Pietenpol-Archive.digest.vol-jk
July 20, 2010 - July 31, 2010
      > Hotmail.
      > http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4
      Rick Holland
      Castle Rock, Colorado
      "Logic is a wreath of pretty flowers, that smell bad"
Subject: Pietenpol Metal Brackets & Fittings
Date: Jul 20, 2010
Earlier this year, I polled a number of local Pietenpol builders about whether they would have fabricated their own metal brackets & fittings, or purchased them if they had been available. Based on the information gathered, we've gone ahead and made a series of metal kits specifically for the Piet. The kits are substantially complete, and I'm bringing a very large sample set with me to Brodhead. While the samples were made to prints and spec's, they are not made from 4130, and may not be used in aircraft. That said, the 4130 alloy kits will be available in the August timeframe. Because I value the great comments from this forum, I'd appreciate it if any and all of you would stop by to spend a few minutes with me, give me your feedback, and let me know what you think. The completed kits are: 1. Empennage 2. Jenny Landing Gear 3. One Piece Wing kit 4. Center Wing Section of Three Piece Wing 5. LH or RH Wing Kit. In addition to the above, we're putting together an engine mount kit, and a controls kit. In the controls kit, there will be dual stick & rudder, along with the bellcrank behind the pilot's seat. With a few exceptions, all of the parts in the various kits will have all holes pre-drilled, and will be pre-bent. In several cases - those spelled out in the plans - the parts will be drilled or bent during assembly. Pricing is being developed as I write this, but suffice it to say, the cost to you isn't the principal benefit... According to the guys we polled, you might find yourself in the air one to two years earlier. I'm personally looking forward to seeing each of you I've met, and those who've added so many great comments during the past year. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305622#305622 ________________________________________________________________________________
Subject: Re: Big Piet meets little Piet
Date: Jul 20, 2010
As a RC builder and pilot I appreciated the effort. Thanks for sharing. Keep us updated. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305629#305629 ________________________________________________________________________________
Date: Jul 20, 2010
Subject: Metallurgists opinions please
I am using aluminum struts for my wings and cabanes. I am wondering if 6061-T6 aluminum will work for the insert material in these struts, or should I use 7075 instead. Is 6061 suitable? Is 7075 overkill? Thanks. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: IGNITION SHIELDING Needed on A-65
Date: Jul 20, 2010
After installing a cowl mounted antenna (RAMI AV-534) for my hand held radio I have ignition noise in the radio. Is the IGNITION SHIELDING BRAID as sold by Aircraft Spruce effective? http://www.aircraftspruce.com/catalog/elpages/shieldbraid.php Pictures attached of the offending ignition. :) -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305640#305640 Attachments: http://forums.matronics.com//files/sam_0853_650.jpg http://forums.matronics.com//files/sam_0747_153.jpg http://forums.matronics.com//files/sam_0733_112.jpg ________________________________________________________________________________
Subject: carb rebuilder?
Date: Jul 20, 2010
Don Swords of Don's Dream Machines did ours for the 6 Big Piets and supplied the cores. He does seminars at Osh and SnF on small Continentals and holds several STC's for them. His number is 770-412-8885. We used UPS for shipping. Barry Davis -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Tuesday, July 20, 2010 11:00 AM Subject: Pietenpol-List: carb rebuilder? --> Hey, I'm looking for a good shop to rebuild my Marvel carb from the 0200. Any suggestions? Contact info would be appreciated too. Thanks, Douwe ________________________________________________________________________________
Date: Jul 20, 2010
Douwe=2C I have rebuilt dozens=2C if not hundreds of these things. Do it y ourself=2C it really is a no-brainer. It is all remove and replace=2C no a djustments. The rebuild kits are not expensive (or they didn't use to be). Just disassemble and clean=2C reassemble with new jets and gaskets and yo u are there. the shaft bushings are the only parts that wear. Ifr you rep lace the shaft bushing=2C you need a ream for that=2C but it is the most ch allenging (not) part of the procedure. Gene > From: bed(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: carb rebuilder? > Date: Tue=2C 20 Jul 2010 17:45:38 -0400 > > > Don Swords of Don's Dream Machines did ours for the 6 Big Piets and suppl ied > the cores. He does seminars at Osh and SnF on small Continentals and hold s > several STC's for them. His number is 770-412-8885. We used UPS for > shipping. > Barry Davis > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe > Blumberg > Sent: Tuesday=2C July 20=2C 2010 11:00 AM > To: pietenpolgroup > Subject: Pietenpol-List: carb rebuilder? > > --> > > Hey=2C > > I'm looking for a good shop to rebuild my Marvel carb from the 0200. Any > suggestions? Contact info would be appreciated too. > > Thanks=2C > > Douwe > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jul 20, 2010
Subject: Re: Metallurgists opinions please
I am using 1X1 in. 6061-T6 square bars in my aluminum cabanes. I have salvaged Cub steel lift struts, that I will shorten at the bottom to overcome likely corrosion issues. Tim in central TX -----Original Message----- From: Michael Perez Sent: Jul 20, 2010 4:13 PM Subject: Pietenpol-List: Metallurgists opinions please I am using aluminum struts for my wings and cabanes. I am wondering if 6061-T6 aluminum will work for the insert material in these struts, or should I use 7075 instead. Is 6061 suitable? Is 7075 overkill? Thanks. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jul 20, 2010
Subject: Re: Pietenpol Metal Brackets & Fittings
Good for you, Tom -----Original Message----- >From: tkreiner <tkreiner(at)gmail.com> >Sent: Jul 20, 2010 2:29 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Pietenpol Metal Brackets & Fittings > > >Earlier this year, I polled a number of local Pietenpol builders about whether they would have fabricated their own metal brackets & fittings, or purchased them if they had been available. Based on the information gathered, we've gone ahead and made a series of metal kits specifically for the Piet. > >The kits are substantially complete, and I'm bringing a very large sample set with me to Brodhead. While the samples were made to prints and spec's, they are not made from 4130, and may not be used in aircraft. That said, the 4130 alloy kits will be available in the August timeframe. > >Because I value the great comments from this forum, I'd appreciate it if any and all of you would stop by to spend a few minutes with me, give me your feedback, and let me know what you think. > >The completed kits are: > >1. Empennage >2. Jenny Landing Gear >3. One Piece Wing kit >4. Center Wing Section of Three Piece Wing >5. LH or RH Wing Kit. > >In addition to the above, we're putting together an engine mount kit, and a controls kit. In the controls kit, there will be dual stick & rudder, along with the bellcrank behind the pilot's seat. > >With a few exceptions, all of the parts in the various kits will have all holes pre-drilled, and will be pre-bent. In several cases - those spelled out in the plans - the parts will be drilled or bent during assembly. > >Pricing is being developed as I write this, but suffice it to say, the cost to you isn't the principal benefit... According to the guys we polled, you might find yourself in the air one to two years earlier. > >I'm personally looking forward to seeing each of you I've met, and those who've added so many great comments during the past year. > >-------- >Tom Kreiner > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=305622#305622 > > ________________________________________________________________________________
Subject: Re: Dogs at Brodhead
Date: Jul 20, 2010
My wife and I had our dog with us at Brodhead last year, and nobody said anything at all about it, and nobody seemed to mind. In fact, he got a lot of head scratches and attention, which he greatly appreciated. We kept him leashed and picked up after him, and we had no problem at all with him there. Billy McCaskill Urbana, IL Looking forward to Brodhead again this year, but this time I won't have my wife or the dog with me... -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305661#305661 ________________________________________________________________________________
Subject: Re: IGNITION SHIELDING Needed on A-65
Date: Jul 20, 2010
Try a location as faraway from the engine as possible with the antenna. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305663#305663 ________________________________________________________________________________
Date: Jul 20, 2010
This antenna needs a ground plane. There aren't any locations that are of a significant distance from the engine. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305669#305669 ________________________________________________________________________________
Date: Jul 20, 2010
Yeah, but still, you might try it somewhere else and see if it works. We moved our antenna to the cut-out in the rear of our wing center section, and it works quite well, no shielding and no interference. Good luck! > >This antenna needs a ground plane. There aren't any locations that >are of a significant distance from the engine. > >-------- >Dan Plett -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Jul 20, 2010
Dan, For what it's worth, I'd buy some shielding and give that a try. I put my antenna in the same location on N502R and had wonderful results. Over 50 miles on a handheld while I was at 500 feet AGL. I have used the shielding on 2 strokes with very good results. Gene in Beautiful (but HOT) Tennessee -------------------------------------------------- From: "Dan P" <dlplett(at)swko.net> Sent: Tuesday, July 20, 2010 7:56 PM Subject: Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65 > > This antenna needs a ground plane. There aren't any locations that are > of a significant distance from the engine. > > -------- > Dan Plett > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305669#305669 > > > ________________________________________________________________________________
Date: Jul 20, 2010
Dan, One more thing. Make sure your ground wire has good contact with your cowling. Gene -------------------------------------------------- From: "Dan P" <dlplett(at)swko.net> Sent: Tuesday, July 20, 2010 7:56 PM Subject: Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65 > > This antenna needs a ground plane. There aren't any locations that are > of a significant distance from the engine. > > -------- > Dan Plett > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305669#305669 > > > ________________________________________________________________________________
Subject: Re: Broadhead 2010
Date: Jul 20, 2010
along my route from NY. Looked at the prog charts and decided the stationary front is going to remain in place during my whole trip to Brohead. I decided that the better decision is to load up the car and remain dry, but I am still coming. Barbara was relieved and the wrinkles of concern have subsided from her face. I hope you guys flying in are careful and remain safe. Hope to see all of you at Broadhead. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305686#305686 ________________________________________________________________________________
Date: Jul 20, 2010
Do you have access to the bell crank for your elevator? I was able to fit a large sheet of light aluminum behind the rear seat and install my antenna out the bottom. Works great. On Jul 20, 2010, at 8:34 PM, Jeff Boatright wrote: > > > > Yeah, but still, you might try it somewhere else and see if it > works. We moved our antenna to the cut-out in the rear of our wing > center section, and it works quite well, no shielding and no > interference. Good luck! > >> >> This antenna needs a ground plane. There aren't any locations >> that are of a significant distance from the engine. >> >> -------- >> Dan Plett > > > -- > > Jeff Boatright > "Now let's think about this..." > > ________________________________________________________________________________
Date: Jul 20, 2010
Thanks for all the suggestions. Looks like I have a lot of options. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305696#305696 ________________________________________________________________________________
Subject: Bit of progress
Date: Jul 21, 2010
Hi guys what a great feeling I just had to share Also would like to ask opinions I am planning on no Dihedral but a bit of washout by making the rear strut 3/4 of an inch longer is this how others have done it? Would 3/4 be to much or to little? Thanks Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305712#305712 Attachments: http://forums.matronics.com//files/pietenpol_096_366.jpg http://forums.matronics.com//files/pietenpol_094_311.jpg http://forums.matronics.com//files/pietenpol_100_185.jpg ________________________________________________________________________________
Date: Jul 21, 2010
Jack, Typically, the "generators" are along the road south of the gas pump. Look forward to meeting you. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305716#305716 ________________________________________________________________________________
Date: Jul 21, 2010
Subject: Re: Bit of progress
We dropped our ailerons by about 1/2 " on both sides for wash out,not sure about =0Astrut size,I'll have to check that.=0A=0AAnd yes no dihedral on a split wing either.=0A=0A=0A________________________________=0AFrom: carson =0ATo: pietenpol-list(at)matronics.com=0ASent: Wed, July 21, 2010 6:11:52 AM=0ASubject: Pietenpol-List: Bit of progress=0A=0A-- =0AHi guys=0Awhat a great feeling I just had to share=0AAlso would like to ask opinions =0AI am planning on no Dihedral but a bit of washout by making the rear strut 3/4 =0Aof an inch longer is this how others have done it? W ould 3/4 be to much or to =0Alittle?=0AThanks =0ACarson=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p= 305712#305712=0A=0A=0A=0A=0AAttachments: =0A=0Ahttp://forums.matronics.com/ /files/pietenpol_096_366.jpg=0Ahttp://forums.matronics.com//files/pietenpol _094_311.jpg=0Ahttp://forums.matronics.com//files/pietenpol_100_185.jpg=0A =========================0A ================= ________________________________________________________________________________
Subject: WX forecast Chicago
Date: Jul 21, 2010
Wednesday Partly cloudy HI 88=C2=B0 LO 72=C2=B0 A few isolated thunderstorms possible Wednesday afternoon affecting only 10 to 20 percent of Chicago's far southern suburbs. Sunshine mixed with cottony cumulus clouds, quite warm and fairly humid. Wednesday's highs av erage 4 degrees above normal. A light, variable large-scale wind regime al lows onshore (easterly) lake breezes to develop by afternoon. Partly cloud y Wednesday night, warm and moderately humid. Thursday Thunderstorms HI 83=C2=B0 LO 76=C2=B0 Extensive cloudiness, more humid. Storms capable of downpours and gusty wi nds develop by afternoon affecting more than 60 percent of the area. Heavi est downpours could produce quick 1 to 2 inches of rain. Friday Mostly cloudy HI 97=C2=B0 LO 75=C2=B0 Possibly hottest day of the year and potentially the hottest of the past four years. Partly sunny, windy, hot, humid. Gusty or severe storms after noon and/or evening over as much as 70 percent of the area. Saturday Thunderstorms HI 85=C2=B0 LO 67=C2=B0 Opens humid. Clusters of showers and possible storms affect up to 60 perce nt of the area. Storms settle south, exiting the area late morning and aft ernoon. Cloud breaks follow. Winds shift northwest 8 to 18 mph. Sunday Partly cloudy HI 85=C2=B0 LO 66=C2=B0 Sun and cottony fair weather clouds, warm and less humid. Light northeast breezes at 5 to 14 mph. ________________________________________________________________________________
Subject: New cylinder - low oil pressure?
Date: Jul 21, 2010
Dan: my oil pressure stays up in the 35+ range once the engine is fired up and running, hot or cold. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jul 21, 2010
Subject: Fwd: CorvAircraft> New Oshkosh notes.
>From William Wynne: Friends, You can click on this link to read a slightly updated version of our Oshkosh plans. _http://FlyCorvair.com/hangar.html_ (http://FlyCorvair.com/hangar.html) If you are headed to the show, come to our booth and we will take a minute to introduce you to everyone. If some one would forward this to the Piet list I would appreciate it. Thank you. William Wynne 5000-18 HWY 17 #247 Orange Park, FL 32003 _http://FlyCorvair.com/hangar.html_ (http://flycorvair.com/hangar.html) _http://ZenVair.com_ (http://flycorvair.com/) ________________________________________________________________________________
Subject: Big Piet meets little Piet
Date: Jul 21, 2010
Tim: I have no idea what make or model of engine is on the 1/2-scale Air Camper, but the builder mentioned that it is 20HP. Full-size Piets have flown on less ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Date: Jul 21, 2010
For me, lifting the wing and supporting it with a kind of scaffold THEN measuring the struts/strut fittings was the only way I could get the wings where I wanted them. I found that a tiny bit of difference in the wings (I can't imagine 2 perfectly exact hand made wings or anything else for that matter) made each fitting a tiny bit different. Rather than making fittings and "bolting it up", I would recommend putting the wing where you want it THEN building the struts and strut fittings around that.... Now that I think about it, I believe the curve of the fuse and such made it impossible for me to make one set of struts then just "add or subtract an exact amount" from the length of the other. Maybe I'm over thinking this (or just don't know what I'm talking about, as usual) but I don't think I was able to make such a simple adjustment. Those dimensions ended up being a bit more "custom fit" for mine as I recall. Maybe after another cup of coffee I wonder where I came up with all this... :-) jm -----Original Message----- >From: carson <carsonvella(at)yahoo.com.au> >Sent: Jul 21, 2010 5:11 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Bit of progress > > >Hi guys >what a great feeling I just had to share >Also would like to ask opinions >I am planning on no Dihedral but a bit of washout by making the rear strut 3/4 of an inch longer is this how others have done it? Would 3/4 be to much or to little? >Thanks >Carson > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=305712#305712 > > >Attachments: > >http://forums.matronics.com//files/pietenpol_096_366.jpg >http://forums.matronics.com//files/pietenpol_094_311.jpg >http://forums.matronics.com//files/pietenpol_100_185.jpg > > ________________________________________________________________________________
Date: Jul 21, 2010
You might want to try a MiracleAntenna, http://www.miracleantenna.com/.- It is =0Amy understanding that it is a 1/2 wave antenna and does not need a ground =0Aplane.- Most aircraft antennas are 1/4 wave antennas and requi re-a-ground plane =0Ato provide the-other half of the antenna.=0A-M ike Volckmann =0A=0A=0AThe only thing we ever learn from history is that we never learn from history. =0AGeorge Bernard Shaw =0A=0A=0A=0A=0A=0A_______ _________________________=0AFrom: Dan P <dlplett(at)swko.net>=0ATo: pietenpol- list(at)matronics.com=0ASent: Tue, July 20, 2010 5:56:30 PM=0ASubject: Pietenp ol-List: Re: IGNITION SHIELDING Needed on A-65=0A=0A--> Pietenpol-List mess age posted by: "Dan P" =0A=0AThis antenna needs a ground plane.- There aren't any locations that are of a =0Asignificant distance from the engine.=0A=0A--------=0ADan Plett=0A=0A=0A=0A=0ARead this topic on line here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=305669#305669 ======================= ________________________________________________________________________________
Date: Jul 21, 2010
A couple months ago a I spotted an aircamper at Hampton NewHampshire that was in its final rigging phase. He used a slick idea to rig his wings. A couple of temporary telescoping pieces of electrical conduit with the telescoping bit suitably sliced and a hose clamp allowed for a infinitely adjustable strut previous to making up the permanent ones to the resulting length needed. Hope the attached pictures show the detail well enough. Michael in Maine ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> > > For me, lifting the wing and supporting it with a kind of scaffold THEN measuring the struts/strut fittings was the only way I could get the wings where I wanted them. ________________________________________________________________________________
Date: Jul 21, 2010
a closer picture of the adjustable temporary strut. Michael ________________________________________________________________________________
Subject: A few more pix of N666TB at Hampton NH
Date: Jul 21, 2010
Date: Jul 21, 2010
I was wondering, as it looked compact and perhaps light. In 2006 I saw a fellow at Brodhead with a single place mini-air camper. He had BP airfoils, wings shortened by a couple of feet on either side, and maybe the Hstab and elevators a little shorter. The engine was a Kawasaki 450. It had no mufflers and was really noisy, but it seemed to fly just fine. He was largely ignored by the purists. -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: Jul 21, 2010 7:51 AM >To: Pietenpol List >Subject: Pietenpol-List: Big Piet meets little Piet > > >Tim: I have no idea what make or model of engine is on >the 1/2-scale Air Camper, but the builder mentioned that >it is 20HP. > >Full-size Piets have flown on less ;o) > >Oscar Zuniga >Air Camper NX41CC >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net >_________________________________________________________________ >The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. >http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 > > ________________________________________________________________________________
Date: Jul 21, 2010
Subject: Re: A few more pix of N666TB at Hampton NH
Nice pics! I like that antennae location... Hey Mike, if you're ever there again could you please get a picture of how the retractable step is mounted inside the fuse? Assume it slides into another piece of tubing but wonder how that tubing is fastened to the fuse. I've been wrestling with that for a long time... thanks for the pictures! Someone's built a nice looking GN1 there..... jm -----Original Message----- >From: Michael Silvius <silvius(at)gwi.net> >Sent: Jul 21, 2010 10:09 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: A few more pix of N666TB at Hampton NH > ________________________________________________________________________________
Date: Jul 21, 2010
No true! Not true! My dad and I spent quite a bit of time talking with the fellow and his wife. The wife was a very nice, outgoing person. Hubby was much quieter. I think they've been to more than one B'head, 'cause the year I talked with them, the K450 had a muffler. > >I was wondering, as it looked compact and perhaps light. > >In 2006 I saw a fellow at Brodhead with a single place mini-air >camper. He had BP airfoils, wings shortened by a couple of feet on >either side, and maybe the Hstab and elevators a little shorter. >The engine was a Kawasaki 450. It had no mufflers and was really >noisy, but it seemed to fly just fine. He was largely ignored by >the purists. > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Jul 21, 2010
Jim: DJ's old site shows several pictures on how he did it. http://www.imagedv.com/aircamper/log/image-pages/03-08-04.htm I am thinking potentialy you could even have a bunge on the inside so it is self retracting though that may complicate dismount. Michael ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> > > Hey Mike, if you're ever there again could you please get a picture of how the retractable step is mounted inside the fuse? Assume it slides into another piece of tubing but wonder how that tubing is fastened to the fuse. I've been wrestling with that for a long time... > > thanks for the pictures! Someone's built a nice looking GN1 there..... > ________________________________________________________________________________
Date: Jul 21, 2010
Nice looking GN-1 and I like the adjustable strut length jig idea. > From: silvius(at)gwi.net > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: A few more pix of N666TB at Hampton NH > Date: Wed=2C 21 Jul 2010 10:09:25 -0500 > _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H otmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid= PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Date: Jul 21, 2010
Are you sure you weren't looking at a Roger Mann RW-1 "Ragwing Ultra Piet"? http://www.ragwing.net/fleet/RW01Ultra-Piet.html -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305785#305785 ________________________________________________________________________________
Date: Jul 21, 2010
Thanks Michael, I like DJ's way of doing it. I remember seeing this a long time ago but had forgotten....thanks for the reminder! DJ had a lot of really neat ideas. jm -----Original Message----- >From: Michael Silvius <silvius(at)gwi.net> >Sent: Jul 21, 2010 12:43 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: A few more pix of N666TB at Hampton NH > > >Jim: > >DJ's old site shows several pictures on how he did it. >http://www.imagedv.com/aircamper/log/image-pages/03-08-04.htm > >I am thinking potentialy you could even have a bunge on the inside so it is >self retracting though that may complicate dismount. > >Michael > > >----- Original Message ----- >From: "Jim Markle" <jim_markle(at)mindspring.com> >> >> Hey Mike, if you're ever there again could you please get a picture of how >the retractable step is mounted inside the fuse? Assume it slides into >another piece of tubing but wonder how that tubing is fastened to the fuse. >I've been wrestling with that for a long time... >> >> thanks for the pictures! Someone's built a nice looking GN1 there..... >> > > ________________________________________________________________________________
Date: Jul 21, 2010
Oscar, Dunno. It is possible. I do not recall the details from conversations from 4 years ago, but at the time I believed this fellow had scaled down plans for the Piet and then built it accordingly. I recall sitka materials and (I think) latex paint. As I recall he also had a reduction drive of his own fabrication, and had added marker lights driven off a turn signal blinker. My buddy Ron and I found him an interesting fellow, and he and his wife quite pleasant. I think they might have been from Minnesota or northern Wisconsin. I found his plane novel and interesting, but not something I wanted to build. For myself if I were going simple, slow, and historic like a Piet, but single place, I would not build half-a-Piet or some such, or a Scout, but likely a FlyBaby. Of course, that is another whole subject worthy of further discussion. Tim in central TX -----Original Message----- >From: taildrags <taildrags(at)hotmail.com> >Sent: Jul 21, 2010 12:55 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Big Piet meets little Piet > > >Are you sure you weren't looking at a Roger Mann RW-1 "Ragwing Ultra Piet"? > >http://www.ragwing.net/fleet/RW01Ultra-Piet.html > >-------- >Oscar Zuniga >San Antonio, TX >Air Camper NX41CC > > > ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Jul 21, 2010
Roger Mann sells plans for the "Ultra Piet" under the Rag Wing company name. A google search will probably yield a website and more info. If memory serves me correctly, he uses the KAW 440 almost exclusively in his single seat designs. The Ultra Piet is a single seat design, and sounds similiar to what you're describing (I don't know about the airfoils, etc). Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com On Jul 21, 2010, at 11:50 AM, Tim Willis wrote: > > > > I was wondering, as it looked compact and perhaps light. > > In 2006 I saw a fellow at Brodhead with a single place mini-air > camper. He had BP airfoils, wings shortened by a couple of feet on > either side, and maybe the Hstab and elevators a little shorter. > The engine was a Kawasaki 450. It had no mufflers and was really > noisy, but it seemed to fly just fine. He was largely ignored by > the purists. > > > -----Original Message----- >> From: Oscar Zuniga <taildrags(at)hotmail.com> >> Sent: Jul 21, 2010 7:51 AM >> To: Pietenpol List >> Subject: Pietenpol-List: Big Piet meets little Piet >> >> > >> >> >> Tim: I have no idea what make or model of engine is on >> the 1/2-scale Air Camper, but the builder mentioned that >> it is 20HP. >> >> Full-size Piets have flown on less ;o) >> >> Oscar Zuniga >> Air Camper NX41CC >> San Antonio, TX >> mailto: taildrags(at)hotmail.com >> website at http://www.flysquirrel.net >> _________________________________________________________________ >> The New Busy think 9 to 5 is a cute idea. Combine multiple >> calendars with Hotmail. >> http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 >> >> >> >> > > ________________________________________________________________________________
Date: Jul 21, 2010
N8031 had an antenna mounted to the wing faring. I took it off, but the previous owner had no problem with it there and the ignition cables are unshielded. Dan On 07/20/2010 07:56 PM, Dan P wrote: > --> Pietenpol-List message posted by: "Dan P" > > This antenna needs a ground plane. There aren't any locations that are of a significant distance from the engine. > > -------- -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 21, 2010
Wing faring? Where is that located? > >N8031 had an antenna mounted to the wing faring. I took it off, but >the previous owner had no problem with it there and the ignition >cables are unshielded. > >Dan > ________________________________________________________________________________
Date: Jul 21, 2010
With all the wind resistance of a Piet I figured why retract a step? So I did a fixed one. rick On Wed, Jul 21, 2010 at 11:43 AM, Michael Silvius wrote: > > Jim: > > DJ's old site shows several pictures on how he did it. > http://www.imagedv.com/aircamper/log/image-pages/03-08-04.htm > > I am thinking potentialy you could even have a bunge on the inside so it is > self retracting though that may complicate dismount. > > Michael > > > ----- Original Message ----- > From: "Jim Markle" <jim_markle(at)mindspring.com> > > > > Hey Mike, if you're ever there again could you please get a picture of > how > the retractable step is mounted inside the fuse? Assume it slides into > another piece of tubing but wonder how that tubing is fastened to the fuse. > I've been wrestling with that for a long time... > > > > thanks for the pictures! Someone's built a nice looking GN1 there..... > > > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jul 21, 2010
Douwe, there is really nutt'n to it, save the big money.- Like others on here have said it's just a bunch of remove and replace stuff.- Buy the ma rvell scebler manual with the updates and the overhaul kit and fix her up. - Just be sure to get it good and cleaned out before assembly, dirt and g rime finds its way into those tiny jets and passages.- Have heard small g uitar string is good for roto-rootering them out, but haven't tried it myse lf.- Just dont grind or remove the material while cleaning. - Shad - P.S.- since I am not going to Brodhead I will go out and work on my airpl ane.=0A=0A=0A ________________________________________________________________________________
Date: Jul 21, 2010
Subject: Riblett 612 or 613.5, and jigs too...
