Pietenpol-Archive.digest.vol-gx
August 10, 2008 - August 20, 2008
      Alternatively, the 612 might be better for higher hp Piets.  With 100 hp or more
      the pilot gets a faster climb in any event, and the 612 would have less drag
      and allow a faster cruising speed than the 613.5.  And as you and Mr. Riblett
      have reported, there are no negatives associated with the 612 when compared to
      BP's original "FC-10" airfoil. (We may not know that much about the pitching
      moment of the 613.5 as yet.)
      Do you agree with this discussion of the 613.5 vs. the 612?  And with a 612 foir
      higher hp Piets?  Is this the right way//a right way to think of the choices?
      Tim in central TX
      -----Original Message-----
      >From: Pieti Lowell <Lowellcfrank(at)yahoo.com>
      >Sent: Aug 9, 2008 11:38 AM
      >To: pietenpol-list(at)matronics.com
      >Subject: Pietenpol-List: Riblett's Info
      >Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol
      >Read this topic online here:
      >http://forums.matronics.com/viewtopic.php?p=197525#197525
      >http://forums.matronics.com//files/riblett_p2_118.jpg
      >http://forums.matronics.com//files/riblett_p1_976.jpg
      ________________________________  Message 8  _____________________________________
Subject: Re: Riblett's Info
Tim , as per usual, you are on track, Riblitt's better design even over the 612 is the 613.5, As you know it is easy to see the difference . But you can also carry a larger fuel tank in the 613.5. Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197633#197633 ________________________________ Message 9 _____________________________________
Subject: Re: Pietenpol-List: Riblett's Info Alright, so if you had 90hp, not heavy or light, and wanted better stol characteristics, which would you choose? Jeremy in Dallas Tim Willis wrote: Lowell, Thanks for posting this. Some may not know of your experience with various airfoils. Of course, you are one of the few (maybe the only one) who has changed wings on the same plane with the same engine,and changed engines with the same wing and plane, and then changed both. You can report empirical data on the effect of each of the changes. I think, based on talking with you about this earlier this year, and our more recent discussions at Brodhead, many builders should use either a Riblett GA30U-612 or a GA30U-613.5 instead of BP's airfoil. I believe you agree with that evaluation as a good decision for all but Piet purists. (Room for all instide the tent.) And we have discussed the merits of both these Riblett airfoils. I'd like to lay out some impressions of the 613.5, and see if you will confirm or change this post, for the benefit of others considering these choices. I'll ask you to pardon me in advance,if I am misinterpreting any of our discussions, or if I have crossed them up with similar discussions with Bill Rewey or Roman Bukolt. As you know, and as we have discussed, the 613.5 is "fatter" than the other airfoils. You and I have discussed its comparative merits. For the benefit of others on the board, the 613.5 has more loft on the Y-axis and a bigger radius, resulting in more camber. Otherwise it looks much like the NACA 2412 or 4412 and the Riblett 612, all of them peaking "Y" at 30 percent of the "X" (chord). All of these have better laminarity than BP's airfoil in the early part of the airfoil, before the airflow "goes turbulent." (All are characterized as "turbulent airfoils," but some are more turbulent than others.) The Riblett GA30U-613.5 seems to me a better choice for a Piet with less powerful engines, such as most Model A's (not your fuel-injected baby) or Continental A-65s. I think you have agreed with this opinion, perhaps even postulated it yourself. The 613.5 would give the Piet builder a faster climb, better safe payload on hot days, etc. A wing built with it would weigh a little more than one using a 612 airfoil-- how much more depending upon whether the builder uses filler blocks at the top of each spar or a full-height built-up ply and wood spar. Alternatively, the 612 might be better for higher hp Piets. With 100 hp or more the pilot gets a faster climb in any event, and the 612 would have less drag and allow a faster cruising speed than the 613.5. And as you and Mr. Riblett have reported, there are no negatives associated with the 612 when compared to BP's original "FC-10" airfoil. (We may not know that much about the pitching moment of the 613.5 as yet.) Do you agree with this discussion of the 613.5 vs. the 612? And with a 612 foir higher hp Piets? Is this the right way//a right way to think of the choices? Tim in central TX -----Original Message----- >From: Pieti Lowell >Sent: Aug 9, 2008 11:38 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Riblett's Info > > >Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=197525#197525 > > >Attachments: > >http://forums.matronics.com//files/riblett_p2_118.jpg >http://forums.matronics.com//files/riblett_p1_976.jpg > > ________________________________ Message 10 ____________________________________ From: shad bell <aviatorbell(at)yahoo.com> Subject: Pietenpol-List: Delaware, Ohio Fly-In Hello Ohio Area-Pieters,- Just wondering if any Ohio Piets planned on a ttending the Delaware, Ohio fly-in on Aug 16, 17.- If any one plans on go ing send me an e-mail, and they can stop by Chapman Field in Centerburg Ohi o for free donuts and coffee before we fly over to Delaware, ( before 9AM). - Skipp G., Mike C., And Don Emch, let me know if you want to go I will w ait for you and we can make a group arrival on Saturday Morning.- Dad say s they are wanting fly-bys, so if you want to we can do some in-trail, or l oose formation fly-bys low, and slow. - Shad=0A=0A=0A ________________________________________________________________________________
Date: Aug 10, 2008
Jeremy, On a Pietenpol with 90hp, seeking more STOL characteristics, I would choose the Riblett GA30U-613.5. On a much faster plane, such as a Zenith 601 or a KR-2, the best choice would be another airfoil, and might be a NACA 4412. You are seeking fast cruise in the latter case, not STOL. Moreover, on your Piet, as Lowell points out, you can put more gas in the wing tank space with the 613.5. Go nuts, widen the center wing to 36-40 inches, and add a "Tiger Moth bulge" as well, and you would really increase the tank capacity. And at the perfect spot, right at the CG. Your arse would never endure the range you might thus achieve. Tim in central TX -----Original Message----- >From: jeremy bramall <outofthebox50(at)yahoo.com> >Sent: Aug 9, 2008 10:17 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Riblett's Info > >Alright, so if you had 90hp, not heavy or light, and wanted better stol characteristics, which would you choose? > > Jeremy in Dallas > >Tim Willis wrote: > >Lowell, > >Thanks for posting this. Some may not know of your experience with various airfoils. Of course, you are one of the few (maybe the only one) who has changed wings on the same plane with the same engine,and changed engines with the same wing and plane, and then changed both. You can report empirical data on the effect of each of the changes. > >I think, based on talking with you about this earlier this year, and our more recent discussions at Brodhead, many builders should use either a Riblett GA30U-612 or a GA30U-613.5 instead of BP's airfoil. I believe you agree with that evaluation as a good decision for all but Piet purists. (Room for all instide the tent.) And we have discussed the merits of both these Riblett airfoils. > >I'd like to lay out some impressions of the 613.5, and see if you will confirm or change this post, for the benefit of others considering these choices. I'll ask you to pardon me in advance,if I am misinterpreting any of our discussions, or if I have crossed them up with similar discussions with Bill Rewey or Roman Bukolt. > >As you know, and as we have discussed, the 613.5 is "fatter" than the other airfoils. You and I have discussed its comparative merits. > >For the benefit of others on the board, the 613.5 has more loft on the Y-axis and a bigger radius, resulting in more camber. Otherwise it looks much like the NACA 2412 or 4412 and the Riblett 612, all of them peaking "Y" at 30 percent of the "X" (chord). All of these have better laminarity than BP's airfoil in the early part of the airfoil, before the airflow "goes turbulent." (All are characterized as "turbulent airfoils," but some are more turbulent than others.) > >The Riblett GA30U-613.5 seems to me a better choice for a Piet with less powerful engines, such as most Model A's (not your fuel-injected baby) or Continental A-65s. I think you have agreed with this opinion, perhaps even postulated it yourself. > >The 613.5 would give the Piet builder a faster climb, better safe payload on hot days, etc. A wing built with it would weigh a little more than one using a 612 airfoil-- how much more depending upon whether the builder uses filler blocks at the top of each spar or a full-height built-up ply and wood spar. > >Alternatively, the 612 might be better for higher hp Piets. With 100 hp or more the pilot gets a faster climb in any event, and the 612 would have less drag and allow a faster cruising speed than the 613.5. And as you and Mr. Riblett have reported, there are no negatives associated with the 612 when compared to BP's original "FC-10" airfoil. (We may not know that much about the pitching moment of the 613.5 as yet.) > >Do you agree with this discussion of the 613.5 vs. the 612? And with a 612 foir higher hp Piets? Is this the right way//a right way to think of the choices? > >Tim in central TX > >-----Original Message----- >>From: Pieti Lowell >>Sent: Aug 9, 2008 11:38 AM >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Riblett's Info >> >> >>Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=197525#197525 >> >> >> >> >>Attachments: >> >>http://forums.matronics.com//files/riblett_p2_118.jpg >>http://forums.matronics.com//files/riblett_p1_976.jpg >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Piet Roster
Date: Aug 10, 2008
Dick; There is a very useful and complete listing of Piets and GN-1s that is published by Doc and Dee Mosher, editors of the BPA Newsletter. It is not available online. The booklet lists the airplanes in several different formats for easy searching. You can get one of these by contacting Doc. Complete info is here: http://www.pietenpols.org/ , and while you're at it be sure to sign up for a subscription to the newsletter! Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: wing leding edge
Date: Aug 10, 2008
Date: Aug 10, 2008
Tim Willis wrote: > On a Pietenpol with 90hp, seeking more STOL characteristics, I would choose the Riblett GA30U-613.5. On a much faster plane, such as a Zenith 601 or a KR-2, the best choice would be another airfoil, and might be a NACA 4412. It's not really Piet-related, but you bring up something that has interested me for some time. A STOL KR-2 could be a really interesting sport aircraft. I wonder whether the GA30U-613.5 would be suitable for such an application? For the sake of argument, picture a Corvair on the nose and stall and top speeds just within the LSA limit. Owen ________________________________________________________________________________
Subject: another day of Pietenpoling
Date: Aug 10, 2008
Since the list has once again quieted down, I thought I'd just mention that I had another fine time in my Piet yesterday. Weather was typical hot August, wind was the usual slight x-wind out of the southeast, and the objective was Cannon Field, home of the International Liaison Pilot and Aircraft Association here in San Antonio ( http://www.centercomp.com/ILPA/ ). It's 25 statute miles from my home field, as the crow flies and if I don't violate the controlled airspace on the way. I never made it to Cannon. Got distracted with the many sights to see, the air was very nice (not too bumpy), everything is still green from the rains of a few weeks ago, and I needed to practice laying down a nice swath of smoke on a couple of fields along the way. It's easy if you pick fields with the rows lined up with the wind, but trickier if they are cross wind or skewed. I don't have smoke yet but a guy has to practice ;o) The Piet was in top flying form, performance was great, so were my landings. Poor Steve Dortch was down on the ground by his hangar, trying his level best to make his old Suburban turn from a toad into a princess by the application of a few meager coats of red paint, but between getting all wrapped up in blue masking tape and fighting the heat and breeze, I think he and his painting buddies got more paint on them than on the Suburban. By the way, the guy wielding the spray gun (mostly) was Steve Jones, editor of the EAA Chapter 35 newsletter that was nominated for one of the top five awards at Oshkosh for "best chapter newsletter". He and his wife Freda are our next-hangar-neighbors and are great folks. Not sure how the awards ended up but getting into the top five at Oshkosh is plenty to be proud about. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 10, 2008
Tim and/or Lowell How did you decide where is the CG is located and what angle of attack to use when switching to a 613.5 airfoil? Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: "Tim Willis" <timothywillis(at)earthlink.net> Sent: Saturday, August 09, 2008 4:42 PM Subject: Re: Pietenpol-List: Riblett's Info > > > Lowell, > > Thanks for posting this. Some may not know of your experience with > various airfoils. Of course, you are one of the few (maybe the only one) > who has changed wings on the same plane with the same engine,and changed > engines with the same wing and plane, and then changed both. You can > report empirical data on the effect of each of the changes. > > I think, based on talking with you about this earlier this year, and our > more recent discussions at Brodhead, many builders should use either a > Riblett GA30U-612 or a GA30U-613.5 instead of BP's airfoil. I believe you > agree with that evaluation as a good decision for all but Piet purists. > (Room for all instide the tent.) And we have discussed the merits of both > these Riblett airfoils. > > I'd like to lay out some impressions of the 613.5, and see if you will > confirm or change this post, for the benefit of others considering these > choices. I'll ask you to pardon me in advance,if I am misinterpreting any > of our discussions, or if I have crossed them up with similar discussions > with Bill Rewey or Roman Bukolt. > > As you know, and as we have discussed, the 613.5 is "fatter" than the > other airfoils. You and I have discussed its comparative merits. > > For the benefit of others on the board, the 613.5 has more loft on the > Y-axis and a bigger radius, resulting in more camber. Otherwise it looks > much like the NACA 2412 or 4412 and the Riblett 612, all of them peaking > "Y" at 30 percent of the "X" (chord). All of these have better laminarity > than BP's airfoil in the early part of the airfoil, before the airflow > "goes turbulent." (All are characterized as "turbulent airfoils," but > some are more turbulent than others.) > > The Riblett GA30U-613.5 seems to me a better choice for a Piet with less > powerful engines, such as most Model A's (not your fuel-injected baby) or > Continental A-65s. I think you have agreed with this opinion, perhaps > even postulated it yourself. > > The 613.5 would give the Piet builder a faster climb, better safe payload > on hot days, etc. A wing built with it would weigh a little more than one > using a 612 airfoil-- how much more depending upon whether the builder > uses filler blocks at the top of each spar or a full-height built-up ply > and wood spar. > > Alternatively, the 612 might be better for higher hp Piets. With 100 hp > or more the pilot gets a faster climb in any event, and the 612 would have > less drag and allow a faster cruising speed than the 613.5. And as you > and Mr. Riblett have reported, there are no negatives associated with the > 612 when compared to BP's original "FC-10" airfoil. (We may not know that > much about the pitching moment of the 613.5 as yet.) > > Do you agree with this discussion of the 613.5 vs. the 612? And with a > 612 foir higher hp Piets? Is this the right way//a right way to think of > the choices? > > Tim in central TX > > -----Original Message----- >>From: Pieti Lowell <Lowellcfrank(at)yahoo.com> >>Sent: Aug 9, 2008 11:38 AM >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Riblett's Info >> >> >> >>Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=197525#197525 >> >> >> >> >>Attachments: >> >>http://forums.matronics.com//files/riblett_p2_118.jpg >>http://forums.matronics.com//files/riblett_p1_976.jpg >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 10, 2008
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Dick, Go to Glenn Thomas's very nice site www.flyingwood.com. Jack www.textors.com ________________________________________________________________________________
Date: Aug 10, 2008
Tim Willis wrote: > As I recall, Mark Langford has documented EVERYTHING about his work on his Corvair-equipped KR-2. He would be the guy to ask about the Riblett airfoil. Thanks, Tim. I know of Mark's plane, but did not think of him for the Riblett airfoil. My impression was that he was trying to get high-end performance out of his plane, while I am trying to limit the high end and extend the bottom end just enough to make sure of being within the LSA stall requirement. Or would be, if this were anything more than a thought exercise. A Piet is still my first priority--though it could wind up having the wing on the bottom. Owen ________________________________________________________________________________
Date: Aug 10, 2008
I have spent some time researching the KR-2S. It might be our next build. If you get the stall speed down, the builder can set his own VNE right? Jeremy in Dallas ------Original Message------ From: Owen Davies Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Sent: Aug 10, 2008 2:40 PM Subject: Re: Pietenpol-List: Riblett's Info Tim Willis wrote: > On a Pietenpol with 90hp, seeking more STOL characteristics, I would choose the Riblett GA30U-613.5. On a much faster plane, such as a Zenith 601 or a KR-2, the best choice would be another airfoil, and might be a NACA 4412. It's not really Piet-related, but you bring up something that has interested me for some time. A STOL KR-2 could be a really interesting sport aircraft. I wonder whether the GA30U-613.5 would be suitable for such an application? For the sake of argument, picture a Corvair on the nose and stall and top speeds just within the LSA limit. Owen Sent via BlackBerry from T-Mobile ________________________________________________________________________________
Date: Aug 10, 2008
Good question. Lowell can answer this better than I, for it's mostly theory for me. But I'll try: Most airfoils have far less pitching moment than the Piet. The Piet's reverse pitching moment lets you move the CG back as far as 25 percent back on the airfoil, as you likely know. Most airfoils are closer to the 20 percent mark (the front limit on Piet's range). Accordingly, a BIG assumption might be to move the CG froward a bit, into the 22-20 percent of the chord range when using the Riblett airfoils. Aren't you addressing the "angle of incidence," the angle of the chord of the wing to the airplane's axis. This is the 2 degrees the airfoil is tilted up above the upper longeron (exactly the 1 inch recommended taller front cabane on the Piet) when using BP's airfoil. Piper Cubs have about this same 2 degrees with another airfoil (Clark Y?), and a degree or two is common, I think, on Taylorcraft, Aeroncas, and the like. (Someone else should confirm this.) So I'd start there with a Riblett 613.5, too. The advantage of a Piet is that you can change it some by cutting the cabanes-- start with them taller than you might want, then whittle front or back down slightly and test again. However, the word "test" is operative. Recall that when you change the design, you (or someone) has just become a test pilot. Lowell actually changed his wing, so he is the "go to guy" on this. Roman Bukolt has, or will soon have, a Riblett 612 on his Piet, and he should be another excellent source of information on this. Tim in central TX -----Original Message----- >From: catdesigns(at)att.net >Sent: Aug 10, 2008 3:14 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Riblett's Info > > >Tim and/or Lowell > >How did you decide where is the CG is located and what angle of attack to >use when switching to a 613.5 airfoil? > >Chris Tracy >Sacramento, Ca >Website at http://www.WestCoastPiet.com > > >----- Original Message ----- >From: "Tim Willis" <timothywillis(at)earthlink.net> >To: >Sent: Saturday, August 09, 2008 4:42 PM >Subject: Re: Pietenpol-List: Riblett's Info > > >> >> >> Lowell, >> >> Thanks for posting this. Some may not know of your experience with >> various airfoils. Of course, you are one of the few (maybe the only one) >> who has changed wings on the same plane with the same engine,and changed >> engines with the same wing and plane, and then changed both. You can >> report empirical data on the effect of each of the changes. >> >> I think, based on talking with you about this earlier this year, and our >> more recent discussions at Brodhead, many builders should use either a >> Riblett GA30U-612 or a GA30U-613.5 instead of BP's airfoil. I believe you >> agree with that evaluation as a good decision for all but Piet purists. >> (Room for all instide the tent.) And we have discussed the merits of both >> these Riblett airfoils. >> >> I'd like to lay out some impressions of the 613.5, and see if you will >> confirm or change this post, for the benefit of others considering these >> choices. I'll ask you to pardon me in advance,if I am misinterpreting any >> of our discussions, or if I have crossed them up with similar discussions >> with Bill Rewey or Roman Bukolt. >> >> As you know, and as we have discussed, the 613.5 is "fatter" than the >> other airfoils. You and I have discussed its comparative merits. >> >> For the benefit of others on the board, the 613.5 has more loft on the >> Y-axis and a bigger radius, resulting in more camber. Otherwise it looks >> much like the NACA 2412 or 4412 and the Riblett 612, all of them peaking >> "Y" at 30 percent of the "X" (chord). All of these have better laminarity >> than BP's airfoil in the early part of the airfoil, before the airflow >> "goes turbulent." (All are characterized as "turbulent airfoils," but >> some are more turbulent than others.) >> >> The Riblett GA30U-613.5 seems to me a better choice for a Piet with less >> powerful engines, such as most Model A's (not your fuel-injected baby) or >> Continental A-65s. I think you have agreed with this opinion, perhaps >> even postulated it yourself. >> >> The 613.5 would give the Piet builder a faster climb, better safe payload >> on hot days, etc. A wing built with it would weigh a little more than one >> using a 612 airfoil-- how much more depending upon whether the builder >> uses filler blocks at the top of each spar or a full-height built-up ply >> and wood spar. >> >> Alternatively, the 612 might be better for higher hp Piets. With 100 hp >> or more the pilot gets a faster climb in any event, and the 612 would have >> less drag and allow a faster cruising speed than the 613.5. And as you >> and Mr. Riblett have reported, there are no negatives associated with the >> 612 when compared to BP's original "FC-10" airfoil. (We may not know that >> much about the pitching moment of the 613.5 as yet.) >> >> Do you agree with this discussion of the 613.5 vs. the 612? And with a >> 612 foir higher hp Piets? Is this the right way//a right way to think of >> the choices? >> >> Tim in central TX >> >> -----Original Message----- >>>From: Pieti Lowell <Lowellcfrank(at)yahoo.com> >>>Sent: Aug 9, 2008 11:38 AM >>>To: pietenpol-list(at)matronics.com >>>Subject: Pietenpol-List: Riblett's Info >>> >>> >>> >>>Riblett's letter to Pieti Lowell, ref air foils for a Pietenpol >>> >>> >>> >>> >>>Read this topic online here: >>> >>>http://forums.matronics.com/viewtopic.php?p=197525#197525 >>> >>> >>> >>> >>>Attachments: >>> >>>http://forums.matronics.com//files/riblett_p2_118.jpg >>>http://forums.matronics.com//files/riblett_p1_976.jpg >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 10, 2008
I recall Oscar and someone else posting such postulates and some calculations. This is altogether beyond my ken. IT might be a better discussion on the KR-2 board, but as Owen states about Mark L., most of those guys are trying to hit 200mph, not low and slow. Tim in central TX -----Original Message----- >From: outofthebox50(at)yahoo.com >Sent: Aug 10, 2008 3:32 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Riblett's Info > > >I have spent some time researching the KR-2S. It might be our next build. If you get the stall speed down, the builder can set his own VNE right? > >Jeremy in Dallas >------Original Message------ >From: Owen Davies >Sender: owner-pietenpol-list-server(at)matronics.com >To: pietenpol-list(at)matronics.com >ReplyTo: pietenpol-list(at)matronics.com >Sent: Aug 10, 2008 2:40 PM >Subject: Re: Pietenpol-List: Riblett's Info > > >Tim Willis wrote: >> On a Pietenpol with 90hp, seeking more STOL characteristics, I would choose the Riblett GA30U-613.5. On a much faster plane, such as a Zenith 601 or a KR-2, the best choice would be another airfoil, and might be a NACA 4412. >It's not really Piet-related, but you bring up something that has >interested me for some time. A STOL KR-2 could be a really interesting >sport aircraft. I wonder whether the GA30U-613.5 would be suitable for >such an application? For the sake of argument, picture a Corvair on the >nose and stall and top speeds just within the LSA limit. > >Owen > > >Sent via BlackBerry from T-Mobile > > ________________________________________________________________________________
Date: Aug 10, 2008
outofthebox50(at)yahoo.com wrote: > If you get the stall speed down, the builder can set his own VNE right? I'm not sure how that works. I believe the phrase "prop-limited" has some value. Ditto throttle stops. Yet, I'd hate to build a fast airplane, hoping they would trust me to hold it under my stated VNE. Could waste a lot of time and money that way. Owen ________________________________________________________________________________
Date: Aug 10, 2008
Owen: If a low wing wood built LSA is what you are loking for: http://www.menestrel.org.uk/ Like the Jodel D18 but without the coplexity of the bent wing Michael in Maine ----- Original Message ----- From: "Owen Davies" <owen5819(at)comcast.net> > Thanks, Tim. I know of Mark's plane, but did not think of him for the > Riblett airfoil. My impression was that he was trying to get high-end > performance out of his plane, while I am trying to limit the high end > and extend the bottom end just enough to make sure of being within the > LSA stall requirement. > > Or would be, if this were anything more than a thought exercise. A Piet > is still my first priority--though it could wind up having the wing on > the bottom. > > Owen ________________________________________________________________________________
Date: Aug 10, 2008
Michael Silvius wrote: > If a low wing wood built LSA is what you are loking for: > http://www.menestrel.org.uk/ > > Like the Jodel D18 but without the coplexity of the bent wing It's not that I am specifically looking for a low-wing airplane, nor even necessarily wood construction. I plan to build my Piet with the steel-tube fuselage, for example. (This does feel like sacrilege, even though the master designed it himself, but I really enjoy welding and it will be good practice for any future projects, which almost surely will be steel tube.) It's just that the KR-2 seems like such a natural place to begin for a small, cheap, two-place LSA. That Menestrel really is a pretty plane, though. It reminds me a lot of the Emeraude, a plane I've always loved. And the construction looks pretty simple. The builders' group doesn't seem to have any U.S. members, though. Thanks for pointing it out. Owen ________________________________________________________________________________
Subject: rim width
Date: Aug 11, 2008
On the subject of rims and wheels, where do I get a wide enough (4 inch or so) hub? And can you get a hub with internal drum brakes? Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Skip Gadd Sent: August 8, 2008 4:04 PM Subject: RE: Pietenpol-List: rim width Douwe, Mine are 2.25", tires are 26" OD. Got three rims from motorcycle graveyard, all the same but had different hubs. Skip > [Original Message] > From: Douwe Blumberg <douweblumberg(at)earthlink.net> > To: pietenpolgroup > Date: 8/8/2008 9:12:40 AM > Subject: Pietenpol-List: rim width > > > Hey, > > Building my third set of wheels for this bugger, and Buchannans wants to > know what width rim I want to use. I am going with 21" modern alloy > motorcycle rims, and sounds like there are a few options. Does anyone > remember the width of theirs? > > Douwe > > ________________________________________________________________________________
Date: Aug 11, 2008
Subject: From print to jig...how?
I received my Riblett print today. For those who may not know, it is a full size drawing like the full size Pietenpol rib print. How did you guys get the print transferred to the wood base on you rib jigs? I know someone sandwiched the print under Plexiglas. Any suggestions welcomed. ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: From print to jig...how?
Date: Aug 11, 2008
Mike, Secure your drawing to your jig board. Take a sharp awl, and punch a hole through the paper every 1/2 inch or so. Take up the drawing and connect the dots. Kip Gardner On Aug 11, 2008, at 6:33 PM, Michael Perez wrote: > I received my Riblett print today. For those who may not know, it > is a full size drawing like the full size Pietenpol rib print. How > did you guys get the print transferred to the wood base on you rib > jigs? I know someone sandwiched the print under Plexiglas. Any > suggestions welcomed. > > ________________________________________________________________________________
Date: Aug 11, 2008
I stretched 4mil clear visqueen over mine. Hold downs and positioners are fastened thru the visqueen and the plan and into the backup board. 11 ribs done and can still see all the lines very clearly, although it wouldn't matter as the positioners do their jobs. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (11 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, August 11, 2008 3:34 PM Subject: Pietenpol-List: From print to jig...how? I received my Riblett print today. For those who may not know, it is a full size drawing like the full size Pietenpol rib print. How did you guys get the print transferred to the wood base on you rib jigs? I know someone sandwiched the print under Plexiglas. Any suggestions welcomed. ________________________________________________________________________________
Date: Aug 11, 2008
My mistake, what I-am asking is: is there a way to easily transfer the pl an onto the jig, and keep the original plan intact. I have heard how to sim ply make a copy is not always good, wondering if there is any other way. Th e making holes and connecting the dots is a way I haven't thought of. I gue ss once the jig is made and proven, we don't need the plan, but I would lik e to try and salvage mine. - It seems the easiest is to tape it down, cover with plastic, build. ________________________________________________________________________________
Date: Aug 11, 2008
Mike, It does minimal damage to the plan. Lay out the jig, put the plan away, no problem. Kip Gardner On Aug 11, 2008, at 8:45 PM, Michael Perez wrote: > > My mistake, what I am asking is: is there a way to easily transfer > the plan onto the jig, and keep the original plan intact. I have > heard how to simply make a copy is not always good, wondering if > there is any other way. The making holes and connecting the dots is > a way I haven't thought of. I guess once the jig is made and > proven, we don't need the plan, but I would like to try and salvage > mine. > > It seems the easiest is to tape it down, cover with plastic, build. > > _- > ======================== > 3D=======================3 > D============ > _- > ======================== > 3D=======================3 > D============ > _- > ======================== > 3D=======================3 > D============ > _- > ======================== > 3D=======================3 > D============ > ________________________________________________________________________________
Date: Aug 11, 2008
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Michael.....Michael....Michael Take it to Kinko's...oops I mean FedEx and have them laminate a copy for you...couple of buck and they can do it while you wait. This way you still have your original and the laminated copy works great to keep the glue from sticking to the table. Then...create your jig on top of the lamination! If you question your glue sticking to the lamination....do a small test sample and the next day see if it pops off! No stinking wax paper here baby.....tee-hee-hee... Kenneth M. Heide, BA, CPO, FAAOP --- On Mon, 8/11/08, Michael Perez wrote: > From: Michael Perez <speedbrake(at)sbcglobal.net> > Subject: Re: Pietenpol-List: From print to jig...how? > To: pietenpol-list(at)matronics.com > Date: Monday, August 11, 2008, 7:45 PM > My mistake, what Iam asking is: is there a way to easily > transfer the plan onto the jig, and keep the original plan > intact. I have heard how to simply make a copy is not always > good, wondering if there is any other way. The making holes > and connecting the dots is a way I haven't thought of. I > guess once the jig is made and proven, we don't need the > plan, but I would like to try and salvage mine. > > It seems the easiest is to tape it down, cover with > plastic, build. ________________________________________________________________________________
Date: Aug 12, 2008
Gary, Are you using the Riblett airfoil on your Piet? I got a copy of it from Roman Bulthol (spelling) at Brodhead. I won't put my pictures up from Brodhead as Bill Church did such a great job; but it was great being there and getting to talk to other builders like Rich Navratil, Greg Cardinal, Gary and Shad Bell, Bill Rewery, etc. It was neat to be able to see their planes and ask them why they did what they did. One of the best forums ever was a group of six guys from Atlanta who are building six Piets together. They get together every Monday night, one Saturday a month, and one full six day week every summer. They are just about ready to cover all six Piets. Once they are all done and signed off for flight; they will put all six serial numbers in a hat and have a drawing. Until then no one knows which airplane will be theirs. They did a great job of talking about the whole project and showing a great slide show as they did their presentation. 14 Piets were at Brodhead. Cheers, Jim B. PS we just got back from Brodhead/Oshkosh late last Friday night On Aug 11, 2008, gboothe5(at)comcast.net wrote: I stretched 4mil clear visqueen over mine. Hold downs and positioners are fastened thru the visqueen and the plan and into the backup board. 11 ribs done and can still see all the lines very clearly, although it wouldn’t matter as the positioners do their jobs. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (11 ribs down…) From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, August 11, 2008 3:34 PM Subject: Pietenpol-List: From print to jig...how? I received my Riblett print today. For those who may not know, it is a full size drawing like the full size Pietenpol rib print. How did you guys get the print transferred to the wood base on you rib jigs? I know someone sandwiched the print under Plexiglas. Any suggestions welcomed. http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution ________________________________________________________________________________
From: Marc Davis <marcs_listreading(at)hotmail.com>
Subject: tail wheel
Date: Aug 12, 2008
Has anyone figured the weight of a standard leaf spring type tail wheel as compared to a Piet style tail skid converted to a tail wheel. I know there are many vari ations but I'm trying to decide if I should keep my current leaf spring or build a the original style. I n eed to improve my CG picture. Marc _________________________________________________________________ Reveal your inner athlete and share it with friends on Windows Live. http://revealyourinnerathlete.windowslive.com?locale=en-us&ocid=TXT_TAG LM_WLYIA_whichathlete_us ________________________________________________________________________________
Subject: tail wheel
Date: Aug 12, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Marc, like most things the answer is: "It depends". It depends on how many leaves you have in your leaf spring, how long you make the A-Arm, what diameter tubing and what wall thickness. In my case it saved about 1.5 lbs. I also saved weight by going to the Aircraft Spruce "Homebuilders Special" 4" tailwheel instead of the 6" Scott that I started with. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Marc Davis Sent: Tuesday, August 12, 2008 3:02 PM Subject: Pietenpol-List: tail wheel Has anyone figured the weight of a standard leaf spring type tail wheel as compared to a Piet style tail skid converted to a tail wheel. I know there are many variations but I'm trying to decide if I should keep my current leaf spring or build a the original style. I need to improve my CG picture. Marc _____ Reveal your inner athlete and share it with friends on Windows Live. Share now! <http://revealyourinnerathlete.windowslive.com?locale=en-us&ocid=TXT_TAG LM_WLYIA_whichathlete_us> _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Aug 12, 2008
Mike et al: Regarding the suggestion that you have a copy of your rib drawing made at Kinko's and having it laminated sounds like a great idea. However, let me tell you what can happen if you do. I lofted, very carefully, the GA30U-612 airfoil and took it to a professional engineering firm to have a few copies made. I told them that it must be an exact copy since it would be used on a building jig and the spar locations must be on the mark. I went to pick up the copies and laid out the copy over the original. Registering the leading edge on both and moving left to right, I found that within about 14 inches the copy started to stray from the original. between the spar locations the copy was off by a quarter inch. I called for the manager who said he would do the prints on another digital printer and it should be fine. They did it again and once again we checked for accuracy. It was better this time but the spar locations were still off by one eighth of an inch. I then decided that I would try Kinko's and they assured me they could make an exact copy. We tried it and it was way worse than the engineering blueprint company. It would not be such a big deal if it were not for the spar locations. I finally decided to just use the original under thin clear plastic and am taking very good care of the jig so as to not harm my original. If you decide to try the Kinko's copy routine, just be sure to put the original and the print on a light table to check for accuracy. Another suggestion would be to simply lay down a bunch of carbon paper on the jig board and trace the outline and also use a straight edge for the intercostals and spar locations. Have fun. Bob -------- Robert Butsch EAA 66532 Pietenpol NX45BB (Alpha stage) In Indy IN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=198217#198217 ________________________________________________________________________________
Date: Aug 12, 2008
The simplest way to end up with an undamaged full size Riblett plan, I would think, would be to just buy two prints. Another $10 and you can have one print on the jig, and one in perfect condition for reference or what have you. Ryan On Mon, Aug 11, 2008 at 7:45 PM, Michael Perez wrote: > > My mistake, what I am asking is: is there a way to easily transfer the plan > onto the jig, and keep the original plan intact. I have heard how to simply > make a copy is not always good, wondering if there is any other way. The > making holes and connecting the dots is a way I haven't thought of. I guess > once the jig is made and proven, we don't need the plan, but I would like to > try and salvage mine. > > It seems the easiest is to tape it down, cover with plastic, build. > ________________________________________________________________________________
Subject: tail wheel
Date: Aug 12, 2008
Thanks Jack On West Coast Piet I see both setups on your plane. Which way did you switch? Thanks Marc Subject: RE: Pietenpol-List: tail wheelDate: Tue=2C 12 Aug 2008 15:10:18 -0 400From: Jack.Phillips(at)cardinalhealth.comTo: pietenpol-list(at)matronics.com Marc=2C like most things the answer is: =93It depends=94. It depends on h ow many leaves you have in your leaf spring=2C how long you make the A-Arm =2C what diameter tubing and what wall thickness. In my case it saved abou t 1.5 lbs. I also saved weight by going to the Aircraft Spruce =93Homebuil ders Special=94 4=94 tailwheel instead of the 6=94 Scott that I started wit h. Jack Phillips NX899JP From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Marc DavisSent: Tuesday=2C August 12 =2C 2008 3:02 PMTo: pietenpol-list(at)matronics.comSubject: Pietenpol-List: ta il wheel Has anyone figured the weight of a standard leaf spring type tail wheel as compared to aPiet style tail skid converted to a tail wheel. I know there are many variations but I'm trying to decide if I should keep my current le af spring or build a the original style. I need to improve my CG picture. Marc Reveal your inner athlete and share it with friends on Windows Live. Share now! http://www.matronics.com/contribution ______________________________ ___________________ This message is for the designated recipient only and may contain privilege d=2C proprietary or otherwise private information. If you have received it in error=2C pleas e notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese _________________________________________________________________ Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest http://www.gowindowslive.com/summergames?ocid=TXT_TAGHM ________________________________________________________________________________
Date: Aug 13, 2008
You know, it seems to me it would be just as fast and also absolutely accurate if you just lay out the ordinates on your base with a good ole' bic pen. You guys are spending waaayyyy to much time and money agonizing over this crap. It would be done already and you'd even have two ribs done for show and tell at tomorrows EAA meeting! Next time your wife comes home after spending six hours and burning $30 in gas to save $10 on a new dress you won't have anything to say about it. :-) :-) Clif "Neither can the wave that has passed by be recalled, nor the hour which has passed return again." ~ Ovid Subject: Re: Pietenpol-List: From print to jig...how? The simplest way to end up with an undamaged full size Riblett plan, I would think, would be to just buy two prints. Another $10 and you can have one print on the jig, and one in perfect condition for reference or what have you. Ryan On Mon, Aug 11, 2008 at 7:45 PM, Michael Perez wrote: My mistake, what I am asking is: is there a way to easily transfer the plan onto the jig, and keep the original plan intact. I have heard how to simply make a copy is not always good, wondering if there is any other way. The making holes and connecting the dots is a way I haven't thought of. I guess once the jig is made and proven, we don't need the plan, but I would like to try and salvage mine. It seems the easiest is to tape it down, cover with plastic, build. Checked by AVG - http://www.avg.com 8/12/2008 4:59 PM ________________________________________________________________________________
Subject: Looking for wheels and brakes for my Piet
Date: Aug 12, 2008
It time to put the Piet on wheels. OK guys-anybody out there have wheels or brakes for a 1" axle, I can't find anything but new stuff here in Anchorage and it is really spendy. Not to choosy in Alaska. Rob ________________________________________________________________________________
Date: Aug 13, 2008
Subject: What set of plans do I use??
I have the original artical on building the Pietenpol. I want to build a Piet with a Model A engine and I was wondering if there was a better set of plans to build from, perhaps with a lighter empty weight? I was wondering if the steel fuselage with built-up spars and even 1/4" x 1/4" cap strips would bring the ship in a little lighter? Also my plans lack the details for the steel fuselage, they give the structure details but nothing about the mounting tabs. Anyway, any help, Ideas or opinions are greately apprecated. Charley ________________________________________________________________________________
Date: Aug 13, 2008
Subject: Re: What set of plans do I use??
Charley, If you are using a Model A, make sure and research the archives on the subject of moving your engine forward. I missed this, and was surprised to find this out. It turns out that I am OK with me as the pilot, but I am only 150 lbs. Dan Helsper Poplar Grove, IL. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Subject: Re: With great dismay
Date: Aug 13, 2008
VGhlcmUgYXJlIG5vIFBpZXRzIGluIEhhd2FpaS4gSnVzdCBsYW5kZWQgT2hhcmUgb24gdGhlIHdh eSBiYWNrIGhvbWUgd2l0aCBubyBwcm9qZWN0cyB0byBsb29rIGF0IHRoaXMgcGFzdCB3ZWVrDQoN CkEgd2VlayB3aXRob3V0IGEgUGlldCBqdXN0IHBsYW5lIHN1eA0KDQpKb2huDQpTZW50IGZyb20g bXkgVmVyaXpvbiBXaXJlbGVzcyBCbGFja0JlcnJ5DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0t LS0tDQpGcm9tOiBIZWxzcGVyU2V3QGFvbC5jb20NCg0KRGF0ZTogV2VkLCAxMyBBdWcgMjAwOCAw Njo0ODoxNiANClRvOiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJl OiBQaWV0ZW5wb2wtTGlzdDogV2hhdCBzZXQgb2YgcGxhbnMgZG8gSSB1c2U/Pw0KDQoNCkNoYXJs ZXksDQogDQpJZiB5b3UgYXJlIHVzaW5nIGEgTW9kZWwgQSwgbWFrZSBzdXJlIGFuZCByZXNlYXJj aCB0aGUgYXJjaGl2ZXMgb24gdGhlICANCnN1YmplY3Qgb2YgbW92aW5nIHlvdXIgZW5naW5lIGZv cndhcmQuIEkgbWlzc2VkIHRoaXMsIGFuZCB3YXMgc3VycHJpc2VkIHRvIGZpbmQgIA0KdGhpcyBv dXQuIEl0IHR1cm5zIG91dCB0aGF0IEkgYW0gT0sgd2l0aCBtZSBhcyB0aGUgcGlsb3QsIGJ1dCBJ IGFtIG9ubHkgMTUwIGxicy4gDQogIA0KDQpEYW4gIEhlbHNwZXINClBvcGxhciBHcm92ZSwgSUwu DQoNCg0KDQoNCioqKioqKioqKioqKioqTG9va2luZyBmb3IgYSBjYXIgdGhhdCdzIHNwb3J0eSwg ZnVuIGFuZCBmaXRzIGluIHlvdXIgYnVkZ2V0PyANClJlYWQgcmV2aWV3cyBvbiBBT0wgQXV0b3Mu ICAgICAgDQooaHR0cDovL2F1dG9zLmFvbC5jb20vY2Fycy1CTVctMTI4LTIwMDgvZXhwZXJ0LXJl dmlldz9uY2lkPWFvbGF1dDAwMDUwMDAwMDAwMDE3ICkNCg0K ________________________________________________________________________________
Date: Aug 13, 2008
Plans can be ordered from the Pietenpol family at: http://www.pressenter.com/~apietenp/ Articles on built up spars can be found in the construction section of: www.westcoastpiet.com Don't downsize the rib capstrips. You won't save enough weight to make a difference. Roman Bukolt can comment on the steel tube fuselage. Where are you located Charley? You might have a Pietenpol close by that you can look at. Greg Cardinal Minneapolis ----- Original Message ----- From: "charles loomis" <rameses32(at)yahoo.com> Sent: Wednesday, August 13, 2008 4:59 AM Subject: Pietenpol-List: What set of plans do I use?? > > > I have the original artical on building the Pietenpol. I want to build a > Piet with a Model A engine and I was wondering if there was a better set > of plans to build from, perhaps with a lighter empty weight? I was > wondering if the steel fuselage with built-up spars and even 1/4" x 1/4" > cap strips would bring the ship in a little lighter? Also my plans lack > the details for the steel fuselage, they give the structure details but > nothing about the mounting tabs. > > Anyway, any help, Ideas or opinions are greately apprecated. > Charley > > > ________________________________________________________________________________
Subject: tail wheel
Date: Aug 13, 2008
I originally had a leaf spring. I changed it for the BHP design A-Arm setup Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Marc Davis Sent: Wednesday, August 13, 2008 2:19 AM Subject: RE: Pietenpol-List: tail wheel Thanks Jack On West Coast Piet I see both setups on your plane. Which way did you switch? Thanks Marc _____ Subject: RE: Pietenpol-List: tail wheel Date: Tue, 12 Aug 2008 15:10:18 -0400 From: Jack.Phillips(at)cardinalhealth.com Marc, like most things the answer is: "It depends". It depends on how many leaves you have in your leaf spring, how long you make the A-Arm, what diameter tubing and what wall thickness. In my case it saved about 1.5 lbs. I also saved weight by going to the Aircraft Spruce "Homebuilders Special" 4" tailwheel instead of the 6" Scott that I started with. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Marc Davis Sent: Tuesday, August 12, 2008 3:02 PM Subject: Pietenpol-List: tail wheel Has anyone figured the weight of a standard leaf spring type tail wheel as compared to a Piet style tail skid converted to a tail wheel. I know there are many variations but I'm trying to decide if I should keep my current leaf spring or build a the original style. I need to improve my CG picture. Marc _____ Reveal your inner athlete and share it with friends on Windows Live. Share now! <http://revealyourinnerathlete.windowslive.com/?locale=en-us&ocid=TXT_TA GLM_WLYIA_whichathlete_us> http://www.matronics.com/contribution _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution _____ Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest Find out how. <http://www.gowindowslive.com/summergames?ocid=TXT_TAGHM> _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Aug 13, 2008
I live just outside Port Macquarie, Australia, but I'm originally from Kansas. The last Pietenpol I saw up close was about 15 years ago at K-State Salina, when I was attending for my Avionics courses. It was in a small room upstairs in a hanger, ready for covering. Unfortunately the builder passed away before he finished the ship, his craftsman ship was flawless. I'm sure someone on this list knows the aircraft I am speaking of. Charley --- On Wed, 8/13/08, gcardinal wrote: > From: gcardinal <gcardinal(at)comcast.net> > Subject: Re: Pietenpol-List: What set of plans do I use?? > To: pietenpol-list(at)matronics.com > Date: Wednesday, August 13, 2008, 9:28 PM > "gcardinal" > > Plans can be ordered from the Pietenpol family at: > http://www.pressenter.com/~apietenp/ > > Articles on built up spars can be found in the construction > section of: > www.westcoastpiet.com > > Don't downsize the rib capstrips. You won't save > enough weight to make a > difference. > Roman Bukolt can comment on the steel tube fuselage. > > Where are you located Charley? You might have a Pietenpol > close by that you > can look at. > > Greg Cardinal > Minneapolis > > ----- Original Message ----- > From: "charles loomis" > > To: > Sent: Wednesday, August 13, 2008 4:59 AM > Subject: Pietenpol-List: What set of plans do I use?? > > > loomis > > > > > > I have the original artical on building the Pietenpol. > I want to build a > > Piet with a Model A engine and I was wondering if > there was a better set > > of plans to build from, perhaps with a lighter empty > weight? I was > > wondering if the steel fuselage with built-up spars > and even 1/4" x 1/4" > > cap strips would bring the ship in a little lighter? > Also my plans lack > > the details for the steel fuselage, they give the > structure details but > > nothing about the mounting tabs. > > > > Anyway, any help, Ideas or opinions are greately > apprecated. > > Charley > > > > > > > > > > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Aug 13, 2008
Group, one thing I remember from A+P school, drafting classes and blueprint reading, is don't ever use measurements you physically take from the plans ( with a ruler on the paper).- Go by the published dimension.- I do not know if your full size rib has written dimensions at rib stations.- The reason for this is paper WILL change sizes with expansion, and contraction due to temp, and humididy.- Copy machines will usually not give a perfect 1 to 1 copy (much more noticable on a bigger drawing).- For a Piet or an y other low performance airplane I dont think 1/8 or even 1/4 inch would ma ke too much difference, the airplane would never know the difference.- Th e only thing that is critical would be the spar spacing, so that they all e nd up the same from the center section to the outboard wing pannels.- As a kid I remember building a couple of my early R/C models, and they were no t all top notch streight as an arrow ships, but they all flew, and flew well after trimming them out.- Just keep all the "Identical" pieces as " identical" as you can and don't swet the small stuff. - Just my 2 cents worth, Shad=0A=0A=0A ________________________________________________________________________________
Date: Aug 13, 2008
Try: http://www.airdromeairplanes.com/HeavyDutyWheels.html Looks like I'm going to get mine there. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Rob Stapleton, Jr. Sent: August 13, 2008 3:29 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Looking for wheels and brakes for my Piet It time to put the Piet on wheels. OK guys-anybody out there have wheels or brakes for a 1" axle, I can't find anything but new stuff here in Anchorage and it is really spendy. Not to choosy in Alaska. Rob ________________________________________________________________________________
Subject:
Date: Aug 13, 2008
As much as I hate to... I'll be selling my Piet project in a couple of week s=2C probably putting it on Ebay starting the auction as some very low pric e. Several years ago=2C I bought a project from a guy who was an Air Force mai ntenance officer on both the B-1 and B-2 aircraft. He also is an A&P/IA=2C moved a few times=2C took a job with Cessna after getting out of the milita ry... I bought this about 5 years ago and had plans to finish it with my father =2C but soon after I brought it home=2C my dad passed away=2C thus the proj ect has been gathering dust in my hanger here in Central Texas. It was originally set up for a Corvair=2C but I had planned on putting my C ontinental A-80 on it. The fabric was pulled back off the front of the fuse lage and probably needs to be completely replaced. It is a Piet fuselage wi th Grega wings. The original builder wanted the Grega wings because of the different stall characteristics=2C but he wanted the "looks" of a Pietenpol and built the fuselage from the Piet plans. The wings are covered and painted and it has an "number" already on the win gs=2C but they can be easily painted over. It has Honda CB 350 wheels (they look pretty cool) and I had them powder co ated red (I had planned on painting a Texas flag design or total red for th is project.) The center section was already built=2C but I removed the fabric and lower plywood with the intention of installing a small supplemental fuel tank... I have new plywood and fabric to recover. My dad said there needs to be som e washers welded onto the metal tabs that attach to the wings. I don't know why these were omitted by the original builder. The lift struts are ready to go and I have all the cables. The instrument panel IS NOT INCLUDED. I have a small fortune in the panel a nd I am keeping it (pilot and passenger both) I paid a lot of money for "pr emium carpathian burl elm" veneer that I laminated in a vacuum bag=2C and i t looks like it belongs in a 1930-ish Rolls Royce. Again=2C the panel and g auges are not for sale=2C please don't ask. If anybody is interested=2C please e-mail me off this list at "N900ML@HOTMA IL.COM" and I can provide more info and pictures. I won't be able to send a ny recent pictures anytime soon=2C but can do so sometime in mid September. I'll also be selling the rebuilt A-80 engine FOR PARTS ONLY. I don't want t he liability if someone goes flying and they nose in someday. My dad rebuil t the engine (he had an A&P license) and I simply want the engine to go as a "parts project" with the buyer signing a bill of sale stating this. The engine case was sent to Divco for a rebuild. The accessory case went of f for repair too. The cylinders were sent off and are Cermnil (the nickel b ore process=2C vastly superior to channel chrome=2C satin chrome) The crank was rebuilt I think M03 under. New bearings new=2C rod bolts=2C new Slick mags with dual impulse couplers... Long story made short=2C this engine loo ks like it just came out of the Twilight Zone as if being in a time warp si nce 1941. I also have a rebuilt yellow tagged carb on this engine and the i ntake tubes are powder coated candy apple blue. The valve covers are powde r coated in Continental yellow... I've never seen an A-65 or A-80 that is a s pretty as this engine. This engine even has a new data plate that looks i ncredible. All the info from the old data plate was PROFESSIONALLY engraved onto the new data plate. BUT AGAIN=2C I WANT TO EMPHASIZE THE ENGINE WILL BE SOLD ONLY WITH THE UNDERSTANDING THAT IT IS A "PARTS ENGINE=2C" not some thing that is ready to stab onto an airplane and go flying. The engine will be sold separate from the airplane project. If anybody wants a sneak preview=2C this project can be seen at the airport in Ballinger=2C Texas (between San Angelo and Abilene.) I won't be able to show it until sometime in mid or late September (please don't ask to see i t earlier). RSB _________________________________________________________________ Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest http://www.gowindowslive.com/summergames?ocid=TXT_TAGHM ________________________________________________________________________________
Date: Aug 13, 2008
In 1991 I received my print from H. Riblett, I first checked all the numbers to be sure that the print matched the airfoil, then I taped the print to the base board,and took a pin and went along all the lines punching small holes every half inch, before connecting the dots I rechecked the airfoil. Then I proceeded to finish the shape of the airfoil with a ball point pen. Construction is the same as Pietenpol Between each rib assembly I laid a sheet of Vis-quine,(spelling) and it worked well enough to finish my wing, and it did fly as well as Mr. Riblett predicted. The interesting thing, I recently remeasured the original drawing and it is much different than when I got it. If there is enough interest, I can pass along the Page 4 of Riblett's letter to me that gives these coordinates, and notes, In order to get them to size one must print out the page. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=198374#198374 ________________________________________________________________________________
Date: Aug 13, 2008
Among other comments, Pieti Lowell wrote: > If there is enough interest, I can pass along the Page 4 of Riblett's letter to me that gives these coordinates, and notes, In order to get them to size one must print out the page. > Pieti Lowell I would love to have a copy! Wouldn't surprise me if others felt the same way. Owen ________________________________________________________________________________
Subject: Re: No Title
Date: Aug 13, 2008
got any pictures? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=198379#198379 ________________________________________________________________________________
Date: Aug 13, 2008
Subject: Re: tenpol-List:
Roy, I am sorry for the loss of your father and the drive to finish this pr oject. It is understandable...life will jack you pretty hard at times and t he unforseen futer is always changing. I wish you and yours the best and ho pe that maybe someday, the "building bug" will visit you again. - I am new to this project and am just now getting my wing jigs made. I am al ways looking to purchase what I will need in the future...engine included. If the engine does not sell with the plane, I would be interested in talkin g to you about purchasing it. Please let me know, when you know. Thanks. --- On Wed, 8/13/08, Roy Brooks wrote: From: Roy Brooks <n900ml(at)hotmail.com> Subject: Pietenpol-List: Date: Wednesday, August 13, 2008, 10:07 AM #yiv1594811430 .hmmessage P { margin:0px;padding:0px;} #yiv1594811430 { FONT-SIZE:10pt;FONT-FAMILY:Tahoma;} As much as I hate to... I'll be selling my Piet project in a couple of week s, probably putting it on Ebay starting the auction as some very low price. Several years ago, I bought a project from a guy who was an Air Force maint enance officer on both the B-1 and B-2 aircraft. He also is an A&P/IA, move d a few times, took a job with Cessna after getting out of the military... I bought this about 5 years ago and had plans to finish it with my father, but soon after I brought it home, my dad passed away, thus the project has been gathering dust in my hanger here in Central Texas. It was originally set up for a Corvair, but I had planned on putting my Con tinental A-80 on it. The fabric was pulled back off the front of the fusela ge and probably needs to be completely replaced. It is a Piet fuselage with Grega wings. The original builder wanted the Grega wings because of the di fferent stall characteristics, but he wanted the "looks" of a Pietenpol and built the fuselage from the Piet plans. The wings are covered and painted and it has an "number" already on the win gs, but they can be easily painted over. It has Honda CB 350 wheels (they look pretty cool) and I had them powder co ated red (I had planned on painting a Texas flag design or total red for th is project.) The center section was already built, but I removed the fabric and lower pl ywood with the intention of installing a small supplemental fuel tank... I have new plywood and fabric to recover. My dad said there needs to be some washers welded onto the metal tabs that attach to the wings. I don't know w hy these were omitted by the original builder. The lift struts are ready to go and I have all the cables. The instrument panel IS NOT INCLUDED. I have a small fortune in the panel a nd I am keeping it (pilot and passenger both) I paid a lot of money for "pr emium carpathian burl elm" veneer that I laminated in a vacuum bag, and it looks like it belongs in a 1930-ish Rolls Royce. Again, the panel and gauge s are not for sale, please don't ask. If anybody is interested, please e-mail me off this list at "N900ML@HOTMAIL .COM" and I can provide more info and pictures. I won't be able to send any recent pictures anytime soon, but can do so sometime in mid September. I'll also be selling the rebuilt A-80 engine FOR PARTS ONLY. I don't want t he liability if someone goes flying and they nose in someday. My dad rebuil t the engine (he had an A&P license) and I simply want the engine to go as a "parts project" with the buyer signing a bill of sale stating this. The engine case was sent to Divco for a rebuild. The accessory case went of f for repair too. The cylinders were sent off and are Cermnil (the nickel b ore process, vastly superior to channel chrome, satin chrome) The crank was rebuilt I think M03 under. New bearings new, rod bolts, new Slick mags wit h dual impulse couplers... Long story made short, this engine looks like it just came out of the Twilight Zone as if being in a time warp since 1941. I also have a rebuilt yellow tagged carb on this engine and the intake tube s are powder- coated candy apple blue. The valve covers are powder coated in Continental yellow... I've never seen an A-65 or A-80 that is as pretty as this engine. This engine even has a new data plate that looks incredibl e. All the info from the old data plate was PROFESSIONALLY engraved onto th e new data plate. BUT AGAIN, I WANT TO EMPHASIZE THE ENGINE WILL BE SOLD ON LY WITH THE UNDERSTANDING THAT IT IS A "PARTS ENGINE," not something that is ready to stab onto an airplane and go flying. The engine will be s old separate from the airplane project. If anybody wants a sneak preview, this project can be seen at the airport i n Ballinger, Texas (between San Angelo and Abilene.) I won't be able to sho w it until sometime in mid or late September (please don't ask to see it ea rlier). RSB Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest Find out how. ________________________________________________________________________________
Date: Aug 13, 2008
QSB3ZWVrIGluIEhhd2FpaSBzdXg/ICANCg0KSW50ZXJuZXQgc2lyLCBmb3IgdGhlIFBpZXQgZml4 Lg0KDQogSSBoYXZlbid0IGFjdHVhbGx5IHNlZW4gYSBmbHlpbmcgUGlldCB5ZXQuICBEYWQgd2Fu dHMgdG8gZmx5IHRvIGNob3JwdXMgY2hyaXN0eSBpbiB0aGUgcmFucyB3aGVuIGl0IGNvb2xzIG9m Zi4gIEknbSBob3Bpbmcgd2UgY2FuIHN0b3AgYW5kIGJ1bSBhIHJpZGUgZnJvbSBvbmUgb2YgdGhl IGZseWluZyBQaWV0cywgc291dGggb2YgdXMsICBvbiB0aGUgd2F5LiANCg0KSmVyZW15IGluIERh bGxhcw0KDQpEbyBub3QgYXJjaGl2ZQ0KIA0KU2VudCB2aWEgQmxhY2tCZXJyeSBmcm9tIFQtTW9i aWxlDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAiSm9obiBSZWNpbmUiIDxB bXNhZmV0eUNAYW9sLmNvbT4NCg0KRGF0ZTogV2VkLCAxMyBBdWcgMjAwOCAxMToxOTozNSANClRv OiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJlOiBQaWV0ZW5wb2wt TGlzdDogV2l0aCBncmVhdCBkaXNtYXkNCg0KDQoNCg= ________________________________________________________________________________
Date: Aug 13, 2008
Copy that Shad. My plan has no specific numbers other then the spar locatio ns. To measure and duplicate would be at best, an eyeball copy. What I ened ed up doing was laid tracing paper over the print, copied it and-used a r uler to duplicate the cross members and other straight lines. This traced c opy will be laid on the jig and covered with thin plastic. Took about 30 mi n. to do, saved me an additional $10.00 and I still have my new original. - For those of you who question my eagerness to do things different and ask q uestions: if all we did was follow the crowd, we would still be getting aro und in horse and buggy. --- On Wed, 8/13/08, shad bell wrote: From: shad bell <aviatorbell(at)yahoo.com> Subject: Re: Pietenpol-List: Re: From print to jig...how? Date: Wednesday, August 13, 2008, 8:34 AM Group, one thing I remember from A+P school, drafting classes and blueprint reading, is don't ever use measurements you physically take from the plans ( with a ruler on the paper).- Go by the published dimension.- I do not know if your full size rib has written dimensions at rib stations.- The reason for this is paper WILL change sizes with expansion, and contraction due to temp, and humididy.- Copy machines will usually not give a perfect 1 to 1 copy (much more noticable on a bigger drawing).- For a Piet or an y other low performance airplane I dont think 1/8 or even 1/4 inch would ma ke too much difference, the airplane would never know the difference.- Th e only thing that is critical would be the spar spacing, so that they all e nd up the same from the center section to the outboard wing pannels.- As a kid I remember building a couple of my early R/C models, and they were no t all top notch streight as an arrow ships, but they all flew, and flew well after trimming them out.- Just keep all the "Identical" pieces as " identical" as you can and don't swet the small stuff. - Just my 2 cents worth, Shad 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Aug 13, 2008
Thats what you get for living in paradise. But think how good it will feel to be able to say that you are the first to build (and fly) a Piet in paradise. You can post some pics of you in your Piet flying over one of those volcanoes. Rick On Wed, Aug 13, 2008 at 5:19 AM, John Recine wrote: > There are no Piets in Hawaii. Just landed Ohare on the way back home with > no projects to look at this past week > > A week without a Piet just plane sux > > John > > Sent from my Verizon Wireless BlackBerry > > ------------------------------ > *From*: HelsperSew(at)aol.com > *To*: > *Subject*: Re: Pietenpol-List: What set of plans do I use?? > Charley, > > If you are using a Model A, make sure and research the archives on the > subject of moving your engine forward. I missed this, and was surprised to > find this out. It turns out that I am OK with me as the pilot, but I am only > 150 lbs. > Dan Helsper > Poplar Grove, IL. > > > ------------------------------ > Looking for a car that's sporty, fun and fits in your budget? Read reviews > on AOL Autos<http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017> > . > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Subject: Piet for sale
Date: Aug 13, 2008
Sorry. I didn't put the correct topic on this message=2C but it is in regar d to the Piet project I plan on selling in mid to late September. I used to be on this list a couple of years ago (started the TACO movement) and just wanted to give you guys a heads-up if anyone is looking to "jump-start" an Air Camper and be miles ahead of the game. When this project sells=2C I won't be much help in being able to load the s tuff onto or in a trailer. So=2C be prepared to bring a friend or two... I' ve turned into a decrepit old guy. Stayed tuned... Pictures and info will be available in mid to late Septembe r. (Sorry for the double-post) From: n900ml(at)hotmail.com Subject: Pietenpol-List: Date: Wed=2C 13 Aug 2008 09:07:50 -0500 As much as I hate to... I'll be selling my Piet project in a couple of week s=2C probably putting it on Ebay starting the auction as some very low pric e. Several years ago=2C I bought a project from a guy who was an Air Force mai ntenance officer on both the B-1 and B-2 aircraft. He also is an A&P/IA=2C moved a few times=2C took a job with Cessna after getting out of the milita ry... I bought this about 5 years ago and had plans to finish it with my father =2C but soon after I brought it home=2C my dad passed away=2C thus the proj ect has been gathering dust in my hanger here in Central Texas. It was originally set up for a Corvair=2C but I had planned on putting my C ontinental A-80 on it. The fabric was pulled back off the front of the fuse lage and probably needs to be completely replaced. It is a Piet fuselage wi th Grega wings. The original builder wanted the Grega wings because of the different stall characteristics=2C but he wanted the "looks" of a Pietenpol and built the fuselage from the Piet plans. The wings are covered and painted and it has an "number" already on the win gs=2C but they can be easily painted over. It has Honda CB 350 wheels (they look pretty cool) and I had them powder co ated red (I had planned on painting a Texas flag design or total red for th is project.) The center section was already built=2C but I removed the fabric and lower plywood with the intention of installing a small supplemental fuel tank... I have new plywood and fabric to recover. My dad said there needs to be som e washers welded onto the metal tabs that attach to the wings. I don't know why these were omitted by the original builder. The lift struts are ready to go and I have all the cables. The instrument panel IS NOT INCLUDED. I have a small fortune in the panel a nd I am keeping it (pilot and passenger both) I paid a lot of money for "pr emium carpathian burl elm" veneer that I laminated in a vacuum bag=2C and i t looks like it belongs in a 1930-ish Rolls Royce. Again=2C the panel and g auges are not for sale=2C please don't ask. If anybody is interested=2C please e-mail me off this list at "N900ML@HOTMA IL.COM" and I can provide more info and pictures. I won't be able to send a ny recent pictures anytime soon=2C but can do so sometime in mid September. I'll also be selling the rebuilt A-80 engine FOR PARTS ONLY. I don't want t he liability if someone goes flying and they nose in someday. My dad rebuil t the engine (he had an A&P license) and I simply want the engine to go as a "parts project" with the buyer signing a bill of sale stating this. The engine case was sent to Divco for a rebuild. The accessory case went of f for repair too. The cylinders were sent off and are Cermnil (the nickel b ore process=2C vastly superior to channel chrome=2C satin chrome) The crank was rebuilt I think M03 under. New bearings new=2C rod bolts=2C new Slick mags with dual impulse couplers... Long story made short=2C this engine loo ks like it just came out of the Twilight Zone as if being in a time warp si nce 1941. I also have a rebuilt yellow tagged carb on this engine and the i ntake tubes are powder coated candy apple blue. The valve covers are powde r coated in Continental yellow... I've never seen an A-65 or A-80 that is a s pretty as this engine. This engine even has a new data plate that looks i ncredible. All the info from the old data plate was PROFESSIONALLY engraved onto the new data plate. BUT AGAIN=2C I WANT TO EMPHASIZE THE ENGINE WILL BE SOLD ONLY WITH THE UNDERSTANDING THAT IT IS A "PARTS ENGINE=2C" not some thing that is ready to stab onto an airplane and go flying. The engine will be sold separate from the airplane project. If anybody wants a sneak preview=2C this project can be seen at the airport in Ballinger=2C Texas (between San Angelo and Abilene.) I won't be able to show it until sometime in mid or late September (please don't ask to see i t earlier). RSB Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest Find out how. _________________________________________________________________ Your PC=2C mobile phone=2C and online services work together like never bef ore. ________________________________________________________________________________
Date: Aug 13, 2008
You mean to say Roy Brooks is the same as Sterling Brooks, the Head Honcho of TACO? Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Roy Brooks Sent: Wednesday, August 13, 2008 1:50 PM Subject: Pietenpol-List: Piet for sale Sorry. I didn't put the correct topic on this message, but it is in regard to the Piet project I plan on selling in mid to late September. I used to be on this list a couple of years ago (started the TACO movement) and just wanted to give you guys a heads-up if anyone is looking to "jump-start" an Air Camper and be miles ahead of the game. When this project sells, I won't be much help in being able to load the stuff onto or in a trailer. So, be prepared to bring a friend or two... I've turned into a decrepit old guy. Stayed tuned... Pictures and info will be available in mid to late September. (Sorry for the double-post) _____ From: n900ml(at)hotmail.com Subject: Pietenpol-List: Date: Wed, 13 Aug 2008 09:07:50 -0500 As much as I hate to... I'll be selling my Piet project in a couple of weeks, probably putting it on Ebay starting the auction as some very low price. Several years ago, I bought a project from a guy who was an Air Force maintenance officer on both the B-1 and B-2 aircraft. He also is an A&P/IA, moved a few times, took a job with Cessna after getting out of the military... I bought this about 5 years ago and had plans to finish it with my father, but soon after I brought it home, my dad passed away, thus the project has been gathering dust in my hanger here in Central Texas. It was originally set up for a Corvair, but I had planned on putting my Continental A-80 on it. The fabric was pulled back off the front of the fuselage and probably needs to be completely replaced. It is a Piet fuselage with Grega wings. The original builder wanted the Grega wings because of the different stall characteristics, but he wanted the "looks" of a Pietenpol and built the fuselage from the Piet plans. The wings are covered and painted and it has an "number" already on the wings, but they can be easily painted over. It has Honda CB 350 wheels (they look pretty cool) and I had them powder coated red (I had planned on painting a Texas flag design or total red for this project.) The center section was already built, but I removed the fabric and lower plywood with the intention of installing a small supplemental fuel tank... I have new plywood and fabric to recover. My dad said there needs to be some washers welded onto the metal tabs that attach to the wings. I don't know why these were omitted by the original builder. The lift struts are ready to go and I have all the cables. The instrument panel IS NOT INCLUDED. I have a small fortune in the panel and I am keeping it (pilot and passenger both) I paid a lot of money for "premium carpathian burl elm" veneer that I laminated in a vacuum bag, and it looks like it belongs in a 1930-ish Rolls Royce. Again, the panel and gauges are not for sale, please don't ask. If anybody is interested, please e-mail me off this list at "N900ML(at)HOTMAIL.COM" and I can provide more info and pictures. I won't be able to send any recent pictures anytime soon, but can do so sometime in mid September. I'll also be selling the rebuilt A-80 engine FOR PARTS ONLY. I don't want the liability if someone goes flying and they nose in someday. My dad rebuilt the engine (he had an A&P license) and I simply want the engine to go as a "parts project" with the buyer signing a bill of sale stating this. The engine case was sent to Divco for a rebuild. The accessory case went off for repair too. The cylinders were sent off and are Cermnil (the nickel bore process, vastly superior to channel chrome, satin chrome) The crank was rebuilt I think M03 under. New bearings new, rod bolts, new Slick mags with dual impulse couplers... Long story made short, this engine looks like it just came out of the Twilight Zone as if being in a time warp since 1941. I also have a rebuilt yellow tagged carb on this engine and the intake tubes are powder coated candy apple blue. The valve covers are powder coated in Continental yellow... I've never seen an A-65 or A-80 that is as pretty as this engine. This engine even has a new data plate that looks incredible. All the info from the old data plate was PROFESSIONALLY engraved onto the new data plate. BUT AGAIN, I WANT TO EMPHASIZE THE ENGINE WILL BE SOLD ONLY WITH THE UNDERSTANDING THAT IT IS A "PARTS ENGINE," not something that is ready to stab onto an airplane and go flying. The engine will be sold separate from the airplane project. If anybody wants a sneak preview, this project can be seen at the airport in Ballinger, Texas (between San Angelo and Abilene.) I won't be able to show it until sometime in mid or late September (please don't ask to see it earlier). RSB _____ Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest Find out how. <http://www.gowindowslive.com/summergames?ocid=TXT_TAGHM> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com ="_blank">http://www.matronics.com/contribution _____ Your PC, mobile phone, and online services8587394/direct/01/' target='_new'>See how Windows(r) fits your life This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any o ther use of the email by you is prohibited. Dansk - Deutsch - Espanol - Fr ancais - Italiano - Japanese - Nederlands - Norsk - Portuguese - Svenska: w ww.cardinalhealth.com/legal/email ________________________________________________________________________________
Date: Aug 13, 2008
Jim Boyer Hi Lowell, I would appreciate a copy of the cordinates for the Riblett. I got a drawing of it from Bill Rewey at Brodhead last week but it doesn't have any coordinates. Thanks, Jim On Aug 13, 2008, Lowellcfrank(at)yahoo.com wrote: In 1991 I received my print from H. Riblett, I first checked all the numbers to be sure that the print matched the airfoil, then I taped the print to the base board,and took a pin and went along all the lines punching small holes every half inch, before connecting the dots I rechecked the airfoil. Then I proceeded to finish the shape of the airfoil with a ball point pen. Construction is the same as Pietenpol Between each rib assembly I laid a sheet of Vis-quine,(spelling) and it worked well enough to finish my wing, and it did fly as well as Mr. Riblett predicted. The interesting thing, I recently remeasured the original drawing and it is much different than when I got it. If there is enough interest, I can pass along the Page 4 of Riblett's letter to me that gives these coordinates, and notes, In order to get them to size one must print out the page. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=198374#198374 ________________________________________________________________________________
Date: Aug 13, 2008
I'd love to see page 4, just to check my out my print before I poke it full of holes. Ken On Wed, Aug 13, 2008 at 9:19 AM, Pieti Lowell wrote: > Lowellcfrank(at)yahoo.com> > > In 1991 I received my print from H. Riblett, I first checked all the > numbers to be sure that the print matched the airfoil, then I taped the > print to the base board,and took a pin and went along all the lines punching > small holes every half inch, before connecting the dots I rechecked the > airfoil. Then I proceeded to finish the shape of the airfoil with a ball > point pen. Construction is the same as Pietenpol > Between each rib assembly I laid a sheet of Vis-quine,(spelling) and it > worked well enough to finish my wing, and it did fly as well as Mr. Riblett > predicted. The interesting thing, I recently remeasured the original drawing > and it is much different than when I got it. > If there is enough interest, I can pass along the Page 4 of Riblett's > letter to me that gives these coordinates, and notes, In order to get them > to size one must print out the page. > Pieti Lowell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=198374#198374 > > -- Ken Chambers 512-796-1798 ________________________________________________________________________________
Date: Aug 13, 2008
I have to agree with Clif on this one. I ended up lofting the dimensions for the Piet airfoil off the plans, even though I got the full size rib print with my plan set. As I recall there was a slight difference in size between the spars, However in retrospect, 1/4 inch difference in that distance won't make a bit of difference since all the ribs come off the same jig. If you already have a full size riblet plan, what in the world are you going to do with it after you make your jig?? Don't get too bogged down on the small stuff like this or you'll never get through the things that aren't covered in the plans. Just my 2 cents Ben Charvet Clif Dawson wrote: > You know, it seems to me it would be just as fast and also > absolutely accurate if you just lay out the ordinates on your > base with a good ole' bic pen. > > You guys are spending waaayyyy to much time and money > agonizing over this crap. It would be done already and > you'd even have two ribs done for show and tell at tomorrows > EAA meeting! > > Next time your wife comes home after spending six hours > and burning $30 in gas to save $10 on a new dress you > won't have anything to say about it. :-) :-) > > Clif > > > "Neither can the wave that has passed by be recalled, > nor the hour which has passed return again." > ~ Ovid > > > > > *Subject:* Re: Pietenpol-List: >From print to jig...how? > > The simplest way to end up with an undamaged full size Riblett > plan, I would think, would be to just buy two prints. Another $10 > and you can have one print on the jig, and one in perfect > condition for reference or what have you. > > Ryan > > On Mon, Aug 11, 2008 at 7:45 PM, Michael Perez > > wrote: > > > My mistake, what I am asking is: is there a way to easily > transfer the plan onto the jig, and keep the original plan > intact. I have heard how to simply make a copy is not always > good, wondering if there is any other way. The making holes > and connecting the dots is a way I haven't thought of. I guess > once the jig is made and proven, we don't need the plan, but I > would like to try and salvage mine. > > It seems the easiest is to tape it down, cover with plastic, > build. > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > Checked by AVG - http://www.avg.com > 8/12/2008 4:59 PM > * > > ** > > > ** ________________________________________________________________________________
Date: Aug 13, 2008
Paper will shrink under various atmospheric conditions. In a message dated 8/13/2008 9:19:48 A.M. Central Daylight Time, Lowellcfrank(at)yahoo.com writes: --> Pietenpol-List message posted by: "Pieti Lowell" In 1991 I received my print from H. Riblett, I first checked all the numbers to be sure that the print matched the airfoil, then I taped the print to the base board,and took a pin and went along all the lines punching small holes every half inch, before connecting the dots I rechecked the airfoil. Then I proceeded to finish the shape of the airfoil with a ball point pen. Construction is the same as Pietenpol Between each rib assembly I laid a sheet of Vis-quine,(spelling) and it worked well enough to finish my wing, and it did fly as well as Mr. Riblett predicted. The interesting thing, I recently remeasured the original drawing and it is much different than when I got it. If there is enough interest, I can pass along the Page 4 of Riblett's letter to me that gives these coordinates, and notes, In order to get them to size one must print out the page. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=198374#198374 **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Date: Aug 13, 2008
Subject: Re: From print to jig...how?
