Pietenpol-Archive.digest.vol-hz
August 03, 2009 - August 11, 2009
Subject: compression struts-- need some help, pls
Date: Aug 03, 2009
Here are some pictures that may help...more at my site. Make sure when you position them, they will "clear" your covering. Jack www.textors.com Tim, I made a little plywood pocket for my compression struts, made the struts to the exact length for the distance between the spars and the installed the compression struts with no glue. Just the tension of the drag wires and anti-drag wires holds the compression struts in place. I also did not glue the ribs - just nailed them to the spars. Jack Phillips NX899JP Icarus Plummet -----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim Willis Sent: Sunday, August 02, 2009 10:15 PM Subject: Pietenpol-List: compression struts-- need some help, pls I have a some wing-building questions that center around the compression struts in the wings. 1. How long are these struts? On the surface, this sounds dumb, but please bear with me. For instance, the minimum distance between the front and rear spars is the distance across the ribs. If made exactly to plans, that distance is 27 5/8", except as adjusted for the ply thicknesses added to the spars on both ends and middle. So do you make the compression struts EXACTLY according to that ADJUSTED rib dimension? My real question here is, if you do so, both all the ribs and the several compression struts will be in compression. Is that what you want? Or do you make the compression struts just a few thousandths longer, so you can still slightly slide the ribs around until they are glued or nailed? Does it matter? 2. The answer to that might well be interrelated to this question. What are the sequences-- first, second, third-- gluing the compression struts, lightly tensioning the drag/anti-drag wires, nailing the ribs, final tensioning the wires? [Perhaps you need to know that for my wing layout I am using a flat table with three "piers" on it. The piers hold the struts up. The spars look like a bridge span sitting on the three piers. This is a method I borrowed from a posting on "biplaneforum.com," as demonstrated to me by my friend here John Nunn, the forum's founder(?), moderator, and webmaster, on his Skybolt wings. Thus I have some flexibility in sequence. I have made the piers a little longer than the 27 5/8" rib dimension FOR NOW, so that the ribs move on smoothly, but I can adjust this to accommodate the intelligence you impart to me.] 3. It seems strange that with all the gusseting we do elsewhere--to increase gluing area and to triangulate attach points-- that the compression struts are just butt-glued to the spars. IMO, in some ways these are the most important sticks on the plane, after the longerons. Haven't you added glue blocks or a light gusset, or made a U-pocket for the struts? Thanks, Tim in central TX Checked by AVG - www.avg.com 05:56:00 ________________________________________________________________________________
Date: Aug 03, 2009
Subject: Re: Congrats to Kurt Shipman!!!
It IS a beauty of an airplane! Congratulations, Kurt. ________________________________________________________________________________
Date: Aug 03, 2009
Subject: Re: Hagerstown, Dirksons, Brodhead, OSH
I bought a copy of the movie while at OSH and watched it the first thing when I got back. It's a feel-good movie in the best sense of the phrase, all the more so because it's a true story -- sort of a fairy tale come true! On the technical side, the photography, writing, editing, the whole sheebang, are _great_. A good story told well. ________________________________________________________________________________
Date: Aug 03, 2009
Hey Kurt, Congrats from me also,beautiful plane and well deserved .I enjoyed meeting and flying with everyone. This trip was a dream come true for me after seven years of building. Randy Bush NX294RB **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! =JulystepsfooterNO115) ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Aug 03, 2009
Subject: Congrats to Kurt Shipman!!!
That was one CLEAN airplane-Kurt deserved that Lindy fair and square. He was on a short leash to get home for some business he had to take care of when I spoke with him at Brodhead but I am so glad h e gave the judges enough time to inspect and award Kurt's hard work. He's another Poplar Grove, IL guy if I'm not mistaken . I think next year Dan Helsper is going to take a Lindy and he's from Poplar Grove as well. Way to go Kurt ! Mike C. ________________________________________________________________________________
Date: Aug 03, 2009
Another kudo for a very clean airplane. What kind of carburetor are you usi ng, and what kind of speed can you get? Congrats, Gardiner Mason.=0A=0A=0A =0A=0A________________________________=0AFrom: "Cuy, Michael D. (GRC-RXD0)[ ASRC Aerospace Corporation]" =0ATo: "pietenpol-list (at)matronics.com" =0ASent: Monday, August 3, 20 09 9:40:19 AM=0ASubject: RE: Pietenpol-List: Congrats to Kurt Shipman!!!=0A =0A =0AThat was one CLEAN airplane=94Kurt deserved that Lindy fair=0A and square. He was on a short leash to get home for some=0Abusiness=0Ahe had to take care of when I spoke with him at Brodhead but I=0Aam so glad h e gave the judges enough time to inspect and award=0AKurt=99s hard wo rk. He=99s=0Aanother Poplar Grove, IL guy if I=99m not mist aken. I think=0Anext year Dan Helsper is going to take a Lindy and he =99s=0Afrom Poplar Grove as well. Way to go Kurt !=0A =0AMike C.=0A ==================== ________________________________________________________________________________
Date: Aug 03, 2009
Subject: trip comments -- pretty girls
I noticed that in one of Jeff Boatright's many great video YouTube posts that Bill Rewey was extra helpful helping board one young lady into his airplane and helping her with the shoulder and lap belts. And they probably think he's harmless-- Hah ! There are some advantages to getting older:) ________________________________________________________________________________
Subject: Re: trip comments -- pretty girls
Date: Aug 03, 2009
I think that was my wife. LOL! Every person that I have showed the video to has commented on that... "did you see that? He put his hand right on her a$$." I say so what... she got a Piet ride out of the deal. Ha ha! Good for Bill. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255790#255790 ________________________________________________________________________________
Subject: Re: Brodhead Video
Date: Aug 03, 2009
Bumping this now that several people are back home. Yes, I know... shameless tactics. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255791#255791 ________________________________________________________________________________
Subject: Re: Tensioning cables without turnbuckles
Date: Aug 03, 2009
Tim; I haven't tried this idea as yet but here it is for your information. My thought is to make up one end of the brace wires directly to the fitting, then mount the fittings up with a number of washers between them and the structure, then make up the other ends as tight as possible, remove the washers, tighten, and all should be tight. This may take some trial & error to get it right. Seems like this will be easier using cable than hard wire but I haven't tried either, as I said. This would eliminate shackles and turnbuckles; a little weight and more money. If you try it, let me know you results as I intend to use the idea. Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255792#255792 ________________________________________________________________________________
Date: Aug 03, 2009
And you guys thought we elders were over the hill, Thoughts are the same delivery takes longer, Crank is being checked, Hamilton blades don't look too good, prop extension will be replaced. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255830#255830 ________________________________________________________________________________
Date: Aug 03, 2009
Lowell, If I remember correctly, I heard tell of a Hamilton prop on a T-Craft for sale at Olson Airport (outside Elgin, IL) a few months back. The airport owner, John Olson, told the guy to take the Hamilton off and put a Sensenich prop on it so the plane would sell. I'll ask around the airport and try to find out what happened to the plane and/or prop and get back to you. Cheers, Dan Pieti Lowell wrote: > > And you guys thought we elders were over the hill, Thoughts are the same delivery takes longer, > Crank is being checked, Hamilton blades don't look too good, prop extension will be replaced. > > Pieti Lowell > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=255830#255830 > > > > > > > > > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 03, 2009
Subject: Re: ok, lemme have it!
Hi Shad, Just to clarify - Tres Clements and Ryan Malherbe flew N8031 across the country. Man, what I wouldn't have given to been able to do that trip! Anyway, N8031 found a new home yesterday at Olson Airport just west of Elgin, IL. Ryan and Jessie were there and took some great photos and video for me since my camera battery chose that inopportune time to die. Thank you, thank you, thank you! My head is still in a haze. Or in the clouds, however you want to look at it. I'm kind of speechless. I want to go out to the airport and go fly it right now, but I have to change the oil first and wait until my CFI, Stefano, gets back from LA - he's got a lot more time in taildraggers than I do and this is a new airplane for me so I'm erring on the side of caution. Speaking of oil changes and owner performed engine maintenance - Essco has several manuals for small Continental Engines. One is an operator manual, one is a maintenance and overhaul manual, one is an operator, maintenance, and overhaul manual. One is from 1938, another from 1944, another from 1971, etc. Does anyone have a recommendation on which manual I should pick for this A-65-8? Thanks, Dan shad bell wrote: > Dan, I won't nit pick your airplane 1 bit. You flew it farther in a > week than I will all year. It got you the equivilent of a > trans-continental flight!! I would have to have an ass-ectomy if I sat > that long in 92GB. Congrats on one helluva long cross country, and yes > Randy Bush and I saw it with the racers, and you were the only airplane > that wasn't plastic, or a factory built "home built". > > Shad > > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 03, 2009
Will, Thanks. It seems like that or something like it might work in some cases, where the pull is straight toward the long axis of the bolt. I have thought of other devices that could fit in the spool of the eyelet at the cable end, but have a cutout for the shackle pin. With such a device the cable could be tensioned and the pin and shackle set, and then the tension removed. However that takes a way to align the tension straight down the cable. It could work for the seatbelt cables and the like, but the empennage might be more problematic. We need to hear from someone who so rigged the tail. Speak up, you riggin' magicians. Tim -----Original Message----- >From: Will42 <will(at)cctc.net> >Sent: Aug 3, 2009 1:14 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Tensioning cables without turnbuckles > > >Tim; I haven't tried this idea as yet but here it is for your information. > >My thought is to make up one end of the brace wires directly to the fitting, then mount the fittings up with a number of washers between them and the structure, then make up the other ends as tight as possible, remove the washers, tighten, and all should be tight. This may take some trial & error to get it right. Seems like this will be easier using cable than hard wire but I haven't tried either, as I said. This would eliminate shackles and turnbuckles; a little weight and more money. If you try it, let me know you results as I intend to use the idea. > >Will > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=255792#255792 > > ________________________________________________________________________________
Date: Aug 03, 2009
Subject: Back from Brodhead and Oshkosh
Just wanted to post a note on the list saying how much I enjoyed meeting more of the Pietenpol crew at Brodhead and Oshkosh. I flew out in my Stinson but spent time talking to the other California Pieters about a trip out when more of their airplanes are in the air. It was a real pleasure meeting Gary Boothe from Cool, CA, seeing Jim Boyer once again, getting a close up look at Gary and Shad Bell's and Randy Bush's Corvair powered Piets, meeting Don Emch and marveling over his beautiful Piet with the covered wire wheels, seeing Dick Navratil's unique wood-grain radial-powered Piet, meeting Jeff Boatright and his dad (thanks for the videos!) and of course catching up on twenty years' worth of history with Ernie Moreno over a beer. I didn't get to see much of William Wynne at Brodhead but got to talk with Grace a couple times, and saw them again at Oshkosh where I invited them to chastise me severely for not getting the Pfeifer going yet so I would move it to the top of the priority list when I got home. They did. I would have liked to get a Piet ride but that was my own fault for not hanging around the group more. I got the oil changed on the Stinson before going up to Oshkosh and looked around Brodhead a bit, but there is never enough time to see and do everything and talk to everyone in such a short time as a long weekend. It was a kick to walk through the group of Pietenpols up at Oshkosh where they were displayed just inside the old main gate. With the rain everyone was battened down but the birds still looked beautiful. Happy 80th birthday! I recommend a trip to Brodhead for everyone building a Pietenpol. A Southwest flight into Chicago and a rental car shared between two or three people is relatively inexpensive and the wealth of information and inspiration there are priceless. I even got to run out to the runway with Randy and a bunch of others when a RV-7A stuck the nose wheel into the turf and turned over. I walked the last hundred yards with a couple of the other old guys, but it turned out the pilot wasn't badly injured. I'm looking forward to getting together with some of the other West Coast Pieters in September for lunch and swapping stories, and then getting back to Brodhead in a couple of years to admire all the beautiful airplanes there. Thanks for the memories! Darrel Jones Pfeifer Sport NX154JP Sonoma, CA ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Subject: Re: Back from Brodhead and Oshkosh
Date: Aug 03, 2009
Believe it not, those -A model RV's have quite a habit of burying the nosewheel. Like I always say "the little wheel goes in the back". Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com > I even got to run out to the runway with Randy and a bunch of others > when a RV-7A stuck the nose wheel into the turf and turned over. I > walked the last hundred yards with a couple of the other old guys, > but it turned out the pilot wasn't badly injured. ________________________________________________________________________________
Date: Aug 03, 2009
Darrel, It was certainly my pleasure to meet you, though it's definitely odd that we had to travel so far when we only live 80 miles apart!! Someday you may want to take your Stinson to Georgetown and I'll pick you up and show you may project. Realistically, I think I can make Brodhead 2011 in my Piet. In fact, I hereby throw down the challenge: West Coast Piet builders - get ready for an historical mecca to Brodhead in 2011 in our Piets!! I know Mike Groah will be flying by then, and so should Jim Boyer! Chris Tracy, Mike Weaver...you boys can do it, too! And, Darrel, I take back that offer to show you my project...you need to spend that day on the Pfeifer, so you can join us!! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Darrel Jones Sent: Monday, August 03, 2009 2:50 PM Subject: Pietenpol-List: Back from Brodhead and Oshkosh Just wanted to post a note on the list saying how much I enjoyed meeting more of the Pietenpol crew at Brodhead and Oshkosh. I flew out in my Stinson but spent time talking to the other California Pieters about a trip out when more of their airplanes are in the air. It was a real pleasure meeting Gary Boothe from Cool, CA, seeing Jim Boyer once again, getting a close up look at Gary and Shad Bell's and Randy Bush's Corvair powered Piets, meeting Don Emch and marveling over his beautiful Piet with the covered wire wheels, seeing Dick Navratil's unique wood-grain radial-powered Piet, meeting Jeff Boatright and his dad (thanks for the videos!) and of course catching up on twenty years' worth of history with Ernie Moreno over a beer. I didn't get to see much of William Wynne at Brodhead but got to talk with Grace a couple times, and saw them again at Oshkosh where I invited them to chastise me severely for not getting the Pfeifer going yet so I would move it to the top of the priority list when I got home. They did. I would have liked to get a Piet ride but that was my own fault for not hanging around the group more. I got the oil changed on the Stinson before going up to Oshkosh and looked around Brodhead a bit, but there is never enough time to see and do everything and talk to everyone in such a short time as a long weekend. It was a kick to walk through the group of Pietenpols up at Oshkosh where they were displayed just inside the old main gate. With the rain everyone was battened down but the birds still looked beautiful. Happy 80th birthday! I recommend a trip to Brodhead for everyone building a Pietenpol. A Southwest flight into Chicago and a rental car shared between two or three people is relatively inexpensive and the wealth of information and inspiration there are priceless. I even got to run out to the runway with Randy and a bunch of others when a RV-7A stuck the nose wheel into the turf and turned over. I walked the last hundred yards with a couple of the other old guys, but it turned out the pilot wasn't badly injured. I'm looking forward to getting together with some of the other West Coast Pieters in September for lunch and swapping stories, and then getting back to Brodhead in a couple of years to admire all the beautiful airplanes there. Thanks for the memories! Darrel Jones Pfeifer Sport NX154JP Sonoma, CA ________________________________________________________________________________
From: "Patrick Panzera" <panzera@experimental-aviation.com>
Subject: Brodhead Photo
Date: Aug 03, 2009
Be sure and view it full size. www.contactmagazine.com\Fly-Ins\Brodhead-2008a.jpg Pat ________________________________________________________________________________
From: "Patrick Panzera" <Panzera@experimental-aviation.com>
Date: Aug 03, 2009
> <panzera@experimental-aviation.com> > > Be sure and view it full size. > > www.contactmagazine.com\Fly-Ins\Brodhead-2008a.jpg Oops... the file name says 2008, but I shot the photo(s) on Saturday, 7/25/2009. Pat ________________________________________________________________________________
Date: Aug 03, 2009
I know Rans aircraft used some tabs that had staggered holes for the bolt and Nico the cable through the other end hole. gives you some take-up adjustment and you can put a few extra twists in the cable to get just a little more. -I wouldn't want to un-twist it.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255887#255887 ________________________________________________________________________________
Date: Aug 03, 2009
Subject: Re: Brodhead Photo
Hey Pat, The link doesn't work for me. Hep me! Thanks, Jeff ><panzera@experimental-aviation.com> > >Be sure and view it full size. > >www.contactmagazine.com\Fly-Ins\Brodhead-2008a.jpg > >Pat -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Aug 03, 2009
Try this: http://www.contactmagazine.com/Fly-Ins/Brodhead-2008a.jpg -----Original Message----- >From: Jeff Boatright <jboatri(at)emory.edu> >Sent: Aug 3, 2009 8:04 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Brodhead Photo > > >Hey Pat, > >The link doesn't work for me. Hep me! > >Thanks, > >Jeff > >><panzera@experimental-aviation.com> >> >>Be sure and view it full size. >> >>www.contactmagazine.com\Fly-Ins\Brodhead-2008a.jpg >> >>Pat > >-- >--- > >Jeffrey H. Boatright, Ph.D. >Associate Professor of Ophthalmology >Emory University School of Medicine >Editor-in-Chief >Molecular Vision > > ________________________________________________________________________________
Date: Aug 03, 2009
2011 sounds good to me....that will give me 2010 to finish and fly up there and work out the squaks... :-) -----Original Message----- >From: Gary Boothe <gboothe5(at)comcast.net> >Sent: Aug 3, 2009 7:01 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Back from Brodhead and Oshkosh > > >Darrel, > >It was certainly my pleasure to meet you, though it's definitely odd that we >had to travel so far when we only live 80 miles apart!! Someday you may want >to take your Stinson to Georgetown and I'll pick you up and show you may >project. > >Realistically, I think I can make Brodhead 2011 in my Piet. In fact, I >hereby throw down the challenge: > >West Coast Piet builders - get ready for an historical mecca to Brodhead in >2011 in our Piets!! > >I know Mike Groah will be flying by then, and so should Jim Boyer! Chris >Tracy, Mike Weaver...you boys can do it, too! And, Darrel, I take back that >offer to show you my project...you need to spend that day on the Pfeifer, so >you can join us!! > >Gary Boothe >Cool, Ca. >Pietenpol >WW Corvair Conversion >Tail done, Fuselage on gear >(13 ribs down.) > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Darrel Jones >Sent: Monday, August 03, 2009 2:50 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Back from Brodhead and Oshkosh > > >Just wanted to post a note on the list saying how much I enjoyed meeting >more of the Pietenpol crew at Brodhead and Oshkosh. I flew out in my >Stinson but spent time talking to the other California Pieters about a >trip out when more of their airplanes are in the air. > >It was a real pleasure meeting Gary Boothe from Cool, CA, seeing Jim >Boyer once again, getting a close up look at Gary and Shad Bell's and >Randy Bush's Corvair powered Piets, meeting Don Emch and marveling over >his beautiful Piet with the covered wire wheels, seeing Dick Navratil's >unique wood-grain radial-powered Piet, meeting Jeff Boatright and his >dad (thanks for the videos!) and of course catching up on twenty years' >worth of history with Ernie Moreno over a beer. > >I didn't get to see much of William Wynne at Brodhead but got to talk >with Grace a couple times, and saw them again at Oshkosh where I >invited them to chastise me severely for not getting the Pfeifer going >yet so I would move it to the top of the priority list when I got >home. They did. > >I would have liked to get a Piet ride but that was my own fault for not >hanging around the group more. I got the oil changed on the Stinson >before going up to Oshkosh and looked around Brodhead a bit, but there >is never enough time to see and do everything and talk to everyone in >such a short time as a long weekend. > >It was a kick to walk through the group of Pietenpols up at Oshkosh >where they were displayed just inside the old main gate. With the rain >everyone was battened down but the birds still looked beautiful. Happy >80th birthday! > >I recommend a trip to Brodhead for everyone building a Pietenpol. A >Southwest flight into Chicago and a rental car shared between two or >three people is relatively inexpensive and the wealth of information and >inspiration there are priceless. > >I even got to run out to the runway with Randy and a bunch of others >when a RV-7A stuck the nose wheel into the turf and turned over. I >walked the last hundred yards with a couple of the other old guys, but >it turned out the pilot wasn't badly injured. > >I'm looking forward to getting together with some of the other West >Coast Pieters in September for lunch and swapping stories, and then >getting back to Brodhead in a couple of years to admire all the >beautiful airplanes there. > >Thanks for the memories! > >Darrel Jones >Pfeifer Sport NX154JP >Sonoma, CA > > ________________________________________________________________________________
Date: Aug 03, 2009
Gary, Done deal! I'll bring my old, out of date charts to the September meeting so we can start planning our route. We'll be OK as long as they don't close some airports or put tall towers up along our route. At least none over 500' AGL. Darrel Gary Boothe wrote: > > Darrel, > > It was certainly my pleasure to meet you, though it's definitely odd that we > had to travel so far when we only live 80 miles apart!! Someday you may want > to take your Stinson to Georgetown and I'll pick you up and show you may > project. > > Realistically, I think I can make Brodhead 2011 in my Piet. In fact, I > hereby throw down the challenge: > > West Coast Piet builders - get ready for an historical mecca to Brodhead in > 2011 in our Piets!! > > I know Mike Groah will be flying by then, and so should Jim Boyer! Chris > Tracy, Mike Weaver...you boys can do it, too! And, Darrel, I take back that > offer to show you my project...you need to spend that day on the Pfeifer, so > you can join us!! > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion > Tail done, Fuselage on gear > (13 ribs down.) > > ________________________________________________________________________________
Date: Aug 03, 2009
Twist the wire to lengthen or shorten it. I made up the bottom braces tight enough to have to pull down a little on the stab to put in the clevis pins on both sides. Then supported the entire tail on 2X4's just outside the stab fittings. This tensions the bottom cables. I tied a milk bottle container to the tail and filled it with bricks for more tension. The upper cables were already nico'd to the rudder so I ran them to their respective places on the stab, set up all the bits, pulled everything tight and clamped with those U bolt cable clamps. At this point I ran around tweaking the tension and making absolutely sure the rudder fin was 90 and straight, the two ends of the stab were absolutely level with each other using wynding sticks and then proceeded to do up the nico's, checking everything after each crimp. The wynding stick method, ancient as it is, is accurate to more than a hundredth of a degree. With a good eye even closer. All you need are two straight, square sticks or tubes, one white, the other black. The longer the better. Clif Wynding sticks, kinda like the way they built the SR-71. Subject: Pietenpol-List: Re: Tensioning cables without turnbuckles > Tim; I haven't tried this idea as yet but here it is for your information. > make up the other ends as tight as possible, remove the washers, tighten, and all should be tight. This may take some trial & error to get it right. Seems like this will be easier using cable than hard wire but I haven't tried either, as I said. > Will > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=255792#255792 > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 17:56:00 ________________________________________________________________________________
Date: Aug 03, 2009
Subject: Re: Split axle fittings: aargh! yo se de eso
hola oscar te entiendo lo dificil que es para my weld partes no me quedo mu y bien nesesito modificarlo para que aga match con los tagplug pero estoy t ratando porsierto copie el diseno de stirman fuel gauge y mas omenos estoy terminandolo tube algun problema para allar partes paresidas pero the thing nuts son difisil the encontrar para 5/8"d coper thing, pero por hahi ba la cosa perto estou en el mismo dilema weldig parts dode es mas fasil en cotr ar el sellador mencionado en el articulo en spruse ho en local storage grac ias de nuevo por todas tus ideas que son de mucha ayuda .jorge de hanford. --- On Sat, 8/1/09, Oscar Zuniga wrote: From: Oscar Zuniga <taildrags(at)hotmail.com> Subject: Pietenpol-List: Split axle fittings: aargh! Date: Saturday, August 1, 2009, 8:48 AM Andrew; I noticed on the beautifully-fabricated set of split-style landing gearlegs that I bought from Arlene Walsh's estate (off the Aerial biplane) that the attach bolt holes were drilled after the legs were fitted up and that no two of them go straight through the center of the fitting.- Apparently there are just too many things to keep lined up by jigging.- However, the legs on 41CC were made in the conventional way, using Bill Rewey's jig method, and they slide on fairly easily and are not forced or sprung into place so there must be a way to do it successfully. Maybe you can put a pin and lever on the end of the leg and tweak the fittings into alignment, or are they so far out that they can't be tweaked a bit?- It sure would be a shame to have to scrap them and start over. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net le, List Admin. =0A=0A=0A ________________________________________________________________________________
Subject: Re: Brodhead photos
Date: Aug 03, 2009
Excellent! Next time, I'll shave...and maybe wait until I wake up a little more before fielding questions from the throngs in front of a camera. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255926#255926 ________________________________________________________________________________
Date: Aug 03, 2009
Took 40 minutes to get to Brodhead from my place, 2 hours to get to OSH (lots of S-turning behind the 'Slow Group'), and an hour flat to get home (90 miles). Lots of kids had the chance to sit in the airplane at OSH (and by that, I mean the builders as well as the youngin's). Hopped a few rides at Brodhead despite some windy conditions...anybody building that wants to fly a Piet, just let me know next year. I should have #2 finished by then and #3 should be covered. Next trip is Blakesburg then back to Brodhead for Grassroots. Thanks everybody for a great time! Feels SO good to get her in the air at last. Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255927#255927 Attachments: http://forums.matronics.com//files/piet12_200.jpg ________________________________________________________________________________
Date: Aug 04, 2009
Rob, It was great meeting you briefly. Your plane is gorgeous. Hopefully I'll have our Piet up to B'head next year. Jeff > >Took 40 minutes to get to Brodhead from my place, 2 hours to get to >OSH (lots of S-turning behind the 'Slow Group'), and an hour flat to >get home (90 miles). > >Lots of kids had the chance to sit in the airplane at OSH (and by >that, I mean the builders as well as the youngin's). > >Hopped a few rides at Brodhead despite some windy >conditions...anybody building that wants to fly a Piet, just let me >know next year. I should have #2 finished by then and #3 should be >covered. > >Next trip is Blakesburg then back to Brodhead for Grassroots. > >Thanks everybody for a great time! Feels SO good to get her in the >air at last. > >Rob -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Aug 04, 2009
For the most part I agree but maybe the encontrar para coper thing should be 1/2" instead of 5/8"???..... Hey wait, this isn't pig latin........never mind. -----Original Message----- >From: jorge lizarraga <flightwood(at)yahoo.com> >Sent: Aug 4, 2009 1:18 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Split axle fittings: aargh! yo se de eso > >hola oscar te entiendo lo dificil que es para my weld partes no me quedo muy bien nesesito modificarlo para que aga match con los tagplug pero estoy tratando porsierto copie el diseno de stirman fuel gauge y mas omenos estoy terminandolo tube algun problema para allar partes paresidas pero the thing nuts son difisil the encontrar para 5/8"d coper thing, pero por hahi ba la cosa perto estou en el mismo dilema weldig parts dode es mas fasil en cotrar el sellador mencionado en el articulo en spruse ho en local storage gracias de nuevo por todas tus ideas que son de mucha ayuda .jorge de hanford. > >--- On Sat, 8/1/09, Oscar Zuniga wrote: > >From: Oscar Zuniga <taildrags(at)hotmail.com> >Subject: Pietenpol-List: Split axle fittings: aargh! >To: "Pietenpol List" >Date: Saturday, August 1, 2009, 8:48 AM > > >Andrew; > >I noticed on the beautifully-fabricated set of split-style >landing gearlegs that I bought >from Arlene Walsh's estate (off the Aerial biplane) that >the attach bolt holes were drilled after the legs were fitted >up and that no two of them go straight through the center of >the fitting. Apparently there are just too many things to >keep lined up by jigging. However, the legs on 41CC were >made in the conventional way, using Bill Rewey's jig method, >and they slide on fairly easily and are not forced or sprung >into place so there must be a way to do it successfully. > >Maybe you can put a pin and lever on the end of the leg and >tweak the fittings into alignment, or are they so far out >that they can't be tweaked a bit? It sure would be a shame >to have to scrap them and start over. > >Oscar Zuniga >Air Camper NX41CC >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > >le, List Admin. > > ________________________________________________________________________________
Date: Aug 04, 2009
Rob, It was really nice to meet you and to see your airplane. I hope to see you again at Brodhead in the future. I don't know how many more times I'll brave the trip over the mountains in mine (3 days instead of 40 minutes for me), but I'll be there even if I leave the Pietenpol in the hangar. I'll eventually bring it back again. Jack Phillips NX899JP Icarus Plummet Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of skybachs Sent: Tuesday, August 04, 2009 2:02 AM Subject: Pietenpol-List: Re: trip comments Took 40 minutes to get to Brodhead from my place, 2 hours to get to OSH (lots of S-turning behind the 'Slow Group'), and an hour flat to get home (90 miles). Lots of kids had the chance to sit in the airplane at OSH (and by that, I mean the builders as well as the youngin's). Hopped a few rides at Brodhead despite some windy conditions...anybody building that wants to fly a Piet, just let me know next year. I should have #2 finished by then and #3 should be covered. Next trip is Blakesburg then back to Brodhead for Grassroots. Thanks everybody for a great time! Feels SO good to get her in the air at last. Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255927#255927 Attachments: http://forums.matronics.com//files/piet12_200.jpg ________________________________________________________________________________
Date: Aug 04, 2009
Subject: for those of you who might not have met Jim Markle yet
Here is his shining face next to me at Brodhead two weeks ago. (He's the Roscoe Turner look-alike contest winner) Also pictured are John Hofmann, Ryan & Jess Mueller, and Captain Jack Phill ips. Mike C. PS-thank you to ALL of your great suggestions in data recovery of my photo memory card. It worked ! ________________________________________________________________________________
Date: Aug 04, 2009
Hi Rob, skybachs wrote: > > Took 40 minutes to get to Brodhead from my place, 2 hours to get to OSH (lots of S-turning behind the 'Slow Group'), and an hour flat to get home (90 miles). S-turns? 90mph? What kind of engine do you have on your Piet? > > Hopped a few rides at Brodhead despite some windy conditions...anybody building that wants to fly a Piet, just let me know next year. I should have #2 finished by then and #3 should be covered. > Wait... what? #2 will be done and #3 on the way? Are you going into the Pietenpol building business? > Next trip is Blakesburg then back to Brodhead for Grassroots. > > Thanks everybody for a great time! Feels SO good to get her in the air at last. > I echo everyone else's comments - you've got a fine, fine airplane, there. Cheers, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 04, 2009
Subject: Cut off for ad/article (Piet. news letter)
Does anyone know what the cut off date is for submitting an article/ad in the next Pietenpol newsletter? ________________________________________________________________________________
Subject: Re: for those of you who might not have met Jim Markle
yet
Date: Aug 04, 2009
I had the pleasure of meeting Jim this past weekend. Mark (K5YAC) and I drove out to Jim's place to check out his progress. Won't be long now Jim!! Oh yeah Jim......ya' got that mailbox fixed yet? :P Jody Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255963#255963 ________________________________________________________________________________
Date: Aug 04, 2009
CDAWSON5854(at)shaw.ca wrote: > The wynding stick method, ancient as it is, is accurate > to more than a hundredth of a degree. With a good eye > even closer. > > All you need are two straight, square sticks or tubes, > one white, the other black. The longer the better. > > > > > > > > > > > > > > Clif; can you provide more info on the wynding sticks; I don't know about this. Thanks so much...................Will -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 17:56:00[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255966#255966 ________________________________________________________________________________
Date: Aug 04, 2009
yet Thanks, I think that the picture in the Post Office looks a lot more like him! John ________________________________________________________________________________
Date: Aug 04, 2009
