Pietenpol-Archive.digest.vol-jp
September 03, 2010 - September 18, 2010
      C-85-12
      Wire Wheels
      Broadhead in 1996
      http://forums.matronics.com/viewtopic.php?p=311248#311248
Subject: Re: Pietenpol airlines shirts
Date: Sep 03, 2010
Before the whole List gets filled with everyone placing their T-Shirt orders, thought it might be a good time to mention that John usually just makes the T-Shirts available through Caf Press, rather than taking orders. (At least that's how his other great designs have been offered). So, it's probably best to just wait till John says the design is available, and then place your orders through the website. (Unless things are different for this design). Of course, seeing all these requests for shirts is probably a good motivator for John to get it done sooner. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311254#311254 ________________________________________________________________________________
Subject: Re: Lee Bottom Fly-In
Date: Sep 03, 2010
Anybody who does not come back smiling from a flight in a Piet obviously has something very wrong with them! :D -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311258#311258 ________________________________________________________________________________
Date: Sep 03, 2010
Subject: Re: Thanks for the input-stits-ceconite-stewart
Stewart system doesn't use any volatile solvents, so you can just use spar varnish. You can use any quality brand. Do yourself and buy it by the gallon. I used 3 quarts just doing my wing. As someone else mentioned, it also works well with Latex paint. Watch the youtube videos for an idea how it works. It is basically like a heat activated contact cement with no odor. I did my covering with bare hands, no respirator, in a closed up shop. It is heat activated, so you can work it as slow or fast as you want, while shrinking your fabric around compound curves, like wing tips and elevator edges. I've used the Randolph systems in their covering seminars at Osh and Sun-n-fun, and would use Stewart Eco-bond again in a heartbeat. Ben Charvet Mims, Fl Took mom (76 years old) for her first Pietenpol ride today On 9/3/2010 7:37 AM, Michael Perez wrote: > You guys using the Stewart's System, did you use their varnish for the > bare wood prior to covering, if not, what brand/type varnish did you use? > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > --- On *Fri, 9/3/10, Dave Sornborger //* wrote: > > > From: Dave Sornborger <dsornbor(at)aol.com> > Subject: Pietenpol-List: Thanks for the input-stits-ceconite-stewart > To: pietenpol-list(at)matronics.com > Date: Friday, September 3, 2010, 7:16 AM > > Thanks Guys,Looks like Stewart is the way to go.Not much into the > toxicity levels of the others,not to mention the KaBoom! factor. > Thanks again.Dave > > *http://www.matronil="nofollow" target="_blank" href="http://forums.matronics.com">http:======================= > > * > > * > > > * ________________________________________________________________________________
Date: Sep 03, 2010
Ben: Good on you, mate! How did you get a 76 year old folded up enough to get into the front 'pit? Tom Stinemetze McPherson, KS. >>> Ben Charvet 9/3/2010 1:03 PM >>> Ben Charvet Mims, Fl Took mom (76 years old) for her first Pietenpol ride today ________________________________________________________________________________
Subject: Re: 40 hour fly-off, state of model A
Date: Sep 03, 2010
Perhaps Im thick or something but is there something different in those prints that would make a plane built from them a more beautiful flying airplane? Since he was referring to flying Allen Rudolph's old Piet and said, if I were to build another Piet I'd do my best to replicate THAT one, I assume there was something he noted about THAT airplane. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311276#311276 ________________________________________________________________________________
Date: Sep 03, 2010
Well, it was a bit of a sarcastic reply. The Allen Rudolf Piet is pretty well built to the plans. Technically, I should have taken a picture of the F&G Manual, because I believe it was supposed to have been constructed from that version of the plans back in the early '30s. The point is that if you want to have a beautiful flying airplane, what's contained in those prints will get you just that. :) Ryan On Fri, Sep 3, 2010 at 1:57 PM, BYD wrote: > > Perhaps I=92m thick or something but is there something different in thos e > prints that would make a plane built from them a more beautiful flying > airplane? Since he was referring to flying Allen Rudolph's old Piet and > said, =93if I were to build another Piet I'd do my best to replicate THAT > one=94, I assume there was something he noted about THAT airplane. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311276#311276 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Sep 03, 2010
Ryan, I certainly won't argue with that, and I wondered if he might have meant that, but I also wondered if there might have been details he noticed when flying it that became obvious during operation. I have only flown in an original but not at the controls. Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311287#311287 ________________________________________________________________________________
Subject: Started my rib jig today
Date: Sep 03, 2010
Used a pneumatic headless pinner for the blocks so it went together fairly quickly. I'm fairly sure I'm going to staple the gussets instead of just clamping so I can try to bang the ribs out fairly quickly. Attached are some photos - does everything look correct? I'm open to any suggestions from you guys on how to improve the jig and the rib building process. Thanks. Jamie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311293#311293 Attachments: http://forums.matronics.com//files/rib2_121.jpg http://forums.matronics.com//files/rib4_439.jpg http://forums.matronics.com//files/rib1_173.jpg ________________________________________________________________________________
Date: Sep 03, 2010
Subject: Re: Started my rib jig today
Jamie: Looks good to me and very close to how I did mine. Note that the two spar spacers you have will be very easy to glue to your ribs unless your put something between the spar spacer and the sticks to be glued. I tried small pieces of waxed paper which worked OK but had to be replaced each time as they would rip when you pulled the glued up spar out of the jig (after the glue cured of course.) I found that coating the spar spacer at the joints with a light coat of Vaseline kept the glue from sticking and made removal from the jig a lot simpler. Your milage may vary. Tom Stinemetze McPherson, KS. >>> "JGriff" 9/3/2010 4:33 PM >>> http://forums.matronics.com//files/rib1_173.jpg ________________________________________________________________________________
Subject: Tailbrace wire idea
Date: Sep 03, 2010
Saw a plane at a fly-in a couple of weeks ago that used a different idea for the tailbrace wires. The plane was a Rans S-6, and I noticed that the tailbrace wires did not have any turnbuckles. The method used to avoid turnbuckles was to put a pattern of staggered holes in the small brackets attached to the cables that get screwed to the tailplanes. If the cable isn't snug enough, move to the next hole. Well, my description probably has you scratching your head as to what I'm trying to explain, so here's a picture: Personally, I think I prefer the traditional turnbuckles, but this method is a lightweight alternative that has some merit. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311298#311298 Attachments: http://forums.matronics.com//files/tailbrace_104.jpg ________________________________________________________________________________
Date: Sep 03, 2010
Jamie its looking=C2- good; get building ribs. Cheers, Jim B. ----- Original Message ----- From: "JGriff" <jgriffith19(at)comcast.net> Sent: Friday, September 3, 2010 2:33:53 PM Subject: Pietenpol-List: Started my rib jig today Used a pneumatic headless pinner for the blocks so it went together fairly quickly. I'm fairly sure I'm going to staple the gussets instead of just cl amping so I can try to bang the ribs out fairly quickly. Attached are some photos - does everything look correct? I'm open to any suggestions from you guys on how to improve the jig and the rib building process. Thanks. Jamie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311293#311293 Attachments: http://forums.matronics.com//files/rib2_121.jpg http://forums.matronics.com//files/rib4_439.jpg http://forums.matronics.com//files/rib1_173.jpg =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Sep 03, 2010
My two cents... If I were building a new rib jig today I think it would be the 612 rib. I would also drill two holes in both vertical upright braces that are next to the wing spars. Instead of nailing the ribs to the spar through the top capstrip as shown in the plans, many builders nail the uprights to the spar. I used a picture frame nailer to squeeze the nails into the spar. Hope you enjoy building your ribs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311304#311304 ________________________________________________________________________________
Date: Sep 03, 2010
My two cents... If I were building a new rib jig today I think it would be the 612 rib. I would also drill two holes in both vertical upright braces that are next to the wing spars. Instead of nailing the ribs to the spar through the top capstrip as shown in the plans, many builders nail the uprights to the spar. I used a picture frame nailer to squeeze the nails into the spar. Hope you enjoy building your ribs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311305#311305 ________________________________________________________________________________
Date: Sep 03, 2010
Mike, I am not aware that they sell varnish, but I used two-part epoxy varnish which is bulletpoof (but expensive). If I were you I would call Dan Stewa rt and ask him. The Stewart's are very good about calling you back with ad vice. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Fri, Sep 3, 2010 6:37 am Subject: Re: Pietenpol-List: Thanks for the input-stits-ceconite-stewart You guys using the Stewart's System, did you use their varnish for the bar e wood prior to covering, if not, what brand/type varnish did you use? Michael Perez Karetaker Aero www.karetakeraero.com --- On Fri, 9/3/10, Dave Sornborger wrote: From: Dave Sornborger <dsornbor(at)aol.com> Subject: Pietenpol-List: Thanks for the input-stits-ceconite-stewart Date: Friday, September 3, 2010, 7:16 AM Thanks Guys,Looks like Stewart is the way to go.Not much into the toxicity levels of the others,not to mention the KaBoom! factor. Thanks again.Dave http://www.matronil="nofollow" target="_blank" href="http://forums.m atronics.com">http:================== ===== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Sep 03, 2010
Subject: Re: Tailbrace wire idea
This is a generally great idea to save weight, money, and some rigging. However, those multiple choice" cross-drilled holes are way too close together. As I understand it, we are supposed to have 2 times the diameter of the hole, from the center of the hole, to the edge of the material or to another such hole. Our BP drawings do not always provide that, either re edges, but these holes shown are very tight to each other. Tim in central TX -----Original Message----- >From: Bill Church <billspiet(at)sympatico.ca> >Sent: Sep 3, 2010 5:20 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Tailbrace wire idea > > >Saw a plane at a fly-in a couple of weeks ago that used a different idea for the tailbrace wires. The plane was a Rans S-6, and I noticed that the tailbrace wires did not have any turnbuckles. The method used to avoid turnbuckles was to put a pattern of staggered holes in the small brackets attached to the cables that get screwed to the tailplanes. If the cable isn't snug enough, move to the next hole. >Well, my description probably has you scratching your head as to what I'm trying to explain, so here's a picture: > >Personally, I think I prefer the traditional turnbuckles, but this method is a lightweight alternative that has some merit. > >Bill C. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=311298#311298 > > >Attachments: > >http://forums.matronics.com//files/tailbrace_104.jpg > > ________________________________________________________________________________
Date: Sep 03, 2010
Good work Jamie, the only thing I did different was add round cams cut from 1" dowels when several of you outside blocks are, made it easier to insert and remove parts (and finished ribs). The dowels are drilled off center and held down with short desk screws. rick On Fri, Sep 3, 2010 at 3:33 PM, JGriff wrote: > > Used a pneumatic headless pinner for the blocks so it went together fairly > quickly. I'm fairly sure I'm going to staple the gussets instead of just > clamping so I can try to bang the ribs out fairly quickly. > Attached are some photos - does everything look correct? > I'm open to any suggestions from you guys on how to improve the jig and the > rib building process. Thanks. > Jamie > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311293#311293 > > > Attachments: > > http://forums.matronics.com//files/rib2_121.jpg > http://forums.matronics.com//files/rib4_439.jpg > http://forums.matronics.com//files/rib1_173.jpg > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Sep 03, 2010
To keep from gluing my rib to my jig, I used pieces of plastic grocery bag, about a 2"x2" square under each joint. After removing the rib from the jig the next day, the plastic will peel right off. I'm not sure it would be a great idea to pull the rib out of the jig before the glue is cured if that's what you meant by "bang the ribs out fairly quickly" I did my ribs one day at a time, and it took over a month. It is a good way to see if you have the stamina to finish the project though. I made a few practice ribs using cheap lumber, and they are still in use as wall decorations. Have fun and enjoy the journey! Ben Charvet Mims, Fl On 9/3/2010 5:33 PM, JGriff wrote: > --> Pietenpol-List message posted by: "JGriff" > > Used a pneumatic headless pinner for the blocks so it went together fairly quickly. I'm fairly sure I'm going to staple the gussets instead of just clamping so I can try to bang the ribs out fairly quickly. > Attached are some photos - does everything look correct? > I'm open to any suggestions from you guys on how to improve the jig and the rib building process. Thanks. > Jamie > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311293#311293 > > > Attachments: > > http://forums.matronics.com//files/rib2_121.jpg > http://forums.matronics.com//files/rib4_439.jpg > http://forums.matronics.com//files/rib1_173.jpg > > ________________________________________________________________________________
Date: Sep 04, 2010
Looks good Jamie. Make sure and steam-bend your upper cap strip. I was at your stage in July of 2000. Keep going little by little. Dan Helsper Poplar Grove, IL. -----Original Message----- From: JGriff <jgriffith19(at)comcast.net> Sent: Fri, Sep 3, 2010 4:33 pm Subject: Pietenpol-List: Started my rib jig today Used a pneumatic headless pinner for the blocks so it went together fairly uickly. I'm fairly sure I'm going to staple the gussets instead of just lamping so I can try to bang the ribs out fairly quickly. ttached are some photos - does everything look correct? 'm open to any suggestions from you guys on how to improve the jig and the rib uilding process. Thanks. amie ead this topic online here: http://forums.matronics.com/viewtopic.php?p=311293#311293 ttachments: http://forums.matronics.com//files/rib2_121.jpg ttp://forums.matronics.com//files/rib4_439.jpg ttp://forums.matronics.com//files/rib1_173.jpg -======================== ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Sep 04, 2010
Well there are a heck of a lot of Rans aircraft out there.I owned an S-12 -they all use the same stainless steel tabs as far as I know-they are thick enough and very nicely made.as far as I know they never had a failure from one.I'm pretty sure Randy Schlitter has tested about all his parts pretty thoroughly before he puts them on the market.he also tells you if you need just a little more tension you can 0put another twist or two in the cable.with the price of turnbuckles these days it makes sense to consider. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311352#311352 ________________________________________________________________________________
Date: Sep 04, 2010
The jig has a layer of 3 mil mylar so hopefully that will be OK. I didn't think about how to keep the epoxy from sticking to the spar spacers I have in place. Guess I'll have to figure out a way to get some wax paper in there. I soaked the first 15" of the top cap strip in hot water for about 20 minutes and clamped it in my former. Seemed to work OK. So even though I'll staple the gussets on I should wait for 24 hours or so before removing the rib to do the other side? Thanks for all the help and encouragement. Jamie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311353#311353 Attachments: http://forums.matronics.com//files/rib6_208.jpg ________________________________________________________________________________
Date: Sep 04, 2010
Subject: Try some paste wax....
Just wax up the spar insert pieces (or anything else you don't want epoxy to stick to....) real good. Epoxy won't stick to wax. You may have to do it the first few times but after a while it will have enough wax embedded that epoxy won't stick to it....ever. I've used paste car wax in the past for epoxy laminations and hollow core wing molds and it worked fine. If you have a composites products store available you can get this stuff called "mold release" which is also just basically wax. Easier (which I like since I'm lazy) than fiddling around with wax paper, etc. jm -----Original Message----- >From: JGriff <jgriffith19(at)comcast.net> >Sent: Sep 4, 2010 8:21 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Started my rib jig today > > >The jig has a layer of 3 mil mylar so hopefully that will be OK. I didn't think about how to keep the epoxy from sticking to the spar spacers I have in place. Guess I'll have to figure out a way to get some wax paper in there. I soaked the first 15" of the top cap strip in hot water for about 20 minutes and clamped it in my former. Seemed to work OK. > >So even though I'll staple the gussets on I should wait for 24 hours or so before removing the rib to do the other side? > >Thanks for all the help and encouragement. >Jamie > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=311353#311353 > > >Attachments: > >http://forums.matronics.com//files/rib6_208.jpg > > ________________________________________________________________________________
Date: Sep 04, 2010
Subject: Re: antenna
Clif, - You are a pleura of information! Thank for the posting. - KMHeide - --- On Fri, 9/3/10, Clif Dawson wrote: From: Clif Dawson <CDAWSON5854(at)shaw.ca> Subject: Re: Pietenpol-List: Re: antenna Date: Friday, September 3, 2010, 1:13 AM The groundplane does not have to be solid. Mine is an aluminum mesh acquired from an art supply house. I've added this antenna article also. My understanding is that you don't have to ground the groundplane to anything else. It IS the " ground " . The coax from the radio is attached to the groundplane. The only concern I have with mine is how it will be affected by the control cabling when I finaly get the thing in the air. Clif oo.com> > > This is good information. I like the idea of an internal ground plane she et even if it isn't too big. I am guessing it needs to be grounded to the n egative battery terminal since it's mounted in a wood fuselage? or maybe on ly the radio grounding from the antenna coax? probably wouldn't matter for the ELT but might with a radio antenna as far as interference. =0A=0A=0A ________________________________________________________________________________
Subject: Re: Try some paste wax....