Dear Pieti, I, too, have the full-size Riblett template. I intend to use the airfoil on my GN-1. If it's not too much trouble I'd like for you to send me what you've got. I think your information would give me a more broad understanding of this airfoil- of which knowledge, of course, I could pass on to younger airplane nuts. Yours, Al Lyscars Manchester, NH ----- Original Message ----- From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> Sent: Wednesday, August 13, 2008 10:19 AM Subject: Pietenpol-List: Re: From print to jig...how? > > > In 1991 I received my print from H. Riblett, I first checked all the > numbers to be sure that the print matched the airfoil, then I taped the > print to the base board,and took a pin and went along all the lines > punching small holes every half inch, before connecting the dots I > rechecked the airfoil. Then I proceeded to finish the shape of the airfoil > with a ball point pen. Construction is the same as Pietenpol > Between each rib assembly I laid a sheet of Vis-quine,(spelling) and it > worked well enough to finish my wing, and it did fly as well as Mr. > Riblett predicted. The interesting thing, I recently remeasured the > original drawing and it is much different than when I got it. > If there is enough interest, I can pass along the Page 4 of Riblett's > letter to me that gives these coordinates, and notes, In order to get them > to size one must print out the page. > Pieti Lowell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=198374#198374 > > > ________________________________________________________________________________
Date: Aug 13, 2008
From: Tim Verthein <minoxphotographer(at)yahoo.com>
Subject: Waldo Update
Egad David! You must have hit it lucky. I went to warshows.com and looked up the Great Waldo Pepper. Here's the listing: "GREAT WALDO PEPPER SKU: AC54,AC54DVD (1975) Lots of flying and lots of fun in this great Redford flying festival film. Robert Redford, Bo Svenson. 107 min. This title has been out of print for awhile. Available on VHS (MAY BE USED), AND DVD PRICE: $99.98 $99.98 VHS $99.98 DVD" I consider sending out freebie copies to be a service to the aviation community and a somewhat slap in the face to the movie company and collectors. This is the sort of movie that generally winds up in sale bins at walmart for $5 that nobody buys because they've never heard of it. For some reason it's been out of print for years. I've mailed out a mountain of these the past few days and if you're one of those who e-mailed me for one you should have it shortly. Enjoy them. If you didn't email me for one but posted to the list only, I *may* miss you. Tim in Bovey Gentleman, I bought a copy of the Waldo Pepper DVD while at Oshkosh for $32.00 (New). The vendor imports the DVD's from Germany. The DVD cover is in German, but the movie is in English. The movie is titled "Tollkuhne Flieger" with Robert Redford. If anyone is interested go to www.warshows.com or call at 1-973-328-8488. Take care, David ________________________________________________________________________________
Date: Aug 13, 2008
Why does it matter so much that I want to keep the print in nice condition? - I'm not asking about sizes, shapes, measurements, etc. I just wanted to know how to transfer the lines from one to another. Is that so wrong? Simp le question, I thought. --- On Wed, 8/13/08, Ben Charvet wrote: From: Ben Charvet <bcharvet(at)bellsouth.net> Subject: Re: Pietenpol-List: From print to jig...how? Date: Wednesday, August 13, 2008, 3:18 PM I have to agree with Clif on this one. I ended up lofting the dimensions for the Piet airfoil off the plans, even though I got the full size rib print with my plan set. As I recall there was a slight difference in size between the spars, However in retrospect, 1/4 inch difference in that distance won't make a bit of difference since all the ribs come off the same jig. If you already have a full size riblet plan, what in the world are you going to do with it after you make your jig?? Don't get too bogged down on the small stuff like this or you'll never get through the things that aren't covered in the plans. Just my 2 cents Ben Charvet Clif Dawson wrote: > You know, it seems to me it would be just as fast and also > absolutely accurate if you just lay out the ordinates on your > base with a good ole' bic pen. > > You guys are spending waaayyyy to much time and money > agonizing over this crap. It would be done already and > you'd even have two ribs done for show and tell at tomorrows > EAA meeting! > > Next time your wife comes home after spending six hours > and burning $30 in gas to save $10 on a new dress you > won't have anything to say about it. :-) :-) > > Clif > > > "Neither can the wave that has passed by be recalled, > nor the hour which has passed return again." > ~ Ovid > > > > > *Subject:* Re: Pietenpol-List: >From print to jig...how? > > The simplest way to end up with an undamaged full size Riblett > plan, I would think, would be to just buy two prints. Another $10 > and you can have one print on the jig, and one in perfect > condition for reference or what have you. > > Ryan > > On Mon, Aug 11, 2008 at 7:45 PM, Michael Perez > > wrote: > > > My mistake, what I am asking is: is there a way to easily > transfer the plan onto the jig, and keep the original plan > intact. I have heard how to simply make a copy is not always > good, wondering if there is any other way. The making holes > and connecting the dots is a way I haven't thought of. I guess > once the jig is made and proven, we don't need the plan, but I > would like to try and salvage mine. > > It seems the easiest is to tape it down, cover with plastic, > build. > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > Checked by AVG - http://www.avg.com > 8/12/2008 4:59 PM > * > > ** > > > ** ________________________________________________________________________________
Date: Aug 13, 2008
I just covered my jig material with carbon paper, laid the full size print on top and traced it with a blunt nail. No damage to source and a nice copy on the jig. Jim On Wed, Aug 13, 2008 at 7:04 PM, Michael Perez wrote: > Why does it matter so much that I want to keep the print in nice > condition? I'm not asking about sizes, shapes, measurements, etc. I just > wanted to know how to transfer the lines from one to another. Is that so > wrong? Simple question, I thought. > > > --- On *Wed, 8/13/08, Ben Charvet * wrote: > > From: Ben Charvet <bcharvet(at)bellsouth.net> > Subject: Re: Pietenpol-List: From print to jig...how? > To: pietenpol-list(at)matronics.com > Date: Wednesday, August 13, 2008, 3:18 PM > > > > > I have to agree with Clif on this one. I ended up lofting the > dimensions for the Piet airfoil off the plans, even though I got the > full size rib print with my plan set. As I recall there was a slight > difference in size between the spars, However in retrospect, 1/4 inch > difference in that distance won't make a bit of difference since all the > ribs come off the same jig. If you already have a full size riblet > plan, what in the world are you going to do with it after you make your > jig?? Don't get too bogged down on the small stuff like this or you'll > > never get through the things that aren't covered in the plans. > > Just my 2 cents > > Ben Charvet > > > Clif Dawson wrote: > > You know, it seems to me it would be just as fast and also > > absolutely accurate if you just lay out the ordinates on your > > base with a good ole' bic pen. > > > > You guys are spending waaayyyy to much time and money > > agonizing over this crap. It would be done already and > > you'd even have two ribs done for show and tell at tomorrows > > EAA meeting! > > > > Next time your wife comes home after spending six hours > > and burning $30 in gas to save $10 on a new dress you > > won't have anything to say about it. :-) :-) > > > > Clif > > > > > > "Neither can the wave that has passed by be recalled, > > nor the hour which has passed return again." > > ~ Ovid > > > > > > > > > > *Subject:* Re: Pietenpol-List: >From print to jig...how? > > > > The simplest way to end up with an undamaged full size Riblett > > plan, I would think, would be to just buy two prints. Another $10 > > and you can have one print on the jig, and one in perfect > > condition for reference or what have you. > > > > Ryan > > > > On Mon, Aug 11, 2008 at 7:45 PM, Michael Perez > > > wrote: > > > > > > My mistake, what I am asking is: is there a way to easily > > transfer the plan onto the jig, and keep the original plan > > intact. I have heard how to simply make a copy is not always > > good, wondering if there is any other way. The making holes > > and connecting the dots is a way I haven't thought of. I guess > > once the jig is made and proven, we don't need the plan, but I > > would like to try and salvage mine. > > > > It seems the easiest is to tape it down, cover with plastic, > > build. > > > > * > > > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > > > href="http://forums.matronics.com">http://forums.matronics.com > > > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > Checked by AVG - http://www.avg.com > > 8/12/2008 4:59 PM > > * > > > > ** > > > > > > ** > > > * > > 3D > * > > ________________________________________________________________________________
Date: Aug 14, 2008
For those who may not be aware, a spreadsheet of the 612 section with co-orgdinates was posted here a while ago. JohnW ---- Original Message ---- From: owen5819(at)comcast.net Subject: Re: Pietenpol-List: Re: From print to jig...how? Date: Wed, 13 Aug 2008 10:41:57 -0400 > > >Among other comments, Pieti Lowell wrote: >> If there is enough interest, I can pass along the Page 4 of >Riblett's letter to me that gives these coordinates, and notes, In >order to get them to size one must print out the page. >> Pieti Lowell >I would love to have a copy! Wouldn't surprise me if others felt the >same way. > >Owen > > ________________________________________________________________________________
Date: Aug 14, 2008
Subject: Route 3/4" spar?
I am have decided to use solid Sitka 3/4" spars with my Riblett ribs. My qu estions are now as follows:-should I route out the front 3/4" spar? Shoul d I do both? Rear only? Neither? ________________________________________________________________________________
Subject: TACO
Date: Aug 14, 2008
I, too, am a card-carrying full Colonel in the TACO organization. I have to caution some of you about Mike Cuy... being a yankee, Sterling issued Mike a "green card" for undocumented aliens. I'll bet he even eats salsa that comes out of a jar and eats tamales with the shuck still on 'em. As to transferring the outline of a wing rib plan to a board or another piece of paper, I used my wife's pattern tracer from her sewing stuff. It looks like a miniature pizza cutter but with little teeth on the rim of the wheel. As you follow the outline of your template, the wheel makes a continuous string of tiny holes. You pull off your template and go over the row of holes with the edge of a pencil to define the line, then get a flexible stick or ship's curve (if you have one) along the edge and fair in a nice true dark line. that's what I did on my Flying Squirrel. I agonized over getting it exact whereas a quick glance at the prototype shows that the designer simply built and flew, with very little concern for exactitude. His flew long ago, mine ain't yet. Moral of the story: don't worry about precision. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Route 3/4" spar?
Date: Aug 14, 2008
Neither Hans -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Thu, 14 Aug 2008 7:09 am Subject: Pietenpol-List: Route 3/4" spar? I am have decided to use solid Sitka 3/4" spars with my Riblett ribs. My questions are now as follows:should I route out the front 3/4" spar? Should I do both? Rear only? Neither? D======================= =========== D======================= =========== D3D====3 D======================= =========== D======================= =========== ________________________________________________________________________________
Date: Aug 14, 2008
Niether.... >From: Michael Perez <speedbrake(at)sbcglobal.net> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Route 3/4" spar? >Date: Thu, 14 Aug 2008 05:09:21 -0700 (PDT) > >I am have decided to use solid Sitka 3/4" spars with my Riblett ribs. My >questions are now as follows:should I route out the front 3/4" spar? >Should I do both? Rear only? Neither? ________________________________________________________________________________
Date: Aug 14, 2008
Neither Dan Helsper Poplar Grove, IL. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 ) ________________________________________________________________________________
Date: Aug 14, 2008
None of the above. On Thu, Aug 14, 2008 at 6:09 AM, Michael Perez wrote: > I am have decided to use solid Sitka 3/4" spars with my Riblett ribs. My > questions are now as follows: should I route out the front 3/4" spar? Should > I do both? Rear only? Neither? > > * > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Subject: Aileron hinge
Date: Aug 14, 2008
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Awhile back, on another subject, someone stated they installed their aileron hinge before cutting the aileron free. I'm trying to figure out how to do that. Was it a temporary attachment? Also, after temporarily mounting the hinge, have people had problems with a fit after covering? I'm planning on using a full length piano hinge. If it binds, I will cut into sections after it is attached. Thanks, Jack www.textors.com ________________________________________________________________________________
Date: Aug 14, 2008
Hi Jack......I installed my hinges before cutting the aileron free from the wing. It worked out great, BUT, I used the modified strap hinges as per the plans. They will simply poke through a slot in the fabric when covered. I don't see how you would be able to fit up a piano hinge before cutting the aileron free.... Ed Grentzer >From: "Jack T. Textor" <jtextor(at)thepalmergroup.com> >Reply-To: pietenpol-list(at)matronics.com >To: >Subject: Pietenpol-List: Aileron hinge >Date: Thu, 14 Aug 2008 09:33:38 -0500 > >Awhile back, on another subject, someone stated they installed their >aileron hinge before cutting the aileron free. I'm trying to figure out >how to do that. Was it a temporary attachment? Also, after temporarily >mounting the hinge, have people had problems with a fit after covering? >I'm planning on using a full length piano hinge. If it binds, I will >cut into sections after it is attached. > >Thanks, > >Jack > >www.textors.com > > ________________________________________________________________________________
Date: Aug 14, 2008
So, what you guys are trying to tell me is to route both spars down to 1/4" and use lots of lightning holes?-- - Thanks for the replys. Sounds like solid it is. ________________________________________________________________________________
Date: Aug 14, 2008
Subject: Re: Waldo Update
Tim, I just called the phone number for Belle & Blade War Video (www.warshows.com) [1-800-365-2104] and spoke to Linda concerning "The Great Waldo Pepper" movie DVD. She said that it is in stock for $32.00 (imported from Germany) and to call her and ask for the movie and it is not listed on the web site or catalog currently, they need to update. I've been trying to find the old TV series "The Tales of the Golden Monkey" which Linda is working on. Does anyone remember this series about 25 years ago? Good Luck, David On Wed, Aug 13, 2008 at 6:24 PM, Tim Verthein wrote: > minoxphotographer(at)yahoo.com> > > Egad David! You must have hit it lucky. I went to warshows.com and looked > up the Great Waldo Pepper. Here's the listing: > "GREAT WALDO PEPPER > SKU: AC54,AC54DVD > (1975) Lots of flying and lots of fun in this great Redford flying festival > film. Robert Redford, Bo Svenson. 107 min. This title has been out of print > for awhile. Available on VHS (MAY BE USED), AND DVD > PRICE: $99.98 > $99.98 VHS > $99.98 DVD" > > I consider sending out freebie copies to be a service to the aviation > community and a somewhat slap in the face to the movie company and > collectors. This is the sort of movie that generally winds up in sale bins > at walmart for $5 that nobody buys because they've never heard of it. For > some reason it's been out of print for years. > > I've mailed out a mountain of these the past few days and if you're one of > those who e-mailed me for one you should have it shortly. Enjoy them. If > you didn't email me for one but posted to the list only, I *may* miss you. > > Tim in Bovey > > Gentleman, > > I bought a copy of the Waldo Pepper DVD while at Oshkosh for $32.00 > (New). > The vendor imports the DVD's from Germany. The DVD cover is in > German, but > the movie is in English. The movie is titled "Tollkuhne Flieger" with > Robert Redford. If anyone is interested go to www.warshows.com > or call at 1-973-328-8488. > > Take care, > David > > ________________________________________________________________________________
Date: Aug 14, 2008
Subject: Re: Aileron hinge
Jack, Can't remember the details, but I cut the aileron away before installing the hinge. Just took time to get the top edges even before securing the hinge. I used the nutplates from AS&S inside held with tiny brass screws, that I got from a hobby store. Just lay them out so they don't interfere with any rib, with the spacing. Used flat head screws, so's not to interfere I had no problem with fit after I covered, then put the hinge back on. My full length hinge never seemed to bind at all. Very happy with it thanks to Mike Cuy's recomendation. Don't waste money on the extruded hinge. The basic rolled hinge is fine. That's what they use on the highspeed planes, so it's OK for us walt evans NX140DL ----- Original Message ----- From: Jack T. Textor To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 10:33 AM Subject: Pietenpol-List: Aileron hinge Awhile back, on another subject, someone stated they installed their aileron hinge before cutting the aileron free. I'm trying to figure out how to do that. Was it a temporary attachment? Also, after temporarily mounting the hinge, have people had problems with a fit after covering? I'm planning on using a full length piano hinge. If it binds, I will cut into sections after it is attached. Thanks, Jack www.textors.com ________________________________________________________________________________
Date: Aug 14, 2008
David: Was'nt that one the one with the Grumman Mallard and the little black eye Jack Russel terrier. Michael in Maine ----- Original Message ----- From: David Jones I've been trying to find the old TV series "The Tales of the Golden Monkey" which Linda is working on. Does anyone remember this series about 25 years ago? Good Luck, David ________________________________________________________________________________
Date: Aug 14, 2008
Michael, Yes, that's the series. It was set at Key West or somewhere in the Caribbean and they would fly from one island to another with their adventures. I spoke to the people at Amazon about the subject, but never heard anything. Take care, David On Thu, Aug 14, 2008 at 1:23 PM, Michael Silvius wrote: > David: > > Was'nt that one the one with the Grumman Mallard and the little black eye > Jack Russel terrier. > > Michael in Maine > > > ----- Original Message ----- > *From:* David Jones > > I've been trying to find the old TV series "The Tales of the Golden Monkey" > which Linda is working on. Does anyone remember this series about 25 years > ago? > > Good Luck, > David > > * > > * > > ________________________________________________________________________________
Date: Aug 14, 2008
I did the same thing. Works fine and flies to--Jim Lagowski ----- Original Message ----- From: walt To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 1:21 PM Subject: Re: Pietenpol-List: Aileron hinge Jack, Can't remember the details, but I cut the aileron away before installing the hinge. Just took time to get the top edges even before securing the hinge. I used the nutplates from AS&S inside held with tiny brass screws, that I got from a hobby store. Just lay them out so they don't interfere with any rib, with the spacing. Used flat head screws, so's not to interfere I had no problem with fit after I covered, then put the hinge back on. My full length hinge never seemed to bind at all. Very happy with it thanks to Mike Cuy's recomendation. Don't waste money on the extruded hinge. The basic rolled hinge is fine. That's what they use on the highspeed planes, so it's OK for us walt evans NX140DL ----- Original Message ----- From: Jack T. Textor To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 10:33 AM Subject: Pietenpol-List: Aileron hinge Awhile back, on another subject, someone stated they installed their aileron hinge before cutting the aileron free. I'm trying to figure out how to do that. Was it a temporary attachment? Also, after temporarily mounting the hinge, have people had problems with a fit after covering? I'm planning on using a full length piano hinge. If it binds, I will cut into sections after it is attached. Thanks, Jack www.textors.com href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Checked by AVG - http://www.avg.com 8/13/2008 4:14 PM ________________________________________________________________________________
Date: Aug 14, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
That's pretty much what I did, although I didn't trust the little brass screws to always hold the nutplates in place, so I epoxied them in place as well as screwed them on. I followed Tony Bingelis' advice and made my piano hinges in multiple pieces and would NOT recommend doing it that way - it was a bear getting them to all line up properly and nay binding caused by wing deflection would be no worse than the binding caused by all those little hinges not being perfectly aligned with each other. I also used the expensive extruded hinges and would NOT recommend that either. Too expensive and no benefit over the rolled hinges. Over all, I really like the piano hinge installation since it also seals the gaps between the ailerons and the wing, but if I had it to do over again I would use rolled hinges and make them one-piece. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt Sent: Thursday, August 14, 2008 1:22 PM Subject: Re: Pietenpol-List: Aileron hinge Jack, Can't remember the details, but I cut the aileron away before installing the hinge. Just took time to get the top edges even before securing the hinge. I used the nutplates from AS&S inside held with tiny brass screws, that I got from a hobby store. Just lay them out so they don't interfere with any rib, with the spacing. Used flat head screws, so's not to interfere I had no problem with fit after I covered, then put the hinge back on. My full length hinge never seemed to bind at all. Very happy with it thanks to Mike Cuy's recomendation. Don't waste money on the extruded hinge. The basic rolled hinge is fine. That's what they use on the highspeed planes, so it's OK for us walt evans NX140DL ----- Original Message ----- From: Jack T. Textor <mailto:jtextor(at)thepalmergroup.com> To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 10:33 AM Subject: Pietenpol-List: Aileron hinge Awhile back, on another subject, someone stated they installed their aileron hinge before cutting the aileron free. I'm trying to figure out how to do that. Was it a temporary attachment? Also, after temporarily mounting the hinge, have people had problems with a fit after covering? I'm planning on using a full length piano hinge. If it binds, I will cut into sections after it is attached. Thanks, Jack www.textors.com href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any o ther use of the email by you is prohibited. Dansk - Deutsch - Espanol - Fr ancais - Italiano - Japanese - Nederlands - Norsk - Portuguese - Svenska: w ww.cardinalhealth.com/legal/email ________________________________________________________________________________
Date: Aug 14, 2008
Took mine down to 1/8" (lighter that way). On Thu, Aug 14, 2008 at 9:29 AM, Michael Perez wrote: > So, what you guys are trying to tell me is to route both spars down to 1/4" > and use lots of lightning holes? > > Thanks for the replys. Sounds like solid it is. > > * > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Subject: Aileron hinges
Date: Aug 14, 2008
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
Jack, I cut both ailerons free, sanded the faces smooth then installed the piano hinge and nut plates ala Walt Evan's and others (seen in upper portion of photo along with coiled up aileron cables) using aluminum extruded piano hinge. I believe you could use formed hinges rather than extruded but Bingelis said the extruded ones are more reliable if aileron flutter is encountered. (then again aileron flutter to a Pietenpol is probably about as chancy as having excess rates of climb) I used full-length hinges as I believe it is more difficult to align sections of them so I steered clear of that method---plus if you use the full-span you essentially have a gap-filler there where you make the hinge top/line even with the top of the wing and the aileron eliminating the necessity of putting clear tape or matching fabric tape over that gap to keep the aileron effectiveness up. Mike C. ________________________________________________________________________________
Date: Aug 14, 2008
Subject: Re: Aileron hinges
Mike, What are those two parallel pieces running down the center of your wing that look like wood cap strip material? Dan Helsper Poplar Grove, IL. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-Volkswagen-Jetta-2009/expert-review?ncid=aolaut00030000000007 ) ________________________________________________________________________________
Subject: in lieu of inter-rib lacing tape....wing bay explaination
Date: Aug 14, 2008
Dan, Good eyes. That is capstrip material glued the length of the wing ribs to help stabilize the ribs and keep them in position under the forces they experience when you heat taughten your dacron fabric. The standard practice is/was to wrap and then criss-cross inter-rib-lacing tape (like basements have X's in between floor joists ?) to help hold the ribs in place but I'm told that mice like to eat that stuff and it tends to deteriorate over time. Frank Pavliga advised me to simply glue in strips of leftover capstrip material (actually I think I just ordered more to do this job) for this purpose and it worked out great. One additional comment--I was really surprised by all of the creaking and groaning that the wood did as I tightened the fabric with my iron at the three increasingly higher shrink temperatures. Fabric is powerful. Mike C. ________________________________________________________________________________
Date: Aug 14, 2008
oh oh....someone doesn't have the video.... ----- Original Message ----- From: HelsperSew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 3:23 PM Subject: Re: Pietenpol-List: Aileron hinges Mike, What are those two parallel pieces running down the center of your wing that look like wood cap strip material? Dan Helsper Poplar Grove, IL. ------------------------------------------------------------------------- ----- Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. ________________________________________________________________________________
Date: Aug 14, 2008
Just don't use spars at all. It will be really light. Seriously, Ok to route 1", I wouldn't route 3/4" Barry ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 3:11 PM Subject: Re: Pietenpol-List: Route 3/4" spar? Took mine down to 1/8" (lighter that way). On Thu, Aug 14, 2008 at 9:29 AM, Michael Perez wrote: So, what you guys are trying to tell me is to route both spars down to 1/4" and use lots of lightning holes? Thanks for the replys. Sounds like solid it is. -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 14, 2008
Yea, it was about some guys in the South Pacific flying around. I would think they would have it, though, it wasn't THAT unknown at the time. Gene ----- Original Message ----- From: David Jones<mailto:planecrazy2020(at)gmail.com> To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 2:11 PM Subject: Re: Pietenpol-List: Waldo Update Michael, Yes, that's the series. It was set at Key West or somewhere in the Caribbean and they would fly from one island to another with their adventures. I spoke to the people at Amazon about the subject, but never heard anything. Take care, David On Thu, Aug 14, 2008 at 1:23 PM, Michael Silvius > wrote: David: Was'nt that one the one with the Grumman Mallard and the little black eye Jack Russel terrier. Michael in Maine ----- Original Message ----- From: David Jones<mailto:planecrazy2020(at)gmail.com> I've been trying to find the old TV series "The Tales of the Golden Monkey" which Linda is working on. Does anyone remember this series about 25 years ago? Good Luck, David http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Aug 14, 2008
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: John Deere alternator
Fellow Pieter's....... - I have a brand new (in-the-box) never opened John Deere Alternator for sale . It is the one recommended by William Wynne for the Corvair installation. It retails for $260.10......anyone interested?.....200.00 and it is yours! - 701-793-3030 or email me Kenneth M. Heide, BA, CPO, FAAOP - =0A=0A=0A ________________________________________________________________________________
Date: Aug 14, 2008
Subject: Re: tenpol-List:spark plugs
Maybe some of you guys have run into this but it's my first time and I have to say if the right person had not come along at the right time it would have cost me a bundle.I changed the harness and then I was in the process of changinging the spark plugs when the AME(aircraft maintenance engineer)came up to me and asked what I was doing.I said I'm changing the plugs but I'm convinced that's not the problem and that it was the mags were going bad.He said"what's the gap your using?" I said .25 and he said use .15;that mag can't keep up with the .25 and it will fail.I do as he said because he said they use the same gap in the tow plane and it works fine.Now shes running like a sowing machine.I took her up for a flight and it was glorious. I owe that guy a lot and he never even hung around for a thankyou. Next time I see him I'll have to find out what his poison is!Now you know ;check the spark plug gap when things get rough or don't work at all. ________________________________________________________________________________
Date: Aug 14, 2008
yes a lot of the mags need a small gap-another tip-if you have the mag off-don't spin it unless the plug contacts are grounded or crank the engine with the wires off and the ignition on unless the wires are grounded.another way to cook it.Raymond Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=198661#198661 ________________________________________________________________________________
Subject: old engine for sale
Date: Aug 14, 2008
Hello, Pieters; I got an email from a gent who asked that I post this for anyone who might be interested. I know nothing else about this engine. -------------------------- This is an estate sale of old aircraft and parts that are up for bid. I saw this engine and thought that perhaps someone might find it to be of interest and perhaps even of use: http://www.dtroneaircraftcollection.com/index.php?option=com_content&task=view&id=38&Itemid=40 12. Globe Aero engine - "1930", 50 h.p., air-cooled, upright, 4-cylinder; uses many Ford model A parts; no accessories. (A conversation piece) Included is the July 1930 "Aero Digest" article showing photos and drawings and giving performance data and full descriptions of the engine and its parts. A copy of the article in the March 1997 "Experimenter", titled "Light Plane Heritage: Liquid or Air Cooling?" with photos and description of the Globe is also included. Appraised value $1,500. There's a couple of pictures of the engine on the site. It's a four-cylinder, air-cooled engine. It appears to have one magneto and a single updraft carburetor. The rockers are exposed. There's a swing-out engine mount attached. No prop hub is visible. I have no connection to the sale and just happened across the listing. Regards to all,David PauleBoulder, CO ---------------- Oscar Zuniga San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 14, 2008
Subject: Re: old engine for sale
This engine is part of Denny Trone's collection that is up for sale. Denny was a fixture at Brodhead, who passed on in the crash of a Dormoy Bathtub a couple months ago. I had the opportunity to be given a short tour of his collection a number of years back, and it was pretty amazing. I would recommend going to the site and browsing through the items for sale. There are numerous pictures of each item, be it aircraft or engine, and a short history of each as well. There are many one of a kind antique aircraft and engines in there. Pretty neat. Ryan On Thu, Aug 14, 2008 at 9:39 PM, Oscar Zuniga wrote: > > > Hello, Pieters; I got an email from a gent who asked that I post this for > anyone who might be interested. I know nothing else about this engine. > -------------------------- > This is an estate sale of old aircraft and parts that are up for bid. I saw > this engine and thought that perhaps someone might find it to be of interest > and perhaps even of use: > http://www.dtroneaircraftcollection.com/index.php?option=com_content&task=view&id=38&Itemid=4012. > > Globe Aero engine - "1930", 50 h.p., air-cooled, upright, 4-cylinder; uses > many Ford model A parts; no accessories. (A conversation piece) Included is > the July 1930 "Aero Digest" article showing photos and drawings and giving > performance data and full descriptions of the engine and its parts. A copy > of the article in the March 1997 "Experimenter", titled "Light Plane > Heritage: Liquid or Air Cooling?" with photos and description of the Globe > is also included. Appraised value $1,500. There's a couple of pictures of > the engine on the site. It's a four-cylinder, air-cooled engine. It appears > to have one magneto and a single updraft carburetor. The rockers are > exposed. There's a swing-out engine mount attached. No prop hub is visible. > I have no connection to the sale and just happened across the listing. > Regards to all,David PauleBoulder, CO > ---------------- > > Oscar Zuniga > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > ________________________________________________________________________________
Date: Aug 14, 2008
Yeah, Eismann mag's use .018" walt evans NX140DL ----- Original Message ----- From: H RULE To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 9:35 PM Subject: Re: Pietenpol-List:spark plugs Maybe some of you guys have run into this but it's my first time and I have to say if the right person had not come along at the right time it would have cost me a bundle.I changed the harness and then I was in the process of changinging the spark plugs whenthe AME(aircraft maintenance engineer)came up to me and asked what I was doing.I said I'm changing the plugs but I'm convinced that'snot the problem and that it was the mags were going bad.He said"what's the gap your using?" I said .25 and he said use .15;that mag can't keep up with the .25 and it will fail.I do as he said because he said they use the same gap in the tow plane and it works fine.Now shes running like a sowing machine.I took her up for a flight and it was glorious.I owe that guy a lot and he never even hung around for a thankyou.Next time I see him I'll have to find out what his poison is!Now you know ;check the spark plug gap when things get rough or don't work at all. ________________________________________________________________________________
Date: Aug 14, 2008
Sorry "Eisemann" walt evans NX140DL ----- Original Message ----- From: H RULE To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 9:35 PM Subject: Re: Pietenpol-List:spark plugs Maybe some of you guys have run into this but it's my first time and I have to say if the right person had not come along at the right time it would have cost me a bundle.I changed the harness and then I was in the process of changinging the spark plugs whenthe AME(aircraft maintenance engineer)came up to me and asked what I was doing.I said I'm changing the plugs but I'm convinced that'snot the problem and that it was the mags were going bad.He said"what's the gap your using?" I said .25 and he said use .15;that mag can't keep up with the .25 and it will fail.I do as he said because he said they use the same gap in the tow plane and it works fine.Now shes running like a sowing machine.I took her up for a flight and it was glorious.I owe that guy a lot and he never even hung around for a thankyou.Next time I see him I'll have to find out what his poison is!Now you know ;check the spark plug gap when things get rough or don't work at all. ________________________________________________________________________________
Date: Aug 14, 2008
Anything with a Grumman Goose Bug Smasher in it has got to be good! I've kicked myself many times for not taping it. http://www.goldmonkey.com/ http://www.warlockvideos.com/talesofthegoldmonkey.html?gclid=CNqK_diQj5 UCFREUiQodAj4Ugw http://www.scifi2k.com/monkey/monkey.html http://dvd.search.ebay.com/Tales-Of-The-Gold-Monkey_DVDs-Movies_W0QQbsZSe archQQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQfposZV3RQ204B8QQ fsooZ1QQfsopZ1QQfstypeZ1QQftrtZ1QQftrvZ1QQsacatZ11232QQsadisZ200QQsargnZQ 2d1QQsaslcZ2QQsatitleZQ22TalesQ20OfQ20TheQ20GoldQ20MonkeyQ22QQsofocusZunk nown I've never used anything like this myself but here it is. http://www.downloadnova.com/member-files/Tales%2Bof%2Bthe%2BGold%2BMonkey %2B-%2BSeason%2B1.html http://members.aol.com/thegneech/goose.htm Have fun! Clif So why did bush operators like the goose? --- Original Message ----- From: David Jones To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 11:11 AM Subject: Re: Pietenpol-List: Waldo Update Michael, Yes, that's the series. It was set at Key West or somewhere in the Caribbean and they would fly from one island to another with their adventures. I spoke to the people at Amazon about the subject, but never heard anything. Take care, David On Thu, Aug 14, 2008 at 1:23 PM, Michael Silvius wrote: David: Was'nt that one the one with the Grumman Mallard and the little black eye Jack Russel terrier. Michael in Maine ----- Original Message ----- From: David Jones I've been trying to find the old TV series "The Tales of the Golden Monkey" which Linda is working on. Does anyone remember this series about 25 years ago? Good Luck, David Checked by AVG - http://www.avg.com 8/14/2008 6:03 PM ________________________________________________________________________________
Subject: built-up spar
Date: Aug 15, 2008
In my case I've decided to use a built up spar (3 piece wing) I do not have enough material to fill in the sections that were supposed to be solid. Should I get more spar material or just use something local like #1 pine or ash or oak? Bob ________________________________________________________________________________
Date: Aug 15, 2008
I you use Ash, you will probably set a record for the heaviest Pietenpol spar ever built. Sitkas Spruce weighs 27 lbs/cu. ft. Ash weighs 42 lbs/ cu. ft. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Robert Gow Sent: Friday, August 15, 2008 9:08 AM Subject: RE: Pietenpol-List: built-up spar In my case I've decided to use a built up spar (3 piece wing) I do not have enough material to fill in the sections that were supposed to be solid. Should I get more spar material or just use something local like #1 pine or ash or oak? Bob _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Aug 15, 2008
Clif, Good Job! Thanks, How did you get this info? David On Fri, Aug 15, 2008 at 1:45 AM, Clif Dawson wrote: > Anything with a Grumman Goose Bug Smasher in it has > got to be good! > > I've kicked myself many times for not taping it. > > > http://www.goldmonkey.com/ > > > http://www.warlockvideos.com/talesofthegoldmonkey.html?gclid=CNqK_diQj5UCFREUiQodAj4Ugw > > http://www.scifi2k.com/monkey/monkey.html > > > http://dvd.search.ebay.com/Tales-Of-The-Gold-Monkey_DVDs-Movies_W0QQbsZSearchQQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQfposZV3RQ204B8QQfsooZ1QQfsopZ1QQfstypeZ1QQftrtZ1QQftrvZ1QQsacatZ11232QQsadisZ200QQsargnZQ2d1QQsaslcZ2QQsatitleZQ22TalesQ20OfQ20TheQ20GoldQ20MonkeyQ22QQsofocusZunknown > > I've never used anything like this myself but here it is. > > > http://www.downloadnova.com/member-files/Tales%2Bof%2Bthe%2BGold%2BMonkey%2B-%2BSeason%2B1.html > > http://members.aol.com/thegneech/goose.htm > > Have fun! > > Clif > > So why did bush operators like the goose? > > > --- Original Message ----- > *From:* David Jones > *To:* pietenpol-list(at)matronics.com > *Sent:* Thursday, August 14, 2008 11:11 AM > *Subject:* Re: Pietenpol-List: Waldo Update > > Michael, > > Yes, that's the series. It was set at Key West or somewhere in the > Caribbean and they would fly from one island to another with their > adventures. I spoke to the people at Amazon about the subject, but never > heard anything. > > Take care, > David > > On Thu, Aug 14, 2008 at 1:23 PM, Michael Silvius wrote: > >> David: >> >> Was'nt that one the one with the Grumman Mallard and the little black eye >> Jack Russel terrier. >> >> Michael in Maine >> >> >> ----- Original Message ----- >> *From:* David Jones >> >> I've been trying to find the old TV series "The Tales of the Golden >> Monkey" which Linda is working on. Does anyone remember this series about >> 25 years ago? >> >> Good Luck, >> David >> >> * >> >> * >> >> > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > Checked by AVG - http://www.avg.com > 8/14/2008 6:03 PM* > > * > > * > > ________________________________________________________________________________
Date: Aug 15, 2008
Bob, I used spruce for my "blocking in" sections, ash or oak may be a bit heavy. Cheers Peter Wonthaggi Australia http://www.cpc-world.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Robert Gow Sent: Friday, 15 August 2008 11:08 PM Subject: RE: Pietenpol-List: built-up spar In my case I've decided to use a built up spar (3 piece wing) I do not have enough material to fill in the sections that were supposed to be solid. Should I get more spar material or just use something local like #1 pine or ash or oak? Bob ________________________________________________________________________________
Date: Aug 15, 2008
Thanks. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Peter W Johnson Sent: August 15, 2008 9:55 AM To: pietenpol-list(at)matronics.com Subject: RE: Pietenpol-List: built-up spar Bob, I used spruce for my "blocking in" sections, ash or oak may be a bit heavy. Cheers Peter Wonthaggi Australia http://www.cpc-world.com ---------------------------------------------------------------------------- -- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Robert Gow Sent: Friday, 15 August 2008 11:08 PM To: pietenpol-list(at)matronics.com Subject: RE: Pietenpol-List: built-up spar In my case I've decided to use a built up spar (3 piece wing) I do not have enough material to fill in the sections that were supposed to be solid. Should I get more spar material or just use something local like #1 pine or ash or oak? Bob http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 15, 2008
Bob, I built...built up spars, take a look at my site and the attached drawing. I used 7 ply marine plywood and Douglas fir. Jack www.textors.com ________________________________________________________________________________
Subject: Re: built-up spar
Date: Aug 15, 2008
Hey Jack, did you use okoume, mahogany, or birch? What types and sizes of plywood have others used as web for spars? I am looking to go pick up some spruce next week and place an order for plywood. Thanks in advance for any suggestion or comments. -------- I just hope when it's my turn to reach up and touch the face of God, I don't poke him in the eye on accident. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=198729#198729 ________________________________________________________________________________
Date: Aug 15, 2008
John, If I remember correctly it was Meranti BS1088 which is heavier and more solid than Okume. About 28# for a 4x8 sheet. Jack www.textors.com Hey Jack, did you use okoume, mahogany, or birch? What types and sizes of plywood have others used as web for spars? I am looking to go pick up some spruce next week and place an order for plywood. Thanks in advance for any suggestion or comments. -------- I just hope when it's my turn to reach up and touch the face of God, I don't poke him in the eye on accident. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=198729#198729 ________________________________________________________________________________
Subject: tenpol-List:
Date: Aug 15, 2008
Sorry for the delay. I've had some problems and asked Oscar to help post some info about my project and parts. My hands are injured=2C and hard to type=2C sorry for the "form letter" but the below info basically states the "Who=2C What=2C When and Why"... I am sending this to all who have inquired. If you see it again as posted by Oscar=2C I apologize. Also=2C I won't be much help in loading this stuff=2C so I would advise to bring a friend and a suitable trailer. Oscar: I'm having fits responding to people on the Piet list who have asked off-li ne questions about my engine and Piet project. Can you send this out=2C with my apology that I've turned into an old fart on a farm that is binary challenged? I just can't get my poop out on the Pi etenpol list for some reason and I've had a lot of e-mail about this stuff. Part of the reason I can't respond individually to each inquiry is I am in so much pain from arthritis and I jumped into break up a SECONDdog fight in May=2C and my hands are injured and shoulder hurts. The first dog fight sent me to the emergency room. I learned it's best to pull off one dog at a time and lock them up somewhere=2C rather than jump in the middle and try to stop 7 dogs! ( i rescue abandoned dogs... See YouTube and type in "Winters Texas" and look for the abandoned mother dog and her pups... I have 10 dogs and am trying to find homes for most of them.) I got a shot of Decadron and Medrol today=2C I start Predisone tomorrow and Celebrex after the Predisone=2C so I hope to be feeling much better in a couple of weeks... It just hurts to type and I haven't been up to sending out individual=2C personal e-mails. I'd starve to death if I were a homeless person on a corner somewhere. I hurt too much to hold up a sign 'HOMELESS=2C NEED TACOS AND CORONA=2C GOD BLESS YOU'. I plan on cleaning up my hanger when I get back on my feet=2C and when it cools off (and if the diverticulitis calms down with the Predisone) and I will organize all my stuff I am selling=2C provide a better description and I'll post everything on YouTube with commentary. This might not happen until cooler weather hits=2C maybe in about 5 weeks. My hanger is like an oven and I think the heat exacerbates the diveticulitis. Prior to getting the info out on YouTube=2C I'll invite any and all to come out and take a sneak preview in the hanger BEFORE I put this all on EBAY=2C if they wish to see it up-close and in person. I don't even know what amount to ask=2C but I have to go through my engine receipts=2C see how many THOUSANDS I have in rebuilding this engine (that was advertised to me as having only 5 hours SMOH=2C he should have said the SWWO=2C 'WORLD'S WORST OVERHAUL') I think by putting this on Ebay with an honest description=2C the goods will bring fair-market-value=2C and I won't have to dicker with the price. I also will be selling my Cessna 150/150 having a 160 horsepower Lycoming 0-320 E2D that CAN EMBARRASS any Cessna 172 out there. More on the Cessna later when I get it on YouTube. The farm more than likely (my paradise with a grass strip=2C 5TA6) will be the last thing to go. But for now=2C I ask everyone to please be patient and understand I just ca n't do much e-mail at this time. Date: Wed=2C 13 Aug 2008 07:57:46 -0700 From: speedbrake(at)sbcglobal.net Subject: Re: Pietenpol-List: Roy=2C I am sorry for the loss of your father and the drive to finish this project. It is understandable...life will jack you pretty hard at times and the unforseen futer is always changing. I wish you and yours the best and hope that maybe someday=2C the "building bug" will visit you again. I am new to this project and am just now getting my wing jigs made. I am al ways looking to purchase what I will need in the future...engine included. If the engine does not sell with the plane=2C I would be interested in talk ing to you about purchasing it. Please let me know=2C when you know. Thanks . --- On Wed=2C 8/13/08=2C Roy Brooks wrote: From: Roy Brooks <n900ml(at)hotmail.com> Subject: Pietenpol-List: Date: Wednesday=2C August 13=2C 2008=2C 10:07 AM As much as I hate to... I'll be selling my Piet project in a couple of week s=2C probably putting it on Ebay starting the auction as some very low pric e. Several years ago=2C I bought a project from a guy who was an Air Force mai ntenance officer on both the B-1 and B-2 aircraft. He also is an A&P/IA=2C moved a few times=2C took a job with Cessna after getting out of the milita ry... I bought this about 5 years ago and had plans to finish it with my father =2C but soon after I brought it home=2C my dad passed away=2C thus the proj ect has been gathering dust in my hanger here in Central Texas. It was originally set up for a Corvair=2C but I had planned on putting my C ontinental A-80 on it. The fabric was pulled back off the front of the fuse lage and probably needs to be completely replaced. It is a Piet fuselage wi th Grega wings. The original builder wanted the Grega wings because of the different stall characteristics=2C but he wanted the "looks" of a Pietenpol and built the fuselage from the Piet plans. The wings are covered and painted and it has an "number" already on the win gs=2C but they can be easily painted over. It has Honda CB 350 wheels (they look pretty cool) and I had them powder co ated red (I had planned on painting a Texas flag design or total red for th is project.) The center section was already built=2C but I removed the fabric and lower plywood with the intention of installing a small supplemental fuel tank... I have new plywood and fabric to recover. My dad said there needs to be som e washers welded onto the metal tabs that attach to the wings. I don't know why these were omitted by the original builder. The lift struts are ready to go and I have all the cables. The instrument panel IS NOT INCLUDED. I have a small fortune in the panel a nd I am keeping it (pilot and passenger both) I paid a lot of money for "pr emium carpathian burl elm" veneer that I laminated in a vacuum bag=2C and it looks like it belongs in a 1930-ish Ro lls Royce. Again=2C the panel and gauges are not for sale=2C please don't a sk. If anybody is interested=2C please e-mail me off this list at "N900ML@HOTMA IL.COM" and I can provide more info and pictures. I won't be able to send a ny recent pictures anytime soon=2C but can do so sometime in mid September. I'll also be selling the rebuilt A-80 engine FOR PARTS ONLY. I don't want t he liability if someone goes flying and they nose in someday. My dad rebuil t the engine (he had an A&P license) and I simply want the engine to go as a "parts project" with the buyer signing a bill of sale stating this. The engine case was sent to Divco for a rebuild. The accessory case went of f for repair too. The cylinders were sent off and are Cermnil (the nickel b ore process=2C vastly superior to channel chrome=2C satin chrome) The crank was rebuilt I think M03 under. New bearings new=2C rod bolts=2C new Slick mags with dual impulse couplers... Long story made short=2C this engine looks like it just came out of the Twilight Zone as if being in a t ime warp since 1941. I also have a rebuilt yellow tagged carb on this engin e and the intake tubes are powder coated candy apple blue. The valve cover s are powder coated in Continental yellow... I've never seen an A-65 or A-8 0 that is as pretty as this engine. This engine even has a new data plate t hat looks incredible. All the info from the old data plate was PROFESSIONAL LY engraved onto the new data plate. BUT AGAIN=2C I WANT TO EMPHASIZE THE E NGINE WILL BE SOLD ONLY WITH THE UNDERSTANDING THAT IT IS A "PARTS ENGINE =2C" not something that is ready to stab onto an airplane and go flying. Th e engine will be sold separate from the airplane project. If anybody wants a sneak preview=2C this project can be seen at the airport in Ballinger=2C Texas (between San Angelo and Abilene.) I won't be able to show it until sometime in mid or late September (please don't ask to see it earlie r). RSB Got Game? Win Prizes in the Windows Live Hotmail Mobile Summer Games Trivia Contest Find out how. 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D _________________________________________________________________ Get ideas on sharing photos from people like you. Find new ways to share. http://www.windowslive.com/explore/photogallery/posts?ocid=TXT_TAGLM_WL_P hoto_Gallery_082008 ________________________________________________________________________________
Date: Aug 15, 2008
Subject: Sky King
Long as we're talking about airplane shows, remember Sky King? I'm not old enough to have seen it in it's original run, but I did watch in reruns when I was a kid. Sky King and his niece Penny saving the west from evil doers. In the first season or so he flew a Cessna T-50, which was made of wood (the Bamboo Bomber, as I recall). Great 50's TV. And between my interest in aviation, the the fact that my Wife is from Montana, it makes for fun watching. And episodes ARE available VERY cheaply on Amazon, eBay, etc. I actually have an autographed 8x10 black and white glossy of Sky with "Songbird" hanging in my office at work. Tim in Bovey ________________________________________________________________________________
Date: Aug 15, 2008
Subject: Re: Sky King
If you really like Sky King (or his niece Penny). Every episode is available for free on this website: http://www.americanflyers.net/entertainment/skyking.asp Ben Tim Verthein wrote: > > Long as we're talking about airplane shows, remember Sky King? > > I'm not old enough to have seen it in it's original run, but I did watch in reruns when I was a kid. Sky King and his niece Penny saving the west from evil doers. In the first season or so he flew a Cessna T-50, which was made of wood (the Bamboo Bomber, as I recall). Great 50's TV. And between my interest in aviation, the the fact that my Wife is from Montana, it makes for fun watching. And episodes ARE available VERY cheaply on Amazon, eBay, etc. > > I actually have an autographed 8x10 black and white glossy of Sky with "Songbird" hanging in my office at work. > > Tim in Bovey > > > > > > ________________________________________________________________________________
Date: Aug 15, 2008
That's where I was going to send him, I watch the on occasion so I can feel like a kid again too. I grew up on Sky King and Mike Nelson. I love the sky and the water..... John In a message dated 8/15/2008 9:32:36 P.M. Eastern Daylight Time, bcharvet(at)bellsouth.net writes: --> Pietenpol-List message posted by: Ben Charvet If you really like Sky King (or his niece Penny). Every episode is available for free on this website: http://www.americanflyers.net/entertainment/skyking.asp Ben Tim Verthein wrote: > > Long as we're talking about airplane shows, remember Sky King? > > I'm not old enough to have seen it in it's original run, but I did watch in reruns when I was a kid. Sky King and his niece Penny saving the west from evil doers. In the first season or so he flew a Cessna T-50, which was made of wood (the Bamboo Bomber, as I recall). Great 50's TV. And between my interest in aviation, the the fact that my Wife is from Montana, it makes for fun watching. And episodes ARE available VERY cheaply on Amazon, eBay, etc. > > I actually have an autographed 8x10 black and white glossy of Sky with "Songbird" hanging in my office at work. > > Tim in Bovey > > > > > > **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-Volkswagen-Jetta-2009/expert-review?ncid=aolaut00030000000007 ) ________________________________________________________________________________
Date: Aug 15, 2008
Thanks, The Gneech I've had in my favourites for years, Tales I found a while back and the others came from a google search, " tales of the gold monkey". There's a lot more sites out there. There was an animated Saturday morning kiddies takeoff on the Gold Monkey also. So, no biters on the bushplane thing? :-) Clif ----- Original Message ----- From: David Jones To: pietenpol-list(at)matronics.com Sent: Friday, August 15, 2008 6:52 AM Subject: Re: Pietenpol-List: Waldo Update Clif, Good Job! Thanks, How did you get this info? David On Fri, Aug 15, 2008 at 1:45 AM, Clif Dawson wrote: Anything with a Grumman Goose Bug Smasher in it has got to be good! I've kicked myself many times for not taping it. http://www.goldmonkey.com/ http://www.warlockvideos.com/talesofthegoldmonkey.html?gclid=CNqK_diQj5 UCFREUiQodAj4Ugw http://www.scifi2k.com/monkey/monkey.html http://dvd.search.ebay.com/Tales-Of-The-Gold-Monkey_DVDs-Movies_W0QQbsZSe archQQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQfposZV3RQ204B8QQ fsooZ1QQfsopZ1QQfstypeZ1QQftrtZ1QQftrvZ1QQsacatZ11232QQsadisZ200QQsargnZQ 2d1QQsaslcZ2QQsatitleZQ22TalesQ20OfQ20TheQ20GoldQ20MonkeyQ22QQsofocusZunk nown I've never used anything like this myself but here it is. http://www.downloadnova.com/member-files/Tales%2Bof%2Bthe%2BGold%2BMonkey %2B-%2BSeason%2B1.html http://members.aol.com/thegneech/goose.htm Have fun! Clif So why did bush operators like the goose? --- Original Message ----- From: David Jones To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 11:11 AM Subject: Re: Pietenpol-List: Waldo Update Michael, Yes, that's the series. It was set at Key West or somewhere in the Caribbean and they would fly from one island to another with their adventures. I spoke to the people at Amazon about the subject, but never heard anything. Take care, David On Thu, Aug 14, 2008 at 1:23 PM, Michael Silvius wrote: David: Was'nt that one the one with the Grumman Mallard and the little black eye Jack Russel terrier. Michael in Maine ----- Original Message ----- From: David Jones I've been trying to find the old TV series "The Tales of the Golden Monkey" which Linda is working on. Does anyone remember this series about 25 years ago? Good Luck, David href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Checked by AVG - http://www.avg.com 8/14/2008 6:03 PM Checked by AVG - http://www.avg.com 8/15/2008 5:29 PM ________________________________________________________________________________
Date: Aug 16, 2008
The Goose they have in the show was the second Goose they tried to fly out to the islands. The first, a Goose owned and flown by a fellow from Anchorage by the name of Dodge, went down with engine trouble half way there. Dodge was rescued just before it sank. Dodge was also the pilot suspected of being the one that flew a helicopter into a mexican prison to get an American out. Dodge flew a pink P51 out of Merrill Field in Anchorage. He retired as an Alaska Airlines Pilot. He and his sons are very well known in the Alaskan aviation circles. The Goose was loved for it's ability to land almost anywhere, it's performance and it's payload. Gene ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Saturday, August 16, 2008 12:28 AM Subject: Re: Pietenpol-List: Waldo Update Thanks, The Gneech I've had in my favourites for years, Tales I found a while back and the others came from a google search, " tales of the gold monkey". There's a lot more sites out there. There was an animated Saturday morning kiddies takeoff on the Gold Monkey also. So, no biters on the bushplane thing? :-) Clif ----- Original Message ----- From: David Jones To: pietenpol-list(at)matronics.com Sent: Friday, August 15, 2008 6:52 AM Subject: Re: Pietenpol-List: Waldo Update Clif, Good Job! Thanks, How did you get this info? David On Fri, Aug 15, 2008 at 1:45 AM, Clif Dawson wrote: Anything with a Grumman Goose Bug Smasher in it has got to be good! I've kicked myself many times for not taping it. http://www.goldmonkey.com/ http://www.warlockvideos.com/talesofthegoldmonkey.html?gclid=CNqK_diQj5 UCFREUiQodAj4Ugw http://www.scifi2k.com/monkey/monkey.html http://dvd.search.ebay.com/Tales-Of-The-Gold-Monkey_DVDs-Movies_W0QQbsZSe archQQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQfposZV3RQ204B8QQ fsooZ1QQfsopZ1QQfstypeZ1QQftrtZ1QQftrvZ1QQsacatZ11232QQsadisZ200QQsargnZQ 2d1QQsaslcZ2QQsatitleZQ22TalesQ20OfQ20TheQ20GoldQ20MonkeyQ22QQsofocusZunk nown I've never used anything like this myself but here it is. http://www.downloadnova.com/member-files/Tales%2Bof%2Bthe%2BGold%2BMonkey %2B-%2BSeason%2B1.html http://members.aol.com/thegneech/goose.htm Have fun! Clif So why did bush operators like the goose? --- Original Message ----- From: David Jones To: pietenpol-list(at)matronics.com Sent: Thursday, August 14, 2008 11:11 AM Subject: Re: Pietenpol-List: Waldo Update Michael, Yes, that's the series. It was set at Key West or somewhere in the Caribbean and they would fly from one island to another with their adventures. I spoke to the people at Amazon about the subject, but never heard anything. Take care, David On Thu, Aug 14, 2008 at 1:23 PM, Michael Silvius wrote: David: Was'nt that one the one with the Grumman Mallard and the little black eye Jack Russel terrier. Michael in Maine ----- Original Message ----- From: David Jones I've been trying to find the old TV series "The Tales of the Golden Monkey" which Linda is working on. Does anyone remember this series about 25 years ago? Good Luck, David href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Checked by AVG - http://www.avg.com 8/14/2008 6:03 PM href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Checked by AVG - http://www.avg.com 8/15/2008 5:29 PM ------------------------------------------------------------------------- ----- Checked by AVG. 8/7/2008 5:54 AM ________________________________________________________________________________
Subject: Practice prop
Date: Aug 16, 2008
I'm looking for a used wood prop with which I can gain experience in good takeofs and landings. My first real landing resulted in a damaged left gear and destroyed metal prop. Repairs are in progress and I hope to be back in the air in Sept. No damage to the wings, fuselage and it appears to the engine ( no abrupt prop stop ). One more engine check to go. I have a gorgeous wood, custom prop given to me by a friend, but am reluctant to use it until I get better at this landing thing. The embarassing part is I got my taildragger rating on a Friday and smacked my plane the following Monday. Something in the low 70's in dia and low 40's pitch. Is there anything out there?? Jim Lagowski, NX221PT ________________________________________________________________________________
Date: Aug 16, 2008
Subject: Re: Practice prop
Maybe instead of investing in an expendable prop in case it gets pranged again, it would be better to spend that money for some more flight training. Murphy states that if you spend money on an expendable prop you will then damage everything but the prop the next time you do something. Figure out why your incident happened, and resolve the issue. If it's a problem with the aircraft, fix that. If it was a problem with the pilot, fix that. Just out of curiosity, how was the prop destroyed without damaging the engine? If the prop is bent while it is not turning, that could still transmit a tremendous amount of force to the crankshaft. Make sure nothing was damaged before taking to the skies again.... Ryan On Sat, Aug 16, 2008 at 8:17 PM, Lagowski Morrow wrote: > I'm looking for a used wood prop with which I can gain experience in good > takeofs and landings. My first real landing resulted in a damaged left gear > and destroyed metal prop. Repairs are in progress and I hope to be back in > the air in Sept. No damage to the wings, fuselage and it appears to the > engine ( no abrupt prop stop ). One more engine check to go. > > I have a gorgeous wood, custom prop given to me by a friend, but am > reluctant to use it until I get better at this landing thing. The > embarassing part is I got my taildragger rating on a Friday and smacked my > plane the following Monday. > > Something in the low 70's in dia and low 40's pitch. Is there anything out > there?? > > Jim Lagowski, NX221PT > ________________________________________________________________________________
Date: Aug 17, 2008
Jim, for what it's worth, I completely agree wdith Ryan. If your not already doing this on landing your Piet, try this next time...Before the wheels touch add 50 to 100 rpms above idle. Makes a HUGE difference in landing a Piet. Gene N502R ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Saturday, August 16, 2008 8:55 PM Subject: Re: Pietenpol-List: Practice prop Maybe instead of investing in an expendable prop in case it gets pranged again, it would be better to spend that money for some more flight training. Murphy states that if you spend money on an expendable prop you will then damage everything but the prop the next time you do something. Figure out why your incident happened, and resolve the issue. If it's a problem with the aircraft, fix that. If it was a problem with the pilot, fix that. Just out of curiosity, how was the prop destroyed without damaging the engine? If the prop is bent while it is not turning, that could still transmit a tremendous amount of force to the crankshaft. Make sure nothing was damaged before taking to the skies again.... Ryan On Sat, Aug 16, 2008 at 8:17 PM, Lagowski Morrow wrote: I'm looking for a used wood prop with which I can gain experience in good takeofs and landings. My first real landing resulted in a damaged left gear and destroyed metal prop. Repairs are in progress and I hope to be back in the air in Sept. No damage to the wings, fuselage and it appears to the engine ( no abrupt prop stop ). One more engine check to go. I have a gorgeous wood, custom prop given to me by a friend, but am reluctant to use it until I get better at this landing thing. The embarassing part is I got my taildragger rating on a Friday and smacked my plane the following Monday. Something in the low 70's in dia and low 40's pitch. Is there anything out there?? Jim Lagowski, NX221PT ------------------------------------------------------------------------- ----- Checked by AVG. 8/7/2008 5:54 AM ________________________________________________________________________________
Date: Aug 17, 2008
Subject: practice prop
I'd much rather help a Piet pilot in need than page through message after m essage dealing with old tv shows and movies. Much of those discussions shou ld be one-on-one imho. - Blowing off someone in need with a "fix the pilot" line doesn't get his Pie t (or snowflake) back into the air. I have broken two props many hundreds o f miles from home and would not have gotten back so quickly if kindred spir its not helped me out. - So... I have an unused spare that we could talk about if you are still in n eed. Please email me off site for details. - Larry W. - ps. breaking a wood prop usually does nothing bad to the engine.=0A=0A=0A ________________________________________________________________________________
Subject: Re: practice prop
Date: Aug 17, 2008
Larry, not sure how anyone can be "blowing off someone" when they are suggesting the Pilot fix the problem that led to the crash that broke the prop. Don't know how you broke two props but perhaps if you had "fixed the problem" it would have been only one prop. Just my thoughts. It is wonderful of you to help him out with the spare prop. It just goes to show what great folks are here on this site. Gene (and yes, I have broken a prop. ONCE) ----- Original Message ----- From: Lawrence Williams To: Pietlist Sent: Sunday, August 17, 2008 6:49 AM Subject: Pietenpol-List: practice prop I'd much rather help a Piet pilot in need than page through message after message dealing with old tv shows and movies. Much of those discussions should be one-on-one imho. Blowing off someone in need with a "fix the pilot" line doesn't get his Piet (or snowflake) back into the air. I have broken two props many hundreds of miles from home and would not have gotten back so quickly if kindred spirits not helped me out. So... I have an unused spare that we could talk about if you are still in need. Please email me off site for details. Larry W. ps. breaking a wood prop usually does nothing bad to the engine. 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ------------------------------------------------------------------------- ----- Checked by AVG. 8/7/2008 5:54 AM ________________________________________________________________________________
Date: Aug 17, 2008
Ryan, I agree. Next it'll be a broken neck. If a certified plane, any prop strike is a manditory engine teardown walt evans NX140DL ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Saturday, August 16, 2008 9:55 PM Subject: Re: Pietenpol-List: Practice prop Maybe instead of investing in an expendable prop in case it gets pranged again, it would be better to spend that money for some more flight training. Murphy states that if you spend money on an expendable prop you will then damage everything but the prop the next time you do something. Figure out why your incident happened, and resolve the issue. If it's a problem with the aircraft, fix that. If it was a problem with the pilot, fix that. Just out of curiosity, how was the prop destroyed without damaging the engine? If the prop is bent while it is not turning, that could still transmit a tremendous amount of force to the crankshaft. Make sure nothing was damaged before taking to the skies again.... Ryan On Sat, Aug 16, 2008 at 8:17 PM, Lagowski Morrow wrote: I'm looking for a used wood prop with which I can gain experience in good takeofs and landings. My first real landing resulted in a damaged left gear and destroyed metal prop. Repairs are in progress and I hope to be back in the air in Sept. No damage to the wings, fuselage and it appears to the engine ( no abrupt prop stop ). One more engine check to go. I have a gorgeous wood, custom prop given to me by a friend, but am reluctant to use it until I get better at this landing thing. The embarassing part is I got my taildragger rating on a Friday and smacked my plane the following Monday. Something in the low 70's in dia and low 40's pitch. Is there anything out there?? Jim Lagowski, NX221PT ________________________________________________________________________________
Date: Aug 17, 2008
Larry, The comment was not meant to be flippant, or blowing him off. I'm sorry if it came across that way. I'm just saying that before throwing another prop on and giving it a second shot, make sure to address the issue that caused the accident in the first place (be that plane or pilot). In addition, in Jim's original post he mentions that the prop he destroyed was a metal prop, not a wood prop. I would want to make absolutely sure the engine was not damaged before flying it again. At the very least take a runout measurement on the crank. Depending upon how exactly it was damaged, maybe even a teardown. And as Gene mentioned, thanks for offering up a prop for Jim. Have a good day, Ryan On Sun, Aug 17, 2008 at 6:49 AM, Lawrence Williams wrote: > I'd much rather help a Piet pilot in need than page through message after > message dealing with old tv shows and movies. Much of those discussions > should be one-on-one imho. > > Blowing off someone in need with a "fix the pilot" line doesn't get his > Piet (or snowflake) back into the air. I have broken two props many hundreds > of miles from home and would not have gotten back so quickly if kindred > spirits not helped me out. > > So... I have an unused spare that we could talk about if you are still in > need. Please email me off site for details. > > Larry W. > > ps. breaking a wood prop usually does nothing bad to the engine. > ________________________________________________________________________________
Date: Aug 17, 2008
Larry Williams, Thanks for the offer to help out with a prop.!! What is your personal e-mail address?--Jim Lagowski ----- Original Message ----- From: Lawrence Williams To: Pietlist Sent: Sunday, August 17, 2008 7:49 AM Subject: Pietenpol-List: practice prop I'd much rather help a Piet pilot in need than page through message after message dealing with old tv shows and movies. Much of those discussions should be one-on-one imho. Blowing off someone in need with a "fix the pilot" line doesn't get his Piet (or snowflake) back into the air. I have broken two props many hundreds of miles from home and would not have gotten back so quickly if kindred spirits not helped me out. So... I have an unused spare that we could talk about if you are still in need. Please email me off site for details. Larry W. ps. breaking a wood prop usually does nothing bad to the engine. 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D Checked by AVG - http://www.avg.com 8/15/2008 5:29 PM ________________________________________________________________________________
Date: Aug 17, 2008
Tm90IHRvIGp1bXAgZGlyZWN0bHkgaW4gdGhlIG1pZGRsZSBvZiBhbGwgdGhpcyBidXQgSSBndWVz cyBJIGFtLiBUaGUgZW5naW5lIEkgYm91Z2h0IGZvciBteSBQaWV0IGhhZCBhIHN0cmlrZS4gVGhl IG93bmVyIHRvbGQgdGhlIHBlcnNvbiBJIGJvdWdodCBpdCBmcm9tIHNhaWQgaXQgd2FzIGEgbWlu aW1hbCBzdHJpa2UgYXQgaWRsZSBpbiBoaWdoIGdyYXNzLiBUaGUgZW5naW5lIHdpdGggNjAwIGhy cyBTTU9IIGhhZCB0aGUganVncyByZW1vdmVkLCBydW5vdXQgY2hlY2tlZCBhbmQgdmlzdWFsIGlu c3BlY3Rpb24gYnkgYW4gQSBhbmQgUCBhbmQgY29uc2lkZXJlZCBzYWZlIGFuZCBhaXIgd29ydGh5 IG9uIHRoYXQgYWR2aWNlLCBJIHBsYW4gdG8gY29tcGxldGVseSBkaXNhc3NlbWJsZSBzZW5kIHRo ZSBjcmFuayBvdXQgZm9yIGluc3BlY3Rpb24gYW5kIG1hZ25hZmx1eC4gVGhlbiByZWJ1aWxkIHRo ZSBlbmdpbmUgaXRzIGEgc21hbGwgZXhwZW5zZSBub3cgdGhhdCBtYXkgaGVscCBtZSB0byBhdm9p ZCBwYXlpbmcgdGhlIHVsdGltYXRlIHByaWNlIGxhdGVyLiANCg0KSSBhbSBidWlsZGluZyBhcyBp ZiBteSBsaWZlIGRlcGVuZHMgb24gaXQuIA0KDQpKb2huIFJlY2luZQ0KTlg4OTVCUCByZXNlcnZl ZA0KDQpMeWNvbWluZyAwMjM1IDEwOGhwIHBvd2VyDQpTZW50IGZyb20gbXkgVmVyaXpvbiBXaXJl bGVzcyBCbGFja0JlcnJ5DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAid2Fs dCIgPHdhbHRkYWtAdmVyaXpvbi5uZXQ+DQoNCkRhdGU6IFN1biwgMTcgQXVnIDIwMDggMDk6NDI6 MzEgDQpUbzogPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSZTogUGll dGVucG9sLUxpc3Q6IFByYWN0aWNlIHByb3ANCg0KDQpSeWFuLA0KSSBhZ3JlZS4NCk5leHQgaXQn bGwgYmUgYSBicm9rZW4gbmVjay4NCklmIGEgY2VydGlmaWVkIHBsYW5lLCBhbnkgcHJvcCBzdHJp a2UgaXMgYSBtYW5kaXRvcnkgZW5naW5lIHRlYXJkb3duDQp3YWx0IGV2YW5zDQpOWDE0MERMDQoN Cg0KICAtLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0tIA0KICBGcm9tOiBSeWFuIE11ZWxsZXIg DQogIFRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tIA0KICBTZW50OiBTYXR1cmRheSwg QXVndXN0IDE2LCAyMDA4IDk6NTUgUE0NCiAgU3ViamVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBQ cmFjdGljZSBwcm9wDQoNCg0KICBNYXliZSBpbnN0ZWFkIG9mIGludmVzdGluZyBpbiBhbiBleHBl bmRhYmxlIHByb3AgaW4gY2FzZSBpdCBnZXRzIHByYW5nZWQgYWdhaW4sIGl0IHdvdWxkIGJlIGJl dHRlciB0byBzcGVuZCB0aGF0IG1vbmV5IGZvciBzb21lIG1vcmUgZmxpZ2h0IHRyYWluaW5nLiBN dXJwaHkgc3RhdGVzIHRoYXQgaWYgeW91IHNwZW5kIG1vbmV5IG9uIGFuIGV4cGVuZGFibGUgcHJv cCB5b3Ugd2lsbCB0aGVuIGRhbWFnZSBldmVyeXRoaW5nIGJ1dCB0aGUgcHJvcCB0aGUgbmV4dCB0 aW1lIHlvdSBkbyBzb21ldGhpbmcuIA0KDQogIEZpZ3VyZSBvdXQgd2h5IHlvdXIgaW5jaWRlbnQg aGFwcGVuZWQsIGFuZCByZXNvbHZlIHRoZSBpc3N1ZS4gSWYgaXQncyBhIHByb2JsZW0gd2l0aCB0 aGUgYWlyY3JhZnQsIGZpeCB0aGF0LiBJZiBpdCB3YXMgYSBwcm9ibGVtIHdpdGggdGhlIHBpbG90 LCBmaXggdGhhdC4NCg0KICBKdXN0IG91dCBvZiBjdXJpb3NpdHksIGhvdyB3YXMgdGhlIHByb3Ag ZGVzdHJveWVkIHdpdGhvdXQgZGFtYWdpbmcgdGhlIGVuZ2luZT8gSWYgdGhlIHByb3AgaXMgYmVu dCB3aGlsZSBpdCBpcyBub3QgdHVybmluZywgdGhhdCBjb3VsZCBzdGlsbCB0cmFuc21pdCBhIHRy ZW1lbmRvdXMgYW1vdW50IG9mIGZvcmNlIHRvIHRoZSBjcmFua3NoYWZ0LiBNYWtlIHN1cmUgbm90 aGluZyB3YXMgZGFtYWdlZCBiZWZvcmUgdGFraW5nIHRvIHRoZSBza2llcyBhZ2Fpbi4uLi4NCg0K ICBSeWFuDQoNCg0KDQoNCiAgT24gU2F0LCBBdWcgMTYsIDIwMDggYXQgODoxNyBQTSwgTGFnb3dz a2kgTW9ycm93IDxqaW1kZWJAY2hhcnRlci5uZXQ+IHdyb3RlOg0KDQogICAgSSdtIGxvb2tpbmcg Zm9yIGEgdXNlZCB3b29kIHByb3Agd2l0aCB3aGljaCBJIGNhbiBnYWluIGV4cGVyaWVuY2UgaW4g Z29vZCB0YWtlb2ZzIGFuZCBsYW5kaW5ncy4gTXkgZmlyc3QgcmVhbCBsYW5kaW5nIHJlc3VsdGVk IGluIGEgZGFtYWdlZCBsZWZ0IGdlYXIgYW5kIGRlc3Ryb3llZCBtZXRhbCBwcm9wLiBSZXBhaXJz IGFyZSBpbiBwcm9ncmVzcyBhbmQgSSBob3BlIHRvIGJlIGJhY2sgaW4gdGhlIGFpciBpbiBTZXB0 LiBObyBkYW1hZ2UgdG8gdGhlIHdpbmdzLCBmdXNlbGFnZSBhbmQgaXQgYXBwZWFycyB0byB0aGUg ZW5naW5lICggbm8gYWJydXB0IHByb3Agc3RvcCApLiBPbmUgbW9yZSBlbmdpbmUgY2hlY2sgdG8g Z28uDQoNCiAgICBJIGhhdmUgYSBnb3JnZW91cyB3b29kLCBjdXN0b20gcHJvcCBnaXZlbiB0byBt ZSBieSBhIGZyaWVuZCwgYnV0IGFtIHJlbHVjdGFudCB0byB1c2UgaXQgdW50aWwgSSBnZXQgYmV0 dGVyIGF0IHRoaXMgbGFuZGluZyB0aGluZy4gVGhlIGVtYmFyYXNzaW5nIHBhcnQgaXMgSSBnb3Qg bXkgdGFpbGRyYWdnZXIgcmF0aW5nIG9uIGEgRnJpZGF5IGFuZCBzbWFja2VkIG15IHBsYW5lIHRo ZSBmb2xsb3dpbmcgTW9uZGF5LiANCg0KICAgIFNvbWV0aGluZyBpbiB0aGUgbG93IDcwJ3MgaW4g ZGlhIGFuZCBsb3cgNDAncyBwaXRjaC4gSXMgdGhlcmUgYW55dGhpbmcgb3V0IHRoZXJlPz8NCg0K ICAgIEppbSBMYWdvd3NraSwgTlgyMjFQVA0KDQoNCg0KDQoNCg= ________________________________________________________________________________
Subject: prop strikes
Date: Aug 17, 2008
Nothing is mandatory on an experimental, amateur built airplane. I used drywall screws in several places where they were not only appropriate but totally safe and functional and had no qualms about doing it even though they were not AN certified hardware. I view prop strikes in a similar fashion where if you know (not second hand) the circumstances of the prop strike you can logically determine if the engine really warrants a tear down or not. Things like having a wood prop strike are far different from having a metal prop strike as the wood is so much more forgiving and absorbs great forces upon impact that help buffer the blow to the prop hub and crankshaft. Low idle vs. run up rpm would be another big factor as well as the report of the dial gauge results on crankshaft runout. If the engine is weak in compression numbers the past year or two and high time.....a prop strike, even if the dial numbers show a true crank, might be a good reason to take a winter to major an engine. There are cases where I would (personally) not perform a teardown but if there is any doubt......tear it out. Mike C. ________________________________________________________________________________
Date: Aug 17, 2008
Subject: Re: Homemade Turnbuckles
Sorry Jack for the lateness in catching up post-Brodeah/post-Oshkosh Turnbuckles... uh that would be a firm NO at this time, too many fussy operations for too small a return on the time invested. ... plus probably too many "advisors" on this one thank you =) Its not that we mind helpful input from experienced builders, just there are some items that will illicit as many variations as respondents and by the time you incorporate everyone's wish lists the very next question asked is "why is it so expensive?". For the time being we'll stick to custom fabbed hardware and not compete with products you can buy off the shelf. It was a pleasure meeting everyone at Brodhead and we look forward to next year! Regards, Chrissi & Randi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details =============================== In a message dated 8/5/2008 9:35:58 A.M. Central Daylight Time, Jack.Phillips(at)cardinalhealth.com writes: --> Pietenpol-List message posted by: "Phillips, Jack" Maybe this would be an area for the CozyGirrrls to make some parts. There are several dozen turnbuckles required to build a Pietenpol, and they could offer a turnbuckle kit. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim Willis Sent: Tuesday, August 05, 2008 10:22 AM Subject: Re: Pietenpol-List: Homemade Turnbuckles In theory, we should be able to build stronger turnbuckles than standard aircraft ones. The A/C turnbuckles are made of brass. Their male threads are rolled, making them stronger than the cut threads we would make. However, I believe the female (tapped) threads are cut. That would likely be the wekaer link, and more likely to strip in tension. Moreover, brass is has less tensile and shering strength than either steel or stainless steel. Building our own turnbuckles out of stainless steel (female) and a cap bolt (male) might be the best of all worlds. The high quality steel cap bolt (socket head) has rolled threads and is case hardened, as well. The mating female part (homemade) has cut threads, but the S.S. material is much stronger than the brass. Moreover, the builder might experiment with slightly undersize tap drills to achieve nearly interference fit (more thread-to-thread surface). This last step might not be practical, and a real tap-breaker, but perhaps a worthy experiment. Also, as in the demontrated design, the homebuilder can make the straps that carry the loads on the ends of the entire turnbuckle assembly as thick and wide as needed. Of course, as stated first in this note... this is only THEORY, and that is why testing is so important. If it works, the proper homemade turnbuckle would be not only cheaper, but better than store-bought aircraft quality. It would also be more in keeping with the barndoor hinge, baling wire, and oatmeal carton LE heritage of the Piet itself. Note, though, that this is definitely NOT an appeal for Home Depot turnbuckles. Tim in central Texas -----Original Message----- >From: gcardinal <gcardinal(at)comcast.net> >Sent: Aug 5, 2008 6:22 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Homemade Turnbuckles > >Bill, > >Dale Johnson built a pull tester for testing the cables on NX18235. We also used it to test some homemade turnbuckle barrels. >Dale would be happy to do a test on one or more of your turnbuckles. >Let me know if you are interested. > >Greg Cardinal > ----- Original Message ----- > From: Bill Church > To: pietenpol-list(at)matronics.com > Sent: Thursday, July 31, 2008 12:34 PM > Subject: RE: Pietenpol-List: Homemade Turnbuckles > > > Ken, > > I kind of got sidetracked away from the homemade turnbuckles for a while, and I've actually been building my tailfeathers. So, the short answer to your question is "No, I haven't". > Having said that, here's the long answer. > I didn't do any strength calculations, but I have a strong feeling that the turnbuckles as I made them will be sufficient in strength, but I have yet to do some real-world pull testing to see what they can safely handle. Before I do the pull test I wanted to refine the design a bit to make them a bit more user friendly. That way I'll be testing the proper part, not just something similar. I still plan to do it, just not right now. If you need an answer right now, I think just about anyone could make up a set of these in a short period of time, and then do their own testing using a simple apparatus (lever and pivot). When I do get around to revising the design and doing the pull-testing, I'll share the results with the list. > If you want more details about how I made the prototype, let me know. > > Bill C. > > >----------------------------------------------------------------------- ------- > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide, BA, CPO, FAAOP > Sent: Thursday, July 31, 2008 12:37 PM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Homemade Turnbuckles > > > Bill, > > Have you nailed down the materials (thickness, width, length, rod size, etc) to manufacture the turnbuckles for the tail section? After seeing the price for the turnbuckles on Aircraft Spruce and others, I think making my own would be a great idea... any assistance? > > > Kenneth M. Heide, BA, CPO, FAAOP > > > **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-Volkswagen-Jetta-2009/expert-review?ncid=aolaut00030000000007 ) ________________________________________________________________________________
Subject: inspection holes
Date: Aug 17, 2008
I am about ready to cover my center section on the GN-1 I got from D.J. but am concerned how I can rig my aileron cables and get to them once it is time to rig up.i had intentions of running them through the top pulleys in the center section and down in the open and install the turnbuckles where they are easily reached and safety wired.but if I have much of anything on the end of the cables I can't very well remove the cables and wings once they are rigged without cutting them.so my only option I can see is to put openings under the center section to reach in and complete the hook-up ahead of the pulleys.that is - between the wing root and pulley.is there any way to get two hands through two inspection rings and connect and safety them up without amputation ? I'm thinking about some large fabricated door for access under there that would allow pretty well the whole width and at least 8 inches front to back to do it.anyone got better ideas? also a simple connection to hook the top cross cables together without the expense of another turnbuckle-I have thought of using something like a motorcycle chain master link and go through the nico-pressed loops to link them together.will this get by an inspection? seems like under Experimental Amateur built it should.I hear about guys fabricating home made turnbuckles with wire and allen screws and it for sure should be strongest than that.just wouldn't allow for adjustment so the final connections would need to be at the aileron horns and set right.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199127#199127 ________________________________________________________________________________
Date: Aug 17, 2008
Subject: My Piet has wings!