Hi All: Can anyone recall where the Riblett 613.5 was discussed as potentially a better airfoil for the Piet than the 612? I think I remember seeing this somewhere but I can't seem to find it in the archives. I know the 613.5 is a thicker airfoil, and I am looking for a higher lift from my wing verses the original FC-10 due to the air density here in Central California. So far I have one 613.5 and one 612 built. I have built a computer generated and CNC cut Peg Jig's for both airfoils, and I finished recently a really accurate stick cutting jig for the individual rib sticks. But, I paused the project, and am now going to pick back up again soon. Thanks for the memory help! -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax ________________________________________________________________________________
Subject: Re: WX forecast Chicago
Date: Jul 21, 2010
And here's the weather from only 32 mi. north of Brodhead. Tomorrow Thurs.Temps ranging from 70 @ 7AM to77 @ noon Winds south @ 12 - 15 mph some possibl light rain Afternoon temps ranging from 80 - 89 by 4PM winds shifting to 19 SW around 3 Pm continued light rain with brief possible downpour. Friday- Temps ranging from 82 @ 7AM to87 @ noon Winds in the morning 13 - 15 out of the west shifting to the SW around 10AM Possible light rain in the afternoon temps 86 wind w @ 13 On Jul 21, 2010, at 6:06 AM, helspersew(at)aol.com wrote: > Wednesday > Partly cloudy > HI > 88=B0 > LO > 72=B0 > A few isolated thunderstorms possible Wednesday afternoon affecting > only 10 to 20 percent of Chicago's far southern suburbs. Sunshine > mixed with cottony cumulus clouds, quite warm and fairly humid. > Wednesday's highs average 4 degrees above normal. A light, variable > large-scale wind regime allows onshore (easterly) lake breezes to > develop by afternoon. Partly cloudy Wednesday night, warm and > moderately humid. > Thursday > Thunderstorms > HI > 83=B0 > LO > 76=B0 > Extensive cloudiness, more humid. Storms capable of downpours and > gusty winds develop by afternoon affecting more than 60 percent of > the area. Heaviest downpours could produce quick 1 to 2 inches of > rain. > Friday > Mostly cloudy > HI > 97=B0 > LO > 75=B0 > Possibly hottest day of the year and potentially the hottest of the > past four years. Partly sunny, windy, hot, humid. Gusty or severe > storms afternoon and/or evening over as much as 70 percent of the > area. > Saturday > Thunderstorms > HI > 85=B0 > LO > 67=B0 > Opens humid. Clusters of showers and possible storms affect up to 60 > percent of the area. Storms settle south, exiting the area late > morning and afternoon. Cloud breaks follow. Winds shift northwest 8 > to 18 mph. > Sunday > Partly cloudy > HI > 85=B0 > LO > 66=B0 > Sun and cottony fair weather clouds, warm and less humid. Light > northeast breezes at 5 to 14 mph. > > ________________________________________________________________________________
From: "bubbleboy" <scott.dawson(at)optusnet.com.au>
Date: Jul 22, 2010
Hi Tom...keep us informed. I am interested in what you are doing. -------- Scotty Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305903#305903 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: generator campers
Date: Jul 22, 2010
FYI everyone with campers on wheels, and generators... Last year someone drove their small rv across to the trees and was asked to move it back along the road to the south as that area is for tent camping only. See ya'll there!! Douwe ________________________________________________________________________________
Subject: Wx forecast- Chicago
Date: Jul 22, 2010
Thursday Thunderstorms HI 87=C2=B0 LO 77=C2=B0 The Chicago area is at risk for severe thunderstorms this afternoon and ev ening. A weather watch may become necessary over sections of the area Exte nsive cloudiness, warm, humid and turning breezy this afternoon. Southeast winds become southerly increasing 11 to 23 mph and gusty. Showers and thu nderstorms develop later this morning then sweep the area in clusters this afternoon and evening. 40 to 60 percent of the Chicago area may be expose d to rainfall and some storms may grow severe this afternoon and evening with downpours and strong winds possible in the heavier storms. Storms ex it early Thursday night then scattered clouds, windy, very warm and muggy. Friday Mostly cloudy HI 96=C2=B0 LO 75=C2=B0 Potentially 2010's hottest. Peak heat indexes surge above 100-degrees. A temp of 95 or higher at O'Hare would be this area's hottest in 4 years. Partly sunny, windy, very humid. Isolated strong t-storms possible. Saturday Mostly cloudy HI 90=C2=B0 LO 69=C2=B0 A cloud/sun mix, quite warm, humid. Rain-free periods, but clusters of thu nderstorms may affect up to 60 percent of the metro area. Downpours and gu sts possible in a few of the heavier storms. Southwest winds shift westerl y then in the afternoon=C3=A2=C2=C2=94then north 6 to 17 mph by evening . Sunday Partly cloudy HI 82=C2=B0 LO 66=C2=B0 A mix of sun and cottony clouds, cooler and less humid. Northeast winds 6 to 14 mph may limit highs to the 70s at the beaches while the warmest inl and locations reach the mid 80s. ________________________________________________________________________________
Date: Jul 22, 2010
Carson: Most, if not all Piets I've ever seen have threaded fork ends at the lower end of the wing struts to allow adjusting the wing rigging prior to tightening the strut X-brace wires. The fork ends on 41CC have plenty of threads on the ends, probably enough to allow 3/4" differential between fore and aft struts, but I do not have any washout rigged into the wings. As someone else noted, Corky rigged 41CC such that the aileron trailing edges droop maybe 1/2"-5/8" below the trailing edge of the wing, providing the same effect as washout (more lift at the wingtips than at the roots). People always tell me my airplane is out of rig; I tell them that's the way Corky said to do it. Then I fly merrily into the sky ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jul 22, 2010
Mark; Why not ask Harry Riblett about the 612 vs. 613.5? I believe he's still around and talks freely with homebuilders. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ The New Busy is not the old busy. Search, chat and e-mail from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_3 ________________________________________________________________________________
Date: Jul 22, 2010
I've just been corrected: > Oscar, > What you've described is Wash-IN. Wash-OUT gives > a higher angle of incidence at the root than at the tip > in order start a stall at the root first. You want the > tips to keep flying after a stall has initiated, > keeping aileron control as long as possible. > The people who tell you 41CC is out of rig are correct. > Mike Hardaway Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Date: Jul 22, 2010
Oscar, What you've described is Wash-IN. Wash-OUT gives a higher angle of incidence at the root than at the tip in order start a stall at the root first. You want the tips to keep flying after a stall has initiated, keeping aileron control as long as possible. The people who tell you 41CC is out of rig are correct. Mike Hardaway -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Thursday, July 22, 2010 5:47 AM Subject: Pietenpol-List: Bit of progress --> Carson: Most, if not all Piets I've ever seen have threaded fork ends at the lower end of the wing struts to allow adjusting the wing rigging prior to tightening the strut X-brace wires. The fork ends on 41CC have plenty of threads on the ends, probably enough to allow 3/4" differential between fore and aft struts, but I do not have any washout rigged into the wings. As someone else noted, Corky rigged 41CC such that the aileron trailing edges droop maybe 1/2"-5/8" below the trailing edge of the wing, providing the same effect as washout (more lift at the wingtips than at the roots). People always tell me my airplane is out of rig; I tell them that's the way Corky said to do it. Then I fly merrily into the sky ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:W L:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jul 22, 2010
So I guess I am slightly confused about why one would droop the ailerons instead of washout. My understanding (solely from my reading of Stick and Rudder) was that the purpose of washout was not to create lift per se, but rather to decrease the angle of attack of the tips of the wings, preventing the tips from stalling first. By that logic, wouldn't drooping the ailerons increase the angle of attack on the at the tips, making the problem worse? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305929#305929 ________________________________________________________________________________
Subject: Brodhead fly-in still on? weather is bad.
From: "motorbikemikexb9" <motorbikemikexb9(at)comcast.net>
Date: Jul 22, 2010
Dose anyone know if the brodhead fly-in is still happening. I'm planing to drive up Saturday but the weather looks stormy. If it is storming is it totally called off? I was hoping to make it up there to photograph and look at the uncovered Piet that was to be on display. It would me help fill in a couple of the blanks on the old drawings. I'd love to get some input from other builders as well. Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305930#305930 ________________________________________________________________________________
Subject: Re: Brodhead fly-in still on? weather is bad.
Date: Jul 22, 2010
Just talked to Ryan - about 8 people were there at 8am and 4 piets were on the field. I'll be heading up during the lull around noon. Dan -- yocum(at)gmail.com ________________________________________________________________________________
From: "Perry Rhoads" <prhoads61(at)frontiernet.net>
Date: Jul 22, 2010
It's on! A little wet right now, but it'll get better. Perry Rhoads N12939 sent from Brodhead ----- Original Message ----- From: "motorbikemikexb9" <motorbikemikexb9(at)comcast.net> Sent: Thursday, July 22, 2010 8:44 AM Subject: Pietenpol-List: Brodhead fly-in still on? weather is bad. > > > Dose anyone know if the brodhead fly-in is still happening. I'm planing > to drive up Saturday but the weather looks stormy. If it is storming is > it totally called off? I was hoping to make it up there to photograph and > look at the uncovered Piet that was to be on display. It would me help > fill in a couple of the blanks on the old drawings. I'd love to get some > input from other builders as well. > > Thanks, Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305930#305930 > > > ________________________________________________________________________________
Date: Jul 22, 2010
I beleive Mike Cuy did the same thing with his ailerons. rick On Thu, Jul 22, 2010 at 6:46 AM, Oscar Zuniga wrote: > > > Carson: > > Most, if not all Piets I've ever seen have threaded > fork ends at the lower end of the wing struts to > allow adjusting the wing rigging prior to tightening > the strut X-brace wires. The fork ends on 41CC have > plenty of threads on the ends, probably enough to allow > 3/4" differential between fore and aft struts, but > I do not have any washout rigged into the wings. > > As someone else noted, Corky rigged 41CC such that the > aileron trailing edges droop maybe 1/2"-5/8" below the > trailing edge of the wing, providing the same effect > as washout (more lift at the wingtips than at the > roots). People always tell me my airplane is out of > rig; I tell them that's the way Corky said to do it. > > Then I fly merrily into the sky ;o) > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > _________________________________________________________________ > Hotmail is redefining busy with tools for the New Busy. Get more from your > inbox. > > http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_2 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jul 22, 2010
My pietenpol has a little droop at the trailing edge of the aileron too.(3 /8") But only while at rest on the ground, in the air there is none. Rigging of the fixed part of the wing is "0" wash-out. Hans NX 15KV -----Original Message----- From: Oscar Zuniga <taildrags(at)hotmail.com> Sent: Thu, Jul 22, 2010 7:46 am Subject: Pietenpol-List: Bit of progress arson: ost, if not all Piets I've ever seen have threaded ork ends at the lower end of the wing struts to llow adjusting the wing rigging prior to tightening he strut X-brace wires. The fork ends on 41CC have lenty of threads on the ends, probably enough to allow /4" differential between fore and aft struts, but do not have any washout rigged into the wings. s someone else noted, Corky rigged 41CC such that the ileron trailing edges droop maybe 1/2"-5/8" below the railing edge of the wing, providing the same effect s washout (more lift at the wingtips than at the oots). People always tell me my airplane is out of ig; I tell them that's the way Corky said to do it. hen I fly merrily into the sky ;o) Oscar Zuniga ir Camper NX41CC an Antonio, TX ailto: taildrags(at)hotmail.com ebsite at http://www.flysquirrel.net ________________________________________________________________ otmail is redefining busy with tools for the New Busy. Get more from your nbox. ttp://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_2 ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jul 22, 2010
Many times Ive heard builders mention building a flat wing or one with no dihedral. I hope Vi Kapler will jump in if Im wrong, but I believe Bernard would have two people lift up on the wing tips when he measured for the wing struts thereby introducing a slight dihedral on his single piece flat wing. Having flown a Piet with anhedral (wingtips lower), I can warn you that you do not want to experience it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305976#305976 ________________________________________________________________________________
Date: Jul 22, 2010
Subject: Re: Riblett 612 or 613.5, and jigs too...
Good idea Oscar. I did in fact try to call him on the issue a couple of months ago, and left a message, but I wasn't sure if he was indeed still around, so I chickened out on calling again. I didn't think to call back this time, so i think I will give another shout out to him on this issue. Thanks for the suggestion. Mark On Thu, Jul 22, 2010 at 5:54 AM, Oscar Zuniga wrote: > > > Mark; > > Why not ask Harry Riblett about the 612 vs. 613.5? > I believe he's still around and talks freely with > homebuilders. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > _________________________________________________________________ > The New Busy is not the old busy. Search, chat and e-mail from your inbox. > http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_3 > > -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax ________________________________________________________________________________
Date: Jul 22, 2010
Mark, Riblett is certainly the authority on his own airfoils and any response you get will no doubt be illuminating. Please share. This board likely knows more about Pietenpols and their flying characteristics than Harry Riblett, though, and has at least some anecdotal comparisons specific to Piets. We may know some stories Riblett does not know, and he some of which we are uninformed, in mating Ribletts to Piets. What's more, I think YOUR choice to a degree, though, relates to what engine and what applications you have or intend. Do you have a 60+hp A-65 or a 90+hp Corvair? Do you want to get off the ground and over 50' AGL in a hurry, or want to cruise faster? How is this preference reflected... do you have a climb prop or a cruise prop? Is your challenging app to fly 1000 miles to Brodhead with full fuel but a light load, as quickly as a Piet can, or to take a heavy friend flying on a hot day? Both Riblett airfoils are reputed to give more lift, less drag than the BP airfoil. No one has put them up to a side-by-side test.*** (see below) None of them-- Riblett or BP-- unlike the NACA 2412, for instance, have been in wind tunnels. Likely comparisons: --The 613.5 should have both more lift and drag than the 612. --The 612 should have more lift and less drag than BP's FC10. --The 612 should be faster than the 613.5 and BP's FC10. --All else equal, you should attain 50' AGL faster with the 613.5 --You might have the gentlest stall with the 613.5... this remains to be seen. Some may rightly disagree with each of these statements. You can change a lot of the flight dynamics witha ANY airfoil by building the Piet as light as possible, powering it up a bit, and/or by adding some wingspan. With a thicker section and chord on a 613.5, little changes in the angle of incidence (from the 2 degrees of the FC10) might tune the Riblett quite differently to achieve a different optimum. Who has worked on this? Kept a lab book? Both considered and accommodated differential pitching moments? ***Note: Lowell Frank has had different wings, featuring BP's FC 10 and NACA 2412, on the same plane with the same engine. Then he changed to a more powerful engine. He has the closest to comaparative data. Some of the Riblett 612 and 613.5s are just coming on line now. (If memory serves, check with Roman Bukolt, for instance.) This is just grist for the mill... there are many other considerations. Adherence to the original design, with its well known envelope, are two. But it is your plane and your applications. In my case, starting afresh, as a fat boy in a warm climate, with an A-65, I would go with the Riblett 613.5 and add wingspan, as well. And go on a diet, too. Tim in central TX -----Original Message----- >From: Mark Roberts <mark.rbrts1(at)gmail.com> >Sent: Jul 22, 2010 3:11 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Riblett 612 or 613.5, and jigs too... > > >Good idea Oscar. I did in fact try to call him on the issue a couple >of months ago, and left a message, but I wasn't sure if he was indeed >still around, so I chickened out on calling again. I didn't think to >call back this time, so i think I will give another shout out to him >on this issue. > >Thanks for the suggestion. > >Mark > >On Thu, Jul 22, 2010 at 5:54 AM, Oscar Zuniga wrote: >> >> >> Mark; >> >> Why not ask Harry Riblett about the 612 vs. 613.5? >> I believe he's still around and talks freely with >> homebuilders. >> >> Oscar Zuniga >> Air Camper NX41CC >> San Antonio, TX >> mailto: taildrags(at)hotmail.com >> website at http://www.flysquirrel.net >> ______________________________________________________________ >> >-- >Mark Roberts >California Laser Etch >www.california-laser.com >888-882-5015 >888-882-5016 fax > > ________________________________________________________________________________
Date: Jul 22, 2010
If you plan on putting dihedral in your wings (3 piece) You will probably w ant to cut the outboard wing pannel spar butt ends with a little bit of an angle (not a square 90 deg angle) to allow the top side of the spars to hav e clearance , and not hit the centersection spar butts after puting in your dihedral. - Here's to you in Brodhead, wish I could have made it, Shad=0A=0A=0A ________________________________________________________________________________
Date: Jul 22, 2010
Weather's better this afternoon. Windy, but partly sunny....and hot, of course. 6 Piets on the ground, a Sky Scout in the air, and two more about to arrive. Good times! Ryan Sent from my iPad On Jul 22, 2010, at 8:44 AM, "motorbikemikexb9" wrote: > > Dose anyone know if the brodhead fly-in is still happening. I'm planing to drive up Saturday but the weather looks stormy. If it is storming is it totally called off? I was hoping to make it up there to photograph and look at the uncovered Piet that was to be on display. It would me help fill in a couple of the blanks on the old drawings. I'd love to get some input from other builders as well. > > Thanks, Mike > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=305930#305930 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 22, 2010
Just saw Jack and Randy fly over the house- on their way. They should be there very soon. Storms on radar just north of you. Tornado warnings for southern Wis. Batten down, and I'll see you tomorrow morning!!! Dan Helsper Poplar Grove, IL. -----Original Message----- From: Ryan Mueller <rmueller23(at)gmail.com> Sent: Thu, Jul 22, 2010 5:03 pm Subject: Re: Pietenpol-List: Brodhead fly-in still on? weather is bad. Weather's better this afternoon. Windy, but partly sunny....and hot, of co urse. Piets on the ground, a Sky Scout in the air, and two more about to arrive . ood times! Ryan Sent from my iPad On Jul 22, 2010, at 8:44 AM, "motorbikemikexb9" <motorbikemikexb9@comcast. net> rote: b9(at)comcast.net> Dose anyone know if the brodhead fly-in is still happening. I'm planing to rive up Saturday but the weather looks stormy. If it is storming is it to tally alled off? I was hoping to make it up there to photograph and look at the ncovered Piet that was to be on display. It would me help fill in a coupl e of he blanks on the old drawings. I'd love to get some input from other buil ders s well. Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=305930#305930 -======================== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jul 22, 2010
HA! Tim, that was the best said response to date of any of my post replies.... Especially the Lose Weight part (all the years when I was as skinny as a noodle and made fun of fat folk is coming back to bit me in the belly... My legs are still so skinny I have considered suing them for non-support...) All kidding aside, I really do appreciate your reply, as it was a good summary of the design thoughts, and was presented very nicely--- (Not "Why the H#ll do you want to do that? Just build it the way he designed it!!") To update all: I did just hang up from a delightful 20 minute call to Harry Riblett. We discussed the airfoil and the plane design, and while I appreciate that he has not built and flown a Piet, he does understand the basic design and the flight dynamics of it. Before i pass along his thoughts (as of today 7/22/10), I want to explain (again) why I would even mess around with the design in the first place. I'm 6'4" and 250lbs. Even with a dramatic weight loss, I'd still like my wife to go along if the temp in Central California goes above 90 degrees (about 6 months outta the year...). So, since my wife actually LIKES the Piet design (a first for the ones I have shown her), I'd like the extra lift I will need to fly comfortably. I called Harry to ask (as Oscar suggested.... Thanks Oscar!) which would be better for me to use: the GA30-612 or the GA30-613.5. (He kept correcting me when I simply said 'the 612 or the 613.5... "It's the GA30-613.5..."). He said the GA30-613.5 was the one I would want to go with due to the higher lifting co-efficient of the airfoil. He said about 1 degree of incidence would be good, as I mentioned that Lowell had to hold 30-40 lbs of forward stick at cruise. I also know that a couple of extra feet on the wing tips would help, and that I'll need to account for that in tail area as well. But, as to the 2 airfoils that have been batted about in the forum, he seemed to think the GA30-613.5 would be a better choice if one was considering an alternative to the original FC-10. Now, I know there are lots of opinions about this, so I am not trying to start another war, but just passing along the discussion I had with him about the differences with the 2 airfoils for an open cockpit, draggy high wing design. It's a 19 year update on the original letter that he wrote and has been posted on this forum in the past. :o0 To those going to Brodhead, I envy ya'll. Mark On Thu, Jul 22, 2010 at 2:00 PM, Tim Willis wrote: > > Mark, > > Riblett is certainly the authority on his own airfoils and any response you get will no doubt be illuminating. Please share. > > This board likely knows more about Pietenpols and their flying characteristics than Harry Riblett, though, and has at least some anecdotal comparisons specific to Piets. We may know some stories Riblett does not know, and he some of which we are uninformed, in mating Ribletts to Piets. > > What's more, I think YOUR choice to a degree, though, relates to what engine and what applications you have or intend. Do you have a 60+hp A-65 or a 90+hp Corvair? Do you want to get off the ground and over 50' AGL in a hurry, or want to cruise faster? How is this preference reflected... do you have a climb prop or a cruise prop? Is your challenging app to fly 1000 miles to Brodhead with full fuel but a light load, as quickly as a Piet can, or to take a heavy friend flying on a hot day? > > Both Riblett airfoils are reputed to give more lift, less drag than the BP airfoil. No one has put them up to a side-by-side test.*** (see below) > None of them-- Riblett or BP-- unlike the NACA 2412, for instance, have been in wind tunnels. > > Likely comparisons: > > --The 613.5 should have both more lift and drag than the 612. > --The 612 should have more lift and less drag than BP's FC10. > --The 612 should be faster than the 613.5 and BP's FC10. > --All else equal, you should attain 50' AGL faster with the 613.5 > --You might have the gentlest stall with the 613.5... this remains to be seen. > > Some may rightly disagree with each of these statements. > > You can change a lot of the flight dynamics witha ANY airfoil by building the Piet as light as possible, powering it up a bit, and/or by adding some wingspan. > > With a thicker section and chord on a 613.5, little changes in the angle of incidence (from the 2 degrees of the FC10) might tune the Riblett quite differently to achieve a different optimum. Who has worked on this? Kept a lab book? Both considered and accommodated differential pitching moments? > > ***Note: Lowell Frank has had different wings, featuring BP's FC 10 and NACA 2412, on the same plane with the same engine. Then he changed to a more powerful engine. He has the closest to comaparative data. Some of the Riblett 612 and 613.5s are just coming on line now. (If memory serves, check with Roman Bukolt, for instance.) > > This is just grist for the mill... there are many other considerations. Adherence to the original design, with its well known envelope, are two. But it is your plane and your applications. > > In my case, starting afresh, as a fat boy in a warm climate, with an A-65, I would go with the Riblett 613.5 and add wingspan, as well. And go on a diet, too. > > Tim in central TX > > -----Original Message----- >>From: Mark Roberts <mark.rbrts1(at)gmail.com> >>Sent: Jul 22, 2010 3:11 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Riblett 612 or 613.5, and jigs too... >> >> >>Good idea Oscar. I did in fact try to call him on the issue a couple >>of months ago, and left a message, but I wasn't sure if he was indeed >>still around, so I chickened out on calling again. I didn't think to >>call back this time, so i think I will give another shout out to him >>on this issue. >> >>Thanks for the suggestion. >> >>Mark >> >>On Thu, Jul 22, 2010 at 5:54 AM, Oscar Zuniga wrote: >>> >>> >>> Mark; >>> >>> Why not ask Harry Riblett about the 612 vs. 613.5? >>> I believe he's still around and talks freely with >>> homebuilders. >>> >>> Oscar Zuniga >>> Air Camper NX41CC >>> San Antonio, TX >>> mailto: taildrags(at)hotmail.com >>> website at http://www.flysquirrel.net > >>> ______________________________________________________________ >>> >-- >>Mark Roberts >>California Laser Etch >>www.california-laser.com >>888-882-5015 >>888-882-5016 fax >> >> > > -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax ________________________________________________________________________________
Date: Jul 23, 2010
Mark, Glad to see you got that figured out! Any day now you will be posting pics of finished ribs! Gary Boothe Sent on the Sprint Now Network from my BlackBerry -----Original Message----- From: Mark Roberts <mark.rbrts1(at)gmail.com> Sender: owner-pietenpol-list-server(at)matronics.com Date: Thu, 22 Jul 2010 15:52:32 or 613.5, and jigs too... HA! Tim, that was the best said response to date of any of my post replies.... Especially the Lose Weight part (all the years when I was as skinny as a noodle and made fun of fat folk is coming back to bit me in the belly... My legs are still so skinny I have considered suing them for non-support...) All kidding aside, I really do appreciate your reply, as it was a good summary of the design thoughts, and was presented very nicely--- (Not "Why the H#ll do you want to do that? Just build it the way he designed it!!") To update all: I did just hang up from a delightful 20 minute call to Harry Riblett. We discussed the airfoil and the plane design, and while I appreciate that he has not built and flown a Piet, he does understand the basic design and the flight dynamics of it. Before i pass along his thoughts (as of today 7/22/10), I want to explain (again) why I would even mess around with the design in the first place. I'm 6'4" and 250lbs. Even with a dramatic weight loss, I'd still like my wife to go along if the temp in Central California goes above 90 degrees (about 6 months outta the year...). So, since my wife actually LIKES the Piet design (a first for the ones I have shown her), I'd like the extra lift I will need to fly comfortably. I called Harry to ask (as Oscar suggested.... Thanks Oscar!) which would be better for me to use: the GA30-612 or the GA30-613.5. (He kept correcting me when I simply said 'the 612 or the 613.5... "It's the GA30-613.5..."). He said the GA30-613.5 was the one I would want to go with due to the higher lifting co-efficient of the airfoil. He said about 1 degree of incidence would be good, as I mentioned that Lowell had to hold 30-40 lbs of forward stick at cruise. I also know that a couple of extra feet on the wing tips would help, and that I'll need to account for that in tail area as well. But, as to the 2 airfoils that have been batted about in the forum, he seemed to think the GA30-613.5 would be a better choice if one was considering an alternative to the original FC-10. Now, I know there are lots of opinions about this, so I am not trying to start another war, but just passing along the discussion I had with him about the differences with the 2 airfoils for an open cockpit, draggy high wing design. It's a 19 year update on the original letter that he wrote and has been posted on this forum in the past. :o0 To those going to Brodhead, I envy ya'll. Mark On Thu, Jul 22, 2010 at 2:00 PM, Tim Willis wrote: > > Mark, > > Riblett is certainly the authority on his own airfoils and any response you get will no doubt be illuminating. Please share. > > This board likely knows more about Pietenpols and their flying characteristics than Harry Riblett, though, and has at least some anecdotal comparisons specific to Piets. We may know some stories Riblett does not know, and he some of which we are uninformed, in mating Ribletts to Piets. > > What's more, I think YOUR choice to a degree, though, relates to what engine and what applications you have or intend. Do you have a 60+hp A-65 or a 90+hp Corvair? Do you want to get off the ground and over 50' AGL in a hurry, or want to cruise faster? How is this preference reflected... do you have a climb prop or a cruise prop? Is your challenging app to fly 1000 miles to Brodhead with full fuel but a light load, as quickly as a Piet can, or to take a heavy friend flying on a hot day? > > Both Riblett airfoils are reputed to give more lift, less drag than the BP airfoil. No one has put them up to a side-by-side test.*** (see below) > None of them-- Riblett or BP-- unlike the NACA 2412, for instance, have been in wind tunnels. > > Likely comparisons: > > --The 613.5 should have both more lift and drag than the 612. > --The 612 should have more lift and less drag than BP's FC10. > --The 612 should be faster than the 613.5 and BP's FC10. > --All else equal, you should attain 50' AGL faster with the 613.5 > --You might have the gentlest stall with the 613.5... this remains to be seen. > > Some may rightly disagree with each of these statements. > > You can change a lot of the flight dynamics witha ANY airfoil by building the Piet as light as possible, powering it up a bit, and/or by adding some wingspan. > > With a thicker section and chord on a 613.5, little changes in the angle of incidence (from the 2 degrees of the FC10) might tune the Riblett quite differently to achieve a different optimum. Who has worked on this? Kept a lab book? Both considered and accommodated differential pitching moments? > > ***Note: Lowell Frank has had different wings, featuring BP's FC 10 and NACA 2412, on the same plane with the same engine. Then he changed to a more powerful engine. He has the closest to comaparative data. Some of the Riblett 612 and 613.5s are just coming on line now. (If memory serves, check with Roman Bukolt, for instance.) > > This is just grist for the mill... there are many other considerations. Adherence to the original design, with its well known envelope, are two. But it is your plane and your applications. > > In my case, starting afresh, as a fat boy in a warm climate, with an A-65, I would go with the Riblett 613.5 and add wingspan, as well. And go on a diet, too. > > Tim in central TX > > -----Original Message----- >>From: Mark Roberts <mark.rbrts1(at)gmail.com> >>Sent: Jul 22, 2010 3:11 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Riblett 612 or 613.5, and jigs too... >> >> >>Good idea Oscar. I did in fact try to call him on the issue a couple >>of months ago, and left a message, but I wasn't sure if he was indeed >>still around, so I chickened out on calling again. I didn't think to >>call back this time, so i think I will give another shout out to him >>on this issue. >> >>Thanks for the suggestion. >> >>Mark >> >>On Thu, Jul 22, 2010 at 5:54 AM, Oscar Zuniga wrote: >>> >>> >>> Mark; >>> >>> Why not ask Harry Riblett about the 612 vs. 613.5? >>> I believe he's still around and talks freely with >>> homebuilders. >>> >>> Oscar Zuniga >>> Air Camper NX41CC >>> San Antonio, TX >>> mailto: taildrags(at)hotmail.com >>> website at http://www.flysquirrel.net > >>> ______________________________________________________________ >>> >-- >>Mark Roberts >>California Laser Etch >>www.california-laser.com >>888-882-5015 >>888-882-5016 fax >> >> > > -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax ________________________________________________________________________________
Date: Jul 22, 2010
Sometimes a guy has to slap his head 40 or 50 times before he finally straightens up... :o) You've been a good inspiration for me Gary! I appreciate that. Now, where's my epoxy... (Yer sure we can fly one of these things made outta Poplar?) Mark On Thu, Jul 22, 2010 at 5:10 PM, wrote: > > Mark, > > Glad to see you got that figured out! Any day now you will be posting pics of finished ribs! > > Gary Boothe > Sent on the Sprint Now Network from my BlackBerry > > -----Original Message----- > From: Mark Roberts <mark.rbrts1(at)gmail.com> > Sender: owner-pietenpol-list-server(at)matronics.com > Date: Thu, 22 Jul 2010 15:52:32 > To: > Reply-To: pietenpol-list(at)matronics.comSubject: Re: Pietenpol-List: Riblett 612 or 613.5, and jigs too... > > > HA! Tim, that was the best said response to date of any of my post > replies.... Especially the Lose Weight part (all the years when I was > as skinny as a noodle and made fun of fat folk is coming back to bit > me in the belly... My legs are still so skinny I have considered suing > them for non-support...) > > All kidding aside, I really do appreciate your reply, as it was a good > summary of the design thoughts, and was presented very nicely--- (Not > "Why the H#ll do you want to do that? Just build it the way he > designed it!!") > > To update all: > > I did just hang up from a delightful 20 minute call to Harry Riblett. > We discussed the airfoil and the plane design, and while I appreciate > that he has not built and flown a Piet, he does understand the basic > design and the flight dynamics of it. Before i pass along his thoughts > (as of today 7/22/10), I want to explain (again) why I would even mess > around with the design in the first place. > > I'm 6'4" and 250lbs. Even with a dramatic weight loss, I'd still like > my wife to go along if the temp in Central California goes above 90 > degrees (about 6 months outta the year...). > > So, since my wife actually LIKES the Piet design (a first for the ones > I have shown her), I'd like the extra lift I will need to fly > comfortably. > > I called Harry to ask (as Oscar suggested.... Thanks Oscar!) which > would be better for me to use: the GA30-612 or the GA30-613.5. (He > kept correcting me when I simply said 'the 612 or the 613.5... "It's > the GA30-613.5..."). He said the GA30-613.5 was the one I would want > to go with due to the higher lifting co-efficient of the airfoil. > > He said about 1 degree of incidence would be good, as I mentioned that > Lowell had to hold 30-40 lbs of forward stick at cruise. > > I also know that a couple of extra feet on the wing tips would help, > and that I'll need to account for that in tail area as well. > > But, as to the 2 airfoils that have been batted about in the forum, he > seemed to think the GA30-613.5 would be a better choice if one was > considering an alternative to the original FC-10. > > Now, I know there are lots of opinions about this, so I am not trying > to start another war, but just passing along the discussion I had with > him about the differences with the 2 airfoils for an open cockpit, > draggy high wing design. > > It's a 19 year update on the original letter that he wrote and has > been posted on this forum in the past. :o0 > > > To those going to Brodhead, I envy ya'll. > > Mark > > On Thu, Jul 22, 2010 at 2:00 PM, Tim Willis wrote: >> >> Mark, >> >> Riblett is certainly the authority on his own airfoils and any response you get will no doubt be illuminating. Please share. >> >> This board likely knows more about Pietenpols and their flying characteristics than Harry Riblett, though, and has at least some anecdotal comparisons specific to Piets. We may know some stories Riblett does not know, and he some of which we are uninformed, in mating Ribletts to Piets. >> >> What's more, I think YOUR choice to a degree, though, relates to what engine and what applications you have or intend. Do you have a 60+hp A-65 or a 90+hp Corvair? Do you want to get off the ground and over 50' AGL in a hurry, or want to cruise faster? How is this preference reflected... do you have a climb prop or a cruise prop? Is your challenging app to fly 1000 miles to Brodhead with full fuel but a light load, as quickly as a Piet can, or to take a heavy friend flying on a hot day? >> >> Both Riblett airfoils are reputed to give more lift, less drag than the BP airfoil. No one has put them up to a side-by-side test.*** (see below) >> None of them-- Riblett or BP-- unlike the NACA 2412, for instance, have been in wind tunnels. >> >> Likely comparisons: >> >> --The 613.5 should have both more lift and drag than the 612. >> --The 612 should have more lift and less drag than BP's FC10. >> --The 612 should be faster than the 613.5 and BP's FC10. >> --All else equal, you should attain 50' AGL faster with the 613.5 >> --You might have the gentlest stall with the 613.5... this remains to be seen. >> >> Some may rightly disagree with each of these statements. >> >> You can change a lot of the flight dynamics witha ANY airfoil by building the Piet as light as possible, powering it up a bit, and/or by adding some wingspan. >> >> With a thicker section and chord on a 613.5, little changes in the angle of incidence (from the 2 degrees of the FC10) might tune the Riblett quite differently to achieve a different optimum. Who has worked on this? Kept a lab book? Both considered and accommodated differential pitching moments? >> >> ***Note: Lowell Frank has had different wings, featuring BP's FC 10 and NACA 2412, on the same plane with the same engine. Then he changed to a more powerful engine. He has the closest to comaparative data. Some of the Riblett 612 and 613.5s are just coming on line now. (If memory serves, check with Roman Bukolt, for instance.) >> >> This is just grist for the mill... there are many other considerations. Adherence to the original design, with its well known envelope, are two. But it is your plane and your applications. >> >> In my case, starting afresh, as a fat boy in a warm climate, with an A-65, I would go with the Riblett 613.5 and add wingspan, as well. And go on a diet, too. >> >> Tim in central TX >> >> -----Original Message----- >>>From: Mark Roberts <mark.rbrts1(at)gmail.com> >>>Sent: Jul 22, 2010 3:11 PM >>>To: pietenpol-list(at)matronics.com >>>Subject: Re: Pietenpol-List: Riblett 612 or 613.5, and jigs too... >>> >>> >>>Good idea Oscar. I did in fact try to call him on the issue a couple >>>of months ago, and left a message, but I wasn't sure if he was indeed >>>still around, so I chickened out on calling again. I didn't think to >>>call back this time, so i think I will give another shout out to him >>>on this issue. >>> >>>Thanks for the suggestion. >>> >>>Mark >>> >>>On Thu, Jul 22, 2010 at 5:54 AM, Oscar Zuniga wrote: >>>> >>>> >>>> Mark; >>>> >>>> Why not ask Harry Riblett about the 612 vs. 613.5? >>>> I believe he's still around and talks freely with >>>> homebuilders. >>>> >>>> Oscar Zuniga >>>> Air Camper NX41CC >>>> San Antonio, TX >>>> mailto: taildrags(at)hotmail.com >>>> website at http://www.flysquirrel.net >> >>>> ______________________________________________________________ >>>> >-- >>>Mark Roberts >>>California Laser Etch >>>www.california-laser.com >>>888-882-5015 >>>888-882-5016 fax >>> >>> >> >> >> >> >> > > > -- > Mark Roberts > California Laser Etch > www.california-laser.com > 888-882-5015 > 888-882-5016 fax > > -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax ________________________________________________________________________________
