Pietenpol-Archive.digest.vol-ja
March 27, 2010 - April 01, 2010
      >     Any other thoughts?
      >     --- On *Fri, 3/26/10, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace
      >     Corporation] //* wrote:
      >         From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]
      >         Subject: RE: Pietenpol-List: Front seat front support
      >         To: "pietenpol-list(at)matronics.com"
      >         Date: Friday, March 26, 2010, 4:14 PM
      >         Mikemy gut tells me that it needs to extend to the sides of
      >         the fuselage because it acts as a fuselage bulkhead/ twisting
      >         stiffener if Im picturing your question correctly in my head.
      >         Mike C.
      >         *From:* owner-pietenpol-list-server(at)matronics.com
      >         [mailto:owner-pietenpol-list-server(at)matronics.com] *On Behalf
      >         Of *Michael Perez
      >         *Sent:* Friday, March 26, 2010 3:52 PM
      >         *To:* pietenpol-list(at)matronics.com
      >         *Subject:* Pietenpol-List: Front seat front support
      >         I see the prints show the front (passenger) seat front support
      >         plywood going from the top of seat  down to the bottom sides
      >         of the fuselage. Can this piece just be the same size as the
      >         front of the seat, (square) or does it need to extend to the
      >         sides of the fuselage?
      >         *http://www.matronics.com/Navigator?Pietenpol-List*
      >         *http://forums.matronics.com*
      >         *http://www.matronics.com/contribution*
      >         " rel=nofollow target=_blank>http://www.matronics.com/Navigator?Pietenpol-List
      >         et=_blank>http://forums.matronics.com
      >         llow target=_blank>http://www.matronics.com/contribution
      >     href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List
      >     href="http://forums.matronics.com">http://forums.matronics.com
      >     href="http://www.matronics.com/contribution">http://www.matronics.com/c
Subject: Re: C-90 GPU For Sale
Date: Mar 27, 2010
Tim.. There was a big rush to buy these GPU engines and convert them for air work back in the '60s. All were military surplus and had varying numbers of hours of service on them. I vaguely remember reading more than a few articles on the conversion requirements in Sport Aviation articles from the time. Surly, a quick search of the Sport Aviation archives (online @ EAA) would reveal the posts. My dim memory of the subject nags that the application of this power plant was a marginal benefit to air work compared to other available engines-primarily due to its high weight to HP output ratio. However, due to it's cheap acquisition cost back then many guys made a go of it. Al Lyscars ----- Original Message ----- From: "Tim Willis" <timothywillis(at)earthlink.net> Sent: Friday, March 26, 2010 3:19 PM Subject: Re: Pietenpol-List: C-90 GPU For Sale > > > I believe that was a "ground power unit." Various branches of the > military used everything from A-40s on up to power electric generators. > After all, they are light, air-cooled, etc. > > If this is right, and it was hooked to a gen, you'll have to look at what > it takes to add a propeller and whatever else it takes to make it a real > aircraft engine. For instance, I would guess that the carb on a GPU might > be on top of the engine, as on an auto, but I am guessing. > > Others on the board must know a lot more about this than I do. > Tim in central TX > > > -----Original Message----- >>From: Dan Yocum <yocum(at)fnal.gov> >>Sent: Mar 26, 2010 2:10 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: C-90 GPU For Sale >> >> >>Jack, >> >>I guess I'm not up on the nomenclature - what does GPU stand for? >> >>Thanks, >>Dan >> >> >>On 03/26/2010 12:54 PM, Jack wrote: >>> I received a response to my wanted post in Craigslist for an engine. >>> Since I already J have one I wanted to share. I ask the gent to share >>> more info but have not heard back. He responded with; >>> >>> I have a C-90 GPU engine that I will let you have for $1,500 >>> >>> Joseph Stephenson >>> >>> micahstephenson(at)aol.com >>> >>> Jack >>> >>> DSM >>> >>> * >>> >>> >>> * >> >>-- >>Dan Yocum >>Fermilab 630.840.6509 >>yocum@fnal.gov, http://fermigrid.fnal.gov >>"I fly because it releases my mind from the tyranny of petty things." >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Rudder cables
Date: Mar 27, 2010
Petri, I assume that you have springs at the end of the tailwheel cables, to the tailwheel? The springs allow continued travel of the rudder past the maxing of the tailwheel. walt evans NX140DL ----- Original Message ----- From: Pieti Lowell To: pietenpol-list(at)matronics.com Sent: Friday, March 26, 2010 6:59 PM Subject: Pietenpol-List: Re: Rudder cables Walt, When the tail wheel horns are shorter than the rudder horns the tail wheel will max the rotation before the rudders equal rotation. I.E. If the Tail wheel horns are a total length of 6 " and the rudder horns are 12 " long, you push right rudder fully down and the cable to the movement of the tail wheel will be maxed, and the rudder will have hardly moved, when the tail lifts off and you have a cross wind you have no rudder control, because the cable on the rudder has hardly moved at half the forward distant. and you need a bunch of forward speed to take up the long dwell time, getting off the ground,and with very little rudder control. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291876#291876 ________________________________________________________________________________
Subject: Cylinder Head Temp
Date: Mar 27, 2010
Does anybody know what the CHT runs on a Continental with J-3 cooling eyebrows? I made a pair and that ended up too low for the front plugs -- probably reduced frontal area by 40%. It wouldn't be the first do-over. Thanks, Tom Bernie "flying in May" ________________________________________________________________________________
Date: Mar 27, 2010
Tom, I don't know the actual temperatures, but I can tell you that two years ago I broke the bracket attaching the eyebrow to the left front cylinder on the way to Brodhead. This allowed the eyebrow to splay out, leaking some of the cooling air. I made a couple of makeshift repairs which didn't hold and finally remade the bracket (out of steel - the original was aluminum) when I got home. The airplane probably flew a total of 20 hours with less than optimum cooling on the left side. The next year at the annual condition inspection I found that both cylinders on that side had weak compression so I pulled the cylinders and discovered that both of them had the piston rings stuck. I replaced the rings with new ones and have had no problems since. In discussing the problem of stuck piston rings with a number of people knowlegeable about small Continentals I found that the primary culprit to cause stuck piston rings is high cylinder head temps. All this is a long preamble to saying, if I were you I'd make them over. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas Bernie Sent: Saturday, March 27, 2010 9:23 AM Subject: Pietenpol-List: Cylinder Head Temp Does anybody know what the CHT runs on a Continental with J-3 cooling eyebrows? I made a pair and that ended up too low for the front plugs -- probably reduced frontal area by 40%. It wouldn't be the first do-over. Thanks, Tom Bernie "flying in May" ________________________________________________________________________________
Subject: Re: Cylinder Head Temp
Date: Mar 27, 2010
Thanks Jack, that's all I needed to hear. Two interesting and contradictory things I found were that some Mooney Mites have no eyebows and some have very minimal ones, and Super Cubs can have "low rise" eyebrows inside the cowling! One thing for sure, I'm not going to spend $500 bucks for a pair. Tom On Mar 27, 2010, at 9:31 AM, Jack Phillips wrote: > > Tom, > > I don't know the actual temperatures, but I can tell you that two years ago > I broke the bracket attaching the eyebrow to the left front cylinder on the > way to Brodhead. This allowed the eyebrow to splay out, leaking some of the > cooling air. I made a couple of makeshift repairs which didn't hold and > finally remade the bracket (out of steel - the original was aluminum) when I > got home. The airplane probably flew a total of 20 hours with less than > optimum cooling on the left side. The next year at the annual condition > inspection I found that both cylinders on that side had weak compression so > I pulled the cylinders and discovered that both of them had the piston rings > stuck. I replaced the rings with new ones and have had no problems since. > > In discussing the problem of stuck piston rings with a number of people > knowlegeable about small Continentals I found that the primary culprit to > cause stuck piston rings is high cylinder head temps. > > All this is a long preamble to saying, if I were you I'd make them over. > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas > Bernie > Sent: Saturday, March 27, 2010 9:23 AM > To: Pietenpol list > Subject: Pietenpol-List: Cylinder Head Temp > > > Does anybody know what the CHT runs on a Continental with J-3 cooling > eyebrows? I made a pair and that ended up too low for the front plugs -- > probably reduced frontal area by 40%. It wouldn't be the first do-over. > Thanks, > Tom Bernie > "flying in May" > > > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2010
The best source of info on the small Continentals that I know is Harry Fenton. I discussed my stuck rings with him and pointed out that some airplanes, including the Rose Parakeet don't have any cooling eyebrows. His response was that they will exhibit cooling problems sooner or later. The Mooney Mite is a lot faster, so maybe it can get enough cooling. All I know is I had less cooling on that side and got stuck rings on both those cylinders. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas Bernie Sent: Saturday, March 27, 2010 10:20 AM Subject: Re: Pietenpol-List: Cylinder Head Temp Thanks Jack, that's all I needed to hear. Two interesting and contradictory things I found were that some Mooney Mites have no eyebows and some have very minimal ones, and Super Cubs can have "low rise" eyebrows inside the cowling! One thing for sure, I'm not going to spend $500 bucks for a pair. Tom On Mar 27, 2010, at 9:31 AM, Jack Phillips wrote: > > Tom, > > I don't know the actual temperatures, but I can tell you that two years ago > I broke the bracket attaching the eyebrow to the left front cylinder on the > way to Brodhead. This allowed the eyebrow to splay out, leaking some of the > cooling air. I made a couple of makeshift repairs which didn't hold and > finally remade the bracket (out of steel - the original was aluminum) when I > got home. The airplane probably flew a total of 20 hours with less than > optimum cooling on the left side. The next year at the annual condition > inspection I found that both cylinders on that side had weak compression so > I pulled the cylinders and discovered that both of them had the piston rings > stuck. I replaced the rings with new ones and have had no problems since. > > In discussing the problem of stuck piston rings with a number of people > knowlegeable about small Continentals I found that the primary culprit to > cause stuck piston rings is high cylinder head temps. > > All this is a long preamble to saying, if I were you I'd make them over. > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas > Bernie > Sent: Saturday, March 27, 2010 9:23 AM > To: Pietenpol list > Subject: Pietenpol-List: Cylinder Head Temp > > > Does anybody know what the CHT runs on a Continental with J-3 cooling > eyebrows? I made a pair and that ended up too low for the front plugs -- > probably reduced frontal area by 40%. It wouldn't be the first do-over. > Thanks, > Tom Bernie > "flying in May" > > ________________________________________________________________________________
Date: Mar 27, 2010
I'm convinced. Thanks. On Mar 27, 2010, at 10:37 AM, Jack Phillips wrote: > > The best source of info on the small Continentals that I know is Harry > Fenton. I discussed my stuck rings with him and pointed out that some > airplanes, including the Rose Parakeet don't have any cooling eyebrows. His > response was that they will exhibit cooling problems sooner or later. > > The Mooney Mite is a lot faster, so maybe it can get enough cooling. All I > know is I had less cooling on that side and got stuck rings on both those > cylinders. > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas > Bernie > Sent: Saturday, March 27, 2010 10:20 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Cylinder Head Temp > > > Thanks Jack, that's all I needed to hear. Two interesting and contradictory > things I found were that some Mooney Mites have no eyebows and some have > very minimal ones, and Super Cubs can have "low rise" eyebrows inside the > cowling! One thing for sure, I'm not going to spend $500 bucks for a pair. > Tom > > On Mar 27, 2010, at 9:31 AM, Jack Phillips wrote: > > >> >> Tom, >> >> I don't know the actual temperatures, but I can tell you that two years > ago >> I broke the bracket attaching the eyebrow to the left front cylinder on > the >> way to Brodhead. This allowed the eyebrow to splay out, leaking some of > the >> cooling air. I made a couple of makeshift repairs which didn't hold and >> finally remade the bracket (out of steel - the original was aluminum) when > I >> got home. The airplane probably flew a total of 20 hours with less than >> optimum cooling on the left side. The next year at the annual condition >> inspection I found that both cylinders on that side had weak compression > so >> I pulled the cylinders and discovered that both of them had the piston > rings >> stuck. I replaced the rings with new ones and have had no problems since. >> >> In discussing the problem of stuck piston rings with a number of people >> knowlegeable about small Continentals I found that the primary culprit to >> cause stuck piston rings is high cylinder head temps. >> >> All this is a long preamble to saying, if I were you I'd make them over. >> >> Jack Phillips >> NX899JP >> Raleigh, NC >> >> -----Original Message----- >> From: owner-pietenpol-list-server(at)matronics.com >> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas >> Bernie >> Sent: Saturday, March 27, 2010 9:23 AM >> To: Pietenpol list >> Subject: Pietenpol-List: Cylinder Head Temp >> > >> >> Does anybody know what the CHT runs on a Continental with J-3 cooling >> eyebrows? I made a pair and that ended up too low for the front plugs -- >> probably reduced frontal area by 40%. It wouldn't be the first do-over. >> Thanks, >> Tom Bernie >> "flying in May" >> >> >> >> >> >> >> >> >> > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2010
I copied mine from a J3 Cub. The inboard attach point was an up angle attaching under the casestuds/nuts. I was advised that the attach mat'l Can't be Aluminum. Must have a angle of steel under the nuts or lose the seal on the case due to soft aluminum compressing. walt evans NX140DL ----- Original Message ----- From: Thomas Bernie To: pietenpol-list(at)matronics.com Sent: Saturday, March 27, 2010 10:20 AM Subject: Re: Pietenpol-List: Cylinder Head Temp Thanks Jack, that's all I needed to hear. Two interesting and contradictory things I found were that some Mooney Mites have no eyebows and some have very minimal ones, and Super Cubs can have "low rise" eyebrows inside the cowling! One thing for sure, I'm not going to spend $500 bucks for a pair. Tom On Mar 27, 2010, at 9:31 AM, Jack Phillips wrote: > > Tom, > > I don't know the actual temperatures, but I can tell you that two years ago > I broke the bracket attaching the eyebrow to the left front cylinder on the > way to Brodhead. This allowed the eyebrow to splay out, leaking some of the > cooling air. I made a couple of makeshift repairs which didn't hold and > finally remade the bracket (out of steel - the original was aluminum) when I > got home. The airplane probably flew a total of 20 hours with less than > optimum cooling on the left side. The next year at the annual condition > inspection I found that both cylinders on that side had weak compression so > I pulled the cylinders and discovered that both of them had the piston rings > stuck. I replaced the rings with new ones and have had no problems since. > > In discussing the problem of stuck piston rings with a number of people > knowlegeable about small Continentals I found that the primary culprit to > cause stuck piston rings is high cylinder head temps. > > All this is a long preamble to saying, if I were you I'd make them over. > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas > Bernie > Sent: Saturday, March 27, 2010 9:23 AM > To: Pietenpol list > Subject: Pietenpol-List: Cylinder Head Temp > > > Does anybody know what the CHT runs on a Continental with J-3 cooling > eyebrows? I made a pair and that ended up too low for the front plugs -- > probably reduced frontal area by 40%. It wouldn't be the first do-over. > Thanks, > Tom Bernie > "flying in May" > > > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2010
In the '60s, those were Lycoming O-290s. Different engine, different issues ,but there might be similar issues with the current crop of GPUs. Some of the issues were converting the ignition to dual magnetos, converting the induction to an updraft carb with mixture control, and whittling down a mounting boss on teh front of the case to save weight. Oh, and the starter ring gear wasn't there, nor the starter, both needed to be acquired. The sludge tubes in the crank were totally full of sludge, I remember, so that mandated a full overhaul with extra emphasis on cleaning passageways. And the crankshaft prop flange tended to crack. Eventually a flange beef-up kit was available that seemed to fix that problem. Sounds like a lot of work, but probably not much different, all in all, than converting a Model A. Just remember that when you open the crate, you'd be getting a project, not a flyable airplane engine. David Paule There was a big rush to buy these GPU engines and convert them for air work back in the '60s. All were military surplus and had varying numbers of hours of service on them. ________________________________________________________________________________
Subject: links to email attachments
Date: Mar 27, 2010
Jack asked: >I noticed when you "attach" pictures they are in >a link form below the attachment area. How is that >done? I think if you post the email via the Matronics Piet forum rather than the email list and add the attachment there, the link to the attachment shows up in your post. If you are on the digest version of the email list (which I am), this can be very useful because as everyone who takes the digest knows, attachments don't come through in the daily digest. On the forum, they do. I take the digest so I won't spend as much time reading Piet emails at work, but I find myself logging onto the forum to check them anyway. PS, if you want to get me in trouble, call my boss, Pat Griffith, at (210)522-5533 and tell him I'm reading airplane emails instead of working. Maybe he'll fire me and I can go work on airplanes full-time instead of being an engineer. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: New Member Lurking on the Lists
Date: Mar 27, 2010
Good Morning All - Just wanted to take a minute and introduce myself, as I will be spending time reading this list. My name is Gary Wilson and as of now, I have not built an airplane, but helped my father build a Questair Venture. It took him 20 years, but it turned out to be a beautiful bird (see pic). Now with a family of my own, we are just about ready to start our own "family" plane. While walking through the affordable flying hangar at Oshkosh in 2008, I saw my first Piet, and have been fascinated ever since. We have now settled on the Air Camper as our family plane, and plan to start construction in the fall. Here is my plan of action so far to get us to the August time frame. 1 - Join local EAA chapter and start attending regular meetings to develop a network of local builders. 2 - Attend Brodhead - Take as many notes and pictures as I can! 3 - Oshkosh - spend time in the woodworking tent and study engine options (especially William Wynne's Corvair option). 4 - Order Plans As a first timer just getting started, I would certainly welcome any advice you might provide as I get started. Also, if anyone is building or has a Pietenpol in the Greenville (Appleton) Wisconsin area, I would love to hear from you. I look forward to learning a lot from each of you! Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291947#291947 Attachments: http://forums.matronics.com//files/venture_856.jpg ________________________________________________________________________________
Date: Mar 27, 2010
That is correct, Walt. I made those brackets out of steel, but had used aluminum under the rocker box cover screws. Those aluminum brackets were what broke, and now ALL the brackets on mine are steel. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of walt Sent: Saturday, March 27, 2010 11:17 AM Subject: Re: Pietenpol-List: Cylinder Head Temp I copied mine from a J3 Cub. The inboard attach point was an up angle attaching under the casestuds/nuts. I was advised that the attach mat'l Can't be Aluminum. Must have a angle of steel under the nuts or lose the seal on the case due to soft aluminum compressing. walt evans NX140DL ----- Original Message ----- From: Thomas <mailto:tsbernie(at)earthlink.net> Bernie Sent: Saturday, March 27, 2010 10:20 AM Subject: Re: Pietenpol-List: Cylinder Head Temp Thanks Jack, that's all I needed to hear. Two interesting and contradictory things I found were that some Mooney Mites have no eyebows and some have very minimal ones, and Super Cubs can have "low rise" eyebrows inside the cowling! One thing for sure, I'm not going to spend $500 bucks for a pair. Tom On Mar 27, 2010, at 9:31 AM, Jack Phillips wrote: > > Tom, > > I don't know the actual temperatures, but I can tell you that two years ago > I broke the bracket attaching the eyebrow to the left front cylinder on the > way to Brodhead. This allowed the eyebrow to splay out, leaking some of the > cooling air. I made a couple of makeshift repairs which didn't hold and > finally remade the bracket (out of steel - the original was aluminum) when I > got home. The airplane probably flew a total of 20 hours with less than > optimum cooling on the left side. The next year at the annual condition > inspection I found that both cylinders on that side had weak compression so > I pulled the cylinders and discovered that both of them had the piston rings > stuck. I replaced the rings with new ones and have had no problems since. > > In discussing the problem of stuck piston rings with a number of people > knowlegeable about small Continentals I found that the primary culprit to > cause stuck piston rings is high cylinder head temps. > > All this is a long preamble to saying, if I were you I'd make them over. > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Thomas > Bernie > Sent: Saturday, March 27, 2010 9:23 AM > To: Pietenpol list > Subject: Pietenpol-List: Cylinder Head Temp > > > Does anybody know what the CHT runs on a Continental with J-3 cooling > eyebrows? I made a pair and that ended up too low for the front plugs -- > probably reduced frontal area by 40%. It wouldn't be the first do-over. > Thanks, > Tom Bernie > "flying in May" > > > > > > > > > p; Features Chat, http://www.matnbsp; <http://www.matronics.com/Navigator?Pietenpol-List> via the Web href="http://forums.matronics.com">http://forums.matronics.com _p; generous bsp; href="http://www.matronics.com/contribution">http://www.matronics.com/c==== =========== ________________________________________________________________________________
Subject: Re: New Member Lurking on the Lists
Date: Mar 27, 2010
If you're only going to have one airplane, get one with more seats than your family, so you can take friends along as well as family. Make sure that it has a closed cockpit and a heater, so that you can actually use it in a practical manner. It should have a cruise speed of at least twice the speed of a car, point to point, or else it won't get used for traveling. The "at least" is pretty important, by the way. David Paule ________________________________________________________________________________
Date: Mar 27, 2010
Subject: Re: Front seat front support
I was more specifically looking at the ears that extend to the sides. I won dered why I could not just ply the seat front only. (Which would prevent ra cking of the seat as well.) No matter now, I already have the "eared" plywo od epoxied in. --- On Fri, 3/26/10, Ben Charvet wrote: From: Ben Charvet <bcharvet(at)bellsouth.net> Subject: Re: Pietenpol-List: Front seat front support Date: Friday, March 26, 2010, 11:07 PM I'm in the process of ballasting my Piet up to gross weight to complete pha se 1, and when you think about piling 200 pounds on that seat, you will be glad you put in all the bracing(I added extra) that the plans call for.=C2 - Remember if the seat collapses, you lose rudder control, possibly ailer ons and elevator too.=C2- Once again you get to hear someone say " build it to the plans, build it to the plans.." Ben Charvet On 3/26/2010 8:50 PM, gcardinal wrote: Mr. Cuy is right on. That brace prevents the front seat from racking side-t o-side. =C2- Greg Cardinal =C2- ----- Original Message ----- From: Michael Perez Sent: Friday, March 26, 2010 4:33 PM Subject: RE: Pietenpol-List: Front seat front support I believe=C2- you are thinking of the right thing Mike. I looked at it an d thought it needed to extend to sides for a reason, it just looks inadequa te to really do much in my eyes. Those ears get some holes in them for the rudder cables as well. I guess there is a reason for them to be extended, I just have a hard time seeing it...being such a small piece. =C2- Any other thoughts? --- On Fri, 3/26/10, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] <michael.d.cuy @nasa.gov> Subject: RE: Pietenpol-List: Front seat front support Date: Friday, March 26, 2010, 4:14 PM #yiv959734480 UNKNOWN { FONT-FAMILY:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} #yiv959734480 UNKNOWN { FONT-FAMILY:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} #yiv959734480 UNKNOWN { FONT-FAMILY:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;} #yiv959734480 #yiv1263658796 #yiv1263658796 P.MsoNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"serif";} #yiv959734480 #yiv1263658796 LI.MsoNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"serif";} #yiv959734480 #yiv1263658796 DIV.MsoNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"serif";} #yiv959734480 #yiv1263658796 A:link { COLOR:blue;TEXT-DECORATION:underline;} #yiv959734480 #yiv1263658796 SPAN.MsoHyperlink { COLOR:blue;TEXT-DECORATION:underline;} #yiv959734480 #yiv1263658796 A:visited { COLOR:purple;TEXT-DECORATION:underline;} #yiv959734480 #yiv1263658796 SPAN.MsoHyperlinkFollowed { COLOR:purple;TEXT-DECORATION:underline;} #yiv959734480 #yiv1263658796 PRE { FONT-SIZE:10pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Courier New";} #yiv959734480 #yiv1263658796 SPAN.HTMLPreformattedChar { FONT-FAMILY:Consolas;} #yiv959734480 #yiv1263658796 SPAN.EmailStyle19 { COLOR:#1f497d;FONT-FAMILY:"sans-serif";} #yiv959734480 #yiv1263658796 .MsoChpDefault { } #yiv959734480 UNKNOWN { MARGIN:1in;} #yiv959734480 #yiv1263658796 DIV.Section1 { } Mike=94my gut tells me that it needs to extend to the sides of the fu selage because it acts as a fuselage bulkhead/ twisting stiffener if I=99m picturing your question correctly in my head. =C2- Mike C. =C2- =C2- =C2- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, March 26, 2010 3:52 PM Subject: Pietenpol-List: Front seat front support =C2- I see the prints show the front (passenger) seat front support plywood goin g from the top of seat=C2- down to the bottom sides of the fuselage. Can this piece just be the same size as the front of the seat, (square) or does it need to extend to the sides of the fuselage?=C2- =C2- =C2-http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matro nics.comhttp://www.matronics.com/contribution =C2- " rel=nofollow target=_blank>http://www.matronics.com/Navigator?Pietenp ol-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution ________________________________________________________________________________
Date: Mar 27, 2010
Gary, Welcome!! I'm always happy to meet someone who's name I can remember... Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of gtche98 Sent: Saturday, March 27, 2010 10:35 AM Subject: Pietenpol-List: New Member Lurking on the Lists Good Morning All - Just wanted to take a minute and introduce myself, as I will be spending time reading this list. My name is Gary Wilson and as of now, I have not built an airplane, but helped my father build a Questair Venture. It took him 20 years, but it turned out to be a beautiful bird (see pic). Now with a family of my own, we are just about ready to start our own "family" plane. While walking through the affordable flying hangar at Oshkosh in 2008, I saw my first Piet, and have been fascinated ever since. We have now settled on the Air Camper as our family plane, and plan to start construction in the fall. Here is my plan of action so far to get us to the August time frame. 1 - Join local EAA chapter and start attending regular meetings to develop a network of local builders. 2 - Attend Brodhead - Take as many notes and pictures as I can! 3 - Oshkosh - spend time in the woodworking tent and study engine options (especially William Wynne's Corvair option). 4 - Order Plans As a first timer just getting started, I would certainly welcome any advice you might provide as I get started. Also, if anyone is building or has a Pietenpol in the Greenville (Appleton) Wisconsin area, I would love to hear from you. I look forward to learning a lot from each of you! Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291947#291947 Attachments: http://forums.matronics.com//files/venture_856.jpg ________________________________________________________________________________
Date: Mar 27, 2010
Why wait 4-5 months to buy plans? You can't start building until you have plans! If you are interested in the Wynne Corvair conversion shoot me an email. We are putting our build on hiatus as we just have no space to build where we live right now, and can't spend enough time at the shop where we have the project. We're going to try to buy a flying Piet instead. As such we have our Corvair conversion parts for sale...pretty much everything you need to build a Wynne Corvair conversion: case, crank, heads, Wynne parts, overhaul parts. Everything reworked/new and ready to put together. Send me an email for details. Best of luck with your build! Ryan rmueller23(at)gmail.com On Mar 27, 2010, at 12:35 PM, "gtche98" wrote: > > > > Good Morning All - Just wanted to take a minute and introduce > myself, as I will be spending time reading this list. My name is > Gary Wilson and as of now, I have not built an airplane, but helped > my father build a Questair Venture. It took him 20 years, but it > turned out to be a beautiful bird (see pic). > > Now with a family of my own, we are just about ready to start our > own "family" plane. While walking through the affordable flying > hangar at Oshkosh in 2008, I saw my first Piet, and have been > fascinated ever since. We have now settled on the Air Camper as our > family plane, and plan to start construction in the fall. Here is > my plan of action so far to get us to the August time frame. > > 1 - Join local EAA chapter and start attending regular meetings to > develop a network of local builders. > 2 - Attend Brodhead - Take as many notes and pictures as I can! > 3 - Oshkosh - spend time in the woodworking tent and study engine > options (especially William Wynne's Corvair option). > 4 - Order Plans > > As a first timer just getting started, I would certainly welcome any > advice you might provide as I get started. Also, if anyone is > building or has a Pietenpol in the Greenville (Appleton) Wisconsin > area, I would love to hear from you. > > I look forward to learning a lot from each of you! > > Gary > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291947#291947 > > > Attachments: > > http://forums.matronics.com//files/venture_856.jpg > > ________________________________________________________________________________
Date: Mar 27, 2010
Subject: Re: A little health scare slightly off topic
A friend at work (in his 30s) had the same thing. He worked 60-70 hrs a week and the doctor also told him it was stress related. He told the company owner that he could only work 40 hrs a week from now on and don't even think about calling him on evenings or weekends to got fly out to a client site to work 16 hrs/day to fix any problem that comes up. Owner said OK. Didn't even change his salary. Good luck with your eye problem. rick On Fri, Mar 26, 2010 at 6:53 PM, Doug Dever wrote: > I had a little health scare recently. I noticed a dark blurry spot with > distortion in my vision a couple weeks ago. Went to my optometrist > yesterday who is a long time friend from high school. She identified the > problem as macular edema (fluid under the center of the retina). > She immediately scheduled an appointment with a retina specialist for > today. After having my eyes dialated and filled with 4 different kinds of > drops, poked, lenses literally stuck against my eye, blinded by light, > flourescent dye injected into my veins and then flash blinded by 47 pictures > I was diagnosed with cystoid macular edima ( therelatively benign kind that > usually goes away on its own). The Dr. said it is almost always caused by > stress. > > The moral is I guess I need to get back to building. It's a great stress > reliever for me in the summer. In the winter I ski. Skied 77 days this > year. Now if I could onlyfigure out a way to build 77 days this summer. > Doug Dever > In beautiful Stow Ohio > > > ________________________________ > Hotmail: Trusted email with powect/01/' target='_new'>Sign up now. > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 27, 2010
Gary, Welcome to the fold. If I may comment on your strategy I would suggest you buy the plans and begin building ASAP so when you arrive at Brodhead you have a bit of build experience to guide your picture taking, question asking and research. Its much easier to ask great questions and get solid advice when your approach is from the actual build and not the virtual or conceptual aspects of the build. Having been down that road and still in the build I found it much more to my benefit and comprehension to ask questions from experience rather than the theoretical. You will also find that since no two are alike designs and dimensions will differ from drawings to actual examples. During my travels of meeting other builders even before I began to build my project, its hard to appreciate the advice you may receive. One of the best pieces I got was from Hans Vandervort, he said that "many builders spent too much time looking at and studying the drawings trying to figure things out, you just need to start building and the rest will come to you as you go". The design and build leaves much to the builder own initiative and creativity which is where the no two like comes from. The bad news is the plans and drawings are not there insert flap A into slot B they do require some reasoning the good news is they require some reasoning and allow you the builder to make it your airplane. You just have to be ready for that. And when you get stuck or hit the builders block, pull back give her a good long look and shell talk to ya, she'll tell ya what has to be done next. You just have to be willing to listen to her. I love the process and most importantly I really love my new found friends and getting to see them each year at Brodhead. I can wait for July to get here. For me its Christmas, my birthday, the Holy Grail and Mecca all rolled up into one spectacular event of friendship, airplanes, stories, jokes and good old fashion telling lies, oh yeah (warning, watch out for Markle)! Hope to see ya there. John In a message dated 3/27/2010 3:43:10 P.M. Eastern Daylight Time, gboothe5(at)comcast.net writes: --> Pietenpol-List message posted by: "Gary Boothe" Gary, Welcome!! I'm always happy to meet someone who's name I can remember... Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of gtche98 Sent: Saturday, March 27, 2010 10:35 AM Subject: Pietenpol-List: New Member Lurking on the Lists Good Morning All - Just wanted to take a minute and introduce myself, as I will be spending time reading this list. My name is Gary Wilson and as of now, I have not built an airplane, but helped my father build a Questair Venture. It took him 20 years, but it turned out to be a beautiful bird (see pic). Now with a family of my own, we are just about ready to start our own "family" plane. While walking through the affordable flying hangar at Oshkosh in 2008, I saw my first Piet, and have been fascinated ever since. We have now settled on the Air Camper as our family plane, and plan to start construction in the fall. Here is my plan of action so far to get us to the August time frame. 1 - Join local EAA chapter and start attending regular meetings to develop a network of local builders. 2 - Attend Brodhead - Take as many notes and pictures as I can! 3 - Oshkosh - spend time in the woodworking tent and study engine options (especially William Wynne's Corvair option). 4 - Order Plans As a first timer just getting started, I would certainly welcome any advice you might provide as I get started. Also, if anyone is building or has a Pietenpol in the Greenville (Appleton) Wisconsin area, I would love to hear from you. I look forward to learning a lot from each of you! Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=291947#291947 Attachments: http://forums.matronics.com//files/venture_856.jpg ________________________________________________________________________________
Date: Mar 27, 2010
Totally agree, you will get 10 times more out of your Broadhead experience (and encounters with any other homebuilders) if you had the plans and had spent time coming up with a list of questions. And especially if you start building something before Broadhead, even if its just building ribs, which is where most people start anyhow. rick > Gary, > > Welcome to the fold. If I may comment on your strategy I would suggest you > buy the plans and begin building ASAP so when you arrive at Brodhead you > have a bit of build experience to guide your picture taking, question asking > and research. Its much easier to ask great questions and get solid advice > when your approach is from the actual build and not the virtual or > conceptual aspects of the build. > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 28, 2010
Subject: Continental A-65 and Stromberg carb for sale
