Pietenpol-Archive.digest.vol-ix
February 25, 2010 - March 06, 2010
      Conversations about appropriate woods went =3D from ash=3D20 = to
      spruce,  including hickory. I decided that I liked the look of =3D
      hickory = and=3D20 the  decision was that easy. For size, I just
      used the plans dimensions = =3D for=3D20  steel.
                  Later=3D20 conversations with another builder (either =
      Cliff  Dawson or Douwe =3D Blumberg),=3D20 far  more intelligent
      and = educated than  I, showed published =3D strengths of=3D20
      various woods, and = verified that  hickory had plenty of strength
      for =3D our=3D20 purposes. I think I = can find  that email,
      but it=3D92s on my other =3D computer at=3D20 home.
                  My=3D20 wing struts will also be hickory, roughly the =
      shape and  size on the =3D plans.=3D20 Connections will surely
      be similar to = Douwe=3D92s. All  cabanes and wing =3D struts
      are=3D20 laminated = because=3D85.that=3D92s what everyone
      does! Really, it gives you =3D an=3D20 opportunity to rotate the =
      grain and  eliminate the possibility of =3D having a weak=3D20
      link. Also, it = looks really  cool!
                  My=3D20 wood source is a local hardwood supplier, in =
      Auburn, Ca  (California=3D20 Hardwoods), who does his own
      wholesale purchasing = in whatever  length =3D and size=3D20
      needed. He even mills, if necessary. He = located my fir  spars
      and sold =3D all four=3D20 for $185!! Bonus is that he helped =
      build some  wood airplanes and knows =3D what=3D20 grains to
      look = for.
                  Further=3D20 note:  If anything goes wrong, = I=3D92ll
      blame  Chris Tracy for =3D publishing all=3D20 those = photos!
                  Gary=3D20 Boothe
                  Cool,=3D20 CA
                  Pietenpol
                  WW=3D20 Corvair Conversion
                  Tail=3D20 done, Fuselage on gear
                  18=3D20 ribs done
      owner-pietenpol-list-server(at)matronics.com=3D20
      [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of =
      =3D Ray=3D20 Krause
                  Sent: Monday, February 22, 2010 1:51  PM
                  To: =3D pietenpol-list(at)matronics.com
                  Subject: = Re:  Pietenpol-List: =3D Sky=3D20 =
      Scout...
                  Gary,
                  If I  made =3D these 22"=3D20 struts (front/center)
      from metal, they would = weigh 22+  ounces without =3D
      the=3D20 ends. How did you decide on the = thickness and shape
      for the struts? =3D Why did=3D20 you chose Hickory versus, say =
      ash?  Did  you laminate because you =3D needed=3D20 to get to a
      certain = thickness, or for  strength?  There is a =3D source
      for=3D20 hickory and ash that = has 2" (8/4)  material in Chico,
      I think.  I =3D got some=3D20 1" ash for = 2.37 per board
      foot.
                  Are  your =3D "flying=3D20 struts" (the long struts)
      also hickory?  = What=3D20  shape?
                  Ray=3D20 Krause.
                  P.S.  The =3D aerostream=3D20 tubing is very
      expensive, about $56.00 per = front strut  ($28.00/ft and =3D
      .7593=3D20 lbs/ft). Wicks has it for $17.00/ft = right now. I
      am not sure of its =3D quality.=3D20 None of the aerotubing matches
      = the  recommended sizes on the plans (1.5 =3D X .75=3D20 and
      2" X  1").
                    -----  =3D Original=3D20 Message -----
                    To: pietenpol-list@matron= ics.com=3D  =3D20
                    Sent: =3D  Monday, February=3D20 22, 2010 7:31 AM
                    Subject:  RE:=3D20 Pietenpol-List: Sky Scout...
                    Ray,
                    I had a couple free minutes before I took = =3D off
      for  the=3D20 week. It took 10 seconds to pull off one of the rear
      = cabanes. It =3D  measures=3D20 21" end-to-end, and weighs 18
      oz (had to use the = postal=3D20  scales!).
                    Gary Boothe
                    Cool, Ca.
                    Pietenpol
                    WW Corvair Conversion, =3D = mounted
                    Tail done, Fuselage on gear
                    (18 ribs down=3D85)
                    -----Original Message-----
      Ray=3D20  Krause
                    Sent: Sunday, February 21, 2010 8:54 PM
                    To:=3D20  pietenpol-list(at)matronics.com
                    Subject: Re: Pietenpol-List: = Sky=3D20  Scout...
      Krause"=3D20
                    Shad,
                    Thanks for the comments on the = struts.  =3D I
      will=3D20 probably go with the 4130
                    struts from Wicks.  It is just that I = =3D
      really=3D20 enjoy the wood working.  If the
                    wood were comparable, I would maybe go =
      that=3D20  way.
                    I would appreciate the Dillsburg Aero =3D
      Reference. =3D20 The size of the metal
                    struts is included in the plans; so I can = =3D
      probably  get=3D20 pretty close to the
                    right size.
                    Thanks for your help.
                    Ray Krause
                    ----- Original Message -----
                    To:=3D20
                    Sent: Saturday, February 20, 2010 = 5:33=3D20  PM
                    Subject: Re: Pietenpol-List: Sky=3D20  Scout...
                    > --> Pietenpol-List message posted = =3D by:
      shad=3D20 bell
                    > Ray, I am not 100% sure but I would = bet =3D
      wooden=3D20 struts are heavier than
                    > streamlined tube.  The bolts, = and =3D steel
      end=3D20 fittings that would be
                    > required add up fast.  As for = the =3D
      older=3D20 metal designation, just usse 4130,
                    > If you need I can see what dimensions = =3D
      ours  are,=3D20 some where in the 2 inch
                    > by 9/16 (minor axis) .049 wall =3D  thickness.
      =3D20 also check dillsburg aero works
                    > for tube prices, wicks is also having = a =3D
      special=3D20 "sale" on streamlined
                    > tubing of some dimensions.  I = can =3D look
      up=3D20 the number for Dillsburg Aero
                    > Works in PA if you need me to, I have = a =3D
      price=3D20 list out in my hanger, he
                    > does not have a web =3D = site.
                    > Shad
      <=3D/PRE>http://=www.mat=3Dronics.com/Navigator?Pietenpol-List&=l
      t;=3DB><=3D/PRE>http://forums.matronics.com=3D<=3D/PRE>=3Dhttp:
      //www.matronic=s.com/c=3Dontribution<=3D/PRE>
      href=3D3D"http://www.matronics.com/Navigator?Pietenpol-List">http://ww=
      w.mat=3Dronics.com/Navigator?Pietenpol-Listhref=3D3D"http://forums.ma
      tronics.com">http://forums.matronics.com=
      href=3D3D"http://www.matronics.com/contribution">http://www.matronics.=
      com/c=3D
      3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=
      3D3D=3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D3D=
      3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D=
      3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3
      D=3D3D=3D3D=3D3D=3D=3Dhref=3D'3D"http://www.matronics.com/Nav
      igator?Pietenpol-List"'>http://www=.matronics.com/Navigator?Pietenpol-L
      ist3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D
      3D=3D3D=3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D
      3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=
      3D3D=3D3D=3D3D=3D3D=3D=3Dhref=3D'3D"http://forums.matronics.c
      om"'>http://forums.matronics.com3D=3D3D=3D3D=3D3D=3D3D=3D3D=3
      D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D=3
      D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D
      =3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D
      =3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3Dhref=
      3D'3D"http://www.matronics.com/contribution"'>http://www.matronics.c=om
      /contribution3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=
      3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D=
      D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3
      D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D  ~=B2=03r
      3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
      3Dhref='3D"http://www.matronics.com/Navigator?Pietenpol-List"'>http://w
      ww.matronics.com/Navigator?Pietenpol-List3D=3D=3D=3D=3D=3D=3D
      3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://forums.m
      atronics.com"'>http://forums.matronics.com3D=3D=3D=3D=3D=3D=3
      3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://www.matr
      onics.com/contribution"'>http://www.matronics.com/contribution3D=3D=3
      ~=B2
                  r
      http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.
      comhttp://www.matronics.com/contribution
      href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat
      style="color: blue; text-decoration: underline;
      ">http://www.matronics.com/Navigator?Pietenpol-List
      blue; text-decoration: underline; ">http://forums.matronics.com
      ">http://www.matronics.com/contribution
Subject: Re: Sky Scout...
Date: Feb 25, 2010
Thanks, Jack, I already have the 3/4" spars, so no need to build them up from plywood. I saw these sketches before and thought about it. I will keep this as an alternative. Thanks again. Ray ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Thursday, February 25, 2010 3:27 AM Subject: RE: Pietenpol-List: Sky Scout... Ray, You could consider a built up spar like attached. They are a lot of work but strong and just a bit less expensive that solid. There are more pictures at www.textors.com. Jack DSM Thanks, Gary. The wing is exactly the same, except 27" shorter. Routing would be a lot of work, but doable. The ribs I got with the other wood are all built and seem to be made for the 1" spar. I will have to make a decision on which way to go. I have been putting in hard points in the fuselage for the seat and shoulder safety belts; thankfully I only need one set! I put the hard pints one station behind the seat, so I will have to find the right seat belts to fit. ACS has some that might work, when I get that far. Got the turtle deck mostly done today, that was fun. Thanks for the help. Ray Krause P.S. Guess I will have to take the Waiex to the Peit fly in. ----- Original Message ----- From: Gary Boothe To: pietenpol-list(at)matronics.com Sent: Wednesday, February 24, 2010 7:59 PM Subject: RE: Pietenpol-List: Sky Scout... No problem, Ray. I took your meaning to be, would the same information apply to a Sky Scout. Having never seen Sky Scout plans, I could not say, with real authority, that a =BE" spar is OK for the Sky Scout; however, it is my understanding that the two airplanes are very similar, maybe even the same wing. Lots of conversations on this list point out that vintage aircraft such as the T-craft or Piper Cub, have used an assortment of spar materials, =BE" thick. It is my recollection that the same conversation led to the agreement that, after routing, you basically end up with a =BE" spar, anyhow. Please, someone (I know this is a bashful group), if I have mis-directed Ray, please jump in! Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Wednesday, February 24, 2010 12:29 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Sky Scout... Gary, Thanks. I became confused answering all the e-mails that I started with these questions. I know that you are building an Air Camper! Thanks for the info on the spars. Ray Krause ----- Original Message ----- From: gboothe5(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Tuesday, February 23, 2010 12:15 PM Subject: Re: Pietenpol-List: Sky Scout... Negative. Sent from my Verizon Wireless BlackBerry ------------------------------------------------------------------------- - From: "Ray Krause" <raykrause(at)frontiernet.net> Date: Tue, 23 Feb 2010 11:24:54 -0800 To: Subject: Re: Pietenpol-List: Sky Scout... Gary, Thanks for the information. If = using the 3/4" spar material, would I still rout out the spar as shown in the = plans? Are you building a Sky Scout? Ray Krause ----- Original Message ----- From: gboothe5(at)comcast.net To: pietenpol-list(at)matronics.com= Sent: Tuesday, February 23, = 2010 9:15 AM Subject: Re: Pietenpol-List: = Sky Scout... Ray, FYI...3/4" is an acceptable dimension for = spars. Gary Sent from my Verizon Wireless BlackBerry ------------------------------------------------------------------------ From: "Ray Krause" <raykrause(at)frontiernet.net&g= t; Date: Tue, 23 Feb 2010 07:59:45 -0800 To: Subject: Re: Pietenpol-List: Sky Scout... Thanks, Gary. I will accept your humility with a = =3D grain of=3D20 salt! Your beautiful workmanship attests to your =3D abilities! The point about laminating to avoid = =3D wood defects is=3D20 well taken, I will follow suit. After = computing the costs of =3D the=3D20 metal struts, I am leaning towards the wood = struts! As far as the =3D spars=3D20 go, they were included in the wood I got = with the Sky Scout package; =3D they are=3D20 spruce. But rather than the 1" = thickness, they are 3/4", I think I =3D will=3D20 sandwich then with two pieces = of 1/8" birch plywood to get the 1" (so =3D they fit=3D20 the ribs). = The Hughes Hardwood =3D place in=3D20 Chico = had beautiful parallel grain fir that would have made beautiful =3D spars,=3D20 = cheap, too. Next time I am in Chico, I will check out the =3D = hickory. =3D20 The ash seems to be really dense/heavy (stronger than hickory?). = I =3D will=3D20 try to look it up. Thanks for the response. And yes, I = =3D have referenced=3D20 Chris's web site and printed many photos.... but it = makes my eyes and =3D brain=3D20 hurt! Ray ----- Original Message ----- From:=3D20 Gary=3D20 Boothe To: pietenpol-list@matronics= .com=3D =3D20 Sent: Monday, February 22, 2010 =3D = 3:17=3D20 PM Subject: RE: Pietenpol-List: =3D Sky=3D20 = Scout... Ray, Your=3D20 questions are intelligent and = educated=3D85.attributes to which I make =3D no personal=3D20 claim. In all honesty, I perused = the West Coast Piet web site to =3D exhaustion.=3D20 Too bad Chris Tracy = doesn=3D92t have sponsors, or he=3D92d be a rich man! =3D After=3D20 looking at every = application of wood strut that has been built and is =3D flying,=3D20 I decided = it was doable. Conversations about appropriate woods went =3D from ash=3D20 = to spruce, including hickory. I decided that I liked the look of =3D hickory = and=3D20 the decision was that easy. For size, I just used the plans dimensions = =3D for=3D20 steel. Later=3D20 conversations with another builder (either = Cliff Dawson or Douwe =3D Blumberg),=3D20 far more intelligent and = educated than I, showed published =3D strengths of=3D20 various woods, and = verified that hickory had plenty of strength for =3D our=3D20 purposes. I think I = can find that email, but it=3D92s on my other =3D computer at=3D20 home. My=3D20 wing struts will also be hickory, roughly the = shape and size on the =3D plans.=3D20 Connections will surely be similar to = Douwe=3D92s. All cabanes and wing =3D struts are=3D20 laminated = because=3D85.that=3D92s what everyone does! Really, it gives you =3D an=3D20 opportunity to rotate the = grain and eliminate the possibility of =3D having a weak=3D20 link. Also, it = looks really cool! My=3D20 wood source is a local hardwood supplier, in = Auburn, Ca (California=3D20 Hardwoods), who does his own wholesale purchasing = in whatever length =3D and size=3D20 needed. He even mills, if necessary. He = located my fir spars and sold =3D all four=3D20 for $185!! Bonus is that he helped = build some wood airplanes and knows =3D what=3D20 grains to look = for. Further=3D20 note: If anything goes wrong, = I=3D92ll blame Chris Tracy for =3D publishing all=3D20 those = photos! Gary=3D20 Boothe Cool,=3D20 CA Pietenpol WW=3D20 Corvair Conversion Tail=3D20 done, Fuselage on gear 18=3D20 ribs done From:=3D20 owner-pietenpol-list-server(at)matronics.com=3D20 [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of = =3D Ray=3D20 Krause Sent: Monday, February 22, 2010 1:51 PM To: =3D pietenpol-list(at)matronics.com Subject: = Re: Pietenpol-List: =3D Sky=3D20 = Scout... Gary, If I made =3D these 22"=3D20 struts (front/center) from metal, they would = weigh 22+ ounces without =3D the=3D20 ends. How did you decide on the = thickness and shape for the struts? =3D Why did=3D20 you chose Hickory versus, say = ash? Did you laminate because you =3D needed=3D20 to get to a certain = thickness, or for strength? There is a =3D source for=3D20 hickory and ash that = has 2" (8/4) material in Chico, I think. I =3D got some=3D20 1" ash for = 2.37 per board foot. Are your =3D "flying=3D20 struts" (the long struts) also hickory? = What=3D20 shape? Thanks, Ray=3D20 Krause. P.S. The =3D aerostream=3D20 tubing is very expensive, about $56.00 per = front strut ($28.00/ft and =3D .7593=3D20 lbs/ft). Wicks has it for $17.00/ft = right now. I am not sure of its =3D quality.=3D20 None of the aerotubing matches = the recommended sizes on the plans (1.5 =3D X .75=3D20 and 2" X 1"). ----- =3D Original=3D20 Message ----- From: Gary=3D20 Boothe To: pietenpol-list@matron= ics.com=3D =3D20 Sent: =3D Monday, February=3D20 22, 2010 7:31 AM Subject: RE:=3D20 Pietenpol-List: Sky Scout... Ray, I had a couple free minutes before I took = =3D off for the=3D20 week. It took 10 seconds to pull off one of the rear = cabanes. It =3D measures=3D20 21" end-to-end, and weighs 18 oz (had to use the = postal=3D20 scales!). Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, =3D = mounted Tail done, Fuselage on gear (18 ribs down=3D85) -----Original Message----- From: = owner-pi= etenpol=3D -list-server(at)matronics.com=3D20 [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of = Ray=3D20 Krause Sent: Sunday, February 21, 2010 8:54 PM To:=3D20 pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: = Sky=3D20 Scout... Krause"=3D20 Shad, Thanks for the comments on the = struts. =3D I will=3D20 probably go with the 4130 struts from Wicks. It is just that I = =3D really=3D20 enjoy the wood working. If the wood were comparable, I would maybe go = that=3D20 way. I would appreciate the Dillsburg Aero =3D Reference. =3D20 The size of the metal struts is included in the plans; so I can = =3D probably get=3D20 pretty close to the right size. Thanks for your help. Ray Krause ----- Original Message ----- = From: "shad bell"=3D20 <aviatorbell(at)yahoo.com> To:=3D20 Sent: Saturday, February 20, 2010 = 5:33=3D20 PM Subject: Re: Pietenpol-List: Sky=3D20 Scout... > --> Pietenpol-List message posted = =3D by: shad=3D20 bell > > > Ray, I am not 100% sure but I would = bet =3D wooden=3D20 struts are heavier than > streamlined tube. The bolts, = and =3D steel end=3D20 fittings that would be > required add up fast. As for = the =3D older=3D20 metal designation, just usse 4130, > If you need I can see what dimensions = =3D ours are,=3D20 some where in the 2 inch > by 9/16 (minor axis) .049 wall =3D thickness. =3D20 also check dillsburg aero works = > for tube prices, wicks is also having = a =3D special=3D20 "sale" on streamlined > tubing of some dimensions. I = can =3D look up=3D20 the number for Dillsburg Aero > Works in PA if you need me to, I have = a =3D price=3D20 list out in my hanger, he > does not have a web =3D = site. > > > Shad > > > > > > > > <=3D/PRE>http://=www.mat=3Dronics.com/Navigator?Pietenpol-List&=l t;=3DB><=3D/PRE>http://forums.matronics.com=3D<=3D/PRE>=3Dhttp: //www.matronic=s.com/c=3Dontribution<=3D/PRE> href=3D3D"http://www.matronics.com/Navigator?Pietenpol-List">http://ww= w.mat=3Dronics.com/Navigator?Pietenpol-Listhref=3D3D"http://forums.ma tronics.com">http://forums.matronics.com= href=3D3D"http://www.matronics.com/contribution">http://www.matronics.= com/c=3D 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D= 3D3D=3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D3D= 3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D= 3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3 D=3D3D=3D3D=3D3D=3D=3Dhref=3D'3D"http://www.matronics.com/Nav igator?Pietenpol-List"'>http://www=.matronics.com/Navigator?Pietenpol-L ist3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D 3D=3D3D=3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D= 3D3D=3D3D=3D3D=3D3D=3D=3Dhref=3D'3D"http://forums.matronics.c om"'>http://forums.matronics.com3D=3D3D=3D3D=3D3D=3D3D=3D3D=3 D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D=3 D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D =3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D =3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3Dhref= 3D'3D"http://www.matronics.com/contribution"'>http://www.matronics.c=om /contribution3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D= 3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D=3D3D=3D3D=3D3D= 3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3 D=3D=3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3 D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=3D ~=B2=03r 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3Dhref='3D"http://www.matronics.com/Navigator?Pietenpol-List"'>http://w ww.matronics.com/Navigator?Pietenpol-List3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://forums.m atronics.com"'>http://forums.matronics.com3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://www.matr onics.com/contribution"'>http://www.matronics.com/contribution3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ~=B2 ---------------------------------------------------------------------- r http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-Listhref="http://forums.matronics.com">h ttp://forums.matronics.comhref="http://www.matronics.com/contribution"> http://www.matronics.com/c http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 25, 2010
Oscar, It would be nice to see the data on the drag of the various materials, but I will believe you...I plan to use the streamlined material. I sure enjoy your postings to this site. Ray ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Thursday, February 25, 2010 6:06 AM Subject: Pietenpol-List: Sky Scout... > > > Guys, if you don't already have the original > Flying & Glider Manuals, you should get a copy > by all means. Besides the Air Camper and Sky > Scout plans and details, there are a whole > bunch of other interesting aircraft in them, > well worth your time to peruse. > > And for whoever mentioned that they didn't > think there was much difference in drag between > round and streamline tubing, there really is. > I can dig up the old aircraft design manual > that has a graph of relative drag between > round, simple teardrop, streamline, and one > or two other shapes. It's significant. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Subject: Re: Steerable tailwheel- hooked to rudder
Date: Feb 25, 2010
This is true. The Cub uses different springs for just this reason. When I questioned the A&P that changed to new anti-shimmy springs on the Cub; he said this was an old trick that had been learned with many bad experiences. I don't know about the experiences; but the Cub kept the different springs! Ray ----- Original Message ----- From: "Jim Ash" <ashcan(at)earthlink.net> Sent: Thursday, February 25, 2010 6:40 AM Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > > Once upon a time I'd heard from others wiser than I that the two springs > should be different. This is so they apply unequal forces on the tailwheel > and put a light loading on the linkages. Otherwise, a force-neutral setup > could allow an unwanted oscillation which could ruin your day. Picture the > flutter that would happen if your elevator weren't loaded to one side; > same concept. > > Jim Ash > > > -----Original Message----- > From: helspersew(at)aol.com > Sent: Feb 25, 2010 7:35 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > > > That settles it, I already have some light weight springs I bought from > Mcmasters. Hook to rudder! > > Dan Helsper > Poplar Grove, IL. > > > -----Original Message----- > From: bill55 <bliimatainen(at)antennaplus.com> > To: pietenpol-list(at)matronics.com > Sent: Thu, Feb 25, 2010 5:47 am > Subject: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > > > > > Dan, > > We just finished and test flew the Model A powered Sky Scout based in > Brodhead > (this past November) and originally had the tail skid. It did not take > long to > realize we needed a steerable tail wheel! We used a Ken Perkins design > (due to > time constraint) and attached to the lower rudder with light springs (as > Dennis > Hall on his Aircamper). The process worked great except for the full > swivel > design of the tail wheel. I machined that out and the airplane flys and > ground > handles great. Feel free to check it out at Brodhead as anyone knows how > to get > into my hangar. I was always apprehensive about the horns on the lower > rudder > but am convinced this is logical solution (and possibly lighter?) > > Bill Liimatainen > Monroe, Wisconsin > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288111#288111 > > > =================================== > t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > =================================== > tp://forums.matronics.com > =================================== > _blank>http://www.matronics.com/contribution > =================================== > > > ________________________________________________________________________________
Subject: Re: Dick's two cylinder Harley engine
Date: Feb 25, 2010
There was a little biplane at Brodhead that had one of those Harley engines. It was called a Snyder Baby Bomber (I think), and was owned by the late Denny Trone, (again, I think). I watched it taxi towards the runway once, but the engine stalled part way, and had to be pulled back to the hangar. Not sure if it's still there. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288215#288215 Attachments: http://forums.matronics.com//files/brodhead_328_small_186.jpg ________________________________________________________________________________
Date: Feb 25, 2010
About five years ago at the Dayton Air Show a University Engineering Class brought a 1905 Wright Flyer replica with a Twin Cam 88. It too had the balanced ( softtail ) engine. I'm sure they flew it at Dayton and I think it was at Oshkosh the next year. http://www.usuwrightflyer.org/news/2003-mar13-slt Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288216#288216 ________________________________________________________________________________
Subject: another Russian Aircamper
Date: Feb 25, 2010
http://www.reaa.ru/yabbfiles/Attachments/DSC09481-1_001.JPG ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Subject: Sky Scout...
Date: Feb 25, 2010
I think the Sprit of St. Louis" used round tubing for All landing gear, and struts... Was streamlined with Balsa! Round Tube is VERY draggy!!!!!!!!!!!!!!!! Dave -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Ray Krause Sent: Thursday, February 25, 2010 1:55 PM Subject: Re: Pietenpol-List: Sky Scout... Oscar, It would be nice to see the data on the drag of the various materials, but I will believe you...I plan to use the streamlined material. I sure enjoy your postings to this site. Ray ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Thursday, February 25, 2010 6:06 AM Subject: Pietenpol-List: Sky Scout... > > > Guys, if you don't already have the original > Flying & Glider Manuals, you should get a copy > by all means. Besides the Air Camper and Sky > Scout plans and details, there are a whole > bunch of other interesting aircraft in them, > well worth your time to peruse. > > And for whoever mentioned that they didn't > think there was much difference in drag between > round and streamline tubing, there really is. > I can dig up the old aircraft design manual > that has a graph of relative drag between > round, simple teardrop, streamline, and one > or two other shapes. It's significant. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Feb 25, 2010
Thanks, Santiago, Beautiful plane! The streamline struts seem pretty cheap, at least on initial glance. Ray ----- Original Message ----- From: santiago morete To: pietenpol-list(at)matronics.com Sent: Thursday, February 25, 2010 8:10 AM Subject: Pietenpol-List: Sky Scout... Ray, Round tube are structurally better than streamlined struts, subjected to compression, but they are less efficient aerodynamically, as Oscar said. I chose round struts because that's what I can afford :-) Attached is a photo of a beautiful Piet with round lift struts and streamlined cabanes. Saludos Santiago ------------------------------------------------------------------------- ----- Encontra las mejores recetas con Yahoo! Cocina. http://ar.mujer.yahoo.com/cocina/ ________________________________________________________________________________
Date: Feb 25, 2010
The trick to FEA is defining a model that's practical enough to be useful. Any model of simply a mass and two opposed springs with no dampening is going to define a 2nd-order system with a natural resonant frequency. Your excitation forces are not going to be applied to the same points in both systems, and with direct cables, I suspect your feet end up being the dampeners. Taking it one step further, if your system has some ugly zeros and poles, the trick is to make sure the operating range of your system is well clear of the unstable parts. I suspect the differental springs move the center of the oscillation away from straight, so as to reduce the chance of it happening during landing and takeoff. I suppose the new resonance point would be during a tight fast hard turn, like a ground loop, but at that point your tailwheel shimmy is probably going to be way down on your list of immediate problems anyhow. Jim -----Original Message----- From: David Paule Sent: Feb 25, 2010 4:03 PM Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder I thought about this some more and decided that springs of different spring constants would have no effect. This is because the net torque about the steering axis is the same. To verify this, I made a simple finite element model and sure enough, with two identical springs I got a certain natural frequency. With one spring slightly lower and one spring slightly higher in value, adding to the same total amount, the resulting natural frequency was identical. Just use two springs the same, life is simpler that way. It's damping that prevents the shimmy. David Paule ----- Original Message ----- From: "Jim Ash" <ashcan(at)earthlink.net> Sent: Thursday, February 25, 2010 7:40 AM Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > > Once upon a time I'd heard from others wiser than I that the two springs should be different. This is so they apply unequal forces on the tailwheel and put a light loading on the linkages. Otherwise, a force-neutral setup could allow an unwanted oscillation which could ruin your day. Picture the flutter that would happen if your elevator weren't loaded to one side; same concept. > > Jim Ash > > > > -----Original Message----- > From: helspersew(at)aol.com > Sent: Feb 25, 2010 7:35 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > > > That settles it, I already have some light weight springs I bought from Mcmasters. Hook to rudder! > > Dan Helsper > Poplar Grove, IL. > > > > > > -----Original Message----- > From: bill55 <bliimatainen(at)antennaplus.com> > To: pietenpol-list(at)matronics.com > Sent: Thu, Feb 25, 2010 5:47 am > Subject: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > > > > Dan, > > We just finished and test flew the Model A powered Sky Scout based in Brodhead > (this past November) and originally had the tail skid. It did not take long to > realize we needed a steerable tail wheel! We used a Ken Perkins design (due to > time constraint) and attached to the lower rudder with light springs (as Dennis > Hall on his Aircamper). The process worked great except for the full swivel > design of the tail wheel. I machined that out and the airplane flys and ground > handles great. Feel free to check it out at Brodhead as anyone knows how to get > into my hangar. I was always apprehensive about the horns on the lower rudder > but am convinced this is logical solution (and possibly lighter?) > > Bill Liimatainen > Monroe, Wisconsin > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288111#288111 > > > > > > > > ========== > t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ========== > tp://forums.matronics.com > ========== > _blank>http://www.matronics.com/contribution > ========== > > > > > > > ========== > Pietenpol-List Un/Subscription, > --> http://www.matronics.com/Navigator?Pietenpol-List bsp; via the href="http://forums.matronics.com">http://forums.matronics.com bsp; - generous support! > bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > ========== > > > ________________________________________________________________________________
Subject: Re: laminating struts and tv
Date: Feb 25, 2010
I checked the DAP site and found this data sheet what I think is for the better product. I've used it to build my tail feathers and testing shows that the joint fails anywhere BUT the actual glue line. This is also the more water resistant/tolerant product than the water activated. Incidentally, I mix the stuff using a beam balance scale my ex-wife got from the US Attorneys office after a drug case was adjudicated. It still has the "Evidence" sticker on it. One of the few useful things I ever got from her. http://www.dap.com/docs/tech/00030205.pdf Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288235#288235 ________________________________________________________________________________
Date: Feb 25, 2010
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Subject: Tailwheel & shimmy
This can be useful for those of us who design our own tailwheels. As far as I know, (not too far) the main cause of tailwheel shimmy-is an incorrect castor angle. Saludos - Santiago=0A=0A=0A Yahoo! Cocina=0A=0AEncontra las mejores recetas con Yahoo! Cocina.=0A=0A=0Ahttp://ar.mujer.yahoo.com/cocina/ ________________________________________________________________________________
Subject: Re: Tailwheel & shimmy
Date: Feb 25, 2010
Isn't that going to change as the spring flexes? Especialy on landing? The one thing I could see happening is that, with the already negative "castor", The angle is going to get closer to the horizontal with flexing and negate steering capability. The principle of differential springs here is paralleled with the reason for offsetting the jury struts. Harmonic vibration. Clif "My soul is in the sky." ~ William Shakespeare This can be useful for those of us who design our own tailwheels. As far as I know, (not too far) the main cause of tailwheel shimmy is an incorrect castor angle. Saludos Santiago ________________________________________________________________________________
Subject: Sky Scout.."Glue" question?