Date: Jul 22, 2010
In Rockford for the night. Watched an awesome lightning display up north as we were driving in. Looks like we are under a thunderstorm/tornado watch at the moment, but the forecast calls for improving conditions over the next couple of days. See ya'll tomorrow. -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306054#306054 ________________________________________________________________________________
Subject: Brodhead Friday 0700
Date: Jul 23, 2010
Got here late last night during storm, raining now. Have not had a chance to get over to the main action since I'm in the "motor home" area on the far SE end of the field. Attached is a current radar image. Looks pretty cruddy for today. I would do a cam if someone would tell me how. But again, my coach is a long way from the action. Jack DSM ________________________________________________________________________________
Subject: Re: Brodhead Friday 0700
Date: Jul 23, 2010
Jack, Actually, the further away from the landing area, the better! In fact, hopefully, you are so far away that we really can't make out who, or what's landing. That will make it more like that 'other' show. No need to narrate or zoom in...just shake the camera once in awhile. :-O Wish I was there, too... Gary Boothe Sent on the Sprint Now Network from my BlackBerry -----Original Message----- From: "Jack" <jack(at)textors.com> Sender: owner-pietenpol-list-server(at)matronics.com Date: Fri, 23 Jul 2010 06:16:53 0700 This is a multi-part message in MIME format. ________________________________________________________________________________
Subject: Re: Brodhead Friday 0818 hrs
Date: Jul 23, 2010
Hi Jack, According to the "future" radar image at Weatherchannel.com, last time I looked, this stuff is suppose to dry up between 9 and 10. This is what I am hoping for, as I am pointed toward Brodhead (on the ground) and waitin g to go. Right now it is raining, and still rumbling. Glad I stayed home last night. I imagine the tenters just had a delightful evening last nigh t. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Jack <jack(at)textors.com> Sent: Fri, Jul 23, 2010 7:16 am Subject: Pietenpol-List: Brodhead Friday 0700 Got here late last night during storm, raining now. Have not had a chance to get over to the main action since I=99m in the =9Cmotor ho me=9D area on the far SE end of the field. Attached is a current ra dar image. Looks pretty cruddy for today. I would do a cam if someone would tell me how. But again, my coach is a long way from the action Jack DSM ________________________________________________________________________________
Date: Jul 23, 2010
I set up tents late yesterday afternoon against the woods.....hope they are still there! Apparently, I drove thru or near (2) tornadoes on my way home to Ft. Atkinson yesterday. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306069#306069 ________________________________________________________________________________
Subject: Lifetime Experience
Date: Jul 23, 2010
All, Yesterday was a learning experience I shall never forget or top. It brought tears to my eyes. My good friend Tom Wottreng assembled my C-85 with me. What a knowledgeable man and a good guy. I've attached a couple of pictures so as to not clutter the list. Next week when I'm home I will update my site with more shots. Jack DSM ________________________________________________________________________________
Date: Jul 23, 2010
Congrats on the new engine Jack!!! Almost like having a new baby.... Brian SLC-UT From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Friday, July 23, 2010 7:56 AM Subject: Pietenpol-List: Lifetime Experience All, Yesterday was a learning experience I shall never forget or top. It brought tears to my eyes. My good friend Tom Wottreng assembled my C-85 with me. What a knowledgeable man and a good guy. I've attached a couple of pictures so as to not clutter the list. Next week when I'm home I will update my site with more shots. Jack DSM ________________________________________________________________________________
Date: Jul 23, 2010
From: "wayne(at)taildraggersinc.com" <wayne(at)taildraggersinc.com>
Subject: R/C Piet Kit on RCGroups For Sale (Not Mine)
I saw this post today, and thought someone here might be interested in looking at this kit. It's a lot easier to build and fly a 64" wingspan model that a 1/2 scale! Here's the link: http://www.rcgroups.com/forums/showthread.php?t=1274159 Wayne Bressler Taildraggers, Inc. www.taildraggersinc.com ________________________________________________________________________________
Date: Jul 23, 2010
Hey Mark, that jig is still looking good in my garage. I haven't built one yet but it's fast becoming time. Again thanks for the jig it looks great. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306117#306117 ________________________________________________________________________________
Subject: Re: Brodhead Clearing 0730 Saturday
Date: Jul 24, 2010
Thought he may tell the list himself, but since you asked, it's Kevin Purtee's. He can most accurately provide details, but I believe he broke the left gear on takeoff. On landing it gave away completely. Within the hour, the plane was on saws horses and the gear was being welded. I would guess he will be in the air today. We are off to the other show. Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Sent: Saturday, July 24, 2010 7:07 AM Subject: Re: Pietenpol-List: Brodhead Clearing 0730 Saturday ________________________________________________________________________________
Date: Jul 24, 2010
I heard Kevin Purtee had a messed up wheel, it was bent inward or just dangling or something... He circled the field a couple times then landed nice and smooth (I have no idea how he was able to do that!) and did a nice gentle ground loop and the plane just leaned down and rested on the wing tip. Word I got (and I'm sure there's more to this...) was that his landing turned what could have easily been a bad situation into a nice, minimal damage landing he walked away from. Mark C called me right after it happened but my cell coverage out here isn't too good and I was having trouble hearing everything...so I hope I at least got some of that right! JM....in Pryor Oklahoma where the weather is depressing and disappointing because I didn't get to go to BRODHEAD!!!! -----Original Message----- From: Jeff Boatright Sent: Jul 24, 2010 8:06 AM Subject: Re: Pietenpol-List: Brodhead Clearing 0730 Saturday Jack, Thanks for the photos, but what is the wreck in the first image? And why not archive? Jeff Now clearing, nice evening last night, heavy storms overnight. Jack DSM Do not archive -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Subject: Another Piet builder in the making!
Date: Jul 24, 2010
Hello everyone! My name is Curt Merdan, and I recently began my journey to Brodhead figuratively speaking. A few months back, I was talking with my wife Laura, saying that I needed to find something to do in my freetime other than surfing the internet in a endless search for nothing. Then I came up with this crazy idea of building an airplane. Laura said that would be a great idea. Wow, I got her blessing! I went back to the internet to find the perfect airplane and guess what I found. The beautiful, wood and fabric Pietenpol Aircamper. It is the perfect tribute to my heritage. I am the son of a Seamstress and Carpenter from Minnesota. I've got my plans, wood for the tail, glue, questions and motivation! Curt Merdan 817-875-5027 Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306140#306140 ________________________________________________________________________________
Date: Jul 24, 2010
Welcome, Curt!! Where in Texas is Flower Mound? Don't forget to check out www.westcoastpiet.com. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2112 Sent: Saturday, July 24, 2010 7:33 AM Subject: Pietenpol-List: Another Piet builder in the making! Hello everyone! My name is Curt Merdan, and I recently began my journey to Brodhead figuratively speaking. A few months back, I was talking with my wife Laura, saying that I needed to find something to do in my freetime other than surfing the internet in a endless search for nothing. Then I came up with this crazy idea of building an airplane. Laura said that would be a great idea. Wow, I got her blessing! I went back to the internet to find the perfect airplane and guess what I found. The beautiful, wood and fabric Pietenpol Aircamper. It is the perfect tribute to my heritage. I am the son of a Seamstress and Carpenter from Minnesota. I've got my plans, wood for the tail, glue, questions and motivation! Curt Merdan 817-875-5027 Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306140#306140 ________________________________________________________________________________
Subject: Re: Another Piet builder in the making!
Date: Jul 24, 2010
Welcome Curt! Looking forward to hearing of your progress. -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306143#306143 ________________________________________________________________________________
Date: Jul 24, 2010
MARK!!!!!! What the heck are you doing on email?????? Get to the field!!!!!!! -----Original Message----- >From: K5YAC <hangar10(at)cox.net> >Sent: Jul 24, 2010 10:04 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Another Piet builder in the making! > > >Welcome Curt! Looking forward to hearing of your progress. > >-------- >Mark Chouinard >Finishing up Wings - Working on Center Section > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=306143#306143 > > ________________________________________________________________________________
Date: Jul 24, 2010
Flower Mound is sortof just north of Dallas, maybe a bit NW. Nice area with a little airport I used to fly in and out of (NW Regional I think) nearby. There are now several Piet builders in the DFW area....now that I DON'T live in Plano anymore!!! :-) jm...Pryor, OK -----Original Message----- >From: Gary Boothe <gboothe5(at)comcast.net> >Sent: Jul 24, 2010 9:37 AM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Another Piet builder in the making! > > >Welcome, Curt!! Where in Texas is Flower Mound? Don't forget to check out >www.westcoastpiet.com. > >Gary Boothe >Cool, CA >Pietenpol >WW Corvair Conversion >Tail done, Fuselage on gear >20 ribs done > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2112 >Sent: Saturday, July 24, 2010 7:33 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Another Piet builder in the making! > > >Hello everyone! > >My name is Curt Merdan, and I recently began my journey to Brodhead >figuratively speaking. > >A few months back, I was talking with my wife Laura, saying that I needed to >find something to do in my freetime other than surfing the internet in a >endless search for nothing. >Then I came up with this crazy idea of building an airplane. Laura said >that would be a great idea. Wow, I got her blessing! > >I went back to the internet to find the perfect airplane and guess what I >found. The beautiful, wood and fabric Pietenpol Aircamper. It is the perfect >tribute to my heritage. I am the son of a Seamstress and Carpenter from >Minnesota. > >I've got my plans, wood for the tail, glue, questions and motivation! > >Curt Merdan >817-875-5027 >Flower Mound, TX > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=306140#306140 > > ________________________________________________________________________________
Date: Jul 24, 2010
He's a lot closer to Jim Markle and the Oklahoma builders than he is to me down here in San Antonio! Welcome to the list, Curt. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306154#306154 ________________________________________________________________________________
Date: Jul 24, 2010
Thanks everyone for the warm welcome! I hope this time next year, my wife and I can make it to Brodhead and share some of our buiding experiences! Curt Merdan Flower Mound, TX (10 mile final from 18R at DFW) (19 mile final from 13R at DAL) Tail Feather jig...sounds like a dance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306156#306156 ________________________________________________________________________________
Date: Jul 24, 2010
Carl, Welcome aboard. Keep us updated. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306160#306160 ________________________________________________________________________________
Subject: Re: R/C Piet Kit on RCGroups For Sale (Not Mine)
Date: Jul 24, 2010
That would be a fun project. Now if I didn't already have an attic full of RC airplanes --------------------. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306162#306162 ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Jul 24, 2010
Curt-that sounds great. my Daughter lives about 20 miles or less from you.I manage to get down there from time to time.I'd like to keep up with your progress.sure not many Piets up here around the Texas panhandle.hope you keep us posted with your progress. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306170#306170 ________________________________________________________________________________
Date: Jul 24, 2010
Subject: Brodhead 2010: Memories (courtesy of Gene Rambo)
Memories from Brodhead 2010, near and dear to our hearts! http://dl.dropbox.com/u/2314248/DSCN2970.MOV ________________________________________________________________________________
Date: Jul 24, 2010
Subject: Re: Brodhead 2010: Memories (courtesy of Gene Rambo)
Looks a tiny bit wet....I suppose those flashes weren't from arc welding.... -----Original Message----- From: Ryan Mueller Sent: Jul 24, 2010 10:58 PM Subject: Pietenpol-List: Brodhead 2010: Memories (courtesy of Gene Rambo) Memories from Brodhead 2010, near and dear to our hearts! http://dl.dropbox.com/u/2314248/DSCN2970.MOV ________________________________________________________________________________
Subject: Crash - Long Post
Date: Jul 24, 2010
Hi - I'd like to recount my mishap at Brodhead on Friday for members of the list. The trip up: I made it from Austin to Brodhead in 3.5 days. 1.0 day delay due to weather. The only issue I had during the trip was an attempted ground loop east of Kansas City. I dragged the right wing tip but the damage was minimal. It didn't make me happy but it was not a tragedy. The mishap: I was doing a touch and go at Brodhead. During the "go" part I felt the aircraft yaw sharply to the left. It felt like I had struck something with the left gear or that the tire caught in the wet ground. I powered through it and managed to avoid going into the corn field to the left of the runway. I thought to myself, "For goodness sake (or something like that), what's wrong with my ability to control this thing?" thinking back to the wingtip dragging episode. As I continued around the pattern I looked out and saw that my left landing gear V was hanging from the rear attach point. The front part of the V had been ripped loose from the mounting lug. I flew over the field trying to get everyone's attention on the ground. I knew I had succeeded when I saw everyone running in the same direction with a definite purpose. I waited for the pattern to clear and then landed on one of the closed runways to take advantage of a direct head wind. I also planned the approach to take me in the vicinity of the group so that there was rescue available quickly. The people on the ground did a great job clearing everyone off of the runways. I turned off the fuel on short final and performed a wheel landing. I held the left wing up as long as possible. When the left gear dug in we were going pretty slow. I flipped the ignition and battery off. The aircraft spun around ~180 degrees, the left wing tip touched the ground and the aircraft came to a rest. There was no further incident. I will never forget the look on Jessie Mueller's face as I was careening toward her and Ryan's brand new airplane. I was stomping on the right brake pretty hard. The repair: if you've got to wreck a Piet do it at Brodhead. Matt Smith, a local, along with his Dad and son, spent 7 hours making the necessary repairs. The landing gear V needed the lugs reattached, the bungee cross strut tab on the bottom of the V had pulled out, and the bungee cross strut was bent. Matt, an amazingly talented and knowledgeable A&P/IA did great work and taught me a lot in the 7 hours. Unbelievable. You know he wouldn't take any money, right? Of course not. I cannot express the depth of my gratitude to Matt, his Dad and son. In addition to Matt and his family, several knowledgeable people looked over the rest of the aircraft for me and verified that the landing gear was the only apparent damage. I appreciate you. Today: flew ~3 hours and took ~8 passengers. I told them all that I had wrecked the day before. They all said, "I know" and we went flying. Amazing. Cause: the yaw I felt on my touch and go was the left gear V front attachment failing. If I had not noticed that the gear was hanging from the rear lug this event may have gone very, very badly. I don't always check to see if the gear's still there before landing but I've started to do so now. I'm glad I looked. Anyway, the V attach lugs failed because I hit something or because the welds were stressed and chose that time to fail. I did not find anything on the runway so it may have been the latter. As I've mentioned here before I have ~140 hours on the plane since the first flight last September and I've done ~400 landings. I've worked the gear pretty hard. Lessons Learned & Things I'll Start Doing: I'll darn sure preflight those attachment lugs better. I'll also take the right gear off and have a professional verify the integrity of my welds on that side. My before landing check now includes a visual check of "Gear down and locked." Good things: I was delighted to meet many of my internet friends in person. What a great group of people! Then, with the wreck, they really came through and showed me how wonderful they are. I have been nicknamed Kevin "Axel" Purtee from TGWP. They had to explain the reference to me since it's been years since I've seen the movie. It is quite funny and I shall wear my new nickname with pride. I was presented an award for "The shortest landing at Brodhead in 2010" which I will frame and hang in a prominent place. I have now been enshrined in the Hitler video. A thing of beauty. I'm going to miss some of you and I'm sorry, but thanks to everyone who helped, including Jack Phillips, Gary at Brodhead, Lowell Frank, Rob Busch, Ernie Moreno, Mike Cuy, Don Emch, John Hoffman and all the rest of the dozens of people who helped. Thanks especially to Ryan and Jessie Mueller and Dan Yocum. They rock. Sounds like an acceptance speech - sorry. You may wanna archive this one. You guys are spectacular. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306189#306189 ________________________________________________________________________________
Subject: Re: Crash - Long Post
Date: Jul 25, 2010
What a story Kevin... it really couldn't have turned out better. Glad you and your ship came out ok. We saw you flying most of the day Saturday. Hope you have a safe trip home. -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306207#306207 ________________________________________________________________________________
Date: Jul 25, 2010
Kevin- great to hear that you and the airplane survived to fly another day. I've heard story after story about how folks step up to the plate when things like this happen, and you're back in the air before you know it. Obviously, I'm jealous because you made it to Brodhead and I never have. If you get time in the next couple of weeks, I'd sure like to hear about your flight up there and back, with as much detail as you can remember. Next year I will turn 60 (July 28) and I am hoping I will be able to celebrate that occasion with my first flight to Brodhead in 41CC. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
Date: Jul 25, 2010
Kevin, I saw the vid and have to say that was some great flying and landing skills on your part. Great job in saving what could have resulted in a serious and catastrophic event. Just amazing! John Sent from my Verizon Wireless BlackBerry -----Original Message----- From: "kevinpurtee" <kevin.purtee(at)us.army.mil> Sender: owner-pietenpol-list-server(at)matronics.com Date: Sat, 24 Jul 2010 23:01:03 Subject: Pietenpol-List: Crash - Long Post Hi - I'd like to recount my mishap at Brodhead on Friday for members of the list. The trip up: I made it from Austin to Brodhead in 3.5 days. 1.0 day delay due to weather. The only issue I had during the trip was an attempted ground loop east of Kansas City. I dragged the right wing tip but the damage was minimal. It didn't make me happy but it was not a tragedy. The mishap: I was doing a touch and go at Brodhead. During the "go" part I felt the aircraft yaw sharply to the left. It felt like I had struck something with the left gear or that the tire caught in the wet ground. I powered through it and managed to avoid going into the corn field to the left of the runway. I thought to myself, "For goodness sake (or something like that), what's wrong with my ability to control this thing?" thinking back to the wingtip dragging episode. As I continued around the pattern I looked out and saw that my left landing gear V was hanging from the rear attach point. The front part of the V had been ripped loose from the mounting lug. I flew over the field trying to get everyone's attention on the ground. I knew I had succeeded when I saw everyone running in the same direction with a definite purpose. I waited for the pattern to clear and then landed on one of the closed runways to take advantage of a direct head wind. I also planned the approach to take me in the vicinity of the group so that there was rescue available quickly. The people on the ground did a great job clearing everyone off of the runways. I turned off the fuel on short final and performed a wheel landing. I held the left wing up as long as possible. When the left gear dug in we were going pretty slow. I flipped the ignition and battery off. The aircraft spun around ~180 degrees, the left wing tip touched the ground and the aircraft came to a rest. There was no further incident. I will never forget the look on Jessie Mueller's face as I was careening toward her and Ryan's brand new airplane. I was stomping on the right brake pretty hard. The repair: if you've got to wreck a Piet do it at Brodhead. Matt Smith, a local, along with his Dad and son, spent 7 hours making the necessary repairs. The landing gear V needed the lugs reattached, the bungee cross strut tab on the bottom of the V had pulled out, and the bungee cross strut was bent. Matt, an amazingly talented and knowledgeable A&P/IA did great work and taught me a lot in the 7 hours. Unbelievable. You know he wouldn't take any money, right? Of course not. I cannot express the depth of my gratitude to Matt, his Dad and son. In addition to Matt and his family, several knowledgeable people looked over the rest of the aircraft for me and verified that the landing gear was the only apparent damage. I appreciate you. Today: flew ~3 hours and took ~8 passengers. I told them all that I had wrecked the day before. They all said, "I know" and we went flying. Amazing. Cause: the yaw I felt on my touch and go was the left gear V front attachment failing. If I had not noticed that the gear was hanging from the rear lug this event may have gone very, very badly. I don't always check to see if the gear's still there before landing but I've started to do so now. I'm glad I looked. Anyway, the V attach lugs failed because I hit something or because the welds were stressed and chose that time to fail. I did not find anything on the runway so it may have been the latter. As I've mentioned here before I have ~140 hours on the plane since the first flight last September and I've done ~400 landings. I've worked the gear pretty hard. Lessons Learned & Things I'll Start Doing: I'll darn sure preflight those attachment lugs better. I'll also take the right gear off and have a professional verify the integrity of my welds on that side. My before landing check now includes a visual check of "Gear down and locked." Good things: I was delighted to meet many of my internet friends in person. What a great group of people! Then, with the wreck, they really came through and showed me how wonderful they are. I have been nicknamed Kevin "Axel" Purtee from TGWP. They had to explain the reference to me since it's been years since I've seen the movie. It is quite funny and I shall wear my new nickname with pride. I was presented an award for "The shortest landing at Brodhead in 2010" which I will frame and hang in a prominent place. I have now been enshrined in the Hitler video. A thing of beauty. I'm going to miss some of you and I'm sorry, but thanks to everyone who helped, including Jack Phillips, Gary at Brodhead, Lowell Frank, Rob Busch, Ernie Moreno, Mike Cuy, Don Emch, John Hoffman and all the rest of the dozens of people who helped. Thanks especially to Ryan and Jessie Mueller and Dan Yocum. They rock. Sounds like an acceptance speech - sorry. You may wanna archive this one. You guys are spectacular. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306189#306189 ________________________________________________________________________________
Date: Jul 25, 2010
Subject: the video....?: Crash - Long Post
Is the video available online somewhere? -----Original Message----- >From: John Recine <amsafetyc(at)aol.com> >Sent: Jul 25, 2010 11:35 AM >To: Pietenpol builders Board >Subject: Re: Pietenpol-List: Crash - Long Post > > >Kevin, > >I saw the vid and have to say that was some great flying and landing skills on your part. Great job in saving what could have resulted in a serious and catastrophic event. > >Just amazing! > > >John >Sent from my Verizon Wireless BlackBerry > >-----Original Message----- >From: "kevinpurtee" <kevin.purtee(at)us.army.mil> >Sender: owner-pietenpol-list-server(at)matronics.com >Date: Sat, 24 Jul 2010 23:01:03 >To: >Reply-To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Crash - Long Post > > >Hi - I'd like to recount my mishap at Brodhead on Friday for members of the list. > >The trip up: I made it from Austin to Brodhead in 3.5 days. 1.0 day delay due to weather. The only issue I had during the trip was an attempted ground loop east of Kansas City. I dragged the right wing tip but the damage was minimal. It didn't make me happy but it was not a tragedy. > >The mishap: I was doing a touch and go at Brodhead. During the "go" part I felt the aircraft yaw sharply to the left. It felt like I had struck something with the left gear or that the tire caught in the wet ground. I powered through it and managed to avoid going into the corn field to the left of the runway. I thought to myself, "For goodness sake (or something like that), what's wrong with my ability to control this thing?" thinking back to the wingtip dragging episode. > >As I continued around the pattern I looked out and saw that my left landing gear V was hanging from the rear attach point. The front part of the V had been ripped loose from the mounting lug. > >I flew over the field trying to get everyone's attention on the ground. I knew I had succeeded when I saw everyone running in the same direction with a definite purpose. I waited for the pattern to clear and then landed on one of the closed runways to take advantage of a direct head wind. I also planned the approach to take me in the vicinity of the group so that there was rescue available quickly. The people on the ground did a great job clearing everyone off of the runways. > >I turned off the fuel on short final and performed a wheel landing. I held the left wing up as long as possible. When the left gear dug in we were going pretty slow. I flipped the ignition and battery off. The aircraft spun around ~180 degrees, the left wing tip touched the ground and the aircraft came to a rest. There was no further incident. I will never forget the look on Jessie Mueller's face as I was careening toward her and Ryan's brand new airplane. I was stomping on the right brake pretty hard. > >The repair: if you've got to wreck a Piet do it at Brodhead. Matt Smith, a local, along with his Dad and son, spent 7 hours making the necessary repairs. The landing gear V needed the lugs reattached, the bungee cross strut tab on the bottom of the V had pulled out, and the bungee cross strut was bent. Matt, an amazingly talented and knowledgeable A&P/IA did great work and taught me a lot in the 7 hours. Unbelievable. You know he wouldn't take any money, right? Of course not. I cannot express the depth of my gratitude to Matt, his Dad and son. In addition to Matt and his family, several knowledgeable people looked over the rest of the aircraft for me and verified that the landing gear was the only apparent damage. I appreciate you. > >Today: flew ~3 hours and took ~8 passengers. I told them all that I had wrecked the day before. They all said, "I know" and we went flying. Amazing. > >Cause: the yaw I felt on my touch and go was the left gear V front attachment failing. If I had not noticed that the gear was hanging from the rear lug this event may have gone very, very badly. I don't always check to see if the gear's still there before landing but I've started to do so now. I'm glad I looked. Anyway, the V attach lugs failed because I hit something or because the welds were stressed and chose that time to fail. I did not find anything on the runway so it may have been the latter. As I've mentioned here before I have ~140 hours on the plane since the first flight last September and I've done ~400 landings. I've worked the gear pretty hard. > >Lessons Learned & Things I'll Start Doing: I'll darn sure preflight those attachment lugs better. I'll also take the right gear off and have a professional verify the integrity of my welds on that side. My before landing check now includes a visual check of "Gear down and locked." > >Good things: I was delighted to meet many of my internet friends in person. What a great group of people! Then, with the wreck, they really came through and showed me how wonderful they are. I have been nicknamed Kevin "Axel" Purtee from TGWP. They had to explain the reference to me since it's been years since I've seen the movie. It is quite funny and I shall wear my new nickname with pride. I was presented an award for "The shortest landing at Brodhead in 2010" which I will frame and hang in a prominent place. I have now been enshrined in the Hitler video. A thing of beauty. > >I'm going to miss some of you and I'm sorry, but thanks to everyone who helped, including Jack Phillips, Gary at Brodhead, Lowell Frank, Rob Busch, Ernie Moreno, Mike Cuy, Don Emch, John Hoffman and all the rest of the dozens of people who helped. Thanks especially to Ryan and Jessie Mueller and Dan Yocum. They rock. Sounds like an acceptance speech - sorry. > >You may wanna archive this one. > >You guys are spectacular. > >-------- >Kevin Purtee >NX899KP >Austin/Georgetown, TX > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=306189#306189 > > ________________________________________________________________________________
Date: Jul 25, 2010
Ryan, I'm having a little trouble downloading the video file. Is it on-line somewhere? Thanks, Darrel Jones Pfeifer Sport N154JP Sonoma, CA On 7/24/2010 7:58 PM, Ryan Mueller wrote: > Memories from Brodhead 2010, near and dear to our hearts! > > http://dl.dropbox.com/u/2314248/DSCN2970.MOV > * > > > * ________________________________________________________________________________
Date: Jul 25, 2010
Takes a LONG time to download but it will download....mine played in the browser (Firefox) window after it downloaded, took about 10 minutes.... -----Original Message----- From: Darrel Jones Sent: Jul 25, 2010 1:02 PM Subject: Re: Pietenpol-List: Brodhead 2010: Memories (courtesy of Gene Rambo) Ryan, I'm having a little trouble downloading the video file. Is it on-line somewhere? Thanks, Darrel Jones Pfeifer Sport N154JP Sonoma, CA On 7/24/2010 7:58 PM, Ryan Mueller wrote: Memories from Brodhead 2010, near and dear to our hearts! http://dl.dropbox.com/u/2314248/DSCN2970.MOV href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 25, 2010
Jim, Thanks. I thought the download might have hung up. I'll just let it run. Darrel On 7/25/2010 11:25 AM, Jim Markle wrote: > --> Pietenpol-List message posted by: Jim Markle > > Takes a LONG time to download but it will download....mine played in the browser (Firefox) window after it downloaded, took about 10 minutes.... > > -----Original Message----- > > From: Darrel Jones > > Sent: Jul 25, 2010 1:02 PM > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: Brodhead 2010: Memories (courtesy of Gene Rambo) > > > ________________________________________________________________________________
Date: Jul 25, 2010
Just watched the "Memories" video. I thought the audio on my computer was malfunctioning! Just the thunder and downpour. Need to get some floats on those Piets. Thanks, Darrel Jones ________________________________________________________________________________
Subject: model A engine
Date: Jul 25, 2010
where would the best place to start be, concerning the model A? I would like to know where i can find cores, parts, build logs, conversions, ect. So I can try and get a full picture. Just in case we decide that the model A is what we want to go with. I heard one up at Brodhead.... it was soo cool!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306250#306250 ________________________________________________________________________________
Date: Jul 25, 2010
I did the same....then started it a third time and forgot about it...then my computer started thundering and lightning....a bit creepy when you don't expect it! Actually, I love it. Really makes you feel like you're there. Interesting effect. jm....in Hampton CT....beautiful area but sure ain't Brodhead!!! :-) -----Original Message----- >From: Darrel Jones <wd6bor(at)vom.com> >Sent: Jul 25, 2010 1:55 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Brodhead 2010: Memories (courtesy of Gene Rambo) > > >Jim, > >Thanks. I thought the download might have hung up. I'll just let it run. > >Darrel > >On 7/25/2010 11:25 AM, Jim Markle wrote: >> --> Pietenpol-List message posted by: Jim Markle >> >> Takes a LONG time to download but it will download....mine played in the browser (Firefox) window after it downloaded, took about 10 minutes.... >> >> -----Original Message----- >> >> From: Darrel Jones >> >> Sent: Jul 25, 2010 1:02 PM >> >> To: pietenpol-list(at)matronics.com >> >> Subject: Re: Pietenpol-List: Brodhead 2010: Memories (courtesy of Gene Rambo) >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 25, 2010
Subject: Re: model A engine
If I was doing it again (instead of buying one already built) I would figure out a way to get with Lowell Frank and/or Ken Perkins. There are others but I would find out everything you can from those two. Do a search of the Matronics Archives (http://www.matronics.com/searching/) for anything from Lowell. ("Pieti Lowell"). Ken doesn't get on this list but he also knows a LOT about what's going on with Model A's. There won't be a book you can just check out but these folks and some others and the original Pietenpol plans....that will be a great start! That may have very well been Ken's Model A you heard...what a sweet sound. If you're interested in more, I did an "engine start to engine stop" video of a ride Ken gave me several years ago (he enjoyed it so much he went out and bought a new computer so he could watch it!)...I would be glad to send you a copy on CD. jm -----Original Message----- >From: j_dunavin <j_dunavin(at)hotmail.com> >Sent: Jul 25, 2010 3:23 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: model A engine > > >where would the best place to start be, concerning the model A? >I would like to know where i can find cores, parts, build logs, conversions, ect. So I can try and get a full picture. Just in case we decide that the model A is what we want to go with. >I heard one up at Brodhead.... it was soo cool!! > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=306250#306250 > > ________________________________________________________________________________
Date: Jul 25, 2010
Dan, sell the RC planes... it will clear up space in the attic, and it will help fund your purchase of the plans for the 1:1 scale, or your first order of wood and T-88. Get busy building, man! Billy McCaskill Urbana, IL tail section done, ribs coming very soon! -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306259#306259 ________________________________________________________________________________
Date: Jul 25, 2010
Subject: Down from the heavens...