Date: Sep 04, 2010
That is a great idea! Thanks!. Do not archive. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311366#311366 ________________________________________________________________________________
Date: Sep 04, 2010
You'll want to thoroughly clean the wax off the completed rib before gluing to the spar. If the rib won't stick to the jig it won't stick to the spar. I think I might have used varnish on the that spot on the jib? Don't remember. 1993-1995 -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311398#311398 ________________________________________________________________________________
Subject: Re: leading edge covering
Date: Sep 04, 2010
Thanks for the replies. We'll probably go for the plywood. One more question. Do you add filler strips to the top of the front spar between the ribs so as to have something to attach the rear edge of the covering to? -------- Thanks, Jim Birke Ira G. Ross Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311399#311399 ________________________________________________________________________________
Date: Sep 04, 2010
Real mold release agent is made from PVA (poly-vinyl acetate) and contains no wax. Resins and some epoxies (not sure abobut T-88) can absorb some of the wax and interfere with proper curing and the ability for glue to stick to it when it's supposed to. Just something to consider while building your Piet or any other wood structures... Also avoid any waxes or lubricants containing silicone, as it will interfere with adhesion of finishes like varnish, shellac, etc... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311400#311400 ________________________________________________________________________________
Date: Sep 04, 2010
I forgot to mention, the grocery bag pieces are free, and even reusable. They will stretch to fit the contour you need and are very easy to use. At Sun-n-Fun this year someone made a rib in the rib jig without using any release protection. I wonder how they ever got that rib out..... Ben On 9/4/2010 9:37 PM, Billy McCaskill wrote: > --> Pietenpol-List message posted by: "Billy McCaskill" > > Real mold release agent is made from PVA (poly-vinyl acetate) and contains no wax. Resins and some epoxies (not sure abobut T-88) can absorb some of the wax and interfere with proper curing and the ability for glue to stick to it when it's supposed to. Just something to consider while building your Piet or any other wood structures... > > Also avoid any waxes or lubricants containing silicone, as it will interfere with adhesion of finishes like varnish, shellac, etc... > > -------- > Billy McCaskill > Urbana, IL > tail section almost done, starting on ribs soon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311400#311400 > > ________________________________________________________________________________
Subject: Gussets
Date: Sep 04, 2010
Hello, May be you just talk about gussets, but I do not find anything so I want you to ask and talk about them. Th problem with the gussets begun because I we don't have plywood in 1.5 mm ( 1/16" ) here where I leave. I begun with the wing ribs but the minimun plywood I have is 3 mm and I do not like it, it is so so... So I thought in make mine on replace for the gussets. I started with wood sheets (3), but is very difficult to make becuase it bends too much when I put the adhessive, and are very heavy (i used epoxy). Then I try with 2 sheets of wood and fiberglas in the middle... it look fin, and a last option with only three layers of fiberglass. The one with wood is very strong, the sandwich of wood and fiberglas is ok, and the fiberglass only it is a little soft in bending (my english is very shot as you can see). Reading and googleing I find some articles where talk about even "paper" gussets, so I have a big question and is "what are the gussets for (I suspect) ad how hard have they be, in tension, compression, bending". What do you recommend? May be I can use the 3mm plywood ?.. I want to understand the job the gussets do in the rib. Thank you, best regards. mario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311402#311402 ________________________________________________________________________________
Date: Sep 04, 2010
No, do not support the rear edge of the plywood. When you cover the wing this will allow the plywood to deform slightly and make a smooth transition. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jimbir Sent: Saturday, September 04, 2010 6:24 PM Subject: Pietenpol-List: Re: leading edge covering Thanks for the replies. We'll probably go for the plywood. One more question. Do you add filler strips to the top of the front spar between the ribs so as to have something to attach the rear edge of the covering to? -------- Thanks, Jim Birke Ira G. Ross Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311399#311399 ________________________________________________________________________________
Subject: Re: Gussets
Date: Sep 04, 2010
Hi Mario, If there is a hobby shop near you which sells radio control model airplanes and supplies, 1.5mm plywood should be available there in smaller sheets. It will be more expensive buying it this way than buying full sheets, but if full sheets are not available then this might be your only option for getting the 1.5mm plywood. The 3mm ply will add a LOT of additional weight to your wing ribs, as there are a lot of gussets on each rib and there are 30 ribs to build... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311408#311408 ________________________________________________________________________________
Date: Sep 05, 2010
Hello Mario, There are also several sources on line. This one currently on ebay: item number: 15048268181 $23USD for approx. 18 sq/ft 1.5mm hobby plywood. This is about the same price as Aircraft Spruce & Specialty; approx. $25 for 20 sq/ft. (according to my calculations. I personally purchased from ACS for the convenience and reliability. As with everything, shipping is a factor, but I would check into it. Good luck, Steve Owings, MD -------- Steve www.mypiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311426#311426 ________________________________________________________________________________
Date: Sep 05, 2010
Subject: Okoume plywood
Members of the list: - With the price of Okoume, has anyone found a reasonable source to purchase this type of plywood? With truck shipping varying, thought I would ask befo re prying open my wallet and shelling out some-clams..... - KM Heide- - =0A=0A=0A ________________________________________________________________________________
Subject: Re: Okoume plywood
Date: Sep 05, 2010
I'm lucky and have Boulter about a mile from where I work. They do ship however. http://www.boulterplywood.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311457#311457 ________________________________________________________________________________
Date: Sep 05, 2010
Thank you for the data Steve, here U$S 7 a sheet of an A4 paper size... too much , no? this is why I am traying to build them regards Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311477#311477 ________________________________________________________________________________
Date: Sep 05, 2010
Ken, I'm lucky to have a boat supplier in town. I don't believe they ship, but not sure. Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Sunday, September 05, 2010 12:00 PM Subject: Pietenpol-List: Okoume plywood Members of the list: With the price of Okoume, has anyone found a reasonable source to purchase this type of plywood? With truck shipping varying, thought I would ask before prying open my wallet and shelling out some clams..... KM Heide ________________________________________________________________________________
Subject: Multi Use Power Tool
Date: Sep 05, 2010
All, Harbor Freight http://www.harborfreight.com has that multi use power tool on sale through tomorrow. Jeez they got them in variable speed, battery and air powered now. Mine has actually worked very well. Happy Labor Day all! Jack DSM ________________________________________________________________________________
Subject: Tail Wheel
Date: Sep 05, 2010
List, Today I solved a 2 year old problem - my tail wheel. I knew I had it rigged wrong and contemplated many fixes, including completely rebuilding it. The symptom was too much force was required on the rudder pedals, and when the wheel moved from left to right, the tail lifted a little. I put the question to The List a few months ago and got several helpful responses, including this one from Santiago: http://www.pierceaero.net/tws.php In the end, the most simple fix seemed to be the best one.took about 1 hr! BEFORE AFTER Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (20 ribs down.) ________________________________________________________________________________
Date: Sep 05, 2010
I found mine within driving distance here: http://www.worldpanel.com/ in Riviera Beach, Florida. Try looking at okoume.org, they list a few suppliers that may be closer to you. Ben Charvet On 9/5/2010 12:59 PM, KM Heide CPO/FAAOP wrote: > Members of the list: > > With the price of Okoume, has anyone found a reasonable source to > purchase this type of plywood? With truck shipping varying, thought I > would ask before prying open my wallet and shelling out some clams..... > KM Heide > */ /* > *//* > > > * > > > * ________________________________________________________________________________
Subject: Gotta Motor
Date: Sep 05, 2010
Was able to combine work w/pleasure and traded an airline ticket home from Atlanta for a one-way car rental. Just returned to Dallas from Don's(dream machines) in Griffin, GA w/my newly overhauled A65-8. Glad I googled around and called him. Had to tear out the back seat to get the engine in the car. Not too shabby. 6k cash for a GN-1 airframe... $4,100 total for overhauled engine w/Slick 4333 mags. Need a cheap prop next...hoping for wood...like that look. Hmmm.. now pondering(see photo) all the little nickle&dime stuff (what size engine bolts/airfilter/carb heat box type..etc etc)... Will be digging thru Aircraft Spruce catalog for awhile .. Larry (Garland, TX) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311495#311495 Attachments: http://forums.matronics.com//files/00002_183.jpg http://forums.matronics.com//files/00001_529.jpg http://forums.matronics.com//files/00004_734.jpg ________________________________________________________________________________
Subject: Re: Gotta Motor
Date: Sep 05, 2010
Nice! and the journey continues. -------- Dan Plett N28WH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311498#311498 ________________________________________________________________________________
Subject: Re: Multi Use Power Tool
Date: Sep 05, 2010
I have the variable speed model (Father's Day gift!), and I use it frequently around the house during our remodeling projects, and it works great. A very good tool to have, and for a few jobs that I've tackled it was about the ONLY tool that would do the job. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311500#311500 ________________________________________________________________________________
Date: Sep 06, 2010
Subject: Re: Tail Wheel
Date: Sep 06, 2010
I put those filler pieces in there and wish I hadn't. Oh well, it still fl ies well. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Chris <catdesigns(at)att.net> Sent: Sat, Sep 4, 2010 10:19 pm Subject: RE: Pietenpol-List: Re: leading edge covering No, do not support the rear edge of the plywood. When you cover the wing his will allow the plywood to deform slightly and make a smooth transition . Chris acramento, Ca estcoastpiet.com -----Original Message----- rom: owner-pietenpol-list-server(at)matronics.com mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jimbir ent: Saturday, September 04, 2010 6:24 PM o: pietenpol-list(at)matronics.com ubject: Pietenpol-List: Re: leading edge covering Thanks for the replies. We'll probably go for the plywood. ne more question. Do you add filler strips to the top of the front spar etween the ribs so as to have something to attach the rear edge of the overing to? -------- hanks, Jim Birke ra G. Ross Aerospace Museum ead this topic online here: http://forums.matronics.com/viewtopic.php?p=311399#311399 ======================== =========== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Sep 06, 2010
Quick Google search turned up this list of Boatbuilding Lumber supply houses. Looks like there are a lot of options here: http://www.glen-l.com/resources/lumber-suppliers.html Here is their list for Minnesota: Courtland - Courtland Hardwoods, 321 Main Street, PO Box 35, 56021, 507-359-7811 Maple Grove - Midwest Hardwood Corp., 9540 83rd Ave. North, 55369, 612-425-8700 Minneapolis - Industrial Lumber & Ply, 4100 Washington Ave N, 55412 612/521 4767 St. Bonifacius - Midwest Boat Appeal and Marine Plywood, 4340 Main St, 55375, (952) 446-9611 They also link to a couple other "wood finder" sites. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311527#311527 ________________________________________________________________________________
Date: Sep 06, 2010
I waited about 10 hours before flipping the rib over, one side before going to work then finish the other side after dinner. rick On Sat, Sep 4, 2010 at 7:21 AM, JGriff wrote: > > The jig has a layer of 3 mil mylar so hopefully that will be OK. I didn't > think about how to keep the epoxy from sticking to the spar spacers I have > in place. Guess I'll have to figure out a way to get some wax paper in > there. I soaked the first 15" of the top cap strip in hot water for about 20 > minutes and clamped it in my former. Seemed to work OK. > > So even though I'll staple the gussets on I should wait for 24 hours or so > before removing the rib to do the other side? > > Thanks for all the help and encouragement. > Jamie > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311353#311353 > > > Attachments: > > http://forums.matronics.com//files/rib6_208.jpg > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Sep 06, 2010
Subject: Color suggestions
I've struggled over the looks of my Model A engine and finally realize I need to clean it up and add some color....but I'm not taking it apart to do every little piece individually. I've already removed bits and pieces (started sand blasting yesterday) so I can powder coat the pieces that will fit in the oven. The rest I'll leave assembled and clean/mask and air brush. I already have black and cream and blue powder and matched industrial paint of the same colors and would like to use one or all of those. I don't want to have to buy any new paint. Maybe all black? All black big pieces with the little stuff blue? (Julia doesn't like that idea) Attached is a pretty close picture of my eventual overall paint scheme. Anyone with a better understanding of what might look good have any suggestions for me? Maybe I need to call a share holder's meeting to discuss this? :-) Seriously, I have no idea what would look good but would really appreciate any and all suggestions.... jm ________________________________________________________________________________
Date: Sep 06, 2010
Anyone try cheap hairspray applied to jig before starting each rib? Works a s a mold release for fiberglass layups.. --- On Sat, 9/4/10, Ben Charvet wrote: From: Ben Charvet <bencharvet(at)gmail.com> Subject: Re: Pietenpol-List: Re: Try some paste wax.... Date: Saturday, September 4, 2010, 10:16 PM - I forgot to mention, the grocery bag pieces are free, and even reusable.- They will stretch to fit the contour you need and are very easy to use.- At Sun-n-Fun this year someone made a rib in the rib jig without using any release protection.- I wonder how they ever got that rib out..... Ben On 9/4/2010 9:37 PM, Billy McCaskill wrote: > -->- Pietenpol-List message posted by: "Billy McCaskill" > > Real mold release agent is made from PVA (poly-vinyl acetate) and contain s no wax.- Resins and some epoxies (not sure abobut T-88) can absorb some of the wax and interfere with proper curing and the ability for glue to st ick to it when it's supposed to.- Just something to consider while buildi ng your Piet or any other wood structures... > > Also avoid any waxes or lubricants containing silicone, as it will interf ere with adhesion of finishes like varnish, shellac, etc... > > -------- > Billy McCaskill > Urbana, IL > tail section almost done, starting on ribs soon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311400#311400 > > le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Sep 06, 2010
Jim, Although I'm conservative, by nature, I really like colorful Piets! I say, "Be bold! Let the paint reflect your out-going personality!" But the frugal side says you have to go with what's in the cupboard (wonder how that orange marking paint and Golden Oak stain will look....?) Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (20 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Monday, September 06, 2010 6:49 AM Subject: Pietenpol-List: Color suggestions I've struggled over the looks of my Model A engine and finally realize I need to clean it up and add some color....but I'm not taking it apart to do every little piece individually. I've already removed bits and pieces (started sand blasting yesterday) so I can powder coat the pieces that will fit in the oven. The rest I'll leave assembled and clean/mask and air brush. I already have black and cream and blue powder and matched industrial paint of the same colors and would like to use one or all of those. I don't want to have to buy any new paint. Maybe all black? All black big pieces with the little stuff blue? (Julia doesn't like that idea) Attached is a pretty close picture of my eventual overall paint scheme. Anyone with a better understanding of what might look good have any suggestions for me? Maybe I need to call a share holder's meeting to discuss this? :-) Seriously, I have no idea what would look good but would really appreciate any and all suggestions.... jm ________________________________________________________________________________
Date: Sep 06, 2010
I bought a sheet of oakume large enough to do my leading edge with lots lef t over from a boat supply place on Long Island. It was very cheap=2C and t hey pre-cut the strips for me. Shipping was negligible. I will dig out th e receipt and give you a name and number in the next day or two. it was so cheap=2C I cannot imagine why anyone would hesitate. Gene Date: Sun=2C 5 Sep 2010 09:59:43 -0700 From: kmheidecpo(at)yahoo.com Subject: Pietenpol-List: Okoume plywood Members of the list: With the price of Okoume=2C has anyone found a reasonable source to purchas e this type of plywood? With truck shipping varying=2C thought I would ask before prying open my wallet and shelling out some clams..... KM Heide ________________________________________________________________________________
Subject: Re: Color suggestions
Date: Sep 06, 2010
Chevy Competition Orange! :) -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311549#311549 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Sep 06, 2010
Ford Blue ----- Original Message ----- From: Billy McCaskill <billmz(at)cox.net> Date: Monday, September 6, 2010 12:36 Subject: Pietenpol-List: Re: Color suggestions > > Chevy Competition Orange! > > :) > > -------- > Billy McCaskill > Urbana, IL > tail section almost done, starting on ribs soon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311549#311549 > > > > > > > > > > ________________________________________________________________________________
Subject: Happy Labor Day
Date: Sep 06, 2010
OK, per Jim Markle's suggestion, I flew my Pietenpol this morning to celepbrate Labor Day, in the grand tradition of one BH Pietenpol. In flying it I found that the airspeed indicator doesn't work (mud dauber in the pitot tube) and the right brake doesn't really stop the wheel from turning, but does make suggestions that the wheel should stop turning. Now I've got to spend the rest of the day bleeding the brakes so I can fly it to Culpepper VA tomorrow. Jack Phillips NX899JP Raleigh, NC ________________________________________________________________________________
Date: Sep 06, 2010
Subject: Re: Happy Labor Day
C'mon Jack, Bernie flew without brakes, even on Labor Day! And our Labor Day flights show that No. 4 exhaust valve is leaking. Ah well, remember, we do this for fun, right?! :'( >OK, per Jim Markle's suggestion, I flew my Pietenpol this morning to >celepbrate Labor Day, in the grand tradition of one BH Pietenpol. >In flying it I found that the airspeed indicator doesn't work (mud >dauber in the pitot tube) and the right brake doesn't really stop >the wheel from turning, but does make suggestions that the wheel >should stop turning. > >Now I've got to spend the rest of the day bleeding the brakes so I >can fly it to Culpepper VA tomorrow. > >Jack Phillips >NX899JP >Raleigh, NC -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Subject: Wing education, please advise..
Date: Sep 06, 2010
We have the plans now, and are going though them in an effort to better understand the construction process and to save a little more money. This question came up: Well I know so and so, who is building a short fues. piet. He says that he has a different wing rib layout, and that layout will provide a better glide ratio that the one in the plans. So and so says that the original one drops like a rock. This is kinda frustrating for me as I want to stick with the plans. Every aircraft has a glide ratio, and you best distance over alt. drop will depend on air density, weight, ect. I also think that this other wing must also have a thicker cord, thus creating more lift, which would produce more drag. More drag equals less airspeed. My thinking is that if it was good enough for Mr. Pietenpol, it's going to be good enough for me. Anyway. What other wing could my Dad's buddy be talking about? What is the glide ratio of the long fues. corvair powered Piet? Is there any problem with the aircraft "dropping like a rock" if the engine quits? I would think no more than any other aircraft, right? Please educate me on these other wing designs people are using, and why you would consider going away from what works, IE the plans. Thanks for the help guys Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311568#311568 ________________________________________________________________________________
Date: Sep 06, 2010
Subject: Re: Wing education, please advise..
> Please educate me on these other wing designs people are using, and why you would consider going away from what works, IE the plans. > Some have used the Riblett airfoil. You can search on it in the archives. I built my wing to the plans, and it has a nicer glide ratio than the Baby Ace I just sold with clipped Cub wings (28 ft). I have found the Pietenpol airfoil to be very satisfactory, with a gentle stall. As you said, why fix it if it isn't broken. Ben ________________________________________________________________________________
Subject: antenna location-on the nose?
Date: Sep 06, 2010
I am struggling with where I can mount the antenna for my ELT right now. I could possibly work some type of a ground plane into the tail section but it would have been a whole lot easier before covering.what would work great is just stick it on the front fuselage cover behind the engine. it is aluminum and would provide a nice ground plane.I don't think it would bother me any up there as far as sight.only thing I'm wondering about it-is would the prop-wash beat it around and destroy it? the thing is maybe 14" long with a spring coil about 2/3 of the way up it so it would catch some blast for sure.also ideally if I did that I'd stick the box itself under the front seat.I know most are behind in the tail section but I didn't see anything in the instructions that said it had to be-just mounted to primary load carrying structures such as longerons,beams,trusses etc. Can anybody tell me if it is a bad idea to use these locations? while it would sure work good for installation-I'm concerned about prop-wash on the nose. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311580#311580 ________________________________________________________________________________
Date: Sep 06, 2010
Made about 200 wing rib gussets today on Labor day. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311582#311582 ________________________________________________________________________________
Date: Sep 06, 2010
Joe, I have flown the Pietenpol, a 4412 and the last wing is the Riblett 612 since 2004, the test that I tried from 3000 Ft, I shut the Ford to idle. glided 9 miles to the airport, had to side slip to the runway, an never touched the throttle until taxi time. And my wing is clipped 2 Ft. All on a 74 Deg. day at 850Ft. airport elevation. It is not slower, and it lifts very well, even when I had a Werner 145 at 348 Lbs of engine up front. I have told this a number of times, If any one wants to check it out check at Brodhead 2011. Only if I can still get in , and remember where the throttle is. Pieti Lowell Don't archive Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311584#311584 ________________________________________________________________________________
Date: Sep 06, 2010
Joe, I really don't think the Riblett is going to give you a better glide ratio. If someone says it 'drops like a rock' they have probably never flown draggy airplanes from this era, and probably never flown a Piet. The Pietenpol wing is a fantastic flying airfoil. I regularly haul 420ish pounds of passenger weight and full fuel of 15 gallons. I have never felt concerned in any way in it's climb. The stall is gentle and VERY slow. On landing you just have to be ready for it to give up it's flying speed quickly, just like any old draggy airplane. If you build it LIGHT and to the plans you will be thrilled with it! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311585#311585 ________________________________________________________________________________
Date: Sep 06, 2010
Joe. By the way , If you look just over the wheel, spot a point on the ground, and If you are flying a Pietenpol airfoil, that is about where you will land. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311587#311587 ________________________________________________________________________________
Date: Sep 06, 2010
Thanks for the replies. So in summery it would seem that there is no adverse side affects to going with a different wing, but the question would remain.. why go that route? Looks like I need to get some stick time in a piet 8) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311588#311588 ________________________________________________________________________________
Date: Sep 06, 2010
winds 33 gusting to 40 Piet is in the hangar. :( -------- Dan Plett N28WH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311592#311592 ________________________________________________________________________________
Date: Sep 06, 2010
> By the way , If you look just over the wheel, spot a point on the ground, and If you are flying a Pietenpol airfoil, that is about where you will land. > Pieti Lowell > Ya that's what my Dad's friend said, and for some reason he's all worried about it. AGH stick with the plans. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311593#311593 ________________________________________________________________________________
Date: Sep 06, 2010
Joe, If you're ever planning to be in the Northeast Ohio area, please look me up. You'd be welcome to get some stick time. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311594#311594 ________________________________________________________________________________
Date: Sep 06, 2010
You are probably refering to the Riblett 612 airfoil. If in doubt always stay with the plans, you will be happy. If I was to build a second Piet/wing I would probably experiment with the 612. Attached a comparison and coordinate for both plus the 613.5 just to make things more confusing. rick On Mon, Sep 6, 2010 at 2:02 PM, j_dunavin wrote: > > We have the plans now, and are going though them in an effort to better > understand the construction process and to save a little more money. > This question came up: > Well I know so and so, who is building a short fues. piet. He says that he > has a different wing rib layout, and that layout will provide a better glide > ratio that the one in the plans. So and so says that the original one drops > like a rock. > This is kinda frustrating for me as I want to stick with the plans. Every > aircraft has a glide ratio, and you best distance over alt. drop will depend > on air density, weight, ect. > I also think that this other wing must also have a thicker cord, thus > creating more lift, which would produce more drag. More drag equals less > airspeed. > My thinking is that if it was good enough for Mr. Pietenpol, it's going to > be good enough for me. > > > Anyway. What other wing could my Dad's buddy be talking about? > What is the glide ratio of the long fues. corvair powered Piet? > Is there any problem with the aircraft "dropping like a rock" if the engine > quits? I would think no more than any other aircraft, right? > > Please educate me on these other wing designs people are using, and why you > would consider going away from what works, IE the plans. > > Thanks for the help guys > Joe > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311568#311568 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Eaa conspiracy?
