30 degrees, per what Ken Perkins recommends. What do you think? Dan Helsper Poplar Grove, IL. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Date: Aug 05, 2008
Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Date: Aug 05, 2008
William Wynne told me the ready to fly weight of the Corvair including wood prop and around 6 lbs for a mount comes to 240 lbs (with starter). Sounds like yours will come to more than that. Rick On Mon, Aug 4, 2008 at 6:21 PM, skellytown flyer wrote: > > yes the weight did include oil in the case.,but not the carb or the exhaust > stacks except the cast iron headers. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196521#196521 > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 05, 2008
Ben I built the entire wing except for the wing tip bow, diagonals and plywood leading edge covering. then I made up the three airleron spars and slid them into place from the wing end and glued them in with T-88. The wing has to be square when this is done. I used the plumb bob method which is described at the top of page 66 of the " EAA Aircraft building Techniques WOOD" book checking the alighnment continuously during construction. If you don't have one it is available through EAA book store and well worth it but there are other methods of squareing the wing. I did one set of airleron spars with the wing verticle as shown in the book and the other wing horizontal on saw horses, the horizontal one was much easier to work with. All 30 ribs are identicle thanks to the genious of Mr. B. Pietenpol but the airleron spars only pick up the outer six/seven. Once the airleron spars were glued in I used my rib jig to make the inside end rib for the airleron. I used the wing tip bow to mark the airleron spar ends and carefully cut them to match up to the tip bow with a good sharp box saw. I then glued on the wing tip bow, the airleron diagonals. the inner end blocking and even installed my airleron hinges. I then cut the airleron free with my box saw. since it was part of the wing when it was built it fits perfectly. This is the way I did it and it worked perfectly I'm sure there are other valuable opinions from people on the list. Hope this helps. Ed Grentzer >From: Ben Ramler <ben_ramler2002(at)yahoo.com> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: ribs and ailerons >Date: Tue, 5 Aug 2008 09:20:38 -0700 (PDT) > > >Afternoon Group, > Here's a question... Once all 31 ribs are made how many of the ribs >need to be set aside for the ailerons? >73, >Ben in MN > > ________________________________________________________________________________
Date: Aug 05, 2008
walt, How big-butted are you talking about here? Furthermore, is the Piet a truly capable 2-seater at all? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196707#196707 ________________________________________________________________________________
Date: Aug 05, 2008
Tom, There is a saying that you may not have heard since you are fairly new to the list - "This plane was designed when midgets ruled the earth!" Bernard, by all accounts, was about 5'4" and weighed maybe 140 lbs. Now that's just about my size, and my wife is about the same, and our daughter will probably be about equal or less as an adult, so for us, yes, it's a capable 2-seater. Heck, we could even carry 50-60 lbs of baggage if there was space for it! For two 200+ lb. guys, add in a full load of fuel and you're close to gross, if not over, depending on how light or heavy you built your plane. Kip G. On Aug 5, 2008, at 2:48 PM, Tom Anderson wrote: > > > walt, > How big-butted are you talking about here? > Furthermore, is the Piet a truly capable 2-seater at all? > > -------- > Location: Eastern N.C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196707#196707 > > ________________________________________________________________________________
Date: Aug 05, 2008
yes at least page 1 page. ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Tuesday, August 5, 2008 12:03:57 PM Subject: RE: Pietenpol-List: ribs and ailerons Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Date: Aug 05, 2008
not sure where the rest of the plans went to though. I have hard time reading plans though to be honest. ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Tuesday, August 5, 2008 12:03:57 PM Subject: RE: Pietenpol-List: ribs and ailerons Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Date: Aug 05, 2008
Yikes! Ben, what are you doing trying to build a plane without having or reading the plans??? The plans is all there is. There ain't no other way to do it. Maybe it's time to order a new set of plans (or put the project to rest). Or are you just pulling our collective leg? Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 5:08 PM Subject: Re: Pietenpol-List: ribs and ailerons --> not sure where the rest of the plans went to though. I have hard time reading plans though to be honest. ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Tuesday, August 5, 2008 12:03:57 PM Subject: RE: Pietenpol-List: ribs and ailerons --> Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons --> Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Date: Aug 05, 2008
Build light! Somewhere I once saw "Simplicate and add lightness!" Just for some numbers, I have an A-65 Continental and it weighs in at 626lbs. empty. Full fuel is just under 15 gallons. I regularly carry a 230lb. passenger with full fuel and me at nearly 185 lbs. It doesn't exactly claw for altitude at that weight, but basically I know if I can get the passenger into the front hole I can lift them out of a respectable field. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196754#196754 ________________________________________________________________________________
Subject: Just for kicks
Date: Aug 05, 2008
Just thought I'd throw this picture in from a week or so ago, somewhere in Ohio... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196756#196756 Attachments: http://forums.matronics.com//files/flying_circus00541_181.jpg ________________________________________________________________________________
Subject: Re: Model A mag timing
Date: Aug 05, 2008
Should work great, even without an impulse. Max RPM is the results, In the olden days 73 Oct. was max. Then 25 Deg. is what most mfg. recommended. Keep plugs at .015"/.018" or it is hard starting. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196757#196757 ________________________________________________________________________________
Date: Aug 05, 2008
Absolutely a two seater. Had my 190 pounder brother-in law up today. and I weigh 210# But you have to build light. My empty weight was at 595#. With us and gas, still climbs like crazy. Look at this youtube. with Don at 180# http://www.youtube.com/watch?v=CLrIDeDLR48 No white knuckles at all. Build light build light build light walt evans NX140DL ----- Original Message ----- From: "Tom Anderson" <tomanderson_nc(at)yahoo.com> Sent: Tuesday, August 05, 2008 2:48 PM Subject: Pietenpol-List: Re: How hard is it to get into the front seat > > > walt, > How big-butted are you talking about here? > Furthermore, is the Piet a truly capable 2-seater at all? > > -------- > Location: Eastern N.C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196707#196707 > > > ________________________________________________________________________________
Date: Aug 05, 2008
Has anybody done the door mod with a tube-and-fabric fuselage instead of a wooden one? Jim Ash -----Original Message----- >From: gcardinal <gcardinal(at)comcast.net> >Sent: Aug 5, 2008 7:10 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: How hard is it to get into the front seat > > >Charley, > >Keri-Ann Price sells plans for a modification to add a door to the passenger >seat. Her website is: > >http://www.geocities.com/keriannprice/Pietenpol_Plan_Packages.html > >Greg > >----- Original Message ----- >From: "charles loomis" <rameses32(at)yahoo.com> >To: >Sent: Tuesday, August 05, 2008 3:48 AM >Subject: Pietenpol-List: How hard is it to get into the front seat > > >> >> I think I remember seeing a video showing that it was pretty difficult. >> The reason I ask is because my misses is not the most flexible person and >> she has a bad back. I really wish to build a Pietenpol with a Model A >> engine, but I also want to take her flying and show her why there is >> nothing else like it. >> Charley >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 05, 2008
Subject: Re: Just for kicks
I love those colors. :^)) walt evans NX140DL ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> Sent: Tuesday, August 05, 2008 6:05 PM Subject: Pietenpol-List: Just for kicks > > Just thought I'd throw this picture in from a week or so ago, somewhere in > Ohio... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196756#196756 > > > Attachments: > > http://forums.matronics.com//files/flying_circus00541_181.jpg > > > ________________________________________________________________________________
Date: Aug 05, 2008
nope. Dad said the flyer and glider manual is what to use. ----- Original Message ---- From: Bill Church <eng(at)canadianrogers.com> Sent: Tuesday, August 5, 2008 4:39:04 PM Subject: RE: Pietenpol-List: ribs and ailerons Yikes! Ben, what are you doing trying to build a plane without having or reading the plans??? The plans is all there is. There ain't no other way to do it. Maybe it's time to order a new set of plans (or put the project to rest). Or are you just pulling our collective leg? Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 5:08 PM Subject: Re: Pietenpol-List: ribs and ailerons --> not sure where the rest of the plans went to though. I have hard time reading plans though to be honest. ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Tuesday, August 5, 2008 12:03:57 PM Subject: RE: Pietenpol-List: ribs and ailerons --> Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons --> Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Date: Aug 05, 2008
you have 150 to spend??? I don't! ----- Original Message ---- From: Bill Church <eng(at)canadianrogers.com> Sent: Tuesday, August 5, 2008 4:39:04 PM Subject: RE: Pietenpol-List: ribs and ailerons Yikes! Ben, what are you doing trying to build a plane without having or reading the plans??? The plans is all there is. There ain't no other way to do it. Maybe it's time to order a new set of plans (or put the project to rest). Or are you just pulling our collective leg? Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 5:08 PM Subject: Re: Pietenpol-List: ribs and ailerons --> not sure where the rest of the plans went to though. I have hard time reading plans though to be honest. ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Tuesday, August 5, 2008 12:03:57 PM Subject: RE: Pietenpol-List: ribs and ailerons --> Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons --> Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Date: Aug 05, 2008
Ben, Ben, Ben. Yes, it is possible to build an Air Camper from the Flying and Glider Manual drawings. I wouldn't want to, but it's been done. Those drawings are so small I find them pretty hard to read, though. Nonetheless, those are your plans. I assume you "splurged" for the $8 for the EAA reprint of the FGM. Use those plans to deternmine how many ribs are affected by the ailerons. As for $150 being too much to spend, how do you plan to build the rest of the plane if $150 for a set of plans is too much money? How are you going to come up with the cash for a motor? How about a propellor? Wheels? Instruments? The cheapest recent build that I can recall hearing about was around $5,000. Assuming someone gave you all of the materials to build the plane, and you live on a property big enough to have your own runway, what are you going to do when it comes time to fill the tank at $5 a gallon (or more)? The Pietenpol is one of the most economical "real" aircraft you can build. It can be built cheaply, but it still ain't free. Building an airplane from plans drawn in 1934 is a challenge. Building an airplane without using those plans, and not spending any money is called dreaming. Pleasant dreams, Ben. BC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 6:30 PM Subject: Re: Pietenpol-List: ribs and ailerons --> nope. Dad said the flyer and glider manual is what to use. you have 150 to spend??? I don't! ----- Original Message ---- From: Bill Church <eng(at)canadianrogers.com> Sent: Tuesday, August 5, 2008 4:39:04 PM Subject: RE: Pietenpol-List: ribs and ailerons --> Yikes! Ben, what are you doing trying to build a plane without having or reading the plans??? The plans is all there is. There ain't no other way to do it. Maybe it's time to order a new set of plans (or put the project to rest). Or are you just pulling our collective leg? Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 5:08 PM Subject: Re: Pietenpol-List: ribs and ailerons --> not sure where the rest of the plans went to though. I have hard time reading plans though to be honest. ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Tuesday, August 5, 2008 12:03:57 PM Subject: RE: Pietenpol-List: ribs and ailerons --> Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons --> Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Date: Aug 05, 2008
Lowell, I have had the radiator checked, my timing is 28 degrees but I plan to try 30 degrees. My waster inlet looks to be clean, and I'm runing 100LL. My pump looks to be in excellent shape, I just replaced the head gasket. How can you tell a Model T waster pump from a Model A? Does any one know if Don Hicks used a T or A water pump? Chet ----- Original Message ----- From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> Sent: Tuesday, August 05, 2008 10:27 AM Subject: Pietenpol-List: Re: Roll Call > > > Chet, > Have you: > Set timing at 28 Deg ? > Cleaned the casting out from the water inlet with a stiff wire ? > Use a Ford T water pump in place of the A pump ? > Check head gasket and H2O openings.in castings ? > Radiator clean and large enough ? > Auto fuel ? > I run a Ford B supped- up to 90 HP and when it ran hot,In the water pump I > found one impeller of two broke off, welded it on, solved problem, I use a > Funk pump, externally mounted, like the "T" pump, which I have used in the > past with success. > Pieti Lowell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196633#196633 > > > ________________________________________________________________________________
Date: Aug 05, 2008
And the long fuselage version gives you a bit more cockpit length and you can always widen the fuselage as many have done (widened mine two inches). Of course that doesn't necessarily increase your gross weight. Rick On Tue, Aug 5, 2008 at 1:01 PM, Kip and Beth Gardner < kipandbeth(at)earthlink.net> wrote: > kipandbeth(at)earthlink.net> > > Tom, > > There is a saying that you may not have heard since you are fairly new to > the list - "This plane was designed when midgets ruled the earth!" Bernard, > by all accounts, was about 5'4" and weighed maybe 140 lbs. Now that's just > about my size, and my wife is about the same, and our daughter will probably > be about equal or less as an adult, so for us, yes, it's a capable 2-seater. > Heck, we could even carry 50-60 lbs of baggage if there was space for it! > For two 200+ lb. guys, add in a full load of fuel and you're close to gross, > if not over, depending on how light or heavy you built your plane. > > Kip G. > > On Aug 5, 2008, at 2:48 PM, Tom Anderson wrote: > >> tomanderson_nc(at)yahoo.com> >> >> walt, >> How big-butted are you talking about here? >> Furthermore, is the Piet a truly capable 2-seater at all? >> >> -------- >> Location: Eastern N.C. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=196707#196707 >> >> >> >> >> >> >> >> >> >> >> > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 05, 2008
Looks just as beautiful in Ohio as it did at Broadhead. Rick On Tue, Aug 5, 2008 at 4:05 PM, Don Emch wrote: > > Just thought I'd throw this picture in from a week or so ago, somewhere in > Ohio... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196756#196756 > > > Attachments: > > http://forums.matronics.com//files/flying_circus00541_181.jpg > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 05, 2008
And to look at it from the other perspective, my Pietenpol is very close to Don's in most respects (65 Continental, wire wheels), but mine is heavy, weighing 745 lbs empty. I also carry 15 gallons of fuel, and I weigh 200. I can carry passengers as heavy as 205 - as long as I'm flying off a 6,000' runway. Climb rate on a hot day with a 200 lb passenger is somewhere around 100 fpm, +/- 90 fpm. My home field is 2,000' long and I will NOT carry passengers out of it. You midwesterners don't know how good you've got it. When you say a strip is 2,000' long, you fail to mention that that is the RUNWAY length, but that the approaches are long and flat and you can fly a mile before you hit anything. In North Carolina, when we say a runway is 2,000 long, that means after 2,000' you come to the 100' tall trees. You've got to be able to get off the ground and then CLIMB! I've done the calculations, and if I lift off after a 400' roll, that means I've got 1600' to climb 100'. At 50 mph I'll cover that 1600' in 21.8 seconds, and in that 21.8 seconds at 200 fpm I will climb exactly 72 feet. Would I carry passengers out of a short field in the Midwest? I did it at Brodhead and got about that much climb rate. Will I do it at home? No thanks - I'll fly 15 miles and meet them at Sanford, with a 6,000' runway and approaches similar to Wisconsin. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Don Emch Sent: Tuesday, August 05, 2008 5:59 PM Subject: Pietenpol-List: Re: How hard is it to get into the front seat Build light! Somewhere I once saw "Simplicate and add lightness!" Just for some numbers, I have an A-65 Continental and it weighs in at 626lbs. empty. Full fuel is just under 15 gallons. I regularly carry a 230lb. passenger with full fuel and me at nearly 185 lbs. It doesn't exactly claw for altitude at that weight, but basically I know if I can get the passenger into the front hole I can lift them out of a respectable field. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196754#196754 ________________________________________________________________________________
Date: Aug 05, 2008
So would the Model A pull the pietenpol along safely with 320 lbs of humans + fuel? "I say it that way so I don't get in trouble for telling the misses weight." hehe --- On Wed, 8/6/08, Don Emch wrote: > From: Don Emch <EmchAir(at)aol.com> > Subject: Pietenpol-List: Re: How hard is it to get into the front seat > To: pietenpol-list(at)matronics.com > Date: Wednesday, August 6, 2008, 7:59 AM > Emch" > > Build light! > > Somewhere I once saw "Simplicate and add > lightness!" > > Just for some numbers, I have an A-65 Continental and it > weighs in at 626lbs. empty. Full fuel is just under 15 > gallons. I regularly carry a 230lb. passenger with full > fuel and me at nearly 185 lbs. It doesn't exactly claw > for altitude at that weight, but basically I know if I can > get the passenger into the front hole I can lift them out of > a respectable field. > > Don Emch > NX899DE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196754#196754 > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Aug 05, 2008
Hey Jack, Same considerations down here in Georgia. 2000' means up and out and on top of it ALL in 2000'. This and other considerations (heat, humidity, too much BBQ) explains the puckered look of most pilot seats in Piets from the South... ;) Lotta sphincter muscles workin' over time down here on hot days in Piets... Jeff > >And to look at it from the other perspective, my Pietenpol is very close to >Don's in most respects (65 Continental, wire wheels), but mine is heavy, >weighing 745 lbs empty. I also carry 15 gallons of fuel, and I weigh 200. >I can carry passengers as heavy as 205 - as long as I'm flying off a 6,000' >runway. Climb rate on a hot day with a 200 lb passenger is somewhere around >100 fpm, +/- 90 fpm. > >My home field is 2,000' long and I will NOT carry passengers out of it. You >midwesterners don't know how good you've got it. When you say a strip is >2,000' long, you fail to mention that that is the RUNWAY length, but that >the approaches are long and flat and you can fly a mile before you hit >anything. In North Carolina, when we say a runway is 2,000 long, that means >after 2,000' you come to the 100' tall trees. You've got to be able to get >off the ground and then CLIMB! I've done the calculations, and if I lift >off after a 400' roll, that means I've got 1600' to climb 100'. At 50 mph >I'll cover that 1600' in 21.8 seconds, and in that 21.8 seconds at 200 fpm I >will climb exactly 72 feet. Would I carry passengers out of a short field >in the Midwest? I did it at Brodhead and got about that much climb rate. >Will I do it at home? No thanks - I'll fly 15 miles and meet them at >Sanford, with a 6,000' runway and approaches similar to Wisconsin. > >Jack Phillips >NX899JP > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Don Emch >Sent: Tuesday, August 05, 2008 5:59 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: How hard is it to get into the front seat > > >Build light! > >Somewhere I once saw "Simplicate and add lightness!" > >Just for some numbers, I have an A-65 Continental and it weighs in at >626lbs. empty. Full fuel is just under 15 gallons. I regularly carry a >230lb. passenger with full fuel and me at nearly 185 lbs. It doesn't >exactly claw for altitude at that weight, but basically I know if I can get >the passenger into the front hole I can lift them out of a respectable >field. > >Don Emch >NX899DE > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=196754#196754 > > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Aug 05, 2008
One of the old Buckeye Association newsletters (back in the days when Frank pavliga was the editor, I think) had a drawing on a way to do this. Kip G. On Aug 5, 2008, at 6:22 PM, Jim Ash wrote: > > Has anybody done the door mod with a tube-and-fabric fuselage > instead of a wooden one? > > Jim Ash > > -----Original Message----- >> From: gcardinal <gcardinal(at)comcast.net> >> Sent: Aug 5, 2008 7:10 AM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: How hard is it to get into the front >> seat >> >> >> >> Charley, >> >> Keri-Ann Price sells plans for a modification to add a door to the >> passenger >> seat. Her website is: >> >> http://www.geocities.com/keriannprice/Pietenpol_Plan_Packages.html >> >> Greg >> >> ----- Original Message ----- >> From: "charles loomis" <rameses32(at)yahoo.com> >> To: >> Sent: Tuesday, August 05, 2008 3:48 AM >> Subject: Pietenpol-List: How hard is it to get into the front seat >> >> >>> >>> >>> I think I remember seeing a video showing that it was pretty >>> difficult. >>> The reason I ask is because my misses is not the most flexible >>> person and >>> she has a bad back. I really wish to build a Pietenpol with a >>> Model A >>> engine, but I also want to take her flying and show her why there is >>> nothing else like it. >>> Charley >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 05, 2008
NX18235 has 3/32 cables bracing the cabanes. No adjustments needed in 140 hours of flying. Greg ----- Original Message ----- From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> Sent: Tuesday, August 05, 2008 9:04 AM Subject: Pietenpol-List: Re: Homemade Turnbuckles > > > Has anyone talked with Frank Pavliga ? His Piet used 3/32 cable to cross > angle support the cabanes, and had to keep tightening because of stretch, > and replaced them after a few hours of flight. Do other applications of > 3/32 cable experience the same problem ? Don't chance it. > Allen Rudolf's piet still flys with 1/8 Th" cables and the plane weights > under 640 Lbs. And will fly two people on a 90 Deg. day with a standard > Ford A just turning 1950 RPM. > Pieti Lowell[/quote] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196610#196610 > > > ________________________________________________________________________________
Subject: intercom
Date: Aug 05, 2008
Does anyone have a intercom installed? I tried a portable Sigtronics and it didnt work, it kept the mic open because of wind noise. I'm thinking it might work if I installed a PTT in the front cockpit and we talked but broadcast the conversation, but I dont want that. Dick N. ________________________________________________________________________________
Subject: intercom
Date: Aug 06, 2008
Dick, I use an HM200 (http://www.ozpilot.com.au/cgi-bin/webitempage.pl?hm200). There is a fair amount of wind noise but I put some large foam covers over the microphone (ala Sports Commentators) and that stops some of it. It also plugs nicely into the Icom hand held. Cheers Peter Wonthaggi Australia http://www.cpc-world.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Wednesday, 6 August 2008 2:14 PM Subject: Pietenpol-List: intercom Does anyone have a intercom installed? I tried a portable Sigtronics and it didnt work, it kept the mic open because of wind noise. I'm thinking it might work if I installed a PTT in the front cockpit and we talked but broadcast the conversation, but I dont want that. Dick N. ________________________________________________________________________________
Date: Aug 05, 2008
Bill, If you are going to blast me for what I am going to do maybe I should consider dropping off the list. Ben in MN ----- Original Message ---- From: Bill Church <eng(at)canadianrogers.com> Sent: Tuesday, August 5, 2008 5:53:25 PM Subject: RE: Pietenpol-List: ribs and ailerons Ben, Ben, Ben. Yes, it is possible to build an Air Camper from the Flying and Glider Manual drawings. I wouldn't want to, but it's been done. Those drawings are so small I find them pretty hard to read, though. Nonetheless, those are your plans. I assume you "splurged" for the $8 for the EAA reprint of the FGM. Use those plans to deternmine how many ribs are affected by the ailerons. As for $150 being too much to spend, how do you plan to build the rest of the plane if $150 for a set of plans is too much money? How are you going to come up with the cash for a motor? How about a propellor? Wheels? Instruments? The cheapest recent build that I can recall hearing about was around $5,000. Assuming someone gave you all of the materials to build the plane, and you live on a property big enough to have your own runway, what are you going to do when it comes time to fill the tank at $5 a gallon (or more)? The Pietenpol is one of the most economical "real" aircraft you can build. It can be built cheaply, but it still ain't free. Building an airplane from plans drawn in 1934 is a challenge. Building an airplane without using those plans, and not spending any money is called dreaming. Pleasant dreams, Ben. BC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 6:30 PM Subject: Re: Pietenpol-List: ribs and ailerons --> nope. Dad said the flyer and glider manual is what to use. you have 150 to spend??? I don't! ----- Original Message ---- From: Bill Church <eng(at)canadianrogers.com> Sent: Tuesday, August 5, 2008 4:39:04 PM Subject: RE: Pietenpol-List: ribs and ailerons --> Yikes! Ben, what are you doing trying to build a plane without having or reading the plans??? The plans is all there is. There ain't no other way to do it. Maybe it's time to order a new set of plans (or put the project to rest). Or are you just pulling our collective leg? Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 5:08 PM Subject: Re: Pietenpol-List: ribs and ailerons --> not sure where the rest of the plans went to though. I have hard time reading plans though to be honest. ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Tuesday, August 5, 2008 12:03:57 PM Subject: RE: Pietenpol-List: ribs and ailerons --> Count them. You do have the plans, don't you? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Tuesday, August 05, 2008 12:21 PM Subject: Pietenpol-List: ribs and ailerons --> Afternoon Group, Here's a question... Once all 31 ribs are made how many of the ribs need to be set aside for the ailerons? 73, Ben in MN ________________________________________________________________________________
Subject: Re: Ribs and sanding
Date: Aug 05, 2008
End grain cannot be succesfully glued. It may hold for a short time with little stress on it but you'd better not trust your backside to it. Glueing edge or flat grain will hold up to the strength of the fibers. Sanded joints will never be as strong as planed or scraped ones. Wood faces should also be fresh at the time of glueing. The best way is to learn how to use and properly sharpen cabinet scrapers. It's not that hard but does have it's own learning curve. Isn't that what we're supposed to be doing? Learning? http://woodgears.ca/scraper/index.html http://www.taunton.com/finewoodworking/pages/w00007.asp? "Life is change. Growth is optional. Choose wisely." ~Karen Kaiser Clark Clif > > Gary's comments refer more to glue joints for end-grain spruce (or > whatever softwood you are building with). When spruce is sawn, the end > grain has open pores which will absorb the adhesive. If the end is sanded > (and especially if the wood gets burned in sanding), the pores tend to get > clogged, which impedes the absorption of the adhesive. If the epoxy > doesn't "bite" into the wood, the joint will not achieve the strength that > is needed. That is a bad thing. > Bill C. ________________________________________________________________________________
From: Marc Davis <marcs_listreading(at)hotmail.com>
Date: Aug 06, 2008
I've seen the following idea used to save money on turnbuckles. The turnbu ckles for the cross bracing inside the wing are eliminated. This is done by preloading the cables before crimping the nicopress. The w ing is first trammeled. Then the first end of the cable is installed as nor mal. The second end of the cable is run through the nicopress=2C around th e thimble and back through the nicopress. It then continues about half wa y towards the first end. At this point it passes over a pulley and down th rough a hole in the table that the wing is on. At the end of the cable han g weights to tension the cable. Both cables in a pair are setup like this. When everything is set the second nicopress is crimed and the excess cab le is cut off. No turnbuckles needed. The down side is that you have to r eplace the cables to re trammel the wing but I don't think this is done ver y often. Marc _________________________________________________________________ Get Windows Live and get whatever you need=2C wherever you are. Start here . http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home_082008 ________________________________________________________________________________
Date: Aug 06, 2008
Ben, I thought you came to this list to learn and get advice? If you only came to hear what you want to hear, then maybe you would be better going elsewhere. The builders here were asked for their advice and they gave it. They didn't blast you at all. I've belonged to this groug for several years and have yet seen anyone blast anybody. I have seen an outstanding exchange of ideas. When I first came to the group "I" thought one of the old timers was blasting me. Others set me straight and the "old timer" (sorry Corky) has been a mentor and a friend. If you stick around, you just might learn a thing or two AND make some great mentors/friends. Gene in Tennessee having a great time flying N502R (sure glad I didn't let false pride get in my way and I stuck around) ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Tuesday, August 05, 2008 11:43 PM Subject: Re: Pietenpol-List: ribs and ailerons > > > Bill, > If you are going to blast me for what I am going to do maybe I should > consider dropping off the list. > Ben in MN > > > ----- Original Message ---- > From: Bill Church <eng(at)canadianrogers.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 5:53:25 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > > > Ben, Ben, Ben. > > Yes, it is possible to build an Air Camper from the Flying and Glider > Manual > drawings. I wouldn't want to, but it's been done. Those drawings are so > small I find them pretty hard to read, though. Nonetheless, those are your > plans. I assume you "splurged" for the $8 for the EAA reprint of the FGM. > Use those plans to deternmine how many ribs are affected by the ailerons. > > As for $150 being too much to spend, how do you plan to build the rest of > the plane if $150 for a set of plans is too much money? How are you going > to > come up with the cash for a motor? How about a propellor? Wheels? > Instruments? The cheapest recent build that I can recall hearing about was > around $5,000. Assuming someone gave you all of the materials to build the > plane, and you live on a property big enough to have your own runway, what > are you going to do when it comes time to fill the tank at $5 a gallon (or > more)? The Pietenpol is one of the most economical "real" aircraft you can > build. It can be built cheaply, but it still ain't free. > > Building an airplane from plans drawn in 1934 is a challenge. > Building an airplane without using those plans, and not spending any money > is called dreaming. > > Pleasant dreams, Ben. > > > BC > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 6:30 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: ribs and ailerons > > --> > > nope. Dad said the flyer and glider manual is what to use. > > you have 150 to spend??? I don't! > > > ----- Original Message ---- > From: Bill Church <eng(at)canadianrogers.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 4:39:04 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > --> > > Yikes! > > Ben, what are you doing trying to build a plane without having or reading > the plans??? > The plans is all there is. > There ain't no other way to do it. > > Maybe it's time to order a new set of plans (or put the project to rest). > > Or are you just pulling our collective leg? > > Bill C. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 5:08 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: ribs and ailerons > > --> > > not sure where the rest of the plans went to though. I have hard time > reading plans though to be honest. > > > ----- Original Message ---- > From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 12:03:57 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > --> > > Count them. You do have the plans, don't you? > > Jack Phillips > NX899JP > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 12:21 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: ribs and ailerons > > --> > > Afternoon Group, > Here's a question... Once all 31 ribs are made how many of the ribs need > to be set aside for the ailerons? > 73, > Ben in MN > > > -- > Checked by AVG. > 4:05 PM > ________________________________________________________________________________