Date: Feb 25, 2010
The discussion on laminating struts has touched on glue/adhesives to be used, or that could be used. When building the aircraft, using the two part epoxy adhesives (T-88) is a little cumbersome. What about single stage poly urethane adhesives/glues, i.e. Gorilla Glue, Titebond? Has anyone used these, with what results? There are mixed reviews on this subject: Fine Woodworking (August '07) and woodgears.ca/joint_strength/glue.html . I am sure there are other reports both supportive and contradictive. I have tested Gorilla Glue with aircraft spruce and plywood, spruce long grain to long grain and butt to long grain and cross grain: with proper usage, the wood breaks before the glue bond. That is, wood grains come off with the break. Hope this does not cause any consternation! Ray Krause ________________________________________________________________________________
Date: Feb 25, 2010
I beg to differ, there is a tailwheel plan in the original plans. It even has a parking brake incorporated in it. Gene ----- Original Message ----- From: Rick Holland<mailto:at7000ft(at)gmail.com> To: pietenpol-list(at)matronics.com Sent: Thursday, February 25, 2010 11:14 AM Subject: Re: Pietenpol-List: Steerable tailwheel- hooked to rudder > Excellent design Skip. I know we are not supposed to change anything from the Piet plans but since the plans do not include a tailwheel (and a left and right cable running to a tailwheel control horn), I think we can give Skip official dispensation here. I think this design simplifies and improves the design of any Piet incorporating a tailwheel and is based on a flight proven design (the GN-1). I will do it this way on my next Piet project. Rick On Thu, Feb 25, 2010 at 10:12 AM, Skip Gadd > wrote: > Dan, > I made a double horn for rudder and tailwheel steering so the torsional load > from the tailwheel would not have to travel through wood. Also since the > rudder horn is moved to the bottom of the rudder I added some extra support > to spread the load up the rudder. The horns are constructed like > Pietenpols, two pieces of .032 edge welded. The attached picture is the > current status of the project, so the design has not been flight tested. > Skip > > > > ----- Original Message ----- > From: > To: pietenpol-list(at)matronics.com > Sent: 2/24/2010 7:48:58 PM > Subject: Pietenpol-List: Steerable tailwheel- hooked to rudder > Hi Guys, > > I have been wrestling with the engineering of making my free-castoring > tailwheel into a steerable type. The conventional wisdom on this list has > been that one should not connect the tailwheel with the rudder, as per the > Aeronca Champ, and many others of that era, due to the fact (?) that the > wooden rudder is not strong enough to handle the loads. I see that Ken > Perkin's Time Machine is set-up just that way. > > Any new thoughts on this subject? > > Dan Helsper > Poplar Grove, IL. > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Feb 25, 2010
Santiago, Thanks for posting that! I designed my own tailwheel, but had no idea if the geometry was good.now I can check it. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of santiago morete Sent: Thursday, February 25, 2010 5:26 PM Subject: Pietenpol-List: Tailwheel & shimmy This can be useful for those of us who design our own tailwheels. As far as I know, (not too far) the main cause of tailwheel shimmy is an incorrect castor angle. Saludos Santiago _____ Encontra las mejores recetas con Yahoo! Cocina.
Subject: Re: Sky Scout.."Glue" question?
Date: Feb 25, 2010
One problem with gorilla glue is that it has not been tested over time. Yes, a glue joint is strong, but in ten years? twenty? after repeated temperature changes?? Stick with the known glues, they are not all that expensive. Gene ----- Original Message ----- From: Ray Krause<mailto:raykrause(at)frontiernet.net> To: pietenpol-list(at)matronics.com Sent: Thursday, February 25, 2010 9:57 PM Subject: Pietenpol-List: Sky Scout.."Glue" question? The discussion on laminating struts has touched on glue/adhesives to be used, or that could be used. When building the aircraft, using the two part epoxy adhesives (T-88) is a little cumbersome. What about single stage poly urethane adhesives/glues, i.e. Gorilla Glue, Titebond? Has anyone used these, with what results? There are mixed reviews on this subject: Fine Woodworking (August '07) and woodgears.ca/joint_strength/glue.html . I am sure there are other reports both supportive and contradictive. I have tested Gorilla Glue with aircraft spruce and plywood, spruce long grain to long grain and butt to long grain and cross grain: with proper usage, the wood breaks before the glue bond. That is, wood grains come off with the break. Hope this does not cause any consternation! Ray Krause http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Feb 25, 2010
Yes, Clif, I agree with you.- The negative castor angle should be conside red with the airplane fully loaded.- Here is the article from where I too k the graphic www.pierceaero.net/tws.php I think you are right about the springs, in fact, the Maule-anti-shimmy s prings that Aircraft Spruce,-and other sells, are nothing more than sprin gs of different sizes. Saludos - Santiago=0A=0A=0A Yahoo! Cocina=0A=0AEncontra las mejores recetas con Yahoo! Cocina.=0A=0A=0A
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Feb 26, 2010
My experience with Gorilla Glue is that it requires a very precise clamping pressure and no gaps to make a strong joint. To much pressure and you starve the joint & that's where it fails. Too little pressure or gaps and you get foaming with zero joint strength. Also, as Gene says, there's no history yet, so it's impossible to say if it will hold up. Titebond 3 is more forgiving but you still need a good wood-wood fit and the right clamping pressure. Compared to epoxy, it has a much lower gap strength, but better than Gorilla. Given that it's based on much older chemistry/technology than Gorilla Glue, I'd guess it will last about as long as it's older white glue (Elmer's) predecessors i.e. a long time in a protected environment. Whether or not it's truly waterproof, and therefore able to retain strength, in an unprotected environment for a long time is also an unanswered question. I would not use either glue in a structural situation, although I think that would be an interesting experiment for Titebond 3, just not a flying experiment at this point ;) Kip Gardner On Feb 25, 2010, at 9:57 PM, Ray Krause wrote: > The discussion on laminating struts has touched on glue/adhesives > to be used, or that could be used. When building the aircraft, > using the two part epoxy adhesives (T-88) is a little cumbersome. > What about single stage poly urethane adhesives/glues, i.e. Gorilla > Glue, Titebond? Has anyone used these, with what results? There > are mixed reviews on this subject: Fine Woodworking (August '07) > and woodgears.ca/joint_strength/glue.html . I am sure there are > other reports both supportive and contradictive. > > I have tested Gorilla Glue with aircraft spruce and plywood, spruce > long grain to long grain and butt to long grain and cross grain: > with proper usage, the wood breaks before the glue bond. That is, > wood grains come off with the break. > > Hope this does not cause any consternation! > > Ray Krause > > ________________________________________________________________________________
Date: Feb 26, 2010
Gorilla glue expands as it cures .I made the mistake of using it on the rub ber trim that I put around my wing end covers.I had to do a lot of triming afterwards to get the exccess off.=0A=0A=0A=0A=0A__________________________ ______=0AFrom: Gene Rambo <generambo(at)msn.com>=0ATo: pietenpol-list@matronic s.com=0ASent: Thu, February 25, 2010 10:27:17 PM=0ASubject: Re: Pietenpol-L ist: Sky Scout.."Glue" question?=0A=0A=0AOne problem with gorilla glue is t hat it has not been tested over time.- Yes, a glue joint is strong, but i n ten years?- twenty?- after repeated temperature changes??- Stick wi th the known glues, they are not all that expensive.=0A=0AGene=0A----- Orig inal Message ----- =0A>From: Ray Krause =0A>To: pietenpol-list(at)matronics.co m =0A>Sent: Thursday, February 25, 2010 9:57 PM=0A>Subject: Pietenpol-List: Sky Scout.."Glue" question?=0A>=0A>=0A>The discussion on laminating struts has touched on glue/adhesives to be used, or that could be used.- When b uilding the aircraft, using the two part epoxy adhesives (T-88) is a little cumbersome.- What about single stage poly urethane adhesives/glues, i.e. Gorilla Glue, Titebond?- Has anyone used these, with what results?- Th ere are mixed reviews on this subject: Fine Woodworking (August '07) and wo odgears.ca/joint_strength/glue.html .-I am sure there are other reports b oth supportive and contradictive.=0A>-=0A>I have tested Gorilla Glue with aircraft spruce and plywood, spruce long grain to long grain and butt to l ong grain and cross grain:- with proper usage, the wood breaks before the glue bond.- That is, wood grains come off with the break.=0A>-=0A>Hope this does not cause any consternation!=0A>-=0A>Ray Krause=0A>=0A>=0A>tit le=http://www.matronics.com/Navigator?Pietenpol-List href="http://www.m atronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?P ietenpol-List=0A>href="http://forums.matronics.com">http://forums.matroni cs.com=0A>href="http://www.matronics.com/contribution">http://www.matroni ======================= ________________________________________________________________________________
Date: Feb 26, 2010
Maybe I'm weird (uh, OK...), but I like working with T-88 epoxy. I save used Coke cans, turn them upside down, their bottoms make perfect miniature mixing dishes. The can itself, oddly enough, fits most hands perfectly, so it's easy to hold the mixing dish without getting glue all over you. Some people spend a lot of time trying to get the perfetc 50/50 mix between hardener and resin, but I am not sure that that is hyper-critical. TLAR seems to work out pretty well when using T-88. -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]." <michael.d.cuy(at)nasa.gov>
Date: Feb 26, 2010
Subject: The Flying Life by Sport Aviation author Lauran Paine
For any of you who are fans of Lauran Paine's articles in EAA's Sport Aviat ion Magazine, you'll probably want to have this book on your coffee table. Amazon.com carries it. In this last EAA issue Lauran did a story about a gent (and good friend) wh o is building a Pietenpol in Texas. Mike C. The Flying Life: stories for the aviation soul (Volume 1) Lauran Paine Jr.<http://www.amazon.com/s/ref=ntt_athr_dp_sr_1?_encoding =UTF8&sort=relevancerank&search-alias=books&field-author=Lauran%20P aine%20Jr.> (Author) No customer reviews yet. Be the first.<http://www.amazon.com/review/create- review/ref=dp_top_cm_cr_acr_wr_link?ie=UTF8&nodeID=&asin=0965760707 > ________________________________ Price: $14.95 & eligible for FREE Super Saver Shipping on orders over $25. Details <http://www.amazon.com/gp/help/customer/display.html/ref=mk_gship_dp?ie =UTF8&nodeId=527692&pop-up=1> o o In Stock. Ships from and sold by Amazon.com. Gift-wrap available. Want it delivered Monday, March 1? Order it in the next 5 hours and 18 minutes, and choose One-Day Shipping at checkout. Details<http://www.amazon.com/gp/help/customer/display.html/ref=ftinfo_dp _?ie=UTF8&nodeId=3510241&pop-up=1> From: TomTravis(at)aol.com [mailto:TomTravis(at)aol.com] Sent: Thursday, February 25, 2010 9:07 PM Subject: Fwd: oil and drips Just FYI, the new book, "The Flying Life," is out.....at amazon.com, anyway . I don't have any hard copies yet...only the "proof copy." Hard copies come later. It's pretty evident that publishing is an on-line computer-world any more. They asked me if I wanted to put it on "Kindle." I said, "What's Kindle? I've heard of kindling but not kindle." A book in an electronic box??!!? C'mom!!! Anyway....more later..... Lauran ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: anybody near Portland?
Date: Feb 26, 2010
I'll be flying into Portland March 4 and have the aft free. Anybody building a Piet out there? Douwe ________________________________________________________________________________
Subject: Sky Scout..."Glue"question?
Date: Feb 26, 2010
If anyone is a member or subscriber to "Fine Woodworking", they ran a glue comparison in August of 2007 on six of the common wood glues, here: http://www.finewoodworking.com/Materials/MaterialsPDF.aspx?id=28897 I'm not a member so I can't access the article but I think I remember the results and Gorilla Glue didn't place too well in the tests. My own experience with it has NOT been on airplane stuff but what I've found is that even with the air squeezed out of the container and the container tightly capped, the stuff will set up on the shelf and be useless so there's no point in buying more than you can readily use. It also foams out of the joint considerably, if you care about that. It's T88 for me... Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Feb 26, 2010
Subject: was glue question now latex paint
So what is the best type of latex paint we should use on our fabric ? I'm going to build my next Piet for under $5K using Elmers, Home Depot lumber, all aluminum fittings, Ace Hardware, and latex paint with a junkyard Suzuki Sidekick engine and then............ take my family and loved ones for airplane rides !!! PS-- though I'm not a fan of latex, I don't blame some builders from using it because of the cost savings and easy clean up...even if it normally does look like crap. ________________________________________________________________________________
Date: Feb 26, 2010
Subject: Re: anybody near Portland?
If no one shows up you MUST get down to McMinville (south of Portland I think) to see Howard Hughes' Spruce Goose (which has VERY little spruce!). It's a bit of a drive from Portland but I'll bet it's worth it! It's supposed to be in a pretty neat museum..... -----Original Message----- >From: Douwe Blumberg <douweblumberg(at)earthlink.net> >Sent: Feb 26, 2010 9:32 AM >To: pietenpolgroup >Subject: Pietenpol-List: anybody near Portland? > > >I'll be flying into Portland March 4 and have the aft free. Anybody >building a Piet out there? > >Douwe > > ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: McMinnville photo
Date: Feb 26, 2010
Here is a shot of a P-38 and part of the Spruce Goose at McMinnville. Rick Schreiber Richard Schreiber lmforge(at)earthlink.net Why Wait? Move to EarthLink. ________________________________________________________________________________
Date: Feb 26, 2010
Another worthwhile stop is Pearson Field across the river from Portland International. They have a great museum and one of the oldest airports in the country. The first aircraft landing here was in 1911! here is a link http://www.cityofvancouver.us/history.asp?menuid=10466&submenuid=10537&itemID=16095 Rick Schreiber > [Original Message] > From: Jim Markle <jim_markle(at)mindspring.com> > To: > Date: 2/26/2010 10:19:59 AM > Subject: Re: Pietenpol-List: anybody near Portland? > > > If no one shows up you MUST get down to McMinville (south of Portland I think) to see Howard Hughes' Spruce Goose (which has VERY little spruce!). > > It's a bit of a drive from Portland but I'll bet it's worth it! It's supposed to be in a pretty neat museum..... > > > -----Original Message----- > >From: Douwe Blumberg <douweblumberg(at)earthlink.net> > >Sent: Feb 26, 2010 9:32 AM > >To: pietenpolgroup > >Subject: Pietenpol-List: anybody near Portland? > > > > > >I'll be flying into Portland March 4 and have the aft free. Anybody > >building a Piet out there? > > > >Douwe > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 26, 2010
dfwplt wrote: > If no one shows up you MUST get down to McMinville (south of Portland I think) to see Howard Hughes' Spruce Goose (which has VERY little spruce!). > > It's a bit of a drive from Portland but I'll bet it's worth it! It's supposed to be in a pretty neat museum..... > > > > -- Drive??? why not fly in, there is an airport across the street. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288319#288319 ________________________________________________________________________________
Subject: Torque Tube Safety Bracket
Date: Feb 26, 2010
I am planning to weld brackets over my torque tube collars (as I've seen others do very nicely) and I finally made a bending jig which gives good results (attached). My question is regarding the middle "Safety Bracket" (correct term?) in the middle of the torque tube, which measures 2 1/4" high (unless I am miss-reading). Does anyone know the purpose for this being over-sized? Has anyone just opted to make another collar and bracket, as on the ends? Or is there some, unforeseen alignment problem which will become obvious when I go to install? Thanks. Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288320#288320 Attachments: http://forums.matronics.com//files/84_metal_bending_jig_2_897.jpg ________________________________________________________________________________
Date: Feb 26, 2010
Kip, I agree about the "gap filling" feature of Gorilla glue. If the joint is not tight, the filler is very weak and does not serve as a bond. But in the areas of true contact, the joint seems to be very strong. As far as clamping goes, it seems take a lot of squeeze pressure to squeeze out enough glue to cause "starvation" because the glue foams in between the joint. I think the foaming creates enough pressure to impregnate the wood. In my "tests", where I glued aircraft plywood to spruce (as in gussets) and used 5/8" brads (from a brad gun) and no clamps, there is always significant wood failure, not joint failure. Sometimes the outer veneer of the plywood separates and sticks to the spruce! You and Gene are correct, there is no history proving the longevity of the bonds. Please note that none of my "tests" are scientific nor calibrated. They are only based on observation of the wood breaking before the bond. I plan to place some of the bonds in water and organic solvents to see if they weaken. As an interesting side note: I have been looking for a small bead to place in the fuel sight tube on my Waiex so I can more easily see the fuel level. I have found nothing that will both float and not dissolve. One day I had a bright idea to try some of the foam from the Gorilla Glue that had dripped on the work bench. After about 7 days, it was still floating and not dissolved (the fuel evaporated!). It also floated in turpentine for over a month, is still floating and still intact! Ray Krause ----- Original Message ----- From: Kip and Beth Gardner To: pietenpol-list(at)matronics.com Sent: Friday, February 26, 2010 4:01 AM Subject: Re: Pietenpol-List: Sky Scout.."Glue" question? My experience with Gorilla Glue is that it requires a very precise clamping pressure and no gaps to make a strong joint. To much pressure and you starve the joint & that's where it fails. Too little pressure or gaps and you get foaming with zero joint strength. Also, as Gene says, there's no history yet, so it's impossible to say if it will hold up. Titebond 3 is more forgiving but you still need a good wood-wood fit and the right clamping pressure. Compared to epoxy, it has a much lower gap strength, but better than Gorilla. Given that it's based on much older chemistry/technology than Gorilla Glue, I'd guess it will last about as long as it's older white glue (Elmer's) predecessors i.e. a long time in a protected environment. Whether or not it's truly waterproof, and therefore able to retain strength, in an unprotected environment for a long time is also an unanswered question. I would not use either glue in a structural situation, although I think that would be an interesting experiment for Titebond 3, just not a flying experiment at this point ;) Kip Gardner On Feb 25, 2010, at 9:57 PM, Ray Krause wrote: The discussion on laminating struts has touched on glue/adhesives to be used, or that could be used. When building the aircraft, using the two part epoxy adhesives (T-88) is a little cumbersome. What about single stage poly urethane adhesives/glues, i.e. Gorilla Glue, Titebond? Has anyone used these, with what results? There are mixed reviews on this subject: Fine Woodworking (August '07) and woodgears.ca/joint_strength/glue.html . I am sure there are other reports both supportive and contradictive. I have tested Gorilla Glue with aircraft spruce and plywood, spruce long grain to long grain and butt to long grain and cross grain: with proper usage, the wood breaks before the glue bond. That is, wood grains come off with the break. Hope this does not cause any consternation! Ray Krause href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Date: Feb 26, 2010
Yes, it expands 3-4 times its volume. If the joint is not clamped or nailed, the joint will separate and be very weak. A spruce to spruce joint with a plywood gusset nailed with a brad gun is almost impossible to get apart! Ray Krause ----- Original Message ----- From: H RULE To: pietenpol-list(at)matronics.com Sent: Friday, February 26, 2010 4:25 AM Subject: Re: Pietenpol-List: Sky Scout.."Glue" question? Gorilla glue expands as it cures .I made the mistake of using it on the rubber trim that I put around my wing end covers.I had to do a lot of triming afterwards to get the exccess off. ------------------------------------------------------------------------- ----- From: Gene Rambo <generambo(at)msn.com> To: pietenpol-list(at)matronics.com Sent: Thu, February 25, 2010 10:27:17 PM Subject: Re: Pietenpol-List: Sky Scout.."Glue" question? One problem with gorilla glue is that it has not been tested over time. Yes, a glue joint is strong, but in ten years? twenty? after repeated temperature changes?? Stick with the known glues, they are not all that expensive. Gene ----- Original Message ----- From: Ray Krause To: pietenpol-list(at)matronics.com Sent: Thursday, February 25, 2010 9:57 PM Subject: Pietenpol-List: Sky Scout.."Glue" question? The discussion on laminating struts has touched on glue/adhesives to be used, or that could be used. When building the aircraft, using the two part epoxy adhesives (T-88) is a little cumbersome. What about single stage poly urethane adhesives/glues, i.e. Gorilla Glue, Titebond? Has anyone used these, with what results? There are mixed reviews on this subject: Fine Woodworking (August '07) and woodgears.ca/joint_strength/glue.html . I am sure there are other reports both supportive and contradictive. I have tested Gorilla Glue with aircraft spruce and plywood, spruce long grain to long grain and butt to long grain and cross grain: with proper usage, the wood breaks before the glue bond. That is, wood grains come off with the break. Hope this does not cause any consternation! Ray Krause title=http://www.matronics.com/Navigator?Pietenpol-List href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navig.matronics.com/" rel=nofollow target=_blank>http://forums.matronics.com ________________________________________________________________________________
Date: Feb 26, 2010
Subject: Re: was glue question now latex paint
I need to remember to take a BIG can of whup ass next time I go to Cleveland.... -----Original Message----- >From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov> >Sent: Feb 26, 2010 10:14 AM >To: "pietenpol-list(at)matronics.com" >Subject: Pietenpol-List: was glue question now latex paint > > >So what is the best type of latex paint we should use on our fabric ? > >I'm going to build my next Piet for under $5K using Elmers, Home Depot lumber, >all aluminum fittings, Ace Hardware, and latex paint with a junkyard Suzuki >Sidekick engine and then............ > >take my family and loved ones for airplane rides !!! > > >PS-- though I'm not a fan of latex, I don't blame some builders from using it >because of the cost savings and easy clean up...even if it normally does look like crap. > > ________________________________________________________________________________
Date: Feb 26, 2010
Dan, N8031 has the steerable tailwheel attached to control horns bolted to the bottom of the rudder. It's flown 400+ hours that way and most of that on pavement, which I would guess puts a higher load on the tailwheel during turning. That's a WAG, though. You can just see the horns in this (fuzzy) picture: http://5n429glenoak.homelinux.net/gallery/N8031/img_2592 Dan On 02/24/2010 06:15 PM, helspersew(at)aol.com wrote: > Hi Guys, > I have been wrestling with the engineering of making my free-castoring > tailwheel into a steerable type. The conventional wisdom on this list > has been that one should not connect the tailwheel with the rudder, as > per the Aeronca Champ, and many others of that era, due to the fact (?) > that the wooden rudder is not strong enough to handle the loads. I see > that Ken Perkin's Time Machine is set-up just that way. > Any new thoughts on this subject? > Dan Helsper > Poplar Grove, IL. > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Feb 26, 2010
Yeah, but isn't it enough that he has to live near Cleveland? Jeff (originally Okie) > >I need to remember to take a BIG can of whup ass next time I go to >Cleveland.... > > ________________________________________________________________________________
Date: Feb 26, 2010
Correct, I was thinking about the original Flying and Glider manual plans. On Thu, Feb 25, 2010 at 10:39 PM, Gene Rambo wrote: > I beg to differ, there is a tailwheel plan in the original plans. It even > has a parking brake incorporated in it. > > Gene > > ----- Original Message ----- > From: Rick Holland > To: pietenpol-list(at)matronics.com > Sent: Thursday, February 25, 2010 11:14 AM > Subject: Re: Pietenpol-List: Steerable tailwheel- hooked to rudder > > Excellent design Skip. I know we are not supposed to change anything > from the Piet plans but since the plans do not include a tailwheel > (and a left and right cable running to a tailwheel control horn), I > think we can give Skip official dispensation here. I think this design > simplifies and improves the design of any Piet incorporating a > tailwheel and is based on a flight proven design (the GN-1). I will do > it this way on my next Piet project. > > Rick > > On Thu, Feb 25, 2010 at 10:12 AM, Skip Gadd wrote: >> Dan, >> I made a double horn for rudder and tailwheel steering so the torsional >> load >> from the tailwheel would not have to travel through wood. Also since the >> rudder horn is moved to the bottom of the rudder I added some extra >> support >> to spread the load up the rudder. The horns are constructed like >> Pietenpols, two pieces of .032 edge welded. The attached picture is the >> current status of the project, so the design has not been flight tested. >> Skip >> >> >> >> ----- Original Message ----- >> From: >> To: pietenpol-list(at)matronics.com >> Sent: 2/24/2010 7:48:58 PM >> Subject: Pietenpol-List: Steerable tailwheel- hooked to rudder >> Hi Guys, >> >> I have been wrestling with the engineering of making my free-castoring >> tailwheel into a steerable type. The conventional wisdom on this list has >> been that one should not connect the tailwheel with the rudder, as per the >> Aeronca Champ, and many others of that era, due to the fact (?) that the >> wooden rudder is not strong enough to handle the loads. I see that Ken >> Perkin's Time Machine is set-up just that way. >> >> Any new thoughts on this subject? >> >> Dan Helsper >> Poplar Grove, IL. >> >> > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell p; Features Chat, > http://www.matnbsp; via the Web title=http://forums.matronics.com/ > href="http://forums.matronics.com">http://forums.matronics.com > _p; generous bsp; > title=http://www.matronics.com/contribution > href="http://www.matronics.com/contribution">http://www.matronics.com/c================ > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Feb 26, 2010
The springs attached to the tailwheel on N8031 apply zero force when in the neutral position. Therefore, no oscillation is present and no dampening is required. Dan On 02/25/2010 05:46 PM, Jim Ash wrote: > --> Pietenpol-List message posted by: Jim Ash > > The trick to FEA is defining a model that's practical enough to be useful. Any model of simply a mass and two opposed springs with no dampening is going to define a 2nd-order system with a natural resonant frequency. Your excitation forces are not going to be applied to the same points in both systems, and with direct cables, I suspect your feet end up being the dampeners. > > Taking it one step further, if your system has some ugly zeros and poles, the trick is to make sure the operating range of your system is well clear of the unstable parts. I suspect the differental springs move the center of the oscillation away from straight, so as to reduce the chance of it happening during landing and takeoff. I suppose the new resonance point would be during a tight fast hard turn, like a ground loop, but at that point your tailwheel shimmy is probably going to be way down on your list of immediate problems anyhow. > > Jim > > > -----Original Message----- > From: David Paule > Sent: Feb 25, 2010 4:03 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > > > > > I thought about this some more and decided that springs of different spring constants would have no effect. This is because the net torque about the steering axis is the same. > > To verify this, I made a simple finite element model and sure enough, with two identical springs I got a certain natural frequency. With one spring slightly lower and one spring slightly higher in value, adding to the same total amount, the resulting natural frequency was identical. > > Just use two springs the same, life is simpler that way. > > It's damping that prevents the shimmy. > > David Paule > > > ----- Original Message ----- > From: "Jim Ash"<ashcan(at)earthlink.net> > To: > Sent: Thursday, February 25, 2010 7:40 AM > Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder > >> --> Pietenpol-List message posted by: Jim Ash >> >> Once upon a time I'd heard from others wiser than I that the two springs should be different. This is so they apply unequal forces on the tailwheel and put a light loading on the linkages. Otherwise, a force-neutral setup could allow an unwanted oscillation which could ruin your day. Picture the flutter that would happen if your elevator weren't loaded to one side; same concept. >> >> Jim Ash >> >> >> >> -----Original Message----- >> From: helspersew(at)aol.com >> Sent: Feb 25, 2010 7:35 AM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder >> >> >> That settles it, I already have some light weight springs I bought from Mcmasters. Hook to rudder! >> >> Dan Helsper >> Poplar Grove, IL. >> >> >> >> >> >> -----Original Message----- >> From: bill55<bliimatainen(at)antennaplus.com> >> To: pietenpol-list(at)matronics.com >> Sent: Thu, Feb 25, 2010 5:47 am >> Subject: Pietenpol-List: Re: Steerable tailwheel- hooked to rudder >> >> >> --> Pietenpol-List message posted by: "bill55" >> >> Dan, >> >> We just finished and test flew the Model A powered Sky Scout based in Brodhead >> (this past November) and originally had the tail skid. It did not take long to >> realize we needed a steerable tail wheel! We used a Ken Perkins design (due to >> time constraint) and attached to the lower rudder with light springs (as Dennis >> Hall on his Aircamper). The process worked great except for the full swivel >> design of the tail wheel. I machined that out and the airplane flys and ground >> handles great. Feel free to check it out at Brodhead as anyone knows how to get >> into my hangar. I was always apprehensive about the horns on the lower rudder >> but am convinced this is logical solution (and possibly lighter?) >> >> Bill Liimatainen >> Monroe, Wisconsin >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=288111#288111 >> >> >> >> >> >> >> >> ========== >> t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> tp://forums.matronics.com >> ========== >> _blank>http://www.matronics.com/contribution >> ========== >> >> >> >> >> >> >> ========== >> Pietenpol-List Un/Subscription, >> --> http://www.matronics.com/Navigator?Pietenpol-List > > bsp; via the href="http://forums.matronics.com">http://forums.matronics.com > > bsp; - generous support! >> bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> ========== >> >> >> > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: anybody near =?UTF-8?Q?Portland=3F?