I passed a real milestone this afternoon. Finally got the wings temporarily hung on the fuselage to do the final fittings on the aileron cables. Now I can move the wings out to my hangar and make the final preps to start covering. Between this afternoon, and all the great stuff I saw at Brodhead, I'm really excited that the end is in sight (or maybe within a year) Ben Charvet Mims, Fl P1010097.JPG ________________________________________________________________________________
Subject: Vicksburg, MS
Date: Aug 17, 2008
Anyone in the Vicksburg, MS area that has or is building a Piet. If so I would like to take a look see the week of the 25th. Please drop me a note and lets see if we can get togeather. Chet ________________________________________________________________________________
Date: Aug 17, 2008
Subject: Re: My Piet has wings!
Ben, Congratulations on your milestone!! How sweet it is to finally see an airplane!! I know the feeling, as I was at your stage last November. Keep going!! Dan Helsper Poplar Grove, IL. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-Volkswagen-Jetta-2009/expert-review?ncid=aolaut00030000000007 ) ________________________________________________________________________________
Date: Aug 17, 2008
Subject: Using motercycle chain links
We have chain links in the control system of 92GB, work fine.- I know all about hooking up the aileron cables in the C/S, it sucks!- We have 2 rou ghly 6inchx 6 inch square aluminum inpection covers right behind where the ail cables go through the C/S.- When the wings are removed the lower ail cables stay with the outboard wing panels,- The balence cable is split vi a motorcycle chain link and also stays with the outboard panels.- not sure if this helps or not for the question of routing aileron cables? Shad=0A=0A=0A ________________________________________________________________________________
Subject: Re: Using motercycle chain links
Date: Aug 17, 2008
yes it does help-thanks.I will start trying to frame the inspection area in tomorrow.do you sleeve the pins on the master link with short pieces of tubing or just let the cable thimble ride on the pins?Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199173#199173 ________________________________________________________________________________
Date: Aug 17, 2008
Great Work Ben!!! -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199218#199218 ________________________________________________________________________________
Date: Aug 17, 2008
Okay, let's see if I got this right. :-) 1-The pulleys are in the center section. 2-The cable has to come apart at or near the junction between the center section and outer wing. 3-The turnbuckles are on the horn down at your feet. So it appears to me you need one small opening ten to twelve inches outboard of the pulley. You make the connection six inches outboard of the pulley when the system is in neutral ( aileros flat ). You unhook the turnbuckle connection and pull the cable and connector down through the hole. Since the connection is six inches outboard and the hole is twelve inches then this places the connector below the wing by six inches. Easy to get at now, isn't it. :-) Once those two connections are undone then unhooking the top connections at both horns allows you to pull the entire top cable turnbuckle assembly out the inspection hole you've added in the middle of the center section far enough to easily work on it. My kids don't call me Crowdad for nothin' ! Clif ----- Original Message ----- From: shad bell To: Pietenpol Discussion Sent: Sunday, August 17, 2008 5:43 PM Subject: Pietenpol-List: Using motercycle chain links We have chain links in the control system of 92GB, work fine. I know all about hooking up the aileron cables in the C/S, it sucks! ________________________________________________________________________________
Date: Aug 18, 2008
Subject: Weight and balance question
Good people, I have not covered my plane yet, but it is almost fully assembled. I am trying to estimate the CG of the fabric and paint. I know the approximate weight of all this, but I need some guesses from you guys as far as what the "arm" is, when doing my W&B calculations. Please help. Thanks. Dan Helsper Poplar Grove, IL. **************Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. (http://autos.aol.com/cars-Volkswagen-Jetta-2009/expert-review?ncid=aolaut00030000000007 ) ________________________________________________________________________________
Subject: Re: From print to jig...how?
Date: Aug 18, 2008
I am in the process of building my Corvair 110 and soon to start on the Piet, where can I learn more about the Riblett airfoil and where can I obtain the drawing? Thank you all for all of your help, Joser. -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199236#199236 ________________________________________________________________________________
Date: Aug 18, 2008
Jose, How is the Corvair engine project going? What exactly did you do to the engine? Did you follow William Wyne's manuals? I am curious here in Alaska aobut what I need to do the additional engine project---I am also building a Piet with Corvair. As for the Riblett airfoil I can't help...I am using the traditional Pietenpol airfoil. Regards, Rob Rob Stapleton, Photojournalist Anchorage, Alaska 907-230-9425 KL2AN Skype:rob.stapleton.jr IM Windows Live Messenger: foto(at)alaska.net -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Joser Sent: Monday, August 18, 2008 5:25 AM Subject: Pietenpol-List: Re: From print to jig...how? I am in the process of building my Corvair 110 and soon to start on the Piet, where can I learn more about the Riblett airfoil and where can I obtain the drawing? Thank you all for all of your help, Joser. -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199236#199236 ________________________________________________________________________________
Date: Aug 18, 2008
Yes, nice--but pretty hefty looking struts..actually a good idea for setting the wing in place. RS Rob Stapleton, Photojournalist Anchorage, Alaska 907-230-9425 KL2AN Skype:rob.stapleton.jr IM Windows Live Messenger: foto(at)alaska.net -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Joser Sent: Sunday, August 17, 2008 10:03 PM Subject: Pietenpol-List: Re: My Piet has wings! Great Work Ben!!! -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199218#199218 ________________________________________________________________________________
Date: Aug 18, 2008
Hi Rob, after speaking at length with scores of builders, I will build my corvair strictly to WW's manual and recommendations. I have read many articles involving the Corvair conversion and without a doubt no one is better qualified than WW. I have disassembled the engine and will clean, powdercoat, paint and assemble with a nitrided crank, the recommended cam and all of the gold products that WW offers. Will post pictures as I complete the work, hope to see your project soon, right now I am preparing for a major storm, later, Joser. -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199295#199295 ________________________________________________________________________________
Date: Aug 18, 2008
Thats what I am doing Jose. Needed more than 65 HP due to my high altitude. Rebuilding a run out O-200 would have run around $9500. Will end up costing me around $5500 with all of William's part but the exhaust manifold. Rick On Mon, Aug 18, 2008 at 9:51 AM, Joser wrote: > > Hi Rob, after speaking at length with scores of builders, I will build my > corvair strictly to WW's manual and recommendations. I have read many > articles involving the Corvair conversion and without a doubt no one is > better qualified than WW. I have disassembled the engine and will clean, > powdercoat, paint and assemble with a nitrided crank, the recommended cam > and all of the gold products that WW offers. Will post pictures as I > complete the work, hope to see your project soon, right now I am preparing > for a major storm, later, Joser. > > -------- > Jose R. Soto > Apopka, Florida > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=199295#199295 > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Aug 18, 2008
Rick, I need the 100hp because I am 6'2" 260# Hahahaha. I have used this opportunity to remove the weight from the body, I was over three hundred at the beginning of the year! So I am on the Pietenpol lifestyle plan! -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199310#199310 ________________________________________________________________________________
Date: Aug 18, 2008
Check the archives for info on the Riblett airfoil, in particular emails from Pieti Lowell. The prints are available from me for $10.00. Roman Bukolt 6505 Urich Terrace Madison, Wi. 53719 On Aug 18, 2008, at 8:25 AM, Joser wrote: > > I am in the process of building my Corvair 110 and soon to start on > the Piet, where can I learn more about the Riblett airfoil and where > can I obtain the drawing? Thank you all for all of your help, Joser. > > -------- > Jose R. Soto > Apopka, Florida > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=199236#199236 > > ________________________________________________________________________________
Date: Aug 18, 2008
Hi Roman, I need two copies, how do I pay you? jsoto5(at)cfl.rr.com Thanks, Joser. -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199344#199344 ________________________________________________________________________________
Date: Aug 18, 2008
Subject: Re: Weight and balance question
Dan, In my layman's terms,,,The arm is the length, from the pivot point, a certain weight that is figured in. And what effect the weight has at that distance. So a 5 lb weight at the C/G has no "moment" effect, while that 5 lbs at the tail (which is a long "arm" has lots of effect.) see http://en.wikipedia.org/wiki/Torque also I have a nifty program that I figured in my wt/bal for my Piet. Whould you like it? It's in Excel format Very simple to use, click a box, and change the value. The final C/G automatically changes walt evans NX140DL ----- Original Message ----- From: HelsperSew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, August 18, 2008 7:07 AM Subject: Pietenpol-List: Weight and balance question Good people, I have not covered my plane yet, but it is almost fully assembled. I am trying to estimate the CG of the fabric and paint. I know the approximate weight of all this, but I need some guesses from you guys as far as what the "arm" is, when doing my W&B calculations. Please help. Thanks. Dan Helsper Poplar Grove, IL. ------------------------------------------------------------------------- ----- Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos. ________________________________________________________________________________
Date: Aug 18, 2008
Just send a check $20 On Aug 18, 2008, at 2:42 PM, Joser wrote: > > Hi Roman, I need two copies, how do I pay you? jsoto5(at)cfl.rr.com > Thanks, Joser. > > -------- > Jose R. Soto > Apopka, Florida > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=199344#199344 > > ________________________________________________________________________________
Date: Aug 18, 2008
10-4 -------- Jose R. Soto Apopka, Florida Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199396#199396 ________________________________________________________________________________
Date: Aug 18, 2008
The struts in the picture were made from 2X4 stock ripped down the middle. I cut an angle on one end where they fit against the fuselage, and bolted the other end to the wing after getting a good estimate how long they needed to be. As I raised the outboard end of the wing I had my wife place the temp struts on top of the strut fittings. Then I could place shims between the strut and the fuselage side to get the wash in/out close to flat. After all that was done I made marks on the lower end where the hole needs to be, so I can use these temporary struts as a template for the actual struts. One other cool thing that happened. A friend gave me a set of struts from a Piper Tripacer. The shortest ones are exactly the right length for the forward struts. The other piper struts are longer and have an angled end where they fit the wing of the Tri-Pacer, so that end will need to be trimmed down. They came complete with adjustable forks. They are a little wider than they need to be. I'm wondering, the Tri-Pacer doesnt use strut braces with these same struts, do you think I'll need them for the Piet? Rob Stapleton, Jr. wrote: > > Yes, nice--but pretty hefty looking struts..actually a good idea for setting > the wing in place. > RS > > Rob Stapleton, Photojournalist > Anchorage, Alaska > 907-230-9425 > KL2AN > Skype:rob.stapleton.jr > IM Windows Live Messenger: foto(at)alaska.net > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Joser > Sent: Sunday, August 17, 2008 10:03 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: My Piet has wings! > > > Great Work Ben!!! > > -------- > Jose R. Soto > Apopka, Florida > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=199218#199218 > > > ________________________________________________________________________________
Date: Aug 18, 2008
Date: Aug 19, 2008
The Kansas City Dawn patrol website did have a great program that you could download and use too.forget the guy's name-Dick Starks maybe? anyway they have a fine site you might want to checkout.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199494#199494 ________________________________________________________________________________
From: Marc Davis <marcs_listreading(at)hotmail.com>
Subject: Blocking
Date: Aug 19, 2008
In reading the plans I see three places (on each side) where the plans call for blocking to fill in the V's of clusters. On my fuselage this is done on all cluster s. Are others doing this? I'm rebuilding the lower aft section and am trying to decide if I should pu t these put these back in. Trying to "Simplify and add lightness". Marc _________________________________________________________________ See what people are saying about Windows Live. Check out featured posts. http://www.windowslive.com/connect?ocid=TXT_TAGLM_WL_connect2_082008 ________________________________________________________________________________
Date: Aug 19, 2008
Subject: Re: Blocking
The gussets take the place of blocks at each cluster. The blocks near the cockpit area are to strengthen the landing gear mount area. Your question falls under the "can you improve Bernards design?" Not likely by adding weight or items not found to be needed in 70 years. Cheers, Jim On Aug 19, 2008, marcs_listreading(at)hotmail.com wrote: In reading the plans I see three places (on each side) where the plans call for blocking to fill in the V's of clusters. On my fuselage this is done on all clusters. Are others doing this? I'm rebuilding the lower aft section and am trying to decide if I should put these put these back in. Trying to "Simplify and add lightness". Marc See what people are saying about Windows Live. Check out featured posts. Check It Out! ________________________________________________________________________________
Subject: Three piece wings
Date: Aug 19, 2008
The three piece wing plans show a 3/4 inch wide spar rather than a routed 1 inch spar in the regular plans. I'm wondering if anyone knows why the thickness is less? I assume three piece wings have been built to these plans and are still hanging in there. On another question - the spar material that came with my project is 1/2 inch. Over the winter it has cupped a little. I'm face gluing the spars together, with the grain properly arranged, and milling the 1 inch back down to 3/4 inch. Actually I've given the task to a local furniture maker - If it doesn't work, then I'm no further behind. Any issues that anyone can see with this approach? Bob ________________________________________________________________________________
Subject: Blocking
Date: Aug 19, 2008
Thats what I was thinking. The guy who built this plane seems to have been a bit conservative=2C I think I'll remove the "improvements" and save a bit of weight. Thanks Marc > Date: Tue=2C 19 Aug 2008 17:48:57 +0000 > From: jimboyer(at)hughes.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Blocking > > > > The gussets take the place of blocks at each cluster. The blocks near the cockpit area are to strengthen the landing gear mount area. Your question falls under the "can you improve Bernards design?" Not likely by adding wei ght or items not found to be needed in 70 years. > Cheers=2C > Jim > > > On Aug 19=2C 2008=2C marcs_listreading(at)hotmail.com wrote: > > > > > > > > In reading the plans I see three places (on each side) where the plans ca ll for blocking > to fill in the V's of clusters. On my fuselage this is done on all clust ers. Are others doing this? > I'm rebuilding the lower aft section and am trying to decide if I should put these put these back in. > > Trying to "Simplify and add lightness". > Marc > > See what people are saying about Windows Live. Check out featured posts. Check It Out! > > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ Be the filmmaker you always wanted to be=97learn how to burn a DVD with Win dows=AE. ________________________________________________________________________________
Subject: tail wheel
Date: Aug 19, 2008
I weighed the tail wheel that came with my plane and it came to 10.25 lbs. I've been thinking about building a new one more like the original design. In the interest of keeping things light I was thinking about using a bungi e instead of the coil spring normally used. Attached is a crude picture of w hat I have in mind. I know the is dangerously close to an 'improvement' but what do you think? The bungie would be attached to the tail post with a turn buckle for adjust ment. If the picture doesn't come through here is a link. http://picasaweb.google.com/sandy.n.marc/Pietenpol/photo#523636271252841089 8 Thanks for your thoughts. Marc _________________________________________________________________ Get thousands of games on your PC=2C your mobile phone=2C and the web with Windows=AE. /9j/7gAOQWRvYmUAZAAAAAAA/9sAQwAIBgYHBgUIBwcHCQkICgwUDQwLCwwZEhMPFB0aHx4dGhwc ICQuJyAiLCMcHCg3KSwwMTQ0NB8nOT04MjwuMzQy/8AAEQgDUgRMA1IRAEcRAEIRAP/EAB8AAAEF AQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFB BhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RV VldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrC w8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+v/aAAwDUgBHAEIAAD8A+f68PrzC iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiitiw8K67qW Da6XcFWTzFd18tWXjBDNgHqOhq9baNqV3jybOUgruDMNqkexOAetIWA710th8K9TmKtfXttbIUDY jBldW4+UjgdzyCenfNbFt4LvJMG5uIoVK5wuXYHjgjgfkaaXHat9PhZpC2bobu6a5aLaJSV2o/Hz BQP0JPB65wa0l8GWIgZTPMZSmA5Iwrccgf0z0P0NJvNeY6vpF5omoyWV7HslXkEcq69mU9wf/rdR XIX1jPp101vcJtdeQR0YdiD6U8EEZFUarUtFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFbFh4V13UsG10u4KsnmK7r5asvGCGbAPUdD V620bUrvHk2cpBXcGYbVI9icA9aQsB3rpbD4V6nMVa+vba2QoGxGDK6tx8pHA7nkE9O+a2LbwXeS YNzcRQqVzhcuwPHBHA/I00uO1dNYfDHQrba101xeNsAYPJtXPHzALgj6ZPXvWvbeD9NhwZjLOduC GbC545GOfwyetIXP0rprDRtM0sqbGwtrdwgj3xxgOV46t1PQdSf8de2sLOzwbe2iiYLt3Ko3Y479 TTSSepq9/n/P+f8A69mij/P+f8//AFyij/P+f8//AFyiszWtA07xBarBqEG/ZkxyKcNGSMZU/lwc jgZBqnqGmWmpwiO6j3bc7WBwyk9wf6dOlKCR0rxPxF4dvPDeom2uRvifJhnUfLIv9COMjt7ggnz3 VdKn0m68qX5kbmOQDhx/j6j/AOsakBBFY9UKWiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiitXTPDWs6woex06aSMqWEhARGwcHDNgE57A5q7aaRqF+N1ta yOpBIc/KpwccE8GkLAdTXUWHwr1OYq19e21shQNiMGV1bj5SOB3PIJ6d81s23gu8kwbm4ihUrnC5 dgeOCOB+Rppcdq6aw+GOhW21rpri8bYAweTauePmAXBH0yevete28H6bDgzGWc7cEM2FzxyMc/hk 9aQufpXTWGjaZpZU2NhbW7hBHvjjAcrx1bqeg6k/469tYWdng29tFEwXbuVRuxx36mmkk9TV7/P+ f8//AF7NFH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f 8/5/+uUVVv8ATrPVLVra+t454T/C4zg4xkHseTyORn84bm1gvITDcxJJGezDOPceh560A46V4r4s 8JXPhq8BBaawlP7mf077Wx0b+fUdwPPdb0SXSJ8jL2zn93J/Q+/8/wCUitu+tc5WVTqKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK09P8Paxqvlmy064lSTOyTZtjOM5+c4Xt jr14q3a6Xf3uw29pK6vna+3CnH+0eKQkDqa6bT/hdrFz5bXs9vZxtneufMkX04HynPH8XQ/hWxa+ Db+XYbiWKBTncM72HpwOD+dIXFdLp/wu0e38tr24uLx1zvXIjjbPTgfMMZH8XUfhWva+DbCLY1xL LOwzuGdqn04HP600ufpXTad4e0fSvLNlp1vFJHnbKEDSDPX5zlu5HXpxWva6XYWWw29pEjJnD7cs M/7R570hJPetP/P+f8//AF7lJR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n /P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8A n/65RRn/AD/n/P8AVM0VzfjyWSLwVqLRuyEqi5UkcF1BH4gkH6/nk+JXZPD12UYqcKMg9iwB/MH9 fzVPvCvDK85qWiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiitPT/D2sar5ZstOuJUkzsk2 bYzjOfnOF7Y69eKt2ul397sNvaSur52vtwpx/tHikJA6mum0/wCF2sXPltez29nG2d658yRfTgfK c8fxdD+FbFr4Nv5dhuJYoFOdwzvYenA4P50hcV0un/C7R7fy2vbi4vHXO9ciONs9OB8wxkfxdR+F a9r4NsItjXEss7DO4Z2qfTgc/rTS5+ldNp3h7R9K8s2WnW8UkedsoQNIM9fnOW7kdenFa9rpdhZb Db2kSMmcPtywz/tHnvSEk960/wDP+f8AP/17lJR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RR/n/P+ f/rlFH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/ +uUUf5/z/n/65RR/n/P+f/rlFGf8/wCf8/1TNFJ1/wA/5/z+p/n/AD/n/wCuUf5/z/n/AOun+f8A P+f/AK6VzPxA/wCRI1H/ALZf+jF/z/nnJ8T/APIu3X/AP/Q1/wA/55cn3hXh9edVLRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRV6w0bU9T2mxsLidS/l70jJQNxwW6DqOp71ZttPvLzBt7aWUFtu5UJUH3PQ dRSEgdTXTWHwx1252tdNbWabwGDyb328fMAuQevTI6dq17bwfqU2DMYoF3YIZtzY45AGQfpmkLj6 11Wn/C7R7fy2vbi4vHXO9ciONs9OB8wxkfxdR+FbVr4NsItjXEss7DO4Z2qfTgc/rTS5+ldNp3h7 R9K8s2WnW8UkedsoQNIM9fnOW7kdenFa9rpdhZbDb2kSMmcPtywz/tHnvSEk960/8/5/z/8AXuUl H+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8 /wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf /rlFH+f8/wCf/rlFH+f8/wCf/rlFGf8AP+f8/wBUzRSdf8/5/wA/qf5/z/n/AOuUf5/z/n/66f5/ z/n/AOulH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8Arlcz8QP+RI1H/tl/6MX/AD/nnJ8T /wDIu3X/AAD/ANDX/P8AnlyfeFeH151UtFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFXrDRtT1PabGwuJ1L+XvSMlA3HB boOo6nvVm20+8vMG3tpZQW27lQlQfc9B1FISB1NdNYfDHXbna101tZpvAYPJvfbx8wC5B69Mjp2r XtvB+pTYMxigXdghm3NjjkAZB+maQuPrXS2Hwr0yHa19e3FywcNiMCNCvHBHJ9eQR1/PXtvBdnHg 3FxLMQ2cKAikccdz+Rppc9q6aw8LaFpu02ul2ysriRXdfMdW4wQzZI6Dof8A6+vbaNptpgw2cQYN uDMNzA8cgnJ/z+aFie9bH+f8/wCf/r36Sj/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8A P/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1y ij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P +f8AP/1yijP+f8/5/qmaKTr/AJ/z/n9T/P8An/P/ANco/wA/5/z/APXT/P8An/P/ANdKP8/5/wA/ /XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8 /wD1yuZ+IH/Ikaj/ANsv/Ri/5/zzk+J/+Rduv+Af+hr/AJ/zy5PvCvD686qWiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiir1ho2p6ntNj YXE6l/L3pGSgbjgt0HUdT3qzbafeXmDb20soLbdyoSoPueg6ikJA6mumsPhjrtzta6a2s03gMHk3 vt4+YBcg9emR07Vr23g/UpsGYxQLuwQzbmxxyAMg/TNIXH1rpbD4V6ZDta+vbi5YOGxGBGhXjgjk +vII6/nr23guzjwbi4lmIbOFARSOOO5/I00ue1dNYeFtC03abXS7ZWVxIruvmOrcYIZskdB0P/19 e20bTbTBhs4gwbcGYbmB45BOT/n80LE962P8/wCf8/8A179JR/n/AD/n/wCuUUf5/wA/5/8ArlFH +f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8A rlFH+f8AP+f/AK5RUiwSt0Qj68fz/wA/1esUjdFP8qUKx7VMtk2MvIqj25/z/n8ZBbHGWcD6U4R+ pApjG3j4UGQ+54H5df8AP4tbyU4UFz7ngUh2jpzUTOWPYDrhen+f8/WMsWPYewppOab/AJ/z/n/6 6UUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUZ/wA/5/z/AFTN FJ1/z/n/AD+p/n/P+f8A65R/n/P+f/rp/n/P+f8A66Uf5/z/AJ/+uf5/z/n/AOuUf5/z/n/65/n/ AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uUf5/wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuUf5/z /n/65/n/AD/n/wCuVzPxA/5EjUf+2X/oxf8AP+ecnxP/AMi7df8AAP8A0Nf8/wCeXJ94V4fXnVS0 UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUVZtNOvtQ 3/YrK4udmN/kxM+3PTOBx0NTQWlzdbvs9vLLtxu8tC2M+uKMgdTXTWnw18RXO/zY7a124x50wO7P ps3frjrWvB4R1WXdvSKHGMeZIDn6bc03eK6az+E9im/7bqdxNnG3yUWPHrnO7Pb0/GteDwTbLu+0 XksnTHlqEx+ec0nmHsK6jT/CWgaZL5trpkKyZVg75kKkHIKlicH6e1bNroemWb74bOMPkEM2XKkd CMk4P0ppYnvW1/n/AD/n/wCvoUlH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/ AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFSJBK/ 3VP8v8/5/F6xO3RTShSegqZLJj95wPTHP+f8/jItqx6uB6Y5pwjPc1MlpCOuW+pqVbeMep+ppwRf rUyqkYyoVR3xx6e9SAKg4AA74pRgegqCS9VOE+Y+vb/69QvcqvC/Mf0ppkA6c1TkmeU/Oxx6DoP8 /wCfeu8jSH5j+HpTCxPU0z/P+f8AP/120lH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5 /wDrlFH+f8/5/wDrlFGf8/5/z/VM0UnX/P8An/P6n+f8/wCf/rlH+f8AP+f/AK6f5/z/AJ/+ulH+ f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/ 5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/ +uf5/wA/5/8Arlcz8QP+RI1H/tl/6MX/AD/nnJ8T/wDIu3X/AAD/ANDX/P8AnlyfeFeH151UtFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFWbTTr7UN/2KyuLnZjf5MTP tz0zgcdDU0Fpc3W77Pbyy7cbvLQtjPrijIHU101p8NfEVzv82O2tduMedMDuz6bN36461rweEdVl 3b0ihxjHmSA5+m3NN3iums/hPYpv+26ncTZxt8lFjx65zuz29PxrXg8E2y7vtF5LJ0x5ahMfnnNJ 5h7CultPBvh2y3+VpNs2/GfOBlxj03k469q14NB0q33bLGI7sZ3jf+W4mm7ie9bv+f8AP+f/AK+l SUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n /wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUVIkMj42ofXPT/P+fxcsbtjCn1pQpPap ksnONzhfpzjpUq2zHG5gPpzThGe5xUyWcQxklvqfpUi2yDGST+NOEY+tTIiJjaoH0/D3qRUVcbQB /kUoAHQU4Hpz+v096cKWjIAyTx9fp70ZwMk/rRVaS9VOE+Y+vb/69QPcqvC/Mf0phkA6c1TkmeU/ Oxx6DoP8/wCfeu8jSH5j+HpTCxPU0z/P+f8AP/120lH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDr lFH+f8/5/wDrlFH+f8/5/wDrlFGen+f8/wCfxSikz/n/AD/n+pn/AD/n/P8AUo/z/n/P/wBdP8/5 /wA//XSj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yj/ AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z /P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A 9crmfiB/yJGo/wDbL/0Yv+f885Pif/kXbr/gH/oa/wCf88uT7wrw+vOqlooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooqe0sru/lMVnazXEgXcUhjLkDpnA7cj86kht57lykEMkrAZKxqW OPwoziujsPh34ivdrPbR2qMgcNcSAZzjjauWB56ECta28K6rcYLRJCpXcGlfH4YGSDz3FNLgV1dn 8J7FN/23U7ibONvkosePXOd2e3p+NbUHgm2Xd9ovJZOmPLUJj885pPMPYV0tp4N8O2W/ytJtm34z 5wMuMem8nHXtWvBoOlW+7ZYxHdjO8b/y3E03cT3rd/z/AJ/z/wDX0qSj/P8An/P/ANcoo/z/AJ/z /wDXKKP8/wCf8/8A1yij/P8An/P/ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ANcoo/z/ AJ/z/wDXKKP8/wCf8/8A1yinxwySY2qfr2pyRu+Nqn60oUnoKnSyc43OF+nOOlSrbMcbmA+nNOEZ 7nFTJZxDGSW+p+lSLbIMZJP404Rj61MiImNqgfT8PepFRVxtAH+RSgAdBTgenP6/T3pwpaAenP6/ T3oFFAPTn9fp70CijIAyTx9fp70ZwMk/rRVaS9VOE+Y+vb/69QPcqvC/Mf0phkA6c1TkmeU/Oxx6 DoP8/wCfeu8jSH5j+HpTCxPU0z/P+f8AP/120lH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+ f8/5/wDrlFH+f8/5/wDrlFGen+f8/wCfxSikz/n/AD/n+pn/AD/n/P8AUo/z/n/P/wBdP8/5/wA/ /XSj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yj/AD/n /P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yooriGdnWKRXK4zt 56/5/wA92JNHKzBHDFeuP8/5/mgZWJAOcVL/AJ/z/n/67/8AP+f8/wD11o/z/n/P/wBc/wA/5/z/ APXKP8/5/wA//XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XK5T4i3 EUPgy6jkfDTvHHGME7m3hsfkpP8AnnG8VSpHoEys2DIyqvudwP8AIH/PVyferxSvPalooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooqe0sru/lMVnazXEgXcUhjLkDpnA7cj86kht57lykEMkrAZKxqWOP woziujsPh34ivdrPbR2qMgcNcSAZzjjauWB56ECta28K6rcYLRJCpXcGlfH4YGSDz3FNLgV01h8K IF2tqOpyPlBujt0C7W46Mc5HXsP6Vr23gmIYN1eO2V5WJQMHjuc5H4CkMnoK6aw8D+HdP2lNNjmc IEZ7gmXd05wSVyfYD/HXtvDulWuCtokjbQpaX589OcHjP0FNLE963oo44YkiiRY40UKqIMBQMYAH 9P8AJ00RY0VEUKigBVUYAHtSU/8Az/n/AD/9d1FH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8A rlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUU9IpHxt U89+3+f8/Vyxu2Nqn60oBPQVMlnI2NzKo+uSP8/595FtnOMkD8elKIz34qZLOMYLMW9s4H86kW2Q YySacIx35qZIo0xtVQR0Pft71KsaLjCgYpwAHQU8Hpz+v096cKWgHpz+v096BRQD05/X6e9AooB6 c/r9PegUUA9Of1+nvQKKAenP6/T3oFFV5bxU4Q7z9eB0/P8Az+MMlwq8L8x+tNLgdOapSTPKfnY4 9B0H+f8APvWeRpD8x/D0qMsT1NM/z/n/AD/9dtJR/n/P+f8A65RR/n/P+f8A65RR/n/P+f8A65RR /n/P+f8A65RR/n/P+f8A65RRnp/n/P8An8UopM/5/wA/5/qZ/wA/5/z/AFKP8/5/z/8AXT/P+f8A P/10o/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANco/wA/ 5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9cqhc6tbw8IfNb/Z PH5//r/xqzahDFwp8xvY8fn/AJ/xjaZV6cn2rHub+e64eQBf7q8D+fNZ013LPwzgL/dHSoGkZ+p4 9BV/Q+ftHP8Ad/r/AJ/zza0r/lr+H9alt/4q2P8AP+f8/wD19H/P+f8AP/15qP8AP+f8/wD1z/P+ f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yuG +Kf/ACLFt/1+L/6A9c74z/5A8P8A18D/ANBanx/e/CvIq4apKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKntLK7v 5TFZ2s1xIF3FIYy5A6ZwO3I/OpIbee5cpBDJKwGSsaljj8KM4ro7D4d+Ir3az20dqjIHDXEgGc44 2rlgeehArWtvCuq3GC0SQqV3BpXx+GBkg89xTS4FdNYfCiBdrajqcj5Qbo7dAu1uOjHOR17D+la9 t4JiGDdXjtleViUDB47nOR+ApDJ6CumsPA/h3T9pTTY5nCBGe4Jl3dOcElcn2A/x17bw7pVrgraJ I20KWl+fPTnB4z9BTSxPet6KOOGJIokWONFCqiDAUDGAB/T/ACdNEWNFRFCooAVVGAB7UlP/AM/5 /wA//XdRR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH +f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFOSN3xtUnnqO3+f8+6qjNjaCfpSgE9BU6WcjY3 Mqj65I/z/n3lW2c4yQPx6UojPfipks4xgsxb2zgfzqRbZBjJJpwjHfmpkijTG1VBHQ9+3vUqxouM KBinAAdBTwenP6/T3pwpaAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegU UA9Of1+nvQKKAenP6/T3oFFQSXkacA7z7HjtUT3CLwDuPt+FNLge9U5LiSX7zYHoOnb/AD/nms8z v1bj0FRlie9Rf5/z/n/67KSj/P8An/P/ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ANco o/z/AJ/z/wDXKKM9P8/5/wA/ilFJn/P+f8/1M/5/z/n+pR/n/P8An/66f5/z/n/66Uf5/wA/5/8A rn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuUf5/z/n/65/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uUf5 /wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuVQudWt4eEPmt/snj8/wD9f+NWbUIYuFPmN7Hj 8/8AP+MbTKvTk+1Y9zfz3XDyAL/dXgfz5rOmu5Z+GcBf7o6VA0jP1PHoKrZ9xUGfem0Z9xRn3orY 0Pn7Rz/d/r/n/POjpX/LX8P61Pb/AMVbH+f8/wCf/r6P+f8AP+f/AK81H+f8/wCf/rn+f8/5/wDr lH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlcN8U/wDkWLb/ AK/F/wDQHrnfGf8AyB4f+vgf+gtT4/vfhXkVcNUlFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFS29tPdzrBbQyTTN92ONSzHjPAFP iiknkEcMbySN0VFyT+AorodP8A+ItQ8tvsX2aJ8/vLlgm3Geq/e7encdua1LXwzqt1sP2fykbPzS ttx9R1/SmlwO9dLp/wAJ/wDVPqWp+vmRWyflh2/A/d9vete18E/ca7vP99IV/LDH8O1IZPQV1Gme BfD2mKMWK3Mm0qZLr94SCc/dPy57cDp+uzZ+G9LtAP8ARhM+MFpvnzznp0z9B/8AXaWJ710MUccM SRRIscaKFVEGAoGMAD+n+TqIixoqIoVFACqowAPakp/+f8/5/wDruoo/z/n/AD/9coo/z/n/AD/9 coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9copy Ru+Nqk89R2/z/n3VUZsbQT9KUAnoKmSzlbGSq8+ufTn/AD/+uRbZzjOF59aURn2FTJZIMbmLc9uP T3qVbZRjLE04RjuamSGJMbUXrn19PepFijXGFHXNOCgdhUgPTn9fp708UtAPTn9fp70CigHpz+v0 96BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/ X6e9AoqCS8jTgHefY8dqie4ReAdx9vwppcD3qnJcSS/ebA9B07f5/wA81nmd+rcegqMsT3qL/P8A n/P/ANdlJR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RRnp/n/P +fxSikz/AJ/z/n+pn/P+f8/1KP8AP+f8/wD10/z/AJ/z/wDXSj/P+f8AP/1z/P8An/P/ANco/wA/ 5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/ AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyuQ1v4iaPpeY7Vv7QuB/DC37sdOr8joT0zyCDisPUfFVhZ 5SE/apfSM/KOnVvx7Zp4Qn2rzrUPE2seKb2Gzu7vybeaRU8mEERjJAyRnLcjPJPOcYrlbrWL7WZ0 gnn2RSOF8uMYUZI6jqfXk044RC2M4Ga9Ez7iukz71m0Z9xRn3ooz7ijPvRRn3FGfeitjQ+ftHP8A d/r/AJ/zzo6V/wAtfw/rU9v/ABVsf5/z/n/6+j/n/P8An/681H+f8/5/+uf5/wA/5/8ArlH+f8/5 /wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlcN8U/8AkWLb/r8X/wBA eud8Z/8AIHh/6+B/6C1Pj+9+FeRVw1SUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUVLb2093OsFtDJNM33Y41LMeM8AU+KKSeQRwxvJI3RUXJP4Ci uh0/wD4i1Dy2+xfZonz+8uWCbcZ6r97t6dx25rUtfDOq3Ww/Z/KRs/NK23H1HX9KaXA710un/Cf/ AFT6lqfr5kVsn5YdvwP3fb3rXtfBP3Gu7z/fSFfywx/DtSGT0FdNp/gHw7p/lt9i+0ypn95cMX3Z 9V+6evp6d+Tr2vhnSrXYfs/nOv8AFKd2c+o6Hr6U0uT3robe3gtIEgtoY4IU+7HEoVVyc8AfX9fz 1Yoo4I1jhjSONeioAAPoBSVL/n/P+f8A676KP8/5/wA//XKKP8/5/wA//XKKP8/5/wA//XKKP8/5 /wA//XKKP8/5/wA//XKKP8/5/wA//XKKP8/5/wA//XKKP8/5/wA//XKKVVZvuqTj05x/n/Puqqzd ATj05oAJ6VOlnKxGcKPrmpFt3PXC/jTghPtUyWSDG5i3Pbj096lW2UYyxNOEY7mpkhiTG1F659fT 3qRYo1xhR1zTgoHYVID05/X6e9PFLQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAP Tn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70Ci oJLyNOAd59jx2qJ7hF4B3H2/CmlwPeqclxJL95sD0HTt/n/PNZ5nfq3HoKjLE96i/wA/5/z/APXZ SUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RRnp/n/P+ fxSikz/n/P8An+pn/P8An/P9Sj/P+f8AP/10/wA/5/z/APXSj/P+f8//AFz/AD/n/P8A9co/z/n/ AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/ 5/z/APXKP8/5/wA//XP8/wCf8/8A1yuQ1v4iaPpeY7Vv7QuB/DC37sdOr8joT0zyCDisPUfFVhZ5 SE/apfSM/KOnVvx7Zp4Qn2rzTW/Fusa/lLu42W5/5d4flj7dR1bkZ5Jwc4xXI6jrl/qeVml2xH/l lHwvbr69M85p4UCsOs6lq7o//IbsP+viP/0IVPZf8f8Ab/8AXVf5imS/6p/9016zn3Fdln3rOoz7 ijPvRRn3FGfeijPuKM+9FbGh8/aOf7v9f8/550dK/wCWv4f1qe3/AIq2P8/5/wA//X0f8/5/z/8A Xmo/z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P /wBc/wA/5/z/APXK4b4p/wDIsW3/AF+L/wCgPXO+M/8AkDw/9fA/9Banx/e/CvIq4apKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKdHHJNKkUSNJI7BVRRksT0AH c0qI0jqiKWdjhVUZJPoKK6TT/APiLUPLb7F9mifP7y5YJtxnqv3u3p3Hbmta18M6rdbD9n8pGz80 rbcfUdf0ppcDvXS6f8J/9U+pan6+ZFbJ+WHb8D9329617XwT9xru8/30hX8sMfw7Uhk9BXTaf4B8 O6f5bfYvtMqZ/eXDF92fVfunr6enfk69r4Z0q12H7P5zr/FKd2c+o6Hr6U0uT3robe3gtIEgtoY4 IU+7HEoVVyc8AfX9fz1Yoo4I1jhjSONeioAAPoBSVL/n/P8An/676KP8/wCf8/8A1yij/P8An/P/ ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8A n/P/ANcopVVm+6pOPTnH+f8APuqqzdATj05oAJ6VMtpK3Xav1apFt5D6D8acEb2FTLYr/FIT6Y4q RbVe7n2xThGPWpkghXoi/jz6e9SrFGvRR+PNOCqOwqUHpz+v096eKWgHpz+v096BRQD05/X6e9Ao oB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9Pe gUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70Ciq93qFnp0KzX15BbRMwUPPKEBOM4yT1wDUU91b2sY kuZ4oUJwGkcKCfTk0U0ahCykpvbDFcFSvIOD17ccHv1HB5b9rjK5XccEjkEdDjv/AJP400uB71Wk uJJfvNgeg6dv8/55geZ36tx6CoyxPeov8/5/z/8AXZSUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUU f5/z/n/65RR/n/P+f/rlFGen+f8AP+fxSikz/n/P+f6mf8/5/wA/1KP8/wCf8/8A10/z/n/P/wBd KP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA/ /XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XK5DW/iJo+l5jtW/tC4 H8MLfux06vyOhPTPIIOKw9R8VWFnlIT9ql9Iz8o6dW/HtmnhCfavNNb8W6xr+Uu7jZbn/l3h+WPt 1HVuRnknBzjFcjqOuX+p5WaXbEf+WUfC9uvr0zzmnhQKw6zqWiiiiiiruj/8huw/6+I//QhU9l/x /wBv/wBdV/mKZL/qn/3TXrOfcV2Wfes6jPuKM+9FGfcUZ96KM+4oz70VsaHz9o5/u/1/z/nnR0r/ AJa/h/Wp7f8AirY/z/n/AD/9fR/z/n/P/wBeaj/P+f8AP/1z/P8An/P/ANco/wA/5/z/APXP8/5/ z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9crhvin/AMixbf8AX4v/AKA9c74z /wCQPD/18D/0FqfH978K8irhqkoooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooop 0cck0qRRI0kjsFVFGSxPQAdzSojSOqIpZ2OFVRkk+gorfsPA/iLUMFNNkhQuEL3BEe3pztPzEc9g a07bw7qt1graNGu7aWl+THvg8457CkLAd66aw+FE7bW1HU40w43R26F9ycdGOMHr2P49K17bwTIc G6vEXDcrEu7K8dzjB/A00yegrpbD4d+HbHaXtpLt1cOHuJM46cbVwpHsQevete18K6Vb4LRNOwbc GlbPpxgYBH1FJvJrpLSytLCIxWdtDbxltxSFAgzwM4HfpWtBbwWybIIY4lJyVjUKM8c8d6bnNT/5 /wA/5/8Ary0Uf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUU f5/z/n/65RR/n/P+f/rlFKqsxwoJPXjn/P8An8QAscAE/SgDPSpktZWxwFHufp/n/PMi28jY4A+p pwRj7VMtiv8AFIT6Y4qVbVe7n2xThGPWpkghXoi/jz6e9SrFGvRR+PNOCqOwqUHpz+v096eKWgHp z+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQ D05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70Ciori7t7K3a4uriKCBMbpJX CquSAMknHU/rTJZ4reIyzSpHGuMu7AAdO5NFcxqXxI8MaZ5q/wBoG6mj2/u7VDJuzjo33Dwf73Y9 +Kx7vxbo1nvX7V5zpj5IVLZzjo33f1ozXKal8Zv9amlaT6eXNdSfTOUX8R970PtWHefED762Vj6b JJn+mcqPx7/4UZqG0v8A4geLtz/azpWnS7TvRPLwvynMZ/1hyOc7sHkZ7VHBdeKNdy3n/YrV9p3K uzjj7v8AEc9euDyM00uBXWaR4bs9MkW6lL3uplR5t9csXlY4xkEk7eDjA7YBz32rHSYLNhO5a4vC BvuZTucnGOMk44OOO2OtRlia2f8AP+f8/wD19Cko/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A 9coo/wA/5/z/APXKKP8AP+f8/wD1yijPT/P+f8/ilFJn/P8An/P9TP8An/P+f6lH+f8AP+f/AK6f 5/z/AJ/+ulH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f 8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlchrfxE0fS8x2rf2h cD+GFv3Y6dX5HQnpnkEHFYeo+KrCzykJ+1S+kZ+UdOrfj2zTwhPtXmmt+LdY1/KXdxstz/y7w/LH 26jq3IzyTg5xiuR1HXL/AFPKzS7Yj/yyj4Xt19emec08KBWHWdS0UUUUUUUUUUUVd0f/AJDdh/18 R/8AoQqey/4/7f8A66r/ADFMl/1T/wC6a9Zz7iuyz71nUZ9xRn3ooz7ijPvRRn3FGfeitjQ+ftHP 93+v+f8APOjpX/LX8P61Pb/xVsf5/wA/5/8Ar6P+f8/5/wDrzUf5/wA/5/8Arn+f8/5/+uUf5/z/ AJ/+uf5/z/n/AOuUf5/z/n/65/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uVw3xT/5Fi2/6/F/9Aeu d8Z/8geH/r4H/oLU+P734V5FXDVJRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRTo45JpUiiRp JHYKqKMliegA7mlRGkdURSzscKqjJJ9BRW/YeB/EWoYKabJChcIXuCI9vTnafmI57A1p23h3VbrB W0aNd20tL8mPfB5xz2FIWA7101h8KJ22tqOpxphxujt0L7k46McYPXsfx6Vr23gmQ4N1eIuG5WJd 2V47nGD+Bppk9BXS2Hw78O2O0vbSXbq4cPcSZx042rhSPYg9e9a9r4V0q3wWiadg24NK2fTjAwCP qKTeTXSWllaWERis7aG3jLbikKBBngZwO/StaC3gtk2QQxxKTkrGoUZ454703Oan/wA/5/z/APXl oo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBcoo/z /n/P/wBcoo/z/n/P/wBcopVVmOFBJ68c/wCf8/iAFjgAn6UAZ6VMlrK2OAo9z9P8/wCeZFt5GxwB 9TTgjH2qZLEcbpD9B2PFSrajjc/5U4R+pqZLeFcYUE+5z6e9SLDGuPlB+vNKFUdqlGAAB04/p71I OAAKdQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05 /X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRUVxd29lbtcXVx FBAmN0krhVXJAGSTjqf1pks8VvEZZpUjjXGXdgAOncmiuY1L4keGNM81f7QN1NHt/d2qGTdnHRvu Hg/3ux78Vj3fi3RrPev2rznTHyQqWznHRvu/rRmuU1L4zf61NK0n08ua6k+mcov4j73ofasO8+IH 31srH02STP8ATOVH49/8KM1yep/EjxRqXmr/AGgbWGTH7u1UJtxjo3LjOP73c9uKxLzxbrN3vH2r yEbHyQjbjGOjfe7etJmuZurq4vbh7i7nlnnfG6SVyzNgYGSeegArGmmluJWlnleWRuruxYn8TRXQ aD4G1jXNkvlfZLRsHz5xjcpxyq9W4OR0B9a1NN8OX+o7X2eRAcHzJBjI46DqeDn096aWAr0vQfA2 j6Hsl8r7Vdrg+fOAdp4OUXoORkdSM9TXXaZ4csNO2vs86cYPmSc4PHKjoOR9femFia6b/P8An/P/ ANfYpKP8/wCf8/8A1yij/P8An/P/ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ANcooz0/ z/n/AD+KUUmf8/5/z/Uz/n/P+f6lH+f8/wCf/rp/n/P+f/rpR/n/AD/n/wCuf5/z/n/65R/n/P8A n/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65R/n/AD/n/wCuf5/z/n/6 5R/n/P8An/65/n/P+f8A65XIa38RNH0vMdq39oXA/hhb92OnV+R0J6Z5BBxWHqPiqws8pCftUvpG flHTq349s08IT7V5prfi3WNfyl3cbLc/8u8Pyx9uo6tyM8k4OcYrkdR1y/1PKzS7Yj/yyj4Xt19e mec08KBWHWdS0UUUUUUUUUUUUUUUUUVd0f8A5Ddh/wBfEf8A6EKnsv8Aj/t/+uq/zFMl/wBU/wDu mvWc+4rss+9Z1GfcUZ96KM+4oz70UZ9xRn3orb0RMQyyZzubbj6f/rrU0tf3cj56tjH0/wD11Ytx 8rH1Nav+f8/5/wDr3v8AP+f8/wD15aP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/ z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyuG+Kf/IsW3/X4v/oD1zvjP/kDw/8AXwP/ AEFqfH978K8irhqkoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooorcs/BviK+3+VpNwuzGfOAizn03kZ/D+t aMGg6rcbtljKNuM+YNn5bsZ/Ck3Ad66jT/hRdNLnUtRhjjDKdtsC5YdxlgNp6Y4PX89m18FTF83d 1GqAjiEFiR35OMfr/i0yDsK6iw+Hfh2x2l7aS7dXDh7iTOOnG1cKR7EHr3rYtfCulW+C0TTsG3Bp Wz6cYGAR9RSbya6S0srSwiMVnbQ28ZbcUhQIM8DOB36VrQW8FsmyCGOJSclY1CjPHPHem5zU/wDn /P8An/68tFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5 /wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFWLaGObq5BH8I/n/n/9csMS SdWII7D+f+f/ANbkUN3q2lvCuMKCfc59PerCwxrj5QfrzTwqjtUowAAOnH9PepBwABTqAenP6/T3 oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9f p70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKZJNHBC800ixxRrud3bCqBgkkk8 CmvIkcbSSOqooyzMcAD1JzRXOaj8QfDGmZWTVY55BHvVLbMu72DLlQeOhI9+KybvxTo1nkNepIwX cFhy+fbI4zx3NGa5PUfjNbruXS9KlkzH8sl1IE2v7qucjp/EM89OtYd38QIhkWdk7ZXh5n24b/dG cjp3FGa5HVfiX4m1RTGt4tlEVAKWalCSDnO4ksD0HBAwPc5wr3xfrF6ConFuhABWAbe+c5OSPwNJ muWurq4vbh7i7nlnnfG6SVyzNgYGSeegArFmmluJWlnleWRuruxYn8TRUNMoooorptB8DaxrmyXy vslo2D584xuU45VercHI6A+ta+m+HL/Udr7PIgOD5kgxkcdB1PBz6e9NLAV6XoPgbR9D2S+V9qu1 wfPnAO08HKL0HIyOpGeprrtM8OWGnbX2edOMHzJOcHjlR0HI+vvTCxNdN/n/AD/n/wCvsUlH+f8A P+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUZ6f5/z/n8UopM/ 5/z/AJ/qZ/z/AJ/z/Uo/z/n/AD/9dP8AP+f8/wD10o/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8 /wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1 yj/P+f8AP/1z/P8An/P/ANcrkNb+Imj6XmO1b+0Lgfwwt+7HTq/I6E9M8gg4rD1HxVYWeUhP2qX0 jPyjp1b8e2aeEJ9q801vxbrGv5S7uNluf+XeH5Y+3UdW5GeScHOMVyOo65f6nlZpdsR/5ZR8L26+ vTPOaeFArDrOpaKKKKKKKKKKKKKKKKKKKKKKKKu6P/yG7D/r4j/9CFT2X/H/AG//AF1X+Ypkv+qf /dNes59xXZZ96zqM+4oz70UZ9xRn3ooz7ijPvRW9ov8Ax5v/ANdD/If5/wA862mf8ezf75/p/n/P Ni3/ANWfrWl/n/P+f/r3P8/5/wA//Xlo/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1y j/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/AJ/z/wDXK87+LF3IlhptmAvlyyvKx75QADHt85/T 8eW8bTMttaQADa7s5PfKgAf+hH/PV8fUmvLa42pKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK3LPwb4ivt/laTcLsxnzg Is59N5Gfw/rWjBoOq3G7ZYyjbjPmDZ+W7GfwpNwHeums/hRfPv8Atup28OMbfJQy59c5247ev+Ov B4JuW3faLyKPpjy1L5/PHtTfMHpXTWfw18O22/zo7i73Yx50xG36bNvXPfP+OxB4S0qLdvSWfOP9 ZJjb9NuP8/qm810tnp1jp+/7FZ29tvxv8iJU3Y6Zx16n8/z14LS2td32e3ih3Y3eWgXPp069abkn qatf5/z/AJ/+vNRR/n/P+f8A65RR/n/P+f8A65RR/n/P+f8A65RR/n/P+f8A65RR/n/P+f8A65RR /n/P+f8A65RR/n/P+f8A65RR/n/P+f8A65RSqCxAAJPoOf8AP+fxACTgcn2oqVLWV8fLtB7k9KkW CRscYHuelOCMamSy6b3/AAWpFtem5vwFKI/U1l63OdOa0MXKsW3g/wAXA/Lr/wDr70dUlNkbcx9C W3A9+n+NRXDeVs2985p9vcR3MQkjbK/qD/j/AJ+roZkmjDocj+X/ANf/AD9VVg65BqX/AD/n/P8A 9eSlpVYowZTgjnj/AD/n+YrFSCDgj0oBwcitCC5WXCnh/TPB6dOauRTiTAPDfzqVXDcd6nB6c/r9 PepRTqAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAen P6/T3oFFAPTn9fp70CimSTRwQvNNIscUa7nd2wqgYJJJPApryJHG0kjqqKMszHAA9Sc0Vzmo/EHw xpmVk1WOeQR71S2zLu9gy5UHjoSPfism78U6NZ5DXqSMF3BYcvn2yOM8dzRmuT1H4zW67l0vSpZM x/LJdSBNr+6rnI6fxDPPTrWHd/ECIZFnZO2V4eZ9uG/3RnI6dxRmuT1H4n+KNQ3Kl3HZxtHsZLaP GevIZssD7gjp61iXfjLWbrIWdLdSu0rCmPxyckH6GkzXLXl/eajMJr67nupVXaHnkLsB1xknpyfz rFuLq4u5BJczyzOBtDSOWIHpk0VXqKiiiiiiiiiium0HwNrGubJfK+yWjYPnzjG5TjlV6twcjoD6 1r6b4cv9R2vs8iA4PmSDGRx0HU8HPp700sBXpeg+BtH0PZL5X2q7XB8+cA7TwcovQcjI6kZ6muu0 zw5YadtfZ504wfMk5weOVHQcj6+9MLE103+f8/5/+vsUlH+f8/5/+uUUf5/z/n/65RR/n/P+f/rl FH+f8/5/+uUUf5/z/n/65RRnp/n/AD/n8UopM/5/z/n+pn/P+f8AP9Sj/P8An/P/ANdP8/5/z/8A XSj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8A P/1z/P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yuQ1v4iaPpeY7Vv7Q uB/DC37sdOr8joT0zyCDisPUfFVhZ5SE/apfSM/KOnVvx7Zp4Qn2rzTW/Fusa/lLu42W5/5d4flj 7dR1bkZ5Jwc4xXI6jrl/qeVml2xH/llHwvbr69M85p4UCsOs6loooooooooooooooooooooooooo ooooq7o//IbsP+viP/0IVPZf8f8Ab/8AXVf5imS/6p/9016zn3Fdln3rOoz7ijPvRRn3FGfeijPu KM+9Fb2i/wDHm/8A10P8h/n/ADzraZ/x7N/vn+n+f882Lf8A1Z+taX+f8/5/+vc/z/n/AD/9eWj/ AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z /P8An/P/ANcrzT4tf8wf/tt/7JXJeN/+XD/tp/7LUkfevNK5Gn0UUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUVuWfg3xFfb/K0m4XZjPnAR Zz6byM/h/WtGDQdVuN2yxlG3GfMGz8t2M/hSbgO9dNZ/Ci+ff9t1O3hxjb5KGXPrnO3Hb1/x14PB Ny277ReRR9MeWpfP549qb5g9K6az+Gvh223+dHcXe7GPOmI2/TZt6575/wAdiDwlpUW7eks+cf6y TG36bcf5/VN5rpbPTrHT9/2Kzt7bfjf5ESpux0zjr1P5/nrwWlta7vs9vFDuxu8tAufTp1603JPU 1a/z/n/P/wBeaij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/ APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKVQWIABJ9Bz/AJ/z+IAScDk+1FSpayvj 5doPcnpUiwSNjjA9z0pwRjUyWXTe/wCC1Itr03N+ApRH6mpktoVx8uSO5P096lWCNccZPuacEUdq lUBQAuAPQfh709QAABgD2pw46UoPTn9fp70oooB6c/r9PegUVzfiw8WfP9/+S+9YviA8W3P97+Qq pe/8s/x/pWBBcy20geKTHOSM8Hr15rIinkgcMj456dj9arK5Q5Bro7S8jvIt6HDD7y55U1tW9wlx HuU4I6rnpVtHDrkfiPSrH+f8/wCf/rzU6gEggg4I547f5/z7gOCCDj6UVft7sPtRzh/XsenvVuG4 DYVuG9exqRXzwetWQenP6/T3qYU+gHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKK569 8deGNP8AL87WrZt+ceQxmxjHXZnHXv15rKuPEmjWuzzNQhbd08omTpjrtzj8aK47UfjNbruXS9Kl kzH8sl1IE2v7qucjp/EM89OtYF38QIhkWdk7ZXh5n24b/dGcjp3FGa5PUfif4o1DcqXcdnG0exkt o8Z68hmywPuCOnrWJd+MtZushZ0t1K7SsKY/HJyQfoaTNcteX95qMwmvrue6lVdoeeQuwHXGSenJ /OsW4uri7kElzPLM4G0NI5YgemTRVeoqKKKKKKKKKKKKKKKK6bQfA2sa5sl8r7JaNg+fOMblOOVX q3ByOgPrWvpvhy/1Ha+zyIDg+ZIMZHHQdTwc+nvTSwFel6D4G0fQ9kvlfartcHz5wDtPByi9ByMj qRnqa67TPDlhp219nnTjB8yTnB45UdByPr70wsTXTf5/z/n/AOvsUlH+f8/5/wDrlFH+f8/5/wDr lFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFJn/P8An/P9Uz/n/P8An+pR/n/P +f8A66f5/wA/5/8ArpR/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65R/n/AD/n/wCuf5/z /n/65R/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65XIa38RNH 0vMdq39oXA/hhb92OnV+R0J6Z5BBxWHqPiqws8pCftUvpGflHTq349s08IT7V5prfi3WNfyl3cbL c/8ALvD8sfbqOrcjPJODnGK5HUdcv9Tys0u2I/8ALKPhe3X16Z5zTwoFYdZ1LRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRWn4dt/tPiCyj37cSeZnGfujdj8cYq3pkfm6lAu7GG3Zx6c/0qOdtsLn 2xXqefcV12fes+jPuKM+9FGfcUZ96KM+4oz70VvaL/x5v/10P8h/n/POtpn/AB7N/vn+n+f882Lf /Vn61pf5/wA/5/8Ar3P8/wCf8/8A15aP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANco /wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yvNPi1/zB/wDtt/7JXJeN/wDlw/7af+y1 JH3rzSuRp9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFbFh4V13UsG10u4KsnmK7r5asvGCGbAPUdDV620bUrvHk2cpBXcGYbVI9icA9aQsB3rpbD4V6nM Va+vba2QoGxGDK6tx8pHA7nkE9O+a2LbwXeSYNzcRQqVzhcuwPHBHA/I00uO1dNYfDHQrba101xe NsAYPJtXPHzALgj6ZPXvWvbeD9NhwZjLOduCGbC545GOfwyetIXP0rprDRtM0sqbGwtrdwgj3xxg OV46t1PQdSf8de2sLOzwbe2iiYLt3Ko3Y479TTSSepq9/n/P+f8A69mij/P+f8//AFyij/P+f8// AFyij/P+f8//AFyij/P+f8//AFyij/P+f8//AFyij/P+f8//AFyij/P+f8//AFyij/P+f8//AFyi lUFiAASfQc/5/wA/iAEnA5PtRUqWsr4+XaD3J6VIsEjY4wPc9KcEY1Mll03v+C1Itr03N+ApRH6m pktoVx8uSO5P096lWCNccZPuacEUdqlUBQAuAPQfh709QAABgD2pw46UoPTn9fp70oooB6c/r9Pe gUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRXN+LDxZ8/3/5L71i+IDxbc/3v5Cql 7/yz/H+lc1n3FYmfeqtPimkhcPHIUYHqD/nNPSR4mDI5UjuDShipyDg10dhfpeR44WVfvLn9R/n/ AOvs2l2tyno46r/Uf5/+vajkDj0I6irf+f8AP+f/AK9in0f5/wA/5/8ArlFXbe7BASVueMNnr0/z /nmzDccBXPPY1Ij9jWTe+OvDGn+X52tWzb848hjNjGOuzOOvfrzVK48SaNa7PM1CFt3TyiZOmOu3 OPxp9cpe/GbT4/L+waVdT5zv8+QRY6Yxjdnv6fjWJcfEC1Tb9msppf73muEx0xjG7PejNcne/Ffx RdeX5MttZ7c58iHO/p13lumO2OprDuPG2szbfLeG325z5Ued313Z/SkzXJ3uq6jqfl/b7+6u/Lzs 8+ZpNucZxk8ZwPyrEuL26vNv2m5mn252+bIWxnrjP0oqpUFFFFFFFFFFFFFFFFFFFFFFFbmh+EdY 1/D2lvstz/y8THbH36Hq3Ix8oOD1xWjp2h3+p4aCLbF/z1k4Xv09emOM0hYCvTvD/wAP9K0SWO5m Zr28jYMskgwqEZwVUHryOpPIBGK7DS/DFlp7pNITcXCnIdhgKexC+vI656cUwuT7V1v+f8/5/wDr 7lNo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n /P8A9copM/5/z/n+qZ/z/n/P9Sj/AD/n/P8A9dP8/wCf8/8A10o/z/n/AD/9c/z/AJ/z/wDXKP8A P+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8 /wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBcrkNb+Imj6XmO1b+0Lgfwwt+7HTq/I6E9M8gg4rD1HxVY WeUhP2qX0jPyjp1b8e2aeEJ9q801vxbrGv5S7uNluf8Al3h+WPt1HVuRnknBzjFcjqOuX+p5WaXb Ef8AllHwvbr69M85p4UCsOs6loooooooooooooooooooooooooooooooooooooooooora8J/8jNa f8D/APQGq9o3/IVh/wCBf+gmorj/AFDfh/OvTM+4rq8+9UKM+4oz70UZ9xRn3ooz7ijPvRW9ov8A x5v/ANdD/If5/wA862mf8ezf75/p/n/PNi3/ANWfrWl/n/P+f/r3P8/5/wA//Xlo/wA/5/z/APXP 8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/AJ/z/wDX K80+LX/MH/7bf+yVyXjf/lw/7af+y1JH3rzSuRp9FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFbFh4V13UsG10u4KsnmK7r5asvGCGbAPUdDV620bUrvHk2cpBXcGYbVI9 icA9aQsB3rpbD4V6nMVa+vba2QoGxGDK6tx8pHA7nkE9O+a2LbwXeSYNzcRQqVzhcuwPHBHA/I00 uO1dNYfDHQrba101xeNsAYPJtXPHzALgj6ZPXvWvbeD9NhwZjLOduCGbC545GOfwyetIXP0rprDR tM0sqbGwtrdwgj3xxgOV46t1PQdSf8de2sLOzwbe2iiYLt3Ko3Y479TTSSepq9/n/P8An/69mij/ AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1 yij/AD/n/P8A9coo/wA/5/z/APXKKVQWIABJ9Bz/AJ/z+IAScDk+1FSpayvj5doPcnpUiwSNjjA9 z0pwRjUyWXTe/wCC1Itr03N+ApRH6mpktoVx8uSO5P096lWCNccZPuacEUdqlUBQAuAPQfh709QA ABgD2pw46UoPTn9fp70oooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096B RQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFc34sPFnz/f/kvvWL4gPFtz/e/kKqXv /LP8f6VzWfcViZ96q0Z9xRn3opySNGwZHKsCcEHBHX3pyuyMGVipHQg0AkHIODW/p2orcqI5CBMP /Hvce9a1neicBHIEg/X3HvVmKXfwfvfzrQ/z/n/P/wBe5UtH+f8AP+f/AK5RXn/jXwEdSkbUtHjU XjHM9vkKJc/xAk4Devr16/e5jxB4aN25u7BAJyf3kWQA/wDtD39fX69XK+ODXlUkbwyvFKjJIjFW RhgqR1BHY1xTo0bsjqVZTgqRgg1JTaSiiiiiiiiiiiiiiiiiiiiiitzQ/COsa/h7S32W5/5eJjtj 79D1bkY+UHB64rR07Q7/AFPDQRbYv+esnC9+nr0xxmkLAV6Zofw60fSsSXa/2hcD+KZR5Y69EyQe COueRkYrr9O8K2Flh5x9ql9ZB8o+i/j3zTC5PtXX/wCf8/5/+vu02j/P+f8AP/1yij/P+f8AP/1y ij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yikz/AJ/z/n+qZ/z/AJ/z/Uo/z/n/ AD/9dP8AP+f8/wD10o/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yj/AD/n/P8A9c/z /n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANcr mdd8c6Pom+Lzftd2uR5EBB2nkYZui8jBHJGeh75OpeI7DTtyb/PnGR5cZzg89T0HIx6+3q4KT9K8 y8Q+NNU8Qq0EjLBZFsi3i6HBJG49WPI9BwDjNcfqniC81QGNyIrcnPlJ354yep/lx0p4UD61zlZV Ooooooooooooooooooooooooooooooooooooooooooooooooora8J/8AIzWn/A//AEBqvaN/yFYf +Bf+gmorj/UN+H869Mz7iurz71Qoz7ijPvRRn3FGfeijPuKM+9Fb2i/8eb/9dD/If5/zzraZ/wAe zf75/p/n/PNi3/1Z+taX+f8AP+f/AK9z/P8An/P/ANeWj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9 c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9crzT4tf8wf8A7bf+yVyX jf8A5cP+2n/stSR9680rkafRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRWnp/h7WNV 8s2WnXEqSZ2SbNsZxnPznC9sdevFW7XS7+92G3tJXV87X24U4/2jxSEgdTXUaZ8LdUuVD6hcw2Sl Sdq/vXBzwCAQvI54Y9uK2bPwbezANdTR24I6D52Bz7cfrSFx25rqLD4Y6FbbWumuLxtgDB5Nq54+ YBcEfTJ6962bbwfpsODMZZztwQzYXPHIxz+GT1ppc/SumsNG0zSypsbC2t3CCPfHGA5Xjq3U9B1J /wAde2sLOzwbe2iiYLt3Ko3Y479TTSSepq9/n/P+f/r2aKP8/wCf8/8A1yij/P8An/P/ANcoo/z/ AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ANco oGSQB19v8/5/mDkgD9KKlS2lfGFwM9zjHTmnrDI2Plxz3PSlCMe1TR2XTe+PZalS1/vN+Apwj9T+ VTpbQrj5ckdyfp71KsEa44yfc04Io7VKoCgBcAeg/D3p6gAADAHtThx0pQenP6/T3pRRQD05/X6e 9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r 9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9Aorn/ABVExtILncgj ibaxZsfe2gd+ecD8RWRr0bG3imyoSM4bJ9cAfrx+NVrtGZFYchc5rls+4rBz71Toz7ijPvRRn3FG feijPuKM+9Fbmman5m2CdvnzhGz1/wDr/wA/56llfb8RSt838Lev/wBf/P1sRS5+Vjz2Nav+f8/5 /wDr6FTUf5/z/n/65RXG+NfBUevRNf2CqmpovIzgTgdAT/e9D+B4wRgeIPDy6khubYBbxRyOgkHo ff0P4ehpytjjtXj9xbT2k7QXMMkMy43RyKVYZGRkH2NcJLFJBIY5Y3jcdVdcEfhUlRUyiiiiiiii iiiiitzQ/COsa/h7S32W5/5eJjtj79D1bkY+UHB64rR07Q7/AFPDQRbYv+esnC9+nr0xxmkLAV6Z ofw60fSsSXa/2hcD+KZR5Y69EyQeCOueRkYrr9O8K2Flh5x9ql9ZB8o+i/j3zTC5PtXX/wCf8/5/ +vu02j/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1yij/P+f8AP/1y ikz/AJ/z/n+qZ/z/AJ/z/Uo/z/n/AD/9dP8AP+f8/wD10o/z/n/P/wBc/wA/5/z/APXKP8/5/wA/ /XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8 /wD1yj/P+f8AP/1z/P8An/P/ANcrmdd8c6Pom+Lzftd2uR5EBB2nkYZui8jBHJGeh75OpeI7DTty b/PnGR5cZzg89T0HIx6+3q4KT9K8013xzrGub4vN+y2jZHkQEjcDkYZurcHBHAPpXI6l4jv9R3Jv 8mA5HlxnGRz1PU8HHp7U8KB9a5qsinUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUVteE/wDkZrT/AIH/AOgNV7Rv+QrD/wAC/wDQTUVx/qG/D+demZ9xXV596oUZ9xRn3ooz 7ijPvRRn3FGfeit7Rf8Ajzf/AK6H+Q/z/nnW0z/j2b/fP9P8/wCebFv/AKs/WtL/AD/n/P8A9e5/ n/P+f/ry0f5/z/n/AOuf5/z/AJ/+uUf5/wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuUf5/z /n/65/n/AD/n/wCuV5p8Wv8AmD/9tv8A2SuS8b/8uH/bT/2WpI+9eaVyNPoooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooorT0/w9rGq+WbLTriVJM7JNm2M4zn5zhe2OvXirdrpd/e7Db2krq+dr7cKcf7R4 pCQOprptP+F2sXPltez29nG2d658yRfTgfKc8fxdD+FbFr4Nv5dhuJYoFOdwzvYenA4P50hcV0un /C7R7fy2vbi4vHXO9ciONs9OB8wxkfxdR+Fa9r4NsItjXEss7DO4Z2qfTgc/rTS5+ldNp3h7R9K8 s2WnW8UkedsoQNIM9fnOW7kdenFa9rpdhZbDb2kSMmcPtywz/tHnvSEk960/8/5/z/8AXuUlH+f8 /wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf /rlFH+f8/wCf/rlFAySAOvt/n/P8wckAfpRUqW0r4wuBnucY6c09YZGx8uOe56UoRj2qZLInG9wO ei8+lSran+JwPpThH6mpktYVxxuOc8n6e9SLBGMcZ5zyacEUe9TIqqMKAB7fh71IoCjCgAe1OGB0 pQenP6/T3pRRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v09 6BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CimSTRwQvNNIscUa7nd 2wqgYJJJPApryJHG0kjqqKMszHAA9Sc0VgXXjzw1aXCW51aGaZwCi2+ZQxJwBuXKg5HQkVlz+JtH t5BGb5JHIyoiy+fbI4z9TSMwRCxzgDJqrc+OIxkWtozfLw0r4w30Gcjj1/8Ar1Z/FCDIt7djxw0j YwfoM5H41TfUB/AhPHVjWPc+K9VuMhZ0gUrtKxL9eckkg/Q//Xzp9fv5sgSrECMERr+uTk1A97M3 RgoxjgV3WmO0mlWbu5ZmgQlicknaOetdVYsz2FszMWYxISScknArRhJMMZJySoq0D05/X6e9Tin1 yfxKP/FvtU57Rf8Ao1Kw/F//ACK15/wD/wBDWjtXl+geLz+6s9Sb/ZW5Y/lu/wAfz7muK07W/uQX R9hKT+Wf8f8A69VJrbq0f/fNdnn3FbmfeqtGfcUZ96KM+4oz70UZ9xRn3orV03U/KxBO/wAmcK5P 3fr7VoWV9sxFK3y/wt/dqaKXHyseOx9K3P8AP+f8/wD19SrFH+f8/wCf/rlFc34t8JW3iWz3KVhv 4l/czdiP7reqnP1BOR3Bydb0SLV4MjCXKD93J/Q+o/l/NVbb9K8Vv9OvNLumtr62kgmH8LjGRkjI PQjg8jg159c2s9nMYbiJo3HZh19x6j3qUEHpVaoaKKKK3ND8I6xr+HtLfZbn/l4mO2Pv0PVuRj5Q cHritHTtDv8AU8NBFti/56ycL36evTHGaQsBXpmh/DrR9KxJdr/aFwP4plHljr0TJB4I655GRiuv 07wrYWWHnH2qX1kHyj6L+PfNMLk+1df/AJ/z/n/6+7TaP8/5/wA//XKKP8/5/wA//XKKP8/5/wA/ /XKKP8/5/wA//XKKP8/5/wA//XKKP8/5/wA//XKKTP8An/P+f6pn/P8An/P9Sj/P+f8AP/10/wA/ 5/z/APXSj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj /P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yuZ13xzo+ib 4vN+13a5HkQEHaeRhm6LyMEckZ6Hvk6l4jsNO3Jv8+cZHlxnODz1PQcjHr7ergpP0rzTXfHOsa5v i837LaNkeRASNwORhm6twcEcA+lcjqXiO/1Hcm/yYDkeXGcZHPU9TwcentTwoH1rmqyKdRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRW14T/5Ga0/4H/6A1XtG/wCQ rD/wL/0E1Fcf6hvw/nXpmfcV1efeqFGfcUZ96KM+4oz70UZ9xRn3orodITbYBs53sT9O39P1/PY0 5dtoDnO5if6f5/zmzAMR/U1f/wA/5/z/APXtf5/z/n/68lH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/ AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArleafFr/AJg//bb/ANkrkvG/ /Lh/20/9lqSPvXmlcjT6KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK09P8Paxqvlmy064lSTOyTZtjOM5+c4Xtjr14 q3a6Xf3uw29pK6vna+3CnH+0eKQkDqa6bT/hdrFz5bXs9vZxtneufMkX04HynPH8XQ/hWxa+Db+X YbiWKBTncM72HpwOD+dIXFdLp/wu0e38tr24uLx1zvXIjjbPTgfMMZH8XUfhWva+DbCLY1xLLOwz uGdqn04HP600ufpXTad4e0fSvLNlp1vFJHnbKEDSDPX5zlu5HXpxWva6XYWWw29pEjJnD7csM/7R 570hJPetP/P+f8//AF7lJR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8A n/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RQMkgDr7f5/z/MHJAH6UVKltK+MLgZ7nGOnN PWGRsfLjnuelKEY9qmSyJxvcDnovPpUq2p/icD6U4R+pqZLWFccbjnPJ+nvUiwRjHGec8mnBFHvU yKqjCgAe34e9SKAowoAHtThgdKUHpz+v096UUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+ v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD0 5/X6e9Aopkk0cELzTSLHFGu53dsKoGCSSTwKa8iRxtJI6qijLMxwAPUnNFc5qPxB8MaZlZNVjnkE e9Utsy7vYMuVB46Ej34rJu/FOjWeQ16kjBdwWHL59sjjPHc0Zrk9R+M1uu5dL0qWTMfyyXUgTa/u q5yOn8Qzz061h3fxAiGRZ2TtleHmfbhv90ZyOncUZrk9R+J/ijUNypdx2cbR7GS2jxnryGbLA+4I 6etYl34y1m6yFnS3UrtKwpj8cnJB+hpM1y15f3mozCa+u57qVV2h55C7AdcZJ6cn86xbi6uLuQSX M8szgbQ0jliB6ZNFO03/AJCtn/13T/0IUWv/AB9w/wC+v86ZN/qJP90/yr0bPuK6TPvWPRn3FGfe ivVNKP8AxKLHn/lhH3/2V9673T/+Qda/9ck/kK2Yf9RH/uj+VWwenP6/T3qwKfXJ/Eo/8W+1TntF /wCjUrD8X/8AIrXn/AP/AENaO1fPleW0ldR4f8WPYpHZ3oL24OFlzkxD0x3H8hnr0rX03WWt1WC4 y0QOA/dB/Uf59qrzW28lk4b09a71JFkRXR1ZGGVYHIIPf3FdErBlDKwIPIIOc1TPBweDS59xRn3o oz7ijPvRRn3FGfeitDTtSNqwjlbMJP4p7/5//Xcs70wEJIcxk/8AfPv/AJ//AFyxS7OD93+Vb6Os ihkYMvYqcj/P+frrKyuoZWBHqDmrAIIyDke1O/z/AJ/z/wDXdS1j+IvDtn4k0421yNkqZMM6jLRM ccj1B4yO/wBcGqGq6VBq1r5M3yuvMcgGSh/r7j/6xpQcGvKIPh/4hn1Oaz+yrGsTYa4kbERBGQVP VgfYEjIziuKj8MapJdyW/khQhwZWOEPoQep/Ad+cU/eMZr0DQ/h1o+lYku1/tC4H8Uyjyx16Jkg8 Edc8jIxXT6d4VsLLDzj7VL6yD5R9F/Hvmmlyfauv/wA/5/z/APX3abR/n/P+f/rlFH+f8/5/+uUU f5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RSZ/wA/5/z/AFTP+f8AP+f6lH+f8/5/+un+ f8/5/wDrpR/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65R/n/ AD/n/wCuf5/z/n/65R/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5XM67450fRN8Xm/a7t cjyICDtPIwzdF5GCOSM9D3ydS8R2Gnbk3+fOMjy4znB56noORj19vVwUn6V5prvjnWNc3xeb9ltG yPIgJG4HIwzdW4OCOAfSuR1LxHf6juTf5MByPLjOMjnqep4OPT2p4UD61zVZFOoooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooora8J/wDIzWn/AAP/ANAar2jf 8hWH/gX/AKCaiuP9Q34fzr0zPuK6vPvVCjPuKM+9FGfcUZ96KM+4oz70V0ml/wDIOi/4F/6Ef8/5 52rD/jzj/H+Z/wA/55tQ/wCqFXP8/wCf8/8A17H+f8/5/wDrvo/z/n/P/wBc/wA/5/z/APXKP8/5 /wA//XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XK80+LX/MH/AO23 /slcl43/AOXD/tp/7LUkfevNK5Gn0UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUVesNG1PU9psbC4nUv5e9IyUDccFug6jqe9WbbT7y 8wbe2llBbbuVCVB9z0HUUhIHU101h8MddudrXTW1mm8Bg8m99vHzALkHr0yOnate28H6lNgzGKBd 2CGbc2OOQBkH6ZpC4+tdLYfCvTIdrX17cXLBw2IwI0K8cEcn15BHX89e28F2ceDcXEsxDZwoCKRx x3P5Gmlz2rq9O8PaPpXlmy063ikjztlCBpBnr85y3cjr04ratdLsLLYbe0iRkzh9uWGf9o896Qkn vWn/AJ/z/n/69yko/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8 /wD1yij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yigZJAHX2/z/AJ/mDkgD9KKlS2lfGFwM 9zjHTmnrDI2Plxz3PSlCMe1TJZE43uBz0Xn0qVbU/wATgfSnCP1NTJawrjjcc55P096kWCMY4zzn k04Io96mRVUYUAD2/D3qRQFGFAA9qcMDpSg9Of1+nvSiigHpz+v096BRQD05/X6e9AooB6c/r9Pe gUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+ nvQKKAenP6/T3oFFAPTn9fp70CiuevfHXhjT/L87WrZt+ceQxmxjHXZnHXv15rKuPEmjWuzzNQhb d08omTpjrtzj8aK5S9+M2nx+X9g0q6nznf58gix0xjG7Pf0/GsS4+IFqm37NZTS/3vNcJjpjGN2e 9Ga5O9+K/ii68vyZbaz25z5EOd/TrvLdMdsdTWHceNtZm2+W8Nvtznyo87vruz+lJmuQvL+81GYT X13PdSqu0PPIXYDrjJPTk/nWFcXVxdyCS5nlmcDaGkcsQPTJoqvUVFFFFFFFFFFWtN/5Ctn/ANd0 /wDQhUtr/wAfcP8Avr/OmTf6iT/dP8q9Gz7iukz71j0Z9xRn3or1TSj/AMSix5/5YR9/9lfeu90/ /kHWv/XJP5CtmH/UR/7o/lVsHpz+v096sCn1yfxKP/FvtU57Rf8Ao1Kw/F//ACK15/wD/wBDWjtX z5XltJV630XVbuBZ7bTLyaFs7ZI4GZTg44IHrVmLT72eMSQ2dxIh6MkRIP4gUmR6iu78M6B4r06V bO5sUFkxzukuExF6kbSSc+mOp7ZNdFpOla1bOIJbZRATnc0q/J9MEn8P/r1BNEknzA4b+ddnHocp z5k6L6bQW/w/z+u8mlyHO+VR6YGahFue7AfSp00SAKN8shbuVwB/X1qVdLi2jdI5PcjApwt1xyTm rKabZowYQjI9SSPyJ561OtlbKwIiGfck/wBaeIkBztqxHFHFny40TOM7QB/n/P4ypGkf3EVc9dop wUDoAPpT/wDP+f8AP/130tH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5 /wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFJn/P8An/P9Uz/n/P8An+pR /n/P+f8A66f5/wA/5/8ArpR/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65R/n/AD/n/wCu f5/z/n/65R/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65XM67 450fRN8Xm/a7tcjyICDtPIwzdF5GCOSM9D3ydS8R2Gnbk3+fOMjy4znB56noORj19vVwUn6V5prv jnWNc3xeb9ltGyPIgJG4HIwzdW4OCOAfSuR1LxHf6juTf5MByPLjOMjnqep4OPT2p4UD61zVZFOo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooora8J/ 8jNaf8D/APQGq9o3/IVh/wCBf+gmorj/AFDfh/OvTM+4rq8+9UKM+4oz70UZ9xRn3ooz7ijPvRXS aX/yDov+Bf8AoR/z/nnasP8Ajzj/AB/mf8/55tQ/6oVc/wA/5/z/APXsf5/z/n/676P8/wCf8/8A 1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8// AFyvIfin/wAjPbf9ea/+hvXDeM/+QxD/ANe4/wDQmqWP7v41w9c7TqKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKvWGjanqe02NhcTqX8vekZKBuOC 3QdR1PerNtp95eYNvbSygtt3KhKg+56DqKQkDqa6aw+GOu3O1rprazTeAweTe+3j5gFyD16ZHTtW vbeD9SmwZjFAu7BDNubHHIAyD9M0hcfWulsPhXpkO1r69uLlg4bEYEaFeOCOT68gjr+evbeC7OPB uLiWYhs4UBFI447n8jTS57V01h4W0LTdptdLtlZXEiu6+Y6txghmyR0HQ/8A19e20bTbTBhs4gwb cGYbmB45BOT/AJ/NCxPetj/P+f8AP/179JR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RR/n/P+f/rl FH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RUqW0r4wuBnucY6c09YZGx8 uOe56UoRj2qZLInG9wOei8+lSran+JwPpThH6mpktYVxxuOc8n6e9SLBGMcZ5zyacEUe9TIqqMKA B7fh71IoCjCgAe1OGB0pQenP6/T3pRRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFF APTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70 CigHpz+v096BRXPXvjrwxp/l+drVs2/OPIYzYxjrszjr3681lXHiTRrXZ5moQtu6eUTJ0x125x+N Fcpe/GbT4/L+waVdT5zv8+QRY6Yxjdnv6fjWJcfEC1Tb9msppf73muEx0xjG7PejNcne/FfxRdeX 5MttZ7c58iHO/p13lumO2OprDuPG2szbfLeG325z5Ued313Z/SkzXJ3uq6jqfl/b7+6u/Lzs8+Zp NucZxk8ZwPyrEuL26vNv2m5mn252+bIWxnrjP0oqpUFFFFFFFFFFFFFFFFFFFFFFFWtN/wCQrZ/9 d0/9CFS2v/H3D/vr/OmTf6iT/dP8q9Mitbmdd0MEsi5IyiFhn8Pr/nv1McE0q7o4ncZxlVJrJCOw yqkj2FXI9C1KTYfI2hucsw4B9RnPfpVhNKvX2/utoPdmHGfXnNPFtKcfLjPqa7yzuPs1hbQFdzRR KjEHjIAHHrXV283kWkERGWRFVjnjgDpWkjbI0XqQADTzfSZ4VQPqT6e/+f5v+1PngDH50vmH0FVb oLf2z212kc8D43RyIGU4II4PXkCoJ8XMLQzqskbY3I6gg9D0pu9j3qrZ6dY6fv8AsVnb22/G/wAi JU3Y6Zx16n8/zhgtLa13fZ7eKHdjd5aBc+nTr1pMk9TVr/P+f8//AF5qKP8AP+f8/wD1yij/AD/n /P8A9coo/wA/5/z/APXKKcqO/wB1WOOu0Zx/n/PuqqzfdBOPTnFABPQUrRPGoLjbntnn646/5/NW RkALDGe2efypSCBzxTP8/wCf8/8A120lH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf /rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFJn/P+f8AP9Uz/n/P+f6lH+f8/wCf/rp/n/P+ f/rpR/n/AD/n/wCuf5/z/n/65R/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5R/n/P+f8A 65/n/P8An/65R/n/AD/n/wCuf5/z/n/65R/n/P8An/65/n/P+f8A65XM67450fRN8Xm/a7tcjyIC DtPIwzdF5GCOSM9D3ydS8R2Gnbk3+fOMjy4znB56noORj19vVwUn6V5prvjnWNc3xeb9ltGyPIgJ G4HIwzdW4OCOAfSuR1LxHf6juTf5MByPLjOMjnqep4OPT2p4UD61zVZFOooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooroPBkHneIUk37fJjd 8Yznjbj/AMe/StLQ49+pK27GxS3Tr2/rUN02IcepxXo2fcV0+feqNGfcUZ96KM+4oz70UZ9xRn3o rpNL/wCQdF/wL/0I/wCf887Vh/x5x/j/ADP+f882of8AVCrn+f8AP+f/AK9j/P8An/P/ANd9H+f8 /wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+ f/rleQ/FP/kZ7b/rzX/0N64bxn/yGIf+vcf+hNUsf3fxrh652nUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUV2lh8MddudrXTW1mm8Bg8m99vHzALkHr0yOnaug tvB+pTYMxigXdghm3NjjkAZB+maaXH1rpbD4V6ZDta+vbi5YOGxGBGhXjgjk+vII6/nr23guzjwb i4lmIbOFARSOOO5/I00ue1dNYeFtC03abXS7ZWVxIruvmOrcYIZskdB0P/19e20bTbTBhs4gwbcG YbmB45BOT/n80LE962P8/wCf8/8A179JR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/ AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5R UiwSt0Qj68fz/wA/1esUjdFP8qUKx7VMlkx+84Hpjn/P+fxkW1Y9XA9Mc04RnuamS0hHXLfU1Ktv GPU/U04Iv1qZFVPugDPp+HvUiqq/dAH0pwAHSnA9Of1+nvSiigHpz+v096BRQD05/X6e9AooB6c/ r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9 Of1+nvQKKAenP6/T3oFFAPTn9fp70CisTUfGPh7Ss/a9YtlZZPLaON/NdWHUFUyR0PUf/XzrrX9K ss+ffwhg2wqjb2B9wuSOhork9R+MWkwZXT7C6u3WTbmQiJGX+8D8x7DgqOvbocO78fWMWRa2007B sZchFI9QeT+YHWjNcnqPxa8RXe5bQW1ivmblaOPe+3spL5B7cgDp26ViXfjnVZ8iAQ2y7sgou5se hLZB/IUma4691XUdT8v7ff3V35ednnzNJtzjOMnjOB+VYFxe3V5t+03M0+3O3zZC2M9cZ+lFVKgo ooooooooooooooooooq5aaTqV/EZbPT7q4jDbS8MLOAeOMgdeR+dTw2V3coXgtZpVBwWjjLDPpx9 aMgd62rbwB4lufJP9n+Ukm075ZUXaD3K53DGeRjPtWhF4Y1aXYfsuxXwdzuowD6jOfwxmm719a2b T4Uak8pF5qNpDHtyGhDSHPHGCF/nWhB4Ku2cie6gRMdYwXOfocUnmD0rYtPhRpqREXmo3Usm7IaE LGNvHGDuyevf/wCvfg8FWipie6mds9YwFGPoc0nmH0ratvAHhq28k/2f5rx7TvklZtxGOSudpz3G Me1X4fDGkReWfsu9kx8zuTkjuRnB+mMUm8+tbVppOm2Epls9PtLeQrtLwwqhxxxkfhxWhBZWls++ C1gicjBaOMKccelJknvVz/P+f8//AF7FFH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFOVHf7qscddo zj/P+fdVVm+6CcenOKACegqRbSdgCI8fUgY/X/P83i3lIB2Y/GnBG9KmXTpMjdIgHsc4/wA/595B ZvkZdQPbnFOER7kVKunIPvSk+mOMfzqRbNR96Qn0xxilEQ7mpVsrcADbnHcsf8f8/wA3i1hAAxn3 JpfLWldre3+YhFYZIAAz3pXMMPJCgjoAOaUlU54BqpNqDvlY/kX16n/PP+e9eS7ZuE+Ueveo2lJ4 HFUySTknJPJOf1/z/wDrr5JOSeetMo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBc oo/z/n/P/wBcoo/z/n/P/wBcopM/5/z/AJ/qmf8AP+f8/wBSj/P+f8//AF0/z/n/AD/9dKP8/wCf 8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+ f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXK5nXfHOj6Jvi837XdrkeRAQdp 5GGbovIwRyRnoe+TqXiOw07cm/z5xkeXGc4PPU9ByMevt6uCk/SvNNd8c6xrm+Lzfsto2R5EBI3A 5GGbq3BwRwD6VyOpeI7/AFHcm/yYDkeXGcZHPU9TwcentTwoH1rmqyKdRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRXTeBv+Q3N/17 t/6Etavh/wD4/wB/+uR/mKr3f+qH+9/SvQM+4rpM+9U6M+4oz70UZ9xRn3ooz7ijPvRXSaX/AMg6 L/gX/oR/z/nnasP+POP8f5n/AD/nm1D/AKoVc/z/AJ/z/wDXsf5/z/n/AOu+j/P+f8//AFz/AD/n /P8A9co/z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9cryH 4p/8jPbf9ea/+hvXDeM/+QxD/wBe4/8AQmqWP7v41w9c7TqKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK+l/wDP+f8AP/1/Xaho/wA/5/z/APXKKP8AP+f8/wD1 yij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8 /wD1yipFglbohH14/n/n+r1ikbop/lShWPapksmP3nA9Mc/5/wA/jItqx6uB6Y5pwjPc1MlpCOuW +pqVbeMep+ppwRfrUyKqfdAGfT8PepFVV+6APpTgAOlOB6c/r9PelFFAPTn9fp70CigHpz+v096B RQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e 9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFYmo+MfD2lZ+16xbKyyeW0cb+a6sOoKpkjoeo/8A r511r+lWWfPv4QwbYVRt7A+4XJHQ0Vyeo/GLSYMrp9hdXbrJtzIREjL/AHgfmPYcFR17dDh3fj6x iyLW2mnYNjLkIpHqDyfzA60Zrk9R+LXiK73LaC2sV8zcrRx7329lJfIPbkAdO3SsS78c6rPkQCG2 XdkFF3Nj0JbIP5CkzXJ6jr2ravuGoaldXKGTzPLklJQNzyF6Dqeg4zWHd6nfX2RdXc0ylt+13JUH 2HQdT0orPqrRRRRRRRRRRRRRVm006+1Df9isri52Y3+TEz7c9M4HHQ1NBaXN1u+z28su3G7y0LYz 64oyB1NbFv4G8S3UCzR6VIFboJHSNuuPusQR+VXovDmrTRiRbJgp6B2VT+RINJuX1rct/hTqrTqL m/so4f4niLOw44wpAzzjvWlF4KvTIBNc26R92TLEfhgZ/Om+YPQ1sWfwnsU3/bdTuJs42+Six49c 53Z7en41eg8E2y7vtF5LJ0x5ahMfnnNHmHsK2rL4feHLNYt1m1xJGd3mTyElucjKghT6Yxj1z30L fwvpMATNuZXU53SOTnnuBwfpj/67d59a3LTSdNsJTLZ6faW8hXaXhhVDjjjI/DitGCytLZ98FrBE 5GC0cYU449KTJPern+f8/wCf/r2KKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKcqO/wB1 WOOu0Zx/n/PuqqzfdBOPTnFABPQVItpOwBEePqQMfr/n+bxbykA7MfjTgjelTLp0mRukQD2Ocf5/ z7yCzfIy6ge3OKcIj3IqVdOQfelJ9McY/nUi2aj70hPpjjFKIh3NSrZW4AG3OO5Y/wCP+f5vFrCA BjPuTS+WtSrFEpBVEBBOCAOOtSBEUghVBHtTgAOgFPz7in596WjPuKM+9FGfcUZ96KjluI4Rl3Ge w6k9aZJKkYyzDPp3pGYL1NUZtQd8rH8i+vU/55/z3qSXbNwnyj171E0pPA4qmSSck5J5Jz+v+f8A 9dfJJyTz1plH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCu UUf5/wA/5/8ArlFJn/P+f8/1TP8An/P+f6lH+f8AP+f/AK6f5/z/AJ/+ulH+f8/5/wDrn+f8/wCf /rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDr n+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlczrvjnR9E3xeb9ru1yPIgIO08jDN0XkYI5Iz0PfJ1LxH YaduTf584yPLjOcHnqeg5GPX29XBSfpXmmu+OdY1zfF5v2W0bI8iAkbgcjDN1bg4I4B9K5HUvEd/ qO5N/kwHI8uM4yOep6ng49PanhQPrXNVkU6iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiium8Df8AIbm/692/9CWtXw//AMf7 /wDXI/zFV7v/AFQ/3v6V6Bn3FdJn3qnRn3FGfeijPuKM+9FGfcUZ96K6TS/+QdF/wL/0I/5/zztW H/HnH+P8z/n/ADzah/1Qq5/n/P8An/69j/P+f8//AF30f5/z/n/65/n/AD/n/wCuUf5/z/n/AOuf 5/z/AJ/+uUf5/wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuV5D8U/wDkZ7b/AK81/wDQ3rhv Gf8AyGIf+vcf+hNUsf3fxrh652nUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUV9L/5/z/n/AOv67UNH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8A P+f/AK5RUiwSt0Qj68fz/wA/1esUjdFP8qUKx7VMlkx+84Hpjn/P+fxkW1Y9XA9Mc04RnuamS0hH XLfU1KtvGPU/U04Iv1qZFVPugDPp+HvUiqq/dAH0pwAHSnA9Of1+nvSiigHpz+v096BRQD05/X6e 9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r 9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CisnUvE+h6P5gv9VtopItu+LzN0gzjHyAlu4PTp z0qjd6zp1hvFzewoyY3Juy4zjHyjnv6UVympfF7Q7XzEsLe6vpF27Gx5Ub9M8k7hjn+HqPTmsS78 d6dDvW2imuXGNpxsRumeTyO/b/GjNchqvxb168Yrp8cGnxhgVKjzZMY5BLfKQTzwoPTnrnCvfHOp 3BxarHapkEEDe3ToSeOvtSZrkNR17VtX3DUNSurlDJ5nlySkoG55C9B1PQcZrBu9Tvr7IuruaZS2 /a7kqD7DoOp6UVn1Voooooooqe0sru/lMVnazXEgXcUhjLkDpnA7cj86kht57lykEMkrAZKxqWOP wozitq38DeJbqBZo9KkCt0EjpG3XH3WII/KtCLw5q00YkWyYKegdlU/kSDSbl9a3Lf4U6q06i5v7 KOH+J4izsOOMKQM8471pReCr0yATXNukfdkyxH4YGfzpvmD0NbFn8J7FN/23U7ibONvkosePXOd2 e3p+NXoPBNsu77ReSydMeWoTH55zR5h7Cte3+HXhqGBY5LOSdh1lknYMef8AZIHfHA/+vei8K6RH GEeBpWHV2kOT+RA/T/66bz61u22i6VaTrPbaZZQTL92SKBVZcjHBA9D/AJ76UWn2UEgkhtLeOQdG SNQR9CKbk+pq9/n/AD/n/wCvZoo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9copyo7/dVjjrtGcf 5/z7qqs33QTj05xQAT0FSLaTsARHj6kDH6/5/m8W8pAOzH404I3pUy6dJkbpEA9jnH+f8+8gs3yM uoHtzinCI9yKlXTkH3pSfTHGP51Itmo+9IT6Y4xSiIdzUq2VuABtzjuWP+P+f5vFrCABjPuTS+Wt SrFEpBVEBBOCAOOtSBEUghVBHtTgAOgFPz7in596WjPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7i jPvRRn3FGfeio5biOEZdxnsOpPWmSSpGMswz6d6RmC9TVGbUHfKx/Ivr1P8Ann/PepJds3CfKPXv UTSk8DiqZJJyTknknP6/5/8A118knJPPWmUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/ AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUmf8/5/wA/1TP+f8/5/qUf5/z/AJ/+un+f8/5/+ulH+f8A P+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf /rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlczrvjnR9E3xeb9ru1yPIgIO08jDN0Xk YI5Iz0PfJ1LxHYaduTf584yPLjOcHnqeg5GPX29XBSfpXmmu+OdY1zfF5v2W0bI8iAkbgcjDN1bg 4I4B9K5HUvEd/qO5N/kwHI8uM4yOep6ng49PanhQPrXNVkU6iiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiium8Df8hu b/r3b/0Ja1fD/wDx/v8A9cj/ADFV7v8A1Q/3v6V6Bn3FdJn3qnRn3FGfeijPuKM+9FGfcUZ96K6T S/8AkHRf8C/9CP8An/PO1Yf8ecf4/wAz/n/PNqH/AFQq5/n/AD/n/wCvY/z/AJ/z/wDXfR/n/P8A n/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65R/n/AD/n/wCuf5/z/n/6 5XkPxT/5Ge2/681/9DeuG8Z/8hiH/r3H/oTVLH938a4eudp1FFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFfS/8An/P+f/r+u1DUiwSt0Qj68fz/AM/1esUjdFP8 qUKx7VMlkx+84Hpjn/P+fxkW1Y9XA9Mc04RnuamS0hHXLfU1KtvGPU/U04Iv1qZFVPugDPp+HvUi qq/dAH0pwAHSnA9Of1+nvSiigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T 3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9 fp70CisnUvE+h6P5gv8AVbaKSLbvi8zdIM4x8gJbuD06c9Ko3es6dYbxc3sKMmNybsuM4x8o57+l FcpqXxe0O18xLC3ur6RduxseVG/TPJO4Y5/h6j05rEu/HenQ71toprlxjacbEbpnk8jv2/xozXJ6 l8XtcuvNSwt7axjbbsbBlkTGM8n5TnB/h6H15rDvPHepTb1toobZTja2C7r0zyeD+Xf8aTNcnqfi fXNY81b/AFW6mjlxvi8wrGcYx8gwvYHp1561iXms6lf7xc3s0iPjcm7CHHT5Rx29KKyao0VPaWV3 fymKztZriQLuKQxlyB0zgduR+dSQ289y5SCGSVgMlY1LHH4UZxWvaeCvEd7EZItKmVQduJisR7dn IJ69avweH9WuELpZSAA4+chD+TEGk3L61t23ws1qXymnubKFG2lxvZnQHGeAMEj0zj3rQi8Gag+w yTW8anBYbiWUd+MYJ/Gk3itq0+E9okpN5qs0se3hYYhGQeOcktn6Y/8Ar6EHgmBXJnvZHXHSNApz 9STSeZ7Vr2nw38OW8RSW3mumJzvlmIIHHA2bR+ner0HhPSYkKvFJMSc7nkOR/wB84FJvNbVt4d0W 08kwaVZI8O3Y4hUupGMHceSffOf66EOlafBsMdlbqyY2t5YLDGMHPXNJk+taf+f8/wCf/r3KSj/P +f8AP/1yij/P+f8AP/1yij/P+f8AP/1yilVWc4UEnrxz+P8An/8AWqgscKCT145oAJ6VKtrOwyIy Pqcfzp6wSsMhCPqcU4Ix7VKunynblkX156VILSQ4yyj156Uoib1AqVdOUH5pSR7DGPfqf8/q8Wag 8yHHsKcIh3apVsYFGCC3PUt0/KpFtYgPXnuaURqKlWCFdu2NBg8HHSpBFGuMKvHTinBVHYVJn3FP z70tGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz 7ijPvRUctxHCMu4z2HUnrTJJUjGWYZ9O9IzBepqjNqDvlY/kX16n/PP+e9SS7ZuE+UeveomlJ4HF UySTknJPJOf1/wA//rr5JOSeetMo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/ APXKKP8AP+f8/wD1yij/AD/n/P8A9copM/5/z/n+qZ/z/n/P9Sj/AD/n/P8A9dP8/wCf8/8A10o/ z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc /wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBcrmdd8c6Pom+Lzftd2uR5 EBB2nkYZui8jBHJGeh75OpeI7DTtyb/PnGR5cZzg89T0HIx6+3q4KT9K8013xzrGub4vN+y2jZHk QEjcDkYZurcHBHAPpXI6l4jv9R3Jv8mA5HlxnGRz1PU8HHp7U8KB9a5qsinUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUV03gb/kNzf9e7f+hLWr4f8A+P8Af/rkf5iq93/qh/vf0r0DPuK6TPvVOjPuKM+9FGfc UZ96KM+4oz70V09hH5dhCuc5Xd+fP9f899y0TZaRjOcjP58/1/z3txjEairP+f8AP+f/AK83+f8A P+f/AK7qP8/5/wA//XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP 8/5/z/8AXP8AP+f8/wD1yvIfin/yM9t/15r/AOhvXDeM/wDkMQ/9e4/9CapY/u/jXD1ztOoooooo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooor6tREQAIAOnT8PevbVV VGFAH0oAA6U4Hpz+v096UUtAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nv QKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/ T3oFFZ+oa9pOkZGoala27rH5nlySgOV9QucnoegOaq3Wp2Njn7VdwxMF37WcbiPYZyeh6UVyeo/F vw9abltBdXz+XuUxx7E3dlJYgjp1Cnr36Vh3XjnSoMiATXLbcgqm1c+hLYI/I9aM1yGq/F/WLtDH ptrBYKVHzk+dICDkkE4XBHGCp78+mFe+PL+dStpBHbAgfMT5jA57Z4/Q0ma5a71/xH4jne2mvr68 afGbaMna+0Z4jXjjGeB2zWLPqeratI0UlzczmXGYUJ2tj/YHHbPT3oz70tn4N8RX2/ytJuF2Yz5w EWc+m8jP4f1og0HVbjdssZRtxnzBs/LdjP4Um4DvW1ZfC/W7hYnuZbS1Vm+dWcu6DOM4UYJxyBu/ KtC38HajKEaV4IQT8yltzKM+3B/Ok3it20+E9okpN5qs0se3hYYhGQeOcktn6Y/+vpQeCYFcme9k dcdI0CnP1JNJ5ntWvafDfw5bxFJbea6YnO+WYggccDZtH6d6vQeE9JiQq8UkxJzueQ5H/fOBSbzW 1beHdFtPJMGlWSPDt2OIVLqRjB3Hkn3zn+uhDpWnwbDHZW6smNreWCwxjBz1zSZPrWn/AJ/z/n/6 9yko/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9copVVnOFBJ68c/j/n/9aqCxwoJPXjmgAnpU q2s7DIjI+px/OnrBKwyEI+pxTgjHtUq6fKduWRfXnpUgtJDjLKPXnpSiJvUCpV05QfmlJHsMY9+p /wA/q8Wag8yHHsKcIh3apVsYFGCC3PUt0/KpFtYgPXnuaURqKlWCFdu2NBg8HHSpBFGuMKvHTinB VHYVJn3FPz70tGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70U Z9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70VHLcRwjLuM9h1J60ySVIxlmGfTvSMw Xqaozag75WP5F9ep/wA8/wCe9SS7ZuE+UeveomlJ4HFUySTknJPJOf1/z/8Arr5JOSeetMo/z/n/ AD/9coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9copM/wCf8/5/ qmaKP8/5/wA//XT/AD/n/P8A9dKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANco/wA/ 5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/ AJ/z/wDXK5nXfHOj6Jvi837XdrkeRAQdp5GGbovIwRyRnoe+TqXiOw07cm/z5xkeXGc4PPU9ByMe vt6uCk/SvNNd8c6xrm+Lzfsto2R5EBI3A5GGbq3BwRwD6VyOpeI7/Udyb/JgOR5cZxkc9T1PBx6e 1PCgfWuarIp1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFdN4G/wCQ3N/17t/6Etavh/8A4/3/AOuR /mKr3f8Aqh/vf0r0DPuK6TPvVOjPuKM+9FGfcUZ96KM+4oz70V1Vr/x5wf8AXNf5f5/z13rf/j2i /wBwfy/z/nrcT7i/QVN/n/P+f/ryf5/z/n/660f5/wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/z/n/ AOuUf5/z/n/65/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uV5D8U/+Rntv+vNf/Q3rhvGf/IYh/wCv cf8AoTVLH938a4eudp1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFfV4PTn9fp717cKWgHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oF FAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUVn6hr2k6RkahqVrbusfmeXJKA5X1C5y eh6A5qrdanY2OftV3DEwXftZxuI9hnJ6HpRXMXPxS0XzxbaXb32qXLRlo1t4SAzYPyndhu3JCng9 +axpvGmneZ5NlFc3spXKCKMgE+nPPbsDSZxWVL4x8caqJV0rw0LJBGFLXRO8Mc/MpcoD242n364q k+v+I73eLLSBbqFwTNncCe43bQe3GD79aTeB3rLudA+IOtwb7/W0hEkZje3NwUBXkYZY12nIPvwe fSqU2m+KNRj3XOohNylGi80qCPcINpzmk8we9Lb/AAmgWdTc6vJJCPvJFAEY8cYJY+3Y0ReCIhIp mvnePuqRhSfocn+VJ5ntWxZ/DXw7bb/OjuLvdjHnTEbfps29c98/434PCWlRbt6Sz5x/rJMbfptx /n9U3mte38K6BbQLDHo9kVXoZIhI3Jz95sk9fWr0Wi6ZDGEWwtyB3ZAx/M5JpNx9a2P8/wCf8/8A 179JR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RSqrOcKCT145/H/P/AOtVBY4UEnrxzQAT 0qVbWdhkRkfU4/nT1glYZCEfU4pwRj2qVdPlO3LIvrz0qQWkhxllHrz0pRE3qBUq6coPzSkj2GMe /U/5/V4s1B5kOPYU4RDu1SrYwKMEFuepbp+VSLaxAevPc0ojUVKsEK7dsaDB4OOlSCKNcYVeOnFO CqOwqTPuKfn3paM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3o oz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ 96KjluI4Rl3Gew6k9aZJKkYyzDPp3pGYL1NUZtQd8rH8i+vU/wCef896kl2zcJ8o9e9RNKTwOKpk knJOSeSc/r/n/wDXXySck89aZR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n/P8An/65RR/n /P8An/65RR/n/P8An/65RSZ/z/n/AD/VM0Uf5/z/AJ/+uf5/z/n/AOuUf5/z/n/66f5/z/n/AOul H+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/ n/P+f/rlH+f8/wCf/rn+f8/5/wDrlVdRu/7P0u7vdnmfZ4Xl2Zxu2qTjPb/P4xXc/wBls57jbu8q Nn25xnAzj/P/AOtRyQK8Y13xzrGub4vN+y2jZHkQEjcDkYZurcHBHAPpXAal4jv9R3Jv8mA5Hlxn GRz1PU8HHp7VIFA+tc1WRTqKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK6bwN/yG5v8Ar3b/ ANCWtXw//wAf7/8AXI/zFV7v/VD/AHv6V6Bn3FdJn3qnRn3FGfeijPuKM+9FGfcUZ96K6q1/484P +ua/y/z/AJ671v8A8e0X+4P5f5/z1uJ9xfoKm/z/AJ/z/wDXk/z/AJ/z/wDXWj/P+f8AP/1z/P8A n/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9crx r4mXSXHi3ykDBra3SJ8jgk5fj2w4/X61wXi+ZZdc2KDmKJUbPc8tx+DCpU+7XHVg06iiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiivq8Hpz+v0969uFLQD05/X6e 9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFGQBknj6/T3ozgZJ/WiozcRKATIPwOfT3phmjUZL j8Dmk3Ad6jN7EDwWb6D6e9MNzGD1J+lJ5i+9Zdxc6tP5fk3FraI0YEqiIyurdyjlgPTGUPqQc4ql LPfS7PLlhgUqN4CF2B77WJA+mVP0PSm+Z7VmzaGb2R21DV9VvI3iMTQNceVGVPqsQQE8kc54Pfiq cmnG4djdX97OjJsMZl2IQfZAuT9fX6UnmNTbfwroFtAsMej2RVehkiEjcnP3myT19aSLRdMhjCLY W5A7sgY/mck0m4+tbH+f8/5/+vfpKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKVQWICgk +g5/z/n8QAk4AJPtQOelSJbTt0jIx68fz/z/AFkWCVuiEY9eKcEY9qlXT5iASyL7E9KeLSQgElR7 Z6Uoib2FTLpqg/NNx7DH9akFkM8ycewpwiH96pVsIF65b6np+X+f6yLaxDrk/U9KURqPepVghXbt jQYPBx0qQRRrjCrx04pwVR2FSZ9xT8+9LRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7i jPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM +4oz70UZ9xRn3ooz7ijPvRRn3FGfeiorq7t7K3a4u7mG3gT70krhVXJwMknHUgf55jmnit4mlnmj ijXq7sAB9STRWHfePPC+n+X52t2rb848gmfGPXZux179eazbnxNo1rt8zUYW3Zx5RMn57c4696TI 9awrr4weGoLh4okv7lF6SxQgK3HbcwPfHI/+vmzePNIilZEW6mUdHSMYP/fRB/SjdVCy+JHiLxEF TQ/DkMZEmJLi5mZ4lHccBefmBwCTjsaq2/i7VdVAXTdJjTDfNLNIWQDv2HPIPc+1IXArqrO41g7Z dQvojIY9rQWsW2JScHILZcnqM5Ax/Dnk7ME1+cPdXKbiuDHCmEHvk5YnqOoHt6xtKT04qUkk5JyT yTn9f8//AK35JOSeetMo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKP8A P+f8/wD1yij/AD/n/P8A9copM/5/z/n+qZoo/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A10/z/n/P /wBdKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5 /wA//XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBcphkQSBNw3Ht/n/P9U3rvCbhuPb/P+f6mRnGe af8A5/z/AJ/+uv8An/P+f/rlZniP/kWNW/685v8A0A/5/wA81NV/5A97/wBe8n/oJ/z/AJ5VfvD6 18+V5fU1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFdb4Et919d3O/HlxiPbjruOc/wDj v61s+Ho83E0u7G1QuMev/wCqq142EVfU5ruc+4roM+9VKM+4oz70UZ9xRn3ooz7ijPvRXVWv/HnB /wBc1/l/n/PXet/+PaL/AHB/L/P+etxPuL9BU3+f8/5/+vJ/n/P+f/rrR/n/AD/n/wCuf5/z/n/6 5R/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65Xh3xA/5HfUf+ 2X/ota878T/8jFdf8A/9AWpU+6K5qsinUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUV9Vm4iUAmQfgc+nvXtZmjUZLj8DmjcB3qM3sQPBZvoPp70w3MYPUn6Unm L71Gb/0T8S1MN36L+tN8z2qM3spGAQvuP8/5/mw3MhHYe4pPMb6VGbiVjkyN+BppmkJ5c/gaTcx7 mo8knJPPX/P+f/rszk5JpKP8/wCf8/8A1yij/P8An/P/ANcoo/z/AJ/z/wDXKKVQWICgk+g5/wA/ 5/EAJOACT7UDnpUiW07dIyMevH8/8/1kWCVuiEY9eKcEY9qlXT5iASyL7E9KeLSQgElR7Z6Uoib2 FTLpqg/NNx7DH9akFkM8ycewpwiH96pVsIF65b6np+X+f6yLaxDrk/U9KURqPepVt4VAAjTg9xmn iGJQAEXj1GacFUdhUmfcVJn3paM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4 oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeij PuKM+9FGfcUZ96KM+4oz70VFdXdvZW7XF3cw28CfeklcKq5OBkk46kD/ADzHNPFbxNLPNHFGvV3Y AD6kmisO+8eeF9P8vztbtW35x5BM+Meuzdjr3681m3PibRrXb5mowtuzjyiZPz25x170mR61hXXx g8NQXDxRJf3KL0lihAVuO25ge+OR/wDXzZvHmkRSsiLdTKOjpGMH/vog/pRurnbr42XL27LaaHFF P/C8twZFHPOVCqTxnvWVN8RJmiYQaciSdmeUsB9QAM/nSbqw774teKbvy/JmtbLbnPkQA78+u/d0 9sdTWbc+Odan2+XJDb7c58qPO767s/5NG41hXXjPxNd3Dzy67fq74yIp2jXpjhVwB+ArNm8QaxPK 0j6ldBm6hJCg/IYApMn1rDrNorV0bw5qmvS7bC1Zow2Gmb5Y06Zy3qMg4GTjtV3T9JvdTfFtCSmc GRuFXp3/ABHA5pCQOtek6D8NNOsNk+qP9uuBhvL6RKeD06tznrwQeVrrdM8I2lttkvG+0SjB29EH Tt/F368HPSmFyenFdtFHHDEkUSLHGihVRBgKBjAA/p/k9CiLGioihUUAKqjAA9qbT/8AP+f8/wD1 3UUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/AJ/+uUUmf8/5/wA/1TNF H+f8/wCf/rn+f8/5/wDrlH+f8/5/+un+f8/5/wDrpR/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8A P+f/AK5R/n/P+f8A65/n/P8An/65R/n/AD/n/wCuf5/z/n/65R/n/P8An/65/n/P+f8A65UUtxHF 95sn+6Ov+f8AP1ZJMkfU8+g/z/n+aFgvU1SlvJHyFwo9jz+dVZLl3yB8o9jUbSE9OKS1/wCPpfqf 5Gkt/wDXr9T/ACNCffFaf+f8/wCf/r3v8/5/z/8AXlrM8R/8ixq3/XnN/wCgH/P+eamq/wDIHvf+ veT/ANBP+f8APKr94fWvnyvL6moooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooors/AP/MQ5 /wCef/s9bvhz/l5/4D/7NVW8/g/Guzz7itzPvVWjPuKM+9FGfcUZ96KM+4oz70V1Vr/x5wf9c1/l /n/PXet/+PaL/cH8v8/563E+4v0FTf5/z/n/AOvJ/n/P+f8A660f5/z/AJ/+uf5/z/n/AOuUf5/z /n/65/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uUf5/wA/5/8Arn+f8/5/+uV4d8QP+R31H/tl/wCi 1rzvxP8A8jFdf8A/9AWpU+6K5qsinUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUV9L/AOf8/wCf/r+u1DR/n/P+f/rlFH+f8/5/+uUUqgsQFBJ9Bz/n/P4gBJwA Sfagc9KkS2nbpGRj14/n/n+siwSt0QjHrxTgjHtUq6fMQCWRfYnpTxaSEAkqPbPSlETewqZdNUH5 puPYY/rUgshnmTj2FOEQ/vVKthAvXLfU9Py/z/WRbWIdcn6npSiNR71KtvCoAEacHuM08QxKAAi8 eozTgqjsKkz7ipM+9LRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPu KM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3oo z7ijPvRRn3FGfeiorq7t7K3a4u7mG3gT70krhVXJwMknHUgf55jmnit4mlnmjijXq7sAB9STRWHf