Pietenpol-Archive.digest.vol-hd
November 14, 2008 - November 29, 2008
      You're close, but not quite accurate. A solid 1" spar has a bit more
      strength than a routed 1" spar (not equal).
      Here's the brief engineering lesson for the day:
      Every beam, regardless of the material it is made of, has "Section
      Properties". These are properties of the shape (provided the section is
      homogeneous - all one material throughout) that are used to determine (when
      coupled with material properties), the load carrying capacity of that beam.
      The Section Property in question here is called the Moment of Inertia about
      the neutral axis (I sub x). The Moment of Inertia is directly related to the
      load carrying capacity of the section, so a section with a Moment of Inertia
      value of 2 can carry twice the load that a section with a Moment of Inertia
      value of 1, and only half the load that a section with a value of 4 can, and
      so on. I have calculated the Moments of Inertia for three spar sections
      (routed 1", solid 1" and solid 3/4"). Using the routed 1" section as the
      basis (since this is the section shown in the plans) we see that a solid 1"
      spar can actually carry 119% as much as a routed 1" spar, and a solid 3/4"
      spar can carry 89% as much as a routed 1" spar. This relationship holds, no
      matter what material the spar is made of. The actual load carrying capacity
      comes when we apply the Material Properties (using the appropriate formulas)
      for the specific material that the spar is made of (Sitka Spruce, Douglas
      Fir, 7075 Aluminum, old cheese etc.).
      Calculations done by others have indicated that even the routed 1" spar is a
      bit over-designed (let alone a solid 1" spar), and that a solid 3/4" spar is
      sufficient to carry the loads. As we see from above, the solid 3/4" spar can
      carry almost 90% the load that the routed 1" spar can, which allows a Piet
      builder to save money and time.
      I've made up a simple drawing to show these sections and their Moments of
      Inertia, and attached it to illustrate.
      There will be a brief written quiz on Monday. This concludes today's lesson.
      Bill C.
        _____
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene Rambo Sent: Friday, November 14, 2008 8:33 AM
Subject: Re: spar thickness reduction
Mike: A 1" I-beam has the same strength as a solid 1" spar but less weight. Gene ________________________________________________________________________________
Date: Nov 14, 2008
Well Done and thanks Bill John In a message dated 11/14/2008 3:28:55 P.M. Eastern Standard Time, eng(at)canadianrogers.com writes: Gene, You're close, but not quite accurate. A solid 1" spar has a bit more strength than a routed 1" spar (not equal). Here's the brief engineering lesson for the day: Every beam, regardless of the material it is made of, has "Section Properties". These are properties of the shape (provided the section is homogeneous - all one material throughout) that are used to determine (when coupled with material properties), the load carrying capacity of that beam. The Section Property in question here is called the Moment of Inertia about the neutral axis (I sub x). The Moment of Inertia is directly related to the load carrying capacity of the section, so a section with a Moment of Inertia value of 2 can carry twice the load that a section with a Moment of Inertia value of 1, and only half the load that a section with a value of 4 can, and so on. I have calculated the Moments of Inertia for three spar sections (routed 1", solid 1" and solid 3/4"). Using the routed 1" section as the basis (since this is the section shown in the plans) we see that a solid 1" spar can actually carry 119% as much as a routed 1" spar, and a solid 3/4" spar can carry 89% as much as a routed 1" spar. This relationship holds, no matter what material the spar is made of. The actual load carrying capacity comes when we apply the Material Properties (using the appropriate formulas) for the specific material that the spar is made of (Sitka Spruce, Douglas Fir, 7075 Aluminum, old cheese etc.). Calculations done by others have indicated that even the routed 1" spar is a bit over-designed (let alone a solid 1" spar), and that a solid 3/4" spar is sufficient to carry the loads. As we see from above, the solid 3/4" spar can carry almost 90% the load that the routed 1" spar can, which allows a Piet builder to save money and time. I've made up a simple drawing to show these sections and their Moments of Inertia, and attached it to illustrate. There will be a brief written quiz on Monday. This concludes today's lesson. Bill C. ____________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene Rambo Sent: Friday, November 14, 2008 8:33 AM Subject: Re: Pietenpol-List: spar thickness reduction Mike: A 1" I-beam has the same strength as a solid 1" spar but less weight. Gene **************Get the Moviefone Toolbar. Showtimes, theaters, movie news & p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
Date: Nov 14, 2008
Bill, When you get a moment, we'd like to hear about modulus of elasticity under typical live loadings in flight for these three shapes. I think that sitka spruce compared to tofu would complete the exercise nicely. Cheers, Al Lyscars ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Friday, November 14, 2008 3:26 PM Subject: RE: Pietenpol-List: spar thickness reduction Gene, You're close, but not quite accurate. A solid 1" spar has a bit more strength than a routed 1" spar (not equal). Here's the brief engineering lesson for the day: Every beam, regardless of the material it is made of, has "Section Properties". These are properties of the shape (provided the section is homogeneous - all one material throughout) that are used to determine (when coupled with material properties), the load carrying capacity of that beam. The Section Property in question here is called the Moment of Inertia about the neutral axis (I sub x). The Moment of Inertia is directly related to the load carrying capacity of the section, so a section with a Moment of Inertia value of 2 can carry twice the load that a section with a Moment of Inertia value of 1, and only half the load that a section with a value of 4 can, and so on. I have calculated the Moments of Inertia for three spar sections (routed 1", solid 1" and solid 3/4"). Using the routed 1" section as the basis (since this is the section shown in the plans) we see that a solid 1" spar can actually carry 119% as much as a routed 1" spar, and a solid 3/4" spar can carry 89% as much as a routed 1" spar. This relationship holds, no matter what material the spar is made of. The actual load carrying capacity comes when we apply the Material Properties (using the appropriate formulas) for the specific material that the spar is made of (Sitka Spruce, Douglas Fir, 7075 Aluminum, old cheese etc.). Calculations done by others have indicated that even the routed 1" spar is a bit over-designed (let alone a solid 1" spar), and that a solid 3/4" spar is sufficient to carry the loads. As we see from above, the solid 3/4" spar can carry almost 90% the load that the routed 1" spar can, which allows a Piet builder to save money and time. I've made up a simple drawing to show these sections and their Moments of Inertia, and attached it to illustrate. There will be a brief written quiz on Monday. This concludes today's lesson. Bill C. ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene Rambo Sent: Friday, November 14, 2008 8:33 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: spar thickness reduction Mike: A 1" I-beam has the same strength as a solid 1" spar but less weight. Gene ________________________________________________________________________________
Date: Nov 14, 2008
Subject: Re: MY CONTINENTAL A-80 AIRCRAFT ENGINE on EBAY & YouTube.
Think you have to Copy and Paste walt evans NX140DL ----- Original Message ----- From: Roy Brooks To: pietenpol-list(at)matronics.com Sent: Friday, November 14, 2008 2:10 PM Subject: RE: Pietenpol-List: MY CONTINENTAL A-80 AIRCRAFT ENGINE on EBAY & YouTube. For some reason, my YouTube link doesn't seem to come up, so here it is again. Maybe Mattronics has something that eliminates links, if so, go to YouTube and just type in this (A-80 AIRCRAFT ENGINE.) Sorry.... Here is the link one more try. http://www.youtube.com/watch?v=O31jul0OYUI ------------------------------------------------------------------------- ----- From: n900ml(at)hotmail.com To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: MY CONTINENTAL A-80 AIRCRAFT ENGINE on EBAY & YouTube. Date: Fri, 14 Nov 2008 12:44:33 -0600 PIETERS=85 I am selling my Continental A-80 engine (as I advised here a month or so ago) and now seen on YouTube. Just type in =93A-80 Continental Aircraft Engine.=94 If that doesn=92t work, use this direct link =85 http://www.youtube.com/watch?v=O31jul0OYUI This engine will go on Ebay and I=92ll post a note here to give interested parties a =93heads-up=94 the day it goes up for auction. It will be sold through Ebay to the highest bidder. I=92ll probably start the auction at $1. It will be necessary for the winning bidder to pick the engine up at Bruce Field in Ballinger, Texas. Here are some details about the history of this engine. This is a long story and if you ARE NOT in the market for an engine being sold for PARTS ONLY please save yourself some time and don=92t bother reading this. I made this video for YouTube in order to show some of the =93highlights=94 about the overhaul on this engine done by my father in 2005. My father was an A&P Mechanic and had 5 type ratings in jets when he retired. He overhauled my Continental A-80 engine and passed away soon after signing the engine logbook. It is bittersweet having to sell this engine, because his signature in the logbook is the last thing he ever signed before he passed away in 2005. My dad learned he had a relapse of colon cancer and at age 85, and he simply decided NOT to undergo chemotherapy a second-time after seeing my mom go though cancer treatment with chemo and radiation not working for her, just a year earlier. Getting my dad to overhaul the engine helped to keep him occupied when that he was living alone as a widower and I simply did not have the savvy to attempt this myself. My dad was tough as nails and the last thing he wanted to accomplish in life was to overhaul my Continental A-80 engine. When he was 78, he overhauled my Lycoming 0-320 E2A engine. In my youth, he overhauled my 1963 Ford van engine, my 1965 Mustang engine and transmission, half a dozen motorcycle engines, he built boats, campers, travel trailers. When he was younger, he rebuilt and flew several old Army Air Corp trainers. He was an instructor pilot during WW2 in the Army Air Corp. The man was a gifted mechanic and I was the =93artist=94. He built stuff, I made them look nice. It was a great partnership for 54 years. When he was 82, he bought a Volkswagen Westfalia and we pulled the engine from that (see this on YouTube, =93Rebuilding my dad=92s Westfalia). I can=92t even remember how many VW based dune buggies my dad and I built, but it was ALWAYS a common sight to see split engine cases and air cooled engines in our garage when I was young. I am not in the position to warranty this engine or guarantee the sufficiency of this engine for use in either a certificated or experimental airplane. By being =93up-front=94 with everyone about the condition of my father (he was in Hospice Care at home when he did this overhaul) it is my goal to be as above-board as possible. I am selling this engine on Ebay as a =93PARTS ENGINE.=94 All bidders will need to understand this is a salvage project for the value of the parts that can be obtained when they disassemble the engine. A Bill Of Sale signed by me and the successful bidder will reflect =93PARTS ENGINE.=94 I can tell you that had I NOT become so decrepit myself, I would have had no reservation about putting this engine on the Piet project my dad and I were working on. My dad NEVER let me down, and my confidence level in this engine is very high. But that being said, I want to emphasize, THIS IS A PARTS ENGINE and must be disassembled by whoever purchases it, for use of parts that can be salvaged. This engine was originally in a Pietenpol I bought in November 2003 (the first time my dad was sick with colon cancer). I had previously committed to travel out-of-state with my father to inspect and purchase a Pietenpol, but my father became ill within a day or so of my trip out of town and he wasn=92t able to go with me. The guy who was selling a Piet (in 2003) sent me e-mails stating the engine had only 5 hours since major overhaul. I made a quick trip out-of-state to buy the Piet and I brought it home on a trailer. When my dad was finally well enough to leave his house, he came out to my farm so we could start the engine. It began leaking oil and gas and ran very rough, despite having fresh gasoline (I think the ride back to Texas on a trailer was all that was needed to make this engine spring a leak.) I pulled the engine out of the Pietenpol, took it to my father=92s house and we disassembled it in his garage (watch the YouTube video.) It was scary to see what was inside the engine as we pulled the oil tank off, removed the cylinders and split the case. The lobes on the camshaft were out of tolerance, the crankshaft was so pitted, the journals looked like Swiss cheese (see this on YouTube, it is pathetic) and the guy who re-built it was so cheap, he made many of engine gaskets rather than purchase REAL OEM gaskets. It was also evident old cotter pins were re-used (inside the engine) and the builder failed to adequately safety-wire the oil pick-up tube onto the engine. The tube could have fallen of into the oil sump! (The list of horrors goes on=85) Long story made short (nearly $7,000 later) I sent the engine case off to Divco, the accessory case went to Drake, I bought a NEW camshaft, had the cylinders rebuilt (Cerminil) bought a new oil pump-kit, new rod bolts, all new gaskets=85 the list of new stuff goes on and on and on. Shortly after the case and parts came back, my father had a relapse of colon cancer and he basically threw in the towel so to speak. He didn=92t want to do chemo again, but he did want to rebuild the engine=85 This was his last priority in life. I think if you will take the time to look at my YouTube video, you=92ll agree, this is the one of the BEST looking A-series engines you will have ever seen. I spared no expense in bringing this engine back to life. I even bought new air-intake tubes, new pushrod tubes and had them powder coated in Candy Apple Blue. I powder coated the valve covers in Continental Gold=85 All new rubber, all new clamps, all new bolts inside and outside the engine. The Slick Mags appeared relatively new when I bought the Pietenpol, They are dual-impulse coupler and they sparked nice and hot. That was the best thing about this Piet project was the new Slick mags. I am not certain where the wiring harness is, but I=92m fairly confident I can find them. When I put the engine on Ebay, bidders will have to be pre-approved prior to submitting a bid. NOBODY gets to bid unless they contact me through Ebay and state they understand the =93no warranty, no guarantee, this is a PARTS engine=94 and they understand it is not being intended for use in any airplane because it is a PARTS ENGINE. I simply can=92t take on the liability and as such, I=92ll be taking a price-beating on this engine by not stating it is =93airworthy.=94 For anybody wanting to see my receipts, yellow tags, release forms, Cerminil process and ALL THE PARTS I bought, I am willing to send you a CD of the receipts and a DVD (as the one YouTube except with better resolution) for $20. I can=92t afford to be mailing CDs and DVDs out to every =93tire-kicker=94 out there and the $20 will be refunded to who ever actually wins the bid. $20 gets you the CD of the receipts with some pictures AND the DVD as shown on YouTube. The DVD should have better resolution than the video I uploaded onto YouTube. Simply send me a money order with your mailing address, and I am happy to put the discs and info in the mail to you. My mail address is P.O. Box 1991. Abilene, Texas 79604. The video on YouTube isn't too bad, but the CD and DVD have greater detail and resolution. Please let me make it clear, the engine will be sold on Ebay, I will not end the auction early, I will not have a buy-it-now price, nor an asking price. I added up the receipts I could find, and the math comes to around $6,600 (not including the powder coating for valve covers, air intake tubes, pushrod tubes and other engine parts.) My expense on this engine pushes the $7,000 mark easily. In a few weeks, I will be getting ready the Piet project (NOT THE JUNK PILE I FIRST BOUGHT) BUT THE SECOND FINER EXAMPLE OF fuselage, wings, center section, lift struts etc. and offering pictures and a YouTube video of it in about a month or so. It is a Piet Fuselage with Grega wings. It was originally started by an Air Force Maintenance Office who worked on the B-1 program. He was also a B-2 Maintenance Officer at a base in MO. when he retired. It is my understanding he is also an A&P/IA and HE works at Cessna in Wichita, Kansas. I felt pretty confident in this guys abilities and this time, I took my father with me for a pre-buy inspection. My dad liked what he saw on this project and I bought it. The original builder had this Aircamper project set up for a Corvair, but I elected to go with my Continental A-80. I sold the Corvair parts and motormount to a TACO official not too far from me. MORE DETAILS ABOUT THIS WILL COME IN A FEW WEEKS. ------------------------------------------------------------------------- ----- Windows Live Hotmail now works up to 70% faster. Sign up today. ww.matronics.com/contribution st">http://www.matronics.com/Navigator?Pietenpol-List onics.com ------------------------------------------------------------------------- ----- Stay up to date on your PC, the Web, and y19462413/direct/01/' target='_new'>Click here ________________________________________________________________________________
Date: Nov 14, 2008
Thanks for the "lesson", but I completely disagree. I won't argue engineering on here though. Gene ----- Original Message ----- From: ALAN LYSCARS<mailto:alyscars(at)verizon.net> To: pietenpol-list(at)matronics.com Sent: Friday, November 14, 2008 5:18 PM Subject: Re: Pietenpol-List: spar thickness reduction Bill, When you get a moment, we'd like to hear about modulus of elasticity under typical live loadings in flight for these three shapes. I think that sitka spruce compared to tofu would complete the exercise nicely. Cheers, Al Lyscars ----- Original Message ----- From: Bill Church<mailto:eng(at)canadianrogers.com> To: pietenpol-list(at)matronics.com Sent: Friday, November 14, 2008 3:26 PM Subject: RE: Pietenpol-List: spar thickness reduction Gene, You're close, but not quite accurate. A solid 1" spar has a bit more strength than a routed 1" spar (not equal). Here's the brief engineering lesson for the day: Every beam, regardless of the material it is made of, has "Section Properties". These are properties of the shape (provided the section is homogeneous - all one material throughout) that are used to determine (when coupled with material properties), the load carrying capacity of that beam. The Section Property in question here is called the Moment of Inertia about the neutral axis (I sub x). The Moment of Inertia is directly related to the load carrying capacity of the section, so a section with a Moment of Inertia value of 2 can carry twice the load that a section with a Moment of Inertia value of 1, and only half the load that a section with a value of 4 can, and so on. I have calculated the Moments of Inertia for three spar sections (routed 1", solid 1" and solid 3/4"). Using the routed 1" section as the basis (since this is the section shown in the plans) we see that a solid 1" spar can actually carry 119% as much as a routed 1" spar, and a solid 3/4" spar can carry 89% as much as a routed 1" spar. This relationship holds, no matter what material the spar is made of. The actual load carrying capacity comes when we apply the Material Properties (using the appropriate formulas) for the specific material that the spar is made of (Sitka Spruce, Douglas Fir, 7075 Aluminum, old cheese etc.). Calculations done by others have indicated that even the routed 1" spar is a bit over-designed (let alone a solid 1" spar), and that a solid 3/4" spar is sufficient to carry the loads. As we see from above, the solid 3/4" spar can carry almost 90% the load that the routed 1" spar can, which allows a Piet builder to save money and time. I've made up a simple drawing to show these sections and their Moments of Inertia, and attached it to illustrate. There will be a brief written quiz on Monday. This concludes today's lesson. Bill C. ------------------------------------------------------------------------- --- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene Rambo Sent: Friday, November 14, 2008 8:33 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: spar thickness reduction Mike: A 1" I-beam has the same strength as a solid 1" spar but less weight. Gene http://www.matronics.com/contribution on> http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> ________________________________________________________________________________
Subject: spar thickness reduction
Date: Nov 14, 2008
Gene, What part do you "completely disagree" with? I think this List is a better venue to discuss engineering than it is to discuss the merits of Chinese imports, so if you take issue with anything I wrote, please share your thoughts. Maybe I've overlooked something. Unless someone can point out any errors in what I've written, I stand by what I wrote. By the way, the "lesson" was directed at the list members in general, not an any one person. But more specifically, it was directed to those on the list that are not familiar with strengths of materials, and who might appreciate a basic explanation of some things that get brought up from time to time, such as spar design. Bill C. ________________________________________________________________________________
Subject: Re: build vs. buy?
Date: Nov 14, 2008
Jim. As I understand it, it is basically the same, except the conditional can be signed off by an A&P and the Annual needs to be signed off by an A&P with an inspection authorization. See FAR 91.409 (c). There may be more to it than that and I'm sure someone here knows ....the rest of the story. Gene in rainy, foggy Tennessee ----- Original Message ----- From: "Jim Ash" <ashcan(at)earthlink.net> Sent: Thursday, November 13, 2008 9:30 PM Subject: Re: Pietenpol-List: build vs. buy? > > I guess I'm a little surprised to learn the rules are different for > experimentals. For years, I thought they were the same. > > So what's the difference between a conditional inspection and an annual? > > Jim Ash > > -----Original Message----- >>From: Gene & Tammy <zharvey(at)bellsouth.net> >>Sent: Nov 13, 2008 7:23 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: build vs. buy? >> >> >> >>Not completely correct. You would need to get a "condition inspection" >>not >>an annual for an experimental airplane. A lot of A & P's I know will let >>you do most, if not all, of the condition inspection under their >>supervision. On the experimentals I have owned I have usually paid >>between >>$50.00 and $150.00 for a condition inspection. Well worth the price to >>have another set of trained eyes looking over everything. I like to fly >>and >>can't affort to own a plane and build at the same time so buying a >>completed >>Piet was a good way for me to go. Besides, an experimentel airplane is >>never done and I'm always tinkering with it anyway. >>If you follow the airplanes selling on E-bay and Barnstormers have you >>ever >>wondered why there are so many homebuilt planes with 0 or very few hours >>for >>sale? So many of these have been built by folks that are going to wait >>until the plane is finished to learn to fly. Many times they have either >>gotten too old or they find they really don't like to fly. If you love to >>build then build for the love of it, not to get a cheap airplane. Many >>time >>(really I'd say most times) you can buy a well built experimental for less >>than you can build one for. >>My 2 cents worth >>Gene in beautiful Tennessee (spent the first half of the afternoon flying >>the Piet and the second half riding the Gold Wing. Life just doesn't get >>any better) >> >> >> >> >> >> >> >> >> >>Original Message ----- >>From: "Jim Ash" <ashcan(at)earthlink.net> >>To: >>Sent: Thursday, November 13, 2008 4:51 PM >>Subject: Re: Pietenpol-List: build vs. buy? >> >> >>> >>> If you're an A&P, that might work. But for those of us who aren't, >>> buying >>> one from someone else would require us to get our annuals professionally >>> done by somebody else, just as if you'd bought a standard-type. If you >>> built your own, you can get a special A&P certificate for that specific >>> aircraft and do the annuals yourself. >>> >>> Jim Ash >>> >>> >>> >>> -----Original Message----- >>>>From: Tom Anderson <tomanderson_nc(at)yahoo.com> >>>>Sent: Nov 13, 2008 4:26 PM >>>>To: pietenpol-list(at)matronics.com >>>>Subject: Pietenpol-List: build vs. buy? >>>> >>>> >>>> >>>>For those of you that have built a Piet in the past 5 yrs. or so, would >>>>you be willing to share how much your overall costs were? >>>>In talking with several members on this forum (thanks Jack, Jeff, and a >>>>couple of others), I have come to the conclusion that I'm likely not >>>>going >>>>to save much, if anything, by building a Piet. In fact, I've come to >>>>the >>>>conclusion that it may be in my best interest to purchase a well-built >>>>one >>>>that's already got the minimum hours flown off it and just learn to fly >>>>it. Then, when the kids have left home and I'm bored in my older age, >>>>build me one just like I want, if I'm still inclined to do so. >>>> >>>>Any comments, suggestions, or meaningful discussion? >>>> >>>>-------- >>>>Location: Wilson, NC >>>> >>>> >>>> >>>> >>>>Read this topic online here: >>>> >>>>
http://forums.matronics.com/viewtopic.php?p=213979#213979 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >>> -- >>> Checked by AVG. >>> 7:58 AM >>> >>> >> >> >> >> >> > > > -- > Checked by AVG. > 7:58 AM > > ________________________________________________________________________________
Date: Nov 14, 2008
That would be me...in need of a lesson in strengths. Please, if you would n ot mind Gene, I would be interested in hearing you. - - ________________________________________________________________________________
Subject: Re: Brakes
Date: Nov 14, 2008
I have a M.C. brake actuator on the stick. I also have a steerable tail wheel. I would get tighter turning radius with dual actuators, but for simplicity, it's just fine for me. Dick N. ----- Original Message ----- From: Marc Dumay To: pietenpol-list(at)matronics.com Sent: Thursday, November 13, 2008 9:45 PM Subject: Pietenpol-List: Brakes Good day fellow mentors. Having no experience yet flying a tail dragger, especially a Pietenpol, I was curious as to what most Piet builders think of having brakes or not on their aircraft? We will be flying both grass and hard surface runways. We plan on having brakes, but not brake pedals. We are thinking of having a brake handle like on a motorcycle. The drawback, would be that we don't have individual braking " left or right", just both wheels would brake the same amount. We will have a antilock regulator and proportioning valve. We hope to use a steerable tail wheel, and are a bit concerned about the ease of taxing and turning without individual brakes on our Piet. Any input or advice would be appreciated. Marc and Larry ________________________________________________________________________________
Subject: Re: Brakes
Date: Nov 14, 2008
About five years ago (April 12, 2003 to be exact) Pietenpol builder John McNarry posted the following. It sounded like an interesting arrangement, but I can't find any postings from John since 2004, so I don't know if it ever got operational. The basic arrangement makes sense, just not sure how it would perform in the real world Bill C. : I won't claim this works as I have only made a proof of concept mock up. I have the straight axle gear 21" rims with cable operated drum brakes and the rudder bar. The brake control is like a motorcycle hand brake mounted on the front of the stick. The sheathed cable runs down the stick and splits into two cables parallel to the aileron torque tube. These two cable sheaths are anchored to the floor and the inner cable make a 180 degree turn back towards the front at about under the seat. They then pass over moving pulleys that are fastened with rod links to the rudder bar. This means the cables have an S shaped path and exit the floor at about the rear landing gear "V" strut. Sheathed motorcycle cables take the pull from there to the drum brake levers. With the handle squeezed hard toward the stick the wheels are locked. The lever is at a bit of a stretch but I can get my fingers around it. When the rudder bar is moved, the cable on the side the bar is pressed gets tighter. The opposite side goes slack. The differential is enough that the opposite wheel turns freely. The hand lever moves toward the stick slightly. The slack cable is held on the pulleys by guards and fair lead tubes on the torque tube. I haven't built the whole affair yet and plan to have a row of holes on the pull rod attachment at the rudder bar. This will allow me to find the right rudder bar pull point. Benefits: Brakes! I can hold the brakes with one hand. Differential braking. No Hydraulics. Motorcycle cables are adjustable. Thinking this up is a cure for insomnia. Disadvantages: The pile of parts weighs about 2 lbs. I can't seem to find the time to finish it. Rudder bar? Well the first vehicles I drove where "Capital I go-karts" with front axle steering. You pushed on the opposite side from the direction you wanted to steer. All my time has been in older tail draggers. The Tiger Moth has the only rudder bar I've flown. It has no brakes and a funny linkage that keeps the pedal attached to the bar from swinging in an arc. It still requires a lot of leg motion. Learn to dance. Fly a tail dragger! John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214307#214307 ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: Lockable Tailwheels
Date: Nov 14, 2008
Fellow Pieters, I have a question for those who have built your own steerable tailwheels. Did you make them lockable or not? If they are steerable, without locking for takeoff, how do they behave in a crosswind? Most of the homemade assemblies I have seen appear to be non-lockable, while the purchased units like Matco or the ACSS Homebuilders special are lockable. RicK Schreiber Valparaiso, IN lmforge(at)earthlink.net ________________________________________________________________________________
Date: Nov 15, 2008
Subject: Re: Lockable Tailwheels
I don't have a lock and it's not steerable as yet.I use the-brakes and th e rudder to steer.I'm thinking of installing a steering mechanism using cab les to the rudder cables as others have done.-=0A=0A=0A=0A=0A____________ ____________________=0AFrom: Richard Schreiber <lmforge(at)earthlink.net>=0ATo : pietenpol-list =0ASent: Saturday, November 15, 2008 12:28:36 AM=0ASubject: Pietenpol-List: Lockable Tailwheels=0A=0A =0AFellow Pieters,=0A=0AI have a question for those who have built your own steerable tailwheels. Did you make them lockable or not? If they are steer able, without locking for takeoff, how do they behave in a crosswind? Most of the homemade assemblies I have seen appear to be non-lockable, while the purchased units like Matco or the ACSS Homebuilders special are lockable. =0A=0A=0ARicK Schreiber=0AValparaiso, IN=0A=0Almforge(at)earthlink.net=0A=0A =======0A ________________________________________________________________________________
Date: Nov 15, 2008
Your choices for tailwheels (once you exclude skids) are a full-swivel but not steerable, steerable but not full swivel, or lockable, which is a compromise between both. (Did I forget anything?) I have a lockable pneumatic (I don't recall if it's 6" or 8") Scott on my Cub. That after the little steerable solid rubber wheel with the bad bearings that was more skid than wheel. I didn't ask for a lockable tailwheel; it's what my A&P got for me and installed. But I'm glad he did. One of my hassles with the old tailwheel was ground handling. Rolling backwards pretty much necessitated me lifting the rear of the plane and walking it. With the new one, I can roll the plane backwards on all its wheels without having to lift it any more. It's never caused me any problems in a crosswind. The only goofiness to it is that when I want to unlock it, sometimes it takes a determined kick on the pedals to get it to 'snap out' of being locked. I don't know if the force required to get it to unlock is adjustable or not; I've gotten used to it and haven't bothered screwing with it. As I think about it, my next choice would be a full-swivel over a steerable. My brakes are good enough, and I can goose the throttle and wash the rudder to bring it around also. I got pretty good at it with the old lousy tailwheel, which steered rather poorly anyhow. Jim Ash -----Original Message----- >From: Richard Schreiber <lmforge(at)earthlink.net> >Sent: Nov 15, 2008 12:28 AM >To: pietenpol-list >Subject: Pietenpol-List: Lockable Tailwheels > >Fellow Pieters, > >I have a question for those who have built your own steerable tailwheels. Did you make them lockable or not? If they are steerable, without locking for takeoff, how do they behave in a crosswind? Most of the homemade assemblies I have seen appear to be non-lockable, while the purchased units like Matco or the ACSS Homebuilders special are lockable. > > >RicK Schreiber >Valparaiso, IN > >lmforge(at)earthlink.net ________________________________________________________________________________
Date: Nov 15, 2008
We flew NX92GB for the 1st 2 years with a fixed non steerable t/w.- Taxi was a "think 5 min ahead" type of ordeal.- It was fine on grass, but coul d get dicy on a paved runway with a crosswind.- All was well untill that transition time where the rudder became inefective, but you still had forwa rd speed, and it would weather vane.- The brakes are not really strong so a blast of power and rudder was required to keep it on the runway.- The 1st time I experianced it I had to think quickly, after flying champs I was used to the tailwheel traction to steer in that situation.- I would reco mend at least a steerable T/W for your piet, unless you plan on never landi ng on hard surfaced runways. - Shad=0A=0A=0A ________________________________________________________________________________
Date: Nov 15, 2008
Thanks to all for your responses. John, I may make a "vacation" trip to WI to learn to fly that Cub. I may be in touch requesting some additional info. on it. -------- Location: Wilson, NC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214394#214394 ________________________________________________________________________________
Date: Nov 15, 2008
You need to see Ken Perkins steerable tailwheel... Look at his Mykitplanes site. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214396#214396 ________________________________________________________________________________
Date: Nov 15, 2008
I have only had 1 landing in a tailwheel aircraft, a Luscomb about a month ago. Due to my inexperience in tailwheel landings what I was wondering (or maybe not understanding) is this. I plan on installing a steerable tailwheel. Do I need to have or is it desirable to have the tailwheel lockable. Will I gain that much stability in crosswind takeoffs and landings if the tailwheel will lock? I am not that concerned about having the wheel be full castering for ground maneuvering when I need to put the Piet in a hangar. Rick Schreiber ----- Original Message ----- From: shad bell Sent: 11/15/2008 5:13:05 PM Subject: Re: Pietenpol-List: Lockable Tailwheels We flew NX92GB for the 1st 2 years with a fixed non steerable t/w. Taxi was a "think 5 min ahead" type of ordeal. It was fine on grass, but could get dicy on a paved runway with a crosswind. All was well untill that transition time where the rudder became inefective, but you still had forward speed, and it would weather vane. The brakes are not really strong so a blast of power and rudder was required to keep it on the runway. The 1st time I experianced it I had to think quickly, after flying champs I was used to the tailwheel traction to steer in that situation. I would recomend at least a steerable T/W for your piet, unless you plan on never landing on hard surfaced runways. Shad ________________________________________________________________________________
Date: Nov 15, 2008
For clarification's sake, my Scott tailwheel is called a locking tailwheel. By that definition, there is an additional moving mechanism between the wheel and the bellcrank. The 'locked' state means that this mechanism is engaged and locks the bellcrank to the wheel, becoming a steerable tailwheel. The 'unlocked' position disengages the bellcrank from the wheel and allows it to caster a full 360 degrees. 'Full 360 degrees' is actually kind of a lie. If the tailwheel is castered around to the straight rear positon, it will automatically lock again. This is how to get it to lock. To unlock it requires side pressure to 'break it loose'. Sometimes snapping the pedals quickly (with the wheel on the ground) will unlock it also. I suspect there's a littel ball-and-sprint detent mechanism inside it. Locked, by this definition does not imply 'locked straight forward' so much as 'locked to the bellcrank'. Is this everybody else's understanding? Jim Ash -----Original Message----- >From: Richard Schreiber <lmforge(at)earthlink.net> >Sent: Nov 15, 2008 6:30 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Lockable Tailwheels > >I have only had 1 landing in a tailwheel aircraft, a Luscomb about a month ago. Due to my inexperience in tailwheel landings what I was wondering (or maybe not understanding) is this. I plan on installing a steerable tailwheel. Do I need to have or is it desirable to have the tailwheel lockable. Will I gain that much stability in crosswind takeoffs and landings if the tailwheel will lock? I am not that concerned about having the wheel be full castering for ground maneuvering when I need to put the Piet in a hangar. > >Rick Schreiber >----- Original Message ----- >From: shad bell >To: pietenpol-list(at)matronics.com >Sent: 11/15/2008 5:13:05 PM >Subject: Re: Pietenpol-List: Lockable Tailwheels > > >We flew NX92GB for the 1st 2 years with a fixed non steerable t/w. Taxi was a "think 5 min ahead" type of ordeal. It was fine on grass, but could get dicy on a paved runway with a crosswind. All was well untill that transition time where the rudder became inefective, but you still had forward speed, and it would weather vane. The brakes are not really strong so a blast of power and rudder was required to keep it on the runway. The 1st time I experianced it I had to think quickly, after flying champs I was used to the tailwheel traction to steer in that situation. I would recomend at least a steerable T/W for your piet, unless you plan on never landing on hard surfaced runways. > >Shad > > ________________________________________________________________________________
Date: Nov 15, 2008
I think this clarifies some confusion, because there were aircraft that had true "locking tailwheels" that locked in the straight forward position when the stick was held in a certain position (something makes me think full forward). Anyone with high horse power tailwheel time can probably clarify this. Your style of "locking tailwheel" can be forced out of it's detent by a particularly strong gust, just the same as pushing sideways on the tail in order to get it to swivel into position to push into the hangar. On Sat, Nov 15, 2008 at 7:23 PM, Jim Ash wrote: > > For clarification's sake, my Scott tailwheel is called a locking tailwheel. > By that definition, there is an additional moving mechanism between the > wheel and the bellcrank. The 'locked' state means that this mechanism is > engaged and locks the bellcrank to the wheel, becoming a steerable > tailwheel. The 'unlocked' position disengages the bellcrank from the wheel > and allows it to caster a full 360 degrees. > > 'Full 360 degrees' is actually kind of a lie. If the tailwheel is castered > around to the straight rear positon, it will automatically lock again. This > is how to get it to lock. To unlock it requires side pressure to 'break it > loose'. Sometimes snapping the pedals quickly (with the wheel on the ground) > will unlock it also. I suspect there's a littel ball-and-sprint detent > mechanism inside it. > > Locked, by this definition does not imply 'locked straight forward' so much > as 'locked to the bellcrank'. > > Is this everybody else's understanding? > > Jim Ash > > -----Original Message----- > >From: Richard Schreiber <lmforge(at)earthlink.net> > >Sent: Nov 15, 2008 6:30 PM > >To: pietenpol-list(at)matronics.com > >Subject: Re: Pietenpol-List: Lockable Tailwheels > > > >I have only had 1 landing in a tailwheel aircraft, a Luscomb about a month > ago. Due to my inexperience in tailwheel landings what I was wondering (or > maybe not understanding) is this. I plan on installing a steerable > tailwheel. Do I need to have or is it desirable to have the tailwheel > lockable. Will I gain that much stability in crosswind takeoffs and landings > if the tailwheel will lock? I am not that concerned about having the wheel > be full castering for ground maneuvering when I need to put the Piet in a > hangar. > > > >Rick Schreiber > >----- Original Message ----- > >From: shad bell > >To: pietenpol-list(at)matronics.com > >Sent: 11/15/2008 5:13:05 PM > >Subject: Re: Pietenpol-List: Lockable Tailwheels > > > > > > > >We flew NX92GB for the 1st 2 years with a fixed non steerable t/w. Taxi > was a "think 5 min ahead" type of ordeal. It was fine on grass, but could > get dicy on a paved runway with a crosswind. All was well untill that > transition time where the rudder became inefective, but you still had > forward speed, and it would weather vane. The brakes are not really strong > so a blast of power and rudder was required to keep it on the runway. The > 1st time I experianced it I had to think quickly, after flying champs I was > used to the tailwheel traction to steer in that situation. I would recomend > at least a steerable T/W for your piet, unless you plan on never landing on > hard surfaced runways. > > > >Shad > > > > > > > > ________________________________________________________________________________
Date: Nov 15, 2008
Tom, If your an EAA member give them a call and they can give you a full list of all instructors that instruct in tail wheel aircraft and where their at. There is also a web site anyone can go to that EAA has listed all of that info also but I don't remember what it is. If you need it just let me know and I'll call the EAA and find out. Gene ________________________________________________________________________________
Date: Nov 15, 2008
That's right, and that's how I found mine who is willing, and has been, instructing me, in my Piet! > >Tom, If your an EAA member give them a call and they can give you a >full list of all instructors that instruct in tail wheel aircraft >and where their at. There is also a web site anyone can go to that >EAA has listed all of that info also but I don't remember what it >is. If you need it just let me know and I'll call the EAA and find >out. >Gene ________________________________________________________________________________
Date: Nov 15, 2008
My particular tailwheel takes quite a bit to unlock it; sometimes you really have to work at it to break it loose, to the point where I wonder if I shouldn't loosen the detent a bit. I can't imagine even being IN my plane in the kind of crosswind it would take to break it loose. Maybe others' tailwheels aren't so 'stiff'. Jim -----Original Message----- >From: Lloyd Smith <lesmith240(at)gmail.com> >Sent: Nov 15, 2008 7:39 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Lockable Tailwheels > >I think this clarifies some confusion, because there were aircraft that had >true "locking tailwheels" that locked in the straight forward position when >the stick was held in a certain position (something makes me think full >forward). Anyone with high horse power tailwheel time can probably clarify >this. Your style of "locking tailwheel" can be forced out of it's detent by >a particularly strong gust, just the same as pushing sideways on the tail in >order to get it to swivel into position to push into the hangar. > >On Sat, Nov 15, 2008 at 7:23 PM, Jim Ash wrote: > >> >> For clarification's sake, my Scott tailwheel is called a locking tailwheel. >> By that definition, there is an additional moving mechanism between the >> wheel and the bellcrank. The 'locked' state means that this mechanism is >> engaged and locks the bellcrank to the wheel, becoming a steerable >> tailwheel. The 'unlocked' position disengages the bellcrank from the wheel >> and allows it to caster a full 360 degrees. >> >> 'Full 360 degrees' is actually kind of a lie. If the tailwheel is castered >> around to the straight rear positon, it will automatically lock again. This >> is how to get it to lock. To unlock it requires side pressure to 'break it >> loose'. Sometimes snapping the pedals quickly (with the wheel on the ground) >> will unlock it also. I suspect there's a littel ball-and-sprint detent >> mechanism inside it. >> >> Locked, by this definition does not imply 'locked straight forward' so much >> as 'locked to the bellcrank'. >> >> Is this everybody else's understanding? >> >> Jim Ash >> >> -----Original Message----- >> >From: Richard Schreiber <lmforge(at)earthlink.net> >> >Sent: Nov 15, 2008 6:30 PM >> >To: pietenpol-list(at)matronics.com >> >Subject: Re: Pietenpol-List: Lockable Tailwheels >> > >> >I have only had 1 landing in a tailwheel aircraft, a Luscomb about a month >> ago. Due to my inexperience in tailwheel landings what I was wondering (or >> maybe not understanding) is this. I plan on installing a steerable >> tailwheel. Do I need to have or is it desirable to have the tailwheel >> lockable. Will I gain that much stability in crosswind takeoffs and landings >> if the tailwheel will lock? I am not that concerned about having the wheel >> be full castering for ground maneuvering when I need to put the Piet in a >> hangar. >> > >> >Rick Schreiber >> >----- Original Message ----- >> >From: shad bell >> >To: pietenpol-list(at)matronics.com >> >Sent: 11/15/2008 5:13:05 PM >> >Subject: Re: Pietenpol-List: Lockable Tailwheels >> > >> > >> > >> >We flew NX92GB for the 1st 2 years with a fixed non steerable t/w. Taxi >> was a "think 5 min ahead" type of ordeal. It was fine on grass, but could >> get dicy on a paved runway with a crosswind. All was well untill that >> transition time where the rudder became inefective, but you still had >> forward speed, and it would weather vane. The brakes are not really strong >> so a blast of power and rudder was required to keep it on the runway. The >> 1st time I experianced it I had to think quickly, after flying champs I was >> used to the tailwheel traction to steer in that situation. I would recomend >> at least a steerable T/W for your piet, unless you plan on never landing on >> hard surfaced runways. >> > >> >Shad >> > >> > >> > >> >> >> >> >> >> ________________________________________________________________________________
Date: Nov 15, 2008
I've got friends in central Fl who make their living teaching tailwheels: http://www.flytailwheel.com/ They used to have an L-3 (Champ), but I don't know any more. He's still flying the J-3. Jim -----Original Message----- >From: Jeff Boatright <jboatri(at)emory.edu> >Sent: Nov 15, 2008 8:15 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: build vs. buy? > > >That's right, and that's how I found mine who is willing, and has >been, instructing me, in my Piet! > > >> >>Tom, If your an EAA member give them a call and they can give you a >>full list of all instructors that instruct in tail wheel aircraft >>and where their at. There is also a web site anyone can go to that >>EAA has listed all of that info also but I don't remember what it >>is. If you need it just let me know and I'll call the EAA and find >>out. >>Gene > > ________________________________________________________________________________
Subject: condition insp. vs. annual insp.
Date: Nov 15, 2008
>From a guy who I greatly respect... A&P=2C Tech Counselor=2C builder=2C pil ot=2C and guru Jeff Scott:> Saying that they are pretty much the same about sums it up. Most mechanics > treat them the same=2C although technically s peaking an annual inspection is > an inspection for airworthiness while a c ondition inspection for an > Experimental is an inspection for serviceabili ty.> > Amateur built planes are not signed off as airworthy=2C but instead are > signed off as serviceable. It's actually a fine nit to pick as servic eable > and airworthy typically mean the same thing=2C but it doesn't put t he > professional mechanic in the position of making an airworthiness state ment > about your go fast special built with lumber from the local yard=2C gorilla > glue=2C Radio Shack electronics and hardware store bolts and plum bing=2C then > built from plans that were only used as a suggestive guideli ne. By stating > in the logs that upon inspection the airframe and engine a re serviceable=2C > the mechanic is not stating that those parts should be in the air or are > airworthy. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX ________________________________________________________________________________
Date: Nov 15, 2008
Brain fart - They moved their operation to Griffin, Ga this year. Jim -----Original Message----- >From: Jim Ash <ashcan(at)earthlink.net> >Sent: Nov 15, 2008 8:23 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: build vs. buy? > > >I've got friends in central Fl who make their living teaching tailwheels: > >http://www.flytailwheel.com/ > >They used to have an L-3 (Champ), but I don't know any more. He's still flying the J-3. > >Jim > >-----Original Message----- >>From: Jeff Boatright <jboatri(at)emory.edu> >>Sent: Nov 15, 2008 8:15 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Re: build vs. buy? >> >> >>That's right, and that's how I found mine who is willing, and has >>been, instructing me, in my Piet! >> >> >>> >>>Tom, If your an EAA member give them a call and they can give you a >>>full list of all instructors that instruct in tail wheel aircraft >>>and where their at. There is also a web site anyone can go to that >>>EAA has listed all of that info also but I don't remember what it >>>is. If you need it just let me know and I'll call the EAA and find >>>out. >>>Gene >> >> >> >> >> > > ________________________________________________________________________________
Date: Nov 16, 2008
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade T1 Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for 19+ years worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, Wiki and PhotoShare. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 16, 2008
Subject: Machine gun plans
I've had no success in reaching the gentleman in Kansas City who reportedly has a booklet or set of instructions for making the propane machine gun as per the kcdawnpatrol website. If anyone has these instructions and is finished with them, I'd be happy to buy them. Thanks, Dick Carden ________________________________________________________________________________
Date: Nov 16, 2008
You are correct, Lloyd. SNJ's and AT-6's had true locking tailwheels that, once locked, were unlocked by pushing the stick full forward. I believe the P-51 had the same arrangement. I believe DC-3's also had a tailwheel that could be locked straight ahead for takeoff and landing, then unlocked to facilitate low speed ground handling. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Lloyd Smith Sent: Saturday, November 15, 2008 7:40 PM Subject: Re: Pietenpol-List: Lockable Tailwheels I think this clarifies some confusion, because there were aircraft that had true "locking tailwheels" that locked in the straight forward position when the stick was held in a certain position (something makes me think full forward). Anyone with high horse power tailwheel time can probably clarify this. Your style of "locking tailwheel" can be forced out of it's detent by a particularly strong gust, just the same as pushing sideways on the tail in order to get it to swivel into position to push into the hangar. On Sat, Nov 15, 2008 at 7:23 PM, Jim Ash wrote: For clarification's sake, my Scott tailwheel is called a locking tailwheel. By that definition, there is an additional moving mechanism between the wheel and the bellcrank. The 'locked' state means that this mechanism is engaged and locks the bellcrank to the wheel, becoming a steerable tailwheel. The 'unlocked' position disengages the bellcrank from the wheel and allows it to caster a full 360 degrees. 'Full 360 degrees' is actually kind of a lie. If the tailwheel is castered around to the straight rear positon, it will automatically lock again. This is how to get it to lock. To unlock it requires side pressure to 'break it loose'. Sometimes snapping the pedals quickly (with the wheel on the ground) will unlock it also. I suspect there's a littel ball-and-sprint detent mechanism inside it. Locked, by this definition does not imply 'locked straight forward' so much as 'locked to the bellcrank'. Is this everybody else's understanding? Jim Ash -----Original Message----- >From: Richard Schreiber <lmforge(at)earthlink.net> >Sent: Nov 15, 2008 6:30 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Lockable Tailwheels > >I have only had 1 landing in a tailwheel aircraft, a Luscomb about a month ago. Due to my inexperience in tailwheel landings what I was wondering (or maybe not understanding) is this. I plan on installing a steerable tailwheel. Do I need to have or is it desirable to have the tailwheel lockable. Will I gain that much stability in crosswind takeoffs and landings if the tailwheel will lock? I am not that concerned about having the wheel be full castering for ground maneuvering when I need to put the Piet in a hangar. > >Rick Schreiber >----- Original Message ----- >From: shad bell >To: pietenpol-list(at)matronics.com >Sent: 11/15/2008 5:13:05 PM >Subject: Re: Pietenpol-List: Lockable Tailwheels > > >We flew NX92GB for the 1st 2 years with a fixed non steerable t/w. Taxi was a "think 5 min ahead" type of ordeal. It was fine on grass, but could get dicy on a paved runway with a crosswind. All was well untill that transition time where the rudder became inefective, but you still had forward speed, and it would weather vane. The brakes are not really strong so a blast of power and rudder was required to keep it on the runway. The 1st time I experianced it I had to think quickly, after flying champs I was used to the tailwheel traction to steer in that situation. I would recomend at least a steerable T/W for your piet, unless you plan on never landing on hard surfaced runways. > >Shad > > ________________________________________________________________________________
Date: Nov 16, 2008
Subject: No nails in spars
Anyone flying a Piet. that has no nails on the vertical rib supports to the spars?- The plan calls for them, but I know we have omitted other shown nails, (gussets) so why not these? ________________________________________________________________________________
Subject: lockable tailwheels
Date: Nov 16, 2008
thanks to everyone who responded about lockable tailwheels. I finally understand the differences. I plan on building my own (with steering) similar to what Don Emch and Greg Cardinal/Dale Johnson have done. Rick Schreiber Valaparaiso IN Richard Schreiber lmforge(at)earthlink.net ________________________________________________________________________________
Subject: stall speeds
Date: Nov 16, 2008
Howdy=2C Pietenpolers- In preparation for experimenting with vortex generators on the wings and ho rizontal stabilizer of 41CC (close your ears=2C purists!)=2C I went up this afternoon to run a stall se ries to get a rough idea of what the stall speeds are for my airplane. It was a cool afternoon with a light breeze=2C just me aboard and half a tank of fuel. That's as scientific as I'm going to get up to this p oint. I took the airplane up to about 2500 ft. (climbed like a rocket in the cool air) and did stalls power -off and power-on. The pitot gets a little crazy during power-on stalls due to the extreme angle and the propwash=2C so the airspeed needle jumps around quite a bit and I'm sure the readings aren't very accur ate=2C but I'll get relative numbers "before and after" anyway. Power-off stalls happen at 37-38 MPH and power-on happen at about 32-34 ind icated. The airplane has to be stalled briskly or it will just go nose-high and mush without muc h of a break at the stall. The nose will then bob up and down in and out of stall. Bringing the nose up crisply and quickly will bring it to a more noticeable stall. Rudders are required to keep the nose straight. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 16, 2008
Oscar, P. F. Beck has vortex generators on his Corvair Piet. He told me they reduced the stall enough that he thought they were worthwhile, I don't remember the numbers. Skip ----- Original Message ----- From: Oscar Zuniga Sent: 11/16/2008 9:01:09 PM Subject: Pietenpol-List: stall speeds Howdy, Pietenpolers- In preparation for experimenting with vortex generators on the wings and horizontal stabilizer of 41CC (close your ears, purists!), I went up this afternoon to run a stall series to get a rough idea of what the stall speeds are for my airplane. It was a cool afternoon with a light breeze, just me aboard and half a tank of fuel. That's as scientific as I'm going to get up to this point. I took the airplane up to about 2500 ft. (climbed like a rocket in the cool air) and did stalls power-off and power-on. The pitot gets a little crazy during power-on stalls due to the extreme angle and the propwash, so the airspeed needle jumps around quite a bit and I'm sure the readings aren't very accurate, but I'll get relative numbers "before and after" anyway. Power-off stalls happen at 37-38 MPH and power-on happen at about 32-34 indicated. The airplane has to be stalled briskly or it will just go nose-high and mush without much of a break at the stall. The nose will then bob up and down in and out of stall. Bringing the nose up crisply and quickly will bring it to a more noticeable stall. Rudders are required to keep the nose straight. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 16, 2008
Subject: Re: Machine gun plans
Richard Carden wrote: > > > I've had no success in reaching the gentleman in Kansas City who > reportedly has a booklet or set of instructions for making the propane > machine gun as per the kcdawnpatrol website. If anyone has these > instructions and is finished with them, I'd be happy to buy them. > Thanks, Dick Carden Richard and the group, I am also looking for the propane machine gun plans. I didn't want to re-invent the wheel trying to come up with one for my airplane. Please let me know what you find. Thanks, Darrel Jones, Pfeifer Sport NX154JP Sonoma, CA ________________________________________________________________________________
Subject: Re: No nails in spars
Date: Nov 16, 2008
Michael, The ribs on NX18235 are attached to the spar with T-88, not nails. I think this far more common than nailing the ribs to the spars. Greg Cardinal ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Sunday, November 16, 2008 5:12 PM Subject: Pietenpol-List: No nails in spars Anyone flying a Piet. that has no nails on the vertical rib supports to the spars? The plan calls for them, but I know we have omitted other shown nails, (gussets) so why not these? 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: elevator trim
Date: Nov 16, 2008
I took a few pictures of my elevator trim system and put them up on a webpa ge today=2C at http://www.flysquirrel.net/piets/trim.htmlOscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 16, 2008
Subject: Re: stall speeds
Oscar, We, too, plan to install VGs. Did you make yours, or buy 'em? Our power-off stall with two on board and 12 gal in the fuselage tank is 38-40 mph. Don't know what the power-on stall is - I keep my eyes closed for those! =-O There is a definite break with either type of stall, no need to bring the nose up crisply. Heavy right wing drop, very consistent. I put both those down to the aluminum wrap used for the leading edge (rather than the plywood skin called for in the plans). Really a bad modifications - gives a very lumpy leading edge. One of the few mistakes the original builder made, IMO. Jeff >Howdy, Pietenpolers- >... > >Power-off stalls happen at 37-38 MPH and power-on happen at about >32-34 indicated. The airplane >has to be stalled briskly or it will just go nose-high and mush >without much of a break at the stall. >The nose will then bob up and down in and out of stall. Bringing >the nose up crisply and quickly will >bring it to a more noticeable stall. Rudders are required to keep >the nose straight. > >Oscar Zuniga >Air Camper NX41CC >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 16, 2008
Try this; http://www.kcdawnpatrol.org/machine-gun.htm Clif > I am also looking for the propane machine gun plans. I didn't want to > re-invent the wheel trying to come up with one for my airplane. Please > let me know what you find. > > Thanks, > Darrel Jones, ________________________________________________________________________________
Subject: vortex generators
Date: Nov 17, 2008
My VGs are Landshorter's premolded polycarbonate ones, available from my friends Joa Harrison and his wife, at http://www.landshorter.com If you want to home-brew your own, Jack Hart's website has good details on fabrication and installation as he made them for his Kolb Firefly. The photo and narrative sequence begins here: http://www.thirdshift.com/jack/firefly/firefly18.html Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Update & Alert: Continental A-80 Engine to be sold
Date: Nov 17, 2008
I received an e-mail this weekend from a friend advising an A&P had looked at my video and my engine has two connecting rods (bottoms can be seen with oil holes facing the wrong way) and there are odd rocker arms... (one of t he reasons I wanted to be as up-front on showing the pictures and video... glad this was spotted before I place this up for sale or donate to an aviat ion museum as a static piece never to be flown again. I recall seeing insi de the engine case 3-1941 and I suspect this engine ---or at least the case --- may have been in a trainer during WW2. I can state that when we opened the packaged rocker arms=2C we called AEA i n Dallas (where we bought them) and asked them why the rocker arms didn't a ll look alike. They told us that rocker arms for the "A" series engines are available in several styles (old and new) and that they are interchangeabl e. Don't know if this is "kosher" but I've heard from other sources that ro cker arms (and other parts like brand-new camshafts) are getting harder and harder to find these days... There may be some validity to this=2C but I a m no expert on the subject and I advise being skeptical. They might all nee d to be matched? This being said=2C this engine "project" has a lot of really good parts. I' m wondering if I should disassemble it and sell off the parts? Any suggesti ons! I simply don't want the liability if some stranger buys this=2C stabs it on an airplane=2C crashes and lawyers start showing up on my front door. My o ther concern is if someone I don't know (as in a scoundrel) buys this and r esells it on Ebay as an airworthy=2C ready to stab engine. (My old "Worlds Fastest" Cherokee was sold in the 1990s to a great guy who moved to Florida=2C a hurricane came in=2C flooded the Cherokee up to and i nside the cockpit=2C inside the wing-roots and tailcone. AIG "totaled" the Cherokee=2C sold it." Wentwurth (misspelled on purpose) bought it=2C sold i t again and the Cherokee is flying again=2C despite having been exposed to salt water and sitting in a humid Florida environment for 5 months until AI G could settle the claim. The salt content was so evident=2C it changed the color of the carpet. It looked like th salt had "wicked" up pretty darned high. I found the Cherokee on Ebay being advertised basically as "pristine " "worlds fastest Cherokee" not a "rust dog.") I for one don't think that i s very reputable and thus my reasoning for trying to be as "communicative" about my A-80 engine. One other observation by the mechanic who saw my video... the rings on a Ce rmanil engine are different than rings on a regular chrome (and I believe a regular steel jug.) I recall when we bought the rings for this engine=2C w e were assured they were the right rings for the nickle-bore process. That' s why I took pictures of the rings being placed in the slots=2C and trying to show the numbers on the rings (top ring=2C 2nd down=2C 3rd down 4th down =2C 5th down=2C) In fact=2C my logbook reflects this entry=2C "TOP RING=2C 22206. 2nd 3555A=2C 3rd 35551=2C 4th 3595=2C 5th Ring 3595." The top ring (if memory serves me correct=2C and please understand I have a hard time re membering where I put my car keys on many days) is the "oddball ring" and I think has a higher molybdenum content in it. I recall their saying someth ing along the lines of "chrome rings won't work in a nickle bore cylinder" thus our being so demanding when we were buying the right piston rings. The logbook also has entries concerning the part numbers of the oil pump kit =2C #21343=2C #3562=2C #21160=2C #2456. One thing I like about nickle over the chrome process is I've had step-wear problems in previous engines with chrome jugs. Also=2C nickle holds oil re siduals on the surface better than chrome. I flew a Cherokee years ago that sprung a leak=2C dumping all the oil overboard (call me Capt. Exxon Vladez ) and that engine had the Cermnil jugs. Teardown showed the crankshaft was shot=2C but the jugs looked pretty darned good. We sent them back to ECI=2C they did a simply refurb (installed valves etc) and the jugs went back on the 0-320 Lycoming. Chrome and Iron cylinders may have held up just fine (w ithout oil) but I was so impressed that I was able to milk the engine to a runway=2C I became a big fan of nickel lined cylinders... Last question=2C I think I'd like to keep the logbook and simply give the s ales-receipts and yellow tags to the buyer. The logbook is dated Oct. 21 =2C 2005 (my birthday) and for nothing more than sentimentality=2C it has s ome significance for me. Observations=2C comments and indulgence are very much appreciated. I guess this is like that TV show=2C DEAL or NO DEAL... Should I DISSEMBLE or NO DISSEMBLE? and then sale? _________________________________________________________________ Stay up to date on your PC=2C the Web=2C and your mobile phone with Windows Live ________________________________________________________________________________
Date: Nov 17, 2008
I'm not seeing the "two connecting rods" bottoms facing the wrong way... Ju st wanted to clear this up. I must be jinxed in more ways than one.... AGGG H. From: n900ml(at)hotmail.com Subject: Pietenpol-List: Update & Alert: Continental A-80 Engine to be sold Date: Mon=2C 17 Nov 2008 09:00:09 -0600 I received an e-mail this weekend from a friend advising an A&P had looked at my video and my engine has two connecting rods (bottoms can be seen with oil holes facing the wrong way) and there are odd rocker arms... (one of t he reasons I wanted to be as up-front on showing the pictures and video... glad this was spotted before I place this up for sale or donate to an aviat ion museum as a static piece never to be flown again. I recall seeing insi de the engine case 3-1941 and I suspect this engine ---or at least the case --- may have been in a trainer during WW2. I can state that when we opened the packaged rocker arms=2C we called AEA i n Dallas (where we bought them) and asked them why the rocker arms didn't a ll look alike. They told us that rocker arms for the "A" series engines are available in several styles (old and new) and that they are interchangeabl e. Don't know if this is "kosher" but I've heard from other sources that ro cker arms (and other parts like brand-new camshafts) are getting harder and harder to find these days... There may be some validity to this=2C but I a m no expert on the subject and I advise being skeptical. They might all nee d to be matched? This being said=2C this engine "project" has a lot of really good parts. I' m wondering if I should disassemble it and sell off the parts? Any suggesti ons! I simply don't want the liability if some stranger buys this=2C stabs it on an airplane=2C crashes and lawyers start showing up on my front door. My o ther concern is if someone I don't know (as in a scoundrel) buys this and r esells it on Ebay as an airworthy=2C ready to stab engine. (My old "Worlds Fastest" Cherokee was sold in the 1990s to a great guy who moved to Florida=2C a hurricane came in=2C flooded the Cherokee up to and i nside the cockpit=2C inside the wing-roots and tailcone. AIG "totaled" the Cherokee=2C sold it." Wentwurth (misspelled on purpose) bought it=2C sold i t again and the Cherokee is flying again=2C despite having been exposed to salt water and sitting in a humid Florida environment for 5 months until AI G could settle the claim. The salt content was so evident=2C it changed the color of the carpet. It looked like th salt had "wicked" up pretty darned high. I found the Cherokee on Ebay being advertised basically as "pristine " "worlds fastest Cherokee" not a "rust dog.") I for one don't think that i s very reputable and thus my reasoning for trying to be as "communicative" about my A-80 engine. One other observation by the mechanic who saw my video... the rings on a Ce rmanil engine are different than rings on a regular chrome (and I believe a regular steel jug.) I recall when we bought the rings for this engine=2C w e were assured they were the right rings for the nickle-bore process. That' s why I took pictures of the rings being placed in the slots=2C and trying to show the numbers on the rings (top ring=2C 2nd down=2C 3rd down 4th down =2C 5th down=2C) In fact=2C my logbook reflects this entry=2C "TOP RING=2C 22206. 2nd 3555A=2C 3rd 35551=2C 4th 3595=2C 5th Ring 3595." The top ring (if memory serves me correct=2C and please understand I have a hard time re membering where I put my car keys on many days) is the "oddball ring" and I think has a higher molybdenum content in it. I recall their saying someth ing along the lines of "chrome rings won't work in a nickle bore cylinder" thus our being so demanding when we were buying the right piston rings. The logbook also has entries concerning the part numbers of the oil pump kit =2C #21343=2C #3562=2C #21160=2C #2456. One thing I like about nickle over the chrome process is I've had step-wear problems in previous engines with chrome jugs. Also=2C nickle holds oil re siduals on the surface better than chrome. I flew a Cherokee years ago that sprung a leak=2C dumping all the oil overboard (call me Capt. Exxon Vladez ) and that engine had the Cermnil jugs. Teardown showed the crankshaft was shot=2C but the jugs looked pretty darned good. We sent them back to ECI=2C they did a simply refurb (installed valves etc) and the jugs went back on the 0-320 Lycoming. Chrome and Iron cylinders may have held up just fine (w ithout oil) but I was so impressed that I was able to milk the engine to a runway=2C I became a big fan of nickel lined cylinders... Last question=2C I think I'd like to keep the logbook and simply give the s ales-receipts and yellow tags to the buyer. The logbook is dated Oct. 21 =2C 2005 (my birthday) and for nothing more than sentimentality=2C it has s ome significance for me. Observations=2C comments and indulgence are very much appreciated. I guess this is like that TV show=2C DEAL or NO DEAL... Should I DISSEMBLE or NO DISSEMBLE? and then sale? Stay up to date on your PC=2C the Web=2C and your mobile phone with Windows Live <>Click here _________________________________________________________________ Windows Live Hotmail now works up to 70% faster. http://windowslive.com/Explore/Hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_fast er_112008 ________________________________________________________________________________
Date: Nov 17, 2008
A lot of my text is NOT showing up in my original post. For some reason=2C the text I placed in Bold or Italics or in a color other than BLACK doesn't make it through Mattronics and back to my e-mail=2C so if anyone needs cla rity on this=2C please send me an e-mail off the list and I can send the or iginal text direct to you=2C bypassing the list. Sorry for the error and 3 posts in ONE DAY... I hope to take some action on this be weeks-end and decide to part it out t o put on Ebay or not. From: n900ml(at)hotmail.com Subject: Pietenpol-List: Update & Alert: Continental A-80 Engine to be sold Date: Mon=2C 17 Nov 2008 09:00:09 -0600 I received an e-mail this weekend from a friend advising an A&P had looked at my video and my engine has two connecting rods (bottoms can be seen with oil holes facing the wrong way) and there are odd rocker arms... (one of t he reasons I wanted to be as up-front on showing the pictures and video... glad this was spotted before I place this up for sale or donate to an aviat ion museum as a static piece never to be flown again. I recall seeing insi de the engine case 3-1941 and I suspect this engine ---or at least the case --- may have been in a trainer during WW2. I can state that when we opened the packaged rocker arms=2C we called AEA i n Dallas (where we bought them) and asked them why the rocker arms didn't a ll look alike. They told us that rocker arms for the "A" series engines are available in several styles (old and new) and that they are interchangeabl e. Don't know if this is "kosher" but I've heard from other sources that ro cker arms (and other parts like brand-new camshafts) are getting harder and harder to find these days... There may be some validity to this=2C but I a m no expert on the subject and I advise being skeptical. They might all nee d to be matched? This being said=2C this engine "project" has a lot of really good parts. I' m wondering if I should disassemble it and sell off the parts? Any suggesti ons! I simply don't want the liability if some stranger buys this=2C stabs it on an airplane=2C crashes and lawyers start showing up on my front door. My o ther concern is if someone I don't know (as in a scoundrel) buys this and r esells it on Ebay as an airworthy=2C ready to stab engine. (My old "Worlds Fastest" Cherokee was sold in the 1990s to a great guy who moved to Florida=2C a hurricane came in=2C flooded the Cherokee up to and i nside the cockpit=2C inside the wing-roots and tailcone. AIG "totaled" the Cherokee=2C sold it." Wentwurth (misspelled on purpose) bought it=2C sold i t again and the Cherokee is flying again=2C despite having been exposed to salt water and sitting in a humid Florida environment for 5 months until AI G could settle the claim. The salt content was so evident=2C it changed the color of the carpet. It looked like th salt had "wicked" up pretty darned high. I found the Cherokee on Ebay being advertised basically as "pristine " "worlds fastest Cherokee" not a "rust dog.") I for one don't think that i s very reputable and thus my reasoning for trying to be as "communicative" about my A-80 engine. One other observation by the mechanic who saw my video... the rings on a Ce rmanil engine are different than rings on a regular chrome (and I believe a regular steel jug.) I recall when we bought the rings for this engine=2C w e were assured they were the right rings for the nickle-bore process. That' s why I took pictures of the rings being placed in the slots=2C and trying to show the numbers on the rings (top ring=2C 2nd down=2C 3rd down 4th down =2C 5th down=2C) In fact=2C my logbook reflects this entry=2C "TOP RING=2C 22206. 2nd 3555A=2C 3rd 35551=2C 4th 3595=2C 5th Ring 3595." The top ring (if memory serves me correct=2C and please understand I have a hard time re membering where I put my car keys on many days) is the "oddball ring" and I think has a higher molybdenum content in it. I recall their saying someth ing along the lines of "chrome rings won't work in a nickle bore cylinder" thus our being so demanding when we were buying the right piston rings. The logbook also has entries concerning the part numbers of the oil pump kit =2C #21343=2C #3562=2C #21160=2C #2456. One thing I like about nickle over the chrome process is I've had step-wear problems in previous engines with chrome jugs. Also=2C nickle holds oil re siduals on the surface better than chrome. I flew a Cherokee years ago that sprung a leak=2C dumping all the oil overboard (call me Capt. Exxon Vladez ) and that engine had the Cermnil jugs. Teardown showed the crankshaft was shot=2C but the jugs looked pretty darned good. We sent them back to ECI=2C they did a simply refurb (installed valves etc) and the jugs went back on the 0-320 Lycoming. Chrome and Iron cylinders may have held up just fine (w ithout oil) but I was so impressed that I was able to milk the engine to a runway=2C I became a big fan of nickel lined cylinders... Last question=2C I think I'd like to keep the logbook and simply give the s ales-receipts and yellow tags to the buyer. The logbook is dated Oct. 21 =2C 2005 (my birthday) and for nothing more than sentimentality=2C it has s ome significance for me. Observations=2C comments and indulgence are very much appreciated. I guess this is like that TV show=2C DEAL or NO DEAL... Should I DISSEMBLE or NO DISSEMBLE? and then sale? Stay up to date on your PC=2C the Web=2C and your mobile phone with Windows Live <>Click here _________________________________________________________________ See how Windows=AE connects the people=2C information=2C and fun that are p art of your life ________________________________________________________________________________
Date: Nov 17, 2008
Subject: Re: vortex generators
Oscar, Are those VGs on your Piet? Can you tell us how they changed its flight characteristics? Thanks, Steve Ruse Quoting Oscar Zuniga : > > > My VGs are Landshorter's premolded polycarbonate ones, available > from my friends Joa Harrison and his wife, at > http://www.landshorter.com > > If you want to home-brew your own, Jack Hart's website has good > details on fabrication and installation > as he made them for his Kolb Firefly. The photo and narrative > sequence begins here: > http://www.thirdshift.com/jack/firefly/firefly18.html > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Nov 17, 2008
I have not yet installed the VGs on my airplane, Steve. I'm going to paint them this weekend, lay out the pattern on my wing, and maybe get them installed but won't have flight test info for another couple of weeks. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 17, 2008
I used no nails there. Only glue and clamps. Those clamps made from slices of PVC pipe that someone introduced years ago worked really great for this walt evans NX140DL ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Sunday, November 16, 2008 6:12 PM Subject: Pietenpol-List: No nails in spars Anyone flying a Piet. that has no nails on the vertical rib supports to the spars? The plan calls for them, but I know we have omitted other shown nails, (gussets) so why not these? 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 17, 2008
Thank you all. I planned on just using T-88, but I wanted to be sure omitting the nails was cool. ________________________________________________________________________________
Date: Nov 17, 2008
Subject: In case you did not notice...
I have been asking questions on wings/assembly. That's because I am 2 ribs short of having my full compliment made and I am moving into wing/CS assemb ly! I have all the spars made and am working on metal hardware and compress ion struts. I bet these last-2 ribs take me longer to do then all the oth ers. I can't believe I am almost done with them. What a great feeling of ac complishment.- Just some useless FYI. Now back to local programming... ________________________________________________________________________________
Date: Nov 17, 2008
Way to go Michael! I did my ribs as my first project. They were moved all over the house and garage for 4 years while I did other parts of the Piet. I thought back then that they were always in the way and I could never find a suitable place to store them. Boy was I wrong!!! Once they become a wing is when the space really gets gobbled up. Rick Schreiber In wintry NW Indiana with 14 inches of snow on the way. ----- Original Message ----- From: Michael Perez Sent: 11/17/2008 4:46:21 PM Subject: Pietenpol-List: In case you did not notice... I have been asking questions on wings/assembly. That's because I am 2 ribs short of having my full compliment made and I am moving into wing/CS assembly! I have all the spars made and am working on metal hardware and compression struts. I bet these last 2 ribs take me longer to do then all the others. I can't believe I am almost done with them. What a great feeling of accomplishment. Just some useless FYI. Now back to local programming... ________________________________________________________________________________
Date: Nov 17, 2008
Subject: Re: In case you did not notice...
That sounds great. I know I was excited to start my wings. This past weekend I hinged the aileron on my right wing. That makes that wing done other than the aileron horn and some sanding/varnishing! Then I have to do it all over again for the other wing. It should go faster though as I've made all the parts for the other wing as I've been going along. Get going and get that wing together, it's great to hear progress reports. Mike Groah Tulare CA Fuse done (for the most part), tail done, one wing almost done, center section nearly done, Lots left to do. (Christmas this year marks a year of work on the project) Michael Perez wrote: I have been asking questions on wings/assembly. That's because I am 2 ribs short of having my full compliment made and I am moving into wing/CS assembly! I have all the spars made and am working on metal hardware and compression struts. I bet these last 2 ribs take me longer to do then all the others. I can't believe I am almost done with them. What a great feeling of accomplishment. Just some useless FYI. Now back to local programming... ________________________________________________________________________________
Date: Nov 18, 2008
UmljaGFyZA0KDQpZb3UgaGF2ZSB0aGUgcGVyZmVjdCBzaG9wIGluIHdoaWNoIHRvIHdhdGNoIGl0 IHNub3cgd2hpbGUgeW91IGJ1aWxkDQoNCkpvaG4NCg0KUHMgSSBob3BlIHRvIGJlIHN0YXJ0aW5n IG15IHdpbmdzIGluIHRoZSBuZXh0IDIgd2Vla3MNCg0KDQpTZW50IGZyb20gbXkgVmVyaXpvbiBX aXJlbGVzcyBCbGFja0JlcnJ5DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAi UmljaGFyZCBTY2hyZWliZXIiIDxsbWZvcmdlQGVhcnRobGluay5uZXQ+DQoNCkRhdGU6IE1vbiwg MTcgTm92IDIwMDggMTY6NTc6MjYgDQpUbzogPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+ DQpTdWJqZWN0OiBSRTogUGlldGVucG9sLUxpc3Q6IEluIGNhc2UgeW91IGRpZCBub3Qgbm90aWNl Li4uDQoNCg0KV2F5IHRvIGdvIE1pY2hhZWwhIEkgZGlkIG15IHJpYnMgYXMgbXkgZmlyc3QgcHJv amVjdC4gVGhleSB3ZXJlIG1vdmVkIGFsbCBvdmVyIHRoZSBob3VzZSBhbmQgZ2FyYWdlIGZvciA0 IHllYXJzIHdoaWxlIEkgZGlkIG90aGVyIHBhcnRzIG9mIHRoZSBQaWV0LiBJIHRob3VnaHQgYmFj ayB0aGVuIHRoYXQgdGhleSB3ZXJlIGFsd2F5cyBpbiB0aGUgd2F5IGFuZCBJIGNvdWxkIG5ldmVy IGZpbmQgYSBzdWl0YWJsZSBwbGFjZSB0byBzdG9yZSB0aGVtLiANCg0KQm95IHdhcyBJIHdyb25n ISEhIE9uY2UgdGhleSBiZWNvbWUgYSB3aW5nIGlzIHdoZW4gdGhlIHNwYWNlIHJlYWxseSBnZXRz IGdvYmJsZWQgdXAuDQoNClJpY2sgU2NocmVpYmVyDQpJbiB3aW50cnkgTlcgSW5kaWFuYSB3aXRo IDE0IGluY2hlcyBvZiBzbm93IG9uIHRoZSB3YXkuDQoNCg0KLS0tLS0gT3JpZ2luYWwgTWVzc2Fn ZSAtLS0tLSANCkZyb206IE1pY2hhZWwgUGVyZXogDQpUbzogcGlldGVucG9sLWxpc3RAbWF0cm9u aWNzLmNvbQ0KU2VudDogMTEvMTcvMjAwOCA0OjQ2OjIxIFBNIA0KU3ViamVjdDogUGlldGVucG9s LUxpc3Q6IEluIGNhc2UgeW91IGRpZCBub3Qgbm90aWNlLi4uDQoNCg0KSSBoYXZlIGJlZW4gYXNr aW5nIHF1ZXN0aW9ucyBvbiB3aW5ncy9hc3NlbWJseS4gVGhhdCdzIGJlY2F1c2UgSSBhbSAyIHJp YnMgc2hvcnQgb2YgaGF2aW5nIG15IGZ1bGwgY29tcGxpbWVudCBtYWRlIGFuZCBJIGFtIG1vdmlu ZyBpbnRvIHdpbmcvQ1MgYXNzZW1ibHkhIEkgaGF2ZSBhbGwgdGhlIHNwYXJzIG1hZGUgYW5kIGFt IHdvcmtpbmcgb24gbWV0YWwgaGFyZHdhcmUgYW5kIGNvbXByZXNzaW9uIHN0cnV0cy4gSSBiZXQg dGhlc2UgbGFzdCAyIHJpYnMgdGFrZSBtZSBsb25nZXIgdG8gZG8gdGhlbiBhbGwgdGhlIG90aGVy cy4gSSBjYW4ndCBiZWxpZXZlIEkgYW0gYWxtb3N0IGRvbmUgd2l0aCB0aGVtLiBXaGF0IGEgZ3Jl YXQgZmVlbGluZyBvZiBhY2NvbXBsaXNobWVudC4gIEp1c3Qgc29tZSB1c2VsZXNzIEZZSS4gTm93 IGJhY2sgdG8gbG9jYWwgcHJvZ3JhbW1pbmcuLi4NCg0KDQoNCg= ________________________________________________________________________________
Date: Nov 17, 2008
I went to get the snow blower ready and found a couple of missing springs. I'm not tackling that drive with a shovel.......gee retired, no grass to cut and snowed in, Guess I'll have to spend even more time working on the Piet. Now that I have decided how I'll do the tailwheel, I've started fabricating that. The wood for the straight axle main gear is cut and planed, so that will be next. Rick Schreiber ----- Original Message ----- From: Sent: 11/17/2008 10:12:24 PM Subject: Re: Pietenpol-List: In case you did not notice... Richard You have the perfect shop in which to watch it snow while you build John Ps I hope to be starting my wings in the next 2 weeks Sent from my Verizon Wireless BlackBerry From: "Richard Schreiber" <lmforge(at)earthlink.net> Date: Mon, 17 Nov 2008 16:57:26 -0600 Subject: RE: Pietenpol-List: In case you did not notice... Way to go Michael! I did my ribs as my first project. They were moved all over the house and garage for 4 years while I did other parts of the Piet. I thought back then that they were always in the way and I could never find a suitable place to store them. Boy was I wrong!!! Once they become a wing is when the space really gets gobbled up. Rick Schreiber In wintry NW Indiana with 14 inches of snow on the way. ----- Original Message ----- From: Michael Perez Sent: 11/17/2008 4:46:21 PM Subject: Pietenpol-List: In case you did not notice... I have been asking questions on wings/assembly. That's because I am 2 ribs short of having my full compliment made and I am moving into wing/CS assembly! I have all the spars made and am working on metal hardware and compression struts. I bet these last 2 ribs take me longer to do then all the others. I can't believe I am almost done with them. What a great feeling of accomplishment. Just some useless FYI. Now back to local programming... ???~???,? g(???M4?G?q???z????.?'??y?J?i??X???lN?2??? ________________________________________________________________________________
Date: Nov 18, 2008
Subject: What Members Are Saying...
Dear Listers, November is the Annual Matronics List Fund Raiser. The Lists are supported solely through your generous Contributions during this time. Please make your Contribution today and pick up a really nice free gift at this same time: http://www.matronics.com/contribution Listers have been including some really nice comments regarding what the Lists mean to them along with their Contributions this year. I've included a few of them below. Please read them over and see if some perhaps echo your feelings as well. Thank you for your support this year! Matt Dralle Matronics Email List and Forum Administrator ------------------------------------------------------------------------------ Best bargain in the entire industry!! -Owen B Every year your lists are better, sure #1 in e-mail list in the world. -Gary G Thank you for an awesome site! -Ashley M Your lists are important to me and well worth paying for. -Calvin A Thank you for providing such and informative and ad free environment to learn by. -Myron H As always, a valuable and extremely useful resource. Stephen T As always, a great service. -Reade G Very much appreciate this site and the communications it has enabled between builders. -Larry M This service is worth every penny. -Robert S Great site! Thanks a ton for its functionality! -Peter B The RV-10 list feels like my community. -Dave S The lists are fantastic, a great source! -Jimmy Y I've learned a lot from the List. -Gabriel F A wonderful resource. -Gerald G Well done. -Richard N Years of good service. -William M Valuable service. -Keith H The site is quite helpful. -Jon M Very interesting List that I read form the beginning. -Alain L A well managed site. -Carl B Great service. -Svein Kare J Still the most useful program on the computer. -Fergus K Great contribution to my project! -Robert K Thanks for keeping a great list. -Dt G The List continues to provide excellent information. -Tony C This is a wonderful resource that has easily saved me a bunch on my build-time. -Ralph C Thank you for providing a great service. The Zenith builder's community would be in sad shape without the Zenith-List's. -Terrence P I really do get pleasure out of reading the List every day. -Bill V Great source of information. -Arthur V Thanks for a great service. Very enjoyable. -Louis B You know we all could not do without your support!! -James S Great resource! -Douglas D Thanks for the great service. -John B ________________________________________________________________________________
Subject: New Pictures on the web page
Date: Nov 18, 2008
I was cleaning up my computer so I could reformat the hard drive due to frustrating computer problems and came across some pictures Dan Helsper sent me way to long ago, sorry for loosing them Dan. Dan does some incredibly nice work. http://westcoastpiet.com/dan_helsper.htm Jeff Boatright has their plane flying again after the uhmm firm Navy like landing. Check out how good Jeff's plane looks now. http://westcoastpiet.com/wayne,_bob_anf_jeff.htm Arthur Mason from England sent me some pictures too. Arthur has been flying his Pietenpol in England for a long time and it still looks great. http://westcoastpiet.com/new_page_28.htm As long as were into project updates, I have been mounting the control horns on the tail. http://westcoastpiet.com/control_horns1.htm I am slowly working on a write-up on how I make the control horns for the webpage. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ________________________________________________________________________________
Date: Nov 18, 2008
Every time I see photos of Dan's metal fittings, I can't help wondering what color (or colour, for those of us up North, or across the pond) scheme he has planned for his Piet. But I don't want to know. I want it to be a surprise. Like waiting till your child is born to find out if it's a boy or a girl (or otherwise). And, after seeing the new pics of Jeff's plane after the make-over, I had to check to see that it was the same plane. What a difference a paint scheme (or hairstyle) can make. Thanks for posting the pics, Chris. Bill C. ________________________________________________________________________________
Date: Nov 18, 2008
Oh, in my last post I forgot to mention the great step-by-step photos Chris added for the building of his control horns. To all those out there that are afraid of the built-up control horns, you can see here that they don't take any special equipment to make. A vise, a hammer, a couple pieces of rod, and a bit of bar. Don't know if Chris was an experienced welder before starting to build his Piet, but he appears to be one now. So much nicer looking than the flat steel control horns (in my opinion, anyway). Well worth the extra effort, and I would imagine a very satisfying part of the project. Very nice work, Chris. Bill C. ________________________________________________________________________________
Date: Nov 18, 2008
Tom, The link was in the original message from Chris. But here it is again: <http://westcoastpiet.com/control_horns1.htm> http://westcoastpiet.com/control_horns1.htm ________________________________________________________________________________
Subject: A huge Thank You to Chris Tracy
Date: Nov 18, 2008
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <Michael.D.Cuy(at)nasa.gov>
Chris, I cannot tell you how many times I have sent the link to your photos of Pietenpols to others. Just a fantastic wealth of information you've compiled for us and I'm never surprised to learn a new way that builders have come up with to build the various parts of a Piet---totally creative and refreshing to see. Many others on the list maintain excellent builders logs, blogs, and web pages and I often times will refer questions to those other sites as well. What a talented a diverse group of guys in the Pietenpol community. Just fantastic people and most of them are nice even:) Mike C. ________________________________________________________________________________
Subject: nails in spars
Date: Nov 18, 2008
I recently was part of a Boeing Stearman rebuild. The ribs are not glued bu t MAY be nailed to the spars if you want. I put in a couple of those small brads into each spar just to keep them from moving during the covering proc ess. They weren't really needed since the ribs were a tight fit anyway. If you are going to use nails=2C don't do it until the drag and anti-drag wire s are in place and snug. That way you can move the ribs a half an inch or s o either way to keep them clear of the wires. That is the way it is done on the Stearman. The ribs do not need to be in the exact position that is sho wn on the plans unless it is one of the "key" ribs like the root=2C wing-ti p or aileron-end rib.Cheers=2C Jeff HillLead CoordinatorHawk One 817/706-81 54jeff2dogs(at)hotmail.com _________________________________________________________________ Windows Live Hotmail now works up to 70% faster. http://windowslive.com/Explore/Hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_fast er_112008 ________________________________________________________________________________
Date: Nov 18, 2008
Bill, Thanks for the kind words. The plane looks 100% better. I think it's stronger, too. Could not have been possible without the help of Mark, Mike, Ron, Sky, & Tom (the regulars at 2GA9). BTW, that prop is a Cloudcars 76x38 and is a great success. Climb rate hasn't been measured precisely yet, but at the point in the pattern where we used to be at 400' agl, we're now at 600', and where we used to be at 600', we're at 1000' !! No change in stop speed, but we're turning 2500 rpm in initial climb (on a C-75/85). Jeff PS: Hairstyle?? I used to have one of those... >And, after seeing the new pics of Jeff's plane after the make-over, >I had to check to see that it was the same plane. What a difference >a paint scheme (or hairstyle) can make. > ________________________________________________________________________________
Date: Nov 18, 2008
Subject: Nice Pics and other update info its the 2 for 1 email
day Jeff she sure looks different from last I saw her, nice job! I was on the builders site and noticed that the list may be a little short or in need of updating. Here is the link for anyone who has not added themselves or needs to update their information, I thought it may be a good time for everyone to stop ther, take a look , sign up or do some maintenance on their entries. _http://www.flyingwood.com/Directory.asp_ (http://www.flyingwood.com/Directory.asp) The work was done by someone else the least we can do is maker sure our own information is accurate. John **************Get the Moviefone Toolbar. Showtimes, theaters, movie news & p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
Subject: Pietenpol on Barnstormers
Date: Nov 18, 2008
http://www.barnstormers.com/listing.php?id=286220 I saw this project a couple of years ago. Good workmanship. Kapler hinges and Ken Perkins steel fittings according to the owner. ________________________________________________________________________________
Date: Nov 18, 2008
Wow, those are some nifty pictures on Chris Tracy's site! Dan Helsper's plane is going to be a beauty, with classic Air Camper lines and features and that 35 HP cabin heater up front! And the face-lift on the Boatright Piet is a day-and-night makeover all right! Chris' website is truly a treasure and a beginning Piet builder could do much worse than to spend an hour or two just browsing the photos on that website to glean details and information that pictures can tell much better than words. PS, this past Nov. 11, Veteran's Day, marked four years since 41CC went nose-over. What a joy it's been to fly the airplane after getting it repaired and back in the air though. You guys with snow on the ground, I feel sorry for you. We can still go out and fly anytime we want down here in sunny TX!!! Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 18, 2008
I have the machine gun plans. I printed them from the dawn patrol site. It is just one page of diagram. Go to their site and you will find what you want. In a message dated 11/16/2008 8:24:38 P.M. Central Standard Time, wd6bor(at)vom.com writes: --> Pietenpol-List message posted by: Darrel Jones Richard Carden wrote: > --> Pietenpol-List message posted by: Richard Carden > > > I've had no success in reaching the gentleman in Kansas City who > reportedly has a booklet or set of instructions for making the propane > machine gun as per the kcdawnpatrol website. If anyone has these > instructions and is finished with them, I'd be happy to buy them. > Thanks, Dick Carden Richard and the group, I am also looking for the propane machine gun plans. I didn't want to re-invent the wheel trying to come up with one for my airplane. Please let me know what you find. Thanks, Darrel Jones, Pfeifer Sport NX154JP Sonoma, CA **************Get the Moviefone Toolbar. Showtimes, theaters, movie news & p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
Subject: Re: New Pictures on the web page
Date: Nov 18, 2008
Thanks Bill. The control horns turned out to be a very satisfying project. These are the second set I made. The first ones were simply bent into facets, kind of like the stealth fighter. Thanks to Jim Markle for saying I could do better, these have the curved shape they should. And I must admit are way better looking then the first set. As for welding, I had never welded an inch prior to starting to building. I tried for 3 years to find someone to weld the fittings but gave up and bought a gas welder and the welding video and book from EAA. Did some reading on the web and went at it. I can't imagine building this plane and not being able to weld my own stuff. It comes in so handy. And to think I was afraid of welding when I started. What was I thinking. I like welding now so much so that I am thinking about buying a TIG welder. It's not worth the cost but it would be great fun to have. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Tuesday, November 18, 2008 9:06 AM Subject: RE: Pietenpol-List: New Pictures on the web page Oh, in my last post I forgot to mention the great step-by-step photos Chris added for the building of his control horns. To all those out there that are afraid of the built-up control horns, you can see here that they don't take any special equipment to make. A vise, a hammer, a couple pieces of rod, and a bit of bar. Don't know if Chris was an experienced welder before starting to build his Piet, but he appears to be one now. So much nicer looking than the flat steel control horns (in my opinion, anyway). Well worth the extra effort, and I would imagine a very satisfying part of the project. Very nice work, Chris. Bill C. ________________________________________________________________________________
Date: Nov 19, 2008
Chris' comments about the control horns are right on the mark. I think they represent one of the most satisfying parts of the entire project. When you first look at the design it's hard to imagine how easy they are to build and how strong they end up. That Bernhard Pietenpol fellow was pretty smart. I picked up a barely used Miller Syncrowave 250 tig machine recently and can hardly wait to try it out. The cost was next to nothing (it was basically a "gift" from a friend) and the more I find out about this thing the more I think it's WAY too much machine. But more is (in this case) better, right? In the last two weeks I finished up those 9" tall, half round cowling support pieces that sit on the longerons and last weekend made the pattern for the pilot's instrument panel cowling. Nice to be able to see the cowling taped down...that's a very satisfying achievement. Sure is encouraging to read all the notes about people flying and building then going out to my shop and actually making some sawdust myself! This group is great. Jim in Pryor OK ----- Original Message ----- From: catdesigns(at)att.net To: pietenpol-list(at)matronics.com Sent: Tuesday, November 18, 2008 11:04 PM Subject: Re: Pietenpol-List: New Pictures on the web page Thanks Bill. The control horns turned out to be a very satisfying project. These are the second set I made. The first ones were simply bent into facets, kind of like the stealth fighter. Thanks to Jim Markle for saying I could do better, these have the curved shape they should. And I must admit are way better looking then the first set. As for welding, I had never welded an inch prior to starting to building. I tried for 3 years to find someone to weld the fittings but gave up and bought a gas welder and the welding video and book from EAA. Did some reading on the web and went at it. I can't imagine building this plane and not being able to weld my own stuff. It comes in so handy. And to think I was afraid of welding when I started. What was I thinking. I like welding now so much so that I am thinking about buying a TIG welder. It's not worth the cost but it would be great fun to have. Chris Tracy Sacramento, Ca Website at http://www.WestCoastPiet.com ----- Original Message ----- From: Bill Church To: pietenpol-list(at)matronics.com Sent: Tuesday, November 18, 2008 9:06 AM Subject: RE: Pietenpol-List: New Pictures on the web page Oh, in my last post I forgot to mention the great step-by-step photos Chris added for the building of his control horns. To all those out there that are afraid of the built-up control horns, you can see here that they don't take any special equipment to make. A vise, a hammer, a couple pieces of rod, and a bit of bar. Don't know if Chris was an experienced welder before starting to build his Piet, but he appears to be one now. So much nicer looking than the flat steel control horns (in my opinion, anyway). Well worth the extra effort, and I would imagine a very satisfying part of the project. Very nice work, Chris. Bill C. href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 19, 2008
Subject: Engineering Feat
Fellow Pietsters: Building a Piet seems to be one small challenge after another. Solving each challenge is a thrill and really gives you a sense of accomplishment that will be, hopefully, capped by that moment when our creations leave the ground for the first time. The url that I am attaching has nothing to do with building an Air Camper BUT it sure explains the feeling of accomplishment. Enjoy! http://j-walkblog.com/index.php?/weblog/posts/moving_big_rocks Tom Stinemetze McPherson, KS ________________________________________________________________________________
Date: Nov 19, 2008
Subject: Re: Hi again to the list from Japan
Among other very interesting comments, Mark Stanley wrote: > You can't buy Stika spruce over here or 4130 so it also makes things a > little difficult. Those little luxuries need to be imported from the USA. Really fascinating to hear about Piets growing in such an unintuitive environment! Please keep us informed. As for 4130, why not follow the designer's lead? Mr. P. undoubtedly used whatever steel was at hand, especially in the first planes. (Surely someone talked to him about this issue and recorded the answer?) He probably used 1020, which forms nearly all the structure of Piper, Aeronca, Taylorcraft, etc., models pre-WWII. If you were building a steel-tube fuselage, you could safely use pretty much whatever ERW structural tubing is available at the nearest supplier. The fittings aren't any more fragile. There really isn't any need to go to the trouble and cost of importing 4130 unless Japanese regulations require it. Owen ________________________________________________________________________________
Date: Nov 19, 2008
Hey Oscar We may have some snow on the ground but I haven't cleaned any bugs off the prop lately. With the front cockpit covered and the long undies in place I,m getting some good take off performance and still enjoying the Piet. Dick N. in the skies over Mn and Wi. ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Tuesday, November 18, 2008 9:44 PM Subject: Pietenpol-List: New Pictures on the web page Wow, those are some nifty pictures on Chris Tracy's site! Dan Helsper's plane is going to be a beauty, with classic Air Camper lines and features and that 35 HP cabin heater up front! And the face-lift on the Boatright Piet is a day-and-night makeover all right! Chris' website is truly a treasure and a beginning Piet builder could do much worse than to spend an hour or two just browsing the photos on that website to glean details and information that pictures can tell much better than words. PS, this past Nov. 11, Veteran's Day, marked four years since 41CC went nose-over. What a joy it's been to fly the airplane after getting it repaired and back in the air though. You guys with snow on the ground, I feel sorry for you. We can still go out and fly anytime we want down here in sunny TX!!! Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 19, 2008
For machine gun instructions email this _address---nancystorey(at)aol.com-- _ (mailto:address---nancystorey(at)aol.com-- ) for instructions/$20 In a message dated 11/16/2008 7:28:04 A.M. Central Standard Time, flywrite(at)verizon.net writes: --> Pietenpol-List message posted by: Richard Carden I've had no success in reaching the gentleman in Kansas City who reportedly has a booklet or set of instructions for making the propane machine gun as per the kcdawnpatrol website. If anyone has these instructions and is finished with them, I'd be happy to buy them. Thanks, Dick Carden **************One site has it all. Your email accounts, your social networks, and the things you love. Try the new AOL.com %26icid=aolcom40vanity%26ncid=emlcntaolcom00000001) ________________________________________________________________________________
Subject: Piet on Barnstormers
Date: Nov 19, 2008
Yesterday I posted a link to a project for sale. I have pictures available for anybody who is interested. E-mail me off-list, I don't want to bog down the list with 8.5 mb of pictures. One picture is included. Greg ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Behind By 21% - Advertising May Be Needed...?