Subject: intercom
Date: Aug 06, 2008
Hi Dick, I've got one and it works to some extent. It is a panel mount (I think it is Sigtronics but will have to check it to make sure). It did not work well using regular headphones, but when I use the leather flying helmets from Gibson & Barnes that have headsets built in with noise cancelling microphones, it works fairly well. The squelch is always open, but you can at least hear each other talk. Sure is nice when taking passengers for a ride. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Wednesday, August 06, 2008 12:14 AM Subject: Pietenpol-List: intercom Does anyone have a intercom installed? I tried a portable Sigtronics and it didnt work, it kept the mic open because of wind noise. I'm thinking it might work if I installed a PTT in the front cockpit and we talked but broadcast the conversation, but I dont want that. Dick N. ________________________________________________________________________________
Date: Aug 06, 2008
Andrew King sent me this shot after flying it back from Brodhead. He needed to make a pit stop and the freshly cut wheat looked just right! The farmer will never know he owned an airstrip for a short time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196846#196846 ________________________________________________________________________________
Subject: intercom/headsets
Date: Aug 06, 2008
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Dick, I have a 9 volt battery powered 2-place Sigtronics intercom w/ squelch and volume control. Microphone sponges/covers are a must to cut wind noise and if possible use noise cancelling head sets. I just purchased a Flightcom Classic ANR (active noise reduction) headset to replace my very old Pilot Avionics at Oshkosh and tried it last weekend and could hear unicom frequencies 75% better than I did with my old Pilot Avionics units. Transmissions were so much more clear as well. I'm sold on ANR headsets. I'm now saving up for a second set of the Flightcom Classics. By the way I shopped every vendor at OSH for the best price on the Flightcom Classic ANR's and Gulfcoast Avionics was the best at $269. Steer clear from the Pilotmall.com Mike C. PS-- I have a very new Lightspeed ANR headset for sale (which is fantastic) but the ear shape doesn't fit my khaki cloth helmet style. I forget what model but they are nice. ________________________________________________________________________________
Subject: turnbuckles
Date: Aug 06, 2008
B&B Aircraft Supplies - This is a mom and pop shop with a whole warehouse full of new aircraft parts. Nice people and great prices. Check here before you go elsewhere. No website, so you need to call or fax your order. Phone - 913-884-5930. Fax 913-84-6533. Many of you on the list know this to be the most cost effective place to purchase brass turnbuckles but the point was driven home again when I visited them at Oshkosh. No frills, no web site, but excellent prices on turnbuckles if you want to cut to the chase and speed up your process. ________________________________________________________________________________
Date: Aug 06, 2008
Ben, I think you've gotten some good advice from those on the list, particularly Bill Church.. More than once you have posted a note to the effect that you want to make different ribs for the ailerons than the rest of the wing, and several people (myself included) have said as nicely as possible that the way you build this wing (which is mentioned in the F&GM) is to build the wing then cut the ailerons free. Yet you seem to persist in wanting to do it differently. People on this list are primarily interested in helping others to build good SAFE Pietenpols. There is a good deal of bantering and a lot of humor but basically, most people want to help others as they themselves were helped at various stages of their projects. It is a bit frustrating when a new builder comes along, asks for advice, then discards it, seeming to say "I know better how to do this than all those who have actually built and flown one of these planes". Remember, the purpose of allowing amateur built airplanes to be licensed as "Experimental", according to the FAA is to encourage "Education and Recreation". It is NOT necessarily to allow people to build a plane as cheaply as possible. You can build a Pietenpol for as little as $5,000 or so, if you really know what you are doing and are a very good "scrounger". More likely it will cost something between $10,000 and $15,000. Remember that this will be spread over several years. I've got about $15,000 in mine but that was spread over 8 years of building, so I tell people that I spent as much on this airplane as a 2-pack a day smoker would have spent on cigarettes in the same timeframe. There are several areas that should NOT be scrimped on. I would include the plans and builders manual in that category. If you have built airplanes before, it is possible to build a flying Pietenpol from the F&GM plans, but it would be difficult - especially if you are trying to do things cheaply. For example, the F&GM plans only show the straight axle, wire wheel type of landing gear. Having built that, I can assure you that it is NOT the cheapest gear you can build. My wheels alone cost nearly $1,000. My recommendation is to buy the improved (1934) plans from the Pietenpol family. You really also need the Tony Bingelis books to explain 95% of the procedures you will need to learn to be able to build this airplane. A Pietenpol is a fairly simple design, but you will need to know more techniques than a high school shop class will teach. It is not exactly like building a birdhouse - there is a lot more to it, such as welding and trammeling, and rigging and aligning. Remember - your life will depend on the quality of your workmanship. This list will offer worlds of good advice, but it does no good unless you heed it. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Wednesday, August 06, 2008 5:07 AM Subject: Re: Pietenpol-List: ribs and ailerons Ben, I thought you came to this list to learn and get advice? If you only came to hear what you want to hear, then maybe you would be better going elsewhere. The builders here were asked for their advice and they gave it. They didn't blast you at all. I've belonged to this groug for several years and have yet seen anyone blast anybody. I have seen an outstanding exchange of ideas. When I first came to the group "I" thought one of the old timers was blasting me. Others set me straight and the "old timer" (sorry Corky) has been a mentor and a friend. If you stick around, you just might learn a thing or two AND make some great mentors/friends. Gene in Tennessee having a great time flying N502R (sure glad I didn't let false pride get in my way and I stuck around) ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Tuesday, August 05, 2008 11:43 PM Subject: Re: Pietenpol-List: ribs and ailerons > > > Bill, > If you are going to blast me for what I am going to do maybe I should > consider dropping off the list. > Ben in MN > > > ----- Original Message ---- > From: Bill Church <eng(at)canadianrogers.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 5:53:25 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > > > Ben, Ben, Ben. > > Yes, it is possible to build an Air Camper from the Flying and Glider > Manual > drawings. I wouldn't want to, but it's been done. Those drawings are so > small I find them pretty hard to read, though. Nonetheless, those are your > plans. I assume you "splurged" for the $8 for the EAA reprint of the FGM. > Use those plans to deternmine how many ribs are affected by the ailerons. > > As for $150 being too much to spend, how do you plan to build the rest of > the plane if $150 for a set of plans is too much money? How are you going > to > come up with the cash for a motor? How about a propellor? Wheels? > Instruments? The cheapest recent build that I can recall hearing about was > around $5,000. Assuming someone gave you all of the materials to build the > plane, and you live on a property big enough to have your own runway, what > are you going to do when it comes time to fill the tank at $5 a gallon (or > more)? The Pietenpol is one of the most economical "real" aircraft you can > build. It can be built cheaply, but it still ain't free. > > Building an airplane from plans drawn in 1934 is a challenge. > Building an airplane without using those plans, and not spending any money > is called dreaming. > > Pleasant dreams, Ben. > > > BC > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 6:30 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: ribs and ailerons > > --> > > nope. Dad said the flyer and glider manual is what to use. > > you have 150 to spend??? I don't! > > > ----- Original Message ---- > From: Bill Church <eng(at)canadianrogers.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 4:39:04 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > --> > > Yikes! > > Ben, what are you doing trying to build a plane without having or reading > the plans??? > The plans is all there is. > There ain't no other way to do it. > > Maybe it's time to order a new set of plans (or put the project to rest). > > Or are you just pulling our collective leg? > > Bill C. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 5:08 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: ribs and ailerons > > --> > > not sure where the rest of the plans went to though. I have hard time > reading plans though to be honest. > > > ----- Original Message ---- > From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 12:03:57 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > --> > > Count them. You do have the plans, don't you? > > Jack Phillips > NX899JP > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 12:21 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: ribs and ailerons > > --> > > Afternoon Group, > Here's a question... Once all 31 ribs are made how many of the ribs need > to be set aside for the ailerons? > 73, > Ben in MN > > > -- > Checked by AVG. > 4:05 PM > ________________________________________________________________________________
Subject: intercom
Date: Aug 06, 2008
Dick I have a open cockpit Skybolt with the same or louder noise problem. I used a Micro-Air radio with a built in intercom. I installed a centering togle switch in both cockpits. If you push it down you talk to each other. And if you push it up you talk to the world. It works very well. Glad I could finaly give some advice. Jerry Grogan ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 4:52 AM Subject: RE: Pietenpol-List: intercom Hi Dick, I've got one and it works to some extent. It is a panel mount (I think it is Sigtronics but will have to check it to make sure). It did not work well using regular headphones, but when I use the leather flying helmets from Gibson & Barnes that have headsets built in with noise cancelling microphones, it works fairly well. The squelch is always open, but you can at least hear each other talk. Sure is nice when taking passengers for a ride. Jack Phillips NX899JP ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick Navratil Sent: Wednesday, August 06, 2008 12:14 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: intercom Does anyone have a intercom installed? I tried a portable Sigtronics and it didnt work, it kept the mic open because of wind noise. I'm thinking it might work if I installed a PTT in the front cockpit and we talked but broadcast the conversation, but I dont want that. Dick N. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 06, 2008
Jack, I have never ever implied that I know more than the rest of the people on this list and I am a little offended that you would even suggest a such a thing. Just because I always try to do things differently doesn't that I am ignoreing you. Ben in MN ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Wednesday, August 6, 2008 6:58:22 AM Subject: RE: Pietenpol-List: ribs and ailerons Ben, I think you've gotten some good advice from those on the list, particularly Bill Church.. More than once you have posted a note to the effect that you want to make different ribs for the ailerons than the rest of the wing, and several people (myself included) have said as nicely as possible that the way you build this wing (which is mentioned in the F&GM) is to build the wing then cut the ailerons free. Yet you seem to persist in wanting to do it differently. People on this list are primarily interested in helping others to build good SAFE Pietenpols. There is a good deal of bantering and a lot of humor but basically, most people want to help others as they themselves were helped at various stages of their projects. It is a bit frustrating when a new builder comes along, asks for advice, then discards it, seeming to say "I know better how to do this than all those who have actually built and flown one of these planes". Remember, the purpose of allowing amateur built airplanes to be licensed as "Experimental", according to the FAA is to encourage "Education and Recreation". It is NOT necessarily to allow people to build a plane as cheaply as possible. You can build a Pietenpol for as little as $5,000 or so, if you really know what you are doing and are a very good "scrounger". More likely it will cost something between $10,000 and $15,000. Remember that this will be spread over several years. I've got about $15,000 in mine but that was spread over 8 years of building, so I tell people that I spent as much on this airplane as a 2-pack a day smoker would have spent on cigarettes in the same timeframe. There are several areas that should NOT be scrimped on. I would include the plans and builders manual in that category. If you have built airplanes before, it is possible to build a flying Pietenpol from the F&GM plans, but it would be difficult - especially if you are trying to do things cheaply. For example, the F&GM plans only show the straight axle, wire wheel type of landing gear. Having built that, I can assure you that it is NOT the cheapest gear you can build. My wheels alone cost nearly $1,000. My recommendation is to buy the improved (1934) plans from the Pietenpol family. You really also need the Tony Bingelis books to explain 95% of the procedures you will need to learn to be able to build this airplane. A Pietenpol is a fairly simple design, but you will need to know more techniques than a high school shop class will teach. It is not exactly like building a birdhouse - there is a lot more to it, such as welding and trammeling, and rigging and aligning. Remember - your life will depend on the quality of your workmanship. This list will offer worlds of good advice, but it does no good unless you heed it. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Wednesday, August 06, 2008 5:07 AM Subject: Re: Pietenpol-List: ribs and ailerons Ben, I thought you came to this list to learn and get advice? If you only came to hear what you want to hear, then maybe you would be better going elsewhere. The builders here were asked for their advice and they gave it. They didn't blast you at all. I've belonged to this groug for several years and have yet seen anyone blast anybody. I have seen an outstanding exchange of ideas. When I first came to the group "I" thought one of the old timers was blasting me. Others set me straight and the "old timer" (sorry Corky) has been a mentor and a friend. If you stick around, you just might learn a thing or two AND make some great mentors/friends. Gene in Tennessee having a great time flying N502R (sure glad I didn't let false pride get in my way and I stuck around) ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Tuesday, August 05, 2008 11:43 PM Subject: Re: Pietenpol-List: ribs and ailerons > > > Bill, > If you are going to blast me for what I am going to do maybe I should > consider dropping off the list. > Ben in MN > > > ----- Original Message ---- > From: Bill Church <eng(at)canadianrogers.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 5:53:25 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > > > Ben, Ben, Ben. > > Yes, it is possible to build an Air Camper from the Flying and Glider > Manual > drawings. I wouldn't want to, but it's been done. Those drawings are so > small I find them pretty hard to read, though. Nonetheless, those are your > plans. I assume you "splurged" for the $8 for the EAA reprint of the FGM. > Use those plans to deternmine how many ribs are affected by the ailerons. > > As for $150 being too much to spend, how do you plan to build the rest of > the plane if $150 for a set of plans is too much money? How are you going > to > come up with the cash for a motor? How about a propellor? Wheels? > Instruments? The cheapest recent build that I can recall hearing about was > around $5,000. Assuming someone gave you all of the materials to build the > plane, and you live on a property big enough to have your own runway, what > are you going to do when it comes time to fill the tank at $5 a gallon (or > more)? The Pietenpol is one of the most economical "real" aircraft you can > build. It can be built cheaply, but it still ain't free. > > Building an airplane from plans drawn in 1934 is a challenge. > Building an airplane without using those plans, and not spending any money > is called dreaming. > > Pleasant dreams, Ben. > > > BC > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 6:30 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: ribs and ailerons > > --> > > nope. Dad said the flyer and glider manual is what to use. > > you have 150 to spend??? I don't! > > > ----- Original Message ---- > From: Bill Church <eng(at)canadianrogers.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 4:39:04 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > --> > > Yikes! > > Ben, what are you doing trying to build a plane without having or reading > the plans??? > The plans is all there is. > There ain't no other way to do it. > > Maybe it's time to order a new set of plans (or put the project to rest). > > Or are you just pulling our collective leg? > > Bill C. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 5:08 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: ribs and ailerons > > --> > > not sure where the rest of the plans went to though. I have hard time > reading plans though to be honest. > > > ----- Original Message ---- > From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> > To: pietenpol-list(at)matronics.com > Sent: Tuesday, August 5, 2008 12:03:57 PM > Subject: RE: Pietenpol-List: ribs and ailerons > > --> > > Count them. You do have the plans, don't you? > > Jack Phillips > NX899JP > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler > Sent: Tuesday, August 05, 2008 12:21 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: ribs and ailerons > > --> > > Afternoon Group, > Here's a question... Once all 31 ribs are made how many of the ribs need > to be set aside for the ailerons? > 73, > Ben in MN > > > -- > Checked by AVG. > 4:05 PM > ________________________________________________________________________________
Subject: ribs and ailerons
Date: Aug 06, 2008
No offense intended, Ben, any more than you intended to offend people by asking their advice and then ignoring what they told you. Now go spend less time sending emails and more time making sawdust! Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Wednesday, August 06, 2008 9:43 AM Subject: Re: Pietenpol-List: ribs and ailerons Jack, I have never ever implied that I know more than the rest of the people on this list and I am a little offended that you would even suggest a such a thing. Just because I always try to do things differently doesn't that I am ignoreing you. Ben in MN ________________________________________________________________________________
Subject: Re: How hard is it to get into the front seat
Date: Aug 06, 2008
This is very interesting stuff. BTW, how does a Piet's useful load compare to some other small planes like a C-152 and J-3 Cub? I mean "real world" usefulness, not the published numbers. I just don't want to spend years building an aircraft only to find out that I (6'2" and 195 lbs) can't carry a 180 lb. passenger without scaring the schit out of myself. I'd be kinda heartbroken if I couldn't share the ride with others. Jack, I think you're probably a gold nugget for my research. What's the best way for me to get in touch with you? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196872#196872 ________________________________________________________________________________
Date: Aug 06, 2008
Subject: Re: ribs and ailerons
agian I wasn't ignoreing anyone! later Ben ----- Original Message ---- From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> Sent: Wednesday, August 6, 2008 8:59:18 AM Subject: RE: Pietenpol-List: ribs and ailerons No offense intended, Ben, any more than you intended to offend people by asking their advice and then ignoring what they told you. Now go spend less time sending emails and more time making sawdust! Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Wednesday, August 06, 2008 9:43 AM Subject: Re: Pietenpol-List: ribs and ailerons Jack, I have never ever implied that I know more than the rest of the people on this list and I am a little offended that you would even suggest a such a thing. Just because I always try to do things differently doesn't that I am ignoreing you. Ben in MN ________________________________________________________________________________
Date: Aug 06, 2008
Subject: Re: intercom
When I was getting the taildragger endorsement maybe 15 years ago, I was in a rented J-3 with the instructor up front. As is common in Cubs, we never shut the door. He had a voice-activated portable which I found annoying because there was only one squelch control, but the noise levels between the two seat were very different. Your squelch choices were nobody talks, or both mics were always open. Plus a single volume control was never quite balanced between front and back seats, although I admittedly have a volume control on my headset. When I bought my Cub, I went looking for a voice-activated portable that had individual squelch and volume controls. IIRC there weren't a lot of choices at the time, and I ended up with PS Engineering's Aerocom II (which I don't think is made any more). The separate squelch and volume controls did the trick for me. One down side is that my passengers don't have access to their controls, so I have to adjust them for both of us. I also have a PTT, which is used just for radio transmitting. If memory serves, I can also rig a radio PTT for my passenger, but I've never done it. I haven't really kept up with the improvements in intercoms in the last 10 years or so because mine works just fine for my purposes. I spoke with the folks at PS Engineering 4 or 5 years ago at Sun 'n Fun and I guess their squelch circuits are automatic now, at least for the models I cared about. The down side to letting an engineer decide how a circuit should behave is the risk that the choices he made and built into the design might not work for your specific needs. I'm not a fan of one-size fits all / one size fits nobody engineering, and I resent having the squelch control removed. My concern would be that they tailored the circuits towards spam can airplanes with enclosed environments, possibly at the expense of open-cockpits, because they probably move more units in that market space. But to be fair, if the engineering is truly that sophisticated and works the way I would like it to, then I might actually concede and join the 21st century come time to purchase my next intercom. Granted it ain't open cockpit, but Cubs are notoriously noisy. After having flown only once without a headset or any hearing protection, I'll never do it again. I'm frankly amazed how anybody can communicate at all over the din, let alone with a voice-activated system. Jim -----Original Message----- >From: Dick Navratil <horzpool(at)goldengate.net> >Sent: Aug 6, 2008 12:13 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: intercom > >Does anyone have a intercom installed? I tried a portable Sigtronics and it didnt work, it kept the mic open because of wind noise. I'm thinking it might work if I installed a PTT in the front cockpit and we talked but broadcast the conversation, but I dont want that. >Dick N. ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Date: Aug 06, 2008
Hello All! I am building the short fuselage version.... I sat in it and said NO WAY!!!! (I am 6'2") I then removed the front seat, moved the rudder bar forward. Now I fit! But it is now a single seat with baggage in front. Maybe I will make a Mail Plane out of her!!!! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Rick Holland Sent: Tuesday, August 05, 2008 4:28 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: How hard is it to get into the front seat And the long fuselage version gives you a bit more cockpit length and you can always widen the fuselage as many have done (widened mine two inches). Of course that doesn't necessarily increase your gross weight. Rick On Tue, Aug 5, 2008 at 1:01 PM, Kip and Beth Gardner wrote: Tom, There is a saying that you may not have heard since you are fairly new to the list - "This plane was designed when midgets ruled the earth!" Bernard, by all accounts, was about 5'4" and weighed maybe 140 lbs. Now that's just about my size, and my wife is about the same, and our daughter will probably be about equal or less as an adult, so for us, yes, it's a capable 2-seater. Heck, we could even carry 50-60 lbs of baggage if there was space for it! For two 200+ lb. guys, add in a full load of fuel and you're close to gross, if not over, depending on how light or heavy you built your plane. Kip G. On Aug 5, 2008, at 2:48 PM, Tom Anderson wrote: walt, How big-butted are you talking about here? Furthermore, is the Piet a truly capable 2-seater at all? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196707#196707 -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 06, 2008
Dave, let me know how it works as I am also 6'2", but I have not begun the building process yet! I am getting the engine ready first and reading as mu ch as I can. I helped build a Piet back in 87, it was just the ribs, so I h ave a long way to learn, but I am having so much fun I don't think I'll eve r build another R/C aircraft! Thanks for the posts, they are a real help!!! Joser ----- Original Message ----- From: Dave Abramson To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 10:24 AM Subject: RE: Pietenpol-List: Re: How hard is it to get into the front sea t Hello All! I am building the short fuselage version.... I sat in it and said NO WAY !!!! (I am 6'2") I then removed the front seat, moved the rudder bar forw ard. Now I fit! But it is now a single seat with baggage in front. Maybe I will make a Mail Plane out of her!!!! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol -list-server(at)matronics.com]On Behalf Of Rick Holland Sent: Tuesday, August 05, 2008 4:28 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: How hard is it to get into the front s eat And the long fuselage version gives you a bit more cockpit length and y ou can always widen the fuselage as many have done (widened mine two inches ). Of course that doesn't necessarily increase your gross weight. Rick On Tue, Aug 5, 2008 at 1:01 PM, Kip and Beth Gardner wrote: h(at)earthlink.net> Tom, There is a saying that you may not have heard since you are fairly ne w to the list - "This plane was designed when midgets ruled the earth!" Be rnard, by all accounts, was about 5'4" and weighed maybe 140 lbs. Now tha t's just about my size, and my wife is about the same, and our daughter wil l probably be about equal or less as an adult, so for us, yes, it's a capab le 2-seater. Heck, we could even carry 50-60 lbs of baggage if there was s pace for it! For two 200+ lb. guys, add in a full load of fuel and you're close to gross, if not over, depending on how light or heavy you built you r plane. Kip G. On Aug 5, 2008, at 2:48 PM, Tom Anderson wrote: c(at)yahoo.com> walt, How big-butted are you talking about here? Furthermore, is the Piet a truly capable 2-seater at all? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196707#196707 -- Rick Holland Castle Rock, Colorado href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Aug 06, 2008
Joser: An Air Camper is a radio controlled (i.e. R/C) aircraft - - assuming your wife is on the other end of the intercom circuit. Stinemetze >I am having so much fun I don't think I'll ever build another R/C aircraft! Thanks for the posts, they are a real help!!! >Joser ________________________________________________________________________________
Date: Aug 06, 2008
If you have the long fuselage plans, have a good look at the mods I made. Use the long fuse plan, but refer to the short fuse plan for building the bridge decks and turtle deck. If you do that, the front cockpit stays the same but you will gain approx 9 inches in the rear cockpit. I also reclined the rear seat by 1 1/2" for comfort. Dick N. ----- Original Message ----- From: "Tom Anderson" <tomanderson_nc(at)yahoo.com> Sent: Wednesday, August 06, 2008 9:03 AM Subject: Pietenpol-List: Re: How hard is it to get into the front seat > > > This is very interesting stuff. > BTW, how does a Piet's useful load compare to some other small planes like > a C-152 and J-3 Cub? I mean "real world" usefulness, not the published > numbers. > > I just don't want to spend years building an aircraft only to find out > that I (6'2" and 195 lbs) can't carry a 180 lb. passenger without scaring > the schit out of myself. I'd be kinda heartbroken if I couldn't share the > ride with others. > > Jack, > I think you're probably a gold nugget for my research. What's the best > way for me to get in touch with you? > > -------- > Location: Eastern N.C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=196872#196872 > > > ________________________________________________________________________________
Date: Aug 06, 2008
Tom, Useful load of a Pietenpol is kind of a nebulous term since the builder can specify what the gross weight of the airplane is. I can only speak to my own plane's performance. With a Continental A65, and a Sensenich 72x40 prop I have taken a passenger as heavy as 205 in it on a 93F day. I am 6'2" and weigh 200. We had full fuel that day so our total weight was 745 (empty weight) + 8 (oil) + 90 (fuel) + 200 (me) + 205 (passenger) = 1,248 lbs. We got off the ground in about 500' and then slogged upwards at the blistering rate of about 100 - 150 fpm. We were flying from a 6,000' runway. You can do it, and if your home field has a long runway you will have no problems. If you fly out of the typical North Carolina grass strip you will be lucky to have 2500 feet before you get to the tall skinny pines we have around here. A Piet doesn't work so well on such a strip - at least when carrying passengers. If you build your Piet lightly, your performance will be much enhanced. Most Piets are at least 100 lbs lighter than mine. The things that added weight to mine are: 1. Long fuselage 2. Fuselage 1" wider than plans 3. Straight axle 4. Wire Wheels 5. Polyurethane paint (added at least 60 lbs) 6. Semi-electrical system (battery, no generator, radio, transponder, intercom) 7. Instruments in the front cockpit (maybe 4 lbs added) 8. Seat cushions (sure was nice for the 34 hour round trip to Brodhead) Build it Light! Every time I have to turn a passenger down for a ride from a short runway I'm reminded of the features that added weight to mine (of course, flying it by myself, I LOVE those features). Best way to get in touch with me is through this email address, the phone number below, or by my cellphone (919) 427-4440. You can email me at home: pietflyr(at)bellsouth.net but I don't check it every day. Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tom Anderson Sent: Wednesday, August 06, 2008 10:03 AM Subject: Pietenpol-List: Re: How hard is it to get into the front seat This is very interesting stuff. BTW, how does a Piet's useful load compare to some other small planes like a C-152 and J-3 Cub? I mean "real world" usefulness, not the published numbers. I just don't want to spend years building an aircraft only to find out that I (6'2" and 195 lbs) can't carry a 180 lb. passenger without scaring the schit out of myself. I'd be kinda heartbroken if I couldn't share the ride with others. Jack, I think you're probably a gold nugget for my research. What's the best way for me to get in touch with you? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196872#196872 _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Aug 06, 2008
Ben, When I read your reply, I thought that maybe the words I wrote were not clear, and could be taken the wrong way, but I see that a few other listers have confirmed that what I wrote was not out of line (Thanks Gene and Jack for the support). My comments were not intended to "blast" you. Sorry to hear you took them that way. They were offered in the spirit of helping. You asked for advice, and that is what I gave. Based on your comments, it seemed as though you did not grasp the size or complexity of the project. As with any advice, it is yours to do with as you please. But, honestly Ben, are you planning to build a Pietenpol with only one page of the plans, which you find hard to follow? If you are, I suggest that you really need to find a local experienced mentor to guide you through the building process on a one-on-one basis. These plans have (almost) all the information needed to build an airplane, but there are a lot of areas that are a challenge to decipher. I read and interpret drawings every day as part of my job, and even I find some parts of these plans a bit difficult, so I can't imagine how hard it would be for someone who finds plans hard to follow. If you really intend to build yourself an Air Camper, you will not want to drop off the list, because this list is a wealth of information, with lots of members who have tons of experience (lots more than me), which most are willing and eager to share. On the other hand, if you are going to get offended by someone's reply to your questions, maybe you need to give your questions a bit more thought before throwing them out there for a reply. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Wednesday, August 06, 2008 12:44 AM Subject: Re: Pietenpol-List: ribs and ailerons --> Bill, If you are going to blast me for what I am going to do maybe I should consider dropping off the list. Ben in MN ________________________________________________________________________________