Date: Feb 26, 2010
I live in the Portland area and I'm building a Piet! Well I have a few ribs built anyway :) It's been too cold to work in my garage this winter, so unfortunately, my building activity has been very limited. All of those museums around here are really great. Actually I've never made it up to the one at Pearson Field. In addition to those mentioned is a museum at Hood River - old cars and old planes. Among the planes I saw there was a ... Pietenpol! (SkyScout) ALso such things as Taylor Cub, Aeronca C-3, Boeing 40, etc. Let me know what your plans are and maybe we can get together. --Ken wrote: > > > I'll be flying into Portland March 4 and have the aft free. Anybody > building a Piet out there? > > Douwe > > ________________________________________________________________________________
Date: Feb 26, 2010
http://www.goldenageair.org/collection/1917_rumpler_c_v.htm Painted with Sherwin-Williams best exterior latex - Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288350#288350 ________________________________________________________________________________
Date: Feb 26, 2010
Jim, Mikee's not worth it! Come on down my way (one hr. south of Cleveland) & I'll show you how to keep bees instead & oh yeah, you can have a look at my semi-dormant project too. Kip Gardner On Feb 26, 2010, at 12:49 PM, Jim Markle wrote: > > > > I need to remember to take a BIG can of whup ass next time I go to > Cleveland.... > > -----Original Message----- >> From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" >> >> Sent: Feb 26, 2010 10:14 AM >> To: "pietenpol-list(at)matronics.com" >> Subject: Pietenpol-List: was glue question now latex paint >> >> [ASRC Aerospace Corporation]" >> >> So what is the best type of latex paint we should use on our fabric ? >> >> I'm going to build my next Piet for under $5K using Elmers, Home >> Depot lumber, >> all aluminum fittings, Ace Hardware, and latex paint with a >> junkyard Suzuki >> Sidekick engine and then............ >> >> take my family and loved ones for airplane rides !!! >> >> >> PS-- though I'm not a fan of latex, I don't blame some builders >> from using it >> because of the cost savings and easy clean up...even if it >> normally does look like crap. >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 26, 2010
Mikey is just mad because he spent $3000 on "real" aircraft paint and us latexers are only spending $200. rick On Fri, Feb 26, 2010 at 3:20 PM, Kip and Beth Gardner wrote: > > > Jim, > > Mikee's not worth it! Come on down my way (one hr. south of Cleveland) & > I'll show you how to keep bees instead & oh yeah, you can have a look at my > semi-dormant project too. > > Kip Gardner > > > On Feb 26, 2010, at 12:49 PM, Jim Markle wrote: > >> >> >> >> I need to remember to take a BIG can of whup ass next time I go to >> Cleveland.... >> >> -----Original Message----- >>> >>> From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" >>> >>> Sent: Feb 26, 2010 10:14 AM >>> To: "pietenpol-list(at)matronics.com" >>> Subject: Pietenpol-List: was glue question now latex paint >>> >>> Aerospace Corporation]" >>> >>> So what is the best type of latex paint we should use on our fabric ? >>> >>> I'm going to build my next Piet for under $5K using Elmers, Home Depot >>> lumber, >>> all aluminum fittings, Ace Hardware, and latex paint with a junkyard >>> Suzuki >>> Sidekick engine and then............ >>> >>> take my family and loved ones for airplane rides !!! >>> >>> >>> PS-- though I'm not a fan of latex, I don't blame some builders from >>> using it >>> because of the cost savings and easy clean up...even if it normally does >>> look like crap. >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Feb 26, 2010
Seriously, though... everything I've seen about the use of latex paint on aircraft indicated that the Sherwin-Williams product was the best. Consumer Reports always seems to rank their product at the top of the heap in their testing. I tested some Valspar Ultra Premium that is supposed to be nearly as good at lower cost but it has not flown on an aircraft that I know of. Sidebar: after nearly a half-dozen sincere attempts by the paint specialist at Lowe's to match the Poly- Tone yellow paint that I took for them to match the Valspar latex to, they couldn't do it. Not that the Poly-Tone color is an oddball though... it's the exact color that is used on every yellow stripe that you see painted on every road and highway in the country... "Federal Yellow". Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Dick's new Piet
Date: Feb 26, 2010
I had the rocker box covers on my Pietenpol chrome plated by a place that had an exhibit at Sun'n' Fun several years ago: Spacecoast Plating. Maybe they'll be at SNF this year and you can talk with them then, Dick. They did a good job on my rocker box covers and they were pretty inexpensive, I thought. I paid $40 for all four. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Thursday, February 25, 2010 1:02 PM Subject: Re: Pietenpol-List: Dick's new Piet Chroming for your struts? Many years ago I had a Harley with a lot of custom plating (chrome and gold) that was done at a place in Padukah KY, Brown's Plating I think. They've been around forever. Might be worth checking on for a source of your plating...I think I actually saw the place mentioned somewhere not long ago so their probably still around.... -----Original Message----- >From: Dick N <horzpool(at)goldengate.net> >Sent: Feb 25, 2010 11:28 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Dick's new Piet > > >Hi Douwe >Check out Mike Cuys post with the Harley. I'm checking on where to have all >of the chroming done for the struts and all at this point. >Dick >----- Original Message ----- >From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> >To: "pietenpolgroup" >Sent: Thursday, February 25, 2010 8:54 AM >Subject: Pietenpol-List: Dick's new Piet > > >> >> >> So Dick, >> >> What engine are you using? is this an aircamper or a scout? I'm always >> interested in different engines. >> >> Douwe >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 26, 2010
Steve, For whatever reason, I could not open the attachment. My plans are packed away somewhere so I can't review them but as I recall, the fore and aft brackets hold the tube in place and the center bracket is un-necessary. At least, looking at my pictures, I didn't install it on mine. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of chase143(at)aol.com Sent: Friday, February 26, 2010 12:19 PM Subject: Pietenpol-List: Torque Tube Safety Bracket I am planning to weld brackets over my torque tube collars (as I've seen others do very nicely) and I finally made a bending jig which gives good results (attached). My question is regarding the middle "Safety Bracket" (correct term?) in the middle of the torque tube, which measures 2 1/4" high (unless I am miss-reading). Does anyone know the purpose for this being over-sized? Has anyone just opted to make another collar and bracket, as on the ends? Or is there some, unforeseen alignment problem which will become obvious when I go to install? Thanks. Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288320#288320 Attachments: http://forums.matronics.com//files/84_metal_bending_jig_2_897.jpg ________________________________________________________________________________
Subject: latex paint
Date: Feb 26, 2010
Painted with Lowes semi gloss exterior latex. I still have the test frame in the back yard after 8 years. The message is ready to be sent with the following file or link attachments: Zxcv ________________________________________________________________________________
Subject: Re: McMinnville photo
Date: Feb 26, 2010
The most dramatic contrast to me was seeing an SR-71 sitting under the wing of the Spruce Goose. Most of the aircraft on display at McMinnville are airworthy. wrote: Here is a shot of a P-38 and part of the Spruce Goose at McMinnville. Rick Schreiber Richard Schreiber lmforge(at)earthlink.net [1] Why Wait? Move to EarthLink. Links: ------ [1] mailto:lmforge(at)earthlink.net ________________________________________________________________________________
Date: Feb 26, 2010
Mike sounds like "fisherman north". Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288408#288408 ________________________________________________________________________________
Subject: Re: Dick's new Piet
Date: Feb 26, 2010
Thanks for the suggestions, Jack and Jim. I'll check them out. Dick N. ----- Original Message ----- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Friday, February 26, 2010 3:21 PM Subject: RE: Pietenpol-List: Dick's new Piet > > > I had the rocker box covers on my Pietenpol chrome plated by a place that > had an exhibit at Sun'n' Fun several years ago: Spacecoast Plating. > Maybe > they'll be at SNF this year and you can talk with them then, Dick. They > did > a good job on my rocker box covers and they were pretty inexpensive, I > thought. I paid $40 for all four. > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle > Sent: Thursday, February 25, 2010 1:02 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Dick's new Piet > > > > Chroming for your struts? Many years ago I had a Harley with a lot of > custom plating (chrome and gold) that was done at a place in Padukah KY, > Brown's Plating I think. They've been around forever. > > Might be worth checking on for a source of your plating...I think I > actually > saw the place mentioned somewhere not long ago so their probably still > around.... > > > -----Original Message----- >>From: Dick N <horzpool(at)goldengate.net> >>Sent: Feb 25, 2010 11:28 AM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Dick's new Piet >> >> >>Hi Douwe >>Check out Mike Cuys post with the Harley. I'm checking on where to have > all >>of the chroming done for the struts and all at this point. >>Dick >>----- Original Message ----- >>From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> >>To: "pietenpolgroup" >>Sent: Thursday, February 25, 2010 8:54 AM >>Subject: Pietenpol-List: Dick's new Piet >> >> >>> >>> >>> So Dick, >>> >>> What engine are you using? is this an aircamper or a scout? I'm always >>> interested in different engines. >>> >>> Douwe >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Feb 26, 2010
This thing is incredible! I have a photo somewhere of my Cherokee in front of the doors. The cherokee is just a tiny blip at the bottom of the photo! Clif Subject: RE: Pietenpol-List: anybody near Portland? There is also a great air museum in Tillamook Oregon. That is just over to the coast from Portland. It is in an old WW2 blip hanger. I nice museum not too far from Portland. vic groah NX414MV ________________________________________________________________________________
Date: Feb 26, 2010
Struts!! Which struts. Beware of hydrogen embrittlement. I understand it's not a good thing on structural parts. Clif > > Chroming for your struts? Many years ago I had a Harley with a lot of > custom plating (chrome and gold) that was done at a place in Padukah KY, > Brown's Plating I think. They've been around forever. ________________________________________________________________________________
Date: Feb 26, 2010
And I'm sure you can find a good deal on aluminum patio chairs to strap to the wings. I hear the tourists love the view from wingtips. Big money in sightseeing. Clif > Mikee are you planning to fly that thing to Belize? I understand the laws > there will permit you to run an airline with such an aircraft as long as > there are no certified aircraft materials in it. I believe Corky can get > you a good price on ping-pong balls for flotation. > > Jack Phillips ________________________________________________________________________________
Date: Feb 27, 2010
http://www.spacecoast-plating.com/ ----- Original Message ----- From: "Dick N" <horzpool(at)goldengate.net> Sent: Friday, February 26, 2010 10:16 PM Subject: Re: Pietenpol-List: Dick's new Piet > > Thanks for the suggestions, Jack and Jim. I'll check them out. > Dick N. > ----- Original Message ----- > From: "Jack Phillips" <pietflyr(at)bellsouth.net> > To: > Sent: Friday, February 26, 2010 3:21 PM > Subject: RE: Pietenpol-List: Dick's new Piet > > >> >> >> I had the rocker box covers on my Pietenpol chrome plated by a place that >> had an exhibit at Sun'n' Fun several years ago: Spacecoast Plating. >> Maybe >> they'll be at SNF this year and you can talk with them then, Dick. They >> did >> a good job on my rocker box covers and they were pretty inexpensive, I >> thought. I paid $40 for all four. >> >> Jack Phillips >> NX899JP >> Raleigh, NC >> >> -----Original Message----- >> From: owner-pietenpol-list-server(at)matronics.com >> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim >> Markle >> Sent: Thursday, February 25, 2010 1:02 PM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: Dick's new Piet >> >> >> >> Chroming for your struts? Many years ago I had a Harley with a lot of >> custom plating (chrome and gold) that was done at a place in Padukah KY, >> Brown's Plating I think. They've been around forever. >> >> Might be worth checking on for a source of your plating...I think I >> actually >> saw the place mentioned somewhere not long ago so their probably still >> around.... >> >> >> -----Original Message----- >>>From: Dick N <horzpool(at)goldengate.net> >>>Sent: Feb 25, 2010 11:28 AM >>>To: pietenpol-list(at)matronics.com >>>Subject: Re: Pietenpol-List: Dick's new Piet >>> >>> >>>Hi Douwe >>>Check out Mike Cuys post with the Harley. I'm checking on where to have >> all >>>of the chroming done for the struts and all at this point. >>>Dick >>>----- Original Message ----- >>>From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> >>>To: "pietenpolgroup" >>>Sent: Thursday, February 25, 2010 8:54 AM >>>Subject: Pietenpol-List: Dick's new Piet >>> >>> >>>> >>>> >>>> So Dick, >>>> >>>> What engine are you using? is this an aircamper or a scout? I'm >>>> always >>>> interested in different engines. >>>> >>>> Douwe >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Feb 27, 2010
Subject: Piet-N-Pup
Warning! Raw video - no editing - this video is only for those who really can't get enough of Pietenpols, Pups, or sport aviation in general. No music, no Easter eggs. http://www.youtube.com/watch?v=VqAbnyA99Qs -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Feb 27, 2010
Subject: Re: Piet-N-Pup
I own both a GN-1 Aircamper and an N3Pup but the pup is not very good with the 1/2 VW in it at only 28hp so I'm switching the engine back to the 503 r otax at 52 hp with reduction drive.The only thing-I can get out of the pu p right now is a good fast taxi and on a good day just get airborn.Kinda sc ary actually.If I had one of those Scott Cassler 45hp on it that would make all the difference in the world but can't afford one at this time.I was ab lr to pick up a 503 at $1800 US but the 45hp 1/2 VW comes in at $6000-CND to- my door.I don't know what the guy in the video is using but it sound s stronger than mine.I am sitting at 210 lbs right now.If I was at the 145l bs I should be at then the 1/2VW I have now would probably be OK.I know,I k now,it would be cheaper to loose the weight than change the engine.Very har d to loose it at 63 years old.--=0A=0A=0A=0A=0A________________________ ________=0AFrom: Jeff Boatright <jboatri(at)emory.edu>=0ATo: pietenpol-list@ma tronics.com=0ASent: Sat, February 27, 2010 6:52:13 AM=0ASubject: Pietenpol- =0A=0AWarning! Raw video - no editing - this video is on ly for those who really can't get enough of Pietenpols, Pups, or sport avia tion in general. No music, no Easter eggs.- =0Ahttp://www.youtube.com/wat ch?v=VqAbnyA99Qs=0A=0A-- =0AJeff Boatright=0A"Now let's think about this. ================= ________________________________________________________________________________
Subject: engine run up
Date: Feb 27, 2010
Brought my wings to the airstrip but left the fuse in my workshop to do some engine runups at home, close by my tools. The engine has 14hrs in the test stand, but this was the first time running in the fuselage. With one inch of snow on the ground, and temps in the high twenties, it was a bit nippy, but she started right off and purred along beautifully. Am trying an Aerocarb, and have about three hours on it. So far I really like it. Seems like the sticky slide bugs and fuel leaking have been worked out, but we'll see. With this type of carb, one does have to be careful about switching off the fuel or it'll sit there and drip eventually. However, having two moving parts and no venturi or butterfly valve to ice up are big plusses in my book. But, we'll see... so far, so good. If it doesn't work out, I'll go back to the weber which has been bomb-proof. Hopefully will get the fuse to the airport now in a couple of weeks and put her together for the final time, do some ground runs, debugging and get Mr. Frank down here to do the honors as soon as the weather cooporates. Fun stuff! Douwe ________________________________________________________________________________
Subject: Re: engine run up
Date: Feb 27, 2010
Hi Douwe, Great news. If you want to send me some pics and I will make sure they get posted to this list. Hopefully I will be able to fly into Brodhead with you in July. Can't wait. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Sat, Feb 27, 2010 11:33 am Subject: Pietenpol-List: engine run up hlink.net> Brought my wings to the airstrip but left the fuse in my workshop to do so me ngine runups at home, close by my tools. The engine has 14hrs in the test tand, but this was the first time running in the fuselage. With one inch f snow on the ground, and temps in the high twenties, it was a bit nippy, ut she started right off and purred along beautifully. Am trying an erocarb, and have about three hours on it. So far I really like it. Seem s ike the sticky slide bugs and fuel leaking have been worked out, but we'll ee. With this type of carb, one does have to be careful about switching ff the fuel or it'll sit there and drip eventually. However, having two oving parts and no venturi or butterfly valve to ice up are big plusses in y book. But, we'll see... so far, so good. If it doesn't work out, I'll o back to the weber which has been bomb-proof. Hopefully will get the fuse to the airport now in a couple of weeks and pu t er together for the final time, do some ground runs, debugging and get Mr. rank down here to do the honors as soon as the weather cooporates. Fun stuff! Douwe -======================== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 27, 2010
For what it is worth some RAG Wing aircraft builders have used Excel glues with some success: http://www.excelglue.com/ under the fuselage chapter the results can be viewed http://homepages.paradise.net.nz/wilsonnz/ note http://homepages.paradise.net.nz/wilsonnz/Miscellaneous/notes1.jpg Michael in Maine ----- Original Message ----- From: Ray Krause The discussion on laminating struts has touched on glue/adhesives to be used, or that could be used. When building the aircraft, using the two part epoxy adhesives (T-88) is a little cumbersome. What about single stage poly urethane adhesives/glues, i.e. Gorilla Glue, Titebond? Has anyone used these, with what results? There are mixed reviews on this subject: Fine Woodworking (August '07) and woodgears.ca/joint_strength/glue.html . I am sure there are other reports both supportive and contradictive. I have tested Gorilla Glue with aircraft spruce and plywood, spruce long grain to long grain and butt to long grain and cross grain: with proper usage, the wood breaks before the glue bond. That is, wood grains come off with the break. Hope this does not cause any consternation! Ray Krause ________________________________________________________________________________
Date: Feb 27, 2010
This is VERY exciting... -----Original Message----- >From: Douwe Blumberg <douweblumberg(at)earthlink.net> >Sent: Feb 27, 2010 11:33 AM >To: pietenpolgroup >Subject: Pietenpol-List: engine run up > > >Brought my wings to the airstrip but left the fuse in my workshop to do some >engine runups at home, close by my tools. The engine has 14hrs in the test >stand, but this was the first time running in the fuselage. With one inch >of snow on the ground, and temps in the high twenties, it was a bit nippy, >but she started right off and purred along beautifully. Am trying an >Aerocarb, and have about three hours on it. So far I really like it. Seems >like the sticky slide bugs and fuel leaking have been worked out, but we'll >see. With this type of carb, one does have to be careful about switching >off the fuel or it'll sit there and drip eventually. However, having two >moving parts and no venturi or butterfly valve to ice up are big plusses in >my book. But, we'll see... so far, so good. If it doesn't work out, I'll >go back to the weber which has been bomb-proof. > >Hopefully will get the fuse to the airport now in a couple of weeks and put >her together for the final time, do some ground runs, debugging and get Mr. >Frank down here to do the honors as soon as the weather cooporates. > >Fun stuff! > >Douwe > > ________________________________________________________________________________
Date: Feb 27, 2010
Hi Gary, - That's beautiful! I can see you beefed up the tubes at the end, but, have y ou considered adding a tube between the two arms? like an "A", to help with the torsional loads.- I'm not flying yet, but I can see that most people with this setup and a steerable tail wheel had to do that. Dan H.- maybe you-should to consider doing the same thing, now that you have an steerable tail wheel. I would like to know the opinion of more experienced people. Saludos - Santiago=0A=0A=0A Yahoo! Cocina=0A=0AEncontra las mejores recetas con Yahoo! Cocina.=0A=0A=0Ahttp://ar.mujer.yahoo.com/cocina/ ________________________________________________________________________________
Date: Feb 27, 2010
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Hi Douwe, That's wonderful, congratulations! Saludos - Santiago=0A=0A=0A Yahoo! Cocina=0A=0AEncontra las mejores recetas con Yahoo! Cocina.=0A=0A=0Ahttp://ar.mujer.yahoo.com/cocina/ ________________________________________________________________________________
Subject: International Piet
Date: Feb 27, 2010
Just stumbled across this shot of a "Pietenpol Air Camper" from the Czech Republic. I think it more likely started life as a GN-1. http://www.airliners.net/photo/Pietenpol-Aircamper/1638829/L/ Funny how some "personal touches" can drastically change the look of this plane. Some of the "special features" this plane has include V-struts, a dorsal fin, squat landing gear, and a clunky cowl. Also, the cockpits look to be stretched. Put these features all together, and the result is YUCK. Well, that's just my opinion. There are probably some people out there that think this thing looks good. I think that planes like this one provide a good argument for the recommendation to "stick to the plans". BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288523#288523 ________________________________________________________________________________
Subject: Tailwheel & shimmy
Date: Feb 27, 2010
Thanks, Santiago! I have noticed that extra tube on some pictures, but don't really understand the geometry that would require it, unless it may take some load off the brackets, bolted to the fuselage. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of santiago morete Sent: Saturday, February 27, 2010 10:40 AM Subject: Pietenpol-List: Tailwheel & shimmy Hi Gary, That's beautiful! I can see you beefed up the tubes at the end, but, have you considered adding a tube between the two arms? like an "A", to help with the torsional loads. I'm not flying yet, but I can see that most people with this setup and a steerable tail wheel had to do that. Dan H. maybe you should to consider doing the same thing, now that you have an steerable tail wheel. I would like to know the opinion of more experienced people. Saludos Santiago _____ Encontra las mejores recetas con Yahoo! Cocina. http://ar.mujer.yahoo.com/cocina/ ________________________________________________________________________________
Date: Feb 28, 2010
Subject: Re: International Piet
From: Pastor Mike Townsley <allischalmersguy(at)gmail.com>
Bill, I am with you on that opinion. I know others may differ. Mike Townsley On Sun, Feb 28, 2010 at 3:26 AM, Bill Church wrote: > billspiet(at)sympatico.ca> > > Just stumbled across this shot of a "Pietenpol Air Camper" from the Czech > Republic. I think it more likely started life as a GN-1. > > http://www.airliners.net/photo/Pietenpol-Aircamper/1638829/L/ > > Funny how some "personal touches" can drastically change the look of this > plane. Some of the "special features" this plane has include V-struts, a > dorsal fin, squat landing gear, and a clunky cowl. Also, the cockpits look > to be stretched. Put these features all together, and the result is YUCK. > Well, that's just my opinion. There are probably some people out there that > think this thing looks good. I think that planes like this one provide a > good argument for the recommendation to "stick to the plans". > > BC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288523#288523 > > ________________________________________________________________________________
Subject: Re: Tailwheel & shimmy
Date: Feb 27, 2010
Hi Gary, I have wondered the same thing. Is that extra tube really necessary? The fuselage/bracket attach points are only a couple inches away, and it woul d seem to me that that tube would be redundant. Wish some engineering type s would chime in on this (Bill?, EH?) Santiago, what do you mean "torsion al"loads? Twisting? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sat, Feb 27, 2010 1:19 pm Subject: RE: Pietenpol-List: Tailwheel & shimmy Thanks, Santiago! I have noticed that extra tube on some pictures, but don =99t really understand the geometry that would require it, unless it may take some load off the brackets, bolted to the fuselage. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down) From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of santiago morete Sent: Saturday, February 27, 2010 10:40 AM Subject: Pietenpol-List: Tailwheel & shimmy Hi Gary, That's beautiful! I can see you beefed up the tubes at the end, but, have you considered adding a tube between the two arms? like an "A", to help with the torsional loads. I'm not flying yet, but I can see that most pe ople with this setup and a steerable tail wheel had to do that. Dan H. maybe you should to consider doing the same thing, now that you ha ve an steerable tail wheel. I would like to know the opinion of more experienced people. Saludos Santiago Encontra las mejores recetas con Yahoo! Cocina. http://ar.mujer.yahoo.com/cocina/ http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 27, 2010
Keep wishing, Dan! Oh, all right... I'll "chime in". I can see how one could think that such a cross member wouldn't be necessary, since the forward arms are connected to the fuselage - but those connections at the fuselage can't really resist twisting. And the tailwheel assembly will definitely be imparting twisting forces on the fuselage brackets. The geometry of a tailwheel is different from the skid, in that it's contact point with the ground is several inches away from the steel frame, whereas the skid is immediately below the frame. This arrangement provides what is called a moment arm (engineering term), and the result is that when the tail of the plane is subjected to side loads, the tailwheel will try to twist the steel frame. If the tubes are not tied together (other than back where the tailwheel is attached), the individual tubes will twist. By welding a crossmember between the two arms, the arms are no longer able to twist individually, and the twisting forces will be transferred directly to the fuselage rather than those tubes and the mounting brackets. Attached is a shot I found that shows the assembly that Ken Perkins makes, and the cross member can clearly be seen. This cross member won't eliminate the twisting of the steel frame, since it's basically only two dimensional, but it will definitely be better than not having the cross member. Hope this helps. Bill C. (engineering type) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288532#288532 Attachments: http://forums.matronics.com//files/kp_tailwheel_111.jpg ________________________________________________________________________________
Date: Feb 27, 2010
Having built my tailwheel first without the cross tube and finding that tailwheel steering inputs went mostly into twisting the tailwheel arm rather than turning the wheel, I rebuilt it and added the cross tube making the ailwheel arm into an "A" shape. That works well. Here is the original one: And here is the improved version: Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Saturday, February 27, 2010 3:01 PM Subject: Re: Pietenpol-List: Tailwheel & shimmy Hi Gary, I have wondered the same thing. Is that extra tube really necessary? The fuselage/bracket attach points are only a couple inches away, and it would seem to me that that tube would be redundant. Wish some engineering types would chime in on this (Bill?, EH?) Santiago, what do you mean "torsional"loads? Twisting? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sat, Feb 27, 2010 1:19 pm Subject: RE: Pietenpol-List: Tailwheel & shimmy Thanks, Santiago! I have noticed that extra tube on some pictures, but don't really understand the geometry that would require it, unless it may take some load off the brackets, bolted to the fuselage. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) _____ From: <mailto:owner-pietenpol-list-server(at)matronics.com> owner-pietenpol-list-server(at)matronics.com [ mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of santiago morete Sent: Saturday, February 27, 2010 10:40 AM Subject: Pietenpol-List: Tailwheel & shimmy Hi Gary, That's beautiful! I can see you beefed up the tubes at the end, but, have you considered adding a tube between the two arms? like an "A", to help with the torsional loads. I'm not flying yet, but I can see that most people with this setup and a steerable tail wheel had to do that. Dan H. maybe you should to consider doing the same thing, now that you have an steerable tail wheel. I would like to know the opinion of more experienced people. Saludos Santiago _____ Encontra las mejores recetas con Yahoo! Cocina. <http://ar.mujer.yahoo.com/cocina/> http://ar.mujer.yahoo.com/cocina/ <http://www.matronics.com/Navigator?Pietenpol-List> http://www.matronics.com/Navigator?Pietenpol-List <http://forums.matronics.com/> http://forums.matronics.com <http://www.matronics.com/contribution> http://www.matronics.com/contribution =================================== t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List =================================== tp://forums.matronics.com =================================== _blank>http://www.matronics.com/contribution =================================== http://www.matronics.com/Navigator?Pietenpol-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 27, 2010
Oh ALLRIGHT! Now I have to add more weight way back there! UGH! Who asked you to chime in anyway? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Bill Church <billspiet(at)sympatico.ca> Sent: Sat, Feb 27, 2010 3:19 pm Subject: Pietenpol-List: Re: Tailwheel & shimmy a> Keep wishing, Dan! Oh, all right... I'll "chime in". I can see how one could think that such a cross member wouldn't be necessa ry, ince the forward arms are connected to the fuselage - but those connection s at he fuselage can't really resist twisting. And the tailwheel assembly will efinitely be imparting twisting forces on the fuselage brackets. The geome try f a tailwheel is different from the skid, in that it's contact point with the round is several inches away from the steel frame, whereas the skid is mmediately below the frame. This arrangement provides what is called a mom ent rm (engineering term), and the result is that when the tail of the plane is ubjected to side loads, the tailwheel will try to twist the steel frame. If the ubes are not tied together (other than back where the tailwheel is attache d), he individual tubes will twist. By welding a crossmember between the two arms, he arms are no longer able to twist individually, and the twisting forces will e transferred directly to the fuselage rather tha! n those tubes and the mounting brackets. Attached is a shot I found that shows he assembly that Ken Perkins makes, and the cross member can clearly be se en. his cross member won't eliminate the twisting of the steel frame, since it 's asically only two dimensional, but it will definitely be better than not having he cross member. Hope this helps. Bill C. (engineering type) ead this topic online here: http://forums.matronics.com/viewtopic.php?p=288532#288532 ttachments: http://forums.matronics.com//files/kp_tailwheel_111.jpg -======================== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Feb 27, 2010
I will ask the builder what his all-up weight is for him and plane. BTW, he's not getting the static rpm that he should be getting. >I own both a GN-1 Aircamper and an N3Pup but the pup is not very >good with the 1/2 VW in it at only 28hp so I'm switching the engine >back to the 503 rotax at 52 hp with reduction drive.The only thing I >can get out of the pup right now is a good fast taxi and on a good >day just get airborn.Kinda scary actually.If I had one of those >Scott Cassler 45hp on it that would make all the difference in the >world but can't afford one at this time.I was ablr to pick up a 503 >at $1800 US but the 45hp 1/2 VW comes in at $6000 CND to my door.I >don't know what the guy in the video is using but it sounds stronger >than mine.I am sitting at 210 lbs right now.If I was at the 145lbs I >should be at then the 1/2VW I have now would probably be OK.I know,I >know,it would be cheaper to loose the weight than change the >engine.Very hard to loose it at 63 years old. > > >From: Jeff Boatright <jboatri(at)emory.edu> >To: pietenpol-list(at)matronics.com >Sent: Sat, February 27, 2010 6:52:13 AM >Subject: Pietenpol-List: Piet-N-Pup > >-=========================== -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Feb 27, 2010
Here are a couple Clif. 1) A self-portrait with a rental 150 that I took while on my long student pilot solo cross-country. 2) Panorama (from 7 individual photos) taken during EAA Chapter's Poker Run. My rental 150 is on the left of the 13 aircraft parked outside the blimp hangar. Clif Dawson wrote: > This thing is incredible! I have a photo somewhere of my Cherokee in > front of the > doors. The cherokee is just a tiny blip at the bottom of the photo! > > Clif > > *Subject:* RE: Pietenpol-List: anybody near Portland? > > There is also a great air museum in Tillamook Oregon. That is just > over to the coast from Portland. It is in an old WW2 blip hanger. > I nice museum not too far from Portland. > > vic groah NX414MV > > > * > > > * ________________________________________________________________________________
Date: Feb 27, 2010
Douwe. A few teaspoons of Marvel, or as I do, try 2 cycle synthetic in the fuel for the first 5 hours, I use it all the time Go Snow, some where to help the warming problem! Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288548#288548 ________________________________________________________________________________
Date: Feb 27, 2010
Yes Dan, twisting, sorry if I'm not using the right words.- I guess you a re thinking, at this point,-that a tailskid would be nice, simple, light and you already have one! :-) Saludos - Santiago=0A=0A=0A Yahoo! Cocina=0A=0AEncontra las mejores recetas con Yahoo! Cocina.=0A=0A=0Ahttp://ar.mujer.yahoo.com/cocina/ ________________________________________________________________________________
Date: Feb 27, 2010
Hey! It's still lighter than a leafspring arrangement. I originally used a Scott Tailwheel with a leafspring and then went with an Aircraft Spruce "Homebuilder's Special" tailwheel with the A arm and save nearly 4 pounds. Leaf springs are HEAVY. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Saturday, February 27, 2010 5:27 PM Subject: Re: Pietenpol-List: Re: Tailwheel & shimmy Oh ALLRIGHT! Now I have to add more weight way back there! UGH! Who asked you to chime in anyway? Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Re: Sky Scout..."Glue"question?
Date: Feb 27, 2010
There were two glue articles. Here is the first one. Greg Cardinal ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Friday, February 26, 2010 9:41 AM Subject: Pietenpol-List: Sky Scout..."Glue"question? > > > If anyone is a member or subscriber to "Fine Woodworking", > they ran a glue comparison in August of 2007 on six > of the common wood glues, here: > > http://www.finewoodworking.com/Materials/MaterialsPDF.aspx?id=28897 > > I'm not a member so I can't access the article but I > think I remember the results and Gorilla Glue didn't > place too well in the tests. My own experience with > it has NOT been on airplane stuff but what I've found > is that even with the air squeezed out of the container > and the container tightly capped, the stuff will set > up on the shelf and be useless so there's no point in > buying more than you can readily use. It also foams > out of the joint considerably, if you care about that. > > It's T88 for me... > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
Date: Feb 27, 2010
And the second one.... Greg ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Friday, February 26, 2010 9:41 AM Subject: Pietenpol-List: Sky Scout..."Glue"question? > > > If anyone is a member or subscriber to "Fine Woodworking", > they ran a glue comparison in August of 2007 on six > of the common wood glues, here: > > http://www.finewoodworking.com/Materials/MaterialsPDF.aspx?id=28897 > > I'm not a member so I can't access the article but I > think I remember the results and Gorilla Glue didn't > place too well in the tests. My own experience with > it has NOT been on airplane stuff but what I've found > is that even with the air squeezed out of the container > and the container tightly capped, the stuff will set > up on the shelf and be useless so there's no point in > buying more than you can readily use. It also foams > out of the joint considerably, if you care about that. > > It's T88 for me... > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > > ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: anybody near Portland?
