Pietenpol-Archive.digest.vol-hb
October 22, 2008 - November 03, 2008
      a big wad of oil goo in the bottom, but no rust.
      Jack Phillips
      NX899JP
      -----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Ash Sent: Wednesday, October 22, 2008 8:44 AM
Subject: Re Lift Struts
Please be careful if you're going to use old Cub struts. The original struts breathed, which allowed moisture into them, especially during temperature changes. This moisture would condense inside, run down, and accumulate at the bottom of the strut. The strut would rust from the inside-out, leaving little or no indication of a problem until it was structurally unsound. The AD requires the old struts to be punch tested at stations within a specified distance from the bottom and rolled with (hot) linseed oil. The rolling consequently requires their removal. The AD is satisfied permanently if the struts are replaced with sealed struts, available from Univair. The on-going cost and hassle of the AD has incented a lot of Cub people to just bite the bullet, replace their struts, and be done with it, which is what I did with mine maybe 6-8 years ago. This is why there is a glut of old Cub struts around. This is a well-known AD for the Cub, and sealed struts add value to a Cub when doing a pre-purchase inspection. The last time I saw mine they were in a junk pile next to the A&P's hangar with a number of others, but I haven't lived in the area for 6+ years, that A&P is gone, and the airport (X55) has changed hands since then. I always meant to grab them and take them home, but I'd be willing to wager they're gone now. Non-sealed Cub struts may certainly be used like Jack did. Cub fronts and backs are the same. I'll probably use some myself. But the lower end should probably be hacked off and a new lower fitting welded onto the slightly shorter strut, if a visual inspection of the internals of the strut comes up relatively clean. I might also be inclined to dry them out somehow, roll them once, then fill in the oil filler hole, effectively sealing them. Jim -----Original Message----- >From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> >Sent: Oct 22, 2008 8:05 AM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Re Lift Struts > >Graham, > > > >Much of this is in the Archives, for these are common questions. > > > >Some planes have smaller rear lift struts than front lift struts. >However, most planes have a rear spar much smaller and further aft than >the Pietenpol's rear spar. In most planes the rear spar carries less >than half the load of the front spar. In the Pietenpol design, the two >spars are the same size and the rear spar is relatively far forward, >suggesting that it carries a substantial part of the wing load. > > > >As for alloy, I assume you are referring to aluminum alloy. These have >been used with success in the past (interplane struts on a Stearman are >aluminum) and several Piet builders are using SkyTek aluminum strut >material. Again, check the archives. Several Pietenpols are flying >with wooden struts as well. > > > >I used lift struts from a couple of J-3 Cubs (a recent AD made a LOT of >Cub struts available for very little money) because they were cheap and >readily available. Also, being steel, they were readily weldable to >incorporate the fittings to attach to the spars and the fuselage (and >the jury struts). > > > >Jack Phillips > >NX899JP > > > > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham & >Robin Hewitt >Sent: Wednesday, October 22, 2008 2:40 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re Lift Struts > > > > > > > > > >Hi Builders > >I would appreciate some feed back on Lift struts for Pietenpols > > > >Some plans show all four struts to be 2.68 inches X 1.44 inches with a > >wall of .049 > > > >Am sure that many Cubs and similar types have the rear strut much > >smaller in section than the front > > > >And the front strut much less than 2 inches wide. > > > >Has any one considered Alloy , I believe that some Ballanca planes use > >this with fittings bolted to the ends. > > > >Your views would be appreciated > > > >Regards Graham Hewitt > > > > > > > > > > > > > > > > > >_________________________________________________ > >or otherwise private information. If you have received it in error, please notify the sender > >Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Oct 22, 2008
They're not the same? I've owned that plane for 15 years and never noticed. And I do a really long and thorough pre-flight, so it's that much more embarrassing. I never thought about the cable leads, but now that you mention it, you're right. When I ordered the sealed struts, I just ordered a set, assuming it was 4x of the same thing, not thinking it was 2x2. I had them shipped straight to my A&P, so I never saw the invoice; just a healthy charge on a card. I stand corrected. When you say the front struts are bigger, is that only in length, or cross-section as well? Jim -----Original Message----- >From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> >Sent: Oct 22, 2008 10:49 AM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Re Lift Struts > > >Everything Jim said is true, except that the front and rear struts are >the same on a Cub. The front struts are bigger, and have fairlead lugs >for the aileron cables welded to the strut. > >Since Cub struts are a little over 10' long and a Pietenpol strus is >typically about 8', you can safely cut off the bottom 2' where the rust >is and then eiather seal or oil the struts. When I cut mine, there was >a big wad of oil goo in the bottom, but no rust. > >Jack Phillips >NX899JP > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Ash >Sent: Wednesday, October 22, 2008 8:44 AM >To: pietenpol-list(at)matronics.com; pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Re Lift Struts > > >Please be careful if you're going to use old Cub struts. > >The original struts breathed, which allowed moisture into them, >especially during temperature changes. This moisture would condense >inside, run down, and accumulate at the bottom of the strut. The strut >would rust from the inside-out, leaving little or no indication of a >problem until it was structurally unsound. The AD requires the old >struts to be punch tested at stations within a specified distance from >the bottom and rolled with (hot) linseed oil. The rolling consequently >requires their removal. The AD is satisfied permanently if the struts >are replaced with sealed struts, available from Univair. The on-going >cost and hassle of the AD has incented a lot of Cub people to just bite >the bullet, replace their struts, and be done with it, which is what I >did with mine maybe 6-8 years ago. This is why there is a glut of old >Cub struts around. This is a well-known AD for the Cub, and sealed >struts add value to a Cub when doing a pre-purchase inspection. > >The last time I saw mine they were in a junk pile next to the A&P's >hangar with a number of others, but I haven't lived in the area for 6+ >years, that A&P is gone, and the airport (X55) has changed hands since >then. I always meant to grab them and take them home, but I'd be willing >to wager they're gone now. > >Non-sealed Cub struts may certainly be used like Jack did. Cub fronts >and backs are the same. I'll probably use some myself. But the lower end >should probably be hacked off and a new lower fitting welded onto the >slightly shorter strut, if a visual inspection of the internals of the >strut comes up relatively clean. I might also be inclined to dry them >out somehow, roll them once, then fill in the oil filler hole, >effectively sealing them. > >Jim > > >-----Original Message----- >>From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> >>Sent: Oct 22, 2008 8:05 AM >>To: pietenpol-list(at)matronics.com >>Subject: RE: Pietenpol-List: Re Lift Struts >> >>Graham, >> >> >> >>Much of this is in the Archives, for these are common questions. >> >> >> >>Some planes have smaller rear lift struts than front lift struts. >>However, most planes have a rear spar much smaller and further aft than >>the Pietenpol's rear spar. In most planes the rear spar carries less >>than half the load of the front spar. In the Pietenpol design, the two >>spars are the same size and the rear spar is relatively far forward, >>suggesting that it carries a substantial part of the wing load. >> >> >> >>As for alloy, I assume you are referring to aluminum alloy. These have >>been used with success in the past (interplane struts on a Stearman are >>aluminum) and several Piet builders are using SkyTek aluminum strut >>material. Again, check the archives. Several Pietenpols are flying >>with wooden struts as well. >> >> >> >>I used lift struts from a couple of J-3 Cubs (a recent AD made a LOT of >>Cub struts available for very little money) because they were cheap and >>readily available. Also, being steel, they were readily weldable to >>incorporate the fittings to attach to the spars and the fuselage (and >>the jury struts). >> >> >> >>Jack Phillips >> >>NX899JP >> >> >> >> >> >>-----Original Message----- >>From: owner-pietenpol-list-server(at)matronics.com >>[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham >& >>Robin Hewitt >>Sent: Wednesday, October 22, 2008 2:40 AM >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Re Lift Struts >> >> >> >> >> >> >> >> >> >>Hi Builders >> >>I would appreciate some feed back on Lift struts for Pietenpols >> >> >> >>Some plans show all four struts to be 2.68 inches X 1.44 inches with a >> >>wall of .049 >> >> >> >>Am sure that many Cubs and similar types have the rear strut much >> >>smaller in section than the front >> >> >> >>And the front strut much less than 2 inches wide. >> >> >> >>Has any one considered Alloy , I believe that some Ballanca planes use >> >>this with fittings bolted to the ends. >> >> >> >>Your views would be appreciated >> >> >> >>Regards Graham Hewitt >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >>_________________________________________________ >> >>or otherwise private information. If you have received it in error, >please notify the sender >> >>Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands >- Norsk - Portuguese > > > > >_________________________________________________ > >or otherwise private information. If you have received it in error, please notify the sender > >Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese > > ________________________________________________________________________________
Date: Oct 22, 2008
They are bigger in cross section. I opted to use the front struts for my Pietenpol, so used the struts from 2 different J-3's. I used the fronts because they are bigger and stronger even though it meant cutting off the fairlead lugs and grinding down the welds. Most people use the rear struts for that reason. I sold the rear struts that I had (I got the complete sets of struts from two Cubs) to Rick Holland for use on his Piet. If I had it to do over again, I would probably just buy new streamline tubing and make them from scratch. New tubing is 4130 and considerably stronger than the 1018 steel used in the J-3. Those struts are only .035" wall also, whereas new stuff is .049". What is the saying, "The sour taste of poor quality lasts a lot longer than the sweet taste of low price."? Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Ash Sent: Wednesday, October 22, 2008 11:11 AM Subject: RE: Pietenpol-List: Re Lift Struts They're not the same? I've owned that plane for 15 years and never noticed. And I do a really long and thorough pre-flight, so it's that much more embarrassing. I never thought about the cable leads, but now that you mention it, you're right. When I ordered the sealed struts, I just ordered a set, assuming it was 4x of the same thing, not thinking it was 2x2. I had them shipped straight to my A&P, so I never saw the invoice; just a healthy charge on a card. I stand corrected. When you say the front struts are bigger, is that only in length, or cross-section as well? Jim -----Original Message----- >From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> >Sent: Oct 22, 2008 10:49 AM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Re Lift Struts > > >Everything Jim said is true, except that the front and rear struts are >the same on a Cub. The front struts are bigger, and have fairlead lugs >for the aileron cables welded to the strut. > >Since Cub struts are a little over 10' long and a Pietenpol strus is >typically about 8', you can safely cut off the bottom 2' where the rust >is and then eiather seal or oil the struts. When I cut mine, there was >a big wad of oil goo in the bottom, but no rust. > >Jack Phillips >NX899JP > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Ash >Sent: Wednesday, October 22, 2008 8:44 AM >To: pietenpol-list(at)matronics.com; pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Re Lift Struts > > >Please be careful if you're going to use old Cub struts. > >The original struts breathed, which allowed moisture into them, >especially during temperature changes. This moisture would condense >inside, run down, and accumulate at the bottom of the strut. The strut >would rust from the inside-out, leaving little or no indication of a >problem until it was structurally unsound. The AD requires the old >struts to be punch tested at stations within a specified distance from >the bottom and rolled with (hot) linseed oil. The rolling consequently >requires their removal. The AD is satisfied permanently if the struts >are replaced with sealed struts, available from Univair. The on-going >cost and hassle of the AD has incented a lot of Cub people to just bite >the bullet, replace their struts, and be done with it, which is what I >did with mine maybe 6-8 years ago. This is why there is a glut of old >Cub struts around. This is a well-known AD for the Cub, and sealed >struts add value to a Cub when doing a pre-purchase inspection. > >The last time I saw mine they were in a junk pile next to the A&P's >hangar with a number of others, but I haven't lived in the area for 6+ >years, that A&P is gone, and the airport (X55) has changed hands since >then. I always meant to grab them and take them home, but I'd be willing >to wager they're gone now. > >Non-sealed Cub struts may certainly be used like Jack did. Cub fronts >and backs are the same. I'll probably use some myself. But the lower end >should probably be hacked off and a new lower fitting welded onto the >slightly shorter strut, if a visual inspection of the internals of the >strut comes up relatively clean. I might also be inclined to dry them >out somehow, roll them once, then fill in the oil filler hole, >effectively sealing them. > >Jim > > >-----Original Message----- >>From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> >>Sent: Oct 22, 2008 8:05 AM >>To: pietenpol-list(at)matronics.com >>Subject: RE: Pietenpol-List: Re Lift Struts >> >>Graham, >> >> >> >>Much of this is in the Archives, for these are common questions. >> >> >> >>Some planes have smaller rear lift struts than front lift struts. >>However, most planes have a rear spar much smaller and further aft than >>the Pietenpol's rear spar. In most planes the rear spar carries less >>than half the load of the front spar. In the Pietenpol design, the two >>spars are the same size and the rear spar is relatively far forward, >>suggesting that it carries a substantial part of the wing load. >> >> >> >>As for alloy, I assume you are referring to aluminum alloy. These have >>been used with success in the past (interplane struts on a Stearman are >>aluminum) and several Piet builders are using SkyTek aluminum strut >>material. Again, check the archives. Several Pietenpols are flying >>with wooden struts as well. >> >> >> >>I used lift struts from a couple of J-3 Cubs (a recent AD made a LOT of >>Cub struts available for very little money) because they were cheap and >>readily available. Also, being steel, they were readily weldable to >>incorporate the fittings to attach to the spars and the fuselage (and >>the jury struts). >> >> >> >>Jack Phillips >> >>NX899JP >> >> >> >> >> >>-----Original Message----- >>From: owner-pietenpol-list-server(at)matronics.com >>[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Graham >& >>Robin Hewitt >>Sent: Wednesday, October 22, 2008 2:40 AM >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Re Lift Struts >> >> >> >> >> >> >> >> >> >>Hi Builders >> >>I would appreciate some feed back on Lift struts for Pietenpols >> >> >> >>Some plans show all four struts to be 2.68 inches X 1.44 inches with a >> >>wall of .049 >> >> >> >>Am sure that many Cubs and similar types have the rear strut much >> >>smaller in section than the front >> >> >> >>And the front strut much less than 2 inches wide. >> >> >> >>Has any one considered Alloy , I believe that some Ballanca planes use >> >>this with fittings bolted to the ends. >> >> >> >>Your views would be appreciated >> >> >> >>Regards Graham Hewitt >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >>_________________________________________________ >> >>or otherwise private information. If you have received it in error, >please notify the sender >> >>Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands >- Norsk - Portuguese > > > > >_________________________________________________ > >or otherwise private information. If you have received it in error, please notify the sender > >Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese > > _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Subject: Re: Re Lift Struts
Date: Oct 22, 2008
Cross section is bigger on the front strut as well. Not the best picture but you can see the difference here. These are the sealed struts with the big forks on my Cub. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2810 Crossroads Drive, Ste 3800 Madison, WI 53718 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Oct 22, 2008, at 10:11 AM, Jim Ash wrote: > > They're not the same? I've owned that plane for 15 years and never > noticed. And I do a really long and thorough pre-flight, so it's > that much more embarrassing. I never thought about the cable leads, > but now that you mention it, you're right. When I ordered the sealed > struts, I just ordered a set, assuming it was 4x of the same thing, > not thinking it was 2x2. I had them shipped straight to my A&P, so I > never saw the invoice; just a healthy charge on a card. I stand > corrected. > > When you say the front struts are bigger, is that only in length, or > cross-section as well? > > Jim > > -----Original Message----- >> From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> >> Sent: Oct 22, 2008 10:49 AM >> To: pietenpol-list(at)matronics.com >> Subject: RE: Pietenpol-List: Re Lift Struts >> >> > >> >> Everything Jim said is true, except that the front and rear struts >> are >> the same on a Cub. The front struts are bigger, and have fairlead >> lugs >> for the aileron cables welded to the strut. >> >> Since Cub struts are a little over 10' long and a Pietenpol strus is >> typically about 8', you can safely cut off the bottom 2' where the >> rust >> is and then eiather seal or oil the struts. When I cut mine, there >> was >> a big wad of oil goo in the bottom, but no rust. >> >> Jack Phillips >> NX899JP >> >> >> -----Original Message----- >> From: owner-pietenpol-list-server(at)matronics.com >> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim >> Ash >> Sent: Wednesday, October 22, 2008 8:44 AM >> To: pietenpol-list(at)matronics.com; pietenpol-list(at)matronics.com >> Subject: RE: Pietenpol-List: Re Lift Struts >> >> >> Please be careful if you're going to use old Cub struts. >> >> The original struts breathed, which allowed moisture into them, >> especially during temperature changes. This moisture would condense >> inside, run down, and accumulate at the bottom of the strut. The >> strut >> would rust from the inside-out, leaving little or no indication of a >> problem until it was structurally unsound. The AD requires the old >> struts to be punch tested at stations within a specified distance >> from >> the bottom and rolled with (hot) linseed oil. The rolling >> consequently >> requires their removal. The AD is satisfied permanently if the struts >> are replaced with sealed struts, available from Univair. The on-going >> cost and hassle of the AD has incented a lot of Cub people to just >> bite >> the bullet, replace their struts, and be done with it, which is >> what I >> did with mine maybe 6-8 years ago. This is why there is a glut of old >> Cub struts around. This is a well-known AD for the Cub, and sealed >> struts add value to a Cub when doing a pre-purchase inspection. >> >> The last time I saw mine they were in a junk pile next to the A&P's >> hangar with a number of others, but I haven't lived in the area for >> 6+ >> years, that A&P is gone, and the airport (X55) has changed hands >> since >> then. I always meant to grab them and take them home, but I'd be >> willing >> to wager they're gone now. >> >> Non-sealed Cub struts may certainly be used like Jack did. Cub fronts >> and backs are the same. I'll probably use some myself. But the >> lower end >> should probably be hacked off and a new lower fitting welded onto the >> slightly shorter strut, if a visual inspection of the internals of >> the >> strut comes up relatively clean. I might also be inclined to dry them >> out somehow, roll them once, then fill in the oil filler hole, >> effectively sealing them. >> >> Jim >> >> >> -----Original Message----- >>> From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com> >>> Sent: Oct 22, 2008 8:05 AM >>> To: pietenpol-list(at)matronics.com >>> Subject: RE: Pietenpol-List: Re Lift Struts >>> >>> Graham, >>> >>> >>> >>> Much of this is in the Archives, for these are common questions. >>> >>> >>> >>> Some planes have smaller rear lift struts than front lift struts. >>> However, most planes have a rear spar much smaller and further aft >>> than >>> the Pietenpol's rear spar. In most planes the rear spar carries >>> less >>> than half the load of the front spar. In the Pietenpol design, >>> the two >>> spars are the same size and the rear spar is relatively far forward, >>> suggesting that it carries a substantial part of the wing load. >>> >>> >>> >>> As for alloy, I assume you are referring to aluminum alloy. These >>> have >>> been used with success in the past (interplane struts on a >>> Stearman are >>> aluminum) and several Piet builders are using SkyTek aluminum strut >>> material. Again, check the archives. Several Pietenpols are flying >>> with wooden struts as well. >>> >>> >>> >>> I used lift struts from a couple of J-3 Cubs (a recent AD made a >>> LOT of >>> Cub struts available for very little money) because they were >>> cheap and >>> readily available. Also, being steel, they were readily weldable to >>> incorporate the fittings to attach to the spars and the fuselage >>> (and >>> the jury struts). >>> >>> >>> >>> Jack Phillips >>> >>> NX899JP >>> >>> >>> >>> >>> >>> -----Original Message----- >>> From: owner-pietenpol-list-server(at)matronics.com >>> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of >>> Graham >> & >>> Robin Hewitt >>> Sent: Wednesday, October 22, 2008 2:40 AM >>> To: pietenpol-list(at)matronics.com >>> Subject: Pietenpol-List: Re Lift Struts >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> Hi Builders >>> >>> I would appreciate some feed back on Lift struts for Pietenpols >>> >>> >>> >>> Some plans show all four struts to be 2.68 inches X 1.44 inches >>> with a >>> >>> wall of .049 >>> >>> >>> >>> Am sure that many Cubs and similar types have the rear strut much >>> >>> smaller in section than the front >>> >>> >>> >>> And the front strut much less than 2 inches wide. >>> >>> >>> >>> Has any one considered Alloy , I believe that some Ballanca planes >>> use >>> >>> this with fittings bolted to the ends. >>> >>> >>> >>> Your views would be appreciated >>> >>> >>> >>> Regards Graham Hewitt >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> _________________________________________________ >>> >>> or otherwise private information. If you have received it in error, >> please notify the sender >>> >>> Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - >>> Nederlands >> - Norsk - Portuguese >> >> >> >> >> >> >> >> >> _________________________________________________ >> >> or otherwise private information. If you have received it in error, >> please notify the sender >> >> Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - >> Nederlands - Norsk - Portuguese >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Lift Struts
Date: Oct 22, 2008
41CC has the larger size strut on the main and the smaller one of the rear. The bottoms are welded closed very much like the Cub picture that John posted, but the top ends of the struts are open in order to fit the attach straps as detailed in the plans. I'm not sure I've ever noticed any drain holes in the bottoms of the struts but then again the top ends of the struts are under the wings so I would not expect to ever get rain in them. And since I never wash the airplane, there is no fear of wash water getting in them either ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Corvair College #12
Date: Oct 22, 2008
Is camping under the wing allowed at the college? Also, is there a toilet available? Gardiner Mason ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Wednesday, October 22, 2008 8:42 AM Subject: Pietenpol-List: Corvair College #12 > > >>From William Wynne: > > We've posted an update on our Web site at > > http://FlyCorvair.com/hangar.html with all the information for Corvair > College #12 to be held Nov. 7-9 just > outside Columbia, S.C. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Date: Oct 22, 2008
Corky wrote- >Had planned to drill a small hole on lower extreme of all four struts but >that was before ole Al set in so you will have to do it. >Fronts are NEW stuff. Ok, Corky- I'll take care of it but you know they say you can keep Mr. Alzheimer at bay by keeping your mind challenged. For example of a good mental challenge, have you ever wondered how much water an empty milk jug would displace, and how many of them it might take to float a Piet at full gross if it were to go down in Calcasieu Lake? By the way, I know your eyesight is pretty fair, judging by the AARP eye chart you sent me a while ago ;o) Oscar Zuniga current caretaker of Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Corvair College #12
Date: Oct 22, 2008
Gardiner asks- >Is camping under the wing allowed at the college? >Also, is there a toilet available? Since the event is taking place at an airpark and being hosted by residents of the park, I assume that there will be toilets available in their home or hangar. I would also assume people could camp under their wing. However, you can get that info from William Wynne if there is any doubt. Oscar Zuniga current caretaker of Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 22, 2008
Subject: Re: Lift Struts
Rain ain't the problem; it's condensation. If the tops of your struts are open (and have been for years), do yourself the favor and inspect the bottoms. If they're really open, maybe you could get a fiberscope down there for a look-see. Jim -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: Oct 22, 2008 12:44 PM >To: Pietenpol List >Subject: Pietenpol-List: Lift Struts > > >41CC has the larger size strut on the main and the smaller one of the rear. The bottoms are welded closed very much like the Cub picture that John posted, but the top ends of the struts are open in order to fit the attach straps as detailed in the plans. I'm not sure I've ever noticed any drain holes in the bottoms of the struts but then again the top ends of the struts are under the wings so I would not expect to ever get rain in them. And since I never wash the airplane, there is no fear of wash water getting in them either ;o) > >Oscar Zuniga >Air Camper NX41CC >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Oct 22, 2008
From: Ben Williams <Ben.Williams(at)pdi.dreamworks.com>
How about this? The price is for 10'.... http://store.leadingedgeairfoils.com/product_info.php?products_id=6425 ________________________________________________________________________________
Subject: Pietenpol Bomber
Date: Oct 25, 2008
My dad told me that things were less dangerous back then. Cigarettes didn' t cause cancer=2C there was no use for airbags=2C drunk driving didn't kill people etc. Do no archive Subject: RE: Pietenpol-List: Pietenpol BomberDate: Tue=2C 21 Oct 2008 12:58 .com Ahhh=2C reminds me of the days of my youth=85 Back when I was 18=2C my Dad bought a J-3. My brother and I were going to enter it in a flour-sack bombing contest at an airshow in Memphis=2C so we asked a local farmer who had an airstrip if we could practice bombing at hi s place. He said he=92d rather we=92d use lime than flour so it would do h is fields some good and let us go. We started practicing with various alti tudes and weren=92t being very successful. I decided to try the dive-bomb approach. I took the Cub up to 1=2C000=92=2C chopped the throttle to idle and stood it on its nose=2C watching the airspeed to keep it out of the red line (125 mph on a Cub). I tossed the bomb out at about 100=92 and pulled back on the stick. You know=2C it takes just about 100=92 to pull a Cub ou t of a terminal velocity dive. I pointed the nose to the sky and gave it f ull throttle and it kept going down! It finally began to climb as the tail wheel kissed the grass. I decided right then and there that dive bombing i s not my preferred technique. As he was watching this from the saftey of t he ground=2C my brother kept wondering =93how am I going to get home if he crashes the airplane?=94 The farmer watched us practice day after day and finally said =93Boys=2C I =92ve got 40 acres in watermelons. There are always a few that the crows h ave pecked holes in that I can=92t sell. I sure would enjoy watching you d rop them.=94 We took the stick out of the back=2C and my brother flew the Cub from the f ront seat while I sat in the back with a watermelon under each arm and 3 of them on the floorbards. I made an adjustable bombsight that proved to be pretty accurate=2C as long as the altitude was constant and the wind wasn =92t blowing too hard. I would lean out the door and shout instructions to him=2C as he maintained a constant altitude. I=92d shout =93Left a bit. Steady. Steady. A little bit to the right ' Bomb=92s Away! We got wher e we could consistently hit a target the size of a car from 500=92. Let me tell you=2C when you drop a watermelon 500=92 it digs a crater about 6=92 in daimeter and a foot deep and just fills it with mud. It throws a shower of mud and dirt about 30=92 in the air. Spectacular! Jack Phillips NX899JP Raleigh=2C NC From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of shad bellSent: Monday=2C October 20=2C 2008 2:36 PMTo: Pietenpol DiscussionSubject: Pietenpol-List: Pietenpol Bom ber Hello guys=2C we had a blast this past saturday with a little airport hange r party/fly-in. We were going to have a spot landing competition=2C and bo mb drop=2C but just did the bombdrop. It was windy and a little bit cold b ut we still had fun. A friend of mine I work with came by in time for his 1st ride in the piet=2C little did he know he was getting drafted into the Pietenpol Airforce. He was my bombbardier. Water balloons were the ordena nce=2C and a blue barrel the target. That is the 1st time I have tried tha t=2C we did one low torpedo type run=2C and a 900ft high=2C B-29 style app roach. Of course the B-29's bombsight was waaaaay off. Earl=2C with his b lue Stinson 108 actually hit the barrel=2C with his girlfriend as his bomba dier=2C and the Eckles boys in the cub got close with the "stuka" dive bomb aproach. Next year I will try to plan a little better and get a few more invites out so we can have team bombdrop=2C Piets vs ???? (I bet RV's woul d have a heck of a time throwing stuff out.) Safe building and water bombing=2C _________________________________________________ This message is for the designated recipient only and may contain privilege d=2C proprietary or otherwise private information. If you have received it in error=2C pleas e notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese _________________________________________________________________ When your life is on the go=97take your life with you. ________________________________________________________________________________
Subject: RE: Lift struts
Date: Oct 25, 2008
I wrestled with the lift strut issue for a while. Checked out some old struts off some Cubs and T-crafts but ultimately decided to go with new steel streamline tubing. Paid about $900 for four 8-foot lenghts but would rather be sure of the integrity of these pretty crucial pieces of hardware. The roughly 2.5 x 1 inch by .049 stuff is stiff enough that I may not need jury struts. A bigger issue for me was the fitting at the top of the strut that attached into the fitting on the wing. The fabricated fitting according to plans allowed my strut to move up and down about a half inch, partly because it can slide up and down inside the strut on the bolt that holds it to the strut. I bought some 1 x 1 mild steel bar stock on line and machined (if you can call using a grinder to shape the part..) fittings that slide into the streamline tube. No slop and I'll feel a lot better about that critical attach point. Matt Paxton ________________________________________________________________________________
Date: Oct 25, 2008
Subject: Re: RE: Lift struts
For those who haven't bought...I found this in the archives but I wanted to double check and make sure, so I called Bill Rewey this morning to verify. He said that Wag-Aero's 1020 mild steel streamline tubing would work. 1.78" x 1.06" x .049", listed at $5.99 per ft in their catalog. If you get five 8 ft lengths you have one length for each strut, and the fifth length of tubing for the cabanes. I tried calling Wag-Aero to check price, but they are only open M-F. Might be worth looking into though. Ryan On Sat, Oct 25, 2008 at 8:41 AM, wrote: > I wrestled with the lift strut issue for a while. Checked out some old > struts off some Cubs and T-crafts but ultimately decided to go with new > steel streamline tubing. Paid about $900 for four 8-foot lenghts but would > rather be sure of the integrity of these pretty crucial pieces of hardware. > The roughly 2.5 x 1 inch by .049 stuff is stiff enough that I may not need > jury struts. > > A bigger issue for me was the fitting at the top of the strut that attached > into the fitting on the wing. The fabricated fitting according to plans > allowed my strut to move up and down about a half inch, partly because it > can slide up and down inside the strut on the bolt that holds it to the > strut. I bought some 1 x 1 mild steel bar stock on line and machined (if you > can call using a grinder to shape the part..) fittings that slide into the > streamline tube. No slop and I'll feel a lot better about that critical > attach point. > > ________________________________________________________________________________
Subject: Re: RE: Lift struts-Wag Aero
Date: Oct 25, 2008
Subject: the Pietenpol as a chick magnet
Date: Oct 26, 2008
The list sure has been slow lately so I thought I'd report on having another friendly and attractive woman fall for the old Pietenpol charm. Our next-door-neighbors (hangar-wise) are Steve & Freda Jones, editors of the EAA Chapter 35 award-winning newsletter and some really nice folks. Word got to me that Freda had been looking at that empty front cockpit of my airplane and wondering when I might be giving rides. So up we went yesterday. Freda was the picture-perfect Piet passenger. Didn't touch anything unless asked to, enjoyed every minute of the ride, doesn't notice bumpy air, and (most importantly) complimented the pilot on his landing ;o) She is not a very tall person so she had very little problem getting in the front cockpit, we got her buckled in, and went off to see the sights around Medina Lake. Landing was on grass and I didn't drop it in too hard but Freda thought it was pretty nice anyway. I think Steve got some pictures but don't worry... unlike Mike Cuy who likes to, um, get physical when he helps ladies into his airplane, the only assistance I gave Freda was to guide her foot to the step when she was getting out. I tell you, these old airplanes are chick magnets, even the unwashed ones like mine. The hangar grime and oil drips may even add a certain dashing air to the airplane. Or at least it's a good excuse for my lack of attention to washing it ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 26, 2008
Subject: Magnetic wood