This is what happens when you let Mike Cuy fly your wife in your Pietenpol: http://www.youtube.com/watch?v=Q70zh8s_6fU Ryan ________________________________________________________________________________
Date: Jul 25, 2010
Sorry for the troubles with the video. Now that we are home I've had a chance to put it up on Youtube. It is an example of the storms we camped in on Friday night: http://www.youtube.com/watch?v=OayCWX5REXg On Sun, Jul 25, 2010 at 6:03 PM, Jim Markle wrote: > jim_markle(at)mindspring.com> > > I did the same....then started it a third time and forgot about it...then > my computer started thundering and lightning....a bit creepy when you don't > expect it! > > Actually, I love it. Really makes you feel like you're there. Interesting > effect. > > jm....in Hampton CT....beautiful area but sure ain't Brodhead!!! :-) > > > -----Original Message----- > >From: Darrel Jones <wd6bor(at)vom.com> > >Sent: Jul 25, 2010 1:55 PM > >To: pietenpol-list(at)matronics.com > >Subject: Re: Pietenpol-List: Brodhead 2010: Memories (courtesy of Gene > Rambo) > > > > > >Jim, > > > >Thanks. I thought the download might have hung up. I'll just let it run. > > > >Darrel > > > >On 7/25/2010 11:25 AM, Jim Markle wrote: > >> --> Pietenpol-List message posted by: Jim Markle< > jim_markle(at)mindspring.com> > >> > >> Takes a LONG time to download but it will download....mine played in the > browser (Firefox) window after it downloaded, took about 10 minutes.... > >> > >> -----Original Message----- > >> > >> From: Darrel Jones > >> > >> Sent: Jul 25, 2010 1:02 PM > >> > >> To: pietenpol-list(at)matronics.com > >> > >> Subject: Re: Pietenpol-List: Brodhead 2010: Memories (courtesy of Gene > Rambo) > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 25, 2010
Billy You got it right about needing to sell the RC airplanes. Every now and then I build another one for something to do. Fly it a few times then up in the attic it goes. I considered building a Piet then I came across a really nice one for sale a few weeks ago. I missed out on the adventure and challenge of building and went straight to the enjoyment of flying. :D -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306262#306262 Attachments: http://forums.matronics.com//files/sam_0804_166.jpg ________________________________________________________________________________
Date: Jul 25, 2010
Axel's landing was a thing of beauty. "The pond Axel the pond's the safest place!" There were a bunch of us positioned in case any emergency were to befell him. "it just means the world to him you care....They're good people Axel!" I myself was ready to smack him with a two-by-four in case It was necessary. I feel blessed to be a part of this group. Weather kept the Cub in the hangar and the rains at night did not dampen the fun. This is not the same event it was ten years ago. Since 1998 or so, with the growth of this list, a new breed of Pietenpol builder has come forth and some beautiful machines have been hatched. This year we added Dan Helsper's and Kevin's, I mean Axel's, ships to that list. I also have found some of my best friends are those I only see once or twice a year but for whom I have great respect and tend to love like a brother. My eyes water a bit, when we all leave, for some reason. It was great to add Kevin and his new bride as well as the Chouinard family among others to the friend list. I will add some pictures and comments after I get a charge back on my camera. However, this gentleman would like to have the last word on Kevin's situation: http://gallery.me.com/johnnyskyrocket#100026 -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Jul 25, 2010, at 1:01 AM, kevinpurtee wrote: > > Hi - I'd like to recount my mishap at Brodhead on Friday for members of the list. > > The trip up: I made it from Austin to Brodhead in 3.5 days. 1.0 day delay due to weather. The only issue I had during the trip was an attempted ground loop east of Kansas City. I dragged the right wing tip but the damage was minimal. It didn't make me happy but it was not a tragedy. > > The mishap: I was doing a touch and go at Brodhead. During the "go" part I felt the aircraft yaw sharply to the left. It felt like I had struck something with the left gear or that the tire caught in the wet ground. I powered through it and managed to avoid going into the corn field to the left of the runway. I thought to myself, "For goodness sake (or something like that), what's wrong with my ability to control this thing?" thinking back to the wingtip dragging episode. > > As I continued around the pattern I looked out and saw that my left landing gear V was hanging from the rear attach point. The front part of the V had been ripped loose from the mounting lug. > > I flew over the field trying to get everyone's attention on the ground. I knew I had succeeded when I saw everyone running in the same direction with a definite purpose. I waited for the pattern to clear and then landed on one of the closed runways to take advantage of a direct head wind. I also planned the approach to take me in the vicinity of the group so that there was rescue available quickly. The people on the ground did a great job clearing everyone off of the runways. > > I turned off the fuel on short final and performed a wheel landing. I held the left wing up as long as possible. When the left gear dug in we were going pretty slow. I flipped the ignition and battery off. The aircraft spun around ~180 degrees, the left wing tip touched the ground and the aircraft came to a rest. There was no further incident. I will never forget the look on Jessie Mueller's face as I was careening toward her and Ryan's brand new airplane. I was stomping on the right brake pretty hard. > > The repair: if you've got to wreck a Piet do it at Brodhead. Matt Smith, a local, along with his Dad and son, spent 7 hours making the necessary repairs. The landing gear V needed the lugs reattached, the bungee cross strut tab on the bottom of the V had pulled out, and the bungee cross strut was bent. Matt, an amazingly talented and knowledgeable A&P/IA did great work and taught me a lot in the 7 hours. Unbelievable. You know he wouldn't take any money, right? Of course not. I cannot express the depth of my gratitude to Matt, his Dad and son. In addition to Matt and his family, several knowledgeable people looked over the rest of the aircraft for me and verified that the landing gear was the only apparent damage. I appreciate you. > > Today: flew ~3 hours and took ~8 passengers. I told them all that I had wrecked the day before. They all said, "I know" and we went flying. Amazing. > > Cause: the yaw I felt on my touch and go was the left gear V front attachment failing. If I had not noticed that the gear was hanging from the rear lug this event may have gone very, very badly. I don't always check to see if the gear's still there before landing but I've started to do so now. I'm glad I looked. Anyway, the V attach lugs failed because I hit something or because the welds were stressed and chose that time to fail. I did not find anything on the runway so it may have been the latter. As I've mentioned here before I have ~140 hours on the plane since the first flight last September and I've done ~400 landings. I've worked the gear pretty hard. > > Lessons Learned & Things I'll Start Doing: I'll darn sure preflight those attachment lugs better. I'll also take the right gear off and have a professional verify the integrity of my welds on that side. My before landing check now includes a visual check of "Gear down and locked." > > Good things: I was delighted to meet many of my internet friends in person. What a great group of people! Then, with the wreck, they really came through and showed me how wonderful they are. I have been nicknamed Kevin "Axel" Purtee from TGWP. They had to explain the reference to me since it's been years since I've seen the movie. It is quite funny and I shall wear my new nickname with pride. I was presented an award for "The shortest landing at Brodhead in 2010" which I will frame and hang in a prominent place. I have now been enshrined in the Hitler video. A thing of beauty. > > I'm going to miss some of you and I'm sorry, but thanks to everyone who helped, including Jack Phillips, Gary at Brodhead, Lowell Frank, Rob Busch, Ernie Moreno, Mike Cuy, Don Emch, John Hoffman and all the rest of the dozens of people who helped. Thanks especially to Ryan and Jessie Mueller and Dan Yocum. They rock. Sounds like an acceptance speech - sorry. > > You may wanna archive this one. > > You guys are spectacular. > > -------- > Kevin Purtee > NX899KP > Austin/Georgetown, TX > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306189#306189 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 25, 2010
Subject: Re: IGNITION SHIELDING Needed on A-65
----- Original Message ---- From: Jeff Boatright <jboatri(at)emory.edu> Sent: Wed, July 21, 2010 4:19:35 PM Subject: Re: Pietenpol-List: Re: IGNITION SHIELDING Needed on A-65 Wing faring? Where is that located? > >N8031 had an antenna mounted to the wing faring. I took it off, but >the previous owner had no problem with it there and the ignition >cables are unshielded. > >Dan > ________________________________________________________________________________
Date: Jul 25, 2010
Kevin, Welcome to my club. Just as I turned the corner after landing,I spotted you taking that final left turn at 28 ft over my head, I stopped and whipped out my camera , snapped a perfect shot through my cabanes just to the left of the Ford radiator, you were about 10 Ft off the turf, with wheel snugged up under like a trick pilot showing off , and as you administered a perfect, lame duck landing, I proudly lowered my surprise shot of the day to my lap, and to my astonishment the two camera batteries had sped to my lap without my knowledge just pry or to the speedy camera work. Sorry Kevin By the way, I see you got a few new drain holes at the trailing edge of the wing, that is the good news. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306269#306269 ________________________________________________________________________________
Date: Jul 25, 2010
That hitler parady was a gutt buster!!!!- Wish I could have been there th is year, and may you all have a fun and safe flight home from "pietenpol pa radise".- Look out Kevin and Randy the furor is looking for you and the U nited States Corvair-force.- It's ok though you should have at least 10-1 5 mph advantage on the rest of them. - Shad Lt.- Crank Snapper U.S.Corvair-force RET=0A=0A=0A ________________________________________________________________________________
Date: Jul 25, 2010
Kevin gave his consent, so here it is. People in Wichita pay $15 or $20 to see a crash like this: http://www.youtube.com/watch?v=IH-lwcgop-8 <http://www.youtube.com/watch?v=IH-lwcgop-8>Ryan On Sun, Jul 25, 2010 at 9:00 PM, shad bell wrote: > That hitler parady was a gutt buster!!!! Wish I could have been there this > year, and may you all have a fun and safe flight home from "pietenpol > paradise". Look out Kevin and Randy the furor is looking for you and the > United States Corvair-force. It's ok though you should have at least 10-15 > mph advantage on the rest of them. > > Shad > Lt. Crank Snapper U.S.Corvair-force RET > > * > > * > > ________________________________________________________________________________
Date: Jul 25, 2010
Subject: Re: Lifetime Experience
that engine looks great congrat sooner we have another flyship seyou jorge from hanford. --- On Fri, 7/23/10, Jack wrote: From: Jack <jack(at)textors.com> Subject: Pietenpol-List: Lifetime Experience Date: Friday, July 23, 2010, 6:55 AM All, Yesterday was a learning experience I shall never forget or top. It brought tears to my eyes.=C2- My good friend Tom Wottreng assembled my C-85 with me.=C2- What a knowledgeable man and a good guy.=C2- I=99ve atta ched a couple of pictures so as to not clutter the list.=C2- Next week wh en I=99m home I will update my site with more shots. Jack DSM =C2- =C2-=0A=0A=0A ________________________________________________________________________________
Date: Jul 25, 2010
Kevin looked so cool, calm and collected during the whole thing. I especially liked the leisurely loop right in front of the camera. Couldn't have planned it better. Very professional! Typical of those Corvair Piet pilots. Darrel On 7/25/2010 7:31 PM, Ryan Mueller wrote: > Kevin gave his consent, so here it is. People in Wichita pay $15 or > $20 to see a crash like this: > > http://www.youtube.com/watch?v=IH-lwcgop-8 > > Ryan ________________________________________________________________________________
Date: Jul 25, 2010
That's defiantly a start. And yes it was Ken's piet. I double checked my pictures against the west coast piet library. I just can't believe that it has enough power to weight ratio, but when I talked to the taller guy wiping it down on Sat. He seemed to indicate that, though it wasn't a fast climber it had plenty of guts, for two. He did say that it got a little hot in the summer time, but sure was nice in the fall:) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306286#306286 ________________________________________________________________________________
Date: Jul 25, 2010
WOW super good landing! I'm not sure that my normal landings in the 172 look as good as that :o Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306287#306287 ________________________________________________________________________________
Subject: Pietenpol Oscars
Date: Jul 25, 2010
My votes: Best Dramatic Film of the Year - The Great Axel Purtee, by Jess Mueller - http://www.youtube.com/watch?v=IH-lwcgop-8 Best Comedy Film of the Year - Hitler's Tribute to Corvairs, by John Hoffman - http://gallery.me.com/johnnyskyrocket#100026 Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (20 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Sunday, July 25, 2010 7:32 PM Subject: Re: Pietenpol-List: Crash - Long Post Kevin gave his consent, so here it is. People in Wichita pay $15 or $20 to see a crash like this: http://www.youtube.com/watch?v=IH-lwcgop-8 <http://www.youtube.com/watch?v=IH-lwcgop-8> Ryan On Sun, Jul 25, 2010 at 9:00 PM, shad bell wrote: That hitler parady was a gutt buster!!!! Wish I could have been there this year, and may you all have a fun and safe flight home from "pietenpol paradise". Look out Kevin and Randy the furor is looking for you and the United States Corvair-force. It's ok though you should have at least 10-15 mph advantage on the rest of them. Shad Lt. Crank Snapper U.S.Corvair-force RET " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 26, 2010
Oscar I hoping for the same thing, I will be 57 the 28th. Jack Jack Textor 29 SW 58th Drive Des Moines, IA 50312 www.textors.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Sunday, July 25, 2010 8:56 AM Subject: Pietenpol-List: Crash - Long Post Kevin- great to hear that you and the airplane survived to fly another day. I've heard story after story about how folks step up to the plate when things like this happen, and you're back in the air before you know it. Obviously, I'm jealous because you made it to Brodhead and I never have. If you get time in the next couple of weeks, I'd sure like to hear about your flight up there and back, with as much detail as you can remember. Next year I will turn 60 (July 28) and I am hoping I will be able to celebrate that occasion with my first flight to Brodhead in 41CC. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net _________________________________________________________________ Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:W L:en-US:WM_HMP:042010_1 ________________________________________________________________________________
Date: Jul 26, 2010
This site might be of interest; http://www.handhantique.com/modelab/modelab.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306300#306300 ________________________________________________________________________________
Date: Jul 26, 2010
Subject: This is not the same event it was ten years ago
I would like to echo John Hofmann's sentiments about the Brodhead fly in. Actually, he said it so well, there is nothing more for me to say. As the Brits would say: "Hear! Hear!" John Fay in Peoria On Sun, Jul 25, 2010 at 7:40 PM, John Hofmann wrote: > Axel's landing was a thing of beauty. > > "The pond Axel the pond's the safest place!" > > There were a bunch of us positioned in case any emergency were to befell > him. > > "it just means the world to him you care....They're good people Axel!" > > I myself was ready to smack him with a two-by-four in case It was > necessary. > > I feel blessed to be a part of this group. Weather kept the Cub in the > hangar and the rains at night did not dampen the fun. This is not the same > event it was ten years ago. Since 1998 or so, with the growth of this list, > a new breed of Pietenpol builder has come forth and some beautiful machines > have been hatched. This year we added Dan Helsper's and Kevin's, I mean > Axel's, ships to that list. I also have found some of my best friends are > those I only see once or twice a year but for whom I have great respect and > tend to love like a brother. My eyes water a bit, when we all leave, for > some reason. It was great to add Kevin and his new bride as well as > the Chouinard family among others to the friend list. I will add some > pictures and comments after I get a charge back on my camera. > > However, this gentleman would like to have the last word on Kevin's > situation: > > http://gallery.me.com/johnnyskyrocket#100026 > > -john- > > John Hofmann > Vice-President, Information Technology > The Rees Group, Inc. > 2424 American Lane > Madison, WI 53704 > Phone: 608.443.2468 ext 150 > Fax: 608.443.2474 > Email: jhofmann(at)reesgroupinc.com > > ________________________________________________________________________________
Date: Jul 26, 2010
Dan, Where do you live? Can you give us a few more particulars of your purchase and a couple of pics? John Fay in Peoria On Sun, Jul 25, 2010 at 7:26 PM, Dan P wrote: > > Billy > You got it right about needing to sell the RC airplanes. Every now and > then I build another one for something to do. Fly it a few times then up in > the attic it goes. > > I considered building a Piet then I came across a really nice one for sale > a few weeks ago. I missed out on the adventure and challenge of building > and went straight to the enjoyment of flying. :D > > -------- > Dan Plett > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306262#306262 > > > Attachments: > > http://forums.matronics.com//files/sam_0804_166.jpg > > ________________________________________________________________________________
Date: Jul 26, 2010
Subject: Re: Down from the heavens...