Date: Feb 27, 2010
Thanks Ken, My mother did not have any pictures of Tillamook, so now I have some idea of what it was like when she was there in 1944-45. Kip Gardner On Feb 27, 2010, at 6:26 PM, Ken Howe wrote: > Here are a couple Clif. > > 1) A self-portrait with a rental 150 that I took while on my long > student pilot solo cross-country. > > 2) Panorama (from 7 individual photos) taken during EAA Chapter's > Poker > Run. My rental 150 is on the left of the 13 aircraft parked outside > the > blimp hangar. > > Clif Dawson wrote: >> This thing is incredible! I have a photo somewhere of my Cherokee >> in front of the >> doors. The cherokee is just a tiny blip at the bottom of the photo! >> Clif >> *Subject:* RE: Pietenpol-List: anybody near Portland? >> There is also a great air museum in Tillamook Oregon. That is >> just >> over to the coast from Portland. It is in an old WW2 blip >> hanger. I nice museum not too far from Portland. vic >> groah NX414MV * >> * > > ________________________________________________________________________________
From: "wayne & Cathy Boniface" <catway(at)sympatico.ca>
Date: Feb 27, 2010
Hey guys: on your "A" frame tail wheel assembly what do you use for a spring. is this something that acs carries or something you had to find somewhere else I'm thinking the coil spring from the front end of a motorcycle, or is that to stiff, this is getting to me so any ideas would be appreciated. wayne waterloo on. ________________________________________________________________________________
Date: Feb 27, 2010
John Deere. I can dig up the part # tomorrow. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of wayne & Cathy Boniface Sent: Saturday, February 27, 2010 6:48 PM Subject: Re: Pietenpol-List: Re: Tailwheel & shimmy Hey guys: on your "A" frame tail wheel assembly what do you use for a spring. is this something that acs carries or something you had to find somewhere else I'm thinking the coil spring from the front end of a motorcycle, or is that to stiff, this is getting to me so any ideas would be appreciated. wayne waterloo on. ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Feb 27, 2010
Here is a repeat of a post from 1997..... "John Deere sells a spring that's a perfect match for the specs; its part number is T 143444, and it costs about $9.00. Its outer dia. is 1.5 in.; full length ( no load ) is 6.73" ; the coil itself is .191" thick. I've tested its compresed load, and it almost gets totally compressed under my weight (c. 210 lbs.). I don't know what the spring is used for in a John Deere, but Ken Perkins tells me that the spring for a 1929 JD rake is a perfect match. Maybe "that's what it's for." This is the spring I used and I think it cost me $19 a couple of years ago Rick Schreiber Valparaiso, IN ----- Original Message ----- From: wayne & Cathy Boniface Sent: 2/27/2010 8:51:21 PM Subject: Re: Pietenpol-List: Re: Tailwheel & shimmy Hey guys: on your "A" frame tail wheel assembly what do you use for a spring. is this something that acs carries or something you had to find somewhere else I'm thinking the coil spring from the front end of a motorcycle, or is that to stiff, this is getting to me so any ideas would be appreciated. wayne waterloo on. ________________________________________________________________________________
Date: Feb 28, 2010
I just bought one a few months ago. I think the part number is still good, and it cost about 19.00 Gene ----- Original Message ----- From: Richard Schreiber<mailto:lmforge(at)earthlink.net> To: pietenpol-list(at)matronics.com Sent: Saturday, February 27, 2010 11:04 PM Subject: Re: Pietenpol-List: Re: Tailwheel & shimmy Here is a repeat of a post from 1997..... "John Deere sells a spring that's a perfect match for the specs; its part number is T 143444, and it costs about $9.00. Its outer dia. is 1.5 in.; full length ( no load ) is 6.73" ; the coil itself is .191" thick. I've tested its compresed load, and it almost gets totally compressed under my weight (c. 210 lbs.). I don't know what the spring is used for in a John Deere, but Ken Perkins tells me that the spring for a 1929 JD rake is a perfect match. Maybe "that's what it's for." This is the spring I used and I think it cost me $19 a couple of years agoRick SchreiberValparaiso, IN ----- Original Message ----- From: wayne & Cathy Boniface<mailto:catway(at)sympatico.ca> To: pietenpol-list(at)matronics.com Sent: 2/27/2010 8:51:21 PM Subject: Re: Pietenpol-List: Re: Tailwheel & shimmy Hey guys: on your "A" frame tail wheel assembly what do you use for a spring. is this something that acs carries or something you had to find somewhere else I'm thinking the coil spring from the front end of a motorcycle, or is that to stiff, this is getting to me so any ideas would be appreciated. wayne waterloo on. http://www.matronics.com/Navigator?Pietenpol-List m/Navigator?Pietenpol-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Feb 28, 2010
I got mine from McMaster-Carr. I don't remember the part number but you can look at their springs online and figure it out. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of wayne & Cathy Boniface Sent: Saturday, February 27, 2010 9:48 PM Subject: Re: Pietenpol-List: Re: Tailwheel & shimmy Hey guys: on your "A" frame tail wheel assembly what do you use for a spring. is this something that acs carries or something you had to find somewhere else I'm thinking the coil spring from the front end of a motorcycle, or is that to stiff, this is getting to me so any ideas would be appreciated. wayne waterloo on. ________________________________________________________________________________
Subject: tailwheel arm
Date: Feb 28, 2010
Dan, I did the same thing, converting from a skid to a tailwheel and learned a lesson I want to share. My tailwheel arms had pins that stuck into the fuse brackets, but when I put the cross member in, I could no long spread the arm to get the pins in. I had to take off the fuse fittings, mount the arm and then reassemble onto the fuse. If you used the original design, you might want to watch out for this one. Good luck! D ps. I'll just send pics once it's all together at the field becuase now it just looks like a fuselage again!! pss. Applying dimple tape in the next couple of days to do another runup and see what it does to my static rpm, will report back ________________________________________________________________________________
Date: Feb 28, 2010
thanks guy's, I'm off to our John Deer dealer, wayne waterloo on. ________________________________________________________________________________
Date: Feb 28, 2010
Wayne I went to a used tractor parts dealed. Told him what I was looking for and he sent me back to a building out back where I went thru a pile of springs looking for the right ones. I think they came to about $2.00 ea. Dick N. ----- Original Message ----- From: wayne & Cathy Boniface To: pietenpol-list(at)matronics.com Sent: Saturday, February 27, 2010 8:47 PM Subject: Re: Pietenpol-List: Re: Tailwheel & shimmy Hey guys: on your "A" frame tail wheel assembly what do you use for a spring. is this something that acs carries or something you had to find somewhere else I'm thinking the coil spring from the front end of a motorcycle, or is that to stiff, this is getting to me so any ideas would be appreciated. wayne waterloo on. ________________________________________________________________________________
Date: Feb 28, 2010
Or use bolts to attach it to the fuselage, rather than pins. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Sunday, February 28, 2010 8:43 AM Subject: Pietenpol-List: tailwheel arm Dan, I did the same thing, converting from a skid to a tailwheel and learned a lesson I want to share. My tailwheel arms had pins that stuck into the fuse brackets, but when I put the cross member in, I could no long spread the arm to get the pins in. I had to take off the fuse fittings, mount the arm and then reassemble onto the fuse. If you used the original design, you might want to watch out for this one. Good luck! D ps. I'll just send pics once it's all together at the field becuase now it just looks like a fuselage again!! pss. Applying dimple tape in the next couple of days to do another runup and see what it does to my static rpm, will report back ________________________________________________________________________________
Subject: Wood Cabanes
Date: Feb 28, 2010
A few days back, the subject of wood cabanes came up again. I remembered that Clif Dawson had sent me some facts and figures to back up, Why it's OK to use Wood for Cabanes: "Spruce has a tensile strength of 6700 lb/square inch. For the sake of argument let's say a strut is 1" X 3 1/2". With streamlining, the area should be 2/3 of the square area, or 2.3 square inch. There are four struts or 5.2 square inches. That's 34840 lbs (yes I know the front ones take the majority of the load) .Dividing on the assumption of equal load on a 1200 lb AC we get 29 g! How much less if properly calculated? 25 g? 20 g? Is this adequate? There's a bolt at each end. The strength here is based on how much force required to pull a plug of wood out by the bolt. That plug has two faces, the square area of which is the width of the strut times the distance from the end to the bolt. If the strut is 1" thick and the bolt is 1" from the end then you have two faces each 1" square or two square inches. The "shear parallel to the grain" is 1120 lb per square inch. So we have a strength here of 2240 lb. Four struts so that's a total of 8960 lb. That's still over 7 g. If we added another such bolt we have 14 g capacity. Taking into account the higher front strut stress I'd bet we still have at least 10 g to play with. And this is for plain, solid spruce, no plywood, no laminated straps or embedded tubing or anything else to complicate matters. You can add a little more strength by using Western Hemlock or Doug Fir but not much. " Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) ________________________________________________________________________________
Subject: dimpletape on a Ford
Date: Feb 28, 2010
I applied the dimpletape to my Ford prop and ran it in pretty much the same conditions as yesterday and my best guess is that it gained 20 to 25rpm static. While I was hoping for a bit more, this is certainly better than nothing. It was interesting because though the tach showed differently, I'd swear the engine was stronger, and it was a bit quieter and easier sounding. I'm gonna leave it on, as it is almost invisible. Douwe ________________________________________________________________________________
Date: Feb 28, 2010
Subject: Re: Aluminum struts
Bryan Sorry for the late reply. Din not get out to the hanger until today. The strut material measures 3 1/4 by 1 1/4. I used 4130 for the cabanes as it was given to me.Hope this is of some use. Jim Ballew Collinsville, OK In a message dated 2/24/2010 10:20:28 A.M. Central Standard Time, lgreen1(at)sc.rr.com writes: What size did you use for the cabanes and struts Jim? Bryan Green Elgin SC ----- Original Message ----- From: _Pietn38b(at)aol.com_ (mailto:Pietn38b(at)aol.com) Sent: Wednesday, February 24, 2010 10:28 AM Subject: Re: Pietenpol-List: Aluminum struts All These are done the same way I did mine in 1995. I have taken mine apart a couple of times to check for corrosion, all looks good. I got my strut material from a kit manufacturer in Kansas. Rans Aircraft I think. At the time the cost was about 1/4th the cost of making them from 4130. Jim Ballew Pietenpol N38B Collinsville, Ok. In a message dated 2/24/2010 8:00:01 A.M. Central Standard Time, helspersew(at)aol.com writes: Hi All, I used the alum struts like Larry Williams. The aluminum insert is 7075 aluminum that I got from Mcmastercarr.com. The bottom fitting (not shown) is the 7075 insert, that I tapped for J-3 forked wing strut fitting (ACS or Wag Aero?). Inserts are bolted through the strut with 1/4" bolts. Dan Helsper Poplar Grove, IL. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c (
http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Feb 28, 2010
Subject: Re: dimpletape on a Ford
Dowe, Just wondering how much the dimple tape costs. I was also wondering how it was to work with, as far as attatching it to the prop. I was debating on when to apply it, before or after varnish? I have a spare prop that I am planning on putting the dimple tape on for the corvair. Shad ________________________________________________________________________________
Date: Feb 28, 2010
Date: Feb 28, 2010
Thanks Jim that's a big help. My rear struts and cabanes are damaged, but the front struts are ok. I think I'll use the rear struts to fabricate new cabanes and make aluminum rear struts. Bryan Green Elgin SC ----- Original Message ----- From: Pietn38b(at)aol.com To: pietenpol-list(at)matronics.com Sent: Sunday, February 28, 2010 6:09 PM Subject: Re: Pietenpol-List: Aluminum struts Bryan Sorry for the late reply. Din not get out to the hanger until today. The strut material measures 3 1/4 by 1 1/4. I used 4130 for the cabanes as it was given to me.Hope this is of some use. Jim Ballew Collinsville, OK In a message dated 2/24/2010 10:20:28 A.M. Central Standard Time, lgreen1(at)sc.rr.com writes: What size did you use for the cabanes and struts Jim? Bryan Green Elgin SC ----- Original Message ----- From: Pietn38b(at)aol.com To: pietenpol-list(at)matronics.com Sent: Wednesday, February 24, 2010 10:28 AM Subject: Re: Pietenpol-List: Aluminum struts All These are done the same way I did mine in 1995. I have taken mine apart a couple of times to check for corrosion, all looks good. I got my strut material from a kit manufacturer in Kansas. Rans Aircraft I think. At the time the cost was about 1/4th the cost of making them from 4130. Jim Ballew Pietenpol N38B Collinsville, Ok. In a message dated 2/24/2010 8:00:01 A.M. Central Standard Time, helspersew(at)aol.com writes: Hi All, I used the alum struts like Larry Williams. The aluminum insert is 7075 aluminum that I got from Mcmastercarr.com. The bottom fitting (not shown) is the 7075 insert, that I tapped for J-3 forked wing strut fitting (ACS or Wag Aero?). Inserts are bolted through the strut with 1/4" bolts. Dan Helsper Poplar Grove, IL. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c t href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List ms.matronics.com/">http://forums.matronics.com tp://www.matronics.com/contribution">http://www.matronics.com/contributio n ________________________________________________________________________________
Date: Feb 28, 2010
Douwe, Where did you get the dimple tape? Thanks, Jeff > > >I applied the dimpletape to my Ford prop and ran it in pretty much the same >conditions as yesterday and my best guess is that it gained 20 to 25rpm >static. While I was hoping for a bit more, this is certainly better than >nothing. > >It was interesting because though the tach showed differently, I'd swear the >engine was stronger, and it was a bit quieter and easier sounding. > >I'm gonna leave it on, as it is almost invisible. > >Douwe > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Feb 28, 2010
Jeff, You can get it straight from the person that invented it: http://www.dimpletape.com/ Make sure to check out the usage examples....you can tape your prop, your wings, and you can give the leftover to your beret-wearing speed skater friends, or you can apply it to the wing on your 1981 Ford LTD. :P Ryan On Sun, Feb 28, 2010 at 7:38 PM, Jeff Boatright wrote: > > Douwe, > > Where did you get the dimple tape? > > Thanks, > > Jeff > > >> douweblumberg(at)earthlink.net> >> >> I applied the dimpletape to my Ford prop and ran it in pretty much the >> same >> conditions as yesterday and my best guess is that it gained 20 to 25rpm >> static. While I was hoping for a bit more, this is certainly better than >> nothing. >> >> It was interesting because though the tach showed differently, I'd swear >> the >> engine was stronger, and it was a bit quieter and easier sounding. >> >> I'm gonna leave it on, as it is almost invisible. >> >> Douwe >> >> > > -- > > Jeff Boatright > "Now let's think about this..." > > ________________________________________________________________________________
Date: Feb 28, 2010
Ryan, Thanks for the link. If I wrap my head with it, will I think faster? I guess like MMO, it couldn't hurt! =-O Jeff >Jeff, > >You can get it straight from the person that invented it: > ><http://www.dimpletape.com/>http://www.dimpletape.com/ > >Make sure to check out the usage examples....you can tape your prop, >your wings, and you can give the leftover to your beret-wearing >speed skater friends, or you can apply it to the wing on your 1981 >Ford LTD. :P > >Ryan -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Feb 28, 2010
Thanks! Ray Krause ----- Original Message ----- From: "gcardinal" <gcardinal(at)comcast.net> Sent: Saturday, February 27, 2010 4:02 PM Subject: Re: Pietenpol-List: Sky Scout..."Glue"question? > And the second one.... > > Greg > > ----- Original Message ----- > From: "Oscar Zuniga" <taildrags(at)hotmail.com> > To: "Pietenpol List" > Sent: Friday, February 26, 2010 9:41 AM > Subject: Pietenpol-List: Sky Scout..."Glue"question? > > >> >> >> >> If anyone is a member or subscriber to "Fine Woodworking", >> they ran a glue comparison in August of 2007 on six >> of the common wood glues, here: >> >> http://www.finewoodworking.com/Materials/MaterialsPDF.aspx?id=28897 >> >> I'm not a member so I can't access the article but I >> think I remember the results and Gorilla Glue didn't >> place too well in the tests. My own experience with >> it has NOT been on airplane stuff but what I've found >> is that even with the air squeezed out of the container >> and the container tightly capped, the stuff will set >> up on the shelf and be useless so there's no point in >> buying more than you can readily use. It also foams >> out of the joint considerably, if you care about that. >> >> It's T88 for me... >> >> Oscar Zuniga >> Air Camper NX41CC >> San Antonio, TX >> mailto: taildrags(at)hotmail.com >> website at http://www.flysquirrel.net >> >> >> >> > ________________________________________________________________________________
Date: Feb 28, 2010
Subject: Markle Mania 2010 final results
Good evening everyone, We are emailing this evening to distribute the final update regarding Markle Mania 2010, the effort to help Jim Markle keep his Pietenpol project. We have received 73 generous donations out of 78 that were pledged, for a grand total of $*6490.50*. No further donations have arrived in the past few weeks, so I think it is safe to say that we can draw this to a close. As I noted above, we received 78 pledged donations that were emailed to marklepietenpolfund(at)gmail.com. Over the past month we have received 73 of those pledged donations via checks in the mail, Paypal payments, and even a Western Union transfer (first time I had ever used them!). Money came in from generous contributors all across the US, Canada, Mexico, Argentina, and Australia (I'm pretty sure that's everyone, if I missed your country I apologize). This was truly a global effort to help a most valued member of the Pietenpol community keep his dream alive. We spoke with Jim last month after we started collecting contributions, and asked about how he wanted to do the payout. We agreed to send one large payment at that time for whatever we had collected, and then we would forward the remainder to him later on. We made one transfer on Feb 8 for $5,985.50, and the final transfer on Feb 24 for $455. Here are links to two screen captures from the online banking page of the Bank of America account we used for collecting the funds, showing the transfers made to Jim: Transfer 1 <http://dl.dropbox.com/u/2314248/markle1.jpg>: http://dl.dropbox.com/u/2314248/markle1.jpg Transfer 2 <http://dl.dropbox.com/u/2314248/markle2.jpg>: http://dl.dropbox.com/u/2314248/markle2.jpg In addition to the funds sent to us, Jim did receive one check in the mail for $50. Add that to the $6440.50 that we transferred to him and we arrive at the grand total of $6,490.50. Commemorative "stock certificates" are in the works. We're not sure whether we will try to print and mail those out; we may do a digital certificate in PDF format, and then those that wish to have hard copies may print them out themselves. We may also try to have some sort of informal get-together at Brodhead 2010, possibly a "certificate burning", we're not sure yet. We may even have a t-shirt design made up that could be purchased from CafePress. We will work with other members of the Pietenpol community on this, and will update everyone later this year when we figure out the details. We want to thank everyone who participated in Markle Mania 2010. This is an unbelievable community of airplane builders and aviation enthusiasts that we are so fortunate to be a part of; thank you for doing your part to help Jim keep the dream of building and flying his Pietenpol alive. As I'm sure you do, we look forward to the day when Jim's Piet rolls off the grass and into the sky, hopefully winging it's way to Brodhead. Thank you again, and have a good evening! Ryan Mueller & Jessica Ozbirn ________________________________________________________________________________
Date: Feb 28, 2010
Thanks, again! Ray Krause ----- Original Message ----- From: "gcardinal" <gcardinal(at)comcast.net> Sent: Saturday, February 27, 2010 4:02 PM Subject: Re: Pietenpol-List: Sky Scout..."Glue"question? > There were two glue articles. > Here is the first one. > > Greg Cardinal > > ----- Original Message ----- > From: "Oscar Zuniga" <taildrags(at)hotmail.com> > To: "Pietenpol List" > Sent: Friday, February 26, 2010 9:41 AM > Subject: Pietenpol-List: Sky Scout..."Glue"question? > > >> >> >> >> If anyone is a member or subscriber to "Fine Woodworking", >> they ran a glue comparison in August of 2007 on six >> of the common wood glues, here: >> >> http://www.finewoodworking.com/Materials/MaterialsPDF.aspx?id=28897 >> >> I'm not a member so I can't access the article but I >> think I remember the results and Gorilla Glue didn't >> place too well in the tests. My own experience with >> it has NOT been on airplane stuff but what I've found >> is that even with the air squeezed out of the container >> and the container tightly capped, the stuff will set >> up on the shelf and be useless so there's no point in >> buying more than you can readily use. It also foams >> out of the joint considerably, if you care about that. >> >> It's T88 for me... >> >> Oscar Zuniga >> Air Camper NX41CC >> San Antonio, TX >> mailto: taildrags(at)hotmail.com >> website at http://www.flysquirrel.net >> >> >> >> > ________________________________________________________________________________
Subject: dimpletape
Date: Mar 01, 2010
First off, THANK YOU! Ryan for doing the scutwork of "Markle Mania" ensuring that a great idea was turned into action. Shad, the dimpletape was easy to work with, just follow the directions. His price is on the order form from his website. You have to order it the old fashioned way and send him a ck. I made sure both the tape and the prop were warm since it's freezing here, stuck it on, rubbed it down with the backside of a spoon and started her up. For a permanent installation, he recommends flowing some crazy glue around the edges, and you can spray a thin coat of urathane over it if you please. I'm going to just use the crazy glue. I'd varnish your prop first and if you want to varnish over the tape, install the tape before the final coat. I don't think you should fill the holes in the tape with too much varnish. I spoke with the guy, and he says you can do the same thing on a wood prop by using the tape as a pattern and dimple the prop surface using a 1/8th inch ball grinder in a dremel and doing halfway in. There's a picture of this on the site. Douwe ________________________________________________________________________________
Subject: Pietenpol logo
Date: Mar 01, 2010
Does anybody have a good quality Pietenpol logo in jpeg or something similar? I want to have some old-fashioned white mechanics coveralls silscreened with a cool logo on the back. I found a neat old mobilgas logo, but then got to thinking about the classic Pietenpol signature. Douwe ________________________________________________________________________________
Date: Mar 01, 2010
Douwe, This is all I have, not sure who to credit with the design Jack DSM Does anybody have a good quality Pietenpol logo in jpeg or something similar? I want to have some old-fashioned white mechanics coveralls silscreened with a cool logo on the back. I found a neat old mobilgas logo, but then got to thinking about the classic Pietenpol signature. Douwe ________________________________________________________________________________
Subject: Re: Pietenpol logo
Date: Mar 01, 2010
There's always this one... -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288731#288731 Attachments: http://forums.matronics.com//files/bhplogo_752.jpg ________________________________________________________________________________
Date: Mar 01, 2010
Are there any other Listers out there using Dimpletape, and, if so, how much performance increase is realized? Cheers, Gardiner Mason ________________________________ From: Jeff Boatright <jboatri(at)emory.edu> Sent: Sun, February 28, 2010 10:15:48 PM Subject: Re: Pietenpol-List: dimpletape on a Ford Re: Pietenpol-List: dimpletape on a Ford Ryan, Thanks for the link. If I wrap my head with it, will I think faster? I guess like MMO, it couldn't hurt! =-O Jeff Jeff, > >>You can get it straight from the person that invented it: > http://www.dimpletape.com/ > >>Make sure to check out the usage examples....you can tape your prop, >your wings, and you can give the leftover to your beret-wearing speed >skater friends, or you can apply it to the wing on your 1981 Ford >LTD. :P > Ryan -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 01, 2010
Subject: Riblett 612 and angle of incidence
Pieti, I watched the videos Jeff B. put on Youtube of your talk at Brodhead last year. You mentioned that you kept your AoI of 2 degrees from the FC-10 and that you'd probably like to see it at 1 degree or less because at flat out cruise you've got to apply a significant (30-40lbs) amount of forward pressure on the stick. The question I have is this: did you build the angle of incidence into the spar orientation in the ribs or did you keep the spars at a 90 degree angle to the wing chord? Also, looking at the Riblett 612, I see that if you keep the front spar the same distance from the leading edge as the FC1-1, 6 inches, that dictates that the front spar and the rear spar will not be aligned, vertically - the front spar must be shifted down an inch or so to fit in the rib with respect to the aft spar. How did you address this? Did you even worry about it? Thanks, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: Riblett 612 and angle of incidence
Date: Mar 01, 2010
Dan, Sure sounds like somebody is going full speed ahead on building another Pi et. :O) Dan Helsper Poplar Grove, IL. -----Original Message----- From: Dan Yocum <yocum(at)fnal.gov> Sent: Mon, Mar 1, 2010 9:18 am Subject: Pietenpol-List: Riblett 612 and angle of incidence Pieti, I watched the videos Jeff B. put on Youtube of your talk at Brodhead last year. You mentioned that you kept your AoI of 2 degrees from the FC-10 an d that you'd probably like to see it at 1 degree or less because at flat out cruise you've got to apply a significant (30-40lbs) amount of forward pressure on the stick. The question I have is this: did you build the angle of incidence into the spar orientation in the ribs or did you keep the spars at a 90 degree ang le to the wing chord? Also, looking at the Riblett 612, I see that if you keep the front spar th e same distance from the leading edge as the FC1-1, 6 inches, that dictate s that the front spar and the rear spar will not be aligned, vertically - the front spar must be shifted down an inch or so to fit in the rib with respect to the aft spar. How did you address this? Did you even worry abo ut it? Thanks, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ======================== ============ ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
Date: Mar 01, 2010
Subject: John Hofmann's tribute video (Markle)
For those whom may have missed it, John's video is awesome! Very, well done and very funny! I have watched it a handfull of times now and think it is great. The link is below.- I am honored to be mentioned in the video as w ere many of the viewers of this list. - FYI, the Pin the Tail on Perez GAME will be for sale on my site if I ever f igure out how to make it. (This is NOT an invite for suggestions either) - http://gallery.me.com/johnnyskyrocket#100017 - - - ________________________________________________________________________________
Date: Mar 01, 2010
Wow Douwe! Over the past week or so I was thinking exactly the same thing. The logo would need to look 'period correct'. I'll look around in some of my '30s aviation books and magazines to try to see some from those times. I know they were quite popular back then. Maybe the price would come down if we could get a few of them made up. Do you know where you can get a set of nice cotton white coveralls? Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288772#288772 ________________________________________________________________________________
Date: Mar 01, 2010
Gardiner, Bill Rewey wrote an article in one of the last 3 BPA newsletters on his use of the dimpletape. He says he gets about 10% decrease in fuel consumption using it on his prop. If anyone's willing to put the stuff on their wing, I'd be interested in seeing what results they get. I reckon it would act quite a bit like VGs. Dan On 03/01/2010 08:35 AM, airlion wrote: > Are there any other Listers out there using Dimpletape, and, if so, how > much performance increase is realized? Cheers, Gardiner Mason > > ------------------------------------------------------------------------ > *From:* Jeff Boatright > *To:* pietenpol-list(at)matronics.com > *Sent:* Sun, February 28, 2010 10:15:48 PM > *Subject:* Re: Pietenpol-List: dimpletape on a Ford > > Ryan, > > Thanks for the link. If I wrap my head with it, will I think faster? I > guess like MMO, it couldn't hurt! =-O > > Jeff > > >> Jeff, >> >> You can get it straight from the person that invented it: >> http://www.dimpletape.com/ >> >> Make sure to check out the usage examples....you can tape your prop, >> your wings, and you can give the leftover to your beret-wearing speed >> skater friends, or you can apply it to the wing on your 1981 Ford LTD. :P >> Ryan > > > -- > > > Jeff Boatright > "Now let's think about this..." > > * > > > * > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 01, 2010
I am VERY SLOWLY working on logos for our planes as well as homebuilts and experimentals. (this doesn't do you guys any good right now.) I have a couple prototypes in work, but they are full color and have a more modern "feel." (this does not help you guys either.) I made up some iron on transfers from these and was not happy with how that worked. (could have been the cheap paper I used) I could work on a more nostalgic looking logo, but I am not clear yet as to how to get it from Photo Shop on to a decal, iron on, silk screen, etc. with the quality I want. ________________________________________________________________________________
Date: Mar 01, 2010
I am planning to use dimple tape on the prop and VGs on the wing. If it can be proven that dimple tape is just as good in this application, I would us e it. I think that would look a little nicer then the VGs. (How would both dimple tape and VGs work on the wing?) --- On Mon, 3/1/10, Dan Yocum wrote: From: Dan Yocum <yocum(at)fnal.gov> Subject: Re: Pietenpol-List: dimpletape on a Ford Date: Monday, March 1, 2010, 12:25 PM Gardiner, Bill Rewey wrote an article in one of the last 3 BPA newsletters on his use of the dimpletape.- He says he gets about 10% decrease in fuel consumption using it on his prop. If anyone's willing to put the stuff on their wing, I'd be interested in seeing what results they get. I reckon it would act quite a bit like VGs. Dan On 03/01/2010 08:35 AM, airlion wrote: > Are there any other Listers out there using Dimpletape, and, if so, how > much performance increase is realized? Cheers, Gardiner Mason > > ------------------------------------------------------------------------ > *From:* Jeff Boatright > *To:* pietenpol-list(at)matronics.com > *Sent:* Sun, February 28, 2010 10:15:48 PM > *Subject:* Re: Pietenpol-List: dimpletape on a Ford > > Ryan, > > Thanks for the link. If I wrap my head with it, will I think faster? I > guess like MMO, it couldn't hurt! =-O > > Jeff > > >> Jeff, >> >> You can get it straight from the person that invented it: >> http://www.dimpletape.com/ >> >> Make sure to check out the usage examples....you can tape your prop, >> your wings, and you can give the leftover to your beret-wearing speed >> skater friends, or you can apply it to the wing on your 1981 Ford LTD. : P >> Ryan > > > -- > > > Jeff Boatright > "Now let's think about this..." > > * > > > * > > * > > > * -- Dan Yocum Fermilab- 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." le, List Admin. ________________________________________________________________________________
Date: Mar 01, 2010
Subject: Re: John Hofmann's tribute video (Markle)
Now that was very funny.I had no idea that Jim was doing that much damage t o the Germans.=0A=0A=0A=0A=0A________________________________=0AFrom: Micha el Perez =0ATo: pietenpol-list(at)matronics.com=0ASe nt: Mon, March 1, 2010 11:40:49 AM=0ASubject: Pietenpol-List: John Hofmann' s tribute video (Markle)=0A=0A=0AFor those whom may have missed it, John's video is awesome! Very, well done and very funny! I have watched it a handf ull of times now and think it is great. The link is below.- I am honored to be mentioned in the video as were many of the viewers of this list.=0A =0AFYI, the Pin the Tail on Perez GAME will be for sale on my site if I eve r figure out how to make it. (This is NOT an invite for suggestions either) =============== ________________________________________________________________________________
Date: Mar 01, 2010
I am going to put dimple tape on my Aerona. I will report in after I have had a chance to evaluate. Can that stuff be removed if I don't like it? Dan Helsper Poplar Grove, IL. I am planning to use dimple tape on the prop and VGs on the wing. If it ca n be proven that dimple tape is just as good in this application, I would use it. I think that would look a little nicer then the VGs. (How would both dimple tape and VGs work on the wing?) --- > > > -- > > > > * > > > * > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly b= --> http://www.matronics.com/Navigator?Pietenpol; - MATRONICS WEB FORUMS - ==== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Mar 01, 2010