Good evening all, We have a Continental A-65 for sale if any might be interested. Here is the info on the engine: We purchased it from a couple in Florida last year; they had removed it from their Cub to install a larger engine. The engine has logs back to day one (6-11-46), with 1505TT, and 709SMOH (majored in '57). It was removed from the J-3 in 2002. It looks like part of the reason for it's low time is that the Cub it was attached to was damaged in a storm in '69, and didn't get rebuilt until '93. Other than that the logs are pretty uneventful. The engine is complete, except for the carb and magneto harnesses. Apparently they swapped those items out on to the replacement engine. Here is a pic: http://dl.dropbox.com/u/2314248/IMG_1200resize.jpg That's how it sits right now, in the shipping crate and ready to go. The mags are in the box in the image, they are Bendix mags, and I have no reason to doubt that they work; they worked fine when the engine was removed from the airplane. We are asking $3,000 for it, which is exactly the amount we paid for it. As I mentioned, it does not come with a carb. We do also have a carb for sale, either with the engine or separately. It's a Stromberg NA-S3A1, that has been overhauled and yellow-tagged by Russ Romey at D&G Supply in Niles, MI. Corvair enthusiasts may recognize that shop as the go-to place for Corvair conversion carb overhauls, and that is why we sent it there. It is currently set up for a Corvair, which means equivalent to a C-85. I talked with Russ about changing it over to A-65 configuration, and he said it would cost about $100. I think it's mainly a venturi change, is all. The carburetor is available for $600. We paid $200 for the core, and $475 to have it overhauled, as it was missing the throttle arm and main needle. If you might be interested in either please email me and we can discuss further. Have a good evening! Ryan ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: welcome Gary
Date: Mar 28, 2010
Welcome Gary! Honestly, you couldn't have found a more helpful and encouraging group, nor a more wonderful plane... #1 advice... go to Brodhead #2 advice... build to the plans (except for minor stuff) #3 advice... use spruce, dont use a heavier wood, or think you have to beef up the design, it's been flying for 80 yrs. #4 advice... build to the plans.. #5 advice... build light #6 advice... build to the plans.... #7 advice... have fun and involve your family (if applicable) #8 advice... build to the plans..... Douwe ________________________________________________________________________________
Subject: Weight and balance- Douwe's Piet
Date: Mar 28, 2010
Hi Douwe, Please tell us your empty weight, and EW CG location. Did you move your en gine forward of plans? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Sun, Mar 28, 2010 5:51 am Subject: Pietenpol-List: welcome Gary hlink.net> Welcome Gary! Honestly, you couldn't have found a more helpful and encouraging group, no r more wonderful plane... #1 advice... go to Brodhead 2 advice... build to the plans (except for minor stuff) 3 advice... use spruce, dont use a heavier wood, or think you have to beef p the design, it's been flying for 80 yrs. 4 advice... build to the plans.. 5 advice... build light 6 advice... build to the plans.... 7 advice... have fun and involve your family (if applicable) 8 advice... build to the plans..... ouwe ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Subject: Re: Continental A-65 and Stromberg carb for sale
Date: Mar 28, 2010
Ryan, sounds like a great buy! I spent $6,000 rebuilding mine. Do you mind if I post this on the flybaby site? Gene ----- Original Message ----- From: Ryan Mueller To: Pietenpol List Sent: Sunday, March 28, 2010 12:36 AM Subject: Pietenpol-List: Continental A-65 and Stromberg carb for sale Good evening all, We have a Continental A-65 for sale if any might be interested. Here is the info on the engine: We purchased it from a couple in Florida last year; they had removed it from their Cub to install a larger engine. The engine has logs back to day one (6-11-46), with 1505TT, and 709SMOH (majored in '57). It was removed from the J-3 in 2002. It looks like part of the reason for it's low time is that the Cub it was attached to was damaged in a storm in '69, and didn't get rebuilt until '93. Other than that the logs are pretty uneventful. The engine is complete, except for the carb and magneto harnesses. Apparently they swapped those items out on to the replacement engine. Here is a pic: http://dl.dropbox.com/u/2314248/IMG_1200resize.jpg That's how it sits right now, in the shipping crate and ready to go. The mags are in the box in the image, they are Bendix mags, and I have no reason to doubt that they work; they worked fine when the engine was removed from the airplane. We are asking $3,000 for it, which is exactly the amount we paid for it. As I mentioned, it does not come with a carb. We do also have a carb for sale, either with the engine or separately. It's a Stromberg NA-S3A1, that has been overhauled and yellow-tagged by Russ Romey at D&G Supply in Niles, MI. Corvair enthusiasts may recognize that shop as the go-to place for Corvair conversion carb overhauls, and that is why we sent it there. It is currently set up for a Corvair, which means equivalent to a C-85. I talked with Russ about changing it over to A-65 configuration, and he said it would cost about $100. I think it's mainly a venturi change, is all. The carburetor is available for $600. We paid $200 for the core, and $475 to have it overhauled, as it was missing the throttle arm and main needle. If you might be interested in either please email me and we can discuss further. Have a good evening! Ryan ------------------------------------------------------------------------- ----- Checked by AVG - www.avg.com 03/27/10 19:32:00 ________________________________________________________________________________
Date: Mar 28, 2010
Gary: where are you located? It helps you get more help if you have other builders/pilots nearby, so if you'll indicate where you're located, nearby builders might respond. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Cloudcars prop on N502R
Date: Mar 28, 2010
Jerry, sorry it took me so long to get back with you. He will "skin" the prop with glass if you wish. Gene ----- Original Message ----- From: "Jerry Dotson" <jdotson(at)erec.net> Sent: Tuesday, March 23, 2010 9:38 PM Subject: Pietenpol-List: Re: Cloudcars prop on N502R > > Gene what did he put on the leading edge for protection? I can't ell in > the photo. Just wondering. Boy that thing is purty. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > Ribs and tailfeathers done > using Lycoming O-235 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=291515#291515 > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 19:33:00 ________________________________________________________________________________
Date: Mar 28, 2010
Subject: William Wynne Corvair conversion parts for sale
Hello all, We have unfortunately decided to put our Corvair conversion parts up for sale. We just cannot get out to our shop enough to make any meaningful progress on our Pietenpol...at the rate we are going it will be years and years before we would ever finish. We're putting our build on hiatus, until we are living in a space more conducive to being able to work on the project every day. However we still want to have a Piet to fly until such time as we can build our own, and we do have space to hangar an airplane, so we are going to look to purchase a complete, flying Piet. Being able to "liquidate the asset" that is our Corvair conversion will get us a large chunk of the money needed to purchase a flying Pietenpol. We are asking $6,000 for everything. So, here is a list of what we have: Crankcase: hot-tanked clean at an aircraft engine repair station, inspected by WW and deemed serviceable. 9 out of 12 upper head studs removed due to corrosion. One threaded hole for an upper stud was damaged during removal. This hole was time-serted and a serviceable used stud was installed by Mark at Falcon. The threads in the remaining holes look good. I have at least 12 serviceable used upper head studs that were removed from junk cases using less than the maximum torque recommended by WW to avoid twisting the stud (45 ft/lbs, I think?). Crankshaft: magnafluxed and ground .10/.10, shot peened, balanced, polished, and tapped for safety shaft by Quinlin Automotive in Indianapolis. Ion-nitrided at Advanced Nitriding Solutions, with a batch Larry Hudson took in. Cylinder heads: overhauled by Mark at Falcon Machine, with the welded intake tubes. (if you saw Mark's setup at Oshkosh last year you saw one of the heads: it was his display head) 5th Bearing: Weseman BTA 5th bearing Camshaft: new OT-10 with standard gear, new lifters Cylinders, pistons & rods: +.30 cylinders from Clark's, forged pistons (balanced to 1 gram spread) installed on Clark's reconditioned and balanced (1 gram spread) connecting rods Oil Pump: Pro-Flow high volume pump from Clark's All other overhaul parts needed from Clark's (gaskets, bearings, seals, etc) All other engine parts have been cleaned and inspected (pushrods, rocker arms, rear accessory cover, etc) Harmonic Balancer: Rebuilt by Dale Mfg John Deere dynamo WW Parts: Stainless Intake Manifold setup for Stromberg/Marvel carbs Gold Prop Hub - Modified by the Wesemans for use with their 5th bearing Gold Oil Filter Housing Gold Oil Cooler Sandwich Adapter Assy Niagara Oil Cooler Alternator Brackets Ring Gear Top Cover Starter Brackets Safety Shaft Hybrid Studs Gold CNC Billet Oil Pan Oil Pan Installation kit w/ rebent pickup E/P distributor Starter w/ fine tooth gear installed The only thing we have ordered that we do not have yet are the E/P Distributor, and the starter with the fine-tooth gear installed. William Wynne just emailed this morning and noted that those two items have been shipped, so we should have them shortly. This is everything you need to build a top-notch Corvair aircraft engine, and no waiting for parts. In case you do now know, there is a significant lead time for many of these parts. The cylinder heads took 1 year, and some of the WW parts are more than a year. Again, we are asking $6,000 for the lot. William Wynne and Dan Weseman had the following to say on the Corvaircraft list this morning: ----------------------------- Friends, I know Ryan pretty well and have seen his stuff first person, up close. I consider his engine project first class, and a very good deal. The two parts that he had on order with us have been shipped, so everything will be on hand for the buyer. I am not happy to see Ryan's urban residence vs distant workshop situation get him out of building now, but I have a strong feeling we will have in the Corvair movement in the long term. I will gladly support the buyer of the project through the assembly process. If someone pays Ryan's asking price in a friendly and timely manner, I will consider making the engine the demo assembly at the next Corvair college in the buyers area. If someone wanted to pay a skilled person to assemble and test the engine there are a lot of options like Brady on the West coast or Mark from Falcon in the Midwest. In the interest of full disclosure, I never offer an opinion for money or favors, and my comments here are just in support of a friend, we never accept any commission on the resale or assistance of sale of Corvair parts. There are a lot of shady people out there offering to resell a "$3,500 Corvair engine for a friend" which is junk. Ryan is the polar opposite of this, and I just wanted to step in and say so. Thank you. William Wynne 5000-18 HWY 17 #247 Orange Park, FL 32003 ----- Hi guys I also wanted to add that anyone buying The Muellers parts , Which includes our 5thbearing , Will have full support from us for install and service questions etc . Sorry to see the Muellers leave for a while but.... i can never argue with the decision to go flying now vs later ! Ryan be sure to send us some photo's of your new Piet Thanks Dan Weseman --------------------------------- Please contact me if you are interested, either via email or on the phone. Thanks, Ryan Mueller rmueller23(at)gmail.com 815-298-1483 ________________________________________________________________________________
Date: Mar 28, 2010
Good Day Piet Posters, Here's a pretty obvious question for everyone. That is, obvious to everyone but me. Thinking about saving weight everywhere I can and contemplating using an electronic Tach. Small plastic housing, solid state, no tach cable, weighs 70 percent less than conventional, but with no electric system, where do I hook it up. On my car, I just connect one side to distributor and the other side to ground. Then tell the unit, with a switch built in or wiring method, that it is a 4, 6, or 8 cylinder. Question is would the hot side of a Magneto equate to the pos. side of the distributor? Then there's the Hobbs meter---same question, I could even supple it with a battery power, but does an electronic Hobbs read off the mag? 2nd subject for discussion--- I'm concerned about weight because I really want to use motorcycle wheels. To me that is the ultimate antique look. I have 2 - 19 inch wheels with built in brake hubs. They weigh 17 pounds apiece without tire. So I'll be looking for weight savers everywhere. While building to plans of course. This is a GN-1 with A-65 and wood prop ( thanks OZ) so right there I'm 85 pounds less than with model A. By the way, can anyone out there build an aluminum tank? Jeff Wilson GN-1 St. Louis, MO ________________________________________________________________________________
Date: Mar 28, 2010
Subject: Tach Question
Good Day Piet Posters, Here's a pretty obvious question for everyone. That is, obvious to everyone but me. Thinking about saving weight everywhere I can and contemplating using an electronic Tach. Small plastic housing, solid state, no tach cable, weighs 70 percent less than conventional, but with no electric system, where do I hook it up. On my car, I just connect one side to distributor and the other side to ground. Then tell the unit, with a switch built in or wiring method, that it is a 4, 6, or 8 cylinder. Question is would the hot side of a Magneto equate to the pos. side of the distributor? Then there's the Hobbs meter---same question, I could even supple it with a battery power, but does an electronic Hobbs read off the mag? 2nd subject for discussion--- I'm concerned about weight because I really want to use motorcycle wheels. To me that is the ultimate antique look. I have 2 - 19 inch wheels with built in brake hubs. They weigh 17 pounds apiece without tire. So I'll be looking for weight savers everywhere. While building to plans of course. This is a GN-1 with A-65 and wood prop ( thanks OZ) so right there I'm 85 pounds less than with model A. By the way, can anyone out there build an aluminum tank? Jeff Wilson GN-1 St. Louis, MO PS- re-sent 'cause I left out the subject line earlier and if you are like me and hate viruses you won't open an email without a subject line. I call it "tech paranoia". ________________________________________________________________________________
Subject: Re: Tach Question
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Mar 28, 2010
an obvious simple light and cheap one is the Tinytach , it simply has a single wire lead that wraps around one plug wire.an internal battery that lasts several years and it turns itself off after shutdown. I have used 2 on 2 different Rotaxes in a Rans and a Challenger I fly now. the bad news is I have heard they don't work well on a engine like the Corvair. I'd sure be trying one out on mine, but the plane has an electronic instrument panel already. EIS I believe.hopefully before the end of the year I'll get a chance to fly it. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292123#292123 ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Mar 28, 2010
If I recall correctly, PF Beck was using a Tinytach wit his Corvair several years ago with no problems from what he told me then. Don't know if that's still his setup or not. Kip Gardner On Mar 28, 2010, at 4:56 PM, skellytown flyer wrote: > > > an obvious simple light and cheap one is the Tinytach , it simply > has a single wire lead that wraps around one plug wire.an internal > battery that lasts several years and it turns itself off after > shutdown. I have used 2 on 2 different Rotaxes in a Rans and a > Challenger I fly now. the bad news is I have heard they don't work > well on a engine like the Corvair. I'd sure be trying one out on > mine, but the plane has an electronic instrument panel already. > EIS I believe.hopefully before the end of the year I'll get a > chance to fly it. Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292123#292123 > > ________________________________________________________________________________
Date: Mar 28, 2010
Thanks Gene. I hope it will be Ok. I will be operating 99% of the time off grass. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292164#292164 ________________________________________________________________________________
Date: Mar 28, 2010
Gary, Welcome. You will find this to be a great list and a tremendous resource. I agree with Rick's and John's posts above. Get the plans and some material and get into the process as soon as you can. You already know that a home-built aircraft can take 20 years. If you have your time and some resources invested it will be incentive to keep plugging along. I have wanted to build since 1968 and put it off until I purchased someones project 4 years ago. If I had started when I first had the dream I would have been done twice. I always thought I could not afford it but it is a lot easier to put out a little money at a time over a longer period of time. I will also emphasize the importance of EAA. I belonged to the national organization for years but not a local until 6 years ago. Your local guys and gals will be tremendous encouragement. I would also add that if you do not have your license, try to carve out the resources to do that. Sport pilot may be a good way to go if you can find a school in your area. Flying different kinds of airplanes also may be informative as to what kind of flying you will want to do. I was fortunate and had my private license before I even knew EAA existed. Being able to get into the air kept my dream alive. Originally I thought building would be an inexpensive way to own an airplane. Now I realize that building is for the sake of building and flying what you have built. In all of these years of dreaming I owned 5 factory built airplanes which allowed me to perfect my skills and get a lot of experience, but flying my GN-1 when it is finished, I expect will rank right up there as one of my favorite accomplishments. Good Luck and good building. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292166#292166 ________________________________________________________________________________
Date: Mar 28, 2010
Welcome to the List, Gary. You begin by stating that you have not built an airplane before - well, that immediately gives you something in common with a lot of us (maybe most of us). It seems that most Pietenpol builders are first time builders. The construction is fairly basic - just like building a BIG model airplane, except you won't need to use giant Tee-pins. The Questair Venture is most definitely a unique aircraft, and surely more complex than a Pietenpol. Both are sure to gather a crowd at a fly-in. Like the others have said, move "order the plans" up to the top of your list of things to do. Once you get them, and study them a bit, you'll come up with a bunch of questions. When you do come up with the questions, check out the Matronics Pietenpol List Archives. There is a very useful search function that will most likely result in answers to your questions. If you can't find answers there, then post your question here, and somebody will most likely know exactly what you're asking about. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292169#292169 ________________________________________________________________________________
Date: Mar 28, 2010
David, That seems like a strange response to Gary's question. This IS the Pietenpol List - which means it is about building and flying a two-seat, open cockpit, antiquey plane that, under certain circumstances can reach speeds approaching that of an average car. I don't think anyone builds a Pietenpol expecting it to transport a whole family (plus friends) in enclosed, heated comfort, in half the time that a car takes. What it CAN do is transport the pilot (and one lucky passenger at a time) back in time, to a simpler age, when getting there in a hurry wasn't so important -back to the days when flying was more appreciated for the wonder that it really is. Flying in a Pietenpol (or any similar open cockpit airplane, for that matter) is an entirely different experience than flying in any enclosed "Spam can". In my opinion, if you're only going to have one airplane (which, by the way, is one more than most people), get (or even better, build) one that will give you a thrill every time you fly it, rather than be a practical mode of transportation from A to B. If you're looking for a mode of transportation, there are plenty of airlines that can provide that service much more economically than owning your own plane. I don't know of any airline that can provide the experience that a Pietenpol ride can. Bill C. dpaule(at)frii.com PostPosted: Sat Mar 27, 2010 11:10 am Post subject: New Member Lurking on the Lists If you're only going to have one airplane, get one with more seats than your family, so you can take friends along as well as family. Make sure that it has a closed cockpit and a heater, so that you can actually use it in a practical manner. It should have a cruise speed of at least twice the speed of a car, point to point, or else it won't get used for traveling. The "at least" is pretty important, by the way. David Paule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292172#292172 ________________________________________________________________________________
Subject: Charm of the Piet
Date: Mar 29, 2010
Bill, I didn't think an egg-headed engineer like yourself could have written so eloquently. Do you have a ghost writer? What it CAN do is transport the pilot (and one lucky passenger at a time) back in time, to a simpler age, when getting there in a hurry wasn't so importa nt -back to the days when flying was more appreciated for the wonder that it really is. Flying in a Pietenpol (or any similar open cockpit airplane, for that matter) is an entirely different experience than flying in any enclosed "S pam can". Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Re: Charm of the Piet
Date: Mar 29, 2010
Dan, Thanks... I think. "Egg-headed" ??? How eloquent. Would you LIKE to have a ghost writer? Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292185#292185 ________________________________________________________________________________
Date: Mar 29, 2010
Thanks to all for your warm welcome and thoughtful advice. I very much appreciate it, and look forward to getting to know each of you in the upcoming days, months, years. To those that have recommended getting the plans first, I will certainly take that into consideration. I am considering this a long term project, and live only minutes from Oshkosh and hours from Brodhead, so neither of these will be significant excursions for me (thankfully), and I anticipate being at both every year for the foreseeable future. Having said that, you all have me wanting to dive into the plans right now, so we may have to move that one up the list. Oscar - As mentioned at the end of my original post ( [Wink] ), I am in Greenville, WI. I have already received a private email from a Piet builder in Greenville, which was the holy grail email I was looking for...I will be making arrangements to meet up with this individual in the near future. I would love to know if there are any others in this area. Also, my understanding is that Doc Mosher is a member of the Oshkosh EAA chapter, so that is probably where I will secure my local chapter membership. David and Bill - Thank you both for your insights. I had to chuckle just a little bit when David used the word "practical" to refer to an airplane. [Laughing] Unfortunately, in order to follow David's advice (which I would love to do), I would be in the market for a Saratoga, and the budget definately does not support that. No, the Air Camper will be a family airplane in that the entire family will build it and (hopefully) develop a love for low and slow flying, one family member at a time. Thanks again for welcoming me into the fold! Gary Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292189#292189 ________________________________________________________________________________
Date: Mar 29, 2010
As I recall, he used the phrase "family airplane." David Paule > > > That seems like a strange response to Gary's question. > This IS the Pietenpol List - which means it is about building and flying a > two-seat, open cockpit, antiquey plane that, under certain circumstances > can reach speeds approaching that of an average car. > I don't think anyone builds a Pietenpol expecting it to transport a whole > family (plus friends) in enclosed, heated comfort, in half the time that a > car takes..... ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Mar 29, 2010
Gary, Welcome to the list. A great source of photos already exists of Pietenpols that Chris Tracy has so kindly posted for us all and you don't have to even step foot outside your house to hundreds and hundreds of great photos of all kinds of different Piets and Piet building ideas for you. http://www.westcoastpiet.com/ To order plans, the Pietenpol family web site is here: http://www.pressenter.com/~apietenp/ Lastly, save yourself tons of time and money by having the Sportplane Builder series of books by Tony Bingelis at your side during building. These books were instrumental in helping answer a zillion of my questions without ever having to post, ask, or wander around wondering what my options were or how I should go about a certain part of the building process. Don't rely on old wives tales or heresay---go to these books. You'll get the straight poop without any BS and there are great sketches, diagrams, and a complete index to guide you to your answers. There are FOUR books in this series and I highly recommend getting the whole enchilada right up front. Merry Christmas. http://www.aircraftspruce.com/menus/bv/books_bingelis.html If you're not a pilot Gary or don't have any tailwheel time I would visit Steve Krog at Hartford, WI and take an hour of dual in one of his J-3 Cubs to see if you even like low and slow old fashioned flying. Just a thought, your mileage may vary. http://www.sportpilot.org/learntofly/articles/070917_learning.html Finally, don't listen to anything that Jim Markle, myself, or Jack Phillips posts. Mike C. NX48MC ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Mar 29, 2010
Gary: I would buy these 2 publications from the EAA, the 1932 and 1933 Flying and Glider Manuals. These are the Pietenpol publications from the early '30s. They included the plans plus construction notes. For only $6.95 each, its well worth the price. Some have actually built from these publications alone, though if you purchase the plans, you will not only have more detail, but also all of the plan updates. Here is a link http://www.shopeaa.com/search.aspx?find=pietenpol Rick Schreiber Valparaiso, IN > [Original Message] > From: gtche98 <garywilson213(at)yahoo.com> > To: > Date: 3/29/2010 8:32:19 AM > Subject: Pietenpol-List: Re: New Member Lurking on the Lists > > > Thanks to all for your warm welcome and thoughtful advice. I very much appreciate it, and look forward to getting to know each of you in the upcoming days, months, years. > > To those that have recommended getting the plans first, I will certainly take that into consideration. I am considering this a long term project, and live only minutes from Oshkosh and hours from Brodhead, so neither of these will be significant excursions for me (thankfully), and I anticipate being at both every year for the foreseeable future. Having said that, you all have me wanting to dive into the plans right now, so we may have to move that one up the list. > > Oscar - As mentioned at the end of my original post ( [Wink] ), I am in Greenville, WI. I have already received a private email from a Piet builder in Greenville, which was the holy grail email I was looking for...I will be making arrangements to meet up with this individual in the near future. I would love to know if there are any others in this area. Also, my understanding is that Doc Mosher is a member of the Oshkosh EAA chapter, so that is probably where I will secure my local chapter membership. > > David and Bill - Thank you both for your insights. I had to chuckle just a little bit when David used the word "practical" to refer to an airplane. [Laughing] Unfortunately, in order to follow David's advice (which I would love to do), I would be in the market for a Saratoga, and the budget definately does not support that. No, the Air Camper will be a family airplane in that the entire family will build it and (hopefully) develop a love for low and slow flying, one family member at a time. > > Thanks again for welcoming me into the fold! > > Gary > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292189#292189 > > ________________________________________________________________________________
Date: Mar 29, 2010
Gary, At the very least, if you don't feel like laying out $250 for the full set of plans, buy the 1932 Flying and Glider Manual with the original Pietenpol plans from the EAA: http://www.shopeaa.com/1932flyingandglidermanual.aspx It'll be the best $6.95 + S&H you'll ever spend. Heck, sounds like you could save the S&H and drive over and pick it up yourself. The other thing I suggest you do is check out Chris Tracy's excellent Pietenpol web site, http://www.westcoastpiet.com. There are ton of great photos of Piet details as well has hand drawn sketches of how different builders came up different solutions to the same problems. Good stuff. Cheers, Dan On 03/29/2010 08:30 AM, gtche98 wrote: > --> Pietenpol-List message posted by: "gtche98" > > Thanks to all for your warm welcome and thoughtful advice. I very much appreciate it, and look forward to getting to know each of you in the upcoming days, months, years. > > To those that have recommended getting the plans first, I will certainly take that into consideration. I am considering this a long term project, and live only minutes from Oshkosh and hours from Brodhead, so neither of these will be significant excursions for me (thankfully), and I anticipate being at both every year for the foreseeable future. Having said that, you all have me wanting to dive into the plans right now, so we may have to move that one up the list. > > Oscar - As mentioned at the end of my original post ( [Wink] ), I am in Greenville, WI. I have already received a private email from a Piet builder in Greenville, which was the holy grail email I was looking for...I will be making arrangements to meet up with this individual in the near future. I would love to know if there are any others in this area. Also, my understanding is that Doc Mosher is a member of the Oshkosh EAA chapter, so that is probably where I will secure my local chapter membership. > > David and Bill - Thank you both for your insights. I had to chuckle just a little bit when David used the word "practical" to refer to an airplane. [Laughing] Unfortunately, in order to follow David's advice (which I would love to do), I would be in the market for a Saratoga, and the budget definately does not support that. No, the Air Camper will be a family airplane in that the entire family will build it and (hopefully) develop a love for low and slow flying, one family member at a time. > > Thanks again for welcoming me into the fold! > > Gary > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292189#292189 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 29, 2010
Yup - Already have the 32 F&G Manual, and have read BPs article about 30 times! Someone earlier in the thread had mentioned Chris's website and I am working my way through it now. It will take quite some time as he has built up an impressive vault of information. Thanks for the information! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292215#292215 ________________________________________________________________________________
Date: Mar 29, 2010
Well, yeah, he did. But he also just finished saying that he had helped his Dad build a two-seater airplane (over a twenty year period). That's what I assumed was meant by "family" plane - that it was a family project. Different interpretations of the same words, I guess. Anyway, I think that holding out for a six-seater, 200mph airplane would mean NEVER having an airplane, for the vast majority of us. Bill C. Posted: Mon Mar 29, 2010 6:49 am Post subject: New Member Lurking on the Lists As I recall, he used the phrase "family airplane." David Paule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292220#292220 ________________________________________________________________________________
Date: Mar 29, 2010
And as if you didn't already have enough recommended reading material Gary, don't forget the book "The Peitenpol Story" by Chet Peak (who is building a Pietenpol and attends Brodhead sometimes). All the rest of his book are great too. http://www.threepeakspub.com/ rick On Mon, Mar 29, 2010 at 7:30 AM, gtche98 wrote: > > Thanks to all for your warm welcome and thoughtful advice. I very much appreciate it, and look forward to getting to know each of you in the upcoming days, months, years. > > To those that have recommended getting the plans first, I will certainly take that into consideration. I am considering this a long term project, and live only minutes from Oshkosh and hours from Brodhead, so neither of these will be significant excursions for me (thankfully), and I anticipate being at both every year for the foreseeable future. Having said that, you all have me wanting to dive into the plans right now, so we may have to move that one up the list. > > Oscar - As mentioned at the end of my original post ( [Wink] ), I am in Greenville, WI. I have already received a private email from a Piet builder in Greenville, which was the holy grail email I was looking for...I will be making arrangements to meet up with this individual in the near future. I would love to know if there are any others in this area. Also, my understanding is that Doc Mosher is a member of the Oshkosh EAA chapter, so that is probably where I will secure my local chapter membership. > > David and Bill - Thank you both for your insights. I had to chuckle just a little bit when David used the word "practical" to refer to an airplane. [Laughing] Unfortunately, in order to follow David's advice (which I would love to do), I would be in the market for a Saratoga, and the budget definately does not support that. No, the Air Camper will be a family airplane in that the entire family will build it and (hopefully) develop a love for low and slow flying, one family member at a time. > > Thanks again for welcoming me into the fold! > > Gary > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292189#292189 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 29, 2010
Actually the Piet qualifies quite well, during 1929 and 30 the auto didn't travel much faster than 40 mph, young family, wife if she could stand the ride, the first child or family dog. It all seems to fit quite well. Its an airplane not a jet, but they didn't have Jets back in those days and if you dressed properly as if you were riding in your open top car it was pretty much the same environment. Except for the road dirt and dust in your face. Here in Lancaster County Pa the roads contain more than dust and dirt, our Amish community family and work transportation sees to that aspect. John In a message dated 3/29/2010 11:24:51 A.M. Eastern Daylight Time, billspiet(at)sympatico.ca writes: --> Pietenpol-List message posted by: "Bill Church" Well, yeah, he did. But he also just finished saying that he had helped his Dad build a two-seater airplane (over a twenty year period). That's what I assumed was meant by "family" plane - that it was a family project. Different interpretations of the same words, I guess. Anyway, I think that holding out for a six-seater, 200mph airplane would mean NEVER having an airplane, for the vast majority of us. Bill C. Posted: Mon Mar 29, 2010 6:49 am Post subject: New Member Lurking on the Lists As I recall, he used the phrase "family airplane." David Paule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292220#292220 ________________________________________________________________________________
Date: Mar 29, 2010
Subject: Re: welcome Gary
On 03/29/2010 09:31 AM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > There are FOUR books in this series and I highly recommend getting the whole enchilada right up front. Merry Christmas. > > http://www.aircraftspruce.com/menus/bv/books_bingelis.html I'd add one more to that list, too. The "Wood Aircraft Building Techniques" book: http://www.shopeaa.com/woodaircraftbuildingtechniques.aspx Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 29, 2010
That's probably why Cessna sold so many 172s. It's about twice as fast as a car, holds a family of four with a little baggage, and has a heater and is out of the wind. A Piper Tri-Pacer will do about the same thing. Your choice of either for around $25,000, and there's financing available. But a Pietenpol makes a great family project... just not a practical family airplane. Try to imagine how a family with two children would go to an airport 40 miles away for breakfast with one. David Paule > > Anyway, I think that holding out for a six-seater, 200mph airplane would > mean NEVER having an airplane, for the vast majority of us. > ________________________________________________________________________________
Date: Mar 29, 2010
And the Pietenpol design has been known to rescue a family (a wife and two small children on one trip then the pilot went back for the father) from where they were stranded during a snow storm once long ago... So maybe that qualified as two adults and two children.... -----Original Message----- From: AMsafetyC(at)aol.com Sent: Mar 29, 2010 10:41 AM Subject: Re: Pietenpol-List: Re: New Member Lurking on the Lists Actually the Piet qualifies quite well, during 1929 and 30 the auto didn't travel much faster than 40 mph, young family, wife if she could stand the ride, the first child or family dog. It all seems to fit quite well. Its an airplane not a jet, but they didn't have Jets back in those days and if you dressed properly as if you were riding in your open top car it was pretty much the same environment. Except for the road dirt and dust in your face. Here in Lancaster County Pa the roads contain more than dust and dirt, our Amish community family and work transportation sees to that aspect. John In a message dated 3/29/2010 11:24:51 A.M. Eastern Daylight Time, billspiet(at)sympatico.ca writes: --> Pietenpol-List message posted by: "Bill Church" Well, yeah, he did. But he also just finished saying that he had helped his Dad build a two-seater airplane (over a twenty year period). That's what I assumed was meant by "family" plane - that it was a family project. Different interpretations of the same words, I guess. Anyway, I think that holding out for a six-seater, 200mph airplane would mean NEVER having an airplane, for the vast majority of us. Bill C. Posted: Mon Mar 29, 2010 6:49 am Post subject: New Member Lurking on the Lists As I recall, he used the phrase "family airplane." David Paule Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292220#292220============================================== Use the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ================================================== ________________________________________________________________________________
Date: Mar 29, 2010
Subject: new pipes for N8031!
So, the only credit I can take for these is the fact that I could take the old pipes off, send them to the exhaust welder in Fla. (http://www.flyoldplanes.com), and put the shiny new stainless ones on, again. But, dang! it feels good to be able to do some of the work myself on *my* plane. They look really cool, too. Now if the winds would settle down this week, I'd go flying... Cheers, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 29, 2010
Subject: Re: new pipes for N8031!