There's a brief description on Wikipedia - explains it better than I could. http://en.wikipedia.org/wiki/Winding_sticks You could also search the woodworker's forums. --Ken > > > CDAWSON5854(at)shaw.ca wrote: >> The wynding stick method, ancient as it is, is accurate >> to more than a hundredth of a degree. With a good eye >> even closer. >> >> All you need are two straight, square sticks or tubes, >> one white, the other black. The longer the better. >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > Clif; can you provide more info on the wynding sticks; I don't know about > this. Thanks so much...................Will > > > -------------------------------------------------------------------------------- > > > > Checked by AVG - www.avg.com > 17:56:00[/quote] > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=255966#255966 > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2009
Subject: Re: Cut off for ad/article (Piet. news letter)
Approximately August 31st. Greg C. ----- Original Message ----- From: "Michael Perez" <speedbrake(at)sbcglobal.net> Sent: Tuesday, August 4, 2009 9:00:10 AM GMT -06:00 US/Canada Central Subject: Pietenpol-List: Cut off for ad/article (Piet. news letter) ________________________________________________________________________________
yet
Date: Aug 04, 2009
That is the guy from the Paris Air Show, right? Yeah, Jody is right... kind of hard to look for an address when the mailbox door is missing? You think that thing will fly with just one set of uprights on the spars? Looking a little spooky. LOL! -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255984#255984 ________________________________________________________________________________
Date: Aug 04, 2009
Subject: turning base to final for runway 36L at Oshkosh
$1020012 ________________________________________________________________________________
Date: Aug 04, 2009
Subject: OSH09 Don Emch & Larry Williams after arriving at Oshkosh.jpg
Don is on left, Larry on right. By Larry's Ford Pietenpol. ________________________________________________________________________________
Date: Aug 04, 2009
OK; I've used this for years, just didn't know they had a name. Thanks for the info. Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255992#255992 ________________________________________________________________________________
Date: Aug 04, 2009
Thanks. --- On Tue, 8/4/09, gcardinal(at)comcast.net wrote: From: gcardinal(at)comcast.net <gcardinal(at)comcast.net> Subject: Re: Pietenpol-List: Cut off for ad/article (Piet. news letter) Date: Tuesday, August 4, 2009, 12:29 PM #yiv2093032156 p {margin:0;} Approximately August 31st. - Greg C. ----- Original Message ----- From: "Michael Perez" <speedbrake(at)sbcglobal.net> Sent: Tuesday, August 4, 2009 9:00:10 AM GMT -06:00 US/Canada Central Subject: Pietenpol-List: Cut off for ad/article (Piet. news letter) Does anyone know what the cut off date is for submitting an article/ad in t he next Pietenpol newsletter? ________________________________________________________________________________
Date: Aug 04, 2009
Subject: Re: turning base to final for runway 36L at Oshkosh
THAT is a COOL picture! -----Original Message----- >From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov> >Sent: Aug 4, 2009 1:16 PM >To: "pietenpol-list(at)matronics.com" >Subject: Pietenpol-List: turning base to final for runway 36L at Oshkosh > > >$1020012 > > ________________________________________________________________________________
Date: Aug 04, 2009
What a thrill! Thanks for share, J ________________________________________________________________________________
Date: Aug 04, 2009
Subject: Airbus pilots caught bragging
" I overheard them saying "you know we used the same runway that the Pieten pols used when they arrived" Of course I'm kidding but thought about that after they landed that monster A-380 on Runway 36L......just like we did. (but we turned off way earlier) Mike C. ________________________________________________________________________________
Date: Aug 04, 2009
If you look closely, you can see the wing of my Piet, ahead of Mike's. My wing is about even with the middle of the runway, and off to the right, on final for 36L. Don Emch is right at the end of the runway, just about to touch down. Five others had landed just ahead of Don. Quite a show, landing eight Pietenpols in a row there. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Tuesday, August 04, 2009 1:17 PM Subject: Pietenpol-List: turning base to final for runway 36L at Oshkosh $1020012 ________________________________________________________________________________
Subject: Re: Airbus pilots caught bragging
Date: Aug 04, 2009
Well, at least the Piet's didn't "smash" the runway. [Shocked] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256015#256015 ________________________________________________________________________________
Date: Aug 04, 2009
Mike, I think you could safely land a Piet in either the width or length of the Airbus. When I saw the C-5 sitting there with both ends open I told Randi that was their low resistance economy cruise mode ...air just goes straight throug h it =) She's blond but not that blond. We delivered our first Piet 0-200 mount to Paul Siegel at osh. If anyone needs one, the fixture is adjustable in both fuselage width and offset fro m the firewall. See our web site below. CG Products, Custom Aircraft Hardware www.CozyGirrrl.com Cozy Mk-IV RG 13B-turbo Plans #957 Chapter? big pieces done, details, details ======================== ====== If you have a "Spam Blocker" that requires we fill out a form you will not hear from us. Please do not make your spam problem ours. In a message dated 8/4/2009 1:42:24 P.M. Central Daylight Time, michael.d.cuy(at)nasa.gov writes: =9C I overheard them saying =9Cyou know we used the same runw ay that the Pietenpols used when they arrived=9D Of course I=99m kidding but thought about that after they landed th at monster A-380 on Runway 36Ljust like we did. (but we turned off way earlier) Mike C. ======================== ============ (http://www.matronics.com/Navigator?Pietenpol-List) ======================== ============ ======================== ============ (http://www.matronics.com/contribution) ======================== ============ ________________________________________________________________________________
Date: Aug 04, 2009
V2hlbiBJIHNhdyB0aGUgQy01IHNpdHRpbmcgdGhlcmUgd2l0aCBib3RoIGVuZHMgb3BlbiBJIHRv bGQgUmFuZGkgdGhhdCB3YXMgdGhlaXIgbG93IHJlc2lzdGFuY2UgZWNvbm9teSBjcnVpc2UgbW9k ZSAgLi4uYWlyIGp1c3QgZ29lcyBzdHJhaWdodCB0aHJvdWdoIGl0DQoNCkhtbW3igKZJIHdvbmRl ciBpZiB0aGV54oCZdmUgZXZlciB0aG91Z2h0IG9mIHRoYXQgdG8gc2F2ZSBmdWVsICEgICAgICAg IFdlIGNvdWxkIHByb2JhYmx5IGxhbmQgYSBjbGlwcGVkIHdpbmcgUGlldCBJTlNJREUgb2YgYSBD LTUgY2FyZ28NCmFyZWEgaWYgaGUgdGF4aWVkIHNheSAyNSB0byAzMCBtcGguICAgICBUaGV5IGNv dWxkIG1ha2UgdGhlIG9uZSBzaWRlIG9mIHRoZSBDLTUgTGV4YW4gc28gdGhlIGNyb3dkIGNvdWxk IHNlZSBpdCBoYXBwZW5pbmcuDQoNClRoZSB0YXhpd2F5IHRoYXQgcG9zZXMgYXQgMzZSLzE4TCBk dXJpbmcgdGhlIGFpciBzaG93IGNvbnZlbnRpb24gYXQgT3Noa29zaCBpcyBhdCBsZWFzdCBUV0lD RSBhcyB3aWRlIGFzIG15IGhvbWUgYmFzZSBydW53YXkgc28NCkkgc3VzcGVjdCB3ZSBjb3VsZCBs YW5kIGEgUGlldCBwcmV0dHkgbXVjaCBhbnl3aGVyZSB0aGV5IGNsZWFyZWQgdXMgdG8uICAgIEdy ZWcgQ2FyZGluYWwgbGFuZGVkIGF0IHRoZSB1bHRyYWxpZ2h0IGZpZWxkICh0YWlsc2tpZCkNCmFu ZCB0aGF04oCZcyBvbmx5IDEsMjAw4oCZIGxvbmcuICAgR3JlZyBzYWlkIGl0IHdhcyBwZXJmZWN0 LiAgIChub3QgdG8gbWVudGlvbiBpdCB3YXMgZGlyZWN0bHkgaW50byB0aGF0IGd1c3R5IHF1YXJ0 ZXJpbmcgY3Jvc3N3aW5kIHRoZQ0KcmVzdCBvZiB1cyBoYWQgb24gMzZMIFN1bmRheS4gICAgKEdy ZWcgaXMgdGhlIHNtYXJ0ZXN0IG9uIG9mIGFsbCBvZiB1cykNCg0KTWlrZSBDLg0KDQoNCg0KDQoN Cg= ________________________________________________________________________________
Date: Aug 04, 2009
Subject: packed in like sardines at Oshkosh
Date: Aug 04, 2009
Subject: BPA Newsletter
Hello everyone. I have a question on the BPA newsletter. I attended the presentation that Bill Rewey did at Oshkosh regarding building a Pietenpol. In the paper he handed out it says the address for BPA is: BPA Independent Register P.O. Box 225 Broadhead, WI 53520-0255 But on the http://www.pietenpols.org website, it says the address is: Brodhead Pietenpol Association PO Box 3501 Oshkosh, WI 54901 Are these the same organization? I would like to subscribe to the newsletter but want to send the $16 to the right place. Thanks! Mike ________________________________________________________________________________
Subject: Re: BPA Newsletter
Date: Aug 04, 2009
My July newsletter gives the Oshkosh address. Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256031#256031 ________________________________________________________________________________
Date: Aug 04, 2009
Mike, Same organization, but the Brodhead address is old. Send your $ to the Oshkosh address. Have a good day, Ryan On Tue, Aug 4, 2009 at 3:16 PM, Mike Nipp wrote: > > Hello everyone. I have a question on the BPA newsletter. I attended > the presentation that Bill Rewey did at Oshkosh regarding building a > Pietenpol. In the paper he handed out it says the address for BPA is: > > BPA > Independent Register > P.O. Box 225 > Broadhead, WI 53520-0255 > > But on the http://www.pietenpols.org website, it says the address is: > > Brodhead Pietenpol Association > PO Box 3501 > Oshkosh, WI 54901 > > Are these the same organization? I would like to subscribe to the > newsletter but want to send the $16 to the right place. > > > Thanks! > > Mike > > ________________________________________________________________________________
Date: Aug 04, 2009
Man, I don't know about you guys but flying that final would take me about 10 minutes in 41CC, and that's at cruise power! Talk about draggin' it in... Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Brodhead video
Date: Aug 04, 2009
Departures http://www.youtube.com/watch?v=bVvgEaEFcTQ ________________________________________________________________________________
Date: Aug 04, 2009
Clif; I like you chain link shackles. What size chain did you use for what size cable. Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256078#256078 ________________________________________________________________________________
Date: Aug 04, 2009
Cool video Pat. We missed Sunday... I'll bet that was neat. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256094#256094 ________________________________________________________________________________
Date: Aug 04, 2009
Phew. It's been a long couple of days. My wife has been really stressed out over the plane purchase and when she gets stressed, the house gets cleaned. Wwhen she goes on a cleaning binge I have to protect my stuff lest it gets "cleaned" out into the trash cans! She is getting used to the idea, just slowly. Anyway... Thanks for the feedback from everyone. Jeff Boatright wrote: > > Dan, > > I looked N8031 over and I think it's great. This is just my opinion, but > I think you should do a thorough preflight, maybe get a couple more > knowledgeable people to go over the plane too, and then go fly! Life if > really short, and the time that we have to fly is much, much shorter. Yeah, the experimental physicist in me coming out and sometimes I need to "just do it!" In other words, shut up and fly, Dan. Sage advice, Jeff, thanks! > > As to your list, I comment on the items below: > >> - replace exhaust pipes - they're soft steel and starting to rust > > Everything in life is perpetually "starting to rust". Wait until there's > a hole, then patch it. Rinse, repeat. If they get really knarly (like, > in 10 years), maybe replace, but replace with mild steel. In my limited > experience, stainless cracks easier. I've had two pipes depart the > airplane (!), and they were professionally welded. 'nuff said. I won't worry about them until I need to worry about them. > >> - the finish has hairline cracks over the turtledeck stringers and there >> are some circular rings on the horizontal stabilizer. Popular >> consensus is that it's covered in original 1979 Stits Poly-fiber. How >> long before I need to consider rejuvenating or recovering (I realize >> that a punch test should really be performed...)? > > Punch test should be done at the annual condition inspection regardless > of paint condition. Rejuvenator worked for me, can be played around > with next rainy day. Logs say it's Stits Polyfiber with Deero(sp?) Liquid Porcelain (Prairie Gold) with blue 6920-0 Dulux trim. It was repainted in '98 with Sherwin Williams (which explains the 50# weight gain!). >> - There are some bubbles on the leading edge and wrinkles above the ribs >> on the trailing edge, near the center of the plane. Not sure what >> these are signs of... > > Me either. Send us pix. The bubbles only appear on the left wing, not the right. I'm going to venture a guess that he covered that wing first. Here are picts of the wrinkles aft of the trailing spar: http://5n429glenoak.homelinux.net/gallery/N8031/img_2516 Logs say this: 6-20-85 T.T. 46 Hrs Aircraft stored - Rib stiching aft of rear spar rt. wing cut by rodent. Replaced all ribb[sic] stiching aft of spar, wings installed and rigged. Aircraft test flown OK... > >> - The elevator should be rebuilt - it's pretty warped. Sounds like a >> good winter job. > > It just flew further than most Piets ever have. Maybe that warp provides > perfect rigging? :) Also, do you mean one or both of the elevators, or > do you mean the horizontal stabilizer? If it's the stab, maybe the warp > can be handled by adjusting the flying wires. Oh shoot, I was going to take a picture of this today, too. It's the elevator, not the horizontal stabilizer. > >> - The static port needs to be put somewhere on the side of the plane, >> not at the top of the jury strut even with the bottom of the wing. > > Static port? What's that? Try removing the port line into the altimeter, > replacing with a plastic screw plug (hardware store item; sorry, can't > remember thread stats) that you've drilled a tiny hole in. Heh. There's a VSI in the cockpit! Makes me chuckle. > >> - Whoever built it really liked welding. The diagonal cabanes are >> welded to the upright cabanes - there's no chance of just moving the >> wing back a little with the current set up. The lift strut wing >> fittings are welded, too - no pivoting is allowed. > > The cabanes welds are a potential positive safety feature - see > archives. The lift struts being welded seems strange. Please send pix. Here are picts: http://5n429glenoak.homelinux.net/gallery/N8031/img_2514 http://5n429glenoak.homelinux.net/gallery/N8031/img_2509 I will go search the archives about welded diagonal cabanes. > >> - Gap seals on the ailerons, rudder, and elevators. This is a >> no-brainer. > > Yep. We're still running the same "translucent" duct tape we installed > three years ago. Another rainy day project. BTW, does the rudder really > need it? I don't know; what are other's experiences? So, Tres is an aerospace engineer with a company that build UAVs for government use. He noticed that in a full slip the rudder pressure goes to zero and it won't just naturally return to neutral position, so they put yarn tufts all over the vertical stabilizer and rudder and video taped what happened. The rudder actually stalls in the slip. My guess is that since so much air is able to get through the gap between stabilizer and the rudder it exacerbates the problem and helps the stall. This is all gut feeling, intuition on my part. I could be way off. Gap seal shouldn't hurt on the rudder, though. Now to go fly... Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 04, 2009
Subject: Re: Bleriot at Brodhead!!!!
Dave Abramson wrote: > > Hello all! > > Does anyone know where that Bleriot came from that was at Brodhead???? > > Makes the Pietenpol look a little small too! > > Cheers, > > Dave > > > The Bleriot XI belongs to Eric and Debbie Presten from Sonoma, CA. It is an Airdrome Airplane from Rob Baslee in St. Louis, MO. Eric, Debbie and their two boys Curtis and Ben put it together in 29 calendar days to have it ready for Brodhead and Oshkosh. He test flew it then towed it to Brodhead where it made a few hops down the field. Eric is a photographer and author and self-publishes books on vintage and antique airplanes. If you saw the Bleriot you probably saw Eric, Debbie and the kids under the wing selling books. Eric also test-flew the Nieuports Baslee built for the movie Flyboys and also flew another Bleriot replica for the upcoming Amelia Erhart movie. Eric will base the Bleriot at Sonoma Skypark after the airshow and fly-in season. If any of you are out in the area, there are a number of interesting airplanes based there as well as at the Schellville airport two miles away. Darrel Jones Sonoma, CA ________________________________________________________________________________
Date: Aug 04, 2009
Just think. With a long enough pair we could prove the world is flat. At least in Manitoba where you can watch your dog run away for three days. :-) Sorry Will, I can't remember what size, just that the pin hole is 3/16". It will be in the archives somewhere. Also, just that one size for everything. No on the Gb. I was too chicken to keep putting more bricks in the milk case. Clif ----- Original Message ----- From: "Will42" <will(at)cctc.net> Sent: Tuesday, August 04, 2009 10:21 AM Subject: Pietenpol-List: Re: Tensioning cables without turnbuckles > > OK; I've used this for years, just didn't know they had a name. Thanks for > the info. > > Will > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=255992#255992 > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 18:01:00 ________________________________________________________________________________
Date: Aug 04, 2009
Unless you have broken or rotted wood in your wings. then that is just a ba d covering job. the fabric has not been shrunk enough to the proper tempatu re. reshrink it or take it offf and recover the wing. Bill Budgell CAP Aviation Tel: 705-422-1604 Cell:705-330-5763 Fax: 705-422-1604 Email: capaviation(at)rogers.com --- On Tue, 8/4/09, Dan Yocum wrote: From: Dan Yocum <yocum(at)fnal.gov> Subject: Re: Pietenpol-List: ok, lemme have it! Received: Tuesday, August 4, 2009, 11:02 PM Phew.- It's been a long couple of days.- My wife has been really stress ed out over the plane purchase and when she gets stressed, the house gets c leaned.- Wwhen she goes on a cleaning binge I have to protect my stuff le st it gets "cleaned" out into the trash cans! She is getting used to the idea, just slowly. Anyway... Thanks for the feedback from everyone. Jeff Boatright wrote: > > Dan, > > I looked N8031 over and I think it's great. This is just my opinion, but I think you should do a thorough preflight, maybe get a couple more knowled geable people to go over the plane too, and then go fly! Life if really sho rt, and the time that we have to fly is much, much shorter. Yeah, the experimental physicist in me coming out and sometimes I need to " just do it!"- In other words, shut up and fly, Dan.- Sage advice, Jeff, thanks! > > As to your list, I comment on the items below: > >> - replace exhaust pipes - they're soft steel and starting to rust > > Everything in life is perpetually "starting to rust". Wait until there's a hole, then patch it. Rinse, repeat. If they get really knarly (like, in 1 0 years), maybe replace, but replace with mild steel. In my limited experie nce, stainless cracks easier. I've had two pipes depart the airplane (!), a nd they were professionally welded. 'nuff said.- I won't worry about them until I need to worry about them. > >> - the finish has hairline cracks over the turtledeck stringers and there >>---are some circular rings on the horizontal stabilizer.- Popular >>---consensus is that it's covered in original 1979 Stits Poly-fiber .- How >>---long before I need to consider rejuvenating or recovering (I rea lize >>---that a punch test should really be performed...)? > > Punch test should be done at the annual condition inspection regardless o f paint condition. Rejuvenator worked for me,- can be played around with next rainy day. Logs say it's Stits Polyfiber with Deero(sp?) Liquid Porcelain (Prairie Gol d) with blue 6920-0 Dulux trim.- It was repainted in '98 with Sherwin Wil liams (which explains the 50# weight gain!). >> - There are some bubbles on the leading edge and wrinkles above the ribs >>---on the trailing edge, near the center of the plane.- Not sure what >>---these are signs of... > > Me either. Send us pix. The bubbles only appear on the left wing, not the right.- I'm going to ve nture a guess that he covered that wing first. Here are picts of the wrinkles aft of the trailing spar: http://5n429glenoak.homelinux.net/gallery/N8031/img_2516 Logs say this: 6-20-85 T.T. 46 Hrs Aircraft stored - Rib stiching aft of rear spar rt. win g cut by rodent.- Replaced all ribb[sic] stiching aft of spar, wings inst alled and rigged.- Aircraft test flown OK... > >> - The elevator should be rebuilt - it's pretty warped.- Sounds like a >>---good winter job. > > It just flew further than most Piets ever have. Maybe that warp provides perfect rigging? :) Also, do you mean one or both of the elevators, or do y ou mean the horizontal stabilizer? If it's the stab, maybe the warp can be handled by adjusting the flying wires. Oh shoot, I was going to take a picture of this today, too.- It's the ele vator, not the horizontal stabilizer. > >> - The static port needs to be put somewhere on the side of the plane, >>---not at the top of the jury strut even with the bottom of the win g. > > Static port? What's that? Try removing the port line into the altimeter, replacing with a plastic screw plug (hardware store item; sorry, can't reme mber thread stats) that you've drilled a tiny hole in. Heh.- There's a VSI in the cockpit!- Makes me chuckle. > >> - Whoever built it really liked welding.- The diagonal cabanes are >>---welded to the upright cabanes - there's no chance of just moving the >>---wing back a little with the current set up.- The lift strut wi ng >>---fittings are welded, too - no pivoting is allowed. > > The cabanes welds are a potential positive safety feature - see archives. The lift struts being welded seems strange. Please send pix. Here are picts: http://5n429glenoak.homelinux.net/gallery/N8031/img_2514 http://5n429glenoak.homelinux.net/gallery/N8031/img_2509 I will go search the archives about welded diagonal cabanes. > >> - Gap seals on the ailerons, rudder, and elevators.- This is a >>---no-brainer. > > Yep. We're still running the same "translucent" duct tape we installed th ree years ago. Another rainy day project. BTW, does the rudder really need it? I don't know; what are other's experiences? So, Tres is an aerospace engineer with a company that build UAVs for govern ment use.- He noticed that in a full slip the rudder pressure goes to zer o and it won't just naturally return to neutral position, so they put yarn tufts all over the vertical stabilizer and rudder and video taped what happ ened.- The rudder actually stalls in the slip.- My guess is that since so much air is able to get through the gap between stabilizer and the rudde r it exacerbates the problem and helps the stall.- This is all gut feelin g, intuition on my part.- I could be way off.- Gap seal shouldn't hurt on the rudder, though. Now to go fly... Dan -- Dan Yocum Fermilab- 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab.- Just zeros and ones. le, List Admin. ________________________________________________________________________________
Date: Aug 05, 2009
Subject: excellent YouTube videos posted by you guys !
THANK you all so much (Jeff Boatright, Jim Markle...and I'm sure I'm missin g someone or two) for posting all of those videos from Brodhead on YouTube. Just fantastic. Some of you captured the same action from different angles even. Super stuff. I'll be watching those in Febr uary when there is 9" of snow on the ground. This will get you started if you missed the post (s) about the videos. http://www.youtube.com/watch?v=5nIywIgxevI&feature=related Mike C. ________________________________________________________________________________
Date: Aug 05, 2009
Subject: Steve Ruse from Oklahoma & hand propping
Some of you Great Waldo Pepper movie fans will like this. I was fortunate to be able to meet Steve Ruse last Friday morning at Oshkosh and see his well-traveled airplane. Sure is nice to see some younger blood getting into Pietenpols---not that there is anything wrong with the veteran s-they sure know a bunch. After I got my departure briefing from the guys in the shack by the brown a rch I pushed the airplane to the flight line and was looking for a qualified person to prop me and saw S teve again. I didn't even have to think about how to ask him, the words just came out of my mouth. "I'd be obliged if you'd prop me Steve" (substituting Steve for son). Thanks Steve ! Mike C. ________________________________________________________________________________
Date: Aug 05, 2009
Subject: Re: Steve Ruse from Oklahoma & hand propping , Pietenpol-List:
Steve Ruse from Oklahoma & hand propping No problem Mike! It was really great to meet you too. I've always admired your airplane, as everyone does. Meeting a few of you guys sure makes me want to go to Broadhead. I'm itching to do it now. Maybe next year Jim Markle and I can fly up together. Sounds like several days of sheer fun. Steve Quoting "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" : > Some of you Great Waldo Pepper movie fans will like this. I was > fortunate to be able to meet Steve Ruse > last Friday morning at Oshkosh and see his well-traveled airplane. > Sure is nice to see some younger blood > getting into Pietenpols---not that there is anything wrong with the > veterans-they sure know a bunch. > > After I got my departure briefing from the guys in the shack by the > brown arch I pushed the airplane to > the flight line and was looking for a qualified person to prop me > and saw Steve again. I didn't even have > to think about how to ask him, the words just came out of my mouth. > "I'd be obliged if you'd prop me Steve" > (substituting Steve for son). Thanks Steve ! > > Mike C. > > ________________________________________________________________________________
Subject: Re: corvair mounts
Date: Aug 05, 2009
Hi Ryan, I did not want to delete this from my inbox without thanking you. Obviously, I got a little sidetracked with Brodhead and all, but when I got home I did some real searching. Using the key words in Mark's description, I finally found these at Summit Racing, online, and had the grommets within 2 days! I am now ready to get the engine on its mount after I first finish up the brakes this weekend. Hopefully all is going well for you and Jess in moving your project to the hanger/barn. I very much enjoyed meeting both of you. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Sunday, June 28, 2009 4:48 PM Subject: Re: Pietenpol-List: Re: corvair mounts I hadn't noticed the question before, so I may be a bit late with this. From the Corvaircraft archives, here is Mark Langford describing what he used to mount his engine: ----------------- I'm using "Energy Suspension" 9.810R 3/8" I.D. Shock Tower Grommets, straight from the local speed shop. I think WW may use some that are a little larger in diameter, but these work too. I used AN6 bolts with MS21042 steel lock nuts from Wicks. Also, I used 3/8" ID polyurethane tubing from Home Depot between the engine case and bolt to take up the slack in that .56 diameter hole in the case. Washers are large diameter AN970-6 from Wicks. Mark flies the pants off his KR, so you can't go wrong following his lead. Ryan On Sun, Jun 28, 2009 at 1:45 PM, skellytown flyer wrote: Well I was at the hardware store and found some 1/2" O.D. Polyethylene tubing that seems tough. I think I may try that on my bolts where they pass through the case holes.I will make a mental note to keep watch on them and see if I can see any wear.for sure it would be a good item to inspect at annuals.Raymond ________________________________________________________________________________
Date: Aug 05, 2009
Dan, Your lift strut welds look similar to mine and those of other Piets that I've seen. See if Westcoast Piet doesn't have some photos of this fitment on various planes. It's true that your cabane weldments won't allow moving the wing fore or aft, but do you really want to? It sounds like Tres has flown it with a variety of loadings and conducted various maneuvers that encompass what you'd be doing. Did he do a weight and balance and find problems? I suggest doing a W&B now and at every condition inspection anyway, but do you know if your Piet currently has a problem? Along these lines, do you know if Tres put the plane through a complete stall series with various power settings, loadings, and wing angles (for instance, up to 20 degrees of turn)? Any spins? Knowing that the plane is safe for these maneuvers will add confidence to your flying (though spins may be more than anyone is willing to try if they are not sure about any of these other maneuvers). I have never seen puckering on wing fabric like that. I would be very cautious about conducting any of these maneuvers (stalls, spins, etc.) unless you know that they have been completed before with that puckering and that nothing dramatic occurs. Seems to me, as suggested by Bill, that the puckering creates a whole new airfoil. Also, as Bill suggested, it is certainly possible to shrink the fabric if the problem was that it wasn't shrunk correctly at installation. Sherwin Wms comes right off if you apply strong masking tape - it's a feature, not a bug... HTH, Jeff > >>>... The lift strut wing >>> fittings are welded, too - no pivoting is allowed. >> >>The cabanes welds are a potential positive safety feature - see >>archives. The lift struts being welded seems strange. Please send >>pix. > >Here are picts: > >http://5n429glenoak.homelinux.net/gallery/N8031/img_2514 >http://5n429glenoak.homelinux.net/gallery/N8031/img_2509 > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Aug 05, 2009
Subject: A-380 landing video at Oshkosh
I know this isn't Piet related but I didn't realize the Airbus hit the runw ay carrier-style then PIO'ed a bit after touchdown. The pilot probably wasn't used to seeing such a short runway. (6,700') http://www.youtube.com/watch?v=-iIG1ZOPLJA ________________________________________________________________________________
Date: Aug 05, 2009
Ugly!!! And I thought MY landing there looked bad. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Wednesday, August 05, 2009 12:31 PM Subject: Pietenpol-List: A-380 landing video at Oshkosh I know this isn't Piet related but I didn't realize the Airbus hit the runway carrier-style then PIO'ed a bit after touchdown. The pilot probably wasn't used to seeing such a short runway. (6,700') http://www.youtube.com/watch?v=-iIG1ZOPLJA ________________________________________________________________________________
Date: Aug 05, 2009
Subject: Re: A-380 landing video at Oshkosh
I knew she wasn't worth top billing. ________________________________________________________________________________
Date: Aug 05, 2009
Ugh!!! That hurt! Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com Sent from the phone that made the Blackberry obsolete. On Aug 5, 2009, at 12:30 PM, "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" wrote: > I know this isn=99t Piet related but I didn=99t realize the Airbus > hit the runway carrier-style then PIO=99ed a bit after > touchdown. The pilot probably wasn=99t used to seeing such a short > runway. (6,700=99) > > http://www.youtube.com/watch?v=-iIG1ZOPLJA > > ________________________________________________________________________________
Date: Aug 05, 2009
Sure, I started doing that at Brodhead and then realized by the 3rd landing that EVERYONE else's landings are better than mine! :-( >:-} >What a great job!! Critiquing landings at Oshkosh!!................ >Where do I sign up? > >Gary Boothe ________________________________________________________________________________
Date: Aug 05, 2009
Subject: if for any other reason than this-- keep building and
enjoy the view when you're done Gorgeous, lush farm country somewhere in northern Illinois on Saturday mo rning heading from Joliet, IL. You don't see this kind of view from the aisle seat on a 737. (and you don't get Sprite or Diet Coke either--unless you take it in the se at with you !) Mike C. ________________________________________________________________________________
Subject: Re: if for any other reason than this-- keep building
and enjoy
Date: Aug 05, 2009
Maybe I missed it, but you must have recovered your photos. That is a neat shot... looks like a good place to practice emergency procedures. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256214#256214 ________________________________________________________________________________
and enjoy
Date: Aug 05, 2009
WOW What a view. Reminds me of late sixties early seventies flying a 450 Stearman spraying potato bugs just East of Palatka, Fl. Building rib #23 Jerry Dotson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256218#256218 ________________________________________________________________________________
Date: Aug 05, 2009
and enjoy the view when you're done , Pietenpol-List: if for any other reason than this-- keep building and enjoy the view when you're done That is a great view! I saw a lot of pretty country in Northern Iowa on my way up...I never knew that area was so hilly. I think that roughly 97% of the state must be covered in corn. I'll try to post some pictures soon. My only question about your picture is how did you end up so high? There must've been some terrible updrafts that day! Steve Ruse Norman, OK Quoting "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" : > Gorgeous, lush farm country somewhere in northern Illinois on > Saturday morning heading > from Joliet, IL. You don't see this kind of view from the aisle > seat on a 737. > > (and you don't get Sprite or Diet Coke either--unless you take it in > the seat with you !) > > Mike C. > > ________________________________________________________________________________
Subject: Cable-hardware store vs. certified
Date: Aug 05, 2009
Anyone with information on using hardware store cable vs. the certified stuff. I see there is lots of difference in the price; what about the strength and quality? Thoughts? Experience? Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256227#256227 ________________________________________________________________________________
Subject: Re: Cable-hardware store vs. certified
Date: Aug 05, 2009
I wouldn't do it, that cheap stuff is crud. Saving a few bucks that way isn't worth it. - Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256228#256228 ________________________________________________________________________________
Date: Aug 05, 2009
Thank you Mike, I just set that one as my desktop image on my work laptop. It will keep my motivation up to get mine in the air ASAP so I can take my own similar pictures. Great seeing you and the gang at Brodhead. Rick On Wed, Aug 5, 2009 at 2:55 PM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > Gorgeous, lush farm country somewhere in northern Illinois on Saturday > morning heading > from Joliet, IL. You don't see this kind of view from the aisle seat on a > 737. > > (and you don't get Sprite or Diet Coke either--unless you take it in the > seat with you !) > > Mike C. > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Aug 05, 2009
This is all I see every time up, guess I am pretty spoiled. When the engine quits, it is a matter of picking the "best" empty, perfectly flat?field. Dan Helsper Poplar Grove, IL ________________________________________________________________________________
Date: Aug 05, 2009
Will, I agree with Baldeagle! It has been stated before, by veteran builders, to stick with AN hardware as much as possible. There are exceptions, such as the use of motorcycle links to make attachments, but the strength of the links are well demonstrated. How far along are you in your project? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Will42 Sent: Wednesday, August 05, 2009 2:41 PM Subject: Pietenpol-List: Cable-hardware store vs. certified Anyone with information on using hardware store cable vs. the certified stuff. I see there is lots of difference in the price; what about the strength and quality? Thoughts? Experience? Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256227#256227 ________________________________________________________________________________
Date: Aug 05, 2009
Are you building a certified aircraft? Then you don't need certified cable. Is it strong enough ? I dare say you would pull apart what ever it's hook to before the cable would break. Buy a piece and test it to put your mind at ease. Howdy ________________________________________________________________________________
Date: Aug 05, 2009
One difference between aircraft cable and hardware store cable is the lubricant that is impregnated into the aircraft cable (one reason you should never wash your cable with a solvent - it will leach the lubricant out of it). This lubricant is necessary to allow bending the cable over pulleys without chafing the individual strands. Ask Fisherman Ray how his Pietenpol is coming. He was building it exclusively with materials from Home Depot. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of VAHOWDY(at)aol.com Sent: Wednesday, August 05, 2009 6:20 PM Subject: Re: Pietenpol-List: Cable-hardware store vs. certified Are you building a certified aircraft? Then you don't need certified cable. Is it strong enough ? I dare say you would pull apart what ever it's hook to before the cable would break. Buy a piece and test it to put your mind at ease. Howdy _____ ________________________________________________________________________________
Date: Aug 05, 2009
Subject: The Fisherman ! Ray Axiillou Cable-hardware store
vs. certified You can use hardware, cable, glue, and varnish from Home Depot & Lowe's---just don't take any of my family for a ride. Mike C. ________________________________________________________________________________
Date: Aug 05, 2009
Subject: how high was I flying ?
