Pietenpol-Archive.digest.vol-jn
August 18, 2010 - August 29, 2010
      fuel
      tank, avionics, lights, engine, etc.
      Jack
      DSM
Date: Aug 18, 2010
Subject: Re: Grounding Aircraft
Morning Jack, At the very least, the gas filler neck should be grounded to the engine. Since your tank is metal, you can attach a lead anywhere to the tank, say, the mounting strap. I can't contribute to advice on what else to ground with regard to electronics. Dan On 08/18/2010 06:32 AM, Jack wrote: > Would like to hear thoughts on grounding the various parts on a Piet, > fuel tank, avionics, lights, engine, etc. > > Thanks, > > Jack > > DSM > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: Got an engine!
Date: Aug 18, 2010
Attached is an image I took last night of a spark plug hole in my corvair engine. It is oversized by 1/16 of an inch from the others. Can you tell by the threads if a helicoil was once inserted in here and can I use a time sert in this hole? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309257#309257 Attachments: http://forums.matronics.com//files/spark_plug_hole_180.jpg ________________________________________________________________________________
Date: Aug 18, 2010
You may want to direct those questions to Corvair List. Several knowledgable contributors there. Gary Boothe ------Original Message------ From: Kringle Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Got an engine! Sent: Aug 18, 2010 7:17 AM Attached is an image I took last night of a spark plug hole in my corvair engine. It is oversized by 1/16 of an inch from the others. Can you tell by the threads if a helicoil was once inserted in here and can I use a time sert in this hole? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309257#309257 Attachments: http://forums.matronics.com//files/spark_plug_hole_180.jpg Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Aug 18, 2010
It appears that list is dead. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309260#309260 ________________________________________________________________________________
Date: Aug 18, 2010
Not true. I get emails everyday. Sorry, but don't have the link on my B-berry. But I know I can count on Ryan Mueller, or someone else, to jump in here... Gary ------Original Message------ From: Kringle Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Got an engine! Sent: Aug 18, 2010 7:33 AM It appears that list is dead. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309260#309260 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Aug 18, 2010
John, Sure you have the correct one? Try http://www.krnet.org/corvaircraft_inst.html or http://mylist.net/listinfo/corvaircraft Cheers Peter -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Wednesday, 18 August 2010 10:33 PM Subject: Pietenpol-List: Re: Got an engine! It appears that list is dead. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309260#309260 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: remote mounting 0200 air box
Date: Aug 18, 2010
Hey guys, As I'm building my new cowling, I'm finding the air intake really messing up the bottom "lines". I got to thinking, "why can't I just relocate it and mount it remotely"?. As long as the scat tubing from the box to the carb isn't too long to cool the heated air when I use the carb heat, I can't see any downside. Thoughts? Douwe ________________________________________________________________________________
Date: Aug 18, 2010
Bernie never mentioned anything about grounding, It is an excellent idea we elders never considered. Pieti Lowell PS. Never had a fire since 1941, Just Lucky Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309264#309264 ________________________________________________________________________________
Date: Aug 18, 2010
I tried the Matronics Corvair Engine List -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309265#309265 ________________________________________________________________________________
Date: Aug 18, 2010
As Gary and Peter mentioned, Mark Langford's CorvAircraft mailing list is the best active source for Corvair discussion out there. As provided by Peter, the link for information on the list is at: http://www.krnet.org/corvaircraft_inst.html Sign up is at: http://mylist.net/listinfo/corvaircraft <http://mylist.net/listinfo/corvaircraft>The CorvAircraft does not have a web-based forum you can use to access it like the Pietenpol emailing list does; it is strictly an email list. You can either receive all the messages in real time, or you can receive one "lump sum" digest at the end of the day. Personally, I prefer to receive the messages in real-time. I setup a folder for CorvAircraft messages in Gmail, and then a simple filter to redirect the incoming messages from the list to that folder; same with the Piet list. As I mentioned, Mark Langford runs the list. If you haven't seen his site, I would suggest giving it a look. Nothing about Pietenpols, but lots of information about the Corvair: http://fly.hiwaay.net/~langford/index.html <http://fly.hiwaay.net/~langford/index.html>The CorvAircraft list is also the only list that William Wynne spends any amount of time on. He doesn't post that frequently right now, but over the years he has made many an educational post on the list. The list is rather quiet right now for whatever reason, but it is still active. Like the Piet list, the CorvAircraft list has been around for a good number of years, and a tremendous amount of information has already been discussed ad-nauseum. I would highly recommend spending some quality time searching the CorvAircraft archives at: http://www.maddyhome.com/corvairsrch/frame/index.jsp You can generally count posts by the following individuals as reliable information: William Wynne, Mark Langford, Roy Szarafinski, or Dan Weseman to name a few. They have established themselves as knowledgable individuals in the Corvair community. There are plenty of other list members that also provide good information (many from the Piet list: Gary, Oscar, Peter)....just trying to give a starting point if you don't know who anyone is. Hope that helps, Ryan On Wed, Aug 18, 2010 at 7:49 AM, Kringle wrote: > > I tried the Matronics Corvair Engine List > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309265#309265 > > ________________________________________________________________________________
Date: Aug 18, 2010
Douwe, You can just let some of the airbox sit outside the cowling. It doesn't seem to mess up the lines too much. It looks terrible when the cowling is unpainted, but tends to disappear once the plane is finished. Look at what mine looked like before and after paint: Perhaps it helps to paint the cowling a dark color, but I find the airbox hanging down just doesn't draw the eye to it. If you look closely, you can see that the base of the carburetor (where the airbox attaches) is below the line of the cowling, so even if you moved the airbox, you would still have the SCAT hose showing there, and in the picture above, the SCAT hose is much more distracting to the eye than the whole airbox. Of course, mine is an A65 and I believe you are using an O-200, but I don't think they are much different in this regard. I think adding a length of SCAT hose between the air filter and the carburetor would add an unnecessary restriction to the engine airflow, and reduce power. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Wednesday, August 18, 2010 8:45 AM Subject: Pietenpol-List: remote mounting 0200 air box Hey guys, As I'm building my new cowling, I'm finding the air intake really messing up the bottom "lines". I got to thinking, "why can't I just relocate it and mount it remotely"?. As long as the scat tubing from the box to the carb isn't too long to cool the heated air when I use the carb heat, I can't see any downside. Thoughts? Douwe ________________________________________________________________________________
Date: Aug 18, 2010
Here's your link: corvaircraft-join(at)mylist.net. That should get you started. It's a fairly active list! Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Wednesday, August 18, 2010 5:49 AM Subject: Pietenpol-List: Re: Got an engine! I tried the Matronics Corvair Engine List -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309265#309265 ________________________________________________________________________________
Date: Aug 18, 2010
Subject: Carb heat from Continental Cylinder heads?
Has anyone done this and what were your results? My engine is an A-75. I know DC-65/L2 Taylorcrafts take carb heat from the heads instead of the exhaust, and probably a lot of other planes do the same. I made new exhaust for my plane, and would prefer not to put the carb heat on the shiny new pipes if possible. Taking the carb heat off the back of the eyebrows seems like it would be a much cleaner installation, assuming I can get the appropriate RPM drop by applying carb heat. Is there anything else to consider? Steve Ruse Norman, OK ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: Nice Ohio flying weather
Date: Aug 18, 2010
Please knock off the political comments. When those of us with more liberal leanings have been so rash as to expressed our opinions we've been flamed, ridiculed, sent threatening messages off list, etc. I'm tired of it & it violates the basic operating agreements of this list. Thank you, Kip On Aug 17, 2010, at 10:43 PM, Dennis Vetter wrote: > > > Don't blame me. I voted for the old guy and the hot chic. > [Wink] Rant and rave all you want, while you still can! Just > think of the carbon foot print of this administration. You will not > hear about that in the media. I'm new to this site. But not in the > pietenpol world. Back to the weather, what a change from a week > ago. Hope we get some good flying weather from here on out. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309221#309221 > > ________________________________________________________________________________
Date: Aug 18, 2010
Subject: Re: Carb heat from Continental Cylinder heads?
The T-carts that have that carb heat setup....are those on aircraft with pressure cowlings, or just eyebrows over the cylinders? I would be curious to see how much warmer the air would be if you took the air from the eyebrows, as I would think that would be mainly cool "ram air" coming in from the front of the eyebrows. If you could take the air from below the cylinders (after it has passed through the fins) that would certainly be warmer, but that would be a tricker bit of baffling to accomplish, and it's quite possible that would have an affect on the cooling air flow through the cylinders.... Do you have any pictures of the Taylorcraft setup refer to? Ryan On Wed, Aug 18, 2010 at 8:27 AM, Steve Ruse wrote: > > > > Has anyone done this and what were your results? My engine is an A-75. I > know DC-65/L2 Taylorcrafts take carb heat from the heads instead of the > exhaust, and probably a lot of other planes do the same. I made new exhaust > for my plane, and would prefer not to put the carb heat on the shiny new > pipes if possible. Taking the carb heat off the back of the eyebrows seems > like it would be a much cleaner installation, assuming I can get the > appropriate RPM drop by applying carb heat. Is there anything else to > consider? > > Steve Ruse > Norman, OK > > ________________________________________________________________________________
Date: Aug 18, 2010
Totally agree. -------- Al Rice Skybolt 260 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309280#309280 ________________________________________________________________________________
Date: Aug 18, 2010
John, if you can get the dimensions of that hole (diameter to the bot of th e threads)- you might be able to look up the size of available time sert bushings on their web site.- it's already broke, so I don't think you can do any damage trying.- If worse comes to worse it is still going to need to be welded shut and re drilled.- I would NOT use another helicoil for that repair.- We had one that was repaired prior to Dad getting the engin e, it apparently was incorect, and long story short detonate, loose power, crankshaft broke, butt tightens up, and airplane gets a trailer ride home. - If I can help, or provide any useful info I will try.- I did all the time serts on dads engine (on 1 side)-last year (due to a stripped out sp arkplug hole).- And one last thing, install the timeserts with the heads off (maby this is obvious, but none the less) - Shad=0A=0A=0A ________________________________________________________________________________
Date: Aug 18, 2010
Subject: Re: Wood kits
Mark, - For what it's worth.....KUDO'S!! I say this is an excellent idea and suppor t your efforts. The fittings kit would be fantastic right along with the re st of your ideas!. For the purest, you can-build the entire plane to your liking. For people like myself who love to fly, I could use specific parts and pieces to advance the build time. I would rather fly and buy some thin gs to speed up build process! - As you may know, I make the cowlings for the corvair piet using-a pattern from the-orginal Pietenpol (thank you "Fireman Dan" in Mpls). I cover my expenses and sell them to the group with a very small margin of profit. Th is is a hobby to me and not a business... so I see no real income from this (production runs vary widely). That's not to say for you this could not be a business, just explaining my position on my costs: makes it more feasabl e for others who just want a great bank for the buck and give back to the m embers. - So, you have my vote for continuing with your ideas! Please keep the list i nformed. Have plently of photos to share of final products so we can see wh at we are purchasing. The members of this-list can provide input for impr oved changes to some of these parts and pieces; please utilize them as they have "been their and done that!" - Again..... Kudo's! I want to build and enjoy the journey... but not over th ree years! - KM Heide Hawley, MN - --- On Wed, 8/18/10, Mark Roberts wrote: From: Mark Roberts <mark.rbrts1(at)gmail.com> Subject: Re: Pietenpol-List: Re: Wood kits Date: Wednesday, August 18, 2010, 12:10 AM Hey Guys,-Regarding wood kits: My business partner and I took a business trip last week to LA for a confer ence (thus the lack of posts), and on the way down we began assembling pric es and material lists for some wood kits that we mentioned last week or so ago on the list. We have both a CNC router (5' x 10' MultiCam CNC router an d a 4' x 8' laser table), and have some spruce on hand that is spar grade s tuff, but after the response we got, we began thinking that we would offer some sub-assembly kits. These would offer the spruce parts as well as the p ly parts cut to shape using the CNC stuff. Planning all of this was the bulk of our discussion in the car (both direct ions) on the 4 hour trip. We have some of the kit info together, and I have been working to find some of the carriers that can ship reasonably all ove r the country. I haven't posted all this yet as I was wanting to have all t he info for the-number-of requests we've had. I just checked ACS and saw that they now have sub kits available, which was what we were thinking of offering. I can't remember if I posted this earli er when I mentioned that we'd be offering kits, but I think it's great that those options are available! It makes it better for ALL of us to have opti ons, and the ability to choose. We got a new web address for all of this (www.PietenParts.com -or www.Pie tParts.com), and I can tell you that our kits and sub kits will be CNC cut Plywood parts and will have all of the materials listed so you can see what you are getting. I noticed this was missing when I went to the ACS site... But, nice to see the sub kits which is what I was planning to offer origin ally. By the way, we are going to offer our kits with CNC machined rib jigs for t he Original FC-10 airfoil, the Riblett GA-30-612 and the Riblett GA-30-613. 5 airfoils.- One additional item that I am very-excited-about offering is a rib stic k cutting jig that will cut the internal rib sticks for each rib easily and -accurately! It can reduce the amount of time it takes to cut the sticks down to a short afternoon, and they'll snap in place! So far I have the one for the Riblett 613.5 finished, and I still need to finish the FC-10 jig, and the FC-10 and Riblett 612 cutting jig. I cut the parts for the internal rib sticks very accuratly, and importantly, quickly. We hope to have the website up and running before long: www.PietenParts.com -or www.PietParts.com will eventually get you to the same place! By the way, we are pricing the Wing Rib kits, with the Bending Jig, The Sti ck Cutting Jig, and the actual Rib Jig for much less than what I saw on ACS . We are including a 'No Spar' option where you can just buy rib stuff with out spars to see if you even want to go further into the project before co mmitting serious money. Some people may tire after ribs :o\ More soon. Mark On Wed, Aug 11, 2010 at 5:55 PM, Gary Boothe wrote: Whew!!! Just contact Mark Roberts, mark.rbrts1(at)gmail.com. I know he doesn't have kit prices yet, but he has wood... Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of K5YAC Sent: Wednesday, August 11, 2010 5:46 PM Subject: Pietenpol-List: Re: Wood kits Well that is confusing as hell. -You guys normally posted a wood package for the Pietenpol Air Camper... now you only list four "kits" for the different sections of the Pietenpol Air Camper, and none of them are linked to a bill of materials that can be accessed and studied in order to confirm what the customer is actually ordering. -For example, what is included in that $93 1 "wing kit" that is now listed? -Does that include capstrip for wing ribs? If so, what are guys suposed to do that have already built or acquired ribs ? Search for individual items to complete the wings? -Whew! -Not the end of the world, but another challenge for an individual that might have just chosen to purchase your old wood package. I'm not sure how well those packages will go over. -If I remember correct ly, the old wood package was compiled quite some time ago and there are many notes out there that reference that "no capstrip or plywood" package. -Th e contents of the original package is right on according to many past builders, and I am enjoying the fact that some of the guess work is eliminated when following the instruction of veteran builders that have use d your wood package. -In fact, it is one of the main reasons I purchased yo ur package. -I mean, have you guys tried to build one of these from the plan s? I suppose things can change, but I certainly can't recommend what you are currently offering since I have no idea what it includes. -I would like t o suggest that you offer the original package along with those "kits" you are offering. In addition to that... publish a bill of materials (similar to th e GN-1 package) so people can know what they are looking at. Perhaps you know best what it is that your customer wants, but it seems lik e you might not want to mess with something that many people have said is a "no-brainer" when it comes to wood selection. -Lots of people like to acquire their wood in different ways, but I'm sure that many would choose t o pay a little extra to know they have good quality components cut to the sizes they require. -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=308429#308429 Attachments: http://forums.matronics.com//files/asands_801.jpg st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax =0A=0A=0A ________________________________________________________________________________
Subject: Re: remote mounting 0200 air box
Date: Aug 18, 2010
Agree with Jack: having it hang out a bit does not distract/detract and adds to the charm. I bet you'll lose a little of your carb heat effectiveness if you lengthen the run of hose. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309297#309297 ________________________________________________________________________________
Date: Aug 18, 2010
Thanks KM! We WANT to link to the others like yourself that make parts (like Ken Perkins) so we can be a resource for facilitating the planes being built. So, instead of making metal or fiberglass parts, we link to you and Ken, so that someone can be a reference point for the group, along with the Piet list. I dunno how it'll work out, but we'd like to try. This group is such a great team of support, it might not be necessary for a 'link' page, but it might help to organize as one quick stop for the group to use to find answers. All in time. It is TIME consuming to build websites and jigs and such all at once! We have a start, but I want it all done NOW :o) Thanks for the encouragement! Mark On Wed, Aug 18, 2010 at 9:02 AM, KM Heide CPO/FAAOP wrote: > Mark, > > For what it's worth.....KUDO'S!! I say this is an excellent idea and > support your efforts. The fittings kit would be fantastic right along with > the rest of your ideas!. For the purest, you can build the entire plane to > your liking. For people like myself who love to fly, I could use specific > parts and pieces to advance the build time. I would rather fly and buy some > things to speed up build process! > > As you may know, I make the cowlings for the corvair piet using a pattern > from the orginal Pietenpol (thank you "Fireman Dan" in Mpls). I cover my > expenses and sell them to the group with a very small margin of profit. This > is a hobby to me and not a business... so I see no real income from this > (production runs vary widely). That's not to say for you this could not be a > business, just explaining my position on my costs: makes it more feasable > for others who just want a great bank for the buck and give back to the > members. > > So, you have my vote for continuing with your ideas! Please keep the list > informed. Have plently of photos to share of final products so we can see > what we are purchasing. The members of this list can provide input for > improved changes to some of these parts and pieces; please utilize them as > they have "been their and done that!" > > Again..... Kudo's! I want to build and enjoy the journey... but not over > three years! > > KM Heide > Hawley, MN > > * > * > ** > > > --- On *Wed, 8/18/10, Mark Roberts * wrote: > > > From: Mark Roberts <mark.rbrts1(at)gmail.com> > Subject: Re: Pietenpol-List: Re: Wood kits > To: pietenpol-list(at)matronics.com > Date: Wednesday, August 18, 2010, 12:10 AM > > Hey Guys, Regarding wood kits: > > My business partner and I took a business trip last week to LA for a > conference (thus the lack of posts), and on the way down we began assembling > prices and material lists for some wood kits that we mentioned last week or > so ago on the list. We have both a CNC router (5' x 10' MultiCam CNC router > and a 4' x 8' laser table), and have some spruce on hand that is spar grade > stuff, but after the response we got, we began thinking that we would offer > some sub-assembly kits. These would offer the spruce parts as well as the > ply parts cut to shape using the CNC stuff. > > Planning all of this was the bulk of our discussion in the car (both > directions) on the 4 hour trip. We have some of the kit info together, and I > have been working to find some of the carriers that can ship reasonably all > over the country. I haven't posted all this yet as I was wanting to have all > the info for the number of requests we've had. > > I just checked ACS and saw that they now have sub kits available, which was > what we were thinking of offering. I can't remember if I posted this earlier > when I mentioned that we'd be offering kits, but I think it's great that > those options are available! It makes it better for ALL of us to have > options, and the ability to choose. > > We got a new web address for all of this (www.PietenParts.com<http://www.pietenparts.com/> or > www.PietParts.com <http://www.pietparts.com/>), and I can tell you that > our kits and sub kits will be CNC cut Plywood parts and will have all of the > materials listed so you can see what you are getting. I noticed this was > missing when I went to the ACS site... But, nice to see the sub kits which > is what I was planning to offer originally. > > By the way, we are going to offer our kits with CNC machined rib jigs for > the Original FC-10 airfoil, the Riblett GA-30-612 and the Riblett > GA-30-613.5 airfoils. > > One additional item that I am very excited about offering is a rib stick > cutting jig that will cut the internal rib sticks for each rib easily > and accurately! It can reduce the amount of time it takes to cut the sticks > down to a short afternoon, and they'll snap in place! So far I have the one > for the Riblett 613.5 finished, and I still need to finish the FC-10 jig, > and the FC-10 and Riblett 612 cutting jig. I cut the parts for the internal > rib sticks very accuratly, and importantly, quickly. > > We hope to have the website up and running before long: > > www.PietenParts.com <http://www.pietenparts.com/> or www.PietParts.comwill eventually get you to the same place! > > By the way, we are pricing the Wing Rib kits, with the Bending Jig, The > Stick Cutting Jig, and the actual Rib Jig for much less than what I saw on > ACS. We are including a 'No Spar' option where you can just buy rib stuff > with out spars to see if you even want to go further into the project before > committing serious money. Some people may tire after ribs :o\ > > More soon. > > Mark > > > On Wed, Aug 11, 2010 at 5:55 PM, Gary Boothe http://us.mc527.mail.yahoo.com/mc/compose?to=gboothe5@comcast.net> > > wrote: > > > > > Whew!!! Just contact Mark Roberts, mark.rbrts1@gmail.com<http://us.mc527.mail.yahoo.com/mc/compose?to=mark.rbrts1@gmail.com>. > I know he doesn't > have kit prices yet, but he has wood... > > Gary Boothe > Cool, CA > Pietenpol > WW Corvair Conversion > Tail done, Fuselage on gear > 20 ribs done > > -----Original Message----- > From: owner-pietenpol-list-server@matronics.com<http://us.mc527.mail.yahoo.com/mc/compose?to=owner-pietenpol-list-server@matronics.com> > [mailto:owner-pietenpol-list-server@matronics.com<http://us.mc527.mail.yahoo.com/mc/compose?to=owner-pietenpol-list-server@matronics.com>] > On Behalf Of K5YAC > Sent: Wednesday, August 11, 2010 5:46 PM > To: pietenpol-list@matronics.com<http://us.mc527.mail.yahoo.com/mc/compose?to=pietenpol-list@matronics.com> > Subject: Pietenpol-List: Re: Wood kits > > > > > Well that is confusing as hell. You guys normally posted a wood package > for > the Pietenpol Air Camper... now you only list four "kits" for the different > sections of the Pietenpol Air Camper, and none of them are linked to a bill > of materials that can be accessed and studied in order to confirm what the > customer is actually ordering. For example, what is included in that $931 > "wing kit" that is now listed? Does that include capstrip for wing ribs? > If so, what are guys suposed to do that have already built or acquired > ribs? > Search for individual items to complete the wings? Whew! Not the end of > the world, but another challenge for an individual that might have just > chosen to purchase your old wood package. > > I'm not sure how well those packages will go over. If I remember > correctly, > the old wood package was compiled quite some time ago and there are many > notes out there that reference that "no capstrip or plywood" package. The > contents of the original package is right on according to many past > builders, and I am enjoying the fact that some of the guess work is > eliminated when following the instruction of veteran builders that have > used > your wood package. In fact, it is one of the main reasons I purchased your > package. I mean, have you guys tried to build one of these from the plans? > > > I suppose things can change, but I certainly can't recommend what you are > currently offering since I have no idea what it includes. I would like to > suggest that you offer the original package along with those "kits" you are > offering. In addition to that... publish a bill of materials (similar to > the > GN-1 package) so people can know what they are looking at. > > Perhaps you know best what it is that your customer wants, but it seems > like > you might not want to mess with something that many people have said is a > "no-brainer" when it comes to wood selection. Lots of people like to > acquire their wood in different ways, but I'm sure that many would choose > to > pay a little extra to know they have good quality components cut to the > sizes they require. > > -------- > Mark Chouinard > Finishing up Wings - Working on Center Section > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=308429#308429 > > > Attachments: > > http://forums.matronics.com//files/asands_801.jpg > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > -- > Mark Roberts > California Laser Etch > www.california-laser.com > 888-882-5015 > 888-882-5016 fax > > * > > " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List > =nofollow>http://forums.matronics.com > blank rel=nofollow>http://www.matronics.com/contribution > * > > > * > > * > > -- Mark Roberts California Laser Etch www.california-laser.com 888-882-5015 888-882-5016 fax ________________________________________________________________________________
Date: Aug 18, 2010
Subject: Re: appology
To the List, I appologize for voicing my pollitical views on the list, I kn ow this group is about Pietenpols, I guess it just slipped on out.- - Shad - So by the way what are the odds, of me making the wood fabric and tailwhels fly-in?=0A=0A=0A ________________________________________________________________________________
Date: Aug 18, 2010
Hi Shad, First baby: odds are 0 for flying 100 for attending mother-to-be, but wear ear plugs as you won't like the names she calls you! . Second or more baby: odds are greater she will want you the h*&* out of the re; so go flying but buy a nice gift to give her on your return. Good luck, Jim B. ----- Original Message ----- From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Wednesday, August 18, 2010 10:25:53 AM Subject: Re: Pietenpol-List: appology To the List, I appologize for voicing my pollitical views on the list, I kn ow this group is about Pietenpols, I guess it just slipped on out.=C2- Shad So by the way what are the odds, of me making the wood fabric and tailwhels fly-in? == ________________________________________________________________________________
Subject: Grounding Aircraft
Date: Aug 18, 2010
All.thanks so much for your thoughts! Jack, I memorized all of Tony's books, plus, pull many of his articles from the EAA archives, a fantastic resource. But the thoughts I receive here are the best, thank you all! Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Wednesday, August 18, 2010 6:32 AM Subject: Pietenpol-List: Grounding Aircraft Would like to hear thoughts on grounding the various parts on a Piet, fuel tank, avionics, lights, engine, etc. Thanks, Jack DSM ________________________________________________________________________________
Date: Aug 18, 2010
Jack, on your first photo, at the lower joint those look like welded beads, could you elaborate? Thanks, Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Wednesday, August 18, 2010 8:21 AM Subject: RE: Pietenpol-List: remote mounting 0200 air box Douwe, You can just let some of the airbox sit outside the cowling. It doesn't seem to mess up the lines too much. It looks terrible when the cowling is unpainted, but tends to disappear once the plane is finished. Look at what mine looked like before and after paint: Perhaps it helps to paint the cowling a dark color, but I find the airbox hanging down just doesn't draw the eye to it. If you look closely, you can see that the base of the carburetor (where the airbox attaches) is below the line of the cowling, so even if you moved the airbox, you would still have the SCAT hose showing there, and in the picture above, the SCAT hose is much more distracting to the eye than the whole airbox. Of course, mine is an A65 and I believe you are using an O-200, but I don't think they are much different in this regard. I think adding a length of SCAT hose between the air filter and the carburetor would add an unnecessary restriction to the engine airflow, and reduce power. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Wednesday, August 18, 2010 8:45 AM Subject: Pietenpol-List: remote mounting 0200 air box Hey guys, As I'm building my new cowling, I'm finding the air intake really messing up the bottom "lines". I got to thinking, "why can't I just relocate it and mount it remotely"?. As long as the scat tubing from the box to the carb isn't too long to cool the heated air when I use the carb heat, I can't see any downside. Thoughts? Douwe http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Rust Protection Question
Date: Aug 18, 2010
Yet another question for my "list friends".With your wing/center struts, gear and various horns, how are you protecting against rust and corrosion internally after painting? Prior to painting mine rust quickly if I don't coat with oil. Thanks, Jack ________________________________________________________________________________
From: Matthew VanDervort <matthew.vandervort(at)gmail.com>
Subject: Re: Rust Protection Question
Date: Aug 18, 2010
I was planning on linseed oil but haven't done any "real" research yet but a few quick google searches have turned up promising results Sent from my iPhone On Aug 18, 2010, at 8:56 PM, "Jack" wrote: > Yet another question for my =9Clist friends=9DWith yo ur wing/center struts, gear and various horns, how are you protecting agains t rust and corrosion internally after painting? Prior to painting mine rust quickly if I don=99t coat with oil > > Thanks, > > Jack > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: struts
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Aug 18, 2010
I don't know if anybody is needing a set but there is a set of BC12D struts I believe it said they are on Ebay aircraft parts list right now.I do not know that they are suitable for use to make Piet struts but I would sure check it out if I didn't already have mine made./on another note if anybody has any experience hooking up a Datcon tachometer I'd sure appreciate a e-mail off list. I'm having some trouble figuring out how to program mine. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309345#309345 ________________________________________________________________________________
Date: Aug 19, 2010
Are you talking about the cowling? Those are Cleco's, holding the pieces together until I could rivet them. Everything on the cowling is riveted together. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Wednesday, August 18, 2010 8:36 PM Subject: RE: RE: Pietenpol-List: remote mounting 0200 air box Jack, on your first photo, at the lower joint those look like welded beads, could you elaborate? Thanks, Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Wednesday, August 18, 2010 8:21 AM Subject: RE: Pietenpol-List: remote mounting 0200 air box Douwe, You can just let some of the airbox sit outside the cowling. It doesn't seem to mess up the lines too much. It looks terrible when the cowling is unpainted, but tends to disappear once the plane is finished. Look at what mine looked like before and after paint: Perhaps it helps to paint the cowling a dark color, but I find the airbox hanging down just doesn't draw the eye to it. If you look closely, you can see that the base of the carburetor (where the airbox attaches) is below the line of the cowling, so even if you moved the airbox, you would still have the SCAT hose showing there, and in the picture above, the SCAT hose is much more distracting to the eye than the whole airbox. Of course, mine is an A65 and I believe you are using an O-200, but I don't think they are much different in this regard. I think adding a length of SCAT hose between the air filter and the carburetor would add an unnecessary restriction to the engine airflow, and reduce power. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Wednesday, August 18, 2010 8:45 AM Subject: Pietenpol-List: remote mounting 0200 air box Hey guys, As I'm building my new cowling, I'm finding the air intake really messing up the bottom "lines". I got to thinking, "why can't I just relocate it and mount it remotely"?. As long as the scat tubing from the box to the carb isn't too long to cool the heated air when I use the carb heat, I can't see any downside. Thoughts? Douwe http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 19, 2010
My AME recommends linseed oil, too. Dan -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Aug 18, 2010, at 8:28 PM, Matthew VanDervort wrote: > I was planning on linseed oil but haven't done any "real" research yet but a few quick google searches have turned up promising results > > Sent from my iPhone > > On Aug 18, 2010, at 8:56 PM, "Jack" wrote: > >> Yet another question for my =9Clist friends=9DWith y our wing/center struts, gear and various horns, how are you protecting again st rust and corrosion internally after painting? Prior to painting mine rus t quickly if I don=99t coat with oil >> >> Thanks, >> >> Jack >> >> >> >> >> >> ========================= ========= >> >http://www.matronics.com/Navigator?Pietenpol-List >> ========================= ========= >> ums.matronics.com">http://forums.matronics.com >> ========================= ========= >> http://www.matronics.com/contribution">http://www.matronics.com/contribut ion >> ========================= ========= >> > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Test-phase report, and mystery
Date: Aug 19, 2010
Hello all you good people, Beautiful evening. Flew my beloved Piet last night in the pattern right be fore sunset. All went well. I can't do a normal run up because of my margi nal brakes, so in-flight, I decided to test my dual mag set-up. Noticed th at I got about 200 more rpm just running on the left mag alone, and to my surprise the engine ran at least 15 degrees cooler. I know my mags are no t timed exactly together because I can hear the impulse couplings clicking one after another when I pull it through by hand. I am guessing that the timing is more optimal on my left mag. With these symptoms what do you gu ys thing is going on? Please advise. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Aug 19, 2010
Subject: Re: Test-phase report, and mystery
Re-time the right mag to match the left? If they are both impulse I can't see a reason not to have them both the same. Ben On 8/19/2010 7:46 AM, helspersew(at)aol.com wrote: > Hello all you good people, > Beautiful evening. Flew my beloved Piet last night in the pattern > right before sunset. All went well. I can't do a normal run up because > of my marginal brakes, so in-flight, I decided to test my dual mag > set-up. Noticed that I got about 200 more rpm just running on the left > mag alone, and to my surprise the engine ran at least 15 degrees > cooler. I know my mags are not timed exactly together because I can > hear the impulse couplings clicking one after another when I pull it > through by hand. I am guessing that the timing is more optimal on my > left mag. With these symptoms what do you guys thing is going on? > Please advise. > Dan Helsper > Poplar Grove, IL. > > * > > > * ________________________________________________________________________________
Subject: Got an engine!