Nice story Oscar, gives all us in the process of the build something to loo k forward to. I been down and out of work for the past week , just had knee surgery if no t for the no driving thing I would have been back in action sooner. At any rate I been in transition all week from a imp to a limp to a hobble and bac k to the gimp. The doc said it went really well, as if he was gonna say anything different? Like, "I really botched it, I guess I should have stayed home to day instead of screwing up your knee..... The good news is they let me work fro m home that helped. If I had to sit home and watch Oprah all I think I would just shoot myself and be done with it once and for all. As it worked out I got a chance to sneak over to the project and get some work done, I got the elevators and rudder about finished short of the metal parts and the horizontal stabilizer is on the bench in the lay out jig up st age. All in all I got some serious building done lately, bum knee and all. Oh yea the cane thing evokes no sympathy at all from anyone family of outside so n o help there. Which is fine with me, ask for nothing and get what you asked f or is not a disappointment, its what's expected and if you do get something like help or service its more than you expected making it even better. Simp le rule of life I suppose.Ask for nothing, ,expect nothing and anything you receive is a benefit to be cherished. At any rate I been working on the magnet just waiting for my turn to wow th e crowds in feats of aeronautical excellence maybe the greatest display of aeronautical skill since the invention of the aeroplane.... just thought I would share the adventure with ya, John **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 26, 2008
Subject: Re: Magnetic wood
John, Good on ya for continuing to make progress despite having a bum landing gear. Take some pride in the fact that you made good progress despite the condition you find yourself in. I feel your pain...I think, sort of. Somehow I "reignited" the back injury I acquired in Iraq (I don't understand how continually jumping 6ft out of the back of our 7 ton trucks with 70 lbs on my back could hurt me ;) I've been stove up for two weeks (at the young age of 28). It's been a damn challenge to make progress. We did some serious reorganization this weekend, so I can now stand and continue to cut gussets. Woo-hoo! Btw.....if the cane doesn't garner respect, then you may be due for a new AvPimp cane. Ryan On Sun, Oct 26, 2008 at 10:32 PM, wrote: > Nice story Oscar, gives all us in the process of the build something to > look forward to. > > I been down and out of work for the past week , just had knee surgery if > not for the no driving thing I would have been back in action sooner. At any > rate I been in transition all week from a imp to a limp to a hobble and back > to the gimp. The doc said it went really well, as if he was gonna say > anything different? Like, "I really botched it, I guess I should have stayed > home today instead of screwing up your knee..... The good news is they let > me work from home that helped. If I had to sit home and watch Oprah all I > think I would just shoot myself and be done with it once and for all. > > As it worked out I got a chance to sneak over to the project and get some > work done, I got the elevators and rudder about finished short of the metal > parts and the horizontal stabilizer is on the bench in the lay out jig up > stage. All in all I got some serious building done lately, bum knee and all. > Oh yea the cane thing evokes no sympathy at all from anyone family of > outside so no help there. Which is fine with me, ask for nothing and get > what you asked for is not a disappointment, its what's expected and if you > do get something like help or service its more than you expected making it > even better. Simple rule of life I suppose.Ask for nothing, ,expect nothing > and anything you receive is a benefit to be cherished. > > At any rate I been working on the magnet just waiting for my turn to wow > the crowds in feats of aeronautical excellence maybe the greatest display of > aeronautical skill since the invention of the aeroplane.... > > > just thought I would share the adventure with ya, > > John > ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Struts and supports
As I get closer to finishing my ribs, I have been nosing around the plans a t the rest of the wing and it's associated fittings. I am curious... why us e the streamlined or tapered, as I have seen them called, tubes for the str uts and the short runs that go to the engine mounts? Why not just round tub e? I wonder if a slightly smaller dia. tube, maybe heaver wall, would be ju st as good? I am basically thinking out loud, but if someone has some good reasoning behind the streamline use, other then aerodynamics, please... - Then there are the small jury struts. Some use, some do not...when should t hey be used and when can they be omitted? I hear that it is a support issue ...there again, I wonder if the round tube on the struts would still requir e the jurys? - I have also wondered about other materials then the 4130. Aluminum, other s teels, carbon fiber, wood... - Thanks all. ________________________________________________________________________________
Date: Oct 27, 2008
Michael, if you look in the archives under lift struts you will find many questions answered. As for Jury struts, I ran a stress analysis many years ago examining the need for them. I don't have a copy of it at hand now, but it was published in the BPA Newsletter sometime back in 1996. It came to the conclusion that Jury struts are necessary to prevent buckling of the lift struts under negative G loads. You can get some pretty substantial negative G loading from moderate turbulence, or a hard landing. The jury struts should not be placed at the exact middle of the lift struts to prevent harmonic vibrations. As for leaving the struts round, there are two reasons not to do that. One - they're ugly. Two - a Pietenpol doesn't need any help producing drag - it makes quite enough on its own, without giving it any help, and a cylinder is one of the highest drag shapes there is (which is why streamlined struts actually produce less drag than round flying wires). It is quite feasible to make struts with round tubing, with wooden streamlined fairings. Some Piets (including the Canadian built one that won a Lindy award at OSH 2007) have lift struts made entirely of wood. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, October 27, 2008 10:12 AM Subject: Pietenpol-List: Struts and supports As I get closer to finishing my ribs, I have been nosing around the plans at the rest of the wing and it's associated fittings. I am curious... why use the streamlined or tapered, as I have seen them called, tubes for the struts and the short runs that go to the engine mounts? Why not just round tube? I wonder if a slightly smaller dia. tube, maybe heaver wall, would be just as good? I am basically thinking out loud, but if someone has some good reasoning behind the streamline use, other then aerodynamics, please... Then there are the small jury struts. Some use, some do not...when should they be used and when can they be omitted? I hear that it is a support issue...there again, I wonder if the round tube on the struts would still require the jurys? I have also wondered about other materials then the 4130. Aluminum, other steels, carbon fiber, wood... Thanks all. _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 27, 2008
The streamline tube, I assume most use steel. Any research on aluminum? I w onder what the weight difference between wood and the steel struts would be . --- On Mon, 10/27/08, Phillips, Jack wro te: From: Phillips, Jack <Jack.Phillips(at)cardinalhealth.com> Subject: RE: Pietenpol-List: Struts and supports Date: Monday, October 27, 2008, 10:25 AM Michael, if you look in the archives under lift struts you will find many q uestions answered.- As for Jury struts, I ran a stress analysis many year s ago examining the need for them.- I don=92t have a copy of it at hand n ow, but it was published in the BPA Newsletter sometime back in 1996.- It came to the conclusion that Jury struts are necessary to prevent buckling of the lift struts under negative G loads.- You can get some pretty subst antial negative G loading from moderate turbulence, or a hard landing.- T he jury struts should not be placed at the exact middle of the lift struts to prevent harmonic vibrations. - As for leaving the struts round, there are two reasons not to do that.- O ne ' they=92re ugly.- Two ' a Pietenpol doesn=92t need any help produ cing drag ' it makes quite enough on its own, without giving it any help, and a cylinder is one of the highest drag shapes there is (which is why st reamlined struts actually produce less drag than round flying wires).- It is quite feasible to make struts with round tubing, with wooden streamline d fairings.- Some Piets (including the Canadian built one that won a Lind y award at OSH 2007) have lift struts made entirely of wood. - Jack Phillips NX899JP - From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, October 27, 2008 10:12 AM Subject: Pietenpol-List: Struts and supports - As I get closer to finishing my ribs, I have been nosing around the plans a t the rest of the wing and it's associated fittings. I am curious... why us e the streamlined or tapered, as I have seen them called, tubes for the str uts and the short runs that go to the engine mounts? Why not just round tub e? I wonder if a slightly smaller dia. tube, maybe heaver wall, would be ju st as good? I am basically thinking out loud, but if someone has some good reasoning behind the streamline use, other then aerodynamics, please... - Then there are the small jury struts. Some use, some do not...when should t hey be used and when can they be omitted? I hear that it is a support issue ...there again, I wonder if the round tube on the struts would still requir e the jurys? - I have also wondered about other materials then the 4130. Aluminum, other s teels, carbon fiber, wood... - Thanks all. -_________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 27, 2008
Michael; There is another option as well: use round steel tubing (more efficient and affordable) and then slide on molded plastic streamline fairings that the ultralight guys use. Easier to do than making wooden fairings to streamline the round tubing. These used to be available through SkyTek but I don't see them anymore: http://www.ultralightnews.ca/streamlinedfairings/1.html These plastic streamline fairings were installed on the prototype M-19 "Flying Squirrel", which uses round 4130 steel wing lift struts. The airplane cruises at 75-80MPH and picked up about 5 MPH after installing the streamline fairings on the wing struts only. I'm not saying that it will make that big a difference on the Piet, but there is a very large drag difference between round tubing and streamlined. It's on the order of 2 to 3x the drag. The jury struts, cabane braces, and gear legs on 41CC are simple round tubing but cabanes and wing struts are streamlined. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 27, 2008
Michael, Yes, some builders use aluminum struts. They are generally much cheaper than new 4130 streamline tubing. Here is one source: http://www.sky-tek.com/struts.html Also check out DJ Vegh's website: http://www.imagedv.com/aircamper/log/image-pages/03-30-03.htm Paul Poulin, the builder of the Canadian Piet mentioned by Jack, commented that he built his wooden lift struts (solid laminated White Ash) and then weighed them and found them to be slightly lighter than streamlined steel lift struts from a Piper Tri-Pacer (I think). I like Jack Phillips' Number One reason not to use round steel tubing as-is. They ARE ugly. Using round steel tubing, faired with wood, and wrapped with tape, then doped was a typical practice used on aircraft of the same vintage as the Pietenpol (see attached detail from Corben Cabin Ace plans). There has been quite a bit of discussion about this stuff in the past. If you've got a bit of time on your hands, check the archives. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, October 27, 2008 11:23 AM Subject: RE: Pietenpol-List: Struts and supports The streamline tube, I assume most use steel. Any research on aluminum? I wonder what the weight difference between wood and the steel struts would be. ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Aluminum Struts
Larry Williams has been flying his airplane with the aluminum Skytech strut s for years now. These are the same ones I put on my airplane. Advantage is less weight. If you don't want to attempt welding these (which I didn't) you have to insert and attach the end fittings with AN bolts. I used 7075 alumi num rectangular bar stock for the end fittings McMaster Carr Supply # 9055K13 $48.38 for 3 lineal feet. Worked great. Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Subject: Re: Aluminum Struts
Date: Oct 27, 2008
That is a great option! I have the skytechs and am getting near the stage of making the ends and I am trying to work though that. Got any pictures? ----- Original Message ----- From: HelsperSew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, October 27, 2008 12:42 PM Subject: Pietenpol-List: Aluminum Struts Larry Williams has been flying his airplane with the aluminum Skytech struts for years now. These are the same ones I put on my airplane. Advantage is less weight. If you don't want to attempt welding these (which I didn't) you have to insert and attach the end fittings with AN bolts. I used 7075 aluminum rectangular bar stock for the end fittings McMaster Carr Supply # 9055K13 $48.38 for 3 lineal feet. Worked great. Dan Helsper Poplar Grove, IL. ------------------------------------------------------------------------- ----- Play online games for FREE at Games.com! All of your favorites, no registration required and great graphics =93 check it out! ________________________________________________________________________________
Date: Oct 27, 2008
Got22b, I and others would like to address you by name :0) We are very friendly here. Anyway, yes I have photos on my home computer of these end fittings with the aluminum struts. I will make myself a note to post them tonight. Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
Thanks all for the replys. I like the aluminum struts with the custom machi ned end fittings that bolt on. The one thing I can't do/do not own is weldi ng tools. I can make up some really nice fittings and custom mounts, bolt i t together, done. --- On Mon, 10/27/08, HelsperSew(at)aol.com wrote: From: HelsperSew(at)aol.com <HelsperSew(at)aol.com> Subject: Re: Pietenpol-List: Aluminum Struts Date: Monday, October 27, 2008, 1:18 PM Got22b, - I and others would like to address you by name :0)---We are very frie ndly here.- Anyway, yes I have photos on my home computer of these end fi ttings with the aluminum struts. I will make myself a note to post them ton ight.- - Dan Helsper Poplar Grove, IL. Play online games for FREE at Games.com! All of your favorites, no registra tion required and great graphics ' check it out! ________________________________________________________________________________
Date: Oct 27, 2008
Thanks Bill, this is great stuff! Very helpfull! --- On Mon, 10/27/08, Bill Church wrote: From: Bill Church <eng(at)canadianrogers.com> Subject: RE: Pietenpol-List: Struts and supports Date: Monday, October 27, 2008, 11:58 AM Michael, - Yes, some builders use aluminum struts. They are generally much cheaper tha n new 4130 streamline tubing. Here is one source: http://www.sky-tek.com/struts.html - Also check out DJ Vegh's website: http://www.imagedv.com/aircamper/log/image-pages/03-30-03.htm - Paul Poulin, the builder of the Canadian Piet mentioned by Jack, commented that he built his wooden lift struts (solid laminated White Ash) and then w eighed them and found them to be slightly lighter than streamlined steel li ft struts from a Piper Tri-Pacer (I think). - I like Jack Phillips' Number One reason not to use round steel tubing as-is . They-ARE ugly. Using round steel tubing, faired with wood, and wrapped with -tape, then doped was a typical practice-used on aircraft of the same vintage as the Pietenpol (see attached detail from Corben Cabin Ace plans). - There has been quite a bit of discussion about this stuff in the past. If y ou've got a bit of time on your hands,-check the archives. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, October 27, 2008 11:23 AM Subject: RE: Pietenpol-List: Struts and supports The streamline tube, I assume most use steel. Any research on aluminum? I w onder what the weight difference between wood and the steel struts would be . ________________________________________________________________________________
Date: Oct 27, 2008
You'll become a pretty good welder by the time you finish this airplane. There's an awful lot of welding to be done on a wooden airplane. Jack Phillips _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, October 27, 2008 2:09 PM Subject: Re: Pietenpol-List: Aluminum Struts Thanks all for the replys. I like the aluminum struts with the custom machined end fittings that bolt on. The one thing I can't do/do not own is welding tools. I can make up some really nice fittings and custom mounts, bolt it together, done. --- On Mon, 10/27/08, HelsperSew(at)aol.com wrote: From: HelsperSew(at)aol.com <HelsperSew(at)aol.com> Subject: Re: Pietenpol-List: Aluminum Struts Date: Monday, October 27, 2008, 1:18 PM Got22b, I and others would like to address you by name :0) We are very friendly here. Anyway, yes I have photos on my home computer of these end fittings with the aluminum struts. I will make myself a note to post them tonight. Dan Helsper Poplar Grove, IL. _____ Play online games for FREE at Games.com! All of your favorites, no registration required and great graphics - check it out! =http://www.games.com?ncid=emlcntusgame00000001> " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Re: Pietenpol as a chick magnet
In a message dated 10/27/2008 1:50:15 P.M. Central Daylight Time, Michael.D.Cuy(at)nasa.gov writes: an observation that I'm sure many of you have seen Why Mikeee, a Southern gentleman has neither experienced those conditions nor even thought such. Have we missed something? A S G **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
Michael, You probably don't want to be welding the aluminum struts anyway. Many aluminum alloys will lose a significant amount of strength in the area adjacent to the weld. For instance, with 6061-T6 (the alloy the Sky-Tek struts are made of), the design stress (in bending) drops from 24,000 psi to 14,000 psi within 1 inch of the weld. That is a very significant loss (more than 40%). The extreme heat of welding changes the molecular structure of the aluminum, resulting in localized reduced physical strength. The best approach for structural aluminum parts is to use mechanical fastening, rather than welding. But there are lots of other areas on this wooden airplane that will need to be welded. So you will eventually either need to learn that skill, or find someone else that has the skill to do it for you. Steel struts are another story. No issues with loss of strength in the weld areas with steel. Bill C. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, October 27, 2008 2:09 PM Subject: Re: Pietenpol-List: Aluminum Struts Thanks all for the replys. I like the aluminum struts with the custom machined end fittings that bolt on. The one thing I can't do/do not own is welding tools. I can make up some really nice fittings and custom mounts, bolt it together, done. ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Learning to weld
Michael, I would highly recommend that you open yourself to the possibility of learning to weld. As others have stated there are MANY parts on this wood a irplane that need welding. I would hate the thought of every time I wanted somethin g welded that I had to stop what I am doing and run this or that part out to the welder.......what a nightmare! Besides welding is FUN after you get the hang of it. And also besides, learning new building skills have been every bit as rewarding as any other p hase of this whole process. I personally would not attempt the Piet without knowi ng how/having welding equipment. Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
I second that! Although I had gas welding schooling about 25 years ago, I never had any real experience. Many here will tell you that there are easier ways to weld than gas, but getting that set up is cheap! It took awhile to get in the groove, but now I am enjoying each little welding project more and more..and, as Dan says, there's a bunch of them! If things keep progressing this well, I may even do my own engine mount! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (endless metal parts!) (12 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of HelsperSew(at)aol.com Sent: Monday, October 27, 2008 12:37 PM Subject: Pietenpol-List: Learning to weld Michael, I would highly recommend that you open yourself to the possibility of learning to weld. As others have stated there are MANY parts on this wood airplane that need welding. I would hate the thought of every time I wanted something welded that I had to stop what I am doing and run this or that part out to the welder.......what a nightmare! Besides welding is FUN after you get the hang of it. And also besides, learning new building skills have been every bit as rewarding as any other phase of this whole process. I personally would not attempt the Piet without knowing how/having welding equipment. Dan Helsper Poplar Grove, IL. _____ Play online games for FREE at Games.com! All of your favorites, no registration required and great graphics - check %0ahttp://www.games.com?ncid=emlcntusgame00000001> it out! ________________________________________________________________________________
Subject: Pietenpol as a chick magnet
Date: Oct 27, 2008
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <Michael.D.Cuy(at)nasa.gov>
You lie Corky, you lie:)) ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Isablcorky(at)aol.com Sent: Monday, October 27, 2008 3:12 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Pietenpol as a chick magnet In a message dated 10/27/2008 1:50:15 P.M. Central Daylight Time, Michael.D.Cuy(at)nasa.gov writes: an observation that I'm sure many of you have seen Why Mikeee, a Southern gentleman has neither experienced those conditions nor even thought such. Have we missed something? A S G ________________________________ Play online games for FREE at Games.com! All of your favorites, no registration required and great graph1200689022/aol?redir http://www.games.com?ncid=emlcntusgame00000001"> check it out! ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Re: Learning to weld
So then is a MIG ok for doing the brackets? I think most recommend the gas or TIG...I actually have a gas set up, but have only used it as a torch! Boyce ________________________________________________________________________________
Date: Oct 27, 2008
Learning to weld is something I am looking forward to doing. For those of u s that haven't purchased any equipment yet, can those who have provide any recommendations as to what to get for gas welding? Of course I hope to tren d more towards the economical side, but still have the capability to tackle the welding for the airplane.... Ryan On Mon, Oct 27, 2008 at 2:47 PM, Gary Boothe wrote: > I second that! > > > Although I had gas welding schooling about 25 years ago, I never had any > real experience. Many here will tell you that there are easier ways to we ld > than gas, but getting that set up is cheap! It took awhile to get in the > groove, but now I am enjoying each little welding project more and > more=85.and, as Dan says, there's a bunch of them! If things keep progres sing > this well, I may even do my own engine mount! > > > Gary Boothe > ________________________________________________________________________________
Date: Oct 27, 2008
Oh well, that more or less kills it for Randi and I then, attracting women is not on the agenda, I guess we need to look at a P-51 or something similar to attract the Tom Cruise types? =) Randi got spoiled a couple of weeks ago by a ride in an RV doing wingovers and rolls and now you could not slap that RV grin off her face...ugh those d amn adrenalin junkies! Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ===== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/27/2008 1:50:15 P.M. Central Daylight Time, Michael.D.Cuy(at)nasa.gov writes: --> Pietenpol-List message posted by: "Cuy, Michael D. (GRC-RXD0)[ASRC]" What Oscar fails to mention is that most of my lady Pietenpol admirers are 75+ years old and tend to be the kind that pinch you on the cheek while saying "that is such a cute little airplane you have there sonny !" I have never gotten physical with any of my passengers, despite the occasional wandering of ones mind from time to time. One thing I have noted is that at Oshkosh, the more expensive the airplane, the hotter the owner's wife/girlfriend/date is and the more and more that they look more like a daughter than a date or wife. Just stating an observation that I'm sure many of you have seen in the boating world, car world, and otherwise. Mike C. do not archive **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
Dan, Did you use their large strut in the front/small strut in the rear, or the large strut for both front and rear? Ryan On Mon, Oct 27, 2008 at 11:42 AM, wrote: > Larry Williams has been flying his airplane with the aluminum Skytech > struts for years now. These are the same ones I put on my airplane. > Advantage is less weight. If you don't want to attempt welding these (which > I didn't) you have to insert and attach the end fittings with AN bolts. I > used 7075 aluminum rectangular bar stock for the end fittings McMaster Carr > Supply # 9055K13 $48.38 for 3 lineal feet. Worked great. > Dan Helsper > Poplar Grove, IL. > ________________________________________________________________________________
Date: Oct 27, 2008
If possible avoid MIG welding, its too easy to get a pretty weld that is purely cosmetic and is structurally unsound. If you have any experience with gas, the transition to TIG will be easy and you will do nice strong welds. Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ===== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/27/2008 3:05:08 P.M. Central Daylight Time, RAMPEYBOY(at)aol.com writes: So then is a MIG ok for doing the brackets? I think most recommend the gas or TIG...I actually have a gas set up, but have only used it as a torch ! Boyce (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
You mean I could have given Randi a better grin in my RV-4 than I did with my Pietenpol last July? That shameless Hussy!!! Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of CozyGirrrl(at)aol.com Sent: Monday, October 27, 2008 4:09 PM Subject: Re: Pietenpol-List: Pietenpol as a chick magnet Oh well, that more or less kills it for Randi and I then, attracting women is not on the agenda, I guess we need to look at a P-51 or something similar to attract the Tom Cruise types? =) Randi got spoiled a couple of weeks ago by a ride in an RV doing wingovers and rolls and now you could not slap that RV grin off her face...ugh those damn adrenalin junkies! Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ===== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/27/2008 1:50:15 P.M. Central Daylight Time, Michael.D.Cuy(at)nasa.gov writes: (GRC-RXD0)[ASRC]" What Oscar fails to mention is that most of my lady Pietenpol admirers are 75+ years old and tend to be the kind that pinch you on the cheek while saying "that is such a cute little airplane you have there sonny !" I have never gotten physical with any of my passengers, despite the occasional wandering of ones mind from time to time. One thing I have noted is that at Oshkosh, the more expensive the airplane, the hotter the owner's wife/girlfriend/date is and the more and more that they look more like a daughter than a date or wife. Just stating an observation that I'm sure many of you have seen in the boating world, car world, and otherwise. Mike C. do not p; e the es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; ======================== _____ Play online games for FREE at Games.com! All of your favorites, no registration required and great graphics - check it out! =%0d%0ahttp://www.games.com?ncid=emlcntusgame00000001> _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 27, 2008
>Besides welding is FUN after you get the hang of it. And also besides, learning new building skills have been every bit< >as rewarding as any other phase of this whole process. I personally would not attempt the Piet without knowing< >how/having welding equipment. < Do you have any recommendations as to the proper welding equipment to use? I have heard that oxy/acetylene is easier to learn on light 4130 type materials. How big should the tip size be, etc. Is there a good manual / training video available? Tom Stinemetze McPherson, KS. ________________________________________________________________________________
Date: Oct 27, 2008
Ryan, I actually used the small struts on both. This is what Larry Williams used. I thought the large ones were overkill. When you think about it, the Piet ha s redundancy in that regard, with 4 strut attach points vs. 2, when compared to a cub or champ. Dan **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
I would suggest learning with a gas welding set for several reasons. One, it is really a cheap setup, it is the most usefull tool you will ever buy,(welding, cutting, heating, shaping, etc...) Easy transition to TIG welding. Even if you tig weld Cro Molly, you will still need a torch setup to normalize the piece. You do not need to normalize when gas welding due to heat saturation, which is the only negative side of gas welding, the heat saturation tends to warp, but a bit of management and this becomes negligable. You don't need an expencive Henrob set, I welded my first fuse with a full sized Comet 3, now I use a medium size torch, but there are some really nice micro torches that will save you from having to wrap the hoses over your shoulders as you weld the 9 tube cluster upside down. And don't forget, you can weld cast, stainless, and aluminium with a gas welder too. To this day I prefer my gas welder if heat saturation isn't a problem, I feel like I have more control of penitration, and perosity in the weld is never a problem like tig welding. Anyway, just my two cents, as you can tell, I love welding Charley --- On Tue, 10/28/08, HelsperSew(at)aol.com wrote: > From: HelsperSew(at)aol.com <HelsperSew(at)aol.com> > Subject: Pietenpol-List: Learning to weld > To: pietenpol-list(at)matronics.com > Date: Tuesday, October 28, 2008, 6:37 AM > Michael, > > I would highly recommend that you open yourself to the > possibility of > learning to weld. As others have stated there are MANY > parts on this wood airplane > that need welding. I would hate the thought of every time I > wanted something > welded that I had to stop what I am doing and run this or > that part out to > the welder.......what a nightmare! > > Besides welding is FUN after you get the hang of it. And > also besides, > learning new building skills have been every bit as > rewarding as any other phase > of this whole process. I personally would not attempt the > Piet without knowing > how/having welding equipment. > > Dan Helsper > Poplar Grove, IL. > **************Play online games for FREE at Games.com! All > of your favorites, > no registration required and great graphics check it > out! > http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
OK someone please explain to me the difference between gas welding and brazing? Oxy-Acetylene is gas welding right? Boyce ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Oct 27, 2008
Don't worry, The piet is also a Chuck magnet. Problem for you is the definiation of Chuck is usually a 50ish old married man who does not have an airplane himself. Blue Skies Steve D ----- Original Message ----- From: CozyGirrrl(at)aol.com Date: Monday, October 27, 2008 15:23 Subject: Re: Pietenpol-List: Pietenpol as a chick magnet > Oh well, that more or less kills it for Randi and I then, > attracting women > is not on the agenda, I guess we need to look at a P-51 or > something similar to > attract the Tom Cruise types? =) > Randi got spoiled a couple of weeks ago by a ride in an RV doing > wingovers > and rolls and now you could not slap that RV grin off her > face...ugh those damn > adrenalin junkies! > > Regards, Chrissi > > CG Products, Custom Aircraft Hardware > www.CozyGirrrl.com > Cozy Mk-IV RG 13B-turbo > Plans #957 Chapter? big pieces done, details, details > ===== > If you have a "Spam Blocker" that requires > we fill out a form you will not hear from us. > Please do not make your spam problem ours. > > > In a message dated 10/27/2008 1:50:15 P.M. Central Daylight Time, > Michael.D.Cuy(at)nasa.gov writes: > > --> Pietenpol-List message posted by: "Cuy, Michael D. (GRC- > RXD0)[ASRC]" > < > > > What Oscar fails to mention is that most of my lady Pietenpol admirers > are 75+ years old and tend > to be the kind that pinch you on the cheek while saying "that is such a > cute little airplane > you have there sonny !" > > I have never gotten physical with any of my passengers, despite the > occasional wandering of ones > mind from time to time. > > One thing I have noted is that at Oshkosh, the more expensive the > airplane, the hotter the owner's > wife/girlfriend/date is and the more and more that they look more like a > daughter than a date or wife. > Just stating an observation that I'm sure many of you have seen in the > boating world, car world, and > otherwise. > > Mike C. > > do not archive > > > > > > > > > > > **************Play online games for FREE at Games.com! All of your favorites, > no registration required and great graphics check it out! > http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
In a message dated 10/27/2008 3:22:38 P.M. Central Daylight Time, Jack.Phillips(at)cardinalhealth.com writes: You mean I could have given Randi a better grin in my RV-4 than I did with my Pietenpol last July? That shameless Hussy!!! Oh I think Randi has been bitten badly by the aerobatic bug, she's always been an adrenalin junkie. I think she needs a ride in a Pitts =) Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ===== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. Jack Phillips NX899JP ____________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of CozyGirrrl@ aol.com Sent: Monday, October 27, 2008 4:09 PM Subject: Re: Pietenpol-List: Pietenpol as a chick magnet Oh well, that more or less kills it for Randi and I then, attracting women is not on the agenda, I guess we need to look at a P-51 or something simila r to attract the Tom Cruise types? =) Randi got spoiled a couple of weeks ago by a ride in an RV doing wingovers and rolls and now you could not slap that RV grin off her face...ugh those damn adrenalin junkies! Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ===== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/27/2008 1:50:15 P.M. Central Daylight Time, Michael.D.Cuy(at)nasa.gov writes: --> Pietenpol-List message posted by: "Cuy, Michael D. (GRC-RXD0)[ASRC]" What Oscar fails to mention is that most of my lady Pietenpol admirers are 75+ years old and tend to be the kind that pinch you on the cheek while saying "that is such a cute little airplane you have there sonny !" I have never gotten physical with any of my passengers, despite the occasional wandering of ones mind from time to time. One thing I have noted is that at Oshkosh, the more expensive the airplane, the hotter the owner's wife/girlfriend/date is and the more and more that they look more like a daughter than a date or wife. Just stating an observation that I'm sure many of you have seen in the boating world, car world, and otherwise. Mike C. do not p; e the es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; ============ ============ ____________________________________ Play online games for FREE at Games.com! All of your favorites, no registration required and great graphics =93 check it out! http://www.matronics.com/contribution _________________________________________________ , proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
Technically, you've got two pieces of metal to connect. If you connect them with the same kind of metal, that's welding (some creative license for alloy difference applies here). It usually requires more heat and better control of what your doing. You're melting the original edges of the metals you're connecting, so the joint will be one piece of the same stuff. If you connect them with a different kind of metal, that's brazing. Generally the temperatures aren't high enough to melt the host metals, only the filler. Oxy-actelene flame temperatures get high enough to weld steel and aluminum. I've also brazed with my oxy-acetlyene torches. Jim Ash -----Original Message----- >From: RAMPEYBOY(at)aol.com >Sent: Oct 27, 2008 5:10 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Learning to weld > >OK someone please explain to me the difference between gas welding and >brazing? Oxy-Acetylene is gas welding right? >Boyce ________________________________________________________________________________
Date: Oct 27, 2008
In a message dated 10/27/2008 4:29:59 P.M. Eastern Standard Time, ashcan(at)earthlink.net writes: If you connect them with a different kind of metal, that's brazing Sounds like brazing and soldering (as in copper plumbing pipe/lead solder) is the same thing... So, if you are welding 4130 plate, do I use a coat hanger for welding rod, or does it have to be 4130 rod? ________________________________________________________________________________