Date: Aug 06, 2008
Ben We all like to put our mark on our planes and I'm certainly one who has done that. But you have to realize that anything you do to this plane will have a major effect on the flight characterisics, including the most minor changes. If you make changes without knowing what those effects might be, you may be headed for a plane that doesnt perform well or is just dangerous. If you make changes, draw on the experience of others. The first one is the question of ailereons. A number of others have encouraged you to build the wing with ailereons attached, that is the only way to get a true surface. ----- Original Message ----- From: "Ben Ramler" <ben_ramler2002(at)yahoo.com> Sent: Wednesday, August 06, 2008 8:43 AM Subject: Re: Pietenpol-List: ribs and ailerons Jack, I have never ever implied that I know more than the rest of the people on this list and I am a little offended that you would even suggest a such a thing. Just because I always try to do things differently doesn't that I am ignoreing you. Ben in MN ________________________________________________________________________________
Date: Aug 06, 2008
Make a note to put more of an angle on the seat back.... It is a little too vertical. Too late for mine, but I have read about alot of people doing it! Wish I knew before I built mine! Cheers! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Jose Soto Sent: Wednesday, August 06, 2008 7:39 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: How hard is it to get into the front seat Dave, let me know how it works as I am also 6'2", but I have not begun the building process yet! I am getting the engine ready first and reading as much as I can. I helped build a Piet back in 87, it was just the ribs, so I have a long way to learn, but I am having so much fun I don't think I'll ever build another R/C aircraft! Thanks for the posts, they are a real help!!! Joser ----- Original Message ----- From: Dave Abramson To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 10:24 AM Subject: RE: Pietenpol-List: Re: How hard is it to get into the front seat Hello All! I am building the short fuselage version.... I sat in it and said NO WAY!!!! (I am 6'2") I then removed the front seat, moved the rudder bar forward. Now I fit! But it is now a single seat with baggage in front. Maybe I will make a Mail Plane out of her!!!! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Rick Holland Sent: Tuesday, August 05, 2008 4:28 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: How hard is it to get into the front seat And the long fuselage version gives you a bit more cockpit length and you can always widen the fuselage as many have done (widened mine two inches). Of course that doesn't necessarily increase your gross weight. Rick On Tue, Aug 5, 2008 at 1:01 PM, Kip and Beth Gardner wrote: Tom, There is a saying that you may not have heard since you are fairly new to the list - "This plane was designed when midgets ruled the earth!" Bernard, by all accounts, was about 5'4" and weighed maybe 140 lbs. Now that's just about my size, and my wife is about the same, and our daughter will probably be about equal or less as an adult, so for us, yes, it's a capable 2-seater. Heck, we could even carry 50-60 lbs of baggage if there was space for it! For two 200+ lb. guys, add in a full load of fuel and you're close to gross, if not over, depending on how light or heavy you built your plane. Kip G. On Aug 5, 2008, at 2:48 PM, Tom Anderson wrote: walt, How big-butted are you talking about here? Furthermore, is the Piet a truly capable 2-seater at all? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196707#196707 -- Rick Holland Castle Rock, Colorado href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ">http://www.matronics.com/Navigator?Pietenpol-List ics.com .matronics.com/contribution ________________________________________________________________________________
Date: Aug 06, 2008
From: "Dortch, Steven D MAJ MIL USA FORSCOM" <Steven.D.Dortch(at)us.army.mil>
About a week ago I climbed into the front seat of Oscar Zuniga's "Improved" (long) Piet. I am 5ft 8in and 203 LBS and my legs are not limber. It was a job but not too hard. I kind of climbed thru and then backed into the hole. Sitting in the front I had my knees up higher than normal. It felt much better when I put my feet on the rudders. It was fun and comfortable enough for a normal short Piet Flight, but I would not want to spend hours in it. Raising the bottom of the Instrument (that is singular, Oscar only has one guage up front) panel would help for someone taller. The Piet climbed out much better than my friends Aeronca Champ with the same Roaring C-65. It was about 95degrees or more. Oscar is much smaller than me. he did note that the size of the passenger does not affect CG since the PAX is on the center of Gravity. M2C Steve D -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tom Anderson Sent: Wednesday, August 06, 2008 9:03 AM Subject: Pietenpol-List: Re: How hard is it to get into the front seat --> This is very interesting stuff. BTW, how does a Piet's useful load compare to some other small planes like a C-152 and J-3 Cub? I mean "real world" usefulness, not the published numbers. I just don't want to spend years building an aircraft only to find out that I (6'2" and 195 lbs) can't carry a 180 lb. passenger without scaring the schit out of myself. I'd be kinda heartbroken if I couldn't share the ride with others. Jack, I think you're probably a gold nugget for my research. What's the best way for me to get in touch with you? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196872#196872 ________________________________________________________________________________
Date: Aug 06, 2008
Thanks! I'll note it now. ----- Original Message ----- From: Dave Abramson To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 11:17 AM Subject: RE: Pietenpol-List: Re: How hard is it to get into the front sea t Make a note to put more of an angle on the seat back.... It is a little too vertical. Too late for mine, but I have read about alot of people doing it! Wish I knew before I built mine! Cheers! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol -list-server(at)matronics.com]On Behalf Of Jose Soto Sent: Wednesday, August 06, 2008 7:39 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: How hard is it to get into the front s eat Dave, let me know how it works as I am also 6'2", but I have not begun the building process yet! I am getting the engine ready first and reading a s much as I can. I helped build a Piet back in 87, it was just the ribs, so I have a long way to learn, but I am having so much fun I don't think I'll ever build another R/C aircraft! Thanks for the posts, they are a real hel p!!! Joser ----- Original Message ----- From: Dave Abramson To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 10:24 AM Subject: RE: Pietenpol-List: Re: How hard is it to get into the front seat Hello All! I am building the short fuselage version.... I sat in it and said NO WAY!!!! (I am 6'2") I then removed the front seat, moved the rudder bar forward. Now I fit! But it is now a single seat with baggage in front. M aybe I will make a Mail Plane out of her!!!! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-piete npol-list-server(at)matronics.com]On Behalf Of Rick Holland Sent: Tuesday, August 05, 2008 4:28 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: How hard is it to get into the fro nt seat And the long fuselage version gives you a bit more cockpit length a nd you can always widen the fuselage as many have done (widened mine two in ches). Of course that doesn't necessarily increase your gross weight. Rick On Tue, Aug 5, 2008 at 1:01 PM, Kip and Beth Gardner wrote: dbeth(at)earthlink.net> Tom, There is a saying that you may not have heard since you are fairl y new to the list - "This plane was designed when midgets ruled the earth!" Bernard, by all accounts, was about 5'4" and weighed maybe 140 lbs. Now that's just about my size, and my wife is about the same, and our daughter will probably be about equal or less as an adult, so for us, yes, it's a c apable 2-seater. Heck, we could even carry 50-60 lbs of baggage if there w as space for it! For two 200+ lb. guys, add in a full load of fuel and yo u're close to gross, if not over, depending on how light or heavy you built your plane. Kip G. On Aug 5, 2008, at 2:48 PM, Tom Anderson wrote: on_nc(at)yahoo.com> walt, How big-butted are you talking about here? Furthermore, is the Piet a truly capable 2-seater at all? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196707#196707 -- Rick Holland Castle Rock, Colorado href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ">http://www.matronics.com/Navigator?Pietenpol-List ics.com .matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Aug 06, 2008
If I may, I believe this is a case of "It's not WHAT you say, it is HOW you say it." Email is not the best way to comunicate as it were...no tone, no emotion, body language, etc. It is easy to "read into" and misread what is being said. My opinion, nothing more. - - - --- On Wed, 8/6/08, Bill Church wrote: From: Bill Church <eng(at)canadianrogers.com> Subject: RE: Pietenpol-List: ribs and ailerons Date: Wednesday, August 6, 2008, 11:02 AM Ben, When I read your reply, I thought that maybe the words I wrote were not clear, and could be taken the wrong way, but I see that a few other listers have confirmed that what I wrote was not out of line (Thanks Gene and Jack for the support). My comments were not intended to "blast" you. Sorry to hear you took them that way. They were offered in the spirit of helping. You asked for advice, and that is what I gave. Based on your comments, it seemed as though you di d not grasp the size or complexity of the project. As with any advice, it is yours to do with as you please. But, honestly Ben, are you planning to build a Pietenpol with only one page of the plans, which you find hard to follow? If you are, I suggest that you really need to find a local experienced mentor to guide you through the building process on a one-on-one basis. These plans have (almost) all the information needed to build an airplane, but there are a lot of areas that are a challenge to decipher. I read and interpret drawings every day as par t of my job, and even I find some parts of these plans a bit difficult, so I can't imagine how hard it would be for someone who finds plans hard to follow. If you really intend to build yourself an Air Camper, you will not want to drop off the list, because this list is a wealth of information, with lots of members who have tons of experience (lots more than me), which most are willing and eager to share. On the other hand, if you are going to get offended by someone's reply to your questions, maybe you need to give your questions a bit more thought before throwing them out there for a reply. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Ramler Sent: Wednesday, August 06, 2008 12:44 AM Subject: Re: Pietenpol-List: ribs and ailerons --> Bill, --- If you are going to blast me for what I am going to do maybe I sh ould consider dropping off the list. Ben in MN ________________________________________________________________________________
Date: Aug 06, 2008
Hey Mike, Why are you SHOUTING the words "what" and "how"? (sorry, couldn't resist that one.) Actually, I always try to take great care in composing my posts, in order to make sure that what I write is what I really mean to say. Typically, I will write my question or reply, and then I proofread it (and usually edit it) and then I proofread it again (and edit again, and so on, until I am satisfied with my words) before I hit the send button. And, in re-reading my post to Ben, I fail to see how it could be interpreted as a "blast". All I did was state a few facts and ask a few important questions. I stand by my comments, and I stand by my assertion that my posting was intended to help Ben. I'm not sure how it would be possible to misread what I wrote. The funny thing is that in today's email and texting world, written communication is used more than ever before, yet the average person's writing skills today are poorer than they were thirty years ago. If one writes with care and forethought, it is possible to impart tone and emotion (but not body language) into one's writing. The misuse or absence of punctuation in writing is a big contributor to misinterpretation of what is written. A properly placed comma can make a world of difference with regards to the message being conveyed. Listen to me, I sound like a bitter, old English teacher. So, anyway Mike, how's your information gathering going? Ready to take the plunge and join the rest of us "crazies" building and flying Pietenpols? Bill C. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 06, 2008 11:28 AM Subject: RE: Pietenpol-List: ribs and ailerons If I may, I believe this is a case of "It's not WHAT you say, it is HOW you say it." Email is not the best way to comunicate as it were...no tone, no emotion, body language, etc. It is easy to "read into" and misread what is being said. My opinion, nothing more. ________________________________________________________________________________
Subject: fuselage weight
Date: Aug 06, 2008
OK, how come nobody raised the BS flag on me when I posted that my bare fuselage weighed 33 lbs??? The more I thought about it, I realized that it could not possibly be right, but I KNEW I weighed it correctly. Well, my wife just asked me why our bathroom scale was set on kg instead of lbs . . . DOH!!!! I don't know how to reset the scale, but somehow I must have. A quick google converts 33.6 kg into 74.0 lbs, which sounds much more reasonable. And there I thought I was losing a lot of weight on my beer and pizza diet. Damn. Gene ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: fuselage weight
Date: Aug 06, 2008
Gene, Sounds like you need to keep a scientist handy to think in metric for you. :) Actually, I said 'hmmm...." when I saw your post, but I said to myself, 'this is Gene talking, so that weight MUST be right' - Damn! you've disappointed me! My fuse weighs in right at about the same as yours IN POUNDS. Kip On Aug 6, 2008, at 12:16 PM, Gene Rambo wrote: > OK, how come nobody raised the BS flag on me when I posted that my > bare fuselage weighed 33 lbs??? The more I thought about it, I > realized that it could not possibly be right, but I KNEW I weighed > it correctly. Well, my wife just asked me why our bathroom scale > was set on kg instead of lbs . . DOH!!!! > > I don't know how to reset the scale, but somehow I must have. A > quick google converts 33.6 kg into 74.0 lbs, which sounds much more > reasonable. > > And there I thought I was losing a lot of weight on my beer and > pizza diet. > > Damn. > > Gene > > ________________________________________________________________________________
Date: Aug 06, 2008
Bill, I had to throw my 2cents into it.. Al "Listen to me: I sound like a bitter, old English teacher". ________________________________________________________________________________
Date: Aug 06, 2008
Good catch, Al. I knew there was something wrong there, and I couldn't put my finger on it. Oh, by the way, you only need one period at the end of a sentence. (Gotcha!) Bill _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of ALAN LYSCARS Sent: Wednesday, August 06, 2008 12:31 PM Subject: Re: Pietenpol-List: ribs and ailerons Bill, I had to throw my 2cents into it.. Al "Listen to me: I sound like a bitter, old English teacher". ________________________________________________________________________________
Date: Aug 06, 2008
I took the plunge a few weeks ago. I have the 3 sets of plans from the Piet enpols, I have a plan for the Jenny style gear, I have the 4 book set, (can 't remember authors name at the moment) from the EAA on their way and I hav e the Riblett plan on its way as well.- I hope to begin construction as s oon as the Riblett shows up. I have made 64 cap strips to get started. Once I have the plan, the rib jig and bending jig will be made. - Looking ahead, I am trying to get a plan together for making the spars, (ma terial, method, size...) as well as a list of metals that will need to be p urchased. As always, the Corvair engine is being tossed around as an option and all the things I need to find out about that. - With the making of the rib jig, the bending jig,-gussets, and building th e ribs themselves, I will be quite busy once I get the plan. CAN'T WAIT! (s houting) 8^) ________________________________________________________________________________
Date: Aug 06, 2008
. . . and the period goes inside the quotations. gotcha ----- Original Message ----- From: Bill Church<mailto:eng(at)canadianrogers.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 12:41 PM Subject: RE: Pietenpol-List: ribs and ailerons Good catch, Al. I knew there was something wrong there, and I couldn't put my finger on it. Oh, by the way, you only need one period at the end of a sentence. (Gotcha!) Bill ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of ALAN LYSCARS Sent: Wednesday, August 06, 2008 12:31 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: ribs and ailerons Bill, I had to throw my 2cents into it.. Al "Listen to me: I sound like a bitter, old English teacher". href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: Wing Spars
Date: Aug 06, 2008
I've got a Piet project which came with material for the spars (3 piece wing). The Guy obviously intended to glue up spar blanks from a thinner piece of web material and cap strips added to both sides of the main piece top and bottom. The grain run-out on the cap strips (if that is what they are called) do not have very good grain characteristics. I'm thinking to just scrap the material and buy solid spar blanks of the correct dimension. I'm also wondering if it is worth the effort to rout out the areas between the ribs as detailed in the plans. Second question - Did we resolve the motorcycle wheel issue? Have they been used successfully? What about the size? The plans show 24 inches but I see some folks are using different sizes. Bob ________________________________________________________________________________
Date: Aug 06, 2008
That sounds like a plunge. Good to hear that you are making progress. Time never seems to pass as slowly as it does during the time between the moment you decide to build a Pietenpol and the time you can actually start to build. There's always lots of planning, and many different ways to solve every challenge. That's half the fun of a project like this. Enjoy the journey. Bill C. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 06, 2008 12:59 PM Subject: RE: Pietenpol-List: ribs and ailerons I took the plunge a few weeks ago. I have the 3 sets of plans from the Pietenpols, I have a plan for the Jenny style gear, I have the 4 book set, (can't remember authors name at the moment) from the EAA on their way and I have the Riblett plan on its way as well. I hope to begin construction as soon as the Riblett shows up. I have made 64 cap strips to get started. Once I have the plan, the rib jig and bending jig will be made. Looking ahead, I am trying to get a plan together for making the spars, (material, method, size...) as well as a list of metals that will need to be purchased. As always, the Corvair engine is being tossed around as an option and all the things I need to find out about that. With the making of the rib jig, the bending jig, gussets, and building the ribs themselves, I will be quite busy once I get the plan. CAN'T WAIT! (shouting) 8^) ________________________________________________________________________________
Date: Aug 06, 2008
SSB3YXMgYSBsaXR0bGUgYmFmZmxlZCB0b28uICBJIGhhdmUgbmV2ZXIgd2VpZ2hlZCBvdXIgZnVz ZSwgYnV0IEkgd2FzIHByZXR0eSBzdXJlIGl0IHdhcyBtdWNoICBtb3JlIHRoYW4gMzNsYnMuICBJ IHdhcyBnb2luZyB0byBtYWtlIGEgdHJpcCBvdXQgdG8gdGhlIGhhbmdhciB0aGlzIHdlZWtlbmQg anVzdCB0byB3ZWlnaCBpdC4gIEkgZmVlbCBiZXR0ZXIgbm93LiAgSSB0aGluayBJJ2xsIHdhaXQg dGlsbCBpdHMgYSBsaXR0bGUgY29vbGVyLiAgIA0KDQoNCkplcmVteSBpbiBEYWxsYXMgDQpTZW50 IHZpYSBCbGFja0JlcnJ5IGZyb20gVC1Nb2JpbGUNCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0t LS0NCkZyb206IEtpcCBhbmQgQmV0aCBHYXJkbmVyIDxraXBhbmRiZXRoQGVhcnRobGluay5uZXQ+ DQoNCkRhdGU6IFdlZCwgNiBBdWcgMjAwOCAxMjoyNjowMSANClRvOiA8cGlldGVucG9sLWxpc3RA bWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDogZnVzZWxhZ2Ugd2Vp Z2h0DQoNCg0KDQo ________________________________________________________________________________
Date: Aug 06, 2008
Nope. And that wasn't a sentence...only a thought. Al ----- Original Message ----- From: Gene Rambo To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 1:09 PM Subject: Re: Pietenpol-List: ribs and ailerons . . . and the period goes inside the quotations. gotcha ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 12:41 PM Subject: RE: Pietenpol-List: ribs and ailerons Good catch, Al. I knew there was something wrong there, and I couldn't put my finger on it. Oh, by the way, you only need one period at the end of a sentence. (Gotcha!) Bill ------------------------------------------------------------------------- --- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of ALAN LYSCARS Sent: Wednesday, August 06, 2008 12:31 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: ribs and ailerons Bill, I had to throw my 2cents into it.. Al "Listen to me: I sound like a bitter, old English teacher". href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c title=
http://www.matronics.com/Navigator?Pietenpol-List href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Aug 06, 2008
Gene, I stand corrected. As much as I find it conversationally awkward, the period DOES go inside the quotation marks. Al AP Stylebook 2008 ----- Original Message ----- From: Gene Rambo To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 1:09 PM Subject: Re: Pietenpol-List: ribs and ailerons . . . and the period goes inside the quotations. gotcha ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 12:41 PM Subject: RE: Pietenpol-List: ribs and ailerons Good catch, Al. I knew there was something wrong there, and I couldn't put my finger on it. Oh, by the way, you only need one period at the end of a sentence. (Gotcha!) Bill ------------------------------------------------------------------------- --- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of ALAN LYSCARS Sent: Wednesday, August 06, 2008 12:31 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: ribs and ailerons Bill, I had to throw my 2cents into it.. Al "Listen to me: I sound like a bitter, old English teacher". href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c title=http://www.matronics.com/Navigator?Pietenpol-List href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Aug 06, 2008
I have always thought it was awkward too, that is why I noticed it. ----- Original Message ----- From: ALAN LYSCARS<mailto:alyscars(at)verizon.net> To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 1:36 PM Subject: Re: Pietenpol-List: ribs and ailerons Gene, I stand corrected. As much as I find it conversationally awkward, the period DOES go inside the quotation marks. Al AP Stylebook 2008 ----- Original Message ----- From: Gene Rambo<mailto:generambo(at)msn.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 1:09 PM Subject: Re: Pietenpol-List: ribs and ailerons . . . and the period goes inside the quotations. gotcha ----- Original Message ----- From: Bill Church<mailto:eng(at)canadianrogers.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 12:41 PM Subject: RE: Pietenpol-List: ribs and ailerons Good catch, Al. I knew there was something wrong there, and I couldn't put my finger on it. Oh, by the way, you only need one period at the end of a sentence. (Gotcha!) Bill ------------------------------------------------------------------------- - From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of ALAN LYSCARS Sent: Wednesday, August 06, 2008 12:31 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: ribs and ailerons Bill, I had to throw my 2cents into it.. Al "Listen to me: I sound like a bitter, old English teacher". href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c title=http://www.matronics.com/Navigator?Pietenpol-List href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: Re: Wing Spars
Date: Aug 06, 2008
You could just order new capstrip material if the main web is OK. I priced ordering it all to build up an I beam like you describe, and I priced full size spars. Full size was cheaper. I think the built up would be great and probably stronger. One thing I could never find any guidance on is whether it would be acceptable to splice the capstrips and use shorter pieces to buld them up. I can think of no reason why not, as long as any splices are staggered. For what it is worth, it just cost me $1100 (shipping included) for four 15 foot 1x4.75 spars and enough spar material for the ailerons and aileron false spars. All from Wicks, shipped within two weeks of ordering, shipping took two days to get here (VA). I know it is expensive, but I figured this was the one place not to scrimp. I plan on my little boy flying this, and I never want to have to wonder. I am making the one piece wing, and I am routing the spars, for one reason, because it makes the center splice easier. (I can explain why if anyone is seriously planning on building one-piece wing) ----- Original Message ----- From: Robert Gow<mailto:rgow(at)avionicsdesign.ca> To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 1:12 PM Subject: Pietenpol-List: Wing Spars I've got a Piet project which came with material for the spars (3 piece wing). The Guy obviously intended to glue up spar blanks from a thinner piece of web material and cap strips added to both sides of the main piece top and bottom. The grain run-out on the cap strips (if that is what they are called) do not have very good grain characteristics. I'm thinking to just scrap the material and buy solid spar blanks of the correct dimension. I'm also wondering if it is worth the effort to rout out the areas between the ribs as detailed in the plans. Second question - Did we resolve the motorcycle wheel issue? Have they been used successfully? What about the size? The plans show 24 inches but I see some folks are using different sizes. Bob
Date: Aug 06, 2008
Gene, How are you planning to cut the taper for your spar splices? I made a "ramp" type affair for my router to ride on, and it worked pretty good. I can dig up some pictures if you need it. Dan Helsper Poplar Grove, IL. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (
http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Date: Aug 06, 2008
Ben, Where in Minnesota are you located? Contact me off list and we'll see if we can arrange a project visit. Greg Cardinal Minneapolis
Ben,
Greg Cardinal
Minneapolis
Subject: intercom
Date: Aug 06, 2008
Here's a re-post from an earlier post on this subject by Walt Evans. I haven't tried it yet. I have a portable intercom, I think it's an older PS Engineering unit. works OK but it's very easy to open the mic if you turn your head or lift your head up out of the protection of the windscreen. I have yet to try my brother's intercom set... he flies a trike, which is completely open, and his intercoms are integral to the flight helmets. My headsets are Pacific Coast Avionics with the foam muff on the mic (knockoff of David Clarks) and work great. Here's Walt's tip: Got a great idea from somebody, and the cost is free! Get the plastic 35mm film containers. Cut an "X" in the lid and slide it on the mic arm. Then wrap some foam around the mic and slide on the 35mm can after you have drilled a 1/4" hole in the side. Line up the hole with your mouth. Better than sliced bread. Just keep the hole tight against your mouth to keep out engine noise. My engine noise keeps my intercom open, but makes for a pleasant ride with me as the tour guide. walt evans NX140DL Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 06, 2008
Hey Oscar, I'll top that,,, Look here, and you'll see my 35mm film case on the rear mike. http://www.youtube.com/watch?v=CLrIDeDLR48 But if you look at the last few seconds of this vid, you'll see the front mic. The plastic container from a prize from the vending machine, at the local diner. Hey, if it ain't broke,,,don't fix it. AIN'T LIFE GRAND walt evans NX140DL ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Wednesday, August 06, 2008 3:58 PM Subject: Pietenpol-List: intercom > > > Here's a re-post from an earlier post on this subject by Walt Evans. I > haven't tried it yet. I have a portable intercom, I think it's an older > PS Engineering unit. works OK but it's very easy to open the mic if you > turn your head or lift your head up out of the protection of the > windscreen. I have yet to try my brother's intercom set... he flies a > trike, which is completely open, and his intercoms are integral to the > flight helmets. My headsets are Pacific Coast Avionics with the foam muff > on the mic (knockoff of David Clarks) and work great. > > Here's Walt's tip: > > Got a great idea from somebody, and the cost is free! Get the plastic 35mm > film containers. Cut an "X" in the lid and slide it on the mic arm. Then > wrap some foam around the mic and slide on the 35mm can after you have > drilled a 1/4" hole in the side. Line up the hole with your mouth. Better > than sliced bread. Just keep the hole tight against your mouth to keep out > engine noise. > My engine noise keeps my intercom open, but makes for a pleasant ride with > me as the tour guide. > walt evans > NX140DL > > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Date: Aug 06, 2008
Subject: my progress
Afternoon group, Well I went down stairs and touched the glue to see if it was hard enough for me to pull the rib out of this and its still drying but it was good enough for me to take so that was # 12 for me. later, MN Ben ________________________________________________________________________________
Date: Aug 06, 2008
Gene, I did the same thing with my scales. I found a switch near the battery that changes it from lb to kg. Don't know how I tripped it but I did. As you said, it does make a difference. The other Gene ----- Original Message ----- From: Gene Rambo To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 11:16 AM Subject: Pietenpol-List: fuselage weight OK, how come nobody raised the BS flag on me when I posted that my bare fuselage weighed 33 lbs??? The more I thought about it, I realized that it could not possibly be right, but I KNEW I weighed it correctly. Well, my wife just asked me why our bathroom scale was set on kg instead of lbs . . DOH!!!! I don't know how to reset the scale, but somehow I must have. A quick google converts 33.6 kg into 74.0 lbs, which sounds much more reasonable. And there I thought I was losing a lot of weight on my beer and pizza diet. Damn. Gene ------------------------------------------------------------------------- ----- Checked by AVG. 7/22/2008 4:05 PM ________________________________________________________________________________
Date: Aug 06, 2008
Subject: Re: turnbuckles
I have to agree with Mike on this one. I've bought all my turnbuckles from B&B. I bought 6 at Oshkosh last week for $8 each, ($3 for the barrel and $2.50 for the ends. They still add up to one of the most expensive hardware investments in the project, but I didn't think I could come up with a home-made alternative that would be any cheaper if you considered the time involved at all. I've enjoyed some of the ideas for alternatives presented so far. Some of you guys are a lot more creative than I am. (But I'm a lot more creative than I was 4 years ago when I started) Ben Charvet Mims, Fl Cuy, Michael D. (GRC-RXD0)[ASRC] wrote: > > *B&B* *Aircraft* Supplies - This is a mom and pop shop with a whole > warehouse full of new *aircraft* parts. Nice people and great prices. > Check here before you go elsewhere. No website, so you need to call or > fax your order. Phone - 913-884-5930. Fax 913-84-6533. > > > > Many of you on the list know this to be the most cost effective place > to purchase brass turnbuckles but the point was driven home > > again when I visited them at Oshkosh. No frills, no web site, but > excellent prices on turnbuckles if you want to cut to the chase > > and speed up your process. > > > > > > * > > > * ________________________________________________________________________________
Date: Aug 06, 2008
Subject: Auto Gas in an A-65 (with ethanol)
Well, my last source of ethanol free auto gas seems to have switched over. Right now I'm switching over to 100 LL in my Baby Ace. Anybody out there been brave enough to try the gas/ethanol mix in a small continental in a low and slow airplane? Ben Charvet Mims, Fl ________________________________________________________________________________
From: Marc Davis <marcs_listreading(at)hotmail.com>
Date: Aug 06, 2008
Here in Oregon the car gas has ethanol in it. This ethanol is mixed in as the truck is loaded with fuel at the distributor. If you have a large tank (300 gal.) they will deliver ethanol free gas at about the same as the loca l stations are charging. Marc> Date: Wed=2C 6 Aug 2008 21:18:38 -0400> From: bcharvet(at)bellsouth.net> To: pietenpol-list(at)matronics.com> Subject: Pietenpol-List: Auto Gas in an charvet(at)bellsouth.net>> > Well=2C my last source of ethanol free auto gas s eems to have switched > over. Right now I'm switching over to 100 LL in my Baby Ace. Anybody > out there been brave enough to try the gas/ethanol mix in a small > continental in a low and slow airplane? > > Ben Charvet> Mims ===========> > > _________________________________________________________________ Get more from your digital life. Find out how. http://www.windowslive.com/default.html?ocid=TXT_TAGLM_WL_Home2_082008 ________________________________________________________________________________
Subject: The work has started.