Those look great! Two questions: How does the carb heat get heat off those stack? How much did they cost? >So, the only credit I can take for these is the fact that I could >take the old pipes off, send them to the exhaust welder in Fla. >(http://www.flyoldplanes.com), and put the shiny new stainless ones >on, again. > >But, dang! it feels good to be able to do some of the work myself on >*my* plane. > >They look really cool, too. > >Now if the winds would settle down this week, I'd go flying... > >Cheers, >Dan > >-- >Dan Yocum >Fermilab 630.840.6509 >yocum@fnal.gov, http://fermigrid.fnal.gov >"I fly because it releases my mind from the tyranny of petty things." -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 29, 2010
Dan, nice looking pipes. I wouldn't advertise them though. Oh BTW I understand Markle is going to be in the Chicago area soon, I am certain he's gonna love them. A lot! John In a message dated 3/29/2010 4:35:03 P.M. Eastern Daylight Time, yocum(at)fnal.gov writes: So, the only credit I can take for these is the fact that I could take the old pipes off, send them to the exhaust welder in Fla. (http://www.flyoldplanes.com), and put the shiny new stainless ones on, again. But, dang! it feels good to be able to do some of the work myself on *my* plane. They look really cool, too. Now if the winds would settle down this week, I'd go flying... Cheers, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Mar 29, 2010
I took the photos w/o the carb muff attached. You can see the scat hose on the right hand side behind the pipe - that's where the old muff will go, again. Cost was about $100 less then an official FAA Repair Shop (I got a quote from Dawley Aviation in Burlington). Oh, I should note, these are not yellow tagged pipes. I did ask Sonny, the owner/welder, if he did "the right thing" to shield the backs of the welds with argon and he verified that he did. Lucky for me, I know Markle doesn't need A65 pipes, using that old Ford that he is. Whew! Now, the impending addition of that other Piet at my airport... those guys, I'll have to worry about! ;-) Cheers, Dan On 03/29/2010 03:42 PM, Jeff Boatright wrote: > > Those look great! Two questions: How does the carb heat get heat off > those stack? How much did they cost? > > >> So, the only credit I can take for these is the fact that I could take >> the old pipes off, send them to the exhaust welder in Fla. >> (http://www.flyoldplanes.com), and put the shiny new stainless ones >> on, again. >> >> But, dang! it feels good to be able to do some of the work myself on >> *my* plane. >> >> They look really cool, too. >> >> Now if the winds would settle down this week, I'd go flying... >> >> Cheers, >> Dan >> >> -- >> Dan Yocum >> Fermilab 630.840.6509 >> yocum@fnal.gov, http://fermigrid.fnal.gov >> "I fly because it releases my mind from the tyranny of petty things." > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: New Member Lurking on the Lists
Date: Mar 29, 2010
I can imagine a family with two children going an airport 40 miles away for breakfast would look something like this. http://westcoastpiet.com/images/Frank%20Pavliga/pav.jpg Look closely, and count the people. Chris Sacramento,Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of David Paule Sent: Monday, March 29, 2010 9:49 AM Subject: Re: Pietenpol-List: Re: New Member Lurking on the Lists That's probably why Cessna sold so many 172s. It's about twice as fast as a car, holds a family of four with a little baggage, and has a heater and is out of the wind. A Piper Tri-Pacer will do about the same thing. Your choice of either for around $25,000, and there's financing available. But a Pietenpol makes a great family project... just not a practical family airplane. Try to imagine how a family with two children would go to an airport 40 miles away for breakfast with one. David Paule > > Anyway, I think that holding out for a six-seater, 200mph airplane > would mean NEVER having an airplane, for the vast majority of us. > ________________________________________________________________________________
Date: Mar 30, 2010
Subject: Re: William Wynne Corvair conversion parts for sale
Just wanted to update: our Corvair package has been sold to a good home! Thank you to those that inquired. If you still need an engine for your project, do not despair! We still have our Continental A-65 available, with only 1505TT and 709SMOH and complete logs. In the shipping crate, ready to head to your hangar or shop. The first $3,000 snaps it up! :) Have a good day, Ryan On Sun, Mar 28, 2010 at 12:16 PM, Ryan Mueller wrote: > Hello all, > > We have unfortunately decided to put our Corvair conversion parts up for > sale. ________________________________________________________________________________
Date: Mar 30, 2010
Wow! An A65 with only 1505 Total Time? That's pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Tuesday, March 30, 2010 12:16 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Just wanted to update: our Corvair package has been sold to a good home! Thank you to those that inquired. If you still need an engine for your project, do not despair! We still have our Continental A-65 available, with only 1505TT and 709SMOH and complete logs. In the shipping crate, ready to head to your hangar or shop. The first $3,000 snaps it up! :) Have a good day, Ryan On Sun, Mar 28, 2010 at 12:16 PM, Ryan Mueller wrote: Hello all, We have unfortunately decided to put our Corvair conversion parts up for sale. ________________________________________________________________________________
Date: Mar 30, 2010
Tell ya what, If I didnt have an engine with more than that already in it I would be allover that. I passed the $3,000 mark quite a while ago and still counting. Sounds like a great deal John In a message dated 3/30/2010 12:16:47 P.M. Eastern Daylight Time, rmueller23(at)gmail.com writes: Just wanted to update: our Corvair package has been sold to a good home! Thank you to those that inquired. If you still need an engine for your project, do not despair! We still have our Continental A-65 available, with only 1505TT and 709SMOH and complete logs. In the shipping crate, ready to head to your hangar or shop. The first $3,000 snaps it up! :) Have a good day, Ryan On Sun, Mar 28, 2010 at 12:16 PM, Ryan Mueller <_rmueller23(at)gmail.com_ (mailto:rmueller23(at)gmail.com) > wrote: Hello all, We have unfortunately decided to put our Corvair conversion parts up for sale. (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Mar 30, 2010
Ryan, You're not getting rid of your piet are you? I saw your corvair for sale on barnstormers, but didn't put 2 and 2 togeather. Hope youre going to stick with the piet project. Shad ________________________________________________________________________________
Date: Mar 30, 2010
Alright gents. Let's not have any of that old "crank snappin' Corvair" smack again. I just wanted you to know that Ryan's misfortune is my great fortune and his 5th bearing equipped Corvair will be going on N328X in McPherson, KS. This, of course, means that I now have a Corvair project in a much earlier stage of development that I will be making available to persons of high quality and unassailable virtue at some point in the near future. I have kept the crankshaft carefully preserved in formaldehyde separately from the rest of the engine just so it won't snap of it's own accord some cold night in the shop. Tom Stinemetze So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Jack Phillips ________________________________________________________________________________
Date: Mar 30, 2010
From: Ben Williams <Ben.Williams(at)pdi.dreamworks.com>
Subject: project for sale
Pietfolk, I was making good progress until we adopted a little girl. No work has been done on it for four years, my enthusiasm to complete it is gone, and I bought a 1970 AA-1 Yankee. It's time to pass the project on. Here's a link to images... http://willgoh.typepad.com/pietenpol_project/ Corvair engine, Ash for 2+ projects, plywood, AN hardware (bolts, nuts, washers), one piece wing (ribs, spars with douglas fir, t-88) This project is in Daly City, Ca. (SF Bay Area). Not parting out, $500. Thanks, Ben Williams. ________________________________________________________________________________
Subject: Unbelievable Homebuilt Workmanship
Date: Mar 30, 2010
Not sure if this website has been mentioned here before, but there is a father and son team in Switzerland that is building a Hatz biplane that has out of this world workmanship and quality. They have a nice website (in English, no less) documenting the project, which they are almost six years into now, and looks like they are getting close to the covering stage. I know it's not a Piet, but the work is inspiring. Check it out. http://www.aeroplaneworks.ch/index2.html Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292372#292372 ________________________________________________________________________________
Date: Mar 30, 2010
We unfortunately are Shad, because we just cannot spend enough time at the shop to make any meaningful progress. At the rate we are going we will finish about the time we should retire. That is unacceptable. :P Once we have a place where we can build where we live (or very close by) we will start building a Piet again. We're not completely abandoning it, just putting the build on the back burner.; for the next few years at least it looks like flying is feasible, and building not so much, so we're going to fly! So we are selling the project, the 'Vair, the A-65....all of our stuff we have accumulated, and we are going to buy a flying Pietenpol instead. We have been talking with a gentleman that has a very nice Piet for sale....we are going to look at in two weeks, and if all goes well we hope to buy it by the 1st of July, and (crossing my fingers) hopefully have it at Brodhead. Selling the Corvair parts was the key.....selling the A-65 would make it far less stressful to put the money together by July 1, but it should be doable either way. Hopefully someone would like to give the A-65 a good home! :P Have a good day, Ryan On Tue, Mar 30, 2010 at 11:29 AM, shad bell wrote: > > Ryan, You're not getting rid of your piet are you? I saw your corvair for > sale on barnstormers, but didn't put 2 and 2 togeather. Hope youre going to > stick with the piet project. > Shad > > ________________________________________________________________________________
Date: Mar 30, 2010
Ben, Did you omit a ZERO? Jack DSM Pietfolk, I was making good progress until we adopted a little girl. No work has been done on it for four years, my enthusiasm to complete it is gone, and I bought a 1970 AA-1 Yankee. It's time to pass the project on. Here's a link to images... http://willgoh.typepad.com/pietenpol_project/ Corvair engine, Ash for 2+ projects, plywood, AN hardware (bolts, nuts, washers), one piece wing (ribs, spars with douglas fir, t-88) This project is in Daly City, Ca. (SF Bay Area). Not parting out, $500. Thanks, Ben Williams. ________________________________________________________________________________
Date: Mar 30, 2010
Subject: Firewall Fabrication
Builders,=0A=0AI will beginning my steel sheet firewall soon, and am intere sted in builders comments on firewall construction, specifically, if people use a flange as-a means of attaching the cowling. I have been planning o n bending a flange, and I also wonder if the flange is needed for any reaso n at the bottom edge where the cowl-droops down a little below the firewa ll.=0A=0ASo,-=0A1.-- Do people use the flange to attach the cowl alon g the rounded top edge?=0A2.---Is the flange needed at the bottom edg e, or do people roll the bottom edge completely over, or maybe bend a short flange backward on a 45 degree angle along the bottom, or omit the flange on the bottom?=0A3.-- What are good ways to attach the steel firewall s heet to the plywood firewall, and is fiberfrax recommended behind the steel sheet?=0A=0Aby the way, Tony Bingiles recomends using .018" sheet.=0A=0AAl so, I welded up a flanging tool out of a pair of vise grips to make those l ittle waves that are needed when you bend a flange around a curved shape. =0A=0Athanks all,=0A=0Ajohn egan=0Agreenville, wi=0A=0A=0A ________________________________________________________________________________
Subject: Re: Unbelievable Homebuilt Workmanship
Date: Mar 30, 2010
I had a chance to meet those guys when they were here at Poplar Grove. It was a fun time. You can see my hangar off the left wingtip, in the photo with the three guys. One disheartening thing they told me, is that this type of fun flying is so restrictive and expensive there, that even when they finish, they will only be able to afford to fly 15 or 30 hours (can't remember exactly). Th ere are landing and take-off fees for every operation. They also said that a place like Poplar Grove would be unheard of in Switzerland. The governm ent has a stranglehold on general aviation, all in the name of "safety". Dan Helsper Poplar Grove, IL NX929DH -----Original Message----- From: Bill Church <billspiet(at)sympatico.ca> Sent: Tue, Mar 30, 2010 11:59 am Subject: Pietenpol-List: Unbelievable Homebuilt Workmanship a> Not sure if this website has been mentioned here before, but there is a fa ther nd son team in Switzerland that is building a Hatz biplane that has out of this orld workmanship and quality. They have a nice website (in English, no les s) ocumenting the project, which they are almost six years into now, and look s ike they are getting close to the covering stage. know it's not a Piet, but the work is inspiring. Check it out. http://www.aeroplaneworks.ch/index2.html Bill C. ead this topic online here: http://forums.matronics.com/viewtopic.php?p=292372#292372 ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Mar 30, 2010
John, I used thin (probably around .018" dead soft stainless steel from Dillsburg Aeroplane Works for my firewall and bent the flange over on all sides using Tony Bingelis' easy method around the top curvature . I only have three small screws holding my stainless sheet to my 1/8" plywood firewall-you really don't need a whole lot more be cause the motor mount ears and bolts do a nice job of keeping it tight in addition to any cowling you screw to it. I di d put a thin (maybe 1/8" thick or less) Fiberfrax ceramic blanket layer between my 1/8" plywood firewall and the dead soft stainless firewall and just used a few dabs of contact cement on that piece to keep it in place while I installed the sheet stainless. I pref erred going over the fabric with my firewall rather than bending the firewall edges toward the prop-just made more sense to me but then agai n there are probably Piets with flush mounted sheet steel firewalls which is okay too. Mike C. ________________________________________________________________________________
Subject: forming aluminum
Date: Mar 30, 2010
I'm trying to get this cowl formed a little better and a friend wants me to try and put some roll around the edges were it is close to the scoops. it will be along a curve which will cause it to have to stretch too. he says he thinks I can anneal the aluminum enough to form it with a hammer on a block of wood. I'm using .025" 2024T3 which is thin and pretty hard. what are the chances I could get it soft enough to maybe work about a 45 degree bend along a curved edge on it without cracking? Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292399#292399 ________________________________________________________________________________
Subject: Re: totally off topic but outstanding-- B-25 over Dallas/
Ft. W
Date: Mar 30, 2010
true-it is incredible, but kinda looked photo shopped to me.it sits there like it is on a stand never a wobble till it turns away. must have been some mighty smooth air? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292400#292400 ________________________________________________________________________________
Subject: Re: forming aluminum
Date: Mar 30, 2010
Without heat, you should be able to form the edges around a thin welding filler wire. Just leave an extra 1/4" or so, and start forming with linesmen pliers. It's easier than you think. I did all around the openings for my cylenders, and for the front of my eyebrows walt evans NX140DL ----- Original Message ----- From: skellytown flyer To: pietenpol-list(at)matronics.com Sent: Tuesday, March 30, 2010 5:07 PM Subject: Pietenpol-List: forming aluminum I'm trying to get this cowl formed a little better and a friend wants me to try and put some roll around the edges were it is close to the scoops. it will be along a curve which will cause it to have to stretch too. he says he thinks I can anneal the aluminum enough to form it with a hammer on a block of wood. I'm using .025" 2024T3 which is thin and pretty hard. what are the chances I could get it soft enough to maybe work about a 45 degree bend along a curved edge on it without cracking? Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292399#292399 ________________________________________________________________________________
Subject: GN-1 question
Date: Mar 30, 2010
I have found some discrepancies in the GN-1 plans. Certainly not the first. My question concerns the location of the rudder pedals for the rear seat. If I put them where they show on the plans I think I will have my knees in my chin and I am not a tall person. If I put them where i think they need to go they will prevent the support under the front edge of the front seat from extending to the longerons. I read some where on the forum of concern that if the front seat is not supported laterally it could collapse sideways. The previous builder of my project planned to support the front seat on a set of pedestal brackets front and back that give little lateral support. Have any GN-1 builders encountered this. I am estimating that my rudder pedals front and back will be 41" from the backrest of their respective seats. Jon Coxwell Remsen NY -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292403#292403 ________________________________________________________________________________
Date: Mar 30, 2010
Walt, Thanks for sharing that. I am not yet to sheet metal work, but I will get some scrap and practice that. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292404#292404 ________________________________________________________________________________
Dallas/ Ft. W
Date: Mar 30, 2010
Yea, there is something phony about that video. Dan Helsper Poplar Grove, IL. NX929DH -----Original Message----- From: skellytown flyer <skellflyer1(at)yahoo.com> Sent: Tue, Mar 30, 2010 4:09 pm Subject: Pietenpol-List: Re: totally off topic but outstanding-- B-25 over Dallas/ Ft. W o.com> true-it is incredible, but kinda looked photo shopped to me.it sits there like t is on a stand never a wobble till it turns away. must have been some mig hty mooth air? ead this topic online here: http://forums.matronics.com/viewtopic.php?p=292400#292400 ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: Firewall Fabrication
Date: Mar 30, 2010
John - I didn't flange anything. Just took a thin piece of flat stainless, cut out the notches for the engine mount, and then screwed the metal on with a bunch of screws into the structure around the edges. Simple and works great. I put a layer of fiberfrax in between but in retrospect that seems like overkill (silly, expensive and heavy). When I attached the fabric I removed the firewall and glued the fabric around the edge of the structure (had to clearance the fiberfrax a little), and then reattached the metal. Best regards, Kevin Purtee NX899KP Austin/Georgetown Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292409#292409 ________________________________________________________________________________
Date: Mar 30, 2010
Bingelis says you don't need the fiberfrax if using a steel sheet against the firewall, but it can't hurt. rick On Tue, Mar 30, 2010 at 4:11 PM, kevinpurtee wrote: > > John - I didn't flange anything. Just took a thin piece of flat stainless, cut out the notches for the engine mount, and then screwed the metal on with a bunch of screws into the structure around the edges. Simple and works great. > > I put a layer of fiberfrax in between but in retrospect that seems like overkill (silly, expensive and heavy). > > When I attached the fabric I removed the firewall and glued the fabric around the edge of the structure (had to clearance the fiberfrax a little), and then reattached the metal. > > Best regards, > Kevin Purtee > NX899KP > Austin/Georgetown > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292409#292409 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: GN-1 question
Date: Mar 30, 2010
Mine are approx. 40" from the backrest and attached to the front seat cross member. I can send you a picture if you want. Bryan Green Elgin SC ----- Original Message ----- From: "coxwelljon" <coxwelljon(at)frontiernet.net> Sent: Tuesday, March 30, 2010 5:34 PM Subject: Pietenpol-List: GN-1 question > > > I have found some discrepancies in the GN-1 plans. Certainly not the > first. My question concerns the location of the rudder pedals for the > rear seat. If I put them where they show on the plans I think I will have > my knees in my chin and I am not a tall person. If I put them where i > think they need to go they will prevent the support under the front edge > of the front seat from extending to the longerons. I read some where on > the forum of concern that if the front seat is not supported laterally it > could collapse sideways. > > The previous builder of my project planned to support the front seat on a > set of pedestal brackets front and back that give little lateral support. > Have any GN-1 builders encountered this. I am estimating that my rudder > pedals front and back will be 41" from the backrest of their respective > seats. > > Jon Coxwell > Remsen NY > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292403#292403 > > > ________________________________________________________________________________
Date: Mar 30, 2010
Well so much for patience- I couldn't stand to try it without annealing. so I annealed it some and started rolling the edge with pliers and tape over the jaws. it was coming along fairly good. but I decided to trim some and re-anneal and roll some more. that wasn't a good move.when I hit it with the torch again I got an instant crack about 1" long in the curve. guess there was enough stress that the weakening from the heat let er rip.Oh well-I have a pattern and enough metal to cut another one. maybe better luck tomorrow.this is tedious work and I am not a patient person. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292414#292414 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: EW CG of 799B
Date: Mar 30, 2010
Dan, Just got back from a trip, so didn't see your email until today. My empty cg is 49.46. I did move the engine forward 3.5 inches and the wing is back 1" My engine also has a counterbalanced crank and a second magneto, so it's a bit heavier than standard, though it is probably the same as an iron headed engine I'd imagine. Douwe ________________________________________________________________________________
Subject: electronic tach
Date: Mar 30, 2010
Ck out the electronic Westach in the aircraft Spruce catalog. Works great on mine, and Larry Williams has been using one for years with success. Lightweight and easy to install and very accurate (I cked it) Douwe ________________________________________________________________________________
Subject: Re: electronic tach
Date: Mar 30, 2010
Ditto for me--Jim Lagowski ----- Original Message ----- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> Sent: Tuesday, March 30, 2010 7:31 PM Subject: Pietenpol-List: electronic tach > > > Ck out the electronic Westach in the aircraft Spruce catalog. Works great > on mine, and Larry Williams has been using one for years with success. > Lightweight and easy to install and very accurate (I cked it) > > Douwe > > > ________________________________________________________________________________
Date: Mar 30, 2010
Well Jack, at least my boat anchor will get me over those high hills west o f you. Gardiner=0A=0A=0A=0A=0A________________________________=0AFrom: Jack Phillips =0ATo: pietenpol-list(at)matronics.com=0ASen t: Tue, March 30, 2010 12:21:01 PM=0ASubject: RE: Pietenpol-List: William W ynne Corvair conversion parts for sale=0A=0A =0AWow! An A65 with only 1505 Total Time? =0AThat=99s pretty incredible.=0A =0ASo having sold that Chevrolet boat-anchor=0Ayou now have some funds available to purchase a fl ying Pietenpol? =0ACongratulations, Ryan!=0A =0AJack Phillips=0ANX899JP=0AR aleigh, NC=0A =0A=0A________________________________=0A =0AFrom:owner-piete npol-list-server(at)matronics.com [mailto: owner-pietenpol-list-server@matroni cs.com ] On Behalf Of Ryan Mueller=0ASent: Tuesday, March 30, 2010=0A12:16 PM=0ATo: Pietenpol List=0ASubject: Re: Pietenpol-List:=0AWilliam Wynne Corv air conversion parts for sale=0A =0AJust wanted to update: our Corvair pack age has been sold to a good=0Ahome! Thank you to those that inquired.=0A =0AIf you still need an engine for your project, do not despair! We still =0Ahave our Continental A-65 available, with only 1505TT and 709SMOH and co mplete=0Alogs. In the shipping crate, ready to head to your hangar or shop. The first=0A$3,000 snaps it up! :)=0A =0AHave a good day,=0A =0ARyan=0AO n Sun, Mar 28, 2010 at 12:16 PM, Ryan Mueller wrote: =0AHello all,=0A=0AWe have unfortunately decided to put our Corvair convers ion parts up for sale.=0A=0A =0A =0Ahttp://www.matronics.com/Naviga tor?Pietenpol-List=0Ahttp://forums.matronics.com=0Ahttp://www.matronics.com ________________________________________________________________________________
Ft. Wo
Date: Mar 30, 2010
Love the B-25... Grandpa's airplane... I sure miss him. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292422#292422 ________________________________________________________________________________
Subject: William Wynne Corvair conversion parts for sale
Date: Mar 30, 2010
Does that mean you are going to fly it to Brodhead this year, Gardiner? My low power but utterly reliable Continental has made the trip 3 times now. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:04 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Well Jack, at least my boat anchor will get me over those high hills west of you. Gardiner _____ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 12:21:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Wow! An A65 with only 1505 Total Time? That's pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC ________________________________________________________________________________
Date: Mar 30, 2010
Subject: Intercom
Someone was on the list earlier today describing the intercom that worked so well in his Piet. For some reason I cannot find that email. I need the name and part number of this intercom. Thanks, Do not arch rive Lynn Knoll Wichita Piet/Vair in the works ________________________________________________________________________________
Date: Mar 30, 2010
Wow! Suer Duper! And how about that web site? Also well put together. -------- Mark - working on wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292425#292425 ________________________________________________________________________________
Date: Mar 30, 2010
I plan to Jack. I have 12 hours on the fly off now and everything is workin g great so far. By the way, Are you suggesting that Bernie made a mistake by using the corvair as an alternative engine? Cheers, Gardiner=0A=0A=0A=0A =0A=0A________________________________=0AFrom: Jack Phillips <pietflyr@bell south.net>=0ATo: pietenpol-list(at)matronics.com=0ASent: Tue, March 30, 2010 8 :33:01 PM=0ASubject: RE: Pietenpol-List: William Wynne Corvair conversion p arts for sale=0A=0A =0ADoes that mean you are going to fly it to=0ABrodhead this year, Gardiner? My low power but utterly reliable Continental has=0A made the trip 3 times now.=0A =0AJack Phillips=0ANX899JP=0ARaleigh, NC=0A =0A=0A________________________________=0A =0AFrom:owner-pietenpol-list-serv er(at)matronics.com [mailto: owner-pietenpol-list-server(at)matronics.com ] On Be half Of airlion=0ASent: Tuesday, March 30, 2010 8:04=0APM=0ATo: pietenpol-l ist(at)matronics.com=0ASubject: Re: Pietenpol-List:=0AWilliam Wynne Corvair co nversion parts for sale=0A =0AWell Jack, at least my boat anchor will get m e over those=0Ahigh hills west of you. Gardiner=0A =0A=0A__________________ ______________=0A =0AFrom:Jack Phillips =0ATo: piet enpol-list(at)matronics.com=0ASent: Tue, March 30, 2010 12:21:01=0APM=0ASubjec t: RE: Pietenpol-List:=0AWilliam Wynne Corvair conversion parts for sale=0A Wow! An A65 with only 1505 Total=0ATime? That=99s pretty incredible .=0A =0ASo having sold that Chevrolet boat-anchor=0Ayou now have some funds available to purchase a flying Pietenpol? =0ACongratulations, Ryan!=0A =0A ======== ________________________________________________________________________________
Date: Mar 30, 2010
Bryan, Yes, please send or post a picture if it is not too much trouble. I would like to see how you supported the seat as well. Thanks Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292434#292434 ________________________________________________________________________________
Date: Mar 30, 2010
Subject: Re: intercom
Greg, Sure. Here's two shots from westcoastpiet. We've cleaned up the routing of the wires since the photo was taken, using sticky-backed cable clamps from Office Depot or Staples. http://www.westcoastpiet.com/images/Wayne%20Bob%20and%20Jeff/IMG_0126.JPG http://www.westcoastpiet.com/images/Wayne%20Bob%20and%20Jeff/IMG_0127.JPG HTH, Jeff > >Can I get picture Jeff of the intercom and its placement? Thanks Greg, DE > > >-----Original Message----- >>From: Jeff Boatright <jboatri(at)emory.edu> >>Sent: Mar 21, 2010 7:30 AM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Re: intercom >> >> >>Douwe, >> >>Our intercom is a FlightTech ITC-401TC. It's a portable that runs off >>a 9V battery. We replace the battery at every annual, whether it >>needs it or not. We've mounted in on the back of the front seat, to >>the right of the pilot's left-leg knee out. Works great with every >>mix of headsets that we've thrown at it. >> >>Jeff >> >> >>-- >>--- >> >>Jeffrey H. Boatright, Ph.D. >>Associate Professor of Ophthalmology >>Emory University School of Medicine >>Editor-in-Chief >>Molecular Vision >> >> >> >> > > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Mar 30, 2010
John, I used 12 ga. Galvanized and a former to help make the bends (also my home made flanging pliers). Not as shiny as Mike C's, nor is it flight tested or fire tested. The sides and top are bent forward, while the bottom is bent back. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Egan Sent: Tuesday, March 30, 2010 10:44 AM Subject: Pietenpol-List: Firewall Fabrication Builders, I will beginning my steel sheet firewall soon, and am interested in builders comments on firewall construction, specifically, if people use a flange as a means of attaching the cowling. I have been planning on bending a flange, and I also wonder if the flange is needed for any reason at the bottom edge where the cowl droops down a little below the firewall. So, 1. Do people use the flange to attach the cowl along the rounded top edge? 2. Is the flange needed at the bottom edge, or do people roll the bottom edge completely over, or maybe bend a short flange backward on a 45 degree angle along the bottom, or omit the flange on the bottom? 3. What are good ways to attach the steel firewall sheet to the plywood firewall, and is fiberfrax recommended behind the steel sheet? by the way, Tony Bingiles recomends using .018" sheet. Also, I welded up a flanging tool out of a pair of vise grips to make those little waves that are needed when you bend a flange around a curved shape. thanks all, john egan greenville, wi ________________________________________________________________________________
Date: Mar 30, 2010
Date: Mar 30, 2010
Skellytown, I am so ignorant about shete medal work that I don't even know how to spell it! But someone sent me the attached, "Bead Wire" and I was able to produce two cooling ears right. My first one was with .025 and I had a great deal of trouble making it bend, so I switched to .016 and the next two came out great. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of skellytown flyer Sent: Tuesday, March 30, 2010 2:07 PM Subject: Pietenpol-List: forming aluminum I'm trying to get this cowl formed a little better and a friend wants me to try and put some roll around the edges were it is close to the scoops. it will be along a curve which will cause it to have to stretch too. he says he thinks I can anneal the aluminum enough to form it with a hammer on a block of wood. I'm using .025" 2024T3 which is thin and pretty hard. what are the chances I could get it soft enough to maybe work about a 45 degree bend along a curved edge on it without cracking? Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292399#292399 ________________________________________________________________________________
Date: Mar 30, 2010
I think Bernard liked to experiment. At the time he used that Corvair, it was far cheaper than an aircraft engine. That is no longer the case (the email that started this thread was about a Corvair PROJECT that was for sale for $6,000, which is four times as much as I paid for my Continental A-65, and is nearly half what I've got in the Lycoming O-540 that I'll put in the RV-10). I owned a Corvair for several years (we bought it new in 1966, so it wasn't worn out when we got it, although it was 3 years later) and learned a great deal about the "reliability' of both the engine and the car. I remember that the Corvair was used in one of my machine design classes in college as an example of how NOT to design a belt-drive system. But these airplanes are licensed as "Experimental", so go for it. I just prefer aircraft engines for aircraft, and car engines for cars. The design requirements are totally different. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:50 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale I plan to Jack. I have 12 hours on the fly off now and everything is working great so far. By the way, Are you suggesting that Bernie made a mistake by using the corvair as an alternative engine? Cheers, Gardiner _____ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 8:33:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Does that mean you are going to fly it to Brodhead this year, Gardiner? My low power but utterly reliable Continental has made the trip 3 times now. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto: owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:04 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Well Jack, at least my boat anchor will get me over those high hills west of you. Gardiner _____ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 12:21:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Wow! An A65 with only 1505 Total Time? That's pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC ________________________________________________________________________________
Date: Mar 30, 2010
I moved mine far enough forward for my legs. Don't trust the CAD plans. Tom Bernie N666TB Gloucester Mass On Mar 30, 2010, at 5:34 PM, coxwelljon wrote: > > I have found some discrepancies in the GN-1 plans. Certainly not the first. My question concerns the location of the rudder pedals for the rear seat. If I put them where they show on the plans I think I will have my knees in my chin and I am not a tall person. If I put them where i think they need to go they will prevent the support under the front edge of the front seat from extending to the longerons. I read some where on the forum of concern that if the front seat is not supported laterally it could collapse sideways. > > The previous builder of my project planned to support the front seat on a set of pedestal brackets front and back that give little lateral support. Have any GN-1 builders encountered this. I am estimating that my rudder pedals front and back will be 41" from the backrest of their respective seats. > > Jon Coxwell > Remsen NY > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292403#292403 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 30, 2010
Thanks for the pictures of you intercom Jeff. Greg -----Original Message----- >From: Jeff Boatright <jboatri(at)emory.edu> >Sent: Mar 30, 2010 9:17 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: intercom > > >Greg, > >Sure. Here's two shots from westcoastpiet. We've cleaned up the >routing of the wires since the photo was taken, using sticky-backed >cable clamps from Office Depot or Staples. > >http://www.westcoastpiet.com/images/Wayne%20Bob%20and%20Jeff/IMG_0126.JPG > >http://www.westcoastpiet.com/images/Wayne%20Bob%20and%20Jeff/IMG_0127.JPG > > >HTH, > >Jeff > >> >>Can I get picture Jeff of the intercom and its placement? Thanks Greg, DE >> >> >>-----Original Message----- >>>From: Jeff Boatright <jboatri(at)emory.edu> >>>Sent: Mar 21, 2010 7:30 AM >>>To: pietenpol-list(at)matronics.com >>>Subject: Re: Pietenpol-List: Re: intercom >>> >>> >>>Douwe, >>> >>>Our intercom is a FlightTech ITC-401TC. It's a portable that runs off >>>a 9V battery. We replace the battery at every annual, whether it >>>needs it or not. We've mounted in on the back of the front seat, to >>>the right of the pilot's left-leg knee out. Works great with every >>>mix of headsets that we've thrown at it. >>> >>>Jeff >>> >>> >>>-- >>>--- >>> >>>Jeffrey H. Boatright, Ph.D. >>>Associate Professor of Ophthalmology >>>Emory University School of Medicine >>>Editor-in-Chief >>>Molecular Vision >>> >>> >>> >>> >> >> > > >-- >--- > >Jeffrey H. Boatright, Ph.D. >Associate Professor of Ophthalmology >Emory University School of Medicine >Editor-in-Chief >Molecular Vision > > ________________________________________________________________________________
Date: Mar 31, 2010
All the engine choices AFTER the model A were compromises for Bernie.er,.. sorry..Bernard (Bernerd). :o) Dan Helsper Poplar Grove, IL. -----Original Message----- From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, Mar 30, 2010 8:26 pm Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sa le I think Bernard liked to experiment. At the time he used that Corvair, it was far cheaper than an aircraft engine. That is no longer the case (the email that started this thread was about a Corvair PROJECT that was for sale for $6,000, which is four times as much as I paid for my Continental A-65, and is nearly half what I=99ve got in the Lycoming O-540 that I=99ll put in the RV-10). I owned a Corvair for several years (we bought it new in 1966, so it wasn=99t worn out when we got it, alth ough it was 3 years later) and learned a great deal about the =9Crel iability=99 of both the engine and the car. I remember that the Cor vair was used in one of my machine design classes in college as an example of how NOT to design a belt-drive system. But these airplanes are licensed as =9CExperimental=9D, so go for it. I just prefer aircraft engines for aircraft, and car engines for cars. The design requirements are totally different. Jack Phillips NX899JP Raleigh, NC From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:50 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sa le I plan to Jack. I have 12 hours on the fly off now and everything is worki ng great so far. By the way, Are you suggesting that Bernie made a mistak e by using the corvair as an alternative engine? Cheers, Gardiner From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 8:33:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sa le Does that mean you are going to fly it to Brodhead this year, Gardiner? My low power but utterly reliable Continental has made the trip 3 times now. Jack Phillips NX899JP Raleigh, NC From: owner-pietenpol-list-server(at)matronics.com [mailto: owner-pietenpol-l ist-server(at)matronics.com ] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:04 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sa le Well Jack, at least my boat anchor will get me over those high hills west of you. Gardiner From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 12:21:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sa le Wow! An A65 with only 1505 Total Time? That=99s pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds availabl e to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC http://www.matronics.com/Navigator?P href="http://www.matronics.com/cont ribution"http://www.matronics.com/co============ ===== http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== http://www.matronics.com/contribution ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Mar 31, 2010
I don't understand why everybody is flanging the firewall. The fabric only needs 1" of glue surface and does not need to wrap around at all. I glued a 1" wide piece of spruce vertically on the front of the fuse frame. This is what the fabric is glued to. The front cowl then overlaps this piece, and serves as security for the cowl hold-on screws. Dan Helsper Poplar Grove, IL. NX929DH -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Tue, Mar 30, 2010 8:13 pm Subject: RE: Pietenpol-List: Firewall Fabrication John, I used 12 ga. Galvanized and a former to help make the bends (also my home made flanging pliers). Not as shiny as Mike C=99s, nor is it flight tested or fire tested. The sides and top are bent forward, while the bott om is bent back. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (18 ribs down) From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of John Egan Sent: Tuesday, March 30, 2010 10:44 AM Subject: Pietenpol-List: Firewall Fabrication Builders, I will beginning my steel sheet firewall soon, and am interested in builde rs comments on firewall construction, specifically, if people use a flange as a means of attaching the cowling. I have been planning on bending a fl ange, and I also wonder if the flange is needed for any reason at the bott om edge where the cowl droops down a little below the firewall. So, 1. Do people use the flange to attach the cowl along the rounded top edg e? 2. Is the flange needed at the bottom edge, or do people roll the bottom edge completely over, or maybe bend a short flange backward on a 45 degre e angle along the bottom, or omit the flange on the bottom? 3. What are good ways to attach the steel firewall sheet to the plywood firewall, and is fiberfrax recommended behind the steel sheet? by the way, Tony Bingiles recomends using .018" sheet. Also, I welded up a flanging tool out of a pair of vise grips to make thos e little waves that are needed when you bend a flange around a curved shap e. thanks all, john egan greenville, wi href="http://www.matronics.com/Navigator?Pietenpol-List"http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com"ht tp://forums.matronics.com href="http://www.matronics.com/contribution"ht tp://www.matronics.com/c ________________________________________________________________________________
Date: Mar 31, 2010
Gents - We'll be demonstrating this stuff again at Sun 'n Fun in the metal forming workshop in a couple weeks. Sometimes people bring their current part to work on, and we welcome them (although we obviously can't fit a custom part to a plane that's in North Carolina; we get asked to do just that at least a couple times during the week every year). We usually get a nice collection of tools lent to us by assorted vendors. Amongst these has been a power bead roller with a number of different die sets, including some that will form a wire-rolled edge. One of our guys made himself a new set of eyebrows for his J-5 there a few years back. If you're going to be there, bring the part. Even if you're not, we've got material to play with and we can work with you to show you how to fabricate your part when you get home. That being said: I've never annealed 2024. I HAVE annealed loads of 3003 with a torch, and it's something I demonstrate at SNF. I suppose we could try annealing 2024 and see what happens, but I'd rather spare the pain and suffering and talk to somebody who knows more sheet metal metallurgy than I do before wasting the time, if it's truly a waste. There is a formula used to calculate the minimum bending radius of a piece of sheet metal. Any radius smaller than that, and you're risking it cracking, as you found out. I've got it in my sheet metal books (low tech) but it can be found online with a simple search. When you're working metal like this, be careful about making abrupt marks on the metal surface (chisel marks, course sandpaper scratches, tooling marks). These can create stress risers and promote a failure starting in that area. Smooth marks (hammer blows) are ok. I bought a bead-roller from Harbor-Fright, but the dies still have machining marks on them. I'm not using them until I can polish them out, specifically for this reason. Ditto with the anvils on their English Wheel. You get what you pay for. Putting tape like you did over plier jaws, rivet sets, and other assorted tools that could make a mess is a good technique and is widely used. I usually use masking tape. Rubber tool-handle dip also works well and probably holds up better, but it's messy and takes time to dry. With my patience apparently being similar to others here, I usually just opt for the tape. Jim Ash -----Original Message----- >From: skellytown flyer <skellflyer1(at)yahoo.com> >Sent: Mar 30, 2010 7:11 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: forming aluminum > > >Well so much for patience- I couldn't stand to try it without annealing. so I annealed it some and started rolling the edge with pliers and tape over the jaws. it was coming along fairly good. but I decided to trim some and re-anneal and roll some more. that wasn't a good move.when I hit it with the torch again I got an instant crack about 1" long in the curve. guess there was enough stress that the weakening from the heat let er rip.Oh well-I have a pattern and enough metal to cut another one. maybe better luck tomorrow.this is tedious work and I am not a patient person. Raymond > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=292414#292414 > > ________________________________________________________________________________
Date: Mar 31, 2010
Jack - The last time I pointed the same thing out in this forum a couple years back, I got blasted. Tread lightly. Jim Ash -----Original Message----- From: Jack Phillips Sent: Mar 30, 2010 9:26 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale I think Bernard liked to experiment. At the time he used that Corvair, it was far cheaper than an aircraft engine. That is no longer the case (the email that started this thread was about a Corvair PROJECT that was for sale for $6,000, which is four times as much as I paid for my Continental A-65, and is nearly half what Ive got in the Lycoming O-540 that Ill put in the RV-10). I owned a Corvair for several years (we bought it new in 1966, so it wasnt worn out when we got it, although it was 3 years later) and learned a great deal about the reliability of both the engine and the car. I remember that the Corvair was used in one of my machine design classes in college as an example of how NOT to design a belt-drive system. But these airplanes are licensed as Experimental, so go for it. I just prefer aircraft engines for aircraft, and car engines for cars. The design requirements are totally different. Jack Phillips NX899JP Raleigh, NC From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:50 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale I plan to Jack. I have 12 hours on the fly off now and everything is working great so far. By the way, Are you suggesting that Bernie made a mistake by using the corvair as an alternative engine? Cheers, Gardiner From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 8:33:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Does that mean you are going to fly it to Brodhead this year, Gardiner? My low power but utterly reliable Continental has made the trip 3 times now. Jack Phillips NX899JP Raleigh, NC From: owner-pietenpol-list-server(at)matronics.com [mailto: owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:04 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Well Jack, at least my boat anchor will get me over those high hills west of you. Gardiner From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 12:21:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Wow! An A65 with only 1505 Total Time? Thats pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC http://www.matronics.com/Navigator?P href="http://www.matronics.com/contribution">http://www.matronics.com/co================ http://www.matronics.com/Navigator?Pietenpol-List ="From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Mar 31, 2010
Subject: Bernard used an aluminum block V-8 engine too
I may be incorrect on this but I swear that one of Bernard's experiments wa s to use a V-8 engine on one of his planes but that didn't make it any more right or wrong than using a Lambert, Continental, Corvair, or Subaru. I'm with Jack on reliability though of a Continental. It is all a perso nal choice but you takes yer chances. Mike C. ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Re: Bernard used an aluminum block V-8 engine too
I suspect that engine reliability is a product of several variables, only one of which is the original design of the engine. How well is it maintained? How hard is it run? How frequently is it run? Was it assembled correctly? Were the right parts used / replaced? Is it properly set up for the task? Is the pre-flight thorough enough to catch a problem early? Granted a Lycoming or Continental was constructed specifically to be used on aircraft while an automobile engine was designed to be in an entirely different environment (multiple and frequent speed changes, dirtier air, LOTS of vibration, and on and on) but these things can be and are correctable. William Wynne has amassed a vast amount of data on the Corvair engine over the years and that has been incorporated into current engine technology to great effect. Besides, some of the older technology engines without all these refinements have gone over 1,000 hours trouble free. Newer ones have obviously snapped a couple of cranks for one reason or another but so have the aircraft engines if improperly used. Sure you have to assemble a Corvair yourself, or pay someone to do it for you, but let's remember that many of you folks are doing the same thing with your aircraft grade engines. If you don't do it right it is still going to bite you where it hurts. And YES, it probably will cost more to convert a Corvair with all the newest parts. (But what a gorgeous engine you have when it's all done.) My decision to go with a Corvair over the other choices was based, primarily, on available power. I have flown RC models for many years and have personally experienced the woes of trying to fly an underpowered aircraft. I don't want that feeling when my own "patutie" is in the plane. I plan to fly, at least once, from McPherson, KS to Mojave, CA and back which will require a certain amount of mountain flying. I don't particularly want to taxi all the way across the divide although that would certainly be a new type of experimental aviation. Also, did I happen to mention that I am not exactly a light weight? I also plan to carry a lot of passengers if I can find anyone with enough guts to fly with me. I will appreciate the extra margin of safety with regard to climb speed. Sorry! I'm now off the soapbox. This is me blushing. Tom Stinemetze Proud new owner of Ryan Mueller's Corvair project. N328X >>Im with Jack on reliability though of a Continental. It is all a personal choice but you takes yer chances. >>Mike C. ________________________________________________________________________________
Subject: Re: forming aluminum
Date: Mar 31, 2010
Gary, Very nice bead work! You'll probably want to beef up the corner shown in the top picture where the mounting screw is, because it'll most likely crack from the relief radius to the mounting hole. David Paule > I am so ignorant about shete medal work that I don't even know how to > spell > it! But someone sent me the attached, "Bead Wire" and I was able to > produce > two cooling ears right. My first one was with .025 and I had a great deal > of > trouble making it bend, so I switched to .016 and the next two came out > great. > > Gary Boothe ________________________________________________________________________________
Subject: New Corvair starter for sale
Date: Mar 31, 2010
I have a brand new WW starter (just arrived), I have not even taken it out of the box. I think they go for $210 now and $25 shipping. Would like to get $200 and I'll pay to ship. Please let me know if interested, thanks. Steve chase143(at)aol.com And....no, I am not trying the fuel the Corvair/A65 debate! hahaha LOL :-) -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292510#292510 ________________________________________________________________________________
Date: Mar 31, 2010
Subject: used, good condition A-65 starter for sale.