Date: Oct 27, 2008
If you're planning on welding tubing, Aircraft Spruce sells small piles of short cuts of assorted 4130 tubing. You can practice your notching and clusters. I've got a set of bottles and a Henrob torch kit. Others prefer a Meco or Smith torch for light work. Yer basic Victor torches are way too big for aircraft purposes. Jim Ash -----Original Message----- >From: TOM STINEMETZE <TOMS(at)mcpcity.com> >Sent: Oct 27, 2008 4:27 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Learning to weld > > >>Besides welding is FUN after you get the hang of it. And also besides, learning new building skills have been every bit< >as rewarding as any other phase of this whole process. I personally would not attempt the Piet without knowing< >how/having welding equipment. < > > >Do you have any recommendations as to the proper welding equipment to use? I have heard that oxy/acetylene is easier to learn on light 4130 type materials. How big should the tip size be, etc. Is there a good manual / training video available? > >Tom Stinemetze >McPherson, KS. ________________________________________________________________________________
Date: Oct 26, 2008
This has been covered at length in the archies, but it should be re-sated every now-and-then. 4130, the chrome-moly alloy most used in airplanes, was formulated with gas welding in mind. 4130 retains its strength without post-welding heat treatment when welded with gas, allowing the amateur (like most of us on this list) to achieve very strong and pretty welds with very inexpensive equipment. Gas welding, using Oxy-Acetylene, is a great choice for the amateur airplane builder. Mike Hardaway ________________________________________________________________________________
Date: Oct 27, 2008
Boyce, Here's a very basic answer. Yes, when people write gas welding, they are referring to welding using an Oxy-Acetylene torch. By definition, welding involves heating the two (or more) metal parts being joined to a temperature slightly above their melting point. The pieces being joined melt together (sometimes with added filler material) to become one. Brazing involves heating the two (or more) metal parts being joined to a temperature less than their melting point. A third element is added (the brazing rod) which has a melting point lower than the metals being joined. The brazing rod melts, and becomes adhered to the other parts, forming a bridge between the two. The pieces being brazed do not melt together. Brazing is basically like a high strength solder joint. The general consensus regarding brazing and welding of Pietenpol structures is that it is okay to braze a Pietenpol fuselage IF you build using 1020 steel tubing (as shown in the plans), but NOT if you use 4130 Chro-moly tubing. The 4130 tubing will tend to become brittle when brazed. 4130 can be successfully welded, but the welds need to be normalized (allowed to cool very slowly, without any drafts) following welding. Bill C. ________________________________________________________________________________
Date: Oct 27, 2008
uh oh....OK now I'm going to the garage when I get home to see what brand of torch I have! I think it was a Lincoln. Do they make gas welders/torches? It might be Victor though I hope not. What do I look for to determine what is the "right" size? Tip size? Thanks! Boyce ________________________________________________________________________________
Date: Oct 27, 2008
> OK someone please explain to me the difference between gas welding and brazing? Oxy-Acetylene is gas welding >right? >Boyce Boyce:I quote from Wikipedia: Weldingis a fabrication process that joins materials, usually metals or thermoplastics, by causing coalescence. This is often done by melting the workpieces and adding a filler material to form a pool of molten material (the weld puddle) that cools to become a strong joint, with pressure sometimes used in conjunction with heat, or by itself, to produce the weld. This is in contrast with soldering and brazing, which involve melting a lower-melting-point material between the workpieces to form a bond between them, without melting the workpieces.Hope that helps.Tom StinemetzeMcPheson, KS. ________________________________________________________________________________
Date: Oct 27, 2008
Tom: Take a look at the Meco Midget Torch: http://www.tinmantech.com/html/meco_midget_torch.php O got one on ebay a while back and I love it I also have a Meco Aviator but I like the midget better http://www.tinmantech.com/html/meco_aviator_jet_adaptor.php I have heard that the Henrob-Dillon-Cobra are the cat's meow, but have never used one: http://www.cut-like-plasma.com/ Michael ----- Original Message ----- From: TOM STINEMETZE To: pietenpol-list(at)matronics.com Sent: Monday, October 27, 2008 3:27 PM Subject: Re: Pietenpol-List: Learning to weld Do you have any recommendations as to the proper welding equipment to use? I have heard that oxy/acetylene is easier to learn on light 4130 type materials. How big should the tip size be, etc. Is there a good manual / training video available? Tom Stinemetze McPherson, KS. ________________________________________________________________________________
Date: Oct 27, 2008
[It has been my experience that welding with 4130 rod has failed in our competition robots. (FIRST), by changing to a lower carbon rod there wasn't any failures. Pieti Lowell , . > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210632#210632 ________________________________________________________________________________
Subject: Re: Struts and supports
Date: Oct 27, 2008
[ The late Hosey Challis, builder of 8 Pietenpols,built his last Piet with round 4130 struts and faired them with balsa wood, fabric and dope. I flew this Pietenpol for 12 years, sold it to a fellow in England, it's now in a show room. By the way I could do spins, snaps loops slow-rolls etc. all with confident and a bit slow. Pieti Lowell . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210637#210637 ________________________________________________________________________________
Subject: 80 th at Oshkosh
Date: Oct 27, 2008
Just got info from Doc Moser, with the news about 80th , looks good , I'm In and ready to go. Maybe from Brodhead to EAA. My Super B is looking good and running perfect, not bad for a 20 year since overhauled Ford . Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210642#210642 ________________________________________________________________________________
Date: Oct 27, 2008
As per my Mentor, (personal AP for Leo Laudenschlauger) told me,,,you use mild filler rod to do your welding. Don't use 4130 filler rod. He uses mild filler rod do all his repairs. His most recent was a Piper Vagabond. I followed his rules,,, and nothing flew off yet walt evans NX140DL ----- Original Message ----- From: RAMPEYBOY(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, October 27, 2008 5:32 PM Subject: Re: Pietenpol-List: Learning to weld In a message dated 10/27/2008 4:29:59 P.M. Eastern Standard Time, ashcan(at)earthlink.net writes: If you connect them with a different kind of metal, that's brazing Sounds like brazing and soldering (as in copper plumbing pipe/lead solder) is the same thing... So, if you are welding 4130 plate, do I use a coat hanger for welding rod, or does it have to be 4130 rod? ________________________________________________________________________________
Date: Oct 27, 2008
Well, got home and checked, sure enough I have a Victor! Never fails if you need two of something I only have one, or if you need red, I have every color BUT red! Oh well, I'm still building my Mustang II, so it will be a while before a Piet is in my life anyway.... Boyce ________________________________________________________________________________
Date: Oct 27, 2008
Boyce, I may not know how to weld, but I have found in my reading thus far that you should never use coat hangars for your welding rod. There is no way to know what the alloy of the metal is, and the paint on the coat hangar will contaminate the weld. Budd Davisson agrees with Walt, saying to use a mild steel rod with a copper coating (prevents it from rusting whilst being stored). Ryan On Mon, Oct 27, 2008 at 4:32 PM, wrote: > In a message dated 10/27/2008 4:29:59 P.M. Eastern Standard Time, > ashcan(at)earthlink.net writes: > > If you connect them with a different kind of metal, that's brazing > > Sounds like brazing and soldering (as in copper plumbing pipe/lead > solder) is the same thing... > > So, if you are welding 4130 plate, do I use a coat hanger for welding rod, > or does it have to be 4130 rod? > ________________________________________________________________________________
Date: Oct 27, 2008
You're not completely at a loss. You can still probably use your regulators and hoses. Jim Ash -----Original Message----- >From: RAMPEYBOY(at)aol.com >Sent: Oct 27, 2008 6:54 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Learning to weld > >Well, got home and checked, sure enough I have a Victor! Never fails if you >need two of something I only have one, or if you need red, I have every color >BUT red! Oh well, I'm still building my Mustang II, so it will be a while >before a Piet is in my life anyway.... > >Boyce ________________________________________________________________________________
Date: Oct 27, 2008
Is there anyone making the steel parts or ribs or ?? for the Piet for resale? I have an unmeasurable respect for you guys plans building. Occasionally, I think when the Mustang is complete, I will buy a completed Pietenpol, or maybe an unfinished project to speed the process along. I have three young children, and I barely get any time to build the Mustang(kit/quick build kit). I think when I get it done, I may be done with "projects"! Boyce ________________________________________________________________________________
Date: Oct 27, 2008
I don't understand. What does tank size have to do with it? Just means it is longer between trips to the welding supply store right? Boyce ________________________________________________________________________________
Date: Oct 27, 2008
Here we go again. Gas welded 4130 tubing joints don't need to be normalized. The torch weld spreads enough heat to the adjacent tubing that the thermal gradient is ok without it. TIG welds are a different story; the gas blanket allows the weld area to get amazingly hot, but the gas blanket cools the surrounding area too much, causing thermal stresses right next to the welds. This is where they tend to break if they're not normalized. Jim Ash -----Original Message----- >From: Bill Church <eng(at)canadianrogers.com> >Sent: Oct 27, 2008 5:37 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Learning to weld > >Boyce, > >Here's a very basic answer. > >Yes, when people write gas welding, they are referring to welding using an >Oxy-Acetylene torch. > >By definition, welding involves heating the two (or more) metal parts being >joined to a temperature slightly above their melting point. The pieces being >joined melt together (sometimes with added filler material) to become one. > >Brazing involves heating the two (or more) metal parts being joined to a >temperature less than their melting point. A third element is added (the >brazing rod) which has a melting point lower than the metals being joined. >The brazing rod melts, and becomes adhered to the other parts, forming a >bridge between the two. The pieces being brazed do not melt together. >Brazing is basically like a high strength solder joint. > >The general consensus regarding brazing and welding of Pietenpol structures >is that it is okay to braze a Pietenpol fuselage IF you build using 1020 >steel tubing (as shown in the plans), but NOT if you use 4130 Chro-moly >tubing. The 4130 tubing will tend to become brittle when brazed. 4130 can be >successfully welded, but the welds need to be normalized (allowed to cool >very slowly, without any drafts) following welding. > >Bill C. > > ________________________________________________________________________________
Date: Oct 27, 2008
I guess I don't understand either. I've got a set of adapters that I can use for the smaller acetylene bottles, but other than that, you're correct. I can burn through my small bottles in half a day of cutting, but it's tough to buy a set of larger bottles around here, and my leasing days are done. The swap for my little bottles is conveniently close and painless. Jim -----Original Message----- >From: RAMPEYBOY(at)aol.com >Sent: Oct 27, 2008 7:51 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Learning to weld > >I don't understand. What does tank size have to do with it? Just means it is >longer between trips to the welding supply store right? > >Boyce ________________________________________________________________________________
Date: Oct 27, 2008
see ebay Item number: 330280942484 steel tube GN1 http://cgi.ebay.com/ebaymotors/Pietenpol-GN-1-Aircamper-Aircraft-Quick-Bu ild-Kit_W0QQitemZ330280942484QQihZ014QQcategoryZ63679QQssPageNameZWDVWQQr dZ1QQcmdZViewItem not mine just passing it on Michael ----- Original Message ----- From: RAMPEYBOY(at)aol.com Is there anyone making the steel parts or ribs or ?? for the Piet for resale? I have an unmeasurable respect for you guys plans building. Occasionally, I think when the Mustang is complete, I will buy a completed Pietenpol, or maybe an unfinished project to speed the process along. ________________________________________________________________________________
Date: Oct 27, 2008
That's what I was referring to, yes. Ryan On Mon, Oct 27, 2008 at 6:51 PM, wrote: > I don't understand. What does tank size have to do with it? Just means it > is longer between trips to the welding supply store right? > > Boyce > ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Photos of aluminum strut fittings
Hello Good People!! Here are the photos I promised of the aluminum strut fittings. Any question s please ask. Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Piet for sale
Boyce's comment about buying a completed Pietenpol caused me to remember this. A Craigslist posting of a Piet for sale was posted to the Corvaircraft list about two weeks ago. You can see the ad here: http://grandrapids.craigslist.org/for/876001882.html I called on it a few days after it showed up and spoke with the gentleman who is selling it, a Mr. Carl Pitcher. His father built the aircraft. The gentleman selling it is older, and health issues will preclude him from ever doing anything with the aircraft. He couldn't remember exactly what year it was completed. According to the FAA the airworthiness cert. was issued in September of 1984. It was flown 31.5 hours, flying last in 1989, and was originally powered by an A-65. Apparently his father decided he wanted to convert it over to an automotive engine, and make some other modifications he saw on various Piets at Brodhead. The A-65 was sold, and the airplane was disassembled and uncovered, and has been in dry storage ever since. I believe that was all the more that was ever done to it. He is asking $3,000 for the airplane. As you can see in the ad, there is all sorts of other stuff for sale. A-65 engine mount, exhaust, instruments, etc etc. He also mentioned that he has lots of tools for sale as well. He sent me about a half dozen or more pictures of the airplane, from when it was together and now that it is apart. I'll get them scanned in and post a link to them. Might be a good opportunity to jump start your Piet project. Ryan (I don't know if it is still available, but the ad is still up so I'm assuming so) ________________________________________________________________________________
Subject: Re: Prop carving How-To CD coming soon
Date: Oct 27, 2008
I'd buy one.... Patrick -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210688#210688 ________________________________________________________________________________
Subject: Re: 80 th at Oshkosh
Date: Oct 27, 2008
Thats great news, Lowell. I'll be ready to go too. Do you know if theres a possibility of landing at Pioneer airport? The radial Piet is back running great and the new prop preforms lots better. Dick N. ----- Original Message ----- From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> Sent: Monday, October 27, 2008 5:35 PM Subject: Pietenpol-List: 80 th at Oshkosh > > > Just got info from Doc Moser, with the news about 80th , looks good , I'm > In and ready to go. Maybe from Brodhead to EAA. My Super B is looking good > and running perfect, not bad for a 20 year since overhauled Ford . > Pieti Lowell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210642#210642 > > > ________________________________________________________________________________
Date: Oct 27, 2008
At this time we have been told to get our hard surface landings up to snuff.And steerable tailwheels should be in order for runway 18. Large info coverage will come from all angles, so learn to fly in groups of 5. With a leader, w/radio in each group. It sure will be super, so get those projects finished and flying Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210698#210698 ________________________________________________________________________________
Date: Oct 27, 2008
Most, if not all, of this stuff has been hashed over a number of times over the years. One thing is DON"T braze 4130. Sometimes you can get away with it but I've had it bite me and so have others. 4130 has an open grain which means that the braze material goes into that and fills it up. So? Well, when the joint cools down the steel shrinks more than the brass. I had one nice little joint sitting there cooling behind my back as I turned to turn off the valves. Suddenly CRACK! big split in the tube. AC41.13 says not to braze. Now you know why. By the way, if it helps, you can think of brazing as glueing the metals together, same as glueing wood with your epoxy. Another thing. 4130 gets it's high strength from heat treating. As soon as welding temperatures are reached that goes down the toilet. The heated area might as well be mild steel. That's why you see those fancy fish mouth joints in AC 41.13. Heat normalizing relieves stresses but does not restore any strength. I agree with Robot Man. I bought some of that 4130 rod and now it has the same function as coat hangers. Great for picture hangers and painting hooks. :-) Haven't tried it with marshmallows however. :-) http://www.airbum.com/articles/ArticleZenWelding.html Clif "Education: the path from cocky ignorance to miserable uncertainty." - Mark Twain, writer and humorist ----- Original Message ----- From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> Sent: Monday, October 27, 2008 3:05 PM Subject: Pietenpol-List: Re: Learning to weld > > > [It has been my experience that welding with 4130 rod has failed in our > competition robots. (FIRST), by changing to a lower carbon rod there > wasn't any failures. > Pieti Lowell > > > , . > > >> [b] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210632#210632 > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 7:53 PM ________________________________________________________________________________
Date: Oct 27, 2008
Subject: Re: Photos of aluminum strut fittings
Thanks for up'ing the photos, Dan. A question arises: are you going to install shims or spacers between the wing fittings and the strut attach fitting to prevent fore and aft movement on the bolt, or is that not a concern? Ryan On Mon, Oct 27, 2008 at 8:03 PM, wrote: > Hello Good People!! > > Here are the photos I promised of the aluminum strut fittings. Any > questions please ask. > Dan Helsper > Poplar Grove, IL. > ________________________________________________________________________________
Date: Oct 27, 2008
Dan; I know nothing... I see nothing. However, looking at the pix of the connection between the aluminum bar stock and the streamline strut, unless I'm mistaken DJ Vegh used 3 or 4 bolts to make that same load transfer connection whereas you have two bolts, AN-4? I will look through some of the aluminum tube airframe plans that I have for different airplanes but I believe most of them show 3 or 4 bolts at this type of connection and the bolts are spaced about half the distance that you have these located. Again... I have no calcs, no other information other than I believe I've seen this type of connection made with more load transfer fasteners and a closer spacing. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 27, 2008
Oscar, I am blind, deaf and dumb on this as well. However, amongst the pics of Larry Williams' Piet (which Dan mentioned as using the same struts) at WestCoastPiet, there is one close-up of the strut attach point. http://www.westcoastpiet.com/images/Larry%20Williams/Air_Venture_2003_trip_107.jpg You can see there are only two bolts holding the bar stock attach fitting to the strut. I don't know the size, but the nuts look roughly equivalent to what Dan is using. The spacing is greater on Dan's, but your guess is as good as mine as to what difference that would make. Dan stated that Larry's Piet has been flying for years......DJ's Piet never took to the air while in his custody. (I mean no disrepect to DJ, it's just a point of fact) Not arguing your point, just showing what I ran across. Ryan On Mon, Oct 27, 2008 at 10:06 PM, Oscar Zuniga wrote: > > > Dan; > > I know nothing... I see nothing. However, looking at the pix of the > connection between the aluminum bar stock and the streamline strut, unless > I'm mistaken DJ Vegh used 3 or 4 bolts to make that same load transfer > connection whereas you have two bolts, AN-4? I will look through some of > the aluminum tube airframe plans that I have for different airplanes but I > believe most of them show 3 or 4 bolts at this type of connection and the > bolts are spaced about half the distance that you have these located. > > Again... I have no calcs, no other information other than I believe I've > seen this type of connection made with more load transfer fasteners and a > closer spacing. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 27, 2008
never use coat hanger in an aircraft application, thats like using elmers paste in constructing the fuselage. You don't have to use alloy rod, some do, some dont, but you definately want to use a proper welding rod, coat hanger has too many impurities and fizzes like a fuse, thats bad. Charley --- On Tue, 10/28/08, RAMPEYBOY(at)aol.com wrote: > From: RAMPEYBOY(at)aol.com <RAMPEYBOY(at)aol.com> > Subject: Re: Pietenpol-List: Learning to weld > To: pietenpol-list(at)matronics.com > Date: Tuesday, October 28, 2008, 8:32 AM > In a message dated 10/27/2008 4:29:59 P.M. Eastern Standard > Time, > ashcan(at)earthlink.net writes: > > If you connect them with a different kind of metal, > that's brazing > > > Sounds like brazing and soldering (as in copper plumbing > pipe/lead solder) > is the same thing... > > So, if you are welding 4130 plate, do I use a coat hanger > for welding rod, > or does it have to be 4130 rod? ________________________________________________________________________________
Date: Oct 27, 2008
You can weld with a Victor, I built my first fuselage with a Comet 3 , witch is a full size torch, the smaller ones make it lighter and easier, but it can be done, just as well with a larger torch. --- On Tue, 10/28/08, RAMPEYBOY(at)aol.com wrote: > From: RAMPEYBOY(at)aol.com <RAMPEYBOY(at)aol.com> > Subject: Re: Pietenpol-List: Learning to weld > To: pietenpol-list(at)matronics.com > Date: Tuesday, October 28, 2008, 8:40 AM > uh oh....OK now I'm going to the garage when I get home > to see what brand of > torch I have! I think it was a Lincoln. Do they make gas > welders/torches? It > might be Victor though I hope not. What do I look for to > determine what is > the "right" size? Tip size? Thanks! > Boyce ________________________________________________________________________________
Date: Oct 28, 2008
Maybe I presented this improperly. Victor makes some fine torches, and they're good for heavier metals or straight welds. When you're welding, you need to keep the flame at an angle somewhat perpendicular to the line you're welding. This angle isn't super-critical, but inconsistent torch handling will yield an inconsistent weld. In a straight line, the size of the torch (and lines, for that matter) aren't really a problem; in fact, a heavier setup might actually help some keep their hands from wobbling as much while they're learning. But when you're welding tubing, besides keeping the flame on the weld bead, you have to adjust your holding angle pretty radically as you go around the tubing to keep the flame angle correct with respect to the weld. The smaller the diameter of the tubing, the more radical this movement becomes. I don't mean to make it sound impossible or even difficult; it's just a skill that's alien to a lot of people. I've had the Henrob torch pretty much since I started welding (although I do use it with a set of heavy hoses), so I've had the luxury of using it on 4130. One of its benefits is to be able to more-finely (than my Victor torches) control the flame I want. I've welded fishmouths, clusters and rosebuds with it. I've never tried welding 4130 clusters with my Victor torch. I don't know if I'm agile enough to get it around the corners as fast as needed or do the finess welds on the odd joints. With a little warm-up (I'm probably rusty right now) I'd stack my 4130 Henrob welds up against anybody's, and they'd certainly survive a DAR's inspection. I suppose you can drive finish nails with an 8lb maul, too, but I choose not to. Jim Ash -----Original Message----- >From: charles loomis <rameses32(at)yahoo.com> >Sent: Oct 27, 2008 11:42 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Learning to weld > > >You can weld with a Victor, I built my first fuselage with a Comet 3 , witch is a full size torch, the smaller ones make it lighter and easier, but it can be done, just as well with a larger torch. > > >--- On Tue, 10/28/08, RAMPEYBOY(at)aol.com wrote: > >> From: RAMPEYBOY(at)aol.com <RAMPEYBOY(at)aol.com> >> Subject: Re: Pietenpol-List: Learning to weld >> To: pietenpol-list(at)matronics.com >> Date: Tuesday, October 28, 2008, 8:40 AM >> uh oh....OK now I'm going to the garage when I get home >> to see what brand of >> torch I have! I think it was a Lincoln. Do they make gas >> welders/torches? It >> might be Victor though I hope not. What do I look for to >> determine what is >> the "right" size? Tip size? Thanks! >> Boyce > > > > > ________________________________________________________________________________
Date: Oct 28, 2008
In a message dated 10/27/2008 10:03:01 P.M. Central Daylight Time, rmueller23(at)gmail.com writes: are you going to install shims or spacers between the wing fittings and the strut attach fitting to prevent fore and aft movement on the bolt, or is th at not a concern? Yes, I will do something there to take-up that space. I need some kind of tie-down fitting there anyway so maybe that is a good place for it. Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 28, 2008
Subject: Re: Photos of aluminum strut fittings- bolt number and
spacing Oscar, I am interested in your opinion and others on this. At the time I remember thinking through this and making a conscious decision, but now it eludes me . What is the shear strength of that whole system as it stands? Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 28, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Check with the Cozy Girrrls. Chrissi and Randi were at Brodhead exploring the possibility of making Pietenpol parts. They make high quality parts for other homebuilt aircraft, particularly for the Cozy. http://www.cozygirrrl.com/ Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of RAMPEYBOY(at)aol.com Sent: Monday, October 27, 2008 7:50 PM Subject: Re: Pietenpol-List: Learning to weld Is there anyone making the steel parts or ribs or ?? for the Piet for resale? I have an unmeasurable respect for you guys plans building. Occasionally, I think when the Mustang is complete, I will buy a completed Pietenpol, or maybe an unfinished project to speed the process along. I have three young children, and I barely get any time to build the Mustang(kit/quick build kit). I think when I get it done, I may be done with "projects"! Boyce _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 28, 2008
I hope they will allow for us to land at Pioneer Airport. If so I will probably make the trip. If not, I'll likely pass. Too far to fly with today's gas prices to just be another homebuilt at OSH. This past year I flew the Piet to Brodhead from NC but didn't bother flying another 90 miles to OSH. Mine has a radio so I could lead a group into Pioneer. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Pieti Lowell Sent: Monday, October 27, 2008 10:38 PM Subject: Pietenpol-List: Re: 80 th at Oshkosh At this time we have been told to get our hard surface landings up to snuff.And steerable tailwheels should be in order for runway 18. Large info coverage will come from all angles, so learn to fly in groups of 5. With a leader, w/radio in each group. It sure will be super, so get those projects finished and flying Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210698#210698 _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Oct 28, 2008
Subject: Aluminum Struts
Understood Bill. I have had a few metallurgy classes as well as the various welding classes, but never used the skills and now don't really remember m uch. I DO remember about aluminum and welding, as well as mechanical attach ment reasoning. I'll either find a way around it, or find someone to weld f or me. --- On Mon, 10/27/08, Bill Church wrote: From: Bill Church <eng(at)canadianrogers.com> Subject: RE: Pietenpol-List: Aluminum Struts Date: Monday, October 27, 2008, 3:15 PM Michael, - You probably don't want to be welding the aluminum struts anyway. Many alum inum alloys will lose a significant amount of strength in the area adjacent to the weld. For instance,-with 6061-T6 (the alloy the Sky-Tek struts ar e made of), the design stress (in bending) drops from 24,000 psi to 14,000 psi within 1 inch of the weld. That is a very significant loss (more than 4 0%). The extreme heat of welding changes the molecular structure of the alu minum, resulting in localized reduced physical strength. The best approach for structural aluminum parts is to use mechanical fastening, rather than w elding. But there are lots of other areas on this wooden-airplane-that will nee d to be welded. So you will eventually either need to learn that skill, or find someone else that has the skill to do it for you. Steel struts are another story. No issues with loss of strength in the weld areas with steel. - Bill C. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Monday, October 27, 2008 2:09 PM Subject: Re: Pietenpol-List: Aluminum Struts Thanks all for the replys. I like the aluminum struts with the custom machi ned end fittings that bolt on. The one thing I can't do/do not own is weldi ng tools. I can make up some really nice fittings and custom mounts, bolt i t together, done. ________________________________________________________________________________
Date: Oct 28, 2008
I'm tentatively planning on Brodhead this year (from Atlanta!). I, too, would be more inclined to go on up to OSH if we could land and tie down at Pioneer Field. I don't mind the aspect of being "just another homebuilt at OSH" (maybe I have low self-esteem? ;-)), but I do think having a bunch of Piets tied down in front of the "Pietenpol Field" hangar would be very cool! Is there some way to approach EAA about this? I know that they have a few activities on Pioneer Field that may be of concern (e.g., the helicopter rides), but maybe something can be worked out. > > >I hope they will allow for us to land at Pioneer Airport. If so I will >probably make the trip. If not, I'll likely pass. Too far to fly with >today's gas prices to just be another homebuilt at OSH. This past year >I flew the Piet to Brodhead from NC but didn't bother flying another 90 >miles to OSH. > >Mine has a radio so I could lead a group into Pioneer. > >Jack Phillips >NX899JP >Raleigh, NC > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Pieti >Lowell >Sent: Monday, October 27, 2008 10:38 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: 80 th at Oshkosh > > > >At this time we have been told to get our hard surface landings up to >snuff.And steerable tailwheels should be in order for runway 18. > Large info coverage will come from all angles, so learn to fly in >groups of 5. >With a leader, w/radio in each group. It sure will be super, so get >those projects finished and flying >Pieti Lowell > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=210698#210698 > > >_________________________________________________ > >or otherwise private information. If you have received it in error, >please notify the sender > >Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - >Nederlands - Norsk - Portuguese > > -- _____________________________________________________________ Jeffrey H. Boatright, PhD Associate Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Oct 28, 2008
Maybe a phone call to the PR people at Ford would be in order. Tell them that this will be the 80th anniversary of an originally Ford powered homebuilt. What a rare promotional opportunity they have to illustrate the effect Ford has had on our aviation heritage by having a couple Model A powered Piets at Pioneer Field (along with all the other Piets that can make it, Ford powered or not). Money talks at OSH, and lord knows they throw around plenty of it up there. Or maybe we could find a John Deere connection...hmm.... On Tue, Oct 28, 2008 at 7:40 AM, Jeff Boatright wrote: > > I'm tentatively planning on Brodhead this year (from Atlanta!). I, too, > would be more inclined to go on up to OSH if we could land and tie down at > Pioneer Field. I don't mind the aspect of being "just another homebuilt at > OSH" (maybe I have low self-esteem? ;-)), but I do think having a bunch of > Piets tied down in front of the "Pietenpol Field" hangar would be very cool! > > Is there some way to approach EAA about this? I know that they have a few > activities on Pioneer Field that may be of concern (e.g., the helicopter > rides), but maybe something can be worked out. ________________________________________________________________________________
Date: Oct 28, 2008
OK=2C so I'm blind-deaf-mute- and crazy. I guess it's from advancing age. I checked DJ's site and found this: http://imagedv.com/aircamper/log/image-pages/03-13-04.htm Clearly=2C his setup uses two AN4 bolts to attach the wing strut to the fit ting. His method is pretty elegant in that it incorporates a 4130 bar that's thre aded to accept an adjustable fork end (presumably at the lower end of the strut). And as t o prefabricated metal parts=2C someone on this list has posted a couple of times in the las t 2-3 months about having prefab fittings available for sale but I can't remember who it was. Like the man said=2C as I've gotten older I've finally gotten everything to gether in my life. Now if I could just remember where I put it... Oscar Zuniga Air camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 28, 2008
Oscar, I actually used DJ's idea at the bottom end of my struts, but I used the 7075 aluminum (with the J-3 forks)instead of the 4130. The way I did it at the top end of the fittings do not lend itself to movin g the wing fore and aft. In my case it does not matter because I liked the wa y the airplane looks with the cabanes straight vertical. Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 28, 2008
This is may not be what you were referring to, but I finally ran across this piece o' paper this morning. Ken Perkins makes what appears to be just about every piece of metal on the airplane. He had a price list with him at Brodhead this year. I scanned it and posted the results on Flickr: http://www.flickr.com/photos/rmueller23/2981632152/sizes/o/ http://www.flickr.com/photos/rmueller23/2980775607/sizes/o/ Hopefully that's plenty readable. If not let me know and I'll scan at a higher resolution. Certainly not cheap, as it would set you back about $4600 if you purchased all of the fuse, wing, and tail parts, but if you absolutely want to avoid fabricating them yourself it's one way to go. Unfortunately there was no contact information on the sheet. Maybe someone who has dealt with Ken could provide that if need be. Hope that helps, Ryan On Tue, Oct 28, 2008 at 8:26 AM, Oscar Zuniga wrote: > And as to prefabricated > metal parts, someone on this list has posted a couple of times in the last > 2-3 months about > having prefab fittings available for sale but I can't remember who it was. > > ________________________________________________________________________________
Date: Oct 28, 2008