HOW WOULD THE TAPE WORK ON A WARP DRIVE? GARDINER ________________________________ From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Mon, March 1, 2010 12:51:36 PM Subject: Re: Pietenpol-List: dimpletape on a Ford I am planning to use dimple tape on the prop and VGs on the wing. If it can be proven that dimple tape is just as good in this application, I would use it. I think that would look a little nicer then the VGs. (How would both dimple tape and VGs work on the wing?) --- On Mon, 3/1/10, Dan Yocum wrote: >From: Dan Yocum <yocum(at)fnal.gov> >Subject: Re: Pietenpol-List: dimpletape on a Ford >To: pietenpol-list(at)matronics.com >Date: Monday, March 1, 2010, 12:25 PM > > >Gardiner, > >Bill Rewey wrote an article in one of the last 3 BPA newsletters on his >use of the dimpletape. He says he gets about 10% decrease in fuel >consumption using it on his prop. > >If anyone's willing to put the stuff on their wing, I'd be interested in >seeing what results they get. I reckon it would act quite a bit like VGs. > >Dan > >On 03/01/2010 08:35 AM, airlion wrote: >> Are there any other Listers out there using Dimpletape, and, if so, how >> much performance increase is realized? Cheers, Gardiner Mason >> >> ------------------------------------------------------------------------ >> *From:* Jeff Boatright >> *To:* pietenpol-list(at)matronics.com >> *Sent:* Sun, February 28, 2010 10:15:48 PM >> *Subject:* Re: Pietenpol-List: dimpletape on a Ford >> >> Ryan, >> >> Thanks for the link. If I wrap my head with it, will I think faster? I >> guess like MMO, it couldn't hurt! =-O >> >> Jeff >> >> >>> Jeff, >>> >>> You can get it straight from the person that invented it: >>> http://www.dimpletape.com/ >>> >>> Make sure to check out the usage examples....you can tape your prop, >>> your wings, and you can give the leftover to your > beret-wearing speed >>> skater friends, or you can apply it to the wing on your 1981 Ford LTD. :P >>> Ryan >> >> >> -- >> >> >> Jeff Boatright >> "Now let's think about this..." >> >> * >> >> >> * >> >> * >> >> >> * > >-- >Dan Yocum >Fermilab 630.840.6509 >yocum@fnal.gov, http://fermigrid.fnal.gov/ > > > ________________________________________________________________________________
Date: Mar 01, 2010
Douwe. Here is the logo I'm going to put on the side of my plane. It's a modified version of the other logo that was posted and then I added some wings. The picture is of a sticker I made to see how I liked it ( and I've made a few minor modifications since that sticker). I made the sticker out of some vinyl scraps I had, so it's not the colors I will be doing when I make it for my plane but it gives you the idea. Mike Groah Tulare CA ________________________________ From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Mon, March 1, 2010 12:42:11 AM Subject: Pietenpol-List: Pietenpol logo Does anybody have a good quality Pietenpol logo in jpeg or something similar? I want to have some old-fashioned white mechanics coveralls silscreened with a cool logo on the back. I found a neat old mobilgas logo, but then got to thinking about the classic Pietenpol signature. Douwe ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Mar 01, 2010
I was asking a Tailwind flier friend about the dimple tape. and he said another Tailwind guy said he tried it and it made his airplane 100$ lighter. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288821#288821 ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Mar 01, 2010
That looks way cool! Nice work! Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com On Mar 1, 2010, at 3:13 PM, Michael Groah wrote: > Douwe. > > Here is the logo I'm going to put on the side of my plane. It's a > modified version of the other logo that was posted and then I added > some wings. The picture is of a sticker I made to see how I liked > it ( and I've made a few minor modifications since that sticker). I > made the sticker out of some vinyl scraps I had, so it's not the > colors I will be doing when I make it for my plane but it gives you > the idea. > > Mike Groah > Tulare CA > > From: Douwe Blumberg <douweblumberg(at)earthlink.net> > To: pietenpolgroup > Sent: Mon, March 1, 2010 12:42:11 AM > Subject: Pietenpol-List: Pietenpol logo > > > <100_1166.jpg> ________________________________________________________________________________
Date: Mar 01, 2010
I look forward to seeing your results. I know several people have reported that dimple tape allowed more RPMs, but I wonder if that translates to more thrust. Since the propeller is an airfoil, and the tape has modified the airfoil and cut the drag, I assume that the lift (thrust) of the airfoil may have also been affected, but I'm not sure if it would be more lift or less. Flying, or a thrust test would certainly show this for sure. I'm not saying that I don't believe it will improve the thrust, just that it is unclear to ME. I have VGs on my Kolb and I'm sold on them. I hope the dimple tape works as well. Malcolm Morrison http://home.comcast.net/~mmorrison123/ ----- Original Message ----- From: helspersew(at)aol.com Sent: Monday, March 1, 2010 1:34:51 PM GMT -05:00 US/Canada Eastern Subject: Re: Pietenpol-List: dimpletape on a Ford I am going to put dimple tape on my Aerona. I will report in after I have had a chance to evaluate. Can that stuff be removed if I don't like it? Dan Helsper Poplar Grove, IL. I am planning to use dimple tape on the prop and VGs on the wing. If it can be proven that dimple tape is just as good in this application, I would use it. I think that would look a little nicer then the VGs. (How would both dimple tape and VGs work on the wing?) --- > > > -- > > > > * > > > * > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov , http://fermigrid.fnal.gov "I fly b= --> http://www.matronics.com/Navigator?Pietenpol; - MATRONICS WEB FORUMS - tion" target=_blank>http://www.====================== =================================== t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List =================================== tp://forums.matronics.com =================================== _blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: trailer
Date: Mar 01, 2010
I don't know if there is anybody out there interested in an aircraft hauler or not. but I would sure like to sell mine to make room in my shop to start assembling my project I hauled home from Arizona in it after I bought it from D.J.- Trailer is in great condition and since it is skinned with aluminum I have kept it inside just to prevent a chance of hail dents.but I need the room worse. if you know anyone interested I'd sure appreciate an e-mail.it has also hauled a 2 place Challenger long wing.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288844#288844 ________________________________________________________________________________
Date: Mar 01, 2010
I'm building a 612 wing and have just started doing the ribs with the spars perpendicular to the chord line. You are correct that the front spar is lower than the original but if the chord line is kept at the same angle of incidence with respect to the fuselage as the original airfoil, then (I think) it should be close. I seem to remember somewhere that a 5 degree angle of incidence is a good place to start. My rusty math skills (and a real calculator) indicate that a 1 inch change on the cabanes gives about 2 degrees change on the angle of incidence so the original plans recommendation of 2 inches (IIRC) difference makes mathematical sense and approximates the 5 degree wag. Since it'll be a couple of years before my airplane flies, I'll be interested to see what happens with others. Dave Aldrich Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288846#288846 ________________________________________________________________________________
Date: Mar 01, 2010
Subject: economy dimpletape
Group, I have some mocck up dimple tape on the prop now. I sliced down some of the do-it-yourselfer's adheasive perferated drywall tape. It is the stuff with all the little round holes in it, and its a 50ft roll, 2 inches wide and about $5 worth would probably do every pietenpol that is flying. I might try this stuff and se how it works, just have to use some CA (model airplane super glue) glue to hold it on, and coat it after it is done because it is just a heavy paper. Just have to be careful not to fill in all the holes with varnish. Shad ________________________________________________________________________________
Date: Mar 01, 2010
Subject: Re: Riblett 612 and angle of incidence--No, no, TWO
DEGREES!!! TWO DEGREES!!! >From my memory, the original prints call for a 2 degree angle of incidence. My math at the time showed two degrees to be a few thousandths of an inch less than a one (1) inch difference in the height of the cabanes. Many conversations and a few posts on this board have referred to the front cabane being one inch higher than the rear. Moreover, I have measured a few at Brodhead and elsewhere, and believe that they were all very close to a one inch difference in height. Mine is 1 inch taller. A discussion of alternative and benefits may be warranted, but let's agree on the original benchmark. Let me know if I am wrong. Tim in central TX -----Original Message----- >From: dgaldrich <dgaldrich(at)embarqmail.com> >Sent: Mar 1, 2010 6:52 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Riblett 612 and angle of incidence > > >I'm building a 612 wing and have just started doing the ribs with the spars perpendicular to the chord line. You are correct that the front spar is lower than the original but if the chord line is kept at the same angle of incidence with respect to the fuselage as the original airfoil, then (I think) it should be close. > >I seem to remember somewhere that a 5 degree angle of incidence is a good place to start. My rusty math skills (and a real calculator) indicate that a 1 inch change on the cabanes gives about 2 degrees change on the angle of incidence so the original plans recommendation of 2 inches (IIRC) difference makes mathematical sense and approximates the 5 degree wag. > >Since it'll be a couple of years before my airplane flies, I'll be interested to see what happens with others. > >Dave Aldrich > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=288846#288846 > > ________________________________________________________________________________
Subject: Re: Riblett 612 and angle of incidence--No, no, TWO DEGREES!!!
Date: Mar 01, 2010
Hi Tim Hey, at least our math is the same!!! Can't say the same for my memory. I could have saved the aggravation by walking out to the garage but noooooooooo, it had to be from dim memory. At least someone is reading. I agree that we need to start from known benchmarks and 1 inch/2 degrees sounds like it would work. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288855#288855 ________________________________________________________________________________
Date: Mar 01, 2010
Subject: Re: economy dimpletape
Shad, On a serious note, how close does it look to the expensive stuff? On a lighter note, you can always "coat it after it is done" with drywall mud ;) Tim in central TX -----Original Message----- >From: shad bell <aviatorbell(at)yahoo.com> >Sent: Mar 1, 2010 7:03 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: economy dimpletape > > >Group, I have some mocck up dimple tape on the prop now. I sliced down some of the do-it-yourselfer's adheasive perferated drywall tape. It is the stuff with all the little round holes in it, and its a 50ft roll, 2 inches wide and about $5 worth would probably do every pietenpol that is flying. I might try this stuff and se how it works, just have to use some CA (model airplane super glue) glue to hold it on, and coat it after it is done because it is just a heavy paper. Just have to be careful not to fill in all the holes with varnish. > >Shad > > > > > ________________________________________________________________________________
Date: Mar 01, 2010
Mike, It looks great, nice work! Could you share a digital version? Thanks, DSM Douwe. Here is the logo I'm going to put on the side of my plane. It's a modified version of the other logo that was posted and then I added some wings. The picture is of a sticker I made to see how I liked it ( and I've made a few minor modifications since that sticker). I made the sticker out of some vinyl scraps I had, so it's not the colors I will be doing when I make it for my plane but it gives you the idea. Mike Groah Tulare CA _____ From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Mon, March 1, 2010 12:42:11 AM Subject: Pietenpol-List: Pietenpol logo ________________________________________________________________________________
Date: Mar 01, 2010
You can get some vinyl dimple tape from a good quality sign shop. Cheers, Dan On 03/01/2010 07:03 PM, shad bell wrote: > --> Pietenpol-List message posted by: shad bell > > > Group, I have some mocck up dimple tape on the prop now. I sliced down some of the do-it-yourselfer's adheasive perferated drywall tape. It is the stuff with all the little round holes in it, and its a 50ft roll, 2 inches wide and about $5 worth would probably do every pietenpol that is flying. I might try this stuff and se how it works, just have to use some CA (model airplane super glue) glue to hold it on, and coat it after it is done because it is just a heavy paper. Just have to be careful not to fill in all the holes with varnish. > > Shad > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 01, 2010
Dave, I think you're remembering that the zero lift angle for the FC-10 is -5 degrees. The Riblett zero lift AoI is -3.9 degrees. This is all from the discussion here: http://forums.matronics.com/viewtopic.php?p=226498#226498 Pieti said he kept the Riblett AoI to be 2 degrees, the same as what he had for the FC-10 wing. Did you guys build the AoI into the ribs or keep it at 90 degrees to the chord? Thanks, Dan On 03/01/2010 06:52 PM, dgaldrich wrote: > --> Pietenpol-List message posted by: "dgaldrich" > > I'm building a 612 wing and have just started doing the ribs with the spars perpendicular to the chord line. You are correct that the front spar is lower than the original but if the chord line is kept at the same angle of incidence with respect to the fuselage as the original airfoil, then (I think) it should be close. > > I seem to remember somewhere that a 5 degree angle of incidence is a good place to start. My rusty math skills (and a real calculator) indicate that a 1 inch change on the cabanes gives about 2 degrees change on the angle of incidence so the original plans recommendation of 2 inches (IIRC) difference makes mathematical sense and approximates the 5 degree wag. > > Since it'll be a couple of years before my airplane flies, I'll be interested to see what happens with others. > > Dave Aldrich > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288846#288846 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Piet pic
Date: Mar 01, 2010
here is a great story about P-51's and their pilots but it does have a nice Piet pic at the bottom so you might want to look. there are some other great shots as well. http://forums.corvetteforum.com/off-topic/2400756-oshkosh-2009-wwii-pilot-reunited-with-his-airplane.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288879#288879 ________________________________________________________________________________
Date: Mar 02, 2010
Greetings all, if there is enough interest I will burn the screens, and print the Tee shirt/coveralls, Jake "Jack" Sent by: owner-pietenpol-list-server(at)matronics.com 03/01/2010 04:39 AM Please respond to pietenpol-list(at)matronics.com To cc Subject RE: Pietenpol-List: Pietenpol logo Douwe, This is all I have, not sure who to credit with the design Jack DSM Does anybody have a good quality Pietenpol logo in jpeg or something similar? I want to have some old-fashioned white mechanics coveralls silscreened with a cool logo on the back. I found a neat old mobilgas logo, but then got to thinking about the classic Pietenpol signature. Douwe ________________________________________________________________________ This email has been scanned for SPAM content and Viruses by the MessageL abs Email Security System. ________________________________________________________________________ ________________________________________________________________________________
Date: Mar 02, 2010
Subject: Fw: CorvAircraft> Dimpletape on a propeller
This is forwarded from the Corvaircraft Forum in regards to dimpletape... John F. Richmond, TX -----Forwarded Message----- >From: WilliamTCA(at)aol.com >Sent: Mar 1, 2010 11:37 PM >To: corvaircraft(at)mylist.net >Subject: CorvAircraft> Dimpletape on a propeller > >John, > >This product generated a lot of interest about 15 years ago. If you look at > the article they reference on the webpage, it is dated from 1998. At the >time many of my friends and I did a lot of work on Lancair aircraft. The >people who owned them would gladly sell their children into slavery or science >experiments if it would make their Lancair 320/360/IVP go 15 knots faster. >We were friends with Don Goetz, the main Lancair salesman and test pilot. >His plane had the tape on it, which initially drew my interest. However, it >turned out that Don had a 'dealership' for the tape and would gladly sell >you some of the very high priced rolls right after he got done with his >glowing testimonial. > >If you look at the site, note that it says that F-18s have dimples, not >Dimple tape. If you look at the underside of an SR-71, it is corrugated. >However, putting 1/4" deep corrugations in the underside of a set of KR wings >would probably not get the airframe substantially closer to mach 3. > >in 1998 I worked for a year to modify our Pietenpol after the "Church >parking lot incident." >In the interest of increasing speed we; > >1) Switched from 8.00x4 cub tires to 6x6s with half the cross section. > >2) Changed from a cowl resembling a garbage can to one that looked like a >streamlined can > >3) Installed an 11" spinner > >4) Sank the seats down 4" to bring the pilots and passengers shoulders into > the plane. > >5) Did enough engine mods that it actually raised the static rpm to 2850 >from 2475 > >6) Installed a 68" Warp drive prop in place of 64" wood that should have >had a clock in it. > >7) Made new windshields that were half the height, and angled back twice as > much. > >8) Made a new motor mount to take out all the down thrust and raise the >thrust 4" > >9) Made new gear that discarded the J-3 bungee bags in favor of 2" die >springs. > >10) Made a new exhaust system to eliminate the plume from the straight >pipes. > >11) Made a folding wing hatch to eliminate scallop in trailing edge above >pilots head. > >Numbers 1 through 11 netted a total of 24 mph. #5 and 6 made most of the >difference. Had I only believed in Dimple tape, I could have saved a lot of >work by putting 3 or 4 rolls of it on the Pietenpol. Might have taken an >hour vs the year I spent in the shop. Shows what a luddite I am. You can't >teach monkeys anything. > >On the cases where it actually makes some measurable difference when >applied to a prop, consider two points. First, I would like to know what the >measured Rate of Climb difference is, because a small change in static doesn't >mean much in flight. Second, I think much of the prop benefit was because >some of the props it was applied to were very thick, poor performers. I >would be willing to bet it wouldn't make a measurable difference on a thin prop >like a Warp Drive. This point is comparable to some 1980s and 1990s fast >homebuilts that used to 'reflex' the flaps to minus 5 degrees and speed up >a little. This actually worked on some planes, but all it really indicated >was that the airfoil on the plane had too much camber for the cruise speed >of the plane. It was a band aid. > >Thank you. > >John, Please forward this back to the Pietenpol forum, as I would rather >not see a bunch of very good looking aircampers with dotted tape all over >them at the next Brodhead. > > >William Wynne >5000-18 HWY 17 #247 >Orange Park, FL 32003 >_http://FlyCorvair.com/hangar.html_ (http://flycorvair.com/hangar.html) >_http://ZenVair.com_ (http://flycorvair.com/) >_________________________________________________________ >search the CorvAircraft archives at http://www.maddyhome.com/corvairsrch/index.jsp >to UNsubscribe from CorvAircraft, send a message to CorvAircraft-leave(at)mylist.net >Other CorvAircraft list info is at http://www.krnet.org/corvaircraft_inst.html ________________________________________ ________________________________________________________________________________
Subject: Re: Markle Mania 2010 final results
Date: Mar 02, 2010
Ryan.. Thanks so much for facilitating (I DO hate this verb) the effort. JM wanted to visit me and my project last summer; alas, I was to be at OSH so could not accommodate him. I see my small contribution to Mania as an act of penance and, hopefully, goodwill. In an age of Feds throwing Billions to Bailouts, I'm warmly reminded of what it must have been like for Our Pioneers to have lent an ox or two to a neighbor in Spring in return for a larder full of summer corn in Fall. Just born too late, I guess. God Speed and Blue Skies to us all, Al ----- Original Message ----- From: Ryan Mueller To: Pietenpol List Sent: Sunday, February 28, 2010 11:57 PM Subject: Pietenpol-List: Markle Mania 2010 final results Good evening everyone, We are emailing this evening to distribute the final update regarding Markle Mania 2010, the effort to help Jim Markle keep his Pietenpol project. We have received 73 generous donations out of 78 that were pledged, for a grand total of $6490.50. No further donations have arrived in the past few weeks, so I think it is safe to say that we can draw this to a close. /snipped ________________________________________________________________________________
Date: Mar 02, 2010
DEGREES!!! My prints show 2 degrees. They also show a 1" length difference between the front and back cabanes. ________________________________________________________________________________
Subject: Re: Fw: CorvAircraft> Dimpletape on a propeller
Date: Mar 02, 2010
This was primarily for thermal expansion and secondarily for stiffness. It had nothing to do with the transition to turbulent flow, as the SR-71 operated at a very high Reynolds Number, even at "low" speeds. David Paule >> If you look at the underside of an SR-71, it is corrugated. ________________________________________________________________________________
Date: Mar 02, 2010
This is how I'm doing my ribs: Spars are perpendicular to the chord line. The lower surface of the Riblett 612 at the front spar location is quite a bit below the read spar location, so I've built a spacer into the truss. The standard 4 3/4" high spar will sit on top of the spacer and just fit to the top capstrip. If I remember correctly (don't have my notes here at work) the front spar still sits slightly lower than the rear with respective to their positions in the FC10 section. When it comes time to mount the wing I'll do the math to put the wing at the right angle so that when the wing is at cruise AOA the fuselage will be level. That's the great thing about building a Pietenpol, you can leave those decisions until you have to make them. --Ken > > Dave, > > I think you're remembering that the zero lift angle for the FC-10 is -5 > degrees. The Riblett zero lift AoI is -3.9 degrees. This is all from > the discussion here: > > http://forums.matronics.com/viewtopic.php?p=226498#226498 > > Pieti said he kept the Riblett AoI to be 2 degrees, the same as what he > had for the FC-10 wing. > > Did you guys build the AoI into the ribs or keep it at 90 degrees to the > chord? > > Thanks, > Dan > > > On 03/01/2010 06:52 PM, dgaldrich wrote: >> --> Pietenpol-List message posted by: >> "dgaldrich" >> >> I'm building a 612 wing and have just started doing the ribs with the >> spars perpendicular to the chord line. You are correct that the front >> spar is lower than the original but if the chord line is kept at the same >> angle of incidence with respect to the fuselage as the original airfoil, >> then (I think) it should be close. >> >> I seem to remember somewhere that a 5 degree angle of incidence is a >> good place to start. My rusty math skills (and a real calculator) >> indicate that a 1 inch change on the cabanes gives about 2 degrees change >> on the angle of incidence so the original plans recommendation of 2 >> inches (IIRC) difference makes mathematical sense and approximates the 5 >> degree wag. >> >> Since it'll be a couple of years before my airplane flies, I'll be >> interested to see what happens with others. >> >> Dave Aldrich >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=288846#288846 >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Mar 02, 2010
Tim, It is just a med-heavy paper adheasive tape, with 1/8 inch holes in it. They carry it at your local Home Depot, or Lowes. It is not actually dimpled, it has holes, but it would probably have the same effect. I might try a sign shop for some vinal tape as Jeff suggested. I'm not expecting a drastic increase in performance, or economy, just a little. It also just gives us something to experiment with for some thing to do. The perferated drywall tape, by the way, is an easy way to get acceptable results on your drywall projects, I can frame, but I hate drywall, and the sticky back tape makes it a little eaiser. Shad ________________________________________________________________________________
Date: Mar 02, 2010
Dan. I tried to build the 612 the same as the FC 10 per the drawings. 90 deg. with a spacer T88ed to the top of the spar to rib. Harold R. suggested I use a 1 deg angle of incidence for best performance. I would just make the change in the cabane height. to achieve the 1 Deg. Keep in mind that my wings are clipped 2 Ft, much like a clipped wing 4412 on an earlier Piet that performed great but much faster on landing speed. I am sure you will be satisfied with the glide using the 612, approaches the J3. Pieti Lowell I watched the videos Jeff B. put on Youtube of your talk at Brodhead last year. You mentioned that you kept your AoI of 2 degrees from the FC-10 and that you'd probably like to see it at 1 degree or less because at flat out cruise you've got to apply a significant (30-40lbs) amount of forward pressure on the stick. The question I have is this: did you build the angle of incidence into the spar orientation in the ribs or did you keep the spars at a 90 degree angle to the wing chord? Also, looking at the Riblett 612, I see that if you keep the front spar the same distance from the leading edge as the FC1-1, 6 inches, that dictates that the front spar and the rear spar will not be aligned, vertically - the front spar must be shifted down an inch or so to fit in the rib with respect to the aft spar. How did you address this? Did you even worry about it? Thanks, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things."[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288909#288909 ________________________________________________________________________________
Date: Mar 02, 2010
Tim The 1 inch is correct but if you go 612 use 1/2 inch to get 1 Deg. Pieti Lowell My prints show 2 degrees. They also show a 1" length difference between the front and back cabanes. [/quote] > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288912#288912 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: logos, coveralls etc.
Date: Mar 02, 2010
Hey Don, Great minds think alike eh? I talked to my friend at Old Rhinebeck (owns the beautiful "626" that used to fly there) since they are really good at the period look. He directed me to Universal Overall company as the only place he could find old cotton coveralls. Ck out their site, they have cotton coveralls with hidden buttons. I'd have somebody put buttons down the front. They come in many colors, but White or unbleached probably would look great. I just got a pretty good old Mobilgas image that would certainly have that thirties look, and the kind folks from this site have been sending me stuff too, so we'll see. Let's talk and see what we come up with. Being an artist, I can always clean on of these up or make our own. The important thing to me is to get something that really looks old. Sounds like we have an offer from a silkscreener to make screens (thanks Jake!) which is the best printing way to go as it'll outlast and stay fresher than a heat transfer. The ultimate would be to have it embroidered, but I'll have to ck out the price on that, and it probably is way overkill. Don, let me know if you want to order a few coveralls with me, and anybody else and let's put our heads together about a logo so we can get something done before flying season. Douwe douweblumberg(at)earthlink.net ________________________________________________________________________________
Date: Mar 02, 2010
Thank you, sir. I'm just trying to think ahead a bit. If I can keep a true parallelogram between the front and rear cabanes, rib and top longeron, then there shouldn't be too much trouble shifting the wing back and forth to adjust for proper CG location. Well, I'll be a son-of-a-gun! If you placed the spar at the bottom of the ribs, and built your cabanes exactly the same height, that would build in a 1"3/32 difference between the front and rear cabanes, which, of course, makes an AoI of 2.16 degrees. Furthermore, and this is the beautiful part, shifting the wing back and forth wouldn't change the angle of incidence. Lowell, if you didn't re-adjust your cabane lengths and kept a shorter one in the back, you might actually have a 4 degree angle of incidence. Maybe I'm doing my geometry wrong... it's been known to happen. Ok, enough dithering, hypothesizing, and pontificating. Time to get to work. Thanks again, Dan On 03/02/2010 08:58 AM, Pieti Lowell wrote: > --> Pietenpol-List message posted by: "Pieti Lowell" > > Dan. > I tried to build the 612 the same as the FC 10 per the drawings. 90 deg. with a spacer T88ed to the top of the spar to rib. Harold R. suggested I use a 1 deg angle of incidence for best performance. I would just make the change in the cabane height. to achieve the 1 Deg. Keep in mind that my wings are clipped 2 Ft, much like a clipped wing 4412 on an earlier Piet that performed great but much faster on landing speed. I am sure you will be satisfied with the glide using the 612, approaches the J3. > Pieti Lowell > > I watched the videos Jeff B. put on Youtube of your talk at Brodhead > last year. You mentioned that you kept your AoI of 2 degrees from the > FC-10 and that you'd probably like to see it at 1 degree or less because > at flat out cruise you've got to apply a significant (30-40lbs) amount > of forward pressure on the stick. > > The question I have is this: did you build the angle of incidence into > the spar orientation in the ribs or did you keep the spars at a 90 > degree angle to the wing chord? > > Also, looking at the Riblett 612, I see that if you keep the front spar > the same distance from the leading edge as the FC1-1, 6 inches, that > dictates that the front spar and the rear spar will not be aligned, > vertically - the front spar must be shifted down an inch or so to fit in > the rib with respect to the aft spar. How did you address this? Did > you even worry about it? > > Thanks, > Dan > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 02, 2010
Subject: A Piet is a Piet
Saturday was a banner day for Pietenpoling in central AR. There was an EAA lunch at a far distant (12 miles) airport that I had decided to attend. The wx was a vicious gale (5-7 kts) but there were no clouds and the temp was a balmy 49 deg so, with the promise of cheap eats of the high cholesterol v ariety, off I went. With the conditions as they were I expected some bumps due to gusts but not much else as the terrain here is like unto a pancake. Boy, was I in for a surprise! About half way to my goal I started feeling little nibbles of lift. Then su ddenly I noticed the tail rise and my loosely held altitude of 1000' starte d going up at a rate that I had never before seen in my Piet. I put the nos e down and brought the mighty Ford back to idle but the climb continued. Si nce everything else was out of my ability to deal with, I decided to just r elax and see what was in store for me. Now this was not a head-knocking, co ntrol fighting struggle to stay upright, rather it was smooth and calm like an elevator. 3K came and went then 5K. Now, 5K was my all-time highest flight ever and a s discussed a few months ago, that's the altitude where things get kind of weird in a Piet. All of a sudden there is a voice in your head that whisper s, "You don't belong here", and the Piet seems to be too small and too deli cate to be that high. As all that was bouncing around in my brain I passed 6K then 7. Going through 8 thousand feet things got eerily quiet and I coul d see the curvature of the earth and stars were appearing in the blackness that was gathering around me. I think it was real but it could have been be cause I had my eyes closed for a while. Prayer Donica know. Well the lift subsided just as gently as it had come and I had a long,long, long glide to the luncheon airport but it was a crosswind to a paved runway and I just don't do that so I did a 180 and headed back home. Of course I took the great circle route around my earlier adventure. Now my Air Camper is about as stock as any one out there and it has served me well, even setting the absolute altitude record for Pietenpol aircraft i n Lonoke County. I've flown it to OSH twice, C37 often, flown with geese an d egrets and herons, had an unscheduled landing in a bean field, done touch -and-go's in farm fields all over the fruited plain and never ever felt lik e I wanted or needed a more powerful engine, different airfoil, pushrods, r adio, lights or any other thing more or less than what Mr. Pietenpol sugges ted. I do have a high performance (read high dollar) head that promised better f uel economy while delivering higher RPM, power, acceleration, smoother idle , etc. I don't think the engine or the airframe can tell any difference. As for adding dimple tape and VG's and other innovations for no apparent pu rpose, I'll take a pass. My simple, cheap, honest, easy-to-maintain and joy -to-fly Pietenpol Air Camper fulfills it's role perfectly. - Larry=0A=0A=0A ________________________________________________________________________________
Date: Mar 02, 2010
Subject: Re: logos, coveralls etc.
