Pietenpol-Archive.digest.vol-hn
March 24, 2009 - April 13, 2009
Date: Mar 24, 2009
Dick, I don't know where your flying out of but some of those complete idiots may know more than you think they do. At many airports that ultralights fly out of, ultralights have a different pattern altitude and at some they even have different patterns. Sometimes we have to be careful who we call the Idiot. My two (2) cents worth Gene ----- Original Message -----
Sent: Tuesday, March 24, 2009 5:03 PM
Subject: Re: Transponder
> > >>>> I've made provisions for a transponder and encoder in my Piet, >>>> not because of FAA regulations, but because I want the ability to >>>> be seen by ATC and by aircraft equipped with traffic recognition. >>>> And for that same reason, I'm installing wingtip strobes, as >>>> we've got some complete idiots flying ultralights in my area, and >>>> some of them seem unable to comprehend, or simply disregard, >>>> patterns and pattern altitudes. A transponder and strobes are for >>>> me just part of the "see and be seen" mantra. Dick Carden > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 09:19:00 ________________________________________________________________________________
Subject: Knots in wood
Date: Mar 24, 2009
I just received my capstrip for my wing ribs today, and while inspecting I found a knot in one of the strips (pictured below). This section of wood will likely get cut away, but I'm just wondering if this is the type of stuff I should look out for. This is the 1/2" side of a 1/2" x 1/4" capstrip, so the knot is approximately 1/16" in diameter. Reason for concern? -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236050#236050 ________________________________________________________________________________
Date: Mar 24, 2009
Mark, I am traveling and don't have my copy of AC43.13, but if memory serves me correctly, it allows for up to 1/8" knots that are not loose. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage ready for gear (13 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of K5YAC Sent: Tuesday, March 24, 2009 7:22 PM Subject: Pietenpol-List: Knots in wood I just received my capstrip for my wing ribs today, and while inspecting I found a knot in one of the strips (pictured below). This section of wood will likely get cut away, but I'm just wondering if this is the type of stuff I should look out for. This is the 1/2" side of a 1/2" x 1/4" capstrip, so the knot is approximately 1/16" in diameter. Reason for concern? -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236050#236050 ________________________________________________________________________________
Subject: Re: Knots in wood
Date: Mar 24, 2009
Thanks Gary... I have a copy here that I'll look through to see if I can find that info. -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236052#236052 ________________________________________________________________________________
Date: Mar 24, 2009
c. Hard knots. Sound, hard knots up to 3/8 inch in maximum diameter are acceptable providing: (1) they are not projecting portions of I-beams, along the edges of rectangular or beveled unrouted beams, or along the edges of flanges of box beams (except in lowly stressed portions); (2) they do not cause grain divergence at the edges of the board or in the flanges of a beam more than specified in column 3; and (3) they are in the center third of the beam and are not closer than 20 inches to another knot or other defect (pertains to 3/8 inch knots=94smaller knots may be proportionately closer). Knots greater than 1/4 inch must be used with caution. Chapter 1 AC 43.13 Joe Motis Piety piet piet No archivos In a message dated 3/24/2009 7:53:40 P.M. Pacific Daylight Time, hangar10(at)cox.net writes: --> Pietenpol-List message posted by: "K5YAC" Thanks Gary... I have a copy here that I'll look through to see if I can find that info. -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236052#236052 **************Feeling the pinch at the grocery store? Make dinner for $10 o r less. (http://food.aol.com/frugal-feasts?ncid=emlcntusfood00000001) ________________________________________________________________________________
Date: Mar 24, 2009
Subject: Re: fuel tank material
I used .040 5052, tig welded. Even though it would be a little heavier next time I would go with .050, easier and stronger welds and stronger overall. Rick On Tue, Mar 24, 2009 at 10:48 AM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > > Jack, > > I know the gent who welded up my tank used 5052 and I'm almost positive he > used .032" thick but can't recall > the H rating. I'm sure the Tony Bingelis books give a good suggestion in > case you'd like backup on what is best. > for vibration/fatigue resistance. > > Mike C. > > > * > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Mar 24, 2009
Great! Thanks Joe. -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236057#236057 ________________________________________________________________________________
Subject: Re: fuel tank material- Stewart System update
Date: Mar 25, 2009
I made mine out of 5052, .050. I taught myself how to TIG weld aluminum, after failing miserably at trying to gas weld the stuff. I bought all of Kent White's books, filler rod, torches etc. and he made it look so easy at his OSH seminars, I thought it would be easy. NOT!??????? It took me MANY hours and two tanks before I was able to TIG weld a good one. I only had 5 leaks to fix! I am intalling an access panel (.025 alum) over it so I can?remove it?easily if I have to. I stiffened the top panel of the tank by hammering-in an impresion of a 5/8" steel rod in two places. One mistake I made was placing the filler neck too far aft, so as to make it difficult to reach when re-fueling. I should have kept this as far foward as possible. (center-section wing tank). The fuel gauge is a "Stearman" type with the cork float and the see-through plastic clinder hanging down from the tank. I bought one from ACS and had to cut it down to fit in the shallower tank. Another mistake I made wa s to place the gauge right?in front of the front seat passenger, making it even more difficult?to get in. But I decided to leave it there. I actually made an aluminum housing that protects the plastic cylinder because I was afraid that somebody might use it as a handle, or bump it with their head.? FYI I am well-into the Stewart System covering all my control sufaces. I predict over time that this system will over-take Polyfiber. It is far superior in my opinion. No fumes, plus you can work at your own pace with the glue. This glue is some kind of rubber-based stuff. You paint it on, let it dry, place the fabric on it, tack it with an iron, then paint more glue down through the fabric and you are done. Dan Helsper Poplar Grove, IL NX929DH ________________________________________________________________________________
From: "Glenn Thomas" <glennthomas(at)flyingwood.com>
Date: Mar 25, 2009
What I did was order about 10% more capstrip than I needed. Then I put aside pieces like that one, and used them for the internal short pieces, simply cutting out knots. I had an order from Aircraft Spruce that had so much of that kind of wood, and poorly cut wood, that I had them replace it. Also, I just planed the extra capstrip down and am using it for the capstrip in the empennage now, so I really didn't end up with anything unused. FYI -------- Glenn Thomas N????? http://www.flyingwood.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236072#236072 ________________________________________________________________________________
Subject: Re: Lets clean it up
Date: Mar 25, 2009
Mark, your points are well-taken. One thing I like about this forum is the friendly exchanges we have here. I've looked briefly at other lists that have greater discipline in enforcing adherence to topics and list protocol. This list has a unique culture that has no "enforcer" and the climate is almost always friendly. I call it my home on the range and come here for encouraging casual friendly atmosphere mixed with an incredible range of knowledge. Most of us like it this way despite the flaws in sticking to topics. Other characteristics of the disciplined forums you refer to are cocky moderators that "flame" you and cliques that seem to exclude rather than include. So, don't take offense to the comments you've received, I just think a lot of other guys like me are just trying to keep a unique forum they way they like it, the way it has been for many years. Take care, welcome, and look forward to seeing your project advance. -------- Glenn Thomas N????? http://www.flyingwood.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236074#236074 ________________________________________________________________________________
Date: Mar 25, 2009
Subject: flying, cabane and jury struts
I am building/having built all my struts from laminated wood (ash and mahogany 3/8 strips) for those that have used wood as strut material: Has anyone beefed up the dimensions of the wood to compensate for the strength difference? I am also considering a routed channel in each cabane strut to run wires and plumbing rather than the typical zip tie method of keeping all the wing wire and plumbing runs secure? Will the routed out center of the cabane strut weaken its integrity and should it be made slightly larger to make up for the hollowed center? anyone have any recommendations I need to consider with the intended plan? Please provide your best advice in this intended material and slight design change. Thanks John **************Great Deals on Dell 15" Laptops - Starting at $479 leclick.net%2Fclk%3B213153654%3B34689672%3Bo) ________________________________________________________________________________
Date: Mar 25, 2009
I use the rolling two years for my answer, its always going to be done in two years and I am always right, no matter what! John **************Great Deals on Dell 15" Laptops - Starting at $479 leclick.net%2Fclk%3B213153654%3B34689672%3Bo) ________________________________________________________________________________
Date: Mar 25, 2009
I agree completely. The Stewart Systems products are pleasant to work with. Covered ailerons in the dining room, Wing in the living room and no problems, no smell, no worry about it catching fire, etc. The glue is cool in that you can use an iron to really make it smooth, with PolyBrush you are not supposed to iron it, with Ekobond I get it the way I want it, then iron the edges of the tapes repeatedly, sometimes adding a bit more glue, the results are edges that I can't feel the pinked edges of. Very nice. Also I managed to cover my wings and ailerons using maybe two clamps at most, just to get the fabric roughly in place, rest was using the glue to tack it. Hard to explain, but it is very pleasant to work with, and forgiving. Had one tape (trailing edge of wing panel) that wasn't right, instead of ironing it in place, I had tried using cloths pins and the fabric shifted and had some excess along the back edges that wouldn't come out, I hadn't ironed the tapes with a hot iron yet, so was able to pull them off (a week after putting them on) without any problem. Anyway, when linen and dope ruled, polyfiber had resistance, think the Stewart Systems stuff will as well, but it is nice to work with and you can get excellent results pretty easy with it. Jim D. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236137#236137 ________________________________________________________________________________
Date: Mar 25, 2009
Subject: Let's clean it up
One of my favorite quotes in all of literature might sum this one up nicely : - "It is not advisable, James (or Mark), to venture unsolicited advise. You s hould spare yourself the embarrassing discovery of their exact value to you r listener." - Larry Williams xcg, xcmr, epp=0A=0A=0A ________________________________________________________________________________
Subject: Re: flying, cabane and jury struts
Date: Mar 25, 2009
My opinion is that the wood should actually be as strong as steel. It will have more ability to flex and absorb shock loads. When I get around to it, I plan on doing the same thing with my radial eng Piet. Allan Wise flew his very unique Piet for years with wood struts. It didn't have any steel internal strapping and was very strong. Dick N. ----- Original Message ----- From: AMsafetyC(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, March 25, 2009 8:05 AM Subject: Pietenpol-List: flying, cabane and jury struts I am building/having built all my struts from laminated wood (ash and mahogany 3/8 strips) for those that have used wood as strut material: Has anyone beefed up the dimensions of the wood to compensate for the strength difference? I am also considering a routed channel in each cabane strut to run wires and plumbing rather than the typical zip tie method of keeping all the wing wire and plumbing runs secure? Will the routed out center of the cabane strut weaken its integrity and should it be made slightly larger to make up for the hollowed center? anyone have any recommendations I need to consider with the intended plan? Please provide your best advice in this intended material and slight design change. Thanks John ------------------------------------------------------------------------- ----- Great Deals on Dell 15" Laptops - Starting at $479 ________________________________________________________________________________
Subject: Some Sad News
Date: Mar 25, 2009
For those of you who attend Brodhead and know Bill and Sue Knight, Sue passed away last night after a very short and courageous bout with cancer. The funeral is Saturday in Brodhead but I don't know the details. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2810 Crossroads Drive, Ste 3800 Madison, WI 53718 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com ________________________________________________________________________________
Subject: Jim Lagowski Pietenpol completion in April Sport Pilot
Date: Mar 25, 2009
Jim Lagowski from Michigan has a very nice pic of his completed Piet in the April edition of EAA Sport Pilot on page 53. Nice paint job! Lorin Miller -------- Lorin Miller Waiex N81YX Pietenpol next up Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236177#236177 ________________________________________________________________________________
Date: Mar 26, 2009
Hi, I'am thinking of doing the same, I think the ash struts should be sized so its strength is at least equal to the spruce at the fuse and spar ends of the attachment.ie say 75% the thickness of spruce. Also as the strut material will be vertical grained the struts should have a layer or two of ply with the grain running across to prevent splitting at the bolt attachment points. Is anyone currently flying with wood struts and if so what dimensions have they used? Regards Mike T. ----- Original Message ----- From: AMsafetyC(at)aol.com To: pietenpol-list(at)matronics.com Sent: Thursday, March 26, 2009 2:05 AM Subject: Pietenpol-List: flying, cabane and jury struts I am building/having built all my struts from laminated wood (ash and mahogany 3/8 strips) for those that have used wood as strut material: Has anyone beefed up the dimensions of the wood to compensate for the strength difference? I am also considering a routed channel in each cabane strut to run wires and plumbing rather than the typical zip tie method of keeping all the wing wire and plumbing runs secure? Will the routed out center of the cabane strut weaken its integrity and should it be made slightly larger to make up for the hollowed center? anyone have any recommendations I need to consider with the intended plan? Please provide your best advice in this intended material and slight design change. Thanks John ------------------------------------------------------------------------- ----- Great Deals on Dell 15" Laptops - Starting at $479 ________________________________________________________________________________
Subject: reinforcing for: cabane and jury struts
Date: Mar 26, 2009
I added carbon fiber to my laminated mahoghany/spruce cabanes (WAY overkill!). Decided not to do the lift struts in wood because of the weight, but there are several Piets flying out there using wood struts with and without reinforcing laid into a routed center area. Sure looks good. Anyway, for those of you that are using laminated wood for cabanes or struts, I have PLENTY of carbon fiber left over. Probably enough to laminate struts for 100 Piets! I've attached a picture of how I laid the carbon fiber in between the laminations. Other materials, like Kevlar, are probably better in tension than carbon fiber but it added no noticable thickness to the lamination and had to help reinforce the bolt areas. You can just barely see it in the lamination. In fact, after vacuum bagging the whole thing you couldn't even tell the carbon was there until sanding those areas and finding a tiny black area between the laminations. Mostly I figure it probably strenghtened up the bolt hole area to help avoid splitting. So if anyone wants to do the same, contact me OFF LIST (jim_markle(at)mindspring.com) and I'll send you enough material to do your lift struts and cabanes. Jim in Pryor.... ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: wooden struts
Date: Mar 26, 2009
My lift, cabanes and jury struts are wood. They're a sandwich; spruce-1/4 ply-spruce. I don't recall the exact thickness, but they're copied from Alan Wise's who's flown hundreds and hundreds of hours with his. I believe the only metal he used was steel strap sandwiched in the jury struts, which is what I did. Won't do anything in compression, but will be helpful in tension. Just tracked down a guy up north who's piet I noticed had wooden struts in an old back issue of the newsletter. Finally talked to him and he's done the same thing with no problems whatsoever. I know Gary (now Keri-Ann) Price's used wood struts, but they DID have square tubing inside, so the wood was really cosmetic. I like your idea of hiding the lines etc inside the cabanes. Rather than bulking it up further, why don't you rout a channel and epoxy a thin walled steel tube in there to act as a conduit? The tube would more than make up for the material routed out. I'll send you a picture of my struts offline since I still can't figure out how to send or view photos. Douwe ________________________________________________________________________________
Subject: Re: how do I view photos
Date: Mar 26, 2009
For everyone using Windows XP here is the handiest picture resizing tool in the world. This link will tell you all about it. I wouldn't be without it. http://www.microsoft.com/windowsxp/using/digitalphotography/learnmore/tips/eschelman2.mspx I don't know why it wouldn't work with Vista. -------- Jim Birke Ira G. Ross Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236300#236300 ________________________________________________________________________________
Subject: Re: reinforcing for: cabane and jury struts
Date: Mar 26, 2009
I am sure no expert on carbon fiber or any other method of fabric re-inforcment-but does the stuff really give much added strength if you cannot pre-tension it when you lay it up? I don't know-that's why I'm asking.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236309#236309 ________________________________________________________________________________
Date: Mar 26, 2009
Subject: Finding Flight
Group, I ________________________________________________________________________________
Date: Mar 26, 2009
Subject: Findng Flight
Group, After watching the Finding Flight DVD I bought at brodhead last year I can't wait fot July!- I got a little done on my Jungster tonight, afte r watching my 3 month old all day.- Any suggestions on how to get airplan e building done and watch a newborn at the same time?- He is OK in the sh op as long as it's warm, and I don't have the belt/disk sander blowing dust in to the air.- I figure I might has well start him young, hell who know s if his generation might be the last to be able to build there own airplan e.- Hopefully Jacob will learn to fly in the piet, then beg me to fly my Jungster or the Cassutt on his 16th B-day.- Any ways, I am looking forwar d to flying to Brodhead and Oshkosh this year for the 80th ann. of the Piet .- I hope to be able to join up with a few Ohio/ mid west piets enroute t o Brodhead and fly up togeather.- And by the way; Can someone tell me whe n the Winchester Indiana Hay Field fly in is?- I want to try to get the time off work to attend. - Anxious and ready to fly, Shad=0A=0A=0A ________________________________________________________________________________
Date: Mar 26, 2009
Subject: Re: Findng Flight
From: "Paul N. Peckham" <peckham9(at)countryspeed.com>
Date: Mar 26, 2009
Shad, I know the feeling of trying to find time to build. I don't have an answer, but I do have a story. When one of my boys was about 3, he was out in the shop with me, was getting a little tired, so he climbed up on the workbench and promptly fell asleep. Didn't get much done after that, but it was definitely one of those Kodak moments............ Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236332#236332 ________________________________________________________________________________
Date: Mar 27, 2009
Shad, I have three little ones. When I'm working on the Mustang II, I have often thought an extra "pack and play" would work. If you're not familiar with it, it is like a fold up crib, but with tall netted sides. That'll keep him captive, up away from dangerous tools, plus he's up off the dirty floor, and still give him a bit of room to move around. _Walmart.com: Graco, Pack 'n Play Playard, Tango in the Tongo: Gear_ (http://www.walmart.com/catalog/product.do?product_id=7964354) Boyce BTW it's easier when they're little than when they get to be 3 yrs old. My oldest will be 5 in July, and he's starting to get to the fun yrs again. Those 2's, and 3's were rough! ________________________________________________________________________________
Date: Mar 27, 2009
oh, also be thoughtful of the noises our power tools make. My 18 month old was crying the other day when I was using the drill. Funny the wife doesn't bother him with the vacuum, but the drill sure did! Boyce ________________________________________________________________________________
Date: Mar 27, 2009
The strength is derived from both resin and fibers. Think of it like steel bar reinforced concrete. Having the fibers in tension is not only unnecessary, but potentially weakening, as the resin will have to maintain the stretched fibers for the life of the part even when there are no flying loads. It is an interesting concept though and some scientific testing would be fun to do. :) If you get a chance read Zeke Smith's books on composite structures. The first few chapters cover how loads transfer in what intuitive looks like a weak structure. Hope that helps. Ameet --- On Thu, 3/26/09, skellytown flyer wrote: > From: skellytown flyer <rhano(at)att.net> > Subject: Pietenpol-List: Re: reinforcing for: cabane and jury struts > To: pietenpol-list(at)matronics.com > Date: Thursday, March 26, 2009, 8:49 PM > flyer" > > I am sure no expert on carbon fiber or any other method of > fabric re-inforcment-but does the stuff really give much > added strength if you cannot pre-tension it when you lay it > up? I don't know-that's why I'm asking.Raymond > ________________________________________________________________________________
Date: Mar 27, 2009
Ameet, if it is, as you say, like reinforced concrete, I would think putting the fibers in tension would be like prestressed reinforced concrete, in which steel is tensioned before pouring the concrete. The finished structure is stronger than just concrete poured over dormant re-bar. Of course, those are different materials than epoxy and carbon, so none of these logical parallels may hold. Moreover, I only have personal experience with plain old concrete and re-bar, so my opinion means little. Does your cited reference cover putting carbon fiber rods or the like in tension (either for or against)? Tim in central TX -----Original Message----- >From: Ameet Savant <ameetsavant(at)yahoo.com> >Sent: Mar 27, 2009 8:54 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: reinforcing for: cabane and jury struts > > >The strength is derived from both resin and fibers. Think of it like steel bar reinforced concrete. > ________________________________________________________________________________
Date: Mar 27, 2009
if its not the smoking kind then its hemp, which is the same plant and or family and fiber material that rope is made of. John **************Free Credit Report and Score Tracking! Get it Now for $0 at CreditReport.com. k) ________________________________________________________________________________
Date: Mar 27, 2009
Tim: Steel cables are prestressed in concrete due to the strength characteristic s of the base concrete material. Concrete is extremely strong in compression but relatively week in tension. Pre-stressing the steel causes the concrete to be held in compression in such a manner that the design bending loads will increase the compression on parts of the concrete structure while decreasing the compression on other parts but not to the point where any part of the concrete ceases to be in compression. Wood has different characteristics and is pretty strong in tension as well as compression. This is absorbed knowledge not "book larnin" so I am quite willing to stand corrected if I got this wrong. Tom Stinemetze McPherson, KS. >>>I would think putting the fibers in tension would be like prestressed reinforced concrete, in which steel is tensioned before pouring the concrete. ________________________________________________________________________________
Date: Mar 27, 2009
Tim, Good to hear from you. The composite books I have read don't ever mention putting the fibers in tension. They only insist on maintaining the fibers straight for obvious reasons. The concrete analogy is to exhibit the principle of a composite structure. concrete acts as a matrix that holds and transfers load to the re-bar making the composite stronger than both materials individually could be. the concrete may be very similar to resin, but the steel re-bar is certainly not like a fiber. The fiber alone has no strength in compression and the resin provides that compressive ability by holding the fibers straight under such a load. Like you say, there may not be direct parallels between the two composites. Ameet. --- On Fri, 3/27/09, Tim Willis wrote: > From: Tim Willis <timothywillis(at)earthlink.net> > Subject: Re: Pietenpol-List: Re: reinforcing for: cabane and jury struts > To: pietenpol-list(at)matronics.com > Date: Friday, March 27, 2009, 9:21 AM > > > Ameet, if it is, as you say, like reinforced concrete, I > would think putting the fibers in tension would be like > prestressed reinforced concrete, in which steel is tensioned > before pouring the concrete. The finished structure is > stronger than just concrete poured over dormant re-bar. Of > course, those are different materials than epoxy and carbon, > so none of these logical parallels may hold. Moreover, I > only have personal experience with plain old concrete and > re-bar, so my opinion means little. Does your cited > reference cover putting carbon fiber rods or the like in > tension (either for or against)? > Tim in central TX ________________________________________________________________________________
Date: Mar 27, 2009
now theres an idea; one of you guys out there just getting started could tr y building a concrete Piet.=0A=0A=0A=0A=0A________________________________ =0AFrom: TOM STINEMETZE <TOMS(at)mcpcity.com>=0ATo: pietenpol-list(at)matronics.c om=0ASent: Friday, March 27, 2009 10:41:27 AM=0ASubject: Re: Pietenpol-List : Re: reinforcing for: cabane and jury struts=0A=0A=0ATim:=0A-=0ASteel ca bles are prestressed in concrete due to the strength characteristics of the base concrete material.- Concrete is extremely strong in compression but relatively week in tension.- Pre-stressing the steel causes the concrete to be held in compression in such a manner that the design bending loads w ill increase the compression on parts of the concrete structure while decre asing the compression on other parts-but not to the point where any part of the concrete ceases to be in compression.- Wood has different characte ristics and is pretty strong in tension as well as compression.- =0AThis is absorbed knowledge not "book larnin" so I am quite willing to stand corr ected if I got this wrong.=0A-=0ATom Stinemetze=0AMcPherson, KS.=0A=0A>>> I would think putting the fibers in tension would be like prestressed reinf orced concrete, in which steel is tensioned before pouring the concrete.- =================== ________________________________________________________________________________
Date: Mar 27, 2009
I know we have strayed slightly off topic here but to set the record straig ht, some filters on cigarettes in the past have actually been made of fibre glass and it has caused damage in the lungs of those who smoked them.Now b ack to the Piet;it would be interesting to see one made out of hemp and fib re glass composite.Probably cost a fortune but it would be extremely strong and light weight.I just know some body is going to say why on earth would you build a plane such as the-Piet and the way it looks out of a modern c omposite.Usually these things are kept for the sleek and futuristic stuff s uff as the Ratan group puts out.-=0A=0A=0A=0A=0A_________________________ _______=0AFrom: Bill Church <eng(at)canadianrogers.com>=0ATo: pietenpol-list@m atronics.com=0ASent: Friday, March 27, 2009 12:22:09 PM=0ASubject: RE: Piet enpol-List: Re: reinforcing for: cabane and jury struts=0A=0A=0AActually, I don't anyone should be smoking any kind of fibreglass...=0A=0A=0A_________ _______________________=0AFrom: owner-pietenpol-list-server(at)matronics.com [ mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of H RULE=0ASen t: Friday, March 27, 2009 10:23 AM=0ATo: pietenpol-list(at)matronics.com=0ASub ject: Re: Pietenpol-List: Re: reinforcing for: cabane and jury struts=0A=0A =0Aone of the strongest composites is fibre glass and marijuana;they grow i t for this purpose;it's not the same stuff ya smoke though=0A=0Ado not arch ======================= ________________________________________________________________________________
Date: Mar 27, 2009
To set the record straight even further, hemp fibers used in rope, cloth, paper etc come from the same plant as Marijuana: Cannabis sativa . The difference comes from the cultivation. Good fiber comes from plants that are very low in THC concentrations and vice-versa. Near where I live, a company produces bamboo bicycles that are held together with hemp fiber and epoxy. High quality bamboo acts an awful lot like fiberglass and people swear by the bamboo bikes. The hemp, though, has to be imported from Canada because it's illegal to grow, even in California. Now, back to the subject at hand. The problem of composite materials is in the different ways the different materials react to stress. Because carbon fiber is MUCH stiffer than wood, putting the wood/carbon sandwich in tension loads the carbon fiber much quicker that it does the wood. What happens is that the carbon could be loaded to near failure before the wood begins to carry any load. In a Piet's cabane strut, not much load is ever carried during normal usage. The carbon fiber will carry virtually all the relatively light loads. The same would be true of a lift strut made from the same sandwich though the loading is much higher. If you make a wood/carbon sandwich structural member, design in enough carbon to carry all of the expected tension loads. The wood won't be doing much. Wood, by the way, is already a composite in the sense of being made from fibers in a matrix. The cellulose fibers are held together by a lignin glue. In fiberglass or carbon fiber composites the glass or the carbon is the fiber, held together in an epoxy or polyester or whatever matrix (even Elmer's, but not particularly well). Mike Hardaway ----- Original Message ----- From: "H RULE" <harvey.rule(at)rogers.com> Sent: Friday, March 27, 2009 10:08:03 AM GMT -08:00 US/Canada Pacific Subject: Re: Pietenpol-List: Re: reinforcing for: cabane and jury struts I know we have strayed slightly off topic here but to set the record straight, some filters on cigarettes in the past have actually been made of fibre glass and it has caused damage in the lungs of those who smoked them.Now back to the Piet;it would be interesting to see one made out of hemp and fibre glass composite.Probably cost a fortune but it would be extremely strong and light weight.I just know some body is going to say why on earth would you build a plane such as the Piet and the way it looks out of a modern composite.Usually these things are kept for the sleek and futuristic stuff suff as the Ratan group puts out. [snip for brevity] ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Date: Mar 27, 2009
I wana Bamboo bike!!!!! -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of bike.mike(at)comcast.net Sent: Friday, March 27, 2009 11:57 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: reinforcing for: cabane and jury struts To set the record straight even further, hemp fibers used in rope, cloth, paper etc come from the same plant as Marijuana: Cannabis sativa. The difference comes from the cultivation. Good fiber comes from plants that are very low in THC concentrations and vice-versa. Near where I live, a company produces bamboo bicycles that are held together with hemp fiber and epoxy. High quality bamboo acts an awful lot like fiberglass and people swear by the bamboo bikes. The hemp, though, has to be imported from Canada because it's illegal to grow, even in California. Now, back to the subject at hand. The problem of composite materials is in the different ways the different materials react to stress. Because carbon fiber is MUCH stiffer than wood, putting the wood/carbon sandwich in tension loads the carbon fiber much quicker that it does the wood. What happens is that the carbon could be loaded to near failure before the wood begins to carry any load. In a Piet's cabane strut, not much load is ever carried during normal usage. The carbon fiber will carry virtually all the relatively light loads. The same would be true of a lift strut made from the same sandwich though the loading is much higher. If you make a wood/carbon sandwich structural member, design in enough carbon to carry all of the expected tension loads. The wood won't be doing much. Wood, by the way, is already a composite in the sense of being made from fibers in a matrix. The cellulose fibers are held together by a lignin glue. In fiberglass or carbon fiber composites the glass or the carbon is the fiber, held together in an epoxy or polyester or whatever matrix (even Elmer's, but not particularly well). Mike Hardaway ----- Original Message ----- From: "H RULE" <harvey.rule(at)rogers.com> To: pietenpol-list(at)matronics.com Sent: Friday, March 27, 2009 10:08:03 AM GMT -08:00 US/Canada Pacific Subject: Re: Pietenpol-List: Re: reinforcing for: cabane and jury struts I know we have strayed slightly off topic here but to set the record straight, some filters on cigarettes in the past have actually been made of fibre glass and it has caused damage in the lungs of those who smoked them.Now back to the Piet;it would be interesting to see one made out of hemp and fibre glass composite.Probably cost a fortune but it would be extremely strong and light weight.I just know some body is going to say why on earth would you build a plane such as the Piet and the way it looks out of a modern composite.Usually these things are kept for the sleek and futuristic stuff suff as the Ratan group puts out. ------------------------------------------------------------------------- ----- [snip for brevity] ________________________________________________________________________________
Date: Mar 27, 2009
IMHO that is slightly inaccurate. In a composite structure, due to the differing stiffness the load will be carried proportional to the moduli. Because carbon has a very high modulus it will carry a larger portion of the load. But the wood does carry some. My statement is a bit oversimplified. It ignores the amount of carbon and wood used in the said composite. If I use a very small amount of carbon in the strut it will get overloaded and my wooden strut will have to carry all the load. Which if I happily reduced in size because I added "some" carbon, will also fail. :) Isn't design fun?! Regards. Ameet --- On Fri, 3/27/09, bike.mike(at)comcast.net wrote: > From: bike.mike(at)comcast.net <bike.mike(at)comcast.net> > Subject: Re: Pietenpol-List: Re: reinforcing for: cabane and jury struts > To: pietenpol-list(at)matronics.com > Date: Friday, March 27, 2009, 1:56 PM ... > The problem of composite > materials is in the different ways the different materials > react to stress. Because carbon fiber is MUCH stiffer than > wood, putting the wood/carbon sandwich in tension loads the > carbon fiber much quicker that it does the wood. What > happens is that the carbon could be loaded to near failure > before the wood begins to carry any load. ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Mar 27, 2009
Subject: what is Harvy smoking?
Harvey, I'm glad you're on the list, you make me smile from time to time with your posts. Do we need to send a few buckets of warm water up there to Canada to thaw you out or will you be okay with warming of days ? Mike Cuy in Ohio PS: Only smoking Texaco Canopus Oil No. 13 thru my A-65 exhaust stacks. ________________________________________________________________________________
Date: Mar 27, 2009
Subject: Re: what is Harvy smoking?
Thank God it's starting to warm up in cold Canada;can't wait to pull the GN -1 Aircamper out and go for a toot.Couple of buckets of beer wouldn't be a bad thought though!I don't smoke anymore but when I did I enjoyed it especi ally the wacky tabaky!Glad you like the posts.This is a great list,best of them all!Your a great bunch of people,the best!=0A=0Ayou can archive that! =0A=0A=0A=0A=0A________________________________=0AFrom: "Cuy, Michael D. (G RC-RXD0)[ASRC Aerospace Corporation]" =0ATo: "piete npol-list(at)matronics.com" =0ASent: Friday, Mar ch 27, 2009 3:58:20 PM=0ASubject: Pietenpol-List: what is Harvy smoking?=0A =0A=0A-=0AHarvey, =0A-=0AI'm glad you're on the list, you make me smile from time to time with your posts.--- Do we need to send a few bucke ts of warm water up there to Canada=0Ato thaw you out or will you be okay w ith warming of days ?----- =0A-=0AMike Cuy in Ohio=0A-=0APS: Only smoking Texaco Canopus Oil No. 13 thru my A-65 exhaust stacks.-- ===================== ________________________________________________________________________________
Date: Mar 27, 2009
Boyce, Yes the pack and play is set up in the shop, untill my wife notices it's missing and covered in sawdust.- I just try to make sure I am at the gluing stepswhen he is out there, that way the dust and noise is at a mini mum. - Shad=0A=0A=0A ________________________________________________________________________________
Subject: annual inspections
Date: Mar 27, 2009
Mike Cuy and all, Question,,,,,,,,,,,,,,I originally licenced my Piet in November. I always did my inspection in Nov. and logged the same. Last Nov. time got away from me, and didn't do it, or fly it since then. If I inspect it tomorrow,,,do I date it now or last Nov? Does the inspection have to match the licencing? Or will this be my "new" year to start? Thanks all. PS Can't wait to fly this weekend and check out the old valley. walt evans NX140DL ________________________________________________________________________________
Subject: Re: annual inspections
Date: Mar 27, 2009
Walt, You will now be on a March to March cycle. Annual condition inspections run on a 12 calendar month basis. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2810 Crossroads Drive, Ste 3800 Madison, WI 53718 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Mar 27, 2009, at 5:22 PM, walt wrote: > Mike Cuy and all, > Question,,,,,,,,,,,,,,I originally licenced my Piet in November. > I always did my inspection in Nov. and logged the same. > Last Nov. time got away from me, and didn't do it, or fly it since > then. > > If I inspect it tomorrow,,,do I date it now or last Nov? > Does the inspection have to match the licencing? > Or will this be my "new" year to start? > Thanks all. > PS Can't wait to fly this weekend and check out the old valley. > walt evans > NX140DL > > ________________________________________________________________________________
Date: Mar 27, 2009
My 8 year old loves to come down to the shop and help me or "build stuff, dad". I took a bunch of small 1x1 and 1x2s of various lengths, drilled holes through them at different locations, and gave him a bunch of bolts/nuts. He loves to bolt them together and make different shapes. I broke down for Christmas and bought him his own wrench set and tool box. He now keeps all his real and plastic tools in it. I also bought him his own flashlight and tape measure (got tired of mine going missing). He really has a blast. I also put up an electronic dart board. Him and his older brother will play darts down there while I"m working also. Lorin -------- Lorin Miller Waiex N81YX Pietenpol next up Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236461#236461 ________________________________________________________________________________
Subject: Re: Straight Axle gear
Date: Mar 27, 2009
I've been away for a week so I'm labouriously going through tons of email. Here's the link to my web pages for landing gear legs. It starts with a comprehensive, 2X4 jig and goes from there. http://clifdawson.ca/Pietenpol3.html I have a lot more stuff to put up but I'm having trouble uploading it and also getting ahold of the tech support. Clif Subject: Re: Pietenpol-List: Straight Axle gear Thank you all for your comments on the gear. I made up some material to make practice legs from and I'll get started on that soon. e flying. Thanks. Mike Groah > ________________________________________________________________________________
Subject: wood vs metal strut weights
Date: Mar 28, 2009
In the occassional discussion re wooden struts, I often read the comment that wood struts weigh more. While this certainly may be true, I wonder if this is based upon actual weights or educated guessing? So... I am going to weigh my wood struts and would apprciate it if anybody out there could tell me what their steel struts weigh. Was hoping somebody has those numbers somewhere, or maybe has their struts handy along with a convnient scale. Douwe ________________________________________________________________________________
Date: Mar 28, 2009
Douwe, I recall speaking with Paul Poulin, who flew his Air Camper, Canadian Goose C-GZHT to Brodhead two summers ago. His lift struts, cabane struts and jury struts were all made of solid laminated white ash. He said that he weighed his wood lift struts, and then weighed some steel struts (off a Piper, I think) and found his wood struts to be slightly lighter. Of course, the weight of wood struts would depend on the species of wood, and the profile of the strut, and the weight of the steel struts would depend on the profile of the streamline material, as well as the wall thickness. Bill C. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com on behalf of Douwe Blumberg Sent: Sat 28/03/2009 10:19 AM Subject: Pietenpol-List: wood vs metal strut weights In the occassional discussion re wooden struts, I often read the comment that wood struts weigh more. While this certainly may be true, I wonder if this is based upon actual weights or educated guessing? So... I am going to weigh my wood struts and would apprciate it if anybody out there could tell me what their steel struts weigh. Was hoping somebody has those numbers somewhere, or maybe has their struts handy along with a convnient scale. Douwe ________________________________________________________________________________
Subject: Re: wood vs metal strut weights
Date: Mar 28, 2009
Wood versus steel...I expect the wood to be lighter. For reference, my aluminum 6061T6 lift struts (about 1" X 2.44") weigh a bit over 4 pounds each. After reading all these great messages about sandwiching carbon fiber (or equiv.) in a lamination....I'm now wishing I had made mine from wood..... But I've rebuilt just about every part of this project at least once so the struts...they stay the way they are right now! Jim in rainy wet Pryor OK ----- Original Message ----- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> Sent: Saturday, March 28, 2009 9:19 AM Subject: Pietenpol-List: wood vs metal strut weights > > > In the occassional discussion re wooden struts, I often read the comment > that wood struts weigh more. While this certainly may be true, I wonder > if > this is based upon actual weights or educated guessing? > > So... > > I am going to weigh my wood struts and would apprciate it if anybody out > there could tell me what their steel struts weigh. Was hoping somebody > has > those numbers somewhere, or maybe has their struts handy along with a > convnient scale. > > Douwe > > > ________________________________________________________________________________
Subject: Straight axle gear
Date: Mar 28, 2009
Clif wrote- >I'm having trouble > uploading it and also getting ahold of the tech support. In the Piet world=2C "tech support" consists of those wide elastic suspende rs. Mine are black=2C but yours can be whatever color you like. Just like in my Piet world the "cockpit data recorder" is a kneeboard and p encil. It's no use trying to record voice data in a Piet because it all ge ts blown out of the cockpit by the mighty A65. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: black ash instead of white ash
Date: Mar 28, 2009
I've found a source of black ash for $1.00/BF and wondered if it's a good s ubstitute for white ash. What I read is that it's slightly softer and ligh ter. I plan on making ash flying struts and landing gear. Any thoughts or experience with black ash? Tom B. ________________________________________________________________________________
Subject: Re: black ash instead of white ash
Date: Mar 28, 2009
Tom I have been flying with LG struts of laminated Douglas Fir for 5 years without problems. I know others that have used Sitka to make gear legs. You are probably fine. Come up to Osceola some day for a ride. Dick N. ----- Original Message ----- From: TOM MICHELLE BRANT To: pietenpol-list(at)matronics.com Sent: Saturday, March 28, 2009 11:10 AM Subject: Pietenpol-List: black ash instead of white ash I've found a source of black ash for $1.00/BF and wondered if it's a good substitute for white ash. What I read is that it's slightly softer and lighter. I plan on making ash flying struts and landing gear. Any thoughts or experience with black ash? Tom B. ________________________________________________________________________________
Subject: Riblett Airfoil
Date: Mar 28, 2009
Gents: Does anyone have Roman Bukolt's email address? I purchased the Riblett airfoil drawing from Roman a few years ago. I'm just now setting up a jig to start building my ribs. I'm a little unsure on a couple of points on building these ribs, and I need a little help. Thanks Fellows, Al Lyscars Manchester, NH ________________________________________________________________________________
Date: Mar 28, 2009
Subject: Re: Riblett Airfoil
Roman is at: conceptmodels(at)tds.net Would you want to elaborate on the points you are unsure of? Ryan On Sat, Mar 28, 2009 at 12:04 PM, ALAN LYSCARS wrote: > Gents: > > Does anyone have Roman Bukolt's email address? > > I purchased the Riblett airfoil drawing from Roman a few years ago. I'm > just now setting up a jig to start building my ribs. I'm a little unsure on > a couple of points on building these ribs, and I need a little help. > > Thanks Fellows, > > Al Lyscars > Manchester, NH > ________________________________________________________________________________
Date: Mar 28, 2009
Hi Ryan, I've got a set of Grega GN-1 plans which I'm going to build from, and I bought Roman's template a few years ago. - My GA30-612 Riblett drawing doesn't list much detail. For example, there are no notes concerning the number of ribs to build. Should I rely on my Grega drawings for this info? - The Grega plans specify compression members in at least two of the ribs; are there any compression members in the Riblett? - I am very unsure as to how to construct the trailing edge spar sections as far as the aileron sections go. Am I missing a "notes page" which may have been part of Roman's submittal? I've moved between then and now..anything's possible! Ryan, thanks for offering to help. Al Lyscars ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Saturday, March 28, 2009 3:15 PM Subject: Re: Pietenpol-List: Riblett Airfoil Roman is at: conceptmodels(at)tds.net Would you want to elaborate on the points you are unsure of? Ryan ________________________________________________________________________________
Date: Mar 28, 2009
Al, I don't have Roman's Riblett print; we purchased ours from Bill Rewey, but I believe they have essentially the same information (if not, someone with Roman's print can chime in, hopefully). With that being said, here are thoughts regarding a few of your questions: Switching to the Riblett changes the shape of the rib you are building, but it should not affect the amount of ribs you build. Defer to your Grega plans for the number; if your plans show 29 (for example), then build 29. If the Grega plan shows two ribs with compression members, then I would say build two Riblett ribs with compression members and install in the appropriate location. As far as compression members go, I believe our print from Bill shows the compression members as dashed line verticals in the print. If your print has those dashed line vertical members then that would be where you would locate those pieces. As far the the aileron section spars, I can't speak to that regarding the Grega, as I have not seen GN-1 plans. Is it that you are having trouble reconciling that part of Grega design with the Riblett rib, or that you are having trouble with the Grega design in and of itself? Time for dinner! Ryan On Sat, Mar 28, 2009 at 2:49 PM, ALAN LYSCARS wrote: > Hi Ryan, > > I've got a set of Grega GN-1 plans which I'm going to build from, and I > bought Roman's template a few years ago. > > - My GA30-612 Riblett drawing doesn't list much detail. For example, > there are no notes concerning the number of ribs to build. Should I rely on > my Grega drawings for this info? > > - The Grega plans specify compression members in at least two of the > ribs; are there any compression members in the Riblett? > > - I am very unsure as to how to construct the trailing edge spar sections > as far as the aileron sections go. Am I missing a "notes page" which may > have been part of Roman's submittal? I've moved between then and > now..anything's possible! > > Ryan, thanks for offering to help. > > Al Lyscars > > > ----- Original Message ----- > *From:* Ryan Mueller > *To:* pietenpol-list(at)matronics.com > *Sent:* Saturday, March 28, 2009 3:15 PM > *Subject:* Re: Pietenpol-List: Riblett Airfoil > > Roman is at: conceptmodels(at)tds.net > > Would you want to elaborate on the points you are unsure of? > > Ryan > > * > > > * > > ________________________________________________________________________________
Date: Mar 28, 2009
Black ash is what I get when I burn my wet fire wood.- Usually small piec es of spruce scrap turn to white ash, as long as there is no dried glue on them.- - Ha Ha Ha, Just kidding now don't stone me, Shad=0A=0A=0A ________________________________________________________________________________
Date: Mar 28, 2009
Subject: Re: Free Waldo Peppers Again!