ePPC+n+X52t2rb848gmfGPXZux179eazbnxNo1rt8zUYW3Zx5RMn57c4696TI9awrr4weGoLh4ok v7lF6SxQgK3HbcwPfHI/+vmzePNIilZEW6mUdHSMYP8A30Qf0o3Vzt18bLl7dltNDiin/heW4Mij nnKhVJ4z3rKm+IkzRMINORJOzPKWA+oAGfzpN1Yd98WvFN35fkzWtltznyIAd+fXfu6e2OprNufH OtT7fLkht9uc+VHnd9d2f8mjcawrrxn4mu7h55ddv1d8ZEU7Rr0xwq4A/AVmzeINYnlaR9SugzdQ khQfkMAUmT61h1m0UUUUUUUUUUUUVq6N4c1TXpdthas0YbDTN8sadM5b1GQcDJx2q7p+k3upvi2h JTODI3Cr07/iOBzSEgda9J0H4aadYbJ9Uf7dcDDeX0iU8Hp1bnPXgg8rXW6Z4RtLbbJeN9olGDt6 IOnb+Lv14OelMLk9OK7aKOOGJIokWONFCqiDAUDGAB/T/J6FEWNFRFCooAVVGAB7U2n/AOf8/wCf /ruoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yikz/n/ AD/n+qZoo/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXT/P+f8AP/10o/z/AJ/z/wDXP8/5/wA//XKP 8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A 1z/P+f8AP/1ysLW/Fuj6BlLu433A/wCXeH5pO3UdF4OeSMjpnvnajrlhpmVnl3S/88o/mbt19Oue f17uCk1FpOvSa3o8N8sQtxLu/dh9xGGI68enp3qKz1R9RsY7gJ5QfPyhs4wSOv4VFKSrFQasHv0/ OnnvUdB79PzoPeip7X/j6X6n+RqW3/16/U/yNOT74rT/AM/5/wA//Xvf5/z/AJ/+vLWZ4j/5FjVv +vOb/wBAP+f881NV/wCQPe/9e8n/AKCf8/55VfvD618+V5fU1FFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFdn4B/5iHP/ADz/APZ63fDn/Lz/AMB/9mqrefwfjXZ59xW5n3qrRn3FGfeijPuK M+9FGfcUZ96K6q1/484P+ua/y/z/AJ671v8A8e0X+4P5f5/z1uJ9xfoKm/z/AJ/z/wDXk/z/AJ/z /wDXWj/P+f8AP/1z/P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+ f8//AFz/AD/n/P8A9crw74gf8jvqP/bL/wBFrXnfif8A5GK6/wCAf+gLUqfdFc1WRTqKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK+p004cb5fqAOhr2hbMcbpP wFIIvVqlWwgXrlvqen5f5/rItrEOuT9T0pRGo96lW3hUACNOD3GaeIYlAARePUZpwVR2FSZ9xUmf eloz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfc UZ96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRT ZZo4IXmmlSOKMFnd2wqgZJJJPSmvIkcbSSOqIoLMzHAA9SfSisO98b+GLCFZZtcsmUttAgk85s89 QmTj36fnzm3HiPR7aMPJqVuQWx+7fzD37Lk4oz71hXvxd8MWswSE3t4pXd5kEGFB54O8qc/hjn61 m3HjvR4ZAsZuJxjO6OPAHXj5iDSbhWBd/Gw/v1s9D/vCGSa4+u0sgX6ZAb2z3rLn+In+sW30718t 5JfyJUD9M/jRurAvfi74nuoQkJsrNg27zIISWI54+csMc+mePrnMuPHeszRhYzbwEHO6OPJPt8xI xSbjWFe+OPE9/MJZtcvVYLtxBJ5K457JgZ5PPWs248R6zcyB5NSuAQMfu38sfkuB3oyfWsOWWS4m eaaR5JZGLu7sSzMeSST1NZru8sjSSOzuxLMzHJJPUk0lMptFFFFFFFFFFFFFFFFFFFFFFXtM0bUd ZnMOn2kk7D7xUYVeDjLHgZwcZPNWbOwur+Qx2sDysOuOg+p6DpSEgda9O8O/DWxsVSfWCt5dA58t SfJXkY44LHjvxzjB6nsNK8JW1sFkviJ5gc7AfkHIx9fx456erC+eldxFHHDEkUSLHGihVRBgKBjA A/p/k9EiLGioihUUAKqjAA9qbT/8/wCf8/8A13UUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z /n/65RR/n/P+f/rlFJn/AD/n/P8AVM0Uf5/z/n/65/n/AD/n/wCuUf5/z/n/AOun+f8AP+f/AK6U f5/z/n/65/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uUf5/wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/ z/n/AOuUf5/z/n/65/n/AD/n/wCuVha34t0fQMpd3G+4H/LvD80nbqOi8HPJGR0z3ztR1yw0zKzy 7pf+eUfzN26+nXPP693BSa811v4iaxquY7Vv7Ptz/DC2ZD06v16g9McHBzXJaj4qv73KQn7LF6Rn 5j06t/hjr3p4QD3rkKwqdXrvgr/kULHp/wAtO/8AttXbaB/yBLf/AIF/6EaqTf61q3z36fnWke9M oPfp+dB70VPa/wDH0v1P8jUtv/r1+p/kacn3xWn/AJ/z/n/697/P+f8AP/15azPEf/Isat/15zf+ gH/P+eamq/8AIHvf+veT/wBBP+f88qv3h9a+fK8vqaiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiuz8A/8xDn/nn/AOz1u+HP+Xn/AID/AOzVVvP4Pxrs8+4rcz71Voz7ijPvRRn3FGfeijPu KM+9FdVa/wDHnB/1zX+X+f8APXet/wDj2i/3B/L/AD/nrcT7i/QVN/n/AD/n/wCvJ/n/AD/n/wCu tH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+ f8/5/wDrleHfED/kd9R/7Zf+i1rzvxP/AMjFdf8AAP8A0BalT7ormqyKdRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRX1rn3Fe5596fRn3FGfeijPuKM+9FGfcU Z96KM+4oz70UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70UZ9xRn3ooz7ijPvRRn 3FGfeijPuKM+9FGfcUZ96KM+4oz70U2WaOCF5ppUjijBZ3dsKoGSSST0pryJHG0kjqiKCzMxwAPU n0orDvfG/hiwhWWbXLJlLbQIJPObPPUJk49+n585tx4j0e2jDyalbkFsfu38w9+y5OKM+9YV78Xf DFrMEhN7eKV3eZBBhQeeDvKnP4Y5+tZtx470eGQLGbicYzujjwB14+Yg0m4VgXfxsP79bPQ/7whk muPrtLIF+mQG9s96y5/iJ/rFt9O9fLeSX8iVA/TP40bqwL34u+J7qEJCbKzYNu8yCEliOePnLDHP pnj65zLjx3rM0YWM28BBzujjyT7fMSMUm41hXvjjxPfzCWbXL1WC7cQSeSuOeyYGeTz1rNuPEes3 MgeTUrgEDH7t/LH5Lgd6Mn1rDllkuJnmmkeSWRi7u7EszHkkk9TWa7vLI0kjs7sSzMxyST1JNJTK bRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRV7TNG1HWZzDp9pJOw+8VGFXg4yx4GcHGTzVmzsLq/ kMdrA8rDrjoPqeg6UhIHWvR9D+F1rBiXWrj7S/8AzwhJWMdRy3DN1B424PrXV6d4Nhjw+oS+c3/P OMkL+fU9vT8aaX9K723t4LSBILaGOCFPuxxKFVcnPAH1/X8+miijgjWOGNI416KgAA+gFMqX/P8A n/P/ANd9FH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RSZ/wA/5/z/AFTN FH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrp/n/AD/n/wCulH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDr n+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlYW t+LdH0DKXdxvuB/y7w/NJ26jovBzyRkdM987UdcsNMys8u6X/nlH8zduvp1zz+vdwUmvNdb+Imsa rmO1b+z7c/wwtmQ9Or9eoPTHBwc1yWo+Kr+9ykJ+yxekZ+Y9Orf4Y696eEA965CsKnUUUUUUV674 K/5FCx6f8tO/+21dtoH/ACBLf/gX/oRqpN/rWrfPfp+daR70yg9+n50HvRU9r/x9L9T/ACNS2/8A r1+p/kacn3xWn/n/AD/n/wCve/z/AJ/z/wDXlrM8R/8AIsat/wBec3/oB/z/AJ5qar/yB73/AK95 P/QT/n/PKr94fWvnyvL6mooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooors/AP/ADEOf+ef /s9bvhz/AJef+A/+zVVvP4Pxrs8+4rcz71Voz7ijPvRRn3FGfeijPuKM+9FdbEnlwpHnO1QufX/P +ffoI12Rqmc7QBn1/wA/597qjCgegp/+f8/5/wDru/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj /P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yvDviB/yO+o /wDbL/0Wted+J/8AkYrr/gH/AKAtSp90VzVZFOoooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooor61z7ivc8+9Poz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70 UZ9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96KM+4oz70Vh3XjPw1aW7Ty67YMinkRTiVuTjhV JJ69gazZvEGkQRGR9StSo6hJA5/JSSaM+9Yd98WvC9p5fkzXV7uznyICNn13leue2eh/HNufHOjQ bfLkmuM5z5cRG367sf1/xTcKwL/41xh5k07RmZdv7qW4m2nOOrIAeAe27kdxmsu5+IihpFtNPLDH yPLJjnHdRnv2zRurnb34u+J7qEJCbKzYNu8yCEliOePnLDHPpnj65yrjx3rM0YWM28BBzujjyT7f MSMUm41hXvjjxPfzCWbXL1WC7cQSeSuOeyYGeTz1rNuPEes3MgeTUrgEDH7t/LH5Lgd6Mn1rDllk uJnmmkeSWRi7u7EszHkkk9TWa7vLI0kjs7sSzMxyST1JNJTKbRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRV7TNG1HWZzDp9pJOw+8VGFXg4yx4GcHGTzVmzsLq/kMdrA8rDrjoPqeg6 UhIHWvR9D+F1rBiXWrj7S/8AzwhJWMdRy3DN1B424PrXV6d4Nhjw+oS+c3/POMkL+fU9vT8aaX9K 723t4LSBILaGOCFPuxxKFVcnPAH1/X8+miijgjWOGNI416KgAA+gFMqX/P8An/P/ANd9FH+f8/5/ +uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUf5/z/n/65RSZ/wA/5/z/AFTNFH+f8/5/+uf5/wA/ 5/8ArlH+f8/5/wDrp/n/AD/n/wCulH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8A P+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlZGv+JNP8N28Ut+ZczZ 8qONMmTBGcHpxuHU/n3panq1rpMSPcl8yZ2Kq5LYxnHbv3P/ANdwUmvL9b+ImsarmO1b+z7c/wAM LZkPTq/XqD0xwcHNcdqPiq/vcpCfssXpGfmPTq3+GOvenhAPeuQrCp1FFFFFFFFFFFFeyeFrb7J4 X0+PeH3RCTOMffy2Ovbdj8K7vR4vJ0i2TOcpv9OuT/WqcpzI31rYPfp+dXT3ptB79PzoPeip7X/j 6X6n+RqW3/16/U/yNOT74rT/AM/5/wA//Xvf5/z/AJ/+vLWZ4j/5FjVv+vOb/wBAP+f881NV/wCQ Pe/9e8n/AKCf8/55VfvD618+V5fU1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFdn4B/5 iHP/ADz/APZ63fDn/Lz/AMB/9mqrefwfjXZ59xW5n3qrRn3FGfeijPuKM+9FGfcUZ96K7D/P+f8A P/1+i/z/AJ/z/wDXu0f5/wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuUf5/z/n/65/n/AD/n /wCuUf5/z/n/AOuf5/z/AJ/+uUf5/wA/5/8Arn+f8/5/+uV4d8QP+R31H/tl/wCi1rzvxP8A8jFd f8A/9AWpU+6K5qsinUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUV9a59xXuefen0Z9xRn3ooz7ijPvRRn3FGfeijPuKM+9FGfcUZ96Kw7rxn4atLdp5ddsGRTyI pxK3Jxwqkk9ewNZs3iDSIIjI+pWpUdQkgc/kpJNGfesO++LXhe08vyZrq93Zz5EBGz67yvXPbPQ/ jm3PjnRoNvlyTXGc58uIjb9d2P6/4puFYV18bLdLl1tNDllgH3XluBGx45yoVgOc9zWbN8RIllYQ ac7x/wALPLtJ+oAP86N1c9dfGDxNcW7RRR2Fs5xiWKFiy89t7MPbkHrWVN491iWJkRbaFj0dIySP ++iR+lJuNYV9488U6h5fna3dLszjyGEOc+uwDPTv059TWbc+JtautvmajONuceUfL6+u3GfxoyfW sO6u7m+uXubu4luJ3xullcuzYGBknk8AVmzTy3MrSzyvLI3V3YsT+JpKhqOiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiir2maNqOszmHT7SSdh94qMKvBxljwM4OMnmr NnYXV/IY7WB5WHXHQfU9B0pCQOtej6H8LrWDEutXH2l/+eEJKxjqOW4ZuoPG3B9a6vTvBsMeH1CX zm/55xkhfz6nt6fjTS/pXe29vBaQJBbQxwQp92OJQqrk54A+v6/n00UUcEaxwxpHGvRUAAH0AplS /wCf8/5/+u+ij/P+f8//AFyij/P+f8//AFyij/P+f8//AFyij/P+f8//AFyij/P+f8//AFyikz/n /P8An+qZoo/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XT/AD/n/P8A9dKP8/5/z/8AXP8AP+f8/wD1 yj/P+f8AP/1z/P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8// AFz/AD/n/P8A9cp8ULzHCjj1PT/P+fq+OJpD8o/E9P8AP+fq4KW6VeitI05b5z79P5+9Wo7dF5Pz H3qRUA6815f8aemh/wDbf/2nXHfELppv/bX/ANkpa8oriKKKKKKKKKKKKKKKKK9s0L/kXtN6f8es Xf8A2BXf6d/yC7X/AK4p/wCg1Sf77fU1oHv0/OrJ70lB79PzoPeip7X/AI+l+p/kalt/9ev1P8jT k++K0/8AP+f8/wD173+f8/5/+vLWV4mkSLwtqrSOqKbSVQWOBkqQB9SSB+PvzT1d1TRr0swUeQ4y Tjkggfqf1/NV+8K+fq8wqaiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiuz8A/8xDn/nn/ AOz1u+HP+Xn/AID/AOzVVvP4Pxrs8+4rcz71Voz7ijPvRRn3FGfeijPuKM+9Fdh/n/P+f/r9F/n/ AD/n/wCvdo/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yj/AD/n/P8A9c/z/n/P/wBc o/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yvDviB/yO+o/9sv/AEWted+J/wDkYrr/ AIB/6AtSp90VzVZFOooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooor6cv/F3h7TEmN1rNkrQsVkjWUPIpzgjYpLcHrxxzXsd1rulWayGbULcGNtrIHDMDnGNoyf0p +fesC++LXhe08vyZrq93Zz5EBGz67yvXPbPQ/jl3PjnRoNvlyTXGc58uIjb9d2P6/wCKbhWFdfGy 3S5dbTQ5ZYB915bgRseOcqFYDnPc1mzfESJZWEGnO8f8LPLtJ+oAP86N1c9dfGDxNcW7RRR2Fs5x iWKFiy89t7MPbkHrWVN491iWJkRbaFj0dIySP++iR+lJuNYV9488U6h5fna3dLszjyGEOc+uwDPT v059TWbc+JtautvmajONuceUfL6+u3GfxoyfWsO6u7m+uXubu4luJ3xullcuzYGBknk8AVmzTy3M rSzyvLI3V3YsT+JpKhqOiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiir2maNqOszmHT7SSdh94qMKvBxljwM4OMnmrNnYXV/IY7WB5WHXHQfU9B0pCQOt ej6H8LrWDEutXH2l/wDnhCSsY6jluGbqDxtwfWur07wbDHh9Ql85v+ecZIX8+p7en400v6V3tvbw WkCQW0McEKfdjiUKq5OeAPr+v59NFFHBGscMaRxr0VAAB9AKZUv+f8/5/wDrvoo/z/n/AD/9coo/ z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9coo/z/n/AD/9copM/wCf8/5/qmaKP8/5/wA//XP8/wCf 8/8A1yj/AD/n/P8A9dP8/wCf8/8A10o/z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj /P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yqt5qNrYrme UBsZCDlj17fgeen9YLi8gtVzLIAcZCjkn8P8/wCLXlSMfM3Pp3rIh8QS3erWkMKLHC86K27BZgWx z2GR/wDr9c+PV5LjULeKNQkTSqpzySM1AtyXnRVAClgD713QwAAOnH9PeuqHAAFaNAPTn9fp70Ci vJ/jT00P/tv/AO064j4hdNN/7a/+yUleUVxFFFFFFFFFFFFFFFFFe2aF/wAi9pvT/j1i7/7Arv8A Tv8AkF2v/XFP/QapP99vqa0D36fnVk96Sg9+n50HvRU9oCblcD1zj8amtwTOPx/rTk+/Wn/n/P8A n/693/P+f8//AF5a5n4gf8iRqP8A2y/9GL/n/POT4n/5F26/4B/6Gv8An/PLk+8K8PrzqpaKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKsWljd6hKYrK1nuZAu4pDGXIGcZwO3I/OpYLae6cpbwy TOBkrGpY49eKK9O8KeCdX0exuri8WJJJdpWBX3uAu7OccdwQAT+fB6/R/Dl/Y2s0s4QO+MRBtzYG fTjuOmf6VXuUMigr/D2rQz7ipc+9U6M+4oz70UZ9xRn3ooz7ijPvRXYf5/z/AJ/+v0X+f8/5/wDr 3aP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9c/z/AJ/z/wDXKP8AP+f8 /wD1z/P+f8//AFygDJ6/5/z/AJ9VAyf8/wCf8/mteB+Lbp7zxbqksgUMtw0Q2jjCfIPxworzPXJm uNcvHYAESlOPRflH6CpV4UVi1n0tFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFXtM0bUdZnMOn2kk7D7xUYVeDjLHgZwcZPNWbOwur+Qx2sDysOuOg+ p6DpSEgda9H0P4XWsGJdauPtL/8APCElYx1HLcM3UHjbg+tdXp3g2GPD6hL5zf8APOMkL+fU9vT8 aaX9K723t4LSBILaGOCFPuxxKFVcnPAH1/X8+miijgjWOGNI416KgAA+gFMqX/P+f8//AF30Uf5/ z/n/AOuUUf5/z/n/AOuUUf5/z/n/AOuUUf5/z/n/AOuUUf5/z/n/AOuUUmf8/wCf8/1TNFH+f8/5 /wDrn+f8/wCf/rlH+f8AP+f/AK6f5/z/AJ/+ulH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+ f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlZOs+I9L0G ItfXSrIVysK/NI/XGF9DgjJ4z39ad/q1npqZuZgGxkRjlm69vwPJ4/qoUnpXHw/EC61rU5ba0gW1 tRGxDscyNzjJPQZBHAyQe5rn/wDhKJ7+6eG3jEMIUkMeXPP6df8A69R3ZaKEFWwScfpSs7OxZnyx JJJOSTz1qJmLMWZskkkknNZ5OTknmrmkH/idWHP/AC8p/wChVY08/wDEztOf+Wyfzp8H/HxH/vj+ depA9Of1+nvXeCtigHpz+v096BRXinximkbxRZQmRjEtkrKhb5QS75IHqcD8hXnnj53Os28Zdii2 4IXPAJZsn9B+QpK87rlKKKKKKKKKKKKKKKKK9s0L/kXtN6f8esXf/YFd/p3/ACC7X/rin/oNUn++ 31NaB79Pzqye9JQe/T86D3oq1Y/69/8Ad/rVi1/1rfT+tPj+8a0P8/5/z/8AXt/5/wA/5/8AryVz PxA/5EjUf+2X/oxf8/55yfE//Iu3X/AP/Q1/z/nlyfeFeH151UtFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFdDovgnXtcZTBZNBAyhhPcgxoQRkEcZYH/AGQeo9a1dP8ADup6iw8u3McZAPmzfKuCMgju fwz1FJkV6Bo3wo0y3SKTVriS8m6tFG2yLkDjj5jgknORnjj16fT/AATZxKj30rzydWRTtTp09Tg9 8jtxSbq7qzsbPT4jFZWsFtGW3FIYwgJ4GcDvwK6W3toLVNlvDHChOSsahQTxzxSVYB6c/r9PepRR WLq+k+aDc2w/edXQfxe49+fx+vXL1HT/ADMzQD5+rKO/uPf/AD9YJoc/OnXuPWudYFWKtwQSCD26 1jkFSQeCDyD2qr0ODSZ9xSZ96KM+4oz70V2H+f8AP+f/AK/Rf5/z/n/692j/AD/n/P8A9c/z/n/P /wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1ylAHGSKcAOORS04HpyKUHpyKK+ef Ef8AyM+rf9fk3/oZryzVf+Qxe/8AXxJ/6EalX7o+lZlVKWiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiir2maNqOszmHT7SSdh94qMKvBxljwM4OMnmrNnYXV/ IY7WB5WHXHQfU9B0pCQOtej6H8LrWDEutXH2l/8AnhCSsY6jluGbqDxtwfWur07wbDHh9Ql85v8A nnGSF/Pqe3p+NNL+ld7b28FpAkFtDHBCn3Y4lCquTngD6/r+fTRRRwRrHDGkca9FQAAfQCmVL/n/ AD/n/wCu+ij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXK KTP+f8/5/qmaKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANdP8/5/z/8AXSj/AD/n/P8A9c/z/n/P /wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANco/wA/ 5/z/APXP8/5/z/8AXKydZ8R6XoMRa+ulWQrlYV+aR+uML6HBGTxnv607/VrPTUzczANjIjHLN17f geTx/VQpPSvN9e+JWo3/AJkGmJ9itzkeZ1lYcjr0XII6cgj71clqXi26ud0dmv2eI8burkc9+34c j1qQIB15riZJJJpXlldpJHYszscliepJ7mued2kdndizscszHJJ9TTq6TwfGhlu5SPnUKoPoDnP8 hWloyjfK/wDEAAD7HP8AgKpagxCxrngkmuqz7itbPvVGrukH/idWHP8Ay8p/6FVnTz/xM7Tn/lsn 86kg/wCPiP8A3x/OvUgenP6/T3rvBWxQD05/X6e9AorxH4w/8jdaf9eCf+hyV5149/5DsH/Xsv8A 6E1JXn1ctRRRRRRRRRRRRRRRRXtmhf8AIvab0/49Yu/+wK7/AE7/AJBdr/1xT/0GqT/fb6mtA9+n 51ZPekoPfp+dB70Vasf9e/8Au/1qxa/61vp/Wnx/eNaH+f8AP+f/AK9v/P8An/P/ANeSuZ+IH/Ik aj/2y/8ARi/5/wA85Pif/kXbr/gH/oa/5/zy5PvCvD686qWiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiipba2nv LhYLWCSeZ87Y4kLMcDPAHPSnxQyzyrFDG8kjdERSSfwFFdxpHwp1e83NqU8WnoMhRxM5PGOFOMcn vnjpzXR2Pgm/uMm7kS1XoBxIx6dgcY59e3SkyK9F0XwToOhqhgs0nnVgwuLkCRwQcgjspGf4QOg6 11eneHdM04KY7dZJAQfNlwzZByCOw69gO1JnNdCD05/X6e9aopKAenP6/T3oFFAPTn9fp70CigHp z+v096BRQD05/X6e9AorL1XSheL5sOBcAfg/HQ81Qv7AXK+ZHgTAf99VFND5g3L97+dcuwKsVbgg kEHt1rCIKkg8EHkHtVPocGkz7ikz70V2H+f8/wCf/r9F/n/P+f8A692j/P8An/P/ANc/z/n/AD/9 coAz/n/P+f1UDP8An/P+f1WnLgY5FOHHcUUoPTkUA9ORRQD05FAPTkUV88+I/wDkZ9W/6/Jv/QzX lmq/8hi9/wCviT/0I1Kv3R9KzKqUtFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFXtM0bUdZnMOn2kk7D7xUYVeDjLHgZwcZPNWbOwur+Qx2sDysOuOg+p6DpSEgda9H 0P4XWsGJdauPtL/88ISVjHUctwzdQeNuD611eneDYY8PqEvnN/zzjJC/n1Pb0/Gml/Su9t7eC0gS C2hjghT7scShVXJzwB9f1/Ppooo4I1jhjSONeioAAPoBTKl/z/n/AD/9d9FH+f8AP+f/AK5RR/n/ AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUZ/z/n/AD/VM0UnX/P+f8/qf5/z /n/65R/n/P8An/66f5/z/n/66Uf5/wA/5/8Arn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuUf5/z/n/6 5/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uUf5/wA/5/8Arn+f8/5/+uVk6z4j0vQYi19dKshXKwr8 0j9cYX0OCMnjPf1p3+rWempm5mAbGRGOWbr2/A8nj+qhSeleb698StRv/Mg0xPsVucjzOsrDkdei 5BHTkEferktS8W3Vzujs1+zxHjd1cjnv2/DketSBAOvNcTJJJNK8srtJI7FmdjksT1JPc1zzu0js 7sWdjlmY5JPqadTaSiiiiuo8Hf8AL7z/AHP/AGatXRv+W3/Af61S1D/ln+P9K6jPuK1M+9Uau6Qf +J1Yc/8ALyn/AKFVnTz/AMTO05/5bJ/OpIP+PiP/AHx/OvUgenP6/T3rvBWxQD05/X6e9AorxH4w /wDI3Wn/AF4J/wChyV5149/5DsH/AF7L/wChNSV59XLUUUUUUUUUUUUUUUUV7ZoX/Ivab0/49Yu/ +wK7/Tv+QXa/9cU/9Bqk/wB9vqa0D36fnVk96Sg9+n50HvRVqx/17/7v9asWv+tb6f1p8f3jWh/n /P8An/69v/P+f8//AF5K5n4gf8iRqP8A2y/9GL/n/POT4n/5F26/4B/6Gv8An/PLk+8K8PrzqpaK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKK3NF8Ia3r6rJZWTfZywHnykInJwSCfvAYOduSK0dP0LUdTAe3tz5RIHmudq9c Z56474zRkV6FovwnsLZkl1e6a8baMwR/u0BxyCwO5hkjBG3pyOcV1Wn+CLaJle+nNwcD92nyqDjn nOT146dKburu9O02y0q0W1sLaK3hGPljGMnAGT6nAHJyTXS2lpb2UAhtoUijGOFGMnAGT6n3pKtA 9Of1+nvUwooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9A ooB6c/r9PegUVn6hpUV8hdcJcYGHzwfY/n/nvTvLCO6UsuFmxw3r9ajlhEgyOG9a5WWN4ZWjkG11 PIP+f8/zwZEaJyjjawPINUyCpweCK63/AD/n/P8A9ff/AM/5/wA//XuUoGTyR/n/AD/nu4DnnFLT genIpR25FFAPTkUA9ORRQD05FAPTkUUA9ORQD05FFfPPiP8A5GfVv+vyb/0M15Zqv/IYvf8Ar4k/ 9CNSr90fSsyqlLRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRV7TNG1HWZ zDp9pJOw+8VGFXg4yx4GcHGTzVmzsLq/kMdrA8rDrjoPqeg6UhIHWvR9D+F1rBiXWrj7S/8AzwhJ WMdRy3DN1B424PrXV6d4Nhjw+oS+c3/POMkL+fU9vT8aaX9K723t4LSBILaGOCFPuxxKFVcnPAH1 /X8+miijgjWOGNI416KgAA+gFMqX/P8An/P/ANd9FH+f8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f 8/5/+uUUf5/z/n/65RRn/P8An/P9UzRSdf8AP+f8/qf5/wA/5/8ArlH+f8/5/wDrp/n/AD/n/wCu lH+f8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+ f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlZOs+I9L0GItfXSrIVysK/NI/XGF9DgjJ4z39ad/q1npqZu ZgGxkRjlm69vwPJ4/qoUnpXm+vfErUb/AMyDTE+xW5yPM6ysOR16LkEdOQR96uS1LxbdXO6OzX7P EeN3VyOe/b8OR61IEA681xMkkk0ryyu0kjsWZ2OSxPUk9zXPO7SOzuxZ2OWZjkk+pp1NpKKKKKKK KKKK6jwd/wAvvP8Ac/8AZq1dG/5bf8B/rVLUP+Wf4/0rqM+4rUz71Rq7pB/4nVhz/wAvKf8AoVWd PP8AxM7Tn/lsn86kg/4+I/8AfH869SB6c/r9Peu8FbFAPTn9fp70CivEfjD/AMjdaf8AXgn/AKHJ XnXj3/kOwf8AXsv/AKE1JXn1ctRRRRRRRRRRRRRRRRXtmhf8i9pvT/j1i7/7Arv9O/5Bdr/1xT/0 GqT/AH2+prQPfp+dWT3pKD36fnQe9FWrH/Xv/u/1qxa/61vp/Wnx/eNaH+f8/wCf/r2/8/5/z/8A XkrmfiB/yJGo/wDbL/0Yv+f885Pif/kXbr/gH/oa/wCf88uT7wrw+vOqlooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooqW2tp7y4WC1 gknmfO2OJCzHAzwBz0p8UMs8qxQxvJI3REUkn8BRXZ6N8Lta1FI5r14tPhfnEnzSgYBB2D3IGCQR zx69Bp/g3ULtUkuGS1jbs3L4xkHb+PQkGkyK9C0j4feHdJ3H7J9tkbjfebZMDjgLgL264zyecV1N h4W0qxyfI+0Mf4rjD4HHGOn6Z5pM11IPTn9fp71tCkoB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFF APTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70 CigHpz+v096BRVDUrCG9jUs2yVfuuBnj0IzyP8/Wpe2kV0gy22QdG6/gf8//AF45Y1kHJw3Y1IAB jkU8Y45FLSg9ORQD05FFAPTkUA9ORRQD05FAPTkUUA9ORQD05FFNkljhiaWWREjRSzO5wFA6knNI zrGhd3VUUZZmOAB70tfPGvSJN4i1OWJ1eN7uVldTkMC5wQe4ryzU3WTVbx0YMrTuQwOQRuPNSDoK z6q0tFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFXtM0bUdZnMOn2kk7D7xUYVeD jLHgZwcZPNWbOwur+Qx2sDysOuOg+p6DpSEgda9H0P4XWsGJdauPtL/88ISVjHUctwzdQeNuD611 eneDYY8PqEvnN/zzjJC/n1Pb0/Gml/Su9t7eC0gSC2hjghT7scShVXJzwB9f1/Ppooo4I1jhjSON eioAAPoBTKl/z/n/AD/9d9FH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5R R/n/AD/n/wCuUUZ/z/n/AD/VM0UnX/P+f8/qf5/z/n/65R/n/P8An/66f5/z/n/66Uf5/wA/5/8A rn+f8/5/+uUf5/z/AJ/+uf5/z/n/AOuUf5/z/n/65/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uUf5 /wA/5/8Arn+f8/5/+uVk6z4j0vQYi19dKshXKwr80j9cYX0OCMnjPf1p3+rWempm5mAbGRGOWbr2 /A8nj+qhSeleb698StRv/Mg0xPsVucjzOsrDkdei5BHTkEferktS8W3Vzujs1+zxHjd1cjnv2/Dk etSBAOvNcTJJJNK8srtJI7FmdjksT1JPc1zzu0js7sWdjlmY5JPqadTaSiiiiiiiiiiiiiiiiuo8 Hf8AL7z/AHP/AGatXRv+W3/Af61S1D/ln+P9K6jPuK1M+9Ua1vDKq/iKzDBWG5jg88hWIP51oaIF bWbYMARuJwfXBxU9pg3UeeeT/KvSQenP6/T3rtRWrQD05/X6e9AorxH4w/8AI3Wn/Xgn/ocledeP f+Q7B/17L/6E1JXn1ctRRRRRRRRRRRRRRRRXt2jRvFoWnxyIUdbaMMrcEEKMgj1r0CwVk062VlKs IkBB4IOKpPy7Y9avHv0/OrB70lB79PzoPeirVj/r3/3f61Ytf9a30/rT4/vGtD/P+f8AP/17f+f8 /wCf/ryVm69odx4k0W40m1ZVmuNu1m6DawY/oD/nrHcaLceIYG0u1ZVmnxtLdPlO4/oD/nroaLpV xrWrwafa7fOm3bd3ThSx/QGsC0+A106r9ovmz3EYx/MGpbT4H3jhTcXvJ6hBjH5g139r8IdSfBnu k57Ip4/Gtm0/Z/tBIjTXN04ByULrg+xwoP5Gti1+A9v5itLc3DAHJUuuD7cAH8q1rf4MAspkuJjg gldwwfbpWwnwG0M43QOP+2z/AONayfAzRzjdE4/7at/jWmnwasDjcHH/AG0P+NWU+A3h5EI8hife QmrC/AvQlX/VyZ95TU3/AApXSSMkzZ9BKwoPwM0AHH2Vv+/lIfghoYOPIk/7+0w/BjSQcbZ/+/5q jN8AdGf/AFRmT/toT/Wqc3wI0p/9U8yf8DzVeb4LWb/6qeZP+BA1iX3wBjQ5gu7gDHTIP9DWLe/A kRnMN3Nj8D/Ssi7+DU0OTFdyMP8AaA/pXK6j8F9ZtIC9vdRzyA/caPZkfXJrmNQ+EGs2kBaCdJpA fuMmzI+uTXP33w01e0i3RMsrA/dK7ePbk1x9/wCENd01nFxp8gC/xKQQfpXJ33hfWdOZhcWMihe4 wQfpXM3ei6lYki5s5I8d8ZH6Vh1j1Qoooooooooooooooooooooooooooooooooooooooooooooo ooooorU0jw3rGu7jpthJOq5y+QqZGONzEDPI4znmrtjpN/qWfsls8ijq3Cr24yeM8jijNei6L8Jb aNUl1q8aaTcD5NsdqYB5BY8kEY6bSOevBrq9P8DwoFfULgyPkHy4ThevQk8nIx0xTd1d7puk6dpE Xl6fZQWylVVjGgBcDpuPVjyeTnqfXnprSxtLFNlrbxwggA7FALY6ZPU/jSZq6D05/X6e9WBRQD05 /X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB 6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRUbTdAp/H8vemNJ2U/jSFvS ockkEtUec45pKAenIpAenIpKAenIoB6ciigHpyKAenIooB6cigHpyKKyde8R2HhyzS4vpGJc7Y4o wC7njOAT26kn+ZGaWparbaTbrLcsTuOFROWbpnAz/n+agE9K8e8R+MtU8Rt5cr/Z7MZAtomO1hnI L/3jwPbjgDmuD1XX7zVTtdvKgHAiQnB5z83qen5dBUgUCudrKpaKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKs2GnXmqXS21jbSXEx/hRc4GQMn0GSOTxU1taz3kwit4nlc9lGcc4yfQc9 aCQOtej+HfhjEiCfXm8xzgrbQyfKAR/Ew5JyeinHHU5xXV6V4PRV83UzubgiFG4Ax3I6nnt6d80w v6V6Fb28FpAkFtDHBCn3Y4lCquTngD6/r+fUxRRwRrHDGkca9FQAAfQCmVL/AJ/z/n/676KP8/5/ z/8AXKKP8/5/z/8AXKKP8/5/z/8AXKKP8/5/z/8AXKKP8/5/z/8AXKKM/wCf8/5/qmaKTr/n/P8A n9T/AD/n/P8A9co/z/n/AD/9dP8AP+f8/wD10o/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf 8/8A1yj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yqGp 6zp2jQCbULuOBW+6GOWbkZwoyT1GcA4z+de8v7WwjEl1Okanpnkn6Dqev+e6gE9K851v4oXU+YtG g+zJ/wA95gGkPQ8Lyo7jndkHtXKaj4xmkylhH5K/89JAC3bt0Hf1/CniP1rgJJJJpXlldpJHYszs cliepJ7muYd2kdndizscszHJJ9TT6bSUUUUUUUUUUUUUUUUUUUUUUV1Hg7/l95/uf+zVq6N/y2/4 D/WqWof8s/x/pXUZ9xWpn3qjWx4XP/FR2nPd/wD0Fq0dCP8AxOrfnu3/AKCans/+PpPx/ka9HB6c /r9Peu0FatAPTn9fp70CivEfjD/yN1p/14J/6HJXnXj3/kOwf9ey/wDoTUlefVy1FFFFFFFFFFFF FTW1ndXjlLW2mnYdREhYj8qlgtbi6cpbwSzMO0aFj+lPihlnfZDE8jeiKSf0r3Y9+n516Ge9Z1B7 9PzoPeig9+n50HvRVqx/17/7v9asWv8ArW+n9afH941of5/z/n/69v8Az/n/AD/9eStnwoofxLaB hkHfx/wBv8/556TwEofxpp4YZB8zj/tm3+f889p8JlD/ABN0hWGQfO4/7YvXpoRR0UV7aEUdFFfT wRR0UU6nU6iiiiiiiiiiiikIB6ikIB6ikIB6ioJbSKYfMo/GoJbSKYfMo/GoJbSKYfMo/GsPUtBs 7mFlliUrWHqWg2dzCyyxKVrD1LQbO5hZZYlK15T4s+FenaiJHtoxBc8kSL1J9+xryzxT8MLC9Ej2 qCC45Ide59+cGvMvEfw6tZxI1mBDNyQexPuM814nr/hrUfD10YruLMZJ2Sr0Yf0rx3W/D9/oN0Yr uL5CTskHRh/SvMdT0q70m5MN1HtyfkbIww9ax6yqo0UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UU+KKSeVIoo2kkdgqIgyWJ4AA7mnIjSOqIpZ2ICqoySfQUV2Wi/DHW9SZXvQmnW7KG3SYZyCMjCA 8HpkMVIz36Vv6f4O1G7ZWuNtrEQDl8MxyP7oP0znHWkyK9A0b4c+H9LSNprf7fcryZLjlSSACAmd uOpGQSM9TgV1Gn+E9LslQyRfaZRyXl5HQD7vTHXrn60ma64Hpz+v0963RSUA9Of1+nvQKKAenP6/ T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUD/AD+nvQKKAenP6/T3oFFAPTn9 fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKQuFGSf1+nvSFgByf88UZxULSF sc4Hp+VRFy3fim5zTAenIpoPTkUlAPTkUA9ORRQD05FAPTkUUA9ORQD05FFAPTkUA9ORRXn/AIn+ JVvaK9pohW4uCpU3P8ETZxwD988E56dPvciuY1jxdFArQacRLLggzfwoc44/vd/bp1p6p615beXl zqF5Ld3czTTytud26n/63bHauMuLiW6neeeQySucsx708DAqCo6KKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKs2GnXmqXS21jbSXEx/hRc4GQMn0GSOTxU1taz3kwit4nlc9lGcc4yfQc9aC QOtehaD8LvuT65cejfZoD9Dhn/MEL9Q1dRpvg37smoy+h8mM/Tq35jA/OmF/SvQ7DT7PS7Vbaxto 7eEYO2MYycAZPqcAcnJ/r1NtawWcIit4kiQdlHsBn3NMJz1qz/n/AD/n/wCvNRR/n/P+f/rlFH+f 8/5/+uUUf5/z/n/65RR/n/P+f/rlFH+f8/5/+uUUZ/z/AJ/z/VM0UnX/AD/n/P6n+f8AP+f/AK5R /n/P+f8A66f5/wA/5/8ArpR/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65R/n/AD/n/wCu f5/z/n/65R/n/P8An/65/n/P+f8A65R/n/P+f/rn+f8AP+f/AK5VDU9Z07RoBNqF3HArfdDHLNyM 4UZJ6jOAcZ/OveX9rYRiS6nSNT0zyT9B1PX/AD3UAnpXnOt/FC6nzFo0H2ZP+e8wDSHoeF5Udxzu yD2rlNR8YzSZSwj8lf8AnpIAW7dug7+v4U8R+tcHcXM93O09zNJNM33pJGLMeMck1zUssk8hklke SRurOck/jT6iplFFFFFFFFFFFFFFFFFFFFFFFFFFFFdR4O/5fef7n/s1aujf8tv+A/1qlqH/ACz/ AB/pXUZ9xWpn3qjWx4XP/FR2nPd//QWrR0I/8Tq357t/6Cans/8Aj6T8f5GvRwenP6/T3rtBWrQD 05/X6e9AorwT4p3kl145uInChbWGKFCM5IKh+eeuXP4YrzLxpcPN4klRgMQxoi47jG7n8WNJXF1z 1FFFFSQW81zKIoIpJZD0WNSxP4CnxQyzyCOGN5HPRUUkn8BTkR5HCIrMxOAqjJNdhonww8QauymS H7JEf4pOT1/uiur0b4c69qzKXg+yxH+KTk9fSt/SvBetao4xbNBET9+T/Dr+eK9L0D4JWMJSS8D3 L5z+8+6PwHH55r0bQvgxaRlHvN9w+c/P90fgP65rutG+E8fyPds0rZHB4Ufh/jmvS9M8B2VjCkUc EaRqMKoUAAe1ejaZ4EsrKJI44Y0ReihQAK7/AE3wJZ2caIkKKg6DA4rzE9+n514ae9fK9B79PzoP eig9+n50HvRVqx/17/7v9asWv+tb6f1p8f3jWh/n/P8An/69v/P+f8//AF5K2/Ct3b2WqvPcbcLC dhYdGyOn4Z/P8+r+H11bWXiGW4uQmEtm2MwztYsoyPfBI/E+vPofwbuLS08Zz3N0sZ8uxcxM6glG LoMj0O0sPoT611UvjLTYhzMmfrXosvjLTYhzMmfrXt0vjLTYhzMmfrVKX4gaYnSVfzFUpfiBpidJ V/MVSl+IGmJ0lX8xVGX4maTH965Rfqaoy/EzSY/vXKL9TVGX4maTH965Rfqapv8AFjREODqMI+rG qb/FjREODqMI+rGqb/FjREODqMI+rGm/8Lb0PP8AyEof++jTf+Ft6Hn/AJCUP/fRpv8AwtvQ8/8A ISh/76NTr8WNBxxqNsfrKKnX4saDjjUbY/WUVOvxY0HHGo2x+sorUtfHNncsAkyHPbIzWpa+ObO5 YBJkOe2RmtS18c2dywCTIc9sjNaA8T2zf8tF/A1oDxPbN/y0X8DWgPE9s3/LRfwNV7nXY2HDD161 XuddjYcMPXrVe512Nhww9etZsl9HPwMfSs2S+jn4GPpWbJfRz8DH0rnfEOi22s2TwzQq4YZz71zv iDRbbWLJ4ZYQ4IyD6Gue1/RrfV7No5Ig2fmDDqD6188+KNCOgasbYbvLdd6Z7ckY/SvBPEWjNomp m252Mu9c9hkjH6V45q2nNpd+1s+em4ZHbJH9KxKyao0UUUUUUUUUUUUUUUUUUUUUUUUUUVpaX4f1 bWmA06wnnUsV8wLhAQMkFzhQcY6nuPWrdlpd9qDAWtrJICSNwGFBAzgseBRmu/0j4RfebWtQ9ljs z9MEsw+vG30Oe1dRYeBep1C69gtufpzkj68Y/Gk3V6HpOi6ZokBh02zit1bG4ryzc5G5iSTjJxkn Ga6mx0+z06Ly7SBIlPUjq31JOT1PWm5q+D05/X6e9WhRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQ KKAenP6/T3oFFAPTn9fp70CigHpz+v096BRTlRjjgj6/hShSaUA0vyrjnJ+v+f8AP6rwvfJ+tHAp ucnr+v096bnNJSA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AoqNpQOAc n6/T3pjSAcA80hNRbixBLZqPcSQSaTNID05FID05FJQD05FAPTkUUA9ORQD05FFAPTkUA9ORRVHV tYs9D0576+l2RIMADlnbsqjPJP8A9c8Amq19fwadaNcXD7UXgAclj6AdzSgZPFeQ+J/Huoa6z21s zWmn5ICIxDyqRj94QeR1+Ucc85wDXDax4mutSLQwkwWuSAqkhnGMfMc/Xj3708KB9a5KsOnUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUVZsNOvNUultrG2kuJj/Ci5wMgZPoMkcnipra1nvJ hFbxPK57KM45xk+g560Egda9C0H4Xfcn1y49G+zQH6HDP+YIX6hq6jTfBv3ZNRl9D5MZ+nVvzGB+ dML+leh2Gn2el2q21jbR28IwdsYxk4AyfU4A5OT/AF6m2tYLOERW8SRIOyj2Az7mmE561Z/z/n/P /wBeaij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXKKM/5 /wA/5/qmaKTr/n/P+f1P8/5/z/8AXKP8/wCf8/8A10/z/n/P/wBdKP8AP+f8/wD1z/P+f8//AFyj /P8An/P/ANc/z/n/AD/9co/z/n/P/wBc/wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yj/AD/n/P8A 9c/z/n/P/wBcqhqes6do0Am1C7jgVvuhjlm5GcKMk9RnAOM/nXvL+1sIxJdTpGp6Z5J+g6nr/nuo BPSvOdb+KF1PmLRoPsyf895gGkPQ8Lyo7jndkHtXKaj4xmkylhH5K/8APSQAt27dB39fwp4j9a4O 4uZ7udp7maSaZvvSSMWY8Y5JrmpZZJ5DJLI8kjdWc5J/Gn1FTKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKK6jwd/wAvvP8Ac/8AZq1dG/5bf8B/rVLUP+Wf4/0rqM+4rUz71RrY8Ln/AIqO057v/wCg tWjoR/4nVvz3b/0E1PZ/8fSfj/I16OD05/X6e9doK1aAenP6/T3oFFfPnxL/AOSgan9If/RSV5Z4 v/5Gi8/7Z/8AoC0lZWk+GdX1qRVs7OQqf+Wjjav59/wqDS/D2qaxIq2lo7Kf42GF/Pv+FXbHSb7U nC2tu75ON2MD869M8N/BWSUpJq0nmZ/5Zxkhfz6n9K9F8PfB2aZkk1R92f8AlnGcD8+v8q7jQ/hd dXDq9++FP8Cf49f5V6z4f+Hel6VEBb2cUfckKMk/WvVNA+HumaXGBBaRJ6ttGfzr0jQ/h/p2nIvl 2yA45YjJ/OuyttJt4FACjiuxttJt4FACjiuwttJt4FACjiryoqjgYq8qKo4GKvKiqOBihpEQfMwF DSIg+ZgKGkRB8zAV8/nv0/Ovls96+JqD36fnQe9FB79PzoPeirlgAXkPfj+tWbQDc570+Lqavf5/ z/n/AOva/wA/5/z/APXkrkfiJqd5pfh6GaynMMj3SoWAB42se/0FY3ibULrTtNSW0maKRpQhYY5G CcfoKsWd1PaTGS3laNiu0le49K8mn1vVLkYlv52HoHI/lXEzatqFx/rbydh6byKkkuriUkyXErZ7 Fzj8qpO7SNudix9Sc1UZixyxJPqahAAzgAZ5NNpKWiiiiiiiiipIbie3JMM0kZPUoxGfyp8U0sJJ ileMnqVYilV2Q5Vip9QcVuWfjXXLRVUXhlUdBJzWxa+LdZtVCreM6joJOavwa5qduoEd5IQBwHO7 /wCvXZaL8RnvP3F1lJAuQc8H6V1ek/ECW5Hk3WUcDhs8Gt2x8aXJXy7vggcODxXdaLqzXrfK2RnB Oa7bRdWa9b5WyM4JzXXaLqzXrfK2RnBOa6tB5kYJ6iurQeZGCeorq0HmRgnqK8o+LmmI2mwXnHmQ PgN7N1HX6H8PevLfipp6Gxgu8DfE+3d7HqP5V5z8Q7NViguMAsrbc+xzx/KvH68qrz+iiiiiiiii iiiiiiiiiiiiuw0X4ba9qyrLPGlhAWGTc5DkZwSE65Ho23ORg1vaf4R1K+CvIq2sZI5l4bGcHC9f zxnikyK9D0X4baDpTLLPG2oThRzc4KA4wSEHGDno27GBj36rT/COmWTK8im6kwOZsFQcc4Xp3757 Uma66KOOCKOKJFjjRQqIgwFAwAAOwrcjRY0VEUKigBVXgAccCkpwPTn9fp704UUA9Of1+nvQKKAe nP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AopVBPTJ/wAj3oGT05op6xnjP5U8IeM0oFPA CgfzJ/z/AJ/VQAopelMaTPA6euf8+tNL56UhNRg9Of1+nvTRSUA9Of1+nvQKKAenP6/T3oFFAPTn 9fp70CigHpz+v096BRSFgoBJ/X6e9IWAGSaM1C0pbgHA/wD1VGZCehwKbmmA9ORTAenIpKAenIoB 6ciigHpyKAenIooB6cigHpyKKAenIoB6ciiuN8T/ABCstEL2tiFvL9SUdckJEcfxH+I57D0OSCOc DWPFNvp5aG223FyCVYZO1Djue/PYe/IpyqTz2ryTU9VvtYvDd6hcNPMVC7mAGAOgAHAH07knvXD3 l7cX8/n3UpkkwBk8YA7ADpUgGBxVOoKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKs2GnXm qXS21jbSXEx/hRc4GQMn0GSOTxU1taz3kwit4nlc9lGcc4yfQc9aCQOtehaD8LvuT65cejfZoD9D hn/MEL9Q1dRpvg37smoy+h8mM/Tq35jA/OmF/SvQ7DT7PS7Vbaxto7eEYO2MYycAZPqcAcnJ/r1N tawWcIit4kiQdlHsBn3NMJz1qz/n/P8An/681FH+f8/5/wDrlFH+f8/5/wDrlFH+f8/5/wDrlFH+ f8/5/wDrlFH+f8/5/wDrlFGf8/5/z/VM0UnX/P8An/P6n+f8/wCf/rlH+f8AP+f/AK6f5/z/AJ/+ ulH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5 /wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlUNT1nTtGgE2oXccCt90Mcs3IzhRknqM4Bxn8695f2thGJ LqdI1PTPJP0HU9f891AJ6V5zrfxQup8xaNB9mT/nvMA0h6HheVHcc7sg9q5TUfGM0mUsI/JX/npI AW7dug7+v4U8R+tcHcXM93O09zNJNM33pJGLMeMck1zUssk8hklkeSRurOck/jT6iplFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFdZ4QiZbe6myu13VAO+QCf/ZhWvo6ERyvkYJA/If8A16oa gw3ovcAn/P5V0mfcVpZ96p1seFz/AMVHac93/wDQWrR0I/8AE6t+e7f+gmp7P/j6T8f5GvRwenP6 /T3rtBWrUT3UET7HmUSYB2A5bB4zjOfWhDvk8tTufAO0HnFWLOxur+UR2sDyt/sjgfU9BXOf8K2t Nf8AE9zrV7G7+ds2wyDhdqBeRnnp3qSx+GkGrazJqV8rOZNuImHyjCgfj0r0Lw58NGmKy6idzZz5 Y+7/APXr0vSPDFrZxKscSqAMYHpXqGkeGLWziVY4lUAYwPSvVtI8MWtnEqxxKoAxgeldHDZxxKAF GPSujhs44lACjHpXRw2ccSgBRj0qZpEjHJAFTNIkY5IAqZpEjHJAFU7jVreD7zqPxqncatbwfedR +NU7jVreD7zqPxrA1HxlbWqt84wO+elYGo+Mra1VvnGB3z0rA1HxlbWqt84wO+eleca/8YbC0LJF cLK/92M7v1rzvXfi7Z2+5YZhM/8AdjO79elef6z8VYU3LbN57Y4EfIP49KpHv0/OuLPevEqD36fn Qe9FB79PzoPeirth1l/D+tWrTq/4f1qSLvV3/P8An/P/ANez/n/P+f8A6764b4p/8ixbf9fi/wDo D1zvjP8A5A8P/XwP/QWp8f3vwryKuGqSiiiiiiiiiiiiiiiiiiiiilUMXUJndnjHXNKASwC5znjF GMjFe9eDdPljtIfMVgSM4P8A+v3r2rwbp8sdpD5isCRnB/8A1+9eleDdPljtIfMVgSM4P/6/evRY 4dkIFeixw7IQK9Fjh2QgV518TREPD90ZSD8p2rnv2NeefEkRDQ5zKQePlXPfsa4D4hCIaY5lIPzD aue+eDXgleJV5fRRRRRRRRRRRRV/StE1LW7gwabZyXDj7xXhV4JG5jwM4OMnmrNlp13qMvl2kDys OpHAH1J4HTvRmu90b4SSypHLrN/5OeWt7YBmAIGPnPAIJ5wCOODzXT6f4Gd1R7+58vPWKLBOMf3j wDk+h6daTdXoekeHNH0LcdNsYoHf70mSzkHHG5iTjgcZxXU2Gk2Gm5NpbJGzdW5LY44ySTjgcUmc 1qA9Of1+nvV0UlAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/ T3oFFOVGOPT1/KlCk4pQDUixgYzk/wCf8/56vCY65NKBTgOnB/z/AJ/z3X8KWml1Xr19M/5/z+qF gKTIFRFixyT/AJ496ZnJ60mc0gPTn9fp70gpKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X 6e9AopjSheM8/X6e9NZwvGeaQnFQlyxBLf54qIsWIyaTOaQHpyKQHpyKSgHpyKAenIooB6cigHpy KKAenIoB6ciiqt9qVnpdqbm+uooIQPvO2MnGcAdScA8DJqG5u4LOHzrmZIox3Y9eM4HqfalHPSvK fEvxIvdS3W2kmSytPlPm52zMRyeQflGcdOeOvJFcVq/iy4u8w2O+3h4+fOJD68g8D/DrzinhMda4 aucp1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFWbDTrzVLpbaxtpLiY/wAKLnAyBk+gyRye KmtrWe8mEVvE8rnsozjnGT6DnrQSB1r0LQfhd9yfXLj0b7NAfocM/wCYIX6hq6jTfBv3ZNRl9D5M Z+nVvzGB+dML+leh2Gn2el2q21jbR28IwdsYxk4AyfU4A5OT/Xqba1gs4RFbxJEg7KPYDPuaYTnr Vn/P+f8AP/15qKP8/wCf8/8A1yij/P8An/P/ANcoo/z/AJ/z/wDXKKP8/wCf8/8A1yij/P8An/P/ ANcooz/n/P8An+qZopOv+f8AP+f1P8/5/wA//XKP8/5/z/8AXT/P+f8AP/10o/z/AJ/z/wDXP8/5 /wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8 /wCf8/8A1z/P+f8AP/1yqGp6zp2jQCbULuOBW+6GOWbkZwoyT1GcA4z+de8v7WwjEl1Okanpnkn6 Dqev+e6gE9K851v4oXU+YtGg+zJ/z3mAaQ9DwvKjuOd2Qe1cpqPjGaTKWEfkr/z0kALdu3Qd/X8K eI/WuDuLme7nae5mkmmb70kjFmPGOSa5qWWSeQySyPJI3VnOSfxp9RUyiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiuy8JH/AIlUvI/15/8AQRW1pH/Ho3P/AC0P8hWdf/69f93/ABre z7ir+feqtafh+5itNbt555AkSbyx6/wt+f0/yb+jSpFqsEjthV3E9/4T+dWLFWe8jVQWYk4A5J4N dpZyarrYGIXsbdugDZlK89T/AA5GOByD/FXeaVpV/q4VpYntYm5Cg/OR7ntkY4HI9a9K8N+BJr8R zX8boGwRGD0Hv/hXV6R4YhthkJgsSxY8lie59/rXe6N4XgtFG2MLnnPc+5r1jRPCttYxIkUSoo6A CuqtrRIR0A/rXV21okI6Af1rrLa0SEdAP61YNzFCDyPxqwbmKEHkfjVg3MUIPI/Gsq88QQwggSDH rmsq88QQwggSDHrmsq88QQwggSDHrmuB8T/E/TtJVkkuVMuCVQHJP4CuD8TfEzT9LVo2nDS4+VBy T+ArhfEXxIs7ANEJd8vZF5/lXkmtfFzVL0stkvlr2d+T+VeVav8AFPVb0lbQeUv95uT+Veb6l8QN WvuIW8lT68t/hXE6hrmp6oxN5eTSAknaWO0fhXHX2r6hqLE3d3LKCc7WY4H4VzVzeXN4265nklOc /OxIB9h2rPqlUFe+Hv0/OvSD3qjQe/T86D3ooPfp+dB70VdsOsv4f1q1adX/AA/rUkXerv8An/P+ f/r2f8/5/wA//XfXDfFP/kWLb/r8X/0B653xn/yB4f8Ar4H/AKC1Pj+9+FeRVw1SUUUUUUUUUUUU UUUUUUUUUV2XgPwzNq2opeNGTDE3GR1Pr+H8/pXVeC/Ds2raglyYyYYm4yO/r+FbfhzRJtVv0YRk xRsCTjivofRdJW2gXjoOa9/0XSVtoF46DmvbdF0lbaBeOg5rRuWEcRGQK0blhHERkCtG5YRxEZAr wr4tasT5VhHKMs+6RQRnHb3rw/4paoWkisUkGSxdwMZx2968b+IOoebeR2QYHBLuODjpjNeVV5rX FUUUUUUV1OkfD7xDq+5vsn2ONeN95mPJ44C4Ld+uMcHnNbNj4W1W+yfI+zqP4rjKZPHGMZ79cYpM ivRdF+GOh6aqvehtRuAwbdL8qDByMIDyORkMWBx74rq9O8HadaBWuM3coIOX4UYP90H6ZzmkzXZx RxwRRxRIscaKFREGAoGAAB2FdBGixoqIoVFACqvAA44FJTgenP6/T3pwooB6c/r9PegUUA9Of1+n vQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRSjJxjn/ACPegZPTminrGeMn/P8An/Pq4IeM0oFP VQMYB/P/AD/n9XhQOxpQKX8+v+f8/wCSUtH5/n/n/P6lFRtIDwv55/z60wuDwKaT6VHnPf8AX6e9 Nz70lAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUbgBknj6/T3ozgZJoqFps4CnA9c /So2kzwD+NIW9KjB6ciowenIptAPTkUA9ORRQD05FAPTkUUA9ORQD05FFAPTkUA9ORRXM+JfG+ne HMwf8fV+Ap+zIcbQe7NyBx25PI4wc1kav4itdK/d/wCuuRj90pxgH1Pbj8eR9acqk/SvH9b8Qaj4 guln1CffsyI41GEjBOcAflyck4GScVwmoapd6pMJLqTdtzsUDCqD2A/r14FPAA6VmVTpaKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKVVLMFUEk8AAdaUAswVQSScADvSMyou5mCqO5OK0bXQNUvM+ VaSf8C+X+dadn4c1e+z5FjL/AMCG3+dQNeQhtoJY5wdoyB75qve6bfaa4W9tJoCxIUyIQGx1weh6 jp61X1DSdR0pwl/ZXFsWLBTLGVD467T0bqOR6ip1YMMg5qrVOloooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooqzYadeapdLbWNtJcTH+FFzgZAyfQZI5PFTW1rPe TCK3ieVz2UZxzjJ9Bz1oJA616FoPwu+5Prlx6N9mgP0OGf8AMEL9Q1dRpvg37smoy+h8mM/Tq35j A/OmF/SvQ7DT7PS7Vbaxto7eEYO2MYycAZPqcAcnJ/r1NtawWcIit4kiQdlHsBn3NMJz1qz/AJ/z /n/681FH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUZ/ z/n/AD/VM0UnX/P+f8/qf5/z/n/65R/n/P8An/66f5/z/n/66Uf5/wA/5/8Arn+f8/5/+uUf5/z/ AJ/+uf5/z/n/AOuUf5/z/n/65/n/AD/n/wCuUf5/z/n/AOuf5/z/AJ/+uUf5/wA/5/8Arn+f8/5/ +uVQ1PWdO0aATahdxwK33QxyzcjOFGSeozgHGfzr3l/a2EYkup0jU9M8k/QdT1/z3UAnpXnOt/FC 6nzFo0H2ZP8AnvMA0h6HheVHcc7sg9q5TUfGM0mUsI/JX/npIAW7dug7+v4U8R+tcHcXM93O09zN JNM33pJGLMeMck1zUssk8hklkeSRurOck/jT6iplFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFdl4SP/Eql5H+vP8A6CK2tI/49G5/5aH+QrOv/wDXr/u/410UEM11OILdfMmI JC9vxPb/APXWvZ2dxqFwILVN8hGeeg+pqTS9JvNYuhBZx7m7seFX6mvQ/DPg5IDHcXKLLcY++R0+ gycD+f5V6n4V8ExWQSedBLcHrIR0+g7Cva/B3gG20qNJXjEtweWlYc/h6CvQrDTo4FHygV6LYadH Ao+UCvSrDTo4FHygVpNNHCvXGBWk00cK9cYFaTTRwr1xgVmX2uw26Md4wOetZl9rsNujHeMDnrWZ fa7Dbox3jA5615r4q+KVlpu+MzhpOcRR8t/Pj8a848T/ABOtLEtGJtz84jj5b8eeK888RfEaC3Zo 45N7jPyJyfxryLXviPrWsGSOGU2sDE/c++Rn+92/CvKdb8f6xqxdI5TbQseifeIz69vwrzrVPF2q amWXzjDET0Tr19ev5VyDu8jl3ZmY9SxyTXKszOxZmLMepJyTWBTaSiiiiiiivfD36fnXpB71RoPf p+dB70UHv0/Og96Ku2HWX8P61atOr/h/WpIu9Xf8/wCf8/8A17P+f8/5/wDrvrhvin/yLFt/1+L/ AOgPXO+M/wDkDw/9fA/9Banx/e/CvIq4apKKKKKKKKKKKKKKKKKKK67wf4IufEc6zTh4rEHlgMNJ 7D/Gun8KeD7jxBcLJKHisweWA5f2X/Gtrw94duNcueVdLVThpB1J9F/xr6G8P+HLfTbaOGCFY41A +QDgf41794f8OW+nW0cUMQjRQPkA6f417VoHh2DT7eOOKIIo/hH+PeumCLCnQcV0oRYU6DiulCLC nQcVyXibWobG3eSSVURQSSTXJeJtahsbd5JJVRFBJJNcl4m1qGxt3kklVEUEkk18z+JNXbXNduL3 5tjELGGPRRwPz6/jXzpr+qtrOsz3h3bGICBj0Ucf/X/GvD9Vv21LUpro7sORgMegAxVfTtI1HV5v K0+ynuWDKrGNCQpY4G49FHucDiqtpY3V9JstbeSU5AOxchc9MnoPxqnXe6L8JbmVlk1q8SGMqD5N sdz8jkFiMAg46bgefY102n+B5nYPqFwsaEA+XCctyOhJ4GOOmaTdXoGjeFNF0JIvsVjF5yci4kAa UkgAncemR2GByeOa6jT9E0/TVT7PbJ5i/wDLVhufOACc9s+g45pM5rZB6c/r9PetAUlAPTn9fp70 CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFOVGOPT1/KlCk4pQDT1 jA65P+f8/wCergnrk0oFPA6cH/P+f893fhS0fn1/z/n/ACSij8+v+f8AP+SUUjMF6/ln/P8An9UJ A6/zpM4qIuW78fWmFie9JnNNB6c/r9PekFJQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T 3oFFNaRVxzz6Z+nvTS4Xvz9aM4qAuWIy34VEXLEZNNzmkB6cikB6cikoB6cigHpyKKAenIoB6cii gHpyKAenIoqKe5gtIDPczxQwqBukkcKoyQOST7/rTJJo4IzJLKkca9WdgAOnfNKOa8w8T/EyS4R7 PQw0UTKUe6cEOeeqc8cDqeeegIzXH6x4veVWg03KIQVaZhhv+A88fU889sU5U9a88kkkmleWV2kk dizOxyWJ6knua5V3aR2d2LOxyzMckn1NPptJRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRVy30q/uiB DaStnoSuAfxNXbXSNQvCBb2cz55B24B/E8VC13AuP3oOem3n+Vb+n+ANVvOZNsQ4OB835+ldNpnw 11q/AMirCCAcfex9eeKiN2zr+6hbJH8fb8q6mx+GNrGC93IzKCCd7YA/Kuy034PWqKZL+dioxne2 APyNNJuXzukCLjBCjH610mn+GdMtQBb24YdeF2j3rrNK8G6NZgC1tBJ3zt2j3601bdCxY5dj1Jro LTSUATCKvptFdXYaHGqx7YkX0CjH9f8AP850hHHAqXVPCem69YNa6hArjaVSQAeZETjlW7Hgexxz kdZ9Y8DaR4l0xrLVbZJF2sscoUebCTg7kbscgH0OOcjgzqmK+ZZYZLeZ4Zo3jljYo6OpDKw4IIPQ ivkCeCa1uJLe4ieKaJikkcilWRgcEEHkEHtS0yo6KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKs2GnXmqXS21jbSXEx/hRc4GQMn0GSOTxU1taz3kwit4nlc9lGcc4yfQc9 aCQOtehaD8LvuT65cejfZoD9Dhn/ADBC/UNXUab4N+7JqMvofJjP06t+YwPzphf0r0Ow0+z0u1W2 sbaO3hGDtjGMnAGT6nAHJyf69TbWsFnCIreJIkHZR7AZ9zTCc9as/wCf8/5/+vNRR/n/AD/n/wCu UUf5/wA/5/8ArlFH+f8AP+f/AK5RR/n/AD/n/wCuUUf5/wA/5/8ArlFGf8/5/wA/1TNFJ1/z/n/P 6n+f8/5/+uUf5/z/AJ/+un+f8/5/+ulH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlH+f 8/5/+uf5/wA/5/8ArlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlVb/UbPTLU3N9cxwQ j+J2xk4JwPU4B4GSffvFc3UFnCZbiVI0Hdj14zgep9v8lQM9K878Q/E4urW+hIyHd/x9yqMkAn7q HPB45PqeAea5XVPGBYGLTVK8/wCvcD17KfXjk+p4708J6/lXnlxcz3c7T3M0k0zfekkYsx4xyTXL SyyTyGSWR5JG6s5yT+NPqKmUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUV3vgXTri+sGSNcBpzyRxjaBXV+FNHudTj2RrhDIcsfoKsaf4dutd1CNYxtgHDyZ/Qe/P+el eyaH4etNJt2uJlRf4nc9/r6mvaPDvhi20yHeY1B6k46/U9zXsOjaFpfhjS5Lu58q3t4V3SSH06fU noO5JNap8UQQJi1tnZiDzIQAPTgZz+ldTHeRwD93GSfUnH0+tZl58ZLG2gxpOlXEspVvmumCKh/h OFLbh1yMr9earN4u1JnQgQKq5yiocNn15z+X60p1W4JX7gA6gDr+v+f54Mvxl8USXEEipp8SR7t0 KQttlyMDdlieOowR75qOfxLdTxYZFD9yrHB/Dmql3c3NxGdrgPjj0J7f5/yba/GK8nhRLzTUMmfn khmKjGeykHt/tc+1ePePfGOuQarLpgKwRqAwlTJ8wEA5BIHuD15B5rw7x34m1+11WXTJ0NqFAcMD nzFPIIPTHUcZ5BGa53WPGN9qxZY3MUGegPzH6mvOZJHlkLyOzuerMck1wDu8jl3ZmY9SxyTXPkli SSST1JptNpKKKKKKKKKKKKK98Pfp+dekHvVGg9+n50HvRQe/T86D3oq7YdZfw/rVq06v+H9aki71 d/z/AJ/z/wDXs/5/z/n/AOu+uG+Kf/IsW3/X4v8A6A9c74z/AOQPD/18D/0FqfH978K8irhqkooo oooooooooqxZ2NzqFwsFpC0sp6KtTWtpPezrBbRNJI3RRT4YpLiZYolLyN0UdTXqPhP4TGaVJ9Xb zMHIhT7v4nv29Pxr0nwt8LmuJUn1Rt+DnyU+7+J79v8A69dz4e+H0l3Ikt+Ttzny16fif8K9u0nw 9FaQoioqhRgBRjAr2jSfD0VpCiKiqFGAFGMCvWtJ8PRWkKIqKoUYAUYwK3NkcCdhj9K3NkcCdhj9 K3NkcCdhj9K57Wtahs4HLMAF9657Wtahs4HLMAF9657Wtahs4HLMAF968Y8TWviPxreCHT7cw6Zu /wCPi4by1fjIIH3ipyOQCDn614n4on1fxXeeTaRmOwDf62Y7QxxnOOpHPUA9frXhvinxE2tXrIjM bZG+XP8AEfWrekfCnR7Pc2pTSaix4C8xIBx2Vs5698c9KhsPBVhBk3cj3THgD7igcdgc569+/Sue 3V3FrbW9nbpb2sMUEKfdjiUKoycnAHHU/rXRwwxW8SxQxpHGvREAAH4CkqUHpz+v096eKKAenP6/ T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUoycY5/yPegZPTminrGeM04IeM0 oFPCAY4P4/5/z/NwUDtS4pfz6/5/z/krS0fn1/z/AJ/ySij8+v8An/P+SUUfn1/z/n/JKKY0g6L/ AD/z600uO1ITUWc9/wBfp70zPvTaAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9Aooz7/ AK/T3oz70VE03QKfx/KozJ0Cn8aQt6VEDnHNR56c02gHpyKAenIooB6cigHpyKKAenIoB6ciigHp yKAenIorC8ReLNO8Nwf6RJ5l20ZaK2T7z9Byeij3PocZxis7VdbtdJi/evvmK5SFerfX0HuffrSg E15B4j8V6l4km/0mTZaK5aK2T7qcY5PVjjufU4xnFcJqut3erSfvm2wq2UiXovb8T7n1PSpAoFYV ZtLRRRRRRRRRRRRRRRRRRRRRRRRU0Fnc3RxBBJJzjKrkZ+tT29ldXZxb28kvOMqpIz9ajkmji++4 B9O/5Vt2XgvWLwr+5EYJ/iOTj6Ct/T/Aeu35XFuIwSPvHJx64FQteg5EcbOexPAP+fpXUad8MGYq bqVmPcfdB/z9a7LSvg7LIVa8mZuxX7oP9f1ppkuZD8uIxnsMmut0z4e6faFGFsu4fxEc/mTXcaR8 KtLszG/2UFx/Ey8/mT/n+Z9laT/WOz85wTxW42naZpSAS7FfGVjAyxHPb3x16e9dG+k6NoaKJvLW TGUiUbnYc9B74IycD39XmKKEc4B7DvQbiSY7LODyk/vuAW7dug7+tBupbg+Xp9r5MfaSQAv26DOB 39etG4twi4HqetWINNaVxJKzSOe5q3baQ88gmndpZG7t2/8Arc9P8lyxFjljk1rW9iqAZ7Vu2umq irnsf8/5/wAmZYwKuJGEHArQjiWMYAp4GKdT+lLXjPxr0mX7dp+tKwaBo/sjjj5WBZ1PXJyC3bjb 7ivn/wDaG0Ob+0dL8Qo4a3aL7C68fIwLOp65O4M/bjZ15FNPWvJ68RpKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKs2GnXmqXS21jbSXEx/hRc4GQMn0GSOTxU1taz3kwit4nlc9l Gcc4yfQc9aCQOtehaD8LvuT65cejfZoD9Dhn/MEL9Q1dRpvg37smoy+h8mM/Tq35jA/OmF/SvQ7D T7PS7Vbaxto7eEYO2MYycAZPqcAcnJ/r1NtawWcIit4kiQdlHsBn3NMJz1qz/n/P+f8A681FH+f8 /wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFH+f8/wCf/rlFGf8AP+f8/wBUzRSdf8/5 /wA/qf5/z/n/AOuUf5/z/n/66f5/z/n/AOulH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8A rlH+f8/5/wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlVb/AFGz0y1N zfXMcEI/idsZOCcD1OAeBkn37xXN1BZwmW4lSNB3Y9eM4Hqfb/JUDPSvPtd+KH34NEg9R9pnH1GV T8iC30K1y+peMfvR6dF6jzpB9eQv5Hn8qeE9a89v9RvNUumub65knmP8TtnAyTgegyTwOK5e5up7 