Dear Listers, The percentage of people making a Contribution to support the Lists this year is currently lagging behind last year by approximately 21%! I'm hoping that everyone is just waiting until the last minute to show their support... ;-) Please remember that it is solely your direct Contributions that keep these Lists up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I will likely have to start adding advertisements to offset the costs of running the Lists. But I *really* don't want to have to start doing that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2008
From: "Glenn Thomas" <glennthomas(at)flyingwood.com>
Subject: Re: Engineering Feat
A great example of somebody using his head and being resourceful. Great video. On Wed, Nov 19, 2008 at 11:08 AM, TOM STINEMETZE wrote: > *Fellow Pietsters:* > ** > *Building a Piet seems to be one small challenge after another. Solving > each challenge is a thrill and really gives you a sense of accomplishment > that will be, hopefully, capped by that moment when our creations leave the > ground for the first time. The url that I am attaching has nothing to do > with building an Air Camper BUT it sure explains the feeling of > accomplishment. Enjoy!* > *http://j-walkblog.com/index.php?/weblog/posts/moving_big_rocks*> > ** > *Tom Stinemetze* > *McPherson, KS* > > * > > -- Glenn Thomas Storrs, CT http://www.flyingwood.com ________________________________________________________________________________
Date: Nov 20, 2008
Hi Hans, Thanks for that info, I will check into it over here. Sounds like a better option than importing 4130. Useful info for repairs at work as well. Mark > 4130 is identical to: > > European standard steel DIN 25CrMo4, > > Or Japanes standard steel JIS SCM 430H > > BR > > Hans ________________________________________________________________________________
Date: Nov 20, 2008
Very cool, but I would like to know how he got the blocks to his house, how he got the blocks up on the stair case looking wood thing to roll it, how to get the blocks up on the stones to turn it, how to get the barn up on it's pivot, etc. Where there's a will... ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Spar cuts for dihedral
When looking at the 3 piece wing plan, the spars are butt joined to the win g spars. For those of you who have some dihedral, did you cut an angle on t he center section spars? (or the wing spars?) From my calculations, it woul d take a very small cut to get a inch or so at the tip. It looks to me that the wing attach fitting takes the loads, so having a gap between the spars should not be a problem. This leads me to my next question:- if a gap is OK, why not cut the C.S. spar at an angle back to the first rib? Leaving, of course, material around that first bolt that attaches the fitting to the spar. ________________________________________________________________________________
Date: Nov 20, 2008
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
That's what I did Mike, about 3/16th in at the top. Also don't forget to round out underneath the wing straps so the straps from the center section can tuck behind the wing strap when bolting together. Jack www.textors.com ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Re: Spar cuts for dihedral
Wow, Mike, You re reading my mind I was contemplating an angular spar butt cut to create the dihedral so that it was a non gap fit at spar to center section. I just wasn't certain at the slight off 90 degree cut and what that number should be, 90.25, 90.5 91 or 92 degrees to yield the desired 1 to 2 inch elevation at the wing tip. I would be interested in the recommended angle to achieve optimum dihedral from the performance and appearance perspectives. Nobody really wants a limp or floppy Piet.... well maybe some do, just not me if I can avoid it. John In a message dated 11/20/2008 11:47:58 A.M. Eastern Standard Time, speedbrake(at)sbcglobal.net writes: When looking at the 3 piece wing plan, the spars are butt joined to the wing spars. For those of you who have some dihedral, did you cut an angle on the center section spars? (or the wing spars?) From my calculations, it would take a very small cut to get a inch or so at the tip. It looks to me that the wing attach fitting takes the loads, so having a gap between the spars should not be a problem. This leads me to my next question: if a gap is OK, why not cut the C.S. spar at an angle back to the first rib? Leaving, of course, material around that first bolt that attaches the fitting to the spar. ======== (mip://0460be50/3D"http://www.matronics.com/contribution") ======== (mip://0460be50/3D"http://www.matronics.com/Navigator?Pietenpol-List") ======== (mip://0460be50/3D"http://forums.matronics.com") ======== **************One site has it all. Your email accounts, your social networks, and the things you love. Try the new AOL.com ew-dp%26icid=aolcom40vanity%26ncid=emlcntaolcom00000001) ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Center section hardware
Does anyone have their center section hardware made, but not installed? I a m looking for a total weight of one center section hardware set.- The lon g wing attach strap, the welded cabane fitting and the top and bottom piece s that makeup the pulley holder.- No bolts, or pulley and only one set fo r one end of one spar. The picture attached is what I am after. This is a p icture from Jack T's website. (I hope he does not mind.) ________________________________________________________________________________
Date: Nov 20, 2008
Of course, the quickest way would be to plop the parts on a scale and take the reading. But I would imagine that most of the completed fittings are mounted on spars. That being the case, it should be pretty simple to calculate: 4130 has a density of 0.283 pounds per cubic inch. A 12" x 12" piece of .080 steel has a volume of 12 x 12 x .08 = 11.52 cubic inches 11.52 x 0.283 = 3.260 pounds per square foot (or 0.0226 pounds per square inch, or 0.362 ounces per square inch.) Figure out the area (length x width) of the components (in square inches) and add them up, then multiply by the weight per square inch. Simple. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Thursday, November 20, 2008 12:24 PM Subject: Pietenpol-List: Center section hardware Does anyone have their center section hardware made, but not installed? I am looking for a total weight of one center section hardware set. The long wing attach strap, the welded cabane fitting and the top and bottom pieces that makeup the pulley holder. No bolts, or pulley and only one set for one end of one spar. The picture attached is what I am after. This is a picture from Jack T's website. (I hope he does not mind.) ________________________________________________________________________________
Date: Nov 20, 2008
Well, since you ask... For a 1" rise of the wingtips, the angle is 0.365 degrees For a 2" rise of the wingtips, the angle is 0.729 degrees I'm sure that information will be very helpful. Your angle setting for your miter saw (or hand saw) does adjust to three decimal places, doesn't it? _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com Sent: Thursday, November 20, 2008 12:18 PM Subject: Re: Pietenpol-List: Spar cuts for dihedral Wow, Mike, You re reading my mind I was contemplating an angular spar butt cut to create the dihedral so that it was a non gap fit at spar to center section. I just wasn't certain at the slight off 90 degree cut and what that number should be, 90.25, 90.5 91 or 92 degrees to yield the desired 1 to 2 inch elevation at the wing tip. I would be interested in the recommended angle to achieve optimum dihedral from the performance and appearance perspectives. Nobody really wants a limp or floppy Piet.... well maybe some do, just not me if I can avoid it. John ________________________________________________________________________________
Date: Nov 20, 2008
From: "Phillips, Jack" <Jack.Phillips(at)cardinalhealth.com>
I did that calculation while building mine, knowing that I wanted about =BD " dihedral (not enough to produce any "Dihedral Effect" on stability, but t o avoid the optical illusion you get with a one piece wing that the wing is actually drooping). Once I saw the tiny angular difference, I just said t o heck with it - the spars can handle the deformation required, and I can't cut an angle that small with any accuracy. In fact, you could easily put that amount of dihedral in a one-piece wing. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Bill Church Sent: Thursday, November 20, 2008 1:51 PM Subject: RE: Pietenpol-List: Spar cuts for dihedral Well, since you ask... For a 1" rise of the wingtips, the angle is 0.365 degrees For a 2" rise of the wingtips, the angle is 0.729 degrees I'm sure that information will be very helpful. Your angle setting for your miter saw (or hand saw) does adjust to three de cimal places, doesn't it? _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com Sent: Thursday, November 20, 2008 12:18 PM Subject: Re: Pietenpol-List: Spar cuts for dihedral Wow, Mike, You re reading my mind I was contemplating an angular spar butt cut to crea te the dihedral so that it was a non gap fit at spar to center section. I j ust wasn't certain at the slight off 90 degree cut and what that number sho uld be, 90.25, 90.5 91 or 92 degrees to yield the desired 1 to 2 inch eleva tion at the wing tip. I would be interested in the recommended angle to ac hieve optimum dihedral from the performance and appearance perspectives. Nobody really wants a limp or floppy Piet.... well maybe some do, just not me if I can avoid it. John _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Nov 20, 2008
Our center section and wing panels are connected by the equivalent of a pair of large hinges, with hinge halves in the vertical middle of the butt ribs of the center section and each wing panel, and with pins being AN5 bolts (AN5 is by memory, so don't count on that). If the lift struts are removed, the wing panels can be raised several feet at the tip or lowered all the way to the ground. When the panels and center section are in the same plane (no dihedral), the gap between the butt ribs of a wing and the center section is about an inch. >When looking at the 3 piece wing plan, the spars are butt joined to >the wing spars. For those of you who have some dihedral, did you cut >an angle on the center section spars? (or the wing spars?) From my >calculations, it would take a very small cut to get a inch or so at >the tip. It looks to me that the wing attach fitting takes the >loads, so having a gap between the spars should not be a problem. >This leads me to my next question: if a gap is OK, why not cut the >C.S. spar at an angle back to the first rib? Leaving, of course, >material around that first bolt that attaches the fitting to the >spar. -- _____________________________________________________________ Jeffrey H. Boatright, PhD Associate Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Nov 20, 2008
Mike, No, I don't mind...Total hardware weight as shown in the picture is 41.7 ounces. The rear straps and pulleys come to 23.25 ounces and the front set is 18.45 ounces. For a total of 2.6 pounds or 2 pounds 9.7 ounces. It does include paint, no bolts. Jack www.textors.com ________________________________________________________________________________
Date: Nov 20, 2008
>From what I figured, with a 5" tall spar, 1 degree of dihedral over the length of the 158.5" long spar would place the end of the spar 2.766" higher then horizontal. The cut on the spar to get that angle would be .174" in at the top. Of course, I may had loused up the math...haven't had to do this is quite some time. ________________________________________________________________________________
Date: Nov 20, 2008
Thank you Jack and thanks for the website picture use. What material and si ze pully is that? --- On Thu, 11/20/08, Jack T. Textor wrote: From: Jack T. Textor <jtextor(at)thepalmergroup.com> Subject: RE: Pietenpol-List: Center section hardware Date: Thursday, November 20, 2008, 3:07 PM Mike, No, I don=92t mind=85Total hardware weight as shown in the picture is 41.7 ounces.- The rear straps and pulleys come to 23.25 ounces and the front s et is 18.45 ounces.- For a total of 2.6 pounds or 2 pounds 9.7 ounces.- It does include paint, no bolts. Jack www.textors.com - ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Plexiglass Scratch Repair...
Dear Listers, During the fitting of the Plexiglass canopy on my RV-8, I managed to put some pretty disheartening scratches in the windscreen section. You can see from the pictures that they looked pretty bad. A call to Van's revealed that a replacement canopy would be $640 + $250 shipping to California! Ack. So what to do... A bit of surfing and I found this "Scratch Off" windshield repair kit for $35 on the Aircraft Spruce web site: http://www.aircraftspruce.com/catalog/cspages/scratchoff.php Frankly, it just seemed too good to be true. Nothing for $35 could be that "magic" I thought, but what did I have to lose at this point.... Well, the kit arrived yesterday and I decided to give it a try tonight. In a word: WOW! In about 2 hours the windscreen looked as good as new - no kidding - AS GOOD AS NEW! The pictures really don't do the repair justice. It looks better in person. There are basically two sponges in the kit with four decreasingly porous pastes. You just put some of the first paste on the sponge and buff it in with a drill at 1200 RPM or less. Then you wash everything down good including the sponge and windshield with warm water. Then you use the next finer paste and repeat the process. Etc, etc, until you've used the 4th paste that is kind of like car wax. Frankly, the scratches were gone after the first application of paste - I started at #2 based on the instructions and the "observed severity" of the scratch depth. So, the bottom line is, if you've got scuffs or mild scratches in your Plexiglass buy this repair kit. It works! Matt Dralle RV-8 #82880 ________________________________________________________________________________
From: "Scott Knowlton " <flyingscott_k(at)hotmail.com>
Date: Nov 21, 2008
Subject: Re: Plexiglass Scratch Repair...
We used crest toothpaste at our local gliding club when I was a kid. It acted as a very mild rubbing compound and worked great. I've used the techique on my Stinson with great results but suggest you try a test area first. Good luck. Scott Knowlton Slow piet builder -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Date: Fri, 21 Nov 2008 05:25:15 Subject: Pietenpol-List: Plexiglass Scratch Repair... Dear Listers, During the fitting of the Plexiglass canopy on my RV-8, I managed to put some pretty disheartening scratches in the windscreen section. You can see from the pictures that they looked pretty bad. A call to Van's revealed that a replacement canopy would be $640 + $250 shipping to California! Ack. So what to do... A bit of surfing and I found this "Scratch Off" windshield repair kit for $35 on the Aircraft Spruce web site: http://www.aircraftspruce.com/catalog/cspages/scratchoff.php Frankly, it just seemed too good to be true. Nothing for $35 could be that "magic" I thought, but what did I have to lose at this point.... Well, the kit arrived yesterday and I decided to give it a try tonight. In a word: WOW! In about 2 hours the windscreen looked as good as new - no kidding - AS GOOD AS NEW! The pictures really don't do the repair justice. It looks better in person. There are basically two sponges in the kit with four decreasingly porous pastes. You just put some of the first paste on the sponge and buff it in with a drill at 1200 RPM or less. Then you wash everything down good including the sponge and windshield with warm water. Then you use the next finer paste and repeat the process. Etc, etc, until you've used the 4th paste that is kind of like car wax. Frankly, the scratches were gone after the first application of paste - I started at #2 based on the instructions and the "observed severity" of the scratch depth. So, the bottom line is, if you've got scuffs or mild scratches in your Plexiglass buy this repair kit. It works! Matt Dralle RV-8 #82880 ________________________________________________________________________________
Date: Nov 21, 2008
Steve Erik Billing from Windsor Ont=2C We Have a 1946 Aeronca Champ( And I Have S tarted a Pietenpol Project ) and we use Mirror Glaze =2C=2Cfrom any Boat p lace costs between 5-7=2C8 bucks and Works GREAT !!!!!!! We've Used it f or 20 Odd Years Takes out Even Deep Scratches Very Well Please Pass the In fo On to Others Cheers Erik > From: flyingscott_k(at)hotmail.com> To: dralle(at)matronics.com=3B pietenpol-li st(at)matronics.com> Date: Fri=2C 21 Nov 2008 11:59:28 +0000> Subject: Re: Pie tenpol-List: Plexiglass Scratch Repair...> > --> Pietenpol-List message pos ted by: "Scott Knowlton " > > We used crest toot hpaste at our local gliding club when I was a kid. It acted as a very mild rubbing compound and worked great. I've used the techique on my Stinson wit h great results but suggest you try a test area first. Good luck. > > Scott Knowlton > Slow piet builder> > -----Original Message-----> From: Matt Dra lle > > Date: Fri=2C 21 Nov 2008 05:25:15 > To: > Subject: Pietenpol-List: Plexiglass Scratch Repa ir...> > > Dear Listers=2C> > During the fitting of the Plexiglass canopy o n my RV-8=2C I managed to put some pretty disheartening scratches in the wi ndscreen section. You can see from the pictures that they looked pretty ba d. A call to Van's revealed that a replacement canopy would be $640 + $250 shipping to California! Ack.> > So what to do... A bit of surfing and I found this "Scratch Off" windshield repair kit for $35 on the Aircraft Spru ce web site:> > http://www.aircraftspruce.com/catalog/cspages/scrat choff.php <http://www.aircraftspruce.com/catalog/cspages/scratchoff.php> > > Frankly=2C it just seemed too good to be true. Nothing for $35 could be that "magic" I thought=2C but what did I have to lose at this point....> > Well=2C the kit arrived yesterday and I decided to give it a try tonight. In a word: WOW! In about 2 hours the windscreen looked as good as new - no kidding - AS GOOD AS NEW! The pictures really don't do the repair justice . It looks better in person.> > There are basically two sponges in the kit with four decreasingly porous pastes. You just put some of the first past e on the sponge and buff it in with a drill at 1200 RPM or less. Then you wash everything down good including the sponge and windshield with warm wat er. Then you use the next finer paste and repeat the process. Etc=2C etc =2C until you've used the 4th paste that is kind of like car wax.> > Frankl y=2C the scratches were gone after the first application of paste - I start ed at #2 based on the instructions and the "observed severity" of the scrat ch depth.> > So=2C the bottom line is=2C if you've got scuffs or mild scrat ches in your Plexiglass buy this repair kit. It works!> > Matt Dralle> RV- =======================> > > _________________________________________________________________ ________________________________________________________________________________
Date: Nov 21, 2008
Mike, They are 2" Bell-Memphis, BM 24566-3, not sure about material. Got them at OSH for $10.00 a piece. Check eBay, they usually have quite few. Jack www.textors.com ________________________________________________________________________________
Subject: Plexi Scratches
Date: Nov 21, 2008
Another idea for removing small, very shallow and minor scratches is to use toothpaste and a soft rag -- I can't think of the brand name off hand but use one with a little grit in it. I've also used this over the years with model airplanes to remove scratches from canopies and clear parts. And your parts will have a nice, clean minty aroma when polished out! Fred B. La Crosse, WI ________________________________________________________________________________
Date: Nov 21, 2008
NX41CC is rigged with 3" of dihedral, measured from wing root to last rib outboard on the wing. Computationally, I guess it works out to about 1.02 degrees. As far as I know, there is no angle cut of the centersection spar... there is enough flex of the wing to allow 3" deflection at the wingtip with the spar butts cut square. The wing attach fittings are bolted up and then the threaded fork at the bottom of the lift struts is adjusted until the desired dihedral is obtained at the wingtip. I believe the Pietenpol manual mentions something along these lines or perhaps a bit less (1"?), but no angle cuts of the spar butts that I can recollect. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 21, 2008
What I am wondering is does the wing attach fittings/bolt take all the loads and if people are cutting the C.S. spars with a gap and no butt joint, why could we not cut that angle all the way back to the first rib on the C.S? ________________________________________________________________________________
Date: Nov 21, 2008
The wing attach fittings/bolt take all the loads on my Piet. There is no butt joint between the center section and the wing panel. I do not know if that is to plans. Plane has about 400 hrs on it. >What I am wondering is does the wing attach fittings/bolt take all >the loads and if people are cutting the C.S. spars with a gap and no >butt joint, why could we not cut that angle all the way back to the >first rib on the C.S? -- _____________________________________________________________ Jeffrey H. Boatright, PhD Associate Professor, Emory Eye Center, Atlanta, GA, USA Senior Editor, Molecular Vision, http://www.molvis.org/molvis mailto:jboatri(at)emory.edu ________________________________________________________________________________
Date: Nov 21, 2008
Subject: Rib/spar epoxy
What methods have you guys used to apply the epoxy on to the ribs/spars without wiping it off while sliding on the ribs? Maybe you position the rib first then epoxy around it? ________________________________________________________________________________
Subject: Plexi Glass Cleaner
Date: Nov 21, 2008
Steve Erik Billing from Windsor we have a 1946 Aeronca Champ and I have Started a Piet project =2C=2C=2C=2C=2C=2C we just Use Mirror Glaze that you can get at Any Boat Store usually about 5-8 $$$ work GREAT and Even Fills Deep S cratches May Want to Pass the Info On Cheers Erik Billing Windsor Ontario Canada _________________________________________________________________ ________________________________________________________________________________
Date: Nov 21, 2008
Mike, Slip all the ribs on; position them just to the side of where they will be. Apply your epoxy to the spar, and then slide the rib into position and clamp. I glued mine, some just nail theirs. Jack www.textors.com ________________________________________________________________________________
Date: Nov 21, 2008
Thanks Jack. That is exactly what I had planned to do, but hoped there was some better way that I just wasn't thinking of.- Your website, by the way , is very cool. I refer to the pictures from time to time to see how you di d things. --- On Fri, 11/21/08, Jack T. Textor wrote: From: Jack T. Textor <jtextor(at)thepalmergroup.com> Subject: RE: Pietenpol-List: Rib/spar epoxy Date: Friday, November 21, 2008, 11:43 AM Mike, Slip all the ribs on; position them just to the side of where they will be. - Apply your epoxy to the spar, and then slide the rib into position and clamp.- I glued mine, some just nail theirs. Jack www.textors.com - ________________________________________________________________________________
Subject: No bugs on the prop or windshield
Date: Nov 21, 2008
22 degrees on the ground this afternoon when I went out for a fresh afternoon flight. The Piet really performs nicely in the cool air. I flew the A-65 Piet, pulled the prop thru 8 times, 2 shots of prime and left the primer open and it started on the first pull. Dick N. ________________________________________________________________________________
Subject: Re: No bugs on the prop or windshield
Date: Nov 21, 2008
Dick, What is your dress code?? Do you have an engine heater?--Jim Lagowski ----- Original Message ----- From: Dick N. To: pietenpol-list(at)matronics.com Sent: Friday, November 21, 2008 6:42 PM Subject: Pietenpol-List: No bugs on the prop or windshield 22 degrees on the ground this afternoon when I went out for a fresh afternoon flight. The Piet really performs nicely in the cool air. I flew the A-65 Piet, pulled the prop thru 8 times, 2 shots of prime and left the primer open and it started on the first pull. Dick N. ------------------------------------------------------------------------- ----- Checked by AVG - http://www.avg.com 11/21/2008 9:37 AM ________________________________________________________________________________
Date: Nov 22, 2008
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2008
Dick, does your primer go straight to the cylinder or to the carb? I've been preheating the engine and it's starting right up but I've never heard of leaving the primer open while starting. Gene in beautiful but windy Tennessee ----- Original Message ----- From: Dick N. To: pietenpol-list(at)matronics.com Sent: Friday, November 21, 2008 5:42 PM Subject: Pietenpol-List: No bugs on the prop or windshield 22 degrees on the ground this afternoon when I went out for a fresh afternoon flight. The Piet really performs nicely in the cool air. I flew the A-65 Piet, pulled the prop thru 8 times, 2 shots of prime and left the primer open and it started on the first pull. Dick N. ------------------------------------------------------------------------- ----- Checked by AVG. 11/6/2008 7:58 AM ________________________________________________________________________________
Date: Nov 22, 2008
Gene and Jim My primer goes to each cyl. I had the type that went to the carb when I first built, but came close to having a big engine fire when I had a backfire while starting. Luckily there was a very close fire ext. There is a guy at my field who is locally regarded as a hand propping expert. Around here with a wide range of temps and no mixture control you have to adjust starting procedure to temp. In winter, I open the needle valve 1/2 turn. If I forget to close it in warmer times, it will flood the engine very easily. I hope Skip Gadd's shoulder has recovered from Brodhead this year. Leaving the primer open kind of functions like a choke. I don't pre heat the engine and it will start easily if I remember the rules. The biggest thing to remember is when flying, make throttle adjustments very slowly, even in the air. If you slam the throttle in too fast the engine might die. I was dressed with quilted long undies, jeans, rugby and sweatshirts. Thin nylon socks with insulated hunting socks over and thinsulate hunting boots. I didn't yesterday, but sometimes insert boot warmers, which are cheap and chemically release heat. On top a Carhart work jacket and a leather, fleece lined flying helmet and thinsulate cloves. I also remove my summer seat pad to lower down an extra couple of inches. It's a bit cold but I've decided it's better than dreaming about spring coming in 5 months. Happy flying Dick N. ----- Original Message ----- From: Gene & Tammy To: pietenpol-list(at)matronics.com Sent: Saturday, November 22, 2008 6:07 AM fast the enging might flood and die. Subject: Re: Pietenpol-List: No bugs on the prop or windshield Dick, does your primer go straight to the cylinder or to the carb? I've been preheating the engine and it's starting right up but I've never heard of leaving the primer open while starting. Gene in beautiful but windy Tennessee ----- Original Message ----- From: Dick N. To: pietenpol-list(at)matronics.com Sent: Friday, November 21, 2008 5:42 PM Subject: Pietenpol-List: No bugs on the prop or windshield 22 degrees on the ground this afternoon when I went out for a fresh afternoon flight. The Piet really performs nicely in the cool air. I flew the A-65 Piet, pulled the prop thru 8 times, 2 shots of prime and left the primer open and it started on the first pull. Dick N. href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- --- Version: AM ________________________________________________________________________________
Subject: some test flight numbers
Date: Nov 22, 2008
It was a cool, overcast day at the airport but perfectly flyable. I decided to retorque the prop bolts on my airplane (16 ft.-lbs on my wood Hegy) and then take it up to make sure everything was airworthy as well as jot down some performance numbers that I haven't bothered to make note of before. After the engine started warming up, I did a normal runup and then checked static RPM. A couple of different attempts got the same result: 2300 RPM on the tach. With the information I had gotten by checking my mechanical tach against a digital one, I know that this is an actual RPM of about 2100. Not sure if that is good or bad, but that's what my A65 turns in 55 degree weather at 1040' MSL with the Hegy prop. I made three takeoffs and full-stop landings to see what the indicated airspeeds were for when the tail came off the ground and when the airplane left the runway. Tail seems to start up at about 25 MPH indicated, and shortly after that the airplane is light on the mains and floats off at maybe 30-35 but it's accelerating pretty rapidly once it comes up on the mains so it's hard to tell. Also, I was down to maybe 1/3 tank of fuel up front but I'll bet with full fuel the tail comes up much sooner. Just some points on the performance chart. Oscar Zuniga NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 22, 2008
Thanks for the info Dick. My primer goes into the carb and no problems so far. I do a preheat with a simple heater I built (I don't like to start an engine without preheating if the temp is below 40 degrees). I do pretty much as you do for starting. For my A-65 it's two squirts of prim followed by 6 blades with the throttle wide open (mags off). Then with throttle just slightly cracked open and mags on, it will start on 1st or 2nd blade, running at about 800 rpm. I've only flooded the engine a few time but clearing it was easy. Mags off. Throttle wide open. 8 blades in reverse. Throttle just slightly cracked, mags on and she'll start right up. I dress in layers, with the top part being my insulated coveralls. I bought some bands that go around my pant legs (to keep the wind out) and they work great. I intend to do as you did and make a cover for the front cockpit and I'm hoping that will take care of the "draft". I use insulated motorcycle gloves that extend about 4 inches above the wrist (looks like train engineer gloves), as I tend to rest my left arm on the side of the cockpit and without them the wind will blow right up the sleeve. We don't have and probably won't get any snow. I miss it and I'm jealous of the pilots that get to use the frozen lakes as their own private play grounds. For the pilots that put their planes up for the winter, I really encourage you to try cool weather flying just once. There's a good chance you'll get hooked. It's no colder than riding a snow machine. In fact, with my new taller windshild I find it less so. The air is soooo smooth and the plane performs so well, it's worth getting dressed up for. Try it, you'll like it. Gene in Tennessee (18 degrees last night but got up to 40 degrees this afternoon.) ----- Original Message ----- From: Dick N. To: pietenpol-list(at)matronics.com Sent: Saturday, November 22, 2008 9:19 AM Subject: Re: Pietenpol-List: No bugs on the prop or windshield Gene and Jim ________________________________________________________________________________
Subject: Questions
Date: Nov 23, 2008
Hi everyone My fuse is coming along great but I have a couple of questions. Where the plans call for a 3/16 hole for the cabane fittings is that for a AN3 bolt? When fitting the tail the rear most horizontal stab fittings under the stab do you use one bolt to go right through both fittings and do I need some sort of shim to square things up because of the fuse angle? Or maybe a better question is how do I fit the tail fittings to the fuse? Thanks Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215846#215846 ________________________________________________________________________________
Subject: A great place to visit
Date: Nov 23, 2008
For what it's worth. If you haven't visited www.bowersflybaby.com you are missing out. The flybaby is a wood airplane and uses the same engines we use. One of my favorite sections is Harry Fenton's section on engines. A must read if your not an A & P. Most of our engine questions are answered and if their not, he will answer them. Lots of great building, clothing, flying and general information for those of us that build, maintain, fly or just love open cockpit wooden planes. Gene in Tennessee (looks like it's going to be a great flying day!) ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: fuse painting etc
Date: Nov 23, 2008
Hey everybody, Got the engine mounted finally and am starting to connect things up and finish all the little things on the fuse. My question is this. For those of you finished, when did you paint the fuselage in the process? It seems to make sense to get everything fabricated and assembled, then disassemble and paint but that seems like it might be uncecessary work. I could paint the fabric now, but I'm afraid of messing it up as everything is fitted and affixed etc. Also, if I plumb for my wing tank, do I do it with the sheet metal off for easier access, and if so, can you get the sheet metal down over the fuel lines sticking up from the fuse? Appreciate any tips. Douwe ________________________________________________________________________________
Subject: Re: Questions
Date: Nov 23, 2008
Hi all After posting this question I finally found the answers 3/16=an3 A found some pictures on west coast Piet of Santiago Morete's and realised how stupid I really am to have not of thought to do it that way. Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215893#215893 ________________________________________________________________________________
Date: Nov 24, 2008
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even just a single dinner out. Isn't the List worth at least that much to you? Won't you please take a minute to make your Contribution today and support the Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 24, 2008
Subject: Spar Varnish
Spar varnish from Ace Hardware has been recommended; is the recommendation based upon some particular quality or capability of the Ace product as opposed to, say, Sherwin-Williams spar varnish? Or it a matter of economy. I'm about ready to apply varnish, and would appreciate feedback, Dick Carden ________________________________________________________________________________
Subject: Re: Spar Varnish
Date: Nov 24, 2008
I tried one of the hardware store brands on a couple of repair pieces a while back and it came out with more yellow color than other parts. I like Marine Spar Varnish by Minnwax. According to the tech rep from West System, it is slower to totally cure than other varnishes. I don't know if that means much of anything, but I think a slower cure should mean a more durable finish in the end. Dick N. ----- Original Message ----- From: "Richard Carden" <flywrite(at)verizon.net> Sent: Monday, November 24, 2008 6:52 AM Subject: Pietenpol-List: Spar Varnish > > > Spar varnish from Ace Hardware has been recommended; is the > recommendation based upon some particular quality or capability of the > Ace product as opposed to, say, Sherwin-Williams spar varnish? Or it a > matter of economy. I'm about ready to apply varnish, and would appreciate > feedback, Dick Carden > > > ________________________________________________________________________________
Date: Nov 24, 2008
The type of spar varnish you use is not important (ie. brand) as is the type of covering system you use. An example would be if you use Poly Fiber system, the Poly Tack glue will melt common spar varnish. But if you use the Stewart System (water based) any spar varnish is ok.In the case of Poly Products, it is best to use a Epoxy based varnish. Ernie ----- Original Message ----- From: "Richard Carden" <flywrite(at)verizon.net> Sent: Monday, November 24, 2008 4:52 AM Subject: Pietenpol-List: Spar Varnish > > > Spar varnish from Ace Hardware has been recommended; is the > recommendation based upon some particular quality or capability of the > Ace product as opposed to, say, Sherwin-Williams spar varnish? Or it a > matter of economy. I'm about ready to apply varnish, and would appreciate > feedback, Dick Carden > > > ________________________________________________________________________________
Date: Nov 24, 2008
I still like the epoxy varnish from PolyFiber. More expensive, but bulletproof. No worries about the fabric finish lifting it. Absolutely the best protection for wood. As they say, the bitterness of reduced quality remains long after the sweet taste of low price is forgotten. Dick, I'll get a taste of cold weather Pietenpoling this weekend. I'm going to fly mine up to Smith Mountain Lake, Virginia (about a 2 hour trip) and leave it in my new hangar up there. I'll have the front cockpit cover on and the cabin heat going full blast (it will slightly warm my right foot). Temps should be in the 40' so not too bad. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick N. Sent: Monday, November 24, 2008 12:49 PM Subject: Re: Pietenpol-List: Spar Varnish I tried one of the hardware store brands on a couple of repair pieces a while back and it came out with more yellow color than other parts. I like Marine Spar Varnish by Minnwax. According to the tech rep from West System, it is slower to totally cure than other varnishes. I don't know if that means much of anything, but I think a slower cure should mean a more durable finish in the end. Dick N. ----- Original Message ----- From: "Richard Carden" <flywrite(at)verizon.net> Sent: Monday, November 24, 2008 6:52 AM Subject: Pietenpol-List: Spar Varnish > > > Spar varnish from Ace Hardware has been recommended; is the > recommendation based upon some particular quality or capability of the > Ace product as opposed to, say, Sherwin-Williams spar varnish? Or it a > matter of economy. I'm about ready to apply varnish, and would appreciate > feedback, Dick Carden > > > _________________________________________________ or otherwise private information. If you have received it in error, please notify the sender Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - Norsk - Portuguese ________________________________________________________________________________
Date: Nov 24, 2008
Just keep in mind that if you are using Poly Fibre or similar, with a MEK base,,,the glue to attach the fabric will attack/lift the varnish. You have to cover the parts accepting fabric with epoxy varnish. You simply cover just the parts that will see the glue, and it works like magic, and doesn't lift. I found this out while attaching fabric to my fuse. On the sides of the cockpits it started to lift, and it was too late to go back. I added a strip of ply with nails to secure it, and that's how it is today. But I spread epoxy on the rest with good results. walt evans NX140DL ----- Original Message ----- From: "Richard Carden" <flywrite(at)verizon.net> Sent: Monday, November 24, 2008 7:52 AM Subject: Pietenpol-List: Spar Varnish > > > Spar varnish from Ace Hardware has been recommended; is the > recommendation based upon some particular quality or capability of the > Ace product as opposed to, say, Sherwin-Williams spar varnish? Or it a > matter of economy. I'm about ready to apply varnish, and would appreciate > feedback, Dick Carden > > > ________________________________________________________________________________
Date: Nov 24, 2008
Doug Bryant and Chuck Ganzer used Ace spar varnish and told me that the glue they used didn't lift the varnish,- however, I never asked what they used. I just assumed it was Poly Fiber (Stitts) Chuck, if your listening, chime in. Leon S. in Ks. ________________________________________________________________________________
Date: Nov 24, 2008
Subject: Re: Spar Varnish, glue alternatives
I covered my fuselage with epoxy, and my wings with Spar Varnish... I used about 3.5 quarts of spar varnish doing 2 coats, so you can save some money by just buying a gallon to start with. After it was all said and done, I'm using the water based Stewart System glue, sold at AS as Ekobond. This stuff is great to work with and is odorless. I'm using the water based Sherwin Williams system for paint and the Ekobond works well with it. Just my $.02. I've experimented a little with the Sherwin Williams latex. I bought a gallon of gray in flat and a gallon of "buff:" in gloss. It took one thinned brushed coat and two sprayed coats of gray to get opacity, then two coats of color over that, thinned about 1/3 with water and applied with my HVLP gun that I used to use to paint cars. The finish isn't real glossy, but a kind of satin authentic Piet look. So far I've only painted my tail surfaces. I got one wing covered last weekend, and in the next few days (or weeks) I'll be spending some time with the rib stitch needle. I made a rotator table out of two Work-mate tables so I can swing the wing to do the work solo. I'll post a few pictures in the next few days. Stewart systems has a nice web-site and their whole application manual is available there for free as a PDF file. Ben Charvet Mims, Fl walt wrote: > > Just keep in mind that if you are using Poly Fibre or similar, with a > MEK base,,,the glue to attach the fabric will attack/lift the varnish. > You have to cover the parts accepting fabric with epoxy varnish. ________________________________________________________________________________
Subject: Spar Varnish, glue alternatives
Date: Nov 24, 2008
Ben; I'm quite interested in your latex application technique. You say "thinned". Does that mean you used Floetrol or water? Two completely different things, as I understand it... water will thin the paint but Floetrol makes it flow out. Not sure how much of that is product hype and how much is real. Either way, one or the other is necessary for shooting latex from a regular gun so I'm curious as to your technique. So far, nothing but the very best for my "Flying Squirrel" fiberglass project airplane... genuine Wal-Mart flat grey and flat white primers, never pay more than $2 per rattle can ;o) However, if I ever get around to building the ultralight version of the Longster that I have in mind, it will be fabric covered and I'd like to use latex house paint on it. So far my experience with trying to shoot latex house paint from a regular gun has been less than fantastic, but I was too cheap to buy Floetrol and I work in pretty warm weather, which leads to instant nozzle clogging. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 24, 2008
I experimented with Floetrol, windshield washer fluid, and plain old water. The floetrol gave the worse results, and I couldn't tell the difference between water and washer fluid. I was honestly surprised how nice it went on with the HVLP gun. Getting it thin enough must be the trick, and I was probably using a little more pressure than I would use for an auto paint job, because there was more overspray. One thing I did do was spray all the pieces flat so I could put on a good wet coat, the water reducer/thinner allowed it to flow out very smooth. The Sherwin Williams latex is quite thick, so I am using 2 parts SW to one part distilled water. Ben Oscar Zuniga wrote: > > > Ben; > > I'm quite interested in your latex application technique. You say "thinned". Does that mean you used Floetrol or water? Two completely different things, as I understand it... water will thin the paint but Floetrol makes it flow out. Not sure how much of that is product hype and how much is real. Either way, one or the other is necessary for shooting latex from a regular gun so I'm curious as to your technique. > > ________________________________________________________________________________
Date: Nov 24, 2008
Hope you're right, Dick. I'm using spar varnish from Zinsser (Home Depot). It takes a couple days to dry at 75 deg / 30% humidity! If varnish is anything like cement, we're in good shape. :-) Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (endless metal parts!) (12 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick N. Sent: Monday, November 24, 2008 9:49 AM Subject: Re: Pietenpol-List: Spar Varnish I tried one of the hardware store brands on a couple of repair pieces a while back and it came out with more yellow color than other parts. I like Marine Spar Varnish by Minnwax. According to the tech rep from West System, it is slower to totally cure than other varnishes. I don't know if that means much of anything, but I think a slower cure should mean a more durable finish in the end. Dick N. ----- Original Message ----- From: "Richard Carden" <flywrite(at)verizon.net> Sent: Monday, November 24, 2008 6:52 AM Subject: Pietenpol-List: Spar Varnish > > > Spar varnish from Ace Hardware has been recommended; is the > recommendation based upon some particular quality or capability of the > Ace product as opposed to, say, Sherwin-Williams spar varnish? Or it a > matter of economy. I'm about ready to apply varnish, and would appreciate > feedback, Dick Carden > > > ________________________________________________________________________________
Date: Nov 24, 2008
Oscar, I do not think that the latex house paint is a good cover process for aircraft because of the weight of the paint. The Poly, Stewart, etc etc are light weight processes for aircraft. The latex method has only in my opinion, one good feature, it is cheap. Ernie ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Monday, November 24, 2008 7:06 PM Subject: Pietenpol-List: Spar Varnish, glue alternatives > > > Ben; > > I'm quite interested in your latex application technique. You say > "thinned". Does that mean you used Floetrol or water? Two completely > different things, as I understand it... water will thin the paint but > Floetrol makes it flow out. Not sure how much of that is product hype and > how much is real. Either way, one or the other is necessary for shooting > latex from a regular gun so I'm curious as to your technique. > > So far, nothing but the very best for my "Flying Squirrel" fiberglass > project airplane... genuine Wal-Mart flat grey and flat white primers, > never pay more than $2 per rattle can ;o) However, if I ever get around > to building the ultralight version of the Longster that I have in mind, it > will be fabric covered and I'd like to use latex house paint on it. So > far my experience with trying to shoot latex house paint from a regular > gun has been less than fantastic, but I was too cheap to buy Floetrol and > I work in pretty warm weather, which leads to instant nozzle clogging. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Date: Nov 25, 2008
Hi Gene, You said you are using Polyurethane varnish. I'm no expert on the subject but I think I have read reports that polyurethane varnish doesn't let the wood 'breath' properly. Apparently 'normal varnish' (whatever that is) will let the wood swell and contract as it likes. I heard that with polyurethane, as the wood expands and contracts, the fibers eventually become damage due to the polyurethane varnish not flexing along with the wood..................... At the place that I work here in Japan, we just use a clear spar type varnish from the local paint shop or in some cases, a thin coat of whatever glue we are using at the time. (only for small areas, i.e.; rib gussets etc) Japan's climate is fairly 'moist' (summer is very humid, then there is the rainy season as well) and I have seen cases here of wooden aircraft that spend their life outside, having a wooden member which has basically rotted away with the polyurethane coating still 'intact' so to speak ! .After saying all of that, in my copy of EAA Aircraft Building Techniques 'WOOD' book, on pg 94, under the sub heading "Protection against deterioration", Tony Bingelis said (quote) "This treatment followed by 2 or 3 coats of a good polyurethane varnish applied to the structure helps seal the wood and reduce its sensitivity to humidity changes". He also said that T-88 epoxy glue thinned with lacquer to a brushing consistency is a good surface treatment. I think is Tony's advice in his books/articles is generally very good so I am in two minds on this subject. So,has anyone else had long term experience with polyurethane varnishes on wood? Mark ________________________________________________________________________________
Date: Nov 25, 2008
Steve E., one of the more prominent examples of Piet builders that painted with latex, had an empty weight of 626 lbs with an A-65 powered latex-painted Piet. That is a pretty decent weight for any Piet, especially considering it was all Douglas Fir. As such it would seem that the weight increase from latex versus "aircraft coverings" is minimal. I can't find any mention of a concern about weight increase from latex in the archives. It would seem that the good features of latex is that it works, and it is cheap. Check out Steve's firsthand accounts at: http://www.westcoastpiet.com/steve_eldridge.htm I'm not arguing latex versus dope/traditional, just pointing out that it is a valid option. Ryan On Mon, Nov 24, 2008 at 11:49 PM, Ernie Moreno wrote: > ewmoreno(at)minetfiber.com> > > Oscar, I do not think that the latex house paint is a good cover process > for aircraft because of the weight of the paint. The Poly, Stewart, etc etc > are light weight processes for aircraft. The latex method has only in my > opinion, one good feature, it is cheap. > > Ernie ________________________________________________________________________________
Subject: Spar Varnish 2
Date: Nov 25, 2008
Hi Gene, I just posted a message and being the local village idiot, I wrote the following -"He also said that T-88 epoxy glue thinned with lacquer to a brushing consistency is a good surface treatment" It should say 'T-88 epoxy glue thinned with lacquer THINNER to a brushing consistency is a good surface treatment" That makes more sense I think!! Mark ________________________________________________________________________________
Date: Nov 24, 2008
So what's the weight difference with DRY paint? Clif ----- Original Message ----- From: "Ernie Moreno" <ewmoreno(at)minetfiber.com> Sent: Monday, November 24, 2008 9:49 PM Subject: Re: Pietenpol-List: Spar Varnish, glue alternatives > > > Oscar, I do not think that the latex house paint is a good cover process > for > aircraft because of the weight of the paint. The Poly, Stewart, etc etc > are > light weight processes for aircraft. The latex method has only in my > opinion, one good feature, it is cheap. > > Ernie > > > ----- Original Message ----- > From: "Oscar Zuniga" <taildrags(at)hotmail.com> > To: "Pietenpol List" > Sent: Monday, November 24, 2008 7:06 PM > Subject: Pietenpol-List: Spar Varnish, glue alternatives > > >> >> >> >> Ben; >> >> I'm quite interested in your latex application technique. You say >> "thinned". Does that mean you used Floetrol or water? Two completely >> different things, as I understand it... water will thin the paint but >> Floetrol makes it flow out. Not sure how much of that is product hype >> and >> how much is real. Either way, one or the other is necessary for shooting >> latex from a regular gun so I'm curious as to your technique. >> >> So far, nothing but the very best for my "Flying Squirrel" fiberglass >> project airplane... genuine Wal-Mart flat grey and flat white primers, >> never pay more than $2 per rattle can ;o) However, if I ever get around >> to building the ultralight version of the Longster that I have in mind, >> it >> will be fabric covered and I'd like to use latex house paint on it. So >> far my experience with trying to shoot latex house paint from a regular >> gun has been less than fantastic, but I was too cheap to buy Floetrol and >> I work in pretty warm weather, which leads to instant nozzle clogging. >> >> Oscar Zuniga >> Air Camper NX41CC >> San Antonio, TX >> mailto: taildrags(at)hotmail.com >> website at http://www.flysquirrel.net >> >> >> >> > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 2:36 PM ________________________________________________________________________________
Date: Nov 25, 2008
Subject: Re: Re: Spar Varnish
Gosh, I'm almost sorry I asked! ;-) Or maybe I just didn't ask enough questions. I'll start over: I'm using the medium-weight heat- shrinkable fabric from AS. I don't plan to follow anybody's proprietary processes. What I want to do is protect the wood with a sealant (varnish) and then apply a "glue" to attach the fabric to the framework. Apparently there are spar varnishes and there are spar varnishes, and the selection depends upon what glue you use to attach the fabric. One archive recommendation says that using varnish itself as a glue if an excellent method as it bonds varnish to varnish with the fabric in between. I've also read that a sticky-backed tape should be put over the framework so as to underlie the fabric so that when it's stitched the fabric doesn't contact the edges of the wood, which might cause fabric fraying/abrasion. Then a cement, the fabric, the stitching and finally the pinked tape. I like the Sherwin- Williams latex idea, if for no other reason it has all the qualities I want. I get mixed messages from the archives, which is understandable since different strokes for different folks. What I'd like is/are recommendations for a complete process from those who've been there and done that. (I reinvented the wheel once, and it's not a thing of beauty!!) Dick Carden ________________________________________________________________________________
Date: Nov 25, 2008
Dick, If you are an EAA member, you can log in to their website and search for "Ron Alexander" and "varnish" and you will get several articles he has written on covering with fabric. One of his articles suggests you take a rag soaked with MEK and lay it on a sample of the varnish you are going to use, and if it hasn't affected it after 30 minutes, it should be OK to use. BTW, I did this test with Minwax Spar Varnish and didn't see any effect from the MEK at all. Good luck, John Franklin GN-1 ...almost ready to cover Richmond, TX ________________________________________ ________________________________________________________________________________
Subject: latex house paint
Date: Nov 25, 2008
It sounds to me like it might be time for a scientific test. Lay up two wooden test frames of a statistically-significant size (say maybe 2 ft. square apiece), cover both using the same fabric, and then finish one with the Poly-Fiber process and the other with the Fisher latex house paint method (as detailed in Stevee's notes on Westcoastpiet). When completely cured, cut both test sections out of their frames and put them on a digital scale and compare the weight. Multiply the difference by the approximate number of yards of fabric used in a Piet project, and we will then know how much difference there is in weight. I was quite surprised to see that John Dilatush's (now Greg Bacon's) "Mountain Piet" also wears latex house paint. It's a beauty. I do value Ernie Moreno's input. He is a Tech Counselor and has quite a number of fine projects under his belt, is extremely generous with his time and talent, and lives at the Independence, Oregon airpark that spawned the "Noon Patrol"... the squadron of 13 Nieuport replicas that flew into the history books a few years ago as a remarkable group project. Pictures and story at http://eaa292.org/noonpatrol_hi-res.html Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 25, 2008
I too would love to see the entire process thoroughly explained and in detail for start to finish. Of late I have completed the wood work on my tail section and while waiting for my spar material to come in I thought I would start the sanding and coating process of the tail assemblies so bot the spar and coating discussions are timely for me. I would like to use house paint but want to make sure that the preparation though the final paint is detailed and understood. Changing or removing or destroying the finish or the fabric is not something I would like to do after using the wrong varnish, process or step progression. Can someone clarify the process, step by step material by material so I too know what to purchase, how much and how to apply it for the best results. Based upon yesterdays discussion I have probably looked at, at least a dozen different coating and varnishes and still have nothing to base a decision on. I would love to see a concensus for the collective wisdom on the ultimate coating and coloring system from an availability, cost and ease of application perspective. As usual I appreciate and value your input, this entire issue has gotten rather confusing for me. Thanks John Recine In a message dated 11/25/2008 8:11:37 A.M. Eastern Standard Time, flywrite(at)verizon.net writes: --> Pietenpol-List message posted by: Richard Carden Gosh, I'm almost sorry I asked! ;-) Or maybe I just didn't ask enough questions. I'll start over: I'm using the medium-weight heat- shrinkable fabric from AS. I don't plan to follow anybody's proprietary processes. What I want to do is protect the wood with a sealant (varnish) and then apply a "glue" to attach the fabric to the framework. Apparently there are spar varnishes and there are spar varnishes, and the selection depends upon what glue you use to attach the fabric. One archive recommendation says that using varnish itself as a glue if an excellent method as it bonds varnish to varnish with the fabric in between. I've also read that a sticky-backed tape should be put over the framework so as to underlie the fabric so that when it's stitched the fabric doesn't contact the edges of the wood, which might cause fabric fraying/abrasion. Then a cement, the fabric, the stitching and finally the pinked tape. I like the Sherwin- Williams latex idea, if for no other reason it has all the qualities I want. I get mixed messages from the archives, which is understandable since different strokes for different folks. What I'd like is/are recommendations for a complete process from those who've been there and done that. (I reinvented the wheel once, and it's not a thing of beauty!!) Dick Carden **************One site has it all. Your email accounts, your social networks, and the things you love. Try the new AOL.com %26icid=aolcom40vanity%26ncid=emlcntaolcom00000001) ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: Varnishing Wood
Date: Nov 25, 2008
I have been reading the posts recently on varnishing wood with interest and would like to add my 2 cents to the discussion. First a little history. I have worked in the coatings industry for over 35 years serving as a Technical Director for various paint companies supplying coatings to the international market. I now own my own paint company supplying high performance coatings to the firearms industry. The formulations used for wood varnish, have been in a state of flux for the past two decades due primarily to mandates from Congress, the Environmental Protection Agency and cost considerations. This has been especially true for the last 10 years. In order to meet the current environmental regulations for low solvent content, manufacturers have had to dramatically reformulate their products. The old non-urethane based varnishes were made by cooking various seed oils, such as linseed, tung, soybean etc., with resins. This was a costly process and based more on art than any real science. These cooked varnish formulations began to be replaced by the urethane varnishes in the 50's. By the 70's, this replacement began to accelerate. This was due to the superior performance and ease of manufacture of the oil modifed urethanes. By the late 80's the replacement of the old cooked varnishes with the oil modifed urethanes was almost complete. Their may have been a few hold outs, but t hey were relying on perceived quality not on fact. By the mid to late 90's there were many oil-modifed urethane varnishes on the maket that far surpased the old style vrnishes in quality. These oil- modified urethane varnishes dried faster, had better flexibility, better color retention and much better resistance to UV degredation than the old style varnishes. Many of these oil-modifed urethanes were more than adequate for varnishing wood aircraft, no matter what finishing process was used. In the late 90's Mike Cuy picked a good one from Minwax for his plane. Others in the past, have used spar varnish from ACE hardware with success . However, as I stated before, these formulations have changed dramatically in the past 10 years, to satisfy the current VOC regulations and probobaly would not pass the 30 minute lacquer thinner test. I certainly do not have access to the competion's formulas, but I know what I have had to do to my formulations in the past to satisify these regulations! None of the changes are good for aircraft wood varnishes. This especially true when it comes to solvent resistance. If it were me (which it is as I am in the varnishing stage on my Piet) this is what I would do. 1. If you are finishing with a system that contains strong lacquer solvents such as Stits, Randolph etc., varnishing with a two part epoxy would be a good option. Just be aware that epoxies have very poor resistance to UV light and the coatings are expensive and somewhat difficult to apply. 2. If you finish with the Stewart's water based system, you have more options. Since solvent attack is not an issue, most of the currently available exterior grade oil modified urethanes would be OK. 3. This is the process I am going to use. This is not ment as an advertisement, its just what I have done. Since I manufacture and sell high performance varnishes for firearms, this is what I have used on my Pietenpol. Our Permalyn finish was designed for exterior use, with flexibility and resistance to gun cleaning solvents in mind. I have tested for resistance to strong lacquer solvents with a 30 min soak and it passes just fine. For those that might be interested here is a link to information on the varnish http://www.laurelmountainforge.com/finish.htm. Rick Schreiber Valparaiso, IN lmforge(at)earthlink.net ________________________________________________________________________________
Date: Nov 25, 2008
Good post, Rick. Nice to hear from someone who actually is an expert on the subject. I used PolyFiber's 2 part epoxy varnish on my Pietenpol. Since the landing gear struts are exposed to sunlight any time the plane is out of the hangar, what should I look for in UV degradation? Will I notice a yellowing, or a change in clarity? Of course, since the plane spends most of its life in a hangar, the changes may take years to appear. The longest period of continuous use outside a hangar is the occasional trip to Brodhead. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard Schreiber Sent: Tuesday, November 25, 2008 11:33 AM Subject: Pietenpol-List: Varnishing Wood I have been reading the posts recently on varnishing wood with interest and would like to add my 2 cents to the discussion. First a little history. I have worked in the coatings industry for over 35 years serving as a Technical Director for various paint companies supplying coatings to the international market. I now own my own paint company supplying high performance coatings to the firearms industry. The formulations used for wood varnish, have been in a state of flux for the past two decades due primarily to mandates from Congress, the Environmental Protection Agency and cost considerations. This has been especially true for the last 10 years. In order to meet the current environmental regulations for low solvent content, manufacturers have had to dramatically reformulate their products. The old non-urethane based varnishes were made by cooking various seed oils, such as linseed, tung, soybean etc., with resins. This was a costly process and based more on art than any real science. These cooked varnish formulations began to be replaced by the urethane varnishes in the 50's. By the 70's, this replacement began to accelerate. This was due to the superior performance and ease of manufacture of the oil modifed urethanes. By the late 80's the replacement of the old cooked varnishes with the oil modifed urethanes was almost complete. Their may have been a few hold o uts, but they were relying on perceived quality not on fact. By the mid to late 90's there were many oil-modifed urethane varnishes on the maket that far surpased the old style vrnishes in quality. These oil- modified urethane varnishes dried faster, had better flexibility, better color retention and much better resistance to UV degredation than the old style varnishes. Many of these oil-modifed urethanes were more than adequate for varnishing wood aircraft, no matter what finishing process was used. In the late 90's Mike Cuy picked a good one from Minwax for his plane. Others in the past, have used spar varnish from ACE hardware with success . However, as I stated before, these formulations have changed dramatically in the past 10 years, to satisfy the current VOC regulations and probobaly would not pass the 30 minute lacquer thinner test. I certainly do not have access to the competion's formulas, but I know what I have had to do to my formulations in the past to satisify these regulations! None of the changes are good for aircraft wood varnishes. This especially true when it comes to solvent resistance. If it were me (which it is as I am in the varnishing stage on my Piet) this is what I would do. 1. If you are finishing with a system that contains strong lacquer solvents such as Stits, Randolph etc., varnishing with a two part epoxy would be a good option. Just be aware that epoxies have very poor resistance to UV light and the coatings are expensive and somewhat difficult to apply. 2. If you finish with the Stewart's water based system, you have more options. Since solvent attack is not an issue, most of the currently available exterior grade oil modified urethanes would be OK. 3. This is the process I am going to use. This is not ment as an advertisement, its just what I have done. Since I manufacture and sell high performance varnishes for firearms, this is what I have used on my Pietenpol. Our Permalyn finish was designed for exterior use, with flexibility and resistance to gun cleaning solvents in mind. I have tested for resistance to strong lacquer solvents with a 30 min soak and it passes just fine. For those that might be interested here is a link to information on the varnish http://www.laurelmountainforge.com/finish.htm. Rick Schreiber Valparaiso, IN lmforge(at)earthlink.net _________________________________________________ This message is for the designated recipient only and may contain privilege d, proprietary or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is p rohibited. Dansk - Deutsch - Espanol - Francais - Italiano - Japanese - Nederlands - N orsk - Portuguese ________________________________________________________________________________
Date: Nov 25, 2008
The main difference in weight in the different topcoats is how much you wind up putting on. The pigments used in white house paint, Stits, Randolph, Airtech etc are all the same and weigh the same. The difference in weight of the base resins is negligible, the real difference in weight of the dry, cured film is in how much you apply. There is probably more pigment in latex house paint, as the manufacturer is trying for one coat coverage, than in a typical aircraft coating. However, if you use house paint you should be able to get by with less application thickness. One word of caution, if you go the non-certified route and use latex house paint or auto paint, you are serving as your own test lab. Unfortunately with most of us this testing will occur on the plane as the final product. Even if you make up some test frames and stick them outside for a few years of exposure, its not real world. For example, make a test frame using Duponts 2 part Urethane Imron for the fabric topcoat, it will appear to weather just fine. However, put this same coating on a fabric covered aircraft wing and it will crack and ringworm in a couple of years time. Some will claim they have used auto enamels with success, but how thick did they apply it and how many flight hours on the cover job? Latex house paint may work fine for some, but if you follow someone elses lead you can't be sure of the same results unless you follow the exact same procedure. Rick Schreiber > [Original Message] > From: Oscar Zuniga <taildrags(at)hotmail.com> > To: Pietenpol List > Date: 11/25/2008 8:08:26 AM > Subject: Pietenpol-List: latex house paint > > > It sounds to me like it might be time for a scientific test. Lay up two wooden test frames of a statistically-significant size (say maybe 2 ft. square apiece), cover both using the same fabric, and then finish one with the Poly-Fiber process and the other with the Fisher latex house paint method (as detailed in Stevee's notes on Westcoastpiet). > > When completely cured, cut both test sections out of their frames and put them on a digital scale and compare the weight. Multiply the difference by the approximate number of yards of fabric used in a Piet project, and we will then know how much difference there is in weight. > > I was quite surprised to see that John Dilatush's (now Greg Bacon's) "Mountain Piet" also wears latex house paint. It's a beauty. > > I do value Ernie Moreno's input. He is a Tech Counselor and has quite a number of fine projects under his belt, is extremely generous with his time and talent, and lives at the Independence, Oregon airpark that spawned the "Noon Patrol"... the squadron of 13 Nieuport replicas that flew into the history books a few years ago as a remarkable group project. Pictures and story at http://eaa292.org/noonpatrol_hi-res.html > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Nov 25, 2008
Subject: Re: latex house paint (OT)
Among other comments, Oscar Zuniga wrote: > I do value Ernie Moreno's input. He is a Tech Counselor and has quite a number of fine projects under his belt, is extremely generous with his time and talent, and lives at the Independence, Oregon airpark that spawned the "Noon Patrol"... (etc.) Speaking of Ernie, it's probably time for me to goose someone about the Independence Flyer ultralight project. How's it going, Ernie? Is it going at all? For those not familiar with it, the Independence Flyer is one of the Independence EAA chapter's group projects, a well-designed ultralight that closely resembles two of my favorite antiques (well, not MY antiques, alas, but you get the idea), the Aeronca C-2 and C-3. It seems to have been pretty much on hold since everyone there got Nieuport fever. If I had a few doubloons to my name, didn't live about as far from Independence as it's possible to get without leaving the continent, and had an ultralight-friendly airport less than 3 hours drive away, I'd offer to buy the project, just to see it completed. Owen ________________________________________________________________________________
Date: Nov 25, 2008
Now, there's an educated reply. Thanks for sharing your knowledge, Rick. I just recently finished "varnishing" my empennage with Minwax's Spar Urethane. I noticed that the can had a note indicating that the product was "improved", and was now quicker drying. That obviously means that the formulation has been changed. What it doesn't say is whether the newest "improvement" results in a more durable finish (the sticker on the lid of the can did not claim it to be more durable, so I doubt that it is). I recall postings from a few years ago that implied that hardware store urethanes are much less impervious to solvents if one attempts to cover soon after sealing, as the finish has not fully cured. As I recall, it was suggested that the urethane be allowed to cure for at least a month before applying solvent-based adhesives (hope my memory is working). I have recently been thinking that the Stewart's water-based adhesives sound like a good idea, and may be the route I take when I get to that stage of building, and I read recently that Kitplanes magazine is planning to publish an in-depth review of the products. From what I have read, the Stewart's products work as well as, if not better than the traditional systems. The disadvantage, at this point, is the relative newness of the system, and the lack of a long-term proven track record. I have no doubt that, with the way things have been going, practically all solvent-based products will become increasingly more rare, if not banned outright. Some may say that the traditional finishes will never be replaced, but I can recall just a few years ago, hearing many people say that they would never be able to restrict cigarette smoking. Same story with leaded gasoline. Change is coming, like it or not. The good thing is that someone is working on solutions now. Bill C. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard Schreiber Sent: Tuesday, November 25, 2008 11:33 AM Subject: Pietenpol-List: Varnishing Wood I have been reading the posts recently on varnishing wood with interest and would like to add my 2 cents to the discussion. First a little history. I have worked in the coatings industry for over 35 years serving as a Technical Director for various paint companies supplying coatings to the international market. I now own my own paint company supplying high performance coatings to the firearms industry. The formulations ... . Rick Schreiber Valparaiso, IN ________________________________________________________________________________
Date: Nov 25, 2008
Jack, Typical 2 part epoxy clears show pretty severe degradation within 6 months of continual exterior exposure here in the midwest. Degradation naturally will occur faster in southern climates. The mode of degradation is loss of gloss, with the coating turning a chalky white given enough exposure time. In your case, since you do not hanger the Piet outside, the limited exterior exposure will probably not be a problem. If and when it ever becomes an issue, just remove the gear legs and re-sand to bare wood or at least remove the surface oxidation. Then refinish with an exterior grade varnish. If you get on the Gougeon Brothers West System epoxy web site they talk about some of these issues. Even though they market a 2 part epoxy clear for wood, they too talk about using an exterior varnish over their epoxy for UV protection. Rick Schreiber 5936D ----- Original Message ----- From: Phillips, Jack Sent: 11/25/2008 10:53:59 AM Subject: RE: Pietenpol-List: Varnishing Wood Good post, Rick. Nice to hear from someone who actually is an expert on the subject. I used PolyFibers 2 part epoxy varnish on my Pietenpol. Since the landing gear struts are exposed to sunlight any time the plane is out of the hangar, what should I look for in UV degradation? Will I notice a yellowing, or a change in clarity? Of course, since the plane spends most of its life in a hangar, the changes may take years to appear. The longest period of continuous use outside a hangar is the occasional trip to Brodhead. Jack Phillips NX899JP From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard Schreiber Sent: Tuesday, November 25, 2008 11:33 AM Subject: Pietenpol-List: Varnishing Wood I have been reading the posts recently on varnishing wood with interest and would like to add my 2 cents to the discussion. First a little history. I have worked in the coatings industry for over 35 years serving as a Technical Director for various paint companies supplying coatings to the international market. I now own my own paint company supplying high performance coatings to the firearms industry. The formulations used for wood varnish, have been in a state of flux for the past two decades due primarily to mandates from Congress, the Environmental Protection Agency and cost considerations. This has been especially true for the last 10 years. In order to meet the current environmental regulations for low solvent content, manufacturers have had to dramatically reformulate their products. The old non-urethane based varnishes were made by cooking various seed oils, such as linseed, tung, soybean etc., with resins. This was a costly process and based more on art than any real science. These cooked varnish formulations began to be replaced by the urethane varnishes in the 50's. By the 70's, this replacement began to accelerate. This was due to the superior performance and ease of manufacture of the oil modifed urethanes. By the late 80's the replacement of the old cooked varnishes with the oil modifed urethanes was almost complete. Their may have been a few hold o uts, but they were relying on perceived quality not on fact. By the mid to late 90's there were many oil-modifed urethane varnishes on the maket that far surpased the old style vrnishes in quality. These oil- modified urethane varnishes dried faster, had better flexibility, better color retention and much better resistance to UV degredation than the old style varnishes. Many of these oil-modifed urethanes were more than adequate for varnishing wood aircraft, no matter what finishing process was used. In the late 90's Mike Cuy picked a good one from Minwax for his plane. Others in the past, have used spar varnish from ACE hardware with success . However, as I stated before, these formulations have changed dramatically in the past 10 years, to satisfy the current VOC regulations and probobaly would not pass the 30 minute lacquer thinner test. I certainly do not have access to the competion's formulas, but I know what I have had to do to my formulations in the past to satisify these regulations! None of the changes are good for aircraft wood varnishes. This especially true when it comes to solvent resistance. If it were me (which it is as I am in the varnishing stage on my Piet) this is what I would do. 1. If you are finishing with a system that contains strong lacquer solvents such as Stits, Randolph etc., varnishing with a two part epoxy would be a good option. Just be aware that epoxies have very poor resistance to UV light and the coatings are expensive and somewhat difficult to apply. 2. If you finish with the Stewart's water based system, you have more options. Since solvent attack is not an issue, most of the currently available exterior grade oil modified urethanes would be OK. 3. This is the process I am going to use. This is not ment as an advertisement, its just what I have done. Since I manufacture and sell high performance varnishes for firearms, this is what I have used on my Pietenpol. Our Permalyn finish was designed for exterior use, with flexibility and resistance to gun cleaning solvents in mind. I have tested for resistance to strong lacquer solvents with a 30 min soak and it passes just fine. For those that might be interested here is a link to information on the varnish http://www.laurelmountainforge.com/finish.htm. Rick Schreiber Valparaiso, IN lmforge(at)earthlink.net http://www.matronics.com/contribution From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Nov 25, 2008
Bill, You are right about letting oil modified urethanes cure for an extended period of time before applying fabric. This is true of any varnish that cures by oxidation. Epoxies or 2 part urethanes cure by an entirely different chemical process and should be ready for covering in 24 to 72 hours. As for the oil modified varnishes, one month would be plenty of time. You may be able to cover sooner, depending on the thickness of the applied varnish and the temperature in the room where the parts are kept. Its best to coat a scrap of wood exactly the same as the part being covered. When the test piece is capable of passing the 30 minute MEK or lacquer thinner test, then you are good to go. I am very aware of the Stewart's water based system. Dan and Doug Stewart are both members of the Short Wing Piper Club as I am. I have attended their covering seminars and have a copy of their covering DVD set and I am impressed! If my facts are straight, the adhesive and primer parts of their water based system have been around for a number of years and have worked quite well. The top coat part is relatively new, but the entire system is certified. I do have some familiarity with how the products are formulated and I think they will perform OK. I plan on probably using their system at least up through the primer and maybe the entire way. Rick Schreiber Valparaiso, IN 5936D PA22-150 ----- Original Message ----- From: Bill Church Sent: 11/25/2008 11:54:11 AM Subject: RE: Pietenpol-List: Varnishing Wood Now, there's an educated reply. Thanks for sharing your knowledge, Rick. I just recently finished "varnishing" my empennage with Minwax's Spar Urethane. I noticed that the can had a note indicating that the product was "improved", and was now quicker drying. That obviously means that the formulation has been changed. What it doesn't say is whether the newest "improvement" results in a more durable finish (the sticker on the lid of the can did not claim it to be more durable, so I doubt that it is). I recall postings from a few years ago that implied that hardware store urethanes are much less impervious to solvents if one attempts to cover soon after sealing, as the finish has not fully cured. As I recall, it was suggested that the urethane be allowed to cure for at least a month before applying solvent-based adhesives (hope my memory is working). I have recently been thinking that the Stewart's water-based adhesives sound like a good idea, and may be the route I take when I get to that stage of building, and I read recently that Kitplanes magazine is planning to publish an in-depth review of the products. From what I have read, the Stewart's products work as well as, if not better than the traditional systems. The disadvantage, at this point, is the relative newness of the system, and the lack of a long-term proven track record. I have no doubt that, with the way things have been going, practically all solvent-based products will become increasingly more rare, if not banned outright. Some may say that the traditional finishes will never be replaced, but I can recall just a few years ago, hearing many people say that they would never be able to restrict cigarette smoking. Same story with leaded gasoline. Change is coming, like it or not. The good thing is that someone is working on solutions now. Bill C. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard Schreiber Sent: Tuesday, November 25, 2008 11:33 AM Subject: Pietenpol-List: Varnishing Wood I have been reading the posts recently on varnishing wood with interest and would like to add my 2 cents to the discussion. First a little history. I have worked in the coatings industry for over 35 years serving as a Technical Director for various paint companies supplying coatings to the international market. I now own my own paint company supplying high performance coatings to the firearms industry. The formulations ... . Rick Schreiber Valparaiso, IN ________________________________________________________________________________
Date: Nov 25, 2008
Owen, The Indy project is moving forward again and the last bit of structure is being completd now, the motor mount. The aircraft is structurely complete now and is covered and painted. Engine has been completed and run. Hope to put a few photos on the chapter website soon. Ernie ----- Original Message ----- From: "Owen Davies" <owen5819(at)comcast.net> Sent: Tuesday, November 25, 2008 9:13 AM Subject: Ernie Moreno? Was: Re: Pietenpol-List: latex house paint (OT) > > Among other comments, Oscar Zuniga wrote: >> I do value Ernie Moreno's input. He is a Tech Counselor and has quite a >> number of fine projects under his belt, is extremely generous with his >> time and talent, and lives at the Independence, Oregon airpark that >> spawned the "Noon Patrol"... (etc.) > Speaking of Ernie, it's probably time for me to goose someone about the > Independence Flyer ultralight project. How's it going, Ernie? Is it going > at all? > > For those not familiar with it, the Independence Flyer is one of the > Independence EAA chapter's group projects, a well-designed ultralight that > closely resembles two of my favorite antiques (well, not MY antiques, > alas, but you get the idea), the Aeronca C-2 and C-3. It seems to have > been pretty much on hold since everyone there got Nieuport fever. If I had > a few doubloons to my name, didn't live about as far from Independence as > it's possible to get without leaving the continent, and had an > ultralight-friendly airport less than 3 hours drive away, I'd offer to buy > the project, just to see it completed. > > Owen > > > ________________________________________________________________________________
Date: Nov 25, 2008
We in the ultralight field have been painting our planes for years with latex and with great results.It lasts longer from UV than most paints and weathers better too.Real easy to apply and clean up as you know is a breeze. ________________________________ From: Bill Church <eng(at)canadianrogers.com> Sent: Tuesday, November 25, 2008 1:41:48 PM Subject: RE: Pietenpol-List: latex house paint Oscar, This is the first time that I have read that John Dilatush's (now Greg bacon's) Piet was painted with Latex. Is this a recent discovery? Bill C. ________________________________________________________________________________
Date: Nov 25, 2008
Ben and others contemplating using latex house paint as a topcoat. Be very careful thinning these products with a lot of water for spray application. I don't want to bore everyone with the technology, but this is how these products work. The base resin, whether it be acrylic or Poly Vinyl Acetate, is basically composed of very tiny spherical particles of resin, water, coalescing solvent, emulsifiers and some various other magic ingredients. As the water and coalescing solvents evaporate, the resin particles get packed closer and closer. Finally they are packed so tight by capillary action that the coalescing solvent migrates into the resin particles and causes the resin to "fuse" into a continuous film. Without the coalescing solvent or if its in the wrong proportions, the resins do not coalesce and the coating turns to dust. If too much water is added, it can severely impact this process as the water interferes with the fusing process. The problem with doing this on an aircraft coating is you would have no idea how severely this has affected the paint. It may appear to be ok, but you find out later that your latex topcoat starts to lose adhesion to the primer in the slipstream when the plane goes over 60 mph. Just remember this is not just a cosmetic issue. If the primer or the topcoat starts to unzip on the wing, especially in the leading edge area, you could be in for a world of hurt. The airfoil could be affected the same as if it had a coating of frost on it and stop flying. This is why the FAA is so adamant about following the STC for coatings systems. Its not about cosmetics, but flight safety. Rick Schreiber Valparaiso, IN > [Original Message] > From: Ben Charvet <bcharvet(at)bellsouth.net> > To: > Date: 11/24/2008 9:19:07 PM > Subject: Re: Pietenpol-List: Spar Varnish, glue alternatives > > > I experimented with Floetrol, windshield washer fluid, and plain old > water. The floetrol gave the worse results, and I couldn't tell the > difference between water and washer fluid. I was honestly surprised how > nice it went on with the HVLP gun. Getting it thin enough must be the > trick, and I was probably using a little more pressure than I would use > for an auto paint job, because there was more overspray. One thing I > did do was spray all the pieces flat so I could put on a good wet coat, > the water reducer/thinner allowed it to flow out very smooth. The > Sherwin Williams latex is quite thick, so I am using 2 parts SW to one > part distilled water. > > Ben > Oscar Zuniga wrote: > > > > > > Ben; > > > > I'm quite interested in your latex application technique. You say "thinned". Does that mean you used Floetrol or water? Two completely different things, as I understand it... water will thin the paint but Floetrol makes it flow out. Not sure how much of that is product hype and how much is real. Either way, one or the other is necessary for shooting latex from a regular gun so I'm curious as to your technique. > > > > > > ________________________________________________________________________________
Date: Nov 25, 2008
paint (OT) Ernie Moreno wrote: > Owen, The Indy project is moving forward again and the last bit of > structure is being completd now, the motor mount. The aircraft is > structurely complete now and is covered and painted. Engine has been > completed and run. Hope to put a few photos on the chapter website soon. Good news, indeed, Ernie! I'm looking forward to hearing how it flies. Owen ________________________________________________________________________________
Subject: NORDO news
Date: Nov 25, 2008
The latest issue of the "NORDO News", newsletter from the bunch who runs the Lee Bottom Fly-In, includes some pix of Piets, including Mike Cuy making smoke, like on the Sunday pix from the fly-in: http://www.smugmug.com/photos/swfpopup.mg?AlbumID=6580047&AlbumKey=haLgg Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 26, 2008
Subject: Just A Few More Days...
Dear Listers, There are just a few more days left in this year's List Fund Raiser. There are some great gifts available when you make a qualifying Contribution and there's plenty still available. Don't forget that its *your* Contribution that keeps the computers running, the electricity turned on, and the computer room AC cooling! If you look forward to reading your List email each day, won't you please take a minute right now to make your personal Contribution? Credit Card or Paypal: http://www.matronics.com/contribution Personal Check: Matronics / Matt Dralle PO Box 347 Livermore, CA 94550 Thank you for your support! Matt Dralle ________________________________________________________________________________
Date: Nov 26, 2008
Bill Church wrote- > > This is the first time that I have read that John Dilatush's (now Greg > bacon's) Piet was painted with Latex. > Is this a recent discovery? Well, I went back and re-read the info from John (down near the bottom, at http://www.westcoastpiet.com/steve_eldridge.htm ) and it actually says that he used the Fisher method, which involves black latex house paint as the primer, weave filler, and UV protection, and then applied automotive enamel over that. So I was only partially correct in what I said. On a completely different subject, I just noticed that Mike Cuy's Piet has brass leading edges on the prop. Hmmm... I don't remember seeing that in the construction videos. I sure like that look on a prop for these airplanes. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 26, 2008
I realize there is much I do not know about many things so it surprises me to learn that an automotive paint which I suspect would have been a solvent based enamel could adhere to a latex paint. It stands to reason the two materials are vastly different in chemistry and properties. The typical enamel automotive style coating would be a brittle material more rigid and with little flexibility other than its own expansion properties where as the underlying a latex material is a more flexible rubber type material with greater flex capability. When the skin needed to flex under load, the top coat automotive coating would be resistant to that mechanical stretching and begin to lose adhesion to its latex bonding base and chip off perhaps causing the cloth to follow. Although the use of automotive paint sounds attractive and would permit a nice smooth and highly more aerodynamic surface it doesn't sound practical over the latex base. I suspect one would have to uses an automotive primer, base coat and clear coat system to do it all properly. These are my own though's of how materials work and behave. I call once again on the collective wisdom and science of the experts and the coating Gods to show me the errors of my ways and point me the direction of truth. I would love to use a latex base and get the ease of application and cost benefit and the automotive finish topcoat if it is possible, practical and does not compromise safety of flight. It seems that like the airplane the coating systems are a series of compromises and there is just something about a wing loosing its covering in flight is just a bit more adventure than I care to experience. John In a message dated 11/26/2008 8:44:46 A.M. Eastern Standard Time, taildrags(at)hotmail.com writes: --> Pietenpol-List message posted by: Oscar Zuniga Bill Church wrote- > > This is the first time that I have read that John Dilatush's (now Greg > bacon's) Piet was painted with Latex. > Is this a recent discovery? Well, I went back and re-read the info from John (down near the bottom, at http://www.westcoastpiet.com/steve_eldridge.htm ) and it actually says that he used the Fisher method, which involves black latex house paint as the primer, weave filler, and UV protection, and then applied automotive enamel over that. So I was only partially correct in what I said. On a completely different subject, I just noticed that Mike Cuy's Piet has brass leading edges on the prop. Hmmm... I don't remember seeing that in the construction videos. I sure like that look on a prop for these airplanes. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net **************Life should be easier. So should your homepage. Try the NEW AOL.com. ________________________________________________________________________________
Date: Nov 26, 2008
John, Flex agents are available for automotive paints.works well, highly caustic, though, and you would definitely want your own air supply. I learned this the hard way, and, for that reason, am very interested in the Stewart System. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (endless metal parts!) (12 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com Sent: Wednesday, November 26, 2008 6:10 AM Subject: Re: Pietenpol-List: latex house paint I realize there is much I do not know about many things so it surprises me to learn that an automotive paint which I suspect would have been a solvent based enamel could adhere to a latex paint. It stands to reason the two materials are vastly different in chemistry and properties. The typical enamel automotive style coating would be a brittle material more rigid and with little flexibility other than its own expansion properties where as the underlying a latex material is a more flexible rubber type material with greater flex capability. When the skin needed to flex under load, the top coat automotive coating would be resistant to that mechanical stretching and begin to lose adhesion to its latex bonding base and chip off perhaps causing the cloth to follow. Although the use of automotive paint sounds attractive and would permit a nice smooth and highly more aerodynamic surface it doesn't sound practical over the latex base. I suspect one would have to uses an automotive primer, base coat and clear coat system to do it all properly. These are my own though's of how materials work and behave. I call once again on the collective wisdom and science of the experts and the coating Gods to show me the errors of my ways and point me the direction of truth. I would love to use a latex base and get the ease of application and cost benefit and the automotive finish topcoat if it is possible, practical and does not compromise safety of flight. It seems that like the airplane the coating systems are a series of compromises and there is just something about a wing loosing its covering in flight is just a bit more adventure than I care to experience. John In a message dated 11/26/2008 8:44:46 A.M. Eastern Standard Time, taildrags(at)hotmail.com writes: Bill Church wrote- > > This is the first time that I have read that John Dilatush's (now Greg > bacon's) Piet was painted with Latex. > Is this a recent discovery? Well, I went back and re-read the info from John (down near the bottom, at http://www.westcoastpiet.com/steve_eldridge.htm ) and it actually says that he used the Fisher method, which involves black latex house paint as the primer, weave filler, and UV protection, and then applied automotive enamel over that. So I was only partially correct in what I said. On a completely different subject, I just noticed that Mike Cuy's Piet has brass leading edges on the prop. Hmmm... I don't remember seeing that in the construction videos. I sure like that look on a prop for these airplanes. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List e the es y - MATRONICS WEB FORUMS ======================== _____ Lifoptin=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000002">Try the NEW AOL.com. ________________________________________________________________________________
Date: Nov 26, 2008
Gary, Where would I get information on the Stewart System is there a web site I can review to become familiar with their system? Please advise Thanks John In a message dated 11/26/2008 9:40:33 A.M. Eastern Standard Time, gboothe(at)calply.com writes: John, Flex agents are available for automotive paintsworks well, highly caustic, though, and you would definitely want your own air supply. I learned this t he hard way, and, for that reason, am very interested in the Stewart System. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, working on fuselage (endless metal parts!) (12 ribs down) ____________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC@a ol.com Sent: Wednesday, November 26, 2008 6:10 AM Subject: Re: Pietenpol-List: latex house paint I realize there is much I do not know about many things so it surprises me to learn that an automotive paint which I suspect would have been a solvent based enamel could adhere to a latex paint. It stands to reason the two materials are vastly different in chemistry and properties. The typical enamel automotive style coating would be a brittle material mor e rigid and with little flexibility other than its own expansion properties where as the underlying a latex material is a more flexible rubber type material with greater flex capability. When the skin needed to flex under l oad, the top coat automotive coating would be resistant to that mechanical stretchin g and begin to lose adhesion to its latex bonding base and chip off perhaps causing the cloth to follow. Although the use of automotive paint sounds attractive and would permit a nice smooth and highly more aerodynamic surface it doesn't sound practical over the latex base. I suspect one would have to uses an automotive primer, base coat and clear coat system to do it all properly. These are my own though's of how materials work and behave. I call once again on the collective wisdom and science of the experts and the coating G ods to show me the errors of my ways and point me the direction of truth. I would love to use a latex base and get the ease of application and cost benefit and the automotive finish topcoat if it is possible, practical and does not compromise safety of flight. It seems that like the airplane the coatin g systems are a series of compromises and there is just something about a win g loosing its covering in flight is just a bit more adventure than I care to experience. John In a message dated 11/26/2008 8:44:46 A.M. Eastern Standard Time, taildrags(at)hotmail.com writes: --> Pietenpol-List message posted by: Oscar Zuniga Bill Church wrote- > > This is the first time that I have read that John Dilatush's (now Greg > bacon's) Piet was painted with Latex. > Is this a recent discovery? Well, I went back and re-read the info from John (down near the bottom, at http://www.westcoastpiet.com/steve_eldridge.htm ) and it actually says that he used the Fisher method, which involves black latex house paint as the primer, weave filler, and UV protection, and then applied automotive enamel over that. So I was only partially correct in what I said. On a completely different subject, I just noticed that Mike Cuy's Piet has brass leading edges on the prop. Hmmm... I don't remember seeing that in t he construction videos. I sure like that look on a prop for these airplanes. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at sp; (And Get Some AWESOME FREE find you for -Matt Dralle, List e the es y - MATRONICS WEB FORUMS ____________________________________ Lifoptin=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000002">Try th e NEW AOL.com. http://www.matronics.com/contribution _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?Pietenpol-List) **************Life should be easier. So should your homepage. Try the NEW AOL.com. m00000002) ________________________________________________________________________________
Date: Nov 26, 2008
John, You didn't try very hard. I just googled "stewart system" and the company website came up as the number 1 site. Or just click here: http://www.stewartsystems.aero/ Bill C. ________________________________________________________________________________
Date: Nov 26, 2008
I suppose not, I goggled it and came up with a dozen Stewart's one of which was Martha and I know she's not coking up coatings in her kitchen so I figured I would ask rather than waste time on whats Martha up to today! Thanks for the link John In a message dated 11/26/2008 1:23:38 P.M. Eastern Standard Time, eng(at)canadianrogers.com writes: John, You didn't try very hard. I just googled "stewart system" and the company website came up as the number 1 site. Or just click here: _http://www.stewartsystems.aero/_ (http://www.stewartsystems.aero/) Bill C. (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?Pietenpol-List) **************Life should be easier. So should your homepage. Try the NEW AOL.com. ________________________________________________________________________________
Date: Nov 26, 2008
Auto paint was used on my wing.=0A=0A=0A=0A=0A_____________________________ ___=0AFrom: Gary Boothe <gboothe(at)calply.com>=0ATo: pietenpol-list@matronics .com=0ASent: Wednesday, November 26, 2008 9:36:27 AM=0ASubject: RE: Pietenp ol-List: latex house paint=0A=0A=0AJohn,=0A-=0AFlex agents are available for automotive paints=85works well, highly caustic, though, and you would d efinitely want your own air supply. I learned this the hard way, and, for t hat reason, am very interested in the Stewart System.=0A-=0AGary Boothe =0ACool, Ca.=0APietenpol=0AWW Corvair Conversion=0ATail done, working on fu selage (endless metal parts!)=0A(12 ribs down=85)=0A=0A____________________ ____________=0A=0AFrom:owner-pietenpol-list-server(at)matronics.com [mailto:ow ner-pietenpol-list-server(at)matronics.com] On Behalf Of AMsafetyC(at)aol.com=0AS ent: Wednesday, November 26, 2008 6:10 AM=0ATo: pietenpol-list(at)matronics.co m=0ASubject: Re: Pietenpol-List: latex house paint=0A-=0AI realize there is much I do not know about many things so it surprises me to learn that an automotive paint which I suspect would have been a solvent based enamel co uld adhere to a latex paint. It stands to reason the two materials are vast ly different in chemistry-and properties. =0A-=0AThe typical enamel aut omotive style coating would be a brittle material more rigid and with littl e flexibility other than its own expansion properties where as the underlyi ng a latex material is a more flexible rubber type material with greater fl ex capability. When the skin needed to flex under load, the top coat automo tive coating would be resistant to that mechanical stretching and begin to lose adhesion to its latex bonding base and chip off perhaps causing the cl oth to follow.=0A-=0AAlthough the use of automotive paint sounds attracti ve and would permit a nice smooth and highly more aerodynamic surface it do esn't sound practical over the latex base. I suspect one would have to uses an automotive primer, base coat and clear coat system-to do it all prope rly.=0A-=0AThese are my own though's of how materials work and behave. I call once again on the collective wisdom and science-of the experts and t he coating Gods to show me the errors of my ways and point me the direction of truth. =0A-=0AI would love to use a latex base and get the ease-of application and cost benefit and-the automotive finish topcoat if it is p ossible, practical and does not compromise safety of flight. It seems that like the airplane the coating systems are a series of compromises and there is just something about a wing loosing its covering-in flight is just a bit more adventure than I care to experience.=0A-=0AJohn=0A-=0A-=0AIn a message dated 11/26/2008 8:44:46 A.M. Eastern Standard Time, taildrags@h ildrags(at)hotmail.com>=0A=0A=0ABill Church wrote-=0A> =0A> This is the first time that I have read that John Dilatush's (now Greg=0A> bacon's) Piet was painted with Latex.=0A> Is this a recent discovery?=0A=0AWell, I went back and re-read the info from John (down near the bottom, at http://www.westcoa stpiet.com/steve_eldridge.htm ) and it actually says that he used the Fishe r method, which involves black latex house paint as the primer, weave fille r, and UV protection, and then applied automotive enamel over that.- So I was only partially correct in what I said.=0A=0AOn a completely different subject, I just noticed that Mike Cuy's Piet has brass leading edges on the prop.- Hmmm... I don't remember seeing that in the construction videos. - I sure like that look on a prop for these airplanes.=0A=0AOscar Zuniga =0AAir Camper NX41CC=0ASan Antonio , TX=0Amailto: taildrags(at)hotmail.com=0Aw ebsite at sp; - - - -- (And Get Some AWESOME FREE find you for - - - - - - - - - - -Matt Dralle, List e the es y - - - - - -- - MATRONICS WEB FORUMS =0A=0A=0A-=0A=0A___________ _____________________=0A=0ALifoptin=new-dp&icid=aolcom40vanity&ncid=e mlcntaolcom00000002">Try the NEW AOL.com.=0A -=0A -=0Ahttp://www.matron =0A ________________________________________________________________________________
Subject: Re: Varnishing Wood
Date: Nov 27, 2008
Hi Richard, Thanks for your excellent 2 cents worth!. This is just the type of info that people need to hear so that we have at least half a chance to make the right choice concerning which timber finishes to use. I don't think too many of us will take what you say as an advertisement, it is just great to hear the facts from those who are in a position to know what is happening. Thank you very much! Mark Stanley Japan Ribs, fin,rudder & a pile of sticks ----- Original Message ----- From: Richard Schreiber To: pietenpol-list Sent: Wednesday, November 26, 2008 1:33 AM Subject: Pietenpol-List: Varnishing Wood I have been reading the posts recently on varnishing wood with interest and would like to add my 2 cents to the discussion. ....... ________________________________________________________________________________
Date: Nov 27, 2008
V2VsbCBzYWlkIE1hcmsgYW5kIHRoYW5rcw0KDQpIYXBweSBUaGFua3NnaXZpbmcgdG8gYWxsDQoN CkpvaG4NCg0KTGl2aW5nIHRoZSBkcmVhbSwgb25lIGRheSBhdCBhIHRpbWUhDQpTZW50IGZyb20g bXkgVmVyaXpvbiBXaXJlbGVzcyBCbGFja0JlcnJ5DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0t LS0tDQpGcm9tOiAiTWFyayBTdGFubGV5IiA8bW1yYWxseUBuaWZ0eS5jb20+DQoNCkRhdGU6IFRo dSwgMjcgTm92IDIwMDggMjA6NTA6MDEgDQpUbzogPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5j b20+DQpTdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IFZhcm5pc2hpbmcgV29vZA0KDQoNCkhp IFJpY2hhcmQsDQoNClRoYW5rcyBmb3IgeW91ciBleGNlbGxlbnQgMiBjZW50cyB3b3J0aCEuIFRo aXMgaXMganVzdCB0aGUgdHlwZSBvZiBpbmZvIHRoYXQgDQpwZW9wbGUgbmVlZCB0byBoZWFyIHNv IHRoYXQgd2UgaGF2ZSBhdCBsZWFzdCBoYWxmIGEgY2hhbmNlIHRvIG1ha2UgdGhlIHJpZ2h0IA0K Y2hvaWNlIGNvbmNlcm5pbmcgd2hpY2ggdGltYmVyIGZpbmlzaGVzIHRvIHVzZS4NCkkgZG9uJ3Qg dGhpbmsgdG9vIG1hbnkgb2YgdXMgd2lsbCB0YWtlIHdoYXQgeW91IHNheSBhcyBhbiBhZHZlcnRp c2VtZW50LCBpdCANCmlzIGp1c3QgZ3JlYXQgdG8gaGVhciB0aGUgZmFjdHMgZnJvbSB0aG9zZSB3 aG8gYXJlIGluIGEgcG9zaXRpb24gdG8ga25vdyANCndoYXQgaXMgaGFwcGVuaW5nLiBUaGFuayB5 b3UgdmVyeSBtdWNoIQ0KDQpNYXJrIFN0YW5sZXkNCkphcGFuDQpSaWJzLCBmaW4scnVkZGVyICYg YSBwaWxlIG9mIHN0aWNrcw0KICAtLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0tIA0KICBGcm9t OiBSaWNoYXJkIFNjaHJlaWJlcg0KICBUbzogcGlldGVucG9sLWxpc3QNCiAgU2VudDogV2VkbmVz ZGF5LCBOb3ZlbWJlciAyNiwgMjAwOCAxOjMzIEFNDQogIFN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0 OiBWYXJuaXNoaW5nIFdvb2QNCg0KDQoNCiAgSSBoYXZlIGJlZW4gcmVhZGluZyB0aGUgcG9zdHMg cmVjZW50bHkgb24gdmFybmlzaGluZyB3b29kIHdpdGggaW50ZXJlc3QgDQphbmQgd291bGQgbGlr ZSB0byBhZGQgbXkgMiBjZW50cyB0byB0aGUgZGlzY3Vzc2lvbi4gLi4uLi4uLiANCg0K ________________________________________________________________________________
Date: Nov 27, 2008
Subject: Cold turkey day flying
Well I went up and froze my buggers for about a half hr today.- It was 27 degrees, but I just had to go flying.- The old corvair takes a little wa rming up in this weather, my preheater did not do a very good job last nigh t.- The only part of me that even got cold was my feet (OK my buggers did not freeze). Insulated coveralls, a ski mask, ski goggles, and a fleece li ned pilots helmet and I was good.- The problem with the piet is boots.- If I put on great big insulated snow boots I couldn't get them to the rudd er bar, much less move it back and forth.- Hope you all have a good Thank sgiving, and all be thankfull for the gift of flight.- Now I gonna go eat turkey. - Happy Thanksgiving Shad=0A=0A=0A ________________________________________________________________________________
From: Scott Knowlton <flyingscott_k(at)hotmail.com>
Date: Nov 27, 2008
Happy Thanksgiving. You may be a good candidate for the electric socks sol d in the Lands End catologue! Scott Knowlton Slow Piet Builder Date: Thu=2C 27 Nov 2008 08:53:25 -0800From: aviatorbell(at)yahoo.comSubject: Pietenpol-List: Cold turkey day flyingTo: pietenpol-list(at)matronics.com Well I went up and froze my buggers for about a half hr today. It was 27 d egrees=2C but I just had to go flying. The old corvair takes a little warm ing up in this weather=2C my preheater did not do a very good job last nigh t. The only part of me that even got cold was my feet (OK my buggers did n ot freeze). Insulated coveralls=2C a ski mask=2C ski goggles=2C and a fleec e lined pilots helmet and I was good. The problem with the piet is boots. If I put on great big insulated snow boots I couldn't get them to the rudd er bar=2C much less move it back and forth. Hope you all have a good Thank sgiving=2C and all be thankfull for the gift of flight. Now I gonna go eat turkey. Happy Thanksgiving Shad 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D _________________________________________________________________ ________________________________________________________________________________
Date: Nov 27, 2008
Glad you went flying today Shad. I wanted to but there was a direct crossw ind and I'm still learning this taildragger thing. Fingers are crossed for tomorrow. Yall have fun and happy Thanksgiving!! Jonathan Date: Thu=2C 27 Nov 2008 08:53:25 -0800From: aviatorbell(at)yahoo.comSubject: Pietenpol-List: Cold turkey day flyingTo: pietenpol-list(at)matronics.com Well I went up and froze my buggers for about a half hr today. It was 27 d egrees=2C but I just had to go flying. The old corvair takes a little warm ing up in this weather=2C my preheater did not do a very good job last nigh t. The only part of me that even got cold was my feet (OK my buggers did n ot freeze). Insulated coveralls=2C a ski mask=2C ski goggles=2C and a fleec e lined pilots helmet and I was good. The problem with the piet is boots. If I put on great big insulated snow boots I couldn't get them to the rudd er bar=2C much less move it back and forth. Hope you all have a good Thank sgiving=2C and all be thankfull for the gift of flight. Now I gonna go eat turkey. Happy Thanksgiving Shad 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D _________________________________________________________________ Proud to be a PC? Show the world. Download the =93I=92m a PC=94 Messenger t hemepack now. ________________________________________________________________________________
Subject: cold turkey day flying
Date: Nov 27, 2008
Jonathan; You just can't use the same landing technique in gusts or crosswinds that you do when it's calm or the wind is right down the runway. Carry a little extra power and airspeed on final when landing into a crosswind or gusty winds. Hold the upwind wing down and touch down on that main wheel first. Let the airspeed bleed off while you keep the airplane pointing straight with the rudders, hold upwind stick to stop sidewise drift, and let the tail settle down as the airplane slows. Then start breathing again ;o) Believe me, after 30 years of flying taildraggers, it gets easier but never less exciting. And the Piet is the perfect instructor. Do a couple of these landings and you won't even notice the cold! Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 28, 2008
Subject: Just 3 Days Left - Please Make Your List Contribution
Today! There are only three days left until the end of this year's List Fund Raiser. Please take a minute to show your support as so many others have this year and make sure YOUR name is on the forthcoming List of Contributors 2008! Its quick and easy using the secure web site with a credit card or PayPal: http://www.matronics.com/contribution or by sending your personal check to: Matronics Lists c/o Matt Dralle PO Box 347 Livermore, CA 94551-0347 (Please write your email address on the check!) Thank you in advance for your support of these List services! Matt Dralle Matronics Email and Forum Administrator ________________________________________________________________________________
Date: Nov 28, 2008
Subject: cold turkey day flying, varnish
Oscar et al- - The skies over central Arkansas are free of enemy intruders as of 27 Nov. 0 800. - L. Williams TACO xcg, xcmr, epp - ps. The Alan Rudolph Piet (built in the 40's I believe and kept outside or in crude structures for most of it's Minnesota life) was disassembled for r estoration around 2000-and found to have wonderfully preserved woodwork. Upon questioning Mr. Rudolph about what was used as a varnish he stated tha t it was thinned dope. - Say what you will about the latesr state-of-the-art things we all try to la vish on our Piets, but-an awful lot of it is overkill. Just build the dar ned thing and GO FLY!!!=0A=0A=0A ________________________________________________________________________________
Subject: Larry Williams observation
Date: Nov 28, 2008
From: "Cuy, Michael D. (GRC-RXD0)[ASRC]" <Michael.D.Cuy(at)nasa.gov>
Say what you will about the latest state-of-the-art things we all try to lavish on our Piets, but an awful lot of it is overkill. Just build the darned thing and GO FLY!!! This is so profoundly true Larry. When I was building my goal was to make a safe airplane using sound building materials and practices but the ultimate goal was to fly sooner rather than later and not to get caught up in excess pontification. Even using that approach you learn so much when building a plans-built airplane--you can't help not to and that was the original intent of homebuilt aircraft---to fly of course, but as an educational experience. I'm afraid with all the fast-builds and 'throw your money at an outfit' and they will build it for you while you pose with a different shirt and calendar by your project over a two weeks time. ________________________________________________________________________________
Subject: Continental A-65 rod bearing, piston and wrist-pin?