It weighs nothing and costs nothing and it hasn't broken yet. I hear the Model A uses the same kind of starter. Seriously, for us full-figured girls having more power would be GREAT. I've often fantasized about having an 0-200 someday. I can easily see why the power of the Corvair is SO popular plus lots of guys don't feel like hand propping and some need the electrical system to support radios and transponders to get in and out of controlled or under controlled airspace environments. I can especially see guys like Tom S. in Texas and Gary B. in CA having to fly in hot weather conditions. I can especially see Rick Holland needing the power at his high elevations in Colorado with that thin air. As much as I rag on the auto engines I can certainly see why it is a good option for lots of you guys. Mike C. ________________________________________________________________________________
Date: Mar 31, 2010
Initial cost has crept up (though there is no need to buy every Wynne gold-level part), but maintenance/overhaul costs are still pretty distinct. >I think Bernard liked to experiment. At the time he used that >Corvair, it was far cheaper than an aircraft engine. That is no >longer the case (the email that started this thread was about a >Corvair PROJECT that was for sale for $6,000, which is four times as >much as I paid for my Continental A-65, and is nearly half what I've >got in the Lycoming O-540 that I'll put in the RV-10). I owned a >Corvair for several years (we bought it new in 1966, so it wasn't >worn out when we got it, although it was 3 years later) and learned >a great deal about the "reliability' of both the engine and the car. >I remember that the Corvair was used in one of my machine design >classes in college as an example of how NOT to design a belt-drive >system. > >But these airplanes are licensed as "Experimental", so go for it. I >just prefer aircraft engines for aircraft, and car engines for cars. >The design requirements are totally different. > >Jack Phillips >NX899JP >Raleigh, NC > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Sun-N-Fun
I've been faithfully flying off my Phase 1 time in hopes of bringing my Piet to Sun-N-Fun. Anybody else planning to bring theirs? Ben Charvet 16.6 hrs done ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Re: William Wynne Corvair conversion parts for sale
To play devil's advocate: the Corvair project for $6,000 is everything needed to assemble the Wynne based Corvair conversion, all parts reworked, overhauled, or new. How much did you have in your A-65 after the cost of acquisition, rework, new parts, etc? Just curious... ;) Ryan On Tue, Mar 30, 2010 at 8:26 PM, Jack Phillips wrot e: > I think Bernard liked to experiment. At the time he used that Corvair, > it was far cheaper than an aircraft engine. That is no longer the case ( the > email that started this thread was about a Corvair PROJECT that was for s ale > for $6,000, which is four times as much as I paid for my Continental A-65 , > and is nearly half what I=92ve got in the Lycoming O-540 that I=92ll put in the > RV-10). I owned a Corvair for several years (we bought it new in 1966, s o > it wasn=92t worn out when we got it, although it was 3 years later) and > learned a great deal about the =93reliability=92 of both the engine and t he > car. I remember that the Corvair was used in one of my machine design > classes in college as an example of how NOT to design a belt-drive system . > > > But these airplanes are licensed as =93Experimental=94, so go for it. I just > prefer aircraft engines for aircraft, and car engines for cars. The desi gn > requirements are totally different. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *airlion > *Sent:* Tuesday, March 30, 2010 8:50 PM > > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: William Wynne Corvair conversion parts for > sale > > > I plan to Jack. I have 12 hours on the fly off now and everything is > working great so far. By the way, Are you suggesting that Bernie made a > mistake by using the corvair as an alternative engine? Cheers, Gardiner > > > ------------------------------ > > *From:* Jack Phillips > *To:* pietenpol-list(at)matronics.com > *Sent:* Tue, March 30, 2010 8:33:01 PM > *Subject:* RE: Pietenpol-List: William Wynne Corvair conversion parts for > sale > > Does that mean you are going to fly it to Brodhead this year, Gardiner? My > low power but utterly reliable Continental has made the trip 3 times now. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com ] *On Behalf Of *airlion > *Sent:* Tuesday, March 30, 2010 8:04 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: William Wynne Corvair conversion parts for > sale > > > Well Jack, at least my boat anchor will get me over those high hills west > of you. Gardiner > > > ------------------------------ > > *From:* Jack Phillips > *To:* pietenpol-list(at)matronics.com > *Sent:* Tue, March 30, 2010 12:21:01 PM > *Subject:* RE: Pietenpol-List: William Wynne Corvair conversion parts for > sale > > Wow! An A65 with only 1505 Total Time? That=92s pretty incredible. > > > So having sold that Chevrolet boat-anchor you now have some funds availab le > to purchase a flying Pietenpol? Congratulations, Ryan! > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > *http://www.matronics.com/Navigator?P href="http://www.matronics.com/co ntribution">http://www.matronics.com/co============ ==== > * > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== > =========== =========== =========== > > * > > ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Re: electronic tach
The westach is the tach on NX92GB. The one we use has the tach generator. The only problem I have seen with it is it is inacurate, when compared to a timing light/ tach (snap on brand). The higher the rpm's the more inacurate it is. We indicate 3100rpm static, which the timing light reads about 2750-2800 rpm. the westach is consistant just not accurate, in our case anyhow. I don't know if others have this problem or not. We replaced the tah generator once, and it seemed a little more accurate for the 1st few hrs, but then read higher rpm's as time went by. I am not sure if there are any adjustments on the tach gauge or not. On another note, I am missing out on the best flying weather in the past 4-5 months, due to a bad back, I look like a question mark. ??? I need to get healed up and back to work, and get started on some fly-in planning for our little Ohio Piet fly-in here in June. Shad ________________________________________________________________________________
Date: Mar 31, 2010
Subject: B-25 gathering in april
To any of you around Ohio, dayton area, there is supposed to be a big staging of 20+ B-25's at urbana grimes airport on april 16-17. They are gathering for the Doolittle Radiers reunion in Dayton. They are scheduled to meet at Urbana, and fly out to dayton in a mass formation on the morning of Sat April 17. I am not sure what time exactly, but I have heard that this will be the biggest gathering of B-25's in 50 or so years. Hope to see some of you there if you can make it. Shad ________________________________________________________________________________
Subject: Sun-N-Fun
Date: Mar 31, 2010
Looks like 2 of the Big Piets will be there, Harold and Bruce. Frank and I are not going to have the hours flown off. Bummer! Barry Davis -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Wednesday, March 31, 2010 12:02 PM Subject: Pietenpol-List: Sun-N-Fun --> I've been faithfully flying off my Phase 1 time in hopes of bringing my Piet to Sun-N-Fun. Anybody else planning to bring theirs? Ben Charvet 16.6 hrs done ________________________________________________________________________________
Date: Mar 31, 2010
Thanks everyone, - I've decided to go with a real cable driven Tach for the sake of the look. I want it to be antique looking all over. Even my A-65 comes from the late '40's. Using wire wheels too. Jeff Wilson GN-1 St. Louis, MO chapt 64 --- On Wed, 3/31/10, shad bell wrote: From: shad bell <aviatorbell(at)yahoo.com> Subject: Re: Pietenpol-List: electronic tach Date: Wednesday, March 31, 2010, 11:25 AM The westach is the tach on NX92GB.- The one we use has the tach generator .- The only problem I have seen with it is it is inacurate, when compared to a timing light/ tach (snap on brand).- The higher the rpm's the more inacurate it is.- We indicate 3100rpm static, which the timing light read s about 2750-2800 rpm.- the westach is consistant just not accurate, in o ur case anyhow.- I don't know if others have this problem or not.- We r eplaced the tah generator once, and it seemed a little more accurate for th e 1st few hrs, but then read higher rpm's as time went by. I am not sure if there are any adjustments on the tach gauge or not. On another note, I am missing out on the best flying weather in the past 4-5 months, due to a bad back, I look like a question mark. ??? I need to get healed up and back to work, and get started on some fly-in planning for our little Ohio Piet fly -in here in June.- Shad - - - le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Mar 31, 2010
The USSR built this bad boy with 16 Corvair engines. On Wed, Mar 31, 2010 at 9:56 AM, Ryan Mueller wrote: > To play devil's advocate: the Corvair project for $6,000 is everything > needed to assemble the Wynne based Corvair conversion, all parts reworked , > overhauled, or new. How much did you have in your A-65 after the cost of > acquisition, rework, new parts, etc? Just curious... - ;) > Ryan > > On Tue, Mar 30, 2010 at 8:26 PM, Jack Phillips > wrote: >> >> I think Bernard liked to experiment.- At the time he used that Corvair , it >> was far cheaper than an aircraft engine.- That is no longer the case ( the >> email that started this thread was about a Corvair PROJECT that was for sale >> for $6,000, which is four times as much as I paid for my Continental A-6 5, >> and is nearly half what I=92ve got in the Lycoming O-540 that I=92ll put in the >> RV-10).- I owned a Corvair for several years (we bought it new in 1966 , so >> it wasn=92t worn out when we got it, although it was 3 years later) and >> learned a great deal about the =93reliability=92 of both the engine and the >> car.- I remember that the Corvair was used in one of my machine design >> classes in college as an example of how NOT to design a belt-drive syste m. >> >> >> >> But these airplanes are licensed as =93Experimental=94, so go for it.- I just >> prefer aircraft engines for aircraft, and car engines for cars.- The d esign >> requirements are totally different. >> >> >> >> Jack Phillips >> >> NX899JP >> >> Raleigh, NC >> >> >> >> ________________________________ >> >> From: owner-pietenpol-list-server(at)matronics.com >> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion >> Sent: Tuesday, March 30, 2010 8:50 PM >> >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for >> sale >> >> >> >> I plan to Jack. I have 12 hours on the fly off now and everything is >> working great so far.- By the way, Are you suggesting that Bernie made a >> mistake by using the corvair as an alternative engine? Cheers, Gardiner >> >> >> >> >> >> ________________________________ >> >> From: Jack Phillips <pietflyr(at)bellsouth.net> >> To: pietenpol-list(at)matronics.com >> Sent: Tue, March 30, 2010 8:33:01 PM >> Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for >> sale >> >> Does that mean you are going to fly it to Brodhead this year, Gardiner? >> My low power but utterly reliable Continental has made the trip 3 times now. >> >> >> >> Jack Phillips >> >> NX899JP >> >> Raleigh, NC >> >> >> >> ________________________________ >> >> From: owner-pietenpol-list-server(at)matronics.com [mailto: >> owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion >> Sent: Tuesday, March 30, 2010 8:04 PM >> To: pietenpol-list(at)matronics.com >> Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for >> sale >> >> >> >> Well Jack, at least my boat anchor will get me over those high hills wes t >> of you. Gardiner >> >> >> >> ________________________________ >> >> From: Jack Phillips <pietflyr(at)bellsouth.net> >> To: pietenpol-list(at)matronics.com >> Sent: Tue, March 30, 2010 12:21:01 PM >> Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for >> sale >> >> Wow!- An A65 with only 1505 Total Time?- That=92s pretty incredible. >> >> >> >> So having sold that Chevrolet boat-anchor you now have some funds >> available to purchase a flying Pietenpol?- Congratulations, Ryan! >> >> >> >> Jack Phillips >> >> NX899JP >> >> Raleigh, NC >> >> >> >> http://www.matronics.com/Navigator?P >> href="http://www.matronics.com/contribution">http://www.matronics.com/ co================ >> >> >> >> >> >> http://www.matronics.com/Navigator?Pietenpol-List >> >> http://forums.matronics.com >> >> http://www.matronics.com/contribution >> >> >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > =========== =========== =========== =========== > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Re: Sun-N-Fun
Ben, I am flying my time off too with 13 hours on the clock. I will be working in th woodshop carving a prop. Stop by and say hello. Cheers, Gardiner Mason ----- Original Message ---- From: Ben Charvet <bcharvet(at)bellsouth.net> Sent: Wed, March 31, 2010 12:01:42 PM Subject: Pietenpol-List: Sun-N-Fun I've been faithfully flying off my Phase 1 time in hopes of bringing my Piet to Sun-N-Fun. Anybody else planning to bring theirs? Ben Charvet 16.6 hrs done ________________________________________________________________________________
Subject: Re: used, good condition A-65 starter for sale.
Date: Mar 31, 2010
Mikee- In some jurisdictions, what you posted about being "for sale" would be considered as "solicitation" and you would be arrested by the vice squad ;o) I remember when I first got 41CC and there were some issues with the ignition harnesses. I was at work, Charlie was at the hangar attempting to start the engine and called me on the phone with the news that "the airplane needs a new starter". For a minute all I saw were dollar signs until the joke clicked in my head. Ever since I replaced the lower harness and all the plugs on the 65, it has started quite readily except when it's hot and I flood the thing. I like to hand-prop and I like the simplicity of no electrics. To me, it enhances the open cockpit experience. The 75 that is now on the airplane is even easier to start, what with dual impulse mags. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292534#292534 ________________________________________________________________________________
Date: Mar 31, 2010
I'll second what David suggests... beefing that area up. It's not a reflection on how smooth the engine might run (Corvairs being quite smooth), it's that the eyebrow leading edges are just inches aft of that prop, which delivers pulsed air past the eyebrows continuously. I've repaired several cracked pieces on 41CC's cooling eyebrows due to the propwash pulsations. Metal fatigue, plain and simple. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292539#292539 ________________________________________________________________________________
Date: Mar 31, 2010
Yes, the voice of reason. 7000 ft. runway elevation, 95 degrees F, density altitude 10,900. At that altitude the C-65 will be putting out around 43 HP. The Corvair or O-200 around 67 HP. Unfortunately the price of used O-200 has increased as the economy has gone to hell. The guy at Wentworth said the demand for these has increased because people are downsizing there expectations from that RV-7/8/9 with the O-360 (or similar, after they realized it was going to cost $70k +) to an LSA kit (or even better a Pietenpol). And Jack, we don't use that stinkin dual 90 degree cooling fan/belt on WW Corvair conversions. rick On Wed, Mar 31, 2010 at 9:24 AM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > > > It weighs nothing and costs nothing and it hasn't broken yet. I hear the Model > A uses the same kind of starter. > > Seriously, for us full-figured girls having more power would be GREAT. I've often > fantasized about having an 0-200 someday. > > I can easily see why the power of the Corvair is SO popular plus lots of guys don't > feel like hand propping and some need the electrical system to support radios and > transponders to get in and out of controlled or under controlled airspace environments. > I can especially see guys like Tom S. in Texas and Gary B. in CA having to fly in hot > weather conditions. > > I can especially see Rick Holland needing the power at his high elevations in Colorado > with that thin air. As much as I rag on the auto engines I can certainly see why it is > a good option for lots of you guys. > > Mike C. > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 31, 2010
Actually, when you go back and look at some of the stuff Sikorsky designed and built (at age 29!) in pre-WWI Russia, it's really impressive, especially when compared to just about anything else flying at the time. Good thing he jumped ship to our side. >The USSR built this bad boy with 16 Corvair engines. -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 31, 2010
Subject: metal fatigue minimized by using 0000 dead soft aluminum
I have had very minimal cracking issues with my hand-made Cub style cooling eyebrows/baffles since I used 0000 or dead soft .025" aluminum to make them. The dead soft resists metal fatigue very nicely and makes forming that reinforcement wire into the leading edge an easy event. ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Re: Intercom
Lynn, I bought a FLIGHTECH ITC-401/1-ENRI from ACS. P.F. Beck also lauds this intercom in the most recent BPA newsletter. Coupled with mic muffs, it works quite well in N8031. Dan On 03/30/2010 07:30 PM, dknoll(at)cox.net wrote: > --> Pietenpol-List message posted by: > > Someone was on the list earlier today describing the intercom that worked so well in his Piet. For some reason I cannot find that email. I need the name and part number of this intercom. > Thanks, > > Do not arch rive > > Lynn Knoll > Wichita > Piet/Vair in the works > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: Insurance question
Date: Mar 31, 2010
dan.loegering(at)odayequi wrote: > Ran into an odd situation recently and wanted to see what others have done in the past, or are currently doing. > > I recently sold my house and am renting now, so I switched to a renters insurance policy. Since I was bored last night (the plane is still in storage for another week) I was reading through the policy, and came across the statement that "aircraft and aircraft parts are not covered." Huh? > > Spoke to my agent today and he had never come across this either, did some research and they do not cover aircraft or parts on ANY of their policies. > > So my question is this - what, if anything, did you do to provide coverage for your projects while they were in the project stage? I am simply looking to cover my costs of materials in the event of theft, fire, etc... Is this something that I should not worry about (I am normally a trusting individual, but the new house is close to a high school and the garage is located in the alley - apparently there have been issues in the past with some of the garages being used as gathering places by the students) One neighbor suggested blocking the windows and getting a bigger lock... I may not go to that extreme (it isn't THAT bad of a neighborhood...) but I will definitely be putting in a new lock. > > It will be nice to get back to building though - time to make more sawdust and grind some metal! > > Dan Loegering > Fargo, ND Dan, I would check into a special policy. Your greatest risk may not be from vandalism. I had a good friend who lived in a great timber frame house, attached workshop, and totally off the grid. He was building an Rans from a kit. They called for forming the tank by filling it full of fuel and letting sit and take shape. The tank was closed yet fumes leaked across the floor to a heater on the other side of the shop. The whole thing went up including the house and was a total loss. Fortunately there was no loss of human life. Insurance paid nothing on the airplane and would not even cover a PV array because it was next to the house and not attached exept by wiring. Rans gave him a good deal on a new kit but the fire took several years out of his life while he rebuilt his house. He is now starting again on the Rans. It has made me think both about insurance and what I do in the shop. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292548#292548 ________________________________________________________________________________
Subject: Re: GN-1 question
Date: Mar 31, 2010
luther b green wrote: > Mine are approx. 40" from the backrest and attached to the front seat cross > member. I can send you a picture if you want. > Bryan Green > Elgin SC > --- Bryan, I tried to respond to your email but it comes back with address unknown. I would like to see some pictures and since you are re-building I would like to know what issues you are running into. Mine has never flown but I an doing plenty of re-building of someone else's work. I almost think starting from scratch is easier. I think mine is sound, but the original builders (2 or 3) were not as particular as I would like. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292550#292550 ________________________________________________________________________________
Date: Mar 31, 2010
Tom Bernie wrote: > I moved mine far enough forward for my legs. Don't trust the CAD plans. > Tom Bernie > N666TB > Gloucester Mass > > Tom, I am working from the hand drawn plans but there are lots of mistakes there as well. I purchased a set of original Piet plans as a reference which I encourage anyone building a GN-1 to do. > > BTW I found a link to your project photo documentation and read through your past posting on the forum. Looking at your photos was really helpful and your posting indicated that we are addressing some issues in similar ways. > > Jon Coxwell > > > > > > > > > > > -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292552#292552 ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Re: New Corvair starter for sale
Steve - is it a front mounted starter? If so - count me in for it. Cheers jon In a message dated 3/31/2010 8:56:29 A.M. Mountain Daylight Time, chase143(at)aol.com writes: --> Pietenpol-List message posted by: "chase143(at)aol.com" I have a brand new WW starter (just arrived), I have not even taken it out of the box. I think they go for $210 now and $25 shipping. Would like to get $200 and I'll pay to ship. Please let me know if interested, thanks. Steve chase143(at)aol.com And....no, I am not trying the fuel the Corvair/A65 debate! hahaha LOL :-) -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292510#292510 ________________________________________________________________________________
Subject: forming aluminum
Date: Mar 31, 2010
Thanks, David! That picture was taken while testing for fit, and adding some other stuff on the back. Since then I have added more support. In retrospect, using dead soft, as Mike C advises, would be a good idea.....lots of time to do that when needed. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of David Paule Sent: Wednesday, March 31, 2010 7:25 AM Subject: Re: Pietenpol-List: forming aluminum Gary, Very nice bead work! You'll probably want to beef up the corner shown in the top picture where the mounting screw is, because it'll most likely crack from the relief radius to the mounting hole. David Paule > I am so ignorant about shete medal work that I don't even know how to > spell > it! But someone sent me the attached, "Bead Wire" and I was able to > produce > two cooling ears right. My first one was with .025 and I had a great deal > of > trouble making it bend, so I switched to .016 and the next two came out > great. > > Gary Boothe ________________________________________________________________________________
Date: Mar 31, 2010
Jon, Yes, I believe it is. I will double check tonight, and save it for you if you want it. I'll drop me a note off-line. Thanks, Steve -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292560#292560 ________________________________________________________________________________
Subject: William Wynne Corvair conversion parts for sale
Date: Mar 31, 2010
What Bad Boy? Did you attach a pic of something? BED -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Sent: Wednesday, March 31, 2010 1:34 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Actually, when you go back and look at some of the stuff Sikorsky designed and built (at age 29!) in pre-WWI Russia, it's really impressive, especially when compared to just about anything else flying at the time. Good thing he jumped ship to our side. >The USSR built this bad boy with 16 Corvair engines. -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Mar 31, 2010
Dan, Your question prompted me to do a little more research with my State Farm Agent and in fact I found that I do not have insurance that covers my GN-1 while I am building it. Nor can I get it through State Farm. I then went to the EAA website and ended up making a call to their insurance program. Not a lot of help there either for those of us that are building from plans. I did find out that the the minimum hull insurance while building is going to be around $500 per year plus or minus. That kind of coverage will go up to $40,000 and is the minimum. (That would be a real nice Piet or GN-1). I asked the question about liability insurance and that is where things get sticky for tail draggers. They not only want tailwheel time which is understandable, but want some time in the same model. I have 100 hours of tail wheel and 1700 hours total, but none in a GN-1 or a Piet. The EAA insurance agent told me I should be thinking about getting some more tail wheel time and try real hard to get GN-1 time before my airplane is ready to fly. This is just a heads up. Thanks Dan for raising this question. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292561#292561 ________________________________________________________________________________
Date: Mar 31, 2010
Previous post from ?? had some pix. > >What Bad Boy? Did you attach a pic of something? >BED > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff >Boatright >Sent: Wednesday, March 31, 2010 1:34 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale > > >Actually, when you go back and look at some of the stuff Sikorsky designed >and built (at age 29!) in pre-WWI Russia, it's really impressive, especially >when compared to just about anything else flying at the time. Good thing he >jumped ship to our side. > > >>The USSR built this bad boy with 16 Corvair engines. > > >-- > >Jeff Boatright >"Now let's think about this..." -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Subject: Re: metal fatigue minimized by using 0000 dead soft aluminum
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Mar 31, 2010
Thanks Michael. I am going to cut another piece and I am trying to decide whether to use the same .025- 2024T3 or switch to some soft aluminum I have on hand that is about .035. I have no intention of making a special order for more.and I don't think the thickness difference will amount to much more than a half pound. I'm only talking bout around 2 1/2 sq. ft. here if I use the thin I think I'll forget the rolled up edge and just cut a little more clearance and use some rubber edge trim over it.I need to get off high center and keep this project moving along while I have the time at home.and I don't need a complete roll around wire-just an up turned lip would help stiffen the area and give extra clearance if the engine shifts enough.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292566#292566 ________________________________________________________________________________
Subject: just famous- not rich
Date: Mar 31, 2010
Well, yippee-! A friend here at work passed along his copy of the April/May 2010 "Air & Space Smithsonian" magazine and I'm quoted in the magazine. Harrumph... okay, so my quote is just a tiny part of a really nifty article called "The Pride of Cherry Grove", all about Piets. Really nice story and pix, all the usual suspects. Good job! Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 31, 2010
Yea, check this out Barry. rick On Wed, Mar 31, 2010 at 1:55 PM, Barry Davis wrote: > > What Bad Boy? Did you attach a pic of something? > BED > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff > Boatright > Sent: Wednesday, March 31, 2010 1:34 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for s ale > > > Actually, when you go back and look at some of the stuff Sikorsky designe d > and built (at age 29!) in pre-WWI Russia, it's really impressive, especia lly > when compared to just about anything else flying at the time. Good thing he > jumped ship to our side. > > >>The USSR built this bad boy with 16 Corvair engines. > > > -- > > Jeff Boatright > "Now let's think about this..." > > =========== =========== =========== alle, List Admin. =========== > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Sun-N-Fun
Date: Mar 31, 2010
I'm planning to fly mine down. I won't be able to get there until Friday morning, though. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Wednesday, March 31, 2010 12:02 PM Subject: Pietenpol-List: Sun-N-Fun I've been faithfully flying off my Phase 1 time in hopes of bringing my Piet to Sun-N-Fun. Anybody else planning to bring theirs? Ben Charvet 16.6 hrs done ________________________________________________________________________________
Date: Mar 31, 2010
I have a total of $7,000 in my A-65, but that included NEW Millenium Cylinders and pistons, which was $3400 of that total. I also sent the crankcasr out to Divco for overhauling, and the crankshaft and connecting rods were overhauled by Aircraft Specialties. I bought a new camshaft, and new Slick magnetos. I did the overhaul myself, under the supervision of an A&P/IA. I could have done it much cheaper, but I like reliability, which is what started this thread. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Wednesday, March 31, 2010 11:57 AM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale To play devil's advocate: the Corvair project for $6,000 is everything needed to assemble the Wynne based Corvair conversion, all parts reworked, overhauled, or new. How much did you have in your A-65 after the cost of acquisition, rework, new parts, etc? Just curious... ;) Ryan On Tue, Mar 30, 2010 at 8:26 PM, Jack Phillips wrote: I think Bernard liked to experiment. At the time he used that Corvair, it was far cheaper than an aircraft engine. That is no longer the case (the email that started this thread was about a Corvair PROJECT that was for sale for $6,000, which is four times as much as I paid for my Continental A-65, and is nearly half what I've got in the Lycoming O-540 that I'll put in the RV-10). I owned a Corvair for several years (we bought it new in 1966, so it wasn't worn out when we got it, although it was 3 years later) and learned a great deal about the "reliability' of both the engine and the car. I remember that the Corvair was used in one of my machine design classes in college as an example of how NOT to design a belt-drive system. But these airplanes are licensed as "Experimental", so go for it. I just prefer aircraft engines for aircraft, and car engines for cars. The design requirements are totally different. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:50 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale I plan to Jack. I have 12 hours on the fly off now and everything is working great so far. By the way, Are you suggesting that Bernie made a mistake by using the corvair as an alternative engine? Cheers, Gardiner _____ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 8:33:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Does that mean you are going to fly it to Brodhead this year, Gardiner? My low power but utterly reliable Continental has made the trip 3 times now. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto: owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:04 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Well Jack, at least my boat anchor will get me over those high hills west of you. Gardiner _____ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 12:21:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Wow! An A65 with only 1505 Total Time? That's pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC http://www.matronics.com/Navigator?P href="http://www.matronics.com/contribution">http://www.matronics.com/co=== ============ http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 31, 2010
Did I not read once that an O-200 crank would fit some of the older Continentals? if so maybe you could find one that is too undersized to make the yellow tag specs but still cleaned up OK. I think it is common for airboat engines so they should be out there.maybe you just need a little more stroke? not wanting to get personal here. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292577#292577 ________________________________________________________________________________
Subject: A-65 power
Date: Mar 31, 2010
as usual I probably popped off about something I know nothing about. but this fellow seems to cover a lot of things on engine mods.sounds like the old A-65 is kinda light in places but he gives some tips. http://www.bowersflybaby.com/tech/fenton.htm#mod_a65 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292578#292578 ________________________________________________________________________________
Date: Mar 31, 2010
Great fakes! Nice staging, too. Who did them? David Paule > The USSR built this bad boy with 16 Corvair engines. ________________________________________________________________________________
Subject: Corvair vs. Continental - long
Date: Mar 31, 2010
