Pietenpol-Archive.digest.vol-iz
March 18, 2010 - March 27, 2010
      Jon Coxwell
      GN-1 Builder
      Recycle and preserve the planet
      http://forums.matronics.com/viewtopic.php?p=290771#290771
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: Bending aluminum tubing
Date: Mar 18, 2010
Good People, I was wondering about what alloy to use for my aluminum Pitot tubes. I have some 1/4 inch 3003 - .035", but that seems too easy to bend. I was thinking about 6061T6, but was concerned about how easy it would be to put in the 90 deg bends even with using a tubing bender and packing the tube with sand. Does any have any experience with 6061 or 5052? Those that made your own pitot tubes, what did you use and how have they held up to the casual knock and bump? I off in a few minutes to see a friends corvair project for his piet. Its going to be in the 60's here in Indiana and in the 70' tomorrow - with snow this weekend. Rick Schreiber, Valparaios, In Richard Schreiber lmforge(at)earthlink.net Why Wait? Move to EarthLink. ________________________________________________________________________________
Subject: Re: GN-1 cabane length
Date: Mar 18, 2010
OK, I did my measuring. I did a little more looking on the web and found that the recommended angle of incidence for the Pietenpol wing is 3 degrees. I am assuming it is the same for the GN-1 wing. From posts I read this allows for some washout on the tips. As I remember from Broadhead this summer the washout makes the Piet a much better flying bird. I struck a chalk line from the trailing edge to the center of the curve on the leading edge to get the chord line. The chord line is at an angle of 1.83 degrees to a line through the center of the mounting holes for the cabane struts. To get to the recommended 3 degrees I will need to lengthen my front cabanes by 5/8" to get 3 degrees. Probably the easiest is to weld another tube for the attach bolt on top of the existing attach point and a new saddle strap over the top. The fix will be tell tale at any gatherings but then I am not building a show plane and it seems like a lot less work than cutting the strut and lengthening it. Thanks for your comments -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290778#290778 ________________________________________________________________________________
Subject: Re: Bending aluminum tubing
Date: Mar 18, 2010
test walt evans NX140DL ----- Original Message ----- From: Richard Schreiber To: pietenpol-list Sent: Thursday, March 18, 2010 1:30 PM Subject: Pietenpol-List: Bending aluminum tubing Good People, I was wondering about what alloy to use for my aluminum Pitot tubes. I have some 1/4 inch 3003 - .035", but that seems too easy to bend. I was thinking about 6061T6, but was concerned about how easy it would be to put in the 90 deg bends even with using a tubing bender and packing the tube with sand. Does any have any experience with 6061 or 5052? Those that made your own pitot tubes, what did you use and how have they held up to the casual knock and bump? I off in a few minutes to see a friends corvair project for his piet. Its going to be in the 60's here in Indiana and in the 70' tomorrow - with snow this weekend. Rick Schreiber, Valparaios, In Richard Schreiber lmforge(at)earthlink.net Why Wait? Move to EarthLink. ________________________________________________________________________________
Subject: Re: covering
Date: Mar 18, 2010
Like Jack I used the Poly fiber manual and video. Worked great and actually was fun once I got the hang of it. Started with the tail pieces since they are easy to do--Jim Lagowski in slowly warming up N. Michigan ----- Original Message ----- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Wednesday, March 17, 2010 9:26 PM Subject: RE: Pietenpol-List: covering > > > Worked for me. I followed the PolyFiber manual and found it worked well > and > fabric work was one of the most enjoyable parts of building the airplane. > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick > Holland > Sent: Wednesday, March 17, 2010 7:10 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: covering > > > While on the subject of fuselage covering, did the Bingelis method > work for you guys? 4 pieces, bottom first, then each side, then back > turtle deck? > > rick > > On Wed, Mar 17, 2010 at 2:00 PM, Jeff Boatright wrote: >> >> Rick, >> >> I think you're smart to do this. >> >> Jeff >> >> >>> >>> I have decided to just pull everything off the firewall and glue the >>> fabric to the firewall, whats an extra couple hours on a five years >>> project? >>> >>> rick >>> >>> On Wed, Mar 17, 2010 at 1:16 AM, Clif Dawson >>> wrote: >>>> >>>> >>>> >>>> Well, I hadn't thought about it a lot. A few times in >>>> passing as I was doing other things. I think I can wedge >>>> the edges foreward enough to stuff some glue and an >>>> inch or so of fabric in there. There's 1/8" of fibrefrax >>>> that can be pushed aside and the only places close to >>>> the edges that are bolted down are the four engine >>>> mount bolts. If worse comes to worse one could >>>> wrap a thin strip of aluminum around it and screw >>>> it down. Also I expect an inch of cowling will be >>>> over it as well. >>>> I'll work it out. With a pencil. Like my constipated >>>> accountant. >>>> Now you know why pencils have brown erasers. :-) >>>> >>>> Clif >>>> "I am always doing things I can't do, that's how I get to do them. " ~ >>>> Pablo >>>> Picasso >>>>> >>>>> Great question, I am also ready to remove my engine and start fuselage >>>>> covering. Would be easier to not unbolt all that stuff from the >>>>> firewall and remove the stainless firewall cover and wiring. >>>> >>>> rick >>>>>> >>>>>> Clif, >>>>>> Just wondering...are you going to remove all the engine stuff and >>>>>> firewall to get a wrap-around on your fabric? >>>>>> Gary Boothe >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> -- >>> Rick Holland >>> Castle Rock, Colorado >>> >>> "Logic is a wreath of pretty flowers, that smell bad" >>> >>> >> >> >> >> >> >> >> > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > > > ________________________________________________________________________________
Date: Mar 18, 2010
Subject: West coast Pietenpol Meet
For those on the west coast, or going to be on the west coast during this June we are having a Pietenpol meet on June 5, 2010. Charlie Miller is hosting us at Frazier Lake Airpark (1C9) which is a beautiful grass strip in California. I sent out informational fliers this past week to those in California that I know about, but I'm sure there are other builders/owners who lurk. We already have a couple Pietenpols that have committed to be there. It will be a fun day of looking at and talking Pietenpols! I'll try to attach the flier as a pdf. Thanks, Mike Groah Tulare CA Still building! ________________________________________________________________________________
Subject: Re: A GN-1 Air Camper with a 2000cc Volkswagen engine
Date: Mar 18, 2010
Hey, Nice colors! walt evans NX140DL ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Thursday, March 18, 2010 7:51 AM Subject: Pietenpol-List: A GN-1 Air Camper with a 2000cc Volkswagen engine I wonder if this airplane has flown yet ? My guess is that it would be a single seater for all practical purposes but who knows. I e-mailed the person who posted this asking if it has flown yet. Will report back if I hear anything. Mike C. http://www.youtube.com/watch?v=Zd0OtA9Du-k ________________________________________________________________________________
Date: Mar 18, 2010
Rick I purchased two telescoping aluminum tubes and plan on installing a "disposable" pitot tube in the wing leading edge, gluing the larger tube in the LE with flexible tubing attached at the rear and the smaller tube press-fit into it. After the first moron bangs his head on it and bends it (me, of course) I just pull it out and shove in a new piece of tubing. rick On Thu, Mar 18, 2010 at 11:30 AM, Richard Schreiber wrote: > Good People, > > I was wondering about what alloy to use for my aluminum Pitot tubes. I have > some 1/4 inch 3003 - .035", but that seemstooeasy to bend. I was > thinking about 6061T6, but was concerned about how easy it would be to put > in the 90 deg bends even with using a tubing bender and packing the tube > with sand. Does any have any experience with 6061 or 5052? Those that made > your own pitot tubes, what did you use and how have they held up to the > casual knock and bump? > > I off in a few minutes to see a friends corvair project for his piet. Its > going to be in the 60's here in Indiana and in the 70' tomorrow - with snow > this weekend. > > Rick Schreiber, > Valparaios, In > > > Richard Schreiber > lmforge(at)earthlink.net > Why Wait? Move to EarthLink. > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Mar 18, 2010
I silver soldered a lug to a brass 1/4" tubing ELL and mounted it to the front spar with the bottom flush with the fabric. and tubed the wing with nylon tubing. I am thinking if I can get some brass to just bend the pitot tube from I'd use that. otherwise copper. it is soft and bends easily but I think it will be easy to straighten if damaged and easy to replace plus it might look kinda natural on an old bird. 8 inches or so won't weigh enough more than aluminum to even notice. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290789#290789 ________________________________________________________________________________
Date: Mar 18, 2010
I've had some experience with 6061. With a Fisher 404, used alot of it. It was 6061-T6 (pretty sure of the T6 hardness) This was shown by my mentor. Turn on an acy. torch with just the gas for a sooty yellow flame. Float the soot over the area that you want to soften, and coat it with black soot. Now here's the tricky part. Add the oxy to get a regular neutral flame. Now float the flame over the soot to erase the soot. If you linger in one spot too long, the tube melts. But if you keep it moving, with practice, you can erase all the soot. Let it cool in still air. Now all the hardness is gone and its soft like taffy. You use this if you are going to flatten a round tube, to make an end to be drilled. Now bend or flatten, or do what you have to do. When done set it aside, and in awhile (If I remember right, about 2 to 3 months) It will "age" back to a T6. Pretty amazing. walt evans NX140DL ----- Original Message ----- From: Richard Schreiber To: pietenpol-list Sent: Thursday, March 18, 2010 1:30 PM Subject: Pietenpol-List: Bending aluminum tubing Good People, I was wondering about what alloy to use for my aluminum Pitot tubes. I have some 1/4 inch 3003 - .035", but that seems too easy to bend. I was thinking about 6061T6, but was concerned about how easy it would be to put in the 90 deg bends even with using a tubing bender and packing the tube with sand. Does any have any experience with 6061 or 5052? Those that made your own pitot tubes, what did you use and how have they held up to the casual knock and bump? I off in a few minutes to see a friends corvair project for his piet. Its going to be in the 60's here in Indiana and in the 70' tomorrow - with snow this weekend. Rick Schreiber, Valparaios, In Richard Schreiber lmforge(at)earthlink.net Why Wait? Move to EarthLink. ________________________________________________________________________________
Date: Mar 18, 2010
Tom, isn't the "standard" to build with the aft cabanes 1" shorter? Tim in central TX -----Original Message----- >From: Thomas Bernie <tsbernie(at)earthlink.net> >Sent: Mar 18, 2010 8:47 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: GN-1 cabane length > > >Guys, >If you build cabane length to the CAD or previous plans you will end up with zero or minus angle of incidence (from mean cord line). The plane will fly tail low (as reported) with added trim drag and you won't be able to touch down at stall speed with out hitting the tail wheel first. I physically measured the angle of my center section to confirm 1.5 degree a.o.i. with the aft struts 1" shorter. >Tom Bernie >Gloucester Mass >N666TB > >On Mar 18, 2010, at 6:28 AM, skellytown flyer wrote: > >> >> Jon I expect you will get many answers on that.I like you bought my project and the cabanes were done. I believe DJ made them both longer to help with entry and with more angle of attack to help the fuselage fly more level since he thought many of the planes flew in a tail low attitude.naturally it flies with the wing at the right angle to provide the needed lift and your fuselage angle is determined by that. so he reasoned that having slightly longer front cabanes would level the fuse in flight.at least that's what I remember him telling me.does that make sense or help? I'm currently trying to finish up the cowling so I can start final assembly. Where are you located?Raymond. Texas panhandle >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=290729#290729 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Air & Space
Date: Mar 18, 2010
Three very good articles... http://www.airspacemag.com/history-of-flight/The-Pride-of-Cherry-Grove.html dwilson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290812#290812 ________________________________________________________________________________
Subject: pitot tube location
Date: Mar 18, 2010
The pitot on 41CC is located about halfway down the jury strut on the starboard side. You have to duck to get under the lift struts at that point anyway, so you don't even get close to the jury struts or pitot and nobody has even come close to bumping the pitot yet. If you put it up on the wing leading edge, unless you're building your Piet as a trigear it will actually be up higher than most peoples' heads (except for very tall folks). That said, I have seen more than one KR with the removable insert type of pitot tube. Down at the level of a KR's wing leading edge, pitots are really in harm's way for getting bent or broken. PS, good to see Walt back on the list! Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Mar 18, 2010
Subject: one man's suggestion for not bending any tubing
Richard, I ended up simply sticking a piece of =BC" stainless steel tubing thru a ho le in the leading edge of my wing and connecting it inside the wing with poly tubing and fittings from Wicks sold for the pu rpose of being used in routing airspeed and pitot/static lines. Don't bother running static lines-you don't need them in an open cockpit airplane. Just plug the ASI and altimeter static ports with a pipe plug and drill a tiny hole in th e plug to let the instrument vent slightly. Whala. Also to hide my air speed line coming down from the inside of the wing I ju st ran it down the inside of the right rear cabane strut into the instrument panel bay. We don't need to bend no stinkin'g tubing !!! We ain't got no stinking t ubing. Mike C. ________________________________________________________________________________
Subject: Handheld GPS
Date: Mar 18, 2010
So I'm going to buy a Garmin GPSMAP 96 (black and white) and just curious as to what everyone else uses. I have a Garmin 92, but its a little outdated, and the 96 seems to be better but equivalent in weight and size. I learned to navigate by map, but its nice to have the GPS for when night fall or the gas level gets low! the only electronics I plan on running is for coms between seats, and a battery powered GPS for standby. Stuff like that does come in Handy!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290819#290819 ________________________________________________________________________________
Date: Mar 18, 2010
timothywillis(at)earthlin wrote: > Tom, isn't the "standard" to build with the aft cabanes 1" shorter? > Tim in central TX > > > -- Tim, I think that is the norm for the Piet. but the GN-1 has the spars relocated and thus the attachment hardware relocated, and with the larger radius leading edge which adjusts the leading edge end of the mean aerodynamic chord upward. All of these slight changes add up to 3/8" less on the GN-1. Perhaps I am splitting too many hairs here and the actual angle of incidence may not be that critical. Maybe several with flying GN-1's could chime in here. Jon in central NY -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290820#290820 ________________________________________________________________________________
Date: Mar 18, 2010
Subject: simple LE wing pitot tube installation
Subject: Re: Handheld GPS
Date: Mar 18, 2010
I use a sectional, a compass and a clock. No worries. I have yet to experience a "Low Signal Strength" or "Low Battery" with a sectional. My teenagers might tell you I'm old-school because I'm too thick headed to learn how to program a GPS....... Greg Cardinal ----- Original Message ----- From: "VanDy" <matthew.vandervort(at)gmail.com> Sent: Thursday, March 18, 2010 9:36 PM Subject: Pietenpol-List: Handheld GPS > > > So I'm going to buy a Garmin GPSMAP 96 (black and white) and just curious > as to what everyone else uses. I have a Garmin 92, but its a little > outdated, and the 96 seems to be better but equivalent in weight and size. > I learned to navigate by map, but its nice to have the GPS for when night > fall or the gas level gets low! the only electronics I plan on running is > for coms between seats, and a battery powered GPS for standby. Stuff like > that does come in Handy!!! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=290819#290819 > > > ________________________________________________________________________________
Subject: Big day!!
Date: Mar 19, 2010
This message is from Douwe Blumberg. Went to the strip today, which is really a slice of paradise. 3100' of eautiful smooth grass, with no buildings on either side and NO traffic hatsover. God is good!!! Hooked everything back up after having removed the wings for transport, ga ve t a good bath and fiddled with the mixture control a little and then we ere off for some taxi-testing. Everything worked well, I ever got the tai l p at a nice slow speed, thanks to a good breeze coming straight down the unway. Seemed rather surreal after all this time. The pictures are helping me elieve it is almost there! Douwe ________________________________________________________________________________
Subject: #3 of 3 photos from Douwe
Date: Mar 19, 2010
Subject: Big day!!
Date: Mar 19, 2010
Looking good, Douwe! Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Friday, March 19, 2010 6:57 AM Subject: Pietenpol-List: Big day!! This message is from Douwe Blumberg. Went to the strip today, which is really a slice of paradise. 3100' of beautiful smooth grass, with no buildings on either side and NO traffic whatsover. God is good!!! Hooked everything back up after having removed the wings for transport, gave it a good bath and fiddled with the mixture control a little and then we were off for some taxi-testing. Everything worked well, I ever got the tail up at a nice slow speed, thanks to a good breeze coming straight down the runway. Seemed rather surreal after all this time. The pictures are helping me believe it is almost there! Douwe ________________________________________________________________________________
Date: Mar 19, 2010
Subject: Photo sizes
Guys Can you please shrunk down your photos before sending them? Between all the photos I received since last night, you guys burned up 13 meg of disk and blew the limit on my email buffer space. The photos are cool and I like seeing them, but we're not printing a magazine here. We don't need 1 meg+ resolution on every photo to get the point across. Jim Ash ________________________________________________________________________________
Subject: Re: Photo sizes
Date: Mar 19, 2010
I love the big files as I save them all to my PIET folders. I just don't get emailed updates I do mine all by computer. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290876#290876 ________________________________________________________________________________
Subject: Big day!!
Date: Mar 19, 2010
Beautiful pics!!! I like the old barn and water tower in the background. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Friday, March 19, 2010 3:57 AM Subject: Pietenpol-List: Big day!! This message is from Douwe Blumberg. Went to the strip today, which is really a slice of paradise. 3100' of beautiful smooth grass, with no buildings on either side and NO traffic whatsover. God is good!!! Hooked everything back up after having removed the wings for transport, gave it a good bath and fiddled with the mixture control a little and then we were off for some taxi-testing. Everything worked well, I ever got the tail up at a nice slow speed, thanks to a good breeze coming straight down the runway. Seemed rather surreal after all this time. The pictures are helping me believe it is almost there! Douwe ________________________________________________________________________________
Date: Mar 19, 2010
From: Mike Townsley <allischalmersguy(at)gmail.com>
Subject: Re: Big day!!
Way to go Douwe! The plane looks fantastic, a true antique! Pics with the old watertower look great! Nice job. I am anxious to hear of the maiden voyage! Mike Townsley helspersew(at)aol.com wrote: > This message is from Douwe Blumberg. > > > Went to the strip today, which is really a slice of paradise. 3100' of > beautiful smooth grass, with no buildings on either side and NO traffic > whatsover. God is good!!! > > Hooked everything back up after having removed the wings for transport, gave > it a good bath and fiddled with the mixture control a little and then we > were off for some taxi-testing. Everything worked well, I ever got the tail > up at a nice slow speed, thanks to a good breeze coming straight down the > runway. > > Seemed rather surreal after all this time. The pictures are helping me > believe it is almost there! > Douwe > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Mar 19, 2010
If you think raising the tail is fun, wait till you raise the mains too! Looking forward to hearing your first flight report. Beautiful airplane! Ben Charvet 11.1 hours on Hobbs On 3/19/2010 6:57 AM, helspersew(at)aol.com wrote: > This message is from Douwe Blumberg. > > > Went to the strip today, which is really a slice of paradise. 3100' of > beautiful smooth grass, with no buildings on either side and NO traffic > whatsover. God is good!!! > > Hooked everything back up after having removed the wings for transport, gave > it a good bath and fiddled with the mixture control a little and then we > were off for some taxi-testing. Everything worked well, I ever got the tail > up at a nice slow speed, thanks to a good breeze coming straight down the > runway. > > Seemed rather surreal after all this time. The pictures are helping me > believe it is almost there! > Douwe > ________________________________________________________________________________
Date: Mar 19, 2010
Great job Douwe. It looks like we will have a great turn out at Brodhead this year. I have 7 hours now on mine now and a clear and warm weekend coming up. Gardiner Mason --- On Thu, 3/18/10, Mike Townsley wrote: > From: Mike Townsley <allischalmersguy(at)gmail.com> > Subject: Re: Pietenpol-List: Big day!! > To: pietenpol-list(at)matronics.com > Date: Thursday, March 18, 2010, 4:40 PM > --> Pietenpol-List message posted > by: Mike Townsley > > Way to go Douwe! The plane looks fantastic, a true antique! > Pics with > the old watertower look great! Nice job. I am > anxious to hear of the > maiden voyage! > Mike Townsley > > helspersew(at)aol.com > wrote: > > This message is from Douwe Blumberg. > > > > > > Went to the strip today, which is really a slice of > paradise. 3100' of > > beautiful smooth grass, with no buildings on either > side and NO traffic > > whatsover. God is good!!! > > > > Hooked everything back up after having removed the > wings for transport, gave > > it a good bath and fiddled with the mixture control a > little and then we > > were off for some taxi-testing. Everything > worked well, I ever got the tail > > up at a nice slow speed, thanks to a good breeze > coming straight down the > > runway. > > > > Seemed rather surreal after all this time. The > pictures are helping me > > believe it is almost there! > > Douwe > > > > > > > ------------------------------------------------------------------------ > > > > > > > ------------------------------------------------------------------------ > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Mar 19, 2010
FYI If memory serves me right, in 2005 at Broadhead, I measured the cabanes of all the Piets (18?). Everyone had 1" shorter rear cabane than the front one. Roman B. NX20795 Also my Piet has the 1" difference. On Mar 18, 2010, at 2:52 PM, coxwelljon wrote: > > > > OK, I did my measuring. I did a little more looking on the web and > found that the recommended angle of incidence for the Pietenpol wing > is 3 degrees. I am assuming it is the same for the GN-1 wing. From > posts I read this allows for some washout on the tips. As I > remember from Broadhead this summer the washout makes the Piet a > much better flying bird. > > I struck a chalk line from the trailing edge to the center of the > curve on the leading edge to get the chord line. The chord line is > at an angle of 1.83 degrees to a line through the center of the > mounting holes for the cabane struts. To get to the recommended 3 > degrees I will need to lengthen my front cabanes by 5/8" to get 3 > degrees. Probably the easiest is to weld another tube for the > attach bolt on top of the existing attach point and a new saddle > strap over the top. The fix will be tell tale at any gatherings but > then I am not building a show plane and it seems like a lot less > work than cutting the strut and lengthening it. > > Thanks for your comments > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=290778#290778 > > ________________________________________________________________________________
Date: Mar 19, 2010
Here's a differing viewpoint regarding photo sizes: I LIKE the big photos. Personally, I'm always disappointed when the photo attachments are so small that I can't make out details. I know that a few years ago, there were still a few guys with dial-up internet connections who were constantly complaining about how long it would take to download the messages that had decent sized photos attached - but I don't think there are too many people still on dial-up. My home email is pretty basic (through my phone line) and I can send and receive attachments up to 10 Megs. I think that the size limit prescribed by Matronics is reasonable (2 Meg maximum), in today's world. So I say, keep the big photos coming - especially like those great shots of Douwe's new plane, and the close-up details of Mike's pitot lines. Each of those shots were worth at least 1000 proverbial words. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290892#290892 ________________________________________________________________________________
Date: Mar 19, 2010
Subject: Re: simple LE wing pitot tube installation
Is that a 50 caliber machine gun in your wing Michael?- Cheers, Gardiner --- On Thu, 3/18/10, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] <michael.d.cuy @nasa.gov> Subject: Pietenpol-List: simple LE wing pitot tube installation Date: Thursday, March 18, 2010, 3:31 PM =0A=0A =0A =0A=0A=0A=0A-=0A =0A-=0A=0A =0A ________________________________________________________________________________
Date: Mar 19, 2010
Subject: Big day!!