Date: Aug 19, 2010
Ryan wrote [about Mark Langford's website]- >Nothing about Pietenpols, but lots ofinformation about the Corvair Not true... not true. Pietenpol content on Mark's site: http://home.hiwaay.net/~langford/corvair/wwrear.html There is also a Piet based at Moontown, where Mark frequently flies. I only have one picture of it, rather fuzzy. Red struts and gear legs, Continental engine, looks like a metal prop on it, and the owner's initials are RM but that's about all I know about it. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 19, 2010
At normal operating conditions, a Continental's cylinder head temperature will be somewhere around 350F. At those same conditions, the EGT will be about 1000F HIGHER than the CHT. Which one will do a better job of carb heat? Quick... you need that heat and you need it right now, and you only get one shot at it ;o) Especially if you run a Stromberg like mine that makes ice like crazy. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 19, 2010
The impulses may not be in perfect delay as the actual running timing, which should be set per specs. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309372#309372 ________________________________________________________________________________
Date: Aug 19, 2010
Let's see, since "heat loss = heat gain," I'd go where there is the most heat (3X). Great point, Oscar, on the time issue. It is calories or BTUs /second you want. That sharpens the point. The heat is also more focused-- more easily tapped, if you will, into a tube, without using a "funnel"-- at the exhaust. I love this board. Tim in central TX -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: Aug 19, 2010 8:43 AM >To: Pietenpol List >Subject: Pietenpol-List: Carb heat from Continental Cylinder heads? > > >At normal operating conditions, a Continental's cylinder >head temperature will be somewhere around 350F. At those >same conditions, the EGT will be about 1000F HIGHER than >the CHT. Which one will do a better job of carb heat? > >Quick... you need that heat and you need it right now, and >you only get one shot at it ;o) Especially if you run a >Stromberg like mine that makes ice like crazy. > >Oscar Zuniga >Air Camper NX41CC >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > ________________________________________________________________________________
Date: Aug 19, 2010
Oscar: I had thought about the difference in CHT & EGT, but it also occurred to me that you need heat the most when the engine is at part throttle or even idle. What is the EGT after 20 seconds of 1,700RPM operation, then 10 seconds at idle? Probably still warmer than the CHT, but probably a long, long way from 1,300F. The mass of the cylinder heads just means they stay warm longer. Ryan M.: I believe the L2 is a pressure cowling setup, maybe that allows it to work. The carb heat connection would come from the lower part of the back of the eyebrows, not far from the exhaust port on the head, which is probably more like 400 to 500 degrees, rather than the 350 or so at the plug. IF I try it, I'll do ground testing first to verify adequate RPM drop and let the group know what I find. Thanks for all the information so far! It is definitely nice to hear about the things I hadn't considered yet. Steve Ruse Norman, OK Quoting Oscar Zuniga : > > > At normal operating conditions, a Continental's cylinder > head temperature will be somewhere around 350F. At those > same conditions, the EGT will be about 1000F HIGHER than > the CHT. Which one will do a better job of carb heat? > > Quick... you need that heat and you need it right now, and > you only get one shot at it ;o) Especially if you run a > Stromberg like mine that makes ice like crazy. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Aug 19, 2010
Steve, I don't have a Pietenpol, but I do have a JPi EDM700 on my 150 with an O-200. Pretty much immediately after start-up I see 100F across the CHTs and EGTs in the 800s Within 1 minute I have 100-150s on my CHTs and 800-1000 EGTs Within 2 minutes I'm up to 200-230s on CHTs and still 800-1000s on the EGTs The heads within 5 minutes of ground operation are in the 220-280 range depending what's going on. Taxi, idle, runup. The runup looks like 260-290 on the CHTs, 950-1100 on the EGTs Takeoff gets me in the 330-360 range on CHT with 1200-1350s for EGTs OAT was 40-50F. My CHT probes are on the spark plugs. Hope this helps, ~Matt On Thu, Aug 19, 2010 at 8:28 AM, Steve Ruse wrote: > > > > Oscar: > I had thought about the difference in CHT & EGT, but it also occurred to me > that you need heat the most when the engine is at part throttle or even > idle. What is the EGT after 20 seconds of 1,700RPM operation, then 10 > seconds at idle? Probably still warmer than the CHT, but probably a long, > long way from 1,300F. The mass of the cylinder heads just means they stay > warm longer. > > Ryan M.: > I believe the L2 is a pressure cowling setup, maybe that allows it to work. > The carb heat connection would come from the lower part of the back of the > eyebrows, not far from the exhaust port on the head, which is probably more > like 400 to 500 degrees, rather than the 350 or so at the plug. > > IF I try it, I'll do ground testing first to verify adequate RPM drop and > let the group know what I find. > > Thanks for all the information so far! It is definitely nice to hear about > the things I hadn't considered yet. > > Steve Ruse > Norman, OK > > Quoting Oscar Zuniga : > >> > >> >> >> At normal operating conditions, a Continental's cylinder >> head temperature will be somewhere around 350F. At those >> same conditions, the EGT will be about 1000F HIGHER than >> the CHT. Which one will do a better job of carb heat? >> >> Quick... you need that heat and you need it right now, and >> you only get one shot at it ;o) Especially if you run a >> Stromberg like mine that makes ice like crazy. >> >> Oscar Zuniga >> Air Camper NX41CC >> San Antonio, TX >> mailto: taildrags(at)hotmail.com >> website at http://www.flysquirrel.net >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 19, 2010
Need more information, Dan. Which mag impulse clicks over first? I seems to me (and I'm just thinking out loud here) that if one mag were timed correctly and the other came in later, that would do little to boost power and you would have a drop in RPM when switched to just the late mag. But if one were timed correctly and the other was timed too early, it would run poorly on the early mag, and OK on the correct one. The only thing that would make it run better on one mag than on both would be if one mag was so early that it was wasting some of the energy in firing very early and the engine ran better without it at all. But I can't think it would run well on that mag alone. Are you sure your switch is wired correctly? Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Thursday, August 19, 2010 7:46 AM Subject: Pietenpol-List: Test-phase report, and mystery Hello all you good people, Beautiful evening. Flew my beloved Piet last night in the pattern right before sunset. All went well. I can't do a normal run up because of my marginal brakes, so in-flight, I decided to test my dual mag set-up. Noticed that I got about 200 more rpm just running on the left mag alone, and to my surprise the engine ran at least 15 degrees cooler. I know my mags are not timed exactly together because I can hear the impulse couplings clicking one after another when I pull it through by hand. I am guessing that the timing is more optimal on my left mag. With these symptoms what do you guys thing is going on? Please advise. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Aug 19, 2010
That's why you always pull carb heat on while the engine is at cruise power BEFORE reducing to idle. Let it warm the carburetor for a few seconds before reducing the throttle. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Steve Ruse Sent: Thursday, August 19, 2010 9:29 AM Subject: Re: Pietenpol-List: Carb heat from Continental Cylinder heads? Oscar: I had thought about the difference in CHT & EGT, but it also occurred to me that you need heat the most when the engine is at part throttle or even idle. What is the EGT after 20 seconds of 1,700RPM operation, then 10 seconds at idle? Probably still warmer than the CHT, but probably a long, long way from 1,300F. The mass of the cylinder heads just means they stay warm longer. Ryan M.: I believe the L2 is a pressure cowling setup, maybe that allows it to work. The carb heat connection would come from the lower part of the back of the eyebrows, not far from the exhaust port on the head, which is probably more like 400 to 500 degrees, rather than the 350 or so at the plug. IF I try it, I'll do ground testing first to verify adequate RPM drop and let the group know what I find. Thanks for all the information so far! It is definitely nice to hear about the things I hadn't considered yet. Steve Ruse Norman, OK Quoting Oscar Zuniga : > > > At normal operating conditions, a Continental's cylinder > head temperature will be somewhere around 350F. At those > same conditions, the EGT will be about 1000F HIGHER than > the CHT. Which one will do a better job of carb heat? > > Quick... you need that heat and you need it right now, and > you only get one shot at it ;o) Especially if you run a > Stromberg like mine that makes ice like crazy. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Aug 19, 2010
On 08/19/2010 07:43 AM, Oscar Zuniga wrote: > --> Pietenpol-List message posted by: Oscar Zuniga > > > At normal operating conditions, a Continental's cylinder > head temperature will be somewhere around 350F. At those > same conditions, the EGT will be about 1000F HIGHER than > the CHT. Which one will do a better job of carb heat? But, the cylinder has (a) a higher mass and (b) a higher Specific Heat than the exhaust gas. We could Do Science to figure out which one will dump more hot air into the carb, if I could only remember the equation... Q=cM(Tsub1 - Tsub2), or something like that... > > Quick... you need that heat and you need it right now, and > you only get one shot at it ;o) Especially if you run a > Stromberg like mine that makes ice like crazy. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
From: "Aircraft Spruce Info" <info(at)aircraftspruce.com>
Date: Aug 19, 2010
Thanks for the builder who posted the comment about the Pietenpol wood kits from Aircraft Spruce. We simply split the original wood kit into four smaller kits for the wing, fuselage, stabilizer and elevator, and rudder and fin. This allows a builder to buy the wood in sections instead of as one large kit. All of these kits are on our website and the contents of each kit can be accessed online. If any builders need clarification or have any questions on our kits, please let us know. Aircraft Spruce & Specialty Co. Customer Service Dept. info(at)aircraftspruce.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309410#309410 ________________________________________________________________________________
Date: Aug 19, 2010
Just did a quick check, and the Aircraft Spruce website NOW has the contents of each wood kit listed (it didn't a few days ago, as was noted by Mark). I haven't checked ALL of the details (and I don't think I will, since I already have all my spruce), but I did notice one thing that is wrong. The wing kit lists 500 ft of 1/4" x 1/4" capstrip. The plans do not call for 1/4" x 1/4" anywhere. The capstrip size should be 1/4" x 1/2". I recall seeing a materials list that someone had posted a while back, that had a small note at the bottom, regarding capstrip size relating to engine horsepower, but the plans DO NOT have any reference to that - who knows where that came from. Just seems logical that a wood kit should be based on the actual plans, and not on some modification that some, unknown person came up with. http://www.aircraftspruce.com/builderkits.php?PN=01-00582 Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309412#309412 ________________________________________________________________________________
Date: Aug 19, 2010
There are, I believe, (do not have the plans with me here at work) 1/4" X 1 /4" cap strips that go between the ribs along the edges of the ailerons and wing, (where the aileron was removed) to give the fabric a place to attach . Or is this 1/2" X 1/4" as well? Either way, 500' of it seems a bit much. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com --- On Thu, 8/19/10, Bill Church wrote: From: Bill Church <billspiet(at)sympatico.ca> Subject: Pietenpol-List: Re: Wood kits Date: Thursday, August 19, 2010, 12:36 PM > Just did a quick check, and the Aircraft Spruce website NOW has the content s of each wood kit listed (it didn't a few days ago, as was noted by Mark). I haven't checked ALL of the details (and I don't think I will, since I alr eady have all my spruce), but I did notice one thing that is wrong. The win g kit lists 500 ft of 1/4" x 1/4" capstrip. The plans do not call for 1/4" x 1/4" anywhere. The capstrip size should be 1/4" x 1/2". I recall seeing a materials list that someone had posted a while back, that had a small note at the bottom, regarding capstrip size relating to engine horsepower, but the plans DO NOT have any reference to that - who knows wh ere that came from. Just seems logical that a wood kit should be based on the actual plans, and not on some modification that some, unknown person came up with. http://www.aircraftspruce.com/builderkits.php?PN=01-00582 Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309412#309412 le, List Admin. ________________________________________________________________________________
Date: Aug 19, 2010
Wow, $930.38 just for wing wood! I paid $850 for the full airframe wood kit minus cap-strip and plywood 6 years ago. (But its not 6 years ago is it?). rick On Thu, Aug 19, 2010 at 10:36 AM, Bill Church wrote: > billspiet(at)sympatico.ca> > > Just did a quick check, and the Aircraft Spruce website NOW has the > contents of each wood kit listed (it didn't a few days ago, as was noted by > Mark). > I haven't checked ALL of the details (and I don't think I will, since I > already have all my spruce), but I did notice one thing that is wrong. The > wing kit lists 500 ft of 1/4" x 1/4" capstrip. The plans do not call for > 1/4" x 1/4" anywhere. The capstrip size should be 1/4" x 1/2". > I recall seeing a materials list that someone had posted a while back, that > had a small note at the bottom, regarding capstrip size relating to engine > horsepower, but the plans DO NOT have any reference to that - who knows > where that came from. > Just seems logical that a wood kit should be based on the actual plans, and > not on some modification that some, unknown person came up with. > > http://www.aircraftspruce.com/builderkits.php?PN=01-00582 > > Bill C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309412#309412 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: This weekend in Southern Ontario
Date: Aug 19, 2010
If you're in or around southern Ontario, Canada this weekend, there's a Pietenpol-related event going on. The Ultralight Pilot's Association of Canada (UPAC) is holding its annual convention tomorrow evening (Friday) thru Sunday. They are "featuring" (whatever that means) Pietenpol Air Campers this year. The convention is held at the Lubitz Flying Field, near Waterloo, Ontario. Back in 1980, Ed Lubitz flew his Ford Fiesta powered Air Camper to Oshkosh, and caused a stir with his auto engine conversion. So, THAT Pietenpol will most likely be on display. Ed recently built a replica of the Silver Dart - the first aircraft to fly in Canada (which was designed by a group led by Alexander Graham Bell) just over 100 years ago. Details about the convention can be found at their website: www.upac.ca Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309441#309441 ________________________________________________________________________________
Date: Aug 19, 2010
Thanks Maybe I can shoot down. Bob -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: August 19, 2010 3:41 PM Subject: Pietenpol-List: This weekend in Southern Ontario If you're in or around southern Ontario, Canada this weekend, there's a Pietenpol-related event going on. The Ultralight Pilot's Association of Canada (UPAC) is holding its annual convention tomorrow evening (Friday) thru Sunday. They are "featuring" (whatever that means) Pietenpol Air Campers this year. The convention is held at the Lubitz Flying Field, near Waterloo, Ontario. Back in 1980, Ed Lubitz flew his Ford Fiesta powered Air Camper to Oshkosh, and caused a stir with his auto engine conversion. So, THAT Pietenpol will most likely be on display. Ed recently built a replica of the Silver Dart - the first aircraft to fly in Canada (which was designed by a group led by Alexander Graham Bell) just over 100 years ago. Details about the convention can be found at their website: www.upac.ca Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309441#309441 ________________________________________________________________________________
Date: Aug 19, 2010
Bill C., you are correct that the reference to 1/4"x 1/4" capstrip is NOT on the Pietenpol plans, but it is shown on the Grega GN-1 plans. They state that 1/4"x 1/4" is acceptable for engines up to 65hp (I think, plans not in front of me), but for engines above 65hp to use 1/4"x 1/2" capstrip for the ribs. I have not built my Piet ribs yet, but I will follow convention and stick to the 1/4"x 1/2" capstrips on mine. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309445#309445 ________________________________________________________________________________
Date: Aug 19, 2010
Subject: Re: This weekend in Southern Ontario
Sure wish we were spending the weekend in Suthern Ontario instead of Nuthern Louisiana CMC ________________________________________________________________________________
Date: Aug 19, 2010
This seems like a good plan from AS&S. I have not evaluated the kits by mat erial, size of lumbar,-and total amount. Do these kits contain all the ri ght pieces?-Also, do you have to do any ripping of the wood itself or is this pre-cut? - KMHeide- - --- On Thu, 8/19/10, Bill Church wrote: From: Bill Church <billspiet(at)sympatico.ca> Subject: Pietenpol-List: Re: Wood kits Date: Thursday, August 19, 2010, 11:36 AM > Just did a quick check, and the Aircraft Spruce website NOW has the content s of each wood kit listed (it didn't a few days ago, as was noted by Mark). I haven't checked ALL of the details (and I don't think I will, since I alr eady have all my spruce), but I did notice one thing that is wrong. The win g kit lists 500 ft of 1/4" x 1/4" capstrip. The plans do not call for 1/4" x 1/4" anywhere. The capstrip size should be 1/4" x 1/2". I recall seeing a materials list that someone had posted a while back, that had a small note at the bottom, regarding capstrip size relating to engine horsepower, but the plans DO NOT have any reference to that - who knows wh ere that came from. Just seems logical that a wood kit should be based on the actual plans, and not on some modification that some, unknown person came up with. http://www.aircraftspruce.com/builderkits.php?PN=01-00582 Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309412#309412 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Aug 19, 2010
Dan=2C for one thing I would not have impulses on both=2C it isn't necessar y. An impulse also retards the spark a bit=2C when it is operating. At cr uise=2C the impulse should not be doing anything. Most modern aircraft eng ines have both mags timed the same. Older engines=2C like the 65 Continent al=2C etc=2C had one at some thing like 28 BTC and the other at 30 BTC. Li kewise on some radials. I think it is because one spark plug is closer to the intake valve than the other=2C and it is to give a more even burn. It sounds like your left mag is timed about right=2C and your right may be timed too early=2C igniting the fuel early causing a loss of performance an d a higher temperature. Time the right a little later (closer to TDC=2C re gardless of where it is now) and see if it improves. Make sure the impulse has popped when you time it=2C it will mess up the timing. I would still take off one of the impulses. Gene Subject: Pietenpol-List: Test-phase report=2C and mystery Date: Thu=2C 19 Aug 2010 07:46:17 -0400 From: helspersew(at)aol.com Hello all you good people=2C Beautiful evening. Flew my beloved Piet last night in the pattern right bef ore sunset. All went well. I can't do a normal run up because of my margina l brakes=2C so in-flight=2C I decided to test my dual mag set-up. Noticed t hat I got about 200 more rpm just running on the left mag alone=2C and to m y surprise the engine ran at least 15 degrees cooler. I know my mags are no t timed exactly together because I can hear the impulse couplings clicking one after another when I pull it through by hand. I am guessing that the ti ming is more optimal on my left mag. With these symptoms what do you guys t hing is going on? Please advise. Dan Helsper Poplar Grove=2C IL. ________________________________________________________________________________
Subject: Re: Got a compass
Date: Aug 19, 2010
apparently it's a mark VII http://www.taircraft.com/parts/instruments/compass.html scroll all the way to the bottom. Regardless know that I know it's WW2 vintage, my dad will go nuts :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309490#309490 ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Re: Fwd: CorvAircraft> New Oshkosh notes.
Hi Ryan and Jesse, So how many hours do you have on the really nice white and green Piet? Have n't heard Jesse squeal out here in No. Cal. so isn't she flying in it? Jim B. ----- Original Message ----- From: "Ryan Mueller" <rmueller23(at)gmail.com> =========== -List Email Forum - =========== -=C2-=C2- - MATRONICS WEB FORUMS - =========== - - List Contribution Web Site - -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2- -Matt Dralle, List Admin. =========== ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: AS&S
Date: Aug 20, 2010
Kudos to Aircraft Spruce and Specialty for being responsive enough to our needs to: (a.) even hear our group grumblings and (b.) to respond quickly to such. No they're not perfect, but I've pretty much built my plane from their catalog and have always appreciated the things they've done right which have far outnumbered the mistakes. Douwe Ps. Hey Dan, Gene is bang on about your mag timing. (no surprise right?) ________________________________________________________________________________
Subject: Mag timing/ impulse on both mags
Date: Aug 20, 2010
Gene and Douwe, Yes I think you are right on the mag timing problem. I am going to get ar ound to looking at it this afternoon. But Gene, I am not sure why I would need to remove one of the impulse couplings. My Aeronca has two Slick mag s and both have the impulses. Even when I ran the old Bendix mags, they bo th had it. Please explain. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Tail wheel..good reading
http://fly.hiwaay.net/~langford/kgear.html#tailwheel Above is a link to an write-up I just came across. You may read the whole thing, but if you click on the "tail wheel update" link at the top of the page it will take you to what I read. It is a little long winded, but I found it interesting. Just passing it along. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: Mag timing/ impulse on both mags
Date: Aug 20, 2010
One less mechanical thing to break/malfunction. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309524#309524 ________________________________________________________________________________
Subject: Why not post replies in the original topic???