> This is what happens when you let Mike Cuy fly your wife in your Pietenpol: Way to go Jess - what fun! By the way, was that a flight in your new airplane with Mike Cuy doing the drivin' or was that in Mike's plane? Tom Stinemetze McPherson, KS ________________________________________________________________________________
Date: Jul 26, 2010
That was Mike flying with Jess in our new Pietenpol.... :) Ryan On Mon, Jul 26, 2010 at 9:14 AM, TOM STINEMETZE wrote: > > This is what happens when you let Mike Cuy fly your wife in your > Pietenpol: > > *Way to go Jess - what fun! By the way, was that a flight in your new > airplane with Mike Cuy doing the drivin' or was that in Mike's plane?* > ** > *Tom Stinemetze* > *McPherson, KS* > > > * > > * > > ________________________________________________________________________________
Date: Jul 26, 2010
Hi Kevin, Really glad you got the Piet flying again. It is always best to fly with so meone who had a learning experience; you know they won't let the same thing happen again. Really great to meet you in person and have many more happy hours flying th at wonderful Piet. Jim ----- Original Message ----- From: "kevinpurtee" <kevin.purtee(at)us.army.mil> Sent: Saturday, July 24, 2010 11:01:03 PM Subject: Pietenpol-List: Crash - Long Post il> Hi - I'd like to recount my mishap at Brodhead on Friday for members of the list. The trip up: I made it from Austin to Brodhead in 3.5 days. =C2-1.0 day d elay due to weather. =C2-The only issue I had during the trip was an atte mpted ground loop east of Kansas City. =C2-I dragged the right wing tip b ut the damage was minimal. =C2-It didn't make me happy but it was not a t ragedy. The mishap: I was doing a touch and go at Brodhead. =C2-During the "go" p art I felt the aircraft yaw sharply to the left. =C2-It felt like I had s truck something with the left gear or that the tire caught in the wet groun d. =C2-I powered through it and managed to avoid going into the corn fiel d to the left of the runway. =C2-I thought to myself, "For goodness sake (or something like that), what's wrong with my ability to control this thin g?" thinking back to the wingtip dragging episode. As I continued around the pattern I looked out and saw that my left landing gear V was hanging from the rear attach point. =C2-The front part of the V had been ripped loose from the mounting lug. =C2- I flew over the field trying to get everyone's attention on the ground. =C2 -I knew I had succeeded when I saw everyone running in the same direction with a definite purpose. =C2-I waited for the pattern to clear and then landed on one of the closed runways to take advantage of a direct head wind . =C2-I also planned the approach to take me in the vicinity of the group so that there was rescue available quickly. =C2-The people on the ground did a great job clearing everyone off of the runways. =C2- I turned off the fuel on short final and performed a wheel landing. =C2-I held the left wing up as long as possible. =C2-When the left gear dug in we were going pretty slow. =C2-I flipped the ignition and battery off. =C2-The aircraft spun around ~180 degrees, the left wing tip touched the ground and the aircraft came to a rest. =C2-There was no further incident . =C2-I will never forget the look on Jessie Mueller's face as I was care ening toward her and Ryan's brand new airplane. =C2-I was stomping on the right brake pretty hard. =C2- The repair: if you've got to wreck a Piet do it at Brodhead. =C2-Matt Smi th, a local, along with his Dad and son, spent 7 hours making the necessary repairs. =C2-The landing gear V needed the lugs reattached, the bungee c ross strut tab on the bottom of the V had pulled out, and the bungee cross strut was bent. =C2-Matt, an amazingly talented and knowledgeable A&P/IA did great work and taught me a lot in the 7 hours. =C2-Unbelievable. =C2 -You know he wouldn't take any money, right? =C2-Of course not. =C2-I cannot express the depth of my gratitude to Matt, his Dad and son. =C2-I n addition to Matt and his family, several knowledgeable people looked over the rest of the aircraft for me and verified that the landing gear was the only apparent damage. =C2-I appreciate you. Today: flew ~3 hours and took ~8 passengers. =C2-I told them all that I h ad wrecked the day before. =C2-They all said, "I know" and we went flying . =C2-Amazing. Cause: the yaw I felt on my touch and go was the left gear V front attachme nt failing. =C2-If I had not noticed that the gear was hanging from the r ear lug this event may have gone very, very badly. =C2-I don't always che ck to see if the gear's still there before landing but I've started to do s o now. =C2-I'm glad I looked. =C2-Anyway, the V attach lugs failed beca use I hit something or because the welds were stressed and chose that time to fail. =C2-I did not find anything on the runway so it may have been th e latter. =C2-As I've mentioned here before I have ~140 hours on the plan e since the first flight last September and I've done ~400 landings. =C2- I've worked the gear pretty hard. Lessons Learned & Things I'll Start Doing: I'll darn sure preflight those a ttachment lugs better. =C2-I'll also take the right gear off and have a p rofessional verify the integrity of my welds on that side. =C2-My before landing check now includes a visual check of "Gear down and locked." Good things: I was delighted to meet many of my internet friends in person. =C2-What a great group of people! =C2-Then, with the wreck, they reall y came through and showed me how wonderful they are. =C2-I have been nick named Kevin "Axel" Purtee from TGWP. =C2-They had to explain the referenc e to me since it's been years since I've seen the movie. =C2-It is quite funny and I shall wear my new nickname with pride. =C2-I was presented an award for "The shortest landing at Brodhead in 2010" which I will frame an d hang in a prominent place. =C2-I have now been enshrined in the Hitler video. =C2-A thing of beauty. I'm going to miss some of you and I'm sorry, but thanks to everyone who hel ped, including Jack Phillips, Gary at Brodhead, Lowell Frank, Rob Busch, Er nie Moreno, Mike Cuy, Don Emch, John Hoffman and all the rest of the dozens of people who helped. =C2-Thanks especially to Ryan and Jessie Mueller a nd Dan Yocum. =C2-They rock. =C2-Sounds like an acceptance speech - sor ry. You may wanna archive this one. =C2- You guys are spectacular. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306189#306189 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Jul 26, 2010
Ryan and Jesse, Jesse sounded like she was having too much fun in that flight with Mike. Yo u guys have one nice Piet enjoy it; I'm jealous. Really great seeing your two again and Arlene says Hi too. Jim ----- Original Message ----- From: "Ryan Mueller" <rmueller23(at)gmail.com> Sent: Sunday, July 25, 2010 7:31:58 PM Subject: Re: Pietenpol-List: Crash - Long Post Kevin gave his consent, so here it is. People in Wichita pay $15 or $20 to see a crash like this: http://www.youtube.com/watch?v=IH-lwcgop-8 Ryan On Sun, Jul 25, 2010 at 9:00 PM, shad bell < aviatorbell(at)yahoo.com > wrote: That hitler parady was a gutt buster!!!!=C2- Wish I could have been there this year, and may you all have a fun and safe flight home from "pietenpol paradise".=C2- Look out Kevin and Randy the furor is looking for you and the United States Corvair-force.=C2- It's ok though you should have at l east 10-15 mph advantage on the rest of them. Shad Lt.=C2- Crank Snapper U.S.Corvair-force RET " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp:// forums.matronics.com _blank">http://www.matronics.com/contribution == ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: brass plating and metal rolling
Date: Jul 26, 2010
Hey everyone. Great to see you all, and glad we all weathered the storm. Marci and I had a great time, and I got the shot in the arm I need to get back to building!! Two questions. 1. I have an aluminum part I want brass plated. I know this is a multi step process involving zinc or nickel plating, then brass plating etc. I am having a heck of a time finding a plating shop to do it, any ideas out there? 2. If I wanted a thin wall stainless tube that I simply couldn't find stock, I was thinking I could have a sheet metal shop roll some up for me. What is this process called and what type of shop would I look for? I'm thinking six foot lengths about 2.5" in diameter. Thanks, Douwe ________________________________________________________________________________
Date: Jul 26, 2010
Subject: Re: brass plating and metal rolling
Hi Douwe, McMaster-Carr has 0.065 walled 2.5" OD stainless tubing for $104-118 per 6' lengths. Can't help you on the brass plating, though. Cheers! Dan On 07/26/2010 01:59 PM, Douwe Blumberg wrote: > --> Pietenpol-List message posted by: "Douwe Blumberg" > > Hey everyone. > > Great to see you all, and glad we all weathered the storm. Marci and I had > a great time, and I got the shot in the arm I need to get back to building!! > > Two questions. > > 1. I have an aluminum part I want brass plated. I know this is a multi step > process involving zinc or nickel plating, then brass plating etc. I am > having a heck of a time finding a plating shop to do it, any ideas out > there? > > 2. If I wanted a thin wall stainless tube that I simply couldn't find stock, > I was thinking I could have a sheet metal shop roll some up for me. What is > this process called and what type of shop would I look for? I'm thinking > six foot lengths about 2.5" in diameter. > > Thanks, > > Douwe > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 26, 2010
Many years ago I had a custom motorcycle with some gold and chrome plating done by a place in Padukah, KY, Brown's Plating maybe. Don't remember the name for sure but it's been there forever and might be an option to check out. >From Hartford CT (my email yesterday said "Hampton, CT"...what a dummy, I'm STAYING at the Hampton Inn!!)....far far from Brodhead and/or my shop....oh well. jm -----Original Message----- >From: Douwe Blumberg <douweblumberg(at)earthlink.net> >Sent: Jul 26, 2010 2:59 PM >To: pietenpolgroup >Subject: Pietenpol-List: brass plating and metal rolling > > >Hey everyone. > >Great to see you all, and glad we all weathered the storm. Marci and I had >a great time, and I got the shot in the arm I need to get back to building!! > >Two questions. > >1. I have an aluminum part I want brass plated. I know this is a multi step >process involving zinc or nickel plating, then brass plating etc. I am >having a heck of a time finding a plating shop to do it, any ideas out >there? > >2. If I wanted a thin wall stainless tube that I simply couldn't find stock, >I was thinking I could have a sheet metal shop roll some up for me. What is >this process called and what type of shop would I look for? I'm thinking >six foot lengths about 2.5" in diameter. > >Thanks, > >Douwe > > ________________________________________________________________________________
Date: Jul 26, 2010
Subject: Re: Riblett 612 or 613.5, and jigs too...
> You can change a lot of the flight dynamics witha ANY airfoil by building the Piet as light as possible, powering it up a bit, and/or by adding some wingspan. I had the opportunity to see Ty Daniels take off at Brodhead in his Piet - talk about an absolute elevator! Unbelievable. He and his wife were at 100' within 100' of leaving the runway! I'm not exaggerating. At that height he nosed it over a bit to gain some extra speed to keep flying, but then he just kept climbing, although at a slower rate. The key is to build light light light. Ty's plane weighs 640 *with 12gal fuel!!* Ty's a young guy about 6'3" and 140lbs. His wife is 110lbs. He's got an A-65 with a McCauley climb prop of unknown pitch. For comparison, N8031 is between 710-730lbs *empty* and with just my butt in there I could get to 250-300' by the end of the 2400' runway. Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 26, 2010
You could do it yourself: http://www.caswellplating.com/kits/ For the stainless tubing I recommend: http://www.burnsstainless.com Hans NX15KV -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Mon, Jul 26, 2010 1:59 pm Subject: Pietenpol-List: brass plating and metal rolling hlink.net> Hey everyone. Great to see you all, and glad we all weathered the storm. Marci and I ha d great time, and I got the shot in the arm I need to get back to building! ! Two questions. 1. I have an aluminum part I want brass plated. I know this is a multi st ep rocess involving zinc or nickel plating, then brass plating etc. I am aving a heck of a time finding a plating shop to do it, any ideas out here? 2. If I wanted a thin wall stainless tube that I simply couldn't find stoc k, was thinking I could have a sheet metal shop roll some up for me. What is his process called and what type of shop would I look for? I'm thinking ix foot lengths about 2.5" in diameter. Thanks, Douwe -======================== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Jul 26, 2010
Subject: Ryan and Jess new Piet at Brodhead
Now there is a TRUSTING husband to allow an infidel like me to fly thier br and new Pietenpol and then let his wife Jess go along for my first time flying it. What a NICE flying Pietenpol and it climbs really well with a strong engine , straight rigging, and excellent windshields. I flew with no goggles and my contacts in and no issues what so ever. I was honored to be able to hop a few rides for Ryan and Jess, plus Jack Ph illips had enough for the day and was meeting up on the field with one of his good buddies from North Carolina. Getting a little sun and seeing Sean Tucker trying to pull more g's than a human body should be ever able to endure here at Oshkosh. As Walt Evans says, Ain't life grand ? Mike C. in Oshkosh ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Subject: Re: Ryan and Jess new Piet at Brodhead
Date: Jul 26, 2010
Mike, Thank you for the nice report on N502R. I spent a lot of time bringing her to that point. It was hard to let her go but it really helps that such a nice couple bought her and have become her caretakers. I'm doing well and wish to thank everyone for their prayers. They have really helped. My last exam indicated that the Chemo is working, so keep the prayers coming. As a side note, I have all 4 of Tony Bingelis' books, in new condition, that I will let go to anyone on this list for $50. plus shipping. Everyone, fly safe Gene in beautiful (but VERY HOT) Tennessee From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Monday, July 26, 2010 3:50 PM Subject: Pietenpol-List: Ryan and Jess new Piet at Brodhead Now there is a TRUSTING husband to allow an infidel like me to fly thier brand new Pietenpol and then let his wife Jess go along for my first time flying it. What a NICE flying Pietenpol and it climbs really well with a strong engine, straight rigging, and excellent windshields. I flew with no goggles and my contacts in and no issues what so ever. I was honored to be able to hop a few rides for Ryan and Jess, plus Jack Phillips had enough for the day and was meeting up on the field with one of his good buddies from North Carolina. Getting a little sun and seeing Sean Tucker trying to pull more g's than a human body should be ever able to endure here at Oshkosh. As Walt Evans says, Ain't life grand ? Mike C. in Oshkosh ________________________________________________________________________________
Date: Jul 26, 2010
Gene, I would like to buy your set of Bengellis books. Gardiner Mason --- On Mon, 7/26/10, Gene & Tammy wrote: From: Gene & Tammy <zharvey(at)bentoncountycable.net> Subject: Re: Pietenpol-List: Ryan and Jess new Piet at Brodhead Date: Monday, July 26, 2010, 6:41 PM =0A=0A =0A =0A=0A=0A=0AMike,=0AThank you for the nice report on N502R.- I spent a =0Alot of time bringing her to that point.- It was hard to let h er go but it =0Areally helps that such a nice couple bought her and have be come her =0Acaretakers.- I'm doing well and wish to thank everyone for th eir =0Aprayers.- They have really helped.- My last exam indicated that the =0AChemo is working, so keep the prayers coming.=0AAs a side note, I ha ve all 4 of Tony Bingelis' books, in =0Anew condition, that I will let go t o anyone on this list for $50. plus =0Ashipping.- =0AEveryone, fly safe =0AGene-- in beautiful (but VERY HOT) =0ATennessee=0A=0A =0A=0AFrom: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace =0ACorporation] =0ASe nt: Monday, July 26, 2010 3:50 PM=0ATo: pietenpol-list(at)matronics.com =0A=0A Subject: Pietenpol-List: Ryan and Jess new Piet at =0ABrodhead=0A =0A=0ANow there is a TRUSTING husband to allow an infidel like me to fly th ier =0Abrand new Pietenpol and then=0Alet his wife Jess go along for my fir st time =0Aflying it.- =0A-=0AWhat a NICE flying Pietenpol and it climb s really =0Awell with a strong engine, straight rigging, and excellent =0Aw indshields.-- I flew with no goggles and my contacts in and no issues =0Awhat so ever.-- =0A-=0AI was honored to be able to hop a few rides for =0ARyan and Jess, plus Jack Phillips had enough for the day and was=0A meeting up on the field with one of his good =0Abuddies from North Carolina . =0A-=0AGetting a little sun and seeing Sean Tucker trying =0Ato pull mo re g's than a human body should be ever able to endure=0Ahere at Oshkosh. ---- As Walt =0AEvans says, Ain't life grand ?=0A-=0AMike C. in O shkosh=0A-=0A-=0A- href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =0A=0A=0A ________________________________________________________________________________
Date: Jul 26, 2010
Gardiner, you can contact me off list at zharvey(at)bentoncountycable.net or 731-336-6893. Also, just in case anyone is interested, I have a maule tail wheel assembly I'd let go very cheaply. Gene From: airlion Sent: Monday, July 26, 2010 5:46 PM Subject: Re: Pietenpol-List: Ryan and Jess new Piet at Brodhead Gene, I would like to buy your set of Bengellis books. Gardiner Mason --- On Mon, 7/26/10, Gene & Tammy wrote: From: Gene & Tammy <zharvey(at)bentoncountycable.net> Subject: Re: Pietenpol-List: Ryan and Jess new Piet at Brodhead To: pietenpol-list(at)matronics.com Date: Monday, July 26, 2010, 6:41 PM Mike, Thank you for the nice report on N502R. I spent a lot of time bringing her to that point. It was hard to let her go but it really helps that such a nice couple bought her and have become her caretakers. I'm doing well and wish to thank everyone for their prayers. They have really helped. My last exam indicated that the Chemo is working, so keep the prayers coming. As a side note, I have all 4 of Tony Bingelis' books, in new condition, that I will let go to anyone on this list for $50. plus shipping. Everyone, fly safe Gene in beautiful (but VERY HOT) Tennessee From: Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] Sent: Monday, July 26, 2010 3:50 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Ryan and Jess new Piet at Brodhead Now there is a TRUSTING husband to allow an infidel like me to fly thier brand new Pietenpol and then let his wife Jess go along for my first time flying it. What a NICE flying Pietenpol and it climbs really well with a strong engine, straight rigging, and excellent windshields. I flew with no goggles and my contacts in and no issues what so ever. I was honored to be able to hop a few rides for Ryan and Jess, plus Jack Phillips had enough for the day and was meeting up on the field with one of his good buddies from North Carolina. Getting a little sun and seeing Sean Tucker trying to pull more g's than a human body should be ever able to endure here at Oshkosh. As Walt Evans says, Ain't life grand ? Mike C. in Oshkosh href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-Listhref="http://forums.matronics.com">h ttp://forums.matronics.comhref="http://www.matronics.com/contribution"> http://www.matronics.com/chttp://www.matronics="nofollow" target="_blank" href="http://forums.matronics.com">http:/========== ============== ________________________________________________________________________________
Subject: Re: R/C Piet Kit on RCGroups For Sale (Not Mine)
Date: Jul 26, 2010
I guess I missed seeing the picture of your newly acquired Piet in your post Dan... Congrats, and hope to see you in Brodhead with it next year! Billy McCaskill Urbana, IL tail section done, ribs coming next! -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306386#306386 ________________________________________________________________________________
Date: Jul 26, 2010
Douwe, it was a pleasure meeting you and your wife this past weekend! As for the thin-wall stainless tubing, just how thin are you looking for? You might check in your local area for shops that do car exhaust work, many newer cars have stainless exhaust systems and 2.5" diameter is a common size for car exhaust systems. Wall thickness is approximately .032" or thereabout. Might be what you are looking for, and might save you some money getting it locally. Billy McCaskill Urbana, IL tail section done, ribs coming next -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306387#306387 ________________________________________________________________________________
Date: Jul 26, 2010
I have to echo Mike Cuy's sentiments about what a nice airplane that Jess and Ryan have now. I was fortunate enough to get a ride in the plane with Mike at the controls, and it was a great ride. He even let me take the stick for a few minutes. It flew just like an airplane should, and getting a ride was a great shot in the arm for me to stop making excuses and start making sawdust again! It's really a shame that Brodhead lasts only 2 days, how great it would be if it were a week-long event! I got to meet a lot of people, but didn't have enough time to meet as many people as I would have liked to! But there is always next year! Billy McCaskill Urbana, IL tail section done, ribs coming next -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306389#306389 ________________________________________________________________________________
Subject: A Piet owner for two weeks now
Date: Jul 26, 2010
I have had inquiries on the purchase and ownership of my Piet. Rather than hi jacking someone else's topic I'll start one of my own. >From a Barnstormers ad we located a Piet for sale in Collinsville, Ok just north of Tulsa. June 19th Steve R, my son and I flew to Collinsville for an inspection. A few days later my offer was accepted. July 10th Steve R, my son and I flew back to Collinsville for a final inspection and to take delivery. Steve flew it to Alva, OK. Once in Alva Steve gave me a few hours of dual time before soloing and flying it back to Liberal, KS were it is now home. N28WH first flew in 1995 and has approx 200 hrs on the airframe. The A-65 has approx 40 hrs on it since rebuild. I have somewhere between 10 to 15 hrs in it so far. I'm still trying to get the hang of flying a tail dragger. It's getting better. The good landings are beginning to out number the bad. [Shocked] -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306390#306390 Attachments: http://forums.matronics.com//files/sam_0731_115.jpg http://forums.matronics.com//files/cid_9c321fad_1b19_43c5_9de6_8afe831c3dfe_214.jpg http://forums.matronics.com//files/sam_0742_233.jpg http://forums.matronics.com//files/pietenpol_003_183.jpg http://forums.matronics.com//files/cid_36e763f3_a8d3_49f3_a20f_a71a290839b4_803.jpg ________________________________________________________________________________
Subject: Re: A Piet owner for two weeks now
Date: Jul 26, 2010
Thank you. Kevin Helf did a really nice job building that Piet. His wood working ability and equipment would rival that of many cabinet shops. His A&P skills were evident through out the construction. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306410#306410 ________________________________________________________________________________
Date: Jul 26, 2010
Subject: Jess having fun and Ryan's first ride on Sunday morning
with Jack Phillips The great part about Gene P.'s Piet being flown at Bhead by Jack Phillips was the fact that on Sunday morning Jack tookoff with a stout Ryan Mueller (much like me) in the front seat to the East into a nice 10 mph breeze and that airplane did a great job of getting out of there, bar none. I'm impressed as could be. Several good buddies including Glenn Thomas, Rob Busch, and John Hofmann watched as Gene's Cloudcar prop and that newer 50 SMOH engine and combo was incredible getting out of there. They did a fine job and I hope Ryan will give us his impressions of what he felt the plane handled like from the front seat after they got flying over to Poplar Grove, IL (Home of Dan Helsper's AMAZING Ford Piet for fuel. Gene P. should be given a very big pat on the back for just building by the plans to have a VERY NICE performing Piet as the plans show------stellar perofrmance without reinvening the wheel. My hat is off to Gene P. from TN. Congrats to Ryan and Jess in Chicago for being the new caretakers of her. Mike C. ________________________________________________________________________________
Date: Jul 27, 2010
Subject: Re: Jess having fun and Ryan's first ride on Sunday morning
with Jack Phillips
Hi Mike, She did an admirable job of hauling Jack and my "stout" behind out of Brodhead, indeed. This was also with an almost full tank of gas; we filled up the evening before and there was only one short ride hopped that morning. Granted she did not climb like a rocket, but we were able to keep up with Dan & Dan. That was my first time up in a Piet so I can't compare to other Piets, but she flew nicely. Just to clarify, Gene was not the original builder of N502R. With that being said he is responsible for making her such a beautiful, strong flying airplane, having done a quality major overhaul on the engine, installing the Cloudcars prop, etc. We feel very blessed to have been given the chance to be N502R's caretakers and we look forward to having lots of fun with her and sharing her with others as much as we possibly can. Time for bed. Have fun at OSH Mikee! Ryan On Mon, Jul 26, 2010 at 11:34 PM, Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation] wrote: > Aerospace Corporation]" > > > The great part about Gene P.'s Piet being flown at Bhead by Jack Phillips > was the fact that on Sunday morning Jack tookoff with a stout Ryan Mueller > (much like me) in the front seat to the East > into a nice 10 mph breeze and that airplane did a great job of getting out > of there, bar none. I'm impressed as could be. Several good buddies > including Glenn Thomas, Rob Busch, and John Hofmann > watched as Gene's Cloudcar prop and that newer 50 SMOH engine and combo > was incredible getting out of there. They did a fine job and I hope Ryan > will give us his impressions of what he felt the plane handled like from the > front seat after they got flying over to Poplar Grove, IL (Home of Dan > Helsper's AMAZING Ford Piet for fuel. Gene P. should be given a very big > pat on the back for just building by the plans to have a VERY NICE > performing Piet as the plans show------stellar perofrmance without > reinvening the wheel. My hat is off to Gene P. from TN. Congrats to > Ryan and Jess in Chicago for being the new caretakers of her. > > Mike C. > > ________________________________________________________________________________
Date: Jul 26, 2010
morning with Jack Phillips Congrats to Ryan and Jess.- I hope to be able to make next years pilgrama ge to Brodhead in NX92GB.- Jess nice camera work covering Axle's airshow, but -I could hear some worry in your voice, could not have had a better cammera angle anywhere.- Kevin, thats was some good stick and rudder skil ls, and I hope to meet you next year at brodhead with your nice corvair pie t.- If I happen to be down in Texas in the next year or so I will look yo u up, I go to Dallas once in a while and could catch a flight to Austin if I have the time (a free fringe bennifit of working for an airline).- - Shad=0A=0A=0A ________________________________________________________________________________
Subject: Re: Brodhead 2010: Memories (courtesy of Gene Rambo)
Date: Jul 27, 2010
This was my first time at Brodhead, and I enjoyed every minute of it. When I heard it thundering I was glad to be in a dry motel room :) I'm still kind of new to the Piet. but learned a lot while there. I really wanted to go for a ride, but I feel way to awkward asking someone for a ride in there airplane. We ( my girlfriend and I) will be back next year hopefully with some picture progress on my Pietenpol. Great even, loved it! Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306427#306427 ________________________________________________________________________________
Date: Jul 27, 2010
Hi Larry, Welcome to the list! I believe I spoke with you, your daughter, and a gentleman from SW Minnesota while I was buttoning up N8031 one night. Or, maybe that wasn't you - I met so many wonderful people I can't keep everyone straight in my head. I thought you already had a flying Pietenpol? Or again, is that my faulty memory playing tricks on me? Dan On 07/27/2010 07:52 AM, Larry Vetter wrote: > --> Pietenpol-List message posted by: "Larry Vetter" > > This was my first time at Brodhead, and I enjoyed every minute of it. When I heard it thundering I was glad to be in a dry motel room :) > > I'm still kind of new to the Piet. but learned a lot while there. I really wanted to go for a ride, but I feel way to awkward asking someone for a ride in there airplane. We ( my girlfriend and I) will be back next year hopefully with some picture progress on my Pietenpol. Great even, loved it! > > Larry > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306427#306427 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 27, 2010
Subject: =?UTF-8?Q?(CS)=C2=B2 t-shirts?
Hey Bratman; are you really making up some "Crank Snappin' Corvair Society" t-shirts to sell? I would like to be first in line if you are. We should get somebody with artistic skills to make up a (CS) logo for us to emblazon with pride on our Corvair powered birds. Maybe Karetaker Aero as he's obviously had some practice at it. By the way, the new Hitler spoof had me rollin' on the floor when the boss walked in. Embarrassing but worth it. Tom Stinemetze N328X or maybe N328 x (CS) ________________________________________________________________________________
Date: Jul 27, 2010
Subject: =?iso-8859-1?Q?Re=3A_Pietenpol-List=3A_=28CS=29=B2_t-shirts?
If there is a big enough, (serious) interest in a(CS)2- type logo, I can work on that. Always open for logo ideas/designs! Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com - ________________________________________________________________________________
Subject: =?iso-8859-1?Q?RE=3A_Pietenpol-List=3A_Re=3A_Pietenpol-List=3A_?=
=?iso-8859-1?Q?=28CS=29=B2_t-shirts?
Date: Jul 27, 2010
I would buy several (CS)2 t-shirts. Brian SLC-UT From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Tuesday, July 27, 2010 11:12 AM Subject: Pietenpol-List: Re: Pietenpol-List: (CS)=B2 t-shirts If there is a big enough, (serious) interest in a(CS)2 type logo, I can work on that. Always open for logo ideas/designs! Michael Perez Karetaker Aero www.karetakeraero.com - ________________________________________________________________________________
From: Matthew VanDervort <matthew.vandervort(at)gmail.com>
Subject: Re: ?Q?Re:_Pietenpol-List:_RE:_Pietenpol-List:_Re:_Pietenpol-?= =?utf-8?Q?List:_=28CS=29=C2=B2_t-shirts?
Date: Jul 27, 2010
I would buy a couple as well!! Sent from my iPhone On Jul 27, 2010, at 1:18 PM, brian.e.jardine@l-3com.com wrote: > I would buy several (CS)2 t-shirts. > > > > Brian > > SLC-UT > > > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Michael Perez > Sent: Tuesday, July 27, 2010 11:12 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Pietenpol-List: (CS)=C2=B2 t-shirts > > > > If there is a big enough, (serious) interest in a(CS)2 type logo, I can w ork on that. Always open for logo ideas/designs! > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > - > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 27, 2010
Subject: Re: ?Q?Re:_Pietenpol-List:_Re:_Pietenpol-List:_(CS)=C2=B2_t-shirts?
Hi Michael, Put me down for a shirt. thanks, Jim ----- Original Message ----- From: "Michael Perez" <speedbrake(at)sbcglobal.net> Sent: Tuesday, July 27, 2010 10:11:50 AM Subject: Pietenpol-List: Re: Pietenpol-List: (CS)=C2=B2 t-shirts If there is a big enough, (serious) interest in a(CS)2=C2- type logo, I c an work on that. Always open for logo ideas/designs! Michael Perez K aretaker Aero www.karetakeraero.com - == ________________________________________________________________________________
Subject: Re: 859-1?Q?Re:_Pietenpol-List:_=28CS=29=B2_t-shirts?
Date: Jul 27, 2010
Actually, yes I am. I am just about finished. I have been revamping my website and will post them in the next week or so as I have a bit of time while on vacation this week. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Jul 27, 2010, at 11:29 AM, TOM STINEMETZE wrote: > Hey Bratman; are you really making up some "Crank Snappin' Corvair Society" t-shirts to sell? I would like to be first in line if you are. > > We should get somebody with artistic skills to make up a (CS)=B2 logo for us to emblazon with pride on our Corvair powered birds. Maybe Karetaker Aero as he's obviously had some practice at it. By the way, the new Hitler spoof had me rollin' on the floor when the boss walked in. Embarrassing but worth it. > > Tom Stinemetze > N328X > or maybe N328 x (CS)=B2 > > > > ________________________________________________________________________________
Date: Jul 27, 2010
Subject: =?iso-8859-1?Q?Re=3A_Pietenpol-List=3A_RE=3A_Pietenpol-List=3A_Re=3A_Piet?=
=?iso-8859-1?Q?enpol-List=3A_=28CS=29=B2_t-shirts? I am missing something. What is a CS2 t shirt? I haven't seen any pictures of it. Gardiner. --- On Tue, 7/27/10, Matthew VanDervort wrot e: From: Matthew VanDervort <matthew.vandervort(at)gmail.com> Subject: Re: Pietenpol-List: RE: Pietenpol-List: Re: Pietenpol-List: (CS) =B2 t-shirts Date: Tuesday, July 27, 2010, 1:37 PM I would buy a couple as well!! Sent from my iPhone On Jul 27, 2010, at 1:18 PM, brian.e.jardine@l-3com.com wrote: =0A=0A=0A=0AI would buy several (CS)2 -t-shirts. =0A=0A - =0A=0ABrian =0A=0ASLC-UT =0A=0A - =0A=0A=0A=0AFrom: owner-pietenpol-list-server@matro nics.com=0A[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael=0APerez =0ASent: Tuesday, July 27, 2010 11:12 AM =0ATo: pietenpol-list(at)matronics.com =0ASubject: Pietenpol-List: Re: Pietenpol-List: (CS)=B2 t-shirts =0A=0A=0A =0A - =0A=0A=0A =0A =0A If there is a big enough, (serious) interest in =0A a(CS)2- type logo, I can work on that. Always open for logo=0A idea s/designs! =0A =0A Michael Perez =0A Karetaker Aero =0A www.karetakeraero.com =0A =0A - =0A =0A =0A=0A=0A - -http://www.matronics.com/Navigator?Pietenp ol-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution - =0A=0A=0A=0A=0A=0A ========= >http://www.matronics.com/Navigator?Pietenpol-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contributio n ========= =0A ________________________________________________________________________________
Date: Jul 27, 2010
Subject: =?iso-8859-1?Q?Re=3A_Pietenpol-List=3A_Re=3A_Pietenpol-List=3A_=28CS=29?=
=?iso-8859-1?Q?=B2_t-shirts? Thank you Tom for the kind words. Feel free to use that logo as a screen sa ver. (But please do not reproduce it.- 8^[ )- ) I actually have a few o ther logos just like it for "Homebuilders" and "Experimental". Ultimately, I would like to buy an embroidery set-up and sell them and my other creatio ns in the form of patches that can sewn on anything the customer wishes. It appears that John Hoffman is already in the works on just such a logo. I f he would like some input, or if we believe there should be more then one entity working on such a project, I could work on the art. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Jul 27, 2010
Subject: Fwd: Fw: Cajun Recipes
----=_NextPart_000_007C_01CB2B50.1E874270-- ________________________________________________________________________________
Date: Jul 27, 2010
Subject: Re: ?Q?Re:_Pietenpol-List:_(CS)=C2=B2_t-shirts?