The plane looks amazing; I like the color scheme. That plane ain't gonna get lost against a blue sky. Very nice job, Douwe. Jim Ash -----Original Message----- From: Gary Boothe Sent: Mar 19, 2010 8:39 AM Subject: RE: Pietenpol-List: Big day!! Beautiful pics!!! I like the old barn and water tower in the background Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Friday, March 19, 2010 3:57 AM Subject: Pietenpol-List: Big day!! This message is from Douwe Blumberg. Went to the strip today, which is really a slice of paradise. 3100' ofbeautiful smooth grass, with no buildings on either side and NO trafficwhatsover. God is good!!! Hooked everything back up after having removed the wings for transport, gaveit a good bath and fiddled with the mixture control a little and then wewere off for some taxi-testing. Everything worked well, I ever got the tailup at a nice slow speed, thanks to a good breeze coming straight down therunway. Seemed rather surreal after all this time. The pictures are helping mebelieve it is almost there! Douwe ________________________________________________________________________________
Date: Mar 19, 2010
Actually, I save a lot of them myself, too. Jim -----Original Message----- >From: Jerry Dotson <jdotson(at)erec.net> >Sent: Mar 19, 2010 7:26 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Photo sizes > > >I love the big files as I save them all to my PIET folders. I just don't get emailed updates I do mine all by computer. > >-------- >Jerry Dotson >59 Daniel Johnson Rd >Baker, FL 32531 > >Started building NX510JD July, 2009 >Ribs and tailfeathers done >using Lycoming O-235 > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=290876#290876 > > ________________________________________________________________________________
Date: Mar 19, 2010
What's GPS? Doug Dever In beautiful Stow Ohio _________________________________________________________________ Hotmail: Trusted email with Microsoft=92s powerful SPAM protection. ________________________________________________________________________________
Date: Mar 19, 2010
I'm not on dial-up; it's DSL. What I am on is a web-mail server with limited buffer space for each user. I'm a visual guy, and a picture is worth a thousand words to me also. But I suspect you could cut the photo resolution in half, still get the point across, and only a photographer could tell the difference. Glamour shots like Douwe's plane need really good resolution because I'll blow them up to full-screen size (I'd do life-size if I had the monitor for it), but you don't need that for close-up's of welds, glue joints and other such construction tips. I'm not trying to cause any dissention amongst the ranks. If I'm the only one who cares, I'll sit down ahd shut up. Blue skies. Jim -----Original Message----- >From: Bill Church <billspiet(at)sympatico.ca> >Sent: Mar 19, 2010 8:00 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Photo sizes > > >Here's a differing viewpoint regarding photo sizes: > >I LIKE the big photos. >Personally, I'm always disappointed when the photo attachments are so small that I can't make out details. I know that a few years ago, there were still a few guys with dial-up internet connections who were constantly complaining about how long it would take to download the messages that had decent sized photos attached - but I don't think there are too many people still on dial-up. My home email is pretty basic (through my phone line) and I can send and receive attachments up to 10 Megs. I think that the size limit prescribed by Matronics is reasonable (2 Meg maximum), in today's world. >So I say, keep the big photos coming - especially like those great shots of Douwe's new plane, and the close-up details of Mike's pitot lines. Each of those shots were worth at least 1000 proverbial words. > >Bill C. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=290892#290892 > > ________________________________________________________________________________
Date: Mar 19, 2010
What's GPS? Doug Dever In beautiful Stow Ohio Doug-that stands for getting pretty stupid:) ________________________________________________________________________________
Date: Mar 19, 2010
Subject: a serious response: Handheld GPS
I use a simple Garmin Pilot III GPS since it doesn't draw enough current to warrant a supplemental battery like the larger and/or color screens do. I'm old school too Greg for the most part with regard to things like GPS and cell phones. (use a Tracphone only when necessary) I've always been a hold out on things like getting answering machines, gps, and cell phones. For many years I went everywhere NORDO but finally broke down and bought a handheld Icom A-4 mostly to just hear where the other guys in the pattern are. I usually just announce my arrival with a few puffs of smoke. Mike C. ________________________________________________________________________________
Date: Mar 19, 2010
Tim, I think 1" has been working out about right for Piet guys. The GN-1 is sort of a different animal -- the plans, depending on which ones you have, all give different lengths that result in insufficient, or negative a.o.i. The way the spars and fittings are configured (i.e. equal height at the spar attach fittings does not give you zero a.o.i.). This has come up a couple of times among GN-1 builders in the past -- but no consensus. We know the plans give a crappy result, so every man for himself. Regards, Tom On Mar 18, 2010, at 11:10 AM, Tim Willis wrote: > > Tom, isn't the "standard" to build with the aft cabanes 1" shorter? > Tim in central TX > > > -----Original Message----- >> From: Thomas Bernie <tsbernie(at)earthlink.net> >> Sent: Mar 18, 2010 8:47 AM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: Re: GN-1 cabane length >> >> >> Guys, >> If you build cabane length to the CAD or previous plans you will end up with zero or minus angle of incidence (from mean cord line). The plane will fly tail low (as reported) with added trim drag and you won't be able to touch down at stall speed with out hitting the tail wheel first. I physically measured the angle of my center section to confirm 1.5 degree a.o.i. with the aft struts 1" shorter. >> Tom Bernie >> Gloucester Mass >> N666TB >> >> On Mar 18, 2010, at 6:28 AM, skellytown flyer wrote: >> >>> >>> Jon I expect you will get many answers on that.I like you bought my project and the cabanes were done. I believe DJ made them both longer to help with entry and with more angle of attack to help the fuselage fly more level since he thought many of the planes flew in a tail low attitude.naturally it flies with the wing at the right angle to provide the needed lift and your fuselage angle is determined by that. so he reasoned that having slightly longer front cabanes would level the fuse in flight.at least that's what I remember him telling me.does that make sense or help? I'm currently trying to finish up the cowling so I can start final assembly. Where are you located?Raymond. Texas panhandle >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=290729#290729 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: Re: a serious response: Handheld GPS
Date: Mar 19, 2010
I'm not flying my Piet yet (nowhere close), but I have, and intend to use, a Garmin GPSMAP 195 and an Icom IC-A22 NAVCOM. Of course I won't need the GPS unless I'm flying cross country. Even then I don't NEED it, but it sure is nice to just fly direct, following the CDI. As for the radio, it is such a small package, and offers so much added safety that I can't really consider NOT using it. I also hope to teach my son to fly in the Piet... so he will need to learn to use the radio, and I'm sure we will appreciate the intercom. I have a great view of the approach to rwy 17 from my hangar, where I see non-radio guys cutting off people on final all the time. I'm not trying to include everyone in that comment. Heck, there may be days that I just want to fly around the patch without my headset on, but just yesterday I saw one of our breezy fliers cut off two aircraft (at different times) that were well established on final. For starters he took the active and departed in front of one, and later he flew a short pattern and turned final right in front of another that was already established on final and was flying a proper pattern. I know all of the people involved and I imagine Mr. Breezy will hear about it. I'm aware that these things just happen occasionally, but we have students flying at our field, and I regularly see people stop by that are not from our field (for fuel, visit, etc.) and they probably don't know (nor do they expect to see) Mr. Breezy cutting in underneath them. We all need to work on our scan to be safe, but I also think this particular pilot's vision may improve if he had something on his ears. :) Anyhow, I'm not trying to rant as much as I am trying to promote a couple of useful widgets. Especially the radio. As stated above, the IC-A22 is a NAVCOM, so I could navigate with it using VOR stations, which is actually pretty fun. A lot of bang for the buck in a modern day handheld. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290915#290915 ________________________________________________________________________________
Date: Mar 19, 2010
Very cool! I am going to the hangar RIGHT NOW to make some wood shavings. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290917#290917 ________________________________________________________________________________
Date: Mar 19, 2010
I'd also prefer smaller ones. You can always post them in one of the free photo sites and provide us with a link, after all. Thanks for the beautiful pictures anyway! Real pretty airplane, with the perfect color scheme. David Paule ________________________________________________________________________________
Date: Mar 19, 2010
Subject: Re: Air & Space
Thanks for the link, makes me want to go read my copy of The Pietenpol Story again. rick On Thu, Mar 18, 2010 at 7:40 PM, dwilson wrote: > > Three very good articles... > > http://www.airspacemag.com/history-of-flight/The-Pride-of-Cherry-Grove.html > > > dwilson > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=290812#290812 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 19, 2010
Subject: Re: one man's suggestion for not bending any tubing
Mike I must have gotten the leading edge pitot tube idea from you, one question, did you glue the stainless tube to your leading edge? Or is it removable? thanks rick On Thu, Mar 18, 2010 at 1:27 PM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > Richard, > > > I ended up simply sticking a piece of stainless steel tubing thru a hole > in the leading edge of my wing and connecting > > it inside the wing with poly tubing and fittings from Wicks sold for the > purpose of being used in routing airspeed and > > pitot/static lines. Dont bother running static linesyou dont need > them in an open cockpit airplane. Just plug the > > ASI and altimeter static ports with a pipe plug and drill a tiny hole in the > plug to let the instrument vent slightly. Whala. > > > Also to hide my air speed line coming down from the inside of the wing I > just ran it down the inside of the right rear cabane > > strut into the instrument panel bay. > > > We dont need to bend no stinking tubing !!! We aint got no stinking > tubing. > > > Mike C. > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 19, 2010
I have a copy of the newer CAD version of the GN-1 plans, the bottom bolt to top bolt centerline measurements are 23 1/4" front and 23 1/2" rear. rick On Thu, Mar 18, 2010 at 8:55 PM, coxwelljon wrote: > > > timothywillis(at)earthlin wrote: >> Tom, isn't the "standard" to build with the aft cabanes 1" shorter? >> Tim in central TX >>a >> >> -- > > Tim, > > I think that is the norm for the Piet. but the GN-1 has the spars relocated and thus the attachment hardware relocated, and with the larger radius leading edge which adjusts the leading edge end of the mean aerodynamic chord upward. All of these slight changes add up to 3/8" less on the GN-1. Perhaps I am splitting too many hairs here and the actual angle of incidence may not be that critical. Maybe several with flying GN-1's could chime in here. > > Jon in central NY > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=290820#290820 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 19, 2010
Wow, beautiful, especially the wood struts and cabanes and the paint job. What kind of paint did you use? (I liked the large pictures). rick On Fri, Mar 19, 2010 at 4:57 AM, wrote: > This message is from Douwe Blumberg. > > > Went to the strip today, which is really a slice of paradise. 3100' of > beautiful smooth grass, with no buildings on either side and NO traffic > whatsover. God is good!!! > > Hooked everything back up after having removed the wings for transport, gave > it a good bath and fiddled with the mixture control a little and then we > were off for some taxi-testing. Everything worked well, I ever got the tail > up at a nice slow speed, thanks to a good breeze coming straight down the > runway. > > Seemed rather surreal after all this time. The pictures are helping me > believe it is almost there! > > Douwe > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 19, 2010
Tim, I know that -- I built my GN-1 from CAD plans. The plans are wrong and that's not the only thing in the plans you have to watch out for. Tom On Mar 19, 2010, at 4:23 PM, Rick Holland wrote: > > I have a copy of the newer CAD version of the GN-1 plans, the bottom > bolt to top bolt centerline measurements are 23 1/4" front and 23 1/2" > rear. > > rick > > On Thu, Mar 18, 2010 at 8:55 PM, coxwelljon wrote: >> >> >> timothywillis(at)earthlin wrote: >>> Tom, isn't the "standard" to build with the aft cabanes 1" shorter? >>> Tim in central TX >>> a >>> >>> -- >> >> Tim, >> >> I think that is the norm for the Piet. but the GN-1 has the spars relocated and thus the attachment hardware relocated, and with the larger radius leading edge which adjusts the leading edge end of the mean aerodynamic chord upward. All of these slight changes add up to 3/8" less on the GN-1. Perhaps I am splitting too many hairs here and the actual angle of incidence may not be that critical. Maybe several with flying GN-1's could chime in here. >> >> Jon in central NY >> >> -------- >> Jon Coxwell >> GN-1 Builder >> Recycle and preserve the planet >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=290820#290820 >> >> >> >> >> >> >> >> >> >> >> > > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > > > > > ________________________________________________________________________________
Date: Mar 19, 2010
Subject: cork float
I am making a cork fuel float as a back up for my capacitince gage. How do I treat the cork so it won't come apart in the fuel? Gardiner ________________________________________________________________________________
Date: Mar 19, 2010
Subject: Re: cork float
Good question Gardiner, was looking for an answer to that question last week. Have a wine cork from a nice 2005 Shiraz on the end of a stainless welding rod (to be my sole fuel gauge) and couldn't find a thing in any of the 4 Bingelis books (as far as treating the cork with anything). Have heard of people coating them with varnish, and have seen auto fuel tank floats used in place of cork, any ideas would be appreciated. Rick On Fri, Mar 19, 2010 at 5:05 PM, airlion wrote: > > I am making a cork fuel float as a back up for my capacitince gage. How do I treat the cork so it won't come apart in the fuel? Gardiner > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 19, 2010
Hey Gardiner, I coated ours in regular old T-88. No problems so far, but I only use avgas. Jeff > >I am making a cork fuel float as a back up for my capacitince gage. >How do I treat the cork so it won't come apart in the fuel? Gardiner -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 19, 2010
I-remember seeing someone use a ping pong ball in the past ;should be in th archives=0A=0A=0A=0A=0A________________________________=0AFrom: Rick Hol land =0ATo: pietenpol-list(at)matronics.com=0ASent: Fri, M arch 19, 2010 7:38:43 PM=0ASubject: Re: Pietenpol-List: cork float=0A=0A--> Pietenpol-List message posted by: Rick Holland =0A=0AG ood question Gardiner, was looking for an answer to that question=0Alast we ek. Have a wine cork from a nice 2005 Shiraz on the end of a=0Astainless we lding rod (to be my sole fuel gauge) and couldn't find a=0Athing in any of the 4 Bingelis books (as far as treating the cork with=0Aanything). Have he ard of people coating them with varnish, and have=0Aseen auto fuel tank flo ats used in place of cork, any ideas would be=0Aappreciated.=0A=0ARick=0A =0AOn Fri, Mar 19, 2010 at 5:05 PM, airlion wrote: =0A>=0A> I am making a cork fuel float as a back up for my capacitince gage . How do I treat the cork so it won't come apart in the fuel? Gardiner=0A> =0A>=0A>=0A>=0A>=0A>=0A>=0A=0A=0A=0A-- =0ARick Holland=0ACastle Rock, Color ============= ________________________________________________________________________________
Date: Mar 19, 2010
Subject: just another idea and concept to ponder
Hello good people..... A new idea and concept for the group to ponder. As we all know and have recognized we all share a common bond as fellow lovers of the blue, aviators, builders connected through the design genius of Bernard Pietenpol and his flying contraption the aeroplane. We as a collection of builders have at our disposal some, many and all of the requisite skill levels to construct such a machine with little assistance or intervention from the outside world. The there are those who would love to join our ranks but may be lacking in skills, equipment and time to turn their dream into a reality. From prints to Piet if you will. We know that everyone has a skill set that is good in some areas and not so good in others. Knowing these basic tenants I am curious as to who or what builders would welcome the talents of other builders equipped with tools and skills would be interested in having a group of builders show up at their hanger, barn, basement or garage for a weekend build utilizing all the skills of the people interested in lending a hand to accomplish a number of tasks to get the project going bring the tools to get the certain aspects completed. Woodworkers, metal workers, mechanical workers and the like showing up to get a build from a stalled stage to a more accomplished state of being a Pietenpol. I am speaking about two groups of people, those with the skills and resources capable of committing to a 2 or 3 day weekend to participate in building another Piet as one group. The other group would be a builder or would be builder who in need of assistance in advancing their project to a next or greater level of completion. This again is but another concept for consideration. For example I have both tools not all that I need but certainly more than other that are portable, a trailer to transport them and no skills to speak of. I also have lodging as in a popup/tent camper to bring to a build site for a few days to help another builder. There are others with tools and skills that may also be portable. Through this cooperative of a half dozen or more people who would be willing to share their time and expertise to get another build moving and another builder to a next level of completion. I am wonder how many of us would be willing to pitch in for a week end to help and how many would be interested in receiving those willing to help. Before I go any further with this concept it would be nice to know if there is any interest at all in helping or being helped. Just in case you were wondering, I have all of my tools marked for identification purposes. I know how this works. Helpers bring tools and skills and resources as needed helped provide a keg on tap burgers and a place for a fire and I think we are cooking with gas! What say you? John ________________________________________________________________________________
Date: Mar 19, 2010
Rick, I tried a cork the size of a wine cork on a 1/8in welding rod and it was not enough to float it. Bigger cork maybe? Cheers, Gardiner ________________________________ From: H RULE <harvey.rule(at)rogers.com> Sent: Fri, March 19, 2010 7:58:56 PM Subject: Re: Pietenpol-List: cork float I remember seeing someone use a ping pong ball in the past ;should be in th archives ________________________________ From: Rick Holland <at7000ft(at)gmail.com> Sent: Fri, March 19, 2010 7:38:43 PM Subject: Re: Pietenpol-List: cork float Good question Gardiner, was looking for an answer to that question last week. Have a wine cork from a nice 2005 Shiraz on the end of a stainless welding rod (to be my sole fuel gauge) and couldn't find a thing in any of the 4 Bingelis books (as far as treating the cork with anything). Have heard of people coating them with varnish, and have seen auto fuel tank floats used in place of cork, any ideas would be appreciated. Rick On Fri, Mar 19, 2010 at 5:05 PM, airlion wrote: > > I am making a cork fuel float as a back up for my capacitince gage. How do I treat the cork so it won't come apart in the fuel? Gardiner > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of phe many List utilities such as List > http://www.matronics.com/Navigator?Pietenpol-List http://www.===================== ________________________________________________________________________________
Date: Mar 19, 2010
Shellac? Sent from my iPhone On Mar 19, 2010, at 6:05 PM, airlion wrote: > > I am making a cork fuel float as a back up for my capacitince gage. > How do I treat the cork so it won't come apart in the fuel? Gardiner > > ________________________________________________________________________________
Subject: Re: puffs of smoke
Date: Mar 19, 2010
[Laughing] -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290981#290981 ________________________________________________________________________________
Date: Mar 19, 2010
I think at one time Shellac was used.but with the ever changing automotive fuels I wouldn't bet anything would stand up long term.but if you stay with avgas it might-and maybe 2 floats in line could work-I'm still looking for a good round brass float to try on mine. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290986#290986 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Mar 19, 2010
Subject: Re: a serious response: Handheld GPS On the Cheap
I am one CSOB (Cheap Son Of a Beech) I fly a VFR only 1948 Beechcraft Bonanza. Other than a compas and map My Vtail only has a VOR for navigation. Currently I use two handhelds in that Bonanaza. One is a handheld Magellan Explorist 200. It is a hiking GPS, the database has airports as well. It shows a moving map with major roads, towns by name and bodies of water. It has a light function. You can also set it up on a navigation screen that has a Compass rose with your heading and the bearing direct to your destination. You can put in multiple waypoints. Show ETA, ETE, GS, Bearing, HEading and distance traveled. Uses 2 AA batteries. Cost new on amazon is about $130. It has a small screen for the map but plenty big for the navigation screen The other GPS is the Garmin NUVI 370. It is the one I bought for my wife to get around San Antonio. She hates driving in towns. I put it on Off Road function and It gives me a direct to arrow. It also has airports in the database. It also shows the roads (in detail), the towns, rivers, golf courses, parks, Airports and other detail. It plugs into my cigar lighter, though it has a pretty robust battery. Cost about $350 I set the Garmin on Map page and the Magellan on Navigation page. Then I follow with the map. Using the VOR just to keep current with it. Anyone should be able to find a GPS that does this much at least as cheap. Just an Idea. no Aviation database but it tell you where north is. Blue Skies, Steve D ----- Original Message ----- From: K5YAC <hangar10(at)cox.net> Date: Friday, March 19, 2010 9:47 Subject: Pietenpol-List: Re: a serious response: Handheld GPS > > I'm not flying my Piet yet (nowhere close), but I have, and intend to use, a Garmin GPSMAP 195 and an Icom IC-A22 NAVCOM. Of course > I won't need the GPS unless I'm flying cross country. Even then I > don't NEED it, but it sure is nice to just fly direct, following > the CDI. As for the radio, it is such a small package, and offers > so much added safety that I can't really consider NOT using it. I > also hope to teach my son to fly in the Piet... so he will need to > learn to use the radio, and I'm sure we will appreciate the intercom. > > I have a great view of the approach to rwy 17 from my hangar, > where I see non-radio guys cutting off people on final all the > time. I'm not trying to include everyone in that comment. Heck, > there may be days that I just want to fly around the patch without > my headset on, but just yesterday I saw one of our breezy fliers > cut off two aircraft (at different times) that were well > established on final. For starters he took the active and > departed in front of one, and later he flew a short pattern and > turned final right in front of another that was already > established on final and was flying a proper pattern. I know all > of the people involved and I imagine Mr. Breezy will hear about > it. I'm aware that these things just happen occasionally, but we > have students flying at our field, and I regularly see people stop > by that are not from our field (for fuel, visit, etc.) and they > probably don't know (nor do they expect to see) Mr. Breezy cutting > in underneath them. We all need to ! > work on our scan to be safe, but I also think this particular > pilot's vision may improve if he had something on his ears. :) > > Anyhow, I'm not trying to rant as much as I am trying to promote a > couple of useful widgets. Especially the radio. As stated above, > the IC-A22 is a NAVCOM, so I could navigate with it using VOR > stations, which is actually pretty fun. A lot of bang for the > buck in a modern day handheld. > > -------- > Mark - working on wings > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=290915#290915 > > > > > > > > > > ________________________________________________________________________________
Subject: cork float
Date: Mar 19, 2010
I made a float out of fishing rod handle cork rings glued together, and coated the whole thing with T-88, and then with Stits PolyFiber Epoxy Varnish. Works great. The fishing rod cork rings can be purchased from any company that sells rod building supplies. I think I got mine from Hook & Hackle: http://www.hookhack.com/ Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Friday, March 19, 2010 8:11 PM Subject: Re: Pietenpol-List: cork float Rick, I tried a cork the size of a wine cork on a 1/8in welding rod and it was not enough to float it. Bigger cork maybe? Cheers, Gardiner _____ From: H RULE <harvey.rule(at)rogers.com> Sent: Fri, March 19, 2010 7:58:56 PM Subject: Re: Pietenpol-List: cork float I remember seeing someone use a ping pong ball in the past ;should be in th archives _____ From: Rick Holland <at7000ft(at)gmail.com> Sent: Fri, March 19, 2010 7:38:43 PM Subject: Re: Pietenpol-List: cork float Good question Gardiner, was looking for an answer to that question last week. Have a wine cork from a nice 2005 Shiraz on the end of a stainless welding rod (to be my sole fuel gauge) and couldn't find a thing in any of the 4 Bingelis books (as far as treating the cork with anything). Have heard of people coating them with varnish, and have seen auto fuel tank floats used in place of cork, any ideas would be appreciated. Rick On Fri, Mar 19, 2010 at 5:05 PM, airlion wrote: > > I am making a cork fuel float as a back up for my capacitince gage. How do I treat the cork so it won't come apart in the fuel? Gardiner > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of phe many List utilities such as List > http://www.matronics.com/Navigator?Pietenpol-List http://www.===================== ________________________________________________________________________________
Date: Mar 19, 2010
Just something to think about. The more systems you have the more preceived problems you have to solve. How much redundantcy do you really need on a simple plane and when does that plane become complicated? JMHO if you have an electronic fuel gauge that is backup for a stick fuel tester watch and the knowlege of your fuel burn per hour plus reserve. The best backup fuel guage would be a sight glass. I am not trying to start anything just start a thought process. "Trusting any fuel gauge should only be done in the pattern for dead stick practice" Bryan Green Elgin SC ----- Original Message ----- From: "skellytown flyer" <skellflyer1(at)yahoo.com> Sent: Friday, March 19, 2010 8:59 PM Subject: Pietenpol-List: Re: cork float > > > I think at one time Shellac was used.but with the ever changing automotive > fuels I wouldn't bet anything would stand up long term.but if you stay > with avgas it might-and maybe 2 floats in line could work-I'm still > looking for a good round brass float to try on mine. Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=290986#290986 > > > ________________________________________________________________________________
Date: Mar 19, 2010
at7000ft wrote: > I have a copy of the newer CAD version of the GN-1 plans, the bottom > bolt to top bolt centerline measurements are 23 1/4" front and 23 1/2" > rear. > > rick > > Rick and others, It looks like the concensus for Piet plans is 1" longer for the front. I will have to do some looking at my Piet plans (I have both Piet and GN-1 drawings) and see what 1" does as far as the angle of incidence. I will report back. Seems like with a few GN-1 builders out there it would be good to settle this as there is no support from Don Grega. -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290993#290993 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: intercom
Date: Mar 19, 2010
Hey, What would be a good set up to allow pilot and passenger to talk through their headsets. Is all I need two headsets, a battery powered intercom unit and two push to talk adaptors? I prefer push to talk as they just seem less finnicky in an open cockpit enviornment. Thanks Douwe ________________________________________________________________________________
Date: Mar 19, 2010
Gardnier. I use a cork just to fit through the filler, about 2 inches long, with a SS wire pushed through, and bent 120 degree, pushed back into the cork. Dip 5 or more times in Shellac. Remove when not flying, cap with a vent is to keep fuel clean when not flying. I have used this construction in Piets since 1965, running 90 % on auto gas and 10 % 100 low lead. Keep the SS wire small dia. Still working well. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290995#290995 ________________________________________________________________________________
Date: Mar 19, 2010
Subject: Re: intercom
Douwe, We have this set-up in our Piet. It works with several different headsets. We've been very, very happy with the rig. I'll check the manufacturers of of the intercom and PTT switch when I go out tomorrow. Too long since installed from me to remember the company names. J > > >Hey, > >What would be a good set up to allow pilot and passenger to talk through >their headsets. Is all I need two headsets, a battery powered intercom unit >and two push to talk adaptors? I prefer push to talk as they just seem less >finnicky in an open cockpit enviornment. > >Thanks > >Douwe -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 19, 2010
Check out Lynx headsets at: http://www.easyflight.com/price/sr1ss.html I have no experience with them but they are designed for open cockpit / high noise enviroments. I have heard reports that they work well. Greg Cardinal ----- Original Message ----- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> Sent: Friday, March 19, 2010 10:02 PM Subject: Pietenpol-List: intercom > > > Hey, > > What would be a good set up to allow pilot and passenger to talk through > their headsets. Is all I need two headsets, a battery powered intercom > unit > and two push to talk adaptors? I prefer push to talk as they just seem > less > finnicky in an open cockpit enviornment. > > Thanks > > Douwe > > > ________________________________________________________________________________
Date: Mar 19, 2010
luther b green wrote: > Just something to think about. The more systems you have the more preceived > problems you have to solve. How much redundantcy do you really need on a > simple plane and when does that plane become complicated? > JMHO if you have an electronic fuel gauge that is backup for a stick fuel > tester watch and the knowlege of your fuel burn per hour plus reserve. The > best backup fuel guage would be a sight glass. I am not trying to start > anything just start a thought process. > > "Trusting any fuel gauge should only be done in the pattern for dead stick > practice" > Bryan Green > Elgin SC > --- Something else to think about, there was a recent article in the EAA ultra light online newsletter. http://www.eaa.org/lightplaneworld/articles/1003_warning.asp A fellow fried his rotax engine because of a fiberglass and epoxy gas tank. T88 is epoxy and may be subject to deterioration by the ethanol blend fuels. I am not recommending the use of ethanol but it could end up in a fuel tank by mistake for someone who uses auto fuel. cork is a natural material and doesn't really absorb liquid. Does it need to be sealed? I would put a cork in a can of gas and let it sit for some days and see what happens. Jon Adirondack Park NY -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=290998#290998 ________________________________________________________________________________