Jack (et al), Here is my debate: You, and others, have said things that have caused me to pause and consider my decisions, and sometimes change my path. As always, you are the epitome of common sense and good judgment..or are you? I know that you know spam can drivers that look at you in your little home-made airplane (exquisite as it is, even with its "reliable" engine) and say, if not to you at least to themselves, "I would/could never do that." "You're going to fly it where? To Brodhead?" Or, how about the guys who say flying a taildragger is too dangerous! And all of those spam can drivers know ground pounders who say, "You're a pilot? You fly a Cessna/Piper/Beech? Isn't that scary? I could never do that!" The great mathematician, Augusta De Morgan, said: "Great fleas have little fleas upon their backs to bite 'em, And little fleas have lesser fleas, and so ad infinitum. And the great fleas themselves, in turn, have greater fleas to go on, While these again have greater still, and greater still, and so on." So, everyone has their limits. When we make the decision to build an experimental airplane, we set ourselves on a less traveled path.but that's just the beginning. Consider the individual who decides: To build an airplane, To build a wood & fabric airplane, To build a wood & fabric airplane designed in 1929, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, and fir spars, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, and wooden struts, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, wooden struts, and a non-A/C engine, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, wooden struts, a non-A/C engine, with a home-made prop, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, wooden struts, a non-A/C engine, a home-made prop, painted with house paint instead of dope, "ad infinitum.." At which point would most builders stop.at which point would you stop? My ex-father-in-law, insurance agent, thought I was nuts to start flying in the first place (age 17)! Am I nuts? Maybe. Nuts about flying. Am I suicidal? Definitely not! I fully respect your opinion about A/C engines if for no other reason than you are vastly more experienced than I. But this project has been a series of path choices for me, and, for some reason, I keep choosing the less-traveled path. In the end, I expect that I will have many, many taxi hours and ground runs of my "crank-breaking" Corvair, not that that will expose any/all problems, but the actual take-off should be a non-event. For me, the choice of using a Corvair was a merely a result of choosing a less-traveled path.having more hp, a smoother less expensive engine, were just fortunate by-products. Meeting William Wynne was a God-send! If you know a risk management expert, please give him my contact info! ..or, are we ALL beyond risk management? Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Wednesday, March 31, 2010 2:49 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale I have a total of $7,000 in my A-65, but that included NEW Millenium Cylinders and pistons, which was $3400 of that total. I also sent the crankcasr out to Divco for overhauling, and the crankshaft and connecting rods were overhauled by Aircraft Specialties. I bought a new camshaft, and new Slick magnetos. I did the overhaul myself, under the supervision of an A&P/IA. I could have done it much cheaper, but I like reliability, which is what started this thread. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Wednesday, March 31, 2010 11:57 AM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale To play devil's advocate: the Corvair project for $6,000 is everything needed to assemble the Wynne based Corvair conversion, all parts reworked, overhauled, or new. How much did you have in your A-65 after the cost of acquisition, rework, new parts, etc? Just curious... ;) Ryan On Tue, Mar 30, 2010 at 8:26 PM, Jack Phillips wrote: I think Bernard liked to experiment. At the time he used that Corvair, it was far cheaper than an aircraft engine. That is no longer the case (the email that started this thread was about a Corvair PROJECT that was for sale for $6,000, which is four times as much as I paid for my Continental A-65, and is nearly half what I've got in the Lycoming O-540 that I'll put in the RV-10). I owned a Corvair for several years (we bought it new in 1966, so it wasn't worn out when we got it, although it was 3 years later) and learned a great deal about the "reliability' of both the engine and the car. I remember that the Corvair was used in one of my machine design classes in college as an example of how NOT to design a belt-drive system. But these airplanes are licensed as "Experimental", so go for it. I just prefer aircraft engines for aircraft, and car engines for cars. The design requirements are totally different. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:50 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale I plan to Jack. I have 12 hours on the fly off now and everything is working great so far. By the way, Are you suggesting that Bernie made a mistake by using the corvair as an alternative engine? Cheers, Gardiner _____ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 8:33:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Does that mean you are going to fly it to Brodhead this year, Gardiner? My low power but utterly reliable Continental has made the trip 3 times now. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto: owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:04 PM Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Well Jack, at least my boat anchor will get me over those high hills west of you. Gardiner _____ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Tue, March 30, 2010 12:21:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Wow! An A65 with only 1505 Total Time? That's pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC http://www.matronics.com/Navigator?P href="http://www.matronics.com/contribution">http://www.matronics.com/co=== ============ http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 31, 2010
I ran into the same problem with the EAA insurance. If you have recent tailwheel time in a similar aircraft and go through the EAA Flight advisor program you can probably get them to insure your first flight. They did for me. Their original quote wanted 5 or 10 hours in type. One other question to be asking.. will you insure a Corvair powered Piet/GN-1? Four years ago neither Avemco nor the EAA would. Thats one of the reasons I ended up with a Continental. Ben Charvet On 3/31/2010 4:04 PM, coxwelljon wrote: > --> Pietenpol-List message posted by: "coxwelljon" > > > I asked the question about liability insurance and that is where things get sticky for tail draggers. They not only want tailwheel time which is understandable, but want some time in the same model. I have 100 hours of tail wheel and 1700 hours total, but none in a GN-1 or a Piet. The EAA insurance agent told me I should be thinking about getting some more tail wheel time and try real hard to get GN-1 time before my airplane is ready to fly. This is just a heads up. Thanks Dan for raising this question. > > Jon Coxwell > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292561#292561 > > ________________________________________________________________________________
Subject: Re: Corvair vs. Continental - long
Date: Mar 31, 2010
I kind of lost the point,,,what is your point? walt evans NX140DL ----- Original Message ----- From: Gary Boothe To: pietenpol-list(at)matronics.com Sent: Wednesday, March 31, 2010 7:52 PM Subject: Pietenpol-List: Corvair vs. Continental - long Jack (et al), Here is my debate: You, and others, have said things that have caused me to pause and consider my decisions, and sometimes change my path. As always, you are the epitome of common sense and good judgment..or are you? I know that you know spam can drivers that look at you in your little home-made airplane (exquisite as it is, even with its "reliable" engine) and say, if not to you at least to themselves, "I would/could never do that." "You're going to fly it where? To Brodhead?" Or, how about the guys who say flying a taildragger is too dangerous! And all of those spam can drivers know ground pounders who say, "You're a pilot? You fly a Cessna/Piper/Beech? Isn't that scary? I could never do that!" The great mathematician, Augusta De Morgan, said: "Great fleas have little fleas upon their backs to bite 'em, And little fleas have lesser fleas, and so ad infinitum. And the great fleas themselves, in turn, have greater fleas to go on, While these again have greater still, and greater still, and so on." So, everyone has their limits. When we make the decision to build an experimental airplane, we set ourselves on a less traveled path.but that's just the beginning. Consider the individual who decides: To build an airplane, To build a wood & fabric airplane, To build a wood & fabric airplane designed in 1929, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, and fir spars, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, and wooden struts, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, wooden struts, and a non-A/C engine, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, wooden struts, a non-A/C engine, with a home-made prop, To build a wood & fabric airplane, designed in 1929, with Poplar instead of A/C Spruce, with fir spars, wooden struts, a non-A/C engine, a home-made prop, painted with house paint instead of dope, "ad infinitum.." At which point would most builders stop.at which point would you stop? My ex-father-in-law, insurance agent, thought I was nuts to start flying in the first place (age 17)! Am I nuts? Maybe. Nuts about flying. Am I suicidal? Definitely not! I fully respect your opinion about A/C engines if for no other reason than you are vastly more experienced than I. But this project has been a series of path choices for me, and, for some reason, I keep choosing the less-traveled path. In the end, I expect that I will have many, many taxi hours and ground runs of my "crank-breaking" Corvair, not that that will expose any/all problems, but the actual take-off should be a non-event. For me, the choice of using a Corvair was a merely a result of choosing a less-traveled path.having more hp, a smoother less expensive engine, were just fortunate by-products. Meeting William Wynne was a God-send! If you know a risk management expert, please give him my contact info! ..or, are we ALL beyond risk management? Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Wednesday, March 31, 2010 2:49 PM To: pietenpol-list(at)matronics.com Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale I have a total of $7,000 in my A-65, but that included NEW Millenium Cylinders and pistons, which was $3400 of that total. I also sent the crankcasr out to Divco for overhauling, and the crankshaft and connecting rods were overhauled by Aircraft Specialties. I bought a new camshaft, and new Slick magnetos. I did the overhaul myself, under the supervision of an A&P/IA. I could have done it much cheaper, but I like reliability, which is what started this thread. Jack Phillips NX899JP Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Wednesday, March 31, 2010 11:57 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale To play devil's advocate: the Corvair project for $6,000 is everything needed to assemble the Wynne based Corvair conversion, all parts reworked, overhauled, or new. How much did you have in your A-65 after the cost of acquisition, rework, new parts, etc? Just curious... ;) Ryan On Tue, Mar 30, 2010 at 8:26 PM, Jack Phillips wrote: I think Bernard liked to experiment. At the time he used that Corvair, it was far cheaper than an aircraft engine. That is no longer the case (the email that started this thread was about a Corvair PROJECT that was for sale for $6,000, which is four times as much as I paid for my Continental A-65, and is nearly half what I've got in the Lycoming O-540 that I'll put in the RV-10). I owned a Corvair for several years (we bought it new in 1966, so it wasn't worn out when we got it, although it was 3 years later) and learned a great deal about the "reliability' of both the engine and the car. I remember that the Corvair was used in one of my machine design classes in college as an example of how NOT to design a belt-drive system. But these airplanes are licensed as "Experimental", so go for it. I just prefer aircraft engines for aircraft, and car engines for cars. The design requirements are totally different. Jack Phillips NX899JP Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:50 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale I plan to Jack. I have 12 hours on the fly off now and everything is working great so far. By the way, Are you suggesting that Bernie made a mistake by using the corvair as an alternative engine? Cheers, Gardiner ------------------------------------------------------------------------- ----- From: Jack Phillips <pietflyr(at)bellsouth.net> To: pietenpol-list(at)matronics.com Sent: Tue, March 30, 2010 8:33:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Does that mean you are going to fly it to Brodhead this year, Gardiner? My low power but utterly reliable Continental has made the trip 3 times now. Jack Phillips NX899JP Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto: owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion Sent: Tuesday, March 30, 2010 8:04 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale Well Jack, at least my boat anchor will get me over those high hills west of you. Gardiner ------------------------------------------------------------------------- ----- From: Jack Phillips <pietflyr(at)bellsouth.net> To: pietenpol-list(at)matronics.com Sent: Tue, March 30, 2010 12:21:01 PM Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale Wow! An A65 with only 1505 Total Time? That's pretty incredible. So having sold that Chevrolet boat-anchor you now have some funds available to purchase a flying Pietenpol? Congratulations, Ryan! Jack Phillips NX899JP Raleigh, NC http://www.matronics.com/Navigator?P href="http://www.matronics.com/contribution">http://www.matronics.com/c o================= http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.comhttp://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com_blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 31, 2010
How much to do the same with an O-200? (To compare apples to apples) rick On Wed, Mar 31, 2010 at 3:49 PM, Jack Phillips wrote: > I have a total of $7,000 in my A-65, but that included NEW Millenium > Cylinders and pistons, which was $3400 of that total. I also sent the > crankcasr out to Divco for overhauling, and the crankshaft and connecting > rods were overhauled by Aircraft Specialties. I bought a new camshaft, and > new Slick magnetos. I did the overhaul myself, under the supervision of an > A&P/IA. I could have done it much cheaper, but I like reliability, which is > what started this thread. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller > Sent: Wednesday, March 31, 2010 11:57 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale > > > To play devil's advocate: the Corvair project for $6,000 is everything > needed to assemble the Wynne based Corvair conversion, all parts reworked, > overhauled, or new. How much did you have in your A-65 after the cost of > acquisition, rework, new parts, etc? Just curious... ;) > > > Ryan > > On Tue, Mar 30, 2010 at 8:26 PM, Jack Phillips > wrote: > > I think Bernard liked to experiment. At the time he used that Corvair, it > was far cheaper than an aircraft engine. That is no longer the case (the > email that started this thread was about a Corvair PROJECT that was for sale > for $6,000, which is four times as much as I paid for my Continental A-65, > and is nearly half what Ive got in the Lycoming O-540 that Ill put in the > RV-10). I owned a Corvair for several years (we bought it new in 1966, so > it wasnt worn out when we got it, although it was 3 years later) and > learned a great deal about the reliability of both the engine and the > car. I remember that the Corvair was used in one of my machine design > classes in college as an example of how NOT to design a belt-drive system. > > > But these airplanes are licensed as Experimental, so go for it. I just > prefer aircraft engines for aircraft, and car engines for cars. The design > requirements are totally different. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion > Sent: Tuesday, March 30, 2010 8:50 PM > > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale > > > I plan to Jack. I have 12 hours on the fly off now and everything is working > great so far. By the way, Are you suggesting that Bernie made a mistake by > using the corvair as an alternative engine? Cheers, Gardiner > > > ________________________________ > > From: Jack Phillips <pietflyr(at)bellsouth.net> > To: pietenpol-list(at)matronics.com > Sent: Tue, March 30, 2010 8:33:01 PM > Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale > > Does that mean you are going to fly it to Brodhead this year, Gardiner? My > low power but utterly reliable Continental has made the trip 3 times now. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion > Sent: Tuesday, March 30, 2010 8:04 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale > > > Well Jack, at least my boat anchor will get me over those high hills west of > you. Gardiner > > > ________________________________ > > From: Jack Phillips <pietflyr(at)bellsouth.net> > To: pietenpol-list(at)matronics.com > Sent: Tue, March 30, 2010 12:21:01 PM > Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale > > Wow! An A65 with only 1505 Total Time? Thats pretty incredible. > > > So having sold that Chevrolet boat-anchor you now have some funds available > to purchase a flying Pietenpol? Congratulations, Ryan! > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > http://www.matronics.com/Navigator?P > href="http://www.matronics.com/contribution">http://www.matronics.com/co================ > > > http://www.matronics.com/Navigator?Pietenpol-List > > > http://forums.matronics.com > > http://www.matronics.com/contribution > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > > > tp://forums.matronics.com > > _blank">http://www.matronics.com/contribution > > > http://www.matronics.com/Navigator?Pietenpol-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 31, 2010
Raymond: that's the C-series Continentals, not the A-series. The C-series have a longer stroke and different cases, thus the ability to fit a starter and other accessories to them as compared with the A-series, which are rare as hen's teeth with anything in the way of accessory drives from the factory. The -8 configuration is most common in "our" small Continentals on these airplanes, whereas the later C-series have many more common configurations with starters, generators, vacuum pumps, and other stuff. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292592#292592 ________________________________________________________________________________
Date: Apr 01, 2010
The point being - everyone has their own level of accep tance of what is "reliable." I wish to re-iterate that Jack, Mike C, William Wynne a nd others have helped me to balance my frugal approach to building with an overall view of practicality and safe ty. Gary Sent from my Verizon Wireless BlackBerry -----Original Message----- From: "walt" <waltdak(at)verizon.net> Date: Wed, 31 Mar 2010 20:55:00 Subject: Re: Pietenpol-List: Corvair vs. Continental - long This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Mar 31, 2010
Subject: Re: William Wynne Corvair conversion parts for sale
Here is an O-200 ready to fly on the Cessna newsgroup for $16000, can build 3 Corvairs for that price. >>>>>>>>>>>>>>>>>>>>>>>>> Re: Engine CONTINENTAL O-200-A Have O-200A All new internal parts, cylinders,mags, etc etc, no expense spared 0 SMOH Asking $16,000 obo >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Mar 31, 2010 at 3:49 PM, Jack Phillips wrote: > I have a total of $7,000 in my A-65, but that included NEW Millenium > Cylinders and pistons, which was $3400 of that total. I also sent the > crankcasr out to Divco for overhauling, and the crankshaft and connecting > rods were overhauled by Aircraft Specialties. I bought a new camshaft, and > new Slick magnetos. I did the overhaul myself, under the supervision of an > A&P/IA. I could have done it much cheaper, but I like reliability, which is > what started this thread. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller > Sent: Wednesday, March 31, 2010 11:57 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale > > > To play devil's advocate: the Corvair project for $6,000 is everything > needed to assemble the Wynne based Corvair conversion, all parts reworked, > overhauled, or new. How much did you have in your A-65 after the cost of > acquisition, rework, new parts, etc? Just curious... ;) > > > Ryan > > On Tue, Mar 30, 2010 at 8:26 PM, Jack Phillips > wrote: > > I think Bernard liked to experiment. At the time he used that Corvair, it > was far cheaper than an aircraft engine. That is no longer the case (the > email that started this thread was about a Corvair PROJECT that was for sale > for $6,000, which is four times as much as I paid for my Continental A-65, > and is nearly half what Ive got in the Lycoming O-540 that Ill put in the > RV-10). I owned a Corvair for several years (we bought it new in 1966, so > it wasnt worn out when we got it, although it was 3 years later) and > learned a great deal about the reliability of both the engine and the > car. I remember that the Corvair was used in one of my machine design > classes in college as an example of how NOT to design a belt-drive system. > > > But these airplanes are licensed as Experimental, so go for it. I just > prefer aircraft engines for aircraft, and car engines for cars. The design > requirements are totally different. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion > Sent: Tuesday, March 30, 2010 8:50 PM > > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale > > > I plan to Jack. I have 12 hours on the fly off now and everything is working > great so far. By the way, Are you suggesting that Bernie made a mistake by > using the corvair as an alternative engine? Cheers, Gardiner > > > ________________________________ > > From: Jack Phillips <pietflyr(at)bellsouth.net> > To: pietenpol-list(at)matronics.com > Sent: Tue, March 30, 2010 8:33:01 PM > Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale > > Does that mean you are going to fly it to Brodhead this year, Gardiner? My > low power but utterly reliable Continental has made the trip 3 times now. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com ] On Behalf Of airlion > Sent: Tuesday, March 30, 2010 8:04 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: William Wynne Corvair conversion parts for sale > > > Well Jack, at least my boat anchor will get me over those high hills west of > you. Gardiner > > > ________________________________ > > From: Jack Phillips <pietflyr(at)bellsouth.net> > To: pietenpol-list(at)matronics.com > Sent: Tue, March 30, 2010 12:21:01 PM > Subject: RE: Pietenpol-List: William Wynne Corvair conversion parts for sale > > Wow! An A65 with only 1505 Total Time? Thats pretty incredible. > > > So having sold that Chevrolet boat-anchor you now have some funds available > to purchase a flying Pietenpol? Congratulations, Ryan! > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > http://www.matronics.com/Navigator?P > href="http://www.matronics.com/contribution">http://www.matronics.com/co================ > > > http://www.matronics.com/Navigator?Pietenpol-List > > > http://forums.matronics.com > > http://www.matronics.com/contribution > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > > > tp://forums.matronics.com > > _blank">http://www.matronics.com/contribution > > > http://www.matronics.com/Navigator?Pietenpol-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Mar 31, 2010
Might as well toss in my two cents here since I just spent at least as much as Jack did to bring a core A75 to essentially zero time, and to my mind "factory new" specs. I also have a Corvair engine on my workbench, slowly getting built up to power a future Piet-like project. I've spent probably a couple of thousand $$ on the Corvair and will spend maybe another couple on it before it runs, so in the end I'll have just about as much money in one as in the other. The Corvair is about 20 years newer than the Continental and will develop 25% more takeoff power for the same dollars. I can buy common overhaul parts for the Corvair several blocks from my house at any one of a number of auto parts houses, but I can't say the same for my Continental. I'm lucky, living in a very strong military town where there is an active aircraft community, that I can actually buy AN hardware and aircraft parts in town but I cannot go to AutoZone and buy a set of valve springs, rockers, piston rings, bearings, spark plugs, plug wires, or other common parts for the A75. I can't order them there and nobody would know what they are. Granted, I have never had the need to do this but it's nice to know I can find common parts for the Corvair from Bar Harbor to Brownsville, San Francisco to Ft. Myers, and auto repair shops can work on many aspects of them whereas I would NEVER take ANY part of my Continental engine to an auto repair shop. The Corvair is a more modern engine than the Continental in the way it was designed, the ignition, the type of fuel it is designed to burn, the operating RPM, the metallurgy. It is very tolerant of high temperatures and insufficient care and will very likely keep the airplane flying with one or maybe even two cylinders dead. When it's together and running as designed, it is inherently a very smooth and powerful engine and tends to operate without the cooling problems that are prevalent in many other auto engine conversions. It has successfully flown in many airframes, fast and slow, over a very good period of years. I like the Corvair but I fly behind a Continental. Why? Because I needed to fly more than I wanted to spend another few years tinkering. In effect I have the best of both worlds... I fly my Continental-powered Piet while building up and tinkering with the Corvair. One of these days, I might just take to the air in some sort of Corvair-powered Pietenpol offspring. Admittedly, I am more of a builder than I am a flyer, although I like both. I just can't imagine bolting together a kit, registering it, going out and flying, and never spending any time in the shop working on an airplane or engine. Not to seem trite here, but "it's all good" and there are no one-size-fits-all engines in experimental aviation. Less filling, more taste- bring on the next round. And finally... as with women, so with engines. All have their endearing traits and any of them can leave you confused, angry, and hurt but on a good day, they are oh-so-sweet, all of them! -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=292601#292601 ________________________________________________________________________________
Date: Mar 31, 2010
Yeah, my frugal nature needs balancing, too. One time when discussing how to fix something on the Piet, after trying to get the correct and acceptable method through my head after a dozen attempts, my friend and local A&P finally blurted out in exasperation, "Jeff, at what point does a sense of self-preservation kick in for you?!" >The point being - everyone has their own level of acceptance of what >is "reliable." > >I wish to re-iterate that Jack, Mike C, William Wynne and others >have helped me to balance my frugal approach to building with an >overall view of practicality and safety. > >Gary -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
From: "Perry Rhoads" <prhoads61(at)frontiernet.net>
Date: Mar 31, 2010
You can buy insurance to cover your project while under construction. Start with the EAA program and research it from there. Keep in mind your homeowners policy was never meant to cover anything but your home and contents. Your premium is based on just that exposure. Cars, boats, motorcycles, and yes airplanes are not part of the contract. All of those require separate coverage that is tailored to the exposure. Perry Rhoads(yup, I'm an insurance agent) Piet N12939 ----- Original Message ----- From: "coxwelljon" <coxwelljon(at)frontiernet.net> Sent: Wednesday, March 31, 2010 12:57 PM Subject: Pietenpol-List: Re: Insurance question > > > > dan.loegering(at)odayequi wrote: >> Ran into an odd situation recently and wanted to see what others have >> done in the past, or are currently doing. >> >> I recently sold my house and am renting now, so I switched to a renters >> insurance policy. Since I was bored last night (the plane is still in >> storage for another week) I was reading through the policy, and came >> across the statement that "aircraft and aircraft parts are not covered." >> Huh? >> >> Spoke to my agent today and he had never come across this either, did >> some research and they do not cover aircraft or parts on ANY of their >> policies. >> >> So my question is this - what, if anything, did you do to provide >> coverage for your projects while they were in the project stage? I am >> simply looking to cover my costs of materials in the event of theft, >> fire, etc... Is this something that I should not worry about (I am >> normally a trusting individual, but the new house is close to a high >> school and the garage is located in the alley - apparently there have >> been issues in the past with some of the garages being used as gathering >> places by the students) One neighbor suggested blocking the windows and >> getting a bigger lock... I may not go to that extreme (it isn't THAT bad >> of a neighborhood...) but I will definitely be putting in a new lock. >> >> It will be nice to get back to building though - time to make more >> sawdust and grind some metal! >> >> Dan Loegering >> Fargo, ND > > > Dan, > > I would check into a special policy. Your greatest risk may not be from > vandalism. I had a good friend who lived in a great timber frame house, > attached workshop, and totally off the grid. He was building an Rans > from a kit. They called for forming the tank by filling it full of fuel > and letting sit and take shape. The tank was closed yet fumes leaked > across the floor to a heater on the other side of the shop. The whole > thing went up including the house and was a total loss. Fortunately there > was no loss of human life. Insurance paid nothing on the airplane and > would not even cover a PV array because it was next to the house and not > attached exept by wiring. Rans gave him a good deal on a new kit but the > fire took several years out of his life while he rebuilt his house. He is > now starting again on the Rans. It has made me think both about insurance > and what I do in the shop. > > Jon Coxwell > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=292548#292548 > > > ________________________________________________________________________________
Date: Mar 31, 2010
Try Jenny at NationAir(they have a website) in St. Louis. I insured N12939 with her for a reasonable amount without time in type, nor any dual required. The only requirement was one hour of solo Piet time before taking passengers. Perry Rhoads Piet N12939 ----- Original Message ----- From: "Ben Charvet" <bcharvet(at)bellsouth.net> Sent: Wednesday, March 31, 2010 7:09 PM Subject: Re: Pietenpol-List: Re: Insurance question > > I ran into the same problem with the EAA insurance. If you have recent > tailwheel time in a similar aircraft and go through the EAA Flight advisor > program you can probably get them to insure your first flight. They did > for me. Their original quote wanted 5 or 10 hours in type. One other > question to be asking.. will you insure a Corvair powered Piet/GN-1? Four > years ago neither Avemco nor the EAA would. Thats one of the reasons I > ended up with a Continental. > > Ben Charvet > > > On 3/31/2010 4:04 PM, coxwelljon wrote: >> --> Pietenpol-List message posted by: >> "coxwelljon" >> >> >> I asked the question about liability insurance and that is where things >> get sticky for tail draggers. They not only want tailwheel time which is >> understandable, but want some time in the same model. I have 100 hours >> of tail wheel and 1700 hours total, but none in a GN-1 or a Piet. The >> EAA insurance agent told me I should be thinking about getting some more >> tail wheel time and try real hard to get GN-1 time before my airplane is >> ready to fly. This is just a heads up. Thanks Dan for raising this >> question. >> >> Jon Coxwell >> >> -------- >> Jon Coxwell >> GN-1 Builder >> Recycle and preserve the planet >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=292561#292561 >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 31, 2010
Only if you plan on sitting in a lawn chair under a bunch of helium filled weather baloons with a BB gun to shoot them out one at a time for landing purposes! :-) http://www.markbarry.com/lawnchairman.html are we ALL beyond risk management? Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done ________________________________________________________________________________
Date: Apr 01, 2010
Subject: Supersonic Piet?
Dear List members, After years of lurking I am ready to begin building! The problem has always been the choice of engine, but now I have it! At the Air Museum there is an old engine from a Mirage 3!!! Last night I pored over my copies from a friend's Flying and Gliding manual, and with some napkins from KFC roughed out the design. Obviously it was meant to be. Of course a few little tweaks will be needed, but after all spruce is a form of carbon fibre. The wing root gaps will prevent spanwise shock waves at mach 1, and if the wings are swept a little, say 45 degrees, she should remain stable up to the thermal thicket at Mach 3. The first stage conpressor will allow pressurisation of the cockpit, and only two questions remain: How to route the tailwheel cables around the tailpipe, and what landing gear to use? I like the Jenny style, but maybe I should consider the new monowheel undercarriage as proposed by some of the engineers on the list recently? Perhaps tomorrow it will look different.... Happy first of April! Coen van WYk ________________________________________________________________________________
Subject: Re: electronic tach
Date: Apr 01, 2010
Electronic tachs are way too modern for a Pietenpol. They should not even be discussed on this list. (OK, I'm bracing for the shelling) I bought a 4" Jones Tach (1918) on Ebay. Tested it and found a 200 rpm error. Sent it to be rebuilt and it got sent back with a big HAZMAT sticker in it. Th ey said they could not open the case on account of it had radium painted dial and markings. So I contacted Bob's Speedometer Shop in Michigan, and he made me a custom gearbox that eliminated the error. Made the wrong rat io the first time and had to have it made twice. Then had to pay him to sh orten my newly purchased tach cable. This whole escapade cost me about $90 0.00 before it was all over. Not too funny comedy of errors. Great looking result, but way too expensive. The price for being a purist. One of those deals that starts to go bad and you just keep going instead of trying something else. Dan Helsper Poplar Grove, IL. NX929DH -----Original Message----- From: shad bell <aviatorbell(at)yahoo.com> Sent: Wed, Mar 31, 2010 11:25 am Subject: Re: Pietenpol-List: electronic tach The westach is the tach on NX92GB. The one we use has the tach generator. The nly problem I have seen with it is it is inacurate, when compared to a tim ing ight/ tach (snap on brand). The higher the rpm's the more inacurate it is . We ndicate 3100rpm static, which the timing light reads about 2750-2800 rpm. the estach is consistant just not accurate, in our case anyhow. I don't know if thers have this problem or not. We replaced the tah generator once, and it eemed a little more accurate for the 1st few hrs, but then read higher rpm 's as ime went by. I am not sure if there are any adjustments on the tach gauge or ot. On another note, I am missing out on the best flying weather in the pa st -5 months, due to a bad back, I look like a question mark. ??? I need to get ealed up and back to work, and get started on some fly-in planning for our ittle Ohio Piet fly-in here in June. Shad ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Apr 01, 2010
Subject: Re: used, good condition A-65 starter for sale.