Hi John, I should have known you were the one doing the crank snapping shirts. I def initely want at least one. Thanks and it was nice seeing you at Brodhead. Jim ----- Original Message ----- From: "John Hofmann" <jhofmann(at)reesgroupinc.com> Sent: Tuesday, July 27, 2010 11:21:17 AM Subject: Re: Pietenpol-List: (CS)=C2=B2 t-shirts Actually, yes I am. I am just about finished. I have been revamping my webs ite and will post them in the next week or so as I have a bit of time while on vacation this week. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email:=C2- jhofmann(at)reesgroupinc.com On Jul 27, 2010, at 11:29 AM, TOM STINEMETZE wrote: Hey Bratman; are you really making up some "Crank Snappin' Corvair Society" t-shirts to sell?=C2- I would like to be first in line if you are.=C2- We should get somebody with artistic skills to make up a (CS)=C2=B2 logo fo r us to emblazon with pride on our Corvair powered birds.=C2- Maybe Karet aker Aero as he's obviously had some practice at it.=C2- By the way, the new Hitler spoof had me rollin' on the floor when the boss walked in.=C2- Embarrassing but worth it. Tom Stinemetze N328X or maybe N328 x (CS)=C2=B2 href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com/">htt p://forums.matronics.com href="http://www.matronics.com/contribution">htt p://www.matronics.com/contribution == ________________________________________________________________________________
Date: Jul 27, 2010
Subject: =?iso-8859-1?Q?Re=3A_Pietenpol-List=3A_Re=3A_Pietenpol-List=3A_Re=3A_Piet?=
=?iso-8859-1?Q?enpol-List=3A_=28CS=29=B2_t-shirts? I appreciate that Tom.- Embroided patches are something that will take ti me mainly because of the initial start up costs, but I feel eventually, I w ill get there. Michael Perez Karetaker Aero www.karetakeraero.com - ________________________________________________________________________________
Subject: Flight report- First Flight into Brodhead NX929DH...a
log entry
Date: Jul 27, 2010
Hello all you good people, I finally was able to catch my breath after returning from Brodhead, to do a little writing. Got up early on Friday. Kept checking the weather radar every 15 minutes.. .............watching that stationary front, was agonizing. Had to wait ti ll 12 noon on Friday to depart, since my home-made prop could not tolerate one drop of rain. At 12:15, was finally able to start-er up, and taxi out to runway. As I took-off, and ventured away from the Poplar Grove Airport perimeter, I got a lump in my throat and a knot in my stomach. I said to myself..."now I know how Charles Lindbergh felt when he left the security of the land beneath him (Nova Scotia), and ventured out over the Atlantic "..............there was no turning back now.................... very nerv ous along the way.... kept checking the oil pressure, water temp., and pic king out emergency landing fields on the ground along the way.........over and over and over again............ took comfort in the repetitive report , from the sound of my Ford model A ............. ........"pockita-pockit a-pockita-pockita".....Finally was able to settle down, look down, and app reciate God's creation....How beautiful she is!!! WOW!!! ........was using my GPS to stay on course.....after about 35 minutes, got close enough to spot the airfield at Brodhead.......turned off the GPS, and as I approach ed closer, lowered the nose, increased airspeed, and came roaring-in over the treetops to surprise the crowd!!!!........it was spectacular.!!!! ... Made a tight right-hand turn,.... and then a left....... then hard-over for a 45-degree- bank, 360 turn right over the crowd at low level....... came-around.... and landed.....taxied -in and shut-er down right in front of the crowd......before I could remove my goggles and leather helmet, I was getting an ovation......WOW!!!.......ten years of building finally pa id-off!!! Thanks to all for the support and encouragement along the way, from everyb ody on this list. I don't know about you all, but I am addicted to this li st, and I consider you all among my good friends, even though I have never met many of you. This list and it's people is what kept me going through the years, when I was stuck or discouraged. Those few days when nobody wr ote in were very depressing for me. So keep writing. Dan Helsper Poplar Grove, IL. Got up early on Friday. Kept checking the weather radar every 15 minutes.. .............watching that stationary front, was agonizing. Had to wait ti ll 12 noon on Friday to depart, since my home-made prop could not tolerate one drop of rain. At 12:15, was finally able to start-er up, and taxi out to runway. As I took-off, and ventured away from the Poplar Grove Airport perimeter, I got a lump in my throat and a knot in my stomach. I said to myself..."now I know how Charles Lindbergh felt when he left the security of the land beneath him (Nova Scotia), and ventured out over the Atlantic "..............there was no turning back now.................... very nerv ous along the way.... kept checking the oil pressure, water temp., and pic king out emergency landing fields on the ground along the way.........over and over and over again............ took comfort in the repetitive report , from the sound of my Ford model A ............. ........"pockita-pockit a-pockita-pockita".....Finally was able to settle down, look down, and app reciate God's creation....How beautiful she is!!! WOW!!! ........was using my GPS to stay on course.....after about 35 minutes, got close enough to spot the airfield at Brodhead.......turned off the GPS, and as I approach ed closer, lowered the nose, increased airspeed, and came roaring-in over the treetops to surprise the crowd!!!!........it was spectacular.!!!! ... Made a tight right-hand turn,.... and then a left....... then hard-over for a 45-degree- bank, 360 turn right over the crowd at low level....... came-around.... and landed.....taxied -in and shut-er down right in front of the crowd......before I could remove my goggles and leather helmet, I was getting an ovation......WOW!!!.......ten years of building finally pa id-off!!! Thanks to all for the support and encouragement along the way, from everyb ody on this list. I don't know about you all, but I am addicted to this li st, and I consider you all among my good friends, even though I have never met many of you. This list and it's people is what kept me going through the years, when I was stuck or discouraged. Those few days when nobody wr ote in were very depressing for me. So keep writing. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Re: Flight report- First Flight into Brodhead NX929DH...a
log en
Date: Jul 27, 2010
After about 35 MINUTES? Now how do you equate that to crossing the Atlantic, at night-? Here in Texas it takes that long just to unfold our state map! ;o) Just kidding with you, Dan. What a handsome airplane you've built, and it's great to hear all the excitement. Well worth celebrating. I'm sure your daughter is mighty proud of you, too. (That IS your daughter in the picture with you, isn't it?) -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306508#306508 ________________________________________________________________________________
Date: Jul 27, 2010
log entry Dan, Beautiful post; beautiful experience, beautiful plane, great builder. Congratulations. Keep it up. This is an important milestone, but now you need to add the hours, see the sites, buy the $$$ burgers, look over more of God's green earth. Get bugs on your teeth. You have done the heavy lifting, fun though it may have been. Now is the second phase of "fun... fun... fun...," and no one takes the T-bird away. Piet builders and fliers are special people, all right. Look what they did to help Kevin Purtee this last week. Look at all the posts in great detail, unselfishly offered, over the years. All the pictures of tiny little details. Terrific stories and cameraderie. And of course Brodhead is magical. Tim in central TX -----Original Message----- From: helspersew(at)aol.com Sent: Jul 27, 2010 7:41 PM Subject: Pietenpol-List: Flight report- First Flight into Brodhead NX929DH...a log entry Hello all you good people, I finally was able to catch my breath after returning from Brodhead, to do a little writing. Got up early on Friday. Kept checking the weather radar every 15 minutes...............watching that stationary front, was agonizing. Had to wait till 12 noon on Friday to depart, since my home-made prop could not tolerate one drop of rain. At 12:15, was finally able to start-er up, and taxi out to runway. As I took-off, and ventured away from the Poplar Grove Airport perimeter, I got a lump in my throat and a knot in my stomach. I said to myself..."now I know how Charles Lindbergh felt when he left the security of the land beneath him (Nova Scotia), and ventured out over the Atlantic"..............there was no turning back now.................... very nervous along the way.... kept checking the oil pressure, water temp., and picking out emergency landing fields on the ground along the way.........over and over and over again............ took comfort in the repetitive report, from the sound of my Ford model A ............. ........"pockita-pockita-pockita-pockita".....Finally was able to settle down, look down, and appreciate God's creation....How beautiful she is!!! WOW!!! ........was using my GPS to stay on course.....after about 35 minutes, got close enough to spot the airfield at Brodhead.......turned off the GPS, and as I approached closer, lowered the nose, increased airspeed, and came roaring-in over the treetops to surprise the crowd!!!!........it was spectacular.!!!! ... Made a tight right-hand turn,.... and then a left....... then hard-over for a 45-degree- bank, 360 turn right over the crowd at low level....... came-around.... and landed.....taxied -in and shut-er down right in front of the crowd......before I could remove my goggles and leather helmet, I was getting an ovation......WOW!!!.......ten years of building finally paid-off!!! Thanks to all for the support and encouragement along the way, from everybody on this list. I don't know about you all, but I am addicted to this list, and I consider you all among my good friends, even though I have never met many of you. This list and it's people is what kept me going through the years, when I was stuck or discouraged. Those few days when nobody wrote in were very depressing for me. So keep writing. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
log en
Date: Jul 27, 2010
Dan, I saw your airplane and heard some of your explanations of your wheel covering. Congratulations, it is a beautiful ship. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306510#306510 ________________________________________________________________________________
Date: Jul 27, 2010
log entry Congratulations on finishing such a fine bird. I only wish I only lived 35 minutes away, because I sure would have loved to have my plane there instead of a rented Nissan. I'm only about 1300 miles away, so that is about 20 hours flying time. I'd sure feel like Lindberg at the end of that flight! Maybe some day. Nice meeting you and all the others in person, only wish I'd had more time to spend with each of you. Ben Charvet Soon to be back in Mims, Fl On 7/27/2010 8:41 PM, helspersew(at)aol.com wrote: > Hello all you good people, > I finally was able to catch my breath after returning from Brodhead, > to do a little writing. > > Got up early on Friday. Kept checking the weather radar every 15 > minutes...............watching that stationary front, was agonizing. > Had to wait till 12 noon on Friday to depart, since my home-made prop > could not tolerate one drop of rain. At 12:15, was finally able to > start-er up, and taxi out to runway. As I took-off, and ventured away > from the Poplar Grove Airport perimeter, I got a lump in my throat and > a knot in my stomach. I said to myself..."now I know how Charles > Lindbergh felt when he left the security of the land beneath him (Nova > Scotia), and ventured out over the Atlantic"..............there was no > turning back now.................... very nervous along the way.... > kept checking the oil pressure, water temp., and picking out emergency > landing fields on the ground along the way.........over and over and > over again............ took comfort in the repetitive report, from > the sound of my Ford model A ............. > ........"pockita-pockita-pockita-pockita".....Finally was able to > settle down, look down, and appreciate God's creation....How beautiful > she is!!! WOW!!! ........was using my GPS to stay on course.....after > about 35 minutes, got close enough to spot the airfield at > Brodhead.......turned off the GPS, and as I approached closer, lowered > the nose, increased airspeed, and came roaring-in over the treetops to > surprise the crowd!!!!........it was spectacular.!!!! ... Made a tight > right-hand turn,.... and then a left....... then hard-over for a > 45-degree- bank, 360 turn right over the crowd at low level....... > came-around.... and landed.....taxied -in and shut-er down right in > front of the crowd......before I could remove my goggles and leather > helmet, I was getting an ovation......WOW!!!.......ten years of > building finally paid-off!!! > _*/Thanks to all for the support and encouragement along the way/*_, > from everybody on this list. I don't know about you all, but I am > addicted to this list, and I consider you all among my good friends, > even though I have never met many of you. This list and it's people is > what kept me going through the years, when I was stuck or discouraged. > Those few days when nobody wrote in were very depressing for me. So > keep writing. > Dan Helsper > Poplar Grove, IL. > ________________________________________________________________________________
Subject: A Ford:
Date: Jul 27, 2010
Never mind you Cranky Snappers! Check out this for your "A" powered Time Machine. :-) Clif ________________________________________________________________________________
log en
Date: Jul 27, 2010
A great Piet and a great guy Congratulations Dan, but East to West was also that flyer Beryl Markham , also solo across the Atlantic. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306516#306516 ________________________________________________________________________________
Date: Jul 27, 2010
Subject: Re: Pietenpol-List: =?ISO-8859-1?Q?=28CS=29=B2?= =?ISO-8859-1?Q?_t-shirts?
I'll take one. Darrel Jones Pfeifer Sport N154JP On 7/27/2010 10:11 AM, Michael Perez wrote: > If there is a big enough, (serious) interest in a(CS)2 type logo, I > can work on that. Always open for logo ideas/designs! > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > - > > > * > > > * ________________________________________________________________________________
Subject: Broadhead 2010
Date: Jul 27, 2010
Just got back to Remsen NY, 2200 miles R/T, driving. Sure would be nice to do it in a GN-1. I just want to say that this event is what grassroots flying is all about. No glitzy airshow but great people, great food, and great airplanes all around. Special thanks to Dale McCleskey for bringing the only GN-1 (that I saw) and for the great ride he gave me including some flying from the front hole. I have a real incentive to get my bird in the air and see if I can sit in it long enough to get to Brodhead in 2011. I think Dale was a newcomer to Brodhead but he sure flew the pants off that little bird and he always had a different passenger. Dale, I hope you got home OK and will post some of your navigation experiences. Great stories! Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306520#306520 ________________________________________________________________________________
Date: Jul 27, 2010
log entry
Congratulations Dan! Great write-up as well. Here's a couple vids we had from the weekend...(sorry, not the greatest) Arrival: http://www.youtube.com/watch?v=MHheb54LX9s <http://www.youtube.com/watch?v=MHheb54LX9s>Taking off: http://www.youtube.com/watch?v=e_dTXVEiHh4 <http://www.youtube.com/watch?v=e_dTXVEiHh4>Ryan On Tue, Jul 27, 2010 at 7:41 PM, wrote: > Hello all you good people, > > I finally was able to catch my breath after returning from Brodhead, to do > a little writing. > > Got up early on Friday. Kept checking the weather radar every 15 > minutes...............watching that stationary front, was agonizing. Had to > wait till 12 noon on Friday to depart, since my home-made prop could not > tolerate one drop of rain. At 12:15, was finally able to start-er up, and > taxi out to runway. As I took-off, and ventured away from the Poplar Grove > Airport perimeter, I got a lump in my throat and a knot in my stomach. I > said to myself..."now I know how Charles Lindbergh felt when he left the > security of the land beneath him (Nova Scotia), and ventured out over the > Atlantic"..............there was no turning back now.................... > very nervous along the way.... kept checking the oil pressure, water temp., > and picking out emergency landing fields on the ground along the > way.........over and over and over again............ took comfort in the > repetitive report, from the sound of my Ford model A ............. > ........"pockita-pockita-pockita-pockita".....Finally was able to settle > down, look down, and appreciate God's creation....How beautiful she is!!! > WOW!!! ........was using my GPS to stay on course.....after about 35 > minutes, got close enough to spot the airfield at Brodhead.......turned off > the GPS, and as I approached closer, lowered the nose, increased airspeed, > and came roaring-in over the treetops to surprise the crowd!!!!........it > was spectacular.!!!! ... Made a tight right-hand turn,.... and then a > left....... then hard-over for a 45-degree- bank, 360 turn right over the > crowd at low level....... came-around.... and landed.....taxied -in and > shut-er down right in front of the crowd......before I could remove my > goggles and leather helmet, I was getting an ovation......WOW!!!.......ten > years of building finally paid-off!!! > > *Thanks to all for the support and encouragement along the way*, from > everybody on this list. I don't know about you all, but I am addicted to > this list, and I consider you all among my good friends, even though I have > never met many of you. This list and it's people is what kept me going > through the years, when I was stuck or discouraged. Those few days when > nobody wrote in were very depressing for me. So keep writing. > > > Dan Helsper > Poplar Grove, IL. > > ________________________________________________________________________________
Subject: model a engine available?
Date: Jul 27, 2010
I see on craigslist that there is a 1929 flathead 4 model A engine with tra nny for $125. Don't know if this is a desirable core or not. This is in t he Minneapolis=2C Mn area. Tom B. ________________________________________________________________________________
Subject: Photos from Brodhead 2010
Date: Jul 27, 2010
Okay Piet lovers, I have managed to edit, resize and upload to photobucket.com the 400 photos that I took this past weekend. They have been sized to 800x600 so that they load quickly for easier viewing. Hope that you all enjoy them! http://s238.photobucket.com/albums/ff297/billmz/Brodhead%20Pietenpol%20Fly-In%202010/ -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306527#306527 ________________________________________________________________________________
Subject: Piets in N. California/So. Oregon
Date: Jul 28, 2010
Anybody know of any Piets or builders in the northern California or southern Oregon area? I just noticed a note from Rex Ervin in Klamath Falls, Oregon in the latest BPA newsletter inquiring about this. I'd also like to know if anyone knows Rex and can maybe put me in contact with him? Thanks. PS, had one of the smoothest flights ever in my airplane the other morning. I rarely get to fly in the early morning and it was superb. It really lets you see where your airplane needs tweaking in trim... I think I need to add some more rudder trim to 41CC but had never really noticed it since most of my flying is in the bumpy afternoons. Not a hands-off airplane but I'll bet it could be pretty close to it if I took some time to work on refining it. Gosh, that will mean a lot more flying to get it figured out. Hard work, but somebody has to do it ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Piets in N. California/So. Oregon
Date: Jul 28, 2010
Oscar, Don't know Rex, but there are several of us builders in NCal, including the notorious Chris Tracy. Gary Boothe ------Original Message------ From: Oscar Zuniga Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Piets in N. California/So. Oregon Sent: Jul 28, 2010 7:33 AM Anybody know of any Piets or builders in the northern California or southern Oregon area? I just noticed a note from Rex Ervin in Klamath Falls, Oregon in the latest BPA newsletter inquiring about this. I'd also like to know if anyone knows Rex and can maybe put me in contact with him? Thanks. PS, had one of the smoothest flights ever in my airplane the other morning. I rarely get to fly in the early morning and it was superb. It really lets you see where your airplane needs tweaking in trim... I think I need to add some more rudder trim to 41CC but had never really noticed it since most of my flying is in the bumpy afternoons. Not a hands-off airplane but I'll bet it could be pretty close to it if I took some time to work on refining it. Gosh, that will mean a lot more flying to get it figured out. Hard work, but somebody has to do it ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Jul 28, 2010
log entry Man, that big ol' prop looks good! Thanks for the vids! -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Jul 28, 2010
Oscar, What do you think of your new A75 with the chromed cylinders? Better'n the A65? I'm slowly but surely acquiring the pieces of an A75 with chromed cylinders from my dad... I'm thinking of putting it back together and maybe putting it on my Piet. Though, I gotta say, after the rings seated in the "new" #4 cylinder this past weekend I can't complain much about the new climb rate. Thanks, Dan On 07/28/2010 09:33 AM, Oscar Zuniga wrote: > --> Pietenpol-List message posted by: Oscar Zuniga > > > Anybody know of any Piets or builders in the northern > California or southern Oregon area? I just noticed a > note from Rex Ervin in Klamath Falls, Oregon in the > latest BPA newsletter inquiring about this. I'd also > like to know if anyone knows Rex and can maybe put me > in contact with him? Thanks. > > PS, had one of the smoothest flights ever in > my airplane the other morning. I rarely get to fly in > the early morning and it was superb. It really lets > you see where your airplane needs tweaking in trim... > I think I need to add some more rudder trim to 41CC > but had never really noticed it since most of my > flying is in the bumpy afternoons. Not a hands-off > airplane but I'll bet it could be pretty close to it > if I took some time to work on refining it. Gosh, > that will mean a lot more flying to get it figured out. > Hard work, but somebody has to do it ;o) > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 28, 2010
Hello Oscar, There is a flying Piet in Chico, CA. Don't know the owners name but found o ut about it on this site couple of months ago. Also there is Irwin Furst somewhere in the Lincoln, CA (Sacramento area) wi th a flying Piet. Then there is the group of us starting with Chris Tracy, Carmichael, Gary B oothe, Cool, Michael Weaver, Lincoln, me in Santa Rosa, and Vic and Michael Groah, Tulare all building Piets. Vic and Michael are about ready for cove r and Chris and Gary should also be close. Jim ----- Original Message ----- From: "Oscar Zuniga" <taildrags(at)hotmail.com> Sent: Wednesday, July 28, 2010 7:33:09 AM Subject: Pietenpol-List: Piets in N. California/So. Oregon Anybody know of any Piets or builders in the northern California or southern Oregon area? =C2-I just noticed a note from Rex Ervin in Klamath Falls, Oregon in the latest BPA newsletter inquiring about this. =C2-I'd also like to know if anyone knows Rex and can maybe put me in contact with him? =C2-Thanks. =C2- PS, had one of the smoothest flights ever in my airplane the other morning. =C2-I rarely get to fly in the early morning and it was superb. =C2-It really lets you see where your airplane needs tweaking in trim... I think I need to add some more rudder trim to 41CC but had never really noticed it since most of my flying is in the bumpy afternoons. =C2-Not a hands-off airplane but I'll bet it could be pretty close to it if I took some time to work on refining it. =C2-Gosh, that will mean a lot more flying to get it figured out. Hard work, but somebody has to do it ;o) Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net =C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2- =C2- =C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2- =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Jul 28, 2010
Oregon] On 07/28/2010 09:54 AM, Ryan Mueller wrote: > Ya know, a Cloudcars prop cut for a flanged A-65 might help as well.... :) Yup. That thought did cross my mind, too. I kind of like my McCauley 74x42 prop, though. I'm guessing that I'd need a new one for the A75... Ok, let's take this discussion on yet another tangent: I meant to ask you - what RPM were you and Jack running from Poplar Grove to Olson? I think I was at about 2070 (or 1800 indicated on my tachometer). Were you much off of that? Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: To Door or not to Door
Date: Jul 28, 2010
I'm still gathering info for my decision. One of the few concerns I have is access to the front cockpit. I see that very few Piets seem to have built some kind of door, or at least a lower coaming for the front cockpit. Are there reasons for this of which I'm sorely ignorant? It seems that either a small door, or even just a lowered side on one side, would ease entry and exit. Does anyone have a door? Does it help or not that much? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306563#306563 ________________________________________________________________________________
Subject: Re: Photos from Brodhead 2010
Date: Jul 28, 2010
Great pictures Billy. You really captured the spirit of the event. -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306564#306564 ________________________________________________________________________________
Subject: Re: To Door or not to Door
Date: Jul 28, 2010
Dale McClesky's wood version GN-1 had a door and he gave me a ride at Brodhead. This is the first time I have been in the front cockpit even though I have a 70% complete GN-1. I will definitely make the conversion before I cover the fuselage. I am 67, fairly limber, but I would have had a difficult time getting into the front without the door. Dale said his GN-1 plans showed the door, mine do not for the wood version but do on the steel tube fuselage. One can pretty well interpret what to do from there as the tubing layout almost exactly follows the wood version except for the door. I think there have been plan modifications for the Piet as well which one can find on the internet. If one wants to hop passengers I think the door is a real advantage. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306567#306567 ________________________________________________________________________________
log
Date: Jul 28, 2010
You should see Dan's prop in person, Jeff. It's a work of art, and the perfect crowning touch to the rest of his flawless Piet! -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306568#306568 ________________________________________________________________________________
Date: Jul 28, 2010
Jon I have a door in the front pit and it makes it a lot easier. The way I did it was to add an extra longeron 7 inches lower than plans from the firewall back to behind the rear seat. I also have the 26 inch wide fuse. Empty wt is 750 lbs. Cheers, Gardiner Mason NX 840 LM ----- Original Message ---- From: coxwelljon <coxwelljon(at)frontiernet.net> Sent: Wed, July 28, 2010 12:02:42 PM Subject: Pietenpol-List: Re: To Door or not to Door Dale McClesky's wood version GN-1 had a door and he gave me a ride at Brodhead. This is the first time I have been in the front cockpit even though I have a 70% complete GN-1. I will definitely make the conversion before I cover the fuselage. I am 67, fairly limber, but I would have had a difficult time getting into the front without the door. Dale said his GN-1 plans showed the door, mine do not for the wood version but do on the steel tube fuselage. One can pretty well interpret what to do from there as the tubing layout almost exactly follows the wood version except for the door. I think there have been plan modifications for the Piet as well which one can find on the internet. If one wants to hop passengers I think the door is a real advantage. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306567#306567 ________________________________________________________________________________
wi
Date: Jul 28, 2010
Here's a picture I took of Jess in the front seat with Mike C. at the controls... Definitely looks like they are having fun! -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306572#306572 Attachments: http://forums.matronics.com//files/n502r_732.jpg ________________________________________________________________________________
California/So. Oregon]
Date: Jul 28, 2010
Dan, Ryan and I were running about 2000 RPM to keep from running over Dan Helsper in his Model A powered Piet. I occasionally had to throttle back to 1900 as we still got too close every now and then. Still sitting in west Tennessee waiting for the weather to improve in North Carolina so I can fly the RV-4 home. Gotta get out of here before my mother puts another 15 pounds on me, feeding me all my favorite foods. I hope to be home by Friday. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum Sent: Wednesday, July 28, 2010 11:33 AM Subject: mccauley vs. cloudcars prop [was: Re: Pietenpol-List: Piets in N. California/So. Oregon] On 07/28/2010 09:54 AM, Ryan Mueller wrote: > Ya know, a Cloudcars prop cut for a flanged A-65 might help as well.... :) Yup. That thought did cross my mind, too. I kind of like my McCauley 74x42 prop, though. I'm guessing that I'd need a new one for the A75... Ok, let's take this discussion on yet another tangent: I meant to ask you - what RPM were you and Jack running from Poplar Grove to Olson? I think I was at about 2070 (or 1800 indicated on my tachometer). Were you much off of that? Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 28, 2010
California/So. Oregon] On 07/28/2010 11:29 AM, Jack Phillips wrote: > --> Pietenpol-List message posted by: "Jack Phillips" > > Dan, > > Ryan and I were running about 2000 RPM to keep from running over Dan Helsper > in his Model A powered Piet. I occasionally had to throttle back to 1900 as > we still got too close every now and then. > > Still sitting in west Tennessee waiting for the weather to improve in North > Carolina so I can fly the RV-4 home. Gotta get out of here before my mother > puts another 15 pounds on me, feeding me all my favorite foods. I hope to > be home by Friday. Hi Jack, Hope that weather clears out for you... if only so you don't max out the gross weight on your Piet. ;-) From Brodhead to Poplar Grove I was running 1700 indicated, which is really about 1950 true RPM. What about after we dropped Dan H. off? What RPM were you running between Poplar Grove and Olson? I kept mine steady at 1800 indicated, or 2070 true. Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 28, 2010
Phil, You've gotten a few responses in favor of a door. Let me give some arguments against it, so you can judge for yourself. Pietenpols don't handle weight very well. A small addition in weight makes a big impact on performance. Adding a door requires cutting the main structural member of the fuselage and requires adding a substantial amount of structure to replace the lost strength and stiffness. There are very few lightweight passengers that would require a door. The ones that are heavy enough to have trouble climbing in without a door are likely too heavy to carry well. I use the lack of a door as a screen to prevent taking the most obese passengers, without having to tel them they are simply too heavy to fly. Just something to think about. "Simplicate and add Lightness" Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phil Sent: Wednesday, July 28, 2010 11:35 AM Subject: Pietenpol-List: To Door or not to Door I'm still gathering info for my decision. One of the few concerns I have is access to the front cockpit. I see that very few Piets seem to have built some kind of door, or at least a lower coaming for the front cockpit. Are there reasons for this of which I'm sorely ignorant? It seems that either a small door, or even just a lowered side on one side, would ease entry and exit. Does anyone have a door? Does it help or not that much? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306563#306563 ________________________________________________________________________________
Date: Jul 28, 2010
After leaving Poplar Grove I was running 2150. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum Sent: Wednesday, July 28, 2010 12:39 PM Subject: Re: mccauley vs. cloudcars prop [was: Re: Pietenpol-List: Piets in N. California/So. Oregon] On 07/28/2010 11:29 AM, Jack Phillips wrote: > --> Pietenpol-List message posted by: "Jack Phillips" > > Dan, > > Ryan and I were running about 2000 RPM to keep from running over Dan Helsper > in his Model A powered Piet. I occasionally had to throttle back to 1900 as > we still got too close every now and then. > > Still sitting in west Tennessee waiting for the weather to improve in North > Carolina so I can fly the RV-4 home. Gotta get out of here before my mother > puts another 15 pounds on me, feeding me all my favorite foods. I hope to > be home by Friday. Hi Jack, Hope that weather clears out for you... if only so you don't max out the gross weight on your Piet. ;-) From Brodhead to Poplar Grove I was running 1700 indicated, which is really about 1950 true RPM. What about after we dropped Dan H. off? What RPM were you running between Poplar Grove and Olson? I kept mine steady at 1800 indicated, or 2070 true. Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 28, 2010