Tim I would gladly send you at least postage costs for a DVD. Thanks Rick Holland 3732 Castle Butte Dr Castle Rock, CO 80109 On Wed, Mar 18, 2009 at 4:15 PM, Tim Verthein wrote: > minoxphotographer(at)yahoo.com> > > > Hey Gang- > > Last year I sent out several dozen free home made Waldo Pepper DVD's to > anyone who wanted one. Many sent me something in return - not necessary but > always welcome. > > Once again, if anyone wants one, contact me off list and I'll get one to > you. The "used and new" on Amazon starting at $15 are for VHS tapes, their > DVD's are starting at $49 (at least today, it varies daily). Note they also > have soundtrack recordings, paperback books and related items. > > My copies are from my original (old) VHS tape, not the finest remastered > digital quality, but certainly watchable, and free. > > I just like to share a good movie. > > Tim in Bovey > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Subject: wood strut weights
Date: Mar 29, 2009
I weighed my struts, with the steel end strap fittings and the bracing cables with associated hardware, including bolts. They weigh in a bit under 6 lbs each ( 5 lbs 12 oz). Someone gave an aprox weight for aluminum struts at just over 4 lbs. Havn't heard any weights yet for steel struts, but I'm guessing it won't be less than the wood, though it might not be much more. The strap fittings on each end are fairly substantial and undoubtedly add a lot of weight, whereas they can be integral and much simpler when using a steel strut. Douwe ________________________________________________________________________________
Subject: fueling center section tank
Date: Mar 29, 2009
For those using a center section tank, what is your technique for getting up there without using a ladder? Never really paid attention to this before, but I'm now wondering if there should be a step somewhere or can you use the tire/strut etc ??? Thanks Douwe ________________________________________________________________________________
Subject: Re: fueling center section tank
Date: Mar 29, 2009
Douwe, I have been faced with this dilemma and will probably try to add some kind of permanent "refuling step"? made from aluminum streamline tubing. It will have to stick-out of the fuze at the approximate height of the top longeron. Otherwise it is near impossible to refuel without a ladder, especially because my filler neck is located at the thickest part of the tank, close to the center. It is hard to reach back there, and especially hard to see what you are doing. Dan Helsper Poplar Grove, IL NX929DH -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Sun, 29 Mar 2009 3:06 am Subject: Pietenpol-List: fueling center section tank For those using a center section tank, what is your technique for getting up there without using a ladder? Never really paid attention to this before, but I'm now wondering if there should be a step somewhere or can you use the tire/strut etc ??? Thanks Douwe ________________________________________________________________________________
Date: Mar 29, 2009
The fuel tank filler neck on NX18235's center section tank is offset to the left for ease of fueling. Standing on the tire puts me at a height that allows me to easily place the fuel nozzle into the neck but not high enough to be able to see into the tank. A step built into the fuselage would have been a great help. Greg Cardinal ----- Original Message ----- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> Sent: Sunday, March 29, 2009 3:06 AM Subject: Pietenpol-List: fueling center section tank > > > For those using a center section tank, what is your technique for getting > up > there without using a ladder? > > Never really paid attention to this before, but I'm now wondering if there > should be a step somewhere or can you use the tire/strut etc > > ??? > > Thanks > > Douwe > > > ________________________________________________________________________________
Date: Mar 29, 2009
After reading Tim Verthein's offer for a copy of Waldo Pepper I thought I'd see if my original DVD copy would transfer as well. It did copy and I'll make the same offer that Tim did. The copy will be on a DVD-R formated disc. This should play on 90% of the DVD players currently on the market. I have found that low quality players may not successfully play some DVD-R discs. If you have a higher end DVD player, you should be fine. These copies are crisp and clear. You won't be able to tell the difference from an original DVD. Each will feature full screen, Dolby Digital sound, captioned, and with Spanish and French subtitles, Region 1, scene index and features. I'm asking $2.00 a copy to cover the cost of the disc, sleeve and postage. I was at one time able to mail discs through the mail for the cost of a stamp, but the USPS now adds a $.20 surcharge for DVD's because they have to hand cancel each envelope. Contact me off list at franck(at)geneseo.net if you are interested. Put "Waldo" in the subject line and include your name and mailing address. I'll mail out the movie, you watch it and if you're satisfied, then you mail me the funds. Such a deal, huh? Ron ________________________________________________________________________________
Subject: Hand propping a 65
Date: Mar 29, 2009
In reading what's new on the fishnet group about hand propping a 65. it was discussed about an add-on starter built from a battery drill. Anyone hear of any/all tips. PS I just want to touch a button. :^) walt evans NX140DL ________________________________________________________________________________
Date: Mar 29, 2009
Subject: Re: Hand propping a 65
Walt, Look in the the Feb, or March Sport Aviation Magizine, there is a who le artical on it. - Shad --- On Sun, 3/29/09, walt wrote: From: walt <waltdak(at)verizon.net> Subject: Pietenpol-List: Hand propping a 65 Date: Sunday, March 29, 2009, 10:49 AM In reading what's new on the fishnet group about hand propping a 65. it was discussed about an add-on starter-built from a battery drill. Anyone hear of any/all tips. - PS I just want to touch a button.-- :^) - - walt evans NX140DL - - =0A=0A=0A ________________________________________________________________________________
Date: Mar 29, 2009
Douwe, Our filler neck is back a little to far to be at an easy reach.- I have soaked my-canvas helmet-and my jacket 2 dozzen times from over ru nning the tank.- It runs right into the rear cockpit.- On a positive no te we only burn 100LL so it evaporates and doesn't leave that terrible auto gas smell in the clothes or seat cussion.- Put it as far forward as prac tcal, and watch out filling it on a hot summer day, when you spend 5 min tr ying to find the line boy to pay for your gas, you will come back to an ove r flowing vented fuel cap, and a wet seat. - Shad =0A=0A=0A ________________________________________________________________________________
Date: Mar 29, 2009
April 2009 Sport Aviation has a small article on two options you could buy. Very pricey! Here are the details: Harold Hamp: 7350 Osborn Rd Elwell, MI 48832 989-463-1762 The other is an Alan Eke System which was detailed in Aug 2006 issue. Regards, Ameet --- On Sun, 3/29/09, walt wrote: > From: walt <waltdak(at)verizon.net> > Subject: Pietenpol-List: Hand propping a 65 > To: Fishnet(at)topica.com, pietenpol-list(at)matronics.com > Date: Sunday, March 29, 2009, 9:49 AM > In reading what's new on the fishnet group about hand > propping a 65. it was discussed about an add-on starter > built from a battery drill. > Anyone hear of any/all tips. > > PS I just want to touch a button. :^) > > > walt evans > NX140DL ________________________________________________________________________________
Date: Mar 29, 2009
From: "conceptmodels tds.net" <conceptmodels(at)tds.net>
Al,My email address is: conceptmodels(at)tds.net Also Bill Rewey is more knowledgable than I, about the Riblett airfoil. He doesn't do email but can be reached at 608-833.5839 On Sat, Mar 28, 2009 at 12:04 PM, ALAN LYSCARS wrote: > Gents: > > Does anyone have Roman Bukolt's email address? > > I purchased the Riblett airfoil drawing from Roman a few years ago. I'm > just now setting up a jig to start building my ribs. I'm a little unsure on > a couple of points on building these ribs, and I need a little help. > > Thanks Fellows, > > Al Lyscars > Manchester, NH > > * > > ________________________________________________________________________________
Date: Mar 29, 2009
Subject: Landing gear tubing size
The split axle gear that came with our project is not good to go, unfortunately. We were scrutinizing the plans yesterday afternoon in preparation for ordering tubing to fabricate new gear vees. The tubing thickness called for is 14 gauge, which translates to .0785". The 4130 from ACS, Wicks, Airparts, etc comes in either .065 or .095. What is the consensus on the tubing thickness used? Ryan ________________________________________________________________________________
Date: Mar 29, 2009
I welded a couple of steps onto my left gear, copied the idea from a Piet at Broadhead. The rear one to help people get in the front cockpit and the front one (which is horizontal with the fuse down on the tailwheel) to get to the top of the CC. Of course this won't work too well with wooden gear. Rick On Sun, Mar 29, 2009 at 2:06 AM, Douwe Blumberg wrote: > douweblumberg(at)earthlink.net> > > For those using a center section tank, what is your technique for getting > up > there without using a ladder? > > Never really paid attention to this before, but I'm now wondering if there > should be a step somewhere or can you use the tire/strut etc > > ??? > > Thanks > > Douwe > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Mar 29, 2009
Sail boaters use folding mast steps that would work well. Gene ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Sunday, March 29, 2009 12:15 PM Subject: Re: Pietenpol-List: fueling center section tank I welded a couple of steps onto my left gear, copied the idea from a Piet at Broadhead. The rear one to help people get in the front cockpit and the front one (which is horizontal with the fuse down on the tailwheel) to get to the top of the CC. Of course this won't work too well with wooden gear. Rick On Sun, Mar 29, 2009 at 2:06 AM, Douwe Blumberg wrote: For those using a center section tank, what is your technique for getting up there without using a ladder? Never really paid attention to this before, but I'm now wondering if there should be a step somewhere or can you use the tire/strut etc ??? Thanks Douwe ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- Rick Holland Castle Rock, Colorado ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/28/09 07:16:00 ________________________________________________________________________________
Date: Mar 29, 2009
The latest Sport Aviation or perhaps Sport Pilot has an article about the guy who did this and will do it for others. I talked to him and all he wants is~$1800 to do one for your plane--Jim Lagowski ----- Original Message ----- From: walt To: Fishnet(at)topica.com ; pietenpol-list(at)matronics.com Sent: Sunday, March 29, 2009 10:49 AM Subject: Pietenpol-List: Hand propping a 65 In reading what's new on the fishnet group about hand propping a 65. it was discussed about an add-on starter built from a battery drill. Anyone hear of any/all tips. PS I just want to touch a button. :^) walt evans NX140DL ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/28/09 07:16:00 ________________________________________________________________________________
Subject: Re: Landing gear tubing size
Date: Mar 29, 2009
Did you look at the Pietenpol plans? walt evans NX140DL ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Sunday, March 29, 2009 12:54 PM Subject: Pietenpol-List: Landing gear tubing size The split axle gear that came with our project is not good to go, unfortunately. We were scrutinizing the plans yesterday afternoon in preparation for ordering tubing to fabricate new gear vees. The tubing thickness called for is 14 gauge, which translates to .0785". The 4130 from ACS, Wicks, Airparts, etc comes in either .065 or .095. What is the consensus on the tubing thickness used? Ryan ________________________________________________________________________________
Date: Mar 29, 2009
Yes, hence I said the plans called for 14 gauge tubing. 1 3/8" diameter 14 gauge 1020 tubing, to be specific. I was looking at the 4130 sizes in the Wicks, ACS, and Airparts catalogs because they do not have 1020 in the OD needed (two don't even carry 1020). Is this a "substitute with a particular size of 4130 tubing" situation, or a "call Dillsburg Aero because no one else on the face of the earth carries 1 3/8" 14 gauge (.078) 1020 tubing anymore"? Ryan On Sun, Mar 29, 2009 at 4:14 PM, walt wrote: > Did you look at the Pietenpol plans? > walt evans > NX140DL > > > ----- Original Message ----- > *From:* Ryan Mueller > *To:* pietenpol-list(at)matronics.com > *Sent:* Sunday, March 29, 2009 12:54 PM > *Subject:* Pietenpol-List: Landing gear tubing size > > The split axle gear that came with our project is not good to go, > unfortunately. We were scrutinizing the plans yesterday afternoon in > preparation for ordering tubing to fabricate new gear vees. The tubing > thickness called for is 14 gauge, which translates to .0785". The 4130 from > ACS, Wicks, Airparts, etc comes in either .065 or .095. What is the > consensus on the tubing thickness used? > > Ryan > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Subject: elongating holes
Date: Mar 29, 2009
Is it acceptable to elongate or oversize holes in order for some things to line up? I'm putting the hinges on the elevators and one of them isn't mat ching up quite right. I could either elongate /oversize the holes a bit or plug them and re-drill. This also came up when I attached the horiz. stab with the little metal brackets - didn't quite line up perfectly. Guess I' m not drilling straight or something. Tom B. ________________________________________________________________________________
Subject: 41CC flight today
Date: Mar 29, 2009
I took 41CC up this afternoon for the first time in two months. It's been wayyyy too long but I had some squawks to take care of after the annual con dition inspection and then we had some medical issues in the family that ha ve been taking lots of my time. But today was the day and all the "essenti al to safety of flight" squawks were taken care of and it was time to go up . I'll wait and change the pop rivets on the fuel valve handle another tim e=2C and I'll live with the tach cable the way it is for awhile too. We had a stiff and gusty south breeze=2C pretty much straight down the runw ay=2C and the airplane jumped right off the ground. Everything worked pret ty as you please=2C I did three very nice landings on the grass=2C and am v ery happy with the smoothness and harmony of the controls. I rerigged all the tail surfaces since I had decided to pull the turnbuckles off and insta ll some missing washers=2C proper cotter pins=2C and change out some mismat ched hardware here and there. I also found a discarded shoe on the side of the road on the way to the airport and I pinked out two leather rub patche s and glued them to the leading edge of the horizontal stabilizer where the elevator cables touch. Voila=3B no more wear spots. The Piet is such an enjoyable airplane to fly and to work on. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: elongating holes
Date: Mar 29, 2009
I would plug and re-drill Chris Sacramento, CA WestCoastPiet.com ----- Original Message ----- From: TOM MICHELLE BRANT To: pietenpol-list(at)matronics.com Sent: Sunday, March 29, 2009 5:29 PM Subject: Pietenpol-List: elongating holes Is it acceptable to elongate or oversize holes in order for some things to line up? I'm putting the hinges on the elevators and one of them isn't matching up quite right. I could either elongate /oversize the holes a bit or plug them and re-drill. This also came up when I attached the horiz. stab with the little metal brackets - didn't quite line up perfectly. Guess I'm not drilling straight or something. Tom B. ________________________________________________________________________________
Date: Mar 29, 2009
Ryan, 14 ga. tubing is .083 and is available from Dillsburg. Greg Cardinal ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Sunday, March 29, 2009 5:28 PM Subject: Re: Pietenpol-List: Landing gear tubing size Yes, hence I said the plans called for 14 gauge tubing. 1 3/8" diameter 14 gauge 1020 tubing, to be specific. I was looking at the 4130 sizes in the Wicks, ACS, and Airparts catalogs because they do not have 1020 in the OD needed (two don't even carry 1020). Is this a "substitute with a particular size of 4130 tubing" situation, or a "call Dillsburg Aero because no one else on the face of the earth carries 1 3/8" 14 gauge (.078) 1020 tubing anymore"? Ryan On Sun, Mar 29, 2009 at 4:14 PM, walt wrote: Did you look at the Pietenpol plans? walt evans NX140DL ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Sunday, March 29, 2009 12:54 PM Subject: Pietenpol-List: Landing gear tubing size The split axle gear that came with our project is not good to go, unfortunately. We were scrutinizing the plans yesterday afternoon in preparation for ordering tubing to fabricate new gear vees. The tubing thickness called for is 14 gauge, which translates to .0785". The 4130 from ACS, Wicks, Airparts, etc comes in either .065 or .095. What is the consensus on the tubing thickness used? Ryan href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List a>http://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 29, 2009
Propping the engine is something I have mixed feelings about. On one hand =2C I like the utter simplicity of having no electrics=2C no starter=2C no gadgets and no messing about. On the other hand=2C I worry about the engin e stopping sometime with only moments to spare for a retry in flight=2C and not being able to give it another try at starting by just punching a butto n or pulling a handle. It's not really something I should worry about... they always say the main thing to do when the engine quits is to fly the airplane and not worry with gadgets that might distract. I have found my airplane to be extremely sim ple and fuss-free=2C easy and quick to start now that I know the drill=2C a nd not at all difficult to prop. I also think it adds an aura of "old time -ness" to the whole flight when it begins with a hand-prop. It's how I lea rned to fly and it always works. On the other hand=2C there is a lot to be said for being in the cockpit=2C strapped in=2C brakes set=2C and in control of everything when the engine i s lit. There is no doubt that electric (or other automatic) starters have something to be said for them. For now=2C though=2C I'm starter-free and h appy with that. I sure wouldn't pay $1800 for a starter unless I lost the physical ability to prop my airplane=2C and then I might be out of luck fly ing entirely. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 29, 2009
This is a problem I have not had to solve, thank goodness. I have a picture somewhere of a fellow using a short plywood scaffold board to refuel his Piet's center wing tank. As you likely know, any proper "scaffold board" has boards on the underside, at each end of the main plank, at the overhangs, so the board cannot slide off each end. In this case the plank is sited across the upper longerons at the rear of the pilot's seat. The pilot can then stand very high and see everything while filling the upper tank. That would work very well at the home hangar, esp. on Piets without upholstery there. However, where would you carry the board for trips? You don't want it underfoot in the cockpits, and you don't want it behind the pilot for CG reasons. And of course, wherever it might go, it has to be firmly affixed in its storage agea, and well away from cables, bellcranks, etc., for in-flight safety. Tim in central TX -----Original Message----- >From: gcardinal <gcardinal(at)comcast.net> >Sent: Mar 29, 2009 5:58 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: fueling center section tank > > >The fuel tank filler neck on NX18235's center section tank is offset to the >left for ease of fueling. >Standing on the tire puts me at a height that allows me to easily place the >fuel nozzle into the neck but not high enough to be able to see into the >tank. A step built into the fuselage would have been a great help. >Greg Cardinal ________________________________________________________________________________
Date: Mar 29, 2009
Well, that's what I get for not doing things myself. :P There were three people gathered around the Machinery Handbook, whilst I checked the gauge listed on the plans. I should have verified that they were looking at the correct chart (three relatively experienced people, one who is a metalworker). Hmm, I'll have to check myself :P Thanks Greg. Ryan On Sun, Mar 29, 2009 at 9:14 PM, gcardinal wrote: > *Ryan,* > ** > *14 ga. tubing is .083 and is available from Dillsburg.* > ** > *Greg Cardinal* > > ----- Original Message ----- > *From:* Ryan Mueller > *To:* pietenpol-list(at)matronics.com > *Sent:* Sunday, March 29, 2009 5:28 PM > *Subject:* Re: Pietenpol-List: Landing gear tubing size > > Yes, hence I said the plans called for 14 gauge tubing. 1 3/8" diameter 14 > gauge 1020 tubing, to be specific. I was looking at the 4130 sizes in the > Wicks, ACS, and Airparts catalogs because they do not have 1020 in the OD > needed (two don't even carry 1020). > > Is this a "substitute with a particular size of 4130 tubing" situation, or > a "call Dillsburg Aero because no one else on the face of the earth carries > 1 3/8" 14 gauge (.078) 1020 tubing anymore"? > > Ryan > > On Sun, Mar 29, 2009 at 4:14 PM, walt wrote: > >> Did you look at the Pietenpol plans? >> walt evans >> NX140DL >> >> >> >> ----- Original Message ----- >> *From:* Ryan Mueller >> *To:* pietenpol-list(at)matronics.com >> *Sent:* Sunday, March 29, 2009 12:54 PM >> *Subject:* Pietenpol-List: Landing gear tubing size >> >> The split axle gear that came with our project is not good to go, >> unfortunately. We were scrutinizing the plans yesterday afternoon in >> preparation for ordering tubing to fabricate new gear vees. The tubing >> thickness called for is 14 gauge, which translates to .0785". The 4130 from >> ACS, Wicks, Airparts, etc comes in either .065 or .095. What is the >> consensus on the tubing thickness used? >> >> Ryan >> >> * >> >> href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c* >> >> * >> >> " target="_blank"> <http://www.matronics.com/Navigator?Pietenpol-List>http://www.matronics.com/Navigator?Pietenpol-List >> a> <http://forums.matronics.com>http://forums.matronics.com >> _blank"> <http://www.matronics.com/contribution>http://www.matronics.com/contribution >> * >> >> > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Mar 30, 2009
I stuffed up a couple of holes and filled them with T88 and re drilled. I think it will be ok the rest of the Piet is held together with it. Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236822#236822 ________________________________________________________________________________
Date: Mar 30, 2009
Tom, I also had trouble with those plans-built hinges to line up. I had to do a lot of fudging like you propose. Somebody has to have figured out a way to line-up all those things. Maybe you could put a rod all the way through all three hinges before marking for the holes in the wood? That sounds easy but in reality? A slight bit of elongation will not hurt in my opinion. This is what I did. Dan Helsper Poplar Grove, IL NX929DH ________________________________________________________________________________
Subject: Re: Jim Lagowski Pietenpol completion in April Sport Pilot
From: "Glenn Thomas" <glennthomas(at)flyingwood.com>
Date: Mar 30, 2009
Yes, that's a pretty paint scheme and the wood color looks fantastic with the paint colors. Cowling is nice too. Is that a Fly Baby landing gear setup? Looks like it would be a bit lighter than Jenny gear. -------- Glenn Thomas N????? http://www.flyingwood.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236829#236829 Attachments: http://forums.matronics.com//files/jimlagowskipiet_919.jpg ________________________________________________________________________________
Date: Mar 30, 2009
Mixing sawdust or fiberglass flox with t-88 would probably work well, I have to fill one on my project as well. Shad ________________________________________________________________________________
Date: Mar 30, 2009
Al, I am using the 3 piece wing plan for the Pietenpol with the Riblett 612 ribs. What you must do is build the ribs per the Riblett full scale drawin g and modify/include what you need to do match the print of the wing. (rega rdless of the type of plane/wing)- Our Pietenpol wings use compression st ruts at the drag cable attach points on the spars. These are separate from the ribs. Our ribs do not include any kind of built in compression struts. (if I am reading you question correctly.) There are extra braces that are b uilt into a few ribs for the ends of the wings and those are also shown on the Riblett plan.- My 3 piece Pietenpol wing will use a total of 31 ribs. ________________________________________________________________________________
Date: Mar 30, 2009
Subject: some gorgeous photos of a Ford Pietenpol flying in California
go here: http://forum.planetalk.net/viewtopic.php?t=7708 Serial Number 1 Type Registration Individual Manufacturer Name BOWE WALTER Certificate Issue Date 10/12/2004 Model PIETENPOL AIR CAMPER Status Valid T ype Aircraft Fixed Wing Single-Engine Type Engine Reciprocating Pending Num ber Change None Dealer No Date Change Authorized None Mode S Code 50074262 MFR Year 2005 Fractional Owner NO To search FAA registrations go here: http://registry.faa.gov/aircraftinqu iry/ ________________________________________________________________________________
Subject: Re: some gorgeous photos of a Ford Pietenpol flying in
California
Date: Mar 30, 2009
That IS a beautiful plane! Thanks Mike walt evans NX140DL ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Monday, March 30, 2009 2:30 PM Subject: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California go here: http://forum.planetalk.net/viewtopic.php?t=7708 Serial Number 1 Type Registration Individual Manufacturer Name BOWE WALTER Certificate Issue Date 10/12/2004 Model PIETENPOL AIR CAMPER Status Valid Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating Pending Number Change None Dealer No Date Change Authorized None Mode S Code 50074262 MFR Year 2005 Fractional Owner NO To search FAA registrations go here: http://registry.faa.gov/aircraftinquiry/ ________________________________________________________________________________
Subject: Photo resizing tool
Date: Mar 30, 2009
I buried this in a reply to a previous thread and you might have missed it. Here it is again. It's a very handy picture resizing tool as an add-on from Microsoft This link will tell you all about it. It allows you to select one or more photos and make them smaller and better suited as attachments to lists such as this. http://www.microsoft.com/windowsxp/using/digitalphotography/learnmore/tips/eschelman2.mspx It says it's for XP but, I don't know why it wouldn't work with Vista. -------- Jim Birke Ira G. Ross Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236906#236906 ________________________________________________________________________________
Subject: Wingtip attachment
Date: Mar 30, 2009
Would you be so kind as to tell me the best way to attach the wingtips to the spars? I can see the blocks at the leading and trailing edges but, the plans are a little vague about the spars. Looks like some kind of an angle. -------- Thanks, Jim Birke Ira G. Ross Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236908#236908 ________________________________________________________________________________
Date: Mar 30, 2009
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Here you go Jim, more pictures on my site. Jack www.textors.com ________________________________________________________________________________
Californi
Date: Mar 30, 2009
Very cool pics. I hope mine turns out that nice. -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236918#236918 ________________________________________________________________________________
Subject: Re: Wingtip attachment
Date: Mar 30, 2009
Thanks for the info. A couple of questions. 1. bolt size thru the spars. 2. is the screw thru the tip the same size as the screws thru the leading edge and are they counter-bored the same way? -------- Thanks, Jim Birke Ira G. Ross Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236920#236920 ________________________________________________________________________________
Date: Mar 30, 2009
Jim, AN3 through the spars, the tip was a bit smaller (it was an MS?)and bored in to hide the head. Jack Textor Vice President 3737 Woodland Avenue Suite #300 West Des Moines, IA 50266 515-225-7000 www.thepalmergroup.com This e-mail, including attachments, is covered by the Electronic Communications Privacy Act, 18 U.S.C. 2510-2521, is confidential, and may be legally privileged. If you are not the intended recipient, you are hereby notified that any retention, dissemination, distribution, or copying of this communication is strictly prohibited. Please reply to the sender that you have received the message in error, and then please delete it. Thank you. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jimbir Sent: Monday, March 30, 2009 4:09 PM Subject: Pietenpol-List: Re: Wingtip attachment Thanks for the info. A couple of questions. 1. bolt size thru the spars. 2. is the screw thru the tip the same size as the screws thru the leading edge and are they counter-bored the same way? -------- Thanks, Jim Birke Ira G. Ross Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236920#236920 ________________________________________________________________________________
Date: Mar 30, 2009
Thanks, Michael. I'm now aware that I'll blend the Riblett airfoil construction into the specific detail called out in my plans. On a technical construction note (the egg or chicken story), how does one transition from full-size ribs to ailerons during the jig work? Make a bunch of full-size then cut them to order, or make required number of full-size, then modify the jig? And is it advisable to use 1/2" Sitka in the aileron spars or are you all using something else? With great thanks, Al ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Monday, March 30, 2009 11:07 AM Subject: Re: Pietenpol-List: Riblett Airfoil Al, I am using the 3 piece wing plan for the Pietenpol with the Riblett 612 ribs. What you must do is build the ribs per the Riblett full scale drawing and modify/include what you need to do match the print of the wing. (regardless of the type of plane/wing) Our Pietenpol wings use compression struts at the drag cable attach points on the spars. These are separate from the ribs. Our ribs do not include any kind of built in compression struts. (if I am reading you question correctly.) There are extra braces that are built into a few ribs for the ends of the wings and those are also shown on the Riblett plan. My 3 piece Pietenpol wing will use a total of 31 ribs. ________________________________________________________________________________
Date: Mar 30, 2009
Al, At least for the Pietenpol, you build full size ribs for the aileron portion of the wing. After you have assembled the wing and finished installing the various components for the ailerons (braces, beams/spars, etc) you cut the ailerons free of the wing. Then you finish the aileron and bay off by enclosing the open ends and adding 1/4x1/4 filler strips as shown in the plans. What one might term the aileron false spar and aileron spar are referred to as the "aileron beams" in the Piet plans, and are shown to be 1/2". Ryan On Mon, Mar 30, 2009 at 8:38 PM, ALAN LYSCARS wrote: > Thanks, Michael. > > I'm now aware that I'll blend the Riblett airfoil construction into the > specific detail called out in my plans. > > On a technical construction note (the egg or chicken story), how does one > transition from full-size ribs to ailerons during the jig work? Make a > bunch of full-size then cut them to order, or make required number > of full-size, then modify the jig? > > And is it advisable to use 1/2" Sitka in the aileron spars or are you all > using something else? > > With great thanks, > > Al > > ----- Original Message ----- > *From:* Michael Perez > *To:* pietenpol-list(at)matronics.com > *Sent:* Monday, March 30, 2009 11:07 AM > *Subject:* Re: Pietenpol-List: Riblett Airfoil > > Al, I am using the 3 piece wing plan for the Pietenpol with the Riblett > 612 ribs. What you must do is build the ribs per the Riblett full scale > drawing and modify/include what you need to do match the print of the wing. > (regardless of the type of plane/wing) Our Pietenpol wings use compression > struts at the drag cable attach points on the spars. These are separate from > the ribs. Our ribs do not include any kind of built in compression struts. > (if I am reading you question correctly.) There are extra braces that are > built into a few ribs for the ends of the wings and those are also shown on > the Riblett plan. My 3 piece Pietenpol wing will use a total of 31 ribs. > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Mar 30, 2009
That's exactly what I did. I used 3/16" hard piano wire from the hobby shop and a straight piece of 1 1/2" L iron clamped 1"above the hinge rod. Clamp one hinge to the stab then the other at the other end. Measure the center rod as 1" down, clamp and start drilling. Once I'd established the hinges and drilled them I marked around the bases with a knife and routed out the wood with a little hand router. Also, wood cabane struts, go to my message #40283 from Jan 6 for strength and load calculations. Ash or any other hardwood is overkill. Especialy considering the weight penalty. Wing struts require a few more strategicaly placed bolts. Clif Tom, I also had trouble with those plans-built hinges to line up. I had to do a lot of fudging like you propose. Somebody has to have figured out a way to line-up all those things. Maybe you could put a rod all the way through all three hinges before marking for the holes in the wood? Dan Helsper ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/30/09 17:56:00 ________________________________________________________________________________
Date: Mar 31, 2009
Subject: Wood Adhesion
Hello all, Here is a link to the results of a wood adhesion study I came across. It is a pretty good read. I am looking at other parts of the website. It certainly has some really good information about wood in general. http://www.fpl.fs.fed.us/documnts/pdf1997/vick97a.pdf Regards, Ameet Savant ________________________________________________________________________________
Date: Mar 31, 2009
Subject: hand propping
I have found that carrying a good quality rope to fly-in's or on cross coun try trips assures me that the airplane will stay put during hand propping. I tie the rope around the tailwheel an d then to either a tie down anchor in the pavement or a nearby fence post. I have also found that it isn't wise to let anyone (I mean anyone) prop you r airplane but yourself. I have had people say that they were experienced in hand propping who had no idea what they were doing and were not only dangerous but clearly afraid and unsure of themselves. To add to thi s, most times those people didn't get me going anyway and I ended up doing it myself. Unless you know for a fact that a person is experienced at hand propping, just do it yourself. You'll never sue yourself either. I have to laugh at the Hollywood imitators out there who give a big old leg swing to prop a little Continental engine. My grandmother could prop a Continental engine without a big leg k ick and if timed properly and you have at least one impulse mag (if you don't, get one) you should be actuall y able to prop the thing with one hand while having both feet on the ground. I suppose the big theatrical l eg kick helped back in the days when you hand propped bigger engines but I've hand propped Stearman's and d idn't require any off-balance leg action but merely used the method I was taught---to pull down on the pr op while stepping away from it with my right foot to backup away from the prop arc in one motion-- not bal ancing on one foot and hoping you don't slip or get off balance. To each his own though-- whatever works fo r you. The whole country went down the drain when they invented electric starters for airplanes and cars. :)) Mike C. ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Mar 31, 2009
Subject: Re: hand propping
Mike, I agree about letting just anyone hand prop. The military flying club where I learned to fly had an actual hand propping "Class" that you were required to pass. Not difficult but you had to take it in order to go in the Piper cub. Rules I quickly remember: Pilot behid stick. not a wuffo no hats or floppy shirt tails. we did the leg swing but mostly as a reminder to be moving away from the prop after swinging it. Never run around the plane. (actually never run on the ramp.) When the "Pilot" says "hot" his hand is on the mag switch, when "cold" his hand is visible to the "Propper" NEVER RUSH the proceedures! Blue Skies and safe propping, Steve D ----- Original Message ----- From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov> Date: Tuesday, March 31, 2009 7:29 Subject: Pietenpol-List: hand propping > > I have found that carrying a good quality rope to fly-in's or on > cross country trips assures me that the airplane > will stay put during hand propping. I tie the rope around the > tailwheel and then to either a tie down anchor in > the pavement or a nearby fence post. > > I have also found that it isn't wise to let anyone (I mean anyone) > prop your airplane but yourself. I have had > people say that they were experienced in hand propping who had no > idea what they were doing and were not > only dangerous but clearly afraid and unsure of themselves. To > add to this, most times those people didn't > get me going anyway and I ended up doing it myself. Unless you > know for a fact that a person is experienced > at hand propping, just do it yourself. You'll never sue yourself > either. > I have to laugh at the Hollywood imitators out there who give a > big old leg swing to prop a little Continental > engine. My grandmother could prop a Continental engine without a > big leg kick and if timed properly and you > have at least one impulse mag (if you don't, get one) you should > be actually able to prop the thing with one > hand while having both feet on the ground. I suppose the big > theatrical leg kick helped back in the days > when you hand propped bigger engines but I've hand propped > Stearman's and didn't require any off-balance > leg action but merely used the method I was taught---to pull down > on the prop while stepping away from it > with my right foot to backup away from the prop arc in one motion-- > not balancing on one foot and hoping you > don't slip or get off balance. To each his own though-- whatever > works for you. > > The whole country went down the drain when they invented electric > starters for airplanes and cars. :)) > > Mike C. > > > ________________________________________________________________________________
Date: Mar 31, 2009
Jim=3B the way I start my 65 is pretty specific to the Stromberg NA-S3A1 ca rb. What carb do you have on yours? Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 31, 2009
Mikeee- that is truly a gorgeous airplane=2C and a very interesting aileron cable setup. Sure makes it easy to inspect and service the cables and pul leys! The one thing that puzzles me is the apparent thrust-line of the engine. I t sure seems to be cocked down but maybe that's just the angle of the photo s or something. Look at the line of the top longerons and then the line of the head or the prop axis. I guess that's the way they're setup though... Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
California
Date: Mar 31, 2009
There is a deliberate downward cant to the engine (memory says 3 degrees but it may be more). This is to allow the thrust line to line up with the direction of flight more directly in a climb. At least that's according to the article in the Flying and Glider manual. I guess with 36 horsepower he thought he could use any advantage at all. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Oscar Zuniga Sent: March 31, 2009 8:32 AM To: Pietenpol List Subject: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California Mikeee- that is truly a gorgeous airplane, and a very interesting aileron cable setup. Sure makes it easy to inspect and service the cables and pulleys! The one thing that puzzles me is the apparent thrust-line of the engine. It sure seems to be cocked down but maybe that's just the angle of the photos or something. Look at the line of the top longerons and then the line of the head or the prop axis. I guess that's the way they're setup though... Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 31, 2009
Mike, I agree about the leg kick being an unnecessary thing that's picked up from the movies. In addition to being unnecessary, it also makes the whole process more dangerous. When your leg is coming back down and swinging behind you, the natural movement for your torso to make is to lean forward. You actually end up bringing your upper body closer to the path of the propeller with that ridiculous method. One thing I still haven't gotten used to, since getting hitched, is propping with a wedding ring. I always take it off and slip it in my pocket, as I don't want to scratch the finish on the prop. :P Ryan On Tue, Mar 31, 2009 at 7:14 AM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > > I have found that carrying a good quality rope to fly-in's or on cross > country trips assures me that the airplane > will stay put during hand propping. I tie the rope around the tailwheel > and then to either a tie down anchor in > the pavement or a nearby fence post. > > I have also found that it isn't wise to let anyone (I mean anyone) prop > your airplane but yourself. I have had > people say that they were experienced in hand propping who had no idea what > they were doing and were not > only dangerous but clearly afraid and unsure of themselves. To add to > this, most times those people didn't > get me going anyway and I ended up doing it myself. Unless you know for a > fact that a person is experienced > at hand propping, just do it yourself. You'll never sue yourself either. > > I have to laugh at the Hollywood imitators out there who give a big old leg > swing to prop a little Continental > engine. My grandmother could prop a Continental engine without a big leg > kick and if timed properly and you > have at least one impulse mag (if you don't, get one) you should be > actually able to prop the thing with one > hand while having both feet on the ground. I suppose the big theatrical > leg kick helped back in the days > when you hand propped bigger engines but I've hand propped Stearman's and > didn't require any off-balance > leg action but merely used the method I was taught---to pull down on the > prop while stepping away from it > with my right foot to backup away from the prop arc in one motion-- not > balancing on one foot and hoping you > don't slip or get off balance. To each his own though-- whatever works > for you. > > The whole country went down the drain when they invented electric starters > for airplanes and cars. :)) > > Mike C. > > > * > > * > > ________________________________________________________________________________
Date: Mar 31, 2009
Mike I pretty much agree with your thoughts. Having wire wheels, I carry 2 nylon cargo straps which get tucked under the seat while flying. I tie from the rear cabane strut, around the top of the wheel and back to the cabane. one on each side. It keeps the wheels locked in place. Also the country really went downhill when teachers lost the paddle in the classroom. Dick N. ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Tuesday, March 31, 2009 7:14 AM Subject: Pietenpol-List: hand propping I have found that carrying a good quality rope to fly-in's or on cross country trips assures me that the airplane will stay put during hand propping. I tie the rope around the tailwheel and then to either a tie down anchor in the pavement or a nearby fence post. I have also found that it isn't wise to let anyone (I mean anyone) prop your airplane but yourself. I have had people say that they were experienced in hand propping who had no idea what they were doing and were not only dangerous but clearly afraid and unsure of themselves. To add to this, most times those people didn't get me going anyway and I ended up doing it myself. Unless you know for a fact that a person is experienced at hand propping, just do it yourself. You'll never sue yourself either. I have to laugh at the Hollywood imitators out there who give a big old leg swing to prop a little Continental engine. My grandmother could prop a Continental engine without a big leg kick and if timed properly and you have at least one impulse mag (if you don't, get one) you should be actually able to prop the thing with one hand while having both feet on the ground. I suppose the big theatrical leg kick helped back in the days when you hand propped bigger engines but I've hand propped Stearman's and didn't require any off-balance leg action but merely used the method I was taught---to pull down on the prop while stepping away from it with my right foot to backup away from the prop arc in one motion-- not balancing on one foot and hoping you don't slip or get off balance. To each his own though-- whatever works for you. The whole country went down the drain when they invented electric starters for airplanes and cars. :)) Mike C. ________________________________________________________________________________
Date: Mar 31, 2009
I agree with Ryan, Al. You use the same rib jig for all the ribs. The only difference are the extra cap strip pieces that are shown on the Riblett pla n as well as the Pietenpol plan for the end ribs. (the last wing rib before the center section and the last rib at the wing tip.) - Build the entire wing with all the aileron Pisces in place. Then using a sm all hand saw, cut the aileron free. Once free finish up the cut areas both on the free aileron as well as the aileron bay on the wing as per the print s. (As Ryan said. We are referring to the Pietenpol prints.) ________________________________________________________________________________