I worked the line for the local EAA chapter in Illinois a few times. I was one of the ones who knew how to hand-prop, so I was kept a lot busier than some of the others. A guy would show up with his A-65/J-3 with no impulse couplings, and he seemed to flood it frequently. Nothing like standing on a hot ramp in the blazing sun trying to get him going. I needed the exercise anyhow, but geeze. JIm Ash -----Original Message----- >From: taildrags <taildrags(at)hotmail.com> >Sent: Mar 31, 2010 1:14 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: used, good condition A-65 starter for sale. > > >Mikee- > >In some jurisdictions, what you posted about being "for sale" would be considered as "solicitation" and you would be arrested by the vice squad ;o) > >I remember when I first got 41CC and there were some issues with the ignition harnesses. I was at work, Charlie was at the hangar attempting to start the engine and called me on the phone with the news that "the airplane needs a new starter". For a minute all I saw were dollar signs until the joke clicked in my head. Ever since I replaced the lower harness and all the plugs on the 65, it has started quite readily except when it's hot and I flood the thing. I like to hand-prop and I like the simplicity of no electrics. To me, it enhances the open cockpit experience. > >The 75 that is now on the airplane is even easier to start, what with dual impulse mags. > >-------- >Oscar Zuniga >San Antonio, TX >Air Camper NX41CC > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=292534#292534 > > ________________________________________________________________________________
Date: Apr 01, 2010
Well said Gary! I especially liked the poem as there is just something about flying and poetry that compliment each other. However, since you so eloquently quoted a great mathematician, here is a quotation from another relatively well known math guy - Albert Einstein - that you might appreciate. "Great spirits have always found violent opposition from mediocrities. The latter cannot understand it when a man does not thoughtlessly submit to hereditary prejudices but honestly and courageously uses his intelligenc e." Please, don't anybody on the list get the idea that I am attacking anyone who has previously commented on this string! I have learned virtually everything I know about Piets and their engines, etc. from comments made on this list and I value it highly. A good-natured argument is frequently the best way to turn up bits of knowledge that we all need to hear. Stinemetze N328X ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Apr 01, 2010
Subject: bad news, left wing damage
Have some bad news about my Piet. That replica flying bicycle I built ala the one at Old Rhinebeck that I had suspended over my Piet with a good rope let loose sometime in the past two weeks sinc e I was at the hangar and it destroyed the left wing and cracked the rear spar just outside of the lift struts. Loo ks like I'll be sitting on the sidelines watching everyone else fly this summer. Oh well, stuff happens. Mikee ________________________________________________________________________________
Date: Apr 01, 2010
Subject: Re: bad news, left wing damage
Mike, So sorry to hear bout your damage. I am hoping you can make a hasty repair that is safe and get the Michael Cuy pilgrimage to Brodhead , the smoke approach is always a crowd pleaser and an anticipated event. I expect to be in Cinci within the next 2 weeks on business and can make the drive to lend a hand if you're interested, just let me know on that of f list and we can work out details. John In a message dated 4/1/2010 10:14:26 A.M. Eastern Daylight Time, michael.d.cuy(at)nasa.gov writes: Have some bad news about my Piet. That replica flying bicycle I built ala the one at Old Rhinebeck that I had suspended over my Piet with a good rope let loose sometime in the past two weeks since I was at the hangar and it destroyed the left wing and cracked the rear spar just outside of the lift struts. Looks like I=99ll be sitting on the sidelines watching everyone else fly this summer. Oh well, stuff happens. Mikee ________________________________________________________________________________
Date: Apr 01, 2010
TWlrZWUsDQoNCiANCg0KSSB0aGluayB5b3UgYXJlIHRvbyBzbWFydCBvZiBhIGd1eSB0byBsZXQg c29tZXRoaW5nIGxpa2UgdGhhdCBoYXBwZW7igKYuLm11c3QgYmUgYW4gQXByaWwgIGZvb2zigJlz IGpva2UuICBKDQoNCiANCg0KQnJpYW4NCg0KU0xDLVVUDQoNCiANCg0KRnJvbTogb3duZXItcGll dGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1waWV0ZW5wb2wt bGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIEFNc2FmZXR5Q0Bhb2wuY29t DQpTZW50OiBUaHVyc2RheSwgQXByaWwgMDEsIDIwMTAgODoyOCBBTQ0KVG86IHBpZXRlbnBvbC1s aXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDogYmFkIG5ld3Ms IGxlZnQgd2luZyBkYW1hZ2UgDQoNCiANCg0KTWlrZSwNCg0KIA0KDQpTbyBzb3JyeSB0byBoZWFy IGJvdXQgeW91ciBkYW1hZ2UuIEkgYW0gaG9waW5nIHlvdSBjYW4gbWFrZSBhIGhhc3R5IHJlcGFp ciB0aGF0IGlzIHNhZmUgYW5kIGdldCB0aGUgTWljaGFlbCBDdXkgcGlsZ3JpbWFnZSB0byBCcm9k aGVhZCAsIHRoZSAgc21va2UgYXBwcm9hY2ggaXMgYWx3YXlzIGEgY3Jvd2QgcGxlYXNlciBhbmQg YW4gYW50aWNpcGF0ZWQgZXZlbnQuIA0KDQogDQoNCkkgZXhwZWN0IHRvIGJlIGluIENpbmNpIHdp dGhpbiB0aGUgbmV4dCAyIHdlZWtzIG9uIGJ1c2luZXNzIGFuZCBjYW4gbWFrZSB0aGUgZHJpdmUg dG8gbGVuZCBhIGhhbmQgaWYgeW91J3JlIGludGVyZXN0ZWQsIGp1c3QgbGV0IG1lIGtub3cgb24g dGhhdCBvZmYgbGlzdCBhbmQgd2UgY2FuIHdvcmsgb3V0IGRldGFpbHMuDQoNCiANCg0KSm9obg0K DQogDQoNCkluIGEgbWVzc2FnZSBkYXRlZCA0LzEvMjAxMCAxMDoxNDoyNiBBLk0uIEVhc3Rlcm4g RGF5bGlnaHQgVGltZSwgbWljaGFlbC5kLmN1eUBuYXNhLmdvdiB3cml0ZXM6DQoNCgkgDQoNCglI YXZlIHNvbWUgYmFkIG5ld3MgYWJvdXQgbXkgUGlldC4gICBUaGF0IHJlcGxpY2EgZmx5aW5nIGJp Y3ljbGUgSSBidWlsdCBhbGEgdGhlIG9uZSBhdCBPbGQgUmhpbmViZWNrIHRoYXQgSSBoYWQgc3Vz cGVuZGVkDQoNCglvdmVyIG15IFBpZXQgd2l0aCBhIGdvb2Qgcm9wZSBsZXQgbG9vc2Ugc29tZXRp bWUgaW4gdGhlIHBhc3QgdHdvIHdlZWtzIHNpbmNlIEkgd2FzIGF0IHRoZSBoYW5nYXIgYW5kIGl0 IGRlc3Ryb3llZCB0aGUNCg0KCWxlZnQgd2luZyBhbmQgY3JhY2tlZCB0aGUgcmVhciBzcGFyIGp1 c3Qgb3V0c2lkZSBvZiB0aGUgbGlmdCBzdHJ1dHMuICAgIExvb2tzIGxpa2UgSeKAmWxsIGJlIHNp dHRpbmcgb24gdGhlIHNpZGVsaW5lcyB3YXRjaGluZyBldmVyeW9uZQ0KDQoJZWxzZSBmbHkgdGhp cyBzdW1tZXIuICAgT2ggd2VsbCwgc3R1ZmYgaGFwcGVucy4gDQoNCgkgDQoNCglNaWtlZQ0KDQoJ IA0KDQoJIA0KDQoJDQoNCgkgDQoNCgkNCgkNCgkgDQoNCg= ________________________________________________________________________________
Date: Apr 01, 2010
Sounds like an April fools joke to me. Bryan Green Elgin SC ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] To: pietenpol-list(at)matronics.com Sent: Thursday, April 01, 2010 10:13 AM Subject: Pietenpol-List: bad news, left wing damage Have some bad news about my Piet. That replica flying bicycle I built ala the one at Old Rhinebeck that I had suspended over my Piet with a good rope let loose sometime in the past two weeks since I was at the hangar and it destroyed the left wing and cracked the rear spar just outside of the lift struts. Looks like I'll be sitting on the sidelines watching everyone else fly this summer. Oh well, stuff happens. Mikee ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Apr 01, 2010
Mike, That certainly is bad news! I know how long it takes to build ribs.you may be down 2 or 3 years (at my pace). Hoping for a speedy recovery, Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Thursday, April 01, 2010 7:13 AM Subject: Pietenpol-List: bad news, left wing damage Have some bad news about my Piet. That replica flying bicycle I built ala the one at Old Rhinebeck that I had suspended over my Piet with a good rope let loose sometime in the past two weeks since I was at the hangar and it destroyed the left wing and cracked the rear spar just outside of the lift struts. Looks like I'll be sitting on the sidelines watching everyone else fly this summer. Oh well, stuff happens. Mikee ________________________________________________________________________________
Date: Apr 01, 2010
Subject: ding, ding, ding ! Winner, Winner-- we have a WINNER
!!!!!! QnJpYW4gSmFyZGluZSwgeW91IGFyZSBjb3JyZWN0LiAgICBNeSBwb3N0IHdhcyBqdXN0IGEgc3Bv b2YuICAgIEhhcHB5IEFwcmlsIEZvb2zigJlzIERheSBnZW50cyBidXQgdGhhbmsgeW91IGtpbmRs eQ0KZm9yIHRoZSBzeW1wYXRoaWVzLg0KDQpJIHRoaW5rIEnigJltIGdvaW5nIG91dCB0byB0aGUg aGFuZ2FyIGFueXdheSBqdXN0IHRvIG1ha2Ugc3VyZSB0aGF0IHJvcGUgaXMgc2VjdXJl4pi6DQoN Ck1pa2UgQy4NCg0KUFPigJRub3cgZ28gb3V0IHRoZXJlIGFuZCBqZXJrIHNvbWVib2R54oCZcyBj aGFpbiBiZWZvcmUgdGhpcyBsb25nLXN0YW5kaW5nIEFtZXJpY2FuIHRyYWRpdGlvbiBnb2VzIGRv d24gdGhlIGRyYWluIGxpa2UNCnRoZSByZXN0IG9mIG91ciBjb3VudHJ5ICEhISEhISEhISENCg0K DQoNCg= ________________________________________________________________________________
Date: Apr 01, 2010
Mike, Further thought.I have ribs just hanging in my garage. You would have to check them to see if they match yours, but I would be glad to send them if they would help you get back in the air sooner. With my kitchen remodel, I'm moving somewhat slowly on the Piet. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 18 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Thursday, April 01, 2010 7:13 AM Subject: Pietenpol-List: bad news, left wing damage Have some bad news about my Piet. That replica flying bicycle I built ala the one at Old Rhinebeck that I had suspended over my Piet with a good rope let loose sometime in the past two weeks since I was at the hangar and it destroyed the left wing and cracked the rear spar just outside of the lift struts. Looks like I'll be sitting on the sidelines watching everyone else fly this summer. Oh well, stuff happens. Mikee ________________________________________________________________________________
Date: Apr 01, 2010
Using the light-speed breakaway factor, accessible because I'm using a GE CFM-6 with an aftermarket afterburner, I was able to finish my Piet and fly off the 25 hours simultaneously yesterday. Unfortunately, the factor still applies so I'll be attending Brodhead this year but no one will remember me until 2021, and then everyone will see me in the photos from 1998. This high-speed physics stuff sure makes Einstein relevant. Mike Hardaway _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bryan green Sent: Thursday, April 01, 2010 7:51 AM Sounds like an April fools joke to me. Bryan Green Elgin SC ________________________________________________________________________________
Date: Apr 01, 2010
Mikee: I started to say that this wouldn't have happened if you had a Corvair on there instead of that A-65. However I changed my mind because there just isn't anything funny about a broken Piet! Especially one that has given me so much motivation. Our prayers for your speedy recovery. Stinemetze N328X ________________________________________________________________________________
Date: Apr 01, 2010
Sorry to hear about the wing Mike. My uncovered wings have been hanging ove r both my cars in my garage for a couple years. Have often wondered what my car hoods would look like if the ceiling bolts pulled out. Maybe I will go add a couple redundant ceiling bolts and ropes after hearing about this. rick On Thu, Apr 1, 2010 at 8:50 AM, bryan green wrote: > Sounds like an April fools joke to me. > Bryan Green > Elgin SC > > ----- Original Message ----- > *From:* Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] > *To:* pietenpol-list(at)matronics.com > *Sent:* Thursday, April 01, 2010 10:13 AM > *Subject:* Pietenpol-List: bad news, left wing damage > > > Have some bad news about my Piet. That replica flying bicycle I built > ala the one at Old Rhinebeck that I had suspended > over my Piet with a good rope let loose sometime in the past two weeks > since I was at the hangar and it destroyed the > left wing and cracked the rear spar just outside of the lift struts. > Looks like I=92ll be sitting on the sidelines watching everyone > else fly this summer. Oh well, stuff happens. > > Mikee > > > ------------------------------ > > * > =========== =========== =========== =========== > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Apr 01, 2010
Did the spars on the bicycle crack or the spar on the pietenpol crack. You can fly the bicycle flying machine to the ohio piet fly in if you have to, I to, think this sounds like a Mike Cuy april fools joke. Shad P.S. I really really really hope you're kidding around Mike hate to see a damaged airp;ane, especcially a homebuilt. ________________________________________________________________________________
Date: Apr 01, 2010
Subject: Re: ding, ding, ding ! Winner, Winner-- we have a
WINNER !!!!!! See. Prayer works! >>> "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" 4/1/2010 10:00 AM >>> Brian Jardine, you are correct. My post was just a spoof. Happy April Fools Day gents but thank you kindly for the sympathies. I think Im going out to the hangar anyway just to make sure that rope is secureJ Mike C. PSnow go out there and jerk somebodys chain before this long-standing American tradition goes down the drain like the rest of our country !!!!!!!!!! ________________________________________________________________________________
Date: Apr 01, 2010
Ryan, see waht happens when they use a continental, they are so old that everything around them turns old and rots, in this case the rope. Mike just clip the wings shorter, to where the crack is, put on a 145hp warner, and paint "Mike Cuy's Bug'ger Be gon'er" upside down on the fuselage and do airshows. Mike Cuys Clipped wing Piet. Again I hope this is a joke, Shad ________________________________________________________________________________
Subject: Re: ding, ding, ding ! Winner, Winner-- we have a WINNER
Date: Apr 01, 2010
He's a four-flusher Mary Beth. Not falling for it this year. I bit hook, line and sinker two years ago. John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Apr 1, 2010, at 10:00 AM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > Brian Jardine, you are correct. My post was just a spoof. Happy April Fool=92s Day gents but thank you kindly > for the sympathies. > > I think I=92m going out to the hangar anyway just to make sure that rope is secureJ > > Mike C. > > PS=97now go out there and jerk somebody=92s chain before this long-standing American tradition goes down the drain like > the rest of our country !!!!!!!!!! > > > > ________________________________________________________________________________
Date: Apr 01, 2010
Mike=2C we have never met but I have used your video and your postings repe atedly on our Piet build. Only a fellow builder could share the sorrow you must be experiencing at this time. We are all so sorry for your loss. I h ave admired both your workmanship and your willingness to help us novice bu ilders. Vic N414MV no not archive. From: michael.d.cuy(at)nasa.gov Date: Thu=2C 1 Apr 2010 09:13:23 -0500 Subject: Pietenpol-List: bad news=2C left wing damage Have some bad news about my Piet. That replica flying bicycle I built ala the one at Old Rhinebeck that I had suspended over my Piet with a good rope let loose sometime in the past two weeks sinc e I was at the hangar and it destroyed the left wing and cracked the rear spar just outside of the lift struts. Loo ks like I=92ll be sitting on the sidelines watching everyone else fly this summer. Oh well=2C stuff happens. Mikee _________________________________________________________________ Hotmail: Trusted email with powerful SPAM protection. /9j/4AAQSkZJRgABAQEBLAEsAAD/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQEBQoHBwYIDAoMDAsK CwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUEBQkFBQkUDQsNFBQUFBQU FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBT/wAARCAMABAADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD5H8PW bG2+Zv8AgVdBFZ/7W+s3wxF/xK8bfeugjX/gFfDYiZ9hh4CLEv8AdqVUb/PahV/2qfJDLN92TZ2P vXCd3ITorf7VS5b+81OigaH70n/AvWnRsv8As+u2s/QrlHKrf7XvTlVv9qShVX/ZqV/KpF8gf7u5 O1Du3/stN+2Rf3vp7VC1yv8AeplEdzp8V5/rI1f+KrMUfk/d+Tsab53+zx/dp3mP/cekBYWXyerV Fc3f+i1Eyz/8s42/xqCexuZv+Wbf4VPKMns5fJ+83uPfNTreQf8APT6fWok0eXPy/wD6qlg8ON/z 2XzKJeoDXlx/F9FqI3X91tn+Fa8WkLD95lfsWp0el2038W//AGqkrkMhtSaH+GR+9NXUG/hVv/r1 0S6XZ/8APP8A+v8ASpUsYIf+Wa/7ydqjnDkOYnuZ/wDlnuft+FQSQX3/AE09/auy8tYvur/9c1G0 HnfdVkqufyDkOYWxvJvvbvL61Zg0q5/ibZ/tetbiwSQ/8s/+Bf8A16s21nLNztb/AHU9/wDCnzdk Vy/zHPro0v8Ae9jU8WjNL96ZvTb6V1Nn4c1Cb7tpPN33JH2rRi8FarN/q9NdO/z9/wA61jRq/ZiZ yrUurRyEejQfxSM9O/sm2/us/wDWu9tPhxq833o7aH0WaT+eK0IPhXef8vF/BBH/ANMY34/9Bqo4 TEdjKWLw38x5qtlbfxW6+m5+9TrZrD92Nf8AdSvTLb4RWcP+sv5X/wByPr+dasHwz0iH7xupv9l5 P8K2jl2I7nNLMcP3PG5Ip/8Almv/AH36VG0dz/Ey+n0r3aDwDoMP/Lgr/wC08j1oR+GtItP9Xplj D2/1aV0Ryup9qRlLNKfSJ87R20833m+qp/WrUHhq+1H/AFNjeTemyJ/5+9fR8cEUP+phVPTZU+yX /npsrWOV0/tSZlLN/wCWB8823w1167+7plxD23TbOR+NXrH4L6z/AA2drD/v3P8AUV7dqeoWehWv 2u/mWGP+8/c+wryrxZ8RbvXf9Eslks7Lp/00kHufeorYfDYTdl0cXiMX8MTkdX8MLoV19k+2Wt5J /wAtfs2/93j1aqaJ5P8Aq12erev0p0reV936/JU9ravN/rG2eteFL+6j2o/3mVvm/h/H/wCvUqwN 9l+X5/8Af7VbWCL+GHf6M9CWrTXP2S3he5uPurBD3rIoz1l8r/WSL6t/n2rs/BngXU/F3+rX7Np3 e5f+P/dFXND+EGoTXVrd6zDGkfa19PqfevaLN4NNtfmZYYupf0A/wq2TKYzw74R0/wAMWv8Ao8Kp 6t/y0Y/7TVLrXiC2077zK9x/DAneuKl+Itt4j+1f2Rdb7e3/AHfm+rexrI/tBof9Lkk2d2d+9c8p mUYG5Z6zc67a/a7j5Ps88kflJ/DtrcsdHimtvtckjP32143pGn6hDrtzq0mxPtHytOn8a7v4vpXs fg+6+16Da7v9Z+8Q+1evlk/9p3PPzCH+zGrBZxQ/djX/AHql2/7VOVadt/2fr719ifMkO2k+f+L8 Kn2/3qFjWgCHbUm1v61J8vtTeaCBqrRt/vVIv+9Rt/xqyxv5+tG1vWpHX+9Rs9qgCHy2/wBqnMv+ 9Ttq07y2/wBz/foAjaq1zPHD/rZkh/2nqe5nhh/1ki1yfidf7Rtf3MbT/wCy9BB5d8TNesTdfuZP