Date: Aug 06, 2008
I've started working on my 'new' piet. Here's the list so far: elevators w ill have to be rebuiltnew tail brace wiresLower lingering replace for the l ast 25'Move seat back back a few inchesbuild new motor mount For those of you with a short fuselage and a C65=2C how long a mount did you build and did you have to move the wing back? Marc _________________________________________________________________ Your PC=2C mobile phone=2C and online services work together like never bef ore. /9j/4AAQSkZJRgABAAEASABIAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAwICQsJCAwLCgsODQwPEyAUExEREyccHRcgLigwMC0oLCwzOUk+MzZFNywsQFdARUxOUlNSMT1a YFlQYElQUk8BDQ4OExATJRQUJU80LDRPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAcICWAMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/AOSnMqSFQSPTBrmcI9jdSbKFzfXMbbRM4HcZqlShvYhyexTDZJ3H3zWtuxKZ ZtFBXjpSYF0DC8VIxw7UAOC5FIC1EhKKcUwJvL/cnjtSAueUPs0TeopvYRHcp/o5PtmlYC3MPliP qopgRTjDxn0cVL3KW5FrKEzNinJhEPBwA8TWGf8AnpiqhuEj2mtDMKAKuojNjOB3Q01uTLZmNbwT tYxoAXjJz7isasW5GTu1oL80DL1BxwcVCViNiGeUJu8sbSRzu9aq1y0zE1FvM1tWdRl4X6fQVqze PU8+iAMTAjIEv9Ky6FvoWWRfL6D8qQjMf6citEMr3Q+UU0JldaZJp2Fos9s7MSCrcYqGNEs+nm3V WVt2RnpSZSZSmi3rkdRQnYbQxDlRngg1Qrh1PPGTSFc0LPTHuiVjYHBwaQcxeXw/J3akHMP/ALAC jmWjQOYBosS9ZR+dDsHMB0q2HWVf++qLoOYBp1oBkzJj/eoug5ivd2tnHbSGOZWYDgA01YOa5Y8O afb3NjPJNCrsHwCw9hVtsSKF5HHBLiNAoJ6LxUIq7WxXlV/LzISW6jPcUwu3uVPwpgQysd5Apolk bFmNMDpPCsBSKe4PX7o/z+VedjZXaidVBaNmqeBXAdIA4FIBM80xik0WEN+nFHqAhcjrzTsgIVnM hkXoA3FauHKkxJjiagZga7NuuIos8Lyfqa9LCxtFyOOvK7K+zzJTjpmuowFkiMe3JzmkM2ZNVtja lBu37NvT2qUM58g1YgwaAHAGgBcYHWkAmDTAMUAdbp3iKxtdPhgcPvjXHC98VNhanNXLi6vJZFH3 2LDNUMpuMMaaEMbpQIsx28hjDBOKQ0Sx2crD5UxikVoL9in/ALlILjBbSk4CmmIDYzf3DTuAj20q YBQ0gFFrLj7hpjN27XEwPtUSBdTnJmMkrM3rVrREkAOJKYFy2YKxUdD0qWM0EOVqRkgHAoAeuAKQ FqKVRAoxzmgCZJAYyKOgmXYjmwi9uKroD3Ipebf8KkCds/Z4Af7vB9qbDqNuB8qn/aFIa3G6sMTf lRLYqG5B4Wbb4jsT/wBNh/Oqp7ike11oZhQBBejdayj1Q01uKWxX0ck2Sg9uBRLcmGxJfSxwoGki Mi9CQM4qHYcrHOzyR/asocI2SFbsKkyMnUwf7ZtXUdUfj8BV9jaGxwCD5ZfaX/Gs2W+hZI/dmpQG U/DYrQZDc/cFMTKy0xG5pIH2ST6/0qGBoTqCsQP9ypAx54WjLPj5N2M0ykyqyYbctNA0Mx0PuKZB 2dj4RkuIWuEu5IFbBYBv1rnlVSdmjL2ivYjufCrpYtdf2q+M4VWBy3OOOeaSrJvYvmSVyjN4S1aM x7i370ZUZOTWvPFPlsO/UsyeBNWWx+1iSJlxkjzMEe3PetWklcXMluZQ8MaszYW0dyf7pzQrPYXP HoMufDWr2xYSWFwMDJ+QkUWsVzIoGyuY8M9vIo9SpFCC6Os8LAJpczEZBlP/AKCKGNGHqjf6T+NQ imLeAfZUz94DimCMwjFFyiuw3SYHWq2IJrdQOOC45A9aBHV6chh0uJXwHf5mrx68uao2d9OPLFDz WNjUM0WAbnmiwBmnYQ3NAxC1NIRHwM8Cq1AY7BRVJXA5e4kM1279ctxXrU48sEjzpu8iwjFCSKdx pGsNIeeFHaTDEZximJWIxo/yZ3tn2XikMbJpIUr87c/7NAiWPRFYAmUj8KQXHPoaqBiUnPtTC49N AU/8tj+VAXEm0ERrkTEn6UBcRNAJzmXH4UBcbLoOxSfN6c9KAGR6O6DzBKOmeRRcDEb77fWqEMfH 60CNK0mb5InXHpSYGgnGeKQwLYBJoAjhIxn3oAlzQBFJzKg9KAJelAE+q/Kmc4OCKl9Bo5qQYkz7 1aCxCcg57GmSTjOBtwMikUXbdiI1OckjmoYy2rZUUAOHSkBKn+roGSRtigDQtWBs1HoafQlj2H7g j2NDAndd1hbn/Z60PYOpDOSIvmHIIIPrSAfri4kU+qg0SKhuZ/h0BPENm3/Tdf51UHsEke4VoZhQ BFcjNtL/ALp/lTQnsZ+n3CQ6WrMTxkcUqjsRF+6ULi4aQsodwh/vVijNlZogwLY3kAkk9qpDRlah zqFmT1w44+lX2NobHAqOLn/rp/jWZp0LP8JqRGQ3U1oMiufuD60xMrAcmmI3NH/49Zf97+lQwNGQ fLF/u0gKlwm6wlyP+Wn9KYGVtCoaQ+hF3H+8Kok9CSRGKyXJ8hVQfKq8Nxxx71xzbu3Y5WveZbtm sJZkmZ0eHBBgwQVPbAqIS5d0Vtub+G1LTWkSF4pYMFJDx09PwpRjOV5djR35DBF20UvnyF3m83LD PB4/KtoN7tnIn3NK18RGDzZZLWPdwAE4OPWtlVZpGpboR3fiqe5IWGNY4zwd3OfalKTZMqsmVPEV 7bf8ItPHEV85lG5h1zmtIWsOEldJHP8AhrA0eQ/9NW/9BFWzr6nOamR9pyTgA1CRbK73DyjZ1QCn YEQjNIotWdj5kEtwy/KKGxKxDbWzveRY6FgOKU5KMW2KKuzrLlVRgiDAUYrxL31PQRBTGIeKBid6 YhM0AITinYY0mmhDCadhFS+l8u3c98YFb0o3kjObtG5zyDMo+temcJaHf61DL6HYoCsKAD+EUyEK o/digZG/LgUhioDgUCHOPmQe9MCyiADpTEQXP8I96AJAMZpARXJxbt70DK8x2WzH0Q/yoA47uaoQ zb86j1NAG8I1JTjkYpDRIoOOKQA4+Q/SgBkYwo4oAcOKAGDm4+goAkJ5NAFnUIoVQMnzkkgc5zSk Ujnbj5dvHQVSEyAfNEQe3SmIfH0HtwaQy7CQFAPUCoYywjjFAiUNxQMfE37s/WlYCRGoAtWkv7kj 3oBloODCR9aZJZjcHTYOOhIpvYGMuJIxavk87QaTGLrMscsdvJETtMQzn1pSKjuZWlSCLWbZ2OFW ZST6c0Q3Kke3C8ttwQXEW49BvGa2MLof58WCRKmB1+YcUBdDJ5I/s8vzLgKc89OKAexh+HXFxo0k oIZt54zkcVM9SLWiV7sBFEm4IhIBz0yazRCLCRlbEjyjlTjOe3am2M528cjUrQMOdzcE89K0WtjW D0OF/juh/wBNP8azNHsSg/u/wpCMtupq0BDc/wCrHHemDKw6mmI3dGGLSX/e/pUMDSkwFh/3aQFa 4H+gy/8AXT+lMDIP3SKVhkOclB/tCqJO8MTC3jZ0OO2e9czjqccnqRW7RrIDtAIOc5pOKBNmjpmq Txys13LNJERjYp60lHl2NHPQWFjO6RQwmUkn5D/P8KpK5jvoit9ivJGdoh/qeXHoKcUFiBo/kYMx Ric5PTFGwmSzwpLYtbSSbY5MHOK2iranRCktyKztIrS1MEUxKFi2SO5FW2b2KE/h+0lYO9y+R14o ukMpatpFvY2gmhlZizbcEcUmxow+/pSKNawvM6VNZlsAg4z2NLW5JLokYmnJHCoMk471zYqfLC3c 1oq7L7ncT3rzUdgzpTENJpgJTSAQ0ANJpoBhNMBrGqQGXqsuAsY+prtw8epzVn0MqDmZfrXWc5bQ D5fdhUFdDsY1woyc8UyBcYQUhkZGJPoKBj1HAoEKB++Qe2afQRZHTFMCvMP3sY96AJQODmgCveDE IHvQBWv/AJbKY+iUIZx7dKYgjG64jHvQBvoMNSBD1Hy0ihkvEZpANUfKM+lACgcUxDIuZ2PpQDH9 aAKdou+XDyOoHOQai9jWxBexlJFBJKnOCaqLJaKij5gOw9Kskc67OnOBSBjmbJGCRnmkNibmHRjT AeHb+8fzpAKruucOw/GkA8TyDo7fnRYCVLmRPuyMPxpDsiwt7MBgSNikOyJ4L6cRiIOducgVLKUU y95VxJ5aSOfnB44qVK7sOUOVFae7JARpWZYxgYUcVdmZXsVXfJLD9aEW9UJFeSZxmqI5UT/bpVGA f1ouHIhTqE2Dhjz15PNLUXIixZtqUo2W0crKey5AqlFsOWJ0Nh4ev5VDX87Rp18tXJNVyJCsjQ1i BLLTgbeSdTuGSZWOf1oaQWRzZnmiull3szLyCxJxkVKbQ7KxXNrH85wcudx56mhgNaFFU9enHNId jEbqatARXP8Aqx9aBMrAcmmI39DUNayA561IzSKbgv8AsjApBYrzwgIIgMq7bjzQS2RPp8DxN5Ks CATndnmgZhqvzR5/vCmI7jzTJGqkeXkZB7VyydmcbWpVC75EyxBdu/FNBY1oLWS2Yu28Jj5grDJF Mlmho9nDPcO8tw0WIyEVSc/U+tNNLRijYqTNJpt5gu0sZ6t61EtdhEV1crMytMjBTkJgDBqY6BYL lhuyowuOnpXZHY747EIORx2NMobjcWpWAz/ExI0+Bexf+lJlI5bHNAysZXR228ZNVYg7DRkEeipL j5pBzj615WMl76idlFWjcG71zmww59aYDSaYhtMQlMY0mmIjJp2AYxqkhGHfP5s7nPA4FejSXLE4 6jvIgtxiYVqyEXLcbpYlxwXFQU9jsW+RTgdqZCBQdoz1pDI3+830oGPUcCmhCgfvx7LQIs9BVAV5 Bm4T6ZpAS4+WgCteDiMerUAZ2vu0dg+04BIB+lCGcoHyfwpiJbQZvI/rQBthhk/SkMlHC1IEdxxH TGCjigQUDIbY5ZzTESjtQBXhglWRS8ThRyRis2a3JL+Pedy87QCPpSi7A0ZLLh/l4x1rVEWHyIx2 svzY7UkwaF8p3wdvPei47DDG+cbeaBCrFJ/doEL5Tk4CmgBPIlz900ASpDK2cITikUTJBL/cNKw7 lyzhc5k8ssqnmolFspSSJ55rhJo5gjhQe3pRGFhSlcrTrwJjbyosgOCD1q9jOxHOpGFXPSpW5o07 F7wrpKarqPk3G9IwpbK9a1SRB3EXg3TE5KO/1ar5UK5eg8P6bb/ctI8j1GaYrl5YY4lwiKoHYDFA hHHFIZleJow2iXB/ugEe3NRIZxzMWaIsB88fb2qRi5ApgRTlVGWOODipAwj16VaAiuOYx9aAKw60 EnQ6EP8ARX/3v6UhmiqsF+br7UgIZ1PRerfpTJaLVtEBGoxwQf5UirHKyLtuVX0kx+tBJ2xi/cfM VzjG0nmuZ76HHLcrtZTm2jldkaDcQAGGQad0hqSSJba4zN5aDyk+67HmkS0iwkxEW7j7x5wc0O5F h1xcNcpkj5QMcnpU20KTS3HLFLdNbwyR87SY9vcUuoluNnR0lKMMAYAruVuU7Y7CIoHtQWOCABiK AMfxOMWdv/vn+VSykcx3oGUypLtVdCTuVi+y6daW/dUBP1rwpy55tnfFWViBqEURmqSENp2AaRTA aTimIjLGqsIYWH0qrCuRyN8vFXCN3YUnZGHcKFkLL0716KOJ7jLfmQ/Shgi/YjN5Av8AtipKex2T qCD9KokTGMVIELfeagZKB0oQgT/XN7CmInY+1MCDH+kj2WgCcfdFAFa7/wBbEPxoAyfEoY2QAPG7 mmh9Dlk75oAajFZMqSMd6BE4nl/vtQNEwupgMeYcVIxWu5iMM+RTABeTDo36UABvZv7w/KgViNLm WNiVbrQFh/22X1FAWO3vEzDnA6VD2GtzDvrXMbOhAxzg1mpamqMSWNgxCjH41qmQ0OKsVGegxQBb t0YDLDnAFSx2FdfnzigQnemI6jTNFtJrOGZ0Ys4yfmrOTaNkkaCaNYp0t1P1zUOTKsuxitBGjsAi jnHAqbsLITy19KLvuFkJt2gheAewp3fcLICARg9PSldhZdhcDaAeg6D0ouFkMOB2H5UJgbXhRlS+ ZjhRtx0963o7mdTRHajpXSYC0wGNSAY3UCkMrX8Yms54iOGQrSaA85LkR247oxQ1kMlDUxjJkSX7 /OOlArGK4G4/WmiiK5BEY+tAmVR1NMk6LQxiybPGW/pSKNBR1x0pAKV+TjqTTEWIlJZFHHBNIZyl 4oW/A/6aA0IlnaTx+Zbl4UOVTdhVPGOuTXLfocclqVEkiSENDIxMg+dPQ007EtK+hJaMnnorACTc MA9KpsTNK51HzoFtZn2pGxxtUZqXJ7BdvQz442kk2xJIQBmpSJNRNNvnsGuDCUhRc5JwcVfs21ct Re5UuGRCgLYJAxXStEdkdhizR/KN469KdyhTNHzhhx70wMzxSVaxtCpzlmP8qllROXI5pFDtFtvt erW8RHBfLfQcn+VZYifJSbCCvI62/ffcPjoOBXjR2O4qNVgMNWhDDQAhpgRsapCGNxVIkiY1aEUr yXYowcGumiru5lUZlu5b6Dmuo52PtR8zH2pMEaejpnU4eO+akqR1zDg/hVEA3GKljIGH3vqKGMeB yKEIWMfM59wKYEtMREATO59BigCwOABTAqz83aewpDMbxKxEEYHdjTQHMH5QfyoEEMbux2KTigaJ hBJ08tvypDH+TIo5jb8qQDShB5Uj8KBjSD6GmIQjFADaAFFAHo1wubYfSpewdTLlTMUgI6qa53ub RMB4gWUkYPrWqYNDHUmLAOecD60yWXY14LHrwPyFAEcg5oQmRdDQI9A0OEnQbSQ9wf51nJamyaNF Y8pgVBRzN3DtnkGcfMagCDaBTAYQKAGkCgBOKAEwPSgDf8LJiRnx/EFrpo7GNQ61N3JJGO1dBiOP FMBCOKQiI/ezQMgmbhh9aQHm9+vlXlzH0xMGH41iWh3O7g0AD8ZoGYz8MfrVIGQ3OfL/ABpiZWXr QSdFoi5scn+8aTKNEDikAv8AdHvTAt2y5mA9EoEcnqHyaiOP41NSuomdb9sY8pGYwVwUB4NcltTk lJvQqvHmVxCPlCFuT0I61SvbUOW5CuVh81pMsTkDHSh72FJWdkWbVHnkB2EiqsTsdnoujONkpxE4 xlXGcitFC5UIOWp00sKSwtE4BRhtI9RW/kdVtLHnmqwRR38qBRtQ4X2FJAiolvH8p2g0xkTQRR7y Ix1zQMztfheSG3WJC3J4A+lTIqJhvaTR53RkVFy+Vmh4Og2y3d2w/wBUm0fU1xY+fuxgaUY63NF+ prgR0kTVYEZNUhDTVAJQAxhTQiJuBWiJIHNWibkF5CiT2/m5w0TPwM+uK7aStE5pu7Mcd61Mya1H Dmkxo2dBXOpxeyk1CKkdORkZ96tkDZO1IogB3f8AfVJiJkHNAAvAJ/2qYE2KaERRgGSQ++KYEx6i kBWfm7PstAzA8Tt80C+xNNCOflAC/U0AXtHQEyH8KTA1EXlfrSGTsMmncZXlUGcDA4FIBdigD5RQ IiuI08pvlH5UACWsWxSUGaYB9lh5/digdzp4LuG9tGaHdgHHIxUJ3LnTlC3MVQVYFQRnHSsGVAxf Lx270XsbWIZogGUhcD2rSD0M5os5UKAOgpkFeU0IRXJ5piO78KXEr6IsbkbY3O31xUS3NUjcgUkj DLUMo57U4il5Kp/vVkNFFkwadmMjYAdx+dNIkYSvqPzp2YXG5T+8B+NFmF0NeWJDzIv507MLo6Pw y6mAPGQ2ZgOPpXRT0RjUep1aglRg4IPNdBkSEdKBDM8ZFAEZFDGVZj8wqQPPvEa+Vqch7MP5GsmW iJXyB9KVhiyHg/SgDIccn600DIrsERj600JlUcGmI6LRT/xLz/vGkxmiuehH4+tIB4UZpiLcA23D egSgDk9V/wCQkuP74/nUoTOleHcsbuNhxg4zzXNscUpdhGhjkZtvEa8EjqfamthJtbky26BMIp2/ 3TQyW2x8cjQ7pAAp24yfSpkxbmnoxm1AtFb3DLMfmCmQgYFKKk3ZFxUuh16Wl6YkL3m2VVwQq/Ka 6eSb1bN+SXc4vUo8XMm47iCct61otDSJXQBUHaqRRE2QxFAIfC26ZBjoDms5msFoZl/G017tTA2j PpisldvQ9ClyqF2WLOBbTTSoABmkLn6V5OIlzVPQmKS2Jkso3jDNnceetYc7WwxjadH2ZxVKqwIz pidpGqvasViM6YO0h/Kq9qwsMOmkdJB+VNVQsPt7TyZd7EMAOlKU7qyAslUPWMflWVmuoDDFCesS /wDfNO8l1AZJbQSY3wo2BtGR0HpVqrUWzJcY9is2k2B/5dY/w4rRYiquouSPYZ/ZFgAdtuFz6E0/ rNXuL2cOxJbWNvazebChVsY5OatYqp3E6cWWd2MDjAqvrdQn2MQZs0/rk+wvYxI9uGyDVfXJdg9g iVXx2q1jH1RPsOzBXAGCM85qvri7C9g+47zl9DVfW4dhexY2N1XdnIyc1SxdMn2UiTzVJ61X1mn3 F7KRGqEyyPxg9OapV6fcHTkYHiC1nmuEMUTsir1AqlWp9xckuxiT2c6qMwuCD/dqlUj3Dkl2Lukx OkT7lIye4o5k+ouVmjGPmWi4WZKaAK55mb2FADyOgpiIbn/Vge9AEwGEQU+gDJHEUTO3QUBa5u2t nd2yPGLaUr1B24zXLCcF1O2vOVVLTYp2WnXo1FpJl2jBAVuM1TtJaMwXu7lZ12s6njDEVmbqzRVn GFx6VpC5nPYQ9BWhmVpT81CEQMSGpgeqaEqyaXauEXDRjPFYS3Ny8Y1Xog59BSAjksoJv9ZCp96Q x62kAGPJTH+7QByvjiFIvsxjRVHI+UYprciRylaEhikFgK5GKadgO48IwFdNs8cFpmY+9bxWxlI6 uJlLMmcN1IrUzJfpRcBjcd+KAGkUwKcww/4ZqQOH8XxbbsNisZaM0iZkB3IppDJZOgoAy5ByTTQy K7/1A+tNbilsUu9Mg6HQW/0R1/26llGoudvzetAD14kX0piLMPNzNkjheKAOb1qL/iYQFRyxHSpR LPSNL8Ox31oftTMjgABVPSs6cE7nPGCdzEv9NNm8kVvukjRyGkA+XOOlTKLT8jOSd9SpIsiqjHK5 9DUWZJntNNc3UlvEF3IeM9xVOCirsuyUbs7nwnpV3Y2wuZIIXlbpkkMBWsYyWqNIRa1R01rcpdI5 UEMhKsp6qfStU7mqaZw+qL/pM2Om80kNFJ12gDPOKoZBkHNAyW1x5kh9F4rKZrT2MqV1+3kHJ4Ar JO2p6EF+7L143KQr2AFeM/ibJReC4UAdqwvcBrCmAw1QCEUwGGhAMIpiExVAJigBCKYCEUCGkUxC YpgIRTsIQigBMUwExii4CUgCmAfhTEFDsAhWlYaYYI6UABDU9hCf8BouAhUen6VXMwGlU9B+VPnl 3CyGmGLP3Rk1SqS7i5UNMEf90VXtZrqLkiRvaxsBlelNV6ncXs49hDAvHXirWImL2cSleopkSLOF +839BW0aspRuwjSV9D1B5Nn8f5V4nP5HTyjBKzHAYn8KpVbCcSZdKknG6SKJV65kQV1R9ra70XmZ SlGJFJoGmZ/fRxyHvtjApe3UdOa4leXQhk0PRduBp6/XzCP5VaxlugezZSl8OaI3WzYf7srCrjjB ezM+78JaTJ/qRcwn1Egb+Yq1jEL2ZtaYY9Os47b95IIxgMQATR9YiyrMtNqFsoywZR7iqVSL2Jeh Tm8UaPADuugSOyqSa1SbJ50Zk3j7S1z5ccsgA64AqvZsXtEY2t6/Fr0MQitZYhGcljyMVSptO7J5 7mGkkJbaZNp7ZFVyMXOhN3zEIruAcEqOKORhzkg8vndKEAGTkdKOUOY2dP8AF0OmW1vAtv5hiyS5 fAOa0TfQhu5JP8Q5zzb20UZPcnJqrsmxdt/iRFtH2iyLEdTG2P0NPmA0YPHWj3CjzfNh74Zc4/Kj mQGta61p16M297C/tuwad0Ikcq06BSCCp6GmM5LxjFmNH71lMqJz1jymKlFFhhxxQBmTDk/WhFMr 3f8AqMY701uTLYqIpPaqISNvQ8hXHTvUMuxtL0FMQMxDKF6mgTFt3b7TNk4O3pQIoX8Z+02L/wC2 P51OzB7HqGmTTyaxdRjYqIozjnnHFKF3JmEL8zLEWk4gmglcSRu/mD5QMN1NWoaWK5dLMpazoTXk kTW6JGcYbsBUyg5NWInTbehw1nZTp4lniK/vMsuPpipkTNe5Y9B0iXUY5/IvIcRgYVxTg5J2ZVNy Tsy7aE/ar75QMOMY7/KKuO7NVuzib4s93KwbA3HIH1pxCJnXJYSHEnboRVFFSV5UjJG059qBovae C8EmVG7aAMVjPV2RtDRGO3OpN7N/KsJaI9OH8Iv22Z74MfUtXlT0RgahrnGMNUIYRTGNNMQ00wGE U0AhpiEpgIaAGmgQlNAJTQhKYCUAIaYCUAJQAuKACquIUCpAMUwDFIYYoATFMBMUhCFRVJCGFaAG laYDdtACFaYyBrWIyGQj5j3zWim0rIafLqj0SwsZbsg7dsfdjXBRozqv3du5c6ip7mwiW1ku2JAX /vGumdWlhlyw1fc5rTqO70RBNKZD8xJ/GuCdadR3kzaMFEgYL6VN2XYheNT3P50XYWIjCnvVczQE TIo4BNNTYiCdkiQu8m1R1JrSLcnZITsjltR1KLUmktreVlCnbuHc16+GoOKvLc5ak+Y5NtKuhclC hYE8sOldtzEuRabDEgwGecnGCMAUXGPniaAEG53DoVSldBbsTQWU1ygW1seAP9Y3GTWM60IbstQk y0mgagwCyzCJfRO9ZvEx6FKkxx8LxH/Wyyk98cVH1p9CvZIB4as1x99vqaf1lh7NA3hy0Yfxj6Gm sQxezRJB4Wsn+V7lol9cZrVV09yZQsR33hfTbYAw6mZSw5G3pWvOnsKFNzMs6O8b4jkaROmcbRT5 olPD1F0LMFnqsJxbOR2+WUkik6kTPkkty5d2l20C/a5ZVJGcO2RmsvaXZ1wp0prfUzLfajuC8gUd 1rZPQ5pR5XYtA4GUuAfZxSJKe9DJ++woz1XkUbF3Ibgr5fXdz2pkuxVc7SMDFMLmzou7zQG/u1K3 G9jZxyPrTJIkc+dle3HNIkWElrmdmAztHSmIhu2wlqxXOxg2PXmoe4+h6vp9mnm/bV+UzIGK+nFU oe9zGahaVzSxWpYYoA5zTbJBrjzkKSXm5xz95ayiveM1udFjFamhStH33N7gcCQD8doqI7slbs4i e1WG5uXBJMjknPbmnEEZ15wxI4plFSWTKYHJFA0aGmZ8vg4b2+lY/bNtomLGc3bnvk1jV6nqJWpI 19KjxvfHtXjVGYF48VmAw0wGGmIYaaAaaoQ000A00AIaYCGgBKYhDQA3FMQUwENADaYBQAYoAOlA gFMBcUgDFABigAxRYAxTC4lAhvemAhFADSKYCYpANIqgEIpgerzyoq+XGMKPSssXiV/DhojKEH8T KjY9K8xs6ERnb6UrlDSBVK4DCq+lGoyNwvpVXEVnaMPswc1aTtcDP1q1+0WToi7z3Ge1dOEqRjP3 jKqm1ocsunpYxlII3mlfBY4OVPoP8a9Z1I3vzGFna1iebStTulVokEIPUOwH6CsXjacXbcr2LZJF 4avZSDdXcaY7opJrOePX2UUqNt2X7Pw7Z2h3KnmSf3pOTXNPFTmWoKOxoeSRwMACsVK4xpib/Jo5 gGtG47frVXQWIpPkBZ8Ko6k1UU27IHoUpLtnB8iLKf8APV+F/wDr10Rpu9pMzcuxWNrNdMBLKQv/ AHyD9B/jW6movljuTyt7llLKOEbUiX3ZqyqTqN2b+40haOwNaKAdrFT6dqhVJI6Y1mjMu9PumnDR vGF98iuiGJSWqMa3vlW/eFIdk/m+cp4XOR9a7ozptXRxSTTKRkaZk+yQSjj5gy9TROpBBGMupoWm nMU3zxAHvvbP6VxTrWdkzZQRJvgjRjDCsxBwRGAatc7VxpdgT+zbiH/SA9rP3VrfcP0NbJW6mbv2 HWen2EqPHJbrI2eJpJDCP++Rk1anFdSeWRdsdDi8w51CNWUcCJQf1J5/KmnETUi1J4eneRfJ1KTa epaIcflTuugtRo8O3sTkpfwt/vpT0ERf2TqUMkjGGOYOOsTj+RpWFYbJpd6bePdauSB0AqJJjPVL Ej7HAOn7tePTitlsInzTAWgDB0uVTrEibskGbj/ga1lHchbm6TxWpZVtsF7lh0MnX14AqI7tiRxl 4R57/wC8acdgRk3gzk0xlQAbiMUDRYtN32lUjXHB+fnr6VlrzGq+EqeSI5ZDtAwcEjoa48VKyOqn OUo2ZsWUfl2yjuea8eTuzQlNJAMNUAw0xDDTAYapCENMBpoAQ0AIaYDTTENNAhKoApAIRTATFMAo EGKACgBQKBC4oGGKADFIQYpgIRQITFMBuOKAExQMQimAmKAEIpgJimB6S2TXkGiGEGkMTYaYDWU+ tO4ET5UE1SQFdy2ARiq5VcBnk4O7HPrRzPYBNjCkAmxuwFO4hPLbvVIQnlsOgpgJ5bjtQA0xuO1M Q0xN/doAqXM/lOIkQyTsMiNev1PoK2hS5tXoiXK2xSnhZcPenzHP3IV+7XRHtDRdyH5kkdtO5Dyj BH3RjhfoKzlOytEpLuWFi2cgEn1NZWYxTu9KpXAiYHuKFdAULqZpJTb24/eAfO2Pu10QhZc0iHK+ iHW9lFCPmXcx5LGpc5NlWSC7uIbOBndCQOwGSauHNJ2iiZWWpRGoaTqEAjulvYmI+YKMCvQjTjT3 Wpk3KWxmtbWMNwfsPnrDjq3Un2onOPVF04TLlulmqB0kcOepIyfzrJyRsk0NZQJmMU4w3PNQ2uhS 8yZVdv4kJ9jRcGPAnQ/L+YNFxWRKLy9T7sko+jGhSkLkgSR6reMwUMWPuoNWpzRLpxJk8QXEPDgf kQapVWtyPYLoy3F4lZgAxIP+y5FCqrqS6DRL/wAJEc5NzOp9mBp8y7i9m10LMfiC4I+TUGH+9GCK fN5i5bdCmLuVJo5or1N8bMykgqcsec0l5Mnkj2NK11293/vpFmU9VWUCi8xOEe5qR+IFji2ixlAx xtINWqjWlg5F0Zyl3c/vWZ0dee46VSn5DVJ9ClK6yLlZD9DVc8Q9nLsQkvhiqgnFPmXRi5WuhJbX jxDd8uQDkHscGo63OinBOOpBb3D3EqxyAKucj3rz8XF7m0VGKsjoOAoAIxXlWfYq4000Aw0wGGqA YaAG45qkIaaYCGgQ00wENMBppgNoEFAhKYwoATFMQYpgAFIBcUAOAoEGKQwxQAYpiDHFADcUAIRQ ITFMBCKBiEUAJimAmKEAYpgei5ryDWwmaAEJ4pgMJoAq3MuFIFawV2AwDI+nFEtwFJxUgJmgQmaY BmqQhKYBTSAKpoRUvLkxDZH/AKw98fdFaQgvilsS30RXjVLCMyv89xLx7mtLOpvokTpHRC2tuWc3 Ex3OelTOd9ENKxbPSsuhQ3imITjFNAVb6cW8DMPvHhfrWtOF5akydiHTLcQWo3DLuS7E9cmqqT5p