Steve Ruse-- those photos were taken from a maxiumu o 2,000'msl. I can assure you ! Mike C. Never one to wander into the stratosphere. ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Aug 05, 2009
I didn't build my Piet but I have done a lot of minor "adjustments" to it and this is my "view" of non aircraft items. "I know I could save money by buying non aircraft items from Lowe's and maybe it would be ok. However, I think my life is worth the extra dollars and I enjoy flying so much that I would not want to interfere with that joy by worrying about wether I did the right thing by buying because it was cheaper." As I tell everyone, "I worry about everything on the ground, just so I don't worry about them while I'm in the air." Gene in Tennessee ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Wednesday, August 05, 2009 5:24 PM Subject: RE: Pietenpol-List: Cable-hardware store vs. certified One difference between aircraft cable and hardware store cable is the lubricant that is impregnated into the aircraft cable (one reason you should never wash your cable with a solvent - it will leach the lubricant out of it). This lubricant is necessary to allow bending the cable over pulleys without chafing the individual strands. Ask Fisherman Ray how his Pietenpol is coming. He was building it exclusively with materials from Home Depot. Jack Phillips NX899JP Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of VAHOWDY(at)aol.com Sent: Wednesday, August 05, 2009 6:20 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Cable-hardware store vs. certified Are you building a certified aircraft? Then you don't need certified cable. Is it strong enough ? I dare say you would pull apart what ever it's hook to before the cable would break. Buy a piece and test it to put your mind at ease. Howdy ------------------------------------------------------------------------- ----- http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/05/09 05:57:00 ________________________________________________________________________________
Date: Aug 05, 2009
Mike, the 360's landing was much better than mine, FAA wanted to know how many hours I had in class, told them, (her ) 2000 plus, end of conversation, You Piet Captains did a good job. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256247#256247 ________________________________________________________________________________
Subject: Re: ok, lemme have it!
Date: Aug 05, 2009
If they re-stitched the wing, then the buckling fabric is a simple side-affect. I would undo/redo those stitches...maybe a touch of heat from a heatgun while the stitches were out would help as well. Static port: if you move the static port to the back of the panel by removing the static line and plugging, the low pressure in the cockpit area will give you false readings. Try lowering the pitot/static tube to create more room from the bottom of the wing. I put a bushing in front of my static port with a set screw so I could slide it fore and aft from the static port until I got accurate readings. Warped stab can be tweaked with cable adjustments of course, but a warped elevator is a cosmetic problem. Adding another hinge (or heck, a piano hinge full span) might help....and you'd get your gap seal to boot. Don't sweat the cabanes: all your wb adjustments will be with weight added/subtracted around the plane. If she's flying nose heavy or light but the wb is good, there are plenty of things to adjust in the rigging and spring/bungees to add to the bellcrank or the stick itself to help it trim out. If I had known you were flying by, I would've invited you to stop by the Piet Factory (or Brassroots as they're calling it) and done a once-over. Rob -------- NX29NX, C65, Hegy prop, Blue/Cream flying! NX31TM, C85-12, GN-1, 90% done, Red/Cream NX30NX, Corvair, on gear, wings/tail done NX31NX, Hatz CB-1, O-320B, on gear, ribs done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256258#256258 ________________________________________________________________________________
Subject: Grassroots 2009
Date: Aug 05, 2009
Anybody heading this way for Grassroots/Brodhead in September? I'm 50 sm due east of Brodhead (BUU) at an airport with cheap gas and nice grass. Anybody who wants or needs a little pre-Brodhead tweak/clean is welcome to stop by the shop and use what I have available. We'll be taking the Piet and a Clipper as well as our ground-support vehicle for transporting camping supplies, ice, and a variety of 'juices'. If you want to unload or ship anything ahead of your trip, feel free to use my place as you like. Rob -------- NX29NX, C65, Hegy prop, Blue/Cream flying! NX31TM, C85-12, GN-1, 90% done, Red/Cream NX30NX, Corvair, on gear, wings/tail done NX31NX, Hatz CB-1, O-320B, on gear, ribs done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256260#256260 ________________________________________________________________________________
Date: Aug 05, 2009
I would love to be there, but if I come, it will be in the RV-4. One across the mountains in a year in the Piet is enough for me. Jack Phillips NX899JP Icarus Plummet Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of skybachs Sent: Wednesday, August 05, 2009 8:10 PM Subject: Pietenpol-List: Grassroots 2009 Anybody heading this way for Grassroots/Brodhead in September? I'm 50 sm due east of Brodhead (BUU) at an airport with cheap gas and nice grass. Anybody who wants or needs a little pre-Brodhead tweak/clean is welcome to stop by the shop and use what I have available. We'll be taking the Piet and a Clipper as well as our ground-support vehicle for transporting camping supplies, ice, and a variety of 'juices'. If you want to unload or ship anything ahead of your trip, feel free to use my place as you like. Rob -------- NX29NX, C65, Hegy prop, Blue/Cream flying! NX31TM, C85-12, GN-1, 90% done, Red/Cream NX30NX, Corvair, on gear, wings/tail done NX31NX, Hatz CB-1, O-320B, on gear, ribs done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256260#256260 ________________________________________________________________________________
Subject: KZ400 wheels and plans for Jenny style gear
Date: Aug 05, 2009
I've got a line on some KZ400 wheels - they're 18" but only 1.6" rim with a 5 1/2" hub. Would need to replace the bearings but my question is are the rims too narrow? The tires are 3" wide... This is for a front rim. The rears have the integral brake drum built into the hub - I'm considering thi s too for use of the brakes - I like the drum brakes being simple cable ope rated. I think the rears are 1.85" wide. Opinions or experience? Also - my Hoopman plans didn't include any gear plans except the cub style - are the Jenny style plans available seperately? I could probably go from photos and other peoples dimensions / descriptions=2C but plans would be n ice if they're available. Thanks=2C Tom Brant Brooklyn Park=2C MN 80% fuselage=2C tail=2C ribs done=2C 40% Corvair engine - Buying spar mater ial in another two weeks - yeah! ________________________________________________________________________________
Date: Aug 05, 2009
I was heading out to work this morning at about 8 a.m. Pacific and passed Eric and Debbie coming back into town with the Bleriot in tow. I think he had said that he might hangar it at Schellville, where Frank Schelling has his original Curtis Jenny JN-4H. Eric test flew the Jenny and has flown most of the rides in it for Frank. If you come to Northern California be sure to get by Schellville and Sonoma Skypark. Darrel Jones ________________________________________________________________________________
Subject: Re: KZ400 wheels and plans for Jenny style gear
Date: Aug 05, 2009
[quote="tmbrant(at)msn.com"] Also - my Hoopman plans didn't include any gear plans except the cub style - are the Jenny style plans available seperately? I could probably go from photos and other peoples dimensions / descriptions C but plans would be nice if they're available. Thanks C Tom Brant Brooklyn Park C MN 80% fuselage C tail C ribs done C 40% Corvair engine - Buying spar material in another two weeks - yeah! > [b] Tom; I believe the wood/straight axel gear plans are available from the Pietenpol family; these are also detailed in the '32 Flying and Glider manual. Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256281#256281 ________________________________________________________________________________
Date: Aug 05, 2009
What's the axle size? I've got some Yamaha 90 wheels that would be terrific, but the axle is only 1/2". Much too wimpy for MY landings :) -------- NX29NX, C65, Hegy prop, Blue/Cream flying! NX31TM, C85-12, GN-1, 90% done, Red/Cream NX30NX, Corvair, on gear, wings/tail done NX31NX, Hatz CB-1, O-320B, on gear, ribs done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256286#256286 ________________________________________________________________________________
Date: Aug 05, 2009
axle size is 17 MM (5/8") but if you press out the bearings=2C it could be larger. Another thing to consider is the gauge of the spokes - the KZ400 s pokes are pretty heavy. > Subject: Pietenpol-List: Re: KZ400 wheels and plans for Jenny style gear > From: skybachs(at)yahoo.com > Date: Wed=2C 5 Aug 2009 19:40:40 -0700 > To: pietenpol-list(at)matronics.com > > > What's the axle size? > > I've got some Yamaha 90 wheels that would be terrific=2C but the axle is only 1/2". Much too wimpy for MY landings :) > > -------- > NX29NX=2C C65=2C Hegy prop=2C Blue/Cream flying! > NX31TM=2C C85-12=2C GN-1=2C 90% done=2C Red/Cream > NX30NX=2C Corvair=2C on gear=2C wings/tail done > NX31NX=2C Hatz CB-1=2C O-320B=2C on gear=2C ribs done > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256286#256286 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Aug 05, 2009
Speaking of the Jenny.....I've this pic out there before, but why not once more. Here's a shot of the Jenny taxiing back down 9, framed under the wing of Kurt's Piet at Grassroots '08: http://users.rcn.com/ryan.mueller/P1010207.JPG Ryan On Wed, Aug 5, 2009 at 8:37 PM, Darrel Jones wrote: > > I was heading out to work this morning at about 8 a.m. Pacific and passed > Eric and Debbie coming back into town with the Bleriot in tow. I think he > had said that he might hangar it at Schellville, where Frank Schelling has > his original Curtis Jenny JN-4H. Eric test flew the Jenny and has flown most > of the rides in it for Frank. If you come to Northern California be sure to > get by Schellville and Sonoma Skypark. > > Darrel Jones > > ________________________________________________________________________________
Date: Aug 05, 2009
and enjoy the view when you're done Mike, That rual landscape is VERY tempting to go low and buzz all the farm houses you see.- I was tempted to do just that on my way home from OSH on tues morning, but I behaved since I was flying with Don E.- We had a goo d time flying home.- The strangest part was the bitter sweet feeling of l eaving OSH.- I guess because saying so long to a great group of Pieters, and knowing I won't get up to Brodhead for a few years makes it sad, but ge tting the hell out of Plastic Airplane central, where pizza is only 20 buck s a slice, and addmision is only 25 bucks a day....anyways I might go back to OSH in 2019 for the 90th, untill then I will make Brodhead my Mecca.- Fly safe and hope to see Y'all soon.- I am hoping to make MERFI , so any piets that want to, head on in to my place and we will fly over togeather. - Shad=0A=0A=0A ________________________________________________________________________________
Subject: N444MH- Howard Henderson's Piet
Date: Aug 06, 2009
Howdy, low 'n' slow fliers- I had forgotten that we have a very historic, authentic, and nice Air Camper right down here in south Texas... it's 444MH, the beautiful Ford-powered Piet that Howard Henderson built in the 80s and that was in Sport Aviation in 1989. The entire story and pix are still on Grant McLaren's pages, at http://www.grantmaclaren.com/444mh/index.html including a shot of the instrument panel, which is about as simple as they get. The airplane is now owned by Ron Hollmer, who lives down in the Ingleside/Aransas Pass area (near Corpus Christi, TX) and he and his wife Pat were kind enough to send me some recent pix of the airplane. I'll forward those to Chris Tracy for adding to his westcoastpiet treasure-trove. Straight axle gear, wooden gear legs, about as true to the original BHP plans as they get. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 06, 2009
Jeff Boatright wrote: > > Dan, > > Your lift strut welds look similar to mine and those of other Piets that > I've seen. See if Westcoast Piet doesn't have some photos of this > fitment on various planes. > > It's true that your cabane weldments won't allow moving the wing fore or > aft, but do you really want to? It sounds like Tres has flown it with a > variety of loadings and conducted various maneuvers that encompass what > you'd be doing. Did he do a weight and balance and find problems? I > suggest doing a W&B now and at every condition inspection anyway, but do > you know if your Piet currently has a problem? Tres did do a W&B but didn't find anything that needed to be addressed immediately otherwise I'm sure he would have done it. The only reason I'm thinking about addressing the issue is because it does take some forward pressure on the stick to keep it level - the plane does NOT fly hands off when power is applied. With power off it flies nice and level. Again, gap seals on the horizontal should help. > > Along these lines, do you know if Tres put the plane through a complete > stall series with various power settings, loadings, and wing angles (for > instance, up to 20 degrees of turn)? Any spins? Knowing that the plane > is safe for these maneuvers will add confidence to your flying (though > spins may be more than anyone is willing to try if they are not sure > about any of these other maneuvers). Looking at the phase I flight logs, the original builder took the plane to 120mph on 2 occasions and 140mph on another! The first flight I had in it, we did a couple of power off stalls - it mushed right out and mostly straight ahead. It might have dropped a little on the right side, but that could have been due to turbulence (lots of thermals marked by Cu's in the sky). > > I have never seen puckering on wing fabric like that. I would be very > cautious about conducting any of these maneuvers (stalls, spins, etc.) > unless you know that they have been completed before with that puckering > and that nothing dramatic occurs. Seems to me, as suggested by Bill, > that the puckering creates a whole new airfoil. Also, as Bill suggested, > it is certainly possible to shrink the fabric if the problem was that it > wasn't shrunk correctly at installation. Sherwin Wms comes right off if > you apply strong masking tape - it's a feature, not a bug... The puckering is behind the rear spar so the puckers might even help keep the air attached to the wing! ;-) Thanks for the feedback, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 06, 2009
Bill Budgell wrote: > Unless you have broken or rotted wood in your wings. then that is just a > bad covering job. the fabric has not been shrunk enough to the proper > tempature. reshrink it or take it offf and recover the wing. Nope, no ribs are broken, luckily. And now that you say it, it makes perfect sense that the correct amount of heat wasn't applied. Can that be fixed this many years and 2 coats of top coat/paint later? Maybe I'll just ignore it for the time being - it's flown 9,000+ miles in the last 18 months, and 3,200 of those in the past 2 weeks! Thanks, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 06, 2009
Hi Rob, skybachs wrote: > > If they re-stitched the wing, then the buckling fabric is a simple side-affect. I would undo/redo those stitches...maybe a touch of heat from a heatgun while the stitches were out would help as well. > > Static port: if you move the static port to the back of the panel by removing the static line and plugging, the low pressure in the cockpit area will give you false readings. Try lowering the pitot/static tube to create more room from the bottom of the wing. I put a bushing in front of my static port with a set screw so I could slide it fore and aft from the static port until I got accurate readings. > It's even worse than that - the static port line was cut *inside* the wing so it should just be moved somewhere on the fuselage. Tres did a full Vx, Vy, max L/D, min sink analysis on the plane for a school paper and it shows that the airspeed indicated on the ASI is off, but the difference is linear over the flight envelope. For the time being I'll use his numbers to get the feel for the plane, and put a new static port on the side sometime in the future. > Warped stab can be tweaked with cable adjustments of course, but a warped elevator is a cosmetic problem. Adding another hinge (or heck, a piano hinge full span) might help....and you'd get your gap seal to boot. > Where the horizontal stab/elevator hinge, it's straight. The TE of the elevator is warped end-to-end. Kind of strange... > Don't sweat the cabanes: all your wb adjustments will be with weight added/subtracted around the plane. > > If she's flying nose heavy or light but the wb is good, there are plenty of things to adjust in the rigging and spring/bungees to add to the bellcrank or the stick itself to help it trim out. > > If I had known you were flying by, I would've invited you to stop by the Piet Factory (or Brassroots as they're calling it) and done a once-over. > BUU isn't very far from LL53. When I can drop by? ;-) > Rob > > -------- > NX29NX, C65, Hegy prop, Blue/Cream flying! 90mph on a A-65 on a Piet? Was there a tailwind on the day you flew home from OSH? > NX31TM, C85-12, GN-1, 90% done, Red/Cream > NX30NX, Corvair, on gear, wings/tail done > NX31NX, Hatz CB-1, O-320B, on gear, ribs done Clearly you have too much time your hands. Here, let me lend you a couple of twin 2 year olds... Cheers, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 06, 2009
Subject: flying low over farm fields
Great fun that is Shad. I learned my lesson though to scope out for wires , but good, about 10 years ago when I came around a stand of trees over fla t farmland and came upon high tension wires-fortunately the wires were abou t 2,000 feet ahead of me so I had plenty of time to divert. I was down lo w chasing a friend in his Cub ala the Kessler/Pepper scenes in The Great Wa ldo Pepper. (but not with near the theatrics or engine noises) Great fun but you really have to know the field (s) well. ________________________________________________________________________________
Date: Aug 06, 2009
Subject: Lee Bottom/ Hanover, Indiana / Grassroots 2009
Hmmm..if you RV-4 up there Jack I'd drive up unless it conflicts with the same weekend as Ginger and Rich Davidson's Lee Bottom Flying Field gathering--which was amazing last year. Loved it. More: http://www.leebottom.com/ ________________________________________________________________________________
Date: Aug 06, 2009
Yes...I'm the third greatest pilot in the world behind Kessler and Waldo Pe pper:) Yeah, right !!! I actually lost a good dogfight to a 73 year old guy by the name of Bob Whi te flying his Cub on my tail. I seriously could not shake Bob so I smoked him-and looked back, he' s weaving and going all over the place because he couldn't see squat in the smoke-he was that c lose to me. Great fun but I was humbled-he was a good stick ! Tell us how you fought the black and yellow German...... Ernst Kessler..... .. you fought Ernst Kessler? ________________________________________________________________________________
Date: Aug 06, 2009
Subject: Watch Bleriot XI Replica
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Aug 06, 2009
folks in Wichata gave 10.. 20 dollars to see a crash like this Oh-you saw some of my landings did you ? :) ________________________________________________________________________________
Date: Aug 06, 2009
Subject: Watch Elvis in Action
Subject: Re: flying low over farm fields
Date: Aug 06, 2009
It's reassuring that people here quote Waldo Pepper.... - Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256393#256393 ________________________________________________________________________________
Date: Aug 06, 2009
They're good People Andrew ! >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol- >list-server(at)matronics.com] On Behalf Of Baldeagle >Sent: Thursday, August 06, 2009 4:08 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: flying low over farm fields > > > >It's reassuring that people here quote Waldo Pepper.... > > >- > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=256393#256393 > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Aug 06, 2009
Subject: great EAA photo of Ken Perkins
WOW-I finally found ONE photo of a Pietenpol in the EAA photo galleries. P erhaps there are more but even in the Sunday arrival video they show FACTOR Y builts landing-Bonanzas, Mooneys, Cessnas. Pathetic. Mike C. ________________________________________________________________________________
Date: Aug 06, 2009
There was also a nice shot that I found in the gallery: Jack Phillips _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Thursday, August 06, 2009 4:30 PM Subject: Pietenpol-List: great EAA photo of Ken Perkins WOW-I finally found ONE photo of a Pietenpol in the EAA photo galleries. Perhaps there are more but even in the Sunday arrival video they show FACTORY builts landing-Bonanzas, Mooneys, Cessnas. Pathetic. Mike C. ________________________________________________________________________________
Date: Aug 06, 2009
Whatcha doin' in California Newt ? New guy.....Brown. Well I'll get him when he gets down. ________________________________________________________________________________
Date: Aug 06, 2009
"I still am cute" No archive ________________________________________________________________________________
Date: Aug 06, 2009
Mikee- We lived nearly 10 years in Medford, Oregon- which is next door to Central Point, home of Erickson Aircrane and the Sikorski conversions in the video. They fly all over the world doing firefighting, selective logging, rescue, heavy lifting and placement, and other specialized tasks. Very interesting but remote connection to experimental aviation is that while I was still living in Oregon, Jack Erickson also located and restored a P-38 Lightning to complete and authentic flying condition and I got to see one of the test flights. I believe the airplane is in the Tillamook Air Museum, http://www.warbirdregistry.org/p38registry/p38-4427083.html Tillamook is about 60 miles from McMinnville, where the one and only Hughes HK-1 "Spruce Goose" is now located. Since the Spruce Goose has wooden structural components, I have now connected this topic with the Pietenpol Air Camper and made the post relevant ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: WP
Date: Aug 06, 2009
"The last time I went flying with you all I saw was the inside of a paper sac" ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Subject: Re: great EAA photo of Ken Perkins
Date: Aug 06, 2009
Is there an organization for those of us who still enjoy the more traditional aspects of aviation? What the EAA was all about in the fifties, sixties, and seventies? I thought I had heard that Paul Poberezny had started a grassroots organization a few yeas back, but I can't recall the details. Does anyone know of such a group? Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com Sent from the phone that made the Blackberry obsolete. On Aug 6, 2009, at 4:30 PM, "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" wrote: > WOW=94I finally found ONE photo of a Pietenpol in the EAA photo galler > ies. Perhaps there are more but even in the Sunday arrival video th > ey show FACTORY builts landing=94Bonanzas, Mooneys, Cessnas. Patheti > c. > > Mike C. > > > > ________________________________________________________________________________
Date: Aug 06, 2009
Paul had started the Sport Aviation Association but it is now defunct. If you are looking for something similar to the good old days look no further than the BPA........ Greg Cardinal SAA #1468 ----- Original Message ----- From: Wayne Bressler To: pietenpol-list(at)matronics.com Sent: Thursday, August 06, 2009 5:54 PM Subject: Re: Pietenpol-List: great EAA photo of Ken Perkins Is there an organization for those of us who still enjoy the more traditional aspects of aviation? What the EAA was all about in the fifties, sixties, and seventies? I thought I had heard that Paul Poberezny had started a grassroots organization a few yeas back, but I can't recall the details. Does anyone know of such a group? Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com Sent from the phone that made the Blackberry obsolete. On Aug 6, 2009, at 4:30 PM, "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" wrote: WOW=94I finally found ONE photo of a Pietenpol in the EAA photo galleries. Perhaps there are more but even in the Sunday arrival video they show FACTORY builts landing=94Bonanzas, Mooneys, Cessnas. Pathetic. Mike C. ________________________________________________________________________________
Date: Aug 06, 2009
Lowell, As I recall the ATIS for 36L "340 at 19 gusting to 24". What happened to you could have happened to any one of us. Skip > Mike, the 360's landing was much better than mine, FAA wanted to know how many hours I had in class, told them, (her ) 2000 plus, end of conversation, You Piet Captains did a good job. > Pieti Lowell ________________________________________________________________________________
Date: Aug 06, 2009
Speaking of Ken, I missed an absolutely perfect shot of him polishing the Ford emblem on his engine by seconds. This was the best I could do: http://users.rcn.com/ryan.mueller/IMG_0392.JPG Ryan P.S.: Thanks for the pic Mike. A nice shot... On Thu, Aug 6, 2009 at 3:30 PM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > WOW=97I finally found ONE photo of a Pietenpol in the EAA photo gallerie s. > Perhaps there are more but even in the Sunday arrival video they show > FACTORY builts landing=97Bonanzas, Mooneys, Cessnas. Pathetic. > > Mike C. > ________________________________________________________________________________
Date: Aug 06, 2009
Come on up any time. Bring your elevators if you want to learn how to recover and we'll see if we can get them straight. Putting the static port in the propwash never works real well with the Piets. I'd be happy to help you re-route the static line to it's proper spot. There's always room in the shop for another Piet! Drop me an e-mail if you'd like to come up, by Piet or car, it's not that far. [Wink] Rob -------- NX29NX, C65, Hegy prop, Blue/Cream flying! NX31TM, C85-12, GN-1, 90% done, Red/Cream NX30NX, Corvair, on gear, wings/tail done NX31NX, Hatz CB-1, O-320B, on gear, ribs done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256457#256457 ________________________________________________________________________________
Date: Aug 06, 2009
Favorite line at the Miracle Aircraft Company shop-full-o-Piets: "A monoplane. Are you telling me you're building me an airplane with only one wing?" "Just thought you'd like to know: the biplane's gone the way of the Dodo. " -------- NX29NX, C65, Hegy prop, Blue/Cream flying! NX31TM, C85-12, GN-1, 90% done, Red/Cream NX30NX, Corvair, on gear, wings/tail done NX31NX, Hatz CB-1, O-320B, on gear, ribs done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256458#256458 ________________________________________________________________________________
Date: Aug 07, 2009
weren't you scared? don't be dumb ________________________________________________________________________________
Subject: wing question
Date: Aug 07, 2009
Hi all How much do I curve the wing tip bow? Is it to the same curve as the top of the rib? Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256480#256480 ________________________________________________________________________________
Date: Aug 07, 2009
Carson, I followed a line which was half of the height of the wing rib. Check out http://www.cpc-world.com/images/IMG_0605_JPG.jpg It seemed to work out alright. Cheers Peter Wonthaggi Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of carson Sent: Friday, 7 August 2009 10:47 PM Subject: Pietenpol-List: wing question Hi all How much do I curve the wing tip bow? Is it to the same curve as the top of the rib? Carson ________________________________________________________________________________
Date: Aug 07, 2009
Subject: landing at Oshkosh on Sunday
Skip is 100% right-- that incident could have happened to anyone of us Lowell. Mother Nature was rough that morning with those gusty conditions. Just a matter of timing in the flare if you're dealt a lull between gusts or you get slammed. There are some days when landing a Pietenpol in gusty conditions should qualify one to be certified to ride bulls. Wednesday during the Homebuilt Review Showcase (where they shafted one of our three Pietenpol guys--Jack Phillips by cutting one of the Piets out of the event) the Rotec powered Junior Ace from Poplar Grove nearly lost it in similar wind conditions when landing. Three times he nearly had his wing tips in the turf--scary stuff but he managed to add power, continue down the runway and get a second chance. I was astonished at the ineptitude of the EAA/FAA/and law enforcement people who kept Lowell and his plane out on the runway for well over an hour. First off---Lowell's well being, once that was established to not be an issue they should have cleared off and talked with him elsewhere if they needed to. I should know better--if the gov't is involved they will take the least practical path to a conclusion. Mike C. ________________________________________________________________________________
Date: Aug 07, 2009
I did just what Peter did. Just make it the midpoint of the height between the capstrips at each point along the airfoil. In other words, make the wingtip follow the camber line of the airfoil. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Peter W Johnson Sent: Friday, August 07, 2009 9:04 AM Subject: RE: Pietenpol-List: wing question Carson, I followed a line which was half of the height of the wing rib. Check out http://www.cpc-world.com/images/IMG_0605_JPG.jpg It seemed to work out alright. Cheers Peter Wonthaggi Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of carson Sent: Friday, 7 August 2009 10:47 PM Subject: Pietenpol-List: wing question Hi all How much do I curve the wing tip bow? Is it to the same curve as the top of the rib? Carson ________________________________________________________________________________
Date: Aug 07, 2009
Subject: 1st time at Oshkosh: Randy Bush by his Corvair-powered
NX294RB There were several other first-timers in our group to Oshkosh like Skip Gad d and perhaps Rob Bach, Mike Madrid-but didn't keep track very well. It was a pleasure to see Randy Bush in Wisconsin with his dream come true. Great stuff. Mike C. PS-have you used your 2009 glass mug yet Randy ? ________________________________________________________________________________
NX294RB
Date: Aug 07, 2009
I've had a good time following Randy's progress with his Pietenpol. Randy is from my hometown (Jackson, Tennessee) and my mother has sent me newspaper clippings through the years about Randy's Pietenpol project. What I didn't know until recently was that Randy's mother (a Nurse) used to work for my father (who was a physician). I met Randy's mom at Brodhead and enjoyed talking with her. Small world! Nice job, Randy, and another good-looking Pietenpol added to the field at Brodhead. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Friday, August 07, 2009 9:46 AM Subject: Pietenpol-List: 1st time at Oshkosh: Randy Bush by his Corvair-powered NX294RB There were several other first-timers in our group to Oshkosh like Skip Gadd and perhaps Rob Bach, Mike Madrid-but didn't keep track very well. It was a pleasure to see Randy Bush in Wisconsin with his dream come true. Great stuff. Mike C. PS-have you used your 2009 glass mug yet Randy ? ________________________________________________________________________________
Date: Aug 07, 2009
Subject: Re: landing at Oshkosh on Sunday
You're looking at an airline pilot son ________________________________________________________________________________
Date: Aug 07, 2009
Subject: side door cut out for front seat
I was surfing the net the other night during down time at work (don't tell my boss) and came across a video of a young gentleman trying to climb into the front seat.- It did not look easy.- Maybe I just missed it, but I d on't recall seeing any Piets with a door cut out to make things easier.- Has any one had luck with this?- If so, what additional bracing is needed ?- How about steel fuseluges, are they more forgiving of such mods?- Al so, sorry I forgot which one it was, but one of the beautiful Corvair power ed Piets had tabs on the bottom longeron, aft of the pilot seat... float at tachments?- Just a guess. - Matt -=0A=0A=0A ________________________________________________________________________________
Date: Aug 07, 2009
Matt, Gary Price developed a door mod for the front seat some years ago, but few Piets use it. Basically, anyone too large to be able to climb into the front cockpit of a Piet is probably too heavy to carry anyway. Any door mod requires cutting the upper longeron and that is simply not a good idea, particularly in the area between the cabane struts (and the landing gear/lift strut fittings). Substantial beefing up of the remaining structure attempts to restore some of the strength lost by cutting the longeron, and succeeds in adding substantial weight. I'm 6'2" and 200 lbs and I can make it into the front 'pit of my Piet with little trouble. My wife does it all the time. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Matt Keyes Sent: Friday, August 07, 2009 4:17 PM Subject: Pietenpol-List: side door cut out for front seat I was surfing the net the other night during down time at work (don't tell my boss) and came across a video of a young gentleman trying to climb into the front seat. It did not look easy. Maybe I just missed it, but I don't recall seeing any Piets with a door cut out to make things easier. Has any one had luck with this? If so, what additional bracing is needed? How about steel fuseluges, are they more forgiving of such mods? Also, sorry I forgot which one it was, but one of the beautiful Corvair powered Piets had tabs on the bottom longeron, aft of the pilot seat... float attachments? Just a guess. Matt ________________________________________________________________________________
Date: Aug 07, 2009
skybachs wrote: > > Come on up any time. Bring your elevators if you want to learn how to recover and we'll see if we can get them straight. Elevators will be a winter project, so in a few months when it starts getting cold. > Putting the static port in the propwash never works real well with the Piets. I'd be happy to help you re-route the static line to it's proper spot. There's always room in the shop for another Piet! Yeah, I gotta stop thinking like a glider pilot and remember that there's a big windmill up in front. > > Drop me an e-mail if you'd like to come up, by Piet or car, it's not that far. [Wink] This weekend is out - I'm on kid duty - but maybe next weekend Stefano and I will fly up. I'll drop you a line a couple days ahead of time to see if you'll be around. Thanks! Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 07, 2009
Kurt Shipman's Piet (Lindy Award winner, Osh "09!) has tabs for floats. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Matt Keyes Sent: Friday, August 07, 2009 1:17 PM Subject: Pietenpol-List: side door cut out for front seat I was surfing the net the other night during down time at work (don't tell my boss) and came across a video of a young gentleman trying to climb into the front seat. It did not look easy. Maybe I just missed it, but I don't recall seeing any Piets with a door cut out to make things easier. Has any one had luck with this? If so, what additional bracing is needed? How about steel fuseluges, are they more forgiving of such mods? Also, sorry I forgot which one it was, but one of the beautiful Corvair powered Piets had tabs on the bottom longeron, aft of the pilot seat... float attachments? Just a guess. Matt ________________________________________________________________________________