Date: Aug 20, 2010
I've noticed that on this forum that some members rather than post comments, replies, suggestions etc in the original post they post in a new topic. Example, there are at least 10 new topics started with Dear sage builders, engineers,advisors and fellow lovers... Just looking through the first couple of pages of topics there numerous other examples. The topic become very disjointed. It is hard to follow the topic in a chronological order as to who is replying to who. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309527#309527 ________________________________________________________________________________
Date: Aug 20, 2010
I plan on using that same wheel, but I am going to see if I can get it from the place mentioned in the write-up and get some better bearings. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Re: Why not post replies in the original topic???
I noticed the same thing...even with my replies. I reply to the original post. (So I thought...I don't start a new topic) Something amiss with the server? Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 20, 2010
Oh man... I sure am glad that I didn't start this thread. How does that go? Don't disconcert the masses, right? -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309539#309539 ________________________________________________________________________________
Date: Aug 20, 2010
That is right Bill... one of the Ohio Piet guys had an old typed list that has obviously floated around for years, but I can't remember the name. I was told that his list was used to create the AS&S bill of materials for the original Pietenpol wood package, minus any capstrip or ply. I'm not sure if that is all true, but I did use that list to inventory the parts I received from AS&S and it was right on, with the exception of two extra 3/16" strips for the empennage. Much of the hand written and photo copied notes were difficult to read, so I retyped them a few months ago and posted them here for others to use. I've found the list useful when trying to determine what lengths to use for which assemblies... I figured others would too. Getting to the point... at the bottom of his page he had a note stating... 65HP or less - 1/4" x 1/4" capstrip 65HP or more - 1/4" x 1/2" capstrip Perhaps that is where it came from? I agree that 1/4" x 1/2" should be used as per the original plans. Bill Church wrote: > Just did a quick check, and the Aircraft Spruce website NOW has the contents of each wood kit listed (it didn't a few days ago, as was noted by Mark). > I haven't checked ALL of the details (and I don't think I will, since I already have all my spruce), but I did notice one thing that is wrong. The wing kit lists 500 ft of 1/4" x 1/4" capstrip. The plans do not call for 1/4" x 1/4" anywhere. The capstrip size should be 1/4" x 1/2". > I recall seeing a materials list that someone had posted a while back, that had a small note at the bottom, regarding capstrip size relating to engine horsepower, but the plans DO NOT have any reference to that - who knows where that came from. > Just seems logical that a wood kit should be based on the actual plans, and not on some modification that some, unknown person came up with. > > http://www.aircraftspruce.com/builderkits.php?PN=01-00582 > > Bill C. -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309542#309542 ________________________________________________________________________________
Date: Aug 20, 2010
Dan I am with you on both mags having impulse couplings. It will definitely start better. The only problem I have ever seen an impulse coupling give is back when I first started flying the oils were not as good as now. They would gum up...get sticky and not engage sometime. Washed up and work good as new. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309545#309545 ________________________________________________________________________________
Date: Aug 20, 2010
Dan=2C I was not suggesting you HAVE to remove one=2C just that another is not necessary. Most modern engines only have one. Many more old continent als and such had none at all. Radials=2C except Kinners (probably somethin g else=2C but I can't think of one) dont have impulses. I think the Model A would start just fine with no impulse=2C but if you want one that is fine . I just think two is overkill and may be somehow contributing to your pro blem. Gene Subject: Pietenpol-List: Mag timing/ impulse on both mags Date: Fri=2C 20 Aug 2010 10:02:32 -0400 From: helspersew(at)aol.com Gene and Douwe=2C Yes I think you are right on the mag timing problem. I am going to get aro und to looking at it this afternoon. But Gene=2C I am not sure why I would need to remove one of the impulse couplings. My Aeronca has two Slick mags and both have the impulses. Even when I ran the old Bendix mags=2C they bot h had it. Please explain. Dan Helsper Poplar Grove=2C IL. ________________________________________________________________________________
Subject: Last Ribs
Date: Aug 20, 2010
OK, i am down to my last 6 ribs! I am making the 3 piece wing and have noticed that some people have the 2 outer center section ribs sheeted in ply and others do not. Why the 2 different methods and what size ply was used by those that used it? Also, would the inner ribs of each wing panel need to be sheeted too? Thanks- Earl -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309552#309552 ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Re: Last Ribs
The added sheeting on the center section and inboard wing ribs aids in atta ching fabric. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com --- On Fri, 8/20/10, echobravo4 wrote: From: echobravo4 <eab4(at)comcast.net> Subject: Pietenpol-List: Last Ribs Date: Friday, August 20, 2010, 2:27 PM OK, i am down to my last 6 ribs! I am making the 3 piece wing and have noticed that some people have the 2 outer center section ribs sheeted in ply and others do not. Why the 2 different methods and what size ply was used by those that used it? Also, would the inner ribs of each wing panel need to be sheeted too? Thanks- Earl -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up whe re I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309552#309552 le, List Admin. ________________________________________________________________________________
Date: Aug 20, 2010
I'm one of those that sheeted it in (1/16") ply and I have NO idea why I did that (I've made that statement more than once in my life!). Seriously, I would not do it again. I would definitely put in the extra "compression" 1/4 X1/2 vertical pieces but I'm sure those are enough. Actually, I ended up routing out most of the ply anyway...see attached. JM -----Original Message----- >From: echobravo4 <eab4(at)comcast.net> >Sent: Aug 20, 2010 2:27 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Last Ribs > > >OK, i am down to my last 6 ribs! > >I am making the 3 piece wing and have noticed that some people have >the 2 outer center section ribs sheeted in ply and others do not. > >Why the 2 different methods and what size ply was used by those that used >it? > >Also, would the inner ribs of each wing panel need to be sheeted too? > >Thanks- >Earl > >-------- >Earl Brown > >I may not have gone where I intended to go, but I think I have ended up where I intended to be. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=309552#309552 > > ________________________________________________________________________________
Date: Aug 20, 2010
While we're on the subject of minor problems......can someone tell me why some of the post are in such small print? It seems once a thread goes small it all goes small and stays that way. I was thinking maybe someone was typing in such a small font that it forced my screen to go small to get the lines in? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309565#309565 ________________________________________________________________________________
Subject: Turtle Deck
Date: Aug 20, 2010
Ok folks I have been looking around the archives and have not found the answer to my mystery yet. I am preparing to start my turtle deck and I cant seem to find what dimensions of the wood is height and width. Secondly I want to put a head rest or even maybe go a little higher in the back, I watched a friend today taxi out in his GN-1 and it looked a little low. Any thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309569#309569 ________________________________________________________________________________
Subject: cowl support
Date: Aug 20, 2010
Hey guys I see some of you have a piece of what looks like 1 x 1 behind the cowl support that is bent the same radius. Then I see some of you have placed what looks like 1 x 1 in between the cowl support and the panel. Those that have the bent radius what was the method to you madness. It looks nice and seems as if it would give great support the cowl when it is laid. Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309570#309570 ________________________________________________________________________________
Date: Aug 20, 2010
Make the turtle decks as high as you want! Mine are 1 1/2" higher, but not flight tested... Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bcolleran Sent: Friday, August 20, 2010 1:57 PM Subject: Pietenpol-List: Turtle Deck Ok folks I have been looking around the archives and have not found the answer to my mystery yet. I am preparing to start my turtle deck and I cant seem to find what dimensions of the wood is height and width. Secondly I want to put a head rest or even maybe go a little higher in the back, I watched a friend today taxi out in his GN-1 and it looked a little low. Any thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309569#309569 ________________________________________________________________________________
Subject: Magneto problem- mystery solved
Date: Aug 20, 2010
Good (some if you) People, First of all I would like to agree with Mike C. who has in the past advoca ted changing the topic line to suit the changing conversation so as to not drag the same old topic line out days and days, so that the resulting con versation is not even close to the original anymore. (now waiting to be fl amed). This afternoon I had some time to go out in the hangar and try to solve my magneto problem. Y'all (getting ready to move to TN) were correct. I disc overed that the bolts on the right (malfunctioning) mag had loosened up an d the mag had rotated quite a bit and it was firing way too early. Then I checked the the left (correctly functioning) mag and it was still right on (30 degrees before TC). So I tightened everything down and expect ever ything to be OK. Had to button up the hangar because a storm was about to hit. I'll try running it tomorrow. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Aug 20, 2010
Bill, You may need as many as 4 or 5 of those, depending on how you design things. Take a piece of 3/4" plywood or particle board and make a template that matches the radius you decide upon. You'll need to clamp all together with pipe clamps or furniture clamps (2 would do), so make it so you can sandwich the pieces between. Cut a bunch of thin strips, 1/16" x 3/4", glue and clamp...its fun! Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bcolleran Sent: Friday, August 20, 2010 1:59 PM Subject: Pietenpol-List: cowl support Hey guys I see some of you have a piece of what looks like 1 x 1 behind the cowl support that is bent the same radius. Then I see some of you have placed what looks like 1 x 1 in between the cowl support and the panel. Those that have the bent radius what was the method to you madness. It looks nice and seems as if it would give great support the cowl when it is laid. Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309570#309570 ________________________________________________________________________________
Date: Aug 20, 2010
Bill I made the turtle deck from 1/4 by 1 inch redwood. Light and strong. The height is the same as the instrument panel. That is so the shoulder strap will not put downward pressure on the spine. Dale > [Original Message] > From: bcolleran <bcolleran(at)comcast.net> > To: > Date: 8/20/2010 3:58:18 PM > Subject: Pietenpol-List: Turtle Deck > > > Ok folks I have been looking around the archives and have not found the answer to my mystery yet. I am preparing to start my turtle deck and I cant seem to find what dimensions of the wood is height and width. > > Secondly I want to put a head rest or even maybe go a little higher in the back, I watched a friend today taxi out in his GN-1 and it looked a little low. > > Any thoughts? > > Thanks, > > Bill > N424BK > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309569#309569 > > ________________________________________________________________________________
Subject: Hi, I'm Tucker
Date: Aug 20, 2010
I just joined the list, I'm 13 and building a Pietenpol. My grandfather built a Skybolt and RV-9A and is helping me. Been looking at the Pietenpols at Oshkosh for the past 5 years and when we got home this year, we decided to go for it. I got the plans from Mr. Pietenpol and just got a Corvair engine. We spent yesterday and today tearing it down. I'm really excited about getting started. I need to order Mr. Wynne's Corvair book. Here's a picture. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309576#309576 Attachments: http://forums.matronics.com//files/img_0007_154.jpg ________________________________________________________________________________
Date: Aug 20, 2010
Welcome, Tucker. It's very refreshing to get some young blood on this list - all these old folks are getting me down. Serioulsy, we're very glad to have you and you will find this list to be an emnormous asset as you build your airplane. Next year you need to come to Brodhead the weekend before Oshkosh. Now as you get started you need to buy the set of 4 Tony Bingelis books, The Sportplane Builder, Sportplane Construction Techniques, Firewall Forward, and Tony Bingelis on Engines. They will tell you most of what you need to know, this list can provide the rest. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tucker Sent: Friday, August 20, 2010 5:32 PM Subject: Pietenpol-List: Hi, I'm Tucker I just joined the list, I'm 13 and building a Pietenpol. My grandfather built a Skybolt and RV-9A and is helping me. Been looking at the Pietenpols at Oshkosh for the past 5 years and when we got home this year, we decided to go for it. I got the plans from Mr. Pietenpol and just got a Corvair engine. We spent yesterday and today tearing it down. I'm really excited about getting started. I need to order Mr. Wynne's Corvair book. Here's a picture. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309576#309576 Attachments: http://forums.matronics.com//files/img_0007_154.jpg ________________________________________________________________________________
Subject: Re: Hi, I'm Tucker
Date: Aug 20, 2010
Wow! 13 years old, and building yourself an airplane. Way to go! When I was your age, I was only building flying models. One good thing is that the Pietenpol is built just like a model airplane (just on a bigger scale). In fact, the bigger scale is actually easier to work with - except for those GIANT Tee-pins (just kidding). You and your grandfather are in for a fun ride. Welcome to the List! Keep us updated with your progress, and ask any questions that you might come up with as you go. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309579#309579 ________________________________________________________________________________
Date: Aug 20, 2010
Hi Tucker, Congrats on choosing to build a Pietenpol. Between the knowledge your grandfather has acquired, and the knowledge on this list you should have plenty of help successfully completing your goal of building a Piet. A quick note about Corvairs for aircraft use: you should not just use any Corvair engine when looking to convert one for aircraft use. There are suitable engine codes that indicate particular characteristics of an engine that make it a good candidate for converting to an aircraft engine. Based on the picture of the engine that you sent, it looks like you have a 140 horsepower engine (the 4 carburetors indicate that). You will want to check the engine code that is stamped on top of the crankcase, behind the oil filler tube. It needs to end in the following two letters to be suitable for conversion for aircraft use: AH, RN, RX, RY. If it does not end in any of those four pairs, then unfortunately it is not suitable to use for an aircraft conversion. If it does end in those four codes you can rebuild it for aircraft use, but there are a few considerations to make before you proceed with it. You will not be able to use the cylinder heads from that engine; you will need to find different, more appropriate cylinder heads (95 or 110 horsepower cylinder heads). You will also have to replace the crankshaft gear with a different gear, because it is retarded 4 degrees and is not suitable for aircraft use. This can be a rather difficult task to accomplish, and is not ideal to have to do so. The 140 horsepower engines may be more valuable to the car guys, as I think they are a little rarer. You might look up your local Corvair car club, and ask around and see if anyone wants to trade for one or two 110 horsepower engine cores (of the proper code). You mentioned you need to buy William Wynne's manual. I would highly recommend doing so before proceeding much further with your Corvair rebuild. The manual is chock full of information about which kinds of engines are going to be best suited for conversion for aircraft use, and the best way to go about rebuilding one to ensure you end up with a reliable engine. Good luck! Ryan On Fri, Aug 20, 2010 at 4:32 PM, Tucker wrote: > > I just joined the list, I'm 13 and building a Pietenpol. My grandfather > built a Skybolt and RV-9A and is helping me. Been looking at the Pietenpols > at Oshkosh for the past 5 years and when we got home this year, we decided > to go for it. I got the plans from Mr. Pietenpol and just got a Corvair > engine. We spent yesterday and today tearing it down. I'm really excited > about getting started. I need to order Mr. Wynne's Corvair book. Here's a > picture. > > -------- > Tucker > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309576#309576 > > > Attachments: > > http://forums.matronics.com//files/img_0007_154.jpg > > ________________________________________________________________________________
Date: Aug 20, 2010
Tucker, Welcome, I can't to begin to tell you just how impressed I am with you. Such great ambitions and goals at such a young age your grandfather must be delighted. I am building one with my grandson too, he's a bit younger but it makes him happy to know he's part of the project. And when we work together I am I'm in the presence of the 2 greatest joys of my life. I can't wait to meet you and your grandfather in Brodhead next year. Where are you from? Along with the list we have one additional resource available to assist in your build. Many of us travel with our jobs and if a builder doesn't live near you I am certain one of our traveling crew would be more than happy to lend a hand, advice or support so please keep us all in mind as available resources in helping with your build. Best of luck in the hours of enjoyment you and your grandfather are going to have building the dream together. John Lititz Pennsylvania ------Original Message------ From: Tucker Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: Pietenpol builders Board Subject: Pietenpol-List: Hi, I'm Tucker Sent: Aug 20, 2010 5:32 PM I just joined the list, I'm 13 and building a Pietenpol. My grandfather built a Skybolt and RV-9A and is helping me. Been looking at the Pietenpols at Oshkosh for the past 5 years and when we got home this year, we decided to go for it. I got the plans from Mr. Pietenpol and just got a Corvair engine. We spent yesterday and today tearing it down. I'm really excited about getting started. I need to order Mr. Wynne's Corvair book. Here's a picture. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309576#309576 Attachments: http://forums.matronics.com//files/img_0007_154.jpg Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Aug 20, 2010
Actually I thought the sheeting on the inboard wing ribs keeps the fabric from pulling the ribs in when shrinking. I still ended up with a slight warpage. Ben Charvet On 8/20/2010 2:41 PM, Michael Perez wrote: > The added sheeting on the center section and inboard wing ribs aids in > attaching fabric. > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > --- On *Fri, 8/20/10, echobravo4 //* wrote: > > > From: echobravo4 <eab4(at)comcast.net> > Subject: Pietenpol-List: Last Ribs > To: pietenpol-list(at)matronics.com > Date: Friday, August 20, 2010, 2:27 PM > > > > > OK, i am down to my last 6 ribs! > > I am making the 3 piece wing and have noticed that some people have > the 2 outer center section ribs sheeted in ply and others do not. > > Why the 2 different methods and what size ply was used by those > that used > it? > > Also, would the inner ribs of each wing panel need to be sheeted too? > > Thanks- > Earl > > -------- > Earl Brown > > I may not have gone where I intended to go, but I think I have > ended up where I intended to be. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p://www.matronics.com/Navigator?Pietenpol-List" > target="_blank">http://www - MATRONICS WEB FORUMS - > = --> <http://forums.matronics.com/viewtopic.php?p=309552#309552> > > > <http://forums.matronics.com> > > * > > > * ________________________________________________________________________________
Date: Aug 20, 2010
Bill take a look at my site, this link will get you close http://textors.com/IMG_2022_640x427.jpg . You will need a form, plastic wrap and I used 1/16 (cut with a razor knife) and thin super glue. Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Friday, August 20, 2010 4:18 PM Subject: RE: Pietenpol-List: cowl support Bill, You may need as many as 4 or 5 of those, depending on how you design things. Take a piece of 3/4" plywood or particle board and make a template that matches the radius you decide upon. You'll need to clamp all together with pipe clamps or furniture clamps (2 would do), so make it so you can sandwich the pieces between. Cut a bunch of thin strips, 1/16" x 3/4", glue and clamp...its fun! Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bcolleran Sent: Friday, August 20, 2010 1:59 PM Subject: Pietenpol-List: cowl support Hey guys I see some of you have a piece of what looks like 1 x 1 behind the cowl support that is bent the same radius. Then I see some of you have placed what looks like 1 x 1 in between the cowl support and the panel. Those that have the bent radius what was the method to you madness. It looks nice and seems as if it would give great support the cowl when it is laid. Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309570#309570 ________________________________________________________________________________
Date: Aug 20, 2010
Bill, I used 1/4" fir strips from Lowes, my deck is 2" higher than plans and matched the forward cowls. A suggestion, don't do as I did and use 11 strips. I did so to smooth out the deck and Fireman Dan pointed out I added a lot of weight to the rear of my ship, good advice. I drilled lightening holes to help a little. See here http://textors.com/IMG_1949_640x427.jpg . Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bcolleran Sent: Friday, August 20, 2010 3:57 PM Subject: Pietenpol-List: Turtle Deck Ok folks I have been looking around the archives and have not found the answer to my mystery yet. I am preparing to start my turtle deck and I cant seem to find what dimensions of the wood is height and width. Secondly I want to put a head rest or even maybe go a little higher in the back, I watched a friend today taxi out in his GN-1 and it looked a little low. Any thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309569#309569 ________________________________________________________________________________
Date: Aug 20, 2010
I have an idea this is one Pietenpol that WILL get finished.... http://www.tuckerrice.net/index.htm -----Original Message----- >From: Bill Church <billspiet(at)sympatico.ca> >Sent: Aug 20, 2010 4:55 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Hi, I'm Tucker > > >Wow! 13 years old, and building yourself an airplane. Way to go! >When I was your age, I was only building flying models. >One good thing is that the Pietenpol is built just like a model airplane (just on a bigger scale). In fact, the bigger scale is actually easier to work with - except for those GIANT Tee-pins (just kidding). >You and your grandfather are in for a fun ride. >Welcome to the List! >Keep us updated with your progress, and ask any questions that you might come up with as you go. > >Bill C. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=309579#309579 > > ________________________________________________________________________________
Date: Aug 20, 2010
That's a neat picture.... -----Original Message----- >From: Jack <jack(at)textors.com> >Sent: Aug 20, 2010 6:54 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Turtle Deck > > >Bill, I used 1/4" fir strips from Lowes, my deck is 2" higher than plans and >matched the forward cowls. A suggestion, don't do as I did and use 11 >strips. I did so to smooth out the deck and Fireman Dan pointed out I added >a lot of weight to the rear of my ship, good advice. I drilled lightening >holes to help a little. See here http://textors.com/IMG_1949_640x427.jpg . >Jack >DSM > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bcolleran >Sent: Friday, August 20, 2010 3:57 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Turtle Deck > > >Ok folks I have been looking around the archives and have not found the >answer to my mystery yet. I am preparing to start my turtle deck and I cant >seem to find what dimensions of the wood is height and width. > >Secondly I want to put a head rest or even maybe go a little higher in the >back, I watched a friend today taxi out in his GN-1 and it looked a little >low. > >Any thoughts? > >Thanks, > >Bill >N424BK > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=309569#309569 > > ________________________________________________________________________________
Date: Aug 20, 2010
Welcome Tucker! This is a great group of people that are a great resource for information and support! Have fun and keep us posted on the progress! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309592#309592 ________________________________________________________________________________
Date: Aug 20, 2010
Good to have a young man starting his Pietenpol.- You are a very fortunat e person to be able to start your airplane at a young age.- The rest of u s only dreamed of building a real airplane when we were 13, most of us were still building models.- You will learn a lot while building. You will fi nd practical uses for all that math you learn in school, and be able to app ly it to something you like to do.- By the time you are half way done wit h your Pietenpol, You will be teaching your high school shop teacher how to do something (do they still have shop classes?).- If you need any help w ith the corvair, I will help you the best I can, if I do not know the answe r, I will tell you I don't know.- Like Ryan M. said, get William Wynne's manual, and study it.- Do your research, and decide for sure you like the corvair.- You can decide later in your build which engine to use.- Kee p on truck'n, Tucker, you'll be flying befor you know it! - Shad - -=0A=0A=0A ________________________________________________________________________________
Date: Aug 20, 2010
Subject: Re: Turtle Deck
Made my rear turtle deck 3" higher and both instrument boards 2" higher. As shown in the Bingelis books you don't want your shoulder harness attach point too low. rick On Fri, Aug 20, 2010 at 2:56 PM, bcolleran wrote: > > Ok folks I have been looking around the archives and have not found the > answer to my mystery yet. I am preparing to start my turtle deck and I cant > seem to find what dimensions of the wood is height and width. > > Secondly I want to put a head rest or even maybe go a little higher in the > back, I watched a friend today taxi out in his GN-1 and it looked a little > low. > > Any thoughts? > > Thanks, > > Bill > N424BK > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309569#309569 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Aug 20, 2010
If you raise the turtle deck, you may have a greater need for the flop. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309600#309600 ________________________________________________________________________________
Date: Aug 20, 2010
Some users receive the digest once a day. In order to respond, they in essence send an email to the list and the subject line becomes the title to a new topic. If you're viewing the list online by actually visiting the website, then you can "reply" to the message within the topic. Two methods and two results. When responding to the digest it is not apparent that you are creating a new topic. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309602#309602 ________________________________________________________________________________
Subject: Plnas came in !!
Date: Aug 20, 2010
Went over to my Dad's house and we looked over the plans and read over the book. I'm sooo excited that we have the plans now. Now we gata start making some saw dust 8) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309608#309608 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Aug 21, 2010
Great to see a young man interested in using his hands. I wish more young people would do so. Then I could be sure that someone would become a Machinist and help keep my old Bonanza in the air. Check out this site about the image of manual labor in America. http://www.ratzenberger.com/index.php ----- Original Message ----- From: shad bell <aviatorbell(at)yahoo.com> Date: Saturday, August 21, 2010 4:34 Subject: Re: Pietenpol-List: Hi, I'm Tucker > Good to have a young man starting his Pietenpol. You are a very > fortunate person to be able to start your airplane at a young > age. The rest of us only dreamed of building a real airplane when > we were 13, most of us were still building models. You will learn > a lot while building. You will find practical uses for all that > math you learn in school, and be able to apply it to something you > like to do. By the time you are half way done with your > Pietenpol, You will be teaching your high school shop teacher how > to do something (do they still have shop classes?). If you need > any help with the corvair, I will help you the best I can, if I do > not know the answer, I will tell you I don't know. Like Ryan M. > said, get William Wynne's manual, and study it. Do your research, > and decide for sure you like the corvair. You can decide later in > your build which engine to use. Keep on truck'n, Tucker, you'll > be flying befor you know it! > > Shad > > > > > ________________________________________________________________________________
Date: Aug 21, 2010
If you raise the deck and cowlings you will want to consider extending the center section struts. Otherwise she will be plenty hard to get in the front pit; Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Friday, August 20, 2010 10:07 PM Subject: Re: Pietenpol-List: Turtle Deck Made my rear turtle deck 3" higher and both instrument boards 2" higher. As shown in the Bingelis books you don't want your shoulder harness attach point too low. rick On Fri, Aug 20, 2010 at 2:56 PM, bcolleran wrote: Ok folks I have been looking around the archives and have not found the answer to my mystery yet. I am preparing to start my turtle deck and I cant seem to find what dimensions of the wood is height and width. Secondly I want to put a head rest or even maybe go a little higher in the back, I watched a friend today taxi out in his GN-1 and it looked a little low. Any thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309569#309569 ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Rust Protection Question
Date: Aug 21, 2010
If the metal piece was not sealed I sprayed (or sloshed, if spraying wasn't practical) primer on the inside. For sealed pieces I used the linseed oil. Be careful: if you put linseed oil in a "sealed" part the linseed will find its way out through any tiny holes over the course of weeks or months and will cause complications during painting. I had that happen on one or two pieces, however, I cleaned the parts really well prior to spraying and didn't have too much trouble. If you can paint the outside of the part prior to adding the oil you'd avoid the problem. Given the sequence of fabrication, though, that's usually not practical. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309622#309622 ________________________________________________________________________________
Subject: Re: Plnas came in !!