Date: Nov 28, 2008
Does anyone have an old A-65 rod bearing and/or piston and wrist pin I can buy for a non-airworthy need? I am happy to send a money order to anyone ha ving spare parts. I want to partially reassemble my old (worn-out) crankshaft and a rod & cap (maybe with a piston if I can find one) and then make pictures of the fini shed assembly to compare with the way my A-80 engine went back together. (s ee attached photo) I need to mate these above listed items up according to and following the C ontinental Overhaul Manual (and Continental Overhaul Film I have=2C produce d by Continental for mechanics) that we followed religiously when the engin e was being reassembled=2C in order to satisfy a concern about how the rod bearings are attached onto a crankshaft. The manual (and the film) state the casting numbers on the rods all go "up" when the rods are attached to the crankshaft WHEN the crankshaft is bolted to an engine make-up (build) stand and being reassembled. Otherwise=2C the rods can easily go on the wrong way=2C if not following the manual. When t he rods are attached in this fashion=2C it my understanding all the oil hol es on the rod caps are facing in the same direction as well=2C because the bearings have an indentation forcing the rod caps to all "look" or face the same when attached to the crankshaft. The attached picture shows my replacement yellow-tag crankshaft with the ro ds attached. I had one observation from an e-mail I received in regard to t he video I put on YouTube that 2 of the rod caps are showing the oil holes NOT going the right direction. But=2C when the rod caps are installed onto the rod=2C when the rod is mated to the crankshaft as per the overhaul manu al=2C they all will be facing the same direction. This may not be the case for a Lycoming engine but it seems to be the proper way on the "A" series e ngines made by Continental. When I called an A&P/IA who works on my Cessna=2C he read from the manual a nd advised that (without seeing my crank) the rods are ALL installed correc tly=2C if the casting numbers are going "up." I am simply doing this "expe riment" to satisfy my own curiosity and if the rods were installed improper ly (and if I ever actually decide to sell this engine) I want to represent it as honestly as possible and not be deceptive (like the original seller w as to me) in regard to the overhaul. My higher resolution photos all show t he casting numbers "going up" on the crankshaft as described in the manual and the film. After I have satisfied my curiosity and finished my photo project=2C I'm pr obably going to have the "bad" crank and rod powder coated silver and turne d into a cup holder stand for my hanger. Should look pretty wild. _________________________________________________________________ Proud to be a PC? Show the world. Download the =93I=92m a PC=94 Messenger t hemepack now. /9j/4RszRXhpZgAASUkqAAgAAAAJAA8BAgAFAAAAegAAABABAgAMAAAAgAAAABIBAwABAAAAAQAA ABoBBQABAAAAjAAAABsBBQABAAAAlAAAACgBAwABAAAAAgAAADIBAgAUAAAAnAAAABMCAwABAAAA AgAAAGmHBAABAAAAsAAAAPgBAABTT05ZAABEQ1ItVFJWNzMwIABIAAAAAQAAAEgAAAABAAAAMjAw NToxMDoxMSAxNzozODo0MQARAJqCBQABAAAAggEAAJ2CBQABAAAAigEAACKIAwABAAAAAgAAAACQ BwAEAAAAMDIxMAOQAgAUAAAAkgEAAASQAgAUAAAApgEAAAGRBwAEAAAAAQIDAAKRBQABAAAAugEA AASSCgABAAAAwgEAAAWSBQABAAAAygEAAAmSAwABAAAAAAAAAAqSBQABAAAA0gEAAACgBwAEAAAA MDEwMAGgAwABAAAAAQAAAAKgBAABAAAAgAQAAAOgBAABAAAAYAMAAAWgBAABAAAA2gEAAAAAAAAB AAAAPAAAALQAAABkAAAAMjAwNToxMDoxMSAxNzozODo0MQAyMDA1OjEwOjExIDE3OjM4OjQxAAIA AAABAAAAAAAAAGQAAACqAAAAZAAAACkAAAAKAAAAAgABAAIABAAAAFI5OAACAAcABAAAADAxMDAA AAAACgADAQMAAQAAAAYAAAAPAQIABQAAAHYCAAAQAQIADAAAAHwCAAASAQMAAQAAAAEAAAAaAQUA AQAAAIgCAAAbAQUAAQAAAJACAAAoAQMAAQAAAAIAAAAyAQIAFAAAAJgCAAABAgQAAQAAAK0CAAAC AgQAAQAAAH8YAAAAAAAAU09OWQAARENSLVRSVjczMCAASAAAAAEAAABIAAAAAQAAADIwMDU6MTA6 MTEgMTc6Mzg6NDEAAP/Y/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLAQADAQEBAQEB AQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQy gZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVm Z2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS 09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJB UQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RV VldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6 wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9sAhAAHBAUGBQQHBgUGBwcHCAoR CwoJCQoVDxAMERkWGhoYFhgYHB8oIhwdJh4YGCMvIyYpKi0tLRshMTQxKzQoLC0rAQcHBwoJChQL CxQrHBgcKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKysrKyv/ wAARCAB4AKADASEAAhEBAxEB/9oADAMBAAIRAxEAPwDwyO0WRflJB77q998FXhv/AA3Yzl9zmIKx /wBpeD+oqsOvfMsU/wB3qdNa5wPm59a07ZsnnvXqQ3PGnpsaEHSrcb8cHj3rS12Zk6OCByKnRxjt /jWbhZ3LjO6sTRSHGdw/OrEb5wcjjtXPUhZ3OqnK6sTxNmp1NcclZnpU5XiPUninjpUlhRQAUUAB 5qKQBQSxAAHJJxigGfn6JQB99q9a+B+qLcaNdWDEl7aTeB/st/8AXB/OroaS1MsQuaGh6VC+0DNa EE205xzmvUizx5oupcYxnGMdKnW6GMDvWqSephLRWsSC854xx71Kl3+vWrcdCVLsWYL0H0z71aiu gSMYrKdO6NYTdy1HcgYzxVuO5B71wVaL3R6VGukmiZZAe9SI30rlaa0Z3Jpq6Hhs0tIYUUAFcx8S 9QFp4clgXeWuMRuEGSEPX8DyPzppXM6k1GN2fFS6M5Qt5qcHG3qa6v4TO2k+LI4zIGS9iMRUHjPD A9euRj8azTbaNpJJM9mic7QfQ496uQgszBMOUXcQOwrrqY6lTlyvc4qeX1qlP2myJElIH86lSXn0 +ld6meW43HeaSR1qRJmU55x14rRTM3FdCVZm3d/pVmK4YAg5rS9yL2LsE5Pfoeauwz+uR9TWbVzR SsWY7o561ZiuDkYJxXLVgmjrpVGmW4p6mSbNcM4W1PSp1VLTqPDU4HNQakGpXtvpun3F9eyCK3to 2llc87VUZJ/IV4nJ8Qk14S3iRyy3LzEpE/EdvFn5fX5sADPuxGCciJ14UVzTBUp1ZKMFd3R4GIjz sBGOOKZBNJZ30NxCN0sMqugwTlgcj9QKvbUmK95HuQ8S6esa4eSTb85VU5B9OcVueEb6O9tnvlRx EzbD5igZHfj07fhXmzXNWdTzPXoy9nRVN9Cx5RjcoRg//Wp6KdoOTntX0dKXPFSPkK8fZzcbkiqS vcge1PjQ7uufT3FdMUc7n2LEcWO5NSohUjLCtFoZX1sXLeMnp196uxRlWAzzx071m2lqaJN2RYii 5HJ+lWo1x95sADua5pzSV2ddGPNNLocJYePru91K5NsYfs6PiFGjIyuTtJ5zkjrzXceGNTbVLItM EWZGw6pnGD0PPt/I15KxXtJ8ltD3vqapU1PqbAXtmpFGOtamJ4/+0tq19eaJ/wAI/pEMk0YZJb/Z jBA+ZIyT9NxHXhcd68Z8Nazq3h6K5s9S0+a3URmVftETRlT0HBHOTiuXFU4V4ezbNaFWVKTkjaT4 G+P1znToWB7faIf/AIusfUfAPiHw3fwz69a/ZY937tWVTvI54I9P0rWTfYI8qNC3t4oLVjMrmRjy 3mH6AAdv5/yr0/w8FsPD1vbDGQuDnqCeSK5Iu7sdkrRjcuaK0t/HI3lkmM4fHOPTP5GrSSwGbyhP F5mfubgW/LNfQYaUPZpXPl8VCbqv3Xa5bFnKRkRMR67D/OnrbOjZKEY9RiutOPc4HGfVE8cOVJ+U g9KkSA8cdT24o1YXsXrWDAHTFW0hJXGBWVR21Z0Uo9ixHCB2wPauZ+KWsf2P4bNshKz32YlI/hjH 3z0I6ELjIPzZHSuHEVUk2zvw9FuSseOpcy2sMzW5w4RtpxnnGRXR+DvGV7o18k6F7m3dAZY2bhwe Rj0PXH415mHfL7x7te79095jdJI1eNgyMAVYcgj1qh4l1u08P6TJfXsiqAQsak4Mjnoo9e547Ant XW9DhWp4jHdNrGsG51TUp7mKF/N/fKqrkfxFVAyeMgdMkYHAxy3jq9l8Ra1bPfLKdJhYolrBKImU YwW3FWG7oeR2xx1rmbu72KcWoNNn0RN478NQa1/ZMurQre7gnlFW68cbsY7+teKftVahef8ACaaZ Z28cjxx6f5oCjPLO4bj6ItbzWgQaueaeELme51+BZFZ443DSjOMDIHP4kcV69HeOiqu1yu0gMRgM fb6CuWS95JHQ2+Rth4Z8UWWjajcC4Z5EwyOkIHyPlTzkjsTXeW+t2s+jHUwxWDaWIfAbjjHXqewz 3FaK8ZNMwmlOCmjLHjVFhlnawb7OhOJTPt47Z+U8+3NJcePbNY7U2e2WSdN7gsQsR44JAwTyRgeh raVo6vYwpxc3YF+INobOGaK3BklLfumnwQvylWwVzghu6jkEV0ml3sWpWUF2sa/OueRnB7j881fM lsxOD+0jN1Hx3oul6vLps6yvPDt8zyo1IQlQwByQehB4Heku/iDpttPbhbWeSKY43gjcD6BQefzG eapVOrY4UfeScdGWNd+I3h7Qvs63st0DcDcq/ZXUhckZIYDHKn35Bxgg1554z8Qw+MNVE+l3MdzC EVYYdyiRRjkFM5zuyc+mPSsq0XUhdO5dOXsZu6t/X3nJ3Zkt5RHNE8ZJ5DLtPP1pNKM9xFHGkE8g gZsbYiwZPTOOnQ8d1rihKzsenJ3jzJnuPwg8RnVfDhsZo0jn0srblFPPl4+TIxx0K/8AAa6bWrOw 1O3SLUdOS+RG3qjop2tjGRk8HnqK9Dmc9WedLfQ56/8Ahx4cuVDRR3lkchisEhP4YIb9KwdS+D1p NuNnrMkKtziaAMf0I/lUOmuhPO0efajpdndHGqRytKw8yWYkM7seeGzke9Ta82ka/cQS6lrWvvPD CII5EsYGYKM8bjJlup5bJOTmueU7zT6f10O2lTtCyWv9dSjZaT4ZsoGMN3rExkP3pbaJGTBzn5W5 zz1PGBj0pn9tM3mCOZjEt0EHmdI8xgt+GUX9fWsk3OTNGlTirshtLaC+1p9hURS8gAFT2ycjqetb 008k97badC8y20p2sN5G/aruN397GCeadOpOT94mpTgoWiZ3i0M8DoskioqjaM9B9O1efzRlmEu+ R4gCFVmztxk/5+tdL0Vjmik3zEWhapcWWtRsZCyKBGVHQqT6fr9RXuvh7xL9k0yGzR4Ds4GFc7iR vI5xyN2D9D25rGVSNOSc9EdFKjOr7sddV9xga7pdjda5c+IBO5umiZX4PlnauA2MD5gAO/QdK4nx RcXEuspb2d+BstIriOWJiArhgynOOo3H8RUfWIzl7mwvqs6UbVNGc94l1e7lit1nuZLlSwdJZnZp MFRwcngDPT1J68YqaLfTW2pwT28zxyo25XRiCCBxg+tbw0jpoY1Jc0tdTtNN8QRzQiLWgLiGBGkj eT7yYByM45yB07nHtjZ0CwW11aZ5LmSa0uceVEw+aNsdmzjGAe3Yc8c5Sqcm5rGm5u6Zu+FPFuua Pe3WkWstvcXghUQ3N9lojGsgzwpBJALgKCBls5AzXovw48av4qs5kvLVbW+tH8q4jU5UOPTPY9R1 78nGT1xqxkknuc8qTV5Q2OtDc0x244yapIxlJWPn7WL7TZJ5FhnPlkZRGfJC8Hrjk9a5DU9R08Ep Y6jGjd/Mjdh19VFclqluh2zlDma1I5L9JLOIRS+dKFwWQMqk556jI71Hp15cRwiF2VDNODKA2RkA Y9M9/wA6zi6ilrYuSp8ulzp/BpdtYlDAny4SwLckgo3H+fT89rw9J9o8ZWNpj70U8pfHQLER/JjV U4+9cKs7RMTxo5N55CzOiwQmRthID9Rz7cfrXD6leQjzFg3bRvABOTjnGT610JpnNK8TCsJF/tOP c20F1yWwMc17pothp0lh5r3YE6uRJCwSLIx0WRzgZHfoO/es6sObS1zSjU5E9bFCwS/uPD+ozX4t LOQiVo7eC5R/MVV4Y5O4kkMOnv6Z4bx3D/ZM2ieS6+fJpCNcc/cfey4Izwdqj86ypxSla1jSvUco 3crs4jUZzJKOoVcYH0qSKVxslQgEcZNdfLoccmdNo0qzywGUZRmUOvXPOD+Fdf4c1K4k8OaXE+6R pmt08zaWYbc9WOdq4JHXHKjoBjlrU1KNmdOHqWd/I9E8N+FJLrWo7iQrA0cTYd227QwHB+vAq38P rC9sPiV4viSaFrW3ltfO2gnLGD5cH27+9bKm1JMmtUTp8qPQRcKM4IHrSNcDs31xXZY8yUkfHmr6 PrOkeIHtr19xibETAhgy9unQY7HmrMOiW81r5l3bFXAz5qzFcn6EGvOqVlHVbHs0KLm1zLUk0bRr uNijxzbJSDAHlU7RwSSAO49xjPIOKtakj2Fy0LyExCVJAM8fd21POptWBwlCLR0Hga7jl1yQ9I3h ePcem4o4A/Enj6V1WjwHSfElvczjZMY3ihz0IeM5/wDHea1hHUwm3ZHK+ObRzqct5HcNGmzynhI4 fOckHPHX37Vx8mhsJAbIFix+4cYB+prOc/Zs3px51fsyPxD4bh0z7AYj80m4zy7iygjb+Q5OPWul fXZbeSJoWYFFBjwODkdfUdqqNfmipLcj2HJJxexmavrN5LYNbq0YR2yFQYK59Mdvr7VQ1a1ute1i e+twrA7cq3Bc4PIyccYXP1pSq294unQU5KPQ5vVbNYrox/OJVB37iMZyeB7YxSWMIk+QsVB5J9B3 /HpW6ndXRyyp8krNHV2lt9lhMReOJord7nJJwPLRiqHGeWIAHuw55r0HwVp1pMNJ0qG5VZ4Egkm2 Lu27PmPPPXb3H8VRO9i6eklY7L4z6uln4fttP0u6+xXs0qyQrahR8iAhgw6kDcowCCDtPbB4r4b6 pdaRZTWyXTJqFzNJc3M0kYJmY9MAjjgdOnU554mpUa2RtToNWkzqV8Ravj/kIYK9QY1HPftTj4i1 VoWaK+DANjcY05/Ss1ip9QeDpp6bni0F5JqHiCW5kYnzJWkG7sD0FdL4bsDf6vbxsreVu8wkc5A5 /InFY4hI6sK29WdVqEEcUcjKuGC4ya4TW4/tM6yABQnLb/T/ACKwoTUXqdNWHM0itYs+nECCVc5y HRsbfTv25rW1XxAr3ltJZTs8VswIDLjc20hiPm77n4I/+t2/WI2UonEsLLm5ZFa/1dtUXbIMKP4n b9OKzZjtbzAUwPY/41hVq870NaOHdOLT3NB9ZhWDYhjaQDOwjn+dUJLhJUyNit7L15rGlBpm9SSl oUJ5ssG3KzLjv0q9ZXkcMnmpGmWwGwvNdFSN0ctJ2dkY+tJHNqbM+du/JAx0zWdthtrjliFPQ9SO /Y9arDyaST2KxMIybl1NO41hBaCC2j3lyDM8qj58HheDwMgflXT/AAu8QeGNLGoT+Jp9RS4YItt9 kjVmBBYlgxB2npzweOpBwOl2aPO1T7GTqvia41nxBbXrpKkKXDCOB5jKyCTjlzjdjCjOOQorftla K9iIJUhiVIHHt/Ksmr6M7G4/ZOplnyTJ8uxxkLnrnpVaO4dWyQWj7DjIFYxjZBOXMzzfREIT7R5w bduHlqOR0xk5969D+HUYeKeXewYJt444P/6qyxLep14RLQ0vE1wRZ7Q2M5OfSuB1uVo4maQ4J6N/ MVnTWhpUfvGOt2T/AMtTj+8y80jGN8BWZz1IArRRsNyu9SUQqsW5sc9vQVHIgyCg9KqLCcGkRxwg N5h++epxSfvoz8pPXNa30OVqzJbq1McccvmKxcfMMYwaqsNnOF9xQndGc48rIpGEnzEZ9yTk1Vu4 1mXkEd+KI3TKk9GQqMxggHn1pAeMAc10HG9y2QZLVguNxHA/Wu6s70SaBDf26BmJVpAXxj1AHfqf yNZz92Ny4ayszatLh57NnE2U6bM8YqQzSBFVWcEH61gnds6pR0VjgNGil+xksjryW+ZTXqPg+P7P oKMyhHlJY7vYY/8Ar/jWVdptnRQTUVcreJZWJAUqQox07V574snKQRBWXl/m4/H19arDrm0IxDSu YEd4VPCg+h5/xqzBqJZxuLEDkjn/ABrZ09DL2ptwayJN0YRMAd2xipkkSQ7ixGOy85/IVy+zcTvV RSZKtrFIpcFssOjdOn0+lVorQGU/akAQHjDZ3UKo7WInT1uR60YDCNpBA7ZFYMksZb7+F6gg54ro oJtHJiZJPRkAniSQ4c4+lMmuFZABuAznnit+R7nP7RJWYkY3QhskjJHTv2qPlTjB9+as55WvctWz 8NtIAB44616X4B8Om78MxFp/3bOxKbfujJ4H881z16nsouR2YOl7Wqkbtj4Yk+0SR2LM4ZRlHYZ+ pPH+TWkvgzUZgA+1FHH3v8M1eEw88QucyzOrDC3pu+pxtpBbh1UR4G7ccjHeuvVRFbxjGAFAAHQZ /wD1158n956tONruxz2sOsrEk8n+VcZqFpHfXKK+7aM4Ga7MJG8jzsfO0B1v4ZtGwSCCecZrSsvB UEybhjr37/pXbOMUrnmwqTbLq+CwAQkm3Pv0/SnJ4Jk35W4PPo1YuNI6FVrbF208ISIMZVzjqx5/ lU83guaQcPAny465z+lYONJPqdEa9d6GVqPgsxLmeVShPRf/ANVZyeE7In94GIHHp/Ku6jCnJaHn 4irVWkzSsPCekkrvtiR3LOf8a27Twxo8OCLCE44yRniu6FGn1R59StV76HJ/FXSraxksLi0WONZY 3jEMaBQNhBz/AOPgfhXAEYmYAAkc+tcFZJTaR6VFt0ot7l3S4d8i787ev1r1T4VXxSSeDafk+YoT 99WG0jHqOCPfFeXjruNkevlslCV2dpocxs9YglIOzeUYZ7Nx+mQfwru3GOq9668ok+SVzm4g1nH0 PBNJjaeRAxG98AgdvSuq1GQR27sinvgevYV5krLU9SDb0ZyGoz4+VuRnjA9azrW2Ms+4AkduOg7f zr0cLozycfdo37CyiBG9046KDW1AiKMAjpXRUldnHThbcnUY98D1qRFAPasTVE0ZAckAg/5xVqJl 75/lWM0dFOVtyG/gjuYGT0+6a5u6sniYll4/veldOFqW0Zz4qF9UTadCZXIYbQOrVbi1LTLoyW9l dLLNbyPHKuCCGXAbqOcZH516Cq2djzvYtq5hfEi2a78HvJDCrNbXKSPKRykZBU4PuxT8h6V5Q+AM kEZ6n3rmq/xJM6MM3yJPoaFuoUR4BAx0Ndp8NTJ/wlMAAOx0dJDnAxtyMnoOQvP1rhqq6Z6dHoep 29mL11+zkSMQCVX5ivscA4/HFdfM22Jd25SFG4HkjjpSyuMoJtrQ1zqpTnZJ6nz34U8T6Vtjnln2 k8lWAGDXQapqtndWmLS5jlPAIRgSPwrnr03GdjooVOandbnL3E3n3LDcMY/LtXR6LbLHaxHOSyA7 j7810U9LI4sQ1LU2oQMYx3zVtQO4OfXGa1sct0kSIi5JwCM9KcsMOc+Wme2RzUST7mkWi1FBb5GY IiB/sipoYrNSB9kg+UYA8sZFYTUn1OqMoLoSxpbRuGW1t0C4xiFfXPpz17+gqSfyJbcxvDFjocLU JTvuay9m1flI7QpapiFEVepx3rz3TbYWHjHX4QpkZ7sytMzfdEqiTGPqMflXVCXLJSZzSXMnBKxt a1p8N54K1eOW4CqbYy4XrmP5wD7EqB9K8Uisbi8uFitYXmkI4SNdxP0A5rtqXnNpI8ynHkp3Z3Ph jwBqTiGTWrd7GFyUTzwQS3YlR8wA+8eBnbjOSAfSPA3hyxsby+tNak+0C2lT7NLENkM6Ntx8q/xB mC8nnjrXFN0+a0jug6tk4rTv/Wh2smpWOnRrbxR+UgHypHFtA/lXP6zqLkTXECy+Uo3EhenvW9Cq ndroc9enKNubqf/ZAP/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEBAQEB AQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGR oQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdo aWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEH YXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZX WFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLD xMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/bAIQAAQEBAQEBAQEBAQEBAQEBAgEB AQEBAwICAQIDAwMDAwMDAwQEBQQEBAUEAwMFBgUFBQYGBgYDBAcHBwYHBQYGBgEBAQEBAQECAQEC BgQDBAYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYGBgYG/8AA EQgDYASAAwEhAAIRAQMRAf/aAAwDAQACEQMRAD8A/hLmuHaAq0xxGmZQxJBI+6Rj8u/QGs5GunmW Jjv/AHLShB/EFHP0OMflXkyrTqJOpLVH1OJcJRnSpq1yXcZo0kQSBNjJvx/ET0B7VatQ4uGEaGAN IP3ca8W0SgKRz1IPP4msm5at9T5+lOeHxahVVrd9v6udbbomdzpMTkTQY+7CB0VSO54OT3pxk2LI blDGZCCioufNToeR6fnXNOc+dU6S1W52YudWnB4yUy/bQXQu4GRQk/mpGFSbkDdkqx6DK/oa/oi/ 4JlfEG5Pg3T9NMpuLq2gks7VrhComjkWTC4xxhOp9MetedgJ+w4royT3v+aNqtSON4UxM29V/k/6 9T96NN2PHaxrI7BImSMbceUuSCp/u4HO4fz6dHp4tBb/AGe4k+z3krMdj3LLLEegkQqeeAOD61/W OBp3pxV9X3P5Hw1KrLE129fT0N9fPfDeWjSyR+U0u7Hk4OckDgcdB6nPrVq2jSNrY5WOEoLV4mbD RA9ATzlwM4JrmxdCCrpqWuwqFevS5qUlZ/mblvAbiObzcRzRMI9pm3xwjkICOASFOckd8ZreUtug SGGRzlLmGR5h8uc4XbnORgnmvVozjSlax52JrYjD14+yd4ve5cDxCbfcQSzo6loYGlMbSFWyDkHu OfTgetSQ4M00hKxkf6PNGwbCZ5xgdeCetYe1jKo4X1KqSpOUnVqXXSxeRIhBIYyJAskpMqt88q5J wR2yR+RNX0PlhBIsQVIRcF8cQFV3Fj9MkAD0q61SnGrGFLr+BLpyr4J06UrNdyZUZk/ewTyIsgmD W1wyy3DsAVUdhnr79637R1lZZRHCI5AgWzlnA+cA5yQeuQQR6mumjXVNclWN0eBRwONqS9vi3eJq RAgRx4ji2QyNPFGQVddwzuJ9OgP/ANatS1lgSaKRoWmjtpTGlq0wQJG/G4n27fjW/tKNaVqkT0vg 0iaVkskMdsjIk0q7ozJLNyWySuF5zx3JGMVpWsTiRULOsLXLTTKrgsCV5Jzk4HH5DpXVyUasVJrQ Uq/1dqq1qyz5GFbDgkQloYgSiJ1LAY6FjitO3jE0LxRxXAmimFwZAxOwrwSxyM84HNe3hKqlT9m9 0ebj8zwqbq1YpOXkalvbwRyealukc7zeTeK1yX+fHBx0Hbj3Na1uuZJoJrSN3UqkFzLcBVCrnIUZ 5yOufwrmw06Km5T3PAxUqVFRxdJ6v+v+HLnzkowDO+2JE3ceYOeNp7Zx+QrStrWGOOG4CNINQuRN G0shCu8XDDaeFxmtMwqKMFQhU5ZPXqc+ErYiePdaVLmhtbT79SwEaT92YwZRKrGPIKqoG4EY65/Q jitqSKbzZU8mWKGIocNc5eUnBHTkcc84B5FfO4n206UJ15Xa0PscNicLFSwtGmrO9/UuSwyozeVF byzTmKISyzEMke/c/wAo74/vCr/kxYtyVDbZHkx1JQH7p9s4468120KahTTluzgqYuUJWT5UW2RQ TFPhpw3kzkjJjdV3op7YOent71dg06Yxlo7aQwxXAtI7jeG88sMkBc9T2+vtU0MPCnepF7nJUxbq 11F9TSaNyp36eljPcwolz5bbmlkAKDcvqAOvvU8COIwVhDeTLHCY9xDJ1HJ9cc/lXTKnJW5kVLEx rQdKCty9S9bogngkiRDM8TyX8r3ZO1zkJtUDjgevUVKiKImkKIwVhHO7JuLnH3F984JPPpTacXaR z4GvKXMpS110+RYWGDZJcPZRXE8i7GdZCPJdV4OMckgn29c1PPGnnExQyb/NW2nUXAJChMqVU9Rz k49KcKNWd5U0cFenONZxk99f8i7Fh3IEBVmIgO+Xbgbc85+g6etOWF99tNEp8+JQGjluiQjkc5bH I9OOhrDG4aHsOTEK68uj6df0+Z6eR0K2EqWdZKb7vp2+F/mvRlyNWZnWSyZYobSWSNoZCzSlScnP qckjHap0tooFMclnLc3It1it5Dd82wVN2SP4sj/Pp87RlOEJUZarvZX/AF/M+ynN1a6p19PRv/gf kFuhZzbrZ2ZR44jplwt4cROgO5mBAx3A5PerItkicp5DAkENsuA2w4PIxxyT1rGGHtV9tzGqq0cP OUVC36mgttslnjk8mMon2pzISfPDKCEXGcMeOOKabcQOcwIJFXEiA7dzdjj1H9K6FTUW5LqcHvzm 13Hw7ZJFJhMrKjIUicjfjk5PcD+lWtqmHYSsSxdBIwJyT07twBz9aww7rKU/abDxGDdO3tlcmkSW ZpnGnT3y27eZ9jgdRKqj7mXJC9ee3FWECM+S0cZYHc2wnIHUD3zgflXUouzZ51XEw5lBdCSMQiKM LBLEVgG4NJlpJM5y2MjoccHnAqSYMR9jlXzUVzbpau5WKJs5yTjgdR19KcI80rS0RVevUoTTtoSQ xAlpzYrDK8LtHcrc70uIVJwpXgg5JP4VelEIaaY27OyW6pG8l06g8c8epP8Ak04wk63LDVnNWr1p QtKGjJvL8oCBkZzG+9AWGQc845q1CNxRYkBZweJJwvnru45pZ1Qo+wdSpNRV+1/wFkeJrVMd/ssH Ly5uVv5lyNIjI7C3SC4SXzHuxICtyCOVBHoB9MVKsbAxyGEkmFtzebgy/MSQARgA/wBK+CqunTm4 UZcyWzta/wAj9bwnPVhH28eW6u1f9S1/rFRCoizCWWDzAxCZOd2Oh68elSwJGwliIVYdn2b96d2w HB5z16f1rDVK4Tm/4afuixxRjaktsiXUF0YQsr8WwAK9exIOfap2Yee16LPY4t0t4f34+RN2CfXB 64Jyevaqk07ClVa/dQfulxUdLibeo3I5RiACQeOMjsKmALiJgNsci+YRgESnsfUEYP51Nla9yY8q 95LQfsRJJSlvNHHG7mVJ5NzkA5LEjoOTwOnoKkCliY/LyobekYfDc54GfYDn6U1ZJyb0HaVWShDd l8wuWsrgIoEVw0kJVsBGA2suO+N/XpzU8YjAkiBMTSyEQgvg7QMEj8cc/SvKxuNU8I6mCqaJ2ej6 +v8AkfW5TlEqWZww+b0W5WbXvLp6efmkTPiPYqQssIVXMO/dtOM546kmpmESNMDGMggxx+ZuC/iM Z7V8tUhGDSjNP0v+qR+i0as6qbnTcfW36NkzQFCYZI1eNXWaSVJMcckZGf5Vby6TsggJuI5Ps/zD AJI+bHOOneszYnVVYIsREaPHiE5+4CeCf/r0Iwc8dAxBGehB/wA/nQBYRSXYBTHnKJnnPB+X9aaO ABtyijdsY9Scf/WoAvsDs8vywXEKh2LY8of5H6VJkEl+PmYbFDdTj9CRxQBKq8qMEhTvHOOnQcfX 9KfnDggfP5bBcc5HegBPmSNEUKViQRhFGAoz2o5KNuXhuN2fu9aAHjC4BUls59iOP/rVIqsCcqMG bZ5RPUj/AD+tADv9aXGNi7zLIevFSAHYGaMAIolYgj97k4XjtxmgC1sx5TMgCgoNm/7h7HPt/Whx 86HAJP7iTAxjIzmgCwdoJbI67WHp7fr+tBGxGJG1UGBzngUAKrDLLwWVuQD7UhUEOCMBz83PXj/6 1AC7SgVV4A+UD9BT8jI5wQORQAgJOAehzz/eppIwMNyPbrQAZweG4JyTilJGPvcg56daAGscnPt+ VGeOvfpigBCc45zx6dKPSgBSeRg5wOOKOOfm6+3WgAB9TjHTijvndzn0oAAcE/Nj3x1pM8HnqeRi gA7cHOevHSgHGRnGRzQAAkdKdnIyW5znGKADOMkNyeoxTep5PHrigBeg4bOevFICemcA9eKAHDA6 P/47TSffOeTx3oAXgZw3b0ozkHLfhjrQADp1xg5AxS9MZPHQcelAASM5Bxz6UobqCfocUAKW46ZU njmk3YAGMgjHWgBAR83y7cHAOc5/z/SjZuyDnaf/AB4f5NAEbgcvk/cKZB/1a8kn9BVZoeMGPMsg w+W4YdSvHsKAIXjzhxGq/ulwA2SPT/CokiJJXYDhCu1m/i6/0/SgCMLhdwz8rhSAcH1HP5/lUeOM NggjnjtQAOMlG5UoMtkk5PQH244xUUqrhvl3ZGDk4BIPy/r/AD5oAgnQmQyL9+RfLC7/AL23kfTB JOe9UfKyAVUlW2op6B26nvnP6UAV3iCkuU+YAgsDkgNz+uB+VU5oDLcfNhE2Kxffy2fbt6UAf4aV tp0RW3VpUW6jcRxzvyYHVgS7rjBGC3Qdq0YtItRLM28ENK8IMqAhRyCwP+0ASAema+bxH1iU26Ks j36WLWCk6OIjdotNoSKpVUQlpRNBggfZz2z2I9fr7UtnYxvBG8luZInu1d4mG1mCtnLd+MD8uK2i 5OKc1qY5jSWNtiF01NOCzW2kklAM4E53kfIJGyOjdgMnipLjTQ6FSQjgG6jRMArIuWX6HHHPHP1r WlyOdqu2v5HNiuXE4SFJRelr/INLRw6iSVczTfuZn4Knj73r37Cv1j/4JveNJrLWJtHunDML1ms4 DLgKAv75jnruJDAA/LyK+fxsJwzehiKe+n5hgcPU+oYnBx+F/wCR/T74SvZrnR4bgo09uE8+0SLA My7nGGB5C5zj6128aIxbyESS4JSNIWO1biMBmIz/AHumcegr+osiqV8RgaeIqvofy5xDOjk9arRo ys79PI2reVYxcM8MUsm1Ht2kkKNFGoXIYg7chjnPetdfOWR4XhEzTSRyKs0oHk7kOCRkE5X86744 SpPE8zfU8GpGpiqEMXzdDTgmjaKKYwhyYN0kvV4o422j5SeeoPFaCmaNW8sAz+TKIWDglJNoQAnu Mc598V31qMKU7J6oeDw2MxWIvPWGpbWJXnjEEY3fZvsw2jgLgZ2k8kZGfwNaMatPIhSJrhIJi8bR MDgLkBuO2euelaKjTp03Vm9WYYik6FaVJ9DRVGDv5pEcz3atK0pyIj1JbHJz29MVrqILuISrCtxE 8zOLlQ2z5SVAAOOuOB+vNcdGarLnlGyLrYatDCOpRlq7XLirLdTQGWA7jAkqRxMQyRgsMEDoRjP0 FWTbQLbTPGseJQ0okk+cwSMDyoPByAenFepRwinGNST0OLBVmoyo4iXur+v6/E145GtRdhlyscf7 2QgZWMqCSAe3Pr1NbUaoqOFtlfAWcTGTcANo4J7noa6Zzw1JcktLk/WJ1L4ehH5mhbG3EDBLYF2Z ooQ1yYhgNgNuAJwew4NaaK0XlQwxIdpM3yybFU9Nuc+ta04xpwUIM8zMKk8MlCc79i6rP9nUQCPd GyxRqvzBlkByc9wCDWtCU+0tiKP5wtjHJ9pCmMIMKu05J43MSPx7V3qj7Gkq0pb/AKnzNaX1ynyY qDTT/r+v8jRcGKQ4tVDkRwSskm0yBgQBxkE961LaJPIkk8qWJZZUbM8wIyG/g5yRgYxx1/GtaFRU F7Gsrf15G1bD0cZOmqUrcvT8S7bxyiKExRRSQm5ZbS3Lt5YPJcs2cjJ98cVo26lFgKwCR/LklkCt kRtkkBMnHQYPrn2r0qcnaUZStG29zDGU6NbHQpuD07Lf+v6saECpKsLonlxKdk3nHAyB90d+e/pj ir0UCqix7YYJWxH9pUktASpxknOT9a+bqunTk6lSV/1+Wn5H1tOhRpUIywkWuy7fn+ZqqWa4SdYH VZGRJWM20sMEFf8AaOcYPGKsrB+6QOjpDDP5dtE9z5rY4GSepJ6HP15qf3nPzfZIxeX05U41Z6su ZTN5LIIZ4I3CJ5shLyFWxx79ifQVchsBMuyaKNWki/tCNFuSxL4+ZQ2eMAex5rSnSqValovQ4V7L CwblsaiRQgyNbwyK00yy2iJuR4yxHG0/U8n9KnEEMFzJLHtBVEhvY2umkAA/iIJ2/iB6dq0q83tH zO9jhWK55yp04pLU0It0KvGltATaosCqs2MqT1HXOBz3zUltJGJIrhVTPmSDbLkDftAJ644wD+Oa 3eEk0mmY0q3sm/du+j7E/lQlHg23CQiRmj8y4bLSMchmPGQeQFzjB9qvSKjRsoijCSBIZBE+WyVI bHJIJwa6Y1FQlHD2IvOrSdaV/wCrkEUSI0dwkHItlWASZZ4B90DPfNXUZiswnjLBbXGEn+Xex2/M eo5xj61hi6Fau37HSS/rsd1OGFioVsRdp7+poQLDNL+7KMsa+YqBzi4wDvH1yCPx4p9qWSP7VbWw lUIJBaLIUUknaAWzn8c18tjJ4hVH7RXkt9l+R9RRjSwtOM6Xwr1/UvmBVkk2xssfzSs0bZNuQOnH bGOlVSqSSxnaQ0JQrIj8sozt4z7+nfmsotJ3aNK+PVScYzZaVWldBHa7hM7TFd4wrBhggk5PSr0S XCuHksmXbPJkvMMsoyd455GQPzp3ktjohUhSipJajUWaRYEks/KaeZyVtpMllYdc9sHntV5BJIjR OuE3MIJY5gXkyMupHtwc570e9Lccq1WouWpII0L28UhEDfa5FuLeUMGD4IVZD7ZXqalAeWWfy7Q7 4Xk8z5woDAbgTjtnjp9KNmkzzpwpVpSpqOvcvo7TyqClvErTFiiy7VXOOMnoOPwprCRdjShDLLG0 iiKUOGGSOD0+la1vZOVobHn+0nKTo4h6Jk1tDCqykRELKFT97KfLJzlgM8Dr2/wq6PNDWNqFuZzG jSRRCXeVGD94nsBnjNDo1KU0ovU9HEylCg1uSIxWC7ZLWK3uFUvFGr70jkOMEDvx1H+1V8bY4ooZ bNrcoCCty251JGCw9iOg9q8zOMBWrTji3U96OtmtO+6/4PqdOQ4yNLDSoVaNufRuO+umqbt62t6M EQReeohk2QyAAGTmRfXPueavQLLGqAlEnjZZSoO4Kc5JPJ5IJ4zXymMxEcTWeIW8tXpZJ+Wr/Q/Q cvwPJh/YxdlHRa3bXnorfiOdXLoqJJELv5oJuG8wLx26ipYpm824WSKDyt7LE+8lnwQOR2JHP0HN czu4m8KfPBwdk/8AhywiCGaISQkpbSiUCK4DPMSDnd7AZqSONWEgfYsPkN9oJkwJFA3Lk/Xge+an W1jOdONO1nctJ95BHGiNk3sZDYMMjLtJPr6VO77ElBRCYBtiRHwuQM4JPXOR7UKyeo6Nqn7p6L/h ySJBkvOPnClCYz94dQPz4qVXEb/KFaXzUnfAztU5ByO2SAPwrWM4pkTgo7bF8RQMSEhA/c7FIfmJ ZDk89c9TU8SLK7NHHId6Miv0Iixzx2GBWOYVFOjetNRV1rZP+v0PUyWnVWJ/2ei56PRS5fxTTfp1 JUiGYgkW0p8yBB9wgY475xmpSQoLMpCDAL9AMdunWvlsznhq1ReykrrRvv56K39bH6Bw/Sx+Fw7W Jpu0tUrv3f7tpO6b+a7stWsSSLh42MkTli2/iRXAxkegFXIVfZH5ihwrYZFbGMNx+QH415UkoyaT ufR05SnBSlGz7O36Nr8R4BQeTv3XCymH5xxKxBb9BxTkKsBIqkeYm6PIwQDjr6nipLJ2QlnZwcyA TcnJbJAyTSK2GTC8YIc7vve3t/8AWoA0kXkLsDB4tuQ3+rXsPfvz7UoBWMNt3SRBkUDopOMfpigC yuRhSuMrvI3dG64/nRuCj5sZz/M4oAM9j1zjrke1OGckAbsKSAD1xQA5AM5YfuyQjHHQH/8AVT/L ZTscNwp4z94dfyHX6igA9GYN5cjAlT1O0Y/l+pqY/K0vyCM7NrrnJUEj8OhxigCZRuKxomyGMeUk Y48kg4/QVIjDzGlAxErFCRzlsjn8eKAJCpJJdOW2gKHxgA+v4/pSjcZPVQoAY9SckH+lADyQCmQM bhtPvg/0p4Ax1zk9aADkk8cZwaBx07/cFAAMDp35xTBknr3zQApJAHOR2OKQHjG7HPTFAATnjdx1 6UZxjB7elADaeDgfexx0xQAbug3dRzx0pGOe+ce1AAO+TjJ54ozwRnj6daADpnB9ulIPrgHrQAow MfN39OlJ1PJx74oAUnPU9OnHWgcd+vB4oAAcDg8nqMU2gAp2eME9O2KAEDEdD0pdxx1/SgBM9Pbp QSTj26UAL04zwORx1NBx/eznrxQAZ4HqOKM+/Xk8dKAHAgYJPbHTrSgdRnvyMdaAEIzn3I7dadwM jsP0oABnpyccE5qvIhySflBUKD6nPH5frmgCJowD5joF2yFnK/xejfT2qCRAEkbGONilT97B5JH1 wKAIGPKl0z8oRQWxsA6/j9aibbn5QdqscNn7y9qAGkbG5XPy5254GRn/AApMKDnPzKm33bJGf5UA RFdqKmR8sRDMw/hA5OPriqckBMjMsQUBVjL+ZwyLnGR+P1/KgCF4/NkQBFBdzuYHOcc7sen+FVWi 8z5F+/IylTgHawJx1+p/OgD/AA9pNKlt7l1lUA7vmGz524C556DH9cVs2ektOkRcbIZVE3IJ3wkA bm7YGDjvye9fOVasY1OTm0Po5xhyOU+hb+xIGhj8oshiP2di3yrjKjHHGemevU1DJaXaLfF4U+zB BL9md8mR8bdwb3xyPQCtKclKKcdTdfVamD9pV0f9fgI0MsZZIQwaTy7lJVXCo0Y+YdcA8nGOtLJF HJ5JSIwJNBHiKRd7RSnnHXI6Z68Z9a2moqKZwwxlF3T2I5bU7XlLZl+2ILSMH/UxjCnJHfB44r6d /Ze8VP4R+JnhwtJviu7pNPjZnKrbh3C7ivQ5LDIH3jjpiuXM+WEKVanHS6/PU3y1RbqNWXMnY/rn +Cepx6noMMDv52FSFpWAbzM+Zwo6DIGD2H4V77CrLlZ4wjSPv8qJ8CJv4VweQcD+ea/oHhurKvl9 KrRelv8AM/mXjfA4eGa1o11s/wADUdJInVXjR4HUN5EwJ3gryDyMZ9TitGJllhlihDQo7BYxI4LT ADPJ64GceuDXv1alenFOCuz42GJwbh7PD/Cvnsa0YSOdoXiE0ckMcsoM5EkTNwhGP4c9R0PWtUwr HEse3Plv+6A5Z2Xkge/NelhmoXq1Vr3F9ew+Ik6WBVmvwNKEBUuEJiWUOjtFtJdgGDLsORtGNxx9 a01WCNrhTH5q7SGt1k+Vi4JUt/eH19q5qMK2IxMubRHPUlTwydSv7z7Ea2QjlmvyLZJ5pLdJ7iF8 MIxjYT1JxkjHoa6WC3edl8hmji5eRYkBRioLEbOu3GMEdzWXtYxrexa1IeYTr4Rxowt/X9dTQtvn SC4ijZWMOUMYDNLwdyjpk7QevHNXEEilPk8vz7dbxLdnBWPHGwntgevvXRTrSp3jfQ8nD0P3kpVd /wCtS2IBNLPDc7Q8YQzNu4eM5ycjgjGOR7VfgdoZwyIXjlWS3fnCwnZ0P14yRyMgV1/uq3ubruaY GlUhXqU1/Wn+X5nQ2ltNc2cVxFBBAULgeZcqC5jXBGOuADkdc5qeCWN7fcIHCndG8kiHbGzH5Gx7 kY465rtg4OKVJ6I4MwlH61CH4G+iCTFn5OQyGZoM4G5weAR9MjHTNWWL3lvE5gWB9qo8JfLW7YwM OPVR/k16M8PGgozb1uTCNGFVvFaW6musfmfaESMQ75hdRefJl7ccBeRx9OOgrTilkd1kl0pFS2IN oLiTAmIQx5AzyeScH2retSlOUa0Oh89Vo4f67OtGTszQSC4RITHE80bwiGTzHCx2oQlt55yN2SOn fitGLyLa4lkaOK1OAV2ZOQ4wWH0qsXCdTDyUJWf+R7FGrg1KFSS5na3n/XcsMySJb/aooleU+ZcQ SDOQG3RsD1GcAEdjW/AsvnXaTWZWT7MGiia5B37hkADOMEYPtjmvnvYxxMY1ZrU+iqRnDDyqQ6Fp RKotgJImt2R7q4tijM+/7oA9cfMaupEtu7WqxMFdHkDZCM20ZX6EMR9c12Rcb+8jw4ZisXD2U17y LiB2WHMKK93Gsk8QuAwdcqCARjHSpo4WBgkaNT5m+XbIAqgqMYbn72K0oVFSqKUhxpymm4rRbmnC zfJ5iK1ts27Q4CqVznO75snj8quqvmsjyRxRpcKlq4Zzz8pYBQef4R19fwrevPDzvpqeTh6VGGLq OtL3b/8AAJ7dllEO9k8zcViTb8+MFRz269OvNSNbXdvLHHJavHG8BnCSNt3kcDI9z7Y4rnUZqapr Vl42FBKEsMvdNFkjF4IpYN7JtVY4rk7JlZT94duf5fWnW2Y0jd40ZXKKY1Hy3IH90+gPFd1ShVnD 3nqY4OMK7lSb/wCH/pj0jkUxtcSvNDBLIbmW5VS6jnAUjHCgge+PWiMHduZRG90fNSeLI8xDnb1P t/OtqTpxpujN3aRUMLW0qLRmqGGWm3xk7vLjkX5Ta46j88du9M+z22+5lEMcBR1mnCLgseGVuvIz 1+tfMY2hCMfaR0XZqz/4PqfU4OpiMTeFdcz6tPmX/A8lZFyRpGnEsUPlvMrRwp/A5C8kn8+vvSDa ipujASNHULG3KcfIAvpk9c15eysbYmlCsrwVmizFazXcMsX2a2upIkjeRLi+8ryo1xuZGJ+Y8/d7 irUiLND5ZICrEsOUJUJGhO0D3Hf9aL62YqFSpNyVRWsSqHI3MCrqwaImTAjYjABPfv8An7VcUmON 4wI2eGTyuDlo3K8hge+PwrR06tOzktCcdVozUKdTRpBbQpBAIIrcW620QjeBFCLGm7kFew57dKkk 3ZkkEckU4iBi8xwGVA3AJ7gj15qJJ6SZy4fFct41XoWpVVJmSO2jCOFkWJZipKn7xYjr16e5pYVU SOBAqRjhSSQHIxj5f5Y/StZSVW0mrG1WhSqqTpS1/r8yWKJBC+2BWdlM8axp8pctnOffnn1Na6t+ 9En2OGGUxOkNuk2TJKDjaeTtP6c16WE1Up9DgqVKyXsZ9BsIX5bZ1AEPylQCCrDkk+g7VYiSNZby W3MjybY7dIpnLiRlHJGflGd3Irz8RGWNq2p7fNP700d+HmsNhpVo/E9NbNW21TT1+ZfUqBN50Qlk cog/ehDAAew6c9D6AVOu6J28q3TbHIXERuRtORgZI/n7181mWDoKrL63iWmtk1J/c30PqclzHGww 6+rYVWe7Uor5tJaPyGCNIys0sapdCFY2SO6JVSeCBnpgDrgVJNLOl1BHBZLeySzi1PlzeWwJwVIJ BAzlhz1r56dOpCMZTVk9v+AfSRnTqTfLK7W//BL8RYSZa3Nu2CksbEHfJkqd30AABzT0VJGRXhWf DbvLfo+AMZHoMZ+tL3Vod9BRh7SE3/WpZidFZ28tZ41k8mS3LEB0OeAfQ+3pUqQbREiRpLM6KjsZ sAB2BdQe5C9Pp2pySS0OSCUpOMSe4dJPMkDh7eErHM78KSrHgD/dq0qbA7OhPmgCN92NpU88dMc/ nU2aeqJlHllZl2CKZ2uVigiVGjS6jm8zmUINhI54Oe1TxIuy2mi2JE9v5xzLlvvMCpHbaQffmt1C 7UKe78n+L2/EuNN8jqytZPur/Jb/ADsyaJQJWk27JUdZGkV8eaBgLgdm9TQruViIzGyNIqpjAO48 kgdTivn8XgfbVZzxKa5b7QaT87+9+J9zluY1cHhqVHA8rUmviqxbiu3LaFvRXL0CF40ZFOJvNZXc ffVBnGPftUqKA8Lr+8ZzzGX+8uB978QfrXyx98WvuKoGJAXVN5b7/U5HPf09qkzEFaVSNqRh53HJ JyFzx0GTigCZEbeVcL5mAoCjncThlB9Dx1pYwGmDniTymg3sxOFOOnvxQBbTaskkhQttkEEWH5x6 Z/WrJA+VFzhJAU5+/g4I9gBQBMQPl3D/AJaDZz17j/PtQWxwBuJ5A6ccAn9aAH/wgYHAAGP4qbgk gY684HfOMD/PpQBJHnnurMqMpON2TwPxqRlUsBtIVXCud3Qk9Pw6Z9qAIzlWYcrtJH3unt+VPUfe KJjAAXDZ254/HPT8aAJgxilYMm5jGsZXP0qdkUQuMEhNwRgenfkex/lQAsJIdmlXacqnUYLAdfrg 1NvGWBwQDtJHBXOMD/69ACorZUMAQEKiTPv0/TNTKcHbj1xQAvPr16cUm3Bxngk8YoAbu98AdOOl Oz2Y9ODx1oATngr6YFJu/wBrvjpQA0nOBnOBQDjpQAZPX3zTixHRs/hQAgJ4GcD6Uh6nnOe+OtAC k5xznj06Ug+uMdOKAFB65bGevFJnp7HNACnHUNk59KCenOec9KADvnPOM9O9BOerds9O9ACZz1PU 5PFKen3s46DFACdsZ98Yo4PU4/CgB3AGA34baQdOuCDkDFABk5Bzz06dKQgdjn8KAHDAzh+vX5aT Ax979KAG04HAPOM9RigBc8Yz2446UA9i2Bj0oAcG469Dg+9IOR74wD6igBQcHoBgc0whtv8AecEk AYG7rgf59KAGMuCgTACqQF67wOnPt/Wq4B2EtjI+baW+6QfmP+enagCA/JGC4XBIXHYhs4I9+ODU Hlgdc7c5cZ5C9R/P/OaAIyFKMhAzux15K45oI27iD8iHG8jG6gBG+9HGD88kRmjyPvoOp/z60zao cyEAHaMnPTrzQBQIk8pFVQgiRkk9SSST+mKi2qWTKByUCl92ACwwv5daAP8AFYfRNLvYrONWMY1C 4FoZ0XcZowcMrewxyc5rITTJoP3ACzAI0a7xncnK9COoAr5aOChFKU3qenLGuTatp0Lr2qri3njh ijAWQAtyVRh0GR0JBrUNpFLHdrcKokuLjyoYBICpYZJbcAMnaeR05rshBJcq2OaTqzipzehhX+lh R9kd442jd7CVohhopOq/N0AyQPw/CqD6WDdLPOiparHvuIj0afbkoMYPLc+tejV9nQo+wjrc4liF VrypqNkiC3sJXZkZyzlDM5KHddZbhBxgAdAe1dV4Tjn07WtKvVlMLadqkN22MFQRJGyBs9Rkc456 HFfP51XqSwSpR2Vvw/U9TB13TrR5Nd16XP6tf2OvFra94F0ucbVWTTlIlDb2jYmQbcj6YyBj+v6E yeb9ueRPKiPniKdXUSeWFX7yn1OcYr9t8PlOrk9KvfRf8E/nbxJxVSjxBOhCF+Z/8AbDH9qSFbpo w0iMs6oP+WYG6NjzyD6Hp+Fa8apIyq5XyFu/NuiRkSrsAHPt09a/REl1R8vXyrD4HDwxPfy9S9FJ dypN+62SNOjWz+YAG2gIATwdo4wOnNbrlZRbySeZA8bOs8IYqGLMMsewwM81NSq4QUG9Do+qUKiW Mw0LKxriILBI9xalZFlF1HECQCqEojZ/iGMfTNaMMdzKXiiSCK4lvVmLmQAxbQdwBPJB4471rKcm lFaWPNq0KVNTrPUstbLPtk8tUieGW7d1+9cbcAhh0AyCOPTitK1RreYq28uHEUacIsIf7209D8oB xV0lRdGTqfEeFjs1pxw6pQVmuxrlFKMBHkRsw2EljKhXJ9jzn/IqeK2gt7dVXZBCtsqwxHksCcBc fn16A1NOLjK8tEyqVT21JYmK1saVqJlMXlxoqSExyNJLt+xLjhDxzn06dKngDqbdZI5I4i5jESyf MrHOByPxOfXrXSsJU1pt6HNgVi5xqSrq0mbNrHOI3MsCpM0CyRMXBBAYK0a+gGAc98+3OrbR72sL hoUX7UplM0k5URqpYBDzn5TnOfUV203Sp/uYvY8uNCpGcsfPWS/r9DTRMC2MwDFJnnJ3HcAOmAPr gc1qxySy2EE6KgeN5A0RjAW4XdlWByMEA/pXotujh1Hm3FPHwx2HcK1P3l+hPb4SOKaONkhVXt7Z 3JZmCfLID26nGP8AGulit5yjQwKiyoi+XLcThROAvOBk5OePXit8NCpSqqm5dDzqMacI+2qq0Xoi 7BJJHaTJ9gMQljjgn+0ud1sO4AzjPsa0wZs2fkwKCGWK5dslrfIyuOzAYHT1rhzD2sby5W437q2n yufSZdHCxjz0mua1lo+u+zSv6lwJAsbqjGR5rgpAJFwzr3Iz0x049a044xdXNm8yvGBF5sBL4ZWA 2Hp75Fc9NurFTkrGlWEsPTlZ3uaUCNdRRMtuttFGZYdsE/7yeXccHk8bvUcDFOjCLcPFe2iwOrRT OftCyRXjADcFKnoBgZ9TWl273PPw0I06jlQWpp+U0AWNLaa2kTzHDSfMbbJ6A+mCOfbtVm2jV0dQ jmMuqzRo5DKCwJZTyASR6UcrlHbYwr1KlGpLERlo916l64DWc6Q3kLfbIMwlpECssbMHyDk9Rj8K tSzRMkcCLEh+1SuWZmDyIwGOnQDGRXZQlQUf326OGGHWIw9TFN7/AORPGILhEWEW7tbXL+c6Md0O 0YBYE9yexqcHZJFdW4KsSixMzZZSRh1DHPBx9K7qc6NaXNDcWFnGtgnFLRbFtTI6Ok9qlpcGCOMR i5DbGxvJ3A8kenQ54qVViWPTzbrDDAu43SeYVEZ5BVmPQnrgdM1nU9pOso09LdRYWusO25IsbfmQ RKHzK4dmuiw+bkfKRyQfXHSmw+dLHJACTKo+SbdxjGM4/MY9zWkYQhJ1OrN3i50qzlU2/q33luKP yXIu4GeFSlvcw3DbMhujFvcYwBT28yaweVrMLdzGWJpZJiklnGDiPawJHY9fUV4ePxtSjV5aNRST 7KLt5Xs9z2sDhYZk5znQcderkk9N7af11LUPICyRKjSyMfs4nBEe0dVbvnvx2qQLl5FlIdo02rNC 5zeMwHyJ9B1J4rw6sozqc0dv67JfkfQ/V6eFo8tSV5f13b/MeHVGmcREbFEUbGQu0XQZLYHX9MVo zxN5awyQRGNG3xAPn5t2X2DjnHcetJ2TbsefUdRL92rsU7cTHyFmgdwNtxMRvjBDhuOmDxinzQS3 Ky4srWV7c/aYpIJTC8rYPykE9cAd+a0c51ZRVR6GtOnSnTf1hXkWoMiNgzTv52xBHKwHkheWAPTj Pc1I8bSMyMsm5CywSYAJjyACV9ev/wCqujGU1FxlHY48TSw6UXPT0Jowm+NRGJ4VvN0iSS7TOo53 AjkEcdOtAmmeR5pYI455Qy7Eudyr838BIAzwM5olTo1LQpOxD5MLHnpaplyDfAqIvlqvkkOD8xlY tuZjnPqOmKtx5TzYVfajE3QZBlpGxkBjnryfpzXXTisPR7swcZ4qvJxVhm0R2k7xcRWMHnnzLza8 uCMZJO5ufTnFaTDzRNAUMouwXTyR8lnhcsSOpGf5/WnGhT9oqi3NaFNrmwtRlgFvmyEO2NWEOTuV jkZU9OnXPtUwJEkzC3E891GgEksuwRKpyWA6ZABx615Ge4XA1sOquLly22er/BHdkuIzHC4qeGw0 ee+ttF03uyTb5cyiS1CmXKlFO3zAqnJJznGCOnrUkkUbw2rxh4rqE+QrSXpJnDAbAw6cY4J5/Ovk MfOlTnCGDrc8UmleOy+a19bH2+UQqyjN4ylySbu7S3aW+j0XlcumGPbDv3H76iRZSpyeCTznk9P0 6090uE2PFEkiQx7olebb52DgjkYPX68V5clFHdUn+9k4suJEqrIsUEWBCW2Ry8BuTnPQEnn6U+Pf HbAmFVaCceZIsozI2PmwOuDxmlLWWhVGo6alDuT5DeXmJdshMjpnG3tuP4VZjYuFJVQYxggZxn19 jj9K0lzRlyk8qSkpPVFqBwAsgRfs0trvhDSAuGzgFsdQSAcemetXoVyZZ1hR5LgGONQcfMT84x7k H/IrRxteFtSNb6EixBGTcnkqVLyHeGA2jKg+mfX2pzPKI2YxEO0e5FU5bJGR1/CuStV+s0alGtHR d1vpuj1cLGtg8Thq1Kqrya+F6rXZ9vQuO2FMiARziSNBCjEeWMYcg/kcHmpofkJYwM8XnA/J/AHb aTjnj+Vfn5+0FraySSBgElWVbJU38AYHORxn6cU+JjthKRlVb9w4LH90uT2x0z1/OgCwhKMjIoJT 96nyg7T1z/OpYvk2FRuy5YqfbnIPtzQBdjOHEjBTugWRwCMpkZOcde351KQqyMgGFbbJvH8L5649 6AJFbEcrsrB40Zim7OTjIH48fTNPjLFAzJ5TuokkjLBtrEDjIoAXJIGFIwBnkcZ/GgDPOThWxjHY UAKFOC2MjAXg9DipMDZllwuNyt1z2x+hoAEXOSVLcmMAHBDEcfhQm1TIzKCseG5bAVV5ZifQ89em KAHlSq7go3LKWbB4XdgrVlGRvMiiU/Icqc8GTHGPb9OKAHRsPLjGwnad0eSOT0z+Z/WplG75RkOI RHI2c7W4x9etAE/IPY+mTz1ppBIIkXarAZ5z16j/AOvQA4DYMIOBxjPQZx+lP7YI74wKAEzjqcH6 dKTPU7udvHHWgBO33upyRim9M4+lABnoc8jgDFHXOTjn0oAXP+1yBgcUmfftigBRwRg445OOlA4P B49cUAGffvnp3pM5HXvnpQAdsZyOvSl4A+9z1xigAJ9GzznpS59W6HjigBM9eehyOOtBPv8AhigA zx175xijP+11HPFABnn73GMZxQO/zd8dKAEJ6c5wPTpQPr29KAAcE8/TjrS/j1OTxQAh7c54x06U ZOMZ7Y6UALnA4b8MUmTyfUYNACg++OMdKM8AZ74xigBT1wx79fWjty3UbRx2oAXaGUo2CMYI9QaM cAdT90+1AEWxBlAhw42HL/w4/wDr/rUZjfKIBjyxuR88MRwARQBWZCFllAUHzEyQ33WzyPzpjZ3Y IGTJsIUg+cc889hQBWJyWwSqBVQJ+JJ5/Km8jgHnbgcd+1AAD15GfQj+VMZAxzjO9THuz90EHt9c UARHcQA2BmMFw3Qdc802FEC/vEYriL+LIYen5/zoA/w9tK8bPceTZXbbLnfHHBLGuxIFLc5x6gkD PvXeG6Wa2nuo5pYraNJLiKbB4CkIydc7t2OvrXj1J01UfLH3TswFHmpunWd2bgjjka5Rtsc0sf8A oUhQlUlwDgjqC3zZzwCO1XYE8+C1KxPbweW0Z3EtuPQKw9QeSR7V48liXX+staHp16tCFJ4TaSHX EBvHdS+NrOlpHMny78ghnOMEE56+tZ8Nr5UZSMoJLd3njgbqjqm4kk9GI/MY69K9361N1PaWR83B Jc3sUnJF1bR/tU9tBdb4Y4Y9Qs0nfebdJCCQrDG45BwD61PZ2TLK6zhkj3YSEgne5B2kkdCB/P2r ixMHXpzqNban02U1cNGj++Xvf5n7u/sAeOLpfDWg6XdOJbiENFFA8+6QxxxcMcfePPA9Ae/X9vrA rc2tpMpiLOzzruJxYyZbByP7xxk57iv0vworxr4GUakrcv8AkfknixhcHg8TSq0lrPXz1Zo2ubiS N+pki33ecZtWkBVenUZ/n2rUS1DxWsNxAsgLxySxRz4D46gkevH51+ty5XN22PyTEyxE6UaCXw9/ IvQ3B+0vJJAX3SkTW3nbWuVHGApBwAwGMda2oAxg84Im+LYwilYs3PO49s5zjtxVUqMqqcYvVHPW xNenSioLT/MvrvRRsD7Zbh5VVuTjO/I59c1vrp4glkCxBLhwluWZ8mRiwfK46AY6mtKE1TpS9qrv scuKmuVUYrVln5JQqSKqyvbkvB5RABfgjPfnHA71btVjZoblyHia52QjeFAmwY2B67QGH49PeuT6 zHEVOWH/AAx4WZZLSdP2lZ+n9fI07fYTBGGSTC+aqRxlehxnrnnnI9x61pWokZ7eMoHSO43qkhJE qFecnsA354rqlBysqWqQsFL2eE9jbb9C/ZkytIYkIs5ZFWNYw2LaTLbyG75IHyirjKwuL5GtzB9n BeZJZdqozd1/u98j/GvRxFSVCmpRMVjKSg1XdjVt4nV54o2QKssZWJySYAyiSQ59+np0rZhDO7rG oWS5jKwNtzt5ONwPBzn+VLDc0r1pdTyp4iKSw6jq/wDgmnIig2MUluY5UcQWssqEmM8uNvpnBznt 07Vfhb97EJZcO3DKx6EnA9ge2Owrs5ZSaSPPr4yUMT9VhH3u9uhopGUku38h5YoZ/nLEkKSwKtnP rnIArUgAto4GksoXSS5Z7WUSYDhss4/vDnn8K9yMOSHK3qRWccRhnhZuzTNOLznQMpjWFVLQFnGF bBOeTzzmrlvNiFQ8Z2SIs9uTIWe4OOc98egrOrhquJu6c7W18i8tlQwM1DEQvb8/vsaltEPPgjhR Y7Zb9tQiji/eCdcMQmTyByc/StGBVijyseIml3F2J2RKxJAznuT07V4ur0ie7T+tYlTi9Io1PssC rI1xIvmwIVngc7lkcgbU/wBnk9e9T2zj91s+xSpJH5lyBIfLhO3DLnAzg9xTVRtct9DKjy0n7a2u n6k6wxSGS1ktyfIyWkmPmedKR06+w46dPSrEMjRx7Li3SC5luTbeXFLIXiUnCscYA6+/StIVVCMo 23IdTC4iq7y0fzLotpPss/yAohZLVzyySfcLrnrnHTt+NXIJXmjN1AIxFOixwSfaeGZVwwAxwCRy 3rmt4YaMrwbvI5ZNQxTwsVoWZMEzzywhVmuFMoSTYzNkK+1sc9AOnHGKtRPC0csSoYl88mJ5JQC2 eVGegxjGa6aFB0U7s4J05xqypUloOgWW6WMLaxTZnP2iO5kVUtMqxDB84JJGPx49KsFYoG81reF5 I1VrLqNhcAtHg9sj73v6V0v3k7s5oUJwxbcp+6WystveMPJVJY7kwyolxu8vr2xtGAOceopkbg3c jrbmdYpEhXdKcSpjuAM9CfwBpVKUlFJSt/XmYZjXp1p+zqa/ft8rMldZIJ3jMRMjsqWt6w/cSAN0 GTkYB6kelX8SrJJbyhyVkIkdjkuCD979MH6VzNU3b2vxW62vbrt/wxrgoVcPSl7DWF1a3Na/TfX0 6ksQVBDlViS3jMQkgAAbCFTx0AzgECkhdwIysdskbRDCrJhpHxzx1Ax6V4tXKXU9/C1E4rtzN/Oy aT+4+kp5rVjNfWYtN/zcsf8AwHmab/EuRKUhdJAI5I4cwJFIrrNg9yD/AHc9fTpU8US74pI45LdZ FELb5Mqh5K7c8A47+1eJOS5mlse/uuZE0JjZVkurYz2kigTB2wZCxxg+gxg/hU8ccccShGkC2zeU Az5ABXIyc5OBxQ7aciPNk61CpKq9rjE3SSJvjRNjFQ7y7t2ecjHHHqO1WmmjYyTSqQsUjLI6n5ZN p5IPbivRpzlWpyjJGVZurNVI9UXI94kBkt5A8pV4o1X/AFvAwVyeTz/OlnjjSKOIp5hRiIpN5yMD LHP1659PenhvdqezcdRSpK16UrokjlRt0bbAruo3qzYO4HNXcQCXzXtYGYFpY/8ASCiltuDuH0B6 eldUacIz06l+0q06MXTl/WpA5UxxululzIttm2Vn+eIAjIBPAGACefStoIsLlRBJG7z7UEtyWaJN oDdABnr2pQpWrOpcw56imqt9f6QqESmaIQwSRXFvJKqOdrwxqDleuOOTn3xUpCFQDn7P5B+6cZ9O nzcDP5+1TiaPtaMqZvhKknjI1Zb7kjM2yzgjWFo45Xk8x3OUD/eOeS3ReKupJKpmd4DcBQPtLEgA kfL1GME5x+B6V83jslwGHwiqSfJbdtOT/Bpfh9x9Rgc2zGvmDw9OPO3srpJfg3p6kkS7vOQWSgpt PySbjCMgKHX7uMk8jnNSyTbLpIgqYaMCKNpsvIRwzAenPOTXxtRJtqD06dP1f5n1zjKlK07X8v6X 5F52lRDcrC11GkBl8hJVDSjO0YyfXt+PanCJmd1EbeasnlOm3iLA6E5/zmiEW1ZDh+7lfcnZhIRc bCkNywMLSOQZ9oGRjtk/hx9aswzASsdgUJumH7zOzsTx+J/Goi3qaTqJSc4dSygYBV2Dc0pVpFIA bjO4jt6VbYhXYbg4WJUjKnhehyPxzzXbRUYUnOtszDZ6FiEr+8hiRYfte1ZZmcsCDnkjrwOOBTYn TezJG5jmkKRQPLl4kUcHOefXnBxXPXo0JUKlWgraNv8AH7zuw9epVxNGFSbdmrX6a9OxqP8ALHA3 G4RkSmI99x/HOMY+lW0jmhYZRIxPbhlk83DTDPT27Y+tfmx+3j9peWS2ki2OQ/nRNINrgAenTnHv VkMQhVUJ8yAYPm/MhzyOe47n3oAlbcuSE3cZRQ2PM7ce2amhTcBuXG0gbAeCSeB/OgCwhEZHyhlC 70+fAyOOf9rFWlWMKCFHMajbn7oY+tADyrbwQgYRqTHzjHt+h/OnYDNHIqnYJDKTnG/jbg+3P6UA SBfm3MAWKbT8x4PXp+dO7gbs7sAA4HP+f5UAKuASWXcCh6k8e9KdpC+it8/YAf48mgBzjB27eU+R sHh8ZwcU3cMj92egOSeHPORQA9vuD5QHBy3PJBAINOV2XawUEKhRSpOTjkn9aALETpFt3KMkqw+f pxyf16VIjHLqycGQMVBwRnpn8BnNAE6EgoTzvTyt27rjOD+I5p+CYyqqUONoAOTjoKAHDkAlfmcD I3fdp446nP6YoAaMg4HAPtRy3Gc++OlACemeQTmkJ75yQeOKADPfPJ4PHakPU9+aAFzkcnp0GKB0 IzjvjFADaUfXGDnpQAvHJ3cntjrRnoN3QZHHegA45+br14o6AfN79O9ACdetKOn3u+elAB77uR04 oz/tf7XTvQAu4/3vfpSZ/wBrtnp3oAAevOMnnil7fe524xigBAcd8c56Uue27jr070AJ77uQfSgH 1OO/SgBc4HDZ9sUh7c9Tk8dKAE9ee2Bx1owOOe/PHSgA6Hg596OmMH3+lADg3J55xjOOlAPqc/Nn p+tAC8bTk7gPbFOJHDZ6A/jQA0jJBzxncCO9MZTlgo+ZVyjZ6E9v0FADCuxSqoBsX5DnO7uR7VTu AoKgYICKV44CjP8AWgCB0LAOAfnDbRn+EUzKhVBTLZIPPUdqAIf4ogx25Bkx/wA9R05/HH5VJ2SQ klhtB55Q54/pQBWKbhHE0YKRkyrufOHPB/nXkvxn+JWkfDrwreCe5EOoNALpghPm24jeMgqoGTnc Fx756U0m9jlxmNwuAo/WMZPlj3P8SKXRtp8+MMltdWxkt8jd5+0Dv1HJz0/Su90WaW2sioY4fyo3 Vxk3MuwqpJPPJB9MY5PFeBUqVJ1V7p9ThZxUZ160LdjuLW4lgS5T5hJa3MccIEgLBWAXGe7Kc5Jx 2xXSWDhYnhZQXEm6JRHncSRkMfpjgfSpq0o1IqMtjjw8HWquvLbX+vuN2cCVLW3SWLF3eGNniOEi CPn5lzxjlWx0zVe60+ET3Ntc26tGly08qytu82VG4VwO+DgY9BXrRr0KdDkhqcM4KnVkor5l2TSz 9tTeSiMhPzrnZs2/u89zhuBVyNVt5LnCLFeJa+Stw3y+QVJ5ye+Mfe615tOda84uOmvz0Z0uNGhh oym7XaP0U/Yg8Tyab4h1S0MsVoLeGLU7Uuu+S2V40Urs/hDcsvHc8V/Rt4LumvNAtudyzIbaUG5+ YRsshyG4wdwGT6mvs/C/F0XXrYbZn5r4tKu8to1sHBuX/BO1SJ0R9p2XEFwItxcFcEDk446/nzWl Dbxo5uILGbaGwjTT4ilOCN2ByATn6Zr9jnGdSvZtpL8T8MyvEYxxU6j16lsySrgmN2KhQi7hG0bK DwG9ifxwK3YNpgWNysk0YkWWUAx5ccAlemec+5Oa7ISlCfPB6l4rEVPaP2b9166GjBK0sskkrRyS CXfbRyxYbawCEM3ruAOO1atvGoEyojm1vZN80wnbdEcbNqgnjBXt9azU6k5y9qupwYzGVKFq8t9l 89jRSE70ijhSWNZQHlefa0RxnOM9AAPrn2qVEC8Io2SwBGfP3yG3Bj69TW6dOlNVqe5105z+q+0x Ot+hqWcvmSQ5RY57iKS5cg7SXGQEAPQZA6VtJmJEBiUb7KeWQhuGU4G/2+YGt7VZQ+sUnr2POpe5 Nzivde35F5USMPDskj+yW0chLycFGILbQOmRVpQT9pCQp5ckS5Vgf3oXgMD1IPv2zVTpYmrJc+xE 8kw9Sl7WrP01LkKyRrbQyCNTbksGK/MnXnnqvbnscVuhkjliHlMYXcO88jne6EZk3Y9OwFeriMN/ sq0sefGlPD1PbWuXooPs6BX86V2SKCF5JMs4BO35ec8HrntzW6FgLtuJlXIb92T8vy8rnucelaYW vVw9JQqq551WVKVWriMPG8l19SwqeSkCmGPAMhleS4J8tMgocD2469601WS1jkURqZIbiNcTSfLK G4dhzkbQfTB4rWOKqe1VSe36HkUXSVGVXEq02a4RYtryQ7zDcNlGOCG25XB784/WtF45miTbi4Qg R+aRtETHO7Iz8o5x69a6a+LeEqc7jpZ62v8ALY7lB4vDyU5a3Wl7X8zRtA0TSIsZcxS/Z/MLZCDA YBccbcn71XrUwR5C2kDrbxqkU0shIGM5Yj0zjnHWvAVeti6jm9F/XkevKGJeG5oSdvN3/Mtxif7N EIUll+dmiuRjcGc49APXAJ47Vdt0tp7pI5IzMrTNaFY7gJ5Sgf3uo5x0H9a9GlTU4Sb6Hn1606VJ RT1JtgZY4WiSYq3+kspyBIu7IH0IGSatQlWMcUMf+jvJkNHJ821hnHPYEfzranQpVIWctTmk8On7 WLs10JkjinljuvKLeQzTWUwm4jlXhvYjJ/WtAOR9juW2KtpMLpsD5Ji3yqo6DaN3Xv8AhTnTlhf3 ydzL65VnjFJUx0eIA8awzJJDLPPJB5xc+cQSSmSdqkY47e1XUSbbKDb2pjuI1KeXcFyrDHRTyD68 967aU3UpqUkViZVliGubTyJn2yJcGKLy43uiNiOGihwMjk+pH5ipEEkVw5a2lWeVAbiMxfOUMfGe xyOfoKu1mTLDVp0ZyvrqSeYqxPGI1Eeww/fIYOT1HX/d+uaueYPNEdqpjuY1G7ZlVjdVw2D/ABZ4 oavKzPnI16LpeyqP3hiJEJPJtoljiuZIkkxcbnlm6NtHUHq34Gro8yJxJDb2082BaCWa6ZWtxu42 9mDAc54+lbYmnUTVO9vu7/M9aLVKrFRp3ST32/4ceEhm2mS1QbnZFD7XXlvmIPZjz+WKlibdMqmC 3xO+F3y7NyZ24J7AgD/Oa6VUnUwsvYNxa7Wf53PHrOriMU6WIiuXzv8Ao0x1tDDGhgWCD92GDJEM Y28ZyeDyQv5mrCBIGhSGGNdpYmOKTCQAAYK+vJ6V8LXjisVUqTp03LXX3Vf52Wn4H6Nl8cNgsDRp VasVZWVpOz9LvXXvdkrqyeYmSQ8oWZWfIduRnnoPXtVzzgYBsgMeFWNUBB3ru29OuOp9RxXHGShB pROyyxUVJS1HvIsEO5V+WKTbEuD8hBwPftn26VO8kieesZtZpMFY2uHYJE23kqv48/StsNRq+1U3 sdFd0o4dtvV/8EuM8/mRTyxBiyeYHimDJIFwFAPqRn8qc7tLGXELwxvEYWR23NEp5IJ6ZGfpXoOO rcd2ePTqSipRgtf62FtSsaWrSQyWtvAzQReZIGDKOC4I7YPQ89KuxBlL42O/kGUSHnzpMFQfYEAd K5aHNUrSdR3sdFK6w051FuTiYKoZvKWMosXmgjaAW6Z68GreVillZUQ4mIkkMp3XS/wn0BBHauy9 9zy6Eq1SUpVFZFsrGyyKEbMLGKNt4zk8c/iatBJo5gXgXMUa+SqOG81WAb/AY/8A1U07as6qk3Uq XSshEYxgSSRKcyeSDtwr8/dGDxgY4qxbxLGj5j8w+aZZCXO7afu85zjmuDMPaxw94VlDzaX3K515 bHnxkYujz+Wv36X0XUsREmLMYdomSQM68eeVPIHfp0wM1oOqpKkSRERNuKI77vLTaCOe46Dnvivz jFTpupzRm5N7tr/gu5+o0aU1ejKCjbZJ3Vl8kKyDY67EZdmVDA4B7dP881OZSkskgsoXkkjWHmdi VTHJTnAPUnPYH0rNKMJNxdxrf3UEEe2N4lt4ZZJ9xt3lmYEDOVIJOACR6GprfYgjVY0Ek7He/m4K kjGCR6YBGfpSp0nOryyBKW/RGoAceUw+8g3hJB85zz098fnUyAMQyglBHIkyrkEdgwPt0x/Kt6kI UouDd2wbe45rnZEZQgjiK+dE7n5oFxhgD6Hrz6VPEfJ3jaGVFIchuQWGFZfocfWuyjTVOKi0H5mh GFJDlTgcg5++OuevAJq1ERvnGWaO43QvJOhHl7jkn/PbpX51nUaMMxqSpz5ru7VmrPt5+qP1nhie Lnk9OniafLZaO6d13tbT5kceWkHmK0jOwhILgFwPkBz0HAFXtyMyptEsUTAW7q/8OdvPPODx+Ga8 +sqNozpS33Vnp5a3uezhZYn36deOi2babku9klb0sWC5FxHsXdMVMWwtjAJ5+oIH1FWI1CKFPz7A JH5wOewI9M49cCsDrLa5KlUhx+73liew74qTcQ7uYwUOd4dh94f5wKAJlZSEZz8sjgxkHPJGce3I qyWB6/ckUrtIOScZNACrkkEqRuG4/P8AcPHH+fSgNkBhjy/vA+o9aAHHIbHPHtwfp+dIQCCACAeC QT83v/SgB3JwfQ8+9IwDKU5IcYKjp3oAmj5aNXG4ZEQUt2oQbvMCANJyFRT0U8bvp2/GgCdNxVHj jBKAFmU/e4xt56cf0qaAgIVYHa0Y3Rk9Rx82fTGP1oAnxtyfu5lHGc85x+ox9KXJLcfKpkwfpj37 e1ADyg+6MZAzwMYwcgU5QcDJJcAAtigBSNwHIxmkY+/zYweOtACDHXdgnr8tG4ZHOeME+tAACACM 9T6UhOM4Oc9eKAEBI6UdOh9ulABnoPSgflQAvQEA5yfSlHHRv0oAOOTu68H5ab6/T86AF6d/fp3p Sxx97OeoxQAmePvdOgxRnnr1HPFABnn72BjGcUueg3ccdqAEz1G7rk9OtGenzeh6dKAAntuyOvSl zwPm6f7PSgBCf9rPO7p3ozx169RigBc453c9cYpM8/eyM5zigBOuSTz9OtH454oAMD17elB68HOO hxQAucg8984xRnjr36YoAUkbcdTSg54BxntjpQAZHGOTn0pmzBeXJkYrhV6dKAHMo2EFS3BDDOMi q7R75MgEbdvzZ4cA5/n/ACoAqMPlml8sbmkKyNn7gznH51XkjaIFCqqSMq3Xn39utAEfRjuAUg8+ xpuRuUPn/ZKt944NABJdQ2ME17cjdBA6Kyd33nbn3Oe1fhx+2J8YrrxPcXWhnVJrGEHF3qURWQq5 ii+UEjK9AMjpj1rweIMwqYDBe0ofFdHynFGJSoxwTjvrv28v1P8ALQS2YxB5olM0EYktow2PseDy cdOQQMnoQfrVw26Wc0SXcbBZ4guYl+YMvzKuexZhgE9OK5ZYuMJcvLsfrFTDOFS1XWBp2FsxeWLL mWyijvZ3ldmN5cyZJyTjkLjOOBjGOa6CFbtQggZ/PWWSZCVVGiCkbW25xyCTj/Z967vdcbLc87Hu FKLpUdNTYS9nJt0QISMwSyCTKomMkEf3TzjA6tzWzZ3yR4t45UDZ3CMrkxsc456Djjmp8g9jGhg4 Sq62/wAzQE0TA3MaslvPN9odPNJaORBsYuT3zg+nQCnXF7ZW9ytwY5Gha7Rooyc7o8FcSdmIJyM9 fwzW1KVJzkqmi6HFXr0sVTjKi/ke3fs/eLbvwv8AETRknmjjtbi7hF9qDPn7SEZQG3dyARjvnI9a /ql+CWtRatoul/uzeyXFrIVV5P8AlnsmfJx7Y5/Kvc8O4UaOf1aE49f0PD4/o1f9WlXgtI/8E9rS MyOqs4H2e3+0mORsgswCg5/2Rnr6/nfR1SC6nvJbeLyLpbiLfNhGlTaFBPUcEnH0r+g68YQqOEdj +Vo4r6zapRWr3X/ALxkeaO6DgvujVbdmz+5yQ24evpmte0mRY4twZphcbklkywY5LMRnjnAHPPXF c6mnUdOx2SwrlhY0W9Ua9irQtLss3YpEJLmAuAqs/Acn1PXir0L3EYtnMaCN1ZL23ON1qoOIxz1J HJHoBWsoJO0XdHBjJvHpUq6somo3kP8Aad1m8lyYvO0/94wBQEBmK5xkjOOasWca29upjAWOzhj0 +5ITPkOGZmznhuMc0pWTstjKtzYaC9tv/XY1LOJtsyP5dxLHDvnmD4EgfLc91wO1anm7oopHUlkY QQSBj8hxuxjoe9d+BqRacEjnq1akcRClFbmmsUkhlDO8SwskS+X1ndu4b09vateK48pFb7OsltMD EXDEtGFPznaBluQvbjt1rtv7TV6WZOKUqtqMN9x7WyfZv3qu06eYwjSUkzoTuww5znPA7VvYm23G 54BJbsX88z+YVTYMbvTHAx1HNXPE+2TbloEKnLh5YaqrP/hy6qsLWOaAQR4ZJGEkm3YBwSuenU/W teODBMg2MsNvH5u6VdrI4xkBu+SM4561tToyqzi5bHz2HxFHB1Jx5Llq1QRuYBBDGqWiqkpmKeQe oKr0P4+taUUTtIkrGGNLsNmRGUsrHsD/AA5xjHvXs0pUJy5JbIMRChjKCnbY1Yo7hRFGELhXObgj DROPuhh3HvV8Skx2eYRbiRiY5pGDGR+Tnb2BwcAjvXdUjRnTlCivNvU8WU3TxsKrjeG2qT38tjQj SOOLzY4i6l3klVWyxGCME9c45IwKvWBInWKSNHRrVVZ2kwsTHLbD6jjORx0r5RxtFNO/9ef/AAT6 7m1cZw5YLZaJeVrGjbTMzrK0QhnbzCtrJIdm1WAMnBwTjpj1q1EkBluplicoLsxiQ5RklZM4XPOO Ov1ppRbUb6HDOtSdRRgye3kVTNM8BuTbPNLKkMobzZCqk4cden04NTw7o7mzBt1t4XR3umil8zCt 8vAPTBxxXXTo0qq5abs0cGZYVTcXU2f9f1oTYEkcc4jjhDQ+S4tzlVPIOB0ycZP1q3JIz7mht0j8 +2jSELwMKcpgE7R8w64rtSpuLhuXSr4ekoqro1oXBma3jjuGikvLiAz3TQSExIYsGQI3HY9O+Kug tIunutuY1vopoIDGpxtUhTz2OW/pThSp07qCOatFuTqR63aJYHKy+XLGmx2VXMkoy8gyeSPlXIGf x5pkRZpEnCbWEoaYlgSx6ZIHfBwK3k4qovZHFSljaVbkqPRkpzdyXsDQJaxW8xOZHDMGV8jB7+ua nV/PdVRfsrO7rDG8qgyR/fL5J44BrSL5sReucGKyrmbxNJ2sXMFPLjhKLKlyWVluMNCiL2I9c9O+ eKiMvmwxzW9mIZJ/9HaVCWa62kkbwTwPTHrXXLD05XTnd+o8Pi8RWw/NBaIuGedpIfLswCuV+1iU kTuckhweF6HGM5zUbmMRwiRI2iMuBBIv7tiMkLnOc9TjtVxhUoQUUtWY1J1Kr5pkxEUYitnhja1h H7tVmILHduVuOcDAOO/FXyQZHjXy9u4A7WwbnI5O3quBissTSxCjJU6lo2fRf18016Hq0q+XOnHm pe8mlu/v0a+5p37ltVkAt1iRDbySGFy9wFdpMgng849+nFODh7ZBHGiwqZLRplYlrlt24qwPBwQe QBXwEZU6PJGFS6e+j0/z0Pt6PtqeFnXq0rW2d9/8hbVzsd3QjdCCIi/IBOSOPQ9verhkWad5sRlH hVo1ifCQHHJI75A6D0rariaVPEclN3j3tYrDzljsLGdaHK+qvs/UsI0atLIoSRYlEjHf9xBgbc9s k1YhjmnW3hSweW5jV2lkhnJFyxJI2qf7o7e1bTqQuqVzop06UbSpomgtnlaYAKzwNH5Z+0A/bMjs uc8Z5wMcCpWlWSJogH3QGJ0xMUXjIyenviinSpU7umedTq16eLm5y93sTB0itgHtWSJ5GlSZGUqQ DuK7Qc5OepFaGwxzafLLabJ5P31ukN6ZldWPClQOG474IrGdedr04fgKjGm58tXQSMS7JneCISzs HLpMOAXPXn0x19avwYlught4VnnAjd2k2uQTgDJOAM810pO3unTLCqlGT5vdIovJEX2S1QRQq0sW 1iUwQTnHfGc896vQRLab447eCEJkIscu8zqcbjz3OT3qKlGlVXs6yTXnqeXRzGtgsWnh20+603/Q truKhI4mtzFDkI0oLQtj69RgZxVoFJgltFCrAptYu3Y9ifQHvXyfEeAp0qUcTQgoxWjsrb+iP0PJ MydaTpSk3J66u+mz3ZM3mRskSWSXEqy+S1ubjAKqCck9SPb3FW0EbCHzIYLWAW5kWNJ2kLMoyOOo 5AGK+TUW1oj6K6RG0hWKU4DPG6x7N23Jbpz2q/DG6MieVyiGLbJg+UDkBgMc/wCeaEm9EdFSmo07 wloy1bMYlcuIyUTckKnPmtyeT2OOeuKs/ugrxGF9rZKP5vXPUc98n8faqnNzacjncbS5JaEpKsFX YhTYIEQHhSOufb61YBKzAHcSUFt14i/hYfl+HNdsK8JQftHYIqTahDW5eSMJI2IjE6N5LIxxge/0 /wD11MhZoZOEMgIEdwwz5bYODjoQRXz2c4enWwyqxmnFvST1fXRcsW3fzZ9fw9iKmExjoezkpJO8 VpfzlzSSTXkiaARFzN9nkEKje8LyHJP17ZPp61NBGvLokSRCQAxl8bFyWB98EfpXx1emqNaVKLul 5W/DofomErvE4aFeStddGmvvWjJEZpri3kCeWggdJUK/NJuOVY+hGe3rV8YRn3KT8wDJnPtnj6fp WJ0FrzG2QqeNiFflT+HvgemP5Um0jYfl/c/6RJk43rjof50ASBhsQOB5Zc57YTjOPx/lVxjtEhYY 2ISp3/cHGM+uSKAF2vt2nPEgDuX+4xAHH1BOKk3BUKqCPLZUA/LGf0oAmO4fXBycUxgCCrAAMytg jqy8j+X6UAOBBz8x4GRkdaPlII75GG9P8/0oAeSDFHx8xy7qByvtn8P1pyDLkqDsYhCoPUHkD9Ot AE6bhHl0Bby9irkDeuevtg96lGIkYZynl7o5Qcbhxxjt1PNABERLgD9384CpjOxgOGz9B0qyhAG4 RnBVAhL9Rz/KgB2HA5wRtUE7sZI7/wAqegAzgHrn5mz+VADgBjjntmkJCnA5HQigAHb+9R0z82MD +70oATrglu/HFKx5PPbnjpQAmASOd2BgDGKb06UAAPvjHI470d8+/WgBc9cnGR6daQe5xQAvtnIz npRnHQ5/CgAJyTk9Bxx1o44+btjp0oAXPUbuOnTrRn/a9+negBMk4ye/p0oz1+bv6daADcRwD+lL nnO7nb6UAJnJyW6H0p27/b7/AN2gBM/7Xf0oz1G7jHpQABjj72MdBik4znd75x3oAPx7+lA9M4HT pQAn40Zz1PQcUAJT89MHA44x0oATvnPO70p271PtjH3qAEHPHfGB7UpORjOfw96AEUnA3fKdvI9D SMEygfLEtleO45oAr+SNxDDKtIZCgP3euCf5VVkVju3IE25eRsgk7vuigCBlJ3BV2bGMmC+doOPz /rUYXdtAG5wTxjrx0HvQB8d/tl/HDSfhL4DvibhI7iGylv1iM+1ZijQ5XPUOQ5Az68dK/lM+LX7R Wo+Jtdv7pS5t4rj7MI2lz5W5EYMcDqThTx1WvGzehGqlGo9D4fPnLG4h+y+xp+p/ESXkEaGR0/cN HD8gIIUcc++APrgmteSW3X7QsYHmR+ZNBAWyt10Cg+hwDzXBXrqjU+G5+rVXOWJ9tUnZdizCgLeZ +7LLEmwsdgQEBmyRwOf5VJNevFHEybXEoaASOOZFHUj3IPB7DFa4euq8ZaWOfFVYvFKpUWn/AA5S GqI0scJ8t5llBeQJ5ayxrkkNjhSFA59c9c1pQ61FKI7mOWMRCN4UjERBSPIYBvXHOCfU16tbCpU/ aUUJzk6r9srRLUOsboZAZi/2hhtSVwFiUA4X3HfBPp61DJ4jIaKKAs1lE5eS1aXmd2A2uWPTa3IA 6e9GHwqlGNW+pzThSVSX1R2S26Eml+NLnw9qeiXAaSW1ttVtr9od4ywWUOynJ+UFicgnkZPev6wP 2NPiDB4k8JaBNbCKGKWxinR1l+Z8B1+b0HYjsDmu/hLEwo8VNPrc8zibDYnMOFKsHLX/AIfz/wCH P0Du4lEt+ZbVoY8GJmWQFYzuyvlkdh8wJPGMd6sgxLHK7xxIv2f5UY5aCXgAYzyeOnev36pUhiKz jGVmj+UcFgamExMqc3e3+Ro+Y5imRreFnEYa3mFwQ0eDkAAcHPOc+vtV+3EMqHc4lhEphk5ITaBt JI9sfmK1PYr4rD0qcY1HZ/8ABZrMrG3tyqPmOM3ZZXIaQZ4Pp26VqwmOa7t1VIhPcFnDM+MyOV+T 2BGSSOO1avByw9PmXzPkcTi5xzL2dRaPa39f16mraxR7YkKi0mEUuYssS8G/7g9DgDnpg1MFUvGE RCiyPdPcZJwWwASgyc446V1VYUqFNRildnS4VcRX5a0b22/r9C/EQJt8FusiXLF3QNje6ZXD+wJ4 /GtqOSZvJiW08qeFyZg+N0hK4IwcAfj2+tbYipKhBRpI5K+ExGI5nV919DZgB2JGoOHAuRAjhSQr 4Kknkdz7irlu6AWqoQ6xRs9xLHJj7XvY7CoB/wAgCumm6nsbVVqLDUPqkeavK7RctTHHJGw8uIxo JEnLE8hiuTn2/XtWtDEMSsbVYlExgvDvz9qZ3+Vie3Q8Z5ohg4VZewUTnzDE0+eM1qv+HItRefzW u7f99ZRRzJdRPlQwGF6dQP1ro4RZXCfbGj3ny02hQM8Yyq88/X/61db5sKnSte6ObE0akaDmtF+Z sxrPbqxuIYPNhuTGk63BY3IBAXI7cEZ+nrWhZKG3JIIo4gxVtz+YJJATwMcdgc+9ejCneiqdSJx5 ZWk6kpOF4GvG0guEDL9nEmZYrhmPzOo+83Uc54zU0UzO1tJ9nijjRWt5o/4mbd9fc578134erGhS cILU8zOKtX68mofu/Tz/AK7F1Y0c+YYHtriBpERxcsTuI53LkhuMYLdMYrSRoh8kUaW8m+Ih2ky0 YUfKRk5xxXi42DqNzqy1+Sfrpv8AOx20cylUkoUqbat0u0vv2/rUu20yC5ldoYXecFLQtuBtpFOT jHTdnpyPpViTyndZPLInQGFt8zHcZG3KdueW+UY9q4m7pLsRicNinKNWl1f6liTY6tEobyZrZXZ0 BDRyjOQDxx/F9OKcsszxqWZoW3hI/I+bIBwCeMdjxXZSqUoUGk/ePbzCPsY06teGlvU0FmWZAsSo sT75YoC2EQ4IyO59+TVpCHBkgtWkD4RILubzA7hOefTv0wOPxvCyo/G5aniYmnKtzSlHRiozusDR