As Jack has mentioned, keeping the weight down is important. Our Piet appears to be built relatively close to the plans, and as such is a lighter airplane. It performs quite nicely....heck, it was able to haul over 1200 lbs out of Brodhead with an A-65 on a nice summer day. If I was to attempt to make it easier to get into or out of, I would much rather raise the cabanes a couple of inches than add all the weight that a front door would require. If you are going to use a Corvair you could probably handle the extra weight better because of having more power on tap, but I would still rather just keep the weight down and have an even better performing airplane. As Jack said, if you are too big to get in without a door then you are probably too heavy to fly in a Piet anyhow. If you are just not limber enough to get in the front with any amount of assistance, then a door is probably not going to make the difference between getting in or not. You still have to climb up inside, and negotiate struts, wires, the wing, etc.... Ryan On Wed, Jul 28, 2010 at 11:40 AM, Jack Phillips wrote: > pietflyr(at)bellsouth.net> > > Phil, > > You've gotten a few responses in favor of a door. Let me give some > arguments against it, so you can judge for yourself. > > Pietenpols don't handle weight very well. A small addition in weight makes > a big impact on performance. Adding a door requires cutting the main > structural member of the fuselage and requires adding a substantial amount > of structure to replace the lost strength and stiffness. > > There are very few lightweight passengers that would require a door. The > ones that are heavy enough to have trouble climbing in without a door are > likely too heavy to carry well. I use the lack of a door as a screen to > prevent taking the most obese passengers, without having to tel them they > are simply too heavy to fly. > > Just something to think about. > > "Simplicate and add Lightness" > > Jack Phillips > NX899JP > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phil > Sent: Wednesday, July 28, 2010 11:35 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: To Door or not to Door > > > I'm still gathering info for my decision. One of the few concerns I have > is > access to the front cockpit. I see that very few Piets seem to have built > some kind of door, or at least a lower coaming for the front cockpit. Are > there reasons for this of which I'm sorely ignorant? It seems that either > a > small door, or even just a lowered side on one side, would ease entry and > exit. Does anyone have a door? Does it help or not that much? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306563#306563 > > ________________________________________________________________________________
Date: Jul 28, 2010
Hi Phil, You have gotten=C2- quite a few responses to your question on door or not . I have added a door to my Piet in building (door plans from Keri Ann Price) and with out the door my wife with two artifical hip joints and one knee w ould not be able to get in. At our West Coast Piet gathering down at Frazie r Lake Charlie Miller, with a door in his Piet, gave my wife a ride. She wa s able to get in without problem with the door but would be prevented from flying in the Piet without it. I weighed all the parts as I built the door for my Piet, I did not rout out the excess wood as the door plans show, and it still added just a few ounc es less than 11 pounds. As I am building with a Corvair I think that is a f air trade for being able to take my wife for rides. Jim Wait until you too are in your 60's or 70's and not so limber; you'll appre ciate your door more then. ----- Original Message ----- From: "Phil" <hopkinsp2(at)gmail.com> Sent: Wednesday, July 28, 2010 8:35:08 AM Subject: Pietenpol-List: To Door or not to Door I'm still gathering info for my decision. =C2-One of the few concerns I h ave is access to the front cockpit. =C2-I see that very few Piets seem to have built some kind of door, or at least a lower coaming for the front co ckpit. =C2-Are there reasons for this of which I'm sorely ignorant? =C2 -It seems that either a small door, or even just a lowered side on one si de, would ease entry and exit. =C2-Does anyone have a door? =C2-Does it help or not that much? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306563#306563 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Jul 28, 2010
Another issue with gravitationally challenged passengers is that they tend to spill over the narrow front seat a bit and prevent full rudder pedal motion (in my plane, anyway). Made for an interesting crosswind roll-out one time... Not that that has much to do with a door. -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Jul 28, 2010
Thanks for the replies. Sounds like a growing contingent of Piets out on the west coast. I may try snooping around with online phone books to see if I can get in touch with Rex in Klamath Falls. As to my A75, it does not have chromed cylinders... the bores were in good shape and only needed dressing after reconditioning. It pulls stronger than my A65, doesn't leak or burn oil, has GREAT oil pressure, and seems to be settling in after overhaul (still only about 30 hrs. on it). This one has the flanged hub for the prop; the 65 had a tapered hub. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306589#306589 ________________________________________________________________________________
Date: Jul 28, 2010
Ryan; I'm interested in your comment about hauling 1200 lbs.- obviously you're running a higher gross weight than 41CC, which Corky registered as 1088 lbs. so that's what I have on all my paperwork. That's 102 lbs. difference; quite a bit. I have flown my airplane at gross with the A65 on a hot day and it was OK but no great shakes. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306591#306591 ________________________________________________________________________________
Subject: swapping rides
Date: Jul 28, 2010
Question for you guys who have had the pleasure of flying not only your Piet, but perhaps several others: what kinds of differences do you note between the different Piets you've flown? I ask the question because I saw Mike Cuy flying a "foreign" airplane with passenger and am curious to know how these planes might vary in handling. I'm certain that the airplane and propeller combo make a big difference, but what about just the flying and handling characteristics? Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jul 28, 2010
It would seem the gross weight is a nebulous figure from aircraft to aircraft. You have A-65 powered Piets placarded in the mid 1000s, and then you have Corvair powered Piets in the mid 1200s. The Last Original, with the lower powered Pietenpol engine conversion (70hp according to the data plate), is placarded at 1282..... Ryan On Wed, Jul 28, 2010 at 12:53 PM, taildrags wrote: > > Ryan; I'm interested in your comment about hauling 1200 lbs.- obviously > you're running a higher gross weight than 41CC, which Corky registered as > 1088 lbs. so that's what I have on all my paperwork. That's 102 lbs. > difference; quite a bit. > > I have flown my airplane at gross with the A65 on a hot day and it was OK > but no great shakes. > > -------- > Oscar Zuniga > San Antonio, TX > Air Camper NX41CC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306591#306591 > > ________________________________________________________________________________
Date: Jul 28, 2010
Hi Ryan, et al; The differing gross weights make sense considering the empty weights vary g reatly. Mike Cuy I think said his empty weight was 632lbs while Dick Navrat il's new Piet with the radial is 810lbs. Put two 200lb people in each one a nd you have 1032lbs and 1210lbs respectively. some Piets have longer center sections for more fuel but also benefit from more wing area. Jim ----- Original Message ----- From: "Ryan Mueller" <rmueller23(at)gmail.com> Sent: Wednesday, July 28, 2010 11:31:34 AM Subject: Re: Pietenpol-List: Re: To Door or not to Door It would seem the gross weight is a nebulous figure from aircraft to aircra ft. You have A-65 powered Piets placarded in the mid 1000s, and then you ha ve Corvair powered Piets in the mid 1200s. The Last Original, with the lowe r powered Pietenpol engine conversion (70hp according to the data plate), i s placarded at 1282..... Ryan On Wed, Jul 28, 2010 at 12:53 PM, taildrags < taildrags(at)hotmail.com > wrote : Ryan; I'm interested in your comment about hauling 1200 lbs.- obviously you 're running a higher gross weight than 41CC, which Corky registered as 1088 lbs. so that's what I have on all my paperwork. =C2-That's 102 lbs. diff erence; quite a bit. I have flown my airplane at gross with the A65 on a hot day and it was OK b ut no great shakes. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306591#306591 =========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List =========== http://forums.matronics.com =========== le, List Admin. ="_blank">http://www.matronics.com/contribution =========== == ________________________________________________________________________________
Date: Jul 28, 2010
Hi Oscar, That's a good question and one that has not been discussed much that I know of. I have flown four Air Campers: 1. A GN-1 built by Mike Lucky back in 1975 (I thought it was a Pietenpol), that he had just finished and asked me to help fly off some of the test time on it. It had a Continental 65 and wire wheels and flew very well. It flew almost exactly like the J-3 Cub that I owned at the time. Cruise was about 75 mph and climb was a spritely 350 fpm. 2. Mike Cuy's NX48MC. It had been a little over 25 years since I last flew an Air Camper so I didn't have much to compare it to. It flew very well, but the main thing I remember was my tendency to land it about 3 feet off the ground. Until he told me to come in a bit faster and not flare until I was just above the ground, I was always dropping it in. Climb was OK with one person on board, not so good with two. 3. My own Icarus Plummet (NX899JP). It flies very much like Mike Cuy's, which should be expected since they both have wire wheels, straight axles and Continental 65's. The biggest difference is that mine weighs 120 lbs more than Mike's, and the climb rate is not as good. My deck angle is also a bit higher than his (21" wheels versus his 19" wheels) and the result is that mine is slightly more difficult to land. I usually wheel land mine because it is very difficult to get 3 good 3-point landings in a row with it. With me alone I can get about 400 fpm climb and the cruise is about 72. With a 200 pounder in the front seat on a hot day, I get a good solid 100 fpm climb. 4. Ryan Mueller's N502R, which I ferried to Brodhead for him. This is the best flying Pietenpol I have flown. It is not quite as light as Mike Cuy's (645 lbs compared to Cuy's 632 lbs) but it has a Jay Anderson CloudCars prop that gives it superlative performance. Like every other Pietenpol I've flown, it has a Continental A65 for power. The big difference it had from the others is that when I picked it up in Tennessee and flew it for the first time I was appalled at the very heavy and un-responsive ailerons. I looked out and realized they had no gap seals. Once I landed the very first thing I did was to apply blue painter's tape to seal the gaps and the result was astonishing - about double the roll rate and half the stick-force required to move the ailerons. I had read about the benefits of sealing the gaps, but had never flown one without gap seals. It is a HUGE difference. With that prop it climbs very well with one person and not bad with two. When Ryan and I left Brodhead Sunday we weighed 1165 lbs and climbed at about 200 fpm. Cruise at 2150 RPM indicates 77 mph and I believe it to be accurate. I had to throttle back for Randy Bush to keep up with his Corvair powered Pietenpol. I'd like to fly a Corvair powered Pietenpol and a Model A powered one, as long as it is in the midwest where there are plenty of good fields for a forced landing. Hope this helps answer your question, Oscar. Perhaps some others with more experience flying other Pietenpols, such as Lowell Frank, Andrew King or Frank Pavliga will chime in as well. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Wednesday, July 28, 2010 1:56 PM Subject: Pietenpol-List: swapping rides Question for you guys who have had the pleasure of flying not only your Piet, but perhaps several others: what kinds of differences do you note between the different Piets you've flown? I ask the question because I saw Mike Cuy flying a "foreign" airplane with passenger and am curious to know how these planes might vary in handling. I'm certain that the airplane and propeller combo make a big difference, but what about just the flying and handling characteristics? Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jul 28, 2010
This is a great list. Ask a question, get lots of help quickly! I'm not worried about gravitationally challenged passengers. I'm about FAA normal, and the passengers I'll be taking up regularly are all smaller than me. But I am worried about less limber passengers. My wife, for instance, is one of those. Smaller than me, but stiff. None of us are as young as we used to be. So, to rehearse, there's arguments for and against, and my options seem to be to leave it alone, raise the wing (am I getting that right? with the suggestion to add a couple of inches on to the cabanes? does raising the wing change weight and balance or flying characteristics? ), or put in a door. How about just adding a kind of door cut out without an actual door? I would still have to beef up the structure there, as I'd be interrupting the top longeron, but it seems that this is doable at small increase in weight. Is it just too freaky for passengers to have a bit lower structure on one side of them? It seems that at least for some, being able to get the legs in over a lower sill, as it were, helps enough in mounting/dismounting for less limber passengers to make a significant difference (the difference between going flying or just not because it's too hard to get in). It's interesting to see more people with doors than I thought there were. I know of Keri Ann's plans. Vic, if you used a different plan, I'd sure appreciate seeing it and any pics. I am thinking Corvair, but if a nice A65 or, better, C75 were to fall into my lap, I wouldn't kick her out. Thanks again for all the info so far. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306604#306604 ________________________________________________________________________________
Date: Jul 28, 2010
I responded to the question about a front door, and I am in favor of it. It also makes it easier to work on the front pit to the firewall, Also when I saw Kevins plane at Brodhead He had a door panel just behind the firewall to give access to the rudder pedals. A very good idea and I am going to put one in. Gardiner mason ________________________________ From: Ryan Mueller <rmueller23(at)gmail.com> Sent: Wed, July 28, 2010 12:58:59 PM Subject: Re: Pietenpol-List: To Door or not to Door As Jack has mentioned, keeping the weight down is important. Our Piet appears to be built relatively close to the plans, and as such is a lighter airplane. It performs quite nicely....heck, it was able to haul over 1200 lbs out of Brodhead with an A-65 on a nice summer day. If I was to attempt to make it easier to get into or out of, I would much rather raise the cabanes a couple of inches than add all the weight that a front door would require. If you are going to use a Corvair you could probably handle the extra weight better because of having more power on tap, but I would still rather just keep the weight down and have an even better performing airplane. As Jack said, if you are too big to get in without a door then you are probably too heavy to fly in a Piet anyhow. If you are just not limber enough to get in the front with any amount of assistance, then a door is probably not going to make the difference between getting in or not. You still have to climb up inside, and negotiate struts, wires, the wing, etc.... Ryan On Wed, Jul 28, 2010 at 11:40 AM, Jack Phillips wrote: > >Phil, > >You've gotten a few responses in favor of a door. Let me give some >arguments against it, so you can judge for yourself. > >Pietenpols don't handle weight very well. A small addition in weight makes >a big impact on performance. Adding a door requires cutting the main >structural member of the fuselage and requires adding a substantial amount >of structure to replace the lost strength and stiffness. > >There are very few lightweight passengers that would require a door. The >ones that are heavy enough to have trouble climbing in without a door are >likely too heavy to carry well. I use the lack of a door as a screen to >prevent taking the most obese passengers, without having to tel them they >are simply too heavy to fly. > >Just something to think about. > >"Simplicate and add Lightness" > > >Jack Phillips >NX899JP >Raleigh, NC > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com > >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Phil >Sent: Wednesday, July 28, 2010 11:35 AM >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: To Door or not to Door > > >I'm still gathering info for my decision. One of the few concerns I have is >access to the front cockpit. I see that very few Piets seem to have built >some kind of door, or at least a lower coaming for the front cockpit. Are >there reasons for this of which I'm sorely ignorant? It seems that either a >small door, or even just a lowered side on one side, would ease entry and >exit. Does anyone have a door? Does it help or not that much? > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=306563#306563 > > >======================= >st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >========== >http://forums.matronics.com >========== >le, List Admin. >="_blank">http://www.matronics.com/contribution >========== > > ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: progress!
Date: Jul 28, 2010
Got home all fired up and the engine mount is done, the firewall is done and the engine is hanging on the mount!! Brodhead or bust!! (not sure what year though...) Douwe ________________________________________________________________________________
Date: Jul 28, 2010
Jim and the bunch, There is also a Piet flying out of Petaluma. He's been over to Schellville, but I haven't seen him yet. Darrel On 7/28/2010 8:21 AM, Jim Boyer wrote: > > Hello Oscar, > > There is a flying Piet in Chico, CA. Don't know the owners name but > found out about it on this site couple of months ago. > > Also there is Irwin Furst somewhere in the Lincoln, CA (Sacramento > area) with a flying Piet. > > Then there is the group of us starting with Chris Tracy, Carmichael, > Gary Boothe, Cool, Michael Weaver, Lincoln, me in Santa Rosa, and Vic > and Michael Groah, Tulare all building Piets. Vic and Michael are > about ready for cover and Chris and Gary should also be close. > > Jim > > > ----- Original Message ----- > From: "Oscar Zuniga" <taildrags(at)hotmail.com> > To: "Pietenpol List" > Sent: Wednesday, July 28, 2010 7:33:09 AM > Subject: Pietenpol-List: Piets in N. California/So. Oregon > > > Anybody know of any Piets or builders in the northern > California or southern Oregon area? I just noticed a > note from Rex Ervin in Klamath Falls, Oregon in the > latest BPA newsletter inquiring about this. I'd also > like to know if anyone knows Rex and can maybe put me > in contact with him? Thanks. > > PS, had one of the smoothest flights ever in > my airplane the other morning. I rarely get to fly in > the early morning and it was superb. It really lets > you see where your airplane needs tweaking in trim... > I think I need to add some more rudder trim to 41CC > but had never really noticed it since most of my > flying is in the bumpy afternoons. Not a hands-off > airplane but I'll bet it could be pretty close to it > if I took some time to work on refining it. Gosh, > that will mean a lot more flying to get it figured out. > Hard work, but somebody has to do it ;o) > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net &nbbsp; -Matt > Dralle, List Adm======== > > > * > > > * ________________________________________________________________________________
log entry
Date: Jul 28, 2010
Dan=2C beautiful=2C beautiful airplane (even if you did steal my paint sche me)!!! I love the photo of "The Farting Bratmen"=2C it is a wonderful meme nto=2C especially since I (ahem) don't have any photos of my own. (inside jab=2C totally joking) I have to say that I had more fun at this fly-in th an any I can remember. We laughed ourselves silly over the Hitler video=2C we jumped in to help Kevin get back into the air within hours (well=2C he could have)=2C we ate brats=2C we drank beer (just a little bit)=2C we end ured the endless overnight thunderstorms=2C and we each wet ourselves a lit tle bit at the howitzer shot at 4am on saturday! I will never forget a sec ond of any of it!! I cannot wait until next year=2C and I am heading out t he first thing in the morning to get to work to make sure there is another black and yellow german at Brodhead next year. Thank you all for the memories=2C my friends=2C more to come . . . . Gene Rambo Subject: Pietenpol-List: Flight report- First Flight into Brodhead NX929DH. ..a log entry Date: Tue=2C 27 Jul 2010 20:41:48 -0400 From: helspersew(at)aol.com Hello all you good people=2C I finally was able to catch my breath after returning from Brodhead=2C to d o a little writing. Got up early on Friday. Kept checking the weather radar every 15 minutes... ............watching that stationary front=2C was agonizing. Had to wait ti ll 12 noon on Friday to depart=2C since my home-made prop could not tolerat e one drop of rain. At 12:15=2C was finally able to start-er up=2C and taxi out to runway. As I took-off=2C and ventured away from the Poplar Grove Ai rport perimeter=2C I got a lump in my throat and a knot in my stomach. I sa id to myself..."now I know how Charles Lindbergh felt when he left the secu rity of the land beneath him (Nova Scotia)=2C and ventured out over the Atl antic"..............there was no turning back now.................... very nervous along the way.... kept checking the oil pressure=2C water temp.=2C and picking out emergency landing fields on the ground along the way....... ..over and over and over again............ took comfort in the repetitive r eport=2C from the sound of my Ford model A ............. ........"pockita- pockita-pockita-pockita".....Finally was able to settle down=2C look down =2C and appreciate God's creation....How beautiful she is!!! WOW!!! ....... .was using my GPS to stay on course.....after about 35 minutes=2C got close enough to spot the airfield at Brodhead.......turned off the GPS=2C and as I approached closer=2C lowered the nose=2C increased airspeed=2C and came roaring-in over the treetops to surprise the crowd!!!!........it was specta cular.!!!! ... Made a tight right-hand turn=2C.... and then a left....... t hen hard-over for a 45-degree- bank=2C 360 turn right over the crowd at low level....... came-around.... and landed.....taxied -in and shut-er down ri ght in front of the crowd......before I could remove my goggles and leather helmet=2C I was getting an ovation......WOW!!!.......ten years of building finally paid-off!!! Thanks to all for the support and encouragement along the way=2C from every body on this list. I don't know about you all=2C but I am addicted to this list=2C and I consider you all among my good friends=2C even though I have never met many of you. This list and it's people is what kept me going thro ugh the years=2C when I was stuck or discouraged. Those few days when nobod y wrote in were very depressing for me. So keep writing. Dan Helsper Poplar Grove=2C IL. ________________________________________________________________________________
Subject: Re: progress!
Date: Jul 28, 2010
I got home all fired up to get back on my Piet build too, only to realize that my garage needs a very thorough cleaning and re-organizing before I can do anything. Seems that in the year since I've last worked on it, I have totally cluttered up my workspace with much extraneous stuff. I can't even see the top of my table saw. :( And since I'm leaving Friday for two weeks, I don't think that the garage will get cleaned until I return. I did study my blueprints tonight and did a quick inventory of wood on hand though. I guess that's better than not doing anything... And now I am about to watch Dan Helsper's excellent prop carving CD presentation again while the wife works on her nursing homework. -------- Billy McCaskill Urbana, IL tailfeathers almost done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306632#306632 ________________________________________________________________________________
Date: Jul 28, 2010
Subject: Dan's Prop
Dan, Is it still possible to get your CD about carving a prop? Your prop looked good in pictures, but seeing it right there in front of my eyes was a truly moving experience. John Fay in Peoria ________________________________________________________________________________
Subject: Re: Dan's Prop
Date: Jul 29, 2010
Hi John, Thank you for the compliment on my prop. Yes, you can get the prop-carving CD from me. Send me $25 to PO Box 454, Belvidere, IL. and it will go out post paid. Also now available at Aircraftspruce.com, but it will cost mor e. Dan Helsper Poplar Grove, IL. -----Original Message----- From: John Fay <jfay1950(at)gmail.com> Sent: Wed, Jul 28, 2010 10:36 pm Subject: Pietenpol-List: Dan's Prop Dan, Is it still possible to get your CD about carving a prop? Your prop looked good in pictures, but seeing it right there in front of my eyes was a truly moving experience. John Fay in Peoria ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jul 29, 2010
The full address (with the zip code) is Dan Helsper, PO Box 454, Belvidere , IL. 61008. :O) -----Original Message----- From: helspersew(at)aol.com Sent: Thu, Jul 29, 2010 6:18 am Subject: Re: Pietenpol-List: Dan's Prop Hi John, Thank you for the compliment on my prop. Yes, you can get the prop-carving CD from me. Send me $25 to PO Box 454, Belvidere, IL. and it will go out post paid. Also now available at Aircraftspruce.com, but it will cost mor e. Dan Helsper Poplar Grove, IL. -----Original Message----- From: John Fay <jfay1950(at)gmail.com> Sent: Wed, Jul 28, 2010 10:36 pm Subject: Pietenpol-List: Dan's Prop Dan, Is it still possible to get your CD about carving a prop? Your prop looked good in pictures, but seeing it right there in front of my eyes was a truly moving experience. John Fay in Peoria ======================== =========== " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ======================== p://forums.matronics.com ======================== blank>http://www.matronics.com/contribution ======================== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
From: "Dale McCleskey" <dale.mccleskey(at)lifeway.com>
Date: Jul 29, 2010
To the whole door, weight, climb, load discussion. My GN-1 Piet has the door. It weighs 705 empty and with a Sensenich 72X42 prop on my A-65 I was getting 250 fpm climb with a combined 410 lbs of pilot/passenger. About 430 lbs of load is the most I've carried without feeling really marginal. With my current prop though my cruise suffers. Coming back with Randy Bush I was making about 68 at 2250. I normally cruise 65 at about 2100. -------- Dale McCleskey Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306654#306654 ________________________________________________________________________________
Date: Jul 29, 2010
I think the door will always be controversial. I just couldn't make myself cut that upper longeron. My wife has had a spinal fusion and multiple orthopedic problems, and can still get in the front seat with no problem. I did make my cabanes 2 inches taller than the plans, and put a cross brace 2 inches down from the top of my split gear for her to use as a step. We are both 55 now. I put a retractable step to make it easier to get into the rear cockpit, but never use it. I have the long fuselage, used Douglas Fir entirely, with an A-65. Empty weight came in at 692, and I grossed it at 1200. I've flown it twice at full gross and it still has a decent rate of climb. I agree with Jack, that the minor acrobatics required to get in, can help you eliminate inappropriate passengers. I have a maximum passenger limit of 200 pounds with full fuel. How do you eyeball a female potential passenger to determine if she is over that limit? I'm sure not going to ask! Ben Charvet Mims, Fl Home from Brodhead/Osh and headed to the airport for some Pietenpol therapy On 7/28/2010 11:35 AM, Phil wrote: > --> Pietenpol-List message posted by: "Phil" > > I'm still gathering info for my decision. One of the few concerns I have is access to the front cockpit. I see that very few Piets seem to have built some kind of door, or at least a lower coaming for the front cockpit. Are there reasons for this of which I'm sorely ignorant? It seems that either a small door, or even just a lowered side on one side, would ease entry and exit. Does anyone have a door? Does it help or not that much? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306563#306563 > > > ________________________________________________________________________________
Subject: Dan's Prop
Date: Jul 29, 2010
To all considering Dan's CD, or carving their own prop, I saw Dan's prop last year at Brodhead '09 (sorry to have missed seeing his plane this year), bought his CD and carved my prop last December. It took me about 40 hours, but he lays it all out very nicely, even how to figure pitch! Admittedly, I have not run my engine yet, but if this prop fails I would not hesitate to carve another - it was very enjoyable. Mine is hickory and is shaped similar to PF Beck's, for a CS Corvair: Prop mounted 2.jpg Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Thursday, July 29, 2010 4:44 AM Subject: Re: Pietenpol-List: Dan's Prop The full address (with the zip code) is Dan Helsper, PO Box 454, Belvidere, IL. 61008. :O) -----Original Message----- From: helspersew(at)aol.com Sent: Thu, Jul 29, 2010 6:18 am Subject: Re: Pietenpol-List: Dan's Prop Hi John, Thank you for the compliment on my prop. Yes, you can get the prop-carving CD from me. Send me $25 to PO Box 454, Belvidere, IL. and it will go out post paid. Also now available at Aircraftspruce.com, but it will cost more. Dan Helsper Poplar Grove, IL. -----Original Message----- From: John Fay <jfay1950(at)gmail.com> Sent: Wed, Jul 28, 2010 10:36 pm Subject: Pietenpol-List: Dan's Prop Dan, Is it still possible to get your CD about carving a prop? Your prop looked good in pictures, but seeing it right there in front of my eyes was a truly moving experience. John Fay in Peoria =================================== t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List =================================== tp://forums.matronics.com =================================== _blank>http://www.matronics.com/contribution =================================== =================================== t" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List =================================== tp://forums.matronics.com =================================== _blank>http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Subject: contact info for cloud car props?
Date: Jul 29, 2010
Can someone provide contact info for cloud car props and Jay Anderson? Thanks Douwe ________________________________________________________________________________
Subject: Cloudcars just called me, disregard
Date: Jul 29, 2010
Date: Jul 29, 2010
Date: Jul 29, 2010
Hi Ben, My wife has had 3 back surgeryies (sp) along with all the artificial joints and she gets around fine; she walked all over Brodhead with me this year a nd last year. We are both 72 so lost some flexibility in the 22 years diffe rence. I like my door, hopefully my Piet will be at Brodhead next year and you can see how easy it is to get in for us older less flexible types. Jim ----- Original Message ----- From: "Ben Charvet" <bencharvet(at)gmail.com> Sent: Thursday, July 29, 2010 5:04:56 AM Subject: Re: Pietenpol-List: To Door or not to Door I think the door will always be controversial. =C2-I just couldn't make myself cut that upper longeron. =C2-My wife has had a spinal fusion and multiple orthopedic problems, and can still get in the front seat with no problem. =C2-I did make my cabanes 2 inches taller than the plans, and put a cross brace 2 inches down from the top of my split gear for her to use as a step. =C2-We are both 55 now. =C2-I put a retractable step to make it easier to get into the rear cockpit, but never use it. =C2-I have the lon g fuselage, used Douglas Fir entirely, with an A-65. =C2-Empty weight came in at 692, and I grossed it at 1200. =C2-I've flown it twice at full gross a nd it still has a decent rate of climb. =C2-I agree with Jack, that the mino r acrobatics required to get in, can help you eliminate inappropriate passengers. =C2-I have a maximum passenger limit of 200 pounds with full fuel. =C2-How do you eyeball a female potential passenger to determine if she is over that limit? =C2-I'm sure not going to ask! Ben Charvet Mims, Fl Home from Brodhead/Osh and headed to the airport for some Pietenpol therapy On 7/28/2010 11:35 AM, Phil wrote: > --> =C2-Pietenpol-List message posted by: "Phil" > > I'm still gathering info for my decision. =C2-One of the few concerns I have is access to the front cockpit. =C2-I see that very few Piets seem to have built some kind of door, or at least a lower coaming for the front cockpit. =C2-Are there reasons for this of which I'm sorely ignorant? =C2 -It seems that either a small door, or even just a lowered side on one si de, would ease entry and exit. =C2-Does anyone have a door? =C2-Does it help or not that much? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306563#306563 > > > > > > > > > > > > =C2- =C2- =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: This is not the same event it was ten years ago
Date: Jul 29, 2010
I can't speak on how the event was 10 years ago, but I know this year was great... once again, magical. There are a ton of new posts on the board, but I don't have much time to read or write at the moment... I'm volunteering on the Warbird flight line this week at OSH. This place is a whole different kind of amazing. Our first time here and we are really blown away. Thanks for your kind words John, and thanks to all you regulars for allowing us into the fold and making us feel welcome. We are already looking forward to next year. Better get back to it... I'll catch up with you guys next week. -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306697#306697 ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Subject: Re: contact info for cloud car props?