Subject: Re: side door cut out for front seat
Date: Aug 07, 2009
Jack, You better re-read the last line=C2-of your=C2-previous post before yo ur wife=C2-sees it :O) -----Original Message----- From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Fri, Aug 7, 2009 3:33 pm Subject: RE: Pietenpol-List: side door cut out for front seat Matt, =C2- Gary Price developed a door mod for the front seat some years ago, but few Piets use it.=C2- Basically, anyone too large to be able to climb into the front cockpit of a Piet is probably too heavy to carry anyway.=C2- Any door mod requires cutting the upper longeron and that is simply not a good idea, particularly in the area between the cabane struts (and the landing gear/lift strut fittings).=C2- Substantial beefing up of the re maining structure attempts to restore some of the strength lost by cutting the longeron, and succeeds in adding substantial weight. =C2- I=99m 6=992=9D and 200 lbs and I can make it into the fr ont =98pit of my Piet with little trouble.=C2- My wife does it all the time. =C2- Jack Phillips NX899JP Raleigh, NC =C2- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Matt Keyes Sent: Friday, August 07, 2009 4:17 PM Subject: Pietenpol-List: side door cut out for front seat =C2- I was surfing the net the other night during down time at work (don't tell my boss) and came across a video of a young gentleman trying to climb in to the front seat.=C2- It did not look easy.=C2- Maybe I just missed it, but I don't recall seeing any Piets with a door cut out to make thing s easier.=C2- Has any one had luck with this?=C2- If so, what addition al bracing is needed?=C2- How about steel fuseluges, are they more forgi ving of such mods?=C2- Also, sorry I forgot which one it was, but one of the beautiful Corvair powered Piets had tabs on the bottom longeron, aft of the pilot seat... float attachments?=C2- Just a guess. =C2- Matt =C2- =C2- =C2- =C2- http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution =C2- ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -========= ======================== ======================== = -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Aug 07, 2009
Yeah, wow, she's 6'2"...? ;-) Matt At 02:33 PM 8/7/2009 Friday, you wrote: >Jack, > >You better re-read the last line of your previous post before your wife sees it :O) > > >-----Original Message----- >From: Jack Phillips <pietflyr(at)bellsouth.net> >To: pietenpol-list(at)matronics.com >Sent: Fri, Aug 7, 2009 3:33 pm >Subject: RE: Pietenpol-List: side door cut out for front seat > >Matt, > >Gary Price developed a door mod for the front seat some years ago, but few Piets use it. Basically, anyone too large to be able to climb into the front cockpit of a Piet is probably too heavy to carry anyway. Any door mod requires cutting the upper longeron and that is simply not a good idea, particularly in the area between the cabane struts (and the landing gear/lift strut fittings). Substantial beefing up of the remaining structure attempts to restore some of the strength lost by cutting the longeron, and succeeds in adding substantial weight. > >I'm 6'2" and 200 lbs and I can make it into the front cockpit of my Piet with little trouble. My wife does it all the time. > >Jack Phillips >NX899JP >Raleigh, NC > > >---------- >From: <mailto:owner-pietenpol-list-server(at)matronics.com>owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Matt Keyes >Sent: Friday, August 07, 2009 4:17 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: side door cut out for front seat > >I was surfing the net the other night during down time at work (don't tell my boss) and came across a video of a young gentleman trying to climb into the front seat. It did not look easy. Maybe I just missed it, but I don't recall seeing any Piets with a door cut out to make things easier. Has any one had luck with this? If so, what additional bracing is needed? How about steel fuseluges, are they more forgiving of such mods? Also, sorry I forgot which one it was, but one of the beautiful Corvair powered Piets had tabs on the bottom longeron, aft of the pilot seat... float attachments? Just a guess. > >Matt > > > > > > > > ><http://www.matronics.com/Navigator?Pietenpol-List>http://www.matronics.com/Navigator?Pietenpol-List > > >http://forums.matronics.com > > ><http://www.matronics.com/contribution>http://www.matronics.com/contribution > > > >=================================== >t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List >=================================== >tp://forums.matronics.com >=================================== >_blank>http://www.matronics.com/contribution >=================================== > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Aug 07, 2009
My Piet has a door. the fuselage and tail feathers are all welded tubing and the cut-out is reinforced and yes it makes it a lot easier to get in. You cn see numerous pics of my Piet on the Westcoast piet site in it is NX20795. Look under the name Roman Bukolt. On Aug 7, 2009, at 3:16 PM, Matt Keyes wrote: > I was surfing the net the other night during down time at work > (don't tell my boss) and came across a video of a young gentleman > trying to climb into the front seat. It did not look easy. Maybe I > just missed it, but I don't recall seeing any Piets with a door cut > out to make things easier. Has any one had luck with this? If so, > what additional bracing is needed? How about steel fuseluges, are > they more forgiving of such mods? Also, sorry I forgot which one it > was, but one of the beautiful Corvair powered Piets had tabs on the > bottom longeron, aft of the pilot seat... float attachments? Just a > guess. > > Matt > > ________________________________________________________________________________
Date: Aug 07, 2009
Subject: Shipman's fuselage tabs
In speaking with Kurtat Brodhead I believe he indicated those tabs were for snow skis-- the bungee that holds the rear tips of the skis. ________________________________________________________________________________
Date: Aug 07, 2009
You fellows ,I don't think you know the half of it, I got a registered letter late Friday , dated Thursday, saying that I have 10 days from the letter's date to respond to FAA regarding practically redoing my complete Private License Tests learning over, from getting a tail dragger to be retested , check ride , Area operations III,, IV etc, Where does one begin ? so far dozens of phone calls just to find an Instructor with a conventional gear plane, and when asked if it would be OK to take my check-ride in a Pietenpol HA only certified craft with ALL paper work on the plane complete. and it goes on and on. Still no airplanes yet available and I don't blame anyone to get involved , what a hassle and with over 2000 tail dragger hours. Pieti Lowell Wednesday during the Homebuilt Review Showcase (where they shafted one of our three Pietenpol guys--Jack Phillips by cutting one of the Piets out of the event) the Rotec powered Junior Ace from Poplar Grove nearly lost it in similar wind conditions when landing. Three times he nearly had his wing tips in the turf--scary stuff but he managed to add power, continue down the runway and get a second chance. I was astonished at the ineptitude of the EAA/FAA/and law enforcement people who kept Lowell and his plane out on the runway for well over an hour. First off---Lowell's well being, once that was established to not be an issue they should have cleared off and talked with him elsewhere if they needed to. I should know better--if the gov't is involved they will take the least practical path to a conclusion. Mike C.[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256592#256592 ________________________________________________________________________________
Date: Aug 07, 2009
Pieti, I have my Piet for sale and I't will be gone by next weekend, but I would be happy to help you out as in getting you reinstated, and the tail dragger endorsment. I'm a CFII with lots of tail dragger time also, I'm sure you can teach me a couple of things. Please fell free to e-mail me or call chethartley1(at)mchsi.com 573-645-0534 Brent Scott and I know each other and I live only a few miles from him. Chet ________________________________________________________________________________
Date: Aug 07, 2009
Lowell, Have you told EAA about this? If this is the treatment you get, why should anyone fly into Oshkosh, particulalry anyone with a taildragger? Jeff > >You fellows ,I don't think you know the half of it, I got a >registered letter late Friday , dated Thursday, saying that I have >10 days from the letter's date to respond to FAA regarding >practically redoing my complete Private License Tests learning over, >from getting a tail dragger to be retested , check ride , Area >operations III,, IV etc, Where does one begin ? so far dozens of >phone calls just to find an Instructor with a conventional gear >plane, and when asked if it would be OK to take my check-ride in a >Pietenpol HA only certified craft with ALL paper work on the plane >complete. and it goes on and on. Still no airplanes yet available >and I don't blame anyone to get involved , what a hassle and with >over 2000 tail dragger hours. >Pieti Lowell -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Aug 07, 2009
I thought this kind of thing is what your AOPA is for. Clif > Lowell, > > Have you told EAA about this? If this is the treatment you get, why > should anyone fly into Oshkosh, particulalry anyone with a > taildragger? > > Jeff >> >>You fellows ,I don't think you know the half of it, I got a >>registered letter late Friday , dated Thursday, saying that I have >>10 days from the letter's date to respond to FAA regarding >>practically redoing my complete Private License Tests learning over, ________________________________________________________________________________
Date: Aug 08, 2009
Lowell, I've been through what you are going through, and I must say that it is can be an unpleasant experience. You aren't by chance enrolled in the AOPA legal services plan, are you? I found first-hand that FAA inspectors can try to overstep their power and duties quite regularly. Having someone to ask "can they ask me that" made it much easier for me. It is a privilege that they have to re-evaluate any airman, at the airman's expense. It stinks, but you'll have to take it seriously! If they don't give you a satisfactory result to the checkride, you won't be able to fly anymore. Respond before the deadline, and keep in mind that you don't have to take the checkride within 10 days, you just have to respond. In my case, it was actually a month or two after the accident before the re-evaluation ride. Also note that you aren't obliged to answer questions about the past. The FAA inspectors know that they don't have the privilege of interrogating you to try and get evidence for a violation. In my case they were trying to use the reevaluation ride as a chance to do just that. I spent a couple of hours dodging questions about the accident flight and requesting that the inspector stick to general questions about my qualifications to hold my certificate. It was a diplomatic tightrope to say the least. I hope that you end up with a good FSDO and inspector, and that your experience was better than mine. Let them know that you are going to have trouble finding a tailwheel airplane to rent, and that should buy you some time. You might also consider hiring a specialized aviation lawyer if you are not in the legal services plan, depending on how important it is to you that you continue to hold your certificate. You can also find the inspector's handbook online and read about what the boundries are for the checkride, as far as what they should and shouldn't be asking you about. >From this point on, take notes about who you talk to at the FAA/NTSB, including the date and time, and a brief summary of the discussion. In my case my file fell between the cracks on their end, and they tried to accuse me of avoiding the checkride, when they had actually not been returning my phone calls. This is the kind of thing you might be up against! The folks at both the NTSB and the FAA are not your friend. As for the rest of you, think seriously about that legal services plan! As some have said, this type of thing can happen to any of us. Hang in there! You can do this, but be smart about it. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Pieti Lowell Sent: Friday, August 07, 2009 10:02 PM Subject: Pietenpol-List: Re: landing at Oshkosh on Sunday You fellows ,I don't think you know the half of it, I got a registered letter late Friday , dated Thursday, saying that I have 10 days from the letter's date to respond to FAA regarding practically redoing my complete Private License Tests learning over, from getting a tail dragger to be retested , check ride , Area operations III,, IV etc, Where does one begin ? so far dozens of phone calls just to find an Instructor with a conventional gear plane, and when asked if it would be OK to take my check-ride in a Pietenpol HA only certified craft with ALL paper work on the plane complete. and it goes on and on. Still no airplanes yet available and I don't blame anyone to get involved , what a hassle and with over 2000 tail dragger hours. Pieti Lowell Wednesday during the Homebuilt Review Showcase (where they shafted one of our three Pietenpol guys--Jack Phillips by cutting one of the Piets out of the event) the Rotec powered Junior Ace from Poplar Grove nearly lost it in similar wind conditions when landing. Three times he nearly had his wing tips in the turf--scary stuff but he managed to add power, continue down the runway and get a second chance. I was astonished at the ineptitude of the EAA/FAA/and law enforcement people who kept Lowell and his plane out on the runway for well over an hour. First off---Lowell's well being, once that was established to not be an issue they should have cleared off and talked with him elsewhere if they needed to. I should know better--if the gov't is involved they will take the least practical path to a conclusion. Mike C.[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256592#256592 ________________________________________________________________________________
Date: Aug 08, 2009
jim you need any help a voice from the past tom ________________________________________________________________________________
Date: Aug 08, 2009
She's not 6'2", but she's not 5'2" either . Karen is about 5' 9" tall. She doesn't seem to have any problem climbing into the front seat. Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, August 07, 2009 7:46 PM Subject: Re: Pietenpol-List: side door cut out for front seat Yeah, wow, she's 6'2"...? ;-) Matt At 02:33 PM 8/7/2009 Friday, you wrote: >Jack, > >You better re-read the last line of your previous post before your wife sees it :O) > > >-----Original Message----- >From: Jack Phillips <pietflyr(at)bellsouth.net> >To: pietenpol-list(at)matronics.com >Sent: Fri, Aug 7, 2009 3:33 pm >Subject: RE: Pietenpol-List: side door cut out for front seat > >Matt, > >Gary Price developed a door mod for the front seat some years ago, but few Piets use it. Basically, anyone too large to be able to climb into the front cockpit of a Piet is probably too heavy to carry anyway. Any door mod requires cutting the upper longeron and that is simply not a good idea, particularly in the area between the cabane struts (and the landing gear/lift strut fittings). Substantial beefing up of the remaining structure attempts to restore some of the strength lost by cutting the longeron, and succeeds in adding substantial weight. > >I'm 6'2" and 200 lbs and I can make it into the front cockpit of my Piet with little trouble. My wife does it all the time. > >Jack Phillips >NX899JP >Raleigh, NC > > >---------- >From: owner-pietenpol-list-serve r(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Matt Keyes >Sent: Friday, August 07, 2009 4:17 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: side door cut out for front seat > >I was surfing the net the other night during down time at work (don't tell my boss) and came across a video of a young gentleman trying to climb into the front seat. It did not look easy. Maybe I just missed it, but I don't recall seeing any Piets with a door cut out to make things easier. Has any one had luck with this? If so, what additional bracing is needed? How about steel fuseluges, are they more forgiving of such mods? Also, sorry I forgot which one it was, but one of the beautiful Corvair powered Piets had tabs on the bottom longeron, aft of the pilot seat... float attachments? Just a guess. > >Matt > > > > > > > > ><http://www.matronics.com/Navigator?Pietenpol-List>http://www.matronics.com /Navigator?Pietenpol-List > > >http://forums.matronics.com > > ><http://www.matronics.com/contribution>http://www.matronics.com/contributio n > > > >=================================== >t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List >=================================== >tp://forums.matronics.com >=================================== >_blank>http://www.matronics.com/contribution >=================================== > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: viewing the posts
Date: Aug 08, 2009
is it just me or are others having trouble seeing the posts? some seem to be so wide I have to scroll way to the right to read all of a message and see the rest of the picture. is there a way to correct that or is it just because the large picture size causes it to run out? as you see I'm not computer literate.but have sure enjoyed the fine pictures and got some good ideas for how to enclose my cowl. I have finally gotten my air scoops done and ready to start that next. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256628#256628 ________________________________________________________________________________
Subject: Re: wing question
Date: Aug 08, 2009
I did the same thing as Peter. looks good.--Jim Lagowski ----- Original Message ----- From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> Sent: Friday, August 07, 2009 9:04 AM Subject: RE: Pietenpol-List: wing question > > > Carson, > > I followed a line which was half of the height of the wing rib. Check out > http://www.cpc-world.com/images/IMG_0605_JPG.jpg > > It seemed to work out alright. > > Cheers > > Peter > Wonthaggi Australia > http://www.cpc-world.com > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of carson > Sent: Friday, 7 August 2009 10:47 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: wing question > > > Hi all > How much do I curve the wing tip bow? > Is it to the same curve as the top of the rib? > Carson > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 06:22:00 ________________________________________________________________________________
Date: Aug 08, 2009
Subject: landing at Oshkosh on Sunday & Kurt's attach points
Lowell-- I thought somewhere in the front of Sport Aviation they have a legal advocacy group department that can help you thru such things as the FAA is trying to put you thru. My apologies for posting incorrect info about Kurt Shipman's Piet fittings-- they are in fact for floats. Mike C. ________________________________________________________________________________
Date: Aug 08, 2009
Subject: Re: viewing the posts
I also open some of these messages and have to scroll for some and not for others. I did a bit of reconfiguring on my email client (what I use to open/view emails) and the scrolling seems to have gone away....maybe you need to tweak the program setup a little....I don't know, but it's worth a try... And I agree, the pictures are great and I still marvel at what fantastic ideas show up here...except that sometimes I have to go change something that's already built because of a "new" way of doing something shows up in a picture....I've finally stopped that though and have decided to finish "as is" and modify later.... It will probably be a little over 100 degrees in NE Oklahoma today....I'll definitely need to open the doors and turn on the big fan! Trammeling wings and finishing lift strut fittings today.....JM -----Original Message----- >From: skellytown flyer <rhano(at)att.net> >Sent: Aug 8, 2009 7:45 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: viewing the posts > > >is it just me or are others having trouble seeing the posts? some seem to be so wide I have to scroll way to the right to read all of a message and see the rest of the picture. is there a way to correct that or is it just because the large picture size causes it to run out? as you see I'm not computer literate.but have sure enjoyed the fine pictures and got some good ideas for how to enclose my cowl. I have finally gotten my air scoops done and ready to start that next. Raymond > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=256628#256628 > > ________________________________________________________________________________
Subject: Re: landing at Oshkosh on Sunday & Kurt's attach points
Date: Aug 08, 2009
Thanks Mike, I am getting good support on this one, I will keep all posted,, as I know others might be in the same position. Pieti Lowell . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256645#256645 ________________________________________________________________________________
Date: Aug 08, 2009
Subject: 10 years ago, 1999: 70th Anniversary of the Pietenpol
Air Camper I know I've posted this before but Lowell Frank and Bill Rewey were with us when we flew SEVENTEEN Pietenpols from Hartford, WI into Oshkosh on Runway 18L. (the taxiway turned runway for the event) There was a southwest crosswind and a DC-3 tookoff from 18R and his propwash upset on of our group upon landing, damaging his airplane. I can't think of the gents name off hand but he was from MO. I don't recall the hubbub that ensued but know he ended up having to trailer his plane home. Something like this where they will dog a guy who is totally competent to belittle him to get some dual and a sign off in tailwheels after thousands of hours (in type even) is irritating when you KNOW that there are all kinds of accidents that go unreported--some I've seen at my home base where the airplane is quietly put away in the hangar. Some of those accidents should be investigated though because of incompetency or poor maintenance but the FAA can't differentiate I guess and have to put everyone thru the meat grinder if it be a whoopsie or your medical getting reinstated. Years ago a pair of guys from a nearby grass airport went up to the Lake Erie Islands, bought a case of wine and flew it back--drinking all the way. They overshot the runway in the Cessna Cardinal and went across a road, shearing off both wings between two trees. They got the airport Ford 8N out, dragged the mess back to the hangar and locked the doors. Those are the kinds of guys who need some wrist slaps. ________________________________________________________________________________
Date: Aug 08, 2009
Hi Lowell I was just ahead of you, landing at the same time and it could have just as easily been me on the side of the runway. I caught the same gust and thought I had broke a bungee as my wing tip was way down and I had every bit of rudder and aileron stuffed in to hold the wing down. Good luck with the feds. I still have your strobe. If you would send me your address off list, I'll mail it back. Dick N. horzpool(at)goldengate.net ----- Original Message ----- From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> Sent: Saturday, August 08, 2009 9:56 AM Subject: Pietenpol-List: Re: landing at Oshkosh on Sunday & Kurt's attach points > > > Thanks Mike, > I am getting good support on this one, I will keep all posted,, as I know > others might be in the same position. > Pieti Lowell > . > > . > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256645#256645 > > > ________________________________________________________________________________
Date: Aug 08, 2009
To door, or not to door... that is the question. Corky already had a well reinforced door cutout on his second Piet-- my current project. (Oscar's Piet was his first.) I am keeping the cutout and have fabbed a door. Concerned about hard landings and stress points right there, I added one more diagonal brace, as well. As Jack rightly says, no doubt you lose strength cutting the top longeron. You gain weight trying to get enough strength, not all of it, back. Those are good reasons not to do it. However, many of my likely future passengers, like myself, just don't bend that well anymore. For instance, my wife is only 5' 3" and under 100 pounds, but she is no longer flexible. [As an aside, I doubt, despite my best intentions, that she will ever fly in it. She doesn't like first class in a 747. Her loss. I am still hopeful.] I became somewhat convinced the door could be a good idea when my neighbor my same age, 67, at 6 feet and in good shape ( a runner), had some trouble getting into and out of the Piet here, even with the door cutout and a stepstool. There is just not a lot of room to put feet, trunk, shoulders, through various restrictions and into the right spaces. A few months back Oscar took a passenger of about 55 years age and 200 pounds. He was of average height, but I saw that he had a lot of trouble bending into the spaces, both getting in and out. Of course, even with the door cutout, I will be unlikely to carry someone my height, girth, and weight. It's a fact. In short, having a door is a choice with some possible future benefits but known immediate penalties. It also adds complexity and time to the build. Likely many who add the door, I have specific passengers in mind that I/they wish to fit. That's my case-- as I once told Chuck Gantzer, I am trying to make it easier for tall Nicole Kidman to get in ;) Seriously, on balance, if Corky had not already done a good job with the coutout, I likely would not have added a door. It's your choice. Tim in central TX >>>-----Original Message----- >>From: Jack Phillips <pietflyr(at)bellsouth.net> >>To: pietenpol-list(at)matronics.com >>Sent: Fri, Aug 7, 2009 3:33 pm >>Subject: RE: Pietenpol-List: side door cut out for front seat >> >>Matt, >> >>Gary Price developed a door mod for the front seat some years ago, but few >Piets use it. Basically, anyone too large to be able to climb into the >front cockpit of a Piet is probably too heavy to carry anyway. Any door mod >requires cutting the upper longeron and that is simply not a good idea, >particularly in the area between the cabane struts (and the landing >gear/lift strut fittings). Substantial beefing up of the remaining >structure attempts to restore some of the strength lost by cutting the >longeron, and succeeds in adding substantial weight. >> >>I'm 6'2" and 200 lbs and I can make it into the front cockpit of my Piet >with little trouble. My wife does it all the time. >> >>Jack Phillips >>NX899JP >>Raleigh, NC >> ________________________________________________________________________________
Date: Aug 08, 2009
I am having the same experience on some of the post; even those without pictures and under the same heading as those that display without scrolling. No e-mail involved here so I don't know how to remedy. I also have trouble with the search feature; have to continually do the search over to see additional posts. Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256663#256663 ________________________________________________________________________________
Date: Aug 08, 2009
Hey Guys, I know there is a set of plans (from Yesterday's Wings Aeroplane Works) published that I saw from Mike Groah for a door in the passenger side. I was under the belief it was engineered to be strong enough for the plane. Mark On Sat, Aug 8, 2009 at 9:58 AM, Tim Willis wrote: > timothywillis(at)earthlink.net> > > To door, or not to door... that is the question. > > Corky already had a well reinforced door cutout on his second Piet-- my > current project. (Oscar's Piet was his first.) I am keeping the cutout and > have fabbed a door. Concerned about hard landings and stress points right > there, I added one more diagonal brace, as well. > > As Jack rightly says, no doubt you lose strength cutting the top longeron. > You gain weight trying to get enough strength, not all of it, back. Those > are good reasons not to do it. However, many of my likely future > passengers, like myself, just don't bend that well anymore. For instance, > my wife is only 5' 3" and under 100 pounds, but she is no longer flexible. > [As an aside, I doubt, despite my best intentions, that she will ever fly > in it. She doesn't like first class in a 747. Her loss. I am still > hopeful.] > > I became somewhat convinced the door could be a good idea when my neighbor > my same age, 67, at 6 feet and in good shape ( a runner), had some trouble > getting into and out of the Piet here, even with the door cutout and a > stepstool. There is just not a lot of room to put feet, trunk, shoulders, > through various restrictions and into the right spaces. > > A few months back Oscar took a passenger of about 55 years age and 200 > pounds. He was of average height, but I saw that he had a lot of trouble > bending into the spaces, both getting in and out. Of course, even with the > door cutout, I will be unlikely to carry someone my height, girth, and > weight. It's a fact. > > In short, having a door is a choice with some possible future benefits but > known immediate penalties. It also adds complexity and time to the build. > Likely many who add the door, I have specific passengers in mind that > I/they wish to fit. That's my case-- as I once told Chuck Gantzer, I am > trying to make it easier for tall Nicole Kidman to get in ;) Seriously, on > balance, if Corky had not already done a good job with the coutout, I likely > would not have added a door. It's your choice. > > Tim in central TX > > >>>-----Original Message----- > >>From: Jack Phillips <pietflyr(at)bellsouth.net> > >>To: pietenpol-list(at)matronics.com > >>Sent: Fri, Aug 7, 2009 3:33 pm > >>Subject: RE: Pietenpol-List: side door cut out for front seat > >> > >>Matt, > >> > >>Gary Price developed a door mod for the front seat some years ago, but > few > >Piets use it. Basically, anyone too large to be able to climb into the > >front cockpit of a Piet is probably too heavy to carry anyway. Any door > mod > >requires cutting the upper longeron and that is simply not a good idea, > >particularly in the area between the cabane struts (and the landing > >gear/lift strut fittings). Substantial beefing up of the remaining > >structure attempts to restore some of the strength lost by cutting the > >longeron, and succeeds in adding substantial weight. > >> > >>I'm 6'2" and 200 lbs and I can make it into the front cockpit of my Piet > >with little trouble. My wife does it all the time. > >> > >>Jack Phillips > >>NX899JP > >>Raleigh, NC > >> > > ________________________________________________________________________________
Date: Aug 08, 2009
Mark, I have not seen the plans, or spoken with anyone involved with them, but I would be curious to know if proper stress analyses(sp?) were performed for those drawings, or whether they were drawn because it 'looked good'. Not to disparage those that drew them up; just curious. I concur with Jack's opinions on the detriments to adding the door. Some have built one in, and it has worked; I'm just not a fan. I look at the door argument and say this: why, in all his years of building Pietenpol Air Campers and making changes to the design such as lengthening the fuselage, using a Corvair auto engine, etc, did he never an Air Camper with a door for the front cockpit (I've never heard/read of one)? He mentions lengthening the cabanes four inches on the first Piet built for the Corvair; what other reason for doing that would he have besides easing entry into the front cockpit? And if a door was a better idea, why didn't he do that instead? I'm sure it wasn't because he didn't think of it. He had been in and around aviation for probably 30 some-odd years by that point, and I'm sure he had observed side entry doors on many other open cockpit biplane/parasol aircraft. Finally, I think there's an issue with Matt using that video for illustrating how difficult it is to get into a Piet. No doubt, it is more challenging than many light aircraft. However, it appears that the gentleman attempting to enter the cockpit was not given a proper step-by-step explanation of how to do it, and he did not have someone helping him accomplish it. He just had a cameraman standing there laughing at him as he tried to figure it out (no offense to the cameraman, I'm just sayin'). With a minute of explanation, and some help to accomplish it, I'm sure it would looked far less foolish. It would have been less funny for us to watch, but I digress.... Ryan On Sat, Aug 8, 2009 at 3:34 PM, Mark Roberts wrote: > Hey Guys, > > I know there is a set of plans (from Yesterday's Wings Aeroplane Works) > published that I saw from Mike Groah for a door in the passenger side. I was > under the belief it was engineered to be strong enough for the plane. > > Mark > > On Sat, Aug 8, 2009 at 9:58 AM, Tim Willis wrote: > >> timothywillis(at)earthlink.net> >> >> To door, or not to door... that is the question. >> >> Corky already had a well reinforced door cutout on his second Piet-- my >> current project. (Oscar's Piet was his first.) I am keeping the cutout and >> have fabbed a door. Concerned about hard landings and stress points right >> there, I added one more diagonal brace, as well. >> >> As Jack rightly says, no doubt you lose strength cutting the top longeron. >> You gain weight trying to get enough strength, not all of it, back. Those >> are good reasons not to do it. However, many of my likely future >> passengers, like myself, just don't bend that well anymore. For instance, >> my wife is only 5' 3" and under 100 pounds, but she is no longer flexible. >> [As an aside, I doubt, despite my best intentions, that she will ever fly >> in it. She doesn't like first class in a 747. Her loss. I am still >> hopeful.] >> >> I became somewhat convinced the door could be a good idea when my neighbor >> my same age, 67, at 6 feet and in good shape ( a runner), had some trouble >> getting into and out of the Piet here, even with the door cutout and a >> stepstool. There is just not a lot of room to put feet, trunk, shoulders, >> through various restrictions and into the right spaces. >> >> A few months back Oscar took a passenger of about 55 years age and 200 >> pounds. He was of average height, but I saw that he had a lot of trouble >> bending into the spaces, both getting in and out. Of course, even with the >> door cutout, I will be unlikely to carry someone my height, girth, and >> weight. It's a fact. >> >> In short, having a door is a choice with some possible future benefits but >> known immediate penalties. It also adds complexity and time to the build. >> Likely many who add the door, I have specific passengers in mind that >> I/they wish to fit. That's my case-- as I once told Chuck Gantzer, I am >> trying to make it easier for tall Nicole Kidman to get in ;) Seriously, on >> balance, if Corky had not already done a good job with the coutout, I likely >> would not have added a door. It's your choice. >> >> Tim in central TX >> >> >>>-----Original Message----- >> >>From: Jack Phillips <pietflyr(at)bellsouth.net> >> >>To: pietenpol-list(at)matronics.com >> >>Sent: Fri, Aug 7, 2009 3:33 pm >> >>Subject: RE: Pietenpol-List: side door cut out for front seat >> >> >> >>Matt, >> >> >> >>Gary Price developed a door mod for the front seat some years ago, but >> few >> >Piets use it. Basically, anyone too large to be able to climb into the >> >front cockpit of a Piet is probably too heavy to carry anyway. Any door >> mod >> >requires cutting the upper longeron and that is simply not a good idea, >> >particularly in the area between the cabane struts (and the landing >> >gear/lift strut fittings). Substantial beefing up of the remaining >> >structure attempts to restore some of the strength lost by cutting the >> >longeron, and succeeds in adding substantial weight. >> >> >> >>I'm 6'2" and 200 lbs and I can make it into the front cockpit of my Piet >> >with little trouble. My wife does it all the time. >> >> >> >>Jack Phillips >> >>NX899JP >> >>Raleigh, NC >> > ________________________________________________________________________________
Date: Aug 08, 2009
Subject: I hope the list is dead tonight.....