Please post something to the list when you get a price and design worked out, I might be interested. Steve Ruse Norman, OK Quoting Douwe Blumberg : > > > Hey Don, > > Great minds think alike eh? > > I talked to my friend at Old Rhinebeck (owns the beautiful "626" that used > to fly there) since they are really good at the period look. He directed me > to Universal Overall company as the only place he could find old cotton > coveralls. Ck out their site, they have cotton coveralls with hidden > buttons. I'd have somebody put buttons down the front. They come in many > colors, but White or unbleached probably would look great. > > I just got a pretty good old Mobilgas image that would certainly have that > thirties look, and the kind folks from this site have been sending me stuff > too, so we'll see. Let's talk and see what we come up with. Being an > artist, I can always clean on of these up or make our own. The important > thing to me is to get something that really looks old. > > Sounds like we have an offer from a silkscreener to make screens (thanks > Jake!) which is the best printing way to go as it'll outlast and stay > fresher than a heat transfer. The ultimate would be to have it embroidered, > but I'll have to ck out the price on that, and it probably is way overkill. > > Don, let me know if you want to order a few coveralls with me, and anybody > else and let's put our heads together about a logo so we can get something > done before flying season. > > Douwe > douweblumberg(at)earthlink.net > > ________________________________________________________________________________
Subject: Re: A Piet is a Piet
Date: Mar 02, 2010
Larry I was indeed a beautiful day even in my rental 150 around Batesville/Mtn. View. Where was the EAA function? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288929#288929 ________________________________________________________________________________
Date: Mar 02, 2010
On 03/02/2010 10:42 AM, Lawrence Williams wrote: > in my brain I passed 6K then 7. Going through 8 thousand feet things got > eerily quiet and I could see the curvature of the earth and stars were Wave lift in AR? Who knew! Sounds like a grand day. Here it's sunny, 36 degrees, winds aren't too high at 9mph, and my exhaust is off and sent out for replacement.... humph. > I do have a high performance (read high dollar) head that promised > better fuel economy while delivering higher RPM, power, acceleration, > smoother idle, etc. I don't think the engine or the airframe can tell > any difference. > As for adding dimple tape and VG's and other innovations for no apparent > purpose, I'll take a pass. My simple, cheap, honest, easy-to-maintain > and joy-to-fly Pietenpol Air Camper fulfills it's role perfectly. There are only 2 reasons I'm interested in the dimple tape - better climb rate and lower fuel consumption. If I can clear the trees/corn stalks by a bigger margin, that's a winner. If I can save 10% on gas, well, that's a nice bonus, too. All this talk about going 24mph faster in a Pietenpol... good grief, people! What on earth for?!?? -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: the vintage coverall project
Date: Mar 02, 2010
Hey guys (...and gals??) Some people are interested in getting some vintage coveralls with some kind of cool old logo silkscreened on the back. Anybody who is interested contact me offlist at douweblumberg(at)earthlink.net Right now I'm thinking that everybody can order their size and color and have them shipped to me. Then those who want vintage buttons added can have that done with mine. My friend will do the silkscreening. The old mobilgas logo I like is only two colors so that'll only cost $20 each and some more if you want your name on the front. If you want a different logo than what we all come up with it'll be more, especially if it's full color and you have to pay for the screen charge yourself. I think the coveralls are around $36 Let me know who is interested and I'll get you the details and we'll all figure out what logo suits us, or if we want to do more than one. Douwe ________________________________________________________________________________
Date: Mar 02, 2010
DEGREES!!! Thanks, Lowell and Dan. This has uncovered something in my own peculiar case. I have the BP FC10 airfoil with an added nose, but am still using the original 2 degree (1") difference. Thus with a different airfoil nose, I have a larger radius at the nose, resulting in a slightly different (higher) chord line, and will have more AoI than I thought with my application. I'll take a look. I can still change it if I need to. However, with an A65, lift and climb are more important to me than speed, so I am erring on the right side in my mind with more AoI, but I don't need more pitching moment, etc. Tim in central TX -----Original Message----- >From: Pieti Lowell <Lowellcfrank(at)yahoo.com> >Sent: Mar 2, 2010 9:06 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Riblett 612 and angle of incidence--No, no, TWO DEGREES!!! > > >Tim >The 1 inch is correct but if you go 612 use 1/2 inch to get 1 Deg. >Pieti Lowell My prints show 2 degrees. They also show a 1" length difference between the front and back cabanes. >[/quote] >> [b] > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=288912#288912 > > ________________________________________________________________________________
Date: Mar 02, 2010
> > >All this talk about going 24mph faster in a Pietenpol... good grief, >people! What on earth for?!?? > So I can finally get the jump on that d@mned Pitts!!! -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 02, 2010
Very nice! Thanks for the essay. >Saturday was a banner day for Pietenpoling ... perfectly. > >Larry -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 02, 2010
Shad, I was just pulling your leg on the drywall mud bit. I think your idea might work very well, and admire your ability to visualize that connection. For the natural permanence of the vinyl sign material, that might work better. I have never seen it, though. In fact, I have never used that particular adhesive dimpled paper tape with drywall, but have used the plain paper and the adhesive nylon tape. I love carpentry, but also hate doing drywall. If the adhesive perforated paper drywall tape works for this, we will have to rename it "plane paper." Tim in central TX -----Original Message----- >From: shad bell <aviatorbell(at)yahoo.com> >Sent: Mar 2, 2010 8:58 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: economy dimpletape > > >Tim, It is just a med-heavy paper adheasive tape, with 1/8 inch holes in it. They carry it at your local Home Depot, or Lowes. It is not actually dimpled, it has holes, but it would probably have the same effect. I might try a sign shop for some vinal tape as Jeff suggested. I'm not expecting a drastic increase in performance, or economy, just a little. It also just gives us something to experiment with for some thing to do. The perferated drywall tape, by the way, is an easy way to get acceptable results on your drywall projects, I can frame, but I hate drywall, and the sticky back tape makes it a little eaiser. > >Shad > > > > > ________________________________________________________________________________
Date: Mar 02, 2010
Also interested. Rick On Tue, Mar 2, 2010 at 11:57 AM, Steve Ruse wrote: > > Please post something to the list when you get a price and design worked > out, I might be interested. > > Steve Ruse > Norman, OK > > Quoting Douwe Blumberg : > >> >> >> Hey Don, >> >> Great minds think alike eh? >> >> I talked to my friend at Old Rhinebeck (owns the beautiful "626" that used >> to fly there) since they are really good at the period look. He directed >> me >> to Universal Overall company as the only place he could find old cotton >> coveralls. Ck out their site, they have cotton coveralls with hidden >> buttons. I'd have somebody put buttons down the front. They come in many >> colors, but White or unbleached probably would look great. >> >> I just got a pretty good old Mobilgas image that would certainly have that >> thirties look, and the kind folks from this site have been sending me >> stuff >> too, so we'll see. Let's talk and see what we come up with. Being an >> artist, I can always clean on of these up or make our own. The important >> thing to me is to get something that really looks old. >> >> Sounds like we have an offer from a silkscreener to make screens (thanks >> Jake!) which is the best printing way to go as it'll outlast and stay >> fresher than a heat transfer. The ultimate would be to have it >> embroidered, >> but I'll have to ck out the price on that, and it probably is way >> overkill. >> >> Don, let me know if you want to order a few coveralls with me, and anybody >> else and let's put our heads together about a logo so we can get something >> done before flying season. >> >> Douwe >> douweblumberg(at)earthlink.net >> >> >> >> >> >> > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Mar 02, 2010
Lawrence, Thanks for one of the best and enjoyable postings I've read in a long while. Next time you'd better carry oxygen with ya! Who knows what a Piet will really do? Gene N502R ----- Original Message ----- From: Lawrence Williams To: Pietlist Sent: Tuesday, March 02, 2010 10:42 AM Subject: Pietenpol-List: A Piet is a Piet Saturday was a banner day for Pietenpoling in central AR. There was an EAA lunch at a far distant (12 miles) airport that I had decided to attend. The wx was a vicious gale (5-7 kts) but there were no clouds and the temp was a balmy 49 deg so, with the promise of cheap eats of the high cholesterol variety, off I went. With the conditions as they were I expected some bumps due to gusts but not much else as the terrain here is like unto a pancake. Boy, was I in for a surprise! About half way to my goal I started feeling little nibbles of lift. Then suddenly I noticed the tail rise and my loosely held altitude of 1000' started going up at a rate that I had never before seen in my Piet. I put the nose down and brought the mighty Ford back to idle but the climb continued. Since everything else was out of my ability to deal with, I decided to just relax and see what was in store for me. Now this was not a head-knocking, control fighting struggle to stay upright, rather it was smooth and calm like an elevator. 3K came and went then 5K. Now, 5K was my all-time highest flight ever and as discussed a few months ago, that's the altitude where things get kind of weird in a Piet. All of a sudden there is a voice in your head that whispers, "You don't belong here", and the Piet seems to be too small and too delicate to be that high. As all that was bouncing around in my brain I passed 6K then 7. Going through 8 thousand feet things got eerily quiet and I could see the curvature of the earth and stars were appearing in the blackness that was gathering around me. I think it was real but it could have been because I had my eyes closed for a while. Prayer Donica know. Well the lift subsided just as gently as it had come and I had a long,long,long glide to the luncheon airport but it was a crosswind to a paved runway and I just don't do that so I did a 180 and headed back home. Of course I took the great circle route around my earlier adventure. Now my Air Camper is about as stock as any one out there and it has served me well, even setting the absolute altitude record for Pietenpol aircraft in Lonoke County. I've flown it to OSH twice, C37 often, flown with geese and egrets and herons, had an unscheduled landing in a bean field, done touch-and-go's in farm fields all over the fruited plain and never ever felt like I wanted or needed a more powerful engine, different airfoil, pushrods, radio, lights or any other thing more or less than what Mr. Pietenpol suggested. I do have a high performance (read high dollar) head that promised better fuel economy while delivering higher RPM, power, acceleration, smoother idle, etc. I don't think the engine or the airframe can tell any difference. As for adding dimple tape and VG's and other innovations for no apparent purpose, I'll take a pass. My simple, cheap, honest, easy-to-maintain and joy-to-fly Pietenpol Air Camper fulfills it's role perfectly. Larry ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/02/10 07:34:00 ________________________________________________________________________________
Date: Mar 02, 2010
| Going through 8 thousand feet things got eerily quiet and I could see the curvature | of the earth and stars were appearing in the blackness that was gathering around | | me. Larry, I think you were in the Twilight Zone in your Piet at 8k ft. I lived at 8k ft. in CO for 11 years and never saw stars during the daylight hours (except for that big one at the center of the solar system). Rick > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 02, 2010
I'm interested, Roman Bukolt NX20795 On Mar 2, 2010, at 9:04 AM, Douwe Blumberg wrote: > > > > Hey Don, > > Great minds think alike eh? > > I talked to my friend at Old Rhinebeck (owns the beautiful "626" > that used > to fly there) since they are really good at the period look. He > directed me > to Universal Overall company as the only place he could find old > cotton > coveralls. Ck out their site, they have cotton coveralls with hidden > buttons. I'd have somebody put buttons down the front. They come > in many > colors, but White or unbleached probably would look great. > > I just got a pretty good old Mobilgas image that would certainly > have that > thirties look, and the kind folks from this site have been sending > me stuff > too, so we'll see. Let's talk and see what we come up with. Being an > artist, I can always clean on of these up or make our own. The > important > thing to me is to get something that really looks old. > > Sounds like we have an offer from a silkscreener to make screens > (thanks > Jake!) which is the best printing way to go as it'll outlast and stay > fresher than a heat transfer. The ultimate would be to have it > embroidered, > but I'll have to ck out the price on that, and it probably is way > overkill. > > Don, let me know if you want to order a few coveralls with me, and > anybody > else and let's put our heads together about a logo so we can get > something > done before flying season. > > Douwe > douweblumberg(at)earthlink.net > > ________________________________________________________________________________
Date: Mar 03, 2010
I'm in, too. Gary Boothe Sent from my Verizon Wireless BlackBerry -----Original Message----- From: Roman Bukolt <conceptmodels(at)tds.net> Date: Tue, 2 Mar 2010 15:13:29 Subject: Re: Pietenpol-List: logos, coveralls etc. I'm interested, Roman Bukolt NX20795 On Mar 2, 2010, at 9:04 AM, Douwe Blumberg wrote: > > > > Hey Don, > > Great minds think alike eh? > > I talked to my friend at Old Rhinebeck (owns the beautiful "626" > that used > to fly there) since they are really good at the period look. He > directed me > to Universal Overall company as the only place he could find old > cotton > coveralls. Ck out their site, they have cotton coveralls with hidden > buttons. I'd have somebody put buttons down the front. They come > in many > colors, but White or unbleached probably would look great. > > I just got a pretty good old Mobilgas image that would certainly > have that > thirties look, and the kind folks from this site have been sending > me stuff > too, so we'll see. Let's talk and see what we come up with. Being an > artist, I can always clean on of these up or make our own. The > important > thing to me is to get something that really looks old. > > Sounds like we have an offer from a silkscreener to make screens > (thanks > Jake!) which is the best printing way to go as it'll outlast and stay > fresher than a heat transfer. The ultimate would be to have it > embroidered, > but I'll have to ck out the price on that, and it probably is way > overkill. > > Don, let me know if you want to order a few coveralls with me, and > anybody > else and let's put our heads together about a logo so we can get > something > done before flying season. > > Douwe > douweblumberg(at)earthlink.net > > ________________________________________________________________________________
Subject: Re: Sun n Fun
Date: Mar 02, 2010
Hi Greg A rudder would be fine. Let me know. Dick ----- Original Message ----- From: "greg menoche" <gnwac(at)earthlink.net> Sent: Wednesday, February 24, 2010 2:28 PM Subject: Re: Pietenpol-List: Sun n Fun > > Dick, any chance of a rudder. Greg Menoche here in DE working on ribs. > It would be a great feeling to know that members at S&F had a part in the > completion of my one day Piet? Thanks. > > > -----Original Message----- > From: Dick N > Sent: Feb 24, 2010 11:48 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Sun n Fun > > > I just finished watching the morning news and it looks like you east > coasters are going to be getting another snow storm. Time to start > packing up and heading for Lakeland, Fl. for Sun and Fun. I have been > told that our Wood work Shop will be back in the indoors where it was 2 > years ago. For all who are not familiar, that workshop is kind of the 2nd > home of Pietenpol after Brodhead. If anybody needs anything built for a > Pietenpol contact me directly we can do it. Projects on hand for this > year are a prop for Gardiner Mason and if no other projects come around a > fuselage for me and maybe a tail section also. These will be for my new > Sky Scout. > Dick N. > > > ________________________________________________________________________________
Date: Mar 02, 2010
Larry: One must breath the exhaust of a Ford to have such a flight, A cure would be, try looking off to the right in place of the left for the first 20 minutes after take off. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289009#289009 ________________________________________________________________________________
Date: Mar 02, 2010
DQpJIHRoaW5rIGl0IG11c3QgYmUgdGhlIFUyLCBhcyB0aGUgU1I3MSBpcyBzdXBlcnNvbmljIGFu ZCB0ZWNobmljYWxseSBhIHBsYW5lIGZseWluZyBzdXBlcnNvbmljIGNhbm5vdCBzdGFsbC4gQXQg bGVhc3QgdGhhdCBpcyBteSBleHBlcmllbmNlLg0KTWF4DQoNCj4gRGF0ZTogVHVlLCAyIE1hciAy MDEwIDE5OjQwOjQ3IC0wNjAwDQo+IEZyb206IGppbV9tYXJrbGVAbWluZHNwcmluZy5jb20NCj4g VG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NCj4gU3ViamVjdDogUmU6IFBpZXRlbnBv bC1MaXN0OiBGdzogQ29ydkFpcmNyYWZ0PiBEaW1wbGV0YXBlIG9uIGEgcHJvcGVsbGVyDQo+IA0K PiAtLT4gUGlldGVucG9sLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEppbSBNYXJrbGUgPGppbV9t YXJrbGVAbWluZHNwcmluZy5jb20+DQo+IA0KPiBBbSBJIHN1cmUgaGUgd2FzIG5vdCB0YWxraW5n IGFib3V0IHRoZSBVLTI/Pz8/ICBOb3BlLCBJJ20gbm90IHN1cmUgYXQgYWxsISAgQXMgZ29vZCBh cyBNWSBtZW1vcnkgaXMsIG1heWJlIGhlIHdhcyB0YWxraW5nIGFib3V0IHRoZSBKZW5ueSEgIDot KQ0KPiANCj4gSSB0aGluayBpdCB3YXMgdGhlIFNSNzEuLi4uYnV0IHdobyBrbm93cy4uLi4uICA6 LSkNCj4gDQo+IGRvIG5vdCBhcmNoaXZlDQo+IA0KPiANCj4gLS0tLS1PcmlnaW5hbCBNZXNzYWdl LS0tLS0NCj4gPkZyb206IFRpbSBXaWxsaXMgPHRpbW90aHl3aWxsaXNAZWFydGhsaW5rLm5ldD4N Cj4gPlNlbnQ6IE1hciAyLCAyMDEwIDE6MTAgUE0NCj4gPlRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRy b25pY3MuY29tDQo+ID5TdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IEZ3OiBDb3J2QWlyY3Jh ZnQ+IERpbXBsZXRhcGUgb24gYSBwcm9wZWxsZXINCj4gPg0KPiA+LS0+IFBpZXRlbnBvbC1MaXN0 IG1lc3NhZ2UgcG9zdGVkIGJ5OiBUaW0gV2lsbGlzIDx0aW1vdGh5d2lsbGlzQGVhcnRobGluay5u ZXQ+DQo+ID4NCj4gPkppbSwNCj4gPkFyZSB5b3Ugc3VyZSBoZSB3YXMgbm90IHRhbGtpbmcgYWJv dXQgdGhlIFUtMj8gIFN1Y2ggYSBkaWZmZXJlbmNlIGJldHdlZW4gY3J1aXNpbmcgYW5kIHN0YWxs aW5nIG9uIGEgVS0yLiAgDQo+ID5UaW0gaW4gY2VudHJhbCBUWA0KPiA+ZG8gbm90IGFyY2hpdmUN Cj4gPg0KPiA+DQo+ID4tLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KPiA+PkZyb206IEppbSBN YXJrbGUgPGppbV9tYXJrbGVAbWluZHNwcmluZy5jb20+DQo+ID4+U2VudDogTWFyIDIsIDIwMTAg MTE6MjggQU0NCj4gPj5UbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbQ0KPiA+PlN1Ympl Y3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDogRnc6IENvcnZBaXJjcmFmdD4gRGltcGxldGFwZSBvbiBh IHByb3BlbGxlcg0KPiA+Pg0KPiA+Pi0tPiBQaWV0ZW5wb2wtTGlzdCBtZXNzYWdlIHBvc3RlZCBi eTogSmltIE1hcmtsZSA8amltX21hcmtsZUBtaW5kc3ByaW5nLmNvbT4NCj4gPj4NCj4gPj5PbmNl IGxpdmVkIG5leHQgZG9vciB0byBhbiBFeC1TUjcxIHBpbG90Li4uaGUgdG9sZCBtZSB0aGUgZGlm ZmVyZW5jZSBiZXR3ZWVuIHN0YWxsIGFuZCBWbmUgYXQgYWx0aXR1ZGUgd2FzIHNvbWV0aGluZyBs aWtlIDQga25vdHMuLi5ub3QgcmVsYXRlZCB0byBhbnl0aGluZyBpbiB0aGlzIGNvbnZlcnNhdGlv biBidXQgSSB0aG91Z2h0IHRoYXQgd2FzIFZFUlkgaW50ZXJlc3RpbmcuDQo+ID4+DQo+ID4+ZG8g bm90IGFyY2hpdmUNCj4gPj4NCj4gPj4tLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KPiA+Pg0K PiA+PkZyb206IERhdmlkIFBhdWxlIA0KPiA+Pg0KPiA+PlNlbnQ6IE1hciAyLCAyMDEwIDg6NTEg QU0NCj4gPj4NCj4gPj5UbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbQ0KPiA+Pg0KPiA+ PlN1YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDogRnc6IENvcnZBaXJjcmFmdD4gRGltcGxldGFw ZSBvbiBhIHByb3BlbGxlcg0KPiA+Pg0KPiA+Pg0KPiA+Pg0KPiA+Pu+7vw0KPiA+Pg0KPiA+Pg0K PiA+Pg0KPiA+Pg0KPiA+Pg0KPiA+Pg0KPiA+PlRoaXMgd2FzIHByaW1hcmlseSBmb3IgdGhlcm1h bCBleHBhbnNpb24gYW5kIA0KPiA+PnNlY29uZGFyaWx5IGZvciBzdGlmZm5lc3MuIEl0IGhhZCBu b3RoaW5nIHRvIGRvIHdpdGggdGhlIHRyYW5zaXRpb24gdG8gdHVyYnVsZW50IA0KPiA+PmZsb3cs IGFzIHRoZSBTUi03MSBvcGVyYXRlZCBhdCBhIHZlcnkgaGlnaCBSZXlub2xkcyBOdW1iZXIsIGV2 ZW4gYXQgDQo+ID4+ImxvdyIgc3BlZWRzLg0KPiA+PiANCj4gPj5EYXZpZCBQYXVsZQ0KPiA+PiAN Cj4gPj4gDQo+ID4+IA0KPiA+PiA+PiBJZiB5b3UgbG9vayBhdCB0aGUgdW5kZXJzaWRlIG9mIGFu IFNSLTcxLCBpdCBpcyANCj4gPj5jb3JydWdhdGVkLiAgDQo+ID4+DQo+ID4+DQo+ID4+DQo+ID4+ DQo+ID4+DQo+ID4+DQo+ID4+DQo+ID4+DQo+ID4+DQo+ID4+DQo+ID4+DQo+ID4+DQo+ID4NCj4g Pg0KPiA+DQo+ID4NCj4gPg0KPiA+DQo+IA0KPiANCj4gDQo+IA0KPiANCj4gXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09 ICAgICAgICAgIC0gVGhlIFBpZXRlbnBvbC1MaXN0IEVtYWlsIEZvcnVtIC0NCj4gXy09IFVzZSB0 aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KPiBfLT0gdGhl IG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCj4gXy09 IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KPiBf LT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KPiBfLT0NCj4gXy09ICAgLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UGlldGVucG9sLUxpc3QNCj4gXy09DQo+ IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQo+IF8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KPiBf LT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEN Cj4gXy09DQo+IF8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCj4gXy09DQo+ IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQo+IF8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0N Cj4gXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCj4gXy09ICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KPiBfLT0g ICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPiBfLT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiAN Cj4gDQo+IA0KIAkJIAkgICAJCSAg ________________________________________________________________________________
Date: Mar 03, 2010
DQpUaGUgcHVycG9zZSBvZiB0aGUgbm9zZSBjb25lIChvciBzcGlrZSkgd2FzIHRvIGtlZXAgdGhl IHN1cGVyc29uaWMgYm93IHdhdmUgYXR0YWNoZWQgdG8gdGhlIGlubGV0IG9mIHRoZSBlbmdpbmUu IEpldCAodHVyYmluZSkgZW5naW5lcyB3aWxsIG5vdCBvcGVyYXRlIHdpdGggc3VwZXJzb25pYyBh aXJmbG93IGdvaW5nIHRocm91Z2ggdGhlIGVuZ2luZXMuIElmIHRoZSBzcGlrZSB3YXMgbm90IGlu IHRoZSBwcm9wZXIgcGxhY2UgdGhlIGVuZ2luZSB3b3VsZCBjb21wcmVzc29yIHN0YWxsIGFuZCBm bGFtZW91dC4gQXQgY3J1aXNlIChtYWNoIDMrKSB0aGlzIHdvdWxkIGNhdXNlIGEgeWF3aW5nIGlu dG8gdGhlIGRlYWQgZW5naW5lIHJlc3VsdGluZyBpbiBsb3NzIG9mIGNvbnRyb2wgYW5kIGJyZWFr dXAgb2YgdGhlIGFpcmNyYWZ0LiBUaGlzIHdhcyB0aGUgY2F1c2Ugb2YgYWxsIGJ1dCBvbmUgb2Yg dGhlIFNSLTcxIGNyYXNoZXMuIFRvIGZpeCB0aGlzLCB0aGV5IGFkZGVkIGF1dG9tYXRpYyBzaHV0 ZG93biBvZiB0aGUgZ29vZCBlbmdpbmUgaWYgdGhydXN0IG9uIG9uZSBzaWRlIHN1ZGRlbmx5IGRy b3BwZWQuIFRoZSByZWFzb24geW91IGNhbid0IHN0YWxsIHN1cGVyc29uaWNhbGx5IGlzIHRoZSBj b250cm9scyBhcmUgbm90IGFzIGVmZmVjdGl2ZSBhbmQgd291bGQgbm90IGJyaW5nIHRoZSB3aW5n IGludG8gYSBzdGFsbCBhbmdsZSBvZiBhdHRhY2suLi5vciBzb21ldGhpbmcgbGlrZSB0aGF0Lg0K RGF0ZTogV2VkLCAzIE1hciAyMDEwIDA1OjA1OjE4IC0wODAwDQpGcm9tOiBoYXJ2ZXkucnVsZUBy b2dlcnMuY29tDQpTdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IEZ3OiBDb3J2QWlyY3JhZnQ+ IERpbXBsZXRhcGUgb24gYSBwcm9wZWxsZXINClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3Mu Y29tDQoNCg0KDQpUaGUgU1I3MSBoYWQgYSBuYXN0eSBoYWJpdCBvZiBibG93YmFjayB3aGljaCB3 b3VsZCBtYWtlIHRoZSBlbmdpbmUgY3V0IG91dC5UaG9zZSBub3NlIGNvbmVzIGhhZCB0byBiZSBt b3ZlZCBhdCBqdXN0IHRoZSByaWdodCB0aW1lIGluIGp1c3QgdGhlIHJpZ2h0IGNvbmRpdGlvbnMg b3IgdGhpcyB3b3VsZCBoYXBwZW4uSW4gZWZmZWN0IHRoZSBlbmdpbmVzIHdvdWxkIHN0YWxsIG5v dCB0aGUgd2luZy5CdXQgSSdtIHN1cmUgaWYgeW91IGJyb3VnaHQgdGhlIHdpbmcgdG8gdGhlIHBy b3BlciBhbmdsZSBvZiBhdHRhY2sgaXQgd291bGQgc3RhbGwgYXMgYWxsIG90aGVycyBkby4NCg0K DQoNCg0KDQpGcm9tOiBNYXggSGVnbGVyIDxtYXhoZWdsZXJAbXNuLmNvbT4NClRvOiBwaWV0ZW5w b2wtbGlzdEBtYXRyb25pY3MuY29tDQpTZW50OiBUdWUsIE1hcmNoIDIsIDIwMTAgMTA6NTY6MzMg UE0NClN1YmplY3Q6IFJFOiBQaWV0ZW5wb2wtTGlzdDogRnc6IENvcnZBaXJjcmFmdD4gRGltcGxl dGFwZSBvbiBhIHByb3BlbGxlcg0KDQoNCg0KSSB0aGluayBpdCBtdXN0IGJlIHRoZSBVMiwgYXMg dGhlIFNSNzEgaXMgc3VwZXJzb25pYyBhbmQgdGVjaG5pY2FsbHkgYSBwbGFuZSBmbHlpbmcgc3Vw ZXJzb25pYyBjYW5ub3Qgc3RhbGwuIEF0IGxlYXN0IHRoYXQgaXMgbXkgZXhwZXJpZW5jZS4gDQoN Cg0KTWF4DQoNCj4gRGF0ZTogVHVlLCAyIE1hciAyMDEwIDE5OjQwOjQ3IC0wNjAwDQo+IEZyb206 IGppbV9tYXJrbGVAbWluZHNwcmluZy5jb20NCj4gVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmlj cy5jb20NCj4gU3ViamVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBGdzogQ29ydkFpcmNyYWZ0PiBE aW1wbGV0YXBlIG9uIGEgcHJvcGVsbGVyDQo+IA0KPiAtLT4gUGlldGVucG9sLUxpc3QgbWVzc2Fn ZSBwb3N0ZWQgYnk6IEppbSBNYXJrbGUgPGppbV9tYXJrbGVAbWluZHNwcmluZy5jb20+DQo+IA0K PiBBbSBJIHN1cmUgaGUgd2FzIG5vdCB0YWxraW5nIGFib3V0IHRoZSBVLTI/Pz8/IE5vcGUsIEkn bSBub3Qgc3VyZSBhdCBhbGwhIEFzIGdvb2QgYXMgTVkgbWVtb3J5IGlzLCBtYXliZSBoZSB3YXMg dGFsa2luZyBhYm91dCB0aGUgSmVubnkhIDotKQ0KPiANCj4gSSB0aGluayBpdCB3YXMgdGhlIFNS NzEuLi4uYnV0IHdobyBrbm93cy4uLi4uIDotKQ0KPiANCj4gZG8gbm90IGFyY2hpdmUNCj4gDQo+ IA0KPiAtLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KPiA+RnJvbTogVGltIFdpbGxpcyA8dGlt b3RoeXdpbGxpc0BlYXJ0aGxpbmsubmV0Pg0KPiA+U2VudDogTWFyIDIsIDIwMTAgMToxMCBQTQ0K PiA+VG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NCj4gPlN1YmplY3Q6IFJlOiBQaWV0 ZW5wb2wtTGlzdDogRnc6IENvcnZBaXJjcmFmdD4gRGltcGxldGFwZSBvbiBhIHByb3BlbGxlcg0K PiA+DQo+ID4tLT4gUGlldGVucG9sLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFRpbSBXaWxsaXMN CiA8dGltb3RoeXdpbGxpc0BlYXJ0aGxpbmsubmV0Pg0KPiA+DQo+ID5KaW0sDQo+ID5BcmUgeW91 IHN1cmUgaGUgd2FzIG5vdCB0YWxraW5nIGFib3V0IHRoZSBVLTI/IFN1Y2ggYSBkaWZmZXJlbmNl IGJldHdlZW4gY3J1aXNpbmcgYW5kIHN0YWxsaW5nIG9uIGEgVS0yLiANCj4gPlRpbSBpbiBjZW50 cmFsIFRYDQo+ID5kbyBub3QgYXJjaGl2ZQ0KPiA+DQo+ID4NCj4gPi0tLS0tT3JpZ2luYWwgTWVz c2FnZS0tLS0tDQo+ID4+RnJvbTogSmltIE1hcmtsZSA8amltX21hcmtsZUBtaW5kc3ByaW5nLmNv bT4NCj4gPj5TZW50OiBNYXIgMiwgMjAxMCAxMToyOCBBTQ0KPiA+PlRvOiBwaWV0ZW5wb2wtbGlz dEBtYXRyb25pY3MuY29tDQo+ID4+U3ViamVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBGdzogQ29y dkFpcmNyYWZ0PiBEaW1wbGV0YXBlIG9uIGEgcHJvcGVsbGVyDQo+ID4+DQo+ID4+LS0+IFBpZXRl bnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBKaW0gTWFya2xlIDxqaW1fbWFya2xlQG1pbmRz cHJpbmcuY29tPg0KPiA+Pg0KPiA+Pk9uY2UgbGl2ZWQgbmV4dCBkb29yIHRvIGFuIEV4LVNSNzEg cGlsb3QuLi5oZSB0b2xkIG1lIHRoZSBkaWZmZXJlbmNlIGJldHdlZW4gc3RhbGwgYW5kIFZuZSBh dCBhbHRpdHVkZSB3YXMgc29tZXRoaW5nIGxpa2UgNCBrbm90cy4uLm5vdCByZWxhdGVkIHRvIGFu eXRoaW5nIGluIHRoaXMgY29udmVyc2F0aW9uIGJ1dCBJIHRob3VnaHQgdGhhdCB3YXMgVkVSWSBp bnRlcmVzdGluZy4NCj4gPj4NCj4gPj5kbyBub3QNCiBhcmNoaXZlDQo+ID4+DQo+ID4+LS0tLS1P cmlnaW5hbCBNZXNzYWdlLS0tLS0NCj4gPj4NCj4gPj5Gcm9tOiBEYXZpZCBQYXVsZSANCj4gPj4N Cj4gPj5TZW50OiBNYXIgMiwgMjAxMCA4OjUxIEFNDQo+ID4+DQo+ID4+VG86IHBpZXRlbnBvbC1s aXN0QG1hdHJvbmljcy5jb20NCj4gPj4NCj4gPj5TdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6 IEZ3OiBDb3J2QWlyY3JhZnQ+IERpbXBsZXRhcGUgb24gYSBwcm9wZWxsZXINCj4gPj4NCj4gPj4N Cj4gPj4NCj4gPj7Dr8K7wr8NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4g Pj5UaGlzIHdhcyBwcmltYXJpbHkgZm9yIHRoZXJtYWwgZXhwYW5zaW9uIGFuZCANCj4gPj5zZWNv bmRhcmlseSBmb3Igc3RpZmZuZXNzLiBJdCBoYWQgbm90aGluZyB0byBkbyB3aXRoIHRoZSB0cmFu c2l0aW9uIHRvIHR1cmJ1bGVudCANCj4gPj5mbG93LCBhcyB0aGUgU1ItNzEgb3BlcmF0ZWQgYXQg YSB2ZXJ5IGhpZ2ggUmV5bm9sZHMgTnVtYmVyLCBldmVuIGF0IA0KPiA+PiJsb3ciIHNwZWVkcy4N Cj4gPj4gDQo+ID4+RGF2aWQgUGF1bGUNCj4gPj4gDQo+ID4+IA0KPiA+PiANCj4gPj4gPj4gSWYg eW91IGxvb2sgYXQgdGhlIHVuZGVyc2lkZSBvZiBhbg0KIFNSLTcxLCBpdCBpcyANCj4gPj5jb3Jy dWdhdGVkLiANCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4N Cj4gPj4NCj4gPj4NCj4gPj4NCj4gPj4NCj4gPg0KPiA+DQo+ID4NCj4gPg0KPiA+DQo+ID4NCj4g DQo+IA0KPiANCj4gDQo+IA0KJj09PT0NCj4gDQo+IA0KPiANCsKmwrfigLp+4oCww63CsizDnmco 4oCTxaDDk000w5NHw5pxw7zCosOqw6J6wrnDnsOBw4ouwq4nwqs4Xj4nwq16emjigJ3CuMKswrRJ xaHFoFFowq7DqVLDh8Kt4oCmw6PCtsK6J+KAsMOLxaDDi0V5wqtuwq3Dqw0KIGrDuCBqw5orwrbi gKDDq8Kjw5he4oSiwqnDsi4rLcK6w5jCpcWgw5jFvsKyw4vFk+KApsKrxaDDi1TFuMO0wq5uw4cr xaDigLpiwqJwwq3DiGLCvcOkxb5qwrchxZIn4oCT4oCg77+9w6w2wrLCujDCscOgwqFqw5FAQ8Oh wqLDmizigKbCqsOeandmwrnDiGbCucOIZsKiwrfvv73CqGt5w7HCtsOaw78w4oSiwqtrwqJ4xZPC scOKJsO8w5bCr8Wgwq3CosKzw6J6w5fCp8Km4oCwS8Wgw4thwrbDmsO/MOKEosKra8KieMWTwrHD iibDvMOWwq/FoMKtwqLCs8OiesOXwqfCpuKAsEvFoMOLbDRONOKCrOKAmVhARTlMxaHihKLDqCt5 wqtcwqJ7XsW+w5bCpcKy4oCgwq9qKVpuV8Kv4oCwwqtheWfigLrFoMOuxaFqw558bcK2xbjDv37F oMOuxaHDicWhwrbCuifigLDDi8KiaG3CtsW4w79+xaDDrsWhw4nFocK2wron4oCww4vCom/DmsOi wrLDkMKoxb7DmsOibsOrYsKidcW+bSjCrXzDoWp5MsKiw6fDqMKvKi7CrsKnesK6LsKyw4vCqcKm xaDDrQ0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVucG9sLUxpc3QgRW1haWwg Rm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRv IGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJz Y3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBD aGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0g ICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdA0K Xy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpf LT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEN Cl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0K Xy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFu ayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQogCQkgCSAgIAkJICA ________________________________________________________________________________