Date: Jul 29, 2010
Douwe, how about catching me up to date on your rebuild? You can contact Jay Anderson at 325-356-2810. Tell him Gene said hi. I was the first to use his prop on a Piet and I can't tell you how good he was to work with. When I was on your case about getting you to get to work on your plane, after it was dinged up, I was called "cruel" by some. If they think I was cruel to you then I guess I'm being REALLY cruel to my self by undergoing some really bad Chemo. Now that's being CRUEL. But then you're going to end up with a great, and safe plane to fly and I'm going to end beating the cancer. Guess there is something to be said about having the balls to be "cruel". Still asking for all the prayers I can get Gene in HOT Tennessee -------------------------------------------------- From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> Sent: Thursday, July 29, 2010 9:07 AM Subject: Pietenpol-List: contact info for cloud car props? > > > Can someone provide contact info for cloud car props and Jay Anderson? > > Thanks > > Douwe > > > ________________________________________________________________________________
Date: Jul 29, 2010
Subject: Re: carb rebuilder?
I was thinking about rebuilding mine , myself. Who was it had experience in the MA3A carb? I figure if there are no internal settings and its just cleaning and parts changing it should be simple. Anyone have a manual and resource for the kits to do that? John In a message dated 7/20/2010 10:56:46 A.M. Eastern Daylight Time, douweblumberg(at)earthlink.net writes: --> Pietenpol-List message posted by: "Douwe Blumberg" Hey, I'm looking for a good shop to rebuild my Marvel carb from the 0200. Any suggestions? Contact info would be appreciated too. Thanks, Douwe ________________________________________________________________________________
Date: Jul 29, 2010
John, Dad and I rebuilt his ma-3sp carb, and there ain't nuttin to it.- H e bought the rebuild kit from Chief Aircraft I believe.- The mannuals are a little pricey but I believe they had more than 1 model included in them. - The only real setting I remember is setting the float height.- A prop per size drill bit is all you need to set it, you are just using it like a feeler gauge, or just use you feeler gauges.- If you have ever rebuilt a marvel schebler tractor carborator it's about the same.- Also there are s ome AD's on them, 1 for the 2 piece venturi, and one for the float.- If y ou have the brass float and it is in good shape your golden.- The a.d. wa s on the phenolic float, which got fuel soaked (absorbant) and sunk, thus f looding the engine, and leaking fuel in the cowling. - - Hope this helps Shad -=0A=0A=0A ________________________________________________________________________________
Subject: Re: 4am Howitzer Shot?
Date: Jul 29, 2010
I think the sky rumbled for 30 seconds after that strike. I was sure the next sound I was going to hear was emergency vehicles arriving at the airport. The headlines the next day would be "Mutiple deaths at Pietenpol fly-in!". All I could think of was if the tent campers were okay. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306758#306758 ________________________________________________________________________________
Subject: New pietenpol admirer! (off topic, kind of)
Date: Jul 29, 2010
So thought that I would share, that we had our little girl on 7/22 at 1839, 7lbs 12ozs, and healthy as can be! And we had our first bonding experience involving a Pietenpol! might look like shes taking a nap, but shes really just enjoying the moment!! (rebuild!) tail feathers removed wing ready for trailing edge Corvair being removed soon. -------- www.vansavition.com follow my Piet rebuild there! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306767#306767 Attachments: http://forums.matronics.com//files/maddybeth_253.jpg ________________________________________________________________________________
Date: Jul 29, 2010
Subject: Re: Riblett 612 or 613.5, and jigs too...
Hey Jim! Sorry I missed this post a few days ago! Contact me off line when you can. I think there might be a couple of holes missing for the rear support (R12a and b) struts. Not hard to drill yourself, but I am not sure if they are missing on yours or not. I've got one rib built, and starting back up again soon. With all the summer distractions, I've gotten behind! Glad to hear from ya! It was great to meet you and your family when you came through. What a great sport this one where we can eventually meet some of the folks we swap ideas with over the forum! Mark On Fri, Jul 23, 2010 at 2:58 PM, flea wrote: > > Hey Mark, that jig is still looking good in my garage. I haven't built one yet but it's fast becoming time. > > Again thanks for the jig it looks great. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=306117#306117 > > -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax ________________________________________________________________________________
Subject: Re: (CS)=?ISO-8859-1?Q?=B2?= t-shirts
Date: Jul 29, 2010
i Will take at least 3! tail feathers removed wing ready for trainling edge corvair ready to be removed metal fittings waiting to be blasted and powder coated -------- www.vansavition.com follow my Piet rebuild there! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306778#306778 ________________________________________________________________________________
Date: Jul 30, 2010
I wasn't there, but I heard that the lightning strike hit Purtee's landing gear attachment... Mike Whaley MerlinFAC(at)cfl.rr.com ________________________________________________________________________________
Date: Jul 30, 2010
That would explain a lot. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306786#306786 ________________________________________________________________________________
Subject: Re: New pietenpol admirer! (off topic, kind of)
Date: Jul 30, 2010
Very much on topic in my opinion. Children are all precious and potential Piet builders and flyers. Keep on a keeping on with the rebuild. Jerry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306787#306787 ________________________________________________________________________________
Subject: need help finding some Brodhead guys
Date: Jul 30, 2010
Trying to figure out the right prop for an 0200 piet is turning out to be a bit tricky. There are only a few around and each one has a different prop and all the "experts" completely disagree. I noticed one of the "Brodhead gang" owns a red Hatz with cream wings which is 0200 powered and I thought his prop experience may prove helpful. However, I don't know his name, but I've seen him there every time I've visited. He pals around with Ted Davis, is about 5'9" with a moustache and was one of the guys behind the Barnstorming movie. Does anyone know who I'm talking about who could help me with a name or a way to find him? OR, does anyone have a number for Ted Davis? He's certainly know. Thanks! Douwe ________________________________________________________________________________
Subject: rebuild progress report for Gene
Date: Jul 30, 2010
Hey Gene, I just said a prayer for you! Sorry you have to go through this, I know how tough it is having watched a bunch of friends do it recently. Sounds like you know the Lord and are keeping an optimistic attitude, keep it up!! He's got a plan!!! Don Emch has the wings and is pretty much ready to start covering, so they should be done within a few months Greg Cardinal rebuilt the tail surfaces and I just got those at Brodhead (wouldn't charge me, just told me to "pay it forward") Fixed some surprisingly minor damage to the fuselage, which is stripped and installed an 0200. Just finished the mounts and firewall a couple of days ago. Making new wheels (my fourth set!.... don't ask...) Will have a completely new "look" and color scheme as the new engine just doesn't seem to work with that old 20/30's look I was going for with the old one. I agree with Jack when he says rebuilding his was one of the hardest things he's done. It definitely is a slogging match now, and much of the fun has been taken out of it. Brodhead helped a lot, and coming up with a new look has interjected some novelty back into the project. Other than that it is a daily fight to get my but out there and move it forward. However, I am determined to get her done, hopefully by end of winter, unless this 0200 throws me some curves and turns out not to be as represented. Stay tough bro!! Douwe ________________________________________________________________________________
Date: Jul 30, 2010
Subject: Re: need help finding some Brodhead guys
Hi Douwe, Shorter gentleman (although not quite properly sized) with a moustache that hangs with Ted and was involved in Barnstorming sounds like Jim Hammond. He has a Hatz as well, so that's probably who you are thinking of. I'll forward you his contact info I have from the MAAC directory offlist. If for some reason that is not who you are thinking of I'll include Ted's information so you could reach out to him. I'm also going to include Tim Mickel's info, as he has the red O-200 powered Piet that was at Brodhead. Good luck! Ryan On Fri, Jul 30, 2010 at 6:33 AM, Douwe Blumberg wrote: > douweblumberg(at)earthlink.net> > > Trying to figure out the right prop for an 0200 piet is turning out to be a > bit tricky. There are only a few around and each one has a different prop > and all the "experts" completely disagree. > > I noticed one of the "Brodhead gang" owns a red Hatz with cream wings which > is 0200 powered and I thought his prop experience may prove helpful. > However, I don't know his name, but I've seen him there every time I've > visited. > > He pals around with Ted Davis, is about 5'9" with a moustache and was one > of > the guys behind the Barnstorming movie. > > Does anyone know who I'm talking about who could help me with a name or a > way to find him? OR, does anyone have a number for Ted Davis? He's > certainly know. > > Thanks! > > Douwe > > ________________________________________________________________________________
Date: Jul 30, 2010
Subject: Re: rebuild progress report for Gene
> >I agree with Jack when he says rebuilding his was one of the hardest things >he's done. It definitely is a slogging match now, and much of the fun has >been taken out of it. Brodhead helped a lot, and coming up with a new look >has interjected some novelty back into the project. Other than that it is a >daily fight to get my but out there and move it forward. [Jim] Well I sure know THAT feeling! Think of it this way...this isn't YOU doing something on your own...it's you being a part of a community of VERY special people involved with something special. I know you realize this, but I also know that feeling of working on something "alone, all by yourself" and then realizing this ain't just you... I suppose all this is obvious when you see how these people step up but I just can't keep quiet about it....something special (on MANY levels!) is going on with this Pietenpol crowd...what an honor to get to be a part of it. Blessed in Pryor....jm However, I am >determined to get her done, hopefully by end of winter, unless this 0200 >throws me some curves and turns out not to be as represented. > >Stay tough bro!! > >Douwe > > ________________________________________________________________________________
Date: Jul 30, 2010
Douwe, Sensenich has a list of props for different engines on their web site: http://www.sensenich.com/products/browse/14 Univair publishes an incredibly low resolution (read as: piss-poor) pdf parts manual which lists many aircraft/engine/prop combinations. http://univairparts.com/pdfs/propeller.pdf If all that fails, you could just call Sensenich or McCauley sales and ask them what prop dia and pitch they recommend. Cheers, Dan On 07/30/2010 06:57 AM, Douwe Blumberg wrote: > --> Pietenpol-List message posted by: "Douwe Blumberg" > > Hey Gene, > > I just said a prayer for you! Sorry you have to go through this, I know how > tough it is having watched a bunch of friends do it recently. Sounds like > you know the Lord and are keeping an optimistic attitude, keep it up!! He's > got a plan!!! > > Don Emch has the wings and is pretty much ready to start covering, so they > should be done within a few months > > Greg Cardinal rebuilt the tail surfaces and I just got those at Brodhead > (wouldn't charge me, just told me to "pay it forward") > > Fixed some surprisingly minor damage to the fuselage, which is stripped and > installed an 0200. Just finished the mounts and firewall a couple of days > ago. > > Making new wheels (my fourth set!.... don't ask...) > > Will have a completely new "look" and color scheme as the new engine just > doesn't seem to work with that old 20/30's look I was going for with the old > one. > > I agree with Jack when he says rebuilding his was one of the hardest things > he's done. It definitely is a slogging match now, and much of the fun has > been taken out of it. Brodhead helped a lot, and coming up with a new look > has interjected some novelty back into the project. Other than that it is a > daily fight to get my but out there and move it forward. However, I am > determined to get her done, hopefully by end of winter, unless this 0200 > throws me some curves and turns out not to be as represented. > > Stay tough bro!! > > Douwe > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jul 30, 2010
That may be Jim Hammon. I can ask around and see if I can get a phone number for him. Darrel Jones Pfeifer Sport On 7/30/2010 4:33 AM, Douwe Blumberg wrote: > --> Pietenpol-List message posted by: "Douwe Blumberg" > > Trying to figure out the right prop for an 0200 piet is turning out to be a > bit tricky. There are only a few around and each one has a different prop > and all the "experts" completely disagree. > > I noticed one of the "Brodhead gang" owns a red Hatz with cream wings which > is 0200 powered and I thought his prop experience may prove helpful. > However, I don't know his name, but I've seen him there every time I've > visited. > > He pals around with Ted Davis, is about 5'9" with a moustache and was one of > the guys behind the Barnstorming movie. > > Does anyone know who I'm talking about who could help me with a name or a > way to find him? OR, does anyone have a number for Ted Davis? He's > certainly know. > > Thanks! > > Douwe > > > ________________________________________________________________________________
Date: Jul 30, 2010
What sounded like her crying was really just her quoting relevant advice from this list, in baby-speak. Congratulations! Mike Whaley MerlinFAC(at)cfl.rr.com ----- Original Message ----- From: "VanDy" <matthew.vandervort(at)gmail.com> Sent: Thursday, July 29, 2010 10:38 PM Subject: [piet] Pietenpol-List: New pietenpol admirer! (off topic, kind of) > > So thought that I would share, that we had our little girl on 7/22 at 1839, 7lbs 12ozs, and healthy as can be! And we had our first bonding experience involving a Pietenpol! might look like shes taking a nap, but shes really just enjoying the moment!! > > ________________________________________________________________________________
Subject: Re: To Door or not to Door
Date: Jul 30, 2010
My door design ......... -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306827#306827 Attachments: http://forums.matronics.com//files/nov18_02_197.jpg ________________________________________________________________________________
Subject: battery
Date: Jul 29, 2010
Hey, What is the lightest battery I can use to start my 0200. I won't be running anything except maybe a smoke pump and a couple of cigarette sockets for gps etc. Just need it for starting. Thoughts? Douwe ________________________________________________________________________________
Date: Jul 30, 2010
Subject: Re: battery
We've had very good luck with this one: http://www.odysseybatteries.com/battery/pc625.htm We use it on a C-85 w/o charging system. We run a gps, electronic tach, and starter. We charge with a 5W 12x12 solar panel. >Hey, > >What is the lightest battery I can use to start my 0200. I won't be >running anything except maybe a smoke pump and a couple of cigarette >sockets for gps etc. > >Just need it for starting. > >Thoughts? > >Douwe -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Jul 30, 2010
I believe the WW 'Vair guys commonly use the PC680 from Odyssey: http://www.odysseybatteries.com/battery/pc680series.htm <http://www.odysseybatteries.com/battery/pc680series.htm>A little taller and wider, but a bit thinner for FW mounting if so desired. A bit more powerful than the 625. Either way, the Odyssey batteries seem to be favorites in the Corvair camp. Ryan On Fri, Jul 30, 2010 at 1:38 PM, Jeff Boatright wrote: > We've had very good luck with this one: > > http://www.odysseybatteries.com/battery/pc625.htm > > We use it on a C-85 w/o charging system. We run a gps, electronic tach, and > starter. We charge with a 5W 12x12 solar panel. > > > Hey, > > > What is the lightest battery I can use to start my 0200. I won't be > running anything except maybe a smoke pump and a couple of cigarette sockets > for gps etc. > > > Just need it for starting. > > > Thoughts? > > > Douwe > > > * > * > > -- > > > Jeff Boatright > "Now let's think about this..." > > * > > * > > ________________________________________________________________________________
Date: Jul 30, 2010
But mine goes to 11! >:-} >I believe the WW 'Vair guys commonly use the PC680 from Odyssey: > ><http://www.odysseybatteries.com/battery/pc680series.htm>http://www.odysseybatteries.com/battery/pc680series.htm > ><http://www.odysseybatteries.com/battery/pc680series.htm>A little >taller and wider, but a bit thinner for FW mounting if so desired. A >bit more powerful than the 625. > >Either way, the Odyssey batteries seem to be favorites in the Corvair camp. > >Ryan > >On Fri, Jul 30, 2010 at 1:38 PM, Jeff Boatright ><jboatri(at)emory.edu> wrote: > >We've had very good luck with this one: > ><http://www.odysseybatteries.com/battery/pc625.htm>http://www.odysseybatteries.com/battery/pc625.htm > >We use it on a C-85 w/o charging system. We run a gps, electronic >tach, and starter. We charge with a 5W 12x12 solar panel. > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Jul 30, 2010
jEFF, i like my odyssey 680 for my corvair. Do you leave your plane out in the sun for solar panel charging? I have a solar panel that I used on my boat years ago and It worked fine in the sun. Gardiner ________________________________ From: Jeff Boatright <jboatri(at)emory.edu> Sent: Fri, July 30, 2010 2:55:41 PM Subject: Re: Pietenpol-List: battery Re: Pietenpol-List: battery But mine goes to 11! >:-} I believe the WW 'Vair guys commonly use the PC680 from Odyssey: > http://www.odysseybatteries.com/battery/pc680series.htm > A little taller and wider, but a bit thinner for FW mounting if so desired. A bit more powerful than the 625. > Either way, the Odyssey batteries seem to be favorites in the Corvair camp. > Ryan > On Fri, Jul 30, 2010 at 1:38 PM, Jeff Boatright wrote: > >We've had very good luck with this one: > http://www.odysseybatteries.com/battery/pc625.htm > We use it on a C-85 w/o charging system. We run a gps, electronic tach, and starter. We charge with a 5W 12x12 solar panel. > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Jul 30, 2010
I don't know if you have an old starter like the ancient Delco I had on my old Lycoming in the Tri-pacer but the large aircraft battery barely turned it over. now I have a gear reduction type Japanese starter rigged on the Corvair engine and a little 20 Amp gel cell sealed battery ( which is several years old) turns it over fine.I know that doesn't answer you question except for the fact that there are geared starters out there to replace the old heavy aircraft starters that definitely take a lot less juice.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=306880#306880 ________________________________________________________________________________
Date: Jul 31, 2010
Subject: Trying to come up with a color scheme
List: Is there an internet source available for the Piet where you can take an outline of the plane and fill in the colors to see what the plane would look like with various color schemes? John Fay in Peoria ________________________________________________________________________________
Date: Jul 31, 2010
Subject: project progress update
I don't post very often, as I like to sit back and just soak up the information from everyone else, but I told Gary Boothe I'd send him a pic or two updating the progress on my cowl and I figured I'd let everyone else see too. All of the firewall forward stuff really eats a lot of time and seems like it doesn't show. Friends drop by hearing that we have been working on the plane and I'm sure they can't see any progress. We do although, have the engine just about ready to run, as soon as I get the carb rebuilt and the air filter mounted. The cowl is getting closer, but there is still a bunch to do there as well. My dad (Vic) and I are still plugging away at it out here in California, and may actually finish it one of these days! Anyways, I'm gonna go grab my wife and daughter and go enjoy the morning air flying the Piper. Keep building! Mike Groah Tulare CA ________________________________________________________________________________
Date: Jul 31, 2010
John, This is REALLY low tech, but you can save this jpg, then right click and choose open with "Paint." You should have that program with most Microsoft operating systems. That'll keep you busy for the rest of the day.. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Fay Sent: Saturday, July 31, 2010 5:53 AM Subject: Pietenpol-List: Trying to come up with a color scheme List: Is there an internet source available for the Piet where you can take an outline of the plane and fill in the colors to see what the plane would look like with various color schemes? John Fay in Peoria ________________________________________________________________________________
Date: Jul 31, 2010
Subject: Re: project progress update
Wow...looking good Mike. With all due respect to other Corvair Piet builders, that is quite possibly the most attractive Corvair cowling on a Piet that I've seen yet. I take it you are either setup with a rear starter or hand prop...? Ryan On Sat, Jul 31, 2010 at 9:28 AM, Michael Groah wrote: > I don't post very often, as I like to sit back and just soak up the information from everyone else, > but I told Gary Boothe I'd send him a pic or two updating the progress on my cowl and I figured > I'd let everyone else see too. All of the firewall forward stuff really eats a lot of time and seems like > it doesn't show. Friends drop by hearing that we have been working on the plane and I'm sure they > can't see any progress. We do although, have the engine just about ready to run, as soon as I get the > carb rebuilt and the air filter mounted. The > cowl is getting closer, but there is still a bunch to do there > as well. My dad (Vic) and I are still plugging away at it out here in California, and may actually finish > it one of these days! Anyways, I'm gonna go grab my wife and daughter and go enjoy the morning air > flying the Piper. Keep building! > > Mike Groah > Tulare CA > > ________________________________________________________________________________
Date: Jul 31, 2010
Try this http://westcoastpiet.com/paint_piet_bmp_files.htm Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Fay Sent: Saturday, July 31, 2010 5:53 AM Subject: Pietenpol-List: Trying to come up with a color scheme List: Is there an internet source available for the Piet where you can take an outline of the plane and fill in the colors to see what the plane would look like with various color schemes? John Fay in Peoria ________________________________________________________________________________
Date: Jul 31, 2010
Very nice, Mike. For whatever reason, it seems to be difficult to make a nice looking cowl on a Corvair, but you've managed to do it. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Groah Sent: Saturday, July 31, 2010 10:29 AM Subject: Pietenpol-List: project progress update I don't post very often, as I like to sit back and just soak up the information from everyone else, but I told Gary Boothe I'd send him a pic or two updating the progress on my cowl and I figured I'd let everyone else see too. All of the firewall forward stuff really eats a lot of time and seems like it doesn't show. Friends drop by hearing that we have been working on the plane and I'm sure they can't see any progress. We do although, have the engine just about ready to run, as soon as I get the carb rebuilt and the air filter mounted. The cowl is getting closer, but there is still a bunch to do there as well. My dad (Vic) and I are still plugging away at it out here in California, and may actually finish it one of these days! Anyways, I'm gonna go grab my wife and daughter and go enjoy the morning air flying the Piper. Keep building! Mike Groah Tulare CA ________________________________________________________________________________
Date: Jul 31, 2010
Hi Mike, Your cowling is looking good. Making it out of aluminium has got to be a real challenge; you and your dad Vic are doing a nice job of it. Now if you just had a 200 ton hydropress for the small stuff. We had one at the Boeing plant I worked at and boy would that have made cowling and steel fitting easy. Thats what my nightmares are made of. Cheers, Jim ----- Original Message ----- From: "Michael Groah" <dskogrover(at)yahoo.com> Sent: Saturday, July 31, 2010 7:28:32 AM Subject: Pietenpol-List: project progress update I don't post very often, as I like to sit back and just soak up the information from everyone else, but I told Gary Boothe I'd send him a pic or two updating the progress on my cowl and I figured I'd let everyone else see too. All of the firewall forward stuff really eats a lot of time and seems like it doesn't show. Friends drop by hearing that we have been working on the plane and I'm sure they can't see any progress. We do although, have the engine just about ready to run, as soon as I get the carb rebuilt and the air filter mounted. The cowl is getting closer, but there is still a bunch to do there as well. My dad (Vic) and I are still plugging away at it out here in California, and may actually finish it one of these days! Anyways, I'm gonna go grab my wife and daughter and go enjoy the morning air flying the Piper. Keep building! Mike Groah Tulare CA ________________________________________________________________________________
Date: Jul 31, 2010
Subject: Re: Trying to come up with a color scheme
It may be low tech Gary; but thanks for doing it. This will be fun to play with. Jim ----- Original Message ----- From: "Gary Boothe" <gboothe5(at)comcast.net> Sent: Saturday, July 31, 2010 7:34:35 AM Subject: RE: Pietenpol-List: Trying to come up with a color scheme John, This is REALLY low tech, but you can save this jpg, then right click and ch oose open with =9CPaint.=9D You should have that program with m ost Microsoft operating systems. That=99ll keep you busy for the rest of the day. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of John Fay Sent: Saturday, July 31, 2010 5:53 AM Subject: Pietenpol-List: Trying to come up with a color scheme List: Is there an internet source available for the Piet where you can take an ou tline of the plane and fill in the colors to see what the plane would look like with various color schemes? John Fay in Peoria =C2- =C2- http://www.matronics.com/Navigator?Pietenpol-List h ttp://forums.matronics.com http://www.matronics.com/contribution =C2- ________________________________________________________________________________
Date: Jul 31, 2010
Chris you must do these things in your spare time right? This Piet web site is amazing; just ask and it usually turns right up. Especially at West Coast Piet. Cheers, Jim ----- Original Message ----- From: "Chris" <catdesigns(at)att.net> Sent: Saturday, July 31, 2010 7:58:33 AM Subject: RE: Pietenpol-List: Trying to come up with a color scheme Try this http://westcoastpiet.com/paint_piet_bmp_files.htm Chris Sacramento, Ca Westcoastpiet.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Fay Sent: Saturday, July 31, 2010 5:53 AM Subject: Pietenpol-List: Trying to come up with a color scheme List: Is there an internet source available for the Piet where you can take an outline of the plane and fill in the colors to see what the plane would look like with various color schemes? John Fay in Peoria ________________________________________________________________________________
Date: Jul 31, 2010
Here's the one I use. Should work fine in Paint or pretty much any program. Simple but it seems to give a good idea of things. when I'm bored or get an idea I'll spend a few minutes to make up a new color scheme, must have a hundred ideas by now. I think the original came from DJ Vegh way back when. -Mike Mike Whaley MerlinFAC(at)cfl.rr.com ----- Original Message ----- From: "John Fay" <jfay1950(at)gmail.com> Sent: Saturday, July 31, 2010 8:53 AM Subject: [piet] Pietenpol-List: Trying to come up with a color scheme > List: > > Is there an internet source available for the Piet where you can take an > outline of the plane and fill in the colors to see what the plane would look > like with various color schemes? > > John Fay > in Peoria > ________________________________________________________________________________
Date: Jul 31, 2010
Just a note=2C the starter is in the front in the normal Corviar position. Unfortunatly no press=2C just hand formed. VG Date: Sat=2C 31 Jul 2010 16:03:42 +0000 From: boyerjrb(at)comcast.net Subject: Re: Pietenpol-List: project progress update Hi Mike=2C Your cowling is looking good. Making it out of aluminium has got to be a re al challenge=3B you and your dad Vic are doing a nice job of it. Now if you just had a 200 ton hydropress for the small stuff. We had one at the Boeing plant I worked at and boy would that have made cowling and stee l fitting easy. Thats what my nightmares are made of. Cheers=2C Jim ----- Original Message ----- From: "Michael Groah" <dskogrover(at)yahoo.com> Sent: Saturday=2C July 31=2C 2010 7:28:32 AM Subject: Pietenpol-List: project progress update I don't post very often=2C as I like to sit back and just soak up the info rmation from everyone else=2C but I told Gary Boothe I'd send him a pic or two updating the progress on m y cowl and I figured I'd let everyone else see too. All of the firewall forward stuff really ea ts a lot of time and seems like it doesn't show. Friends drop by hearing that we have been working on the plane and I'm sure they can't see any progress. We do although=2C have the engine just about ready to run=2C as soon as I get the carb rebuilt and the air filter mounted. The cowl is getting closer=2C but there is still a bunch to do there as well. My dad (Vic) and I are still plugging away at it out here in Cali fornia=2C and may actually finish it one of these days! Anyways=2C I'm gonna go grab my wife and daughter an d go enjoy the morning air flying the Piper. Keep building! Mike Groah Tulare CA ________________________________________________________________________________
Date: Jul 31, 2010
Wow, that is surprising. It sure doesn't look like there is room for the ring gear in there. Any other pics would be greatly appreciated. Are you driving the dynamo/alternator off the rear? Thanks Vic, Ryan On Sat, Jul 31, 2010 at 4:07 PM, V Groah wrote: > Just a note, the starter is in the front in the normal Corviar position. > Unfortunatly no press, just hand formed. VG > > ------------------------------ > Date: Sat, 31 Jul 2010 16:03:42 +0000 > From: boyerjrb(at)comcast.net > > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: project progress update > > > Hi Mike, > Your cowling is looking good. Making it out of aluminium has got to be a > real challenge; you and your dad Vic are doing a nice job of it. > Now if you just had a 200 ton hydropress for the small stuff. We had one at > the Boeing plant I worked at and boy would that have made cowling and steel > fitting easy. Thats what my nightmares are made of. > Cheers, > Jim > > > ----- Original Message ----- > From: "Michael Groah" <dskogrover(at)yahoo.com> > To: pietenpol-list(at)matronics.com > Sent: Saturday, July 31, 2010 7:28:32 AM > Subject: Pietenpol-List: project progress update > > > I don't post very often, as I like to sit back and just soak up the information from everyone else, > but I told Gary Boothe I'd send him a pic or two updating the progress on my cowl and I figured > I'd let everyone else see too. All of the firewall forward stuff really eats a lot of time and seems like > it doesn't show. Friends drop by hearing that we have been working on the plane and I'm sure they > can't see any progress. We do although, have the engine just about ready to run, as soon as I get the > carb rebuilt and the air filter mounted. The > cowl is getting closer, but there is still a bunch to do there > as well. My dad (Vic) and I are still plugging away at it out here in California, and may actually finish > it one of these days! Anyways, I'm gonna go grab my wife and daughter and go enjoy the morning air > flying the Piper. Keep building! > > Mike Groah > Tulare CA > > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Jul 31, 2010
Thanks all for the info. I'm going to try them this evening. John Fay On Sat, Jul 31, 2010 at 7:53 AM, John Fay wrote: > List: > > Is there an internet source available for the Piet where you can take an > outline of the plane and fill in the colors to see what the plane would look > like with various color schemes? > > John Fay > in Peoria > > ** > >
July 20, 2010 - July 31, 2010
Pietenpol-Archive.digest.vol-jk