....because everyone is out flying the pants off of their Piets, or getting rides in Piets, or taking to the skies any which way they possibly can. My better half (and you that met her know that is a severe understatement) is working this evening. I have spent some time cleaning firearms, and will spend some time cleaning our engine block later on. I hope everyone is having an enjoyable weekend! Ryan ________________________________________________________________________________
Subject: A65 to A75 swap
Date: Aug 08, 2009
A little update on my engine swap. Last weekend I got the engine started and everything came up normally but the engine developed an oil leak about the time I was ready to shut it down anyway. Also had a very slow drip from the Curtis valve on the gascolator and the prop was one bolt out of "clock" and a bit out of track. Today I took care of all those squawks. Re-clocked and shimmed the prop to bring it into track, replaced the Curtis drain valve on the gascolator (DO NOT try to just replace the O-ring on the nose of the valve... if it leaks, replace it). The oil leak turned out to be at one of the oil gallery plugs at the front of the engine and I think I'm eventually going to have to heli- coil it because the threads on that side aren't great. Engine started up just fine, runup was normal, and off we went to seat the rings. Here are a couple of lessons learned. Performance figures will not mean anything right now because the engine is very tight and I flew the airplane with the cowling off, in order to have everything where I could see it readily. If Dick Navratil can fly his Rotec radial powered piet with no cowling, so can I! And I also figured flying it without the cowling would provide more drag and thus more load on the engine to help with seating the rings. 1. In a slip (or even in straight flight), a bare Piet firewall into the wind is more effective than flaps, a belly board, and Precise Flight wing spoilers. In other words, it has the coefficient of drag of a broadside barn door. My first approach to landing was nearly vertical. 2. With power on, this engine/prop combo goes into the redline VERY quickly when the nose goes down and revs build very readily. Same for the airplane... nose down equals Vne very quickly unless power is pulled off right now. It didn't do that with the 65. 3. (A) It gets VERY bumpy on an August afternoon. (B) The vertical travel of the fuel needle on a Stromberg NAS3 carb is only about 1/16" from full open to full shut. (C) When a Piet with a Stromberg hits a big summer bump on downwind, the rapid vertical change can bounce the float in the carb, making the engine hiccup momentarily. (D) When cautiously breaking in a new engine and it hiccups, it can make a Piet pilot's heart stop. I now know this ;o) The engine is running strong and smooth, starts easily (but is still very stiff), and promises to provide the airplane with a real kick in the pants. The proof will come soon, as I put the cowling back on and get more relaxed in the airplane where I can put it through its paces. Oscar Zuniga Air Camper NX41CC, A75 and Culver prop San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Enduring attributes of the Pietenpol design
Date: Aug 08, 2009
Gentlemen, With all this talk about front cockpit doors etc, I think this, an appropriate time, to take the opportunity to expound on one?of the great?attributes?of the Pietenpol design. * Difficulty of entry. In order to get into the front cockpit, one must be somewhat of a contortionist. In my airplane (not yet flying) I have?concluded upon a number of specific instructions.? 1) Chock wheels. 2) Step over?left-rear wing strut and brace wire with left foot/leg. 3) While lifting left foot and leg, place left foot on top of left tire.?Using left hand, grasp?left-front wing strut. 4) Place right hand, onto left-hand front cockpit longeron. Pull body weight forward,?with both hands/arms, placing entire body weight onto left?leg. Continuing to lift body weight forward, and after slight?hesitation at the top, begin to shift body weight to the port side, so as to allow oneself to lift right leg to sufficient height?to allow to swing right foot over the top of the left-hand passenger cockpit longeron, all-the-while bending the body forward into a quite?unatural position, (hoping that cramping will not set-in) and down onto the front passenger seat frame. (I will have a "red dot" placed in the appropriate spot as to have a "place of reference" to?inform the potential front seat passenger where the correct?placement is, to put the right foot, at this stage of entry, since my seat is woven whicker, and consequently is kind of weak in the middle). 5) While?changing body weight onto right foot, continue to shift body weight to starboard, being careful as to not knock one's head into the?downward-protruding fuel gauge (that is obviously in the way) at this point of the entry procedure. 6) Continue shifting body weight to starboard, and?protrude passenger head out past (and in between and through) right-hand cabane struts, until potential passenger has shifted sufficient body weight over so he (she) is able to lift the left leg up, over, and into the front cockpit floor area. Once this has been accomplished, the passenger can "settle" down into the front seat, awaiting help from the pilot/crew, to fasten all appropriate seat belts etc. ? Let's not forget, that Bernard (he pronounced it "Ber-nerd") never, ever,?mentioned this design change. As such, it will never be "approved". Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Aug 08, 2009
Cleaning your guns? That's a good way to keep your Better Half in line... I had a fantastic day! Just finished ALL the welding on my straight axle (similar to Larry Williams'). I'll paint tonight and install tomorrow. I cannot say how many months I have been fretting over this! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Saturday, August 08, 2009 4:20 PM Subject: Pietenpol-List: I hope the list is dead tonight..... ....because everyone is out flying the pants off of their Piets, or getting rides in Piets, or taking to the skies any which way they possibly can. My better half (and you that met her know that is a severe understatement) is working this evening. I have spent some time cleaning firearms, and will spend some time cleaning our engine block later on. I hope everyone is having an enjoyable weekend! Ryan ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Aug 08, 2009
Subject: video of a gent who is 6' 3" tall getting into a Pietenpol
I've had guys in their 80's get into my cockpit. Raise the cabanes 2 or 3" higher than plans and forget about the door. Get a Cub or Champ if you want a door:) Kidding-- put a door in if you want but you don't need one. Mike C. http://www.youtube.com/watch?v=A-EgR2eGbN0 ________________________________________________________________________________
Date: Aug 08, 2009
Subject: Milestone day in my Pietenpol build
Today was a great one! I've been installing a used A-65 on my project for the last 3 weeks. I bought it about 18 months ago and it had just been sitting on the hangar floor since then. Today everything was finally all hooked up, the prop installed, fuel lines, engine gauges, etc. I turned on the fuel and immediately had a dripping from the carbureter. Turns out I hadn't tightened the filter screen cover. That was fixed quick enough. With the switch off I pulled it through 6 blades and could tell by the sound of the carbureter that it had fuel. On the second blade if fired on 2 or 3 cylinders. I switched it off and pulled through 2 more blades, switch on, and it started! I had the tailwheel tied to a tree, but still I only ran it up to 1500 rpm and only ran it a few minutes because I haven't installed the eyebrows yet. >From this link you can see the smile I had. http://www.facebook.com/photo.php?pid=399331&l=5d09aea9f0&id=1542217055 After that I loaded my wings onto my trailer and took them out to the airport so I'd have more room in my shop. I'm hoping to get my decals installed next week and get through the 2 or 3 hundred small projects still necessary to finish this thing off. Ben Charvet Mims Fl Hoping to have it in the air for the 80th anniv year ________________________________________________________________________________
Date: Aug 08, 2009
Way to go Ben and way to go Oscar-- both engines have RUN ! Your new Florida outdoor air conditioner unit, right Ben ? ________________________________________________________________________________
Date: Aug 08, 2009
Way to go, Ben! Jack Phillips NX899JP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Saturday, August 08, 2009 9:28 PM Subject: Pietenpol-List: Milestone day in my Pietenpol build Today was a great one! I've been installing a used A-65 on my project for the last 3 weeks. I bought it about 18 months ago and it had just been sitting on the hangar floor since then. Today everything was finally all hooked up, the prop installed, fuel lines, engine gauges, etc. I turned on the fuel and immediately had a dripping from the carbureter. Turns out I hadn't tightened the filter screen cover. That was fixed quick enough. With the switch off I pulled it through 6 blades and could tell by the sound of the carbureter that it had fuel. On the second blade if fired on 2 or 3 cylinders. I switched it off and pulled through 2 more blades, switch on, and it started! I had the tailwheel tied to a tree, but still I only ran it up to 1500 rpm and only ran it a few minutes because I haven't installed the eyebrows yet. >From this link you can see the smile I had. http://www.facebook.com/photo.php?pid=399331&l=5d09aea9f0&id=1542217055 After that I loaded my wings onto my trailer and took them out to the airport so I'd have more room in my shop. I'm hoping to get my decals installed next week and get through the 2 or 3 hundred small projects still necessary to finish this thing off. Ben Charvet Mims Fl Hoping to have it in the air for the 80th anniv year ________________________________________________________________________________
Date: Aug 08, 2009
Cool, Gary. One thing about the wire wheel Pietenpol - you'll draw a crowd wherever you go. Jack Phillips NX899JP _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Saturday, August 08, 2009 9:05 PM Subject: RE: Pietenpol-List: I hope the list is dead tonight..... Cleaning your guns? That's a good way to keep your Better Half in line... I had a fantastic day! Just finished ALL the welding on my straight axle (similar to Larry Williams'). I'll paint tonight and install tomorrow. I cannot say how many months I have been fretting over this! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Saturday, August 08, 2009 4:20 PM Subject: Pietenpol-List: I hope the list is dead tonight..... ....because everyone is out flying the pants off of their Piets, or getting rides in Piets, or taking to the skies any which way they possibly can. My better half (and you that met her know that is a severe understatement) is working this evening. I have spent some time cleaning firearms, and will spend some time cleaning our engine block later on. I hope everyone is having an enjoyable weekend! Ryan http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 08, 2009
Mark, You can make the cutout strong enough. My point is that it is likely never as strong as before the top longeron was cut, and it certainly weighs more. Tim -----Original Message----- From: Mark Roberts Sent: Aug 8, 2009 3:34 PM Subject: Re: Pietenpol-List: side door cut out for front seat Hey Guys, I know there is a set of plans (from Yesterday's Wings Aeroplane Works) published that I saw from Mike Groah for a door in the passenger side. I was under the belief it was engineered to be strong enough for the plane. Mark ________________________________________________________________________________
Date: Aug 08, 2009
Subject: Re: A65 to A75 swap
Good job! ________________________________________________________________________________
Subject: Re: Axle welding
Date: Aug 09, 2009
Looks good Gary!!=C2- One more milestone checked off. Dan Helsper Poplar Grove, IL -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sat, Aug 8, 2009 8:05 pm Subject: RE: Pietenpol-List: I hope the list is dead tonight..... Cleaning your guns? That=99s a good way to keep your Better Half in line.. =C2- I had a fantastic day! Just finished ALL the welding on my straight axle (similar to Larry Williams=99). I=99ll paint tonight and inst all tomorrow. I cannot say how many months I have been fretting over this! =C2- Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done,=C2-Fuselage=C2-on gear (13 ribs down) From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Saturday, August 08, 2009 4:20 PM Subject: Pietenpol-List: I hope the list is dead tonight..... =C2- ....because everyone is out flying the pants off of their Piets, or gettin g rides in Piets, or taking to the skies any which way they possibly can. My better half (and you that met her know that is a severe understatement ) is working this evening. I have spent some time cleaning firearms, and will spend some time cleaning our engine block later on. I hope everyone is having an enjoyable weekend! Ryan =C2- =C2- http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www. matronics.com/contribution =C2- ________________________________________________________________________________
Date: Aug 09, 2009
Subject: Magneto and prop for Model A
Hi, Guys, Can anyone recommend good sources for a magneto and a prop to use with the Model A engine? Thanks. John Smoyer Hockessin, DE ________________________________________________________________________________
Subject: Re: Enduring attributes of the Pietenpol design
Date: Aug 09, 2009
V2VsbCBpdHMgb2ZmaWNpYWwgRGFuIGhhcyBjaGVja2VkIHRoZSBsb3N0IHBhcGVycyBvZiBCZXIg bmVyZCBhbmQgcmVuZGVyZWQgdGhlIG9mZmljaWFsIG9waW5pb24uIA0KDQpBY3R1YWxseSwgSSB0 aG91Z2h0IHRoZSBmcm9udCBwaXQgaWRlYSB3b3VsZCBiZSBhIG5lYXQgbW9kaWZpY2F0aW9uIHNv IEkgZnJhbWVkIG9uZSBpbi4gDQoNClRoZSBtb3JlIEkgbG9va2VkIGF0IGl0IHRoZSBtb3JlIEkg bGlrZWQgaXQgaG93ZXZlciwgSSBjb3VsZCBub3QsIHdvdWxkIG5vdCBhbmQgZGlkIG5vdCBjdXQg dGhlIHVwcGVyIGxvbmdlcm9uLiBUaGUgdGhvdWdodCBvZiB3aGljaCBmcmlnaHRlbmVkIHRoZSBo ZWxsIG91dCBvZiBtZSBhbmQgc28gSSBhYmFuZG9uZWQgdGhlIGlkZWEgYW5kIGRlY2lkZWQgdG8g Z28gd2l0aCB0aGUgY29udmVudGlvbmFsIHdpc2RvbS4gTm8gY3V0dGluZyBzdHJ1Y3R1cmFsbHkg IGludGVncmFsIHBhcnRzICBmb3IgbWUuICBXaGVuIGEgcG90ZW50aWFsIHBhc3NlbmdlciBkb24n dCBmaXQgdGhleSBkb24ndCByaWRlLiBXaGljaCB3ZWxsIGV4cGxhaW5zIHdoeSBJIGhhdmUgeWV0 IHRvIGNhdGNoIGEgcmlkZSBpbiBteSAzIEJyb2RoZWFkcy4gSSBkb24ndCBmaXQgc28gSSBkb24n dCByaWRlLiBFbmQgb2Ygc3RvcnkuIA0KDQpJIHJlZnVzZSB0byBjb21wcm9taXNlIHNhZmV0eSBm b3IgYW55b25lIG9yIGFueXRoaW5nIQ0KDQpKdXN0IG15IHBvc2l0aW9uLiANCg0KSm9obiANClNl bnQgZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIEJsYWNrQmVycnkNCg0KLS0tLS1PcmlnaW5hbCBN ZXNzYWdlLS0tLS0NCkZyb206IGhlbHNwZXJzZXdAYW9sLmNvbQ0KDQpEYXRlOiBTYXQsIDA4IEF1 ZyAyMDA5IDIwOjQ0OjEyIA0KVG86IDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPg0KU3Vi amVjdDogUGlldGVucG9sLUxpc3Q6IEVuZHVyaW5nIGF0dHJpYnV0ZXMgb2YgdGhlIFBpZXRlbnBv bCBkZXNpZ24NCg0KDQpHZW50bGVtZW4sIA0KDQpXaXRoIGFsbCB0aGlzIHRhbGsgYWJvdXQgZnJv bnQgY29ja3BpdCBkb29ycyBldGMsIEkgdGhpbmsgdGhpcywgYW4gYXBwcm9wcmlhdGUgdGltZSwg dG8gdGFrZSB0aGUgb3Bwb3J0dW5pdHkgdG8gZXhwb3VuZCBvbiBvbmU/b2YgdGhlIGdyZWF0P2F0 dHJpYnV0ZXM/b2YgdGhlIFBpZXRlbnBvbCBkZXNpZ24uDQoNCiogRGlmZmljdWx0eSBvZiBlbnRy eS4gSW4gb3JkZXIgdG8gZ2V0IGludG8gdGhlIGZyb250IGNvY2twaXQsIG9uZSBtdXN0IGJlIHNv bWV3aGF0IG9mIGEgY29udG9ydGlvbmlzdC4gSW4gbXkgYWlycGxhbmUgKG5vdCB5ZXQgZmx5aW5n KSBJIGhhdmU/Y29uY2x1ZGVkIHVwb24gYSBudW1iZXIgb2Ygc3BlY2lmaWMgaW5zdHJ1Y3Rpb25z Lj8NCg0KMSkgQ2hvY2sgd2hlZWxzLiANCg0KMikgU3RlcCBvdmVyP2xlZnQtcmVhciB3aW5nIHN0 cnV0IGFuZCBicmFjZSB3aXJlIHdpdGggbGVmdCBmb290L2xlZy4gDQoNCjMpIFdoaWxlIGxpZnRp bmcgbGVmdCBmb290IGFuZCBsZWcsIHBsYWNlIGxlZnQgZm9vdCBvbiB0b3Agb2YgbGVmdCB0aXJl Lj9Vc2luZyBsZWZ0IGhhbmQsIGdyYXNwP2xlZnQtZnJvbnQgd2luZyBzdHJ1dC4gDQoNCjQpIFBs YWNlIHJpZ2h0IGhhbmQsIG9udG8gbGVmdC1oYW5kIGZyb250IGNvY2twaXQgbG9uZ2Vyb24uIFB1 bGwgYm9keSB3ZWlnaHQgZm9yd2FyZCw/d2l0aCBib3RoIGhhbmRzL2FybXMsIHBsYWNpbmcgZW50 aXJlIGJvZHkgd2VpZ2h0IG9udG8gbGVmdD9sZWcuIENvbnRpbnVpbmcgdG8gbGlmdCBib2R5IHdl aWdodCBmb3J3YXJkLCBhbmQgYWZ0ZXIgc2xpZ2h0P2hlc2l0YXRpb24gYXQgdGhlIHRvcCwgYmVn aW4gdG8gc2hpZnQgYm9keSB3ZWlnaHQgdG8gdGhlIHBvcnQgc2lkZSwgc28gYXMgdG8gYWxsb3cg b25lc2VsZiB0byBsaWZ0IHJpZ2h0IGxlZyB0byBzdWZmaWNpZW50IGhlaWdodD90byBhbGxvdyB0 byBzd2luZyByaWdodCBmb290IG92ZXIgdGhlIHRvcCBvZiB0aGUgbGVmdC1oYW5kIHBhc3Nlbmdl ciBjb2NrcGl0IGxvbmdlcm9uLCBhbGwtdGhlLXdoaWxlIGJlbmRpbmcgdGhlIGJvZHkgZm9yd2Fy ZCBpbnRvIGEgcXVpdGU/dW5hdHVyYWwgcG9zaXRpb24sIChob3BpbmcgdGhhdCBjcmFtcGluZyB3 aWxsIG5vdCBzZXQtaW4pIGFuZCBkb3duIG9udG8gdGhlIGZyb250IHBhc3NlbmdlciBzZWF0IGZy YW1lLiAoSSB3aWxsIGhhdmUgYSAicmVkIGRvdCIgcGxhY2VkIGluIHRoZSBhcHByb3ByaWF0ZSBz cG90IGFzIHRvIGhhdmUgYSAicGxhY2Ugb2YgcmVmZXJlbmNlIiB0bz9pbmZvcm0gdGhlIHBvdGVu dGlhbCBmcm9udCBzZWF0IHBhc3NlbmdlciB3aGVyZSB0aGUgY29ycmVjdD9wbGFjZW1lbnQgaXMs IHRvIHB1dCB0aGUgcmlnaHQgZm9vdCwgYXQgdGhpcyBzdGFnZSBvZiBlbnRyeSwgc2luY2UgbXkg c2VhdCBpcyB3b3ZlbiB3aGlja2VyLCBhbmQgY29uc2VxdWVudGx5IGlzIGtpbmQgb2Ygd2VhayBp biB0aGUgbWlkZGxlKS4NCg0KNSkgV2hpbGU/Y2hhbmdpbmcgYm9keSB3ZWlnaHQgb250byByaWdo dCBmb290LCBjb250aW51ZSB0byBzaGlmdCBib2R5IHdlaWdodCB0byBzdGFyYm9hcmQsIGJlaW5n IGNhcmVmdWwgYXMgdG8gbm90IGtub2NrIG9uZSdzIGhlYWQgaW50byB0aGU/ZG93bndhcmQtcHJv dHJ1ZGluZyBmdWVsIGdhdWdlICh0aGF0IGlzIG9idmlvdXNseSBpbiB0aGUgd2F5KSBhdCB0aGlz IHBvaW50IG9mIHRoZSBlbnRyeSBwcm9jZWR1cmUuIA0KDQo2KSBDb250aW51ZSBzaGlmdGluZyBi b2R5IHdlaWdodCB0byBzdGFyYm9hcmQsIGFuZD9wcm90cnVkZSBwYXNzZW5nZXIgaGVhZCBvdXQg cGFzdCAoYW5kIGluIGJldHdlZW4gYW5kIHRocm91Z2gpIHJpZ2h0LWhhbmQgY2FiYW5lIHN0cnV0 cywgdW50aWwgcG90ZW50aWFsIHBhc3NlbmdlciBoYXMgc2hpZnRlZCBzdWZmaWNpZW50IGJvZHkg d2VpZ2h0IG92ZXIgc28gaGUgKHNoZSkgaXMgYWJsZSB0byBsaWZ0IHRoZSBsZWZ0IGxlZyB1cCwg b3ZlciwgYW5kIGludG8gdGhlIGZyb250IGNvY2twaXQgZmxvb3IgYXJlYS4gT25jZSB0aGlzIGhh cyBiZWVuIGFjY29tcGxpc2hlZCwgdGhlIHBhc3NlbmdlciBjYW4gInNldHRsZSIgZG93biBpbnRv IHRoZSBmcm9udCBzZWF0LCBhd2FpdGluZyBoZWxwIGZyb20gdGhlIHBpbG90L2NyZXcsIHRvIGZh c3RlbiBhbGwgYXBwcm9wcmlhdGUgc2VhdCBiZWx0cyBldGMuDQo/DQpMZXQncyBub3QgZm9yZ2V0 LCB0aGF0IEJlcm5hcmQgKGhlIHByb25vdW5jZWQgaXQgIkJlci1uZXJkIikgbmV2ZXIsIGV2ZXIs P21lbnRpb25lZCB0aGlzIGRlc2lnbiBjaGFuZ2UuIEFzIHN1Y2gsIGl0IHdpbGwgbmV2ZXIgYmUg ImFwcHJvdmVkIi4NCg0KRGFuIEhlbHNwZXINClBvcGxhciBHcm92ZSwgSUwuDQoNCg0KDQo ________________________________________________________________________________
Date: Aug 09, 2009
Ben; it's quite a feeling, isn't it? The work seems to go faster and with more purpose once the airplane has a beating heart. One small suggestion, and you may have already done this but it wasn't evident in the photo- while doing engine tests, keep a fire extinguisher handy and out of range of the engine and spinning prop. Mine could have come in handy when I first started my A65 since my engine flooded frequently before I got the hang of starting it, and things do tend to leak when you're doing initial fitup. There are plenty of pictures and videos of fresh engine starts where a new project burnt to the ground. Oscar Zuniga Air Camper NX41CC- A75 and Culver prop San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: side door cut out for front seat
Date: Aug 09, 2009
Referencing the 55-year-old guy that I gave a ride to and that Tim mentioned, I want to clarify that the gentleman informed me that he had back and shoulder injuries, bad knees, and was a smoker. He had an inordinately difficult time climbing into my airplane due to his physical issues. It really isn't all that difficult. And to the matter of putting a red dot, "X", or other mark on the front seat where a passenger should land their foot when climbing in, the difficulty is that in that point of the maneuver, their head is well out the starboard side, and they cannot look down past the top longeron to see the seat. In cases like that, I generally help guide their foot to the proper place on the seat because they have no idea. The thing is, once a person has done it once or twice, they seem to slither in much more easily, all the sooner to get settled in and airborne. I have never had a passenger get out and say they'll never go up in a Piet again... most are ready and willing to go back up at the next offer of a ride and it will be much easier for them to climb in the second time around. Except for women, who always seem to need assistance in the form of some strategically-placed manual guidance, eh Mikee?? "Never disconcert the Ms.'s"- is that the new mantra? Oscar Zuniga Air Camper NX41CC- A75 with Culver prop San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 09, 2009
As to the side door cutout, that entire side framing of the fuselage can be infilled with 1" thick polystyrene foam board and glassed both sides, a la KR. That treatment will provide VERY adequate strength and stiffness to the area where a door cutout is made. Normal fabric covering can then proceed and the fiberglass will only be visible inside the cockpits on the cutout side. I have no idea what the new load paths would be, but I'll wager that the cutout will no longer be the "soft" structural area of that side of the airplane. Oscar Zuniga Air Camper NX41CC- A75 with Culver prop San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Magneto and prop for Model A
Date: Aug 09, 2009
J. Anderson of Cloudcars propellers (325-356-2810) can recommend a prop and build it too and he will work with you to find what you want/need. As for the magneto choice; there are lots of good mags out there and priced right if you look around (ebay always has lots of them listed). A four cylinder tractor mag with the correct rotation is what you need; also whether flange mount or base mount depending on your set-up. I would recommend a side drive rather than the end mount; it's much easier to get to if service is needed. You might want to talk to a magneto shop to see what mags still have service parts available if needed. I haven't tried this but I believe a nice side drive can be fashioned from a governor drive set-up. Will Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256775#256775 ________________________________________________________________________________
Subject: accident/incident investigations
Date: Aug 09, 2009
Mikee- it's interesting that you mention the cases that you have seen, and the hassles that Pieti (Lowell Frank) is going through. I thought for sure I was going to have to endure the same sort of grilling when 41CC went over on its nose. I researched the definition of "accident" and "incident" and I thought for sure that the situation with 41CC was an "accident" and that both Charlie (pilot) and I (owner) were in for some hell from the NTSB and FAA. Not so. Apparently the investigators didn't even care to come look at the airplane even though we didn't touch it after retrieving it from the field and moving it to the hangar. We sent pictures and someone from a local law enforcement agency came by to look at it, but the big boys didn't deem it serious enough to slap either me or Charlie. Strange to think that Lowell's incident was serious enough in their eyes to cause all this ruckus, yet the situation with 41CC was not. Carb ice stopped the engine, an off-field landing was made in a rough field, welds broke on the landing gear legs, collapsing the gear and putting the airplane on its nose and then over on its back. I dunno... sounds a little bit more like an "accident" than Lowell's broken bungee, no? I'm not asking that my case be reopened for investigation, so don't go turning me in!!! I just feel bad about Pieti. Oscar Zuniga Air Camper NX41CC- A75 with Culver prop San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 09, 2009
Subject: Re: accident/incident investigations
Maybe the difference is in the audience? When people have a big audience (10,000 EAA attendees) vs a small audience (a few cows and maybe one farmer?)....people sometimes change personalities, honesty, virtue, morals, integrity, etc...it's sad but we're all human after all. And I agree, I really feel bad about this whole thing.... -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: Aug 9, 2009 10:28 AM >To: Pietenpol List >Subject: Pietenpol-List: accident/incident investigations > > >Mikee- it's interesting that you mention the cases that you >have seen, and the hassles that Pieti (Lowell Frank) is going >through. I thought for sure I was going to have to endure >the same sort of grilling when 41CC went over on its nose. I >researched the definition of "accident" and "incident" and I >thought for sure that the situation with 41CC was an "accident" >and that both Charlie (pilot) and I (owner) were in for some >hell from the NTSB and FAA. Not so. Apparently the >investigators didn't even care to come look at the airplane >even though we didn't touch it after retrieving it from the >field and moving it to the hangar. We sent pictures and >someone from a local law enforcement agency came by to look at >it, but the big boys didn't deem it serious enough to slap >either me or Charlie. Strange to think that Lowell's incident >was serious enough in their eyes to cause all this ruckus, yet >the situation with 41CC was not. > >Carb ice stopped the engine, an off-field landing was made in >a rough field, welds broke on the landing gear legs, collapsing >the gear and putting the airplane on its nose and then over on >its back. I dunno... sounds a little bit more like an "accident" >than Lowell's broken bungee, no? > >I'm not asking that my case be reopened for investigation, so >don't go turning me in!!! I just feel bad about Pieti. > >Oscar Zuniga >Air Camper NX41CC- A75 with Culver prop >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Aug 09, 2009
>From personal experience, flying without a cowling is a drag, and then some. That was what helped me wreck my left gear and prop last year. Be real careful flying without a cowling. Oscar is right about the barn door and vertical landing--Jim Lagowski ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Saturday, August 08, 2009 8:25 PM Subject: Pietenpol-List: A65 to A75 swap > > > A little update on my engine swap. Last weekend I got the > engine started and everything came up normally but the engine > developed an oil leak about the time I was ready to shut it > down anyway. Also had a very slow drip from the Curtis valve > on the gascolator and the prop was one bolt out of "clock" and > a bit out of track. > > Today I took care of all those squawks. Re-clocked and shimmed > the prop to bring it into track, replaced the Curtis drain valve > on the gascolator (DO NOT try to just replace the O-ring on the > nose of the valve... if it leaks, replace it). The oil leak > turned out to be at one of the oil gallery plugs at the front > of the engine and I think I'm eventually going to have to heli- > coil it because the threads on that side aren't great. Engine > started up just fine, runup was normal, and off we went to seat > the rings. Here are a couple of lessons learned. > > Performance figures will > not mean anything right now because the engine is very tight > and I flew the airplane with the cowling off, in order to have > everything where I could see it readily. If Dick Navratil can > fly his Rotec radial powered piet with no cowling, so can I! > And I also figured flying it without the cowling would provide > more drag and thus more load on the engine to help with seating > the rings. > > 1. In a slip (or even in straight flight), a bare Piet firewall > into the wind is more effective than flaps, a belly board, and > Precise Flight wing spoilers. In other words, it has the coefficient > of drag of a broadside barn door. My first approach to landing > was nearly vertical. > > 2. With power on, this engine/prop combo goes into the redline > VERY quickly when the nose goes down and revs build very readily. > Same for the airplane... nose down equals Vne very quickly unless > power is pulled off right now. It didn't do that with the 65. > > 3. (A) It gets VERY bumpy on an August afternoon. (B) The vertical > travel of the fuel needle on a Stromberg NAS3 carb is only about > 1/16" from full open to full shut. (C) When a Piet with a > Stromberg hits a big summer bump on downwind, the rapid vertical > change can bounce the float in the carb, making the engine > hiccup momentarily. (D) When cautiously breaking in a new engine > and it hiccups, it can make a Piet pilot's heart stop. I now > know this ;o) > > The engine is running strong and smooth, starts easily (but is > still very stiff), and promises to provide the airplane with a > real kick in the pants. The proof will come soon, as I put the > cowling back on and get more relaxed in the airplane where I > can put it through its paces. > > Oscar Zuniga > Air Camper NX41CC, A75 and Culver prop > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 18:17:00 ________________________________________________________________________________
Date: Aug 09, 2009
While at Brodhead, in a conversation with another tire-kicker like me, an individual was telling me about his aviation background. He as taking an FAA course, as I recall, and the subject matter was not popular with all the students. Their motto was, "Comply and graduate." That may apply here, too. "Gee, Newt...do you think if I study real hard I'll pass the test?" Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Sunday, August 09, 2009 9:08 AM Subject: Re: Pietenpol-List: accident/incident investigations Maybe the difference is in the audience? When people have a big audience (10,000 EAA attendees) vs a small audience (a few cows and maybe one farmer?)....people sometimes change personalities, honesty, virtue, morals, integrity, etc...it's sad but we're all human after all. And I agree, I really feel bad about this whole thing.... -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: Aug 9, 2009 10:28 AM >To: Pietenpol List >Subject: Pietenpol-List: accident/incident investigations > > >Mikee- it's interesting that you mention the cases that you >have seen, and the hassles that Pieti (Lowell Frank) is going >through. I thought for sure I was going to have to endure >the same sort of grilling when 41CC went over on its nose. I >researched the definition of "accident" and "incident" and I >thought for sure that the situation with 41CC was an "accident" >and that both Charlie (pilot) and I (owner) were in for some >hell from the NTSB and FAA. Not so. Apparently the >investigators didn't even care to come look at the airplane >even though we didn't touch it after retrieving it from the >field and moving it to the hangar. We sent pictures and >someone from a local law enforcement agency came by to look at >it, but the big boys didn't deem it serious enough to slap >either me or Charlie. Strange to think that Lowell's incident >was serious enough in their eyes to cause all this ruckus, yet >the situation with 41CC was not. > >Carb ice stopped the engine, an off-field landing was made in >a rough field, welds broke on the landing gear legs, collapsing >the gear and putting the airplane on its nose and then over on >its back. I dunno... sounds a little bit more like an "accident" >than Lowell's broken bungee, no? > >I'm not asking that my case be reopened for investigation, so >don't go turning me in!!! I just feel bad about Pieti. > >Oscar Zuniga >Air Camper NX41CC- A75 with Culver prop >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Aug 09, 2009
Subject: door cutout
Oscar as a good idea with the foam and glass. The cutout may be reinforced like the rest of the plane, as well; for instance, with 1' thick ply or spruce for some of the infill, with ply gussets inboard of that, and of course the outside ply skin. It's plenty strong. As in the rest of the plane, the key is triangulation with diagonals and bonding with gussets. Tim in central TX ________________________________________________________________________________
Date: Aug 09, 2009
John, We've had people your size and larger in our front pit, so I'm not sure why you haven't been able to get a ride. In fact, our cockpits have an annoying amount of sheet aluminum cowling around them. I guess the builder was going for a look, or maybe he thought a tightly cowled pit would be warmer in the winter. It makes it that much more difficult to get in. In any event, we've had 6'2" 230 lb people in the front, so if I ever make it up your way, I'll give you a ride. Jeff ________________________________________________________________________________
Date: Aug 09, 2009
Subject: Re: side door cut out for front seat