yYy3Eryue7HOOc4HoOelPAA6VWqGiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiitPQtGl1vUUt0JVMjew5IHtWho+lSatfpboSFyNzDkgVZsbN767SBM5Y8kDoK+if CmgwabZRRRoAEUAA1774V0GDTrOKNEACgDBr2TwvocNjaoqoMgd+Oav+JbqOE2VmZArS+Y6r3bbt GQfbd0966S5uoIZ7ezaRVmlDui92C7c4+m4ce9c/8Ybp4rPRrJXAileWVkwPmZAoBz14Dt+dYdJ/ n/P+f/r+UUUf5/z/AJ/+uUUf5/z/AJ/+uVyXxG+zf8IlJ5/+s85Ps/X7/fp/s7+vH44riPisbP8A 4QeT7T/rvPj+zcn/AFmeen+xv68fjjL4s7+Pxrx2vBqnooooooooooooq3pUEdzrFlBMu6KW4jR1 zjILAEcVPZxrLfW8bjKPIqsPUE0jnCMR1Ar3E9+n516Ce9UqD36fnQe9FB79PzoPeirth1l/D+tW rTq/4f1qSLvV3/P+f8//AF7P+f8AP+f/AK764b4p/wDIsW3/AF+L/wCgPXO+M/8AkDw/9fA/9Ban x/e/CvIq4apKKKKKKKVVZ2CqCzE4AAySaUAswVQSScADvQBk4Fdn4a+HOqa06SXKNbW55wR87DHp 2/Gus8PeAdT1l1edGtoDzyPmP4dvxrf0fwjqOrOpKGCIj7zD5vwH+Ne4+FvANnpMCpDbqMfeYgZP 1PftXtPhjwHaaXCqRwKMfeYgZP1PftXrHhvwNb6fGoEQJ/iZgMmu+tNLit1Bx0rvbTS4rdQcdK7u 00uK3UHHSp5pUhXrjHYVPNKkK9cY7Cp5pUhXrjHYVymu+JbWwt3eWdEAHBZsCuU13xLa2Fu7yzog A4LNgVymu+JbWwt3eWdEAHBZsCuPWO51idbm/XZakBkgfhmOf4x2GMcc9ecYIPnN5qFxrE3mTArb EZWNuGbn+Idhjt7847+LeI/GE2sO0cG5YD/E3BP4VqA9Of1+nvTBXL0A9Of1+nvQKKAenP6/T3oF FAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUU5UY49PX8qUKTilANPWPgZyT9f8/wCf 1cE9c0oFPAA6Dv8A5/z/AJLgPalo/Pr/AJ/z/klFH59f8/5/ySij8+v+f8/5JRR+fX/P+f8AJKKQ sFAz6+v+f8/qEgdaTOKiLlvp9ajLZ+lJnNNB6c/r9PekFJQD05/X6e9AooB6c/r9PegUUA9Of1+n vQKKAenP6/T3oFFIXVcZP6/T3pCwXqaM4qBpC+ORj0qIuWxyMU3OaaD05FNB6cikoB6cigHpyKKA enIoB6ciigHpyKAenIopskscMTSyyIkaKWZ3OAoHUk5pGdY0Lu6qijLMxwAPelrzzxP8S0tmez0L bLKpKPdOMoOOqc/Mc9zxx0YHNctrHi9Yi0Gm4dwSrTMMqOP4eeee54475pyp615hcXM93O09zPJN M2N0krlmOBgZJ9q46WaSeQyTSPJIerOxJP4mn1FTKKKKKKKKKKKKKKKKKckbyttjRnY9lGTTkjeV wkaM7HoqjJprukYBdlUE4yTitaz8L6te4MdtsUjIZzj/AOvW1YeEda1HaYrMqrDIaQ4H+NQteRBs KGf3UcD866Sx+Gd5Ng3MxUdwgAx+Jrq9N+Eeo3GDdTFBjlUABH4n/Co/tFw+NsSJ65Of8K67Tvhr p8IDPArtwfmGcfnmu60n4Q6ZCA0sAkY4yHG4D880nkSyf6yVjkYI6DH0rqrPwpbQAbYlz712un+B rO2A2QJn3qRLNF6KK2YdJijABUYFdDb6FBEACgwO1TrCo7Vm3XiHTrRhFZIb2Yf88m+QdOrfj2z0 xxWPfeK9IsGEOnRnUrgY/wBS37sdOr8joe2eRg4qJ7mJOIx5je3T86zhLrOoMpmuTAu4MEtxsAwM dR8x69CayVn8Q6qyNcXptULBlitR5YGBjqDuPXOCTz+FRbp5CNz7R6LxV6y0WOJVCpjFaWneHYoF UJHjBxUkcAA4FbMFkqAccV0VtpqRgZAxU6xgVbVFUcCryRqg4FPAxTqf0pajeZUqGW4SPv7/AIUh YCqNxfqvfFZt3qiJn5sccc1G0gFeb/FTUftPhpIo2jI+0oX37ScAN93POc46c4z2zXknxn1f7X4S SCJ4mBu0L79hOAG+7nnOSPu84z2zliShpNue1eN14JUtFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFWbDTrzVLpbaxtpLiY/woucDIGT6DJHJ4qa2tZ7yYRW8TyueyjOOcZPoOetBIHWvQtB +F33J9cuPRvs0B+hwz/mCF+oauo03wb92TUZfQ+TGfp1b8xgfnTC/pXodhp9npdqttY20dvCMHbG MZOAMn1OAOTk/wBeptrWCzhEVvEkSDso9gM+5phOetWf8/5/z/8AXmoo/wA/5/z/APXKKP8AP+f8 /wD1yij/AD/n/P8A9coo/wA/5/z/APXKKP8AP+f8/wD1yijP+f8AP+f6pmik6/5/z/n9T/P+f8// AFyj/P8An/P/ANdP8/5/z/8AXSj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/ z/8AXP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKq3+o2emWpub65j ghH8TtjJwTgepwDwMk+/eK5uoLOEy3EqRoO7HrxnA9T7f5KgZ6V59rvxQ+/BokHqPtM4+oyqfkQW +hWuX1Lxj96PTovUedIPryF/I8/lTwnrXnt/qN5ql01zfXMk8x/ids4GScD0GSeBxXL3N1PeTGW4 leVz3Y5xznA9Bz0p4AHSq1Q0UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUAEnAGTRQSAMk4Ar2f4c6DHaWEcsgJll+Z89jjpjPavWvh9okdvaJM4Jkk+Zs9uPS u/8ABGlRiMXD5LSdc9h9K9Wt9sUa7eABXqdvtijXbwAK9Nt9sUa7eABXD+PbjzdW0bDEFFnIIPI5 jrlPFdwZdc0faxDIsxBBwQcx8/5//X5X8ZZ/On0MZ+79o5/791Ysd1zECWwc4zj9a6vTd15CpZsN nGQP1+v+fr55H84q41hMBldrc9jz9ea0G0u4C5Ta4z0Bwfrz/n+snlt25qOS3kiiLvhcdBnNQy2k sELSSgIR0Gc88c/5/wD1tKlRk8V5b8SbqWWK3jaQ+WJT8gPGQOuM9eTz714v8WL2edbWFpT5QlJE YY7cgdcZ68nn3qO3djeEZ42Hj8RXnleYVdooooooooooooq/of8AyMGm/wDX1F/6GKs6f/yE7X/r sn8xTX/1bfQ17ae/T867896p0Hv0/Og96KD36fnQe9FXbDrL+H9atWnV/wAP61JF3q7/AJ/z/n/6 9n/P+f8AP/131538WLuRLDTbMBfLlleVj3ygAGPb5z+n48t42mZba0gAG13Zye+VAA/9CP8Anq+P qTXltcbUlPiiknlWKKNpJGOFRBkk+wp0cbzSLHEjO7HCqoySfYUqqzuERSzMcAAZJNdl4d+GOu62 UkliNpAe8g+cj6dvx/Kut0H4c63rRV3hNtCe8g+Y/h2/Gui0fwVq+rlWEJhiP8UnX8v8cV7D4U+E lhpKrIyGWfvLIAT24+nFes+F/hRZaaFkdTLN/wA9JACe1ek+HvhjbWm2WYGSUfxOBweK9KsfD8Ns i4QCvSLHw/DbIuEAr0Ox8Pw2yLhAK0xHFbjsDWmI4rcdga0xHFbjsDWffamkALbh9M1n32ppAC24 fTNZ99qaQAtuH0zXC634pkL/AGWziNxcsCVjU4zjuSeAOnJ7kDvXA+IfF/kjyIF86ds7YwcZx6ns Pf3HrXnfirxzDpsBXcHkOQqA8k1kWemsLlb6+mae828ZbKRE9dg+hxnr9MkHjCJrm5F1eTNLPjhd 2Uj9do/HGf5ZIrx7VtZvNZufNupWIByqbsha0QenP6/T3qQVn0A9Of1+nvQKKAenP6/T3oFFAPTn 9fp70CigHpz+v096BRSjJIA5/wAj3oHOKKcI24zxTghpcGpAgGOD+f8An/P6uCgY4NLil/Pr/n/P +StLR+fX/P8An/JKKPz6/wCf8/5JRR+fX/P+f8koo/Pr/n/P+SUUfn1/z/n/ACSimNIBwOufX/Pr /nu0uBwOtITUe4k5J/X6e9MznqabSA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD0 5/X6e9AoqNph0U/jn6UwyDoD+NIW9KhySQS1R5zjmkoB6cikB6cikoB6cigHpyKKAenIoB6ciigH pyKAenIorM1rxBp3h+1WfULjZvyI41G55CBnAH9TwMjJGaqahqlrpcKy3Uu3dnaoGWYgZwB/XpyK UAnpXj/ibxvqXiPMH/HrYHb/AKMjZ3Ed2bAJ57dOBxkZrhNX8RXeq5j/ANTbcfulOckdye/P4dPr UgUD61zNY9LRRRRRRRRRQBk4HWikJCgkkADkk9q0LTQ9SvGAitJMEgbmG0frWlZeH9Vv2AgspcEg bmXaOfr/AEqJruFTgPuOM/KM5/GuisPh3qNyR50gTnoozkfWuo034XaveEec6xDI4Vc5H14qI3Ur 5EcWPQsf6f8A166vTfhjaJ5bTIZGHUsc5/DpXbaR8HbRfKa4Uyt3LHIP4dKTFxJ96TaD2Xj9etdb p/g2ytlQJbqAOgx0rudK+Hun2aII7VAB0GBgUqWSg5IyTySa3oNDhhAAUD6V09r4at7cAKiqB6VY W3Ve1Xks4k7D8q049Pgj6KD+FSBAKkYxW8TyOyxxoCzMxwFA6kmpnMFrC80jJFFGpd3dsKoHJJJ6 D3pThQSSABySa5+/8WxKWh0uE3UvI808RKeR9W5A6cEHg1yeqePIVZ7fRbc303K+e2VhQ/MM+r4I B4wCDw1VpL0crCu8+vYf41jvaX+sSLLqM7SANuSMcInXGF6ZwxGTk46msCSw1TxBMs+r3LyqH3JC Pljj+9jCDjIDEZOTjgk1AUknIaVieeB2H4VsWejJEF2oBiug07w9HCq7YgMfjU8cAHQVsQ2SqBwM da6C301EAyBjOc1OsYFWlQL0FXljVOg5p+MU6ndKKiadFHWoHuo0HUZpCwFUp79VH3qzrrVEQH5s cZGeKjaQCsLUNehgDFpAPqa5nVvFEFsrM0oHsWz/AFqvLcqveuD13x9FCWjhcySdMKc/1rzHxJ8T o4y8Vs5lk5HynOOvU54quGnuf9Uvy/3m4Fee6rrd3q8gM7kRg5CA8Z9T6mvMdY1++1uQG5kPlg5E YJxn1Pqef85NXLe3EIJLbnPVsVnVl1NRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRVmw0681S6 W2sbaS4mP8KLnAyBk+gyRyeKmtrWe8mEVvE8rnsozjnGT6DnrQSB1r0LQfhd9yfXLj0b7NAfocM/ 5ghfqGrqNN8G/dk1GX0Pkxn6dW/MYH50wv6V6HYafZ6XarbWNtHbwjB2xjGTgDJ9TgDk5P8AXqba 1gs4RFbxJEg7KPYDPuaYTnrVn/P+f8//AF5qKP8AP+f8/wD1yij/AD/n/P8A9coo/wA/5/z/APXK KP8AP+f8/wD1yij/AD/n/P8A9cooz0/z/n/P4pRSZ/z/AJ/z/Uz/AJ/z/n+pR/n/AD/n/wCun+f8 /wCf/rpR/n/P+f8A65/n/P8An/65R/n/AD/n/wCuf5/z/n/65R/n/P8An/65/n/P+f8A65R/n/P+ f/rn+f8AP+f/AK5R/n/P+f8A65/n/P8An/65VW/1Gz0y1NzfXMcEI/idsZOCcD1OAeBkn37xXN1B ZwmW4lSNB3Y9eM4Hqfb/ACVAz0rz7Xfih9+DRIPUfaZx9RlU/Igt9CtcvqXjH70enReo86QfXkL+ R5/KnhPWvPb/AFG81S6a5vrmSeY/xO2cDJOB6DJPA4rl7m6nvJjLcSvK57sc45zgeg56U8ADpVao aKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKt6XB9 p1S1hyAGkXJPpnmrFhCLjULeEkAPIASfTNPijEsyRMcB2Ck/WvpDw7Z+XbocY46V9B+HbPy7dDjH HSvZ/Dtn5duhxjjpWxezmGMmti9nMMZNbF7OYYya848QXf2rXLJd2diSd/UpXC3139q8RWi7s7I5 Op9SleN/Ei7+1X2nLuzsEvf12V0WlcxD/eNei6HzCOc/Off/ABrl4en410Cfd611UR+Xr/nP+f8A PWwOlUtQ/wBQf61naqf9FbnHHc//AF6ZL92vG/iIeIOf+Wp/lXgHxTPz2/P/AC1b+VVrb/j9P+4f 5iuCrzer1FFFFFFFFFFFFX9D/wCRg03/AK+ov/QxVnT/APkJ2v8A12T+Ypr/AOrb6GvbT36fnXfn vVOg9+n50HvRQe/T86D3oq9YKdsjcYJx/n8/897doOHbsTj/AD+dSRjgmrn+f8/5/wDr2P8AP+f8 /wD131w3xC0DUden0mLT4PMKebvYsAFzsxn8jWF4i0S/1qayjsYPMK79xyAFztxn8jV/TNMvNTka O0hMjDGcEDGab4d+C13cur6rLgZB8uE9fYkitPQPg9eXTq+pybVyD5cR6+xJFdtovww1C8kDXziN Mj5IuSfqSK9c8O/DPSdHANvZRxtjBbALEe56mvV/D3w20vScNDZoj4wWIyxHuepr0zQvh1p2mkMl socDlm5Pr1rtbXSIIAMIBjiu0tdIggAwgGOK7G10iCADCAY4q+qJGO3Her6okY7cd6vqiRjtx3qt c38cKEllX6mq1zfxwoSWVfqarXN/HChJZV+prkNc8Y2tjGxMoGB1JrkNc8Y2tjGxMoGB1JrkNc8Y 2tjGxMoGB1Jrkbq51bW5CWkaztWIIzzIw4PTtwT15B7VwGp+INR1aRhG7W8BPBP3iOO3br3/ACry XxF8Q7m/keOyLCPPDn/CpLHT7ewVvJBLvgySO2WcgAcnP6Djk8c1mQwJCWYFmd8b3Y5ZunX/AA6c 1xM9xLcymWaRnc9Sxq0D05/X6e9SioqAenP6/T3oFFAPTn9fp70CigHpz+v096BRTlVmxjp/+r3p QCcYpQCaesfrk/5/z/nq4J60oFPAAAAH+f8AP+fVwGOgpaPz6/5/z/klFH59f8/5/wAkoo/Pr/n/ AD/klFH59f8AP+f8koo/Pr/n/P8AklFH59f8/wCf8kooJAAJ9fX/AD/n9QkDr60VE0m7ocD6/wCf WmF89OlNJpgPTn9fp700UlAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUhcKMk/r9P ekLADk/54ozioWlLYGcD/wDVURct34ppOaYD05FNB6cikoB6cigHpyKKAenIoB6ciigHpyKAenIo oB6cigHpyKK4bxL8SLPTM22k+Xe3Y2nzc7oVB5PIPzH6cc9cgiuc1fxZBZ5hsdlxOMfP1jH4g8n6 evXjFPVSeteTXl5c6heS3d3M008rbndup/8Ardsdq4i4uJbqd555DJK5yzHvTwMCoKjooooqzbad eXhH2e2kkB6ELx+fSrVrpt7ekC2tZZAehC8fn0qKS4iiOGcZzjA5Nb1j4F1a7KlwsSsM+pH+frXS ad8OtbvihZFiVhn+8R/T9ajN5n/VxM3PfgYrqdP+F8eQbl5JOOhOB+ldlpfwcUkG8kkkOORnA/Tn 9aYGunxllTHXavX88112m+BLG1zstowTjOFAzXdaT8M9OtAdtrGCcZwoGf8AGgWhfHmMz46bjmuj ttAghA2xgA11tn4Vt7dRsiVQR6VOlsq9BWlHp8KAcVsRaVBGBlR+VSiNRVhYkUYC1bWCNBgLxTsA U+pOlLUc88NtCZbiWOKMYBeRgoGTgcn3IFRXN1b2cDT3U8UEKkBpJXCqMnAyTxySB+NIzKi7mYKP UnFc/deLoGRV0uF7p3HDupRF69cjJ7cY79a5S+8e2zxqmi28l7I44lkVoo04PXcAxIOOMDg9c1We 9UjEKlye54ArLktL7WJRJqEzSKrbliHCJ16D15IycnHesSaw1PX51l1a4aVFbcsA+WKPrjCjqRuI ycnHGT3hKSTnMrZAPA7Cta00hIxxGAa3rDQUiHyxAEd6mSEDtWvDZog6da3oNPjQfd4P+f8AP+cz qgFWVULjAq6qKoGB0p+KUkDqcUpIHUgUVG86KOoqGS6jQdR+dIWAqhNqCqOXH51l3OrIinLgY9+l RNKB3rBvvEMMCnMi8ds1y+peLLe2RszLkds1XkuVUda4bXPH0MJaOFi78jCnP9eK818R/E2KIvDa sZH5GFPTr1OeKgDTXP8Aql+X+8eBXA6l4gv9SY+ZKUQ/wqT+przXVfEmo6s7GaZljP8AApP6+vWr EdjGp3SnzW/2un5VlVkVaoooooooooooooooooooooooooooooooooooooooooor6OsNPs9LtVtr G2jt4Rg7YxjJwBk+pwBycn+vq9tawWcIit4kiQdlHsBn3NQk561Z/wA/5/z/APXmoo/z/n/P/wBc oo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBcoo/z/n/P/wBcooz0/wA/5/z+KUUmf8/5/wA/1M/5 /wA/5/qUf5/z/n/66f5/z/n/AOulH+f8/wCf/rn+f8/5/wDrlH+f8/5/+uf5/wA/5/8ArlH+f8/5 /wDrn+f8/wCf/rlH+f8AP+f/AK5/n/P+f/rlH+f8/wCf/rn+f8/5/wDrlVb/AFGz0y1NzfXMcEI/ idsZOCcD1OAeBkn37xXN1BZwmW4lSNB3Y9eM4Hqfb/JUDPSvPtd+KH34NEg9R9pnH1GVT8iC30K1 y+peMfvR6dF6jzpB9eQv5Hn8qeE9a89v9RvNUumub65knmP8TtnAyTgegyTwOK5e5up7yYy3Eryu e7HOOc4HoOelPAA6VWqGiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiitHQG2a9ZNxxKDyMirujts1i0bjiUHkZFS2rbLyBuOJVPIyOor6c0FQ9u Dnr6V9IaCoe3Bz19K930FQ9uDnr6Vo39gZoWAHbjitG/sDNCwA7ccVo39gZoWAHbjivK9e02ax1i O7k3eVgqSRkLkjnPpxXmt/Zvpmvx3c5YQEbCxGQhJHJPYds14t490G7S5S7UOyR5BXGcZxz+ldLp X+q/4Ea9L0P/AFHr85/z3rkYfu/jW+n3etdTEfl6/wCc/wCf89bA6VS1D/UH+tZ2qn/RW5xx3P8A 9emS/drxv4idIP8Arqf5V4B8U+Wt+c/vW/lVa2/4/T/uH+Yrgq83q9RRRRRRRRRRRRV/Q/8AkYNN /wCvqL/0MVZ0/wD5Cdr/ANdk/mKa/wDq2+hr209+n513571ToPfp+dB70UHv0/Og96K0LH/Ut/vn /P8An/8AXdtf9Uf941LH90/WrX+f8/5/+vN/n/P+f/rurqvBVjFeSXjSLny9mPx3f4V6B8MbGK8k 1NpFz5flY/Hf/hXsHwKsYryTXWkXPl/Z8fj5n+FdzHbRRD5UA+lenR20UQ+VAPpXt8dtFEPlQD6V ISqjkgCpCVUckAVISqjkgCqc+oxxDgjP1qnPqMcQ4Iz9apz6jHEOCM/WuY1jxfa2MbNJKFVRkkkc fjXMax4vtbGNmklCqoySSOPxrmNY8X2tjGzSShVUZJJHH41xt7rWrazI8dtC1vGG2tLOCuOnRerc H6dea4HVfFt9qTvHaoyLnBklyAOnIHU9fp715d4h+JRn3xWeXPTdn5R7+9VrXQrWKVLi5JvLoEES TchT8p+Veg5GQeSM9awBZq8qz3Lm4mGCGk6KeDwOg5GQeT7157e39zqMvmXUpc9h2H4VqA9Of1+n vVkVWoB6c/r9PegUUA9Of1+nvQKKUZJAHP8Ake9A5xRTljY4zxTghOKUA1IEAxwfz/z/AJ/VwUDH BpcUv59f8/5/yVpaPz6/5/z/AJJRR+fX/P8An/JKKPz6/wCf8/5JRR+fX/P+f8koo/Pr/n/P+SUU fn1/z/n/ACSij8+v+f8AP+SUU1nA4HJ+v+fX/PdCwH1+tITURYsck/r9Peo85Oc03NID05/X6e9A ooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CimNKF4Byfr9KYZAOAcmkzUO4sQS2aj3 EkEmkzSA9ORSA9ORSUA9ORQD05FFAPTkUA9ORRQD05FAPTkUVT1LVrHR7P7XqFykEIIXcQSST2AG ST9O3NQXd7b2EHn3Uyxx5Ayecn0wOTSgE9K8k8T/ABBvtaV7SyDWdgylHXILygn+I9uB0HqQSQa4 fWPFFzqCtBbgwWxBVhn5nGe57cdh6nk09Vx161yMNvNcEiGGSQjqEUn+VYsNtPcsVghklI6hFLfy oaRExvdVz0ycVtWfhDV7xgPIEYzyWOePoK3bDwRrl+4AtfLXPVjnj6CoDepnCK78cEDArptO+GUk mGupnPOcKAvFdfpXwguJsNeTv1ztUBeKYZriQfKojH5muu0z4d2FqVZYFLdQx5I/E13Oj/CjTbRk cW6luoZuSPxJ/wA/zPs8kmfMkZgeozx+VdRZ+GbaEDESjnnIrtNP8GWluoCwKOecgVLHaKvatWLT IowMjvW5BosEQGR0OamWICrSW8adBV2O1ij6KD3p4UCpQMCpwABgUtFFFFFFRzzw20JluJY4oxgF 5GCgZOByfcgVFc3VvZwNPdTxQQqQGklcKoycDJPHJIH40jMqLuZgo9ScVzV34tMpEek2xlzj9/Op Vex4XgnqRzjB9a46/wDHrTsItBtDPkj/AEm5Uqn8J+VOGbgsOduCAeRVV73dxCuf9pun5VmLpd3q U6z6hPJcSL0Mh4XgA4UcDoM4FYqaJfaxcpc6rcy3cy9DKRtTIAO1R8q52jOAOf1hELysGkYsfftW 9aaTHGB8tdPYaDFEB8vbNWEhA7VqxWix9ucVuwWCRYOOcVMEAqwFA6CrQRVxgdKfigkDrSkgdTRU T3Cr0PNQSXSIODz0ppYCqM+oqg5Yf4Vl3Oroi8uMD36VG0oHeue1HxFDbqSZB+dcpq3i23tEJMy8 Z6Gq0t0qjrXn+ueP1BaO3YysMj5en515b4i+JwZmitGMrDIyvA/OolWe5wVG1P7zf09a4e+1y/v2 bzZ2Ck/dXgf4155qGvajqTMZ7htrHOxTgf41YjsYlwXHmN6t0/Ks6s2rNFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFfS/+f8AP+f/AK/rtQ0f5/z/AJ/+uUUf5/z/AJ/+uUUf5/z/ AJ/+uUUf5/z/AJ/+uUUZ6f5/z/n8UopM/wCf8/5/qZ/z/n/P9Sj/AD/n/P8A9dP8/wCf8/8A10o/ z/n/AD/9c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyj/P8An/P/ANc/z/n/AD/9co/z/n/P/wBc /wA/5/z/APXKP8/5/wA//XP8/wCf8/8A1yqt/qNnplqbm+uY4IR/E7YycE4HqcA8DJPv3iubqCzh MtxKkaDux68ZwPU+3+SoGelefa78UPvwaJB6j7TOPqMqn5EFvoVrl9S8Y/ej06L1HnSD68hfyPP5 U8J6157f6jeapdNc31zJPMf4nbOBknA9BkngcVy9zdT3kxluJXlc92Occ5wPQc9KeAB0qtUNFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFS207W1zHMucowbAOM+1SQymCdJV6qwPXGaVWKsGHUV9G+BNci1CyicvnIAIJzivfvAmtxX9nG5 fkgBgTkg17B4F1qO+tIyzHd0YMeQRXp1vEk6djXp1vEk6djXp1vEk6djVS/8NQ3kbBowc5zkVUv/ AA1DeRsGjBznORVS/wDDUN5GwaMHOc5Fc1J4QubVlNo2xFOfL25U8Yx7fhj/ABxY9D1PSygsZcQo c+S6BkPGAPUAdeCOn1zwWr/Cm0unMkMRgbPJh4z+HSoRHqMDBZrPcoX5njbktx0U9uvf86vQa7fQ EJeaYxVU+aS3kBJfI6IcYB5/iOOOuc1x178MdXt2P2d0lUE53/KR6euazLq7nkLxPpt9D8ud7xhl J9PlYnP4f/Xo3XieK4MkEmmalagKWEksQZWORx8jMc8+mOOvrgXXg7xBASrabKfdcEfzry7xzp99 fiIW1ncyFZCT+6YYGPevHviJFPqbQ/Y7a5l2yMT+5cYGPcVkjQ9VtbovNp9wq7SM+WTzkelcZ/wj usf9A25/74NcJ/Ymqf8AQPuf+/Zqb7Fef8+dz/35b/CpE8L65J93TJ/xGKkTw9q8n3dOn/FcVImm X8n3bOf8YyKsx+CPEkhwmlSE/wC+o/rVmPwf4gkOE02Qn/eUf1qzH4d1eQ4SxkJ/Af1rRtvhf4ru QD9gWPPZ5R/TNX7f4ceJ7gDGnhP9+Rf6E1cg8E+IZz8unso9Wdf8a6Cx+CGuXBUzTpGvcBcn+db1 l8GdduCplkjjB6gDJrXtPhbr9yAXEUWffdXR2fwQ/soHU57uVzaAzhcYGV+YfyrbX4LvplnPqU93 IxtI2nC7cAlRu/pWhf8AwmubDQtQv57on7NbSTbQuAdqE/0qwe/T86wz3ryqg9+n50HvRQe/T86D 3orQsf8AUt/vn/P+f/13bX/VH/eNSx/dP1q1/n/P+f8A683+f8/5/wDrursPAkyRDUC7Yz5f/s1e jfCuZIhq5dsZ8n/2evZ/gJMkQ8Ql2xn7N/7VrevfEFvag5ZRj1Ndne+ILe1ByyjHqa9TvfEFvag5 ZRj1NclqPjsGQwWoaeTIG2JS+3JwM4+6D6nA61x2rfEGGJzFC/myZHyxjcRnpnHQe5461xOu/Euy sMobhC/ZV+Y/kP61hT3eu6i37y6SziO04X945HcHsp7Z+Yf15K98SazfsQsy20Zwf77kdx6A/wDf X+PnGr/EzVL1mWzHkof4n5P5dB+tNt9OtoWSRgZp1O4TzHe+SACQf4c+i4HJ45rLEQZ1klZppQdw klO5gSACR6Z9Bgc9K426vbq+k8y7uZJ3znLtnB9h0H4VbB6c/r9PepBUFAPTn9fp70CigHpz+v09 6BRTlVmxjOPX8qUAnFKBmnrH0yT+H+f8/wA3BPXNKBTwAAAB/n/P+fVwGOgpaPz6/wCf8/5JRR+f X/P+f8koo/Pr/n/P+SUUfn1/z/n/ACSij8+v+f8AP+SUUfn1/wA/5/ySij8+v+f8/wCSUUfn1/z/ AJ/ySisS98WaTZ3cdlFP9tv5JDGlpaESSbgcMDzhcZJO4jgH0NZ1zrljBOtukn2i6ZyiwQEO+QcH POFx7kdD6UVft57mZfMnjWFWAxDnc6nJ+8wODkFeB0OfmYEGrMUk0g3SKsYI4jzll5PU5x0I4HQ5 5NNJ9KkB6c/r9PenikoB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CijcAMk/r9PekyA OT+tGahaUtgA4GP8KjMmeAcCmk1GD05FMB6cikoB6cigHpyKKAenIoB6ciigHpyKAenIooB6cigH pyKKxNZ157KMw6fB9rvGU7eR5cZ6fOc59eBk8ds5qG4N6UCWNqZ5mU7SThFP+0c5/LP4dajaeNDg kkjsozXDz+Dta8R6i1/q9wTI4wEjGFjHZVz2H9c8nrTh+G2ta3d/atTmKswxtTgJ6AE9vw7/AJtF xMwxHEF56sc8Vu6b8NLGIKZIfMbGCX+bP4dK6zSfhBp8WxpoTKwGCXO7PuR0o8ueQgtKw9lOBXWW XhG0gUBIFUDpxXcab4CsLVAIrVVA4Ax0A/z/AJ7ujskUcKK24NHiiXGAB9K6S28PwQrt2gD0AqdY AKupaRJ0UVox2MEfRAakCAdqlCKvQVOsar0GKdjFOp1FFFFFFFFFFVrzULTT4DNd3EcSdix5JxnA HUnAPA5qnqGq2GlWxuL67igi5wXbljgnCjqTgHgcmmvIka7nYKPeufn8WTTu0enWJK9Fmn4B5/uj nGMY5B56evKXPju4uZXi0jTGZOi3FycAncckIOSCMYJIPPTjBqtesxIij47M3+FUBp95qM6zX0zz ODkBzwvA6AcDoOlZa6Vf6vcpcancS3MqnIDn5V4H3VHyr0GcDn+cflPKwaRix9+1bVppMcYGF461 0djoUUQGE4xmrCQgdq1YrVUA45xW5BYpGBkcgVMEAqwAB0q2FCjA4FOoJAHJoLBRknFFRSXCqODz 0qvLdog4PPSmlgKzrnUVQHLDGemaybvV1jBJcYz0zUbS471z2o+JIYFOZBx71yer+L7e1RszAY9/ /r/5/nVlulUda4HWvH6jMdu3mOMj5Tx+deYeIPidu3R2jeYwyPlPH5//AK6iRZ7nBUbU/vN/T1rh tQ1m91Jj58x2E/cU8f8A16881LW7/VXJuZ2Kk52A8f8A16tQ2ccZDN87/wB5u30FUKzqsUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUV9L/5/wA/5/8Ar+u1DR/n/P8An/65 RR/n/P8An/65RRnp/n/P+fxSikz/AJ/z/n+pn/P+f8/1KP8AP+f8/wD10/z/AJ/z/wDXSj/P+f8A P/1z/P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n /P8A9co/z/n/AD/9c/z/AJ/z/wDXKiuLmC0gae5mjhhX70kjBVGTjkn6/r+bZZY4IzJLIkcY6s5A A/H/AD/ivWvPfEXxNiRDBoI8xzkNcyxkKAR/Cp5Jyf4hjjoc5rl9V8Xoq+Vpo3seszrwOOwPfnv6 d809U9a85v8AUbzVLprm+uZJ5j/E7ZwMk4HoMk8DiuUubqe8mMtxK8rnuxzjnOB6DnpTwAOlVqho oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooorqfB3ip/D97tlYm2b64U5//XXReFPEj6De/OzG3bqOcA5//XWpoOsyaLemYFjE 2Nyc/n+VfSnhfxPbahZxSQzhgRnr0r6L8L+J7bULOKSGcMCM9ele8eF/E9tqFnFJDOGBGevSu4tb qOZMhh+ddxa3UcyZDD867i1uo5kyGH51YKq3JANWCqtyQDVgqrckA1G9tE/3kB+tRvbRP95AfrUb 20T/AHkB+tQNpls3WMVA2mWzdYxUDaZbN1jFRHRbRv4KiOi2jfwVEdFtG/gpv9h2n9ym/wBh2n9y m/2Haf3KUaJZj/lmD9aUaJZj/lmD9aUaJZj/AJZg/Wnro9mDnyVP4U9dHswc+Sp/Cnro9mDnyVP4 VOllbxgBYlGPap0sreMALEox7VOllbxgBYlGPapgijooqYIo6KKmCKOiiqWtRvLoOoxxIzu9rKqq oyWJU4AHrWf4iikm8M6tDDG0kj2cyoiDJYlDgADqayfFkEtz4N1yCCJ5ZpdPuESONSzOxjYAADqS e1eGHv0/Ovms96+PKD36fnQe9FB79PzoPeitCx/1Lf75/wA/5/8A13bX/VH/AHjUsf3T9atf5/z/ AJ/+vN/n/P8An/67qPM1EDy7GeOFJP8AWu2SQMcYHfk9yOvfvcstRv7JJY7KRIxNjzGbJIAzjA79 fX/6+74f8TXnh6C8Szxm52biT0C7v/iqhXRkmIfULq4vH+RirvtjDDrhQehz0Yt/PMMkc10Q17dz XBO0lS+1Mj0APQ56HP8AjXvte1TUiftN7KynB2K21avwQw20SxQRpFGOiIAoGTk8D3NPjjSJAkaK iDoqjArOqQHpz+v096cKKAenP6/T3oFFA5x/n096B2op6xscZ4pwQnFKAaeEAxwT9T/n/P6uCget Linfn1/z/n/JWlo/Pr/n/P8AklFH59f8/wCf8koo/Pr/AJ/z/klFH59f8/5/ySij8+v+f8/5JRR+ fX/P+f8AJKKPz6/5/wA/5JRVe8v7PToVmvrqC2iZtoeeUICcE4yT6Z4/yYp7m3tYxJczxwoTgNI4 UE+nNFcFrXxc0u2jkj0i3lvJxwkso2Rcg88/McHAwQM88+vM6h46s4VdLCJ55P4XcbU6dfU4PbA7 8+pXP2knjT4hTFmu2sNMIwxjDRxMrEKyqOsh4bgkgcjIzWXA/iDxTISZza2ZGCVyiEHggd36HgnH XkZpM4r0bw94b07w1ZNbWCMS7bpJZCC8h7ZIxwM8ADH4k56zStJtNItzFbKcscu7kFm9Mn2/z15T Oa1wenP6/T3q8KSgHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKa0gXjPP1+nvTWcLx nmkJxUBcsQS3+eKiLFiMmkzmkB6cikB6cikoB6cigHpyKKAenIoB6ciigHpyKAenIopVyxAHJxU1 rbTXlzHb28Zklc4VV6n/AD60tSixnlGOUGOoPNdzovgB9iS6j8zlQfKU8L9Tnk9Pbr1o2M3HSpbf QoosfuwMV11p4Ygg24iUY9KVbcL2rQjsYowMDpWrDpkEQGF6dKkEYFWFjRei1bWKNOiinYAp1Ppa KKKKKKKKKQsB1IpC6r1YCjNRPdRIOWqB72GMZLA/Q00uBVG71u2tIjJJIqoO569M8ep9hWZf+JLO xhaWWVUQdz1PGeB3PHAFRvcIgyTgVgXHiS/vSY9PiMSdPOlGT3GVX8iCfxFcrd+L9U1JjFpUJgjP y/aJhlscjKr+RBP4rVdrqSTiMYH94/4VDb6LJc3AuLuR5pj/ABSHccZzgegyTwOBUFp4dlvLsXV/ NJPcN/HK24gZJwPQZJwBwM8U1YC7bnJZvU1v2mlpEF2qAK6mw0WOELtUKv8An/P+ebKQgY4rTjtl QD1rZis0jA9alCAVMBjpVkAAcU6gsB1NBZQDkjiioJLpUB9arTXqRgjuKaXArPuNTRActwOetZN3 rKRg5cYHPJ4xUTSgd653U/EsFsjFpVA65zXI6z4xtbONmaZQBk5z/wDX/wA/zrS3SoOorzzWvH5d njtMuem7PH/168r8QfE6SZnissuc43Z+Xv8AnUaxXFx1/dL6sOfyrir3VLy/Ymedip/gB+X8q4C+ 1a91F2a5uHYMc7Mnb+VW4bWKE5ALN/ebk1TqlU1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFfS/8An/P+f/r+u1DRnp/n/P8An8UopM/5/wA/5/qZ/wA/5/z/AFKP 8/5/z/8AXT/P+f8AP/10o/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8AXP8AP+f8/wD1yj/P+f8AP/1z /P8An/P/ANco/wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yori5gtIGnuZo4YV+9JIw VRk45J+v6/m2WWOCMySyJHGOrOQAPx/z/ivWuC1v4oWsGYtGg+0v/wA95gVjHQ8Lwx7jnHPr35nU fGMMeUsI/Ob/AJ6SAhe3bqe/p+NOEfrXnOp6zqOszibULuSdh90McKvAzhRwM4GcDmuVvL+6v5BJ dTvKw6Z6D6DoOlPAA6VRqtS0UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUV6D4VuZ7PR7Wa1naGT5uR0PzN1FdTo Go3enWsMtpO0bZJ46Hk02113UNGv2e0nKAEEr26V6LpHxJktJDDefeVd7MDxt55/SvS9B+Jkqbku lbdGu92HIC+p9uK9L8OfFtNoS9YRSDrubr7ivQNH8e2V+g8u4RjjkZ5HvXoWj+PbK/QeXcIxxyM8 j3r0zR/HtlfoPLuEY45GeR710tvrdrOOHXP1rpbfW7WccOufrXS2+t2s44dc/WraXsD9HFW0vYH6 OKtpewP0cU/7TD/fFP8AtMP98U/7TD/fFH2mL++KPtMX98UfaYv74o+0xf3xR9pi/vij7TF/fFNN 5AvVxTTeQL1cU03kC9XFQvqtrGPmkUfiKhfVbWMfNIo/EVC+q2sY+aRR+IqpJ4jsIwSZkH41Uk8R 2EYJMyD8aqSeI7CMEmZB+NUJ/G+mQnBmXPtWfceONLgzunUY5rOuvHOlWqs0lwiqoJJJ4Arym6aF 7qdrdCkLSMY0JyQuTgHn0rwi9e3kvrh7SMx2zSsYkY5Kpk4B5PIGO5r5W1GS0l1O7ksImhs3mdoI 3OSkZY7QeTyBgdT9aiPfp+dQHvVag9+n50HvRWhY/wCpb/fP+f8AP/67tr/qj/vGpY/un61a/wA/ 5/z/APXm/wA/5/z/APXdU1t1b8P8/wCf/wBc0HU/hTl71OD05/X6e9SinUA9Of1+nvQKKVQW6An/ ACPelAJ6UoqRY+mSfw/z/n+bgnrSgU8AAAAf5/z/AJ9XAY6Clo/Pr/n/AD/klFH59f8AP+f8koo/ Pr/n/P8AklFH59f8/wCf8koo/Pr/AJ/z/klFH59f8/5/ySij8+v+f8/5JRR+fX/P+f8AJKKwtb8Y 6F4fZor69X7QAW+zxAvJnGQCB93ORjcQDn61m6jr+m6WSlzcDzQCfKT5m6ZwcdM54ziivOdb+Lt/ cq0Oj2q2S7jieUiSQjIwQpG1TjOQd3Xg9zyeo+OrmYGOwgFuMn9453sRnjjoO+evX8aK4S8vtS13 UBLdTz3l3K2xASWJJJIVR2GScKOOeK5q4ubvUroPPJLcTudq55PJ6AfU9BRXo/hL4YmKaK/18IWR iVseGU4IwXYHBHU7Rx0yeq11uh+DikiXOqbSVJItuCO2CxBwfp9PpSE+lemxRxwRRxRIscaKFREG AoGAAB2FdfGixoqIoVFACqvAA44FNpwPTn9fp704UUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70Cij IAyT+v096M46n9aKhabOApwPXP0qNpM8A/jSFvSowenIqMHpyKbQD05FAPTkUUA9ORQD05FFAPTk UA9ORRQD05FAPTkUVYtrOW4wR8qY+8Rx+HrXQeHvCOp+IGV418i04JuJVO0jODt/vHg+3HJFOVC3 09a1obSKBQFBJ9T3r1nRPDenaDamC0RmLHc8shy7ntk+2cY/xOZQgAqcDArXAAGBTqKKKKKKKKKQ kDqcUhIHUgUUx5406sPzqKS6hi+84/A0hYDvVWTUokPGKpy6xChwMUwygVnXHiCKLOZFBHvWRd+K oIQczIpH+1/n/P6xNcqO4rFu/FUSsFVmZieg/nXOX/jiBHCI7OxPQZ+me/rUD3gBwDmqQ1DVL8/u h9nQ45OC3b8B3Hes0arrWqnEK/ZIzjkgM/b8B3B61H5s0nT5R+tXbLQWYq8zvKwAG6Rix/U1pab4 YdiklxJLM4AXfK5Y/mT/AJ/nJHbk4LEk+pOa6C00tIwMLjmursdESEKFTHPNWUhA7VpR2yoB61sQ 2aRgcc5zUoUCpwMCrIAAwKdSFgOppCygHJHFFQSXSoDyKqy3qRg8j6/5/wA/1aXArNudSSMN83HX rxWPe6wkQY78Dr14qJ5QO9c1qvii3tkZmmGACSSeBXHa341tLNHZpxgAknPAqrJdAHAOSeABXnus +PmlZltiZD0znAFeWa98S5rh2S0LP23E4A/xpgguZz837tcdW5P5Vxt7qV3fuWuJWYE52g8Vwl9q l5qMpe5mZ8nO3PA/CrcNrFCdwG5v7zcmqlU6mooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooor6Wz/AJ/z/n+vrmf8/wCf8/1ho/z/AJ/z/wDXT/P+f8//AF0o /wA/5/z/APXP8/5/z/8AXKP8/wCf8/8A1z/P+f8AP/1yj/P+f8//AFz/AD/n/P8A9co/z/n/AD/9 c/z/AJ/z/wDXKP8AP+f8/wD1z/P+f8//AFyori5gtIGnuZo4YV+9JIwVRk45J+v6/m2WWOCMySyJ HGOrOQAPx/z/AIr1rgtb+KFrBmLRoPtL/wDPeYFYx0PC8Me45xz69+Z1HxjDHlLCPzm/56SAhe3b qe/p+NOEfrXnOp6zqOszibULuSdh90McKvAzhRwM4GcDmuVvL+6v5BJdTvKw6Z6D6DoOlPAA6VRq tS0UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUV3nh0/wDEhteR/F/6E1b+m/8AIPi59f5msu8/4+n/AA/l WjaIG1vdySIgPzY/4V03hSMNq8j8kqgHtyT/AICq6DNxn/Z/rXe2FjZ3BWae1glkA2h3jDMB6ZP1 P517Fp2k6bfFJ7vT7S4mA2rJLCrsF9ATn1P51qW7MhDIxVvUHBrQTQ4IoUS0u7612tnclwzkj0w+ 4d/TPH53P+EH0oW8aWVxqFkUbO+K6ZyR0xiQuMc9hngc+uxaeINXswog1G5UL0DPuH65qG5fW7OV mt9azFgbUktwzD1ywYA857f/AF8y/wBD1iynd7TxE3kYGyOa0DuOOcsrKDk56L7c99WP4jeIrc5+ 0xuPdOf51zOtfEvWdACCVYrncxXIBXGPxNcT4i8ea14ZMau0N3vYrnaUxj8TVq3+LWuGTyjbwOQp OSzD0rI/4XhqX/Pin/fZrC/4XPqv/PlF/wB9mrP/AAtXW/8An0tv+/jVBN8btZY4itIlHY7zmopf jJrTf6u2hQf7xNNf4o644+WOCM+xJp9j8QfHWvNjTLEyAsVEgT92GAzgucKDjHU9x61HB8Q/GOqN iyhDAkjcE+UHGeWPH61Sl+IniJzxcxKPTy8/1rr9OsPE84dtc1uMZyFjsUHtglmH142+nPatm2u/ Ek+46lqyjPAW2Ue3OWH14x+NUpvGmvT/AHr5h9FFW00CAq63N5e3QfH+sm27foU29c98/wCK/Znk V1uL26nDY+9Jtx9CmPWs+bWtTuFKy387A+jbf1GKs3Fva29vLNHbxJJ5ZTeiAHBxxn0zj8qLhI0h kk2Lv2FdwAzg4/8ArVRuJ5JUJlkdyAQCzE4zWKe/T86yT3qnQe/T86D3ooPfp+dB70VoWP8AqW/3 z/n/AD/+u7a/6o/7xqWP7p+tWv8AP+f8/wD15v8AP+f8/wD13VPbdW/D/P8An/8AXNB1P4U5KsrG xxnipwpPtTwDT1QDHBJ/z/n/ADy4KBjqaUCnfn1/z/n/ACVpaPz6/wCf8/5JRR+fX/P+f8koo/Pr /n/P+SUUfn1/z/n/ACSij8+v+f8AP+SUUfn1/wA/5/ySij8+v+f8/wCSUVFc3VvZW7XF1PHBAn3p JXCquTgZJ46n9fzZNNFbxGWaRI416u7AAfUn6/rRXD678VtH02YwafC+pSq2HZH2Rjkg4Yg7jwOg IIPX15zUvG1hZyeXaxtduDhirbUHXODzn8BjnrRXm2tePfEOuJJDPe+RbSdYLYbFxjBBP3iDk5BJ HNcjqHibVdRV45Ljy4W6xRDaMYwRnqQeeCTRXNVkUVs6B4W1XxJceXYwYiGd1xLlYlIxwWweeRwM nn05rQ0vRb3VpdttHhBnMr5CDHbPryOPegnFe2eGfCWmeGYB9mTzLtkCTXT/AHn5zwM4UZ7D0Gc4 zXoej6HZ6PGPJXdOyhXmbq3f14HsPQZzTc5reB6c/r9PetMUlAPTn9fp70CigHpz+v096BRQD05/ X6e9AooB6c/r9PegUU1pAuMnn0z9KQuF6nmjOKgLliMt+FQlyxGTTc5pAenIpAenIpKAenIoB6ci igHpyKAenIooB6cigHpyKKFySoHJPAH5U+JHmlSKJS8jkKqqMlicYAHc0tadppxBV5+38H+Nej+F /h00UkV7rgUshJFnwwyMYLkEg9ztHtk9RUiR92/KtEAAAAYA6AV6JHGkMSRRIqRoAqqowFA6ADsK kpadRRR0opjSovVhUbTxJ1cfnSZA71A9/CneqsuqW8f8WfxppkUVQuNajjBJYKPrisy78RRRKSXV APU44/Oo2nA74rGvPFUMQbMnHeuev/HFvArbpsAcnnioHvFHeuZ1L4g2kAI89S3cKdx/KuN1f4p2 UAIW4BbPIU7j+P8An/68Xnyy48uNmB6HHH59K56TxrqOqOY9Ps5pmzgMeF/E1y03xC1bWXMWmWU0 7bsBjwvTuc4z9aayzcebIkfqCct+QrRsNF1nUGV7+5KjO7yoOB+J7/pWnpnh3X9VZJNSvGVc7vJt +B+J6nj6VH5JkxgvjHOT3+g6frXXaZ4aihAwg9/X867zRvB0FsqlYx7nOST6k+v+frZitQvaujtd LWMcKMiuvsdFSIcKMg9c1ZSECtGO3RMcVrw2kceOPfFShQKmAwKsAADAp1IWA6mms6qOSKM1Xkul UHn3qpNfIinBHrTC4FZl1qqR5zIB+NY17rccecygcev+f8/rE8wHeuY1bxXBbIzeaAAOSW4/nXGa 545tbRHbzlAUcksMfzqrLdgHC8k8Aeteeaz48knZ0tctn+Nun/168r1/4kXF20kdnuIP8bE4/wDr 0iW88/Mh8tD2PU/4Vx91e3N7IXuJmc+hPArhru+ur6UyXMzyN/tHgfSrcNvHAPkX5u7Hkmq9V6lo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooor6W/z /n/P/wBf1v8Az/n/AD/9eCj/AD/n/P8A9c/z/n/P/wBco/z/AJ/z/wDXP8/5/wA//XKP8/5/z/8A XP8AP+f8/wD1yj/P+f8AP/1z/P8An/P/ANcqK4uYLSBp7maOGFfvSSMFUZOOSfr+v5tlljgjMksi RxjqzkAD8f8AP+K9a4LW/ihawZi0aD7S/wDz3mBWMdDwvDHuOcc+vfmdR8Ywx5Swj85v+ekgIXt2 6nv6fjThH615zqes6jrM4m1C7knYfdDHCrwM4UcDOBnA5rlby/ur+QSXU7ysOmeg+g6DpTwAOlUa rUtFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFd54dP/ABIbXkfxf+hNW/pv/IPi59f5msu8/wCP p/w/lWrYf8ho/wDXNe/+01dV4Q/5Csh54C9/c1BH/wAfH4D+Zr0LSj+7XnvXtmhn9yvPetKHoK21 5T1610a8x+vJ6/5/z/OcdKzdS5Q9+DWPq5zG3OeD/n/P/wCuKXpXjnxA6w/9dW/lXgPxN/1tvx/y 1f8ApVa1/wCP0/7h/mKraL8Nte1ZVlnjSwgLDJuchyM4JCdcj0bbnIwa5vT/AAjqV8FeRVtYyRzL w2M4OF6/njPFX8ivQ9F+G2g6UyyzxtqE4Uc3OCgOMEhBxg56NuxgY9+q0/wjplkyvIpupMDmbBUH HOF6d++e1JmuuijjgijiiRY40UKiIMBQMAADsK3I0WNFRFCooAVV4AHHApKcD05/X6e9OFFAPTn9 fp70Ciquo/8AHhL9B39xVe8/483+g/mKZL/qjWEe/T86yT3qvQe/T86D3ooPfp+dB70VoWP+pb/f P+f8/wD67tr/AKo/7xqWP7p+tWv8/wCf8/8A15v8/wCf8/8A13VbslO1m7E4/wA/n/nvZthwx9Tj /P5/57yRjgmrX59f8/5/yZ6fR+fX/P8An/JKKPz6/wCf8/5JRR+fX/P+f8koo/Pr/n/P+SUUfn1/ z/n/ACSij8+v+f8AP+SUUfn1/wA/5/ySisTWvFuiaBHJ9uvo/OT/AJdo2DyklSwG0cjI7nA5HPPO fqGuadpit9puU8xf+WSHc+cZHHbPqeOR+JXnut/F+5lZotEslhiII866G58kcEKDgEHPUsDx7g8r qPjuZ2KadbiNMEeZNy3I6gA4GDnrntRXn2paxqWsTebqN9PcsGZlErkhCxydo6KPYYHFctd393fy b7u5lmIJI3tkLnrgdB+FFUqr0UUUV6P4S+GUt3i88QJJBD8pjtlYB5Oh+fuowcY4br0xz1uh+D3n /f6orxR8FIQQGbofm9B2x1+ndCfSvV7W2t7O3S3tYYoIU+7HEoVRk5OAOOp/Wu2hhit4lihjSONe iIAAPwFNqUHpz+v096eKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRRn3/X6e9Gfeiomm7Kfxz9K jaTsp/GkLelRA5xzUeenNNoB6cigHpyKKAenIoB6ciigHpyKAenIooB6cigHpyKKmt7aW4ICDjux 6CtfQ/DmpeIJtllFiIZ3TyZEakAHBbnnkcDJ59OacqlulbFtaJbL8vzMRyxr1zw54UsPDcTGAtNc yKBJPIBk9MhR2XPOOfcnAqVVC/Wpiyr1YCttnRerAfjTsioHvYU75qtJqNvH1bJ+tNMiiqk2sRRg /Mox3NULjxBDED86jHc9KY04HcVk3PiWGNceaD6YNYN74xt4lwZwc9MHvUD3Sj+Kub1Dx1aW65ad R2ALVyOqfEyxtlyblc8gAtk/of8AP84DebziMFz6KMmuUvviSGb9wsjjH+7iuK1L4stI3+jJIwx/ u4pfLu5M/KqY/vN1/LNc3eeMtTuvuFYsjBxya5K+8daveZ2usIIwduSfzp62GWzJKzD0UYqhBHq2 tzbEaafPBJPyj69u9Z1vDrOvz7IzPcE8EknaPr2705ktbbqils5APzN+v0rsNE+Hudkt8TKx58te FH+P+eK7vw/8Lmcxy6iTKx58teFH17n/ADxTGmml4QbFP5//AFq9C0zw1DbxqixhVXACrxgV6no/ g+3tYlRIgirgBV4wKWO27nknrXSW2mqgwFAHauus9HSMABAB2GaspEB2rQSBEHStaK2jjH3alCgV KBgVOAAMClppYL1NNZ1XqaM1Xlu1Sqc9+kfftxzTC4FZd1qixjlxjvzWJfa2kS8yDGOef/r1C8wH euW1fxbb2qkvOi/Vsf1rite8d2tkrb7hF+rYz+Of8/zrSXWW2rlmPQDkmvPNX8dy3JZbYEjsWyB/ jXleu/Ea5vSyWudvq2cflQLSeUgyMEXuBya5K6vbi8fdPKz+gJ4FcVdXtzeyb7iZ5D2yeBVqG3ig HyLz3Y8k1BUFS0UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUV9Lf5/wA/5/8Ar+t/5/z/AJ/+vBR/n/P+f/rn+f8AP+f/AK5R/n/P+f8A65/n /P8An/65UVxcwWkDT3M0cMK/ekkYKoycck/X9fzbLLHBGZJZEjjHVnIAH4/5/wAV61wWt/FC1gzF o0H2l/8AnvMCsY6HheGPcc459e/M6j4xhjylhH5zf89JAQvbt1Pf0/GnCP1rznU9Z1HWZxNqF3JO w+6GOFXgZwo4GcDOBzXK3l/dX8gkup3lYdM9B9B0HSngAdKo1WpaKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKK7zw6f8AiQ2vI/i/9Cat/Tf+QfFz6/zNZd5/x9P+H8q1rAf8Tgtn/lmo/wDH mrrPB6/8TORsjoo5+pqCP/X59q9B0o/u15717VoZ/crz3rSh6CtteU9etdGvMfryev8An/P85x0r N1E/KefyrH1c/Kfm9enWopelYfh3a2q6gxRdyrHtbHIDFsjPp8o/KvKr9g2szjavyqCDjnknIz+A qC0wZpTgZAGD+f8AhXRg9Of1+nvUQq3QD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFF VdR/48JfoO/uKr3n/Hm/0H8xTJf9Uawj36fnWSe9V6D36fnQe9FB79PzoPeitCx/1Lf75/z/AJ// AF3bX/VH/eNSx/dP1q1/n/P+f/rzf5/z/n/67qu2f+pP+9/T/P8Anrbtv9Wf96pI/u/jVj8+v+f8 /wCTLT6Pz6/5/wA/5JRR+fX/AD/n/JKKPz6/5/z/AJJRR+fX/P8An/JKKZLLHBC80zrHFGCzu7YV QOSST2/z9Ud0jjaSRgqKCzMxwAPUn0oritb+KWhaYrJYl9SuFYrtiJVAQcHLkcg5OCoYHHvk87qP jPTbNStsWu5QxGE4UYPdj+OMZorznXfiNr+sy4iuW0+3DZSK1cqepxuf7xODg9AcZxXJ6l4s1TUH +SZrWIHKpCxB79W6ng/T2orkqw6KKKKKKK0tF0LUdfvVtdPt2clgHkIOyIHPLN2HB9zjjJ4q3p+m 3Wp3AhtYixyAzkfKnux7dDRnFe0eFvAumeGttxn7VqA3f6S427QccKuSBx35PJ5wcV6Dovhuz0jb L/rroZ/fMMYBxwBnjjv15PY4ppOa6kHpz+v0962hSUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70Cig Hpz+v096BRSFwoBJ/wA8e9IWCgZNGcVAZC2OcD0/Koi5bHPFNzmmg9ORTQenIpKAenIoB6ciigHp yKAenIooB6cigHpyKKAenIoB6ciirdvbL8r3D7V/u9z+tdt4d8DNM0d1rbmCAEMLYffkXGfmOflH T36jjg09VHVj+FWX1KGJdqAAD07V6ANTsrGBYbWKKGFc7URQqrnngDj1/OlMqgcVm3XiGONT+8A7 9ay73xZFEpBlVe/BzxUT3IA61gX/AI0trdSWmVcDPLVyuqfEWztFYvcKu0Z5b/69V3vRkAHJPQet crqPxIiTIhYyN/sf41xWq/FqNdy25Mrf7P8AjSA3Mp+WMqM9X4/+vXMX3ju/uCwhUIM8MxyfyrkN R+Iuq3bN5IEYzkMSSaetlI2DJNj1Cj+p/wAKwrnWNQuyTNdSEZzgHAFc5d61qV6xM95KwJzgNgCp ls4F5KbjjGWOf06VRJJJJOSe9UCSTknJNTABQAAABwAK0NO0W+1RwLaElD/y0bhfz7/hWlpehajq 8gW0gJU/8tG4X8+/4VHJcRxHBOW/urya7bQ/h2CUlvj5rddi8KP8f88V6F4c+Fm9km1FvObqY14U dPz/APr9KgaaWXhRsX9a9E03w3DaxKkcSoqjgAdBXquj+ELeyhRIoERVHAAxgUsdsBz3PJNb9tpq oMbBiuptNHWNcbABnirCxY7VoJAiDpWrFbRxj7tShQKlAwKnAAGBS01nVepprSKnU0ZxVaW8VcYI FUp9QRMYIH4/5/z+rC4FZN3qyRLkuB2rCv8AXo4Vy0gHY1C8wHeuT1jxjb2yEmULjuTXCa/8Qbaz QkzBSCec5J/z/n3qSXeW2oCzHoByTXn2seObm7LJa5Cnjc39BXl+u/ES91AtHakqh43N/MCnLaTT czNsX+6OT/hXKT3E1zIZJ5Gkb1Y1xs9zNdSmSeVpHPdjmrkUMcIxGgGep7n8aiqKn0UUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUV9L f5/z/n/6/rf+f8/5/wDrwVFcXMFpA09zNHDCv3pJGCqMnHJP1/X82yyxwRmSWRI4x1ZyAB+P+f8A FetcFrfxQtYMxaNB9pf/AJ7zArGOh4Xhj3HOOfXvzOo+MYY8pYR+c3/PSQEL27dT39Pxpwj9a851 PWdR1mcTahdyTsPuhjhV4GcKOBnAzgc1yt5f3V/IJLqd5WHTPQfQdB0p4AHSqNVqWiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiu88On/iQ2vI/i/8AQmrf03/kHxc+v8zWXef8fT/h /KtjT+dVb/cX+bV1/g7m/l/4D/M1DH/rvwH9a9A0s/uo+f8AOa9o0U/uIufX+daMP3RW0vKevWui XmP15PX/AD/n+c46VmaieDzWPqzfK3P5f/rqKWsTw5/yFNS/3Yu/u9eUXv8AyGrj/cTv/tNUNp/r pfov9a6MHpz+v096YKtUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CilUFunP+R70oBPTmlHNV9SQj TpSeen8xUF6pFlIT7fzFMlH7pq589+n51jnvVag9+n50HvRQe/T86D3orTtP+PZfx/n/AJ/z1v2/ +oX8f5/5/wA9Zk+4Kn/z/n/P/wBeT/P+f8//AF1q7Z/6k/739P8AP+etu2/1Z/3qkj+7+NWPz6/5 /wA/5MtPo/Pr/n/P+SUUfn1/z/n/ACSisrWPEujaDsGp38cDuRiPl3IOedq5OODzjH9aV/q+n6Zt F5dJGzdF5ZsHPOBk44PP+SV5zrXxgmlSSHRbDyc8LcXJ3MAV5+QcAgnjJYccjmuT1Dx47q8en23l 56SzHJxj+6OAc+5HtRXn+ra5qeu3An1O9luXX7oY4VeADtUcDOBnA5rl77UrzUpRJeXDysOgJ4X6 AcDoOlFZ9VaKKKKKKKlgtp7p9sELyHjO1c4+vpU1va3F2+y3hklbjIRScfX0pryJGMuwX6967nwx 8MrzUyl1q7m0s2BwiMPNfpgjggDnqeeOnINdFpXgy5uHD6ifs8PPyKwLnpj1AHP6dOc0LIHUMvQ9 MjFet6dptlpVotrYW0VvCMfLGMZOAMn1OAOTkmu4tLS3soBDbQpFGMcKMZOAMn1PvSVaB6c/r9Pe phRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFRtMOin8c/SmGQdAfxpC3pUO4kglu ajzkgk0lAPTkUgPTkUlAPTkUA9ORRQD05FAPTkUUA9ORQD05FFRyTxwIGkkVRjufpU1vbyXMiomA OAWP3V+ppGYKMkgVmXPiWztBnzVz0yTit+xv9H8Nqtw86y3ZXaXJwqeu3v7Z/lnBhe7RO9c1qHxE tIuFmDHOMJk1l6n8V7SL5Y5g5zjCAmmCWeX/AFcTkEZBxgEfU1y198Qruc4hiIX/AGm6Vxmo/E/U bo4hj2r/ALbHIpRa3Egy8ix8cAfMawLrxFql2CHuWUEEEJxnNc1eeJtXvciW8cKQQQnGc1MljEpy xd/948fpWY8jyNukdmPqxzWU8jyNud2Y+rHNToiRjCKqjrgDFNptOooorQ07Rb/VG/0aAlO8jcKP x7/hWlpegajrDYtLdimcGRuFH49/wqKS4jiOCct/dXk13mifD2FCsl3+/f0I+Ufh/jmvSfDvwviU pLe/6RJ/dI+Ufh3/ABzVcyzTdDsX0U8/nXoWn6BHCoGwAY4Ar1LSfC0VuiqIwoA4A/8A106K2Cjp W/baekYGBjiuqs9KSIDC445qykYFXUiVR0rSjgRFAx2qQACpAMCpQABgUtNLqvUimNKi9WH50mRV WW8VMYIqlPqCx4ww/D/P+f5tZ8VlXerpEuXcAD1rCv8AXo4F3SSKoBxzULzADk1yOs+MrazT5plX k45GTXB6/wDEC0sUwZ1BycDIyaqtcF22Rgs3oK871bxtdXbFbbKrn7zdT+FeWa34/vr9mW2JRMn5 m6n8Kctk8gzNIVz/AAr1H41zE08tw++aRnb1JrkZp5biQvNIzse7HNWooY4RiNAuevqfxqOo6koo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooor1fxB8TLezlktdIhW6lQ7TPIf3WePugHLDqM5A7jI69rqni+K3d4bGMTOpwZWPyf hjr39PxqMJnrXm2p6zqOszibULuSdh90McKvAzhRwM4GcDmuTvL+6v5BJdTvKw6Z6D6DoOlPAA6V RqtS0UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUVd07SNR1ebytPsp7lgyqxjQkK WOBuPRR7nA4qxaWN1fSbLW3klOQDsXIXPTJ6D8aK73RfhLcyssmtXiQxlQfJtjufkcgsRgEHHTcD z7Gum0/wPM7B9QuFjQgHy4TluR0JPAxx0zSbq2NR8NR+HraBLR2azHyqZGBYNgk59c8nj/8AXav9 GXSooxAxa3+6Cx+YHGef8/8A1868jZZPMzkMfyqjp/8AyFW5/gX+bVreDf8Aj/l+i/zNV4/9d+Fe g6X/AKmP8a9p0X/j3i/H+daMP3RWyvKevWuhXmP15PX/AD/n+c46VlaoxCMQef8APvWJrTFY3IPP 1/8Ar1FKeDWN4bP/ABM9SPqsX83ryu9/5DNwfVE/9CaobT/Wy/Rf610YPTn9fp70wVaoB6c/r9Pe gUU8IxxxinBWOKXBp6oBjOSf8/5/zy4KBjqaUCnAdOD/AJ/z/nuv4UtU9V/5BsvHp39x/n/PNa// AOPKT8P51HN/qmrnD36fnWKe9VaD36fnQe9FB79PzoPeitO0/wCPZfx/n/n/AD1v2/8AqF/H+f8A n/PWZPuCp/8AP+f8/wD15P8AP+f8/wD11q7Z/wCpP+9/T/P+etu2/wBWf96pI/u/jUssscELzTOs cUYLO7thVA5JJPb/AD9ZHdI42kkYKigszMcAD1J9KfXH638TfD+ks0UEj6hOAcC2IKA4yAXzjBz1 XdjnI7HB1HxhpdiSkbtdSgHiHBXOOMt0wc9s45/ErzrW/ibr+rK0MEq6fAWJAtiQ5GcgFyc5GOq7 c5ORzXJ6j4w1S+UxxuLWIk8Q5DEZ4y3X8sd6K4+WWSeZ5ppGklkYs7ucsxPJJJ6msF3eSRpJGZ3Y kszHJJPcmimU2inIjyOERWZj0CjJNOSN5XCRozseiqMk0jMqLuYgAdya1bLw1qt8R5dsyAjIMnH6 da2LDwprOokeVaMgIyDJ8v6df0qF7uJTgEuf9kZro9P+G13PtNxMVBHKouMH6nr+VdZpnwmv7ra1 1MUBHKouMH6nr+VMNzK/3IgvPVjniursPhxp8JDPArZ67/m/nXWw/DPRNIgFzfhFjJCkyAvk+wOf 0pojnfG+ZuPTj+VdZY6JZWJVkiUupBUntUc81sP3dlAIYRxzgs3PU+n0+vJqSO2jjwQASOlaQPTn 9fp71WFS0A9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRSFwoyT+v096QsAOT/nijOKh aUtwDgf/AKqjMhPQ4FNzmmA9ORTAenIpKAenIoB6ciigHpyKAenIooB6cigHpyKKAenIoB6ciiuO 8S/EKw0RntbMC9vkJR0BISI4H3m7nPYehBIrC1bxTa6cWhgxcXCnayg4VD7nv9B79KXaxA24Hua8 1v8Axhq+oOzSXBXPTHb6Vzd14t1W4UoswhQnO2MYxUQsQxBmldz3GcD/AD+NY01zPcEmaZ5CTn5m zWPNcz3LFpppJCTn5mJqaKCKH/VoAfXv+dRVFUlFFFFFFFFFaumeHtQ1QqYoikR/5aPwPw9a2NJ8 NalrDKYYSkR/5auMD8PWoJbqOPIHzt6D+prvNG+Htsm17lTO4PV/u/l/+uvSNA+FtsmyS7U3Dg5y 4+X8v/11AXnlJ+bYvov+Nd9YaDHGFG0AdsV6fpfheKFVUIFHbFSR2wHat6309IwMCuptNJjiAwMY /wA+v+f52FiAq8kSp0rRjgSMDHapAAKfUtLTGkVeppjzInU/lSEgVVmvVT+IDBqhcaksf8QGD2pj SAVj3msJECS44Oetc/qPiCKFWLSDg561DJOB3rjtY8aQWit+9A/H+VcBr/xEt7NXCzDJ9Dz+H+f/ AK9RrlpH2RKWY9hXn2qeM7y8JEBKD+8ev5V5frHjzUNQYiBjGP7x6/5/OpI7J3w074/2F/qf8/Wu bklkmcvK7Ox6ljk1yskskzl5XZ3PVmOTVyONIl2ooUe1MplOoooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooorpNG8C6/raRywWfk20nSe4bYuMZBA+8Qcj BAI5rW0/w3qmoqjxweXE3SSU7R0yDjqQcjkCkyK9C0j4U6PZ7m1KaTUWPAXmJAOOytnPXvjnpXVW HgqwgybuR7pjwB9xQOOwOc9e/fpSbq7i1trezt0t7WGKCFPuxxKFUZOTgDjqf1ro4YYreJYoY0jj XoiAAD8BSVKD05/X6e9PFFRzQxXMDQzKHjcYZT36e9MkjSeJo5FDIwwQfwpGUOpVhkHtXAyWD6b4 ikgY5Uxq0ZzklSzYz7/5+tTw5aNZaxPESCpCshzklcnH+f8AJzGjMV0VPTGR9Mmu00vPkx16/ouf s8Rq9D90Vsj7vrya6FfuevJ7/wCf8/rY7Vlaqf3bc/r/APXrD1s/un5/X/69QTdDWP4aBbUtRxz8 kX83ry28BOsXGOfkT69WqKz5ll+i/wBa6ZYzxn8qQIeM1bAp4UDGB/n/AD/n1cAB0FLil/Pr/n/P +SUtH59f8/5/ySij8+v+f8/5JRVPVf8AkGy8enf3H+f881r/AP48pPw/nUc3+qaucPfp+dYp71Vo Pfp+dB70UHv0/Og96K07T/j2X8f5/wCf89b9v/qF/H+f+f8APWZPuCp/8/5/z/8AXk/z/n/P/wBd a47xh4+vPC93Fp9lZwSSugnMs5JXBLLt2jHPAOc/h3rD13xPPo0yWtvbxu7KJC8hJGDkYwMenXNS R/d/GvLdV8Q6vrbE6lqM9wpYN5bNhAQMAhB8oOM9B3PrXGXuq3+okm7upZQSDtJwoIGMhRwKfWZV OitC00TUbx9sVrIBkAs42gfn1/CtKy0HVL99sFnJjIBZxtA/Pr+FQtdQqM7w3oF5robD4eajckGZ xGM8hVzx9Tj+VdRpvwv1a8I89hGM8hVzx9TjB/A1Gbtm4jiPTqxxzXU6b8MrSFg0+6Y5yPM5H5Di uz0n4P2kLh7ktMc5Hmcj8hwaaftEnV9o9FGK62w8HWlsgSOBVA7KAB+Vdxpnw/sLRAkdsqgdlAA/ KlW0BO5ss3ck1u2+hQxBcIox6V01p4ZggCkRKMdxU626jtU7R29t8q4Z/T0+tZeueItK0BWt7fbd XwUgIpBSJs4+cg9evHXjnGc07aq+5qEuWOSfwB6dPevO9S1W71a5M11KW5JSME7I844UZ46D6980 lNB6c/r9PeqQooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CimNKF4Byfr9KYZAOAcm kzUJYsQS2eKj3EkEmkzmkB6cikB6cikoB6cigHpyKKAenIoB6ciigHpyKAenIoqrfalZ6Xam5vrq KCED7ztjJxnAHUnAPAyahubuCzh865mSKMd2PXjOB6n2pRz0ryXxX8QbvWd9nppktdPZNjhgBJLn GckZwO2AeRnOc4HD614on1DdBaF4bUrtYEDc/rn0HbA989cU9Vx161xVc/TqKKKKKKKKKKKK19K8 Oajqzr5URSI/8tHGAR7etbWjeFtU1p18iAxxHnzZBgEe3r/KoZLlEJUfO3oK9A0L4f21uyPMhnmG DlxwPoP/ANZr0/w58L7W3aOS4Q3M4wcuBtB9h0/magYyz8McL/dH9a72x0OONVGwfTHFemaZ4ahh VR5YHP3ccZqSO3AxxW3b2KooHAxXS2mmJGijAAH+f8/5zYWMAVcWMJ0rQSJUHFPAxT6k6UtMaRV6 mo3mRBkmkJAqpPehAcHpVC51JUBw3TimNJisa91qKENukA79a57UvEUNuGLzAd+tQSTheprjta8b W1oCDKAT2HJ/IV5/4h+I1pZgr53zHsOT+Q/z/WsZ3lYrEpY+3avPdV8Y3t8xEJMaep5P/wBb9a8u 1nxxqOpOwiZokJ4JOT/9bv61KlluOZ33f7KnA/OudeR5W3SOzt6scmuYeR5WLSOzse7HJq0iJGMI qqCc4AxTabTqKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKsWljd6hKYrK1nuZAu4pDGXIGcZwO3I/OpYLae6cpbwyTOBkrGpY49eKK73RfhPfXKrLq90tmu 4fuIsSORnkE52qcYwRu68jtXTaf4IuZgHv51gGR+7TDMRnnnOB2x160m6vQtF8IaHoLJLZWSfaAo HnyHe+cYJBJ+UnJztwDmup07QtO0xle3t180ADzXO5umM89M5OcYpM5rcB6c/r9PetIUlAPTn9fp 70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUVwN88j+NdRDuzKnlKgJyFHlqcD8ST+PvzW0Uu3i S9ySVBQLk8D5AcD8/wBffnNlJOoS5JIGAPyFdhpf+pj6163ov/HvEcH61di+6K2R938TXQLynrye /wDn/P6z9qytVP7tuf8AP51h62f3T8/r/wDXqCboax/CbltU1QY4CQ8fjJ/n/PPlc0hfWroYwFjj 4/4E/wDn/PMVkczTfRf611X59f8AP+f8l9XaPz6/5/z/AJJRR+fX/P8An/JKKPz6/wCf8/5JRR+f X/P+f8koqnqv/INl49O/uP8AP+ea1/8A8eUn4fzqOb/VNXOHv0/OsU96q0Hv0/Og96KD36fnQe9F adp/x7L+P8/8/wCet+3/ANQv4/z/AM/56zJ9wVP/AJ/z/n/68n+f8/5/+utee+N/C95rviKCaBgs S2qoTjJzvY9PxrH1HwfqHiPUkmtiBCsQjJwSd2Sen4+tNacxYVYy5PPXAqDTvhihKm5d5MjBUnaM +vHP61taV8H1Yo128j5GCpO3n145/Wm+Zcv02oM9hzXX6b4FsbRFEdug6AkDk49T3rudI+Gmm2aK I7ZB0BO3k49T3pPsxkIMjFvqa6K18PwxgARKB9K66y8KW8SgLAij1IH+f8/nMlso7CtOLTYk6gVs Q6PBGBlR+VSiICrCQRoOBVyO1ijHC08KBT2ZY0JY4Ud6S6urfT7SS5uZVigiGWdu3+J/maXoKpTX pY7Yjgf3vWvN/EfxBnume10ctBACVNx/HIMY4B+6OTz16dOlML+lUwenP6/T3rhhTKAenP6/T3oF FAPTn9fp70CigHpz+v096BRQD05/X6e9Aoo3ADJP6/T3pMgDk/rRmoWmJwFOB/8Aq96jMhOMHApN 1Rg9ORTAenIptAPTkUA9ORRQD05FAPTkUUA9ORQD05FFAPTkUA9ORRXM+JfG+neHMwf8fV+Ap+zI cbQe7NyBx25PI4wc1kav4itdK/d/665GP3SnGAfU9uPx5H1pyqT9K8d1jXNQ128a5v7hpDuJSPJ2 Rg44UdhwPc45ya4K/wBRutSnMtzKW5JVM/KnsB26CngADis6qtLRRRRRRRRRW5pXhXUtTIbyzDEf 4nHP4D/HFdDo3g3VdXZWERghP8cg5x7D/HFV3u0XiMeYfY8fnXoOh+A7S1KuY/Nl/vPz/wDq616f 4d+GlnaMkjRedKP4pOf/ANXWoCss/wDrG4/ujgV3NloaRgDbx6dq9I07w1FCANgx/d7VPHbgdq2r eyRFHygAHpXSWumxxqPlAAPQdqnWMCriRhBwKvxxLGMAU8DFOp/SlqN5VQdaiknSMcketISBVOe/ Ve9Z9zqiLwG7fn+tMaQCsa91yKJTmQevWud1LxLBCjZlHrnPSq8lwAOtcVrXjmG2BUS8+gOSa868 Q/EqG1BSOX5umAck/wCf8+9U3EkzbYULHvjtXn2p+LL6+dhG7RqT1zzXmGreMtS1J22StEhPUH5j U0dgSd07lv8AZU4H59awWZnYs7FmPJJOSa51mZ2LOxZickk5Jq4qqi7VUKPQDFJSUtFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFdDovgnXtcZTBZNBAyhh PcgxoQRkEcZYH/ZB6j1rV0/w7qeosPLtzHGQD5s3yrgjII7n8M9RSZFegaN8KNMt0ik1a4kvJurR Rtsi5A44+Y4JJzkZ449en0/wTZxKj30rzydWRTtTp09Tg98jtxSbq7qzsbPT4jFZWsFtGW3FIYwg J4GcDvwK6W3toLVNlvDHChOSsahQTxzxSVYB6c/r9PepRRQD05/X6e9AooB6c/r9PegUUA9Of1+n vQKKAenP6/T3oFFAPTn9fp70CilUE9Mn/I96Bk9OaK4S6XPjTUgw/jj/APRSUzQUDeILwMP+WqDr /wBM1/z/AJ5zpB/p8ufUf+giuv00ARrivWNHAEKY7Zq5F0Fa4+7W8Pufiep/z/n9Z+1Y+qn5etYG tn5Op/GoJulY/hH/AJC2q/7kPH4y/wCf88+VN/yHbz/rnHx/wKSobH/XTfRf611n59f8/wCf8mar 1H59f8/5/wAkoo/Pr/n/AD/klFH59f8AP+f8koo/Pr/n/P8AklFZ2sXVvFai3knjSab/AFUbuA0m CCdozk4HPH/66epTRJbeU8iLJJ9xGYAtg5OB3xUc3+pasE9+n51kHvVWg9+n50HvRQe/T86D3orT tP8Aj2X8f5/5/wA9b9v/AKhfx/n/AJ/z1mT7gqf/AD/n/P8A9eT/AD/n/P8A9da0NPtEnjMjdmx/ KvUPhtYJc6DPK/a6ZR/3wn+NSIgYZNaSWsSdFruo7GGMcLmpAgHapQqr0FTqir0AFOxS06iiiioZ rmOHgnLf3Qawdf8AFunaApSR/Puugt4mG4HGRu/ujke/PANIWArOlneZgWI9gOnb3ryjWtfvtfu1 nvXXCDakcfCJ0zgZPXuf6AVGST1qMHpz+v096zBSUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigH pz+v096BRTWkC8ZyfTP0ppcL35+tGcVAXLEEt/nioixYjJpuc0gPTkUgPTkUlAPTkUA9ORRQD05F APTkUUA9ORQD05FFRT3MFpAZ7meKGFQN0kjhVGSBySff9aZJNHBGZJZUjjXqzsAB075pRzXl3in4 kzXQ+yaC8kEPzLJcsuHfqPl67R3zw3TpjnjdZ8WyTDyNNZ405DSkYZu3HoO+ev07vVPWvPK5anUU UUUUUqqWYKoJJOAB3pVUswVQSScADvSEgAkkADqTW7pfhHU9SYFo/IiODvcc/gP8cV0Wj+CdW1Zg xi+zwnB3yDn8B/jioGu06RgufbgfnXoegeBbSz2yeV5ko/5aPzj6en4V6j4Z+G1nZbJTCZZx/wAt ZOcfT0/D9ahIln/1h49BwK7ey0NIlA28j0r0jTvDUcKgbOR6dKmjtwB0rZhsVQDgYrobfTUjAyox njBqdYwKtoioOBV5IljAAFPAxTqf0pajeZUHUVDJcJGOoP40hYCqVxqCqPvY4+lZ11qqIv3scfT+ tRtIBWJf65HECTJkY6Zrm9T8SwwKWaXIx0z/AJ/rUElwB3riNa8d29tlVl3v/dXk/wCfrXnPiD4l 21vuWOXzH/upyf5/z/8A11hLLcNiJSw6FuwrgdU8U32oMwRzFGfQ/N/9avM9X8X6jqbsBI0UZ9D8 359qnjsVBDTNvb07D/GsNmLMWYkknJJ71z7MWYsxJJOST3q0AAAAAAOgFJSUtFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFS21tPeXCwWsEk8z52xxIWY4GeAO elPihlnlWKGN5JG6Iikk/gKK7jSPhTq95ubUp4tPQZCjiZyeMcKcY5PfPHTmujsfBN/cZN3IlqvQ DiRj07A4xz69ulJkV6LovgnQdDVDBZpPOrBhcXIEjgg5BHZSM/wgdB1rq9O8O6ZpwUx26ySAg+bL hmyDkEdh17AdqTOa6EHpz+v0961RSUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD 05/X6e9AooB6c/r9PegUU5UY49PX8qUKTilANSLGBjOSf8/5/wA8vCAY6mlApwHTg/5/z/nuv4Ut ef3f/I76p/10j/8ARSVDoH/Ix33/AF1T/wBFr/n/ADzlyf8AIQm+o/8AQRXXad/qhXq+k/6lecc/ hV2LpWsPu1uj7n4nqf8AP+f1m7Vj6qfl/rWBrh+XuevJqCbpWN4R/wCQtqo/2IP5y15S3/IcvB/0 yj/9CkqGx/1030X+tdb+fX/P+f8AJnq9R+fX/P8An/JKKPz6/wCf8/5JRWVf+IbKwlWLEtxKWwyQ ANs68sSQOoxjOeRxTGkYOiRwyylmwdgzt68kk/5zUMlzFGcZLMOy81zV3e+KdZQxRNHplu/XyAXl wVII8w8dTnIUEcc9y1fD3iTVVCl0sYX6+SpZ8YIxvP1zkLn+ZjNzI2RHFj0LH+lQWPhg6Xctqc80 093MnlPNNIzsw46kn/ZFRap4JXw/YpqcjyS3MriFpJXLMw2k8knr8ophMxGZGyCeBjpWke/T86xj 3pKD36fnQe9FB79PzoPeitO0/wCPZfx/n/n/AD1v2/8AqF/H+f8An/PWZPuCp/8AP+f8/wD15P8A P+f8/wD11ra0kEWhJBwXJHvwK9e+GEcieF5mdGVZLt2QkYDDaoyPUZBH4Gp4vufjV6u1p9FFFNLq oyWA/Go5Z4YY2kllREQbmZmAAHqaMj1qnPegjbF3/irz3xL8QhLFJZ6KWAcAG75U4PUKDyD0G764 HQ0wv6VTySck5J9/p715+8jyyNJI7PI53MzNksT1JOeaZSA9Of1+nvTRRQD05/X6e9AooB6c/r9P egUUA9Of1+nvQKKMgDJP6/T3ozjqf1oqJps4Cn8fy96jaTPCn8aQt6VED05FRg9ORTaAenIoB6ci igHpyKAenIooB6cigHpyKKAenIoB6ciisLxF4s07w3B/pEnmXbRlorZPvP0HJ6KPc+hxnGKztV1u 10mL96++YrlIV6t9fQe59+tKATXjviLxPqHiO7aS4kZLYEGK2VjsTGcHHduT83XnsOK4LVdYutWn LSuViz8kIb5Vx0+p561IBgVi1n0tFFFKqlmCqCWJwAByTSqrOwVQWYnAAGSTSEgAknAHUmuj0nwZ qOolXmX7PEf733j+Hb8fyrqdE8BarqpV5V+zQn+/94j6dvx/Kq8l2ORENx9T0H+Neh6H4Hs7II6R ZfHMj8n/AD9K9R8O/DiysQkiw7pMDMknJ/z9KhMck5BkYn0HYfhXZ2eiJGB8mSK9C0/w5HCoAjyR VhLcDtWzDZInG3ArorfTkj4KACp1jA7VZVAvQVdWNU6Dmn4xTqd0oqN5lTuDUMlwkY6g96QsBVGf UFUdQPxrMutVVRncBx61G0grCv8AXYoFJMg4HrXM6n4nhtkJaUcDpn/69V5LgKOtcLrnjyGEtGkh Z/ReTXmviP4lxQlo4ZC8nopyf51X3T3H+qQlf7x4FcHqXiW+1EkeYY4z2B5P415rq3inUdVYhpmS M9lPJ+pqaKwXhp28xvTsP8axiSSSTknvWISSck5Jq2AFAAAAHAAoopaKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK3NF8Ia3r6rJZWTfZywHnykInJwSCfvAYO duSK0dP0LUdTAe3tz5RIHmudq9cZ56474zRkV6FovwnsLZkl1e6a8baMwR/u0BxyCwO5hkjBG3py OcV1Wn+CLaJle+nNwcD92nyqDjnnOT146dKburu9O02y0q0W1sLaK3hGPljGMnAGT6nAHJyTXS2l pb2UAhtoUijGOFGMnAGT6n3pKtA9Of1+nvUwooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9 fp70CigHpz+v096BRSjJxjn/ACPegZPTminrGeMn/P8An/Pq4IeM0oFPVQMYB/P/AD/n9XhQOxpQ KX8+v+f8/wCSUtH59f8AP+f8koo/Pr/n/P8AklFcBdf8jvqn/XSP/wBFJUWgf8jFf/8AXVP/AEWv +f8APOXJ/wAhCb6j+QrrtO/1Q5/wr1fSf9QvP+FXYulao+7W4Pufiep/z/n9Zu1Y2rdB1rn9dPyj kn3z/wDXqCasfwj/AMhbVev3IO/vLXlTf8h28/65R9/eSobH/XTfRf611byJGu5zge5/zn/P424Y JbiQRwxs7HsozV0kAZJxVaS7kb5beLd/tOcAHtx36+1bVp4UvrgAyYiHp1NMMh6Iufc1Vk0y5v8A 5bqZ3QknyxwvXOCB19s5retPBEW4eaGkPox4qMxPLw7Ej07Vct9CijAwiiuhtPDEMQG2JV6c4p62 4HatCPT4UHStaHSYIxyB+VSiJRWf4iiWPTY9oGfNH8mrjfixCkXhO12qAftqZP8AwCSo7kARDHrX Mnv0/OvGz3qrQe/T86D3ooPfp+dB70Vp2n/Hsv4/z/z/AJ637f8A1C/j/P8Az/nrMn3BU/8An/P+ f/ryf5/z/n/661s2VxHFYxhm55/ma9o8DXUMPgrTw7c/vMj/ALaNUyMAgyabLqsKDgj61qz67BGD tI+p9KQzKKqf2pJcErD0z17D8awNT8aQWiHMmWzwicnH5/5/m3zS/C07ezY3Nn8fp71wGsa/fa1J /pEpEAbckIPC9vxPufU460v40gPTn9fp71liigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1 +nvQKKa0gXGTz6Z+lIXC9TzRnFQlyxGTx6ZqIuWPX8KbnNNB6cimg9ORSUA9ORQD05FFAPTkUA9O RRQD05FAPTkUU2SWOGJpZZESNFLM7nAUDqSc0jOsaF3dVRRlmY4AHvS15z4r+JIh3WWgvmZX2vdl QyYGPuZyG5yMkY44zkEcprXi0R5t9MbMithpyAV/4D1z9T+Gc5pyp615hJJJNK8srtJI7FmdjksT 1JPc1xzu0js7sWdjlmY5JPqafTaSinIjyOERWZj0CjJNOSN5XCRozseiqMk0jMqLuYgAdya6fSfB F9fENc/uUPYYLf56V12ifD7UtSZWuQYIz2GCx/oO1VXvC3EK5/2m6flXoWheCLSwCtHAGk7yPy35 /wBBXqPhv4c2WnBWS3DyDrI/Lfn/AEFN8uSY5kOe+Owrs7TSEjA+UcDIr0Kx0COJR8g4GRx0qdIA O1a0VmqdVFbsGnpH1Uf5/wA/57zBAO1WAir0FXFjVegxT8Yp1O6UVE86L3FQyXMadwaQsBVCfUVX uPzrKutWVP4h789KiaXFYWoeIIrdTlxkds1zGreKoLVTukBYds1XluQo61wWuePIo2Mcbl2/uqc4 rzLxH8S41Zo4HMh/uqc4/GoA09z/AKpfl/vHgVw2peIr/UWIaQxp/dU/1rznVfE+o6ox3zNHH/dU /wBasx2Ua8yHzG9+n5VkVjVZoooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooqW2tp7y4WC1gknmfO2OJCzHAzwBz0p8UMs8qxQxvJI3REUkn8BRXZ6N8Lta1FI5r 14tPhfnEnzSgYBB2D3IGCQRzx69Bp/g3ULtUkuGS1jbs3L4xkHb+PQkGkyK9C0j4feHdJ3H7J9tk bjfebZMDjgLgL264zyecV1Nh4W0qxyfI+0Mf4rjD4HHGOn6Z5pM11IPTn9fp71tCkoB6c/r9PegU UA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9Aopyoxx6ev5UoUnFKAaesY HXJ/z/n/AD1cE9cmlArz/wAH6z4wvPF93Za5A8dtHE7tE0IRIiWwuxgp3jhgMtgjJycc9r4k0vw1 a+G7a50mVXmeRVV1lLs/y5bcCfl6gnjgkDAzWbYz3z3zx3CkKASRtwBzxg45716H+fX/AD/n/J4y tOj8+v8An/P+SUUfn1/z/n/JKKPz6/5/z/klFH59f8/5/wAkorgLof8AFb6p/vxHk/8ATJKi0Af8 VHf/APXRD1/2FrLk/wCQhN9R/IV12nf6kc969Y0n/j3Bz3q7F92tT+H8a2x938T1/wA/5/nN2rG1 YhUBPFc5rrBIwTx171Xm4FUPCNhI8uoXkb4DyJCVx3UFs5z38z9Peue8J+E4NZutR1GfLoJFtvKy QMqN+7IPORJj8O+aZZRkmVwepC4+n/666mPTlBy+Se5PNehWuhW9vGqJGqKM4CjA/KrYiHerMdtH HjC9KvxWcMWMKOOlOCgdqlCqvQVMqKvQAU7FLTqKKKKxvEv/ACDY/wDrqP8A0Fq4H4u/8ipa/wDX 8n/ouSoLr/VD61yx79Pzrxc96q0Hv0/Og96KD36fnQe9Fa0ChYEA9M/n/wDr/wA99GIYiUD0z/n/ AD/9eZRhRUn+f8/5/wDru/z/AJ/z/wDXWuN8R+NoNH1GWxyTJHjIAPGVB/rU8vxEh0Gyj00ZaWLO QAeMnd/WoJGnLssUTMBjnoP1rS0Ox1XVV+06wklpAdpjt9w3vnBy3J2jBxjr16d3W+t6zqimW8DW 0RwUiJ+Y98nnjr06/TuqW0rOfOddvYIetdXGiRoEjVVUdAvAp5Ysckkk9STVoAAYAAHtTgenP6/T 3pBRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKM+/wCv096M+9FRNN0Cn8fyqNpOyn8aQt6VEDnH NR56c02gHpyKAenIooB6cigHpyKKAenIoB6ciigHpyKAenIorM1rxBp3h+1WfULjZvyI41G55CBn AH9TwMjJGaqahqlrpcKy3Uu3dnaoGWYgZwB/XpyKUAnpXjfiPxlqniNvLlf7PZjIFtEx2sM5Bf8A vHge3HAHNcDquv3mqna7eVAOBEhODzn5vU9Py6CpAoFc7WVS06ON5ZBHGjO56KoyT+FPjikmkEcS M7t0VRkn8KRmCjLEAeprqtI8C3t6yveN5EZ/hHLH+g/Wux0P4dahqLI96fs0R/hHLH+g/Wqz3eeI lz/tN0/KvRdE8HWlkoENuqnqWPJP1Neq+HvAFlYqvk2yA9Szck/U5qMQtKwaQlj79q6600iNAMrn vXd2OgRRquVzxn6VYSADtWvFaqgHqK34LFI1GeoFThAKnCgdBVpVVegxTsUpIAyaUkAZJwKKhkuF QdRmq8t2ka8EZzimlgKz7jUVQckYB7msq61dUXllAB7np/n/AD7xtLisDUPEMNuOZB+dcrqviy2t V+aYE5yOarSXKr3rgtc8eohaOBi7ei88+5rzHxF8TFDNFbOZG54XB59zUSrPc4KjYh/ib+lcPqGv 32oMd8hRP7qn+teean4i1DVGPmzMqf3VJqeKxjXmQ+a3+10/KsusmrVFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFamkeG9Y13cdNsJJ1XOXyFTIxxuYgZ5HGc 81dsdJv9Sz9ktnkUdW4Ve3GTxnkcUZr0XRfhLbRqkutXjTSbgfJtjtTAPILHkgjHTaRz14NdXp/g eFAr6hcGR8g+XCcL16Enk5GOmKburvdN0nTtIi8vT7KC2UqqsY0ALgdNx6seTyc9T689NaWNpYps tbeOEEAHYoBbHTJ6n8aTNXQenP6/T3qwKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9 AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70A+9FSRvnAPX6/59f893q2cA04GpPz6/ 5/z/AJLqWsq1+fxTqTqCyLa20ZYcgOGmYqffDocejKe4zoz/AC+H7FWyGa4nkAPUqVjAb6ZVhn1B 9KhTm8lI6bEGffLH+o/OtX8+v+f8/wCTnVNR+fX/AD/n/JKKPz6/5/z/AJJRR+fX/P8An/JKKPz6 /wCf8/5JRXCXo/4rLUD6tH/6LX/Gl0Qf8Tu5OeSyj/x0f41my/8AH/L9R/IV1enjEK89ea9U0sbb deevNW4/uitPt+P+f8/5Oz/CPqf8/wCf/wBc1Yms8RdhxXNeIeIOw4NV5/u1L4J/5B99/wBfh/8A RaVP8N/+QTqf/YQb/wBFRUth/qpP9/8AoK6auzq3RRRRRRTTIi9WA/GmNLGv3nUfjSZA71Xkv4UH WqsuqW8QHzZNNMiisPW79Lq1SNcZD5/Q/wCNeefE/VI73w9bRLjIu1b/AMcf/GoJ5A6gD1rDPfp+ deUnvUFB79PzoPeig9+n50HvRWvF/qU/3R/n/P8A+vRj/wBWv0H+f8//AK51+6PpT/8AP+f8/wD1 3f5/z/n/AOuVUs/D2mRazLrfkb9Qm481znYNqrhR0HA69eTzg4qO30qzS/fUfL3XUn8bHO0YAwB2 4HXryecVIp+UVsA9Of1+nvV8UUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRSFwoBJ /wA8e9IWCgZNGcVA0hbHOB6Z+lRFy2OcD0puc00HpyKaD05FJQD05FAPTkUUA9ORQD05FFAPTkUA 9ORRQD05FAPTkUVwfir4i2unxSWejyLc3hUAXC4aKPI6g5+Zhx7c8ngiub1rxXDao0Fg4luCB+9G CiZ9+5/Tn2xT1U968pvLy51C8lu7uZpp5W3O7dT/APW7Y7VxNxcS3U7zzyGSVzlmPengYFMgt5rm URwRtI57KM0tvbzXUoigieSQ9FUZprusa7nYAe9dbo3gO7uysl6fLTg7B17dT/hXaaD8N76/Ky32 YYuDsHXt1/8ArVVe6d+IVwP7zf0FehaL4RtbIL5ECKcctjk/U16l4e8CWdgFMFsinHLEAk49TTVh ZyC7Fj7muts9IjjA4ru9P0GKIKcD8qspCBWtFbLGoHpW9BZJEoHp7VMEAqcDHSrIAA4p1BIA5NBY KMk4oqGS5SNevNV5ryOJScjI6+1NLgVn3OpKi/eHB7msm81hET74GD3P+f8AP6xvKAOtc9qPiKG3 UlpFAHPJrk9X8XW9opZpVAHPJ/8Ar1VlulUcmuA1rx+MsluS7ex4ry/xB8Ti7NHaEu3qDxUSC4uc FV2If4m/pXEX2tXt+SJJSqH+FT1+vrXn2oa7f6iSJZmCH+BT1+vrVqGzjiwx+d/7zf0FZ9ZtWKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKfFFJPKkUUbSSOwVEQ ZLE8AAdzTkRpHVEUs7EBVUZJPoKK7LRfhjrepMr3oTTrdlDbpMM5BGRhAeD0yGKkZ79K39P8Hajd srXG21iIBy+GY5H90H6ZzjrSZFegaN8OfD+lpG01v9vuV5MlxypJABATO3HUjIJGepwK6jT/AAnp dkqGSL7TKOS8vI6Afd6Y69c/WkzXXA9Of1+nvW6KSgHpz+v096BRQD05/X6e9AooB6c/r9PegUUA 9Of1+nvQKKAenP6/T3oFFAPTn9fp70CinKrNjGcev5UoBOKUDNPWPpkn8P8AP+f5uCeuaUCsDxPf XemGyntSVXLq4IyrfdIB/I+/X8cnXbq4sTbS25IXLBsjKnoQD+R/Wq15I8XlsnA5z6Vd0zU4NUth LEcOMB4yeVP59PQ1asb6K+hDxnDDhkJ5U1JDMsyZXr3HpV0Hpz+v096sin0A9Of1+nvQKKkSToGP 45/z605X7E0oPrWdpH/IT13g/wDH+v8A6TQ/5/zzqaj/AMeOkf8AXo3/AKPlqOD/AFtx/wBdB/6C tav59f8AP+f8nOqaj8+v+f8AP+SUUfn1/wA/5/ySinpE74IU4z1J/wA/5/XX0rw1q2sKslpaN5JY DzpDtTkkZBP3gMHOM/4mCasJaqOWJb2rtdL+HFnAyyalcNdHAPlJlEBwcgnOSMnjp096dtrzSS7F 74s1OUReWEuWh27s58vCZ/Hbn8fz4KOaCbxnqy2tqtrDBdtbLGrZ/wBViPdn1Ozd369T1OSX8y9m OMYYr+XH9K7Kw/1K8joK9H0w/wCjpyOg6n/69Xo/uitLsP8AP+f8/jsfwj6/5/z/AJMtYWsn9ye1 cz4hOLc9B1qvP92n+CZUOn6h833b0g/Xy4/8al+G08Z0nVvmHy6kynPr5UX+NLYEeVL7Sf0FdE93 CnVua6yTULeIcuM+1WS6jvVObWIkBwR+NUJ/EEEYO0j8aY04FZV34khjBzKoHQc1h3/i+3hUlp1A HA+b9etQvdKP4hXNaj47srckG4X061x2q/E7T7ViPtKk9OuT/wDrqubzcxWMM59FGTXKX3xIySIF ZsHFcVqXxZkclbZHODgHp/WkC3cvRAgxkFz/AJNL4T8SXuta3NFcYEa27OBnPO5R/U1h2firUNfv nhumHlKhcLnPOQP6mnm2aLLNLvzwBjGK7U9+n51onvRQe/T86D3ooPfp+dB70Vrxf6lP90f5/wA/ /r0Y/wDVr9B/n/P/AOudfuj6U/8Az/n/AD/9d3+f8/5/+uVah/1S8/5zViL/AFYp69KeD05/X6e9 PFLQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKjaUDhTz65+nvTGkA4B59aQmodxJBLc1HnJBJpKA enIpAenIpKAenIoB6ciigHpyKAenIooB6cigHpyKKp6lq1jo9n9r1C5SCEELuIJJJ7ADJJ+nbmoL u9t7CDz7qZY48gZPOT6YHJpQCeleP+J/Huoa6z21szWmn5ICIxDyqRj94QeR1+Ucc85wDXCax4mu tSLQwkwWuSAqkhnGMfMc/Xj3708KB9a5i3tZ7uQJbwvI2QMKucfX0rJtrS4vJBHbQSSuSBhFzj6+ lDyJGPnYD0yetdfo3gC4uSsl++xeD5aHJ/E/4fnXc6B8NLu8Ky6i/lpwfKjOSenU/wCH51Xe5Z+I lwP7x/oK9H0bwnb2USpBAkaccgcn/E16xoHge10+JUgt0jTjkDkn19z9f/1tWBnbc5JJ7muotdJj Qg7Oe5NdpZaFHGVPljPQk1YSEDtWnHbKgHt2rZhskjAxgY7YqUIBUwGOlWQABxTqCQByaCwUZJxR UMtysYPNVp71IlPPIppcCs251JVBy+B9ax7zWFVTmTaBznPT9aieUDvXN6l4lht1b94Cfr/9euQ1 jxlbWisfOBI9+n6/5/nVlu1Uda4HWvH+4tHbHzG9QePz/wD115hr/wATXkLx2hMjdNwPH5//AK6a sVxP1/dr6t1/KuKvdXvNQbM8px/dXgVwF/rF9qT5uJmI/ug4FWIrKGJt2C7Z4L84qjVCrFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFaWl+H9W1pgNOsJ51LFfMC 4QEDJBc4UHGOp7j1q3ZaXfagwFraySAkjcBhQQM4LHgUZrv9I+EX3m1rUPZY7M/TBLMPrxt9DntX UWHgXqdQuvYLbn6c5I+vGPxpN1eh6ToumaJAYdNs4rdWxuK8s3ORuYkk4ycZJxmupsdPs9Oi8u0g SJT1I6t9STk9T1puavg9Of1+nvVoUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD 05/X6e9AooHOP8+nvQO1FPWNjjPFOCk+1KAaeqAY4JP+f8/55cFAx1NKBTvz6/5/z/krS0fn1/z/ AJ/ySiuf8YxPJogZFyscwd8noMEZ/Mj86yPEcbPpYZRkJIGbnoMEfzIqrfKTb5A6Nk1xVreXFjP5 1tKY5ORkc5HuO9cxBczWsvmwOUfpkdxVBJGjbchwa7TTfEtjdpFHc3MFvduwQRSSBfMbIA2ZPOfT r+mey0aW41i0mlgtZnNsAbgxoWVBzySOg4PX0P47enWl9qltcT2ljczx2q7rh4omdYlwTliPujCn r6Gp5NesFlaCCRry4RtjQ2imUq3Ta5HEZJyPnKjg88GtaPSLxokmmRbWBwGWW5YRhl4+ZQTlxj+6 CeRxyM6UPhvU3gjubmJLC1kUSJPfOIVdCM7kDfNKAMHEYY8jjkZaDrV53ttPiPuZ5ipx9FRh/wBt Bk9wPmcP7Jtf+fi+kHv5MQI/NnU/8AOPc8P/AOKesP8An81WYfS2gDD/AL6eRCf+uTYHYn5dfTIL S2tfs8jMJS29rogFpWOATJjr2wQOAAoGAoGXfXN61z9ohVZIsBfsu/aI1H/PPOffgnBJ3Egli2Pe TvNeSXMdvDGshGYIRsVQAANvXJwAPmJJ6k5JJnkRonKuMEe+Rz0Oe4Of1/Oezb+0FjNorzF87VRS WyM5GOoI5yOo70iOroGU5BqGSYIOFLfj/n/P69DZeEr2eMS3JFshGVBG5j36Z469+faguB2zWDqV 3qasJLa5MTKcrtUEZwR3znr3qW40iXTJEudPkK3EJ3RyOqvg+uCMZ5449D1qrLJN1V9uOmBW5oGv x6xCYpVEV9EP3sXYj+8vt/L8ie88LeKYvEFu0MyrBqUI/fQZ4I/vp/s9OOoJwexNi2uROuCNsg6j +orZroqnryO0H/FR6sQP+X+4z/39avBLFf8Air9dIH/MUus/9/mrFT/j6m/66N/Ou70/mJeR0HWv T9L5gTkdB15rRj+6K0W4WtduE6+/+f8AP/15e1YOscRntx6+9ctr/ETduPX3qtP0rk9P8SwaKuoR TSqpN2X5OONif4Vwuk+MbXw6mqwTzKjNfNJgtjI8qMf0NVIbkRGROrGTgDvwKzdR+JMA3LDuc+xy PzrK1X4txfMluskh9jx+dS7rqX7kLAZxluMf1rmL7x3qNyWEQ2A9CWya4/UPiNq94zCI+Wp6ZYk0 9bKVsGWbHqEH9T/hWDc6vf3RPm3MhB7A4rnLrWNQvCTPdytntu4qRLGBcEqXI7uc5/DpVIkkkk5J 71RJJOSck1YACgAAADgAUUUtdd8Ov+RguP8Ar1b/ANCStvwv/wAhOT/rif5iobj/AFY+tenHv0/O utPeq9B79PzoPeig9+n50HvRWvF/qU/3R/n/AD/+vRj/ANWv0H+f8/8A651+6PpT/wDP+f8AP/13 f5/z/n/65VqH/VLz/nNWIv8AVinr0p4PTn9fp708UtAPTn9fp70CikLBQCT+v096QsAMk0ZqFpS3 AOB/+qozIT0OBTc5pgPTkUwHpyKSgHpyKAenIooB6cigHpyKKAenIoB6ciigHpyKAenIorj/ABT4 +s9BAtrLyr2+O4Mof5ISOPnI6nI+7165I4zhaz4mg00CK32XFzyCA3yx9vmx3z2/l3cqk/SvKbi4 1fxNqBnmaW8udoXdgAKB0HGAB1/HPc1x23U9fvdwWW6nwFyBwB2HoKV5I4V+ZgPT1NdPo/w+ll2y X7/9s0/x/Ku00L4Y3FwVk1F+D/yyQ/1/I1We5lk4jXYPU8mvRNJ8LQWsarFCqL7DFeq6F4KtrKJF hgVE9hj9KSO2ydzZJPUk5NdPaaWkePkGfWu0sdEji24jG7+8aspCB2rTjt0THFbMNpHHjj3xUoUC pgMCrAAAwKdSEgDk0hYKMk4oqCS7RAcHtVWa/jQHB7U0uBWZdamqA5bA7c1jXusrGrZcqO2TUTyg d65vVPE0NujHzRj3NcfrXjO3tI3PnAD3NVJrtVB5rz7WfHpkLJbEyN/ezx+deW6/8SpLgsloS5/v ZwKasNxccn92vqw5/KuMvdTu79iZ5SQf4RwK4O+1S81Fy1xMzA/wjpVuG1ihOVGW/vNyaqVTqaii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiuw0X4ba9qyrLPGlhA WGTc5DkZwSE65Ho23ORg1vaf4R1K+CvIq2sZI5l4bGcHC9fzxnikyK9D0X4baDpTLLPG2oThRzc4 KA4wSEHGDno27GBj36rT/COmWTK8im6kwOZsFQcc4Xp3757Uma66KOOCKOKJFjjRQqIgwFAwAAOw rcjRY0VEUKigBVXgAccCkpwPTn9fp704UUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096 BRQD05/X6e9AopVBboCf8j3pQCelKKkWPpkn8P8AP+f5uCetKBTwAAAB/n/P+fVwGOgpaPz6/wCf 8/5JRR+fX/P+f8koo/Pr/n/P+SUUfn1/z/n/ACSis7X4PtGg3ibiuIy+ev3fm9e+P1/Onq0XnaTc rnGELZ69Of6f57xXK7rZx04z+XNeaHv0/OuIPesms/UNGtNRuEmn37k4wrYDDOcH9enrXU+G/H+t +FdMu7DTTbeVcMXBlj3NE5GCy89cBeGyPlHHXPX+FPiT4g8G6Re6bpRtfJuXMgaaLc0LldpdOQM4 C8MGHyjjrn0jw/rUN5Etm0cVvLGNsccY2oVHQKM8YA6VJp+tnU5X+0v/AKUzFiSxPmZPJyTnPr+d Yi38l9PJLcyNJcSMXd3YkuSckknkmtwHpz+v0960RUlAPTn9fp70CitnQraPVJ1s7iSMIoJXLESA dSEPQ89QfUkdzVC+8T6j4Mjk1TSlZmlKiaNkDQSEcKZOQwwCcFSMkKGJGBVO+la1jM8atuPXAyp/ 3u/4j2o8QaXBpd3FDBKzK0e4hzlhzj0Ax/8AXrv/AIZeMtR8baDdXmp2kMLw3JhR7cYjYbVOMM5b cM85AGGGM80afdSXcLPIoBDYBXp/Oufnt1dDxXV3NqkiEY6/5/z/AJzZZQRWFd2UkMqXFs5iuIjl XXqP8fTHv+fM3+nTW88d3aSGC6hbckicFT688H0x0OSDkHms8ZUhlOGHQitCy8XSSo0N8kcNyudp ThJB7ZPB9q1NO8eyzo9vqccVveKTtMeRHKvqMnII7jJ9R3AljvSQVkAV/boa5DSZRNq+oygkh7ud gfrIa4DQphca/q86sSJL+5cHPXMrGqMJ3TSn1dj+td9p5/dLz2Fep6Uf3C89hWlH90Vot92tZz8n Xt6+31/z/OU9K5/WOEPWuV8QcRnqPxqtP0rwzxaf+KiuRnjj+VfN/jQ58VXvP8Q/kKbp4G2Y4GTJ jP4CsOsCrlFFFFFFFFFFFFdd8Ov+RguP+vVv/Qkrb8L/APITk/64n+YqG4/1Y+tenHv0/OutPeq9 B79PzoPeig9+n50HvRWvF/qU/wB0f5/z/wDr0Y/9Wv0H+f8AP/651+6PpT/8/wCf8/8A13f5/wA/ 5/8ArlWof9UvP+c1Yi/1Yp69KeD05/X6e9PFLTGlC4AOT9fp701pAOAcn60hOKhLFiCWzxUW4kgk 0mc0gPTkUgPTkUlAPTkUA9ORRQD05FAPTkUUA9ORQD05FFQXl7b6fZyXd3OkUES7ndugHH5n0HfI qOe4itYGnnkVIkGWY9qUc15nrnjTVtfuXsPDyyQ2YYD7Uu5JHweTnPyr04+9ge5Fcrd6xqeuXBs9 GjkWDcB565Vj+PYdOOv54pHljhHzt83ZRyaraP8AD0yMr38hbgHyl4H4nr/KtjQvhg87LJqMhPAP kpx+BPX+VQm5lk4Rdg9Tya9F0rwxDaxKkMKRov8ACBivV9E8GW9lCqQQJEi8bQKEtyTuOSe5PJrp bbS0jAwo4PU12FnoiRgbUHB6k1ZSEDtWilui4OK14rWNMHHNSBQKmAwKsAADAp1IWA6kUhdV6sBR mq8t2iD8OKpzagkY4PJHFMLgVmXOqKikl8DHUmse81pI1JMmBjqTUTzADrXL6r4rt7ZWPmjA6kmu K1zxxa2auRMOOpLVVluwDheSeAB3rz7WPHkkxZbbLse5+6P8a8t134kT3TOttlmPc5Cj9eaRLeef DSHy1Pbua5C71C7vnLXEzNn+HPH5Vw95qV5fyF7md3z2zx+VW4raKLBVAWH8R5NVaq1LRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRV/StE1LW7gwabZyXDj7xXhV4JG 5jwM4OMnmrNlp13qMvl2kDysOpHAH1J4HTvRmu90b4SSypHLrN/5OeWt7YBmAIGPnPAIJ5wCOODz XT6f4Gd1R7+58vPWKLBOMf3jwDk+h6daTdXoekeHNH0LcdNsYoHf70mSzkHHG5iTjgcZxXU2Gk2G m5NpbJGzdW5LY44ySTjgcUmc1qA9Of1+nvV0UlAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/ r9PegUUA9Of1+nvQKKBzj/Pp70DtRT1RjjtTgpOKXBp6oBjgk/5/z/nlwUDHU0oFOA6cH/P+f891 /Clo/Pr/AJ/z/klFH59f8/5/ySij8+v+f8/5JRR+fX/P+f8AJKKPz6/5/wA/5JRR+fX/AD/n/JKK juIFubaWB9wSVWRiDzgjH9f892TRLPA8TZCupUkHnBGKayh0KnOCMV5Oe/T868/Pesag9+n50HvR Sq7I4dGKspyGBwQfXrTgzKwZThgcgg8g+tGSDkHBrs9F8SLeSJa3eEmOAsgPEh+nY/z/ACB6TTNa Fy6wXGFlPCvnhz/Q1ft7sOQj8N2PrXQA9Of1+nvWwKs05HZHV0cqykEMDgg8e9NdEljaORVdHG1l YZBB6giggMpVgCDwQe9OmuJrl1eeaSVwAAzuWOPxPua0PD2pt4b3R2MEKWzsHeBVCqTwNwx0bHGe e2c4FNSKOMYjRUGc4UYpoIYYJr0/T9QttVs0uLdwUPBB6qeOCM9f8fTqtQyxBwaWeEOD0/z/AJ/z 3aRmsHU9LSdCGXJ/lXMazosd1GQygkfpVeWEMOlct4bi8m4uYtxPlzSJkn0c1xPg+H7Pd3kG4nyr mVMk+khHPrVO1G1nX0Yj9a9G0/8A1Y+nevXNK/1K/Tua1I+laLfdrWc/J17evt9f8/zlPSue1j7h 4IrlPEH+rPBH41Wn6V4Z4t/5GK559P5V83+MznxVec55H8hSaf8A6uX/AK6f0FYlYNW6KKKKKKKK KsWVlc6lexWdnC01xM21EXqT/Qe/QVLb2813cJbwRmSVzhVHeivW/B/w+l0WNr68uv8ATpodnkKB siyQSC2fmPC9MAc/e4NdxoXhZ7BDcXE3+kvHt8sY2pznBPft09+tRyL5i4rdngkgcrIuOeD2NX5Y niYh1xzwexqsylTgioz36fnUZ70lB79PzoPeiteL/Up/uj/P+f8A9ejH/q1+g/z/AJ//AFzr90fS n/5/z/n/AOu7/P8An/P/ANcqzCQIQSeP/r1YjOIwSaev3aa0xOApwP8A9XvTTITjBwKN1Rg9ORTA enIptAPTkUA9ORRQD05FAPTkUUA9ORQD05FFAPTkUA9ORRWPq+vppwENrD9tvSwXyEcLs6El2528 EEcEnPA6mq81zLuEVnAbq4JClFbAXp95u3B6dT2FNeRI/vNzjgDqa5U+Hb/X7uK71+589kz5UCDb FGCc4A7+mTyRjOcVNYeA7rVLiK51yfzmHKQoMRp0OMdT6c9Riommlk4QeWvr1JrrtM8NRW0arFCk aqMAY7V6No3g+C0iRIYI4kUYA284pY7bvjk9Sepro7bS0jGAv4muvs9FjhXAQY45NWUhA7VoxwIg 6c1rRW0cY+7zUoUCpQMCpwABgUtIWVepAprOqfeYCjOKrSXiIOCKpzajHGDgjNMLgVlXeqrGuS4A 781h32uJCmWkAHfmoXmAHWuX1bxXb2sZZ5lAHcmuL1zxza2cZd51AHcn/wCvVZ7nJ2qCzHoBya89 1jx1NOWS1yf9o9BXlmu/Ea5uyyWmcf3j0FNS2nnwZD5aen8R/wAK5K6vbm8bdPKz+xPFcVdX1zev uuJnf2J4q5DbxwD5F57seSar1XqWiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiup0j4feIdX3N9k+xxrxvvMx5PHAXBbv1xjg85rZsfC2q32T5H2dR/FcZTJ44xjPfrj FJkV6Lovwx0PTVV70NqNwGDbpflQYORhAeRyMhiwOPfFdXp3g7TrQK1xm7lBBy/CjB/ug/TOc0ma 7OKOOCKOKJFjjRQqIgwFAwAAOwroI0WNFRFCooAVV4AHHApKcD05/X6e9OFFAPTn9fp70CigHpz+ v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKVQW6c/5HvSgE9OaUc09Yzxn8qcEPGaAKeFAx gf5/z/n1cAB0FLil/Pr/AJ/z/klLR+fX/P8An/JKKPz6/wCf8/5JRR+fX/P+f8koo/Pr/n/P+SUU fn1/z/n/ACSij8+v+f8AP+SUUfn1/wA/5/ySisrWPEujaDsGp38cDuRiPl3IOedq5OODzjH9aV/q +n6ZtF5dJGzdF5ZsHPOBk44PP+SV5zrXxgmlSSHRbDyc8LcXJ3MAV5+QcAgnjJYccjmuT1Dx47q8 en23l56SzHJxj+6OAc+5HtRXPaN4ia9lMF8yid2JWQKFDE9sDAB9Mcdvri2epGdyk5XzGOQwAAPt gcCqF1a7cyRj5e49K6A9+n51oHvVOg9+n50HvRQe/T86D3orrdD8SoUFtqEu1hgJMx+8M9G9D7/n 79FpetqVEN4+GHCyE9fr/j/k3be7GNkpwezetdOD05/X6e9bgq3QD05/X6e9Aooz05/X6e9X9I1e 40e7E0ByhwJIyeHH+PPB/wDrglOBDDBNekaPrFvrVmJYiFdcCSMnJQ/1B7GkqKSLeP8A69WJod49 fxppGa8/0jjV9SGel5MOf+uhryvQfl1/Vxu6ahcDn/rq1Z0P+ul/32/nXfaf/qx9O9epaV/qV+nc 1ox9K0W+7Ws5+Tr29fb6/wCf5ynpXPax9w9R9TXKa+P3Z6j6mq0/SvDPFnPiK4/D+VfN/jI58U3n PcfyFJp/+rl/66f0FYlYNW6KKKKKK6Tw14K1TxK4eJPs9mME3MykKw3YOz+8Rz7cYJGRWtpHh691 dgyL5VvxmaQHB5wdv949fy6ikJxXtHh7w3p3hqya2sEYl23SSyEF5D2yRjgZ4AGPxJz6FpWk2mkW 5itlOWOXdyCzemT7f568pnNa4PTn9fp71eFJTZI45k2SKGX0P/66a6JIu1wGHvSEBhgjIrJutNeP LQ5kXjj+L/69Z1xZMmWj+dfTvULxEcryKoHv0/Oqh71HWvF/qU/3R/n/AD/+vRj/ANWv0H+f8/8A 651+6PpUgUHqcf5/+vUgXPU0uKcD05GPSnA9ORiloB6cikB6cikoB6cigHpyKKAenIoB6ciigHpy KAenIopNwUZLAADkk9KVQWKgck8ACjOO9Z1xcXF1mG1JWMrhpBkN+HPH1/ydqw8OXN1gygqp7A8/ zqF3Z/lTgY696mstCCncwO4ksT1Jz1J967LS/CqQKuEC4547iljt8cnrW7baakYGFGcda6mz0eOI DagzjrirKRAdq0EhRB0rUjt0QdOakCgVJU3QUtNLBepprOq9TRmq0t4q9GH51Sn1BE+6wz9aYXAr KutVWNcs4AHvWHfa2kS7nkUAZ7/5/wA/rC8wA5Ncnq3i+3tUb94oA7k1wuu+PbazRsSrx/Fu/wA+ tVJLrJ2oCzdgOTXnureOLi5Zlts8/wAbZx+VeW618Qru8d1ticH+Ns/ypyWk0pzM2wf3V5NcrcXU 93JvnlaRvVj0rjrm6uLuTzLiZ5G9WNXI4Y4RiNQPX1NQ1DT6KKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKu6dpGo6vN5Wn2U9ywZVYxoSFLHA3Hoo9zgcVYtLG6vpNlrbyS nIB2LkLnpk9B+NFd7ovwluZWWTWrxIYyoPk2x3PyOQWIwCDjpuB59jXTaf4Hmdg+oXCxoQD5cJy3 I6EngY46ZpN1egaN4U0XQki+xWMXnJyLiQBpSSACdx6ZHYYHJ45rqNP0TT9NVPs9snmL/wAtWG58 4AJz2z6DjmkzmtkHpz+v0960BSUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/ X6e9AooB6c/r9PegUU5UY44I+v4UoUmlANSKgGM5J/z/AJ/zy8KBjqaUCnAdOD/n/P8Anuv4UtH5 9f8AP+f8koo/Pr/n/P8AklFH59f8/wCf8koo/Pr/AJ/z/klFH59f8/5/ySij8+v+f8/5JRR+fX/P +f8AJKKZLLHBC80zrHFGCzu7YVQOSST2/wA/VHdI42kkYKigszMcAD1J9KK4rW/iloWmKyWJfUrh WK7YiVQEHBy5HIOTgqGBx75PO6j4z02zUrbFruUMRhOFGD3Y/jjGaK881r4leIdWeRILn7BbNwI7 bhgN2Rl/vZ6A4IBx05NcrqHi7Vb5nWOX7LCeiQ8Hrn73XPbjH0orj6waKKKKKKK6TRPEDI32a+kL Ix+WZzkqfRj6e/b6dNKx1EqfKnYkE8Ox6fWqd1aAjfEvPdR3+ldWe/T861j3qhQe/T86D3ooPfp+ dB70V0vh/wAQ+QVs71/3WcRyk/c9jz0/l9Om5pGseUVtrl/3fRHJ+77H2/lVu2uduI5D8vY+ldcj q6K6MGVgCCDkEce9dCrBlDKwKkAgg9elXQQQCDkUoPTn9fp70oooB6c/5496s6fqFxpt2lzbSbZF 7How4yCM8iinAhsA16Touv2mtxlUzHOgBeJ+vbkeo7Z/PryleeaWf+J3qnP/AC+z/wDow151ohz4 k1sZP/ISufp/rW/z/nnMh/4+Jv8Aro38672w/wBWOnTvXqOl/wCqHTp3rRj6VfY/L/8AXrVc/J/9 f2/z/nrKelc/q/3GrlNe/wBW3b2P+f8AP8603SvC/Ff/ACMNx9B/Kvm7xj/yNF39V/kKbp/+rl/6 6f0FYtYVXKfFFJPKkUUbSSOwVEQZLE8AAdzTkRpHVEUs7EBVUZJPoKK9R8JfDExTRX+vhCyMStjw ynBGC7A4I6naOOmT1Wuz0PwcUkS51TaSpJFtwR2wWIOD9Pp9KQn0r02KOOCKOKJFjjRQqIgwFAwA AOwrr40WNFRFCooAVV4AHHAptOB6c/r9PenCigHpz+v096BRQD05/X6e9AooB6c/r9PegUVTurCK dSy4STHXsT71WntI5QWXCv69j9aY8YYZHBpI02oqkgkACkRdqKCQeMUAYAFPBzjmnZ6c0UA9ORQD 05FFAPTkUA9ORRQD05FAPTkUUA9ORQD05FFNaTaOPmbHCirum6XdanMqQodn8UmOF6fmeelITgep 9KEsJbpgZjhRyqjtXfaL4QjtgpcZkIwXPU/rx/nrSCNnPzdOwrWttPSMcDFddZ6THEBhcev+c1Mk QFXUiVBjFaUcCRjAGakAAqSpaWms6r1NMaRU6kfnSZAqpNfKnQjr61RuNSSPoRwfXtTGkArJutXS PO58Y7ZrCvtejh3b5QMds8moXmA6muT1fxjb2aEtKq/jya4TXviBa2KMTMq9e+ST/X/P41muGdtk YLN6CvPdW8bXN2zLb5AP8Tf4V5brfxAvb9mW2JVSc7m/w/OhLOaXmZtg/uryf8K5ee4muX3zSM7f 7RrkZ7ma5ffPK0jerHNXYoY4VxGgX19T+NRVFT6KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKK6TRvAuv62kcsFn5NtJ0nuG2LjGQQPvEHIwQCOa1tP8N6pqKo8cHlxN0klO 0dMg46kHI5ApMivQtI+FOj2e5tSmk1FjwF5iQDjsrZz17456V1Vh4KsIMm7ke6Y8AfcUDjsDnPXv 36Um6u4tba3s7dLe1highT7scShVGTk4A46n9a6OGGK3iWKGNI416IgAA/AUlSg9Of1+nvTxRQD0 5/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CilGTjHP+R70DJ6c0U9Yzxn8q eEPGaUCnqoGMA/5/z/nu4ADHFKBS/n1/z/n/ACSlo/Pr/n/P+SUUfn1/z/n/ACSij8+v+f8AP+SU Ufn1/wA/5/ySij8+v+f8/wCSUUfn1/z/AJ/ySij8+v8An/P+SUVmar4h0fRFJ1LUILdgA3ls+ZCC cAhBliM56A96qXuq2GnDN3dRxHAO0tliCcZCjkj8KK831r4wTSpJDoth5OeFuLk7mAK8/IOAQTxk sOORzXI6h48d1ePT7by89JZjk4x/dHAOfcj2orz/AFbXNT124E+p3sty6/dDHCrwAdqjgZwM4HNc vfalealKJLy4eVh0BPC/QDgdB0orPqrRRRRRRRRRRRRRRRRW1omuNp7C3nJa1Y/Uxn1Ht7f5N2xv jbny5OYj/wCO1WurUSjcnD/zrs0ljmj8yJ0dD0ZWyD1962gyuu5WVge4Oc1nMpUkMCD6GnHv0/Ol PekoPfp+dB70VuaFrzadILe4YtaMeucmM56j29vx+urpWrNZv5MxJtyfqU9/p7f5Ni2uTEdrcp/K u3R1dFdGDKwBBByCOPeuoVgyhlYFSAQQevStAEEAg5FKD05/X6e9KKKAenP6/T3qW2uZrS4juLeQ xyocqwPSiuTXQ7jTdRurkyLLDcXDygr1Xc27BH1OM89PfFWNADDVruWV1L3VxJPheBl2LEDk+vvV H7M0UrvkFWYn6ZrqLA/J17d69R0w5jHOeO9W4+lX2+7Wo/3P/r/5/wA/rKelc9q5Hlsc8fWuU15g ImORj6/5/wA/rVm6V4Z4qIPiCcg54X+VfN3i8g+Jrsg5Hy9/YUmn/wCrl/66f0FJoHhbVfElx5dj BiIZ3XEuViUjHBbB55HAyefTmqel6Le6tLtto8IM5lfIQY7Z9eRx71cJxXtnhnwlpnhmAfZk8y7Z Ak10/wB5+c8DOFGew9BnOM16Ho+h2ejxjyV3TsoV5m6t39eB7D0Gc03Oa3genP6/T3rTFJQD05/X 6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFNaQLjJ59M/SkLhep5ozioTIWIyePT8qiLliOe PSm5zTQenIpoPTkUlAPTkUA9ORRQD05FAPTkUUA9ORQD05FFAPTkUA9ORRU0VvJJj+Eeprs9B8DT 3Yjn1LdFGwBWIcMf97047dee1KATV+3sVTB5z6mvRNP0aC1jVIoljReiquBUixgVdSMJ0rVjhWMc U8DFPqSlprSKnU0x5Uj+8wFISBVOe/VM47Vn3OqLHnacY70xpMVkXmsJGpJccc9awNQ8QRwqS0gG Dnr/APXqB5wB1rkNZ8ZQWqsfNA9DmuC8QfEK2s1fbKB6HOarNctI+yJSzHsK891Xxnd3m5IMqp/i b+gry7WfHl/qG5ICUQ/xHr+VPjsnfDTvgf3F/qa5qWaSeQvK7Ox7sc1yks0k8hklkZ3PUscmrkca RLtRQo9qZTKdRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRVi0sbvUJTFZW s9zIF3FIYy5AzjOB25H51LBbT3TlLeGSZwMlY1LHHrxRXe6L8J765VZdXuls13D9xFiRyM8gnO1T jGCN3Xkdq6bT/BFzMA9/OsAyP3aYZiM885wO2OvWk3V6FovhDQ9BZJbKyT7QFA8+Q73zjBIJPyk5 OduAc11OnaFp2mMr29uvmgAea53N0xnnpnJzjFJnNbgPTn9fp71pCkoB6c/r9PegUUA9Of1+nvQK KAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9Aopyoxx6ev5UoUnFKAaesYHXJ/wA/5/z1 cE9cmlAp4HTg/wCf8/57u/Clo/Pr/n/P+SUUfn1/z/n/ACSij8+v+f8AP+SUUfn1/wA/5/ySij8+ v+f8/wCSUUfn1/z/AJ/ySij8+v8An/P+SUUyWWOCF5pnWOKMFnd2wqgckknt/n6o7pHG0kjBUUFm ZjgAepPpRXH638TfD+ks0UEj6hOAcC2IKA4yAXzjBz1XdjnI7HB1HxhpdiSkbtdSgHiHBXOOMt0w c9s45/ErzrW/ibr+rK0MEq6fAWJAtiQ5GcgFyc5GOq7c5ORzXJ6j4w1S+UxxuLWIk8Q5DEZ4y3X8 sd6K4+WWSeZ5ppGklkYs7ucsxPJJJ6msF3eSRpJGZ3YkszHJJPcmimU2iiiiiiiiiiiiiiiiiiii iiiiitLSNXk0ybBy9u5+eP8AqPf+dWbO8a1fHLRn7y/1FQ3Fus6+jjoa7iC5hu4vNgkSRD3B/n6H 2rdSVJk3xsGU+hrLdGRirqQfepT36fnTj3pKD36fnQe9Famja1LpU5By9s7fPHn9Rz1/nV/TdTks JTnLQsfmTP6j3/nU0E5hb1U9RXeQTxXMKTQyB43GQwPXp711kUqTxLJG4ZGGQQa0VYOoZTkHvUgP Tn9fp708UtGAwwcEHgg9+nvSqxVgysQQQQQenSjrRAFizz8vvXfeGPE1vcKlreyLHdEhVJ+7J/gf bv264pANv0qdpcrhR+Z/z/n9etefKYUfmf8AP+f1UtxxWPf2xlGSSw96wNUs2mBLEsPQnpUMiZrn 7jwFp+r3cdxqKuojIwsbBTIMg4Y+n059x38r8R6DpGq30cjAs8bctGcBhn7pPce4/A0W8bRljnCn +H+tdZa21vZ26W9rDFBCn3Y4lCqMnJwBx1P61JDDFbxLFDGkca9EQAAfgKmqUHpz+v096eKKAenP 6/T3oFFAPTn9fp70CigHpz+v096BRRn3/X6e9Gfeio2m6BT+P5e9MaTsp/GkLelQ5JIJao85xzSU A9ORSA9ORSUA9ORQD05FFAPTkUA9ORRQD05FAPTkUU+KN5mCoM+/pV/StIvtZukt7KFnJIDPg7I8 92Pbofr2zSgE9K07awVAGfk+teq+HPBNlowSZ/392M/v2GMA9guSBx35PJ5wcVIsfrV1EVBwK6lI ljAAFPAxTqfS0x5VQcntmo5J0jBJI6ZpCQKpz36pkZxis+51RUyAcEUxpMVj32sxxAlpMZ9657Uv EMMAYvNjPTnpUEk4HU1xuteNYLRSDKAT0AOSa8+8Q/EW3s1K+aAx6AHJP61WM8krFYlLH27V5/qn jK8vSyw5jQ8bmOTXmWseOdQ1FmWEtGh4yTkkf0qRbFmIM0mR/dX/ABrnZZZJnLyuzse7HNcvLLJM 5eV2dj3Y5q3HGkS7UUKPamUynUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UV0Oi+Cde1xlMFk0EDKGE9yDGhBGQRxlgf8AZB6j1rV0/wAO6nqLDy7cxxkA+bN8q4IyCO5/DPUU mRXoGjfCjTLdIpNWuJLybq0UbbIuQOOPmOCSc5GeOPXp9P8ABNnEqPfSvPJ1ZFO1OnT1OD3yO3FJ ururOxs9PiMVlawW0ZbcUhjCAngZwO/Arpbe2gtU2W8McKE5KxqFBPHPFJVgHpz+v096lFFAPTn9 fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKUZOMc/wCR70DJ6c0U9YzxmnBD xmlAp6qBjAP5/wCf8/q8KB2NKBS/n1/z/n/JKWj8+v8An/P+SUUfn1/z/n/JKKPz6/5/z/klFH59 f8/5/wAkoo/Pr/n/AD/klFH59f8AP+f8koo/Pr/n/P8AklFZmq+IdH0RSdS1CC3YAN5bPmQgnAIQ ZYjOegPeql7qthpwzd3UcRwDtLZYgnGQo5I/CivPdY+MP3F0TTvdpL38cgKrfQ53eox3rlb/AMe/ dGnWvuXuPx4wD9Oc/hRXnmq+IdX1tidS1Ge4UsG8tmwgIGAQg+UHGeg7n1rlb3Vb/USTd3UsoJB2 k4UEDGQo4FFZlU6KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKuabqU2mXHmRfMh4eMnhh/j6G pra5e2k3LyD95exqOaFZ02t17H0rubLUbbUYmkt33YxuU8FTjuK3YLmK5QtG2cdQeCKy5YXhbDjG eh9atHv0/OpT3plB79PzoPeir+m6tc6XOHiYtFuy8Rb5W9foeBz/AJNuy1CexlDIxMectGW4b/6/ HWpIpnhbIOR3XPWu+sr2C/tlngfch4IPVTxkHnr/AJ+vW2t1FdwLLE2VPB9QeODWlHIsiBlPFTg9 Of1+nvUwp1APTn9fp70CilU4xzx9f/r12eheMUhtGh1N3Zo1ykgG4v7Hn73v37+6Umc4/wA/1rF1 nxJd6vmP/UWpx+5U5yR3J6nk/Tp35KigHpz+v096xhRQD05/X6e9AooB6c/r9PegUUA9Of1+nvQK KAenP6/T3oFFIXCgEn/PHvSFgoGTRnFQtIWxzgen5VEXLd+KbnNMB6cimg9ORSUA9ORQD05FFAPT kUA9ORRQD05FAPTkUUA9ORQD05FFXbWweYLJIdsZH4muz8MeAbnV4ob2/drexkUlVXiVxxgjIIAP qeuOmCDT1jJwT0rUihSFQqKABXqVhptnpdstvZW8cMY7IMZOMZPqcAcnmpQABxUlW6WmPKqDJNRy TpGMk5+lISBVKfUFUEA9qzbrVUUEKeo7VG0gFYt7rUcIJaUD2zXO6l4jitwS84B9M1BJOF6muN1r xvDbKQJQCemDkmvPfEHxHhtVKpMAT0wck1WM8kzbYVLH27V5/qfi6+vSVhYxJ69//rV5jq3jXUdQ JWJ2iQ988n/CpY7HPM77v9lTgfnXPO7OxZ2LMepJya5pnZ2LOxZj1JOSauKqooVVCgdgMUlJS0UU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUVLbW095cLBawSTzPnbHEhZjgZ4A56U +KGWeVYoY3kkboiKST+AoruNI+FOr3m5tSni09BkKOJnJ4xwpxjk988dOa6Ox8E39xk3ciWq9AOJ GPTsDjHPr26UmRXoui+CdB0NUMFmk86sGFxcgSOCDkEdlIz/AAgdB1rq9O8O6ZpwUx26ySAg+bLh myDkEdh17AdqTOa6EHpz+v0961RSUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD0 5/X6e9AooB6c/r9PegUU5VZsY6f/AKvelAJxilAJp6x8DOSfr/n/AD+rgnrmlAp4AHQd/wDP+f8A JcB7UtH59f8AP+f8koo/Pr/n/P8AklFH59f8/wCf8koo/Pr/AJ/z/klFH59f8/5/ySij8+v+f8/5 JRR+fX/P+f8AJKKPz6/5/wA/5JRXH618SvD2lJIsFwb+5U4EVtypJBIJf7uOgOCSM9Dg1g6h4v0q yV1jl+1TDokXIzjP3umPpnr0orznX/idresZis2/s22P8MDkyHp1k4PUH7uODg5rk9U8Y6jf5S3P 2OH0jb5z06t1656Y696K42WWSeZ5ppGklkYs7ucsxPJJJ6msB3eSRpJGZ3YkszHJJPcmimU2iiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiip7O8msblZ4Gww6g9GHofapIZngkDxnBH60 ySNZUKOMj+VdxpmsW+qI3lgpKvLRsefqPUf571uWt5HdKdvyuOSpNZk9u8B5wVPQit6LRtSncqll KD1+cbB+Zx61px6ZeysVW2kB6/MNo/WkEErHAjP48VqW/hC6k5uLiKJSM4XLkH0PQd/U1fh8Ozvz NLHGCM8fMc+/5+tTLYufvMF+nNb+laJDpTmSKeZ2dQrhmG0njnH5+vWtaw0yKwYuksjMygMCRgnj nH+etWYbdYTkMxJHPpWmD05/X6e9XhUtAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegU UA9Of1+nvQKKAenP6/T3oFFAPTn9fp70Cio2mA4Byfrx296YZAOAcmk3VDuJIJbmo85IJNJQD05F ID05FJQD05FAPTkUUA9ORQD05FFAPTkUA9ORRTokeVgsYLHHQfhVmwsLzU7lbayt5J5T/CgzgZAy fQcjk8DNKAScCte109IMNId8g6egr1jw14Cs9GaO6vWW7vlIZGwQkRx2GfmOc8n0GADUqxheTyau V1/Sn1G8yJ1OaikuI4+rA/Q0hYCqM+oKOA3btWZc6qoyA3btUbSCsS+1yOFSWlyPrXN6n4lht0Je bI/3v/r1XkuAo5NcVrnjqC3DKkm5uyryTXnXiP4lQW4dIpNz9Nq8n8ariWW4OIVJHQt2H415/qXi m/vmIVzEme3U/WvMtV8X6nqTsBKYkJ/hPJ+tTR2CkZnYuT2BwBWIzM7FmJYnqSc1gMxZizEknqSa tqqooVVCqOwGKSkpaKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK3NF8Ia3r6r JZWTfZywHnykInJwSCfvAYOduSK0dP0LUdTAe3tz5RIHmudq9cZ56474zRkV6FovwnsLZkl1e6a8 baMwR/u0BxyCwO5hkjBG3pyOcV1Wn+CLaJle+nNwcD92nyqDjnnOT146dKburu9O02y0q0W1sLaK 3hGPljGMnAGT6nAHJyTXS2lpb2UAhtoUijGOFGMnAGT6n3pKtA9Of1+nvUwooB6c/r9PegUUA9Of 1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRSjJIA5/yPegc4opwjbjPFOCGlwakCAY4P5/5 /wA/q4KBjg0uKX8+v+f8/wCStLR+fX/P+f8AJKKPz6/5/wA/5JRR+fX/AD/n/JKKPz6/5/z/AJJR R+fX/P8An/JKKPz6/wCf8/5JRR+fX/P+f8korP1bXNM0K3WfU7yO3Rj8oY5ZuQDhRkt1GcA4z+dW +1Kz02ISXlwkSnoCclvoByeo6etFef618YIYnkh0WwM2OFuLkkKTu5+QckEdMkHnkcc8vqHjyNGe PT7bzMdJZjgZz/dHJGPcdenqV5zrHiXWde2jU9QlnRcYj4VARnnaoAzyecZ5rk7/AFfUNT2i8unl Vei8Bc884HGeTzRWVVKiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiinxRSTypFFG0 kjsFREGSxPAAHc05EaR1RFLOxAVVGST6Ciuh07wH4k1LayaZJDGXCF7kiLb052t8xHPUA+1alr4Z 1e7wVs2jUttLTEJjpzg8457CkyK6az+EF3JETe6vBDJu4WGIygjjnJK88njH41sW/gOdkJuL6ON8 8CNC4xx3JFG6umsvhf4atd/nR3N5uxjz5sbfps29c989B+Oxb+DdIh3eYks+cY8yTG36bcetJk11 Nlpmn6dv+w2Vta+Zjf5ESpux0zjr1P51s29na2m77Nbww7sbvLQLnHTOPrSVaB6c/r9PepxRQD05 /X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AooB 6c/r9PegUUhYKASf1+nvSFgBkmjNQtKW4BwP/wBVRmQnocCm5pgPTkUwHpyKSgHpyKAenIooB6ci gHpyKKAenIoB6ciigHpyKAenIoq1aWT3AVydsfr3P0rqfC3gu88QBLqVvs+nh8NIfvSAddg6dsZP Az3wRT0Qtz2rXhhjgQKgx2J7n616vpOi2Gh2a29lAqDADyEDfIR3Y9zyfpnjFSgBRgUSTIg6irUt zHEBlh+dBYCqE+oKOjACsu61ZR0YAc9TUbS1hX+vRQAl5ATz3rmdU8TwWykyTBm571WkuAvU1xOt eOYrcFUkBb+6pya858Q/EmKAFIpAW6bVOTVcSS3BxCpIzgnsK4LU/E99qBKhzHGfQ8n8a811bxbq WqMy+a0cZ9DyfqasRWKjDTNvb07f/XrFJLEkkknkk1hEliSSSTySatABQAAABwAKSkpaKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK+owenP6/T3r2YUygHpz+v096BRQD0 5/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CinKrNjGcev5UoBOKUDNPWPpk n8P8/wCf5uCeuaUCngAAAD/P+f8APq4DHQUtH59f8/5/ySij8+v+f8/5JRR+fX/P+f8AJKKPz6/5 /wA/5JRR+fX/AD/n/JKKPz6/5/z/AJJRR+fX/P8An/JKKPz6/wCf8/5JRXJa78RvD+jQ/urldQuC CUitXDjvjc/3QMjHcjIOD3w9S8WaXp8fyTC6lIyqQsGHfq3Qcj3PPSivOdb+KWu6mzJYldNtypXb F88hyADlyOD1wVC4z361yeo+M9SvCVtiLSIgjCfMxyO7H8cYx1oripZZJ5nmmkaSWRizu5yzE8kk nqa553eSRpJGZ3YkszHJJPcmimU2iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiirFpY3eoS mKytZ7mQLuKQxlyBnGcDtyPzqWC2nunKW8MkzgZKxqWOPXiiujsfhx4mvWh3WSW0cq7vMnlUBRjI 3KCWB6DGM881rW3hPWLgx5t1iRxnfI4GOM8gZI/KkyK6bTfhB/qn1PVfXzIrVPyw7fgfu+o962LT wJ9xry99d6Qr+WGP4dqN1dTpvw88Nad5TfYftUqZ/eXLl92fVc7D1/u+nfmtm08K6Ra7D9m851z8 0zbs59R93v6UmTXQ2djZ6fEYrK1gtoy24pDGEBPAzgd+BWrb20Fqmy3hjhQnJWNQoJ454pKsA9Of 1+nvUoooB6c/r9PegUUA9Of1+nvQKKcqscYB/wA496UKTjg0oBp6wscZYD8fpThGTjJApQvvQVRM ZbcfTP0oIVcZOT6ZowB71HnOP8+nvTM5xTaQHpz+v096BRQD05/X6e9AooB6c/r9PegUUA9Of1+n vQKKAenP6/T3oFFMaULwDk/X6e9NMgHGeaTNQlyxBJFRFixBJFJnNID05FID05FJQD05FAPTkUUA 9ORQD05FFAPTkUA9ORRTo1aR1RPmY9AKnsrS41C7itLSJpZ5TtRF6n/PXPalAJIArTtdOVAHn+Zs D5ew/wAa9M8NfDu3tEju9a2zzlVItv4I2zn5iD856DHTr161IseOW/KrclwiDkiu2lu44hywp5YC s+fUlUfeAx1rKutYVQfmAwefb/P+feJpcVh32vRQglpASPfrXM6n4ogtwS8wJHPB6/5/z715LhV6 muF1vx5FAzRxsWf+6leaeIfiXFEzxQMWfPRD/WoFae5/1S4X+8eBXA6j4hvtRY7pDGh/hU/1rzbV PEuo6o5MkrIhP3VP9asR2MandIfMb36flWWSWJJJJPJJrIJLEkkknkk1ZACgAAADgAUlJS0UUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUV9Rg9Of1+nvXswplAPTn9 fp70CigHpz+v096BRQD05/X6e9AooHOP8+nvQO1FPWNjjPFOCk+1KAaeqAY4JP8An/P+eXBQMdTS gU78+v8An/P+StLR+fX/AD/n/JKKPz6/5/z/AJJRR+fX/P8An/JKKPz6/wCf8/5JRR+fX/P+f8ko o/Pr/n/P+SUUfn1/z/n/ACSiqWpaxpujwiXUb2C2UhmUSyAFwBk7R1br0GTyPXmvd39pYR77u4jh BBI3tgtjrgdT9Bnr+ZXn+t/F+1iVotEsnnlDEeddDanB4IUHLAjPUrjjryK5fUfHcKKU063aR8ke ZNwvXqADk5GeuMcUV55rXi3W9feT7bfy+RJ/y7RsViA3bgNo64Pc5PA5rldQ1zUdTZ/tFy/lt/yy Q7UxnIGO+PU5NFYlZ1FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFWrPTL/Ud/2GyubrZjf5ET Ptz0zgcdDU1vZ3N3u+zW8023G7y0LYz0ziiups/hf4lut/mxWtptxjz5wd2fTZu6e+OtbVv4N1eb dvSGDGMeZIDn6bc0mRXU2Xwg09N/27VbmbONnkIsWPXOd2eo9PxrZt/Alqu77RezSZxt8tQmPrnO aTdXR6d4D8NadtKaZFPIECM9yTLu6c7WO0E+oA/Kte18NaRa7StmkjbQpaX589OcE4z9BRk10UUc cEUcUSLHGihURBgKBgAAdhWpGixoqIoVFACqvAA44FJTgenP6/T3pwooB6c/r9PegUUA9Of1+nvQ KKcqOex/P6e9KFY9qUA1IsJ4y4/ziniM8ZYUoX3pywoMZOfx+lKI14yc/jShRUihRjGBx/hTwAMY x0pRilB6cjp/hRnpyKKgacnAU/j+XvUZl7L+dNLelQ5z3/X6e9R596bQD05/X6e9AooB6c/r9Peg UUA9Of1+nvQKKAenP6/T3oFFG4AZJ4+v096M4GSaKhabOApwPXP0qNpM8A/jSFvSowenIqMHpyKb QD05FAPTkUUA9ORQD05FFAPTkUA9ORRQD05FAPTkUVXmvra1nt47iUIJXCb8ZCZ7t6Dtn39MmrNh ardXltFNOtvBLKI3uHBKx57nH/6hkZIGTTWlRGUMcbjjPpXRILezTCcnux6/nXtOkaNpPhu32WcY MhJDTyYMjA44LcccDgccZ69bA2oOKqXGogA/MBg0t3q4UH5gMH1/z/n9WNLXP6j4hgt1JMgPOetc nq3iy2tFYtMp5z1qtLcqo61wmsePYxuSOTec4wnNeaa98TEO+OGTec4whzUA+0XBwiEL13NwK4fU fEF9qDHdIY0P8Kn+teean4k1HU3O+ZkjP8Cn+tWYrGNTmQ+Y3+10/KsqsirVFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFfUYPTn9fp717MKZQD05/X6 e9AopVBboCf8j3pQCelKKkWPpkn8P8/5/m4J60oFPAAAAH+f8/59XAY6Clo/Pr/n/P8AklFH59f8 /wCf8koo/Pr/AJ/z/klFH59f8/5/ySij8+v+f8/5JRR+fX/P+f8AJKKPz6/5/wA/5JRR+fX/AD/n /JKK5TWPiL4c0jYPthvZG52WREuBzyWzt7dM55HGKxb/AMV6TYbR5/2hjzttyHwOeSc4/DOeelFe da18Vdb1KOSGySPToX7xktLjbgjeeOpJyACOOeueT1DxrqN2rx26paxt3Q7nxjBG4/XsARRXE3N1 cXtw9xdTyzzvjdJK5ZmwMDJPJ4Fc7NNLcStLNK8sjdXdixP4mioqZRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRWppvhvWtX8o2OmXMqS52S7NsZxnPznC9sdevFXbTSdQvtn2azldXztfbhTj/AGjx+tGR XTWPwp164WJ7maztVZsOjSF3QZxnCjaTjkDd+Va9t4J1KUI00kEAJ+ZS25lGfbg+vWk3Cun0/wCE mlQbWv7+5umDhtsYWJGXj5SOT68gjr2rYtfA1lHg3NzNMwbOFARSOOCOT+RpN1dTp3hLw/pe02ml WquriRZHXzHVuMEMxJHQdD/9fatdD0uz2mCyhDBg4ZhuYHjoSSRRmtkHpz+v0960BSUA9Of1+nvQ KKAenP6/T3oFFA5x/n096B2op6xuccfmfp704Ixx/n0pQDT1g6Zcfh+FOEfTLUoX3p6woMc5+p+l OEa+ufxpQop64GMYHFOGBjGKUUoPTkdP8KAenNFAPTkdP8KAenNFAPTkdP8ACgHpzRTWkCAcgnHS kLhQOfwoJxVdpC+MnjsPyqIuWxk8UwnNMB6c/r9PemikoB6c/r9PegUUA9Of1+nvQKKAenP6/T3o FFAPTn9fp70CimtIq4559M/T3ppcL35+tGcVAXLEEt/nioixYjJpuc0gPTkUgPTkUlAPTkUA9ORR QD05FAPTkUUA9ORQD05FFA5xzTo0eWRI4wXdiFVVGSScYAHc0VIIm2gk8+ldno/gh9qz6p15At1b P0JYH9B7c9qXBrKv7ASg5HXua0dR0iN4ggRVULgccAenWoJI91Zqatd6XCLeRDLApwrbuYx6e46f T8hWTHrt/otstpMhntlbCNu+aIY6f7QzjHTHvwKiEzwrtIyo6e1clrnj0IzxQsXcEjC9j7muH8R/ Es73ht2LuCRhegPuaFW4uT8o2J/eb+lcNf6ze6gx82UhD/Ap4/8Ar151qOuX+puxnmYKf4FJA/8A r1Zhs44iGPzv/eb+grPrOqxRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRX1MqMcdq9oCk4puDT1QDHBJ/z/n/PLgoGOppQKcB04P8An/P+e6/h S0fn1/z/AJ/ySij8+v8An/P+SUUfn1/z/n/JKKPz6/5/z/klFH59f8/5/wAkoo/Pr/n/AD/klFH5 9f8AP+f8koqrqOp2Ok2hutQuo7aEE/NI2MnBOAOrHAPAyT6esN1eW1jAZrqZIoxnlz14JwPU9eBR XA638XbC2ZodHtHvG2nE8pMaBscELjcwyTkHb04POa5jUfHVrCSlhA1wcH945KqDjjjqe+enSivN 9a8W63r7yfbb+XyJP+XaNisQG7cBtHXB7nJ4HNclqGuajqbP9ouX8tv+WSHamM5Ax3x6nJorErOo ooooooooooooooooooooooooooorcs/B3iO+lMUOjXasF3ZmTyhjju+Bnkcda0YNA1a5cpHYTggZ /eLsH5tgd6TI9a6bT/hJqk+1r+/trVGQNiMGV1bj5SOB3PIJ6d85rYtfA17Jg3NzDCpXOF+dgeOC OB+RNG6up074V+H7Xa101zetsCsskmxN3GWAXBHfgk9e/Wtq18F6XDgzmW4O3BDPtXPHI24P6nrS bq6TTfDei6T5RsdMtopIs7JdgaQZ6/Oct3I69OOla1ppOnWOw21nCjJna+3LDPX5jz39aM1qA9Of 1+nvV0UlAPTn9fp70CigHpz+v096BRSjJxjn/I96Bk9OaKcsbtjt9T9PenKjHHb6mlAJp6wdMv8A l+FOEfTLUoX3qRY0GOh+p+lOVFGO/wBaUAU5cDGMD/IpwwMYxSilB6cjp/hQD05ooB6cjp/hQD05 ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05oqF58YCkE+tMaXGApBpC3pUO STknP4/T3qLOe/60ykB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CijPv+v096M+9FRN NnAU/j+VRtJ2U/jSFvSogc45qPPTmm0A9ORQD05FFAPTkUA9ORRQD05FAPTkUUA9ORQD05FFQz3c NqEMjgFuFUdT096lt4WuZliRlBI6seKa0ioBk9egpbe7D4OQK77w/p9jpqrIgEk5wfOcDI4x8voO v59TxQsma0Ek34/xrqY5d+Me2ef8/wCf1kBzTZI1dccU2WJZFxx/n/P+e6EZFZV9YCRCMZrD1LS1 ljIxnvUMkeRXnHijwitxIbmBvLmx8xxw3pn/AB/nXkvjDwOJ5Td27eXNj5jt4bjjP+P86ijma24I LR+np9K88mhkt5milUq6nBBrzGaGS3meGZCkiHDKe1X0dXUMpyp6GmVHS0UUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUV9V/n1/z/n/ACfa6KPz 6/5/z/klFH59f8/5/wAkoo/Pr/n/AD/klFH59f8AP+f8koo/Pr/n/P8AklFH59f8/wCf8koo/Pr/ AJ/z/klFc1rXj3w9obyQz3hnuY+sFsPMbO4ggn7oI5yCQf65GoeJtK01mjkuPMmXrFENxznBGegP Xgn/AOuV5zrHxa1m92LpkMWnIMFm4mdjzkZYYxyOMZ4681yd/wCONQuNos40tFHJPEjE89yMY59O 3WiuEubq4vbh7i6nlnnfG6SVyzNgYGSeTwK5qaaW4laWaV5ZG6u7FifxNFRUyiiiiiiiiiiiiiii iiiinxRSTypFFG0kjsFREGSxPAAHc05EaR1RFLOxAVVGST6Ciuh07wH4k1LayaZJDGXCF7kiLb05 2t8xHPUA+1alr4Z1e7wVs2jUttLTEJjpzg8457CkyK6az+EF3JETe6vBDJu4WGIygjjnJK88njH4 1sW/gOdkJuL6ON88CNC4xx3JFG6umsvhf4atd/nR3N5uxjz5sbfps29c989B+Oxb+DdIh3eYks+c Y8yTG36bcetJk11Nlpmn6dv+w2Vta+Zjf5ESpux0zjr1P51s29na2m77Nbww7sbvLQLnHTOPrSVa B6c/r9PepxRQD05/X6e9AooB6c/r9PegUUqgnpk/5HvQMnpzRT1ic9SB9T9KeI2PoPxpQpp6wDjL /l+FKIxxlqUL709Y0GOh478+lPVFGOn40oAp4PTkdP8AClHbkUtAPTkdP8KAenNFAPTkdP8ACgHp zRQD05HT/CgHpzRQD05HT/CgHpzRQD05HT/CgHpzRQD05HT/AAoB6c0UA9OR0/woB6c0UA9OR0/w oB6c0U0uFAJYdP8ACgsABkijOO9QPKXwM4X0/L3qFnLcZ4phbNRg9Of1+nvTRSUA9Of1+nvQKKAe nP6/T3oFFAPTn9fp70CigHpz+v096BRSF1XGT+v096QsF6mjOKgMhYjJ49PyqIuWI549KbnNNB6c img9ORSUA9ORQD05FFAPTkUA9ORRQD05FAPTkUUA9ORQD05FFef+J/iVb2ivaaIVuLgqVNz/AARN nHAP3zwTnp0+9yK5jWPF0UCtBpxEsuCDN/Chzjj+939unWnqnrXBWniW+GpNd3c7zPI255G6/wD6 u2Ow6elYWm+I7y01D7RLMzlmyzHqP/re1Vbqy3sZoiRJxwTwa9J0XXo7hFIYZI4wa9e8O+J4ruNP nAYjsf8A69V4Z+cHIYcEHtXV2l4H4Lc/Wu4sdQEmAzc/WraPmtOOTOK2Ypd2On5/5/z+soNEgXbk kUSquzJIoOMVnyWUEx/eLkHtmsubTrW4b96m5T1XP+H1qMxq3UVgaz4E0XV4X/dG3uShVJkYnacg gkE8/T0J74Ncxrvw08P63A+IWtboxlY543J2sSCCVJ5HUY9GPfBpYkWI/JwD1GeK8SvbK5068ltL uFoZ4m2ujdv8R3B6EV89ahp93pV/NY30DwXMLbXjbqD/AFBHII4IIIqwDkZFQVWooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooor6r/Pr/AJ/z/k+1 0Ufn1/z/AJ/ySij8+v8An/P+SUUfn1/z/n/JKKPz6/5/z/klFV7y/s9OhWa+uoLaJm2h55QgJwTj JPpnj/Jinube1jElzPHChOA0jhQT6c0V5/rfxdsLZmh0e0e8bacTykxoGxwQuNzDJOQdvTg85rl9 R8dWsJKWEDXBwf3jkqoOOOOp756dKK851vxjrviBWivr5vszMW+zxDYnJBAIH3gMDG4kj865PUdf 1LVFKXNy3lEk+Ug2r1zjjrjHGc0VhVm0UUUUUUUUUUUUUUUVYtLG71CUxWVrPcyBdxSGMuQM4zgd uR+dSwW0905S3hkmcDJWNSxx68UV0dj8OPE160O6yS2jlXd5k8qgKMZG5QSwPQYxnnmta28J6xcG PNusSOM75HAxxnkDJH5UmRXTab8IP9U+p6r6+ZFap+WHb8D931HvWxaeBPuNeXvrvSFfywx/DtRu rqdN+HnhrTvKb7D9qlTP7y5cvuz6rnYev930781s2nhXSLXYfs3nOufmmbdnPqPu9/Skya6GzsbP T4jFZWsFtGW3FIYwgJ4GcDvwK1be2gtU2W8McKE5KxqFBPHPFJVgHpz+v096lFFAPTn9fp70CigH pz+v096BRSqC2MAn/I96UAnGP89KUc09YWOMkD8fpTljJxkgfjShTT1hXjL/AOeKcIxxlqUKPWnq iDGAPx59PenBVHpQAKeD05HT/ClB6c0tAPTkdP8ACgHpzRQD05HT/CgHpzRQD05HT/CgHpzRQD05 HT/CgHpzRQD05HT/AAoB6c0UA9OR0/woB6c0UA9OR0/woB6c0UA9OR0/woB6c0UA9OR0/wAKAenN FAPTkdP8KAenNFAPTkdP8KAenNFRtMFwAQT/AC6U1pAuADk0hbFV9xY5Jz+P096hySeT+tMzmkB6 c/r9PegUUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+v096BRUbTdAp/H8vemNJ2U/jSFvSo ckkEtUec45pKAenIpAenIpKAenIoB6ciigHpyKAenIooB6cigHpyKKztX1yw0KzNzfXCoApKRggv IRjhRnk8j6Z5IFVb7UrbTbczXMqqMEqufmfpwBnnr+tKAT0ryTxP491DXWe2tma00/JARGIeVSMf vCDyOvyjjnnOAa4fWPE11qRaGEmC1yQFUkM4xj5jn68e/enhQPrXJVh06iiir+napPp8qlWJQHke n0q/puq3Gmzo8bHYD0/wqrc2SznzFO2UDr2P1r0zRPEEd3DGd4yfevXPDniqK8hiJkAboeapxysj bJBtdeCDXZ2d6HUZNeh6fqSyIAW7etW0kyKvFix6/r9PetMuWI547DP096lzSA9Of1+nvSA9Of1+ nvSUA9Of1+nvQD05/X6e9FeDeOoFt/GupIhyC6v90DlkVj0AHU9ep7knJr5p+JFslr8QdXjQ5DOk n3VXl0Vj90AdSeep6kk5JlT7grna5WnUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUV9V/n1/z/n/J9roo/Pr/AJ/z/klFH59f8/5/ySiuc1vxz4f0 