Date: Sep 06, 2010
As it says in the notes below the obit, these are typically family submitted. I would suspect EAA simply published it as they received it from the family. No conspiracy in my mind... Now if CNN had reported it, I would be a little more skeptical. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311611#311611 ________________________________________________________________________________
Subject: Fly in
Date: Sep 06, 2010
Hey all I just got back from the Blakesburg, Ia. AAA fly in. It is a great fly in. Full of antique airplanes, all OSH rejects. I mean no radios, short grass strip and hundreds of planes you won't see anywhere else in the world. Just look up Antique Airplane Assn. on Google. Dick N. ________________________________________________________________________________
Subject: Re: Fly in
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Sep 06, 2010
www.antiqueairfield.com Lots of good photos on their site right now! Wayne Bressler Jr. Taildraggers, Inc. taildraggersinc.com On Sep 6, 2010, at 8:53 PM, "Dick N" wrote: > Hey all > I just got back from the Blakesburg, Ia. AAA fly in. It is a great fly in . Full of antique airplanes, all OSH rejects. I mean no radios, short gras s strip and hundreds of planes you won't see anywhere else in the world. Ju st look up Antique Airplane Assn. on Google. > Dick N. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: cabane strut length
Date: Sep 06, 2010
Anyone have any good data on Cabane strut length. Can't find dimensions on the drawings. Tom B. ________________________________________________________________________________
From: "Steve Singleton" <slsingleton(at)cvalley.net>
Subject: Split Axel gear width
Date: Sep 06, 2010
Need some advice-I'm setting up my split axel with 19in wheels and useing the plans spec of 56in gear width. Just wondering if this is what most Piets have. Also have the top longerons at about 50in. I do not have the tires mounted yet so height may be a bit more when done. Any advice would be apreciated. Thanks. Steve Singleton ________________________________________________________________________________
Date: Sep 06, 2010
Subject: Re: Fly in
Hey Dick I spent all day Saturday up there and most of Sunday morning. We were driving the Model A around the flight line. They said that was the most planes and people they ever had. To bad we didn't run into to you. On Mon, Sep 6, 2010 at 7:53 PM, Dick N wrote: > Hey all > I just got back from the Blakesburg, Ia. AAA fly in. It is a great fly > in. Full of antique airplanes, all OSH rejects. I mean no radios, short > grass strip and hundreds of planes you won't see anywhere else in the > world. Just look up Antique Airplane Assn. on Google. > Dick N. > > * > > * > > ________________________________________________________________________________
Date: Sep 06, 2010
Tom B. Dimensions are on the drawing "Complete wing strut details for improved aircamper", this is left of the tail wheel drawing and above the drawing with the Ford engine mount details. The dimensions are shown on the detail of the "rear right center strut side view". Many have added an inch or two to the length to ease entry. Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of TOM MICHELLE BRANT Sent: Monday, September 06, 2010 8:49 PM Subject: Pietenpol-List: cabane strut length Anyone have any good data on Cabane strut length. Can't find dimensions on the drawings. Tom B. ________________________________________________________________________________
Date: Sep 06, 2010
No! no! no! Go get yourself some British Railroad Engine Green and paint your engine with that. Then get some BRE yellow and pinstripe the thing. Oh, and all those accessories? Powder coat brass! :-) Of course, if you do that then you have to have a train horn. I don't think you should chop the blue off at the seat though. It looks incomplete. http://www.pietenpolclub.co.uk/#/g-buco/4534056775 Subject: Pietenpol-List: Color suggestions > I've struggled over the looks of my Model A engine and finally realize I > need to clean it up and add some color> > I already have black and cream and blue powder and matched industrial > paint of the same colors and would like to use one or all of those. I > don't want to have to buy any new paint. > > Maybe all black? All black big pieces with the little stuff blue? (Julia > doesn't like that idea) > > Attached is a pretty close picture of my eventual overall paint scheme. > Anyone with a better understanding of what might look good have any > suggestions for me? Maybe I need to call a share holder's meeting to > discuss this? :-) > > Seriously, I have no idea what would look good but would really appreciate > any and all suggestions.... > > jm > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 23:35:00 ________________________________________________________________________________
Date: Sep 07, 2010
CDAWSON5854(at)shaw.ca wrote: > No! no! no! Go get yourself some British Railroad Engine Green and > paint your engine with that. Then get some BRE yellow and pinstripe > the thing. > > > Then all your lacking is a John Deere decal. :) -------- Dan Plett N28WH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311647#311647 ________________________________________________________________________________
Date: Sep 07, 2010
I vote for the ford blue, or for the british railroad green with brass idea Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311648#311648 ________________________________________________________________________________
Date: Sep 07, 2010
>From center of one tire to center of the other, my tread measures 72". I have 21" wheels. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Steve Singleton Sent: Monday, September 06, 2010 11:52 PM Subject: Pietenpol-List: Split Axel gear width Need some advice-I'm setting up my split axel with 19in wheels and useing the plans spec of 56in gear width. Just wondering if this is what most Piets have. Also have the top longerons at about 50in. I do not have the tires mounted yet so height may be a bit more when done. Any advice would be apreciated. Thanks. Steve Singleton ________________________________________________________________________________
Date: Sep 07, 2010
Engine's gotta be black if you keep the paint scheme that you show in the picture. I like the green and brass, but not with that paint scheme. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311655#311655 ________________________________________________________________________________
Date: Sep 07, 2010
NX41CC did not fly this Labor Day. Still in the hangar, working on squawks from the condition inspection. You know how it is... you pull the cowlings and covers to work on one thing and you end up doing half a dozen others. I decided to change the engine thrustline to eliminate some of the left-turning tendency that the rudder trim tab does not correct, as well as a bit of nose-up tendency in cruise. Probably not possible to ever fly the airplane hands-off, but I'm going to work on it. Using washers on the engine mount bolts to put the engine at about 2 degrees downthrust and 2 degrees right thrust. It was set pretty much straight and level in both axes. I also had to remake one of the cooling eyebrow mounting tabs and the bracket that holds it to the engine. Fatigue cracks. We'll see how it flies... should be back in the air this weekend. There is the Critter's Lodge fly-in the 24th through 26th of this month, then Reklaw October 22-24, and then a fly-in at Kingsbury Aerodrome on November 13. Maybe able to make one or two of those. Oscar Zuniga Air Camper NX41CC San Antonio, TX mailto: taildrags(at)hotmail.com website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Sep 07, 2010
Joe, All of the airfoils currently being used will be suitable for the Piet, and the FC-10 - the original, is widely described in these pages. My Piet is being built using a three piece wing, with a center section baggage compartment. The airfoil I've chosen is the Riblett 613.5, which will give me 27% greater baggage compartment volume. If used for a wing tank, 27% greater fuel volume... In a Piet, with such little room for storage, baggage, cockpit covers, etc., increasing the size of a baggage compartment might be the most useful thing you can do to the craft. Since the plane is plans built, scratch built, and the philosophy of Mr. Pietenpol was to try different things, like the Corvair, for example, why not use another airfoil if it provides what you want in the aircraft? Just my .02 worth. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311663#311663 ________________________________________________________________________________
Date: Sep 07, 2010
I may POSSIBLY be taking the RV down to Recklaw so if you make that one....you'll have a place to stay. Don't know for sure yet but sure hoping to make it! jm -----Original Message----- >From: Oscar Zuniga <taildrags(at)hotmail.com> >Sent: Sep 7, 2010 9:18 AM >To: Pietenpol List >Subject: Pietenpol-List: Happy Labor Day > > >NX41CC did not fly this Labor Day. Still in the hangar, >working on squawks from the condition inspection. You >know how it is... you pull the cowlings and covers to >work on one thing and you end up doing half a dozen others. > >I decided to change the engine thrustline to eliminate >some of the left-turning tendency that the rudder trim tab >does not correct, as well as a bit of nose-up tendency in >cruise. Probably not possible to ever fly the airplane >hands-off, but I'm going to work on it. Using washers on >the engine mount bolts to put the engine at about 2 degrees >downthrust and 2 degrees right thrust. It was set pretty >much straight and level in both axes. > >I also had to remake one of the cooling eyebrow mounting >tabs and the bracket that holds it to the engine. Fatigue >cracks. > >We'll see how it flies... should be back in the air this >weekend. There is the Critter's Lodge fly-in the 24th >through 26th of this month, then Reklaw October 22-24, and >then a fly-in at Kingsbury Aerodrome on November 13. Maybe >able to make one or two of those. > >Oscar Zuniga >Air Camper NX41CC >San Antonio, TX >mailto: taildrags(at)hotmail.com >website at http://www.flysquirrel.net > > ________________________________________________________________________________
Subject: Re: Fabric
Date: Sep 07, 2010
Carson - I used the 2.6. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311679#311679 ________________________________________________________________________________
Subject: Continental engine
Date: Sep 07, 2010
Has anyone had experience with a 1954 Continental C-125 Aircraft Engine? There is a guy on the field who is selling one for $500, don't know if it has logs yet or not just saw a post. Brian SLC-UT ________________________________________________________________________________
Subject: Re: Split Axel gear width
Date: Sep 07, 2010
Thanks Jack-I thought this looked a bit narrow. Steve Singleton ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Tuesday, September 07, 2010 6:34 AM Subject: RE: Pietenpol-List: Split Axel gear width From center of one tire to center of the other, my tread measures 72". I have 21" wheels. Jack Phillips NX899JP Raleigh, NC ________________________________________________________________________________
Date: Sep 07, 2010
Subject: Permision to go to Lee Bottom
Well, I got the OK from the "Boss" to go down to the Wood, Fabric, And Tail wheels fly-in.- Now all I need is some good weather for a few days.- Le aving friday about noon, heading home sat, mid afternoon.- Hope to see so me of you there. - Shad=0A=0A=0A ________________________________________________________________________________
Date: Sep 07, 2010
Oscar, Your note on adding washers to change the thrustline reminded me of this article I read recently. I'm not suggesting you did anything wrong by any means, your story simply triggered this in my memory. I just wanted to throw this out to the group as a reminder that it is very important to used tried and proven methods and materials when it comes to airframes, engines and other critical components. In this report, a Stearman lost his engine in flight. "Lost" as in, the engine fell off the airplane. This of course drastically changes the CG and makes the airplane uncontrollable. The Stearman crashed, killing the pilot. The accident investigation determined the cause of the crash was the use of low carbon steel washers on the engine mount bolts. In short, the low-carbon steel washers compressed more than a higher quality washer would've done during aerobatic maneuvers. This reduced tension on the bolts, which resulted in a shearing load being placed on the bolts rather than this load being passed from the mount to the airframe through friction on the washers (no bolt tension = no friction). This allowed the bolts to move slightly, causing fatigue and eventually failure. Prior to reading this, it would've been easy (for me at least) to assume that any steel washer would be adequate. Granted, our engine mounts aren't subject to anywhere near this type of stress...still, its worth the extra pennies in my opinion to use tried and proven parts wherever possible (unless you have the engineering knowledge necessary to deem a part acceptable). http://www.caa.co.za/resource%20center/accidents%20&%20incid/reports/2007/8321.pdf Steve Ruse Norman, OK Quoting Oscar Zuniga : > > > NX41CC did not fly this Labor Day. Still in the hangar, > working on squawks from the condition inspection. You > know how it is... you pull the cowlings and covers to > work on one thing and you end up doing half a dozen others. > > I decided to change the engine thrustline to eliminate > some of the left-turning tendency that the rudder trim tab > does not correct, as well as a bit of nose-up tendency in > cruise. Probably not possible to ever fly the airplane > hands-off, but I'm going to work on it. Using washers on > the engine mount bolts to put the engine at about 2 degrees > downthrust and 2 degrees right thrust. It was set pretty > much straight and level in both axes. > > I also had to remake one of the cooling eyebrow mounting > tabs and the bracket that holds it to the engine. Fatigue > cracks. > > We'll see how it flies... should be back in the air this > weekend. There is the Critter's Lodge fly-in the 24th > through 26th of this month, then Reklaw October 22-24, and > then a fly-in at Kingsbury Aerodrome on November 13. Maybe > able to make one or two of those. > > Oscar Zuniga > Air Camper NX41CC > San Antonio, TX > mailto: taildrags(at)hotmail.com > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Sep 07, 2010
Jack, Steve was asking about the split steel gear, not the wood Jenny-style gear as you have on your plane. On my plans, the split gear is shown as 56" center to center between the wheels. However, the wheels shown on the plans are much more like ATV tires than motorcycle wheels. I think that Don Emch has split gear and motorcycle tires, maybe he will chime in and discuss how he built his landing gear. I see no reason not to make that dimension a bit wider to give better stability while taxiing and during take-off or landing roll-outs... Steve, maybe you should block up your fuselage with saw horses (or whatever it takes) to the proper stance and height to the top longeron that the plane will have while sitting on the ground, and then take the measurements for your landing gear so that you can build it to make it sit like it should. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311711#311711 ________________________________________________________________________________
Date: Sep 07, 2010
Subject: Jeff's camera mount
Jeff, A while back you posted how you mounted your video camera to your Pietenpol, but I can't seem to find how you did it in the archives. Can you elaborate on what you use and how you mount it? I mounted my video camera to the rear cabane on N8031 a couple weeks ago but the vibration of the picture is pretty bad except when the throttle is almost closed. It's either due to the prop wash or the engine vibration, but I'm leaning toward prop wash. Thanks, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 07, 2010
My split gear with 21" inch wheels is 60" ctr to ctr. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311717#311717 Attachments: http://forums.matronics.com//files/img_2681_122.jpg ________________________________________________________________________________
Date: Sep 07, 2010
Subject: A 1930's Aircraft Print
From: Gerry Holland <gholland@content-stream.co.uk>
Hi. Spotted a Print of a range of 1930=B9s Homebuilt Aircraft including Sky Scout and my own Aircraft, a Corben. Some nice models. 3rd item on web page. http://ptatransitauthority.blogspot.com/ Regards Gerry ________________________________________________________________________________
Date: Sep 07, 2010
Subject: Re: Jeff's camera mount
Dan, I bought an inexpensive mini-tripod. The legs are like angle iron in shape. When they are folded together, they can be strapped to a cabane. I use the velcro that the tripod came with plus plenty of electrician's tape. When I screw the camera to the tripod, it's upside-down, but your camera may fit rightside-up. Regardless, keep the camera from touching the tripod. I turn the thumb screw pretty tightly, plus I wrap tape around the perimeter of the camera twice, capturing the thumb screw on either side per turn of tape. There is a photo of a tripod/camera strapped to a tree at this link that is similar to this: http://www.amazon.com/Pedco-UltraPod-Lightweight-Camera-Tripod/dp/B000ANCPNM/ref=pd_sim_dbs_p_13 Note that you can find these tripods on the web for $10 or less. Mine was a promotional Minolta tripod that I got for something like $9 delivered: http://www.campmor.com/outdoor/gear/Product___87557 HTH, Jeff > >Jeff, > >A while back you posted how you mounted your video camera to your >Pietenpol, but I can't seem to find how you did it in the archives. >Can you elaborate on what you use and how you mount it? > >I mounted my video camera to the rear cabane on N8031 a couple weeks >ago but the vibration of the picture is pretty bad except when the >throttle is almost closed. It's either due to the prop wash or the >engine vibration, but I'm leaning toward prop wash. > >Thanks, >Dan > >-- >Dan Yocum >Fermilab 630.840.6509 >yocum@fnal.gov, http://fermigrid.fnal.gov >"I fly because it releases my mind from the tyranny of petty things." -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Sep 07, 2010
Oops. I meant to write: "Keep the camera from touching the cabane." I find if it touches any part of the plane, it picks up vibration in the film pretty badly. > >Dan, > >I bought an inexpensive mini-tripod. The legs are like angle iron in >shape. When they are folded together, they can be strapped to a >cabane. I use the velcro that the tripod came with plus plenty of >electrician's tape. When I screw the camera to the tripod, it's >upside-down, but your camera may fit rightside-up. Regardless, keep >the camera from touching the tripod. I turn the thumb screw pretty >tightly, plus I wrap tape around the perimeter of the camera twice, >capturing the thumb screw on either side per turn of tape. > >There is a photo of a tripod/camera strapped to a tree at this link >that is similar to this: > >http://www.amazon.com/Pedco-UltraPod-Lightweight-Camera-Tripod/dp/B000ANCPNM/ref=pd_sim_dbs_p_13 > >Note that you can find these tripods on the web for $10 or less. >Mine was a promotional Minolta tripod that I got for something like >$9 delivered: > >http://www.campmor.com/outdoor/gear/Product___87557 > >HTH, > >Jeff > ________________________________________________________________________________
Date: Sep 07, 2010
A pretty simple rule to abide by when trying to determine what hardware to use: if it's going on an aircraft, then it should be aircraft grade AN/MS/NAS hardware.... Ryan On Tue, Sep 7, 2010 at 6:34 PM, Dan P wrote: > > That it is. Another concern that goes hand in hand with tried and true > construction is the quality of the fasteners themselves. Many of the bolts > that lumber yards and hardware store sell do not meet the grade rating > stamped on the bolts, nuts and washers. > > One of the local pilots told of a Pitts crash where two people were killed. > The investigation determined that bolts/nuts that fastening the tail had > pulled the threads out of the nut. The bolts were bought at a hardware > store. Be sure your buying quality fasteners. Lawson is one brand I use > that is top quality > > -------- > Dan Plett > N28WH > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311745#311745 > > ________________________________________________________________________________
Date: Sep 07, 2010
One more thought: Check out which airfoil is flying when the ambient temperatures are in the high 90's, and you want to take a friend that weights over 200 , up to cooler air. You just might need an 0200 or more to even get off the runway. Only my experiences of many thousand hours since 1941, has taught me a few well learned lessons. By the way, did Mr Pietenpol ever install a Corvair engine with out the supplied blower ? Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311750#311750 ________________________________________________________________________________
Subject: What to look for in a 3/4 built Pietenpol
Date: Sep 07, 2010
I may go look at a partially built Pietenpol that sounds like it is on its gear and mostly covered. I think it is a short fuselage, 3 piece wing, and has an A65 that has 800 hours but hasn't run in a while. It's been a 10 year project that the builder has lost interest in. Unfortunately I couldn't get a lot of information due to spotty cell phone reception but I'm going to call back later this week to get more info. I may go look at it this weekend but if I do what are some of the things I should look for? Are there some gotchas I should keep an eye open for? I need help coming up with a checklist and questions I should be asking so any help is appreciated. Thanks. Jamie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311751#311751 ________________________________________________________________________________
Date: Sep 07, 2010
>I have my fuselage blocked up and my axles set where the longeron will be >at 51in. The 56 looked a bit narrow so i moved the wheels out to 60in. To >me this still seems narrow. I really enjoy the building process but will be >much glad when this gear is done. Steve S Jack, Steve was asking about the split steel gear, not the wood Jenny-style gear as you have on your plane. On my plans, the split gear is shown as 56" center to center between the wheels. However, the wheels shown on the plans are much more like ATV tires than motorcycle wheels. I think that Don Emch has split gear and motorcycle tires, maybe he will chime in and discuss how he built his landing gear. > > I see no reason not to make that dimension a bit wider to give better > stability while taxiing and during take-off or landing roll-outs... > > Steve, maybe you should block up your fuselage with saw horses (or > whatever it takes) to the proper stance and height to the top longeron > that the plane will have while sitting on the ground, and then take the > measurements for your landing gear so that you can build it to make it sit > like it should. > > -------- > Billy McCaskill > Urbana, IL > tail section almost done, starting on ribs soon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311711#311711 > > > ________________________________________________________________________________
Subject: Review of Blakesburg Antique Aircraft Association flyin
Date: Sep 07, 2010