I must agree with you there! And besides, door or no door, I will still get to fly! :o) So, it really depends on how badly the passenger wants to go with me!! :oD Mark On Sat, Aug 8, 2009 at 8:39 PM, Tim Willis wrote: > timothywillis(at)earthlink.net> > > Mark, > You can make the cutout strong enough. My point is that it is likely never > as strong as before the top longeron was cut, and it certainly weighs more. > Tim > > > -----Original Message----- > From: Mark Roberts > Sent: Aug 8, 2009 3:34 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: side door cut out for front seat > > Hey Guys, > > I know there is a set of plans (from Yesterday's Wings Aeroplane Works) > published that I saw from Mike Groah for a door in the passenger side. I was > under the belief it was engineered to be strong enough for the plane. > > Mark > > ________________________________________________________________________________
Subject: WP
Date: Aug 09, 2009
"You can beat him Waldo, with my monoplane" ________________________________________________________________________________
Date: Aug 09, 2009
Hey, now! None o' that. I met John. He SEEMED right enough... Allowances must be made for cheese intake and resultant output, but I figger that's all just part of the charm of the natives... > >Jeff, If you've ever met John you'll realize that his size is just an excuse >for not giving him a ride. There are other reasons... > >Jack Phillips >NX899JP > ________________________________________________________________________________
Date: Aug 09, 2009
He's an inferior model but he'll suit our purposes! John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2810 Crossroads Drive, Ste 3800 Madison, WI 53718 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Aug 9, 2009, at 5:38 PM, Jeff Boatright wrote: > > > > Hey, now! None o' that. I met John. He SEEMED right enough... > Allowances must be made for cheese intake and resultant output, but > I figger that's all just part of the charm of the natives... > >> > >> >> Jeff, If you've ever met John you'll realize that his size is just >> an excuse >> for not giving him a ride. There are other reasons... >> >> Jack Phillips >> NX899JP >> > > ________________________________________________________________________________
Date: Aug 09, 2009
To All Pilots, F%&# the FAA.- They are usually just a bunch of gestapo se lf rightoius power hungry wenies who don't even know what an airplane is. - A fellow Piet builder who I won't mention his name, said that the faa i s nothing but a rotation of a__ holes, and he spent 20+ years working for t hem.- I think the job requirements for being in the faa is heartbeat, no soul, and you must not know anything practical about anything aviation rela ted (besides the letter of the law).- I think the same goes for the aircr aft-maintenance side of the FAA, worthless!- Most faa maintenance inspe ctors today are there because the sucked as mechanics.- This, of course i s my own generalized oppinion, formed from 15+ years in aviation, both as a pilot, and a mechanic.- I know at one time many many years ago (while th e earth was still cooling) the faa guys were the experianced, and sharpest guys in the field (maybe?).- But that ain't the case anymore sonny. - Sincerly, You know who - P.S.- any FAA guys reading this, go study airplanes, and real world flyin g skill, instead of therory, law and textbook answers to real world experia nce problems.=0A=0A=0A ________________________________________________________________________________
Date: Aug 09, 2009
Subject: Piettie, in response to the faa's letter
Mr Piettie Lowell, See if you can get one of those spring loaded boxing glo ves into an envelope (like in the old cartoons), and send it back to the FA A inspector.- With it send a letter- in response to his flight review l etter, and ask him what the hell he wants you to teach him during this flig ht review.- And then make sure it is in you Ford powered Pietenpol, and t hen see what in the hell he has to say!- I am just a pup myself at 31 yrs old, but it burns me to see the govt. run things so bass akwords as they d o.- You know a lifetime more than the desk pilot who would review your sk ills. - Give, Em Hell, Shad=0A=0A=0A ________________________________________________________________________________
Date: Aug 09, 2009
Next time.don't hold back. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Sunday, August 09, 2009 5:09 PM Subject: RE: Pietenpol-List: Re: landing at Oshkosh on Sunday To All Pilots, F%&# the FAA. They are usually just a bunch of gestapo self rightoius power hungry wenies who don't even know what an airplane is. A fellow Piet builder who I won't mention his name, said that the faa is nothing but a rotation of a__ holes, and he spent 20+ years working for them. I think the job requirements for being in the faa is heartbeat, no soul, and you must not know anything practical about anything aviation related (besides the letter of the law). I think the same goes for the aircraft maintenance side of the FAA, worthless! Most faa maintenance inspectors today are there because the sucked as mechanics. This, of course is my own generalized oppinion, formed from 15+ years in aviation, both as a pilot, and a mechanic. I know at one time many many years ago (while the earth was still cooling) the faa guys were the experianced, and sharpest guys in the field (maybe?). But that ain't the case anymore sonny. Sincerly, You know who P.S. any FAA guys reading this, go study airplanes, and real world flying skill, instead of therory, law and textbook answers to real world experiance problems. ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Aug 09, 2009
Aw, come on guys, the FAA and the IRS are here to help ya. Gene in Very hot Tennessee ----- Original Message ----- From: Gary Boothe To: pietenpol-list(at)matronics.com Sent: Sunday, August 09, 2009 7:15 PM Subject: RE: Pietenpol-List: Re: landing at Oshkosh on Sunday Next time.don't hold back. ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Sunday, August 09, 2009 5:09 PM To: pietenpol-list(at)matronics.com Subject: RE: Pietenpol-List: Re: landing at Oshkosh on Sunday To All Pilots, F%&# the FAA. They are usually just a bunch of gestapo self rightoius power hungry wenies who don't even know what an airplane is. A fellow Piet builder who I won't mention his name, said that the faa is nothing but a rotation of a__ holes, and he spent 20+ years working for them. I think the job requirements for being in the faa is heartbeat, no soul, and you must not know anything practical about anything aviation related (besides the letter of the law). I think the same goes for the aircraft maintenance side of the FAA, worthless! Most faa maintenance inspectors today are there because the sucked as mechanics. This, of course is my own generalized oppinion, formed from 15+ years in aviation, both as a pilot, and a mechanic. I know at one time many many years ago (while the earth was still cooling) the faa guys were the experianced, and sharpest guys in the field (maybe?). But that ain't the case anymore sonny. Sincerly, You know who P.S. any FAA guys reading this, go study airplanes, and real world flying skill, instead of therory, law and textbook answers to real world experiance problems. http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/09/09 18:10:00 ________________________________________________________________________________
Date: Aug 09, 2009
Aw, Shad, don't sugar-coat it. Tell us how you really feel. Back in the old days around here in Northern California our local FAA guy used to build more airplanes than the local EAA folks. Boy, do we ever miss him. And what's up with having to hire an engineer and send reams of paperwork to Kansas to get a "field approval" to make an old airplane safer. "We're from the FAA and we're here to help." Chilling words. On a cheerier note, our local tower guys were our guest speakers at our last EAA meeting. One of them is actually building his own light sport A/C, so there may be a glimmer of hope. All the best to the Pietenpol crowd from Sonoma, CA! Darrel shad bell wrote: > To All Pilots, F%&# the FAA. They are usually just a bunch of gestapo > self rightoius power hungry wenies who don't even know what an > airplane is. A fellow Piet builder who I won't mention his name, said > that the faa is nothing but a rotation of a__ holes, and he spent 20+ > years working for them. I think the job requirements for being in the > faa is heartbeat, no soul, and you must not know anything practical > about anything aviation related (besides the letter of the law). I > think the same goes for the aircraft maintenance side of the FAA, > worthless! Most faa maintenance inspectors today are there because > the sucked as mechanics. This, of course is my own generalized > oppinion, formed from 15+ years in aviation, both as a pilot, and a > mechanic. I know at one time many many years ago (while the earth was > still cooling) the faa guys were the experianced, and sharpest guys in > the field (maybe?). But that ain't the case anymore sonny. > > Sincerly, You know who > > P.S. any FAA guys reading this, go study airplanes, and real world > flying skill, instead of therory, law and textbook answers to real > world experiance problems. > > > * > > > * ________________________________________________________________________________
Date: Aug 09, 2009
Subject: Re: landing at Oshkosh on Sunday
Sorry to hear about the FAA fiasco Lowell, its enough to make a pilot look seriously into going part 103 for a next aircraft build project. I have been thinking seriously about a Legal Eagle XL for my next project. Good luck Rick On Sat, Aug 8, 2009 at 1:27 AM, Jared Yates wrote: > > Lowell, I've been through what you are going through, and I must say that > it > is can be an unpleasant experience. You aren't by chance enrolled in the > AOPA legal services plan, are you? I found first-hand that FAA inspectors > can try to overstep their power and duties quite regularly. Having someone > to ask "can they ask me that" made it much easier for me. > > It is a privilege that they have to re-evaluate any airman, at the airman's > expense. It stinks, but you'll have to take it seriously! If they don't > give you a satisfactory result to the checkride, you won't be able to fly > anymore. Respond before the deadline, and keep in mind that you don't have > to take the checkride within 10 days, you just have to respond. In my > case, > it was actually a month or two after the accident before the re-evaluation > ride. > > Also note that you aren't obliged to answer questions about the past. The > FAA inspectors know that they don't have the privilege of interrogating you > to try and get evidence for a violation. In my case they were trying to > use > the reevaluation ride as a chance to do just that. I spent a couple of > hours dodging questions about the accident flight and requesting that the > inspector stick to general questions about my qualifications to hold my > certificate. It was a diplomatic tightrope to say the least. I hope that > you end up with a good FSDO and inspector, and that your experience was > better than mine. Let them know that you are going to have trouble finding > a tailwheel airplane to rent, and that should buy you some time. You might > also consider hiring a specialized aviation lawyer if you are not in the > legal services plan, depending on how important it is to you that you > continue to hold your certificate. You can also find the inspector's > handbook online and read about what the boundries are for the checkride, as > far as what they should and shouldn't be asking you about. > > >From this point on, take notes about who you talk to at the FAA/NTSB, > including the date and time, and a brief summary of the discussion. In my > case my file fell between the cracks on their end, and they tried to accuse > me of avoiding the checkride, when they had actually not been returning my > phone calls. This is the kind of thing you might be up against! The folks > at both the NTSB and the FAA are not your friend. As for the rest of you, > think seriously about that legal services plan! As some have said, this > type of thing can happen to any of us. > > Hang in there! You can do this, but be smart about it. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Pieti > Lowell > Sent: Friday, August 07, 2009 10:02 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: landing at Oshkosh on Sunday > > > > You fellows ,I don't think you know the half of it, I got a registered > letter late Friday , dated Thursday, saying that I have 10 days from the > letter's date to respond to FAA regarding practically redoing my complete > Private License Tests learning over, from getting a tail dragger to be > retested , check ride , Area operations III,, IV etc, Where does one begin > ? > so far dozens of phone calls just to find an Instructor with a conventional > gear plane, and when asked if it would be OK to take my check-ride in a > Pietenpol HA only certified craft with ALL paper work on the plane > complete. and it goes on and on. Still no airplanes yet available and I > don't blame anyone to get involved , what a hassle and with over 2000 tail > dragger hours. > Pieti Lowell > > Wednesday during the Homebuilt Review Showcase (where they shafted one of > our three Pietenpol guys--Jack Phillips by cutting one of the Piets out of > the event) the Rotec powered Junior Ace from Poplar Grove nearly lost it in > similar wind conditions when landing. Three times he nearly had his wing > tips in the turf--scary stuff but he managed to add power, continue down > the > runway and get a second chance. > > I was astonished at the ineptitude of the EAA/FAA/and law enforcement > people > who kept Lowell and his plane out on the runway for well over an hour. > First off---Lowell's well being, once that was established to not be an > issue they should have cleared off and talked with him elsewhere if they > needed to. I should know better--if the gov't is involved they will take > the least practical path to a conclusion. > > Mike C.[/quote] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256592#256592 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Hello I'm new here. I'm looking for a little help.
From: "motorbikemikexb9" <motorbikemikexb9(at)comcast.net>
Date: Aug 09, 2009
Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. I've been a fan of the Air Camper for several years now. I Love their classic look and feel, as well as the "top wing / open cockpit" design. I'm planning to get started building a Air Camper for myself very soon. I was up at Oshkosh last week and seeing them up close finally nudged me over the edge into deciding to build one. I have a pretty solid background in metal fabrication and wood working. I have also scratch built and flown dozens of giant scale R/C's over the past 10 years. I do know alot about airplanes but feel I still have alot to learn. I'm mostly concerned about airframe strength, Proper covering technique and figuring out what is needed to get a airframe / engine built safe and certified. This will be my first full scale build. All of my R/C's have been very safe good flying machines but I have never had to go through any certification process to fly them. I'm currently working on my private pilots license as well. To sum things up I'm looking for any information, pointers, or any good places to find information that will help me with my build. Some admediate concerns are: what plans to use?, what do you guys think is a better route to go: Wood or steel tube Fuse? What engines can be used? Are certain grades of fasteners or hardware recomended or required for this type of build. where is a good place to find books / DVD's covering full scale aircraft Building / covering / certification? Are their any local Air Camper builders near the Chicago/ Milwaukee area? Thanks In advance for any help. I plan to be a regular here on the forum and hopefully meet many of you in person "as or after" my plane comes together. Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256853#256853 ________________________________________________________________________________
Subject: landing at Oshkosh on Sunday
Date: Aug 09, 2009
I'll tell you another good one. Last year I got to fly the EA-6B Prowler simulator at Whidbey Naval Air Station. As I sat in the left seat of the sim with the throttles in my left hand and stick in my right, he voice in the headphones was the simulator operator, up in a darkened room somewhere. My buddy Maj. Kyle "Itchy" Rash was the right seater and my instructor. Incidentally, Itchy is up for promotion to LtCol next month, so the beer will soon be flowing. On my second or third attempt at landing the "Prowler" on the deck of a carrier at sea, the voice in the headphones asked, "flying left seat, what do you normally fly?" to which I responded, "ahhh, you probably don't know the airplane but it's an experimental single-engine, two-place high winger called a Pietenpol Air Camper". Silence, followed by, "I've always wanted to build one but I'm six foot four and don't think I'd fit. It's a great little airplane. Fly your final to the carrier deck just like you'd fly a short and soft field in the Piet. Give it a try." I nailed the next landing. There are some good folks out there on the other end of the radio, and I'll bet there are still some good folks in the FAA and NTSB too. We just need to get them into a Piet and when we're done flying, sit them in a chair outside the hangar some evening, project "The Great Waldo Pepper" on the side of the hangar wall, and hand them a beer. Oscar Zuniga Air Camper NX41CC- A75 with Culver prop San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 09, 2009
Subject: Re: Hello I'm new here. I'm looking for a little help.
Welcome to the best place for the best information on your intended build. There are DVDs available from fellow builders. Mike Cuy has a really good one along with other Piet builders. The books by Tony Bengellis are a must for the builders library. The plans are available through the pietenpol family so they are easily gotten and would recommend you join the BPA for the news letter. You just missed the Brodhead gathering where you can see the piets up close talk to the builders and get some really great advice while stealing ideas. Who knows with the number of piets in Illinois you can visit some in progress of building and get a chance to ride in some already built. The folks you'll meet on this board and in person in Brodhead are some of the best folks you'll ever meet most are friendly and ready to lend advice. Building a Piet is rewarding on to itself and the journey is spectacular plus you'll end up with a great airplane and a bunch of new friends. I think you made 2 wise choices on in building the Piet and the second was to come here. Enjoy the adventure John message dated 8/9/2009 9:49:43 P.M. Eastern Daylight Time, motorbikemikexb9(at)comcast.net writes: --> Pietenpol-List message posted by: "motorbikemikexb9" Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. I've been a fan of the Air Camper for several years now. I Love their classic look and feel, as well as the "top wing / open cockpit" design. I'm planning to get started building a Air Camper for myself very soon. I was up at Oshkosh last week and seeing them up close finally nudged me over the edge into deciding to build one. I have a pretty solid background in metal fabrication and wood working. I have also scratch built and flown dozens of giant scale R/C's over the past 10 years. I do know alot about airplanes but feel I still have alot to learn. I'm mostly concerned about airframe strength, Proper covering technique and figuring out what is needed to get a airframe / engine built safe and certified. This will be my first full scale build. All of my R/C's have been very safe good flying machines but I have never had to go through any certification process to fly them. I'm currently working on m! y private pilots license as well. To sum things up I'm looking for any information, pointers, or any good places to find information that will help me with my build. Some admediate concerns are: what plans to use?, what do you guys think is a better route to go: Wood or steel tube Fuse? What engines can be used? Are certain grades of fasteners or hardware recomended or required for this type of build. where is a good place to find books / DVD's covering full scale aircraft Building / covering / certification? Are their any local Air Camper builders near the Chicago/ Milwaukee area? Thanks In advance for any help. I plan to be a regular here on the forum and hopefully meet many of you in person "as or after" my plane comes together. Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256853#256853 ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Aug 09, 2009
Mike, Step one is to read all the books by Tony Bingelis. They are available everywhere, but the easiest place to get them is either Aircraft Spruce or Wicks. I'd post a link, but I'm typing on my phone... Next step is to get a complete set of plans from the Pietenpol family. Also, the EAA sells the old Flying and Glider Manuals with the original build article and "plans". With regards to hardware store nuts and bolts, I think Mike Cuy said it best, "you can use whatever hardware store parts you want, but you won't be taking any oc my family flying". (or something like that)... Point is, use aircraft grade hardware abc materials. It's not worth the cost savings. And the last piece of advice I'll give is this: memorize every line from The Great Waldo Pepper. You'll need the knowledge to decipher what's actually being said on this list. Wayne Bressler Jr. Not building yet. Still dreaming and planning! Taildraggers, Inc. taildraggersinc.com Sent from the phone that made the Blackberry obsolete. On Aug 9, 2009, at 9:47 PM, "motorbikemikexb9" wrote: > > > > Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. > I've been a fan of the Air Camper for several years now. I Love > their classic look and feel, as well as the "top wing / open > cockpit" design. I'm planning to get started building a Air Camper > for myself very soon. I was up at Oshkosh last week and seeing them > up close finally nudged me over the edge into deciding to build > one. I have a pretty solid background in metal fabrication and wood > working. I have also scratch built and flown dozens of giant scale > R/C's over the past 10 years. I do know alot about airplanes but > feel I still have alot to learn. I'm mostly concerned about > airframe strength, Proper covering technique and figuring out what > is needed to get a airframe / engine built safe and certified. This > will be my first full scale build. All of my R/C's have been very > safe good flying machines but I have never had to go through any > certification process to fly them. I'm currently working on m! > y private pilots license as well. > > To sum things up I'm looking for any information, pointers, or any > good places to find information that will help me with my build. > > Some admediate concerns are: > what plans to use?, what do you guys think is a better route to go: > Wood or steel tube Fuse? What engines can be used? Are certain > grades of fasteners or hardware recomended or required for this type > of build. where is a good place to find books / DVD's covering full > scale aircraft Building / covering / certification? Are their any > local Air Camper builders near the Chicago/ Milwaukee area? > > Thanks In advance for any help. I plan to be a regular here on the > forum and hopefully meet many of you in person "as or after" my > plane comes together. > > Thanks, Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256853#256853 > > ________________________________________________________________________________
Date: Aug 09, 2009
Hi Mike, I'm your confusing email address doppelganger, bike.mike. One of my bikes is a motorbike (BMW R100R) but the rest are human powered. Most of the guys on the list are fair-minded, reasonable people. However, there are a few of the "type A" sort who believe that a genuine "Pietenpol" Aircamper is made of wood, is powered by a Model A engine, and is built from a set of plans approved by Bernard H. Pietenpol (never say "Bernie"), signed by draftsman Orrin Hoopman, and sold by the Pietenpol family. Most of this crowd is extremely helpful, freely giving of their combined centuries of experience building and flying this magnificent flying machine. In the heartland of America you have access to many brilliant examples of Piets built by every sort of craftsman; visit them and you will acquire a list of lifelong friends. As to your specific questions, there will be many answers from the various camps regarding the merits of wood over steel, Model A over Corvair over Continental over Rotec, and even the merits of Home Depot over Wicks over Aircraft Spruce and Specialty. Be prepared to do some of your own research. Welcome to the coolest list-serve in the world. Mike Hardaway -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of motorbikemikexb9 Sent: Sunday, August 09, 2009 6:48 PM Subject: Pietenpol-List: Hello I'm new here. I'm looking for a little help. --> Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. I've been a fan of the Air Camper for several years now. I Love their classic look and feel, as well as the "top wing / open cockpit" design. I'm planning to get started building a Air Camper for myself very soon. I was up at Oshkosh last week and seeing them up close finally nudged me over the edge into deciding to build one. I have a pretty solid background in metal fabrication and wood working. I have also scratch built and flown dozens of giant scale R/C's over the past 10 years. I do know alot about airplanes but feel I still have alot to learn. I'm mostly concerned about airframe strength, Proper covering technique and figuring out what is needed to get a airframe / engine built safe and certified. This will be my first full scale build. All of my R/C's have been very safe good flying machines but I have never had to go through any certification process to fly them. I'm currently working on m! y private pilots license as well. To sum things up I'm looking for any information, pointers, or any good places to find information that will help me with my build. Some admediate concerns are: what plans to use?, what do you guys think is a better route to go: Wood or steel tube Fuse? What engines can be used? Are certain grades of fasteners or hardware recomended or required for this type of build. where is a good place to find books / DVD's covering full scale aircraft Building / covering / certification? Are their any local Air Camper builders near the Chicago/ Milwaukee area? Thanks In advance for any help. I plan to be a regular here on the forum and hopefully meet many of you in person "as or after" my plane comes together. Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256853#256853 ________________________________________________________________________________
Subject: Re Fuel vents
Date: Aug 10, 2009
Intend to use a cork float on a wire thru the fuel cap as a fuel quantity gage Will this double as a fuel vent without any probs? Thanks Graham Hewitt in Oz ________________________________________________________________________________
Date: Aug 10, 2009
Let's get this straight she's just driving, you're just flying. I'm the one doing a great stunt. John Sent from my Verizon Wireless BlackBerry -----Original Message----- From: Wayne Bressler <wayne(at)taildraggersinc.com> Date: Sun, 9 Aug 2009 22:28:04 Subject: Re: Pietenpol-List: Hello I'm new here. I'm looking for a little help. Mike, Step one is to read all the books by Tony Bingelis. They are available everywhere, but the easiest place to get them is either Aircraft Spruce or Wicks. I'd post a link, but I'm typing on my phone... Next step is to get a complete set of plans from the Pietenpol family. Also, the EAA sells the old Flying and Glider Manuals with the original build article and "plans". With regards to hardware store nuts and bolts, I think Mike Cuy said it best, "you can use whatever hardware store parts you want, but you won't be taking any oc my family flying". (or something like that)... Point is, use aircraft grade hardware abc materials. It's not worth the cost savings. And the last piece of advice I'll give is this: memorize every line from The Great Waldo Pepper. You'll need the knowledge to decipher what's actually being said on this list. Wayne Bressler Jr. Not building yet. Still dreaming and planning! Taildraggers, Inc. taildraggersinc.com Sent from the phone that made the Blackberry obsolete. On Aug 9, 2009, at 9:47 PM, "motorbikemikexb9" wrote: > > > > Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. > I've been a fan of the Air Camper for several years now. I Love > their classic look and feel, as well as the "top wing / open > cockpit" design. I'm planning to get started building a Air Camper > for myself very soon. I was up at Oshkosh last week and seeing them > up close finally nudged me over the edge into deciding to build > one. I have a pretty solid background in metal fabrication and wood > working. I have also scratch built and flown dozens of giant scale > R/C's over the past 10 years. I do know alot about airplanes but > feel I still have alot to learn. I'm mostly concerned about > airframe strength, Proper covering technique and figuring out what > is needed to get a airframe / engine built safe and certified. This > will be my first full scale build. All of my R/C's have been very > safe good flying machines but I have never had to go through any > certification process to fly them. I'm currently working on m! > y private pilots license as well. > > To sum things up I'm looking for any information, pointers, or any > good places to find information that will help me with my build. > > Some admediate concerns are: > what plans to use?, what do you guys think is a better route to go: > Wood or steel tube Fuse? What engines can be used? Are certain > grades of fasteners or hardware recomended or required for this type > of build. where is a good place to find books / DVD's covering full > scale aircraft Building / covering / certification? Are their any > local Air Camper builders near the Chicago/ Milwaukee area? > > Thanks In advance for any help. I plan to be a regular here on the > forum and hopefully meet many of you in person "as or after" my > plane comes together. > > Thanks, Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256853#256853 > > ________________________________________________________________________________
Date: Aug 09, 2009
Frankly, most of the FAA employees I have met are themselves pilots and/or mechanics, most with considerably more than 15 years of experience, who love airplanes and aviation the business of keeping it all safe. Several are airplane builders. But then I have only received the business end of one "inquiry" (inquisition really, but I learned a lot about density altitude). Any large collection of people is going to have a few fools and the FAA is not exempt. Shad, I'm sorry that your experiences have only brought those exceptions to the surface. Mike (one of many) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Sunday, August 09, 2009 5:09 PM Subject: RE: Pietenpol-List: Re: landing at Oshkosh on Sunday To All Pilots, F%&# the FAA. They are usually just a bunch of gestapo self rightoius power hungry wenies who don't even know what an airplane is. A fellow Piet builder who I won't mention his name, said that the faa is nothing but a rotation of a__ holes, and he spent 20+ years working for them. I think the job requirements for being in the faa is heartbeat, no soul, and you must not know anything practical about anything aviation related (besides the letter of the law). I think the same goes for the aircraft maintenance side of the FAA, worthless! Most faa maintenance inspectors today are there because the sucked as mechanics. This, of course is my own generalized oppinion, formed from 15+ years in aviation, both as a pilot, and a mechanic. I know at one time many many years ago (while the earth was still cooling) the faa guys were the experianced, and sharpest guys in the field (maybe?). But that ain't the case anymore sonny. Sincerly, You know who P.S. any FAA guys reading this, go study airplanes, and real world flying skill, instead of therory, law and textbook answers to real world experiance problems. ________________________________________________________________________________
Date: Aug 09, 2009