JWE96s86sVNvbESOCDgg84XGejEdD175Oo+JNL01SJbgSSgkeVCQ7ZBwQecDr3I70V55rXxc1O5k kj0i3js4OiSyDzJfvdeflGRgYw2Oea5bUPHV5MzpYRJbx/wu43P16+gyO2D35orgry/vNRmE19dz 3UoXaHnkLkDJOMk9Mk/nXMXFzcXcgkuZ5ZnAwGkcsQPTn60VXqKiiiiiiiiiirVnpl/qO/7DZXN1 sxv8iJn256ZwOOhqa3s7m73fZreabbjd5aFsZ6ZxRXU2fwv8S3W/zYrW024x584O7Pps3dPfHWtq 38G6vNu3pDBjGPMkBz9NuaTIrqbL4Qaem/7dqtzNnGzyEWLHrnO7PUen41s2/gS1Xd9ovZpM42+W oTH1znNJuro9O8B+GtO2lNMinkCBGe5Jl3dOdrHaCfUAflWva+GtItdpWzSRtoUtL8+enOCcZ+go ya6KKOOCKOKJFjjRQqIgwFAwAAOwrUjRY0VEUKigBVXgAccCkpwPTn9fp704UUA9Of1+nvQKKAen P6/T3oFFOVWOMA/5x70oUnHBpQDT1hY4ywH4/SnCMnGSBShfenrCvGWz+P0pwjHGTmlCj1p6qoxj b/nFOAAx0pQB7U4HpyOn+FKD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD 05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/h QD05ooB6cjp/hQD05ooB6cjp/hQD05oqG4u7eytzcXVxFBAgG6SVwqrkgDJJx1P60yWeK3iMs0qR Rr1d2AA6dSTRWMvjTQ5r17Kyu2vrtFz5VpE0oPTHzj5ByQMlgATyRWePEOnSXDW9vObmdRnZAhfP T+IfL3AyTgdyKM4rXeYsABwP/wBXvV5pC3A6U0tmogenP6/T3pgptAPTn9fp70CigHpz+v096BRQ D05/X6e9AooB6c/r9PegUUhcKMk/r9PekLADk/54ozioWkLY5wPT8qiLlu/FNzmmA9ORTQenIpKA enIoB6ciigHpyKAenIooB6cigHpyKKAenIoB6ciiuN8T/EKy0Qva2IW8v1JR1yQkRx/Ef4jnsPQ5 II5wNY8U2+nlobbbcXIJVhk7UOO5789h78inKpPPavJNT1W+1i8N3qFw08xULuYAYA6AAcAfTuSe 9cPeXtxfz+fdSmSTAGTxgDsAOlSAYHFU6gooooooooooq1ZX81jIGjY7c5K561asr+exlDxOQAcl c8Gq91aLcgHOx16MB29K9T8G66mpXMELMS5z+gzzzXsnw+8Spqt9bWzsTISf0UnnmqcBeO4EMoww /X3rvgenP6/T3r1IHpz+v096u0A9Of1+nvQD05/X6e9FZOv+IbHw7p5uLuVfMZW8iHJzKwGcDGcD oM4wMj15xPE3inTvCumG6vZl811b7PBk7pnC52jGcDoC2MDIz15VQSeK+f7m4lu7qa5nffNM5kkb AGWJyTx718wXd1NfXk93cvvnnkaWR8AbmY5JwOOpqboKiqGiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiivqO8v7PToVmvrqC2iZtoeeUICcE4yT6 Z4/yfZp7m3tYxJczxwoTgNI4UE+nNFcFrXxc0u2jkj0i3lvJxwkso2Rcg88/McHAwQM88+vM6h46 s4VdLCJ55P4XcbU6dfU4PbA78+pXnmt+Odf11mE988EDAqbe2JjQggAg85YH/aJ6n1rldR8SapqR IkuWjiII8qElVwRgg9z+JPU0VzlZNFFFFFFFamm+G9a1fyjY6ZcypLnZLs2xnGc/OcL2x168VdtN J1C+2fZrOV1fO19uFOP9o8frRkV01j8KdeuFie5ms7VWbDo0hd0GcZwo2k45A3flWvbeCdSlCNNJ BACfmUtuZRn24Pr1pNwrp9P+EmlQbWv7+5umDhtsYWJGXj5SOT68gjr2rYtfA1lHg3NzNMwbOFAR SOOCOT+RpN1dTp3hLw/pe02mlWquriRZHXzHVuMEMxJHQdD/APX2rXQ9Ls9pgsoQwYOGYbmB46Ek kUZrZB6c/r9PetAUlAPTn9fp70CigHpz+v096BRQD05/X6e9Aopyo57H8/p70oVj2pQDUiwnjLj/ ADiniM8ZYUoX3pywoMZOfx+lKI14yc/jShRUihRjGBx/hTwAMYx0pRilB6cjp/hQD05ooB6cjp/h QD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp /hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05ooB6cjp/hQD05oqvd6 hZ6dCs19eW9tETtDzyBATjOMk9cA1FPdW9pGslzcRQoTgNI4UZ9OT1orldR+KHhjT8ql3LeSK+xk toicY6ncxCkcdQT1GOKxbvxlo1rkLO9wyttKwoT+OTgEfQmjNctffGiUrKmn6OisDiKW4mLDGerI AOSO27gnqe+Nc/EF8OtrYKDnCPLJnjPdR7e/50ZrltT+JPijUvNX+0PssMmP3dqoTbjHRuXGSP73 c9uKxbzxdrN5vH2ryI2x8kK7cYx0b73b1pM07QPB+teMrj7fd3EqW0mQ19cN5jOVAAABOW7DPQYP ORil0zQdQ1+X7VPK6wtkG5lO4sRgYAJyfTPTg+mKQmvYdC8PaZ4dtDBp0GzftMkjNl5CABknP14G AMnA5rvNN0qz0qDyrSPbuxvcnLORjkn+nTk0mc1qA9Of1+nvV0UlAPTn9fp70CigHpz+v096BRQD 05/X6e9AooB6c/r9PegUVG0oHAOT9fp70xpAOAeaQmotxYgls1HuJIJNJmkB6cikB6cikoB6cigH pyKKAenIoB6ciigHpyKAenIoqrfalZ6Xam5vrqKCED7ztjJxnAHUnAPAyahubuCzh865mSKMd2PX jOB6n2pRz0rynxL8SL3Ut1tpJksrT5T5udszEcnkH5RnHTnjryRXFav4suLvMNjvt4ePnziQ+vIP A/w684p4THWuGrnKdRRRRRRRRRRRRRRRRRRVvTNRn0q/hu4MF4pFfa33WwcgGrulapcaPqdvfW20 yQSrKFcZVipyAfbiopoFmC54ZTlW9DXsuj/EPQdTSNZrj7DcNwY7jhQQAT8/3cdQM4Jx055990H4 p+G9YSJLi6/s66bhorrhQQoJIk+7jqASQTjpyMhQj3qvrHxL0XTlZLIvqFwGK7Y8qgIIzlz1HXBU NnHvmq2vfFzw/pSMlgz6pdKxXZFlIwQQDlz1B5wVDA49DkgQnrxXluv+I9Q8SXi3F864RdscUeQi DvgEnk45P9AK8Z8TeK9U8WX6XWpSLiNdsUMQIjjHGcAk8nGSSSfwAAkACjismsSloooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooq3qOp32rXbXW oXUtzMc/NI2cDJOAOgGSeBwM1Pd3lzfTma6meWQ93OcDOcD0HJ4FFVKgorcs/B3iO+lMUOjXasF3 ZmTyhjju+Bnkcda0YNA1a5cpHYTggZ/eLsH5tgd6TI9a6bT/AISapPta/v7a1RkDYjBldW4+Ujgd zyCenfOa2LXwNeyYNzcwwqVzhfnYHjgjgfkTRurqdO+Ffh+12tdNc3rbArLJJsTdxlgFwR34JPXv 1ratfBelw4M5luDtwQz7VzxyNuD+p60m6uk03w3ouk+UbHTLaKSLOyXYGkGevznLdyOvTjpWtaaT p1jsNtZwoyZ2vtywz1+Y89/WjNagPTn9fp71dFJQD05/X6e9AooB6c/r9PegUUDnH+fT3oHainrG 5xx+Z+nvTgjHH+fSlANPWDplx+H4U4R9MtShfenrCgxzn6n6U4Rr65/GlCinrgYxgcU4YGMYpRSg 9OR0/wAKAenNFAPTkdP8KAenNFAPTkdP8KAenNFAPTkdP8KAenNFAPTkdP8ACgHpzRQD05HT/CgH pzRQD05HT/CgHpzRQD05HT/CgHpzRQD05HT/AAoB6c0UA9OR0/woB6c0UA9OR0/woB6c0UA9OR0/ woB6c0UA9OR0/wAKAenNFVLzVdP03y/t+oWtr5gOzz5lTdjGcZPPUfnUNxe2tps+03UMO7O3zZAu cYzjJ560Vyd78V/DFp5fkzXV5uznyICNnTrvK9eemen54dx430aDZ5ck1xnOfLjI29Ou7H9aM1yd 78Z9Rfy/sGk2sGM7/PkaXd0xjG3Hf1/xw7j4g3bbfs1jDHjO7zWL5+mMY7+tGa5nUfiD4o1Lcr6r LBHvLqltiLb143L8xAz0JPvk1j3finWbzIa9eNd24LD8mPbI5I+pNJmubllknmeaaRpJZGLO7nLM TySSeprJd3kkaSRmd2JLMxyST3JoplNoqW2tp7y4WC1gknmfO2OJCzHAzwBz0p8UMs8qxQxvJI3R EUkn8BRXqnhX4Xx2zx3uvFJZVZXS0RgyDjpJ/eOT0HHHVgcV2ui+DUhZLjUyruCGWBTlen8Xryeg 4475ppPpXpQPTn9fp711wpKAenP6/T3oFFAPTn9fp70CigHpz+v096BRQD05/X6e9AopCwUAk/r9 PekLADJNGahaUtwDgf8A6qjMhPQ4FNzTAenIpgPTkUlAPTkUA9ORRQD05FAPTkUUA9ORQD05FFAP TkUA9ORRXM+JfG+neHMwf8fV+Ap+zIcbQe7NyBx25PI4wc1kav4itdK/d/665GP3SnGAfU9uPx5H 1pyqT9K8f1vxBqPiC6WfUJ9+zIjjUYSME5wB+XJyTgZJxXCahql3qkwkupN23OxQMKoPYD+vXgU8 ADpWZVOloooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooor3Cy+F/hq13+dHc3m7GPPmxt+mzb1z3z 0H4+jW/g3SId3mJLPnGPMkxt+m3HrTcmupstM0/Tt/2GytrXzMb/ACIlTdjpnHXqfzrZt7O1tN32 a3hh3Y3eWgXOOmcfWkq0D05/X6e9TiigHpz+v096BRQD05/X6e9AopRk4xz/AJHvQMnpzRTljdsd vqfp705UY47fU0oBNPWDpl/y/CnCPplqUL71IsaDHQ/U/SnKijHf60oApy4GMYH+RThgYxilFKD0 5HT/AAoB6c0UA9OR0/woB6c0UA9OR0/woB6c0UA9OR0/woB6c0UA9OR0/wAKAenNFAPTkdP8KAen NFAPTkdP8KAenNFAPTkdP8KAenNFAPTkdP8ACgHpzRQD05HT/CgHpzRQD05HT/CgHpzRQD05HT/C gHpzRQD05HT/AAoB6c0Vnahr2k6RkahqdrbusfmeXJKA5X1C5yehxgHNVbrU7Gxz9qvIYmCb9rON xHsM5PQ9KK5PUfi34etMraC6vn8vcpjj2Ju7KS5BHTqFPXv0rEu/HOlQZEAmuW2ZBVNq59CWwfxw etGa5TUfjHq8+5dPsLW0Qx7d0hMrq3PzA8D04Knp36Vh3Xj6+kyLW2hgUpjLEuwPqDwPzBozXMXv jrxRf+X52tXS+XnHkMIc5x12AZ6d6x7jxLrN1t8zUZl25x5Z8v8APbjP40ma56sqiiiiiiiiiiii it/w14R1LxNcD7Mnl2iyBJrl8bU78DOWOOw9RnGc1p6RoV3rEo8ldsAYLJM3Rfp6n2HqM4zSE4r2 bwz4S0zwzAPsyeZdsgSa6f7z854GcKM9h6DOcZr0DR9Ds9HjHkrunZQrzN1bv68D2HoM5pM5reB6 c/r9PetMUlAPTn9fp70CigHpz+v096BRQD05/X6e9AooB6c/r9PegUUxpQvGefr9Pems4XjPNITi oS5Yglv88VEWLEZNJnNID05FID05FJQD05FAPTkUUA9ORQD05FFAPTkUA9ORRUU9zBaQGe5nihhU DdJI4VRkgckn3/WmSTRwRmSWVI416s7AAdO+aUc15h4n+Jklwj2ehhoomUo904Ic89U544HU889A RmuP1jxe8qtBpuUQgq0zDDf8B54+p557Ypyp6155JJJNK8srtJI7FmdjksT1JPc1yru0js7sWdjl mY5JPqafTaSiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiivqMHpz+v0969mFMpVBPTJ/wAj 3oGT05op6xOepA+p+lPEbH0H40oU09YBxl/y/ClEY4y1KF96esaDHQ8d+fSnqijHT8aUAU8HpyOn +FKO3IpaAenI6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKAen I6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKA enI6f4UA9OaKAenI6f4UA9OaKxr7xb4f01JWutZslaE7ZI1lDyKcgEbFJbOfbiqFxrml2iuZtQtw YzhlDhmBzjG0ZOfworltS+L+iWvmJYW91fSLjY23yo3zjPJ+YY5/h6j05rFu/HmnQ71toprl1xtO NiN0zyeR37f40Zrk9S+L+uXXmJYW9rYxtjY2DLInTPJ+U5wf4eh9eaxLzx5qU29baKG2U42tje69 M8ng/l3/ABozXJ6n4n1zWPNW/wBVupo5cb4vMKxnGMfIML2B6deetYd5rOpX+8XN7NIj43Juwhx0 +UcdvSkrJqjRRRRRRRRRRRRRRRRRRRRRRXpXhX4XvcrHe6+WihZVdLRGw556Sf3RjsOeeqkYrrtE 8GtMEuNTJRCAywKcMef4vTjsOee2KQn0r1S1trezt0t7WGKCFPuxxKFUZOTgDjqf1rtYYYreJYoY 0jjXoiAAD8BTalB6c/r9PeniigHpz+v096BRQD05/X6e9AooB6c/r9PegUUbgBknj6/T3ozgZJoq Fps4CnA9c/So2kzwD+NIW9KjB6ciowenIptAPTkUA9ORRQD05FAPTkUUA9ORQD05FFAPTkUA9ORR WF4i8Wad4bg/0iTzLtoy0Vsn3n6Dk9FHufQ4zjFZ2q63a6TF+9ffMVykK9W+voPc+/WlAJryDxH4 r1LxJN/pMmy0Vy0Vsn3U4xyerHHc+pxjOK4TVdbu9Wk/fNthVspEvRe34n3PqelSBQKwqzaWiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiivq1UQYwB+PPp717aFUelAAp4PTkdP8AClB6 c0tAPTkdP8KAenNFAPTkdP8ACgHpzRQD05HT/CgHpzRQD05HT/CgHpzRQD05HT/CgHpzRQD05HT/ AAoB6c0UA9OR0/woB6c0UA9OR0/woB6c0UA9OR0/woB6c0UA9OR0/wAKAenNFAPTkdP8KAenNFAP TkdP8KAenNFAPTkdP8KAenNFc9e+OvDGn+X52t2rbwceQTNjGOuzOOvf+lZdx4l0a12eZqMJ3Zx5 ZMnp125x+NGa5jUfjHpVvldPsLq7dX25kIiRl/vA/MfTgqOvbpWPd+PrKLItbaadg2MuQikeoPJ/ MDrRmuU1H4t+IrvK2gtbFQ+5Wjj3vt5wpL5B7cgDp26Vh3fjnVp8iAQ2y7sgom5sehLZB+uBSZrk tR17VtX3DUNSurlDJ5nlySkoG55C9B1PQcZrDu9Tvr7IuruaZS2/a7kqD7DoOp6UVn1Voooooooo oooooooooooooooooooorS0XQtR1+9W10+3ZyWAeQg7Igc8s3YcH3OOMniren6bdancCG1iLHIDO R8qe7Ht0NGcV7R4W8C6Z4a23GftWoDd/pLjbtBxwq5IHHfk8nnBxXoOi+G7PSNsv+uuhn98wxgHH AGeOO/Xk9jimk5rqQenP6/T3raFJQD05/X6e9AooB6c/r9PegUUA9Of1+nvQKKAenP6/T3oFFNaR Vxzz6Z+nvTS4Xvz9aM4qAuWIy34VEXLEZNNzmkB6cikB6cikoB6cigHpyKKAenIoB6ciigHpyKAe nIopskscMTSyyIkaKWZ3OAoHUk5pGdY0Lu6qijLMxwAPelrzzxP8S0tmez0LbLKpKPdOMoOOqc/M c9zxx0YHNctrHi9Yi0Gm4dwSrTMMqOP4eeee54475pyp615bJJJNK8srtJI7FmdjksT1JPc1xju0 js7sWdjlmY5JPqafTaSiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiivrAHpyOn +Fe3A9OaWgHpyOn+FAPTmigHpyOn+FAPTmigHpyOn+FAPTmigHpyOn+FAPTmigHpyOn+FAPTmigH pyOn+FAPTmigHpyOn+FAPTmigHpyOn+FAPTmigHpyOn+FAPTmimSTRwQtNNKkcUalnd2wqgckkk8 fWkeRI4zJI6oirlmY4AHqTRXOaj8QfDGmZWTVYp5BHvVLYGXd/s7lyoJx3I7Z4rIu/FOjWeQ16kj BNwWEF8+2RxnjuaM1yt58aLOOZRY6PPPFt5aeYRNn0wA3Hvnv09cW4+IMCyAW1hJImOTJIEOfoM/ zozXLXvxX8UXXl+TLa2ezOfIgB35x137umO2OtY1x431mbb5bw2+3OfKjzu+u7NJmuTvdV1HU/L+ 3391d+XnZ58zSbc4zjJ4zgflWHcXt1ebftNzNPtzt82QtjPXGfpRVSoKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKK7jwj8OrvW9l5qfmWmnOm+MqQJJc9MA52jvkjkYxnOR0eheFJ9R2z3m+C0Zd ykEb3z0x6Dvkj0x1zSE17Dp2m2WlWi2thbRW8Ix8sYxk4AyfU4A5OSa720tLeygENtCkUYxwoxk4 AyfU+9Nq0D05/X6e9TCigHpz+v096BRQD05/X6e9AooB6c/r9PegUUZ9/wBfp70Z96KiaboFP4/l UZk6BT+NIW9KiBzjmo89OabQD05FAPTkUUA9ORQD05FFAPTkUA9ORRQD05FAPTkUVma14g07w/ar PqFxs35Ecajc8hAzgD+p4GRkjNVNQ1S10uFZbqXbuztUDLMQM4A/r05FKAT0rx/xN431LxHmD/j1 sDt/0ZGzuI7s2ATz26cDjIzXCav4iu9VzH/qbbj90pzkjuT35/Dp9akCgfWuZrHpaKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK+sAenI6f4V7cD05paAenI6f4UA9OaKAen I6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKAenI6f4UA9OaKhuLu3src3F1cRQQIBuklcKq5IAy ScdT+tMlnit4jLNKkUa9XdgAOnUk0VzOpfEnwxpnmL/aH2qaMD93aoZN2cdG+4eD/e7HvxWPd+Lt Gs94+1ee6Y+SFS2c46N90/nRmuT1L4zn96mlaT6eXNdSfTO5F/Efe9D7Vh3fxB++tlY+mySZvpnK j8e/+FGa5nUfih4ov9yx3cVnG0ZjZLaMDOc87mywPPUEYxxzWPd+MtZushZ0t1KbSsKY/HJyQfoa TNcreX95qMwmvrue6lVdoeeQuwHXGSenJ/OsW4uri7kElzPLM4G0NI5YgemTRVeoqKKKKKKKKKKK KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKtafpt7qt2trYW0lxM2PljXOBkDJPQDJHJ4GamtbS4vZx DbQvLIeyjpzjJ9ByOTRXsPhH4d2mieXeamIrvUUk3xlSTHFjpgHGTznJHBxjpk97oXhSDTttxebJ 7tW3KQTtT0x6nvkj0x0yWk5ruAenP6/T3roxSUA9Of1+nvQKKAenP6/T3oFFAPTn9fp70CigHpz+ v096BRSF1XGT+v096QsF6mjOKgaQvjkY9KiLlscjFNzmmg9ORTQenIpKAenIoB6ciigHpyKAenIo oB6cigHpyKKAenIoB6ciiuG8S/Eiz0zNtpPl3t2Np83O6FQeTyD8x+nHPXIIrnNX8WQWeYbHZcTj Hz9Yx+IPJ+nr14xT1UnrXk15eXOoXkt3dzNNPK253bqf/rdsdq4i4uJbqd555DJK5yzHvTwMCoKj oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooor6vUn5Of4f8K9uH8P0 pR2+lCk/Jz/D/hQP4fpQO30oUn5Of4f8KB/D9KB2+lCk/Jz/AA/4UD+H6UDt9KFJ+Tn+H/Cgfw/S gdvpXMfEG7ubLwLf3FrcSwTqse2SJyrDMqA4I56Ej8ax/FM81v4buZYJXikATDoxUj517ijsPpXz 7dXVxe3D3F3PLPO+N0krlmbAwMk89ABXlk00txK0s8ryyN1d2LE/iaSoaZRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRXsfwkjRfDV3KEUSNeFWcDkgKmAT6DcfzPrXfeBk UaRO4UB2uCC2OSAFwP1P5mmt1Fd8CeOT2/pXTAnjn/PFJQCeOT2/pQCeOf8APFFAJ45Pb+lAJ45/ zxRQCeOT2/pQCeOf88UUAnjk9v6UAnjn/PFFAJ45Pb+lAJ45/wA8UVASS4yexqIklhz2pvekUn5f 93/CkU/d+lIO1Ck/L/u/4UKfu/SgdqFJ+X/d/wAKFP3fpQO1Ck/L/u/4UKfu/SgdqFJ+X/d/woU/ d+lA7VzXj2WSLwRqDRyMjFEUlTgkGRAR+IJH41k+JXdPDtyVZlJVQSDjgsoP6E05PvCvC683qSii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiv/Z ________________________________________________________________________________
Date: Aug 19, 2008
Subject: Re: tail wheel
Marc, In my opinion, 10 lbs is unacceptable. My tail wheel complete is half that weight. Five extra lbs. is a huge amount way back on the tail on an airplane that is already tail heavy to begin with. Please reconsider. Dan Helsper Poplar Grove, IL. **************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals?ncid=aoltrv00050000000047) ________________________________________________________________________________
Date: Aug 19, 2008
Marc, I like the idea, do you have any plans to support the attaching point for the turn buckle? NX920Y flying well in MO with no heat problem anymore. Chet ________________________________________________________________________________
From: Marc Davis <marcs_listreading(at)hotmail.com>
Subject: tail wheel
Date: Aug 19, 2008
Chet I was thinking about an eye bolt through the tail post near the bottom. Also adding blocking where the last brace meets the tail post to help trans fer loads to the brace and longerons. The hinge would look something like the hinge for the bell crank (but welde d). Also adding a travel stop so the bungee would always be under some tension and the tail wheel would not flop down in flight. The normal spring is fully compre ssed at 190lbs so a 400 lb bungee with a 2 to 1 advantage in the tail wheel arm should be abo ut the same. My old tail wheel with two leaf spring compressed with about 100 lbs. Marc From: Chethartley1(at)mchsi.comTo: pietenpol-list(at)matronics.comSubject: Re: Pi etenpol-List: tail wheelDate: Tue=2C 19 Aug 2008 20:13:57 -0500 Marc=2C I like the idea=2C do you have any plans to support the attaching point for the turn buckle? NX920Y flying well in MO with no heat problem anymore. Chet _________________________________________________________________ Get thousands of games on your PC=2C your mobile phone=2C and the web with Windows=AE. ________________________________________________________________________________
Subject: tail wheel
Date: Aug 19, 2008
Dan I think you misread my post. I agree that 10.25 lbs is too heavy. This is what the plane came with. I looking for a better solution. The attached photo is one idea I'm considering to make it lighter. I like the look of your tail wheel. I was thinking that if you could replace the spring with a bungee it would be lighter still. Thanks for the info about the weight of your solution. Marc From: HelsperSew(at)aol.comDate: Tue=2C 19 Aug 2008 20:45:30 -0400Subject: Re: Pietenpol-List: tail wheelTo: pietenpol-list(at)matronics.com Marc=2C In my opinion=2C 10 lbs is unacceptable. My tail wheel complete is half tha t weight. Five extra lbs. is a huge amount way back on the tail on an airpl ane that is already tail heavy to begin with. Please reconsider. Dan HelsperPoplar Grove=2C IL. It's only a deal if it's where you want to go. Find your travel deal here. _________________________________________________________________ Be the filmmaker you always wanted to be=97learn how to burn a DVD with Win dows=AE. ________________________________________________________________________________
Date: Aug 19, 2008
Marc, You have come up with an interesting concept. A couple of things that came to mind when I looked at it: Accessing the bungees: bungees don't last forever, so you would probably want a provision for accessing the bungees that wouldn't require you to remove the fabric from the rear of your fuselage in order to access the area. With round access panels it could be almost impossible to remove a bungee, then install and tension a new one. You would possibly want to consider making the fuselage sides of the last bay (or from the tail post to however far forward you deem necessary) sheet metal panels, so you can remove them entirely and be able to work back there. You would need some sort of upstop, or some way to prevent damage to the fuselage if the bungee breaks. If you put bumpers on the fuselage or the tailwheel "V", you would need to ensure they are of sufficient thickness to absorb a hard landing bungee failure without contacting the tailwheel during normal landings (you wouldn't want the tailwheel banging/bottoming out all the time). If you were to install a cable inside the fuselage to catch the tailwheel internally, possibly connected to another eyebolt in the same position, you would need to consider the momentary loads that a hard landing bungee failure would impose upon the tailpost and make sure that wouldn't damage the structure. Dan's design is pretty simple, and at 5 lbs is relatively light. A bungee may be lighter than a spring and the two small cups that hold it in place, but you would not just be replacing the spring with a bungee. You would be replacing the spring with a bungee, eyebolt, turnbuckle, the additional tube you have into the fuselage to catch the bungee, the downstop, and whatever upstop mechanism you choose, and any access panels you may need to add back there for your suspension. Would those items together weigh less than the spring? That would be something to consider calculating. Just some food for thought. Have a good evening, Ryan On Tue, Aug 19, 2008 at 5:44 PM, Marc Davis wrote: > I weighed the tail wheel that came with my plane and it came to 10.25 lbs. > I've been thinking about building a new one more like the original design. > In the interest of keeping things light I was thinking about using a > bungie > instead of the coil spring normally used. Attached is a crude picture of > what I have in mind. > I know the is dangerously close to an 'improvement' but what do you think? > The bungie would be attached to the tail post with a turn buckle for > adjustment. > If the picture doesn't come through here is a link. > > > http://picasaweb.google.com/sandy.n.marc/Pietenpol/photo#5236362712528410898 > > Thanks for your thoughts. > Marc > ________________________________________________________________________________
Date: Aug 20, 2008
Subject: tail wheel
Has anyone installed an RV-like tailwheel and spring assembly on a Piet? A good photo of one is about halfway down this page: http://www.flycorvair.com/wagabond.html Jeff ________________________________________________________________________________
Date: Aug 19, 2008
Bob Siebert did. http://westcoastpiet.com/images/Bob%20Siebert/DS0004.jpg Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Tuesday, August 19, 2008 9:30 PM Subject: RE: Pietenpol-List: tail wheel > > Has anyone installed an RV-like tailwheel and spring assembly on a > Piet? A good photo of one is about halfway down this page: > http://www.flycorvair.com/wagabond.html > > Jeff > > > > ________________________________________________________________________________
Date: Aug 20, 2008
Subject: No clamps on ribs?
I started a prototype rib just to get familular with procedures and methods. I bought some Craftsman, 3/4" mini clamps to hold the gussets. I see on the T-88 bottles it states to use minimal clamping force as too much clamping will starve the joint. I believe these clamps are too tight. I am thinking about finger pressing the gussets in place and let set...no clamps. What say you? ________________________________________________________________________________
Date: Aug 20, 2008
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Mike, This is what I did; see my site for more pictures. Jack www.textors.com ________________________________________________________________________________
Date: Aug 20, 2008
Subject: Re: No clamps on ribs?
Get some coated nails, a comfortable sized long nosed pliers, a good heavy headed small hammer and forget about clamps. Nathan and Levi **************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals?ncid=aoltrv00050000000047) ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Date: Aug 20, 2008
Remember, you want ALL the ribs identical!!! Use blocks over rib dwg. to hold all the wood. I even cut 2 pieces of my spar and put them on my rib print. Then used the glue coated nails from ACS, small spring loaded needle nose pliers. and small hammer and nailed the gussets down. Let dry over night.... then do other side. 1 rib per day.......... got-em done in no time. dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Michael Perez Sent: Wednesday, August 20, 2008 8:35 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: No clamps on ribs? I started a prototype rib just to get familular with procedures and methods. I bought some Craftsman, 3/4" mini clamps to hold the gussets. I see on the T-88 bottles it states to use minimal clamping force as too much clamping will starve the joint. I believe these clamps are too tight. I am thinking about finger pressing the gussets in place and let set...no clamps. What say you? ________________________________________________________________________________
Date: Aug 20, 2008
Subject: Re: From print to jig...how?
Go raid your wife's dressmaking supplies, you are looking for a "tick wheel" its a little handle with a thin wheel on it with notches, it is used for transferring a dress pattern to material, we use colored wax transfer papers between the patterns and the cloth and trace with the tick wheel, it leaves colored dotted lines on the cloth. Use carbon paper instead. Any fabric store should sell tick wheels for less the $2. Regards, Chrissi (fabricating our Cozy engine cowls now) CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ============================= **************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals?ncid=aoltrv00050000000047) ________________________________________________________________________________
Date: Aug 20, 2008
The clamps that Jack used work good if the ply pcs are made a little big so you can route off the excess. Because the Plywood can move around a little from the pressure from the clamp if the clamp is not on straight. But you can glue two sides at once. When we build ribs we do one side at a time and use 2 pound weights on each pc of ply wood. Its about the right amount of pressure. You still have to make the ply pcs a little big on the outside of the rib so you can route them off for a very nice finished product. Jerry Grogan Sky Classic Aircraft ----- Original Message ----- From: Jack T. Textor To: pietenpol-list(at)matronics.com Sent: Wednesday, August 20, 2008 10:57 AM Subject: RE: Pietenpol-List: No clamps on ribs? Mike, This is what I did; see my site for more pictures. Jack www.textors.com ________________________________________________________________________________
Date: Aug 20, 2008
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Them damned southern boys always got to copy us yankees..... Kenneth M. Heide, BA, CPO, FAAOP - --- On Wed, 8/20/08, Isablcorky(at)aol.com wrote: From: Isablcorky(at)aol.com <Isablcorky(at)aol.com> Subject: Re: Pietenpol-List: No clamps on ribs? Date: Wednesday, August 20, 2008, 11:00 AM Get some coated nails, a comfortable sized long nosed pliers, a good heavy headed small hammer and forget about clamps. Nathan and Levi It's only a deal if it's where you want to go. Find your travel deal here. =0A=0A=0A ________________________________________________________________________________
Date: Aug 20, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Like Nathan (or is it Corky?) said, use the AN501 nails from AS&S and just nail the little suckers down. For Resorcinol you need the nails spaced clo sely together (about every =BD" to =BE") but for T-88 just one at each corn er is sufficient. Or staple them down and remove the staples later. Don't obsess over it. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of JERRY GROGAN Sent: Wednesday, August 20, 2008 2:16 PM Subject: Re: Pietenpol-List: No clamps on ribs? The clamps that Jack used work good if the ply pcs are made a little big so you can route off the excess. Because the Plywood can move around a little from the pressure from the clamp if the clamp is not on straight. But you can glue two sides at once. When we build ribs we do one side at a time and use 2 pound weights on each pc of ply wood. Its about the right amount of pressure. You still have to make the ply pcs a little big on the outside of the rib so you can route them off for a very nice finished product. Jerry Grogan Sky Classic Aircraft ----- Original Message ----- From: Jack T. Textor <mailto:jtextor(at)thepalmergroup.com> To: pietenpol-list(at)matronics.com Sent: Wednesday, August 20, 2008 10:57 AM Subject: RE: Pietenpol-List: No clamps on ribs? Mike, This is what I did; see my site for more pictures. Jack www.textors.com _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Aug 20, 2008
Copy, Hell - I notice you Yankees are still using needle-nose pliers, when any good Southerner knows to go to Radio Shack and get some of those little spring-loaded electronics probes for 99 cents. You just squeeze the plunger and a little hook extends from the probe. You hook that over the nail then release the plunger and the nail is held securely whilst you whop it into place with a tack hammer. Jack Phillips Raleigh, NC But born and raised in Tennessee _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KMHeide, BA, CPO, FAAOP Sent: Wednesday, August 20, 2008 2:30 PM Subject: Re: Pietenpol-List: No clamps on ribs? Them damned southern boys always got to copy us yankees..... Kenneth M. Heide, BA, CPO, FAAOP --- On Wed, 8/20/08, Isablcorky(at)aol.com wrote: From: Isablcorky(at)aol.com <Isablcorky(at)aol.com> Subject: Re: Pietenpol-List: No clamps on ribs? Date: Wednesday, August 20, 2008, 11:00 AM Get some coated nails, a comfortable sized long nosed pliers, a good heavy headed small hammer and forget about clamps. Nathan and Levi _____ It's only a deal if it's where you want to go. Find your travel deal here <http://information.travel.aol.com/deals?ncid=aoltrv00050000000047> =2E _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Aug 20, 2008
I wish I'd have read about those spring-loaded electronics probes before I whopped the dickens (technical term) out of my fingers nailing my gussets in place. Tom Stinemetze McPherson, KS - neither North, South, East or West according to the weather people. (central being somewhere between Chicago and New York) >>> "Phillips, Jack" 8/20/2008 1:40 PM >>> Copy, Hell I notice you Yankees are still using needle-nose pliers, when any good Southerner knows to go to Radio Shack and get some of those little spring-loaded electronics probes for 99 cents. You just squeeze the plunger and a little hook extends from the probe. You hook that over the nail then release the plunger and the nail is held securely whilst you whop it into place with a tack hammer. Jack Phillips Raleigh, NC But born and raised in Tennessee ________________________________________________________________________________
Date: Aug 20, 2008
I'm with Corky, Use aircraft nails, but I used a tack hammer. Magnet on one tip to pick up the nail, then with a little practice, set the nail and turn the hammer over, and hammer home. Nothing flew off yet. PS I'm 210# and took up a 190#'er. with 10 gallons aboard. Next plan is to take me and a 230#'er up. No white knuckles so far walt evans NX140DL ----- Original Message ----- From: Isablcorky(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, August 20, 2008 12:00 PM Subject: Re: Pietenpol-List: No clamps on ribs? Get some coated nails, a comfortable sized long nosed pliers, a good heavy headed small hammer and forget about clamps. Nathan and Levi ------------------------------------------------------------------------- ----- It's only a deal if it's where you want to go. Find your travel deal here. ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Aug 20, 2008
It has been mentioned before, but probably bears repeating. What I used was light weight staples. Buy a light weight staple gun and use either 1/4" staples (on 1/16" gussets) or 3/16" on thicker gussets. After the adhesive cures, use small end nippers to grip and remove the staples. I also used aircraft nails and nailing strips on thicker plywood surfaces such as the fuselage sides. Once you get a system down using the hand staple gun works real well. I think I picked up my gun at Home Depot for less than $10 and 1,000 staples only costs a couple of bucks. Rick Schreiber Valparaiso, IN ----- Original Message ----- From: TOM STINEMETZE Sent: 8/20/2008 2:06:19 PM Subject: RE: Pietenpol-List: No clamps on ribs? I wish I'd have read about those spring-loaded electronics probes before I whopped the dickens (technical term) out of my fingers nailing my gussets in place. Tom Stinemetze McPherson, KS - neither North, South, East or West according to the weather people. (central being somewhere between Chicago and New York) >>> "Phillips, Jack" 8/20/2008 1:40 PM >>> Copy, Hell I notice you Yankees are still using needle-nose pliers, when any good Southerner knows to go to Radio Shack and get some of those little spring-loaded electronics probes for 99 cents. You just squeeze the plunger and a little hook extends from the probe. You hook that over the nail then release the plunger and the nail is held securely whilst you whop it into place with a tack hammer. Jack Phillips Raleigh, NC But born and raised in Tennessee ________________________________________________________________________________
Date: Aug 20, 2008
Use nails, and a wire-stripping pliers, with the small serrations in the jaws, to hold the nail straight. Dan Helsper Poplar Grove, IL. **************It's only a deal if it's where you want to go. Find your travel deal here. (http://information.travel.aol.com/deals?ncid=aoltrv00050000000047) ________________________________________________________________________________
Subject: takeoff performance, Walt Evans
Date: Aug 20, 2008
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <michael.d.cuy(at)nasa.gov>
PS I'm 210# and took up a 190#'er. with 10 gallons aboard. Next plan is to take me and a 230#'er up. Walt--that is AMAZING. You've got a 65hp right ? Can I ask things like your runway length, obstacle heights at runway ends, were there any winds, and what was the OAT ? I used to be able to take 200 pound passengers when my engine was tight but now....not so much. I wait until I get a nice 70 F day with some wind down the runway and then still restrict my passenger weight to around 160, 170 max. My empty weight is 632lbs. Mike C. ________________________________________________________________________________
Subject: Re: takeoff performance, Walt Evans
Date: Aug 20, 2008
Mike, I regularly carry my Dad. He is about 225lbs. or so. I go about 180lbs. I've gone with full fuel several times. On Andrew's Brodhead trip this year he carried himself and Nigel Hitchman on a couple of flights. One of which was for a TP cutting routine out of the hayfield. I would imagine that makes for a total passenger weight of about 430lbs or so. A bit much for my taste, but they seemed to make out just fine. Don't really know other conditions. Don Emch Read this topic online here: http://forums.matronics.com/viewtopic.php?p=199703#199703 ________________________________________________________________________________
Date: Aug 20, 2008
Mike, Yeah A-65 With the 190'er aboard I cleared the end of the 2500' runway at probably 300'. Not really any trees at the end. Just a lake in this direction. It was a coolish morning, mayby 75 deg. My fear is not making the trees, only that the engine won't quit. Knock on wood, it hasn't burped yet. This Youtube,,, http://www.youtube.com/watch?v=CLrIDeDLR48 was last year, of me taking my friend Don, who's mayby 170/180 up in the AM. The runway is 2500' and we started at the end, not using the 500' grass end. You can see how we did. One BIG thing that I've found,,Is that with the P factor on the A-65, It's textbook. Have to hold right rudder on climbout. I built my plane and engine mount right to the print. Except about 1 3/4" longer. So it should fly like all the rest. If you watch the ball on climbout, you see that by "stepping on the ball" the climb increases, and all around performance goes up. "step on the ball" "step on the ball" Just a note,,, After I took Don flying, He persued his dream of taking glider lessons. Ironically he is taking lessons from the guy who first showed me his Fisher Celibrity, uncovered, on the gear, and I fell in love with building a wooded airplane. And my second project was my Piet, which I'm flying now. Hopefully I was the inspiration for that! Ain't Life Grand! walt evans NX140DL ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC] To: pietenpol-list(at)matronics.com Sent: Wednesday, August 20, 2008 4:51 PM Subject: Pietenpol-List: takeoff performance, Walt Evans PS I'm 210# and took up a 190#'er. with 10 gallons aboard. Next plan is to take me and a 230#'er up. Walt--that is AMAZING. You've got a 65hp right ? Can I ask things like your runway length, obstacle heights at runway ends, were there any winds, and what was the OAT ? I used to be able to take 200 pound passengers when my engine was tight but now....not so much. I wait until I get a nice 70 F day with some wind down the runway and then still restrict my passenger weight to around 160, 170 max. My empty weight is 632lbs. Mike C. ________________________________________________________________________________
Date: Aug 20, 2008
With a 200# pilot, 160# passenger and 85# of fuel, NX18235 flies very nicely on an 80 degree evening. Here is the view on short final. Greg Cardinal ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> Sent: Wednesday, August 20, 2008 4:44 PM Subject: Pietenpol-List: Re: takeoff performance, Walt Evans > > Mike, > > I regularly carry my Dad. He is about 225lbs. or so. I go about 180lbs. > I've gone with full fuel several times. On Andrew's Brodhead trip this > year he carried himself and Nigel Hitchman on a couple of flights. One of > which was for a TP cutting routine out of the hayfield. I would imagine > that makes for a total passenger weight of about 430lbs or so. A bit much > for my taste, but they seemed to make out just fine. Don't really know > other conditions. > > Don Emch > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=199703#199703 > > > ________________________________________________________________________________
Date: Aug 20, 2008
Nice video Walt. While there I noticed the video by Grant McClaren, Simple Light and Cheap, also a great video, about 4 minutes. See it at http://www.youtube.com/watch?v=-2Ch9QhwyBY&NR=1 Jack www.textors.com ________________________________________________________________________________
Date: Aug 20, 2008
Jess says: "For me, at the wing rib building workshop at Oshkosh, using a stapler to attach the gussets got me a finished rib far quicker than sitting around yakking about it. Gentleman start your staplers! ;) " Ryan On Wed, Aug 20, 2008 at 10:34 AM, Michael Perez wrote: > I started a prototype rib just to get familular with procedures and > methods. I bought some Craftsman, 3/4" mini clamps to hold the gussets. I > see on the T-88 bottles it states to use minimal clamping force as too much > clamping will starve the joint. I believe these clamps are too tight. I am > thinking about finger pressing the gussets in place and let set...no clamps. > What say you? > > ** > > ________________________________________________________________________________
Date: Aug 20, 2008
Greg, Is that Stanton? Kirk On Aug 20, 2008, at 5:07 PM, gcardinal wrote: > With a 200# pilot, 160# passenger and 85# of fuel, NX18235 flies > very nicely on an 80 degree evening. > Here is the view on short final. > > Greg Cardinal > > ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> > To: > Sent: Wednesday, August 20, 2008 4:44 PM > Subject: Pietenpol-List: Re: takeoff performance, Walt Evans > > >> >> Mike, >> >> I regularly carry my Dad. He is about 225lbs. or so. I go about >> 180lbs. I've gone with full fuel several times. On Andrew's >> Brodhead trip this year he carried himself and Nigel Hitchman on a >> couple of flights. One of which was for a TP cutting routine out >> of the hayfield. I would imagine that makes for a total passenger >> weight of about 430lbs or so. A bit much for my taste, but they >> seemed to make out just fine. Don't really know other conditions. >> >> Don Emch >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=199703#199703 >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Date: Aug 20, 2008
nice picture! walt evans NX140DL ----- Original Message ----- From: "gcardinal" <gcardinal(at)comcast.net> Sent: Wednesday, August 20, 2008 6:07 PM Subject: Re: Pietenpol-List: Re: takeoff performance, Walt Evans > With a 200# pilot, 160# passenger and 85# of fuel, NX18235 flies very > nicely > on an 80 degree evening. > Here is the view on short final. > > Greg Cardinal > > ----- Original Message ----- > From: "Don Emch" <EmchAir(at)aol.com> > To: > Sent: Wednesday, August 20, 2008 4:44 PM > Subject: Pietenpol-List: Re: takeoff performance, Walt Evans > > >> >> Mike, >> >> I regularly carry my Dad. He is about 225lbs. or so. I go about 180lbs. >> I've gone with full fuel several times. On Andrew's Brodhead trip this >> year he carried himself and Nigel Hitchman on a couple of flights. One >> of >> which was for a TP cutting routine out of the hayfield. I would imagine >> that makes for a total passenger weight of about 430lbs or so. A bit >> much >> for my taste, but they seemed to make out just fine. Don't really know >> other conditions. >> >> Don Emch >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=199703#199703 >> >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Date: Aug 20, 2008
Charlie Rubeck who made over 5000 Piet and GN-1 ribs used ether an office stapler with the bottom anvil part removed or nothing. He would use finger pressure till the glue suction took over. When you use the no clamp method there can be no stress in the joint trying to lift the gusset up. ----- Original Message ----- From: Michael Perez Sent: 8/20/2008 11:41:26 AM Subject: Pietenpol-List: No clamps on ribs? I started a prototype rib just to get familular with procedures and methods. I bought some Craftsman, 3/4" mini clamps to hold the gussets. I see on the T-88 bottles it states to use minimal clamping force as too much clamping will starve the joint. I believe these clamps are too tight. I am thinking about finger pressing the gussets in place and let set...no clamps. What say you? ________________________________________________________________________________
Date: Aug 20, 2008
Yes, it is Stanton (SYN) on a Sunday evening about a week and a half ago. Gave rides to five teenagers. They all loved it. Greg ----- Original Message ----- From: "Kirk Huizenga" <kirkh1(at)gmail.com>
August 10, 2008 - August 20, 2008
Pietenpol-Archive.digest.vol-gx