DSsiwwX2FRG7dkNnMjxc8F3JEtlDJEHKq5yCR+FezBckbI5dZMdc66l3NGZLWPyIzlo0kI3n61Tn ysaptl+PxPYSABtNZcdg4NS6kexSpz6Mc+u6OwIeymGeuFU0e0i+g+Souoz7doEiBWgmT32c/oam 8H0HaohFl8OnP72ZPrE1FqYc1QIbfQnz/wATMqD0DKV/mKFCmNzmuhX1CLTLYqsGoeaz8jYcgD3q JQithwnJ7oqqEzlbxh+BrI2uhw3AjF5E3+9RqxXRLiUgYktW/Kn7wtCRYJ3BPkQuf9k4od+g7W6i fZZ+hs2GPRqLNdBaCeUyH/j3nU+zUX8gs2SiVQvMN2D7YNUpLzJcWLHedfMZ1AHGY+n5U/aW3Bwu TC+iEZHm5cnnqAf1pqpEORokF3bnbv8AKYe2P8KfNELSGNPbyElI0UfX/wCvTvEdmFq1jcXsduSC 7nkZ7CnGOtzOU+VaG5f6bbS2UgEaphTggdK3aTVjn5ne5xBurmJWCTOMV57jF6M3uyaTULuCOGRZ d29MkFehrGFOM24tF3aLmna5Dc5ScrDIPU4DVlUw0oax1LU11NPIPIOR7Vz8ti7pjTRYBuOtUtAG 4oENxTAQ0wGmmAhoENpgGKYhKQwxTAMUAGKBBjFDAUCgBcUALigAxQAYosIMUwGkUgEIoQhCKYxM UAJigBMUAGKoBMUID0DcK8g2sGR60aCsNZgBTHYjZhg0wKRfezcH5T0rZWikIcjDYKzYwLe9AhM+ 9NAJn3piDPvVIAz709hBnimhEF5crawNK3OOAPU9hW0I88rEt2K0a/Z4nu7sgMBuI9KqTc5csRL3 UMtIZLlvtVyuN33E9B2qqr5fcQJX1LxzWNirjTmi2oDSDRZgGCO1WotIlmbdBrnUY4ADsjXe39K3 ScabfcneRdwcdDWCRZFexzCwuHiA37doz6niu3CUtXNmNSWlkcWmjTRyiEyAyFc/KM7fevQTSVzO z2JB4dxgNc4/4BU3iVqhx8PDoLl/rs4p+4F5DT4bbten/vmi8V0HqIPDkg6XjY+hpXj2DUDoUydL 0/kaPdC7RE2nTqWAu923qAtHKuw+dlGWK4Vjs3sf9zFHKgcpD4xqG37n5ik4RBSkSZvh1gB/Cj2a K5pDle772386l00HOx6zT/xW7D6UvZdmVz36AL2aP+CUfjS9mw5kuhKmpSqhcGZcHBGTUukx867D l16ZQAJpQPQ0KnJBzRJBrrnk3B/EUnCfYpOPceuuZ6yxn3Kilyy7D5o9yzDftP8A6vy2HT7mapKQ nbuEyyFWDwqjEcELitoxvujGUrFe3t5bSZbrzUR05yauxky/qHiN5o/IVXVWHzMqnms6nO1aI4pX 1KEYglTiVgT2KGuFxqr7JteJFqKOSEiyyqMDAPNaUYSWskKTXcy5LS5kGNir/vECu2MbGUpMlWK6 to9sd5GmRzhjVOEHuiU2ti9p11fbSGuTIe3GawlhqUuhanNG5ZPcSr++Cfh1rjq4ZR+BG8Zt7lkx v/db8q5/ZTXQvmj3GlGH8JH4UnCS6DuMIpNWAaRQIQ0AJiqsIMUDDFMQYpAGKBhimAYpCHAUwFxQ AYosAYoAMUCExQAhoAbigQYoGIRSATFMQmKADFAxMU0B3Wa8g2DNADWNMZG1MCqTh29Mf1qxDUPy 0PcBSaAEzTEJmgQmaoQZpgJmmI5bxXq/2bUrK2EnlKv7xm/QV6eDp3g5WuYTfvpMiu9WS6UI1yzR Y3YPcjpWsaLhqo6ltwb3LkWujyl33Ue7HIK4rGeH1+EpOPclXXUKgedAx9zip+rrswdu5JHrtsWx JJGvuJAaTw9tri+ZZGpWjKCLqLB6ZcVjKhOPQOZX3JBdwtws8bE+jCmoztawrruUbadP7SnbzF+Y Y6+lb1U1FJomFjQ385BrnuzQmE8f2SQOT+7YOfpXqYRp0n6nPU0kUtPtys888gG+VFY+2c4H5V0X sQzIhJnCO00gc55B6VwSqzTaR1KnFpFgPIpwblz+A/wqFXmV7KIGWUDAlc/VRVqpMXskMMlwrAiY 7f8AcFX7Ri9khsxllXaZsA9wopfWJLoHsV3GL5oJUuh+sdH1lvoHsV3H5kHeA/VKftu6D2fmO+c/ wW5/A0Kshezfcb84P+pgP4kVftUL2bvuPnWZ48RwwoT3DGkqqK9k+4LuHW2jb38z/wCtT9qr6C9m +4jnjAtgp9d/T9KTqjVNjYzIBiSBW9ww/wAKn2vmX7PyHGKEjLWufo4qXUfcfs/IUW8B/wCXT/x4 UlUl3H7PyF+zwoQUtB+JH+Fae1styHS8izAIkUbopI+eiYwKj2serH7OXREjraO25jcenTNP20ej F7OXVDPsdrPLFDF52ZHALEdBWsaqbsRKk0r2NEeGwFy07qvpxmttDK5BLoMR2kXErY6gLjNNNIXK Qy+GbZl3SMy+3P8AjT5l1DlZAPClo5BA787najmQWaHHwtBHnbbg/SX/AOtTaXcdxYtEityQ0TR+ u5+BUygn1Dm1LEWm2zs0cd2CRzhe9ZLDroyva90Xl0tioVpSAvY8UOjLbmF7SPYil0t1k3fbyqAf cxx/OqjDS1xOSbvYh8gO+xb4Bs9CmabgCkluP/s26xxPC3f/AFVS6ZXPHzEfTpx3ttvuhFS6N9rD U4+ZH9gmI+VLVsdSHIqPZLsh80e7FWwdlDeRHg9Cs3B/Sj2C7Bzx7jf7LmJ4gOB6SCj6suwc67h/ ZkuceTL+BU1P1VD5/Ma2nSAgGKYfVM/1oeFFzjzpEoGQ4/FSKn6s+4c4waXOT8rJx6kipeGl0Y+d C/2VdAfcU/RhU+wmHOhp066HPksfpzS9hPsPmRE1tMn3onH/AAE1LpTXQLoaYnHVSPwqeSS6DuNK n0pWAaRSs0AmKBBjigBCKAExRYBMUAJiiwBimAYpoDs815B0C5oARqAImNMCvJw4/EVaEMQ9RTYC k0gGk1SEJmgQmaYhM0wDdQhHn/xBXOrW5H8UOP1Ne1l38N+py1viOcnldX2KxAUY4NeiYkfmyHq7 fnRoMN7d2P50CBKTAXvnuKAGZIPpTAu3rH7Yy5PAUfpQ0B67psUY0y1V0UOI1yGHPSspxi3sUmQX 0UbNHbxYDTsA2D/COaIxS2BskVSs1y+35VHb2FAzzj+07sY8tlUEk9Kjli9zXmaRCNZvC33xx7U/ YQfQj2su53tt4enn8NW+pxzuZpEDFe1YzpRWtjaNVvQwbkXluoLSMBkDp70ezgVzSRZtt0m8Fj8q lv1GP61apRsZyqSTNCKzjIBJb3p+xiL2sihr/mafZGeDDbXAIYdjR7JB7VmANcutu/yoyKl00Upy sNHiKdR/ql/Oh4dPqCrNdDT0vXmvrqOBkWMsQAc1H1WN9xvE2Wx1R0eQnCzKT9Kv6pFdTD693Qkm iXChf3i8+opfVPMaxy7GTpTtql49rF8rIGYknjAOKhYS7NHjElsacmlXMOCSjA8cHpTeDl0EsfT6 ol/s6dYzIQpA9GrJ4Op0ZqsbTZUSTepbYwA9RUfVqpr9YgNMybsD+VTKhW6ItV6fcapEhJVeF5Pt WM6dSGsjSNWEtmWdJnhbUIE3hn3AhQea0o897vYzqyjayOxIEgO7IHbFei7HAroQxBVBC5o2HuMd Fk/h+X6U7haxC0MMZORk9lHFS3Fbhq9jOujqEmRDHBEo7dT+dRKa6FKD6mLLFdPetE8oVgoZtnTN ZOqktDVUrlqCwKAfvHBHc4rKVeZfso9SwnnqeLhumPuik69RB7GDGMkrEq02fqgpLE1FqP2MBFhc OCpiyO5jp/WqgexiWQ92q/LJEQP9il9Zl2D2URkpvJVwRCfwIprFyXQXsF3KscNzDI2I48uMH5jV rGeQnh13LcUM8FnFkDb0Fd0J80bnLKFnYuidkChiQX6cdK0TI5WhzC4MqkMrJ39aeoWRfUXPljCq R9KSuGhWcOARJGAw6YNO4+XsQKPIb52bB7E8UmGhYaMeXvRzhu47VMpqI4xvsLEjFhHHNGWx3GM1 KqQezKcJLckkjuICC7hVzjGMg1blFbslJvYspbl8FgMH2qlZojUkOmxkfwH6qKOVMOZkbaXCfvRR N/wEUnCPYfMU5dEtmJzBGAO4yKh0Y9UUpshHhu2lAxke4NQ8PB9B87MnXNKh0uNXYudxwoqHhYlc 5iIwdQwBANcE4qLsap3QuKgBMUAGKYBigDrwa8k6RQaBATxTAiagCGX/AOvVICIHDGqEBNIBpNNC Gk0wEzTJDNACZpiOH8eL/wATSzY9PKJ/ImvZy5+5I5a26ORJyST3r0jESgBaAFTqaQDu9AAV9KaA uSSRxauskwYxq6swXqRxR1A9SsvFel3NsskfnBOmPKPFY1KkYuzLhTlJaEMOt6bcaqJPtAASLEYK EFiTzx+FUpaCsyxb6jZyQXTpcxbgGYqxwenvSurDs0eXgsGDEYpJaFshHL/jWhke3+HVJ8EWK9CY sfqazq/Aaw+MytX04GyDFesiKeOnzCuVM6XuZZtVguboDr5K8emSf8K6ab9056qsyZWXYiHo1Nyt oQkyn4ni3aDccEEFTz9aoVjioR+7ArKW5utjR1HQ3nt5L6xizFGAJAO7YySPYf41otjF7mEjFGDK SpByCO1UKx3nhrxQJoY7efi5Q4Uk/fH+NNO25zVKet0b82rxQ4811HfBPNU2YqDb0OY8LuIddlcs pLRPtGcZy2aEbST5TpZtQYbf4V3AMufWi7MGn1HPdQg7NxBJ4GDzTKhHUq3XyqaR1mdjLmkMsKBB ZTOOr/KK8nHTvNRR10Fpcp6CoXxLBI/CIhJwK0g1Cim+4pXc7I9FS8tSmcsMdylbqvS7kezmJ58D IzCQE+mCKXtqbV7j5ZXtYi+0Bhg5jTHUDmojVU/JDcOUquFyWXd+Nc1Scd4myT6jMj1rN1Ex2scx 4oQx+ZJGzK5KDcDg45rWi7u1gexyVzqt3bybFuJSAOCWNdfsoyMudoamvXo4Ez/nQ6MRqqOHiDUE YBbl1AFCoRtqJ1Wmauiavd3crCSdiQua561OMFoXGo2jZS8nTOJSc+orm0K5mSx6jcAZJU/UU1FB zsk/tSXuqUOI+csDXX8hInto2C+pNdUK3JHlMZRu7j21xWYH7KAB/t1ccTboS6bkWx4it32+ZbOp H90ir+tIn2Rdj8T2X8Ucq/8AAQf601iYidNj213SZclmdT7oar29MFGS0A6hpNyrq8qBSMAODx+l CrQfUHFolgm0tYPLjuogAOMtim5QkrXEuaLvYifykYGOWJj2KsK4JU3F+7qdampbmqqxzRjzGU8e tegkpR945G3F6D1iZMCNxt44NaJW0RDd9yRt/BXB9qsm5XnR3wQzxEHOV5zRZDvYoardyW1uSDuY 8ZxTGlcoaLrTXQcQxlnjOGV8pz7VFxtEPjeQyQWisu0sSSM57UN6BFaHMxptRQOgFeTV+I6I7DsV mMTFABimAYpgdSGrx0dA4GgBSaAImNAEMhq0Ih3cirACaQDCaYhpNAhN1MQZpgJmmI47x+MS2kg/ uOv8v8a9bL3pJHNW3RxteoYBQAZoAcn3qQC96aAdQBLfjM+4fxKp/Shgje8NEtp0iejmuDFL3kdm Hfula8H3x0IB6VtF7EdGLpertB+7nOUPf0q5wu7oiE1szaltIruLeAM9iO9TzWZu4Joxbiy2PtI2 sPStEzncbM9b8ISrJ4NtFVgXjUqQD0OTSnrGwQ0kM1UubWGPs1wgP55/pXLJWdjpjrqcxfPKNcuk QAh1VQD7AZ/nWtLaxnV+IsJEZJkHYcU5K7REXZDvEFs0mh3h2MQqA5x71bIOAjXC4rNm8dj1fRdG +yaLbtncjxB8AdMjJquaSMmkzgfFmgpazG6s1/dPy6Dsf8K0IucyGKMGUkEcgjtQNo07O5E0sQk/ 1m7BPqDxVpkNW2NixikW9DRYDbGXr9DVxtczloTXmu2kKgBwJgOe+DTbRHLcn0rUIr64jZXR2z0H Wi6sNRszTurmJiUWRCynBXPIrM1KUTgueKVxljUTsiiiH+8a8CrPnqtnoQXKkixp8IRIJSAODk/U 12VbKhFGMf4jOh+12MUEqrICSOCTWanSjFpLU15ZtpsrQTrIzbZoyuOADzXLG7VmayLiMAg+cfnV xuiWKBuBJqrX1JegxGilG5Sce4qlbYV2cv4x+SGUA90P862pqzC+hzNro8eoQtK8rqwO3AFazrOm 7JEctzP1DTJNPnG4b4z0cCtYVVURHLYrSQFuVGK0UrbhKDeqLmh3AsbkmQHYwwT/AHazrw546Ewf K9TqgQVDKcg9DXmtWN7j8YUVa2EJimAuKAHAUAGKQCgUABGcAdTSAeBxVWsAuKADbQAAsOhI+lVz tKxNkSpc3Ef3JpF+jGjnl3HZEi6lfL926l/76oU5dxcqJk1vUU6XLH6gGr9vNdSeSIT61ezpsldW HX7oqvrEwUIohh1GaF96qmfpQsTO4OCItVu31Mx+cAvl9NtOWJnJWBQSK2MAAVzb6staCYpDDFAh MUxhihCOjBrxzpHqaBDiaBEbGmBC54q0BXzz9DVAJvzn2pIQ0mmA0tTJE3c1QCbqADNAjk/H4/c2 be7j+Vepl28kc9bocXXrHOJQAooAcn3qQDsfNTQD9lAie4XIib/YA/KmwRseGvliuB7g/pXFiVqj qoPRkMnziRvXNPqikvdMhSDXUcho6bqktk205aL+76fSolBM1hUcToA1veWwZSGB79wax1idOklc bbXl/ok++3lIjY8j+FvY1d1JWMWnFnZadrFvrCWaxHZMsu54yeRhTz9OaxmrO5pBk9h4dj1ci9km aPMkhwvVhuOP5VdKNzKrLU6O00WztR8kW4+rHNdCikZcxF4kgV9AvowAB5LcAe1KfwiW54kqc+lc x1pHuOiASaDYj1t0H/jtdKV4o5ZaSZx+oRbZSrqCoLDn+VAjgtW0cwQpdW4JiOQ6/wB0gkflQ0Um ZaBkKspIIOQfSkNo05r7z9Ndg/l3SEZPTcp6kVSZDRiiJWHMhz64piJbSebTrqOeJsMpyCO9AG1Y 3Ky6vNcsCqSAnJHFSyjXtjHJcqEYHnJCnk1lVm4wbLgryLl7KJrglc4zgV4cVY7jdmi8q2gjxxtH 8q7MV8MImNH4myO/gjFjIQvIXvXNZXVju1sc9o8YW8ZlBGUPGfpW9V+6cxsliO/61zCGNI+OJGH0 JoWg7jLe982Z4lndXj6ru/lXRsk7Gi5ZCXlkLsMsheQyEfNn0rSMnFocoJpoqrbGwYxhNo9PWuic FUWhyax3HSLHcRFXAZT1BrjalBlppmRLp3kuccp2rZVbo2hZkb6eNu4DpVxrW0YpUVLYmsJHtgEO Wiz/AN81VSmpq6Oezi7M2chhuU5B71ztWKExRYBcUgFAoEOApDDFAABl8DtStqA8CqaEhQKVgFxQ AmKADFABtoEIRwB60mMCPSqaQhuKkYmKAExRYAxQAmKADbTAMUIDcBrxzoJFNADiaQiNjVAQueDV IRWLcmrSAQtRYBpNMQ0mgQ3PNUhC5oAM0Acz48GdNt29Jf6V6WX/ABswrbHD165zBQAtACp94UAT L9+hAyUD2qrEkxXdCntkUMDR0ZvLiuf93NctdXaOii9GLIm1WB61le7udFrIwicMcV2LY4mOBzTE WrK6ktJN8Z47qehqXFPcqM3HY6aC6jv7bcq8Dhl9652nE64yU0MMMtjIs9q7Lj+Jeq01K+jIcOXV HdeB/EKXQSzm2xPHEFHP3znr9auCszGWup2gIArYzMvxAXl065ghbazRMS2PujFRPYcdzxXGDiuU 7EeyeHbuGHw5p7TyLHmEfeOK6k0oo5JfEY+qCKVppEIaMNuDKeDQthHPiIzRyxAcCUjHswB/xpgY Gq6DJaZniQm3J5/2TWctNjaLutTIlt9o6fL/ACpRncco2Gw2QYHBbd2GK0TMWiBYTI/ldCxxj0NM R1H2ZBCkf91QMimK5d0q2htJGuCfmCHbXn46fu8qOmgtbl+1mgdUTAL9eleYou50t2NW7uFlECDn YmD9c11YiXNJeRnSVh+ooPskmOmw/wAq5W3zI7Vsczpny3B/3TXTPY5maRNYCGE0AYV7BJ9skmjJ Ugggj6V1wmuWzKUXujX0LW0kIhuwFlHAbs3/ANeplFxd1sWpX3N+aCK5i2t06/SiM3umJow73Tpb Q+YmSh7/AONdKaqLUwknHYqiQONrDB9K5503BjUiNl2gDtUo6IzvoQSIUO5e/atac2nYc4KSuSWk 204H3e6+laOClqjlkrMvggjI6Vk1YQ4CkAuKQC4oADU2AIhwT6miK6gyQCqEOAoAMUrAGKLAGKLA FABt3MB6UW1sHQcFFJjQ4RKe1TcYv2ZT0yKXMFhDaHsaOYLDTat2o5gsMNu47U7oVhhjYdQaq6AT bjtTA1FavHOklU0CHk0hEbGqAhkPWmhFR2w1apaCE3ZpWAaTQA0mqEJuoELupgJmgDnvG/OkR+0w /ka78B/EZhW2OGr2TmCgAoAVeDQBKr8gkdKBFyIowGGGfeqTJJ1X5CPxqguWbEbVmHTKj+dc9ZbG 1F7li4XErelccWdr2MG4jMUhHYmu5bHA9yEHFUIsRHIoA2dIlMVtcYwOQayqI2ptpGla3omXyz8r /wA6ylGxtGdxs9syHzbc7WHJAP8AKiMujFOHY3tE8cXNlD5N6GmCjCt3+hqrNfCzJ26nQDxFbnS5 hNKrTyoxYjpkjoPYUnOVrWFyo8zY/NxWR0HqHhnVtOPh2zhumQsiFWVgD3NbxkrWsc84+8RvJabL m0tdojJDoFHqatEW1GWOkyi7kRgEE0YKlv8AZP8AgaoGdBbaPbx27RSKJQww24cGi1xJnFeJvBjW jPcWK77Y8lO6f/WrnqQcdUdFKalozAgsREowOvU+lYRrXdjolSsrmVd6XLZ3QkXJizkH3rrjO+hx zhZ6GlZQ3Nz0+VfUiqszOyNe4XyLJIjjLGvJxU26lux20laJFpnErt6DArB7GjNJW5H1qE3uwW5q 3ozZy7v7pq7Xep0HLWXE30WtJbGLLhNZogaWxTAhaDeGPrSvbQ3h8Jkxx4nXj+L+tdPNoZyOktr5 4DtPKVnYmM7GzBNHcRAggg8EVrGZbV9inqfhtthubP5k6mMdVru5eZXORySdjCIK8NXLUpW1iXGQ wxHbvIynQH0rFJ2udUKl9CF0w25eCKuM7DnBSRYglYduO4roaU1c45LlZbXBGRWLVgFxUPQBelIB rdDUvRDJUTaoA9K0S0EOAoEOxQAYosAYpWAMUgDFIBFHLGhbtj8h6DmkxkyioGSAUhi4pAOUUhjt tIBhUVQhjRqewpq6AjRq842J0NICTPFAiNjTAhkNUhFSU81ohDc4FDAaWoAaTTEJmnYBc02IM0gM PxiN2jH2kU/zrtwP8UxrfCcJivaOUKAF4oAUGgCRVOQB3oAtrZHbwearlZPMOSCaMnnjFFmF0yxY SSmUo4OCO/1FZVPh1NKfxGlcHMprhjojvZlXJjfcjHBBr0IyvFHnSTUmZrDa2KAJojimgZpWrhYZ fcVNRFwGiQ5BBI5zU2GmbNlcGaFd45B61lJG8J9xbi2E4ZkAVx+tTGVipRTKqTzW+YyWCjjBrXm0 MHHUjJB5FYS0OhGpZTMLZQGxjtXRT+E5qvxFizvzb6jA+9gwdRweMZ5rQzR1g1Z4Lu0ctkCUo2fQ g/1AqTVpHQR65a4+dwpqrmbjYvpLDcxna6upGDzR5E+aPP7iBBdXEaoFVJSo+lePiaUqcuaJ62Hq qceVkLwrjaygrnj2rSjW5vUirS5dixZRDcUP3l5x6iu1T0OKUHcytUm3TkA8KMCvH1lJs7ErJIXT eIS3qama1AuK3zD60JX0EtzcvlxYy/7tCWtzoucpb8Sfga1lsZMn3VCIELUxMvSRqj4AyFABH4c0 VklI6KXwmIE/fZ9DWiZnIuE0zIfBdSW7ZjOB3HrQNSsdloWrx3yeWSBKOxPJrvoVeb3WYVYL4kU/ EGjxMTNDhGbr6VdS0dQp+8rHNDfAxhdTj+6f6VlZPYtpxdyN4h1HK1zTi47HRTqXVmRx5R2PboBS hNwNKkFNE6P3X8RXXZVFocLThoycHiueUeXcaYhNQxjQpZgOmTU2voMthcCtrEXHbaLDDGKVgDFI AxQAYpWAMYFJghVTCDnmktIgPRPapZRIFNSxi4NFgHqPWk0A8EVNhhRYAIoGRsKoRTjavOsalhGq QJc8UARsaoCvK2KaQirM3FaoTGbqAELUWAaTTEGaYhc07AGaQGV4oXfolx/s4P6iurB6VUZVfhPP 69w5BaACgBR1oAuIOVPvSW43saSD5RXQjAdjrQBJBgNn0rnr/AbUfjJScgE9+a4D0EUJ7NJGZwSC a9CnH3UcFR2mylLZup4OabRKYxPkOCKgpFlHKow9aTGtB0ZzyRmhjRqWEoMSoQR8/P0pWHc6nU4o iYJYgF3xjIHrXL1OhSsY11CJjgjDetUnYpq6MySNomwetafEjL4RJ7llt1RSRjNEE1oKTT1KlpcF LgtIzE7fl571sjFnWXN0Hw5JwWVxj8DTFcbNeHDcknHrRYC5aatJbqwV2GcHrTFcdby/bdRmWF97 FgwQHk8c1lNX0ZpCXK7o13spljLPEwA4JxxXj1qMqUuaOx6tGtGorMrNGQccgjow7VtSqqorGdSn ysw9UgkhkLMCVPepdPkZF7k9mdtug6cVzyXvATq3zL9aGtBLc6G7ybOUf7BrGB1NHKLw1dUtUc7H bqggfbfPcIPfJq4K8kJl+EtLucnqTUVviOmlpEzXXDsfeqRlIQtWpkMLUAOhnkgkWSJirKcgimm1 sB1uleJIL2IW2oDa54344NdUK6kuWRk6bi7xJ9SsYZU8t1DDGYpF4I/xpzlyehpFc5y9zby2T7XG UPRh0NRGanoEoOOxCwA5HT0rOcLbG1OpfRiD5cEHntUxk4PQ0nBT3LCybl469xXXpUWhxOLg7MTd XLJcujKJLYb5foKUdWDL4St7GYbaVgGMGHVTUMocilh0ppXEO2YpNAN280hgykgAdScVnPRDRN5J Bxih6DRMsNQ2UiTyuOlTcY0x0CGMmKY7DQOaLCHhakYpoQDGGcAck1QGLFKeK4GjUuRS1DQE4k4p AMdxVIRXkbrVpAVZDxVpEsiVuKbVgAmgBM07CDNMBQaBC5pMCjro3aRdD/YrfDfxURU+E4KS3ZUD gZBr3jjIKAFFADh0oAuJ90fhUrcb2NJPuiuowHUCHDPIHU4/nWFb4TWl8RYkHCj0Febc9MhIxxXp UdYHnVtJleUZqmQiJ7bzFyv3hUtDTsNEZ28dfSsL2dmbpXQ3ymXlSQvf2q0S9CSO4kfBjU9euelD C5rQ3V9LaxyeYWUErtY8isna5ortEv2yU/6yL5h/EKVkXFtCnbMvtUJ2NWrrUhTT5Lh/LRcj1rRy VjF02OuPC84KmAlmPAX1ohUu7EyhZXFuGmtFWGZSk0S7WU9iOK3MQt5muJQgGWk457UXAfdLLZvJ HI+4YGBjpQncGrGYJ2h1iCRXaPcuCynBoYkeueG76FPDwNzIWjDMq7zksKh2asxq6d0ZPnQXE0gi yFB4B9K8KvB0Z+6e1RmqsdRHhSVTDMMqeldVKoqiszCrTcXdGRdwNaNj+DsazqUnFmaZCkm6RR7i s3G6GtzrrsFbWVWByFPFc6i4vU6L3Whx8nyjNdb2MZEe+psQS2zlWZx6YrWmrMmResWPljHTNc1V e8ddJe6RyJyx7cmqT1MJGeWrosZjS1KwCbqdgLVh/wAfG7sozV01eRMtNjbtdVePEUzEw5zj0rSS 08hwaRpP5c8XZ429a5pe6+aJ0rVamPd6a0QLRAsnp3WuynUUlZnNODTujOdTH2yvY1FSlbVGlOr0 YR/Xn1rOM+R6G0oc6LChZFyODXT7tRHFJODsy/p0I2N65yaiNPlZLdy75WO1aWEHl0rAWIkUEHaO KaASddzFsAfShgV2QioaGM2VnIpDoot8qqB05rBu7sXYvpBk5IpSdxpEywD0rNjHeT7UhjGgouBE 8GKdxEDREdqpBYYODRYQjUWGMjGZR7c1UV71hM52JuK4pI2LcTVkwLIPFSIjc1SQitK1WgK7sa0Q iEOc9cc1YhfM9qmwB5lOwChxRYCQGiwgzSAqavzpd0ByfLNbYf8AiIifws5SzjadCFx8ozivacrM 5lG+xDdaa+C8WCe4FVcTRm8g81RI4UAW4vuD6VPUfQ04vuCupGDHUxDl6gj1FYVvhNaXxIsMcgV5 iPTZE/Br0KGsDgxC94ryH0rRmSFt2yeKENksyCLEmOD1FZVYXWhdKdnqKYt43KPlrGM7e6zdxv7x FHD9nY7RlSc/SruZll5DHDjgAnNQ1dlrRCxXIA60NAMMrK+VOPX3rNm6N3w3IJLk+m3pWNV6G9LU 6Z4eA0fIH6VEKlhVKXY5jxFpNxI8l3ETIWJZwevPeuyNW25xyp32Odt5XgdXU/MhyK2UkzNwaJ7u /kvZHeYfMfTpTVuhDuVIFhkuka4cgIMrj1oegJG3a+II7YCIl2TPc8VDLSRJeamy3KSw/uyOQBXn Tj7STudkJcmx0Wk6jHqMWRgOv3l7g1wyhKi7ndGcakS48STqY5hkHoa7qdVVFqclSm4MwLuzksbt OpiLjDfjRKFmZnoOsW6SWkhBwwQnPrxW9alFq5nSm07HnN2dkX41yLY3kU/MosQSxyYjPuataEs1 NLYNEfY1y1k7nXR+EfjIf6Gl1MZGIWrrMxu6gBN9OwFuzcgMc9eKqmupEifzK0JLNlqD2rcHKd1r GcOY1hO25vWtzFcrvQ/UVk3Z66HStVoRto5umkNtjcozs7GuyjNyfKzmrRUdTEntnhkZSpVl6qe1 VOlfYKdW2jIwcEEHFc6k4M6XFTRbtrpo3Vl49R611xkpo4pwcGbkE6TpleD3HpRYgcaQDlI+lADh igY1k4pMBgiyQKxkUi5ZQBHd9ucDFc8dJNlvZIshMdqgZKiCmkJsfsFPlFca0dJxGmRPH7VDVirk DxUICpLFg5rRMCBgauxJJbBAsjFQT0FaUktWyZHHW78CuCSOi5diasGgLStxUgMkPFAis5rRICB2 q0IgJw5FadBATRYBM07CAGnYB6mpEPBpWAjuAHgkRuQVNaU3yzTE9mcfFqkacGEpj+6a9rlZzKaR cS8QgNlwD3K5qdi1Z6lW4t7a5feJAjd8cVSk0S4pkJ0t/wDlnIrU1NEuDHrZzRrhlourhyvsXIgQ oBGDXTGSsYOLHdqq5NiNpcMoUjryayqaqxcFqXGYbRXmpa2PTIJxIxBQhRjuK68Onaxx4jdFV1lH 8YP4VtqYEljneQVxz1pxBlm6OYiF6DqacgjuUdO1DyXaKTlCflPoa46tPm1R006ltGajwkYwTg/p SpzUtGVODWpXvP8Aj2z3BqyDPWYiqsJMug7kU+orCW50LYnt7p7Z1kjcqwPBojFSVmKUnF3R2eha 7FeqIpCEuPTs30rirUpU3fodlKsprXc2JIt4Oz5W6ketKFRpWYVKXVHNa54aF0Gns1CT916Bv/r1 1U6nL6HLOF9tzi5Wmt5TFMpVl4KsOa60k1dHM5NaMt2jQqyC6tg6S/dweRUzUkroqDg3qXzoljMV eOaSME9H5ArD21tGb+wT+FjrvRrvcXjKSr22moi49ypQkuhTtXvdNuhMsboU68cEU501ONmTCbg7 nc6XqEGqWwePhh95O4NeTKEqEz0IzVSJaCLMVinUMNwwTXoU6iqbHLOm4nValGPsMz/xeWRXbVXu nDB+8eW6odtvnp81efHU7JGT5nvV8pBKJflAp2EbOjOfs7H/AGq5a251UVoXYDmUfWsWZS3Obmf9 9J/vH+ddyWhmR76dhBvosMtQy7YgMY71a0RDHiX3piHCSkMsW109vIHQ4Pp61nKKluVGTidVoGqJ LcBshX242+tOjeErsuo1ONja1Owt9SjUnCTnhXx+hr0E1JXOSzicbqWmy2szJIpVh+RrKdNM2p1X