Date: Mar 31, 2009
California Yup that's the way the engine is supposed to be mounted on the Piet and the GN-1 Aircamper.No mistake about it that's right in the directions.=0A=0A =0A=0A=0A________________________________=0AFrom: Oscar Zuniga <taildrags@h otmail.com>=0ATo: Pietenpol List =0ASent: Tue sday, March 31, 2009 9:32:27 AM=0ASubject: Pietenpol-List: some gorgeous ph otos of a Ford Pietenpol flying in California=0A=0AMikeee- that is truly a gorgeous airplane, and a very interesting aileron cable setup.- Sure make s it easy to inspect and service the cables and pulleys!=0A-=0AThe one th ing that puzzles me is the apparent thrust-line of the engine.- It sure s eems to be cocked down but maybe that's just the angle of the photos or som ething.- Look at the line of the top longerons and then the line of the h ead or the prop axis.- I guess that's the way they're setup though...=0A -=0AOscar Zuniga=0AAir Camper NX41CC=0ASan Antonio, TX=0Amailto: taildrag =============== ________________________________________________________________________________
Date: Mar 31, 2009
Great posts about the wedding ring Ryan and paddling kids in school Dick N. ! What about when they let women vote and start smoking ? :)))) Uh boy, I can hear the bleeding heart liberals now thinking I might be actu ally serious. PS...take a break, unwind undies. I am just KIDDING. PSS---- I re-read my post and by no means did I mean to belittle the seriou sness of hand propping an airplane nor did I want to make fun of those incredibly brave men who flew early hand-propped airplanes both in civilian and military roles by likening them to my grandmother's ability to hand prop but if you do it, just try to learn from someone who r eally knows what they are doing and practice it on a dead engine somewhere safe with the plug wires disconnected and the fuel off. Hand pr opping is still a super serious thing and the one post put it best---- take your time, think thru each step. If you're in a rush, don't fly. Go home and have some chips. Take 5, chock the plane, tie it down, do anything but rush. Mike C. ________________________________________________________________________________
Date: Mar 31, 2009
With an electric starter it just means that you old guys can fly longer!=0A =0A=0A=0AThe whole country went down the drain when they invented electric starters for airplanes and cars.-- :))=0A-=0AMike C.=0A-=0A-=0A ________________________________________________________________________________
Date: Mar 31, 2009
There was a man that used to come to our RAA meetings.One day he happened t o just move his prop to the horizontal position and it fired and almost kil led him.The prop stuck his head and caved part of it in.He doesn't fly anym ore or come to our meetings.Be careful out there when touching props in any manner.You never know when a mag off switch is going to fail or if there i s gas in the chamber or when it will fire.Always treat a prop like you woul d a loaded gun,never assume anything.=0A=0Aarchive this=0A=0A=0A=0A=0A_____ ___________________________=0AFrom: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerosp ace Corporation]" =0ATo: "pietenpol-list(at)matronics. com" =0ASent: Tuesday, March 31, 2009 11:25:4 2 AM=0ASubject: RE: Pietenpol-List: hand propping=0A=0A=0AGreat posts about the wedding ring Ryan and paddling kids in school Dick N.-- !--- -- What about when they let women vote and start smoking ?- :))))=0A -=0AUh boy, I can hear the bleeding heart liberals now thinking I might b e actually serious.-- PS...take a break, unwind undies.- I am just KI DDING. =0A-=0APSS---- I re-read my post and by no means did I mean to bel ittle the seriousness of hand propping an airplane nor did I want to make f un=0Aof those incredibly brave men who flew early hand-propped airplanes bo th in civilian and military roles by likening them to my grandmother's=0Aab ility to hand prop but if you do it, just try to learn from someone who rea lly knows what they are doing and practice it on a dead engine=0Asomewhere safe with the plug wires disconnected and the fuel off.-- Hand propping is still a super serious thing and the one post put it best----=0Atake you r time, think thru each step.-- If you're in a rush, don't fly.-- - Go home and have some chips.-- Take 5, chock the plane, tie it down =============== ________________________________________________________________________________
Date: Mar 31, 2009
A fellow in the Amarillo, TX area has had two incidents with moving a prop and the engine starting. First time he was turning the prop to "Break the oil loose" on a somewhat cool day and his tripacer started and taxied into a Cessna 182 with 3 pax waiting for the pilot to finish paying for fuel. No one was hurt but both planes were damages. They think he had accidently hit the mag switch onto one mag while loading the plane. I heard it happen, and when I stuck my head outside there was still aluminium flying. Sounded like someone putting a mower on a steel fencepost. Second time he had a single seat homebuilt and was turning the prop and it fired. He dove out of the way and the plane taxied down the runway at an angle and tookoff. but the wheels caught on a Bobwire fence and the plane flipped onto railroad tracks. No train was coming and the plane wreckage was rescured. I think he has quit flying. He had a good reputation as a safe pilot and was otherwise respected. Blue Skies, Steve D. ----- Original Message ----- From: H RULE <harvey.rule(at)rogers.com> Date: Tuesday, March 31, 2009 10:56 Subject: Re: Pietenpol-List: hand propping > There was a man that used to come to our RAA meetings.One day he > happened to just move his prop to the horizontal position and it > fired and almost killed him.The prop stuck his head and caved part > of it in.He doesn't fly anymore or come to our meetings.Be careful > out there when touching props in any manner.You never know when a > mag off switch is going to fail or if there is gas in the chamber > or when it will fire.Always treat a prop like you would a loaded > gun,never assume anything. > > archive this > > > > > ________________________________ > From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" < > To: "pietenpol-list(at)matronics.com" < > Sent: Tuesday, March 31, 2009 11:25:42 AM > Subject: RE: Pietenpol-List: hand propping > > > Great posts about the wedding ring Ryan and paddling kids in school Dick N. ! What about when they let women vote and start smoking ? :)))) > > Uh boy, I can hear the bleeding heart liberals now thinking I might be actually serious. PS...take a break, unwind undies. I am just KIDDING. > > PSS---- I re-read my post and by no means did I mean to belittle the seriousness of hand propping an airplane nor did I want to make fun > of those incredibly brave men who flew early hand-propped airplanes both in civilian and military roles by likening them to my grandmother's > ability to hand prop but if you do it, just try to learn from someone who really knows what they are doing and practice it on a dead engine > somewhere safe with the plug wires disconnected and the fuel off. Hand propping is still a super serious thing and the one post put it best---- > take your time, think thru each step. If you're in a rush, don't fly. Go home and have some chips. Take 5, chock the plane, tie it down=============== ________________________________________________________________________________
California
Date: Jan 01, 1990
Gorgeous ship, but wing will be more solid if he adds some jury struts--and it will make it easier for passengers to get in also since he can then remove the crosswires at front cockpit side. Mac in Oregon ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Monday, March 30, 2009 10:30 AM Subject: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California go here: http://forum.planetalk.net/viewtopic.php?t=7708 Serial Number 1 Type Registration Individual Manufacturer Name BOWE WALTER Certificate Issue Date 10/12/2004 Model PIETENPOL AIR CAMPER Status Valid Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating Pending Number Change None Dealer No Date Change Authorized None Mode S Code 50074262 MFR Year 2005 Fractional Owner NO To search FAA registrations go here: http://registry.faa.gov/aircraftinquiry/ ------------------------------------------------------------------------- ----- 12:00 AM ________________________________________________________________________________
Date: Mar 31, 2009
California I believe you're thinking of the cabane brace struts that tie the top of the cabanes to the engine mounts, maintaining wing fore/aft position. Jury struts stabilize the lift struts near (but not at) mid span of the struts. NX12988 does have jury struts. The cross-bracing cables by the passenger cockpit are what is specified in the original plans. NX12988 looks beautifully plans-built. ----- Original Message ----- From: "Mac Zirges" <macz(at)casco.net> Sent: Monday, January 1, 1990 2:02:46 AM GMT -08:00 US/Canada Pacific Subject: Re: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California Gorgeous ship, but wing will be more solid if he adds some jury struts--and it will make it easier for passengers to get in also since he can then remove the crosswires at front cockpit side. Mac in Oregon ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Monday, March 30, 2009 10:30 AM Subject: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California go here: http://forum.planetalk.net/viewtopic.php?t=7708 Serial Number 1 Type Registration Individual Manufacturer Name BOWE WALTER Certificate Issue Date 10/12/2004 Model PIETENPOL AIR CAMPER Status Valid Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating Pending Number Change None Dealer No Date Change Authorized None Mode S Code 50074262 MFR Year 2005 Fractional Owner NO To search FAA registrations go here: http://registry.faa.gov/aircraftinquiry/ href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Date: 4/6/07 12:00 AM ________________________________________________________________________________
Date: Mar 31, 2009
Steven I tried to e-mail you but the address didn't work-do you live in Amarillo? I'm 50 miles away.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237057#237057 ________________________________________________________________________________
Californi
Date: Mar 31, 2009
It has jury struts. Those are the ones out on the main struts. The original plans show the brace cables between the cabanes on the right side. Walt tried to keep it as original to the plans (Flying and Glider Manual) as possible. Heck he even used an N number from one of Mr. Pietenpol's ships. That particular one though had the steel split axle gear. Sure is a pretty ship! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237063#237063 ________________________________________________________________________________
Date: Mar 31, 2009
Raymond, I think we discussed a Piet that is in a museum in Canadian at some point in the past. ----- Original Message ----- From: skellytown flyer <rhano(at)att.net> Date: Tuesday, March 31, 2009 12:41 Subject: Pietenpol-List: Re: hand propping > > Steven I tried to e-mail you but the address didn't work-do you live in Amarillo? I'm 50 miles away.Raymond > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=237057#237057 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 31, 2009
Oscar, my carb is the same as yours, NA-S3A1, per my engine log book.-Jim ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Tuesday, March 31, 2009 9:16 AM Subject: Pietenpol-List: Hand propping a 65 Jim; the way I start my 65 is pretty specific to the Stromberg NA-S3A1 carb. What carb do you have on yours? Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/31/09 06:02:00 ________________________________________________________________________________
Subject: Fuselage Plywood
Date: Mar 31, 2009
Hello all, I apologize if this has been asked but there was little in the archive regarding plywood preferences for the fuselage large pieces. I cant seem to find sitka spruce (preferred) in large sheets. Does anyone have a good source and/or recommendations for/against the following 3 choices from Boulter? Khaya African Mahogany, Flat Sawn Okoume, Rotary Cut White Birch, Rotary Cut Thanks, Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237080#237080 ________________________________________________________________________________
Date: Mar 31, 2009
Subject: Re: Fuselage Plywood
LOL, at first glance this looked like an email from Kenya asking me to help get $10million out of the country by givng them my bank account number. Blue Skies, Steve D. > > Khaya African Mahogany, Flat Sawn > Okoume, Rotary Cut > White Birch, Rotary Cut > > Thanks, > Steve > > ________________________________________________________________________________
Date: Mar 31, 2009
Hi Steve, =C2- I used mahagony (1/8") for the sides and birch (1/4") for the floor.=C2- Birch is stronger, mahogany is lighter. =C2- Jack Phillips NX899JP --- On Tue, 3/31/09, chase143 wrote: From: chase143 <chase143(at)aol.com> Subject: Pietenpol-List: Fuselage Plywood Date: Tuesday, March 31, 2009, 3:50 PM Hello all, I apologize if this has been asked but there was little in the archive regarding plywood preferences for the fuselage large pieces. I can=C3=A2 =82=AC=84=A2t seem to find sitka spruce (preferred) in large sheets. Does anyone have a good s ource and/or recommendations for/against the following 3 choices from Boulter? Khaya African Mahogany, Flat Sawn Okoume, Rotary Cut White Birch, Rotary Cut Thanks, Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237080#237080 ________________________________________________________________________________
Date: Mar 31, 2009
Breaking the oil loose, eh? You would think that even on the coldest day in Texas the starter would have the oomph to overcome the friction from all that solidified oil... ;) I think one of the things that this gentleman's tales of woe illustrates is to avoid complacency. One should strive to not become complacent in the air; there is no reason to not have the same mindset on the ground. If you are going to be moving the propeller, there is absolutely no reason to not take the time to step around to the cockpit/cabin and verify that the switches are off, the throttle is closed, etc. If you are pulling the engine through before you go flying you should verify those conditions. If you are turning the prop into a particular position after you have shutdown, then you should have verified those conditions when you exited the aircraft. As Mike pointed out, take your time and be deliberate about the act of hand-propping an airplane. As they used to tell us on the rifle ranges: slow is smooth, and smooth is fast. And as Harvey stated, treat every propeller as if it is loaded. And never point your propeller at anything that you do not intend to fly....or something like that. :) Ryan On Tue, Mar 31, 2009 at 11:05 AM, Dortch, Steven D MAJ NG NG NGB < steven.d.dortch(at)us.army.mil> wrote: > steven.d.dortch(at)us.army.mil> > > A fellow in the Amarillo, TX area has had two incidents with moving a prop > and the engine starting. > > First time he was turning the prop to "Break the oil loose" on a somewhat > cool day and his tripacer started and taxied into a Cessna 182 with 3 pax > waiting for the pilot to finish paying for fuel. No one was hurt but both > planes were damages. They think he had accidently hit the mag switch onto > one mag while loading the plane. I heard it happen, and when I stuck my head > outside there was still aluminium flying. Sounded like someone putting a > mower on a steel fencepost. > > Second time he had a single seat homebuilt and was turning the prop and it > fired. He dove out of the way and the plane taxied down the runway at an > angle and tookoff. but the wheels caught on a Bobwire fence and the plane > flipped onto railroad tracks. No train was coming and the plane wreckage was > rescured. > > I think he has quit flying. He had a good reputation as a safe pilot and > was otherwise respected. > > Blue Skies, > Steve D. > ________________________________________________________________________________
Date: Mar 31, 2009
Subject: hand propping story
When I was a kid (17 or 18) and the line boy,-I remember having a very cl ose call while handpropping a tricycle gear cessna 150.- The ramp was wet ashphalt and some one left the master on for 3 or 4 hrs.-I don't think -the guy in the cockpit knew his ass from his elbow when it came to start ing an engine.- Long story short He had the throttle set wrong (wide open ) and I tried and tried to get it started by hand propping it.- Eventuall y a old timer came out and chastized me for not having someone sit on the t ail to get more of a taildragger stance, and he sat on it.- Well a few ba ldes later after exausting myself-I slipped and went right on my back und er the prop.- Thank God I thought quick enough to let go of the prop on t he way down, so it did not go through compression.- That was the only clo se call I have had with props,-except for-some old fart at Brodhead las t year wanting to try on the piet for size and he hit the starter button wi th his knee while climbing out, and dad got whacked in the arm by the prop.- Pr ops are inherintly dangerous if you got a electric starter or you hand prop they will get you if you are not careful. - Shad=0A=0A=0A ________________________________________________________________________________
Date: Mar 31, 2009
When I worked at Elliott Flying Service going through college, we had a guy and his partner prop a Bellanca, 6 cylinder, not sure of the size. Full throttle, brakes couldn't hold, he went through a fence and into the line office. Lot's of damage to plane and property, lucky no people were injured! Jack www.textors.com ________________________________________________________________________________
Date: Mar 31, 2009
U3RldmUsDQoNCkkndmUgbmV2ZXIgZXZlbiBoZWFyZCBvZiBTaXRrYSBwbHl3b29kLg0KSSBoYXZl bid0IGJ1aWx0IG15IGZ1c2VsYWdlIHlldCwgYnV0IEkgZGlkIGJ1eSBteSBwbHl3b29kIGZvciBp dC4gSSBib3VnaHQgT2tvdW1lIE1hcmluZSBQbHkgZnJvbSBOb2FoJ3MgTWFyaW5lLCBiYXNlZCBv biBzdWdnZXN0aW9ucyBmcm9tIHRoZSBMaXN0Lg0KDQogaHR0cDovL3d3dy5ub2Foc21hcmluZS5j b20vaHRtbC9jX3NwbGFzaC5odG1sDQoNCklmIHlvdSdyZSB1c2luZyBwbHl3b29kIGZvciBzdHJ1 Y3R1cmFsIHVzZSBpbiBhbiBhaXJwbGFuZSwgeW91IHJlYWxseSBzaG91bGQgYmUgdXNpbmcgYSBw bHl3b29kIHRoYXQgaXMgbWFudWZhY3R1cmVkIHVzaW5nIHdhdGVycHJvb2YgYWRoZXNpdmVzLg0K Qm90aCBBaXJjcmFmdCBQbHkgYW5kIE1hcmluZSBQbHkgdXNlIHdhdGVycHJvb2YgKGFjdHVhbGx5 IGJvaWwtcHJvb2YpIGFkaGVzaXZlcyBleGNsdXNpdmVseS4NCkkgZG9uJ3Qga25vdyBpZiBCb3Vs dGVyJ3MgV2hpdGUgQmlyY2ggUGx5IGlzIG1hZGUgd2l0aCB3YXRlcnByb29mIGdsdWVzLg0KDQpP a291bWUgaXMgYSBiaXQgbGlnaHRlciB0aGFuIEJpcmNoIChpbiBkZW5zaXR5KSwgYW5kIEJpcmNo IGlzIGxpZ2h0ZXIgdGhhbiBPa291bWUgKGluIGNvbG9yKS4gU28sIHdoYXRldmVyIHlvdSBkbywg Y2hvb3NlIHRoZSBsaWdodGVyIG9uZSAgOikNCg0KSSdtIG5vdCBmYW1pbGlhciB3aXRoIEtoYXlh LCBidXQgZnJvbSBCb3VsdGVyJ3Mgd2Vic2l0ZSBkZXNjcmlwdGlvbiwgaXQgaXMgcHJvYmFibHkg c2ltaWxhciB0byB0aGUgT2tvdW1lLCBidXQgbmljZXIgbG9va2luZywgYW5kIHF1aXRlIGEgYml0 IG1vcmUgZXhwZW5zaXZlLg0KDQpQZW9wbGUgaGF2ZSBidWlsdCBzdWNjZXNzZnVsIFBpZXRzIHVz aW5nIGxvdHMgb2YgZGlmZmVyZW50IGtpbmRzIG9mIHBseXdvb2RzLiBJIGhhdmUgcmVhZCBhYm91 dCBzb21lIGJ1aWxkZXJzIHVzaW5nIG1haG9oYW55IGRvb3Igc2tpbnMuIFByZXR0eSBzdXJlIHRo b3NlIGFyZW4ndCBtYWRlIHdpdGggd2F0ZXJwcm9vZiBnbHVlcywgdGhvdWdoLg0KDQpCaWxsIEMu DQoNCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206IG93bmVyLXBpZXRlbnBvbC1s aXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcGlldGVucG9sLWxpc3Qtc2Vy dmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBjaGFzZTE0Mw0KU2VudDogVHVlc2RheSwg TWFyY2ggMzEsIDIwMDkgMzo1MSBQTQ0KVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20N ClN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBGdXNlbGFnZSBQbHl3b29kDQoNCi0tPiBQaWV0ZW5w b2wtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogImNoYXNlMTQzIiA8Y2hhc2UxNDNAYW9sLmNvbT4N Cg0KSGVsbG8gYWxsLA0KSSBhcG9sb2dpemUgaWYgdGhpcyBoYXMgYmVlbiBhc2tlZCBidXQgdGhl cmUgd2FzIGxpdHRsZSBpbiB0aGUgYXJjaGl2ZSByZWdhcmRpbmcgcGx5d29vZCBwcmVmZXJlbmNl cyBmb3IgdGhlIGZ1c2VsYWdlIGxhcmdlIHBpZWNlcy4gSSBjYW7DouKCrOKEonQgc2VlbSB0byBm aW5kIHNpdGthIHNwcnVjZSAocHJlZmVycmVkKSBpbiBsYXJnZSBzaGVldHMuIERvZXMgYW55b25l IGhhdmUgYSBnb29kIHNvdXJjZSBhbmQvb3IgcmVjb21tZW5kYXRpb25zIGZvci9hZ2FpbnN0IHRo ZSBmb2xsb3dpbmcgMyBjaG9pY2VzIGZyb20gQm91bHRlcj8NCg0KS2hheWEgQWZyaWNhbiBNYWhv Z2FueSwgRmxhdCBTYXduDQpPa291bWUsIFJvdGFyeSBDdXQNCldoaXRlIEJpcmNoLCBSb3Rhcnkg Q3V0DQoNClRoYW5rcywNClN0ZXZlDQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVy ZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD0yMzcwODAj MjM3MDgwDQoNCg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVucG9s LUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMg TmF2aWdhdG9yIHRvIGJyb3dzZSBfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBM aXN0IFVuL1N1YnNjcmlwdGlvbiwgXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5 IEJyb3dzZSwgQ2hhdCwgRkFRLCBfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0K Xy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5w b2wtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZP UlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2Vi IEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09 DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0K Xy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Mar 31, 2009
Just make sure you get a type that's glued with the correct glue. It's been a long time since i looked into this, but there is some kind of Lloyd's or British Mil. Spec. rating that indicates the correct adhesive. Kip Gardner On Mar 31, 2009, at 4:20 PM, Dortch, Steven D MAJ NG NG NGB wrote: > NGB" > > LOL, at first glance this looked like an email from Kenya asking me > to help get $10million out of the country by givng them my bank > account number. > > Blue Skies, > Steve D. > >> >> Khaya African Mahogany, Flat Sawn >> Okoume, Rotary Cut >> White Birch, Rotary Cut >> >> Thanks, >> Steve >> >> > > ________________________________________________________________________________
Subject: hand propping and The Great Waldo Pepper
Date: Mar 31, 2009
I'm nearly certain that I saw a scene in TGWP where an airplane is propped and the pilot reaches over to work the ignition switches which are located on the outside of the cockpit. It's not the first time I've seen mag switc hes on the outside of those old-timey planes=2C either. Now there's a way to ensure that the propper knows the condition of the mags=2C hot or cold: they are clearly visible to him/her. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 31, 2009
The Tigermoths I've seen, like this one, have the mag switches on the outside ahead of the pilots windshield where they're visible to the prop man. Clif ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Tuesday, March 31, 2009 1:25 PM Subject: Re: Pietenpol-List: hand propping If you are going to be moving the propeller, there is absolutely no reason to not take the time to step around to the cockpit/cabin and verify that the switches are off, the throttle is closed, etc. Ryan ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: oukume plywood
Date: Apr 01, 2009
Most boat builders are going with Oukume plywood these days. It is very strong, stiff and exceptionally lightweight. It's a newer wood on the scene than the old standbyes, but it is good stuff. Two minor drawbacks. It is more suseptible to rot than the others, so when used in a boat, must be well varnished. Shouldn't matter in a plane, just varnish carefully as you would anyways. Second drawback is it's odd pinkish color. I'm not sure I'd like it in my cockpits, though one could likely play around with some stain and fix it. If I were building again, I'd use it for as much as possible. Douwe ________________________________________________________________________________
Date: Apr 01, 2009
Larry Williams model A Piet has this setup. ----- Original Message ----- From: Oscar Zuniga the ignition switches which are located on the outside of the cockpit. Now there's a way to ensure that the propper knows the condition of the mags, hot or cold: they are clearly visible to him/her. ________________________________________________________________________________
Date: Apr 01, 2009
Bill C.~~Sorry, on my plywood post I said I could not find sheets of Sitka Spruce, I meant to say Finnish Birch, that was a total Piet building Freudian slip! Thanks all for the replies, and notes on waterproof ply, etc . Jack, do you remember where you found the mahogany, and was it a specific type, all I find is from Boulter? Will also look into Okoume Marine Ply. Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237183#237183 ________________________________________________________________________________
Date: Apr 01, 2009
I just bought regular aircraft grade mahogany and birch plywood from Aircra ft Spruce and Specialty.- Figure out all you will need-ahead of time so you can order it all at once - the shipping costs more than the plywood. - Jack NX899JP --- On Wed, 4/1/09, chase143 wrote: From: chase143 <chase143(at)aol.com> Subject: Pietenpol-List: Re: Fuselage Plywood Date: Wednesday, April 1, 2009, 8:31 AM Bill C.~~Sorry, on my plywood post I said I could not find sheets of Sitka Spruce, I meant to say Finnish Birch, that was a total Piet building Freudi an slip! Thanks all for the replies, and notes on waterproof ply, etc . Jack, do you remember where you found the mahogany, and was it a specific t ype, all I find is from Boulter? Will also look into Okoume Marine Ply. Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237183#237183 ________________________________________________________________________________
Date: Apr 01, 2009
I completely agree about the absurd leg swing. Placing yourself off-balance on one foot in front of a spinning propeller is just stupid, not to mention unnecessary. My Travel Air, with a 220 Continental (Stearman engine) does not have a starter, or an impulse, and I have hand propped every one of its 1800 hours. It does not take a leg swing to get it going, either, and certainly not a C-65. I never allow anyone in the cockpit, I have a bungee that I hook onto the throttle to hold it full aft (closed). If I am on a crowded or sloping ramp I tie down the tail (mostly to make airport feel better) I trained dozens how to prop my Champ years ago. C-65 and no impulse. Stand flat footed facing prop, hook last joint of R/H pinkie over trailing edge of prop, pull down firmly. Started every time, even without an impulse. The biggest thing is to NOT be afraid of it, and ALWAYS treat it as if it were hot. Gene ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Tuesday, March 31, 2009 8:14 AM Subject: Pietenpol-List: hand propping I have found that carrying a good quality rope to fly-in's or on cross country trips assures me that the airplane will stay put during hand propping. I tie the rope around the tailwheel and then to either a tie down anchor in the pavement or a nearby fence post. I have also found that it isn't wise to let anyone (I mean anyone) prop your airplane but yourself. I have had people say that they were experienced in hand propping who had no idea what they were doing and were not only dangerous but clearly afraid and unsure of themselves. To add to this, most times those people didn't get me going anyway and I ended up doing it myself. Unless you know for a fact that a person is experienced at hand propping, just do it yourself. You'll never sue yourself either. I have to laugh at the Hollywood imitators out there who give a big old leg swing to prop a little Continental engine. My grandmother could prop a Continental engine without a big leg kick and if timed properly and you have at least one impulse mag (if you don't, get one) you should be actually able to prop the thing with one hand while having both feet on the ground. I suppose the big theatrical leg kick helped back in the days when you hand propped bigger engines but I've hand propped Stearman's and didn't require any off-balance leg action but merely used the method I was taught---to pull down on the prop while stepping away from it with my right foot to backup away from the prop arc in one motion-- not balancing on one foot and hoping you don't slip or get off balance. To each his own though-- whatever works for you. The whole country went down the drain when they invented electric starters for airplanes and cars. :)) Mike C. http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Apr 01, 2009
Steve, Here are a few more possible sources for Ply:
http://www.cedartreeinc.com/ http://www.exotic-woods.com/welcome.html http://www.publiclumber.com/okoumemarine.html Bill C. ________________________________________________________________________________
California
Date: Jan 01, 1990
Oops, you're right. I have never been good at getting the names of all the specific parts right. I usually say something like "the part in front of the wing that hangs down etc." Shows my lack of sophistication. Mac in Oregon ----- Original Message ----- From: bike.mike(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Tuesday, March 31, 2009 9:11 AM Subject: Re: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California I believe you're thinking of the cabane brace struts that tie the top of the cabanes to the engine mounts, maintaining wing fore/aft position. Jury struts stabilize the lift struts near (but not at) mid span of the struts. NX12988 does have jury struts. The cross-bracing cables by the passenger cockpit are what is specified in the original plans. NX12988 looks beautifully plans-built. ----- Original Message ----- From: "Mac Zirges" <macz(at)casco.net> To: pietenpol-list(at)matronics.com Sent: Monday, January 1, 1990 2:02:46 AM GMT -08:00 US/Canada Pacific Subject: Re: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California Gorgeous ship, but wing will be more solid if he adds some jury struts--and it will make it easier for passengers to get in also since he can then remove the crosswires at front cockpit side. Mac in Oregon ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Monday, March 30, 2009 10:30 AM Subject: Pietenpol-List: some gorgeous photos of a Ford Pietenpol flying in California go here: http://forum.planetalk.net/viewtopic.php?t=7708 Serial Number 1 Type Registration Individual Manufacturer Name BOWE WALTER Certificate Issue Date 10/12/2004 Model PIETENPOL AIR CAMPER Status Valid Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating Pending Number Change None Dealer No Date Change Authorized None Mode S Code 50074262 MFR Year 2005 Fractional Owner NO To search FAA registrations go here: http://registry.faa.gov/aircraftinquiry/ href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ------------------------------------------------------------------------- --- Date: 4/6/07 12:00 AM ------------------------------------------------------------------------- ----- 12:00 AM ________________________________________________________________________________
Subject: Hand propping a 65
Date: Apr 01, 2009
Jim=3B I'll pass along the things that I learned from others on this list=2C thing s that have helped me be able to almost always start my engine=2C hot or co ld. That was not always the case! First of all=2C understand that the Stromberg has a separate fuel circuit f or when the main butterfly is closed or nearly so=2C for idle. I guess the re is not enough impulse at very low throttle settings to suck fuel up thro ugh the main jet. This becomes important in the starting drill because man y old-timers assume that the throttle is to be 'cracked' to start=2C but th at's for carbs with idle cutoff (which the Stromberg doesn't have) and for starting I pull mine all the way back to the idle stop so the carb draws fu el through the idle circuit only. Cold starts are easy=2C and I don't have impulse on either of my mags=2C do n't have a primer=2C don't swing my leg=2C and I was once the 90-pound weak ling in my class so I'm not exactly Mr. Atlas. My point is=2C it's not a d ifficult prop to swing and the compression is so low that it's no sweat unl ess you flood the engine and have to swing it a bunch more times. More on that later. For cold starts=2C I set mags off and wheels chocked=2C fuel on=2C throttle back to the stop=2C and pull the prop through a half-dozen blades fairly s lowly. Then mags hot and prop the engine briskly but no need to throw a hu ge amount of effort into it. The other small detail about swinging the pro p=2C something that has been mentioned on this list before=2C is to start t he prop swing slightly upward first=2C then down. It should sort of slurp fuel in on the slight uptick and then fire on the downswing. It's all done in one motion. Done this way my engine will usually fire on the second pu ll. For hot starts=2C the key is to shut down the engine the right way or it wi ll be flooded and will be a pain to start when you try. This always used t o be the case when I'd land for fuel and try to start back up again... it w ould flood and I'd wear myself out. So the key to shutting it down when yo u're going to be starting it back up fairly soon is to kill it with the mag switch and as the engine winds down=2C ease the throttle open so it's pull ing in plenty of air as it shuts down. If the throttle is left at idle whe n the engine is shut down=2C with no spark the engine pulls fuel through th e idle circuit and it doesn't get ignited and sits there=2C flooding the en gine. Once the engine stops=2C pull the throttle back to the stop=2C shut off the fuel valve=2C and you're shut down. For flooded starts=2C shut off the fuel=2C chock the wheels=2C kill the ign ition=2C open the throttle all the way=2C and start pulling the prop throug h backwards. Once you've pulled it a dozen or so times=2C look to see if f uel is still dripping out of the intake box. At any rate=2C the best thing to do is cool your heels for 10-15 minutes to let excess fuel evaporate (t hrottle still wide open and fuel shut off). Then what I do is put the thro ttle back to the idle stop=2C turn on the mags and fuel=2C and try normal s tart. If it doesn't start in the first couple of attempts=2C it's still fl ooded and you need to repeat the drill. Mine usually starts on the second effort because I get impatient with all those fools standing around laughin g at me trying to start my old timey airplane and I try to short-cut the pr ocess. On the shutdown procedure=2C some would argue that the engine should be sto pped by shutting off the fuel and letting the engine run itself out of fuel . That's OK too=2C but not the way I do it because I like to have the floa t bowl full and ready for the next flight. And remember that the Stromberg does NOT have idle cutoff=2C so you still need to kill the engine with the ignition even though it runs out of fuel. Don't forget to turn off the ma gs!!! Whew! I'm wearing out my starter just writing about it! Honestly=2C after a couple of dozen flights in different conditions=2C hand-propping comes p retty automatically unless something is wrong (spark=2C air=2C or fuel...) Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Hand propping a 65
Date: Apr 01, 2009
Oscar, Thank you, thank you for sharing your experience, especially since we have the same carb. and no electric start. I really appreciate your help, which will be put to good use as soon as it warms up a bit.---Jim Lagowski ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Wednesday, April 01, 2009 2:55 PM Subject: Pietenpol-List: Hand propping a 65 Jim; I'll pass along the things that I learned from others on this list, things that have helped me be able to almost always start my engine, hot or cold. That was not always the case! First of all, understand that the Stromberg has a separate fuel circuit for when the main butterfly is closed or nearly so, for idle. I guess there is not enough impulse at very low throttle settings to suck fuel up through the main jet. This becomes important in the starting drill because many old-timers assume that the throttle is to be 'cracked' to start, but that's for carbs with idle cutoff (which the Stromberg doesn't have) and for starting I pull mine all the way back to the idle stop so the carb draws fuel through the idle circuit only. Cold starts are easy, and I don't have impulse on either of my mags, don't have a primer, don't swing my leg, and I was once the 90-pound weakling in my class so I'm not exactly Mr. Atlas. My point is, it's not a difficult prop to swing and the compression is so low that it's no sweat unless you flood the engine and have to swing it a bunch more times. More on that later. For cold starts, I set mags off and wheels chocked, fuel on, throttle back to the stop, and pull the prop through a half-dozen blades fairly slowly. Then mags hot and prop the engine briskly but no need to throw a huge amount of effort into it. The other small detail about swinging the prop, something that has been mentioned on this list before, is to start the prop swing slightly upward first, then down. It should sort of slurp fuel in on the slight uptick and then fire on the downswing. It's all done in one motion. Done this way my engine will usually fire on the second pull. For hot starts, the key is to shut down the engine the right way or it will be flooded and will be a pain to start when you try. This always used to be the case when I'd land for fuel and try to start back up again... it would flood and I'd wear myself out. So the key to shutting it down when you're going to be starting it back up fairly soon is to kill it with the mag switch and as the engine winds down, ease the throttle open so it's pulling in plenty of air as it shuts down. If the throttle is left at idle when the engine is shut down, with no spark the engine pulls fuel through the idle circuit and it doesn't get ignited and sits there, flooding the engine. Once the engine stops, pull the throttle back to the stop, shut off the fuel valve, and you're shut down. For flooded starts, shut off the fuel, chock the wheels, kill the ignition, open the throttle all the way, and start pulling the prop through backwards. Once you've pulled it a dozen or so times, look to see if fuel is still dripping out of the intake box. At any rate, the best thing to do is cool your heels for 10-15 minutes to let excess fuel evaporate (throttle still wide open and fuel shut off). Then what I do is put the throttle back to the idle stop, turn on the mags and fuel, and try normal start. If it doesn't start in the first couple of attempts, it's still flooded and you need to repeat the drill. Mine usually starts on the second effort because I get impatient with all those fools standing around laughing at me trying to start my old timey airplane and I try to short-cut the process. On the shutdown procedure, some would argue that the engine should be stopped by shutting off the fuel and letting the engine run itself out of fuel. That's OK too, but not the way I do it because I like to have the float bowl full and ready for the next flight. And remember that the Stromberg does NOT have idle cutoff, so you still need to kill the engine with the ignition even though it runs out of fuel. Don't forget to turn off the mags!!! Whew! I'm wearing out my starter just writing about it! Honestly, after a couple of dozen flights in different conditions, hand-propping comes pretty automatically unless something is wrong (spark, air, or fuel...) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 04/01/09 06:06:00 ________________________________________________________________________________
Date: Apr 01, 2009
We have a Stromberg and find that shutting down by turning the fuel off results in easy starting for the next go. An added benefit is the "cool" factor of taxiing up, turning to put the tail towards the hangar, and having the engine juuuust run out of fuel all in one swell foop. ________________________________________________________________________________
Date: Apr 01, 2009
Subject: hand proping
Some things I don't understand or it doesn't make sense to me. What does turning the prop backwards accomplish? If this is necessary why doesn't the engine with electric start have a reversible starter to do the same as a hand prop engine ? You will have to over look my stupidity as I'm not the sharpest knife in th e set. Ted Stone corvair piet builder **************New Low Prices on Dell Laptops =93 Starting at $399 ttp:%2F%2Fad.doubl eclick.net%2Fclk%3B213540506%3B35046329%3Bx) ________________________________________________________________________________
Date: Apr 01, 2009
Subject: Re: hand proping
By turning the prop backwards this clears the engine of unwanted excess fue l when it's flooded. Waiting around does the same thing but it takes longer . If you have an electric start you can do somewhat the same thing with the mags off and just using the starter motor to turn it through but it will h eat up your starter motor and run down your battery. If your like me and yo u don't have a charging system, you don't want to do that. When-I have fl ooded the engine I usually shut everything off, get out and prop backwards by hand. When starting from a cold start I will prime then turn the prop th rough about six times by hand-with all mags and master off. Then when I g et in and turn on master and mags and crack the throttle to about somewhere between 1/4 and 1/2, then when I hit that starter button she usually start s with no problem. Sometimes I will give her some more prime when turning h er over if she is being a bitch that day but that's when you have to be careful not to over do it and flood her.-I am using an 80 hp Franklin with a Marvel - Schebler carb, gravity fed.If she's hot; usually piming a lot or even a little can cause more grief than enough.Most of the time just get in and put the throttle where I mentioned earlier.Turn all the switch' s on and push the starter button and most of the time she'll start no probl em. Unless there's a bunch of people around which usual causes her to flood because she is shy and wants to make an ass out of me!--=0A=0A=0A=0A =0A________________________________=0AFrom: "TGSTONE236(at)aol.com" <TGSTONE23 6(at)aol.com>=0ATo: pietenpol-list(at)matronics.com=0ASent: Wednesday, April 1, 2 009 4:32:40 PM=0ASubject: Pietenpol-List: hand proping=0A=0ASome things I d on't understand or it doesn't make sense to me.=0A=0AWhat does turning the prop backwards accomplish?=0A=0AIf this is necessary why doesn't the engine with electric start have a reversible starter to do the same as a hand pro p engine ?=0A=0AYou will have to over look my stupidity as I'm not the shar pest knife in the set.=0A=0ATed Stone=0Acorvair piet builder=0A=0A_________ _______________________=0ANew Low Prices on Dell Laptops - Starting at $399 =================== ________________________________________________________________________________
Date: Apr 01, 2009
If the engine is flooded, by turning the engine backwards, the valve sequence works in reverse. The exhaust valve opens and pulls fresh air (no more gas) into the exhaust pipes,thru the engine and then the intake valve opens and the gas vapor rich air is pushed out the intake manifold. By repeating this the flooded engine is flushed of the gas, and dries it out. It's not done on the modern engines cause thay are controlled by a computer, and rarely flood. While our planes are working with 1940's technology. walt evans NX140DL ----- Original Message ----- From: TGSTONE236(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, April 01, 2009 4:32 PM Subject: Pietenpol-List: hand proping Some things I don't understand or it doesn't make sense to me. What does turning the prop backwards accomplish? If this is necessary why doesn't the engine with electric start have a reversible starter to do the same as a hand prop engine ? You will have to over look my stupidity as I'm not the sharpest knife in the set. Ted Stone corvair piet builder ------------------------------------------------------------------------- ----- New Low Prices on Dell Laptops - Starting at $399 ________________________________________________________________________________
Date: Apr 01, 2009
When a modern engine floods you turn the key off ,depress the gas peddle to the floor and hold it there,do not pump the gas peddle,turn the key on and turn to start and keep turning with the peddle to the floor.This also work s for vapour locks as well.Nothing to do with Piets but secretly I just kne w you wanted to know.=0A=0A=0A=0A=0A________________________________=0AFrom : walt =0ATo: pietenpol-list(at)matronics.com=0ASent: Wed nesday, April 1, 2009 5:37:30 PM=0ASubject: Re: Pietenpol-List: hand propin g=0A=0A=EF=BB =0AIf the engine is flooded, by turning the engine backwar ds, the valve sequence works in reverse.=0AThe exhaust valve opens and pull s fresh air (no more gas) into the exhaust pipes,thru the engine and then t he intake valve opens and the gas vapor rich air is pushed out the intake m anifold. By repeating this the flooded engine is flushed of the gas, and dr ies it out.=0AIt's not done on the modern engines cause thay are controlled by a computer, and rarely flood.=0AWhile our planes are working with 1940' s technology.=0Awalt evans=0ANX140DL=0A=0A=0A----- Original Message ----- =0AFrom: TGSTONE236(at)aol.com =0ATo: pietenpol-list(at)matronics.com =0ASent: We dnesday, April 01, 2009 4:32 PM=0ASubject: Pietenpol-List: hand proping=0AS ome things I don't understand or it doesn't make sense to me.=0A=0AWhat doe s turning the prop backwards accomplish?=0A=0AIf this is necessary why does n't the engine with electric start have a reversible starter to do the same as a hand prop engine ?=0A=0AYou will have to over look my stupidity as I' m not the sharpest knife in the set.=0A=0ATed Stone=0Acorvair piet builder =0A=0A________________________________=0ANew Low Prices on Dell Laptops - S tarting at $399 =0A=0A=0Ahref="http://www.matronics.com/Navigator?Pietenp ol-List">http://www.matronics.com/Navigator?Pietenpol-List=0Ahref="http:/ /forums.matronics.com">http://forums.matronics.com=0Ahref="http://www.mat ============= ________________________________________________________________________________
Date: Apr 01, 2009
Subject: Mac Zurgis is the date on your computer right?
Mac, Just wondering if your computer's date is correct- or is my inbox me ssed up?- It is dating your email as year 1990.- Just wondering, I almo st thought I had a time machine!- Well I guess a piet is a time machine, ha ha ha. - Shad=0A=0A=0A ________________________________________________________________________________
Date: Apr 01, 2009
Subject: Re: Mac Zurgis is the date on your computer right?