Just a note of clarification, Clif. While 4130 IS heat-treatable, and can be strengthened considerably by heat treatment, it is not usually sold in that condition. Almost all 4130 tubing is sold in Normalized condition. The following definition is from the Aircraft Spruce website: " Normalizing consists of uniform heating to a temperature slightly above the point at which grain structure is affected (known as the critical temperature), followed by cooling in still air to room temperature. This produces a uniform structure and hardness throughout." In its normalized state, 4130 has an ultimate tensile strength of approximately 90,000 psi. This is almost double that of 1020 steel (55,000 psi). With proper heat treating, the strength of 4130 can be doubled again (up to 180,000 psi), but most homebuilt aircraft do not bother with this as the Normalized condition is plenty strong (especially if the airframe was originally designed to be built using 1020 steel). It is my understanding that if 4130 is welded using Oxy-Acetylene, and allowed to cool to room temperature in still air, the welds will not need to be normalized, as they will achieve that state naturally. If the welding is done in (or outside of) a shop where the air is moving, or the ambient air is colder, the welds should probably be normalized, as a safety precaution. I have also read that it is not really necessary to normalize thin-walled (less than 1/8" wall) 4130 tubing or plate that has been TIG welded. The heat produced by TIG welding is extremely intense and localized, thus resulting in a very small Heat Affected Zone. Again these welds should be allowed to cool to room temperature, in still air. This information, however, is what I have read - not based on my own experience. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Clif Dawson Sent: Monday, October 27, 2008 10:54 PM Subject: Re: Pietenpol-List: Re: Learning to weld --> Another thing. 4130 gets it's high strength from heat treating. As soon as welding temperatures are reached that goes down the toilet. The heated area might as well be mild steel. That's why you see those fancy fish mouth joints in AC 41.13. Heat normalizing relieves stresses but does not restore any strength. Clif ________________________________________________________________________________
Subject: normalizing
Date: Oct 28, 2008
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <Michael.D.Cuy(at)nasa.gov>
That is comforting to know Bill since I TIG welded my motor mount and then ala Tony Bingelis's suggestion, normalized with a torch, all the weld clusters before taking it out of my angle iron jig. I normalized the motor mount so I could do Lomcevak's and not worry about the motor falling off. I'm impressed by the 120 VAC TIG units on the market out there now. Very reasonable and if you can't TIG you probably can't finger paint. I was amazed by how easy it was to pickup TIG welding (where you feed the filler rod, it is not fed like in MIG) from a mechanic here at work who taught me over a few lunch hours. Gas welding ? I wouldn't try to weld a lawn mower part with my lack of gas welding skills. TIG is clean, easy, and very controllable even on those thin steel halves of the control horns. Amazing. If you get a chance at Oshkosh go to the Lincoln Electric welding pavilion and hang around the instructors for an hour or so and you'll learn more than you can imagine. I thought welding was a mysterious skill only known by powerful intellects from far away planets but like anything else...once you learn how to do it (like rib stitching), you find yourself enjoying it, feeling more accomplished, and you can barter your welding skills for other favors when someone comes up to you with a broken lawn mower part. Mike C. ________________________________________________________________________________
Date: Oct 28, 2008
Subject: Re: normalizing
I'll plug Sun 'n Fun for the workshops, too. Lincoln has pretty much taken over the welding tent and I really haven't sat through their standard spiel, so I can't really lay claim to how much you can learn as an individual (vs how much they can sell) in the workshop, but I suspect they do a pretty good job. There always seems to be an active contingent hanging around the TIG equipment, while it looks like the gas stations don't get quite their due, but this is from the persective of my workshop across the way, and we're generally too busy to take the time to go over there for a while. Lincoln always offers an attractive 'show special' price on their TIG machines, notably the 175 and 185. I've looked at them but haven't gotten caught in the right 'weak moment' enough to overcome my cheap tendencies and part with that much money in one place for a tool that doesn't run as much as my oil heater in the winter. But if you're looking for a good deal one one, waiting for Sun 'n Fun or OSH might be prudent if you want to be frugal and don't need it this instant. Jim Ash -----Original Message----- >From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <Michael.D.Cuy(at)nasa.gov> >Sent: Oct 28, 2008 11:20 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: normalizing > >That is comforting to know Bill since I TIG welded my motor mount and >then ala Tony Bingelis's suggestion, normalized with a torch, all the >weld clusters before taking it out of my angle iron jig. I normalized >the motor mount so I could do Lomcevak's and not worry about the motor >falling off. > >I'm impressed by the 120 VAC TIG units on the market out there now. >Very reasonable and if you can't TIG you probably can't finger paint. >I was amazed by how easy it was to pickup TIG welding (where you feed >the filler rod, it is not fed like in MIG) from a mechanic here at work >who taught me over a few lunch hours. Gas welding ? I wouldn't try >to weld a lawn mower part with my lack of gas welding skills. >TIG is clean, easy, and very controllable even on those thin steel >halves of the control horns. Amazing. > >If you get a chance at Oshkosh go to the Lincoln Electric welding >pavilion and hang around the instructors for an hour or so and you'll >learn >more than you can imagine. I thought welding was a mysterious skill >only known by powerful intellects from far away planets but like >anything >else...once you learn how to do it (like rib stitching), you find >yourself enjoying it, feeling more accomplished, and you can barter your >welding >skills for other favors when someone comes up to you with a broken lawn >mower part. > >Mike C. > > ________________________________________________________________________________
Subject: prefab metal parts
Date: Oct 28, 2008
>Certainly not cheap=2C as it would set you back about $4600 if you purchas ed >all of the fuse=2C wing=2C and tail parts=2C but if you absolutely want to avoid >fabricating them yourself it's one way to go. Or... buy the project that is for sale in Michigan for $3000 and not only d o you get all the fittings=2C you get a partially completed airplane to go with it and save $1600! Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 28, 2008
Subject: Lift struts
At Brodhead we wee told by someone that Wag-Aero has mild steel streamline tubing for 1/3 t0 1/4 the price of 4130. I promptly called them to find that they only had 2 sticks long enough, then some small pieces. so much for that gold mine. To the lister who said he flew a Piet with round tube lift struts with balsa fairings (sorry I dropped your name), do you happen to know what size and thickness they were? Does anyone know of a bulk source of cheap balsa wood? It,s been a while since I checked, but it was just about as expensive to buy balsa at a hobby store, as to buy 4130 streamline from a supplier. If any one else has some suggestions on round 4130 size and thickness post the info quickly. If having my water well overhauled today doesn't brake the bank, I am going to shoot up to Kansas City for steel tubing and more turnbuckles from B&B to horde for a future project. Thank you Leon Stefan, Nickerson Ks. ________________________________________________________________________________
Subject: Ryan's idea: FORD sponsored Piet gathering for 80th at
Oshkosh
Date: Oct 28, 2008
Ryan, That is a BRILLIANT idea to approach EAA/FORD to sponsor (whatever that might mean) the 80th Anniversary gathering of Pietenpols at Oshkosh. Regarding landing at Pioneer Airport, I believe you would have to walk on water for anyone to be allowed to land there with all the foot traffic and Kid Venture setup there but it is worth a try and inquiry. I just rec'd a thick letter from Doc Mosher in the mail yesterday and unless they are papers serving me a lawsuit or notice of lien, I'm hoping when I open it tonight that it might outline our plans to take a group of Piets into Oshkosh in 2009. Bill Rewey was our lead pilot in 1999 and he's agreed to do that again in 2009, Lord willing, and Doc Mosher has ties at EAA and lives not very far away from EAA HQ. I'll post any news here if that is what Doc's note was about. (Otherwise I'll write from the prison computers:) Mike C. ________________________________________________________________________________
Subject: Re: Lift Struts
Date: Oct 28, 2008
>From the archives Match: #1 Message: #15540 From: Doug413(at)aol.com Date: Nov 19, 2001 Subject: Re: tube drag In a message dated 11/18/01 7:11:02 PM Pacific Standard Time, robertsjunk(at)hotmail.com writes: > I was working in the garage and was thinking about the cost of streamlined struts and wondered what would be the horsepower penalty for going with round struts. So after about an hour looking through my Fluid Dynamics book, of which I haven't looked at in 10 years, I calculated the drag. My assumptions were 100mph at standard pressure and temperature (half the battle was figuring out the density of air) of a 1" diameter tube and got about 0.15 horsepower per foot of length. The coefficient of drag for a eliptical tube, which is close to a streamlined tube, was about 1/3 of that. The sort-of Pietenpol-like aircraft that I'm working on has 25' of tube and would take almost 4 HP to push a round tube through the air. The streamlined tube would save about 2 or 3 horsepower. Just thought y'all would be interested and please don't hold me to the calculations. Robert Haines > Murphysboro, Illinois Robert, I used 1 1/4 dia x .049 wall round tubing and skip welded a steel V shaped trailing edge to it. 102 hours on the ship now without jury struts; works great. I got this idea from a Buckeye Pietenpol Newsletter years ago. Doug Bryant -------- Chris Tracy Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210841#210841 ________________________________________________________________________________
Date: Oct 28, 2008
Leon, For a different approach to streamlining of round lift struts, check out this website. http://personal.southern.edu/~dascott/weedhopper/Streamline/fairings.html This guy uses styrofoam rather than balsa. He wraps the styrofoam with Vinyl tarp repair tape, rather than linen and dope - I imagine dope would not be compatible with the styrofoam. Using styrofoam cut with a hot wire is a lot cheaper than balsa, and should be pretty easy to get decent results. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Leon Stefan Sent: Tuesday, October 28, 2008 12:59 PM Subject: Pietenpol-List: Lift struts At Brodhead we wee told by someone that Wag-Aero has mild steel streamline tubing for 1/3 t0 1/4 the price of 4130. I promptly called them to find that they only had 2 sticks long enough, then some small pieces. so much for that gold mine. To the lister who said he flew a Piet with round tube lift struts with balsa fairings (sorry I dropped your name), do you happen to know what size and thickness they were? Does anyone know of a bulk source of cheap balsa wood? It,s been a while since I checked, but it was just about as expensive to buy balsa at a hobby store, as to buy 4130 streamline from a supplier. If any one else has some suggestions on round 4130 size and thickness post the info quickly. If having my water well overhauled today doesn't brake the bank, I am going to shoot up to Kansas City for steel tubing and more turnbuckles from B&B to horde for a future project. Thank you Leon Stefan, Nickerson Ks. ________________________________________________________________________________
Date: Oct 28, 2008
Subject: Re: Lift struts
Leon, You probably heard Bill Rewey say that during his talk (I heard him mention it at Brodhead and OSH). As I wrote a few days ago, I talked to Bill this past weekend and confirmed the size. He said that their 1.78 x 1.06 x .049 1020 mild steel streamline tubing would work. It's part number L-544-007 in their print catalog (didn't see it online). I called Wag-Aero on Monday to confirm price and availability. The woman I spoke with said the current price is $5.99 per foot (same as in the July '08 catalog), with a 10 ft minimum length. She said it is in stock. When they told you they were almost out of the mild steel they may have been referring to the 1025 tubing of the same dimensions listed as a clearance item in their July '08 catalog. That's what I know about that... Ryan On Tue, Oct 28, 2008 at 11:58 AM, Leon Stefan wrote: > > At Brodhead we wee told by someone that Wag-Aero has mild steel > streamline tubing for 1/3 t0 1/4 the price of 4130. I promptly called > them to find that they only had 2 sticks long enough, then some small > pieces. so much for that gold mine. To the lister who said he flew a > Piet with round tube lift struts with balsa fairings (sorry I dropped > your name), do you happen to know what size and thickness they were? > Does anyone know of a bulk source of cheap balsa wood? It,s been a > while since I checked, but it was just about as expensive to buy balsa > at a hobby store, as to buy 4130 streamline from a supplier. If any one > else has some suggestions on round 4130 size and thickness post the info > quickly. If having my water well overhauled today doesn't brake the > bank, I am going to shoot up to Kansas City for steel tubing and more > turnbuckles from B&B to horde for a future project. Thank you Leon > Stefan, Nickerson Ks. ________________________________________________________________________________
Date: Oct 28, 2008
Y'know, I almost started to mention shaping the streamlines for round tubing out of foam but I've seen first-hand what the Poly-Fiber (Stits) materials do when they even get close to foam. Same as gasoline... the foam dissolves in an instant. However, urethane foam is immune to those effects so any of the readily-available urethane foams could be used to shape the streamlines on round tubing and could then be covered with fabric and finishes and it wouldn't matter if the Poly-Brush, Poly-Spray, or Poly-Tone got through the fabric. Or, using latex house paint, everything would be completely compatible. Some of the benefits of urethane foams: very light, very easy to shape (can even be 'sanded' using a block of the same foam), and not affected by fuels or most solvents. Even a wood guy can work with this stuff ;o) Drawbacks: the foam is sort of fragile and is very dependent on the covering to provide protection against dings, and is also sensitive to sunlight so applying silver or other UV block is essential. Obviously, latex house paint would be perfect in that department. I'd have to guess that balsa would be more forgiving with dings but urethane is cheaper, just as light, and quite easy to shape and fill. The gear legs on my Flying Squirrel are round tubing but I've infilled the vees with polystyrene foam and fiberglassed over the whole thing to make them look sort of like Cub gear. Photos are at http://www.flysquirrel.net/gear/gear.html and pictures of the final product are a couple of photos down on my home page at http://www.flysquirrel.net Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: aileron travel
Date: Oct 28, 2008
Well today was another milestone day for my project. I have both ailerons mated to the wings using aluminum piano hinges. I did a lot of checking and rechecking to make sure everything was lined up properly before I started drilling. Everything worked out great! Everything is in line and the hinges work freely. It was very satisfying to slide the hinge pins back in and have everything fit. Right now I have the hinges mounted with some temporary pan head screws with washers. There seems to be plenty of clearance when I move the ailerons to the bottom of their travel. I was wondering though what the typical down travel is on the ailerons? Right now with the thicker headed temporary screws I am getting about 3 3/4 inches. Richard Schreiber In cold Valparaiso Indiana lmforge(at)earthlink.net ________________________________________________________________________________
Date: Oct 27, 2008
Another drawback of urethane foam is the initial shaping. It can be hot-wire cut but it takes a lot more heat than polystyrene and, worse, it off-gasses some awful stuff, phosgene, I think. It needs to be cut in really good ventilation if hot-wired. It does saw and sand very easily, but leaves some very stubborn dust. ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> [snip] However, urethane foam is immune to those effects so any of the readily-available urethane foams could be used to shape the streamlines on round tubing and could then be covered with fabric and finishes and it wouldn't matter if the Poly-Brush, Poly-Spray, or Poly-Tone got through the fabric. Or, using latex house paint, everything would be completely compatible. > > Some of the benefits of urethane foams: very light, very easy to shape (can even be 'sanded' using a block of the same foam), and not affected by fuels or most solvents. Even a wood guy can work with this stuff ;o) Drawbacks: the foam is sort of fragile and is very dependent on the covering to provide protection against dings, and is also sensitive to sunlight so applying silver or other UV block is essential. [snip] ________________________________________________________________________________
Subject: Re: Learning to weld
Date: Oct 29, 2008
For those curious about TIG welding of 4130, here is a link with some useful information (including recommended filler rods, and whether normalization is required for thin walled tubing welds): http://home.hiwaay.net/~langford/sportair/ Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=210924#210924 ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: aileron travel
Richard, Congrats on the milestone. How 'bout some pictures? Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: Learning to weld @ Sport Air workshops
Bill, I also attended a TIG welding Sport Air EAA workshop at Griffin. It was WEL L worth every penny and more. They give you the perfect mix of theory and practice. It is all spoon-fed to you right there. The beauty is that you hav e instant feedback from the expert. This makes all the difference in the world and you can learn at lightning speed. I had a different instructor but he too wa s an expert that welds at Indy. He worked for Lincoln as an instructor. I agree with the writer of that piece that you linked. I owned a Lincoln 175 square wave machine for months before that but was just guessing on a lot of stuff . BTW I also attended the Sport Air fabric covering workshop. Very good also. Dan Helsper Poplar Grove, IL. **************Play online games for FREE at Games.com! All of your favorites , no registration required and great graphics =93 check it out! http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Hi Richard, Aileron travel should be able to go all the way down till the hinges bottom out. In actuality, at least in my Pietenpol, the limiting factor is the stick hitting my thigh, but it's pretty close to maximum deflection of the aileron. I remember Valparaiso, Indiana. Mike Cuy and I stopped there for fuel on our way to Brodhead in 2005. Nice friendly airport, and as I recall they served hotdogs for pilots flying ot OSH (or Brodhead) Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard Schreiber Sent: Wednesday, October 29, 2008 12:29 AM Subject: Pietenpol-List: aileron travel Well today was another milestone day for my project. I have both ailerons mated to the wings using aluminum piano hinges. I did a lot of checking and rechecking to make sure everything was lined up properly before I started drilling. Everything worked out great! Everything is in line and the hinges work freely. It was very satisfying to slide the hinge pins back in and have everything fit. Right now I have the hinges mounted with some temporary pan head screws with washers. There seems to be plenty of clearance when I move the ailerons to the bottom of their travel. I was wondering though what the typical down travel is on the ailerons? Right now with the thicker headed temporary screws I am getting about 3 3/4 inches. Richard Schreiber In cold Valparaiso Indiana lmforge(at)earthlink.net _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Subject: shaping foam
Date: Oct 29, 2008
Do NOT hot-wire urethane foams! Polyisocyanurate = cyanide! It's OK to hot-wire polystyrene though. What I did to create shapes was to take a block of wood that I could hold in my hand, scribe the desired shape on the end with a marker or pencil, and cut the shape out of the block with a bandsaw (stand the block on end). That shape could be either the leading edge or trailing edge of a streamline (you'd be making those pieces separately and sandwiching your round tube between them). A round recess is easily sanded into the foam by wrapping a piece of dowel or PVC pipe with sandpaper, to create the recess to receive your round strut. With the shape cut out of the block, I glued coarse grit sandpaper into the recess in the block with contact cement and then I had a hand sanding block that I could run up and down the rough-shaped edge and form it to final shape. That's how I did the edges of all the tail surfaces on the Squirrel, pretty quick and pretty easy. I used the roll sandpaper that is used on floor sanding machines... very coarse grit but you can pick your grit according to how much you have to hog off. And on a different subject, not trying to create a political controversy here, but wouldn't it be cool if Sarah Palin showed up at OSH next year, stumbled onto the 80th anniversary gathering, and asked for a ride in a Piet? Any takers? Mikeee-? I'll bet she'd even be game for a flour bombing run ;o) Oscar Zuniga, diving for my foxhole now... Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Oct 29, 2008
Do you know if the AWS spec on welding 4130 tubing they talk about has gone public yet? I'd like to read it. One of my concerns is that the tolerances on certain technical aspects of homebuilding are (in my opinion) too tight to allow the necessary 'wiggle room' for an amateur working under less than ideal conditions in their garage or basement (or under a tarp in the yard somewhere). Although composite construction comes to mind first (mixing proportions, temperature and humidity controls, practical cleanliness), I'm talking the specific point of not normalizing after TIG welding. People who get paid to do something generally try to minimize the work/time ratio, being that time is money for them. As an amateur who happens to also enjoy the process, I'm more inclined to take the extra time and not shortcut that last optional step if there is one. It is my opinion that for most of the things I do around the house, I'm better off doing them myself than hiring a professional. Not because I'm better at it; I'm probably not. But I'm good enough to come close, and I'm more personally interested in the final result and more willing to expend the extra effort to see it gets done as good as I can do it. If the AWS spec is 'tolerant' enough of the TIG process in a less-than-ideal environment to not require normalizing, Ill back off. I do like my gas, but it might be enough to put me over the edge and pick up one of those little Lincoln machines. Jim Ash -----Original Message----- >From: HelsperSew(at)aol.com >Sent: Oct 29, 2008 6:38 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > >Bill, > >I also attended a TIG welding Sport Air EAA workshop at Griffin. It was WELL >worth every penny and more. They give you the perfect mix of theory and >practice. It is all spoon-fed to you right there. The beauty is that you have >instant feedback from the expert. This makes all the difference in the world and >you can learn at lightning speed. I had a different instructor but he too was >an expert that welds at Indy. He worked for Lincoln as an instructor. I >agree with the writer of that piece that you linked. I owned a Lincoln 175 square >wave machine for months before that but was just guessing on a lot of stuff. >BTW I also attended the Sport Air fabric covering workshop. Very good also. > >Dan Helsper >Poplar Grove, IL. > >**************Play online games for FREE at Games.com! All of your favorites, >no registration required and great graphics check it out! >http://www.games.com?ncid=emlcntusgame00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: Normalizing thin tube tig welds
Jim, You can go to Mr. Swaim's web sight _www.tigdepot.net_ (http://www.tigdepot.net) and ask him the question directly about the need (or not) for normalizing thin tube tig welds. I have read in numerous reliable places that it is NOT necessary. Dan Helsper Poplar Grove, IL. **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Adequate rod ends
I am wondering from a tensile strength view, what rod ends are adequate for the lift struts and wing struts. I see them rated from about 45,000PSI on up. I see the bolt holes in the steel fittings are in the order of 1/4" , so that tells me the rod end can only be so big. Is the 45,000PSI tensile enough? ________________________________________________________________________________
Date: Oct 29, 2008
The small Lincoln machines were designed specifically for the homebuilder and are great to use, by all means "pick one up" but please go take a minimu m of a 6 week adult ed TIG welding class after you familiarize yourself with it. They may not teach you any earth shattering epiphanies that will make you a n ace TIG welder overnight but they will force you to do something you will NEVER do at home... PRACTICE, hour after hour of practice but also with som eone looking over your shoulder that has the good judgement to say "try this instead of what you are doing now". Its the adjustments in technique from s omeone who knows that will help turn you into a welder a lot faster than many hour s of frustrating trial and error. All too often we will buy a tool with a project in mind and of course go right into it producing predictably horrid results. Practice what you want t o do on some non critical materials, set up practice welds that simulate the ones you want to do. Don't jump into your project parts hoping they will turn ou t then accept the mediocre results as good enough. Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ===== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/29/2008 8:28:25 A.M. Central Daylight Time, ashcan(at)earthlink.net writes: --> Pietenpol-List message posted by: Jim Ash Do you know if the AWS spec on welding 4130 tubing they talk about has gone public yet? I'd like to read it. One of my concerns is that the tolerances on certain technical aspects of homebuilding are (in my opinion) too tight to allow the necessary 'wiggle r oom' for an amateur working under less than ideal conditions in their garage or basement (or under a tarp in the yard somewhere). Although composite construction comes to mind first (mixing proportions, temperature and humidi ty controls, practical cleanliness), I'm talking the specific point of not nor malizing after TIG welding. People who get paid to do something generally try to minimize the work/time ratio, being that time is money for them. As an amateur who happens to also enjoy the process, I'm more inclined to take the extra time and not shortcu t that last optional step if there is one. It is my opinion that for most of the things I do around the house, I'm better off doing them myself than hiring a professional. Not because I'm better at it; I'm probably not. But I'm good enough to come close, and I'm more personally interested in the final resul t and more willing to expend the extra effort to see it gets done as good as I can do it. If the AWS spec is 'tolerant' enough of the TIG process in a less-than-idea l environment to not require normalizing, Ill back off. I do like my gas, but it might be enough to put me over the edge and pick up one of those little Lincoln machines. Jim Ash -----Original Message----- >From: HelsperSew(at)aol.com >Sent: Oct 29, 2008 6:38 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > >Bill, > >I also attended a TIG welding Sport Air EAA workshop at Griffin. It was WELL >worth every penny and more. They give you the perfect mix of theory and >practice. It is all spoon-fed to you right there. The beauty is that you have >instant feedback from the expert. This makes all the difference in the world and >you can learn at lightning speed. I had a different instructor but he too was >an expert that welds at Indy. He worked for Lincoln as an instructor. I >agree with the writer of that piece that you linked. I owned a Lincoln 17 5 square >wave machine for months before that but was just guessing on a lot of stuff. >BTW I also attended the Sport Air fabric covering workshop. Very good also. > >Dan Helsper >Poplar Grove, IL. > >**************Play online games for FREE at Games.com! All of your favorites, >no registration required and great graphics =93 check it out! >http://www.games.com?ncid=emlcntusgame00000001) **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Figure it out. The lift struts go into the wing panel at just about the middle, so they essentially carry all the lift loads (the cabane struts carry very little load on a Pietenpol). Assuming a gross weight of 1200 lbs, at 5 G's (ultimate loading) that means the wings must support 6000 lbs, or 3,000 lbs per wing panel. If the front struts carry 2/3 of the load, they are carrying 2,000 lbs of LIFT each. To find the tensile load in the strut you've got to figure the total load is the lift load divided by the sine of the angle. Assuming your struts are at a 30 degree angle to the horizontal, each front strut will be carrying an axial load of 2,000 lbs/.50 or 4,000 lbs. I used HMX Rod Ends from Aircraft Spruce for mine. 5/16" screw threads, rated at 5,390 lbs radial load each. I don't understand your reference to a 45,000 psi stress, although I guess if you calculate the area of the threade portion you could deduce the stress involved. Assuming the diameter is 5/16", the rod ends I used would be good for about 70,000 psi. Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 11:11 AM Subject: Pietenpol-List: Adequate rod ends I am wondering from a tensile strength view, what rod ends are adequate for the lift struts and wing struts. I see them rated from about 45,000PSI on up. I see the bolt holes in the steel fittings are in the order of 1/4" , so that tells me the rod end can only be so big. Is the 45,000PSI tensile enough? _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 29, 2008
I did my first welding ever last night. I purchased an Meco Midget off ebay a while ago and just got some tips, ultra-lightweight hose, rod for 4130, and TM1000 lens from tinmantech. I hooked up to a friend's tanks and went to it on some flat .090 and .064 I had sitting around I had a great time running some beads and doing a quick 90 degree weld of two pieces. I took the piece home and shared it with my wife. "I call it Eggplant Palm. Can you find a place to display it prominently in the living room?", I asked whimsically. "I thought this was going to productive not artistic!", she retorted. Sometimes its hard to tell the difference in airplane building. With still much to learn, do, and enjoy KIrk On Oct 27, 2008, at 3:27 PM, TOM STINEMETZE wrote: > >Besides welding is FUN after you get the hang of it. And also > besides, learning new building skills have been every bit< >as > rewarding as any other phase of this whole process. I personally > would not attempt the Piet without knowing< >how/having welding > equipment. < > > Do you have any recommendations as to the proper welding equipment > to use? I have heard that oxy/acetylene is easier to learn on light > 4130 type materials. How big should the tip size be, etc. Is there a > good manual / training video available? > > Tom Stinemetze > McPherson, KS. > > ________________________________________________________________________________
Date: Oct 29, 2008
Congrats. When I was taking welding classes, we were welding two 8"x2" strips of 3/8" steel together. My wife was taking weaving classes at the same time. We joked about our samples being 'refrigerator magnets', like the artwork your 5-year-old brings home from kindergarden. Jim -----Original Message----- >From: Kirk Huizenga <kirkh1(at)gmail.com> >Sent: Oct 29, 2008 12:01 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Learning to weld > >I did my first welding ever last night. I purchased an Meco Midget off >ebay a while ago and just got some tips, ultra-lightweight hose, rod >for 4130, and TM1000 lens from tinmantech. I hooked up to a friend's >tanks and went to it on some flat .090 and .064 I had sitting around > >I had a great time running some beads and doing a quick 90 degree weld >of two pieces. I took the piece home and shared it with my wife. "I >call it Eggplant Palm. Can you find a place to display it prominently >in the living room?", I asked whimsically. "I thought this was going >to productive not artistic!", she retorted. > >Sometimes its hard to tell the difference in airplane building. > >With still much to learn, do, and enjoy >KIrk > >On Oct 27, 2008, at 3:27 PM, TOM STINEMETZE wrote: > >> >Besides welding is FUN after you get the hang of it. And also >> besides, learning new building skills have been every bit< >as >> rewarding as any other phase of this whole process. I personally >> would not attempt the Piet without knowing< >how/having welding >> equipment. < >> >> Do you have any recommendations as to the proper welding equipment >> to use? I have heard that oxy/acetylene is easier to learn on light >> 4130 type materials. How big should the tip size be, etc. Is there a >> good manual / training video available? >> >> Tom Stinemetze >> McPherson, KS. >> >> > ________________________________________________________________________________
Date: Oct 29, 2008
Jack, I am looking at solid, (no swivel bearing) rod ends either aluminum o r steel. There is no reference to radial or axial loads, just tensile. The aluminum are rated at 45,000PSI tensile and the steel around 70,000. In you r response, you state axial load, then say your ends are rated radially. (? ) --- On Wed, 10/29/08, Phillips, Jack wro te: From: Phillips, Jack <Jack.Phillips(at)cardinalhealth.com> Subject: RE: Pietenpol-List: Adequate rod ends Date: Wednesday, October 29, 2008, 11:44 AM Figure it out.- The lift struts go into the wing panel at just about the middle, so they essentially carry all the lift loads (the cabane struts car ry very little load on a Pietenpol).- Assuming a gross weight of 1200 lbs , at 5 G=92s (ultimate loading) that means the wings must support 6000 lbs, or 3,000 lbs per wing panel.- If the front struts carry 2/3 of the load, they are carrying 2,000 lbs of LIFT each.- To find the tensile load in t he strut you=92ve got to figure the total load is the lift load divided by the sine of the angle.- Assuming your struts are at a 30 degree angle to the horizontal, each front strut will be carrying an axial load of 2,000 lb s/.50 or 4,000 lbs. - I used HMX Rod Ends from Aircraft Spruce for mine.- 5/16=94 screw threads , rated at 5,390 lbs radial load each.- I don=92t understand your referen ce to a 45,000 psi stress, although I guess if you calculate the area of th e threade portion you could deduce the stress involved.- Assuming the dia meter is 5/16=94, the rod ends I used would be good for about 70,000 psi. - Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 11:11 AM Subject: Pietenpol-List: Adequate rod ends - I am wondering from a tensile strength view, what rod ends are adequate for the lift struts and wing struts. I see them rated from about 45,000PSI on up. I see the bolt holes in the steel fittings are in the order of 1/4" , s o that tells me the rod end can only be so big. Is the 45,000PSI tensile en ough? - -http://www.matronics.com/contribution -_____________________ ____________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Subject: Chrissi's welding notes, advice
Date: Oct 29, 2008
As a casual observation and opinion I would take note of anything that Chrissi posts very seriously regarding aircraft hardware, fittings, assemblies, heat treating, welding, and otherwise since last summer at Brodhead I had an enjoyable opportunity to meet her and Randi, as many of you did, but was given a look at what you see below (a Cozy motor mount) fabricated from CG Products, namely Chrissi. Absolutely outstanding craftsmanship and quality. http://www.cozygirrrl.com/aircraftparts.htm ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: Ryan's idea: FORD sponsored Piet gathering for 80th
at Oshkosh Can Chevy piets attend? ha ha Shad ________________________________________________________________________________
Subject: how the heck do you rib stitch anyway ???????????