Date: Aug 21, 2010
Measure Twice, cut once. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309636#309636 ________________________________________________________________________________
Date: Aug 21, 2010
Thanks for the note Kevin, that's what I plan to do... Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Saturday, August 21, 2010 9:27 AM Subject: Pietenpol-List: Re: Rust Protection Question If the metal piece was not sealed I sprayed (or sloshed, if spraying wasn't practical) primer on the inside. For sealed pieces I used the linseed oil. Be careful: if you put linseed oil in a "sealed" part the linseed will find its way out through any tiny holes over the course of weeks or months and will cause complications during painting. I had that happen on one or two pieces, however, I cleaned the parts really well prior to spraying and didn't have too much trouble. If you can paint the outside of the part prior to adding the oil you'd avoid the problem. Given the sequence of fabrication, though, that's usually not practical. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309622#309622 ________________________________________________________________________________
Subject: Cork Fuel Guage
Date: Aug 21, 2010
Has anyone flying used a cork/rod type gauge successfully in their center section tank? Was wondering if you can see it while strapped in. Thanks, Jack DSM ________________________________________________________________________________
Date: Aug 21, 2010
Bare metal. Epoxy primer before painting is hard to beat. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309658#309658 ________________________________________________________________________________
Subject: Re: Cork Fuel Guage
Date: Aug 21, 2010
My sight glass hangs down below the wing. I don't have a picture but I did find this from flying-squirrel that is similar to mine. Easy to see while flying. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309660#309660 Attachments: http://forums.matronics.com//files/fuel_gauge_197.jpg ________________________________________________________________________________
Date: Aug 21, 2010
I have been using just such a gauge now for 5 years and I find it to be qui te satisfactory. I would however suggest using a small tube in the gas cap to keep the rod from leaning over as mine does all the time. Someday I'm going to change that and fix it. I did measure and paint the en d of the rod white to indicate when I am running low on fuel. I gave myself a few extra gallons before total empty. just to be on the safe side.You ma y want more.Just paint lower for more fuel at the end. From: jack(at)textors.com Subject: Pietenpol-List: Cork Fuel Guage Date: Sat=2C 21 Aug 2010 15:20:36 -0500 Has anyone flying used a cork/rod type gauge successfully in their center s ection tank? Was wondering if you can see it while strapped in. Thanks=2C Jack DSM ________________________________________________________________________________
Date: Aug 21, 2010
I've got one. Why would you have trouble seeing it? See it hanging down in front of the fornt cockpit windshield? Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Saturday, August 21, 2010 4:21 PM Subject: Pietenpol-List: Cork Fuel Guage Has anyone flying used a cork/rod type gauge successfully in their center section tank? Was wondering if you can see it while strapped in. Thanks, Jack DSM ________________________________________________________________________________
Date: Aug 21, 2010
dfwplt wrote: > I have an idea this is one Pietenpol that WILL get finished.... > > http://www.tuckerrice.net/index.htm > > > -- Clicking through to Captain Al's website removes any doubt that this Piet will get built. Impressive... http://www.captalrice.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309668#309668 ________________________________________________________________________________
Date: Aug 21, 2010
Subject: Front fitting access, center section
I was planning on ply wood sheeting my center section front, up to the firs t spar both top and bottom. This would encase the front wing attach fitting s with no access. (bolt check, corrosion, etc.)- How did you guys sheet/c over that forward area? Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 21, 2010
Jack, I think Jack T meant a Cub-type gauge with the wire sticking out of the fue l cap, on the top of the wing tank. I think Bill Rewey may have done that with his, and I think Kevin has that setup on his Piet. Isn't that what the Hello Kitty mirror is for, Kevin? : ) Ryan On Sat, Aug 21, 2010 at 4:26 PM, Jack Phillips wrot e: > I=92ve got one. Why would you have trouble seeing it? > > > See it hanging down in front of the fornt cockpit windshield? > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Jack > *Sent:* Saturday, August 21, 2010 4:21 PM > > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: Cork Fuel Guage > > > Has anyone flying used a cork/rod type gauge successfully in their center > section tank? Was wondering if you can see it while strapped in. > > Thanks, > > Jack > > DSM > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > ________________________________________________________________________________
Date: Aug 21, 2010
Jack as Ryan said I meant on top of the c-section Jack Textor Sent from my iPhone On Aug 21, 2010, at 4:26 PM, "Jack Phillips" wrote: > I=99ve got one. Why would you have trouble seeing it? > > > > > See it hanging down in front of the fornt cockpit windshield? > > Jack Phillips > NX899JP > Raleigh, NC > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Jack > Sent: Saturday, August 21, 2010 4:21 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Cork Fuel Guage > > Has anyone flying used a cork/rod type gauge successfully in their center s ection tank? Was wondering if you can see it while strapped in. > > Thanks, > > Jack > > DSM > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > ________________________________________________________________________________
Date: Aug 21, 2010
Wow! Thanks for the support and advice from everyone. Captain (my grandpa) said that we can stop by Brodhead on the way to Oshkosh next year. Should be very cool to see all the Pietenpols there. Starting on the fuselage and metal brackets when our order comes in from Aircraft Spruce. Tucker -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309683#309683 ________________________________________________________________________________
Date: Aug 21, 2010
Just the top. No need to do the bottom. Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Saturday, August 21, 2010 2:31 PM Subject: Pietenpol-List: Front fitting access, center section I was planning on ply wood sheeting my center section front, up to the first spar both top and bottom. This would encase the front wing attach fittings with no access. (bolt check, corrosion, etc.) How did you guys sheet/cover that forward area? Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 22, 2010
gtche98 wrote: > > dfwplt wrote: > > I have an idea this is one Pietenpol that WILL get finished.... > > > > http://www.tuckerrice.net/index.htm > > > > > > -- > > > Clicking through to Captain Al's website removes any doubt that this Piet will get built. Impressive... > > http://www.captalrice.com/ That's just what I was thinking too. Go get'm Tucker! -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309732#309732 ________________________________________________________________________________
Date: Aug 22, 2010
Jack - I use the wire float gage. I have a small mirror in the cockpit on a lanyard (hello kitty - kids go nuts for it). I fly by time so I don't usually use the mirror, but, I do use it to make sure the gas cap is on before I take off after refuel. I also use it to make sure I've got gas if I'm giving rides and am not keeping track of time. I drilled a hole in the cap and epoxied in a brass male-to-male hose connector from the hardware store to serve as a guide for the wire gage, thus avoiding the floppy-wire-problem. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309737#309737 ________________________________________________________________________________
Subject: Center Section Cork Fuel Gauge
Date: Aug 22, 2010
OK, now I'm confused... How do you install a wire/float gauge in a center section tank? I didn't know that was possible. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Sunday, August 22, 2010 7:29 AM Subject: Pietenpol-List: Re: Cork Fuel Guage Jack - I use the wire float gage. I have a small mirror in the cockpit on a lanyard (hello kitty - kids go nuts for it). I fly by time so I don't usually use the mirror, but, I do use it to make sure the gas cap is on before I take off after refuel. I also use it to make sure I've got gas if I'm giving rides and am not keeping track of time. I drilled a hole in the cap and epoxied in a brass male-to-male hose connector from the hardware store to serve as a guide for the wire gage, thus avoiding the floppy-wire-problem. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309737#309737 ________________________________________________________________________________
Date: Aug 22, 2010
It looks like you are located in South Florida. If you ever get up to Central Florida, I can show you my Pietenpol. Its located at X21 in Titusville. Ben Charvet ________________________________________________________________________________
Date: Aug 22, 2010
Welcome to the list Tucker. Sounds like you have a lot of will and a lot of support at home. If I can assist in anyway, please feel free to contact me . Michael Perez Karetaker Aero www.karetakeraero.com - ________________________________________________________________________________
Subject: Re: Center Section Cork Fuel Gauge
Date: Aug 22, 2010
I drilled a hole in the cap and run the float wire through that. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309761#309761 ________________________________________________________________________________
Date: Aug 22, 2010
I guess I thought that that would suck fuel out, being on the low pressure side...guess I was wrong!? Gary Boothe ------Original Message------ From: Kevin Purtee Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Center Section Cork Fuel Gauge Sent: Aug 22, 2010 10:15 AM I drilled a hole in the cap and run the float wire through that. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309761#309761 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Aug 22, 2010
Gary - Forgot to mention in my e-mail: if the tank's full and the runway's bumpy the fuel will spew a bit out the float guide during the ground roll. If the ground's smooth or the tank's not completely full it doesn't happen. I don't think there's siphoning due to pressure differential. The fit between the float guide and the wire is pretty tight. There's not a lot of room for liquid to get sucked out. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309792#309792 ________________________________________________________________________________
Date: Aug 22, 2010
Thanks Dan, Sorry we missed it, but our schedules just didn't work out. We do have a line on a corvair motor. We are supposed to go over and help my buddie's Dad tear down an old corvair, and he said we could have the engine. So I suppose that's the next step. We are also still trying to decide what our best option for wood is. We could save money if we buy from this place in Madison. But we could save time, if we order from Aircraft Spruce. Seeing how it's already pre selected wood. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309795#309795 ________________________________________________________________________________
Date: Aug 22, 2010
Or you could put the sight glass out the bottom of the tank,,, Easy to see. This one is similar to mine. -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309796#309796 Attachments: http://forums.matronics.com//files/fuel_gauge_164.jpg ________________________________________________________________________________
Date: Aug 22, 2010
Thanks for the offer Mr. Charvet. I'll start bugging Captain for a trip to Titusville. I have time in a J-3, Lake Amphib, C-172, and Remos G-3 but I can't log dual time until I'm 14. Captain says that learning to fly in a taildragger is the best way to learn to fly properly. A ride in your Piet would be a blast. I'll let you know when we can get up there. Thanks again. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309807#309807 ________________________________________________________________________________
Subject: corvair engine comes alive
Date: Aug 22, 2010
This weekend I was able to get my engine running. We ran it several times over the two days. This run was done at the end of today just to get a quick video to share with you guys. Mike Groah Tulare CA Sent from my iPhone On Aug 22, 2010, at 5:02 PM, "Tucker" wrote: > > Thanks for the offer Mr. Charvet. I'll start bugging Captain for a trip to Titusville. I have time in a J-3, Lake Amphib, C-172, and Remos G-3 but I can't log dual time until I'm 14. Captain says that learning to fly in a taildragger is the best way to learn to fly properly. A ride in your Piet would be a blast. I'll let you know when we can get up there. Thanks again. > > -------- > Tucker > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309807#309807 > > > > > > > > > > ________________________________________________________________________________
Subject: Corvair engine run
Date: Aug 22, 2010
Ok. I forgot the link. Here it is http://www.youtube.com/watch?v=LsoECVtN7p4&feature=youtube_gdata_player Mike Groah Tulare CA Sent from my iPhone On Aug 22, 2010, at 5:02 PM, "Tucker" wrote: > > Thanks for the offer Mr. Charvet. I'll start bugging Captain for a trip t o Titusville. I have time in a J-3, Lake Amphib, C-172, and Remos G-3 but I can't log dual time until I'm 14. Captain says that learning to fly in a t aildragger is the best way to learn to fly properly. A ride in your Piet wo uld be a blast. I'll let you know when we can get up there. Thanks again. > > -------- > Tucker > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309807#309807 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Aug 23, 2010
Subject: Re: Corvair engine run
Hi Mike and Vic, Great job and it sounds and looks like it is running fine. Congratulations. Jim B. ----- Original Message ----- From: "Michael Groah" <dskogrover(at)yahoo.com> Sent: Sunday, August 22, 2010 5:30:00 PM Subject: Pietenpol-List: Corvair engine run Ok. I forgot the link. Here it is http://www.youtube.com/watch?v=LsoECVtN7p4&feature=youtube_gdata_player Mike Groah Tulare CA Sent from my iPhone On Aug 22, 2010, at 5:02 PM, "Tucker" < Tucker(at)tuckerrice.net > wrote: Thanks for the offer Mr. Charvet. =C2-I'll start bugging Captain for a tr ip to Titusville. =C2-I have time in a J-3, Lake Amphib, C-172, and Remos G-3 but I can't log dual time until I'm 14. =C2-Captain says that learni ng to fly in a taildragger is the best way to learn to fly properly. =C2- A ride in your Piet would be a blast. =C2-I'll let you know when we can g et up there. =C2-Thanks again. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309807#309807 http://www.matronics.com/Navigat============== =============;=C2-=C2-=C2-=C2-=C2-=C2 -=C2-- MATRONICS WEB FORUMS - http://forums.mat======== ===================p;=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-t; http://www.m atronics.com/contribution == ________________________________________________________________________________
Date: Aug 22, 2010
Oh thats sweet! Made me go right out and glue some more of my rudder! What carb are you using? Thanks for sharing! Scotty -------- Scotty Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309818#309818 ________________________________________________________________________________
Date: Aug 22, 2010
That's outstanding! Congrats..... -----Original Message----- From: Michael Groah Sent: Aug 22, 2010 7:30 PM Subject: Pietenpol-List: Corvair engine run Ok. I forgot the link. Here it is http://www.youtube.com/watch?v=LsoECVtN7p4&feature=youtube_gdata_player Mike Groah Tulare CA Sent from my iPhone On Aug 22, 2010, at 5:02 PM, "Tucker" wrote: Thanks for the offer Mr. Charvet. I'll start bugging Captain for a trip to Titusville. I have time in a J-3, Lake Amphib, C-172, and Remos G-3 but I can't log dual time until I'm 14. Captain says that learning to fly in a taildragger is the best way to learn to fly properly. A ride in your Piet would be a blast. I'll let you know when we can get up there. Thanks again. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309807#309807 http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigat====================================================; - MATRONICS WEB FORUMS -http://forums.mat====================================================p; t; http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 22, 2010
Subject: Fw: Wood Steamer
- Pieter's - I build this steamer and just though-I would share it with the group. I u sed a Wagner power wall paper steamer and a 36" double wall insulated vent pipe found at the local hardware store. I cut one of the steamer plates apa rt and salvaged the threaded end for the connection into the vent pipe. I d ropped the threaded salvage end into the pipe where I made an entry hole bi g enough to take the threads. I then attached the 7 foot hose that comes wi th the steamer. I used a insert cap for the top end and drilled 5 holes lar ge enough to take the cap strip. Plugged the bottom end with a round piece of wood and then added flashing to give it stability. A few screws to hole everything together and a base piece of wood to keep it upright and stable. The wagner power steamer hold up to 1 gallon of water. - It works fantastic!-A test run-was-done. Results:-10 minutes from s tart to bending jig.So far it steams-very-fast! I covered the top with a rag just to keep the steam in and made the rag untouchable! - This steamer my seem a bit much but-I plan on doing many other things tha t require bending wood. - KMHeide Hawley, MN - - =0A=0A=0A ________________________________________________________________________________
Date: Aug 22, 2010
Thanks everyone. And for those that didn't see it yet I reloaded it on YouTube so now it has it's preview pic and should work better. I also trimmed the length a little. http://www.youtube.com/watch?v=I_e_ZFUjSxs&feature=youtube_gdata_player Mike Groah Sent from my iPhone On Aug 22, 2010, at 6:06 PM, Jim Markle wrote: > > That's outstanding! Congrats..... > > > -----Original Message----- > From: Michael Groah > Sent: Aug 22, 2010 7:30 PM > To: "pietenpol-list(at)matronics.com" > Subject: Pietenpol-List: Corvair engine run > > > Ok. I forgot the link. Here it is > > > http://www.youtube.com/watch?v=LsoECVtN7p4&feature=youtube_gdata_player > > > Mike Groah > Tulare CA > > > > > Sent from my iPhone > > On Aug 22, 2010, at 5:02 PM, "Tucker" wrote: > > > > > > Thanks for the offer Mr. Charvet. I'll start bugging Captain for a trip to Titusville. I have time in a J-3, Lake Amphib, C-172, and Remos G-3 but I can't log dual time until I'm 14. Captain says that learning to fly in a taildragger is the best way to learn to fly properly. A ride in your Piet would be a blast. I'll let you know when we can get up there. Thanks again. > > -------- > Tucker > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309807#309807 > > > > > http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigat====================================================; - MATRONICS WEB FORUMS -http://forums.mat====================================================p; t; http://www.matronics.com/contribution > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 22, 2010
Regarding your potential Corvair core....you will want to check the engine code to determine if the engine is suitable for conversion for aircraft use. Ideally you want to find a 1965-69 95 to 110 HP engine that does not have "smog" heads. You can use every part of an engine that has smog heads, except for the cylinder heads. You would need to find a good set of non-smog heads. Pat Panzera has posted a list of engines codes at his Corvaircraft site: http://www.angelfire.com/ca4/CorvAIRCRAFT/VinSuffix.html <http://www.angelfire.com/ca4/CorvAIRCRAFT/VinSuffix.html>As noted in the chart, here are the various codes you can use: 65-69 95 to 110, usable heads: RA, RD, RE, RF, RG, RX, RH, RJ, RK 65-69 95 to 110, heads are not usable: RS, RU, RV, RW, AC, AD You can also use certain 1964 model years engines, if they have a crankshaft with an 8409 number cast into it. If you find an engine with the following codes you will need to disassemble it to the point of removing the top cover so you can inspect the number on the crank. If it is any number besides 8409 then the engine is no good for aircraft conversion: YC, YN, YL, YM, Z, ZH, ZF, ZD, ZG There are additional codes for 140 HP engines that can be converted for use, but you have to find different cylinder heads and either get a different crank or swap out the retarded crank gear that comes on those cranks. There are issues with swapping cylinder heads from '64 to '65-'69 engines (but it can be done), and there are also head casting numbers that will help determine if the heads are suitable for use: http://www.angelfire.com/ca4/CorvAIRCRAFT/HeadNumbers.html <http://www.angelfire.com/ca4/CorvAIRCRAFT/HeadNumbers.html>All of that info and more is in William Wynne's conversion manual, which you should get a copy of if you intend to use a Corvair. You will also need the "Green Manual": http://www.themotorbookstore.com/1965corvair.html You can get reprints, or find originals on eBay in the same price range. The easiest thing to do would be to find an engine with a code that means it is a 1965-69 95-110HP engine with usable heads. Go ahead and take any engine that is free...if nothing else it will give you practice tearing one down, and there are miscellaneous parts here and there that are usable. Good luck, Ryan On Sun, Aug 22, 2010 at 5:46 PM, j_dunavin wrote: > > Thanks Dan, > Sorry we missed it, but our schedules just didn't work out. > > We do have a line on a corvair motor. We are supposed to go over and help > my buddie's Dad tear down an old corvair, and he said we could have the > engine. So I suppose that's the next step. > > We are also still trying to decide what our best option for wood is. > We could save money if we buy from this place in Madison. > But we could save time, if we order from Aircraft Spruce. Seeing how it's > already pre selected wood. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309795#309795 > > ________________________________________________________________________________
Subject: re: Wood steamer
Date: Aug 23, 2010
Hi Ken, That steamer is GREAT! You should offer those for sale. I wonder if there is anything out there for sale close to this? Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Aug 23, 2010
Subject: Re: re: Wood steamer
Thanks Dan.... - I can say this....it works fantastic and man can it steam in 10 minutes! It cost about $60.00 and was worth every penny so far! - Ken H Hawley, MN - --- On Mon, 8/23/10, helspersew(at)aol.com wrote: From: helspersew(at)aol.com <helspersew(at)aol.com> Subject: Pietenpol-List: re: Wood steamer Date: Monday, August 23, 2010, 6:40 AM Hi Ken, - That steamer is GREAT! You should offer those for sale. I wonder if there i s anything out there for sale close to this? - Dan Helsper Poplar Grove, IL. =0A=0A=0A ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Aug 23, 2010
Subject: great photo web site to 80th Pietenpol Anniversary gathering
a Bhead and OSH I had forgotten about this site. Wow are there ever some nice photos of all the Piets from 2009 here thanks to David Brant who took the photos and posted them. Thanks David ! http://public.fotki.com/dwbrant/fancies-of-flight/pietenpol-80th-anni/ Mike C. ________________________________________________________________________________
Date: Aug 23, 2010
>>> "Tucker" Tucker(at)tuckerrice.net> 8/20/2010 4:32 PM >> ( mailto:Tucker@tu ckerrice.net ) I just joined the list, I'm 13 and building a Pietenpol. My grandfather built a Skybolt and RV-9A and is helping me. Tucker: Seeing your post is a real joy to me. I have been wanting to fly since I was a kid but I was actually 54 years old before I had the chance to get my pilot's license. Now I am building my own Air Camper with occasional help from my grandson and granddaughter ( 7 & 5 years old) and I can't wait for that first time I get to fly with them in my own plane. I hope they get as excited about it as you seem to be! Be sure to let your grandfather (Captain) know just how much you appreciate him! In my case the help usually goes the other way though. Both my boys work for Burt Rutan out in Mojave, CA and are currently on the SpaceShipTwo project. When they get to come home for a visit they always come out to the shop and critique my work and usually take back a part or two that they want to redo or help me out with. So when SpaceShip Zero.One is completed it will be the work of three generations of airplane lovers. If you're ever out Kansas way, give a shout and I'll introduce you to some of our beautiful Kansas scenery. Tom Stinemetze McPherson, KS N328X ________________________________________________________________________________
Subject: Builder List
Date: Aug 23, 2010
I was curious if anyone has a recent list of builders. My airplane is has been slow to start this summer with the Texas heat, but I want to keep up my enthusiasm to get my bird flying. I do travel quite a bit around the country and would love to see some "Piets in progress". If anyone has a list, could you please e-mail it to me or post it here. Thanks! Curtis Merdan Flower Mound, TX Tail Feathers ruffled Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309886#309886 ________________________________________________________________________________
Date: Aug 23, 2010
They have those at harbor freight for much less, I think they were $24.99 you must have missed the sale! Don not archive In a message dated 8/23/2010 8:23:47 A.M. Eastern Daylight Time, kmheidecpo(at)yahoo.com writes: Thanks Dan.... I can say this....it works fantastic and man can it steam in 10 minutes! It cost about $60.00 and was worth every penny so far! Ken H Hawley, MN --- On Mon, 8/23/10, helspersew(at)aol.com wrote: From: helspersew(at)aol.com <helspersew(at)aol.com> Subject: Pietenpol-List: re: Wood steamer Date: Monday, August 23, 2010, 6:40 AM Hi Ken, That steamer is GREAT! You should offer those for sale. I wonder if there is anything out there for sale close to this? Dan Helsper Poplar Grove, IL. " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Pietenpol-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 23, 2010
Tucker, Congratulations on choosing to build a Pietenpol. It's a great little airplane. The best I've ever flown. I'm sure there are better planes, but probably not nearly as economical to fly. Another builder, Ty Daniels, started building his Pietenpol when he was in high school and finished it shortly after graduating. He built a fantastic plane that is one of the lightest Piets I know of: 640lbs with 8 gallons of fuel. It climbs like a rocket and looks really cool: http://www.westcoastpiet.com/new_page_54.htm Stick to the plans, build a little bit every day, and have fun! Good luck! Dan On 08/20/2010 04:32 PM, Tucker wrote: > --> Pietenpol-List message posted by: "Tucker" > > I just joined the list, I'm 13 and building a Pietenpol. My grandfather built a Skybolt and RV-9A and is helping me. Been looking at the Pietenpols at Oshkosh for the past 5 years and when we got home this year, we decided to go for it. I got the plans from Mr. Pietenpol and just got a Corvair engine. We spent yesterday and today tearing it down. I'm really excited about getting started. I need to order Mr. Wynne's Corvair book. Here's a picture. > > -------- > Tucker > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309576#309576 > > > Attachments: > > http://forums.matronics.com//files/img_0007_154.jpg > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Picture attachment sizes (was Fw: Wood Steamer)
Date: Aug 23, 2010
You could try a photo resizer like this one I found at CNET. It will do batch jobs or individual files. It is fairly self-explanatory if you play with it for a minute. http://download.cnet.com/windows/3055-2192_4-10319476.html?tag=pdl-redir -------- Mark Chouinard Finishing up Wings - Working on Center Section Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309896#309896 ________________________________________________________________________________
Subject: Re: Empennage and rib wood questions
Date: Aug 23, 2010
Welcome to the list Tom, you will find tons of help and encouragement here from some very knowledgeable & friendly people on this list. To answer your question, the wood sizes listed in the Aircraft Spruce and Wicks catalogs (and websites) is the actual size as you order it. 1/4"x1/2" capstrip and 1"x1" longeron stock will arrive at your door milled to those actual dimensions. So now you just need to figure out how much wood you need for your first order and get on the phone first thing tomorrow so you can start making airplane parts soon! -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309957#309957 ________________________________________________________________________________
Date: Aug 23, 2010
Curtis, I'm working on a director as we speak. So far the response has been average with 26 responding. If you would like to include your information in the directory, please fill out the attached Word document and return to my home email jack (at) textors.com. Just include the information you wish. I won't plan to post it to my site or any other. After I compile the information, I will make it available via email in some form to all that shared their information. So far those responding include: Rusch, Wilson, Dotson, Markle, Chouinard, Jardine, , Borsuk, Mason, Gow, Stinemetze, Phillips, Howe, Davis, Schomp, Chase, Dever, Cardinal, Perez, Singleton, Morlock, Magnusson, Coxwell, Granos, Zuniga, Perry No matter what the response I will get it out within the next week. Hope this helps Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2112 Sent: Monday, August 23, 2010 9:59 AM Subject: Pietenpol-List: Builder List I was curious if anyone has a recent list of builders. My airplane is has been slow to start this summer with the Texas heat, but I want to keep up my enthusiasm to get my bird flying. I do travel quite a bit around the country and would love to see some "Piets in progress". If anyone has a list, could you please e-mail it to me or post it here. Thanks! Curtis Merdan Flower Mound, TX Tail Feathers ruffled Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309886#309886 ________________________________________________________________________________