tanks for you email and dont have aidea about these dates never before some one telmy about so please telmy if is a problem --- On Wed, 4/1/09, shad bell wrote: From: shad bell <aviatorbell(at)yahoo.com> Subject: Pietenpol-List: Mac Zurgis is the date on your computer right? Date: Wednesday, April 1, 2009, 6:08 PM Mac, Just wondering if your computer's date is correct- or is my inbox me ssed up?- It is dating your email as year 1990.- Just wondering, I almo st thought I had a time machine!- Well I guess a piet is a time machine, ha ha ha. - Shad =0A=0A=0A ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: turnbuckle cable ends
Date: Apr 02, 2009
I need a number of turnbuckle cable eye ends and have an excess of pin eye ends. I was told that I could drill the pin eye ends to a larger size and chamfer the holes to turn them into cable eyes. Has anyone done this? Since I don't have any cable eye ends to look at how much metal is there between the cable hole and the outside of the fitting? Richard Schreiber lmforge(at)earthlink.net ________________________________________________________________________________
Date: Apr 02, 2009
that one was good, it was dated 2009. - shad=0A=0A=0A ________________________________________________________________________________
Date: Apr 02, 2009
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Hello Rick, - That's what I did with some of my turnbuckles.- The pin and cable eye end are the same but with different holes sizes.- If you are using turnbuckl es rated for 1600 pounds, the thimble hole diameter should be .219 and for 800 pounds rated turnbuckles, the thimble hole diameter is .188 When you drill and chamfer the holes, you will loose the corrosion protecti on it may have. Saludos - Santiago=0A=0A=0A Yahoo! Cocina=0ARecetas pr=E1cticas y comida saludab le=0Ahttp://ar.mujer.yahoo.com/cocina/ ________________________________________________________________________________
Date: Jan 01, 1990
Shad-- My computer is an OLD one and has lost its time (and mind sometimes)--just like me. Mac in Oregon ----- Original Message ----- From: shad bell To: pietenpol-list(at)matronics.com Sent: Wednesday, April 01, 2009 5:08 PM Subject: Pietenpol-List: Mac Zurgis is the date on your computer right? Mac, Just wondering if your computer's date is correct or is my inbox messed up? It is dating your email as year 1990. Just wondering, I almost thought I had a time machine! Well I guess a piet is a time machine, ha ha ha. Shad ------------------------------------------------------------------------- ----- 12:00 AM ________________________________________________________________________________
Subject: wood gear question
Date: Apr 02, 2009
Hi all I am shaping the wood gear legs at the moment and looking at some pictures some have what looks like tightly wraped string around them for what looks like about 2 inches. Is this string? If so what type? Is it of any use or just for looks? Hope I have explained this right Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237454#237454 ________________________________________________________________________________
Subject: Re: wood gear question
Date: Apr 02, 2009
On NX18235 it is waxed nylon cord. It might prevent the wood from splitting but it is also cosmetic. See attached picture. Greg Cardinal ----- Original Message ----- From: "carson" <carsonvella(at)yahoo.com.au> Sent: Thursday, April 02, 2009 6:19 PM Subject: Pietenpol-List: wood gear question > > Hi all > > I am shaping the wood gear legs at the moment and looking at some pictures > some have what looks like tightly wraped string around them for what > looks like about 2 inches. > Is this string? If so what type? Is it of any use or just for looks? > Hope I have explained this right > Carson > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=237454#237454 > > > ________________________________________________________________________________
Date: Apr 02, 2009
I was told to use butchers twine which I believe is cotton string. Then cover it with varnish. It might help with splitting but mine will be more for looks. Chris Sacramento, CA WestCoastPiet.com ----- Original Message ----- From: "carson" <carsonvella(at)yahoo.com.au> Sent: Thursday, April 02, 2009 4:19 PM Subject: Pietenpol-List: wood gear question > > Hi all > > I am shaping the wood gear legs at the moment and looking at some pictures > some have what looks like tightly wraped string around them for what > looks like about 2 inches. > Is this string? If so what type? Is it of any use or just for looks? > Hope I have explained this right > Carson > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=237454#237454 > > > ________________________________________________________________________________
Date: Apr 03, 2009
Greg=3B in the picture you posted=2C I assume the airplane was in some sort of dry fit-up and not in airworthy condition at the time since it looks li ke the bolt that holds the lower end of the lift strut to the fuselage atta ch fitting is not secured. I also see that there is a castellated nut on t hat bolt and wonder if you used a nylock there in the final installation? I love the color=2C fit=2C and finish of your airplane. Very sanitary. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Riblett Airfoil
Date: Apr 03, 2009
Michael, Bill, and Ryan, My sincerest thanks go out to you Fellows. It's hard for me to imagine how much more difficult (time consuming) it must have been for those plans building guys in the '60s to collaborate. I really hope that this plans-built stuff is not a dying art. Truly, Al Lyscars Manchester, NH Jigging the Riblett for GN-1 ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Tuesday, March 31, 2009 11:15 AM Subject: Re: Pietenpol-List: Riblett Airfoil I agree with Ryan, Al. You use the same rib jig for all the ribs. The only difference are the extra cap strip pieces that are shown on the Riblett plan as well as the Pietenpol plan for the end ribs. (the last wing rib before the center section and the last rib at the wing tip.) Build the entire wing with all the aileron Pisces in place. Then using a small hand saw, cut the aileron free. Once free finish up the cut areas both on the free aileron as well as the aileron bay on the wing as per the prints. (As Ryan said. We are referring to the Pietenpol prints.) ________________________________________________________________________________
Date: Apr 03, 2009
You are quite welcome Al. ________________________________________________________________________________
Subject: Fuselage building question
Date: Apr 03, 2009
The fuselage plans call for wedges placed between the braces in two spots. It looks like this is reinforcement for the strut hardware at these points. I this a good interpretation, or should all braces on the fuselage get wedges? Not being a structural engineer, just wanted to see what some others have done, thanks. Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237553#237553 ________________________________________________________________________________
Date: Apr 03, 2009
Subject: Re: Fuselage building question
Reenforcement for the wing strut and landing gear attachment points. Only needed where shown on the plans. Rick On Fri, Apr 3, 2009 at 2:34 PM, chase143 wrote: > > The fuselage plans call for wedges placed between the braces in two spots. > It looks like this is reinforcement for the strut hardware at these points. > I this a good interpretation, or should all braces on the fuselage get > wedges? Not being a structural engineer, just wanted to see what some others > have done, thanks. > Steve > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=237553#237553 > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Apr 03, 2009
Very observant, Oscar. The picture was taken during a fit up prior to first flight. A cotter-pinne d castle nut was eventually fitted, very few Nylock nuts were used on the p lane. The sanitary condition=C2-lasted about 2 or 3 hours. I don't know how peo ple keep their airplanes clean. Are you planning to fly up to Brodhead / Oshkosh this year? We'd all love t o see you there. Greg ----- Original Message ----- From: "Oscar Zuniga " < taildrags @ hotmail .com> Sent: Friday, April 3, 2009 8:09:06 AM GMT -06:00 US/Canada Central Subject: Pietenpol -List: wood gear question Greg; in the picture you posted, I assume the airplane was in some sort of dry fit-up and not in airworthy condition at the time since it looks like t he bolt that holds the lower end of the lift strut to the fuselage attach f itting is not secured.=C2- I also see that there is a castellated nut on that bolt and wonder if you used a nylock there in the final installation? =C2- I love the color, fit, and finish of your airplane.=C2- Very sanitary. =C2- Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto : taildrags @ hotmail .com website at http :// www . flysquirrel .net -======================== ________________________________________________________________________________
Date: Apr 03, 2009
Oscar The Jenney used the same style of landing gear and they wrapped the legs to protect the pilot. Lots fo bad landings in training. I varnished the wood first and then wrapped the legs and soaked the cord to keep it in place. On NX18235 the legs are made of white ash . It's a little heavy but it is holding up good. Dale ----- Original Message ----- From: Oscar Zuniga Sent: 4/3/2009 8:13:18 AM Subject: Pietenpol-List: wood gear question Greg; in the picture you posted, I assume the airplane was in some sort of dry fit-up and not in airworthy condition at the time since it looks like the bolt that holds the lower end of the lift strut to the fuselage attach fitting is not secured. I also see that there is a castellated nut on that bolt and wonder if you used a nylock there in the final installation? I love the color, fit, and finish of your airplane. Very sanitary. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 03, 2009
Rick, Thats awesome! Thanks much! Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237573#237573 ________________________________________________________________________________
Subject: Brodhead/Oshkosh 2009
Date: Apr 03, 2009
Greg asked- >Are you planning to fly up to Brodhead / Oshkosh this year? >We'd all love to see you there. I've planned it a couple of years=2C have all the charts=2C have planned the stops close to other Piet folks or grass strips with fuel nearby=2C all of that- but can't commit. I'd love to go. My wife says "go for it" but then again she gets nervous every weekend that I go out to the hangar and tinker with the airplane. She thinks if I'm tinkering with it=2C it must be broken or unairworthy. The only one who will know for sure will be Corky=2C because my first planned stop is in Shreveport =3Bo) Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Brodhead/Oshkosh 2009
Date: Apr 03, 2009
Oscar, I look forward to seeing you at Brodhead this summer. Hope you are able to make the trip. Ernie Moreno ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Friday, April 03, 2009 7:29 PM Subject: Pietenpol-List: Brodhead/Oshkosh 2009 Greg asked->Are you planning to fly up to Brodhead / Oshkosh this year?>We'd all love to see you there.I've planned it a couple of years, have all the charts, haveplanned the stops close to other Piet folks or grass stripswith fuel nearby, all of that- but can't commit. I'd love togo. My wife says "go for it" but then again she gets nervousevery weekend that I go out to the hangar and tinker with theairplane. She thinks if I'm tinkering with it, it must bebroken or unairworthy.The only one who will know for sure will be Corky, because myfirst planned stop is in Shreveport ;o)Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 03, 2009
Oscar, This is the year to make the trip. We've been enjoying your stories for quite some time and want to see you in person, at Brodhead. The gaggles going into Oshkosh will make that trip segment a piece of cake. Just follow the guy in front of you. San Antonio to Wisconsin and back will be a big trip. Take a few extra days and make the journey, not the destination, the reason for the trip. Flying cross-countries in a Piet is a hoot. See you there........ Greg ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Friday, April 03, 2009 9:29 PM Subject: Pietenpol-List: Brodhead/Oshkosh 2009 Greg asked->Are you planning to fly up to Brodhead / Oshkosh this year?>We'd all love to see you there.I've planned it a couple of years, have all the charts, haveplanned the stops close to other Piet folks or grass stripswith fuel nearby, all of that- but can't commit. I'd love togo. My wife says "go for it" but then again she gets nervousevery weekend that I go out to the hangar and tinker with theairplane. She thinks if I'm tinkering with it, it must bebroken or unairworthy.The only one who will know for sure will be Corky, because myfirst planned stop is in Shreveport ;o)Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 03, 2009
Oscar said: The only one who will know for sure will be Corky, because my first planned stop is in Shreveport ;o) Jim said: And I'll make sure Corky has my phone number so I'll have an idea when to expect you to arrive in Pryor.... Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 03, 2009
We are waiting. Have you a nice hangar, transportation, dinner, king bed, private bath and a big breakfast. Even a well stocked bar since I can't drink anymore. Isabelle and Corky **************Hurry! April 15th is almost here. File your Federal taxes FREE with TaxACT. ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Apr 03, 2009
Subject: piets for sale
I just put in Pietenpol for sale in Google and was surprised at the number of completed ones that were for sale. All with A65 or corvairs. some with 3 hours, some with 900 hours. All were under $15000 and some down to $8500. I guess the economy has hit these guys hard and these guys are trying to get out from under a hanger payment or some such. I may have some money for a Piet in several years. I hope these bargans are still around. Any thoughts? Steve D Just a lurker ________________________________________________________________________________
Date: Apr 04, 2009
I've planned it a couple of years, have all the charts, have planned the stops close to other Piet folks or grass strips with fuel nearby, all of that- but can't commit. I'd love to go. My wife says "go for it" Oscar, Let me know when you will be arriving here at Poplar Grove. It is right on the way, two grass strips,?40 mi. short of your goal and a great fuel stop so you don't have to fill-up at Brodhead. As I remember, last year they didn't have fuel there because of some problem with the pumps. Dan Helsper Poplar Grove, IL ________________________________________________________________________________
Date: Apr 04, 2009
Don't worry Pieters, he'll go. You've seen these types when they get the bug. **************Hurry! April 15th is almost here. File your Federal taxes FREE with TaxACT. ________________________________________________________________________________
Subject: fabric going on
Date: Apr 04, 2009
Well it seems like a long time since I hauled D.J.'s project home from Arizona.and I guess it was 2 years ago-maybe even 3? but finally I have the fabric going on the fuselage and it feels good.I am not sure how much more I'll get done this summer because after this month I'm going back to work on a job that will have me traveling all over Kansas and western Oklahoma and even as far as Beatrice Nebraska. but if I can just get the fuselage painted and sitting on the gear in the next 3 weeks plus-every time I get a chance to blot something on it-it will be going on for good with the exception of having to take the wings off to get it out of the shop after weight and balance.i figure easily another year-but it's looking more like I'll outlive it after all.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237733#237733 ________________________________________________________________________________
From: "Glenn Thomas" <glennthomas(at)flyingwood.com>
Date: Apr 05, 2009
Boulter Plywood - I went there and walked around inside the place. They have a special section of mil spec aircraft grade plywood and their prices are very good (at least they where when I bought my 1/8" Finnish Birch for gussets). Steve, Not sure if the shipping will eat away at your savings getting it locally or closer to home though. I'd call them and have them give you a price shipped. -------- Glenn Thomas N????? http://www.flyingwood.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237811#237811 ________________________________________________________________________________
Date: Apr 05, 2009
Since that's the plane you origninally built, we'd all like to see you there too, Corky. Any chance of seeing you at Brodhead this year? -------- Glenn Thomas N????? http://www.flyingwood.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=237813#237813 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Apr 05, 2009
Subject: slight course deviation to Brodhead/Oshkosh possible
? Corky Writes: We are waiting. Have you a nice hangar, transportation, dinner, king bed, private bath and a big breakfast. Even a well stocked bar since I can't drink anymore. Isabelle and Corky Corky, Would that southern hospitality apply to me as well ? I know I'm a nawtherner (but so is your bride...so...you did good in that regard) but mightent (new word I made up) you make an exception should I fly thru your locale ? You can tell your friends and family that you're harboring me from the Confederate Soldiers. Mikee ________________________________________________________________________________ ________________________________________________________________________________
Date: Apr 05, 2009
Subject: Re: slight course deviation to Brodhead/Oshkosh possible
? Hey Yank. Just found today through geneoloy research that one of my ancestors Henry J Moss was in the 18th La Volunteer Regiment, fought at Shiloh, Yellow Bayou, Bayou Lafouche, Labadieville, Mansfield and Pleasant Hill AS a Private in Company A. Still want to come? We are tough die-hards down here BUT would roll out the carpet for you. Corky and Isabelle **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Date: Apr 05, 2009
Raymond wrote- >I figure easily another year-but it's looking more like I'll outlive it af ter all. That's funny... Doc Mosher reports in the most recent issue of the Brodhead Pietenpol Association Newsletter (I just got mine yesterday) that Raymond Hanover=2C N34RH=2C is flying his new Air Camper! Congratulations! Simila rly=2C Doc reports that Jim Markle has sold his Ford-powered NX25JM to Jeff Masessa of Rockaway=2C NJ. What's going on here? Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: fabric going on
Date: Apr 05, 2009
Wow! Rockaway, that's like 5 mi from my house. I'll have to talk to him walt evans NX140DL ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Sunday, April 05, 2009 10:40 PM Subject: Pietenpol-List: fabric going on Raymond wrote- >I figure easily another year-but it's looking more like I'll outlive it after all. That's funny... Doc Mosher reports in the most recent issue of the Brodhead Pietenpol Association Newsletter (I just got mine yesterday) that Raymond Hanover, N34RH, is flying his new Air Camper! Congratulations! Similarly, Doc reports that Jim Markle has sold his Ford-powered NX25JM to Jeff Masessa of Rockaway, NJ. What's going on here? Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 05, 2009
I forgot to renew the N25JM registration with the FAA....and some character from NJ snapped "MY" 25JM right up. DRAT! And 899JM, my second choice, is already registered...to a 737 somewhere. Very disappointing. Oh well. This afternoon when I put another coat of varnish on the jury struts and a couple of 1/8" ply panel pieces....the rest of the Pietenpol was sitting right there in the workshop... :-) But Doc got at least one thing right, it's Ford powered. I finished up most of the fuel lines and mounted the fuel valve last week and one end of that line definitely goes to a Model A engine! I may just have to bolt that prop back on so I can hear it come to life again. I doubt that anything short of a "family need" would ever get this thing out of my life.... Jim in Pryor ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Sunday, April 05, 2009 9:40 PM Subject: Pietenpol-List: fabric going on Raymond wrote- >I figure easily another year-but it's looking more like I'll outlive it after all. That's funny... Doc Mosher reports in the most recent issue of the Brodhead Pietenpol Association Newsletter (I just got mine yesterday) that Raymond Hanover, N34RH, is flying his new Air Camper! Congratulations! Similarly, Doc reports that Jim Markle has sold his Ford-powered NX25JM to Jeff Masessa of Rockaway, NJ. What's going on here? Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 06, 2009
Actually, the Appalachians rise about as high above the surrounding terrain as do the Rockies. Mount Mitchell, in western North Carolina is 6,684' above sea level, but the surrounding terrain is only 595' MSL, so it rises over 6,000' above its surroundings. The land around the Rockies is nearly 6,000' MSL, so only the peaks that are over 12,000' are truly "taller" than the highest peaks in the Appalachians. Density altitude is another matter entirely. Neither mountain range has a wealth of good forced landing sites. Here's typical terrain in the Blue Ridge on the way to Brodhead last year. At about this point in the trip, my GPS indicated I was making 27 knots, groundspeed. Jack Phillips Happy I don't have to get any higher than about 4500' to get to Brodhead. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, April 06, 2009 1:55 PM Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? 4000 ft. high "mounds of dirt" ain't mountains! ________________________________________________________________________________
Date: Apr 06, 2009
Jack=3B what's the problem? I see two candidate landing sites at about you r 2 o'clock position as mountaintop clearings. Set up best glide and get o n with it! =3Bo) Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 06, 2009
? Don't know if they knew each other but I'll bet your ass they recognized each other's yell. This geneology stuff is interesting. Yesterday I found out I was related to Martha Washington through marriage and today I found a line linking me to ole Georgie Patton through marriage. I must be a tough old fart Corky **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Subject: Re: slight course deviation to Brodhead/Oshkoshpossible
Date: Apr 06, 2009
Lots of broccoli If you go into that , it'll just close in around you, won't even make a hole. walt evans NX140DL ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Monday, April 06, 2009 3:24 PM Subject: RE: Pietenpol-List: slight course deviation to Brodhead/Oshkoshpossible ? Actually, the Appalachians rise about as high above the surrounding terrain as do the Rockies. Mount Mitchell, in western North Carolina is 6,684' above sea level, but the surrounding terrain is only 595' MSL, so it rises over 6,000' above its surroundings. The land around the Rockies is nearly 6,000' MSL, so only the peaks that are over 12,000' are truly "taller" than the highest peaks in the Appalachians. Density altitude is another matter entirely. Neither mountain range has a wealth of good forced landing sites. Here's typical terrain in the Blue Ridge on the way to Brodhead last year. At about this point in the trip, my GPS indicated I was making 27 knots, groundspeed. Jack Phillips Happy I don't have to get any higher than about 4500' to get to Brodhead. ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, April 06, 2009 1:55 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? 4000 ft. high "mounds of dirt" ain't mountains! ________________________________________________________________________________
Date: Apr 06, 2009
? You just wait til get you **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Date: Apr 06, 2009
? Hell, I found out that Lady Godiva was my blood kin **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Date: Apr 06, 2009
Jack, which tree would go for if you lost your engine? Gardiner ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Monday, April 06, 2009 3:24 PM Subject: RE: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Actually, the Appalachians rise about as high above the surrounding terrain as do the Rockies. Mount Mitchell, in western North Carolina is 6,684' above sea level, but the surrounding terrain is only 595' MSL, so it rises over 6,000' above its surroundings. The land around the Rockies is nearly 6,000' MSL, so only the peaks that are over 12,000' are truly "taller" than the highest peaks in the Appalachians. Density altitude is another matter entirely. Neither mountain range has a wealth of good forced landing sites. Here's typical terrain in the Blue Ridge on the way to Brodhead last year. At about this point in the trip, my GPS indicated I was making 27 knots, groundspeed. Jack Phillips Happy I don't have to get any higher than about 4500' to get to Brodhead. ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, April 06, 2009 1:55 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? 4000 ft. high "mounds of dirt" ain't mountains! ________________________________________________________________________________
Date: Apr 06, 2009
The shortest, softest looking one I could find. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gardiner Mason Sent: Monday, April 06, 2009 7:56 PM Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Jack, which tree would go for if you lost your engine? Gardiner ----- Original Message ----- From: Jack Phillips <mailto:pietflyr(at)bellsouth.net> Sent: Monday, April 06, 2009 3:24 PM Subject: RE: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Actually, the Appalachians rise about as high above the surrounding terrain as do the Rockies. Mount Mitchell, in western North Carolina is 6,684' above sea level, but the surrounding terrain is only 595' MSL, so it rises over 6,000' above its surroundings. The land around the Rockies is nearly 6,000' MSL, so only the peaks that are over 12,000' are truly "taller" than the highest peaks in the Appalachians. Density altitude is another matter entirely. Neither mountain range has a wealth of good forced landing sites. Here's typical terrain in the Blue Ridge on the way to Brodhead last year. At about this point in the trip, my GPS indicated I was making 27 knots, groundspeed. Jack Phillips Happy I don't have to get any higher than about 4500' to get to Brodhead. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, April 06, 2009 1:55 PM Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? 4000 ft. high "mounds of dirt" ain't mountains! ________________________________________________________________________________
Subject: gas tank float
Date: Apr 06, 2009
What are you using for a float in your tanks? I guess there are still a lot of car gas tanks that use brass floats on their gage senders and maybe I can check out a friends junkyard and find a good one to use in my fuel tank.any ideas on which models might have the best size and shape to fit into the filler neck and have enough buoyancy to raise the brass rod ?Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238067#238067 ________________________________________________________________________________
Date: Apr 06, 2009
Jack, I am taxiing my piet now, but have not done the paper work yet. CG is in range and wt is 771 so far. I hope to have it ready for Brodhead but I am not going to push it as I still have my Cessna 140 tomake the trip.. Cheers, Gardiner. ----- Original Message ----- From: Gardiner Mason To: pietenpol-list(at)matronics.com Sent: Monday, April 06, 2009 7:55 PM Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Jack, which tree would go for if you lost your engine? Gardiner ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Monday, April 06, 2009 3:24 PM Subject: RE: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Actually, the Appalachians rise about as high above the surrounding terrain as do the Rockies. Mount Mitchell, in western North Carolina is 6,684' above sea level, but the surrounding terrain is only 595' MSL, so it rises over 6,000' above its surroundings. The land around the Rockies is nearly 6,000' MSL, so only the peaks that are over 12,000' are truly "taller" than the highest peaks in the Appalachians. Density altitude is another matter entirely. Neither mountain range has a wealth of good forced landing sites. Here's typical terrain in the Blue Ridge on the way to Brodhead last year. At about this point in the trip, my GPS indicated I was making 27 knots, groundspeed. Jack Phillips Happy I don't have to get any higher than about 4500' to get to Brodhead. ------------------------------------------------------------------------- --- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, April 06, 2009 1:55 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? 4000 ft. high "mounds of dirt" ain't mountains! ________________________________________________________________________________
Date: Apr 06, 2009
I'm useing a big cork that I bought at the local Ace hardware. That's what the Aeronca that I fly has for a float and it works fine. Ed G > Subject: Pietenpol-List: gas tank float > From: rhano(at)att.net > Date: Mon=2C 6 Apr 2009 17:36:15 -0700 > To: pietenpol-list(at)matronics.com > > > What are you using for a float in your tanks? I guess there are still a l ot of car gas tanks that use brass floats on their gage senders and maybe I can check out a friends junkyard and find a good one to use in my fuel tan k.any ideas on which models might have the best size and shape to fit into the filler neck and have enough buoyancy to raise the brass rod ?Raymond > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238067#238067 > > > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ Quick access to your favorite MSN content and Windows Live with Internet Ex plorer 8. http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid=B037 MSN55C0701A ________________________________________________________________________________
Date: Apr 06, 2009
Subject: Re: gas tank float
Did you coat that cork with varnish or anything Ed? rick On Mon, Apr 6, 2009 at 8:13 PM, Ed G. wrote: > I'm useing a big cork that I bought at the local Ace hardware. That's what > the Aeronca that I fly has for a float and it works fine. Ed G > > > Subject: Pietenpol-List: gas tank float > > From: rhano(at)att.net > > Date: Mon, 6 Apr 2009 17:36:15 -0700 > > To: pietenpol-list(at)matronics.com > > > > > > What are you using for a float in your tanks? I guess there are still a > lot of car gas tanks that use brass floats on their gage senders and maybe I > can check out a friends junkyard and find a good one to use in my fuel > tank.any ideas on which models might have the best size and shape to fit > into the filler neck and have enough buoyancy to raise the brass rod > ?Raymond > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=238067#238067 > > > > > > > > > > > > > > > > ------------------------------ > Quick access to your favorite MSN content and Windows Live with Internet > Explorer 8. Download FREE now!<http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid=B037MSN55C0701A> > > * > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Apr 06, 2009
I coated mine in epoxy. >Did you coat that cork with varnish or anything Ed? ________________________________________________________________________________
Subject: best place to buy turnbuckles
Date: Apr 06, 2009
Any thoughts on the best (as in cheapest) place to purchase turnbuckles the se days? Aircraft Spruce is around $28/unit as is Wicks. Tom B. ________________________________________________________________________________
Date: Apr 06, 2009
Raymond=3B On 41CC=2C Corky epoxied two large corks butt-to-butt on the end of the bra ss rod that makes up the fuel level indicator right out in front of the pil ot and passenger. These corks are larger than you used to see on a regular Thermos bottle=2C about the size of what you'd use on a 5-gallon bottle of water that Oasis or Ozarka used to deliver to your house for drinking wate r. The two corks are epoxied onto the end of the rod and then liberally pa inted with epoxy=2C and I mean liberally. The pair of corks float well in avgas. You could substitute a brass ball like what is used in a toilet bal lcock but that would be overkill and you couldn't fit it in through a stand ard filler neck. Some folks have used ping-pong balls but those seem too f ragile to me. Corks liberally coated with epoxy are pretty rugged and easy to come by. Corky "calibrated" the brass rod of the float indicator by filing notches i n the rod at every gallon from "full" down to "unusable fuel only remaining ". When I had the fuel tank out while rebuilding the airplane after the no se-over=2C I very carefully checked the calibration by adding one gallon of water to the fuel tank at a time and Corky's calibration was about as prec ise as this engineer could ever arrive at by computation=2C evaluation=2C m icromanagement=2C extrapolation=2C or persuasion. In other words=2C it's a s accurate as can be read while in flight in an open-cockpit airplane and p lenty close enough. I painted the rod red from the final four gallons to t he stop=2C and actually none of that last four gallons should be considered usable for safe flight. I painted the rod yellow from 8 gallons to 4 gall ons=2C as a caution that the airplane is in its final hour of safe=2C comfo rtable VFR flight. The first 8 gallons below the yellow are completely usa ble as two good hours of flight in which the pilot's rear end=2C sanity=2C hearing=2C and good judgement are unimpaired and the airplane is willing an d ready to go wherever it's pointed. Your mileage may vary=2C but I'll bet it's not by much. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 06, 2009
I used a fishing rod handle made of cork, purchased from Bass Pro Shop. Any fishing store should have something similar. It is probably roughly 1-1/8" diameter and 2" tall. It is coated in System Three T-88 epoxy, which has lasted several years with no problems whatsoever, even in auto fuel. Most epoxys are not impervious to ethanol though, so you should always test for ethanol. T-88 is impervious to gasoline or AvGas. I tried a brass rod first and it was too heavy...wouldn't float. I ordered some 1/8" aluminum rod from Aircraft Spruce (after much searching for it elsewhere), and it works great. I drilled the aluminum rod just below and above the cork, then used my smallest safety wire to lock the cork in place. A single strand ties the bottom of the rod to the hole just above the cork, so even if the rod breaks off at a hole, the rod will come out together. Using a single cotter pin on top of the cork instead can cause unexpected loss of components in the fuel tank. I spent the night in a stranger's house in Arkansas as a result of that one time... Steve Ruse Norman, OK ----- Original Message ----- From: "skellytown flyer" <rhano(at)att.net> Sent: Monday, April 06, 2009 7:36 PM Subject: Pietenpol-List: gas tank float > > What are you using for a float in your tanks? I guess there are still a > lot of car gas tanks that use brass floats on their gage senders and maybe > I can check out a friends junkyard and find a good one to use in my fuel > tank.any ideas on which models might have the best size and shape to fit > into the filler neck and have enough buoyancy to raise the brass rod > ?Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238067#238067 > > > ________________________________________________________________________________
Date: Apr 06, 2009
Subject: Re: best place to buy turnbuckles
I hope you foun these plase because I neede too. probably if you found a bo neyard is de best but here in ca, is not to mouch were looking for --- On Mon, 4/6/09, TOM MICHELLE BRANT wrote: From: TOM MICHELLE BRANT <tmbrant(at)msn.com> Subject: Pietenpol-List: best place to buy turnbuckles Date: Monday, April 6, 2009, 8:08 PM #yiv917531085 .hmmessage P { margin:0px;padding:0px;} #yiv917531085 { font-size:10pt;font-family:Verdana;} Any thoughts on the best (as in cheapest) place to purchase turnbuckles the se days?- Aircraft Spruce is around $28/unit as is Wicks. Tom B. =0A=0A=0A ________________________________________________________________________________
Date: Apr 06, 2009
for piet tanks size the think now is a volkswagen, karmanghia or beatle the y have almost the sam zise the tank I trate to put some electric uned like old cars used I dont like a cork floets --- On Mon, 4/6/09, Ed G. wrote: From: Ed G. <flyboy_120(at)hotmail.com> Subject: RE: Pietenpol-List: gas tank float Date: Monday, April 6, 2009, 7:13 PM #yiv1615900122 .hmmessage P { margin:0px;padding:0px;} #yiv1615900122 { font-size:10pt;font-family:Verdana;} I'm useing a big cork that I bought at the local Ace hardware.-That's wha t the Aeronca that I fly has for a float and it works fine.-- Ed G - > Subject: Pietenpol-List: gas tank float > From: rhano(at)att.net > Date: Mon, 6 Apr 2009 17:36:15 -0700 > To: pietenpol-list(at)matronics.com > > > What are you using for a float in your tanks? I guess there are still a l ot of car gas tanks that use brass floats on their gage senders and maybe I can check out a friends junkyard and find a good one to use in my fuel tan k.any ideas on which models might have the best size and shape to fit into the filler neck and have enough buoyancy to raise the brass rod ?Raymond > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238067#238067 > > > > > > > Quick access to your favorite MSN content and Windows Live with Internet Ex plorer 8. Download FREE now! =0A=0A=0A ________________________________________________________________________________
Date: Apr 07, 2009
In a message dated 4/6/2009 10:29:30 P.M. Central Daylight Time, taildrags(at)hotmail.com writes: liberally. The pair of corks float well in avgas. You could substitute a brass ball like what is used in a toilet ballcock but that would be overkill and you couldn't fit it in through a standard filler neck. Some folks have used ping-pong balls but those seem too fragile to me. Corks liberally coated with epoxy are pretty rugged and easy to come by. Oscar_ Excuse my butting in but I feel a correction is due. Those corks are dipped in a solution of gas tank sealer, Hirsch Co..I used to build Model Ts and early 4 cyl Dodge Bros cars and just happened to have a half of a can remaining. Corky **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Date: Apr 06, 2009
From: Andrew M Eldredge <andrew.eldredge(at)gmail.com>
This was taken over bryce canyon at about 10,000 feet. Route was Richfield , Utah, left turn at Panguitch Utah, and putting down in Page, Arizona. BTW, I was freezing my butt off. Next picture is getting the green light for takeoff at Flagstaff. They asked what I was doing flying cross country without a radio. I told them I was having the time of my life. Perhaps I was nuts, but it was true. Andrew, NX7229R Sahuarita AZ On Mon, Apr 6, 2009 at 6:09 PM, Gardiner Mason wrote : > Jack, I am taxiing my piet now, but have not done the paper work yet. C G > is in range and wt is 771 so far. I hope to have it ready for Brodhead bu t I > am not going to push it as I still have my Cessna 140 tomake the trip.. > Cheers, Gardiner. > > ----- Original Message ----- > *From:* Gardiner Mason > *To:* pietenpol-list(at)matronics.com > *Sent:* Monday, April 06, 2009 7:55 PM > *Subject:* Re: Pietenpol-List: slight course deviation to Brodhead/Oshkos h > possible ? > > Jack, which tree would go for if you lost your engine? Gardiner > > ----- Original Message ----- > *From:* Jack Phillips > *To:* pietenpol-list(at)matronics.com > *Sent:* Monday, April 06, 2009 3:24 PM > *Subject:* RE: Pietenpol-List: slight course deviation to Brodhead/Oshkos h > possible ? > > Actually, the Appalachians rise about as high above the surrounding > terrain as do the Rockies. Mount Mitchell, in western North Carolina is > 6,684=92 above sea level, but the surrounding terrain is only 595=92 MSL, so it > rises over 6,000=92 above its surroundings. The land around the Rockies is > nearly 6,000=92 MSL, so only the peaks that are over 12,000=92 are truly > =93taller=94 than the highest peaks in the Appalachians. Density altitud e is > another matter entirely. > > > Neither mountain range has a wealth of good forced landing sites. Here =92s > typical terrain in the Blue Ridge on the way to Brodhead last year. At > about this point in the trip, my GPS indicated I was making 27 knots, > groundspeed. > > > Jack Phillips > > Happy I don=92t have to get any higher than about 4500=92 to get to Brodh ead. > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Rick Holland > *Sent:* Monday, April 06, 2009 1:55 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: slight course deviation to Brodhead/Oshkos h > possible ? > > > 4000 ft. high "mounds of dirt" ain't mountains! > > > ** > > * * > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c * > > * > =========== w.matronics.com/Navigator?Pietenpol-List =========== =========== com/contribution =========== > * > > -- Andrew M. Eldredge Sahuarita, AZ ________________________________________________________________________________
Date: Apr 07, 2009
Subject: Re: Pietenpol old slick mag capaacitors
Anybody know where I can find two capacitors for Slick 447 mags.? Part number is 14-48A. I am trying to get a 85 cont. to run. Thanks Ken Conrad in cold wet Iowa 563 528 9341 (cell) or 563 285 4073 **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Date: Apr 07, 2009
From: Tim Verthein <minoxphotographer(at)yahoo.com>
Subject: From the Newswire at work this morning-Sorta OT
>From the newswire this morning: Plane takes off without pilot An aircraft took off on its own when the pilot could not get into the cockpit in time after starting the propellor manually. Hundreds of visitors to an air show at Goodwood airfield watched in horror as the runaway biplane took off, soared into the air and then crashed into trees, reports the Daily Telegraph. Had it cleared the trees it is believed the plane, which was headed towards nearby Chichester, West Sussex, could have flown for around 150 miles on a full tank of fuel. The small plane had just been refuelled before the incident and its pilots had 'swung' the propellers to restart the engine before getting inside to fly it. But the aircraft - a 1940 model built in the style of a Tiger Moth - began moving before the pilot had a chance to board it. Retired aircraft engineer Malcolm Phillips, 67 of Emsworth, Hants, said: "There were hundreds of people there watching as the plane ran amok, haring round in circles. "We didn't know which way it was going to go and it was worrying that it could head towards the crowd, other planes or the clubhouse." Mr Phillips added: "Normally the idea is that you swing the propellers and have the handbrake on and chocks under the wheels. You also need to make sure the throttle is only set at low revs. "Something clearly went wrong and it jumped over the chocks - I suspect what might have happened is that the throttle became loose." Be careful out there! Tim in Bovey ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: fuse covering/cable routing
Date: Apr 07, 2009
Good morning everyone! Did you guys cover the fuselage under the horizontal stabilizer or leave it open? Seems open would be very nice, almost necessary for access, but would certainly let water inside very easily. Also... Anybody have some good tricks for estimating where to cut the holes in the covering for control cables to exit/enter? Thanks, Douwe ________________________________________________________________________________
Subject: Re: fuse covering/cable routing
Date: Apr 07, 2009
Hi Douwe, Before I disassembled for covering, I taped some paper together onto the structure where the cables exited and made "maps" where the exit points were. I have no clue how it could be done after the fact.... maybe a laser (if its not painted yet). Dan Helsper Poplar Grove, IL ________________________________________________________________________________
Date: Apr 07, 2009
B & B Aircraft Supplies 202 N Center St Gardner, KS 66030 (913) 884-5930 ----- Original Message ----- From: jorge lizarraga To: pietenpol-list(at)matronics.com Sent: Monday, April 06, 2009 11:37 PM Subject: Re: Pietenpol-List: best place to buy turnbuckles I hope you foun these plase because I neede too. probably if you found a boneyard is de best but here in ca, is not to mouch were looking for --- On Mon, 4/6/09, TOM MICHELLE BRANT wrote: From: TOM MICHELLE BRANT <tmbrant(at)msn.com> Subject: Pietenpol-List: best place to buy turnbuckles To: "pietenpol-list(at)matronics.com" Date: Monday, April 6, 2009, 8:08 PM Any thoughts on the best (as in cheapest) place to purchase turnbuckles these days? Aircraft Spruce is around $28/unit as is Wicks. Tom B. " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 07, 2009
Hi Tom I have bought turnbuckles from B&B aircraft. They sell them by the piece but if you give them the AN numbers from the ACS cataloge they will s end you what you need. They are also not shiny new pieces like ACS's they s eem to be new/old stock but perfectly fine hardware. I forget what the last ones I bought for the drag wires in my wings cost but I'm thinking like 8 bucks a piece. They are also great people to work with. Ed G. From: tmbrant(at)msn.com Subject: Pietenpol-List: best place to buy turnbuckles Date: Mon=2C 6 Apr 2009 22:08:18 -0500 Any thoughts on the best (as in cheapest) place to purchase turnbuckles the se days? Aircraft Spruce is around $28/unit as is Wicks. Tom B. _________________________________________________________________ Rediscover Hotmail=AE: Now available on your iPhone or BlackBerry http://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_ Mobile1_042009 ________________________________________________________________________________
Subject: Pietenpol old Slick mag capacitors
Date: Apr 07, 2009
Ken=3B you might try Arnold Kesselring=2C d/b/a "Arn-Air"=2C right there in your state of Iowa. Contact info here: Arn-Air Attn Arnold Kesselring PO Box 148 Bayard=2C IA 50029 USA Phone: 712-651-2255 Fax: 712-651-2258 He made a new ignition harness for one of my mags and I believe he works on older stuff so he should be able to help you. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 07, 2009
I bought all my turnbuckles at B&B aircraft sales in I bought all my turn buckles at B&B aircraft sales in Gardner, KS. Much cheaper than AS or Wicks. They deal in a lot of surplus. Phone no. is 913-884-5930 Jim In a message dated 4/6/2009 11:38:08 P.M. Central Daylight Time, flightwood(at)yahoo.com writes: I hope you foun these plase because I neede too. probably if you found a boneyard is de best but here in ca, is not to mouch were looking for --- On Mon, 4/6/09, TOM MICHELLE BRANT wrote: From: TOM MICHELLE BRANT <tmbrant(at)msn.com> Subject: Pietenpol-List: best place to buy turnbuckles Date: Monday, April 6, 2009, 8:08 PM Any thoughts on the best (as in cheapest) place to purchase turnbuckles these days? Aircraft Spruce is around $28/unit as is Wicks. Tom B. " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Date: Apr 07, 2009
Try this http://www.mustangsunlimited.com/itemdy00.asp?T1=240075+01 Works for me Hans -----Original Message----- From: skellytown flyer <rhano(at)att.net> Sent: Mon, 6 Apr 2009 7:36 pm Subject: Pietenpol-List: gas tank float What are you using for a float in your tanks? I guess there are still a lot of car gas tanks that use brass floats on their gage senders and maybe I can check out a friends junkyard and find a good one to use in my fuel tank.any ideas on which models might have the best size and shape to fit into the filler neck and have enough buoyancy to raise the brass rod ?Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238067#238067 ________________________________________________________________________________
Date: Apr 07, 2009
Does anyone have a list of all the turnbuckles and AN numbers needed to build a piet ? John **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! %3D62%26bcd%3DAprilfooterNO62) ________________________________________________________________________________
Date: Apr 07, 2009
Try B&B Supply, they usually have the best prices. Last number I have for them is (913-884-5930). No website that I know of. Chris Sacramento, CA WestCoastPiet.com ----- Original Message ----- From: TOM MICHELLE BRANT To: pietenpol-list(at)matronics.com Sent: Monday, April 06, 2009 8:08 PM Subject: Pietenpol-List: best place to buy turnbuckles Any thoughts on the best (as in cheapest) place to purchase turnbuckles these days? Aircraft Spruce is around $28/unit as is Wicks. Tom B. ________________________________________________________________________________
Date: Apr 07, 2009
Dowue, make a cardboard template to simulate the covering, and run the cabl es with the tail installed and cut slits in the cardboard where needed.- Simply lay the cardboard over the covering after it is installed and cut yo ur cable exits.- One other trick I learded from the Old Man, was to make an oversized-tear dropped shaped piece of fabric, and a smaller tear shap ed piece of leather (for the cable exits) and sew the leather to the fabric with rib lacing cord etc, then glue the fabric patch(with leather sewed on )-to the fabric on the fuselage.- This will not peel off like so many o f the glued on leather patches, the dacron sticks to dacron much, much bete r than leather does. - Just some tricks to try, Shad=0A=0A=0A ________________________________________________________________________________
Date: Apr 07, 2009
Subject: Re: pilotless flights