Date: Mar 19, 2010
A buddy of mine has a motorcycle battery that he recharges and uses for his handheld radio. Blue Skies, Steve d ----- Original Message ----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Date: Friday, March 19, 2010 22:04 Subject: Pietenpol-List: intercom > > Hey, > > What would be a good set up to allow pilot and passenger to talk through > their headsets. Is all I need two headsets, a battery powered intercom unit > and two push to talk adaptors? I prefer push to talk as they just seem less > finnicky in an open cockpit enviornment. > > Thanks > > Douwe > > > > > ________________________________________________________________________________
Date: Mar 19, 2010
Douwe, I misspoke. We do not have PTT switches in both cockpits. We don't need it. We have a battery-powered intercom with good volume and squelch controls. I'll collect information on the parts tomorrow and post. Jeff > > >Hey, > >What would be a good set up to allow pilot and passenger to talk through >their headsets. Is all I need two headsets, a battery powered intercom unit >and two push to talk adaptors? I prefer push to talk as they just seem less >finnicky in an open cockpit enviornment. > >Thanks > >Douwe -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Subject: Re: just another idea and concept to ponder
Date: Mar 19, 2010
Sounds like a Pietenpol for Humanity project. Something to think about. I think a workshop experience like W. Wynne does with his Corvair engines would be of interest. I kind of like to work by myself and have most of the tools I need, but would be interested in weekend workshop devoted to the various types of construction needed for a Piet or GN-1. A series of workshops to cover most of the processes. Might be helpful to work with a local EAA chapter. Jon Adirondack Park, NY -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291004#291004 ________________________________________________________________________________
Subject: cork float
Date: Mar 19, 2010
There is a product called Quick Polly. It works well on floats. I have us ed it several times. It is a 2 part mix epoxy and cures in about 10 minute s. It has the viscosity of paint thinner and soaks in a bit. The instucti ons that came with the packaging said it is good for sealing gas tanks. I don't have the source at the monent but could look it up on the internet li ke I did to find it the last time. Good luck Vic MX414MV > Date: Fri=2C 19 Mar 2010 16:05:50 -0700 > From: airlion(at)bellsouth.net > Subject: Pietenpol-List: cork float > To: pietenpol-list(at)matronics.com > > > I am making a cork fuel float as a back up for my capacitince gage. How d o I treat the cork so it won't come apart in the fuel? Gardiner > > > =========== =========== =========== =========== > > > _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID27925::T:WLMTAGL:O N:WL:en-US:WM_HMP:032010_1 ________________________________________________________________________________
Date: Mar 20, 2010
HI Rick and all, I have been told to brush shellac over the cork; a couple of coats and it is not bothered by the fuel. Plan on doing that when I finish my tank so don't know for sure. You can get shellac from Woodcraft and probably some paint stores. Jim Jim Boyer Santa Rosa, CA Pietenpol on wheels Tail surfaces done Wing ribs done Corvair engine Mar 19, 2010 04:42:32 PM, pietenpol-list(at)matronics.com wrote: Good question Gardiner, was looking for an answer to that question last week. Have a wine cork from a nice 2005 Shiraz on the end of a stainless welding rod (to be my sole fuel gauge) and couldn't find a thing in any of the 4 Bingelis books (as far as treating the cork with anything). Have heard of people coating them with varnish, and have seen auto fuel tank floats used in place of cork, any ideas would be appreciated. Rick On Fri, Mar 19, 2010 at 5:05 PM, airlion wrote: > > I am making a cork fuel float as a back up for my capacitince gage. How do I treat the cork so it won't come apart in the fuel? Gardiner > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 19, 2010
Don't forget that the solvent that makes shellac liquid is alcohol, preferably grain alky. So be very careful with auto fuel. http://antiquerestorers.com/Articles/jeff/shellac.htm I had two other really good shellac sites but one got blowed up real good when Geocities melted down and the other just dissappeared! Clif > > HI Rick and all, > I have been told to brush shellac over the cork; a couple of coats and it > is not bothered by the fuel. > Jim ________________________________________________________________________________
Date: Mar 19, 2010
If you take the photo at the highest resolution on your camera then each pixel blob is really small. When you reduce that image you still have really small pixels. On the other hand, taking the pic with low resolution means they are quite large. This means that magnifying the image will give a clearer pic to a higher magnification on the former than it will on the latter. My images all start out at 1 to 1.5 meg. I reduce that to 90-120 range to send to the list. Although sometimes I do forget. :-) Clif > > I'm not on dial-up; it's DSL. What I am on is a web-mail server with > limited buffer space for each user. I'm a visual guy, and a picture is > worth a thousand words to me also. > > I'm not trying to cause any dissention amongst the ranks. If I'm the only > one who cares, I'll sit down ahd shut up. > > Blue skies. > > Jim ________________________________________________________________________________
Date: Mar 20, 2010
David Clark Model H5030 is sound powered. No boxes. Just a coax between the two. I have several years experience with them in a noisy 100-110db work area(14,000 HP engine room). The mouthpiece can be stuffed with cotton and just about totally eliminate the background noise. If you are just wanting intercom it can't be beat...at least 20 years without failure. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291020#291020 ________________________________________________________________________________
Subject: Re: GN-1 cabane length
Date: Mar 20, 2010
My cabanes need rebuilding but are measurable and I will do that and post results today sometime. The picture of mine in flight looks level to me so I will keep the length to start with. I'll post the picture also so you guys can take a look. Bryan Green Elgin SC GN-1 rebuilding ----- Original Message ----- From: "coxwelljon" <coxwelljon(at)frontiernet.net> Sent: Friday, March 19, 2010 10:57 PM Subject: Pietenpol-List: Re: GN-1 cabane length > > > > at7000ft wrote: >> I have a copy of the newer CAD version of the GN-1 plans, the bottom >> bolt to top bolt centerline measurements are 23 1/4" front and 23 1/2" >> rear. >> >> rick >> >> > > > Rick and others, > > It looks like the concensus for Piet plans is 1" longer for the front. I > will have to do some looking at my Piet plans (I have both Piet and GN-1 > drawings) and see what 1" does as far as the angle of incidence. I will > report back. Seems like with a few GN-1 builders out there it would be > good to settle this as there is no support from Don Grega. > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=290993#290993 > > > ________________________________________________________________________________
Date: Mar 20, 2010
My intercom box is from Comtronics and has worked well for years with good mike muffs. Bryan Green Elgin SC GN-1 rebuilding ----- Original Message ----- From: "Jerry Dotson" <jdotson(at)erec.net> Sent: Saturday, March 20, 2010 6:38 AM Subject: Pietenpol-List: Re: intercom > > David Clark Model H5030 is sound powered. No boxes. Just a coax between > the two. I have several years experience with them in a noisy 100-110db > work area(14,000 HP engine room). The mouthpiece can be stuffed with > cotton and just about totally eliminate the background noise. If you are > just wanting intercom it can't be beat...at least 20 years without > failure. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > Ribs and tailfeathers done > using Lycoming O-235 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291020#291020 > > > ________________________________________________________________________________
Subject: cabane length
Date: Mar 20, 2010
Mine are all 23.5" hole to hole centers, but I have no idea about the AOI until I set the center section back up and measure. Bryan Green Elgin SC GN-1 rebuilding The message is ready to be sent with the following file or link attachments: clip_image002 ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Mar 20, 2010
I'd be interested in something like this, but not for a year or two. My two big anxiety areas are metalwork in general, and setting up & trammeling the wings. Within the year I will have moved my project into a more or less dedicated 24 x 30' workspace right at my house & I expect the pace tpick up quite a bit at that time. I've actually been hoping to find someone locally who would like to come in as a partner on my project, because I think it's a more sustainable use of resources to share a plane, and i also think the build process would be more fun, but no luck so far. Kip Gardner On Mar 19, 2010, at 8:00 PM, AMsafetyC(at)aol.com wrote: > Hello good people..... > > A new idea and concept for the group to ponder. > > As we all know and have recognized we all share a common bond as > fellow lovers of the blue, aviators, builders connected through the > design genius of Bernard Pietenpol and his flying contraption the > aeroplane. We as a collection of builders have at our disposal > some, many and all of the requisite skill levels to construct such > a machine with little assistance or intervention from the outside > world. > > The there are those who would love to join our ranks but may be > lacking in skills, equipment and time to turn their dream into a > reality. From prints to Piet if you will. We know that everyone has > a skill set that is good in some areas and not so good in others. > Knowing these basic tenants I am curious as to who or what builders > would welcome the talents of other builders equipped with tools and > skills would be interested in having a group of builders show up at > their hanger, barn, basement or garage for a weekend build > utilizing all the skills of the people interested in lending a hand > to accomplish a number of tasks to get the project going bring the > tools to get the certain aspects completed. Woodworkers, metal > workers, mechanical workers and the like showing up to get a build > from a stalled stage to a more accomplished state of being a > Pietenpol. > > I am speaking about two groups of people, those with the skills and > resources capable of committing to a 2 or 3 day weekend to > participate in building another Piet as one group. The other group > would be a builder or would be builder who in need of assistance in > advancing their project to a next or greater level of completion. > > This again is but another concept for consideration. For example I > have both tools not all that I need but certainly more than other > that are portable, a trailer to transport them and no skills to > speak of. I also have lodging as in a popup/tent camper to bring to > a build site for a few days to help another builder. There are > others with tools and skills that may also be portable. > > Through this cooperative of a half dozen or more people who would > be willing to share their time and expertise to get another build > moving and another builder to a next level of completion. > > I am wonder how many of us would be willing to pitch in for a week > end to help and how many would be interested in receiving those > willing to help. > > Before I go any further with this concept it would be nice to know > if there is any interest at all in helping or being helped. > > Just in case you were wondering, I have all of my tools marked for > identification purposes. I know how this works. > > Helpers bring tools and skills and resources as needed helped > provide a keg on tap burgers and a place for a fire and I think we > are cooking with gas! > > What say you? > > > John > > ________________________________________________________________________________
Date: Mar 20, 2010
Don't use Cork. I used a '65 Ford Mustang Fuel float If the picture does not show, Google it, you will see a light copper float with a provision to wrap around a wire It is maintenace free, requires no paint, stands up to any fuel and fits through a standard fuel filler neck Hans NX15KV ________________________________________________________________________________
Date: Mar 20, 2010
DO NOT USE SHELLAC. It is dissolved by alcohol and if you ever happened to use auto fuel it may dissolve and redeposit itself someplace else. ---- Ryan Mueller wrote: > > Shellac? > > Sent from my iPhone > > On Mar 19, 2010, at 6:05 PM, airlion wrote: > > > > > I am making a cork fuel float as a back up for my capacitince gage. > > How do I treat the cork so it won't come apart in the fuel? Gardiner > > > > > > > > > > > > > > ________________________________________________________________________________
Subject:
Date: Mar 20, 2010
Sorry for the big pictures, didn't intend to cause anybody problems. Thanks for the kudos, they weren't why I sent the pics, but they are appreciated. Once she was together and clean at an actual airfield, it just seemd like a formal photo shoot was the closing of one chapter, and getting ready to open the next. Someone asked about paint, I used regular old dope for everything except the logo and the gold edging. I used "one-shot" sign paint for painting the logo and edging. It's all hand painted, and when you get close, you can tell. But I wanted it to look like a couple of kids put it together in 1933. Hopefully the weather will give Lowell a couple of days window to get down here and do the honors. Douwe ________________________________________________________________________________
Date: Mar 20, 2010
Thanks for the info Clif, although several people have had no problems with shellac and auto fuel this article mentions in several places the solubility of shellac in ethanol. Possibly just coating the cork with T-88 is the best way to go. "It is approved by the FDA as a food safe coating when dissolved in pure ethanol (not denatured)." rick On Sat, Mar 20, 2010 at 12:20 AM, Clif Dawson wrote: > > Don't forget that the solvent that makes shellac liquid is alcohol, > preferably > grain alky. So be very careful with auto fuel. > > http://antiquerestorers.com/Articles/jeff/shellac.htm > > I had two other really good shellac sites but one got blowed up real good > when Geocities melted down and the other just dissappeared! > > Clif > >> >> HI Rick and all, >> I have been told to brush shellac over the cork; a couple of coats and it >> is not bothered by the fuel. >> Jim > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 20, 2010
So the only reason you would need an intercom box and a push to talk button is if you want to talk with a passenger and occasionally talk on the com radio? rick On Sat, Mar 20, 2010 at 4:38 AM, Jerry Dotson wrote: > > David Clark Model H5030 is sound powered. No boxes. Just a coax between the two. I have several years experience with them in a noisy 100-110db work area(14,000 HP engine room). The mouthpiece can be stuffed with cotton and just about totally eliminate the background noise. If you are just wanting intercom it can't be beat...at least 20 years without failure. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > Ribs and tailfeathers done > using Lycoming O-235 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291020#291020 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 20, 2010
Subject: cork float
I would suggest that you take whatever you are considering using, shellac, epoxy or whatever, and coat something with it then seal it in a container of gasoline and wait a week then check it for d eterioration. I was wondering if maybe you could make one out of large diameter copper pipe with caps soldered on the ends. Just an idea. ---- Jack Phillips wrote: > I made a float out of fishing rod handlecork rings glued together, and coat ed the whole thing with T-88, and then withStits PolyFiber Epoxy Varnish. =C2- Works great.=C2- The fishing rod corkrings can be purchased from a ny company that sells rod building supplies.=C2-I think I got mine from H ook & Hackle:=C2- http://www.hookhack.com/ =C2- Jack Phillips NX899JP Raleigh, NC =C2- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of airlion Sent: Friday, March 19, 2010 8:11PM Subject: Re: Pietenpol-List: corkfloat =C2- Rick, I tried a cork the size of a wine cork on a 1/8inwelding rod and it w as not enough to float it. Bigger cork maybe? Cheers,Gardiner =C2- From: H RULE<harvey.rule(at)rogers.com> Sent: Fri, March 19, 2010 7:58:56PM Subject: Re: Pietenpol-List: corkfloat I=C2-remember seeing someone use a ping pong ball in the past ;shouldbe i n th archives =C2- From: RickHolland <at7000ft(at)gmail.com> Sent: Fri, March 19, 2010 7:38:43PM Subject: Re: Pietenpol-List: corkfloat Good question Gardiner, was looking for an answer to that question last week. Have a wine cork from a nice 2005 Shiraz on the end of a stainless welding rod (to be my sole fuel gauge) and couldn't find a thing in any of the 4 Bingelis books (as far as treating the cork with anything). Have heard of people coating them with varnish, and have seen auto fuel tank floats used in place of cork, any ideas would be appreciated. Rick On Fri, Mar 19, 2010 at 5:05 PM, airlion wrote: > > I am making a cork fuel float as a back up for my capacitince gage. How d oI treat the cork so it won't come apart in the fuel? Gardiner > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of phe many List utilities such as List > http://www.mat ronics.com/Navigator?Pietenpol-Listhttp://www.========= ============ =C2-=C2-=C2-=C2-=C2-http://www .matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp://www.ma tronics.com/contributionFrom: "Gary Boothe" <gboothe5(at)comcast.net>
Date: Mar 20, 2010
Here's a link to a retailer for the float Hans is referring to (.to which Hans is referring): http://johnsmustang.com/Parts/details-5899.html Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of hvandervoo(at)aol.com Sent: Saturday, March 20, 2010 7:18 AM Subject: Re: Pietenpol-List: Re: cork float FLOAT-FUEL TANK SENDING UNIT <http://johnsmustang.com/pictures/classic_mustang/unsorted/200705/c0az-9202- b.jpg> Don't use Cork. I used a '65 Ford Mustang Fuel float If the picture does not show, Google it, you will see a light copper float with a provision to wrap around a wire It is maintenace free, requires no paint, stands up to any fuel and fits through a standard fuel filler neck Hans NX15KV ________________________________________________________________________________
Date: Mar 20, 2010
Thank you again for your sound advise Hans, for only $5.95 I will never have to worry about alcohol dissolving my shellaced or epoxyied or varnished cork, or pieces of cork clogging my fuel filter: http://www.superiormustangparts.com/proddetail.asp?prod=C0AZ-9202-B The only advantage of a cork float to a brass float I can think of is you don't have to worry about a cork float getting a pin hole and filling with fuel. But as someone already mentioned just keep an extra unvented fuel cap around and swap caps after each flight, it will be obvious if a leak develops. rick On Sat, Mar 20, 2010 at 8:18 AM, wrote: > [image: FLOAT-FUEL TANK SENDING UNIT] > > Don't use Cork. > > I used a '65 Ford Mustang Fuel float > > If the picture does not show, Google it, you will see a light copper float > with a provision to wrap around a wire > > It is maintenace free, requires no paint, stands up to any fuel and fits > through a standard fuel filler neck > > Hans > > NX15KV > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 20, 2010
Had a Gosport system - look it up - when I learned aerobatics in a Stearman. Worked quite well. No batteries or black boxes or expensive headsets or wind noise. "Old technology for old airplanes." David Paule ________________________________________________________________________________
Subject: best fuel float ever
Date: Mar 20, 2010
For both my projects a fellow builder/friend/glider instructor, made my fuel floats for me. A standard ping pong ball, drilled and epoxied to a SS wire. (epozy was from the Hardware store,,,Epoweld, or something like that) Then I drilled the cap and soldered in a vertical brass tube from the hobbie store. They never failed me. and has been soaking in gas since 2002. sorry for the fuzzy pics walt evans NX140DL ________________________________________________________________________________
Subject: Once again "those amazing Continentals"
Date: Mar 20, 2010
This morning was nice and warm, so went to the field to start up my Piet. Brought it outside, primed it 1 1/2 times pulled thru 6 blades with the mags off, left meg (impulse) on , first pull it was running. Oil pressure came right up and it sat there and purred for 10 minutes. What a beautiful engine. It was originally built somewhere in the early 40's (by the date etchings on the cyl. skirts) And here over 65 years later, it runs like a champ. Amazing walt evans NX140DL ________________________________________________________________________________
Date: Mar 20, 2010
Or for less money after shipping: http://cgi.ebay.com/ebaymotors/1965-1973-FORD-MUSTANG-COUGAR-FUEL-SENDING-U NIT-FLOAT_W0QQitemZ360239831852QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Ac cessories?hash=item53dff79b2c On Sat, Mar 20, 2010 at 9:02 AM, Gary Boothe wrote: > Here=92s a link to a retailer for the float Hans is referring to (=85to which > Hans is referring): http://johnsmustang.com/Parts/details-5899.html > > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, mounted > Tail done, Fuselage on gear > (18 ribs down=85) > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of * > hvandervoo(at)aol.com > *Sent:* Saturday, March 20, 2010 7:18 AM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: Re: cork float > > > [image: FLOAT-FUEL TANK SENDING UNIT] > > > Don't use Cork. > > > I used a '65 Ford Mustang Fuel float > > > If the picture does not show, Google it, you will see a light copper floa t > with a provision to wrap around a wire > > > It is maintenace free, requires no paint, stands up to any fuel and fits > through a standard fuel filler neck > > > Hans > > > NX15KV > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > =========== =========== =========== =========== > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 20, 2010
Jon, Felix the GN-1 has both cabane lengths front and rear 22.75". The plane flies just like a Piet(longerons level and elevator just down). The plane flies and lands great, the only thing is when I do a full stall landing the tailwheel always hits first. This is not a real problem as it does not cause a bounce, but I wish there was higher AOA at the 3-point attitude. Because of this I am using a smaller tailwheel on the Piet I am building. If I were building a Grega I would make the front cabane an inch longer. Skip > > It looks like the concensus for Piet plans is 1" longer for the front. I will have to do some looking at my Piet plans (I have both Piet and GN-1 drawings) and see what 1" does as far as the angle of incidence. I will report back. Seems like with a few GN-1 builders out there it would be good to settle this as there is no support from Don Grega. > > -------- > Jon Coxwell > ________________________________________________________________________________
Date: Mar 20, 2010
I'm not making a recommendation... I am just curious if anyone is using one of these. I have and PSEngineering AeroComIII. It is a microprocessor controlled device that samples the ambient noise and adjusts the VOX threshold automatically. It works great everywhere I've used it, but I am wondering if it is capable of doing this in an open cockpit. Anyone have experience with this unit? -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291065#291065 ________________________________________________________________________________
Date: Mar 20, 2010
Subject: Photos
Can anyone tell me how to find or see the photos associated with these mess ages are located?- As they say, a picture is worth a thousand words and i sure would like to be able to see all the fine examples of Piet workmanshi p contained here. I'm starting my Piet build This April and I want to build on the best of the experience all of you have to offer. Thanks, first timer Jeff Wilson =0A=0A=0A ________________________________________________________________________________
Subject: Re: Photos
Date: Mar 20, 2010
Welcome Jeff. If you are getting the list real-time via email they should be attached to the message. If you are getting the digest they won't be, but you can access the list via the web-based forum and they should be in the messages there: http://forum.matronics.com Then scroll down to find the Pietenpol list. You can also find the Matronics list archives at: http://www.matronics.com/search Read the instructions on how best to construct your search, as that will ensure you can find what you are looking for. There is a lot of information in the archives. Have a good day, Ryan Sent from my iPhone On Mar 20, 2010, at 2:45 PM, jeff wilson wrote: > Can anyone tell me how to find or see the photos associated with > these messages are located? As they say, a picture is worth a > thousand words and i sure would like to be able to see all the fine > examples of Piet workmanship contained here. I'm starting my Piet > build This April and I want to build on the best of the experience > all of you have to offer. > > Thanks, first timer > Jeff Wilson > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Mar 20, 2010
Subject: simple 1/4" stainless tubing for airspeed pitot tube
Rick, group-- I used some 5 minute epoxy in my leading edge hole to secure my pitot tube figuring if I ever bent it or needed to remove it I could just take a pair of vise grips or pliers and twist it radially to break the bond. I slid the tubing into the hole then lathered a small section w/ a little epoxy honey then slid that forward twisting around to spread the epoxy a little and let cure. All tubing from that 1/4" pitot tube to the air speed indicator is nylon 1/4" tubing and fittings available thru Wicks or ACS. That tubing works nicely for smoke oil delivery to the firewall too where you then make the transition to metal tubing forward of the firewall. Mike C. ________________________________________________________________________________
Date: Mar 20, 2010
Rick that is right. Those headsets we used each had a male plug on the wire and we had different lengths of coax cables up to about 250 feet long. Most of the time we used a coax about 50 feet. They had female connectors on them. No power required. So the only reason you would need an intercom box and a push to talk button is if you want to talk with a passenger and occasionally talk on the com radio? rick -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291096#291096 ________________________________________________________________________________
Date: Mar 20, 2010
Speaking of metalworking you too can be an expert cowl maker http://www.youtube.com/watch?v=OR4CcczpZFs&feature=related http://www.youtube.com/watch?v=LctS-jTER_M&feature=related http://www.youtube.com/watch?v=zHQEGEpXKVA&feature=related Clif . My two big anxiety areas are metalwork in general, Kip Gardner ________________________________________________________________________________
Subject: Re: Once again "those amazing Continentals"
Date: Mar 20, 2010
My 1940 Cont. A-80 does the same thing. What an incredible engine. I have the original engine log and it served many an airplane....including military training in the past 70 years. Mike King GN-1 77MK Corpus Christi, Texas ----- Original Message ----- From: walt Sent: Saturday, March 20, 2010 11:18 AM Subject: Pietenpol-List: Once again "those amazing Continentals" This morning was nice and warm, so went to the field to start up my Piet. Brought it outside, primed it 1 1/2 times pulled thru 6 blades with the mags off, left meg (impulse) on , first pull it was running. Oil pressure came right up and it sat there and purred for 10 minutes. What a beautiful engine. It was originally built somewhere in the early 40's (by the date etchings on the cyl. skirts) And here over 65 years later, it runs like a champ. Amazing walt evans NX140DL ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Mar 21, 2010
I have to agree with you guys. Amazing and incredible. I love my ol' A 65. So reliable. Once you've owned and flown behind one you understand why they're so loved. Gene N502R ----- Original Message ----- From: "Mike King" <mikek120(at)mindspring.com> Sent: Saturday, March 20, 2010 9:31 PM Subject: Re: Pietenpol-List: Once again "those amazing Continentals" > > > My 1940 Cont. A-80 does the same thing. What an incredible engine. > I have the original engine log and it served many an airplane....including > military training in the past 70 years. > > Mike King > GN-1 > 77MK > Corpus Christi, Texas > > > ----- Original Message ----- > From: walt > To: piet list > Sent: Saturday, March 20, 2010 11:18 AM > Subject: Pietenpol-List: Once again "those amazing Continentals" > > > This morning was nice and warm, so went to the field to start up my Piet. > Brought it outside, primed it 1 1/2 times pulled thru 6 blades with the > mags > off, > left meg (impulse) on , first pull it was running. > Oil pressure came right up and it sat there and purred for 10 minutes. > What a beautiful engine. It was originally built somewhere in the early > 40's (by the date etchings on the cyl. skirts) > And here over 65 years later, it runs like a champ. > Amazing > walt evans > NX140DL > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 19:33:00 ________________________________________________________________________________
Date: Mar 21, 2010
Douwe, Our intercom is a FlightTech ITC-401TC. It's a portable that runs off a 9V battery. We replace the battery at every annual, whether it needs it or not. We've mounted in on the back of the front seat, to the right of the pilot's left-leg knee out. Works great with every mix of headsets that we've thrown at it. Jeff -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 21, 2010
Can I get picture Jeff of the intercom and its placement? Thanks Greg, DE -----Original Message----- >From: Jeff Boatright <jboatri(at)emory.edu> >Sent: Mar 21, 2010 7:30 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: intercom > > >Douwe, > >Our intercom is a FlightTech ITC-401TC. It's a portable that runs off >a 9V battery. We replace the battery at every annual, whether it >needs it or not. We've mounted in on the back of the front seat, to >the right of the pilot's left-leg knee out. Works great with every >mix of headsets that we've thrown at it. > >Jeff > > >-- >--- > >Jeffrey H. Boatright, Ph.D. >Associate Professor of Ophthalmology >Emory University School of Medicine >Editor-in-Chief >Molecular Vision > > ________________________________________________________________________________
Date: Mar 21, 2010
Greg, Sure. Here's two shots from westcoastpiet. We've cleaned up the routing of the wires since the photo was taken, using sticky-backed cable clamps from Office Depot or Staples. http://www.westcoastpiet.com/images/Wayne%20Bob%20and%20Jeff/IMG_0126.JPG http://www.westcoastpiet.com/images/Wayne%20Bob%20and%20Jeff/IMG_0127.JPG HTH, Jeff > >Can I get picture Jeff of the intercom and its placement? Thanks Greg, DE > > >-----Original Message----- >>From: Jeff Boatright <jboatri(at)emory.edu> >>Sent: Mar 21, 2010 7:30 AM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Re: intercom >> >> >>Douwe, >> >>Our intercom is a FlightTech ITC-401TC. It's a portable that runs off >>a 9V battery. We replace the battery at every annual, whether it >>needs it or not. We've mounted in on the back of the front seat, to >>the right of the pilot's left-leg knee out. Works great with every >>mix of headsets that we've thrown at it. >> >>Jeff >> >> >>-- >>--- >> >>Jeffrey H. Boatright, Ph.D. >>Associate Professor of Ophthalmology >>Emory University School of Medicine >>Editor-in-Chief >>Molecular Vision >> >> >> >> > > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 21, 2010