Date: Oct 29, 2008
Years back when I faced covering my project I knew I would have to learn the art of rib stitching. Turns out a few well-spent sessions at the fabric tent at Oshkosh was all I needed along with some video taping of the instructors showing other people how to do these starter knots and finishing knots. I practiced a few times during the week and finally got the hang of it and as it turned out I loved it ! I would come home after work, turn on my little tv in my single car garage and watch the 5 pm news, 6 pm news, Entertainment Tonight, then some of the Indians game, then the 10 pm news, all while ribsitiching and it was great. Highly recommend wrapping your fingers with masking tape where there are rub points and tightening rawness...works like a charm. Welding is the same way---a mystery, intimidating, something you just want to put off but once you jump in, get taught, get some practice, and get some good welds under your belt it is extreeeeeeeeeeemly satisfying.....until your first takeoff or first severe turbulence:) ________________________________________________________________________________
Date: Oct 29, 2008
Among other comments, Leon Stefan wrote: > To the lister who said he flew a > Piet with round tube lift struts with balsa fairings (sorry I dropped > your name), do you happen to know what size and thickness they were? > Does anyone know of a bulk source of cheap balsa wood? (etc.) A guy I used to know built a Heath parasol using round tubing for the lift struts. Don't know the size; in any case, a Piet would need something larger. The interesting part was the fairings: lumberyard blue foam, sanded to shape, wrapped in fiberglass drywall tape, and epoxied. Couldn't have been lighter or stiffer, and it's hard to imagine how it could have been much cheaper. FWIW. Owen ________________________________________________________________________________
Date: Oct 29, 2008
These are spherical rod ends (which I highly recommend for a Pietenpol, since they allow the wing to be repositioned fore and aft to accommodate CG positioning. Straight rod ends will not allow the struts to be at an angle to the chord line). Radial refers to the sperhical bearing. Since the strut is radial to the center of the bearing, a radial load in the bearing translates to an axial load in the strut. The other load specified for such pieces is an axial load in the bearing - in other words, a load trying to push the spherical bearing out of the rod end in the direction of the bolt axis. Confused??? Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 12:27 PM Subject: RE: Pietenpol-List: Adequate rod ends Jack, I am looking at solid, (no swivel bearing) rod ends either aluminum or steel. There is no reference to radial or axial loads, just tensile. The aluminum are rated at 45,000PSI tensile and the steel around 70,000. In your response, you state axial load, then say your ends are rated radially. (?) --- On Wed, 10/29/08, Phillips, Jack wrote: From: Phillips, Jack <Jack.Phillips(at)cardinalhealth.com> Subject: RE: Pietenpol-List: Adequate rod ends Date: Wednesday, October 29, 2008, 11:44 AM Figure it out. The lift struts go into the wing panel at just about the middle, so they essentially carry all the lift loads (the cabane struts carry very little load on a Pietenpol). Assuming a gross weight of 1200 lbs, at 5 G's (ultimate loading) that means the wings must support 6000 lbs, or 3,000 lbs per wing panel. If the front struts carry 2/3 of the load, they are carrying 2,000 lbs of LIFT each. To find the tensile load in the strut you've got to figure the total load is the lift load divided by the sine of the angle. Assuming your struts are at a 30 degree angle to the horizontal, each front strut will be carrying an axial load of 2,000 lbs/.50 or 4,000 lbs. I used HMX Rod Ends from Aircraft Spruce for mine. 5/16" screw threads, rated at 5,390 lbs radial load each. I don't understand your reference to a 45,000 psi stress, although I guess if you calculate the area of the threade portion you could deduce the stress involved. Assuming the diameter is 5/16", the rod ends I used would be good for about 70,000 psi. Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 11:11 AM Subject: Pietenpol-List: Adequate rod ends I am wondering from a tensile strength view, what rod ends are adequate for the lift struts and wing struts. I see them rated from about 45,000PSI on up. I see the bolt holes in the steel fittings are in the order of 1/4" , so that tells me the rod end can only be so big. Is the 45,000PSI tensile enough? http://www.matronics.com/contribution _________________________________________________ This message is for the designated recipient only and may contain privileged, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution <http://www.matronics.com/Navigator?Pietenpol-List> <http://www.matronics.com/contribution> _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 29, 2008
I went to welding classe a couple nights a week for three years. Certified stick. Was working on the MIG cert and TIG certs when the administrative types started making noises that they'd rather have a food service curriculum than welding. I backed off focusing on the certs and practiced all kinds of everything they had. Never got to play with the plasma torch or weld plastic (they didn't have a plastic rig), but did everything else available in the shop. Part of my problem with having access to the really nice toys in that class is that it's emotionally harder to accept having to work on a lesser piece of equipment at home. Specifically, the TIG machines I used were all water-cooled. I've had my reservations about air-cooled machines, but if I got to spend a little quality time with one I imagine I'd get over it. I did a nightmare job welding replacement floor panels into a friend's mid-70's El-Camino, using a cheapie MIG welder he borrowed. I should have known better. The duty cycle on it was about .005 percent. I'd get about 2" of good bead then it would kick off on a thermal check. That was when the feed wasn't so irregular it was bucking back or burning back up into the nozzle. I spent more time fighting and jury-rigging that machine than welding. I can certainly set up a MIG machine, but that little monster was the devil incarnate. That job made me gunshy of even considering anything less than professional-quality equipment. That said, the small Lincoln units are enticing. Maybe next April. Your point about practice is well-taken and sound advice to all. It's why a have a box full of junk 4130 short cuts of assorted sizes here. Granted I haven't welded any 4130 in a while, but I'll have lots of little 'cluster art' and that box will be long empty before I consider welding up anything my butt is going to fly behind, regardless of whether it's with a TIG machine or a gas torch. Jim -----Original Message----- >From: CozyGirrrl(at)aol.com >Sent: Oct 29, 2008 11:34 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > >The small Lincoln machines were designed specifically for the homebuilder >and are great to use, by all means "pick one up" but please go take a minimum of > a 6 week adult ed TIG welding class after you familiarize yourself with it. >They may not teach you any earth shattering epiphanies that will make you an >ace TIG welder overnight but they will force you to do something you will >NEVER do at home... PRACTICE, hour after hour of practice but also with someone >looking over your shoulder that has the good judgement to say "try this >instead of what you are doing now". Its the adjustments in technique from someone >who knows that will help turn you into a welder a lot faster than many hours >of frustrating trial and error. >All too often we will buy a tool with a project in mind and of course go >right into it producing predictably horrid results. Practice what you want to do >on some non critical materials, set up practice welds that simulate the ones >you want to do. Don't jump into your project parts hoping they will turn out >then accept the mediocre results as good enough. > >Regards, Chrissi > >CG Products, Custom Aircraft Hardware >www.CozyGirrrl.com >Cozy Mk-IV RG 13B-turbo >Plans #957 Chapter? big pieces done, details, details >===== >If you have a "Spam Blocker" that requires >we fill out a form you will not hear from us. >Please do not make your spam problem ours. > > >In a message dated 10/29/2008 8:28:25 A.M. Central Daylight Time, >ashcan(at)earthlink.net writes: > >--> Pietenpol-List message posted by: Jim Ash > >Do you know if the AWS spec on welding 4130 tubing they talk about has gone >public yet? I'd like to read it. > >One of my concerns is that the tolerances on certain technical aspects of >homebuilding are (in my opinion) too tight to allow the necessary 'wiggle room' >for an amateur working under less than ideal conditions in their garage or >basement (or under a tarp in the yard somewhere). Although composite >construction comes to mind first (mixing proportions, temperature and humidity >controls, practical cleanliness), I'm talking the specific point of not normalizing >after TIG welding. > >People who get paid to do something generally try to minimize the work/time >ratio, being that time is money for them. As an amateur who happens to also >enjoy the process, I'm more inclined to take the extra time and not shortcut >that last optional step if there is one. It is my opinion that for most of the >things I do around the house, I'm better off doing them myself than hiring a >professional. Not because I'm better at it; I'm probably not. But I'm good >enough to come close, and I'm more personally interested in the final result >and more willing to expend the extra effort to see it gets done as good as I >can do it. > >If the AWS spec is 'tolerant' enough of the TIG process in a less-than-ideal >environment to not require normalizing, Ill back off. I do like my gas, but >it might be enough to put me over the edge and pick up one of those little >Lincoln machines. > >Jim Ash > > >-----Original Message----- >>From: HelsperSew(at)aol.com >>Sent: Oct 29, 2008 6:38 AM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops >> >>Bill, >> >>I also attended a TIG welding Sport Air EAA workshop at Griffin. It was >WELL >>worth every penny and more. They give you the perfect mix of theory and >>practice. It is all spoon-fed to you right there. The beauty is that you >have >>instant feedback from the expert. This makes all the difference in the >world and >>you can learn at lightning speed. I had a different instructor but he too >was >>an expert that welds at Indy. He worked for Lincoln as an instructor. I >>agree with the writer of that piece that you linked. I owned a Lincoln 175 >square >>wave machine for months before that but was just guessing on a lot of >stuff. >>BTW I also attended the Sport Air fabric covering workshop. Very good >also. >> >>Dan Helsper >>Poplar Grove, IL. >> >>**************Play online games for FREE at Games.com! All of your >favorites, >>no registration required and great graphics check it out! >>http://www.games.com?ncid=emlcntusgame00000001) > > >**************Plan your next getaway with AOL Travel. Check out Today's Hot >5 Travel Deals! >(http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
I understand the terms, I was just wondering why the two references in the email...no big deal. I still need to find out what tensile strength will wo rk. I am making my own designed center section wing mounts. With mine, the solid ends-WILL allow adjustment side to side of the center section. (win g tip to wing tip). The fore and aft adjustment will be made at the bottom of the center section struts, at the fuselage. The angle of incidence will be made by adjusting the length of the solid rod ends. --- On Wed, 10/29/08, Phillips, Jack wro te: From: Phillips, Jack <Jack.Phillips(at)cardinalhealth.com> Subject: RE: Pietenpol-List: Adequate rod ends Date: Wednesday, October 29, 2008, 1:16 PM These are spherical rod ends (which I highly recommend for a Pietenpol, sin ce they allow the wing to be repositioned fore and aft to accommodate CG po sitioning.- Straight rod ends will not allow the struts to be at an angle to the chord line).- Radial refers to the sperhical bearing.- Since th e strut is radial to the center of the bearing, a radial load in the bearin g translates to an axial load in the strut.- The other load specified for such pieces is an axial load in the bearing ' in other words, a load try ing to push the spherical bearing out of the rod end in the direction of th e bolt axis.- Confused??? - - Jack Phillips NX899JP From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 12:27 PM Subject: RE: Pietenpol-List: Adequate rod ends - Jack, I am looking at solid, (no swivel bearing) rod ends either aluminum o r steel. There is no reference to radial or axial loads, just tensile. The aluminum are rated at 45,000PSI tensile and the steel around 70,000. In you r response, you state axial load, then say your ends are rated radially. (? ) --- On Wed, 10/29/08, Phillips, Jack wro te: From: Phillips, Jack <Jack.Phillips(at)cardinalhealth.com> Subject: RE: Pietenpol-List: Adequate rod ends Date: Wednesday, October 29, 2008, 11:44 AM Figure it out.- The lift struts go into the wing panel at just about the middle, so they essentially carry all the lift loads (the cabane struts car ry very little load on a Pietenpol).- Assuming a gross weight of 1200 lbs , at 5 G=92s (ultimate loading) that means the wings must support 6000 lbs, or 3,000 lbs per wing panel.- If the front struts carry 2/3 of the load, they are carrying 2,000 lbs of LIFT each.- To find the tensile load in t he strut you=92ve got to figure the total load is the lift load divided by the sine of the angle.- Assuming your struts are at a 30 degree angle to the horizontal, each front strut will be carrying an axial load of 2,000 lb s/.50 or 4,000 lbs. - I used HMX Rod Ends from Aircraft Spruce for mine.- 5/16=94 screw threads , rated at 5,390 lbs radial load each.- I don=92t understand your referen ce to a 45,000 psi stress, although I guess if you calculate the area of th e threade portion you could deduce the stress involved.- Assuming the dia meter is 5/16=94, the rod ends I used would be good for about 70,000 psi. - Jack Phillips, PE Sr. Manager, Disposable Products Research & Development Cardinal Health Clinical Technologies & Services Creedmoor, NC (919) 528-5212 From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 11:11 AM Subject: Pietenpol-List: Adequate rod ends - I am wondering from a tensile strength view, what rod ends are adequate for the lift struts and wing struts. I see them rated from about 45,000PSI on up. I see the bolt holes in the steel fittings are in the order of 1/4" , s o that tells me the rod end can only be so big. Is the 45,000PSI tensile en ough?-- -http://www.matronics.com/contribution -___________________ ______________________________ -This message is for the designated recipi ent only and may contain privileged, proprietaryor otherwise private inform ation. If you have received it in error, please notify the senderimmediatel -Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese - -" target=_blank rel=nofollow>http://www.ma tronics.com/Navigator?Pietenpol-List=nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution - - -http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronic s.comhttp://www.matronics.com/contribution -_____________________________ ____________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Oct 29, 2008
Hey Doug This sounds like a pretty good way to go. Can you tell us more about the steel v trailing edge you welded on to the lift struts. Ken in Austin, making hundreds of gussets for wing ribs. On Tue, Oct 28, 2008 at 3:17 PM, Catdesigns wrote: > > >From the archives > > Match: #1 > Message: #15540 > From: Doug413(at)aol.com > Date: Nov 19, 2001 > Subject: Re: tube drag > > In a message dated 11/18/01 7:11:02 PM Pacific Standard Time, > robertsjunk(at)hotmail.com writes: > > > I was working in the garage and was thinking about the cost of > streamlined struts and wondered what would be the horsepower penalty for > going with round struts. So after about an hour looking through my Fluid > Dynamics book, of which I haven't looked at in 10 years, I calculated the > drag. My assumptions were 100mph at standard pressure and temperature (half > the battle was figuring out the density of air) of a 1" diameter tube and > got about 0.15 horsepower per foot of length. The coefficient of drag for a > eliptical tube, which is close to a streamlined tube, was about 1/3 of > that. The sort-of Pietenpol-like aircraft that I'm working on has 25' of > tube and would take almost 4 HP to push a round tube through the air. The > streamlined tube would save about 2 or 3 horsepower. Just thought y'all > would be interested and please don't hold me to the calculations. > > Robert Haines > Murphysboro, Illinois > > > Robert, I used 1 1/4 dia x .049 wall round tubing and skip welded a steel V > shaped trailing edge to it. 102 hours on the ship now without jury struts; > works great. I got this idea from a Buckeye Pietenpol Newsletter years ago. > > Doug Bryant > > -------- > Chris Tracy > Sacramento, CA > WestCoastPiet.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=210841#210841 > > -- Ken Chambers 512-796-1798 ________________________________________________________________________________
Date: Oct 29, 2008
For what it's worth, according to drawings published in a 1987 edition of the Experimenter, The Heath LN Parasol (with the N-braced wings) apparently used 1 1/8" x .035" (SAE 1015) tubing for the front and rear lift struts, and 1 1/4" x .035" for the center (diagonal) strut. Remember, though, that the Heath is a much smaller plane than the Pietenpol (this fact becomes really apparent if you happen to walk up to Chris Price's Heath that is based at Brodhead. That is a tiny airplane) Bill C. ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Oct 29, 2008
Gee, welding sure sounds like it is work and may take some skill. That makes the deal I just did sound great. In exchange for a $10 military surplus maid cart (you know the maids push them around with a trash bag on one side and a dirty linnen bag on the other with cleaning supplies and sheets in the middle) hanger neigbors Steve and Freda (mentioned by Oscar earlier) are going to practice welding on a swiveling jack onto my old plymouth pickup bed trailer. The weld does not have to be particularly pretty (or pretty at all) so it will be great for Steve to learn/practice welding. The price is right for me also. BTW, Oscar is getting too snooty for his own good. He turned down one of these maid carts. Said he does not want to clutter up his hangers (yes two hangers!) on he keeps his Peit in and one he is building anouther plane in. Blue skies Steve D ----- Original Message ----- From: Jim Ash <ashcan(at)earthlink.net> Date: Wednesday, October 29, 2008 13:02 Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > > I went to welding classe a couple nights a week for three years. Certified stick. Was working on the MIG cert and TIG certs when the > administrative types started making noises that they'd rather have > a food service curriculum than welding. I backed off focusing on > the certs and practiced all kinds of everything they had. Never > got to play with the plasma torch or weld plastic (they didn't > have a plastic rig), but did everything else available in the shop. > > Part of my problem with having access to the really nice toys in > that class is that it's emotionally harder to accept having to > work on a lesser piece of equipment at home. Specifically, the TIG > machines I used were all water-cooled. I've had my reservations > about air-cooled machines, but if I got to spend a little quality > time with one I imagine I'd get over it. I did a nightmare job > welding replacement floor panels into a friend's mid-70's El- > Camino, using a cheapie MIG welder he borrowed. I should have > known better. The duty cycle on it was about .005 percent. I'd get > about 2" of good bead then it would kick off on a thermal check. > That was when the feed wasn't so irregular it was bucking back or > burning back up into the nozzle. I spent more time fighting and > jury-rigging that machine than welding. I can certainly set up a > MIG machine, but that little monster was the devil incarnate. That > job made me gunshy of even considering anything less than > professional-quality equip! > ment. > > That said, the small Lincoln units are enticing. Maybe next April. > > Your point about practice is well-taken and sound advice to all. > It's why a have a box full of junk 4130 short cuts of assorted > sizes here. Granted I haven't welded any 4130 in a while, but I'll > have lots of little 'cluster art' and that box will be long empty > before I consider welding up anything my butt is going to fly > behind, regardless of whether it's with a TIG machine or a gas > torch. > > Jim > > -----Original Message----- > >From: CozyGirrrl(at)aol.com > >Sent: Oct 29, 2008 11:34 AM > >To: pietenpol-list(at)matronics.com > >Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air > workshops> > >The small Lincoln machines were designed specifically for the > homebuilder > >and are great to use, by all means "pick one up" but please go > take a minimum of > > a 6 week adult ed TIG welding class after you familiarize > yourself with it. > >They may not teach you any earth shattering epiphanies that will > make you an > >ace TIG welder overnight but they will force you to do something > you will > >NEVER do at home... PRACTICE, hour after hour of practice but > also with someone > >looking over your shoulder that has the good judgement to say > "try this > >instead of what you are doing now". Its the adjustments in > technique from someone > >who knows that will help turn you into a welder a lot faster > than many hours > >of frustrating trial and error. > >All too often we will buy a tool with a project in mind and of > course go > >right into it producing predictably horrid results. Practice what > you want to do > >on some non critical materials, set up practice welds that > simulate the ones > >you want to do. Don't jump into your project parts hoping they > will turn out > >then accept the mediocre results as good enough. > > > >Regards, Chrissi > > > >CG Products, Custom Aircraft Hardware > >www.CozyGirrrl.com > >Cozy Mk-IV RG 13B-turbo > >Plans #957 Chapter? big pieces done, details, details > >===== > >If you have a "Spam Blocker" that requires > >we fill out a form you will not hear from us. > >Please do not make your spam problem ours. > > > > > >In a message dated 10/29/2008 8:28:25 A.M. Central Daylight Time, > > >ashcan(at)earthlink.net writes: > > > >--> Pietenpol-List message posted by: Jim Ash < > > > >Do you know if the AWS spec on welding 4130 tubing they talk about has gone > >public yet? I'd like to read it. > > > >One of my concerns is that the tolerances on certain technical aspects of > >homebuilding are (in my opinion) too tight to allow the necessary 'wiggle room' > >for an amateur working under less than ideal conditions in their garage or > >basement (or under a tarp in the yard somewhere). Although composite > >construction comes to mind first (mixing proportions, temperature and humidity > >controls, practical cleanliness), I'm talking the specific point of not normalizing > >after TIG welding. > > > >People who get paid to do something generally try to minimize the work/time > >ratio, being that time is money for them. As an amateur who happens to also > >enjoy the process, I'm more inclined to take the extra time and not shortcut > >that last optional step if there is one. It is my opinion that for most of the > >things I do around the house, I'm better off doing them myself than hiring a > >professional. Not because I'm better at it; I'm probably not. But I'm good > >enough to come close, and I'm more personally interested in the final result > >and more willing to expend the extra effort to see it gets done as good as I > >can do it. > > > >If the AWS spec is 'tolerant' enough of the TIG process in a less-than-ideal > >environment to not require normalizing, Ill back off. I do like my gas, but > >it might be enough to put me over the edge and pick up one of those little > >Lincoln machines. > > > >Jim Ash > > > > > > > >-----Original Message----- > >>From: HelsperSew(at)aol.com > >>Sent: Oct 29, 2008 6:38 AM > >>To: pietenpol-list(at)matronics.com > >>Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > >> > >>Bill, > >> > >>I also attended a TIG welding Sport Air EAA workshop at Griffin. It was > >WELL > >>worth every penny and more. They give you the perfect mix of theory and > >>practice. It is all spoon-fed to you right there. The beauty is that you > >have > >>instant feedback from the expert. This makes all the difference in the > >world and > >>you can learn at lightning speed. I had a different instructor but he too > >was > >>an expert that welds at Indy. He worked for Lincoln as an instructor. I > >>agree with the writer of that piece that you linked. I owned a Lincoln 175 > >square > >>wave machine for months before that but was just guessing on a lot of > >stuff. > >>BTW I also attended the Sport Air fabric covering workshop. Very good > >also. > >> > >>Dan Helsper > >>Poplar Grove, IL. > >> > >>**************Play online games for FREE at Games.com! All of your > >favorites, > >>no registration required and great graphics check it out! > >>http://www.games.com?ncid=emlcntusgame00000001) > > > > > > > > > > > > > > > > > >**************Plan your next getaway with AOL Travel. Check out Today's Hot > >5 Travel Deals! > >(http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) > > > > > > ________________________________________________________________________________
Date: Oct 29, 2008
Jack et al., Thanks for this lively discussion on rod ends. It brings to mind some other questions I have. Possibly some of you guys have knowledge and experience that will help me answer them. Jack, the photo you show of a spherical rod end suggests that it fits into a fork. On my struts, the fuselage end is like what I've seen on Cubs - the rod end is a fork and the attach fitting on the fuselage is a flat tang that fits in that fork. In fact, the struts on my Piet may be from a Cub. My question is, how far out can you unscrew the rod end without causing an safety issue? For purposes of just tension or compression loads exactly along the axis of the rod screw shaft, I assume that as long as all the threads of the female end are in contact with threads of the rod, maximum strength is maintained. However, at what point do side loads become an issue? Assuming that our struts and rod ends are refitted from a Cub, does anyone know if Piper ever set a limit an how far the rod ends can be unscrewed? I ask this because I would like to unscrew the rod ends to permit more dihedral. Our dihedral is currently less than 1 degree. Thanks, Jeff ________________________________________________________________________________
Date: Oct 29, 2008
Jim Ash wrote: > That said, the small Lincoln units are enticing. Maybe next April. Yup. Or the Miller or Thermal Arc equivalents. They both are supposed to be better than the Lincoln at low amperage; the Thermal Arc 185TSW in particular is supposed to be extremely good at the low end, where we would be working. Can't verify that from experience, as I keep trying to gather the will to buy a TIG setup and never quite get there. When the time comes, go to sci.engr.joining.welding and ask Ernie Leimkuhler what's best for the purpose. A better model might come along by then, and he's likely to know. Owen ________________________________________________________________________________
Date: Oct 29, 2008
Mike, The overall load that can be carried by the rod ends (or bolts, or tubing, or bar, or whatever) is dependant on two main factors. One is the tensile strength of the material, but the other is equally important - the cross-sectional area of the member. The tensile strength is given in pounds per square inch, so the load (in pounds) that it can carry obviously is dependant on the cross-sectional area (in square inches). Aluminum, with the lower tensile strength would need a bigger cross-sectional area than steel, with the higher strength. You could have two fittings that can both carry the same load - one made of aluminum and one made of steel. The difference will be that the steel fitting will be smaller in cross-section than the aluminum one. If you have a big enough cross-section, you could probably make the fittings out of old cheese (not really recommended - it's really trick to weld). My main point here is that almost any tensile strength will carry the load, provided the cross-sectional area is sufficient. Whether that cross-sectional area is practical is another question. Another thing to always keep in mind is the old saw about a chain only being as strong as its weakest link. Bill C. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 1:52 PM Subject: RE: Pietenpol-List: Adequate rod ends I understand the terms, I was just wondering why the two references in the email...no big deal. I still need to find out what tensile strength will work. ________________________________________________________________________________
Date: Oct 29, 2008
Fess up Oscar, what's the the other plane you're building? Enquiring minds... ________________________________________________________________________________
Date: Oct 29, 2008
Dear Jim, Contact TIGdepot.net and he'll fix you right up with a very nice compact water cooled TIG handpiece with a flexible head and 12 or 25 ft hoses and adapter. All the consumables are the same as the handpiece that comes with the welder. The added bonus is that the three flex tubes coming out of it are v ery flexible compared to the regular single cable, this means much less fatigue and easier maneuverability... it changed my life! For the kind of welding you would be doing (up to 1/8") all you need is a 5 gallon bucket of water and a fountain pump from Harbor Freight. All you will get is a dribble (with 25 ft hoses that's all you will get). I do a lot of production welding with this setup and thin goatskin gloves and never notice the handpiece getting warm. Have fun, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ===== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/29/2008 12:49:48 P.M. Central Daylight Time, ashcan(at)earthlink.net writes: --> Pietenpol-List message posted by: Jim Ash I went to welding classe a couple nights a week for three years. Certified stick. Was working on the MIG cert and TIG certs when the administrative ty pes started making noises that they'd rather have a food service curriculum tha n welding. I backed off focusing on the certs and practiced all kinds of everything they had. Never got to play with the plasma torch or weld plasti c (they didn't have a plastic rig), but did everything else available in the shop. Part of my problem with having access to the really nice toys in that class is that it's emotionally harder to accept having to work on a lesser piece of equipment at home. Specifically, the TIG machines I used were all water-cooled. I've had my reservations about air-cooled machines, but if I got to spend a little quality time with one I imagine I'd get over it. I did a nightmare job welding replacement floor panels into a friend's mid-70's El-Camino, using a cheapie MIG welder he borrowed. I should have known better. The dut y cycle on it was about .005 percent. I'd get about 2" of good bead then it w ould kick off on a thermal check. That was when the feed wasn't so irregular it was bucking back or burning back up into the nozzle. I spent more time fighting and jury-rigging that machine than welding. I can certainly set up a MIG machine, but that little monster was the devil incarnate. That job made me gunshy of even considering anything less than professional-quality equipment. That said, the small Lincoln units are enticing. Maybe next April. Your point about practice is well-taken and sound advice to all. It's why a have a box full of junk 4130 short cuts of assorted sizes here. Granted I haven't welded any 4130 in a while, but I'll have lots of little 'cluster a rt' and that box will be long empty before I consider welding up anything my bu tt is going to fly behind, regardless of whether it's with a TIG machine or a gas torch. Jim -----Original Message----- >From: CozyGirrrl(at)aol.com >Sent: Oct 29, 2008 11:34 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > >The small Lincoln machines were designed specifically for the homebuilder >and are great to use, by all means "pick one up" but please go take a minimum of > a 6 week adult ed TIG welding class after you familiarize yourself with it. >They may not teach you any earth shattering epiphanies that will make you an >ace TIG welder overnight but they will force you to do something you will >NEVER do at home... PRACTICE, hour after hour of practice but also with someone >looking over your shoulder that has the good judgement to say "try this >instead of what you are doing now". Its the adjustments in technique from someone >who knows that will help turn you into a welder a lot faster than many hours >of frustrating trial and error. >All too often we will buy a tool with a project in mind and of course go >right into it producing predictably horrid results. Practice what you want to do >on some non critical materials, set up practice welds that simulate the ones >you want to do. Don't jump into your project parts hoping they will turn out >then accept the mediocre results as good enough. > >Regards, Chrissi > >CG Products, Custom Aircraft Hardware >www.CozyGirrrl.com >Cozy Mk-IV RG 13B-turbo >Plans #957 Chapter? big pieces done, details, details >===== >If you have a "Spam Blocker" that requires >we fill out a form you will not hear from us. >Please do not make your spam problem ours. > > >In a message dated 10/29/2008 8:28:25 A.M. Central Daylight Time, >ashcan(at)earthlink.net writes: > >--> Pietenpol-List message posted by: Jim Ash > >Do you know if the AWS spec on welding 4130 tubing they talk about has gone >public yet? I'd like to read it. > >One of my concerns is that the tolerances on certain technical aspects of >homebuilding are (in my opinion) too tight to allow the necessary 'wiggle room' >for an amateur working under less than ideal conditions in their garage o r >basement (or under a tarp in the yard somewhere). Although composite >construction comes to mind first (mixing proportions, temperature and humidity >controls, practical cleanliness), I'm talking the specific point of not normalizing >after TIG welding. > >People who get paid to do something generally try to minimize the work/time >ratio, being that time is money for them. As an amateur who happens to also >enjoy the process, I'm more inclined to take the extra time and not shortcut >that last optional step if there is one. It is my opinion that for most o f the >things I do around the house, I'm better off doing them myself than hirin g a >professional. Not because I'm better at it; I'm probably not. But I'm goo d >enough to come close, and I'm more personally interested in the final result >and more willing to expend the extra effort to see it gets done as good a s I >can do it. > >If the AWS spec is 'tolerant' enough of the TIG process in a less-than-ideal >environment to not require normalizing, Ill back off. I do like my gas, but >it might be enough to put me over the edge and pick up one of those littl e >Lincoln machines. > >Jim Ash > > >-----Original Message----- >>From: HelsperSew(at)aol.com >>Sent: Oct 29, 2008 6:38 AM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops >> >>Bill, >> >>I also attended a TIG welding Sport Air EAA workshop at Griffin. It was >WELL >>worth every penny and more. They give you the perfect mix of theory and >>practice. It is all spoon-fed to you right there. The beauty is that you >have >>instant feedback from the expert. This makes all the difference in the >world and >>you can learn at lightning speed. I had a different instructor but he to o >was >>an expert that welds at Indy. He worked for Lincoln as an instructor. I >>agree with the writer of that piece that you linked. I owned a Lincoln 175 >square >>wave machine for months before that but was just guessing on a lot of >stuff. >>BTW I also attended the Sport Air fabric covering workshop. Very good >also. >> >>Dan Helsper >>Poplar Grove, IL. >> >>**************Play online games for FREE at Games.com! All of your >favorites, >>no registration required and great graphics =93 check it out! >>http://www.games.com?ncid=emlcntusgame00000001) > > >**************Plan your next getaway with AOL Travel. Check out Today's Hot >5 Travel Deals! >(http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Subject: Normalizing thin tube tig welds
Date: Oct 29, 2008
Jim We Tig weld up frames that can take + - 8g's and we don't mormalize. I don't think you could brake them at 20 g's. We do normalize any welds on an engine mount. We found the best way to do it is to do it in the dark and bring the entire joint to just a dull red and then stop and let it cool by itself. Good luck Jerry Grogan Prairie City, IA ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: Learning to weld @ Sport Air workshops
AKKK ! its the Red -VS- Blue (Lincoln / Miller) argument rearing its ugly head. If you manage to get to SNF or Osh, go into the Lincoln tent and ask one of the guys to run you through the side by side comparison. They have one each Lincoln and Miller side by side with covers stripped off, they start at the power switch, go through the unit piece by piece all the way to the plug, by the time they are done you want to go kick a Miller. This is not a question of taking their word for it as you can see the differences easily once they are pointed out. I am talking about the 175, 185, 225 Pro models aimed at serious entry level welders. In my welding classes I used a brand new very high end Miller every evening, I was very happy to get home to my 185 Pro, as always your mileage may vary. The Lincoln 175-225 Pro models are ideally suited for our thin materials though I have no problem with heavier materials either. It's very easy starting (it is a non-issue) and I have had no problems with it ever. Also TIGdepot.net is your best friend for supplies and answers, give them a call, they know what EAAers need. Regards, Chrissi & Randi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ============================== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/29/2008 1:53:52 P.M. Central Daylight Time, owen5819(at)comcast.net writes: --> Pietenpol-List message posted by: Owen Davies Jim Ash wrote: > That said, the small Lincoln units are enticing. Maybe next April. Yup. Or the Miller or Thermal Arc equivalents. They both are supposed to be better than the Lincoln at low amperage; the Thermal Arc 185TSW in particular is supposed to be extremely good at the low end, where we would be working. Can't verify that from experience, as I keep trying to gather the will to buy a TIG setup and never quite get there. When the time comes, go to sci.engr.joining.welding and ask Ernie Leimkuhler what's best for the purpose. A better model might come along by then, and he's likely to know. Owen **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Chrissy, Confirmation that I made the right choice buying the 175 square wave machine!! Only thing is now you made me envious of the water-cooled torch head!!! Drat!!! OH well.................. Dan Helsper Poplar Grove, IL. **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