hZIPOadSzKnkN0JUHuSCPwq1BKjSSrIzGOSRW+QtvUEEsFx05xyPSu9pcphHEVJUHTqwtb/hy1FJ Ixjg8p0KBXjSIkbWAwWx7g+ueKSK4t0nmu1soJZFieOOJXYLvTG5WbrzwfxpGNCU8YpKD1ewixr9 pkvf7Os7SW7s3keGwkJWR8luCT14qWRrWQQNd2kM09pZsjzXChlRXG0jOPlHTPrilJe8ZUqVSlL2 dR3/ACLXmzwiRQYvNA/dQsMbpGXIMZ5GOBke1X4ZrecbHjZIyqTSSrKwMiZyTu65GK3w9SNKpzyV zixEU5z5NF/XQLaV5w++MB0V7mNJZdm9OQCe3GMj/wDXT/tELRQmWzEaqxjmETl21BinysOPkOSP /rV7MJQqRVRG8KMVhHKfXX/IIpJNqXBt0iu4AsTecQ0ikjjdnsOnAq5vn2wOIXlV4JMgYBmmOBjJ 6Y+XmscTh5VtOa3+Znh54fl9lVX/AASyiw5S5W2WK9S38iUi5OAATyQTtBycdKdJJILRpYonlfyv PUQ4LSyrwQAcD29s15tXBpKNPFVU2+9lr6HdQxFBqUcHSfKt7Nuy6q+/3mlHK8N3F5tuv+jXIJ8y bcrYAPIHQ5OMZPSmW1x8kitHGjwQq0UKj/VsxOSeB1BwPpXgZlluJVV4ivd+dkk/uk3+B6uSZth8 XiFgsDFRj2vJvTprFL8S2ZVjkjjFrJ5IgInlL/LLJ/dx2P8AhU84heKPz4nMRlkjKR3JV2I4zlTk EBuPauGFDlhy9T6TFTpwkv5iSJLWO3gC26K0NxGLSNmZ1VDkE7jznHv3q+mFt4SImUea2yWSTeJ+ c9/qMelaxg6cLLU4FTnOq6T1Y8SbGaOSBY3kg3SFWw25eqkYxnoAasoiW7I1tbwDzYxLNcCYg3DE gNuUcfKDj8KtXcveKTpTi/aPbYnWGJJEjVJYWjjk2f6QWV2B4JA7H3qUeU5AktYp5FdJlSeTcsBb BBU+oGT+NK7tdjoSkrqPZ/kWAxZ03/6xR5KmPI8yMHnjHXnitNEhiS022ZWF5TLOq3OGSQtjdznH rjFLVq5wewU6rqz36ETBJWtSsCAC6eVGbGYyMgnPU5GfatGExmJ7mTaY4eZ4GlIkZTkDA7EYzwO9 cuNp4ieHlChKz72T066Oy2+fY9XAOhRxd8VC69WtemqTZaiiaZ7aFbQO8hDsk12F5blCM4A+XGea khQSpGsKkyRTqYPNmC+SOuS3596+AxkqcGqcK3tFr0sl6LZfI/RMpp4qdKo62G9m/wDEpN+be/33 LLxhHkRbaGVePN2yD96xI5Bzglee/wDKriNKzygBmkuYWTzAeW5ySSevfivOaatc71ta5djaEyOT BlA4SFFO7vyNx/PJoXcylWjSSNz+7BYKWZTySe56Gu+ph+afO9ES7di2kp3ykqxdhsG6XHnMFLYH 8/ekjhGBNsEcrKC4L55OMjrz9aaeHlLlilf0GlqjQG4tM6ogVJCktuZSPmxu5zyeucirwkyIjhw7 R+YsYYcjof8AGt9GmmDi1K9ySMuoGcb1QJuByxyCCfpgkfnTwF2KjqQI3yoU43ggenTGDX59neXy o4ieI5t3otL/ACSb083b0P1LhvM4VMHTwfK/dWrV7L/E2lZ+l15lxJ0a5zkE7zM+3gxjHAI/DtWk OpAyc5GSf9WcYH+P/wCuvCnCdOThNWaPqKdSnVgqlKV0+q2H5BypUbj8qrnooGS354GP9r2qWF9x KAYWaExFcff6kAj64/KpLFjcBI8qFaSMK6hs+Uw559R07UqZWMr5YKhDGDu+5znA7daAL+5o1LMC coGk7hDjBb37cflTo12KibCQZtwycZduGb2FAEm3dvBBwWwSDw3+0P8APalPXDghMHcwYfL/AJzQ A4ElQcjkcY/i9/x/rRjcyqAAWOAvTJoAT7uzgHK5Zh/AQenvTFY7DwC65LLnHJ5C/r1oAnUgShjt Kb1ZgAcAeh9asL8pBC4D8YB3bN2cHHfjtQBJ8okKleYpPkBfttz/AE/WpRhztKYFxEshcZOMUAPD NlQ67WUNNsU5JHQfzNTMO+3O35wN2OR0H60APDA/MOxKk56c8/ypQcjg89elABwcZ/i5AoyeST06 jFADT8wBJ6dfaj1O79KAEBPQnAxjpQOOQcZOOnagBCck8/jjrS8dN3HXp3oATjnn6cdaO2M9+mKA Fztzg/pSegzx9OlADs56t79O9Ge+7n0xQAZx0bqeeOlGf9rqcdO1ACA4HDd/Slzn+LoM9O9ACE57 57dO1Gf9r+HHSgAyemenTil3H+909qAF3f7f/jtG7/bxz/doAQscj5s++OlJ6fN/DjpQAZJ6n26U nfr7ZoAXccYzxjFJgZ64HrigA/HvQOM/lQAdMY7c0E++e3TtQAdBwe/TFPBHXPTJPvQAepzhTyeK UjoPTjnvQAzAyWVcv0Y+vTpVRzGAzxquwRAjB56k49vr2oAqyIwfG0MzENKPRjzj8vzrP1LVbPw/ plzrF9gwW2BEoIBmYtjAz7kflTWrsZ1Z+zpSqdlc/lV/4KGfHS8+LHi678MQpNdaTb7tP1uK5JRT EYw2NgBIJdFPJB4/CvzCl8MIIri6uLESXBsTkRkBpCVXy0BHbI614WYyjiJujGVrH5zWqVvrLxkF dTu2l93nY/jsk1G2mLAeWGuV8k3CZVUGSwIPU9P0qv8AbZWa5QzQLaJerFHCluQwhCj96zdSTn7v b6VFWbo03NrQ/XvY1cRi3Tmv+GRowahMMggL9oJlWVGyCVIQFeedox19cYqxJfswe38wyW6s8UkZ QmOfgqQc8gH1H9K5cNiVNOM3qz2qGXUaU3Wm7o53UpZHdXKF4HhVrNkIy2MggnrgEY567ar22rTp NDC2Xt4XVJdrlVxtIYAdRuIx+Ne1GvOguSSuj57MZurUqRoy06E9vdRSRtqEuUReIjvKgKSF2lep xkY49SelXxKjzBWQySRRPE2CSN2M7ivcYxgjpXFUxNanTajqiMvy6o4r2srI0Y0DvHDIrTxz2yW5 hYgCVeCVyOc4559Pxr98/wDgl/8AEdn0FfDGozu2paWRJqNzKvz3PmK+2Q8YB27flHbrXlZZi54f iOjWhs9PvZ7dfAUXkeKpJ62f4Jn9A1vKJ7e3u4zue9t5UnuIy2JEWQ7V57ZUHP8AtVcsm5l+zpHP Lb3QTyZfuxSKp3r7kA9PTFf1nGEKaWIS+JX/ADP48qVsPRx9bCVJa30+4s2ckMcMl7K0xiSzKfZy +zC98sO+QoHGa0raFY0C42/ZGjDxpIWLk5Oev8II7VOHp05zcqUtzz82lCs4wxD97obIHlupAWRj IqtI0nEg5LZPTv096uxKpSYttZZY+GV/LaQB8llLdCNvb/69e3Cu2/YfaIxeU0J4WNd62+/+v0NJ fLxEbgOAIGiVYJNhli3Hq3UnOf8AGrslykEchgtZknSFVWZJgYzPnC7h1O1etc2Li+WM5P3jnwFV 4iv+5Wv/AAGacSPJGiDyldidwkIAuHzkAehwT09avRruMhuIoh5kmxXSTevA5O7PA4HJrClQqVrL odM5NynHFLVbGvAZiNtvtXzozFIOmA/ITJ65xwRWpATtgEMcKwrHHNGm/wD1RBIcrjIb8iBzXtSt Znzzi8VWcY6IfBKTPEGj2zST+fM6nKr8wCqM9cgZ6VswbAjp5X7mObdKssn3mBJ3fU8HPbjFPWLU kzsVCEsM8JJX82aw8h5zsik5wJGkkwZS/Tcfp3FWtPt4oTEkkcVxBE0bxbwMxPGDgY4YgY5I5OBT pqrPFRmn/Vzy8ZQxLw7pLZG7bu80LnywXYK6R+Z8rb2+ZvcnH1+Y1ehaPbLPFbqYEJ8mEsSozkZ5 9wRg+lereccRGz0aPIqyxGHwkYYdf1/X/ANEXMcksZmQ4MPmwxmQDy325YEgY5wMDFW98bgzsGjt hEtxM7vveEtx82O2e+O9dLk22YqlUw9RPFO6ZcimcDdMmxFVZVjgfDSgMVBJPUYOfxx3q3hpESSW wtZmMOy2nlvPnnZecugIx7A5FXLAVfa8sJ8t+yX/AADjp1qftmsXBuKel5NW9Ohet5IcJIsTRrbx oYVVuWP3txPbnPX071Y86R4xDbhF2zu6PM6/JJjexXPGQD+vvXh16Cw850nK7X9f1qfS4LHU6le0 abd/ml/Xp8y1FO8nztHOghRkaSZgFuOOGUDkDBPB9KnMnlvdhPM/fQp91eHB4CA+oA5PHXvWdOnF v2adjpzKpKMF7fWPYsfvEMjfZYJZkg8xooNRDC6iUbs4OAreoHPHNLCy+XFIjPMbh5bm2mmcok4G Dh2GdmTjjHp611vCRhDmqyPOdXnwzdGOpcknA3StbxGQorySRzhjcODygx0I7HpzVuC8hRkBgupI nTZuScISjnacjuAcjPWvR1smji5631ZLEK7f4Drd2iRVtpHwr3ILJOWkLycBSD2XGAAe9SRybfNL Bd4crueTPlMpBLcH6+/FEVHns9jFKEKEnR0fW3z/AK1GGYC4muo1ckKI490hAJbGQR/D68CrKzRw z+TszH5m62Vm4iP3mJz6n19u9XUjCFRqDujCi5SoxciWK5UxQNHG00LKL2FQ4yjgEIEJ5BI3VZE7 xIJp40jM0oj8oSlyqKdwyB7nn+eKUrX/AHa0OTGyT5acVqS/aTbxbo1FvIs7rLcu3meYjdBjpjkg fX2p8xcfaIihSaLNrGxbBikBH31z8wx0x0NdVL22G1qrQ0xcPZ4SKlLURTNNhAymYDKlcDyj/EwJ 6nP6VYLRPcNLCDG8/wAkQS4OyQrngjtnH50qdbEyreyvr8jzXh4Y2PNL3Ut/xL9vdvL5cRt/LkSB Wl2ybwI2bBOT1OanaSdbK2hNtIllPdZsp0lKiXYSXz3OOeK9KlR9nFpPUy+pRr1XOktESAiNbdYG YFmYyCW62nOeCueox1z6YFW48yzpbSRRlpcF/Ol+4F+ZQSemCcjNZ4hVuW1FbmlqNKs3TWly6t0W SPeoWYP5bFHy0jg9T2HbpT4mmmiVSIvKEEjSb5gpJAIYlT1IPbuOlePLJnytyqvm8oO33K6/FH0l bP6kMPGdKhFwt9qfvddm3d/j6jhcRxQJvt7fy28sXNyJnDW6n7pUAkHLYHToeKuD7N5qM8WdzGUK xO3aGGCR04P8q8TMVLCVJc0k35W/JbHoZPVWMowmouN+9/ze/qSwzYHlPEkhd5PmMvEpHPA/L9av vG9tOHeO1FxNEA8sVwGIHBXGOBnGMdeK46dacqalY9XFYGlOHNeyJbclIyAvlYdpW2S5EbkFsc88 k/0qxG4mWGOZPKaQrGY7f94zEKMZPHVj+ABre1rNI41Vp063sX2ZbEzld/2a3SG4jEFvOZy7yFW+ fnqvNWFlEcltKzAyMw/eM/8ArNuTnPfnjj2oeiudFHCSqSd5aXLLzNGiSRRRArPvErsVaQPgEc8H HP55q2rkKgVRHIoKLMX3bJMkAfrVxqSjCSj1FWhSpVUo6otiTE6r5carGMPH5pYyKoxuz7nn2x9K kQBmaFoIbls7ZIjKAASvU4+8MDp0rkxVGUKXLSq7bu337d+6FRrzeOvOguR7JN79Hq3f0fzZYtYZ WeNmA2XHmbwJQQDHgoV5+U46jHf61ZgmMaOHRyEOB8w2wjPr1P0+lfndapRni5109OmrfTu1f7z9 Rw1KVDC06c1bTsl+Cul8jQRyU3OmC+DavCOSPU8Z6gj9aVlleOV40X91NFDKUb5BuySPyH0qq8XO k1fY6IvW7LCtCVkSWEO7nflpMbXDZH6Vbg3KuXQqGDShy+Rgnsf8PSow0k4cq6FLfUsqhBuC0iS/ Z5ESTe4JRnzgg9x79BVhH82SJMCJRgMyjG5lyM/X/GuuML7g73uWWkkh3gLhXkBUxkEjJGeO57Gr C+WWdBGxVHWaJVkwIGJIPHcEdq8XOcHQxNDmqPlae6i5NfdrY9vIcdiMHiuWkuZO/uuSin9+hZi3 4m8tGCzwKTu5CqpJ4/XJrUXchdRbqpba42OMSsQO/qAOa/P8X7L2zdKq5+bVr/i399j9TwPt/YKN aiqfZJ3t9ySXyuTMVJjj3bih81xjmQAYHH1P6VMgXe4clC5LiTGdxC9x7nArmO0WFgWx/FHICX/u gcnt6c/hUuWbcy8lZjOB/dUH+vH5UATmQEJH5RZlkWQbZCMnOc59896kV8KsaESOny4YkF34Ofcc 0ATZX5pNg2yEKct95cDnH6Yp5Bk+XA8tWD7lbmQgk4x2wQD78igB6lgE3537csB0B4pwBGMHI78U AICASNwJHOPzH9KQJsAVR1bPXoSc96AHIcYbG4M3TOM4PNPDEYUhsBRIVHRsnj6ccUASCSNQyEbg shZcEjeDxj+VKCVRBt4iKyctz6/rkUATJvdJJWQsxwFKvjjPb6Va52nLlGdhs5+4eMD9KAJEYMoe NflJypB9+eKeoxgAYwOMelAC85JGBnGRS5PODzxx6UAIcjp1I/Km8cjd15Jx1oATsCT7DjtRwf4v fpQAZ6jd1Pp1o6kZPGMZxQA3pS56D0oAXPQZ4xjp0ozwPm5HQYoAM+h6jnikyRwDxjHSgBe2M8Yz 070A4HXHfpQAbjnOfbOKNxPU/pQAd/vd89KXcf73fHTtQAZx0bqeflo4/vdsfdoAQE+uO3TtS56n dzjHTrQAE8fez7YoDdBuwMelACFjnrn8KOD1bt6UAJ/Sj8e9ABgc8/TjrSgnpnA+lACe2eM56Uue RzwOhxQAckc9Cc0vGPvZwMdOgoAUEY4PJ5PGKBnOAeOoOKAGsQisxGdqNj3A5quU4lHLLlnZQ332 Pb8sfXNADFQs0m5WVNomwDyjEY+uev5V+ef7c3xutfA/hS40O1uTDMINouorlFZ8NBIeSMAAEjPu cVUVc8rOcY8FgZVUr3018z+XvXdS1fxHrGpeIdZFtcahd3rzT3ds2ftcPmYjjwcElVK5BHYmq0+h yy2rLFEJLpLsyOq4HmQkKAcepycd+K+Wz+i42lSWr/zPz/BynUxjqU5e4r/I/hiUPJcIWbybSJo5 fLB5ySQvXuozgd8mq+LwkxQrhoHYKkchYmJidp56D9etbOtSbV5bn9BqnXVGVasveNlZmLSurM04 jMcJfkRxdXUHryB+lWQ9wyyRztHEsqDIVcj94oZPpkYOB6GtJKElGNtTzZYXGUqdpz3Kl3HeCOC3 ltjBJ5PmRswLByVypBHONo4+voayoknH2a3YhHkiZSZGUAOFbAY9Fxj8cirik5WZw1cPVwb5Ksbl eOe6QW0ht3eKW2a5UMnLhsYAHGM9+feuhMplNsJoiVKYZouMnkcHtngHj370neei6GtOhXWESlJ8 2hs6dLcmOyidVluYI990THhZAGAJ/AFR781+jP7Afj2bw98Vr/R4W8wrcC7mbdhbqRhGoznjCDkA dcnvXgYqXsMwo1KWiTX5n0WCwsZ4OtHEu6cZfkf1feCtTTWNAN4s8StChf7FtMa3Z3v0I447Y4xX WKlw7SvJbWcd5DJ57Ti5ISNnUYJz95tvtnmv6yymTxOW0q97qyP4qzHAfVeJcU2+v+RfEbxQpLLE wZXczW+4HCdB64BODTlJn8mMFfOvrZllJcxrH8wVWVs5LdjjnpXt1MHThByjLY86plU3X+sOer2N xLh7pAqwxuzxkQlHI3CI4OFxz8w5JNaHnW4Cym3E7KkSQIG3DD5y2emOpx/Sub2vs5+0r6O5ssNi KVXlcvdW/Y0IpE8sSmSZ8WwEbyjA8stkLj0GD+NXDJOsl2Y7RJTHblJrBZSnlKSAknzHqOcjvXVj XGrRjVhqZfWqWExl6HVMmV4po53MUks0cJlsbjHzwpwGwSQFJHyg+9dNbzO8Q3IPNEfky4wCY8cK D+AHviuvDT5qMWc2YU60X7bEO6LayC+tgVhXd5m1LSOfiVsfM2TyNuOnfBxWjbtDblZIFSKCMpbC NeBjo2R2BJ7VrvLQ89YnDwbVNbmlLJMRcfZxDbXC3PmQJAchkHLBc8cjuen61pW8kcY/eCRhsV7d hLgBlwGyuOcZI+lE/eqc6XyMnnMadR4anHc1rQTGY7RJC0duFlnUg+Y787xngkDoMADHrVyNldZY FWI27xiVGa42gqPfqc5PHua6qEoYaPtqr0ZFWeMeJvGPu+dzWt/Li+ywtEI9sbb5YGCogx8gxjjg DvViJoZHW4dHWa4kgDKVKmFBk4OOv071pHFJ1+aS06HNmU40oSjTVnp/SNd2eGSa5e1iiNu371Vl 2MozjaM54OfTNXLZC7KrQJFJKR9o2zgbYwCAN3XIz29RXZToODlW3bPM9nUr0Vid/wCn/SLdvFKs yTFDGtmip88m5gRkjryQ3Q9eTViCTZaB2sIrKKS4MzSXEu55N2MjjoMfQj8q9hxlVUKsp2Z47o1M VBu1uXp3/IvCWaS3GzbDv/c3ECkgdTsDdeMjpV1LoPJtKWsVwwLhZF3R25cbWKg9M9voK8bMqEoS 556vySu/usdmW4r2ODk0kpN9ZNJdLJ6/8EUNHMCUtzHNFbARvLeN8pTOQYsbfT3qxKDdW6OtvI0E KD7SmOFzjjPUYOOfb3ryZ8sKkYUrt+lv1Z6qk8RRSr2suzuvyRYgaOSUQlLdmnljZpJTsAfnDBvy 4PSnCeaBovNS3WSIKJEE+/Y6tgsP73btjpXoU6lWU/ZVl63O6i6L/ibPZjDPDEzgWyoJJ1Md0bre WDEhgVx06Y5wK1GeRZFj2w7kg8mFpSxQoTnOccnPetpTmqsaajoc2OpunRummhnniKJGWzRZAzNL smOLhl+bAY8dBnNS3MjBppGgSPy0aSOUSCQF+CeV5Y89h61tdNngZXKOGxVWjidmn08i15gEka+W A6hpjHwGBYKSc9W47U1ndredoFQm3Lyeas+C4LgYHp3+tD3uxXkpPn0SL5ulnj/cEK0MHnvIJQRP tbICxgD1/GkuruJI5LoRFG8+DbcRPvCF2+RPUk8nH59KuVOUEm3uc9OhXq4ic102Lz3UiGeCaG2E mEWCVpGLD1KjG3NV/MYzy5iWYXEL6giBsGBwQuGyeQcE8eldVTEOWFUW9WY0Y1atZLERuLDNJOx3 WUYjuWiXyGm2m2OSWPHpgd/SrplCyyT+QPLuMlgiDl06YPoKtTWHwycPiZ04vATp1NHuTxSuVUm1 MzSMxhgMh/eADqOnft7VaecuzbIXV1YRiLgeQANxPHsT+ldVOqvYqrUfzOSnRrYWTo4fZ6/1clke BhvMMEqLcJL5jIPnJbGVPTjGMdamimiE0qvIAZpVaV8hA7opyuT32gdKmLdaqpxl7qMIc1BTjWjv saDXKwCNbnzbbfZvPJePJv8ANDfcAXHOeR+FSP5zSLNJGn2eN0ms/Mm+e5blZRjvgYA/HiumMm5O LRnXhKnRjNq//DhbLDCLiWK1Xe8igu7Z86EE4IwcDkntVvzcTG42TiOOTyhLI+I5gwOMAcjBH1qK sJ1KbipOL76fqmgeIo0Ze3qUk121/Rr8/kWDOmIXeCLfOD9653CJMEZ9iT296srcfu/IVSJsJLG7 EKskSqQx9vSvnczy2OEaq4nELmlrqrfl/kfZZZnEMfSWEwuFfIuqd7ffb8/Q0JLh4mdjtV22txIG VFAOeehH071Zid5pImVHKycjYc7SvOT6cjtXjylLRPoenLDUI1dJIewQCEfZ1SR1NxHFKctyeT3w Tz/nmr8LytiSG3L7mSGCCeUD5+MkHHHXn6ipu72Z6EKXsl7FLTuWXmRpriOa2jdVbyHQOXR15yTj sCcVbW6Ro5IohLsZS0ibwRIw+XjjnjHFCSlJ3eh5tflVRxgti7HPH8sRtWlDxhYbq4m4jlxyEAIw Vyc5yDxSpPwiRJGCc/MZAdzD5eB0B69f61L0XIzfE11PkcH5lq4/0gX3n2axNcIFmhhVQrqAAdqo fm4ySR+NXlZGmRTHtNwFghWHAChcDgdieOvXmscwo+0wjWDqqFtLybt873T9XqdmXym66ji6Lkt7 Rir6drWsvLbyLMN2oi8vyWhAkKRvHceZ5Q7bhjrxzzVtGVN0ghhaRpY/NleUAdScY6EYOf8A69fE 1cDVwUFSrtNPZp3TR97hcZSxSkoJqS3TVmvJksL3TRQPc2sduyyPFGVlMgljBPJJCnn2HGOtWo5F jEhWJpGnAiUK52xnOD1PoBwO/PtXn0YONSd9EdnWxciRPKhjjtyqzBVAL580KSe/OA2SPwqwJ5Bc kKyyPKiwOXcZGT/Tp+NdaXNdsl3cbXLi4kZHQNHCtwoILn93lvlUN1/vfWrXnZUs0YjRpPLJJyZ0 APzKe/OB6jNSRSVSK5Z62LVozFPNYNunhDNvk/1b8huBxx09O/NXw5MLuMopZf8AWcEsWwCB1AwO 3SvzXO6FajmFSdVW5m2vQ/YeG8VQxGVU6VKV3FWfkyXznYyFY1BG0KwkAaUk4PHRsGpkOx0SVNrP JJcZ3dOm4n0OcZ+teSe+WUkG3JXJJCuhPKZPPP1zipUUMyNt3MuYl+bBIJ5H0OKAJAWCDbgPNGwD EdFU/MP5c1Kdq5kVeI2QouSdo6/kaAJWKhyjQgb9sLHzPubuQAParCFg4j8rZ5Q2MN/Ck8j68Y59 6AFidmZSRnLGRsnqpzj6dvyqb7w+YDPY9cGgAV1dZF4KIxZwR90rz+lNVmbC8I6AMBwcAn29Rn6U APyM4yMgAgY+uP5UblIV8EttJEmTkq2O1AD8EbsgcqMHPTOCP6/nQGUoVAyMZbJxjB4x+H86AJ4m JjZVTDFS0hD/AHkHH4Hn9Kn83zDGfLDbMFyX+6Mjn+VAFhAUYgDIkPJH8LYOT/L86EcMyFUJXZxI W+6Pf34oAnXgBSuOBkFs4P1pSSCBjI7H+7QAzlWyiBt75Y7sYGOv8qeeV5P1OKAG9j9eT/WhjyAD wMEcdKAG++eaOnTuMGgBP6UueoB4zQAd+v40cY6/higA6dD2z0peCeW7dcUAICR0peo5bH4UAJ64 PfHSlyeBngH06UALu6/N39OtIDwOcfNnpQAZ/wBrvkcdaUnI5bPtigBAcDhu/pS5A/j/APHaADd/ td/SkJ77skjBGKAF44+bpj+Gmk56ntQAuf8Aa756Uu44+9z6YoAb06HqMHjpQO4zjj060ABJODnn 6UdeSefpQAo6YJxz6UqnHfjPIxQAoAXPze3Sg8kYPf06UAKSPXB6Z9KTaASVABPBIFAHLeKtWTQ/ D+p37MA8FurOgPMm9ljJ/wDHs8dK/m4/bQ8Tr4/8Q6jbGJdRsrWYzPbzKH/s9lSJRuBPdlJ45I/O rilynxnFU8VVlDA0n7sld/L+u5+f6+Hg90pt4/s0hKxgLEG2juTzyOD9K9S0vwZ5yRs0TwK8RMd2 W2rMCynKgdOQeO9eLnFKrUjFwWh8NCliMLN0KTuuv9XP4Bv3EkcMc8EYkIibzuv2dctx6bsrnPt9 afLbWrPMI2ZBdKIm8pcsyKQSSPQGvFeCqRemp/UbzHDxrPDy3Q2HT4xKrLMpgSBpWQxg4wrbeO/8 VQi1EfkzL5DCJXBCcsQVC8ccEZ/IkV3UJWpKMt0eBjM3jLFqlIvLexSkSuwH2eFftDsQdgXC8HHy 5pn2WyM8rxxpD5itHHboPM3IQSOvAPTnr+VZqjW9u6kpFLMViJ2rIptBbqokZUmuHAij5ysCjn5g evXGPrWbPIlpKIAqRosLae679xMb7jtyfxyR0/KvRwkJzm41PMeb4idOjCeHj/V2dP4e1TSdTMET sJLsFIy0b+X8rYVApPoRz9K95+Fxbwv488O6zDNDDbpdp5iQR4+0xvIgLAg5Gefzzjivnc8o1qdS nK2l1+f+Rtw9m83GdOrro/yP65v2b/FSeI/DlmV2yRy6WqxTi6+XIWUjgjJwB+tfSrRiaGUNG4Al Q7s7ndgcDnOVPr7Gv6c4OxdR5FSjF30Wtz+WfEmpRw3EVVWs22X0KxSXLGGLzG8oTpv3I6noQejc 9ueKsCAQuieWk8fnG1CI25olPzF9p4PPbPBr6GGIrVqTi9PU+cwFO+IhOtfltv8AMt20rKrLCuZD Dh3aTYNu7kd+3U9614IYoGgJlFstrcfdWMeWjBeBweOSPwJpRwrxcfZS6dTPN82pYXEywzg7S6/g X48vZwPOywNJYvLJHKx4bcRsBAztBPB9DmtUBZhHHPbLGd4XekocykfM4YY68joehr1aGH9nS9nL VHFDDe3mkugRx/aI4rJ1QK7vF5bRg+SI8OME9Cc5x6CtOMsFSVywninfcCODGp4wB6nHvxXNTxMq MnCS0/I+hq4Gni8JaDuzQWQkqyoEjgkMsxjlGZk4G0epU8/QmtW2d2hmjVkLrL5029woWH+DGfvZ PYeleotD5HG0o4Wl7NQ1/rUuw7zh5Ukinc/ZjGxO6RSMk8cAbcD/APXVuCQo8sZWM7LYbHWY4kQf MAeygc9DmuSnTqwrSafunBhFQw8J1G9TViZVNoihpbmBHaOWNsZYDdsY/d6HAzWysH2iKRPJJgmd Et0JykrAgjJJ+vXrivRdZTpqm1sRg3XzGUp1HZIvwAzR+XIGMUa4kDzbPlyQWKdcKBjHfNXrN281 I4I7ctMQYrdCR5oUfKMYyOAOneuihSpVY+9ughGjUxjwuIXctoyK2+FX33MRltwJmcTKjEvjOe7E Z9vwq6srlYhIjPdLAkzhQM+Y2SoJHI4I6cetdlWdbRQWiX/BJkpU5So0Xp/kXxcRrcF0URxSWscT SCYt58illbJ5xySBjvU1rInleUqxIhmBZWONidPvHqCMdfWlQq1KkWqnQ4lCLqqpSSVtGW4riTzR EQsT29wQkfBWYlTlgR168k1ZSZZQ0f2VwHX7LGY3GXwQSzL0x8td31iOK/cxXvJnPi8uhUhKalZd P6uSrJG0k6+RFITLhne4xtyCfl7Yxj86HniuYmeeIsgUeZiXAJGNvPXHHTpivTqU4UcLZPoeBGlW weJU5Q5rfoXHuY5Lf7RcWUF6z2629w0wbEDllA4BweuOmKdBJFL5rwRRL5bEujsdgwwXAI5O7+YF eTTp4uGGtGV1t0VvvTv96Z7U8fleMi8ViaNmvWW3o1b7i1cXYhmtkt438qSTYsjbW+xRKOS3TPUD jkmkguIt8yghhCzqA0uBMrHczk8/QD+VYrBVcLUdo6d73X3JN/kXQxdPFWxEatotaJ6P77pfn5Gl bTCaEyPlt0rfaMD5VGDhTjkcAZqJJBbCWGERp5JVo4/lChnOcN7mk0+R8u4YnLqqoupzfMuCSaeQ +Wnl3sSfbEWWbDeTjDDngnr05HWmvI77VZY4YYx9s+Sbe0yjsfQ88H6+tc2HqzqPlkeVUoRhgmqs tUWVukj8thG0jSK8sTwuF8uTI2r3yBnPWrJ3KLiWGCRTbgRs8D4wT0OT3zuA4+lepelQUlF3Zrgo YuFJV4/D/WpB50bR3fnQN5klwr75LzehYgAKc5wRgYI6/jRJKu+RnBWV5wJAH2rbMAOc+mew9awT NqdV08RGUoaE1zcKJBM6FBJPGWhVsmfeNpYHsOhIq7DJaNdkR4NusYS2kim5jX+Nj6ZIP1oveyb0 NcfUq1a0pU/6/pjlkGL1BC0txvZY4vO2+SisM/P0B9PXNW51mj81ikahrMPaAXglMoBPysF4GM02 4qb5fhOahP2mGlzr30WJXPk/Y0s7i4sIJEhNjDOFa3Dgb2VuO2eRzyKfFcRq6W1xZiYoTNHPLeYj tugCFcZ3FDnd+HeunCe1lJxpuyOLFVcXiKLSj7yNGAzPcyQ+VaqdyxKTc+WskSgnALfh6dKazXZk td9tbxS3CbUMV8P3bKcnPGADx6dK7VGvCSlOWhw4eq3Rca0dX+G5cRj5rMyMitPuaJpgCpHTnP8A 9Y06C5keZ2nVotmJ4rqc5SRjnIABxuBH6it42a5iqj5Yey5roliuNrwrKIWuVCwNcLyLhicnao6D A7+g61qrcyGZbi4t1iPmNBawzSKzqzEL2PAPFa1Kkqs2zxJ1sOlyUY2b/Ilkla2jng2xvNtaGcxt vQ5bJ+uB0xVsFTbCKMMlu9wkoyoAjiUE/Mp5wfbnmuLE4SlWw8qFP3XJ3b3vbyuenhK2KwleliKi 5uVNJbWT+X+ZIsiKY5o7dXWWVLeGZ5Tm2Vgfm5PPbn3rWSQxSOiESNHFIjqJNoK92GfUA9OeK+Ox VFUMRKhF3sfp8MRiMVhaVdRtzK+hYElm37yys7e0QwtaBrZmCvGQCQ2WPvzVuG4EwItUOEty8dr5 uGt0C5Lc9M4rnk1CN5HO41HU5LaksVwI0t9kayiORpokD4KM55IJ4B/occVoQPhFjwqoEaUMrcLz yM98VpGCqVLPQjGzWGpxpxXvEpkhnwWgPntKIbeUuFVG2ngehYE8irxulM8N4kG1sfu5BMOwAyD1 BJyPwraNV4duCQo1a1SinWLtvdKszReRNbQSPK8SE8PJjIbA56seT75qQTOI98qlIwfLZxjYXAzj Prg1x1qNHERqRqJNSd9l/lr87sqVXM/aU8TTvHl0Wstvva9bWRMLgsiyFxJtceWCxBw3BBz7Yx9a 1LeWUoyIsReJVBM8/llfTA65Hp34zXyeOyqeDXPSfuLu7v8AJJfez9ByXNpZlV+rVl77V9FZaf8A bzv+BaEhxFEVZZ5lHmszEM2QTgD8D0p8UxdFLLzGnllZBtLcHoO56nj1ryHP2avN6H0MlKk+WojQ juEMhURlP3ShGZyRIM4A/wA9KkkmLmERxB9o81YlkJVFUkHHOasjRdDTt5GjWKY4Bl3SPEzYGMd8 fjV9HZvNyqK0ZVc+bwM54+tedjcvljKbhKpdb2a0/wDJeWX4v5nr5dmUMBUjUhSs/wCaLfN/5NzR /wDJfuJS8mDGxUcFss+AmGBUD3bkfh71OJg5mIUZkGCC2fLOQe30/WvjMVkWPoqdecEop9LvTut3 Zeep95g+KcsrzhhacpOTW8ko69m9Fd9LJolheRp0/cBJGYK5MuVlTdkEenX/AL6zWhHIziUlSBuY IFbkgZAOffBrx60acKsoUpcy6O1r/I+jw86tSjGdeHLJ7q97fPqOV5HlhlQbQFLK4AyMjGPyqwPl j2ouCE8pyP4gSGwfxGc9azNhUZmLfLl2myGzgovBJ9P/ANX41YjmVhIoHmSAmVuxRexB9c5oAmBY RxyBSGEKhWJ/HBHTHqaepxwwGJI1NuoOdhAyce/19aAJQNu0hBu8tmILdzg4pY2xnjCOw8v6Yzj+ dAEnGFQHARPlGc4x6Uh6ANgKccg4z2/z9aAHYYYz93J6jGelJ/IHp60APVuGGM78uBuxgjv+QqWJ 8vGGUksfLkwcZXjAoAlWUJg7QNx2CUN93AA6frRDLjO7JVXMxI6k4xQBahk++7kltgc8cIOoFS5E QZmbCk7hkdM//X/nQBMCQcY5zkigHjPC5/GgA5zgd++OlIM4XBwTx0oAQ5OPmyD04pBgc57dMdaA G/0pTx0OfwoAXjH3vfGKTsOfw9KAFDHjnp7dKTOCcHOe+OtAB24Oc9eOlH444oAXcemeB7UZx36D HSgAznnPIPpSZPr3z070AO3H+92/u0Z/2+vX5aADPQbuB7Umenzd8njpQAuR/f7Y+7Rntu4x6UAJ wT97gDrilzwRu+gx1oATJ4GeBjt0oJ5Hzd/TpQAbjkc9D1xQWPrnn0oATqeaAcd+g4oAMnOaUdME 4Gc9KAFx0w2cYHTpRnnhuvtQAAc8HqMA0MQm5mbheTxjaMf5/OgD42/ae8enS9EksYXDwtBJaXI3 Y3FnjK5HXbg4yPWvwo+I+mF47qZ4YhLdbBfTK3EgBVCrdzheAep2g4rZRcEps/OOJs3wtPEyhU+K Oitc8W0zQYI555CyRPb3LW3nM+ZNjAlHwcn0X3r2Xw9plvFYfapIpBHHaKLiMNtaJEYNnvkcjPf0 rTMp0Hho16ux+awzVTx7eHqWb6PY/wA3dL5CZI1ciYgQS+YPki2nccc47/pjtSyzhUBR3UQyMkWZ N32hc5+b2z+RP4V8rS50nGXQ/p+cKOKxXtqb1ZPbXU0UzIQI2hVPOmJyzbxjYV6Dr+lSzhIobiWM /PA0kEwnG138o7A/0PPAHbNRQoRpydRu7ZzY7L6lHFp13/VyiIpd11maTH2gTXELAlZI+u7J/A46 nNJDqc8TTyyyEAlDBHEuNxHy49u2OfqDXRBe0l7OB21qVSklTpLQat75CyyTmQ3KyFZQ6qDauBtk De+09R6+9Fw1jfJGsq7CxEgdX3eSu4bsAc/ifWvRwqhTlOLZxyqVad9LtdDBFlLZu+7fJJbRNcIY zgzHJ2L7emfb1r1Dw94h1K2+xMZXw0yh52HzWuxV4C9yOB16N+fjZwp4yhKNPp+hOVYmlLEynKO/ 3H9RP/BP34mReKfh94fvpWSCVreO2a3E+5LgKjhgD75AyOnNfrJcAwNOIgyu7FLiPB+YHPzH8sj2 Ga/avDSTxOR06cpdv1Z+Q+KuXxqYyWJxcN9i1bN/x5yZimdmdIIzJ8spPQ4x254Iq3H9mSS3tyFW 0hswbliceYzZG0/7rY6da/QsRR5Jcj2Z+SUMZVq0lSva2ifpqW7SKaSKKKfMUyIHmcKFO7BAPqV6 Dj1zWjZMrSSSRutsJ413SsOVKgB8g9hwQaqNWFLD+xgtToxVH6zQpyrxTt+W/wDX+Res5VfLjcGj C7Zd3zQrnAKD1YdR7VLcNcxfaIbfyY4pp08q5c7jGx4aTYfYqOacKk6ULNXTObG4mk4fU8NO0vI0 gZgWm/dR2UiyW9i7fekcIN5KZznjj0zWrZMpLIN728EqTNvYqThThTxkDOeO9LCP9/7yv2MMNUrZ ZSVLFSvb+kW12xnzJ03IFF55KDguc/IAOR2yehzWvG7yiNp3V5iscZCgAIxHAHbvj8K+gq0XTtJO 6PNzHMIcrjJ3uWllcwJdL8wmfbBJu3Mx+46EdyffgA96txsWkQvGsQ+zg2qbjmVtvP6Dv0rn57K8 x5XRw2Y0qzk9tvuNS2laKZyYlYXEf22SKObKqqgcjGcHPAFaEaypEY7dYJpy0UjQzT+WJOTy3ZSA e3TPakkqTdSO5wZWsTh5yoYmNos1kxGVWa2jmSWfzNryBlmZVOQXHUDg1JDPJG6QgLAY5GjRIZgx kBHP+7tz9aVGcatPniyq0JrFcuH31t+BtW+ZYYzDC8IhTz3cMMxxscAnHoQenXNWLYiG4kSPbB9p ke7eNZAQ0hGRg/7or6CnWjOnfp/kck6OKp13iaiu+ti0nmxiINCoheSSMZmyScZDev4U+FWELEnE Ns3kTTFxtDMP3YI68DJ4/rWKow9t7em9AxEqMcvnVh939ehaSWVJ7ec2vmK8qZ3vtA46cggkmmkx LJKbZsPGMnLZ+05Jy23qMDqa9bAwjzuR5FLF0MZh4zi2pLSxZtLqV4U8wrcTlHdhEmz+LaFAP6k1 ZaW5V5lELyPbLmeWWURhTlV5B5zk+ldGJjFyjKb0uccq1XDVnUm73uSwz7nmdh5QtoPMBV937zOO cdh6VageSGaJJUNs93GZo4SOASuQMDpya9CnU9m5RWzufP46OIr1PZpef4/0gQll2TR21tPC7xxz rOWaYDAZB1GOcnvxTo5HaW7hSONoLK8DQvuBZAV/iB75zz6YpYemo1veej/r+rnLXw2a11zUVaK3 /r/hieTyz5jJFH+8Rkuyrkb92ADk+w61YQlMP9lAMkIBfduiYrkcHoPr61pi5YiXNRU3HzWh9JlN F08G5V7STXX5/d+hDIY2QROsoIEkVzOj5eKNwuQMkAnjHXNXTctCZjEkLoAscikkRvlMJ82eOB+d eTh8A5TnUxsrrurL5NW3ZFLFUaWClh8JCzTWjvLTyd9l6IetxKHVdkjWZjT/AEmOQBYixGMr9773 H8uKUXO4l2h8t0uWiES3BIDqSN3PXjn0qKGXyxWIn7JNRWmu/wB2n3nu1syw+HwEZXTuumz809SY 3UZuIRMsb2waPAVtgnJ4256gDrn3pZLqOX50tREykrw2Rt3+5yex9aill2Kq13h3GzXfb79jxJZk 6VRV4yvFPZWvbzW5Mb1ozCEQzMl2pZi4UhTkFhkds9DUzyNFHcP5Yl8m4KBIXCKPTpkde31rCcHR bpVFaSZ6cZf2hOOIoy32/wCGaLD3LPPFO6QkpbqbhEyBOPQsPTntzUxuDcyQGCNN5R7tY7dt3sOT 7A1C5VT1L+rV/rEYuOvceL6O4ih8y1IaZgt2CxDWy/MBjB5Oc5x09auGcBJWaESsR5G9zuVVBUjB z7D9RWlOqoUnCK1dia1Gr7dwoOy19f6sSie3a3hBjR547gwIyZzCpO7HPHPQdKlmmdcMJNrTwOTJ BKC3I5I/h49xn+VFaUrqMZ3Ry0sM6UJwluyzHOoRmhDxxzMlxcCSQfvHUHB59h+tXEuAZfNiTpKI 3SSbh17L6ZOe1ehg2vZWucE8vnVpWk7MmtZAbdIy20rGsixNIN7DcRg9cngj8M1pmWF5Bsh+83mR TRy/Jb57YPJHHQ+ua6m4xfKzlw2WvDc9XGK/YU3gJnZVcH903ml9u7rkBT34A49e+Kvx3EjMAsUh kb92sbfeUL1B56jk49qb1ep6EfqsKLUpXv8AeSW12juIllO3z1kmiYkAMgxkKckdf1rQiuQPJikC JbyxyRz3LyMxjOSQwUdyflwfwrjxNOSoyeHhq+1l+aZrgsXRjWpvMqnuxWl7tLXsn/wByXbp5CLF AkMEAX5erMGz06E4PPPGBWnHcKQZBsLGQkzh+FwDnPsDXkYvKqdTDQlhaT5rXabTXfe628kfTYfN qcsTLEYmonF/C0mvuVn+LNBZ5IltXj5QOZI5FnVxIBySVxkE56HrxSwyxsLbcqgOpuApYqCcnAPc EkdCK8H9D1Y04Yqq51tGSi+itVknmtlDWuyV1kusB/UfmRyOcVrS7vN+xfY/tE1sDNBaKSSzJ8+R 7DNF7RsckqHsca6kf67FiO6jRZEzHGkkoZWk5LHdyARwOuOe2Ks29xvdMJHHaEGSRyeHYHnI9wOt VP3W1E6MNUr4iEpYt2SZZtpg8kNslmW85iEVJMIOuCcnHIA4zV6K4bcpkUMGSXLvKCR74H6fSmox nBU5ysuu3n3TO2gqUKjxFJcz13vo/lZluKaV13SwW0gKAic3LEBl6qAMdc/hVnc7MsqadPdKE+a1 ikyLiMAKRHuOBz1JPWuHNcno1qaxKr8sUtFZW6uytbf5s78qzvFutKjUoczk73Td/Nu9/nsi5FOg mMSo4t5QWjjZgXtyFwFb6cnjrTzIQ08UgQQQW0cCEP07tyOoIxx618S4ypz5ZqzR92qkZwi4u67o 2t7h5ZDBFE2IokbzM5LAbec9+TxV2K5J24QMXztEjHbnPDN9RQuZp2JceZq46FhmByGIlAkR0wcK DgsM9QMH61LGVLOzIs5lQJEzykbkGSTntyM4oUZJ2H6k/nrGTEE3x+aAzxsdi85yB2/nWoZJLbAc hWdQkyKcgMTwue+c9fftXyOa5L9azOMcOrcybb1av+l/6R9vkvECy/KpKs1LlaSjdJ2620u/61Jb V9gkfy/LC4xC/VOSMen41eWR0ZFMZ/fMSyl+VPfHtgfrXyGJoTwteeHqPWLsfeYPFU8bhoYqktJa 6kyyEsyEBGUADa2eDnr6f/Xp0ZxHtCBTHIqoxOflXtjpg+/pWJ0lh5d+47eWfduB/h9KsecFZXOA IUd0GclwT0470ARr92RQrRtCGlWPOfKPBPPQ5JP0xU29lRXIKeXiQEydzwpB7HPbGKAFVjCQhQrI x83cG/1jH1qwuCVAUEbfOA67WJ7H8/yoAnD53cAAORnd1FIpVkDbfkckgE5GD/THb3oANpxuBOOm 4Dp/nFG77xxhcDkc7hgcigCTnLbgSxIYEnsR/wDqpMsoKkYHDDB6jHH86AJSeREqk8kBTxg4wDn6 9qsgn/R3VdwEIBYvgLg8/wBfzoAlj+bcPLHy/cw2Mgfd/Pnn2qyp27s4+ds5zjngUAPA6dj60cD7 zDrxnjmgBM8Y6Z4A9qbnB4OeMdKAFxgnnHHzcU0/XOOBx2oAUEgdfwxSdCOf06UAB/l0oyaAFz3B 5I54ozxjPfpigBASOnrmlBwfvY464oAUN1+bHPp1o45+fr/s0AGe27jGOlBOeC3fHSgBc4/j/wDH aTj+914Py0AAOOjd8dKOpyW5B44oATJ557+lHvnnr0oAQHk84z14p2f9r/x2gBM5zz19utN/pQA7 PctyOnFJ6c9/yoAOvU9BgcdaXPfPPTGKAEyfXvnpRnHGeM5zigBw5+XP4461g+I9VXStMnmZlLhc bG6lTkA/nTScmooxxFT2OHnW7Jv7kfk38dvFMXiC+uGuEjews9Q37pQzKsiomHUj+H5jnjqK/LH4 5/EnR9FkMdrLEkKbmSQOGW5kCKUVVOMHjOSa+zwGGw1lhqq12/r/AIB/PWI+u51nWIxU5Xi7tWW3 9eZ41ofjzTdSK6h9jhknmjzNLGSSQFYl27llbjA4r6Ig8R2Nhpey7eGznFv5N4rXGHhVlQnJ5zhX 64714XHGQ4n6hGOGW79OvqfCOl7LP3RVS2/p+h/mm3d9HiO3EbykhZUm3fMRxhTjryP070sOurG0 iyRq73hVV3yYWNi4Lfp/Svlo0HKg6lteh/Z7r0YYm2H6E7a7GrnBMQSZZWZBlQM4Qcjk5z2q2NVQ xyKsvms7rErg9ZEzuZT7gjPUdMUQwdRu8tCZY2Ves1J6oa+swlLRGdl23LSMOQA20D6n156Y4qlP rI8iTYFWRWUI+QcjeAeO/BPXGeMVosOsOpSkaVsd7R8t7WLVvf2DyrOrorKrLIsv3XIwo3fX9OKu GOVR85WFlX7SGbBYoeSp74GM/RhXN7OpGXv7Ex5WnUm9RzXIRZPPRpvIeOSLLZDsM/IBj0bIJ9D3 oh1U4tUmlUMbiWKBkBUK2CysSe5APXjiuzEYenUwjVPe36GEa8cBL28l17H7Q/8ABLD4zR/br3wN PJbG+tC18C8pVZ4Ci7mRf4cFxn2Ff096XdnUdJjusm4EQeWObyyA4Zz98gc5xgAV9b4X168Kc8JL Zf5HxnifUhiMvoYxR+JfqbSlndPs8ZSGbylgaQkCVg3fPcDjitGViQVCRN58g83zeFUITlAO5/Hj Ffu9CtCVKS5bWP59qYSp7J3erLEUjFgoh8km3PmR+aWMRIA2vk9MY+72q5CC7sTGnyE7ZlyEyvy8 DsCMfWvFbmpqKjp3PTweCdLBN4mWmpqwrL5QV4Tal7kyTES5DqmVyDnpjj8fbNXFKlGdlhSK2iCr JklkXqA49QRivWnKNekm3Zfr0Pj6UaCxkqs/ivZDZRgSyrayTyQxOECTBGkyBhVbqD79q042kj+0 oGaMyr0BLbnH8IPc89TXmpyvd6W2PZxKo1qEaLXvPqaykAlAVUynPlk8FB1Xd1P9c1dtpZY3jCHz FUlhDIOWH8RHqOQMfU17cK9dw5qUdH5ng4vAxwsfYTd35luMPHJGtvHEJYY5HjkllKiNsEjHqBgf iQKsvJJGLa4iCGTylgXzlxvPG44H1Y1nRVd3WJ1OzDVMvwkPZ0Je91/EvqgjNxbwQqGUGOXyn27Q SGQg+o5+n1NaUU5nmhllRXlZEMSpIEx64J4B6ducmvXwk4XdKfU8ypPFVsRGCWhet2ASW3jUBdpZ GabGxd3I47EZrYVxLIZUK+VFfC5gfYPk2AIDxjI5I/CubE044aole52VqcqPKqD95k9vPHJJvmWJ y7yb4wuMJjnBHb/GrfmS3JjaygUPbFoIWl2qC5AIbJwMdsf1odWTXs+h10sFiqdGca2rZajEU8iX CQQtcqzSymT5W3xpgkHPBIyAO/GKtyTxyOVZU+0XC+XGZDyxP3SOx468+tehQrXap2suh8bj1iZQ eBjRZI07I88bvH/o0nlLtcMt0OOfqGH4Yp9rKkZjdl3kTMvnxHHnZJPDe/I/CvRpznTbcGeNViow UmrSjv8A0gUtJaRK+Z5JsoCJQzxnPCnbxkAfTkVM7q0FwjRsXk3M8glJDKCNykN3P9CRXpRq0atq VRanqPEUKqpypQ1W/wDwSVJEmYzqFaFJ9jrLnMzY3ADPXHXOO1XmaWSCWYOyuVFqhErFo3I4OPdc 1x4ifs8Q509GjzcZifZZjzwjdO//AACcXkTEypHiK1VZUjjbAYOApH445PoKSfZLcyCKKCG6R2S2 t/N3CVWGQScc9D34r2MNGWIp80GVjak8NSnONuV9PMsQS3UwtPLSSF1lhM0dzyJGB5Td2GMjd2qJ fIim+SLdGiy7XaXaiHk4bHGc1pJVqlVQqLU8zC1qrwvJN/8ADFmOVSTNKkcnnzGdoDM2JztAye4G MD/69LF5rH7RJBEplIjkEN4XVgoDEbe2OmeOlb0416FX2cNUeZm13SVCmvebLVvch1gK2ljNI0ix W/2mUgZHIfIOMY9e9OSbEbxRsqufMleOU4d+SAT7jn8MVoq3tKkoVYXS/Q86tHE5fRjCjKwy3vFR IruOHz5AkEdhGhyccqd4PUZ/IVApaHMU0ezYz4hEmd4kA3HnsMjH1Nay9lTX1h9fN2+7b8D6DLKt SpW96zt5K/32v+JZeQxxrK6i+uPs37xgx3M4xkBenQYBPpU4vJYgQltGnmgrKwmILKx+VsdBxxx3 rzvqzxjs3yw7K3+R0YnGexqyxOGgvaed7/mizHOuYxKohAk2hImwQQvy5xxyQf8A9VOlmjBjuEEc dwFxNKf+WyAj93tHGBjk1y/2LUnVlBytHpfVnp5ZxFLF0E6sb1FuldLv/WhMt042zZHkB3kxu3EZ Ujr6j07/AI1ZVt6zB1DSIxeCUTEeX0+dhjB/3e34VxYjCywzlRcrrv8A5/8ADnXhMdHNK7jKHK10 /r/JFiO5Sdv3dksNvNMVdZJyWkwo3EccAkH86kivorZLZnsJjCsaI8IkABCkjKLnAAzg5PODXC4u 9j0p4ik1OlQWpbNxLHFMI4Vn2bZGhV8nYuCSTyRx/KnfanhaKa2QS+VbreC4U/vIZRl8beRkDPOc 9OK0hVnRuoSPHrUFWnGT2Rdt3W3MUbIJyAWjEs2d3mKz4B528nGP0q1b3ikPKVijDOHuYISf3igA enGRxkelbRx1RWUtQhOniKksPJfMuw3eyOYvHHF5hV/KEhmXEhwFVuo4A+mDVvzo3XZLA5QKzTYv CgK4xwRyT05z2r1HKLaaW5w4rCRotxvdpj4rrMr38drDJcB0t97uFlSPdyd+eeAOMdq2GmWOF1RG 8+O5leAytzJ/EMehGT+WKemzPMlhsZjKWultkJJfvFE1pDDvuGUzWyOSVlfAz8wzx171pR38azqd i+QybopEfK4xyT3JApQbw0eaL2Opyaw1OhB7f1+RZhnLRPIq+XbpmRdzZGf4fw7/AI05L53QTx25 klNmJJ037RnJIAPt361z4nDUcb+/qb/f+Dul8kd9DG4ihCMaS0Xy+9xs383+Bs2dxG9w6Ohne4uY xG3mbo3bZkqe4Hb61ctZ5JI2WNSVikaVA9z90tkED8u9fI4mhGjiJU4PRH3GGqPMsDDFVF73kWpZ 5gZI1CtHAoup4k+7tGFUg9Cee3ep1vImRgGnwsnmPGYsRgY3D3I/DisLpI7LSlCNKEPd8yRbl3SS BiyI6xzko/PmKflAA6DHX8a0baVZmFqbKV7uQgW7mck7ASxG0jt1zmknG+x56m6M5Rv/AFqTCVZo 2DwSSoMBpAwxdISQcjggjuenNaD3UckKTItqwNw0XlvfP5rgYO4ADAwccHg1anelyXCNKpNc0UWF uWWSUTLGGCqqjzsgscnOR+HU1atT519cslvNBNNEiSefc/MHAO4k8DqCa58Zg41sKpJq/wDg55dd u33fM9LLa0sLU99P/wAD5I/N9fv+RpLeRuZ5MRspjDRwiViu5H2knPT0/WriXEnHIRBED5it9w5O RnuK+IxNGrQnyVItdrqz+4/QMNiKWIoqpCSb/uvmX32X5IsxzvGTuj2sLV/LjVuBz8pPcZ4qVLiM N5jRhI8uj7WGMBQec++OlZSkmtDreq1L4b5HZiw3sitCx+4Txx+f15p8c6x5hIdpIJo8vGN3Gcfe PXt+Rpq71RPLGCbRoJJL5jwNGscflSLEzH90u3JYFupYgj/JrTSQkROjfu7qFRE8kgDy8DPHYA/y r5nN8up4jErS0WnflheTfTVR++8l+p9XkuZV8JhpuEryTVlKdoqPW0XJfK0WJHKUUDy/LItsbY/m LYP3SfXHNXzNK6MEQyLyImV8M5XBIz6j+dfG47A18BV9nXja+223yb/M/QcuzLD5lRdShK7W9r2T +aV/uLiyofOZQA5DSOjnBBzjJ/TP408SljGVO44xvDdAO49un04riPQJlYBjlN4dgnlr/GPXP1Aq LzGRTNs2iFgOGzxuGG/XpQBOGCndGpCmJi539CSQFx3GOc1NEfkdRAWyACu/qMdf8+tAEyzfKXRN u+QHIPQkYLH1Ax+lWY2yRwT3Xn7w4yf1oAc58xhHuHC7nX+8rZx+B/pT8KSSecPgEDg/5NAAeG45 +Ukt/dIxx/OnoZNrkEL8pUgf3cgfrx70ANBweSFBGQT3P/1/61LGzlixBQ3C5k3fN2AJ/DH6UAWF kGVeM7Q52Op6R8YU/pmrEbgSOr7Qyqofn757fzoAs8SI6jDdVI3fpSgKAIwMKowOelAD9wzjt0zS ZORx3xjPWgBePlBOTnP1puPm9cUAN57che9Gc9T29KAEAzx7ce9Lxj73XqMUAJkg570ZzgE4H0oA Sl65JPb060AGehzyOAMUuePvYOc4xQAucnlv4cHijOOjdsfdoAM56t0PHHWjOOd3OOm2gADHu2Pw pc4/j75+7QA38f4vSlJwDhs5PPFACcEYLe/SjPUbup54oAOnAbg9eKTJIx2FACUvHr2z070AA+uM cjig/nzQAvAwc5welKSehP14oAaWCI7EnailiAOor5r+Nfix4YI9PspRu3q08yt8sUZZSSR3IztP 1rpwlCeJrqnTPC4kzSnlGU1cVVjdbfNp26M/JP45arcWdheysrRRSybxKZgxkO1F5wcgEgDJH6Zr 8MPjfc+Kdb1wstnc29vYQecsFwFl3gZDKoBxnODn8KwxXEH9nY/nqbI+C4JWCx+HqVa6tLbbTYwP DV/qvhaymuRb3GpTzFmkRpjvfflgAOgwSR24FeXfE345fEjULXXNF8Ly21s2o28li2otMTcWYZFX 5E2lWJK4yzAcDr39vH8Y0cdTUIq7RhjuCMLicTPF1Won8V3218OCN8jLt80Nx25Cnp+H/wBaoTJc DcuYycrJJuweG5x+ODn0rwkvZU7Q1sfp+Fg1P2t7JFlbhoSrjPmxFWiXosRXBx1zn/8AVVyAyKVt 9zTC4UywPuCea2OFOeAAf5VyUqrqVkpux2VcbSVWVWlHVlVrh5BPIZPmZg8znnGcAsg65PfvULKU lmjDMizwRiOfGTEgPzMvqTj8McV3tLQ4atJwoqqne5Mj3Az5hZpC0eYUX/V55yT7gD6V0Om62Aph vHMskjyweaG++AMxll6AevvXNXp+0pNG+W0ak8Rem/6/M6cTxSwTSRyq8sZjmY5PAbco4PYnH5Zr mLpW8x8yKZfsasWlk3J5gOC3T0479OKvCKcKa9qjqzJR9tefw3Pqf9i7xzL4I+O/hSF7gqmrK1rL IzbU8syR5UEc5PGOe+Olf2wfCbXRrXhYyvLE7QIDtyfMvSZJOMj5QF4HvXt+H2IqYTN69OpPS/6K x8v4hujWyHDzh0S/M9W3S2s0HlJCxIaSd3mztDjDZJzgg8VYtf8AUxgbZXF19ouGlQFrqPYVbC9B jA+uK/c62NcrSeif6n8/4qFTE0Z06Ts0y5KqRPNs+eFImW4idSAw2hMM33jnPb+lbO5jFbgsfPdD FPMMgrnuo4HIGMdsVNKdWDapbnPjMROGT044p2Wg+NCrTxRRLJhyjTecFFrEwyFAPUNjkdjWuyRy ofLRfNnjKo8sm5EdcFSV7/L6n6c1tPDupQ556P7jgwtHCVJc9KVrIVT5s5AwxW0H7trkhQSGIA9D nPPerFrLK9pCFIEqs0aTBgTKxADA4446ZB/+soUW6Elye8Vg1VxNaVJLa5oaey74lmj82BmVl2Nt kuByCcdsEEY59auwtcIqRs0c8jyyqpRAqpnsCOpCjGD1NVSliado209C4OSxTpV1dFiYRAxQkKYo 4FhEwbIcMc7c9jx2zyDV5YI5fs8sFuftLSsm37YIjGh7nPy444z611fWIKooNM8fMcL7PMU6UHrc t25ZGmK+Us0rfZ5dk++NieQCw6jA7dKvxSqyzTLHInlCEQyI4JjJY5I77QOT9K64uHVahiIylN1K F1Jb9jXhUsfszQb5ZboxKmBuUdVkUjqD1x/kWIJ3ywMLx+TB5W9P42AyWIPHeuZ1XHEKnbQ7IVXi IOF/eReMy74HjhRmhikhSCCbYs/GeTjA4OT+VaKyCUj7MpMZnVovMnBEbYwR24JzzWzblpDfr/Xo crx+JwVRUaiupf8ADfqPa4iddpgDLcKQ7PIBs2nPzAewOPrVr7UiCOL7PIkSn7ZJEWUeSzcDnryA Ov4VtCVRSTjujsnJwjBV1dvqNlkmYG48mKOKWH9xtlyyFT836YzkVKZftSIDErIRI0zxsCkkhIZS MfdGO3+T7VCpP2alJa/10PEzDIKNbHRxFGp7ktxLe5y9wEhwu2ORWU4EanP7zPfJ/LAqZtoDiMHz ZPKZjKcngHLH2OTjFepUqJxhUXxPqcGMyd4LFy+oy91lq2aW5nMYjgmVCY5i9zsdEVN2FH6Y/n0q 7FfNcM8riCJERXyr7QG+VFx05xnn/wCvVYmphor95q/keNTpRoY1wqavUVZykbvtiZozvYJJkOh+ UcnuDzxT1lPkRRidvMmkcxvwpgcMCrE5wSMcY45rCnjIU48ijoVWwtWrU5nL3SRxDdXDPIu1Zrjz cROVaSQDaSBnqTkkdPSp7mThpIkVnljMpjTvL06fQfyNejTxlSnR9pPRHPiHhsPVU+i/r+kSTMPM ilCI1vCY3ljfu2cbT3GT2HTFRRRTBlEunwR3Fs7zRx2F55kcgYk7y3B6Hpgkc0RxFo+3jLQ8mdX6 5jnWj8KJRNvtZVlhEpSIqUhGGOSMben4k/WrZukO8rG6SeWCFml3FsDnnpgY4AroWNdWhyRXzNpR pVarhFXZXW58i0SW3j8+Qolywafy+JG2jnGCMbsAUyATzXAsoY5Lm4uoTHZgHJmbnK+3CgZOOMVx /WpzqvDy2R6mGVChTcOSzQ+3ljI/c20tt55MHlyz+Y9qdvzfMOvPGBwM1ZF0hkVZYYpIvMH2hmYq pIGcL6jPX0rsjVSoOlY8XExljcU3Sjaw+zF3DEqyo7NBl4ZIgNspOemT0VSRz9asykPF9nBQOYFj t5PNG6AA89eQCfw6114VSi3CpLTsS1VwSthnef8AXYfLcqpkjKOfNne5MEYBW3lChSVPueoxirkE srzRoEDw2kSqXeQFWZuqg5+XPr7VFXC0lJ/VIRjO29unysaRxOa1IKWIm5fPr80yKOaVYkt5GPkW 7pmTzxIYNzZGCeT09OtW5XS0mGESa2QMxVJMOd7ZBxzjk5PfmpoYOth6bp0VGMv5lq/ue1+upFXM IfWuWtea10ei+9NXt/hJY0gVnZIF+1tN5v2kXbjyiFI8tecEH36YzVmGVIcvFaW7tMrby0jKyyYA LHB68Y/KsK+B9pB+3q+95U1r81+rRVHOMNRr+xowVv8Ar49PlL9L/eWIdQMkXmBl3YXy4ucI/TJP br25/nTZLpLNfPtvMcRP9rjiY/PAA+3J65zXh1cJWw/Nzwdl1a/4dfifR08Vh8Ql7OSv66/o/wAE a63ojlYrKyEr5cy+YAJD1yfoe3tSQ3xGniaKCMNbw43/AGzyxKxY7FOexIPTpV0KbqtNPY66lB0U 8ZUW5o+dEXWQWls94YFikkL/ADQxONxQnoSW/HArZN1JGqQyotstySYVgYZSRhuHHJ6AD3zXT7WN SpLD1YnnVK9TGSf1dWsSW872sBaHSxNEsIa20+O4Ki5ZeZGCjHOTzz69qtQXvmpHtje2adSzhpRu jjC5YdwOQcdeldltLI554ScKfP1HR3caPOYYfLzaFppd5zPhhxtPGSDnP8q2ZLgu6glUllgAhUcB ztywUdMY61lJ1OdQijXD0a0U6kuvRjpLs/u1MccbebEQpflAoxn261qC/cNGZILeIeYc/Ypywu8D IPI4yCf6U50FWl7Oe3Z2tcyqxq4eaxWGdvNXTX3NL70WoJPMklVCIxIirEZ5gPKlIyAOx75PqKma 4TzPL+YvgRxRrMOdw/vDgDP8/rXh/wBjyq1alPES5Etvc0a9VZP7230Po6fEFDDUadOkudve89U/ nd/oieK4aORhsRXXNsfLl3oWHOc+uPT0rQhnG9njlb93udA1wQH3HqM+w6duK83FYGWGj7SF3Hva 34Xb+878LiKGNqrDzklJdE7+utkvubNBZRPEImiggCkwBEnbN4qnlmJPXn6cVKLrck4WFJTEoRY/ M27gMHCn29681NJ6ndNywlZ+z2LSSws1vNNHDL5dwN8czFTICpDEYGBjjk1dgmZnH2aNTNKxj2T3 O2J2wdoLcjoOT71UaipVI8rs2dUarrxcpR0/G5rrclo45TC0RYgvEZN4JCkuFJA4Bx2qYTTtse0j tJYgytcm5uvLBQMNw9c49xWmJbxuF9hUf5P8GmckcZLD1/rOGh8rtflYuLdQyHzV2CATDy7SWU5d V+Y5PHHTrzUtg0xuTMbZZYtptyouv3qDqCkWeR7+gr5LF5RDCUfa+2v8n+l/yPrsFxDPE1VSeH37 SWi768unz+8vx3haMIQQWcuQkoxEgB5YepyKniuH+TJ+cpswrYDcbcjPYA15U+aEnCpGzR9LGpSq 0lUpSvftt95oNPIrlI1XPmeeNjA+aCQDge2BmrS3Ik82Ewx+XuH70HdjtgY7H+lSn1iCb0RehunQ K6bXkJEUEfmEKo659zjOOc8c1YhugYoyAWMh8xSw6ocknHbt1rz8VlmBxfMp00m+ttb9+l/Tqenh c3zDCOMaVaXLta+lvLt6rVdC0JwjFQxSUxMWUvhRhd2Cfepo7oebC37uGaJUfY3GehH17V87X4Wn aVVVrveyjb8E/wAj6rD8aUabhhlQ07ubb9W2rv5ssS3hnt2Xy3V3QSLsk2uvfGOxz60q3AKxxFGT MRSVg4G45yP54/OvmKmCr0aTqV1yvs9G/NJ9D7GnmeFr4lYbDPmuvijrFeTa2fZFr7XwpZlLAMTh hlgB8qkjj8fapY5VYTMo8xEOEXPKjAH4nOfrXIegTMSS4Q5ZXUgH+6Tyfbv61aV1CRplFG5t2Rnn tx+VAFhbgE8qoAQsnzf6vHHTv6VOJNyLlMoihyxb7h4/kDQA+GbfuIXd8xXG7GO3X260oZtqSN+8 JhG4gctj0/z3oAkAJAIGc8Y4HPT/ABpBgKgK/MARIx/j9MY6UASJIEUjaQ7fLuzwF7jFTwk/MQqu UG5QXACn1oAs7gdrBSUZw6FTjc4zz9D/AEqSJu6qAkjFxk8t/eP8hj2oAsE84z1+UDHtTs45bg8c A9KADOfujr3pOpPbgDPpQAhA4BPPSl6D5T068UAJwuQTg5646UmB/e/SgBdxz97A9cU3rmgBckdD +lB6gE9B6dKAE9s8ClBPAzgZ9KADPOd3IHpS7j/e7+lACZ5+92xnFA/3ujZHFAC5xnDd8/d60mff vnp3oAXPA+b68dKQ8DAbPPTFACAkDg9/SjPXJx1PTrQApPHXtjGKQ/z60ABPTnPHp0ozxjtnNAAC R0pevU4wMDigA6DrzjGMU2gDmfFmuR6LpskjY8wRtKgJ44B/MDj9K/PnxHq1p4jv2vDI9wkSrHNK wcrliDuKfkcjj3r6PIcDPEe1xEXayt96PyfxRzt4LBU8s9nzc+v3Pv8Apb5nx98YdKkvJZbfaSQq 4dUBKxlVVAw5yepwOxr89vFXw90a3e/1zVo4LTRwwSWSWbIuQCPmBJ+UhlztH1r4vOcsxOLxXsKs dz57hjGwy6kqkep8heJPO8Z39/aeFNOltdCinhEl7MuDfMuVLIvXqM9xz361r+Ef2ZdT8ValaxRo 8j3RNy0RhBy3K7tynJGR0H0r3ct4cq0MIrQ26/1/mbZ3xRRrauVrPQ/gAMLx72OMmIyTxuMKpLEf L2xg8mnLblZ0XmC42JLv3Z+bquPQFT1ridSpGleSu0fsMqc54iUIEit8pGdvBkjVvuk9+O4woHXr iiaZ5IeFkgiVkVUc7sA9ifft/wDWrOlRTq+369jGOFqYdulDXqPeaZZHZjy3G3Ibbt4A/D+lMVD8 uJAJhk+Y/QYPBb+WPUe9FfE+yqxhbQ9DDRUaLsvvNURI7lkDqzJ5jKTzGM9/c4H8qjCRFIJ3iJG8 xywqp+UrkrwDjLc/gKjEqm6sITdicMp0IzrPdFtJXtn8yOQzLGSiyAZ8piD26jGeKdFceYrPE4Cu gj+4c/Ljv1GcdvSu1yslc0lfG0eZux0nh/WpdB8SaH4gsJis+latBdohbHO5BuDc89uRgZyelf2o fsYePLXxb4D8OX42XzHS4rkLFL5mW8mXBBPBUd+PQ1hw1U5OKHDa5nxRkcK/CTrc2sEv1dj7wlil jWWBIbU3JhWSAC53JIdoVvm7DLZrRtYPJVCGbfDGschkfO4KCFXI/wBo9fev6CWGrUJJVJaH8hVM xVCu60I6J/mOPkW7yztAHkUAybgWJ6FyrD3P6VqWm7fM085m2zqyCLoN2QSPUnjJP4VXPyzt1PVx EoYnDwqy69P1LrRXMcUSvbySmZwluI4QCkIzlTzgkH8ec1ejK+c8khaO2URxBiNxtkYfK7H1yMfj XbHE0MZD967SRzywsXiPY4d6a+QRI4S2jKIrTJ5qysQPtKgsQc9iMEcdaniwXkMWYpYbXLxhz5Sl mBGR0PT7w9a1ljbU701qbZHWeBx08NUjdf16GnEAzS7NsZWIGKR5CGjGMHk9SfQc1ZyPMEXlII0j kQgrgOVXcABnnHUHPaiOPXLdrU2zTCyxeK9phlaKNIQym3E08T/ZZVW4gkVNnLLtIBPfcM59zUaR wCf7Qto3mebFIrhtwuGj/QYJHFY1qlTENTUdDjjVlim4PeJsW0ZhwhRGeFhcNA7YFuSSDux1JJJF T20kSNLjT4Y5k2xtMTtF1GOSRzwQMn8K7+SbpqU17yOegpKjKUVdr8y1ayJHMZix+R40W4BO6ZSp KnHtnB9MVpRNvjONn7uaSA+a2fPB5zgfjj9etXQ2jOtHXqeRXxlenPmhDX+vIvpNKiRlrf8AdzTs 2fOK8ZHbGRjHAA/GraXKEKGhVhI7K6M2FC/e+91BJ/lTrVqcavLFbs6vZ0MRhY1Kj1fVkqs8atMI 8NHGi3EEbK3kgnuc46HpU/nmKIeYV+yHa8IR9zzMd2c5HGBjGa68NV9jU23KqYWriMJ7Gox6yQ5E s1uhaCPdwQrhMEYz706KeSOPfEsBcRjyFkfy1BIPVumMcc+tepUqVvZ80Fqjwq2IVCfsKOqRKJzD F5MKPcS+UyujgbZWb/aPHBOPpTzJJGrhmhnaN0EavMNiBCCqr3OMkn1x7VDrqNOPtHrpodFCpUlL 2kXo7lixKOqmOKM3E7T7bqSUAzITyC5/3eKsBgcSKsf2YxmKbzZc71wARg9iQOlbul7TdbankY1Y LD1pVZayLMUpAWQwJ9qn+aSVxhlVMhSfXrgDsT3pqzCRd3lSzuIVRAQEVHz8wwPXHP04rdSqVIxo QiclfC15YX61Tk3F20/r8i08iJJcPIV3QPDHcMMK/HonXgck1LHcXW23leJopyR5ajG11ywOW9wA cdyK7KsYeydBS2FmFDCrBLT3n/wR05nhjUyW6xz+WUukZtrSru4OD0O0gfjSS3UbQwyA+YVVZI9p 6kY+Xnvj1rhvOrFJPboedhMupwpKdPruJHcFWjlkddsSsjFHDoqjIO//AHQQcVILgxyW8FxjzIRt mmJysqkHaSBz6Y/XpXXhL87p2NXGrh6/ux32FFxbRiNIfMdZuAkuTwM4YZ6EY4HWq886OlvGVYJB Jtdt5Vp1ONvzdc8dfevWk6Th7ujM5UsVHHe0m7t9BFuX86AC3VYQRL9nfJSXIwOvP1/pWhDOI2wY CEhlS1MG/KPExOc46ZzgDPGKxSbSud1fA6c1OVnfVfnoKrutuN+BFayrB9qKkCUtnap7cHj145qd 5I5GxJCsUizfu2LYALnacn8uPf3qvaum1Wk9jizChQUYwwk7PqS3F3++uJDEsIt2FncTI5LSMCMs 31OelElyyBYpoVKRuX+0btxlUZ7dOn6it1jfb1Y4hf1qd+GWGjlUvby94seZCknlWqKyR5XdKPl2 8FcHGeDz+dSxzxBYpDGUk3yN5kY/1gJ5OO3U/gK1xc4xknT3Pm69GGKip4Tfr5ly2k+0F4GlS13I rm5lkJHPHycHqByCO1EdzGYI/s8SqvnrIGlbgAZ2jPXJXmqWLSpLmV2cuDyhYiv7ZrWP9f1/TFe6 RooFAl8uNlnSJm++Gyp/lx9DVrzgskEwwzx2piVs7XJByAcH26+gr1MJhsFKhOlOmkn5Lz/E6sxr 4mCjiKU3zLRbj0u5JN58pXYM8vkk5B3cMucZ64NWxdedAE8lUXyfK85ZTsurhSclcjgrnA7GvHeS YeFa+GrNL0v/AJGlLiPGyp3xVK/o2vwdye3upSkEEyCK4GIYz5gLMwUkg5/D8+KvJd4SISh32xbH i3lTIMdd/Xpj8cV4WMp06OLa5ub8P6+Vz6rL1HH4SNelBw+7X7v1NSyn8uOwxZmDFw1sLO4m+SaP GB8wPGeh5H4Vdt55LeT/AI84HjkjaGcW8oMIIHIDHjgelQ8bN6bBOjOi7tb+YqT3T2tusltKz/bH hTbMrBo8gq2Ooz75/Stm3mk3pHDYWzTPPJI8UrbWmKjOTg5yAOMV0VMZZxcVuOvyQnGNJNpj7Sf/ AFqJs3b2kVvNztJIwD155/8A1VdXUpEkZfskrFiBJK9yAYiMqQB3bBz7fWumNp++uhw14YhWWH27 fmW2lngEV09u1rK9ssbxSyq4ijVsZZQSFZuoxzzzVkXsimCRYldJLhIFhDD/AFecM+e2O2KPrinU dOUjOrhqaqwmorzLn21ls/Mgt2UJIqtHE20RR5Kqc5+px71pC5WERLKgCyO0f2lgTGCOS3A54A59 /eirD2sPZqTX3frc58XUp0cSsROKfLstVr8mtS1DO1wsM8uny3JQvJHACuXQAl0DZ2p/9erSzZ8t lEccktuZYk3BtpJAww6YAOPfOa+SxWAlRnJU03byf4v/ACPrcJndLGUITx6jCTX8yv8AJXf4tPyN ETx3CTxyFHt2LO7tL/qVQj5c984xxTrV7e+tQr2MMIkZLtLMZ8uBjkDGT6c8158opyTaPZwlPEJO pF6M1ob9BIZhAtz9jZJYohNsit3xt3H1BBPFWUllQL55kkXzJP3rqBvYtkLkccA4z3p2fU0r0Izq QUdGyzDcknzY0VoRDIrFsjzm6AAYyOhHb+tWlZriQNbW/wBpn5MC7+Vwp6MDkdwf60U5OM1I5MTC FP3aLu/M0454CrrHBFaNJEzx+XPuaRvl3uwPPU4/H2pDdu723nIDKo8kt5mGjA4C4H8J+vQCs6+F hXryrYz3t7abLXTzfZ2uehhMzqYWhHD4aPK+rvu/0XlexqrchZEZo7eKOOHcgik+4pBGMZ46frUy 3j7CGg+by9xaCbd8pOMnnIIHavkcdgKuCU60YvkvpdO7X3WXo7Psj7fCZhTxEYU3JOdruzVk/vu/ VXXmaMM8aqtxGEaAgSIkb4wVzyOcirFnOTDGw8p/Ofzrpnn2GIk54XoeQBgcYryo1I1G1HoejrJq xekvA1zHmFpZJoy5kMgRNoB5Ppj06n0p0FwSsUufmlXzFEz/ADKc85Hrx+vat0lJ3QlFc93HUsi6 zFhiTFI+XBbOegAyO4qRpzHHBtBlETFg6zfNIQSOR/D9D6VFehSrw5a0U12eqN6NWrh6ntaEmpLq nZ/gWoLtpW8vYPNLhU5wHz3z2qxFcqpgbqpB3lzgSBSOvoDxXj5lk6x1JUaXLG23u/gnfRd9Gejk XEM8Li54itzSvv72j82mnd9tS5A4SVNqMsULFz8x4Dtk9e/P8qvtcI6cAMrXAtSqvyAeN30/wr87 xFCeGryw9R6rQ/XcHiqeNw0MVSVlLvuTJLseQNtMq7oWBGcBvTt0HWnMzCOYbefLZUYt19yPzFYn SS71AOFGCysxLE5IGKv+cN6xspAMHmFt+QjA5A9+Oc0ATpNlSWAG3Lkg/dXjHHr1qTO8MHHCvg57 NwR/SgB/zHLMxy3Xock+9PiLK5KAfOvloMd+h6/WgBGcZZgpUtBGhxyCoJA/8ezzVhXYRhYl4Myh hnOcjB/lnFAFjzEULkbdjbI5Af8AWDPzHHpUhk2bQI+IXAO5+EJyOv4j86AJyU/eEjhCGbk9Rz/h T8gcHqVyFJ7d6AEQqyjGSuMAknPHFOznjdgqcH2oAUnJwPxGKQgZAzgg8DFACZyQAcnGc460047n B/nQAZYD2P60HqAT0GPpQA2lHXrj3xQAHqe/NOzwDu5A6YoATPTn+LPTpRnBzu5zjpQAucfxds9O 9Jn/AGu2elABx2brweKM8jnoOOKAFBwD83vjHWkz1OeT14oAM4AAP4YoJ9/fp3oAT3zzn0o7nn9O tACk8AZz7Y6UmBjrk+mKAAdeuKbI6xRySE5CLn0zQB8P/Hb4i/aNR/sXT0a5j80IyNeeXEEYAkSE c8kMQB/+vxm3QzW+6O3a5eGHyGWGMhbYO69SAOCAVHYYr9RyajHBcPqvyK87O+nn/XQ/k3xQzLF4 /ixYOjN2ptpq7tvfbb7j4Z+OHxe8J+DRK+qPGLuZXW30eeVhIxwrJynzNnjp09a/OKXQvFXxfvzr niJn0zQpNR3x6NY3jmCSLf8AIzthSSdgJX065ryMLhJY6sqlVbbHvqhHC5V7apU/rU+u/hP+zXrn i3VJYtN0GWys0eGOK7YrslZjIGJIYEDGOTj2r6v+I3jj4R/sleClFhLpOq+MILWSIX6zbtvyxsir kEdWI4796+gziUcNgYYXD6S67dz4XKMor55nMqtad4a2s2f5LYjjBLyRhXe32bfNyXCgZXPYDIwf eoZbHylEnm7F3BJCecZ7Y7fjX4nhatWVVQk9z+y+ehGm8QluSrbyRR3BZgfsluslqhXKsMAc8YHL e/emLbhYvIKsVEcazkt/rAPmOfUYOc16vXmk9DGFStXk50tEOESco4wYJTHjdlieMcjHOMH6CpWs 0Xe+0YZhDNKeVnA5wPQ55yPauf8A3iWvwp/eGDq1JTl7RE6whkmkcHzBCjxJ2fa3t+NSm2DyxmAy SCZUQyFSAhAPU+3T8qxxcU5xaWp31cLGKkpu6v8A16Ef+r2RwOD+5MYIToxyNoH8RA5yfwqQWpkE Yw53fMoiHVl5Uce4APHr1q+aVaqqcdkebGEYycIzcS9akyMoZdplDpJvzst24YMD65z1r+iv/glB 8b7q88OQeD72eSSbw/FBpZfH31aFsD0zghsjqDXn1KiwXElCcZf02e/GjOvw/isMnd/8B3P6Kbea GdrS6jgSSOeyxFfSfKsSpI49eSdpxn6VIItjDyiENyQxDMSs6bssVXPy4Xj61/S+EpvGUYSvtqfx tmaVHH1KLp3imasmXtWjiikju/NIWR5ARNEckBQBw3PU44qzE8UchW1tWla2iE0sUcpAu0bAEZzx xtPvxV2jUktNUdGIw9Glh1jZy5YGgsHlwR+ZHN9olvjPauJ/9Wv3mBGckAHg1agkjV5pEt4VWYkS IcFG38b3PrkH659qHCrUjen8yMtq4WeIU2/dd7EpdpEjjVY3WZmEZzhi68emFwMcHg1LDn7QtvEF SKLdJOd3ytIMHJXPrkge9Np3XKaVlHA4+dSEdHctRCW5SaO6WKZSpSaSaIAT5fO3HUduuKnRpHkx KqKiSSTeWvVFwFiBPUgnnrx+lVLl2RnhsVKKq18RsaiqkAngVZjPJIPtmZzJHI4HYHjAJHTHrViO S5gdIo4ljMas2wtjdnGSfUD8+c120a8JQUKr22+R5dOrGtUeKw73W3qPjIJe3SJFlUC48tM7p2B8 xRk9duCc9xWysytatcYG0yJH5yDvnt7Zz1rsjP2vvUpaHlU61XD42o6mzfQQNPJFJJbpG1zmRgsk h/cq3JbHQZq+piH2uSCMz2el2scwuSnzMXPIQ9PlJIPHNYVMS2vZ0o+8ztxGHlHWC93f7i9KLqN3 iIcXSgmG33ZMvygj5j19vw9KstLH++2Ksbh8K6tnymXB4J4J2556dfSuqm3KN57nJRoxxsIRk7KP T7ywJJ7xI7h1j33Nu0TRu+REzYAxjpkDJNWEfYks8cjurQx7JZkAATBVUA65B3cn1rtw1alTk5TR liqk6dWVWjL3dSXypLUKHjkaWWRhFCZNxikIGNxHUHP4VItwHZ3lElxHaxSNdySyANcFOCOnTOOB ycV2rF0eTU4K9X2mF9+Nm7WYv2kIbeSKMOhjWAPHOFVFHznk85z69TRatk+YkCM1vM14odxEG3ZV jnr9z061knhKj+sX+RjDDV5xSlKyX9f1sJthcvBc72VgkUJ5AWM/Nt+vQ/jV5pdqEQ2a2iSzyTLE ZFk2RjAkkPPJ44B6ZzXsYTE0KanG+pOZUITrQknrZ6CF4VF7FHHIvybCslxvF0zfvAqN2xgA9hVh ZkzHMcsypHMT5pDKw4+73NR7Vxn7SD1e5ywWLoRdDEz31S9DQe5EkUKFhPDdTG6V4z824EqzE9Se DxmoncxLJOLeSZ5QY8rN8ojXnIB4B57c1lRnBV1Ks9ysRNVqXspQ1iSskEt083l/6OLsXEUU1x5j W7kAbVLHHB5Pb86jW4/eTFxGSZwzSxgoSTuHzjoccAH3q6jca0vZnPTrxnaEIW/IWBVjkCRiKN57 ZcW867W3k5+9nBHT3NKl6ZI1/wBFhjV2+zTzbyGZVO4cnnnpx0rsp4mnTg5Je8yp4LEYlwlGV0vw 1IPOnKETAGK3k+0R3bn5ZJeTww54BPbtTWmDXyuRLHuc27xvNuICjA49sjv3rWl9ZcnKstCHQhHN Y03PX+kSRz4ktYmWR5hvEjiThTzweueAQeR1qW2+yS3FxH9jWMW5jkH2bchILli0nPJGQMegrShW jWV30O3Oov2f1fDK03u/68iV7hWWNFSZ2klEcV55pEQTdlgUPVuOp7VYkmS6nS4jjSCK1VklPnEm fY2eQxOOcdPbFcWIxbqpUorQ48vyqhTnF42d2Ojfa0m8MY3nGwvMV+0Bec57YP58VcllVJPOJAWS LyUbfklfvDA6darD1KdGXs27tmePp4WtXeDoRtG421YeRH5wPmySNBMqSk/aDxk4zjGOc+1S+arr EY5IYhG7M4ySwKjgrjHHNelZdNzKanT/AHOHp6dzQaUvbm43gpKvnBDHtMIGBk/ypyOWEghfzWmk Yb1b/WD3HQd66E4fV7T36HkVZVaErUI6v/hiZpBFI0D24UNcLA6NLgQjaSW3DPAYcADq3pSxXMHk iU2caNE6iAsTu5b5icHng/gK6vaVVSVaLuu39djOMKeIrpPWS6DormJpJ0aG3dvNSK3k3EPYoT82 3BxhsDryMCtDd9neO3lt5Xubd54Ylllz5nPysAOh9PangqsZw5banp1MFOMJ4hW5rbDYlcRoyo+1 CTdRMm4RsQRhj68jHb0rR+03MM9mDaCWCGQ3CgXWzycIUBPBJHPfFXicDhMVBOp8X9fL8DzMDmmY Yai5U4WXVW/ys1+Bf0947eC0kuIjfR5iUuzYMjMW3Ocdz04GBj1q9C6OpR7a2E0bF18xsrKedhUZ xkAkY9R718dnGBq0Kjq046X3tb9EvuPs8vzPAY3CwXOufqrp/q395MrNJF5cKxz5iCtHdTHAJ3Z3 HqB9P5VZEkM1vH5dqFwkUFl5chABOdw3E8dOPXJ9K5oVIzbjHodVCKxE5Vai9CzDMERGkQyRNKY5 Ui4eVh0IPbB/z3rWD/aWjjnhiY3MK7oWk3rBkHLbyQK9GnibVY+1locWPw6clUo6egiLC0vyQqlz eSm3ilD8zbRyAM9cDv8AhWpb3IkNuBtWCW4MMYJ3fZ1/iJb69vX61z15RqVXKmv67nHTweJr4eUn IkhkVVP2aBYk+zFQcZW2cMSQw556/TNaltPJGImVRN5oCmFn3I+44IB7DHX3r06NeNSk3bVHm4jL 37k5vb/P8iwLlU3Oxe2MSEPC+drru6BfXvmtG/mlt4j5qJ9phUKiAZkgHDBdw4BIGamli6c4cslZ hXy+FbGJ290mllLK6zW0DiFFmh23LHzJSTxgcdDnPTjpW5DdxRtZRmKKOTMiPPFJuN6+CQxP3QOA P1rmzmjPEUFUjN6brVrfffp6H0OTYmlg631WMVbo9L+i9empMlwxa2jMA3Rr50kDTrlpA3BHQYB7 f/qq+b1ZvMaOPdFc74Jo2bpn5eT2z7V8nVcYJypSUvS/6pH1dRTxcHJwcWu9tfubJvtJZpHCQ25i VZEhjlO3OQMZ5weMnJqxatE5SJooIzEd6yB+iEnLZ455rKlJzjzS0IWDU6CcdJF4zv5uTZw+YAwy 8pHkxlh8ysP93ofbNW4ZVV5RBD5nlp5kqQtt8zIyrsfrgfhW0nKUnM4p0JYe0G7luP7Q0VxOtuI7 ZnWNRBKpSR354z83TOQP/wBWhBORLFKkOY5GKmSOdQwIH8Q69P61VWpHEU5UsTG6f4ehthquLpcs 6HTqr/dp0ZOkqxCFLeBGRd6yNE23y33EjcD1/DHaryOv7uBgyMk2QYWwQQc9wRyc/nXyONyN4Ryr 4Rtr01/rz0PssBxFh8TONHGJQk/NW/F/hqTxztNMrpDOqy5jWUzjau446nHcenrmpIL6cGQPGkdz EHhuFWTdu+fhlbp05615EZK2p9ZXp0oNezkTJJ5DRwxMxjGFbkKTj5hx35yfzqyLmFhK291DBjmA B/OY8KpJxgc9RVW1vfQxcef3Urlv7XsWUPCzmPEe5HwNwxz64/nUpu5o1wfJ8xo2UsfuqcgkL+o/ GnZMnlVNcqVjQt3VFJG7ZA8kow33mc8Bvpn/AOtVtJlE0zmIiUosbBiCWAyfl/E/jXnYzKsDi4SU 6S5n1tZ39VZnqYLN8ywcoyoVnyrpfT0s7r8C5bzDCiWNf3oa3Iim5jfr97HHA68f1q5HdssewYKh 9xk6nGf58+tfnGNy/EYKpKMovlTtezSf9ep+q5dm2FzCjCUZpTavy3Ta/X8CxHKCTnLzKRHGsQ+V VB5P0zirbugZ1GBtZVkCtu2nAGf/ANXrXAeoTjIQdDuAZG38bM9Pz/lU8MxiBK5AVRIDjlTkAkfr QBbjfYdnlqiJuIBfJ2jv0qSF9xAwQGTzOW5XPQfTrQBIcNIdqhdvO0clQenP4Umd25ufncsxz1PT +lAEgYbFXbkh92/2I6U+ObacnJ4YMQcHJ4z9en5UAW0kCyrGqk4xGoz6fxdPSlidXlYKpAClQdx5 XP8AiaALEbEsVYHIJwR0x2/nUgZgIwEO7ChgX+76/lQA4yKql2PyhsH27U7qD3xzgUAHAxk8Z4B7 U0FvnLLsOcL82d3vQApwed2DjBGOlIeDjd/s9O1ACdeM9TnGO9J755z6UAGcfnmlLE96AEyR+eaP r3PNAC5yME9B6UZ/2u2OlACE9s5A6Uegzx1PHSgB3H97tj7tIDgk5/HHWgAz156j0oGP72MjnigA zx9726UoOB97HtigBDjGN2ec9KbQA7pjBySMHivAf2h/ixpXwu8D6he3lxGLp7d5IoFILsqYL4HU HaR+Z9OenB0XiMVToLq0jizGvDD4GrVqPSz/ACPxRh/aAfXdS1TXtTi09HmvVa1i+1tL9njDEBmI UfMq8bQP514x8Wv2wfGmtRL4J+GOnR6zq8knmfabO58qPw7CioRK2VwdxB+QnOQa/oHNMDluDy6j haerirPXr95/G+JeOxmbYnGVF7jb1t5bf1c8o8KfCvUL7UoPEXjW+uNe8W3Mnmpdy9IAeRHDHnHf nGAcV+gnwU/ZV1zxvHJqviPThoXhmwuZJNRSeVfJe2Una7EkLkcEqpOOOa+Zk8Ngo+2rxs3t/n3K qU80xzVHApumrX8v0/U3vj/+0n4A+COmN8O/hRp9tfazqKJ/Z0lmknmz3SAN8rnOE+8cv26etfme fg94x8f6oPGXxO1Yanf3crTQWdwyGGOEYcRtGo6biMNjn1NfKZxiqvsVOS90+rwNSnhZqhRTTe/q j/OBW1eQSYyj7SwiKgEYIHHPTGTz6UNbXKfvCC8flBzPIQCxPUYPcV+b/WUpr2MD+oZwhUrLBwWg gVmihCSDy7vbPHCflwy8devIB49DSP5bjzxkSyRmP5k+8xZWORxgdPyFdlaDq0NOoYTCVcFUlhr+ 75jzIqB4CTvZSxAQMEPGGHTgg8fSnCN3VowH2OxuV3nJY4A/PGM/hWNKq6cOWstvxPXpU6csS409 v6QiecZvtDAAgsqu/bjnOBnt+lTg7dyvFG3nb3cbiqs2c/d7YGDn/JvCylU5pTRyVG1i/q8UTx20 lvHHNIil45JBAA+d68Mh+vJ4pjwkxsjMsTeeJYyw+ZyR0+tVTpRjXlOL3FmGDp+zS59UaGCjq0ik tsDfuzgR5PUev1r9HP8Agm149h8NfGC58P3U8g/4Sa2L22TsWKO2CqVT67xjGCCTjIrx84oQpYuh j27Wf6nVktSbwVbCp7p28tGf17eDdTbVfDVibSYLAypFGZlDMEZ5GUDHcAHOM5zXdkeQ9k3kyZLF fLd8tBG/8ZB4AJ7D1Ff0bkWMdfLqdWGmh/KOcYaWDz3E4Ost29exZVnjur5Mlnil2tLdyDch4AGV 4GOgJ9qltnMohhlsru2Ejjz/ADpgHgxkL0J9Rz3zXpKsqUue2/8Awx4U40sbRlgaktnoavmtLJbX dv5bvIzxtIrBQ4VdrbQO4H5CrMDqZEmMOIJ4MGdGIDgElcg85JGPYVpCrUpvkhs9xUcHOShSrU7c vbyJ4JoXtoF5lMkbySTJMU3ALglfT5sLjvQXdyUkydweaOXfzO7Bcrx0GeCRzWcpKMfeZ7H1uhVx fO9V/mTW80CQRW4hRBDOWe6SVm82NhuIIP3uehPTmtRNx8x3P72aRVJZyRsC7jn8QAOlEZRkuZO5 zY2rPC1VShT9yXkLFAiRXClHkjkzcXX2m5LbQ5BZj3JORwK0RMPPVYYCphlkUAtuIyuAMn1Hemmr WSMsVhFhJRnS0i7/AOQW7fZ3s45Nq7wqi8RsB2zghV5I44zVy0HkwhY1C7ppE2u4w2GyWPXOAcDv zWtGVahNwi7s45Ty9ub6rbb/ACL1s/8ApCRCBlS5+Yrbyki0VPujnk7s8/T8KW3uZGWLyEeaae3a yMavkOQ7cED7vHHFaU63LWc6i1NKcfrFCU27I2PNZYvMSIoUtzvaSRi8HOdmefYfhUzSyyCFp44W Fr5MSwxxhUjUsdxwDnPQVtSr0/aSnLd9Dxp4erhX7WctGyyqqrkC3itzcTM9wBdsyxlecDuuOOKk huUkeRRH8wjKpLywkLfdBHAz6ema9CLbSud1ahhcUlTn17dS0knz7Y/JR1hcs6y5LvyDg9CVGfyp LeWSSB5ooWmghJKNJLgKGUj5Pc4PUc0a3utjmjTw0l9XrfZ2I0IuJBEYnkjkMcUo3/PAFG5GB9Rx n61YluPtAnZ1N7GLYwASLtCgcEDbzweM+tejTjDCRXK7p/oeTmlDEzcG9EicKYIEaOPzI4gYoopp urrxkt3IxjGeaYsieazJAIoriRbhlT7k6ADcODwccde+a5vedR1abPJjJe0hWj0/zLC3jNNstldU WV5445QG2nk7Rx3H+eKfFNHOqNKiArcZQ7iVULnJPfp+VenDEUqt2nsdmMwzxElib6roWd6+XKiW ckY8pb5IoZAG2O3bPUfjkjNTxSiYAFWmhgdYpHh/5Z9AqAdOQOTTxNeDisU46/5nlxwmMr1fbzt8 iJgw8hWhTzwZISMgmUliy5OcAjGKY8ssymZYZIpIoWlnjWXed4QMSvY9+OKftZSpqrSV7np82Hwc ZQir/khXeCExqFW6K2qbIWU5dSAwAJ5wCee9XVwPtIdUYyKWTy5MeZt5x7fjW8Iuc0kjwvrlT6w6 ydk+xVWRUJYwEfaZjNEZvmWUAKwA9Avp71HcFmSPDoJVcgCfpsJBY+4xnr0yPpXRisTOTcFsvxOu OV1FNZnKV/P1JIYxI6y2yuXt7gzSyNfiMRqRgK6dz6DkU9JFEql2RJijzFBIys5/iJI4PHFcaqzo x5oLVnXzzzOryUVZLdlxpzsj82NonERa0dZcgANgjH881ZSeCKWP/RYCqzM8ke44mccfOBzycdOa 6MNOnGbVXY4sdUpUKclJcz6f5ldZys3ltb7pYTMr2JbeuMAkhs9elTiWJrkQC3jEMMaJJGBuMeVy Oc47jH411QrYah7tNMxw0ZYvC3qaPpclhuPIkba6zLDJ5EbnkNlflB9OD+lSRzeWmBBNNHGjW9u5 ly0KgYK8nLdTya1eMpO9jya1bMqL5b7FqJmJdlaR1a2jtmGfkZhuGR2U5bB9ePSrMP20r9mTTbua DCwyPFIm2BBgFzzux16c80SxUa0HFJhUx0o14+1jdWGwsYEgmRYo2mjJFxHMMugdhyvY4/PrzRFd rFNKEtpGkzwwkByr99p68Dp7V1YKq6ajyy0PQboYel9cpRvItvM6LJPJ5ZLjZFJxmR/4dw9CMc4w KkIDqID5YBf94inmRgoyNx5OMg5r08QptxjSWvc78rr0Fz1Kq959Pl/mWYcwWs8P2V1thL+6kWbK yYHLN64zj8DV5bhoplLgkG3aNXU4abkEdBj8DXRRjOEEqjuz5LE/XJYqanom/MfDMDbpHE8cH2KR nt03YXygCxJ9hgnHvW0zqICPJMCTQ+ZaJMx3OOrZx+PpVZjiZOE4t9/u7nB/YVPCVYV03d/5/wBd i0J/3trc3VpbtC91seM3Lbp8LleRzjJHf1qRZjBIylGm8lIZYJI5flXfu8xCMZOMg89Mmvi4YeEr 1oVXKNu23W3Ra/I+/wABiKuFpTjVguZv+ZXfn1f339TSEjwNBJIpj2xtFEpkxxnABJ4IyatW9/FF HJHdwzXCDe06xzAYCqQGyc8EgfL6D3rx/rbcOfkPpJ4edfAJq3QmWSKF03Rut0f36s11jc55BII5 