Date: Aug 24, 2010
Thanks for your efforts Jack. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com --- On Mon, 8/23/10, Jack wrote: From: Jack <jack(at)textors.com> Subject: RE: Pietenpol-List: Builder List Date: Monday, August 23, 2010, 8:50 PM Curtis, I'm working on a director as we speak.- So far the response has been aver age with 26 responding.- If you would like to include your information in the directory, please fill out the attached Word document and return to my home email jack (at) textors.com.- Just include the information you wish.- I won't plan to post it to my site or any other.- After I compile the information, I will make it available via email in some form to all that shared their information. So far those responding include: Rusch, Wilson, Dotson, Markle, Chouinard, Jardine, , Borsuk, Mason, Gow, Stinemetze, Phillips, Howe, Davis, Schomp, Chase, Dever, Cardinal, Perez, Singleton, Morlock, Magnusson, Coxwell, Granos, Zuniga, Perry No matter what the response I will get it out within the next week. Hope this helps Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2112 Sent: Monday, August 23, 2010 9:59 AM Subject:- Pietenpol-List: Builder List I was curious if anyone has a recent list of builders.- My airplane is ha s been slow to start this summer with the Texas heat, but I want to keep up m y enthusiasm to get my bird flying.- I do travel quite a bit around the country and would love to see some "Piets in progress".- If anyone has a list, could you please e-mail it to me or post it here.- Thanks! Curtis Merdan Flower Mound, TX Tail Feathers ruffled Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309886#309886 ________________________________________________________________________________
Date: Aug 24, 2010
oh ya, that's the place, but they want $20 a board ft. NO WAY! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309973#309973 ________________________________________________________________________________
Date: Aug 24, 2010
I believe S4S means "Sanded 4 Sides" -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309974#309974 ________________________________________________________________________________
Date: Aug 24, 2010
Subject: Re: Builder List
----- Original Message ---- From: Jack <jack(at)textors.com> Sent: Mon, August 23, 2010 8:50:35 PM Subject: RE: Pietenpol-List: Builder List Curtis, I'm working on a director as we speak. So far the response has been average with 26 responding. If you would like to include your information in the directory, please fill out the attached Word document and return to my home email jack (at) textors.com. Just include the information you wish. I won't plan to post it to my site or any other. After I compile the information, I will make it available via email in some form to all that shared their information. So far those responding include: Rusch, Wilson, Dotson, Markle, Chouinard, Jardine, , Borsuk, Mason, Gow, Stinemetze, Phillips, Howe, Davis, Schomp, Chase, Dever, Cardinal, Perez, Singleton, Morlock, Magnusson, Coxwell, Granos, Zuniga, Perry No matter what the response I will get it out within the next week. Hope this helps Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2112 Sent: Monday, August 23, 2010 9:59 AM Subject: Pietenpol-List: Builder List I was curious if anyone has a recent list of builders. My airplane is has been slow to start this summer with the Texas heat, but I want to keep up my enthusiasm to get my bird flying. I do travel quite a bit around the country and would love to see some "Piets in progress". If anyone has a list, could you please e-mail it to me or post it here. Thanks! Curtis Merdan Flower Mound, TX Tail Feathers ruffled Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309886#309886 ________________________________________________________________________________
Date: Aug 24, 2010
Subject: Builders near Dallas
Curtis, Jeff Hill, up in The Colony area, was building two Piets up at Tailwind (I think that's the name of the airport)...excellent craftsman and would be a good one to visit...but he may have finished them by now....he was moving right along and I haven't seen him in several years. I sent him a message to see what's up and will forward whatever I hear back.... jm > >I was curious if anyone has a recent list of builders. My airplane is has >been slow to start this summer with the Texas heat, but I want to keep up my >enthusiasm to get my bird flying. I do travel quite a bit around the >country and would love to see some "Piets in progress". If anyone has a >list, could you please e-mail it to me or post it here. Thanks! > >Curtis Merdan >Flower Mound, TX >Tail Feathers ruffled > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=309886#309886 > > ________________________________________________________________________________
Subject: Re: Builders near Dallas
Date: Aug 24, 2010
Jim, Thanks for checking in on another builder close to me. Next week I'm making a road trip to Austin to see Kevin Purtee and Tim Willis to steal some trade secrets. The Colony is a lot closer and I could see Jeff's planes very easily. Thanks again, Curtis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309986#309986 ________________________________________________________________________________
Date: Aug 24, 2010
From: "allen(at)allenrice.net" <allen(at)allenrice.net>
------------Boundary-00=_Q6WNLVC0000000000000-- ________________________________________________________________________________
Subject: Looking for a piet
From: "taildragger21" <taildragger22003(at)yahoo.com>
Date: Aug 24, 2010
Hello guys.. First post here.I am trying to get back into flying after a 7 year slump.. I have totally fell in love with the nostalgia, simplicity, afforadbillity of the air camper. My BIG problem is I dont have much time at all to build.. Does anyone have a flying one or a project for sale?? Eather way could get me there faster.. Regards, chad. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310004#310004 ________________________________________________________________________________
Date: Aug 24, 2010
Subject: Re: Looking for a piet
Hi Chad, There are 2 genuine Piets for sale on barnstormers.com - one's powered by a Ford Model B and the other is powered by a Ford Model A. There's also a GN-1 on there that is a project plane - the engine would have to be torn down and magnafluxed (one or two prop strikes occurred in the recent past) as well as a bunch of fuselage work needs to be done. And there's another one that is called a Pietenpol, but it just... ain't. I think there's another Ford Model A powered one in DeKalb, IL that might still be for sale. Where are you located? Dan On 08/24/2010 10:58 AM, taildragger21 wrote: > --> Pietenpol-List message posted by: "taildragger21" > > Hello guys.. First post here.I am trying to get back into flying after a 7 year slump.. I have totally fell in love with the nostalgia, simplicity, afforadbillity of the air camper. My BIG problem is I dont have much time at all to build.. Does anyone have a flying one or a project for sale?? Eather way could get me there faster.. Regards, chad. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310004#310004 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Aug 24, 2010
.used to be a sky scout on there too. I kinda had my eye on it, but never could find the extra dough to buy it. It was owned by a fellow in Florida I think named Brian Kraut (ya'll correct me) It was a completed plane, that I think had some issues with the 2.2 Chrysler engine installed. Asking price was like $3700 I think. Boyce ________________________________________________________________________________
Date: Aug 24, 2010
Thanks for the replies guys. I am in ky.. I saw those on barnstormers. I have searched the net high and low.. I found a "project" for 6k that had a cont a65 on it but has been setting unused for at least 10 years.. I personally am scared of those being more trouble and money than just building one.. I would also rather have an a65-0200 rather than the model a engine.. Saw the bumped up one on barnstormers. Man that guy has had bad luck.. [Laughing] Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310010#310010 ________________________________________________________________________________
Date: Aug 24, 2010
This one might still be for sale. New ceconite/top overhaul '07. Asking 10.5k last time I checked. Call him and see if it's not sold yet.. Henry 740-269-1194 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310011#310011 Attachments: http://forums.matronics.com//files/n8846_451.jpg ________________________________________________________________________________
Date: Aug 24, 2010
Also an unfinished project would be ideal if not a flying one.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310012#310012 ________________________________________________________________________________
Date: Aug 24, 2010
Wow thanks!! Thats nice!! I will call and see later. Thanks, chad. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310013#310013 ________________________________________________________________________________
Date: Aug 24, 2010
For what it's worth, that's a GN-1 with a... a... what the heck engine is that?!?? The exhaust ports are on top of the cylinders. Maybe it's a GPU. Looks like the builder got tired and didn't bother to put the wingtip bows on. But, he did a good job on the paint. On 08/24/2010 12:14 PM, TriScout wrote: > --> Pietenpol-List message posted by: "TriScout" > > This one might still be for sale. New ceconite/top overhaul '07. Asking 10.5k last time I checked. Call him and see if it's not sold yet.. Henry 740-269-1194 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310011#310011 > > > Attachments: > > http://forums.matronics.com//files/n8846_451.jpg > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Aug 24, 2010
Is that harry clever field in New Philadelphia Ohio??? - Shad For what it's worth, that's a GN-1 with a... a... what the heck engine is that?!??- The exhaust ports are on top of the cylinders.- Maybe it's a GPU.- Looks like the builder got tired and didn't bother to put the wingtip bows on.- But, he did a good job on the paint. On 08/24/2010 12:14 PM, TriScout wrote: > -->- Pietenpol-List message posted by: "TriScout" > > This one might still be for sale. New ceconite/top overhaul '07. Asking 1 0.5k last time I checked. Call him and see if it's not sold yet.. Henry 740 -269-1194 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310011#310011 > > > Attachments: > > http://forums.matronics.com//files/n8846_451.jpg > > -- Dan Yocum Fermilab- 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." le, List Admin. =0A=0A=0A ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Aug 24, 2010
If that is clever field, it's a very old picture, the hangar has not looked like that for at least 10 years, when I moved up here. Maybe he managed to mount the engine upside down somehow? :) Kip Gardner On Aug 24, 2010, at 2:10 PM, shad bell wrote: > Is that harry clever field in New Philadelphia Ohio??? :) > > Shad > > > For what it's worth, that's a GN-1 with a... a... what the heck engine > is that?!?? The exhaust ports are on top of the cylinders. Maybe it's > a GPU. Looks like the builder got tired and didn't bother to put the > wingtip bows on. But, he did a good job on the paint. > > > On 08/24/2010 12:14 PM, TriScout wrote: > > --> Pietenpol-List message posted by: "TriScout" > > > > This one might still be for sale. New ceconite/top overhaul '07. Asking 10.5k last time I checked. Call him and see if it's not sold yet.. Henry 740-269-1194 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=310011#310011 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/n8846_451.jpg > > > > > > > > > > > > > > > > -- > Dan Yocum > Fermilab 630.840.6509 > yocum@fnal.gov, http://fermigrid.fnal.gov > "I fly because it releases my mind from the t - The Pietenpol-List Email ww.matronics.com/Navigator?Pietenpol-List" target=_blank>http://www.matro/forums.matronics.com/" target=_blank>http://forums.matronics.com > Thank you for your generous nbsp; -Matt Dralle, List Admin. > > > > > > > ________________________________________________________________________________
Date: Aug 24, 2010
Subject: Re: Looking for a piet, # 2 is getting close
I think it is an old A-50 Cont.- I believe the OLD cont's had a top exaus t.- But I ain't sure, besides I am flying a car engine what do I know. ha ha .- I think I saw an old taylorcraft, or chief one time years ago, and it had a top exaust continental.- By the way, number 2 is probably going to be here within the week, odds must be 80 to 1 that I make Lee Bottm's F ly in.- If only Jake would sit still, and had some tiny ear muffs........ maybe he could sit on my lap for 2 hrs, maby the car seat will strap in to the front cockpit........have you ever been in a turkish prison?..... - - Shad=0A=0A=0A ________________________________________________________________________________
Date: Aug 24, 2010
You are close, Adrian... S4S means Surfaced 4 Sides. The surfacing is normally done with planers and edgers, not sanding machines. Planers and edgers use cutting blades which provide a suitable surface finish and last a lot longer in a production setting than abrasives would, and the wood does not need to be as smooth as if it were sanded. Interior grade and aircraft grade plywood ARE sanded, though. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310024#310024 ________________________________________________________________________________
Date: Aug 24, 2010
I think some engine guru told me the "exhaust ontop" version is actually a Cont A-50(?)..which is basically an A-65, but w/exhaust ports ontop. I was going to go up and buy this one, until I bought the GN-1 in FL w/out an engine. I thought it'd be fun for me to have somewhat of a project (but not too much of a project), rather than buying a flying one. It is in the for sale section in back of April BPA mag. Super nice older fella that owns it. He doesn't do e-mail, which is probably why he still has it. He did "snail-mail" me some pic's of it and it has two doors on right side. Restored '07.. yes, that is when he flew it to New Phila Arprt for b-fast he told me. he keeps it at his own grass strip nearby(uncharted)... I last spoke to him about 5 weeks ago.. I would think that he still has it. He was axing $10.5k .. maybe you can talk him down 6 or 8k.. who knows.. Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310031#310031 ________________________________________________________________________________
Date: Aug 24, 2010
I'm settled in a little Texas hick town on East side of Dallas called "Garland"(like judy).. well, I guess it's more like a Big hick town(the 'one headlight capital' of the world). I just acquired a GN-1 sans motor, but will have one in a couple of weeks. It isn't quite flyable yet, but ur welcome to come "check out" in it when I get her airborn... Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310034#310034 ________________________________________________________________________________
Date: Aug 24, 2010
does it bother anybody that this thread has been going on for a week with the subject line misspelled? Ben On 8/24/2010 7:43 AM, j_dunavin wrote: > --> Pietenpol-List message posted by: "j_dunavin" > > oh ya, that's the place, but they want $20 a board ft. NO WAY! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309973#309973 > > ________________________________________________________________________________
Date: Aug 24, 2010
Subject: Re: Ben's Piet is Neat!
Yes, thank you for finally commenting on it Ben. By the way I was looking a t the pictures of your Piet on Chris' West Coast Piet site today; still thi nk its a good looking plane. Jim ----- Original Message ----- From: "Ben Charvet" <bencharvet(at)gmail.com> Sent: Tuesday, August 24, 2010 3:15:33 PM Subject: Re: Pietenpol-List: Re: Plnas came in !! =C2-=C2-does it bother anybody that this thread has been going on for a week with the subject line misspelled? Ben On 8/24/2010 7:43 AM, j_dunavin wrote: > --> =C2-Pietenpol-List message posted by: "j_dunavin" > > oh ya, that's the place, but they want $20 a board ft. =C2-NO WAY! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=309973#309973 > > > > > > > > > > > =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Aug 24, 2010
Thanks for your reply. It's good information to have and I'll be adding up the lengths of wood for my order which will be placed tomorrow. It's a pretty exciting process, right from the beginning. Thanks again for your help. I'll accept any other advice you might have. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310042#310042 ________________________________________________________________________________
Date: Aug 24, 2010
We are up to 48, thanks all! Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Monday, August 23, 2010 7:51 PM Subject: RE: Pietenpol-List: Builder List Curtis, I'm working on a director as we speak. So far the response has been average with 26 responding. If you would like to include your information in the directory, please fill out the attached Word document and return to my home email jack (at) textors.com. Just include the information you wish. I won't plan to post it to my site or any other. After I compile the information, I will make it available via email in some form to all that shared their information. So far those responding include: Rusch, Wilson, Dotson, Markle, Chouinard, Jardine, , Borsuk, Mason, Gow, Stinemetze, Phillips, Howe, Davis, Schomp, Chase, Dever, Cardinal, Perez, Singleton, Morlock, Magnusson, Coxwell, Granos, Zuniga, Perry No matter what the response I will get it out within the next week. Hope this helps Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2112 Sent: Monday, August 23, 2010 9:59 AM Subject: Pietenpol-List: Builder List I was curious if anyone has a recent list of builders. My airplane is has been slow to start this summer with the Texas heat, but I want to keep up my enthusiasm to get my bird flying. I do travel quite a bit around the country and would love to see some "Piets in progress". If anyone has a list, could you please e-mail it to me or post it here. Thanks! Curtis Merdan Flower Mound, TX Tail Feathers ruffled Read this topic online here: http://forums.matronics.com/viewtopic.php?p=309886#309886 ________________________________________________________________________________
Date: Aug 24, 2010
[Laughing] hahaha ya I noticed that the other day, but no one had said anything so i just left it alone. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310061#310061 ________________________________________________________________________________
Date: Aug 25, 2010
Subject: plnas came in
I've been wincing at the "plnas", too but there are so many posts with misspellings in them on this list that I've become accustomed to it. My English teacher Mother would be appalled. Seems like the most mis-spelled word is HANGAR. It's typically posted as HANGER which is something you hang something on, not a garage with an airplane in it. I've also noticed another strange thing on the list; some people misspell PIETENPOL and put GN-1 instead???? Maybe it's a cryptic abbreviation from Mr. Pietenpol that I don't know about. Oh, well. Back to my new high tech, super powerful almost finished power-plant! (Working on the compressor section now.) Larry W. I drive a hybrid. It burns rubber and gasoline! ________________________________________________________________________________
Date: Aug 25, 2010
Subject: Re: plnas came in
I have been wondering what "plnas" was in these emails, I thought it was the name of some exotic aircraft. As far as misspellings go I am guilty of spelling "Brodhead" as "Broadhead" several times. rick On Wed, Aug 25, 2010 at 6:04 AM, Lawrence Williams wrote: > I've been wincing at the "plnas", too but there are so many posts with > misspellings in them on this list that I've become accustomed to it. My > English teacher Mother would be appalled. > Seems like the most mis-spelled word is HANGAR. It's typically posted as > HANGER which is something you hang something on, not a garage with an > airplane in it. > > I've also noticed another strange thing on the list; some people misspell > PIETENPOL and put GN-1 instead???? Maybe it's a cryptic abbreviation from > Mr. Pietenpol that I don't know about. > > Oh, well. Back to my new high tech, super powerful almost finished > power-plant! (Working on the compressor section now.) > > Larry W. > > I drive a hybrid. It burns rubber and gasoline! > > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Aug 25, 2010
Sheesh! And I was enjoying the humor. -------- Al Rice Skybolt 260 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310129#310129 ________________________________________________________________________________
Date: Aug 25, 2010
Thats okay Al, there will be many more funny/mispelled words to partake I'm sure. Jim B. ----- Original Message ----- From: "AlRice" <Allen(at)allenrice.net> Sent: Wednesday, August 25, 2010 2:31:38 PM Subject: Pietenpol-List: Re: Plnas came in !! Sheesh! =C2-And I was enjoying the humor. -------- Al Rice Skybolt 260 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310129#310129 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: GN-1
Date: Aug 25, 2010
Got an engine.. yippie! 'Don's dream Machines' out in GA.. is overhauling an A65-8 for my GN-1 and will be running her on a stand in next day or so. Very cheap/reasonable. I'm glad, as the one that the previous owner took off the GN-1 airframe that I bought was a -8. Now .. he did mention that he put the bigger piston pins(but not the 75 pistons)drilled something(rod's), etc, etc... in the event that I convert it to 75hp later. He thinks it's safe to run at higher rpm by getting smaller prop as an "experimental" if I desire to do so, but me thinks me wants to play it safe and get a 72x42pitch. Any thoughts on that...best prop?... especially from GN-1(w/A65) folks? I would really like a wood prop... Ler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310132#310132 ________________________________________________________________________________
Subject: Cap strip length question
Date: Aug 25, 2010
I'm going to place an order for 1/4 x 1/2 cap strips from ACS. Will ordering them cut to 60" long leave me enough length for the rib top cap strips? Seems like there won't be a lot of extra if I order them at that length. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310134#310134 ________________________________________________________________________________
Date: Aug 25, 2010
Subject: Re: Cap strip length question
The wing chord is 60 inches; you will need more than 60 inches in cap strip length. Jim B. ----- Original Message ----- From: "JGriff" <jgriffith19(at)comcast.net> Sent: Wednesday, August 25, 2010 3:26:12 PM Subject: Pietenpol-List: Cap strip length question I'm going to place an order for 1/4 x 1/2 cap strips from ACS. Will orderin g them cut to 60" long leave me enough length for the rib top cap strips? S eems like there won't be a lot of extra if I order them at that length. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310134#310134 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: GN-1
Date: Aug 25, 2010
The quicker you get the plane done the quicker we can meet for lunch somewhere between dallas and austin. I'm just sayin... :) -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310142#310142 ________________________________________________________________________________
Date: Aug 25, 2010
Subject: Re: GN-1
I have had very good, very fair service and prices from Don. In fact, one time his bill was so low that when he told me the amount over the phone, I thought he had missed a decimal place! Literally ten times cheaper than what I had been quoted by others. On other things he's not so inexpensive, but he's always at least competitive. As to prop size, did Don know that this is going on a VERY high-drag plane? As the list knows, my very limitede experience is that you're better off with a long prop with less pitch versus the other way around. Don tends to like to make things go fast and faster. He may not appreciate our type of flying. Not casting aspersions, just saying that there's horses for courses. > >Got an engine.. yippie! 'Don's dream Machines' out in GA.. is >overhauling an A65-8 for my GN-1 and will be running her on a stand >in next day or so. Very cheap/reasonable. I'm glad, as the one that >the previous owner took off the GN-1 airframe that I bought was a -8. > >Now .. he did mention that he put the bigger piston pins(but not the >75 pistons)drilled something(rod's), etc, etc... in the event that I >convert it to 75hp later. He thinks it's safe to run at higher rpm >by getting smaller prop as an "experimental" if I desire to do so, >but me thinks me wants to play it safe and get a 72x42pitch. Any >thoughts on that...best prop?... especially from GN-1(w/A65) folks? >I would really like a wood prop... > >Ler > > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Aug 26, 2010
If you order 100 lengths at 6 foot each you wont be doing too bad. Scotty -------- Scotty Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310171#310171 ________________________________________________________________________________
Date: Aug 26, 2010
My top one measured 60 3/16"..... Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of JGriff Sent: Wednesday, August 25, 2010 5:26 PM Subject: Pietenpol-List: Cap strip length question I'm going to place an order for 1/4 x 1/2 cap strips from ACS. Will ordering them cut to 60" long leave me enough length for the rib top cap strips? Seems like there won't be a lot of extra if I order them at that length. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310134#310134 ________________________________________________________________________________
Date: Aug 26, 2010
I'll order them 6 feet. Not sure how I got 60 inches in my head - must be the sixes! :) Thanks for the help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310177#310177 ________________________________________________________________________________
Date: Aug 26, 2010
Subject: Re: GN-1
Probably when he said smaller prop he meant with less pitch. The extra HP in an A-75 is mostly because it turns at 2600 rpm redline, and this is done by using less pitch. I'm running a Sensenich 72X40 on my A-65 and find that to be about perfect. Jack Phillips has the same prop on his Piet. This prop in actually used on the J-3 as a climb prop. Ben Charvet >> >> Now .. he did mention that he put the bigger piston pins(but not the >> 75 pistons)drilled something(rod's), etc, etc... in the event that I >> convert it to 75hp later. He thinks it's safe to run at higher rpm by >> getting smaller prop as an "experimental" if I desire to do so, but >> me thinks me wants to play it safe and get a 72x42pitch. Any thoughts >> on that...best prop?... especially from GN-1(w/A65) folks? I would >> really like a wood prop... >> >> Ler >> >> > > ________________________________________________________________________________
Date: Aug 26, 2010
According to the log book the engine is an A65-3, I think they came on some pre-war Chief's. Ed and I stopped at New Philly on the way back from the Alliance T-Craft fly in to look at this Piet(GN-1) for a friend. The plane has a good general appearance, and paint job. It has steel tube tail feathers. The plane has some issues. The biggest is since it is a Grega the back pit is smaller than a Piet and this one has real thick foam in the seat back. Ed got in the pit and it fit perfect, Ed is 5'3" and 135lbs. The Ailerons are warped and will need at least recovering and maybe remade. One big red flag is the inside of the fuse is painted black, so you can't get a good look at the wood or joints. This plane does have potential, but you need to look at it real close and know it needs some work. Skip ----- Original Message ----- From: Kip and Beth Gardner Sent: 8/24/2010 2:49:40 PM Subject: Re: Pietenpol-List: Re: Looking for a piet If that is clever field, it's a very old picture, the hangar has not looked like that for at least 10 years, when I moved up here. Maybe he managed to mount the engine upside down somehow? :) Kip Gardner On Aug 24, 2010, at 2:10 PM, shad bell wrote: Is that harry clever field in New Philadelphia Ohio??? :) Shad For what it's worth, that's a GN-1 with a... a... what the heck engine is that?!?? The exhaust ports are on top of the cylinders. Maybe it's a GPU. Looks like the builder got tired and didn't bother to put the wingtip bows on. But, he did a good job on the paint. ________________________________________________________________________________
Subject: Continental A65 to A75 (was GN-1)
Date: Aug 26, 2010
Ler wrote: >Don's dream Machines' out in GA.. is overhauling an A65-8 I'll use this as a launching pad to address a previous email about the GN-1 with a Continental that had up exhaust on it. There were three variants of the A50 that had up exhaust: the -1, -2, and -3. Not likely to see many of those around. Most likely it was one of the A65 variants that had up exhaust: the -1, -3, or -6. The -1 had single ignition... not likely to see many of those. The -6 had a starter. If you find one, keep it... they're worth their weight in platinum. Same with the A65-9, down exhaust with starter. Rare. There were also variants of the A75 and A80 with up exhaust, the -3 and -6, but it's most likely that the airplane in the photo has an up exhaust variant of the A65 on it. >he did mention that he put the bigger piston pins The Continental factory A75 actually has *smaller* diameter piston pins than the A65... 0.859", compared to 0.920" for the A65. >(but not the 75 pistons) The A65 and A75 both have 3-ring pistons and are the same bore, Unless it was a very early 4-ring A65 piston. The only differences between the A65 and A75 pistons is the diameter of the wrist pins and the fact that the A75 pistons have a waffle face on the underside to provide better cooling. >drilled something (rod's) Yes, the rods on the A75 have 1/16" holes drilled in the connecting rod caps for better lubrication. >He thinks it's safe to run at higher rpm by getting smaller prop >as an "experimental" if I desire to do so Maybe so. The one other main thing that the A75 has that the A65 doesn't are stellite-faced valves and a larger carb venturi. >me thinks me wants to play it safe and get a 72x42 pitch. Probably the better approach but it sounds like your engine will be most of the way converted to a 75 as an experimental. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: engine downthrust