Went to Blakesburg, Iowa this year for the 4th year in a row - the big difference being that I actually got to fly myself there this time. I flew the GN-1 in on Saturday, September 4th. The weather was absolutely gorgeous! Severe clear with winds out of the west at about 6 mph - direct crosswind for the north/south grass strip. As I landed, I noticed there was a crowd of around 75 - 100 folks in the "peanut gallery" critiquing landings - which means that mine was definitely not as good as I'd have liked it to be - but hey - nothing got damaged... Taxiing to the assigned parking spot on the south east side of the field - it was like going down the red carpet in Hollywood - about 100 people lined the run and camera's were snapping. They pretty much did this to every non-spam-can plane that landed, but it sure made the old girl happy as she putt-putted past the line of Fairchilds, Curtiss Robins, Howard DGA's, Stearmans, Meyers, and a host of other golden oldies. Talk about a slice of heaven! I had probably 75-80 people stop by the plane and talk to me about it - it was amazing how many had actually either built a Piet, were building a Piet, thier grandpa/uncle/dad had build a Piet - or were thinking about building one. There was a ton of interest in this design. The old girl didn't win the dead grass award for the day - but she sure came away happy knowing that even though she's getting a little old - she's can still turn a young man's head... Cheers! Lorin -------- Lorin Miller Waiex N81YX GN-1 N30PP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311753#311753 Attachments: http://forums.matronics.com//files/blakesburgn30pp_153.jpg ________________________________________________________________________________
Date: Sep 07, 2010
My split gear with 8.0x6 tires ends up at 62" tire center to center. rick On Tue, Sep 7, 2010 at 6:31 PM, Steve Singleton wrote: > slsingleton(at)cvalley.net> > > I have my fuselage blocked up and my axles set where the longeron will be >> at 51in. The 56 looked a bit narrow so i moved the wheels out to 60in. To me >> this still seems narrow. I really enjoy the building process but will be >> much glad when this gear is done. Steve S >> > > > Jack, Steve was asking about the split steel gear, not the wood Jenny-style > gear as you have on your plane. On my plans, the split gear is shown as 56" > center to center between the wheels. However, the wheels shown on the plans > are much more like ATV tires than motorcycle wheels. I think that Don Emch > has split gear and motorcycle tires, maybe he will chime in and discuss how > he built his landing gear. > >> >> I see no reason not to make that dimension a bit wider to give better >> stability while taxiing and during take-off or landing roll-outs... >> >> Steve, maybe you should block up your fuselage with saw horses (or >> whatever it takes) to the proper stance and height to the top longeron that >> the plane will have while sitting on the ground, and then take the >> measurements for your landing gear so that you can build it to make it sit >> like it should. >> >> -------- >> Billy McCaskill >> Urbana, IL >> tail section almost done, starting on ribs soon >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=311711#311711 >> >> >> >> >> >> >> >> >> >> >> >> > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Sep 07, 2010
Good rule, Ryan. Hard to go wrong that way... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311763#311763 ________________________________________________________________________________
Date: Sep 07, 2010
I'd say to definately find out what glue was used and the procedure=2C mix ratios etc... Some are very particular on how they're done. Check out the joints as much as you can see them. Are the joints tightly m ade or are there large gaps? Check to see that it is square - bring your o wn measuring tools too. Check weld quality - by quality I guess all you'll be able to see if if the welds look pretty clean and even or are they real ly irregular and full of holes and slag. If you have the plans=2C take them with you and check out as many dimension s as you can. Someone else may pipe up on the engine but I guess first and foremost - doe s it turn over and does it have compression? If it's sat a long time the b earings may be pretty dry - might plan a rebuild into the cost just to be s ure you're not getting screwed. If the price is right and it looks to be of average or better quality=2C yo u probably have a winner. My $0.02 Tom B. > Subject: Pietenpol-List: What to look for in a 3/4 built Pietenpol > From: jgriffith19(at)comcast.net > Date: Tue=2C 7 Sep 2010 17:31:15 -0700 > To: pietenpol-list(at)matronics.com > > > I may go look at a partially built Pietenpol that sounds like it is on it s gear and mostly covered. I think it is a short fuselage=2C 3 piece wing =2C and has an A65 that has 800 hours but hasn't run in a while. It's been a 10 year project that the builder has lost interest in. Unfortunately I co uldn't get a lot of information due to spotty cell phone reception but I'm going to call back later this week to get more info. I may go look at it th is weekend but if I do what are some of the things I should look for? Are t here some gotchas I should keep an eye open for? I need help coming up with a checklist and questions I should be asking so any help is appreciated. > Thanks. > Jamie > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311751#311751 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: Continental engine
Date: Sep 07, 2010
I am vaguely. The only aircraft I remember seeing that used them was the Swift. Continental made a gazillion of this type engine. It was a 6 cylinder version of the C-85. Displacement is 282 cu. in. The C-145 and the O-300 were developed from the C-125 just a little more stroke. C75,C-85 and C-125 cylinders are the same part number. So I would think it would be a pretty good engine design wise. Most of those C-125's on the Swift have been replaced with Lycoming O-360's not from a reliability standpoint but to get more speed and climb. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 Ribs and tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311767#311767 ________________________________________________________________________________
Subject: Re: What to look for in a 3/4 built Pietenpol
Date: Sep 07, 2010
Also find out what type of wood was used in the construction. Not everyone has used spruce to build an airplane with, or aircraft grade plywood. There are acceptable substitutes for spruce, but you can't use just any ol' wood that kinda looks like it might be ok. Look for any major deviations from the plans, and if there are any, ask why they were made. Look at the hardware that was used. Is it AN hardware? Is there a builder's log or any photo documentation of the build? Is there a log with the engine? Sloppy building procedures and processes are usually readily apparent but sometimes the basic craftsmanship can very good but still not be airworthy just because the builder did not have any experience with aircraft building. Building an airplane isn't the same thing as building a nice bookcase for the family room... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311773#311773 ________________________________________________________________________________
Date: Sep 07, 2010
if you cand buy it later found the log think is for 500. the a65 is 2,500 i n groun rusty part needed over hole .. --- On Tue, 9/7/10, brian.e.jardine@l-3com.com wrote: From: brian.e.jardine@l-3com.com <brian.e.jardine@l-3com.com> Subject: Pietenpol-List: Continental engine Date: Tuesday, September 7, 2010, 8:21 AM Has anyone had experience with a 1954 Continental C-125 Aircraft Engine? There is a guy on the field who is selling one for $500, don't know if it has logs yet or not just saw a post. Brian SLC-UT le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Sep 07, 2010
Subject: Re: cabane strut length
hi tom im builder from hanford and my blue print say if you ask about cente r ones mens cockpit be front ones 21-1/4" bolt to bolt and rear ones 20-1/4 " bolt to bolt if you one put in fron side thoses toll guys you need add 2" more in each one. section if you ask for the wing struts is front and back 89- 3/4' plas modification if your add 2"in center one I hope these dates helpyou tanks for lisening jorge from hanford --- On Mon, 9/6/10, TOM MICHELLE BRANT wrote: From: TOM MICHELLE BRANT <tmbrant(at)msn.com> Subject: Pietenpol-List: cabane strut length Date: Monday, September 6, 2010, 8:48 PM Anyone have any good data on Cabane strut length.- Can't find dimensions on the drawings. Tom B. =0A=0A=0A ________________________________________________________________________________
Date: Sep 07, 2010
I think what Pieti is saying is that if you build your plane with the original FC-10 airfoil that you will have a perfectly serviceable, good flying plane. But if you substitute the GA30-612 Riblett airfoil, you will have a much better flying airplane. Based on his experience (lots of it), and not just theory and opinion, I'm inclined to believe what he has to say. Here's a clip where he talks about the merits of the Riblett airfoils and his experience with them... http://www.youtube.com/watch?v=KHHnzw1V5FY I personally plan to build the 612 airfoil for mine, otherwise I am sticking rather tenaciously to the plans (aside from using one of those confounded Crank Snappin' Corvair motors). -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311778#311778 ________________________________________________________________________________
Date: Sep 08, 2010
I measured last night...mine is 62", not 60" as indicated earlier. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311792#311792 ________________________________________________________________________________
Date: Sep 08, 2010
Jamie, Along with the comments above, if you see the builders log, you might ask for any receipts the builder has accumulated... These will show you exactly what was assembled along the way. just my .02. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311793#311793 ________________________________________________________________________________
Date: Sep 08, 2010
Jamie, Along with the comments above, if you see the builders log, you might ask for any receipts the builder has accumulated... These will show you exactly what was assembled along the way. just my .02. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311798#311798 ________________________________________________________________________________
Date: Sep 08, 2010
OK Is this a Pietenpol that is 75%complete or a 3/4 Scale Pietenpol? (LOL) ----- Original Message ----- From: JGriff <jgriffith19(at)comcast.net> Date: Tuesday, September 7, 2010 19:36 Subject: Pietenpol-List: What to look for in a 3/4 built Pietenpol > > I may go look at a partially built Pietenpol that sounds like it is on its gear and mostly covered. I think it is a short fuselage, 3 piece > wing, and has an A65 that has 800 hours but hasn't run in a while. > It's been a 10 year project that the builder has lost interest in. > Unfortunately I couldn't get a lot of information due to spotty > cell phone reception but I'm going to call back later this week to > get more info. I may go look at it this weekend but if I do what > are some of the things I should look for? Are there some gotchas I > should keep an eye open for? I need help coming up with a > checklist and questions I should be asking so any help is appreciated. > Thanks. > Jamie > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311751#311751 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 08, 2010
For those using the GA30-612 or GA30-613.5 airfoils, are you designing your own trusses, or are there standard truss designs for these airfoils? In my search of the archives, I have learned how to use the proper names of the airfoils ( :D )and I have found information that would indicate that a 613.5 may be a good choice for me (at 225lbs). Unfortunately, I have found nothing on truss design for using these with a piet. Thanks for any insight. I hope to start my ribs before the end of the year, and am asking myself the same questions that Joe is asking. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311811#311811 ________________________________________________________________________________
Date: Sep 08, 2010
Subject: Re: Rib drawing
I retract the following statement - I really meant to say that 28 3/4" is a better dimension since 28 3/4" matches the attach points on the fuselage. Dan On 08/29/2010 02:34 PM, Dan Yocum wrote: > I disagree. I think 29" on-center is a better dimension. It matches the 29" between the attach points on the fuse. And even though WW thinks it's a misguided belief that one can shift the wing back and forth to correct for CoG issues, a perfect parallelogram *will* allow for such shifting. I do agree with his assessment that the attach points for the diagonal cabanes should be heavy duty, permanent jobs, if not welded, but that's a different issue. > > Dan > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 08, 2010
On 09/06/2010 03:48 PM, Pieti Lowell wrote: > --> Pietenpol-List message posted by: "Pieti Lowell" > > Joe, > I have flown the Pietenpol, a 4412 and the last wing is the Riblett 612 since 2004, the test that I tried from 3000 Ft, I shut the Ford to idle. glided 9 miles to the airport, had to side slip to the runway, an never touched the throttle until taxi time. And my wing is clipped 2 Ft. > All on a 74 Deg. day at 850Ft. airport elevation. It is not slower, and it lifts very well, even when I had a Werner 145 at 348 Lbs of engine up front. > I have told this a number of times, If any one wants to check it out check at Brodhead 2011. Only if I can still get in , and remember where the throttle is. That's an L/D ratio of about 15:1. Not bad. That's twice as good as a C-152 (~8:1). Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 08, 2010
Gary, For my Riblett 612 rib, I based the number of trusses on the FC-10. I placed the front spar location as the same as the FC-10 and the rear spar at 28-3/4", on center, from the front spar. I made the 5 trusses between the front and rear spar the same size - 8-5/16". The last upright I kept in the same place as the FC-10, so the ailerons will be the same size on the Riblett 612. One thing I'll restate here, when using the Riblett 612, build all 4 cabanes to be the same length. Why? When you place the front and rear spars on the bottom capstrip of the ribs, this will automatically build in a 1 degree of angle of incidence which is what should be used with the Riblett 612 airfoil. Dan On 09/08/2010 09:31 AM, gtche98 wrote: > --> Pietenpol-List message posted by: "gtche98" > > For those using the GA30-612 or GA30-613.5 airfoils, are you designing your own trusses, or are there standard truss designs for these airfoils? In my search of the archives, I have learned how to use the proper names of the airfoils ( :D )and I have found information that would indicate that a 613.5 may be a good choice for me (at 225lbs). Unfortunately, I have found nothing on truss design for using these with a piet. > > Thanks for any insight. I hope to start my ribs before the end of the year, and am asking myself the same questions that Joe is asking. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311811#311811 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: Fly in
Date: Sep 08, 2010
I sawyou there in the Model A. Too bad I didn't know it was you. Next year I am planning on flying down there for a few days. Dick N. ----- Original Message ----- From: Davis Roger To: pietenpol-list(at)matronics.com Sent: Monday, September 06, 2010 11:22 PM Subject: Re: Pietenpol-List: Fly in Hey Dick I spent all day Saturday up there and most of Sunday morning. We were driving the Model A around the flight line. They said that was the most planes and people they ever had. To bad we didn't run into to you. On Mon, Sep 6, 2010 at 7:53 PM, Dick N wrote: Hey all I just got back from the Blakesburg, Ia. AAA fly in. It is a great fly in. Full of antique airplanes, all OSH rejects. I mean no radios, short grass strip and hundreds of planes you won't see anywhere else in the world. Just look up Antique Airplane Assn. on Google. Dick N. " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 08, 2010
Gary, et al, When I took it upon myself to develop the truss pieces, angles, etc., I made a solid model of the entire wing to set things up. My GA30-613.5 Rib Drawing has truss pieces laid out so that the drag and anti-drag wires fit entirely within the trusses without any cutting required. Some Piets - and other wings, as well - have truss pieces cut to make room for the drag wires, and either above or below the cut, there is a splice. Alternatively, some builders have rib spacing of 11 to 13 inches, rather than the plan specified dim. of 12 in. This took several extra hours of time, but the result is clearance all around the truss pieces. I've attached a couple of jpegs that show the layout. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311830#311830 Attachments: http://forums.matronics.com//files/drag_layout_2_196.jpg http://forums.matronics.com//files/drag_layout_983.jpg ________________________________________________________________________________
Date: Sep 08, 2010
Tom, Following your narrative with great interest; "pegs" didn't show up. Al Lyscars ----- Original Message ----- From: tkreiner To: pietenpol-list(at)matronics.com Sent: Wednesday, September 08, 2010 12:40 PM Subject: Pietenpol-List: Re: Wing education, please advise.. Gary, et al, When I took it upon myself to develop the truss pieces, angles, etc., I made a solid model of the entire wing to set things up. My GA30-613.5 Rib Drawing has truss pieces laid out so that the drag and anti-drag wires fit entirely within the trusses without any cutting required. Some Piets - and other wings, as well - have truss pieces cut to make room for the drag wires, and either above or below the cut, there is a splice. Alternatively, some builders have rib spacing of 11 to 13 inches, rather than the plan specified dim. of 12 in. This took several extra hours of time, but the result is clearance all around the truss pieces. I've attached a couple of jpegs that show the layout. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311830#311830 Attachments: http://forums.matronics.com//files/drag_layout_2_196.jpg http://forums.matronics.com//files/drag_layout_983.jpg ________________________________________________________________________________
Date: Sep 08, 2010
Al, Are you reading the email summary, or looking at the actual Matronics forums? I'm able to see the jpegs large as can be... Let me know. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311836#311836 ________________________________________________________________________________
Subject: need a different part
Date: Sep 08, 2010
Raymond check these out... http://www.lathes.co.uk/index.html http://www.wswells.com they helped a bunch with my South Bend... Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of skellytown flyer Sent: Wednesday, September 08, 2010 8:15 AM Subject: Pietenpol-List: need a different part I know it's pretty far off-topic but I stopped working on my project yesterday to help a friend do some machine work on his. we were cutting a groove on a flange on his ancient 17" Leblond lathe and the tool hung-instead of snapping the tool it broke the whole end off the compound rest.I am sure hoping someone knows about an old junked lathe or someone who salvages them we might be able to find parts from.it probably wouldn't have to even be the same brand if the swivel base would bolt down.I'd sure like to get back to my project. I was almost done installing the ELT and ready to do some electrical work in the panel. thanks for any help.and do not archive. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311801#311801 ________________________________________________________________________________
Date: Sep 08, 2010
Tom, I'm plugged into the piet list to receive all mail as it's sent. Didn't see an attachment on your post. Al ----- Original Message ----- From: tkreiner To: pietenpol-list(at)matronics.com Sent: Wednesday, September 08, 2010 12:59 PM Subject: Pietenpol-List: Re: Wing education, please advise.. Al, Are you reading the email summary, or looking at the actual Matronics forums? I'm able to see the jpegs large as can be... Let me know. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311836#311836 ________________________________________________________________________________
Date: Sep 08, 2010
RGlkIHlvdSBzY3JvbGwgdG8gdGhlIGJvdHRvbT8gSSBvZnRlbiBmb3JnZXQgdG8gZG8gdGhhdC4u Lg0KDQpHYXJ5IEJvb3RoZQ0KU2VudCBvbiB0aGUgU3ByaW50riBOb3cgTmV0d29yayBmcm9tIG15 IEJsYWNrQmVycnmuDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiAiQUxBTiBM WVNDQVJTIiA8YWx5c2NhcnNAbXlmYWlycG9pbnQubmV0Pg0KU2VuZGVyOiBvd25lci1waWV0ZW5w b2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbQ0KRGF0ZTogV2VkLCA4IFNlcCAyMDEwIDEzOjMz OjA1IA0KVG86IDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPg0KUmVwbHktVG86IHBpZXRl bnBvbC1saXN0QG1hdHJvbmljcy5jb21TdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IFJlOiBX aW5nIGVkdWNhdGlvbiwgcGxlYXNlIGFkdmlzZS4uDQoNClRoaXMgaXMgYSBtdWx0aS1wYXJ0IG1l c3NhZ2UgaW4gTUlNRSBmb3JtYXQuDQoNCg= ________________________________________________________________________________
Date: Sep 08, 2010
They're not actually "attached" to the email. There are links to the jpegs below the word "Attachments:" To save you time, here are the links that he "Attached" http://forums.matronics.com//files/drag_layout_2_196.jpg http://forums.matronics.com//files/drag_layout_983.jpg Dan On 09/08/2010 12:33 PM, ALAN LYSCARS wrote: > Tom, > I'm plugged into the piet list to receive all mail as it's sent. Didn't > see an attachment on your post. > Al > > ----- Original Message ----- > *From:* tkreiner > *To:* pietenpol-list(at)matronics.com > > *Sent:* Wednesday, September 08, 2010 12:59 PM > *Subject:* Pietenpol-List: Re: Wing education, please advise.. > > > > > Al, > > Are you reading the email summary, or looking at the actual > Matronics forums? > > I'm able to see the jpegs large as can be... > > Let me know. > > -------- > Tom Kreiner > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311836#311836 > > > http://www.matnbsp; via the Web > href="http://forums.matronics.com">http://forums.matronics.com > <http://www.matronics.com/Navigator?Pietenpol-List> > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/c================ > > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 08, 2010
I have many hours flying Cessna 150's, etc and just one ride in a Piet but from that ride and hours flying Cessna's I just have to say if you believe the Piets glide ratio better than a 150's, well we have this bridge for sale here just South of us going to San Francisco. Jim B. ----- Original Message ----- From: "Dan Yocum" <yocum(at)fnal.gov> Sent: Wednesday, September 8, 2010 8:15:26 AM Subject: Re: Pietenpol-List: Re: Wing education, please advise.. On 09/06/2010 03:48 PM, Pieti Lowell wrote: > --> =C2-Pietenpol-List message posted by: "Pieti Lowell" > > Joe, > I have flown the Pietenpol, a 4412 and the last wing is the Riblett 612 s ince 2004, the test that I tried from 3000 Ft, I shut the Ford to idle. gli ded 9 miles to the airport, had to side slip to the runway, an never touche d the throttle until taxi time. And my wing is clipped 2 Ft. > All on a 74 Deg. day =C2-at 850Ft. airport elevation. It is not slower, and it lifts very well, even when I had a Werner 145 at 348 Lbs of engine up front. > I have told this a number of times, If any one wants to check it out =C2 -check at Brodhead 2011. Only if I can still get in , and remember where the throttle is. That's an L/D ratio of about 15:1. =C2-Not bad. =C2-That's twice as goo d as a C-152 (~8:1). Dan -- Dan Yocum Fermilab =C2-630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: Happy Labor Day
Date: Sep 08, 2010
Even with aircraft grade AN/MS/NAS hardware use only new fasteners in critical locations. It is easy and economical to use used bulk surplus bolts but it can be difficult to determine their previous application and how they were stressed in that application. Build it like your life depends on it. :) -------- Dan Plett N28WH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311856#311856 ________________________________________________________________________________
Subject: Re: Wing education, please advise..