Subject: Han van der voort-gear springs
Date: Mar 03, 2010
From: "Jack T. Textor" <jtextor(at)thepalmergroup.com>
Morning all, Tried to send the following to Hans, must have a bad email. If anyone has his email please send it to me. Or, any comments on the note welcome. Thanks, Jack DSM Hans, I hope all is well with you. I'm building a Piet and currently trying to decide on the size of coil spring to use for the gear. If I'm correct, from your drawing you utilized a 3224-36 which from what I can tell can handle a max load of 2593 pounds. Some other plans I've seen utilize a spring with outside diameter of 1.5 and inside of .75 inches, with a max load of 1672 pounds. Have you been happy with yours? Do you think the second example would be too light? Hans thanks so much! Jack ________________________________________________________________________________
Date: Mar 03, 2010
Subject: a Piet is a Piet
Ok, Ok. Go get your "grain of salt" pills and re read my epic adventure. Al so keep the pills handy whenever you see one of my infrequent posts. - As for Vne vs. stall speed, it ain't uncommon at all. One of our Canadair R J's was leveling out at about =0A=0A=0A ________________________________________________________________________________
Date: Mar 03, 2010
Subject: Re: a Piet is a Piet
Ah comeon Larry. Give us the rest of the story! Stinemetze >>> Lawrence Williams 3/3/2010 8:37 AM >>> Ok, Ok. Go get your "grain of salt" pills and re read my epic adventure. Also keep the pills handy whenever you see one of my infrequent posts. As for Vne vs. stall speed, it ain't uncommon at all. One of our Canadair RJ's was leveling out at about ________________________________________________________________________________
Date: Mar 03, 2010
Max, when are you coming over to the Center of the World (also known as Camden)? Gene N502R =EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD=EF=BD,=EF=BD=03g(=EF =BD=EF=BD=EF=BDM=EF=BDGq=EF=BDz=EF=BD=EF=BD ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/03/10 07:34:00 ________________________________________________________________________________
Date: Mar 03, 2010
With specific hat tip to Arkansas, Oklahoma, and parts of Texas under "Favored Areas": http://www.aviationweather.ws/099_Mountain_Wave_Soaring.php -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 03, 2010
Subject: a piet is a piet
Ahem.....as I was saying before the GN-1 censor cut my message off: - One of our RJ's was leveling off at about 390 when it was noticed that the bugs on the speed tape were moving toward eachother and the stall horn soun ded followed quickly by the stick shaker. They lost a few thousand feet bef ore recovering and a new operating procedure was established by Bombardier. It was found that several other customers had similiar experiences. - At higher altitudes and higher Mach numbers my Piet airspeed spread between cruise and stall is about 20-25 kts so I feel pretty immune to that phenom enon. Something to keep ion mind, though for those of you with more that 50 hp and dimple tape who might explore ever-higher altitude records in the f uture. - I'd like to get some of the coveralls that are being talked about but only if they are immune to oil drips and won't make us look as gay as the Flitze r group. - Later- - Larry - -=0A=0A=0A ________________________________________________________________________________
Date: Mar 03, 2010
I just don't undrstand anyone doubting what a Piet can do. Gene N502R ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Wednesday, March 03, 2010 11:41 AM Subject: Re: Pietenpol-List: a Piet is a Piet > > With specific hat tip to Arkansas, Oklahoma, and parts of Texas under > "Favored Areas": > > http://www.aviationweather.ws/099_Mountain_Wave_Soaring.php > > -- > > Jeff Boatright > "Now let's think about this..." > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 07:34:00 ________________________________________________________________________________
Date: Mar 03, 2010
The Arrow story is very interesting. I encourage list members to google it, but only if you have a spare hour or three... >It would have been interesting to see if the Iroquois engine that >was designed to go into our Avro Arrow would have needed those >cones.The Avro Arrow was being tested while the SR-71 was being >built.Originally the SR-71 was called Archangel and then changed to >Oxcart.The Avro Arrow was touted as being able to reach speeds of >mach 5 with two Iroquois engines on board.Never actually proved >since we were told by the US to destroy this aircraft. I think in my >own personal opinion because it was the only plane in the world >capable of catching the Black Bird.The danger was that we would sell >to the French who would in turn sell to the Russians.I would have >loved to have seen the two birds flying side by side.It is all >speculation now as to whether or not our bird could have in fact out >flown it. -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 03, 2010
DQpJIHNwZW50IGEgd2VlayB0aGVyZSBvbmUgZGF5Li4ubWF5YmUgd2lsbCBjb21lIG92ZXIgd2hl biB5b3Ugd2lsbCBiZSBhcm91bmQuIEhvaGVud2FsZCB3aWxsIGJlIGhhdmluZyB0aGVyZSBmbHkt aW4gMTUgTWF5LCBiZSBzdXJlIHRvIGZseSBpbi4NCg0KRnJvbTogemhhcnZleUBiZW50b25jb3Vu dHljYWJsZS5uZXQNClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBS ZTogUGlldGVucG9sLUxpc3Q6IEZ3OiBDb3J2QWlyY3JhZnQ+IERpbXBsZXRhcGUgb24gYSBwcm9w ZWxsZXINCkRhdGU6IFdlZCwgMyBNYXIgMjAxMCAwOTo1MDo1OCAtMDYwMA0KDQoNCg0KDQoNCg0K DQoNCg0KDQpNYXgsIHdoZW4gYXJlIHlvdSBjb21pbmcgb3ZlciB0byB0aGUgQ2VudGVyIG9mIHRo ZSBXb3JsZCANCihhbHNvIGtub3duIGFzIENhbWRlbik/DQpHZW5lDQpONTAyUg0KDQogIGh0dHA6 Ly93d3cubWF0bmJzcDsgICAgIA0KdmlhIHRoZSBXZWIgDQogIGhyZWY9Imh0dHA6Ly9mb3J1bXMu bWF0cm9uaWNzLmNvbSI+aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfcDsgICAgICAgICAN CmdlbmVyb3VzIA0KICBic3A7ICAgICAgICAgICAgICAgICAgICANCiAgaHJlZj0iaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbiI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2M9 PT09PT09PT09PT09PT09PQ0KDQrvv73vv73vv71+77+977+977+9LO+/vQNnKO+/ve+/ve+/vU3v v71Hce+/vXrvv73vv70NCiAgDQogIA0KDQoNCi0gDQpSZWxlYXNlIA0KICBEYXRlOiAwMy8wMy8x MCAwNzozNDowMA0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVucG9s LUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMg TmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMg TGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1E YXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3Jl Og0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0 ZW5wb2wtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VC IEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUg V2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0K Xy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQogCQkgCSAg IAkJICA ________________________________________________________________________________
Date: Mar 03, 2010
DQpKdXN0IGtpZGRpbmchICAgOykNCg0KRnJvbTogbWF4aGVnbGVyQG1zbi5jb20NClRvOiBwaWV0 ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSRTogUGlldGVucG9sLUxpc3Q6IEZ3 OiBDb3J2QWlyY3JhZnQ+IERpbXBsZXRhcGUgb24gYSBwcm9wZWxsZXINCkRhdGU6IFdlZCwgMyBN YXIgMjAxMCAxNjoxNDoxMiAtMDYwMA0KDQoNCg0KDQoNCg0KDQoNCkkgc3BlbnQgYSB3ZWVrIHRo ZXJlIG9uZSBkYXkuLi5tYXliZSB3aWxsIGNvbWUgb3ZlciB3aGVuIHlvdSB3aWxsIGJlIGFyb3Vu ZC4gSG9oZW53YWxkIHdpbGwgYmUgaGF2aW5nIHRoZXJlIGZseS1pbiAxNSBNYXksIGJlIHN1cmUg dG8gZmx5IGluLg0KDQpGcm9tOiB6aGFydmV5QGJlbnRvbmNvdW50eWNhYmxlLm5ldA0KVG86IHBp ZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDog Rnc6IENvcnZBaXJjcmFmdD4gRGltcGxldGFwZSBvbiBhIHByb3BlbGxlcg0KRGF0ZTogV2VkLCAz IE1hciAyMDEwIDA5OjUwOjU4IC0wNjAwDQoNCg0KDQoNCg0KDQoNCg0KDQoNCk1heCwgd2hlbiBh cmUgeW91IGNvbWluZyBvdmVyIHRvIHRoZSBDZW50ZXIgb2YgdGhlIFdvcmxkIA0KKGFsc28ga25v d24gYXMgQ2FtZGVuKT8NCkdlbmUNCk41MDJSDQoNCiAgaHR0cDovL3d3dy5tYXRuYnNwOyAgICAg DQp2aWEgdGhlIFdlYiANCiAgaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIj5odHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl9wOyAgICAgICAgIA0KZ2VuZXJvdXMgDQogIGJzcDsg ICAgICAgICAgICAgICAgICAgIA0KICBocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vYz09PT09PT09PT09PT09PT09DQoN Cu+/ve+/ve+/vX7vv73vv73vv70s77+9A2co77+977+977+9Te+/vUdx77+9eu+/ve+/vQ0KICAN CiAgDQoNCg0KLSANClJlbGVhc2UgDQogIERhdGU6IDAzLzAzLzEwIDA3OjM0OjAwDQoNCg0KDQoN Cg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBQaWV0ZW5wb2wtTGlzdCBFbWFpbCBGb3J1bSAt DQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3Nl DQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlv biwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZB USwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1MaXN0DQpfLT0NCl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1l IGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpf LT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAg ICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBm b3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCiAJCSAJICAgCQkgIA= ________________________________________________________________________________
Date: Mar 03, 2010
Hey Guys, The Piet logos are very nice and I am sure the talent on this list will offer a great logo for clothing and the plane alike. My question is: Since we have both Piet and GN-1 builders and pilots on this list, would the Piet logo be welcomed on the GN-1? This was Bernard's design and concept and John Grega came along later with his revisions to the same concept. If both parties are in agreement, then I would like to order a coverall and logo for my GN-1. Thanks. Mike King 77Mk GN-1 Corpus Christi, Texas ----- Original Message ----- From: gboothe5(at)comcast.net To: pietenpol-list(at)matronics.com Sent: Tuesday, March 02, 2010 6:10 PM Subject: Re: Pietenpol-List: logos, coveralls etc. I'm in, too. Gary Boothe Sent from my Verizon Wireless BlackBerry -----Original Message----- From: Roman Bukolt <conceptmodels(at)tds.net> Date: Tue, 2 Mar 2010 15:13:29 To: Subject: Re: Pietenpol-List: logos, coveralls etc. I'm interested, Roman Bukolt NX20795 On Mar 2, 2010, at 9:04 AM, Douwe Blumberg wrote: > > > Hey Don, > > Great minds think alike eh? > > I talked to my friend at Old Rhinebeck (owns the beautiful "626" > that used > to fly there) since they are really good at the period look. He > directed me > to Universal Overall company as the only place he could find old > cotton > coveralls. Ck out their site, they have cotton coveralls with hidden > buttons. I'd have somebody put buttons down the front. They come > in many > colors, but White or unbleached probably would look great. > > I just got a pretty good old Mobilgas image that would certainly > have that > thirties look, and the kind folks from this site have been sending > me stuff > too, so we'll see. Let's talk and see what we come up with. Being an > artist, I can always clean on of these up or make our own. The > important > thing to me is to get something that really looks old. > > Sounds like we have an offer from a silkscreener to make screens > (thanks > Jake!) which is the best printing way to go as it'll outlast and stay > fresher than a heat transfer. The ultimate would be to have it > embroidered, > but I'll have to ck out the price on that, and it probably is way > overkill. > > Don, let me know if you want to order a few coveralls with me, and > anybody > else and let's put our heads together about a logo so we can get > something > done before flying season. > > Douwe > douweblumberg(at)earthlink.net > > > > > ________________________________________________________________________________
Date: Mar 03, 2010
We Piet builders will tar and feather any GN-1 driver with a Pietenpol logo. On Wed, Mar 3, 2010 at 4:45 PM, Mike King wrote: > Hey Guys, > > > The Piet logos are very nice and I am sure the talent on this list will > > offer a great logo for clothing and the plane alike. > > > My question is: Since we have both Piet and GN-1 builders and pilots > > on this list, would the Piet logo be welcomed on the GN-1? This was > > Bernard's design and concept and John Grega came along later with > > his revisions to the same concept. > > > If both parties are in agreement, then I would like to order a coverall > > and logo for my GN-1. > > > Thanks. > > Mike King > > 77Mk > > GN-1 > > Corpus Christi, Texas > > > ----- Original Message ----- > From: gboothe5(at)comcast.net > To: pietenpol-list(at)matronics.com > Sent: Tuesday, March 02, 2010 6:10 PM > Subject: Re: Pietenpol-List: logos, coveralls etc. > > I'm in, too. > > Gary Boothe > Sent from my Verizon Wireless BlackBerry > > -----Original Message----- > From: Roman Bukolt <conceptmodels(at)tds.net> > Date: Tue, 2 Mar 2010 15:13:29 > To: > Subject: Re: Pietenpol-List: logos, coveralls etc. > > > I'm interested, > Roman Bukolt NX20795 > On Mar 2, 2010, at 9:04 AM, Douwe Blumberg wrote: > >> > > >> >> Hey Don, >> >> Great minds think alike eh? >> >> I talked to my friend at Old Rhinebeck (owns the beautiful "626" >> that used >> to fly there) since they are really good at the period look. He >> directed me >> to Universal Overall company as the only place he could find old >> cotton >> coveralls. Ck out their site, they have cotton coveralls with hidden >> buttons. I'd have somebody put buttons down the front. They come >> in many >> colors, but White or unbleached probably would look great. >> >> I just got a pretty good old Mobilgas image that would certainly >> have that >> thirties look, and the kind folks from this site have been sending >> me stuff >> too, so we'll see. Let's talk and see what we come up with. Being an >> artist, I can always clean on of these up or make our own. The >> important >> thing to me is to get something that really looks old. >> >> Sounds like we have an offer from a silkscreener to make screens >> (thanks >> Jake!) which is the best printing way to go as it'll outlast and stay >> fresher than a heat transfer. The ultimate would be to have it >> embroidered, >> but I'll have to ck out the price on that, and it probably is way >> overkill. >> >> Don, let me know if you want to order a few coveralls with me, and >> anybody >> else and let's put our heads together about a logo so we can get >> something >> done before flying season. >> >> Douwe >> douweblumberg(at)earthlink.net >> >> >> >> >> > > > http://www.matnbsp; via the Web > href="http://forums.matronics.com">http://forums.matronics.com > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/c================ > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 03, 2010
Mike, I admire your desire to be sensitive to other's view of the world. And before I unload, let me say that I welcome the Piet logo on your GN-1. I agree with your reasoning: Bernard->Grega->Mike. But... Heck, Mike Cuy has an EASTERN (who's zoomin' who?) AIRLINES logo on his Pietenpol. D'ya think Frank Borman gave Mike permission to do that? Heck NO! Frank Borman only WISHES he was as cool and with it as Mike Cuy. And by extension, the rest of us on this h'yar list. Order away! Jeff >Hey Guys, > > >The Piet logos are very nice and I am sure the talent on this list will > >offer a great logo for clothing and the plane alike. > > >My question is: Since we have both Piet and GN-1 builders and pilots > >on this list, would the Piet logo be welcomed on the GN-1? This was > >Bernard's design and concept and John Grega came along later with > >his revisions to the same concept. > > >If both parties are in agreement, then I would like to order a coverall > >and logo for my GN-1. > > >Thanks. > >Mike King > >77Mk > >GN-1 > >Corpus Christi, Texas > > >----- Original Message ----- >From: <mailto:gboothe5(at)comcast.net>gboothe5(at)comcast.net >To: pietenpol-list(at)matronics.com >Sent: Tuesday, March 02, 2010 6:10 PM >Subject: Re: Pietenpol-List: logos, coveralls etc. > >gboothe5(at)comcast.net > >I'm in, too. > >Gary Boothe >Sent from my Verizon Wireless BlackBerry > >-----Original Message----- >From: Roman Bukolt <<mailto:conceptmodels(at)tds.net>conceptmodels(at)tds.net> >Date: Tue, 2 Mar 2010 15:13:29 >To: <pietenpol-list(at)matronics.com> >Subject: Re: Pietenpol-List: logos, coveralls etc. > ><conceptmodels(at)tds.net> > >I'm interested, >Roman Bukolt NX20795 >On Mar 2, 2010, at 9:04 AM, Douwe Blumberg wrote: > >><douweblumberg(at)earthlink.net >> > >> >> Hey Don, >> >> Great minds think alike eh? >> >> I talked to my friend at Old Rhinebeck (owns the beautiful "626" >> that used >> to fly there) since they are really good at the period look. He >> directed me >> to Universal Overall company as the only place he could find old >> cotton >> coveralls. Ck out their site, they have cotton coveralls with hidden >> buttons. I'd have somebody put buttons down the front. They come >> in many >> colors, but White or unbleached probably would look great. >> >> I just got a pretty good old Mobilgas image that would certainly >> have that >> thirties look, and the kind folks from this site have been sending >> me stuff >> too, so we'll see. Let's talk and see what we come up with. Being an >> artist, I can always clean on of these up or make our own. The >> important >> thing to me is to get something that really looks old. >> >> Sounds like we have an offer from a silkscreener to make screens >> (thanks >> Jake!) which is the best printing way to go as it'll outlast and stay >> fresher than a heat transfer. The ultimate would be to have it >> embroidered, >> but I'll have to ck out the price on that, and it probably is way >> overkill. >> >> Don, let me know if you want to order a few coveralls with me, and >> anybody >> else and let's put our heads together about a logo so we can get >> something >> done before flying season. >> >> Douwe >> douweblumberg(at)earthlink.net >> >> >> >> >> > > >http://www.matnbsp; via the Web >href="http://forums.matronics.com">http://forums.matronics.com >_p; generous bsp; >href="http://www.matronics.com/contribution">http://www.matronics.com/c================ > > ><http://www.matronics.com/Navigator?Pietenpol-List>http://www.matronics.com/Navigator?Pietenpol-List ><http://www.matronics.com/contribution>http://www.matronics.com/contribution -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Mar 03, 2010
Subject: Eastern and United issues
Yes sir, Jeff Boatright is correct in saying that I have an old (modified) Eastern Airlines logo on the sides of my fuselage but in American Airline colors !!!!!!!! You should see sometimes I'll get retired AA or EA pilots pointing that out to me. I usually tell them that I wanted to aggravate both demographics so I mixed the logo and colors just to accomplish that. And Jeff, I've got a connection with Frank Borman and he told me it was okay to use the old Eastern logo. He was a cast member with me in the documentary "The Restorers" a few years ago. Mike C. ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Small steps reaches small mile stone
It was nice when I made the change, (temporarily) from working with all woo d to some steel and welding.- Then it became obvious that I need to trans ition over to some cable work.- Over the past couple days, I have made 6 out of the 8 tail brace cables. I read the swager manual, set up the machin e and got to it. Very satisfying to be doing some rigging now! Of course it is all temporary as it will all have to come back apart, but it feels like I have made it to another small mile stone.- What took the longest for m e was getting the angle of the steel fittings on the tail bent so the angle would line up straight with the fork end and cable. The swaging itself is cake. - No big deal to those who have been there, all new and fun for me, so I thou ght I would share. ________________________________________________________________________________
Subject: good books
Date: Mar 04, 2010
Okay, so let's take the dimpletape and SR-71 subject lines away and consider books. I can highly recommend two: "Yeager- An Autobiography" by Chuck Yeager and Leo Janos. "Skunk Works: A Personal Memoir of My Years At Lockheed" by Ben Rich and Leo Janos. Both are very, very interesting reading for a pilot or experimenter. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 04, 2010
Thanks Jeff and others who responded. I would like to order a set or two (different colors) of the coveralls and a logo when available. There is a Piet.....complete with Ford engine and Air Camper logo.... at nearby Rockport Airport. It is a beautiful plane and we plan on flying around South Texas and along the Gulf Coast beachline soon. Thanks again guys.... Mike King 77MK GN-1 Corpus Christi, Texas -----Original Message----- From: Jeff Boatright Sent: Mar 3, 2010 8:36 PM Subject: Re: Pietenpol-List: logos, coveralls etc. Mike, I admire your desire to be sensitive to other's view of the world. And before I unload, let me say that I welcome the Piet logo on your GN-1. I agree with your reasoning: Bernard->Grega->Mike. But... Heck, Mike Cuy has an EASTERN (who's zoomin' who?) AIRLINES logo on his Pietenpol. D'ya think Frank Borman gave Mike permission to do that? Heck NO! Frank Borman only WISHES he was as cool and with it as Mike Cuy. And by extension, the rest of us on this h'yar list. Order away! Jeff Hey Guys, The Piet logos are very nice and I am sure the talent on this list will offer a great logo for clothing and the plane alike. My question is: Since we have both Piet and GN-1 builders and pilots on this list, would the Piet logo be welcomed on the GN-1? This was Bernard's design and concept and John Grega came along later with his revisions to the same concept. If both parties are in agreement, then I would like to order a coverall and logo for my GN-1. Thanks. Mike King 77Mk GN-1 Corpus Christi, Texas ----- Original Message ----- From: gboothe5(at)comcast.net Sent: Tuesday, March 02, 2010 6:10 PM Subject: Re: Pietenpol-List: logos, coveralls etc. I'm in, too. Gary Boothe Sent from my Verizon Wireless BlackBerry -----Original Message----- From: Roman Bukolt <conceptmodels(at)tds.net> Date: Tue, 2 Mar 2010 15:13:29 Subject: Re: Pietenpol-List: logos, coveralls etc. I'm interested, Roman Bukolt NX20795 On Mar 2, 2010, at 9:04 AM, Douwe Blumberg wrote: > > > > Hey Don, > > Great minds think alike eh? > > I talked to my friend at Old Rhinebeck (owns the beautiful "626" > that used > to fly there) since they are really good at the period look. He > directed me > to Universal Overall company as the only place he could find old > cotton > coveralls. Ck out their site, they have cotton coveralls with hidden > buttons. I'd have somebody put buttons down the front. They come > in many > colors, but White or unbleached probably would look great. > > I just got a pretty good old Mobilgas image that would certainly > have that > thirties look, and the kind folks from this site have been sending > me stuff > too, so we'll see. Let's talk and see what we come up with. Being an > artist, I can always clean on of these up or make our own. The > important > thing to me is to get something that really looks old. > > Sounds like we have an offer from a silkscreener to make screens > (thanks > Jake!) which is the best printing way to go as it'll outlast and stay > fresher than a heat transfer. The ultimate would be to have it > embroidered, > but I'll have to ck out the price on that, and it probably is way > overkill. > > Don, let me know if you want to order a few coveralls with me, and > anybody > else and let's put our heads together about a logo so we can get > something > done before flying season. > > Douwe > douweblumberg(at)earthlink.net > > http://www.matnbsp; via the Web href="http://forums.matronics.com">http://forums.matronics.com _p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c================ Pietenpol-List Email Forum - Un/Subscription,Archive Search & Download, 7-Day Browse, Chat, FAQ, href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > - MATRONICS WEB FORUMS - href="http://forums.matronics.com">http://forums.matronics.com - List Contribution Web Site - > -Matt Dralle, List Admin. href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Subject: Re: good books
Date: Mar 04, 2010
Here's a good list of aviation books.... http://www.vansairforce.com/community/showthread.php?t=11441&highlight=books David Paule Okay, so let's take the dimpletape and SR-71 subject lines away and consider books. I can highly recommend two: "Yeager- An Autobiography" by Chuck Yeager and Leo Janos. "Skunk Works: A Personal Memoir of My Years At Lockheed" by Ben Rich and Leo Janos. Both are very, very interesting reading for a pilot or experimenter. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Coveralls and Flitzer group-nice one Larry !