You guys might remember a simmilar incident that happened here in Ohio abou t 8-10 years ago.- A -7AC champ did something simmilar but no one was a round it when it started (supposidly).- A guy flew to breakfast and the e ngine quit while taxing to the ramp, well I guess the pushed it of the runw ay and forgot to shut the mags off.- Then after-he walked away from the airplane the engine kicked back due to a hot spot in the cylinder etc.- The champ took off and flew- 100 miles or so untill the gas ran out, and landed in a field in eastern ohio.- I remember listening in to CMH approa ch on the base unit, at DLZ where I was the Line boy, and the state highway patrol was folowing it in a helicopter untill the heli got low on fuel.- The HW patrol heli was at 9000 ft when he turned back for fuel.- I guess those 7 AC's fly like a champ, pilot or not. - I know this story sounds far fetched, but look it up if you do not believe me! Airport was Urbana Grimes In Urbana Ohio, between 1997-2002 or so. - Shad=0A=0A=0A ________________________________________________________________________________
Subject: pilotless flights
Date: Apr 07, 2009
I remember that story and I can believe it. I fly a Champ and the only diff icult thing about learning to fly it was getting it to stay down on the run way when landing. they just want to keep flying. Ed Date: Tue=2C 7 Apr 2009 09:12:04 -0700 From: aviatorbell(at)yahoo.com Subject: Re: Pietenpol-List: pilotless flights You guys might remember a simmilar incident that happened here in Ohio abou t 8-10 years ago. A 7AC champ did something simmilar but no one was aroun d it when it started (supposidly). A guy flew to breakfast and the engine quit while taxing to the ramp=2C well I guess the pushed it of the runway a nd forgot to shut the mags off. Then after he walked away from the airplan e the engine kicked back due to a hot spot in the cylinder etc. The champ took off and flew 100 miles or so untill the gas ran out=2C and landed in a field in eastern ohio. I remember listening in to CMH approach on the ba se unit=2C at DLZ where I was the Line boy=2C and the state highway patrol was folowing it in a helicopter untill the heli got low on fuel. The HW pa trol heli was at 9000 ft when he turned back for fuel. I guess those 7 AC' s fly like a champ=2C pilot or not. I know this story sounds far fetched=2C but look it up if you do not believ e me! Airport was Urbana Grimes In Urbana Ohio=2C between 1997-2002 or so. Shad _________________________________________________________________ Rediscover Hotmail=AE: Get quick friend updates right in your inbox. http://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_ Updates1_042009 ________________________________________________________________________________
Subject: Brodhead
Date: Apr 07, 2009
My family and I have decided to make a family trip to Brodhead this summer. It has been recommended by many that I attend, and I can see how the exposure would be an enormous help to my project, not to mention what is sure to be some good ol camaraderie. It is on the calendar and I've already requested the time off. That being said, can someone help us to plan accordingly? I mean, we are pretty good planners, but we just don't know what to expect. We are planning to drive up and tent camp and we plan to bring most of our normal camping gear, to include food and the necessary equipment to prepare it, but we are unsure of other accommodations, such as water, electricity, showers, restrooms, etc. We are normally pretty flexible, but would prefer to pack/plan accordingly. I've tried doing a search for "Brodhead", "Fly-In" and other key words... as you can imagine, I received tons of posts that may or may not have been related to the actual event. I've also looked at the Chapter 431 and BPA sites, but I've been unable to gain much in the way of details... perhaps I overlooked the information. Any suggestions for us newbies? -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238174#238174 ________________________________________________________________________________
Subject: Brodhead
Date: Apr 07, 2009
Mark: Food at Brodhead is catered if you want it. I usually flyin with a tent, sleeping bag, clothes and a camera. There are restaurants in Brodhead if you don't want to eat on the field. There is usually so much going on at the field, I hate to leave, unless I am goinh to dinner with friends. Rick Schreiber > [Original Message] > From: K5YAC <hangar10(at)cox.net> > To: > Date: 4/7/2009 1:08:01 PM > Subject: Pietenpol-List: Brodhead > > > My family and I have decided to make a family trip to Brodhead this summer. It has been recommended by many that I attend, and I can see how the exposure would be an enormous help to my project, not to mention what is sure to be some good ol camaraderie. It is on the calendar and I've already requested the time off. > > That being said, can someone help us to plan accordingly? I mean, we are pretty good planners, but we just don't know what to expect. We are planning to drive up and tent camp and we plan to bring most of our normal camping gear, to include food and the necessary equipment to prepare it, but we are unsure of other accommodations, such as water, electricity, showers, restrooms, etc. We are normally pretty flexible, but would prefer to pack/plan accordingly. > > I've tried doing a search for "Brodhead", "Fly-In" and other key words... as you can imagine, I received tons of posts that may or may not have been related to the actual event. I've also looked at the Chapter 431 and BPA sites, but I've been unable to gain much in the way of details... perhaps I overlooked the information. > > Any suggestions for us newbies? > > -------- > Mark > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238174#238174 > > ________________________________________________________________________________
Subject: looking thru old pics
Date: Apr 07, 2009
reaching for the ground walt evans NX140DL ________________________________________________________________________________
Subject: looking through old pics
Date: Apr 07, 2009
Walt=3B I wanna go fly!!! What a clean airplane you have. What's that little box thingie that you have zip-tied to the port side caba ne brace strut? Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 07, 2009
Subject: =?UTF-8?Q?Check out Tailspin's Tales: =A2 Bird ?= =?UTF-8?Q?In
The Cornfield? _Tailspin's Tales: =A2 Bird In The Cornfield_ (http://tailspinstales.blogspot.com/2009/03/bird-in-cornfield.html) Not quite a 7AC or a Piet, but still landed pilotless in a cornfield! **************Feeling the pinch at the grocery store? Make dinner for $10 o r less. (http://food.aol.com/frugal-feasts?ncid=emlcntusfood00000001) ________________________________________________________________________________
Subject: Re: looking through old pics
Date: Apr 07, 2009
I have an old Panasonic camcorder that I put in there to archive all the flights. Then put them on Youtube. Keyword Pietenpol What a concept,,,,hahahahahaha PS with my friend don and with my other friend don walt evans NX140DL ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Tuesday, April 07, 2009 5:49 PM Subject: Pietenpol-List: looking through old pics Walt; I wanna go fly!!! What a clean airplane you have. What's that little box thingie that you have zip-tied to the port side cabane brace strut? Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 07, 2009
Friend of mine gave me a gift of a fuel tank float for two of my projects. First a FFP 404 and secondly for my Piet which I fly now. I emailed him tonight. Here is his response. Walt, Yes. 1/16" SS rod. The best epoxy is called, "JB Weld" It is basically gasoline proof and seals the two 1/16" holes you have to drill in the ping pong ball. JB Weld is sold at most auto parts stores...NAPA for instance also Advance Auto. I also made some with TWO balls on one rod to get more buoyancy. But if you keep the SS rod thin and not to long it will float on one ball. Cook It works beautifully. walt evans NX140DL ----- Original Message ----- From: "skellytown flyer" <rhano(at)att.net> Sent: Monday, April 06, 2009 8:36 PM Subject: Pietenpol-List: gas tank float > > What are you using for a float in your tanks? I guess there are still a > lot of car gas tanks that use brass floats on their gage senders and maybe > I can check out a friends junkyard and find a good one to use in my fuel > tank.any ideas on which models might have the best size and shape to fit > into the filler neck and have enough buoyancy to raise the brass rod > ?Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238067#238067 > > > ________________________________________________________________________________
Date: Apr 07, 2009
My float is like Corky's. My rod is Stainless steel welding rod. The tank holds 12.6 gallons. The tank is just behind the firewall. I put 4 gallons of gas in the tank, put in the float and cap and then bent the rod at the top. The rod goes thru a small tube brazed in the cap. The bend hits the cap when there is still 4 gallons left, ~ 1 hour of flying if throttled back. My engine is the 65 Continental. My gas gage is a calibrated paint stirring stick--Jim Lagowski ----- Original Message ----- From: Oscar Zuniga To: Pietenpol List Sent: Monday, April 06, 2009 11:27 PM Subject: Pietenpol-List: gas tank float Raymond; On 41CC, Corky epoxied two large corks butt-to-butt on the end of the brass rod that makes up the fuel level indicator right out in front of the pilot and passenger. These corks are larger than you used to see on a regular Thermos bottle, about the size of what you'd use on a 5-gallon bottle of water that Oasis or Ozarka used to deliver to your house for drinking water. The two corks are epoxied onto the end of the rod and then liberally painted with epoxy, and I mean liberally. The pair of corks float well in avgas. You could substitute a brass ball like what is used in a toilet ballcock but that would be overkill and you couldn't fit it in through a standard filler neck. Some folks have used ping-pong balls but those seem too fragile to me. Corks liberally coated with epoxy are pretty rugged and easy to come by. Corky "calibrated" the brass rod of the float indicator by filing notches in the rod at every gallon from "full" down to "unusable fuel only remaining". When I had the fuel tank out while rebuilding the airplane after the nose-over, I very carefully checked the calibration by adding one gallon of water to the fuel tank at a time and Corky's calibration was about as precise as this engineer could ever arrive at by computation, evaluation, micromanagement, extrapolation, or persuasion. In other words, it's as accurate as can be read while in flight in an open-cockpit airplane and plenty close enough. I painted the rod red from the final four gallons to the stop, and actually none of that last four gallons should be considered usable for safe flight. I painted the rod yellow from 8 gallons to 4 gallons, as a caution that the airplane is in its final hour of safe, comfortable VFR flight. The first 8 gallons below the yellow are completely usable as two good hours of flight in which the pilot's rear end, sanity, hearing, and good judgement are unimpaired and the airplane is willing and ready to go wherever it's pointed. Your mileage may vary, but I'll bet it's not by much. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 04/06/09 18:59:00 ________________________________________________________________________________
Date: Apr 07, 2009
The Floats in my 1948 V tail Bonanza are varnished Cork. They have worked well for 8 years. In a mix of Car gas and Av Gas. Blue Skies, Steve D. ----- Original Message ----- From: Lagowski Morrow <jimdeb(at)charter.net> Date: Tuesday, April 7, 2009 20:57 Subject: Re: Pietenpol-List: gas tank float > My float is like Corky's. My rod is Stainless steel welding rod. > The tank holds 12.6 gallons. The tank is just behind the firewall. > I put 4 gallons of gas in the tank, put in the float and cap and > then bent the rod at the top. The rod goes thru a small tube > brazed in the cap. The bend hits the cap when there is still 4 > gallons left, ~ 1 hour of flying if throttled back. My engine is > the 65 Continental. My gas gage is a calibrated paint stirring > stick--Jim Lagowski > ----- Original Message ----- > From: Oscar Zuniga > To: Pietenpol List > Sent: Monday, April 06, 2009 11:27 PM > Subject: Pietenpol-List: gas tank float > > > Raymond; > > On 41CC, Corky epoxied two large corks butt-to-butt on the end > of the brass rod that makes up the fuel level indicator right out > in front of the pilot and passenger. These corks are larger than > you used to see on a regular Thermos bottle, about the size of > what you'd use on a 5-gallon bottle of water that Oasis or Ozarka > used to deliver to your house for drinking water. The two corks > are epoxied onto the end of the rod and then liberally painted > with epoxy, and I mean liberally. The pair of corks float well in > avgas. You could substitute a brass ball like what is used in a > toilet ballcock but that would be overkill and you couldn't fit it > in through a standard filler neck. Some folks have used ping-pong > balls but those seem too fragile to me. Corks liberally coated > with epoxy are pretty rugged and easy to come by. > > Corky "calibrated" the brass rod of the float indicator by > filing notches in the rod at every gallon from "full" down to > "unusable fuel only remaining". When I had the fuel tank out > while rebuilding the airplane after the nose-over, I very > carefully checked the calibration by adding one gallon of water to > the fuel tank at a time and Corky's calibration was about as > precise as this engineer could ever arrive at by computation, > evaluation, micromanagement, extrapolation, or persuasion. In > other words, it's as accurate as can be read while in flight in an > open-cockpit airplane and plenty close enough. I painted the rod > red from the final four gallons to the stop, and actually none of > that last four gallons should be considered usable for safe > flight. I painted the rod yellow from 8 gallons to 4 gallons, as > a caution that the airplane is in its final hour of safe, > comfortable VFR flight. The first 8 gallons below the yellow are > completely usable as two good hours of flight in which the pilot's > rear end, sanity, hearing, and good judgement are unimpaired and > the airplane is willing and ready to go wherever it's pointed. > > Your mileage may vary, but I'll bet it's not by much. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > > > > > > > ------------------------------------------------------------------- > ----------- > > > > Checked by AVG - www.avg.com > 04/06/09 18:59:00 ________________________________________________________________________________
Subject: Re: Brodhead
Date: Apr 07, 2009
Mark There is camping right next to the activity area in the grass parking area. There are showers with sometimes hot water and sometimes a line to get in. There is a breakfast on Sat and dinners on Fri and Sat night. Brodhead is a small town, but has a few good restaurants and a grocery store. There s a McDonalds and Subway in walking distance. There is also a hardware store in town. You can bring a BBQ There is fresh water on site and both portapottys and indoor. There is no electricity in the camping area but there is a pavilion with picnic tables. Dick N. ----- Original Message ----- From: "K5YAC" <hangar10(at)cox.net> Sent: Tuesday, April 07, 2009 1:04 PM Subject: Pietenpol-List: Brodhead > > My family and I have decided to make a family trip to Brodhead this > summer. It has been recommended by many that I attend, and I can see how > the exposure would be an enormous help to my project, not to mention what > is sure to be some good ol camaraderie. It is on the calendar and I've > already requested the time off. > > That being said, can someone help us to plan accordingly? I mean, we are > pretty good planners, but we just don't know what to expect. We are > planning to drive up and tent camp and we plan to bring most of our normal > camping gear, to include food and the necessary equipment to prepare it, > but we are unsure of other accommodations, such as water, electricity, > showers, restrooms, etc. We are normally pretty flexible, but would > prefer to pack/plan accordingly. > > I've tried doing a search for "Brodhead", "Fly-In" and other key words... > as you can imagine, I received tons of posts that may or may not have been > related to the actual event. I've also looked at the Chapter 431 and BPA > sites, but I've been unable to gain much in the way of details... perhaps > I overlooked the information. > > Any suggestions for us newbies? > > -------- > Mark > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238174#238174 > > > ________________________________________________________________________________
Date: Apr 07, 2009
Thanks fellas, that tells me enough to know that the necessities are covered. We'll stay tuned to the boards to learn more. -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238257#238257 ________________________________________________________________________________
Date: Apr 08, 2009
Having been twice now the first time I had no idea of what to expect, and again the following year I knew what to expect it was a mix of many things I loved, people I met and there were many things missing. It was Perfect and I can't wait to see you all and do it all over again in just 3 months. It just keeps getting better each time I go! Last year I brought a buddy non pilot but great wood worker and Piet project contributor. Back in December I re invited him, it didn't take long for him to decide. We'll see ya'll in July! John ------Original Message------ From: Dick N. Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Sent: Apr 7, 2009 10:18 PM Subject: Re: Pietenpol-List: Brodhead Mark There is camping right next to the activity area in the grass parking area. There are showers with sometimes hot water and sometimes a line to get in. There is a breakfast on Sat and dinners on Fri and Sat night. Brodhead is a small town, but has a few good restaurants and a grocery store. There s a McDonalds and Subway in walking distance. There is also a hardware store in town. You can bring a BBQ There is fresh water on site and both portapottys and indoor. There is no electricity in the camping area but there is a pavilion with picnic tables. Dick N. ----- Original Message ----- From: "K5YAC" <hangar10(at)cox.net> Sent: Tuesday, April 07, 2009 1:04 PM Subject: Pietenpol-List: Brodhead > > My family and I have decided to make a family trip to Brodhead this > summer. It has been recommended by many that I attend, and I can see how > the exposure would be an enormous help to my project, not to mention what > is sure to be some good ol camaraderie. It is on the calendar and I've > already requested the time off. > > That being said, can someone help us to plan accordingly? I mean, we are > pretty good planners, but we just don't know what to expect. We are > planning to drive up and tent camp and we plan to bring most of our normal > camping gear, to include food and the necessary equipment to prepare it, > but we are unsure of other accommodations, such as water, electricity, > showers, restrooms, etc. We are normally pretty flexible, but would > prefer to pack/plan accordingly. > > I've tried doing a search for "Brodhead", "Fly-In" and other key words... > as you can imagine, I received tons of posts that may or may not have been > related to the actual event. I've also looked at the Chapter 431 and BPA > sites, but I've been unable to gain much in the way of details... perhaps > I overlooked the information. > > Any suggestions for us newbies? > > -------- > Mark > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238174#238174 > > > Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Apr 07, 2009
hello there diacording from pietenpol book sale by don pietenpol granson, p g, 48. you ned for wing8-325 sf turnbuckles and pin.-24 bolt and nut of cor rect size. strut material-=10 325 sf turnbuckles.-10 clevis and pin -16 b olt and nuts,for wood landingear ned 4 326 sf turnbuckles. also I have alis t what i used for my fuselaje and wing if you like to now seyou nex --- On Tue, 4/7/09, AMsafetyC(at)aol.com wrote: From: AMsafetyC(at)aol.com <AMsafetyC(at)aol.com> Subject: Re: Pietenpol-List: best place to buy turnbuckles Date: Tuesday, April 7, 2009, 6:12 AM Does anyone have a list of all the turnbuckles and-AN numbers needed to b uild a piet ? - John A Good Credit Score is 700 o17385/aol?redir=http:%2F%2Fwww.freecreditrepo rt.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DAprilfooterN O62"> See yours in just 2 easy steps! =0A=0A=0A ________________________________________________________________________________
Date: Apr 07, 2009
tanks for sendmy you inform you helmy alot andsave alot$$$$$ tanks jorge --- On Tue, 4/7/09, gcardinal wrote: From: gcardinal <gcardinal(at)comcast.net> Subject: Re: Pietenpol-List: best place to buy turnbuckles Date: Tuesday, April 7, 2009, 4:34 AM - B & B Aircraft Supplies 202 N Center St Gardner, KS 66030 (913) 884-5930 ----- Original Message ----- From: jorge lizarraga Sent: Monday, April 06, 2009 11:37 PM Subject: Re: Pietenpol-List: best place to buy turnbuckles I hope you foun these plase because I neede too. probably if you found a bo neyard is de best but here in ca, is not to mouch were looking for --- On Mon, 4/6/09, TOM MICHELLE BRANT wrote: From: TOM MICHELLE BRANT <tmbrant(at)msn.com> Subject: Pietenpol-List: best place to buy turnbuckles Date: Monday, April 6, 2009, 8:08 PM #yiv1305058386 #yiv917531085 .hmmessage P { PADDING-RIGHT:0px;PADDING-LEFT:0px;PADDING-BOTTOM:0px;MARGIN:0px;PADDING-TO P:0px;} #yiv1305058386 #yiv917531085 { FONT-SIZE:10pt;FONT-FAMILY:Verdana;} Any thoughts on the best (as in cheapest) place to purchase turnbuckles the se days?- Aircraft Spruce is around $28/unit as is Wicks. Tom B. " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenp ol-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =0A=0A=0A ________________________________________________________________________________
Date: Apr 07, 2009
Just received my first issue of BPA News today... reading it cover to cover provided several more answers. Looking forward to July already. -------- Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238268#238268 ________________________________________________________________________________
Subject: Re: From the Newswire at work this morning-Sorta OT
Date: Apr 08, 2009
I just opened my latest Sport Aviation. In it is an article about a diy starter for C-65's and 85's. It uses a Dewalt cordless drill and apparently works quite well. Something to think about with all these horror stories. Also around here you have to have a second person lined up ahead of time to prop for you at flyins as they won't let you do it on your lonesome. Clif I was always taught to respect my elders, But it keeps getting harder to find one. ----- Original Message ----- From: "Tim Verthein" <minoxphotographer(at)yahoo.com> > > > Plane takes off without pilot > > An aircraft took off on its own when the pilot could not get into the > cockpit in time after starting the propellor manually. > ________________________________________________________________________________
Subject: 80th Anniversary OSH Fly-in update
Date: Apr 08, 2009
Here is an update on the 80th anniversary fly-in. Bill Rewey stopped at Waupun, WI (WI07) to investigate it as a potential stopover point. This airport is conveniently located for pilots flying the FISK arrival. It is a private airfield with a N-S paved runway and an E-W grass runway located about 15 miles south of Ripon. The owner is eager to have us stop there on our way to OSH. www.runwayfinder.com is a good site with active sectionals that can be used for flight planning. Here is the form for preordering the 2009 Oshkosh NOTAM: https://secure.eaa.org/airventure/notam_request.html Please order and study it. Greg Cardinal gcardinal(at)comcast.net ________________________________________________________________________________
Subject: slight course deviation to Brodhead/Oshkosh possible
Date: Apr 08, 2009
Congratulations, Gardiner for finishing the Piet and for finally getting Matronics to accept your posts. You've got three months to fly off the time on your Piet and have it ready for Brodhead - should be plenty of time. Hope to see it (and you) there. Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gardiner Mason Sent: Monday, April 06, 2009 9:10 PM Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Jack, I am taxiing my piet now, but have not done the paper work yet. CG is in range and wt is 771 so far. I hope to have it ready for Brodhead but I am not going to push it as I still have my Cessna 140 tomake the trip.. Cheers, Gardiner. ----- Original Message ----- From: Gardiner <mailto:airlion(at)bellsouth.net> Mason Sent: Monday, April 06, 2009 7:55 PM Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Jack, which tree would go for if you lost your engine? Gardiner ----- Original Message ----- From: Jack <mailto:pietflyr(at)bellsouth.net> Phillips Sent: Monday, April 06, 2009 3:24 PM Subject: RE: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? Actually, the Appalachians rise about as high above the surrounding terrain as do the Rockies. Mount Mitchell, in western North Carolina is 6,684' above sea level, but the surrounding terrain is only 595' MSL, so it rises over 6,000' above its surroundings. The land around the Rockies is nearly 6,000' MSL, so only the peaks that are over 12,000' are truly "taller" than the highest peaks in the Appalachians. Density altitude is another matter entirely. Neither mountain range has a wealth of good forced landing sites. Here's typical terrain in the Blue Ridge on the way to Brodhead last year. At about this point in the trip, my GPS indicated I was making 27 knots, groundspeed. Jack Phillips Happy I don't have to get any higher than about 4500' to get to Brodhead. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, April 06, 2009 1:55 PM Subject: Re: Pietenpol-List: slight course deviation to Brodhead/Oshkosh possible ? 4000 ft. high "mounds of dirt" ain't mountains! href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Apr 08, 2009
Jorge, your name is obviously Spainish. Where are you? Steve D ----- Original Message ----- From: jorge lizarraga <flightwood(at)yahoo.com> Date: Tuesday, April 7, 2009 23:45 Subject: Re: Pietenpol-List: best place to buy turnbuckles > tanks for sendmy you inform you helmy alot andsave alot$$$$$ tanks > jorge > --- On Tue, 4/7/09, gcardinal < wrote: > > From: gcardinal < > Subject: Re: Pietenpol-List: best place to buy turnbuckles > To: pietenpol-list(at)matronics.com > Date: Tuesday, April 7, 2009, 4:34 AM > > > > > B & B Aircraft Supplies > 202 N Center St > Gardner, KS 66030 > (913) 884-5930 > > ----- Original Message ----- > From: jorge lizarraga > To: pietenpol-list(at)matronics.com > Sent: Monday, April 06, 2009 11:37 PM > Subject: Re: Pietenpol-List: best place to buy turnbuckles > > > > > > I hope you foun these plase because I neede too. probably if you found a boneyard is de best but here in ca, is not to mouch were looking for > > --- On Mon, 4/6/09, TOM MICHELLE BRANT < wrote: > > From: TOM MICHELLE BRANT < > Subject: Pietenpol-List: best place to buy turnbuckles > To: "pietenpol-list(at)matronics.com" < > Date: Monday, April 6, 2009, 8:08 PM > > > > #yiv1305058386 #yiv917531085 .hmmessage P { > PADDING-RIGHT:0px;PADDING-LEFT:0px;PADDING-BOTTOM:0px;MARGIN:0px;PADDING-TOP:0px;} > #yiv1305058386 #yiv917531085 { > FONT-SIZE:10pt;FONT-FAMILY:Verdana;} > > Any thoughts on the best (as in cheapest) place to purchase turnbuckles these days? Aircraft Spruce is around $28/unit as is Wicks. > > Tom B. > > > " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List > =nofollow>http://forums.matronics.com > blank rel=nofollow>http://www.matronics.com/contribution > > > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > > > > ________________________________________________________________________________
Date: Apr 08, 2009
I spoke to Dan the other day and he only has fork ends at the moment and the long turnbuckles Would it be ok to use the fork end in place of the cable eye and are others using the long or short? They wont post overseas so I need to order all that I need in one go Dan is a very nice fellow I think the 1/2 hour on the phone chatting would have cost about as much as 1 turnbuckle. He also said he would be at OSH. Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238377#238377 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Apr 09, 2009
Subject: Runway Finder-- GREAT web site Greg Cardinal ! 80th
Anniversary OSH Fly-in update www.runwayfinder.com<http://www.runwayfinder.com> is a good site with activ e sectionals that can be used for flight planning. GREAT web site Greg ! Did any of you guys try this ?? You can zoom in , drag around the entire United States just like you would a Google Map. I will checkout Wapun as a possible stop from Brodhead to Oshkosh. Is anyone thinking of simply flying nonstop from Brodhead to OSH via the FI SK approach ? That is my thought as winds are notoriously calmer in the m orning hours but...it is what it is when you get there. Mike C. ________________________________________________________________________________
Subject: Re: Runway Finder-- GREAT web site Greg Cardinal ! 80th
Date: Apr 09, 2009
Mikee, I have used skyvector.com in the past for mapping. It works well, especially with Firefox, to plan routes and get weather. John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2810 Crossroads Drive, Ste 3800 Madison, WI 53718 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Apr 9, 2009, at 12:49 PM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > www.runwayfinder.com is a good site with active sectionals that can > be used for flight planning. > > GREAT web site Greg ! Did any of you guys try this ?? You can > zoom in, drag around the entire United States just like you would a > Google Map. I will checkout Wapun as a possible stop from Brodhead > to Oshkosh. > > Is anyone thinking of simply flying nonstop from Brodhead to OSH via > the FISK approach ? That is my thought as winds are notoriously > calmer in the morning hours but=85it is what it is when you get there. > > Mike C. > > ________________________________________________________________________________
Date: Apr 09, 2009
Ann... now you have a partner son **************New Deals on Dell Netbooks =93 Now starting at $299 (A edir=http:%2F %2Fad.doubleclick.net%2Fclk%3B213771973%3B35379628%3Bw) ________________________________________________________________________________
Date: Apr 09, 2009
Mikee wrote- >Is anyone thinking of simply flying nonstop from Brodhead to OSH via the FISK approach ? No=2C but I thought about flying nonstop from San Geronimo (8T8) to Brodhea d (C37) via direct. It's only 1=2C044 statute and I figure I can make it w ith 75 gallons and that includes a 25% reserve. Since I already have a 16 gal. tank=2C I only need to find room for 59 milk jugs filled with avgas=2C for another 354 lbs. Hmmm... I'd better plug that into the W&B spreadsheet. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 09, 2009
WOW! Are all those milk jugs interconnected with each having their own valv e shut off going to the main tank and if so how do you turn each one on as you go or do you have the valves all back in the rear cockpit to control fr om there?Is there a fuel pump there to pump the gas to the main?Do you have a spare jug in reserve for wee,wees along the way?How do you control the j ugs from colapsing as the fuel is taken out or does that matter?Do you hang them from the center section wing or are they down on the floor?I gotta kn ow how you do this!!!!!=0A=0A=0A=0A=0A________________________________=0AFr om: Oscar Zuniga =0ATo: Pietenpol List =0ASent: Thursday, April 9, 2009 4:28:55 PM=0ASubject: Pie tenpol-List: Runway Finder-- GREAT web site Greg Cardinal ! 80th=0A=0AMikee wrote-=0A-=0A>Is anyone thinking of simply flying nonstop from Brodhead to OSH via the=0AFISK approach ?=0A-=0ANo, but I thought about flying non stop from San Geronimo (8T8) to Brodhead (C37) via direct.- It's only 1,0 44 statute and I figure I can make it with 75 gallons and that includes a 2 5% reserve.- Since I already have a 16 gal. tank, I only need to find roo m for 59 milk jugs filled with avgas, for another 354 lbs.=0A-=0AHmmm... I'd better plug that into the W&B spreadsheet.-=0A-=0AOscar Zuniga=0AAi r Camper NX41CC=0ASan Antonio, TX=0Amailto: taildrags(at)hotmail.com=0Awebsite ========= ________________________________________________________________________________
Annive
Date: Apr 09, 2009
Hey Mike, I'd be interested in leaving at sunrise Sunday morning and flying direct to OSH. Gotta love that smooth morning air. It'd be fun to fly all that way with a few others. It makes the flight seem shorter and more fun when I have to spend time focusing on the guy I'm flying formation with. Looking forward to it! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238558#238558 ________________________________________________________________________________
Date: Apr 09, 2009
What I like about Runwayfinder.com is the ability to enter airport identifiers and it will draw a course line complete with distances. Very nice for flight planning. Brodhead - direct - Oshkosh is good if you have a radio. Those of us doing the nordo thing will have to make a stop. Waupun is very convenient for both the Fisk arrival and the ultralight arrival. Hopefully we can all get into OSH before any significant wind kicks up. Greg ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Thursday, April 09, 2009 12:49 PM Subject: Pietenpol-List: Runway Finder-- GREAT web site Greg Cardinal ! 80th Anniversary OSH Fly-in update www.runwayfinder.com is a good site with active sectionals that can be used for flight planning. GREAT web site Greg ! Did any of you guys try this ?? You can zoom in, drag around the entire United States just like you would a Google Map. I will checkout Wapun as a possible stop from Brodhead to Oshkosh. Is anyone thinking of simply flying nonstop from Brodhead to OSH via the FISK approach ? That is my thought as winds are notoriously calmer in the morning hours but.it is what it is when you get there. Mike C. ________________________________________________________________________________
Date: Apr 09, 2009
I've seen a million good responses on here but wanted to throw in one that has been missed . . . in the old days, the corks were originally coated with many coats of good old-fashioned shellac, which seems to be impervious to all fuels and additives. Gene ----- Original Message ----- From: Rick Holland<mailto:at7000ft(at)gmail.com> To: pietenpol-list(at)matronics.com Sent: Monday, April 06, 2009 10:39 PM Subject: Re: Pietenpol-List: gas tank float Did you coat that cork with varnish or anything Ed? rick On Mon, Apr 6, 2009 at 8:13 PM, Ed G. > wrote: I'm useing a big cork that I bought at the local Ace hardware. That's what the Aeronca that I fly has for a float and it works fine. Ed G > Subject: Pietenpol-List: gas tank float > From: rhano(at)att.net<mailto:rhano(at)att.net> > Date: Mon, 6 Apr 2009 17:36:15 -0700 > To: pietenpol-list(at)matronics.com > > > > What are you using for a float in your tanks? I guess there are still a lot of car gas tanks that use brass floats on their gage senders and maybe I can check out a friends junkyard and find a good one to use in my fuel tank.any ideas on which models might have the best size and shape to fit into the filler neck and have enough buoyancy to raise the brass rod ?Raymond > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238067#238067 .matronics.com/viewtopic.php?p=238067#238067> > > > > > > > ------------------------------------------------------------------------- --- Quick access to your favorite MSN content and Windows Live with Internet Explorer 8. Download FREE now!<http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid =B037MSN55C0701A> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Apr 09, 2009
Subject: Re: gas tank float
That's what I used;went to a wine making store for the cork and used a coat hanger.Works fine.=0A=0A=0A=0A=0A________________________________=0AFrom: Gene Rambo =0ATo: pietenpol-list(at)matronics.com=0ASent: T hursday, April 9, 2009 10:13:59 PM=0ASubject: Re: Pietenpol-List: gas tank float=0A=0A=0AI've seen a million good responses on here but wanted to thro w in one that has been missed . . . in the old days, the corks were origina lly coated with many coats of good old-fashioned shellac, which seems to be impervious to all fuels and additives.=0A=0AGene=0A----- Original Message ----- =0AFrom: Rick Holland =0ATo: pietenpol-list(at)matronics.com =0ASent: Mo nday, April 06, 2009 10:39 PM=0ASubject: Re: Pietenpol-List: gas tank float =0ADid you coat that cork with varnish or anything Ed?=0A=0Arick=0A=0A=0AOn Mon, Apr 6, 2009 at 8:13 PM, Ed G. wrote:=0A=0AI' m useing a big cork that I bought at the local Ace hardware.-That's what the Aeronca that I fly has for a float and it works fine.-- Ed G=0A- =0A> Subject: Pietenpol-List: gas tank float=0A> From: rhano(at)att.net=0A> Da tt.net>=0A> =0A> What are you using for a float in your tanks? I guess ther e are still a lot of car gas tanks that use brass floats on their gage send ers and maybe I can check out a friends junkyard and find a good one to use in my fuel tank.any ideas on which models might have the best size and sha pe to fit into the filler neck and have enough buoyancy to raise the brass rod ?Raymond=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A>
http://forums.matronics.com/viewtopic.php?p=238067#238067=0A> =0A> =0A> =0A>=0A> =0A> =0A> =0A=0A=0A________________________________=0AQuick acce ss to your favorite MSN content and Windows Live with Internet Explorer 8. Download FREE now!=0A=0A=0A" target="_blank">http://www.matronics.com/Nav igator?Pietenpol-List=0Atp://forums.matronics.com=0A_blank">http://www.matr onics.com/contribution=0A=0A=0A=0A=0A-- =0ARick Holland=0ACastle Rock, Colo rado=0A=0A=0A=0Atitle=http://www.matronics.com/Navigator?Pietenpol-List h ref="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matron ics.com/Navigator?Pietenpol-List=0Ahref="http://forums.matronics.com">htt p://forums.matronics.com=0Ahref="http://www.matronics.com/contribution">h === ________________________________________________________________________________
Date: Apr 09, 2009
I can tell you not to overly coat your cork with silicon caulk or the like, for a cork so coated can float in water, but not in gasoline (lower specific gravity). This is based on empirical data. Now for Plan B.......... Does anyone know if ethanol or gasoline will eat up the coating on a cork, if the coating is either West Marine epoxy or West Marine epoxy varnish? Your answer is based on... Chemistry? Mfr. specs.? Tests? Tim in central TX -----Original Message----- >From: H RULE <harvey.rule(at)rogers.com> >Sent: Apr 9, 2009 9:41 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: gas tank float > >That's what I used;went to a wine making store for the cork and used a coat hanger.Works fine. > > ________________________________________________________________________________
Date: Apr 09, 2009
NOT alcohol! That is the solvent for shellac. http://antiquerestorers.com/Articles/jeff/shellac.htm Clif Subject: Re: Pietenpol-List: gas tank float the corks were originally coated with many coats of good old-fashioned shellac, which seems to be impervious to all fuels and additives. Gene ________________________________________________________________________________
Subject: gas tank float
Date: Apr 10, 2009
Friend of mine made me 2 float assy over the years , at different times, for my two projects. They've worked flawlessly. And very simple. Below is his discription. <<<<<<<<<<< Walt, Yes. 1/16" SS rod. The best epoxy is called, "JB Weld" It is basically gasoline proof and seals the two 1/16" holes you have to drill in the ping pong ball. JB Weld is sold at most auto parts stores...NAPA for instance also Advance Auto. I also made some with TWO balls on one rod to get more buoyancy. But if you keep the SS rod thin and not too long it will float on one ball. Cook. >>>>>>>>>>>>> use 1/16" rod from the welding store as the rod. then I found an old ball point pen that had the brass ink tube, cut and cleaned that and soldered it into a hole drilled in the fuel cap. Works absolutely flawlessly!! ( or buy the tube at the hobby store) You can either drop it to the bottom,cut the rod 1/2" from the top of tube, and bend it over,,,,,,,,Or set it higher to make a built in reserve walt evans NX140DL ________________________________________________________________________________
Date: Apr 10, 2009
That's right,they are using enthonal in the gas which will eat that shallac .I think I coat it in JB weld as that other gentleman wrote when I get back down to the field.=0A=0A=0A=0A=0A________________________________=0AFrom: Clif Dawson =0ATo: pietenpol-list(at)matronics.com=0ASent : Friday, April 10, 2009 1:18:20 AM=0ASubject: Re: Pietenpol-List: gas tank float=0A=0A=0ANOT alcohol! That is the solvent for shellac.=0A-=0Ahttp:/ /antiquerestorers.com/Articles/jeff/shellac.htm=0A-=0AClif=0ASubject: Re: Pietenpol-List: gas tank float=0A=0Athe corks were originally coated with many coats of good old-fashioned shellac, which seems to be impervious to a ======= ________________________________________________________________________________
Date: Apr 10, 2009
TEAM Aircraft used to recommend bending a wire like is used to dip out colored easter eggs and glue a ping pong ball to it with T-88 to make a float. Alcohol dissolves the T-88 though. I tried it on my minimax. dennis ----- Original Message ----- From: "Tim Willis" <timothywillis(at)earthlink.net> Sent: Thursday, April 09, 2009 9:52 PM Subject: Re: Pietenpol-List: gas tank float ________________________________________________________________________________
Date: Apr 10, 2009
Of course in the old days they didn't use 25% of the countries corn crops to put Ethanol in car gasoline. Don't know how shellac would handle that. Rick On Thu, Apr 9, 2009 at 8:13 PM, Gene Rambo wrote: > I've seen a million good responses on here but wanted to throw in one > that has been missed . . . in the old days, the corks were originally coated > with many coats of good old-fashioned shellac, which seems to be impervious > to all fuels and additives. > > Gene > > ----- Original Message ----- > *From:* Rick Holland > *To:* pietenpol-list(at)matronics.com > *Sent:* Monday, April 06, 2009 10:39 PM > *Subject:* Re: Pietenpol-List: gas tank float > > Did you coat that cork with varnish or anything Ed? > > rick > > On Mon, Apr 6, 2009 at 8:13 PM, Ed G. wrote: > >> I'm useing a big cork that I bought at the local Ace hardware. That's what >> the Aeronca that I fly has for a float and it works fine. Ed G >> >> > Subject: Pietenpol-List: gas tank float >> > From: rhano(at)att.net >> > Date: Mon, 6 Apr 2009 17:36:15 -0700 >> > To: pietenpol-list(at)matronics.com >> > >> > >> > >> > What are you using for a float in your tanks? I guess there are still a >> lot of car gas tanks that use brass floats on their gage senders and maybe I >> can check out a friends junkyard and find a good one to use in my fuel >> tank.any ideas on which models might have the best size and shape to fit >> into the filler neck and have enough buoyancy to raise the brass rod >> ?Raymond >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=238067#238067 >> > >> > >> > >> > >> > >> > >> > >> >> ------------------------------ >> Quick access to your favorite MSN content and Windows Live with Internet >> Explorer 8. Download FREE now!<http://ie8.msn.com/microsoft/internet-explorer-8/en-us/ie8.aspx?ocid=B037MSN55C0701A> >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Rick Holland > Castle Rock, Colorado > > * > > title=http://www.matronics.com/Navigator?Pietenpol-List href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Apr 10, 2009
Subject: looking for a wingman Don ?
So Don, you are planning the same Brodhead-direct-Oshkosh flight too ? If I can get my butt out of the tent early enough and packed and the weather is favorable, I wouldn't mind tagging along with anyone else who might be, like yourself, thinking of doing that. I flew loose formation with Jack Phillips from Cleveland to Brodhead in 2005 and you're right-- it does make the time go much faster and except for driving Jack nuts with my incessant chatter over the air-to-air frequency we both had the time of our lives. Mike C. ________________________________________________________________________________
Date: Apr 10, 2009
Subject: flying into Oshkosh
I did notice in the BPAN newsletter (thank you Doc and Dee) that EAA is all owing us to land on the ultralight grass runway IF we have a tailskid. Th at's very cool. And then you can get towed to the parking area by the Hom ebuilt HQ. So Don E., will you be flying with a radio via the FISK approach or going N ORDO from Brodhead to OSH ? I will have my Icom handheld to communicate ( I should say listen) to FISK and the tower at OSH. Mike C. ________________________________________________________________________________
Subject: Re: flying into Oshkosh
Date: Apr 10, 2009
Hey Mike C, I haven't studied up on it too much but I would like to try the Brodhead to Oshkosh direct idea. Most of my cross-country planning seems to be planned a few minutes before the flight. Draw a line and go. Not really the best idea I suppose. So I do need to get some time to look over the arrival procedures. I'm a NORDO. So if I feel the urge to get chatty it usually has to be with myself. I can yell pretty loud but I usually have to communicate with my wingman by hand signals. In '07 there were several of us flying together on our way to Brodhead, I think at one point there were actually 9 airplanes. None had radios. We seemed to communicate ok, no real problems. Anyway, the gas range for Brodhead to OSH isn't a problem for me, the butt range is somewhat though. If I can do a NORDO arrival direct from Brodhead I will but I don't know if I can do that from that far out. Ya know, it's only a little over 3 months away! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238659#238659 ________________________________________________________________________________
Date: Apr 10, 2009
Though I'd throw this shot in from '07. Me trying to take air to air shots while flying. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238661#238661 Attachments: http://forums.matronics.com//files/piet_formation_414.jpg ________________________________________________________________________________
Subject: Another Flying Circus picture
Date: Apr 10, 2009
Just another picture... Steve Roth's Fairchild in the background. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238675#238675 Attachments: http://forums.matronics.com//files/piet_and_fairchild_103.jpg ________________________________________________________________________________
Subject: Re: Another Flying Circus picture
Date: Apr 10, 2009
Illinois had to be a barnstormers paradise. All those long beautiful fields... Don, again Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238676#238676 Attachments: http://forums.matronics.com//files/illinois_barnstorming_212.jpg ________________________________________________________________________________
Date: Apr 10, 2009
Subject: NORDO into OSH
I do believe to be NORDO you need to call the tower from an airport where you are 30 minutes from Wittman Field so calling from Brodhead for a NORDO clearance wouldn't work. To be 30 minutes (or whatever the real number is in the NOTAM) from Wittman Field you have to be at Fon Du Lac with a strong tailwind in a Pietenpol:)))) NORDO can sometimes work to your advantage if you want to land on a different runway that whatever the tower is assigning at OSH. It seems over the years they like to use the E-W runways for the radio approaches (wind permitting) and the N-S for the NORDO guys like we did 10 years ago when they use 36 and the 36 taxiway as a parallel 36R/18L. If the wind is howling out of the south and they are landing tower airplanes to the east and NORDO's to the south.....I'm going in NORDO ! Mike C. ________________________________________________________________________________
Date: Apr 11, 2009
No such saying out there like "just follow the ridge" walt evans NX140DL ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> Sent: Friday, April 10, 2009 10:07 PM Subject: Pietenpol-List: Re: Another Flying Circus picture > > Illinois had to be a barnstormers paradise. All those long beautiful > fields... > > Don, again > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238676#238676 > > > Attachments: > > http://forums.matronics.com//files/illinois_barnstorming_212.jpg > > > ________________________________________________________________________________
Date: Apr 11, 2009
Subject: Split axle gear axle attach method
Good morning all, I have a question about the method others have used to attach a "Cessna style" axle to the axle end of their split-axle gear. We are in the process of getting our vees welded up, so I want to make sure what we are looking at doing sounds correct. We are using 6.00x6 wheels and tires. I found a used set from a wind damaged 150 on Barnstormers for a decent price, and they should be winding their way through the USPS as I speak. They come with axles; if the axles are serviceable I will use them, if not I will probably pick up a set of Grove axles: http://www.aircraftspruce.com/catalog/lgpages/grove60x6.php It would appear to me that one of the methods used to provide an attach point for these axles is to weld a circular plate to the gear end, and then bolt the axle to that plate. For reference here's a link to a shot of Bill Rewey's gear from WestCoastPiet: http://www.westcoastpiet.com/images/Bill%20Rewey/IMG_0393.JPG A pic of Tim Mickel's gear appears to show a similar setup, although it's not quite as clear: http://www.westcoastpiet.com/images/Tim%20Mickel/DSCF0157.JPG Does that sound like a good method for providing an attach point for the axles? If so, does anyone have a recommendation for the steel thickness we should fab the mounting plate out of? Thanks, and have a Happy Easter! Ryan ________________________________________________________________________________
Subject: Model A Piet sale / trade / ?