Date: Aug 26, 2010
Another engine question. The Pietenpol drawing for the Continental engine mount shows zero offset in the port- starboard direction and a downthrust resulting from 9/16" difference between upper and lower mount points. My airplane has a rudder trim tab on it but still pulls to one side so I'm thinking of tweaking the engine thrustline to see if some of that will trim out without doing more to the trimtab. On the downthrust, the engine mount on 41CC was built with only 1/8" difference between upper and lower mount points but I can add downthrust by using washers on the upper mounts. What have you other Air Camper/Continental pilots found with setting up your engine thrust-line? Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Aug 26, 2010
Subject: Maule tail wheel mounting
I have a Maule tail wheel, recently acquired piece and am really not certain how the spring mounting is built and connected to the fuse. Anyone have any fitting or mounting drawings or location information pics or advice they are willing to offer so I can get it mounted properly? I am slowly moving towards getting her up on her wheels and would like to have that phase completed before moving into 2010 and 2011 Buildapalooza in December. Please advise Thanks John ________________________________________________________________________________
Date: Aug 26, 2010
skip.. Thanks for the info! This makes me curious now.. I was about to drive 7 hours one way to look at this.. Pictures always make things look better I guess :( :) .. Should I reconsider driving up?? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310187#310187 ________________________________________________________________________________
Subject: Re: Maule tail wheel mounting
Date: Aug 26, 2010
I'd appreciate the same info for the same reason. Thanks! KIp Gardner On Aug 26, 2010, at 9:00 AM, AMsafetyC(at)aol.com wrote: > I have a Maule tail wheel, recently acquired piece and am really not certain how the spring mounting is built and connected to the fuse. Anyone have any fitting or mounting drawings or location information pics or advice they are willing to offer so I can get it mounted properly? > > I am slowly moving towards getting her up on her wheels and would like to have that phase completed before moving into 2010 and 2011 Buildapalooza in December. > > Please advise > > Thanks > > John > > > ________________________________________________________________________________
Subject: ol-List:off topic - blatant self promotion
Date: Aug 26, 2010
Fellow Piet Listers For those of you who are farmers, I'd like to announce that thanks to a layoff, I've just started a new business, New Prosperity Agricultural Consulting. I specialize in high yield fruit & vegetable production, greenhouse & high tunnel systems, organic certification assistance, soil improvement strategies, produce marketing, and the growing system marketed by my former employer (Filtrexx). I hope to have an independent rep agreement with them by the 1st of the year as well. Web site coming soon, in the meantime, if you are interested in learning more, contact me off list at kipg1957(at)earthlink.net Thanks! Kip Gardner ________________________________________________________________________________
Date: Aug 26, 2010
Subject: Re: Continental A65 to A75 (was GN-1)
This is the 3rd or 4th message I've seen singing the praises of Don's Dream Machines. The first one I read was a few weeks ago on the Flybaby list. A gent over there bought a - now get this - a 97hp A-65. I can hear the astonished gasp from here. Yes, it's an experimental engine at this point. Yes, the owner had to sign a bunch of indemnity paperwork. The upshot is that it's an A-65 case with an O-200 crank, a high torque cam and it redlines at 2575. Here's the email thread: http://groups.yahoo.com/group/flybabylist/message/9713 With a 70-52 McCauley prop his rate of climb is 1000+ fpm on his Flybaby. I reckon it would be similar in a Piet with no passenger. Dan On 08/26/2010 07:50 AM, Oscar Zuniga wrote: > --> Pietenpol-List message posted by: Oscar Zuniga > > > Ler wrote: > >> Don's dream Machines' out in GA.. is overhauling an A65-8 > > I'll use this as a launching pad to address a previous email > about the GN-1 with a Continental that had up exhaust on it. > There were three variants of the A50 that had up exhaust: the > -1, -2, and -3. Not likely to see many of those around. Most > likely it was one of the A65 variants that had up exhaust: the > -1, -3, or -6. The -1 had single ignition... not likely to > see many of those. The -6 had a starter. If you find one, > keep it... they're worth their weight in platinum. Same with > the A65-9, down exhaust with starter. Rare. There were also > variants of the A75 and A80 with up exhaust, the -3 and -6, > but it's most likely that the airplane in the photo has an up > exhaust variant of the A65 on it. > >> he did mention that he put the bigger piston pins > > The Continental factory A75 actually has *smaller* diameter > piston pins than the A65... 0.859", compared to 0.920" for the A65. > >> (but not the 75 pistons) > > The A65 and A75 both have 3-ring pistons and are the same bore, > Unless it was a very early 4-ring A65 piston. The only differences > between the A65 and A75 pistons is the diameter of the wrist > pins and the fact that the A75 pistons have a waffle face on > the underside to provide better cooling. > >> drilled something (rod's) > > Yes, the rods on the A75 have 1/16" holes drilled in the connecting > rod caps for better lubrication. > >> He thinks it's safe to run at higher rpm by getting smaller prop >> as an "experimental" if I desire to do so > > Maybe so. The one other main thing that the A75 has that the A65 > doesn't are stellite-faced valves and a larger carb venturi. > >> me thinks me wants to play it safe and get a 72x42 pitch. > > Probably the better approach but it sounds like your engine will > be most of the way converted to a 75 as an experimental. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Aug 26, 2010
I think this is the standard way to do it. (Mike Cuy's method) http://www.westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/tailspring2.jpg -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310197#310197 ________________________________________________________________________________
Date: Aug 26, 2010
Thanks Chris. Looks like you may be having server issues (or maybe I am?!?) - message came thru 5 times. Kip Gardner On Aug 26, 2010, at 11:33 AM, Catdesigns wrote: > > I think this is the standard way to do it. (Mike Cuy's method) > > http://www.westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/tailspring2.jpg > > -------- > Chris > Sacramento, CA > WestCoastPiet.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310197#310197 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: GN-1
Date: Aug 26, 2010
I'm running a Ed Sterba 72x42 on my A-65 and am getting great performance. 3min. /1000 ft @ 3200rpm and cruise at 80mph at 2000rpm. FYI- Roman Bukolt NX20795 On Aug 26, 2010, at 6:29 AM, Ben Charvet wrote: > > > > Probably when he said smaller prop he meant with less pitch. The > extra HP in an A-75 is mostly because it turns at 2600 rpm redline, > and this is done by using less pitch. I'm running a Sensenich 72X40 > on my A-65 and find that to be about perfect. Jack Phillips has the > same prop on his Piet. This prop in actually used on the J-3 as a > climb prop. > > Ben Charvet >>> >>> Now .. he did mention that he put the bigger piston pins(but not >>> the 75 pistons)drilled something(rod's), etc, etc... in the event >>> that I convert it to 75hp later. He thinks it's safe to run at >>> higher rpm by getting smaller prop as an "experimental" if I >>> desire to do so, but me thinks me wants to play it safe and get a >>> 72x42pitch. Any thoughts on that...best prop?... especially from >>> GN-1(w/A65) folks? I would really like a wood prop... >>> >>> Ler >>> >>> >> >> > > ________________________________________________________________________________
Subject: Re: GN-1
Date: Aug 26, 2010
3200 Roman? Isn't that high? Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Roman Bukolt Sent: Thursday, August 26, 2010 11:49 AM Subject: Re: Pietenpol-List: Re: GN-1 I'm running a Ed Sterba 72x42 on my A-65 and am getting great performance. 3min. /1000 ft @ 3200rpm and cruise at 80mph at 2000rpm. FYI- Roman Bukolt NX20795 On Aug 26, 2010, at 6:29 AM, Ben Charvet wrote: > > > > Probably when he said smaller prop he meant with less pitch. The > extra HP in an A-75 is mostly because it turns at 2600 rpm redline, > and this is done by using less pitch. I'm running a Sensenich 72X40 > on my A-65 and find that to be about perfect. Jack Phillips has the > same prop on his Piet. This prop in actually used on the J-3 as a > climb prop. > > Ben Charvet >>> >>> Now .. he did mention that he put the bigger piston pins(but not >>> the 75 pistons)drilled something(rod's), etc, etc... in the event >>> that I convert it to 75hp later. He thinks it's safe to run at >>> higher rpm by getting smaller prop as an "experimental" if I >>> desire to do so, but me thinks me wants to play it safe and get a >>> 72x42pitch. Any thoughts on that...best prop?... especially from >>> GN-1(w/A65) folks? I would really like a wood prop... >>> >>> Ler >>> >>> >> >> > > ________________________________________________________________________________
Subject: O-235 purchase
Date: Aug 26, 2010
Group, I have been thinking my power plant choices for the Piet and have the opportunity to purchase a mid-time O-235, and wanted to get the advice of others be for I jump or pull out the wallet. A hangar neighbor is going with a larger engine on his plane and said he would sell me his O-235 with 1200hrs SMOH, he said it's a 2000 hr engine so I'd have roughly 800 hrs left. He is asking $3500 OBO, but isn't going to include the starter or the current mags but he has another set of mags he would sell with it. I figured I'd off $2500 and see if he bites, and purchase a new starter and new mags. Any thoughts???? Brian SLC-UT ________________________________________________________________________________
Date: Aug 26, 2010
Subject: Re: O-235 purchase
Total time can be misleading, so check the logs and make sure the engine hasn't spent long periods sitting idle (corrosion can do more damage than running). The asking price sounds great. Get a compression check, see what the oil pressure runs, etc. TBO is only a guideline and actual condition is the key. Watch Barnstormers to see what other similar engines are going for. If his price is fair, don't insult him with an offer that is too low, cause you may need the goodwill later on :-) Ben Ben On 8/26/2010 1:46 PM, brian.e.jardine@l-3com.com wrote: > > Group, > > I have been thinking my power plant choices for the Piet and have the > opportunity to purchase a mid-time O-235, and wanted to get the advice > of others be for I jump or pull out the wallet. A hangar neighbor is > going with a larger engine on his plane and said he would sell me his > O-235 with 1200hrs SMOH, he said it's a 2000 hr engine so I'd have > roughly 800 hrs left. He is asking $3500 OBO, but isn't going to > include the starter or the current mags but he has another set of mags > he would sell with it. I figured I'd off $2500 and see if he bites, > and purchase a new starter and new mags. Any thoughts???? > > Brian > > SLC-UT > > * > > > * ________________________________________________________________________________
Date: Aug 26, 2010
It must be off a colt I am guessing, or another 2 place piper.- You proba bly would want other mags any way, the C-1B was a shower of sparks mag, whi ch needs an electrical system for the Starter Vibrator Transformer, which i s for retarding the timing for starts.- A few mods are necesary for using other mags (I think)- I believe you need longer studs in the accesory dr ive if you put on an impulse coupling, not sure about the mag drive gear th ough.- I also have a C1B I am putting on my Jungster.- $3500 sounds lik e a steal if it is a good running engine.- One drawback to the 0-235 is t hat I am told they are the most expensive- 4 cyl engine to overhaul, even an 0-320 is 10-20% cheaper to O/H from the engine gurus I have talked with .- Check the compressions if you can and the oil screen and oil for conta mination if it is not drained yet.- Ring kits are about $800 per cylinder the last time I checked, but I might be mistaken on that as well.- Good luck and happy hunting. - Shad Fly'n the Corvizzle since two thousand and sizzle=0A=0A=0A ________________________________________________________________________________
Subject: Re: tenpol-List:off topic - blatant self promotion
Date: Aug 26, 2010
Good luck in your venture. Looking at the crops from the air in a Piet----- Sweet!!! -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310220#310220 ________________________________________________________________________________
Date: Aug 26, 2010
Hi Shad, At the prices you are quoting you can fly the Corvair and build up a couple of spares. The cost of the ring set almost pays for a 5th bearing to remov e the last doubt most people have. Jim B. ----- Original Message ----- From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Thursday, August 26, 2010 12:34:08 PM Subject: Re: Pietenpol-List: O-235 purchase It must be off a colt I am guessing, or another 2 place piper.=C2- You pr obably would want other mags any way, the C-1B was a shower of sparks mag, which needs an electrical system for the Starter Vibrator Transformer, whic h is for retarding the timing for starts.=C2- A few mods are necesary for using other mags (I think)=C2- I believe you need longer studs in the ac cesory drive if you put on an impulse coupling, not sure about the mag driv e gear though.=C2- I also have a C1B I am putting on my Jungster.=C2- $ 3500 sounds like a steal if it is a good running engine.=C2- One drawback to the 0-235 is that I am told they are the most expensive=C2- 4 cyl eng ine to overhaul, even an 0-320 is 10-20% cheaper to O/H from the engine gur us I have talked with.=C2- Check the compressions if you can and the oil screen and oil for contamination if it is not drained yet.=C2- Ring kits are about $800 per cylinder the last time I checked, but I might be mistake n on that as well.=C2- Good luck and happy hunting. Shad Fly'n the Corvizzle since two thousand and sizzle == ________________________________________________________________________________
Date: Aug 26, 2010
Shad, Thanks for the reply...Yes it's off a PA-16 and it's an 0-235 C1, TT 3248 and 1275 SMOH. The A&P in the hangar next to mine say it is more expensive to overhaul the 0-235, but in my mind how many years will it take to burn up 800 hours flying a Piet? If the guy would sell it I would buy it for $2500, but for $3500, I just might want my shiny 0 hr Corvair. I have 2 complete Corvair engines with all the right numbers and I am into them for $150.00. Brian SLC -UT From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Thursday, August 26, 2010 1:34 PM Subject: Re: Pietenpol-List: O-235 purchase It must be off a colt I am guessing, or another 2 place piper. You probably would want other mags any way, the C-1B was a shower of sparks mag, which needs an electrical system for the Starter Vibrator Transformer, which is for retarding the timing for starts. A few mods are necesary for using other mags (I think) I believe you need longer studs in the accesory drive if you put on an impulse coupling, not sure about the mag drive gear though. I also have a C1B I am putting on my Jungster. $3500 sounds like a steal if it is a good running engine. One drawback to the 0-235 is that I am told they are the most expensive 4 cyl engine to overhaul, even an 0-320 is 10-20% cheaper to O/H from the engine gurus I have talked with. Check the compressions if you can and the oil screen and oil for contamination if it is not drained yet. Ring kits are about $800 per cylinder the last time I checked, but I might be mistaken on that as well. Good luck and happy hunting. Shad Fly'n the Corvizzle since two thousand and sizzle ________________________________________________________________________________
Date: Aug 26, 2010
If you pay $3500 for the Lycoming, you can expect to put maybe another $2000 in it for such things as magnetos, piston rings, spark plugs, etc. for a grand total of $5500, for a certified aircraft engine with known reliability. I seriously doubt you can convert your $150 worth of Corvair stuff into a reasonably reliable engine (depending on terrain) for less than $6,000. Bear in mind also that if you put a certificated prop on your Lycoming you are looking at only 25 hours of phase 1 testing, whereas no matter what kind of prop you put on the Corvair, you are stuck with 40 hours of phase 1 testing. That's an awful long time to bore holes in the sky without being able to take passengers or go anywhere. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of brian.e.jardine@l-3com.com Sent: Thursday, August 26, 2010 5:13 PM Subject: RE: Pietenpol-List: O-235 purchase Shad, Thanks for the reply.Yes it's off a PA-16 and it's an 0-235 C1, TT 3248 and 1275 SMOH. The A&P in the hangar next to mine say it is more expensive to overhaul the 0-235, but in my mind how many years will it take to burn up 800 hours flying a Piet? If the guy would sell it I would buy it for $2500, but for $3500, I just might want my shiny 0 hr Corvair. I have 2 complete Corvair engines with all the right numbers and I am into them for $150.00. Brian SLC -UT From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Thursday, August 26, 2010 1:34 PM Subject: Re: Pietenpol-List: O-235 purchase It must be off a colt I am guessing, or another 2 place piper. You probably would want other mags any way, the C-1B was a shower of sparks mag, which needs an electrical system for the Starter Vibrator Transformer, which is for retarding the timing for starts. A few mods are necesary for using other mags (I think) I believe you need longer studs in the accesory drive if you put on an impulse coupling, not sure about the mag drive gear though. I also have a C1B I am putting on my Jungster. $3500 sounds like a steal if it is a good running engine. One drawback to the 0-235 is that I am told they are the most expensive 4 cyl engine to overhaul, even an 0-320 is 10-20% cheaper to O/H from the engine gurus I have talked with. Check the compressions if you can and the oil screen and oil for contamination if it is not drained yet. Ring kits are about $800 per cylinder the last time I checked, but I might be mistaken on that as well. Good luck and happy hunting. Shad Fly'n the Corvizzle since two thousand and sizzle http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 26, 2010
>>> <brian.e.jardine@l-3com.com> 8/26/2010 4:13 PM >>> Shad, Thanks for the replyYes its off a PA-16 and its an 0-235 C1, TT 3248 and 1275 SMOH. The A&P in the hangar next to mine say it is more expensive to overhaul the 0-235, but in my mind how many years will it take to burn up 800 hours flying a Piet? If the guy would sell it I would buy it for $2500, but for $3500, I just might want my shiny 0 hr Corvair. I have 2 complete Corvair engines with all the right numbers and I am into them for $150.00. Brian SLC -UT Brian:Go into this with your eyes wide open as completing your Corvair might cost you more than you had initially planned. Totally depending on how far you want to go with the project. I put together the attached list of parts that I planned to purchase from William Wynne and this does not include the 5th bearing that many of us are opting for. I chose to purchase a nearly ready-to- assemble project from Ryan Mueller which did have all the extras I wanted and the cost was $6,000. You don't have to go that far or that expensive but the options are there. Tom Stinemetze N328X (very close to up on the gear) ________________________________________________________________________________
Date: Aug 26, 2010
Four years ago, we had a kit of consisting of two new Slick Mags, along with a complete wiring harness for around $1400. installed, and that was a very good price. Prior to purchasing any engine, you might want to put together a comprehensive spreadsheet of costs, and get buy in from all of the suppliers involved. Just my .02 worth. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310231#310231 ________________________________________________________________________________
Date: Aug 26, 2010
Jack, Are you talking just a top overhaul and mags? I would think $2k for a top-to-bottom, everything new or reconditioned overhaul on an O-235 is goin g to be waaaaay more than that. ... Ryan On Thu, Aug 26, 2010 at 4:32 PM, Jack Phillips wrot e: > If you pay $3500 for the Lycoming, you can expect to put maybe another > $2000 in it for such things as magnetos, piston rings, spark plugs, etc. for > a grand total of $5500, for a certified aircraft engine with known > reliability. I seriously doubt you can convert your $150 worth of Corvai r > stuff into a reasonably reliable engine (depending on terrain) for less t han > $6,000. Bear in mind also that if you put a certificated prop on your > Lycoming you are looking at only 25 hours of phase 1 testing, whereas no > matter what kind of prop you put on the Corvair, you are stuck with 40 ho urs > of phase 1 testing. That=92s an awful long time to bore holes in the sky > without being able to take passengers or go anywhere. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of * > brian.e.jardine@l-3com.com > *Sent:* Thursday, August 26, 2010 5:13 PM > > *To:* pietenpol-list(at)matronics.com > *Subject:* RE: Pietenpol-List: O-235 purchase > > > Shad, > > Thanks for the reply=85Yes it=92s off a PA-16 and it=92s an 0-235 C1, TT 3248 and > 1275 SMOH. The A&P in the hangar next to mine say it is more expensive t o > overhaul the 0-235, but in my mind how many years will it take to burn up > 800 hours flying a Piet? If the guy would sell it I would buy it for $25 00, > but for $3500, I just might want my shiny 0 hr Corvair. I have 2 complet e > Corvair engines with all the right numbers and I am into them for $150.00 . > > > Brian > > SLC -UT > > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *shad bell > *Sent:* Thursday, August 26, 2010 1:34 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: O-235 purchase > > > It must be off a colt I am guessing, or another 2 place piper. You > probably would want other mags any way, the C-1B was a shower of sparks m ag, > which needs an electrical system for the Starter Vibrator Transformer, wh ich > is for retarding the timing for starts. A few mods are necesary for usin g > other mags (I think) I believe you need longer studs in the accesory dri ve > if you put on an impulse coupling, not sure about the mag drive gear > though. I also have a C1B I am putting on my Jungster. $3500 sounds lik e a > steal if it is a good running engine. One drawback to the 0-235 is that I > am told they are the most expensive 4 cyl engine to overhaul, even an 0- 320 > is 10-20% cheaper to O/H from the engine gurus I have talked with. Check > the compressions if you can and the oil screen and oil for contamination if > it is not drained yet. Ring kits are about $800 per cylinder the last ti me > I checked, but I might be mistaken on that as well. Good luck and happy > hunting. > > > Shad > > Fly'n the Corvizzle since two thousand and sizzle > > > * * > > * * > > * * > > *http://www.matronics.com/Navigator?Pietenpol-List* > > * * > > *http://forums.matronics.com* > > * * > > *http://www.matronics.com/contribution* > > * * > > * * > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Aug 26, 2010
Not even a top overhaul. Just new mags will be close to $1000, and then whatever else needs to be done will be another grand. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Thursday, August 26, 2010 6:20 PM Subject: Re: Pietenpol-List: O-235 purchase Jack, Are you talking just a top overhaul and mags? I would think $2k for a top-to-bottom, everything new or reconditioned overhaul on an O-235 is going to be waaaaay more than that. ... Ryan On Thu, Aug 26, 2010 at 4:32 PM, Jack Phillips wrote: If you pay $3500 for the Lycoming, you can expect to put maybe another $2000 in it for such things as magnetos, piston rings, spark plugs, etc. for a grand total of $5500, for a certified aircraft engine with known reliability. I seriously doubt you can convert your $150 worth of Corvair stuff into a reasonably reliable engine (depending on terrain) for less than $6,000. Bear in mind also that if you put a certificated prop on your Lycoming you are looking at only 25 hours of phase 1 testing, whereas no matter what kind of prop you put on the Corvair, you are stuck with 40 hours of phase 1 testing. That's an awful long time to bore holes in the sky without being able to take passengers or go anywhere. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of brian.e.jardine@l-3com.com Sent: Thursday, August 26, 2010 5:13 PM Subject: RE: Pietenpol-List: O-235 purchase Shad, Thanks for the reply.Yes it's off a PA-16 and it's an 0-235 C1, TT 3248 and 1275 SMOH. The A&P in the hangar next to mine say it is more expensive to overhaul the 0-235, but in my mind how many years will it take to burn up 800 hours flying a Piet? If the guy would sell it I would buy it for $2500, but for $3500, I just might want my shiny 0 hr Corvair. I have 2 complete Corvair engines with all the right numbers and I am into them for $150.00. Brian SLC -UT From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Thursday, August 26, 2010 1:34 PM Subject: Re: Pietenpol-List: O-235 purchase It must be off a colt I am guessing, or another 2 place piper. You probably would want other mags any way, the C-1B was a shower of sparks mag, which needs an electrical system for the Starter Vibrator Transformer, which is for retarding the timing for starts. A few mods are necesary for using other mags (I think) I believe you need longer studs in the accesory drive if you put on an impulse coupling, not sure about the mag drive gear though. I also have a C1B I am putting on my Jungster. $3500 sounds like a steal if it is a good running engine. One drawback to the 0-235 is that I am told they are the most expensive 4 cyl engine to overhaul, even an 0-320 is 10-20% cheaper to O/H from the engine gurus I have talked with. Check the compressions if you can and the oil screen and oil for contamination if it is not drained yet. Ring kits are about $800 per cylinder the last time I checked, but I might be mistaken on that as well. Good luck and happy hunting. Shad Fly'n the Corvizzle since two thousand and sizzle http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Wife went for first flight tongh in GN-1
Date: Aug 26, 2010
Well - the wife and youngest went up for their first flights tonight with me in the GN-1. They both had blast! It was her first experience in a low and slow open cockpit plane (rest of the time has been in a C-172 with me). We had to come down after 20 minutes and she was sorely disappointed. The 9 year old looked like "Kilroy was here" with his big goggles and headset peering over the side of the fuselage the whole flight. He wanted to go back up after we landed. It was the first flight he's ever been on that he didn't puke..... thank God... I have two more converts in the house! -------- Lorin Miller Waiex N81YX GN-1 N30PP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310243#310243 ________________________________________________________________________________
Subject: Re: GN-1
Date: Aug 26, 2010
OOPS! Someday I'm going to read what I write before hitting the "send" button. Yeah! I meant 2300 rpm. On Aug 26, 2010, at 12:13 PM, Jack wrote: > > 3200 Roman? Isn't that high? > Jack > DSM > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > Roman Bukolt > Sent: Thursday, August 26, 2010 11:49 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: GN-1 > > > > > I'm running a Ed Sterba 72x42 on my A-65 and am getting great > performance. 3min. /1000 ft @ 3200rpm and cruise at 80mph at > 2000rpm. > FYI- Roman Bukolt NX20795 > On Aug 26, 2010, at 6:29 AM, Ben Charvet wrote: > >>> >> >> Probably when he said smaller prop he meant with less pitch. The >> extra HP in an A-75 is mostly because it turns at 2600 rpm redline, >> and this is done by using less pitch. I'm running a Sensenich 72X40 >> on my A-65 and find that to be about perfect. Jack Phillips has the >> same prop on his Piet. This prop in actually used on the J-3 as a >> climb prop. >> >> Ben Charvet >>>> >>>> Now .. he did mention that he put the bigger piston pins(but not >>>> the 75 pistons)drilled something(rod's), etc, etc... in the event >>>> that I convert it to 75hp later. He thinks it's safe to run at >>>> higher rpm by getting smaller prop as an "experimental" if I >>>> desire to do so, but me thinks me wants to play it safe and get a >>>> 72x42pitch. Any thoughts on that...best prop?... especially from >>>> GN-1(w/A65) folks? I would really like a wood prop... >>>> >>>> Ler >>>> >>>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 27, 2010
Subject: Plans Question