Dan, The water cooled head is nice but unless you do a lot of high amp long duty cycle welding you can wait awhile, get a heavier glove =) The best news is you bought a darn good welder to begin with. Go Red! We own three Lincoln welders. Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ============================== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/29/2008 6:17:53 P.M. Central Daylight Time, HelsperSew(at)aol.com writes: Chrissy, Confirmation that I made the right choice buying the 175 square wave machine!! Only thing is now you made me envious of the water-cooled torch head!!! Drat!!! OH well.................. Dan Helsper Poplar Grove, IL. ____________________________________ Plan your next getaway with AOL Travel. _Check out Today's Hot 5 Travel Deals!_ (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
workshops While we're kinda on this, has anybody had any experience with any of those kits that will convert your stick machine to a TIG machine? It sure takes some of the sting out of the price, and gives me a little more versatility to be able to do either stick or TIG. Jim Ash -----Original Message----- >From: Owen Davies <owen5819(at)comcast.net> >Sent: Oct 29, 2008 2:52 PM >To: pietenpol-list(at)matronics.com >Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > > >Jim Ash wrote: >> That said, the small Lincoln units are enticing. Maybe next April. >Yup. Or the Miller or Thermal Arc equivalents. They both are supposed to >be better than the Lincoln at low amperage; the Thermal Arc 185TSW in >particular is supposed to be extremely good at the low end, where we >would be working. Can't verify that from experience, as I keep trying to >gather the will to buy a TIG setup and never quite get there. > >When the time comes, go to sci.engr.joining.welding and ask Ernie >Leimkuhler what's best for the purpose. A better model might come along >by then, and he's likely to know. > >Owen > > ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Adequate rod ends
Well, the nice part about rod ends, they come in all kinds of sizes, shapes, ball configurations, lubricated, solid, etc. If you are worried about the screw length being to short, you may be able to find the same size rod end, just longer on the threads, or one that is threaded up to the head. I would guess, as with nuts and bolts, if you can verify that you have more then 2-4 full threads engaged, you should be OK for the straight tension loads. No clue on side loads. Personally, I plan to use solid rod ends...no ball...and keep them as short as I can, but still have about an inch of adjustment. --- On Wed, 10/29/08, Jeff Boatright wrote: From: Jeff Boatright <jboatri(at)emory.edu> Subject: RE: Pietenpol-List: Adequate rod ends Date: Wednesday, October 29, 2008, 2:48 PM Jack et al., Thanks for this lively discussion on rod ends. It brings to mind some other questions I have. Possibly some of you guys have knowledge and experience that will help me answer them. Jack, the photo you show of a spherical rod end suggests that it fits into a fork. On my struts, the fuselage end is like what I've seen on Cubs - the rod end is a fork and the attach fitting on the fuselage is a flat tang that fits in that fork. In fact, the struts on my Piet may be from a Cub. My question is, how far out can you unscrew the rod end without causing an safety issue? For purposes of just tension or compression loads exactly along the axis of the rod screw shaft, I assume that as long as all the threads of the female end are in contact with threads of the rod, maximum strength is maintained. However, at what point do side loads become an issue? Assuming that our struts and rod ends are refitted from a Cub, does anyone know if Piper ever set a limit an how far the rod ends can be unscrewed? I ask this because I would like to unscrew the rod ends to permit more dihedral. Our dihedral is currently less than 1 degree. Thanks, Jeff ________________________________________________________________________________
Date: Oct 29, 2008
Understood. My delema is this: I can get steel ends or aluminum ends, both solid and both about the same size...1/4" hole, 1/4-20 threads, 1-1/2" long threaded shaft, etc. The steel ends are cheaper, but I am sure they weigh more. They are rated at 75,000 PSI tensil, the aluminum is rated at 45,000. How do I figure if the 45,000 is enough? --- On Wed, 10/29/08, Bill Church wrote: From: Bill Church <eng(at)canadianrogers.com> Subject: RE: Pietenpol-List: Adequate rod ends Date: Wednesday, October 29, 2008, 3:05 PM Mike, - The overall-load that can be carried by the rod ends (or bolts, or tubing , or bar, or whatever) is dependant on two main factors. One is the tensile strength of the material, but the other is equally important - the cross-s ectional area of the member. The tensile strength is given in pounds per sq uare inch, so the load (in pounds) that -it can carry obviously is depend ant on the cross-sectional area (in square inches). Aluminum, with the lowe r tensile strength would need a bigger cross-sectional area-than steel, w ith the higher strength. You could have two fittings that can both carry th e same load - one made of aluminum and one made of steel. The difference wi ll be that the steel fitting will be smaller in cross-section than the alum inum one. If you have a big enough cross-section, you could probably make the fitting s out of old cheese (not really recommended - it's really trick to weld). M y main point here is that almost any tensile strength will carry the load, provided the cross-sectional area is sufficient. Whether that cross-section al area is practical is another question. Another thing to always keep in mind is the old saw about a chain only bein g as strong as its weakest link. - Bill C. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 1:52 PM Subject: RE: Pietenpol-List: Adequate rod ends I understand the terms, I was just wondering why the two references in the email...no big deal. I still need to find out what tensile strength will wo rk. ________________________________________________________________________________
Date: Oct 29, 2008
Subject: Re: Normalizing thin tube tig welds
One of the questions I meant to ask is if I normalize after TIG welding, does it hurt anything besides wasting some of my time? Is there a structural down side to normalizing or is it just the extra work that seems to be the issue? Jim -----Original Message----- >From: JERRY GROGAN <jerry(at)skyclassic.net> >Sent: Oct 29, 2008 4:36 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Normalizing thin tube tig welds > >Jim > >We Tig weld up frames that can take + - 8g's and we don't mormalize. I don't think you could brake them at 20 g's. We do normalize any welds on an engine mount. We found the best way to do it is to do it in the dark and bring the entire joint to just a dull red and then stop and let it cool by itself. > >Good luck >Jerry Grogan >Prairie City, IA > > ________________________________________________________________________________
Date: Oct 29, 2008
workshops I tend to do a lot of welding off and on, and on a wide variety of stuff. I've got a cast iron job for a friend here right now waiting for me to be allowed out. The rod alone prices out at about $7 a stick, but it's still cheaper for him than having the part remade. I'm not really looking for a unit to get me through an airplane. I'm looking for a unit that I can use for everything, including an airplane. I never really got out of the workshop at SNF this last year; been meaning to just to see the show sometime. Jim -----Original Message----- >From: CozyGirrrl(at)aol.com >Sent: Oct 29, 2008 6:59 PM >To: pietenpol-list(at)matronics.com >Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > >AKKK ! its the Red -VS- Blue (Lincoln / Miller) argument rearing its ugly >head. >If you manage to get to SNF or Osh, go into the Lincoln tent and ask one of >the guys to run you through the side by side comparison. They have one each >Lincoln and Miller side by side with covers stripped off, they start at the >power switch, go through the unit piece by piece all the way to the plug, by the > time they are done you want to go kick a Miller. This is not a question of >taking their word for it as you can see the differences easily once they are >pointed out. I am talking about the 175, 185, 225 Pro models aimed at serious >entry level welders. >In my welding classes I used a brand new very high end Miller every evening, >I was very happy to get home to my 185 Pro, as always your mileage may vary. >The Lincoln 175-225 Pro models are ideally suited for our thin materials >though I have no problem with heavier materials either. It's very easy starting >(it is a non-issue) and I have had no problems with it ever. >Also TIGdepot.net is your best friend for supplies and answers, give them a >call, they know what EAAers need. > >Regards, Chrissi & Randi > >CG Products, Custom Aircraft Hardware >www.CozyGirrrl.com >Cozy Mk-IV RG 13B-turbo >Plans #957 Chapter? big pieces done, details, details >============================== >If you have a "Spam Blocker" that requires >we fill out a form you will not hear from us. >Please do not make your spam problem ours. > > >In a message dated 10/29/2008 1:53:52 P.M. Central Daylight Time, >owen5819(at)comcast.net writes: > >--> Pietenpol-List message posted by: Owen Davies > >Jim Ash wrote: >> That said, the small Lincoln units are enticing. Maybe next April. >Yup. Or the Miller or Thermal Arc equivalents. They both are supposed to >be better than the Lincoln at low amperage; the Thermal Arc 185TSW in >particular is supposed to be extremely good at the low end, where we >would be working. Can't verify that from experience, as I keep trying to >gather the will to buy a TIG setup and never quite get there. > >When the time comes, go to sci.engr.joining.welding and ask Ernie >Leimkuhler what's best for the purpose. A better model might come along >by then, and he's likely to know. > >Owen > > >**************Plan your next getaway with AOL Travel. Check out Today's Hot >5 Travel Deals! >(http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Subject: Re: Adequate rod ends
Date: Oct 29, 2008
I think we need some clarification of what's involved with determining the actual strength of the part. There are four areas in question on this fitting. What has to be determined is which area is the smallest. That's going to be the weakest therefore the one that determines if the part is strong enough. This "part" is made up of two pieces, the shank and the base that's welded or bolted to the strut. As you can see in pic 1 there are four "areas" involved. D1 is the solid portion of the threaded shank, D2 is the shank bit between the threads and head, which may be smaller than D1, A is the area of the head cross section that holds the ball and the thread area is the cross section area of the threads themseves. If either the shank or base is stronger than the other, ie one is steel and the other aluminum, then the weaker is the determining strength. In pic 3 area 1 is that at the base of the threads of either or both base and shank. Area two is 1/2 way up the thread. In pic 5 the base material is the stronger. therefore the threads will strip off the shank. In pic 6 both base and shank are the same material and strength so will most likely shear half way up the threads. If either D2 or A are smaller in area than the thread area that you've calculated then one other consideration will come into play when the thing is in place on the plane and you fiddle with it to make adjustments. If you have to screw the shank out of the base then at some point the threaded portion will become the weak link regardless of your initial calculations. Myself, I have four large, robust fork ends that will fit over the standard plates sticking out the Jenny style LG fittings. http://www.wicksaircraft.com/catalog/product_detail.php?pid=9039 Now you have to get out the ol' calculator and do your own arithmatic. :-) Clif "You are never given a dream without also being given the power to make it true. You may have to work for it, however."~ Richard Bach Mike, The overall load that can be carried by the rod ends (or bolts, or tubing, or bar, or whatever) is dependant on two main factors. One is the tensile strength of the material, but the other is equally important - the cross-sectional area of the member. The tensile strength is given in pounds per square inch, so the load (in pounds) that it can carry obviously is dependant on the cross-sectional (in square inches). Another thing to always keep in mind is the old saw about a chain only being as strong as its weakest link. Bill C. ________________________________________________________________________________
Date: Oct 29, 2008
workshops CozyGirrrl(at)aol.com wrote: > AKKK ! its the Red -VS- Blue (Lincoln / Miller) argument rearing its > ugly head. Good heavens, I hadn't meant to start an argument. Just offering options, to be weighed when the time comes. You'll notice that my only firm recommendation was to get up-to-the-minute information when the time comes from the most reliable source I've found on the Net. Owen ________________________________________________________________________________
Date: Oct 29, 2008
workshops Sorry Owen, I meant that to be tongue in cheek but I think it came out too emphatic. And thank you for the additional reference site too. We have seen people usually have a strong preference for Red or Blue, I have found in a round about way that most people whose first experience with welding was in school are Blue people because Blue makes schools an offer that Red cannot compete with, its that simple, in almost any application people prefer the tools they were taught with; good marketing. I agree that good research is important before any major purchase. Sort of like plasma cutters, after investigating what was the best for our needs we decided we cannot afford it (yet)(and its not Red), there was just no sense in buying anything less. This is truly like learning to play a piano; the concept is simple enough but to master it takes years of practice, you can do it well if you take a class and practice a lot. Regards, Chrissi CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ============================== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 10/29/2008 9:21:54 P.M. Central Daylight Time, owen5819(at)comcast.net writes: --> Pietenpol-List message posted by: Owen Davies CozyGirrrl(at)aol.com wrote: > AKKK ! its the Red -VS- Blue (Lincoln / Miller) argument rearing its > ugly head. Good heavens, I hadn't meant to start an argument. Just offering options, to be weighed when the time comes. You'll notice that my only firm recommendation was to get up-to-the-minute information when the time comes from the most reliable source I've found on the Net. Owen **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! (http://travel.aol.com/discount-travel?ncid=emlcntustrav00000001) ________________________________________________________________________________
Date: Oct 29, 2008
workshops I wouldn't recommend them, they are lift start, meaning you touch the tungston tip to the metal you are welding and lift to start the weld, this is bad because it contaminates the tungston and introduces perosity into the weld. Also they don't have a built in gas solinoid for the argon, you turn on the gas, weld, then turn off the gas, very wateful of the gas, espically if you forget to turn it off. I still suggest starting with an Oxy welding setup, it's cheap and the most versitile tool in your shop. But if you must have a TIG, try ebay, I got mine for $600 Australian, it is only DC so I cannot weld Aluminium, but it is High frequency start with a gas solinoid and 140 amp 100% duty, and 180 amp 80%. You should be able to get the same rig in the states for $350 new. Charley --- On Thu, 10/30/08, Jim Ash wrote: > From: Jim Ash <ashcan(at)earthlink.net> > Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > To: pietenpol-list(at)matronics.com > Date: Thursday, October 30, 2008, 10:43 AM > > > While we're kinda on this, has anybody had any > experience with any of those kits that will convert your > stick machine to a TIG machine? It sure takes some of the > sting out of the price, and gives me a little more > versatility to be able to do either stick or TIG. > > Jim Ash > > -----Original Message----- > >From: Owen Davies <owen5819(at)comcast.net> > >Sent: Oct 29, 2008 2:52 PM > >To: pietenpol-list(at)matronics.com > >Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: > Learning to weld @ Sport Air workshops > > > > > > >Jim Ash wrote: > >> That said, the small Lincoln units are enticing. > Maybe next April. > >Yup. Or the Miller or Thermal Arc equivalents. They > both are supposed to > >be better than the Lincoln at low amperage; the Thermal > Arc 185TSW in > >particular is supposed to be extremely good at the low > end, where we > >would be working. Can't verify that from > experience, as I keep trying to > >gather the will to buy a TIG setup and never quite get > there. > > > >When the time comes, go to sci.engr.joining.welding and > ask Ernie > >Leimkuhler what's best for the purpose. A better > model might come along > >by then, and he's likely to know. > > > >Owen > > > > > > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Oct 29, 2008
Jeff, The following may supply your answer (from "Mechanic's Toolbox, www.sacskyranch.com): "If you are using "high strength" bolts in tension (pulling the bolt lengthwise) then one needs a "high strength" nut to prevent stripping of the nut threads. Good Design Practice is to have a sufficiently strong nut so that the first failure is a broken bolt and not a stripped thread. A broken bolt is relatively easy to notice and replace. A stripped thread occurs at the first thread where the stress is highest and progresses along the thread leading to complete failure. The bolt may remain in place unnoticed in a weakened state. When the bolt is in tension the threads are in shear. To meet the above requirement the nut's shear strength should be equal to the bolts shear strength (same material). Sometimes this is not possible, such as when threading into a tapped hole and this is where Thread Engagement Length becomes important. More engaged threads mean more shear stress area to take the load. So our second Good Design Practice is that the "length of engagement should be long enough that thread failure will not occur before the bolt breaks." Generally, bolts can only withstand half as much shear as tension. This means that the thread shear area needs to be at least double the bolt's tensile stress area. Minimum Engagement Length is then the length of engagement that the shear area is twice the bolts tensile stress area. Length of Engagement works up to a point. At some point more engagement doesn't increase shear strength because shear stress is not evenly distributed in the nut. The first threads take most of the load. Adding extra engagement may not significantly increase the load capacity." As you probably know, when using a threaded rod & tube, you would measure back .75"-1" and drill a "sight hole" in the tube. This way you know that your threaded rod is at least as deep as the sight hole. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (endless metal parts!) (12 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Sent: Wednesday, October 29, 2008 11:48 AM Subject: RE: Pietenpol-List: Adequate rod ends Jack et al., Thanks for this lively discussion on rod ends. It brings to mind some other questions I have. Possibly some of you guys have knowledge and experience that will help me answer them. Jack, the photo you show of a spherical rod end suggests that it fits into a fork. On my struts, the fuselage end is like what I've seen on Cubs - the rod end is a fork and the attach fitting on the fuselage is a flat tang that fits in that fork. In fact, the struts on my Piet may be from a Cub. My question is, how far out can you unscrew the rod end without causing an safety issue? For purposes of just tension or compression loads exactly along the axis of the rod screw shaft, I assume that as long as all the threads of the female end are in contact with threads of the rod, maximum strength is maintained. However, at what point do side loads become an issue? Assuming that our struts and rod ends are refitted from a Cub, does anyone know if Piper ever set a limit an how far the rod ends can be unscrewed? I ask this because I would like to unscrew the rod ends to permit more dihedral. Our dihedral is currently less than 1 degree. Thanks, Jeff ________________________________________________________________________________
Date: Oct 30, 2008
workshops I'm set (with the exception of a Meco or Smith torch, and maybe a nice set of two-stange regulators in a weak moment) for oxy-acetylene, but I do agree with your comments as to its versatility. One of the down sides of it for me is that I don't have a garage (working on a shop building), and I can't do it in the basement without (justifiable) complaints from my wife about stinking the whole house up. For the record, I have no allegiance to either Red or Blue. I've used both happily. Besides, I'm registered as an independent. Some of my requirements for a TIG system are 1)HF - I want a versatile tool. One that will do aluminum, stainless, and maybe even the exotics if I ever had a call for it. Not being able to do aluminum or stainless would be a deal-breaker for me, even for a cheapie add-on system. I can do aluminum and stainless with my torches now, but it's a bit of a pain and requires more finess (and more flux). 2) Foot-pedal control. Being able to adjust my heat on the fly is a big deal for me with a TIG setup. If I have to stop a good pass to fiddle with some knobs, I might as well not bother at all. 3) Pre- and Post- flow control. I guess I shouldn't be surprised the add-ons don't have a solenoid valve, but I guess I was taking it for granted they did. Jim Ash -----Original Message----- >From: charles loomis <rameses32(at)yahoo.com> >Sent: Oct 30, 2008 12:23 AM >To: pietenpol-list(at)matronics.com >Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > > >I wouldn't recommend them, they are lift start, meaning you touch the tungston tip to the metal you are welding and lift to start the weld, this is bad because it contaminates the tungston and introduces perosity into the weld. Also they don't have a built in gas solinoid for the argon, you turn on the gas, weld, then turn off the gas, very wateful of the gas, espically if you forget to turn it off. > >I still suggest starting with an Oxy welding setup, it's cheap and the most versitile tool in your shop. But if you must have a TIG, try ebay, I got mine for $600 Australian, it is only DC so I cannot weld Aluminium, but it is High frequency start with a gas solinoid and 140 amp 100% duty, and 180 amp 80%. You should be able to get the same rig in the states for $350 new. > >Charley > > >--- On Thu, 10/30/08, Jim Ash wrote: > >> From: Jim Ash <ashcan(at)earthlink.net> >> Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops >> To: pietenpol-list(at)matronics.com >> Date: Thursday, October 30, 2008, 10:43 AM >> >> >> While we're kinda on this, has anybody had any >> experience with any of those kits that will convert your >> stick machine to a TIG machine? It sure takes some of the >> sting out of the price, and gives me a little more >> versatility to be able to do either stick or TIG. >> >> Jim Ash >> >> -----Original Message----- >> >From: Owen Davies <owen5819(at)comcast.net> >> >Sent: Oct 29, 2008 2:52 PM >> >To: pietenpol-list(at)matronics.com >> >Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: >> Learning to weld @ Sport Air workshops >> > >> >> > >> >Jim Ash wrote: >> >> That said, the small Lincoln units are enticing. >> Maybe next April. >> >Yup. Or the Miller or Thermal Arc equivalents. They >> both are supposed to >> >be better than the Lincoln at low amperage; the Thermal >> Arc 185TSW in >> >particular is supposed to be extremely good at the low >> end, where we >> >would be working. Can't verify that from >> experience, as I keep trying to >> >gather the will to buy a TIG setup and never quite get >> there. >> > >> >When the time comes, go to sci.engr.joining.welding and >> ask Ernie >> >Leimkuhler what's best for the purpose. A better >> model might come along >> >by then, and he's likely to know. >> > >> >Owen >> > >> > >> > >> > >> > >> >> >> http://www.matronics.com/Navigator?Pietenpol-List > > > > > ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Lift struts
Thanks to all who replied to my question about round strut size fairings etc. The bad news is that having my water well overhauled did brake the bank, so my buying trip is off for a while. Since it is now cold weather I'll probably hold off until next spring. I can digest this info for a while....... Ken--, The post from Doug Bryant was from the past. He sold his piet several years ago to someone around St. Louis and I doubt if he watches the list any longer. He and Chuck Ganzer are friends and worked together on Chucks Piet, so maybe Chuck can give some details. I saw Dougs struts and it's a good idea what he did. He ran the idea past several engineers at Beechcraft and they all gave him the thumbs up. Also they said it was strong enough to not need jury struts, and Doug did not install them. My only problem with his set up was weight. As the post reported, the struts were 1 1/4" x .049. Pretty hefty. Then he added the steel fairing to the back side. I don't know the size or thickness of the steel he used. As i recall the sides were around 1 1/2 in. so he would have taken a piece of 3'' flat to a shop and had it bent into a V then every few inches, ran a weld as he welded it to a a strut. Since I'm using the Model A, I have become a stickler for light weight. I was planing to brig a caliper to Brodhead and measure the thickness of the original strut material used on the Alan Rudolph Piet, but forgot to take it. Has anyone ever micked those struts and know the thickness? I bought 3/8 turnbuckle forks at B&B for strut adjustment ends. Less than $2.00 ea. AS&S says they are rated at 20K ea. Should hold an 80k Piet, right? By the way, neither Chuck or Doug put adjustments on the lower strut ends and said they never regretted it. Leon S. Airplane and water well poor in Ks. ________________________________________________________________________________
Date: Oct 30, 2008
Guys, Thanks for all of the responses. I see that I have done a poor job of explaining my question. I have attached a modification of Clif's drawing that shows my concern: As the rod end is unscrewed from the threaded portion of the strut, the rod shaft takes on "strut" function and experiences all the loads that the strut does, including side loads. How far out can the rod be unscrewed before it weakens the overall function of the strut assembly? Thanks again for all the replies, Jeff ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: aileron stuff
Date: Oct 30, 2008
Well guys here is a status report on my project. Per Dan Helsper's request I attached some photos of my wing with the aileron attached. I have also included a photo of drilling the aileron horn attachment. I used the hardwood block and tube method to insure the holes were aligned properly and perpendicular. This idea came from Chris Tracy on his web site. It worked well. This is the same method I used to drill all of the holes for the aileron hinge attachment screws. On the wings I still need to put in the nut plates for the aileron hinges, mount the aileron pulley supports and then run the cable. The fuselage is pretty well done, including all of the controls and cables I have mounted the main instruments in the IP, but still need to do some more like the engine gages, throttle, carb heat etc.. I am going to put the fuel tank in the front and that still needs to be made. The wing center section is complete. My empennage is complete and has been fitted to the fuselage with the guy wires for a test fit. Next on the agenda is the tail wheel and the straight axle main gear. I'd like to have my Piet done for the 80th in Oshkosh, but realistically that might be a stretch, depending on how much I get done this winter. I am also going to use a corvair engine. I have the core, but I still need to rebuild it. Around Valparaiso (VPZ) we have 4 Piet's in various stages on construction. All of them will be using Corvair power. The plan is to rebuild all of the engines at the same time in the same location with the assistance of our local EAA tech counselor. The great thing is the tech counselor is rebuilding a Piet and also doing a corvair conversion. He is also the person who did the restoration of the Allison engines for the Glacier Girl P-38 a few years ago. Rick Schreiber lmforge(at)earthlink.net ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Re: aileron stuff
Rick, The wings look a bit different from when I saw them, really nice. John In a message dated 10/30/2008 2:54:22 P.M. Eastern Daylight Time, lmforge(at)earthlink.net writes: Well guys here is a status report on my project. Per Dan Helsper's request I attached some photos of my wing with the aileron attached. I have also included a photo of drilling the aileron horn attachment. I used the hardwood block and tube method to insure the holes were aligned properly and perpendicular. This idea came from Chris Tracy on his web site. It worked well. This is the same method I used to drill all of the holes for the aileron hinge attachment screws. On the wings I still need to put in the nut plates for the aileron hinges, mount the aileron pulley supports and then run the cable. The fuselage is pretty well done, including all of the controls and cables I have mounted the main instruments in the IP, but still need to do some more like the engine gages, throttle, carb heat etc.. I am going to put the fuel tank in the front and that still needs to be made. The wing center section is complete. My empennage is complete and has been fitted to the fuselage with the guy wires for a test fit. Next on the agenda is the tail wheel and the straight axle main gear. I'd like to have my Piet done for the 80th in Oshkosh, but realistically that might be a stretch, depending on how much I get done this winter. I am also going to use a corvair engine. I have the core, but I still need to rebuild it. Around Valparaiso (VPZ) we have 4 Piet's in various stages on construction. All of them will be using Corvair power. The plan is to rebuild all of the engines at the same time in the same location with the assistance of our local EAA tech counselor. The great thing is the tech counselor is rebuilding a Piet and also doing a corvair conversion. He is also the person who did the restoration of the Allison engines for the Glacier Girl P-38 a few years ago. Rick Schreiber _lmforge(at)earthlink.net_ (mailto:lmforge(at)earthlink.net) **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Date: Oct 30, 2008
Thanks John. I'd like to work on my tank next but I'm trying to decide what to make it out of. I was going to go with aluminium.We have a local welder who does racing tanks. His prices were reasonable, but the last Piet tank he did was around $500 just for labor! I would like to go with glass, but since I will also burn auto fuel I am concerned about solvent resistance. When I get time I'll go through all of the posts to the web site and make a decision, unless someone would like to chime in now. Rick ----- Original Message ----- From: Sent: 10/30/2008 2:28:16 PM Subject: Re: Pietenpol-List: aileron stuff Rick, The wings look a bit different from when I saw them, really nice. John In a message dated 10/30/2008 2:54:22 P.M. Eastern Daylight Time, lmforge(at)earthlink.net writes: Well guys here is a status report on my project. Per Dan Helsper's request I attached some photos of my wing with the aileron attached. I have also included a photo of drilling the aileron horn attachment. I used the hardwood block and tube method to insure the holes were aligned properly and perpendicular. This idea came from Chris Tracy on his web site. It worked well. This is the same method I used to drill all of the holes for the aileron hinge attachment screws. On the wings I still need to put in the nut plates for the aileron hinges, mount the aileron pulley supports and then run the cable. The fuselage is pretty well done, including all of the controls and cables I have mounted the main instruments in the IP, but still need to do some more like the engine gages, throttle, carb heat etc.. I am going to put the fuel tank in the front and that still needs to be made. The wing center section is complete. My empennage is complete and has been fitted to the fuselage with the guy wires for a test fit. Next on the agenda is the tail wheel and the straight axle main gear. I'd like to have my Piet done for the 80th in Oshkosh, but realistically that might be a stretch, depending on how much I get done this winter. I am also going to use a corvair engine. I have the core, but I still need to rebuild it. Around Valparaiso (VPZ) we have 4 Piet's in various stages on construction. All of them will be using Corvair power. The plan is to rebuild all of the engines at the same time in the same location with the assistance of our local EAA tech counselor. The great thing is the tech counselor is rebuilding a Piet and also doing a corvair conversion. He is also the person who did the restoration of the Allison engines for the Glacier Girl P-38 a few years ago. Rick Schreiber lmforge(at)earthlink.net Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Date: Oct 30, 2008
If you are going to do composite you can use vinyl-ester resin as that is resistant to ethanol now comon in auto fuels http://www.aircraftspruce.com/catalog/cmpages/vinylester.php on the other hand if you make it out of aluminum you can cut all the pices yourself and just take them to someone to weld up, should save a bit on labor cost that way. Michael ----- Original Message ----- From: Richard Schreiber Thanks John. I'd like to work on my tank next but I'm trying to decide what to make it out of. I was going to go with aluminium.We have a local welder who does racing tanks. His prices were reasonable, but the last Piet tank he did was around $500 just for labor! I would like to go with glass, but since I will also burn auto fuel I am concerned about solvent resistance. When I get time I'll go through all of the posts to the web site and make a decision, unless someone would like to chime in now. Rick ________________________________________________________________________________
Date: Oct 30, 2008
workshops With a DC rig you can weld everything but Aluminium. Steel, stainless, brass, and copper are no problem, but you need AC for aluminium. I never was a fan for the foot control, doesn't do you much good when welding a fuselage, many times I only had one foot on the floor so foot control would have useless, they make a thumb control that I would suggest, if your spending the money for a AC/DC remote TIG, you might as well spend the extra hundred and get the thumb control. --- On Fri, 10/31/08, Jim Ash wrote: > From: Jim Ash <ashcan(at)earthlink.net> > Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: Learning to weld @ Sport Air workshops > To: pietenpol-list(at)matronics.com > Date: Friday, October 31, 2008, 12:12 AM > > > I'm set (with the exception of a Meco or Smith torch, > and maybe a nice set of two-stange regulators in a weak > moment) for oxy-acetylene, but I do agree with your comments > as to its versatility. One of the down sides of it for me is > that I don't have a garage (working on a shop building), > and I can't do it in the basement without (justifiable) > complaints from my wife about stinking the whole house up. > > For the record, I have no allegiance to either Red or Blue. > I've used both happily. Besides, I'm registered as > an independent. > > Some of my requirements for a TIG system are 1)HF - I want > a versatile tool. One that will do aluminum, stainless, and > maybe even the exotics if I ever had a call for it. Not > being able to do aluminum or stainless would be a > deal-breaker for me, even for a cheapie add-on system. I can > do aluminum and stainless with my torches now, but it's > a bit of a pain and requires more finess (and more flux). 2) > Foot-pedal control. Being able to adjust my heat on the fly > is a big deal for me with a TIG setup. If I have to stop a > good pass to fiddle with some knobs, I might as well not > bother at all. 3) Pre- and Post- flow control. I guess I > shouldn't be surprised the add-ons don't have a > solenoid valve, but I guess I was taking it for granted they > did. > > Jim Ash > > -----Original Message----- > >From: charles loomis <rameses32(at)yahoo.com> > >Sent: Oct 30, 2008 12:23 AM > >To: pietenpol-list(at)matronics.com > >Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: > Learning to weld @ Sport Air workshops > > > > > > >I wouldn't recommend them, they are lift start, > meaning you touch the tungston tip to the metal you are > welding and lift to start the weld, this is bad because it > contaminates the tungston and introduces perosity into the > weld. Also they don't have a built in gas solinoid for > the argon, you turn on the gas, weld, then turn off the gas, > very wateful of the gas, espically if you forget to turn it > off. > > > >I still suggest starting with an Oxy welding setup, > it's cheap and the most versitile tool in your shop. But > if you must have a TIG, try ebay, I got mine for $600 > Australian, it is only DC so I cannot weld Aluminium, but it > is High frequency start with a gas solinoid and 140 amp 100% > duty, and 180 amp 80%. You should be able to get the same > rig in the states for $350 new. > > > >Charley > > > > > >--- On Thu, 10/30/08, Jim Ash > wrote: > > > >> From: Jim Ash <ashcan(at)earthlink.net> > >> Subject: Re: [!! SPAM] Re: Pietenpol-List: Re: > Learning to weld @ Sport Air workshops > >> To: pietenpol-list(at)matronics.com > >> Date: Thursday, October 30, 2008, 10:43 AM > >> > >> > >> While we're kinda on this, has anybody had any > >> experience with any of those kits that will > convert your > >> stick machine to a TIG machine? It sure takes some > of the > >> sting out of the price, and gives me a little more > >> versatility to be able to do either stick or TIG. > >> > >> Jim Ash > >> > >> -----Original Message----- > >> >From: Owen Davies <owen5819(at)comcast.net> > >> >Sent: Oct 29, 2008 2:52 PM > >> >To: pietenpol-list(at)matronics.com > >> >Subject: Re: [!! SPAM] Re: Pietenpol-List: > Re: > >> Learning to weld @ Sport Air workshops > >> > > Davies > >> > >> > > >> >Jim Ash wrote: > >> >> That said, the small Lincoln units are > enticing. > >> Maybe next April. > >> >Yup. Or the Miller or Thermal Arc equivalents. > They > >> both are supposed to > >> >be better than the Lincoln at low amperage; > the Thermal > >> Arc 185TSW in > >> >particular is supposed to be extremely good at > the low > >> end, where we > >> >would be working. Can't verify that from > >> experience, as I keep trying to > >> >gather the will to buy a TIG setup and never > quite get > >> there. > >> > > >> >When the time comes, go to > sci.engr.joining.welding and > >> ask Ernie > >> >Leimkuhler what's best for the purpose. A > better > >> model might come along > >> >by then, and he's likely to know. > >> > > >> >Owen > >> > > >> > > >> > > >> > > >> > > >> > >> > >> http://www.matronics.com/Navigator?Pietenpol-List > > > > > > > > > > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-List ________________________________________________________________________________