Date: Apr 11, 2009
Gentleman: I have decided to upgrade to a little more power and a smoother engine. The Model A engine is a great engine and runs great but by its design there is a vibration that I feel uncomfortable with, mainly because I fly helicopters for a living and any vibs are a no no. So I will be entertaining offers for NX920Y aircamper built by Don Hicks in 2004, The engine has 50+ hours todate and the air-frame is 19+ hour. I flew the airplane today and it was great. I do not wish to take the aircraft apart to re-engine the aircraft. Don built as close as possible to the original plans Pietenpol, and I would love to see the aircraft stay in tack as it was built. If I'm unable to sell the aircraft as a unit I would like to sell the engine, firewall forward to include the mount, prop, radiator and tack, plus cowling. I plan to replace the Model A with a Corvair engine. Or if I find a buyer I will purchase someone else's project and complete it with the Corvair engine. So I am advertising the aircraft local for $13,500.00 Make offers / trades / ???? You can call me at 573-645-0534 ________________________________________________________________________________
Date: Apr 12, 2009
Unless you're landing Williamsport talking to the tower and looking for the airport. Those are the tower instructions John ------Original Message------ From: walt Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Sent: Apr 11, 2009 5:09 AM Subject: Re: Pietenpol-List: Re: Another Flying Circus picture No such saying out there like "just follow the ridge" walt evans NX140DL ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> Sent: Friday, April 10, 2009 10:07 PM Subject: Pietenpol-List: Re: Another Flying Circus picture > > Illinois had to be a barnstormers paradise. All those long beautiful > fields... > > Don, again > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=238676#238676 > > > Attachments: > > http://forums.matronics.com//files/illinois_barnstorming_212.jpg > > > Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Apr 12, 2009
Subject: Re: Split axle gear axle attach method
Hello Ryan Attached some pictures of how I did mine. I used Matco axles/brakes/wheels. Matco recommended 1/4" thick steel for the mount plates. Looking at the pictures you attached its hard to tell if bolt on axles were used or just a single piece of tubing with a collar welded on for brake attachment. Since I have not yet flown I cannot say my design is a proven one. Rick On Sat, Apr 11, 2009 at 8:01 AM, Ryan Mueller wrote: > Good morning all, > > I have a question about the method others have used to attach a "Cessna > style" axle to the axle end of their split-axle gear. We are in the process > of getting our vees welded up, so I want to make sure what we are looking at > doing sounds correct.H > > We are using 6.00x6 wheels and tires. I found a used set from a wind > damaged 150 on Barnstormers for a decent price, and they should be winding > their way through the USPS as I speak. They come with axles; if the axles > are serviceable I will use them, if not I will probably pick up a set of > Grove axles: > > http://www.aircraftspruce.com/catalog/lgpages/grove60x6.php > > It would appear to me that one of the methods used to provide an attach > point for these axles is to weld a circular plate to the gear end, and then > bolt the axle to that plate. For reference here's a link to a shot of Bill > Rewey's gear from WestCoastPiet: > > http://www.westcoastpiet.com/images/Bill%20Rewey/IMG_0393.JPG > > A pic of Tim Mickel's gear appears to show a similar setup, although it's > not quite as clear: > > http://www.westcoastpiet.com/images/Tim%20Mickel/DSCF0157.JPG > > Does that sound like a good method for providing an attach point for the > axles? If so, does anyone have a recommendation for the steel thickness we > should fab the mounting plate out of? > > Thanks, and have a Happy Easter! > > Ryan > > * > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Apr 12, 2009
Walt I have a steel fuel cap from ACS. You can solder brass tubing to steel using lead/tin solder? Rick On Fri, Apr 10, 2009 at 3:32 AM, walt wrote: > Friend of mine made me 2 float assy over the years , at different times, > for my two projects. > They've worked flawlessly. And very simple. > Below is his discription. > > <<<<<<<<<<< > Walt, > > Yes. 1/16" SS rod. > > The best epoxy is called, "JB Weld" > > It is basically gasoline proof and seals the two 1/16" holes you have to > drill in the ping pong ball. > > JB Weld is sold at most auto parts stores...NAPA for instance also Advance > Auto. > > I also made some with TWO balls on one rod to get more buoyancy. But if > you keep the SS rod thin and not too long it will float on one ball. > > > Cook. > > >>>>>>>>>>>>> > > use 1/16" rod from the welding store as the rod. > then I found an old ball point pen that had the brass ink tube, cut and > cleaned that and soldered it into a hole drilled in the fuel cap. > Works absolutely flawlessly!! ( or buy the tube at the hobby store) > You can either drop it to the bottom,cut the rod 1/2" from the top of > tube, and bend it over,,,,,,,,Or set it higher to make a built in reserve > > walt evans > NX140DL > > > * > > * > > -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Date: Apr 12, 2009
Yes, steel solders beautifully. Just remember that if using a propane torch, the cap takes alot longer to come up to temp,,,so you don't discolor the brass tube and make it unsolderable. Goes without saying to pop out the rubber gasket from the gas cap first. Just clean everthing up shiney, coat all with solder paste. PS, I used the same cap as you. walt evans NX140DL ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Sunday, April 12, 2009 10:00 AM Subject: Re: Pietenpol-List: gas tank float Walt I have a steel fuel cap from ACS. You can solder brass tubing to steel using lead/tin solder? Rick On Fri, Apr 10, 2009 at 3:32 AM, walt wrote: Friend of mine made me 2 float assy over the years , at different times, for my two projects. They've worked flawlessly. And very simple. Below is his discription. <<<<<<<<<<< Walt, Yes. 1/16" SS rod. The best epoxy is called, "JB Weld" It is basically gasoline proof and seals the two 1/16" holes you have to drill in the ping pong ball. JB Weld is sold at most auto parts stores...NAPA for instance also Advance Auto. I also made some with TWO balls on one rod to get more buoyancy. But if you keep the SS rod thin and not too long it will float on one ball. Cook. >>>>>>>>>>>>> use 1/16" rod from the welding store as the rod. then I found an old ball point pen that had the brass ink tube, cut and cleaned that and soldered it into a hole drilled in the fuel cap. Works absolutely flawlessly!! ( or buy the tube at the hobby store) You can either drop it to the bottom,cut the rod 1/2" from the top of tube, and bend it over,,,,,,,,Or set it higher to make a built in reserve walt evans NX140DL " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado ________________________________________________________________________________
Subject: Re: straight axel gear
Date: Apr 12, 2009
SSBhbSBkb2luZyBteSBnZWFyIG1vY2sgdXAgYW5kIHdhcyB3b25kZXJpbmcgaWYgYW55b25lIGhh ZCBhIG5vbiBidW5nZWUgZGVzaWduIHdpdGggZGV0YWlsZWQgcGljcz8NCg0KT3IgZGV0YWlsZWQg cGljcyBvZiB0aGUgYnVuZ2VlIG1vdW50IGNvbnN0cnVjdGlvbg0KDQpUaGFua3MNCg0KSm9obg0K U2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgQmxhY2tCZXJyeQ0KDQotLS0tLU9yaWdpbmFs IE1lc3NhZ2UtLS0tLQ0KRnJvbTogIndhbHQiIDx3YWx0ZGFrQHZlcml6b24ubmV0Pg0KDQpEYXRl OiBTdW4sIDEyIEFwciAyMDA5IDEwOjQwOjQwIA0KVG86IDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25p Y3MuY29tPg0KU3ViamVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBnYXMgdGFuayBmbG9hdA0KDQoN Clllcywgc3RlZWwgc29sZGVycyBiZWF1dGlmdWxseS4gSnVzdCByZW1lbWJlciB0aGF0IGlmIHVz aW5nIGEgcHJvcGFuZSB0b3JjaCwgdGhlIGNhcCB0YWtlcyBhbG90IGxvbmdlciB0byBjb21lIHVw IHRvIHRlbXAsLCxzbyB5b3UgZG9uJ3QgZGlzY29sb3IgdGhlIGJyYXNzIHR1YmUgYW5kIG1ha2Ug aXQgdW5zb2xkZXJhYmxlLg0KR29lcyB3aXRob3V0IHNheWluZyB0byBwb3Agb3V0IHRoZSBydWJi ZXIgZ2Fza2V0IGZyb20gdGhlIGdhcyBjYXAgZmlyc3QuDQpKdXN0IGNsZWFuIGV2ZXJ0aGluZyB1 cCBzaGluZXksIGNvYXQgYWxsIHdpdGggc29sZGVyIHBhc3RlLg0KUFMsIEkgdXNlZCB0aGUgc2Ft ZSBjYXAgYXMgeW91Lg0Kd2FsdCBldmFucw0KTlgxNDBETA0KDQoNCiAgLS0tLS0gT3JpZ2luYWwg TWVzc2FnZSAtLS0tLSANCiAgRnJvbTogUmljayBIb2xsYW5kIA0KICBUbzogcGlldGVucG9sLWxp c3RAbWF0cm9uaWNzLmNvbSANCiAgU2VudDogU3VuZGF5LCBBcHJpbCAxMiwgMjAwOSAxMDowMCBB TQ0KICBTdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IGdhcyB0YW5rIGZsb2F0DQoNCg0KICBX YWx0DQoNCiAgSSBoYXZlIGEgc3RlZWwgZnVlbCBjYXAgZnJvbSBBQ1MuIFlvdSBjYW4gc29sZGVy IGJyYXNzIHR1YmluZyB0byBzdGVlbCB1c2luZyBsZWFkL3RpbiBzb2xkZXI/DQoNCiAgUmljaw0K DQoNCiAgT24gRnJpLCBBcHIgMTAsIDIwMDkgYXQgMzozMiBBTSwgd2FsdCA8d2FsdGRha0B2ZXJp em9uLm5ldD4gd3JvdGU6DQoNCiAgICBGcmllbmQgb2YgbWluZSBtYWRlIG1lIDIgZmxvYXQgYXNz eSBvdmVyIHRoZSB5ZWFycyAsIGF0IGRpZmZlcmVudCB0aW1lcywgZm9yIG15IHR3byBwcm9qZWN0 cy4NCiAgICBUaGV5J3ZlIHdvcmtlZCBmbGF3bGVzc2x5LiAgQW5kIHZlcnkgc2ltcGxlLg0KICAg IEJlbG93IGlzIGhpcyBkaXNjcmlwdGlvbi4NCg0KICAgIDw8PDw8PDw8PDw8DQogICAgV2FsdCwN Cg0KICAgIFllcy4gMS8xNiIgU1Mgcm9kLg0KDQogICAgVGhlIGJlc3QgZXBveHkgaXMgY2FsbGVk LCAiSkIgV2VsZCINCg0KICAgIEl0IGlzIGJhc2ljYWxseSBnYXNvbGluZSBwcm9vZiBhbmQgc2Vh bHMgdGhlIHR3byAxLzE2IiBob2xlcyB5b3UgaGF2ZSB0byBkcmlsbCBpbiB0aGUgcGluZyBwb25n IGJhbGwuDQoNCiAgICBKQiBXZWxkIGlzIHNvbGQgYXQgbW9zdCBhdXRvIHBhcnRzIHN0b3Jlcy4u Lk5BUEEgZm9yIGluc3RhbmNlIGFsc28gQWR2YW5jZSBBdXRvLg0KDQogICAgSSBhbHNvIG1hZGUg c29tZSB3aXRoIFRXTyBiYWxscyBvbiBvbmUgcm9kIHRvIGdldCBtb3JlIGJ1b3lhbmN5LiAgQnV0 IGlmIHlvdSBrZWVwIHRoZSBTUyByb2QgdGhpbiBhbmQgbm90IHRvbyBsb25nIGl0IHdpbGwgZmxv YXQgb24gb25lIGJhbGwuDQoNCg0KICAgIENvb2suDQoNCiAgICA+Pj4+Pj4+Pj4+Pj4+DQoNCiAg ICB1c2UgMS8xNiIgcm9kIGZyb20gdGhlIHdlbGRpbmcgc3RvcmUgYXMgdGhlIHJvZC4NCiAgICB0 aGVuIEkgZm91bmQgYW4gb2xkIGJhbGwgcG9pbnQgcGVuIHRoYXQgaGFkIHRoZSBicmFzcyBpbmsg dHViZSwgY3V0IGFuZCBjbGVhbmVkIHRoYXQgYW5kIHNvbGRlcmVkIGl0IGludG8gYSBob2xlIGRy aWxsZWQgaW4gdGhlIGZ1ZWwgY2FwLg0KICAgIFdvcmtzIGFic29sdXRlbHkgZmxhd2xlc3NseSEh ICAoIG9yIGJ1eSB0aGUgdHViZSBhdCB0aGUgaG9iYnkgc3RvcmUpDQogICAgIFlvdSBjYW4gZWl0 aGVyIGRyb3AgaXQgdG8gdGhlIGJvdHRvbSxjdXQgdGhlIHJvZCAxLzIiIGZyb20gdGhlIHRvcCBv ZiB0dWJlLCBhbmQgYmVuZCBpdCBvdmVyLCwsLCwsLCxPciBzZXQgaXQgaGlnaGVyIHRvIG1ha2Ug YSBidWlsdCBpbiByZXNlcnZlDQoNCiAgICB3YWx0IGV2YW5zDQogICAgTlgxNDBETA0KDQoNCg0K DQoiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1Bp ZXRlbnBvbC1MaXN0DQp0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfYmxhbmsiPmh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCg0KDQoNCg0KICAtLSANCiAgUmljayBIb2xs YW5kDQogIENhc3RsZSBSb2NrLCBDb2xvcmFkbw0KDQoNCg0KDQo ________________________________________________________________________________
Subject: gas tank float idea
Date: Apr 12, 2009
A guy could probably get creative and make this thing work. Just have to come up with a way to attach a Stainless Steel welding rod through the bore of it. I suppose you could solder a thin piece top and bottom and run the rod through it and solder. http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=7215711&PMT4NO=61847625 I used a big fat magic marker body for mine. I pulled all of the ink soaked felt out of it, turned up a small fitting on the lathe for the end of it, drilled and tapped it for my 3/32" threaded welding rod and then welded that onto the marker body. Just some ideas. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238819#238819 ________________________________________________________________________________
Subject: Straight axel again
Date: Apr 12, 2009
I have a gear mock up now built. Would anyone mind sending me pics of their axel to gear mounting in detail of the traditional system in addition to any non bungee designs Thanks Happy holiday John Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Subject: Re: Straight axel again
Date: Apr 12, 2009
John, I used Fly Baby gear which has no bungees and a single axle, wire braced. Fat, low pressure tires are the Shock absorber. I did so because of Kyle Bradford in Eaton Rapids Mich. who used the same on his many year old Piet. When I looked at his plane I liked the simplicity of it and copied it. He sent me a copy of a Pete Bowers article which shows how to build the gear. Bowers is/was Mr. Flybaby. I'll send you (or others) a copy of what Kyle sent me. It is from an article datedMay 1963.--Jim Lagowski in N.W. Michigan ----- Original Message ----- From: <amsafetyc(at)aol.com> Sent: Sunday, April 12, 2009 6:12 PM Subject: Pietenpol-List: Straight axel again > > I have a gear mock up now built. > > Would anyone mind sending me pics of their axel to gear mounting in detail > of the traditional system in addition to any non bungee designs > > Thanks > > Happy holiday > > John > Sent from my Verizon Wireless BlackBerry > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 10:51:00 ________________________________________________________________________________
Date: Apr 13, 2009
That would be great please forward for review Thanks John ------Original Message------ From: Lagowski Morrow Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: Pietenpol builders Board Sent: Apr 12, 2009 7:25 PM Subject: Re: Pietenpol-List: Straight axel again John, I used Fly Baby gear which has no bungees and a single axle, wire braced. Fat, low pressure tires are the Shock absorber. I did so because of Kyle Bradford in Eaton Rapids Mich. who used the same on his many year old Piet. When I looked at his plane I liked the simplicity of it and copied it. He sent me a copy of a Pete Bowers article which shows how to build the gear. Bowers is/was Mr. Flybaby. I'll send you (or others) a copy of what Kyle sent me. It is from an article datedMay 1963.--Jim Lagowski in N.W. Michigan ----- Original Message ----- From: <amsafetyc(at)aol.com> Sent: Sunday, April 12, 2009 6:12 PM Subject: Pietenpol-List: Straight axel again > > I have a gear mock up now built. > > Would anyone mind sending me pics of their axel to gear mounting in detail > of the traditional system in addition to any non bungee designs > > Thanks > > Happy holiday > > John > Sent from my Verizon Wireless BlackBerry > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 10:51:00 Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Subject: Re: gas tank float idea
Date: Apr 12, 2009
That looks like it must be a type of float for a pressure vessel like I have seen in the natural gas industry.I would expect it to be pretty heavy for use as a float in a gas tank. but for sure at 750# working pressure it shouldn't collapse! I do appreciate all the ideas on floats. I am thinking I'm going to hold out for some type of brass float because I am afraid that Cork could start to crumble and block the flow. but with a good finger strainer in the tank I doubt that would be a problem. thanks for all the great ideas.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=238851#238851 ________________________________________________________________________________
Date: Apr 12, 2009
Don't know if anyone saw this site yet: http://www.gudim.com/ReplacingCorkFloats.html Brass floats from Ford. The web page is a description of modifying them to fit a Studebaker. May be useful for your needs. HTH, Jeff ________________________________________________________________________________
Date: Apr 13, 2009
Ryan wrote- > I have a question about the method others have used to attach a "Cessna > style" axle to the axle end of their split-axle gear. > We are using 6.00x6 wheels and tires. >They come with axles >For reference here's a link to a shot of Bill > Rewey's gear from WestCoastPiet: > http://www.westcoastpiet.com/images/Bill%20Rewey/IMG_0393.JPG Ryan=3B if you get the pack of drawings and ideas from Bill Rewey=2C one of those drawings is of the gear legs and axles. The gear on 41CC is pretty much built per Bill's detail and I have the same wheels and axles as you'll be using=3B one pic attached but it's not a great one. Best thing is to g et Bill's pack of drawings or wait for the next issue of the Brodhead Piete npol Association Newsletter... word has it that Doc Mosher is going to repr int the gear leg construction drawing in that issue. I did find that I had so shim the axle on one side after the rebuild on my airplane to get both wheels to track straight. They make tapered shims tha t fit between the mounting pad and the axle but they're very expensive. I used calibrated washers. Oscar Zuniga Air Camper NX41CC San Antonio=2C TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net /9j/4RheRXhpZgAASUkqAAgAAAALAA4BAgAgAAAAkgAAAA8BAgAYAAAAsgAAABABAgAMAAAAygAA ABIBAwABAAAAAQAAABoBBQABAAAA1gAAABsBBQABAAAA3gAAACgBAwABAAAAAgAAADEBAgAHAAAA 5gAAADIBAgAUAAAA7gAAABMCAwABAAAAAgAAAGmHBAABAAAAAgEAANYDAABPTFlNUFVTIERJR0lU QUwgQ0FNRVJBICAgICAgICAgAE9MWU1QVVMgT1BUSUNBTCBDTy4sTFREAEM4MzBMLEQzNDBSAEgA AAABAAAASAAAAAEAAAB2ODUtNzMAADIwMDU6MDM6MjQgMDg6MDg6MzMAEwAniAMAAQAAAGQAAAAA kAcABAAAADAyMTADkAIAFAAAAOwBAAAEkAIAFAAAAAACAAABkQcABAAAAAECAwACkQUAAQAAABQC AAAEkgoAAQAAABwCAAAFkgUAAQAAACQCAAAHkgMAAQAAAAEAAAAIkgMAAQAAAAAAAAAKkgUAAQAA ACwCAAB8kgcABgEAALICAACGkgcAfQAAADQCAAAAoAcABAAAADAxMDABoAMAAQAAAAEAAAACoAMA AQAAAIACAAADoAMAAQAAAOABAAAFoAQAAQAAALgDAAAAowcAAQAAAAMAAAAAAAAAMjAwNTowMzoy MyAxNjoyODoxMwAyMDA1OjAzOjIzIDE2OjI4OjEzAAEAAAABAAAAAAAAAAoAAAADAAAAAQAAADcA AAAKAAAAAAAAAAAAAAAAICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAAT0xZTVAAAQAKAAACBAADAAAAOAMAAAECAwABAAAAAQAAAAICAwAB AAAAAAAAAAMCAwABAAAAAAAAAAQCBQABAAAARAMAAAUCBQABAAAATAMAAAYCCAAGAAAAVAMAAAcC AgAFAAAAYAMAAAgCAgAyAAAAZgMAAAkCBwAgAAAAmAMAAAAAAAAAAAAAAAAAAAAAAAAAAAAACgAA AJgCAABkAAAAEv9T/jH+Mf+u/q7+U1I4NQAAW3BpY3R1cmVJbmZvXSBSZXNvbHV0aW9uPTFbQ2Ft ZXJhIEluZm9dIFR5cGU9U1I4NQBPSlogUGVyc29uYWwgQ2FtZXJhAFJBAAAAAAAAAAAAAAIAAQAC AAQAAABSOTgAAgAHAAQAAAAwMTAwAAAAAAYAAwEDAAEAAAAGAAAAGgEFAAEAAAAkBAAAGwEFAAEA AAAsBAAAKAEDAAEAAAACAAAAAQIEAAEAAADcBwAAAgIEAAEAAAB6EAAAAAAAAEgAAAABAAAASAAA AAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/2P/bAMUACwcICQgHCwkJCQwLCw0QGhEQDw8Q IBcYExomIigoJiIlJCowPTMqLTkuJCU1SDU5P0FERUQpM0tQSkJPPUNEQQELDAwQDhAfEREfQSwl LEFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBAQsMDBAO EB8RER9BLCUsQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFB QUH/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAE EQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZH SElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1 tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+gEAAwEBAQEBAQEBAQAA AAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGh scEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlq c3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV 1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCAB4AKADASEAAhEBAxEB/9oADAMBAAIRAxEAPwDo mRT7H+VUblFG/vjpWFRaGkNyhbyLbXYkdVK7grlmChVbhmJ7YBJ/CqmjRy+HvEmpxZVbUtuRgRhP 4h16gKxH1A+hyirp2KmdtpurWUu3/SbeQsQMcqfx6ipfEV1Y3WnSW0hjiWRON7rznoRg5pJvlJue Jzqbe6miZ1ZlcgheehNWr8G5kt1TLSfZVYDPUjJP6A/jW3VCtoX9DvreW38m5dE8rgb2C5Bzj68Y qbUJbcXUDxXELKwdHw4OMjIP5rj8amURxZgaoFnuwyqWAQDK/jVa1tXmuFTawGea0o+9aBFS8byO j1GaKwtI7MFEbIMrEH5T0A+g9h3PXAra0nSEvPDDfYZjHJfQKHEqKymRSexGRzu5ycbsjoMdWKlt FHPho6ts4OeOaCZ4ZU2vGxVhjoRwajEgGS6MRjoDtP8AKua+mhvy6iefFtP7ps9iZB/hTxd24ABh fP8AvClyy7j07BJdQtGdkZVugJNVzI3ds596cU1uJntzD5SBkH0A6VTuUAHXrRNaFxMa8gWaKWF+ FkUq2OOCMU5bt9WstP1V1kPmxCGSRyoDSLnOADxk7z0HGKxp7mk9iDWLKOT5toGQOTxXG3lv9l1N o2UNvXPXjHIrRpJ2IUZOPP0TsZ8LESHd1J5HvV7M0jQsG+ZF+QjqME4/z9KpkIsw2hReF5pWicVm 2mapNDCjitGxQWkJupcbhwgPQt/9auvBU1KfN2OXFTtDl7mRfM8+8tn5vWnrqV6LWG1E8gih3bAD jGevTrWVSfPNtGkI8sUmQeYSec0b2rLlRpzMXefQH8KaTnqo/KlyjchpiUnOMH1qS20e4vpcRKev pW9GnKcrIxqTjBXZ6xpl0b3Tbe6LKzSRqWKjA3Y+Yfgcikut6gNgEd+3XvSlsWtzKlC7tzAkdMA4 NZ2kSFLfVLKVdoguGu0KqG2g4z3HUFRx79a547s1kapW2uE23L7Y9hOeO3bnrXFa8tsdbjFuNsKr sB/HOcfUmuiS1uZRm+Xl8ykNO3zSFySCxPHTnmrtnZLCCM5yc5xWbdxpWLexQOKayfSosaXFWLMg X15+nvUV3J5snlqP3ScAD/P416NJOlh3Pv8A8McNRqpXUexTuI93PIqm8RB4NcC0OtiKD3qVVB7C mxJkqR56AGpobR5iqxoGd2KqOmWH8Oex9M1dKk6jJqVVTRdS1hggMrMSxBdFHBkXo6EdnB6Y/wAa jbUJF3Q28pCq+c55PHBz/nkZrtqS9lH3Tkpx9pL3jrfBFyZdF8osuYZGVV74PzZP4k/lWlclcYyC e496438J2dTPnBHBxnNZlmwstfkuAXCSxjeQ2M8FT+QANc8FeVjSTsrivhlARXUjO0SDO0ZOPfoK zptKkZzNLs29B6c+xrrcHynOnqKYFXgKMelAT/ZFYWNrikADNMJwCeMChRbdkDklqyKZyiYXPmSD AGeg9KhYFIwij657mu/F2jGNNHHhvecpsgbeR8w59qgkU1552EBAz71Pa2rzkbCBk7Qf9rsPx/rW lOHPLlM6kuSNzVjs4oFVp1YqylhH/FKvR0I7MMZHr+ZpJroeW0YfCOApKHmQDlHz2Yfr+Vei+WlH +v6/4c4E5VJef9f18iobiTzN4Oxt287ePm9frUfUZBrzak3N3Z6NOKgrI6TwHLJFdXMZVQskYfJ6 jbxj/wAerfvZwrYLnfg/KByKqWwRM66mACrjJY4VehNOtIQheSSNSVXeQ3cZwPcdz+BFFONtQm7j 5GhC+SQVeb5iemF9PfsPpmsnxBOLO0+07gJS22JSp5AIzz79e2RjuK2WxiynoupteGRLkq8g+ZWC gZHfp+H51pNhugrne5utivIm/wCXoKqy8lgR8sfLe/tXRhoqVRX6GGIly035kMSs5Nww5bhR6CmS AlqmvPnqNlUY8tNIjKtnjpTXUH72BWBqTx6UpXzLmVYEPIBGSw9hUUd1Hb7o4YB5bDD7gCz/AI9v w9vSulKNKz3ZzNyqNrYhnuZpmLM5ycEk9SRxn2OPSocnOTz6ms6lRzeppTpqC0FyT3H5U7Ye/FZG x0togt3DxEo3YjI61ajZv/10J6Da1I42lkvGMYDYIjUhu56/Q/8A1q0IAxV0l5eeba2eMD+IfkGr VbGfUW/WNXuZISZDEPKUMhxnbkfhkiuS8SyPFi1+QwgbQpYErjHQZ44xg8ZBIq+hDWpm6NII9UhB YhWypx3yOP1xXUHJIBGCexrFmkdiG5fyIi3foOO9UsefKIckovzP7/8A667sOuSlKozkr+/UjBFh +B0qB1Bz2x1zXCdZG8D5DEeWn95gf09aaIzHOJIskjGHcAn8B0FK9mO2gkgdyWd2dicksck1Cygd aVwsRlB9KYUxQAnA605WXGM4pgdWVGPlJzT42DHBBB9DU7MvdEWiSF5FJAyS0mQSOegxitCyEhn2 tHvcL5mfRgACOf8Ae7+lb9DEsnEkEUUzCKSa4ypXvtbd1+if/WritcjN14hazVk2NKqh9gz82Op6 nHpnH5kkExb/AE+W2vtse1MDMWD0A6YPuT/Xua0pdQkkjT7DC8xc8sUOxRgHk/iKTj7wJ+6U5Irq RVmkPmlV2jAwSc9cf57VZhhFtDhjlurHPGa6atWLpRhAwp05e0c5ET3aEgJjnjcen4dz+FIu4MWw dx7uBx9B0H1Oa4zqGzMhlEjvvdiAWY5J4wB+goJYg4QjBxzQO3cYVbcfmGD6U1o0I/i/Ok0xpxIG jHTJH1FRtER3BoswbQjRbsdv60xosc9cUWFc7FI+3TFJeRKbOYEZxGx/SlYq9tStA7GLZFGBIykE nnt2re0+OOOVmkAEu3Kg8fhx24PNbMzQBpLyGynk3fKdzDknLIRx6/erj9NR5/GsiOWZvPl68/dD YHP0xQiWbF9Yw39/qFy/CW0aAHJwDuYE/hTbiWbUbVLRrZY4kICbVKttBBGe3GOhz/KnfewrbD10 aZ3SYXVmsSJhi84XYWGV3Z/vEMO/I/GqN8sVwU8iKTGxd5fGN20Z2rnrkHkk9eneueF1HzN2k2RQ wCMcKobuSct+dDRbvvEsMY44q9WTothBFsP3QPwp2zvirsQ33I3iOfamtGQOMe9KwEbIGPAwaiMf XikMjZcY4pCAaQzsQu0Go7tc2cwz/wAs2/kaCjPsVDF2UHC42rnGevNbGn3qrcSeYuV8oEjHOMt0 rQzG/aHaxiQLl3hOFPPYAH9a5XQZWj8XeZcMAyyS7/QYVqBM3JbuCB9Qilby3kJZAy8MCT3x+NVJ 9Tmf9wsrMMkBkXC7RwDzzk+hA71k5djRIWCaeOV5BKdzqUYkDkEEY/Jj+dPVM84FPfULWEaMj6UC L1/lVIkCnQjqaTA7d/arIGlBjgUxkH+NFgTIyACOBTXVDwTjPrU2KuVpIyo4ORUDg9ce1Kw7nZHk bRUUqGSF4wcFlKg9cZFSUZkUu+2eQjOV25GW5BPP6ipY5QZXKk7WUDnjkZ5/WtTMnimje2jIcxgp 1HBGRzz+Brlon+ya0blJAIzLIgduwORkj6EGk9gJLi/nmnaNo8OwaFs9Qe5x9DV23jbHXr0rHyNF 3L8MLGrKQE9atIGxwgJ5HSkNudx4/GrSIY1oyMgjio0jwCB2681RI1lZQcj6EVDICBxQIqyuQee9 ICrDkDFDQXGsgPQ1AynkelSyjqjgDqaYzlFGMk+9Z2NLmVGjRtJEnQnGFOcDqM/lVdjcowkBKsMO WU4O7tj8zWiM2WrVDJAjj5EVgp46kgj+tYmu+ak0cDr5carvVcDLE9STjk8fpSYEWiWwkuycfKo6 +/8AnNdVDbKMDHb0pJFIuRwDPcVII1HGKoLj9g6ccUxwB+fSqJImB45PHaoApYspHSmhDWRunXn6 1BJGcccCkBRnwDyGqDDbAf4T6Z4pkieZzt6/SlcLwT1NSykzog5Ix3pdm7OTkVijcrzRCOQSZPTa efxz/n1qO6tSFLKyMM7lHB479D1zn25q0zNoLGMZZHfIZNyDqAfX8ODWf4jtPO8u6iJaXBEik8gd uPxPFDYrEmi6a0MRLjlj1HpW7FEFTGTx1qkFiUKAMZJ+tDqccE59aYCYYcFs/hTSreob60xDGVye On1xVZ8oc8H8e1MQIxYHKnNNdQR90/pSAzblQpJ75qqe6Z4Pt0qiSBl2HBPPOakVx0P4VLGdKm0c nJ5yTUyFSewOelZI3YTKrgg/QZqkbSdGPkuwUnPT+lMklFpLwMjAORxjBo/s1WlEj/O4GN2BQoiu XEjSNeM5pSDyP1qxCDOT7c1Ln0HNIY0454pMD86YiGaaOI5kkxn9ahmCyxAxyBRnqBRcLDRjaOen fpUbtxjPFMTKVwo+Yr0zn1qjPtyeR1qiGVHf055603eAxzzjoaTA6pHIXgEnHQVKN+SSvy885rFH Qx6uOW5zUy5PUcZpiYpbJ470BgOM5PtVEgWpoJ6Z6elAhygevSnK5OenpnNADcnOT1HbNNJJbBzx QMhnt4pVO4E46c1H5SQKQoYD0JzigBHAIIH/ANaqzHDHb+VUSQSyqrHeBms+4KklgP16VSJKkmOQ SeAD2qs5w+3jmkxHWxOGXGSStWInG0Akt/KsToJUf8vepUkDHjA9qYmgYjpQvTNMkRz8o5ph3Eim IeGAODkZOM44p+RjryKBjWbHXFNZ+MDj1pAM3fyxUZAZdp9cUIZE2FGAeKjMiYI2cZPNUSU5XBJJ GO3pVSRAwIHX1qiGU5FZeWHA71VlHQAdKGB//9n/2wDFAAIBAQEBAQIBAQECAgICAgQDAgICAgUE BAMEBgUGBgYFBgYGBwkIBgcJBwYGCAsICQoKCgoKBggLDAsKDAkKCgoBAgICAgICBQMDBQoHBgcK CgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgECAgICAgIF AwMFCgcGBwoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoK /8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEF EiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJ SlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foBAAMBAQEBAQEBAQEAAAAA AAABAgMEBQYHCAkKCxEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHB CSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX 2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgB4AKAAwEhAAIRAQMRAf/aAAwDAQACEQMRAD8A+spL X7VeTXVr++/dbIo4/wDlnJ5dPvdKzI8MUO94I9/+t+evN/5dG38OqQyQy3ckI0vZCkEeyX/SY98k f/bSsHxBpd95ry6pDJsTy/Nkjkjf/tpsrjn/AAzZe5VKcejaXFoflapLJczT+Z+7jlj/AHfmfu/9 X/q6wby1llk8q/l2PBbbPLkl/ef9M68fFf3D1afszK1zRrCK4m/epM/3LaSOX5JK564sPKt/NuvM 