tPbcn+NeReH9XWbXftcyrDHbz7z/ALq+v4V6N4n8PXf/AC2TZ/ENnr7mvO7PTEs9U+Vl9/8AvnuK 8zGHrYWPY+hYtTttX0v7XaTb7f7qsnf5qordxw6X80j+Z58Z2pH6OvpWH4W8P/Y9L+13TedJ2X/l nEC3Zfatr7d5OhXXl/PJ99VT+IivipQ10Pp0dP8ACyKDWLTXfJV0j+3bfn7kovQV6HDp8UJ+6z15 58B2kvPC+p3c0bpJcXskhV4/T2+leoLF/eb3r7jA/wC7HyWN/wB5GpFinr/wL1p3lrTlb/dr0DiB Ym/2UpxT/a30L1+9/wACp6t/dX/gXrViH/8AkOmf79S7WoWJf72+gZF5ntRscfdqXHtQzUCIPL/v NvpW/wBlakZf96qOpX32P+7/AL1UMzvEDeT/ADr5H+IGoQTamLRpleS4m4T1+avYPirquq3n+puJ /s3Rkh7D3NfOep6RL/btrdyK3l4/WuPEHZh9z3P4J2fk6Xqe1t/7+OLd6hV/+zr0b5f4W9voa5r4 R2ynwd93/j4nkf64/d/+yV1aWsUN1+7jVP8Ac9q+DqH1UDa0GGWG6/0dd8n3S79h7fWt77FJMf38 zP8A7Pp+FZ/hWP8A4+tzf7G30roFiYH5V/4F6V9blcP9mPnMbP8A2kgisYIfuxr/AL3vU69KlWFc fNJ9dlOVl/5Zxj/eevYPMI1jlm+6tSpBz8zLH/s0MzfxN/wGmq/91WemMnVov4Y/+BU5ZZf73/fF CxN/FtT/AH6kVYv4tz/7NUIFP+fWplgkl/hVP9p6Ipf7qqn+5T94/iLPRyECPbRf8tJGfvtSvnr9 oWeCHS7XbGqSedI4b2HrXs/ifxT/AGHpl1dw2T3P2eDzNr/uc49zXxZ8ZviTrnjS6trRo4rO38/Y Irb+6W7sfaoqaI6aG4z4YaD/AGv4n0y0aPf9on8x2/2V/edPpX10v/HrdV4H+zzpX2zXbq7aNvLt 4Nqt6vI3b6BK96vGWG1+99a/P68/9pPsIkvhiJZtdtfMZ/Lt/nGzuxrs2u2/5Zx7P+mj1zXhRfJt bm7/AOfjgN7LWo87zfdVnr67LIf7OfL5hP8A2knnnab/AFkjf7qVAzf3fkoliaL/AFjLD/s+30qL z4P9qb0Z69U84Xc3u/8As0PE38TLD/v/AOFRNqDfwsqf7n9aqNO83+rV3/3O9SWXZJYIv+ek1Qtq Uv8ADth/3P8AGqrRP/y0mjh/2f8A6wqPzbaH7sbTSf3n/oB/jUASee033VZ6x/GF9PpGgXV2zRW0 nZZpP6CrF94geL/WXCQx/wB1PT3FeG/Gf4taVZ6DdWlrdfabn+NIe2PU0FxPGfFl5Pq/ij95Iz/8 tWX/AGjX0J8BdI/sjwxdXcnySahPvDekaf4181+FpZ/Ed1/q2S5uPLRV9M19X6fKukaFa2kPyRfu 4V+gr4zMpX0Pp8LA7K2uWm+7uf8Ag/E+ldCtp5P+vuG91T91/KuI0i+n+0/Iu+T+RNWb7WYrT/j+ vY0k6+Un+t/IV25W6eE3ODHK/wAJ1LalZ6d/qY1TuVTv+NVJdbubz/j3Rkj+9XGSeKGH/HhYt7S3 n/xP/wBeqjNqepf8fl63l/8APJP3MX5CuutmP8pz08D/ADHSahr1naf8fl9vk/54Q/vZfxxWVP4n uZv+PCxEPpLef/Ej/GqVnYrD91Vf/cq9FA+f4U/2a8mpjqnQ9CnhKZTktb7Uf+Qjdyzd/K/5Zg+y ipVsbPTv+ecPYe59hV+KJYvvfU1V1G2g1e1/10iR/wDTGXyd3/AhXFKf8zOuOmyMfxFq+laba/6Z eJbeiv8A4VxDal4p1G5uv7IkS60r92IZHtvK53f3z6V31t4W0Oz+7aJNL95pbn97IfqTU8C/6V9k t4ZH7JBDH1+gFEvZ9jWPtDz2Dwnq+pfZf7Vu0hj6zWtpv+Zvd/lrpLHQdIh/1drBDc9Wk/5ace9e kab8I/EGu/66NNMj7tc/638EFdz4d+Ceg6Rc/v2k1OTrK83+rz7KKmNOo/huVel9o8j03SLvV7n7 JplpPeSf9MY+n1Nd9o/wR1WX/S9avodLt+vlp+9kxXsENoNOtvstgqWcfdoY/wCVLFpC/wAas/fz Ju/4V7FHLKn2zzquOh9n3jivD/w30HSP9RZLeSdDdX376T8F+5XRPpEU33vMfsE9Ppitl4Iv7rTd qjaX+6uz/ZSvao5dTXxHnVMdU+yZ0elQQ/8ALGKHsG/z609lT+6z/wC1Vl4n/ipqWyf7T16sYdjz Jf3ioyN6fglRS2zfxfJWl5Lf7Kf7lee/FXx7feEdCurvSLOK9vfIzG03+rB9wP8AGrjDsSefftO/ EGPwX4OubS3kf+0dQ/cxe2V/oK+Z/gH8MH8aeMf9IjZ9O0//AEi5b+83/LOP8TXMa54w8T/EvxP9 r168a/1G4n8m3tkj/drlvuKg9TX2f8Kvh5F8OvB1taNt+23H7+7l/vSN/gPkr53NsX/zCw+Z9Bgc P/MfnvbRxabbfLuqJNb/ALhrZbS4s/d3+tPWzSH7sf8A9avM5z2/Y9mYa6nL/wA829quQanP/wA8 W/3q0kgS7+7HvqC0xF/rNvpRz+QvY+Y1rq7m/wBXH/8AWpILS+l+8q1tWyr/AA/SrPl+V/Ds/wBr /Cp5n0iV7Kn3MaDTrz/loy+X/nrVxbGX+Jt/9K1LTT7zUf8Aj3hleP8AvJFWrH4K1mb/AJcmTvte RKfsav8AKzOVSl1aMCLT4P4tr1OtnF/zz966yz+Gury/6xorb/Zmk7e2K04vhr/z21CP/tjF2+tX 9TxHY55YvD/zHDskf/2SdqcoU/dWu4/4QTSof9dfSP3K/wDAqlXwxo0P3beR/wDbf1+grT+zqnVk SzHDnCqi/wCz605IH/3+/wBK9BtvDVtN/q7NX/2vX61qWnhaP+KGKH1/z7VrHLv5pGUs0pfZieXw WMv+0/8AHtSr0Gj315/x72Ny/b5Iupr1qDR7aH/lnv8A9+tCKJIfurWscup/aZzyzT+WJ49P4F16 a1/0ew8m4/h86ROfwqtF4M8Q6d/x/ra+u1JP54r2zaKxdeRZrX+VdH1Gn2OX+0ap5Dcztaf8sxVa DxF/xNLXzo1S3+5I3oD6fStHWoOMbdlcnfW7fwr0rmnhKfY3hi6nc9jtvDWnzf6zzX/7afzrXi8N afD92zR+/wA/esXwZqn9r6Da3bfPJ/q5T6svr9a6+3bn5l/2a+WlDuz2pT7GBdaZbRfdt4vfZ/Su v8OTtNpf8KdjsrKazab+H2b61c0u+is9U+yM2z7Ryq/Su/A1f9o9448V/u50Ii837zM/YF6NtPjb 60MyfxN/wFO9fZnzEgVf71CJ/n0pfm/hX/gT07yGm+83/fHekZ2E/wBT95l/3aXd/djZ/wDaenJE v8K0S3UVp/r5khj/ALz+n40CHKjd2WnJEtZa+I4rz/kHWtzqcnQNbRfu/wAXO2otQl1WG1+16lfW Ph237/8ALWT8Pr9GpydviNFd9Dcd1iHzMqerP2/GuR8WfEqx0L/jyVdSveyp/q1/3mrgPFOvQax/ okDXNzH3ub6T94+P7qD5I/yrEVa8HFZh0pntYXL+tX7g1zXNQ125+16lMz3HQL/zzHstZyStF91d /cs/bFXpIPO+9uf+Pb6D3qVIV+y/+zen0FeHz3+I+gjC3wozFiaYf3JOgVP4vpWnZ2+P9d/vbP8A GpIIG/5YxtNcdBEn+sY+wr0bwj8KpdR/0vXVXy+sdr6f75pDOc8MeEdQ8Xf6mPybLobp+/8Au17f 4T8C6f4Xtf3cKfaOsjv/AK1z7mrdnHHZ2v7mNEj+79B7fSm3Nx5v+rVvUu9dFGjUxfwI4K2I7s5r xP4ne7urr7MrJHb/ACGT3FeNeOdevtRtfsklxKlv/wA8vN+99a9h8S2jfZf3fyd/k7mvGfElj/jX u08DTwnxHjSxOpn/AAyuVhurq0/ELXeTu03/AC0WGOvMfCMn2TXf7np716Y7rN96NfdfY/4V8vjo f7QfSYeehq20Cw6X/E/p7113gh2+y3W5f+W+R9CtcrBL/wDWro/Bkv8ApVz+f5VeXz/2k5cZD/Zj rV/3l96Pl9f1oVf/ANmnba++ifJDf++qaq/7X/fFSbaft/26ski2/wCfSnbaX/x/1pzJ/e2pQAx0 xQiZqOW9gh/i3/7NQtqU8v8Aq49n+H0oAu7H/wBz1qCee2h+9JVb7Nczf6yRv92nxabEfvf/AKqB jJdVb/ljD/wJ/T6VH5V3d/eZkrQWCKH7q/8AAqV//wBVAFCLSF/5aN7/AOTU62kcP+rjX3b1qZt3 92myL/eagDyD4l/8fX/s1eLW377Xrb8vn75r2r4gwLDdf368XiXyfFFttVf9fGfyavJxmx62DPYd K0STQtCurS5mWa48+SZtnbe33Bn0FXvD8SzWv2Ro1ePtHVzUv3v2r5veqehT+TdfNIv98/QV8XU3 PpaZ6L4MiWG0ufJ2p+/5VOx210i/7Vcp4A1KDV7TU/JZ0jt73yvn7/KvQV1iqv8Av/7VfbYH/dz5 HG/7yC/5WpVib+L5KRHxQj4r0zhJPKX+L5+1OVv7tNRW/u0NLFD/AKyT/gNMkc/enKj/AN2q/wDa H/PONvT61E6XM33m2f7lUWWJZY4fvMtQtqC/8sY2ftQtkv8AFuf/AGqlWNf4V+lAFN2uZv4tn+5/ iajbSIv+Wjb/APfrSb/gVNaKT+tAHDeNVgtNMutsK18vay6za78u3+/t9K+ivinI0Ol/65vdU718 6wRLNr118u/tu9hXmYyeh6eDgfQvw8gitPB2mbf+eG//AL6Zq31//VWP4T0WTTtL+yed7x+d/D/s D/YFaNpFJ9l/0iRXuejMkfVvYV8LPc+nOw8MOf7L+VV/wrX3f3m/+tWfo1s0OmWu5l/v/XNaCov8 K7/9+vvcJD/Zj5DET/2kFb+7uepVgb+JlT/apis1OVf7qs9dpyAqRf7T1J5zf7lN8hof9Yyw/wC0 9OWeD+FZLn/aqwFVmm/vPVlLaX+LbDH3Z6qveT/wtHbdtqf41G0q/wAW6b/aegC959tD/FJc/wCz D/jQ13P/AMs1ito/71UWum/vbP8AcpiLJN/q42f/AGv8TRzk8hi+Lra0mtftd00k0nbfXx745uba 8126+ywrDH58kgVOwHpX0x8XNTn07Qrry7iKGToq+u70r5QCtd6pdfNv/wCWas/bC1w4yf8Asx6u BgfRHwF0X7J4O+1t8n9oT7x/urXoeoSRQ/d+eT7h9hWH4O03+zdC0y0/594I93+9t/xrVbdqWqW1 pGrP9on+6neviY6s+knsdTp7QWmmW37l3k6nf6n0HtRPqEn97ZH/AHU/rUUsCw/664VP9lKjaaCH /Vw75OzTf4V+gUoWSPjJyu9RiyNN/qVZ/wDc/rQyZ/10yp/s1UvNZWH/AF1wvtEn9FFU0uZ5v9Tb snbdN/8AE1oZmq80EP3Y2f8A2pv8KqX2srD/AK64WH/pknf6KKrf2VPL/wAfVzJ5f9xP3X8v8aie 40jSP+WiJJ3WH+tR6sAe9nm/497Vk/25v6L/APWobSbmb/j6um/3E/dRD/2f9aoz+LG/5crXZ3Be sLVdcb/l+v1g/wCmSen0Fc9TE00XGjUNnV4tKhtfskjJ7qn9f/118j/FX7HZ6pdWlmrPH03ehr3P VfEsH/HpZWzTSf35v8K4mD4dW2r3X2u/ja5k+/8AP2z7e1ebUzCn3PYw+BqfaOG+FU9np2qWt3Or vHb/ADRRQx+duc+ij0317V/ams67/wAedpHZ23RZbn/4kf41LonhO003/VW6JW9P/odr/wBM/vHZ 2A9BXy9adz3Y7aBp+n3f2X/Sr+eb+NlT91k+4HpWhDaQQn5VWsWLxdbfZftcayvH1X92/OW9DWjY 6vFN91leTr9M1jzkSgaa2p/+yo8r/L1Etz/tf7P0psGoQTXXzTIlz18t/wCgpkln5cfeb0+T1qz5 q/3W/wAa1NB8Favrv/HpYSJH2nm/dR/hn/Cu50v4LQAf8TXUWm9YLT91Gfqx/wAK1jBhseY+Y03+ rX950VPU+wrf0j4f+INd/wBXZPbW/Uy3P7rH0X/61e06R4e0bw5a/wChWEEP8JdP9Yfqx9a8Y/aY +OWpeANC/snw7P8AY9VuP3ccsUf+qX2J/wAK9Knl1S17HJLEU/ss34Phxofhy2+1+JNVitrbu8sn lRt9M13mlSaNpFr/AMSqwSGPrvSP731Jr46+CXhq+8f+O7W71u8udWj0/wD0y4nvpHm3P/yzTLt3 NfW0jND91f8A65rzZLodvQ29IS51e6+1ttS26fUn1rc8uCH+Lf8A7Kf41BpWntZ2vyr7s3uas7V7 tv8A9lP8a+1wOG+q4c+WxVYY8v8AzzVYf9z/ABqJomz/AOzPVjdz+7j2f7VRXMqw/wDHxMqd/r9K 9M4xrRJ/Exf/AGUo2ufuov8An3qs2pJN/wAetvJP/tvSPBcXf+um2esaUcvcgfNPBB/rJF/3U71A buSb/j3h2f7T1attNih+6iv/AFq28H97an+fSrAxJ7Fpv+PmRn/2fWvnD9qz4mReHNC/4R7TJkTV dQ/1rJ/yyi9z719D+MNetPDug3V5dN+7t4JHZ37Ae1fnTrOqah8VviLc3cMO+51Cfybdf+eabv4v oPnqK1b6phtX6HdhaNz0f9mL4arq+u/8JDdw79O0/wCS3V/45z6f7te7fF7x5bfDTwJqerTMpuP9 RZxf35j/AIffrX8FeFYvC3hi18PaUqf6PBiSd/X++frXxJ+1H8WJfHXjH7JZ3HnaVp/mW9vs/wCW rbv3kn4mvh6EPrmJvI+iqz+qGb4U0hPEVr9rkbye231roIPBFp/FJK/+16U7wRafY9CtT/y08+Ri vuG/pXSxR/3V/wCBV9LHD0/sxR4tTHYj+YxV8EaR/DC6SdPMSTp9KbF8NdE/iW4f+EnzOp966Pyv J+9JsqX7ZFD/ALf+09bclPscv1mr/MzMsfBGjWn+rtWfv88j/pW1ZeH7G0/1NnAn+2/c/U1TfXli +62//c9frUDarPL91dlO3ZGMq1Tq2dB5kUP95/8AcqOTV4IT8u3/AIB/jWNHY3d394t/vPWlbeHk /wCW0jf7qelaE8pBJrLfwxr7b6akV5d/d8x4/wC7W3BYwQ/djqyq/wCfSsyDJtPD7H/WMvuqd60I NKtof+We/wD2nqzE2Kl+b2/u0ACr/dWnJ/wH/d9Kbu8n73/fNOVv7sf/AAJ6Bj1X/Gkdf721O+31 o2NN95m/3Up6wL/d/wCBUAM+b+GP/gT96gvrZpvvN/3xV7bTZNtMR5d4k01Ybr5VVP8AGuG1KDtt r1nxTar9l+7Xm2qwcfd5/wBiueR205mh8LtT8m6utJk/5eP3sX+8P8RXqdnOs397zK+frS8k0jU7 W7Vf+PefJ9x/9cV7xp90s3+rb9394N6ivl8fR/lPfw8y80t3Dc/Mq+X90r/e/wD1VjywNDqlrd+Y 3mdfp/kV0Sf7VZt1Fn+H/gPtXlrc6Udnar5tr8zN67akWJT935P9qsbQb65m0v8AcrE8n3C03Y/Q etXpbZv+XvUWTv5Vt+6/l/jX3eGnofK1oFm5vraz/wCPiaKH039/oKqf2rPd/wDHhYT3Po837qM/ if8ACpIILTTv+PezjSToZZu/1on1Nv8AntI//XH/ABrsOMiksdQm/wCP3U4rCP8A55Wkf7z/AL6P +FLBoem2f3bRryTr599J/LfTJ7lrO1urtlis7fq0r/1Y1514l8eT3n+h6ezJH937R/y0b6Vx1sTT wm52UcNUxfwna+KPiLbaF/okc32m9/ht7b/Vr/vNXkutavfa7dfa7qRpv7qf8s1/3RVFl877ze59 z7mp9vs392vm8RjKmLPpcPhKeEGxRNN/eT1arkcX/PPd/vev0pkC/wDPT/8AVVnzVi+788n3R7/S uE7hsUCw/e+Tv9frWhouh6h4ouvsmnw/u/4rl/8AVr9K6bwp8M7nV/8AS9V3W1t1Ft/y0b/eNena fbWekW32S1jWGPooTtRv8JnKZkeE/AWn+FrX7qzXv8Vy/f6V0TXP93/xym7PN/8Aiv8ACpYkWL7q 162Hy6pvUPHxGO/lGKWz834L6U9lp9Mbd/spX0tOFNfAjwqk+7KOqxJLa/drxnxTB5N1c/pXtt3F 51r95q8p8Yad5N18u2ioOmeSW0rQ67a7fk9fbDV6la/vvu/J/v8Ace9eY6vF5NyPXt75r07SJPtd ta/d/vCvj8xgfWYGZq2LND/rPn7K3qCvrXSeGJ/J1S1/74NczFOv2X/pp9ytfSp2hurbczJ33V5t Cep0VYaHo3+d1PT/AHKzv7Sg/h3Tf7X/ANelS+uZh+7XZ/Sv0SGx8VM0f95lSqzahBD935/9yqqa fLN/rmq1FYxQ1oYkD30833V2Ui2M83+uk3/7/wDhV5Iv+AU7f/8As0FFaKxWH/bqeONYfuqqf0+l Sqr/AO5Rs/3qBhvWm7H9adRQAjp/tf8AAaZ/u/jT3b/a+lNfd3X/AIFUAMZajZl/wqdk/wBr6VEy r/Cv40AeSfEJkmuv3e5/614uu+HxR8y/88wfpur3H4ir/pXyrXiMv/Ie/Q/99V52MPVwJ7zqi+d9 q3fUe9c1bbvstz5O3zOy/WuluZ4JtU+yeYnmeRJIEfuobsPrWDoyf6Vdfd96+GlufU0ztfg/Z3Vn oWp/alZJPtu8e4CL0r0FVrj/AAbPLDpnyxt/r8nf/u10Sxzzf6xm/wB2vucu/wB2Pj8b/vJeaeCH 7zf8BqL7c3/LOOmxWa1OqrFXpnCROs83+sbZUsVmp/hqREf+FalSL+8VpgNiiX+Hb/vU/ZgfJTkR f9p/9qpd3+7QBD5bfxbUp6qv+/8A7VLSqrfwq3/A6AGtJVa6bybX5mq2y/3mqteKv2X5V/8Ar0Ae L/Fe+X7L/E/8f5V4r4ftXu9U+Zdn7+OP8N1e0fGBubX7vqW9q8u+HVot5r1tt2/8fvmfgG7V4eYT PbwMT6EuVWH+77e1VYp/J/nUs8qzfwt6H3qppunNNqfytJ/pHlptf/VgD0FfLQhqe1Oeh6bZweTa /wAT/wD7NWGi4/eSKkdQtK38Umz/AGU/xpPkx8q/8Cr9BhsfGy3J1li/5Zxs/wDv0ktxJ/z0EP8A sw9/xqszt/e/4DTkhaXPy1oHL3DzV/u7/wDaehrjP8WypHtlh+9J/wABT/Gnqyw/djX/AHnoERQW 8s33V+tS/Zl/5aTKn+ylNad/+WjfRf8A61Cq033Y2/3qAJN0UP8Aq4f+BP8A4VFPdf8APST91/d/ +tStti/1lx/wFP8AGqd9qEENr+7h9/nqiTwr44eIVNt9kXc8n+sK/wCyP8a8h+HGl/2xrumWjRt/ pE/mP/u7vM5/Cuu+OfiBLy6+aRf9R5ar6Fm7CnfAyxWbXbq7Zf8Aj3gwvsX9Pw318/mc+x9BgIHv kDf4VHpDL/anzbvZU7k/4VFf3aw2vy/X8an8P6zp+naX9ru7pUluJ8+V7D2HrXj5fS/2n3vU68dP /ZzXb7TL/qYVT/am7/8AARR/Y8sv/HxM/wDup+6/Qf41jT+OZZv+QdZN6b5v6Cuf1LxBLN/yEdVR O/kQ/wCAr7KpiaaPl40ajOynvtI0L/lpEkv9yHv9ayLnxhLL/wAeNp/wN/8ACvP7zxvp+nXX+i2r TSf337Ee1Z954l1XV/8Aj3/c9lZPX/6/1ryq2Y/ynoU8DUfxHa6rrcn/ADEdRWH/AKZJ3+gHpXOX Piyzsz/odv8AaZOpab+g/wDr151fa59k1P7Jew3lzJb8zSpH+7BPoa7DTIrKX/Uq3rtf/lnj1rx6 2OqHq08DT+0K99r2r/8ALz9mt+m1P3WfyqBPB3926dJPvFk710sEsX2X7tTfLnv7t6V5sq192dcY dkjKs9KSG2+ZVeTs1aMcC/WsjU/Gem6ba/677T2Voex92FSaRrf9o23y7VuLf5ZYP7v0P9w0ShU7 C5/M2U83+6vl/wDPT3+lTywQTf66NZu/lv3pugwXeu3V1aWNrJcyW/Dqn8OfU12+kfC++u/+Qjep Zx94Lb97J+LH/Bqx3Nb2OIuRBD95Y0j6Bf7uPSm22jSTWv2uO1fy+0vr+Ne46X8PtG0f/j20+Ka4 6rPefvdp9if8Ksr8OP7X1P7XqN5Pcx2/zxWkP7qJfqa9CnganY5pYun1Z5d4T+HE/iO1td2oxWdt 1Oz97Jn/AOtXr/hrwHo3h3/j3sIprnvfXMf7xvxNdBp+iWOnf6uOKHuVhj6k+p960kZYf9XGqf7T 9vpXsUcsp/8ALxnmVMx/kQ2CCeb7qt/vVOltF/y0m3/7Kf403zWm/vTf0qTyW/5aSKn+ylexTo0/ sJHlVK1R7srahqEenWt1dqqQ9/Mevz9+MfjH/hP/AIn3V2s3nWWn/uIW9Wr6t/aS8ZQeEfAtztVv tNx+5i392b0Ar5S+DXgH/hLvE+mWlwp+z+f9rvPaNPX6n5Kyx1b6phz0MDS/mPpX4FeCv+EW8CWt 3cLsvdQ/0ub/AGEP+rT8BXqnh+za81T/AKZ2/wA+33rPbb/Cuz/ZTsPaun0aC8tLX+G2/jZvXP8A hXy+X4f65ibv1PQxlb/Z/dNaWJv+XiRU/wBp6gOoQH/VRvc/7SVH9hX+Nmmk/vPVqG2Yfdj2R191 E+WKDPfXn3pEto/7qf40sGmRQ/ws8n9560YoF/ibf/spTl/6ZqqelMfIQrbf7Kp/tPTkii/36n8h v4vk/wBp/wCgpyxr/dZ6CiHc/wDD9NqVBOeMMyp6/wD6qvyycfMypH/nrXg37Rnxb8Q+APDF1d+G re3S4+6by5i83YD/AHRVRhfYlHkP7ZfxKimurXwlZ3Unl/8AHxe/7o/gI9zVH9kf4feda/8ACcXk Pli4/cWCvH/AP9Y4+p+SvGvDHhrWvi54xtbS/uJb/VdQn82/un/hjH+sfj0FfdC/2V4G0G2tI1js 9O0+Daq/88okXufYV8nmuLv/ALLA+qwdKx5f+018VV+HXgT7JYzeTrWseZGmz/llF/y0f8fuV8A2 qvd3X2tvov1ruPjf8Srn4oeO7rVvmS3/ANXbxf8APKFf9Xmtn4I+AV8Ua99ruId+naf88n+23/16 2j/seG9455f7XidD0rUo10j+FUj+8GfsTWZNrKw/6vc/psrsPE9p9s0u5tF2+vz9j7Vy1jpEH2X+ J/8APenleJvhtTixlEzVvrmb+FU9FT+pqzBpV3P97/x+tuC1WE/LGqf7lWlRP7vtXtnmFC20CKL/ AFsjPWvbWsEP+rjVP9qmRt/d+lTr0qA5mTo//wBapFZf4vnqNXX/AH/9lKcu/wDhVUqSCRVp25f6 bUpqQf3mZ6kVV/hVaoA+b+FV/wB6pUib+INSLT0f/wDZoAkiVP4akWo0/wC+KXzV/h3P/s0ih+7+ 9Tl61Htk/wBlP607yF/i3P6UxBuX+H5+3yd6dtb/AGUpydqqX2tWOnf664jST+GJP9YfoooEVtS0 1Zv7z15pr2m/Y7r7uz0r0iXU7y7/ANXZfZov+et93+iD/wCxrzzxPc213/rpp7mT+6n7qMH2Qf41 EjamcDqnlQj7yv22pXpXwz1f+0dB/ef6y3/d/h7151qYaH/VxrDF0H/6hVv4Y6z/AGd4n+ySSN5d x8n/AAJf8a8jHUf9nPYwtY92tZef4f8Ad9RS3S8VDp7rMf8A2b2q/L5X2X95167ff2r5U9iRmabc +Tc/ZGVvUKnc/hXSwRXk3+ph8mP+96/jXJ2Pm2l19rk/1n39v90V6GbmP7L9raRUj++XfsPevocs rW+I8fHwv8JRj0j/AJ7Sb+9ZXinxdpvgu1/1a3Oo9Y7VO/1Nc14u+KLTf6Jojf7LXz9/+uYrzdt0 3/HxM7ydWZ+59668Rjr/AMIjD4H/AJ+Gt4j8Xan4iuvtd3J+76xwJ/q4x7CsyHf/ABLv7j/69O+y tN/q1qtbXksP+sVfQex968KU7/EfRxhTXwIuxbZvut+87f8A1qljiaH734r/AI1BFPHD/pcn+s6f ga6rw54DvvEX+l3qy2enddv/AC0f/wDXWOwTMbSLG8126+yWEPnf3pf+Waj/AGjXqvhbwHY+HP8A S7qRrrUepd/4foK2dN02z0O1+yWkKwxdglXola8/qz1dOFTF/wANHNUrd2SLc/8APP8A/VUsFtx+ 8+eT+7UsECw/d+f/AH6lX/K19LhcDT+2fO4jF1PsBRsT0p3+frRur1jzxyr/ALVJSbW//bpsrJD/ AKxlSrIGyssQ+ZlTvuevL/G+p2n/ACzk86Tvs/xrttYlS7/1e5+1ed694du/4V2R9/8A9dRI0pnk niXUG/hXye9ei+Crn7Zpn6bfSuM8R6JEPvfvPX2ro/ha/nWt1abt/wDF/n6V8vmkOx9Ll8zqruLy fs3zbP4G9xWpuaEf3KjvIP8AEn0xTVb/AL+dPy9K+bW56rPS9PtoprW2/P56u7f8+lZfhyfztCtT /wAB/KtVFXP9+v0PDT0Pja24U50f+9RRXScwbU/vfrT04/otM8z2oTef/iqsQ7Yfajd5JoVP7zb/ APZoP+z/AL1QMZ8/92n+V/eah/8AfpnX7q0ASf8AfNI75pjOv8QWoJL2L+H56AJ2b+6tZes6v/Z1 r8sPnd9vpU7XMs33V2VWn0pbz/j4bfQB4j468R32rm53MqS9PKh7V5PpaSxa9+83P/qzXvvjzTbb Trr90v1+leKamv8AxPvl/wD1DdXn4o9TBHqniPTNQ/4TvTNWt9qWVvZeSzJ2B3fIR7mrvh2WWb7V uZfQ+/y10F4vnf3v9RtrN0W2ihtf1O/+tfCVP7x9VE9D8GP52l/9t66JS393/gVc/wCA1/4ldzuV f9f+hWunVv8Aar7fL/8Adj5LG/7yCw/3mpyqv8K7/wDaelqRYXr1DzhBv/hqWmpEn97fUqsv8K/S gBqq38NOWP8AvN/wGnf5xSrG1WAm1f4Vprf7VStsh/1ki/7qVF9p/wCeMP8AwJ6AG7f7q1z/AIi1 e5s7W68jYknQb+34Vsv5k3+sk+qpWfqNtBDa/wCrXzP71AHyl8TZ9X137V9rnnmk6fP2+iitX4M2 Lf27pny/8e8G8+xCd/xq18XtQX7TdbdqfwD3NX/g5af8TO6u1X/j3g2f99N/9hXzmZzPoMDA9RnX +989W/D8Hnana/K3l/fP4LWfPu/vf8B9K3vCaf6T/f8A3HX0z6V4mFj/ALSehiJ/7MdMsTfwr/wK pViX+JvfalMaXP3mp6s38K/8Cevuz5Ierr/Cuz/apjS/3mamtKv/AC0m/wCAp/jVNtQX/lmq+7P3 oAvfN/DG3+9Q7R/8tJv+ApWDeeIIP4pmeT/nkn+s/wC+RVb7XfXn+pt1h97nt/wEf4rVknRtfxw/ 6uNf956zLvxBF/FNvk/55J/rP++RVRdGab/j7uZZvVP9V+if41I9zpehcySRQx/8807/AICqEI1z fXf+rt1tu4a4/wDiB/itcj4ztdemtbq0tbhoZP4G8vv9Petm88fLCf8AQLTf/tP3/CvN/iL4s1Kb TP8ASr37NH98xQ9//wBdRKrTLhCofOniqCebXbb7dcPNcW/3t/Yj2r3b4J2bWmg/a2X/AI+J87v9 hK8Lj8MahqOqfa5v3Nt9/wA2bsB7V7J4Dtr680u2/wBOaGyt/k8u2/iHufevksxrX+Fn1uDpW+I7 3xL4ggtPvXCp/Eaw9V8XWenaX/oEK3l7/C83+ryPU1hz6RFpGqf6Xl4/umV/4lLffzVtdLWH/RGU JJb/AL61n/vru71rgcPfqcGMreRD/wAJdqmu2v7mTyY7fiZYY/WnWltJD/okhX7Pcc7k/wBYD7Gn SXK6ddfa47bZH0uIP759hWnBHB9l/dsr29x+8gkTsT6V6sqVM8v21Qjj8DWM3+lzNLNcdFkeX7q/ QetbOn6VBaf6tV/vD/61VtK1JZv9EmOyTpGz/wAVXo9QtoT8siv/AA/jXy2Io9z6OnWLEVtB/wA8 w/8ACV9cev0rPubO2s/9LZkhj++zP2HvVyD7XqP/AB6Wzzdyyf41BrOkRzaXdWmoqs0dxw0Sdx71 zWudRn6fLHd/6mRfL7N/hXI+I11KG6+yXl27yf66FU/1c0fsntU934O8Xaja/ZPCuhf2No1vBsbU L6Tyo1X/AJ6Bj6D2qDRfBDWmmWv2+7kv9VuOZ755Ojf7JP8AAK9CjD6p8aXkctWP8rOf89Yj+6j/ AHf/AC1R/wCE+wqe0ubmH+Nk/gRk7ru7/WtmLwnLNdf6RMsMnQrD/wAtB+PrUnifyvC9ra3dgqQ/ v/Llkf8AjL/Wu+pi6fRcxx08PUL2m6U0Vra3dss+lXHUNDJ5MgJ/2k9a7rwx8YfFPhe1/wBN2eIr Loftn7q5/CQen+2K8103x9Bef8fu6H1eugtbuC8/495kmj6nZXjc+ununpTo/wA59B+GPj14R1f/ AES4aXQLj/qKf6sk+ko/d/8AoNemWs/9o2v7mT7TH1V4f9WR7EV8atBFL95V96l0PUNX8I/8gLVb zSu7xW0n7pj7xn5P0r16GZ1P+XiPJqZd/wA+2faMcHk/eZU/2f8A61P/AHX93f8A7T/4V86eE/2k dVtP+Rm0X7Zb/c+1adsikZR/H5Z+Tn6rXrnhP4veGPF3/IK1G2srjobXUf3VyD7If/ZC1e1RxlPu ePUw1Tqmduqzzf7Ef8q5/wAWavc6dpn/ABLvLubjt/sn3rTlXzv9czzem/t9BXAfGP4h23w/8H3V 2zbJOiIndj716MWt0c6Pin4i694u8XfET/iptVnvP7P8wpbP+5jQn0RPQe1fSn7OfhFtO0K61aZd lxqH+rZ+0Cf4mvnP4feH7vxz4ntvMZvtusT+ZO//ADzj/wCWn5Cvuexgg0jTPslvCsMdv8iJ6KF/ pXxmZVvreJsfV4aiJ4TubbxRql19lZJvs/8ArVST7oDd/qa9A8iOH70n/AU/xrM8NaV5Ol/u4Vh+ 0clUi6CtZY4ov9ZJv/2U/wAa97L8P9Uw54OMrf7RoR7k/hjVP9p6esUk397/AHnp0W6X/Uw/8Cp8 u2H/AI+LhfM/u/8A1hXqnnjfLWL7zF/9lKkijl/5Zx7PVk/xqJbn/njD/wADm7/QUMrzf66Zn/2f /rUAStLBD96TzpP7if41A08//LGNYf8AaepYoOoVfo3/ANeh1X+Jt/8Asp/jVgZlzGv/AC3kabud 9fFP7V/xVi8Ua7/wj2nTf8S7T/3l6yf8tJP7n4V9N/Hb4p2Pwv8AAlzdyNElx/q7aD/lpLIfSviL 4UeCLn4reO/9P3XMfn/b9Sf+8m7/AFZ/3jXPjMT9Tw56ODpa7Hvn7Mvw8Xwt4YuvEN/GqajrHMO/ /llbD/V/n9+uH/a6+LK6dpf/AAiWnSMlxcfvL5/+mY/1cf4mvaPid41tvBehXN3Muy30+DJih74/ 1aD6mvzp8b+Krzxd4nubu7k864uJ/Mf2z6fSvlMFS+t4n61I93EztpEz9B0+fV9U+yQxs9xcfu1R Pdv619p/D/wZF4R8MWtou3zPvzMn8Uh/wrx/9nX4dL/yMN9D/sWyP3P98fSvojb5P933rnzDEfW8 RaJrhaP8x5LZ+I7bXdM+12siv/yzZvRh61labL5N1/rFePqvsTUttoMGkfavs27/AEifz3R+xPpU 9tp/95Vf0b/CuLD1vqmJ9w2qUaf1bUnZezbf8Kcrf7z0RRf3l/edD/n3qVVr7qM76xPiakNdQj3e yf7NTRLk/Nupq7f6/SpFb+5uqyCxEn+zUiq1Qo/+1sqRW/uqz/7VVECZf++6d3+b/wAfqNUaX+LZ Uqxr/v1IBFL125f/AGqegl/h2pTk61n33iTTNO/110rydoE/fSn6KKsDSSJP9/8A2nqVf9msFdT1 nUf+QfpTW0fae+k8rj2Sj+xGvP8AkJ6vPcyf8+1j+6iH4j5/1rMDQ1DxBp+nf8fF4iSdo0/1h+ii oItS1XUv+QdpTpH/AM97/wDdR/gv3/0qextLHSP+PKytrOTvK/8ArD9f/wBdOuNQ877zPN/sv3/A UAVv7Glu/wDkK6zLN621j+6j/Ej5/wBat2cFppH/AB6WMGn+p9SPWhYrub7q7I/5fhViLR1/5aSM /wDs+lAGZfOt395pLn/Zf/V/kKwb7wpPefdjW2j/AM9a7y3tooeiqlOnXzj/AOO0FI8O1TwwtoP3 jedXMXNp9juf9HXZLb/OG9CK9X8YWy/w/jXnWrwc9Pbb61y1YHfTmep6JqEV5a2t3Hny7j5wvpn/ AAroVVZh8y8dR9a8w+Guq/8AEsurST/l3/eRt/sN/ga39T8arDbf6BteTo079vpXxVSj/tJ9JHyN LXtVg061/eN+8/giTvXK6n4jvtdtbW0uLhvsVv8AKsCf1+lZTTtN/rpHeTqXfuaFZpfu/wCq7yVt HyZtGH8w2XbD/Rf8ayNKsbma5uvtF0r9lRP8K21tuPmZv8ay9Q09of8AS422dz7Y96dM1NbZLD92 RXj/ALnrSx2f9pXVr5Nq81x/DF6fWk8M+E9Q8aWvytJZ2/n/APHy/wDEPYV634e8P2fhy1/0aNf9 uT+8fc1MgM3wt4BttOuvtd+y3Nz94J/yziPsK7WWX/nnVWCOW7/1a+xf0rXs7GK09Xl/vf4V3YfB 1MX8R4+IxY2Cx/57N/wH/Grqr12ihE5Hy0rtFD/rJPrX09GjTwnwI8CpW/nY9acv/wCovVN9QX/l iu//AGv/AK9Nae5m+78n+5XScxed44f9ZJ71BJqUf/LNd/8AtVFFYsfvVPHbRQ/w76AK/n3N5/EU /wBz/GlXT3/5aNV+mf5NBZAlnFD/AA/8CrK8Sxf6LW43+9WVrVt51rSIPCfFS8f3++30rE8C6nLp Gu3X/PK44/4EP8a7DxPaiE3X3fSuF02Jf7U+4r/7PvXi46H+zHvYGf8AtB6dBqrXd1/F6hfX/wDX VgXazfd3eu2sm22/8sdqeq+mPWti1iX+GNk/j+ua+OZ9JI9A8Cz+doXzf898fQGuiVlrkvAs/wDx 