Members of the list: - - I was reading through my plans and did not see a page for the landing gear and fittings. I do find the diagram in the Pietenpol Booklet and in the Fly ing and Glider Manual that came with the plans. Am I missing this page? Particularly, I was searching for the dimension of the ash piece used in th e wood landing gear section. - Thanks for any assistance. - KMH Hawley, MN - =0A=0A=0A ________________________________________________________________________________
Date: Aug 27, 2010
which ash piece do you mean? If you are referring to the one across the fl oor=2C for the wooden gear version there is not one. You can add one=2C li ke most people have done=2C but then you have to modify the fittings. If y ou mean the ash piece at the bottom of the gear=2C the dimensions are in th e F&G manual=2C something like 1 1/2 by 2 1/2 by 7 (don't have the plans in front of me). Gene Date: Fri=2C 27 Aug 2010 05:08:56 -0700 From: kmheidecpo(at)yahoo.com Subject: Pietenpol-List: Plans Question Members of the list: I was reading through my plans and did not see a page for the landing gear and fittings. I do find the diagram in the Pietenpol Booklet and in the Fly ing and Glider Manual that came with the plans. Am I missing this page? Particularly=2C I was searching for the dimension of the ash piece used in the wood landing gear section. Thanks for any assistance. KMH Hawley=2C MN ________________________________________________________________________________
Date: Aug 27, 2010
KM, I don't have the wood gear page in front of me, but by recollection I don't think that dimension is supplied. Even if it was, I may have ignored it. The gear length probably changes for each plane, depending on what wheels you choose (mine are 21") and what deck angle you want when complete (mine is 13 deg). Tail wheel design will also affect deck angle. In my case, I installed the tail wheel, propped the fuselage up on saw horses and blocks until I got the deck angle, rolled the wheels in to place (the dimension from the leading edge as I recall), then measured for the legs. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Friday, August 27, 2010 5:09 AM Subject: Pietenpol-List: Plans Question Members of the list: I was reading through my plans and did not see a page for the landing gear and fittings. I do find the diagram in the Pietenpol Booklet and in the Flying and Glider Manual that came with the plans. Am I missing this page? Particularly, I was searching for the dimension of the ash piece used in the wood landing gear section. Thanks for any assistance. KMH Hawley, MN ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Aug 27, 2010
Subject: The Great Waldo Pepper released on DVD in WIDESCREEN
http://www.bestbuy.com/site/The+Great+Waldo+Pepper+-+Widescreen+Dolby+-+DVD /18604073.p?skuId=18604073&id=47584 Thanks to an off-list e-mail from a good Piet builder in the Northwest name d Jake I was given this great NEWS about TGWP DVD becoming available in widescreen and at a decent price. Just gather round folks, just gather round.......... Thanks Jake ! Mike C. ________________________________________________________________________________
Date: Aug 27, 2010
Subject: Re: Plans Question
Gene, You are correct in that there is no ash piece explicitly shown for the floor, nor mention of one made in the text (that I can see skimming through his AM). However if you look at the "Cross Section View of Mounted Landing Gear Fittings" portion of the wood landing gear drawing in the F&G Manual it shows an additional wood member of some sort above the floor and under the 1/2" steel strip....maybe 1/2" thick if it is drawn proportional to the longeron, possiby 3/4"? See attached scan please.... Ryan On Fri, Aug 27, 2010 at 7:27 AM, Gene Rambo wrote: > which ash piece do you mean? If you are referring to the one across the > floor, for the wooden gear version there is not one. You can add one, like > most people have done, but then you have to modify the fittings. If you > mean the ash piece at the bottom of the gear, the dimensions are in the F&G > manual, something like 1 1/2 by 2 1/2 by 7 (don't have the plans in front of > me). > > Gene > > ------------------------------ > Date: Fri, 27 Aug 2010 05:08:56 -0700 > From: kmheidecpo(at)yahoo.com > Subject: Pietenpol-List: Plans Question > To: Pietenpol-List(at)matronics.com > > > Members of the list: > > > I was reading through my plans and did not see a page for the landing gear > and fittings. I do find the diagram in the Pietenpol Booklet and in the > Flying and Glider Manual that came with the plans. Am I missing this page? > Particularly, I was searching for the dimension of the ash piece used in > the wood landing gear section. > > Thanks for any assistance. > > KMH > Hawley, MN > * > * > ** > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Aug 27, 2010
Subject: Re: The Great Waldo Pepper released on DVD in WIDESCREEN
So now Aircraft Spruce AND Bestbuy are monitoring this list.... wow -----Original Message----- From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" Sent: Aug 27, 2010 9:00 AM Subject: Pietenpol-List: The Great Waldo Pepper released on DVD in WIDESCREEN http://www.bestbuy.com/site/The+Great+Waldo+Pepper+-+Widescreen+Dolby+-+DVD/18604073.p?skuId=18604073&id=47584 Thanks to an off-list e-mail from a good Piet builder in the Northwest named Jake I was given this great NEWS about TGWP DVD becoming available in widescreen and at a decent price. Just gather round folks, just gather round. Thanks Jake ! Mike C. ________________________________________________________________________________
Date: Aug 27, 2010
Subject: Best Buy and ACS
So now Aircraft Spruce AND Bestbuy are monitoring this list.... wow. That's funny Jim ! Actually Best Buy is now carrying a full spruce kit for the Pietenpol Air Camper and Sky Scout:)) That should trigger a response from Jim Irwin's List Police at ACS. Mike C. ________________________________________________________________________________
Date: Aug 27, 2010
No=2C the plans are clear=2C with the wooden gear version from the F&G manu al the cross pieces are merely 1" square spruce just like every other cross member. There are no ash cross pieces on that version of the plans. Gene Date: Fri=2C 27 Aug 2010 08:03:40 -0500 Subject: Re: Pietenpol-List: Plans Question From: rmueller23(at)gmail.com Gene=2C You are correct in that there is no ash piece explicitly shown for the floo r=2C nor mention of one made in the text (that I can see skimming through h is AM). However if you look at the "Cross Section View of Mounted Landing G ear Fittings" portion of the wood landing gear drawing in the F&G Manual it shows an additional wood member of some sort above the floor and under the 1/2" steel strip....maybe 1/2" thick if it is drawn proportional to the l ongeron=2C possiby 3/4"? See attached scan please.... Ryan On Fri=2C Aug 27=2C 2010 at 7:27 AM=2C Gene Rambo wrote : which ash piece do you mean? If you are referring to the one across the fl oor=2C for the wooden gear version there is not one. You can add one=2C li ke most people have done=2C but then you have to modify the fittings. If y ou mean the ash piece at the bottom of the gear=2C the dimensions are in th e F&G manual=2C something like 1 1/2 by 2 1/2 by 7 (don't have the plans in front of me). Gene Date: Fri=2C 27 Aug 2010 05:08:56 -0700 From: kmheidecpo(at)yahoo.com Subject: Pietenpol-List: Plans Question Members of the list: I was reading through my plans and did not see a page for the landing gear and fittings. I do find the diagram in the Pietenpol Booklet and in the Fly ing and Glider Manual that came with the plans. Am I missing this page? Particularly=2C I was searching for the dimension of the ash piece used in the wood landing gear section. Thanks for any assistance. KMH Hawley=2C MN st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 27, 2010
Gene, Then the piece that is inboard of the longeron in the drawing that I attached, that has the bolt running vertically through it and the ply floor, is just a 1" square cross piece? If so, why is it drawn smaller than the 1" square longeron adjacent to it? Ryan On Fri, Aug 27, 2010 at 8:32 AM, Gene Rambo wrote: > No, the plans are clear, with the wooden gear version from the F&G manual > the cross pieces are merely 1" square spruce just like every other cross > member. There are no ash cross pieces on that version of the plans. > > Gene > > ------------------------------ > Date: Fri, 27 Aug 2010 08:03:40 -0500 > Subject: Re: Pietenpol-List: Plans Question > From: rmueller23(at)gmail.com > To: pietenpol-list(at)matronics.com > > > Gene, > > You are correct in that there is no ash piece explicitly shown for the > floor, nor mention of one made in the text (that I can see skimming through > his AM). However if you look at the "Cross Section View of Mounted Landing > Gear Fittings" portion of the wood landing gear drawing in the F&G Manual it > shows an additional wood member of some sort above the floor and under the > 1/2" steel strip....maybe 1/2" thick if it is drawn proportional to the > longeron, possiby 3/4"? See attached scan please.... > > Ryan > > > On Fri, Aug 27, 2010 at 7:27 AM, Gene Rambo wrote: > > which ash piece do you mean? If you are referring to the one across the > floor, for the wooden gear version there is not one. You can add one, like > most people have done, but then you have to modify the fittings. If you > mean the ash piece at the bottom of the gear, the dimensions are in the F&G > manual, something like 1 1/2 by 2 1/2 by 7 (don't have the plans in front of > me). > > Gene > > ------------------------------ > Date: Fri, 27 Aug 2010 05:08:56 -0700 > From: kmheidecpo(at)yahoo.com > Subject: Pietenpol-List: Plans Question > To: Pietenpol-List(at)matronics.com > > > Members of the list: > > > I was reading through my plans and did not see a page for the landing gear > and fittings. I do find the diagram in the Pietenpol Booklet and in the > Flying and Glider Manual that came with the plans. Am I missing this page? > Particularly, I was searching for the dimension of the ash piece used in > the wood landing gear section. > > Thanks for any assistance. > > KMH > Hawley, MN > * > * > ** > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > > * > > * > > ________________________________________________________________________________
Date: Aug 27, 2010
you're right=2C and I saw that after I posted. I do not have the plans in front of me=2C but I do know for sure that the cross piece is 1" square. I cannot explain why the cross section looks like it does. Many people (inc luding me) built the fuselage to the "improved plans" with ash cross pieces before noticing that the wood gear version did not have them. The ash was added for the "split-type" gear in the improved plans. All I did (and mos t others) was modify the gear fittings (I did it per Pavliga drawings) to m ake them work. I think the modified ones are stronger anyway. I will say that the steel strap shown in the cross section you posted may b e necessary (or at least a good idea) with a 1" square spruce cross piece =2C but I cannot find a single reason to have it on the ash version and I a m not installing one. Gene Date: Fri=2C 27 Aug 2010 08:43:32 -0500 Subject: Re: Pietenpol-List: Plans Question From: rmueller23(at)gmail.com Gene=2C Then the piece that is inboard of the longeron in the drawing that I attach ed=2C that has the bolt running vertically through it and the ply floor=2C is just a 1" square cross piece? If so=2C why is it drawn smaller than the 1" square longeron adjacent to it? Ryan On Fri=2C Aug 27=2C 2010 at 8:32 AM=2C Gene Rambo wrote : No=2C the plans are clear=2C with the wooden gear version from the F&G manu al the cross pieces are merely 1" square spruce just like every other cross member. There are no ash cross pieces on that version of the plans. Gene Date: Fri=2C 27 Aug 2010 08:03:40 -0500 Subject: Re: Pietenpol-List: Plans Question From: rmueller23(at)gmail.com Gene=2C You are correct in that there is no ash piece explicitly shown for the floo r=2C nor mention of one made in the text (that I can see skimming through h is AM). However if you look at the "Cross Section View of Mounted Landing G ear Fittings" portion of the wood landing gear drawing in the F&G Manual it shows an additional wood member of some sort above the floor and under the 1/2" steel strip....maybe 1/2" thick if it is drawn proportional to the l ongeron=2C possiby 3/4"? See attached scan please.... Ryan On Fri=2C Aug 27=2C 2010 at 7:27 AM=2C Gene Rambo wrote : which ash piece do you mean? If you are referring to the one across the fl oor=2C for the wooden gear version there is not one. You can add one=2C li ke most people have done=2C but then you have to modify the fittings. If y ou mean the ash piece at the bottom of the gear=2C the dimensions are in th e F&G manual=2C something like 1 1/2 by 2 1/2 by 7 (don't have the plans in front of me). Gene Date: Fri=2C 27 Aug 2010 05:08:56 -0700 From: kmheidecpo(at)yahoo.com Subject: Pietenpol-List: Plans Question Members of the list: I was reading through my plans and did not see a page for the landing gear and fittings. I do find the diagram in the Pietenpol Booklet and in the Fly ing and Glider Manual that came with the plans. Am I missing this page? Particularly=2C I was searching for the dimension of the ash piece used in the wood landing gear section. Thanks for any assistance. KMH Hawley=2C MN st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 27, 2010
Roger that. Wanted to make sure I wasn't losing my mind. :P Thanks Gene! Ryan On Fri, Aug 27, 2010 at 9:52 AM, Gene Rambo wrote: > you're right, and I saw that after I posted. I do not have the plans in > front of me, but I do know for sure that the cross piece is 1" square. I > cannot explain why the cross section looks like it does. Many people > (including me) built the fuselage to the "improved plans" with ash cross > pieces before noticing that the wood gear version did not have them. The > ash was added for the "split-type" gear in the improved plans. All I did > (and most others) was modify the gear fittings (I did it per Pavliga > drawings) to make them work. I think the modified ones are stronger > anyway. > > I will say that the steel strap shown in the cross section you posted may > be necessary (or at least a good idea) with a 1" square spruce cross > piece, but I cannot find a single reason to have it on the ash version and I > am not installing one. > > Gene > > ------------------------------ > Date: Fri, 27 Aug 2010 08:43:32 -0500 > > Subject: Re: Pietenpol-List: Plans Question > From: rmueller23(at)gmail.com > To: pietenpol-list(at)matronics.com > > Gene, > > Then the piece that is inboard of the longeron in the drawing that I > attached, that has the bolt running vertically through it and the ply floor, > is just a 1" square cross piece? If so, why is it drawn smaller than the 1" > square longeron adjacent to it? > > Ryan > > On Fri, Aug 27, 2010 at 8:32 AM, Gene Rambo wrote: > > No, the plans are clear, with the wooden gear version from the F&G manual > the cross pieces are merely 1" square spruce just like every other cross > member. There are no ash cross pieces on that version of the plans. > > Gene > > ------------------------------ > Date: Fri, 27 Aug 2010 08:03:40 -0500 > Subject: Re: Pietenpol-List: Plans Question > From: rmueller23(at)gmail.com > To: pietenpol-list(at)matronics.com > > > Gene, > > You are correct in that there is no ash piece explicitly shown for the > floor, nor mention of one made in the text (that I can see skimming through > his AM). However if you look at the "Cross Section View of Mounted Landing > Gear Fittings" portion of the wood landing gear drawing in the F&G Manual it > shows an additional wood member of some sort above the floor and under the > 1/2" steel strip....maybe 1/2" thick if it is drawn proportional to the > longeron, possiby 3/4"? See attached scan please.... > > Ryan > > > On Fri, Aug 27, 2010 at 7:27 AM, Gene Rambo wrote: > > which ash piece do you mean? If you are referring to the one across the > floor, for the wooden gear version there is not one. You can add one, like > most people have done, but then you have to modify the fittings. If you > mean the ash piece at the bottom of the gear, the dimensions are in the F&G > manual, something like 1 1/2 by 2 1/2 by 7 (don't have the plans in front of > me). > > Gene > > ------------------------------ > Date: Fri, 27 Aug 2010 05:08:56 -0700 > From: kmheidecpo(at)yahoo.com > Subject: Pietenpol-List: Plans Question > To: Pietenpol-List(at)matronics.com > > > Members of the list: > > > I was reading through my plans and did not see a page for the landing gear > and fittings. I do find the diagram in the Pietenpol Booklet and in the > Flying and Glider Manual that came with the plans. Am I missing this page? > Particularly, I was searching for the dimension of the ash piece used in > the wood landing gear section. > > Thanks for any assistance. > > KMH > Hawley, MN > * > * > ** > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > > * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Aug 27, 2010
I have the wood landing gear print in my set of plans. It was not included in my original set, I had to ask for it. That wood piece you are asking about... I do not have the plans in front of me, but on my plane, that piece is ash, about (from memory)- 2" X 3/4" a nd runs from one side of the fuselage to the other. In the picture you can see one in place for both forward and aft landing gear attach points. I THO UGHT this was shown in the fuselage print? (I'll verify when I get home...i f you still need to know by then.) Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Aug 27, 2010
Subject: gear fitting mods
I fabricated the modified wood gear fittings like Mike P. / Gene R. mentio ned as suggested to me by Frank M. Pavilga because of how much sense they made when Frank and his father (Frank M. Pavliga, deceased) who are/we re both architects changed them a bit. I used both the ash crossmembers and a thin 1" wide strip of 4130 from side to side under the belly just fo r insurance but not having the engineering background I I made some chicken-scratch diagrams trying to show how they go together an d they are posted under my name in the Chris Tracy http://www.westcoastpiet .com/pictures.htm web site. ________________________________________________________________________________
Date: Aug 27, 2010
Subject: multiple messages-- server fouled up?-- ATTENTION, MATRONICS
The last two days including the present, I am occassionally only getting one message from board members, but often 2,3,4 or 6 copies of the same post. Something is wrong with our server. Tim in central TX ________________________________________________________________________________
MATRONICS
Date: Aug 27, 2010
Tim, so far the only ones who have said anything about multiple messages have earthlink dot net addresses. Skip at earthlink, sometimes getting more than 6 copies. > [Original Message] > From: Tim Willis <timothywillis(at)earthlink.net> > To: matronics piet site > Date: 8/27/2010 3:56:37 PM > Subject: Pietenpol-List: multiple messages-- server fouled up?-- ATTENTION, MATRONICS > > > The last two days including the present, I am occassionally only getting one message from board members, but often 2,3,4 or 6 copies of the same post. > > Something is wrong with our server. > Tim in central TX > > ________________________________________________________________________________
Date: Aug 27, 2010
Just checked my plans and both ash pieces are shown on the fuselage page. Both pieces are 3/4" X 2". Yes, I really should keep the floor and shop a little cleaner. Michael Perez Karetaker Aero Www.karetakeraero.com ________________________________________________________________________________
Subject: Re: Wife went for first flight tongh in GN-1
Date: Aug 27, 2010
You know, I tried to go back and edit this message after I posted to correct the misspell - but it didn't seem to fxi ti... Lorin -------- Lorin Miller Waiex N81YX GN-1 N30PP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310315#310315 ________________________________________________________________________________
Subject: engine run-up
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Aug 27, 2010
Well I got my wings back off and rolled my GN-1 out in the sunshine today and got it tied down and ran the Corvair D.J. built up. it sounds strong and smooth so far -I got the timing what looks like close but in the bright sunshine it is difficult to see the marks really well so I'm going to check it again about dusk. but it sure seems to pull Strong so far.I didn't go full open for over a few seconds but I believe it will pretty easily turn 2850 or more.and that should drag this thing into the air pretty well.oil pressure seems to stay around 38 or so even pretty warmat idle. head temps never went over about 284 so far. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310321#310321 ________________________________________________________________________________
Date: Aug 27, 2010
Subject: Re: engine run-up
Congrats! That's great.... -----Original Message----- >From: skellytown flyer <skellflyer1(at)yahoo.com> >Sent: Aug 27, 2010 6:38 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: engine run-up > > >Well I got my wings back off and rolled my GN-1 out in the sunshine today and got it tied down and ran the Corvair D.J. built up. it sounds strong and smooth so far -I got the timing what looks like close but in the bright sunshine it is difficult to see the marks really well so I'm going to check it again about dusk. but it sure seems to pull Strong so far.I didn't go full open for over a few seconds but I believe it will pretty easily turn 2850 or more.and that should drag this thing into the air pretty well.oil pressure seems to stay around 38 or so even pretty warmat idle. head temps never went over about 284 so far. Raymond > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=310321#310321 > > ________________________________________________________________________________
Date: Aug 27, 2010
Congratulations. That's great!! Sent from my iPhone On Aug 27, 2010, at 4:38 PM, "skellytown flyer" wrote: > > Well I got my wings back off and rolled my GN-1 out in the sunshine today and got it tied down and ran the Corvair D.J. built up. it sounds strong and smooth so far -I got the timing what looks like close but in the bright sunshine it is difficult to see the marks really well so I'm going to check it again about dusk. but it sure seems to pull Strong so far.I didn't go full open for over a few seconds but I believe it will pretty easily turn 2850 or more.and that should drag this thing into the air pretty well.oil pressure seems to stay around 38 or so even pretty warmat idle. head temps never went over about 284 so far. Raymond > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310321#310321 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 27, 2010
That's great. One step closer! -------- Dan Plett Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310345#310345 ________________________________________________________________________________
Date: Aug 27, 2010
True Mike but look on the steel split axel gear page upper right drawing, it clearly says the front ash cross piece is 2"x1" with the ends tapered to 3/4". Fortunately either way works. Now on the original fuselage (wood landing gear) there are no ash cross braces. There are 1"x3/4" spruce cross braces. What orientation the 1" dimension should be is debatable. Welcome to the world of Pietenpol drawings. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, August 27, 2010 3:06 PM Subject: Re: Pietenpol-List: Plans Question --> Just checked my plans and both ash pieces are shown on the fuselage page. Both pieces are 3/4" X 2". Yes, I really should keep the floor and shop a little cleaner. Michael Perez Karetaker Aero Www.karetakeraero.com ________________________________________________________________________________
Date: Aug 27, 2010
I'm not wanting to sound like a nay-sayer, but, for what its worth, if you use a certificated engine in an experimental, and intend to keep it as a certificated engine, all the components and accessories need to be PMA stuff, and all the accessories such as mags and starters, have to be on the TCDS (type certificate data sheet) for that engine for it to stay as a certificated engine. Also, you will have to have an A&P who has an IA do the annual on the engine (and prop, if you are shooting for the 25 hour test flight time), if you intend to keep the engine and prop as a certificated set. The prop would also have to be a model that was listed on the TCDS for the engine for everything to qualify for the 25 hour flight test, instead of 40 hour. Any deviation from the TCDS makes it experimental. Disadvantages (some of the disadvantages) of a certificated engine and prop - probably higher repair costs in parts, as they have to be PMA parts, and an A&P would have to sign off on any minor repairs, and an A&P with an IA will have to sign off on major repairs and on the annual on the powerplant. The builder (if he gets a repairman certificate for the airplane, can still sign off the yearly condition inspection on the airframe. (Type Certificated stuff gets annual inspections, experimental stuff gets yearly condition inspections. Most everyone on this list already knows this, but in case there are any who weren't aware, I thought I'd throw that in.) Advantages (some of the advantages) of a certificated engine and prop - generally (no guarantees, but usually) higher likelihood of good reliability, and definitely higher resale value if all the paperwork is kept up. In my opinion, if you can afford it, the certificated engine is the way to go. My two cents worth. There are others who will disagree, who have had excellent success with their experimental engines, and probably just as many, if not more, who will agree with the certificated engine idea. Mike Glasgow FAA A&P; FAA Repairman N777WG -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310354#310354 ________________________________________________________________________________
Date: Aug 28, 2010
This is great info to keep in mind when getting ready to choose your powerplant. Thanks for posting this, Mike! -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310355#310355 ________________________________________________________________________________
Date: Aug 28, 2010
\ I'll just relate my experience. The* FAA inspector* who did my airworthiness inspection knew that I'd rebuilt my engine myself (A-65), and had no problem giving me a 25 hour test period. My repairman certificate has no restrictions on doing the annual condition inspection. Others on the list have had similar experience. Ben Charvet On 8/28/2010 2:30 AM, GliderMike wrote: > --> Pietenpol-List message posted by: "GliderMike" > > I'm not wanting to sound like a nay-sayer, but, for what its worth, if you use a certificated engine in an experimental, and intend to keep it as a certificated engine, all the components and accessories need to be PMA stuff, and all the accessories such as mags and starters, have to be on the TCDS (type certificate data sheet) for that engine for it to stay as a certificated engine. Also, you will have to have an A&P who has an IA do the annual on the engine (and prop, if you are shooting for the 25 hour test flight time), if you intend to keep the engine and prop as a certificated set. The prop would also have to be a model that was listed on the TCDS for the engine for everything to qualify for the 25 hour flight test, instead of 40 hour. Any deviation from the TCDS makes it experimental. > > Disadvantages (some of the disadvantages) of a certificated engine and prop - probably higher repair costs in parts, as they have to be PMA parts, and an A&P would have to sign off on any minor repairs, and an A&P with an IA will have to sign off on major repairs and on the annual on the powerplant. The builder (if he gets a repairman certificate for the airplane, can still sign off the yearly condition inspection on the airframe. (Type Certificated stuff gets annual inspections, experimental stuff gets yearly condition inspections. Most everyone on this list already knows this, but in case there are any who weren't aware, I thought I'd throw that in.) > > Advantages (some of the advantages) of a certificated engine and prop - generally (no guarantees, but usually) higher likelihood of good reliability, and definitely higher resale value if all the paperwork is kept up. > > In my opinion, if you can afford it, the certificated engine is the way to go. My two cents worth. There are others who will disagree, who have had excellent success with their experimental engines, and probably just as many, if not more, who will agree with the certificated engine idea. > > Mike Glasgow > FAA A&P; FAA Repairman N777WG > > -------- > HOMEBUILDER > Will WORK for Spruce > Long flights, smooth air, and soft landings, > GliderMike, aka Mike Glasgow > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310354#310354 > > ________________________________________________________________________________
Date: Aug 28, 2010