luther b green wrote: > My cabanes need rebuilding but are measurable and I will do that and post > results today sometime. The picture of mine in flight looks level to me so I > will keep the length to start with. I'll post the picture also so you guys > can take a look. > Bryan Green > Elgin SC > GN-1 rebuilding > --- Thanks Bryan, I would like to know the lengths and see a picture. Skip, Thanks for that information as well. It sounds like I am in the ball park. Still haven't calculated what 1" equates to on the Piet for comparison but will do it and post it. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291186#291186 ________________________________________________________________________________
Date: Mar 21, 2010
Subject: toe
What kind of toe in or out do I need. Right now with no shims I have 1/4 inch toe in. Measurements taken from front of each wheel to the back of each wheel thanks ,Gardiner Mason ________________________________________________________________________________
Subject: Re: toe
Date: Mar 22, 2010
Hi Gardiner, toe in will acentuate ground looping, it is normal to have zero or slight toe out on a tail dragger. regards Mike T. ----- Original Message ----- From: "airlion" <airlion(at)bellsouth.net> Sent: Monday, March 22, 2010 1:04 PM Subject: Pietenpol-List: toe > > What kind of toe in or out do I need. Right now with no shims I have 1/4 > inch toe in. Measurements taken from front of each wheel to the back of > each wheel thanks ,Gardiner Mason > > ________________________________________________________________________________
From: "Perry Rhoads" <prhoads61(at)frontiernet.net>
Subject: Re: toe
Date: Mar 21, 2010
The tow on N12939 as purchased from Vi Kapler is 0. Handles great on the hard surface I have to operate from. Perry Rhoads N12939 ----- Original Message ----- From: "airlion" <airlion(at)bellsouth.net> Sent: Sunday, March 21, 2010 7:04 PM Subject: Pietenpol-List: toe > > What kind of toe in or out do I need. Right now with no shims I have 1/4 > inch toe in. Measurements taken from front of each wheel to the back of > each wheel thanks ,Gardiner Mason > > > ________________________________________________________________________________
Date: Mar 21, 2010
From: Mike Townsley <allischalmersguy(at)gmail.com>
Subject: Re: toe
I was always told that Toe out was best for a trail dragger. Just a little bit. Mike Townsley airlion wrote: > > What kind of toe in or out do I need. Right now with no shims I have 1/4 inch toe in. Measurements taken from front of each wheel to the back of each wheel thanks ,Gardiner Mason > > > ________________________________________________________________________________
Subject: Empennage questions
Date: Mar 21, 2010
How do most builders tackle the differences in the stems of the tail shapes when adding the capstrips? Picturing the mushroom-shape of the leading edge, the portion that the capstrips glue to are what Im referring to as the stem. Same is true on the T-shaped main beam and the bullet-shaped trailing edge. The T-shaped main beam appears to have the correct stem thickness to allow the capstrips to fit flat. The leading edge mushroom-shape will have a .062 lip at each capstrip and the bullet-shaped trailing edge will have a whopping .125 lip (on each side). Also, The center beam in most cases does not have a gusset at the ends. I have viewed pictures where builders extend existing gussets to provide this support has anyone fabricated and used the tail components per prints without them? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291199#291199 ________________________________________________________________________________
Subject: Phase I complete for 6926J
Date: Mar 21, 2010
Well we lucked out and the runway finely dried out after a really cold and wet winter here in West Virginia. Since March 17 we have had great weather and Ed and I have flown about 12 and 1/2 hours to complete the 25 hour phase I restriction on his Piet. We now have 2 actual flying Piets at Hales Landing. Skip PS. Anyone looking for very a reasonable airport home check out Barnstormers, WV. skipgadd(at)earthlink.net ________________________________________________________________________________
Date: Mar 21, 2010
Subject: Re: Phase I complete for 6926J
Congratulations Skip. The weather here in Florida is really frustrating me. Another 3 day weekend with no flying at all, due to excessive winds and/or rain. I'm still hoping to fly to Sun-N-Fun, but will need some better weather between now and then. Ben Charvet 13.9 hours left in Phase 1 On 3/21/2010 9:12 PM, Skip Gadd wrote: > --> Pietenpol-List message posted by: "Skip Gadd" > > Well we lucked out and the runway finely dried out after a really cold and > wet winter here in West Virginia. Since March 17 we have had great weather > and Ed and I have flown about 12 and 1/2 hours to complete the 25 hour > phase I restriction on his Piet. We now have 2 actual flying Piets at Hales > Landing. > Skip > > PS. Anyone looking for very a reasonable airport home check out > Barnstormers, WV. > > skipgadd(at)earthlink.net > > > ________________________________________________________________________________
Date: Mar 21, 2010
Congrats Skip, and wow, only $149K for a nice house with a 40x40 hanger at your airpark. I could almost afford to retire now to a place that reasonable, and then we would have 3 Piets on the field. rick On Sun, Mar 21, 2010 at 7:12 PM, Skip Gadd wrote: > > Well we lucked out and the runway finely dried out after a really cold and > wet winter here in West Virginia. Since March 17 we have had great weather > and Ed and I have flown about 12 and 1/2 hours to complete the 25 hour > phase I restriction on his Piet. We now have 2 actual flying Piets at Hales > Landing. > Skip > > PS. Anyone looking for very a reasonable airport home check out > Barnstormers, WV. > > skipgadd(at)earthlink.net > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 21, 2010
This is what I have on my tail construction. Where the cap strips were taller then the beams I sanded the capstrips. http://westcoastpiet.com/images/Chris%20Tracy/Tail_Wood_Piece_Location.jpg Exstend the guset to coverer the center beam. Chris Sacramento,Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of BYD Sent: Sunday, March 21, 2010 6:01 PM Subject: Pietenpol-List: Empennage questions How do most builders tackle the differences in the stems of the tail shapes when adding the capstrips? Picturing the mushroom-shape of the leading edge, the portion that the capstrips glue to are what Im referring to as the stem. Same is true on the T-shaped main beam and the bullet-shaped trailing edge. The T-shaped main beam appears to have the correct stem thickness to allow the capstrips to fit flat. The leading edge mushroom-shape will have a .062 lip at each capstrip and the bullet-shaped trailing edge will have a whopping .125 lip (on each side). Also, The center beam in most cases does not have a gusset at the ends. I have viewed pictures where builders extend existing gussets to provide this support has anyone fabricated and used the tail components per prints without them? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291199#291199 ________________________________________________________________________________
Date: Mar 21, 2010
VERY cool idea. Logistics will be the challenge but I'm definitely in! -----Original Message----- From: AMsafetyC(at)aol.com Sent: Mar 19, 2010 7:00 PM Subject: Pietenpol-List: just another idea and concept to ponder Hello good people..... A new idea and concept for the group to ponder. As we all know and have recognized we all share a common bond as fellow lovers of the blue, aviators, builders connected through the design genius of Bernard Pietenpol and his flying contraption the aeroplane. We as a collection of builders have at our disposal some, many and all of the requisite skill levels to construct such a machine with little assistance or intervention from the outside world. The there are those who would love to join our ranks but may be lacking in skills, equipment and time to turn their dream into a reality. From prints to Piet if you will. We know that everyone has a skill set that is good in some areas and not so good in others. Knowing these basic tenants I am curious as to who or what builders would welcome the talents of other builders equipped with tools and skills would be interested in having a group of builders show up at their hanger, barn, basement or garage for a weekend build utilizing all the skills of the people interested in lending a hand to accomplish a number of tasks to get the project going bring the tools to get the certain aspects completed. Woodworkers, metal workers, mechanical workers and the like showing up to get a build from a stalled stage to a more accomplished state of being a Pietenpol. I am speaking about two groups of people, those with the skills and resources capable of committing to a 2 or 3 day weekend to participate in building another Piet as one group. The other group would be a builder or would be builder who in need of assistance in advancing their project to a next or greater level of completion. This again is but another concept for consideration. For example I have both tools not all that I need but certainly more than other that are portable, a trailer to transport them and no skills to speak of. I also have lodging as in a popup/tent camper to bring to a build site for a few days to help another builder. There are others with tools and skills that may also be portable. Through this cooperative of a half dozen or more people who would be willing to share their time and expertise to get another build moving and another builder to a next level of completion. I am wonder how many of us would be willing to pitch in for a week end to help and how many would be interested in receiving those willing to help. Before I go any further with this concept it would be nice to know if there is any interest at all in helping or being helped. Just in case you were wondering, I have all of my tools marked for identification purposes. I know how this works. Helpers bring tools and skills and resources as needed helped provide a keg on tap burgers and a place for a fire and I think we are cooking with gas! What say you? John ________________________________________________________________________________
Date: Mar 21, 2010
another question along the same lines would be" could a PIET be built by as many builders as it would take over the Brodhead weekend?"Much the same wa y as they build the aluminum stol aircraft, CH701,at the Sun N Fun weekend. Then auction or raffle it off at the end of the weekend for some lucky pers on to take home.=0A=0A=0A=0A________________________________=0AFrom: Jim Ma rkle =0ATo: pietenpol-list(at)matronics.com=0ASent: Sun, March 21, 2010 10:47:10 PM=0ASubject: Re: Pietenpol-List: just anothe Markle =0A=0AVERY cool idea.- Logistics will be the challenge but I'm definitely in!=0A=0A=0A=0A-----Original Message--- --=0A=0AFrom: AMsafetyC(at)aol.com=0A=0ASent: Mar 19, 2010 7:00 PM=0A=0ATo: pi etenpol-list(at)matronics.com=0A=0ASubject: Pietenpol-List: just another idea and concept to ponder=0A=0A=0A=0A=0A=0A=0A=0A=0AHello good people.....=0A =0AA new idea and concept for the group to ponder.=0A=0AAs we all know and have recognized we all share a common bond as fellow =0Alovers of the blue, aviators, builders connected through the design genius of =0ABernard Piete npol and his flying contraption the aeroplane. We as a collection =0Aof bui lders have at our disposal some, many and all of the requisite skill =0Alev els to construct such a machine with little assistance or intervention from =0Athe outside world.=0A=0AThe there are those who would love to join our ranks but may be lacking in =0Askills, equipment and time to turn their dre am into a reality. From =0Aprints to Piet if you will. We know that everyon e has a skill set that is good =0Ain some areas and not so good in others. Knowing these basic tenants I am =0Acurious as to who or what builders woul d welcome the talents of other builders =0Aequipped with tools and skills w ould be interested in having a group of builders =0Ashow up at their hanger , barn, basement or garage for a weekend build utilizing =0Aall the skills of the people interested in lending a hand to accomplish a number =0Aof tas ks to get the project going bring the tools to get the certain aspects =0Ac ompleted. Woodworkers, metal workers, mechanical workers and the like showi ng =0Aup to get a build from a stalled stage to a more accomplished state o f being a =0APietenpol.=0A=0AI am speaking about two groups of people, thos e with the skills and =0Aresources capable of committing to a 2 or 3 day we ekend to participate in =0Abuilding another Piet as one group. The other gr oup would be a builder or would =0Abe builder who in need of assistance in advancing their project to a next or =0Agreater level of completion.=0A=0AT his again is but another concept for consideration. For example I have =0Ab oth tools not all that I need but certainly more than other that are portab le, =0Aa trailer to transport them and no skills to speak of. I also have l odging as in =0Aa popup/tent camper to bring to a build site for a few days to help another =0Abuilder. There are others with tools and skills that ma y also be portable. =0A=0A=0AThrough this cooperative of a half dozen or mo re people who would be =0Awilling to share their time and expertise to get another build moving and =0Aanother builder to a next level of completion. =0A=0AI am wonder how many of us would be willing to pitch in for a week en d to =0Ahelp and how many would be interested in receiving those willing to help. =0A=0ABefore I go any further with this concept it would be nice to know if there =0Ais any interest at all in helping or being helped.=0A=0AJu st in case you were wondering, I have all of my tools marked for =0Aidentif ication purposes. I know how this works.=0A=0AHelpers bring tools and skill s and resources as needed helped =0Aprovide a keg on tap burgers and a plac e for a fire and I think we are cooking =0Awith gas! =0A=0AWhat say you?=0A ======================== ________________________________________________________________________________
Date: Mar 21, 2010
The only thing is, with Sun-N-Fun or Oshkosh you're talking week-long events. At Brodhead, depending on when you get there, you really only have two full days: Friday, and Saturday, and Saturday you have the forums during the day. The place turns into a ghost town pretty quick on Sunday since everyone has to either get home or head to Oshkosh. Don't get me wrong, I'm all for helping people out, but I'd rather spend my all-too-short time there on that weekend enjoying the people and the airplanes, and not in a hangar working on a project. You don't have to wait for bucked rivets to dry, either.... Maybe we could knock Oshkosh down to a couple days, and expand Brodhead to a full week... :) Have a good night, Ryan On Sun, Mar 21, 2010 at 10:12 PM, H RULE wrote: > another question along the same lines would be" could a PIET be built by as > many builders as it would take over the Brodhead weekend?"Much the same way > as they build the aluminum stol aircraft, CH701,at the Sun N Fun > weekend.Then auction or raffle it off at the end of the weekend for some > lucky person to take home. > > ------------------------------ > *From:* Jim Markle > > *To:* pietenpol-list(at)matronics.com > *Sent:* Sun, March 21, 2010 10:47:10 PM > *Subject:* Re: Pietenpol-List: just another idea and concept to ponder > > jim_markle(at)mindspring.com> > > VERY cool idea. Logistics will be the challenge but I'm definitely in! > > > -----Original Message----- > > From: AMsafetyC(at)aol.com > > Sent: Mar 19, 2010 7:00 PM > > To: pietenpol-list(at)matronics.com > > Subject: Pietenpol-List: just another idea and concept to ponder > > > Hello good people..... > > A new idea and concept for the group to ponder. > > As we all know and have recognized we all share a common bond as fellow > lovers of the blue, aviators, builders connected through the design genius > of > Bernard Pietenpol and his flying contraption the aeroplane. We as a > collection > of builders have at our disposal some, many and all of the requisite skill > levels to construct such a machine with little assistance or intervention > from > the outside world. > > The there are those who would love to join our ranks but may be lacking in > skills, equipment and time to turn their dream into a reality. From > prints to Piet if you will. We know that everyone has a skill set that is > good > in some areas and not so good in others. Knowing these basic tenants I am > curious as to who or what builders would welcome the talents of other > builders > equipped with tools and skills would be interested in having a group of > builders > show up at their hanger, barn, basement or garage for a weekend build > utilizing > all the skills of the people interested in lending a hand to accomplish a > number > of tasks to get the project going bring the tools to get the certain > aspects > completed. Woodworkers, metal workers, mechanical workers and the like > showing > up to get a build from a stalled stage to a more accomplished state of > being a > Pietenpol. > > I am speaking about two groups of people, those with the skills and > resources capable of committing to a 2 or 3 day weekend to participate in > building another Piet as one group. The other group would be a builder or > would > be builder who in need of assistance in advancing their project to a next > or > greater level of completion. > > This again is but another concept for consideration. For example I have > both tools not all that I need but certainly more than other that are > portable, > a trailer to transport them and no skills to speak of. I also have lodging > as in > a popup/tent camper to bring to a build site for a few days to help another > > builder. There are others with tools and skills that may also be portable. > > > Through this cooperative of a half dozen or more people who would be > willing to share their time and expertise to get another build moving and > another builder to a next level of completion. > > I am wonder how many of us would be willing to pitch in for a week end to > help and how many would be interested in receiving those willing to help. > > Before I go any further with this concept it would be nice to know if there > > is any interest at all in helping or being helped. > > Just in case you were wondering, I have all of my tools marked for > identification purposes. I know how this works. > > Helpers bring tools and skills and resources as needed helped > provide a keg on tap burgers and a place for a fire and I think we are > cooking > with gas! > > What say you? > http://www.matronics.com/Navigator?sp; //forums.matronics.com/" > target=_blank>http://forums.matronics.com > > > * > > * > > ________________________________________________________________________________
Subject: Re: Empennage questions
Date: Mar 21, 2010
Cut a partial relief in the stem and fair the capstrip so it is flush with the lip. The center beam needs to have a gusset on the end. Greg Cardinal ----- Original Message ----- From: "BYD" <byd(at)att.net> Sent: Sunday, March 21, 2010 8:01 PM Subject: Pietenpol-List: Empennage questions > > How do most builders tackle the differences in the stems of the tail > shapes when adding the capstrips? > > Picturing the mushroom-shape of the leading edge, the portion that the > capstrips glue to are what I?Tm referring to as the stem. Same is true > on the T-shaped main beam and the bullet-shaped trailing edge. The > T-shaped main beam appears to have the correct stem thickness to allow the > capstrips to fit flat. The leading edge mushroom-shape will have a > .062? lip at each capstrip and the bullet-shaped trailing edge will have > a whopping .125? lip (on each side). > > Also, > The ?ocenter beam? in most cases does not have a gusset at the ends. I > have viewed pictures where builders extend existing gussets to provide > this support ?" has anyone fabricated and used the tail components per > prints without them? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291199#291199 > > > ________________________________________________________________________________
Date: Mar 21, 2010
No, that couldn't be done. Not to a completed ship if that's what you are suggesting. A bare fuselage would take 6 days alone. Just think of the work involved in the wings. Dick N. ----- Original Message ----- From: H RULE To: pietenpol-list(at)matronics.com Sent: Sunday, March 21, 2010 10:12 PM Subject: Re: Pietenpol-List: just another idea and concept to ponder another question along the same lines would be" could a PIET be built by as many builders as it would take over the Brodhead weekend?"Much the same way as they build the aluminum stol aircraft, CH701,at the Sun N Fun weekend.Then auction or raffle it off at the end of the weekend for some lucky person to take home. ------------------------------------------------------------------------- ----- From: Jim Markle <jim_markle(at)mindspring.com> To: pietenpol-list(at)matronics.com Sent: Sun, March 21, 2010 10:47:10 PM Subject: Re: Pietenpol-List: just another idea and concept to ponder VERY cool idea. Logistics will be the challenge but I'm definitely in! -----Original Message----- From: AMsafetyC(at)aol.com Sent: Mar 19, 2010 7:00 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: just another idea and concept to ponder Hello good people..... A new idea and concept for the group to ponder. As we all know and have recognized we all share a common bond as fellow lovers of the blue, aviators, builders connected through the design genius of Bernard Pietenpol and his flying contraption the aeroplane. We as a collection of builders have at our disposal some, many and all of the requisite skill levels to construct such a machine with little assistance or intervention from the outside world. The there are those who would love to join our ranks but may be lacking in skills, equipment and time to turn their dream into a reality. From prints to Piet if you will. We know that everyone has a skill set that is good in some areas and not so good in others. Knowing these basic tenants I am curious as to who or what builders would welcome the talents of other builders equipped with tools and skills would be interested in having a group of builders show up at their hanger, barn, basement or garage for a weekend build utilizing all the skills of the people interested in lending a hand to accomplish a number of tasks to get the project going bring the tools to get the certain aspects completed. Woodworkers, metal workers, mechanical workers and the like showing up to get a build from a stalled stage to a more accomplished state of being a Pietenpol. I am speaking about two groups of people, those with the skills and resources capable of committing to a 2 or 3 day weekend to participate in building another Piet as one group. The other group would be a builder or would be builder who in need of assistance in advancing their project to a next or greater level of completion. This again is but another concept for consideration. For example I have both tools not all that I need but certainly more than other that are portable, a trailer to transport them and no skills to speak of. I also have lodging as in a popup/tent camper to bring to a build site for a few days to help another builder. There are others with tools and skills that may also be portable. Through this cooperative of a half dozen or more people who would be willing to share their time and expertise to get another build moving and another builder to a next level of completion. I am wonder how many of us would be willing to pitch in for a week end to help and how many would be interested in receiving those willing to help. Before I go any further with this concept it would be nice to know if there is any interest at all in helping or being helped. Just in case you were wondering, I have all of my tools marked for identification purposes. I know how this works. Helpers bring tools and skills and resources as needed helped provide a keg on tap burgers and a place for a fire and I think we are cooking with gas! What say you? http://www.matronics.com/Navigator?sp; //forums.matronics.com/" target=_blank>http://forums.matronics.com ________________________________________________________________________________
Date: Mar 22, 2010
How bout a metal fuselage and wood wings or perhaps metal wings as well.Eac h man would only have to spend a max 1/2 hour at a time,not the whole weeke nd.I have seen pictures on this web page of some pretty nice metal PIETS.I like the idea of making Brodhead a whole week as well.Whether made out of w ood or metal,the project could span a few years of Brodhead get togethers.J ust throwing ideas out here.-=0A=0A=0A=0A=0A_____________________________ ___=0AFrom: Dick N <horzpool(at)goldengate.net>=0ATo: pietenpol-list@matronics .com=0ASent: Mon, March 22, 2010 12:12:35 AM=0ASubject: Re: Pietenpol-List: just another idea and concept to ponder=0A=0A=0ANo, that couldn't be done. - Not to a completed ship if that's what you are suggesting.- A bare fu selage would take 6 days alone.- Just think of the work involved in the w ings.- =0ADick N.=0A----- Original Message ----- =0A>From: H RULE =0A>To: pietenpol-list(at)matronics.com =0A>Sent: Sunday, March 21, 2010 10:12 PM=0A> Subject: Re: Pietenpol-List: just another idea and concept to ponder=0A>=0A >=0A>another question along the same lines would be" could a PIET be built by as many builders as it would take over the Brodhead weekend?"Much the sa me way as they build the aluminum stol aircraft, CH701,at the Sun N Fun wee kend.Then auction or raffle it off at the end of the weekend for some lucky person to take home.=0A>=0A>=0A>=0A________________________________=0AFrom : Jim Markle =0A>To: pietenpol-list(at)matronics.co m=0A>Sent: Sun, March 21, 2010 10:47:10 PM=0A>Subject: Re: Pietenpol-List: just another idea and concept to ponder=0A>=0A>--> Pietenpol-List message p osted by: Jim Markle =0A>=0A>VERY cool idea.- Logistics will be the challenge but I'm definitely in!=0A>=0A>=0A>=0A>----- Original Message-----=0A>=0A>From: AMsafetyC(at)aol.com=0A>=0A>Sent: Mar 19, 2 010 7:00 PM=0A>=0A>To: pietenpol-list(at)matronics.com=0A>=0A>Subject: Pietenp ol-List: just another idea and concept to ponder=0A>=0A>=0A>=0A>=0A>=0A>=0A >=0A>=0A>Hello good people.....=0A>=0A>A new idea and concept for the group to ponder.=0A>=0A>As we all know and have recognized we all share a common bond as fellow =0A>lovers of the blue, aviators, builders connected throug h the design genius of =0A>Bernard Pietenpol and his flying contraption the aeroplane. We as a collection =0A>of builders have at our disposal some, m any and all of the requisite skill =0A>levels to construct such a machine w ith little assistance or intervention from =0A>the outside world.=0A>=0A>Th e there are those who would love to join our ranks but may be lacking in =0A>skills, equipment and time to turn their dream into a reality. From =0A >prints to Piet if you will. We know that everyone has a skill set that is good =0A>in some areas and not so good in others. Knowing these basic tenan ts I am =0A>curious as to who or what builders would welcome the talents of other builders =0A>equipped with tools and skills would be interested in h aving a group of builders =0A>show up at their hanger, barn, basement or ga rage for a weekend build utilizing =0A>all the skills of the people interes ted in lending a hand to accomplish a number =0A>of tasks to get the projec t going bring the tools to get the certain aspects =0A>completed. Woodworke rs, metal workers, mechanical workers and the like showing =0A>up to get a build from a stalled stage to a more accomplished state of being a =0A>Piet enpol.=0A>=0A>I am speaking about two groups of people, those with the skil ls and =0A>resources capable of committing to a 2 or 3 day weekend to parti cipate in =0A>building another Piet as one group. The other group would be a builder or would =0A>be builder who in need of assistance in advancing th eir project to a next or =0A>greater level of completion.=0A>=0A>This again is but another concept for consideration. For example I have =0A>both tool s not all that I need but certainly more than other that are portable, =0A> a trailer to transport them and no skills to speak of. I also have lodging as in =0A>a popup/tent camper to bring to a build site for a few days to he lp another =0A>builder. There are others with tools and skills that may als o be portable. =0A>=0A>=0A>Through this cooperative of a half dozen or more people who would be =0A>willing to share their time and expertise to get a nother build moving and =0A>another builder to a next level of completion. =0A>=0A>I am wonder how many of us would be willing to pitch in for a week end to =0A>help and how many would be interested in receiving those willing to help. =0A>=0A>Before I go any further with this concept it would be nic e to know if there =0A>is any interest at all in helping or being helped. =0A>=0A>Just in case you were wondering, I have all of my tools marked for =0A>identification purposes. I know how this works.=0A>=0A>Helpers bring to ols and skills and resources as needed helped =0A>provide a keg on tap burg ers and a place for a fire and I think we are cooking =0A>with gas! =0A>=0A >What say you?=0A>http://www.matronics.com/Navigator?sp; - - - - // forums.matronics.com/" target=_blank>http://forums.matronics.com=0A>=0A> =0A>=0A>=0A>=0A>=0A>href="http://www.matronics.com/Navigator?Pietenpol-Li st">http://www.matronics.com/Navigator?Pietenpol-List=0A>href="http://for ums.matronics.com">http://forums.matronics.com=0A>href="http://www.matron =========== ________________________________________________________________________________
Subject: Re: just another idea and concept to ponder
Date: Mar 22, 2010