9fN/zzce9davSvucvn/sx8hjof7QPTd/D/vUbf73z/570m6hU/z6fWvTPPJN+R8lPVqr/L/E3+fr TWvov4dz/wCFWBOd2Plpjon8TbP9qqzzyTdPk9aFtmm4kagB0t9Efu0155JvuqtSrAsP8P8AwKnU CKq2zTf6yRv92pUtlz8q1Iqt/CrUbf7zL71AyP5famtu/hWptqRfdXio5GoA8t+ISNNd/vPkj/2K 8Qvk8nXf5/8AfVe5/EPb9rrwzUm/4n38Xp8n+9Xn4rY9bBnvd5L5NqP+uFM08eTbVWvmb7L/ABem 1+9WdLX/AEb5vrt9K+ClufSxPQPBSf8AEs+Xan77n67a6JVX/f71zfgUf8Sz/tvk11McTV95l/8A ux8ljf8AeRE/3Vp+z+/QzRw/ek3/AOylH2r/AJ5x/wDAnr0ThJlib+7SN5UP3pP+ApUbeZN/rGb/ AHacsaw//FVZA/7T/wA84/8AgT01nkm+8zU75f71O2sP9igCBYF/hC1JT9q/xNvpFb+7igsieJv7 v/Aqx9d2/ZPve42etbMsi/xNXMeKbl4bS68uP6fWoLifL3xKlWa6+83+vxu9t1ej/BmBobXU7v8A 65x7vXC9/wDvuvLfF0rza7beZ/z3yVr2D4Z6NFeeDrnzJJYY7ifJaHuFZep/4BXy+aTPpcHA6u6l WL+767n7VueDGuYbrU/tiokf7tLfZJ95dv8AEPr71jGK2vP9EkXfH90o/f61pWN1OP8AU+X/AJ9q 5Mth/tI8bP8A2Y6dtQWH7qqn+161lXOvRfxSedJ90pD+9/QVWXTJ7v8A4+GkeP8Auv8A1UUSzabp 3+umX/rmn/1q+zPmRv267vP9TCsP+1N/RR/jQukSXf8Ax9TPN32f6r/x0f41k33jq2h/484Wf/Pe sm517VdR+9J5EdHOHIdi0+m6R95ooP8AZTv+ArKufG8UPFpCz9tz1wd5rmmWn+uumvJOmy3/AHvX 3/8Ar1lz+LNSu7r/AEOxWwj/AOes372T8q4amOp9WdtPCVOiO7vtc1G7/wCPi4W2j6n2HvXMXPif Sof9XI2pSf8ATH/4o1ltozakf9MuJb2T/p5k6fRacunPD91V8vts7H6V5FTMf5EenTwNP7bEufEO t6j/AMesMGmx99n76T8Sf8KqJ4ejm/0u4ka8k675pK3II/8ARfu+9Srbf3vptrzKmJqdWehGFP7C Rg33h6C7+6qw/wAJ2ehq3pWirp3+pZvL+7tT1961bmx/0X922yTs3+NVdK0pbS6+13N7LNH12P2r k57nQvNl6Xw9/aNr/D5nWNn7fX61jrL/AMulx+5kt/8AUyP/AAt/cP0rprHVItRuvslh5lzcfd8u 2j6H3xWz/wAKjvPEV19rvf8AiWx/xr/y0bHqPau7B4j6puefisP2PNr68aa1+Xb9t/jVO/1PvR4f TU9S/wBE/s64uftHEaQxf6th7nbXtFr8PNB0LH2e0XVr3/npcy/d+tTXPhXUNS1TS7tZrez+z8N5 NsnIPp+Fev8AWKr/AIcTzvq9P/l5I4rTPhHqV59l/tO9g02PqPJ/eyf5/wC+q7Gx8EaNZ3X7m1a/ uev2mb1+g+Sulg0GL/l6ka87jzu30UelXba0gtLX/R4Y4Y+yJF/Sj6pUf8aQvrdP/lzEy/7GaX7z bI/+eaVPZ+H7Gz+7DH5n95+30q+W56Vm+IdVXw7pdzdyKvmdIo3/AI3NdSw9NbI5HiKrdrnEfFnx B51t/ZNqy/8APS8f2/5Zpj3+/XnkcC/3m9qs3Mst5dfa5ZGeS4+eR/7xLVC2Zrr7319q+exVX60e /RpfVRi2K/avtarK8n+rigST75Zv7v1r0jSfC1rZ6X9kubWC/wDtH+vWaPzY3kPoD6GsfwRpH2y6 /tZ9v2e38yC2V/4n/wCWj/h9yvSPCdh9r1213bXjt/3x3+v0rnhDWxtOehzniH9lLw1rtr/xKGuN DvP+ekX72Nm91f1/2DXjHi74B+N/AF1+7sn1Kzt+RfaRJ524e6D5/wBK+zWumm+9Iz/7KVJFLL/y x3J/uV9i8NSa95Hz8MxxF/ePgKx8a31n/wAfUazfw7X/AHUgPvXT6f4s0+8+9I1tJ08ub/Gvr/xL 8LvDfjT/AJD+jWM0ved4/wDSR9HHz14n4s/Y7imuv+KZ8Qfu/vLaavH0PtIn+FebUynrTZ6dPHU/ te6cR8sv91+/1qpd2MV5/rIUf2f+lYvif4eeOfhd/wAf+nXUNl2uof3ts3/Ahu61R07x6/8Ay+R7 4v4pIe/4V4tTCVeqO+M09memeFviH4n8F/8AIM1Nrm2t+BY3/wC9jx7A/P8A98GsP42+OPEHxWtb a0mtbazt7efzLiO2k/1v0HtVSx1nT9R/1Nyj9gvv9KuPF51EMXVwmibM/q9P7UTrf2ZPDVtD/aer SSRPe/8AHrFbeb+8ijH+scr7mvoTRoP7X1T7u/v/AMBH+NfIUlr5N19rg8xLnrHLbSeVIPoRXdeD vjn4w8F/duLfXLLoy30f+k4H92ZP/Zw1ZU3fE3qeoq3tP+XfyPsOWJ4v+PqZYY+yv2+i1H9og/5Y wyTf9NH/ANX+VeK+GP2pPBWr3X2TVftPhe9+6W1SP/RmPtcD/wBn217BYzwala/a7e7gube4+ZJ4 ZEljZT6Y9a+5o4il9ho+TqUal/fTJ2nlm+9Nsi/uQ02CJf8AlnH/AJ9zTkaOH7q+d6M/+FTqs833 l/d10mALB/z0kVP9lKduX+GPf6M/+FDLFD/rJP3ff2+prP8A+Elgu/8AkFW8upydC1nF+7B95T8n 60AabRy/8tPk/wBp/wCgqhqF7BaW37xvc7++KrtDqF3/AMfN1HbesFj++l/GQ/4V87/tifZtI+Hd 1519JD9o/dw2vmfvJ2P976VrGNtWxx/ung/7SPxPX4i+O7r7JIr6No/7uLyf+Wsvt9K9v+Avw3l8 F+Dv9I3W2q6h+/uW/wCWse5f3af8BFeAfs6/Dj/hNPGNt50avo2j+XLNv/5aSn/Vp+H36+ofjH48 i+GngS61Ztv2j/j3tFf+KZl7D2+/XxWYYipi8TZH1mFpWVz5z/a/+Ka3d1a+E9Om/wBC0/8Ae3rJ J/rbgr9w/wC4P/Hq8B+Hngyfxn4ntrSNW/0jlm/55oPX6CsnVbmXXNU/eM00nWR/7xPr9a+oPgH4 Ii8OeGP7WuFX7bqHT/Yj9vrXViK31PDe4YUofW8T7x6ZomjW2haXa2lnGyR2/wC7Rfp/jVm0li1f VP7Js5Fmvf8AVyqn8J/2voKm+0rD95vo3p9K6H4ceD7Hw5pdzdw2/kyXH7wM/wDrTn+MsfWvFwuH +uax+Z6GIrfUzw+WJZv9LX/V9d3rmmTp5Nr97/gVaMEC/Zvsm32H0rMkVof9Zt/+tXmmsRltbNLp dzdybvMt58D3BqNlz95vrWuq+ToPzfP++2D8FrKiVP4tvmdfqDX0+V4n/mGkeFmFH/mJiC7f4VZ/ 6VIsUn/PTZ60NKsP3pFT131QbxHbf8uay38n922j83P/AAL/AOvX0R4JsxwJ/dqZdtYixa3efdjt tNj/AOek0nmyD/gI9PrTovD9pN/yELy61mT/AJ5+Z+6H/AUrQCzP4p02K6+yLcfabj/nlbfvZfxA oWfW9R/49rBLCP8A5630nb2RP8atQTwad/x6w21nH/zzSP8AoKik1Dzv+ek0n/TaT+goAg/4R+Kb /kI6ncalJ18q2/dRZ+g/xrQtI7TSD/oVpbWEf/XP94frimxQXkv/AExj/u+lWYNIUf6xt9AEEmot N/fm/wB/1+gp8cF3efw+TH/dT0q/FBFD91VSp1/y1QBSg0hf4pGertvbRRf6uNUpf93c/fbSv6M1 AE2R/fpP++6avP3V991P28/f/wCA0tig/wDIf+zRs87+9/wPtT1XFO2//XpXEc14j0pZrX5l3+le Warbf8Ak/u+teieLvG9rp3+iWm25vehP/LND715m0ss11+9kZ5PvfPXk4rF0/sHtYPCVPtkdnYra fdZvM6M3qKSVl/i3eo2eoqV5Ofm2pU/lf3W/d/eDJ3rwpT7n0cYW2GWatN95v+A+g96uf7u3/epi qsP+x/nvT7Pz9X/481Hl9Glf+E+30qChysv/ACzVppPuiNO/0rrPD/gpZv8AS9T2P6Qf8s1+tX9B 8PWehWvzfPcfxO9bMAa8+78np7VnZv4Ec8pl5ZY4v9Sv+yF+laFjpEsv+u+SP+dN0+2g07+FppOm /wBPpmqviLxdbeHLX7XqNytt/diT/WSfQV72Hy+nvWPAxGO6UzpUEVn/ABKkf8qw7T4gaDqOqXOk 2WowXN799oofT2b2rwzxT8TtQ8XXX2S1/wBAsrj92I3/AIyf7zH1+tc0ug+JdJ1S6u5If7Mk0/hl h/1sOV/jx8/IrueLt8Jz08K38bPqrz55vuts/wBypksX/ib3rwfwj8eL7Tv9E1mH7fb9DPD/AKxR 7ivaPD/i7S/FFr9r068S5j6MqfwH3Fa08XTfxGdTDVOxrxWsUX3Vqf8AyGpu/wD2v/r05VrpOUdv 96KOn+HrTvl961IBulH/AAJqdupv+98negA21WvFX7LVn/PzU1l82gDxvxhA32r5V+teZXT/AGTV LX5vYt6Zr2vx1Z/3a8W8USwRXXzMv+6n9a4cTDQ9PCz1PRLWWKa2+VV/u7krVtW/49fvf3C31rD0 WTztMtdq+5/CtOKXyfvKvsydjXwMj69nXeEZPJ1T5t3+pkBX33d67rzFz97FebabL5OqWv3n/g3e ma72Kx5+Zmf0r6zKJ/7OfMZlAsvfRfwrv/z61H5883+x/SpFhWGnb/evoPQ8Yg+zN/y0bfU6xrF/ n+VHzfwq1O8v/aoGG7/6y0Krfw0Fl/ho3t/e/wCBUAL5X95lpyv/AHVpn+flp21v9mgB29/So26V N8v8X7yh/wDZ/wB2sxDWVv8Ac/2qZKqf7/8As1M3WqV9c/ZLX/Vs/fb6/jQB558Q7ZYT8q7P4t31 9K8K1xfJ1772z/af/er1rx54iudSPyxrbf3dnf8AGvDrjzxr37zzH7H/AL6rjxR6uCPeNVuf9Ftd q7/8CtXdIb/iV/K1Z16v+i2u7/vr0+Sruly+Tpfzf7u3/gVfBS3PqYno/g2dodLG1V/1+N3pXQbW m/1kn+fpXP8Ag39zoP3mf9/u/wAiulVW/u/99195gf8AdqR8hi/95CKJMU9XX/BaAiY6U5W/uqtd pwDlVv7q05Vi/ibfUSP/ALX0qVVb+GtBjlb+6KGb/aam7lz8zUxrlf4VoAk2t/d+tMbb/wAtG/74 rPutXgi/5ab5O6J/9aqMuoXM3+rhWGPs03+A/wAasDVlvFh+6qp6VxPjfXLS0tbrzrhErRvILmb7 0zv/AL/+Aryn4maDbTWv2uaZfMt/4X9PaokXE8d1HXrbV/FFt5TM/wDHu+tfQvgPbD4O0zd8n+sk P4vXzGslt/b3+jt9d9fRmm332PS7a0/6YRjb7ha+PzSZ9XgzoZNSX+9Ui+NYtOtfskMKvJ3b3PpX nWp+Mraz+0+ZLHN38qH97gD+8B6VJH4utrz/AJA0MV5H937Y8v7okegHvWeX1razIxdGo/hR2Fz4 i1XV/wCJkj/u/wD1qxLzUrSH/j6vvOk/55Q/vv0FY1499ef8fd3K8fUQQ/uY/wAcetTrbwQ/6mNE 77U9a7qmadII5KeXdajJ59cuf+XOzjs4/wDnrc9v+Aj/ABqDyJNR/wCP+6e59Ff/AFefZBU8EEv8 O5O+6mfZm/0Xb9XZ/QegFeXUxNR7yPQp0aS+CJkT+HpZtUtfLk2W9v5n7r1J9q6GOL/ZV/8Aaqyl ovPzf8CqfC/7P+7XNKZ0SII7R/4W+tWls0/ur/wOqF9qsdn9355O0ad/oKvaLofinxH/AMe2mNZ2 /aW+/c4/D/61Acgfuof4kTsFrFu9etrO6/cyedcf88If3uP+Aiuz0/4T2d5df8T3xEk1xb/es7aX yo1+Xufv1HqXxO+HHwu/0TSlgvLz+KPS4vN595j/AI1fJ5D/AHfUoaR4T8T+Iv8AV2Sabbfd8277 /RBXXad8JdL07/kM3supy90mk8qPP+4K07bxHfava4ZWsP3HmGBP4CV7n2rP0pZdR1S18zdN+/8A Mdn7hfX8aI6u0RSnZbHb6Wtno9r9ksbNU9Ehj/dipblZbv8A17L5fQxpRub+9/wFP8KlSB/7qp/v 19fRwNO2qPlamLqX3K8EMcP+rjVP9mp0b3/4DQqp/eaSnp/sr/wGu3Y47sTY/wDd2Uuxf4tz0/8A 66fJUQZf4Y2/3nqB89hyf7K+1ePeOvEH9uap+5f/AEK3+SL/AGj/AMtH/Guz+IfiX+zrX7JDN/pF x97Z/wAsovr715LLIv8ACuz+grw8fiP5Wexl+G/5iZIey+T/AJ6VJpuly6vdfZLXd9ouOWl/54xj /WOfoKgVkH+sbZH1ZvXFdh4Ps2077VuVv7RuII5p1/54Qt/q0P8AtsPnrwke2dOjwWn2a0t49lvb /u4h6Aev1ruvBGlsNM+1zbYftHKl/wC4Pb3riorRvtP2RV/0m4/dhfdq9VtNM+yW1t92GP7g39wP avSyqj/tHvHmY+t/KTxRQQ/wtN/v1ZWeWb/V/J/sw9xTYooof700lXLaKeU/uV2R9P3P+NfXHzg1 bNsfvGWH/f8A8Knj8qL/AJZs/wDtP/hTo7aCH/WTb/8ApnD/AI1OtysP+phSH/af97JVkEkUVzN/ sR91/wCWf41wfjX4HeA/GltdfbdGi/tHqLrS/wB1Jn3I+T9GrsZbvzvvbpv+u3+FUdc1CXTtLuru RW8rr89KJtGdT7DPhL4vfDOP4Xa7a2i6g159o/1Sf8tEA9cVzVp4n1fSB+8ZntugWaPqfZq0PFni W5+I3jrU9WmVn/f/AGW1iTso9D7mvrHwZ4OtPC/g610m6gguf3GbiKaPzt7v6g18jmE6f1m0UfVY edS3vny9Y+OrOb/j8VrOX/np/wAs/wADXRwX0V5/x7zRTerJJ0Hvj1r3S7/ZQ8JeNLW6u7Z5fDdz 0ja0/exHH96E+/uteLePP2WfGHgs/wChRxa/ZdUk06T/AEn8Yvv/APfG6nHLqj1p/cX9ZpXtzFSW 2gm/1iq/+y/9ai0azuvCOp/a/Deo3mg3vU/ZJPKjf/ej+5J+VcR/bms6FdfZLyORJLf5WtryN4pV +oPpW9p3jbT7z/Xf6NJ0Cv8A6s/RhXBKjVwm6ZrLXex7j4Y/ap8S+Hf+Ri0a11+PveWn7q5/74Py f+g16v4W+PXhzx//AKJaazZ6DcH5RBrX/Hy5/wBhPuf+PNXyWlzFef3X77k7VHqGlRTWv7za/cs/ pXZRzGp3PPqZdT+z7p98f8I1azf8fay6l/EJNRk/dg/7MI+T9K0tv95i/YRf8sx9FHpXwh4D8feI vCP+l6D4hu/7O6pA8nm2zD/rm/8A7Jtr2zwv+1s3/Hp4k0Boe32rSP4vrG/+Ne3TzSm/j908ipga i+Fcx77fSraWvzNHDH12v6D2r84vj98Rbv4l/E65+zyfabLT5/slhAn/AC0kLdh7mvor9or9ojT4 fh3/AMUvqMc17qH7j/Vv5kAPqp9BXgv7K/gOXxT4x/ta4tWfTtH/ANUz/wAU5X1/2RXVjMZT+re4 zoweG/mR9J/Bz4eQfDTwda6T+7e9/wBfezp/HO/v7fcr5M/au+LC+NPGP9k6dM02jaP5lvDs/wCW sv8Ay0f8/kr6V/aI+KsXw68CXX2OZP7Z1D/R7Rk/5ZL/AMtH/AV+fMUUmr6p8vz9gqdya8DLqP8A zFVfkeniZ/8AMNA7r4IfDxvF3if9+u+yt/30zeo/55/ia+voLZbP7Ltt28vpuT+AD2rj/hF4PXwj 4YtbRo1S4uP307f7R/wrvF3zfdjb0jX1NePiMR9bxNvuO6jCyJ9K0JdX1O28zalt9+ZvXH+NegNK v8O30H4VW0fSv7I0v5tvmdXb3/8ArVJKrV9fl+E+qb/M+ZxmI7HzpaSNNa2u5W9WX+6ai1K284fL t+lDXMEOmfa2kVO31P8A9erMTLd2v+ea+DPpTBtdMWG5urtf+Xjy93uVqtqqS/av3cjQydN6ensD WzJH5P8ASqksS/xfUVcJ2d0VKGnvFCPSdK/j83VZPvBppP6f/Wq0995X3VituwjTsPaoF0+cn5ZP 3fUD0qeLRooT+83P/s+9ffYbEfW1ofG4ij3InvPO/hab/f8A6Cp4La7m+98nb6D6Cr0Maw/dVU/r Uysv96uw5iG20iKH/Wbn/wBn/CtCKBYfuqqUyF6mT/gP4UAPpVb/AGajX/PtUnzY+agBzf7TLTl/ 3aaq1Ir4qAG7f96n0bv7vz/xUg/3lSgCRTzTkHSo1/3frWF4l8bWmhf6Iv8Apmo9oE/h/wB41lUn /OzaML/Aja1PU7bSLX7Xe3CQx92fv9B715n4l8eT6v8A6JaK9nZf3v8AlpKPesXVdXvNWuvtd6+/ +5Gn+rX6CsqeVf614OIxf8h9FhcD/OSLt/hX/Ipu5v8Aln8/q3p9abAnnf3Uj6jZ3Huass6RWv8A Cn+ynrXlnsFYwt/E2+Tu3pVlrnyf/ifU1A8jy3X7qPzpOoX+79a2tM0yKzP2u4+eT+X0FTLzAk0j w5c6v/x9fJbdfKfv9a6hJ4NN/wBEtY19NyentWZFdz3d19kt1b02pXTab4fitP8Aj6bzrjoP9n/9 dcspmciCytPtd1++ZvM7L/8AWrubTSltP4dlcRr07ad/paqvt9RXL/EP4rtq/wDxKdIZra36TS/8 tHJXt9K9jLqv8yPGxsP5WdD48+Llj4X/ANE0qNb29/inf/Vx/SvDNV1XVfFGp/NJPqWq3HCx+/0r N1LWYLzVLW0luEtvtH7szzf6uPPqa9u8CeGtP8LW3+j/AOk3Fx87X398f7J/uV6Nar/OclOlTMGL 4CyXehf6VfxprXUp/wAsl+p9q5Vb3XPAGp/ZNet5fKt/kgvEk/eRoP7j/wDLRP8Apm4Za+iLaZZq bqun6fq9r9kv7eO5tuux+x/2TXne1/nOuM/I8o/s7RvF2l/a5vKT/qK6d+6iBP8Az3jP+rc/98/7 VYOpeBte8LXP2vT2e5+z/Ot3YyfvAPda29Z+G2p+Ebr+1vDk8s1v/cT/AFqD3X/lon4Vc8MeO4Ls /ZLgQWF7/wA8vM/0ac+3/PN//Hf9yjn7HR/gKfhP4/6vpFz9k1lV1OP7pl/1Mi/U17Z4V+IGjeLf +PC8je46m3f91KP+A+1eeav4T0jxb/x9WphvOrOn7q5A+v8Ay0z/AMCWvPdZ+FGr6Rc/a9Ima/j+ 8ET91cofYe31rpo4nsziqUab3XKfVUTN/Sn7f731r5i0H48eKdCuv+Jq32/tLFeR+TIPo3/xYavY fB/xh0HxR964+x3vT7Nc9z7GvVp4v+c8+phKnQ7+nVEssf8Az0/4Enaomvov4V3123/lOIs7az9S vJbT/V7Xk7M/9ac1zPN91aj+wvN/rG+tWI8n8X6hfajdfvpGf0VO1eVeINIkm/h2elfSfiTSoPsv yxr614t4njTH9z1//VXPVOygX/BUj3mmf6zf2LeldGy/7vrt9a5P4Z3Ky211aN/vD6bq7ONVF18y r/vf8Br4HEw/2k+0pTuXIJ/9K/dsvqP++q9Qidpvu/UNXlEStMP4vQ+xr0zQ7r7Zplt/1w5+or28 qmeLmUTR2/3m+tLv/urz2pjf8CelRW/3K+oPnZCb/ej6U9Y1/ibf/s07/gOz+GrEM2sP9j+tP8pf 9+kanrE/92gATr/zzoVP7zU9nih+83/AU7Uz7T/cVf8AeegCVIsVEzRQ/eb95TXVh95qTav92gBP Pb/lnGv+9UE8bTf6xvfb/wDWqZulRsrUAeeeP7GCzP7tf+Be9eEeIf8AkKfe/wC+K94+I6Nn5pN8 f91P8a8C8QqsOvfL9a87FHqYI9c1Jv8AiWWvy/8APP8AH5a1/D6f8Sz+H12+1Z9ztm0zTN3/ADwj P47F61c8Pxf6L8rV8HU3Pq4npXgiT/iRfd2fv5Btftj/ABrf3Ln5mrC8JKv9l/e/5byfLW2sq/w7 f96vvcD/ALsfG4r/AHklTfj7tPXaPvNWdPq8EP8Ay23y/wBxP8BVaTU7mX/UwrD/ALU3/wASP8a7 DhNnz1/hqnc6zBD96bfJ12J++/QVmtZyzf8AHxdO/qv/ACz/AO+R/jQWs7P7vlp/0zT/AAFaDLLa ldy/6m3WH/auf/iR/jUDWbTf6+Z5u+z/AJZf98is++8SW1p95o0/3/8ACuYvvHnnf8eqvNRzlHZv JbWf8Uaeip7e1ZGoeKraz/iX/PtXEX2r3k3/AB9XUdnH3rFk1W2h/wBRby38v/PR/wBz+prkqYuk viZ008NU6I6zUPGFzef8e8bP/tev4V5Z8QL6+u7W68ySR/7sSf1roZZ9QvPvTLDH90x239WqrbaQ sP3V/wCBev1NePWzP+Q9Wjl387PJfD/gi+m1P7W0yQ/7L9gfb3r1a5iuby5/0mN5rfuydj8v8ArQ i0+D+Jl8zvWlBCv+C14Vatf4j3qcKa2Mj+zfOtv3MKwx9Pkj7U7T9Gg0K1/cqsNtb8hfTNdBFAua r6loNjqP/H5D9pj67H9vaueISmZk8cF5/em/z3rTtoF/u7P9ztSRPbWZ+VVT/ZqppMt9q91/oUMl 5J5+fk/1ar7t/wDXoI5eyNKPbD95VTsKqarfRQ2vyzLD3Lv3HtXT6b8MNX1f/j6mTT4/7sP72TP1 rtdI+G+g6Eflt47m9+959z+9lz7f/qrWMKj+BESnTXxs8x06x1fV/wDjwsJZo+nmv+6j/M11OlfC XULv/kL36wx/88LTv9XP+Fej2Kyw2ttvtora4/ib/XYPtU/lR/8ALTdNJ/t/4V6tHLKj+P3TzamY 0/sIydB8HaN4c/5B9lF5neX/AJaMfdzWpqNi13a3No0z2cdxw8kMn73afRvcVK8/935P9lO9N8pv 7v1Z+9e3Ty/DrpzHmVMdUfU8g+Kun6R4d0K6+zW6+Z5HlCV/9bjd3Y/P+tfN3hLSl13xjplpt/dX F7GG90Vv8Er2z9oPUmitfsn2hP8ASPMcxp/s+9cV8AtDWbXftcis8Wnwcf77/u/1G+ubMJJfCjrw Lv8AEfQxbybX5fkrQ8C2yzXV1dybvL/1a/U+/tWZqb+Ta5/Oul8FW32PQvmjZ5LjzJm/H3+leLl1 G+JO3HT/ANnN7c3/ACzjVKbJ+5/1kip/v1FLLLN/y0WH/ZT/ABqJYIv7q/7z19sfKDxcp/yzjZ/9 qnq0n8Umz/ZSligb+7/wJ6f5S/xNj12VEhDUVf4V/wCBVBqF5Fp1rdXd02y2t/nZn7/T61cVl/hV Ury74meIP7Ruv7Jhk/0e35mb+9IP8K4cRV+qbnVh6P1p6fM5PW9Sn1G7uru4ZfMuP4f7q/3B9Ky5 JGH3tv8AvP6VV/s9Ybr7X50vm/c2PJ+7A/3an8ie8/0S3jaa4uJ9kUafxMf8a+QqTvufWRhZe6SW VjpunXV14h1Fd9lo8GZ18z/j4Y/6uAD/AGmrvfCtncjQrm7v5G/tXUP9LupU/wCej/wD/dHyV5l4 gWDXfGOmeErCRbnStHn87UJ0/wCXq6Vf3jn/AGF/1S17NEv/AB6/L/ts3tUVi4nRfDrSJZtU+1x7 3+z/ADlk/vt6n6b69OisV/5bTL/upXN+D4F0jQvut5lx++kX0z6/QVtxyz3n+rVv91P8a+wy+j/s 2p8pjK3+0mkssFn92Nf96b/CmyXzTfe3P6e30FVltlh/1ki/7qf1qdZY4f8AVxr/ALz/AOFemcQ+ NJ5vu/js/wAakWCOL/WTb/8AZh/xo8ie7/1nyR/3n/oKlMFtD/rJGf1b/ll+dWA0zpn9zGqf7X/L SvAv2r/iFc+HPDH9kW8cn23UP3Cu/YH2+ley+I/H2l+F9Mubu4uPJt7f52a3jfoPpXwn8T/iQvxi 8d/a4I500rT/AN3Cs38TH+PFZ1J/VFeR04eB1f7PXgX+1/E1ruVfs2n/AOkSM/eT/wDX89fTEGmS 3mqfLJvk/wBXEvpn1+lc18F/Cf8AwiPgS28yP/TdQ/0qZfTd/q8/QV6n4T09PtX2vyVf+BWf+97D 2r4anH63ij6SpP6ojoLbTPKtfsjXDzR/cCW37r85DVy2gW0/1Pl2fr5P+sJ93NDK/wDy2kVP9l/8 KcjR/wAK7/8Aaf8Awr7yOnwnyN+5j+KvAHhrx/a/ZNc0K11j/ptcR/vF+ko/xrwbxz+xPp959qu/ Cuv/AGO4+8thqX72P8JU/wAGr6YfzZv9Z8kfbf6ewpIlX/ppN6bKuSv8aRvTxNRfAz84vGHwj8Z/ C+6/4mOkXNnbdftlt+9tm/4GPWsjTfGF1D/x9r9pj7t6V+oBtpPs377yobefhon/AIx7rXmHjf8A Zr+HPjM3XmaL/ZWodfttjJ5WD/1y+5+leZWyum/h909enmn/AD9R8a6br1jqP+okSHsIn7fQVel6 /Kre2zvXc+Nv2Ktc0/8A0vw3q1vrdv1Fvc/6Jcj/AHT9z9a8N1bS/EXgbXfsmp295YXlv962uO4P tXgYjLqmEPWpVqT+BnapF538O/8A2XrS8N/EDVfAFr/ZOlSKllcTyH7H9m/dsT/rMuP9Xn61xGn+ PIJv+PyFoewkTuPeultLy11G1/0WaKaP+8nb8K82XaRucf8AG+11z4l67/a1vDbWcfkeTBp8Mn+p UejH1Pz1X+BXwzl/t77XqMeyPT/mCP3kP+Fd5LF/wP8A3+1VJ4oP+WjeTJ/z1STysf8AAhW8sTU+ rfVomEaNPc9j0+KKH+H6tXU+DNL+2XX2yRc29v8AJCvq3/1q8T0/xdqtp924W8j7Jc9h7OP8Gr1P w18ZfDU1ra2lws+hyfcC3H+rJ9nHqaWBhTWJ/eMxxk6lvcTPQpjUX/Aleo7S7g1G1+121zFcxdpI ZOv4ipPm/wDsa+7jb7J8qfFniLULn7La2kLN/wAfsA+nzV2ujLLCPsknySdN30rmPDF9FqP+s2vJ b/Ky+9dY0v8ApPy/6z+dfmUj7iRavP8AK1i+a/2X7uz/AGa2l/8A11lX0X93/V9akiJFulm+78nd frWhH+9+6tVkamWkrfavsjN7j6//AF69rK8Tb/ZpfI8zH0f5UXlpy/7NN2/7P4VIv+1X16PlyVf9 7/gNWF/2arq+KlT/AIDWgE69acrVGv8AwL/e9akTtQA5V5+9soWL8P8Afp6/7v8AwKjcv+16UAOK /wC0v51HPcwWdr9rmkWGPqZH7VmeIPE9n4ctf3zNNcf8s4E7/WvMde8QXfiO6/0qTZH/AAQJ/q0r zMRi6f2T0cPhKmLOg8UfECe8/wBE0iRoYuhuX/iH+yK4aKOeH70m+Xv/ALR+tTbv7q7/AE9/xqVE WH73zyd/avn6lap1Z9JRo08J8KIlRs/Lt/wrn5YtSvNU/wBYsNv/ABKn8QrclhP8Tf8AAPSoFdIf 9XF+87BO5qI+R1k/2nyv4VSP+89U4IJ7u6+VtkfdvX6VZa3lm/4+GVP9n/GnRXLS/wCiW6M8nQKn f8Ku3Yg0bN4NO/1ar5n8qbc6t5P3tz9wv+Nbdt4FvobX7Xer5MvaD0+prB1Wx/3ff8K66OB/5+Hl 1sX0pmv4D8R30trdeXsf9/8AMqf413SanPqVr+8tfJ9ZfT/9VeT+CNQbSPE32Rmby7j93/wIetXP iB4zlmtfslgyvb/cmlT+Ij0PtXmYjDf7TobxrEHxF8cf27dfZLWSRLe3+Qt/eb2rmvDnh/VfFA+y W6tbad/y2unj6n+4pqe2+Huval4YudWtYSkn30g/5aOn/PRRXRfDrx8032bSNVmihk+4qzfusn2J /wAtXbt8Bict4p+EmvWf+l+Grj+0o/uy6dcx/vWX/dP+s/8AQq4zwj8Q9V8GXX2SzZrbtNpV/wD6 vP8AsE/6uvqSKJf+PuNt8fZk/wA9qzPGfwx8P/EW1/4mdr5N7/yz1CH/AFi/X/npiujD42+ldHmV KVvgZieCPixZ+Kf9Ej222o/xWNz/AKw/7p/5aV6LbXyzfdhZPVfSvlXxz8JfEvw6/wBLmjOt6D/B fW3+th+v/PP/ANBre+H3xxvtH/4/2fWNP/56p/x8wfUf8tMVVbA9aD5vIzjiP50fSas38P1+lcv4 l8Daf4o/0td1ne/894f4z/trWj4Y8X6b4j0v7XYXkVzH3ZP4T/tLW8rJ/DXkclRHbGf8p5DFqGq+ DLr7Jqts9zZW/ED+Z0z/AM85K63SfE9tq9r+5ka5j7t/y0i/66IPT/noldhc2sGo232S4hS5t7j5 Xim/1bfUV5p4g+FFzo91/a3heeVJOpsXk/ej/rm//wAXVxOnnpv4zpdX8P6f4otf9PtYLmL/AJZy p/rAP9lxXnmvfB2e0/0vRrj7T3+zzf6wf7rf/s1oaJ8RUs7r7JfwtYXPS4d4/wB2WH9+L3/56JXo NpqttqJ+WREk+8Nn8YP91q15xctToeWeH/iD4g8F3X2S+WV/+nW+7D/Zb/8AaWvWfCvxe0HXf9Eu pG025/55Xfc/7LfcqDUtMtNXtfsmoWkV5H2Wb+H6GvOvEHwjgm/5A15s/wCnS87f7rj/AAraniez OeUKfVH0as0U33ZFf0ZKfu//AGq+VtP8V+Kvhpdfenhj/wCfW7/exEf7J/8AiDXqPhP9oHSNX/0T VY20q46Bn/1TH2b3+le1Sxf8559TCVPsnoHiGJprb5WX/wCvXiviKz4+b/vqvb7q+gvNL/cyK8fU e9eReKIv9Kutq/XfXRKd9jKmu5x/gOf+ztdutzKn2jke5r0yCVf6/wDjvrXkdpOuneJ7a7k/dx+f sPt81emfaVm+63sPf6V8fmEP9pPq8L/uxqrIsv8Aq2Z4+o+ld94RlSbQv+/ibf8AgXavM7bbCflz 6hfQGu+8Bz+da3O7/fHsCtXls/8AaTnzCH+zHVo+DSp/9luoTb/E3ttpwuP+ea/8CevtT5IEif8A h/76p77f4m/4DUW1pj8zU5VXPy1ZQ/z/APnnHs/2qY26b+Kkd80Irf8A2VQPlHoiGm07b/eZv+AU 1dn8KUhj9rf3f+BUz5f4mZ/9lKa/+9TNz/wq1BmO81Yf7qVDLJ/eanMv95vwSoWlU/dC0yzz74iy tn5Y2f8A2vSvCPEaN/anzbf92vfviQyfZvmZf92vnfxHqcE2qfu239/krixJ6WCPZblZf7M0vb8n 7iMBv+ALWnoLRfZrnzGVI/731/xrFluVGmaFub/lhHlvfZ2rQ0hFmtfm2vH1218FU3PrInpHh+5a HS/3eP8AloSz+v0/+vWn5Dzf66SR/wDZ/wDrCuR8MaqlnpnzSM/7+Q7n7Dd/SotS8dQQ/wDLbfL/ AM84f8a+8wc/9mPjsR/vJ2Xm21p95lT0X/6wqpd6/BZ/3U/2nrzq58S6hef8e8f2aP8AvP6Vi3N9 HN/x8XEt5J/cStamJp9zKNGo9kdxqfj+L/lizXMnTalc/fa9qF596RNPj67nrD+0303/AB6wx2cf Tf603+yFm/4+JGmk67pu30HtXl1Mzp/ZO+nl384S6raf8s/P1KT73yf6oH/eoa51K8/1ezTY+yw/ 6z8Sf8KvRWcX8K7/APa/4FTkKTf6tl9Ds9a8mpjqnQ9OnhKfYzLbR1/5bM00n/PWatFkih/5Z7/6 VZWBP4mp21f7v/fdefKf8zO/YrRK+f7n+zROvk/3U7+Y9WY2/vfPJ12p6VE0vnfdj86ToET/AAqS hYoY4fvL+8/vVJbL5P8ArJGm7gv2+mK19P8ABGr6uP8AVrYR9RJc+nstdZp/w10zTh9r1W4a67/v v3Mf4LUB6nCxPLd/8e8bzSf3Ya3tN8B6zqP+vaOwj6FX/eyH8P8A69eh6ZPp/wBl/wBAhj8u34Oy Lyo8+xq39pb+9/wGL/GvSw+BqYvY4K2Lpo4+y+Dmg6bqn9rTz3V5J5Gz7Ldyfuww/wCWgj/+vXYQ QQWf+phWGP7wby+n0X3NRq+fuqqev/66csTTfdVv97/Gveo5XTXx+8eVUzCptAc7+d/rGZ/9lP8A V05X8n/V7U/3O1HlLD/rJF/3U/xpUlX/AJZx++569aNOn9lHmym38THKrzfdX/gX/wBenbV/ibf6 qn+NMWKWb73/AI/UsUUX8O65/wBzt9TWpiKsuP8AVx7KyvEOtrpGl3V3Kst1J5G/yk749M1ufND/ ABJbf7Kf41h+JJba0tftfkq8nUSTdqsD43+Kvj678Xa7bbbP7HbdCvqN3c+9etfADSv+JDdXbKqf aL3YjeqRr/8AFb68b8ZX0Wr+J7ryY40j/eSbU7Zavpb4daauheGNMtNrJJbwR71f++/7z+b18jmt U+qwcDV1fdN/oke3zPuD6mvR7azlhtfskat5dv8AJu+nrXDaDB9r8T23G/7P++P4ev413x8y7/vP /St8ph1ODMZ9BjwRQn5pN/8Asp/jTfNWH/Vqqf79SNEsP3pP+ApQu3/lmv8A33X0h4gi+bN/ef8A 2qd5an7zf8BSpFiaX73yf79Pby4f9dIqR/6ySR/4VHr9BWYkc54z8Rf8IvoX7nb9tuP3dv8AX+/+ ArxG8u/+ejM/cl/4s+p963fFXiVvFGqfa9uy3+5bRP8Awx+4/wBr79cpLE0118zfu+v1NfJ47EX2 Pq8Hh7bkkTNL/rI/cr71HqviNfA3g668Qxsv9s6h5ljoyf3D/wAtLoD/AGB8i/7daGjaU+o3X2Rp mhj8iSSe5/54wL/rJCfYV5L8QPFi+NPGN1d2sfk6Vp8Edjp1r/zyhX/2cn56xw9LS8jpqTPRfgH4 fcfatWkX/p3RvXH+s/M17fp9t/aWqWtovyfaJ9hb+6v09hXK+A9B/wCEd8MW1pt/eW8Hzr/tt/8A Xr0zwDpqy3V1dyNsj/1abO5PpXLRh9bxJFar/sx2apFD/qYd/YNN/QCrcST3n97y/wDyGKqS6hbW
March 27, 2010 - April 01, 2010
Pietenpol-Archive.digest.vol-ja