EqBueRgjtXI26bOzSoixbTPGwKtg/wA664SU0cU4chrQ3IkXPQ+lKWhBIJBSuMlWSlcY8NUthYmi HfFYzkWkX7RNtoSertSpaUnJ9SZfGSBazsVckC1aiS2OxVWENIqbDGlalxGmRstZtFJlaaMYoRRR mXbnitb6EgkbLCoII3HNbU0+XUhvU4O2fgVxTR0GhC1c8kCLatxWbGNdqaQiu5rRCK7HmrSEQueQ fetEIM0WATNMABoAeppCJBS3AbkEeuaLWYjz24UpcSr6MR+te9H4UcT3LOnag1o21xviPVT/ADqZ 0+ZGkKnKzdNvb3kIeLBHZh/WuZSlB2Z0Sgpq6M+fT2H+rYqwrpUkzncXErLc3NudjyMCOxpuKYlK SLkF3I6AkL9SKpU0xOq0TrOrcGMH9Kfs30YvarqhshtlK70YZPBAzik4yiVGUGTb4nwFk591xXNZ I6E77MPLYnhlYexrWnUUUZ1KbkyOS3k/un8q09rFmXsZIZGjo2MYpqSJcWSXb4tWCdquT00ISdzn u/PBqCzd0m8MsPlyH7vANclWnyvmidVKXMrMuTxZGHGQauE+ZETg4mLcxNA+D93PBrUz2LsP+pjP tWEtzph8JFdsV249TVUzOoEMzoQwJUjoRWjSa1IjdO6Oy8N+KPMKW2osN/RJfX2NedXoOPvQ2O+l WurS3OvZVlAPQ9iO9c0ZtFygYeu+HrfVoyWxHcr0cD/PFdtKpbVHNUhc4y602ewlSKYbDH90+vvX Q6tzH2dhLvUP+Jf9nL7pN+SfbFSo63KvYzodQubY/up3Uemabpxe6BVpx2ZrWXii4C4uIo5h9MGs 3R5fhZqq9/iRq2GvaYs4l8lraTuQMg1jUpzkrWuawnTTvsdJZ3dvfxiS3lWRQQDjqK81KVKaOpuM 0djc/PYSZ/uc/lXvt3geKlaZ5Rrp22hwMfOK4YLU65bGCJPetmiLj/NpWFc6DQGzZtyPvVxV1aR2 UfhL8JxIW7KaztexjLc5SaUNM7L0LEj8674rQyGeZTsA4PSsBMJMACgQ8SUWGPV6QEqPUgTxTNE6 ujFWHQikwOx8PeJI5isF9tRxja/ZjW9Kok7MiaudJf20d3CFaMSKfTqPcV2vUwT5TkNX0SbT38wf NGejgdPrWU6fNubQqW2MYu0XDfhXG4SpSujsTjUViZJ2XHPNdMZKaOWUHBl+CcSDIPPcVnJWEWEa s+Ydi1FUORSRdXCx/WuapKyuXE09myKJfQZrrceWnFGCd5NjgoqbDHBapE3FxTAaVpWHcCtJoEyN lrNotMidOKixVzPuowcD1OKpbDZPNFtKr2VcV3JWSRieW2z9K8+aOhGjA9c0kUi4jcVk0MHNCEQO a0Qiu5rRCIpDxVoQzdVWAM0CHLnHTNAEyJ68UcoGfqd+sbfZoDmVvvEfwiumlTv7z2M5S6FizfNs nsMVz1NJFROL1JduoXA6fOa9in8COR7larEW9Pv5LKTK8ofvL61E4KaLhNxZ0cU0V3EJI2BH6iuZ N03ZnVZVFdEV1aR3CENgMOjCt0+xzSjZmWYWt5NhzntnvWqZm0SpMegAwKrnJ5R5dHYIw5xnPahy uK1i4gBHSuCWkmejH4UMuisTnDgr69K6KDWpz1k7KxTNy2fkcgeua1aTMVKS6k0N7LkAvn61Ps4s v2skWnm2xM/loxAzgiiVKy3BVnfVGd/adrJxNZgf7pqOSS2ZXPHqiWG40858vzIs9flotLqNOHQ0 EbfENrq6HoSMVjaKkbO7W4G2Dr+8jEi+xrTniZOmyJ4NqgJGVUdB6VDV9UXF2VmQPZzT/cjcgHqB Ti7ClqAtPL4dSPrQ5hykyqqrkKSKXMPlOi0DxDJZlYLvLW/ZjyV/+tXJVo9YnRCdtGdnGyTorRsH UjhhXNFuBo0mivqOmR38DRXEYK9nHY10xlfVGbVtDzjxJo1xpco3JugPSRen/wCuuqnJM55xMF62 RiySAfJ+NTLcpbEwqSjS0K+msdRheJsB3CuD0IJrKpBTWppCbiz22Zv3Dp/0zJrXpYw+0efwxJLc GNwCOa4obnW9jK16OK1bEtohVz8sqD+ddCTRLcTCIgZhskK59R0q9CeVdzc0UCO2IDBvm6iuOsrs 6qOiNEHCEk4rnUbsymcezYY/WvStYwEDUWA2dG09L0MXyQPQ1x16rg9DWMUy7JoihjsLAVl9ZZXI MGiNj75H1FH1nyFyCHRZh911NV9ZQchHHYXB3bVyFO04NU6sRcox1aJ9rjBqk09SbD0agLHWeGfE b26+ReMWhBwHJyV/+tXTRrW0exlOFzsGZZ0VlCywuMEdeK7U09UY2sc5rfhzary2q5j67O6/Sk4p lxnY5WSN4SRjI/lXLKm4O8TrjUU/dkPRijAqcHt71cWpqxlODgX7e8BHI571hOm0JM0IbuI4ycGu aUZI0ujRt3SVkRWByaxcW2ojbsmajsDIcHgcV1VJe9bsYxWg9DQmDRJVkAaLgNJouMaTSuOw01Ny hrdKljRVSISXkYIyByaqnHmmkE3aI+cbmYjpXZLchbHj9s/SuOaNkaULVyyRaLsbcVi0McxpAQua tIkgc1ohETGrQiIHHHpVgKTQACaSPsGX9auyYnoR32obLGZoxtkVeM1pCneSIlLQ52wVjMHcklhk k967qlkrHOtzpLA/uiPQ15lXc6YnNeIITHqTnGA4DCvRw8r00c81ZmaBzityBehxQBbsJ2tyzDIP HHrUTjzFRk47G7b3KzxZXr/d9Kw1gzp0qRuhZYlkUbuvY+lbRaZhKNjKuomt5dxHynvWiM7ChzI/ ygBccCjYDSj+7XDU0kztpu8UUtT/ANSPY1rS3IrbGUWYHrXQcpLE5FFx2L8E7EFSODxipcmUoIlW ztGHzxfkaz9oaezHf2daAcb1/Gj2q6h7JrYtwIkUKohJUcAmsZau5aVkPXAbGMChIY28leMBkLAZ xTSVw5mixp+u31sgjWNHjHPzJzSlSvrcqNXyNKLxRERi501H9SDWbhPoyuaD6E41Pw/df6+zeE9y P/rUrVFug9zuSDTfDN0f3V+YyegY4x+dCnJdBcpueH9LXT5R5GoxXFs3WPI/MelZvkk7sbcrWR0E tuhX5GbB7EUOCXwslTfVGfeafHPA8Uy7on4KsOKpRe5bknoed+JfB01grXNjma36lR95P8a6adTo zGdPqjm412oBVt6kJWHikMntP+PmLPTeP50nsM96nwLKZh/zzOPyqvssyXxHBafA9ze7I/vbSa8+ PNf3Tu93qU9esrh5milXEa967qeq1Oebtsc4NKeQuImLBT12nFD0JNHTbaW3hMTjndnIrCpBtnVS mki9qRASGNAVJX5/etIUYpK5zzm7nMTXXmxiMxoCOjAc1bZKIkGSAKhu2pSNjTLi40W8HmxnYfvK e4rkqKFaOm5pFOJ3dmsF9brNAQVYflXlTTi7M3uiRrIelTcCJ7UL2pqQFS2tdkPI5Yk/rVylcVjn dSjLam8aDJzgCu6k7QuzOS1IHjeFtrjaeuKtST1RNrE8R2x/U1cdES9zZ0TXJtNbaSXgPVCenuK0 hVcGS4XO7sL6G+gEsLhlP5j613wmpbHPKNjL1jQ470tNakJKOGUjANU0NS7nH3EMlvI0bKVYHBVh WMoW1RvGfR7DR8qbkPzZpp8ysxSjZ6Escm7pnNclSHKNO5d0+Rkuw4YjYCaimk5phK6Rci1KZDyc 80Sgm7gnY07HUvPk2FcGs37mo9zTD0+cmwpenzBYaWqeYdhpelzDsJuo5h2I5HpXGkJZcSyyN0UY rpw/xORnV6IDW7A8Xt3xWE0aI0oH6VyyRaL8TdK55IY8mkkBEx5q0SQuatARMatARH731q0hBnig LgCKLCGyxo6ncMjFa0209CJWsUo9PkE48pSw7KByK64yVV2MXHlVy/axvGXDKRiuevQlDcunNSMb xSn7yGT1BFaYR6NE1UYag5GK7TInjjGfmOKAJ/kX7vJpDHpK0Th4z07UpRUtxxk47GtZ3S3SnjDD qBXPyuD0OlSU0STRq67WXKmtlIwlGxTXTnSQmM/L1ANXcixZSNkOGHPtXJVXvHVSdola9QmFsDpT puzCqrxMzySx6da6eZHLysngswTzUuZSiyz9m2EbSam90WlYdkp3BqDS9hRPz0zS5R85Kso24JxR yiuO8zOBuyaErBcld9yKPQ8ihL3hPYbIzQnhTtNaWuSnYryPzgcZ9aWoxYlU5yM0nfoOye5YG3j5 R9ajXqVbsWbGL7RcxxKxQscZHaok0lexcYu9kzqbPTL60lWSHUXYD+CRmwa5J1aclZqxsqU4+Z0a SuyD94yP6BsislK+zK5V2JjG7D5WVuOjoDXSovozF2M29sYPLZn0q1uCByFG0mqvLoydDlryDw/O xEljdWbjg+WRx+FapVLCvDqYN5ZRRXwGnmWaEEEM64OauztqQ7J6Hra6kslrMmSMxDGexxzWSqqw /ZO9ziIdZOkXS3Yj3qjbXX1U9fxqKcHF3HN3RqarfQ3Tfa7SXzIXUHGK64pIzbdippd06xnbFwX+ tOUVclPQtXkIl2g5Vc8BRiiw7mNqinz/ACwdxXvTA5Yom48svPcUnBhzGloulTX97GsIEiggtg9B WNWEuVpFRkr6npN14fivrAwzIA4HyNjkGvJp0K1NuVjWVSLZyEM154W1AxTAmEnkdiPUVrKmq0ez KTSO2sLmG/t1mgYMpH5VwODTs9x3sPliyOlQ00UmVHixxjFFyjkXG7xCQez13rSkZvcZrPF6R/si nR+EUtwmQKq49K2T0JIQ2KoRe03UrjT5xJbvj1U9G+tVGbg9BOKe53eka1BqcGVOycD5o+/4V6FO oprzOaUXFkGs21pqFq8h+WaPo2OR7Greo1vY46YNaymOQf4H3rL4tjS7joNOVIeNse47U7cytIT0 d0dBodzb3UUqzIgnwBjHX3Fcjpeybl0L5uaxbNhbsfuY+hrl9o0acqJLa0it3LqST71EpuWgKNi2 HqbtDsO8zAp87FyieYPWjmHyiGQetK7Cw0y1SAjeTqaYFi1BFpn++2a7sPpTv3MZayEPWruB4jA3 Spkios0bd8VzyVi0aEL8CuaSLJi3FRYCJziqQiFjWiERMapAROccjtVxWomG6nYQA0xC5zxVpckb kN3dixaXL21yssZG5RxmlTm6b5kVKKkrEMxlku2ndiS5yQOgqqlZ1NyIwUdil4gh82w3jrGc08K+ WVhVNVc5lI3B5jb8q9EwLAHqjj8KQw+Ueo/CiwCjYD97FFgua2hBBO2GBYjpWVW6RpBo11VQTk5G a5VPU2sBVScqRj2q3NWEoiPHxuTGO9Cd2FrFK5QYyKmF7ly2M8OzdFP5V0GI5Wf2FFgvYcTk5LYH pQ2NLqJkdlzSGGH6AYpAIU45agBvyg9zTAeHJ+6DU7DHGRsgyPj6mnr0FoO2hyN2TRdoLIkCCIN2 HFUpCcSvNqAgmMZjLAdxVpKSIcnF2LGm6zbwXkUkisqqcnAzUTp8ysXCrys7qx8TaTMBuuwmem9S K4ZYZnWq6Nm3v7GcYhvbd/pIKy9hJdA9rHubNqBOo2lcgdQc11QjJrU55yUWPl03zFID7TnJx3rf 2LsZ+1KV54btLsBp4lZ/7wODSVOS6i9omZ7+E7KM5WIrjp81DUkNNFi8t9kBKRnBG3j0rPkT1NOd 7GBp9rayzyx3ciRRhuWYZFNfFYl7XIdat7eFjHYyRCHGflGMmtFoJ6oZ4dgcwknBw56GlKaTHGDs as0L70UIWUc5x0qroVmjEvLe4OpSNEmVB7ChvUSWhzN/aTWU22ZcFuR71smrGb0NbwprkOjXDtNC XD4GV6inYk9Jj1uxlRdzNCWxjzFxRoIXV9Itdas9odC4HyOOQDUOnGRSk0cNZXtz4Z1M293BtTOD t6Eeorlng4SdzX2rsd7BJFeWyzwfMjDjFYTwCezBVbEE6BFYtwB1rkll1VPQ2VaPU4e2Uz6+8yDM e4nNaSozjT5balc6uVtaJbUiF5HA4oo03GFmglJXHXD4PpgVXLqIr7xmqsIeppAT287wSK8bFWHQ ii9noDVzpLTVlu7eRJiFmZcZ7NXdRrp+7IxnC2xkTkyykMvYYPpW6SQpNtEShozkjK1WhOqHA7CJ ISVI/Sk4pqzC/Y3dL1QXAEcpAlHf+9Xm18O4PmjsbwmnozSDVxGthd+KQxplxTAYZSTTATefWgQu 73p3AUk7T70N6AaQXZDEnoua9OK5YJHOt2xmKhstHhIbYflPHvW7gmQnYnjvCnUZ+lZyo32ZSnYu w6pEMbty/hWEsNLoWqiLI1S16GZVPvWDw810HzruDX9sek6fnR7GfYOZdyM3UJ6SofxqvZyXQOZd xpmjPRx+dUoPsK6Gs6kdRVKLE2hgkGAc+1VyiDeKqMLu7JkxwcAdamT5ncaViSNhUSQycYIqAGyo HgdWGQR+VXCXI7ikrozRsimaPd09R1r0FKUldEWitGPR0AJaQZ9Kd2FohvU91NTzSHyxsLtQ9RH+ VPmYckR8JjilVgqD3ApSbkrWDlUdUy4txE4AwMVzum10LUl3GkruxGQPalyPaw+ZCgqNxJ56A5q4 QaZMpLoQJHbl8yyyHHYLW3LFMm8miXyrHAUSyKo/2f8A61NtCsyL+z7E5Iu3+mKNOjCz7DZLO2Uj ypgw9SKXKu49V0GG2XtOtHKu4XfYY1mx6TKaOULvsMFlxyysfrRyvoFxptZVPyxqfxo5e4uYiktr o9QR7A1SikJtkS2Fy7gLC7H2GaeyJNMafcptzbyj/gJrJ2NEE0EmOY2GcdjSuUZF9E32ljtIHfit YvQyktSvsJqrk2JmXgKOAKgpicjpxQIktL25t51aCeWMg9Vcim1oNPU9V8IeOEvlWy1NljuAMJKT xJ9fQ0lPoxOPVHYNMAo3Dd7inzdxKNxjFWBOXGal2KSaKu07JE7EEc/Ss0mmaPY4K8uPItLm4PTz FUnHSiK11G9tDHn1TeAPNUitfdM9TpPBwtpLQlpsP5h+XdjNZzWpcXZHUSR7ANjFl9BinaxJTWDy rqZ3B+boKewmcL4vulmvli3RkxA52dvatY3Iduhd8MeGoNa0uWUS7Jg2F54p63JLdjqV34bulsdW iE1kDwWGcfSmB1q2tje2ZudOkaHcu4NC2P0qH5DRn6joF7q1ssM9xE7LykjJhvpmlFvqNpdDC0++ v/Cd8bW8Vmt2PI7fUVoSddfajaXOkzSwyowMZ4zTSA5XwxGmy6Zh0GBmm1qIzFRTeE8/ez1ptBdk s6AnhjS5I9UHM0VzbgHPyn3Io9lDsHPLuPjhB4wF+hrGWFg9i1Wa3HGFkIA5z0965Z4WUdjWNVMV WMZ5GK5ZQa3NU0Xbd15YYLe9bUcRy+7MicL7CnIBUAgmvQWupixrW0ioGXg+lUSRDcrAr8rg5/8A 1UrJqzGbun6gZkCScOO/rXl4jDuD5o7HRTqX0Zcab3rjsbDDLmnYBN9ADlakxEi0rjsTwxl5EX3p x96SQpaI0pRlyfwr1JvU54qyGbayLPBigHeu0h7DGIFMkjLYpiIbgb09x0pomRTPWrIGn2oAc25S OSMjI5oAfG0jEAMevrSsuw1c0UkwAMmsrGl7EpZ2ICbjj0p8q2sCJo7W6f8A2QfU0uTyDmLUVk6j MtxtHtR7JdUHN2JfNjiUqjMT6k1LpwHdkJuZRnDD8ah0olJtFedzIQWC5HcDrVwXIrIUld3Kpz2N a8xHKTRQyHDZxS5g5BW3J96hSDlIyzMMjPPSndIVmwUMOX5ouhKLH71ReQwx3zST7FWGNNnHlyEf Wq9SS4tyykBuhHapaRabJvNUj7yj2qbIrmYNsP8AEv8A31T5ULmaGBc8Aj86XKUpsd5JzwM0lEOc RkI65A+lVyi5xVjU8gGnawrku1mAC5XFK1h8w/lj83XGMmgVze8L+UHk3hSeMVjUub0mjqo2hHJT j1xWF5dzR8pZUQMAfJUj1qlNkuK7itb2LD5rWLPqVFVzaEchGNF0mUkyWMLHOeFFVFkyVthreF9C kO5rKMe2KqyI1RTuvBOhSsNlqyjOSVfFO3YST6nnHizSbfRvEL2truEIQMNxz1qugupmqSOlSVc6 vRPG91p1uIbiL7UB91mfBA9PehDZqj4kuIiP7PTd/v8AFO6JsRy/ERnQD7Aob1D1LsylocrqGrz3 ivFgRws24oO9A7lAUCHK7IcqxU+oOKQFmPUbyMAJdTAD/bNO4Ek2tam8Pl/bJcfWhPUGZcYaNZJ5 H3M3r3rqWpg1Y7LwDrlhplnIt2P30j4QEfLj60E7Hb3EWiaqJJXmikQIVxu/Wq12DzOEgmufDd80 ySltPZ8eXk4NKUAjI7/w3rUesKXgyqLxsbqKnRaINRvivTv7RtCuQCDhTjkGrVgdzz6aO60eLy50 BMyfKexHrQBFompTkSxoyrzkk0MC0jLGxkY8DmmBXt9VW6ujAIipGeSapqxNye8n+zIGZCwzjjtT AHu44/LLBgH6cUgLPmBGaVidqgKOO/U/0q0SKmoWkuQXGfoamVKMt0NTa2JIBDM2YJFOOymuSpgk 9jaOItuTYw65YZ7AnFYRhUou3Q1cozLHnsVIZfmA4FdKaexn1IHh3x+Z90+hqgYW4KyfMpVhyPeo nblfMEU76Gj5h714rS2R2BvpAPDUmMkRqljLkKE1m2Bo2MY87J/hFdGEjzVL9jKq7RLJFdrM0Jtp DPnsuR1NdtjPUiLc0xXGlqYhM8UAQSpzkVSJZGsUjnCox+gouFi6unTyRR5AQrkHd6UrjsW4NOii HzyZPtxSGkWoo7ZD93OPXmjQdiY3CoMRrijmHYabpz/ER9OKXMFhhlz1OaV2OwxpMVIyIyUWABlv u00BYiiVBluTQA8ZY7Y1J9+1FgCS0IOZCD7CnYRG2APlHApNAiJlfqF/OhIdxPLYg5PGKqOjJlsR w+UkaluWHbFKQo2B7g4+RR+NKxVxhkdx8xP4cUWEJimAm0lgQcYqkyWSM5zwx4oY0w8xx/G350rj F+0TdpGH40XAcLy4XpK340AOXUbkD74P1FFwNDTdflsizrHG0pwBlcj8aHG4lKx0SeNZYo+bSEvn 3AxWPska+0Zag8e8jfYoV77H/wDrUvZ2Y+a6HyfES1VikmmyAjurj/CrUETezHRfEXTmcGWxmjAH VSGNDihX0LifEPRDgNHcr77P/r0coXLMfjzQJF2/anjB/vRmnYR5/wCNNRs9T17z7CbzYhEq7gpH P40WshX1MWpKFFADhSAKACgYtAgFIY6gBKAIPJMw2b9qg9Mda6IbGUzu9K8CSX2mRTrOkZK5GRTT ILF18N70R7bS9QjuXyM1WoFO98Ca8lkkKOsyZyUEnf1ouLYig0HxFoxEsNtMGUceX8350DH3nifV xFFbuAGB5ypB/GqTEylrGvS3enrbSqry8Av6D2oXcCtYiO0tQzsATyadgNCwWSS4EjIjAj5FJxto Yijpdqf7YlyOcMfpVy2JW5uPAJEKkA+x70rjK7WyqoD5KjkZ7UAVdSuGislgTJklOWPfFaKy3IY2 3d9LiSN4wskoyGY8fjTSvqIs6ZpT28/2iSUGTnATpzScgSLhsfPukllGNnO0HrSvfRgWooJZLoyS N5cOP9UTuyf6VMqUGVGpJFhoCRhW49K5p4ea+Fm8a0eqGFXTqM/SuCrTq/aOiModAEnauRq25oPV qloZIpqRlmBMkVDdikacKbRWTYMv2g2ozV6GDXuuRzVXqkPJ5rdskKLjPnds4ruIGohPQE0CsPFu 3fA+tFx2Hrbxj7zk+wpXYEgWJfuoPxoAf5h4AOPoKAAsWBGSKAGfMtAAXYdjQABm9DSGh25sdDQM NxHY0AG127UASCADlm/CgCRXRcKooAcFzzIcD0piJ0nIwkQ/pTXkHqNllRf9dMCf7q80+XuLm7FV 7yNf9VGfqaWiFdsge5kY56UgGCQ+XIxJJxiqiKTGgZwTRJCiOqSw6UALkUDGOSCuOMmqRD3HAAUm NAaBiUCExQMXHtQIckEjNlR3p3SQWLa27H77VDmUoX3HqqxsAKlu5aVipdH98/1qlsQ9yuSM0CDP FAiN2wKaEOtlILEjFEhpFgVmUKKBjhQAuaQB3FAC0AFAxaQC0wKs4PmjBI+la02ZzPQdH8byWljD bPbZCgLkelabEG/H49szjfA6+tMRdTxppjdWdfqKANLTdZs9ScpbSbmAyRQBT1/w3BqqGRAIrgdG A6/WjYDmm8D3wYYeEjvRcDdtvCNitmkd1bo8oHLClqAn/CMWMH3YyQOgz0ouBRl0G2hm82KLa47g 1V2FkQyWuNxxgiqTFYzLuLAwP4jiqRJSbS3a4EplBYEcEVVyQ1HTprq5WQMmMYwe1O+gjTtLdo0H mPlick9voKBbFwR/3adgArtIyKAJU6U0A4nA5FJpPcFpsRtDHJ1GKwnh4T6GsasojXsmX7jZFcNX AtfCdEcQnuN8uWM/OhA9cVwzoTj0N1NMv2mMA1xTunZmqNFTxWYMuwnEQFelh3y07HNJe8OrQBBQ B8/gqOi16BncXeR7UWENJpgJuA70AAcUhiiQetADlcUAO80CgYvnZ6AmgNg3v/dNIBQzn+GgB3ze g/GnYLhmQjjFOwhCrAfOf1osHMAmjj6EZ9uaLBcY10T91fzp6IV2M8yR+5+gpczCxLFZTTfdQ/Wo 5kirE7aayDLsB7A0cw7FadVgUnOfaqjqRJ2IQ+8EYwuatqyJTuxp46ZH0qChQ3v+dAC59aB3Hgcd KAEYAlcnAzVImQqkc0mCDr0pFCrET0FPYRMlscc8UnJD5WTpCi9sn3qHJlKKRJvC8AYqS9EMZuOT QBWaZQ2BkkelXYlyIrg5kY1S2Ie5XzSEGeOlOwrkbAkjAzVCLKnI6YNZtF3HCkNDhSGKKAFpAKOt AC0AKKQBTAcBSAIIPPvok6AkdutawJme06PaafdWlu8UEToI+pQZz6VryoxTL50mwPWzh/74FHKh kbaHpr9bKH/vmiyAks9KsrGQyWtukTEYJWiwF2mAgHNAAaAIZFBzQBTmiyDQBnXEALdOKaEYlzD/ AKSE6BBmrJIiVDlc4Yc81SExVUA7sZ9aZJKqDcRnBx+FMCZFfjPb0piH4yR6GmIkCADnrTsAMg4F FhjSAGA7UgH79pxQA5b5QrqeVAz/APWrGrZG1NMqadcMZCX43nOPSvnMRLnm2j0IaI2kYYGK4yy8 pAAx6V6EWkkkYNDt1UpCsOWrTEfO5kr0rGQbyelAhQGPU0DHBF7tQA7CY6UAN2jsTQA4BRRYdx2V H8IosK4olx3ApcoXAOT0z+VFkO7AyBeGNPQVxhuMfdX86YhrTyHocfSi4Dc55JzSGKoyaQInCKAK QyZZFj6YzQ9R7Ep1JguAx/Clyj5itJeM2eTTSJuVpMyEc96pOxL1F8poeHGCeaqT0sKPcM1BQYHc UwDHpQA4Bu2TRYCQwO4AximlYTdyWKzIHJ/OhtDUWTrAie9Q5FKCHjjgcVFy0hCcUANMmKAGF/ag BpOetAxBHzgAZNMRBMCHYHrVrYze5DjJwOtUSSpAf4jimkIftVR8op2EQkkN6VEkUhwqBjhSGOFK wxRQAo60hi0AKKAFFACikMfDIYLqGVeqtVQJktD2Dwg2LF+NpLZx+FdLepikdFQA1jjtmgAD+oNA C7xjNAAWA6nFACb19RQAx8UAQSDigClKMNz0poTMSdA7yP6tgVZJQ2qQ7uu4E8D6VSEwjxx5blM/ wuKpMkmRzHw6YPXcvIpoRbR1YZUhvpTEOA55oAeQCtMBucCi4xpwSKkBStAGZqJjedIF6g7mxXmY 2fKrdTtox0uPi4dceteO9jqNu2bcy1ilqNl8NW/MRYepq0xNEimtUyGfPIUDuK9W5hYQkdjTAMj1 oCwuT2zRcLChWPQGi47DhG30/GlcLClMdWFFw0EJRT3NACeZ2VQKLCuNMjHgmiw7jaBBQAUwFFIB wbA4oGOD8YosAhPuaACgBfwoAktojLMqgd+aqK1E3ZEl+R9pYDoOKJ7ihoiuPYVJRNHA79Biiwrl hLIfxZp6IdmWEhSPtS5hqI/KqOAKlu5SSQzzEJ4OTUjHGgCPpmgCNqQxpHc8UxERnjDbR8xqlFi5 kWvLwBU2GRx5+0gHp2qhXK10f37/AFqlsQ9yWLaq/dA46itVT6kOVh+0N3p8rQcyGsmOlKwFaZSC DUSQ0NBrMocDSAcKQxwNIBRQMWkAoNACg0hjhSAJB8vHUU0B7B4auVbTLYjGSgyfWtoPmVzNqx0U bhhWhA+mAmKADHagBGQN1oAie2Vu5FO4rFaSyfBw+T69MUXCxBdR3Xkp5bBGUc89aLoCuTKsL+bn eM8np+FAGbcAxQkDk4/WqQjOOUYY6KMVaJY9cSptYgZ6U0IURTQZ2ZI9uR+VUiR74B3SIYyf407U wHCV4mAOJB0yeDz/ADpBYuBTtwDQACI460AHl+1MBSOPegZlXqKmpEqOXQE14mYK0kzuoP3SRB8w rzToNS2bDfSojuMuI9UxEqtTTE0TBq2TIaPn3yvU17BziiIDqaYDgFHQUDHbsUCEMnpQFxhdvWgL jDyeaBA3rQADgimhCEUAJQMbQA5RQA7pSAAe2KAHAcigANAxQOM0AKBzxmgC9ZxsFfchAPetI6ES H/ZFkYyOTyelS0hoetuqjgAfSp5uxXKSKAvapbKSSGmT8KQxvm0DIy+eooAFJByBRYTYsLSHPmpt PWqaRKdxsk0cfU5PtU2KuivJdZPyjA9afKLmIyS/JOaYhu3EiY71ZJrEfKKyNFsQxjF2PcU+gFK5 5uH+tWiHuIsxBwRWsZ2M2rliNtwyAa1U09zNxY8Yz1quVPYXM0JOuYzgUnTXKHPqUQeeK4bWOgcD QA4GlYY8UWGKDSAXNIBaBi0gHA0hik8UAdr4N1fzLZom4aIgfhV0octyZu53VnfKwAzWxmaMcqlc 5poQ/ePWmAm8bselADs0ABagCN3FAFadgeKAM24b94idicn6VSEZ983zqAOOpqkIzcqWwflbviqR LJ1VdoBUEDuO1MkkQFhuzx25pgTAlSQw+X+dMBrqJJYhgDb85/pQItqoA96aAdjjNMQhwBSAUKAu RQBj6kyf2kgU5cLggeleTmSWh3Ya9h68EV41zqLdu3FOIy2j0ASh6AJVlp7CseEhGIyeK984x2zH U0gDtTAQrxmgBpH50CG4waAGkUwE7UAIDQIGPpQA2gYozQA4UgHdTQAoWgBV+8BQBKtvI5+VadmB bh08cb2z7CiwFyO1SMfKoB/Wi6Hykqx9sfU+lJtjsQzoCwKngUXBoi39s0muwJ9xrPxxUlkRBNAA AAOtAC5QdaLBcabhV+4M1VibkMkryZy2PpQSVmUZ4qhABjigBQPTIpASAHMZ61QGsvQZ9KyL6EZK iVW9KqwXKUkbSzuVHyk01oSTQ2Qzlv1pOQ1EuxxRxjAGTUcxdjJlZlnbBxzXRGTSMJRTB5nYYyBW jqtkKCRAU9OKyauXsICy9Rmp5R3Hq+faptYdx4NJgPFSMBQAoNIY4GgBQaBjgaQyTTrySwuy8YJy OR61pBoiSOysPEEYwWYqeODW1jO50Vtr0LRFvNHA5pNMZaXWF25Dgj60rBoIl3NMN8TgAtnJPUel NMCyLy5wD8wI4wCDnincQ5tTlRMlCexyuMUASC5JQE8EjOKAGPLn6UwKRbzJXfPCjbj+dMRnXT/O +7IBGAccVaJZWAbdxhl9aZLHKBgFSU+tO4iykbMoJXkHPBp3Aem77o55/GgCSKPLSNngnaPwoAmQ svGBj1prQGh/O09vQimIUnIHrQIbJIqRO/QKCSKaGldnOacpkL3D53SEnntXzOKqOdRtnqQjypIv 9q5SyeI7QBVpaCLKHikxkgNAxwb0pgeLdO9e8cQGgBBQIOBQMaT70AMbHpzQIZye1MBMYoASgQh6 CmACgBRSGLQBJFG7/dU0WAspaEcu2B6UWAtRW6IAVX8TRdIfKTEYPWldlKNiSN1XvSAkEyg4RfxN