BHTHtUlpOojgS2hXMrlo0j43uzZKgHGM812YfEqcHCL16nBShVnR9ls1+JpxyPMqzwBMiR4SzTYM CZG6PbwW5UjPbPNXYrqObehjVBPKXjhgbcZQDksO/TGR6mu3DYiNK6mtDizFfWqSpNWlF/ItRA3E MW/yopT5qWySyBjcEjB3dsAfzq8txAYY1jW2eW0ASS1aVhJIeh3Hpj8an2kqbvS0TOKphaVZR5Xs XAzSRvFBiHkQrPtCiByAc5J649+Qa045mQGCKGEzlnRIEkwIu5OcEHORz71VCn9ZnKUtupjmGG+p 1IRpy6F21dDc3sjGOSZ0WadcFgkgUAKvuQOvtVqOUFYUZGfMghZlPOQS2Se4HYdPeprZdOcZKina +ibtG3ko6ry/I9Kjj6fsf3kkpW+KK9/5uWj87feSMUkMfyyTiZntbQElBcNgkEgd+D9K00uU+0bp IxM/kxB5PuFyARj2HGK8DHyoUsUsNFrTdJbeV7a+p9Dk7rVcDzV73fW+/na7UfRE0d6+9xLbrbFp pGhb7f5xdTyM8DHHbmtGJ1XbH5Jit5iryRRSEbGjUYGewNc0Wublb1PXUOWDW5MkttKY/MjgQW/7 ze7FhE4JwR34zV5LxzIJjbM0z3RaOeK72vLGCM4yMDPJ70tG7vYyp0OSg6d9y6s7go8cD7JZCFEs 422fJBzg89frk1d3qIo/kKK0wMayn5WUHhgR05H+NaurU5PZPZnj1qL9omnrF7k0kskyBY1aOZlE 8cceCWP3tu0cD1/GrP2mJvtCwISGgQiVydyeu0d+eOlYTwuHxND6rVTUFtbp13dz26eaV8NVjjIp Oclq2v8AKw83QyWRQ6xWoEUsb9ODnj161Iky4jwoKBxKDv4cY5U/X1/pXnYnJsHUpKGHm013S/Gy X3s7qHF2KoVVF01aW+/4XbS9NCwt2k6lWhlAa3R1LzAsAPvD14wPzq6t1uCIIX+RW8+QSACQk5Cq uOOOvvXzdeisNN0XUTa3s/0aTfyuj6+hifrcIV+RpS2ut/mm0vR2ZfhmKo6JyXHygdUPPIx9BU0U 7KLZp9m1m33XHyt024PbJ4/4CKyvqdSaWxppKyOfOEjEM5eMSfMzfX6gU5bqSQRGWJoLhGBlKz71 fGeB0/p+tJpSXLJaCjJwl7rNG3uXdZG2puaZfLfdwEGQycY5PPNWPNKyGQAMEV0Mf97IGRj1x0/G vhc2yGNKc69Ge+tlCVkvVJr77H6JkfEk6lKGGxEL20cnON2/STTf3s1I5w0ojhjZl27V28lwO2Pb Jp4nUgE4CRlfNCtkxjOB+HB4r5M+4LaSbRtbbgswKg4yxwT9OxqVLiRFCDacDByO/HP55oAmS42m U4C7pFYZOSQFxt/+vVpZsMAwO4usTR54jznn3oAsb/lLHGF5O05xg9aAQ4yudpwB7jsaAFOV6ZJ+ 7wPXrz+dKGIP93Pv26UASLIRggbXUkhv6YqxDIGVlCEySYUp5hHmepz69aAJw2QYgvmBNiEF8Zx1 OPyqwrE5+Un5cEA/db0/X9KAF83oCNjMSVUnrj6U4ZwDtILLuZc55oAUqDt65BHQ0/tjqRjgcUAN IHGDj8KQ42rz+lADePX9KXkcE4/CgBPbPGetKT2ByPpQAnbHv0o7Yz36YoAMnj26UoPX5sZPpQA2 njH97HGPu0AJx13dB6UZ689TzxQAueo3dsfdpvbGe/TFAADxjPfnjpSnk8t264oAq395Dp1jdX1w 4WC2hMkjEhcYHqfw/Ov5jP8AgpD+1JH4z8dWfw68PeIrCNdRuimsgRB2ggWNHVVycJuKtyRnjB5I r6DhzD1auO54bJM+T4vxdDD5VJVX5/mfGnhPfrNpYaF4as5kt45WA1Fk8tZ5QpDFTwTjHXmvqjwP 8P49Oll0vw7oDav4jvzFKkNpIpKfMT5kkjELgYbqc9hX6RhaPuzlXk29z+b86zPC4nCR+rRs212R +pPwi/Zb0rwTZQ/ED4vPFrC2UUt09nPc+QjhslUhRWwCvmAZ4JA618wftN/tinxBPF8IvhRZ/YbS 1uZoJrKe9d7bTIiiEmR9ucDnAz95vrXz2OruvNVKrtH7vyPVwFZZVlsaM43bW/r6/wCR8heDvCGk 6LqV1quvXqa34jvw9xe6rekxl224SJeuAqbUyOK63xl4v0/4c+FLjXdVuV06RIkn0u2kQOZ9joWJ JzhdpyD/AEr5bOc0pxwyhUVtv67Hp5BkdbMpctJe+z/Mwghjt5lmntwXi4BVwQd3IUkdM4/A1Yuo 0ntriX5lmjnEc0Gz/XLnBcH12sDgdee9fF0243rR6H9SfVaFes+S911KEttHLG1tBAwMdw0rz4OH i2jayr0BJ4+mPXFQPaXLrbTbWBKmPzFTK7gBkKOpOCOTW/8AaMou9S1ivqlWtWc6mhMNKvR5jSW7 PiPyY3SLkoT6Dp249qmi0eZo1RrWUpbl5XDAjcWwCA31x+WKqOZYR+65fkc2IwWJhf2T/Akt9MuT JcuwlRURXyVAZOQp+o5A96lOiahdSyW8UZSaEPFcBjwxXPygk9AvcZ/pWU8XeaqUnoEMpxyX1mp8 RdbQb/bCRE/kyStEgVM/IkYIPXrn9K0E8M3ZKwXUO4vCFZlQnaG5U546gjH0rkpZlQp1HUv+Z0LL J4qhyy+Mtx+Eb66Ci1B/dsEnWTAV1ZgE3N68EDnpXsXwUOseAPid8PvEltLNOo1aLStREJHzpNNH Hk5wMLtLbh3x2ry87xSx0KcYdJR/M9HJcnnhak/rHZ/kf2Y/s5+LLPVvDNmGjS7t1tTLBMZivmbl nVHQfeBAP0OOa+gLeJrKBoZYvtbIyWqsjYDuBkkjnPGf5jpX9E8H4ilPJaUIvZH8r+I+VVqHElaU 37rv/kTR8WwJQO8oDQzMwK+SuAMsOCMHH1xV2MKs10qySR5tFgbzcssmGyi7+uevI64Ga+kqYmNO N1qfnVbCPDVaU7WV/wBSxERBCZYyrwsd8kfTyw4O47uwI7DueasiQBxb/Z9ksaweZJHJ8sxJyeO5 VcZPr0qfralUjCCumfe4r2VLDKK1Zo+XeNMiQRLCctMI3iDOwHLHA4xxn2pNsiyzNBEGYy+W6eaF MEb4L4J68YPFdE4KcHTex8vRxuGk3BQ95EqqHgAEqv8AZNNiVoy3EK79vyn1wQfXmrsc0iecQuCN sS+ZyCyAhcAd+p4PpmuNVPqdRU5ax3PUdWU4ueMWn3/mWYJCVaNREsTxC2iaTGZZGIO4dsc8A9x+ FSxNLKrQBGhuBA8caySb2bYDiRgOmemPSumreVdVUtP8zy6NaeYxlQ+yupMZWglCFI/s9zC0zrvB WJ4wAVX+7kHOc9qv2/2nYbOYeYbdztt44Q7SttJA3eoBA9+tdlKcuZxWzT/IwngqVJ+xir28iysz CWFfs8w2Ryyq8UoPzFQoXGdzY5/E1ZjzL5ULxNbQyTG4yspTJ28Nkc9RjHqawXVpHRDkm4UpaE6/ PuhdPOMlkqTKZCMSMDznpuXbzxjpVj7QxazlMUk0JuG8yRMHdJgBgR3wvP4UYfDThNYmauXjKVCV BYeDvYvZfzWd2t42tr3E0MgLsF3Eo+funPHA6ZpIiMSQPE8zxnzZGMmBCqZJ3D1x/I16VbEwTjOE jxaSU4TnbRdSxayNi3yzCZbcPArDIk7nBzhfvdfapIDEjNNEhM95C3mzefna3QAL0GR39xTliZNx hHS5hhqLrYh15u6X6k5Xck8KMJGijV5Sj5aIZ5L+vHaoUcxK3lgRxyol5EJE2jhsHHPBJzyemOK6 JYuUH9VS3N3h1VquFaWr6eRYNzNIF+QpJGqSRKkmFIJbj3IAPJqWHKxROAiiQSSeVG/EOTyPxHNa 7rRmOJo4fCqVGlD3l/X9aDh80lwZNqr5SyRhnzyGG457/wD6qcSJUhRY4wQzIqLJjzWPIyPcDvXR HDVJLmeiPLw08VWUnOnaxYgKPboGRGimmfzkaUxlkVDy3bIP6D35cgWI+RJ+6j4EqLyA3XHtng12 4Od4OnKWqM8Vh44SmowlrLz9RMWcNsqsii0DGWaJbjaYkbIOcc9eh60+UmG2cywtH5gKRSK5MjgA fJj6Y5pV8X7JqEDkwtWlrCrHT0GMctBNtEk4hNuQSMmMYJwfoR+VSWkzKjxbJBMEzKvmZ3qRtTBP 1zntisa1ecKqqRe6+R1YTJ3JTw8ldPb+vUiZ4o5LeVDIGVSiBj1wpX+QOT9adiSF4wYITNFFJBJM suRHkhw+P93Ar0U1JJs2dKrglDAz2CFEjWQPCDsZI/tKN5iTM53cKDuBAz9MCpY1ltv9AlV9zxP5 8kSjaYycpgj0GBWU8RRhJwkysZSm5ungrJdy7Lcqby4zseGO0H2zzJdn+6cAZUEL+JxS27mQyCRU EdyDLvL5MKxnCYx0JLfNW0Zx5brU5VGhRmsNXV5P7h7gy7ZgwS4C+W5ER3Mq4LHnswGMfjzToplV t6r5SmZsCHL/AGeNvuhehOAc5pNqK5pGWJw6hVeFw8bWJ5rowSXJktmngtbQx2knm7ZLgM3zblx1 GAR14pT/AKMLiWKJTJc7FuU87Z5zZBRmyeD24x0oxFahTnFRe5wYeg8LiHVxKuXgWL3bJCtx5jOy RNwLqTOSGxwvQY4pZJrdvuxYMsxEZR8bXDcqR0yM59Oa9PCygqbUlq/xOPE5eqmL+sQ0RbkC+XGx KqwWUPuQcoDwT6nGcemarRSt9oikiSVYHm8yRJJV4wp2c4HXIyaqlRp4eWsj0YYnBOlLAOGv/Dly LMrrLhZYZFe1EEo/1RbO3ceowQwHr36Vaje3ibAcGaSV9olVmFu+08FugyAa9OhmDl7iV0jzIKhG k/a/Eia3Lrbw3EpRRGGKSed8sqEbfpn8OKsQBwyxqJ83AXO1ctIxHcZ6fjinHFVoPe6MKqhjKLpw jaTY43JjkjkkgLRRpiV4QGa2jycnbnkHp3PNatrK1s0UbKY/s1wLiEhv9ccYyW6tw3SnVk5f7RDT p+f6Gf1mvhKH1LEQ5m9i7EHSJUhV1U7lgbaNzAklmHcEdOakWaOXZGUkzseUvJJgyAcEeo4GQfet fbU6tOMKq+SPPpYd06l3Kz8iwksz20G1GMb7PInnlO4KrFvLAORjqM+9aCXAWNeEt5JZBGit/Hv+ Yqx5HXj6VyZpgalaio0ptR7dEvRL+u57WVZ5GGIll84K/fq/m3YtQ3TYlUIFjW8iNyspDY2fwKev 41bjvPNZQ1v92FmRvP8AmJG4scjvjGM9ea+ScqFHEfV8K7pdbWPpE8XiIOTjyvtf9UW4pcIhgieO NQsLyO25843bt3Ynnj3rYWVX+0PBbFnCRNGQwAtm/wBlic885H+FGKuoKXmb4XBUa04wm9euoq3l tM1zBE9qZo2Vhc+YHyoByu0fdbJOTmti1nD/AGKaKFR8ghWcSdQSWHJ64wevPIr0KdZ04uPRnn51 hpYSr7HCrRf1/kJFIhuo7ZlEkMsj3Mn74YmbIyeefvDmulhklAnZxHGscnlyyrgl29OPbIpU6s6M rwdznjJ1UqlTcsxyBVRYGALIzB34CkcZz0+UdM96toBD9pC2vlQW0cYURTFXmDDIYepzg8cHJrpl i6kV7j3/AAOKyw2Ic5L3WLaeUjW8iWNy0qTySzvDqezc3OGROdg5A4HUVftmZUjBSWM7XgXa+8dM EliOT9fX8a+fzLLq1aisfOrFS9OW/wA7vU+ry7NMJGf1WnTk1015reiUVoXDcKA0ojDbZVWJc42s BtA5PJ4PcVbIih8sTKyuJgL0Sz485hncAvtxxzXhqfsqsZymnprbp+n3XR7kakpt/u2vXS/mlv8A ekXovtLrMWUICcqwfcQM/wAXHc46elWolcy2xWA72kYmJrsRHaRgfMeOucZ9a1dV05Nzfob3VtCX cF3C3g3SR25lS3lYACTBLDdnAI55zg1eiYQrPF5cf2V1CW8vnZkQ4B4755rWU4xipzdjixDVZeyp /EiNLnMYZo3PkxK7nfuMgAwT0/SrcEkezhGd9jFpTdlViQkZJGOcHgVcZXXuswrYecKcXe9h6PJH u3iMBk8tWikBIUsQM8ZHJ6H1FXPtflsgijAQshkjaTIkdV29f7tdEqzlokrGVPA+2arkqyAPceTG JYjdqYyQFZ2xhzn0x0B9KvwSp1HIQ+bA4yN5PBBGfx/SvAzfA1sXh/aYZXkttvzav+KPdyTMKWX4 ieHxMrQ76v00Wn4XLS3SKJVjgmV9oiE4IPnsRjcMcgex9DVpp41imRYDIsU0axyefxb4yCWXq3px XzdTDV8GowryXM90ne3k/M+1w+IhiqXt6EXy92rJ+a8i7542/MTKYzlGD/dYDqQBkkVYa4Dx5Xy1 Dr8rxy42OB8xHvz9OtYuUmbJX1L8UoZx5JJJ/iLY2HoQPbGOfercc0T/AGdicfZ2ZyxU5kbpjHsP 5Vomktwk2kk0TwSq7RHam8F2SZj9xDyQCfUrz9KvROpEIMTqkkrSuUbcUDHPU/oPrXzWdZLDGweJ wqtNfj9yu2fV5BxBUy6awuKd6b+du1rtJLuX47tsSSNCP3beUMkDaDyPqOPwqz9phd/LdSFcFVlI IMRxkH8emffNfAThOnJwqKzR+n06lOrBVKUrp9VsWw+3yySVdsOcHJjGQCePTP408NkvkM2T8pJ5 69aksm88FZAANrKsaJz8gGe9PhlZtqvyFjPzZ6Ny2fWgCyLn5Qyx/fHmS/NyAOD+lWI5N+MjA8oy 5/ujjGfzFAEgO8grgL1wP4unQ5pVADANjbnBBPagBwcRBmIyAv3v7hHOf0qQSnOcZCuGySAZDnr+ VADVkZWQbuEJCvsHyqfWrQlV0fBZG8wPFnkAgDv/AI0AW43DlxySdpYBvu5HTP8AnrT9/KLj7zY/ ADr/AC/OgCTGCAMjA+tKOvXOODxQAhPXnjFNJHTOMHBGOn+RQA7HTB6DGcU3rn5sjGM46UANIwcU dsZ98YoAXrjnt6dKM9t3TgcdqAEH5Z4NHrz0HHHWgAHB64/CnbjyN3GPTrQAmeg3cdenSjv97vnp QAn49ORx1p49m5PONvWgD8w/+Cmn7XNt+zd8GPELadMra3dabLaiITqjRSsImjbBOTtDZxj+JfTN fx1/C6x1b4m+KNW+JHxK1Jdb8S+Jlt764s3hS3gsE+/FD7uGBy2eSOK+64Zwtf2L9m/iaPxzxEzG k7qWihdPXc/Z/wCAXgTUfGF1Z6L4b0qf7Z5p8m8CLOlvjcG2gMuSduD04Ffsn4O+H/hP9nLw3/wl viXS4r3UdYtTJOJrnbDp0isQeG3cHcOmMZ49/tcVVhhqbwMn67H43lVOli608xp/Cvh31W++33Hw L8Y/jB8W/wBpfWbjRPCEU3hnwppt21hca5C5j32zeWhIXbt2ht2WYngc+lfE/wAUfHvwd+A1w/hK xv3vvGVzfFpirfaopZwq7n3AEYbb9BnAGa+LzHF4WjOeCnOyW706f13/AOB9fw/k+J4oxHOo6R26 ni9v+0FZrJDrmrE6nDNcQvY6PHMEEiMBtYvjAGXzj0r4l/aF+MPjfx7ZFdQu5Hs5oZNKghs7kxrE oAHBCgsQFPOOw9a/nTj7xBw2GxTy3Au8l19D+2vBTwclUksxzeFlbb1X+Z/KPbfDkxymEBJJSWad Xfkv6Z7HA49PrW0nw+huVdpolRAxl8kLn7SRtyFB5J+YV6FTE4/2rUH7rMaccJRm1bX+u50q/DSw e3tHjhe3FvcSw3DNOD575AG9eCFA4BFdfpPwusYd9xe2du0Msr/ZlX7rIu0sxIwRnP6A+prz8Vjc TFWw+6Pbw1HBYuScXp1O3m+FVjaWz3MUe+4iUmaYW+WlbliT/cYKvI9uOtcpd+DfD1tf2MSWvkKI cvfyJn7UrMGOzp04DKfXPbFb4WlipJ1q0jnx+LwVPHqhRp6HJ6r4T0qSaK2ht4kRXkdYyNrhWyyc 4+YggYPr6CuYl8O29rO9ylsHd2N4JAMqrs2C2M4OWP4mvZoThDCSg3/Vjz8dmFF1XToLYLfTWtix kCFVjOSMFrchTgL/ALLHr6baIotPtXjiuYJDbeY1yJooy7RyEE7vcKRjHfPFcOFl9adoqxzyw04N 4hS1LqSQlIQgSKCW0kL2zRg8A/KVY8c8nB6E1qW1wq+TJpqRPdaZNHNpcE0XDzAFlDHjOCMYbrk1 WYUpYeFqevUmjjqtevy1Y2/U/pK/YI+Jdr4t8AaHP/aCNcPZESzXcu1pVjjcSfLj5cngKe2PWv1G eSQQp5CR2z3LHZGW/wBYQD+Xt9Tiv2vw+rSx2TQUfI/n7xRws6Gbuq9nfX+uhbt8C3ECtGVkCuVJ yoUDkYPfcR9PensoLWKneJg7CaQy/KpC/uzzyMDnHfJNfpNPD04U/ZyerPyyOEjjasbu8UWo23RK HwY441jggVMMpGQWJ9e+ehFWkieV33jlIyN2eYk25yT0II/pXTTw6o07w2NcbGcYSpTW1xY1SXYk 4R3i33NsDnEKgHgc54B6elR2+xJoQInuZBujeeRsF4TGRhu+OgBFXVr8006r+Z4GT5Z9ZbnPd7Mv 20sbQmIo7zggzQu43SDaDznAyB3HateC3uZIPLSNzKWFyZIFBC/xBcHoMY9+teLi8VhqVf2tWV0f Uw4XzTF0PqtODduvchWOaOQn7Ijh5Fa2ijmDCSLGc8/KCH7DmtqCz1S8JiXTrg2iWUayanBOGJlP zeUMcj5f4sdzXPV4iwtKLk5q39eh0ZNwFxDiaqpRotcvkydtKvY+JlikiDZhtwMqnHABH8j3rRg0 y5lmFuhe5eVt0DwsR9pkbPyjHKkYIz9K86XGuTYdKlVqK5+nrwhzx4X6zGjqK9vcQCXzrVo1tHEL 88ggEkY68Y9ulZ/2iAyzWkZlFysgCxmIrHKCSx/eHhfmHbrX12XZjhcZhXWoO6Z+R8RcNYnhnFKG Zq1+hpyzNcwSOjJ5yytJtReXVhjk8Z+b+tDzmOM25eRvJxGSrkCMLyc8ZOc16GFqUoqU6j0Pks3l WrYdvLl7z7mhbyxuH/dKJJYAZEjY7XyuFOe1TtcRtOxWylQRRK5jgn2iViAXyTnnI49c4pOnCvUa oLQ5qOJrYLL1Qxe3XzF80RSpvtlmtdrQTvK7JIUkXlh6EZGKeOkF3LbhjDDsjmWTKqqkYIAI9AOn rWmJrRVSCqLRGHtUuV4Rbk0qSTFiqQAvNJMyNPsSR2bcSrHrjBOPWmTHeQ0saXEb3Bm8s5BhCgYB 7sM/yFdNWv7NxSV7kWqTm5W1W7BWDtJuijM0TGNXWbYsLpwEyfvEhhz61MFjlEUSIEjKbVaFzvCo PmI9W/SuhwTd5K5WHxnPNzrR8vMvRXRnt7ScDF0IGBGAWMQO3cV6ZIOMDmlWRZJGEEUcMOnyi18m ecN9ok2ZVo+5Vccjn6msKeMVSLUtEjsp4iHsJSnGyHKwW0IYpIJH8m3duTKMg4JzweSMkflViNY0 IaS3aS6vVKxGGTmIDC5PcjBwe3FXGq5pOgzw55XPMJpJ6MaGUxOmAZfJ8iLfgHKjjJx/dBxnrkUi 754mM8bG3eJ4DFJLnCuvBGMEdK1nzySimVjcNRyyUaPJfzHIAELLbqslpCsVtBM4zgAgkDqcE5Pr SqjRxAsPOEsEayuZQZFdR09u/TissVgqjnGUp2Oyjj60pxxFL4R0xVI2jdnd0YzRK7Y8lTkYOOeh P44qNnQeWAwXymWJ3kPDgnk+5AwfXIr1MIqkcO5ze36GOY4n21JuutXsRxyEy7fLQIso8uRW+d17 yEduvQe/rViOchZolTcVj2FZJiFYZJVv/rdayliKdWD9tHXocOBqOX7ustP6/pE0KLsPkwMskisZ HWQcdcgg8kehqzC7eTCYZFRrrevmMvVVC7cjtzkfjW9HFUaNGMXudtsNUxCrUVewRT3jK0sUZ3sV SQPgYDsVCY9RyT35FRpC8s32eC28uRrh5DCJADHJkKvzcdevH0oxFfnpRWtjnqY2lPM5U3rvt/X9 ehpRSyMYLia0c21yfLEz3BTzWUkEA464A5xjpUR3b8mPeI5FVyY8CbdnHI5+XHX2rom8MuVO1znz NVMNSld31NGFrgXokRY5Z9jkSSSZG1Rx06t16/0qOKFlMdznzJHSRpkWXKx8FQXHU+uB14rqu21y 9B08RhqWUc+I0m+n5lx5QEWZSskTGJ5yZP8AUq3UgdCMfrSSGWC8mUxtDDGDLBFkZlUgYzjv36V0 qtSl79TV7HzVOosLTc6sPmPeR0GECl5CZ09JycZwTx3H1I9q0HVfMHBlmVWgjjEoCnnnocFh8xwf zrpwcbUrvqdWF9jKn9dqLcWBmEDxxwmWVZkEcIP3xnHfpwCc+1WbcXPl3DM5cqrGBVTv05OcN3H5 V1pd2FD6vKq6lJ6iiYxwQz7VeQrkmRghSIHBAxwQCenrVx5ZlQb4k2tg/LNuMK8EnHb3ArtoYiPJ Gi4nLOcVi3O17f5GgLgq6/uZEt8edPcA/urbLKFX1zzyMZ496uQzs14bRIpbhIWWGG7DBDekn5gA eQOnLc80sQlTrqUVsZ08K63NWSsy5G5mjZTZqZJf3bFTgRkE7WHbPr2NWmZtkKPFCUjLTMr3HGOq 7Rnk54pVcVOouWmrI8rFYerLGqvTj7y/RlgzBwx82S5kmeJmLoC0WTgnd2/+tUq3KtEsUgV41uZI /tEKZdvkwGx6H0968LF5biMXHnw8Lcu2qt929/TTzPo8hzSXtZ0qmrk9brW/k7/fez8jQRnXeY7e B2eExS+ZdMBHkKRhc4+6D9M8d60WeFUDJG0KidpGcyl/NyBjjsOv6V82q1a/sHqz6jFYejltBV+f 3/UvsZFJjmtluDZwq+Iiq7VYFsB8fe45J6VpRuBcSGG0jsIHljlltxPk3RK4UOfboCPSvRlCUqik 3p2PN+tOrVVaurksAmFwILcNPLbvI8MgQAgt8zLg+2K2rUk3kbLYJIbXElzavMUUxgEtlh3zzjGa 1UtGddapTrUZTezLVvcQyC4YhliWRYw+dqZble3z+2KuIFlmyrRx798sTSPhgyAAqep65wKasmpL oeHjaFeVCLt6f18yeUQpbzERSuUBkS3jcmWdcZdQcjnPoRVqBTEI5bC2MPk2cRFlLcA+XKVJ2hhx n8TjHJrTEXx8lSqRVuxyRpYvDThUoOz7p26mgk6ytIZI5Y41RZ8ySjEIKjK8Yyc5Oe1W1cBNzwyQ JnYiTHkDI28nrkEd88jPpXg5hha3K6P1hKK2i9Fp+flofZ4HHU5KMXh25dZK7fz7feXVluHkAa2g jtVxPHdHUiXuZuVO+PHyhR785qxH5jLMrW0LvAmXtklBDAEYIPAzuPT3r5qKk5WPcd4y5UWd8REe +C5wt7IqMs2FUY78c8/hzVrz3iXeIJZ5IpVcG2IyFUfePsPbmvVlUoyjKL1sTRoRq4lzbsSIzRG4 VZFUoUwElVhIhyePcZOatLKYpFhZA5EjQCaKbcjIB8rYx/F29KzwtPli6oa/WfZU3cXMYwRjy4jL DIhYyfaGPJOe2MfTinOgw6PEk6BQQJ34VeM55ycEA10x5p3U1oFepTp4n6uaHnWyeXJHAkQ82SeQ QNxPIcbT14HXrnrUsUzLJLE1tB9nmKPbOt2zOh7gjAxzj1rRNtnk4ilOnN3RL5xm8hzlWWN28kEK sxDY5zzxjPHrV/yxCwk8hGjktJPKke5JMeWU/cHUnnBIrGuuam5ObjbW68tfu7rqb0K+Kq4qP7tS jtZ+f5PzLCrNE6I0EiRyp5gnONrgdl+nfFSl5JUjRoX2vL50KCbZ5gQ/LjHOAf65FfCYqrQx+JnJ YjV6/C0n+Lf3qx+hU4YnB0adFUfdSt8Sb+ekV9zL8bN87SqrGS3MLqr/AHS2dx9wcD34rVjuGVAs gjIeBIIm3kGHB4OO5578EGuCNPenTl6npLuicThozGYP3MLjad3EIU849PoKuPOcFWZXUswYhsAc 53Y9P8e1dMORLlh0Jbd7Gh50ZllzlBCPPkjkm5t48DaWHTnOeKseZtNyWODnY7q3QYH3cdOp6ete XmeSxzBNup7/AEb2S7aW+93Z9BlGfTymajGHudUur73d9V2VkSsxG0xhiVwoJbntzk1fWeQu58s5 izJgNwp7g+uefxr4LG4WODq+w9pzSW9k9H213P0zLsdPMKLxPsnGL+G7V2u9lt6E8bNudgUKtMdu ZAflCkKB29z9KkicEOpyHQogY8Egdc+xrjPQJt5GRhsNx1HH+f8ACpvOkKhUwMrhhnngcn8v5UAT xzZPUGKMhlOcFQAePcmrMUjOCQqrnb86nO3GCQfz/CgCdGDKDgH5ckbs7fagsFVm3gAMFxnueg/l +dAD+mODxxwetA4JGBtIHOfujPXH0oAf5qtvIX92ZBhdxzleMZ/OrEcoThgPMwGU5xgbeBnv24oA kSY5UCMGWQLuJf73+R/OpFuXYMAg4VgCHHYj8OAaAJDIwkCEgkygrz/Djpn171KRggJwBJuIHOc/ /XNAEhzxjOffvR2Xr64oADuyF9eM460hxxg9sH6UAIckdc4PpTT25zx6dKAD8ccUpJI6/UYoATPT 26Uu4+vbFACfjSg4HXH4UAIO3OOfTpXM+M/FNp4O8O6hrt7IipbKojVx/rHZgo4/HJ+lBFSXJTlN dD/P8/4LB/tP+I/j18e7fQtIudU0/wAO+CtQlvNYl3rNHrcm61aNkLdMNGQwHZe+a8T/AGRtQ1j4 q+LL7QoTPpvhzR9Otbu8urS4w00pN4+FOMDiIeu0EdDX6p4X0I5hms6N/djf8j8j8Ucmprgqtnkt JTs/vuv0P6pfhH8Xvg38B/DAu7fVNN1u/g0uNUnkYwjTmlXdJvlcYcrnGcV87eNf2kJvjLrN5dal ceT4QjIvLWCDUfNW/ULwsgAACqwX5Tn+lfoHE+WYbB4uricRNJK9j+aODcfUr5MsBRg05W1e3bb8 b9D41/aR/bZufCmg32ieDlt9FtX0lbCDSdGyCI5PKWVnyCSSQSAemPavx/0bStR8YeK73x94kNyd W1a5hud9zMX5iihAMXJwpBznuSa/gjxq48r4GvUw+Wvruu39ep/fX0auAJKqq+OV1/wP+Az3XR9J t7Db5MQU2Eq28G4cTIv3Tx97d+mDTr/R49TRpXYtALYFS0ZIUEEHH4kj6EV/Kf8AbWKxdZ4pz18/ 1P8AQzBZbHAWhQeh/OpJbeVDbTXLpBfSybp440zkljsbcOzdB3z14ro47LdEsrptu7mwxtM+57Xc wD7j034AGRzjOK/tvGYSMKPMnofxNKSqY27Vzp9O0G8Fw0hR5EUxzefuEguHGB5Z9ccAkjGO/Fe4 waZaCzt0t1k+zzRCNJXOZbDks4Gckru3deowOleTgKMq9VyS1PQxMqeV4CWJhpc5q6S1tRNE/mwB I5dQDmclSw+XeORzyFI7ZFeZ+JYUllgnkCxxQ3I320IwyoyKrMpPIJwGzzkgjpX1UsDGlTjTqrU+ My3MZYxzqy13t9xw1zAwuhNDLPJKLdQIygGGJKFgPePAxjrzWalgsttKWCI8UwjWNnwEUqcnbx7c 9OTXn4uMKUVTgtGdOAjUqzm8TH+rGsPDFxO9sEgWW0urEqAFwsQGI1DHs3Bx9T0rdT4Za5sgu/Ia DS3WNtPDxHYpC5OR2xnOOnrXi1cRQwjVKG59Fl2DljqElz2scJrXhybTQpsVkvIo8G7aNVD7SGGG 3cFsqenb3xXOWUVwk4MMjSCBCs5AHXYDyCOu3gYzz9a9GtUliMOopa2PLny4bFvDyex+qn/BNzx2 2n3viTw3e3D20sF6NX0uKSTc/wBmnUKBznGAp47Yx9P6MtNuP7QtopJJo2nBklurtH3icFmaNlGe MgYwORg1+oeF2MdDCywtXp/kfkvizgauJw6nCO3+ZqI0bNaW8UaxmWdXaN2OJAFLFVOeCepqYqGl LgJK6b5LSNkOdqjbICOzA4I79q/WnH21P6xUmfhGH5sNCVOL996rUtWjMZbcW4jknu9MkmMT4AiH q/vnP4mplkbbFAvlMsqs4m3chouVBY/y9BVynNUniY1dEv6QlisZXjHA4iPvtpfodPoGiPq8ELT2 8a2kkUazs0gCyqwEgBwOu1ux5zXVx+FdF0uGaBQZki3yRWwuCxiQbTvOM4PHPPFfhnFXipDAYieH XTT+v6/4P9h+GHgjF5XQxmbU91c5u/udHtruQrHC7RHyLnzGLNGSFxjHUZI/Ou00HVoRYQ3L2TJA ieTII3IeVdpLBicn8a/CM68Vcd9Y9lGb1P6YyXwwyGNN1I01Zf8ADk02oxqERbGNyu62bCLujj4L AEDr8wOfamS+INOsrV1WGN5ElHkTLIR9nUZByOjHdjvXkUeOMyVZxqSbPVzfhjLMvpRq4GglfsvM 88v/ABPd3KmEBLad3bz7eKbewiwDuLYxkkk47A966jQdRWVYyJHWa1QxLKsuTKccE8/qec14uacR 4vEVXUlUa8v6uVhqcFCODqQXL6H0V8PvCVv4gt3+1iSe0k06VBcuNogzDIVJx1GRnJ/u+9eE+JtH l8PeJNb0uaImGFvMUm5/dSjcwQo2DnOM8cdBX9a+BeZV8Xw9JYud9vwR/Df0loYajmiap7P9bmVG oguPJIQLNCscuW5UjJ+b8T0q0zXEDm1m09Irq2iy8hJHnO/8W3oDt6Gv3ajFTpv2OyP5dqzjyRxV SVk+n/AJYkUMmY3DygeTM5P7llBAGBwRzzmppCw8wxxvGHj/AHMoO1URQNz9cnJJ612xxUYUeSnH U86tGjm2McZu0fMW4BuEeGaJQLsiFEkJ2SIAHUsRnHRv8irKmGOecxQthtpUlgcA4JbPAwK400/i M8XLkqrAU1t5dv8AhyZpZbMS+bEx8iEyljMsqyozZXGOnBx1zQCHCh4t8ZCDyElzsXJ756frXve6 oXQ6WGxavF6DZf3qSiSGKecQxjywcpKFJBCk8Agd++atM7K7vbxuEQB1dHysKg/dwT97ORj615tK dStOUIu17nr5hDAxwEVDcfG6/MVTZI7bYkV8/Zy4+ZM9+AOenvUpljL7mjSFj5RjKSbwr427Rx0A 6/jUXnh06M1ofL4ql7eNOMZbf5iTFlgkhcpEYiJU81gyAZ4UehySck96tCUss6gtEII5JnuWOMIC N2T6nI444qqOIlQTUo77HpUaNOX7tSs0I9zG8NwltBt2ZA8tyHG4jgfTI/M0wxLEiWnkTYit2jle Kbd5pDE8Z7jGOveu7A1Zq9WpqjGrl+Lxy+s4ifuI0f3c92ZF3Rx3CQrbKTu2MR+8LE8/wjHpUCTy ssw8nabsrK9y7j/R9p2qAp7EZxXbU9klzR3f4HkTrLDL2VBpxRKmJQ0CqGIZ2cecEyU4Ayf4gcZq G8glkEKpEFSScI6eeFWB1AbaT1+Y/WiVWCpqlEvD1o4yDjOzSFRnJiXyvOuHm891ifagySAmR2AH frUkJDx+YkIVbmVpVKuSYSh4B5Iz1NclaFRwcaTOzB4OClN01fT9Cyr72E6JHG7JLMko+fknaOvG evPT1pdhkWTCkIYfMjLPsAOVHXtnB47UsPh6lN8qk2c2FxlOlOpTrwt0/AmRZlnm8+BbVHvTNcWs U+TCQDhvUEj8cCorcjaoeL95c3HnOr3RwxP+qcD+HKgn9TXdUqzqwUZdB4fD4ehi5YyqTbY1ubVv LKjzGCs0vyQkhl3j1zkDngA5qxKkktt/rXileMFZwQfssgU5GPQdM9PSt67oVWoQe1/Q83NJSxNe M8Prr+pehVmCo0cqzJiaVFI3swXOBjoR1+h706CUi5h8osHiZJmhyFZ0IJ25I4J6AnkVNDFRpQ5J o7cbl88Tg4KMdUi7H9pRZ3NgFit9sjmWT75bJXBX+79PrVWNooGnaK3lE01uqXUk12Ga853HaP4R 8y+nQ16VGvFzVaGqR5VOKqt4N7+fkaUkNzFMEvLPy7iFjax24cE9eOATg45wfWmwkR/aEkXfb27B Vggj8uRmByAxH8TE9fSvQqYzlfuIwxeGpwqww1KXqPtldEe1kVp7hosyeW2IdpyeGJ5KjgDNWYIm ihjht7UKsUuy3BO1rZD8xLA98j9a3vWlS5tv6+Z2vC4XCQajPoPRN11NNBB9pMMf2aRGlAKqSO7c fKcnAz0709Yf3VmkRLOzDzXR/wDUuM5PPPzD2rDC4mSqqpWlocuCjh5Yeti5f1pcswiI3IMUTR/K E3CfaqFm53KTyRg/pWlH80coDyRITgMr5KYyAo/vZA79K9HG4mTi6n3Hh0sTXr0+SqrWNO0dWX7L hZFciZkdsLgdATxnGauIpsbZVFoIjGglgczZZXJII5zxg9+lcNCvOdRRm+h6WJxLp0FCg7ysPlco iJHHHcPIhkRXYqEi5VwxxyQckeoqZF8kwymN5FnaIW68MtiuOflPJ+hOefSt8Vi6lCDp0uux5uEp T+NLV7mjDIsJdXBfa3myS4AEqjdtyOvQGryx4ZWbf5TW5AIXaC/XDE/UYPT1r5jFe1oVlXqrWWv9 a/5n0/1ilXSwtG7cNO/9fciwLn90we0S4tp7eRXV2IZX74U9R756A1cjugYnDSSRBAsplVsiZhxt AIyBjHPeuaFWtVk5RZ2/VKLlyRnY0rMGNA2yVzAwlEk025sqMtx1575NbEaQAwzW6AQfLdRAyFfL VwcnGec57+telCbVNOe5ng4RqQnGRoC8dLSUi28xYJIrWxhA2rtwECtg8HJPJ5q49vI83li0t4JE j8wCa+X5HHyOA34Ej8q0t94Varp03CpHRbFq2PlhFVlYzRAmSMESRdQyt7Edx61oQoqxI4gl2yot skykmLcpJ2qOxxRFtNNErnr4ZylLRFuKV5muLhIVl1MOjqk1wIobhSTlQfUDvVq0mQwSHyIpIGhe N081nKyk9F78Ede2elceae1xVBqpbfs7pfi/yRll+OwmEzCNabbundcySb6b2X33LcqrGqx3EEka 3EIUMJw2Mrke4yTyasRPIGgCww+bGWTbDJuzkfxMe3618xWwypR9opNrvyu34219L+p9msfQxM/Y 06ajPquZNr5K/wCNvQSF3UDerwsijLtJny8kZGAcHoakV4o2jVIFV5C6wvC23CbskAZ4y2KqEaLo SjfTu1/w5rH2i92qkn16/wCRpyiJogn2Tzrklo7mGWXy1tZhwG385GOOBTYW81Ut7tFcmaOOQPNu UKmWBGR7j8hWVKv7OXInojlwkakVOVP4r6lwHfFJmF/M8ryY1R9u5Q4BIHQ845yKdO7IoSW3jjSz ADuf9YjFiASh/l7fjXpwm5x5mrGNd1K8XVUdF1NFY5pHnnCRqkMYi+aUfOidGwOmMn6Yq3bGIRG4 kt4fKERWKaZ9hAUli3XJz7+lW3Hc56tStUoJNaXWo+PzigjKCWXIjg8kgrkj5hz1PPrjmpwqESLs aLdsmkCttZmjI3EEHp046etJ31stSp4uTjGnFaL9P67Gk7u0u+RNpbooXau3JxgcVdtw1yg/czAH h7gHCxu5x83pgD9TmvleIMHJ4aGKk7cult933ufXcL4qNXFzwiWktb6LZbWSt+RHbtI43C3mhdJA GuZJlKXILEcKOfTOfatVSGdlCoIkGzAfkMv3gR29q+U/eUJI+wxEYKb9myeBy7p+8Lhi0a842xvg 9e5yBVq3dW2yLH5krM00kvT7S6koQx9Rx0rVYp83vLQwunq2WJ3wv7xYnRW8uZ5AcmJhgDPTr09v wrQR12sGQshAUktyOmBn0+WuyjWjWTkg06k6SSOsx2nMbZSLsrHvj14/SrrkoGZkWKXGNszYAGeM /n+vvXn18LQzByjXirrZ9Vv/AFbY78FmOKwMr0ZtRe66P16fPdE0ciFguNzTfukDHGGIyPx4q00q nbI8RaQxhlm87DY6EADpkj61+e5jGpDHVY1Zczu9bWv8j9cymdKpltGdCHLG2ive3z6k0Eu+OQDc scRWKRyc/vCcnnuCD1HSp0LOBMhLwTSNGpA4Qp8rc98nHT3riPRJhuUZk24aQom3v3/lUytjJzh9 wGW5G3GD2/zmgCyWCtIgj2OF2hg+QnHX8eOabHMGi2CPjYyEiXoR97jvQBfDYKZyuSSFJ5NSxsUJ G3J2YVs9z1/T+dADejAAjJBxx6cU7HYYAHAA/SgAyH+ZSNrMVXPGCOSPwpY3+UsFOJU+6wwU6Hmg CdJWOVXkMNwHXD9CST7Z/OphOodn8s5CYTDYDD0+maAJkkVlCovXAQb+4GD9MVMo5xhdijy0YNzj jt+H6UAS7jhgiklSRjpmnY4z6HOPU0AJjAJzznPTvTR3+uc+lADsMeCentTccZoAM4GA2QevFKDj A3Y4/u9KAEzyfm7dcdaQsT1NADhknOc4HpX4Gf8ABa3/AIKDaH+yz8HNWs9Nu7WfXNStf7P0porp VNxPI1uFAzkEqZM84AGa3oYWeMlKjB62b+5Hn5liXhcOqi6tL7z+DW7+JWveKtWvPEfiWaW71TxR JBqN2l2yytazqsayJvQKGALLnIHAFfRHwL+LepfCWxMFhK9vYXWrPfywQKYvtih52dmJBKDMh2rj ofSve8P+Jf7EzGrhlu/8v+CLiPKMPxPw48DK1orb01Ptfwpr/ir4xwZ+JV1F4X8Esrm30BdRMreK S0hXdLOqAxrhPujjnJbtXsXjf47/AA98B+HNN8M+Av7M0yNo/saQ2ynybKUrGP3gAAB+XP16d697 xEzbEQwVXE4qVtP8z+ceH8hhg8y+oYWndRdv6/rsfI9pp914+1lfFE0ZabU03QPvdxNbsYi0ZRsB skBhx0PHSvcNI0WDT0VLeMMkMnkOVOMxlAWOfQseMdOnav8AMHxA4pnjc0qyUvdv/wAE/wBW/BXg ZZXw3SxVT3XJL9Uddp9jDMJoJrcmMwo0XHLPHjjP93jp7GntYeYiWsZMMUzLNtGW+Q/MXBOMADjF fkTz9qq3HY/d8HhFRquNrJH80T3IgXLsrG21W4huyJPlnKKh2oTyDgjnvmtux1S1lRWkulD+aZr3 Yv8Arc4IQHuAABmv9OY0quJlOjbT/gH8EUK1LD0VU3/zPRPD/iSztY/LjEMEwuFiuL6CMzSIsgPk R7CcDPr9Sa7WPxDClpawwvG0FtfOm170KbsxruwJD1GeOcfjijA4enRm419zxMxxtXMpSoVJJROW 1nXYtVimsJLdEu7zzXtITMXjhjAUPzgAttPU9skDNcGNStmS5vbi2+ezt0sRIZTh4jwHA7AYC7fo a2qRSm0nc8PDZe8JD3ZWj/WxCtxHtnW4mWPU0i+d0YD7BCuFDDAIYvyPbrWRqc1nd3F7M1u9u1sR DJaRENGFRF8xixOcDK/iTWWIw6qUU2rnoLO6UMR7Gj8zW0XxLJbZ028kMdoImeNUl/4+GwGYnphf lUA++Peu/uviT/os0Gn3kpS7HmSWwG1bMsu1VOevyrtwOM+xrwamSLEzVWXxHfWzyOGpL2Gnex5d rPiDTp5WS2to7OS/V5XQEskaFwdpJPBzzxwMVwc1za75pIBGiwZEiDjfMCUGOuACB161308BXnJq 2iPm8Zm9SpiI4h9f8/63Paf2YviP/wAIj8Z/C3kEW0fie+j0jUrneChZioU7f7ykcAcEMfSv60vh prUGsaBLBbBvtPlgW8aqcKh3yMN3sAcj3r6LgTETwOZVcOtU3+hyccYXE4rIYYqL91LX72z1NY44 fLJgjnWJpLqLcxwyAKOSPut9OoNSxZna03W8WEia6hDNkRkAllJOCeoIxnk1+6eym4OpFe6fzGsU /aKtTp3foOA3PZyGML5C+ew80/v8nDI30wCB3q9BGtzcx2isyWzXUcfmK2HERYbjt7biQuf9r2ry 89q/2dldWtW7P8mfU8Jwjm3FWHwrhd3X4NHsJ1Wz0HTLuf7DHekNHax2fnA7mIj7ggHIVvp0rjNW +wm0kuNCL29i8wvhHdXTCRH25ZQhwRg9OMHFf558S5nXx2b4h81430P9bcmo0Mt4co4SrT95JHBf Zogbe4lgnaS3cXEiNMV8wOOFbPUfMOfUivStJ8xIHWSRxbNGImLLlbeQYKjHX5sck+nFfBV39ar+ zS1Xn2PYw2EjSwPtYPTT/I0ryV7dnnhgtoyI/MjjjnLpGrKckMcg/MCOa4DVdRgJso3Fr5UNg4kx LuFxuPJOOARkDnpxXtYWtUpqMqvzPIzKccRGNBvb/M4hbyWG9n+3WX2WOdxZm4WQvvKHCsMcBuVP 4+1ei6bavp6JBaxeZ9tkUsTgvcsGGTz2wf0HSu3NKip4VOm9dDzcRho1OWcXr/wT7x8EyQaf4ROo RxXM95LJBayTJtj+zrIJEkXBI3A49OMHBrifjL8PprrQNL8Z2UCRqoOlC8il3CZkZ5gXQngAqBuI 7V/VPgtjlSwdHAvaSufxv49ZQsTVxOLerT/4J8wiSNlSV2MMrlQA0e8Sk9SR0AIORya1kLI9xElv LIVlWB5JZ/mCbS6g9yMc9yK/qdUqdOLpQ2P4azKcsTUg4K0VqTRRyLKzJEwSOPbLJI4DQRH5TvPv 24qzGUVLZxFF5s0ribdKdsojyBnPQZI6e1Y0KTow5EycR7GdBVaDs32Gp5kYN3NHA/2RHgSQMqs2 RghxwMYOB/SpI42h04pEGYW1stnaXByC6r8zSMx9D8vP866LdToy+hUoyWKre8/8yYT+fLFFbWgl MkhLxE/8fEhTcQOmAOvpUUAD2XlPbs0iSEXUkeSy8YAZeO/P/wCuuuWKquPLFWR6tfWjKvz+/wBl 8yeMSu0GcKBCS485QAVAAAHG7IqSDeZF3qYlMAeRZGztfkA+v3frWVKp7KTqQ1PAVZfVVTxkHdFq QorrMIkwbdISkcjAIcd2znJ/rUZEirEVRY7cK6QzT3IBZNwHzDqCDuGD2rtxLkqMZvfQ6qEMDVjz zdm9kSxlImg2AHewmcdRbnJwpJHOOemetT2oed5t4VmuHaPLycW8QG3kd898+xrjr1Z1uVyRpLB0 8NG837z2X4DF3GNiA+IpGtIrc8pgjbz3zt6ZHep/Ot1knE4DRNGUj2NllK4K4x68+9KU3GnGMP63 PPcKsIypTnp2uWWLwXu1vN3vgBSwLFCuQufXkcU0IUhs5FijMvnNA+5tuTnGc84xn869qk4uHNNa niVstVem6dGTuyWWEwOBKvlNFNnco6oRzkHkkYI689aprGFMksUcbMkyMzNIVW43Eh23duo/HAqe WLle2p10cFh8uo/2dOp76/QlhCW0YPyB5pZFjQMdshyQy9+QeRmp42iFtFbw7o967ZJIyR57Bss5 64x0/OnduVysNi5J1I4ff8yXbG7LI0CIYy80+G2lQG+Tg+/b+tStDLLbrDMJcTSZihSXiYI3LZ/u 8fjWtOpODfJucmIw1dJYiqtWV5NpjVQwIMpQCHLlkboc44HXkmrLuFk+0FJDsSIKwTa8e0YDIOh7 fyrooU6VWlOpUepvRxH9oSll6Vmi4sTOsjzJHALpivzjcznjop6An8qaynyHbG3fdB0XAXzELbfw B7f0rnpUVKE5J7HDyzwVXkbu0aM0Tlw0cRjCvJKjvL8pcqBuUjuOOPfFXIFLzTjySzTwGbes25lL dGP1AJ49TQqVWreaWh6eIzRRipylr1WxEULoqBGkQzGSZVY7pj0DA+2KlZOJnYR/vQLQKVBGBxyS OAK9nCqFBKUPxOLFZhhOR1eXV9h0Sz28qCCKOaVWEyr54VZc/wATMewHGKn+Zld1VxCQm6288Ibb C8YJ6nuTzXpOc61PnUU/zPLhGjWjOrF+9+JbSMxoiN5WCrDa0oKJwSRnsM55PekMX2hi3lLE8l3H EqySA/uyuMbui5OevStMJKUqTjN3PKxdPHKUae8SeOAHfFFHLLNCC1uucEbRzk9OnehW2xpME3sY v3sKjDSEHPf+HOBmrlhaU0kuh6NCVF0lT5vXoWIIIx9niMTsnzy4W7DIkxOdx7j0H6VbhfZCqJHH Cv2b7TeLEmVBLHHI+o+v406lelf2Vrnm4nL44rDTqUHZpmoxWIq5hEwCMCucKhGBgZ5PJz6ZNXis STXNwbYSiOAwmRZ9rOj4GQvt7+hrVRhKKbWwsJGrRw8a9bVk8a3Aht3ayuDFeXBjjuVlAWBkGQW5 zk5HAHepFkjLBQ+9hNIoMGSqn+EADkfNWfNSbdFO7Z3zUKFelidk9TWQPcNaWwB/e22+YLOELxqM 8se27mnRLGYZJBbqdlpwskxxM7tuCk5IPPSvHxcYUYfVsI9Fo/dvd972sejTqTxWZe3rU9Wrp81t PJXvZk8aPiFvLZQbgsqGfcwDZyp9s5x9K0IdwR/tKiCGZVmuot+6OJ4c+U2B6Ak5Hc15iXJXdCg7 LudOEUalWeIq7q+2u/3fkaOnzfKDKjia6MpmQEAOFO0MX91IPStiNrdZo7w2pWSFWVS0hAKDkDHU DI9+1dtJSi/ZW07nTSoU6qeJpu1/1uXxI0aWMi2YZJJGaRodQXMY253qOTweMH371LGplSQN5QNs A9wWk4jjbGzaP4iW698USqTU1CMb+ZwyqKnUlSra7monmSFkWCQCbzJp2JByvBGwdfbHTFPjNxMH 8u0Yw+cXykxItGKg49Bz09q6HGXJzNaHnxxMsHKeFS0ff+u5pb7O6YtFbzJFNBsMVxcq+9lC78HA wSew/WrqSNbxypPbOUaIMVjuAC7g5AxznggfjUe6ouTCGFpzjGjVWv8AXzLsCBYyWia2laIT3EW7 d5e3G4Ej06ZpSI/LRW2GIONuxh8pY5Q+oP0rCjUpuE6sqyauu2l+lz1cwovBUqdHD4dp2u3rrvr5 IYJh86eVMwHIUSncwHI+mc1OJYneIEsANv2lVcsrA9eB19OO/NceaYGtGl7ajJO/Tljf73qXlWZ4 duMa8Wul+aT1e3urb8icmT7MyFBI8IZ5EJAPlEkgkdD7c1dSWRnS5IktohCoeeRQFLFSrAZzzgZP 1r5J3Wx9rh37B1Iy2l/kSxm2kt44xaefA7us8Cyfdw2ckn3P6VfiLk+WhQpczLbqWdRz1PXkDgZN dDqurT9/f/hzzXHFU+ajS+H5E0SKywMYwRMZIEl3HduB549v161oJGvlMPJtc3VqTIySB/IViMYP qdvIFdk60MJTjBK5zzrVqcVSa2LSR/PDFHGGkDCIhn2Lg9T04K471bUBbeNQkkzjdEjouzz8kFj1 47ZrZN14qcXY19p9YfJSik7Fv7jzOtu8kZtyFMk5boTvAB4+p9MUqwEQiS6jAjuZFtIYhMXVBjOW x0OMfpk1z47HUMNanOXvPZWbv/TN8Dl2Oqx9rTTUE1d3St59zRgcrCPKD7FiEptS4VpGPy7QB3H8 iKuQRsSbf7NtuLqXy3SJuEbGcZPPC1+eY9ShXl7SNp9Ukkl6au5+k4KnF4aM8PLmj0bbba7vRWLK Zkii2xSFGjGzacMnPTGOOAf1PpWjBI3mhzEhxLuQRvl1PKnB7dBz71xwam2mXJODSkhwCGZoy3mQ NCPNB6KzevrnkZq8yO6ztGG3lEQFXwsHO3cw/wD1ciujD86bcFoa1ZKtUSSsTzL++kSGVJkTCCaN sLMvZgDzjH5YoVg85kESlpGVCd2SwXJQc9s5JNd1Ooqkb2t5aXX3N/mTKMITdOMr+etvxSf3ouR4 ZAJIgg3M7EyglWB6g1ISGYMoKFJQHb8P19OfWssROaUqcNLp2fnqKn7OFWEqyuky1+5Jlka3C77g y7EOQQBx+IwPyqaC4wzYDgxkbIBIPuHIy3pX53mOX4rBz58TNSb87v8AHU/XsozfAZhD2WBpuKX9 2y+9XS9LovQyowKkFWZC53N91cYHNWkK4j+QqjZdzn5lOemP1/GvLPbFLKqM75CopLHP3R6/lT0Z mRFyGOwKGA6854oAtRyKixybdrCTb8xznaNvp9aliVhI6yqCzIWZy33l6Y/OgC2rLjAbJYBx9PWg FgSHHDOVjIP3u/4f/W96AFxlQSvK5x7UoCkZGDlAuc5yAcigBQ6rjcoPO1B2fjPOOnSlBYbCTlow FDn2PFAE0JXJOwAI3m5DHt0H54qzHJ8wDbVmAIL4GAxbBGPcYoAkLMnkxbCDkBXzkRkkjj8Kt7jg DA+9tPPQc0AKDxuH8XTB6+9JnB6gN3Ht/kUAPGTnPAPSmA8EE+w4oACCvGeMZ6U04JJHrQAdse/S jJxjtQB5D8b/AIoaZ8Jvh/rvifUJlgezsDPC8vCDDKDk59G/xr/LR/4Kh/tOeIf2xv2vfHTX97YX Hw2+FmvjTPCc8wFw/iPVEtrW4up4xtG2OI+Wo65KN+HtZfGnTwFfFyV2tPvTPmc3xMo5jTwjlo4t 29D5o8HXss76cAiLP9sF7MZDuJmkjWJQFJ2kA9RnHzZOK9ugaR0s7wgpb6fF/aPHKyMY5EfYfVc7 j6ggV8blmOpYfMpVKa9D6bhPKnj8lqV1L3kv0Z6do/xb8UKsOnWd1HZRQ2S2+nW9u+43Hm7iX2kc kSe55OfSvd/hb4L1fxuYr3U0vhaRx/aXfzBJ/aVwDbb1DZwflPXjk8dDXx3jf4hToZBLB1alpP8A 4KO/wj8O1nfGS54+7F6+uh9yaF4St9MsLOC3tEU2Gmx2dopXiWJMKrEHkswJJ6YxW8+i20rNZeU1 vC8cUMkm4lnXPzAgdsgYP+Ff5l47McZUxdWVduUW9Nz/AE/wuRLAZdGlQWiLctvB9nlS0+Rzb/Zs SRbWhYNtLcdRjtnP5Un9mAR2k29wd0gRCeZGXGzdnnGcdOoNdGX49VYujJWOrC4GNafJOWv5H8mL 6lOsqT3WWuFaKe4EnCTjGH3AdSwC4PfArRF0Zf3xkZlkme0jh8vaboMQWDqOBtz+Z9a/1xoypOm6 sVvuf5MrF5lLFulCXuo17e+NqkMaTO2UHnPJ8okKKdhc54K44xwTj1rUl1y7VIJY3MUL2n20RSJg 3IVf3jgc4GTz6EnpSo0YRUp09Uy8bjfYVlTb1HLqry+Tay3Cl57O3kkkDZSOVsscHqBjaPrketaP 2XzUgd599tHI52+cA8m5cHkc44Hb+dcdLDKpUnFvRG2J+tY/Cc1Iz7aAW9tGN0q3n2hhErxMFljU csM8kfyI4qnewm1ubu782RT5RimlZSm6DDb1xnGeecDn8K9C9PC0bHh+2UMRCnPZ9TFRxDPBbMj7 WxJahjsEgKEqwPPI4wDR9suTBp1uQ7tbwwC7nkAAupdzNt788L04461y0KCnetUV7nv1qPPS9lSZ RkvFmvCkxMgEwmzGdpjQKR5fTOSc8j3rmrp5gJTEDLKzjVLRgozMkbYKgMcY5Od3T61dacaMFQpr Vnjcsm/Zx1sYyalPoOp22txzy2V3pOqQazFLbnP2fy5FaNVPUBTnk5J3HPSv6/P2LPiTF4w+Gnhn Wb2SJrq60BNRu7aKQbHnML52v0BOfcHFY5DJYLiSMIbSv/kexxJiI1+D5U2nzJfjZn3RDAEmisnw 1yQ8Fmvm4VCoMiqw78Hrx7U2zmLsJnQTRu25EDcTM3LbehAz2xzj8/37EyjeNJP3T+YcLKNWnKUp JW+Q8YiiuGQGWaK4EL7sFmTPBA98nGORiu88N6KJ7maaaBTDbTxmKR3z5kZjhbqO2SeB6+1fnHit jJZfw5KHN+R+vfR/yx8QcaqrbSDfp0Kmsfa9Me6mghNxbwQl5BuG+3CAMQqn5e33vbFcZd3kN2bf ewhuZYfLgmZ8u3O4lQM9eBj0HtX8B1ZPGTq1qD17f1+R/pzj6lRJYKktV/mSaRPPLdy/aYklxNGV EbYFwu1VKbuQG3YO4+1dhb3F2U8i58xlu5vnZpCXAQ4Ix3BB/T3ryMLg1GrLEVfiZ7mBoVKuW8tn fsSXt3HFez2TbyHjluDlMRhUXGFPr39cg15JeTlrqYSiIXdwZFguI3ydq/MBjoSR2x39q9XBwhd0 8Q7vp0PksVSlTxji3tf9CzcWlxJbROjAX1tBFeR23lZGSdwBI4Pf8q9U8DwSX1/aRyJKWeYMN8pL 2ynnaT3PPTpn6Vti8F7OtGFbqznw2I9piZ0ktEn+R9uadHFdounWUKTN/Z4t3tpWJSfY7RlT3Awf TucV6f4o0CJ/BEumC08s3cQlBhO4QmNJAFGTyA3GMZyPfFf0X4cQlg8RSitl/X+Z/NvirUw+JpYq k9nf9T8+p7aRZpIS+fLgcohtjCEdCUlGDjbnrz6HFRW8r3EE5hQxwSAssbn5LmLhcBu/1r+vcEoy pe0Tu2fwBm+X0pyfsnt0L8wNqJpZLbEBk3sWuMkBQq5OM54OB9KVo1xDBLFFBMoIdEIdnU4CcehH PbFXUxE4Ne1jZHiYXC08LRc6i+W5EInEdx5Ns91JENxi+/nDDgBjjJBHXH9a0DBCZDGYXjilk2Qm eTnYeRn1wSc56VvRrwk+aOqR6SqVvZtUVv0IktnKyPtdMZ8/zHBeQj5doOcgjHJ96e9uZ23kBpIk MHmI/wA2OCMduPfrzWkGpz97RHj06sXWVKb96/fzHK1rdMjvZWT3FnulEpc7ljIzvJzgbhk49jVn y9sUTKksgSaJ40ViTIrc49eh/ACldRk+qPaxNGlTiqVRpt9CTZ84aZELg+RCHXaYQMkADPTryafs YeXGcu8kgQrDhgWYYD/Xpx07U6lSrUtzdDxqOFk68pyjZrbt/VyRI5rtYLNIPL8uVrhLu6ugro27 G1R7kHGc0ieaySN9nfzkm8qXdKdo4zywz1Gcmi7lZRRlQ/tKtiHVqO9i3bpyzeX+5ZgJHDnMBbLA hfvcc+opmxoUSVmdleQsFU42k5G4dh8uOldmGw0uWU3ozXF4yKlGFSFkTxxRrK2bZhIFCSTSTkyX EQH8J/hPzDnmnmRiJpXjUAyLOE37hu27RtHbgZ5/u5reEcTC15XOmlheejPGJ2tsSJCXRUlim+1X KraSP55YB9+5eDwM9O1RnL2MkltaxtHZlnEKuN7kOFaNQxAOGOcnjvXY5uUtTjWXwzCosbXf9MDa vYyfZLi2aHUEuPP+ymUInzFicjnsQe2DUskzJbqkg8+3Fs0KO/zPO+PmyOw9D2FTLR7niYqDwmYS oYeXu9/u+4ld1f5UImSWAQiZGUjyiM7Se/PGaW1Jhht4wEEVpHJGiqSRAI+SM98578/Wt+WMaClF 6v8A4J6069CVCnh73Yjx3RBMKCdpYBNbW/mmOOdwcncwBwMfypfI8z7SIoGbEyWc4WQbdqqWQK38 QGT061nDExouWHtqzeeWRqYlYqlLuWSDuiLRoxhPm+RKSFYAZ2kdR0BzVyTdG9xOAhLssNxbrdBz K7crjPQY6/SuiODq8nOl8jzcZiKWCrNVF8y1Gd1usygszuysZJB8ibSXAz2/+tU0YCeXCfmWOIvl d3PG44PbI4/OumgsVFpT0R8licXRq5g4VF/WpKxcq0gkUmWQ3O15MMpI4znB4AGPpVgRZZourXED O0cjkBtoBfaemTnHXjtXdtqdtTFUoKnHBw5u46FGt7ht5VQ9oVSeXCkoMcEdznGDjt9aFQ23kxTO MC75BfmPcvyZ74yTx9K2VT6s3Ck73NK91XeKvZMux71SDKFnR5LeGT5R5rMM8nqQR6jint5ipIWj AaO1klEYAA8zjgY4OemexqY0qrm5LdExxksOvZXumt/vJIY2UyRN5ciyTxGVUJQhSACCSeoPcY6U SRSERoFQIkb2pkmlB3ruzg/TBGfTFd0sRKMeZxuujOOvltq31uErQf8ASJhCZftSz2pMLRFbYCZV a7VTypGeMjIG7kgA06AeapaeHZEEAL7tu7JzgDPTp7fnTwTfsdTkp4tKtLDJ+7f/AIc1/PEnm+b8 6+eIY5edqZ4Bx2/xAq7vZgx8p4Q8n7tncBgchcn1yO1LGSvR1ZtisXGVeGGwmsS2Y3juCzRPFMwQ xJNMMfLwWUdMEZPqfwq6ksr7ZEgQ3duiww8hAULck8YI2n69KwdGtKnGULLzKzOrVxVKNGMUmvx/ 4cuRRgLMnlbUdyEdnOZgeXBPJOCMjpgURpjyxDG32fzCQVGN4PzMQOgPrx/OuzD4iNKg4RrKV+t1 pvp2ZhQw9b23tvYOM+1nZ9W9XdW+fqKN3lrGkSHYrLEWmK+SJGySemBnAA+tXTbqpTajKbhSkiMx xjOcbScfj3zXgYyboz+oRneN9dLO/wDXY+nwGHjjY/W/Z2bWlno++l/zOigjmN1HDFEwmubxLeLc +0HIYrjd67SCO3fNXkZpbZ5RBLGhkMExuIiGDbsFQDgnB9Ox4NaycY6XOqlKpSrLCSWi/wCHJInM VrFHJbNYizMsBhNwGWTBAjOB93k9/WtBhMs00SxKwCsroCuwKnUhj/tEDjrXP9boxaTehnj8PLE1 4OKs1/maUomkljIi3m3J8uSMgbI+N5B4wSc81YJybh03RwptJcNlJB2x69+cdq3q4lJe0ex4+Z4W VOrz1pWZK0UuyAz2qf6bK81tHZ3W/B4OWUcr7Buua3TbXMcjoVRVhRJLh0uFDSSAAKFXqSR1x0P6 TrPlldoxhb2kKcnzKxZjkd2lkaB7pbpDFKkLcjAI+7n1/lUbNFuS4lUmHz1ggm2gKu0cDHXhu56m hyVNNSbd7dG0vuX5nqVcLCvTlSoWSXna/wB7/IZLAXuo5I3kg8mYyuuAd6lSOfYEkn6VK1qDEF3S mcop3K43Ieg5HT1+gq20vd/z/Pb8T5+GExWEbjWfudrq/wB2/wDXQdAZWSFfKxJJCDMyybkdwNv5 k+laEE8okEf2aSRDHvZnYeWpH3sHOdw+lcecywlXBJ1v4i216eh9bkFLFRx/s8Mn7NrXtfpr/wAE svKYkRVYsUZzK/lZLhsYOO+cc+n41aTz0EMZhLp80jv5gJLEg9+e5/KvjUn0Pup4KrBX3L1q0plj jWNS0s21j5wVreMfeIOcZ4/XFX4Hja3jiaG3Vo2PkhM4OCdvy9RjA5pu8pOT3OarhaUqSnPf/hzW Iby7eQxiAOSPODk7sZyfqDxxVqMKBLOhMgL7XZ4/9YDztxkgEnuK9ah7mHTmeA0pVWqXyJEs3Iia OCKJij3FlO7gs6bSGJ9PmBGBycD2q6nmh4ohb+TuBmmnhb5ZZONgI9SCcHtiuSpPDSppym5R6WXN 89E3p5M9VYip7ZUYw5ZLe75XbqtWlr5oMiQf6sx7QrbS/wCGMjrV6N1LF3t4rgSNseCSUjEY6nI/ rXy2fUq0YYe7bSjq2mtfO+z8mfVcOzUp4hwtHXRJrt0to16F+OFVkkRMqSqg4cMGKqcDg9eavgrH g+QyxOwmTe/Ke3164HWvnEtLXPoqrcpc0uo6IeTG0zoplULbo24HcmSx56cdB3yT61c8uNbicxoy +XDHJKEJP+s5/HkDHpzXdhly0pcr1M5aastpkPFwmSzRiTAPXGfyz+NNRm4ZISY1YJMSwOec/lkY /wAazhiJwk+bUacb3NCVkRsG2VXAkLxF/wDUbuvPrnH+TQwYlJWzgxxyyOOsrAcAe/QfliicpVoy nKVkh0Vz1YxavqtO/wA+hcYMpuVCNHdW7pExJypOeRn23Zz+FTQRfaSEz5eGC+btJC4JyMe/NfnG Ln7TEznz813va1/O3Q/bsBT9jg6dL2fJZfDe9vK/UsRhxGUERUuZJY0MmQwxhQT2B4NW4wIyd0gK uQ6Y4DN3J+vHHtXOdhJlnEbFQChMeAei5P5jvSgkK6rhMrsVs9uO34UATK6FgYkIYlWTHIA7c96n gJX5guSWKBiep4+X/wCvQBawNspVWczICrrxnOccew/nU0b7wCchX+Yeg7Y/OgCRT94kNjPGelO7 4PIPHXrQBGNuWXJ3HLsTz1OT+uafuCnK/wB0r+fFAEyKZDlV3Lnbw3G7Hr9eamRkyxYbXP8ArXPP ldunfJ/nQAqbvMXeBtWU7yO7DjOPxFSxsUALIQrOpUF8kk5G4/hQA9ZsuU2klHZjhuw/n/8AWqZM jO5SCxIGPTqM0AShQpU4UELtBx0HpTiRkH060ANw2Dk8jjpTSfQ55z070ALnB+92xnFBcKpd3Cog 3OzcBQOeTQD01Z/Gx/wcaf8ABSO58FeD9G+AHwu1Rm8cfFC8FlY/YdVSM6JpAktRd3m1lZWKiTOO Dkg+tfxAxta6bDp9vYhrYxH7WWkA87UZ1QRSvIVADOcd+DjpXuY3mw+XUKSjbmV+2zPzXGSq1s1r VMO7tNq67WPQPC+qQwXlq6I7CG/N7BIzY8klNu0hT1fGCR2/GvaIPHlo0djZmWWfTJYy90H6TK6g Y2+3I47GvzfMqdXCVHiGtkfo/AtWpSpSpTnvpb5H0F8DvhnrXxA8R6deyae0On2ESx28QlxJGrzw gjtgeW3TPGefU/sv4M8B23hjR7Kxitkgk8qG3EKR58oBI1UgdSXIyf8Aer+C/HXjeec5rPBudlF6 fn/wT+8/AfgPD4bDPMqKu5Wd/lbc697RGuzEIP3T4ywBCWpwQy54JI5xxxnFNSwkjhDzpm92mV44 hjejE7OvP3f1FfimDxVKFOEa2p/TuMoe79Ub0W/ruRw6Mt+fLkRreKQmdgv3piwHJfqMgcn1Nad7 HbaPYrq115UNtYH7SsFwyHbEFbc2M5JGAOnftX0+UYBZjjXTpr3df66nPlWV0513Ja+fyP46b6WN N8FxH/pcE8ERkA+TaduwFhwT6HPoKqR/aLW8nZAJzKrtDI0u0rJG2Tj/AGju47HFf6uONb20v5X/ AJH+N9JOOHVSivef+Zux3zODKwIiVso7HJuHAyGx2555q0s0sTC1LwpHK4+1BY8fYxJklS3ozLkj OMV14arCGHlh476E5go0cPGvV1Y77bDcXSTOwtZLi8S3xFCStsjIQzLjgBTt45yGp9pezW32Zkkl uEnAUKihf3g3I+0noOevvQ3GFT2bRnHFTeEj7D+uxdfXIpxZM0rSQRQjzElJYQsCRhGHJyAefWsi 51d5zcTSOsCCTdGivlbaPaAsZJ5xwOTnp1rlxk+SyZnhoxqNQrRv+ljm4724ilEs0xkuPMuIljkP 7tFkAByvTGPu4qxe6hcIkVoY2e6ukktrMxuMo2BlwOmAp4z159KqhB03+8duyO6OI/2lUYLQy/tb 2ksQDMEmjZYFdM9jkH3569hWc80wklKvIiyRLYtcRJl1CY3IB6NwSR/d60scnOMVFe9/X/AMqdSn QrTU11M+dIjAIJWLnYRGBIUJUnDbgOuVPGeBxX72/wDBLD4tHVvBuqeGZ5Y2vPDupLpkC+bgxKFO 3g8j5cAHn07V5lHExo51SdZWl/wTvxkPrmSV6KV4v/Jn9AyyW8iG8hRvKeFY2V02m2Ib6+vBx1yP pU24sEWOOFvMUSpIOGLHIGT6Efyr9/oVNadSotD+V8XlHPSrUYz5f+GZJIjG5ht1SNCr+SPmDInI wu4ep4/H2r1DT5GsfDWjXsEUxjuik5AGZQWES8qvIwTu5Hc+ma/nv6QWZ/V8sSoyvf8AzP7B+iRk Kw7nOr8S6/IyLPUbKSG7SR1lvJHlW+t1u12BQoC4boDlc4/CvNLya3spdTuEsQouJXNtC+QVnyNu wE+m488Y7V/FmExFOnhZYmT1f9dD+8akKGHxUab69/66HaeDvC8t5p015YwyRQpaPJK15fCJA0hD FwxPLZywWuzWwub9YpoJI11PSYR/pVyVX7TtHzHB4+YZ9T0xXlUM0qYrGOnS7n11V0sJRlOK0Rw2 seU0fys9nJYrKkZk581myck9uwBPrXl9lbTS3KJeRebbiC5N08D4+yqcFQByWJBySP7vvX22JhSo 4elOD952vqfkuNU8XjfrMNDfg2o9tbyhlSaQyyXSbt8/OABjknABx717L4F0LVra+tdbidopLa7a awlUYMBAOQccY2/rXoU5ueJjSpnNXjh5zaTtI+ovDFxLP4kTW3AW48uQ+bbucDcd67u3B5ye5r3q a9XW76e0niCfZ2UMsc/nJMxbJPmLwfXI7tX7hwbi403CSla1kfhPHuUUFOUb3un/AMN/Vj5I+Nfh i28OeKmvIrBLW3vIpJoLSO8Z4z85BXJONx57ZODXjQiWW3EckaJNBKZXEUpGyMgYCjPRe9f15gcb ReWUquHd3Y/gXiilLCZ/iKLjpd2LhRGDJAZzHKBJIHjGFDAszKOwPH50qpJcWl5E+THcWAimP3XU 4ztDdjkKPwqlUqYqoqcmcdbC4fCYB1qrvIs+QsyiAxxbzbW5nuIHK+ZKhwASTjJGAT7U2JSZEXyT MN3lS5JRUDKxUg45PB/KvUoyw9Gp7Ba7nkZLWWMU68nptbsWbS1QIsW3zWNx51szDJAHznHPXAPJ 7CpXCSXMV5Htd2Z3hMqHCIRg5Hcgk/n7VNSF6c4w3ZhhqKwmJq1catN0Vysb+ZHJlI3i8qSJpvll 2rjBPXnI+mKuxwQ+XLEGliRIzBDIJCXjcYyDzwMgCssOpqHsqkQg6FerLGVYvrb+vUsQlZYnW5gb PnImHl4CqeuB1GPpSQGNWlkEJbaAY442KsGJIUhOVA7nNb06UYy9nTRhh8UpyqU8UrLp93+f9bD0 jkZIJUQQOSxdZHLAx87nz7ckAVIimR/MlWNQG86XL87RkdOAd2QfXpxXbGnUoTVSa0NJ1aOGouhB 2e/5jliHnedCoXzbbYlwH2sCMAhvXqRjpUkEKXCEGN7dbMm3t4ZGDIyg4+7789f511Ua0pqTepz1 MZRqYflqx1RLErpc3cU4PlyR/Z8oOIwh3BVPbfwPw7U6KAwTNcNCUluZPKntsE/Z3YZCkZ5x/erq 8zz8PjHKU439z/gMlkSWBmmUM8cihFMrBVnVWPKnpgn6dKc0aRqsrxhpUgNzIuTvuwGBCqAdueR1 9Kubu24orBY6qlKlTVof5FeW0aNDJc2a3U21ZpINwJMxwNxYHgDIPWnBWjnl3r87qjMzyEhFwfu8 dO596XJUjBc8TeKw+Yy5qOy7of5iyNGESNWx5qTTDyxFCclu3L8D3yRViIOsbsIy37k+fHnHmK2c DnnoBz7V6dKVGlQ54PU48dl0VQ5YTs/xI4hECLiHb5iwiaSWO4LJEvACjsF9+5qbzFVlBtUmX7Qo jHmMmEO4fIMdQOcVHs8JWj7WWj9TycJUxUYqEZ+9+mv9f5k0AQoJCHJ3OYkYkeZuByPcgCrFvHCc SzQ8OihnJB8wccEjpgd61WGcJKVOWx2Sw8Z1FHESblv+JfRjKyFIVnbUJ9jSNOVFuQpO4c9sAYwP 50qQy7F8xMTGZSrsR5SyEEK2B6jjFHtqksQqa2OPHfUKCd4Xf9dyWNUJjvWQl5CZ7lHkyLZ8BB16 Dp1xz2q4ERmXarPFHEscOZiSS3DEjHsfpXS+aSfJueZTr4VU/aRVum2v9f5EbRRCaVhZRTxCQXMb mcsYwF9eo4Iq2qxzAmS3jALZRVwSAR1B65PvWuFcVBrEK7OqrhaNaEK/Pv0/4csW4LSRTEM091G6 RuZNpiCnJyTwMdM1O4kiUJJHIkN2jLE6jkKOW2np6898VKnUV9dzixcI0ZKjCN1/kSBLVrhp5Iwi TwFmf/lo23A2jsOx/OniJyltNKTIftchSR48eUwOApHbI7j0rsUvq9LkqRvcwxdWrVwyU1aI2ZI4 S0n2eUPK4Fw2RujYcE57c/hVhLe6ml+zkLjzzPArShBIWX7uf4QCM596cKkajjRStE8TCUZqo8Sp e7/X9bmkZZI4ZQtnFLcLiREjmIBYELhWHBHX61eaePIIeS6kA22DOAnkHdlgV7jkgfnXRi401R99 nVha9OD9rCNrf1uSyWxWSF5IoTGEEEkJuRmKQggODnjB7D6VfDPaqx8tLlcOLrymBBQrg7QCTj6V pB0/YLXSx6dHGQxuN9pFbFqCIxpEsskZNqka28ZB3KmCSp9Scjk88UkiBUyARLGREkSkkurAsM+w 9O+RXNTnWpxdaDbS2Xl3va7t6nNjJVKuKlBxte+qv91k7K/exoJAyvLFIgLRWqTXEguFXZ83Ht6D 15p8cRkASaKJSs4LFZCNoU7iMk814OY4l1cV7ZVVNejX9fez6nJYPB4BU50nB9btP8f+AjrLSwna WW2hspLt1lkLR2sm/YxJKMh6AFsGltGV3kaOC4mNxLGPs63O42ciDaQQeD8w6r+tLE4f2n71vZG+ YzpOsqtHRvcvujpFNb7W3S25+0BH3LG3mK+3vx39sVdDuq3TfZI+GyyyNtCuzDHrwcZziowk4zXL KOqPNhWr0q6rVn7pppCqXCBYBseaOZoYCqlCPm4YdRk/lThZTG23ravi2vDBPLJdExruYkNkZ57g dK9Bpt8yWgs0qU5PneqZahfakk6RMr/aDL5ka8ycdW/Dv24xWrFBK8iKsCA25Fy6ifLxIyn5hnJ5 Na0YU237V2PKj7mHk4PUv26R+cGmhjkhdCqRi4I3lVIDYGOeckexp1jDM0KqqgLGBHIhdTkA7lKq ecnvgnArjlTaUpVZtq62vdfdqNVsTVlSpYGmuaKd22mn8nsNMcsjxvKiK8kQhliR+Ac5HzEDjr+d NSFZVuRcbyFgXzpEuPLPyNuBP+e1c+LxKp2jF217O33n0jwU8Tg4VKqUpr+9G+m+l/0JIY1Xc5hU SpIxjUsCQMfKAfXnr71YWyhG2GCBpI5YhcBhKWMhJ5UenI7dfwrzM0xGOpyjSlJW8tL+v/Dnp8Pr LcVetyO672dnb01+aLaxeclwNolItludjPsVSwwoJHTkHP61qqjzKiyJHuuM26SwsR5gX5sEZ4GO /fmvB95q1j6eeJnfR6IktoLQyvJBDDvuELjyZdjqpBDLg9sgdea1gkcbv5NvIgWGJYGdsrHwQcd+ oBOfWur6rNUPaR3OT69HE80paIvQxLHHMHKGGUYGDu3SHqcEdAMc1ckZyUgFoqxRlXka3vDuOMYz 0wTj3xnmu6g5+yjGR4tSKjN8mxcGZH8uYRklDHFFHJ/q09APTOadYx+YbXz4mmjhkaFfJucNKRlQ M4I6cH049a83GxxFBOpSqqD7u1vTU7sv+rOahVw7qd0r39dOxImdsKOQhmWQkMOS4dtgUDvt6/Q1 dBlRY08pfNlZifKYfuQOCAe2RgV8jjpSxNaP16utE9U1JN+Sila/mfeZTUhgaE/qVB6taO8WvVyb vbyNBACFCxK2/wDeNsfBY9scc8+/NTShpovIiiluJpgrwtuwqSA5LNngAY6+3evGjG6PonUocjqR jdmjGgQTswXyVxPIVYcFuT0zg56U22MwURrGGO1lgZX2iXJO0H0z3/8Ar1vGTg+eJwytJ7FtHkcl eY5XttqTSHKwuuMEAfl70+PMmxYwygRmOVDzvYcjjHP17Um1NuYnFpIshQ7hss4IUNu/hJPTPXHH WrUA8xxLJudFkaGWENgjtwfUYByKVajVdDmpytf+u6NcPUpU6qnXg5JdE7fmn91iVS3kKjxkmOME ytlnnGT8pHcgd++farkcZ3rneqXE2wYb7q45/AY5PvXyWaUJYSKoVJ8zfXljr58ybl95+oZFiaWO /wBow1NRitLKc2l5crio/cPeBpUhaWNUeJ2ntnD4Vd3y7fTn0P8A9etEeZ50hCmRRGTCg4zx39// AK9eIfTDlPG8KSEOxPn+8SuR7evX096mSNgA5Td5rlAd2Nz4H6cigCRUIVicNmIMAP4fmAqdovMy 6jERZURx1yMD8uf5UAP8sMw3fLFEhbGcl9nT+dXDGrMjFAcMDnunp9aAIxGNkyOu8XW5JgT0Q9qV ZM7M7clFc8cruIGPocfpQBKckBypL4wQW6Z6/Ujr+FOb7rry4cEEKPvCgBwKjOFxknBzy3GB+VLv 42j0K5Jznof50ASAsEfgnKiNSMYUdT+NWEAOxQAiRKJ1JOS69c9OME9PegCVI8okrgcHzi+TnPU8 fSrqgZJAI53YHegBMc4J4PJ+tOHJ+9nHB4oAD82CD344pmec4xu6H0oAD8zDBz+HSvgf/goB+0fH 8BPgj4o1i0vLaxvYrB2a+uW2i22GJjg9vlfPI5yMd67MvpOtjIRXR3+48/NK6oYKbfXT79PM/wAo L4v/ABS8b/tB/F7x98c/iDq1/qup+JtQuYfD8GpuJv7L06MRL5cRMaMm5ofugZyCcnOa8+gtNX1w sltErSm/RQCykKmOy9sZxnOBxXv55i6davOSjZdF2PksLbL6EKad57M1ntDYwJbxy7mkmkimhBw0 KgDY5HryR+NerfDrSxfyCHUSq5ljLPHIGeM4VSF7jG3rjA4PNfknGE3PL6lOk9Wn+v8Amfc8Owqx xVJ4xe7dO5+3/wCzv4j8I6ZpcWmWGli4kunjs5NSmlyJgqQo8vAzgkHjjqSOK+8NPvba6jiNpMbp bcRGKQgnzFAA+o2np359q/zM8QslxGDzOvicRG6uz/UPwbzzLlkdLD0GttPxOh0/TbmSGO7mtneG 5mlabzWJVs/MCCe4HpWXLCtz5ZKyMIVlVrgL12kgYHQBCfqc18NhrYrDOrT06/mfsmIw/NDkrLcm t7S1ijaV5Fjij0sJszj7SygZVDxjIyeTxX5a/t0ftSL4b0HWLHwzqCwawNKmsrOGIhnhIFzEzhcZ J8yIkg9fKI/iFf0B4IZFLOMTODV0r6s8bifMsDwZw+sbXlZNr87H4TWlu9zG7GWSN47cySowyFO7 aUA454BOMYBBol04xvbROF854/PkttvzabgklSejZ65/2q/0XrqVOSqR6b/8Mf424OE6LdOotBzW 8k80LrumjuAs0xbCkMc98dMDBwDj8aZBbObZ5ZYZBcI2ZVYA4jB6so6k5HTuB61NXE8lNSpq9zWp 7Ku5YeSLbwSQmcIYWigVCrmbCIJGA2r6tnbz2qyunIgFmyfZ0WVDbGNsgbG+b6DOTjv0rrpyuk5I 6sFhMNOhKKloimLZbS42rEEIl2Wj7/8AWsTgBV6AEknn1rPuLYGO7WSJd5MNqmU2C1J43MP9hdwH X2q3Rf8AFjG6/I8DERxOFlz01fX8ylfW7RGRSrLI7ifJG7zvlAU49SMfnUX2eNJEilkjKWyLlAhH nc4BHfHzZx6DtmsYq6U6isz0JONLCPmVpMhlto51IlCl2lWKKV3GGGSvH5d+e1Z95HtA2xSSt5jQ rnPzSKuADjoOfocetTVqqjHnmeJUqTeJWHjqijGhjDo/lg3SNZtLJyEjK889vu9a+0P+CdvxI/4Q f47QWFyNll4o0e8sQ0lyBHJdIY1jCjP33U7lHHOfSvJxdOnOvQxcO6/NH2OQ8nLXy+v2f5H9dXhC +Op+HdM8sRQwhEEkbPmdRE8kp3IOSSfT0rrXuZoftM86pO1xPG6S2t0rvIsnzKx/u4JwVHvX71ha s6+X05x2S/zP5bzii8Jn1enfS/6f13NGzgNzci0e1WedrmNorgn/AFEjOBt568so/I13VjI+jaxH aRne81ukTW0jEmWfy4wVVW99zD6EV/Jf0i8Q506eGw710v8Afqf3H9E/LK08JWzLEaR6fd/wDD1u 1stK2R2NvDm4JVoxGAstxl8Nz91uvHrXmhzqBsYlt2vvImkmIfORPtyd5PJAXGcdOMV/MFfDU6OC hTauz+slmlLHZi404fC7fqekaHZ6jCLeG6sXv9ElZGu7lLrypDINpWNYurYHcHgAZzXR6lqtpLZX dxEC7xXr7InBcwD5gudv+cD358zKcK1jopxsmfU5vjKX9nx5nZ/8OeS+J729uLGW1ExmlE0d1AvA iNuGBZlH3skkd+O9VdMD2llcXDpL56lVkQEFrskHJXPbrnHTHvX12Pozq4yEKXQ+NeHWGwDx1V7m /wCG7Y3ut2g+Y2sE0sUcpbLXG9k24A9M4PPf2r7CfQ20DRIBtiIlvIkDwXSFU80OqgkHqCK9jIKV OeZVefaNzxsbGnDKo4iejlb/ACOr8FWzaToVrNdRsLZJJIWcPh7skFvn9Mn1HOK9T8BOt5K05DxT zy/vIkPFsoG4A44GeuR/Wv0zh2Tw2IjzdWfi3FOFqOc405XWvy3Mz9pHRhqWkhvso83KajI1s482 DyyWODnB3YBIP04r4jin3280ksUSq9s8Cs4bcjMRuVvbjp2r+vOGqtLE4CFKi/eR/DfiXhp0879t OO9y5cI8Mkh8hDaCVJkQ3O0JwFC8EnIBNATCyLM0qrbyf2pxLt87PyhVx245HHU19YqfI40Evmj8 2r4x1ILD1ti3PHLFB5bwkLdyC4kaTIIPBDKPQDg/h1qSS2WeISIXHmO0cciSEeWinBwBxggjgjPN dUKFFydWb1+ZwUa0cE3HCu7er1LCRMyuWKxrHIq7S4UspGMrzkc4Hr1NV0gWFeYnhigUzPGjYDxk EcnPPNUqai3JPc9GliFmOHnLEq3Lt+ZZ2iA2zLbeXE8BeTf8zoG6Lj2IzmmovAH2dLl3kN3suLl0 8jB+aQEckHgbTx19K2q4euqbhJWXkcNLFUp+5axfCTSebIojkBGzezYLggllboMDOM1PDvMbvBOL fzFy0PmkmQKM5BPGOMY75NZQpzteOqRw4iOFq4xyU/dX9IZJAY4YWVGeaSJmtyhy0agZYFehVmOD 6YqzNatE0MFxZlNsIltkklLhi2NzBvQH+Q+lenhcVeDVV7HHmVWDqU8RDoNt7do7hxu+2CIgrL5e 1GYjJDHqcEck+lTsSA00yK3K+Q28fMW4GD1+93qI4qMsSpJ+6dFOn9YUq0Vq9RZPOnCfu43by2+1 RTSlWgXcAGJ6ljg4GO1PWCOFkSJPMi8wvuQnl8ZQEHtnHT3r0tbannUKk6FOdGvG1iTapUeZGqLL CwlhUg7gxOTj2OPypfKkkCM6FtzGHBQZc7eEA/2uD+FTDmlJKHQ9PC1KSpVHV2ZCRD5+nwy2x+0F cTfY52XIz8oYnIGCRntxRHGXAEsbiUs8Q8x8ncTzk9x049x0rtdRujKNd6ny9LnWN9jhdI9RsiGY XAIhlSB1iOzkSEAEg98H/OatwW/nRTywwwwtOIxC63BDSAZbYwPA6dR681yxklFxlsz3sZh4qlzO V7X2Kht44Ybq8e08r7LD9ouISAA4ZwBk9FUHpketTpFJEyTXPmRS53yLJNtO1+ep7AdSOoq4Uqzf NA8qFd0qUoWLJtJIDIGO0RzDY6A5y3LMp7jGBjjrViN4hNLJ5biKFvORSpxHuJGzHYDjPrms587n yzYqWMrxlHt1NS3jZvsiyWrQI8cgfZMHAlQE+WehG4nr2AxTXtvMBi2uz4V9olA2EjIbPQ9Wx7Cv Yw8pSh7263M8YqFWc6kFoXhbRTW6QRRo00qBZZg27bhhgeh9e/arMMzkbJkWVSxMc5AQx4JGAB7n ODXTCpyRbR8/CMJTSk7Imit3WKeVoYmcpGVmllKsQgwzjnH3QBz1zUVv5jROwxGJ23RxxLv89c5L E/5xWbp1avu0XZ+h7McNCFKPtXaKe5caCVt5ESR2i3AELIcmLCgkMp6Djg87qf5QkuUMStMzwgSC J8KqZYME7ZP5iqoUas7xTuzPMsxwOGpKVOW+w+3j3WxRYY2IiZbeGVs+bgA8g8qMHnirHmO8T7IC LcwiGMl9zbsDnHYcda1qV1KlGnbYnCYHEVsPKeKfudCaZYlWF/INwkVsS0KXG37QVYADB/iH5H3p /lMkjLHEyyR3JeIPJl8cAZJ4JweO3Y16FCNOeHUGcOAVGg6lCpoiwpkzEwQulvLtaIup6kqQf89q d5ERnWQxpHDbq8LuSVSJM5Hzcn6D2qvYwlFQqu55eNrLCUOeMdNiwIXhcH7MXlNrMnllmXdCRzxz 3I7Z7VoW0bj7JNF5bWsFu0TQxx7drYJLZzn2HGamNKqqr5XaJWDxOEqYH60tL+X6af11L7QQFVkj gYC5KXcgM7BoowAgPU8ZPI/EVoLCqO3mKEjCjzWjlOAFB2Dd1xz+tcNeviKFN0pt83S2unXaK2Oj LnDFVljIx9xaO+mr205n+BaaC2lhENzHg+em+FSVbOdyjI5xgA4p8MMRuY0ltvtds5ZUSV9wJb5N zDAOV6n16V85VqTlK8p39T7/AAdfBxk6eIp8vorflY3RavO8boskjRb3icTFFKKvcA9uev1q6qND PBtxIsKrOlxCQd21SwAHTOSB611YVSt+8fus48Zi4YmPLCFi0YiIkMhYyeaJMhsBfl4Ax14bvWnb W21dsyfOVfzIg2Q+Ojg9BgE5H5V006FOnUbpv5Hh1I1oyi6jvBa/cacEXlpdM8EWReFI7w7t+zHR h1AOcAY7dulM2SQB0EEkEVu6xwjzAxEAwfM65wM9Dk9a6FpszidRYqvaTsjdUtFsle3WSOWVp47h 5wIiqDlcD5gTx2pv2QsTIw2zR3YSPbd7xbKvOQ3Gc5CnOfSk9xKusLWdKGt/0/4cvxGNZsRWssxl tjJdEy4ROuAo4wMkZwe1SpbwN5PmWsL3E0gWa9jYj5QMAEf3f5ZrnxtOrGkq9Gq/RRUn67o9vJ6l NVpe2hFyfeTjby0RJGhBcS/MCwkbam4N68HuOMfQe9NkgE8ZtJIGuBOm1meQLHIyjKKe+ScmvKxG NxFKgmpK/n8X3dPxPdp5Ng3i51pqVpXtb4flJ3b+5FkxJJC0EkPmG/tspvkK7yRtdcAdRxVizjS0 MLmz8wjy1it5nZVj42kKR7civFqYupW5oyS18lf79/xPQWBw1CChCbS85O33bfckXf3tmY7f7JLN I4MIaVwhtMfxMOCeuMe4NXYIziPbCruAUXecqCQR9fp6Y5rOndystTVUHRptwlqXbW2DJDHGoXyp DPIEcAIdoL4OOeRxn1q9CjboJSjbpGdVVlzjBJw2PXIwP5V1LEcnNF/KxNeajTVG2rNNo5baRRNG u5Bwgkw0fG7Hr396lKSt5MbwqERRuxODvHTOOuenTt9atc2KoWTs0ZU54alNxlK5aRpDulTOU8tZ fk2EHace2f8ACo7Msrp/oxu2jjkuPJbEZKqMke3AJrzcfWp1Mvmq1fkadm1q/RpNb+Z6mUYaaxl3 Q5k07J6L1Tae3kaBt3EAsowSQWuRIr7yVYbgd3Xjp+narqecJEZ4rYRsMJIH/eKSNzLtx3I6+1fA TVP2jVJ3Xmrfhd/mfexT9mm1r9/+X5IvkfdGw28v2dHw0gIZiM5z2zkfpXN+O/Hvgj4MfDPxJ8Yf ifdx6d4R8OxxR3P7yRjcytIsaRhYw0hJd1AwO9Tekpp1pWjfVnfgcLPFVo4alrKXTz2R+fA/4LAf AHQIdPOveF4AviVY7zTNNttCuftEMLKxR5S0bEZCkjPIzTNP/wCCunwd8QJGbPwFcaXpmrXzLotv qPnQ3ssqMoB2+Rwrs3GcZr7CGD4IXxZtf+vmvxPvZeG/GsnGgsGtdvyPozw3+2j4J1Hw3JdeIdMh 064EjiJ/IliOnkFmIYlFMnAGBwBk16JoP7Uvwo8SXUf9lRiQqSs0UWoMCZGJGAWAA2gE8da73wnl +Mo/WMsxsXHs2rv8v1Pnc44O4oySfJmGCdu62/W/4HrGneP/AANrNzDYW+r+cVA3SM6xogIJ5B9c HOehFdVa634auhd3FvrNpOIJomEctzsWfBKvj1wQOPQE18tmeSZzg4SpS92z3Vpfcu3mcOFjQocn 1qg5J9HeP4pO3obP2XdK0ivC1tLmdGhnWRQRnGDnkHHH0qQhozbgRFVuAzxuzcSIuQx9Dhsccda+ IznEYyNKnhKsrx/Pz209Ls+y4aweAdWri6NNxknazvp5J319Wky3BHgI7od9wGdjK3VeBgDvz1Pv VlTIh+YHlmORzwOg/wA+nvXzx9gPRcEgAKZCASv8JJ+9/jmlAYEfIRHtP73dkAjGB/P8qALasxK5 XIf5EDH/AFg6AZx29asxq6rGGXbsBAG8Auc5C/j/AEoAsbACqgZQP+7OfuLjGaNrncp3hGQxcP8A 6sdj6596AFCbs71AyWAGeoP+PWkUMrEIoDbVQnd1Utk9fp1oAeAPnOANxyCT97gDP+fSnHIAG3DA jJ/vA45/rQA0gAiQ8EHYOOmcD/CpkTIA2n5jwQ33ieg9u9ADkHz7dmAEZJzn7oHf88VZiUMwkERB wr7c/dOcZHt1P4UAX9pUSBQMuS4Hv70IOgAwFAXaB0I9+9ADuE5znPtQW6YOPXigBM9Oejc8daCe chsnGOlAGZq+qWeiaXearqMixWVnF5k7ucBRkAZ/EgfjX+e9/wAHEf7fmu/GT4j6b+zF4H1LUbLw /Fqia38Qde0nVSBaRW5t5Y7VkA/5a7XByT8q8g5r6XhqMIYqeLrL3Umvm0fM8SRqYmjTwdF2d1Lf pFn83/w8+HXi74jMunaZava6dBabLvWLyQLb6VDGpD5l4HG0DcPf1xXpV34e0bSzY+HfCEEtzquo ieK+1C0AxEERY2zJnAJPTPQHmvOzarGFL2slqeRg4SxOa88tFfQ8Z8RQW+l3Npb6h5barqiK0lqh +WEqmHiY+p2Zz2JPrWFp2vXOnzWlyt3KNupuBOZPlgwDu467gCB16GvicVRlioOE3uftGEoYatQj QqK0l+Z9rfBv42z6Td6Vi4k8wXxgk3XhiSS3AAEeDznAPbn2r9f/AIJfGOKaC2jN47qtvBMC9wAZ pAqK3y9dyhuex3DpX8n+MXB9qc50o6f1/X/AP3nwf4vjllX6pVlqmrI+yLPxDLrNtFbW1/NHEphS 1SSUlY2I4bHYHdjn1NdKmjqyzx3T7VgG6YqSjbvvlARyd2BwPev5Jhk8/rCwdGO3TU/v/JsdTzXB QxUloj5X/aU+L8ng7wvqMGmXEivY2dw7WnlACaR4pSWZiOAAnb+7jvX80vxn8U6n4r8aeIry8JWz ur43NihuTIbBvOkZVUkZK7WHPTOeuTX9xeBXDkMtwH1uUbSf+TP5T+krxFUxNCGT0allddbbNnC2 iXEUWy3/AH8jI4SO4l2KGbuT/eJ6+nHatVb0TQyPLGojSEDUG6ZLEKQGI56Acd+elf1dgcNKdSUq ruj/AD8rY6KilSW5FbyHGY0/1UpkhmztNymcFl74zgY9QfWneX5flSSoVjug8Ms4lGLSYBS6Ef73 PA+bpxTxFONGfInc8+ni1hajqVHe46O4laWxVIm8uELBCWGxrVQx2Fx1AJO4EZ/nUdvdPbzi5jt0 lW4YImHy0bOzbyy/xHOGB6DPXFZ+6mlIzhiHOEvZy5SvdREWlyYW2PaXn2TYZMOJjgM2D7E8Vnzt cSTySlN1vdmJY4mHzSyoCrEdwCM4HbHfmnSnWpuUovQ3liqNPBRhzXIt3mPDBbwnBZirSkAbCAVZ vc469OR+NG6WaSOPYkImjjMMnmrjpkp5nH8XHTpispRjNpy6HTOU8XScOX5r0IruaOCeMiJJI4kV FMwABGeRjp1PXnrVGZNr+QYyXW4eVIpWJ2ZAD5b+8vZe+KKtOE6qTV0jzMI54OhPmim+n3GY8UhE sszhYorgTXEaHaJY8BcY65yRwPWtPwR4guvCPjrwL4ltJCLbTvGEBnUH5mgV13Ow9D0wOevpz4+d 