VmFsdWFibGUgY29tbWVudHMgdGhhbmtzDQoNCkFjdHVhbGx5IG5vdCB0YWxraW5nIGFib3V0IGEg Y29tcGxldGUgc2hpcCBhbmQgbm90IGF0IEJyb2RoZWFkLiANCg0KSnVzdCBhdCBhIGJ1aWxkZXJz IGxvY2F0aW9uIGxvb2tpbmcgZm9yIGEgd2Vla2VuZCBvZiBpbnRlbnNlIGJ1aWxkaW5nIGJ5IGEg Z3JvdXAgYWJsZSBhbmQgY2FwYWJsZSBvZiB3b3JraW5nIG9uIGV2ZXJ5dGhpbmcgaW4gbmVlZCBv ZiBoZWxwIHRvIGFkdmFuY2UgdGhlIHByb2plY3QuIA0KDQpBbGwgYmFzZWQgb24gdGhlIGJ1aWxk ZXJzIHdhbnRzLG5lZWRzLHNjaGVkdWxlIGFuZCByYXcgbWF0ZXJpYWxzL3BhcnRzIG9uIGhhbmQu IA0KDQpXaXRoIGVub3VnaCAgYmVuY2ggc3BhY2UsY2xhbXBzLCBqaWdnaW5nIGFuZCBhIHNhdyBt YW4gaXQgaXMgcG9zc2libGUgdG8gZnJhbWUgb3V0IHRoZSBmdXNlIGFuZCB0YWlsIGZlYXRoZXJz IGluIGEgd2Vla2VuZC4gDQoNCkkgYW0gbm90IGFkdm9jYXRpbmcgd2UgZG8gdGhpcyB0b21vcnJv dyBidXQgaWYgdGhlcmUgd2VyZSBpbnRlcmVzdGVkIHBhcnRpZXMgbWF5YmUgaW4gNiBtb250aCBv ciBzbw0KDQpKb2huDQpTZW50IGZyb20gbXkgVmVyaXpvbiBXaXJlbGVzcyBCbGFja0JlcnJ5DQoN Ci0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAiRGljayBOIiA8aG9yenBvb2xAZ29s ZGVuZ2F0ZS5uZXQ+DQpEYXRlOiBTdW4sIDIxIE1hciAyMDEwIDIzOjEyOjM1IA0KVG86IDxwaWV0 ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBq dXN0IGFub3RoZXIgaWRlYSBhbmQgY29uY2VwdCB0byBwb25kZXINCg0KTm8sIHRoYXQgY291bGRu J3QgYmUgZG9uZS4gIE5vdCB0byBhIGNvbXBsZXRlZCBzaGlwIGlmIHRoYXQncyB3aGF0IHlvdSBh cmUgc3VnZ2VzdGluZy4gIEEgYmFyZSBmdXNlbGFnZSB3b3VsZCB0YWtlIDYgZGF5cyBhbG9uZS4g IEp1c3QgdGhpbmsgb2YgdGhlIHdvcmsgaW52b2x2ZWQgaW4gdGhlIHdpbmdzLiAgDQpEaWNrIE4u DQogIC0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0gDQogIEZyb206IEggUlVMRSANCiAgVG86 IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20gDQogIFNlbnQ6IFN1bmRheSwgTWFyY2ggMjEs IDIwMTAgMTA6MTIgUE0NCiAgU3ViamVjdDogUmU6IFBpZXRlbnBvbC1MaXN0OiBqdXN0IGFub3Ro ZXIgaWRlYSBhbmQgY29uY2VwdCB0byBwb25kZXINCg0KDQogIGFub3RoZXIgcXVlc3Rpb24gYWxv bmcgdGhlIHNhbWUgbGluZXMgd291bGQgYmUiIGNvdWxkIGEgUElFVCBiZSBidWlsdCBieSBhcyBt YW55IGJ1aWxkZXJzIGFzIGl0IHdvdWxkIHRha2Ugb3ZlciB0aGUgQnJvZGhlYWQgd2Vla2VuZD8i TXVjaCB0aGUgc2FtZSB3YXkgYXMgdGhleSBidWlsZCB0aGUgYWx1bWludW0gc3RvbCBhaXJjcmFm dCwgQ0g3MDEsYXQgdGhlIFN1biBOIEZ1biB3ZWVrZW5kLlRoZW4gYXVjdGlvbiBvciByYWZmbGUg aXQgb2ZmIGF0IHRoZSBlbmQgb2YgdGhlIHdlZWtlbmQgZm9yIHNvbWUgbHVja3kgcGVyc29uIHRv IHRha2UgaG9tZS4NCg0KDQoNCi0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLQ0KICBGcm9tOiBKaW0gTWFy a2xlIDxqaW1fbWFya2xlQG1pbmRzcHJpbmcuY29tPg0KICBUbzogcGlldGVucG9sLWxpc3RAbWF0 cm9uaWNzLmNvbQ0KICBTZW50OiBTdW4sIE1hcmNoIDIxLCAyMDEwIDEwOjQ3OjEwIFBNDQogIFN1 YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDoganVzdCBhbm90aGVyIGlkZWEgYW5kIGNvbmNlcHQg dG8gcG9uZGVyDQoNCiAgLS0+IFBpZXRlbnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBKaW0g TWFya2xlIDxqaW1fbWFya2xlQG1pbmRzcHJpbmcuY29tPg0KDQogIFZFUlkgY29vbCBpZGVhLiAg TG9naXN0aWNzIHdpbGwgYmUgdGhlIGNoYWxsZW5nZSBidXQgSSdtIGRlZmluaXRlbHkgaW4hDQoN Cg0KDQogIC0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQoNCiAgRnJvbTogQU1zYWZldHlDQGFv bC5jb20NCg0KICBTZW50OiBNYXIgMTksIDIwMTAgNzowMCBQTQ0KDQogIFRvOiBwaWV0ZW5wb2wt bGlzdEBtYXRyb25pY3MuY29tDQoNCiAgU3ViamVjdDogUGlldGVucG9sLUxpc3Q6IGp1c3QgYW5v dGhlciBpZGVhIGFuZCBjb25jZXB0IHRvIHBvbmRlcg0KDQoNCg0KDQoNCg0KDQoNCiAgSGVsbG8g Z29vZCBwZW9wbGUuLi4uLg0KDQogIEEgbmV3IGlkZWEgYW5kIGNvbmNlcHQgZm9yIHRoZSBncm91 cCB0byBwb25kZXIuDQoNCiAgQXMgd2UgYWxsIGtub3cgYW5kIGhhdmUgcmVjb2duaXplZCB3ZSBh bGwgc2hhcmUgYSBjb21tb24gYm9uZCBhcyBmZWxsb3cgDQogIGxvdmVycyBvZiB0aGUgYmx1ZSwg YXZpYXRvcnMsIGJ1aWxkZXJzIGNvbm5lY3RlZCB0aHJvdWdoIHRoZSBkZXNpZ24gZ2VuaXVzIG9m IA0KICBCZXJuYXJkIFBpZXRlbnBvbCBhbmQgaGlzIGZseWluZyBjb250cmFwdGlvbiB0aGUgYWVy b3BsYW5lLiBXZSBhcyBhIGNvbGxlY3Rpb24gDQogIG9mIGJ1aWxkZXJzIGhhdmUgYXQgb3VyIGRp c3Bvc2FsIHNvbWUsIG1hbnkgYW5kIGFsbCBvZiB0aGUgcmVxdWlzaXRlIHNraWxsIA0KICBsZXZl bHMgdG8gY29uc3RydWN0IHN1Y2ggYSBtYWNoaW5lIHdpdGggbGl0dGxlIGFzc2lzdGFuY2Ugb3Ig aW50ZXJ2ZW50aW9uIGZyb20gDQogIHRoZSBvdXRzaWRlIHdvcmxkLg0KDQogIFRoZSB0aGVyZSBh cmUgdGhvc2Ugd2hvIHdvdWxkIGxvdmUgdG8gam9pbiBvdXIgcmFua3MgYnV0IG1heSBiZSBsYWNr aW5nIGluIA0KICBza2lsbHMsIGVxdWlwbWVudCBhbmQgdGltZSB0byB0dXJuIHRoZWlyIGRyZWFt IGludG8gYSByZWFsaXR5LiBGcm9tIA0KICBwcmludHMgdG8gUGlldCBpZiB5b3Ugd2lsbC4gV2Ug a25vdyB0aGF0IGV2ZXJ5b25lIGhhcyBhIHNraWxsIHNldCB0aGF0IGlzIGdvb2QgDQogIGluIHNv bWUgYXJlYXMgYW5kIG5vdCBzbyBnb29kIGluIG90aGVycy4gS25vd2luZyB0aGVzZSBiYXNpYyB0 ZW5hbnRzIEkgYW0gDQogIGN1cmlvdXMgYXMgdG8gd2hvIG9yIHdoYXQgYnVpbGRlcnMgd291bGQg d2VsY29tZSB0aGUgdGFsZW50cyBvZiBvdGhlciBidWlsZGVycyANCiAgZXF1aXBwZWQgd2l0aCB0 b29scyBhbmQgc2tpbGxzIHdvdWxkIGJlIGludGVyZXN0ZWQgaW4gaGF2aW5nIGEgZ3JvdXAgb2Yg YnVpbGRlcnMgDQogIHNob3cgdXAgYXQgdGhlaXIgaGFuZ2VyLCBiYXJuLCBiYXNlbWVudCBvciBn YXJhZ2UgZm9yIGEgd2Vla2VuZCBidWlsZCB1dGlsaXppbmcgDQogIGFsbCB0aGUgc2tpbGxzIG9m IHRoZSBwZW9wbGUgaW50ZXJlc3RlZCBpbiBsZW5kaW5nIGEgaGFuZCB0byBhY2NvbXBsaXNoIGEg bnVtYmVyIA0KICBvZiB0YXNrcyB0byBnZXQgdGhlIHByb2plY3QgZ29pbmcgYnJpbmcgdGhlIHRv b2xzIHRvIGdldCB0aGUgY2VydGFpbiBhc3BlY3RzIA0KICBjb21wbGV0ZWQuIFdvb2R3b3JrZXJz LCBtZXRhbCB3b3JrZXJzLCBtZWNoYW5pY2FsIHdvcmtlcnMgYW5kIHRoZSBsaWtlIHNob3dpbmcg DQogIHVwIHRvIGdldCBhIGJ1aWxkIGZyb20gYSBzdGFsbGVkIHN0YWdlIHRvIGEgbW9yZSBhY2Nv bXBsaXNoZWQgc3RhdGUgb2YgYmVpbmcgYSANCiAgUGlldGVucG9sLg0KDQogIEkgYW0gc3BlYWtp bmcgYWJvdXQgdHdvIGdyb3VwcyBvZiBwZW9wbGUsIHRob3NlIHdpdGggdGhlIHNraWxscyBhbmQg DQogIHJlc291cmNlcyBjYXBhYmxlIG9mIGNvbW1pdHRpbmcgdG8gYSAyIG9yIDMgZGF5IHdlZWtl bmQgdG8gcGFydGljaXBhdGUgaW4gDQogIGJ1aWxkaW5nIGFub3RoZXIgUGlldCBhcyBvbmUgZ3Jv dXAuIFRoZSBvdGhlciBncm91cCB3b3VsZCBiZSBhIGJ1aWxkZXIgb3Igd291bGQgDQogIGJlIGJ1 aWxkZXIgd2hvIGluIG5lZWQgb2YgYXNzaXN0YW5jZSBpbiBhZHZhbmNpbmcgdGhlaXIgcHJvamVj dCB0byBhIG5leHQgb3IgDQogIGdyZWF0ZXIgbGV2ZWwgb2YgY29tcGxldGlvbi4NCg0KICBUaGlz IGFnYWluIGlzIGJ1dCBhbm90aGVyIGNvbmNlcHQgZm9yIGNvbnNpZGVyYXRpb24uIEZvciBleGFt cGxlIEkgaGF2ZSANCiAgYm90aCB0b29scyBub3QgYWxsIHRoYXQgSSBuZWVkIGJ1dCBjZXJ0YWlu bHkgbW9yZSB0aGFuIG90aGVyIHRoYXQgYXJlIHBvcnRhYmxlLCANCiAgYSB0cmFpbGVyIHRvIHRy YW5zcG9ydCB0aGVtIGFuZCBubyBza2lsbHMgdG8gc3BlYWsgb2YuIEkgYWxzbyBoYXZlIGxvZGdp bmcgYXMgaW4gDQogIGEgcG9wdXAvdGVudCBjYW1wZXIgdG8gYnJpbmcgdG8gYSBidWlsZCBzaXRl IGZvciBhIGZldyBkYXlzIHRvIGhlbHAgYW5vdGhlciANCiAgYnVpbGRlci4gVGhlcmUgYXJlIG90 aGVycyB3aXRoIHRvb2xzIGFuZCBza2lsbHMgdGhhdCBtYXkgYWxzbyBiZSBwb3J0YWJsZS4gDQoN Cg0KICBUaHJvdWdoIHRoaXMgY29vcGVyYXRpdmUgb2YgYSBoYWxmIGRvemVuIG9yIG1vcmUgcGVv cGxlIHdobyB3b3VsZCBiZSANCiAgd2lsbGluZyB0byBzaGFyZSB0aGVpciB0aW1lIGFuZCBleHBl cnRpc2UgdG8gZ2V0IGFub3RoZXIgYnVpbGQgbW92aW5nIGFuZCANCiAgYW5vdGhlciBidWlsZGVy IHRvIGEgbmV4dCBsZXZlbCBvZiBjb21wbGV0aW9uLg0KDQogIEkgYW0gd29uZGVyIGhvdyBtYW55 IG9mIHVzIHdvdWxkIGJlIHdpbGxpbmcgdG8gcGl0Y2ggaW4gZm9yIGEgd2VlayBlbmQgdG8gDQog IGhlbHAgYW5kIGhvdyBtYW55IHdvdWxkIGJlIGludGVyZXN0ZWQgaW4gcmVjZWl2aW5nIHRob3Nl IHdpbGxpbmcgdG8gaGVscC4gDQoNCiAgQmVmb3JlIEkgZ28gYW55IGZ1cnRoZXIgd2l0aCB0aGlz IGNvbmNlcHQgaXQgd291bGQgYmUgbmljZSB0byBrbm93IGlmIHRoZXJlIA0KICBpcyBhbnkgaW50 ZXJlc3QgYXQgYWxsIGluIGhlbHBpbmcgb3IgYmVpbmcgaGVscGVkLg0KDQogIEp1c3QgaW4gY2Fz ZSB5b3Ugd2VyZSB3b25kZXJpbmcsIEkgaGF2ZSBhbGwgb2YgbXkgdG9vbHMgbWFya2VkIGZvciAN CiAgaWRlbnRpZmljYXRpb24gcHVycG9zZXMuIEkga25vdyBob3cgdGhpcyB3b3Jrcy4NCg0KICBI ZWxwZXJzIGJyaW5nIHRvb2xzIGFuZCBza2lsbHMgYW5kIHJlc291cmNlcyBhcyBuZWVkZWQgaGVs cGVkIA0KICBwcm92aWRlIGEga2VnIG9uIHRhcCBidXJnZXJzIGFuZCBhIHBsYWNlIGZvciBhIGZp cmUgYW5kIEkgdGhpbmsgd2UgYXJlIGNvb2tpbmcgDQogIHdpdGggZ2FzISANCg0KICBXaGF0IHNh eSB5b3U/DQogIGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/c3A7ICAgICAgICAg Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8iIHRhcmdldD1fYmxhbms+aHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tDQoNCg0KDQoNCg0KDQoNCg= ________________________________________________________________________________
Subject: Fuselage Update
Date: Mar 22, 2010
Fuselage is going well. I updated my site with some more photos. http://www.textors.com/PietProject.html Jack DSM www.textors.com <http://www.textors.com/> ________________________________________________________________________________
Subject: Re: Fuselage Update
Date: Mar 22, 2010
Jack, You should be very proud of your work. Very nice websight. Dan Helsper Poplar Grove, IL. NX929DH -----Original Message----- From: Jack <jack(at)textors.com> Sent: Mon, Mar 22, 2010 6:03 am Subject: Pietenpol-List: Fuselage Update Fuselage is going well. I updated my site with some more photos. http:// www.textors.com/PietProject.html Jack DSM www.textors.com ________________________________________________________________________________
Subject: A-65 cost
Date: Mar 22, 2010
A friend offered me an A-65, with spare mags, carburetor, pieces as required. Describes it in good shape, running recently, replaced for larger engine. How does $1800 sound? I know there can be a big disparity, but I have no recent price experience. I would probably overhaul anyway based on what I am able to do myself and/or cost to have someone else do it if required. Any recent cost experiences? Thanks, Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291233#291233 ________________________________________________________________________________
Subject: Re: A-65 cost
Date: Mar 22, 2010
Steve; that sounds like a piece of junk and you should run away as fast as you can. Dangerous, unreliable. Give me your friend's name and phone number so I can buy it and keep you out of trouble ;o) Seriously, you should jump on it. I just sold the A65 that came out of 41CC for a good deal more than that, so I think you'll be getting a great deal. Note the recent emails from Walt and others on how nice these old Continentals are. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291234#291234 ________________________________________________________________________________
Date: Mar 22, 2010
Looking very nice, Jack Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Monday, March 22, 2010 7:04 AM Subject: Pietenpol-List: Fuselage Update Fuselage is going well. I updated my site with some more photos. http://www.textors.com/PietProject.html Jack DSM www.textors.com <http://www.textors.com/> ________________________________________________________________________________
Date: Mar 22, 2010
Subject: for the absolute best source of Pietenpol photos anywhere
By far, without question, Chris Tracy's Westcoast Piet web site has the fin est selection of Pietenpol photos anywhere. http://www.westcoastpiet.com/pictures.htm You could spend hours here easily and you'll see more detail and more plane s than you would see in going to five Brodhead events. (but come anyway, please......espec ially if you wear high black dress socks up to your knees in sandals with suspenders, a plaid shirt, and wear a pith he lmet) ________________________________________________________________________________
Date: Mar 22, 2010
From: Pastor Mike Townsley <allischalmersguy(at)gmail.com>
Looks very nice Jack! Mike Townsley On Mon, Mar 22, 2010 at 6:03 AM, Jack wrote: > Fuselage is going well. I updated my site with some more photos. > http://www.textors.com/PietProject.html > > Jack > > DSM > > www.textors.com > > ________________________________________________________________________________
Date: Mar 22, 2010
Would you want to fly a plane built using the primary goal of 'Did it in a weekend?' I would have my hesitations. Are they still doing the build-it-during-the-week thing with the Zenair's at Sun 'n Fun? I remember them doing it back in the early 90's, but I thought the practice had been discontinued. The choreography for a Piet would be far different. A riveted joint is bang bang bang, ready to fly, right away, no glue to dry. Figuring out how to coordinate construction of assemblies while the glue is drying on others would be quite the challenge. I suppose you could have everybody build a rib (one glue pause) then assemble them all (second glue pause). I'd have to think about the glue pauses for a wood fuselage. Jim -----Original Message----- From: H RULE Sent: Mar 21, 2010 11:12 PM Subject: Re: Pietenpol-List: just another idea and concept to ponder another question along the same lines would be" could a PIET be built by as many builders as it would take over the Brodhead weekend?"Much the same way as they build the aluminum stol aircraft, CH701,at the Sun N Fun weekend.Then auction or raffle it off at the end of the weekend for some lucky person to take home. From: Jim Markle <jim_markle(at)mindspring.com> Sent: Sun, March 21, 2010 10:47:10 PM Subject: Re: Pietenpol-List: just another idea and concept to ponder VERY cool idea. Logistics will be the challenge but I'm definitely in! -----Original Message----- From: AMsafetyC(at)aol.com Sent: Mar 19, 2010 7:00 PM Subject: Pietenpol-List: just another idea and concept to ponder Hello good people..... A new idea and concept for the group to ponder. As we all know and have recognized we all share a common bond as fellow lovers of the blue, aviators, builders connected through the design genius of Bernard Pietenpol and his flying contraption the aeroplane. We as a collection of builders have at our disposal some, many and all of the requisite skill levels to construct such a machine with little assistance or intervention from the outside world. The there are those who would love to join our ranks but may be lacking in skills, equipment and time to turn their dream into a reality. From prints to Piet if you will. We know that everyone has a skill set that is good in some areas and not so good in others. Knowing these basic tenants I am curious as to who or what builders would welcome the talents of other builders equipped with tools and skills would be interested in having a group of builders show up at their hanger, barn, basement or garage for a weekend build utilizing all the skills of the people interested in lending a hand to accomplish a number of tasks to get the project going bring the tools to get the certain aspects completed. Woodworkers, metal workers, mechanical workers and the like showing up to get a build from a stalled stage to a more accomplished state of being a Pietenpol. I am speaking about two groups of people, those with the skills and resources capable of committing to a 2 or 3 day weekend to participate in building another Piet as one group. The other group would be a builder or would be builder who in need of assistance in advancing their project to a next or greater level of completion. This again is but another concept for consideration. For example I have both tools not all that I need but certainly more than other that are portable, a trailer to transport them and no skills to speak of. I also have lodging as in a popup/tent camper to bring to a build site for a few days to help another builder. There are others with tools and skills that may also be portable. Through this cooperative of a half dozen or more people who would be willing to share their time and expertise to get another build moving and another builder to a next level of completion. I am wonder how many of us would be willing to pitch in for a week end to help and how many would be interested in receiving those willing to help. Before I go any further with this concept it would be nice to know if there is any interest at all in helping or being helped. Just in case you were wondering, I have all of my tools marked for identification purposes. I know how this works. Helpers bring tools and skills and resources as needed helped provide a keg on tap burgers and a place for a fire and I think we are cooking with gas! What say you? http://www.matronics.com/Navigator?sp; //forums.matronics.com/" target=_blank>http://forums.matronics.com
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: phase one
Date: Mar 22, 2010
Congrats Skip! ________________________________________________________________________________
Date: Mar 22, 2010
Subject: A-65 cost
BUY IT !!!!!!!!!!!!!!!!! You can't loose at that price. BUY IT !!!!!!!!!!!!!!!!!!!!!!! >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol- >list-server(at)matronics.com] On Behalf Of chase143(at)aol.com >Sent: Monday, March 22, 2010 9:42 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: A-65 cost > > > >A friend offered me an A-65, with spare mags, carburetor, pieces as >required. Describes it in good shape, running recently, replaced for >larger engine. How does $1800 sound? I know there can be a big >disparity, but I have no recent price experience. I would probably >overhaul anyway based on what I am able to do myself and/or cost to have >someone else do it if required. Any recent cost experiences? >Thanks, >Steve > >-------- >Steve >www.mypiet.com > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=291233#291233 > > ________________________________________________________________________________
Date: Mar 22, 2010
Thanks Ben and Rick, Rick, Go for it! Actually the guy selling, Mike Frazier has a steel tube Piet project, so a guy might be able to get a home on a runway and the Piet project all at one shot. Skip > wow, only $149K for a nice house with a 40x40 > hanger at your airpark. I could almost afford to retire now to a place > that reasonable, and then we would have 3 Piets on the field. > > rick > ________________________________________________________________________________
Date: Mar 22, 2010
John, Sounds like an old-fashioned barn-raising where the whole community turned out to build a neighbor's barn. I like it! I don't know if I'd be able to get it past the head of the ways and means committee, though. *sigh* Reading more of the thread - if someone showed up with all the ribs and tips built, could the rest of the wing be done in a couple of days? Dan On 03/19/2010 07:00 PM, AMsafetyC(at)aol.com wrote: > Hello good people..... > A new idea and concept for the group to ponder. > As we all know and have recognized we all share a common bond as fellow > lovers of the blue, aviators, builders connected through the design > genius of Bernard Pietenpol and his flying contraption the aeroplane. We > as a collection of builders have at our disposal some, many and all of > the requisite skill levels to construct such a machine with little > assistance or intervention from the outside world. > The there are those who would love to join our ranks but may be lacking > in skills, equipment and time to turn their dream into a reality. From > prints to Piet if you will. We know that everyone has a skill set that > is good in some areas and not so good in others. Knowing these basic > tenants I am curious as to who or what builders would welcome the > talents of other builders equipped with tools and skills would be > interested in having a group of builders show up at their hanger, barn, > basement or garage for a weekend build utilizing all the skills of the > people interested in lending a hand to accomplish a number of tasks to > get the project going bring the tools to get the certain aspects > completed. Woodworkers, metal workers, mechanical workers and the like > showing up to get a build from a stalled stage to a more accomplished > state of being a Pietenpol. > I am speaking about two groups of people, those with the skills and > resources capable of committing to a 2 or 3 day weekend to participate > in building another Piet as one group. The other group would be a > builder or would be builder who in need of assistance in advancing their > project to a next or greater level of completion. > This again is but another concept for consideration. For example I have > both tools not all that I need but certainly more than other that are > portable, a trailer to transport them and no skills to speak of. I also > have lodging as in a popup/tent camper to bring to a build site for a > few days to help another builder. There are others with tools and skills > that may also be portable. > Through this cooperative of a half dozen or more people who would be > willing to share their time and expertise to get another build moving > and another builder to a next level of completion. > I am wonder how many of us would be willing to pitch in for a week end > to help and how many would be interested in receiving those willing to > help. > Before I go any further with this concept it would be nice to know if > there is any interest at all in helping or being helped. > Just in case you were wondering, I have all of my tools marked for > identification purposes. I know how this works. > Helpers bring tools and skills and resources as needed helped provide a > keg on tap burgers and a place for a fire and I think we are cooking > with gas! > What say you? > John > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 22, 2010
Very nice, looks just like my workshop with two completed wings hanging overhead waiting for covering. Rick On Mon, Mar 22, 2010 at 5:03 AM, Jack wrote: > Fuselage is going well. I updated my site with some more photos. > http://www.textors.com/PietProject.html > > Jack > > DSM > > www.textors.com > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 22, 2010
I'd have two questions which could vary the value of it significantly. 1. Is it a certified engine with logs? A certified engine will obviously bring more than a non-certified engine, or one that once was certified but hasn't been maintained that way. IIRC, a certified engine in your Piet would also reduce the required time for your test flights from 40 hours down to 25. 2. What are the compression numbers on the cylinders? This is a standard benchmark of engine health. While it doesn't guarantee perfection, it's a good starting point. Neither of these are show-stoppers; they just change the numbers. Jim Ash -----Original Message----- >From: "chase143(at)aol.com" <chase143(at)aol.com> >Sent: Mar 22, 2010 9:41 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: A-65 cost > > >A friend offered me an A-65, with spare mags, carburetor, pieces as required. Describes it in good shape, running recently, replaced for larger engine. How does $1800 sound? I know there can be a big disparity, but I have no recent price experience. I would probably overhaul anyway based on what I am able to do myself and/or cost to have someone else do it if required. Any recent cost experiences? >Thanks, >Steve > >-------- >Steve >www.mypiet.com > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=291233#291233 > > ________________________________________________________________________________
Date: Mar 22, 2010
With accessories and even if it is run-out, that is a good price. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2810 Crossroads Drive, Ste 3800 Madison, WI 53718 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Mar 22, 2010, at 8:41 AM, chase143(at)aol.com wrote: > > A friend offered me an A-65, with spare mags, carburetor, pieces as required. Describes it in good shape, running recently, replaced for larger engine. How does $1800 sound? I know there can be a big disparity, but I have no recent price experience. I would probably overhaul anyway based on what I am able to do myself and/or cost to have someone else do it if required. Any recent cost experiences? > Thanks, > Steve > > -------- > Steve > www.mypiet.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291233#291233 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 22, 2010
Seeing the bare fuselage gives an idea of just how robust the Piet airframe is. Those beefy 1x1 framing members really make for a stout airplane. Very clean work, Jack. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291261#291261 ________________________________________________________________________________
Subject: A-65 cost
Date: Mar 22, 2010
Sounds like a good price to me, Steve. I paid $1500 for my A-65 as literally a box of parts 10 years ago. I put another $6,000 into it in overhauling it, including new cylinders and pistons, new camshaft, new magnetos, etc. As for overhauling it yourself, I heartily recommend it. Buy the Mattituck video on how to overhaul an O-200 (available from AS&S) and just follow the same procedures. Overhaul manuals for A65's are readily available. They are pretty easy to follow and few special tools are required, other than a piston ring compressor. When you are done, you will know your engine thoroughly. Jack Phillips -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of chase143(at)aol.com Sent: Monday, March 22, 2010 9:42 AM Subject: Pietenpol-List: A-65 cost A friend offered me an A-65, with spare mags, carburetor, pieces as required. Describes it in good shape, running recently, replaced for larger engine. How does $1800 sound? I know there can be a big disparity, but I have no recent price experience. I would probably overhaul anyway based on what I am able to do myself and/or cost to have someone else do it if required. Any recent cost experiences? Thanks, Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291233#291233 ________________________________________________________________________________
Date: Mar 22, 2010
From: Gerry Holland <gholland@content-stream.co.uk>
Steve Hi from UK. To protect your friend from any liability and litigation can I suggest I'll take the A65 off his hands and save you wasting your money! Seriously though at that price you should snap it up. In fact I think it would be economic to ship to UK even. Go for it and even if it's not used you can resell it anytime and it will go. Regards Gerry ________________________________________________________________________________
Date: Mar 22, 2010
Take it, don't look back! I would jump all over it for that price. --- On Mon, 3/22/10, chase143(at)aol.com wrote: From: chase143(at)aol.com <chase143(at)aol.com> Subject: Pietenpol-List: A-65 cost Date: Monday, March 22, 2010, 9:41 AM om> A friend offered me an A-65, with spare mags, carburetor, pieces as require d. Describes it in good shape, running recently, replaced for larger engine . How does $1800 sound? I know there can be a big disparity, but I have no recent price experience. I would probably overhaul anyway based on what I a m able to do myself and/or cost to have someone else do it if required. Any recent cost experiences? Thanks, Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291233#291233 le, List Admin. ________________________________________________________________________________
Date: Mar 22, 2010
How many hours does it have in the last 3-5 years? What are the compressions? What state are the mags in? How long since major? Some or a lot of recent time is good. Can you check the cylinders and cam for corrosion before buying? It'd be nice to pop a cylinder or two off. If it was built with good parts, $1,800 is a good deal. I just paid $900 to overhaul two cylinders a few months ago. Also, did you see the recent article in EAA Sport Aviation magazine about engines having substantially lower failure rates as they have more and more hours? Because that is the case, I'd be more interested in this engine if it has 500 hours than if it has 50 hours. Steve Ruse Quoting "chase143(at)aol.com" : > > > A friend offered me an A-65, with spare mags, carburetor, pieces as > required. Describes it in good shape, running recently, replaced for > larger engine. How does $1800 sound? I know there can be a big > disparity, but I have no recent price experience. I would probably > overhaul anyway based on what I am able to do myself and/or cost to > have someone else do it if required. Any recent cost experiences? > Thanks, > Steve > > -------- > Steve > www.mypiet.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291233#291233 > > ________________________________________________________________________________
Date: Mar 22, 2010
Great replies all!! ~I believe it is certified, has all log books (and many spare parts) ~Jack, I will look for the video, I'd like to rebuild myself (I have a ring compressor I once used on my 351 Cleveland) ~Steve, very interesting stats, I will look up the EAA article. ~Thanks for all the offers to take off my hands! That answers my question! lol I think it's a done deal! Thanks again. Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291272#291272 ________________________________________________________________________________
Date: Mar 22, 2010
Hi Jack, Your fuselage shows very nice and good work. Its really looking good and making good progress. Keep it up, Jim B. Jim Boyer Santa Rosa, CA Pietenpol on wheels Tail surfaces done Wing ribs done Corvair engine Mar 22, 2010 05:08:21 AM, pietenpol-list(at)matronics.com wrote: Fuselage is going well. I updated my site with some more photos. http://www.textors.com/PietProject.html Jack DSM www.textors.com ________________________________________________________________________________
Date: Mar 22, 2010
Beautiful work Jack! I hope mine will look as good. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291276#291276 ________________________________________________________________________________
Date: Mar 22, 2010
Same here. Can't beat the Cont. Mine is 70 years old and has plenty left in her. Like the guys say......BUY IT. Mike King 77MK GN-1 Corpus Christi ----- Original Message ----- From: Michael Perez Sent: Monday, March 22, 2010 9:18 AM Subject: Re: Pietenpol-List: A-65 cost Take it, don't look back! I would jump all over it for that price. --- On Mon, 3/22/10, chase143(at)aol.com wrote: From: chase143(at)aol.com <chase143(at)aol.com> Subject: Pietenpol-List: A-65 cost Date: Monday, March 22, 2010, 9:41 AM A friend offered me an A-65, with spare mags, carburetor, pieces as required. Describes it in good shape, running recently, replaced for larger engine. How does $1800 sound? I know there can be a big disparity, but I have no recent price experience. I would probably overhaul anyway based on what I am able to do myself and/or cost to have someone else do it if required. Any recent cost experiences? Thanks, Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291233#29123= - The Pietenpol-List Email Forum -http://www.matronics.com/Na======================= ________________________________________________________________________________
Date: Mar 22, 2010
So... what assemblies are you lacking John? Do you have all the materials or will we spend most of the first day down at the lumber yard sifting through scraps? Will you be providing food and drink? How big is the basement? [Laughing] [quote="Amsafetyc"]Valuable comments thanksActually not talking about a complete ship and not at Brodhead. Just at a builders location looking for a weekend of intense building by a group able and capable of working on everything in need of help to advance the project. All based on the builders wants,needs,schedule and raw materials/parts on hand. With enough bench space,clamps, jigging and a saw man it is possible to frame out the fuse and tail feathers in a weekend. I am not advocating we do this tomorrow but if there were interested parties maybe in 6 month or soJohn Sent from my Verizon Wireless BlackBerryFrom: "Dick N" Date: Sun, 21 Mar 2010 23:12:35 -0500 Subject: Re: Pietenpol-List: just another idea and concept to ponder No, that couldn't be done. Not to a completed ship if that's what you are suggesting. A bare fuselage would take 6 days alone. Just think of the work involved in the wings. Dick N. > --- -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291281#291281 ________________________________________________________________________________
Date: Mar 22, 2010
Subject: Re: A-65 cost - Engine TBO & EAA article
Below is a link to the article I was referring to. You have to sign up to Oshkosh365.org to read them I think. Good article. A 2nd article in the series was in this month's magazine: http://www.sportaviationonline.org/sportaviation/201002/#pg90 Steve Quoting "chase143(at)aol.com" : > > > Great replies all!! > ~I believe it is certified, has all log books (and many spare parts) > ~Jack, I will look for the video, I'd like to rebuild myself (I have > a ring compressor I once used on my 351 Cleveland) > ~Steve, very interesting stats, I will look up the EAA article. > ~Thanks for all the offers to take off my hands! That answers my > question! lol > I think it's a done deal! Thanks again. > Steve > > -------- > Steve > www.mypiet.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291272#291272 > > ________________________________________________________________________________
Date: Mar 22, 2010
I didn't read the article =2C but I think it will say that frequency is mor e important than total. An engine that flies 5 hrs/yr won't even come clos e to TBO=2C but one that flies 100 hrs/yr will. The last airplane we had w as still flying with good numbers past TBO. It was flown 150hrs/yr. Doug Dever In beautiful Stow Ohio _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID27925::T:WLMTAGL:O N:WL:en-US:WM_HMP:032010_2 ________________________________________________________________________________
Date: Mar 22, 2010
Mark, I got my fuse , wings, tail feathers, center section, landing gear, cabane's and struts built along with most of my metal fittings in stainles s done and the firewall is installed. As soon as I can get a hanger I plan to beg in my trial fits and finishing mounting brackets for alignment. I also had 2 tanks nearly built however 032 aluminum is easily bent on my home made large profile brake just not to easy to get the tig welding settings exac tly right. First arc big honking holes. Soon as I move into a hanger I can do more adjusting on the Piet and I am planning the construction of my hanger kegger just in case the thirst hits me. Right now we are talking about electric, I need 220/100 amp service to run my welders and compressor and the airport only provides one single 11 0 v 15 amp circuit. not nearly enough for serious builders with tools. Soon as I can load the flatbed with steel for the benches and tools I am ready to move the piet to its new home, were I can drink and make sparks all the day. John Bring it on home boy In a message dated 3/22/2010 2:08:12 P.M. Eastern Daylight Time, hangar10(at)cox.net writes: --> Pietenpol-List message posted by: "K5YAC" So... what assemblies are you lacking John? Do you have all the material s or will we spend most of the first day down at the lumber yard sifting through scraps? Will you be providing food and drink? How big is the basement? [Laughing] [quote="Amsafetyc"]Valuable comments thanksActually not talking about a complete ship and not at Brodhead. Just at a builders location looking fo r a weekend of intense building by a group able and capable of working on everything in need of help to advance the project. All based on the build ers wants,needs,schedule and raw materials/parts on hand. With enough bench space,clamps, jigging and a saw man it is possible to frame out the fuse and tail feathers in a weekend. I am not advocating we do this tomorrow but if there were interested parties maybe in 6 month or soJohn Sent from my Verizon Wireless BlackBerryFrom: "Dick N" Date: Sun, 21 Mar 2010 23:12:35 -0500 Subject: Re: Pietenpol-List: just another idea and concept to ponder No, that couldn't be done.=EF=BD Not to a completed ship if that's wh at you are suggesting.=EF=BD A bare fuselage would take 6 days alone.=EF =BD Just think of the work involved in the wings.=EF=BD Dick N. > --- -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291281#291281 ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Mar 22, 2010