Date: Oct 30, 2008
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Rick, Rivet one up... Jack www.textors.com ________________________________________________________________________________
Subject: Re: just plane flyin'
Date: Oct 30, 2008
Oscar, Could you comment please on the flight characteristics of a Piet vs. a typical trike? I figure since your brother has one, you'd be well educated on the differences. Things I'd like to know are: how do they compare flying in turbulence, their load capacity, handling, landing/takeoff distances, glide ratio, etc.. I'm going to buy or build one or the other (a Piet or a trike) and intend to tailor my training around the aircraft itself. Thus, I'm not interested in learing to fly 3-axis planes if I'm going to end up with a weight-shift trike and vice-versa. PM me if you wish. Thanks, Tom -------- Location: Wilson, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211255#211255 ________________________________________________________________________________
Subject: Re: alternative shelter/lower cost
Date: Oct 30, 2008
Thanks for passing this along Walt and Mike. -------- Location: Wilson, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211257#211257 ________________________________________________________________________________
Date: Oct 30, 2008
Jack, I thought of doing that also. Make it out of terne plate, rivet, then solder. If I remember correctly, that is what Bernard did on the early versions. However I do recall some have had trouble with leaks from vibration after only a few hours. Anyone with a terne plate or galvanized tank that they made care to comment? Rick Schreiber ----- Original Message ----- From: Jack T. Textor Sent: 10/30/2008 3:28:19 PM Subject: RE: Pietenpol-List: aileron stuff Rick, Rivet one up Jack www.textors.com ________________________________________________________________________________
Date: Oct 30, 2008
Rick, The original fuel tank on NX18235 was riveted and soldered galvanized steel . A thorough leak check and pressure test when it was new showed it to be l eak free. It started leaking=C2-shortly after=C2-we started flying. After about 4 5 hours of use it was leaking at the rate of approximately 1 gallon / hour. It was pulled and an aluminum tank was made up and taken to a local welder who did his magic with a TIG unit. The new tank has performed flawlessly for over 100 hours. No worries with any kind of fuel. Greg Cardinal ----- Original Message ----- From: "Richard Schreiber" <lmforge(at)earthlink.net> Sent: Thursday, October 30, 2008 3:34:39 PM GMT -06:00 US/Canada Central Subject: RE: Pietenpol-List: aileron stuff Jack, I thought of doing that also. Make it out of terne plate, rivet, then solde r. If I remember correctly, that is what Bernard did on the early versions. However I do recall some have had trouble with leaks from vibration after only a few hours. Anyone with a terne plate or galvanized tank that they ma de care to comment? Rick Schreiber ----- Original Message ----- From: Jack T. Textor Sent: 10/30/2008 3:28:19 PM Subject: RE: Pietenpol-List: aileron stuff Rick, Rivet one up=EF=BD Jack www.textors.com ====== ======================= == ________________________________________________________________________________
Date: Oct 30, 2008
Maybe if you could provide a sketch or image it might make things a bit more clear, but I'm going to go ahead and make a couple of assumptions. I am assuming a set-up just like the one shown in Jack Phillips' photo, with the exception that your rod end does not have the swivel connection. It sounds like you are basically asking how much load a 1/4-20 threaded rod can carry in simple tension. A threaded rod is not as strong as a solid rod of the same diameter would be, since there are threads cut (or rolled) into the rod, which leaves a cross-sectional area less than the solid rod. Experiments have been done to determine the effective diameter of threaded fasteners - this is the diameter of a solid rod that would be approximately equal to the threaded rod. This effective diameter is used to calculate the effective cross-sectional area of the threaded rod, and is referred to as the Tensile Stress Area, which is the number used to calculate the maximum load that can be carried by a threaded fastener. A 1/4-20 thread has a Tensile Stress Area of 0.0318 square inches, whereas a solid rod 1/4" in diameter would have an area of 0.049 square inches. We will use 0.0318 for our calculations. Using the only data we have been supplied with (Tensile Strength - no indication whether this is Ultimate (breaking) or Yield (deforming)), we can easily compute the maximum loading for each material. Maximum Load = Tensile Strength x Tensile Stress Area For the Steel rod: Max Load = 75,000 x 0.0318 = 2385 lb. For the Aluminum rod: Max Load = 45,000 x 0.0318 = 1431 lb. If we recall Jack's explanation of the loads carried by the lift struts of the Pietenpol in flight, we remember that we are looking for a load carrying capacity of about 4000 lb. Based on these numbers we see that with the Aluminum rod ends, your lift struts would likely fail at less than 2 G's of loading (a sharp banked turn or a bit of turbulence). With the Steel rod ends the lift struts will fail at about 3 G's. If I've interpreted your question correctly, I would say neither of the two are a good choice. The 1/4-20 size is not big enough. If we do the calculation the normal way - (that is, we are given the loading and the material strength, and from that we determine the fastener size) we see the following: for the Steel rod: minimum Tensile Stress Area required = 4000 lb/75,000 psi = 0.053 sq in from charts (or calculations using formulae) we see that 5/16-18 thread has Tensile Stress area of 0.0524 and 5/16-24 thread has a value of 0.058 . Either of these should do the job - move up one size to 5/16". for the Aluminum rod: minimum Tensile Stress Area required = 4000 lb/45,000 psi = 0.089 sq in from charts we see that 3/8-24 thread has Tensile Stress area of 0.088 (close enough) and 7/16-14 thread has a value of 0.093 while 7/16-20 thread has a value of 0.119 . You will need to substantially increase the rod size to use aluminum rods. Of course, this may all be an oversimplification. As is often the case, the perceived weight savings by using aluminum becomes much smaller when the sizes need to be increased to account for the reduced strength. I can't imagine there is a real significant weight savings to be had by using aluminum rather than steel in this application. Personally, I don't care for aluminum fasteners (except maybe rivets). I would go for the 5/16-24 size - which just happens to be the size that Jack said he used on his struts. Hope I'm not way off track here. Bill C. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, October 29, 2008 7:50 PM Subject: RE: Pietenpol-List: Adequate rod ends Understood. My delema is this: I can get steel ends or aluminum ends, both solid and both about the same size...1/4" hole, 1/4-20 threads, 1-1/2" long threaded shaft, etc. The steel ends are cheaper, but I am sure they weigh more. They are rated at 75,000 PSI tensil, the aluminum is rated at 45,000. How do I figure if the 45,000 is enough? ________________________________________________________________________________
Date: Oct 30, 2008
Jeff, This is kind of a difficult question to answer. There are a lot of unknowns here: What is the diameter of the strut end? What material is the strut end made of? How long is the strut end in it's fully retracted position, and how long in it's fully extended position? For the most part, when in flight, lift struts are loaded in tension. They can go into compression when experiencing turbulence, or a rough landing. And of course, they are loaded in compression when the plane is at rest, but that loading is pretty minimal (just the static weight of the wings). If the rod end is loaded in simple tension, it doesn't really matter how much is unscrewed (as long as the threads are fully engaged). The only condition that I can think of where it would make a difference how much the threaded portion is unscrewed would be if the rod end was subjected to bending loads (sideways). Then you get an increased bending moment - but I'm not sure how that would occur, and if it did, how much loading it would be. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Sent: Thursday, October 30, 2008 12:04 PM Subject: RE: Pietenpol-List: Adequate rod ends Guys, Thanks for all of the responses. I see that I have done a poor job of explaining my question. I have attached a modification of Clif's drawing that shows my concern: As the rod end is unscrewed from the threaded portion of the strut, the rod shaft takes on "strut" function and experiences all the loads that the strut does, including side loads. How far out can the rod be unscrewed before it weakens the overall function of the strut assembly? Thanks again for all the replies, Jeff ________________________________________________________________________________
Date: Oct 30, 2008
Rick, I played hell trying to find terne plate. And I live in a place of old industry. Some of the old distributors had old rolls of the stuff in the rafters, but it was too thin. But by advise from my building Mentor, don't use galvanized. He said it seems to handle right, but later on it cracks. I finally ended up with aluminum. Cut out all the shapes and held them together by drilling tiny holes about 1/8" from the edge at places about 4" apart along the seam. Looped a piece of thin wire thru and twisted. Then I tacked every few inches along the whole tank, and removed the wire twists. Then finished TIG welding. Of course when I tested the tank for leaks, it was like a watering can sprinkler. (I had never TIG'ed before) So I took it to my friend Don (here http://www.youtube.com/watch?v=FeyWuY2Gmpg in the front seat of my Piet) And being the great welder that he is,,,re TIG'ed all the seams to create 2 flawless tanks. walt evans NX140DL ----- Original Message ----- From: Richard Schreiber To: pietenpol-list(at)matronics.com Sent: Thursday, October 30, 2008 4:34 PM Subject: RE: Pietenpol-List: aileron stuff Jack, I thought of doing that also. Make it out of terne plate, rivet, then solder. If I remember correctly, that is what Bernard did on the early versions. However I do recall some have had trouble with leaks from vibration after only a few hours. Anyone with a terne plate or galvanized tank that they made care to comment? Rick Schreiber ----- Original Message ----- From: Jack T. Textor To: pietenpol-list(at)matronics.com Sent: 10/30/2008 3:28:19 PM Subject: RE: Pietenpol-List: aileron stuff Rick, Rivet one up. Jack www.textors.com ________________________________________________________________________________
Date: Oct 30, 2008
Rick, On my RV8 I used ProSeal at all the joints and rivets, never had a problem. I think Van's sells an improved product today. Jack www.textors.com ________________________________________________________________________________
Date: Oct 30, 2008
Rick, My tank is a Cub tank built by a guy in Cheboygan, Mich. He charged me $140. He has the patterns to make more. If you want I'll ask him if he wants to make anymore. My tank is mounted behind the firewall and holds ~12.6 gallons. Jim Lagowski, in N.W. Mich ----- Original Message ----- From: Richard Schreiber To: pietenpol-list(at)matronics.com Sent: Thursday, October 30, 2008 4:03 PM Subject: Re: Pietenpol-List: aileron stuff Thanks John. I'd like to work on my tank next but I'm trying to decide what to make it out of. I was going to go with aluminium.We have a local welder who does racing tanks. His prices were reasonable, but the last Piet tank he did was around $500 just for labor! I would like to go with glass, but since I will also burn auto fuel I am concerned about solvent resistance. When I get time I'll go through all of the posts to the web site and make a decision, unless someone would like to chime in now. Rick ----- Original Message ----- From: To: pietenpol-list(at)matronics.com Sent: 10/30/2008 2:28:16 PM Subject: Re: Pietenpol-List: aileron stuff Rick, The wings look a bit different from when I saw them, really nice. John In a message dated 10/30/2008 2:54:22 P.M. Eastern Daylight Time, lmforge(at)earthlink.net writes: Well guys here is a status report on my project. Per Dan Helsper's request I attached some photos of my wing with the aileron attached. I have also included a photo of drilling the aileron horn attachment. I used the hardwood block and tube method to insure the holes were aligned properly and perpendicular. This idea came from Chris Tracy on his web site. It worked well. This is the same method I used to drill all of the holes for the aileron hinge attachment screws. On the wings I still need to put in the nut plates for the aileron hinges, mount the aileron pulley supports and then run the cable. The fuselage is pretty well done, including all of the controls and cables I have mounted the main instruments in the IP, but still need to do some more like the engine gages, throttle, carb heat etc.. I am going to put the fuel tank in the front and that still needs to be made. The wing center section is complete. My empennage is complete and has been fitted to the fuselage with the guy wires for a test fit. Next on the agenda is the tail wheel and the straight axle main gear. I'd like to have my Piet done for the 80th in Oshkosh, but realistically that might be a stretch, depending on how much I get done this winter. I am also going to use a corvair engine. I have the core, but I still need to rebuild it. Around Valparaiso (VPZ) we have 4 Piet's in various stages on construction. All of them will be using Corvair power. The plan is to rebuild all of the engines at the same time in the same location with the assistance of our local EAA tech counselor. The great thing is the tech counselor is rebuilding a Piet and also doing a corvair conversion. He is also the person who did the restoration of the Allison engines for the Glacier Girl P-38 a few years ago. Rick Schreiber lmforge(at)earthlink.net ------------------------------------------------------------------------- --- ------------------------------------------------------------------------- --- Checked by AVG - http://www.avg.com 10/30/2008 7:59 AM ________________________________________________________________________________
Date: Oct 30, 2008
Thanks Jim, that would be great! Do you have any dimensions and photos that you could share? Walt and Greg I thought you were the ones that had problems with the riveted and soldered tanks, which is why I did not want to go that route. When I checked if there was anyone locally that could weld up an aluminum that I fabricated, I was given the name of the guy that wants $500. Rick Schreiber ----- Original Message ----- From: Lagowski Morrow Sent: 10/30/2008 8:05:03 PM Subject: Re: Pietenpol-List: aileron stuff Rick, My tank is a Cub tank built by a guy in Cheboygan, Mich. He charged me $140. He has the patterns to make more. If you want I'll ask him if he wants to make anymore. My tank is mounted behind the firewall and holds ~12.6 gallons. Jim Lagowski, in N.W. Mich ----- Original Message ----- From: Richard Schreiber Sent: Thursday, October 30, 2008 4:03 PM Subject: Re: Pietenpol-List: aileron stuff Thanks John. I'd like to work on my tank next but I'm trying to decide what to make it out of. I was going to go with aluminium.We have a local welder who does racing tanks. His prices were reasonable, but the last Piet tank he did was around $500 just for labor! I would like to go with glass, but since I will also burn auto fuel I am concerned about solvent resistance. When I get time I'll go through all of the posts to the web site and make a decision, unless someone would like to chime in now. Rick ----- Original Message ----- From: Sent: 10/30/2008 2:28:16 PM Subject: Re: Pietenpol-List: aileron stuff Rick, The wings look a bit different from when I saw them, really nice. John In a message dated 10/30/2008 2:54:22 P.M. Eastern Daylight Time, lmforge(at)earthlink.net writes: Well guys here is a status report on my project. Per Dan Helsper's request I attached some photos of my wing with the aileron attached. I have also included a photo of drilling the aileron horn attachment. I used the hardwood block and tube method to insure the holes were aligned properly and perpendicular. This idea came from Chris Tracy on his web site. It worked well. This is the same method I used to drill all of the holes for the aileron hinge attachment screws. On the wings I still need to put in the nut plates for the aileron hinges, mount the aileron pulley supports and then run the cable. The fuselage is pretty well done, including all of the controls and cables I have mounted the main instruments in the IP, but still need to do some more like the engine gages, throttle, carb heat etc.. I am going to put the fuel tank in the front and that still needs to be made. The wing center section is complete. My empennage is complete and has been fitted to the fuselage with the guy wires for a test fit. Next on the agenda is the tail wheel and the straight axle main gear. I'd like to have my Piet done for the 80th in Oshkosh, but realistically that might be a stretch, depending on how much I get done this winter. I am also going to use a corvair engine. I have the core, but I still need to rebuild it. Around Valparaiso (VPZ) we have 4 Piet's in various stages on construction. All of them will be using Corvair power. The plan is to rebuild all of the engines at the same time in the same location with the assistance of our local EAA tech counselor. The great thing is the tech counselor is rebuilding a Piet and also doing a corvair conversion. He is also the person who did the restoration of the Allison engines for the Glacier Girl P-38 a few years ago. Rick Schreiber lmforge(at)earthlink.net href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c AVG - 270.8.5/1756 - Release Date: 10/30/2008 7:59 AM ________________________________________________________________________________
Subject: Weight and Balance
Date: Oct 30, 2008
Greetings! Anyone have an excel spreadsheet for weight and balance calculations for a Model A powered Aircamper. Fuselage length firewall to tailwheel is 161.5 inches. You can contact my email... dwilson(at)ci.austin.mn.us Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211320#211320 ________________________________________________________________________________
Date: Oct 30, 2008
Bill, Yes, the bending loads are what I am talking about. As to how that would occur, my assumption is that it would occur just like it does for the rest of the strut. For instance, it's often been said that jury struts are needed to keep the main struts from "collapsing" or phrases to that effect. I've always assumed that such a "collapse" is due to bending, or side, loads. If this is the case for struts, then it must be the case for the shaft of the rod end, since it's simply part of the strut, only skinnier and with all those stress risers (a.k.a, "threads"). When the rod is screwed in all the way, it's shaft is not acting as a length of strut. As it is unscrewed, the shaft is exposed to more and more bending loads the more its length is exposed. I agree that the dimensions you list are needed to make a determination. One time-honored shortcut, though, is to assume that if the part is from a certified airplane (for example, a Cub strut/rod end assembly), then there may already be data out there that will answer this question. That's why in my earlier, and poorly written, post, I asked if anyone knew how far out a Cub rod end could be unscrewed. Maybe Piper determined that 1 inch is OK and 2 inches is not. Of course, even THAT shortcut only works if the Piper and Pietenpol geometries (including jury strut locale, overall lift strut length, etc.) are similar. Thanks again - sorry to take up some much bandwidth on this. Jeff >Jeff, > >This is kind of a difficult question to answer. There are a lot of >unknowns here: >What is the diameter of the strut end? >What material is the strut end made of? >How long is the strut end in it's fully retracted position, and how >long in it's fully extended position? > >For the most part, when in flight, lift struts are loaded in >tension. They can go into compression when experiencing turbulence, >or a rough landing. And of course, they are loaded in compression >when the plane is at rest, but that loading is pretty minimal (just >the static weight of the wings). > >If the rod end is loaded in simple tension, it doesn't really matter >how much is unscrewed (as long as the threads are fully engaged). >The only condition that I can think of where it would make a >difference how much the threaded portion is unscrewed would be if >the rod end was subjected to bending loads (sideways). Then you get >an increased bending moment - but I'm not sure how that would occur, >and if it did, how much loading it would be. > >Bill C. > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] >On Behalf Of Jeff Boatright > >Sent: Thursday, October 30, 2008 12:04 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Adequate rod ends > >Guys, > >Thanks for all of the responses. I see that I have done a poor job >of explaining my question. I have attached a modification of Clif's >drawing that shows my concern: As the rod end is unscrewed from the >threaded portion of the strut, the rod shaft takes on "strut" > >function and experiences all the loads that the strut does, >including side loads. How far out can the rod be unscrewed before it >weakens the overall function of the strut assembly? > >Thanks again for all the replies, > >Jeff > ________________________________________________________________________________
Date: Oct 30, 2008
Subject: Re: Weight and Balance
Dan, Here is a link to the conversation thread where Walt Evans uploaded his Excel W&B spreadsheets. I think it's around 6 messages down: http://forums.matronics.com/viewtopic.php?t=18847&highlight=weight+balance+spreadsheet He had four different versions for various passenger/fuel configurations. Walt's Piet is not Model A powered, but it is at least a starting point for a spreadsheet for yours. I would think that even if there is a Model A specific spreadsheet out there (I haven't found it yet), if you were to use it with no changes you are relying on the fact that the fuel tank, radiator, and other weight stations are the same distance from the datum on their Piet as on yours. Should they be....probably...but I would still want to measure mine. Anywho, I would think Walt's spreadsheet(s) could work for you. You would have to set your own datum, determine the measurements to the stations for the moments you need to calculate, and replace his figures with yours. I hope that helps a bit with what you're looking for. Ryan On Thu, Oct 30, 2008 at 9:57 PM, dwilson wrote: > > Greetings! Anyone have an excel spreadsheet for weight and balance > calculations for a Model A powered Aircamper. Fuselage length firewall to > tailwheel is 161.5 inches. You can contact my email... > dwilson(at)ci.austin.mn.us > > ________________________________________________________________________________
Date: Oct 30, 2008
Jeff, I could be wrong on this, but I believe the "collapsing" that the jury struts eliminate results from negative g-loading that places the struts in compression. Let's say the Piet is flying through smooth air. The wing is making lift, and thusly "lifting" the fuselage. The struts would then be in tension. If you fly through a downdraft and experience negative g's those struts would now be in compression, and that would be where they are susceptible to failure. Here is a link to a short article about model airplanes: http://www.fly-imaa.org/imaa/hfarticles/const/v2-4-69.html I know that they are not the same as a real airplane, but it does simply explain the idea. As far as the loads on the strut being the same as the loads on the rod end fitting....well, they may be transmitted the same but the piece probably would not react the same. One is a hollow steel/aluminum tube, the other is a solid metal fitting. Finally...I posit a situation. The service manual for a J-3 provides rigging instructions (according to the table of contents). But they may not provide such specific data as how far out the fork can be unscrewed. They know exactly how long the strut/fork combination is, because they manufacture it. They specify a standard set of instructions for rigging the airplane, and if things need to be adjusted they are relatively minute adjustments. They don't need to worry about thread engagement on the fork end, because they are dealing with very small adjustments. Thusly, even if engineering calculated the minimum thread engagement that may never have made it into the maintenance manuals, as there was no reason for that to have ever come into play when rigging a Cub (unless it has some serious issues). Maybe that would be the case, I don't know. Just throwing that out there. As you said, even if you could find the data it's for an entirely different airplane, and you probably shouldn't use that standard without some solid analysis. Personally I would think one of the preferable things to do in the situation of a Piet is to look at what others have successfully flown, preferably for many hours, and choose which of those to emulate. Determine how long you want your struts to be, and build them so that they have maximum thread engagement. Ryan On Thu, Oct 30, 2008 at 10:22 PM, Jeff Boatright wrote: > Bill, > > Yes, the bending loads are what I am talking about. As to how that would > occur, my assumption is that it would occur just like it does for the rest > of the strut. For instance, it's often been said that jury struts are needed > to keep the main struts from "collapsing" or phrases to that effect. I've > always assumed that such a "collapse" is due to bending, or side, loads. If > this is the case for struts, then it must be the case for the shaft of the > rod end, since it's simply part of the strut, only skinnier and with all > those stress risers (a.k.a, "threads"). When the rod is screwed in all the > way, it's shaft is not acting as a length of strut. As it is unscrewed, the > shaft is exposed to more and more bending loads the more its length is > exposed. > > I agree that the dimensions you list are needed to make a determination. > One time-honored shortcut, though, is to assume that if the part is from a > certified airplane (for example, a Cub strut/rod end assembly), then there > may already be data out there that will answer this question. That's why in > my earlier, and poorly written, post, I asked if anyone knew how far out a > Cub rod end could be unscrewed. Maybe Piper determined that 1 inch is OK and > 2 inches is not. Of course, even THAT shortcut only works if the Piper and > Pietenpol geometries (including jury strut locale, overall lift strut > length, etc.) are similar. > > Thanks again - sorry to take up some much bandwidth on this. > > Jeff > ________________________________________________________________________________
Date: Oct 31, 2008
Here's some generic ones that I used. Just fill in the blanks, and delete the blanks that don't pertain. have fun walt evans NX140DL ----- Original Message ----- From: "dwilson" <marwilson(at)charter.net> Sent: Thursday, October 30, 2008 10:57 PM Subject: Pietenpol-List: Weight and Balance > > Greetings! Anyone have an excel spreadsheet for weight and balance > calculations for a Model A powered Aircamper. Fuselage length firewall to > tailwheel is 161.5 inches. You can contact my email... > dwilson(at)ci.austin.mn.us > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=211320#211320 > > > ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Adequate rod ends
Bill, you sir, are right on! That is what-I was looking for. Thank you fo r taking the time and effort to do that for me. (and the list) - I am not a big fan of aluminum fasteners as well, usually. However, they do have there place. Wing struts are not one of them. I may use aluminum on t he center struts, but that is yet to be determined. The aluminum solid ends I have been looking at cost more then their steel twins.- For each strut , I will more then likely use one threaded, solid rod end for each. So, for the center section, I would only need to buy 4. Not sure it is worth the a dded cost to buy 4 aluminum fittings...I doubt the weight savings would be much. But, then again it ALL adds up over the entire project. Like I said, TBD on the center section. You have convinced me on steel for the wing stru ts. Thanks again. --- ________________________________________________________________________________
Date: Oct 31, 2008
Subject: Re: Adequate rod ends
Ryan, Thanks for the reply and link. You are describing in part what I'm thinking. The negative g-loading causes compression of the strut. The strut then bows, and like a straw, can eventually snap. Once the bowing starts, loads are no longer 100% in parallel with the former line of the unbowed strut. In a sense, some of the load is now from the side, a bending load. If the rod end shaft is part of the strut diagonal, it will also be subjected to those loads. All of this pondering on my part is because the plane is already built and I'd like to add more dihedral. The easiest thing to do is to back the rod ends out to lengthen the distance between wing as fuselage strut attach points. But easy doesn't mean safe. Like anything on a plane, changing what has proven to be safe into some other configuration demands much consideration. Thanks all for your thoughts, Jeff >Jeff, > >I could be wrong on this, but I believe the "collapsing" that the >jury struts eliminate results from negative g-loading that places >the struts in compression. Let's say the Piet is flying through >smooth air. The wing is making lift, and thusly "lifting" the >fuselage. The struts would then be in tension. If you fly through a >downdraft and experience negative g's those struts would now be in >compression, and that would be where they are susceptible to >failure. Here is a link to a short article about model airplanes: > ><http://www.fly-imaa.org/imaa/hfarticles/const/v2-4-69.html>http://www.fly-imaa.org/imaa/hfarticles/const/v2-4-69.html > >I know that they are not the same as a real airplane, but it does >simply explain the idea. > >As far as the loads on the strut being the same as the loads on the >rod end fitting....well, they may be transmitted the same but the >piece probably would not react the same. One is a hollow >steel/aluminum tube, the other is a solid metal fitting. > >Finally...I posit a situation. The service manual for a J-3 provides >rigging instructions (according to the table of contents). But they >may not provide such specific data as how far out the fork can be >unscrewed. They know exactly how long the strut/fork combination is, >because they manufacture it. They specify a standard set of >instructions for rigging the airplane, and if things need to be >adjusted they are relatively minute adjustments. They don't need to >worry about thread engagement on the fork end, because they are >dealing with very small adjustments. Thusly, even if engineering >calculated the minimum thread engagement that may never have made it >into the maintenance manuals, as there was no reason for that to >have ever come into play when rigging a Cub (unless it has some >serious issues). > >Maybe that would be the case, I don't know. Just throwing that out >there. As you said, even if you could find the data it's for an >entirely different airplane, and you probably shouldn't use that >standard without some solid analysis. Personally I would think one >of the preferable things to do in the situation of a Piet is to look >at what others have successfully flown, preferably for many hours, >and choose which of those to emulate. Determine how long you want >your struts to be, and build them so that they have maximum thread >engagement. > >Ryan ________________________________________________________________________________
Date: Oct 31, 2008
Jeff, I think I understand the question now. You are concerned about buckling. In compression, the strut assembly will act like a column. The longer an unsupported column is, the more prone to buckling it becomes. If the compression forces on the ends of a column are large enough (based on the specific geometry and physical characteristics of the column), once the column starts to buckle, it can suffer a catastrophic collapse. This type of failure can be avoided by a couple of methods. One is to change the structure of the column (larger profile, thicker wall thickness, different materials, etc), and the other method is to provide some intermediate support(s) to effectively shorten the unsupported length of the column. The second of these methods is recommended for the Pietenpol. This is achieved by the addition of jury struts. The lift struts on the Air Camper are about eight feet long, but with the addition of jury struts, the unsupported length becomes roughly half of that. Since the relationship between buckling force and column length is an inverse square, reducing the length by half means that the forces required to buckle the new shorter length increase by a factor of four (likewise, if the length of a column is doubled, the force required to buckle the longer column is only one fourth). The jury struts do very little in ideal flight conditions - straight, level flight, in calm air, followed by a perfect, soft-as-a-feather landing on a smooth-as-glass runway. The only possible problem under these conditions would be if the airflow over the lift struts were to cause the struts to flutter, or vibrate. The addition of the jury struts will help to alleviate this situation. In this instance, the jury struts should be attached at a point that is NOT the midpoint of the strut length, as attachment at the midpoint can allow harmonic vibration to occur, and multiply. Unfortunately, most of us have to live in the real world (except for one weekend in July each year, at a small airport in southern Wisconsin). That real world includes turbulent air, and occasional hard landings and rough runways (or fields) among other things. These conditions all have the power to impart negative G forces on the plane and its occupants. When the Air Camper is put into negative G conditions, the wings (especially the 3-piece wing) will tend to pivot downward, putting the lift struts into compression, rather than tension. When the lift struts are in compression, they begin to act like the columns mentioned above. Unsupported, the lift struts might collapse when subjected to these negative G forces. The consequences are nasty if it happens on the ground, but likely fatal if occuring in flight. So, jury struts are a good thing to have on an Air Camper. Now, with respect to your question, as I mentioned, the calculations to determine the "side loads" the strut ends might encounter are difficult to determine. But, just out of curiosity, I did a few calculations to try to determine how much longer your lift struts might need to be extended, in order to give the wing the dihedral you are desiring. I randomly chose a dimension of 2" for the dihedral (seems about right). Since the lift struts are attached at roughly half way between the fuselage and the wingtip, and the struts are angled at approximately 30 degrees, the resulting lift strut will only need to be extended by approximately 1/2". I'm not sure, but I think that Cub lift strut ends are 7/16" (correct me if that's not right). The forces required to bend a 7/16" diameter bolt would be huge. I would think that your strut attachment brackets would get ripped out of the plane before the strut ends would fail (the old "weakest link in the chain", once again). The short answer is that I don't think that extending your strut ends an extra 1/2" is going to put you at risk (provided the threaded rod is long enough to keep the threads properly engaged). Anybody have a differing view on this matter? Bill C. ________________________________________________________________________________
Date: Oct 31, 2008