Mike,=0A=0AAlong this same thought path-I have a question.-=0A=0AI know that an Amateur Built Experimental needs to have a conditional Inspection =0Aonce per year, and that-the person holding the repairman's certificate for the =0Aairplane or and A&P(with or without-IA)-can do this conditi onal-inspection.- =0A=0A=0AMy question is that if the airplane-has an Experimental Exhibition-Airworthiness =0Acertificate does it still need a conditional inspection or does it need an =0AAnnual and if it is a condit ional inspection-does the A&P need IA.=0A-Mike Volckmann =0A=0AThe only thing we ever learn from history is that we never learn from history. =0AG eorge Bernard Shaw =0A=0A=0A=0A=0A=0A________________________________=0AFro m: GliderMike =0ATo: pietenpol-list(at)matronics.com=0A Sent: Fri, August 27, 2010 11:30:15 PM=0ASubject: Pietenpol-List: Re: O-235 keg(at)yahoo.com>=0A=0AI'm not wanting to sound like a nay-sayer, but, for wha t its worth, if you use a =0Acertificated engine in an experimental, and in tend to keep it as a certificated =0Aengine, all the components and accesso ries need to be PMA stuff, and all the =0Aaccessories such as mags and star ters, have to be on the TCDS (type certificate =0Adata sheet) for that engi ne for it to stay as a certificated engine.- Also, you =0Awill have to ha ve an A&P who has an IA do the annual on the engine (and prop, if =0Ayou ar e shooting for the 25 hour test flight time), if you intend to keep the =0A engine and prop as a certificated set.- The prop would also have to be a model =0Athat was listed on the TCDS for the engine for everything to quali fy for the 25 =0Ahour flight test, instead of 40 hour.- Any deviation fro m the TCDS makes it =0Aexperimental.=0A=0ADisadvantages (some of the disadv antages) of a certificated engine and prop - =0Aprobably higher repair cost s in parts, as they have to be PMA parts, and an A&P =0Awould have to sign off on any minor repairs, and an A&P with an IA will have to =0Asign off on major repairs and on the annual on the powerplant.- The builder (if =0Ah e gets a repairman certificate for the airplane, can still sign off the yea rly =0Acondition inspection on the airframe.- (Type Certificated stuff ge ts annual =0Ainspections, experimental stuff gets yearly condition inspecti ons.- Most =0Aeveryone on this list already knows this, but in case there are any who weren't =0Aaware, I thought I'd throw that in.)=0A=0AAdvantage s (some of the advantages) of a certificated engine and prop - =0Agenerally (no guarantees, but usually) higher likelihood- of good reliability, =0A and definitely higher resale value if all the paperwork is kept up.=0A=0AIn my opinion, if you can afford it, the certificated engine is the way to go .- =0AMy two cents worth.- There are others who will disagree, who have had excellent =0Asuccess with their experimental engines, and probably jus t as many, if not more, =0Awho will agree with the certificated engine idea .=0A=0AMike Glasgow=0AFAA A&P; FAA Repairman N777WG=0A=0A--------=0AHOMEBUI LDER=0AWill WORK for Spruce=0ALong flights, smooth air, and soft landings, =0AGliderMike, aka Mike Glasgow=0A=0A=0A=0A=0ARead this topic online here: =0A=0Ahttp://forums.matronics.com/viewtopic.php?p=310354#310354=0A=0A=0A =================== ________________________________________________________________________________
Date: Aug 28, 2010
That mirrors my experience exactly, Ben. I rebuilt my A65 (had to make a new log, as the old logs were lost). Still got the 25 hr flyoff. My inspection was done by the FSDO, not a DAR Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Saturday, August 28, 2010 5:46 AM Subject: Re: Pietenpol-List: Re: O-235 purchase \ I'll just relate my experience. The FAA inspector who did my airworthiness inspection knew that I'd rebuilt my engine myself (A-65), and had no problem giving me a 25 hour test period. My repairman certificate has no restrictions on doing the annual condition inspection. Others on the list have had similar experience. Ben Charvet On 8/28/2010 2:30 AM, GliderMike wrote: I'm not wanting to sound like a nay-sayer, but, for what its worth, if you use a certificated engine in an experimental, and intend to keep it as a certificated engine, all the components and accessories need to be PMA stuff, and all the accessories such as mags and starters, have to be on the TCDS (type certificate data sheet) for that engine for it to stay as a certificated engine. Also, you will have to have an A&P who has an IA do the annual on the engine (and prop, if you are shooting for the 25 hour test flight time), if you intend to keep the engine and prop as a certificated set. The prop would also have to be a model that was listed on the TCDS for the engine for everything to qualify for the 25 hour flight test, instead of 40 hour. Any deviation from the TCDS makes it experimental. Disadvantages (some of the disadvantages) of a certificated engine and prop - probably higher repair costs in parts, as they have to be PMA parts, and an A&P would have to sign off on any minor repairs, and an A&P with an IA will have to sign off on major repairs and on the annual on the powerplant. The builder (if he gets a repairman certificate for the airplane, can still sign off the yearly condition inspection on the airframe. (Type Certificated stuff gets annual inspections, experimental stuff gets yearly condition inspections. Most everyone on this list already knows this, but in case there are any who weren't aware, I thought I'd throw that in.) Advantages (some of the advantages) of a certificated engine and prop - generally (no guarantees, but usually) higher likelihood of good reliability, and definitely higher resale value if all the paperwork is kept up. In my opinion, if you can afford it, the certificated engine is the way to go. My two cents worth. There are others who will disagree, who have had excellent success with their experimental engines, and probably just as many, if not more, who will agree with the certificated engine idea. Mike Glasgow FAA A&P; FAA Repairman N777WG -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310354#310354 ________________________________________________________________________________
Date: Aug 28, 2010
I had thought it was 1" square=2C but do not have plans in fornt of me. If they are 1" x 3/4=2C then the 1" is in the fore and aft plane=2C 3/4" tall as shown in the drawing Ryan posted. Gene > From: catdesigns(at)att.net > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Plans Question > Date: Fri=2C 27 Aug 2010 22:57:58 -0700 > > > True Mike but look on the steel split axel gear page upper right drawing =2C it > clearly says the front ash cross piece is 2"x1" with the ends tapered to > 3/4". > > Fortunately either way works. > > Now on the original fuselage (wood landing gear) there are no ash cross > braces. There are 1"x3/4" spruce cross braces. What orientation the 1" > dimension should be is debatable. > > Welcome to the world of Pietenpol drawings. > > Chris > Sacramento=2C Ca > Westcoastpiet.com > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael > Perez > Sent: Friday=2C August 27=2C 2010 3:06 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Plans Question > > --> > > Just checked my plans and both ash pieces are shown on the fuselage page. > Both pieces are 3/4" X 2". > > Yes=2C I really should keep the floor and shop a little cleaner. > > > Michael Perez > Karetaker Aero > Www.karetakeraero.com > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Aug 28, 2010
The original question was referring to the "wood" landing gear, not the spl it axle. Those wood pieces would be different for the different style gear used.- I am curious as to what the "original fuselage" plans are. My fuse lage plan is dated 1933 and shows the 2" X 3/4" ash. - - Michael Perez Karetaker Aero www.karetakeraero.com --- On Sat, 8/28/10, Chris wrote: From: Chris <catdesigns(at)att.net> Subject: RE: Pietenpol-List: Plans Question Date: Saturday, August 28, 2010, 1:57 AM True Mike but look on the steel split axel gear page upper right drawing, i t clearly says the front ash cross piece is 2"x1" with the ends tapered to 3/4". Fortunately either way works. Now on the original fuselage (wood landing gear) there are no ash cross braces.- There are 1"x3/4" spruce cross braces.- What orientation the 1 " dimension should be is debatable. Welcome to the world of Pietenpol drawings. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, August 27, 2010 3:06 PM Subject: Re: Pietenpol-List: Plans Question --> Just checked my plans and both ash pieces are shown on the fuselage page. Both pieces are 3/4" X 2". Yes, I really should keep the floor and shop a little cleaner. Michael Perez Karetaker Aero Www.karetakeraero.com le, List Admin. ________________________________________________________________________________
Date: Aug 28, 2010
I can post a small picture of that part of the plan I am referring to if it would help. By now, (or by the time we get it figured out) the original po ster will have his gear finished. Michael Perez Karetaker Aero www.karetakeraero.com --- On Sat, 8/28/10, Gene Rambo wrote: From: Gene Rambo <generambo(at)msn.com> Subject: RE: Pietenpol-List: Plans Question Date: Saturday, August 28, 2010, 11:00 AM I had thought it was 1" square, but do not have plans in fornt of me.- If they are 1" x 3/4, then the 1" is-in the fore and aft plane, 3/4" tall a s-shown-in the drawing Ryan posted. - Gene - > From: catdesigns(at)att.net > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Plans Question > Date: Fri, 27 Aug 2010 22:57:58 -0700 > > > True Mike but look on the steel split axel gear page upper right drawing, it > clearly says the front ash cross piece is 2"x1" with the ends tapered to > 3/4". > > Fortunately either way works. > > Now on the original fuselage (wood landing gear) there are no ash cross > braces. There are 1"x3/4" spruce cross braces. What orientation the 1" > dimension should be is debatable. > > Welcome to the world of Pietenpol drawings. > > Chris > Sacramento, Ca > Westcoastpiet.com > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael > Perez > Sent: Friday, August 27, 2010 3:06 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Plans Question > > --> > > Just checked my plans and both ash pieces are shown on the fuselage page. > Both pieces are 3/4" X 2". > > Yes, I really should keep the floor and shop a little cleaner. > > > Michael Perez > Karetaker Aero > Www.karetakeraero.com > > > > > > > > > > ________________________________________________________________________________
Date: Aug 28, 2010
Hi Michael, The "original" plans (that we can still find) would be the drawings that were published in the 1932 Flying and Glider Manual. Those contain the shortest fuselage, the wood landing gear, etc. They are obviously very small drawings compared to full size plans, and would be a little difficult to build from. The plans available from the family are the "Improved" plans from '33. The "improvements" are the split axle gear, slightly longer fuselage, and I don't recall the rest of the top of my head. Ryan Sent from my iPhone On Aug 28, 2010, at 10:21 AM, Michael Perez wrote: The original question was referring to the "wood" landing gear, not the split axle. Those wood pieces would be different for the different style gear used. I am curious as to what the "original fuselage" plans are. My fuselage plan is dated 1933 and shows the 2" X 3/4" ash. Michael Perez Karetaker Aero www.karetakeraero.com --- On *Sat, 8/28/10, Chris * wrote: From: Chris <catdesigns(at)att.net> Subject: RE: Pietenpol-List: Plans Question Date: Saturday, August 28, 2010, 1:57 AM http://us.mc833.mail.yahoo.com/mc/compose?to=catdesigns@att.net> > True Mike but look on the steel split axel gear page upper right drawing, it clearly says the front ash cross piece is 2"x1" with the ends tapered to 3/4". Fortunately either way works. Now on the original fuselage (wood landing gear) there are no ash cross braces. There are 1"x3/4" spruce cross braces. What orientation the 1" dimension should be is debatable. Welcome to the world of Pietenpol drawings. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server@matronics.com<http://us.mc833.mail.yahoo.com/mc/compose?to=owner-pietenpol-list-server@matronics.com> [mailto:owner-pietenpol-list-server@matronics.com<http://us.mc833.mail.yahoo.com/mc/compose?to=owner-pietenpol-list-server@matronics.com>] On Behalf Of Michael Perez Sent: Friday, August 27, 2010 3:06 PM Subject: Re: Pietenpol-List: Plans Question --> http://us.mc833.mail.yahoo.com/mc/compose?to=speedbrake@sbcglobal.net> > Just checked my plans and both ash pieces are shown on the fuselage page. Both pieces are 3/4" X 2". Yes, I really should keep the floor and shop a little cleaner. Michael Perez Karetaker Aero Www.karetakeraero.com http://www.matronics.com/Navigator?Pietenpol-List< --> http://forums.matronbsp; - List Contribution Web Site -http://www====================== <http://forums.matronics.com/> <http://forums.matronics.com/> <http://forums.matronics.com/> * * ________________________________________________________________________________
Date: Aug 28, 2010
Am going to add a skull cap spinner on my corvair also, figure it may improve airflow around the center of the prop a little. rick On Fri, Aug 27, 2010 at 8:13 PM, skellytown flyer wrote: > skellflyer1(at)yahoo.com> > > Thanks- and after re-reading the post it should have said about 224 was the > highest CHT I saw. and I ran it again at Dusk when I could see the timing > mark a lot better and I had it dead on 32 degrees. a little cooler air temp > and I didn't make as many runs it never got over about 202 CHT. I will > install the top cowl now and may even put the big spinner back on- Wynn > claims it adds a lot to the cooling and air flow I think. I like the looks a > lot better without it but guess performance is something too. I'd kinda like > to find a cheap deal on one of the little skull cap type spinners. now if I > could get the dad gummed Datcon brand tach to calibrate. Raymond do not > archive. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310336#310336 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Plans question
Date: Aug 28, 2010
Ryan said: The "original" plans (that we can still find) would be the drawings that were published in the 1932 Flying and Glider Manual Not so fast Ryan. My recollection is, that there very well might be some early sketches in my possession from the packet of "lost" BHP papers that are entrusted with me, that pre-date the Flying and Glider Manual. Unfort unately, the Costco pickle jar cannot be opened for ANY reason, prior to the "once per calendar year" routine, so as to preserve them from exposur e to oxygen. The next scheduled opening event is 5/25/2011. So FYI y'all might want to get your queries repaired. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Rib drawing
Date: Aug 28, 2010
I received my plans and am about to construct my rib jig on 3/4" MDF. I didn't give much thought to using the supplied rib drawing and instead was going to plot out the shape because so many posts in the archive say not to use it since the drawing is off due to the xerox reproduction. I just double checked the drawing and it seems pretty accurate. The chord is 58" which I assume is correct because it doesn't include the leading or trailing edge. Also the 27 3/4 inch dim given between the spars is spot on. Has the drawing improved from years past? I'm thinking of using it - has anyone else used it instead of plotting it out? Thanks. Jamie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310413#310413 ________________________________________________________________________________
Subject: Re: O-235 purchase
Date: Aug 28, 2010
The interpretation comes into play, when the certified engine has non PMA parts and accessories installed, and is rebuilt by someone other than a person with an A&P rating. If there isn't a paperwork trail on a part going back to Noah and the Ark, it most likely isn't PMA approved, at which time the certified engine does not conform to the TCDS, and is no longer a certified engine. My understanding is, the engine and/or propeller has to conform to the TCDS to continue to be a certified engine. The builder can get a repairman's Certificate after it is completed, but he didn't have one when the engine was rebuilt. Obviously, some FSDO people see this as OK. I suspect there are some who don't see it as OK. My last two cents. I get wound up by involving myself in discussions like this, and begin to wonder why I took the time and went to the expense to get an A&P rating. Especially since I have been looking for a job for nearly 4 months since getting the rating. Everyone wants at least 3 to 5 years experience. -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310416#310416 ________________________________________________________________________________
Date: Aug 28, 2010
Subject: Re: Rib drawing
The 27 3/4 is the important dimension. Go ahead and use it! Ryan Sent from my iPhone On Aug 28, 2010, at 4:35 PM, JGriff wrote: > > I received my plans and am about to construct my rib jig on 3/4" MDF. I didn't give much thought to using the supplied rib drawing and instead was going to plot out the shape because so many posts in the archive say not to use it since the drawing is off due to the xerox reproduction. I just double checked the drawing and it seems pretty accurate. The chord is 58" which I assume is correct because it doesn't include the leading or trailing edge. Also the 27 3/4 inch dim given between the spars is spot on. Has the drawing improved from years past? I'm thinking of using it - has anyone else used it instead of plotting it out? > Thanks. > Jamie > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310413#310413 > > ________________________________________________________________________________
Date: Aug 28, 2010
I used it, I checked the coordinates and also found it right on. rick On Sat, Aug 28, 2010 at 3:35 PM, JGriff wrote: > > I received my plans and am about to construct my rib jig on 3/4" MDF. I > didn't give much thought to using the supplied rib drawing and instead was > going to plot out the shape because so many posts in the archive say not to > use it since the drawing is off due to the xerox reproduction. I just double > checked the drawing and it seems pretty accurate. The chord is 58" which I > assume is correct because it doesn't include the leading or trailing edge. > Also the 27 3/4 inch dim given between the spars is spot on. Has the drawing > improved from years past? I'm thinking of using it - has anyone else used it > instead of plotting it out? > Thanks. > Jamie > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310413#310413 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Aug 28, 2010
My rib layout was the same. Everything measured exactly, so I layed out a straight line on my mdf (after making a copy at Kinkos) and lined it up and applied some spray adhesive and got busy building ribs. If I was to do it again I believe I would seal up the mdf just to make sure no moisture would change it's size...probably not an issue, but couldn't hurt. You could spend countless hours analysing the pros and cons of using that piece of paper. I'm not saying that's a bad idea, just not something that gets me all tingly... Also, right between the nose piece gussets there's enough room to write something...I wrote the date each one came out of the jig..see attached. I say just line it up good and get started. And be sure to let us know how it feels when you take that first rib out of the jig... jm -----Original Message----- >From: JGriff <jgriffith19(at)comcast.net> >Sent: Aug 28, 2010 4:35 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Rib drawing > > >I received my plans and am about to construct my rib jig on 3/4" MDF. I didn't give much thought to using the supplied rib drawing and instead was going to plot out the shape because so many posts in the archive say not to use it since the drawing is off due to the xerox reproduction. I just double checked the drawing and it seems pretty accurate. The chord is 58" which I assume is correct because it doesn't include the leading or trailing edge. Also the 27 3/4 inch dim given between the spars is spot on. Has the drawing improved from years past? I'm thinking of using it - has anyone else used it instead of plotting it out? >Thanks. >Jamie > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=310413#310413 > > ________________________________________________________________________________
Date: Aug 28, 2010
Jamie, As Ryan, Rick and Jim indicated, go ahead and use the supplied drawing without fear. NX18235 was built using that rib drawing and has happily flown 240+ hours. No worries...... Greg Cardinal ----- Original Message ----- From: "JGriff" <jgriffith19(at)comcast.net> Sent: Saturday, August 28, 2010 4:35 PM Subject: Pietenpol-List: Rib drawing > > I received my plans and am about to construct my rib jig on 3/4" MDF. I > didn't give much thought to using the supplied rib drawing and instead was > going to plot out the shape because so many posts in the archive say not > to use it since the drawing is off due to the xerox reproduction. I just > double checked the drawing and it seems pretty accurate. The chord is 58" > which I assume is correct because it doesn't include the leading or > trailing edge. Also the 27 3/4 inch dim given between the spars is spot > on. Has the drawing improved from years past? I'm thinking of using it - > has anyone else used it instead of plotting it out? > Thanks. > Jamie > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310413#310413 > > > ________________________________________________________________________________
Date: Aug 28, 2010
Thanks for the quick answers and encouragement. I'll go with the drawing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310424#310424 ________________________________________________________________________________
Date: Aug 28, 2010
I used it after I measured it like you did. If its spot on for the spar dim ension its on for the rest. Just=C2- the concern is that paper will expand or contact depending on hu midity etc. If you do your rib jig right away its not going to move. Cheers, Jim B. ----- Original Message ----- From: "JGriff" <jgriffith19(at)comcast.net> Sent: Saturday, August 28, 2010 2:35:46 PM Subject: Pietenpol-List: Rib drawing I received my plans and am about to construct my rib jig on 3/4" MDF. I did n't give much thought to using the supplied rib drawing and instead was goi ng to plot out the shape because so many posts in the archive say not to us e it since the drawing is off due to the xerox reproduction. I just double checked the drawing and it seems pretty accurate. The chord is 58" which I assume is correct because it doesn't include the leading or trailing edge. Also the 27 3/4 inch dim given between the spars is spot on. Has the drawin g improved from years past? I'm thinking of using it - has anyone else used it instead of plotting it out? Thanks. Jamie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310413#310413 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Aug 28, 2010
Subject: FSDO's
Guys, one thing that I have found is that every fsdo interperates the FAR's differently.- What one says is- A-O-K, will be a violation with anothe r.- Many of the FAR's are so grey that it takes 10 min of study to interp erate one sentence.- Then, add to that the ego's of some FAA inspectors w ithin the same fsdo.- I have been an A+P for the airlines for 10 + years, and can tell you that those who can't do, supervise, those who can't do ei ther, go to the faa.- My best advise for anyone is when it comes to a maj or concern, such as wheather or not the engine needs an a+p to sign off the overhaul, or changing parts not on the TCDS, etc etc, and it is going to b e a major factor in your making a purchase, call the fsdo and check with th em 1st.- - "We're here to help." - Shad=0A=0A=0A ________________________________________________________________________________
Date: Aug 28, 2010
I used the supplied rib template. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of JGriff Sent: Saturday, August 28, 2010 5:36 PM Subject: Pietenpol-List: Rib drawing I received my plans and am about to construct my rib jig on 3/4" MDF. I didn't give much thought to using the supplied rib drawing and instead was going to plot out the shape because so many posts in the archive say not to use it since the drawing is off due to the xerox reproduction. I just double checked the drawing and it seems pretty accurate. The chord is 58" which I assume is correct because it doesn't include the leading or trailing edge. Also the 27 3/4 inch dim given between the spars is spot on. Has the drawing improved from years past? I'm thinking of using it - has anyone else used it instead of plotting it out? Thanks. Jamie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310413#310413 ________________________________________________________________________________
Date: Aug 28, 2010
Subject: Lycoming 0290 for Piet ?
Help! I have found a local, 0 time since factory remanufacture Lycoming 0290 (125hp) cheap. It is complete. When I say cheap I am talking less than a Covair project. This seems an excessive amount of horsepower for a Piet. Best I can determine this model 0290 weighs 240lb dry. That is not much different than a model =93A=94 from a weigh perspective. Does anyone know o f a successful Piet flying with a 0290? The owner is going to list it Monday so I must act quickly. All thoughts welcome. Thanks, Don ________________________________________________________________________________
Subject: Re: GN-1
Date: Aug 28, 2010
Thanks a bunch Roman/Jeff/Ben/Kevin.. Sorry if I tend to reply late, I fly Int'l cargo and left the message when in Brazil .. or Germany..I think. Yeah, Don in GA said he built a Piet way back when, so I'd think he would understand the drag of a Piet. All excellent stuff. Hmmm, now I'm wondering if I should give the 72x42 pitch that Don said is 'standard' for the A65 some more thought. He did say that it would be plenty safe to change the size/pitch, since I'll be operating it as an experimental. .. larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310438#310438 ________________________________________________________________________________
Subject: Re: Continental A65 to A75 (was GN-1)
Date: Aug 28, 2010
Thanks Dan/Oscar... U guys are the guru's.. I've got the cd's w/maint manuals for the continentals on them and I'm starting to browse and learn from them. This forum is priceless.. Larry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310439#310439 ________________________________________________________________________________
Subject: Re: Lycoming 0290 for Piet ?
Date: Aug 28, 2010
It would definitely raise the service ceiling, and increase the performance if you fly anywhere the density altitude is higher. The excess horsepower won't make a big difference in cruise in anything except fuel consumption, but it will make a difference in take off and climb performance, especially at heavier weights. -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310440#310440 ________________________________________________________________________________
Date: Aug 28, 2010
It's only an excessive amount of power if you open the throttle all the way, and nobody said you need to open the throttle all the way all the time. Extra power is nice to have when you need it! -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310444#310444 ________________________________________________________________________________
Subject: Re: Looking for a piet
From: "taildragger21" <taildragger22003(at)yahoo.com>
Date: Aug 28, 2010
Any more opinions on this plane?? It is a LONG drive..LOL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=310448#310448 ________________________________________________________________________________
Date: Aug 28, 2010
You have a point=2C but I don't think that is interpretation. That would b e bending and some inspectors might be willing to bend more than others. Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Re: O-235 purchase > From: glidermikeg(at)yahoo.com > Date: Sat=2C 28 Aug 2010 14:48:28 -0700 > To: pietenpol-list(at)matronics.com > > > > The interpretation comes into play=2C when the certified engine has non P MA parts and accessories installed=2C and is rebuilt by someone other than a person with an A&P rating. If there isn't a paperwork trail on a part goi ng back to Noah and the Ark=2C it most likely isn't PMA approved=2C at whic h time the certified engine does not conform to the TCDS=2C and is no longe r a certified engine. My understanding is=2C the engine and/or propeller ha s to conform to the TCDS to continue to be a certified engine. The builder can get a repairman's Certificate after it is completed=2C but he didn't ha ve one when the engine was rebuilt. Obviously=2C some FSDO people see this as OK. I suspect there are some who don't see it as OK. > > My last two cents. > > I get wound up by involving myself in discussions like this=2C and begin to wonder why I took the time and went to the expense to get an A&P rating. Especially since I have been looking for a job for nearly 4 months since g etting the rating. Everyone wants at least 3 to 5 years experience. > > -------- > HOMEBUILDER > Will WORK for Spruce > Long flights=2C smooth air=2C and soft landings=2C > GliderMike=2C aka Mike Glasgow > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=310416#310416 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Aug 29, 2010
This is from the 1988 Operator's Manual 60297-9 O-290-D = 260 lb O-290-D2A, D2C = 264 lb O-290-D2B = 265 lb According to the F&G the "A" weighs 244 lb. Add radiator, plumbing and water and you're likely looking at 260 plus lb. So, you guys with A's, how much does that stuff actually weigh? I have both a "D" and a "D2". The difference is 6.5:1 compression ratio on the D and 7.5:1 on the D2. D D2 TO hp 130 140 TO rpm 2800 2800 Rated hp 125 135 Rated rpm 2600 2600 With this kind of power you can balance the rpm/hp to the performance you want, lower rpm, lower hp thus lower fuel burn. The approximate rule of thumb is 0.5 lb of fuel per hp per hour. 2000 rpm on a D2 gives 60 hp. 60 x 0.5 = 30lb/hr. 30lb= 5 gal/hr. The D, at 2025 rpm, should burn 5 gal/hr. So running a prop that will cruise at your desired speed at these rpm will trade off to lesser takeoff and climb performance than these engines are capable of. So the question is, is this tradeoff acceptable to you in your circumstance? Buy the damn engine!!! :-) Clif "Our doubts are traitors, and make us lose the good we oft might win, by fearing to attempt." ....... William Shakespeare I have found a local, 0 time since factory remanufacture Lycoming 0290 (125hp) cheap. It is complete. When I say cheap I am talking less than a Covair project. This seems an excessive amount of horsepower for a Piet. Best I can determine this model 0290 weighs 240lb dry. That is not much different than a model =93A=94 from a weigh perspective. Does anyone know of a successful Piet flying with a 0290? The owner is going to list it Monday so I must act quickly. All thoughts welcome. Thanks, Don ________________________________________________________________________________
Date: Aug 29, 2010
Guys, My C85 had a clean log book to day one. I put new Slick mags on, and
August 18, 2010 - August 29, 2010
Pietenpol-Archive.digest.vol-jn