Dan, That is exactly the concept. Living in Lancaster PA we often have a chance to run across an Amish barn being built, just like in the movie Witness or a Kingdom Hall like the Jehovah witnesses. Really its about a bunch of folks pitching in to get another Piet project off the ground. I am certain that much can be accomplished is short order with the right hands doing there best to make it happen. To me it sounds like fun and a chance to learn from all the others there is much for each of us to share and learn. John In a message dated 3/22/2010 12:45:39 P.M. Eastern Daylight Time, yocum(at)fnal.gov writes: --> Pietenpol-List message posted by: Dan Yocum John, Sounds like an old-fashioned barn-raising where the whole community turned out to build a neighbor's barn. I like it! I don't know if I'd be able to get it past the head of the ways and means committee, though. *sigh* Reading more of the thread - if someone showed up with all the ribs and tips built, could the rest of the wing be done in a couple of days? Dan On 03/19/2010 07:00 PM, AMsafetyC(at)aol.com wrote: > Hello good people..... > A new idea and concept for the group to ponder. > As we all know and have recognized we all share a common bond as fellow > lovers of the blue, aviators, builders connected through the design > genius of Bernard Pietenpol and his flying contraption the aeroplane. We > as a collection of builders have at our disposal some, many and all of > the requisite skill levels to construct such a machine with little > assistance or intervention from the outside world. > The there are those who would love to join our ranks but may be lacking > in skills, equipment and time to turn their dream into a reality. From > prints to Piet if you will. We know that everyone has a skill set that > is good in some areas and not so good in others. Knowing these basic > tenants I am curious as to who or what builders would welcome the > talents of other builders equipped with tools and skills would be > interested in having a group of builders show up at their hanger, barn, > basement or garage for a weekend build utilizing all the skills of the > people interested in lending a hand to accomplish a number of tasks to > get the project going bring the tools to get the certain aspects > completed. Woodworkers, metal workers, mechanical workers and the like > showing up to get a build from a stalled stage to a more accomplished > state of being a Pietenpol. > I am speaking about two groups of people, those with the skills and > resources capable of committing to a 2 or 3 day weekend to participate > in building another Piet as one group. The other group would be a > builder or would be builder who in need of assistance in advancing their > project to a next or greater level of completion. > This again is but another concept for consideration. For example I have > both tools not all that I need but certainly more than other that are > portable, a trailer to transport them and no skills to speak of. I also > have lodging as in a popup/tent camper to bring to a build site for a > few days to help another builder. There are others with tools and skills > that may also be portable. > Through this cooperative of a half dozen or more people who would be > willing to share their time and expertise to get another build moving > and another builder to a next level of completion. > I am wonder how many of us would be willing to pitch in for a week end > to help and how many would be interested in receiving those willing to > help. > Before I go any further with this concept it would be nice to know if > there is any interest at all in helping or being helped. > Just in case you were wondering, I have all of my tools marked for > identification purposes. I know how this works. > Helpers bring tools and skills and resources as needed helped provide a > keg on tap burgers and a place for a fire and I think we are cooking > with gas! > What say you? > John > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 22, 2010
Yuck! Just thought I'd throw that in there for contrast. Really, though, Jack - like everyone else said, you're doing VERY nice work. But your shop is a mess! In one of the photos, it looks like there's a binder under your workbench that is sticking out about 3/4"! That can't actually be a real workshop. I should post a photo of my mess, so you can see what the other end of the spectrum looks like. (can you tell I'm jealous?) Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291310#291310 ________________________________________________________________________________
Date: Mar 22, 2010
Even that depends on other factors, like how the engine is stored. The engine in my plane (an A-75) was last overhauled in 1967...43 years ago. It has about 1,000 total time now. Clearly it has at points gone for years without running in that time. I've put about 400 on it in the last six years, and it is in great shape. The cam and internals look good, and the 400 recent hours I put on it indicate that it is still solid. It has had cylinders replaced, and new mags...but the bottom-end is solid (or is it the middle-end on an opposed engine?). If there had been rust on the cam or crank six years ago, it would've been apparent by now. When I had two cylinders off last year, the internals looked good. Of course, it is BEST to run an engine often. But not running it often doesn't always mean it will be ruined, just that it is more likely. Clearly mine was somehow protected from corrosion. Steve Ruse Quoting Doug Dever : > > I didn't read the article , but I think it will say that frequency > is more important than total. An engine that flies 5 hrs/yr won't > even come close to TBO, but one that flies 100 hrs/yr will. The > last airplane we had was still flying with good numbers past TBO. > It was flown 150hrs/yr. > > Doug Dever > In beautiful Stow Ohio > > > _________________________________________________________________ > Hotmail is redefining busy with tools for the New Busy. Get more > from your inbox. > http://www.windowslive.com/campaign/thenewbusy?ocid=PID27925::T:WLMTAGL:ON:WL:en-US:WM_HMP:032010_2 ________________________________________________________________________________
Date: Mar 22, 2010
Storing an engine in humid Florida vs. dry Colorado could make a difference over a few decades. rick On Mon, Mar 22, 2010 at 2:23 PM, Steve Ruse wrote: > > Even that depends on other factors, like how the engine is stored. The > engine in my plane (an A-75) was last overhauled in 1967...43 years ago. It > has about 1,000 total time now. Clearly it has at points gone for years > without running in that time. I've put about 400 on it in the last six > years, and it is in great shape. The cam and internals look good, and the > 400 recent hours I put on it indicate that it is still solid. It has had > cylinders replaced, and new mags...but the bottom-end is solid (or is it the > middle-end on an opposed engine?). If there had been rust on the cam or > crank six years ago, it would've been apparent by now. When I had two > cylinders off last year, the internals looked good. > > Of course, it is BEST to run an engine often. But not running it often > doesn't always mean it will be ruined, just that it is more likely. Clearly > mine was somehow protected from corrosion. > > Steve Ruse > > Quoting Doug Dever : > >> >> I didn't read the article , but I think it will say that frequency is >> more important than total. An engine that flies 5 hrs/yr won't even come >> close to TBO, but one that flies 100 hrs/yr will. The last airplane we had >> was still flying with good numbers past TBO. It was flown 150hrs/yr. >> >> Doug Dever >> In beautiful Stow Ohio >> >> >> >> _________________________________________________________________ >> Hotmail is redefining busy with tools for the New Busy. Get more from >> your inbox. >> >> http://www.windowslive.com/campaign/thenewbusy?ocid=PID27925::T:WLMTAGL:ON:WL:en-US:WM_HMP:032010_2 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 22, 2010
Ok, I was just trying to be funny. Kind of like... maybe you were recruiting to get some cheap labor. Thanks for the update. LOL! [quote="Amsafetyc"]Mark, I got my fuse , wings, tail feathers, center section, landing gear, cabane's and struts built along with most of my metal fittings in stainless done and the firewall is installed. As soon as I can get a hanger I plan to begin my trial fits and finishing mounting brackets for alignment. I also had 2 tanks nearly built however 032 aluminum is easily bent on my home made large profile brake just not to easy to get the tig welding settings exactly right. First arc big honking holes. Soon as I move into a hanger I can do more adjusting on the Pietand I am planning the construction of my hanger kegger just in case the thirst hits me. Right now we are talking about electric, I need 220/100 amp service to run my welders and compressor and the airport only provides one single 110 v 15 amp circuit. not nearly enough for serious builders with tools. Soon as I can load the flatbed with steel for the benches and tools I am ready to move the piet to its new home, were I can drink and make sparks all the day. John Bring it on home boy In a message dated 3/22/2010 2:08:12 P.M. Eastern Daylight Time, hangar10(at)cox.net writes: > --> Pietenpol-List message posted by: "K5YAC" > > So... what assemblies are you lacking John? Do you have all the materials or will we spend most of the first day down at the lumber yard sifting through scraps? Will you be providing food and drink? How big is the basement? > > [Laughing] > > [quote="Amsafetyc"]Valuable comments thanksActually not talking about a complete ship and not at Brodhead. Just at a builders location looking for a weekend of intense building by a group able and capable of working on everything in need of help to advance the project. All based on the builders wants,needs,schedule and raw materials/parts on hand. With enough bench space,clamps, jigging and a saw man it is possible to frame out the fuse and tail feathers in a weekend. I am not advocating we do this tomorrow but if there were interested parties maybe in 6 month or soJohn > Sent from my Verizon Wireless BlackBerryFrom: "Dick N" > Date: Sun, 21 Mar 2010 23:12:35 -0500 > To: > Subject: Re: just another idea and concept to ponder > > No, that couldn't be done. Not to a completed ship if that's what you are suggesting. A bare fuselage would take 6 days alone. Just think of the work involved in the wings. > Dick N. > > > > --- > > > > > > > -------- > Mark - working on wings > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291281#291281============================================== > > > [b] -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291314#291314 ________________________________________________________________________________
Date: Mar 22, 2010
Oh yeah? Well, I can't even FIND my dog in my workshop. (beat that) BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291317#291317 ________________________________________________________________________________
Date: Mar 22, 2010
Jim, In answer to your #1, It doesn't have to be certified to have a fly off hour of 25. Mine wasn't and I did the 25 hour Phase 1. Just my 2 cents. walt evans NX140DL ----- Original Message ----- From: Jim Ash To: pietenpol-list(at)matronics.com Sent: Monday, March 22, 2010 10:36 AM Subject: Re: Pietenpol-List: A-65 cost I'd have two questions which could vary the value of it significantly. 1. Is it a certified engine with logs? A certified engine will obviously bring more than a non-certified engine, or one that once was certified but hasn't been maintained that way. IIRC, a certified engine in your Piet would also reduce the required time for your test flights from 40 hours down to 25. 2. What are the compression numbers on the cylinders? This is a standard benchmark of engine health. While it doesn't guarantee perfection, it's a good starting point. Neither of these are show-stoppers; they just change the numbers. Jim Ash -----Original Message----- >From: "chase143(at)aol.com" <chase143(at)aol.com> >Sent: Mar 22, 2010 9:41 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: A-65 cost > > >A friend offered me an A-65, with spare mags, carburetor, pieces as required. Describes it in good shape, running recently, replaced for larger engine. How does $1800 sound? I know there can be a big disparity, but I have no recent price experience. I would probably overhaul anyway based on what I am able to do myself and/or cost to have someone else do it if required. Any recent cost experiences? >Thanks, >Steve > >-------- >Steve >www.mypiet.com > > > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=291233#291233 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 22, 2010
Oh yeah? Well, I can't even FIND my wife in my workshop....oh that's right I got rid of the "Practice Wife", and kept the Piet mistress. BJ -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: Monday, March 22, 2010 2:38 PM Subject: Pietenpol-List: Re: Fuselage Update Oh yeah? Well, I can't even FIND my dog in my workshop. (beat that) BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291317#291317 ________________________________________________________________________________
Date: Mar 22, 2010
Subject: What size prop
I am building a Piet and have decided on the Continental A-65 and I want to hear from everyone. What size prop are you using with the A-65? - Thanks, Jeff=0A=0A=0A ________________________________________________________________________________
Date: Mar 22, 2010
Subject: Re: What size prop
I have a Sensenich 72X40, which is considered a climb prop on a Cub. It pulls the full 2300 RPM in a climb, and I still cruise at 78 mph at 2100 rpm. Ben On 3/22/2010 5:30 PM, jeff wilson wrote: > I am building a Piet and have decided on the Continental A-65 and I > want to hear from everyone. > What size prop are you using with the A-65? > Thanks, Jeff > > > * > > > * ________________________________________________________________________________
Date: Mar 22, 2010
Remember guys, as some famous writer said,,,"Its not the destination,,,but the journey that's important" I loved working on my Piet,,,without any kind of pressure. "some like to build,,and some like to fly" "don't build to fly" but "build to build" walt evans NX140DL ----- Original Message ----- From: Dan Yocum To: pietenpol-list(at)matronics.com Sent: Monday, March 22, 2010 12:39 PM Subject: Re: Pietenpol-List: just another idea and concept to ponder John, Sounds like an old-fashioned barn-raising where the whole community turned out to build a neighbor's barn. I like it! I don't know if I'd be able to get it past the head of the ways and means committee, though. *sigh* Reading more of the thread - if someone showed up with all the ribs and tips built, could the rest of the wing be done in a couple of days? Dan On 03/19/2010 07:00 PM, AMsafetyC(at)aol.com wrote: > Hello good people..... > A new idea and concept for the group to ponder. > As we all know and have recognized we all share a common bond as fellow > lovers of the blue, aviators, builders connected through the design > genius of Bernard Pietenpol and his flying contraption the aeroplane. We > as a collection of builders have at our disposal some, many and all of > the requisite skill levels to construct such a machine with little > assistance or intervention from the outside world. > The there are those who would love to join our ranks but may be lacking > in skills, equipment and time to turn their dream into a reality. From > prints to Piet if you will. We know that everyone has a skill set that > is good in some areas and not so good in others. Knowing these basic > tenants I am curious as to who or what builders would welcome the > talents of other builders equipped with tools and skills would be > interested in having a group of builders show up at their hanger, barn, > basement or garage for a weekend build utilizing all the skills of the > people interested in lending a hand to accomplish a number of tasks to > get the project going bring the tools to get the certain aspects > completed. Woodworkers, metal workers, mechanical workers and the like > showing up to get a build from a stalled stage to a more accomplished > state of being a Pietenpol. > I am speaking about two groups of people, those with the skills and > resources capable of committing to a 2 or 3 day weekend to participate > in building another Piet as one group. The other group would be a > builder or would be builder who in need of assistance in advancing their > project to a next or greater level of completion. > This again is but another concept for consideration. For example I have > both tools not all that I need but certainly more than other that are > portable, a trailer to transport them and no skills to speak of. I also > have lodging as in a popup/tent camper to bring to a build site for a > few days to help another builder. There are others with tools and skills > that may also be portable. > Through this cooperative of a half dozen or more people who would be > willing to share their time and expertise to get another build moving > and another builder to a next level of completion. > I am wonder how many of us would be willing to pitch in for a week end > to help and how many would be interested in receiving those willing to > help. > Before I go any further with this concept it would be nice to know if > there is any interest at all in helping or being helped. > Just in case you were wondering, I have all of my tools marked for > identification purposes. I know how this works. > Helpers bring tools and skills and resources as needed helped provide a > keg on tap burgers and a place for a fire and I think we are cooking > with gas! > What say you? > John > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 22, 2010
Bj, Wow, I think I like you! walt evans NX140DL ----- Original Message ----- From: brian.e.jardine@l-3com.com To: pietenpol-list(at)matronics.com Sent: Monday, March 22, 2010 4:52 PM Subject: RE: Pietenpol-List: Re: Fuselage Update Oh yeah? Well, I can't even FIND my wife in my workshop....oh that's right I got rid of the "Practice Wife", and kept the Piet mistress. BJ -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: Monday, March 22, 2010 2:38 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Fuselage Update Oh yeah? Well, I can't even FIND my dog in my workshop. (beat that) BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291317#291317 ________________________________________________________________________________
Date: Mar 22, 2010
I was thinking the same thing. With a mass build, who would be responsible for quality control? There is a little reassurance when you strap your butt in and add the throttle, that you have done YOUR best to make it right. The skills you learn during the journey are part of the process. Ben Charvet On 3/22/2010 5:35 PM, walt wrote: > Remember guys, as some famous writer said,,,"Its not the > destination,,,but the journey that's important" > I loved working on my Piet,,,without any kind of pressure. > "some like to build,,and some like to fly" > "don't build to fly" but "build to build" > walt evans > NX140DL > ________________________________________________________________________________
Date: Mar 22, 2010
I hope the blessed wife does not read your emails ________________________________ From: walt <waltdak(at)verizon.net> Sent: Mon, March 22, 2010 5:36:01 PM Subject: Re: Pietenpol-List: Re: Fuselage Update Bj, Wow, I think I like you! walt evans NX140DL ----- Original Message ----- >From: brian.e.jardine@l-3com.com >To: pietenpol-list(at)matronics.com >Sent: Monday, March 22, 2010 4:52 >PM >Subject: RE: Pietenpol-List: Re: Fuselage > Update > > >Oh > yeah? > >Well, I can't even FIND my wife in my workshop....oh that's right > I got >rid of the "Practice Wife", and kept the Piet > mistress. > >BJ > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] > On Behalf Of Bill >Church >Sent: Monday, March 22, 2010 2:38 PM >To: pietenpol-list(at)matronics.com >Subject: > Pietenpol-List: Re: Fuselage Update > >--> Pietenpol-List message > posted by: "Bill Church" > > >Oh > yeah? >Well, I can't even FIND my dog in my workshop. (beat > that) > >BC > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=291317#291317 > > >> > http://www.matnbsp; >via the Web > href="http://forums.matronics.com">http://forums.matronics.com >_p; >generous > bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/c================ > > ________________________________________________________________________________
Date: Mar 22, 2010
Bill and all, Thanks for the kind words, it all helps! Bill, do you think I'm anal? I do always make sure to dust before mixing epoxy or measuring a for critical cut. Honestly, Wife Susan is very understanding of all the dust, noise and swearing rising up from the family room. Jack DSM Yuck! Just thought I'd throw that in there for contrast. Really, though, Jack - like everyone else said, you're doing VERY nice work. But your shop is a mess! In one of the photos, it looks like there's a binder under your workbench that is sticking out about 3/4"! That can't actually be a real workshop. I should post a photo of my mess, so you can see what the other end of the spectrum looks like. (can you tell I'm jealous?) Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291310#291310 ________________________________________________________________________________
Subject: intercom
Date: Mar 22, 2010
Okay, so if I have two headsets and want to be able to talk back and forth, what do I need? A battery powered intercom and two push to talk switches (if I don't trust the squelch to work) and that's it? Douwe ________________________________________________________________________________
Subject: Instrument Template
Date: Mar 22, 2010
Did some test cutting with my new 3 1/8 forstner bit today, what a honking bit! Does anyone have a PDF for the instrument screw holes? Thanks! Jack DSM ________________________________________________________________________________
Date: Mar 22, 2010
Subject: Re: intercom
Douwe, you only need one PPT switch, and that's for the pilot to communicate on the radio. The communication between the two people in the airplane simply goes through the intercom without need of a PPT switch - you just speak into the microphone. Now, if you want both the passenger and pilot to be able to communicate on the radio, things get more complicated. > > >Okay, so if I have two headsets and want to be able to talk back and forth, >what do I need? > >A battery powered intercom and two push to talk switches (if I don't trust >the squelch to work) and that's it? > >Douwe -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 22, 2010
Jeff, Ben is certainly getting excellent results with his prop. If I were starting from scratch, I would go for a Cloudcars scimitar prop. The folks there usually recommend a 76X38 prop for Piets with A-65s. That big swing and the scimitar shape tend to maximize the thrust per rev, and the scimitar shape flattens out in climb to allow full revs. Jeff Boatright and Gene in TN got better results from their Piets after they switched to Cloudcars. And they look great on the plane. Lastly Jay at Cloudcars seems great to work with, as well. Check it out. Tim in central TX -----Original Message----- From: Ben Charvet Sent: Mar 22, 2010 4:35 PM Subject: Re: Pietenpol-List: What size prop I have a Sensenich 72X40, which is considered a climb prop on a Cub. It pulls the full 2300 RPM in a climb, and I still cruise at 78 mph at 2100 rpm. Ben On 3/22/2010 5:30 PM, jeff wilson wrote: ________________________________________________________________________________
Date: Mar 22, 2010
We do get great performance with the Cloudcars prop and Jay is easy to work with. I don't know about it flattening out in cruise. I think it's the other way around. I'm not sure at all about this, just based on what I've read. For instance: Pitch change and the Scimitar shape The propeller has a fixed pitch that relies on the forward pull of the propeller to automatically provide pitch change proportional to the amount of force being applied to the propeller disk. When a propeller operates at a slower airspeed than its maximum capability, it has a proportional pull in relation to the velocity of forward motion, so at takeoff and climb, the propeller will have its largest forward pull. Due to the scimitar shape, the tip of the propeller cones forward, as the coning angle changes the propeller will lessen pitch that provides shorter takeoffs and higher rates of climb. As the propeller increases in forward speed the disk pressure is reduced, this forces the propeller to increase pitch and top speed. This change in pitch is approximately four inches from takeoff to cruise. This was taken from http://www.princeaircraft.com/TheProp.aspx HTH, Jeff > >Jeff, > >Ben is certainly getting excellent results with his prop. If I were >starting from scratch, I would go for a Cloudcars scimitar prop. >The folks there usually recommend a 76X38 prop for Piets with A-65s. >That big swing and the scimitar shape tend to maximize the thrust >per rev, and the scimitar shape flattens out in climb to allow full >revs. > >Jeff Boatright and Gene in TN got better results from their Piets >after they switched to Cloudcars. And they look great on the plane. >Lastly Jay at Cloudcars seems great to work with, as well. Check it >out. >Tim in central TX > > >-----Original Message----- >From: Ben Charvet >Sent: Mar 22, 2010 4:35 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: What size prop > >I have a Sensenich 72X40, which is considered a climb prop on a Cub. >It pulls the full 2300 RPM in a climb, and I still cruise at 78 mph >at 2100 rpm. > >Ben >On 3/22/2010 5:30 PM, jeff wilson wrote: > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 22, 2010
Jeff, NX18235 is flying with a 72 X 42 prop. Climb rate is 500+ fpm when the airplane is light but falls to 200 fpm at heavier weights. At 2050 rpm in level flight I am seeing about 72 - 75 mph. At 2150 rpm I am seeing 78 - 82 mph. Greg Cardinal ----- Original Message ----- From: jeff wilson To: pietenpol-list(at)matronics.com Sent: Monday, March 22, 2010 4:30 PM Subject: Pietenpol-List: What size prop I am building a Piet and have decided on the Continental A-65 and I want to hear from everyone. What size prop are you using with the A-65? Thanks, Jeff ________________________________________________________________________________
Date: Mar 22, 2010
I'll second that. He and Carmen were pleasant to deal with...I'm sure the prop will be top-notch....I'll let you know in two days when FedEx delivers it! :) Ryan On Mon, Mar 22, 2010 at 9:53 PM, Tim Willis wrote: > timothywillis(at)earthlink.net> > > Jeff, > > Lastly Jay at Cloudcars seems great to work with, as well. Check it out. > Tim in central TX > > ________________________________________________________________________________
Date: Mar 22, 2010
Jeff, look again.... I wrote that it flattened out in climb. Tim in central TX -----Original Message----- From: Jeff Boatright Sent: Mar 22, 2010 10:04 PM Subject: Re: Pietenpol-List: What size prop We do get great performance with the Cloudcars prop and Jay is easy to work with. I don't know about it flattening out in cruise. I think it's the other way around. I'm not sure at all about this, just based on what I've read. For instance: Pitch change and the Scimitar shape The propeller has a fixed pitch that relies on the forward pull of the propeller to automatically provide pitch change proportional to the amount of force being applied to the propeller disk. When a propeller operates at a slower airspeed than its maximum capability, it has a proportional pull in relation to the velocity of forward motion, so at takeoff and climb, the propeller will have its largest forward pull. Due to the scimitar shape, the tip of the propeller cones forward, as the coning angle changes the propeller will lessen pitch that provides shorter takeoffs and higher rates of climb. As the propeller increases in forward speed the disk pressure is reduced, this forces the propeller to increase pitch and top speed. This change in pitch is approximately four inches from takeoff to cruise. This was taken from http://www.princeaircraft.com/TheProp.aspx HTH, Jeff Jeff, Ben is certainly getting excellent results with his prop. If I were starting from scratch, I would go for a Cloudcars scimitar prop. The folks there usually recommend a 76X38 prop for Piets with A-65s. That big swing and the scimitar shape tend to maximize the thrust per rev, and the scimitar shape flattens out in climb to allow full revs. Jeff Boatright and Gene in TN got better results from their Piets after they switched to Cloudcars. And they look great on the plane. Lastly Jay at Cloudcars seems great to work with, as well. Check it out. Tim in central TX -----Original Message----- From: Ben Charvet Sent: Mar 22, 2010 4:35 PM Subject: Re: Pietenpol-List: What size prop I have a Sensenich 72X40, which is considered a climb prop on a Cub. It pulls the full 2300 RPM in a climb, and I still cruise at 78 mph at 2100 rpm. Ben On 3/22/2010 5:30 PM, jeff wilson wrote: [EDITED] Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Subject: Re: Messy shop, was Fuselage Update
Date: Mar 23, 2010
My wife is Polish, and she has this in-bread cleaning lady thing going on. It bothers her so much to see my shop/hangar, that she stays out of there all together! She tries to tell me every move to make when I am inside, but the hangar is MY realm. Now if I can just get rid of the cell phone when I am out there. I purposefully made my hangar detached from my house for that reason. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Bill Church <billspiet(at)sympatico.ca> Sent: Mon, Mar 22, 2010 3:37 pm Subject: Pietenpol-List: Re: Fuselage Update a> Oh yeah? ell, I can't even FIND my dog in my workshop. (beat that) BC ead this topic online here: http://forums.matronics.com/viewtopic.php?p=291317#291317 ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Mar 23, 2010
Line your shop with copper foil and ground it. Jim Ash -----Original Message----- From: helspersew(at)aol.com Sent: Mar 23, 2010 7:33 AM Subject: Re: Pietenpol-List: Messy shop, was Fuselage Update My wife is Polish, and she has this in-bread cleaning lady thing going on. It bothers her so much to see my shop/hangar, that she stays out of there all together! She tries to tell me every move to make when I am inside, but the hangar is MY realm. Now if I can just get rid of the cell phone when I am out there. I purposefully made my hangar detached from my house for that reason. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Bill Church <billspiet(at)sympatico.ca> Sent: Mon, Mar 22, 2010 3:37 pm Subject: Pietenpol-List: Re: Fuselage Update Oh yeah? Well, I can't even FIND my dog in my workshop. (beat that) BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291317#291317 =================================== t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List =================================== tp://forums.matronics.com =================================== _blank>http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Mar 23, 2010
Re:I'll second that. He and Carmen were pleasant to deal with...I'm sure the prop will be top-notch....I'll let you know in two days when FedEx delivers it! Smile Ryan I have a prop ordered from Jay also. How about posting a hi-res picture when you get it (Pleeeeze). -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291404#291404 ________________________________________________________________________________
Subject: Jack's progress
Date: Mar 23, 2010
Nice work Jack! ________________________________________________________________________________
Subject: Re: Fuselage Update
Date: Mar 23, 2010
Hey Jack, I was just pulling your chain. As I wrote in my posting, I'm actually jealous. I wish my workspace was so tidy. A clean workspace is MUCH easier to work in. Keep doing what you're doing. Maybe I should just try to clean up my act a bit. My workshop is out in the garage, so there's no dust working it's way into the house (except what I carry in on my clothes, so I do try to eliminate that before coming back in). Now, if I could only find that dog... BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291406#291406 ________________________________________________________________________________
Date: Mar 23, 2010
Jeff: When I had the A65 on NX41CC it flew behind a Hegy 72x42 wood prop. I think many/most Piets with the A65 use something like that. By the way, the Hegy may be for sale if anyone is interested. $500. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 23, 2010
I've seen your hangar, Dan... I'm sorry to tell you, but the Polish Cleaning Lady has rubbed off on you. Just like my Polish Cleaning Lady has rubbed off on me: I just got done cleaning the garage last week. Now I've got a workbench that I can see the top of, and I even made some sawdust in the process. On 03/23/2010 06:33 AM, helspersew(at)aol.com wrote: > My wife is Polish, and she has this in-bread cleaning lady thing going > on. It bothers her so much to see my shop/hangar, that she stays out of > there all together! She tries to tell me every move to make when I am > inside, but the hangar is MY realm. Now if I can just get rid of the > cell phone when I am out there. I purposefully made my hangar /detached/ > from my house for /that/ reason. > Dan Helsper > Poplar Grove, IL. > > > -----Original Message----- > From: Bill Church <billspiet(at)sympatico.ca> > To: pietenpol-list(at)matronics.com > Sent: Mon, Mar 22, 2010 3:37 pm > Subject: Pietenpol-List: Re: Fuselage Update > > --> Pietenpol-List message posted by: "Bill Church"> > > Oh yeah? > Well, I can't even FIND my dog in my workshop. (beat that) > > BC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291317#291317 > > > =================================== > t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > =================================== > tp://forums.matronics.com > =================================== > _blank>http://www.matronics.com/contribution > =================================== > > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: Instrument Template