3jQi6T1TR7eQVXim6+IlZ2/pH9nn7Mni+DxV4K0m9WcTXN7Zm5trrzAeqyEBW9McZ+h96+i0iihg +ztaGKWO6YthsDcvXjsCDnB4P1r9j4Vm8VkEK9R2SX+Z+EeIVN0M/iqWspSXpujvvCFqY4ZvEE9v JHa2iE2cs052zSI0TqeO4XOD/tH0p+rQXOuzPqFuFuriO8W8uJidrQw7Q52NjJYHjOBmv4i8cMyn Vz14ak+v4X/A/wBK/ArJ6OW8B0Zw0k4pv8UcLqury6oL+4uMm1tZjLJFJJ9245VAWOGyoOT65x71 W0hL37DDd/ZhdX5i81/sigNeBio3HJwPl6jrz71+T5jVhLAppWa/4P8AwT9NySNKnjPrE1p18/6/ U9RsNSe0ma3uIzbQwqs8C78kErnC46EDJ9q4LxAsiX891orJcaRI0pvlhQgxSAjc+BzuHHHc4rPJ KdTEYeVeXT/gnq8RV44jEKlTRgXTyXNyk4Dt5VlFHAmwqGUHJcg9Ac5I5561aW3+0RTs4t1USpay RxTAguUbY35gnAHpXpYSriJYio0+/wCX/DHlZlBUsHF1X7vQ7PwRHLELEyQ3IfIK3E2AkikgMQp5 BPy/n+NfQ2u3Ev2CHSw0k0dtZ7b7T1XLkCVld1OedoPI9eQa+m4cp1nSqSg7u/6HyuYvD1aNJSfo j0mW4MHhjSL6ITNZ3MEXkTDMjO2fLUHvu7ZPrXd+Fi1hexJcqnlrGsBCDaDv5yezccd+lfd5epUa 9OUpar+v+AfnHENGFbC1Y0d7/wBfgep+J2XUfDl/Ktj9qiW3mt3jbBMMTA7F9cqQWPsPrX5v6vb2 6ahdW9ksnkWV1LGhX5VWUs2Mew5x9a/qbw1nOvh3XlsfxR4w4SpgK0ayjd7fiR7keOF1j3s0jKYw M5bdgcZw3c+1TpEEnulRTKyCJIo06wlSQxPsQelfrdGNOopVG9j8KxFWjTw79r8T/wAv6/reXcXk aJtocyOs8oOGyAMKMfxFcdM9fenxRpIY1lt2killEskcc+wOgyuSB90nHSoV90c+BwPsIKrOV2yw xWaE/ZgPJhizub7yg+h6knuabAHS4uVlgXzJYNsCST7hBkDaowf4sE4967MLQVRe0qbGtGvHAVJO pG9+na5M0iJGJclWkuQS7scRxkjAX+o9hVlWCLbLJG0dy0b+fFFJ5gBXOM9wcYJHuaanVnXalt17 HkvEQp4icqr0d7fqTAyTNcCZGQK25tsufNQgDK4PAwR19KsKttMriVohssVjKPAdoUZXc30J7dai nBLFWpPQjDYWnKMlCdkxkETIgIZwREkXlFsH5WwSOcjJ/LOOanl+0JvimtfswaPZNGtwZFi+YOCu eQOP1rpnhOZyqRfyHH2dDDvm6f8ABLMrlSJXhiEZkYojTfd2YIwM5ycjn61I4LzXSvZnynMcgdnJ ERAO9UXqO355rjw8PaVbdDrw1enSwSxtR6NETQZP2gRBFiVJJI1YkqFbu3fkgn1qxCiyyyu4EYj3 uuXJyXztyfwOPrzXsUMRWhWnFx0PCxX1jGR+s037t9tyxKjq3lnyrfeTETI5YyHAbcT0xn09avTy zjyxIiKiSi2VpLnnYe+MZDDkdahe1jV5lLQ1o4WrFqU9miGRCqLNcRyR+Uj7vMkx50ecL09Rk1Ui s3VCptTcH7RGbeZ7wKI4ySQEXOT2yOvSuyMZV5N1JfeYzqUcHjfZxYiIyxQyPC6R3aGSJhJs8nJY MCTzyQRj296tpHFFK5Fqs7h9qolwBsyAMsTyRwBgdzXRiIUYUYwe5z06uIWbOnJXg7le3EjG7jdY /wDSLbYwK48+I8lcHjOVGD+VT3YHnDahdoAsdyyIQHlZQ6qM9fqOK0lSqRw3JB/8MdVahSwuMcZ6 p/8ADFyNJTP5txDPCHCRP5remWCqBkHGOp9uasRxSK8kwQBo7jzyJrkbsg/xDvjIxis6k6f1dR6q xx1ZxpYr2EovW9v+HLn2V/PDra3lyRMFjlSUKkZAJJde+cj6cVM0aqAJLd7e6WQT/ZWx+5YMAFJ5 9M45/CuujGmoKdI5qtZxxPs7+69i4rI0gG3P7yQFMbTkHKgjoDy2R1IFOjjQJ5jBcyTFVAbhDjaG Y9u/HsaK0pU6TcNzzKfPQxnsq0bx6EqwpFHDIqRSGSR3cMTi/YL91c8YyBz7VajjlV4y2HSMS4mk bALkAALgds45roymXuOtVlqelm81UoLDJ2X+RYjtgywPJl5XUEmMkNOoGCw7AZ/lSzReSsUQaSLz czRMy7cRYyv65z35p1q0ed1Y6HkYbKqNT95J3S2TFkDNGpS2ie52kLCJcqyEbtxftnHTHYCrDpIZ 2WRDNHEwjUxzArMCo/h4PGenuK66MqVaPs6u57Ea/wC7nCtK0le1thzxPHsdlDJaMy5IHBfgZyM9 enarQtWY3l9IogjVoo1gdwTMwxuwOuO/SuqNKVHDS+Z4jp1MfOCbt8v+GHxZtwytCFkkkOzEmFVR yTzz7n6CkSFWDhgscjQpbq5GDcYJJbb2I4PHWssJCEKDqzev6F46NGk5UXro9/QtokjhJYowkkqN CX8777E7ZB3wcr39q0UWaRIOFWOO4aJUjT5WXIzj1Jzkn2Nbw9tK7qaI58PiMHVy9ezWsd1/WhYj ACXEwgleNGEKrnLABipwpOducfgKtfZoTtnVZnjWIb/LnKuSx4yfY9Rjp+nj5lmHJV9lRqW3vpfX 5/oztyHLquNf1qVL3bpq7tp30v8AK6NWNAJRFLFJI63BkYFsKWU8kHjuO/StKxhC3ku2IGS4tyi4 c/KsZLFgRxzk9PSvCVNyS9nqz63EYqnFyi43sa1vavM+yORjLLcjfAVA8slflbeTg46f/rp+wmNl lBfMSrNGIgTEwIzwO+MdDXZUjKrh4KmefhZ4fGc6noXLeEKiRyxRbJUlREjmLb3U53A9Rkd62YId kkGIIo0jtk8whiFXO/HB4YjHOK1wPNS5nNa6kVqlPEUfqmHfuos24ZtyzQMd1u0bqZtrM4OFc8Hr j/GrC2zPiba5228TOysnzZ+VsKeOPUda6UzkpywirexgveL4QG42/Yz5kWBudVIlJGRz7d/pTYY0 jMyQWiPEIRO8+SGVm4dQvQrnr9RUtStLX/gHEquGp45QqrvoaPkwgWKWtslpZwAAW8Bb5TgbSMk4 A5yM1ZaNyswjUrNIQsbO/BBHGF6142Kq4zCxhz1156Wb+Vn+h9Vg8JluK550KEn5p3S+d4/jdj1h jtSkR81F3rHKJkb9zu4GOpPPP51P/pPnNJFbRyxxxiOUPLta13DCspzhuM5rxcRinjKznX0XTr/k fR4HB/2fQVOn70urbevn1tYtNaxOXiEMLQRxFpEml2qycjb9M5+tWoosLFFGgiCRBCu4kIFGduPX A6n2rkS+0jevRjXXKWkhR05tt7MUlIYZIBHT0546CtBYJVkZ/JG5ZBbxtLMFEm0DeQecYB6H0oce WTUjSnSjSgoxZYRVidIkjhlgF9HNcJvMZkRBnGeoPT61eiRVuJl8rzUMkilYjtwrA4HPQg55610w hCHJJK77Hnyaw2Jcpa3JEtrR2WY+YZYrbyXnLbgqcKoY56ZwKvIFSQz+WAnku0apEDk44AGeckce lViqqjH2dBa/d/X9akU8Ph8RWnXrPlXe1/68xBGJIxH5u7LhJm8zHlk5OPcDoe36VJ+8IldR88ah wY+SUU9Pr/KuWpiKWHoynWbivNPfW210/k2jqwOW1MZjY0IWle70a2W+9mvmk/I0Ft1GJFVjayl5 PM83lUxhcYOeQT+VWokWS0VmDtDK/k7w53P2BP8AEO3Xp+FfAVKtSvNzqO7Z+n0MMsvisJQj7q2X 3l9NOaWb7DIkzymaMXHmSZcMWAA5yTnjGPSvwp/4K8ftBadrnxN+HH7JuhLbTaX4btG+Inji6sLn ctxdRf2dPbRyAAE/MeMnHA444+P4xzFYDKqjva6f47H1nBmX/wBp8RULraSf3NM/KD+xNN1v+zUm 0azl1UO1pZ272iMLW32ALxjhtzHp716r4a0fTJPHHh6XVtOt7xrGATSRQxhmtEUZQhsEgkrnjn6V /JVHMs1o1b1arsf6M01l9Wn9Zpx1hpsfSF7Bb6vHLc32x9iJegGLJuIpB8wIPXHBxSW2nT+c/wDZ GltZ2llYyQXdzpoQDUlPyFm4yjfMTke/Wvoct47zzAVL4fENJeZeYYDA4igq+JgnzLsd1o2o3Phi y1RdL1KaA37Rx7rqKN2n2IwKhipYAhu/Ixmuu8PfEfxJY28X2LVLiDRxcNJb2csCNHJOcl3IIBwC eOcda/S8n8dc/wAvaWLqc8W9T4PM+AuGc2peyxNBettT1vQv2sfiHp2q6TpNtbz65ZBTd3+pterH KFAkbYIhEASNq9D0bnmv15+D3xGtviH4ft3hkjvDDp73tvazucuCZCwGcYOBkg8/LX67Xz/LOLsg hnlCNnonaK3fnp2PxfjbgOlwbjKLyht05LZtpb+j1PapkRN3AfylypQ8EgU1EcfdOPLdWhJGfLAG OfY5I/CvlT5MnVeYtq5jjGx03/e54Oe3HFDtsR2KsISS6A5+THBwO4/CgC5IhO63MYJxHMAOoOAT 7dMc+tWvLDmKNc5LKV38ZIJ5+vWgB+VL5wCJ5GVQQRgDhsZ6jK1MMALnOQPyoAQ4wwxlSOp6YpjZ 8xBswFiIZ898/wD6qAJVDboyQPvhmUc5GecetKQUBwH+ST7xJyMnjj8DQA5YWZih+8rhGA7epqXy /wB2jbSqbGYfNzn1+nSgB6r88jOpBLgs27IjVvT/ACatbMxBCnAQAgPnbjHH1IoAsKgAZdoAc5YZ 4PrThwM+g5PrQAbhj73P0ppO4nJwPpQAnTOD7dOtAJJ64xk9KAPxu/4K+/tw6V+yv8B/EU2nyG68 QXVqbDT9PtZwX1O8cwmGMAAngtycYy3OK/zg9E8H6r44g174h/ETUb671H4kTN4p8Qac8u7zZ5lV ngDsokOxAkajP/LM4GDX1ODp08PlnK3rOz+66Phs3q18VjJPDP3oXj8vM7jStFuvE+gabe+I7yP4 b/CLTZRbS6XbaqI7zVIGBjYLEhDs2QOMlcEknivJPHnxj8H+FvDt34O+EeiWmkWVs91Hp2ryWgF3 vlVMuxGQMlAcDuSTya8jNqHtqaUJaIyymMnONSurSsfI95rNzeXsEzFnv7i4luLic/8ALX5QXZvQ Z/PI9MUkd6RbEBYZXLHzFZ8ESNgF8dN2MZPpXz2IhCUFWg/kfpVCtVp+7T3Z0Wia4+nXEM8E7vHb XXmoHTDjAIXOOnU8j6V9nfB3423tjqdmslxNCsLYs0ikDLC2Nrsx68rnjocfTH5/xflkc5oSw9Na n02V1amVV45hGWt/6/I/X34NfHG3uTYxRzQy315erJb5iMjSW6iIMCP4Wyxx/vYHSvsjX/ibpuja Lcvf3CrIlsZpgZQZCVVtrnGcEq2MY9ua/lOpwBPBZ3KvPv8A1qf3lwD4h4d8OWqVLO36M/Kv49eO tU1m5vzOE+xQM0UBMwIjly+FKH73y7Qfmx8ueua/HfxbfQan4g1jVbJGlinkCRhoiDGrSHcm08BV YAgjrgdq/qzgjB0cHlkYpan8neMHENXNs5lUw7cte5WuLAGSRY43Cq3mGCZigRc7VGc84JI47nmr LKWt4bT7NNFGl5JDNFcpvlSNSPLZzyOAW4AOcjPSv16NOdFObetj+bcJBVMRyTdor/hy3p1na3Mp ifYHjmb7KbmQq5IbaUcjle3J9Ks3/h+6sVnWJ5JIY7gmKOTGSGwCT2J3EYI6jmualLnm1UW3+V/U 9LEUsF7JVaUve7EEVooghFzHOr3KHzJFlwJGYbQFOBkBh+PSh7KeKYrOjveiWKO4jicKsCxqEYh+ nQZx3wAKTipu/XoRXwnsqUakHcoNapcPf3O8l1Ah87aSS5OUwvH93knp3qvdRSKxbLRSuwZvLmGR z820+h9P/r11unOhRbk9Wcca2Dcfqko6/wBdDI8keX56lTFKpjbdwQGJPzJjnGMY7HB9aWKEx+ZB cRt9pvP+JgZ5Qd11jKlmA6tjP5VwRgmtXqz0akoYfByVKV2QzxZL38hjurW3ga5W3t+BZk4UkenY j1rHkhCsip5wluc3exhxC3ck/wB7jOeuDVRVk4roedSjVr4VVai0/r+vmE9vCIyjNGpgdppZd/8A qyF3Ng9wWCn8fWuUvtMSa3xlYopQ0SkscwhvnYgH/a5xwea87MqMZYWbe+56uCnh6KpqXX/M/pT/ AOCXnxWn8RfCnw5pV/erLPoEEegaha3cuRPJDE21/wC8PMjIY+/vX7XtYfbdRtbTakkV4EH2lXyZ yXAjViSMBtyj/gNfWcNZjWo8HydN3sv0Z8FxvkVLNOKMPhaKs3JNO3mjrNWvUGn2WiafOLOGIwhY nJAZ1WN3BAPCkqeDzyB7Vys+tRvp9/Bpd3La3stilrqdpE+XtY3J2/LjnLL2PQV/E/FmY0sy4mq1 arulf9D/AEJ4QhU4a4RoYCoveaWv3nnqagWna3uosyLcITFbbS6l8ZbngnI6nnsM11ul6ppc+42y zWcs1pLZN5j7pJEA35I4A5GSD0r5ithXmE5RjHU+xyPG0Fl8njJanUalqGj3diJ55rK1vLJIjbxS zAvIPLw7DbkA/N0J6GuXfxDo1pHPZX19plnLZ2guFgW7GL9nfcW4JPA698ivay3JcXSpOjGFo9Ty cw4qy6g1Z6HFXvxE8DWtyry63aT+U7SxG1mYSI2VVsqQARt/h7cVp6f8QvAviTVJtM0fW9Mae2Mh v/tMixCJVxtUnJxIQwGD6j1rpq8N43CUp14OyZzR4ky7OpQw1OV0fQXgaK31C6S6tiyR2tokkbpJ vVof4SO35c/Ka9st9PXVNQuZQhhe9ElsxV8MmMsGOOBu5IA9RXfktCUKCot+8znzbC0cvxV+bRG5 a6dLZazY2VoBZW7Pu+w2x3I8u5TnHPPUnHGc16vFCgjgjCxEGSNmhcZOA7Ajb1PPzccgivoeVrGJ VH163/Q+VVKjiaFaor3fa3bz/I2tY1yC18Mz2Dq07yWlwgmhn2vdDLKeMZ7jgYJ/SvifUvCN1pLa dqE8S3OmzRrJq0jTN5ZOJCSOSQzMAMD+7mv6M4BzecMTTyqm9GtT+XvFfI4TyiriqsfeTMm3t1SK K1h2tFE3myOIyyRxAkpznOcZGfWpUg2RsPKb7O0Ei280spJYHCkE9dwHTPrX9BVY1I0uSitUfxPi p/voKtG79C5DawiVbqO2jnkRnjiZJNnlNsOCWPbp257UsGPNVns1ZnjlgglecgOx4PI6EEdfetIR qKK59z3qEITm3V0RKFjmktpPKSUuSZZxnCsnUAf3Qe9E8cv2UxywOFmRJC1uAfMZX5CkkH8fc0oV nVhZPQ8zH1IxmsXa/kWlgiJDPDmSWYqpL4+Un7+Ox6dOwpPIZPMY7EaK5jaF1lBVyCcZOf4hnOfS vQeGnTi6lGRyYypGpSVWUNLF23iVyqhd6BEWBxJhwMn7vHOMcZ7CpY1ikjhR5EMUzGyjlMmBMg65 x6nr2yc1NOkqcFU57S8zgwM/b1HThHTp/X4jooJZPsx+yAW1wStxeGcKAwYnAH0A/GpXt4Hhk3rN tSWOVIDcEmRzkHJ6EKDn8RiunC1HV5pP+vxOKpCSx7p1ZXX9WHsgSeK6eBJmWX7PEfMy8Py7sqTx 6cdvelEEki27rKftTSPKs0j58zf7gdVOfrW06UKP762tv6/I9LFU4YaSw0l7r2GN5OJQ8SSNbzPH IrjJTIBDEHrg56e1WNplQfIHcFklZRuZjnjd7kHilCspUfay0PF5Z5fifYUHdd+hox8xs3lNNG0u 1Y5QOU9/TnHHTFTo0kghMscUc81qVntw5ICDIAOec9D68e9XUqLEQTT+49ieIeKwTpRWqtoRyCKJ ZkkMLwTIdm+5d94xy2f4celVJYGdTDPDL+6tjYKZ1Uv0DKyY+7jGPxpSnGDXM9zlWAi4xnW3LE0R YxTvtVWUp5W/5FIwCo7Z9SOmanlSGRBNDYLbBXNqtwJvNdYwvzbicZwepAr1ZwoLDRmlex0xUXPm rJRXRld7VFdrowuIoyLOIrISUBUAgqDyMnPqM1oyohDw3FvDMzSiGZZromLOAFYgcZAxxnBwK6qN f28FJLY4MydGlWVdO67ixW86KkETG4DxJICG2gsfvDHTg4xVgWiXDxloh58UAdt7hRGrfeRAeD0G cmudUKNWpKVzwv7Sq4vMORx91aX/ABNCK0wZXhAdI4ofMiD/ACW3OCcHufl59aneMRxXCqjO0cZS SMEfMJGG7GepByfxrroxjRpOjBHbPD0PrMsRfRFoWoUwW26XaskjSyG5IHzAAYyfoPyqQ2ymWJbe CW3PlCJtkp+V1wpJ7EnmnSw0FW54Ruzyq1f6nQWNxDJoAqoV5jSKX5J5JAQrBgQcdevbFR+QE8t1 gVEni82CVSQFdnyXK9c7s8H1Nb1JxbcIRsOjjcPWqPF1ZrUsPGbmKOfySt2f3EIS7zFb4yJG5+6c AcDvU9tAP3aukgYv5kUDTHAzwTk54wOMf4VLhL2MZyemxliHKXP7CdrjmikCpsgEM1zJiGTP+uHI Ax7/AMqutbJuKTgxsLhbXzFG5kkJBIPbrx/+qvRp06FFqPU8Kk8zw1dx5XJdSfZ5RgElvFuePa8M 9yfLSTLDgdc45waLaO3nXCyAxmXy7bepdVk5DsCMnHHT2roipxupSumdmKxElW/dsmucSyRqFJ80 BMqjYxHHg4Y8AHsDz1p8cQmaW7jhYfuYnjDPuZDuxnj1xx6VlVs6Vo62/Q0xDqQnGVRe67/5CmDL DMbFmuFCRbyCuAzgHGOODWjFbCV45QCFubRgixzGQrEMFsHgE/litcTKnDCKrdejdu55eWVV9fnQ wlJ26tRuvn8vP5F5VUO8kyDYsgjlkhTLKuAq47HJx69DVyOyCF55DunuLmQ3VsJ2YBUXKsgzgHGM 4r4x1JV6sYLRLbrb/P5n6JhqmFpUpKj8fXdXf37G3HBIzXHAESkW8afIxLEBmz34H4fjUllBKLee /ayZotOtPmiT5vKUrhcEHAPc9c0mlDEpUfQ66MaOHU62MV2zZ+zymYoIILgsyXqpI+5SCmGIxwuA c4rRitx5d7N5ZeMSCOKQzYUxqACQAMgkn9K7Z1nTqKmo3Pn8XTdGXtsO7KX/AAR32UvM4ASOdHXZ unCrGvGAc8Z4HvzW3F5hS6l/s20JnhWB7l58yFg2WTaTwvIPT2rpskrm2FpRVOM6e7LC2lxdzxWr W8spXdOLr5QpHUjAOegPP+S5LZpZJDb6bJeS3kJglksmAa3jj6ck4GNxB/rWM6nI9VZd7nPjctlP ERWXK81q/lv8jVMB3Sm3tPISSJIozNeM5kxuUkg4UHvkdc4qe2hkdGjNu88zRNtRSFY5XGAenGOa WPf1bDxarW87efY9DBYKlicRzzw6lJ9Ltfjdu33lyNS8siiAMdg5Enytx1znGc0+4tra52x3FjOH 8swPNHOF3scgbSOQPp/hXx+IxFSVT2qqtv7vybPuMNgKeEwSoypRV7Oyd++rukSkM7eY6t+68sxu X4YKAuCe+T39qckXls0xw6upiIkIIjkyOv59a5m7tGkZVJ6TjYtRrJi5Z7WaNxcrjz8FXG3KuGBO ARnA61aWORDHG0bRoWZ3ExLOFPQ8dcc1WiVjRKLmuZ6k+JDAxA2cEQlkG+MA535z+nvWla2gmluG Np5rKQsQdh84cA7gAc4z3/w5qDfLzNXOBVan1vkiy3EvnLE4j3+YxtY1+6BIuBhj/XPJq5BE7R3K NAxkiIeG8S4x5TNy28Y5znAweK0oznTk+aJz4tJVrU0PECRRhLeD5FUBI45djIcnDEHqOO9WYjJC s6Bw10IwXaFgSvPHPTBGR+NZ4ulQqqU4yTtrZq+2vka4VTpYhUrvXTSVt9NXZ6eVi75aQriS2gnj SJZLV/NLCJuh+6Rzg4OfwpIh/rJmt3AD+XDCzMA56bt3UYPrmvmsRm9aVGfsK7Se0XFbdddT7HAZ JTwtSH1rDpu3xKUt/TTfy0NNIX/0NpFUARtEMEF17cDPrTokQXMkiw3CzSuENw0+RcIRtwq9FPXJ 7186tz6mFaTqSlcoeMviB4f+Cnw38cfGjxcGHh/4fWS3sygkfaZWZI8bhkjBdc8Yyw/H+KG5+Kus /GHx/wDEf40a/C6X3xJ1oapo9tcS5e1tI4I4oozlAyFgvTJzjJxmvybxPxU5YFYakveuvwZ+seFG U4mrnixdv3aTvva9tPI2PDfiNtOWS5gDqXtBbSqBkwZwcYPTHXI9TX2R8J9In8Q/bdUtJETVGskE FzE4iKMm05VyccrnnpzX83ZhXnTbpNas/tPhmt9ath4q/wCR6HYpFppW/wBeme4jt5GjmhtfnYjf x0z06cA969C0pp9St/OisWsdNto3iiPljIVskrIwx83K5J56V5kujPfxjdSTw9O7syOx8P2+tW8m s3m630yygNzZwyNlppuEO5Seg556VnXLS6i0NppNnvuGtZ18rf8AIVVtpHTGScHHtV4eUalOUa2n 9MjGQnDBxj9pf8E0tF0ZLK/t0SJf9HheN5Q4IaYDbwvbOSMH0r7/AP2PfGh0PxdDoZe4Fm0Auy81 wBskk+3yvgfeOCFyPTA9a/oPwaxdWvleKyua5o3ur+UfM/NfEzBPEcF/WpK04yir3ezb7aH633Aj +0TzRxBEknxFtGPl5CkDsOo/nTVwiEnKkkAgHO/PPX619sfzuO6mNeF3HaW9T6+1WQrOdgj80CHy ogrYCsDy34+hoAuxIMiRgVkMYZgDwWPUevH5VKUDKS4BJbbtx0UYwT9eaAHNtBDbTkrsz3H/ANbN IEUSNIFHmPGIjJjllByBn0zzQA8cYHcDBPvSqCzZ8sHhVjOQMMc/0H60APTbuV9g8tEKsC33ifQ/ 56VIqBPM81SWRRj5+54x/X8KALQiVQ25RyPLI3Y3KMfMamMI6BRgJ5f3uqcf/XoAEhALEg4MgAB9 BjFTqoRe3+2QuN59aAAnBAxwP0oJPHzduuOtADe4Oefp0oz2zxnrigBOpPPfriuG+JXjnSPh34O1 fxLrFxFDDZWxaJJHwZiSqYH/AH1n2q6cPaVIw7szqycKUpx3SP8AO0/4KD/te/Eb9rr9pTxVe2mg 3P8Awo3wDcyeHtJ1ea9jYeJr/MHnt9neMSLFF5Wdytksrc+v5veL/iX4W0RILDQLG6kitVkhvbq+ RXCOwCxyKhALEZJXb16Gvscwo4fC0qdGEk3FW/U/O8NhcdUzOWKxGinqfnh4r8d67qV/djVJ52jM jZt7aQhQof7qKOFD4GSOxNeY7pFXyiJJAqEQtjAjQnA98Ak5PvXi4vm9g7HtYaUMNibVNRjM8Xl2 6zMsqweTC8g5i2nKZPBPORz7U95kt447iWCS4T5h5McuGcZC7scZHOfwxXySwzjQdWeh9jQxFOXv 0nqv+Caf2hYrqRbdWCWxWeQE/MWI2ud3YEgDj0ruvB668ftF5pVskdtYpFHPf3cywoFOehPU56DN eRiJxp1lyw1aPYwdapUUnPU+0vA/xp0z4fW2n6Z4Zu7zXfEdzE08utSqWtYJWwwRC2WGGXngDgYA r6p+H994z8X6dd33im8eW81i6udV8iykOyKMtGCVJ5CnH19AK+G4kwdCjFVqsNz7bI87xSq08tpT suupwP7Qt7a6T4Yl/s6a1heLSljs1ZMmV2EiCZ0J4YEE49hX5wzw7njJBjSR0SNhJwibSUYn+6ec j1NfV8NqCwMYzjp5fM5eN6lOWMUcO/e699/6+R2Kppg8qOKSCJ7iJZtkq5MUpyWQkemM8deaiaCK J7pzLGG8tdwjyqzqpwo2/wAGSQfc4r7+EXVnyp6n5NKi3Ulh4rW+hRltZ4ZXe6hfGneWSxJQ4bLA EDvgHNW49Zluoobe7eW5iZ0srISykAKCSgbuAMt9CcVrBxoVnGepnh6X1KH1fFw1GT3FuZFkjWWW JVfyVUYkhVGILAZwc+nt7ioRK0InsyTKk8EU8c8kgUFuWIYdsA4JPdqMTVw1Oomlp89znw+IxccZ OFOnoSB7eKV3jyeJI3EQKeejYIGD0UH8ax5LEyyf6VLFcx+eHQLmNQMFtmB16dT0xiutY2mo6o5M VTdSTrw+IyHikKTyX8LQSz/6RFIUy5VVLMDj++CvJ+nrUUcokuLSK7JW4s7Ty7ZW5LhVUhuOM4OB 34968XHVpXVWGmp306bpUUpat/gJNBblLpmhlUxQtb3DIcGKEEiJiehG5hkHpWLfMttuZYHD2zRy 3EigDZGi/vDnv3xjnrW+Hc8RD2kIk15VaWHvQd4mFcCe0vQlwAB9iygAG0oB8mBnAOGB/HmsaeVH jMkku+LzlJJXItnAJVSPqBzXPiZRcJwkuj9NjswKeN9m4aWf6n6Zf8E1PiRrPgq68Y3AJu9F+3R2 IJO8WV2I0eVYwRzw64AH8fHQ1/Qfo/7ZdtpwttTl02wuI47xmt2ktNwiZJCWjMeB1GV6d6+c4b4h oYHBYvL8RU0d0vuP1LO+B/b0cBneFWqt+Zzmv/tdp4h1Ceey021ssXY8vyY2j8pflZV2Fc9sZPof w5q7/aI1LX5bi6kVVu3tGllQrt2srhc7uO3GK/Ea/D2CWa1sZF3Utj9IpZpmtXCU6WLdrLQw5v2h PEBvGtrKGzMB08+TeMmXhxkbvu9VYjH9K4zVfjT4zuZ1e2vYDDJi0875vMtsqSzIT1y3GD65Brto 4HDYWpyxWpVfF42vJwjLRnlniX4meO1S7ns/EF1E4je9iNrN8j5IC7kI7BSOCM5OO1eZ6z4z1e+1 GXfquqWEBA1G/v7XVJQ1tJCoIUDOQOSSB6V9dg3QcVWcbL/hz5fM4YqjL6rvv9xNpviW5iVrqa8u TI4leOSWXi83lS7vnqQFwPTJrvPhr4Xl8R+JbE6fdx202savBrd5qbxb2jiWeB+ACMK3yoSef3nP CmvB45rQwuUS9lbW36n0nhfLmzqGGqx1Xc/oE+GmgT6L4Punn8hLmwsIrF7cXQiacyRNtKEHJ54B Xp+NfUPhnRRBYWc72m5xA1zdeQxIhZY8Bw3px+hr4jhfCVMTShXnI/XeOJYaNV8ys7lXS54L25uL kNPBJHEby3kjcEkodwPX+Ic56YBrp9F1DzryaG6YTfapWMTGMsLfaNy7SOnPX689a+oxCprHxjul /mfmlOhioKfsVaOv5fcef+P9Zv7HXdN0i2tZj9okIYJdgFCkiljtxjbhvXnOK6rxb4aki8A6gk1n G91o97HqF0pfb5cLxyBcEcHr908jHbNfqvh9i0+KoUl00/I/HPFnDutwhWqfa0/U+a4oRIZIUQx/ MYy8bZ+71Cg9cEjOemakjidRIRboYgxu1uY5QxXHyjI69Rgdjmv68k/Z1E+q39T+FqEMNKgq+Ihq SNbus0anfE1w4aKUD7jEgr69CP8AOKuXEEzyu81nbqkq+dF5F0GkhO7aW2jhT68984q6lerXbjFH mYqpKnXhKL0e6+ZcEcbbpo444ysgt0kjztuXXI3D6H2780uxVmdiPKmBiUESBySSc8d+vb3rGrTl TajInMVRpuMsNEbGglUyTwSf6Em4qWMkm7JAxgcn6c81IUTyEQ28sb+WNs6uEMqs/PyY+Zv5VpSr 1KWz0PMxWPbp+zmvuLP2OVPJzDGls8nyxR3K7gPmUNxyBwOvNSqkpWyCwm6CQpDct5gj8k/eBwf9 raDj0rSVsXWUY6BlksKoyjB2v1Jo7VdwjnQPeu0r72cgKG5bA6EdulWrizxHbsbcRiQeRb/xIwTL KobnAHY+tejTpwpXUFY8zPcNCPI6EtXb562IZvLJV3WW4hjjG8KCQ7ZDEYOOuTyOeKsNbOpa3USN JHLGsaDOUiPzDB/vDOB+Oauc5YhNz32Ko0K9GrThjVdtCSIjzzahJAWhvJn2QRMNzPwu8fQ8EdOP rT18+NGjurN1lacz3aSPjzgHUgtjPQentmuGdHESoqmtTrx2FpRxMY2svzLUqTpIGX5pbsrI0SME 2lt25Qfpg9s81VlHlIiqrFI7kI4llMa23Pzvj6DI55zXsQw01hIzfxdT5/2rwOYy/kbZLO08m+Ix xKLu9EgKPk+VtyrHtz6Dmp1t3he5tjDJG1sDcyGRlBaQhcKFPTI4z0qorDOmufc6sdjquKrRhTem /wAiVEaRbcGNWFvNLFK4QFXt25KgdiGPOMk4qSMYg8/5D5YYyPNJ+7lx90j0zx09s100YwnSnTUb IrGTxGOwyo047EUcJjXzlVVmlRdiSDbkHrk8n15I5/CrsURP2m2CJHbvdeWszPlTIBzu9z6+n1zS peywl4TlqzzcRRxX1ZUHpb+upOkUiMzSBYmk2L5SZKhxgke3/wBerkYzMXkcKQH2gxggsDnsMAen rXU+SC5drnmRg8LOLxBZljLly7xrNsW6CxD+HGG78/Wr00cZTEtlBKkRXZ5zEbI2IIGR1IbmopUf YLlTuelisxp4iHJShZCCEf6tYy0lw8zMTMQYUB+Ue+R+ParTxqRICjGFpHVFlONzY74PB6H/APVX o4apCmpczPIqYeddujUjpb7hHtWW3glENsBcLIzss5MkgXAHPofU9cVYjEkrRL5BlFsqz3jKSzMp 4RI09jXPJOT2PP8AqWFw1R0qd2S/Zy8F2n2SKUwgxmIS4Z88MT6n5s4+tRlDFJJhDGwh2yYYMkpx tU46g+/vXXRqwqRVKutj1KWVN4aWIpTs1/wS/NBvtV/dvKYDsjhef5ioVSueefmHargi2kRXcMMU 85a5+RyyxEgElcHAI6Y9/aut0qN+W2rNcFja9LBThOPvP/L8CFI5IvtDeQwkF2sqxPPu2qrYUqT3 2kdfepVGxbRRFslefMkygAWxHJG3pj/E1jTpVacp0Ybdzzsuwb9q/re7ehJtZ4LcAyPvuJo2jRSP Iyd2fTnkfh2qx5S5MsdpAtvdOWnYN94IQFJJOQRycU6VBzwvI9D2KtGjChKhUlcZDb2rXMO+0E9s JTdTM0pikgJQxxuvXJOeR05xWosSoIrGSKRoPMSTakgQNkEFQfvA4P8A+uuLG4abgqNSaUbXTs29 OjMcjn9RrutClJ9Gm0l6+djTjgGyOOKPZGBDDG5l3uXAO0nv06/TPvVmGPbNBLHBbzyQSoRDPLsE YKlTlx7Ekc9vevn1L3rU+h9VjI4eTeJw8bXLMNou4KsMKsXZ3kRsBdx4Y4yc561v22+QRecjhZIj G0Ly7QA2QeAcckD6Y/CtIx+r1Oeqjlx7dXLlFayNhIXSP94rIZFWWZFky8jquCBg8EDH1zTvs7iz mwvmRFXDlGKhT7f3Rk4z9fWvRpz54qcFoedP2bwajW0aWn4l6OyWaJo5raFWFzGLnyxlU+THynvw P0FaUMUIkd40DQ3LLJKxG3JAx3Pcfyq0tNDz4Trum1SeiJfICLEIrKEPcKT5yTthTnAQ5z25qxDA hR0YyNKJirIr58pSTtZsHgZz1/WnWSw6viHY0qUa1WSlgm5T8t/X+v1NAxvI/ly2QePy2RzHcgqi g9SD+HQU+G3QTQnyxIJ8KqggHaARnn8u1fOYrNJJP6rVv/27t83/AJH0WVZPPEJTzTD8rWnxb+dk v/bl6MspAmNkQD+TtTYjgBV6YBxg49elXfJf/XwIX2w7SjS7S44A56A59PQV4lWU6lRyq/Ez2vaR pUvqlPZbfL1ZK1lNMFRUEkhkjim3yrhFwCWB6cYP4mrKxhx5qwlbW6mErvK27sBgDvgAc/lS5LO5 6dHEqtSjSbs0ENqXjllEcjs1woeEyHERHCsADggj1/nWilrs3MV2DzzFMRMAWGPl3D8/zrdeyVK6 1bOKtQrxnKpF38xQrpbpGUVMIAyZ2YBIxn2xWmkMrHUGiCQ28EUSw3DMB9sGSCFXt1yaweqfKY0c TKknZasT7NbKURoJ82bBbbN18r7hkrs7dBg54rYgt4y4igxASDhppOJAOTknv2zXYqlOhhlWlTbb 00V/w7dwp054qryuaT83Zel/wQwW6+bdyQqivdAE46oVBHXvgD8PeryRSh5NkEbSGESKiNkSIF6t jnOf5E14mY4rCxp+zVdKTWvuv7rO9r+b8z2MswOKVb27wjlFNW95fepaKXy0JgFWOBnt5bjyQWHk 3IX7xwAykVMiP+9lG1Xji2Ovn4BUsWwR6+49K+NlFcqakn9+n4flc/RZ1JV4XmrNemvpZ/nY0Etl icIbeNbnqX2gHY4DID/P3q5DbqVt7aG0b7RJKLY/vcLM7n5MAfUA+4qHJQg5djOOqUUfiX/wWl+P baRZeAP2TtDnlsbzxHYXHijx3c2l/sfULeBtMmEIVVBIO/GTzj86/An7NYaVZWVnptpBBaW9vJb/ AGSPgO4ZTH05wq4Gc8nrX8/8e4x4vNIwT+G5/Ung3QpYTJMU+T3nJa/L+v6RXiudzYlzAhh8xkic 5th3993X14xX078GPFcrWy6eWkjtbO4NqUnlyZoyoCsWJ+YYOe3XHavyHMJ8jca2rP3/AIfx0KFV xpfFt/X9dj6wsNW0nTbGxura2lne+vEtIJYIC0dxMOrOuM4+Uc9K6g/2pfwQTapbLZ6Y119vufsd 2yEurcqygAcYB54bpjFeC6dPmVW+p9vFValF1Fp/XU7G+1S8v7aCxso0nK2/lW8scIhVUOCzOwHJ GT9SavaRaWGh6BaQ6Ra/Yjc3FxdR3ULsWiRhkkMc4yc9PWsqVSFVtR6FVKqlhI3V3b8WLHa/ZBKw VXkSEGNME7iw35DHqecfjXZ+B9am8G69pfi4wyzvYJJLNb7f3jxLDcAEN1+9KQB15r9f8Ic3hguI Z4Nq0ZqXn0sfOcU5XLNeFq+ExOn2l/26mz94Phf4mj8YeD4tQjAuPsOLZZz8pjTzZRgjvypH/Ac1 3m0s3AGDhQoPOQOa/a8bQ+q4qeHs9H13P49oTlUpRnPckCksI2BPkybmODwCARkfTH51ejUSSQuY yJQ26Jc8KAvPsRgn865TUsZbeO0YjBGTyxPt2/8Ar+1Pj4UDbt5yydck8nmgBACCzDl2AQnGPlB7 D8fqaUqGVgxG3GCDxntQA/KklgPlBbI3dQRx78Y60+Abgql8MYgZEA+82fu5/CgCZYtwR9u1SpwS /D5OAD+dWYY9ylpEAZTtDZ5OOPwxQBMVwhjwBwE3F+gxgH8+KcMseU2hJcj5ucAdf/rUASr8uRzx g8n1pN3TnODzx1oAQk8Hd19qAeo3YBPp1oATJHAPGfSk3HGM8UAOHAODn1AHWv50/wDgsV+2JFpu mxfAvwXqBPiDxKI0lMMmBFbLLbNIrsAdpIMhBPHGDTuoxlJ9E/y0/E4cdWlQhTnFfaS+Vz+aw+EL GHSrbSLW0d7W0j+1WgklD7HOfMDsfvl2bcO4Ir4z+LPwRtNdVG0/T7iQBczQ28W1lEZKrxnJw/Jw c+vpXwEeI8TQxFsVO+p+p5dkmVZg1OpFWs0tO58K+IP2Y9W06aWe8iu54pxJNDpkeWkmWRnIZB95 mwMAZwMfjWhYfs13Okw3978Rr+00GLw5DDGNLspRNd6hHJjgEHAbB6eo4Jr7z69LGYWnUw6uj8o4 jyf+w82caq913Pln4iWWj6XqMMXheErFZXn2Vklk3m4jQD94cnknPOCeQQOK4JQQ7xxhT5WVXI+6 GG7H0Bz09a1dL2y5J7HPSqQwkvadBiz+XcyBCZQNqhHYD5mzjk9uD9P1q4uqajqgd5DK9tCssaWV tKV+0FwByOB1AGO1cGKp0aNDnUbHbSzOpOfJh9j6a+D/AIVOpahZJMgjSQ4SOBigPyrgMeueB6fd r9d/D9pF4Y8LIbjybBp7K2uZiX5jMKh2AbsM84PUHnpX5ZnmIjicT7OC/rofqHBeGhLETxeJ2Wp+ cPx4+IMXiLWNWsbEBX8547pXUAWsh3klegOcg4HYcYzXznNefaSvmszIIxsWOMkSlFyDjoCfXHev qsow+Jw+GipqyscWeU6WZ5vOdCXu6l0OY7lnSNpIrd/OuFGcyRnhScjAGRnGc9RVqzincFWtAbp5 JpXBlyt4hbsOo4xkD2xX3VKVKU+WXQ+Br4ephsQ8ROd2hyCSWE3sQkkRbr7O1uYiG3L8rfMc9G9a tyWdykal7XmOWVzeFciVBgsAvAG0cccmlUqRhK62MJYnEZnXVWL2LsHh++mjTeFLmVZFWMltoBJC t7/dJ+uKvz6LIyNbeQ8EsEjSXUysJPtBOG2N6Ljrg8HHTmuXFOCjGE+rJbrzrShF7mfqGmXNqzMY kMM2yOWKF8+WhHQZ6nodwrEFlf2k42AIVlzGkxwZmQcKPcAnn8K7ZNOCiZSy90avNT1bJJNLkT7J bRXPn2rGO2ulcbDDERvkAzzgE9uSRWC+jfZm1GWNGVnizsh63XAAY9xxj5en44riq16MH7OpHY6q j+qz5mlfsQPFdW/mCd1E9vIQfLk3oX44XttKgKVOecnrWRqREkFjKvmed5MhuIzhPOilYqqn6cj3 FddCdSheUZbnP7NumoQV0/8AgoxblIvLto7pdwb/AEW4dVLHyQqrGoH3RypOe+Oap6P4di17WNN0 5I2l1C7eJI9oKvF84Hl5HB6qScY55rwM+zB4PBVNOh7mR4T6zmlLAYdWS1fyaP17/Z68AN4N8OaR pHlG9lTZqdw8MYjN5dOq5kOOf4DkDgdq+oNTvtJ1Ff7QshHa6hLO00kyD91KQ+5gB7hcZJr8VwNS c6U6jejZ/Q+c4irSwlDDU46R8vMfHfw6hBYu8Msd1cWhleNX2FZM5iBIHUAE54HODnNZuo3F1aZW WDC3NjJLqNuhws43ZIA/hBHzHHce9dOGnLC0pTqq7X/BHKrLEYVTcdinZX2oyxSXFs0khNhDFcyk 58xUG77vTByOep/Ct6PXZFlW0cJb3JRRBg7QsL4G9iQQQOR6/MK5KWLp1+ao90QqM1GM4S959Nij dWbyQzFgHju7tUihc82S7PNTI6cbWPtxivPdQU3WpTaba25+1S2z3MUk8vU5DKzk4BDKSxGQc8V6 GX4yc6Tdba5nPCudWU6/x/8AD3MhbW4vtVttHgltYru/1fy9L08SE/bLYJuZ26bTnIHYd+tfoX+z d8MfJ1HRp03vJCWltkaQkqu+LcGwcNjb9Pm9ufF47rOpl1Ok901+Z9TwFhqKzrnXRM/a3w/YgaZp dpLEftlskX2sSSbWkJd8Nx+AAHpX0Hp8Saf4ZaG5gtrq4IWJrg3ZWWZnLAKqjAz29utZcMUJUaUa yXR3L8QcW6+aTp05aX3/AK/qxxMNo4e+tr//AElDYs0TWkWyO3yoGHIyCR0xxn8KZpsj6bJFP50r z2VqYnniLbZZdoJxHyNuFP0NPnlPMfZyXn9xVKLp4BRnrp+Zxlvqcni3xne3cFuJfsN48CIZAxj3 FXOM9flAI5yK+oNMjiutFuLVovOL2Vyot0O+RkMbgZ/3Wycnmv0jw/xP/GSc0HbXU/F/EPB+yyGr 7bZr5LfyPjmayazvdT05g3madqs4+yIxAYu+5cSdSCCDxx2zTGjCR3MqKFZ4gjvGNoJXJXI9AQTi v7P541F7RO9z/PrGYiGCpVKVVXSehdntpUgdfI+zXeAQglHl3EZAIJOcAnI989aWO3ihNpNbwnZb TuZGHyi7kyFcBQM8E9cYOa66TpYZqVOVz5+hWni60Z1I6F6K1nWGWdbVo4ll8q3lbpKjMST9Q2ev P4VNJBCio0UEkMKyeVAhbLY4Bb0xz+FdFN0cTNucdTuqTo4iLpzdrDBb+U052yIr3aXcaQzFBIAv 3s/XseDzmldLqRYNscZDSHaZZ8iMg9sc5OR1xWVes5wUJK2p49enhcN+5hLdEphiw/kKqqWaRIdw VYzndyTzgAE/jVqOMOUDJKWUKQofBPzHB9sknA74rojR5a/tYPRnnVZU8NRdGrL3mSvAvnFJYVjB uWt4SJiwt1GWBJHJyQRj3okR3uUQxMHniAtYd+EjBAJH1GSfXiu2rTpXSTuiMNzTS553ktiwi+ZB 5JjUqmYpSG3rHlm27s9SSAcf4VK25YyQI5HmkEjoJMDcAMBQB7HNb1qHsYJKWppXxWJ+sLE4rZaC 2wMka7rSOLzWae6Rp9/kq3JKjHAyOnHSpI0njSwm8mWdr2V2EjD5MDIJJ78H8Kim5xi5U5WZGIxD xsvayl7q6gkIMMmQ5kiRlkLEq2Vfj5h149KQM+I8LGrGUtE0km/MQXALAjnkVtCVerFucvdR5cqU ailOrO99n/wxG8TLMXkgMYREIhmk+Y7yTjPuucZ6Zp7WiBZ7cQB47aM2ds63JMiQsQxL59iQOc8d a0jTo060alJ3ReX4elCUo13aX9fmTxhpHeEqQknHyDIcDAzz05xn6GrzWUFskq2yxwrKqtMA5IkK kA5PoDx9a72+WN2Y/W6mHxEvaStEYYD500kaNeG6uR9lMQ+by84YEd+f0q9DHbxxNmGKeeC7SUiT d+6bo25gcMcDpXGvYzxPOmTPFYiblOLvEebaOM2rhJ0k8/awc4RUOc9OBx0/I1LGqDYYtrylRb7W UkKFb0Pbb3rsVOm66rTW3Q8XFQxGJqqDehpKiLFKy5QR3DkuWDeRweWPvn/OKtzQgyoZE8tWhxl5 OZQANjADpzzzzWzg6rcqUdD18PhIYSDjKetnYSJHjeOSWHa4jIjldlYTtjO7jlcds9fSrRjEUREh CMh8+XzmwGIOenckHJx/Wt3hpRocyWv6HzWZYjFqTVGTLP2SONWJRzJaoITEX2q6sQxOOnH6ZpiW Z8242qylTsSHq6jBKntnqa7KNGPs1Ga1KwGYYmpRlTqw96xbnWS5Lxpstn8lP3iuRjAAB5GBnH60 sULM7eXFn7Qu6WJ23FnONxz9BVzpRlSdKJzVquYwoKFOTvdbkqW2wQmKFZGWLet2shRoy2dyqO/T n9Ks/ZJkSO1ltRLJM/lyw28wBJIOcO3TPH0rSnOnSgq2Ja07m0amMnCUMOm5fiAt5jGu2ziSZpRF MLiY7nAY/Mzc4OOOlOEVnLJaTvaXckMcb+TDBeBTGqnY2TgAgcnn04rPEVPbP2lGdm9drq3rt+Is HPM8PGVfEwbtpa6i9fvf4FpbRBH5JU71i3+YxIFyc55A9uc9P6s8rEMqXFo7WjKkcryAbQpzkkdC elcv1xRTSkm+90l+HN+JVaGYVUqlOMk3razbS9Go/gTC3KoI5LbdE8kUqsBgEoflAHXsCPStmCE3 O8BGKrJgiWXOCQTgHjnPUe1eHmMvaVYuErt9m3by/pL0PqstxM6uAtiIOMrrdJX+Vv1fqWIknMNr KliJYp5jCZGuCrR7DtwRj5gBjjI+talrbgCIiNYrVv8ASpFU7zMuMDaM9N2OOetcv7zD03fd/wDB Na9GrXxKpUn7paSEEIjWsJZ4hJmJyTC+7IAKkc4FbvlRSRJa3EIuVZgi6ejk+XFg5wy/dOeefU1t hHVndTV4vueg6P1RJSfM+xctdOEFpvjiuHNwyTHoWjH3Ocnpir89q5d4Np3WsIQeXMSsitkgg5wO efqa3nTlTp2w+n9eZ43tadepJYqPL2NdLZJFkkjgkDFRgGb7/G0kdADnnHXip1tLhDOxW2ikaD54 VjJMkqgKSOSuCMduBWdXHUqCvU37dTGhg8Vi67jhY+6r6vRfN20J4l2S7AjNLLcqmzjZMSMn5vYd +OlWbaGVw8RbfbRwNDcPBJ95Aw+97bv1968XH16FSo27uS6PZeuid/vPs8iweJw9LmjZRlq+rb8n eSt8k+xN9nluHEaW7zPLsPlorF2VTkBdv6mtM2j29xIZrYq25pFEvSUOBjOOeleROVSbSlLRbeR9 DRowhUk0kr+X59yO2ZxiRhuSKE29szgExqxO4Ajtn+lWRaSWyRRNaiGO1uBshebcv3Tg8ZB9ME8f gKh8z99mSwVGFd1Hr/X5CpGHDvsjZ4mEkYZzgsAeq8djn8BRHCGRQiLBGVCAB+FPJPA/nRvvscOL 5PayUFoXvKHkvKbJp4Y0jzE0xw5dscFcEDHQE+tWMlI50SDZ5sscghZ8jcg+UgknGBngGrqQcJaO 5tSqNYWTm9OhbZZZHtlaC3UtbrG8pmO+JlYgHB4Ldc9vatSFVldQIo2CLu+zO+1ZYgPmyffk12Sj z4dTitTCnOjGmpKN2Ojt/OSMm2G1F3xxxkN8i8gdeMZ7+laH2ZRDJFLhGa3CxmJxIY8nJx6cYP4V 4ub5hh1g1QVW07rbe1/Lb5nr5NgMVWxftp0E4WerStfpo+nmi1FD8sQmgK5AKyx5UuBkEHtz64/w p8ERQ26BFGVkDyRy5Yk54PPABAr5PEV41a8nBtro3a/za3Z+gYCCoYVUsZBKS7X5fRJ7IspBFs5U s6QxqSX/ALvfnrhv51PBZxvtY2ySo25pIncgTsT94844GB+Fc030NakozfNBWLMcQdVczlc5WV2H ysB8oB9sdKt3euaT4L0PWPG/iGJhpHhKzl1C4RnwwKuiIBnOclx16ZGa5MbXeHws5tF4aCqYiMbH 8OPxV+JGrfHz4v8Ajz44+Mp72a88S62tl4Ws2vvtEdvpcccMYKjAZctGNyD+5z7cHHcS/bjIV3Ik flhEOMp/EQffAP0Gc1/LefYuGYZjX5J216H9s8H5Z9V4Ywk6cbNxu/vYsshC28MCIJpZjLIryZ+R Txtx74Hp616P4DvJdO1NIpWWOG4kRsGYFJWO0L0PABJHPQmvksyhSjd1NdPzPqsjr4KniuVbX/rc +/8ATPEoOlafPZwfaJbeSNIpkYbrZ1jIVwc5HGa6HRW1HUUurieXYkVyPNi80h51OPv+o59O/tXz ttOZn6k52qKl0sdtbX0FlZQpCrfZrS3efULiA86ftfBRieoPqOMV00KDy4RMIySuYLdc4iRstzzw cHOPauCpQn7fnpaLqS68VJxUW7GtYCbVRDGMutmzStK6ZE+cqp/AnP6Vc1uKPVIRp3KG5ERufIO1 hGfk2g843AHHrX2vClZ4LPMPiIT6pP5smrmccbCeHrw0acV80fpD+yR8VHg1VvDmqGaz0+4ia1jn uDnz3kN5IGZMk4Copx7V+jTW0kFw8BU7skRsW6D+8PXiv6ozePNjJYmNrT1X9M/jfPcGstzvFZZa 3s5WHxxeWHlOHMZIX5vuDv8A44qzGmzhVAUqDt/unv8AXP8ASvLPLJvX0PzdOlR7CG5IJ2PHux/e xg9e1ADtzEqGyfn2sSfurjqPXnjFPKq/LZwnzKuTy33aAIyudykF1I2nnnnORUyDcHVkB3bVGMct 0Gfy/SgC+m3kqgKyRqn3uQOF2/oeatRqECgg4wNp/u+34UAOI3AhhkDsaaqgEkqQc4xuzx2oAezH ABHPrmo+hGPTOfQ0AKfXOSevHSjjnn9OtACg46N+lKTnq3t0oA+b/wBqL41aF8EPhR4o8U6tqUem /Y9MecXeC5tQGUHKr82W3bRj+9X8SXiOTxn8cviV4q+NfjmCGz8ReIkDeHGeYO1jpRaFvLJAAGUj UnjnGCTivPzbMFhMvnQjH3pNW/FEYWhQxOaQdV+7FP7z0Twl8Eta8VSLb6BolxfrJIIGunk8mJVR tzMo5JyBjgc16pr/AOyL/wAIrp1jqPiV7Z01C3Z4oIblYzZq+HKKVO4kZG7tmvx3O5Tw0HNL3v6/ M+qyzN3PEfV8G76nzN8Qfhh4S8JxXOovYrqCWlrC1mAhE+mtsfLx9dxIOAM96/Gn4gfDz41fFXxt 4htdI8P3eh+F7Ka4h0u/8yGWTXBBKyiILn5TtXgse3FffcE5tGpkkquLV2tvuOrxL+qYTL6OIqRU qmnrubXgD/gmzqvxLgurm+tfEFnOyLb6hZalYeUIbghGbY2B/f2llYgc0/xB/wAEZ/ixE2o3eh67 f65ZXF/Hb2Wlvpe1oEL4LeZ5nO1TjoCcA18rjvEtYHMJUJrS9vQ4sj4Qw3EGUQqTbjJ2Phr4/fsi +OvgHLqd94pc2sNo7R2VgLQ+eJAHBWQAt2Tj68+lfOGj3fh/TLo6h4kvLbS7eOCB5hqcu3yWbtjq CCeCQM19tRzvD5pl6rxas1f8zys24WqcP4pYeT91H6mfsp/C7VNR0u38UmyfLO8eky3BzZavGrLt uOeA2O/fI7Vq/H34sW2iwz+GdI1ET3OoQNcoYpdwg27kl3LjOTJk7eny9Ogr4+lgquLzVVMKrpbn 3eS1lhOH6mJfVfoz87rozM8U903mySO7krLmS4lV/lX6gNwTxzVZomhieLAlxI0cFsnHnMOSgJ7s O/QYNfoM+fmUZrY+GwNRT5qjlZf8P3PXZ9R0dY7URxLcb7eaBGBAxOHVg209RtyuM44PNZyyiGYP YsHlimzKok+eVywwPoQc54xiu+tOWHkpwjofN4ariJVp4bEq6IobuJYWEckcaSySFmCZ27SSxxj+ I8A9D29au/2lbpG0Cb2uGPyWyyYitpSgKN37Fgx7E1OIpOpasvuM055bWksJqn6ehLPdTw3ambzU uYJhMEQ48l/4jxxn07Y+lUf7Uu5o45chohcM9nL5mSk5Jysh7cDPOf1repRjVnGcjvlVp/V/bqPv PYzLnULiI+e8oiguNkgiDbpIVbofYcnjGarPqsMP2yRoV2WsglcyMCdu306hsEcCoxGIVK0I9T06 CeIwSn1X9fmUbu8uk1F1SQO11smWSEnO2ReQp5H90EHnis+a9mme8hhkeIHZHcPHiNnx85DH0Ujq ODk1jKhGFo1Ho+p47ftcYqk4u/X1Ocv7t5p1a3hEtv5hWeSOXAcA5GF4xuyTz0P1rntRN2vlGNJp ZY7km5tZmBQIpwD7EA/5zXTN06/NQ7H0jlhqMOejuY9zLcJcyW/ng3KBxIpHMIIDLu7AgH8eK+jP 2Y/BS+IviGmrXUM89p4Us5p7NyCI3vsRGMYz2Vn+u7H8NfC8Z06lLLY0Ke7tc9jgjnlnv1ytC1r7 fefp1aX19pVvbQK0aySvIkE1vKcsiErtX1ADKMZqbQr53liWe2kLXFo7tYXD/ulQErLkdCFwGDDn 0zXwVKEPZRpQWq/E/aPaQxk5Yio/d7HeWOraRbvb3aRSHUrO1VFufte5AM8AoeG6cH1x0rmbnVZv 7bv1fyminee9uUE+9VIw64I5wTu4OBnjmt3GrGlyKO//AATz8RmsKMnSjHRf15EDXtxcJDIszxrF ZS+SizbVjkBB2qoIBB+Uc9MntWzYXs99YqurRyyXt3AsNyzMC8zKdwV2H3QM4A7gcda4lRo0pewe lzn9vUq0o18Pv/wTQ1S+mggvIYXk/drFI8cXJEe3Emc+oByOgwB3ribq8F7eXs88lvA6+QbyOKbB uArBxuHXAJDHv0HevUjgfZ0lSpPT+v8AMqvmvJKVGrH3/M2vBEMur+KjJIkV2un2v2K1t5bYI4Y5 I2uOjbc9Tzu55r9tP2SfCKz3FndXoH2O6bfbTxx5JQRI6gdtpIYn64r4fjGVRyo4CPl+DR9j4e1K FOjXxlVPms/xR+j9jowTX5J4lT7G5bSrRmk4eNG8wLjr8ueCfWu+1mQm90nRBH88MDXGyKQ/vgXL ZB55AYD/AAr3crqVcLhJK2n/AADxs0nWzHFuaj1v/TGbQzSWssMYUGOSF8cwog4Bxwx4znqSRXIa oU09b66s7ZFlmnkj87zimMoEBx0J6HtWCpxqQliU+510MRXjilhauxxfgi7jsftKahDEt9HbNcXK pCyRtMIyQwP8ROOOp7GvWdD8RNZswHmQRz2cxRI3MhSQkkZY84JyPxr7DgTmp47nj3/4B834j4Wh VwP1Kq909jy3xhaIutS3rJCn2tBIJS3CKdxBz+GK50QRBYYbplcorO3PRiD8x/MDHtX9rZLUo1sJ SlPY/wA1OOsLTyvM54WEuv5bltbWTbcmSPDzwwyA+btNusYAchTxhiM8mrghLGS8+zzSxPi0SOGX abdgQfxPP8q9vE4ejRpuUdz5fE5nGjThTow1/wCCW4bNpZMvbZk5aP8A0stJMxB+UoDjjjJ64NNB lH2fybYSzSSzRSAS/Lkcsu3phQDzTwcLTkprUn65Qr29rTt+ZJHGhlne3SCOKQC5R9mRuI5z7Y4/ CkNuzPGqoU82Tz5TG23dggpz2HcZ9MV21aNGpZTWp56y6nP2rjK3a/oTxwiSWRSkSMp+zWgByWIY 5DH0OTxU0NqryQxCPMJjItra55ES9zkYOQ3PJq1UoUqShNa9Dzvqqp019Yvp8/6+RYgtCPLYwNE8 E32YiMcRAZ+cDrz1H40skEc5cOiSSLMt3hF2lbjGMZPT5e3T604ucdWYzzCliK8YUo6LqWViVg0z Jm1aB7ty0mORx8x4II7HrUENmwhnQRTIpRfs8m4OJV3BlI9R9eRg1th8P7VPmlt+J24+MsTB0KfR X+4liLxwxviJWaRgXXOZWVstk85GT+tItjJExKwPHK8ryRILwSkLuB4xx74HI79Kc8NUjViePg3O VGdCrFpf8P8A5loxKJDNKTa5kE0UxckTMuQQAOhHvxk0NHJDPcQsUjhSOOdo4XG5g43gBudue+DX pTdK/sLfEb4DAeyoTi3oiGO3jjEtuol+WFUt43fdvy2doY/3eck8GpYYI4VEyRKJzIkMUqoAzRHk gj0HJ/GuL6vVw6c4aiwUqmL5k1sO+yRtdMhgaPbiUCV/mUHggKDyRxz71bms3kSCKO3V5LgPCYWu AmyJTwWJ4ySOB3xUOFeULzvYzzmn9Yy2MoRV195JGJI1aNJQlvbwKl1DG3yMW6BT1Jzjp61Zht5B IIpEEUhlZZ2kwoXaMZYH0zx3rreETpxqUtLf1qcGW4n2GC9niNyW1h8mOGLyJnChmKSzbtwHOSM4 6n1q1Zwq0iCGMu3mIpRf41fJUe/TGevy13RrUnSXuGuPoSq4OM6Hul+2CuZWiikkjVHkRXPMzgcZ Hsc/hj6Vd+zzBEkNoqiWFlW8NwGbBHy5HOepwe2K3pUq8abqxdkedUlWo04yh70uv9eg+OHymUyG KXzomCISdtuqrtMm3v1FWBAGRkxw6MiAsAdi8Ej+LnH14NP61WqNQt+ZtialP6jGdONpW1RIkQLQ rMBiaF0iadgRJhTzx6dOfeiEqxkl8tRHKp2yh8liAF4B/L8OK751FRSnU2/I8ChzvERiloWPK823 a1jLsJIFjeOGXkkNwSevv+dAjYTrMbdXUHJKMBgoNu4nrgZzz16Vq05U3OLPo8xhh2o4ZW/L8Sy9 ujwrH5W2bzHWC4kPmAAAdF7HGT/+qrVvDI00e+ISxxWRiuZ0k2CVh93r35ySteHWxGIpfu/bPmfe Nl+TZ15TgMNaaeG27Tu/zsD2aI0jJBJEhnRj8zFvMxnGe4I/rUxghLzMunwSXaybzJLKNipxlcDj jAPv3pV61SOH/eV9fmtfKyX4nW6FCi5U6mF322f3pyf4IcsKyJ5ccfm/aCEQq21jjqCeBgHII7/l TYbREmg22gCx3H2kwNIQpjAO4tz7f1FeVSxVejFzp1NX82/w/UdbCKdJQqUfdXy+WjX5D7OEny5Z VMbzozmJWMgVjkYz1x09K21slikMklvIksC7srdbfIHRfl6Enk+vNZtTrKdebvI0hl0J0qc6K0XT 5+ZcS03F3gWEgrsiWSfarDruPfOeDWo1ncpK1u8awRrGtpF5c6su1uWKsO4I4HtWtB+2j7CSOiVG rhrVLlmGMahcC1himeK2IjkVQVdHweccZGD1zXTR25aM20RWPMK24ljbPmAknlvwIA9a7o00oeyS 0Oaviowmq09yzHZ4ktz9mXy8MFjhu8PNAfvIT2OfxqZLSGHy7aNZYLdW3QxM7TPH3GW6kdOvTFTC k6SlKLduxxYynLGVlCqrRfX/ADNU6fHvleGNbmV/kW23tJ5W3OAVPy5bqD/s1N5A8uJIw0AjlWJy SQUG5d/J5OB+NfM4vMa/t24SaXZq1vLzPr8pwuBp03SlTi7dU27+d9Pu2J5VDSy7xC0bXRdJowVj yr5Xap5H8PBFaZt1MmZYItsji6bKAYfr07c815UU76HpVVOinOi92EUCKYfKygQO6kHls989u/H/ AOqpPsSKkQdd+0OheGViX2jjPPQjPXjg1vThGWs5aBLEVaVOLqR3Li28vlq8SIr3E5VYt/8AqY15 6eh7ehzT4LdLeE2qxLElkqsYwMhCxLr37gmlWhTUv3T0InOOIjeDatqPaJvLlJzPMjAKUcFiCemP 89KsCJVuZlRBChljTM0nAXALnp7HjGazto9TlhKrKo666EscckrfKGUea3yFvlmYdDn8R9OlWoEW VmhiTzn27UXfuIIHOR+orqw9OnVj7z1OnEzoVEmXrfIuA8aSRx28g/fXEikFiAS20fTHI61dMBCn y1SJljZypb5mL5fPU/kPatqk6GCp8lae/Td/ctbd2YxwmJq+7RhdXtfZX9XZX7IlSGODMrQoFmZY 1kzj5icL0/l71pJbhWtmfIRfLZ1Mm9goyrDA5wfSvgs1xlPE4hqjPmh0vFK3o97etvQ/R8twEMLh YSlT5Z9bSb+9fDf0v6kpA8y5ndCqJDtZmcHdGCSB9Bx1q3CrW53xwQsWi3kTRggIRww45PPFeRLc 9BpdSWGLzkeNrVHjkIDiSQ7mUDlkxgjqetOjtoSiQiP7RFDIHt3kn3ED7rEHrkf1quVpXJT7I1be 0kl/c20bStIv+iJ1D4yST+h49K/G/wD4LO/tNar8Ovh94O/Zl+H8dwPF/wAXL1L7xVrkUoSPTNOg uNMnm3HBJBikYYHJ7etfN8VY2GFyqp7TS6/zse5w7hamLzrDUacb+8l+Nuh/N3NbWml3tloWiQQ6 fb2FstrYW9uQgjh4TK+xAJOeT+tZzyMZo7OMokgAWcPIV8mMkjPHI46V/LyoSdd4ps/uytfBcuXU F7sVYuWnOZVJZ55CsQiOXZANob/ZyB9305NdFocHk3MsiqFJZXAkyjcMvy568ELnNZY7D+0oc8o3 RNPDYbnhToLXv6H298Ldbivo/tdxPEzPCkqRyIAMZ2OMcYY9cnPX6V6TNrp057yLS4jdSi2n3SM+ 1XLHCDPPRSR7YFfE0/3UpPv/AJWP07A1alXDw51slqa/h7UVtbeydne7eN2Cy4BeUNglWU8EFen5 9a6nTvF0V9cCC1O8PPlpYsbUc7kI7dAPXiunCQhUnKM4nbCf1ahKddXvs7HpWj6la6fZXNmZxHCl vlpLdVL3DDG3coOCAeePTn31PDyoYdU1a4mkurgQxRWKudpPlvw3HXqcfUVFFVqGJWJtaKaaKweK w1JxlUju0dx8NvGmq6D8R9E1OJo49KuL4QyxPMQSUtr51LMQdoy5GfU/n++3hnVk1/w7pmownzZh ASSehAJRW/EKVyeflr+uMFi55lw9l+N3vDV9L3Z/Nni9ltPL+LKlaKt7W8vXpodAqKCSqgbsM5zy zdx+dOwATweTzjv70j8sFw3YdByfxH9TUoUeYAUJAUhxvGeM5IoAIovMITGPmDKc8grz6/Sl8tmV gkZVEcyMpblCetAE32ct+8WP5BtCpn73c89etO8sxyM2MlFMmGOS+D19qAJYU2KisoKvh0kz1J5x +n6Ve6AA5XvQAgwGwOPX3pdwGOT/AI0AM6cZ7Z6UDHHzYxz0oAM8Ebu/THWkySMdhQAvoM+/ToaH fYkku5f3cZYlztUYGeT2FAPTVn893/BRbxVP8a/GI+HTXeor4V0WeLVdb07T5zGuqTRrbyQo5X5t oOcqCc45r4e8Dfs+W63um3ut6XcWOngPY6bZWl0ZVZVX5CRnnIAAUivLxs1iGqdVaRPmq2eYPLli Gp+83ZfdY+kdS8ZaL4B0iLTNDtI9LAtlggitrMbwAR5hZjkng4znt2r5N8TeL4ZE1DVNVJSOMG8g knuC4gYcqxGcAMMdO571+dZx7GpjVg57Xt/l+Z9h4d5fjcSpV6i1evmfkf8AtEftlLpPjfQ/hp4R 8D6zrOo65cC1vfET27bII1aYyPhx/AqNhVBJxxX1f+zX8NL7VbuHxP4xtYv7T1m5W7IlhEUNtGzH ZlSSNxyBn26c19hPIKeV5NB05aS/4KPjfEviPGV+J8PkdON1H8LM/XTwZYeHZbPTNPl0a1eGxlWa F0hIRrg7UJYDGFO0YJrv/G82maLpM1hplhDC4Rg2om6DNbbgu9Qv3WOS2Cc4B/GvyLirII1asHh1 eTZ+n8H5ri6GKUJL3I3v8j4Sv/8Agn7rn7SWvzalqXh1Nc0eyjlRiNPI8pMvG25i4DEhgfx4HNT/ ABG/4JHfsg/BjwpL4i+MmkeHLdDYjVbrQ7PbPJqIVUkAkAZhncBwRwPpxwU6WbZbClhKKfKfoWDx OV8Y5pONbWKufgP+2N+0j4V0jXNU8AfA3Q7XQNE0W5w01s24aVZKHiL+aB1XAIjzk7eK/JDUhcah O99qF09xcJ5iT3VxJln3Sbm5A/iJDc+tfsXD+Er5fg1Pqz43i/H08JinkWE+BfoYl2oGzZHEUa2a STHysDnhh6jArIuX3CVI1m/494blVdQWLbtgA7YHXI65Ga9hzqVX7WorM/PX7bDVmoK8TXMM9zZy ZCwzSMWVGJJiLYVWYdDtH86vw2d/LN9lQK08oSO3mWTiZhkeWueuf4j2HSvUpVHUc6knojtfsqb9 rNbkFjBcSLctHJNFLKkeHZCGdUyCp7YyTgnqQOOa2bWwnuUa1G5zewkRxH70khO1gwxnG0ZLdO1a 0a/t1tsc1anh4YrmTtua4tLia2hSWMyyJGJr2VWwDswkOQR1GP15qpDp0zGDCyW7Slor6Fl4gK8r Io79TwfTr2orS9jTlKCOurKhXoqnFbDJbFrnaBBslt/3EYYggoMjcT1Oe3p+VUrrw6yWkMkaf6OX GZFzJ9jC7VZ29NwY5POSPasasI1uWtBmOW0qtWpOhQvYiWwtvtFtayTslmsksiXEa4MbFxnjPTaO enI96b/ZOmzskIeKOzhmuZIrmYKAzggnKfe+cAbR0+lY4ipWjD2VWJzOVfDVXTxJbTRtLy6To8Yj HnrHF8rTsQE+f8ATz6cetc7e6ZZQ3It7RUdsPKI532rL5mAHJ/h9ffFcNCjiqUPfu2dlTEU6uDca cdTEXw0080ymzAu9SnNgYmGPOLH5GGO+QFz3z7V+if7P/wAOrHwj4Y0+5kLy6pqKxS65qDHyJTI0 K4BB+6u4FsDO3bjvXxvG+InXxWHoUXtv95+meHWAjHJ6+Mxcden3HqGoajKlxdaVA6ypb3ZtNMET BxCTmRy/1U7iR9O1ccuvS2xSeeLKyStGl9APMkh6Daq52gHOcngYrz5UKEJKpT1a+R2/2jXw3NTw 7vfz+Qy/11baRZSEf7RZCG42PgBlySOMkMAATx0NY9l4tmtdShjyiSwwrcNJImVnBfKYPI4XPBzn j1qvZ1XR9qo2DE1YOKw0Xva/3nc+GrkyySvbZ+ySXLXNmtzc53o5L4wfqePcV6lDDOdSe923FxbG 2AnR5lU7UG/JYDOVIOD7V85VqUo1HUqvVH1OHw7w+Agm/wCtSBbmea4KeUmpLfWE95ql5HAQSw5w /IBKjDZGAStcjpmlWiRl98UiXVm1sNRyZBdszDYd/Uk8HsAPwroeK+tVYRoL3f6/ryCjhY15TxtR a2fTyPZfBNktm9tFbRzXEt/r2nW1zapIWkmElzHbvkH5gPm69lYnPFf0S/s5+EYtM8L6NqeYX8vw vKLZWkUeaxTErbAcg8HAPTbXxPE6f+sMcO5XSv8Anc/QuFaNHDcP1sQormdvxTR9ReGIhcW0d5sj 8uZ3lWFTvECEcMCTzu5P4fjVi3tdUudVv5dQtmshCxe1cyl/PRtpVlPGDjkj37ivpqdarVwvsYSs /wCkfHfXJrEyhKGmo+5kltbu2tAkUcm90nhNyA0ix8yeoOcgAZ9qwtdTbHb2g3Ye2dL83EZjaCYy HA2HsV/kKypYeo6c4SOSnjVKvHGN7s8xlvILB7W2YAKWBVHkyg+Vvm/IfnVm91MW8ioU8lHkS2iu JHyYULbsKRwc9Oa+y4Wp+zopta3R83xvXnjJ2Tto/wAzq/EqQto+l3jW1uIwXhW6W6UG3j2SkswY 8jIArlIWiEMbq0Ze3CyTNKh+TI+6M9cg9un8v694TnOeQ0ebbQ/z+8S8rtxHUrVpd3YnWMiOQG12 MJhbyIJSXlBOfMJOQR6D0+lOlji2pDMFja6zdGMk5kKH7gH+7jp0zX1Lnen7Ko9tvxPhpKjOvFwV ore/9MswZSJvPgYyIVmhBbBj25ByepwCB69KuKFtlCB3jJuGjhHnAlodo5b3JbGAc16NKhCCjPqe ZUccVmH7t+7clhHlNGZbdXt972xVRjKlTjgeh6Z7U2C0lSAwzEt5dt5CskgaSbacbQDyxC5604xb qe0l8j083+r4V06lN+tvUkWG4ZSJZUMvmedDPbgRoTgHJUdCBgfnVgRI6RvlPLljcNbgBfNIHIPd ADjH+FcFp4quk/6R5uKoVK9K0dn941YYpoBOto0IOZN8rgltrYU7upHXH1rR2gWaedZ71BEMUUs+ 1hk4V/U/j619FRoxxEGm9UeVl+HnCs6NdaL+v6/yHPbXLpIFs4I7WMMs/n6kBKq7SuI0wBISx5HU DmmvbmPzbiOMyvFGIBJ5xVHyo+Yr0ABBHTtXHOM4XgmZZl7WNR1b28i1HBPCY47mLyJJ7ZisAfBV Su527feBqGzjxNFJNBGJo5WYEnYksYXCHqCp24HXJPanH2kJxlEqa9pNUr26/cOFrIFhI8tVuFMX BAZWYndk9BuP4GkijWNLVmRLpLS6aTyWjwIDtIVR0J4xg+xr3fZcslV7nm4vHYrFy/s/DRsluxxQ 5zLGouwTDFAjHKg4PLHjnOcduaW3jEscWIpE8gFxtYESMpO9CPfOAc8VlQrSp1ZRrQujvqUKtKjT hSdv1HQNKittCFZQU+c72jDchfqentWk0TPaB1PmXAISZkAJ2dTk9Cc4x3rdxejTLo5nh4upgZ7k P2cJIkkWXJICAsFMigZB9u+asxWMEMMSMRJJCWkyGIaZickjOcHkDrXVTdSWEklsj5zH0I0oNVFr oTRxTPb2swtJo2IaFowyl9q5XkDjB/XJq/Fb+WqTC33MEdZIcY+yAkbWJz68fgOa5ov2cFBI6atf 2+DgqislY0LS3ypu0it5JcG2jbzgAjbuSqk9D34OKfDYSKzJGrbI7U3VzJPcfMGbJIBPcYxj3Fdy ti5tJ2RxyxlTDVOamvdLECSxRxII2WX7ATcMy8wuzACPI65AH05qc2qoJIlKAF/s0jo5w4IyefRa 3pYeNOLtv3IwWOWJlJKOnmWnQRxSuY1jitIxKsDH/WKx2bV7jOB3+tJDC5CQbI9kEJRoy/lpZsRj Yvc5656cV5WIxlKrTcr/AA6PvfyRnl+XYmlXjUqyvz6rtb17+l/UdKdkNvGoRvLURyh1CurLna+/ HQg4+oqcRs9wVki8iGKQQ5aUEzIyA5I6n5uuemBSlXr4XCQnKbXMtnrfzWulvl6Hu0sBTq4ipiK6 TSejvblXZpp3el7u/qKlu5iiWSBGkZ3BEo3AOONwPU4XtjmrVxYoUhmmhhkOGAUsWI2naJN3AAye nrXFRxmJu6tGTTS66v5XV1951p4eF+aKala1tPvSdn62XoO+zYJxGzGG4UriXnOD17YxnFTvaRma 5h5ZDGQpWQchcHaPfnqeTXNXxU8RH95udThJVfYrcnki/fM4RJ4EkRgEygucD5lbJ7H0qL7ILdlQ rcO0+9XljkIHPOSSenbA61hFxTvM9pyp4WCdR3vcvWFhcPHLHboZFNx5Z8tipm/+uB/Kr1tFK5mN laoI/KaLyNSuAzKmSGJyPqRivRwtGVO7T0Z85mOOhT5p9Xsi8La2le5tmtoIUmIt1SJi3LBXBUnn PA6HHNa0MHzJau0EdwkbNNI8m4pjleB0OcjHfFdmmyOP67jFgIqcdf6+4v2S+d9nMav5ggeNmaX/ AFo5OxAOAOT78mtoQJFDDbxwQRJCzL5avt2jO7ge2Mc9cnFLVWSOXEzqxw8cTV300/Mu21mtrFKk URtyoMscRnG1S5DMwGePvdO1Wts0CGZ7byby0dbmEJMR5YJIDK3QjBPGD9K8fNakIwlh8RKzvpo/ 10fqj6/IFiva08dQgmmtbyXpsldej+817a0naWCKBIXQ7HzJIIwVAPc9SMnA71O9uf8ASJCY84Db lPEKnjJx6nA+pr5hwcmoo+rqOLm6kIasljs2CeYsGFgtmvHCY/esWwSB06/41oQ2bgNIFeRkid54 w25IwMAfN69z+FOTVro5qNepOTTiEUJ+ZwzvHzcRl22OFwANqnkepzUq2/nxLE8rGNgJEw5QxsCe fl5IGec8GlHmb0Q8ZGTpWRZ8hGZGWMARzb0WOUqAQNuCp47ZHbnNSCHAuTeJNci5s1tTEZdrRAE/ xe2ePpW1Sl7KSnTfzHRrYSlglBbitAr7kmiMRmXMphGCCBgZ5BJwB7U8RbjLM9vHsgAjaVbgHmQc YHXPHP4Cs1CpNpSV7nnUKk4txW3/AAC3bWsaybZY5jJcv5imS4OxFUcgjtnjpVm32yoZ4YVaJ5Wg VZZM/KuQw3DnGeOma9WnRp09EtTmq1Eouo0X4Io0jdfKzFJDuDJJtaPnhlPJ9sHsan8mWZo43hmH meYZJXwVwAMZGePb1r5XM8wVCpVUKqlPazi7xT3tLQ+0ybDOvTpTnRlGDV21Pd93Fpl6OBj5Mc0D 2yQhhLAy4yQOB7HOOfb3p7wypdOktk5ljhG4wTYecAE4C/l3/nXyEFq00fYzfO24ltUTy418oiaO 0dJo9/IZiWYc8H5cdasRqEgZI03llC4UZEar0HqMZOB7U7OL2FZwin3LEUQSXbiVzJJscq33FPOf U5Ix9TVlIGjeVDGkOFMdsi9PNBJbdnp6mtOl2RopJGvbXmnaBbXnijX7qDTdD0Czk1a/u7psRiIc HGT1yRjPXiv4nv2mP2hL39qn9ojx58cWNxH4XMEPhL4cWV2z7xp0cVoJJ0JAXZK0IGBn/V53dq/L PEnEU1lyw6nq2tD9a8IcL9Y4nhDl6N/d/wAE+Z7qMG7kMaO80kr27SbwpRCS/LdscKO+KxyjSXSS yfxXnkzyYwI0C8Ie+Bjr7+lfh1epUlQUab1R/WmJVSGJdap1+43oUeG0vbmCJg7MxVUkx5ZKgBeu RwMZA5ya6nRkaBGudytmFzaL/CnyfIoHcD16857V5U6+JULVdF6GmCgqlZvr/meieAfFy6Zqtnob P5kl/aIln5R5aUqW24PX7p569fSvqXTZJZLVZvtTqwVrqeJ0GIMAZXPUh+nFfMY908LUcpep+lZT TjUpQo82xy8utXEsgMFw9vApiQv52PJCByrDnAOSRz7ZrttD8UWOlXUYur2zTbaNf3Vy16HUEgDG BxuLce2fevQwP1jERjSw0Lrua5tTw+Hrc1apaP8AX9f1rp3nxj8HWctvY+el29tMbdJLa4xHtIcM MYznIxn3r1iP4+/DSSztUt3vtNubt44vsf2nzQAsa524Uc5XmvrsVwjja2AjOHxH5zmXHeW5fm9N UfejHTT1/wAjp7j4o/DHTNHXUtT8YrFcWxi/tOLThvbYySZDAgfMQ652iv2B/Ye/aO8K/FC0m0mw 1mC/R4ntzNMSrs4uLwMChAKZESDJGD29a/cuAsozaPANWeJhpTlFd+j/AK7HwHizxFlXEdbCZhhm k4q33s/Q0oUZlI2FSAwJ5/OlKluFJOTtyoz1/wA/pXQfkI+MLuYEFsJuCqcBvUfzqQRNFsLYynzH vtII6/mPzoAsRwN5JjdBnczht3fjB/z6VMY2Mju6+XsTZGd3U54P/wBagCYwqzEtzlNhXswHenbT wVwQSScdqAERQgIGSck8nqf6UoIXABz2P0oATPct06cdaXcfXPtigBuT+mKM44B4+lACg56nHGOl L7bu3HFAAp7BsZ9u9fNf7T3xk074SfD/AFDU5ZI5L0hIobZZgshkd0SMDPA3M455xSlLli5djnxc 1Tw82+z+8/BCwuNQ1CYeINdsriDxD4hvv7X1C5F0Gljn2qHGTxtO1QPpWB4z8cLodlcDTkuobs3Z klne9G5YztKsAB65H418/i8VGlGU3ufEYLKKePxlOWLjbl6eZ8qal4xvJhHrmt3Krp1lcS3DRtn/ AEgKcMofoBuYZ/DtX5t/ti/tdXnw58JyXPhTw3c67cXGoS6Yurs+YbECJjGsfAD/ADrjAU89xXz+ W5Xh84zBSrbJ3+7XU/o3KKtPKcgq5nh4pqKenydjF/Zs8BeL/H+p2fiPxP4ZZZpbq21C3uryFY/I nxIroEbMinEpG7ow447/ALb/AA68KWOjaHoemXVnEZUYSQlLpGJQKQAyjPzBhnk16HFmZRp1FhKG 0ex/PGQ4mtxNnWKzfF07JvR7dP8AM+p/CGjm0tLm7dBGHiMVxhSMqCCBj3DZ6cdasWvgvxR441fZ /Ykkfg+ztopoL90SWDUCySJ5bx8OqjKtkjrXwmEx7eNdXE9Nrn6rg8vlhcprTc/elt89D2rxZ4w0 f4AeDvteo38lleW1u1+dPYNCFVo0+YYPP59vxr+UP/goJ/wUL1Tx54q1nwF4MvrW+lTV44tcu1Mk sCwNHMskWcbPOJVCcngCu/KUs1zNyn8Mb6ef9I+m4fo/6pcM1MwxUPfltv2aPwU1nxHfTS3t6WIv dQk+0xLIOTI/Hz49xznnIzXKSzMJrqORJ2tlnMjbxjzUIAdivZifXOeO9fos6ChaVP4T8uqZhicT iXisRv28ii13Ip8xxLLvtxFGzf8AL0FBCtwMdB0wMY5pFYQ2JMZEwjuFtNkZJMEjruwSe2Mj09Ol LknKTppanLis0jOu4xTiiWP4h6Dbk77VZIbLesVmZmy7kkKZD1bBOT6YHtU8nxF0CdbaFgqiNriS BQuBMV2mR0Gf4enXmvoKeFlTtSlpp5HVjcW8TKNOMbRRlQ/EfRHMqwSK9vI4lmP3TKc/J1PCkckC td/iXp8otM7DKZWRpYnJCLg4QAc4wOcnvzXFWqYfD88U7NHq08rWLhGd9DudM8b6FqehBLe/eN7g 7bmGUBGCgABQOoLFvxIFWf8AhJrH7TcFbOJbG4vvNuVDcXsKBQpGfmVgykcd85ry55tTdFwauz3n whVowhioytF+ZmprIhtpYV8tpWleAuFyXIIYgH+IDcvPHNb/AIf8YR6dPNHLHDILaHy7iF4QUlck /u8HhgOpPTnHUV41LMoVK3K3ofQ4fJadCH1uxyHi7xXpOofabi2tU029utxvII/mikOc8DjaB8oH 0FeIan43uI1EYlVkmQQ30shx9rOR85x0bCnJHp719Lia1PEU4qL1R8diMvqUa0sVXV7sp618XWvb oztBDDNdEzXEoX/UfKRC2ffjj2HFcTN8QtQN3EjXH2xkYRJHIQu4YAGW4AHU/wD1q9H6ypYZSS2/ 4PkebiMO8HiHNbS6HrPwavNU8aeLttv9o+w6fBDqcyNkvLHDJEzhcc7iHHGPlGTX69aVqka2L2MN xFFdW955cUl3GGSK3IIwSOMfLnp/hX49mEZY7OKs63S5+75FhvqPDUI13bmt+pi3V5JdxRXgkeKO S6kWJxIM7AnzOoGDtbaePauSuJHJj4WONtMnt2MLY80ljuJz/snII9cV14PAqTlUtozhq1MFhF+8 ldv7jCttM8Q+L9fsvCvhWwhu9a1q3DWV/YsW8uKNkhbzh2BWVCG6kZr6D8DfsS/GHxi17pw8T+FN H1HS9RjsPsd9MbaXWIgqbWZGkDKUbf0PORn0r4zizjihkteGCoK93Z/ge/wvwRUxqedZg7J/Cn1/ pjPFvwR+OvwD8Uad4b+I/hXSptJ1v7PfaFq3hO6+0JCTceWscqMeGJQNuViPm9q9oi05oLfU5cRQ Qi4NpNFcXGEmKqccnqwZiB6kV49bGVJ4qnjIbT1/Q+jxuGw88PNRTUonDXGk2UF5pBkuL+J7aBrS 5SGMlLgbcFSwPO4tgZ4Gcdq517MW72Gkwwv/AGfJIkkVoYyPK8ty6t/tYYdehNfX5Uo4qVoLXf7j 5iljoxhUpTVkr/kfTXwj0ga7428IotvELkST3n2lgHK+TcQK4B7EiQrk9c/7Nf0BeCBBo/hmw0yN DFdyJGHKD5RCS4eM/wC9wM9cV8NUofWuJ6/tdos+ty/EOHCqjQ3dv1/U+hbCS3h0ia4ht40gjtt0 YhzwSML7AZ4z6Vc0xZpNJSKaC2nksjAHu3l3s8nl8DaTjaADjr719fGhSlF1L2aPnMLXg1OWK32K EsK3V3HJbRPd+Xp0++1V8BG4IzkZBwDXP60/nXasNqJGnnlic7pQPk6nIxyMd/wrbL6U5upUqrdn lYyVLDUlKSuuny2PnnxbeXdprtvLFbn5o2t0SQ7QqBxu5PB2kng+tUbnV0n1SOCTftimaaO2PGWH IORnHBJHbnjpX02W4Wrg6rcvhvc+Pq4uWOnKdZaao9Ba4F3ZQWkEKyx21icDfvWVmd9px27fXFa2 mMZlzDbjzraWQrDJ2LcDJ9QQcAetf0zwBXeIwX1WMtD+PPGTJMQs4+uYaej8/M2PKJmMCIkkTMZi ImBLnHJA6g5yPSnWqb2s5pbaOObYltvkJD2Q53N6Houe/NfoVDDqVVxnsj8OxOBdWXtHU26f10Hw 27SOcwG2jt5GYylt6TgtucjbknnnnmtApMInaNC8VoN0v7zLJGx2rxjJLevbvXc6M1X9tF6dTk56 vsnDDKz/AK7WGSKrXE4ZCjRSLLbSmPccuOU9CR19DUzW+2ZX3MZ5VTzZlPKDOCBnp2q787/dyOqn HFPkpVFfzEgtMI4jVo55JRHmWYAOzEk7R16A5q00EtvJDJEuIkjYiKOUbNpGwZ9+elaXjJXjsdVf GR+s/VZqzXyWn/Dkwtv3AjhjiTzIFuUlMmRcRKcFCDwD8pIwOgqYIZEkURps3EIT/rVRhxkH1PT8 OlWpcs26ehx0sTTeJqQnKzQvlK1za72RksQyT7zlXJXK477snP4UsZ2PFb7YmldnjLyyENG4VuBj g56gHpW+HhCtKUah5Ga4hU4urJ310sBBjXDRxNNbOiJaC5B8wFCNzMRx1/DmpLNFDxwahaMojUyr Ako/dv5fGH9OAefSvRjGlRppVehnQdWtQ+uS+G3Qnt4yPLkltJbqLO6do5gv2jk7VPPGSTz25NMF s8pb91FHM4RfLju1khtSudwEg+/npn2qaOIVduNtjlo1msLKtRI/KSRjK9ruhDnzQX/ew4GMj3JA 69hmr1jCZJFkjjkS0jhLScYK7TxuxxznjHpXQttjlr4rHVKMZQ2/zGpalUnmMaXE18Fmlhi/dmAq 2AMAnJx1FXlgaNmESBJJHaObzCAT8nBBHr2rto0ovEtTXyLpuOHu5Ru3+HQjigkKQjYVjljxHcMm 3JThuT2GelTrbzTyqIbYu8n7uPyss0m08jnjk9xwc1LrqnWqRktGdmKnRhy0K2uhPFbSWZmlmn+Z H81YGiK7o2GcMc9VJwOOasRQKxRZ4EDXEUcRImZ15JOF9vXNTQrexk5OOh4GPqSgvYxXu/8ABNJV iWVw9r5SNJFHHH1FtIFYl8k8qeOP51ea1uYJY4pEWGRNtzcpKA6yTAYzjPIwenSoVak61oxa62Tt +On5nbTwM/ZKpGoktves1d+Vn99iTyFilXaiStHGRL5S4CHtweRz0qWJDtTbD50wQKq7yGLdNxPQ nHtipxWKhGFOtTm0100f3pu5GEweJo42axdNOK/xR/FLlt+ZLHa+XJcLcgykMPORH6KoJTb2Kk9e /FSQK3kLc3KxMIU3NFCDukJOCN3btxXkYyv7eXM5fJLQ+nwdPBzjyxgku7ev5f5ehO9s5MqMUBW7 SKSRl3qgJJzkcEsOMdOKfPbjz0VII1DTiIy+YWZE68Z64A/Wrp3qYe81qr2NMRKkv3UX7pZgAlSC UW8NsjKEuUG7DgnlvZiBzjjNDRuyyqYZmha8EZ3SKcwkj1POOp78Vy0ZQi3UaOWn7NRUaexZ8rbJ NI1uSyTeWkckh2QsvXg4zxz9enWmw28SpAGtzIWlMExQFZJPm5GOg46d66qcKSg61fRM562JdD36 T5pEnlTLJO32PzPNusv9om+8DwrFh3wPzHNEERDOmyIAxvuRyWEuecj0OPSpq0KdOi6sX6G0K1bE 0+eqrSLltAsgmYWJF1EkcU0cc+Ci4IU5zzkk5571qR7YEM8UL7o4SX3yAoikbecZPc8VtRqqlho8 yLpqGKTcY3t3LscC7k8u2EkcdsrAJLgrycFSec4Bzx0q8kb4h8qfyWF6JJ3igDZXHzdfbHQ+9dUd bzXUmrGDj7G+v+RtWdpIVSaNIyXmdGWZhHtcfcYY6HPvxWwIBFvLxmN0nWS5eQBiQV2kDBPBPrSr VVTg61RnHRwmLxk4w1Lq25ja5PlyBkVWHmBT5in5T1OQenHuDVmOzcCKD7MVkaMs8TZCxcYVe5we /wBPevkquPqVXL2Xup726+v/AALI+3r5bQVClGouZx0Xl6L173fmbawxSeZvg/1VuTHcRy4WDbgj r16EAf8A6qSS3ixHdtGftE/yOcZWPnIAA4HNcPM9Y9D1JSVGlH2ktWi4LCeLypJrZ4EkOQ7jb5kY IOQe4J/lU8dui7Vhj8vLTec7SktIrDgHPYDt7iqjRctLnPRrTc25/D0LkFtAE8/7G8iLGTNkEbk6 Ac8AhiKZHZ+bBE0kUuRE0dyUmAaKQA7WLjjpnpXTHCzp1FyaourCCcq0pbrT7izFbO6OyxDylizu 2cBB8uCenX1qaNVZXQ/IDAZGaI5EhUnBAPI9OtddOgqbkujPP9g1SVa+jFVI/Kika1Mg8kpn7Qx8 ttxJCj0z6+tTLa4gkMtqDM9wN0jIfM2qTtBwcAE9z61SlCElTQ5UKlJKVVD5IZHJBhiD7FedhKHM ZI2nHY49jV2O2GxhCdsSNgSbRlAR125+prLF4mngsM62Ilbz136dzWlhpY6t7LC07+V1svV/qWoI k2Jt05oJDbgSzm78xbna2VULgbeP51Klsys4njSZ7icGWCfOxwMklmHI5A/OvzCrOpXxM6kpczfV dfwX5H6dhIU6GGjCnDlXZ62/F/my/DCVh3sWIaGSYEyFt7Z+VAT/AD9qmt7ZomiDsC8p8wFHwZBt 69yORjHpWacb2RrdpluKNUbcqM6SQgPEo5XJyOT24OanijcAbgoMiGSdUY8PzwPw7/StKcbya9fy NXVfsvZMtRxI0TsTsMiLuWLgxlcBfwIyOPqatQRMzys0eGk6tjAGSQcd8jFElJxd+mhKeiZ+WX/B ZT4/3Xwi/Zlg+C3hSXS5fHvx1STSJLK/uDvttOS4sXuJnAVmBVHIVcDJHBHJr+XH7Bpfh7TtH8K6 XYwQad4Z8LWek20FpJtXSoEjSJI1Pttx7fjX8/8AiPi1WxscPSlpZ/mf0p4H4PCvDYjNp/FB8v3q 5meS8qWSTwmWY3JMzRfIWY8FiezKoUZ6HrWN4ldrOZZ4N32ma3ENtIeVLB9q7x03c8HHIAr8vwUK 9D3on9CYudWpRco7s6LTre1jkD+ZIn+gySuJEwAUH38k5+9kY9DgVfiuLh57e1to8XM2mGSCNnB2 qx/ebe3bj26VjWq1sXUlCcbbnm4KKoybqv3kXdL04WOr6brly0h1FZbQCESEbIXl2MMfw8d+vHSv rGC+I8PK6vNcvExFuHBGY1AYBj/XvmvhMydSWOjSktL/AJv/ACP03gmt7ec6tTzPkr4zfFB/B8Vn pbmZJfEmqSqJHUH7Mhjlbc5HRMoF5749a5TStVu7yz02CASRSaigXUA9wXLGQFvLJPGwAnBPsO9f v3DOT0KOXU6yW6/E/JPE/NsZQx06GDk7XPQtP0VtItwkMUSrCpeGaIgxyBxnCuOhyf51s6YsFra3 N1cQItjbSI8dvGxDyvj94SV56/nn0r6yCdOmqS/qx+P1sNOrVjian2tX6lhtOtrt/tU2wyQP95I1 d7t1GUQt1wMjr3Fezfs3/HHxP+zj4qm8V6CLy90zVLhJNZsp9RxJJKGvXZz8jkBpJwAFx94YHFfs fg9mOCnWxXDecxUo1VLlv/Ny2i/vZpmGBp5jlNXDUm046rvaOtvmf1l/s9ftaeAvjL4csTNrmnxa xcXExVGuVBQK8ioGTGfuwSYOMnYTgc4+vxG0ih41JR9jJgdMqD/WvmuJuGc04TzWplOawtJbPo13 R8ZluZ0MypOVPSUdJLrF9noieOKJjGPLOSrMx3HkdiPqamSPeu7aN3lh87QN5xzz2r549IsImwKD yQuCfX1/Oh04jGdoVwTnnOOcUASE9ie/cUZIB5xj2oATPU9Gx0x0pCefvZBGCcUAJkg8HjpnFJnt nj6UAOzwQT244pox0zjv0oAX7v3Tn8KM5ySecccdaAMTxLr9l4W0HU/EGpTLDY6batczyMwUL26n 3x+GT2r+Kj9qb/gsF4B/aL/a28V/Cr4X6lF4t074NeIDomqxadJLJDqWoOYd5hIiZJRE8cinD7Va Mg85r3coyn69SqYio0oLT5tHwvHGc1cuwcMPhY3qNp/K+uhpX37dfgT4ZQpZ/E+a0h1e6Ml5p+jy TETMifvGKKgOMJxg5BJNfGOvf8FAfC/je81SaDSNU0u0trkW2k+fGY/tMeQ4YSEYYfMBg45zXyeY 8OONR8s9Dt4czqnWhThi42qPoeH/ABl/bF0HRvDUGqSalNfQx6nHYWmgabHuaZplbp0BYhD1IGVr pPgz4e8T/H+w0XV/GHw+vbDRbm8N3oa6yiKt0FZgr7edjHerfN2GelRDBYLIsJKdSpacun4Hv5zx LiaC/wBXsBrztbdFs/wP1t8FeGrDwj4bsNGstPgW4tYmjuWjIkNwcKpYSjkhRyB9a9/8MRwxzxyy 7WBiS3sFiYEzcsTkf3cDqeePwr89jB18bP2krptnszwFPKMnpwjG2n4n194Ls9P1KVmksWMEM5ui l4xaJHKKAUK9QQcV6v428V6N8LvDv9sa5awRW99YFrSza6eJWiXapZj1brkYIx3ry8zoKlLlprU7 eHcNis2xFLDyldK3Xpc/k7/4KRft9eIrzX5PAPhGBbmW9gnluNVhv97aOgSSLzEQgoz5AwjEY688 Cv54tR1W4guby/WOQ315dq2o3O397qE8gwzSMPvOTzuxxX1HDWClhsF7arG0pH6XxnXw0cPTyWKu orp3RgQ3gMz+XKbp4gDA4RVDFiQI2Y8Z5IJzj86vR6WNRgT+zXk8tnBm2kDyp2+WYhT0UFcDrzz3 r7GhD6xy3+GJ+H42m8BXlXlqv8zldbutC0W4XTLjVLe7vJb4WNnZ6cDcXFtK5/1LRqSdxZgSMZGB 