Date: Sep 08, 2010
Molto bene Gracia Dan, Al ----- Original Message ----- From: Dan Yocum To: pietenpol-list(at)matronics.com Sent: Wednesday, September 08, 2010 2:01 PM Subject: Re: Pietenpol-List: Re: Wing education, please advise.. They're not actually "attached" to the email. There are links to the jpegs below the word "Attachments:" To save you time, here are the links that he "Attached" http://forums.matronics.com//files/drag_layout_2_196.jpg http://forums.matronics.com//files/drag_layout_983.jpg Dan On 09/08/2010 12:33 PM, ALAN LYSCARS wrote: > Tom, > I'm plugged into the piet list to receive all mail as it's sent. Didn't > see an attachment on your post. > Al > > ----- Original Message ----- > *From:* tkreiner > *To:* pietenpol-list(at)matronics.com > > *Sent:* Wednesday, September 08, 2010 12:59 PM > *Subject:* Pietenpol-List: Re: Wing education, please advise.. > > > > Al, > > Are you reading the email summary, or looking at the actual > Matronics forums? > > I'm able to see the jpegs large as can be... > > Let me know. > > -------- > Tom Kreiner > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311836#311836 > > > http://www.matnbsp; via the Web > href="http://forums.matronics.com">http://forums.matronics.com > <http://www.matronics.com/Navigator?Pietenpol-List> > _p; generous bsp; > href="http://www.matronics.com/contribution">http://www.matronics.com/c ================ > > > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 08, 2010
No personal experience here, just an opinion. Sounds like too much engine for this little plane. http://en.wikipedia.org/wiki/Continental_C-125 1) The C-125 is rated at 125 HP. That's 3 times the power of a Ford A, and 2 times that of a Continental A-65. While it would be nice to have a bit more power, at times, this sounds a bit excessive. 2) It has a dry weight of about 290 lbs. That's a full hundred pounds more than a C-85. Haven't yet heard any builders wish they had built their Piet a bit heavier, but I HAVE heard builders wish they had built lighter. There's been a bit of chatter on the List here lately about using bigger powerplants, mostly as a means to lift bigger pilots. My opinion (and I know nobody asked for it, but here it is anyway - feel free to ignore it) is that if you're planning to stick a big engine in a Piet, you should probably build a bigger Piet to go with it. Probably just scaling everything (wings and tail, too - not just fuselage width) up by 5 or 10% would create enough room for the "full-figured" pilot, and sticking a 100 to 125 HP motor on the nose would be a good match. Of course, anyone thinking about making such a change would need to do (or find someone who is qualified to do) the necessary stress calculations for this "new" aircraft. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311863#311863 ________________________________________________________________________________
Date: Sep 08, 2010
The only change I made in the gear was to add brakes. In doing so I made my hubs so that the center of the rim was offset by 2" outboard to allow room for the drum. In order to allow for the wider hubs I lengthened each axle by 2". This opened my gear tread to 60". In using 19" rims it may seem a bit tall and narrow but it really has never presented a problem. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311869#311869 ________________________________________________________________________________
Date: Sep 08, 2010
Dan, You are correct on the cabane length, I left mine as they were on the drawings and found that when I went to the 612, it required a lot of forward stick pressure to hold straight and level,at speeds over 70. So my questions to you guys, which would be better and or easier, shorten the the forward or lengthen the rear cabanes to remain at 1 degree. It is more complex than one thinks. Pieti Lowell Don't archive ] For those using the GA30-612 or GA30-613.5 airfoils, are you designing your own trusses, or are there standard truss designs for these airfoils? In my search of the archives, I have learned how to use the proper names of the airfoils ( :D )and I have found information that would indicate that a 613.5 may be a good choice for me (at 225lbs). Unfortunately, I have found nothing on truss design for using these with a piet. Thanks for any insight. I hope to start my ribs before the end of the year, and am asking myself the same questions that Joe is asking. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311811#311811 [/quote] -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things."[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311873#311873 ________________________________________________________________________________
Date: Sep 08, 2010
With the original piet airfoil on 92GB, she glides about like a 150 with 20 degrees of flaps.- She weighs in about 735 empty.- With the Corvair We still get 75-80mph at 4.8-5.0 gph.- - Shad --- On Wed, 9/8/10, Jim Boyer wrote: From: Jim Boyer <boyerjrb(at)comcast.net> Subject: Re: Pietenpol-List: Re: Wing education, please advise.. Date: Wednesday, September 8, 2010, 3:11 PM #yiv798603033 p {margin:0;} I have many hours flying Cessna 150's, etc and just one ride in a Piet but from that ride and hours flying Cessna's I just have to say if you believe the Piets glide ratio better than a 150's, well we have this bridge for sale here just South of us going to San Francisco. Jim B. - ----- Original Message ----- From: "Dan Yocum" <yocum(at)fnal.gov> Sent: Wednesday, September 8, 2010 8:15:26 AM Subject: Re: Pietenpol-List: Re: Wing education, please advise.. On 09/06/2010 03:48 PM, Pieti Lowell wrote: > --> -Pietenpol-List message posted by: "Pieti Lowell" > > Joe, > I have flown the Pietenpol, a 4412 and the last wing is the Riblett 612 s ince 2004, the test that I tried from 3000 Ft, I shut the Ford to idle. gli ded 9 miles to the airport, had to side slip to the runway, an never touche d the throttle until taxi time. And my wing is clipped 2 Ft. > All on a 74 Deg. day -at 850Ft. airport elevation. It is not slower, an d it lifts very well, even when I had a Werner 145 at 348 Lbs of engine up front. > I have told this a number of times, If any one wants to check it out -c heck at Brodhead 2011. Only if I can still get in , and remember where the throttle is. That's an L/D ratio of about 15:1. -Not bad. -That's twice as good as a C-152 (~8:1). Dan -- Dan Yocum Fermilab -630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I flp; - - - - - - - - --Matt Dral======= ===== =0A=0A=0A ________________________________________________________________________________
Date: Sep 08, 2010
> So my questions to you guys, which would be better and or easier, shorten the the forward or lengthen the rear cabanes to remain at 1 degree. It is more complex than one thinks. > Pieti Lowell I vote for making the rear cabanes 1" longer, rather than making the front ones shorter. This will give a little bit more room for the passenger who has to squeeze himself into the front office. But on the other hand, no additional streamline tubing material will be required if you were to shorten the front cabanes instead... The end result will yield the required angle of incidence whichever method you choose. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311885#311885 ________________________________________________________________________________
Date: Sep 08, 2010
Bill, Don't forget to beef up the mounts and front end. I would be concerned with the additional stresses up front...my two cents Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: Wednesday, September 08, 2010 4:15 PM Subject: Pietenpol-List: Re: Continental engine No personal experience here, just an opinion. Sounds like too much engine for this little plane. http://en.wikipedia.org/wiki/Continental_C-125 1) The C-125 is rated at 125 HP. That's 3 times the power of a Ford A, and 2 times that of a Continental A-65. While it would be nice to have a bit more power, at times, this sounds a bit excessive. 2) It has a dry weight of about 290 lbs. That's a full hundred pounds more than a C-85. Haven't yet heard any builders wish they had built their Piet a bit heavier, but I HAVE heard builders wish they had built lighter. There's been a bit of chatter on the List here lately about using bigger powerplants, mostly as a means to lift bigger pilots. My opinion (and I know nobody asked for it, but here it is anyway - feel free to ignore it) is that if you're planning to stick a big engine in a Piet, you should probably build a bigger Piet to go with it. Probably just scaling everything (wings and tail, too - not just fuselage width) up by 5 or 10% would create enough room for the "full-figured" pilot, and sticking a 100 to 125 HP motor on the nose would be a good match. Of course, anyone thinking about making such a change would need to do (or find someone who is qualified to do) the necessary stress calculations for this "new" aircraft. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311863#311863 ________________________________________________________________________________
Subject: Re: need a different part
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Sep 08, 2010
Jack thank you very much for the link. I sent an e-mail and hopefully will find something.I can adapt about any brand if the dimensions are close.so if you think of anyone that has some salvage machines I'd sure be glad to hear about them.sure don't want to leave my friend with a broken machine. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311888#311888 ________________________________________________________________________________
Date: Sep 08, 2010
Agreed, Jack. Like I said, a qualified person would need to do all the necessary stress calculations. That would include checking the cross-sections of structural members, as well as all fittings, AND the motor mount/attachment. Not something to monkey around with if one doesn't really know what one is doing. I'm sticking with the plans, and installing a C-75. But if I was a bigger guy, I'd think about a Super Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311889#311889 ________________________________________________________________________________
Date: Sep 08, 2010
Here is another company located in Fairfield, Iowa. They rebuild a lot of machinery. http://www.usedtooling.com/home.php On Wed, Sep 8, 2010 at 8:33 PM, skellytown flyer wrote: > skellflyer1(at)yahoo.com> > > Jack thank you very much for the link. I sent an e-mail and hopefully will > find something.I can adapt about any brand if the dimensions are close.so if > you think of anyone that has some salvage machines I'd sure be glad to hear > about them.sure don't want to leave my friend with a broken machine. Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=311888#311888 > > ________________________________________________________________________________
Date: Sep 08, 2010
Another option, provided the C-125 is serviceable and has logs, it to buy and trade it for another engine more suitable for your Piet. Nobody said that you HAVE TO use this engine if you buy it... kinda like the idea of never turning down a Corvair engine core even if it's not one that's usable for converting for flight use. It might be just the thing that someone else is looking for. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311895#311895 ________________________________________________________________________________
Date: Sep 09, 2010
On 09/08/2010 02:11 PM, Jim Boyer wrote: > I have many hours flying Cessna 150's, etc and just one ride in a Piet > but from that ride and hours flying Cessna's I just have to say > > if you believe the Piets glide ratio better than a 150's, well we have > this bridge for sale here just South of us going to San Francisco. Upon further consideration, I think you're right. 15:1 is pretty extraordinary. The Lancair has an L/D of 13:1. No way a Piet has an L/D better than a Lancair. So, what's going on here? Let me make a couple WAGs. Pieti said the temp was 74 degrees. In the summer, that's a cool day around these parts. That temp wouldn't trigger the productions of thermals. So, maybe it was mid to late afternoon on a sunny day early in the spring or late in the fall with lots of fallow fields around. This would produce some good thermals and they would certainly affect his glide ratio. I've been soaring when there were no clouds and the entire altitude range from 1500-4500' AGL was a lifting band - I could NOT find any sink over many miles of area. It's possible he was gliding in a huge parcel of rising air. What else? He could have had a tailwind. 10mph increases the *effective* glide ratio pretty substantially. Those are 2 things that would increase an aircraft's observed glide ratio. There's a Yahoo! group called airfoil. The moderator has posted Xfoil analysis of the Riblett GA30-612 and the FC-10 airfoils in the "Files" section. Unfortunately, he did the analysis of each airfoil using two different Reynolds numbers, so it's hard to draw a conclusion (though, the Riblett looks better than the FC-10). I just downloaded the Xfoil software and am in the process of learning how to use it. When I do, I'll produce some 9x5 glossies with circles and arrows and a paragraph on the back of each one that compare (at least computationally) the Riblett 612 and FC-10 for the same Reynolds numbers. Stay tuned, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 09, 2010
Keep in mind that the 150 is substantially different than a 152. The flaps are consederably larger and produce much more drag. Having a lot of time teaching in 150s I can say that with anything more than 10deg of flaps the glide isn't very good. With full flaps a 150 will not climb even with full power! Flaps off is a whole other ball game. They float forever. Not ha ving flown a piet I can't compare=2C but with 20deg I would say a 150 glide s like a tripacer with no flaps...not very well. Doug Dever In beautiful Stow Ohio > Date: Thu=2C 9 Sep 2010 08:44:29 -0500 > From: yocum(at)fnal.gov > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Wing education=2C please advise.. > > > > On 09/08/2010 02:11 PM=2C Jim Boyer wrote: > > I have many hours flying Cessna 150's=2C etc and just one ride in a Pie t > > but from that ride and hours flying Cessna's I just have to say > > > > if you believe the Piets glide ratio better than a 150's=2C well we hav e > > this bridge for sale here just South of us going to San Francisco. > > Upon further consideration=2C I think you're right. 15:1 is pretty > extraordinary. The Lancair has an L/D of 13:1. No way a Piet has an > L/D better than a Lancair. > > So=2C what's going on here? Let me make a couple WAGs. Pieti said the > temp was 74 degrees. In the summer=2C that's a cool day around these > parts. That temp wouldn't trigger the productions of thermals. So=2C > maybe it was mid to late afternoon on a sunny day early in the spring or > late in the fall with lots of fallow fields around. This would produce > some good thermals and they would certainly affect his glide ratio. > I've been soaring when there were no clouds and the entire altitude > range from 1500-4500' AGL was a lifting band - I could NOT find any sink > over many miles of area. It's possible he was gliding in a huge parcel > of rising air. > > What else? He could have had a tailwind. 10mph increases the > *effective* glide ratio pretty substantially. > > Those are 2 things that would increase an aircraft's observed glide ratio . > > There's a Yahoo! group called airfoil. The moderator has posted Xfoil > analysis of the Riblett GA30-612 and the FC-10 airfoils in the "Files" > section. Unfortunately=2C he did the analysis of each airfoil using two > different Reynolds numbers=2C so it's hard to draw a conclusion (though =2C > the Riblett looks better than the FC-10). I just downloaded the Xfoil > software and am in the process of learning how to use it. When I do=2C > I'll produce some 9x5 glossies with circles and arrows and a paragraph > on the back of each one that compare (at least computationally) the > Riblett 612 and FC-10 for the same Reynolds numbers. > > Stay tuned=2C > Dan > > -- > Dan Yocum > Fermilab 630.840.6509 > yocum@fnal.gov=2C http://fermigrid.fnal.gov > "I fly because it releases my mind from the tyranny of petty things." > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 09, 2010
Might be worth calling Don(don's dream machines) and just chat about it. He's got a hangar full of Continental parts..rebuilds engines for cheap. Does good work they say. Might lead to something..might not.. It lead to me just buying an A65 off a cub he overhauled for me for cheap.. Larry Don Swords(770)412-8885 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=311922#311922 ________________________________________________________________________________
Date: Sep 09, 2010
Sounds good Dan; looking forward to seeing what the analysis points out. Jim B. ----- Original Message ----- From: "Dan Yocum" <yocum(at)fnal.gov> Sent: Thursday, September 9, 2010 6:44:29 AM Subject: Re: Pietenpol-List: Re: Wing education, please advise.. On 09/08/2010 02:11 PM, Jim Boyer wrote: > I have many hours flying Cessna 150's, etc and just one ride in a Piet > but from that ride and hours flying Cessna's I just have to say > > if you believe the Piets glide ratio better than a 150's, well we have > this bridge for sale here just South of us going to San Francisco. Upon further consideration, I think you're right. 15:1 is pretty extraordinary. The Lancair has an L/D of 13:1. No way a Piet has an L/D better than a Lancair. So, what's going on here? Let me make a couple WAGs. Pieti said the temp was 74 degrees. In the summer, that's a cool day around these parts. That temp wouldn't trigger the productions of thermals. So, maybe it was mid to late afternoon on a sunny day early in the spring or late in the fall with lots of fallow fields around. This would produce some good thermals and they would certainly affect his glide ratio. I've been soaring when there were no clouds and the entire altitude range from 1500-4500' AGL was a lifting band - I could NOT find any sink over many miles of area. It's possible he was gliding in a huge parcel of rising air. What else? He could have had a tailwind. 10mph increases the *effective* glide ratio pretty substantially. Those are 2 things that would increase an aircraft's observed glide ratio. There's a Yahoo! group called airfoil. The moderator has posted Xfoil analysis of the Riblett GA30-612 and the FC-10 airfoils in the "Files" section. Unfortunately, he did the analysis of each airfoil using two different Reynolds numbers, so it's hard to draw a conclusion (though, the Riblett looks better than the FC-10). I just downloaded the Xfoil software and am in the process of learning how to use it. When I do, I'll produce some 9x5 glossies with circles and arrows and a paragraph on the back of each one that compare (at least computationally) the Riblett 612 and FC-10 for the same Reynolds numbers. Stay tuned, Dan -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 09, 2010
Yes, but without flaps a 150 glides very well and will float in very light breeze or rising air. Jim B. ----- Original Message ----- From: "Doug Dever" <chiefpepperhead(at)hotmail.com> Sent: Thursday, September 9, 2010 7:20:49 AM Subject: RE: Pietenpol-List: Re: Wing education, please advise.. Keep in mind that the 150 is substantially different than a 152. The flaps are consederably larger and produce much more drag. Having a lot of time teaching in 150s I can say that with anything more than 10deg of flaps the glide isn't very good. With full flaps a 150 will not climb even with full power! Flaps off is a whole other ball game. They float forever. Not having flown a piet I can't compare, but with 20deg I would say a 150 glides like a tripacer with no flaps...not very well. Doug Dever In beautiful Stow Ohio > Date: Thu, 9 Sep 2010 08:44:29 -0500 > From: yocum(at)fnal.gov > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Wing education, please advise.. > > > > On 09/08/2010 02:11 PM, Jim Boyer wrote: > > I have many hours flying Cessna 150's, etc and just one ride in a Piet > > but from that ride and hours flying Cessna's I just have to say > > > > if you believe the Piets glide ratio better than a 150's, well we have > > this bridge for sale here just South of us going to San Francisco. > > Upon further consideration, I think you're right. 15:1 is pretty > extraordinary. The Lancair has an L/D of 13:1. No way a Piet has an > L/D better than a Lancair. > > So, what's going on here? Let me make a couple WAGs. Pieti said the > temp was 74 degrees. In the summer, that's a cool day around these > parts. That temp wouldn't trigger the productions of thermals. So, > maybe it was mid to late afternoon on a sunny day early in the spring or > late in the fall with lots of fallow fields around. This would produce > some good thermals and they would certainly affect his glide ratio. > I've been soaring when there were no clouds and the entire altitude > range from 1500-4500' AGL was a lifting band - I could NOT find any sink > over many miles of area. It's possible he was gliding in a huge parcel > of rising air. > > What else? He could have had a tailwind. 10mph increases the > *effective* glide ratio pretty substantially. > > Those are 2 things that would increase an aircraft's observed glide ratio. > > There's a Yahoo! group called airfoil. The moderator has posted Xfoil > analysis of the Riblett GA30-612 and the FC-10 airfoils in the "Files" > section. Unfortunately, he did the analysis of each airfoil using two > different Reynolds numbers, so it's hard to draw a conclusion (though, > the Riblett looks better than the FC-10). I just downloaded the Xfoil > software and am in the process of learning how to use it. When I do, > I'll produce some 9x5 glossies with circles and arrows and a paragraph > on the back of each one that compare (at least computationally) the > Riblett 612 and FC-10 for the same Reynolds numbers. > > Stay tuned, > Dan > > -- > Dan Yocum > Fermilab 630.840.6509 > yocum@fnal.gov, http://fermigrid.fnal.gov > "I fly because it releases my mind from the tyranny of petty things." > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 09, 2010
yes it does. As my description of floats forever indicates. Lowell was sa ying that a Piet glides like a 150 with 20deg of flap. And from what I get from talking with pieters (new word) that sounds about right. Doug Dever In beautiful Stow Ohio > Date: Thu=2C 9 Sep 2010 15:01:35 +0000 > From: boyerjrb(at)comcast.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Wing education=2C please advise.. > > > Yes=2C but without flaps a 150 glides very well and will float in very li ght breeze or rising air. > Jim B. > ________________________________________________________________________________
Date: Sep 10, 2010
Subject: Cabane to engine mount struts
I am using the small aluminum struts from Carlson Aircraft for my cabane struts. I see Carlson also sells aluminum streamline jury struts. I am curious if you all think these jury struts would be adequate for the struts that run from the cabanes to the top engine mounts? http://carlsonaircraft.com/struts.html Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: epoxy resin
Date: Sep 10, 2010
Hey, I'm getting ready to layup my cowling. Any suggestions as to which epoxy resin to use? I'm kinda leaning towards longer pot life as much of what I've ready seems to focus on a race with the stuff curing in the pot. Thanks Douwe ________________________________________________________________________________