Welcome Mike! As a newbie myself here I am just chipping in to say that I ave asked a rash of questions and never been chewed out once, even though some (many?) were repeats from previous posts. There is an achive that can be searched to get a few answers from, and that was where I was directed a couple of times for more in-depth answers that had been chewed on a while before I came on board. I too am an R/C builder for 40 years, and alas, have finally graduated to the real deal. In fact (horror of horrors), tomorrow a friend of mine is coming over to clean out the entire lot of my R/C stuff. I'll have a very bare garage, as just about every corner of the place is stuffed with R/C materials of one sort or another. However, I am too big to fit into any of those, and I need the room and the money for Piet building! Oh well, if I had seen the Great Waldo Pepper movie (sorry) I'd know a line that would address that problem :o) I guess I need to get over to BlockBusters this week (now that I know where all those lines have come from!) Welcome to a great bunch of guys from all over the place! Mark On Sun, Aug 9, 2009 at 7:40 PM, wrote: > > Let's get this straight she's just driving, you're just flying. I'm the one > doing a great stunt. > > > John > Sent from my Verizon Wireless BlackBerry > > -----Original Message----- > From: Wayne Bressler <wayne(at)taildraggersinc.com> > > Date: Sun, 9 Aug 2009 22:28:04 > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Hello I'm new here. I'm looking for a little > help. > > > wayne(at)taildraggersinc.com> > > Mike, > > Step one is to read all the books by Tony Bingelis. They are > available everywhere, but the easiest place to get them is either > Aircraft Spruce or Wicks. I'd post a link, but I'm typing on my > phone... > > Next step is to get a complete set of plans from the Pietenpol > family. Also, the EAA sells the old Flying and Glider Manuals with > the original build article and "plans". > > With regards to hardware store nuts and bolts, I think Mike Cuy said > it best, "you can use whatever hardware store parts you want, but you > won't be taking any oc my family flying". (or something like that)... > Point is, use aircraft grade hardware abc materials. It's not worth > the cost savings. > > And the last piece of advice I'll give is this: memorize every line > from The Great Waldo Pepper. You'll need the knowledge to decipher > what's actually being said on this list. > > Wayne Bressler Jr. > > Not building yet. Still dreaming and planning! > > Taildraggers, Inc. > taildraggersinc.com > > Sent from the phone that made the Blackberry obsolete. > > On Aug 9, 2009, at 9:47 PM, "motorbikemikexb9" < > motorbikemikexb9(at)comcast.net > > wrote: > > motorbikemikexb9(at)comcast.net > > > > > > > Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. > > I've been a fan of the Air Camper for several years now. I Love > > their classic look and feel, as well as the "top wing / open > > cockpit" design. I'm planning to get started building a Air Camper > > for myself very soon. I was up at Oshkosh last week and seeing them > > up close finally nudged me over the edge into deciding to build > > one. I have a pretty solid background in metal fabrication and wood > > working. I have also scratch built and flown dozens of giant scale > > R/C's over the past 10 years. I do know alot about airplanes but > > feel I still have alot to learn. I'm mostly concerned about > > airframe strength, Proper covering technique and figuring out what > > is needed to get a airframe / engine built safe and certified. This > > will be my first full scale build. All of my R/C's have been very > > safe good flying machines but I have never had to go through any > > certification process to fly them. I'm currently working on m! > > y private pilots license as well. > > > > To sum things up I'm looking for any information, pointers, or any > > good places to find information that will help me with my build. > > > > Some admediate concerns are: > > what plans to use?, what do you guys think is a better route to go: > > Wood or steel tube Fuse? What engines can be used? Are certain > > grades of fasteners or hardware recomended or required for this type > > of build. where is a good place to find books / DVD's covering full > > scale aircraft Building / covering / certification? Are their any > > local Air Camper builders near the Chicago/ Milwaukee area? > > > > Thanks In advance for any help. I plan to be a regular here on the > > forum and hopefully meet many of you in person "as or after" my > > plane comes together. > > > > Thanks, Mike > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=256853#256853 > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2009
Hey Oscar: I'm 6'4" 250lbs... I hope I can fit! (I'm working on the diet... So far it's been the 'High Weight Gain Diet' promoted by Michael Moore... but who listens to him!?) Mark On Sun, Aug 9, 2009 at 7:09 PM, Oscar Zuniga wrote: > > > I'll tell you another good one. Last year I got to fly the EA-6B > Prowler simulator at Whidbey Naval Air Station. As I sat in the left > seat of the sim with the throttles in my left hand and stick in my > right, he voice in the headphones was the simulator operator, up > in a darkened room somewhere. My buddy Maj. Kyle "Itchy" Rash was > the right seater and my instructor. Incidentally, Itchy is up for > promotion to LtCol next month, so the beer will soon be flowing. > > On my second or third attempt at landing the "Prowler" on the deck > of a carrier at sea, the voice in the headphones asked, "flying left > seat, what do you normally fly?" to which I responded, "ahhh, you > probably don't know the airplane but it's an experimental > single-engine, two-place high winger called a Pietenpol Air Camper". > > Silence, followed by, "I've always wanted to build one but I'm six > foot four and don't think I'd fit. It's a great little airplane. > Fly your final to the carrier deck just like you'd fly a short and > soft field in the Piet. Give it a try." > > I nailed the next landing. > > There are some good folks out there on the other end of the radio, > and I'll bet there are still some good folks in the FAA and NTSB > too. We just need to get them into a Piet and when we're done > flying, sit them in a chair outside the hangar some evening, project > "The Great Waldo Pepper" on the side of the hangar wall, and > hand them a beer. > > Oscar Zuniga > Air Camper NX41CC- A75 with Culver prop > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Aug 09, 2009
Subject: Re: Re Fuel vents
That setup worked on our Piet for years. However, I don't think it's a good idea. We now have another hole in the cap, fitted with an aluminum tube bent 90 degrees, facing forward. Cheap redundancy. >Intend to use a cork float on a wire thru the fuel cap as a fuel quantity gage > >Will this double as a fuel vent without any probs? >Thanks Graham Hewitt in Oz ________________________________________________________________________________
Date: Aug 09, 2009
.been working on Taylorcrafts for over 60 years! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) Intend to use a cork float on a wire thru the fuel cap as a fuel quantity gage Will this double as a fuel vent without any probs? Thanks Graham Hewitt in Oz ________________________________________________________________________________
Subject: Re: door cutout
Date: Aug 10, 2009
Might as well go for broke and use carbon fibre. If you can't simplicate, add lightness. :-) Clif The ultimate futility is a job well done that served no purpose in the first place. ----- Original Message ----- From: "Tim Willis" <timothywillis(at)earthlink.net> Sent: Sunday, August 09, 2009 12:59 PM Subject: RE: Pietenpol-List: door cutout > > > > Oscar as a good idea with the foam and glass. The cutout may be > reinforced like the rest of the plane, as well; for instance, with 1' > thick ply or spruce for some of the infill, with ply gussets inboard of > that, and of course the outside ply skin. It's plenty strong. As in the > rest of the plane, the key is triangulation with diagonals and bonding > with gussets. > > Tim in central TX > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 18:10:00 ________________________________________________________________________________
Date: Aug 10, 2009
A certain somebody I know, who built a model B powered Piet, upon my questioning the difficulty of someone getting into the front of his plane with standard length struts, looked at me kind of sideways with an impish little grin and said; " That's not my seat." Clif "It is precisely from the regret left by the imperfect work that another can be born." (Odilon Redon) I must agree with you there! And besides, door or no door, I will still get to fly! :o) So, it really depends on how badly the passenger wants to go with me!! :oD Mark ________________________________________________________________________________
Date: Aug 10, 2009
?" I really do love you Maudy"............. ?"Except in flying weather" ________________________________________________________________________________
Date: Aug 10, 2009
The ultimate futility is a job well done that served no purpose in the first place. During the last 10 years of building, I have added, and then eliminated, a number of these myself. Dan Helsper Poplar Grove, IL. ? ? ________________________________________________________________________________
Subject: Welcome-new guy
Date: Aug 10, 2009
Hi Mike, Welcome to the list. Every former RC builder that I know turned out to be a?superb "real" airplane builder. Lon Deinst who lives on the same field I do, used to be an RC guy. He is a prolific homebuilder, and a very good one at that. Anyone who was at Oshkosh might have seen his replica (built only from two old drawings and a few photos) of Art Chester's 1930 racer, the "Jeep" parked over along the creek by the Theatre in the Woods. Unbelievable craftsmanship and built to exact detail (better than the one that is in the museum that is just cobbled together). So you know more than you think you do. This is just a big model. And don't worry about getting it "certified", they give you 40 hours to kill yourself before they let you harm any passengers :O) Dan Helsper Poplar Grove, IL ________________________________________________________________________________
Date: Aug 10, 2009
Mike, You've already gotten some good advice (and a good dose of lines from The Great Waldo Pepper). Buy the Bingelis books. Apart from being a wealth of good information about all kinds of things you'll need to know to build an airplane (just how much do you know about venting fuel systems, or bleeding brakes? - Those are just a couple of topics he covers well), the books are well written and are interesting reading. As for the questions that invariably come up whenever a new builder gets started, I'll try to list them and will give my opinion on them. You know what they say about opinions - they are like rectums. Everybody's got one and most are full of s--t. What Plans to use? Buy the plans from Andrew Pietenpol (Bernard's grandson). http://www.pressenter.com/~apietenp/ I would also recommend buying the reprint of the 1932 Flying and Glider Manual that EAA publishes. It has the original plans and a commentary from Pietenpol on building that is enjoyable reading. Wood or steel? - Your choice. Anecdotal evidence indicates the steel tube fuselages are lighter. However, they require more planning because you have to weld on fittings for any attachments, rather than just screwing something onto the wood. What engine? - just about everything has been used, from Model A Fords to Szekely 3-cylinder radials to Continentals to Corvairs. Some work better than others. Purists would say that you should use what Pietenpol used, but that covers the gamut above. My personal choice is to use a small Continental (I have an A65, but if I did it over I would probably use an O-200). I live in North Carolina (soon to be moving to the Blue Ridge Mountains of Virginia) and an engine failure in this part of the country is not to be taken lightly. Therefore I want the most reliable engine I can find and it is hard to beat the small Continentals for reliability. Many Piet builders are using Corvairs now, because Pietenpol did it and they are cheap and powerful. They also (in my opinion) are not terribly reliable. Shad Bell knows more about Corvairs than anyone, based on personal FLYING experience and he has had a number of serious failures with his. He also lives in the midwest and I think that is key - every year when I fly mine to Brodhead I breathe a sigh of relief when I cross over the Ohio River and enter the midwest, where the biggest problem in a forced landing is choosing which of a dozen acceptable landing fields is the BEST field. Prior to crossing the Ohio, I think I counted 4 fields that I passed over in Virginia and West Virginia where I could land the Pietenpol and be able to take off again without damaging it. Since you live in the midwest, your engine choice is a little more open. What wood? You didn't ask this, but you will. Again, since this is my email, you get my opinion. I like aircraft grade Sitka Spruce. It has the best strength to weight ratio of any wood, is wonderful to work (doesn't splinter like fir does) and while expensive, it also offers great piece of mind since you don't have to worry if you found all the defects in wood you selected at a lumber yard. Even though it is expensive, the cost of all the wood in the airplane is a small fraction of the total cost of the project. I basically spared no expense in building mine and the total cost of the entire airplane was right at $15,000 which was spread over 8 years of building (I like to tell people I spent the same amount building that airplane that a 2-pack a day smoker would have spent on cigarettes in the same timeframe). Of that amount, all the wood totaled about $1,000. What Glue? Most people use T-88 (I did too in the cockpit area where it shows). I like Resorcinol. Epoxies are fine, but even now the only glue the FAA allows for use when repairing or rebuilding a certificated aircraft is Resorcinol. I like working with it, even though it is more troublesome than epoxy (joints have to fit perfectly because resorcinol will not fill a gap like epoxy will). Hardware? Again, I like certified aircraft parts. It costs a bit more, but you know what you've got instead of hoping that the cheap Chinese steel in those Home Depot bolts can stand the load holding your lift struts to your wing. It also helps convince the DAR or FAA inspector that you know what you're doing when they are inspecting your craft to give you the Airworthiness Certificate. Aircraft Spruce & Specialty sells a kit with an assortment of AN hardware that will cover most of your needs. BTW, order their catalog (www.aircraftspruce.com) . They are a good source (if a bit pricey) for nearly everything you will need, and their catalog has a lot of good information in it. The catalog is free. DVD's? Someone already mentioned Mike Cuy's excellent DVD. It is available through Glenn Thomas' website www.flyingwood.com , under "Inspiration". Also listed there is Chuck Gantzer's DVD on flying NX770CG, which is also worth having. There are other DVD's being offered, but these are the only two I know of from people who have actually finished and flown their Air Campers. Local Pietenpol Builders in the Milwaukee/Chicago area? I know of several, but will let them come forth on their own. You are certainly close enough to Brodhead that you should plan to attend there every year (it is always the weekend before that other Wisconsin fly-in) Join the EAA - While many of us feel the EAA lately has turned their back on homebuilders, especially those of us who are not building from kits, they still are a worthwhile organization to support. They offer a lot of books and sources of information that you will need. Join a good local chapter if you can. Learn to fly before you finish your Pietenpol - I love flying my Pietenpol, but it is not an ideal trainer for a number of reasons. I recommend you get your license in something more conventional, then get your tailwheel training in a Piper J-3 Cub before trying to fly your Pietenpol. If you can find a place where you can do all your training in a Cub, even better. I know Steve Krog at Hartford Wisconsin still trains in Cubs. I'm not sure how far that is from Palatine IL. There may be Cubs for rent at Poplar Grove (C77). That's pretty neat airport, with a lot of homebuilding and Vintage Aircraft activity. OK - I've aired my opinions. Let the flames begin! Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC - Smith Mountain Lake, VA -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of motorbikemikexb9 Sent: Sunday, August 09, 2009 9:48 PM Subject: Pietenpol-List: Hello I'm new here. I'm looking for a little help. Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. I've been a fan of the Air Camper for several years now. I Love their classic look and feel, as well as the "top wing / open cockpit" design. I'm planning to get started building a Air Camper for myself very soon. I was up at Oshkosh last week and seeing them up close finally nudged me over the edge into deciding to build one. I have a pretty solid background in metal fabrication and wood working. I have also scratch built and flown dozens of giant scale R/C's over the past 10 years. I do know alot about airplanes but feel I still have alot to learn. I'm mostly concerned about airframe strength, Proper covering technique and figuring out what is needed to get a airframe / engine built safe and certified. This will be my first full scale build. All of my R/C's have been very safe good flying machines but I have never had to go through any certification process to fly them. I'm currently working on m! y private pilots license as well. To sum things up I'm looking for any information, pointers, or any good places to find information that will help me with my build. Some admediate concerns are: what plans to use?, what do you guys think is a better route to go: Wood or steel tube Fuse? What engines can be used? Are certain grades of fasteners or hardware recomended or required for this type of build. where is a good place to find books / DVD's covering full scale aircraft Building / covering / certification? Are their any local Air Camper builders near the Chicago/ Milwaukee area? Thanks In advance for any help. I plan to be a regular here on the forum and hopefully meet many of you in person "as or after" my plane comes together. Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256853#256853 ________________________________________________________________________________
Subject: Axle Pad
Date: Aug 10, 2009
Straight Axle Guys, Upon the suggestion by PF Beck that a rubber pad under the axle would eliminate a lot of wear and tear, I decided to incorporate one during the set-up of my axle and brakes. My brake design is a copy-cat from Larry Williams, with one very important difference - his is yellow, mine is black. I even ran the anti-rotation rods thru the Hickory block! (Thanks, Larry) Many years ago, a friend had a contract to install rubber padding in horse stalls; the kind that would go on concrete, hold up to the heavy abuse of hooves, and be ergonomic. He had a lot of leftover pieces, which he gave to me and I use for floor padding in my shop.to go over the concrete, hold up to heavy abuse, and be ergonomic.. In the attachment you can see that I have run the anti-rotation rod thru the rubber, but have not yet come up with a good looking solution to fasten down the ends. Nevertheless, I have lots of this stuff; enough for about 15 or 20 Piets! It's easy to cut on a band saw, and I would be happy to send out strips to anyone who thinks this is useful. Maybe you could just cover the price of postage. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) DISCLAIMER: THIS IS NOT FLIGHT TESTED, TAXI TESTED, OR STANDING STILL IN THE HANGER FOR 6 MONTHS TESTED. HECK, I DON'T EVEN KNOW IF IT'S A PROBLEM, BUT IF PF RECOMMENDS IT.IT'S WORTH CONSIDERING! ________________________________________________________________________________
Date: Aug 10, 2009
Subject: N8031 pictures across America
Hi all, Tres and his flying buddy took a bunch of pictures as they flew N8031 across the country from SBP to OSH. He posted them here: http://picasaweb.google.com/TresClements/Pietenpol2009# Looking at these, I do not miss living in the Sonoran Desert (Tucson). Enjoy! Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 10, 2009
Dan, The whole thing just adds a very interesting chapter to that plane! I followed its progress on the 'SPOT' web site (thanks for posting that), until it was time to leave for Brodhead. Happy flying! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum Sent: Monday, August 10, 2009 7:06 AM Subject: Pietenpol-List: N8031 pictures across America Hi all, Tres and his flying buddy took a bunch of pictures as they flew N8031 across the country from SBP to OSH. He posted them here: http://picasaweb.google.com/TresClements/Pietenpol2009# Looking at these, I do not miss living in the Sonoran Desert (Tucson). Enjoy! Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov Fermilab. Just zeros and ones. ________________________________________________________________________________
Date: Aug 10, 2009
Mike, In addition to the Bingelis books, I would highly recommend Chet Peek's book 'The Pietenpol Story'; not so much for the technical information but because it is a very well written history of the Bernard Pietenpol and his aircraft. You can get it directly from Chet: http://www.threepeakspub.com/. There is also a short film that documents the Pietenpol history, 'Finding Flight'. It's very well done, and entertaining as well: http://www.pietenpolmovie.com/ Jack mentioned Poplar Grove.....it's a great airport, and they have a Piper Cub and a Cessna 140 available for rent/instruction. You can find more info at: http://www.poplargroveairmotive.com/home.htm. Plus you can visit Dan Helsper at PG, and he can show you the proper way to build a 'correct' Pietenpol. ;) My wife Jess and I are building a Corvair powered Pietenpol. We've got ribs on spars, and a basic fuselage. We also have just about every part we need to assemble our Corvair, from overhaul to conversion parts. Our Piet is now based at it's new home at Olson Airport (LL53), which is a little airport just southwest of Elgin, off of Rt 47. There is now also a flying Piet at Olson, with the addition of Dan Yocum's new baby. All for now, have a good day, Ryan On Mon, Aug 10, 2009 at 7:31 AM, Jack Phillips wrote: > Mike, > > You've already gotten some good advice (and a good dose of lines from The > Great Waldo Pepper). Buy the Bingelis books. Apart from being a wealth of > good information about all kinds of things you'll need to know to build an > airplane (just how much do you know about venting fuel systems, or bleeding > brakes? - Those are just a couple of topics he covers well), the books are > well written and are interesting reading. > > As for the questions that invariably come up whenever a new builder gets > started, I'll try to list them and will give my opinion on them. You know > what they say about opinions - they are like rectums. Everybody's got one > and most are full of s--t. > > What Plans to use? Buy the plans from Andrew Pietenpol (Bernard's > grandson). http://www.pressenter.com/~apietenp/> I would also recommend > buying the reprint of the 1932 Flying and Glider Manual that EAA publishes. > It has the original plans and a commentary from Pietenpol on building that > is enjoyable reading. > > Wood or steel? - Your choice. Anecdotal evidence indicates the steel tube > fuselages are lighter. However, they require more planning because you > have > to weld on fittings for any attachments, rather than just screwing > something > onto the wood. > > What engine? - just about everything has been used, from Model A Fords to > Szekely 3-cylinder radials to Continentals to Corvairs. Some work better > than others. Purists would say that you should use what Pietenpol used, > but > that covers the gamut above. My personal choice is to use a small > Continental (I have an A65, but if I did it over I would probably use an > O-200). I live in North Carolina (soon to be moving to the Blue Ridge > Mountains of Virginia) and an engine failure in this part of the country is > not to be taken lightly. Therefore I want the most reliable engine I can > find and it is hard to beat the small Continentals for reliability. Many > Piet builders are using Corvairs now, because Pietenpol did it and they are > cheap and powerful. They also (in my opinion) are not terribly reliable. > Shad Bell knows more about Corvairs than anyone, based on personal FLYING > experience and he has had a number of serious failures with his. He also > lives in the midwest and I think that is key - every year when I fly mine > to > Brodhead I breathe a sigh of relief when I cross over the Ohio River and > enter the midwest, where the biggest problem in a forced landing is > choosing > which of a dozen acceptable landing fields is the BEST field. Prior to > crossing the Ohio, I think I counted 4 fields that I passed over in > Virginia > and West Virginia where I could land the Pietenpol and be able to take off > again without damaging it. Since you live in the midwest, your engine > choice is a little more open. > > What wood? You didn't ask this, but you will. Again, since this is my > email, you get my opinion. I like aircraft grade Sitka Spruce. It has the > best strength to weight ratio of any wood, is wonderful to work (doesn't > splinter like fir does) and while expensive, it also offers great piece of > mind since you don't have to worry if you found all the defects in wood you > selected at a lumber yard. Even though it is expensive, the cost of all > the > wood in the airplane is a small fraction of the total cost of the project. > I basically spared no expense in building mine and the total cost of the > entire airplane was right at $15,000 which was spread over 8 years of > building (I like to tell people I spent the same amount building that > airplane that a 2-pack a day smoker would have spent on cigarettes in the > same timeframe). Of that amount, all the wood totaled about $1,000. > > What Glue? Most people use T-88 (I did too in the cockpit area where it > shows). I like Resorcinol. Epoxies are fine, but even now the only glue > the FAA allows for use when repairing or rebuilding a certificated aircraft > is Resorcinol. I like working with it, even though it is more troublesome > than epoxy (joints have to fit perfectly because resorcinol will not fill a > gap like epoxy will). > > Hardware? Again, I like certified aircraft parts. It costs a bit more, > but > you know what you've got instead of hoping that the cheap Chinese steel in > those Home Depot bolts can stand the load holding your lift struts to your > wing. It also helps convince the DAR or FAA inspector that you know what > you're doing when they are inspecting your craft to give you the > Airworthiness Certificate. Aircraft Spruce & Specialty sells a kit with an > assortment of AN hardware that will cover most of your needs. BTW, order > their catalog (www.aircraftspruce.com) . They are a good source (if a bit > pricey) for nearly everything you will need, and their catalog has a lot of > good information in it. The catalog is free. > > DVD's? Someone already mentioned Mike Cuy's excellent DVD. It is > available > through Glenn Thomas' website www.flyingwood.com , under "Inspiration". > Also listed there is Chuck Gantzer's DVD on flying NX770CG, which is also > worth having. There are other DVD's being offered, but these are the only > two I know of from people who have actually finished and flown their Air > Campers. > > Local Pietenpol Builders in the Milwaukee/Chicago area? I know of several, > but will let them come forth on their own. You are certainly close enough > to Brodhead that you should plan to attend there every year (it is always > the weekend before that other Wisconsin fly-in) > > Join the EAA - While many of us feel the EAA lately has turned their back > on > homebuilders, especially those of us who are not building from kits, they > still are a worthwhile organization to support. They offer a lot of books > and sources of information that you will need. Join a good local chapter > if > you can. > > Learn to fly before you finish your Pietenpol - I love flying my Pietenpol, > but it is not an ideal trainer for a number of reasons. I recommend you > get > your license in something more conventional, then get your tailwheel > training in a Piper J-3 Cub before trying to fly your Pietenpol. If you > can > find a place where you can do all your training in a Cub, even better. I > know Steve Krog at Hartford Wisconsin still trains in Cubs. I'm not sure > how far that is from Palatine IL. There may be Cubs for rent at Poplar > Grove (C77). That's pretty neat airport, with a lot of homebuilding and > Vintage Aircraft activity. > > OK - I've aired my opinions. Let the flames begin! > > Jack Phillips > NX899JP > "Icarus Plummet" > Raleigh, NC - Smith Mountain Lake, VA > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > motorbikemikexb9 > Sent: Sunday, August 09, 2009 9:48 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Hello I'm new here. I'm looking for a little help. > > > > Hello everyone. I'm Mike from Palatine IL. I'm taking the plunge. I've > been a fan of the Air Camper for several years now. I Love their classic > look and feel, as well as the "top wing / open cockpit" design. I'm > planning to get started building a Air Camper for myself very soon. I was > up at Oshkosh last week and seeing them up close finally nudged me over the > edge into deciding to build one. I have a pretty solid background in metal > fabrication and wood working. I have also scratch built and flown dozens > of > giant scale R/C's over the past 10 years. I do know alot about airplanes > but feel I still have alot to learn. I'm mostly concerned about airframe > strength, Proper covering technique and figuring out what is needed to get > a > airframe / engine built safe and certified. This will be my first full > scale build. All of my R/C's have been very safe good flying machines but > I > have never had to go through any certification process to fly them. I'm > currently working on m! > y private pilots license as well. > > To sum things up I'm looking for any information, pointers, or any good > places to find information that will help me with my build. > > Some admediate concerns are: > what plans to use?, what do you guys think is a better route to go: Wood or > steel tube Fuse? What engines can be used? Are certain grades of > fasteners > or hardware recomended or required for this type of build. where is a good > place to find books / DVD's covering full scale aircraft Building / > covering > / certification? Are their any local Air Camper builders near the Chicago/ > Milwaukee area? > > Thanks In advance for any help. I plan to be a regular here on the forum > and hopefully meet many of you in person "as or after" my plane comes > together. > > Thanks, Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256853#256853 > > ________________________________________________________________________________
Date: Aug 10, 2009
Brown, new guy, I'll get him when he gets down........ Shake him Waldo ________________________________________________________________________________
Date: Aug 10, 2009
Subject: Any Piets/Projects in the Freeport IL area?
In their infinite wisdom, my employer has decided to have me do some consulting.....several weeks AFTER Brodhead.....to a town a bit south of Brodhead, Freeport Illinois. Why they couldn't have done this a few weeks ago is a mystery to me! :-) Oh well. So is there anyone in that general area? I'll fly into Chicago late Sunday, Aug 23 and drive back to Chicago on Wednesday evening. Jim ________________________________________________________________________________
Date: Aug 10, 2009
Subject: Re: Enduring attributes of the Pietenpol design
Oh I never take kids up alone, I just told you that so you'd work for me ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Subject: Handheld Radio
Date: Aug 10, 2009
Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. ________________________________________________________________________________
Date: Aug 10, 2009
"Tennessee is mine. I've been flying that area for 2 years." _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 8:59 AM Subject: Pietenpol-List: Handheld Radio Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. ________________________________________________________________________________
Subject: Re: Any Piets/Projects in the Freeport IL area?