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Well Explained! - Ken Heide - --- On Fri, 10/31/08, Bill Church wrote: From: Bill Church <eng(at)canadianrogers.com> Subject: RE: Pietenpol-List: Adequate rod ends Date: Friday, October 31, 2008, 12:38 PM #yiv179383659 BLOCKQUOTE { PADDING-BOTTOM:0px;PADDING-TOP:0px;} #yiv179383659 DL { PADDING-BOTTOM:0px;PADDING-TOP:0px;} #yiv179383659 UL { PADDING-BOTTOM:0px;PADDING-TOP:0px;} #yiv179383659 OL { PADDING-BOTTOM:0px;PADDING-TOP:0px;} #yiv179383659 LI { PADDING-BOTTOM:0px;PADDING-TOP:0px;} Jeff, - I think I understand the question now. You are concerned about buckling. In compression, the strut assembly will act like a column. The longer an un supported-column is, the more prone to buckling it becomes. If the compre ssion forces on the ends of a column are large enough (based on the specifi c geometry and physical characteristics of the column), once the column sta rts to buckle, it-can suffer a catastrophic collapse. This type of failur e can be avoided by a couple of methods. One is to change the structure of the column (larger profile, thicker wall thickness, different materials, et c), and the other method is to provide some intermediate support(s) to effe ctively shorten the unsupported length of the column. The second of these m ethods is recommended for the Pietenpol. This is achieved by the addition o f jury struts. The lift struts on the Air Camper are about eight feet long, but with the addition of jury struts, the unsupported length becomes rough ly half of that. Since the relationship between buckling force and column length is an inverse square, reducing the length by half means that the forces required to buckle the new shorter length increase by a factor of four (likewise, if the length of a column is doubled, the force required to buckle the longer column is only one fourth).- The jury struts do ver y little in-ideal flight conditions - straight, level flight, in calm air , followed by a perfect, soft-as-a-feather landing on a smooth-as-glass run way. The only possible problem under these conditions would be if the airfl ow over the lift struts were to cause the struts to flutter, or vibrate. Th e addition of the jury struts will help to alleviate this situation. In thi s instance, the jury struts should be attached at a point that is NOT the m idpoint of the strut length, as attachment at the midpoint can allow harmon ic vibration to occur, and multiply. Unfortunately, most of us have to live in the real world (except for one weekend in July each year, at a small airport in southern Wisconsin). That real world includes turbulent a ir, and occasional hard landings and rough runways (or fields) among other things. These conditions all-have the power to impart negative G forces o n the plane and its occupants. When the Air Camper is put into negative G c onditions, the wings (especially the 3-piece wing) will tend to pivot downw ard, putting the lift struts into compression, rather than tension. When th e lift struts are in-compression, they begin to act like the columns ment ioned above.-Unsupported, the lift struts might collapse when subjected t o these negative G forces. The consequences are nasty if it happens on the ground, but likely fatal if occuring in flight. So, jury struts are a good thing to have on an Air Camper. - Now, with respect to your question, as I mentioned, the calculations to det ermine the "side loads" the strut ends might encounter are difficult to det ermine. But, just out of curiosity, I did a few calculations to try to dete rmine how much longer your lift struts might need to be extended, in order to give the wing the dihedral you are desiring. I randomly chose a dimensio n of 2" for the dihedral (seems about right). Since the lift struts are att ached at roughly-half way between the fuselage and the wingtip, and the s truts are angled at approximately 30 degrees, the resulting lift strut will only need to be extended by approximately 1/2". I'm not sure, but I think that Cub lift strut ends are 7/16" (correct me if that's not right). The fo rces required to bend a 7/16" diameter bolt would be huge. I would think th at your strut attachment brackets would get ripped out of the plane before the strut ends would fail (the old "weakest link in the chain", once again). - The short answer is that I don't think that extending your strut ends an ex tra 1/2" is going to put you at risk (provided the threaded rod is long eno ugh to keep-the threads-properly engaged). - Anybody have a differing view on this matter? - Bill C.- - =0A=0A=0A ________________________________________________________________________________
Subject: Streamlining Struts
Date: Oct 31, 2008
The recent discussion regarding the various methods possible to streamline round struts caused me to remember an article that was published in an issue of To Fly, the magazine that was published by the now defunct Sport Aviation Association that was founded by Paul Poberezny (in an effort to return to the original ideals of the EAA). As the magazine is now out of print, and since the following article used to be available on the SAA website, I figure it would be okay to scan a copy and share it with the List. >From the data presented, one can easily see how beneficial it is to use streamline tube or, if round tube is used, to streamline that round tube. Bill C. ________________________________________________________________________________
Date: Oct 31, 2008
Bill C, Great synopsis of the issues and a very useful analysis of the real-world scenario. Thanks so much, I'll stand you a beer at B'head. Jeff ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's through soley through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), List Browse ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisments. During the month of November I will be sending out List messages every few days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts. Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/). These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: https://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years. I know it sounds a little cliche, but you guys really do feel like family. Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Re:Adequate rod ends
I know that this topic has been beat to death but after all the exotic expl anations and stress analysis, it might be wise to consider what else could be impacted by "merely" unscrewing the rod-ends? - The Piet in question is already built and for some reason the owner (builde r?) wants to add some dihedral, so: - Assuming a one-piece wing, what kind of a load will this cause on the caban e strut fittings? - Assuming a three piece wing, what loads will be imposed on the butt-ends of the spars that will translate directly to the wing-attach fittings? - Jacking up the struts really does have consequences other than putting a li ttle dihedral into the tips. I suspect that the loads to the center section fittings would be a much bigger factor to consider than any cosmetic enhan cement dihedral might add. - Just musing........ - Larry Williams- XCG,XCMR,EPP=0A=0A=0A ________________________________________________________________________________
Date: Nov 01, 2008
Larry, Thanks for the note. Sorry that some information went missing. It's a 3-piece wing; I'm not the builder; not looking for cosmetic enhancement, but possibly more stability. Why would dihedral add load to the center section attach pointsor the wing-attach fittings? Thanks, Jeff >I know that this topic has been beat to death but after all the >exotic explanations and stress analysis, it might be wise to >consider what else could be impacted by "merely" unscrewing the >rod-ends? > >The Piet in question is already built and for some reason the owner >(builder?) wants to add some dihedral, so: > >Assuming a one-piece wing, what kind of a load will this cause on >the cabane strut fittings? > >Assuming a three piece wing, what loads will be imposed on the >butt-ends of the spars that will translate directly to the >wing-attach fittings? > >Jacking up the struts really does have consequences other than >putting a little dihedral into the tips. I suspect that the loads to >the center section fittings would be a much bigger factor to >consider than any cosmetic enhancement dihedral might add. > >Just musing........ > >Larry Williams XCG,XCMR,EPP > ________________________________________________________________________________
Subject: Re: Progress Report
Date: Nov 01, 2008
Guys: Just finished this week splicing and routing my spars (for one piece wing). It was much easier than I expected, but I filled a large shop-vac twice with the sawdust. Now it is getting too cold to be glueing, so I may have to slide the ribs on and make all of the pieces to have ready for when it warms up, or maybe a few warm days left this year? Gene trying my best to make Brodhead/Oshkosh next year ________________________________________________________________________________
Date: Nov 01, 2008
A question I asked Bill Rewey led to answer related to that. Until Larry brought it up I had forgotten about it. On the drawing for his three piece wing, he shows a roughly 1" gap between the center section and wing panels. There are offsets bent in the wing attach fittings, to allow them to mate with the opposite fittings. I believe he also did not extend the spars at all beyond the butt ribs. Anyhow, he pointed out that having the one inch gap between the wing panels and center section (and thusly the ends of the spars of each) prevents the tops of the spars from contacting each other if you add dihedral. With the three piece wing drawing that comes with the Piet plans, I believe there is zero clearance between the ends of the spars of the panel and center section (I'm not at home, so I'm going from memory). According to what the drawing shows it would appear that if you add dihedral the tops of the spar would already be touching, and thusly it would attempt to pull the bottom of the spars apart. This would put additional stress on the wing attach fittings and wing attach bolts. At least that's how it appears. Maybe those who have built the three-piece and added dihedral can add their experience. But if your Piet has the three-piece wings built to the plans with zero clearance between the wing and center section spars, the stress on the fittings and bolts might be something to take into account. Ryan On Sat, Nov 1, 2008 at 9:08 AM, Jeff Boatright wrote: > > > Why would dihedral add load to the center section attach pointsor the > wing-attach fittings? > > Thanks, > > Jeff ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Contribution Site URL Clarification
Dear Listers, In my List Fund Raiser kickoff email last night, I mistyped the URL for the *initial* Contribution web site and couple of people reported receiving SSL certificate errors. The actual payment entry pages where were correct, however, so there were no certificate issues that impacted payment data. I'm sorry for the confusion. Please use the following URL to start your List Contribution: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 01, 2008
Subject: see web page below last try failed to go through
http://www.kontraband.com/videos/14339/The-Best-Air-Race-Pilot-EVER/ I know this has nothing to do with Piets but this is some flying you just have to see. ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Re: see web page below last try failed to go through
http://www.avweb.com/blogs/insider/AVwebInsiderBlog_ViralVideo_KillaThrill_LostWingLanding_199096-1.html It also has nothing to do with actual flying...well, real airplane flying at least. :P On Sat, Nov 1, 2008 at 2:49 PM, H RULE wrote: > http://www.kontraband.com/videos/14339/The-Best-Air-Race-Pilot-EVER/ > > > I know this has nothing to do with Piets but this is some flying you just > have to see. > ________________________________________________________________________________
Date: Nov 01, 2008
Subject: Re: Progress Report, keep going
Gene, what kind of glue??- If it's T-88 keep on building.- Dad built hi s in the winter in an unheated garage.- Just as long as you have a little electric heater with a fan on it.- Put a piece of 2 mil dropcloth plasti c over the wing as to cover it with 2ft or so extra around the edges.- Ta pe or lay a board pipe etc. to hold the sides down, and leave the ends open .- Put the heater with the fan on it at one end and inflate the plastic l ike a greenhouse, it will stay at least 70 degrees all night long.- Keep the glue inside and mix it, then go out glue the pieces on and put up the t ent.- I used the same process last winter building wings for my Jungster, worked like a charm, I left the heat tent on for 48 hrs to make sure the g lue cured, and the temp outside was well below 20 degrees. - Shad=0A=0A=0A ________________________________________________________________________________
Subject: Fuse Question
Date: Nov 02, 2008
Hi All I have finally started building again I have the fuse layed out on the bench. My question,at the front the bottom longeron seems to have a lot of stress from the firewall to the first brace the firewall brace measurement from the top longerron to the bottom is 21 7/8 and at the first brace it is 22 3/4 which is 7/8 over 12 inches. My worry is will it pop when I pull it out of the jig, has anyone had this problem or done it differently OR am I worrying for no reason. I hope I have explained this clearly. Thanks Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211725#211725 ________________________________________________________________________________
Date: Nov 02, 2008
Apparently I have just found out from another pilot friend of mine that it is a well put together hoax;sorry to bother you guys with this junk. ----- Original Message ---- From: Ryan Mueller <rmueller23(at)gmail.com> Sent: Saturday, November 1, 2008 4:08:48 PM Subject: Re: Pietenpol-List: see web page below last try failed to go through http://www.avweb.com/blogs/insider/AVwebInsiderBlog_ViralVideo_KillaThrill_LostWingLanding_199096-1.html It also has nothing to do with actual flying...well, real airplane flying at least. :P On Sat, Nov 1, 2008 at 2:49 PM, H RULE wrote: http://www.kontraband.com/videos/14339/The-Best-Air-Race-Pilot-EVER/ I know this has nothing to do with Piets but this is some flying you just have to see. ________________________________________________________________________________
Date: Nov 02, 2008
Hi Carson The longeron is on a downward slope at that point so all of the bend is not right at the first upright. It continues downward to 23 3/4 and then starts back up in a tight but gentle curve. To answer your question I had no problem with my spruce longerons making that bend and I've never heard of it being a problem except on the early F/W 1929 model where that curve is tighter. I blocked it up tight in the jig at the firewall and pulled it up into the jig blocks dry. I guess you could soak it or steam it but I don't belive it's needed as long as your wood is within specs. I glued all of the joints and installed the blocking and gussets on the one side and the 1/8" plywood on the other and then let each cure for a couple days before removing each side from the jig. I belive I have seen pictures where builders have just glued in the uprights and diagonals and removed the sides from the jig before adding the gussets but I'm not nearly that optomistic. Good luck, I believe the fuselage was one of the most rewarding parts of the project. Ed G. Almost ready to start covering. >From: "carson" <carsonvella(at)yahoo.com.au> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Fuse Question >Date: Sun, 2 Nov 2008 02:53:45 -0800 > > >Hi All >I have finally started building again I have the fuse layed out on the >bench. >My question,at the front the bottom longeron seems to have a lot of stress >from the firewall to the first brace the firewall brace measurement from >the top longerron to the bottom is 21 7/8 and at the first brace it is 22 >3/4 which is 7/8 over 12 inches. >My worry is will it pop when I pull it out of the jig, has anyone had this >problem or done it differently OR am I worrying for no reason. >I hope I have explained this clearly. >Thanks >Carson > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=211725#211725 > > ________________________________________________________________________________
Date: Nov 02, 2008
Sorry to be jumping in here again but I just remembered something I did which worked great. I left the extra length of my longeron 1x1s extend past the firewall 4 or five inches. Useing wire and a hardware store turnbuckle I cranked in some pressure to pull the lower longeron up into place. I left this in place until after I removed the fuse side from the jig and installed the inside gusset on one side and the outside ply on the other. after that cured I trimmed the longerons to length. Might have been overkill but it eliminates the chances of that joint popping loose when removed from the jig. Ed >From: "Ed G." <flyboy_120(at)hotmail.com> >Reply-To: pietenpol-list(at)matronics.com >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Fuse Question >Date: Sun, 02 Nov 2008 07:31:00 -0500 > > >Hi Carson The longeron is on a downward slope at that point so all of the >bend is not right at the first upright. It continues downward to 23 3/4 and >then starts back up in a tight but gentle curve. To answer your question I >had no problem with my spruce longerons making that bend and I've never >heard of it being a problem except on the early F/W 1929 model where that >curve is tighter. I blocked it up tight in the jig at the firewall and >pulled it up into the jig blocks dry. I guess you could soak it or steam it >but I don't belive it's needed as long as your wood is within specs. I >glued all of the joints and installed the blocking and gussets on the one >side and the 1/8" plywood on the other and then let each cure for a couple >days before removing each side from the jig. I belive I have seen pictures >where builders have just glued in the uprights and diagonals and removed >the sides from the jig before adding the gussets but I'm not nearly that >optomistic. Good luck, I believe the fuselage was one of the most rewarding >parts of the project. Ed G. Almost ready to start covering. > > >>From: "carson" <carsonvella(at)yahoo.com.au> >>Reply-To: pietenpol-list(at)matronics.com >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Fuse Question >>Date: Sun, 2 Nov 2008 02:53:45 -0800 >> >> >>Hi All >>I have finally started building again I have the fuse layed out on the >>bench. >>My question,at the front the bottom longeron seems to have a lot of stress >>from the firewall to the first brace the firewall brace measurement from >>the top longerron to the bottom is 21 7/8 and at the first brace it is 22 >>3/4 which is 7/8 over 12 inches. >>My worry is will it pop when I pull it out of the jig, has anyone had this >>problem or done it differently OR am I worrying for no reason. >>I hope I have explained this clearly. >>Thanks >>Carson >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=211725#211725 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Windshild improvement
Date: Nov 02, 2008
For what it's worth. The Fall weather here in Western Tennessee could not be better. 70's during the day and low 30's at night. Since my favorite time to fly is at sunrise, it does get cool in the cockpit. My windshild was of a normal size for a Piet and it was very windy in the cockpit. I needed to wear goggles while flying as it was windy enough that I feared my glasses would be ripped off if I turned my head to the side. Keep in mind, I'm 6' tall and shorter pilots may not have a wind issue. To make a long story short, I redesigned my windshild plus made it 3" taller. What a difference! It's like riding my Gold Wing. Almost no wind in the cockpit at all. I couldn't believe the difference. If any of you put your planes away for the winter, you might try changing your windshild before you do. You just might get a whole lot more flying done this year. Cool weather flying is the best there is. The Ol' Piet flys like a super cub! Gene ________________________________________________________________________________
Date: Nov 02, 2008
Subject: Re: Fuse Question
As best I remember, I extended both longerons forward 6-8 inches past the firewall. Then I glued/nailed a piece of scrap plywood across the two as a temporary gusset. Be sure you remember you have to make mirror image fuse sides, ie you can't put the forward gussets on both sides while in the jig. All this happened on my project afew years ago, and I'm going from my poor memory, but you could wait and cut off the excess after the fuselage is together and the plywood sides are on. I don't remember what I did, but I didn't have any problems with the lower longeron, and mine was all put together dry with no steaming. As Ed says, the curve is not all that steep and it was no problem getting the lower longeron into the jig. Ben Charvet Tails surfaces covered, awaiting one more final assembly before covering wings and fuse. rson wrote: > > Hi All > I have finally started building again I have the fuse layed out on the bench. > My question,at the front the bottom longeron seems to have a lot of stress from the firewall to the first brace the firewall brace measurement from the top longerron to the bottom is 21 7/8 and at the first brace it is 22 3/4 which is 7/8 over 12 inches. > My worry is will it pop when I pull it out of the jig, has anyone had this problem or done it differently OR am I worrying for no reason. > I hope I have explained this clearly. > Thanks > Carson > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=211725#211725 > > > ________________________________________________________________________________
Date: Nov 02, 2008
Carson, I saw no tendencies for the joints to fail, but I installed diagonals and gussets before removing the 1st side from the jig. Check the archives as Dick Navatril had good ideas for making the rear cockpit a little larger, with more slope to the pilot's seat back. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (endless metal parts!) (12 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of carson Sent: Sunday, November 02, 2008 2:54 AM Subject: Pietenpol-List: Fuse Question Hi All I have finally started building again I have the fuse layed out on the bench. My question,at the front the bottom longeron seems to have a lot of stress from the firewall to the first brace the firewall brace measurement from the top longerron to the bottom is 21 7/8 and at the first brace it is 22 3/4 which is 7/8 over 12 inches. My worry is will it pop when I pull it out of the jig, has anyone had this problem or done it differently OR am I worrying for no reason. I hope I have explained this clearly. Thanks Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211725#211725 ________________________________________________________________________________
Subject: Re: Windshild improvement
Date: Nov 02, 2008
Gene, Do you have any pictures and specs. for the re-design? -------- Location: Wilson, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211749#211749 ________________________________________________________________________________
Date: Nov 02, 2008
So how many inches above the top of your head did the top of your new windshield end up? Rick On Sun, Nov 2, 2008 at 6:13 AM, Gene & Tammy wrote: > For what it's worth. > The Fall weather here in Western Tennessee could not be better. 70's > during the day and low 30's at night. Since my favorite time to fly is at > sunrise, it does get cool in the cockpit. My windshild was of a normal size > for a Piet and it was very windy in the cockpit. I needed to wear goggles > while flying as it was windy enough that I feared my glasses would be ripped > off if I turned my head to the side. Keep in mind, I'm 6' tall and shorter > pilots may not have a wind issue. To make a long story short, I redesigned > my windshild plus made it 3" taller. What a difference! It's like riding > my Gold Wing. Almost no wind in the cockpit at all. I couldn't believe the > difference. If any of you put your planes away for the winter, you might > try changing your windshild before you do. You just might get a whole lot > more flying done this year. Cool weather flying is the best there is. The > Ol' Piet flys like a super cub! > Gene > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Subject: Re: Normalizing thin tube tig welds
Date: Nov 02, 2008
Read this article. Normalizing is not necessary. http://home.hiwaay.net/~langford/sportair/ If normalizing is not done correctly it can be hazardous. -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=211804#211804 ________________________________________________________________________________
Date: Nov 02, 2008
Subject: Model A test run report
Hello good people! Today was a glorious and warm day here in northern Illinois. 8-1/2 years in the trenches so far. I rolled out my Piet from the hangar and tied'er down at the tail. Added about two gallons of gas, and pulled'er through 5 blades after a one-shot prime. Walked back 'round and twisted the mags around to "both". Mosied back around to the front and took a'hold of the prop and after three blades she came to life! What a great feeling!! There is noth'in quite like the sound of an "A" and the breeze through your hair (if you have any left). Ran'er up for quite a while and just took it all in! This is the second day of runn'in her so a bit more relaxed and enjoyable. I'm on "cruise control" now that I know she'll run. After 8 1/2 years its a good feel'in!! Made a windshield this weekend, so cross that off the list. It's gett'in closer to Tuesday!! I will work on cover'in her this winter. Got a reading of 1850 RPM static at full throttle with my home-made prop. I think that is pretty close to where it should be. Good enough to test fly'er with. I attached a "fish scale" type spring scale (300 lb capacity) to the tail and got a reading of 260 lbs @ full throttle. Does anybody know if this is good?? I have no idea, but she was pull'in like a banshee!! Hopefully this report will serve as an encouragement to spur on all the rest that are behind me. Keep-on plodding along!! Each small step is one more toward your end goal............. Can't wait to fly her!! Dan Helsper Poplar Grove, IL. **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Subject: windshild
Date: Nov 02, 2008
To better show the outline of the new windshild (for the photo) I put tape around the edge. If you compare the windshild with the tape to the front windshild without the tape you can see the change I made. I'm sure someone else can come up with a better design but it works for me. The front windshild (old design) was 6" taller than the front of the cockpit and the new windshild is 9.5" above the cockpit. Tonight I'll be making a new windshild for the front. The white vertical lines you can see in the new windshild is where I bent each side about 30 degrees to bend around the cockpit. The front windshild is also bent but you can't see the lines in this photo. Hopes this helps Gene ________________________________________________________________________________
Subject: windshild
Date: Nov 02, 2008
This is a second and last photo of the windshild. This time without the tape and it may make it easier to understand what I'm trying to explain. Gene ________________________________________________________________________________
Date: Nov 02, 2008
Subject: Re: windshild
Gene, Have you had a chance to test fly it? Any concerns about changed airflow over the fin and rudder? Thanks, Jeff > >This is a second and last photo of the >windshild. This time without the tape and it >may make it easier to understand what I'm trying >to explain. >Gene > > >Attachment converted: HD:windshild 002.jpg (JPEG/IC) (00C424D3) -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Nov 02, 2008
Jeff. Good catch! Yes I have noticed a small amount of tail heavyness but I believe once I make and install the front windshild that it will do away with it (I use to fly without a front windshild and experienced the same tail heavyness until I installed the front windshild). It wasn't much, but enough so that N502R was not flying hands off but instead wanted to climb a bit at cruise. I think that rather than have any effect on the fin, I'm getting the climb because the windshild slopes back and is installed near the trailing edge of the wing. I believe the air over the taller sloping windshild is pushing down on the airplane behind the CG (sort of like holding your arm out the side causing the airplane to turn in that direction. The front windshild, on the other hand, is located forward of the CG and I believe the wind pushing down on it will even things out. Even if the installation of the taller front windshild does not return it to hands off flying, I will leave them on as the flying is so much more enjoyable in cool weather with the taller windshild and the change is so small. I did not notice any other effect. I have flown with it for two hours, hard climb, fast descent, steep turns and cruise plus slow flight and was unable to detect anyother area where there was a change in the flight characteristics. Gene ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Sunday, November 02, 2008 4:38 PM Subject: Re: Pietenpol-List: windshild > > Gene, > > Have you had a chance to test fly it? Any concerns about changed airflow > over the fin and rudder? > > Thanks, > > Jeff > >> >>This is a second and last photo of the windshild. This time without the >>tape and it may make it easier to understand what I'm trying to explain. >>Gene >> >> >>Attachment converted: HD:windshild 002.jpg (JPEG/IC) (00C424D3) > > > -- > --- > > Jeffrey H. Boatright, Ph.D. > Associate Professor of Ophthalmology > Emory University School of Medicine > Editor-in-Chief > Molecular Vision > > > -- > Date: 10/28/2008 10:04 AM > > ________________________________________________________________________________
Date: Nov 02, 2008
Subject: Re: Model A test run report
Dan, That should be equivalent to 39 to 47 HP. Others might have an idea of how much a A engine develops at the speed read. Congrats, Miguel Azevedo Piper PA22/20-150 On Sun, Nov 2, 2008 at 5:26 PM, wrote: > Hello good people! > > Today was a glorious and warm day here in northern Illinois. 8-1/2 years in > the trenches so far. I rolled out my Piet from the hangar and tied'er down > at the tail. Added about two gallons of gas, and pulled'er through 5 blades > after a one-shot prime. Walked back 'round and twisted the mags around to > "both". Mosied back around to the front and took a'hold of the prop and > after three blades she came to life! What a great feeling!! There is > noth'in quite like the sound of an "A" and the breeze through your hair (if > you have any left). Ran'er up for quite a while and just took it all in! > This is the second day of runn'in her so a bit more relaxed and enjoyable. > I'm on "cruise control" now that I know she'll run. After 8 1/2 years its a > good feel'in!! > > Made a windshield this weekend, so cross that off the list. It's gett'in > closer to Tuesday!! I will work on cover'in her this winter. Got a reading > of 1850 RPM static at full throttle with my home-made prop. I think that is > pretty close to where it should be. Good enough to test fly'er with. I > attached a "fish scale" type spring scale (300 lb capacity) to the tail and > got a reading of 260 lbs @ full throttle. Does anybody know if this is > good?? I have no idea, but she was pull'in like a banshee!! > > Hopefully this report will serve as an encouragement to spur on all the > rest that are behind me. Keep-on plodding along!! Each small step is one > more toward your end goal............. Can't wait to fly her!! > > Dan Helsper > Poplar Grove, IL. > > > ------------------------------ > Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel > > * > > ________________________________________________________________________________
Date: Nov 02, 2008
Gene I also have an over sized windshield and the wind goes right over me making it confortable and quiet. One very nice thing on the Piet design, is that you can trim out the balance using the flying wires on the horiz stab. I made a couple of changes recently which left my plane a little nose heavy at cruise. I let off one turn on the front leading wires and tightened one turn on the bottom. Now it flies perfectly. It was also a beautiful day in NW Wisc. It's weird flying over some of the local snow Ski areas which are open any I was in a light jacket. Soon the lakes will be frozen which will make for some exciting flying at 1-3 ft. Dick N. ----- Original Message ----- From: "Gene & Tammy" <zharvey(at)bellsouth.net> Sent: Sunday, November 02, 2008 6:57 PM Subject: Re: Pietenpol-List: windshild Jeff. Good catch! Yes I have noticed a small amount of tail heavyness but I believe once I make and install the front windshild that it will do away with it (I use to fly without a front windshild and experienced the same tail heavyness until I installed the front windshild). It wasn't much, but enough so that N502R was not flying hands off but instead wanted to climb a bit at cruise. I think that rather than have any effect on the fin, I'm getting the climb because the windshild slopes back and is installed near the trailing edge of the wing. I believe the air over the taller sloping windshild is pushing down on the airplane behind the CG (sort of like holding your arm out the side causing the airplane to turn in that direction. The front windshild, on the other hand, is located forward of the CG and I believe the wind pushing down on it will even things out. Even if the installation of the taller front windshild does not return it to hands off flying, I will leave them on as the flying is so much more enjoyable in cool weather with the taller windshild and the change is so small. I did not notice any other effect. I have flown with it for two hours, hard climb, fast descent, steep turns and cruise plus slow flight and was unable to detect anyother area where there was a change in the flight characteristics. Gene ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Sunday, November 02, 2008 4:38 PM Subject: Re: Pietenpol-List: windshild > > Gene, > > Have you had a chance to test fly it? Any concerns about changed airflow > over the fin and rudder? > > Thanks, > > Jeff > >> >>This is a second and last photo of the windshild. This time without the >>tape and it may make it easier to understand what I'm trying to explain. >>Gene >> >> >>Attachment converted: HD:windshild 002.jpg (JPEG/IC) (00C424D3) > > > -- > --- > > Jeffrey H. Boatright, Ph.D. > Associate Professor of Ophthalmology > Emory University School of Medicine > Editor-in-Chief > Molecular Vision > > > -- > Date: 10/28/2008 10:04 AM > > ________________________________________________________________________________
Subject: windshild
Date: Nov 02, 2008
Gene, When I bought Felix the GN-1 the seller gave me an extra windshield that was about 10" tall. He said he replaced it with a smaller windshield because it blanked out the rudder and it scared him so he took it off. I flew the plane all summer 2007 with the short windshield. About this time last year it started to get cold so I cut down the tall windshield to 7 1/2" and installed it, much better. I probably have at least 50 hours on it with the taller windshield and can not detect any rudder blanking. Another thing that really helps on colder days is a front cockpit cover, keeps the cold air from coming up the pant legs. Skip ----- Original Message ----- From: Gene & Tammy Sent: 11/2/2008 6:08:32 PM Subject: Pietenpol-List: windshield This is a second and last photo of the windshield. This time without the tape and it may make it easier to understand what I'm trying to explain. Gene ________________________________________________________________________________
Date: Nov 02, 2008
Gene, Sounds great! We just remade the windshields on ours because they were so scratched up. We made them the same size as original, but may go to taller ones, as you did, for the same reason. Hey, do you have any photos taken from the side, showing the angle of the windshield? Congrats, Jeff ________________________________________________________________________________
Date: Nov 02, 2008
This might be of interest; http://www.amuffler.com/dyno/dyno1.htm Dan, That should be equivalent to 39 to 47 HP. Others might have an idea of how much a A engine develops at the speed read. Congrats, Miguel Azevedo Piper PA22/20-150 ________________________________________________________________________________
Date: Nov 03, 2008
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 03, 2008
Subject: Dual mags on Model A
Gene (Rambo), Yes I have an aftermarket head with 8 plug holes. I have one mag driven off the end of the crank, and the other off the camshaft. Photo attached. Dan Helsper Poplar Grove, IL. **************Plan your next getaway with AOL Travel. Check out Today's Hot 5 Travel Deals! ________________________________________________________________________________
Subject: aileron stuff
Date: Nov 03, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
Looks great, Rick. Of course I'm partial to engine-turned instrument panels. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard Schreiber Sent: Thursday, October 30, 2008 2:51 PM Subject: Pietenpol-List: aileron stuff Well guys here is a status report on my project. Per Dan Helsper's request I attached some photos of my wing with the aileron attached. I have also included a photo of drilling the aileron horn attachment. I used the hardwood block and tube method to insure the holes were aligned properly and perpendicular. This idea came from Chris Tracy on his web site. It worked well. This is the same method I used to drill all of the holes for the aileron hinge attachment screws. On the wings I still need to put in the nut plates for the aileron hinges, mount the aileron pulley supports and then run the cable. The fuselage is pretty well done, including all of the controls and cables I have mounted the main instruments in the IP, but still need to do some more like the engine gages, throttle, carb heat etc.. I am going to put the fuel tank in the front and that still needs to be made. The wing center section is complete. My empennage is complete and has been fitted to the fuselage with the guy wires for a test fit. Next on the agenda is the tail wheel and the straight axle main gear. I'd like to have my Piet done for the 80th in Oshkosh, but realistically that might be a stretch, depending on how much I get done this winter. I am also going to use a corvair engine. I have the core, but I still need to rebuild it. Around Valparaiso (VPZ) we have 4 Piet's in various stages on construction. All of them will be using Corvair power. The plan is to rebuild all of the engines at the same time in the same location with the assistance of our local EAA tech counselor. The great thing is the tech counselor is rebuilding a Piet and also doing a corvair conversion. He is also the person who did the restoration of the Allison engines for the Glacier Girl P-38 a few years ago. Rick Schreiber lmforge(at)earthlink.net _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Nov 03, 2008
Thanks for the complement Jack. The inspiration actually came from photos of your
October 22, 2008 - November 03, 2008
Pietenpol-Archive.digest.vol-hb