Date: Mar 23, 2010
The screw hole patterns for most common instruments can be found in Bingelis' books. I can find them and scan to .pdf if you don't have the books. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291425#291425 ________________________________________________________________________________
Date: Mar 23, 2010
N8031 has a McCauley 7442 met-l-prop. Climb isn't stellar, but cruise is 88-89mph at 2300RPM. I am supremely jealous of the climb rates those Cloudcar Scimitars produce... On 03/22/2010 04:30 PM, jeff wilson wrote: > I am building a Piet and have decided on the Continental A-65 and I want > to hear from everyone. > What size prop are you using with the A-65? > Thanks, Jeff > > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 23, 2010
Reading comprehension...I should try it some time! DOH! > >Jeff, look again.... I wrote that it flattened out in climb. >Tim in central TX > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 23, 2010
How much are the Cloudcar Scimitars and where do you go to get one? I have a McCaulley 69x39 metal prop (came with the plane) but feel a longer prop would be better for the Cont. A-80. Thanks Mike King 77MK GN-1 Corpus Christi -----Original Message----- >From: Dan Yocum <yocum(at)fnal.gov> >Sent: Mar 23, 2010 11:14 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: What size prop > > >N8031 has a McCauley 7442 met-l-prop. Climb isn't stellar, but cruise >is 88-89mph at 2300RPM. > >I am supremely jealous of the climb rates those Cloudcar Scimitars >produce... > >On 03/22/2010 04:30 PM, jeff wilson wrote: >> I am building a Piet and have decided on the Continental A-65 and I want >> to hear from everyone. >> What size prop are you using with the A-65? >> Thanks, Jeff >> >> >> * >> >> >> * > >-- >Dan Yocum >Fermilab 630.840.6509 >yocum@fnal.gov, http://fermigrid.fnal.gov >"I fly because it releases my mind from the tyranny of petty things." > > ________________________________________________________________________________
Date: Mar 23, 2010
Aircraft Spruce sells a metal hole template that works well for both hole sizes, not real cheap though. http://www.aircraftspruce.com/catalog/inpages/panel_layout.php rick On Mon, Mar 22, 2010 at 7:09 PM, Jack wrote: > Did some test cutting with my new 3 1/8 forstner bit today, what a honking > bit! Does anyone have a PDF for the instrument screw holes? > > Thanks! > > Jack > > DSM > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 23, 2010
A mahogany and maple scimitar prop for my Lycoming O-235 last December was $820. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291435#291435 ________________________________________________________________________________
Date: Mar 23, 2010
Got them Oscar forgot they had them, thanks! Jack DSM The screw hole patterns for most common instruments can be found in Bingelis' books. I can find them and scan to .pdf if you don't have the books. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291425#291425 ________________________________________________________________________________
Date: Mar 23, 2010
Thanks Jerry. Was that from Cloudcar and if so, how do you get in touch with them? Thanks. Mike -----Original Message----- >From: Jerry Dotson <jdotson(at)erec.net> >Sent: Mar 23, 2010 11:21 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: What size prop > > >A mahogany and maple scimitar prop for my Lycoming O-235 last December was $820. > >-------- >Jerry Dotson >59 Daniel Johnson Rd >Baker, FL 32531 > >Started building NX510JD July, 2009 >Ribs and tailfeathers done >using Lycoming O-235 > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=291435#291435 > > ________________________________________________________________________________
Subject: best link in a long time
Date: Mar 23, 2010
http://www.northeastshooters.com/vbulletin/showthread.php/86979-Best-duct -tape-story-ever walt evans NX140DL ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Subject: Cloudcars prop on N502R
Date: Mar 23, 2010
Here's a photo of the cloudcars prop (76x38) on my plane. Needless to say, I love it. Being the first (that I know of) to put the 76 x 38 on a A 65 Piet, Jay worked with me and even told me that after he made it, if it didn't work out he would change it for free. You can contact him at 325 356 2810 or e-mail him at cloudcars @ verizon.net. Tell him Gene from Tennessee said hi. Gene N502R ________________________________________________________________________________
Date: Mar 23, 2010
And if you are an EAA member, you can access the entire library of Sport Aviation magazines online, and after a brief search, one is able to track down an article like the attached. I love that feature. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291472#291472 Attachments: http://forums.matronics.com//files/1984_05_13_945.pdf ________________________________________________________________________________
From: Dan Loegering <dan.loegering(at)odayequipment.com>
Date: Mar 23, 2010
Subject: Insurance question
Ran into an odd situation recently and wanted to see what others have done in the past, or are currently doing. I recently sold my house and am renting now, so I switched to a renters insurance policy. Since I was bored last night (the plane is still in storage for another week) I was reading through the policy, and came across the statement that "aircraft and aircraft parts are not covered." Huh? Spoke to my agent today and he had never come across this either, did some research and they do not cover aircraft or parts on ANY of their policies. So my question is this - what, if anything, did you do to provide coverage for your projects while they were in the project stage? I am simply looking to cover my costs of materials in the event of theft, fire, etc... Is this something that I should not worry about (I am normally a trusting individual, but the new house is close to a high school and the garage is located in the alley - apparently there have been issues in the past with some of the garages being used as gathering places by the students) One neighbor suggested blocking the windows and getting a bigger lock... I may not go to that extreme (it isn't THAT bad of a neighborhood...) but I will definitely be putting in a new lock. It will be nice to get back to building though - time to make more sawdust and grind some metal! Dan Loegering Fargo, ND ________________________________________________________________________________
Subject: Re: Insurance question
Date: Mar 23, 2010
Contact your local police and ask them how serious they'd estimate your local threat is. If their estimate seems more than you are comfortable with, contact an aircraft insurance broker to arrange for coverage while building. It is available. David Paule Ran into an odd situation recently and wanted to see what others have done in the past, or are currently doing. I recently sold my house and am renting now, so I switched to a renters insurance policy. Since I was bored last night (the plane is still in storage for another week) I was reading through the policy, and came across the statement that "aircraft and aircraft parts are not covered." Huh? Spoke to my agent today and he had never come across this either, did some research and they do not cover aircraft or parts on ANY of their policies. ________________________________________________________________________________
Date: Mar 23, 2010
It might also be possible to buy a rider to cover your airplane stuff. Jim -----Original Message----- >From: David Paule <dpaule(at)frii.com> >Sent: Mar 23, 2010 6:58 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Insurance question > > >Contact your local police and ask them how serious they'd estimate your >local threat is. > >If their estimate seems more than you are comfortable with, contact an >aircraft insurance broker to arrange for coverage while building. It is >available. > >David Paule > > > > >Ran into an odd situation recently and wanted to see what others have done >in the past, or are currently doing. > >I recently sold my house and am renting now, so I switched to a renters >insurance policy. Since I was bored last night (the plane is still in >storage for another week) I was reading through the policy, and came across >the statement that "aircraft and aircraft parts are not covered." Huh? > >Spoke to my agent today and he had never come across this either, did some >research and they do not cover aircraft or parts on ANY of their policies. > > ________________________________________________________________________________
Date: Mar 23, 2010
If all you are concerned about is recouping the cost of raw materials, then who's to say you are building an airplane? It could be a one-off wooden boat of your own design, a large weathervane for your yard....find out what won't be an issue and call it that. Keep a list of receipts or documentation for your raw materials for valuation purposes if something is stolen. Kind of like the Feds....don't tell them anymore than they need to know. :P Ryan Sent from my iPhone On Mar 23, 2010, at 3:36 PM, Dan Loegering wrote: > > > > Ran into an odd situation recently and wanted to see what others > have done in the past, or are currently doing. > > I recently sold my house and am renting now, so I switched to a > renters insurance policy. Since I was bored last night (the plane > is still in storage for another week) I was reading through the > policy, and came across the statement that "aircraft and aircraft > parts are not covered." Huh? > > Spoke to my agent today and he had never come across this either, > did some research and they do not cover aircraft or parts on ANY of > their policies. > > So my question is this - what, if anything, did you do to provide > coverage for your projects while they were in the project stage? I > am simply looking to cover my costs of materials in the event of > theft, fire, etc... Is this something that I should not worry about > (I am normally a trusting individual, but the new house is close to > a high school and the garage is located in the alley - apparently > there have been issues in the past with some of the garages being > used as gathering places by the students) One neighbor suggested > blocking the windows and getting a bigger lock... I may not go to > that extreme (it isn't THAT bad of a neighborhood...) but I will > definitely be putting in a new lock. > > It will be nice to get back to building though - time to make more > sawdust and grind some metal! > > Dan Loegering > Fargo, ND > > ________________________________________________________________________________
Date: Mar 23, 2010
Gene, Beautiful prop and Piet! Jack DSM Here's a photo of the cloudcars prop (76x38) on my plane. Needless to say, I love it. Being the first (that I know of) to put the 76 x 38 on a A 65 Piet, Jay worked with me and even told me that after he made it, if it didn't work out he would change it for free. You can contact him at 325 356 2810 or e-mail him at cloudcars @ verizon.net. Tell him Gene from Tennessee said hi. Gene N502R ________________________________________________________________________________
Date: Mar 23, 2010
Tell 'em those ashes were fom a boat you were building. An Airboat, which explains the Continental engine. Now I'll have a bit more 'splaining to do to recover anything from the RV-10 project in my basement. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Loegering Sent: Tuesday, March 23, 2010 4:37 PM Subject: Pietenpol-List: Insurance question Ran into an odd situation recently and wanted to see what others have done in the past, or are currently doing. I recently sold my house and am renting now, so I switched to a renters insurance policy. Since I was bored last night (the plane is still in storage for another week) I was reading through the policy, and came across the statement that "aircraft and aircraft parts are not covered." Huh? Spoke to my agent today and he had never come across this either, did some research and they do not cover aircraft or parts on ANY of their policies. So my question is this - what, if anything, did you do to provide coverage for your projects while they were in the project stage? I am simply looking to cover my costs of materials in the event of theft, fire, etc... Is this something that I should not worry about (I am normally a trusting individual, but the new house is close to a high school and the garage is located in the alley - apparently there have been issues in the past with some of the garages being used as gathering places by the students) One neighbor suggested blocking the windows and getting a bigger lock... I may not go to that extreme (it isn't THAT bad of a neighborhood...) but I will definitely be putting in a new lock. It will be nice to get back to building though - time to make more sawdust and grind some metal! Dan Loegering Fargo, ND ________________________________________________________________________________
Date: Mar 23, 2010
Subject: Mini Piet fly in, Gum Creek Airport in GA
-======================== ________________________________________________________________________________
Date: Mar 23, 2010
Subject: Re: Mini Piet fly in, Gum Creek Airport in GA
Absolutely! I was out flying 1EE this evening. Ya'll shoulda called, I'd've flown over! ________________________________________________________________________________
Subject: Re: Cloudcars prop on N502R
Date: Mar 23, 2010
Gene what did he put on the leading edge for protection? I can't ell in the photo. Just wondering. Boy that thing is purty. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291515#291515 ________________________________________________________________________________
Date: Mar 23, 2010
Jay Anderson CLOUDCARS 325-356-2810 cloudcars(AT)verizon.net That is what I have in my address book -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291520#291520 ________________________________________________________________________________
Date: Mar 24, 2010
Subject: Cloudcar Scimitar Propellers
Gentleman, - I inquired about what prop to use with an A-65 and many of responded and fo r that I thankyou.--A couple of you mentioned a Cloudcar Scimitar. I di d some research and the scimitar design sounds great except for short lifes pan of maybe 500 hours. Well I may not fly more than 100 hours a year so th ats not so bad, but using 3 different search engines, I cannot find anythin g about a Cloudcar prop. So can you tell me please, where are they and what s their phone number?-What is the name of the company? Maybe they just do n't have a presence on the internet. Thanks, - Jeff Wilson GN-1 St. Louis, MO=0A=0A=0A ________________________________________________________________________________
Date: Mar 24, 2010
Subject: Re: Cloudcar Scimitar Propellers
Jeff, I did not know about the short lifespan. Could you send us some links or other information on that? Thanks, Jeff >Gentleman, > >I inquired about what prop to use with an A-65 and many of responded >and for that I thankyou. A couple of you mentioned a Cloudcar >Scimitar. I did some research and the scimitar design sounds great >except for short lifespan of maybe 500 hours. Well I may not fly >more than 100 hours a year so thats not so bad, but using 3 >different search engines, I cannot find anything about a Cloudcar >prop. So can you tell me please, where are they and whats their >phone number? What is the name of the company? Maybe they just don't >have a presence on the internet. >Thanks, > >Jeff Wilson >GN-1 >St. Louis, MO -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 24, 2010
Jeff, here is contact info for Cloudcars. Someone provided this info in the last few days on our site, but this is from my contact with the company. Jay Anderson CLOUDCARS 325-356-2810 cloudcars(at)verizon.net I am sure that the alleged longevity issues you mention are news to all of us. Jay at Cloudcars should be able to dispel any concerns. Tim in central TX -----Original Message----- From: jeff wilson Sent: Mar 24, 2010 7:50 AM Subject: Pietenpol-List: Cloudcar Scimitar Propellers Gentleman, I inquired about what prop to use with an A-65 and many of responded and for that I thankyou. A couple of you mentioned a Cloudcar Scimitar. I did some research and the scimitar design sounds great except for short lifespan of maybe 500 hours. Well I may not fly more than 100 hours a year so thats not so bad, but using 3 different search engines, I cannot find anything about a Cloudcar prop. So can you tell me please, where are they and whats their phone number? What is the name of the company? Maybe they just don't have a presence on the internet. Thanks, Jeff Wilson GN-1 St. Louis, MO ________________________________________________________________________________
Date: Mar 24, 2010
Subject: A message from Cloudcars re scimitar props
I asked Jay at Cloudcars about the alleged longevity issue. This is his reply. He will also post this same or similar info to our site when Matt Dralle recognizes his membership and allows him to post. Tim in central TX ============== In reply to the comments about our propellers' lifespan..... Before everyone goes into a panic, I'd like to clear up a possible misunderstanding!!!! The Scimitars that we cut are NOT "true functioning" Scimitars. They are a "profile Scimitar" (basically like a club profile). All propeller blades will flex. A true functioning Scimitar is designed to flex a lot more than a conventional propeller, and along more of the blade span. On a true functioning Scimitar the lams are vertical instead of horizontal, so as to amplify the woods flexing characteristics. This is not so with our Scimitars. Our lams are a conventional horizontal sandwich or stack, just like Sensenich and others. The airfoil is cut the same also. There is a slight flexing at the tip, which is common in all propellers, especially those with a blade sweep. I'm not sure how someone came up with 500 hours.....all woods have different characteristics and there is no way this could be applied in a concrete way. If any of you guys have knowledge of bow making/archery, especially long bows...this might help to explain the different characteristics of wood elasticity. You won't find us on the internet, we don't have a website, or advertise any more. All of our business is by referral and word of mouth. If you have any questions or concerns, please contact me. Jay Anderson CLOUDCARS cloudcars(at)verizon.net 325-356-2810 ________________________________________________________________________________
Date: Mar 24, 2010
Subject: Re: A message from Cloudcars re scimitar props
Not mentioned is the effect of solid versus lamination or if there is any effect. My prop is solid, most everyone else buys laminated. I'm really cheap. > > >I asked Jay at Cloudcars about the alleged longevity issue. This is >his reply. He will also post this same or similar info to our site >when Matt Dralle recognizes his membership and allows him to post. >Tim in central TX >============== > >In reply to the comments about our propellers' lifespan..... >Before everyone goes into a panic, I'd like to clear up a possible >misunderstanding!!!! > >The Scimitars that we cut are NOT "true functioning" Scimitars. They >are a "profile >Scimitar" (basically like a club profile). All propeller blades will flex. >A true functioning Scimitar is designed to flex a lot more than a >conventional propeller, and along more of the blade span. On a true >functioning Scimitar the lams are vertical instead of horizontal, so >as to amplify the woods flexing characteristics. This is not so with >our Scimitars. > >Our lams are a conventional horizontal sandwich or stack, just like >Sensenich and others. >The airfoil is cut the same also. There is a slight flexing at the >tip, which is common in all propellers, especially those with a >blade sweep. I'm not sure how someone came up with 500 hours.....all >woods have different characteristics and there is no way this could >be applied in a concrete way. If any of you guys have knowledge of >bow making/archery, especially long bows...this might help to >explain the different characteristics of wood elasticity. > >You won't find us on the internet, we don't have a website, or >advertise any more. >All of our business is by referral and word of mouth. > >If you have any questions or concerns, please contact me. >Jay Anderson >CLOUDCARS >cloudcars(at)verizon.net >325-356-2810 -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 25, 2010
But Bill, seeing how I like to change things AND NOT do what others do, I'l l have to make my single wheel landing gear retractable, but no heavier the n a single fixed! ( Now I have to machine a crank handle, gears, shafts...) - I agree with the others as well Jack, very nice fuse. To me, it has been th e most fun part to work on. ________________________________________________________________________________
Subject: Rudder cables
Date: Mar 25, 2010
Hi Everyone out there in Pietland. Has anyone out there run their rudder c ables directly to the rudder horn as per the plans? I drilled a couple litt le holes in my seat back and ran some string and except for the asthetics o f haveing the cable in the rear pit it seems to work out really nice and si mple and Tony B. recommends it. AND those who have run them under the se at.. I have seen pics of pulleys behind the seat to turn the cables up. do they run directly to the rudder from there or is there another pulley or fa irlead at the rear used to turn the cable angle back down?? Thanks in adva nce Ed G. _________________________________________________________________ The New Busy is not the old busy. Search=2C chat and e-mail from your inbox . http://www.windowslive.com/campaign/thenewbusy?ocid=PID27925::T:WLMTAGL:O N:WL:en-US:WM_HMP:032010_3 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: gps speed
Date: Mar 25, 2010
Potentially stupid question but... Are GPS speeds ground speeds or do they have some way to figure out your airspeed? I'm assuming it can only track you against the ground, but who knows these days. Thanks Douwe ________________________________________________________________________________
Date: Mar 25, 2010
Subject: Re: Rudder cables
Ed: I ran the cables from the rudder bar to a set of dual pulleys directly behind the pilot's seat back. One pulley directs the cable up to the rudder horn and the second directs a second cable down to the tail wheel steering horn. There is a small wood fairlead installed on the rudder cables at the point where the cables will exit the airplane. This fairlead is not so much to change cable direction as it is to minimize the size of the slot through the fabric covering material by holding cable movement at that point to just in and out. Sorry, I don't have any photos available at this time. Tom Stinemetze N328X (eventually) >>I have seen pics of pulleys behind the seat to turn the cables up. do they run directly to the rudder from there or is there another pulley or fairlead at the rear used to turn the >>cable angle back down?? Thanks in advance Ed G. ________________________________________________________________________________
Date: Mar 25, 2010
Subject: Cloudcars prop: correcting myself
I stated yesterday that my Cloudcars prop is solid and not laminated. Jay kindly corrected me - all of his props are laminated, it's just that some have alternating woods that are distinctly different in color. My prop is of the same wood stained so dark (my preference) that I couldn't tell. I was up yesterday evening flying. Super still air. It was a good reminder of how much a difference this prop makes. Great climb and no loss of speed at cruise or top rpm. In fact, I was playing around flying loose formation with another guy from 2GA9. To catch up to him I was running at 2500 rpm and approaching 100 mph. That is really fast for our Piet! Once I caught up, we slow-flighted around for about a half hour. I was running at 1850-1900 rpm, which gave level flight at 55-60 mph. Boy, that was a lot of fun! I think I was right at the peak of the power curve. Any slower and I would have had to increase rpm to maintain level flight. Any more rpm, and I picked up speed. -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 25, 2010
Subject: Re: gps speed
ground speeds -----Original Message----- >From: Douwe Blumberg <douweblumberg(at)earthlink.net> >Sent: Mar 25, 2010 8:58 AM >To: pietenpolgroup >Subject: Pietenpol-List: gps speed > > >Potentially stupid question but... > >Are GPS speeds ground speeds or do they have some way to figure out your >airspeed? > >I'm assuming it can only track you against the ground, but who knows these >days. > >Thanks > >Douwe > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Mar 25, 2010
Subject: gps speed
Douwe, GPS indicated your speed over the ground. It is really nice when you're coming home from Wisconsin and sometimes it says 90 or 95 in a Pietenpol. Likewise it is laborious westbound sometimes when it says horrible things like 50, 55.... Mike C. ________________________________________________________________________________
Date: Mar 25, 2010
Ed, I ran mine back to a pair of pullies basically one stage ahead of the point of the pivot of the swingarm of the original tailwheel. Then to the tailwheel, hooked to it with springs. walt evans NX140DL ----- Original Message ----- From: Ed G. To: piet-list piet-list Sent: Thursday, March 25, 2010 12:01 PM Subject: Pietenpol-List: Rudder cables Hi Everyone out there in Pietland. Has anyone out there run their rudder cables directly to the rudder horn as per the plans? I drilled a couple little holes in my seat back and ran some string and except for the asthetics of haveing the cable in the rear pit it seems to work out really nice and simple and Tony B. recommends it. AND those who have run them under the seat.. I have seen pics of pulleys behind the seat to turn the cables up. do they run directly to the rudder from there or is there another pulley or fairlead at the rear used to turn the cable angle back down?? Thanks in advance Ed G. ------------------------------------------------------------------------- ----- The New Busy is not the old busy. Search, chat and e-mail from your inbox. Get started. ________________________________________________________________________________
Date: Mar 25, 2010
ground speed walt evans NX140DL ----- Original Message ----- From: Douwe Blumberg To: pietenpolgroup Sent: Thursday, March 25, 2010 9:58 AM Subject: Pietenpol-List: gps speed Potentially stupid question but... Are GPS speeds ground speeds or do they have some way to figure out your airspeed? I'm assuming it can only track you against the ground, but who knows these days. Thanks Douwe ________________________________________________________________________________
Date: Mar 25, 2010
Subject: FAA issues warning about homebuilt Lancairs
FAA Issues Safety Warning for Homemade Planes AP The Federal Aviation Administration warned pilots that the Lancair, which i s built from kits, and others like it are apt to stall at speeds higher tha t 61 mph. * print<http://www.foxnews.com/us/2010/03/25/faa-issues-safety-warning-homema de-planes/> * email * share * <http://www.foxnews.com/us/2010/03/25/faa-issues-safety-warning-hom emade-planes/> <http://www.foxnews.com/us/2010/03/25/faa-issues-safety-war ning-homemade-planes/> recommend (0) <http://www.foxnews.com/us/2010/03/25/faa-issues-safety-warning-homemade-p lanes/> <http://www.foxnews.com/us/2010/03/25/faa-issues-safety-warning-h omemade-planes/> WASHINGTON -- Federal officials say high-performance homemade planes like t he one that killed a beach jogger last week in South Carolina are likely to stall at higher speeds and have been involved in a disproportionately larg e number of fatal accidents. The Federal Aviation Administration warned pilots on Thursday that the Lanc air, which is built from kits, and others like it are apt to stall at speed s higher that 61 mph. The agency also cautioned that since the planes are b uilt by amateurs, there can be differences in performance, including at wha t speed they might stall. Lancair kits are made by Lancair International Inc. of Redmond, Ore. Pharmaceutical salesman Robert Gary Jones was killed on a Hilton Head Islan d beach as the pilot of a Lancair tried to land the plane. ________________________________________________________________________________
Date: Mar 25, 2010
Hi Douwe, On 03/25/2010 08:58 AM, Douwe Blumberg wrote: > --> Pietenpol-List message posted by: "Douwe Blumberg" > > Potentially stupid question but... > > Are GPS speeds ground speeds or do they have some way to figure out your > airspeed? > > I'm assuming it can only track you against the ground, but who knows these > days. Not unless there's an ASI hooked up to your GPS unit will it show actual airspeed - it only shows ground speed. The hangliding/soaring community has some spiffy handheld GPS/ASI/barometric devices. They come with a little fan that you stick out into the slipstream. Since I'm assuming you're wondering about calibrating your ASI, use this method to determine the real vs. displayed air speeds. Get a winds aloft report to determine the direction of the wind, then fly into the wind for a minute to get an accurate reading. Then using the same power setting, turn around and fly with the wind for a minute. Average the 2 speeds and voila! there you have it. You should do it for at least 3 power settings to see if the difference between real and indicated is linear or some strange exponential curve. Cheers, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 25, 2010
The cables on 41CC are run in parallel from the rudder bar back to the tail. I don't remember exactly what happens under the seat but it's pretty simple... fairleads, I think, and after passing under the seat they diverge with the rudder cables shooting straight on back to the rudder horns but the tailwheel steering cables following the lower longerons to those hard molded plastic fairleads a couple of stations forward of the tailpost, where they dive out the sides to the steering horns on the tailwheel. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291737#291737 ________________________________________________________________________________
Subject: Re: FAA issues warning about homebuilt Lancairs
Date: Mar 25, 2010
Thanks for the warning. Should I mark the airspeed indicator with the lower end of the green arc at 61 MPH now? That's just below cruise speed ;o) Pretty soon the bureaucrats will be trying to regulate, dictate, mandate, and obfuscate everything except what their REAL business is and we'll have so many safety labels, warnings, placards, operating instructions, limitations, decals, permits, certificates, and other junk all over the airplane that we won't need any paint on them at all (latex or otherwise). -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291738#291738 ________________________________________________________________________________
Date: Mar 25, 2010
Well if you have a 30 thousand $ stack like this one and know how to fiddle with all the knobs it will even give you airspeed calibrated for altitude but on your regular handhelds, no. Michael in Maine ----- Original Message ----- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> > Are GPS speeds ground speeds or do they have some way to figure out your > airspeed? > > I'm assuming it can only track you against the ground, but who knows these > days. ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Mar 25, 2010
What does any of this have to do with the incident on the beach? The AP reported this? Sheesh... Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com On Mar 25, 2010, at 5:33 PM, "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" wrote: > > FAA Issues Safety Warning for Homemade Planes > AP > The Federal Aviation Administration warned pilots that the Lancair, > which is built from kits, and others like it are apt to stall at > speeds higher that 61 mph. > print > email > share > recommend (0) > Independent Bitmap) 3.jpg> > WASHINGTON -- Federal officials say high-performance homemade planes > like the one that killed a beach jogger last week in South Carolina > are likely to stall at higher speeds and have been involved in a > disproportionately large number of fatal accidents. > The Federal Aviation Administration warned pilots on Thursday that > the Lancair, which is built from kits, and others like it are apt to > stall at speeds higher that 61 mph. The agency also cautioned that > since the planes are built by amateurs, there can be differences in > performance, including at what speed they might stall. > Lancair kits are made by Lancair International Inc. of Redmond, Ore. > Pharmaceutical salesman Robert Gary Jones was killed on a Hilton > Head Island beach as the pilot of a Lancair tried to land the plane. > > > > > > ________________________________________________________________________________