PQLCM5bg0MCFz71IyFh+Bpp2E1ciZio+ana+wr23GmTgGly2HzEbMSKEhXGHJxVE3DBoGIaQDStM QgXtQAdP60gFJOFwOhqkJ7mgGdwAoPSlbuVcXye7Gp5hqIbcDjiobNFZD4mx3pDJPMFKwjNlU72O O9bpmLRFjmqJExQAYoAQoKAE2EdKVguAYr1FS49h3HhxUWHccGpWGOBoGKKAHCkA5JTFMrDtTWg2 bCS8jgY+ldRgaFoyAHHGRjApAWsL1yQKVhlwNKoXy5So6EZppAXLWa5UndINvNFhEqahdIoR03gd CaAuWbfUhKHDoV2gU7BcifUk3BMkNnFOwrkX2tFVU3De2ST71VhXEaRT95x6daaTE2RCNd37s7T1 yOhFOwiVdy/eXcPVf8KALMG1v9U2D3H/ANamIk3FQzFRkdD70ASxpsjUdTigBxXj3pgKCBkCmSJ0 4AoGV9WjY6ZcBAd2w9KmXwsqHxIydPwLZMelfKT+JnqotCpAk6CtEIkifHBpNDLK1IxwFO4Hiu8d q984RN3vQAu+gYnJoEAGKYCHFIBh6UwG0CEx6UDENMQ5UZugzQBOls38RAFIZYjt0Qjj86NgsWV2 qexHpScilEAQAeBn1JzUlDw+BwfxpgRnceTx+NIB6LQBKKYCnjrQIgklVc5IzQFyu1yD91fxNFie YiLF+pqtg3EwaBWDFAC7aAACgBdtABgUAJ5ZJ+UU0BIlpltzGk7LcaTZYjjjTtmocuxShbcmDADg VDLtYilUuwycD0FNaCaFVCeO1ICTy1Hai4DHlij6cn2ppNibSKZZtxKnGa0S0M2ISGOCgz7UWfQB uz+6fwpp9xWG4FUICKAExQAuKAGFBQA3aw6HNS4hcUSEdRipcWNMeHFTYq5IrVIDJTzTSHc1bZ98 KMPSuqOxky7bvtPWmIvpNllXPvigC2JuQOtKwXLUL7l5osBbV8Ac0ASsxdRtGKoQjQl2j+Rcg53Y polkElukjksOR6GgZEbFX+6zCqTJYgsZYyGSUgDsB2piNFVPakMlEatjcvPqOKYiQQuQAZAVByQR zTAsDigB2fl96ADYD7UCE2/MO1AFheVORnHWhgtDJvbG3s7d5IiUCnv0avMxGDi02tztp1W9CrGw YKR3Ga8VLU6STNUMKYE8MuODSaBFkGpGeG4NfQnCLyBSAXJpgG4igBQ5pAISaAEJPamAAE0CJFiY 9eKBk8duo6jP1p3CxIAAOKm47C57Y4pDSAMORSKFDZ9qAHjHekA4NTAXfyB1p2E2SZCjLEAU7CuR yX0acJ8xoFcqyXUj98D2phci5znvQIcmO9AC7vQUAABoAcBQAuAKAHBc0WAcsTH2p2AeIQoyRSuk NJjuhA4FS5MpKw1lYng5FSUG4r1FSMcrmgY7OSOaBNCSXKxZA5amotibsVZLh5O+B6CrUUiGxoqi R4FABimAFaQCEZOaFpoDE20xCbcUwEoEBFABikMTHtTENKD6fSlYBAGWk4juRvJz6GlYLmnpz7rc Y7HFaQ2Je5pRHvWliSxA3zE9QOKBl6NsmgRcifZwfrRYC0JOKAJkZlNGwmTJMd+MYCj9aokhZjnI 6ZoAnjAxnFUIlBGCKYEkYwMGkBLg4GKYD+nWgB9AATjigBUfnBpASd8d8UwEU4IYDkHBoEZPiOUk RW3U8VwYypywOuhEhjGBj0FeCjrH1QwpgLmgCxDL2NS0B4xXvnEGTimACgBStIBMUAKFoAekeaLj sSqgHWlcLD8hegoGG4mgAoGGeMUAJux3pDDdQA4N6mgLiGSNOrZPYCnYm5E07FwUG0gcVS0JuRs7 MfmJNABQADrQA8CgBR9KAHgdulADlBzQA9ULHgGiwEgg28sfwp2EiRVUD0FS5JFKLFLgdKlyuXaw wmpGNB5piHg0gGsOOTgUw2BI9w4PFFg5iWBMFgwHHSnYVyrcrmY1RJGEpiFAxQAoFMBaQAc0wAdc Un3BCBlDbcjd6U07iFIoAaRigBopiDFAwNABigBMUARTR5GccikItaQ2BIn41cRSNeL5Rk8CrRJZ h4AB64zTEW4unSkBajGe+KYFlDxjtQIsRnH1p2FcXcBGdrbtxyaYEiA4A60ATjjnGKYiRemTQA9A 2fr2NICdVPbiqAcFOMGkBIo7DpQAEd6ADaAaYEikqQR2oEC7HchjjHzH6VLGkc5cSm71V3PRea8T H1NeVHoU1ZE6ivPRsLVAFIBaYCg46UwPIB1r3jiF6UgFyBQAAntQMAM+1IBy4FADt/pQMATQA4Gg Bd1AATxSGJmmAFgo5osK5GZh/CM07CuMLsepxQK4ACmAooAO9AABmgBwBBoAkGaAHKORgUAWEgJ5 xge9OwXJRCiDJ5p2SDVjicDjipc+xSiMDA5OMVDGhjE1JQmCelMLgVbjmmBG7eXyxAoFdFd74jiM fiapRIchkcjyglyTzVWsS3c1rbHkp9KllofkBqQFKf8A15xTELg4piEI5oANpAoANtMBNnpQIGXi gDNkjkjfcMkZzVEmhE4dQRSKQ4g0hjQDQIXFMBMUCExQAuMCgAI4oAXTR5d7t9RTjuJ7G0Fz8p6E 4rWxmW4x0FMC1CPWkBYjGeM0wLCLnj1osIlfCQkd24ppCJETaAAOKBkifeyTQInXkYpgSjGBQBMu fSmBMp45oEOA4z3oGOHAoAFPOKAHP6dO9ABnA45oEV72VYrOSToT8oP6ms6jsjSmrswtPUtG0p4L nNfN4iXNNnoRWhbFYlhVIAoAKYC0wPIMivdOKwcmgBRgUDFzQAtIAoAXI/CgYufSgBQcUAGaAuNZ 8GmK40u3QcUCuJ9aYAKAFxQAdO9AC0AO70AOAHrQA5I2Y8KTQBZjs2HMjBR6VSQrvoWB5cYCouT6 mi6Q+Vgz4HzdfSpcirEbP61BVhmc8mgBwBI9BQAu0CgBHcKOSBRZhdFSW8PIQcetUokORTcsx3M2 T71RI3GfegCaE4BFAGranMC1LKQ9jzQMqyMDKR3oJYoziqAX6UAJ1FAC9KQBg0wEK0AIUz9aYrEL xtGdyD6j1oAkjkD8A4I6g0guPxQMdtoAQoKYhpQ0AJtxQINpoAdGu2aNx1BprcT2NhAGcYbp6Gtj MvRg55oEWkUBM96YE8UecZoAtomOaYhrAmdFHO35v8KAJxnPPakBKgGQSOaYEoFAEiLk+lAE6j14 pgPWgBwz0pAPzjjpTAQcHg9aQD2HGDz70xAo7DmnsBi+Jp9kaQL95vl+metceJnyxZ00okMA8uNV HYV8697nYtEShqBi5FMYtACUwDNNCPIRxXunGOoAMigYA0ALmkAYoAXIFABmgBN3OKYrhQAh65pg LQIKQw6UwCgBcetADlXNICWO3dzwOPemk2Itx2kaDMhyfQVVktw1ZIZdo2xqF+lLm7FKHcTYx+Zz U6vcrbYBgD5Rj3NIBjAnpz70DEVOcmgVyQAelIBTgUahchkk2+1VYTZTlcsfamiSE0wG47mmAnOe BSAkRcAmgDRtCfIGaljQ9jwKBspXJK3G4dDQiSVTuXrVXAcuRQA6gBc80MA4oAcB7UAG2gBStAEU kKMe6t6imKwmXj4Zdw9RQK7Q5ZUPfH1oHckAB5BpALj1oGIVpiYmymA8Jx6UCHKuKdxWLsV1KowH PpzzT5mhcqNC31LbHtlgD+jKcGrU11JcDTtbq0lAxL5bf3XGKpNEuLL6xnBwQ/upyKdrCI7YZaR/ U4H0H+TQBYVeDQBIqnv0oAAMtx19KAJkU7c4oAmHA560XAkXjjii4WHLt79aYhW6g44oGJg5zQA4 ZAoEORct6AcmhuyBK+hyl9KbvWMHonP514+OnpY76asXK8o3FzQAZoAM0AG40wFDCqA8kzxXunGF ABQAuaBi5oAM0AFFhCUwA8UAKKAAigAoYgoGFADgCelAEyQHqxAFNIRaiijUZx+JoukOzZLvAHXF JyZXKkLgycjhR3NK3UYqqFHHX1oARnA96VxibWfrwKLAKVwOOBTJE4UZosFxjsB60xXGsxC5oEVZ GLn2pgRNQBH70AB5470ASxx+oqbgOdcCmkBag4gWhjQ4n5aAIJQHJzQJkUbmNwh6UC2LCkGgY4UA L9KYDlHNAD+/pQA7bmgBRHnvRYA24pgIVpCGmJT1FMLDTbDqCVx6U7isHlSj7sgI9xRoFmgzMvVF b6GloF2KspHBhcGnYLj1nQH5lZfqKQFhApAwaA0JAuDTuFiVMigCdORQBYhd4jmN2T6HFO7WwNF+ LVZkAEkaOo74wapVO5DgX4dRtZOrGM+j8frWilFkOLReUh1G0gj1FXYkVPlPrmp2GPUMyn+HmlqP QcNofGck8ip02YxyHcMnjsaE29R2SJ0wDVojUdt561QhOnFIBQPXmmA27kEFjK+SCflFZzehcFqc hpxMtxNM38TV4GKleR3w2NLNchoFABmgAzQAhNNCHIOaLjPI819AcYoPpRYBaAFFAC/SgAxSAKAA cUwDqKQhR2oGBoAM4NMQAEmgZIsYH3jQFiaLG7AFF7bDsTN/dGKm7ZVrCeZjhRk0ASRrkgnk0aAT uQq5psEiIuXOFpDJI4xGN0hAp2JbFacdEFMREST1NAhrEqKYXFU5Ge9FhXIZCxPzDFAXISOeKAI2 wOnWgYzFAiWKMdcc+tIZMOBjFADJugoAmhOYhQwWwrHAosBCTzQA2SPeuRwfWi4CW7HGDTFcnyel IY7pQA4E0wHg0APB9qADkUxD1YigBw6cigYhHPFFgACgQ5eOKAHbaAAIPSgCRFHGRle4p+orEEim Bgyf6snkelHkBbiwwHekMnVMdKAJAlAEirTAeM0gHEetOwEtvLJbndE2327GmpNEuKZpDWSI/wDU HePQ1r7RdTNwZpQypLGsu/OQMqO1O63uKz2LCjau3pjpRZBcdlRtJJ+bgjNQ7btlK7Hx8DGCMetX DsTIkqybCGgQq8dKBmL4xvRBZrCpw2O3qa5qsrJm9JGRpuEgX1rwat27s7Y7F4NWNhi7qLAITSsA A4pjF3UAPDUhnkdfQnEIDimA4GkAoIoAXpQAtIBCeaAAGmAooAQHApAOBpgKBk0BYmUKtK47EmN4 460AMMqROEU5YnrRYLj3z0FKwx8X0pgWRkLkUDI3PTJ5pBcashTO3r61SE2Jkscsc0Ejs0AKDimA rHjHrTEMxg8UxCkAjBFAEUkRHSlYLkKoS3SiwXJPIAOR1pNDuPwBwRg0DCgCKbpQA6I/JQA56AIS cSUCJC2BgUhiJCxbcPl+tF7CFVvmKnqOtMLkq4pDHA80wFFAD14oFYfQA5RzxTCw8GgB2BTAKAE2 0gsSKtADwO1ACqvNAEjRB0IPQ9qBFe3DRSGNjynQ+ooA0UXABoGSjGcUASBRjNABgdqAHUwDbmkA 9RQMlikeJsxsVPtQnYTVzTt9UyFW4Xp/EK05r7kcttjTjKSophIZGHHsaLaWQttyX5hjd1HBq7vq Tp0Hj6VVybAR70xD4ly4Hbv9KWiQ9ziPE8n23Uo1VuCS2B2HauepqtToWmxLDE0UQAbP1rinh09U axnYfvK/eGK5J4eUTRSQ4Sj1rBwaLQeYKXLYBRJUNAL5lIZIrU7AeT5r6E4heKAFoGIDSELk0xjg aQCHigAJFACgE9BSAkWP1NADuB0FAxKAFGaAHgnGM0ACxJ5gbHNAWJWzQMkicIvPJo6BcHnZhjoP agVyPNAhwNMBwoAUHFADgDVCHhcnpQAjKAeKYhuD+FACqcdelADuDTAXFIBCAwwaVhkTIV57UgIL gYXNABEf3YoBDiaAGiJnbPQUDJdqxe5pAJJLjFOwrlctsct2NMRMj7hxSGiUGgZIvWgBwGKAHL1p iJFOBQMUGgBwoEKB70wJRHnnNKwiREwaoB+wbe+aQChCtFhk0a4HvSApXPF2mOMgimI0oxlR6Uhj wtADgMUAKOtADuv4UwHKMcUhkoUmgQBOaAJVRT0OPrTsmGxIheLlCU91NPVC0ZpW2pnI+0ADOAWH +FWpdyXDsaUbq6/KQ3uDWiZk1Yd6GmIZdyeRZTP/ABEbF/Hr+lRJlwWpxVnGXup5JeX3Y+grmk9T dF/OBzSGVDqNsJjEHUv6UPQZHcX1qknlu4Dnnip9mpbod7EccyvzG4YVzzw66FKZKJiOuRXNKhKJ akhwnHrWLiyySO5TOCwqXBhc8zr3TjDOKAAHFABmgBaAFBx0oGLgn2pAPRABk9aAHZpDDOKAGl/S gA3GgBQ1AEiEUAPDANgUBcdu55oC4Z9qAHgA98UCDaAKADtTAePyoAcKYD1yT7UASIvJyaYhuOaY gApgIRmgREcoaQxwkzx3oAcBgUABOKAK15gICPWpsMbCpZRimBL8ink5NILCGT0oGMJJcfyoFccY ixJY07CFKAjGOKpCZXGYnx27GhoSZaXoCKgslHQYpjH5/CkAq0xDu9Ax4HGaAHjGOtMQ5SQcikA8 NQFiRXFMCQNyPSgQ73FAx6P045pBYqaipV4pcYGcGmBownKA0gJgR6UwFGKQCYyeKAJUXigZKEoA kQgKV2jPr6UgDFAC49KAHAlapNoVh6yKR84p8ye4rE9vIsZDRuVP1q1ZbCaZpQ3qkYkIPuK0vczc Rmqy+dbwpH93kk1Ehx0MAJ5dzJjowFYyWpsmLIA6FT0IwakZjT6Ij8pIQR0JobFYxtRsJoHG8kk8 BvWqWgpFWOaa1IHzJihxuJMv2+tSLgSYYfrUOJakXDqlu6ZOQfpUOCe5SkZ8l3K7lonEiZ6Kefyr RUI22IdV3OdzxTJEzTAWkA4UDHBaQxwGOnFIBQaAHEgUAM3elMBQM0higCgQvFAxRyTxQIdnAoAV Tge9ADhxQA4D0oGSA4HOKADOelMByr82KAFA5piJF5oAlQCmA4AL34piE4FAhABTATHWgBGAIoEV pE5ytIBEmK8Gi4yTdu5FADXC4G/nHak9B2I2kJ4XgVNxjMetOwEqxk+woRJIFCD5RTAdTAY3AoAa UDDmi4WGxSbCVYUbhsTg7fp2qSkSDpQA/wC6AcYzQAoOTQA4GmAoNAChsUAG80XAUS9qALCScCmI d5npQBPDzSAdcR+dCyHv0poBumy5hKP99DgihiRcoKF74pATRgCgCUAdqAHA4HWgABIoAehBHIpA PABoGKFOKBDSvtQADIHNMBOexxQAokYcEn86LsLIY7d+9G4WInoAhnl8qMtgtgdBSsO9jMOqgsyy R7eMjPTNLlC5l3MrSqJHiCKxxlarVEXTIn04Ou+JgfYUX7j5exUaKaIkEHinbsTexHtXdnBRvUcU XaAz6QxwFADsAGkMDmgBQeKQw3UWAXPpQAoGaADoaQATgUwFHNIBaAFU4Y/SgBc5PsKAHCgBe9AD 1NAD+ooAVWAYDFMY/wAwA56UCuPQbhkUwHjFAh68UALnnmmAxvWmIUHB4NAAJB3FADGY+uKAG5OD QBEyop3MefSgEhrTE8LwKm5VhnWkA9IifanYm5IqqDx1qgHg8GkAo9+tAxjSheByaAIywzljQIUs X4HApDGmP06ijYCaF1Mew8Hsap+RK0HhthIcc1JZMksTAF9wNIBHKBspmhAG6gAyTjimA7n6UASp FuA4JPoKdhXHCNYwC7ImemTTUWK4huoEON27HoKrlDmQxJt7nsPSoejsNal+FwAKYFoYYCkMrHEO oIVOBIORVdCdmXgeeaRQqn5jSAmWgCRWOaAH0APUZFADsbaAHDpSGLnAoAbv/OmAoO6kAMBzigCM qaYDGyBSAaTQBC9NCKl1bR3EZVlA75ApkmILW6kUrGgKITgNxmq0J8iq6yWz/OJID69VpWiwu0TC 5kZPnUTL/eXnFHI1sVzIYTDJwpwfRhS23FZGGKkYtAxe9AA33aAEHQUAPHSgBRSGOoAaKQCHpTAF 6UAPHakAH71MATpSAeKAFoActAEidDQAp6imA9RxQBIvA4oAXsKYh/agB/pTAa9MQ00AMbrSAQdD TAd2pDKs33qTAj70ATw/epoRMepoATHI+lMYo71Ihs3QUwZEKYEf8dICfsaAFP8ADSGRvw3HFOOx LJSfni96GMG4dgOOakZJHQMf/FTQiZAM9KYFqJV2Mdo6elXFEsoX0jhhh2Hy+taEMil5ijzUiGNx imA+InfUyHE0ID0rM2NCPpQBVm/5CFv9DTF1NBuooGOSkBOnSkMmWgB1AD07UwHt1oAUdqAEP3qQ DO9ADh0oAcKAGt0FAEbd6AI26UARNQhDB0piZE3WmLoRMoYEMAR6GgDltRAiuj5Y2f7vFVERYlG6 0Dty3qetU9iD/9k ________________________________________________________________________________
Subject: intercom
Date: Aug 06, 2008
Thanks all for the responses. I'll keep working on it. I need to do something about the open mike problem. I now have info to start. Dick N. ________________________________________________________________________________
Date: Aug 06, 2008
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: Re: fuselage weight
Gene.... - I thought I was the village idiot......tee-hee-hee (no emotions displayed i n this post) Kenneth M. Heide, BA, CPO, FAAOP - --- On Wed, 8/6/08, Gene Rambo wrote: From: Gene Rambo <generambo(at)msn.com> Subject: Pietenpol-List: fuselage weight Date: Wednesday, August 6, 2008, 11:16 AM OK, how come nobody raised the BS flag on me when I posted that my bare fus elage weighed 33 lbs???- The more I thought about it, I realized that it could not possibly be right, but I KNEW I weighed it correctly.- Well, my wife just asked me why our bathroom scale was set on kg instead of lbs . . DOH!!!!- - I don't know how to reset the scale, but somehow I must have.- A quick go ogle converts 33.6-kg into 74.0 lbs, which sounds much more reasonable. - And there I thought I was losing a lot of weight on-my beer and pizza die t. - Damn. - Gene =0A=0A=0A ________________________________________________________________________________
Subject: Re: ribs and ailerons
Date: Aug 06, 2008
Try telling that to your wife. :-) Clif ----- Original Message ----- From: Gene Rambo To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 10:09 AM Subject: Re: Pietenpol-List: ribs and ailerons . . . and the period goes inside the quotations. gotcha ________________________________________________________________________________
Subject: Re: How hard is it to get into the front seat
Date: Aug 06, 2008
And put the Pitcairn Mailwing logo on the side. ----- Original Message ----- From: Dave Abramson To: pietenpol-list(at)matronics.com Sent: Wednesday, August 06, 2008 7:24 AM Subject: RE: Pietenpol-List: Re: How hard is it to get into the front seat Hello All! I am building the short fuselage version.... I sat in it and said NO WAY!!!! (I am 6'2") I then removed the front seat, moved the rudder bar forward. Now I fit! But it is now a single seat with baggage in front. Maybe I will make a Mail Plane out of her!!!! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Rick Holland Sent: Tuesday, August 05, 2008 4:28 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: How hard is it to get into the front seat And the long fuselage version gives you a bit more cockpit length and you can always widen the fuselage as many have done (widened mine two inches). Of course that doesn't necessarily increase your gross weight. Rick On Tue, Aug 5, 2008 at 1:01 PM, Kip and Beth Gardner wrote: Tom, There is a saying that you may not have heard since you are fairly new to the list - "This plane was designed when midgets ruled the earth!" Bernard, by all accounts, was about 5'4" and weighed maybe 140 lbs. Now that's just about my size, and my wife is about the same, and our daughter will probably be about equal or less as an adult, so for us, yes, it's a capable 2-seater. Heck, we could even carry 50-60 lbs of baggage if there was space for it! For two 200+ lb. guys, add in a full load of fuel and you're close to gross, if not over, depending on how light or heavy you built your plane. Kip G. On Aug 5, 2008, at 2:48 PM, Tom Anderson wrote: walt, How big-butted are you talking about here? Furthermore, is the Piet a truly capable 2-seater at all? -------- Location: Eastern N.C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196707#196707 -- Rick Holland Castle Rock, Colorado href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Checked by AVG - http://www.avg.com 8/6/2008 4:55 PM ________________________________________________________________________________
Subject: light weight = better climb
Date: Aug 07, 2008
Simple formula; Walt is right. What you gain with a lighter airframe is not only more useful load but better climb. Forget top speed; the Piet isn't about that and a lighter plane won't get you more speed. Lighter weight equals more available excess thrust, and that equals better climb. Corky built 41CC about as light as Walt's airplane but it does have a vacuum venturi and two vacuum gyro instruments (needle/ball and VSI), so it could be a tad lighter. Empty weight of 41CC is currently 627 lbs., which is about 12 lbs. more than Walt's plane. I could easily find those 12 lbs. but like Steve Dortch said, the airplane performs pretty well as it is now with Cont. A65 and a Hegy 72x42 prop. I fly it out of San Geronimo Airpark, paved runway length is 3000' and the field elevation is 1,040 MSL but I have never used more than half the runway to either takeoff or land, and more often than not I use the grass area on the north end rather than the paved runway since it allows me to put the nose more nearly into the wind most days. The day I took Steve up, I estimate the density altitude to have been about 3200' MSL based on dry bulb temp., wet bulb temp., and altimeter setting for that time. A recent aerial photo of our field is at http://www.flysquirrel.net/8T8.jpg and the shot is taken as if on an extremely high final to the area that I operate off of. From this angle, I could probably still slip it in and land on the grass if I chopped the power completely off and threw the airplane into a full cross-controlled slip. The nice thing is that if I run out of grass, I can keep rolling right on to the paved runway... they keep the grass and asphalt transition very smooth just for that reason. I love this airplane! Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: GN-1 WING ON A SHORT FUSE PIET?