3xy7K8edM76czjPHlh9qsn8qKB0rHs7TyriGXykRPK/1kdcptT/hnqn7OfjG18EfHzwZLLLsTWL2 TSPM/wCmkkckkf8A5EgSP/tpX0z8a/hB4J8T+Kb/AMCePPhzp3/CPeLdJntdb1D7THA93JJH+7jd P9Z/37rure9laqI5X7mM5D+dD4ueCPEnwM+LviT4UazK/wBs8O61d6fc7/8Alp5Ekkfmf8D+/wD9 tK9e/wCCc/x9v/hB+1R4b1SLVPsEOqyf2XeyffTy5/8AV/8AkTZX1VvreCc4fyHzP7yGJ5Jn7heD /GUVhqlnLdRRpvto7r/Wf89P9ZJ/0z/eRvX0Pod1peqaWkt/LYzfu9/l+Z/8bkr46FenTxHJM9Kn /DGSfD7S9T86K10vyf4/Lt7m42f+RPMkqz/wgctrZv5tr8kcX7yu+nD2nwG3tze0fQYpT5th5CJJ 5bxeX8nmf/HK6rw/4Slv9n2rQoHf7nmfYvJ/9F+X5n/bSvSoUzGpM6TT/Adrp8nl2EUCTP8A62O4 pnizwxKbP97ax/J/zzrsnQ/dGKqq54V+0Rpcd/o9zpcVh/rItn+r/wBZX4z/APBQj4QaZ4Sj0vxb o+j31tNa6ld6Jr/ma350Dz+ZJcQSQQSR+Zbx7Hk/5aSR+ZH+78v/AFdfMT/d5jyHROpT9kfDHxEs PsHizzR8iXcf/kSs2OKKW/tpRLsr6qhP90eRWhU+2dVeWvk6h5trL8kkm/8A66VDJFFv8qb7/m/6 uuCf7yqdlP8Ad0j7J+F/iO/vvh/pV/a2qTb7aN//ACHXzB+1BdWF/wDGi/v4onTz7aB5I5I9n7ys ahtT/ie+eLeKLaW11R5Yv9+tjUIf7Z8NpqkXzvHH+9/66R//AGvy5P8AtnJXsU5/7NA82vT5Kp73 +wP4jh8vWPAcs3+o8u9sfM/55yR/vP8A2nX0/JLYaXp81/f3SQwxxfvZJK5sUaUdZnAS6X48tdQf /hX2l31hbaje/wCsuLm3RJJJP+Wkccn+rrqvBfwgl0a8m8UeLdUfVdYu/k+0Sf6uCP8A55pXjzqV MR7kD0adOnh6nPM2I9Btf7Qml/4HFXin7dXw0iufgY/iOKPfNp17BdS/9/PL/wDalctH91i0dz/e UjlP2B9UtdU8Iax4durr57G93yx/9M5I/wD45vr0LxhYRS+JZvK8zZ5Uf/ouOsszhTp4iZOCr+5y GJcWHNfNv7Ydr/xXWmwxD/mHf+1KvIv+RjAMd7+GmeQ/2Nf+iU/7LfxH/VfPX3/tKR8xyIZJYXXl /vaP9Ktf+Xp9n/XWjnEtx8f+lXiS+bXVafoN/r1vYaDpcW+a+udkdc9bVwgbU3ZTmfSfw78B2Gha VbaDYxfuYItnmf8APST/AJ6V9P8A7I/7PNr8UPHEN/r0v2bw3ocX9o+ILyT5I47eP/ln5n/PST/V 1+84RLI+HObvA/F5upnPEXL2mU/23P2h/wDhd3xEeXS/9G0TSoo7LRNPj+5BaR/6uOOvmDxhrMUV u/8A0z/5Z105TS/s3JYI5s3rU8yzqci/8A/2Lfi1+1VqianYX9j4e8MQRST33iTWLmNII44/3kkm z/rmj14tb/2Lo3xghuvDvjvUrPStD1vz7bxRo8ey7jgjuP8Aj7gTzI/3nl/vI/3lfhmZ5jVzDOak /wCQ/XcBl2FweTQ/nmf0A+NPBvw5/aM+BelaXLdR+OfD3iPRLSeLVNQtvn1K3kjjkjuHj/5ZyeX+ 8r8Cvjh4S0b4c/GTxh8PvDmqfb7DQ/FF/p1jeeZv8+CC4kjjk3x/6z93GlfPXq/XT6Gc6f8AZXJA 5ISwjYD5dEnlf88q9GB48hnlRf60/PUPkn3q/aETgMfyog/72oZJYf8AllL89bGYfb/+ev36hkuv 3nm0GgRzfvP7lPjhll/1dZgTR2Eo/wBVFvqaPS5f+Wtr/wCRKn2lOmVyVCaLS+n+rqz9h/e1jOv9 s05KgyS1i9N//XSWneTD/wA8o/zrH6wX7AbFYebJ1kerJ0HVJf8Aj10u6f8A6aeVROvTLp4WqTR+ Ete6/wBjP/20rntQ8R2FheTWEvmb4Pkkopz+sVPcLnTqU6fvmbeeN4/M/wBFsN7/APTSmf8ACR3U sfm/crs+rmBWuNZvzH/x9PVaOWWXzpZZZH/66VfIggf0n2/m+bNfyfI/2nz/APrpJ/zzqa8i+1aj Zyy7IfItvIl8uL/WeX/y0k/6aUjsKeoX+l3SPH9g3/a5dltJH89Q65YRXVxDplrdeSknl+Z9n+Ty P3f8Fcn8T3JmlNfbOY1iLS4o4ZYrCOHfJvjt5P3H/fyqclhqmv7NLltbVPskUjxfwf8AkT/lpXlV 4c9TkPSoT/d++c3rEV1FH/akUskyebs/49t6eX/q/n/55/6uuY1iWKLzopYpHh/55x14tfQ7KRyv iyL7Lo/k2sOz91/y0qn4TMUNxbWt/L/r/k8yuVTp+0986acPZmb8ePEd14Y+HF/8QfDlr/p/hWW3 16x/66WE8dx5f/bTyPLr7k+MF/8AC/4l/Cfwx8X9U8W6VDoiS2Gr6TeXEuy1kkn8vyP9Z/y0/ef+ 066uSlXwVaIoTqU8RCf98/I3/gvJ8DNH8E/tYWHxk8L6ZBDo/wARfDlve+Zby/6y/gjjjn/65/J5 H7uvhy3+1afcJf2F1seOTfFJ/wA86+jyWt9Zy1en5afofP5nQ9njZn7efscfFbU/2pP2QLPxj/by f234WNpqFzbxwx75IJ/LtLuP/WeZJ5ckdrP/ANc99ewaH4N8Wy6omqWHiO7SaT/lnJJJ/rK+Bzah Vp4o6acKVRHZ6H/w0FoxSX+2Z3T/AFcckn/LOuz+Hfxz+KFhI8Ws+KI7ny/+Wfmf6us8PUxuHL+q Uz2PwH8X9Lvo0+3+Yk0n/LO4tt6Sf8Dr2Dwp4j8NajafaYfFCKije0Nre9P+AV9jlmLpz+M5cRT0 Ove5tFsjP5bSx7NwVU3EiuS8U+KrRH8y/toZEzm3Qn+D/npXuYmrS9irHHTT9pqeQfFTxlFrNu// ABL32eX5fmR1+aH7cnwL/wCFg+A/iFdWHhL7fqVrZf2ppt5Hc7PIkgk8ySPy/wDlp5kHn18biq3t MbCZ6Hs/3R+SPxgu4rrULOK1G/8A1jxf9c5PLrHs7uWWOG6+55dfW0If7N755X8Sqbceq/avs0sW zfHHs/eRf8tKI7o5SWKbf+8k/wCWtcczvp+/TPsb9lCT7f8ACezupfn8y2kgj/7Z+ZHXz9+2pYHS /jh5X8E+kRv/AORJKwgbKn+8OD1DwH/wlHwX1jxlpcW+88M3sD30cf8Az6T/ALvzP+2ckf8A5Erm Ph3dGW4m0Hyo5vtUf+jR/wDTxH/yz/7aR+ZH/wBtK9bC/wC7HBiqf707n4H/ABG0v4ffGzR9elun S2e2+xalJ5f+sj8v93J/378uT/tnX1d4b17S/iX4gs7HS/Eceq6VBJ9tuZI5Y9n/AEzt/wB3/wA8 /wDpp+8rGvTqeyIoVPZ1D0Lxha6pNHo/9jWEjvBrdo9z5cn+rt45P3n/AJDrpNPsLqLSksL/AFCS 8f7klxJHGkkn/fuuDkR2Tn9shvNL/wBMhv8A7Vshj8zzY5P+Wn/bT/lnXJfHDwlL4y+FHiHwxflH e+02eC28uL/V+ZH/APHK55Uaakqh0053Pjn/AIJ3+J/sHxV1Lwndy7E1LSP9X/00gk/+N76+gfGH lf23eSxf9M0/8hx1nnFNzqc8C8B7nPCZgyS8fuvnr5w/askiuviTZ20Xz7NKj/8ARklcmSq+YR9D XMYUvqyOCt7C1+0J+9jdKs6x4S8qP7TFDv8A45fLr6yderTZ8/T/AHhiSWvmxv8AwbKoaha/ZYvN l+SuynUMA0uW1+zp/wA9q97+Bfgj7LZ23iO/i2XM8ey28z/lnH/z0r2cgwX17OqMTzs4xKwuVTmf Q/w38G3+sahZ2ul2slzNdy7LaOOP/WSf886+pf2iPGWl/stfAO2/Zu8JSx/29qvl3vja8j/56eX+ 7t/+2dfrmdVHjqmFwcPtz/8AJIH5jlEPqtPE41/Y9yB8PeLNeiO//wBGV4z8VPG91FbzfYP9d/yy rXinG0sHls5HJkGC+uZlys/Sf9kb4LD9r39gv4e/Bb4TeJ5tOttVsYIPHUlpFJ9qktIJI/tdp/0z 3yJ5f/XOSvUPiZ/wRr/ZB8JfBu/+H3wv8JT2HiTX7mOG9k1i9uLq6jkj/wBRIn/Pv/rP+Wf+sr+b 8ZGrOrOKmf0Rltalh6XN7M9S8X/D7Xov2J9e/Zq+HV1BpuvSeCbjw14bvI5ZESC78v7HH/38/wCe lfz+/ETwv48+Gnie88JeLdHutKv9NuZLW+s7iLY8FxHJ5ckclVhJUqc+Sf2ycVQ+s4Kc4fYmZWme Ix5c0Wp3Xz/8svLpkevapLJ+6i+T/npXqez9nUPE5EWY7+6lH+tpP3v/AD9Co9p7MPYe0K+oebax /wCtk3v/AKqoZLrytQmsIvuQS/6yr9p7QhUzs/Bei/DCW3SXx54oks5nto3jj83/AFn7yT/4iuki 0H9niLj/AITFH/7fa+fx2Jzf2tqFP3D28LDLfZ/vyzb6N+z78hi8UWP/AG01KtK30D4GYz/b2nO/ /YXj/wDjlcE63ED+M6f+ET/l2atn4c+C0uzyr/Tf/Bl/9sriviJD4V0vxNc2ujTWqWkGkxv+7l3x yTyTx/8AtOpw1TMPrDjUCv8AUvq/PTmeieE/CXgiXw3Zy3WjWk00ltvkkk/56Vcl8JeCPLf7LoNi /wD2yjeuGeOxvtJo7MPQwPs/fIbjRvDkX+q0W1/8Bo6p3FrpcUXmxaXAn/btRTr1f+fhdeFIhkuo ov3UUXyVDJf+n3K6TiW5j+JNZisNPmuTL86R18/Xl1+9mupfvvJvr6LJzzswKHm+4q//AMu6RAV7 szzBlxL5UeaI5fKs3Hm/fpgf0vSf8fiX8sMafu/3v/XT/npR9q+/a/xv89c52FO8iMtw/wBqtY/s 0n+s/db/AN3/ANc//alU7zzYrhLW1l2XMckb23mR7/M/eSeX/rP3dc8zSmc9qF1Lql55uqSzzTSS /vI5Itn/ANsjqnJ/bN//AMSb/jzto4pH+zx/8s4/9Z/10ryp0/5zvp+zsY+qSxRWf2Swljmtklj+ zSfZv9ZXH65FFFqLxRSxv/0zt/nrxKx34f3zB8UebdW6S/u3/wCucVYMkX7uGHzd/lx7K4V/DOyn /EJtQ0u18Rafc2Gd9tdxeRLHJ8/7uSPy6+gf+CJPxQi+LX7Clt8Kdevkm1X4balf+FNbs5Lne/lx yeZBJ5cn/LPy5PL/AO2derlS1qQmceL+A4T/AILlfs6H4i/seah4yksfO1jwRqMGtWVxHc/6y0/e W93Hs8v/AJ5vHJ/rP+Xevyi+H/7N3ijWbOHVP+ESgvIZI9/mfaY/L/8ARlezlEfYKcDx8bPn5Jn3 V/wSz1nxR8Efig/gPxH4DtU0TxHFJa/Z7iX9xJHJH+//ANX/AMtPL3yf9s6+0rPxldeEtD/e/Zft OmySQX1vbyxuiTx/u5P8/wDXOvmc4ofvec2VT2dM9C+H/wC1D4S/s9LDWbVE/wCmlex+C/FvwS8Y 2by391A83/PS48uuPCVKVT3JlKvodJP4D+E2vXn/ABSYe5Ty/wB5JHLs/wBZ/wDbKpx/Ba18Oap9 q0bxdPbTf8so7iTZXpTwuGn/AAyYV/5w8SX37UmgQJbafrFpLZr9yWSSTef+mdcNqEvx91m4mutU 2PD5u+WTzKKlTG/AbU8Php++VpPiDLdRvpmqSwb0i/5Zyf8A2yvCvHEujf8AE11nVBvs9NufPubf zf8AWWn/AC3j/wC/deXOdW8Aqeypn4t/Hj4af8Kq+OHiT4aX8STP4f1u4sovL+fzLfzP3Eif9s3S ubk0bwvax/atUijhf/pnX2lKdX2RwQ9kc3qmqaD/AGgkPhyX5Ek2Sfvd/wDrP/3dVtQ1Tyrh4v4I 5ac4VDan7L7B9XfsL68ZfhvNYSy/voLm4SL97/20ryX9uW//AOLyWH737+kR/vPN/wCmklY/xKnI X/DLn7C+oaNqnxQ1L4aeI4vOsPF3hu7spbeT/lp5cfmf+i0evE/ih4D1T4LfFTWPAd/5iTaVfbLa 4/56R/8ALOT/AL9134H4DjrD/EmqRRahYeI4oo/3/wC//d/9NJP3kf8A388z/tnJHXtn7CfiP7B8 YNV8Ly6p/wAf2m/6N/00kjk8z/0Xvq50/wB2Y0z7Pju47W4SK6+R3/1clb1mbUx/62uCdSx004Fn 7KPL/wBbWJrlh5lnNF5Ub1E/fOlH5xeHLqX4I/toR22fJhtfFEkP/bvd/wD2uevoH4mfFDwlo/jD VdPvtTgtpo7nZJHJJ/q/3dcua0nUowmXgfa/WJnB658c/BFrsisNZ+0vJ/zzjrwj42a1N488dJrG jSzwp9ijSlllH2WM55hjva1KfJyHL/2f4jtZPNi1SRHqzb694ytZH82/85JP+ekVfR8+GxHxnj+w q0ynql/rN9ceb5Maf9c6ZcRy3WzzbWR6v91T/hkezOh+F/w+Hi3xZDYS2uyzj/f3sn/TOvp/w/o0 t1H9gtYo4U+5F+7/ANXX6j4d5b9YnPEzPgOOcdVw9OFGB9sfsv6D/wAKv+Eb/tGePPDljNDofn2v huO3tvIjnu5/3kkkn/XP/ln/ANc6+YPjp8S9V8b+JLzxHqt/JczT3MkkskklfS5RQdTOq1f7EPcP BzOvUp5NRo/bn754xrMuteJ9atvDHhu2N1qGpXMdrZW0Y+/JJ/10rJ8aaT+zd8JbhrX4r/EC78a+ IDF+80DwBqMaWlpJ/wA859Skjkjk/wC2Ecn/AF0r5bxBr1a/JRifQcEUlQ561aHv/YgfTP8AwS9/ 4KifBH4N+NdK+Ev/AArHUfCGm3erRpZXllqVxq/n+e/7yOeP/Wf6z95+7/79x1+m/hOW/wDir8QJ vGN156W0n/IJs5I5Ekgt/wDppH/00r8hzWEIQhCB+lZdOpUqT9tTKHjC1v7AW1r5rp/pOz93/wAt I6+df+Con/BPvwv+0PoafGTRrDZr32aOO9vI4v8Aj7/66VxKFVU7o9aiqUMQfjh488BzeA/Fl54X uok+2WMmy5jk/wCWdZXl/vf9VXq0J89PnmeNXgqdXkgHleV/rTUN5rNhpUnlSzb3+/W1P94YTKEe qeb52q3Uux44/wDRo/8AppUOnyyyxvL5v+s/5aVtyIinubfxA0XVLWTTZbqw/cyaTb/ZpP8Anp+7 /wDs6x7PwRr2oR/aopYNnmf8tL6s6NemqZc4fvAvPAetWtwkcstqnmf6vzL2OqeoeEtZ0uz+1XQj 2fc/dyxvW9PFU6hHIUJPN8yiS6lij8rzX/7+V0GY8apqB/ey306/9tKf/b+sxR+VFqc+z/rrWfs6 dTcBia9rOf3eqTp/21kp58R69F01m6/8CZKPYUv5A2Hx+KPEf/QZu/8AwJkq5p/ijxTLv8rWLr/w JkqJ4bDf8+zTnL8ms6zdaf5t/r07/uv9XJJ/rKp6PYWl/G91dSp/0yj8ys6dOnT+AB+qaNaxf8e0 Uif9tarXH7qNPKq6dT2gFC4l9as+d5UaRf8ATKtDM/pntzFLqEM1qJH8v/WW/lb/ADPL/wA+ZRHF +7+32sU/k/vHuZJPueZ/rPL/AOudZ/uzfnqBcWEvmJdWsrpNPL/rJPn8uSP/AGKreILu6+eKw2TP +7fzLi5+5/uVjXh9g1gYOsarf+Yl1ql19ps5I9kl5b/JXPSS3V1Zvqlro0Cb4v8Aj48z/lnH/rP3 deVX2O2hAwdQuvt9u91LLHC/3IvL+Sub1D/SrxP+Jf8AIn/PP5PMrwa9P7Z7GH2Oe1y6iiuEiiut jyfPH5lY/wDx6yJ5vl7JIv3XlyVwTOmmPjiisNQ/0CXfD/z0rz7/AIJqfFbxt8A/+Cr3i/4B+DfF tppulfEXy72WPULbfBPcRwfbPL/66fPdR115ZCdSdSEP61RnV9l7SHOfqf8AFjwbr3i3R9S8OeI/ 7NvPD2q6JcWWraPHbfv7uOePy5I43/65/u/+2lfix8CNB1TwHrHiH4I+KPPS/wDCWt3el3P2iPY8 nkSeX5n/AG02eZX0WVfWfrc4TPncX9W5ITge36fa6zmG/wBGv0try1ljnsbj7/kSRyfu5P8AppXT fGf42fEb4xeLLPxZ4i+H3hKz1VLJLW+vPDFvJp6X8if8vDp+8j8yT/lp5fl/6ujMsL7Re4YU/aVH yHLax481nwlp/lap4NvkT/lrcafr8n7z/gEkdVtL/bIsPAf7200HxUk3lf6yPVo3j/8AIlfJQwOp 2VqFT7A+X/goT4S+2Q3V1L4jhmg/5aXFtHP/AOPxyV6F4b/4K0+FrDQ00a6+PHiewTzZP3d5bXfl xx/9u9x/7TrpoYTE06hwTp1f+fZ618Pf+Cs/7Pes6Ls8ff8ABRXRvDM/mbLbTdR8C6zeyf8AXTz0 gfy61tY/4LTfCHw1Z3Xh+8/a1+D3iq0MLpZatpttqVrcMn8DyIIEEcn/AEzr6ShltT2PtznnmNK3 sbz/APBZwuuf8FQPhp4t09xbftS/DnfdSfuo5Nbv08v93/y08yzrw3xZ/wAFDvhfa+IJtL174teH 7mwuo/3lxo979qjkj/7aRxyV4mKyfG4hip46n9j/ANNnxh+3J8fvAfjj4oQ+PPAeqyTJPokFlfXH /PeSD935n/fvy6+crzx5rXijVEiluvJtn/1scdfSZbgfZU/fNvb1KlP3zY8N2sWlyXNgZd6eV5lb EctrLIkP8f8Ayz/dUYqH7znO/CT/AHfIfQn7E+sy2v8AbFr8j/6t/L/6aVxn7bkwm+JGiXU3l/vN E/deX/10krjo/GXW9n/OcB8O/Hes/C/xhpvxB0aLfc6NcxzxR/8APT/npH/20j8yOvof/go58NNG +Ivw78PftS/D6VLmzntreO+uI/8AlpaT/vIJP+2cj+X/ANtK7sCc2KPlfQ/+J94XvNBll/fWPmXt t/1z/wCW/wD5D8uT/tnVzwf4y8WeF9fsPFvhK6ez1K0i2faLf/lnJ/q62/dnOtUeqWf7V/7Rk0fl XfxGvnT/AKaW1u//ALTrSt/2uf2kLCRJbXx5Jv8A+mljbv8A+06551/3n/Ls2oYGm6d/3n/gw0oP 2zv2lh08ZQPv/wCWcmk2/wD8bqz/AMNfftLSn/kM2L/9dNJt65vrtP8A59myy2pU+OoeLfESw8Z/ EH4iTfEHXrpEvJ/LeWS3j2fvI69X0f8AaI+I9hZ+Vf2GjX/mfPLJcWP7yST/AL+Vz4iphsRT5KlM 66eEq4ep+7qBcfH3xJKHi/4RLQ/3nyf8g3/V157qul/2zqCXV/FHvgtvIj8uPZXmU4YbD1OeEPZn fOeNxFPkrVOcZH4YtRHn7L/38qtceEopt/7rZ/zzqfaVfac5sqH7vkKw8ERSyf8ALP5KP+EI83/l 1R/+udJY6o3YX1Wkkel/DvwR/wAIvp6WEUUfnSfvLmT/ANp19Cfs7/CW+8eeLLbS/wB4kP37mT/n nH/y0kr+sOGaFLJeD4Tn8fJzn848S1MTmXE/JCfuI7b9rz43RahJbfDnwvdImj6HF5NtHH/5Ekr5 O8ceJz5b/va3yWh9Uyt15/b985c2nTxeNVOB5F4w1SXULe5urmWRIU/5Zxy/6yvOtDl0u61x9Luo k2Tx7IpP+mlfimeY2pj81rOH2D9WybA08Jl0D7G/4If/AAV8L/Er9rzUpfFltBNN4S0S4vdNjuP+ e8kkcccn7z/pm71+0Ph7SotLvPt/kv8A9dJP+Wn/AH7r5jF4R4irCZ9PhK9Kn7hj6xc2vinWLz+x dQtbxNNkkgufscnn+RPH/rI/3ddzJ4d1W+8HvYf2NPc2f2bZJ5nmf6uq9jUJ+tUr/Gfir/wVg/Z4 8OeDfjR/wmXhe/tLm21WWRL6SzuY3jjkj/1ccnl/8tP/AI3Xyd/wi/7z91JXJ7erh/cnA661OljF CtAhuPBtrKfK+1Sf9/KrSfDiw8z97v8A+/ta/wBo1KZh/Z1MLj4aRTf8tfkjplx8L7r/AJdb/Z/1 0qP7YKWXFnxX4d+IPicW32nVIEhtbaOCKOP7n7usG4+GnjPzP9bG9aUcywMEoWIrZbjSGT4feM4v 3vmx/wDf2mXHg3xv5f72ben/AF1rrWY4Koc31HEkMnhfxl5n72HfTJNG8W+X/wAeG+ulYrDGP1Sq QyaX4o8z97YVDLpWvRD/AJA0lbqvSZn7OoQ/YNUi/dRWDpUP2XU8/vbCSrVRMxD7LdRSeb9lkq/o +qS2EiS/ZY3/AOmckuylU1NCbVLW/wBU1hza7Hef/Vxxy0x/Dnii0/12lzpWXtKdP4w5KlQh8rVI rhIrqKdP+ulWbyX78vm/J5VWBj+b51wgNWbi683fLWhmf053n/Eh+xxQy/vki2f9NI/9XJ8//fdH lCG3/wBbG6fu55ZP/adZnV/Eqj7P7VdRzR+bs/dfvJJP+eclU7iWWwkv7DS7DyUjj3+XHH8//AE/ 5aVzzL5/Z/Ac9rn+n3kOqWFhB9pT5JI7iT93J+88v/nn5f8AcrE821/tD7V5qQvPF/q4/k/1lebX OzD7GV4kur/Qbi8tZfPtk+zeRcx2cv8A6H/10/1lcZqlr5tw8X2pN8nz18/iofvD0qFQxNUsIrrZ L/HB/qpPLrEuLWWWNL+KLfs+SvJPSp++QyS/cz/z1r5D/bI8ca9+zp+2T8N/2i/Dh2XOlG3uonj/ AOWklpd+ZJH/ANtI5/LruyZ2zCPoY5hL2FNSP3W8H/EHRvjJ4XsPih8JfGVjqXh7VdN8+xjksf3n mSfvPv8AmV+Wv7dHw58b/Bv9vh/G/jPS/sdn8TdNjvbK48yR4557Ty7eT95J/wAtPL8iST/rpX0G CnUqZjCcDxMTRp0KdWEzb0OLzfJ/e/I//LStvS9L83UE8379erjoVKh5lCp+8N7x54SEvhuGWXS4 0hk/5aSRV4V44+H0QuHHlRu//TOvm4UD051PZ+4eUa58PorW8mllO+uG8UeDYoa2p0yJzPKPiB4c +yyTY+5/00rxOzupRqn2aU/8ta9zBfwjgr1P3h6R4D8qXU7PzYv9ZJGlbHjTwj9g8UQ3Uxf7NPJ+ 8k/55/u683FT9njD0qFP2mCPLviBdSy+IHsPN3pB8kVVtDtfNvLa1Mvk+ZL/AKyvco/7tA8ep/FO 5+yxW3iBD53z/Zo/M/66SVcs/KP73PyVyVjpoU/aHrX7I/i3/hF/FGpWsVhJco9tHJc/9M445P8A Wf8AkSq37ct1a3/xM0r7B86R6TH+8j/66SVzQ/3g6Zw/dnktndf89fuV6X8J/wBpEeF/gvqXwq8e aXPqumweZBptvJc7I/In8zzI/wD2p/20rpwv7uoc2KVSpTPH9Dur/Rtchv7XS5JvLl/1ckX+sjro fCf9qWviSa6sNBn+xyf6v7RV1/Z+zChCp7T3IHoWnyxeZ5v2VEqzJ/rEmhijrxJ06Z7dOdQZJLF8 n+ibHqGS6/651j7MftKpDcX/AJX7ryk/651DFfjzHzWfsDX2/wBgJNUlik/dCj+1P+WPlbMUewI9 uPjupZY/NiutlH2ofP8Ava5J0Dppzph9qzsrb8L2v2q4+3iH5I5P3X/XSvc4byepmedUKX988niD HU8symtWPSPA+gy3UiSyxf8ATSvp+4isP2ffgn9quotmveI7bf8A3PIt/wDnnX9VcR0/Y4Ohgofb P52yOpfGVMZP7B8qeOfFtzfyTSyy70krxzxZr0uqXn2X/wAiV5HEWJp5fk85HXklGpmGZwjM5Lx/ LFF4fe1il/5aJXmMcsUOqP8A7H+rr+fMsnUq05zP3LGQp05whA+kP+Cdf7Sw+AX7UGm/FrXo3TRL vy9L8SeXFv8AMtJP9ZJs/wCmckccn/bOv0a/bo/4K0eCPhp4Dh8G/sya9a634t1W2j/4nlnL59rp MEn/AC0/6aTyf8s4/wDln/rJP+ecnVU9m6fv/YOGnUqKryez+M/M2z+JfjLS9Um1nS/FGq2d5dyS T3N5b6lIk88kn+skd45P3lWfEHxa+IPiiP7L4o8eeINVh/556hrdxN/6MkrwXi8bT9yEz1ZYTDV6 inOmYkmveTZvpcUzpbeZv+z+b8kkn/PTy6rfb4vLxXN7OrU9+Z1+0pKpyE32+1lj/dVNHLFj91Ls eicDRV6QfapcfutlP+3wxf8ALKsfYnSq4/7fazSf3Kk+1xf9M6x9h9kPb/bHRy2ssnmxRffo82wl /wBbCiVE6DRdOvUD7LYSx/vYo6JdLsP+WUVC9pTCc6f2yncaNF5v8H/bSq1xo1h/sVsqlT7Bzez/ AJytJo1r/wA8kqncaNF5fmm1jdP+eldlOvVMfYUrchTuNLjl/wCWSf8AbSs3UPCVhdf6212f9NI6 76FepTOCvQpmVcaDdaXIl1pf3461dC8W69f3D2l/YbESL/WV3zhTxdP2kzm/eU6nuFDxgYpbhLvz n3pHsrntUl/d5rpofwjCf8QzY5f3mKsv/qvxroJP6dvtUstmmqXMu9577Zcx/wDXSOT/AOIq5bxS 38cMXlbEk/1Ucn/LP93Uwh+7NA0+WWH97FfyJDJbSJJJJ/rP3n/POsG40uwtdUm8qw+0pH88ckkU n7uoqUylP+Qp6xYRRSPf6pLOiRxyJFH5W/zJP9iuY1SKKwkeW1l8lI/LT95Fv/eV5U6Z306ntDNu JbWK4T/WJs/1sckv7uT/ANqf8865jUIvNuH+yRSI8nyeX/yzrwcVA76HvmJJaxSyfZLqWOF/K/1n 3656S1luv3UUTo/m7JP3leVM9KloQyWso3xRD/V18t/8FVPDgv8A4N+G/GUX39N1/wAiT/rnPbyf +1IErTLLQx0LmOYVOfBzPvj/AIIr/HjxR8eP+Cc/hvR/Dni2+s9b+F+vyaDqVvp8UbyX9p/rLSOT /pn5c6f+A9M/4LMaN4y8Z/s/+HviLdaNI83gDxTHqlzcafFvSCCT/RJ/3nl/u/8AWQSf9s69LFVs TgMyU4fAcs4YbF0ffPB/h/d2us6XZ3UUu9JI/wDWV6Fo8UUdwn/XSvsZQqVUfL050kzufEH+leD/ ALLLao6eZ+7rx/x5oP2WNJYvv150KB11pnlfizQfNkfzYv8Atp5deaeMNB+/5MVROgYqp7T3Jnj/ AMQPDk1/cfZfN2b/APplvr5nvYP7L8ZzW0u9Nl7Ilb4Oa53A2rUP3ftju9OltJdHubqwk8l4PLfz P+2ldX8R9a8I6x8FEltYfEa+KrSPfe3lxqUf2SePzP8AWJH5fmf6v/ppXFUgqmLXP3Ojn5MN7h4H HdfvPNupnd6v2d15svm+TsT7lfQLY8o6Hw3L5Un7r5H83/lpVnUPDGqXWsXkX/CRuifaZHjjrinU 9nVOqnT9pTNj4f694t+GniT+2fC/iN/tMkez95Hv8yOrPijxbrPi24fWfEcqPNHFsj8uLZ+7rCdS 9QunAzdPtbqX97LFvf8A5Z29XLO1lurzyrDZczJ8nmf8s4KP4YfxDodD0GK6uEi82Sby/wDWyV1V vpcXmc/hXNOftTppw/dlwWsvp/1yo8qLzPK82uacPsHYv5ynJF+7/uVWkil8z/YqkTyEPlebJ+9l +en3GlyxfvfN2VlP++aFaS1l/wCeu+meV5v/AC2qF7T7BXJTqU/fGSSyxSeVF9z/AJ6VZjll/wBV UTpip1KSqchZs7C61S8Swtfvv/3xHXovhfQYpbiGKwik8mOLZHX6p4U5PUqZjPE/yH574kZjTWCh hYfbPor9nf4c6XYXD+MvFNr/AMS7R/3/AO8/5aSf8s464D9oj4vX/jzxLc38t18kcv7qP/nnX7LU h9fzzn+xA/Jafs8BlfJ/OeCeOPEYit/K87564xLo2sj+bFveT/lpX5f4mZjbD/VofbP0XgHLabxH 1mf2DK8URWt1pz2v/PSvPbjwJqkt55sUsGyvyXKqns6dmfpeYQ9pVOz8N2Nro1mlqYtiR1pf2zHF J+5irGvTqYjEc5dOp7OnyDJNe/4HT49Uilj/ANV9aPqn7sPrX7wJLqKX/nm9Mjuv+eXl1dOh9gid f937gzzZf+Wv3KM2sv8Ay1+ej+H8ALb94EnP+ql/8i0ySX/ll5v/AH6q1D2hHs+T3wjuvSX6VNJd fP8A63YlROh+85zanX/d8kB/2tf+etH2+XzU8r7lc3J7Q2pz9n8Ex/2+XP8ABspn9qXXmP8AvaPY c4TqVAj1m6l/1stP/tS6/wBVLElHsw9pUqB9v83Z5vyUzzYpZEzLV8hKnqFxD3+/R9lil/dVGtOm Vf2lTkIbjS/N/wCWWyqdxpfkyedFF8lbUqn85E6H8hlahpXm/wCt+f8A7ZVz2oaDFLJ5X3K9XD1z yp0ypL4YjjkxEZDV/Qvhr4n8Ty+Xo1hI6f8APw/3K9PCQqYyqqNH4zjxdSGEp+0n8B/S7HFdRSJL 5To8kUbxeZ/q/Lk/5af+jKfp0t19o8qK6khtkufPto/K/wCWnl/vP8/9c6k6an8QI47qWR7qWXYn m7/L/d+X+8k8yqEk11YB9U+wTzeRFs8vzf3lZT/dmplahf8A9slIrXz7bZ/rZPK/d/6vzKx9cltY rd5bCWRE+5FcSS7/AP8Ad/f/ANXXm1zqpHGaha38V5N9vup97ySJ+8jkTzP8+ZTNYtf7Qkewilke aOT91JXj16f7v3zvpz/kOS1iKK18mb7Vvf7kkckezy//AI5XN+VLLcTReb/rJK8Sv+8+A9Knf7ZD bxY3/wAdeX/tv+HbDxn+yZ4y0uWxd5rHTftttJH/AM9IJI7j/wBFpJRhfcxdOYYr95gpwPHv+CE/ 7XOqfAf4+a38Jc3cyfEKK0tdNt7f/VyanBcfu43/AOmckck8f/fuvv8A8UeCP2lvj7qHj/4X6p8L rTw94b8Y6bf2tzb3Gm7/ACLjy/L+0eZHJ5cfmbP9Z5f7yuriCjjVjk6cAyX6lPDQnWn/AHD5j+Ac Ws+F/wC1fhf4y8v+2PCur3Gl30fm/wDLSCTy/M/7aV7Tof72RPKir9Aw8+fCwnM+KxdOlTx0/Zne WflXWiTWsn3PK31wHjTT/Nt/N8r56zp0NSZzq00eaeJNL80PFXGSfDTWfGWoQ6XYWDpDd3MafbPs 2+OOssXUpYKlOpM7MsyzE5li6dCHU808afBbxRa6okWg2sGpTXcvkW0cknkJJ+7kkk8x/wDln+7S SviL42WOqeHPitq+mX7I08d8XkESfJv/ANivnuHc1pZ1fEQPtOOuEK3BWLp4Ct19+Br+F9Z/s/T7 mLyY3S7i2f8AXOun0/S5fEfg94v+mUlr/wCQ/Mjr0cVD2dXnPkqb9pS5DxOL77/StW3uTLH5X8de wtjzDV0O6xI/m/8ALOunt7qK6uEv/uJPbRyf9tP9XXFiDqw5sfD7yv8AhYGlfb/9TJcxpJ/20/8A 3lWfiZ4Mi8G+LHsLqV0hn+e2k8quPn/eHTyL2ZT0/S7u/wB8nlR21t/y1kkre0vw5LdSJFa2skNn H/y0/wCWklRUqF04fyHW6X4cltY/3UUeyOr/APY1/wD88vk/56VzVK5304U/Z8gSaDfyyf62mSaD deZWPtjbkGGwl/1MsWymXmjS+Z5NWq9T4CIUKRT/ALFll/13/bKiTS5aidYKdAhk0vP/AMcqtJo1 11/8iR1fOT7AZJYSy/62of7LO/zPstRzinC1P3ztvDfhz+xtLSWX/j51G2j/AHf/ADwg/wDtletf B/wHdapqMNr5TzPJ/qq/pXw7wtPK+Gfbz+2fhfG2K+v597CB6X8fPHlh4S8N23w08L3W+G0+e5kj /wCWkn/LSvmPxpr0Xzyy3VfTZZCpTy+db+c+azD2dTMIUf5Dy7UL+XWdQe6l+dI6p3kUsv8AsV/O nGmO+uZzP+4ftnCeB+r5dDn+2ULibzpPJqhcRRxSf36+Zw+p9JOBD+9l2fvqJIpYtksUvz13X9n7 hx/xBkn2r02U/wC1S/8ALX7lX7OmZ89T2g+OX/prJvp/2m6/1Xm81HIaBHdVN9qi8v8A1Uj1HIi4 eyDzYvb86JIsSfuvuUg/d1PgIZLX79PwP+eJqf3g4E3+ppkkv/XN6xNv+XQzzYc/vZfk/wCelHm4 4+/RyEh537r/AGKZ5sstXyE+0H4/6afPU3ky+Z5uajkC/wBgenX8Km8qLqPkegqAXl/9gjeWX/ln T7f/AImmlvqlrFvhSTZL5f8Ayzq4YT2lPnJ+t+zqQgU7i182TP8AHU3hvwHYeI/Olv7qSGGP5P8A R7be8kn/AEzrqy2hUxmJ9jAxzLEfV6XtJnW+D/2eIrq4+36pFJMnm/u45K9v8B/Ae/v9mlaNpcj+ XH/q46/ojhXhLDZRS9vP4z8N4m4mq5nV9nRqe4fsNJL5uuXksv8AqbWykS2jt/8AWfu/M/1n/bT/ AMh1W8qW12Wt1KkKPY7PL+//ANtP3dfhdP8Ahn7VyE15axSyfuon+zPF/rI/uVWvbC1sLj/QC/7i L91b28W/95/7TrGZoiGSWW6s7mWw1SNPMj2eZb/O8f8A0z/eVieIIbWKzS1updk322RJI7eL5/8A rp+8rjr/AMI0p+09ocfefavtCWsV1+58vZLcSeXPWbeWFrL5MWqXU6JJ/rJI4t/kR/8AXOvGrnoI 5XWPN+e/uotiPJs8zyv8/wCxWDeWtrFqE0V1FP50cX/LOX/lpXz9SnT9oevh/aWMeP8A4+OJX2VT 8WaNa+LfD+q+Erry/J1XTbi1l/7aR+X/AOz1ktzWpsflH8FPEfiP4X/GHRfFOjXX2bVdD1eC6tpP ubLiCTzI/wDyIlf0seD7/wCF3jz4X6P8efCXjyDTfDGq2UGo/wBn6fc7JI7ufy5JLed5JP8AWeZJ /q6+yzGHtKUGjwMFU9w/PH9omLRvBH7fHiH+zLWSwtvF2mwapLZ3Ev7+O4j/ANHkkdP+WfmRpHJX beG5sf8ALWvVySft8HCR5OaQqUMQeo+E7WK68NXPm/f8quJ8WWv+j9a76f8AEOOX8I868QWER3+V DI9ct8ZtS+KvgnQNA0/wd470vQtKvtAkupbufy/M8z7RcRyf8s5JP3b+R+8/6aV8xxvL2OUSlNXu fq3gjRq1+NYQof3uc818I3Vzqnj+O5uviUmqw/bY7WO3jM6SJHJJ5aSb5P8Alp+/T95XxH+234cu vC/7Q+sQ3UW1Ljy57b/bj8vy/wD2SvmvD6SdKsnT5Nv60Pt/pC07Zxg5+05/cOa8KXX/ABK4ZZa9 a8F2st1cPHEJNl3FHdR5/wCmdfX42H7w/B6NT93754Rr2lnTPFeo6XKf9ReSJSfYIpY/OPzvXpR/ hnnj7Y3UUfmxeY6fcre0LVLWWzhii+e5T/lnJSn+8NVubej6zFpeqJqnmxo8Esb13/xM8W6D4os9 K1rzUufMk2S/Z5Pnj/4BXmzoVKh1qZZ0PwtdazGl/rNhstj/AKqz/wCWcf8Av11ul6NYWuyLyvnr gnU+xA76dP7Zt2dh+78qIfJVyOKKX/llIlc3Ojvpw/dj5LW18z+5TJLC1+f97WUy6fs/gIRYRTfu v3e+n3Gl4k/exbE/56eVUe0qGv7soXGjS/JLLVa40uIfvfK+T/pnVe09p8Bkqfs/jIbiwtf+eVVv 7Li+ceVUQqVKfxlzhTIZNG8mT/lnV/QNGtZrx7q/i2W1rFvlj/56f88469HK6FTMcfTowPPx9eng sLUrTOq8JaNd67rH2+/ik3vJ/wA9a+gfC1rYfDn4fzeLZZU+33ceyyj/AOecf/PSv63xdGng8pp4 Oj/gP5noV6mIzKpWn/jPBPHHi2W/uJrq6l+d/wDnpXkXijVLvWdT/su1/j+SWs+I639l5ROf9wrI KH9oZnALjRooo0ii+f8A651m6pYRRR+V9yv5IxFSpjMVzzP6TpUKeHoqEDEksJfn/exp/wBdKoT2 EsX73+OuinM5+RFMy+TcUz7Va/7b10r2lzm/xj47qw/1Utq9Wf8ARfL77M1cvaB/EITa+d/qoqJL CWL/AO2VHtAhTqB9l/6a/wCspgiEXWWSr50HJ/OTRyxRf62pvNi8z/VfJUfvA/d+z98P3XX/AJ6f 9NKJPN6Zj2R1HOWofyBJ2/c76HsP3j0e09mWv3gz7B5v+tG96k/s/wB5Pzpe3L9n/OH9lzUkdhL1 mo9uR7MP7GlH+tp8dhLF/sVM64U6BN9m9qI4pZZP9unS1qhU0pe+aWqfDnxPdaPN9miSZ/L/ANX5 n36p/DPSdQi11NAh1NIbPWIvJ/0uTZHJJ/zwf/pp+7/d/wDTTy6+0nwtiMJhoTn9s+QhxFhsXVnC H2Dp9Q+EGvaX4gfRtUDp/wBsq9X+F3wWurqWGKw0Z/Of5K+94I4cwODqTqfHM+O4zz/HYilCEPgP pP4X/sq3V1bpqniiKRIf+ecf369Xt7v4VfCrR3hlv7WwSD/nnJ588n/bOvvM0zX6vT9jRPjMuy76 xU9tXPr3VPKsPECXcPz2zxRzxx+b+7kj/wCWf/ous24iMVvciK6+eSSSOWSP5P3cn/tOv515PsH9 D14ezqcg94ootnm73eOP/Vx/9c/46pyQ2H2h4rWXyYU8t7n/AJYVjUJKc9ha2v8AxMNBtPtM08ci RSSRR/u/+em//pp/00rB1SKwiM1hYSu7yfPJ/BH/AM9P+/lcFeB0U56mJqF1a3Wofb4pvtMNp5af Z5I9/wC7j/8Ajf7z95WPql1a3Vv5Wn77m5jk3y+X8kfl/wDXOvKxB3L+IcZ4ltf3f+ixb38rf5fm /JHWJqkX7z7V/wBMv9ZJFXg16Z62HnTMiOKKW8mtfufu6dHLF5iSy/fT5P8ArpXItzoPy5/aS8OR /D79rPxTo8UWxE8SSXUX/XOf9/H/AOh1+y//AARr8b+DfiN+yPr3wq8R3/k3+jX0k9zJcXMeyO08 vzI5PLk/d/u/nr7DE06dTLoTqHzuExFSnVrQgcx/wVM8L6Npej+Evi/o2jWr6loerxpqWoafc/8A LpJ/o8nmQf8ALP8A1kH/AC0/5Z1zHgu/+1W8MsUu95I99dHDNSl9XnRgZZ2qtTknM9X8D6h/xL3i ll+/F/yzrnvEkUUtv5Mv/PWvpKdP94eFOp+7POvFgitbN/NO/wD651yti3gPxRpcmkeOBfReTbz2 1lORIggR5I5HjxH+82b4Ef8A4BXhcV5Xic2yedKh8Z994VcU4LhHjGjj8Z/B+Cf/AG8cRfWXwv8A B3iPSo/B3h8GCC58ya9ih8t5PIj8yOPfJH/z0RJP+2cdfI3/AAUqsv7A+L40CMKYJBJP5jRfvIJd 53x7/wDnn/Hs/vk14vCOUYrLsBfFfGfQ+MPFmC4r4lVXA/wYfAeRfDiw/tjw/MPK3vBJXq/wnupf 7Dz+7ebTb6PzZP8Alp5cleti1zs/N8L/ABDyb4+aWfDnxdv4vuJMUmrDj/1ePNrto/7vA55/u6pc s/KlkSKU/JJRqmgxeW+qWvyJHLWfP7OqHJ+7GWesy/aEsNU+RH+TzK9a8J/D7S/9Gv8AS5d6eVv8 yOTf+7qMWa4f+KekafYS2kflfvNj1q6fYf8ALWvBn/DPZp/xC/b2BilTMuz/AKZx1cjtYukUqJUK HtDb+H8AC1/5Zyxb0o+yxRSf6r5/+udItezGfZZYrjMUtElr+74l+Suf94WrfAQ3n+lR/vfMeq3l ebs8r5KP4Zc/fGSWkUsn+u3vTJLAeZ+6ikonqRT/AJyaPR5bqRIrWKSaaST91H/z0qzqOn2H9oQ+ F9Li3pYy/wCk3H/Pef8A5af9+/8AV1+i+GGVVMw4i5/5D4bxFzL6hkvJ/Oeo/Cfwbay3ifaonjs7 WLz76T/nnHR8dPF2qXWyWPYlg8f+jeXLvj8uv6HxWKwyzmFGtUPxShgcQ8rnWonz9488URRRv5Ut ZvhTw5La2b6pdf8AHzd/P5kn/LOOvzrxWzX2WXexh9s+48Pcu9pjPbfyFzUPKiTzfNrntYusSeVF 89fgNCn7RH7NUqHPahdS/wDA6zbi6li/5a70rsp0zzZ1ChcyzSy/6qqcnm+bXTThyGPtPaB9qix5 Uvz0R3UUQ431tyGBcj1TypU/eU/7UZZP9VsqORGnOWY/Kurf91LJv/65VZgsJf8Al6rmnA6acyaP QfNk/dS7KZL4cl8z/Rd+ysfaG0vZhHoN1/z12P8A8sqJNLv4o/76UKf84ew09wms7SGX91LFIj/8 s6uf2XF/z12UTmFCn9uZZt9LtZY04p39i2v/AD2NY8h005/zkn9jWp/5Zf8AXLzKfHo0Xl/6rZWZ oH9jy/8APsaYNL8mTypYvv04a+5AU6dP45j/AA/YaNr3iT/hHJbvZc+Xv8v7nmVvfE/4F6pqHhCb VPB1tIL+1j8+W0/vxx/6zZ/00r9Q4U4Tp51ls6/P78D864h4pWU5rDC8nuVCf9lD4laX8QN/gnWZ dmqw/wDHt/08f/bK6T41/A3S7T7TrMOqo9vdXPl6tBHL88E/+sSdI/8Apn/y0r9Ey7FYbHcLezxP xw9w+AqUMTgOKeWjT9yZ1PhjWR8Vfhvbf2xa7/Gfhi5ktdS8uP5Lu3jj8yOeT/rpHX0b+z/4j+H3 hz4X6P4olljSa+/dyx3EUjvBJ/zz/d/vP+en7yuLJ80/e+wXxnVnmXWw8Kn2Dz79p/8Aaa1TX/E+ nfCvwjrMelabrcjwXOoRmRJ/L/55xv5nlx+ZXZfGz4b/ALWHwg/ZY0f4x/GZPBGg/DbxZpwHh7So LTTbXUb7ZFmO4f7P+/lf/npI/wC8/eJ5lcHGWKp4Dko1vjmd/CWDeZVOeE+SB9jfsf8AxfHxa/Y7 +G/xQ+1edfvokej3vmf8s7uCPy5JJP8Anp/q67+3tZbDT4b+63u/+oi/efJ5kkfmV+e1v4kz9QxX s/rMyaSWKKzeK1id5pPk/eR/6z/npWbeX9r/AGB+98hEni/0n/RpHSP/ALZx1hLY50VvKltdLtv7 V0tEf/VxXFxbRpHJ/wA8/wDWf6z/AK6SVz2uXUNrcZPmb3+Ty/K+eP8A6af5krlrmtP+IU5PDkug xvba95kNs8UbyahZy7/Mj8v/AJZ+Z/n93XMahLf2txDdaN9qhhTzJ7aSP5/Mjj/5aV42Lh7M9KhU 9ocxqkUUsSRWFh8kku+P7R/00/v1zGs2sUWz7KZH/wCmleJi/wB5TPRoT/eFCzxFePFdRSfJ/wAt K6fxhpfw5i8Nw3/hK/uprxJI3/eR/wDLOT/nolYYT6tUpThWNMUqnuTgfmh/wVA8Ljw5+0nYeKYb XZDrmi28/mf35I5JI3/8hxpX1F/wST+IOjaN8ZdH0XxH4tn0fStVi2S3kcsn+s/5ZxyeX/yzk/1f /bSvp6VNYvIuRbHjUajw+cH6QftGfBHwl8WvA+pfBHWRO/8AaumyQW3iC8vY7WeOSTzPL+fy/wB5 H/yz/wC2lfDHwG1TXrXw3/wjni21ks9b0C5n07VreT/WQXcEkkckf/fyOStOHKdOnUnCAs1r1KlO HOe8fD+WKK8SGX5/M/56Vj+IJeZovK/5aV9R/wAvD52f8MufDv4Bf8Lajhv7rxv9gtp7mSDy47He /mRx+Z/y0k/d/u/+uldbof7L/wAIPC8jyy6NPqtz/wAsrjXLmOeOPy/+mcf7v/v5Xh47HVanPRge xgcJSw/JP7Z4/wDtu+HP+KH02W1tY4fsOtxpFHHHsjjjnjkt/wD2pHX5rf8ABRzVPDnjbxbpvjLw 3r0epJPLJ9pkt/8AVpJJHHJ5e/8A56VWB/3cjFfvKp4z8J7+10aS5+1H5JP+Wde0+E9LitreHxHp f/HnPJ9iuY5P+mn/AC0/9F1w47+IdOB984b48eCY9Y8Qabqd1FJvksvIlk/6aRyeXWJpfwvtZf8A j6mdK3p1/Z4YxnQ9pVOks/gtoP8Arft8iJ9//WVf0/4X6LYXHmxXU8373/VyVhOeJqFr2dOoHiT4 QXXiO3TyrCBH/wCWUldD8H/hz4j8EW1zYazfpNC//HtHH8/l1HtKlOnyfGdNOnTqVPbfAd/HYSH/ AJZf6z/plWlb+HLry/3Ur/lXBP8AnO+n/IXI9Buv+B1fksIvL8qaKTfUTqFw/ie4U5LXyt/lS/JT JIpR/wAtaj++XD+SZDJFdeZ5p+emeVL6/rU85FMhkil8z97R9g82Ss5+zNoTIZLWXzP9bUwii/5a /J/1zrORtTnULOl3UujR/avtSJeT/uNN/wCmcn/LST/v3/6Mq/4L8LGKTzYvnSOX93JJF/rK/o3w jwNPB5dPEzp/Gfg/ifmX1jHfVofYPRfHkUujfDubw5Ff/Zrm6j33Mn/TT/lnXg/ijxlrP2ea1upY Ehkl8z7Pbx7II/8ArnX11TJ6WPzKGNn9g+Yp5jVwmC+rfznDaBY/8JTrnm35/wBDtPn/AN967n91 5nlRRb/+mlfhXiRmn1/OfZ/yH7BwLgvqmV3/AJzK1TyvL/1fNc9eWvmh/Nir4PDwPrak+cxNQ0DE jn56yrzQfK3xeV/q67FOp9g5+QyrzS/K/wBVFJVOSwl/4H/00rpp1PaHFOn7MhktD5n9ymfZTEP/ AI5XTAiZJ5f/AEyqW3ilz130f4wL8fm9c76s28ssX72KKuaZtTnURcju5ZZf9VHU0d1df88vkrm9 mdPP7T3yaOW6/wCeWz/ppU3lXX/LLy9lSbL++Pktbu648qOjyr+KJMfwVhp8Bt/17A3Uv/LTzEep o5Zevm/JVk+0qj/9bs/0rZVm3ilhk/1tG/uC/vmrHoOvX+nvfxWsjokX7z93T/gXr2jePdQmsJZf J1K18z/R/wDnpHX6Fwfk31TOaP8AaFP3JnwPFmauvk9aeCqfB8Yn7TPwB1/QoYvjH8PLWQG08v8A tW0iH3D/AM90r3f9gzXLH9qO80zwbHfQWetG5jgvftEXyR/9N/3f/LOv1KNL/VLiCo6f8CtD/wAn PzbGVo8UcPU5z+OE9TS/4Ko/8Em9X/Y517Svj58IvEEl/pl9v/tue3ttlpBf/wCseNPL/wBXG8f/ ACzqP9kjWPhx8WvhQ/iLxjbDWbyPUvIvdMvLnfGn7v8Aj/5aeZ/208uvzrhrE/60Zn9ZrQ5Oac/c P0XiejT4aymhXw/v+4vfPMfGGoR/sq/tEWHla86eHtZ/cW155W//AEf/AJYb/wDppBJ/o8n/AEzq /wCNPFtp4D1SbU9GhgtrPWJZJ444/vwf8s/L/wC/nmV62Kr08i4t/uTPKnD/AFg4d9z7Z5l431u7 8Y3FvdXNsYZoZN5kH/kORKz9cv8AXvEe+LXtUnvP3Wz95LXyHGnFP9t43kh9g+o4S4WeUYJTmfpB /wAETPiDF4j/AGZ/Fvw0lm33Oga3aXtt5kv+rjn/AMyV9n+baxXNtqkttG7wfJbRx/8Afuj95Upw n/ch/wCknsYv2X1j3A82W1vXl8qSZ55ZHto44/8AlnVCOwv7XVIf9Bk8nyt8vlx74/8AV/3P8/6y sZnNAoSWtrfia/mup0hnlkf7PJbb08z/AJaf9s6ytUv7W/vEi1nUI7mGPy/K8u2+Ty/L/wBX+8/5 Z1xzOim/sHMa5LF5c2jWvyeR88X2z5JP9X+8jTy4/wDV/wDPTzK5i31nzbN7WKWCGZ/Mglt5Iv8A WRyf8868TFfwzvw+5m+bcy280v8Azz+SWSOSNP8Axz/43WbqmjWsWjpaxf8AH/8A2lJ5nlyfu/I/ 5Z/+RPMryuT93753qf8AIc3cRXUWqTRS70/56R1DcReaPKlPz149T+KekvgPkj/grP4RN34H8H/E aLZvsdWuNOk/7bx+ZH/6IkrmP2S9eu9Lt9K1618vfaSxzxRyR74/Mjr7fIr4jLeSZ8lmH+yY7ngf sl4T8efFD4ofBPw348uvAej/AG+60nfFZ/bvstrPJ/yzj/56fvI/3nmf8s/Lr5L+NnhK/wDhf+15 4htLvS/s1t400208S2373fBJPJH5d3sf/lp+8TzPM/6aVxZDXxOHzLkmdmdUcNUwqcKh3PguWKXZ 9lmTf/zzklqn4gll+0XJl/5619vT3PlZ6U0dz+zH4t1SLf4csPDl3eW0Gtx3slxbyxv5fmW9xH5f