Date: Sep 10, 2010
Not sure what you mean by "layup" I've had excellent results with West System, they have different hardeners to alter the set time. Jack, Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Friday, September 10, 2010 9:25 AM Subject: Pietenpol-List: epoxy resin Hey, I'm getting ready to layup my cowling. Any suggestions as to which epoxy resin to use? I'm kinda leaning towards longer pot life as much of what I've ready seems to focus on a race with the stuff curing in the pot. Thanks Douwe ________________________________________________________________________________
Subject: Re: epoxy resin
Date: Sep 10, 2010
Douwe The boat guys really like West Systems for their fiberglass stuff. Easy to measure and work with. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312045#312045 ________________________________________________________________________________
Subject: to weld or not to weld
Date: Sep 10, 2010
To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312054#312054 ________________________________________________________________________________
Date: Sep 10, 2010
Nothing wrong with having someone who knows what they are doing help you out. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bcolleran Sent: Friday, September 10, 2010 12:20 PM Subject: Pietenpol-List: to weld or not to weld --> To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312054#312054 ________________________________________________________________________________
Subject: Re: to weld or not to weld
Date: Sep 10, 2010
Probably smarter to hire it out; braver to do it yourself. I'm not smart or brave, but I am cheap, so I did my own, with gas...feels great to say, "Yeah, I did that." Gary Boothe ------Original Message------ From: bcolleran Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: to weld or not to weld Sent: Sep 10, 2010 12:20 PM To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312054#312054 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Sep 10, 2010
Yesterday I welded several bolts to a small piece of angle iron...to make a little rack to hold extension cords... Didn't matter that: 1. A fan was blowing right into the area where I was welding.... 2. Some welds were good, some weren't..... 3. The flux core wire I was using in my mig machine probably wasn't matched up just right with what I was welding.... 4. I filled in some good size gaps with big gobs of weld.... 5. I did it all about the same way most of my neighbors (mostly farmers) weld up their plows, etc... But for aviation welding ALL of those (plus some!) DO matter. Just make sure (and I'm NOT saying you haven't already confirmed this, I'm just sayin') that your friend knows the special care to be taken when welding 4130...on parts that your life will depend on. I found there to be a few gotcha's that were really surprising. Again, not trying to be an alarmist...just some things to think about. I went through the same questions and later found out I should have asked my friend if he was going to let the welds cool slowly, what kind of rod he was going to use, whether he would/would not normalize (or whether he actually had the equipment to normalize "the proper way"), etc, etc. It's a lot more fun asking those important questions now rather than later.... By the way, if you want to appreciate even MORE what a great welder your friend is, look at some pictures of MY welding!!! :-) jm -----Original Message----- >From: bcolleran <bcolleran(at)comcast.net> >Sent: Sep 10, 2010 2:20 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: to weld or not to weld > > >To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? > >Thanks, > >Bill >N424BK > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > ________________________________________________________________________________
Date: Sep 10, 2010
Shall we begin at the beginning? Welding and welders certifications and designations are only worth the value of the organization providing them. And all with their own nuisances. One would think that a master welder should be able t weld anything for anyone for any reason. Not true! welding science and technology can be very specialized where only the most basic of skills are transferable, like striking and holding a arc. Beyond that its all a different game, fillers, fluxes, heats, passes all become part of the equation in all forms of welding. That's not to say you cant trust your friend but you sold know there are varied differences in certifications and designations. Boiler maker Sprinkler fitter pipe fitter pressure vessel atomic The list becomes as endless as the list of materials. My dad would be considered a Master welder and yet he knew his limitations and would shy away from areas he was not completely confident in his skill level and knowledge, he wouldn't touch the work. Just my opinion for what its worth, good news is that motor mounts is not rocket science but metallurgy sure is close. John In a message dated 9/10/2010 3:22:52 P.M. Eastern Daylight Time, bcolleran(at)comcast.net writes: --> Pietenpol-List message posted by: "bcolleran" To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? Thanks, Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312054#312054 ________________________________________________________________________________
Date: Sep 10, 2010
Douwe=2C System Three's clear coat epoxy has a long pot life and wets out really nic e since it's thinner than other laminating resins. I think it would be ple nty strong especially in something nonstructural like a cowling. But you c an check their tech sheet and compare. It's great stuff to work with. Doug Dever In beautiful Stow Ohio From: douweblumberg(at)earthlink.net Subject: Pietenpol-List: epoxy resin Date: Fri=2C 10 Sep 2010 10:25:02 -0400 Hey=2C I=92m getting ready to layup my cowling. Any suggestions as to which epoxy resin to use? I=92m kinda leaning towards longer pot life as much of what I=92ve ready seems to focus on a race with the stuff curing in the pot. Thanks Douwe ________________________________________________________________________________
Date: Sep 10, 2010
If you weld with gas (oxy acetyline) you don't have to worry about much of the stuff that the TIG/MIG guys have to worry about. But it takes a little practice to lay a good weld and the right rod and torch tip for the job. Gas welding equip. is much cheaper and in my opinion more versatile=2C but I'm also comfortable with it. There is not much to weld on a piet=2C so If you don't have the equipment I'd say hire it done. Doug Dever In beautiful Stow Ohio > Date: Fri=2C 10 Sep 2010 15:57:52 -0400 > From: jim_markle(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: to weld or not to weld > om> > > Yesterday I welded several bolts to a small piece of angle iron...to make a little rack to hold extension cords... > > Didn't matter that: > 1. A fan was blowing right into the area where I was welding.... > 2. Some welds were good=2C some weren't..... > 3. The flux core wire I was using in my mig machine probably wasn't match ed up just right with what I was welding.... > 4. I filled in some good size gaps with big gobs of weld.... > 5. I did it all about the same way most of my neighbors (mostly farmers) weld up their plows=2C etc... > > But for aviation welding ALL of those (plus some!) DO matter. > > Just make sure (and I'm NOT saying you haven't already confirmed this=2C I'm just sayin') that your friend knows the special care to be taken when w elding 4130...on parts that your life will depend on. I found there to be a few gotcha's that were really surprising. > > Again=2C not trying to be an alarmist...just some things to think about. I went through the same questions and later found out I should have asked m y friend if he was going to let the welds cool slowly=2C what kind of rod h e was going to use=2C whether he would/would not normalize (or whether he a ctually had the equipment to normalize "the proper way")=2C etc=2C etc. > > It's a lot more fun asking those important questions now rather than late r.... > > By the way=2C if you want to appreciate even MORE what a great welder you r friend is=2C look at some pictures of MY welding!!! :-) > > jm > > > > -----Original Message----- > >From: bcolleran <bcolleran(at)comcast.net> > >Sent: Sep 10=2C 2010 2:20 PM > >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: to weld or not to weld > > > > > > >To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded o nce a long time ago. What is everyones thoughts? > > > >Thanks=2C > > > >Bill > >N424BK > > > > > > > > > >Read this topic online here: > > > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > > > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 10, 2010
One other thing that I don't see people mentioning much is the FAA A&P Airf rame Handbook. It's a good reference to go to for everything from welding to riveting to fabric work etc. Doug Dever In beautiful Stow Ohio From: AMsafetyC(at)aol.com Date: Fri=2C 10 Sep 2010 16:46:02 -0400 Subject: Re: Pietenpol-List: to weld or not to weld Shall we begin at the beginning? Welding and welders certifications and designations are only worth the valu e of the organization providing them. And all with their own nuisances. One would think that a master welder should be able t weld anything for anyone for any reason. Not true! welding science and technology can be very speci alized where only the most basic of skills are transferable=2C like strikin g and holding a arc. Beyond that its all a different game=2C fillers=2C flu xes=2C heats=2C passes all become part of the equation in all forms of weld ing. That's not to say you cant trust your friend but you sold know there a re varied differences in certifications and designations. Boiler maker Sprinkler fitter pipe fitter pressure vessel atomic The list becomes as endless as the list of materials. My dad would be consi dered a Master welder and yet he knew his limitations and would shy away fr om areas he was not completely confident in his skill level and knowledge =2C he wouldn't touch the work. Just my opinion for what its worth=2C good news is that motor mounts is not rocket science but metallurgy sure is close. John In a message dated 9/10/2010 3:22:52 P.M. Eastern Daylight Time=2C bcollera n(at)comcast.net writes: To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? Thanks=2C Bill N424BK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312054#312054===== ================ ====== - MATRONICS WEB FORUMS ====== ================= - List Contr ibution Web Site sp=3B ========= ================ ________________________________________________________________________________
Subject: instruments
Date: Sep 10, 2010
Well I thought I had a nice looking hour meter in the project I bought from D.J. till I tried to figure out how to hook it up just now.I didn't get any manuals with the project but this nice looking Davtron M 800 Chronometer in the panel. it looks really sharp and I assumed it would function as a hour meter to record total aircraft hours. but just now I called the factory and it seems it's main function is a flight timer or such. I need something like a plain old Hobbs meter.so if anybody needs this thing send me an email.we can talk trade. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312066#312066 ________________________________________________________________________________
Date: Sep 10, 2010
I view my Piet project as a learning experience and welding was something I wanted to learn. I ended up really enjoying welding (as long as I don't have to do it for a living). Your friend could be a great resource for learning and inspecting. rick On Fri, Sep 10, 2010 at 1:20 PM, bcolleran wrote: > > To weld the or not to weld. That is the question! I have a friend who is > willing to do all the landing gear and motor mount welding for me. He is a > non-aviation guy but is a master welder. I on the other hand have welded > once a long time ago. What is everyones thoughts? > > Thanks, > > Bill > N424BK > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312054#312054 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Sep 10, 2010
I have spent nearly as much time cutting/bending/grinding/welding metal as I have cutting/sanding/gluing wood on my project. rick On Fri, Sep 10, 2010 at 2:55 PM, Doug Dever wrote: > If you weld with gas (oxy acetyline) you don't have to worry about much of > the stuff that the TIG/MIG guys have to worry about. But it takes a little > practice to lay a good weld and the right rod and torch tip for the job. > Gas welding equip. is much cheaper and in my opinion more versatile, but I'm > also comfortable with it. There is not much to weld on a piet, so If you > don't have the equipment I'd say hire it done. > > Doug Dever > In beautiful Stow Ohio > > > > Date: Fri, 10 Sep 2010 15:57:52 -0400 > > From: jim_markle(at)mindspring.com > > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: to weld or not to weld > > > > jim_markle(at)mindspring.com> > > > > Yesterday I welded several bolts to a small piece of angle iron...to make > a little rack to hold extension cords... > > > > Didn't matter that: > > 1. A fan was blowing right into the area where I was welding.... > > 2. Some welds were good, some weren't..... > > 3. The flux core wire I was using in my mig machine probably wasn't > matched up just right with what I was welding.... > > 4. I filled in some good size gaps with big gobs of weld.... > > 5. I did it all about the same way most of my neighbors (mostly farmers) > weld up their plows, etc... > > > > But for aviation welding ALL of those (plus some!) DO matter. > > > > Just make sure (and I'm NOT saying you haven't already confirmed this, > I'm just sayin') that your friend knows the special care to be taken when > welding 4130...on parts that your life will depend on. I found there to be a > few gotcha's that were really surprising. > > > > Again, not trying to be an alarmist...just some things to think about. I > went through the same questions and later found out I should have asked my > friend if he was going to let the welds cool slowly, what kind of rod he was > going to use, whether he would/would not normalize (or whether he actually > had the equipment to normalize "the proper way"), etc, etc. > > > > It's a lot more fun asking those important questions now rather than > later.... > > > > By the way, if you want to appreciate even MORE what a great welder your > friend is, look at some pictures of MY welding!!! :-) > > > > jm > > > > > > > > -----Original Message----- > > >From: bcolleran <bcolleran(at)comcast.net> > > >Sent: Sep 10, 2010 2:20 PM > > >To: pietenpol-list(at)matronics.com > > >Subject: Pietenpol-List: to weld or not to weld > > > > bcolleran(at)comcast.net> > > > > > >To weld the or not to weld. That is the question! I have a friend who is > willing to do all the landing gear and motor mount welding for me. He is a > non-aviation guy but is a master welder. I on the other hand have welded > once a long time ago. What is everyones thoughts? > > > > > >Thanks, > > > > > >Bill > > >N424BK > > > > > > > > > > > > > > >Read this topic online here: > > > > > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ========================> > > > > > > * > > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Fabric
Date: Sep 10, 2010
Thanks Kevin I think that I will go with the heavier stuff Happy building Carson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312071#312071 ________________________________________________________________________________
Date: Sep 10, 2010
There's not much to weld on a Piet? Let's see, there's just the aileron horns, the elevator horns, the rudder horn, the control system torque tube, the control sticks, the cabane struts, the lift struts, the landing gear struts (if using the Cub style gear), the engine mount, the aileron pulley fittings, etc., etc. Other than that there's not much welding required. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Doug Dever Sent: Friday, September 10, 2010 4:55 PM Subject: RE: Pietenpol-List: to weld or not to weld If you weld with gas (oxy acetyline) you don't have to worry about much of the stuff that the TIG/MIG guys have to worry about. But it takes a little practice to lay a good weld and the right rod and torch tip for the job. Gas welding equip. is much cheaper and in my opinion more versatile, but I'm also comfortable with it. There is not much to weld on a piet, so If you don't have the equipment I'd say hire it done. Doug Dever In beautiful Stow Ohio > Date: Fri, 10 Sep 2010 15:57:52 -0400 > From: jim_markle(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: to weld or not to weld > > > Yesterday I welded several bolts to a small piece of angle iron...to make a little rack to hold extension cords... > > Didn't matter that: > 1. A fan was blowing right into the area where I was welding.... > 2. Some welds were good, some weren't..... > 3. The flux core wire I was using in my mig machine probably wasn't matched up just right with what I was welding.... > 4. I filled in some good size gaps with big gobs of weld.... > 5. I did it all about the same way most of my neighbors (mostly farmers) weld up their plows, etc... > > But for aviation welding ALL of those (plus some!) DO matter. > > Just make sure (and I'm NOT saying you haven't already confirmed this, I'm just sayin') that your friend knows the special care to be taken when welding 4130...on parts that your life will depend on. I found there to be a few gotcha's that were really surprising. > > Again, not trying to be an alarmist...just some things to think about. I went through the same questions and later found out I should have asked my friend if he was going to let the welds cool slowly, what kind of rod he was going to use, whether he would/would not normalize (or whether he actually had the equipment to normalize "the proper way"), etc, etc. > > It's a lot more fun asking those important questions now rather than later.... > > By the way, if you want to appreciate even MORE what a great welder your friend is, look at some pictures of MY welding!!! :-) > > jm > > > > -----Original Message----- > >From: bcolleran <bcolleran(at)comcast.net> > >Sent: Sep 10, 2010 2:20 PM > >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: to weld or not to weld > > > > > >To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? > > > >Thanks, > > > >Bill > >N424BK > > > > > > > > > >Read this topic online here: > > > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > > > > > > > > > > > > > > > > > > > > > > > > ======================= > > > ________________________________________________________________________________
Date: Sep 10, 2010
Oops, I forgot the elevator bellcrank and the journals to support the torque tube, and the rudder pedals, and their supports. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Friday, September 10, 2010 8:22 PM Subject: RE: Pietenpol-List: to weld or not to weld There's not much to weld on a Piet? Let's see, there's just the aileron horns, the elevator horns, the rudder horn, the control system torque tube, the control sticks, the cabane struts, the lift struts, the landing gear struts (if using the Cub style gear), the engine mount, the aileron pulley fittings, etc., etc. Other than that there's not much welding required. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Doug Dever Sent: Friday, September 10, 2010 4:55 PM Subject: RE: Pietenpol-List: to weld or not to weld If you weld with gas (oxy acetyline) you don't have to worry about much of the stuff that the TIG/MIG guys have to worry about. But it takes a little practice to lay a good weld and the right rod and torch tip for the job. Gas welding equip. is much cheaper and in my opinion more versatile, but I'm also comfortable with it. There is not much to weld on a piet, so If you don't have the equipment I'd say hire it done. Doug Dever In beautiful Stow Ohio > Date: Fri, 10 Sep 2010 15:57:52 -0400 > From: jim_markle(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: to weld or not to weld > > > Yesterday I welded several bolts to a small piece of angle iron...to make a little rack to hold extension cords... > > Didn't matter that: > 1. A fan was blowing right into the area where I was welding.... > 2. Some welds were good, some weren't..... > 3. The flux core wire I was using in my mig machine probably wasn't matched up just right with what I was welding.... > 4. I filled in some good size gaps with big gobs of weld.... > 5. I did it all about the same way most of my neighbors (mostly farmers) weld up their plows, etc... > > But for aviation welding ALL of those (plus some!) DO matter. > > Just make sure (and I'm NOT saying you haven't already confirmed this, I'm just sayin') that your friend knows the special care to be taken when welding 4130...on parts that your life will depend on. I found there to be a few gotcha's that were really surprising. > > Again, not trying to be an alarmist...just some things to think about. I went through the same questions and later found out I should have asked my friend if he was going to let the welds cool slowly, what kind of rod he was going to use, whether he would/would not normalize (or whether he actually had the equipment to normalize "the proper way"), etc, etc. > > It's a lot more fun asking those important questions now rather than later.... > > By the way, if you want to appreciate even MORE what a great welder your friend is, look at some pictures of MY welding!!! :-) > > jm > > > > -----Original Message----- > >From: bcolleran <bcolleran(at)comcast.net> > >Sent: Sep 10, 2010 2:20 PM > >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: to weld or not to weld > > > > > >To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? > > > >Thanks, > > > >Bill > >N424BK > > > > > > > > > >Read this topic online here: > > > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > > > > > > > > > > > > > > > > > > > > > > > > ======================= > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Sep 11, 2010