2Nep6N8CPil4lSOKy8Fam1m7vDcatbyq0UciAFcqSpJPI9uR2rlr5lllSryQqK67HyuFx8MxzSpC EL7+Z8MJ4e1N9wkkkaRp9/IO1SxBZvTPHf1qSPwTqzJCscUk+590m18Ag5IVc9OmT9Kzp5vXxFbk fX+v61P1TFZeqVJU7XbLdr4TvYYDNLAxijljhlnUny5nY/KynsCPy79q6q20aaCKONrYs1s/yN5e Gk5x+AOQPm9PwrjxVOFSXtaktjSNCWHoxgnoaMVlLZ3BjXMjCRpiI0KJOMgsST0C88H1yK6iz1C8 tlaVjK8SQncIT8sxZi4AHZS2M15nsMTKpzU17p9vhs6wkMujRxCuzozrVutjN5tkrm/nS7urreV8 twMYA7Z4Hpx9Kz7i8hFpG4t5X81GMOxsGKc9dx5yOn9Kwp4CLrpRYYjOqPsVSw0fdXzscbqKXt3a TGN1DxXZkJi4kYngjHvjPPp+fIXvhu8lkMqwLLDJc7VWRyEZ2HEeeDk9Mnv9a9yNWnhUqM9T4fN8 XGtW5KO3Y5efwhqIjmiuTMbkSBTJPb7GZSDgYHAOMD8KwovB+oySRoICzNc7YUkONp9MfkK2xWOe BwNWp5afczloZTicdWpwbu7r8z9JP2Yfh1D4M8NvcanBO2r69BFfi4a2O+2i8vcsat1VTJuY+3Ff WVss83kxQqq2mxfNWHAkknjyEYn2ydwHB46Yr8pyiri69atias73f6H67mc40sFSwc3pH10LGpLF FZJbjy4riS3mhuXT5yxRvkkAI4wrEH8ua5DWdOaV47a0Eb2dxZTxkCVmivnkwrKJOSNuCSe2cdq+ mhXqrDVaEX0dj5qeGnUr0J1Hdcyt96P0M/YY0/wpLoWt6XJc6GnjTVLiJo21sLBIbZI7f7PsLYO4 n5zgjG8g8ivoj4jfAK/sviVb/EjxXdwad4c0xF0y30/wr4pYSX95LcxyxyS+XJ84RIXGwgqRIc1/ PlXDqpOrhcRTvNyWvyP6mxtPC08qwuIoTtFR26as878aanq3ifxdY+KIEA0eymeOO0N6xVCJmUID 94FY89eu4dxmuYuraxukvra3msW2TE4zj+zckghyQcsNykdc5FfZ4anKjQhQnulY/N6tec6lVu2r /I4m88J6ebiO3nk8pYmEkNy8x/dqr4Z2QfewVHPSvN54Le81v+00hgWW7uFtIJrK4L2zW6tIIyg/ hyxYkYwM+tfacO02lUrrTSX5HxmbvDupGEHZ3S/HU+3P2TvC95c+L4NREDLtE1pHaZAWd2e3YSZH CgAGQAcnzMHkV+zt6t3Z6imlRQeSmlGa1tdh3qrqxDgtgHGSTz618nlHJiczxNd666fcfa57KOW5 XQpUdmv1Z6LPqCRaPpGk2yXVylxErTRpMALchgjyDpyMgYz64res7m4ghaxGd8bjMgwCEU8gDuf8 e9fU0adGpJUqi95fifBPFycZJaEFxei1S7uLS0eFZZpZfMWbdnAB24P1OcV57Bc217dTyKWaSQSF 4drM3yqSAM/n1rtoV19YjRpwt+BlmleDwfIpXZ5j478pYb6/MCtBIDeECQF0j+7jB4yWGTivB7DW JbKaVg++Q3McJVjtZ2Clcg/p+NfV4jAxh7OvN6o+ApVpxqc19+h654N8Qbbi8ikZo1uIS0MW8BX2 hs5HYZPA9a9P8LTXtxHKJoYEcuLmF47neJlLyDlf4TgAkflX7D4a5lGT+rJar9D8b8WsFJUnWlHT +rHb26M8oZHV5Wwj3AwmSDnK47HgY9vynRJZZoSYQ/lJ5aSkk43Z6L36Gv3mCr1KyhTWh/LarYTD ylKaur/1+AiqsXlXSxcQSm3jxJtDEklXAB9+cir8VuIdqPDHt4jk2zlgz8nJ9fX+dVUp1I/u3ozG WY5Sk1QXvMmSEC2mURSYilTMyPkwgvnnPYA59s1MgDO0b2jJeSSA2twkwCsqg84xknByM4wRWlSl OnJQaPJq4mtGDp05XfT+txrWxWW3f7OrxWLlIEQZe5DqQDnqOhJ+pqztEU6SzmRWglw1vGoHmggj n6cGrw2HVVPlWiOTG4iNPDRw83+8e/cese2NpFgkY3EhtQzuB5KnGwkdCSx44pJYV+0yt1uoFxuZ 9qkdCc9Mlgfpzir51OnGhFW10OPL8JVpxli5yvcl2FZpn2BRcny4ndvlhX7rFhnnnp9asPbNLI7C OdbmMje5myrpt27QCOuSOfatqdCpSrq2xtiFQxUVRhrIhhhizGAE+zopEUsqbhesAAUY9c+9W7eN 3WGV4Vi8y2eXyEYFoiDlV+vc5ratapKOHXqdePw9anhYuOi6r7xqwEKCCw+0vult4ZgftTBcZBPy qSM4zUMdrbx2lrZw27WyLIHhtQQXiQnIUlThiDnPsa6Ixp0Y8sUeNHEYeMKdKL06jXh8uZcQK0CQ l4Ywdy7Bk5znJHPPPariW+1HiiKiCYpKEEpJBXGAuM4yf8KunUknzrQ6cVz04uCiuVlhIg5Ushjl dmlfee5G1cHPrzmrMdrG8LeepI+1LH5e8DHBGCO+Tz7V6tCarLna95Hh42jVo2xLkIbGGARLDZFZ JYJRd3McxZJWdgOA33AT3q1JBGIvLITYsPkTqoISVO5x68GvPdOcqsqTWpm81hVw7qSjdr/h/wCv zLP2JIxLbxxyqpK4iM5dlAHIySSc9+avW679kMDNvgUZgYYRFU5wG7jBzxmt6LhRhNVtP68gq8+a YONTD6Nd2l18y+ttH9kx5YMMkUlspZl3kjJwcnOcimRrLGsRtoEMEsLPGjNmRSvG1QeMHr+Vc31m nNSWHqNW7L9bJ/Kz9Ttw6q1J06dXDLmWjv17vd7d9NehpQWyM8UL6eYmvAqzPc3ecF8kg+3AGOnI qby4JxDELds3iKlnDbXG1bIocbcnkgjPHsK8Wtiqlau61R3fp+mx9LHKqfLy0bW7Xvby7slMEAXC Rrsb5Y8yFlXjgk+pK4/L1p5tFltbpYoorV2RpPMnZiiNwQVXOCMjrXPyubtE0qVKeFwzozhsaEcD C5itkzB50sLveB18sEqxIP8AtDIxngbqr/ZIGZW8qRQ6EJGMMYxjnp17/wBK9asqsqShS3OLB2nK VaorJlhVOAPIaSN5VkJRgCFBCYyT7jn/ACbMls6lorhLjEU7HyiwPlKD8vI5PT8KVCLp3pVI28x0 sDVpuWKT93sSNbGXZDHFLD9sV7qS4kbK5TgD2POcdDzVmWLMdxdeXu8sRtJumC+YUGFEYz15O71x V1qaqJQqHNiY0o041KasyIW0ICM0UmY5NqMsx2wtkkbvXIJI+vtSpbi6X7CbZ7l5ZCw8qTawVuG5 HIJA6j04rTljyqLWh20603QjGo9WSJbRw+SLazWBZVENtFGeYosjOMk5weT64xWrHZxRTSpFCXt1 bdtJ2ySgtks2CRz6dsVEKUIylLuYTi6NDk57FqKJWme0NrmNUWSK4iuCuwhi23d94nafp1zWyITJ G6FS6R3AO5HwEHTB+nvXRyyS5raGdLD3nzVp3kjZtktJFubaexW6tNokaQXBy0uSWAGOBjH8+O+j BDvimg8glTIkJIkwTgEqSfTg9ea+YzWVnaWIv/d/zt+up9jlLhGHM6Glviv+lvyZdaPy9ouElLFl JcYLEnjBA7Y7+1ace+NEXZIXFz5kOMfMpPJPX09PWvHlGU6kpU1odNCnBR9tWdkaEVpFLLJEyIbR ovOG8lg55+Un1Gfp0qcRvGLRY0cSy3LRtblssFHGT+HQfpW8Yxq0bNfD/wAE2rKj7N1Yyu2SJb+X AAlsW/0sswkuCoRC33WPIzzn3zVyS3d5RCUaF1mZkhLf6tWXufp7U6E5Qvyxuc06tWVCMZrREht7 YiWG5iE8cOXMz5GxR1wp4OM55qzDBBEjTtZxXAdPJkN1dkLIpzhlUHIwCPqa66GI5rwnozlkqjSc Xb/IqRQCKNI4rSS5yyrOpl3i1KkHcQSMjPQ1eaFw5geKIRRkPEJFLHkZ556g9qiUqixSiylH3OZE /wBnDENGpl8oPKYuRkjrnPv0wamltmgZN5jDTRrcv5LhhJkEAEg9Rx1qJZhhvrqwcX71ntbS3fs/ kfQSw2Jnln9oTp+7dLW+t+3/AAGSwxhplDWUdx9ndRtdyqTN97D+uOOR0PvVuOBWdZI4FjKgFdjN tlYjBJB5+gr4vOZt1rU8S5x/Bfo/kj67IoU6WBdSphVCWy7vfvqvm2WGiLSo4t3aKKHeJk5SE5wF IzkHuOMfpV025xhF2CPAUs4/fFsng9/T3xXk05RUry2PQTSSUiVEjAlCksY0QbWBCujZJOfY+nSr MMMUciv5QBjj2bhJ/qhg/L9B/WpkoqT5dintcmeJiI4sBQkbW7og5YZ4PfkdKmW3kZv9Vh8bFzyS B15+vvVU+fnXs9zNNrYu28RQqyxA74CVDgbYyVbIPrnr9a39Ct4zdLd3gC20EJnvppZQkVioXHzM ccHHOfc9q581lKf7qnJRdvn12Xbzv8j1sBTw/LLEYik5K9tNFr1cr6Pytqfxb/8ABQv4taN+0x+3 J4o+I3hLUxqngjwb4BX4faJqJuXfz7hRYvJ5Cg7QpaI5frkd6+U0spDc38jRrg6fJJMnneY7FWUq fQkY6e9fyhxZiqtbOMRGUtn+h/ZvhtkmGyzhajiKf/L1KXruZF9LcWdvc6h5Cm5aMXsemjGXkA+V euOfXpXPRNDq6213dQPamGZLlrBJhJ5E67lcE8liSRz09K8zDV50oK+jPra7xLlKKWnQ6S2dJLR5 QikEyxRysxVZSB8uPowwR3P0qa0liS6C7GJxBPaSTIQAxDBh9T9eOKyqKjCTrSlqxRlTVKMJfF1O j0YxvboJIFkuSyukjt85iYkHg/h9MGvYYdQjfw6hmMqSwutncxwNta28tBhgewJIyOetfKYujB5j CrD+tbfkfe8KTp4WdSGuqf5H5f8Ax58Vte+Ihq8U259M1CS7u5JpGdVUedHJEqgY3BhyQP4fevcP BbrceHNNnad3/s1Eit4oSQWQgOgGDhj854P9K/oDJK31fJ4unG9/+Cj8N40qfXOI61Lm2b3Pc9Kv 5ktF02MNJcPbmRCF4diMMCfTH8XHWtCwl8xprNbgskQ8ubcoDXLkBSVXtnGOT24zUxw+IlTvF/I+ XxEoqmsPHVluC8tjva3thZxlCnlb98dtluCzY64HPcZq2bQSWl8t3aK1ndQMdlxEDHeeWwXBA443 cZruw1bG5TiYZnQn7yaf4mNDELCYxU6sTpvAnibW/g74nt/iL4BgtLXxBoyyXlxapF8rbbe9Ozcq lgzm6ZRgE/PxX9hP7I/7Rmh/GPwLokd1fpJrLCaMpJMfMucTOkKbeuVjhYZPaPPHQf0txu6vGnAO W8d0aVvZJU6r7yk21fzt1ufL8R4ahlXEsI4SPu4lSm/K2lv6R9mgLGjS43IqbouPu56+9TiIGNBt 2FccD6gkV+GGRIcfxY9h6UcHOD97pxQAnQEEnK+1Gcgd/TjrQAoOep5Pb0pmeh3dDgcdqAG0ueMZ 79KAA8kc9epx0pckdD1HPFABnuW5HTilHOPm6DPTpQB+Sf8AwU2+Imt634Il+CXhLX7vw7feL1ax 1jXdEugt5o9oGhaZ0zld3luwXI/jPU4r8BfA/wCyH+z/APs7eEr3RPhF8OtI0QGDzLzXpGBvr64C Rr58sn33kbacl2Ykt25rys0zGvQhHCYadk9X8jwKOHo4ziGMsVHm5bpeh+bf7Q/wOtPGfjPw9rOo COa9W4ks7eLq9urBhI2eqgqAuTx6c1Jpv7Oer6toln4Y0yaDTCYzpt5IUSbdGF+Xa7EZfJHzH+nG FPNlHk5nfufU0uG8NUx+JnGNnrb5rT8T1D4N/sUfD34f3e3XbSXxPNZ6wdStE1Fo7ifS5JX3hRJg 9CzKM8/QV+g9pHFp1umnaVbR6Ta2UUcT6barujlKqFkk64BbAGPX86+Vz7NYY3Fe2k9EeXwzw7Ww depiMY+apfr6HVwyXKARWtujJHIrTtFdgGFQc555OD6c17j4G8P3GptYxsBGlrJPcmBZssnmfITj r82Sea8uhNzXtcP0PouJsY6uAh7OF7afez9A9Dt7LwF4eGt38S6fp+kacl4kwmXbeSRlSYimCFwG HPP0r8Bf+Cgv7ZGua5qV/wCDfCd9bpLdee9zKl2duhoyyIJlQptY7wvy7h0zXn0atTG5sqc43S6/ 1/XQ+s4MwsMnyWWc9Wfzs+JPDT6pf3Wraley3up6g/mTXV5GoluQm1PMcqMbmIJ2nnHPPNeEeKPC aRtqUlzHLBJ9kQ52EJbl8v5gxwPkXle+ePSvuoYhRrXv7upzwq1MY6uLq6uTPJbvSLokiwjWNrpJ 51kf5ooEcZiQDGGGAxyexGa/Tv8A4Jr/APBKP44/8FQPihq2meG/Edr4F/Z4+H9hYSfEvxHZuYtX 1a+ke8tWsraVmBUIbcu0qKQPkUc52/TTwGLrcN4jH0NFZ/k/8j+V/pKeIEvDnh2jCnFurW5bLrZy ae/Y/s9/Zb/4Iyf8Exf+CfvhqTXdS+FnhfxX8Vb5ZtVu/G3xX8Rtc32p+U0cxaF55nk2jKjA+ViD hRk5/nq+N3xP/wCEq+NHxav/AA1pGnaH4TXx1dWfh6x0KEKtxaiZ/In8xcKFOSo442E5Oa/IuBMm q45rGYz53fl1/qxt4M4lVeDqePqSvUlb4tX13+4/nYj+F+oXP2Ex6ZKpeUwXxwFUKUyA2eh3Dt0z imL8K9ZkSR4FkhiRViLiMh3KnDL5fYY6Hv1r77DYdwl7SW5/RzzPCV4QjH3mW3+GeoRrbB7ZVjuI vPgjcZjknXJb5TyBgAnP1FUP+FcawltbIumvIjlzgr88i7sM5J6fj2HApVqTqwU4L3mGIq08RUV/ uHp8LtVha3gm08XK3cbtBI0GQIV42t6EnkA8nFRj4ZXbGVSlwFs4BbNLHDnLbS+SOAQSQuckccdK 0w75Y+xlueXjqzVT2cH7v9foRN8PNVEd1I1iYnEf2O7tyS0cWwI0K55+Z+vHTv6VZk+GWuGTMMHl xBYYxbeSF81h94kk8Lg55/uVlytV5VFG9v8AI3pVpQy91IS0/wCHIJPhpqsZvpksms4GQT/apI+E UEbi3pkcD0zVO6+Gev2yTWotjNao4uRC9p80pOVz64xnAHaqjGpiZNzhZfieHVq08PhlXqTu32Mb /hANVjlMUkHmE2EjTOBnYSw8pBnoQM89M12fw9+DN9qevvqGo2mNJsBFfahIrAm3bzUWNAvfDYJA znfg8CvG4g9rDBfV4N2dj67gv2mLzF4mvdWWh9v2Wnm0gOlQRSyKLcWz3dtIEEmzKs59gCFI9xir yac0NtGrLKytdSXL3NtcbFimUbCqEj5SuRkfmK+XwdOhhacaENz9AxGKoYivOhV3I4BdfZWjMaPJ BLsZxGCpdSV5PUjucc8n0p2m6OWRrG2ULaRwecscyja43N84/wBond65ABPNenUpTlJzj59Uc9aE cPane9rfmdfp3hu2hutO1KG3aLUNPWO/stShnMZgPUFXBycjgDPfkGvXvDvjLxkYbPT21q71SNka 9nu9XkMss6Ix2kjgEgHBIx90cV8jjMCqc54mK975H1NHO6lTAQwTntZHXx6tKwa+aSaaKS3SXy4n 4lkb/W7to52qM579vd19NEsUq20cMl7ETCkEc5CX9uQrB+B8owMbevGc1xZfRq46M5Ti0zbF46GD cKb1ucj4p8S28enrYuom1BwG81WdFKPlUlBHzEdtoOPkyetc/wDDvSri7/diOd4bS6FhDdTMG3+W ct04wQSOOu8mvtqEFl/D9atPSVrfg0fIV4fXeIIOi/dv+p+rv7I/h82LQ6rPugS5uFNwUhLrGjRA 7gOAB8ucjn15r9JdAv7PV7+6u7qzYG41KWGyneYRfLzvPJwQwA59QK+N4OpLENyW7/yPo+LsRWm4 UoPSKZf1ZfI8T3ZgiZUsbaW1iR7oO0ikIwOQNo6cVvXboRAdiGezG+3dpMswwAqoT0+9z655r7eN OlQxMqjVz4ui6eLpRrW1RgeM72Wz0IQsZZI1l+ZY3/eI+QWyB83J9K4Tw7dwx2f29AZU1GQwxTS3 DYRAh3c9cjJ/+vRiIUqeNp1oP/gipYiVeNVy6f5HKeML5ks8nZNHLCu5j8qXKIdoJ9ByD718wvJP byyXB8u4eQs87XB2qJDhUVVx97GD+Ir6bMalWphYypr+v6ueJlcMNWxc1OVkr2OnsNUuEWwWCZTi aO1aRsgRjkNuHXgnAP49K+kPDmu3Vvq+naY0AnSeBtPM0boWjmiWVihA9sYbvX3XhpUoSzhRq6XP zTxVy6tiMrqSg9EezQrFFOqugkidxJhZNu4kZIPPp/KtC3txZSSrbSGO6miVbWRJGAgEbHGB2yCe O9f1FRjO/PCVrdz+Hq+LpYSrPm95PckPlQyNJ5e2BL1VAZgZJcjso57k+1Wo4TbXES3OyVIWAEqy Eb0cEFgcehx60VPaVq3KtWZwq5Y6Ep04e8v68hxgULFM8Bby7gq6kgFdp4GR/CQRjvmpJDJLHIzp E/7mNy6SYJyx2Mccj0H0/Cu+piKfJOF9djlhSp1LYqMtWTpb7Hkt3G4A/ZfNb5lY/LnPuOuO/wBa miiDgoV+9ueCVuwVsYOPvA4GPSubCwcqE1CVmPMaeHhiYznre/5kwi3wzwO22Vnea2V8fvVyAW55 4ztHpmnSxwTvOs9r5ccsUReCeUE2zgH5s8dxnuORVYarV9r7KozRyeHyyUabutP+HLkNkkssRCRW 9xJHHA5242qMHLckAZxUMMW4vPMGDlGztbORuIA/rnFelOMqcrSVj5uGHxMoSxlCVnoSz2M1tHcy vEzb5VlPlNkLsGSO+McZ+pqugBUo8Lzs0fnxJAfmmkPMY46AdST16VhRrQrVFBqzPdwtavXw376V 2y4bUDJ8u3EkgeITRrsJyfbjOTkVYmt0hjimKB5AGkhCjgp/q+fUEZPpXbFwo1Gpq58vj6FkqkHu U0gQOENtbwvCWhjVJDtkhBy/zH/D2qZ0hAiigUxR9WJcYOxuNo6jHHfmt6eHhXi6m3oenk+ExEn9 Wxc7w7liC1hV5XihPmNtDXEkxKs+W4CnoBjr7Cp1iQxMVREeWUO+BkglWPyt7cc100aNSg7Xumcu f1ada+Gw0X7ul+n9aktraq0tpbvaSI10gY26zhHLFQflPI5IBznFTRjzVLxq1u11EJSshBYTAkZO evAxjpRBx+stKL+52/Kx8zTyjEugsTKVo9rr8Ve6JrcKg/1ckwnjklkRf4X6HPfvnI7Yq9Ogt2Up EJpEspHigjOPNbK5IPIGOB+dcmY1U63Lz8qs3qtPvuj6HJ8vjPBynXjzJNbN3+6233F77H9kaWz2 LcMCt1MBcB2O4ZK/+PYHerX2cQGc2quY4bZy0ZZiTuGBk44APGRXzs8ZXqaJ6vfRb6n1Sw9GLcsP CyXr+JPFDHt3vEZAsCSBGY7XbARwGHuB/OrM0JtxDE6LarHEv2ieNwwtCTu3bvoQMj1rFOVGolJa iw85UXKnQlp1/r+tRw8lEaaS0i8mJfKuEjuSM5bAOOQfw7H61JHaLEdKCwRCGWJk2m83iN87uAee MHrWmIpeznzJir4n2VGUWrtljyY1jLhpmZZnufN3hRIHGAMdMjHfseKsPFPCYi1qiuzPbYtTxMV+ Yc84xnn/AOvXoYPE3so7o46l6eDhyMkkgjaK7hubSaKRbtVybr5Wzhsso6gkZAz/ADqVrVreRrny mMMjieFE5ZMHORz1ySOfWtq1Sai6vU2rYupTpwi0TrbwIrRyqkokQzOXBAZj/BjPBHfNRpEpDBfK Lwsk65/i3bh9BhePfNJc1ejqtWhz9liKEcTybCXEUux4FtmN2ttH5tm1wf3bgHAZj0zkc1YnKPfC W2tzBEUEn2aK53hHIwwVuDgYPbPNLDwnTp8s3cVKpUr1FVtaJPaWZtZRFDpNtawmJ44IklLrEu4P vVifvdc5681sxosfl3At0uopYXO0TmJ5SWCAg8447Ec1omkrMzxUqdlUb16L/gF2GIM6O8SQ2hc2 5czZkB54UZ5wcc8e1TwwSTxi2e2yY5o3uJyTskkUZIIXA9PXvRKrVpUpJOyszxqdStPGWqRdm/68 jpLeEs4uNjG5d1iupYJsDAGNwHtkfnVqKBVEbABpElEbo65GAT1Oee/4V8dXr06icamr7pfm9387 n65h6FHDYdqDbX9bLRL5JF42gllBa1EkiXO9LhG4UgDJHOQCSBjpxWlBG4dfOt/LjZ28mVCf9Ibo 4I6DBrGFOvJP2a0OWrGhTjdK9/wNiC3WSUqqGNmZFPmPtC9QBk8ZpIoiLhJ5IQkjEqhju8ghSVUg D7pJz9fWvQdKEadoomVL2NC9Td7F4WvlMqAIFRmyGm3eYxHbt1P8qkRYhKQ0ZMzw5LCTBjB7k857 1VOnTowZhFOUPaQ1/wCCWI7RGFvCVkwWdWzJkmNh0PPTuKmETOtoq24YyltjiQfuW3bVBU+oBPPT NeRPMMNRq+1qPmh/MndLstL6/M9XD5Tia8Hry1OkXpddXr0XoxZ4o0eeWWOZt58xpoW2JG45ww7j GeB1xTjbsGdCjuuSpUjhww6n0OAMelY0s7w9avyTkkmm03ZOPk9Xd/d6HS8iqxi5cjcotJrpLzTs rL77dySK284QYt2COrrJIs4LStnggZyOOOfSlktstd408oQSqwjJkk24GWzx6/lXh4vPMfzOjSq3 S0va1/VO9vwPpqGRYGC5qtJp725m0n28/mX44PLfyooVjgAy208xsO+Dx17VpQo8cwZkDNEV3Q7u HOeATn0GTXjTre1pcktz2l7ug+2tuXlijMcxjMUjY++VP8uvNWRFGVWWFV3hztDZA3dOR1//AFU6 XsVHkmW5czuyeJQxZGeTyxtaOAgne2euex/w96sSRbJHiZULqMkowIyDuyPwFbONGhNO7uZ6t3RY RXPmTOoeSUZkDYUkc7gfTBIoCRuhwkkIUKdsj7gzDgtx75HsDXRyU6d6jHGPNJRS3NBE3HcqnaMo 2OoZvmA/HBr4L/4KofGR/gf+xH8QYrXVbrQPFHxHjh8H+G9Qtbvyru0muLy0iPk553bZOxyN2RX5 xxDjI4tV6vOvcTSt1Xe+x+l5PRq5RhqFP2DaqtczckuVvS1rXP4+vCmgaB4F8CeHvCWgwNbQeF/D 9rYNmQvcXEkUSxs0sh5ZyASSx5z7V1NpeNGLWcRL5UkGy3EYG/cP7oHqvUn0r+aq1b+0YzrS3f5n 9Z0MJ9VyXB4ShooJK3zOW1Iia21COTfKtvaxfZ42/jbIc/Xjv6GuO1uwkt5IrsFZ/IlW4vVMpRZY zznPBAwRke2K48JVnGboz1/Q+ly+CrQ5aztL/hzb0y4kl8+OSBfIDiWA5A8/nG4knOOv0xWZrF5f QK9nZQpctY3iC6CyY2AsDGfcZAGfr2NOpUw1SfLVW3r+h4+Z4KvUk6mGex0ukXOoXP2W41uEpcXJ dLmASb/Lc4fGOmOMe1et2erfaZYrCOFVfU4xYQ24P37l3RABk/LkA5Occ5ryc3jCKp4jD+X5no8G 1MXSzSNPHLf9dD8v/jpANO8ZeLNLsmit7a9hk1hPtjbxFPI05RzjvmF02jgBAT96vcPgleXJ0dYX tZVjuNBXULeAyCT7IN+FVmB6jJ5B5Bx0r9p4ZxFWplcYzj2/U+P8TcsWF4nqU8PDV3f3H054ekFw kUgK2kjp9jMjKSZo++cdd3Jx2xW3a29hLe3dmqJalCiiWWXcZ03ho3wOOmeOeWzXe61RSqRk9tj4 DCYDEVcc6/Loas0Il84QKHhZT5EUOCJjnHzemB29hWTa3zJHFLJFI43vHI78LBxj5xnkErzjjmtK depisI6UzpqU/q2JnW5Lx79jRfU/JsvKWQfbPJU3ESjeJASQSvc7ckdz0r0D4V/tI/FX9mXxHJ4t 8A2V/wCJtO1BZ5dUsbzXksV0tkS+uY5GxC7sfMnK4Az86n+Hn9z8FuJKE1iuCs8jzUqsZWj/AHlF qL67N3PKz3CS4myiVCi7Sp+9fyj7zXzP7Ff2O/2gLb9oL4XaT4oAjW8MdwHt1f57WKO5ktlVgRkc wNyeu3PHQfWwC44VhkbsE5wa+DzjLK2TZnWyvEP3oOz6fmfGZbjY5jgaeOgrKSvvf8R3ONvQ5waB ggAHoeDivNO4DnOAevGMdKT0OcZ9qAGk5Iyc++OlGfftt6dRQAZyMlucYxigsc4zkAAg+9AACfXv npQD15xn2oAUHgjdjt061wPxK8c6f4A8KajrmoTxQ+XA3kGUcdgTjvjcPzFKUlGLkzKtN06M6i6J n88fjXUNV8e+Lb74geKHlll1Bjp2m27HcNOhTYrYbG4FtqnPf+Xz18R/En2LT7u2t0df7QtDHcCV VYqqlWAwegYDG73r4rOayjeutnszz+G8DisfjYYmk9Xq+h8DXw/tvxBP9jtylkUMoZ1wIHY/dyeS cKTk/LgCr+o39pplvGyCNZYmx5UcxY3SE8HcOmDk898V4+CqP2koN7n6jj6aw2Ik6vxO6+Z1Phu5 kuryO4WSSKaWc3MirEcREYCEg84IGfwr3zw/ATJHcW0S3XnkxCFyxe4OPmbswG7ccVlj6EbctN7n iZHOpRx03WXMmdloFhJqF1C4hkaC3SSA25XKy4b5GOecjB/Sv0M+Dngaz0jTYPE+vW0jaf8AY3ne TYC7JHKAFOD0yw4PbNZNLBZe6kHvp+Y81VLH5jTwOH3bWnz/AMj4T/bi/auuFsP+Ff8Ah+8aC9uo Pssen6VOBFESCplbsBlMnPXp1r8CfHOiX+tanrd/cXEst5fSxzmUFgqxeZkfJyAFxnpk5rnyOjT9 7EX1ex93nklhMro5ThYJW+L5XPFtb8ITx3NvPKPOia9a4dQvlpMVUrsx/DkZIfsM186+J9IawEzN DK8SzpCUMhYTq+XO4HklSMAf3QfXFe1RxcalT2TR4FT2eFwDrQ3R54/hnVZbw3dtpkl1IxFvFDGu 0eW7kSYJ42r1x3wQPf8ATn9jT9ur9qL9j79nzXv2ePgN8PvAXhmTxF4m1LUPF3xh8TeIJDeJbXuq XN25S3SNn3FZW2L5gAJI46V+n5JxBg8Dlc8BiNYvT8/8z+OvpL8F4XxWyzBRxK/g2a+UuY7Zfil8 afGCXM3xG+JniLxDqt1AzS3aaxMvl7/lmjSAECNDGoCgdOvOM1izJBZ2Fra6XFFb2mAkdrkogh5J JwM/e9ckk149Crh1WdLLqajF6v8ApHzvAeL/ANXMDTyd1Pditv8AgXPyou/2xv2YBfytc+MbkGWR b57m08OXU8cJ6GFVEfJIC/N0Byc5qxF+2x+y8tuZI/FWoX17exLbvYT+GLu2FuVcsrNK8WzgH+8M jj6/m9TxE4Ypw5qdRteSP9KcF9Hnj6ninQhhrJ99x11+2p+zA1rbSHWNQujfH7LcNY6FcEIxBxuR k8wZK/3R+RzWVaftpfs8arey6fDf6/FqeoXEQs4Z/Dlxumm3bFjJKgKSCTydvvniuJ+KvC9NKV5N /wCFnuV/ozceYbEKoqT+8s63+178DfDciR67FrFhc3MrwQ3dlYC8trzbuVnBRsgIy7ThTgnFJN+1 /wDsxXls9yPFDyGASJNavoVxHLcyCNWHl5UBUySoJ/iz2r3afiTwXU5HOslzfL8LnxWc+BXG39ov B4eg2tb2VzFP7Yv7Od1dm3h8VT20TA+a194dudkTRgqgVgmDnjkcd62G/aa+EH2W11qLVLm6sby1 aacy6Y7GylUBts6rlkY4Y46ZX3r2qPFXCkX+6xUW/VPyPmcX4XcY5dCeDnS93qn+ZPZftDfBzWVn g0zxSmqyQQy6hPdWdhPODFgkB9qYXG04GM+1bf8Awu/wbeebezeJEvobJF0zUF0+CSdrRyFkj3yF QEAzgg4xk9MV69PPsob5adVfKx8p/qLmuFkqNSne39f1+Bck+JPwtvXstNn8T+HrPWZ0FnFFe36Q yqVLNGRu4IwTgZOCc19b/D/SfD+g+ELezNjZXFzrcP8AwkTX54kmSRf3UiuDhQSH+THGATya+a4k zKhVnH2Urry7n13CmX5jg41a2JilbZeRSsomtbtru3lZzb2avGmwI28Ph1VueS20nPHy8cE1Nfrb W0cMcSRReZcPd3bSfOt5I5xgZ6ZBBz7j0r5OjhqiqTr/ANantvkxNVYu2pesNLngSzS/tWLFjOA/ ytcuRgsw4Axlc4qaXw5d3heEWzefOsIaQLtNj5fDMx477fkHXNZUsTyTlCuz1aM6eLk51Y/megW9 jb+cDBG1tMpi04xqTteSR4wXweEJPOP4Qtbdt4Pdr65ubKT7TqWns8Vs9mSrSFScoU9GBIJI4yTX kTxDljXT3R6mW4OjiKrr0lblNc6bcSwz2JMlttVrYAsU8liMMQOpXII59OOKgWwuYZYLlnlisrJV vJtlvtdI9uxmPGcDkBeetdMMXDDV404v3WbY2lPGyqVUtVf9TxvxAj6r4ihjshAPsd6VgS2clFWJ m3bmPAbaADz64GK9h8DWEEF5FpmnxiS5SKDU2KMRGhlkXAAGck5PHQZr6ri/lhw/TpQ0Urf0j5bh KlUxOb1KjWqufsN8KdMk8NeFbS48pGju7RQRImMZDIzAccEjge34V9L+EJpbmBdRtYkkgtIi6C6G BHLsLnkjDA88evFfM8OYNYKlCjRerVzt4hqyxGIqqOyNzw/IL27uGlVrh47oXAWWTacbT8jH+6e3 pV+W+juTarOQJorkGdiRk4O7bjoSABj1Jr6XE06UbzU9ex8/g6uFjDkpaHAeNNXe81SGytIIszP5 8pZjvjt1dc5x1cE4x7ityS3TT7WNbhcQJbKYp1AOBuIxxnjGM98/WueMfbYmE6mpE5LDYBzprV/5 foeRfESSGcS2TILm5N0LyKIKFWLaeDnr8owRXz/4hjS3bTSAJLlJ45nvXbiWXdyyqR2719XiK0al BKmj5DK4zeJlVitH/wAEqx6iq6hbSJIGlTzblCsm5Q5YAsT64Jx9a+jvh/qP2mzuL3c0Pm3y21u+ 0F1BVwXGPp2/rXrcIYmWFz2nKorIx40putw7XglfR/kz6rs5ftdnCy2sZiYPJtDtl9xKnJPsvANa EFn5MVikkS+VJOsvmCdndck4DZOQcjHNf2FhpvFUkqK07n+ftbLacKuIdXWV9t+g+OF1E0jQLCjz FmIkIKgMQCFxnHQED1rQ8oLAqeSUnLeS8rPw2PmyT06HpXZQpUoSddS0R8zQqVKVSUFDV9OxdlSW CWJpbZiJX8xYjJsWbgEFCOCM/rUCW0QheYpGjQTBblozjAJJXC9TzznkVmoLE1ZybMI1alJTSW/4 bluOOUPHLbxK3lq/nA/KZWcjAOT0x+NOFvBHK3llvnIt5l5IdRkkIOQPm46c0Rp06VdUZrQnmrYK hfFLmROsU7xmcROHGHnbI/cOCSc9vTpUiWu4yvHbqlq8pbaHL+WwIJB3EkK2T9MV2ww1GnLmjHU0 w+Ilb2lTRPbsWRFJM4QSRGJnyhDgF41JbaecAZwMd+KSKGVngilDBU+VlJH749VH0HGPpXpVZSdC 1XV/kcf1SvWc+Sdkvu0CLcjSScu7qdobhjjhgT0HbvTooBDI9vMknlQLHcNcRMGMxPTAB7dDn1+t cfUvL6EqOKjLmutSR4Yj9rN1Gyuii3DXR+WSM8qQg4zzyTQgJt3YRy4+0LHG2wghh12HptI69q7q NOeH/fWujevCNSpOLjr/AF/w5BJaKHhngi/eB2BkE+VQZ7j6gDHuanlTK+dFF5Rn2QFnj5Yn5jle g789wK6U6VKnKrSW+p0VKjo4NUtrlyGO2SCZTFBOkgCSKCdl4Od27PIyDx3+X3pVXyrPKW6MkMw2 lV+VU4ULsHTGAcd6ydTEuj7SLseXOlVq1vq7S5X1LSW2FyIH8uSRollLZWQoA+PUbu304qY22yFP lcMgV4kEeSVY5UknjKt/Osf7QhUpL6u+aXXp667ErLK+GxMsPi9IPS+j16aXuW7dWhRLuDMpWBlS JieZGBADH6ZPp+VPS2SO2QRh3S2tFtxIMrudz834j8jXgVasq/NjIpLXbR737/nY+xpww+XUKeEq ttpbq669+npcnubQptM9vHdToEtbqUvgruICruXgnoa01gfKIsDwB4nWEGcfvCflI3dCOD1rj5mm muh0ulRnQ9rhLLm3LPlTEKPIdDDH5MyMNwyMcrg5A7Y/GnrZxjcYbcu5l8mKKSckSbSdvB4yM5Bx yRW9LnrVXKRw4rBwhR9nT+Jl9IRuuZEt5RhV3OxxgEcsAP4ieaSG2ma3dp1SR7sGFpnALMNwcgj1 HHJGOa7cPhqnLNNaHlZhgqdP2cVLVdPmTNDHK9xbTxLPboHQrJ32gFee5J7n2pTFFGkkzQ3Fukok RXkfBgb5WG7B5yOMD1FbwhGmlCJvXqS5oUlBNC+UqvNKYY5IZ7XzSElZTYSBuPUsSBwOgq9FbC3u BLFFJmZk3Rq5w+RzgHIBHcVNeg6sU3oawq0JVOSp0/rQWCO3uDJObVQlxLcRq8Nwcr2BPoQQc8dR 171cginSOZCnnIEa3uEU4W6iGGAP07n6Vphuaholsc2Jxsrunh3oUxGwMSlHcmVDJNkiQKTwhPfk cE1JDEiPcTi3t0+1EybsEIx27QfUn9M10rD16km7Gft6lZxp0lsXFtPKFvmDLxxvEYGuRENoA3Fl /EVsRxTSSIosLqWCQJHALWT/AFpDZ4bGTge351i/cvDqVjeW0Zp+8Kjb45USOKeUpteNn2i5cMco OOw9etbMNqZJkWCOTzXZYrNIScqCRkbc44/Pr60sa5UsK6+Idunn1NsvX1jFRoqneV/y33N0W4a3 uZHt4yhg2yKVwYN7bABk5Oce9TCKYI7XEEYhRYmjkguSz5yQBtHTkjuevtXwUaTlP2Vz9Fpzpz92 m9jajiad0lZVcmzaPaW/1qjqD9Tn9KupbpELdWjKwLAYYIyMtax5yR7gkevpXrUIyp0+WR5mJcvb PnL4hZ4SiwM+5o3jIuAoRwwO7t2zwat+WIneKARgRz7A3RXdudxPQA84xxmtknc5KlaNKn75ZWEr I7KpQSxqHXkDg/e/E4qWOBxNPEkaNc5CyRyThFOP7xzx2xXlY3M8DQToTxHLLyV389Gl6Ox6uV5d isTGNajh+aD73S/NP7r/ADJWiuGZgwMTcPMsjjcgByQewz29qn+z7TI0seQ8yxExOD9nyN309Bx6 18djM4xNeMaVOo/XWL+5ScfwR9jhcmw1CUpzpr00kvvcVJfeOkiaNpZfKL/uBt8x/wB38uei9upp PssaxfPBLI8dqgt5RcnI5yQR3GMfX1rg9tWjJKTvbTXW3pe56vsabTUVa+rto36tWZK0T7Yg0JhM eSnmEE3AYgZAX7uPX3qR4C5wB5gRtwXlvM429+ntWUKnLUTaudCtfQ0Ei2yKpt1YFxOMthlUHg9f XHFXo4GYllUM8Xyud2McFmIH+etVaKqyv5kJS3FhgEs8cSJIokj893Lcp5Y3BQO/A/WrYUr5jGMy B5Iolk3/APHvF8zOFHduRnp0q4whUjKUVaxS13JkikRZcRG4FrGs8kSSf64kkLz2z/SrnkDzH+Uh eCGEhzJ9f89q0cIzoe1qPbr5IqFN1JKEepI0MuzhwN25YpgvzK3XJHTHIp4xuBjUgFyJg/UYGMj2 4/Wvls2zp4hWwErRXXZ/LW9vkfoOScN08LUUs0heT2VuaPzdmr9tTX0iya8nWJVaF440kLRkMYPq Cf8AOK/k4/4LAftB658aP2xx8JdE8TyP8IfgT4f82/s7VFlil8RXEWm3UMillIG1Uf7pJzg8Gvgc /wAXOlgKlectXpe/c/QMpwOHxmZYfLaatZqVkrKyfpY/MmNri7BkmhcFrd5Y4WcDzVHBV88bvQZ6 Z/C1Zum3TkKbpNhtgqnZt+Qkqpxkg84/GvwXHctOKjFWP6LwvO8VVS+BPQ5q63LbXM0kfnTQ2zZg jkJW+jXhYx0APbPsKxby68yyvJ948m3t3t7FJEyJNi/KOORtyQQTznFLByjSg61Tqenh6br1Jc+l rliwhjtjZlo2ZLq6eSVnbCw/d49+RgD0+uK0bZwdTZsKlzJayXbEoASsX+sUnvgFcdxms6NP2te0 9TzqFSrGpKk9X/kXvtEDG2eb9yj2T3K7oyDK7N0HOOV49vxrrdIeMXsV3IY7r7FNBcKY1wG2hflJ +mAT7VzZrCXL8Nkv6uPA4mrHNIRlL3kfHv7U2gW41GDxCgNqrRtbXMuwD9yySzDPGOWAI4J+UDvz 5z8GfEp0bUobWNA7LPHYXAX5igYsYgo78nHH44r9R4P9rmOVKCdmjwfFjHVsNmVKvLRtP8z7t0KX y7FrhQrTyR4knZm2xkchQmcAsDg5GOKlso7j7fcSDMFvIYlgcsXYtkn5f7oHIP17Yr08RS+q8zqH xmWYivSTqS1TPL/2hL/4mSfDbxJbfCHWY/DniJtNnms72S3NwySBcsgGejAcHkjtk8187fshftC+ K/ir4g1Lwr430TXoNV8PabHc6nqM9jItsRu8oCJ3AJDMHb2+lLLswpYrDyVFWkv6/I+ozKnSp4Sn LBK6lq/xX5H6T2mn2aJe3S77gW91NDAWBDW8YAIc+q9DxUWt2KyafeWTxJLaXWnTRSIigNJEyspP XJOCfzr7Tw4xmHp8bYStWlrez+bSseHDL44d1vYLSVOa+bTP34/4Iq+N5bfwZd+C7+OW0Ms1xHaR 3a7TdXJ1HWLmUqo5BZIhJjnA45HNfv8ApghSD8rDn8q/RPFT6uvEPNlhF7ntHb7kfj2U4WeCy6lh Kis4qwoGAcn2PHSkPUbevfivgD0RMDAye55x1pCcYwc8YzigA44+b2PHSgcHg9O+KAAnByGyfpSH 65zyaAFzkHLdsYxRntnuD0oAbJNFBFJNNMkcEKFpJJDtVB6k1/MX/wAFFf8AgofB4u/aAg/Zy8B3 vl6R4UhOpeNNQUuHijHkGBEYKYyzSFiQSCNgxnFdmEwixXPGfw2f320PB4gr1KWBcaHxHnfhr4x+ Hri0B1RI58QqrJHN8xIQKFIz1Bx253Gvl34u+PLG7N06zqWmDWsVtHIB9olMYICtjPHTJ46+gr83 zzCvBVfq17pH0Xh/VlTwMJ1fiPCF1CzswmGQTPcGC5bPTChgCe4AJHHWuSmmuL66aWcOJ7idY7O3 VcptXJMjN024GMHHOBXzr5ml7Nn6Bi63LFzxGvN/wT1Pws7GdJUVrcyTbXSR93J+78p5+7j2BFfQ /h54JLKGaWeSRriF2tmHWZU4XpypyWH/AOqtYQbmodTy6H/CffFW0fQ+nvgr4Hl1i+h1i9UrZ6RF BctFNcgC9YytGyc/xYKnn+7Vr9rT9pTRPhF4K1XQdEhVfEDaJCLNYdWAMkkkZbZ8qkdQTwM+vPTz 8TH22ZRwNOTt1Dg+msTnGLz2tG8I3t92n4rsfgvr2u6n4yv7rV9UCwaleoHvYWdpFjnUtKmGPXk8 etZ5WK+gFxHgpcCOaSFG+abaQGyfwwPTFfWVaNKhS9mtkiMdnSzXFOo9Gc5q+lRXNhcSogJukcRs gw0Tu4RGAPJI6c8H2r5v1zwuou2EcbSSXLqY7mSAkXSxNskZgBgFTx9DkV83Ki6WJdSnPQ9ujgae NoulJ+6l+hw1xYWlhqEAa3gjkQx2qX1tKzNCI3chVA+UkZYnA6Din6V4kdJILK2t4bR9W1N7YLcK Q0AWRmDsBn5tqE4HI49a9KeO/wBmlzaf0z+afFbCyy6lKNGdkv0/r+keq+HdYvD9mu7pWt4LeY3Z mLL5l2h/dAyH0XbxjPTJr0bSrxb66NrcyxLFb6YrC4juAUmE0xUKAOGZlBOR93NfVcLJVcOnHc/m TB5nmEMY5qH9f1/kf6Imh/sq/s3+HDE+jfBP4W6e6F2c23gSzXzd27Of3XX5uvXgV2kHwU+DVrdG +tvhT8NYLs2/2T7RF4Fs1YRZzsB8rhc546c1GE4K4TwFCOGweXwjFbJI/wBIM18SuPs7xkswzTN6 s6ktW+dr8rItQ/CP4UW8ong+Gvw/glFuLQPD4LtFPlA7gvEfQHkDtVy6+Gfw2vrlL298AeB7y8ix 5d3deEbWSWPAwMMYyRge9dv+rWQeydH6nCz391HjVOKeJq1T21XMajl355f5nK6v+z38CdfJOs/C L4b6jlw5Fz4MtWBOVPTy8dVH+TXmen/sN/shaVfxapp37OXwYtNRglFxFe2/w8tI5Y5Bj5gyIpz1 65r5zMfC3w9zaoquYZRTk15fPofTZF4s+JPDSmskzmpT5t9b36faTKviX9hL9kDxXPNeav8As5fB ifUZ33yan/wr62E7HfvJLAc5PrmvFdR/4Jhfswpq95r/AIR8A6L4Q1q8mVp5tG0yJba6QHlHgYFA MFhwM98185m3ghwPi8O4ZTQeHnveDf5NtW72Po8u8efEOjjFic4xX1hbNTjF/iktfU8k+IX/AASs +DHiQB9G0PR/C2qrPEsesWWiQ/PAN+QyAYJJkH/fJrxq4/4JNaPaGOyttT+H+ot5EJTXT4LENwZY 12MXDSBTuByc4HHHavj8f4S8TYLDqGU4pTa/m/Hzb7H1GD8YeHsZiJ1s4wHK32/qyPK/jH/wS9vd B+GHizXtZ8N/Ab4iW8UD/wBlaRrHheOz2OolVSLje+WwBjGDz0POP5ZPjjoWjeBvFOseH7HwVc+C r63eFU0CSdG0+2Zdqn7Mck+X865UgDp9T+iZNwhjcHwv9exy9+Nr+uv9XPyvOuNcHmPGFPJsqlaM rvfszyO1iMiWjIZJVksHFurEBoyvzOXB7qzHjv8AhWhZ6TDdPaRbll3w/wBqJFcEqZoMgDIzwrNk DPTr0rxsZjrYP2DXK+/3n2f1CrGvCpbTr953uj273VlDb3SrcKjtZzTJN8qAY8tSfXjtzx7iuxst OkuUnv5LSNbKJ/tdx5nJfhjlhj5VwoIHUHrzXxn1h4dunJ6s+lqYOE1Zq0EJakk2UMsTlrhY3WaQ jbKeoVvQgde/StuKa2aCEwTOL7afMMUZVpJi+wKSeQNp647Zq8vap4iVTFO6M8RWq4eKo4Jb9TGu bnUoL+CR5IHhhnk8tjcFjEiMNmU6txkHJ+8KXxdqA0XwXql8qyQXl7u8lluDxKoZ1K5PfaSF6Dac 16+BdPG5nGEo+6LEOtgsiq1YPml/wH/X/DHh3hf7XCby8mbcGgDF2IJeVi3mcdC4D9cHO8mvqP8A Z00m48Q+NhFN5v2i2kV7aKMbRIEjhmDjb83BIyrddx7CvT8QsQ4UcNlvNaOn4M+W8PqePqzr4yor LX8j9fb6BdLsdFtljllEixQyRomfs0pYhsY9N3X3yOler2KzaLotlZ+cqwtAttOFudxfZlcDng84 zxnGa6cDKnJRp01ayYZ57WcudR3a/r+vI6/wzc/ZrKWQ2sDPcoZfP3H90jDpgdScA59jis2ScRan qD+UqG3tJJRKsuSQoDHI6DjOOc1th6Uozk97ny9bDrCY2MW7JnlsN9/aGvo8cbSK06SpG8nzGL7w B/iByR+fevS9ThlSF/tELR2s2F2ly4n5JVTnk/N+IrbBxn9bupf8DQ9nMVCOBUafX/gniHiCWO81 KS1LbpYPNt7vzJMcgI6gH12g9PWvGPEXmNqCJuS3mLF0DNlkdsFEOODwcg+uK9ZYurRm/Yq/9fM+ fwijRXLLdnM2d1ARNevGU2wTab5cYH7xcZHHQ/NznrwfSvZPhpqlyhg0+bYZ4LH7XIjptiuZgpQS jj5Tk8LnGFrqyzMKrzKNVrRPX7zoz7LYzyqVNy1kv80fZPh74hfBOxs7bSvFfxx+GfgvVbWLdrFj 4i194ZoJAzFRt2HHbJzxmu0s/G3wKvT5o/aO+CIm8lTLHb+JibiHezFMrtAJ46f7X0r+s+H+JMJh 8vhGUlt3P4e4n8POIsLntSpQXuu+pqWuo/DS6i3Wvxq+DDy+Q8oEvxBhh3LIdoB3H5TnJ5xXc6L4 b0jXRDc6J8QvhBeW4l8qWL/haNiJWPILoC+NuFOST6V7tPOcFV+G3y1/JnyON4Czl1XVp9PluTxe GUu0WG28W/Dq9k842EUa/EKyRISw3n5jIBwBgepxWyvwy8VTWzTpH4ZkOxrlG/4TWxZJBjZ1ExwO nNems5oJRv19f8tDy8TwPmFFONNXkFz8N/FltHp8s0OmS3MyGC3a28U2lw1zHFj5giSHIAPJ/nWR deHtRs7qW2exmN3a3GLmC0nWQ2vQFsqehz+VddLF0Ksm7W82eTjuGs8wdGH1mDd/mVE0O8CJO1rd mRZWgWX7OedhOAcDkAZ59TTprOSO7u3NneSwzZuHTbsaV2wFYbumMDOeta1cVTp03PmTO2jkmLzD BfV503GS6/eSm0WBvKjsJLadrh4pF83zGkAXcZGfAAO7AwB3qsbdZyYpEEt0qCW9tnbP2aTqvPcg 56YzmtcDmWErp0qc1do+dzDJc5wKVCcHa+r3/Ha4xLnT3tklWSxEO+TZJHc4+0hVw+4HkYwcdaht NQ0q4tbi+SW3mtzCkSzvIUdVfvsODn6120MXGMfZyjdej/UxxWVYjCQg6EtV0Tv+RoRsXhm8xpGS K1LB0GTIwAwyqM9ce9LNA6zWt5ndJE8lqGFxtTJUY+Xpx9PWs1i6VKuo1J2T6N2OulTxFROs6Ur9 0vzIR5KS70ktppbcIk8sM24S7ucMOmcYwe2KutbR3IVZ5I2a7gwhlkJJKHAU+nYc16NTE0aEea91 5a/kfKcuPq4mdGv301/zf9akkASRgoSJYI44oDGg/wBQQ2HUgHnpn8fSrLW5XE0aH5JCPLJ2/KxI yBznjBrkqZpRcpOcVyet3/4Dv9561LLcxcU4Sbl2s7efvXs/l8i5sk8lHTdO6AMpL4VduT07HPTs amWEG6kt57FLiPd5f2g3PFocBlkVQcH5s/LzXz9XEck1PDNK66K34bfiz6/B0Z1cP7HGwfutWbd7 +d/80iSCF4WjXDj7KoMEMh2+ZIp5B9jkn296AmZWa4t0ZkYxlcnDtyQdvt19zWcYOrTbi9V0McVW qymlUil+foasf2NvKBa5leeJY7KUqU86YHLb16AbQetXordXMjNbyRkTIsjeYNroQeBj6en86KNK FWq4SVi8XUqU6UKdJ7FyS33fZr23sX3tGY2vHuBscE85XHB9M8ipIbbyzhrJ5YEvYoLmW0m+aEbS 2G59vqa6YyhhpOE+o6c5Yqom5Ctb28RuQ1pdPPLCb3yxfkrLEfmVQMnbjGcdf51Mke/7Fcz20TOl nIEMc2ftTS8gZ6r268eteqp1I0HCBwYqnSVf21aWqLdnbuImuX0ua7tbdF+1NFdqVkyuNozg/f7+ 3arMdps8xVtlaWRVeW3eXJj4AHfHH9K5KCli4cnLr1PLzbHRk6X1bSwGHyopQoUXkyBZ7griSMKT tGM7SMknH/16litHucpZwmUTSyqZYWw0ZjAZzz7jt61s6c6X7ue5yyUo4mNactJdBkUJNvDI9tLD vUvbwTOGaFQWwcjg9CTn1qSS2F3HaW9zBLJHMZGuYYr4QSTRkY2q3O0E89c+nvbgqdNN7sutWjHF clNaMBC5WMohCRkCAhmkaPAwue/UYz+JpsVtFMZYfLmVnYzxsLkpGFOcjA5I3ep6/WtY410qdqmp 6VTC0oQdSEndGqtsnnxGRVkRFcSB3PzkgDtznI/SrYRZGhRoEQR713GdgIyB93rx17+9ZQn7K9Vd DChD61J+0d5dNbGnFbhri2SFJWnnaUx4l+SWJQu7gcZDYxn6VPDBw0befKsYDIqDZgtkHaR0Of6V 89mOLwVeDqRkpVL6NKSsuujuj7DKsJj8LiOT2TjTd73lGWvySfyOl+zxC3S28oq0Fuqzyh9+XyGB BOSCfl6mrUaMdoVEVzEPNUt98ZJGeevOc+9cVGMKlsRJanrOFTDVHKivd/yNCKJCgXazPGyBZYpM DcMgggdePetOFQscpMcXmxOWPmzEiQYCgFe2CeoHOa6Jxl9g444ihUxcoVCYRGREVoYjtl3SoQGS TJ5I9xir6Ryr9pb7LOLeOVYfNcKFnX7wK4Jxgn/9dc+LxccM7TnFKz3dnfyVtfvN6GAeL0hBy1to tLet9Pu+ZO9qUsgslv56orpKFmVVuiBjgHpgsvFX7ewkcThYWk+zKslzHGwYtkjG4exHb1r4LFZl jsZRVGtWUk9bWta3yX4H32AyvL8tqSq4Wg4Pa9273025n+SI0hR5J5o7e33ykTi5Zm3ztjAB56D6 Z/KrMFuctNtRMR+XId2d7nsF6nnoa8nlS2PXktE2xqQloQrwr5d1E/mQSXAbHJwG5xk9euPrVkwC Ty8wsykgQuxKkMByFP0J69qr2cqjukNNLQXyix7oE3gTxdWO3cMH696lSAymOa5Tc1w5mdYpi6L2 IbvyM8dq3ioxhzJXfUl2aZcWBGKIQW3Seag5O8g/Kc+vt71a8pkMKvHKFUMzBeHnfsfzPTpVQoOr L2nRluMou00WDbuBIGRUkAcuDwEIwc4H16VYjto5FgjXBWJgRDG4DNGTlASTwc557iuirKnSg5ST 17Jt/gmVRoSrzUKbS9Wl+LaRbihiDCbYjGKcSBSpwzDIGcdceh449qmhiZY3iaPzJi6sGikGI1yc jHccj6Yr4HH4lSnWTqyupK0Xe1vR7P7j9NyrASp0aEI0I8ri+aS5b3fZp6/iIo6mMMcgmQE5wQcZ HPAwP1PSrUMP73mMukZdQSNu3cfm+nXOPpXk4ivPE15V57vU+iweFp4LDQwlJ6R013PGf2mv2hvA X7JPwL8X/F/x/rFroyWtoum6DHIXM+s3c8scMSQxrlmffKmAOuB68/wj+EpNc1Uaz4v8QNquoeJ/ H97L4t8R6prcbRz3VzxGmYTjyyUEY2gDG0nrX57xxj3h8NDCNaOz/E+98PMshi+JHj6luSEZRfk2 tDt7lIGgjj43XPm+WSSPIbZ/e9Bg8kd65y2vrpDppQb4YrhUubhx8h+XaAP4hyQf/wBdfluLXtoq vF6H7LyezpujSfvfmESyGG5mwBIYzFJGGH7xF3fw9+D+Oa5+ARiGVU8vybOSO6kiUkFAzbdq46He P0Patoq2BcJL+tSa9eWCwsYvWTHs8kElhE7zs1xNLG0yxFkwcsAc5yQAfr+FakKSPLc3WY0huYja wzo4P2YYDIVzyN5HI56V5+Bqwr1vd2RpGoqVPnrbnNeMZJTaQRW4ZBLcNausXzPGhBYSEZ4G45J9 q7LwLNeJpepXF1DkWpEMLPJn7U3AD7cDOeePxrrzOpKF6VPUwcKbxdHGzVttjkvjDpsniHwjqESL Gk9hBc3FlO8YJjIgbkf8CI6/Qe/5weD9Yk8L6leCCSIS6Ne3KFXJ/dru8zGCc7lYFeuTgsPSvs+A 8Qo4WVC+v/A/4Jz+KmXUMZhMLmL3S/U/WrwndXlloOlatdWS3Z1uxQkXjmJPN2hpMHHPXg+oqrqW pi2tGu3YfurUxWaAbHmjwxChcY4yeMc96+lrU/rVd05H5bha1aMJzofD0MXU7i2niEARJIjp4sVL yHLKVVwHbOAOox7Vq6HB4eNxHY6BpljbvGjC6vII1V3SQZMe9cYAfJ69zXl4qNTA4j2NCPqelkdX F1m6eIVk9bf8MepWOrCwunt5rNLmcBYVOTsR8gJgH5dpCAEGpRrF3LdG5mtvJdBLd3iTR5CFc9Bj Aw20gD9e3r5BTVDOsLi4uz5ov8Ue3hq8MNiPqso36H6A/wDBNP4t6h4O/aFg067nu2tLyKCaS+md cJMYtcu5kcYA2DehBB43kfw1/XdbMk0MEwXy2eBGK5yY8qDjPtmv3rxNwCoZ5HM0n+/Tls+9uu/y sfjWOxDqcRZlhelOdku2np+dyx05ycfnTc56t2I6V+bkjuOCT3z060zv17elACdwc+5OOlKT3zyD xxQAE8dep5GKM55J5HTigBPU55J5GKcOow3UY6UAfmb/AMFP/wBtHQP2RPgNrepyvHd+KNdtV03w 5pEN0Un1C8kljjijBXJXJkBJweMetfxWeCIdbRNZ8c+MWmk+KHj3U5fEHjK8uLgTmzuGWNEiVwAH 2Ika4xzgnvSxNWrhsPaOnN+RlhaNPHY2VFxukmj2OHxHrFtb3ENvcG0u54pGF0FDGzfAbntkdfTo K8113VfEFwZr29nuryX7T9piuLiYqqru3YIXjGcduAa+PlN4us41tmfQYfLHQw7wmHVnuJp/i+5i vkh1Ge4uYFL3CWqKFUHAUxg85POcnr2x29V0XVoryLO7zSkSxhA21Ttbl8dlyec8V5OOy6eHi5U9 jmweb1KbeAzB67L5eZ6haXttbD7TMXjb7HHJGkEm7zCpzgdcY6n8MV9FfDWwvPEuq2ViiFn86FWZ U2srMGDLx9zOOvtXmYSpUpxlWqR2PSzetSweHhRfxPb56H2j4v8AiHY/C7wRepbNELh7SRfKRhuu yY1YJuH+4RnuTX4v/FHxLqfxG1m41/WFlFvNdtNY2d5tea1j2kABscbsnPXjgdc1OU4OFSrLFyWt 9D6jLsNTybIFC/vSWv4nkJRRcWsDLKybjPAkTkDKYG1sdzk9fSqdtcBZb6SBYUMFy9wiO42Rp6c8 bQTyT/FmvpKqlytSj7v9dT4uVSFZ+1ow2ZL5IuFgiiWRTJayW9vO4yBKDnPJzjJPBHfPSsvXtATU LLyBazxPKu0iKZVNg0qgdenG3PGcZ96+bzSi6FOLpXSPrMDVlWwqlzWSX3nz54n8PRSw3UabUup4 5JI4UTa26LHQ9hnPI67h16VwB8PQ2MtxfqkkfyJO8TDk5IUkHOAV5yRydnvRTvVw6hNa6H5r4n5N h81yb2lJXn/w5t2yxbTBbANNdxNZNcLmNo0LlhGD6HHJPHp1r3H4T/CS18Y2n2nVrt/KsLqVU043 flJGVkkCoqggkcDOK/fPCLL8HisbF45pQSd/Wx/GlTDYnLce447RI/0vc/7f/jtGf9v/AMdr58/t EM/7f/jtGf8Ab/8AHaADP+3/AOO0Z/2//HaADP8At/8AjtNJ5yGyR7UAU799sOMbgCu/8ThePriu cuIj+6jUbmC7cZA54GT/ACoA/L7/AIKSfGKPwF4Im8P2d5KsVhHDearaWrqBdzTGWAFieVGWC56j bkD1/g8+LvxGm+IHjnVNfuNSe9soSlut6zF2uX2W7ySqTzncAvGBmP3pcV4uWWcHqnT3qSi/ubR8 jwpGGa+JjnJ/wYzj99n0/UwYdZghilvbjyXt7lGkjhaEnyvMUFgAOWYY78rk46V0Gn+MYbK4uZLp HeNJI4b37M37+OOEpwnBJOMAL3yT1zn8MzF4jGUebktY/qLD4ugpRw9eep6HZeI7WzuYiDbm1vLv FpIWDxqzHeGJHVk5yPWr158Q4XvZodPkga/+bTGQvtSUKBId7EYUFRndj2OK8rD5Yn/tVZH0M8bD HKODpvRbnP2vjWyNhbypO3nSQklpLbH2wh2y+3qufwzir+meMjLb/aTEVvLSKSS2tmcyCaByfLAb rk4dstggDrU43C3nH2MbHn5hjXg0qdGS5SlqnxAt86fNZJFJstord7ppsCI7js292z09FznmuM8S +Nm1iX+y7WYxJODHLaSSFo4ZWDGVd3Ydt2PXGc19NkuEXt1Utay/I8LE4pU8J7OM3ruekfD/AEVd TitrI7TFZwme5nMvztIpRkYnpkIx6duK/QD9k/w1tu9Q1SK0lSbTJnkimBDNfQFBIsrdNrYXgegx XznFLlj86o4acdF/mfY5FQhg8kqVF/W59lX2rz6jq5tbK7jJ+2+VLGkZPmhyCVboSfmzxyDXrLX8 t5c2Vr5TwwWyMhgUKUeNRgliDnueOte/9Yhhr0l0/U+XxFSrVwSxEYnR2gn01I0V7m38yQPvJ3Bo zwoGe3H9OKy/F19Pa6LFcWzFXnuAlwiNgXMR3Arn6H8APpXbk1Z0oTcl3/I+bzbL1mHJXb95P9Tg vB6HVZ11mBgypLJZBQSBczoAGiJHI2kHnocGvWNTkuVtLh8rjd5qlpd25mU7TjgjHX/9dLKKsquI qOS9DfMv9lwMeXV6f5HjepRs8l3O1qlzItuu54eBdrgHdnoMkdO2K8M1e5+xMt+ii7El3I4SFF/e OPuknPReMepFexRpyoKXO+p8/QrQqQVSsveRlWVnHHbabGloBuuDeQxElcRYbc55wzFyetdv4YvS s8E6MiRJexvEyS53oqksueh9fbFctWVWFT2k3y6M7cLiPr79nSe3c/VX9l3SfhH8S/BOs6V4++EP gzxRcx6yLmDUPEdgk73du6+YWYAAhmIJA9q99l/ZZ/ZGnaH7X+zh8K57143eNrbw3H8km5jtJYHI K4ywIxnivWybEY3E0XN1mv69T5DPq9ajjfZ1FdK5zt1+xl+xpfzW8rfsu/CV7Rma/uYzoEavNKV5 QPjlRjtycCucv/2Dv2GNbnnudX/Zr+HB/tQss1vp2jCB+F/dsCMJwxySR619FRxeZYeLhCu/6+Z8 5LExbdqaOfuv+Can7BV8gWP9n/T1vEEdsk41TaYLgnll5wGIBAbHFZ1p/wAE0f2G7SG6Nv8ADnxT pSSTuZodO8b3arNAcYDhZgAQSfu9cVpDOM+pvmp4jX5nDyYd3qugubzK7/8ABNH9jbyJYrbSPiRp KiYLb3OgfErUbZ44u5JFwDnHcY966LR/2Bfgr4WP2nwj8Qvi7pZFv5djBd+OL26aUlsktI0xJbBA w2RwMV6uC4r4loNynW0RzVcPhMdSUa+HSsdFqX7F/gPURcDRvjN8ctOE2kSPJ5XjJ3axnyC+xZJM EcMPUA13HhD4AWPgjU7SeP4g+OfElkT9oa38QXiTu8JQDbs9Qeck5xmvaqca59jI2nL3TGWDyKlQ tSpJS77/ANf1qd7dfD3w5c3dzPE1xY21xMzOPtDusQJBVVwfbt0zzVqPwPYgjzZX+VvNRvIjk8sj OwkZ6+3P4VyvivHUqlozuePVyzK61JxlDV/1/W45vBitvis2gv8Aybhj501rFEu0jI4PQeorCvPD nxDd5LrRZPh7NDDcpDbpq3hWCQxIgxswCC5IbqPTvXp4TjOvC6b0X4nFU4Tws2pSprT+u5y8fhj4 5ETvBpXwK1TVEZdN022uNLNsCrBhnKPgN0JJz90cjFY1voH7RWmpYzaj8IP2c9Tlt97Wsy+JLofb W2kO3yqTkjHAyeetehS47o8zjWTPNr8K0atTmpxVl5bE8Phf4mvaWrXfwE+COiXSwNfXf9heO7qN b9d2A7b0HI3cAc9asnRvFNuJPtPwJ8I+bJF5LX2geNJ5SgRd2XDADbnntjnjmtqvHS9zD+0bj6u3 5nDT4Fwsan16tTSfp387X/rcsW+o6itvaWuufstWf220lXUE160+KZaPUYirKHYbRk8jAKjH4V84 fHXxL+1n4bfw7q37PH7Ffhz4laFHpZHiLQvGfxhl028vr4vkSW7xwyJtAycEqCMDivpcv48yjBxX 9opuPlucmO4InXlei7RfkeNXv7Qv/BQO2NvPrf8AwTJtZZ5Xje4srH4xW/k2carjdjamQV6dMcHi uwtf2i/2iBfadNqH/BND4hWGlXNpLNfLovxVtZpdFnIZT5vmSrvU7QykHHOMV7mG8ReDMXUTjzRX 9eV/xOGXhhmEKcnGsn8v+CXLL9pf4lfaJrbVv2GPjfpd7AyRRrZeKLKQTkj+Fi5HOVPUdcV0aftG azG8x1z9jz4/aYRbb/NvDA7XEykgIqRSk8Ejnp8vNdUeNuGPrLjSxNvKx4uO8MMxxMYVKUeZpd9D Zf8AaN0M5S8+AXx30ueMRodPHhqR2vZgwZ2STYynIOOuK1j+0V4Bjlc6l8NvjRpkM0kg095fBNyz yTLuQRsqR+/1bbXqUOIsjr429DFR+en+ZhW8PMxoYFxrU3zvtZlxvj98FriSRfsXxUt7q0kk063s 9Q+HN/AmrZRWLYaIAEHIAGenvWhJ8fPgbdOsqah4hFjHMlre6hdeHLmJ4XEZG0w+WM4PcHPHPrXT DMMtr4iUpVk1turHhx4GzfCYezpN/wBegtp+0D+z9qMTP4e8aale+ROYNUspNJnEglYBVIymSAG6 L15yea9Z8NXVr4ktZdW0Q3Or6f5n2G3eKyeGRQg+dsPgEbh+APeu2vnWW4RKE6qt5NPY8Wj4f8UV pTdaN4rbfz/pm7/YOqoVtptKeGaOHzHgll+aJWyMbgcE98A96gNpJHbSy3Gn3cAtkG6CWEsZlBxw RnPIP0qMLxJlU6tqVdJ/ccOK8Pc6w8Vip0232Wv5XsPeyuzGZf7PjMCqjSyyTNG7Mc4THXIAB/Gp VI8mKRrFrJLNfLv/ADrgMxBGd2OvAxxnNerPF4Kq3VoV1L0seViuHc1deGGqUWreqLEEe4wrDGzK bbCbjtwRztGecHGef/1xtEs0cWYZBC0rXQMrfKWyAAO+f05ren7Oph3PmMMXlGMpVYzp0m13a/IW BZ1jkllt1aOONZJBLMEWKQNtXGD34H41FHbu0sF0YycxHYgm3mFAckA9OCvbk4rSdCjOEXSd2XDm lhWq6dkaSQysyjyZQ0nmuqgghgMHgA9+TzWtFHGVC7ABNaAmNDkW5Zskc85461z1aOIq03Chot29 Ht0s2mY4OVOjiY1Wrra12nr1uk1oXo4n8lE8tV+ciFFlDAJkjJHYk1eto4wo3Rn5pvJ5GAFA3AD6 H+dfM4h4dzcppWfZW/C7t95+gYWnVceaUtV0bv8AjZfkbKxqouXjQyLNdiR44z/rCFCgj0A9v/r1 oLbRytDbiEl97yQDcUZcKG3Z6+2D6UKlSXLFbIU8XX9CeK2VnXlR5pbfs4YEcgn/ADzWqlrGk08s 1lHPJKsMVwZVYF4RkjkHgEkn6Vr7yT5VdkyjhvbJKWnfsTIiwx5SMi5M0oWJSdjRAgAhznGcnj2N XzbBXARHWJxtERJPl4HX37/XFfH5vmWPUFhqmHUb97S/4H4H12SZXgVJ4vD13K2ml4/J9X99vIsS QuGjkWNZnRiFSMBGy3G7JOOwz7VeSBxG8jRbUEzRxSxzl0bkZJxxnOR3r5aL5Ze8fU7aIfCjoVZE 3Sea1wu5f9YoHIA6HHBNSGHYkbsiZSMO4WQkNu6flW7wsvssc5Jtu2g6BDGzC3jJDuJI2L7mj2k7 sg8Ywe/rUgQJbl/L8uG4gJjXcQyIDj5eMjJrqhT9nDlW5NluTOitvSO2KRyTIZlU/IGC5yvcccfh TokIwBGsau3mQ4bAcHrmphTlT5pJ3bDRq7NCOMvPlEKrbhliQj/VHBIB9evpVl0VISZFd/IiUSOj HEQ6byO4ycAe9ZKp7BSqYqSS83oa0aNfEVOTDxcn2Su/wLCQmNcFTIBDwZG+/wAngD/PT2pv2ddn 7oImyYPHJ/z8Djlz69a8fE5/hm6lCjJLpdt/euWMvzR9LgOGMZOnTxWIg9deWyv6SUpRt9z0LvlF T5ESMqNn9055bnjI/OnPEY0CxxFHj3NJMZ84Hc57Y5P418TVqTcpRlLmu9+/zaufpNCjTUYTjBws rWvZL5J8v5llIo9qyshETr1kJUjjqB7+laVlayS3OxmkdnMYYkZKpnaDnvgdfSsDqP5Yf+C3PxC1 b4wftd/Cf4DHWYLj4VfBbTJvF/i3wqYhNbazq0iaTeWLS/3WgeMuhB+8vIOBj8ttUkLaxDOkP/Lm 1rM3ryQgx0B/2h2HrX4nxdmGIxudug4XjTvE/UvDfAVsswGMxctqs0191jkdWeRItHhsoDFZw3E8 M11KcCeEAjjnO4Nnk8c/jWZHF5ZtGigKtF5cpjf5jkKV2t2IK8jtxXztXDRg1WT90/T5SpwtKTsW YJWbymu2V1jkARIY9iSI7YJOOQQCGHXoR0rk7KS423HmBkSK4dnebaBGiu2NyjjDgZBPpSnX9nOS papmGPSqx9uun6l25eR7S6hiHlTGMT2fm8lZlXhgOy88euQMVvLFE625VId9rNG9uAp2u4HKN7kM 2c1OHjLDpVbb/qVVp0sTCFRaf8OcH40nkmEMIjDNNGbW2Z0VfJc7j85HUAL+II9q9G8P3aCxnCMM bRqMsYb5ItoVVVgepCtwPSvRxnsIYVVI/Ezlmo1cUqdrW/QL5Yr6z1CBE8x20xreGSNs7hlQMDHI I4PHv7V+XvjfRIvCPxHhUxEy6jrRSJZdxMTl5Q/I4wFKjcey8cnjp4Bq1I4ydCS0/wCAVxbVp4rh eVNRu4tfqfpB8LvEUmoeE9NV4hFKjy2cxdS0ltFGSAhU9QQuc4B5r0Ax28llZzxl1uZA0rSOnmCz JBABTtnKjI7fSv0GrVqUcbztaf1+h+O5NjsK6Sw7V2l/X9eh13wy+CPgP4pWtzdfFG68RXWk6BYt MfC/h6cwLqDrcxkyyurAlEIXAyRgnjrXYfE/wf4DGk22r/CDSodJh0CV9N1yCKNAZkVGjaMMCc/M ynIHGB3r4XNczq0c7eJ57w1P1ThXKKOKg5T3auvuPDvDXiWxhmjihCTkX32O4ie5LKkke5JlJP8A ErKR/wABrs31aWa2VjtijW2e9jUk5SM8Akn7owo57V7+ExdSWLo4mT2af43PDr0q2GzWrRq7RZf8 Da5qngz4sfD/AMd3ML3VpY6zPfW0UN41uVn/ALO1KBG3AEMHNyqcjC7g3UV/dv8ABrxhF418A6Lq 8UsUjCNrF/LkBLGE+UfyKEZ77T9K/rHxMzGhnHD/AA1jcNTt+4fM0t25vd9z8gzzLIZdxRmGK9pf 28udK/RK2h6p074PfikIHPOOc9Olfj5yDODnLY59KXPUg8AY6UAJnp83fJ46GkPfnv8AnQAu48c9 OlGeM55znGKAE9u2awfFnijS/BnhvVvE+t3MdtpmkWhubmaVwiqMhQCT05I5oXYmcuWLkfwyftyf tNv+2R+0dr/ieG8Go/Df4dBvDfhEi58yDWr9Gt5bi4QDK7QY9gPYxkCvkzAwbeJZZYEkMh3SjhmG 4BG4PGOcdM1hjHKvN0pP+GrfqenlWHhgWsbCOs9fv0Ot07V11Az3yRpPGiEXGGOSTGFLEDoB9Oe/ WtS60qz1CMKjxIrLlMr5iuoHyjggEkHp0B9a+LrL6tKTqn3FP2HO60lZ2f4mE3giztY7j7BZohF3 9sniiixvYhc9OrcAZrDvNH1PTECwCSF2vvMl+U5lUncBn/dxj1x706mNo4iChVasfL4vI45jNYza adyXw14z1TT9U07RZrB9Q1e9uJntbfyXEYcFvqAxA4GetfpJ4F8bn4YeH5L2+S607Ur2ASauxmEd z5KgSZZcEnOccdNvpWOJw+GhhlDB6tnHVxFTMq0MLXj8HX0PAvF/xM1Px3qf2m6kni06O732GjtM DhIyyozsuVKuHBAHI746DyPV4biSERQJ5SoDi7j/AIZc9sjgEYx7E1nh406CcaktD7OhJYilJ1NV 0/pnmV9YlV8kq0e3/V4+UzYwM/nx17Vyz2stwjW5ljhuS/lyyIcgAkEAjoQcHPTGc131MVTxNFQg tj5pV6eChOfJe/8AkbdsvmNEqMRF58nnu3LncOGzxjChhx6ir0c0t88qS2YSUo7WsIwGJAwmCONx Az6da83F06lWHuPY9PCyi8JGlNpPscBq+hPeWkQiMkxKStFExAUPjlQ3bJI6dP5eW6p4fe2uWig8 kahHJMpjWPdmIgkRgE44KMSR2B9c1x06tNR9hyXbHn2RTxOW+2jL3bf5nPaXbQIt0YIGE1pcLZq8 rHBDfPsUHIbb1Un05616fa634ksUsYtKto1NxcmBtQNxtMcZbnBAIO35hnjPevpcqz7E8OVJaN31 /Q/gPxYoYrKs2SqS913/ADP9MfP+3/47Rn/b/wDHa+uP7FDP+3/47Rn/AG//AB2gAz/t/wDjtGf9 v/x2gAz/ALf/AI7SE/7X/jtAFe8x9ndyNzLgjA5HTpWEp8u6FxM0a21lbyXMjsuQgVclsdeDjj24 oWuhM3yxcj+SL/gtn8d5LC08Vx/akt4oNSFneWEN8GluYjqUEcGdvzYCSnnPSTnpX8hlpq62CujC XyGsUsbaHORcrDhQ5H8IOAAB12Z71w+JGIqSyzKsHD+S/wD5MfPeD+AhPibiLN2rv2tl84nXW/iq aQXCZczWv+jCJJSBGzYDFR3/AIck9B9KzpfEs0Zlh2zXNrb6gjCRJSrToynMm0c/e+X368CvzvDJ zk6E46M/oClhKFeSxcJe91Ohl8SajDIlksiuYXjeOHzAwXG0MML0bHPX+Hmnx+KotMupZr+SMu87 XELo3/H+SSu3HILcDPPpXPODpt02tjWeYvD15xpdWY3/AAl0f2aGNrm6N45WK/tJQVUhm+bnPAUf Nj269q1j4te6AtLO4kkt7m8htIMu21nUEJubgou3djJx2PWueeDnOq51YaFXo1o35rvqNXxFbXc7 Es891LYMtq0sp8uIRsCg9MgBjkdenWk0HVLu98W311cl5LbT5Ybeyk8pmju2fmJMdc7m+92z8w4r uwuCeHjKtDTS/wCBzSrKpU+qVV/W595+ALm5Pk2MunC4uLyVTvZhtbDorKeeWYk4Nfq38H/DKaL4 G1DU4oVxqkieY0uFNw5jZY9ozkElemONtfHxk8bn0rT+G5985LAcPqc1q7I3tEuPtOptdMXkJkEm 4nmMhRuz/vEfpXrdjeXR1SdJdNMcNrbbmNtMHDNu4jXPpxlumPXmuiTnKvUutL6HgYjMI4TD0MPJ br/gHRXd9NaTWVvOM21xukndZMm3GPlBA6Drz1yOlcl498RJFZm0AlWWL5rZPMBW3YY6juST+Rru jV9jhanP0PGx1aEq1NU+rX9fkbXwxgi0/wAP6eZMxLfFrp3kjJNxJguy4/vFjXTeLLw2NjEiRskt xp0juDIGF8qudwz6dAO9dHD2IpVcM6tT4v8AgEcUUpQrU6NN77/eebatci30m8m3Moa3E8T5+9EQ AMn+EjJ4wegr5y8Si2MctjDIt3a6oFkt7lmw4AIGTg/eY5HpX0k5Rq4Z1ILX/gny80qWLSUdNjSh mN0XtgjBLPThHJCCd87YyS2cYA4xzitbw8YLSCW3mMYS1Ro4HeMrFkrsBx1HHcdxXmYpRxFONRvX a33nuZZg1hXOcY/Efoh+x74ok03xidLSFJ21XS5JH2v+8upVTyWVB6IpU++cetfp7eWzC8EG1vKk kmEMLnazxo2OVzkHIr0uHYVadB0pLTqfCcbRdCvCq3dP/MrxK7sha3dIZJW2SyMA0nHITHH9efeo oHLmORY2aXDOwmbYUGCMEdjjt14r6GFJUqrcFoz5DmhOlrHUneOD949tBIlo9tFb24a6BYKODycF vmBHNRJteONolnYFRshkj8oqy8FSM7evTpRJPmUab8zFqDd5PYmwFMUK7eGKvhg6nGSVzn8OPSmS STIjSLHj9yBE07btp4PK+w7k1u9djlo05e0m1s9tf6/EsCPZPbwkgrc2k0ikuCuCMnJHc9vSoJJZ pLOSUwykrEJZGi+YqF4UA5HQdOnWup144aly0ne/9bGU8DNS/dvQdO4Do0m9iqIZo0mx5aEd8H09 OelSecztC+4fupdkShvvKoyM46Z6/hXG3bQzWEq+0cJq1uoinCGMSm53Snc3mBWR8gkvj2xxUjLN JdSJLIoummEQVgAsmBnK44AwR/KtaMYupyyPU+GNx0IkdCgtVmijuDOsqOMxIoIckEcHLHv/ADqK BzZmK2gi3QJC1rAyzEyFcYxznHB4Oc8V21ZTdRSpx2PL9nUq8zS1f/BHo8eyOOGP5UT7LIXuDyVz lj39OO9S/aGDvbT7xFcnyljaYb52UAg7fpmtpQU2puOvmPCUVOMqVbfsWZb++d1y0ksUSNBDJuws Ywcrt9MHrU32q4tUjlgSdZQu8vFfsiT7RjqDkM3ArWUaco/vBVaFWH7qKbiW18SajDJdfPfKif6L NbT3rHzSyLgbiSR0AyPSpf7X1BLf7HI0zxhDDKJ73f8AaW3bhzn8K8ytRox1pyNsHUi19XnH+vMs ya9q8kc1rLeXAgdmhuI0n271GO47DFV7fV7+JTE15qC+XKJEdboubXd8pAB65GD+Fd6w1Fe/FanX KD5OSm7fInTVb9pJHufKvWSGdbOe8jDSoMgK2M8cqME+9M+0WrLBCNDjuLmW2PnaiHUtayx5csQx xzuJ+UZNTToRpVXNy1ZjD26jPnldolMlnLNC9xoehXkyqJIY76D93C45zljycDIHqenaqS22gC5j ux4U0W5LhrzUFvNNV4ZpWIX5hkEccjacZronKMdb2+ZyRxOIqp0oK5e+yeHf3do3gzRZGZZN2Igo YjcWCleoUYzz2qW3eFg9slvAqoDJBaWtuI4ydhAIA78c5ziuj21VLmUmckqVSlzQqLR9DSTUXw0q W6xW6CKeK2uSJVsmwEbk9Tnr6VFNPHJb+bcxtIls5VQYywAY9gPuqD6eprpjmFRW0szilgoNLkdi VrqwuJbqe2022Xz5VmImQ/I6/eGD0U+nvT1ttGYWxTQFRm/cajdRTZa7AJIBJ+7ndjv0rermdWDX sJXNIYWjTlaUNe402GjpgS2OyVdoMgmVo1xlQOmfQdf4fxqOXw74TkUDU9FuJprICNP9K2vZMMEl Dg4ycDpW0M+xsEnzPQl4SnUk4yheJmN8P/BYUzomoxalLMsxhmvXmUgAnrkKByRjFRw/Dzw1bRmK yl1y3k88La+ZqplW3Hou44bv16V7NLjfNqD/AHdR/cn+Z4kuEclrOSq0VZu/YlX4d6As9neXUt9N cmyLiZNWLOsgJByithQQBkYqf/hXUE0dlL/bF0DM8txbxSShVjKk/ePUnrgHjpXRPjjH1kvrHvP0 QqHAuWQc44KmkuquEXgmS1ijVNRa4tVgGyW8j2MWBzjjjIbI/KrMPgnURMjQPZlp4zPdxvMFaRhk cPnbkADjBrop8axcVGs/zscVbgaisS1TWr9P8y7D4d8SR3HlHw/pV0wmks7Vn1d/lJHDKEXrj1yM nuOasv4Y1F1Sf+zbdo45FS6Y3JzbvtKlQTnOcfrXr0uN8DFKDn+djOtwG+dqEdX10AwXkNyZINEu 3tbiDykv4roCO12fIyFGbeSQc7vardjaI/mStpt0suGhxhUchOFYNk8HPcdK3xXF1DFU3SwlVLzs /wArM8+HAX1StGrXpuSXS6/PmW3YmMiq5MsGpAxF08pbbMYDDqAPpirEdxaieO1uvt0E5jMqbdOe Z3GQMFx8q4zzk9/xr5pYmkpvln+n52Pe/sfFOS0t5O11+Jbja2XLgSpaRsDGLiPy2cBjnOTkdOD+ NWvKW4MYERyjKzlZsYG4YzxjoPxrZ141ndszqZVioSta6LCpKCFEKyCKNllaSTaEUk9Pbkn1q1Jb gyqWcrJ5odwzgF2IwGP4D6cV20MRGXuzZx1sLOneNRaDooZLhFdIV8+RHcRCQMVVMtk47cZ4pZIy HjYqdxjaaLJyHXdg/jkcZrd1Kc3yX3BUaqSfIxzQPCwWWMgLMkahmIyAASPr/wDWz2q4sUixkyK2 2KfYg3Z2NJn7o68Ac+1aRgorliZTVty9CJWmWCK3KoIwpI/5aEAkt+OPwojjyqpFGBiZmkDthsKN xY9sk4+tePjM/wABhKjwrbcl2Wifndq/yPocBwzmGNw6xUElF7XerXlZO3zJgpEe5A4RzuV89MjO ee3X8aldcrC5i8h1G1vnJ3HAB6+4r5PNMfz1ubB1tGteVON/VNu59jkeUexpzjj6D0fu88ozsv7t kuVeRbWITzSSJG0KI/ygvkg9uvOc8n69qfDAsRSFV2iFg6YP3lwc5+p7egrwz6ktJGBCEZc7fmRd xwmQQw/HnmuQ+KPxM0T4KfCzxv8AF3xIkf8AZng7ShekO+POZnWPYvqWZ0A//XUVJqnCVR9BOMpr khuz+He+1nXPHniLX/i/4r1DULrxP8UvFa+KLkajKrvp0bQxxQxKCqkqsacKQMVxepwTpqVo88s1 xbi7L58754mcttUHjIBA+Y8V+G5jjpYvOcS4q0W7n9AZHQ/svhvAUams3FN+t2cZMzyyWXmAiKDf DJI0ZPlZY7V5x7kHv+VSRNDF5GRl5ZcSSuf9SysMEL3yBwK4aqpYn91B7Hq4nEc9RU5LRFeWSSNZ bife8pn86R4MhSxJ2/Q4PNcvcJ5t7aX5mNrBZ3Dwz2cQyb9XwBvHbB4DdgT2rlr4lYZ+woxOinTj iZxnVdl2NKJJDPb3AjiRoLh7Bg5/484SN2cjr82Kt6LKL6C8ulS6RIbyS78tx+7BDAIwYeuOfY81 jSq1nS9nynRiYxnWiqT91fiYfjOzDad5qvvmSXeYl5EoUNv4Azg5yBjkir3h6WeHRrKS5Eo1C6RB OrzL50mAFbzBnAYcAgV0YuN6cVa7R5+Kxbp41UIU7ro7f1/X4a2r3MkGnzPDtAvLczvPGgy4j+Vg W69M8+w64r4n+OuluWj8Y6ZapLctbrpwmdyVV40eR9yj5VyoBJbrzzk16XDFZU8zi5OxeYxvlNel BdP0Z7H+zl4xhudM1Kwmbzb54pbzEyl/LZ8RllODhW64JyMV9xaJc6eE+w/Z4CZTHHLeOS3kbFwW AB+Yt/Wv1PE4KNeEpL0PwTKKCp4ueJraX/yOkt7K/j0280nRri6tIdRsX065W1fbNfLIUONwPygA HGPavl7wV8LrX4VeO9b8UHUNbvtIl0+eO38O6nqTtDPdtcm6mbZuJYyIQh7gL1Nfkua4HFUa31dx ur6H7XwhmmXz5cNPdfj/AF/SJ4NWbX9Zj8QXGh2mjxwymK3sNNDBV3yTDnOSMoyj229a7LSyLWH+ z0t7hJZd9lA97ciV54CrfO7n8e3YV9jluHqUsHCniNTw+Ls25c0q1aENLmxrmlQ654P1fw/cF2Mm kSafBcW52zaflWUbT13YO7djjP5/1G/8Em/2gbbxl4CvPAd5qLXt/pV5LFa+bNmRpX1DUi7EEAkv HAH46bccjkf1Lg6WCzLwYeYykvaUJ04JdbSu30/X5H5pxnGeIzDK8bSj7vs5c3a9/wCuh+zi8HAO OBjPekIAOM9uTivyk+fEzgHB9sY7UE9DnkD0oAT8cc+lGTjHagA6YIPP06UucdD1HPFAApOQM47D ivjL9tX4Y+Ifjh8LdS+FOk6nqej6d4kaG21y60mXbMbYzIGRTkHLrvXqCAT61Mr8r5dzjx9WtRws 6lCN2vyPwH1H/giD8KPBejDQfhjp3ifwrHBpw02I6RrMkH2UkgvIF343k8swGSTXyz4x/wCCR3xt 8IfbdR8BeNJbtJfLhgi8RXv22SB3GHby3lOQCASTz1FfLYivmmEvGpC66/I8bLM+q4zC04YpOLVr HgviX9lH9of4bWr22uaJZ+I/stsBeXegWohillUZKANKXJc4PTjJ61892OseJ/D1lqF94p8J6tpk NrBLcXNjBbNcmxnVyuyTABAbAPyrwT1ruw9DDZjhnKorWPvv7RrUsLSxKldHV6F470rUXtbdzeot zCBbz3FkyLECm85PTOc8MR+NdK2v6dqFvNcRyNcBWaJbhSEJeP5flJBBA9QO5rzZZTSnTlJK9j1K We4XEzlGejRs6NqVpo0VxbaTpNv9ulKSxamYw89q+MhADxnOTvHvXK6lqeoz3t3c3F7PcRfOsDTX Hy24RcnaMcg/MTk1jg6WHoP39E/+GNcrhSr4irWS2v8Akaej3ltbXsUDxiTyYzFPbI+xAzrkMvY5 GM4/u4rrpY7h7Z7gGM3MZjyi/dYjA3bO2cnI9a5sz9jRSpwjceDxMI4icG/ivp2ueZamk7/aI1t7 kmV1jjZGEglbO/jvjAwR2ODXnd3DJCJCId28GaC3j63JXcVQE8+uM1vgFQrvTaxz5lh40MNOc1eV xbC3YRGKFDa3MLG9MU77/JGxSQjn0JPX3xWpE80EfmpAGIURKy/LuBO1mUDrjJP41c5Klz0Yrr+B 5uAk8dGNKej/AMv6/UyLyXFp9njCPBbzKiYfIkC5LHPUDA/M153qmnwyxnaXaGS1ZnlZyrQgK2VX ucg4x1JB7GuOeG9nVjXtZ6n1ksU6eCdDEO/QwdGFvY3bXFy0kkssQuZ1ji2ZLKQhKc4GABj/AGcV 6HpFnZSp9gijt5IJ3MmyGPH77OGz7hcjjutedn+OrU5wq04XP4Y8dsox+JzDnwq93/gn+k7n/b/8 doz/ALf/AI7X6if1EGf9v/x2jP8At/8AjtABn/b/APHaM/7f/jtABn/b/wDHaaef4s8elAFeeJ5i iZ+TJJ4+7wMf5964TxZqsfh7wR4y8STKYv7O8N3U5bzdpUrGxbHuMDHrjjrWlJXqxXmjlxs/ZYOt U7Rb/A/zy/8Agsp8SrDxF48utPsblAb7xM7i13EI5ivdLuFJBAJO1zKewLbeeDX4pPc2qoJZ5MMH nf5iuYwqbi5z2I5XscEVy+IeHjPG4WinpGLX4nn+Cc5U8kzXMYu7qTUt7/ZtuZceqSwNYzQXIjlj 1V7y5kMg3KnlArgdfvYyverFl4hlit4jPAkcrXEo+VvmR+f3jEdfMBz7Yr4VwjK0pLVH6pQzLkac VqWLbxSJYLW6to7mwE6sbzzuAJAwCAEdMrknB796z5ru6vpFfJSztYWlVlVgkfz5JIzxxk7sdB+F Rz0/bcr3O7E0/aYKVfm1IZ9UknvZLa7jCI0CR3qrIE84yApnP8W7v0BDDpWnbavEljqFuqySwb3j nt8bGkcERKwb/ZJyU6cVdT2jS9kGVVYQoWk9X/wTTt9UsZbUSR+bDc217NcxfaE2/aFjXoQeBjYT jGDu/E+ufBI/2p4lS9xIjS3DPamQ7kiV0VjKwPC/Nnp13Z7ccmZNxwrs/wCrHbg+SGYxdbV9/M/S f4QW1ldeMdHigRxaqZrSJY4yyoV8qQgt/d+brxnd7V+qniSew03wza2cKjT99ssNtJFJvchSVZmI wNxJAB4xmvhMgw862NxFeekv+AfdcR16VLLqMH8Ls/xMfwyqxWUM8xMd2LZbO2a5bcZJWG3LEZBI J4Jr27RhBBp58xsyiyy12mNzLnGwf3SW+vXNd1CsoVObscssLRzLlr8tlFD7t47iSPeY99tZKJAi ZCqvzFsE89xz79q8X8SXy6rerFG5ni1ISuixvzDscJt3e6kEc+tdVdfW8vnVjp+t0eXGlReOjG2i /r+vQ9w8M+fp9vDpoeKRIoDA80AXamVJDLnI3DgfX61S8TSJeRafbx7dlzuZXiOCsXOeOoJdeelG UN08J7OL/pmOdRTxiqNXirnHa1MzQWun27xyJbWKW9urt94jO5TnIyrHHPWvn7X1EPiq401pZDb2 FisjlMbo5DywC9MA9ceuK+toN06Cjt/X/BPi8XmqnmLpcunkV7K8W6i1BpIif34TyYnCgxswGGzw VYDpW/DNdPCtvE0i3UdmJCpwTbYDAD0OFzn/ABrzsRSlSqOT2Z9BgsT7Om6b7nqnws8fat4b8Z/D PVrazuZYYdftbHV/IkwqxzYjaTc3JC7gSAOd3tmv6BZn3pb3I2pbXM8k6MBlUcMdqhu6n5Tx1rDJ cdVjjKsJu6T0+48njTAYbEYGjFLVpffcjuY71p7VLO2TJeR5Y/MJXZtP4gqeQRxyagVgY3L4JY/P JM2RNIoAG0AZBGMZ6d6+nU6uJrJXsz89rYVYKjGjKN1YsyfZPLikubZZzMzTpHHcH9yRggKT05xn I/nSSNcOxhSIyytJFNJIHCLaMSC3PRsDIx9a9WytoeJOFOE2ooakfkyYt7cRW8k7xCRWVVkOQeCO cEnqfSrLfK7kqnnMBa3Eay5GT06ZHT9MVy0a3PKd9zedWDj7OnGy/Ea3lwujPbKkoHkiUsGIRT0B H17+tJKfNVGeNHxckBZWKLc9cIR0OBg/WinSqubeJ2/roctbEVKdPkir6ihmcW5iRUkWBknE7/Kx HHXA4qKFhLHbj7K9vcxR+ReOjhiihui9OOOPWut25nYJ1WqSlU0LUojebaxIQREiTdkShugC8/Nk ZqEuyhHigeVVuPnkSRflyMbufX0HNSqqTtTepryKrFxh2JGaWKPzvJ82dY2RRu+7uIIHueAOfenw zSefG7xeWQC0KklhuK9/fqR6VUZTS5ranDCVVKdOklpsPQQxqweJ3+0RPNPFDKA8i9Bk9j04OKWR ygili/e7mUs4IAZSNhPI6qOv0NdFvZJTUtS6c4wpKrVevfQcFMpkEIYvcSEb9+wQrjGSB1zjjBqF N4hEKIBFCSsDtL/rcoNp47Z4/CitWlUktLI0cqlX+A9PTUvySIhhMltMWaDAVJAAGHIyR24Iz7/m yRkuBiSKMmVxMC672jUHoQeAf8KurQslKjqOnSVNeb3HhuWYsCNrSKWGOWO3kevtUjiRWDsk0zRM PMLycop+7yPT/wCtV068qUbVyK1VUqftOpMpWe5aDLKslqEDrLjIzuKls9evtzUbKbiCCNpmj864 2CZCCWhyNwOfUAD6HjmuxSVePNYwniJunycjuyyRzbSNDI9zbBnhAbiNWG1dy+mO/wBafEu5rczR 4U7Y53Ug4TBOVAOCeOlebCUHJ+1R0QiqNG/LqTqTHMFhjWEKhuNqOG8lSeMkcZyeR9aIZICsTrGH We4N1OUnaJgVOwqQOCCPSvZjflOWu3Xw6qJFhJlVyX242/LASSHA4H5Z/SpYZWC+WFS6beJ4fMJj MZAICnnkd/8A9VV7u5yUVFzSlsTCXdbSuACo+Qnd9526/lk1NC5mWLhVKqowshXaBwPrnHOayhKM 7uPQ2xEadlUp9RUu3k810hjSNgOHkADsW5QDqOBwfpVmFhbxvsiMchhMZ81ySckht5OeQPSnzLew 3To0XaU7vyJbZVHlLgxm3XIQEjbHg+npz9c1YthPMymNiuFMRL42EgHGSemB09TQnaJpi6cVBVEr Mk8wfNKkChWxG0rthVUH5jjqxI49jVgSLGxaISL5En7uNCTwQOv+e1NLW6OXDuaq2jKzLzPdiFZY go3xgy7rsIGQtgkIcnO709Kl87zNjlUUlTIyZzsZfukE4yODxjvStd6I7qeJhzy9qy4LhzbxzG1m Z3cpFcxXCkWxwOWjJyw7YHTNTRXQklkYRzW3lMJEeSRcXRX7zLjoOeM05LROKOmUv3XtKSJVkdJk Lo7QniVnfnaefz6npU8cg2rKypHGzPDGp6hhyC2OoIz71Kcr3ic0P30edy18ix5zEOpUSyLEkccm d5RsA8YPoCD6YqeN4SJB5HnqI2+cv8okY8AHuehqoTnG7jKx0Rak7AjpP9pjNtH5kFmTbyiQBZZN 