Date: Aug 10, 2009
Jim, Poplar Grove is only a few minutes out of your way either going or coming from Freeport. I am hanging around the house a lot lately and it would be great if you came by here. Email or call my cell 815-298-5680. If your evening was free it is not that far for an evening visit either after work. Dan H. -----Original Message----- From: Jim Markle <jim_markle(at)mindspring.com> Sent: Mon, Aug 10, 2009 9:49 am Subject: Pietenpol-List: Any Piets/Projects in the Freeport IL area? In their infinite wisdom, my employer has decided to have me do some consulting.....several weeks AFTER Brodhead.....to a town a bit south of Brodhead, Freeport Illinois. Why they couldn't have done this a few weeks ago is a mystery to me! :-) Oh well. So is there anyone in that general area? I'll fly into Chicago late Sunday, Aug 23 and drive back to Chicago on Wednesday evening. Jim ________________________________________________________________________________
Subject: Re: landing at Oshkosh on Sunday
Date: Aug 10, 2009
Lowell, in 2007 I had a right main gear strut failure and ground looped on the 09-28 runway at Morey. Needless to say the FAA wanted me to prove my flying competence in a certified tail dragger. I took the failed gear to Milw. FSDO to show them the gear was constructed from 0.058 wall tubing, not 0.074 as shown on the plans. Only got a glazed stare from the guy, like he nothing about steel strength. Also knew nothing about the Piet or homebuilts in general. After several letters and arguements about having to train in a J-3 and then hopefully rent it along with all the paperwork that belongs to the aircraft, he finally conceded and came to Moreys after I told him I repaired the plane and had been flying it all summer. He ended up standing out near the end of the runway and watched me do three landings. Then, lo and behold, one year later, similar incident! This time, because the original shock struts had springs designed for a 2200 lb. aircraft, one bolt retaining the spring, sheared out the end of the tube. That was in June. Finally in late September I received the same letter requiring me to prove I can actually fly a Piet. Again we went round and round. This time he said his boss wouldn't let him come watch. So I switched to plan B. (I spent a lifetime as a Machine Design Engineer), so I presented the FSDO with a detailed technical paper complete with charts, and diagrams describing stress loads,both static, dynamic, and impact and how they, over time affected the strut. Weeks later, I received a letter simply saying "the matter was closed". I wonder if he even had any idea what my tech report said. On Aug 7, 2009, at 9:01 PM, Pieti Lowell wrote: > > > > You fellows ,I don't think you know the half of it, I got a > registered letter late Friday , dated Thursday, saying that I have > 10 days from the letter's date to respond to FAA regarding > practically redoing my complete Private License Tests learning over, > from getting a tail dragger to be retested , check ride , Area > operations III,, IV etc, Where does one begin ? so far dozens of > phone calls just to find an Instructor with a conventional gear > plane, and when asked if it would be OK to take my check-ride in a > Pietenpol HA only certified craft with ALL paper work on the plane > complete. and it goes on and on. Still no airplanes yet available > and I don't blame anyone to get involved , what a hassle and with > over 2000 tail dragger hours. > Pieti Lowell > > Wednesday during the Homebuilt Review Showcase (where they shafted > one of our three Pietenpol guys--Jack Phillips by cutting one of the > Piets out of the event) the Rotec powered Junior Ace from Poplar > Grove nearly lost it in similar wind conditions when landing. Three > times he nearly had his wing tips in the turf--scary stuff but he > managed to add power, continue down the runway and get a second > chance. > > I was astonished at the ineptitude of the EAA/FAA/and law > enforcement people who kept Lowell and his plane out on the runway > for well over an hour. First off---Lowell's well being, once that > was established to not be an issue they should have cleared off and > talked with him elsewhere if they needed to. I should know better-- > if the gov't is involved they will take the least practical path to > a conclusion. > > Mike C.[/quote] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256592#256592 > > ________________________________________________________________________________
Subject: Re: Handheld Radio
Date: Aug 10, 2009
Longest cross cournty I've ever heard of! If you'd use a chart and a compass you might be able to find your way out here. If all else fails, look for a town's name on a water tower. The Mississippi flows South, The Tennessee flows north, the Ohio flows West and if you reach the coast, turn right. Good Luck Gene ----- Original Message ----- From: Gary Boothe To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 11:21 AM Subject: RE: Pietenpol-List: Handheld Radio "Tennessee is mine. I've been flying that area for 2 years." ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 8:59 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Handheld Radio Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/10/09 06:10:00 ________________________________________________________________________________
Date: Aug 10, 2009
Which radio are you going with? I am currently trying to figure out which radio to buy and the best way to mount it also. Also what kind of antenna are you using? thanks Rick On Mon, Aug 10, 2009 at 11:58 AM, Gene & Tammy < zharvey(at)bentoncountycable.net> wrote: > Just ordered a new handheld for N502R and wondering where others are > mounting/keeping them. With each cockpit & panel being somewhat different, > I'd like to see what others have done, before I mount mine. Photos would be > a big help. > Thanks > Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do > well in the Southern humid heat). Looking forward to winter. > > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Aug 10, 2009
Hi Rick, Last night ordered the Vertex VXA - 300 Pilot III from www.skygeek.com for $219.00. Aircraft Spruce wants $340.00 for the same radio. I had read somewhere else, some time ago, that it was easier to use that the Icom and it has a better battery, plus it comes with the headset adapter. I mounted a 45 degree antenna under my cowling (using the cowling as my ground plane). I tried it with an old radio I had and it seemed to work just fine, without engine noise. Gene ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 12:32 PM Subject: Re: Pietenpol-List: Handheld Radio Which radio are you going with? I am currently trying to figure out which radio to buy and the best way to mount it also. Also what kind of antenna are you using? thanks Rick On Mon, Aug 10, 2009 at 11:58 AM, Gene & Tammy wrote: Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/10/09 06:10:00 ________________________________________________________________________________
Date: Aug 10, 2009
Poath ________________________________________________________________________________
Date: Aug 10, 2009
I am thinking about getting this same radio.... I think it would be perfect for the Piet. You get anything done the wife's new car? Do you want to meet to get the shear up to your place and exchange the $70? I think we could cut up some of that heavy steal angle to send with you to make a stand. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 11:51 AM Subject: Re: Pietenpol-List: Handheld Radio Hi Rick, Last night ordered the Vertex VXA - 300 Pilot III from www.skygeek.com for $219.00. Aircraft Spruce wants $340.00 for the same radio. I had read somewhere else, some time ago, that it was easier to use that the Icom and it has a better battery, plus it comes with the headset adapter. I mounted a 45 degree antenna under my cowling (using the cowling as my ground plane). I tried it with an old radio I had and it seemed to work just fine, without engine noise. Gene ----- Original Message ----- From: Rick Holland <mailto:at7000ft(at)gmail.com> To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 12:32 PM Subject: Re: Pietenpol-List: Handheld Radio Which radio are you going with? I am currently trying to figure out which radio to buy and the best way to mount it also. Also what kind of antenna are you using? thanks Rick On Mon, Aug 10, 2009 at 11:58 AM, Gene & Tammy wrote: Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat r onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________ - Release Date: 08/10/09 06:10:00 ________________________________________________________________________________
Date: Aug 10, 2009
Sorry for the miss post. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of brian.e.jardine@L-3com.com Sent: Monday, August 10, 2009 12:24 PM Subject: RE: Pietenpol-List: Handheld Radio I am thinking about getting this same radio.... I think it would be perfect for the Piet. You get anything done the wife's new car? Do you want to meet to get the shear up to your place and exchange the $70? I think we could cut up some of that heavy steal angle to send with you to make a stand. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 11:51 AM Subject: Re: Pietenpol-List: Handheld Radio Hi Rick, Last night ordered the Vertex VXA - 300 Pilot III from www.skygeek.com for $219.00. Aircraft Spruce wants $340.00 for the same radio. I had read somewhere else, some time ago, that it was easier to use that the Icom and it has a better battery, plus it comes with the headset adapter. I mounted a 45 degree antenna under my cowling (using the cowling as my ground plane). I tried it with an old radio I had and it seemed to work just fine, without engine noise. Gene ----- Original Message ----- From: Rick Holland <mailto:at7000ft(at)gmail.com> To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 12:32 PM Subject: Re: Pietenpol-List: Handheld Radio Which radio are you going with? I am currently trying to figure out which radio to buy and the best way to mount it also. Also what kind of antenna are you using? thanks Rick On Mon, Aug 10, 2009 at 11:58 AM, Gene & Tammy wrote: Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat r onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________ - Release Date: 08/10/09 06:10:00 http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 10, 2009
IMO, the best handheld EVAH! was the Vertex VXA-150. Plenty of power, easy to use, great battery life, no frills. For us Pieters, a bonus is the display location - it's at an angle along the top edge. Because everything is so close in the Piet pit (the instrument panel is much closer to the pilot's chest than in many planes), almost regardless of where you install the radio, you are looking more down on it that at it. Sadly, no longer available. I now have the VXA-220, which has the display flat on the vertical face - much more difficult to read. One advantage of the 220 (and 300) over the 150 is that the adapter connection is much, much more stout. But, oddly enough, if you use a headset (which requires the adapter, of course), the built-in PPT on the side of the radio is disabled. Instead, you MUST use a separate PPT switch. I cannot for the life of me understand why they would design it this way. I have always used an external PPT just so I could have the button on the stick, but one time it failed. No biggie, I just removed that part of the circuit from the set-up, plugging the headset directly into the adapter and using the switch on the radio to transmit. Now, can't do that. Cheap redundancy lost. Bummer. The 220 and 300 also have VOX, which would provide a similar level of redundancy in the case of the external PPT switch failing, but I find that it can't cope with the noise in the open cockpit. What is everyone else using and why? >Which radio are you going with? I am currently trying to figure out >which radio to buy and the best way to mount it also. Also what kind >of antenna are you using? > >thanks > >Rick ________________________________________________________________________________
Date: Aug 10, 2009
I have also been thinking seriously about the Vertex VXA - 300 or 220. Much better prices than ICON. A question for anyone that flys with a portable radio, have you ever needed or wish you had the VOR Nav capability on your radio? Rick On Mon, Aug 10, 2009 at 1:50 PM, Gene & Tammy wrote: > Hi Rick, > Last night ordered the Vertex VXA - 300 Pilot III from www.skygeek.com for > $219.00. Aircraft Spruce wants $340.00 for the same radio. I had read > somewhere else, some time ago, that it was easier to use that the Icom and > it has a better battery, plus it comes with the headset adapter. I mounted > a 45 degree antenna under my cowling (using the cowling as my ground > plane). I tried it with an old radio I had and it seemed to work just fine, > without engine noise. > Gene > > ----- Original Message ----- > *From:* Rick Holland > *To:* pietenpol-list(at)matronics.com > *Sent:* Monday, August 10, 2009 12:32 PM > *Subject:* Re: Pietenpol-List: Handheld Radio > > Which radio are you going with? I am currently trying to figure out which > radio to buy and the best way to mount it also. Also what kind of antenna > are you using? > > thanks > > Rick > > On Mon, Aug 10, 2009 at 11:58 AM, Gene & Tammy < > zharvey(at)bentoncountycable.net> wrote: > >> Just ordered a new handheld for N502R and wondering where others are >> mounting/keeping them. With each cockpit & panel being somewhat different, >> I'd like to see what others have done, before I mount mine. Photos would be >> a big help. >> Thanks >> Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do >> well in the Southern humid heat). Looking forward to winter. >> >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > ------------------------------ > - Release Date: 08/10/09 06:10:00 > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Aug 10, 2009
Don't know if this fits your calendar, but September 11-13 is the MAAC Grass Roots Fly-In at Brodhead. > >In their infinite wisdom, my employer has decided to have me do some >consulting.....several weeks AFTER Brodhead.....to a town a bit >south of Brodhead, Freeport Illinois. > >Why they couldn't have done this a few weeks ago is a mystery to me! >:-) Oh well. > >So is there anyone in that general area? I'll fly into Chicago late >Sunday, Aug 23 and drive back to Chicago on Wednesday evening. > >Jim > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Aug 10, 2009
Subject: FSDO/MIDO guys
Some are total idiots, some are wonderful. Luck of the draw. The guy who inspected my Pietenpol was wonderful. A private pilot who stopped flying to raise a family but he was so pumped by visiting Valley City Airport (Cubs, old Fairchilds, Stearmans, etc) that he ended up buying a Champ and getting back into aviation. I even went and helped him look at a few Champs for sale since I had owned one previously. One local guy was pilot, IA/A&P and he was all anti FAA until he got a job with them-- then it went to his head and now he's a big shot moron who likes to point his finger at people who do the same things he used to when he was on the other end of the finger pointing. Moron. Those are the ones who give the good FAA guys bad press. Then there are the ones they hire who haven't a clue about aviation. Mike C. ________________________________________________________________________________
Date: Aug 10, 2009
Nope. >I have also been thinking seriously about the Vertex VXA - 300 or >220. Much better prices than ICON. A question for anyone that flys >with a portable radio, have you ever needed or wish you had the VOR >Nav capability on your radio? > >Rick > ________________________________________________________________________________
Subject: Bear with me, new to the list & first time posting
Date: Aug 10, 2009
Hi everyone, =C2- Oshkosh =93 Pietenpol Pilots: I also had the chance to see many of the Pietenpols and talk with several of the pilots at Oshkosh this year. I can honestly say in my almost 20 years of being a Co-Chairman of homebu ilt parking there, the Pietenpol group is about the most down to earth bun ch of pilots. Every pilot I talked to took the time to answer my questions and encouraged me to start building one. Not=C2-always the reception yo u get with other types of pilots.=C2- =C2-I also want to thank Jack Phillips for his advice. The following day after my conversation with him, I was able to drag myself and my father away from our flight line duties=C2-to go to Polyfiber=99s forum on fabric covering. Jack and=C2-the gentleman from Burlington WI (I can 't remember his name and didn't get his contact info)=C2-inspired me to start right then and there! So now I'm looking for anyone who is building or flying a Pietenpol near Elkhorn, WI. I would like the chance to gain more information and experience in building one prior to starting my own project. =C2- =C2- Homebuilt Review: I also wish the review was a bit longer and feel bad for anyone who was cut due to time constraints. Every year I take part in the recovery on 36L/18R and witnessed the Baby Ace=99s =9Calmost loop=9D across the field this year. He did scrape the right tip a bit but did a great job in recovering. During a homebuilt review about 8 years ago, I luckily avoided a n Avid that looped and went right where I had been standing! The wind cond itions were about the same in both cases.=C2-=C2- =C2- Landing on Sunday =93 I was upset to find out about Mr. Lowell =99s current situation with the FAA and hope things turn out right for him and he=99s flying again soon. The wind was strong that day as it wa s the previous day when an RV-6=99s rudder cable broke / ground loop ed right in the same location. I was training new point personnel at the convention ramp intersection and saw both occur right in front of me. =C2- Not speaking for EAA, just myself, any situation that occurs on the field is met with an array of flashing lights, questions, and subsequent delays at the scene. When an incident occurs, it always reminds me of the scene from Airplane when they roll everything imaginable, crash trucks, police, Budweiser truck, ice cream van, a concrete truck, tractors, etc. But no matter what they send or the problems after the fact, I am glad when that people are able to walk away alive! I have seen the alternative back in 2006 with the TBM vs. RV incident on the taxi-way. Bent metal and splinte red wood can be=C2-repaired, egos can be soothed, licence's reinstated; people can't be brought back to life. Fly safe, Jeff Gaulden =C2-=C2-=C2- ________________________________________________________________________________
Date: Aug 10, 2009
I have the Icom IC-A22 NAV/COM. I don't have a lot of experience with many aviation handhelds, but I've used a whole slew of Icom, Kenwood, Vertex (Yaesu) radios, and others in various hobbies or other applications. They are all pretty good, but I've come to like Icom's robust audio and ease of use. I've got 3 Icom handhelds... one is an old IC2AT 144MHz "brick"... aside from the lack of DTMF tones, it still works great. I also have an 8 year old 4008A FRS radio that has been through everything (wet, hot, dropped repeatedly) and it too works great. I'm sure other manufacturers offer a decent aviation product line, but I can only speak for the ones I've used personally. As for the NAV feature... it is a great backup for the VOR radio. I actually used it on one of my cross country flights, just for fun. It works great, and why not have a backup? Actually, it will be my only VOR reciever in my Piet. Most likely I won't be doing a lot of cross country anyway, and when I do I'll likely use my GPSMAP 195, but it will be nice to have the VOR in the event of a GPS failure. I've never used the Sporty's radios (not sure who actually makes them), but they look like they operate real similar to the Icom for ~$100 less. Can't speak for their performance though. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=257003#257003 ________________________________________________________________________________
Date: Aug 10, 2009
THIS IS MY ICON A24. I HAVE A PPT BUTTON ON THE END OF MY STICK AND THE RADIO IS WIRED INTO MY INTERCOM ON THE LEFT SIDE ( SEE THE PLUGS ABOVE THE WHITE THROTTLE BALL. VERY EASY TO READ, AND CHANGE TO ANY OF 10 CHANNELS PROGRAMED IN. On Aug 10, 2009, at 10:58 AM, Gene & Tammy wrote: > Just ordered a new handheld for N502R and wondering where others are > mounting/keeping them. With each cockpit & panel being somewhat > different, I'd like to see what others have done, before I mount > mine. Photos would be a big help. > Thanks > Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't > do well in the Southern humid heat). Looking forward to winter. > > ________________________________________________________________________________
Date: Aug 10, 2009
Gene, I use an older Sporty's handheld radio. The antenna is one of those Cessna bent external ones which I straitened and put behind my seat,.with a cable to the handheld. The radio is strapped to my left leg with a velcro strap glued to the back of the radio. I didn't want to mount it to anything. It works--Jim Lagowski ----- Original Message ----- From: Gene & Tammy To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 11:58 AM Subject: Pietenpol-List: Handheld Radio Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/10/09 06:10:00 ________________________________________________________________________________
Date: Aug 10, 2009
Re: Pietenpol-List: Handheld RadioI second that. ----- Original Message ----- From: Jeff Boatright To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 2:53 PM Subject: Re: Pietenpol-List: Handheld Radio Nope. I have also been thinking seriously about the Vertex VXA - 300 or 220. Much better prices than ICON. A question for anyone that flys with a portable radio, have you ever needed or wish you had the VOR Nav capability on your radio? Rick ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/10/09 06:10:00 ________________________________________________________________________________
Date: Aug 10, 2009
Great looking cockpit and I like how you located the radio. Thanks Gene ----- Original Message ----- From: Roman Bukolt To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 3:33 PM Subject: Re: Pietenpol-List: Handheld Radio THIS IS MY ICON A24. I HAVE A PPT BUTTON ON THE END OF MY STICK AND THE RADIO IS WIRED INTO MY INTERCOM ON THE LEFT SIDE ( SEE THE PLUGS ABOVE THE WHITE THROTTLE BALL. VERY EASY TO READ, AND CHANGE TO ANY OF 10 CHANNELS PROGRAMED IN. On Aug 10, 2009, at 10:58 AM, Gene & Tammy wrote: Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/10/09 06:10:00 ________________________________________________________________________________
Subject: Re: metal parts
Date: Aug 10, 2009
The one I recall was a fellow that had his work done through emachineshop.com, which offers a neat little 3-D drawing tool that requires you to draw all your own parts, as they do not allow "second prints" so to speak for anyone other than the original customer, or something like that. I actually drew some smaller parts and priced it... very expensive. I can almost picture the guy's website that had the work done... lots of green in the color scheme of the airplane I believe... and I think he also has an R/C model to match. I have it bookmarked at home, but maybe this will help someones memory if we are thinking of the same guy. I may know of a guy... well, shhhhh. I'll let him introduce himself if he wants to offer services. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=257021#257021 ________________________________________________________________________________
Date: Aug 10, 2009
Here is the thread I was thinking of http://forums.matronics.com/viewtopic.php?t=844&highlight=emachineshop And this is direct to DJ Vegh's web site http://www.imagedv.com/aircamper/log/image-pages/06-10-03.htm Hope this is what you were looking for. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=257024#257024 ________________________________________________________________________________
Date: Aug 10, 2009
You are thinking of D.J. Veigh. His website is here: http://www.imagedv.co m/aircamper/index.h Stinemetze, McPherson, KS. >>> "K5YAC" 8/10/2009 4:16 PM >>> The one I recall was a fellow that had his work done through emachineshop.c om, which offers a neat little 3-D drawing tool that requires you to draw all your own parts, as they do not allow "second prints" so to speak for anyone other than the original customer, or something like that. I actually drew some smaller parts and priced it... very expensive. I can almost picture the guy's website that had the work done... lots of green in the color scheme of the airplane I believe... and I think he also has an R/C model to match. I have it bookmarked at home, but maybe this will help someones memory if we are thinking of the same guy. I may know of a guy... well, shhhhh. I'll let him introduce himself if he wants to offer services. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=257021#257021 ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Aug 10, 2009
That was DJ Veigh, I believe. Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com Sent from the phone that made the Blackberry obsolete. On Aug 10, 2009, at 5:16 PM, "K5YAC" wrote: > > The one I recall was a fellow that had his work done through emachineshop.com > , which offers a neat little 3-D drawing tool that requires you to > draw all your own parts, as they do not allow "second prints" so to > speak for anyone other than the original customer, or something like > that. I actually drew some smaller parts and priced it... very > expensive. > > I can almost picture the guy's website that had the work done... > lots of green in the color scheme of the airplane I believe... and I > think he also has an R/C model to match. I have it bookmarked at > home, but maybe this will help someones memory if we are thinking of > the same guy. > > I may know of a guy... well, shhhhh. I'll let him introduce > himself if he wants to offer services. > > -------- > Mark - working on wings > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=257021#257021 > > ________________________________________________________________________________
Date: Aug 10, 2009
Comandante Zuniga: Can't remember anyone real recent posting such an image. At least not within the last couple of years. Must be an other list perhaps? I know DJ had his parts cut by Emachineshop, and I know that would not let clients use previous job files but then most of DJ's stuff would not likely work for a Pietenpol as his was a GN-1 su fiel corresponsal: Michael ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> > > Not too long ago somebody posted a picture of their laser-cut > or waterjet-cut metal parts, all out of a single metal plate. > I can't seem to find that picture or the link to it. Does > that ring a bell with anyone? > > ________________________________________________________________________________
Date: Aug 10, 2009
"Right after the War finished, barnstorming was like this all the time.." _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 10:31 AM Subject: Re: Pietenpol-List: Handheld Radio Longest cross cournty I've ever heard of! If you'd use a chart and a compass you might be able to find your way out here. If all else fails, look for a town's name on a water tower. The Mississippi flows South, The Tennessee flows north, the Ohio flows West and if you reach the coast, turn right. Good Luck Gene ----- Original Message ----- From: Gary Boothe <mailto:gboothe5(at)comcast.net> Sent: Monday, August 10, 2009 11:21 AM Subject: RE: Pietenpol-List: Handheld Radio "Tennessee is mine. I've been flying that area for 2 years." _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 8:59 AM Subject: Pietenpol-List: Handheld Radio Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ - Release Date: 08/10/09 06:10:00 ________________________________________________________________________________
Date: Aug 10, 2009
Where are you located? I'm in Camden. Gene ----- Original Message ----- From: Gary Boothe To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 6:02 PM Subject: RE: Pietenpol-List: Handheld Radio "Right after the War finished, barnstorming was like this all the time.." ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 10:31 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Handheld Radio Longest cross cournty I've ever heard of! If you'd use a chart and a compass you might be able to find your way out here. If all else fails, look for a town's name on a water tower. The Mississippi flows South, The Tennessee flows north, the Ohio flows West and if you reach the coast, turn right. Good Luck Gene ----- Original Message ----- From: Gary Boothe To: pietenpol-list(at)matronics.com Sent: Monday, August 10, 2009 11:21 AM Subject: RE: Pietenpol-List: Handheld Radio "Tennessee is mine. I've been flying that area for 2 years." ------------------------------------------------------------------------- --- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 8:59 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Handheld Radio Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-Listhref="http://forums.matronics.com">h ttp://forums.matronics.comhref="http://www.matronics.com/contribution"> http://www.matronics.com/c ------------------------------------------------------------------------- --- - Release Date: 08/10/09 06:10:00 http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 08/10/09 18:19:00 ________________________________________________________________________________
Date: Aug 10, 2009
Gene, I'm 3 seconds away in California (by internet). But a few of us have made a commitment to fly our newly finished Piets to Brodhead in 2011. Don't worry, I have your directions down. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion Tail done, Fuselage on gear (13 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 4:19 PM Subject: Re: Pietenpol-List: Handheld Radio Where are you located? I'm in Camden. Gene ----- Original Message ----- From: Gary Boothe <mailto:gboothe5(at)comcast.net> Sent: Monday, August 10, 2009 6:02 PM Subject: RE: Pietenpol-List: Handheld Radio "Right after the War finished, barnstorming was like this all the time.." _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 10:31 AM Subject: Re: Pietenpol-List: Handheld Radio Longest cross cournty I've ever heard of! If you'd use a chart and a compass you might be able to find your way out here. If all else fails, look for a town's name on a water tower. The Mississippi flows South, The Tennessee flows north, the Ohio flows West and if you reach the coast, turn right. Good Luck Gene ----- Original Message ----- From: Gary Boothe <mailto:gboothe5(at)comcast.net> Sent: Monday, August 10, 2009 11:21 AM Subject: RE: Pietenpol-List: Handheld Radio "Tennessee is mine. I've been flying that area for 2 years." _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene & Tammy Sent: Monday, August 10, 2009 8:59 AM Subject: Pietenpol-List: Handheld Radio Just ordered a new handheld for N502R and wondering where others are mounting/keeping them. With each cockpit & panel being somewhat different, I'd like to see what others have done, before I mount mine. Photos would be a big help. Thanks Gene, in Hot & Humid Tennessee (this poor Ol' fat Alaska boy doesn't do well in the Southern humid heat). Looking forward to winter. http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ - Release Date: 08/10/09 06:10:00 http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _____ - Release Date: 08/10/09 18:19:00 ________________________________________________________________________________
Date: Aug 10, 2009
As many piets that are under construction, a group of you should get togeat her and have 5-10 sets of fittings cut, divide the cost and it would be muc h cheaper.- If there were any left over you could hold on to them and sel l them at brodhead or to another local builder who came along.- It would help offset the cost a little.=0A=0A=0A ________________________________________________________________________________
Date: Aug 10, 2009
I'd go in on that Let me know Cheers jon In a message dated 8/10/2009 6:21:23 P.M. Mountain Daylight Time, aviatorbell(at)yahoo.com writes: As many piets that are under construction, a group of you should get togeather and have 5-10 sets of fittings cut, divide the cost and it would be much cheaper. If there were any left over you could hold on to them and sell them at brodhead or to another local builder who came along. It would help offset the cost a little. (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Subject: Metal Parts
Date: Aug 10, 2009
This might be the solution for some of you new builders. I just got off the phone with Ken Perkins who lives in Olathe, KS. He has a stock of ready made parts ready to go. He mentioned wing fittings, die spring landing gear shock strut, cabane fittings, lift strut fittings, gear fittings, control sticks, all the flat parts, and complete tail wheel assemblies. His phone: 913-764-6949 His email: kenandveraperkins(at)sbcglobal.net ________________________________________________________________________________
Date: Aug 10, 2009
Something along that line may be happening [Wink] ...............Stay tuned!! Jody Read this topic online here: http://forums.matronics.com/viewtopic.php?p=257054#257054 ________________________________________________________________________________
Date: Aug 11, 2009
VGhhdCdzIGFsbCB5b3UgcGxhbiB0byAgZG8gd2l0aCB5b3VyIGxpZmUgLHJpZGVzIGZvciBjYXNo Pw0KU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgQmxhY2tCZXJyeQ0KDQotLS0tLU9yaWdp bmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogIkdhcnkgQm9vdGhlIiA8Z2Jvb3RoZTVAY29tY2FzdC5u ZXQ+DQoNCkRhdGU6IE1vbiwgMTAgQXVnIDIwMDkgMTY6MDI6MTAgDQpUbzogPHBpZXRlbnBvbC1s aXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSRTogUGlldGVucG9sLUxpc3Q6IEhhbmRoZWxk IFJhZGlvDQoNCg0KIlJpZ2h0IGFmdGVyIHRoZSBXYXIgZmluaXNoZWQsIGJhcm5zdG9ybWluZyB3 YXMgbGlrZSB0aGlzIGFsbCB0aGUgdGltZS4uIg0KDQogDQoNCiAgX19fX18gIA0KDQpGcm9tOiBv d25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbQ0KW21haWx0bzpvd25lci1w aWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIEdlbmUgJiBU YW1teQ0KU2VudDogTW9uZGF5LCBBdWd1c3QgMTAsIDIwMDkgMTA6MzEgQU0NClRvOiBwaWV0ZW5w b2wtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IEhhbmRo ZWxkIFJhZGlvDQoNCiANCg0KTG9uZ2VzdCBjcm9zcyBjb3VybnR5IEkndmUgZXZlciBoZWFyZCBv ZiEgIElmIHlvdSdkIHVzZSBhIGNoYXJ0IGFuZCBhDQpjb21wYXNzIHlvdSBtaWdodCBiZSBhYmxl IHRvIGZpbmQgeW91ciB3YXkgb3V0IGhlcmUuICBJZiBhbGwgZWxzZSBmYWlscywNCmxvb2sgZm9y IGEgdG93bidzIG5hbWUgb24gYSB3YXRlciB0b3dlci4gIFRoZSBNaXNzaXNzaXBwaSBmbG93cyBT b3V0aCwgVGhlDQpUZW5uZXNzZWUgZmxvd3Mgbm9ydGgsIHRoZSBPaGlvIGZsb3dzIFdlc3QgYW5k IGlmIHlvdSByZWFjaCB0aGUgY29hc3QsIHR1cm4NCnJpZ2h0Lg0KDQpHb29kIEx1Y2sNCg0KR2Vu ZQ0KDQotLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0tIA0KDQpGcm9tOiBHYXJ5IEJvb3RoZSA8 bWFpbHRvOmdib290aGU1QGNvbWNhc3QubmV0PiAgDQoNClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRy b25pY3MuY29tIA0KDQpTZW50OiBNb25kYXksIEF1Z3VzdCAxMCwgMjAwOSAxMToyMSBBTQ0KDQpT dWJqZWN0OiBSRTogUGlldGVucG9sLUxpc3Q6IEhhbmRoZWxkIFJhZGlvDQoNCiANCg0KIlRlbm5l c3NlZSBpcyBtaW5lLiBJJ3ZlIGJlZW4gZmx5aW5nIHRoYXQgYXJlYSBmb3IgMiB5ZWFycy4iDQoN CiANCg0KDQogIF9fX19fICANCg0KDQpGcm9tOiBvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJA bWF0cm9uaWNzLmNvbQ0KW21haWx0bzpvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9u aWNzLmNvbV0gT24gQmVoYWxmIE9mIEdlbmUgJiBUYW1teQ0KU2VudDogTW9uZGF5LCBBdWd1c3Qg MTAsIDIwMDkgODo1OSBBTQ0KVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NClN1Ympl Y3Q6IFBpZXRlbnBvbC1MaXN0OiBIYW5kaGVsZCBSYWRpbw0KDQogDQoNCkp1c3Qgb3JkZXJlZCBh IG5ldyBoYW5kaGVsZCBmb3IgTjUwMlIgYW5kIHdvbmRlcmluZyB3aGVyZSBvdGhlcnMgYXJlDQpt b3VudGluZy9rZWVwaW5nIHRoZW0uICBXaXRoIGVhY2ggY29ja3BpdCAmIHBhbmVsIGJlaW5nIHNv bWV3aGF0IGRpZmZlcmVudCwNCkknZCBsaWtlIHRvIHNlZSB3aGF0IG90aGVycyBoYXZlIGRvbmUs IGJlZm9yZSBJIG1vdW50IG1pbmUuICBQaG90b3Mgd291bGQgYmUNCmEgYmlnIGhlbHAuDQoNClRo YW5rcw0KDQpHZW5lLCBpbiBIb3QgJiBIdW1pZCBUZW5uZXNzZWUgKHRoaXMgcG9vciBPbCcgZmF0 IEFsYXNrYSBib3kgZG9lc24ndCBkbyB3ZWxsDQppbiB0aGUgU291dGhlcm4gaHVtaWQgaGVhdCku ICBMb29raW5nIGZvcndhcmQgdG8gd2ludGVyLg0KDQogDQoNCiANCiANCmh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UGlldGVucG9sLUxpc3QNCmh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbQ0KaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KIA0KIA0KIA0K aHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdCI+ aHR0cDovL3d3dy5tYXRyb25pYw0Kcy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1MaXN0DQpocmVm PSJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bQ0KaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbiI+aHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2MNCg0KICBfX19fXyAgDQoNCg0KLSBSZWxlYXNlIERhdGU6IDA4LzEw LzA5IDA2OjEwOjAwDQoNCiANCiANCiANCg0K ________________________________________________________________________________
Subject: Even the plastic model builders (like me) like Piet's!!
Date: Aug 10, 2009
A fellow model builder who was at Air Venture took some good pics of the Piets. And a picture of a now infamous Piet landing. http://www.arcforums.com/forums/air/index.php?showtopic=190432&st Jody Read this topic online here: http://forums.matronics.com/viewtopic.php?p=257064#257064 ________________________________________________________________________________
Date: Aug 10, 2009
They know you Jimmy, they know you. :-) Clif "I count life just a stuff to try the soul's strength on." > In their infinite wisdom, my employer has decided to have me do some > consulting.....several weeks AFTER Brodhead.....to a town a bit south of > Brodhead, Freeport Illinois. > > Why they couldn't have done this a few weeks ago is a mystery to me! :-) > Oh well. > > Jim > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 18:19:00 ________________________________________________________________________________
Date: Aug 10, 2009
I bought an old Delcom because everything is on the end. It came with both a chargable pack and an AA pack. Since the cockpit is small and crouded and I wanted to retain as much antiqueness as possible I didn't want this big black flat thing stuck somewhere. Unfortunately, since I live under the busiest airspace in all of Canada I now have to have a transponder. I got one, a Collins, with sender. It apparently is the shortest one made but it will still be intrusive. Oh well.
August 03, 2009 - August 11, 2009
Pietenpol-Archive.digest.vol-hz