lyf89PLr0XxZr0Wg6PN4p8by/wBiWzyyeX/bFt9ik8v/AJZ/u5K+XzCn7TGzhA96hUpU8FCcz4// AGqP2h/BGv8Ahe58JeEvPv5pJI3l1CSLyI/Mjkjk/d/8tJK/P39oTwaPiNcQ6D4I0a1sIYLmS6+z /ad/l/u5PM3ySV6WHwNTCU/fPNqZj9Yq8kPgPCvB9r5uqJFX0J8J7W6l+H+vaXLFvhu7mOf95/yz /wC2lebmP8h34WH2zN+Lml/arO2uovkeO9/1flf8s5I//tdUPC/hzzdkssW+oVc25P3p1tnYWsUe Da/P/wAsvMjrVt7WL/n1SsZ+0OmnOmX7e1l8v/Vf9c6m0/yx/rbX/v5WZM/4pt2d1axDzTao7v8A 6qtKPWYv+WVjsep5PaGvtAkv5fM+1C1pkmqSyxvF5XzvWM4F06hD5v8Ayy8qREpkkX7vzRLUTgdM J+0Hx2trFG8ssvz/APLOPyqrSfvZPKiqORfzkU6n9wI/KijeY/wU+3+ymTypYtlSWv74+TS/Os3l i8uobfS5bq88rzfJhj+e5uJP+Wcf/LSijTqVaypixFSlSo85iW8v/CR+IH1SK1khh+5bW/3/AC46 9X8H6XFpdn/bN18nkf6r93/y0r+yslwP9k8OUKJ/LmbY7+08+qVjj/iJ4k+1XDj7VvSP/ppXjPin VPt94mjWEX3/APV1Ga4inhMDN/yF5bT+sY5c5saPFa6NZppflfJH/wAtP+eklaRlxGn+i/JX8lZl U+t46daf2z+kcH7LB4WFGBQ1CWKWT975iVQuJYfM/wBVveuX2FT7Bp7amZt5Fx/qqzdQ/wBF/e1o gn+7plC48qWTzZIqoXFhFNH5tVyVKZjz06hQuNLi/wCWXyP/AM9KrS6X+85+/XTTmc4z+y3p9vFL FziOtqdT2hn/AAyaP/prVmP97H5X/POoqBTqe0Jrc/vMfcern72VP9VJXN/y89w7L/u+SY/yh/qu 9WY4popEm8r5P+utHJVNlX/d8hZj80/vfL/26s+V5sfHz1jOgWq5NHbWH/LSGn/2Bayj/RbqinTL 9v8AYJtP0Gwv9UTSxLsmf/lnVz4n/C/xR4R+H83jLQd/+ieXPcx/8tI4/M/1lfVZNw1isVg5432n +A+VzLP8NQxkMLM9O/ZT+KugfELwX5ujaNaJr1j8lzcSfO/l/wDXOvOP2j/2fPFfwX8cW3x4+E1t JHps9zvks44v3cE//PP/AK5yV+n4DhyrmuTLM+fnrL/2w/Oqmf4bLs5eTTh7lQ+vP2RJfh9+038K 38RxX9jC6R+Tq2l3n/LOT/lp/wBs6+efjr8J7v8AYW+LGl/Gr4TTXckJ1KR5bdPntbu0/wCef/tP /v3X1OYVqmZZLTxL/wCXfv8A/b54WS0sPg8bXwFX7fuH2Xqms+N/jJ+zfo/xL8ZRalqXwx8aW0kF lJ9uj8iOT/Yj8z93JHJH/wCQ6/ObXIviD+xv+02/hfwvrUepabqvlz/8S+LfBd28n/TP/pn/AO06 +KzDNMpx+T/XMp+xP3/8Z9HlmBzGlUqZZmtT44c9M9B/awi0H4oeC/K+3x77WL7VZSf886838B/F DVPiN4fh8Oa9a/vtNstn2iOL/WSR/wDLR/8App5f7v8A7Z15HG3+0KhiaM+efIenwZOpToToVvsT NKTzfLSXzd6UySLzY3/0Df8A9M6/IJw/eH6+p/uj6W/4Ip/EuLwb+1Bc/DnVLr/RvGOiSWUXmf8A LS4j/eR/+z1+pUkv2r/RfK/49LaT7N/38/8AIf8A9sr7ahP2mCo/4D56v/CDyjDslilj2SSbP3f/ AC0/5af5/wCudU7ywtbqzhsdQi2eZ5nmx2f/AC0k8z/WVotjjphqF1/odnYapax3PnySPbf9MPL/ AOef/wC7krm7i6i0u5SwtdGnvHTy5LnzLb/ln/z0kj8v/WeZH/rK4q5tT9+oc94wurq1uH1mPWft LyeX9pt/s0kH7zy/+mdcZeaeIrxJYr90RI4/Nt7iWT/nn+8/6Z14mN9melhYDNdimsI3iuoo/JeL f+8ttkn/AFzjk/55/wDkOSscX8v9nzS/YILnfZSQf6RFv/7aJ/00rx5zPQW5zdx5Utw8v/PSqckX lRddiV5U/wB4ejSmeIf8FCfCP/CUfsn+IRFFvm0e5g1GL/tnJ+8/8hu9fNP7JevWsukJaxXSP5cv /LOT/wBp19pkFal9T98+SzuhU+u88D9hv2A/iD4X+Kv7N6fC/WfIfW/DMtwltHeeX5n2f95JBJBH /rJPL8+SP93Xgn7cFhrNrH8OvjVa6Bss7S+/s6+kj/1kcd3HH5f/AF0jkkj/AO2cleZWqezzmHJ/ OerQ/f4KfP8AyBoevxRRwyyS7H/651c1DXopZPKtfPd3/wCnaSvv4HxM6f8AIY9v8RvFvw+kuZfC 3iS+0eafy/NuLeSOGT93/wBNP/jdeV+PPi//AMJHqk11rOsz39zJ/rLi4lkupP8Av5UVK+Gw/vzB UKuI+A8r8aeKIroeVYWF3cp/y1/0byP/AEZXhXxRtfFGvRzWGg2v2ZH/ANZ5cu+SSP8A5aVwV8d7 RHSsIeb6X4WltY/tUX8FenfC/wAR6zo2n3Nr9qjvLaeOvBr1PafxD28PU9n7h2Hji1i8U/Dv+3vK RJv3b+X5v+s/eUeG/C/2DS0/vv8A886xhU/d+4bVoVPaGlHoPlSeV5XyVN9g8r/gFWE/aFyztbX7 R/p+/Z/y08uXZU1vpcsv7vzfOej+GRT/AHnwF+ztfssnMW9KmuIv3n+t/wC/cVT/AMvDadTnJo7W WWPyvK/1n/TWmHS5YpPK/gqS4DJIrrzHi83f/wBc6LjS7qKNPNidEestfjNv7kxhlv7W3mijlkRP L/ef886hH/PWL5/+efl0zKAySKWWT/bqa3sJYpEhltd9c50+0qnQ+H9M8qTzbuL5E/1lYnxg1SKw 8nwRo3yXN35c+r/u/wDVx/8ALOP/ANqf9+6+v4Hyv+0+JqMZ/YPl+LcxpYDIq0/tln4d+F5ZbhP3 Wx3re+IniO10u3TS9L+5HX9WVp81eFE/nVXhTnWPFvHHiiWLf5sv/fyq3gPwRf3Vv/wlF1Fvmuv+ PaPy/wDVx1+a+JGa08NlXs4fbPvOAcuqYjG+0n9g1ZNLurX96IqZ9gllk8qL7/8Azzr+eOen8Z+2 KnV+2VpNGhijeW6D76pyWEUvHmyUe1LU6lOoVri1ii/deb8lZV5o8ssf7obKIfzmM/ae0Mq40uWK PEVZtxpd1/qopaoxn7UrS2Ev/LX56hki/eVov7gcn85Wkil/3KZ5UsMlbU/ZnN+8fwUw82XzPKl+ Spo5YopPN837/wAlFTcFBD/N87915vz1ct7rzZPK82OtV7Ow/wDl4X7eaL5P9W71Zj/elJYpdn8F QdEP4o+T7UZOJfkqzb/apY+uxP8AppXP/EL9o6fvl+30vULq3e6tYpJkT/WyVsfCew0bxn4gv9Bl /wCP+x+f7Pcf8tI/+ekdfVcLZPTqZrR+uw9yfwHzfEucVIZVW+q1Pfh8YftSfCXxH8PrPSvi/wDD mwu3ttNl2al5fz/ZJP8A43Xt/wCy/wCKNB+PHgf+2dGtY/tMnlwa3p8nzp5nl+X9z/nnJX6jkOAw uV8QzwVf+HP34f4z84z7F4nH8PU8wh/Eh7n/AG4eNfG34G+OP2H/AI8WHxH8E6OU0HUv9KtreT7k kf8Ay3t3r7m8J+KPgZ8efgHZ/wDErkvLDxPZbJfL/wCXST/45HJXt5ZTqYDNK2Xx+378Dx89/wBo weFznk/uTPieyv8Axb/wT7/aLfS9Uv4Lzw5qX7i9kEcnlz2/mfJdx19RfGSL4c/G74Z6r4S16XZD fR+foGoRy/JaSf8APST/AJ6R+XXm4OpjqH1rB0vsfB/2+ejmc8F/aGFx8/gn/wC2Hy3+yB8ZfiD8 DdUvPhV48unv/Dela/vi8N6hcSeRHceZ+8/d/wDPOT/pnXZ/HvTB8X769+LOg+Ek0pNLuZJ7L7HH J9kjjf8A1lgkkn/kPzJP+WdfJYb6nQwVaGKqezhDn9z4Oecv5z36k8as5hPC0/ae25J8/wDJCPx8 h4HrEXjL59L0a6/0Of5/9Ik/1dY/g/8A4SP4aeLLmKKJJrbXI/Ik/ebEk/5aV8HRzGpCpCEvsH3G Jyen7OdSj9s7mO1ll/deb5Pmf8tJKP8AT7Xf9ll+SvBxdSlVxMz6TBqqqUDe/ZT8b/8ACvv2kPA3 i2WXyUg8QWnmSf8APOOT93J/6Mr9vNUll/tS5u7WXybby45/3f8Ay08yT/lnJ/1zkr6TA/vMugcG K/h/9vyC3upbWPyopZJpv+mkX/LT/Yot7qX7R5Nh8k3lbLm4uI98f+r/ANZ/yzrc4/3n2Chb2Gqf Z5opdZnSaePfbXHmxv8Au/3f7uNJI/3cn/XOsqS6utLvP7L0vQY4Xguf3dvH893+8/5afu/9XH9+ uWf7sun7/uHK+NNG1S11CG/uooPOni/e/Z/nj8yuV1zRrX7On7qSGzkj3xySRx/6z/rpXiYqgelQ n0Me8l+1SPayxf8AXLzP+WdVrj7LFHcxX9rv8z/V/wCs/d189Of7z3z06cP3Zz155X2jzfOkd6py S+ZbvF9z+OuOc/3h104aHN/ETRrXxl8O9e8JX8W+HUdJnspP+2kckdfnd+yfN4ci1H7Bfywf9NI7 iL/VyV9Lw7/Dmpnz2d/7xA/Sb/gnf8ZNG+DfxUfQdLl0pIfE0VvBJJJbb0jkjk/1n/ft5K+hP2vP Ad/8ePEHiT4D3/he6udKvvD+/Tdct4o/+Jbqcn+o/wCWnmeZHP5cnmeX/wAtJK5s9/2TFKcP7h3Z RT9vShz/AN8+PPhfqhtfDfhvxl5upJeJffZdSjuL6R/Lk8uSOSOSOT/ppW38YNZ0vx54bsItL1m0 m8jxJaQXslncxvJb+Z+7k8z/AL7r7GlC8UfKVKlKcinJYfD7w5p6Wt//AGO9zHF/x8eVH5j1iax4 t0H7O/2DT5Jn/wCelvYyVpQoUqdP98Z1q9Wv8B5p4sml8yaWw8LvD5nzySSeWnmV4/8AECw8ZX8c 1ha3UFhbSRf6TJb/APPP/lpvkqK/svjgFOFX2nvzOS+H9hEY/st/s2eZ+6uP+WcleqaX8G/C8uyW 60aPzv8Apn8leJUqHt0Kf850lt8OdGtbdP8ARd6R/P8AvJamt/DlzLH5vk/JHXN9s6f+XfuB/wAI vLLI/mTb3p8fhyKKT+//ANc6r/l6RTp/yFn/AIRy1tY/9VU0elxRR+bF9ysTp/uD7ew/0zyvK2eZ F/wCpv7Li83HlVM/4nuEL++Pkitf9VLF5O//AJaUy8tb+WNIrWNJn/66bKv+H75cv3j5Jl/yrSKP yvKSF/8AlpHVOSX95+9rGFP7Zc69qnIMuLDS5dko37/+mcknl1WkurCWV7S1tfnp8hHP/IQyWo+f 91smklqaz82KPzTLI7/9NKzn/cNlOl9uBNJqn9gWU3iO/i/c2v8Aqo/+ekn/ACzjrg7OK6v7ybxH ql0iTT3P7y4uP9XHJJJ/rJP+mdftPhdhfq+GrZhWPynxGr+1q0MHRPWtHv8AS/Dnh+aWLy3m8rZ9 oj/1ckkcn+sj/wCekdeV+MPGN0l69zLL8/36/V8or1Mfh/rNaHxn5zm1N4TEKjD7Bw+gaBfePPFP kj/jztPnuZPL/wDIdep+bYWv+ixRbH8r935dfgniRmNPEZrDCw+wfsHAuFxGHy/20/tmbqN/YS7/ ALXLs8z/AJaSViSS6VYXiS2svzx18BCHsz7afs/g9mQ3n2q//eyxfJ/yyrNuLC68z91df9/Kx9n7 N+4UihcS3/z/AMb1QuPt/wDz12f9NJKun+7Mpw+sFC4l82R/3v8Aq6pyf88j89X/ABDFfuyGT971 ++lVpIvN/exUfuy5f3ytcRSkP5VVv9V/rRV/xCPg+MhuP3Uf+q30yOPzea1h/DOeetUf5XlR/u/M eiOX955X8dOn+8K+D3C5b3UX+q/jq/HfiKRP7lX+8Cn7OoX7OH7fcQ21r9+eTZF5kv8Ay0rrdQ+E viO18PvrNhK8zwfPcxx/88/+ele3kmSYnN+dw+weRm+cYbKHBfznT/sv+I9G+INn/Yt1sTVdKk2X Mf8Az0/6aVj/ALTHwb8ZfBvxxYfH34abIbOO52X1n5fyR3H/AMbkr9VWEWO4Wo4mHxw/9sPzX29P C8UVsNW+Cp/7efVf7Ncvhf8AaW+G6X+l+W9hfR+RrenySf6vzP8AWR1833nhLxv/AME2P2mH1kw/ bNBeWOeX+NL/AEyT/lp/10jr0cesNUwdDNcN8cPfOHKY4ieIr5Rif8B9jfGC68G/tYfC9/CWvX9o +larbefoGqW8XyWlx5f7i4/9p/8AbSviH9lf4yeI/wBlr40al+zx8UP3Om317IkUckv7u0u/+eif 9M5Pkrpzn9ziMLmEP65zmymax2VYrLKnxw9+H/bh7H+1/wCBbX9o/wCHn9maXawJ4h0q2kk0iSP5 Enjj/wBZBXk3wc+Ld3pHgjTfB2qy3Tww2WyykuJN/lyR/wCst3ryc+zWllPENCt/4GdWUZdVz/hS dP7cPgMzxrf6L4o8Qv4jtI/9MePyb3/pvHH/AKuSpv8AhPPHv/CJ/wDCB/8ACZakmjxyb5dLjuZN kkn/AD0evzHjbH4fGZrN0PfhM/S+CcBU/seisV8cDEkEXlpL5uyoZPKl/dS18Up1Pjmfdz9l8A+O WW1k/dS76NQur+W3f/V/6qo5AhP91yHPSfafM821l2eRL+7k/wCedfuF8BPiDL8S/gX4G+IPled9 u0CN764/65x/6uvqcu/5FsP+3Txan/L7/Gdnp8uqRRQy3WswPDJbbPM8rZ/202f8tKmki8p4YrWF JpvKjnkkkl/56fvP/Z66+Q5jNvJYhbzS/wBjWM1zBHJ5Ucf/AC0/3P8AxysG30a6it7y6lutVmf/ AFFtHb+W8nmf7cn+rj/1dctQqmYOsWt1fXFzYRaDaW1/dXMf2a4t77el3JHH+88v/np/rKoSWEWs 3kN1LrP2Cwjj/eSSW0jwRyeX/q/L/wCmleTM74HJXFrdS3P2qX76fJJHH8klZt5F9+WL50jl2f62 vn68P3p7FOfPTMe886wvHil89JoP+Wkn+sjkqh5Ust48X/oyvNn/ACHTTX2yh5v2W4f91Hvr86NP sLD4YftSeKvCX2V0SDX7v7NH5f7vy5JPMj/8hule/wAOP95OB4md+5yH1X4b1Twubezv7qKeF4/L eWS3jkgnj/7aV+kHijxRJ4o8D6Vf+A7WO5sNKtoPKvPtMfn39vJHH/pHmf8ALPy45PM8v/lp5ccl dHEVOmuScCMgnU9+E/5z4Y1zwR4I8EfHzxz8OfEcUdgms3MeveH5JP8AXxx3f7yT95/0znjnp9x8 JfC9/cQ/8JlrM94if8e3l6R5Hmf9dP8AnpXpZP8Av8FRmcGYw+r4mcDN1zwldeHLzyvBGvaqiJ/q rf7F56f+RK5jWPFHxLtP3V/4Sjuf+mkcnkV7cK9OmeVP94ee+NPGXij7PNLdeHI7b95/z18+vIvG n2/xHG8V1dXezzP3v7v5I6ivU9oRTh+95DufCel+HNG8PpFf6NfO/l/6uSykT/0ZXYeG7WXVLiwv 7DRrqzs/Kkg/0j/lpHH5f7zy/wDln/y0r5+dOn7M+gpzqc/wHT3GlxeX5ol37P8AnpVa4voopPss vyJ5X/POkv5DTkqezKf2+Pr5Xyfcp8l1ay/6qKRNlXOnYic/3Yz+1bWKRJfN3/8APOOrP2//AEf9 7WM/75dP+GFvLFFH+6p/9oS/8sovkqP8Zf2B8cVhdRebdWDu/mUy382LfLFaybKj2n2DadP7cyaU RSx+bFFH8n/kSq1vLFLv/wBFk/cf8tKjn9pTL5P3hj6xrMst79gilRIafb/ZYo/3X33q1/D9wx6+ +Q/8vD/vd7/886NPiv5rhB53+s/56Vkk2+Y1hUspxMrxBdS+KNQ+wWETzWem/J5kcX+sk/5aSV1v gvwvYCP7VfxI8KfvJfM/5aV/UfCuXf2bwzCHc/nbiPMf7Sz6cjK+KHi2KWT7LF5aQp8kccf/ACzr xbxhr0t/eJpdh880nyRx19BVq/2fllzy8NT+uZklA9C8HeHLbwloaaXYSxvN5W+5k/56SVNqF/ax b/3r/wDXSv5PzavUx+PqVp/bP6QwEKeEwsKP8hzGqXX7zyrSWue1i/v4o38r/wBF1xL2qOv93UMS z17XjJ/pV1J+7l/5510I166l/wBbLvT/AK5VmqlSoE6dMJdU8397VO4l83/ll8kdbL+cx5Cn5VrN /qj/AN/KrXFha+ZnzdlYz/iFwn+65CncWoik/wCulVriL1q+f7ZH8Mh+yyy75fkpklrSMwkisJf/ AI5JUMkUX/s9aFfuxnT/AGKTt+68urp1Oczn/E55lrT9Kv8AVLj7LpdrJM//ADzjjrY8D6NYX/jC Hwv4j8yGaSXZHH9zzJP+ede3lOAeJqwnW+DnPJzLHfV6NT2PxnpHxY+A91/wr+bxb4T+S506Pfc2 8f8Azzj/AOWldz+yH8RtM+Nvhfyrr5Nb075NSs5P+Wn/ADzkr9oyrKqWQcS+xhT9ytD/AMnPx/OM 0q5/w37b7dGf/khxn7RPwN8ZfsofGDTfjx8OtLkTTdRl3yR/weZ/y0t/+2lfZnwztfgZ+0F8A/7U 1S686w8QWMkFzb/8tLST/wCORyV25evqGYYrL39v34f+3izN06+X4LNv5Pcn/wC2nyR4H8XeKP8A gn3+1Bf+EvEl06eFdZk8i5uLf/VyRyf6i7j/APan/bSvfv2kPBug/tBfCi58EXUsc1/B/pWgahJ/ yzk/5aR7/wDnnJWORYWFXDYrKp7w/wDSJi4jxqw+Y4XOMN/Dn/6WfNP7FHxp8R+ErjWPgD433wpY 3P8AxLZLj78En/PCtb9qjwfpHxGmsPiRpSF/EGhnZcxR/fu4I/8AWJXnYZ/XuHqmAq/HT9z/AMAO mrTeW8SrFw+Cp73/AIGY2l/F/VJdEtrCWKR5k8tIpPN/5Z1z2oS/b7ya6/srYk8u+WP/AKaV+bZ5 xFSxWXwoS+P7Z+i5Bw7Vy7NJ14fAyHzZYinlRbKm83zenz/vK+G/eVPjPtlClT9yAy4liH+t+Smf uZv+eb1jA2nMhuPKiP8At1DcSxRWz/8AXOjkDn/d+4ZsEvmyvFDE+zy/9ZX6if8ABIf4jap4t/Zf vPAd/E+zwzrfkW1x/wA9I5/Mk/8AIfyV9Pl074aEDyoQqKpWgfV05uorhLq18xJvM/0b/WPHJ5f/ AKM+/TNQ/wBK1Tyorq7R0ttkUn/LD/ln/wAs/wDV/wDTOu/2Zwc5larLYS6omjTaDd7LSKOeP7P5 fmef/v8A/kOsTxhf6XLHDo0WjTv5dtJPJ9s02NJJP3n+s8z/AJZ/crjnUOmnT/dnMa5r1rfxvFpe yG2tb6P7D5cuyT955f8Azz/eeZ8lVtQlutZs/wDjw+zWc9z+6+0SRvJ9ok8uOT/WfvK8evU+wd9O nU+2c9qFhdaXefZdTlj877n7uTfHVC8jii3mKJHTzd8f/TP/ALaV4lSn+9PSp/wzN1Dyr+OaWLyN 8dz/AKuOONP3cn+XrEuLWK1vHii+59zy/NrgxX8P3Dspv7BWuPL8x/3Uj18SftYeA9U8Oftgv4js LDfDrOm2l15lv8/7z/Vyf+i67shn7PGHm53T9pTge5eB7+L/AIR9DdfJ5f8Az0+SvpDwP+1V/wAI H+zs/wAL9L+FUc2sXUUkEmsahJH5H2T/AJZ7E8vzPM8v935nmV9vUy2lmnJ7Q+VWOxWD54QPE5L/ AOKHxk8aP43j17TbZ9D02PTv7cvL7Y/l+Z5nlonmfvP4/wB5VzVNQ8URbPsvjy+1Wb/l5/tC5r2M uy7DYOn7GjD3IHm4rFVcXU563xzM24m1TXrma182T5P+XiOWTy46m0LS9H8ya1uvtc1z9zzLj/lp /wDG69L+JT/uGNO1OpyfbMfxZovg2W8Swv8ARpHeSPf+7+STy6zdK/Z90aWRJdG8OaxDf/fj/ti2 j2f9s683MMDTqfAd+FxXsyHVPh9qmjahNa6zpklnNHL/AMvEWyj7BDa/uot7v/0z+Svla1Cp7Q9u nUp+zHyWEssflWuz/prJJUMml/Zf+PqWPf8A9cv9XXNUOmnP7ZT1i6lij8qOL/V/8tKzfsmqS7z5 Ufk/9NIqKcP5yJ16lT4CaO1ii/e/Zfnj/wCWlFvFHdSPLLa+TCn/AC0+/R+89mX1gXLeL93/AKve lHlXXmf6qP8Aef8ALSo5DZe0uF5+6/dRfJ/00ouJP3bn935z/wCtkqJw/dgvae0K2l6Nf6hJ5ptZ Nnm75KNQ0uK1/wCPWXZ5n/LPzaS/eVPcMlD2dMp3GjeTslzB/f8A9uj7B5UjyyxU/Z/uilMLfS5o v3trFvesfxRrUui2f2W13pfz/wCq/wCmdenw/l39pZ1QpHmZ5jvqeW1qw/wJay2v+qP+s+T95XVe KNZtfDmlpa2v+u8v95X9WUqdOSp04H841K9RudY8c8ca9i3f/wAhVl/DTSDd6hN4t1WPfj/j1835 P+2lfIeIOafU8qnTh9s+w4IwTxmYQqT+wdr9v/dofK31W1CWwlj/ANVJ+7/56V/N5+4/wzHvLDG+ WL7iR/vfLrH1Cw+1b4vK+SiZcCh/wjkUVx5UsTo6VNFaRRR+VL89H8QP3dP4B8cXlSfvYvk/56VD cWlrdSJ5UuysV+8+AinD2fxkP9l+bv8AKl/7aSVQvLGHH7qLY/8Ay1kjqg5/aU/cM2S1kil/ey7/ APnlUNxFLFJj79OnP2nxmKp1PsFOSKXy/KilqGSK68z/AFW+jnRaghkn7790fMR6fHFL5mf4EqyJ /vCbT/8Aj8SXMafvf9ZJXWxeErDxvrFtf+U9n9utv3v2eP8A5af89P8A0CSvayfLv7Qqex5zysxz GpgKftv5DV+D/laD8QX+F/i3/Q5p5JPsMn3PMk/5511X7Rn7PGvah4Xfxv4Si339jJG9zJH9/wD6 6V+uZPlH17hqth4fHRPyvOM4+o8Q0cT9isezfsZ+Mofjz4TS1uoo01vTf3Gt28n/AKM2f885K8r/ AGgfhD4p/YW/aI0/40+BLCSTw9qMkj/Z/KkRP+m9m9exm2NWK4ewuLj8cPf/APADgyLL3Q4gxWDl 8E//AG8+ydY8UfCr9pv4H21rJawf2D4g02N7a4j+d7S4/wCen/XSOSvif4UfFDxd+x5+0JqXwR+I OqSQ+HtZvv8AWf8ALD7R/wAs7iPzP+WclYZ4nDEYXNqPwf8Atky8jqKvgsVk9b4/sf44Hq/7Wnw+ 0v4+fDf+xxLBDrGmxyPpN5J/y0/6d/8ArnXlf7Lnxo17T/BCfDnxtNIt/o3mWsUlx/0z/wCWdLiH EYjLM4oY3DVOTn9w5Mip4fOsjqYLEw56lH3zN+NlroOs+KLbx5peoeTqvl+Re+XJ/r4/+Wcn/XSO sq48R+I7+JIv7ZkT/pp/z0r8+z/MXgMwrTo/bP0LI8tWZ5fR+s/HAxPsHlSfupdmz5Kmt7q/ik82 WWOb/rpX51UftavPM/Qaf7r3IB9vuunlbH/550Ry3Usnk0fuvaGnPUnT5yb/AE+X91Ls30SWvlSf 62RKx9mWgubWUb4vKkeqGqWssNo8oik/1VFMqc6fsihZ2EUVv5sXyP8A8tI6+2/+CIfxMtdG+KHj n4Qazc7E1zw3/amm/ut/+kWkn+r/AO2kb/8AkOvocu+CHP8AyHm0Kn+21v7/ADH6F29/Lf3CS/ZY 0hSSR5Li4ljSPy/9hKfHd+beJpfmyI6R/wDPL/lnXoy2OPkK3ifWf7BuH1S00u13yReRLeSXOySO T/0XHHXJXGqRS6fNFdWs9tc/YpEuZLzzP38nlx/6v/pn5nmVw15m1NfbOb8UWFrLcfaotGtPnto0 tre3l3+XJ5n7z/lpJ5lU9ctdLi0/TbXS5bu2eS2/07zJd/mfvP8AWf8AXP8A6Z/9M68SvTpnpYf2 lQx9Uupb+8mu7qTzne53ySf+1Kp6hdS/Z4br9x8nyRyeV/rK8auelSMG8+yxXiS3Vr5yff8A3cmx 6oaxayy6El/F88Ly7P3f/PT/AJ51x/8ALo2pmVqkv7r7V+7RE/6a/wCrryL4qaL4I8W+PNH8Uapf +T/Z1tJB/q/9f5n+r/6af/vK9DIMDUxeN9w487xdPD4bkmbfhu/uhcf2pdaDaQzQRR/ZrOT5/I/d /vP+2n/TStK98R+KPiNI/hK60aRIfMj+3XEfmb5I/wDnnHHH+7r9Op06eHpe4fDL2lSqdDZ/Cq/l vHv7XRpIbZI98nl6bsTy/wDcrB1TwvYaz4ghsPCUsdzCku+5k/eJJ5n/ADzq6dSp7M2n7P4DrdP+ HOs2GoJLFpdq9s/yf6rZH/5DrkvjBp8vhLVIdLtbCd7y+l/0K3jkk/8AakcclddA461vsHeeG/hL oPhzR01TWZftOtyR/wCkyXHz1Z+36XoNw9hqmzyZPki/j8v/ALaU6EPaETr+z+A4/wCInxa0uKO5 8L6D8Pr7xzcpZR3Udno/+sgjkk8uOTzJP/adedRy+LdeuLy11T4ValonkS/6z7Tb3Uckf/LOT93+ 8/8AIdeJnEMNP3PtnpZbUq/H7Qfb6N4j0uOaWKWdH/55yfJVCSw1S633V/FPv/55yRf6uvDPYnD7 YS6NdSpmK1qb/hHNel/0q1tdj/8ATSuedSmXTp1fZh/wiWs+Z5t/FBv+/T5PCWtf89UT/tnUfup+ +X+9+AZceEb/AO0JFayxp/10p/8Awi9/F/y9IlR7QOSoVv8AhEpbq483VLqNEj/1f/XSmSeCNZ/1 UV/aPDPLvkkqpBT/AIga5rUujWaaXFLG833PMjrj/tV/5nm/crSnCmRP2pN5WsyyebLVn7XdeYlr L87/APPOon7O5cPaFmK/i0uO51SXeiQR/vZPNrhtL+1eKPEFzrFzF88//kOOv1DwwyqniMZPGT+w fmniDmXsMPDCwO80f7Lo1m+oS/I8cX7quG8aeLbq/keU/IlftuFgp88z8lnU5PcOD0Tw5dfEvxZD o0XyWcHz31x/zzjr1GTwRo1rEkVrF+5T5Iq/B/EnMvrmYwwsPsH7lwJgaeHy720yheaBFFIkNqNn /XSWqclraxb/AN1G6V+bw/dn238QoXEXmy/uqZ9lii2RS/8AfyOjk9oEP4hTuLXypE82VHT/AKaV DJ9li/uOn/TOonAKdQh+wReX5ssv/fymf2WZdh+R0qJ6BD2c6ZWvNGlik4i31TuLWX/VfcT79R/E NoGbqFhLN+6qheWv/TKrhAx/h1DNvIpfM82GoZIpv+WWz/V0fw6YQ9pUqXK3my/8tYo3/wCmkdTW 9z9lj8ryq29mZc9mEktrdSp+6T/prXpfwj1SXxHcXkUUX2m5062+1f63f+7j/wBZ/wCQ/wD0XXuc OT+r46B4ueU6dfAzPQv2nP2ftV8beBrP4yeCIt+paP5c1zcW/wDy0j/5Zyf+P173+xN8QfCXx4+H 7y+LYoIdY0228jW9PuP+mn/LT/rnJX7ngL5fnE4fYrQPxvF0fr+Twn9ujM8r+L/hy/8A2HvjZpXx f8CWrzaVPJvufs8n7u7tJJP3kf8A10jr2n4ka98Pv2jfhVNpd1dR6lpWuRx3Wm3lx9+0uP8AlnJ/ 10/5ZyVtl9ClUxFfAT/rmObNsViadChj6J8i/Av4ra9+zL8aLv8AZ98by/ZtK1S9/wBC8z7kE/8A z0T/AKZyV3P7VHw58OfHjwulpLKkOtabH/xLbz/lp/1z/wCudcWA9njsnr5bW/5d+5/8ga4+dXLc 8wuZUfgqe/8A/JnE+B/jTr1h4PttB8UfJqWnR+R5n/PTy657xLr2l+JNcm161i+zXMn/AB8+X8nm Sf8APSvgs84ipYrJoYWfxw/9sPuMj4aq4XPZ4qH8Gf8A7eU5Psssnm+b/wB/Jaf9li8z91Lsr83n UqYj4z9Jp0KWHp8kBnlS+Z/f/eUeVLLJ/qk/7+VE6dMKHtKfwBIYv9b5Xz1Wkil8z91LWNM2nOmM j+1WsflS/cqzHqn7z91FV8lP7ATnUp/GWZZfN3+VdSb/ACv+WktVryW6lt3/ANK/56fu6jkLhMre V5tt/wAtK9O/YX8UDwH+2D8PdZlutkL+II7K98yTZ5lvPH9n/wDaif8Afuvo8P8AxIHjZX/vkPfP 2VvIpdLvL8y+Z/oklx+8/wCWk8kcnl/u46ZJdfZY5pbq6jR/N3yyXkuz/rp/20/6Z10kvcytUk0u /wBLTWf7UR082T+zftkuyDzPL/1cn/2yuJ1C/wBL8UapeazFpck0NjFb/Zo5LmR45JI/Mkkk/wCe kn3K87F1Dsw8KlyHwvLoMWsTX4/cpY23nySR32xN8f8Azz8z/V+ZJ/00/wCWlYmuazFdaGlrdSv/ AGlJ5j3N55v+sjk/5Z/885P3m+vKnOnTpneoe0qchiWcsMtu91FDsST/AJ6S/wDLP/nnVCeW1luJ oorrekf+q+0f6yvBmerQ/dnPeINUtbWV4pfv/wDLKSubfWbqW3fVJbD7NZxx/vLi8j2fu6yp4TE4 z3IF1K9PD0+eZyVxf3/i23e6hlnTR44v9Gk/5+//ALXT/hf4IsPFusTeKb+XfpsfyaJ5n/LT/p48 uv0TLcD9TwXJA+JxeK+uYnnmd/f+CNK8OaOmqS2sD391c7LHzPnST93/AB//ALuu5s/hVrPhLw29 /dxXX2yeKP7THHHveOP/ALZ13zxXs6nJM5vqntKfPA5L4mf294N8Pw3Uus/vr6WO1to/s2zzJJP+ un+srY8D/AL/AIQjQ0ktdZkub/yvMuY44vnjkq6lfSAU6H2zrdQ8JanYeF7zxHdapHYQ2lt5/wDx MPk/dx14V8PL+/8AG/iy5+KGqaX51zfSf8S397vjgt/L/d//AByt4VKtTD+4Y+zp/WPfPQvDejar dXE39s+W7v8AJJ+6rwH9rzx54jsPElt8IPAV1JZ3M8sb63rlvHv/ALNtP/j8n/LOu3n5KXN/IcfJ +95C58O/Btp4D0+a/wDBF/ssLWL7bYyXEkiXUnmf9dP/AI5/0z/5510/ij4q/DT4VeF08b6ro0lt +8jeSzuJdl9HHJ/zwkk/d3EH7x/9X/z0/wCWdeXgoe1qXOytOnTplPT/AI0/Br4liHWfDniOCGz1 XzP7IuJPkk8yOTy5LedJP9XPHJs/1f7vy5I/+elauoeF7DPlXXyP5VeRmtD2dTnge3l1T2i5JkNn 4Niij/1tXI9B8rZ+6+SvJ5Ds9oQ3lhLF/qrX/lpWbcebFH+6CUe4H8T4yt9li83/AFMf/bSqdxLa /wDPL56icPaVC+f2dMoSRebsP/PP5KZeSywx/uopHSj2dvjBfvPgOe8QaXFdSPdSxb3rEs5br7Z5 RtUSrp/vDGf7up7hpSWt19pe1utifx1MdL+yyfaoot7/APPSSi1/gL/ifvDgPGms3Vzqk3he1l+T zY/tMn/PSuz+FfgP7fp9zfy3VpZw2NtvkkuJdnmf8840/wCelfv/AAjQ/sXhb206Z+G8VV6WZcQ+ x5zK+IHiP79hFKleR+OPEccKPHF/H/5Er7d1fYZZ7Q+UpU6dfH8iPR/hh4Nj8G+F4TqGxLyf9/ff /G62P+WjyxfwV/K2eY2pmGZVqx/SGTYWngMDCkZWqXUUsnmy/O/3P9ZWJJLF/rfN3pHXnrb3zq/6 9laS+tfMeW1tdj/9NJd9Q3F/LLJ/x6/+Q6she19mMkiiupP7n/TOmah/oH7qKLY//TSo/uQLX7tc 8yG3hur/AH/x1ZtIv3nleVseP/W/vaif8PkCH85NeWtrH+6kl31m3lhj97iRKxnT/dm1Cp7QzZLD 93VOSw/6ZUIv957IoXGjRSyfvfk/6aVTuNG8rnFbrY55/wB8rXGjRSy5ii+f/npUNn4Xv9UuPsth azzTf8s4446VOnVxFXkgZznSw/vj5PCV/fx/ZdLv7R7nzf8Aj3ki/wDan+rr0b4Z2ur/ALP3xT8M /Fq20zfo+sXsdrex3Ftsjkj/ANXIP/adfc5Bl2GpYec5/GfH53isTVqQ5D7U+C+seEvBuua98JbC 1gv9H+zf2j4fuLyTfHd6Ld/6uP8A66Qb3gk/7Z18x/FzU9Z/YF/aMh+IPhf7XeeD9c/cfvIvk+yS f6y3f/ppHX6BWre0y+hjIfYPlIwq08wqYOf/AC+gex/EnxH4T+Pnw4/s+a/S503Ubb7Vpt5H/wAs 5PL/ANZ/7Tr5d+CfxL8ZfAL4gX/wW8efJpU8sk+kXEkm+OOT/nn/ANtK9bOsRTy3GYXM6PwfBP8A 7fPlMlw9XN8Jjcsn8cPfh/24dP8AtGaP4Y+JehJdXUqQ6rZfPZXn3P8AtnXAf8LQ8R/2XDa/b97w fJ5nmV8fxNnH9mZp9Zwv2z6rhbJ6uZ5X9WxX2JmJeXV/c3j6pdXe95/n8ynxyyzP+9Ffl+IqVcZV 9tM/U8PQpYOn7GiXI4pfLfyovnjp/wC5/wCfrf8A9NI64+RHf7SnU9wmjz/z9UfvfN/geonD+cun MJJcf886hk/df621/wC/dY0xDJPLl2Sy/f8A+elQ/wCqkTypv+2dbU39iA5+/wC+Hmyxf6maobi6 lij/AHsUlUH7ufvj5NUiisn/AIHqHwvrN1/wkltqtrrNpYPYyR3VtJceYieZH/1zjr1lXpX9w8fC UP3vPM/dHwP48tfFvwr8N+N7CX7ZDrOgW97FcR/8tJJP+Wf7ytLVbCW/vEiuoru28uLfJ9n8t/tE ldyOzEw9niJnMfEXVLD+3LO11TS43h/595LaPzJJPM/5Z/8AXT/ppHXK6hYX1qJppf3L2n2ieSSS OTy5JJP+mf8Ayz8v/V15dY2w6/d85D/b8t1H/wAJHpegfY7yCKN/3cfyRx+X/rP3lcxefb/7QSW/ +d/tMn/ouvHxftTvp/xCnrmqRaBpf2S6uvkk/wBXH5u+T/tmkf8ArP8AWVzdxLr2qSPLaxfZk/6e Iv3lcFPC/WKlzb2/s/gGSaX5V49/dCR7ny/+PiT/AD+7rzr4mX9/4juLawsL+BLb7T+9s/vySR/8 9JP+edfSZbQp0zxMdOpUM3WLq68R/wBm+CNB1mRL++vv3tvb/wCsjtI/9ZJ/7T/7aV7To/w0ilt4 fsErwpBHsit47mNEjr6GnP2Z5vJTqUzN8N+I9Z1Txo90JZ7zTfCOpeRH9jud8ckn7uSfZJ/yzk/e eX/10jr3Wy/aC0vxRGmqaX4c+0+fFv8A3cn7+P8A66SeZ+8rGtD2lU1p6UuT+c8i8SfYPjJ+0hba pql/52leEo5EtreOXej3cn/LT/tn/q69v8B6NamRJbGVIUk/1tx/zzon/EJhTp+zPNP2yPG9r4js 9K/Zp8EXMk2peKpP+JtqEcuyO0sI/L8z/lp/y0/1dc3p/he10bWLO18L6NPDDY23kSeZF/r/APpp s/5Z12UH8EDjnT15zN+OHjKXwb4Pv/FEt09s+nW0kkfl/wDLT/nnH/38rjP2f/2aLXxb8P7zXvi1 dWr694n/AOJjc3lxJ50kcn/LP/tnHW+K/wB3hAxwlP8A2iczkv2lPEf/AAzJef8ACB+EtG1L/S7H z7LUPN3x/u/9ZH+8/wBZ/wBc/wDWf886+GPjJ8UfG/jLxBN4NutZ/wCJVaXO+PS7e5/0WD/rmlYT qfVMPyQD/e6nvmPpevXUVvbaXFvhhS58+KSOX/lp+7/8ifu6+uv2M/2h4tet9H+C3iiX/TLTTZP7 NvJPM8y48uSSTy5H/wCuf+r/AOudeJiqn7o9XA0/3h9FeV5sf+t2VT/e/P8AvdleUezyUyG5z5n7 2V0/6Z1lX8XmyvdRb4fM/wCelXOZnT/eGbeeZ9oSKWX7/wA/+q2R0y4i/wCeUW//AJ6eZWMi6dOq VriW6ijz+73/APLWPyqx9QuovNeKr5CPaGb5t1dRvdQ2Enk/89PMqH7Lwl19l/8AZ6n92Ugk1mKK T915b+Z/rJI6reJPGVrpfh97+18uZ0+SOOT/AJ6eXXfldD63jqdGH2zjx86WHwtSscT4H8Oy6zqD 3V/L88nzyySV2eqazFoOlpF+7/v1/U1HD+zo08N/IfzjiJ3xVTEwPK/GniP97NL5r76yvhf4XuvE fiB/FF/a77axl/0bzP8AlpJXz/G+Y/UMlnA+g4Oy7+0M1uerm6li/wCWVU5LuWLfL5ux5K/mbk9p rM/e1P2elEoSeVLI/wC6d6yp7WPzP+Wj/vK2IqalP+z7WL/VfI8dAtYv9b5saP5X/LSgnkGXEssU n2SIxo//AD0qheS+bI8U0vz/APPSpXs7lf3Cnb+bFH5UUuxKmjtf3nm+a/8A00kqqpFP92XPt/H2 W6i3pVa8+33Uv7r7n/POsy5wD7LL/wAtZfkqG56/uvk8v/lpXPzmyp+0+MrXlrFLG8skX+rrNk0a 6u5PKtYpHf8A6Z/8tK0w6dV8lMjEWS1Ow8F/s+eLdej82S12f887fzf9ZJ/7Trv/AA3+y18RtekT w5oOlukMdt5Gr3Gl2MnlyTySf6vz/wDnn/q/3n/XSv1XB8I4zLcu+s/8vpn5pi+KMFjsb9T/AOXM DufHnwg+CPwb8P6b4D1SKxvPEnm/armS3/1EH/TP/npJXlHxt+Pul/EvT/EPg2W1sUh+0x3VtcW9 t+7gkj/5Zp/zz/8A3ledWxcMJmMMBD/t87KOHqYvLp4v/t+BQ8OfHi61T4f+G4tGlgfxD4Zkke2+ zx7PPj/5aW8n/TOSNI/+2ldVea98NPi18NH8OappcCabrH7/AP1kj+Xcf9tP+WlfX5F9SxM6+Dqn yHENXHYbC0MbE8o+Feq+KPgFqN/8NNZvvtOieZ5+k3Ekm/Z/0zpnxQ8ZaN43jh82wjmubT/j2vP+ edeBjM8+qZRPKcZ9g9zB8P8A1zO6GcYOfx++cfcS391GkV1decn/ADzkkpn2WLtLsSOvzmdepU+M /SaeFpw+AfFFFF/y9VZ/1sn+tR/46IfwgHyfapbjzTL/AKv/AFkf/PSj97dfuf3m/wD551IU/wB2 VvsF/wCYgiv330zzfEcUvm+dv/66Vyzn7Q6fZ/bH2/iPVIpE820/791cj1mKX/W2qJR/DDkTJvtd r/qvK7/89aPsthLxF5iVFOp+8LnD93yD7iwi8vzYpap3FrdRfuvvpVw/eCnQ9mucoaHpd/qn+q8x /wDnrJXW6P8AC+L/AI+rqKRE/wCWcletQ/hnkqfI+c/WX9gPxRF8Qf2N/BMv2p7m28MS3ekeZH8/ +rk/d/PXrWuaz9ls7y6v/LSw8v8AdeX88n+s/wA/9/K7pz+2deKhU9ujktY0/WbXQ7Pxbay/8TWe XfJb3kX/AC0/eRx+X+7/AOWdZWsWul2un3OjX+vX15NHLG/2e3tvOkjjk8vzPMkrgmXA4/4ga9No NnDFr3iOxmmvtSuP+PP55/s8H+jx/u45P9X/ANdPLrhtQ8UazfyeVYXc9mnmyebJJ5bySf8AkPy4 682pD2lU2p1P5CGKK78x7rzX86f55LiSXe8lXDNL5f7379XTphOp+8PPfjx48v8AQbP/AIRfRov9 Je28+5kj/wCWEf8Ayzrnvh34cl8xNU1S73zeVv1LzIv9XH/z0kr2cJD2dM82v+8+M6T4b+CPtfiD UvihFYR3ialLJ9mj+55dhH/q5PM/6af6yu51D4oWvwv0O58R3/heB7mOLZH+7/5af8s/8+XXdT9+ oZSnyU/Znt/7O/wwi+H37O+bWWC51K+tpLq5kklj/fySf6yT95XiHjyLQfAd5D4osLqffPL/AKTH b/P+8/5Zx/8ATT95Rhf3nOZ42FKGIR1Xwfih0DwW8t1F9pv5JJJLm4/56Sf8tP8AyJT/ABJ8WtZ8 BXD6pa2s8LyRfu5I7bfRQhzhXnye5A8c+G/jLxH4j+Ll58afGVhJc/brmS102ST5E8uP/nn/AN/P /Ile8W+sxC4S/wBKMczv5f7vzf8AV1slSqYjngc38PD8kzyj42G1+Kvx48K/Bb/j5sI/L1vX/Li/ 5dI/9XHs/wCuiP8A9+69p8QWmjaXocOqaz4jtNHsI5I0kkk+RI/+mdXP/eIQgR+7+pc8z4J/bI+N Pg3xl8G/EOl6pql1Nc6VJBa6BeWcu+OeTy/4/M/z/wBNK+G7m6lsLhL+6/13mxvRmmlOEDmwNvfm bFxLFFIn2X/nr/q66HwX4z1Twl4s03xRpkuy5065jnj/AO2cleJOftKR7FL92/cP0F8N+PLXxHoV h4o0aV3h1K2jn/1v/PT/AJZ1cude7xRO/wDB5nmV40D3lD2iGf2ofklisPuf6397TL3VLq6uPKis P+WX/LSnIj95P3ChJayy2bxSy/vo5f8AlpFT5LSaKz/0qaqWxj+8GSfZLWzc+V5z1zElrdyyPaS7 Hmn/AOWlawKLMlhDFbw2trdR/wDTS4k/5aVNJan7PNqF1K/9zy/LrO3tPfJ56XwGVHoNhLp80sth Hsf/AFkn3K8o8QX8XiPxB9l0uLZZwSfuv+mlff8Ah1l31vPfbT+wfE8cY76vk3sYVPjO28N6XFa2 7xS70/jl/dVx/wAQPEf7zyv4I/kr9+hU/wBo5z8R/iYf4Dze9tr/AMb6/beG9GO+a6l+/wD88469 s0vw3a+HNLttB0qLZDax+X/qv/IlfiHiXmvt8TDDH7F4fYKnQw86xW1C1l8z97L/AKz/AJaSVQvP Nl/c/u6/LT9IhMoSfuZHi+/VC4iurqT/ANF11UzjnP7Exn2S68tPN/5aUfYJf+eWyonU/kLUPZkP 9l+b/rZfO/7Z1DeaD9kt0l82PZ/0zqJ/zwLp/wB8raXai6kf96N9TR6XL/qo/v0Iv+J8AySw8q4/ ej544v8AWVc+yxRbPNlrGt+898Kf8hDnvEY0f/rlR5v7t/N0/wCfzP8AWSVjKm6lrFwqJTLOifD7 Wdek/e2r20P35ZJP+ef/ALTr2P4R/BHRtUuUsNG8j7Y8fnxXHl70kj/56b/9X5dfuXA/CWGyxQzD MPj/AJD8g4w4ixOP58Fgvg/nPcrP4VeCPhpqFt4j+IPiiC2toLb91pdxJsjkk8z/AFkn/PT/AJ5+ X5dcH8YP2uvCWjaNN4c+Gl/aWaSSyfabezstnl/9NP3f/oz/AFlexxZxFhsLSmoT9/7B4nD/AA7i cRT9pOHuQ+M+S/iJr2qa94gTWfFGvOj+V+9s7OTe/wD33/q64zULCK6k/dfuUjk8zy/+elfjOKwv 9m0/aV6nPXmfpuArVcfpyezoQ/8AJyz4XisNBvJopbWT7Ndx7LmSP/Wf9dP+2clPksNZ8OapNdWG qRukkmzUreO53xxz+X/rE/55+Z/rK78ux1SnhvbfbgGY5dSxFX2P2JjNQv7/AFSRJb/UN6J/qvMl /wBXUPkjzP8AVV4mOxeJzDEe2rHt4HA08vw/saISRReY/wDBTPKii/1Xz1x0/wB57h01vaoJPK+f 91GlMP8ArP8AY/6aVf8ADBTq1Bn7rzf9V/q6fc3UXyeUZERJf3v72mHJUp/GWbOWKKPP2rf/ANdK syX9hLI8Xk/9s45az5Ap1A8qOWRIvJol0H7V/qtlZm06hDJ4cvz/AKqVKmi0Hzf3vmuj/wDXWnyI Pb+0+Mv/ANjS+X/x9bKrT6X5UfF1G6VFQun7L4JnVaFYaX4SsIZdUi+fyv8ARreOL/2nWxJoOs+M o0lv7qS2s/uSaf5ezzP+2n/LSvY/dfYPn17SpDkmfbH/AASv8R2th4b1v4Syy+TbadfR6jHH9p2J +8j/AOWn/fEdfTniT/io7jSrCKwk1WG+vv3Ukcnzwf8ATT95/wBc5Kv4/cPXrU7KE5mb8aPiDo3g PS4dKi17Zf2kkHmWdnc755I/9XJv/wCef/TTzPLr511TxJ4j1mSaW51RIUklk/d2/wAklceNp+09 wxwlT2nPMrWdrDa7Iv8AyJVyO15Tyot+yuZHei55vlR+VL5iVQ8SeKNG8JeH7zXr+LYljbb5ZJKt b+4Y1P3dI8B8H6z4y+L/AI4fw5a/vn1K5+1XPmSbPL/6Z/8AXP8A+N19A3HwH8R6X4fufDlrqkaX +uX0Gj2Nvb+Zsk+13Ecfmb5I/wDV+X+88yvbpz9muQ4KdCnOn7/2z1eTQPCXwfvJvBFr9k+zWttH Bc3klz9q/wCmflx/6uP/AJZ14b8WLWL4ofHzQfh9oMt1eabpvmajqUkkX7uSTzPLjk/d/wDLOtqF OpClzmPPz4mED6K0OKw0vydGiup5pv8AlnHHXhv7QF1daN8TNK+HNrYRp9rl+1XMfl7H8v8A5Z/+ RKihU9mbVoe0PRfhv4Xv/sdz9qEaOkX+jR+Z/r68x/aR1m/8OaPc2ug+Yl4/yRySf8s/MrpwVSm5 nHjaf7s4/wAFXXiO1+G9n8KvK2W2jSef5nmf6yT/AGK7zw/rMsslno2l2v2y5vpY08uT5P3lb0Ke phLYyv2Ur+bxd4w8VfHOW1/faxqX9nabH/z0t4P3cf8A1z8yvSPFHiOw8ZeDr/QNe0udIdStpLWx /wBB2JP/ANM/Mk/1lFL/AHifITUh/s0IH5L/ABs/4SjwH48vPBt1YSW0P2GRJI7z5/Pt/M/1n/TP /V/+Q68i1iXy40i++lc+af7xyGOW/Aben+bdbJZP+ecfm+Z/z0qzeXXlSJJ5vzx/8s68o9Q+xv2N vGUXiP4Lw2Hm/wCk6VcyQSf9c5P3kf8A7Ur1fyopdkuPkryJ/wASZ7lCp7SlAsxxYt/N83f/AO06 ZJL87xebs/6aebRTgHtP3pZ8qw+SWWWR6rahdRSx+VLdR7O8clEPZ3InU/nMfyrC13xRXM6eZ/rY 6huDaxSJdWstX+8BU/aBHNFEfNh/8iVNLLLdS/7H/LSgjk/dnE/GjXh4b0tNBtf9dff99xx/8tKw fhZ4Iv8AWZPNtbXf5Hz/ALzy/L/8iV+2cDzp5Jw1WzXFH4/xg/7Tz2jgKJ22t+KPC+g+E5vDkp2X k/8ArbyP7leA+PNfi/fQiWvdyGGNpzxONrz9yt78Dws0+rV3RwUIe/A7P4N/D+XwxYP4o1A/8TC7 j/d/9M467z7V9zyot6Sf6yvxLP8AG/2nmU5n7DkGB+oZdCJTvIpZrhz5XyP/AKqSsq80aU/30T/n pXh8lj3P7hm3EWN/lRfJ/wA9JKpyQyxO8sstaGSqVBn72X/VSx/9dI6LyWWKP+DZS5KlMqc6dQof a5YQ/lfIlXI5Ypd/2qo5C/3n2zNt/Ktrx/K+f97/AM8v9XVmS1luo38qLY//AKMqJl05kMkspt/+ Wjp/3xVaSW1Mf7reif8AXWsf8Af4zntY8W6XFI8Vh++uf+mddV8I/CXxQ+I3iD7BpfheeZ/vxxxy bPL/AN+T/lnX1XDsKeX4iGKrw5z57OFVzOn7CFTkPpzwP+yr4S0bT08R/G7xbd3O/wAzzdDt7mTZ Vnxh8c/Dlhoc2l+CNG+0w6bF+6jji/1En/PNPM/dxyV24rOMxzvHfVcF9sKeBy7I8u9viteQ8W8W fF+Ww1f/AISO/wBZk1LUkj2RRx/6uOT/ANqV5j4g8SX+syTSxRQWyTy+ZLHbxxp5kn/TSSvWzTHY Lh3LvqVH36/25nzGXUMbxPmM8ZWhyUPsQMG4tfK3+VE9Vo7X0iRHr8+/ifvD7ymvZ/uwksJf9UR/ 37iot4rW1t5oorXY93/x8/8ATSihU9n8AVqFTEU+Qrf6L8/lUzzYustRzmyVvgGXEvm/8uu+mSdf +Wmz/pnWZqQ/uvnzTJP+uslaKpzmXs6VNj5LWL/nr9+mSWsvmP8A6x6anVCcOoySLyinlfcqaO6t bWT97F89Uqn2DH2H7znJo7/96kssW+tKz1SOWdIvNjRKF75fsKlM2PMiit+bmN3pkkXmyJL5UiVj
March 24, 2009 - April 13, 2009
Pietenpol-Archive.digest.vol-hn