24rJ9M9snkVaH2fy7iGxt1E84AFuj8wKTuOf7xJDYB6+1dSxlVU3fdmGJw3tJJpjfItmk3OC0b/v QyNuLAA4OAP881Pc6bZXDKs1vuKxrOhhl5Zh8y/MOgB7e5rfC4+qnySdvwODFYWKk7pNf10K/wDY Wn7bl0imR5XyyfbGJUtj7pByAM9vc05PD9sg8mKa5MkkWxibpid+c4z6dfqPpW7zWtTm4voa0cqh WpqpBxbfTT8SY6JzKI7yc/aEMKNuB8psfw+mCf0FMewv0dvs15MkkDCNJN2QFyAxC9sjPXkZreln rs4z6/1/WhU+G1/Esr9Lf8Gw+VNVkht9l4JLTzJIUikHLnO7LEfwjtkdaic+IC+yGKycyZEULOeG Gckvg/LjGBjiuuOeUnSeGjpHa236HDUyDExq/WpRble9373/AASyt3q8dt9p1HTLR5ZFdmkt5WCj aSFVOBkAY7DmpFv9VVZ420iBvLh8y2Et1/rJCp+UHAwPevNWFylxv7R/ev8AI9aWY52pqEaS+6V7 feKmrXka21vc6FNp6QQfO4uRISWIwVx3YEdv51PdeIYLVpZTpepMIZMyQ2tsSz5JwORzjHWsXltB q1HEJv7v8zd53WpSbr4ZqK3ad7Ptay/Ma/i3SLaCOe+knt4l3I9zNblUj2nLZJxt4x169q/Fb/gr v+1B4D8ZfDvTf2Wvh/rqeI/EHiK4t9b8WvYXQSPSLe2vNNvYt4yNwZPM4z24zzjx+IMO8ryyriKl SLVmtG92tOh14HOY4rH0cNhaTcm09Vpa+uzPw08Sm3ju9MRNLdZUjFqXdwQHVQoUkdBgZ/DmvLPE 95m8hwsjo9w1qTs27A8bDYx7EjlW9vWv5riq0nefxM/q/CzoVKKhRWiOAslkitbFpLaa3mtb+a1a O5u97SmMEKc5+bK4Oc+nemRrGBqjRyXSPbxs9yqrvMbsq4Rc/XPqM5FdOGo14VLzWgUsLCnPnvch lvCSzrK81zcWomuGAC+bnhenGRs+vHvWDptreqJNZv5Y5Jhb7orOUbY45Vzyc/xEH6DArKupV6rc I6oyc4QrSpwdm97mhAksyXtvHGbKDT7kTn7RKG8yNsOSuOShOeexBHQVvTSRp/o9qWWE2Dy3TS52 Z3KwQAdMnv65zWfNVq1fYzZNWlUi1GlNt+py2s3rajp9/DeApJciVZnhbYyAkjcD7AY//VWZ4eE1 1Z2sHmIdTlt3SEW4LSRgghuep+ULk16leNOFJ0pvT/IhV5U2oTj7/mbeqv8Aa9Oht9kkM6W/nTWh nBIRlwkORwASDyM+hxjFeM+L9GtvEHgfxP4bnBNsPMv7F5Iid8wTGwhcHEbYxnk5Hat8ji6eJi5r c6MT7+FnTqbtM+ZfgH4nl8PzXFpdX8YvhqV1p5m3GMSywytFswBjBKYI9Tmv1Q0fXNPXTdHu4Y/L NpNJdXTxBv3krIC2MnjbzgdOfwr9axNaNKEVSle5+I4GNGtjq1Ko/di/0/q529v4mkZpGt0AMr+a JI/mYhcEn8B1PXArE1bVrNbSbUZ4IruC0kkMlt5u17mBRhtrdQSCMZ64rkxGFwyqe3xH9f1+ZvSj XnjF/Zzsz5a8MftT/BnxV4kufB1lM9r4rtLyTSZLC/tngnhTzCo+VwoIYqTnHPUcV9R2NtDOftEd vHdMsDQm5RRi3BA8tmPU4Pp3NcuKhRoVNJe70PTxNPFuq/5+xafT4o7meTdPDcSeRFNN5pfzOdqh RnGdxz9K+uP2JvivdfAX49QX6/ZYoNRlSKe4hnbyo5Uh1m4iZhjJ/eTHPIH74dMDP9A+CuEwmf5T mnC+LklFqVVX2/dwbWh4vE2HxtbhWo6KtUjOG2j5d2f2deFNes/E2g6fq9i5eGeER7+D86YVxkcH DBh/h0ro88jB4zjAr80PlRmf9r/a6d6AffGBxxQADpgnAznpSdcZ+n0oAPXFKDznOPfFAC5ycbs5 PpVea0inwzqCSQxJGd3bFAGc2i2krFmijDNghdnQdcVyt34A0W8ZzLp0Hz7cptHJDbutKSUlyyOW tgsLXTVWC/U8k8Wfs0fDvxSXl1fw+kr/AG9bmOaG6aJojtPz5U54zjBPPFeVav8AsUfCi/BafwvY yy28hltZ8t5sgcqWDtu+YEZ4IPX2rnqYSjUhKFrXPKrZRiYq+GrvTZP/ADPjr46/sIeHbXSbhPAn wu0zxHfqnm6doFwyQQ5UBsmduhBJ5xk5HHWvxP8AHn/BPj9qKx8W3utz/De10nwtukTTrHQdW8/y DMMtH5YcBuSSW2jtiuDDYLEYOnOEHdP+vUzWMqYevCOMi79+n3nzjrfwO/aN8KaqumWnwV8X3ccu meS+t3KCOG3kWP8A5aNu+Tr/AA5z+deWa3oPjLRrSTT9UsZ7BRarMt0sDHYzFI8DJ3EE7hwe1c8s rm0qtvkfXYHPKWDqWw8k+bp+AzT/ABFBA9nNcPp9tcyTozG41OOAWq4IJwSWfhcAf416RDffa4XN t5wi2/feIqJhnOFJ4Ixxx65rmx+XRq2nV0e4q2NxFLMlV5NzF1Zoisk8oW0M12z2kUshAtwq7ghK 9ScnJFcNqtrbMVIcPHJErCZAw835cphuvUjr7+tcuDpuNZNRsj6qpWp18K19oyIrFVjZmYiK6lim mKOTuYNhvmIzztwO2OmKvTM0UiSQwqhMDlDCcLCeD05J9B2yCO1ehjIYeE1d3ueZg3QpqVCpK0lr 87GGWhSOezijE7iTynjjjH3m+fzGXr/ez79OtYN/d2t21vLbRC4SIPJYz7h5bzNkAnjABwR7Yrz8 VFqpaTuYUcyliZunUTsup5fcfaIt7w3KfvhLDLuUsRIgDJwedhJbHoOnFdLoHiN7uSzVLc2PlxQx 5aUDCkkKF7ElUwT6HI61jLALHUXGr8j5XxFyfD5xgaUsPC7VvzP9MUsR0bP4Uuf9v/x2vuT0Az/t /wDjtGf9v/x2gAz/ALf/AI7Rn/b/APHaADP+3/47SAZOQ3TvjpQBSup1Q7Bku8Z347Dt7d8/hXzz +0jq8ulfArxZPEI2F3ZS2Yt3nEQuVMUjbNxP96POevy4789WBh7TG0YPrJfmePxFU9lw/jqt7Wpz f/krP8wD/gpL441PWf2nNSFy1y8ekvdX0TXMyvHqAu7fS3DREHH3lZ8cY27ehBr4Tu72Nl1S4uJD Ja2y+dPFGC6GIgASlev3jwo9TWPiDN4Xi7E4W2kG0eP9HODn4a4PMpTv7WKl57NFFmd1e+MgMFnM JJ2ThiCFZZB/e3dB3HPvSfaZI4gtyCblrjLmJsrsDFueeeoAP1r4unRjVlOo1/Wp+yThQUnGS5Xu PubwqkYZZYomIZkXJ56bcHnrzn1xWkNekggLWsyIZ1+w2yF/mzswwcegX165rm/s+pLFKcuhrCrK s58uy6GTc6qrGaQkrBbwbS8pycKMxh+ufbArYt9TaIzW92rJLNHBfhCwLROQHXdnqABkH1OD0rrx GHhSp+0TIwntYycZrQuanrzOsenWSs9zuadwxJkaR+GGTwSSCcDtX15+yUbbU9Z0yaUQ2qvZQRzL POI4pdoIZSTwMZ5zwS/tivn80qyo4WVVdL/ke/w/ClmOZPDf1/X6H7F/s+fDHVx4m1HxFFBHeaFe xS+VOqgNaYCumDnGBhyCP71fUmvX32q8FoN0UFigAiwS8RDA8jp8wPOfWvz7JK1SrTrYyP2n+aPu s5wcayp4G+kf01O50u2mS0toIoHSMXrXBMEu5baPqS2OWyQRx0z9K9QUpb2C20ttt+0wR6lErzgk Ek7VAHTpu5PavVUb2uclfNKOEwE6FJbf8EwdXma3tNXvGMkkCoLYNG20gFflz6ksa8W0meY65Y2P zrPbxNN5rIMwxjDMG7EkHjvjNdmLnHBYJQm9/wDM8LL3HHScamlkfQFlLHYxziKKOCArJLLFChdY 2UfePpkH9fas6O6tLy/uvPFypSB/ImXARUO07C3qzHH0NRhvaRUYUo6GGOqVMNUspX/E47VLore6 28cUUixo0k9uJBnPHyfQED5h1Br5i8dXtwJLrUtHW3guYriGWDdGTGqOygphvmYZHXtX0eJqP6nG dTc8GnRwtLEqvKKu9yzaX8zR2K6ikSXE2Z3W0iKRyEsc4A5ABOOfWuzt9zCGOK5eGQ2ckcrMOHZj wCP4uwrz446eLjyy6Ht1W6NN1KUdSfVNcCxrb29tLayMscAK/vCrr+ICswUgc4XNfvr+zb4yk+If wH+H3jCK5v8AUZbnwzZ21xLqFmsYVnR88rxlQoyeue9cmVr2WYyXd/5I83PJRrZSpTWqR7Cu5yoU yDzZhcLLLIMhM5JH5Y/Gnmb5pi4+zx7fKt9jKW3Fhtf0GSOnvX1d31PyWhi6kZWetxyvGwnhESo7 4WGPzCGDg5wTgYJx16c01mkS12rA0Tl2iuLe0mAW2JweT3bkkiuqnWjRp8tPdlUqTpV/Zz1uWjgY 8q28ixS4a2trhbnzMoFXcGyOCCTjFQIs8hRDDEkkU5MRBLB8Ag5BAAJU474NaUKNScnXk7eZy1qf spclyRo8yOEtVx5bSyNJLiO3AAIUknPIz+VQNcRyxyzOoeGOHfaMYypcH5QyZ79ue1aqbr3jUlbs ck3OnT91XLcgureSWyuLVo/IjQSIlyHwcBhg88nJzn0pqvLHM6JmCMfvCxb5o2OdgI5OK2w1Sc24 VHexph6lPEJ8rEwyQQOCARNgOjBi0iOAucdDyfyro4PD+tXU0TSaUyZHmJJeHy/sqjIJO4jGeeT+ Fd2Hws603GjHU8qebU6UJWWq/ryGy6IlpAHuPEHhSzJjkljjvPEkSsTGQSIwTgnHXt+dPfw1cxRW 00l9oluJXAe9k8U27RKJBkMxDnb2z9RW08vxkbtwMlmtCdN8qs2OtfC+rSwv5MemXqyzEt9l1yAi JQOPmL4Kkjjvip08JeIIF+1Jo0ihdlhIbW7WaKN2H3UUHJ756k1z16GJpwvy/wCR14bEUYxVGo9T FvLDUdJ+1WU9ve6ffI0MluJ12StFyWK7gQQf8aijJktxL9l+zxx2zARGTdlOMZI749KzneaUb/1u dSn7CtGNC/UarFrMW8Kt9imiVwkcn3iMheeuBk81bhla4VEUO8rllfzE/wBUyg53HjgYB9K66dfl oOm0Uq8eZQW/mW7bSmvLKbUJStvpljFHNf6lqVysFvaZJKeY5IHVD69a4bWfiz+zh4ellttd+Pnw 90q8a2F9d6W+oPJjPIUsBtCnHY+ma9bLMjq5hHXqeVm2IdOknShdrr+mmp5PY/ttfsV6t8QtT+H1 t8ZrbS9astKub77fq2nyxaVdmEoBHFMFIP8ArOOTnjtX0b4Y1Lwl8R9P1C/+E/jTwx8Q9K0Yq2tJ oOsxtNoBZdwWWI4bpzkcc9qWZZdicsbvsi8sx/toKElqIrNKsayyLIM7GKIcyx44Uc4645qyUfyx cyQTWs6oirHJNkRKMqMAcZ65rw+fmk7ntOHKoy7j4meX7NFHbNKTKBHGpyzOM8gdevrWjHpGpXFs ZotE1NlmUlB5bSkNuxuAA4z6e1es41fYafEefjcTGjLlhoTy6Pr0Vy0D6FcR6gqLbLCxcLcnGQCT 90n1qpdJPa3Uy3FsbGRpGMMbSCQbV4Me7oOT1rSm5umoyWpliKScPbUdUPy86RyT25hKsUiVZhlH U5ByCcjn8c1Z3uqrNFbT3Jd/KkaMgGIbRlueOv41FWNSUbU9zfDU08PaavcliLlvKS1MqwRme5XG fKQ8Bzx2yKmVMRr8iphnmZo3LJIo+6ABk59fftWlNPkSe6MquDUI80GTHdH5kccMzrIBOsqz4AfO cMp5P8uKmZUYRXLg5WZPNtY3YHbjkjHB5z/nFWuXsTimpwVZPRj7d4ZI2E4mkTdIiSCMqeDwMHj6 1MrRiNVijlI8pci4k/1YHGAeM8/0obvpE64Kj7FSirJkrxRSSIZAJCka7xgkgod3Xocc5q4ZMmJS 4fDNIgR88dhg+oNJtQ1loebU9jFOMFdkaSyC7mt2iaKBIxLDdZDebkEbQoJK4BAP1q6s6uQUXyQp 8sopLCIY5XnqPT607p631OmjJ4eMYb37dDRDyTKZVJdYAAUnO1XXjJYgenA9MCrHmxv5YhtYxvnM oi89v9HUjJwM84FPltrE71CEXe25Kd6NKpEblYEEVuZeA4Y5bevJyD3z0xVjzgY2RWGJGJJH90qO OP5+1Jxu7hotUTqH8uUxHd58y7CHw4Y8Y69toFSSPJFO6OibWiMTLv24bnJDDnjPHvUO2ljOtFun aD1J1doGEalfMCq4ZXDbSygksR19CPWrscy4TKlJHCGeIHKpz82Djn8u5pwVtWckMNOUueotCZZp ZhIlsPmV9wkaQEzkZJwPw78CrXnAxNLEoztOIXlyFA5A3Y6/0FaxSlHnew1iIUa7VCGu3l9y/wAy Xf5fzEZ3DaQW4DHCjn8aayDHlOGVVCr8zkNIy8k/mKXsuepyQZ6WHxaw1B89N2XZ3/N3RIjFmVWQ qXl8scgBhjOc/hTDODGMRux3BVXOCvPJI+nYegodCrzcvLsdX17DRpe2Ut+l/wDg6Eu4yfJ8h/5Z FSR8i9cn0zRDIp3oyBt5KrtfJDD7v49eKycbXOmFXmcVda+f5aakwc+Zvl/emM+Wyb8+aQR1Pcem PSoZJGjd22JKwCTF2YbWDZyD9O/pRBuMk07BiIqdJxcOby0/UwdZ0Tw/eaFqmp/EWW2t/B2hWTaz rETnZbyQxjd+8xywAHP5ehr+Nnx98QNC+K3xa+LHxV8NaXb6Z4T17xAdJ8F2p00wyQaXDGqKQzAM Vfble3AOfT4fjzHOnl6pOert+Z9D4c5Sq+aTr1qfwp+dn07nmutlrtNHg5lZQYZ0yN0jlMxck43D nJ6YxXn3iK+GoXjIEEDxWLxWM6dLlCQh39i+QckjoK/IcLj6Na9SotUfvOEw7jDmeifTY5GeKG6t PJS1S6ktJ4bz/SZT5dxAnDuOOG55P+NZ7pFFc3MrhmtnZpIYkYgXnA2s3fgE+2AKcsZVjNuOz/ru XjMT7GLUN0ZqqjXawRY3pGfLldw3mS7iEXn2zk1Tub6ae8062mj+0WzFQ4YY2DBIEgPJB7/hXXVq VYw9i371jPAunmEJVeXVfj8iaWGdxDEkixMml7b4GQA2EIyQgHc5OSepAOKSe8jisoWRHd0uiHcX JRIAqg8IOh/ya814XEKip82vy/IuliFVxKUY6HKalOXtZLHaLtbyaRweFF1GTvcE9AFPQd6xdKW6 fy5reUokM9zNbPE+FznGSc5yFGMdOTXVWVf2Nq/c0xloRjXiry/4c72znQWSxFUR3KCBY35gaQ4K 56H5s4A7Ht1rh9Wu57LxDAlwpuNPmJu7+ZQFFwN4RYxwMluc+m3BzmurCVY0oQbd9f1DC1J4uDUl bQ+J9b03/hD/AI4a5pdpNFcWN27eLLKEgrC0MhkQqcjOc5yRk/J3zX6Q+GruLU9K0KOFxGkkiF5h JxcRrEUyc4wFI5H0r9PhT9thIYnql+B+J5lVo5RxNXwvLeM2z0+zmzALSGzzOsJaXU2mAAzyhI4z kcHHHSuZv0SSC502Rf3bjbqMRJxI2ASG4wQTj+XavPc1iY8mIlqvwPaw1Opg58tKGp8+3X7P3wq1 jxxD43uPC9tca/Yss8V6tuIJvPQtgFx1AJ49a+qdG1GNmS1gtvstrEwt4JWm253dS3bsR9K9XC06 Vely3vY2r1KlKp9cqvfoSjUriCW4QvGtw1w9xaqpDJAMnao7DjJ96oa5bR65pCCK1e4nhDahp4hu ChmlcSRfMf4QVkcZ6fMOOMV+seFGPpZLxVSU5e7UTg/SVov5WPN+tzxtWupPRxlb1s7fif1R/wDB K79r+D4z+DZ/B2uTJB4m0yaWOfTvMJMU7X2oqxyVAYGG0V/lHAPORyP2SUlsMvKkZHuDXVx/lWCy PjLMcoy7+HTm0vTTyX5H5zgqWMo4SFLH/wARb37iZGc5zj2ozx15znGK+POobTs4HDZ59KAE69fW nD/exjgcUAKAMEtyKcSO/bmgBAApJxgu2Tz1owSAe5GDQAhI6HqB/kUm1WUh145XGeooAry2dvIQ TEpHUg9G7dKxr3w3pV3uNzZW8rOhhAeLIOTn+XfrxQRUpwqx5KiujndU+HPhvVoisuk2TBwpGLVV wQFCt78KM55NeAePP2L/AIL/ABAglh8QeC9K1JhH5duZ02rb8jJAUgnPPU8Zp6NpyR5dbJsNK0qH utHw54y/4I3/ALLWvyXd6ngO0t71oFsQba7mVrdFbcCh8zOQ2cDpXhPif/gil4UvmmbR/GeuaVDN Lzbx38rCRvlCNGXfbHgKM9AefrWOIoU8TG0tzkq0+IKE4zw8lL1Z4T41/wCCQOp6LbXU3h3VdW1+ 4MqiNLwGA3sgQ53sJMZOMAoB7ivj3Xf+Cb/7Q+l2Zibw3az3skUbw7Jt/wAshAHmbpfmKcn5SAdo rz8Vha0KPNRV2epl3EWHw3NHMYtS66HgXiL9kj44eHbu4sD4K8RwXFvZrbWt7PGJobiXk+aiI579 V4x7V5ZP8MPH1i09rqfhbVLTVbaSNr2xKoBHEG+Z1JOcYGTySOlclVp0Obl97yPRxMcNm0qdWjWS S37nEXXh7VbVZL660aeKCY3En2oMrR2yB8K2TgsP9kA8GvM9TXSGuzFOb3T3nt3tJlktDENUnmAJ cehABwo5571M6VOslKSM8RjIYGE4QkcJqV34ZdroW+r6TPfSatFbWkf9ofvGiiKCRFjHzMQpPHXJ xXHy6zb2+v6c1nc2E+mor2EYjkB+17SxKkD7pXpzggZ7120vaU5KcURg81hToxhNcyP9QcXqkDIK sSAV6496tBywDKwIbocda9U0Fy3Y5/CkLFVZ2bAXrxQAvzcc9T6UgbLFQ/3Tg8dDQA0yDk7xgdSe Mc4qvLdxhfkfcOcrtIPtg0AZV1MZP3sZVmdhExzt8phwcj618Sf8FB5lX9mrVbYW0N2LnVA7WL3Y ha7CxzssSBsYZmUYPGNhOea7ctT/ALRoW/mj+aPC4ndJcO46NZ6OnNffFn+WF+1nc3qftJ/Ee0u3 N5FNfwXMMDW3kpA82n6dI+3kgF2izjI2+XgYzXgTavG1zdLIsgWaziezR1wEnOAzBh06EEHjniuf xAUMRxVmFV78z/I5/AzAPAeFOTUIu0PZq33v9RRqrGOFrUGVZcG6lddgYNnGB2IHBHTuKtQXvlyl YnG67gWOaWRR2P8Aqx6gAZHuT1r4h4iKw6pU9z9VqYbkUqtWd2W5zKhJiaUzLI0ds3nAbE6gL6AD JJ75FZF4yCOWVsRtZ2Cyz20aEtkuQOf4sg5B9eKtfWqS9pJk068adB04fEZ1vqqwrAkub2BJJJSz DY+OgX8Rxz069602uQ8UcLZiWBHiUPIWeIDLYY9Odw/Kppc8qilW1TMKmIxcKaVPUrXUxiitlE09 tcWtutvaNwpiJbeW57Yx15Ga+3/2drO6vvDV1cWsdvLPDpazWyxuf9LLEBzuPJ+Ukg/UnpXg8WRh HAVfZ/E0z67gmOI/tGNdR16n64/sCfEC/wDEVj4x8E+J5L6PUPD93HaaNqk0qhdRjW1RiwQH5FLB hkgY2dK++rPTBJe3k10kUlxPcpLaF15GFzk8kHOMAHvivy7hCU6mGWFm/P7j9Q4kng6WJlUi/es9 Dp7e6SK+a1uIJI/JkDJLCciFy/3XQdOOPTrXYXVw/lCO2VXNl/oMwJCLED8yquevbHHc191mFGNF xh2PzSniHjFOFRaM8v8AGetXT2Fjb2VwymWFZ5cfMkqB8SKQCCDkdcdDXJaBdJJqUsxiDSSMzXGG 4hbIyPT7oxwew9K48VRTrRUne/4Ht4SjRw9P3Xex7JfeILWUrNb7mLWsoS2W6VftD44UrxnIXqfS sS21lBbSJGxdNxeFs7hc7VBfd3GMkehH1r044DFVJKeHeny/I+XxValVqT5N/wBDnbiaNHuXhkhj /tJXCunCuSuFXPbjJ9q80v8ASRdQ28rYuEjuUjkMqkG4kDDIIB4Axx2r6XD5Jja9Hkb0/r+vI+ZW Y0MNU5sTISTR5nk/eyQo8Z2x7EI2Rq3yLjqcHJyfQ11ENg6RTf6uGQyBfJjYq/4HsT1P1qK3D2Oh UXs4aM4KnG+EpVXh6krROF1G21CLz7maB5In3xwTR5ZMnAww7A5Az05P0r9kP+CZdn4kvPgxqOga ZFd6vDo2pNFYabNJva3Bjdi4UYCgjJUdsDPpXxM8Hi8BxIubz0PsquNwmacH1K9J3Tt+TR+ki+Bv FkzYh8M6ncG1b7HI0drkRqRuwD/Fwf0qKLwV4nn+ywp4Z1W63KsyiNxugijLFnC45JB6Hpiv0CND E251HU/H8FChSvSq7FS78LeI4VSC70PVoluIZFQfZi3lx5P3mXuPc5/SscOYriaS1jeCKSAoy2RB WMoAAGJO47u/XFbe3+rw9k46o63VoV8SlSlqvy/ryGoDhpEiliDWv2lEZslpWIDKf7g4Hal8ry0S eRSyRl2lMbHahI34HQtyAOlczrzqLkrbHTXoQqxVtx4clIXaykkPmqCZnwhbORnp90HgUjq0sUwg Z0UTjDeYCUIYgcHrxniqjRjHEKnUWn9WPLxcXQd9y9a2F7euWjsJ1AkfZHFdBDOm3AKt3yBnB6c1 598Q/i18JPhDZTnx1r8LamlrFe2/hXw7fpPf3RjQh0c84IZkzjJ5HtX0+S5DicViGo/B/XdnzWLz XDYOlVpxj7z2XyPz/wDGX/BTaDVbEW/wh+EPijwtFPqCW9/4h1+ENNBEwCrJCrfMRg8jaDnnPFfE /iz4tfELxZqGpaprXxQ+KzXt/M8bQ2WpfZhswFKKuzGM8hupyea/T6eHwWXYf2GEhd9/8j53A4Gr i6XtMz+5f8P+hykKQSzwT3viLxuZYvMeN28RyhIjIu12bn5ScL7ZpYdI02xk1krd+MVn1V9+oLL4 quJDPGyjeQHkIAOBwBkc46YrOUql+SnbzM5YNPFt046Lb5Gjpvhqza1toIfEvxCFlaqty+nv4yul S2YcDaS+Rg44z6Yro7W78c6JqaL4e+J3xJ0vMiTw3KeMJLnYE/gjWTd5ZDHk4PSu2eXqpD2dRXun 0OPNs1jQqxhBWn62Ps/4MftUePvhp4v8PeFvjv8AEbWPiP4d8TalFoOj22vpEdTszIqxRF54lGQG fOGUcAc84r9TL+y+yXtzGzNOI41Je2jGFQ8KS3A6Ht71+Q5jTp4TMamCvqmfa5b9ZxOXUsba0tP1 KEzt5dsqeWzRCN7hA2UtVXcRt9RnHP1rz74o/Hj4KfAkaGfjHrN7oN5r1s19pI0ENdT31ssgViy4 IC5KfMBk9+K9HKsqnmFS7eiMs9xX1XlUVq9D8R/27v8AgoV4X+O/jvRPgb+zvf8AivT/AAhpGl3W teMnkU291NdebbvbxzoyDh45pSBxwg9ePlXwL8PtJ1Od7PWNEtL9URbaQ6hpsQzCoYn96oA79zmv co42SzaODou0Y3XqfS06Mcu4XlXxCvOVmr/M9Z0b4feDNU1fyLvRYNWtIllW2tNyJDaxIvLbiMsp 2jI64BFYvha5+IH7InxL0X9of9n2Q6foQ8RRN8XvhvZXW3TfEGn8KZ0iKk+YAx3f7JP0Ps5rk8sb QvCd1c+JyTMIQxTnmL72V7H6+x/8Fb/2WBrj6d8Qvg38T/h+NSia6g1nS737daXsQIbfEIlcbMc4 ABAI4r3T4e/trfsMfFm71aHwJ8etMsL/AMxLaTQfFun3FtOkpGcbmUDvngY618tmHDdfBYeNenK6 Z7qzaFWfsYLbr0/A+idc1nTPB3hHWviNd6po1/4Z0XQ5NVGqW9151peAgogDjjG7H4fjX4qW37W/ 7THi/V7nxTo3xQ1Tw3oN1qctvo2m+HplQWFqJCq7g8bbgUGcDGM/l9Rw5hcF/Z8q2IjeS0/pnzfE tN4+UIwlZRtt6nJH9tL/AIKA6JdtpFl8XvB9+2miS7ttb8Q+G3la+hDjakkP3SQCMtnNb/hX/gp9 /wAFCBYXOmeKPCHwW8VIkLXdzLrR+xWWsXKMxQALbu0aPhQM88mvIlUwf1p060LI+nynD4erhfZY ee6/4b+v+GPqL4b/APBTbxv4v0RtZ8e/s3+EDq00aJ/ZHgfxyIRaOGKyPueNFZRt4GOQc19n/BH9 oTwP+0hp2u3nhXwrqfgfX/Dd3nxB4X1m7PnqvCb0kPysuQcFMjB/Css0y2NClHFYefuv8PU5vrtb CYx4Gqr9vkezF2LGRgVmtYvLCQ3LfJnGAD1YcVeWVd8qQwSkzFWMgmG5m744xxj8jXmQlFxumexC pCtHmiSobyeK7a1hRkQb5JSRiF2wACCckE54+tTLIyRTXAt5bl2jMUSmQ+XGw78dz7cf18/97Cq5 1H7plWo03B82hIbhpfsEUsbSQRXIm8sykhVIySPyP4irCCJEOELs6MQRL8gYnIIP06itKEnDmn0e xxPEzpp0N7EgdObcGJ1Qo8k0eQyN3yvp0x65q1vCPJKgQMFWRt8YzMrE/dPbGBnHtWkasas+SrEx Sm4tUnp1N628La/qDwvBol7Kp3OJbeNoYiM5yH+6c/1rYh+HXjFvL36cscW7eTcahEBEq5wCA3Xv +VdTwcsRG0Y3NoYijRjaKu11IZtBOlt9r1/xB4S0DTp5tguNU8TRQJIuCGCtnHbp6mvKdX+Pf7MP haP7Z4q/aD+H2n24drfzLC5e4CDooDoD82V54r1sJkWZ11aFNtGdfPsDQfvyX3/5Hm8/7ev7AGl2 hGq/tN+HdOjnnMNrqVxpV4kc7BuTuEJVsAgE5GOM+ldp4J/a+/Yn+J95Dpvw7/af+H2taxcS/YIb SS9Mbyy4PyfvETGdhHfpXZW4YzaEJSjC6W+qf4JsVPO8PKKrJe6+v/D2PphPCWoXsP27TptO1y2v I1IvNM1BGRwP7jkgd68Y/aF+M3w0/ZF+Bfj/APaF+OF3caB4G8C2iz6gsOnz3VzqTuVWOKGGIF2d idoCqckce/i08K3XhRr+7d7npwqRrQ5qD5j87vCP/Bbr9k3xedXfTPhh440K7EIHhtPGttNpy+JQ 6CRWCyRYQYOSTyMEeuNvwb/wUq+KPiLxWF8Q/AP4eXXwtO0zXPgHxy0uq2CK0gGYnijR952cK+Fx 36H9KwHAGGxuGm8PilKS+fT+uh8hm+c5zltWKr4b3fJ2+ez/ADPqq8/bv/ZS0u4htfEvjC/8CyX1 +thBqHi7SZ7W00uR41DJLcFDHtDEjduxjvX1dbzaZqmmWPiHw5qmna/4Y1KE3Gkazol8Li1uUzj5 JFOMZ6HoeK+EzrI8fkNZUMYrX2OvAZlh8yjKpQ6b37k0Um3BcPJHHLhUPOWPP44I/WpfNK3UirEZ v9Fa4yvPzBsHA7nHXivPXJ7NVIPU9ecqt+SqyRwqFXaQBknzuB6g9R7cfyFNUTAwme2LJGDIw87k Acgn8ByfeumNZ1vcg7P7zCnKEZ3rQ5l62Fz5iL5aOxWZ5HcMf3ykEDHoQc569umKYtrcyxxmO1mA heN5gkOfIkXGWB6Z45+vvWvs5Sg4VHf5Fe2hCuquFi4/P+v1LUbTuJLqK1PkRSNLK0ce1VBP3h7D OT+lPQGQ7UXzHB2BQDwT7e+B9cV59XCukr3/AK+89n+2Vyc3Jr2v/wAA/Mb/AIK1/HeL4c/s/aV8 ENEvG/4TH46SS6TNbwzsrWunqYJJ2kwMhCjbT2zgHrX84d5oVjpGhadpWk2o0y3020h0+zhgJC2c cXCqAe2e/t6V+Kcd4hYjMadKMtI3T+8/ZfDyVWOAq4yUfienzRzEN1t1KKK4dJruK9QM/a2jIaMb exyT+Febajb7dZksl/dWkGny/ZpQ/wB9sku+OxJx9T7V8yqeDhRlTpWv/wAOfoM6teUeSbdjnCkV zIXubV/MXbMs0VwUxwRtPIxnHIxg89aUg3GbgwD/AEey/s5QJRiMPtJDjqSR+IA9+eLEUp06casl v/n/AF9x1fuYTUqWqfT9TK1C2SO+sp7e6j32GpRRvdRrkKPmH3TzjDDntg1gXdytwuoySxSGwSGT cHOCsu/aCvd8IWbPocYNduNox+r+1T947lDki/YqxN9paezvpIbLDLFFNp1rNNtDRMgXzSw5BfaR zyKxYLmW4nlDSYaW5dbwuv8AqJZQOeOMjZjI69a4sFhq1TDJ1WeY6tXD1m5w3Od1i7it7VZ2jWUI MQlGKg7mIGSeg9D3qLSJBLBL5NvsQytboEPM8yZMmPTlx+VerOUIxXOcuJqVI4jkj5/cdjp16nkh H3SATrZwiJOMqOFZuxBBwe/es67a1nv7pplaLTVyNP3scyjaTuz/ABfMSBnHANc2Iq0cKk3H9Dqo YmrU/cUI6o+TPjjpg0/xd4L1qTzIbN0+zNeRjJnlaObcu3svyg9eGX8a+gfghr1vq9nFZSM08Ue6 BHuMA6gjYXOO+cHkdua+6wdatXyunWpvU+AzzBUMJnqxOKjeT/M99guLe3df37RZDwxhZcDy87gD z6Acn0q5dash/wBFt0eW0VVuFDHY9zOy8oxwTjjIPp6VSoQxMfaQfr+ppCOOnj1TXw/oZL38Wm2V tcz3FvdtOD/osb4mAfOJGB7Dtj0qvbeI7Z47iS2mkGFR5GVcoQrYJIxnrgflXs4H2GHUlsaZvl0p 1FTiaVz4ss7Q37yvJ5qWslvJHC2RIu3IIXHJyDjHpimt4xSK3EZVEvNQjitoIy2BCrAFQSDwoOMk dN31rry3F1KOZ0K9KVlGSf3O54suTDYyHNHVf5/1957X+y3+1Lpf7Knxd8P+OdusPoF5cTHWl0h2 nNtJDa6xdJI8aI0rDzLoqMd3T05/tU/Z8/ac0r46fD+18YaH4U8VaTZwXkmlTR+INLe3llEREYmC Y4jZgQC2MkHgCv6W8QsBlee5bl/EeVV17SUG6iat7zk+q30XU/Kc+zTE5ZxdjVj6T5KsnKLXRLS1 v8j3xfGVluEbwSJO0YPleZkoewPHHb8xTz400hEd5XaBETzZmkyFiXHJJx0GD+Rr8gjlmNnFShC6 9V/mbVM3y+k3GpUs15P/ACLNv4r0SdQ8V4rIwDK6ISCCAc9OlXU13SJNn+nQqZQWQOcFh6/T/CsK 2ExOHbVaDVvu+/Y6aGLw2JSdCad/v+7ctx6hZSGRY7uJjDzIB/BxnmpluoX4SZCAMelc50lgSKRu DqVH3sHpS/LyM8ZyRigBqL8oGMKCQF9hnFOx1VeB3oAOc7eyjr60c4OewzQAwqWypO4HJxjHBGMf nzT9oPI9OlACdcgdju+hpxAPXtQA3YobJHVcE59KjaCJt25CRxuO89uP5UAUpLG0k2M0Ecg2llL8 7+Dgc9M8/lWRdeF9NuFVZLOBgH2gBP8AVjOe5+nFBE6cKkeSoro5K9+Ffhe+hEF3pFvNDHIGjgkG VU464BHtXmniP9mH4Z66kcdx4X0/YsYRIETaH28k5ByD14HHNQ6dOW8Tx62R0J2dCbi12Pn/AMR/ 8E7/AIDa+8kt14UH2iJGETnVJt2TglQRIAASCc49ua841D/gmH8BNstzH4csYb1Lcqpjs2kErLja 5beDk7mHpxzWNTC0pxagrM8HM+HMzxEnVhiL/wBf11Pn3xb/AMEmPgbNG8ieC9NkkEiy28jMysGO AOknyc5/Ovhz4lf8Eg/CcGjT2vhHwPaR2P2uW4ewWRpoop5UP75keX5mDHgA14NWhmVOuoUk2u9j HDZjWymSo46i7d2tP0P6yhsbkbSccEHtn/636UBVORgYbr7Zr6c+/MXUPEvh/SYmm1PV7GxiQ/vH u5wgTg9SeleBeOP2xP2WvhvJbW3jr4+fCHwtLM3lwRa98QrK1MpGw4AeUEsN6ZXqNwBrkxePweBh 7TF1OVeZ14HA4vMq6w2Apuc+yE8D/tk/sqfEm9hsPA37QXwk8UaldSrbWlnofjy0umvGc8CMJIQ3 Py8fxfL14r6NEEUsIMUilXCkSodwfB5I/lVYXGYXG0vbYSopLyLzDLMwynEPC5lRcJ9mrf8ADkEl i+0CJgSzADjbtHc9+1UJbe7T93JsKmNtzA44zgH9RxXScJnTxXC7Glhb90qpsMg5AAznuOK/Pn/g pfZJf/s5WP27TW1CKy1CR/sIbbvLW9wkaBsgZcDGf4QpJ613ZZ/yMKP+Jfmj5vi5qPDmMk+kZfkz /K9+OVvaaR8cfiXptk7nTrbWrK5jaW6eZWEunWISRXckjco27f4fLGRyDXkUt5JcSgQxBmNz9nEA l+aGQEEYz14GOfXtU8b04LinH01tzfoheEuIlj/C/JpvSKgvzZaN1J5iTnzFW9hM7M4+RCpK7Avb g5BH9KYbyVWs7cNbs1ukekwKEJUqM/eI7KDkN3PFfGRwlK/c/U6uGqTknCpcv2upRzWl00ksgdXW NpHjz8nI3EjoOMAc1jXV+wSaNuN8IKLI2WL5DjdwDg9R+FdE7cjhN6M44KhTxTpN6vcIFilijK+Z bJCCssLElrhV5Vy397JI9xVy41Foizq3+juQs0TdLbkA5x05xz71rTVNLlmtDuxGYQw7lSe3QjcC 6mtbW6m8p7i7SNJ25z8wbI9cjj2xX31+zTcTJpsr2iTQx2ts13FKi4kAyACY+hHYjjiT2r4PjHFq VOo0uj/U+w8NcTP69KdRe7c/Qf8AZPlu9I8da9qjyoNOv9Lk02b7PEN1rMVU7XX7+7JJyO3Ffqjp WuQ20IkjmIZAh2s/yyheAcY+v51+WcJ15U5ztr+mh+j8YYCnXxUcRTdk7/ma8Vwb8DUt7FvtUryr C+3zUYdW4+YDn6dead/aaJFGfMHkW3lzzxkE74cYV93ByR0Oegr72nHE4quq8le9z4WpLCUMLKnR V2jyrXbm4vvEK3dlchrNbeSIvE+fKRiNuOhJAH496fZp9ghjNgcKzGGyhDbE2tksfQdyAe9erQyy 1TnqLT+tjwHjpxo2vY66GG3dllc/azBjzftMuzAwc8ZzyDkVJFvNqJkR4vJR1t3eQY384JxzgDHX pX2GV5TiKsoLDnx+cZ/TwFKV10ZZkid0tpLi4e3kS9a9WCRhhvlwrZxjk4/MZpiiORx5iQx+UCbd +rBiCWHpyPX0461+hYbLo+zjh3H3j8fxeZ4rMsLLFc9kQXgje4jXyJZgksNqZYMom1ASV5HAOSSO DXH67470XQrFru7v4JrqICSK3jySH3hURhjoykDjNfS1sPh8vwbxOLtZenmfO4elXzfGwwtFX18/ 62OGtfjvq4t5bFfCel6fBf2n2WXUrizyY0yDtiQgnuxLY7VxOgfEz4n+A9O1qw+HfxR8ffDu41i1 lgvbvwrqqKQ2G/eKskcgPXkkcn2r+e8zxmFxWePMuXReh/VXD2RUcsyb+zaj0a1X3m//AMNCfta3 lxa3epftWfFeezkV97w3lrFuk2hY3QrAOMcMAOpresPj5+1hLe2t5e/td/F/Sbi1tDp8g06WyaEF sGJzvtyxIXrtIzx+HRWzuTm/YoMHw/gqqdP2VrHunhD9ov8Abf8AAK6Lqtx+0l4j+Jltprfarn+0 LW0I110KsqNHHGMbhleTwSfpX7qfAb41+Hf2j/hxa+PNHDWWvWkML+K9CjhCjRrohw4K7VZCpUhs jqcjgivGwuczlj5Uqz97ocnEXB2Fw+WRx+Ah6/M9bYRygNNGW/fJOS0mCm0ghjjoR6HsKhcsRtKo y+WwynJLlslcYyOPyNfQUqiVf2kz8tc6kGo32JDHKoed7O58ls30M5lBWUjKlSPxBzwAat2lt500 bXHl2LRqZbqS6kC/ZYlXc7OOhIXJx7V6+BpLG4pU6evyOfN8VVhSdRK39M/LP9p79ra/8Q6xH8PP hHcmx8J2LXtlr/iy0uJIpNYeGQLG0coG5cqzYAr8+bjS9Mu7/wDtu/t7/U9WaKRJL7Vr97m4OQoC BjzgFVOfav1mnOjg6UcHH5+p8JhIYmtWeLxFNPt6fkW7Ke0uT9lVpvtEUSRiUwlEVipJXJGGPAq2 9u9zBtu2thH5CQGeOUboY8liMdScg/nSxDrwfNTeh1ZklSUayW5qWNlPcyM++P8A0xfKsGQ4EkgY MCRjByAM11f/AAi1zcQtHBBDDcysH8xpAfJfkybB36Hr049K68ts6qnBbtnl4/ETwlD28luWpLKy t7nUVdJ2jkPlk78bpMAqS2evciqdzc2Hh7TrnxHqsEfkw6YJlminWP7ZtfZkHBPPA29epr6Xno0q E5Sjqj5v6tHFzp1KstX/AFofn94i8d+KvFnjGDWftkltc6fq1rqWhHzQDp0e+CdoZWYbVDvBt3ck Fuvp/Wz4E8aL8Rvhr8NfHCaa8I8VeC7RgpvVOJlyj7sZyflX8+tfzVjcbLHcQYqps7u33f8ADH9F Qy2OF4YoKnrZa/edJbyKyS4/c7WEE+EJVMc4OBn0IwK/Hb/gq1qNvZfE34WQrp1vPcW/hG4t9Lgk jO8zZgfJyM7Ru3ZPp617mV4zHYDC1asdXZ6evofJvA4bHY+jSxW+j79eh+G3grxd8Cf2d7jVtY+M fj/Q/wDhNfGt43i/WBozLJeWN26eWsTDksFWJQqDPT3rv9E/4Kw/sB6PY6lHqHxG1q2txZy2g+3e E71TKS7dV+zjaWOACc98V3cN4ujRo+2x7XMz7Di3h15nQ+pYSXK4/j1O60n/AIKk/wDBO+7uY7XT fiZbadd3Gix6tETDMyW8QUBwzFFQsTnIzuHpxX2L8P8A4kfs9/tJ6Trnhv4TePY/F19f2x0+zt4J QmYnjLhvNDcRkBstx35r7KOc07OnS6n5HmPBObRhDF4h6Qa+f6Hxpay+I/C+hab4J8c6fFb6z4av ptAuXZy8GpwRqRA9tKwBOQVyTknBz61wms2Xgq/t2+26Lp0kt2wkuZ/J/ehIycgHqOT2654r5jNc 5lhsJOjUet9D7/K8so47BwqYePTXT5n9BOqxjw//AMEUvHl7a74JdP8Ahwl3ptwszXJt/MdgQOTy NoUY4zg81+Uvww8UTXHw/wDBmq2cUumLqWh2N5JYrMA0YliXgHjoeCRzya9DLsasPgYUr2uv8z52 vhIV80dKotD0K88TyT21i9xd29jLayPI+pSMx80MuArYHT5Tj9at6Ne6X4huNMn1PUtWutCG8a9o GlzpFDqisMR/OVLLhsHK+/4cWMxkak7y0R6+Byn2tV06On4EXgLSfCvg7WPEEfhNJ9L0JdUjjFt4 g1Brp9B35IZmOCwJLMQBxnivtn9jHxS/hX9oJ9LvIot3iSCXS9Sm06YyQ6yshfyyr44Qna3JHI4r pni4Vsq9i1ojbNsphSmq0tah+w00FzDcNG0UUwt9trcXCXG0xtg5G08nGPz5pyPHF5iQxvNcANK0 dzOdjkgY24Hy/h1NfJ06soXjTW5NGi4UOS+q/wCCTKWR7jbY+ZItuix3zXgHkEEfLgZLdO/TNTl4 mMFzNC2VTyfs63BVHBB3FcYPXr9K6cPOo6jhe4VcPWeGtPcbEPJtg6QzNHa2zKsfRp9hHCn8Qaux /IIfLRzLIzvteXP2hCDt46qckn3/AJ3S5pVZNy0RhGhQnaUo6strFKiRxzRnIUKGkTa0hY5B29z7 /SuD+NPxa0v9nr4EfFX476+jpafDjwzLqVn853S3J+VUCbWD9clcc9s104WonWftVomVHDwhCUYd T+X7xl/wUO/4KGfGPTdH8Z6J+0rq/wAPPDPimyTWRovh7QY7eTRoTgxiOKeDKttI3K6k/Q15Bqfj f9ofxLfXd54v/as+MXiSSYQNre7XIrWGEjO4COJAmGGMgnPJxX3NPizA0qLp5dSSa+/7+v5nm4rh jEzrKc23F69f+GMzxrpTQ+FdO0fVPF/i/VbmCCOTU7jUvEEkg1ZnYDdcRtkAqOy4HPHNdN8GovDv wfMWoeGvDMFrokUgn1XT44VeIxMGBcBvm385JHPX0rko8UValeOHrO1zSfDeFdOU1T1R9J618Ivh 14g069vdPsho+j6zEJptC069zDeyljvbbwEORk8DdWJ4d/Ze8A6fPdarpOjeF78amqTXsd5psYuY pVBVv3mAxADN05BNezgcTmGGx3tqE7pnzlfPcNhKcspcLpdLf5H0V8N/hVrvhCXVb7QPix8WI9Mv IIrq00K1+JMsdrpEavIHWFDlscrwc4x1xXo37Q3gjxZ+098Cl+BvxM8ea94t8N2+t6frejab4lw4 nvYLqGWFnPAOxowcnpk+tfR8QYb+1MlnUhBe07/efn/9t18uz+k6E3Gm3t813Pxtgex0We78D694 dhste8HhtA1J7q0R4pIs/umjyPuumDz0z7V9MeHfHmm6PYIkOp3nhuKy/d6e2mTL5cIJZvLC4w5J JGMHBOa/PeEM0xOSTdGpUu2f0PncKOfYSjUh8Nv1Z7/pPxx8CePtKbwJ8Wfh1beM/BN/p09jLf65 YI8OrRMjLJFLEVwoyBlivO4ivvH9gb4w+BP2Wh4o+Gmpalf2P7OPiO4juPh94bt2nvY/hzdsZZro wnDlbckKwTKqhJwMcV99ntF5/lzlhlzSX323Z+SRhUyLOJUaulJ/LXoftT4f1PQvF+iWvirwFrum eLdAubVr6HU9OmwhjBIOQeQQOoxmrbHaZG8uQOVKRFflaJmYE49ep/A1+VVFCjejyfefY1KvtGpb k8dq010trFbtcPJMY1SFiwKjILHvjIPTPvXyN+2d+3x+yn/wTz8GWvjD9o/xeYfEOtPs8LfDnQIZ L/V9fAyAIraJWdh6kjoRxwcdmUYWeLxXsoR/4bqzOcpRpSlb/h+h/Pwf+Dqez8S+JHtPh1+yf460 Hw48M6aPd+ItEujdaggQNbT7FtiqeYpYYZ+CMEnqfXvhr/wcQyeMLyz0/wAbWNl8J5LlmFrPq2hC S3B2soIk8gIpUqdyse+Aa/XMs4f4VqQ9nOpzTW+v6WPjs5pcWwwzr0ZKKeytr89T9APAH7cvx6+K ESXXww+Jv7OnijTpIEuTHqRXSbiJI8na534J+UjKgr7CvZtJ/aW/bV8+zbUPhl8FNeiWdGlvdO8e N80Ssx6iDBIB/hNa43gnJZ0pvDzd3ex+Z47xC4jyZUsJi4KUtLu3n6Hxh+0F+zf8dP2w/iPonxW+ Kes+HvA2q+F9Ml0nwv4Z8K6usllZRSLD5z+fLtZnfyxkFAF9eTXxt46/YZ+M+h2wvtO8QeF9eiuD LeaXbLqkBlwCgKB1l5OSeSP5V/NfHHhdicPOpjaKu5O5/Qfh743JU6WWV6WnX5f8OfBPiP4f/EXw D4g1K01/wv8A2bp14ssv9pLrCyPFll2oVxuPfvxmvLNdDpqUQikeCbTIFvdRjeA+TP5m7y8tjGBh uAecc1+H4zKq2DbU9X6H9Y5TxVl+Y4SNRSV3YyYEk/sy8srjy2trQLqEzzfvDeMz7w/qFUEjA+mK lJnjmhkcSRpPK0skkhGJW2naPw+XGOmfSvKnXnzKhN7HtYWph5VZTelzHv7CTTrG43OqtBsvbq4Y kCEbiznPfLMAR61zAjuYpPs6F3ZYY1EkhyschyxbjpxgcdMfWuqrjnJKEVqZ1JTxU+Wm7RLFvJDL ZwqLKRxfOLGR5ZNw8zJOeB8y4GR2rhtTa5j1PTbsSZsGlexl0uVAxdg21XVh0OWBAOeD2xXqRqwp aXMJrELErD3vvr5GFqNvMbPapMbSz+VMU/fMXSTlSAeACB/Pjmr+ksqW1ujFGmuJ5pktUfI3uSZN uDwRtHXGeaUuaVO7Wv8AVjzsTTr0Mak/Q1IryKaBbiKPMabGDCXajb8bWY9dykHHrkCq2oF3sI9u 4xWMkty4SXe9+I3GCG6AE9QPbpXk1nUnG9dH0uHo06CU6W/c8D/aQhhuPh3p14pL3uiawLqwWKXC 3HyS+YGB6FGYYzgHGPryvwR169tLZbq4ZjPayRSyRo2WZSpEez/a55PpxX6RkahTyhSm/wCtf8j4 XieEsfmlPl6XPpeHxompWnmabbosk1o0DXKNvZGjYbucYJzuPTGPWtuy1XULt4jh7ZViX7DdRAyG bquAD1PJOev5VwVMXLDc1Sm7X6Hp4XCwp/vKnxGhqeg2swnvdTEslwkCWmySYlIz/E3rkgDnt29a LbVNEgjnW1uzPGzR/bbpowqxHeQVA6g8Ad89+td+DxftFGK18y8XSoqi8RVf9ehp6jYab9u8xykt 9IGhgULuNszYVnRgP9rkflXn1xZ3OjIPMv5rkwP5sssqZESAHcwUcglByegNdlPF0oV/Z31Vzwll 6zGh9boq6TRyytGdDutZ0Oza71C10i+EV3Pc7JJJGVlWOJsE7nVyCeSAQRyK/sD/AOCKP7Uum/FT wD/wjk7XJa4GpWipfQtE32xdRv4zDhgCcC3KggYAXPTp/Q+X1cJmXhT7SlrUhKC87a38z838Ssur YPinJcyhpRlRnzN/zN6a7fefunNb+TvWZRsjmEEzr/y0Y9Ovt/KoDbWc2+CS3jP7g4lUABwowFI+ n8jmvzqMpRd4ux404QqR5aiuim2jadIBGtpAqO0UYBYqqe3rx2A69Ky7jwnpWoFnmS4gdmYI8N9J HsI9CpGAe+PWu2GZY6muWNT79fzOGrlWBrJqUN+za/4BStvCGnwB47e51GCIweYwlvmuHZjldpeQ sSB164/WnHwvcpOWtNZvoFLoW2lDu2ggsMr0749q6v7ZrzjyV4KS80ed/q7Rpe9hK0oy7/8ADW/M w38KeNnSdYPHt3CQMpv02AiJQccfL9Ovr3rC1XS/jbBYLFoXjLRZNRmeSG0k1XSR5bsFJjLBegyP mA98EcVosZlNaUfrFC3p/wACwVcLneFotYKrzPz3/H/M57SNS/ahtJUn1X/hWl7aGNleOxW4jmef AGAS2FX8DyfrWpbeP/j3ZyIl/wCBtDvgk5WZrDViPNU5K4DdDwARk55xXoRwnDGLqWpV5QXpf9X+ CPGlmPF+Ao82Kw8Zv1/ysl83coXf7RXj/R7pbbV/gn4zvFmRvKufDskNykTrkESbiu0FsYPIww/D e0D9prTNRlhs9Z8FePPDN68MjmDWfDshjl8vaG8uWJXRup6HPynjpSr8NUnSdbA4uMuybs/xOjD8 WVFKMMfg5R7tar8D0UfGzwLDHLJeaqtq0eS0dxE8ZQcYXBUEsc9Bk10tn8RfCd81usOtacGuQ3ko 90FdyCAQFOCcZH514U8tx1NXlT/X8j36ec5ZVlyQrL53X4tJHSR61p0wGy6hLZHyh+VOAatLeWsi hlnV1IyrKpxiuOUZQk4zVmelGUZxUoO6LKsjBSrArkkY74peDjnofTvUlCjOSCc9D0qPG88HaAxz 3z2/mKAJNvrzzmmbAM4HfnnuaAIym87imD5SgknPfJH+fWqDQqse8owAnyRn+Dpj86AMue0tbhTH Lbo8ZdZDG/ILIwZD+BA6elQ/2Np27zvsqF3jZtxXoS36ex7UGNXDYeu1KtTT9UmZur65b+GrA6jq oYWscMhba2WOxdxbIB/L296/KL9qv/goDqng/RPEWn/Cye1l1vSrlrP7ZPZvttJgmcg4+cglORwM HrmuzBYGvjqyp09u/wCh5ecZzh8ppxdTd/qfzOftD/En9sT4/wCpa/P4v8d+J9O8MWFzFeW914K8 WS2T3UckRd4kGwLkOXUeg71+XDfsxfszeHdUurvxB8CbrxEz3z6zqN341MuqLPfvBGHP712OWCLl EHl5xwOK9fOsBhIYdUfY6W6/8Mejw9ntfCY2NX2mvpsemeC/gb+yFrJ0TUNM8CW/g3XPC18LzRda 8LrLod1poljBdre9gKTxhQcbUfGGIPHFfrP+yh/wUU/bR/Yd1Swt9T+I9/8Atbfs2S6ymmah4V8c yhvGHw/injtLaI2FxHEEmtknEkux9pQTyElgNo/n3iTAZlwdmX+smR60pNKcOmujlt9la2R/U+S5 7kXH+R/6m8Yr9+ot0qqTck4ptQ3StKTSb1Z/YD+zX+1J8MP2pvhj4c+KXw21D7RpXiLSodZ/su7c Le6VFLGZVE0XVCF2ghgCGOCBkE+/vdRNmOSDoxfYZOSe/v3NfqOW5jhc2wNLMcDK9Oaun5H85Zvl WMyTMq2U5hG1Sm7NeZnGWJCUJ2tgGTH9319+3H0r4T/4KNWt7c/swXj2VlDe3H9uR2Bt7iby1aN4 blJEJ6YcBRz0IzXu5XZZlh3Lbmj+aPi+LteGscr29yX/AKS/Jn+U/wDtG6fPB+0N8TbtLUW9jfXV vdJYrE8QUjTdN3zMjZdC7DCq3IEa9Aa8YRlgvpZzam3AaBvLn+ZozLzIDz1XaPrurn8RnTqcWZko P4ZN/gcngXCsvDHJaGIens1+b/zPddP+GGreNPAV14w0uGO8s9I1hNNZ4G3PApUyhXUchjnODyBn PFcDrfw31vTIry9XbG9gkV1Patz9oVsjG0eh45IxmvicrqwrwdSk7o/Y8fTlhKycVZdPxOFe1vbe 4NrNAqtIxkjSOTB8tFBc89FHGM9+lUWKyxRZLOYNkzyqCWJXlcD0YDGM9BzWuLpVask1sc+HblP6 1KG/kbFvdpbR3E8UUc8s8X2UQXR3KqnnIzjHbr04rLRi80zRbYW1DN1co7DakqgKGx3+793v0reu 5QoqMtUrGOL+oS5q1RMJLaT7dYBZiRqN3aW1k4G1DLNKsIHOdpJkGCeF3Z6V+0P/AAyJ4h+Bvg3w R4xs/GX9taB4q8IW2rTadq2n/wDEwZy4R181WAdPMwPunscnmvy/iTOIYnF18vpq7jzfkfpfBlKG Ayyli6i+Nq332PQvgkmo+H/iBc30FzLcpqukrHqUzEMYp2RGWIfwnaN2TjnsTX6lJqlyun2q2Nu/ l3Edrp9673C4g3lwTnGcE8YHXPWvhOD5T56/tFbf8rH33GkeXD0uXr/m0dnpIks9ItrMwSxxuZhK 11KXklO0DqSePbP+FeO+ONXuX1BdE0hiRC8g1W6ikJEKnaAvpxuHuAa+lrZnUyvLXiKkrbfj/mfA YXBTrY+OGa0fyNDSPD15pdtPJdzyXMKxRwxSnDrExVgWwuS2flH4c1uR3KvBPGAscKlRHuUFp3X5 XBHqW+6a+r4WzmhiMLGpN3ueZxdkFTBVUqK0/r+v+HNyGMyytbyI8U0BFuxTBy7DkEehUZwffFdj aaPI9gpijVLu1uCY38woMfNnZu65UY4/pX7ZwtQvLnpLRJ/cfg3G8K9Sn7Km7Nfec1fXtrPbXN3c WojsYruKVhJKCEh3r8xweSCQcVWWeLQbC4uLiVYboySINOuMgypJna3TAA+v8Wa+1yyMMZnM1TWi v+R+cYqnXy/LUsTKyl/w39fI/Nr43/tdJDcXvhzwXFBcXkEd1/aQjv2X/SN0AiXJ527TIT0GMYPN VvgHro8ZpPrGpyjULXQE+0qmoXLPIbpfLZTuc7gFHYAbgTn1P5l4n8QvnllmFdknb+vkfsPhtwz7 HCQx1Wz2/r7j2fVPEEmp3sV9d2psYIrt7a2UMDGCuDuQc4G0cA+4rHglWO9F2VkuZpoZoIo0P+uS Tk5XkPyOP7uOtfjbn7Dlo1Vdb/iftqpU51o0qL3Nu3njhVAGO6CTYsg+bG08MvsfT2x6Vo2xlhmD TPNGFR5EDr2+8GwOxzgemPwqKqqylKvHY1vSp82Hpz16s+i/gs1xq3hvW/s8ISOx1eC7txOVwyOG xIM8nLKflHsSK+wP2WPFOofDz4mxeK9MjitbLV7WeDxDbC4d0v22hXlcZ2AgMCoxnrzWOOgsP9Wx MF7zt+ZrhPZZjg8VlvPe1/wXmfttMyTWjxAh7OSMmJVwwMUmQCW6nIA47Z/GkivfnsQyII2LBv3Z 2su3AIbt+frX3FPkVKCh2P59xdOjGvUjzaohwRLCmxiywuUEYLtGwPAAB5JyPbg+lfNn7ZXxMm+G HwL1JrYC38SeOrm20fT78XxDm1lfyLomPGeN33sivrOG4To4qVZq1j5jOalWpKEZPSTt+J+GWjvD pelWdharHK5RZGkeTDME6kscbu2SRyRitWK4t5rqdXt3ECMxhjlJHmqFHJHYFieM+9fQY/M+erzu dr/10Or+yXhHCNvdJotStbUt5CkRqzxNmTiFoxyDxyQGyG4zjvXVad5VxcRGe2e7iAjR4/MAZmA4 bdj2yfpWCzqpL9y3p3OyWBrSouriKd4rbuekaL4dnuL+KGCG4lRnR7eWPAjBPuDgduvHSvU7LSGt 4A95Y3TStdubZYiEMJG77685Xjk9DmvseHsRW9olXV0z5DiGhRxVCLprTsYet6WWuZbS2tZb26up mlhtD0tWVAW54GTg8npj3r4M+O3jJbvU5PB1sZF0qzC212xXc6XWYnBL8Y4JAHfPtX0Wet0KElB2 v+T0Plcnwv8AaOc08PNe7G7+4+eriPS9O1O2uNUufs9rG8VpfpE5REVWxJxnAwpGM9cGv2c+A3/B Snw98K/hlc/CO++DF/8AEvUNBjS38IXVtrv2C00yz2vgOVXfnuQp4/GvzGhwhRnmE8VWlY/T8w4q q4fCyy6nHVOyNK+/4KkfGvxHaQnwd8F/hr8MbiyRZ4INUvpL+WXDKCDJtOflyQc56Zr8sf8Agoj+ 1V8XPiZJ8PW8VTaVqXxi8X6hD4O0uTTsQQ+HNOkmgSeaIMuHVFdCQQMkjByK14jWGyfKatfBtW2+ 85eE8Dic04hoYfEz1308meK/Cr9m74Gfs+22keLPEPwn0L4p/FPWWtpPEHi/xDN9qu7OYFizxNuI Vfu5C8dOOK+kr7xp8JNct1h1b4BeArqOMIy6W1ttikupAwzuzg9ctkYr8fwXE2Aw+HUq27/rof0Z mPBuLxGKcqFT3WzjfFfw7/ZP8V6VNpXjz9kr4V6pPc2m5vK00EQxjAYQuQQMkAgkfSvyl+M3w48R /sMfEX4ffHD9nbxDqXhjwZ4nvhJbWlnIJU0MjdGulXgYcK58zaR0OMcHj6jIc+wuMxsVROHMOEMZ hcvlKrLmi0/1/I/bbTPFnw+/a6+FPgnx7Np9rew6mk4S68/fcWVzFIYp8g4VfmRunvg14h4l/Z/u oLaDUPBni2S0NlDNJ5Gpbd+pRINojd2yAOuCPmr7bPciWZ2q4d6vW3oz8GyLOa2R5pWwE4Pk1X4H 6bXP7SfwL8Qf8Ei9c/Z1l8fWdn8XjBB4V1/Q9LczXehXCymQfKMjJ3dP9rNfn78PJoH+GXw5WONo Fg8Iafopt/OLGEpHnyzk84weSc89c14+PnPA1qeHnLWx7GSYeWMx9fMKvwK/5HUw6k8sV/Z37Rz2 T3UTxRzHCs2zaC3qTu6e3tW5b3MMHmRi2gjmjmijsruGQx5WMEbCB8pwOelKhOnWvKs9UevXwuPh FYrDytE6CbxOLzSptMuY7aV5Io7eG4eIq+4NkHK8nOSPm7fhXt/wI8Qy2PxC8L3htLho4tYtYIJR OP3C7mRs/wB44J4PY114rFVaWEcYbf0zxcXhcdKSxDldn9Dmqzp/a1xJcWEcIu4oJ2hjlYOimMN8 ueOSRnPTtWWu9WgcywztI++RYjtwcfKMdjzyema8GlU54KaMFC158xPEyRiZx8mUYyCA7gehyAPf J6d6kMiyQuxQKRFvSUvkqqk/OQOnp+Naczi1y7nVz1XG0n0JRNGYpHWM5djJKG5EqYAOB0Ugj8af HcG2uoQIkdbmP7koI+zgDIyB6kcc8UrzUm+5zOyu2WQsCKjXFtG3mIGhQv8APIw4yST1HWvzV/4L ZfFKT4T/APBNnxNrVksMGpX3xA0ewilu5gIZlN5bo6SI3VMSc9znA5xW9NVYqrydE/yKwlWliMRC NJ63X5n87fhv4n/8J18J/hd8Qr22W3TxhpKiyAhEO2UqAUKDp04z069akTxBG0t5G5YRw3sFwyyJ vGN21gy/3uRj169RXxmGx+LnVUYf1/mft9bKKNPAQ9ovft27FHxtq819cRFCrTXuovPa2KsM30lu du0sc7ei9fwr1rQLmOYWEBjm221pJutI03b8ptdWOMH8fSvtacKd416k9T8zxtZylP8Ad7fiep/D rxJf3Gg/2Rct5d/pLtazQtdF2aFtxi5IAOc49sda9o0DxV5UsNuqxtHLMXkNy2Xt8oMLtPHBBx9a +zwGd0/aKg3939f8E+Jlk+GnXniZQSfbqd9p+vX2myM08AKG8uIHVrr57ZAONuPU7ePbNev+Fdak ktXvLydYorK0juLvU9+5dPAJ3s68ljkAfWvusnzON6mHqO6/Wx+e5/ksVfFKHVWPyr/aNh8NeOv2 itY8ReFPElpD4esPhzbXXiS9a3CpbTxtHFCxUcMcNNnHXgn1r5e1rxJJpPizSxqkkl5o9k8NhYTP aBYIygdY51b1bcoOORnnivy6pLk4gqe1lZa2P2bg+lTxnD0FLSaXc+svAPiC11fw14v8Xa1qdrpn hDwRoMureItV1DLKY1ITyYYwNzyOTwqjkDnArw7Tv+Co1x4POu+H/hb+zxr3xQudMS0t77TwCPPh uTKkZdCM2+MDhwDzz0r28s4twmVY+dKUtFpqz18RwXhs5y32uL+L5HSeDf8AguZ/wUF+BWqCP4Nf 8E/rkW93LcWeq+FrzxjFDZWkjksoOLVo9xwDlWOfXtX0J4Z/4Oyv2jPhJqkFr+2x/wAE5NW8BeGb uSKM+PfC2ry30cCvuOJA1vHDu3eXhVkLHJ+UY5+ilmnB/EqqRpS5Kr1+7yt1Pk6nBOY5fg/bYOfN y9H277n9BPxq/wCCrf7PPhT9g/w9+2r+zl4h0X4nXfxjsYdC+Dnhy1vfMxrFxMLaYXKbDJCttKH8 3zFBGORziv4tvij4On+JXjHUfjj+0/qOj/FT9ofxtqjXuv8Ai3V7R7mz0FPLUx2+nI4xBEixrxtG 4qT3r4upKtgXOglaXfyMMuVCdKVSU9unn0Pmy+8TNaS6jZ6bptmttbCNrO3tSsf2mNQDkjooA6ev pXOyanYXe6xv7aG70aPbHFHPFnZG3zu6nqCTkEcjH1pYXMcXhGpUZtM3qYX2k1iJxv8Akc7ZaLot l4hudU8Japq3gzX9Q11tR+1eGrs2wnmlDLulRsrgKXAAAXLevX3fwr+0Z8c/B7b/AA78f/iZHFe2 ElzaW2qz219ZWkgcqiJG8O5Cc8knuPpX2+B49xGHhyYp36I5K3CnDfEM0p0Fz9z618J/8FLvirpm m2lt4+0mXx5f2sdxPLdSa6sMshic84iRUztxxx7ivq34bftSfsufEPVbS48X3vjXwrqQYxRix8a3 UcVqCG3FF3KnzMMfKTXdVxqzxe9U0/rY+RzHhGpwviXPCQTT6rp0PrzS/B/wQ8Z6Xb3mg+N5L0wh X+y+I/Ec8kqhTnDyM5GSB7jgV0F98HPBmpaZa6T/AMIXHrNtDdEI1tqplN+q/OF8tTyijrxyK/Ps 84Owbi6trtnl4bizPcFjvY05WS8zwbxd8BvAUl0tzFoEPhOe2SKCV7eWRMxnkiNSc7TxxXzxe/CW 4tfs93DdskVhL9pj8y4UpcuB8pIJ4AyTxzn1r8gzzhCnGDnQjZn7vw9x9iaKhSxMrx/L/gnnvivw p4s0uy+1y+G4bmx8xgf7Nu2kfU3bHDqVyGBYE4PpXnN/eXulLpAfS9RS8zHbBfsJeaHLDzX46KAR nPAxmvz76hiMPXSqQukfsOW57l+PoKUJ+9ocJe6k8C3+oW7x+W3nwG+gfeLZY3JIx/C3PXGMg49D rTC3g8i7Cbl88zKWYP8AbbZEVXfceB8xxkfePSubHUva4unGM7W/zPoI1pxqqtPX+rHNS6hB5aTe WpVJnt1beRmOXOMoOQQce4PtXKtcCK6gsgxt541/eXIcKWIOeMdMZA75zXsz5IUHNO7Kx9X603Cr G39f11OqtPLkWISEG1jdZJliCgqu7kqvQkO2OfrSXF95kTxw3AkbTLHzLqNBseOKZ2CAeu4oDx3H NeLPFTqQcJo7cqweIhhnUrS93ozw79ot47j4eanuC2k8+nv5QjKurJCuQfchgrds+9fDPgbx2mka vPPd308K3On28C288y+Vbs7lMt7HcQD64r9DyedNZcnPc+F4ucsDjKVWh/w+v9f8E+2vBHiI3LWC QPB58dzHNFDFcKVdkXG04OM45P1r6M03UdNsL2ztjPaLe3DIbNhdDdG7IHKlfUAk57VxYmNBtza0 Wx6+BrvE0FKe5V8SeOdAvZ7S2HiDTbe/u8C0gm1CNZLhEHzKwyMqT0J7D2rn9N1Cxu0W8sLq11MX Ik23ENyDBBGCVZw3OSCOCT3PavPjmUlUajDVH1Dy3A4jC++/61H6ZrVu9/YSRarayyRzyQeRJfAg IrMSN2c7iRxgcAe9dba3Dak9nqvmRpDFHeWatJEAL9GUE8nkEHIHB4we9eh7Wc2pNas+eoYZ4JSw 1N+70JLvRdOnsxbCU2qROmotHEgU2lwmArqf4mCjB7+1fpZ/wSE+IzfC343Xvg6OZbSGPXLbU9pI EUSXc2u38j57u5IlPuwHuf3nwr9piMhzDL8Q9FrrfpFnxfi7QprgCjjoS96E6cdr7s/ts1JhNdLc Lu8ue3jmiDDGFIzn+frWfE3l7RGSDCoUuW3MeBy3vz/KvEPzQRg3OMeZ2DcBSCOD+GfWnEkkhR8o /iI+91/I9KAJOfKjcZ4T96v/ADyZjt6jr0FR4/dzBScSYWRP7ynr9OQKAH5Kp5JxhnD8sMDjH+H5 UsblmaU8PDJ5oOeVbIGfQdRQAzI8sj+NipD5+6AcnjHf1zQIuWGxS0+ZWIAG4DjnsOn6UAG1ZI0T GY9iy+Wx+6OVG5ex4qu1lasBCbaEiMOiB1UmNT94Z69h/k1UZzh8LsY1cPh6+leCfqjEuvCHhrUl il1DRdOursEFXmslZkbGMgkHnnFZDfDfwjMt1I2h2zyTsAzEElm24yoPTjI4x2rrp5hi6UuaMjza uRZdVSShb0f+dyIfDrTkWCOyv9ctUiaNkjTVJGEiochSCSCBzxjBxg8cVbuPCWpeZEdN8R31gIn/ ANYqxuIH5KqMqeBwx/Ku6GcOfu4qmpI5q2TVYpywdWz+a/Ff5EEOh+MLVmFt4llnMMazxpPbIBI5 HIbC52s3YcgE+xpovfiZaTy+XFpOoxcbEj3RvMBGS5BYkAbhjocVMquUV370HHzX+WqMYU+JMK4x jJTXnb8W7M1YfFXiuE273WktloVeRYJlcQr15JwScjGAMc0xPiddwJLLd6Jq8UUbBp5XtQdgJ5wo JOB9DWv9mYKulLC1/v8A6VvuIlnmPwcuTMKCv5O3+dzYg+JelSC1lPnFLufyLY/Z3InYAnAIXjgH r6Vr23xD8PXaGRbqLb5zRLvfZuAIBIzgnnP0xXLUyjG0/hSfo/8AOx30eIMtq/FJx9V/lc0IfFWi XLTCO7tj5cYaYif+A5GR7ZyKU67pt8Y5ILy2dGJWPZMDubqQPfjpXDPD16ceapBpejPTp4vC1Zcl Kqm/Jpj45YnA8uVCDjGDjk8j86sK5TzB1faYzk/cJHcf0rE6D81f22vjdr3gTw+1ik19YxC4W1vb i3tRKIPmkQKvUMTtQE46fhX8t/xp+N+q315e3+pM9/JPd3Mbx6fwwZyWffnG35lQj09Tmvp8glTo Up1ajsrn5/n0sNi8yjharu1f+vkfl98Q/HnxL+IGs2V5o+p+LfDWk/ZppxHEQv2x/k8v92yn5Qd5 B68YryvTtE13ydXk8Q+MvFkd5I6pbyWckdwYF8soxUkZYkhWPGAeMd65sXmbzHGNvSC7n12WZLg4 ZdB1Je+tfzOV1fUfGfg+FXOtf21ax3CzX51K1+y3F1EGVZQWHybtvOMD869A+G37QF3Z3MFldX0r 6fKscPmqOJC4ZvLCYzwMDJ4LccV8hxG8PPC18FKF1JNfNpo+44YxeMpYihjaT+CS19Hd/kfob+wD /wAFD9b/AGKP2gPBtu08Op/Av4zeMLPw74pgm1NkPhe91C40ixtFUrCflM3nAgtgC7/uqcf30+A/ HmgfEnwrpvjHQZLXULDVbKLU4ZLa53Kkc5kdQSODjGPfBPQivxnwgzmjhcTj+DKqalQlyxWmqSu7 devn6n7B42ZRPHYfLuNqDTVeHNP4tJOVle9108vQ3JW2CILH5hljLRoX4kQHBP58V8lftwI15+zP 4jt5rG6u4rnU1hktoH6/uLkkM3UEgBcjptB/ir+gculU/tTDwUdOZa/NdD+X+I4QnkWKUn9mX/pL P81T4/eBIL/48/EFZnF2l7NZ3cl2+F+3udPsv3yMCWTfsTcuPl8sdN1fPuq/CC2v7JLoQNDL/Zxi aSNQZEdCWMrp0ycY+ho44oSnxJmMKis25fkLwpq0cLwFlCgvhivzZ9Z/sBReH7jTfi98MdYtra/+ 03dxq1lbTK33I7a2SVEPGTulRt3Uh9o+7U3xY+G2l+Gtc1u1ttNlstN3S/6NKdxkVvkZsjg/OSQD 7V+XcM1adOFXC05ap2/A/ZuNMHWhhcLmkXaMl+v6nxprHwyiuLfVDd24fULaJDDJFF88rhCXJX0A AyM8HjmvmPUNIXT5ryBxvEbqys8WPJ4VgSOw2n+Wa+vdGo8L7eL3PnMNWUaypzlp1MK4TzZNhJfc QUUqcFiPlXHoQevfGa9C8KeD7zWL+Bre3do5Zg6ZJK25RcsX7kHPQ+nHNeLisTUw6p05O+35npPB 4LHN8my/rsdN47+GN54c0q21eFZy0aW1wyTKhMzLNyBngLJxH833A+7tX9AWneJE8Xfso/s9a/M1 vcX0/wAMdCtZZdQyst3vdvnReqgBvLxxnAY8Gvz3M6VKWcYmd91J/gfo+TUYSyGgsJ9mUfzPI/hT pt3PfWet6Sokt7C1jsryye7CySPuGxNh7pz83tjvX6OWpBhtTG3mRxyNez2rYw77iAcHjqeh6deK /P8AhylWjUqulM+04toV5YSjVm1pb8zvUu0trK3mVkklh02f96RhU+Vst1xgHoeuQa8J/YwXTPih 8Xv2iPhhr9xFaQ6dqWoa74auNUuN32po7DTrhoE3HIErTmXPQb9gxtrl8Uswlk3DVCcno7X+9nk+ GtBcTcTVMDUWkL/grn3H4m+FK2Xwph13QvAPjq+n0HXbe013XLV4zplpamOUic7ipO7+6oY8Hj0+ T9Wgitv7Ome5hkn1eZxBAhYGJBk7SDxxj9fwrp8Os2o47LqP1d6aanu8dZTDDZrUwdR6K/4Hpvgz SrnVNRub2fbLbQqqXEZhLPja6RgnPJBB5xnAqr411dodQl0SAje0r2kDxN5oJXAwSPug5OD096/t nhqUcPw77WK1/wCHP4J8Q61fD8RxoYRaN6/eO0fwpfalNpPh7QdMae6VGuruGB1KgxoWk3DuMLx3 Oa+Qv24P2gNB+GHhe10HTNH8nx1qawabJpVrcyNLZRrcRrLJIrE7VjhlDE5Gdw719Dw9RWEy7EZv N9H+KZ+fcWRr5xmWFyulNpK10vJn4q6lrlv4t+06y8yJqdq0UNwLYfPdERgyFs/fACjntmvo39mv xPNbQ7WvRFHqiBr6ZYv9cpRVXAHQnCk9/vCv544qg8fiVipaNn9RcHwlgcEsFT1SVkfVumHXNb1R ra3MUs0nlS2NhK3liAorHduAPykEdiTwK3Nbi1vSbeI3IgFzYxyXcTmbYspQYVFk7A5IwRz36V4a wnt5uotbH3lPDvCSp1q71fn5l2x0LxJLaaVO+r2Gm/bYhd3lleOtw6xmNiVyDwVYDvzjp64MGp6j 9mlkt5p40lgk0lLtpBly/HBPHLDKg+tddTC0aOGXtVvb+v66nLVq0v7Uap9bn1L8D/EVwvwUk8Z6 bp891pb+PrTw4mqzBomiuA0tqzLvwJQzhhgdwCK/Qv8AZr0hNX15tNktluJRoU109tdS7RcKbdtw yMqTkE56AgZ61wZrglUxeFwkHo7/AIM9fJJYbkx06E7vVfemfaf7M37X3wc8cWviT4P+PviJ4P8A h78QPh14kudGSTxTfCzHipRtaIhnGW2xsBkEgknivuCTRJ5tPl1/RbvR/E2hfNF/a/hDxDDfWRkP zdQ2AeBgMAcmvq8Py4aboV47fofi+dYGMarrUdt/61M9Ibh52tbmx1FYo2jninguFMkjMcyBUB3Y HX3zX46/8FBvGdzqfxos/BVtaqum+ArO5hvYZZhIUuC0UsEZxkbnVnbceh4x3r63LK9GGBnWnv8A 8A+clGjisdSo0VdL/M+HrWO4nitJnCSTpGZY4TcLIwBBGGx/dzg/QGqMV2kFpPAYprhI5vLYJmRi RnIweT047ACvm6+NoVaLhfY+2/smvZya3Z2fg/S1mjihitjG2sqIpbuLlNrqSZCTzkBen/6q+hvD PgCLzHfxBF5MEFsVnxyL1Cu3gA5w2Bn8a78moSzBxoR27/iefjscso5sNiFe97Hosnivwn4F06wh 0/Q4bvT4pjE9hHO6CFCWA2lecDI6+lUrv4u6RpOmza1arJbTJCBYi4lVmiRgQ24kYPIxg9iDX6zh JQwzhQT1iflGZxqxk672fT+vmfnz8Wf2jPFF7YvrmgxwRtqmq/2bNPp1+CIGMioGZSvQt1Ar481L xXLrmpWupJeyT3d9rMt3K8rbXe4jHkkMWAB+UZBHHAryc4zl1cRq1ofQcM8PYOrhqmawbjPb70ZY 8WW2p+M9KsRHJfbom1CXB+SFAwZiqn72CpB9Miuk8H/EPf8AFzW9Dgu1lCRTSR28jApDuUH5iOej cevXoKyjmqjP2kuv3HPVyt18QqG8vuPoObxFLNB9utRCJY7kHyLu4CebG5UF8dWwEJwK/Pvxr8RY /iP+2V4NsIXRLTSfC+pRxxXs6iGCTzLR0O5sBW43Kq8npxXxfiFWrf2A44eOkmj3+CqkcPxTGlCN p6n29ZaXDqE0E8R826jswsMtzchTagLljhm6EA5xzz7VpRx2MIZZtV0re1st8yPforQKVzgDPVef U+tfglPLcX7OKnG+h/WLxdKlS5akrs6f/R7y1MEN9YzXhtiUiF8kjyrGgYTLk4I4+73xXxB+2nqM cv7OXiPwrqyW0Fy/xD0nxXp8N2xZLO5RiysGUhvnCg+i9MV9FwbhamFzGdSq7JXPNzjMqMsmlRpv +tTF/wCCf3xQt9N8L638OGt7yzutH1X+2dKs4ZgYbSG5Z5nG0E5+dmP/AALmvub4o+Nvsuizbbpb a6W43w5Y+WsbsAeByfQHpk/n/ROX46FWgqtKWqP5RzzB1MPmcFH4Za/jY+DLDxTpFx4p+IH2Gztr G/1Twtb3+sX0MCrM00TlVcOByxUDK5yNoxX0H+yv8So/Emlal4FubsXtsjJqfhyUIFNykcamchep ZCy/J0y/5fmfFuKqVMwjVk7f8F/0j73hPLfrFarhqa2u/uR9LrdRQRxpJcNKbi6lAM65kmIJC4Hq Dgew+nN6G5CJbu5YXMsQmVmfIhYfebp9OvPTFRDH/wCz6P5n0UqMK0Xh3FpIu22omY3EVwjSb5Ej mMBJcbQX3AjryeVr03wHq0eg63outQHckGoNd+ZNcmNAU/eYeP6AjJGBnNUsyqVqKUTwcxyt8kpY fax/SuZY9R0vw7cyacUh1Hw9p+pRQG6NwIFMa4JY89j+lWW8zzWZA7Kbf5VyAHGQe/QjHSu6NRfV 4zZ+eqFTD15UpO6/rzJPPT5ZEikLG1EMoRwQHXqR0xkHoc1YVpEElq6HckbwHJ5BU5znoeoNbQb5 eZqzOm1nqPSaRnji/eF9m1GAxtJG7J9RwM/Wnfbg/n7k3ebANiLISZRwAM9up6e3rVJW947Hh6c4 Woyv3JRcwmSNZFKRJ8qSHIIyOPU9evrivwh/4OUvEDWv/BPrwjpM0TbvEnxO0bUFgbBM3l6jZq+7 P8DKjMc9lOKpVIVKFWHNb/hmRlGFp08fCtBbNfmfzg/CTx0bD9l/4AxiVz9jj1KC2TcQII1mfiMZ 5Y7QQT26da37T4oWt7f2VvI7XNxf6vFBh7swrqEkrAjPcspHA4B6Z4r5jBUFFxjTe/U/dMbjqcoO NXSyZ7hdzyr4mtJJmCmxgNzd24lLb2kcLsPoeAQf9k+te9+HdQ86BIJZhFK4e7YxuVM0WflBI6dC eeuK+lcHzWf9WPx2vOvLEVJQV4nQeEdSubX4qad4eMb3Fv4l0CYPCH25lhMZQD0/1nP0HrXsVo93 p2o+TMzFZrnzC7AItuYwUBwfmz6jtiuOlj4Rxcqct0z14ZY6uC+uTWr6Houn6sYRJZJKzxId0joA THuOeGPTJz68GtLxB45i8E/B740eMIbG01O80nwdJOPtty6C3ZXKhcjIBwepBFffZPjpRvXnLT19 T5LMcqrxocmIjofjP+w/4lXxfrfj/TdXt92p6t4fh8TrMkRmieV3YFFcALtCxjbx0HNe6ftGeGLW 8+FGsm3ms0lsreXVrCWVwpuZ1UFkI6qoA57elfH57LE/2g8XT2b0PoOGMNh6S+qxd7HwP8X/AIxW R8C+HvBl0mrSeHtYS2tLnV9G1b7KY7h4zI0xG7EgQqCN2eQPTI/ob/4J3/BT4S/C/wCCtpqzeAbD xg/jC3tddPifWXdH1s+TA/mTODvaTaxOc87gO1fh/i7xXjMkhThgH773+8/f/CDh3CcR59UwOLX7 tX/I+87Z/hUtrNNffA3wTereX8jTSXGp3cUwjJGAoWTbwCOT61neJdI+CeqR6pZ3PwM8EXGhXmjv pFzoOp3VxNb38ZHzmVXcj5l447D3xX4zlnifnNKvCrh6j5rrY/rHEeD3CfsrQprU/BX4h/sofDP9 k79pPRPHPwP+FTaJ8C/jpqF9Zan4V1DxNdX2j/D3xN/pl/JcWFrKzJCs6RRRbUCKgtYFUAcV458V b+38bte+G7eJtH8dWsM0unabd3AA8QrbP8ghx91+SME8qTx2r+2+FeIlm+Q0syq61Gtfx/rzP8+v GTgmPCHG7o4SnajK709Uj88r2+gl1C5S4il0y9k0WS3ura5mUtYyLIC7L3YgsAPTn3qibmKFbWKR hGY7iVby3c8xD+DP+1gByB24zXZHGwcW56dj5StRl9VVJK0e/UwdR1Zku5riCOMrMBaCPomnRogJ 2kfe3tk+xPGK5U6vIYYLaBGjFxfHUI3zmVEyDMShPJPAGTx2rCVesqcZs8fCQxEa7p0HZoxU8SXC w3Nz56QSRuYZlMm8MgYhGA7n+935FMt9dt7e589rQbrSMTxogClA/U+YO5PJ+gr144+vgnGpTbPS qUI11JVY3PWfh/8AErXfDGq6Zd6N4n8RQXVretql1pkGolY7xJI5CQM8AqTkA9cY719x/Dz9s7x3 q0aSXviO5026W+Ns93cIiy39p/q0VcfKvzdTjPWvaXENX2N6qvY+RxeR5b9ZbnHf+tT9G/hP+2H4 svLBNO8U6Jo2t6ZCv2ZYtR8uZ3WJSzLE+xSFPy/MWGM/n9Ct8V/gR4ltNJHjP4bal4a0fxRJFb+H Nc1uwuYNG1K5MZuGht71x5UsqxIzbVkzhTwcV87/AKz5JjMY8DiJpTfT+vM9Sj4VZ1mOHeM4cqcy im2r9Nz02x8B/B++WVbW71i3mtkMFuILozJ5udysEZhgkDHTjmrEn7P3w/8AGlnewRakYWkRtlxc zKjzyhPmQYYFcc5Y1niuFMPiKklTS/rsfN0cx4hynE+wqq0o7nzp8QP+CavhzxZZ29x4Su7rR9Tx 51re6Vq5MbvH5eC+98Pkg/KQQc8818AfFr4c+PvgZrsmhfE7RTb6Vski0/xdZt/otzvVTEs6/djk O4Z2/KOMda/HOIuHcRleL00f9f1sfuPBHiXQzKayrHr3138jx+CdVmnlnEEAg0yTTbW43h1tmDB9 vIyxLsp6Z65wK42aWO6uBqUSMbmy0/Fy4f5UbduPB++p9RznFeNSoVqMpe1e5+sYynHFcuJg9F0+ ZuHWEUxFd0Ul/ajZA0QJt/LBDSnJ7seRjk1oCO4tvsV7NKvlw2TW8rRx/wAIQSH5v4u/GDgtwa8u cJSryizrwlapVXJ9lHmPj7w5q/j+2i8JeDZLb/hJNYilsLbNq1yvh5VheWO6kjyMx5+TGeWP1r2/ 4N/s4/BT4IWpmvfBUPjf4h3kW3XvEuv5eWS4LCQeUFOFjG4jZgKOPev0PK1ReTxhTXv9f6/r8z83 4oxFTGZ5DCrWMU/wZ9Fnwc+t6VqE7fDPwrZfbGLR3bKbdr6MHG7dwByNv4V6Zofgvw/PZW1t4k8D +CrzTfsaXAmuJmdoJwwUcbx8w7YGD6Vvhss9rT9niHr/AJGf9q3cqWDlsenaF8Pf2XrKOKDxfoHh W4eXc2oaTa2SEhQP3R+YHIPzYAP+Fepyfs3fsLeKfs9nYeD9PvoQrwNZzX2xdNVm3tEcYVlwMhfc 19Pw3kOWYyrKnWirnyfEmbcU0KPtcHN6b2uO07/gl3+x98QV1ODw74P0GG0u4pdP1m6t9b+wzXkB DFGWPzFZCpQjIOcdOtc94y/4I9eGbHSbfS/hN4p8X+HIpLw3enRwayZMKsSxiONZZX2qcHjjOCe9 e/nfh7Uw1JYrCK6Py5+MWPyrGQpY9tLZ/wBeh8G/FH9kj9rP4LRTSXfgObx5o2jypDf61p88YvL6 VMZZ4c7GOwgnbjHFcJ+yJ8ZfDehftfeCf7Dv9OXxBrs8CeIvDtzqapc6QlppWvSpJLGwJUxOx4A3 MZeeEr7fwXw0oY7NMLjV9mpo+/I7b/I/TeLOL8q4o8Lp1Mrqc0va0rpb7s/0VPDl0bvwR4OvGk82 ZtCt4JChyHCIoz9QDz71o/cnLAAF4njlKnKnaRjjpk9c9ePpXxp4Q5UJBRS/O9sFsdeSf0phf5Mo Ml9oDH+AHgkD1xQBIxZVYBgCWX5gfvgdvof6CmiSQqQECqVDY6M59/Q8mgBeAF68YBVjkjr1/wA9 6XlSw+6QMHPG7nB/SgAXaY13oAPmLr1LZGMHtjPSjHUncATvJJOHIGMY+mP0oAC25WAj8ouUkjO7 JxkhlPp2/wDrVIocFRgnaxJ5+VyOf5UANyCyKfMVGcusYOdvA3bf0/yKYDgSBd2CCCAfv9+OfX+V AEuSTmJQSIwgQnktjBP+f605AFkCoq7hED5QO0KDxjn1H5ZoAfwpJCowVgOSCI8nOPU8Um4gxE8t 1hB5LYJG39D+VAEagMJhtUgIsu/OPnJxtA+mSe3SoHhjO1tieYjqyFiMAH7344P6mgTSknGSKq6d ZL8yW6Kw3qSYx3yOmO2Tz71lyeF9DuJpBJp0KRhTtdIfmVimDjtjNdlPMMZSVo1H89fzPNrZNltf 4qSXpp+WhkyeC9GlVXCz20UtpJZ3EVpKczeZhyFPXqOD2rLPgaxtn8+ze4RzB9mj23BZGUdD1JL5 JJPXivQpZ3XTXtV/X9eZ4OI4XnFOWGq37J/5/wDARN/ZGq20dwIb6STzQPKL3L4LcDOc5HGcjjtU 9vdeIrG2leVzc3SwvtlEgYPhyVG3gAgEc98c13Rq5djubngvW3/DM8uU83yqcac5uPZXuvu1R+I/ /BR39r/4Ra3pV94e8I3aX/iDTJBY31xp8RmSZTMVVQu3axCj5mHI3kkZFfzTX02q+Ib+M3vl3Nvu e5N0h2tO8RV4z5Z5CqxYe/GeDXm16tDCZVSpr4qln+hy5Zl2LxvHeJxdaH7uDkvW633fytYvN4d3 vAJXVJZIgUfft2KCenUDqRx6e9ckv7PV54psoL7RPFF94cmjMrafrEcAlheR8Eh4sZfO7vjGeteW 61PD2UtOh+j4ShUdaaoK8f8AI+X/AIm/Av8Aat8EabC9tDo/xq07T4J9Knl01o7TUWWWUGPdDIWi LABiTuXgDrXxVqy3mlMNRvNPvNKuY7h5b/TLqERzh15eIKDgup6EHBHSvJzWnGm3Wmrxf/DHpYDN adKv9Uo6Nb/1/wAA7LRNfS9szompvC4mit7uNww81pAyyo+4f6tvlXDDkEAjBFf2d/8ABu3+3nq3 xW+FOr/s6fFfWI5vH3wWittI/tPUJv33ie3i0bTCLhAFUhXa8WTpkbio5BFfzpj8ZHgzxcwWOS/c YiE+bT7TajHVJtelj+lMqwX+ung7mOHqT/f0KkOXX7CTlLRtf1sj+m3VoMuRYoqB5WkjgI4G0kE/ +Onp6ivmr9pvTtT1v4BfEPS4oBNcfZvPtoPMAiZ/IuVwzdgQOT2wK/pehUxlLOsLKn/Dur7b308z +TOIo058OYxL4+WVv/AWf53Xx+8ODT/jp410za08sGvmG/uZDskMr2Fg8ig91lXa5AGE+7wcivJ7 jS4kN8slrPNFiS6tlYLtfam3fxztABG3pwTXr8WN1eLMVG+rb/Jnm+FGFcfDrLKlSWqjG/3s83+A +tw+A/2iIbhC2mafqmmhdSMz7v8ASJJrWMEeu1Gzt44mXrt4/Q/4+6PY6mp1KK0MkdyUPlIxPk7p pAq56nb8vPtX43leJhl/FeJw046Xf5H9E8V0KuecHYT2L2UfzZ8OXmgynVbN7l7eKyMVzb6tMGV1 ZI/l2Fh1JJ3Aj0IPWvn/AMTaD4Uj8fXWl3NjFJZ6n4ggsFLSBHsMtEh+Y/IR0ABB+8Rnivt8Y40s uqVqctb/AOZ+cYbAypZjTp4l2Tv1PTT+x1/YWl2HitJV1jSdWuFuTCCJGtV3FkUFcg8jbgcjrXf6 V8MLSwiMdpbxvcw6dEskjKEaU+a0gj92U9CfvAY7V8thuacHUqO7Z9RiMP7OpPCxVg8bfDsa94W1 LT40nlmkle6tWaNcTM4IIznjeNwJ7E5HSvr/AMExf2f+yh8EtHuFju7nSI9M0575YwFUrEVVSDkg OCYjj7v3uK+f4ihyYudZdVJH2HDXtY0qdBOyutfmc54Eu7C21jT7jF5a3Wq6cly97bWhkS3jjCs6 t/sLgYYc81+gvgSa4VmxLcCMFwGl+95X3tu4dc5XGOnevyrh/E1HipwXf8z9l41o0VhcPTi7aa/e dXq+pXWl/boo4YbyD+z5VmjZgDtaInf+HJ/D3r4//wCCeV9E37c2rw3uv2um6V4zh1261C4vrQp9 pa2m0SFPtEmNweHzHMaADzEvMc+VXk+P0n/qHhFTjf34J/OR4vglPC4DxHr0WtHGo/mlof0p/tbR Ppf7NvhK08KeI7LWftoXWL/VdN0qazuIghulDbT8r/Ku3gcAZ6cn8LotXm8Q+INInvLgyyveNFcy M3zSsmSGXsQVJOfyr0vDfKqeHyXDUcK7LTTXTXu73MvEDFV8RxPiMRiN7S+enZbH1XbSw+EtAk1E iM/aWMU7QEA7187YCp7e3tzXh/g6Y+O7yXxw6FZ4IQ0vkSboZ0lIJC4OPmZQeM/dGOM1/cVCMcBk GHwKlq0vzZ/DWe1Z5pxVXf2Yt/1/w59FaBcWHgTwj4g8dSa69pruqbksbWFeY7SRGWSZZOOWcKCO 3Xmvzf8AHvgn4Z/HTxFrOrfE/QrrxZ/buim0j1BCbe/t3naGR2WbO5QTFHkcfcr2ca45bw3GjVek rN/ifHSwtXM+InXw0dY3Pgz4rf8ABPT4h6H4nsr39nfxFpvi7w34klTZonirUnS78PwhkMy7l+WQ LtPBxkKMNSaX4D1L9n/XNH/4TObR7m9a3k1Dxjo+m28hSOSVkjTy2zgEZ4RR0J+lfhmc0o4itzYV +4fvvC+IrUsL7PEv941/w59MaPqOm+OfiRoktjdJ4R8NxeJAseqaXM8Zs7YRqM4bO85ByBwQxrb8 Q2djFf6vBJrk19Fb620VleXKZ+1Qb8rL6jb6HnivHp4CMFKTer2+6x9fUrVqkFRqauP6GHoWoLJN Ja6wLme2s7K4jiZZNn9uyctgHB2rjn9O1XfDXhDxd4z8Tx+EPDtvBGNZvLK10oS58uwsgY5bmeZ8 YUqrEZHITB7EVy1aWJvHDKN22vwOnD4vCyxnNUs0ov79T9LP2i1+Ffwr8N/Az9jn4NeI9G+JFt4D 0m2+Ifxa8eaNZFWm8W/2hDNEvm52y/u3kO7uFJwM4r6c/Zv16DQPHsNvdaZEZdS8LappKwXk5i2K 8JaNgw6NvO4YPzHAroxs4wzzDQl8UN/vud2QYeFPLMxxtOPxbf8AgLWh+e3iv4VeGfH2v/EWw+IX w/0vxBc6Z44u0sbrXdGjllucP5kc4BGUZWOzjn5c16v+x74+8XfsYeNLG98MX8eo/BC/Vk8efDvW 0edLZJIliaezABEZQ7mIC5IOeor7TinLFiq1DHYZe91+b9T8lyTH1qrxmCxkrxu7fcfu54T/AGtf 2R/Eksd9ovxV0yz1COSV7TwtrJkhvbqWNC0aKxTkBtueua/nz+N3iqfxX8WvGmpaZdj/AIm3iWTV 7uYxl11CUwxo0gORtA249Pk461wZ5iMPl2WRpUpe87fqY8K5VOjms8RjIXi72+aOT0cS+bFerKEl kspLdZTORHtc5bAPc4HOM1uaFFeapqthdWMVrc6bZyudXs3zvDqu2MRsv+1kkt64FfC4p+0SpKWr P0+MKWGxT53pZ2PqLS7fTdAsNNnazjBtbQJcMpJQtvbbn1GGPI/u1peL/HqLbXOo287XYjby7URN 5aoiHAAA/hA7d6/XeF4qhgfejZ/5H5NxNg62aZr7SM7RV/8AM8UPj7SdY0W/lkUiVrd2eKOc4vCx yjNjtxxg+lfLni3xvqmr6ZcWsEE1rbJ5DWlrPcmTz4+Q2/cP7wIPcZHevXp4+cnJJ9/lofK5pl0M LXjzarsfOvjbVLXw/o9tOHgCTW0lwLMrtWxBIV1PuOGHXkV82Q+IZnjyk7rut/shlmAHnBW835j0 RuQeOa+dxXNPENLU+oyym61J06HqU9A8UTz/ABHj1HzPKax0jUtWha4jHkmYIqJCFHA5yWxjqO/F eX2njjULDxXda/o9y0OqanqH2u41SKcBr87VUqx5wgXcvTPArXFYj6rSpwT10NaFJUcTyqN7Xv6/ 1qe++NvjDdr8Oz5Nw2mXdumya7jkDG6Klt6LwduAydcZJ471+b2geMruf4v2mr6jdtHDqt7m6kkk KN9o2RxpKzdjhNpUHaeDz1rfNq9PHYClhpbafhcyynL62Bz55nVhZO9j6C1LxN4h+1alGmqaoTY3 D6ra3txqTm3guEbamIww3DaxODwCPxrk08aeJLK0mW/8QXk1v9j+ztJJeGSdpn5kkQk5UE8AD7ue OK8SOHoRtFRR+gUczxEKtWdWbab0IdG8b63Lql1FP4i1S4ja4EmjCHXJ0axkOPvsCN6gheOh5qh8 UfF93qMMek6rrN7cPdSm/khvNUaeJghUEhSSvzdB3GPxrnqYPCU4ymlZmOMr5hXowlhnfVfnqdJ+ ztr6eGPG82qK06kaMkQYXBL3hMbBFKMeWU+uPlYemK+vPG3xjn8W6IdKtZ2tLhoDCsyOC7gMXZFY
November 14, 2008 - November 29, 2008
Pietenpol-Archive.digest.vol-hd