Hi Jack, and you forgot the upper cabane strut fittings; each made of 4 pieces of steel welded together. The welding on my Piet was done by a friend who is restoring his own plane, is a licensed pilot, president of our EAA Capter 124 and a professional welder. He was laughing the other day; "I didn't realize how much welding there was in a wooden airplane." Jim ----- Original Message ----- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Friday, September 10, 2010 5:37:24 PM Subject: RE: Pietenpol-List: to weld or not to weld Oops, I forgot the elevator bellcrank and the journals to support the torque tube, and the rudder pedals, and their supports. Jack Phillips NX899JP Raleigh, NC From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Friday, September 10, 2010 8:22 PM Subject: RE: Pietenpol-List: to weld or not to weld Theres not much to weld on a Piet? Lets see, theres just the aileron horns, the elevator horns, the rudder horn, the control system torque tube, the control sticks, the cabane struts, the lift struts, the landing gear struts (if using the Cub style gear), the engine mount, the aileron pulley fittings, etc., etc. Other than that theres not much welding required. Jack Phillips NX899JP Raleigh , NC From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Doug Dever Sent: Friday, September 10, 2010 4:55 PM Subject: RE: Pietenpol-List: to weld or not to weld If you weld with gas (oxy acetyline) you don't have to worry about much of the stuff that the TIG/MIG guys have to worry about. But it takes a little practice to lay a good weld and the right rod and torch tipfor the job. Gas welding equip. is much cheaper and in my opinion more versatile, but I'm also comfortable with it. There is not much to weld on a piet, so If you don't have the equipment I'd say hire it done. Doug Dever In beautiful Stow Ohio > Date: Fri, 10 Sep 2010 15:57:52 -0400 > From: jim_markle(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: to weld or not to weld > > > Yesterday I welded several bolts to a small piece of angle iron...to make a little rack to hold extension cords... > > Didn't matter that: > 1. A fan was blowing right into the area where I was welding.... > 2. Some welds were good, some weren't..... > 3. The flux core wire I was using in my mig machine probably wasn't matched up just right with what I was welding.... > 4. I filled in some good size gaps with big gobs of weld.... > 5. I did it all about the same way most of my neighbors (mostly farmers) weld up their plows, etc... > > But for aviation welding ALL of those (plus some!) DO matter. > > Just make sure (and I'm NOT saying you haven't already confirmed this, I'm just sayin') that your friend knows the special care to be taken when welding 4130...on parts that your life will depend on. I found there to be a few gotcha's that were really surprising. > > Again, not trying to be an alarmist...just some things to think about. I went through the same questions and later found out I should have asked my friend if he was going to let the welds cool slowly, what kind of rod he was going to use, whether he would/would not normalize (or whether he actually had the equipment to normalize "the proper way"), etc, etc. > > It's a lot more fun asking those important questions now rather than later.... > > By the way, if you want to appreciate even MORE what a great welder your friend is, look at some pictures of MY welding!!! :-) > > jm > > > > -----Original Message----- > >From: bcolleran <bcolleran(at)comcast.net> > >Sent: Sep 10, 2010 2:20 PM > >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: to weld or not to weld > > > > > >To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded once a long time ago. What is everyones thoughts? > > > >Thanks, > > > >Bill > >N424BK > > > > > > > > > >Read this topic online here: > > > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > > > > > > > > > > > > > > > > > > > > > > > > ======================== > > ________________________________________________________________________________
Date: Sep 10, 2010
Subject: Re: instruments
The Davtron M 800 Chronometer-is designed as a panel mounted timer to giv e an =0AInstrument Pilot Universal Coordinated Time, Local Time, and-up/d own timers to =0Atime instrument approaches.=0A-Mike Volckmann =0A=0AThe only thing we ever learn from history is that we never learn from history. =0AGeorge Bernard Shaw =0A=0A=0A=0A=0A=0A________________________________ =0AFrom: skellytown flyer <skellflyer1(at)yahoo.com>=0ATo: pietenpol-list@matr onics.com=0ASent: Fri, September 10, 2010 2:13:39 PM=0ASubject: Pietenpol-L er" =0A=0AWell I thought I had a nice looking hour m eter in the project I bought from D.J. =0Atill I tried to figure out how to hook it up just now.I didn't get any manuals =0Awith the project but this nice looking Davtron M 800 Chronometer in the panel. =0Ait looks really sha rp and I assumed it would function as a hour meter to record =0Atotal aircr aft hours. but just now I called the factory and it seems it's main =0Afunc tion is a flight timer or such. I need something like a plain old Hobbs =0A meter.so if anybody needs this thing send me an email.we can talk trade. Ra ymond=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matroni -======================== ________________________________________________________________________________
Subject: Re: Sexy Rib Art
Date: Sep 10, 2010
I like that! If you have an extra one I'm interested. :D -------- Dan Plett N28WH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312104#312104 ________________________________________________________________________________
Subject: Re: Cabane to engine mount struts
Date: Sep 10, 2010
Hi Michael, If you are referring to the jury strut material near the bottom of the page, the stuff with the .375" minor axis dimension, I personally would not use this for the braces that go from the top of the cabane to the engine mounts. It might be strong enough in tension, but if the wing were to somehow try to shift forward in the event of a crash (ask William Wynne about it), those thin alloy struts would buckle and collapse far too easily. Just my non-professional opinion on the matter. I would choose to use the same size material as the cabanes themselves for peace of mind... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312107#312107 ________________________________________________________________________________
Date: Sep 10, 2010
> I think what Pieti is saying is that if you build your plane with the original FC-10 airfoil that you will have a perfectly serviceable, good flying plane. But if you substitute the GA30-612 Riblett airfoil, you will have a much better flying airplane. Based on his experience (lots of it), and not just theory and opinion, I'm inclined to believe what he has to say. Here's a clip where he talks about the merits of the Riblett airfoils and his experience with them... > > http://www.youtube.com/watch?v=KHHnzw1V5FY > > I personally plan to build the 612 airfoil for mine, otherwise I am sticking rather tenaciously to the plans (aside from using one of those confounded Crank Snappin' Corvair motors). Billy, I checked out the video, and he says that he is also getting better cruse speed as well? He really makes it sound like this wing design is the best option for a piet. I mean he even states that he can pull full back elevator with full throttle and climb? Sounds like i should invest some more thought into this other design. Being the guy that I am though I am having some reservation as the plans work and have worked for so long. But like someone else said... Even BP would have tried something different if he though it would be better. Where can I find: A) Rib lay out? B) full wig dinesons, with spars, ailerons, and attachment points? Or is the general wing the same... just different ribs? Urbana hu? Man us northern IL guys got to get together. ( *head scratch*... I guess that's why there is Broadhead hu? ) Anyway I'm with ya on the Corvair motor. OO that's another question: With the extra HP from the corvair motor, would we benefit as much from the Riblet design, as from someone who was using a model A or continental? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312108#312108 ________________________________________________________________________________
Date: Sep 11, 2010
I stated it wrong. There isn't much welding. Yes=2C a lot of little parts . But=2C not a lot of welding. Of course a lot is a relative thing. And m ost of the time I can't relate. Doug Dever In beautiful Stow Ohio From: pietflyr(at)bellsouth.net Subject: RE: Pietenpol-List: to weld or not to weld Date: Fri=2C 10 Sep 2010 20:22:29 -0400 There=92s not much to weld on a Piet? Let=92s see=2C there=92s just the ai leron horns=2C the elevator horns=2C the rudder horn=2C the control system torque tube=2C the control sticks=2C the cabane struts=2C the lift struts =2C the landing gear struts (if using the Cub style gear)=2C the engine mou nt=2C the aileron pulley fittings=2C etc.=2C etc. Other than that there=92 s not much welding required. Jack Phillips NX899JP Raleigh=2C NC From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Doug Dever Sent: Friday=2C September 10=2C 2010 4:55 PM Subject: RE: Pietenpol-List: to weld or not to weld If you weld with gas (oxy acetyline) you don't have to worry about much of the stuff that the TIG/MIG guys have to worry about. But it takes a little practice to lay a good weld and the right rod and torch tip for the job. Gas welding equip. is much cheaper and in my opinion more versatile=2C but I'm also comfortable with it. There is not much to weld on a piet=2C so If you don't have the equipment I'd say hire it done. Doug Dever In beautiful Stow Ohio > Date: Fri=2C 10 Sep 2010 15:57:52 -0400 > From: jim_markle(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: to weld or not to weld > om> > > Yesterday I welded several bolts to a small piece of angle iron...to make a little rack to hold extension cords... > > Didn't matter that: > 1. A fan was blowing right into the area where I was welding.... > 2. Some welds were good=2C some weren't..... > 3. The flux core wire I was using in my mig machine probably wasn't match ed up just right with what I was welding.... > 4. I filled in some good size gaps with big gobs of weld.... > 5. I did it all about the same way most of my neighbors (mostly farmers) weld up their plows=2C etc... > > But for aviation welding ALL of those (plus some!) DO matter. > > Just make sure (and I'm NOT saying you haven't already confirmed this=2C I'm just sayin') that your friend knows the special care to be taken when w elding 4130...on parts that your life will depend on. I found there to be a few gotcha's that were really surprising. > > Again=2C not trying to be an alarmist...just some things to think about. I went through the same questions and later found out I should have asked m y friend if he was going to let the welds cool slowly=2C what kind of rod h e was going to use=2C whether he would/would not normalize (or whether he a ctually had the equipment to normalize "the proper way")=2C etc=2C etc. > > It's a lot more fun asking those important questions now rather than late r.... > > By the way=2C if you want to appreciate even MORE what a great welder you r friend is=2C look at some pictures of MY welding!!! :-) > > jm > > > > -----Original Message----- > >From: bcolleran <bcolleran(at)comcast.net> > >Sent: Sep 10=2C 2010 2:20 PM > >To: pietenpol-list(at)matronics.com > >Subject: Pietenpol-List: to weld or not to weld > > > > > > >To weld the or not to weld. That is the question! I have a friend who is willing to do all the landing gear and motor mount welding for me. He is a non-aviation guy but is a master welder. I on the other hand have welded o nce a long time ago. What is everyones thoughts? > > > >Thanks=2C > > > >Bill > >N424BK > > > > > > > > > >Read this topic online here: > > > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > > > > > > > > > > > > > > > > > > > > > > > > ======================= > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Sep 11, 2010
And don't forget the 4 center strut fittings ?:) rick On Fri, Sep 10, 2010 at 6:37 PM, Jack Phillips wrot e: > Oops, I forgot the elevator bellcrank and the journals to support the > torque tube, and the rudder pedals, and their supports. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Jack Phillips > *Sent:* Friday, September 10, 2010 8:22 PM > > *To:* pietenpol-list(at)matronics.com > *Subject:* RE: Pietenpol-List: to weld or not to weld > > > There=92s not much to weld on a Piet? Let=92s see, there=92s just the ai leron > horns, the elevator horns, the rudder horn, the control system torque tub e, > the control sticks, the cabane struts, the lift struts, the landing gear > struts (if using the Cub style gear), the engine mount, the aileron pulle y > fittings, etc., etc. Other than that there=92s not much welding required . > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Doug Dever > *Sent:* Friday, September 10, 2010 4:55 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* RE: Pietenpol-List: to weld or not to weld > > > If you weld with gas (oxy acetyline) you don't have to worry about much o f > the stuff that the TIG/MIG guys have to worry about. But it takes a litt le > practice to lay a good weld and the right rod and torch tip for the job. > Gas welding equip. is much cheaper and in my opinion more versatile, but I'm > also comfortable with it. There is not much to weld on a piet, so If you > don't have the equipment I'd say hire it done. > > Doug Dever > In beautiful Stow Ohio > > > > Date: Fri, 10 Sep 2010 15:57:52 -0400 > > From: jim_markle(at)mindspring.com > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: to weld or not to weld > > > jim_markle(at)mindspring.com> > > > > Yesterday I welded several bolts to a small piece of angle iron...to ma ke > a little rack to hold extension cords... > > > > Didn't matter that: > > 1. A fan was blowing right into the area where I was welding.... > > 2. Some welds were good, some weren't..... > > 3. The flux core wire I was using in my mig machine probably wasn't > matched up just right with what I was welding.... > > 4. I filled in some good size gaps with big gobs of weld.... > > 5. I did it all about the same way most of my neighbors (mostly farmers ) > weld up their plows, etc... > > > > But for aviation welding ALL of those (plus some!) DO matter. > > > > Just make sure (and I'm NOT saying you haven't already confirmed this, > I'm just sayin') that your friend knows the special care to be taken when > welding 4130...on parts that your life will depend on. I found there to b e a > few gotcha's that were really surprising. > > > > Again, not trying to be an alarmist...just some things to think about. I > went through the same questions and later found out I should have asked m y > friend if he was going to let the welds cool slowly, what kind of rod he was > going to use, whether he would/would not normalize (or whether he actuall y > had the equipment to normalize "the proper way"), etc, etc. > > > > It's a lot more fun asking those important questions now rather than > later.... > > > > By the way, if you want to appreciate even MORE what a great welder you r > friend is, look at some pictures of MY welding!!! :-) > > > > jm > > > > > > > > -----Original Message----- > > >From: bcolleran <bcolleran(at)comcast.net> > > >Sent: Sep 10, 2010 2:20 PM > > >To: pietenpol-list(at)matronics.com > > >Subject: Pietenpol-List: to weld or not to weld > > > > bcolleran(at)comcast.net> > > > > > >To weld the or not to weld. That is the question! I have a friend who is > willing to do all the landing gear and motor mount welding for me. He is a > non-aviation guy but is a master welder. I on the other hand have welded > once a long time ago. What is everyones thoughts? > > > > > >Thanks, > > > > > >Bill > > >N424BK > > > > > > > > > > > > > > >Read this topic online here: > > > > > >http://forums.matronics.com/viewtopic.php?p=312054#312054 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ======================= > > > > > > > > > * * > > * * > > *href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.ma tronics.com/Navigator?Pietenpol-List* > > *href="http://forums.matronics.com">http://forums.matronics.com* > > *href="http://www.matronics.com/contribution">http://www.matronics.com/ c* > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > =========== > =========== =========== =========== > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Wing education, please advise..
Date: Sep 11, 2010
Hi Joe, The only thing that changes when using the Riblett airfoils over the FC-10 is the shape of the rib itself. Nothing else about the wing design changes. You can use the same size spars, the length of the ailerons does not change, same wingspan (although Pieti Lowell's is a little shorter than standard), etc... The coordinates for the Riblett airfoils have been discussed and published here on the list many times, use the search function and it should turn up a spreadsheet with the Riblett GA30-612, GA30-613.5, and the FC-10. The Riblett airfoils should be just as good for the Corvair engine powered Piets as it is for the Ford or Continental/Lycoming/Franklin powered ones. Where in IL are you located? -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312140#312140 ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Sep 11, 2010
I think this has been covered before, but the only real difference is that the 612 and 613.5 cross sections are deeper than the FC, so you will need to fill in the empty space that will exist above the spar at each rib location. There has been some discussion about this, with specific regard to rib incidence - I believe that the consensus is to align the rib centerline 90 degrees to the spar and set the wing incidence (relative to the fuse) by adjusting the cabane lengths? Kip Gardner On Sep 11, 2010, at 11:50 AM, Billy McCaskill wrote: > > > Hi Joe, > > The only thing that changes when using the Riblett airfoils over > the FC-10 is the shape of the rib itself. Nothing else about the > wing design changes. You can use the same size spars, the length > of the ailerons does not change, same wingspan (although Pieti > Lowell's is a little shorter than standard), etc... > > The coordinates for the Riblett airfoils have been discussed and > published here on the list many times, use the search function and > it should turn up a spreadsheet with the Riblett GA30-612, > GA30-613.5, and the FC-10. > > The Riblett airfoils should be just as good for the Corvair engine > powered Piets as it is for the Ford or Continental/Lycoming/ > Franklin powered ones. > > Where in IL are you located? > > -------- > Billy McCaskill > Urbana, IL > tail section almost done, starting on ribs soon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312140#312140 > > ________________________________________________________________________________
Subject: Re: What to look for in a 3/4 built Pietenpol
Date: Sep 11, 2010
I went and looked at it today and it is pretty far along and seems well built. Here are some photos. I'm not sure I will be able to buy the project and if anyone else is interested I'd be happy to pass along the builder's name and contact info via email. The project is located on the CT/RI border near Westerly RI. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312161#312161 Attachments: http://forums.matronics.com//files/dscn1428_117.jpg http://forums.matronics.com//files/dscn1425_110.jpg http://forums.matronics.com//files/dscn1422_135.jpg http://forums.matronics.com//files/dscn1424_733.jpg ________________________________________________________________________________
Date: Sep 11, 2010
Subject: louvers
Good afternoon Listers. I have a Mack truck cowl with a 1 sq ft panel on each side for access. I have two 6 inch intake holes on the nose with a 150 percent opening out the bottom. If I cut louvers on each panel will that mess up my cooling. I would really like the louvers looks wise. Cheers, Gardiner ________________________________________________________________________________
Subject: louvers
Date: Sep 11, 2010
Hi Gardiner, Not that I know that much about pressure cowls, but I recall Kurt Shipman saying how he improved his cooling by increasing the opening at the bottom. With that in mind, I can't see how louvers on the low pressure side would do anything but help...at least they wouldn't hurt. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (20 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Saturday, September 11, 2010 1:51 PM Subject: Pietenpol-List: louvers Good afternoon Listers. I have a Mack truck cowl with a 1 sq ft panel on each side for access. I have two 6 inch intake holes on the nose with a 150 percent opening out the bottom. If I cut louvers on each panel will that mess up my cooling. I would really like the louvers looks wise. Cheers, Gardiner ________________________________________________________________________________
Date: Sep 11, 2010
Subject: Re: louvers
Hi Gardiner, I'v attached a cropped down photo of your cowling, from the first flight pics you sent. Is the panel you are referring to the square panel that is sort of hidden behind the prop? The one which goes around the exhaust pipe, covering from just below the exhaust pipe up to the horizontal rivet line about midway up the cowling? Ryan On Sat, Sep 11, 2010 at 3:50 PM, airlion wrote: > > Good afternoon Listers. I have a Mack truck cowl with a 1 sq ft panel on > each > side for access. I have two 6 inch intake holes on the nose with a 150 > percent > opening out the bottom. If I cut louvers on each panel will that mess up my > cooling. I would really like the louvers looks wise. Cheers, Gardiner > > ________________________________________________________________________________
Date: Sep 11, 2010
Ryan, I have now moved my exhaust pipes down through the hole in the bottom of the cowl . Where the pipes used to come thru show the pipes coming thru a panel on each side as pictured. I have replaced those panels with a hinged access door that I want to put louvers in. Cheers, Gardiner and my best to Jessie. ________________________________ From: Ryan Mueller <rmueller23(at)gmail.com> Sent: Sat, September 11, 2010 7:01:52 PM Subject: Re: Pietenpol-List: louvers Hi Gardiner, I'v attached a cropped down photo of your cowling, from the first flight pics you sent. Is the panel you are referring to the square panel that is sort of hidden behind the prop? The one which goes around the exhaust pipe, covering from just below the exhaust pipe up to the horizontal rivet line about midway up the cowling? Ryan On Sat, Sep 11, 2010 at 3:50 PM, airlion wrote: > >Good afternoon Listers. I have a Mack truck cowl with a 1 sq ft panel on each >side for access. I have two 6 inch intake holes on the nose with a 150 percent >opening out the bottom. If I cut louvers on each panel will that mess up my >cooling. I would really like the louvers looks wise. Cheers, Gardiner > > >========== >st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >========== >http://forums.matronics.com >========== >le, List Admin. >="_blank">http://www.matronics.com/contribution >========== > > ________________________________________________________________________________
Subject: Re: Flight training
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Sep 12, 2010
Good to know-thanks. Dumas is only about 65 miles from here.but Midland is about 175 or so miles south so probably this fellow won't be able to get much good from him.plus I found out what he has built is a very light singe seat that would probably qualify as a legal ultralight so he will need to get some training in a very light aircraft but unless he wants to pursue the full ticket wouldn't have to and still fly.we did locate an instructor up in Perryton even farther north of here that has an aircraft that he trains with so if the guy wants to drive this far maybe he can get some training from him. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312198#312198 ________________________________________________________________________________
Date: Sep 12, 2010
Thanks Bill for your input. Yes, you are looking at the correct struts. I guess it would be wise to go larger/stronger. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Sep 12, 2010
I tried to get away from welding at first. I had not welded in a long, long time and while building the plane, I did not want to take the time to re-learn how to do it. I am fortunate enough to have access to a nice TIG welder, so I took the time to practice and talk to other welders for help. I now have plenty of welded fittings made and I really do enjoy doing it. It is a nice break from the wood and epoxy sometimes. I enjoy it so much that I am going to tackle making my own aluminum fuel tank soon. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Johnson AirSpeed Indicator ....