Date: Aug 07, 2008
I have taken over my late fathers pietenpol project, the fuselage is complete and is the short wood version from the original 1932 plans. I came across a good deal on a set of GN-1 Ribs, spars and plans. After researching this i discovered the spar center to center is 31" instead of 28-3/4, my question is the pick up points on the fuse are all for the 28-3/4 c to c, can the cabane struts run inward slightly and the outboard struts would do the same? Anyone ever do this? i would build the std piet wing if the spar material wasn't so perfect. Also, i have a complete Model A already converted for a Pietenpol for sale missing only the carburetor. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197118#197118 ________________________________________________________________________________
Date: Aug 07, 2008
Date: Aug 07, 2008
Subject: Please connect with me :)
Hi, I looked for you on Reunion.com, but you weren't there. Please connect with me so we can keep in touch. -Bill Do You Know Bill? YES - Connect with Bill, and see who's searching for you http://www.reunion.com/showInviteRegistration.do?uid=277013581 NO - I don't know Bill http://www.reunion.com/showInviteRegistration.do?unsub=true&uid=277013581&invitee=pietenpol-list@matronics.com ---------------------------- Reunion.com - Find Everyone from Your Past. You have received this e-mail because a Reunion.com Member sent an invitation to this e-mail address. For assistance, please refer to our FAQ or Contact Us. http://help.reunion.com/selfhelp?lid=2 Our Address: 2118 Wilshire Blvd., Box 1008, Santa Monica, CA 90403-5784 ________________________________________________________________________________
Date: Aug 07, 2008
Hi Top, I have a GN-1 and am building a Piet. I would not put the Grega wing on the Piet, the Grega center section spar fittings that the cabanes attach to are going the wrong way to pivot the cabanes. They go side to side on the Grega and for and aft on the Piet. You could cut down the front spar to 4.75" and you just have to add .50" to the aft spar and you have Piet spars. It will probably be more work trying to adapt the two plans to each other than making new ribs. Skip > [Original Message] > From: TOPGUN <rmdinfo(at)lakefield.net> > To: > Date: 8/7/2008 10:34:35 AM > Subject: Pietenpol-List: GN-1 WING ON A SHORT FUSE PIET? > > > I have taken over my late fathers pietenpol project, the fuselage is complete and is the short wood version from the original 1932 plans. I came across a good deal on a set of GN-1 Ribs, spars and plans. After researching this i discovered the spar center to center is 31" instead of 28-3/4, my question is the pick up points on the fuse are all for the 28-3/4 c to c, can the cabane struts run inward slightly and the outboard struts would do the same? Anyone ever do this? i would build the std piet wing if the spar material wasn't so perfect. > > Also, i have a complete Model A already converted for a Pietenpol for sale missing only the carburetor. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=197118#197118 ________________________________________________________________________________
Date: Aug 07, 2008
Subject: Re: Auto Gas in an A-65 (with ethanol)
No, I saw what auto gas did to my gascolater back when i was building. It was an approved gascolator. When the auto gas sat in it over the winter, the gasket was all fat and squishy. That's when I swore off auto gas. Also my needle valve is neoprere. What the heck will it do to that??? I don't fly enough every year to warrent going to auto gas to save money. I'm a 100LL guy now walt evans NX140DL ----- Original Message ----- From: "Ben Charvet" <bcharvet(at)bellsouth.net> Sent: Wednesday, August 06, 2008 9:18 PM Subject: Pietenpol-List: Auto Gas in an A-65 (with ethanol) > > Well, my last source of ethanol free auto gas seems to have switched over. > Right now I'm switching over to 100 LL in my Baby Ace. Anybody out there > been brave enough to try the gas/ethanol mix in a small continental in a > low and slow airplane? > Ben Charvet > Mims, Fl > > > ________________________________________________________________________________
Date: Aug 07, 2008
Subject: Web material for spar
Thinking of making my own spars and am curious as to what would make a better web: plywood or spruce, or something else. I was thinking 1/2" web with 1/4" "rails" if you will, to make up the 1" total width. ________________________________________________________________________________
Date: Aug 08, 2008
Michael, Check out the "Wing Spars" section of my web site. http://www.cpc-world.com <http://www.cpc-world.com/> Cheers Peter Wonthaggi Australia http://www.cpc-world.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, 8 August 2008 7:54 AM Subject: Pietenpol-List: Web material for spar Thinking of making my own spars and am curious as to what would make a better web: plywood or spruce, or something else. I was thinking 1/2" web with 1/4" "rails" if you will, to make up the 1" total width. ________________________________________________________________________________
Subject: Re: Web material for spar
Date: Aug 07, 2008
Michael, Take a look at http://westcoastpiet.com/construction.htm Chris Tracy put together a nice website with lots of info including a couple of articles on built-up spars. Greg Cardinal ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Thursday, August 07, 2008 4:53 PM Subject: Pietenpol-List: Web material for spar Thinking of making my own spars and am curious as to what would make a better web: plywood or spruce, or something else. I was thinking 1/2" web with 1/4" "rails" if you will, to make up the 1" total width. ________________________________________________________________________________
Subject: Auto Gas in an A-65 (with ethanol)
Date: Aug 07, 2008
Having destroyed the neoprene needle valve in my old J-3 with car gas back before they put ethanol in, I can assure you that you don't want to try it. Most needle valves now are stainless steel (and they leak). Besides, mogas just stinks. I much prefer the smell of 100 LL. Don't like the price, though. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt Sent: Thursday, August 07, 2008 6:30 PM Subject: Re: Pietenpol-List: Auto Gas in an A-65 (with ethanol) No, I saw what auto gas did to my gascolater back when i was building. It was an approved gascolator. When the auto gas sat in it over the winter, the gasket was all fat and squishy. That's when I swore off auto gas. Also my needle valve is neoprere. What the heck will it do to that??? I don't fly enough every year to warrent going to auto gas to save money. I'm a 100LL guy now walt evans NX140DL ----- Original Message ----- From: "Ben Charvet" <bcharvet(at)bellsouth.net> Sent: Wednesday, August 06, 2008 9:18 PM Subject: Pietenpol-List: Auto Gas in an A-65 (with ethanol) > > Well, my last source of ethanol free auto gas seems to have switched over. > Right now I'm switching over to 100 LL in my Baby Ace. Anybody out there > been brave enough to try the gas/ethanol mix in a small continental in a > low and slow airplane? > Ben Charvet > Mims, Fl > > > ________________________________________________________________________________
Subject: Re: GN-1 WING ON A SHORT FUSE PIET?
Date: Aug 07, 2008
Skip, thanks for your reply......damn, i just had all of the grega wing fittings lazer cut from 4130, turned out beautiful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197246#197246 ________________________________________________________________________________
Date: Aug 07, 2008
From: "Glenn Thomas" <glennthomas(at)flyingwood.com>
Hopefully this isn't a redundant response. Found this video of somebody climbing into the front cockpit. Not easy but where there's a will there's a way and this guy finally finds his way. I am about 5' 10" and 210 lbs and after doing a little Mexican hat dance, was able to get into Walt Evans' front cockpit a couple years ago. Most of the time is spent thinking about how to get in without damaging your gracious host's pride and joy. http://www.youtube.com/watch?v=exLPpG73BWA&feature=related Glenn Thomas Storrs, CT http://www.flyingwood.com ________________________________________________________________________________
Date: Aug 07, 2008
If all else fails a little bit of naked and a bunch of goose grease helps get it done! John In a message dated 8/7/2008 9:50:43 P.M. Eastern Daylight Time, glennthomas(at)flyingwood.com writes: Hopefully this isn't a redundant response. Found this video of somebody climbing into the front cockpit. Not easy but where there's a will there's a way and this guy finally finds his way. I am about 5' 10" and 210 lbs and after doing a little Mexican hat dance, was able to get into Walt Evans' front cockpit a couple years ago. Most of the time is spent thinking about how to get in without damaging your gracious host's pride and joy. _http://www.youtube.com/watch?v=exLPpG73BWA&feature=related_ (http://www.youtube.com/watch?v=exLPpG73BWA&feature=related) Glenn Thomas Storrs, CT _http://www.flyingwood.com_ (http://www.flyingwood.com/) (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: rim width
Date: Aug 08, 2008
Hey, Building my third set of wheels for this bugger, and Buchannans wants to know what width rim I want to use. I am going with 21" modern alloy motorcycle rims, and sounds like there are a few options. Does anyone remember the width of theirs? Douwe ________________________________________________________________________________
Subject: rim width
Date: Aug 08, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Mine are 21" x 3.00. Sun alloy rims from Buchanan's. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Friday, August 08, 2008 9:08 AM Subject: Pietenpol-List: rim width Hey, Building my third set of wheels for this bugger, and Buchannans wants to know what width rim I want to use. I am going with 21" modern alloy motorcycle rims, and sounds like there are a few options. Does anyone remember the width of theirs? Douwe _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Subject: Re: rim width
Date: Aug 08, 2008
I would go wider (like Jack did) if I had it to do over... My rims are 1.85" wide and the tires are about 3" wide. And with air, they are almost exactly 26" tall. Jim in Pryor, OK ----- Original Message ----- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> Sent: Friday, August 08, 2008 8:08 AM Subject: Pietenpol-List: rim width > > > Hey, > > Building my third set of wheels for this bugger, and Buchannans wants to > know what width rim I want to use. I am going with 21" modern alloy > motorcycle rims, and sounds like there are a few options. Does anyone > remember the width of theirs? > > Douwe > > > ________________________________________________________________________________
Date: Aug 08, 2008
Subject: spoke wheels
I got mine from Airdrome Airplanes. Rims are 3 5/8" wide, 7" wide at axle made ready for brakes, rims are 20" across. awaiting on tires and tubes that are to be drop shipped. The ID of the axle bushing is 1 1/4".I am pleased with the quality. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Date: Aug 08, 2008
On NX18235 we used 19" DID rims with a width of 1.85 inches. Greg -------------- Original message -------------- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> > > > Hey, > > Building my third set of wheels for this bugger, and Buchannans wants to > know what width rim I want to use. I am going with 21" modern alloy > motorcycle rims, and sounds like there are a few options. Does anyone > remember the width of theirs? > > Douwe > > > > >
Greg
= Phot
Date: Aug 08, 2008
Mine are the same as Jim's and I would have to agree that a little more width would be nice. I went with the 1.85 because I was concerned about finding a tire for a 21-inch rim that is wider then the common 1.85 rim. You might want to drop down to a 19-inch rim like Mike Cuy and Don Emch. I think there are more tire choices for that size. Chris, I'm so sick and tired of metal fittings, Tracy -------- Chris Tracy Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197336#197336 ________________________________________________________________________________
Subject: Plywood
From: "mr-fix-all" <jb.spiegel(at)us.schneider-electric.com>
Date: Aug 08, 2008
Question, is the 1/16 90 deg birch plywood that aircraft spruce the same 1/16 90 deg birch plywood that hobby stores sell. I received my riblett plans from Roman today and I need to order plywood. -------- "Be who you are and say what you think, those that mind don't matter, and those that matter don't mind" Dr. Seuss Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197373#197373 ________________________________________________________________________________
Subject: rim width
Date: Aug 08, 2008
Douwe, Mine are 2.25", tires are 26" OD. Got three rims from motorcycle graveyard, all the same but had different hubs. Skip > [Original Message] > From: Douwe Blumberg <douweblumberg(at)earthlink.net> > To: pietenpolgroup > Date: 8/8/2008 9:12:40 AM > Subject: Pietenpol-List: rim width > > > Hey, > > Building my third set of wheels for this bugger, and Buchannans wants to > know what width rim I want to use. I am going with 21" modern alloy > motorcycle rims, and sounds like there are a few options. Does anyone > remember the width of theirs? > > Douwe > > ________________________________________________________________________________
Date: Aug 08, 2008
From: "G. Robert Stetson" <gr.stetson(at)verizon.net>
Subject: Autogas vs.Avgas
I run an FBO at Marlboro Airport in Massachusetts. I work very hard at encouraging my customers to get past the emotion of the price differential between autogas and avgas. When you look at the total cost of operating an airplane, if the price of avgas were cut substantially, the difference in the bottom line cost would be trivial. In addition, many have discovered that autogas, with or without ethanol, has been known to damage fuel system components. And, it goes bad over time. I make good money in a side business repairing outdoor power equipment. Every fall, I get a long line of snowblowers that won't start because they were stored over the summer with autogas in the system and the carb is all gummed up. Of course, all Pietenopol owners drain their fuel system for the winter. For my part, all of my outdoor equipment gets put away with avgas in the system during the off season. Avgas was developed for use in airplanes for a reason. Use it, reap the benefits of using it, and forget the additional cost. Just my opinion. ________________________________________________________________________________
Date: Aug 09, 2008
>Of course, all Pietenpol owners drain their fuel system for the winter. What is "winter"? Down here, we fly our airplanes year 'round ;o) PS, I fly avgas in 41CC exclusively. It's an airplane, not a car ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Plywood
Date: Aug 09, 2008
It's what I used on my ribs. Lately I have found a lower quality plywood being sold in my local hobby shop so be careful. I boiled and soaked the good stuff in water just to check it first and it was just fine. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: "mr-fix-all" <jb.spiegel(at)us.schneider-electric.com> Sent: Friday, August 08, 2008 11:34 AM Subject: Pietenpol-List: Plywood > > > Question, is the 1/16 90 deg birch plywood that aircraft spruce the same > 1/16 90 deg birch plywood that hobby stores sell. > > I received my riblett plans from Roman today and I need to order plywood. > > -------- > "Be who you are and say what you think, those that mind don't matter, > and those that matter don't mind" Dr. Seuss > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=197373#197373 > > > ________________________________________________________________________________
Subject: Riblett's Info
Date: Aug 09, 2008
Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197525#197525 Attachments: http://forums.matronics.com//files/riblett_p2_118.jpg http://forums.matronics.com//files/riblett_p1_976.jpg ________________________________________________________________________________
Subject: Riblett's grafts
Date: Aug 09, 2008
The lift,stall and cruise of the Piet, 4412 & 612 airfoils are very interesting to those that need more lift. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197529#197529 Attachments: http://forums.matronics.com//files/riblett_p3_653.jpg ________________________________________________________________________________
Subject: Re: Autogas vs.Avgas
Date: Aug 09, 2008
Oscar, not getting to fly your Piet in the winter is like a pilot never getting to watch "Waldo Pepper". They just don't know what their missing. Gene N502R (an all season bird). > > What is "winter"? Down here, we fly our airplanes year 'round ;o) > >> > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > -- > Checked by AVG. > 5:54 AM > > ________________________________________________________________________________
Date: Aug 09, 2008
The plywood of this sort here near Austin, TX, in both the Hobby Lobby (for sure) and Michael's (as I recall, not so sure) says it is for hobby use only, and not for aircraft use. Go to Boulter plywood in greater Boston. They have a website. A 4X8 foot sheet is $23 plus freight, on a special. and they will cut it into either 4X4 feet or 2X8 feet. UPS may charge some special rates for either, but they will tell you. This is good marine plywood, and very suitable for airplane use. You may want quite a bit, for not only rib gussets, but for wing leading edges. Add it up and see what you think. Tim in central TX -----Original Message----- >From: catdesigns(at)att.net >Sent: Aug 9, 2008 10:51 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Plywood > > >It's what I used on my ribs. Lately I have found a lower quality plywood >being sold in my local hobby shop so be careful. I boiled and soaked the >good stuff in water just to check it first and it was just fine. > >Chris Tracy >Sacramento, Ca >Website at http://www.WestCoastPiet.com > > >----- Original Message ----- >From: "mr-fix-all" <jb.spiegel(at)us.schneider-electric.com> >To: >Sent: Friday, August 08, 2008 11:34 AM >Subject: Pietenpol-List: Plywood > > >> >> >> Question, is the 1/16 90 deg birch plywood that aircraft spruce the same >> 1/16 90 deg birch plywood that hobby stores sell. >> >> I received my riblett plans from Roman today and I need to order plywood. >> >> -------- >> "Be who you are and say what you think, those that mind don't matter, >> and those that matter don't mind" Dr. Seuss >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=197373#197373 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 09, 2008
Subject: Re: Riblett's Info
Lowell, Thanks for posting this. Some may not know of your experience with various airfoils. Of course, you are one of the few (maybe the only one) who has changed wings on the same plane with the same engine,and changed engines with the same wing and plane, and then changed both. You can report empirical data on the effect of each of the changes. I think, based on talking with you about this earlier this year, and our more recent discussions at Brodhead, many builders should use either a Riblett GA30U-612 or a GA30U-613.5 instead of BP's airfoil. I believe you agree with that evaluation as a good decision for all but Piet purists. (Room for all instide the tent.) And we have discussed the merits of both these Riblett airfoils. I'd like to lay out some impressions of the 613.5, and see if you will confirm or change this post, for the benefit of others considering these choices. I'll ask you to pardon me in advance,if I am misinterpreting any of our discussions, or if I have crossed them up with similar discussions with Bill Rewey or Roman Bukolt. As you know, and as we have discussed, the 613.5 is "fatter" than the other airfoils. You and I have discussed its comparative merits. For the benefit of others on the board, the 613.5 has more loft on the Y-axis and a bigger radius, resulting in more camber. Otherwise it looks much like the NACA 2412 or 4412 and the Riblett 612, all of them peaking "Y" at 30 percent of the "X" (chord). All of these have better laminarity than BP's airfoil in the early part of the airfoil, before the airflow "goes turbulent." (All are characterized as "turbulent airfoils," but some are more turbulent than others.) The Riblett GA30U-613.5 seems to me a better choice for a Piet with less powerful engines, such as most Model A's (not your fuel-injected baby) or Continental A-65s. I think you have agreed with this opinion, perhaps even postulated it yourself. The 613.5 would give the Piet builder a faster climb, better safe payload on hot days, etc. A wing built with it would weigh a little more than one using a 612 airfoil-- how much more depending upon whether the builder uses filler blocks at the top of each spar or a full-height built-up ply and wood spar. Alternatively, the 612 might be better for higher hp Piets. With 100 hp or more the pilot gets a faster climb in any event, and the 612 would have less drag and allow a faster cruising speed than the 613.5. And as you and Mr. Riblett have reported, there are no negatives associated with the 612 when compared to BP's original "FC-10" airfoil. (We may not know that much about the pitching moment of the 613.5 as yet.) Do you agree with this discussion of the 613.5 vs. the 612? And with a 612 foir higher hp Piets? Is this the right way//a right way to think of the choices? Tim in central TX -----Original Message----- >From: Pieti Lowell <Lowellcfrank(at)yahoo.com> >Sent: Aug 9, 2008 11:38 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Riblett's Info > > >Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=197525#197525 > > >Attachments: > >http://forums.matronics.com//files/riblett_p2_118.jpg >http://forums.matronics.com//files/riblett_p1_976.jpg > > ________________________________________________________________________________
Date: Aug 09, 2008
Tim , as per usual, you are on track, Riblitt's better design even over the 612 is the 613.5, As you know it is easy to see the difference . But you can also carry a larger fuel tank in the 613.5. Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197633#197633 ________________________________________________________________________________
Date: Aug 09, 2008
Alright, so if you had 90hp, not heavy or light, and wanted better stol characteristics, which would you choose? Jeremy in Dallas Tim Willis wrote: Lowell, Thanks for posting this. Some may not know of your experience with various airfoils. Of course, you are one of the few (maybe the only one) who has changed wings on the same plane with the same engine,and changed engines with the same wing and plane, and then changed both. You can report empirical data on the effect of each of the changes. I think, based on talking with you about this earlier this year, and our more recent discussions at Brodhead, many builders should use either a Riblett GA30U-612 or a GA30U-613.5 instead of BP's airfoil. I believe you agree with that evaluation as a good decision for all but Piet purists. (Room for all instide the tent.) And we have discussed the merits of both these Riblett airfoils. I'd like to lay out some impressions of the 613.5, and see if you will confirm or change this post, for the benefit of others considering these choices. I'll ask you to pardon me in advance,if I am misinterpreting any of our discussions, or if I have crossed them up with similar discussions with Bill Rewey or Roman Bukolt. As you know, and as we have discussed, the 613.5 is "fatter" than the other airfoils. You and I have discussed its comparative merits. For the benefit of others on the board, the 613.5 has more loft on the Y-axis and a bigger radius, resulting in more camber. Otherwise it looks much like the NACA 2412 or 4412 and the Riblett 612, all of them peaking "Y" at 30 percent of the "X" (chord). All of these have better laminarity than BP's airfoil in the early part of the airfoil, before the airflow "goes turbulent." (All are characterized as "turbulent airfoils," but some are more turbulent than others.) The Riblett GA30U-613.5 seems to me a better choice for a Piet with less powerful engines, such as most Model A's (not your fuel-injected baby) or Continental A-65s. I think you have agreed with this opinion, perhaps even postulated it yourself. The 613.5 would give the Piet builder a faster climb, better safe payload on hot days, etc. A wing built with it would weigh a little more than one using a 612 airfoil-- how much more depending upon whether the builder uses filler blocks at the top of each spar or a full-height built-up ply and wood spar. Alternatively, the 612 might be better for higher hp Piets. With 100 hp or more the pilot gets a faster climb in any event, and the 612 would have less drag and allow a faster cruising speed than the 613.5. And as you and Mr. Riblett have reported, there are no negatives associated with the 612 when compared to BP's original "FC-10" airfoil. (We may not know that much about the pitching moment of the 613.5 as yet.) Do you agree with this discussion of the 613.5 vs. the 612? And with a 612 foir higher hp Piets? Is this the right way//a right way to think of the choices? Tim in central TX -----Original Message----- >From: Pieti Lowell >Sent: Aug 9, 2008 11:38 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Riblett's Info > > >Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=197525#197525 > > >Attachments: > >http://forums.matronics.com//files/riblett_p2_118.jpg >http://forums.matronics.com//files/riblett_p1_976.jpg > > ________________________________________________________________________________
Date: Aug 09, 2008
Subject: Delaware, Ohio Fly-In
Hello Ohio Area-Pieters,- Just wondering if any Ohio Piets planned on a ttending the Delaware, Ohio fly-in on Aug 16, 17.- If any one plans on go ing send me an e-mail, and they can stop by Chapman Field in Centerburg Ohi o for free donuts and coffee before we fly over to Delaware, ( before 9AM). - Skipp G., Mike C., And Don Emch, let me know if you want to go I will w ait for you and we can make a group arrival on Saturday Morning.- Dad say s they are wanting fly-bys, so if you want to we can do some in-trail, or l oose formation fly-bys low, and slow. - Shad=0A=0A=0A ________________________________________________________________________________
Date: Aug 10, 2008
Subject: Piet Roster
Is there a roster/list of Piet/GN-1 owners and builders, and if so, (1) can piet list folks access it, and (2) if (1) is "yes", how can it be accessed. Dick Carden From: Pietenpol-List Digest Server <pietenpol-list(at)matronics.com> Date: 2008/08/10 Sun AM 01:57:19 CDT Subject: Pietenpol-List Digest: 10 Msgs - 08/09/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Pietenpol-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Pietenpol-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-08-09&Archive=Pietenpol Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-08-09&Archive=Pietenpol =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Pietenpol-List Digest Archive --- Total Messages Posted Sat 08/09/08: 10 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 08:01 AM - Autogas vs.Avgas (Oscar Zuniga) 2. 08:51 AM - Re: Plywood () 3. 09:41 AM - Riblett's Info (Pieti Lowell) 4. 10:45 AM - Riblett's grafts (Pieti Lowell) 5. 01:21 PM - Re: Autogas vs.Avgas (Gene & Tammy) 6. 03:48 PM - Re: Plywood (Tim Willis) 7. 04:42 PM - Re: Riblett's Info (Tim Willis) 8. 07:38 PM - Re: Riblett's Info (Pieti Lowell) 9. 08:17 PM - Re: Riblett's Info (jeremy bramall) 10. 08:53 PM - Delaware, Ohio Fly-In (shad bell) ________________________________ Message 1 _____________________________________ From: Oscar Zuniga <taildrags(at)hotmail.com> Subject: Pietenpol-List: Autogas vs.Avgas >Of course, all Pietenpol owners drain their fuel system for the winter. What is "winter"? Down here, we fly our airplanes year 'round ;o) PS, I fly avgas in 41CC exclusively. It's an airplane, not a car ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________ Message 2 _____________________________________ From: <catdesigns(at)att.net> Subject: Re: Pietenpol-List: Plywood It's what I used on my ribs. Lately I have found a lower quality plywood being sold in my local hobby shop so be careful. I boiled and soaked the good stuff in water just to check it first and it was just fine. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: "mr-fix-all" <jb.spiegel(at)us.schneider-electric.com> Sent: Friday, August 08, 2008 11:34 AM Subject: Pietenpol-List: Plywood > > > Question, is the 1/16 90 deg birch plywood that aircraft spruce the same > 1/16 90 deg birch plywood that hobby stores sell. > > I received my riblett plans from Roman today and I need to order plywood. > > -------- > "Be who you are and say what you think, those that mind don't matter, > and those that matter don't mind" Dr. Seuss > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=197373#197373 > > > ________________________________ Message 3 _____________________________________ Subject: Pietenpol-List: Riblett's Info From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197525#197525 Attachments: http://forums.matronics.com//files/riblett_p2_118.jpg http://forums.matronics.com//files/riblett_p1_976.jpg ________________________________ Message 4 _____________________________________ Subject: Pietenpol-List: Riblett's grafts From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> The lift,stall and cruise of the Piet, 4412 & 612 airfoils are very interesting to those that need more lift. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197529#197529 Attachments: http://forums.matronics.com//files/riblett_p3_653.jpg ________________________________ Message 5 _____________________________________ From: "Gene & Tammy" <zharvey(at)bellsouth.net> Subject: Re: Pietenpol-List: Autogas vs.Avgas Oscar, not getting to fly your Piet in the winter is like a pilot never getting to watch "Waldo Pepper". They just don't know what their missing. Gene N502R (an all season bird). > > What is "winter"? Down here, we fly our airplanes year 'round ;o) > >> > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > -- > Checked by AVG. > 5:54 AM > > ________________________________ Message 6 _____________________________________ From: Tim Willis <timothywillis(at)earthlink.net> Subject: Re: Pietenpol-List: Plywood The plywood of this sort here near Austin, TX, in both the Hobby Lobby (for sure) and Michael's (as I recall, not so sure) says it is for hobby use only, and not for aircraft use. Go to Boulter plywood in greater Boston. They have a website. A 4X8 foot sheet is $23 plus freight, on a special. and they will cut it into either 4X4 feet or 2X8 feet. UPS may charge some special rates for either, but they will tell you. This is good marine plywood, and very suitable for airplane use. You may want quite a bit, for not only rib gussets, but for wing leading edges. Add it up and see what you think. Tim in central TX -----Original Message----- >From: catdesigns(at)att.net >Sent: Aug 9, 2008 10:51 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Plywood > > >It's what I used on my ribs. Lately I have found a lower quality plywood >being sold in my local hobby shop so be careful. I boiled and soaked the >good stuff in water just to check it first and it was just fine. > >Chris Tracy >Sacramento, Ca >Website at http://www.WestCoastPiet.com > > >----- Original Message ----- >From: "mr-fix-all" <jb.spiegel(at)us.schneider-electric.com> >To: >Sent: Friday, August 08, 2008 11:34 AM >Subject: Pietenpol-List: Plywood > > >> >> >> Question, is the 1/16 90 deg birch plywood that aircraft spruce the same >> 1/16 90 deg birch plywood that hobby stores sell. >> >> I received my riblett plans from Roman today and I need to order plywood. >> >> -------- >> "Be who you are and say what you think, those that mind don't matter, >> and those that matter don't mind" Dr. Seuss >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=197373#197373 >> >> >> >> >> >> >> >> >> >> > > ________________________________ Message 7 _____________________________________ From: Tim Willis <timothywillis(at)earthlink.net> Subject: Re: Pietenpol-List: Riblett's Info Lowell, Thanks for posting this. Some may not know of your experience with various airfoils. Of course, you are one of the few (maybe the only one) who has changed wings on the same plane with the same engine,and changed engines with the same wing and plane, and then changed both. You can report empirical data on the effect of each of the changes. I think, based on talking with you about this earlier this year, and our more recent discussions at Brodhead, many builders should use either a Riblett GA30U-612 or a GA30U-613.5 instead of BP's airfoil. I believe you agree with that evaluation as a good decision for all but Piet purists. (Room for all instide the tent.) And we have discussed the merits of both these Riblett airfoils. I'd like to lay out some impressions of the 613.5, and see if you will confirm or change this post, for the benefit of others considering these choices. I'll ask you to pardon me in advance,if I am misinterpreting any of our discussions, or if I have crossed them up with similar discussions with Bill Rewey or Roman Bukolt. As you know, and as we have discussed, the 613.5 is "fatter" than the other airfoils. You and I have discussed its comparative merits. For the benefit of others on the board, the 613.5 has more loft on the Y-axis and a bigger radius, resulting in more camber. Otherwise it looks much like the NACA 2412 or 4412 and the Riblett 612, all of them peaking "Y" at 30 percent of the "X" (chord). All of these have better laminarity than BP's airfoil in the early part of the airfoil, before the airflow "goes turbulent." (All are characterized as "turbulent airfoils," but some are more turbulent than others.) The Riblett GA30U-613.5 seems to me a better choice for a Piet with less powerful engines, such as most Model A's (not your fuel-injected baby) or Continental A-65s. I think you have agreed with this opinion, perhaps even postulated it yourself. The 613.5 would give the Piet builder a faster climb, better safe payload on hot days, etc. A wing built with it would weigh a little more than one using a 612 airfoil-- how much more depending upon whether the builder uses filler blocks at the top of each spar or a full-height built-up ply and wood spar.
July 31, 2008 - August 10, 2008
Pietenpol-Archive.digest.vol-gw