Date: Mar 25, 2010
So exactly where is this wheel retracted to? It seems to me it could get pretty funky retracted to the rear. New meaning to the expression " crotch rocket" . He! he! Clif "There are many tunes still to be written in the Key of C." Arnold Schoenberg But Bill, seeing how I like to change things AND NOT do what others do, I'll have to make my single wheel landing gear retractable, but no heavier then a single fixed! ( Now I have to machine a crank handle, gears, shafts...) .M Perez ________________________________________________________________________________
Date: Mar 25, 2010
The important thing is, the tail wheel control arms, at the rudder, must rotate the same degree as the rudder, IE. same lengths on each arm or you will experience a very serious problem of tail end control. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291767#291767 ________________________________________________________________________________
Subject: Shock Mounted Instruments
Date: Mar 26, 2010
Tony Bingelis recommends shock mounts for gyros, specifically directional and attitude indicators. Anybody shock mounting their turn and banks? I'm planning for an electric model. Thanks, Jack DSM ________________________________________________________________________________
Date: Mar 26, 2010
well, I don't have my airplane here to be able to check the lengths of the tailwheel and rudder bellcrank horns but looking at the picture, they are pretty close to the same length if not just a tad shorter for the tailwheel ones. The tailwheel bellcrank horns have several different holes that the springs and cables can be hooked up to for different leverage but I've left them where Corky had them and it seems to track and handle just fine. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291790#291790 Attachments: http://forums.matronics.com//files/p6090001_511.jpg ________________________________________________________________________________
Date: Mar 26, 2010
Subject: Scimitar prop short life
Regarding the scimitar shape prop, - The info I have is just word of mouth from a conversation I had not long ag o regarding the true scimitar shape props with vertical laminations. Related to me were the experiences that Wittman had using a Scimitar prop o n his racers, and that they did not last long over 500 hours. But that's an cient history now. I trust that is not an issue with modern wooden props th at use horizontal laminations, and are considered a semi-scimitar shape. I am still somewhere on the learning curve. For instance I had to do a lot of research and reading to convince myself to accept the under camber desig n of the wing for the Piet/GN-1. Don't ask me where I found confirmation fo r my under camber question, I don't take very good notes ( I think I used t hat napkin then threw it away). - Jeff Wilson GN-1 St. Louis, MO -=0A=0A=0A ________________________________________________________________________________
Date: Mar 26, 2010
Subject: happy birthday to Jeff, happy birthday to Jeff
Happy birthday you Pietenpol Pilot you Jeff Boatright, happy birthday to yo u. See what crap everyone knows when you're on Facebook ? You already got your birthday present by getting to fly slow flight formati on with that other gent the other night in that silky smooth air so don't expect anything to show u p via UPS from us listers here okay ? Doesn't mean we don't like you though. Mike C. ________________________________________________________________________________
Date: Mar 26, 2010
Subject: Re: happy birthday to Jeff, happy birthday to Jeff
Hey, I get two birthdays this year! My real one is in August. I'll check my Facebook account, but you may have me mixed up with the other Jeff Boatright (there is at least one other on Facebook). There's even another Jeff Boatright who lives about mile from me in Decatur. Oddly enough, we're all pudgy, balding white guys of about the same age. However, I encourage you: Accept No Substitutes! I am the one true Jeff Boatright!! >Happy birthday you Pietenpol Pilot you Jeff Boatright, happy birthday to you. > >See what crap everyone knows when you're on Facebook ? > >You already got your birthday present by getting to fly slow flight >formation with that other gent >the other night in that silky smooth air so don't expect anything to >show up via UPS from us listers >here okay ? Doesn't mean we don't like you though. > >Mike C. > > ________________________________________________________________________________
Subject: Re: Shock Mounted Instruments
Date: Mar 26, 2010
My Cessna 180 and the old Cessna 170 that I used to have, both had the whole panel shock-mounted. The shock mounts are Cessna p/n 0411059-1 and the panel, as stock with 16 to 18 instruments, took six of them. When the 180 was 31 years old, I replaced them all, and they were clearly due for replacement at that time. David Paule ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Friday, March 26, 2010 5:27 AM Subject: Pietenpol-List: Shock Mounted Instruments Tony Bingelis recommends shock mounts for gyros, specifically directional and attitude indicators. Anybody shock mounting their turn and banks? I'm planning for an electric model. Thanks, Jack DSM ________________________________________________________________________________
Subject: gps speed
Date: Mar 26, 2010
Two years ago enroute to Brodhead over the Blue Ridge Mountains in my Pietenpol the GPS indicated my groundspeed was 27 knots. Somewhat discouraging. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Thursday, March 25, 2010 4:35 PM Subject: RE: Pietenpol-List: gps speed Aerospace Corporation]" Douwe, GPS indicated your speed over the ground. It is really nice when you're coming home from Wisconsin and sometimes it says 90 or 95 in a Pietenpol. Likewise it is laborious westbound sometimes when it says horrible things like 50, 55.... Mike C. ________________________________________________________________________________
Date: Mar 26, 2010
Oscar, Thanks for the picture. I noticed when you "attach" pictures they are in a link form below the attachment area. How is that done? Thanks, Jack DSM well, I don't have my airplane here to be able to check the lengths of the tailwheel and rudder bellcrank horns but looking at the picture, they are pretty close to the same length if not just a tad shorter for the tailwheel ones. The tailwheel bellcrank horns have several different holes that the springs and cables can be hooked up to for different leverage but I've left them where Corky had them and it seems to track and handle just fine. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291790#291790 Attachments: http://forums.matronics.com//files/p6090001_511.jpg ________________________________________________________________________________
Subject: C-90 GPU For Sale
Date: Mar 26, 2010
I received a response to my "wanted" post in Craigslist for an engine. Since I already :-) have one I wanted to share. I ask the gent to share more info but have not heard back. He responded with; I have a C-90 GPU engine that I will let you have for $1,500 Joseph Stephenson micahstephenson(at)aol.com Jack DSM ________________________________________________________________________________
Subject: Flathead Spring Compressor Available
Date: Mar 26, 2010
A friend of mine has a flathead valve spring compressor that he'd like to see go to a good home. Email me directly and I'll forward it to him. David Paule dpaule(at)frii.com ________________________________________________________________________________
Date: Mar 26, 2010
Subject: Re: C-90 GPU For Sale
Jack, I guess I'm not up on the nomenclature - what does GPU stand for? Thanks, Dan On 03/26/2010 12:54 PM, Jack wrote: > I received a response to my wanted post in Craigslist for an engine. > Since I already J have one I wanted to share. I ask the gent to share > more info but have not heard back. He responded with; > > I have a C-90 GPU engine that I will let you have for $1,500 > > Joseph Stephenson > > micahstephenson(at)aol.com > > Jack > > DSM > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 26, 2010
I have a Maule tailwheel on my Piet, and started out using the horns that came with it. With full rudder deflection, the tailwheel would kick over far enough to go free castoring, which made for some embarassing taxiing incidents. I went back and welded extensions on to make the horns the same length as the rudder horns, and that fixed the problem.. It doesnt turn as sharp as I'd like, but I drilled extra holes 1 inch in from the ends so I could adjust the throw. Ben Charvet NX866BC 15.2 hours on Hobbs Still hoping for Sun-N-Fun ________________________________________________________________________________
Date: Mar 26, 2010
Ground power unit. In other words, a C-90 that needs to be modified to work as an aircraft engine. May or may not be made/maintained with airworthy parts. Will need second sparkplug holes drilled, carb and intakes changed, etc. All for the price of a running A-65. OTOH, this may be a good price for an airboat engine. > >Jack, > >I guess I'm not up on the nomenclature - what does GPU stand for? > >Thanks, >Dan > > >On 03/26/2010 12:54 PM, Jack wrote: >>I received a response to my "wanted" post in Craigslist for an engine. >>Since I already J have one I wanted to share. I ask the gent to share >>more info but have not heard back. He responded with; >> >>I have a C-90 GPU engine that I will let you have for $1,500 >> >>Joseph Stephenson >> >>micahstephenson(at)aol.com >> >>Jack >> >>DSM >> >>* >> >> >>* > >-- >Dan Yocum >Fermilab 630.840.6509 >yocum@fnal.gov, http://fermigrid.fnal.gov >"I fly because it releases my mind from the tyranny of petty things." > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 26, 2010
I believe that was a "ground power unit." Various branches of the military used everything from A-40s on up to power electric generators. After all, they are light, air-cooled, etc. If this is right, and it was hooked to a gen, you'll have to look at what it takes to add a propeller and whatever else it takes to make it a real aircraft engine. For instance, I would guess that the carb on a GPU might be on top of the engine, as on an auto, but I am guessing. Others on the board must know a lot more about this than I do. Tim in central TX -----Original Message----- >From: Dan Yocum <yocum(at)fnal.gov> >Sent: Mar 26, 2010 2:10 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: C-90 GPU For Sale > > >Jack, > >I guess I'm not up on the nomenclature - what does GPU stand for? > >Thanks, >Dan > > >On 03/26/2010 12:54 PM, Jack wrote: >> I received a response to my wanted post in Craigslist for an engine. >> Since I already J have one I wanted to share. I ask the gent to share >> more info but have not heard back. He responded with; >> >> I have a C-90 GPU engine that I will let you have for $1,500 >> >> Joseph Stephenson >> >> micahstephenson(at)aol.com >> >> Jack >> >> DSM >> >> * >> >> >> * > >-- >Dan Yocum >Fermilab 630.840.6509 >yocum@fnal.gov, http://fermigrid.fnal.gov >"I fly because it releases my mind from the tyranny of petty things." > > ________________________________________________________________________________
From: "Dave Abramson" <davea(at)symbolicdisplays.com>
Date: Mar 26, 2010
Ground Power Unit DIT-VIT -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com]On Behalf Of Dan Yocum Sent: Friday, March 26, 2010 12:11 PM Subject: Re: Pietenpol-List: C-90 GPU For Sale Jack, I guess I'm not up on the nomenclature - what does GPU stand for? Thanks, Dan On 03/26/2010 12:54 PM, Jack wrote: > I received a response to my wanted post in Craigslist for an engine. > Since I already J have one I wanted to share. I ask the gent to share > more info but have not heard back. He responded with; > > I have a C-90 GPU engine that I will let you have for $1,500 > > Joseph Stephenson > > micahstephenson(at)aol.com > > Jack > > DSM > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 26, 2010
Subject: Front seat front support
I see the prints show the front (passenger) seat front support plywood goin g from the top of seat- down to the bottom sides of the fuselage. Can thi s piece just be the same size as the front of the seat, (square) or does it need to extend to the sides of the fuselage?- ________________________________________________________________________________
Date: Mar 26, 2010
Yes, it is a Ground Power Unit, used as generator engine in Airforce Single downdraft Stromberg on top of the engine. I have one, bought three years ago for $400.-- partial rebuild and convert ed for aircraft use. I would not pay $ 1,500.-- for this Just my 2 c Hans Corvair powered NX15KV -----Original Message----- From: Tim Willis <timothywillis(at)earthlink.net> Sent: Fri, Mar 26, 2010 2:19 pm Subject: Re: Pietenpol-List: C-90 GPU For Sale net> I believe that was a "ground power unit." Various branches of the militar y used verything from A-40s on up to power electric generators. After all, they are ight, air-cooled, etc. If this is right, and it was hooked to a gen, you'll have to look at what it akes to add a propeller and whatever else it takes to make it a real aircr aft ngine. For instance, I would guess that the carb on a GPU might be on top of he engine, as on an auto, but I am guessing. Others on the board must know a lot more about this than I do. im in central TX ----Original Message----- From: Dan Yocum <yocum(at)fnal.gov> Sent: Mar 26, 2010 2:10 PM Subject: Re: Pietenpol-List: C-90 GPU For Sale Jack, I guess I'm not up on the nomenclature - what does GPU stand for? Thanks, Dan On 03/26/2010 12:54 PM, Jack wrote: > I received a response to my =9Cwanted=9D post in Craigslist for an engine. > Since I already J have one I wanted to share. I ask the gent to share > more info but have not heard back. He responded with; > > I have a C-90 GPU engine that I will let you have for $1,500 > > Joseph Stephenson > > micahstephenson(at)aol.com > > Jack > > DSM > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Mar 26, 2010
Mike-my gut tells me that it needs to extend to the sides of the fuselage b ecause it acts as a fuselage bulkhead/ twisting stiffener if I'm picturing your question correctly in my head. Mike C. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, March 26, 2010 3:52 PM Subject: Pietenpol-List: Front seat front support I see the prints show the front (passenger) seat front support plywood goin g from the top of seat down to the bottom sides of the fuselage. Can this piece just be the same size as the front of the seat, (square) or does it n eed to extend to the sides of the fuselage? ________________________________________________________________________________
Subject: Re: GN-1 cabane length
Date: Mar 26, 2010
[/quote] Rick and others, It looks like the concensus for Piet plans is 1" longer for the front. I will have to do some looking at my Piet plans (I have both Piet and GN-1 drawings) and see what 1" does as far as the angle of incidence. I will report back. Seems like with a few GN-1 builders out there it would be good to settle this as there is no support from Don Grega.[/quote] Just to put a cap on this, I measured both the GN-1 airfoil and Piet airfoil and put the dimensions in Cad so I could measure the angle of incidence with different length cabanes. Here is what I found. GN-1 with equal length struts front and back the angle of incidence is 1.75 degrees. GN-1 with front struts 5/8" longer than rear the angle is 3 degrees Piet with front struts 1" longer than rear (accepted standard) is 3.25 deg. My GN-1 struts are equal length and I am going to leave them that way and try them. I have figured and easy way to add length if I need to without building new struts. Jon C. -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291851#291851 ________________________________________________________________________________
Date: Mar 26, 2010
Has the engine in question been converted to aircraft use? If so, that could change the discussion and question of value considerably. Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com On Mar 26, 2010, at 4:09 PM, hvandervoo(at)aol.com wrote: > > Yes, it is a Ground Power Unit, used as generator engine in Airforce > > Single downdraft Stromberg on top of the engine. > > I have one, bought three years ago for $400.-- partial rebuild and > converted for aircraft use. > > I would not pay $ 1,500.-- for this > > Just my 2 c > > > Hans > Corvair powered NX15KV > > > -----Original Message----- > From: Tim Willis <timothywillis(at)earthlink.net> > To: pietenpol-list(at)matronics.com > Sent: Fri, Mar 26, 2010 2:19 pm > Subject: Re: Pietenpol-List: C-90 GPU For Sale > > > > I believe that was a "ground power unit." Various branches of the > military used > everything from A-40s on up to power electric generators. After > all, they are > light, air-cooled, etc. > > If this is right, and it was hooked to a gen, you'll have to look at > what it > takes to add a propeller and whatever else it takes to make it a > real aircraft > engine. For instance, I would guess that the carb on a GPU might be > on top of > the engine, as on an auto, but I am guessing. > > Others on the board must know a lot more about this than I do. > Tim in central TX > > > -----Original Message----- > >From: Dan Yocum <yocum(at)fnal.gov> > >Sent: Mar 26, 2010 2:10 PM > >To: pietenpol-list(at)matronics.com > >Subject: Re: Pietenpol-List: C-90 GPU For Sale > > > > > >Jack, > > > >I guess I'm not up on the nomenclature - what does GPU stand for? > > > >Thanks, > >Dan > > > > > >On 03/26/2010 12:54 PM, Jack wrote: > >> I received a response to my =9Cwanted=9D post in Craigslist for an > engine. > >> Since I already J have one I wanted to share. I ask the gent to > share > >> more info but have not heard back. He responded with; > >> > >> I have a C-90 GPU engine that I will let you have for $1,500 > >> > >> Joseph Stephenson > >> > >> micahstephenson(at)aol.com > >> > >> Jack > >> > >> DSM > >> > >> * > >> > >> > >> * > > > >-- > >Dan Yocum > >Fermilab 630.840.6509 > >yocum@fnal.gov, http://fermigrid.fnal.gov > >"I fly because it releases my mind from the tyranny of petty things." > > > > > > > > > > > ======================== =========== > t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ======================== =========== > tp://forums.matronics.com > ======================== =========== > _blank>http://www.matronics.com/contribution > ======================== =========== > > ________________________________________________________________________________
Date: Mar 26, 2010
Ben, You see, the exact problem you have experienced, is why I suggested when the length of the horns are not correct there could be a problem, a very big problem. I also had the tail wheel horns too short and when the tail lifted, there wasn't enough rudder to keep me on the runway, as the rudder was fully pushed, one direction was restricted in defection, and off the runway we went, Wife on board: And explain that maneuver NOT ! The steerable -full swivel, (Ala, Ken Perkins design ),can be a problem also, if one kicks a full rudder and it might unlock the tail wheel, Something like a landing on 36L at EAA with a 20 knot wind from the 270 quadrant. And the Piet under 20 Knots. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291855#291855 ________________________________________________________________________________
Date: Mar 26, 2010
I believe=C2- you are thinking of the right thing Mike. I looked at it an d thought it needed to extend to sides for a reason, it just looks inadequa te to really do much in my eyes. Those ears get some holes in them for the rudder cables as well. I guess there is a reason for them to be extended, I just have a hard time seeing it...being such a small piece. =C2- Any other thoughts? --- On Fri, 3/26/10, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] <michael.d.cuy @nasa.gov> Subject: RE: Pietenpol-List: Front seat front support Date: Friday, March 26, 2010, 4:14 PM Mike=94my gut tells me that it needs to extend to the sides of the fu selage because it acts as a fuselage bulkhead/ twisting stiffener if I=99m picturing your question correctly in my head. =C2- Mike C. =C2- =C2- =C2- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, March 26, 2010 3:52 PM Subject: Pietenpol-List: Front seat front support =C2- I see the prints show the front (passenger) seat front support plywood goin g from the top of seat=C2- down to the bottom sides of the fuselage. Can this piece just be the same size as the front of the seat, (square) or does it need to extend to the sides of the fuselage?=C2- =C2- =C2-http:/ /www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp: //www.matronics.com/contribution =C2- ________________________________________________________________________________
Date: Mar 26, 2010
Pietri, With the tail horns too short the rudder would react more and get quicker rudder response. walt evans NX140DL ----- Original Message ----- From: Pieti Lowell To: pietenpol-list(at)matronics.com Sent: Friday, March 26, 2010 5:23 PM Subject: Pietenpol-List: Re: Rudder cables Ben, You see, the exact problem you have experienced, is why I suggested when the length of the horns are not correct there could be a problem, a very big problem. I also had the tail wheel horns too short and when the tail lifted, there wasn't enough rudder to keep me on the runway, as the rudder was fully pushed, one direction was restricted in defection, and off the runway we went, Wife on board: And explain that maneuver NOT ! The steerable -full swivel, (Ala, Ken Perkins design ),can be a problem also, if one kicks a full rudder and it might unlock the tail wheel, Something like a landing on 36L at EAA with a 20 knot wind from the 270 quadrant. And the Piet under 20 Knots. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291855#291855 ________________________________________________________________________________
Date: Mar 26, 2010
Wayne and others.that's all the info I have. I have no idea if it's good, bad, high or low time operated by a Great Grandma on Sundays only. Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Wayne Bressler Sent: Friday, March 26, 2010 2:31 PM Subject: Re: Pietenpol-List: C-90 GPU For Sale Has the engine in question been converted to aircraft use? If so, that could change the discussion and question of value considerably. Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com On Mar 26, 2010, at 4:09 PM, hvandervoo(at)aol.com wrote: Yes, it is a Ground Power Unit, used as generator engine in Airforce Single downdraft Stromberg on top of the engine. I have one, bought three years ago for $400.-- partial rebuild and converted for aircraft use. I would not pay $ 1,500.-- for this Just my 2 c Hans Corvair powered NX15KV -----Original Message----- From: Tim Willis <timothywillis(at)earthlink.net> Sent: Fri, Mar 26, 2010 2:19 pm Subject: Re: Pietenpol-List: C-90 GPU For Sale timothywillis(at)earthlink.net> I believe that was a "ground power unit." Various branches of the military used everything from A-40s on up to power electric generators. After all, they are light, air-cooled, etc. If this is right, and it was hooked to a gen, you'll have to look at what it takes to add a propeller and whatever else it takes to make it a real aircraft engine. For instance, I would guess that the carb on a GPU might be on top of the engine, as on an auto, but I am guessing. Others on the board must know a lot more about this than I do. Tim in central TX -----Original Message----- >From: Dan Yocum < <mailto:yocum(at)fnal.gov> yocum(at)fnal.gov> >Sent: Mar 26, 2010 2:10 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: C-90 GPU For Sale > yocum(at)fnal.gov> > >Jack, > >I guess I'm not up on the nomenclature - what does GPU stand for? > >Thanks, >Dan > > >On 03/26/2010 12:54 PM, Jack wrote: >> I received a response to my "wanted" post in Craigslist for an engine. >> Since I already J have one I wanted to share. I ask the gent to share >> more info but have not heard back. He responded with; >> >> I have a C-90 GPU engine that I will let you have for $1,500 >> >> Joseph Stephenson >> >> micahstephenson(at)aol.com < mailto:micahstephenson(at)aol.com> >> >> Jack >> >> DSM >> >> * >> >> >> * > >-- >Dan Yocum >Fermilab 630.840.6509 > yocum@fnal.gov, <http://fermigrid.fnal.gov/> http://fermigrid.fnal.gov >"I fly because it releases my mind from the tyranny of petty things." > > > > t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ________________________________________________________________________________
Date: Mar 26, 2010
Ground Power Unit....not to be confused with GPS Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum Sent: Friday, March 26, 2010 1:11 PM Subject: Re: Pietenpol-List: C-90 GPU For Sale Jack, I guess I'm not up on the nomenclature - what does GPU stand for? Thanks, Dan On 03/26/2010 12:54 PM, Jack wrote: > I received a response to my "wanted" post in Craigslist for an engine. > Since I already J have one I wanted to share. I ask the gent to share > more info but have not heard back. He responded with; > > I have a C-90 GPU engine that I will let you have for $1,500 > > Joseph Stephenson > > micahstephenson(at)aol.com > > Jack > > DSM > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 26, 2010
Some have rigged their tailwheel cable movement to be an adjustable percentage of their rudder cable movement for this reason. rick On Fri, Mar 26, 2010 at 3:23 PM, Pieti Lowell wrote: > > Ben, > You see, the exact problem you have experienced, is why I suggested when the length of the horns are not correct there could be a problem, a very big problem. I also had the tail wheel horns too short and when the tail lifted, there wasn't enough rudder to keep me on the runway, as the rudder was fully pushed, one direction was restricted in defection, and off the runway we went, Wife on board: And explain that maneuver NOT ! > The steerable -full swivel, (Ala, Ken Perkins design ),can be a problem also, if one kicks a full rudder and it might unlock the tail wheel, Something like a landing on 36L at EAA with a 20 knot wind from the 270 quadrant. And the Piet under 20 Knots. > Pieti Lowell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291855#291855 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 26, 2010
Walt, When the tail wheel horns are shorter than the rudder horns the tail wheel will max the rotation before the rudders equal rotation. I.E. If the Tail wheel horns are a total length of 6 " and the rudder horns are 12 " long, you push right rudder fully down and the cable to the movement of the tail wheel will be maxed, and the rudder will have hardly moved, when the tail lifts off and you have a cross wind you have no rudder control, because the cable on the rudder has hardly moved at half the forward distant. and you need a bunch of forward speed to take up the long dwell time, getting off the ground,and with very little rudder control. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291876#291876 ________________________________________________________________________________
Subject: Re: Front seat front support
Date: Mar 26, 2010
Mr. Cuy is right on. That brace prevents the front seat from racking side-to-side. Greg Cardinal ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Friday, March 26, 2010 4:33 PM Subject: RE: Pietenpol-List: Front seat front support I believe you are thinking of the right thing Mike. I looked at it and thought it needed to extend to sides for a reason, it just looks inadequate to really do much in my eyes. Those ears get some holes in them for the rudder cables as well. I guess there is a reason for them to be extended, I just have a hard time seeing it...being such a small piece. Any other thoughts? --- On Fri, 3/26/10, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Subject: RE: Pietenpol-List: Front seat front support To: "pietenpol-list(at)matronics.com" Date: Friday, March 26, 2010, 4:14 PM Mike=94my gut tells me that it needs to extend to the sides of the fuselage because it acts as a fuselage bulkhead/ twisting stiffener if I=99m picturing your question correctly in my head. Mike C. From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, March 26, 2010 3:52 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Front seat front support I see the prints show the front (passenger) seat front support plywood going from the top of seat down to the bottom sides of the fuselage. Can this piece just be the same size as the front of the seat, (square) or does it need to extend to the sides of the fuselage? http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution " rel=nofollow target=_blank>http://www.matronics.com/Navigator?Pietenpol-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: A little health scare slightly off topic
Date: Mar 26, 2010
I had a little health scare recently. I noticed a dark blurry spot with di stortion in my vision a couple weeks ago. Went to my optometrist yesterday who is a long time friend from high school. She identified the problem as macular edema (fluid under the center of the retina). She immediately scheduled an appointment with a retina specialist for toda y. After having my eyes dialated and filled with 4 different kinds of drop s=2C poked=2C lenses literally stuck against my eye=2C blinded by light=2C flourescent dye injected into my veins and then flash blinded by 47 picture s I was diagnosed with cystoid macular edima ( the relatively benign kind t hat usually goes away on its own). The Dr. said it is almost always caused by stress. The moral is I guess I need to get back to building. It's a great stress r eliever for me in the summer. In the winter I ski. Skied 77 days this yea r. Now if I could only figure out a way to build 77 days this summer. Doug Dever In beautiful Stow Ohio _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. ________________________________________________________________________________
Date: Mar 26, 2010
We were talking about the tailwheel horns, not the rudder. The idea is to have the tailwheel and rudder moving at the same angles Ben On 3/26/2010 5:56 PM, walt wrote: > Pietri, > With the tail horns too short the rudder would react more and get > quicker rudder response. > walt evans > NX140DL > > ----- Original Message ----- > *From:* Pieti Lowell > *To:* pietenpol-list(at)matronics.com > > *Sent:* Friday, March 26, 2010 5:23 PM > *Subject:* Pietenpol-List: Re: Rudder cables > > > > > Ben, > You see, the exact problem you have experienced, is why I > suggested when the length of the horns are not correct there could > be a problem, a very big problem. I also had the tail wheel horns > too short and when the tail lifted, there wasn't enough rudder to > keep me on the runway, as the rudder was fully pushed, one > direction was restricted in defection, and off the runway we went, > Wife on board: And explain that maneuver NOT ! > The steerable -full swivel, (Ala, Ken Perkins design ),can be a > problem also, if one kicks a full rudder and it might unlock the > tail wheel, Something like a landing on 36L at EAA with a 20 knot > wind from the 270 quadrant. And the Piet under 20 Knots. > Pieti Lowell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291855#291855 > > > http://www.matnbsp; via the Web > href="http://forums.matronics.com">http://forums.matronics.com > <http://www.matronics.com/Navigator?Pietenpol-List> > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/c================ > > > * > > > * ________________________________________________________________________________
Date: Mar 26, 2010
I'm in the process of ballasting my Piet up to gross weight to complete phase 1, and when you think about piling 200 pounds on that seat, you will be glad you put in all the bracing(I added extra) that the plans call for. Remember if the seat collapses, you lose rudder control, possibly ailerons and elevator too. Once again you get to hear someone say " build it to the plans, build it to the plans.." Ben Charvet On 3/26/2010 8:50 PM, gcardinal wrote: > Mr. Cuy is right on. That brace prevents the front seat from racking > side-to-side. > Greg Cardinal > > ----- Original Message ----- > *From:* Michael Perez > *To:* pietenpol-list(at)matronics.com > > *Sent:* Friday, March 26, 2010 4:33 PM > *Subject:* RE: Pietenpol-List: Front seat front support > > I believe you are thinking of the right thing Mike. I looked at > it and thought it needed to extend to sides for a reason, it just > looks inadequate to really do much in my eyes. Those ears get some > holes in them for the rudder cables as well. I guess there is a > reason for them to be extended, I just have a hard time seeing > it...being such a small piece.
March 18, 2010 - March 27, 2010
Pietenpol-Archive.digest.vol-iz