Date: Mar 04, 2010
Who needs a pith helmet when you've got the flying goggles? -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289221#289221 Attachments: http://forums.matronics.com//files/ap31g6_122.jpg ________________________________________________________________________________
Date: Mar 04, 2010
While on the subject of books, this Lindbergh book is excellent: http://www.amazon.com/Spirit-St-Louis-Charles-Lindbergh/dp/0743237056/ref=sr_1_2?ie=UTF8&s=books&qid=1267723015&sr=8-2 By Lindbergh himself, covers what it was like to fly the mail (yes they flew at night, middle of winter, with no radios of any kind and only a couple lanterns for runway lights), through the engineering and build of the aircraft (they considered detachable gear like the German Comet rocket plane). rick On Thu, Mar 4, 2010 at 9:47 AM, Oscar Zuniga wrote: > > > Okay, so let's take the dimpletape and SR-71 > subject lines away and consider books. I can > highly recommend two: > > "Yeager- An Autobiography" by Chuck Yeager and > Leo Janos. > > "Skunk Works: A Personal Memoir of My Years At > Lockheed" by Ben Rich and Leo Janos. > > Both are very, very interesting reading for a > pilot or experimenter. > > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Re: Small steps reaches small mile stone
I agree Mike, I really like learning how to work with the different materials. Have spent as much time on metal welding/grinding as I have on wood cutting/sanding/gluing. Soon you will get to learn sheet metal/aluminum cutting/bending/riveting for your fuel tank and cowling (and maybe some composite). And building an engine is a great learning experience too, especially when it runs and doesn't leak anything (yet). rick On Thu, Mar 4, 2010 at 8:47 AM, Michael Perez wrote: > It was nice when I made the change, (temporarily) from working with all > wood to some steel and welding. Then it became obvious that I need to > transition over to some cable work. Over the past couple days, I have made > 6 out of the 8 tail brace cables. I read the swager manual, set up the > machine and got to it. Very satisfying to be doing some rigging now! Of > course it is all temporary as it will all have to come back apart, but it > feels like I have made it to another small mile stone. What took the > longest for me was getting the angle of the steel fittings on the tail bent > so the angle would line up straight with the fork end and cable. The swaging > itself is cake. > > No big deal to those who have been there, all new and fun for me, so I > thought I would share. > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 04, 2010
I'm always amazed (after all, our love is reported to be low and slow flight in an open cockpit) that more aren't reading about low and slow flight in open cockpits. I love early aviation and the men & women that pioneered the way for us. Rescue flights in -40 below zero weather, between Alaska and Russia in open cockpit airplanes. Flying into areas where there were no maps or knowledge of what to expect. Crashes that pilots walked away from, only to have to walk hundreds of miles to get help. Others rebuilt their planes and props to fly them out to safety. I also love to read about Bush Pilots and their adventures. So much history. Just a few of the really good books. In The Shadow Of Eagles by Rudy Billberg (I have two of these, so if anyone wants to read it, I will send it to you, then you must send it on to someone else.) Heroes Of the Horizon by Gerry Bruder The Last Of The Bush Pilots by Harmon Helmericks Frank Barr, Bush Pilot in Alaska and the Yukon by Dermot Cole Mercy Pilot, The Joe Crosson Story by Dirk Tordoff MudHole Smith, Alaska Flier by Lone E. Janson (I use to work for MudHole in the early 60's. He was a real true Alaskan pioneer bushpilot) North Star Over My Shoulder By Bob Buck Bush Pilots, Legends of the Old & Bold By Bob Cary & Jack Hautala Wager With The Wind, the Don Sheldon Story by James Greiner Glacier Pilot, the Story of Bob Reeve and the Flyers who pushed back Alaska Air Frontiers by Beth Day Romulo Wings Over Alaska, The Story of Carl Ben Eielson By Edward A. Herron. If you like true war stories then I recommend the following about FAC (Forward air controllers)(low and slow) Pilots in Vietnam. A Lonely Kind of War by Marshall Harrison Vietnam Above the TreeTops by John F. Flanagan Gene in sunny beautiful Tennessee N502R ----- Original Message ----- From: "David Paule" <dpaule(at)frii.com> Sent: Thursday, March 04, 2010 9:09 AM Subject: Re: Pietenpol-List: good books > > Here's a good list of aviation books.... > > http://www.vansairforce.com/community/showthread.php?t=11441&highlight=books > > David Paule > > > Okay, so let's take the dimpletape and SR-71 > subject lines away and consider books. I can > highly recommend two: > > "Yeager- An Autobiography" by Chuck Yeager and > Leo Janos. > > "Skunk Works: A Personal Memoir of My Years At > Lockheed" by Ben Rich and Leo Janos. > > Both are very, very interesting reading for a > pilot or experimenter. > > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 19:34:00 ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Re: e-mail question
It's OK Tom, I'm really not that good at it and most people don't listen to me anyway. - But, as you see, your latest email came through as well. ________________________________________________________________________________
Date: Mar 04, 2010
Here's a short story by one of our ranks that I thoroughly enjoyed. You might, too: http://aviationstories-robbach.blogspot.com/2009/05/5339-by-rob-bach.html Cheers, Dan On 03/04/2010 11:36 AM, Gene & Tammy wrote: > > > I'm always amazed (after all, our love is reported to be low and slow > flight in an open cockpit) that more aren't reading about low and slow > flight in open cockpits. I love early aviation and the men & women that > pioneered the way for us. Rescue flights in -40 below zero weather, > between Alaska and Russia in open cockpit airplanes. Flying into areas > where there were no maps or knowledge of what to expect. Crashes that > pilots walked away from, only to have to walk hundreds of miles to get > help. Others rebuilt their planes and props to fly them out to safety. I > also love to read about Bush Pilots and their adventures. So much history. > Just a few of the really good books. > > In The Shadow Of Eagles by Rudy Billberg (I have two of these, so if > anyone wants to read it, I will send it to you, then you must send it on > to someone else.) > Heroes Of the Horizon by Gerry Bruder > The Last Of The Bush Pilots by Harmon Helmericks > Frank Barr, Bush Pilot in Alaska and the Yukon by Dermot Cole > Mercy Pilot, The Joe Crosson Story by Dirk Tordoff > MudHole Smith, Alaska Flier by Lone E. Janson (I use to work for MudHole > in the early 60's. He was a real true Alaskan pioneer bushpilot) > North Star Over My Shoulder By Bob Buck > Bush Pilots, Legends of the Old & Bold By Bob Cary & Jack Hautala > Wager With The Wind, the Don Sheldon Story by James Greiner > Glacier Pilot, the Story of Bob Reeve and the Flyers who pushed back > Alaska Air Frontiers by Beth Day Romulo > Wings Over Alaska, The Story of Carl Ben Eielson By Edward A. Herron. > If you like true war stories then I recommend the following about FAC > (Forward air controllers)(low and slow) Pilots in Vietnam. > A Lonely Kind of War by Marshall Harrison > Vietnam Above the TreeTops by John F. Flanagan > > Gene in sunny beautiful Tennessee > N502R > > > ----- Original Message ----- From: "David Paule" <dpaule(at)frii.com> > To: > Sent: Thursday, March 04, 2010 9:09 AM > Subject: Re: Pietenpol-List: good books > > >> >> Here's a good list of aviation books.... >> >> http://www.vansairforce.com/community/showthread.php?t=11441&highlight=books >> >> >> David Paule >> >> >> >> >> >> Okay, so let's take the dimpletape and SR-71 >> subject lines away and consider books. I can >> highly recommend two: >> >> "Yeager- An Autobiography" by Chuck Yeager and >> Leo Janos. >> >> "Skunk Works: A Personal Memoir of My Years At >> Lockheed" by Ben Rich and Leo Janos. >> >> Both are very, very interesting reading for a >> pilot or experimenter. >> >> >> Oscar Zuniga >> Air Camper NX41CC >> San Antonio, TX >> mailto: taildrags(at)hotmail.com >> website at http://www.flysquirrel.net >> >> >> >> >> >> >> >> >> > > > -------------------------------------------------------------------------------- > > > Checked by AVG - www.avg.com > 19:34:00 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 04, 2010
Subject: e-mail question
Same here Mike. I rec'd Tom's e-mail but didn't catch much wit or wisdom. Tom, you just give us a warning when that is coming so we can keep an eye out for it. Very much kidding and in good fun. Mike C. Hmmm...I wonder if Amazon sells pith helmets ? ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Top vert.cable fitting.
As we know the brace cables for the vert. stab. come together at the top to one fitting attached to the trailing edge. It appears that I have some twi st on the vert. stab. if I grab the leading edge of it and push/pull side t o side. Any harm in relocating the forward-two cables to the leading edge ? ________________________________________________________________________________
Subject: Re: Top vert.cable fitting.
Date: Mar 04, 2010
You mean like this: http://www.flysquirrel.net/piets/tail01.jpg -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289251#289251 ________________________________________________________________________________
Subject: Gear Springs
Date: Mar 04, 2010
After talking with Hans, I've decided the springs to order are the same as he used, Die Max 9-3224-36. AC Spruce has a pair for $90. H & O Die Supply (800-222-5441) sells them for $67.00 a pair. Jack DSM ________________________________________________________________________________
Date: Mar 04, 2010
Subject: vertical stabilizer fitting location
Mike, I would leave your vertical tail fitting/ cable location right where the pl ans show it and not worry about the twist until you have allowed for change of season/ spring/ summer humidity to come to Ohio, then until a fter you varnish and cover with fabric unless the twist is really noticeable in which case I would simply build a new one. You will be able to take twist out during the fabric taughtening process to by playing the iron over one side at a higher temp than the other as you go thru the three increasing iron temperature stages for the Dacron tightening. Those cables stabilize the hinge line right at the top hinge so when you bo ot the rudder that back edge of your vertical stab is held very firmly. If you grab your stab by the LE when you boot the rudder you' ll have the "guy wires" ahead of the place where all the rudder force is being transferred to the stab. Lastly, if you look at the brace wires/ rods on Piper Cubs or Aeronca Cham ps, Aeronca Sedans, Taylorcrafts, Porterfields, Ryan PT's, Fairchilds.......every one of them uses the hinge line edge of the vertical stab to secure the wires. Mike C. ________________________________________________________________________________
From: "Paul N. Peckham" <peckham9(at)countryspeed.com>
Date: Mar 04, 2010
A few favorites of mine would be Nothing by Chance & Biplane by Richard Bach. If you haven't read Nothing by Chance, it was a barnstorming story that took place in southern Wisconsin and northern Illinois, and no, Bach did not fly into Brodhead. Go figure. Flight of Passage by Rinker Buck is another one that is really a hoot to read. Lastly, Budd Davisson's 2 books, The Stonewall File, and Cobalt Blue will definitely keep you up at night. Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289258#289258 ________________________________________________________________________________
Date: Mar 04, 2010
Yes, like that!- - ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Re: vertical stabilizer fitting location
I'm not sure we are on the same page Mike.- My Vert. stab. is not twisted .- What I am saying is that now that I have it all bolted to the fuse and have my newly made brace cables in place, everything seems solid...except for when I grab the leading edge of the vert. and push sideways on it, then it flexes/twists.- I am not going to move that top cable fitting, only t he front cables off of that fitting-over to a fitting on the leading edge .- Oscar sent a link to a picture of exactly what I am talking about. (bu t with cables)- This will negate the twist. But I am curious if it is NOT a good idea for a reason I am not seeing.- - I would think this would stabilize the tail better and may cut/eliminate th e "flopping around" you guys see when you look back there in flight. Thanks Mike. ________________________________________________________________________________
Date: Mar 04, 2010
How about " West with the Night" Beryl Markham , A great pilot with many records IE. First to woman to cross the Atlantic solo, East to West, and incredible flying in Africa. She also has an autobiography, She was also referred to in the movie" Out of Africa". Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289268#289268 ________________________________________________________________________________
Subject: Good books
Date: Mar 04, 2010
Hi Guys, There is a really good story, of a local nature, that I was totally oblivi ous to until a few years back. There was a man, from Rockford IL., "Fish" Hassel was his name. He was hired by Glenn Curtis as a car mechanic. He went on to get his pilot's licence and was a real charactor, barnstorming and booze-running to Canada during prohibition in the subsequent years. He wrote a book about his life entitled "A Viking With Wings". He wanted to establish the viability of a great-circle air route to Scandinavia in 1927. Here is an excerpt that summarizes this: The people of Rockford, Illinois became interested and decided to back his scheme. A Stinson Detroiter monoplane was obtained and planning of th e flight began. As his co-pilot and navigator, Hassell selected Parker "Sh orty" Cramer, and together they began making test flights in the vicinity of Rockford. (This was actually the old Mechesney Park Airport) They set the date for the take-off as July 26, 1928. When the appointed time arriv ed, they took off with the crowd cheering. But the fuel load proved too he avy and they wound up in a corn field west of the river. (Rock River) After repairing the plane, they again took off on August 16, 1928 and headed for their first scheduled refueling stop, a base on the Sondre Str omfjord in south-west Greenland. After twenty hours in the air, they faile d to find the base and were forced to make an emergency landing. The two adventurers set out to walk to the base. Fourteen days later, they encoun tered a group of Eskimos who brought them into the camp, just as they were about to be given up for lost. From the base, they worked their way to Holstenborg, on the coast whe re they got passage on a tramp steamer to Europe. From there, they made th eir way back to the United States and Rockford. Hassel went on to serve in WWII, establishing the all-important air base in Goose Bay, Greenland. The aircraft that was abandoned on the glacier in 1928, was eventually rec overed, flown back to Rockford IL. in a DC-3, restored, and is on display at the Midway Village Museum here in Rockford, IL. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Good books
Date: Mar 04, 2010
Oh, for the days of wooden airplanes and iron men. _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Thursday, March 04, 2010 4:49 PM Subject: Pietenpol-List: Good books Hi Guys, There is a really good story, of a local nature, that I was totally oblivious to until a few years back. There was a man, from Rockford IL., "Fish" Hassel was his name. He was hired by Glenn Curtis as a car mechanic. He went on to get his pilot's licence and was a real charactor, barnstorming and booze-running to Canada during prohibition in the subsequent years. He wrote a book about his life entitled "A Viking With Wings". He wanted to establish the viability of a great-circle air route to Scandinavia in 1927. Here is an excerpt that summarizes this: The people of Rockford, Illinois became interested and decided to back his scheme. A Stinson Detroiter monoplane was obtained and planning of the flight began. As his co-pilot and navigator, Hassell selected <http://earlyaviators.com/ecramer.htm> Parker "Shorty" Cramer, and together they began making test flights in the vicinity of Rockford. (This was actually the old Mechesney Park Airport) They set the date for the take-off as July 26, 1928. When the appointed time arrived, they took off with the crowd cheering. But the fuel load proved too heavy and they wound up in a corn field west of the river. (Rock River) After repairing the plane, they again took off on August 16, 1928 and headed for their first scheduled refueling stop, a base on the Sondre Stromfjord in south-west Greenland. After twenty hours in the air, they failed to find the base and were forced to make an emergency landing. The two adventurers set out to walk to the base. Fourteen days later, they encountered a group of Eskimos who brought them into the camp, just as they were about to be given up for lost. From the base, they worked their way to Holstenborg, on the coast where they got passage on a tramp steamer to Europe. From there, they made their way back to the United States and Rockford. Hassel went on to serve in WWII, establishing the all-important air base in Goose Bay, Greenland. The aircraft that was abandoned on the glacier in 1928, was eventually recovered, flown back to Rockford IL. in a DC-3, restored, and is on display at the Midway Village Museum here in Rockford, IL. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Mar 04, 2010
You beat me to it. That IS a good book. > >How about " West with the Night" Beryl Markham , A great pilot with >many records IE. First to woman to cross the Atlantic solo, East to >West, and incredible flying in Africa. She also has an >autobiography, She was also referred to in the movie" Out of Africa". >Pieti Lowell > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 04, 2010
Another good one is "Record Flights" by Chamberlin. Also "Building Aeroplanes for The Magnificent Men and Their Flying Machines" by Wheeler. David Paule ----- Original Message ----- From: "Jeff Boatright" <jboatri(at)emory.edu> Sent: Thursday, March 04, 2010 7:27 PM Subject: Re: Pietenpol-List: Re: good books > > You beat me to it. That IS a good book. > >> >> >>How about " West with the Night" Beryl Markham , A great pilot with many >>records IE. First to woman to cross the Atlantic solo, East to West, and >>incredible flying in Africa. She also has an autobiography, She was also >>referred to in the movie" Out of Africa". >>Pieti Lowell >> > > > -- > > Jeff Boatright > "Now let's think about this..." > > > ________________________________________________________________________________
Subject: Re: Just Hello
Date: Mar 04, 2010
HI Matt, Welcome to the list, and Pietenpol country. If you know where Crawdaddy Landing , ( 3KY4 ) is, Douwe Blumberg will have a FIRST flight with his newly completed Ford powered Piet around the end of this month, keep informed You are not far from Carrollton Ky, His Pietenpol is a work of art from my point of view, and has some neet new innovations. Pieti Lowell ] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289287#289287 ________________________________________________________________________________
Date: Mar 04, 2010
Your local beekeeper supply probably does. Poor Mike. Shot down in flames! :-) I feel for you buddy. You should arrive at Broadhead with one of these. That'll fix em! http://www.kcdawnpatrol.org/machine-gun.htm Mike C. Hmmm.I wonder if Amazon sells pith helmets ? ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/04/10 11:34:00 ________________________________________________________________________________
Date: Mar 05, 2010
Subject: vertical stab flexible at front end
Mike, You write: "now that I have it all bolted to the >fuse and have my newly made brace cables in place, everything seems >solid...except for when I grab the leading edge of the vert. and push >sideways on it, then it flexes/twists." Mike-- simple solution. Don't push on it. Not trying to be smart but seriously, many parts of the plane flex and are meant to like wings on an airliner flex way up under flight loads and move around in turbulence. The photo Oscar shows is fully acceptable but isn't the norm and might be a GN-1 tail from the looks of the wide gaps and eye bolt hinge types (as found on GN-1's) Much of the structure will tighten up greatly after fabric and paint have been applied too. Also if you go with the two-fitting location on the vertical fin you'll have two fittings more, two more bolts, nuts and washers that you don't need as well. Just my thoughts. Either installation is totally acceptable though. I simply wouldn't worry the flex. Hundreds of Piets are flying with the single, rearward attach point to the fin with no problems. Mike C. ________________________________________________________________________________
Date: Mar 05, 2010
Subject: Re: vertical stab flexible at front end
I wondered about how the fabric would help. Since I have not done any fabri c work, I just didn't know.- You know me...I save weight every place I ca n and I did think about the added brackets, bolts, nuts, etc.! - "Mike-- simple solution.- Don't push on it."- I laughed when I read thi s...sounds like something I would say.-- - I guess since I already have my cables all made and I would need to buy mor e terminal ends and make new shorter cables if I moved the front ones, I'll leave it.- I may add the spacer/plywood in the location of where that fr ont fitting would go, then after-covering and flying,-if I wanted to ch ange the cables, I would just need to drill the holes and make the fittings . - - ________________________________________________________________________________
Subject: Howard Henderson's Piet
Date: Mar 05, 2010
Mike King wrote- >There is a Piet.....complete with Ford engine >and Air Camper logo.... at nearby Rockport Airport. >It is a beautiful plane and we plan on flying >around South Texas and along the Gulf Coast >beachline soon. Yes, that is Ron Hollmer's Ford A-powered Piet, also known as Howard Henderson's Piet since he built it. N444MH. Some excellent pix of the airplane at www.westcoastpiet.com (of course). Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 05, 2010
Not to get nit-picky (well, maybe I am) but, the the air base in Goose Bay is actually in Labrador, not Greenland. Now, since I retrieved this bit of information about Labrador, does that make me an "information about Labrador retriever"? Dan wrote: Hassel went on to serve in WWII, establishing the all-important air base in Goose Bay, Greenland. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289311#289311 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Mar 05, 2010
I would suggest that you seek out some of the little books written by local aviators. For example Jimmy Hays was an Oklahoma Farmer who wrote a small Magazine sized book about his experiences. He helped establish the flying farmers organization and was very active in various organizations. He was in early air races with Jimmy Dolittle and others of similar fame. His book is a great read. One of my favorite stories is his prop coming to pieces during an air race. He put the plane in a field, pulled the prop and got a ride to the finish line, arriving with the prop on his shoulder. Jimmy Dolittle beat him that time. These books are often hard to find. Besides who knows what is out there. But they often have great stories. Blue Skies, Steve D ----- Original Message ----- From: Bill Church <billspiet(at)sympatico.ca> Date: Friday, March 5, 2010 8:11 Subject: Pietenpol-List: Re: good books > > Not to get nit-picky (well, maybe I am) but, the the air base in Goose Bay is actually in Labrador, not Greenland. > > Now, since I retrieved this bit of information about Labrador, does that make me an "information about Labrador retriever"? > > Dan wrote: > > Hassel went on to serve in WWII, establishing the all-important air base in Goose Bay, Greenland. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289311#289311 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 05, 2010
Gee... nobody picked up on the fact that the photo I posted was of Irene Englund, a Texan who was a WASP in WWII, flew the B-24, and was still flying in her 80s... http://www.arlingtoncemetery.net/ikenglund.htm Wooden airplanes, iron men... and women with wings! -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289324#289324 ________________________________________________________________________________
Date: Mar 05, 2010
Is that Big Jim's Piet by any chance? Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289338#289338 ________________________________________________________________________________
Subject: Construction Photos
Date: Mar 05, 2010
Hi - I haven't been able to get ahold of the (sainted) west coast piet webmaster to post construction photos of NX899KP. The Girl taught me how to post photos on a google blog. Here's the link: http://nx899kp.blogspot.com/ I'll continue to add pictures as I can. If I have any notes I put them as comments. Best regards, Kevin Purtee NX899KP Austin/Georgetown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289353#289353 ________________________________________________________________________________
Date: Mar 05, 2010
Pieti that sounds great! I'm super busy right now with trying to buy a house and all, i think all the signing im having to do is giving me carpel tunnel! Don, Yep it sure, is. Big Jim, known as Grandpa to me lol. I'm getting a house with a barn just big enough to rebuild it in, and it definetly needs the attention, so once the house is settled into i plan on starting into it pretty quick! Right now I am living in Cincinnati ohio, and moving to Troy, Ohio (Old Waco Factory area) first of next month if all goes well. And i can not wait to get started! Hoping the weather holds out for Tuesday so I can get the ole TCraft out and knock the cobwebs off! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289357#289357 ________________________________________________________________________________
Date: Mar 05, 2010
It always amazes me to read the life story of incredible people like this, and saddened to see them pass. Thanks Oscar for the info. Lorin Miller fyi - watched a good "bogie and bacall" movie last night from 1944 (To Have and Have Not). That, was acting. taildrags wrote: > Gee... nobody picked up on the fact that the photo I posted was of Irene Englund, a Texan who was a WASP in WWII, flew the B-24, and was still flying in her 80s... > > http://www.arlingtoncemetery.net/ikenglund.htm > > Wooden airplanes, iron men... and women with wings! -------- Lorin Miller Waiex N81YX Pietenpol next up Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289363#289363 ________________________________________________________________________________
Subject: First Major Milestone
Date: Mar 05, 2010
I'm not sure if this is actually a milestone, but I'm feeling pretty good about it. I took my left wing panel off the jig today and trial fit the aileron. Today was one of the first really nice days we have had in a long time, so I took my wing panel outside and set it on saw horses so I could look it over in the sun light. It all looks good so far. I still need to install control pulleys and LE sheeting, but the framework is complete. We measured the dimensions (front to rear spar - tip to root) and found that there is less than 1/8" difference in the measurements. I was told that is pretty good. I also wanted to check my jig with the water level before to starting the right wing panel... it hasn't moved since we locked it down, prior to starting assembly on the let panel. Here are a few photos. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289365#289365 Attachments: http://forums.matronics.com//files/p3050408_768x576_159.jpg http://forums.matronics.com//files/p3050410_768x576_118.jpg http://forums.matronics.com//files/p3050412_768x576_128.jpg http://forums.matronics.com//files/p3050413_768x576_133.jpg http://forums.matronics.com//files/p3050415_768x576_123.jpg ________________________________________________________________________________
Subject: Re: First Major Milestone
Date: Mar 06, 2010
Mark, Anytime you are proud of your work, and need to stand back and look, it's a milestone. Very nice work. It must be great to get it out into the ligh t. Keep plugging! Dan Helsper Poplar Grove, IL. -----Original Message----- From: K5YAC <hangar10(at)cox.net> Sent: Fri, Mar 5, 2010 10:41 pm Subject: Pietenpol-List: First Major Milestone I'm not sure if this is actually a milestone, but I'm feeling pretty good about t. I took my left wing panel off the jig today and trial fit the aileron. oday was one of the first really nice days we have had in a long time, so I ook my wing panel outside and set it on saw horses so I could look it over in he sun light. It all looks good so far. I still need to install control ulleys and LE sheeting, but the framework is complete. We measured the dimensions (front to rear spar - tip to root) and found th at here is less than 1/8" difference in the measurements. I was told that is retty good. I also wanted to check my jig with the water level before to starting the right ing panel... it hasn't moved since we locked it down, prior to starting ssembly on the let panel. Here are a few photos. -------- ark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289365#289365 ttachments: http://forums.matronics.com//files/p3050408_768x576_159.jpg ttp://forums.matronics.com//files/p3050410_768x576_118.jpg ttp://forums.matronics.com//files/p3050412_768x576_128.jpg ttp://forums.matronics.com//files/p3050413_768x576_133.jpg ttp://forums.matronics.com//files/p3050415_768x576_123.jpg -======================== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Mar 06, 2010
Great shots and comments Kevin, thank you! Jack DSM Hi - I haven't been able to get ahold of the (sainted) west coast piet webmaster to post construction photos of NX899KP. The Girl taught me how to post photos on a google blog. Here's the link: http://nx899kp.blogspot.com/ I'll continue to add pictures as I can. If I have any notes I put them as comments. Best regards, Kevin Purtee NX899KP Austin/Georgetown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289353#289353 ________________________________________________________________________________
Date: Mar 06, 2010
It IS a milestone....you SHOULD feel pretty good about it....wow, this is great! I got to spend the nice weather yesterday spreading gravel on my (800'+) driveway and trying to get a 1951 tractor running (no spark...still!). Looks like YOU had a LOT more fun!!! Nice work Mark! -----Original Message----- >From: K5YAC <hangar10(at)cox.net> >Sent: Mar 5, 2010 10:41 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: First Major Milestone > > >I'm not sure if this is actually a milestone, but I'm feeling pretty good about it. I took my left wing panel off the jig today and trial fit the aileron. Today was one of the first really nice days we have had in a long time, so I took my wing panel outside and set it on saw horses so I could look it over in the sun light. It all looks good so far. I still need to install control pulleys and LE sheeting, but the framework is complete. > >We measured the dimensions (front to rear spar - tip to root) and found that there is less than 1/8" difference in the measurements. I was told that is pretty good. > >I also wanted to check my jig with the water level before to starting the right wing panel... it hasn't moved since we locked it down, prior to starting assembly on the let panel. > >Here are a few photos. > >-------- >Mark - working on wings > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=289365#289365 > > >Attachments: > >http://forums.matronics.com//files/p3050408_768x576_159.jpg >http://forums.matronics.com//files/p3050410_768x576_118.jpg >http://forums.matronics.com//files/p3050412_768x576_128.jpg >http://forums.matronics.com//files/p3050413_768x576_133.jpg >http://forums.matronics.com//files/p3050415_768x576_123.jpg > > ________________________________________________________________________________
Date: Mar 06, 2010
Nice pics, Mark, thanks! I am still a big fan of your wing building jig. That'll work great for me and my cramped work area. How about posting some more in-process pics? Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of K5YAC Sent: Friday, March 05, 2010 8:41 PM Subject: Pietenpol-List: First Major Milestone I'm not sure if this is actually a milestone, but I'm feeling pretty good about it. I took my left wing panel off the jig today and trial fit the aileron. Today was one of the first really nice days we have had in a long time, so I took my wing panel outside and set it on saw horses so I could look it over in the sun light. It all looks good so far. I still need to install control pulleys and LE sheeting, but the framework is complete. We measured the dimensions (front to rear spar - tip to root) and found that there is less than 1/8" difference in the measurements. I was told that is pretty good. I also wanted to check my jig with the water level before to starting the right wing panel... it hasn't moved since we locked it down, prior to starting assembly on the let panel. Here are a few photos. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289365#289365 Attachments: http://forums.matronics.com//files/p3050408_768x576_159.jpg http://forums.matronics.com//files/p3050410_768x576_118.jpg http://forums.matronics.com//files/p3050412_768x576_128.jpg http://forums.matronics.com//files/p3050413_768x576_133.jpg http://forums.matronics.com//files/p3050415_768x576_123.jpg ________________________________________________________________________________
Date: Mar 06, 2010
Mark, Thanks for the pix. It all looks great. If you have them, I would like some more details, please. I'd like to see pix-- both a side view and a top view of the wing tip bow and the curved aileron tip, and how they line up and look together. Perhaps your build is not quite there yet-- the tips. In any event, I continue to have trouble visualizing exactly how that goes together. I should have taken a stepladder and a closeup lens to Brodhead in 2006 or 2008. Thanks, Tim in central TX -----Original Message----- >From: K5YAC <hangar10(at)cox.net> >Sent: Mar 5, 2010 10:41 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: First Major Milestone > > >I'm not sure if this is actually a milestone, but I'm feeling pretty good about it. I took my left wing panel off the jig today and trial fit the aileron. Today was one of the first really nice days we have had in a long time, so I took my wing panel outside and set it on saw horses so I could look it over in the sun light. It all looks good so far. I still need to install control pulleys and LE sheeting, but the framework is complete. > >We measured the dimensions (front to rear spar - tip to root) and found that there is less than 1/8" difference in the measurements. I was told that is pretty good. > >I also wanted to check my jig with the water level before to starting the right wing panel... it hasn't moved since we locked it down, prior to starting assembly on the let panel. > >Here are a few photos. > >-------- >Mark - working on wings > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=289365#289365 > > >Attachments: > >http://forums.matronics.com//files/p3050408_768x576_159.jpg >http://forums.matronics.com//files/p3050410_768x576_118.jpg >http://forums.matronics.com//files/p3050412_768x576_128.jpg >http://forums.matronics.com//files/p3050413_768x576_133.jpg >http://forums.matronics.com//files/p3050415_768x576_123.jpg > > ________________________________________________________________________________
Date: Mar 06, 2010
Thanks for the nice comments fellas. For those that want to see most of my build photos... you can go to my logbook site (posted below in my signature). I've tried to keep it current and relevant to the project, but there are a few "shop" entries that pertain to equipment and such. For those that may not be familiar with mykitlog.com, just click on the link below and when you get to my main page click the ALL link on the right side menu. That will display all of my entries since I've started my project and you can quickly browse for titles and which ones have photos. I do have larger photos available for anyone that is interested in specific details. Perhaps Chris would let me post some of my photos on West Coast Piet? Maybe I'll shoot him a note tonight. Gary, I got the idea for the vertical wing jig from Tony Bingelis' "Sportplane Construction Techniques" (pg. 57). It was super easy to build, and if you have a solid work bench to clamp them to (see my photo above), you won't have to anchor them to the ceiling. I used a water level and shims to get mine leveled up and it is working great. Even if space isn't an issue, I think the vertical configuration allows better access to the entire wing panel. I could be wrong... won't know until I try the other methods. Time to make sawdust! -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289379#289379 ________________________________________________________________________________
Subject: Wood
Date: Mar 06, 2010
I just ordered my plans for my pietenpol. Who do most of you order your wood from? ________________________________________________________________________________
Subject: Wood
Date: Mar 06, 2010
I got most of mine from Wicks Aircraft Supply http://www.wicksaircraft.com/ , and some from Aircraft Spruce and Specialty http://www.aircraftspruce.com/ Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of William Colleran Sent: Saturday, March 06, 2010 1:07 PM Subject: Pietenpol-List: Wood I just ordered my plans for my pietenpol. Who do most of you order your wood from?
February 25, 2010 - March 06, 2010
Pietenpol-Archive.digest.vol-ix