Date: Sep 12, 2010
If anyone is interested in one, I have some kits I put together ....... Please click here. (https://sites.google.com/site/pietenpolplanpackages/pietenpol-plan-packages) -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312204#312204 ________________________________________________________________________________
Subject: atta boy! Dale
Date: Sep 12, 2010
http://www.startribune.com/opinion/commentary/102655644.html?elr=KArks:DCiU1PciUiD3aPc:_Yyc:aUU Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312218#312218 ________________________________________________________________________________
Date: Sep 12, 2010
Has she got a sister ? Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312230#312230 ________________________________________________________________________________
Date: Sep 12, 2010
Is it possible to get a better glide ratio if I stop the prop from rotating , or does that make it worse ? I will try it and let you all know, if it also can be restarted, just in case Palmyra is too far away , I'm Thinking. I'm Thinking, Maybe a video would prove some of my claims,. By the way, the 612 airfoil has under camber and a gorgeous fuller front side that makes a shape as sexy as they come. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312236#312236 ________________________________________________________________________________
Date: Sep 12, 2010
Yes=2C Lowell=2C you will. It's just about the same drag as a disc of the same diameter. Similar to setting a windmilling propeller to zero thrust when simulating an engine failure in a twin. Not quite as good=2C but beat s a windmilling prop any day. even in my ultralight I noticed a difference . Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Re: Wing education=2C please advise.. > From: Lowellcfrank(at)yahoo.com > Date: Sun=2C 12 Sep 2010 15:45:12 -0700 > To: pietenpol-list(at)matronics.com > com> > > Is it possible to get a better glide ratio if I stop the prop from rotati ng =2C or does that make it worse ? I will try it and let you all know=2C i f it also can be restarted=2C just in case Palmyra is too far away =2C I'm Thinking. I'm Thinking=2C Maybe a video would prove some of my claims=2C. > By the way=2C the 612 airfoil has under camber and a gorgeous fuller fron t side that makes a shape as sexy as they come. > Pieti Lowell > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312236#312236 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 12, 2010
There is a certain revelution that when your prop is turning at that rev it makes it seem like there is a big piece of wood in front of the aircraft =2Clike a wall.Increase reves and it goes away=2Creduce revs and it goes aw ay as well.Your prop makes much less drag when stopped. > Subject: Pietenpol-List: Re: Wing education=2C please advise.. > From: Lowellcfrank(at)yahoo.com > Date: Sun=2C 12 Sep 2010 15:45:12 -0700 > To: pietenpol-list(at)matronics.com > com> > > Is it possible to get a better glide ratio if I stop the prop from rotati ng =2C or does that make it worse ? I will try it and let you all know=2C i f it also can be restarted=2C just in case Palmyra is too far away =2C I'm Thinking. I'm Thinking=2C Maybe a video would prove some of my claims=2C. > By the way=2C the 612 airfoil has under camber and a gorgeous fuller fron t side that makes a shape as sexy as they come. > Pieti Lowell > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312236#312236 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Bungee to Spring Conversion Complete
Date: Sep 12, 2010
Finished the swap on my split axle gear from bungees to springs. So far so good. This is what I've noticed: - the plane rocks back and forth a bit during taxi - never noticed that with the bungees. Not a problem, just different, - on landing, the plane is a bit more squirrelly. Again, not a problem,just need to be aware, and I'm supposed to be paying attention anyway, - the plane does not squat out under load near as much as it did with the bungees. Thanks to Kelly Klaus. He's one of our list members. He came to visit a couple of weeks ago and consented to be my crash-test dummy for the gross weight tests on the new gear. Trusting guy! Different subject: Tropical Storm Hermine ran 6" of water through my hangar. Really inconvenient. No major damage though. I continue to be extremely fortunate. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312242#312242 ________________________________________________________________________________
Date: Sep 12, 2010
Yup aluminum welding is even fun with a TIG (yes I know real men weld aluminum with gas). Would recommend .040 or .050 5052, .032 works but is more of a challenge to weld. rick On Sun, Sep 12, 2010 at 8:20 AM, Michael Perez wrote: > I tried to get away from welding at first. I had not welded in a long, long > time and while building the plane, I did not want to take the time to > re-learn how to do it. I am fortunate enough to have access to a nice TIG > welder, so I took the time to practice and talk to other welders for help. I > now have plenty of welded fittings made and I really do enjoy doing it. It > is a nice break from the wood and epoxy sometimes. I enjoy it so much that I > am going to tackle making my own aluminum fuel tank soon. > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Sep 12, 2010
Subject: e-mail problems
Sorry to any of you on list I have not responded to, I just checked my spam folder and found that some piet list measages have been geting "Spam Canne d" for about 3 weeks.- Thanks to all for the kind words (and funny ones t oo) about my new baby boy.- - Happy Building, Flying, And Fixing - Shad=0A=0A=0A ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Sep 12, 2010
Roger, Now I get to throw out some random ideas. The EAA still has an ultralight organization that has instructors. I would check there. I think he will have to travel. Look over at Hobbs, NM. I would also do some calling in Sweetwater and Abilene. San Angelo has a big flying population (relatively.). The other thought he may look at is finding someone with the most similar training aircraft and going there to get the training. It sure is a good idea for him to get training. Ultralights don't require any training by reg. But a lot of people have been hurt training themselves how to fly! Blue Skies, Steve D ----- Original Message ----- From: skellytown flyer <skellflyer1(at)yahoo.com> Date: Sunday, September 12, 2010 7:33 Subject: Pietenpol-List: Re: Flight training > > Good to know-thanks. Dumas is only about 65 miles from here.but Midland is about 175 or so miles south so probably this fellow won't be able to get > much good from him.plus I found out what he has built is a very > light singe seat that would probably qualify as a legal ultralight > so he will need to get some training in a very light aircraft but > unless he wants to pursue the full ticket wouldn't have to and > still fly.we did locate an instructor up in Perryton even farther > north of here that has an aircraft that he trains with so if the > guy wants to drive this far maybe he can get some training from him. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312198#312198 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 12, 2010
Hey Pieti, Her sister's number is GA30-612, and I hear she is available... [Laughing] -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312263#312263 ________________________________________________________________________________
Subject: Re: Bungee to Spring Conversion Complete
Date: Sep 13, 2010
Kevin, It was my pleasure to be your test dummy, no crash included hehe. What an experience, I'm already gearing up for getting some wood soon. Unfortunately I do have some bad news. Two Saturdays ago, our B-25 Yellow Rose was flying out to Lancaster for a show. Somewhere over Austin the oil pressure on our #1 Wright Cyclone Radial engine (rebuilt last year) began dropping while the oil temp on the same engine rose. with this event, the crew shut the engine down and brought her safely back to KHYI on one engine. So now we're in the midst of figuring out how we can get the engine rebuilt and getting funding to do so. :( -------- Kelly Klaus Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312280#312280 ________________________________________________________________________________
Date: Sep 13, 2010
How were you planning on making these louvers? I had given thought to getting some in the sides of my lower cowl,and may some day more for looks but not sure I could do any kind of a decent job by hand. I have seen advertisements in car magazines for people who do such things and I'm guessing they have some kind of special tool for it. also I am not sure how well light aluminum would hold the shape and not develop cracks pretty fast. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312284#312284 ________________________________________________________________________________
Date: Sep 13, 2010
Will it be to my advantage to turn the radiator side ways to gain 10 inches of air space under the wing and also not to interfere with air over the wing with the radiator?. BP built 3 such horizontal radiator installation. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312288#312288 ________________________________________________________________________________
Date: Sep 13, 2010
Two concerns immediately occur to me. First, will cooling ability decline? Second, will the vertical center of pressure be shifted, necessitating larger vertical tail members? I don't know if either of these would be real-world problems, but they may be worth considering. > >Will it be to my advantage to turn the radiator side ways to gain 10 >inches of air space under the wing and also not to interfere with >air over the wing with the radiator?. BP built 3 such horizontal >radiator installation. >Pieti Lowell > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=312288#312288 > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Date: Sep 13, 2010
Quality Machine in Lagrange Ga. has a tool that stsmps out louvers . Gardiner --- On Mon, 9/13/10, skellytown flyer wrote: > From: skellytown flyer <skellflyer1(at)yahoo.com> > Subject: Pietenpol-List: Re: louvers > To: pietenpol-list(at)matronics.com > Date: Monday, September 13, 2010, 8:39 AM > --> Pietenpol-List message posted > by: "skellytown flyer" > > How were you planning on making these louvers? I had given > thought to getting some in the sides of my lower cowl,and > may some day more for looks but not sure I could do any kind > of a decent job by hand. I have seen advertisements in car > magazines for people who do such things and I'm guessing > they have some kind of special tool for it. also I am not > sure how well light aluminum would hold the shape and not > develop cracks pretty fast. Raymond > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312284#312284 > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Subject: Re: to weld or not to weld
Date: Sep 13, 2010
I learned to master TIG & GAS welding by myself with lots of metal scrap and mental frustration at first, but the end accomplishment was very rewarding. Also ... a little something on TIG welding 4130 (http://www.weldingtipsandtricks.com/welding-4130.html). Enjoy. WF2 .... the real cost of welding is all the clothes that have little burn holes in them! -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312301#312301 ________________________________________________________________________________
Date: Sep 13, 2010
How did you find that. Dale > [Original Message] > From: dwilson <marwilson(at)charter.net> > To: > Date: 9/12/2010 1:35:02 PM > Subject: Pietenpol-List: atta boy! Dale > > http://www.startribune.com/opinion/commentary/102655644.html?elr=KArks:DCiU1 PciUiD3aPc:_Yyc:aUU > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312218#312218 > > ________________________________________________________________________________
Subject: Re: Pietenpol airlines shirts
Date: Sep 13, 2010
Anyone interested in a sassy Piet shirt ? Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312344#312344 Attachments: http://forums.matronics.com//files/imgp1061_871.jpg ________________________________________________________________________________
Date: Sep 13, 2010
Ah, yes. Many years ago, in high school, one of my friends went into the welding cubicle wearing a really fancy shirt. He came out wearing a couple of wisps of black carbon and a priceless look on his face. Finally! I have my Terra radio, with built in intercom, wired and working. I just have to get a friend to help me test the transmission end of things. So far I'm overjoyed at the reception. My elevation is about 200' asl. To the North is Vancouver harbour, tower about 400' asl, great reception. To the South, behind a 500' ridge, is Vancouver International, very good, 4 1/2 out of 5. Further South is Boundary Bay and I'd say 3 1/2 to 4 out of 5. So it appears that all those control wires surounding my antenna aren't interfering much, if any. Clif > Enjoy. > WF2 > > .... the real cost of welding is all the clothes that have little burn > holes in them! ________________________________________________________________________________
Subject: My website problems
Date: Sep 14, 2010
My website is currently undergoing a rebellious period and hiding all the links. I added some more pictures to the web page last week and every time I tried to upload the website the upload would end on some server error. So I decided to reload the whole web page. After 9 hours of uploading files, the sever "Timed out" at the last step. I have tried this 3 times now. I tried fixing it all weekend before anyone noticed but it did not work. Now I have decided to rewrite the whole web site architecture from scratch hoping to speed up my upload times. Might take me a few days or weeks. The files are still on the server so if your desperate try this, type in the http://westcoastpiet.com/ in the address bar then add the builders name or page don't forget to connect the names with an underline, followed by .htm It would look something like this if you wanted to see don_emoch pictures http://westcoastpiet.com/don_emoch.htm Unfortunately, there has always been some kind of glitch in the naming structure so not all pages have the correct name, some are called new_page_XX. You can always email me and I will send you a link to the page you are looking for after I get home from work. Sorry for the inconvenience. Chris Sacramento, Ca Westcoastpiet.com ________________________________________________________________________________
Subject: Pietenpolie Girl T- Shirt
Date: Sep 14, 2010
Sample of shirt is available on the post of John's (Pietenpol Airline Shirt ).post Sept. The student Emily Herns, is a past Robotic student of mine, now going for her ME Degree at WI. She is of a single parent family and is pulling a 4.0. Very interesting to talk with. If you wish to donate and order a Pietenpolie Girl Shirt , all for her collage, Email your size and amount, or your donations to " lowellcfrank(at)yahoo.com ".her P.O.Box will be available for a direct contact. I have a few left and will order more. Thank you fellows. Pieti Lowell Don't Archive Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312394#312394 ________________________________________________________________________________
Subject: Band Brakes Available
Date: Sep 14, 2010
During cleanup from TS Hermine I rediscovered these 4" diameter band brakes (drums and bands). I'm not using them and they'll eventually rust to ruin. Call me at 512-422-6371 if you want them. I'd like $10 for postage. Other than that, free to a good home. Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312417#312417 Attachments: http://forums.matronics.com//files/brakes2_117.jpg ________________________________________________________________________________
Subject: Re: Band Brakes Available
Date: Sep 14, 2010
SOLD!!! to Brian in Utah. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312420#312420 ________________________________________________________________________________
Date: Sep 14, 2010
Thanks again. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Tuesday, September 14, 2010 10:23 AM Subject: Pietenpol-List: Re: Band Brakes Available SOLD!!! to Brian in Utah. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312420#312420 ________________________________________________________________________________
Date: Sep 14, 2010
Axel as you know,Ill be in Houston Wednesday so no postage necessary John Recine In a message dated 9/14/2010 12:44:22 P.M. Eastern Daylight Time, kevin.purtee(at)us.army.mil writes: --> Pietenpol-List message posted by: "kevinpurtee" During cleanup from TS Hermine I rediscovered these 4" diameter band brakes (drums and bands). I'm not using them and they'll eventually rust to ruin. Call me at 512-422-6371 if you want them. I'd like $10 for postage. Other than that, free to a good home. Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312417#312417 Attachments: http://forums.matronics.com//files/brakes2_117.jpg ________________________________________________________________________________
Date: Sep 14, 2010
Subject: Me and the Boys
Here is a photo of the Bell Clan minus Grandpa, and his Pietenpol, "Little Joe", Me, and "Shakey Jake", Joe is 2 weeks, I am 32, and Jake is 22months. - If I wasnt a lard Butt, that piet could carry my whole family!!!! - Shad=0A=0A=0A ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC Aerospace Corporation]" <michael.d.cuy(at)nasa.gov>
Date: Sep 14, 2010
Subject: 131 photos from Brodhead, 2010
Relive a fun, fun time. Wow, is it really September 14th already ? Mike C. http://www.flickr.com/photos/52843195@N03/sets/ ________________________________________________________________________________
Subject: Re: 131 photos from Brodhead, 2010
Date: Sep 15, 2010
WWVhaCEgQW5uaXZlcnNhcnkgb2YgdGhlIE5hdGlvbmFsIEFudGhlbSENCg0KR2FyeSBCb290aGUN ClNlbnQgb24gdGhlIFNwcmludK4gTm93IE5ldHdvcmsgZnJvbSBteSBCbGFja0JlcnJ5rg0KDQot LS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogIkN1eSwgTWljaGFlbCBELiAoR1JDLVJY RDApW0FTUkMgQWVyb3NwYWNlIENvcnBvcmF0aW9uXSIgPG1pY2hhZWwuZC5jdXlAbmFzYS5nb3Y+ DQpTZW5kZXI6IG93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tDQpEYXRl OiBUdWUsIDE0IFNlcCAyMDEwIDE5OjQ1OjQ2IA0KVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmlj cy5jb208cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT47IEJQQU48YnBhbkB0ZHMubmV0Pg0K UmVwbHktVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb21TdWJqZWN0OiBQaWV0ZW5wb2wt TGlzdDogMTMxIHBob3RvcyBmcm9tIEJyb2RoZWFkLCAyMDEwDQoNClJlbGl2ZSBhIGZ1biwgZnVu IHRpbWUuICAgICAgIFdvdywgaXMgaXQgcmVhbGx5IFNlcHRlbWJlciAxNHRoIGFscmVhZHkgPw0K DQpNaWtlIEMuDQoNCg0KaHR0cDovL3d3dy5mbGlja3IuY29tL3Bob3Rvcy81Mjg0MzE5NUBOMDMv c2V0cy8NCg0KDQoNCg0KDQo ________________________________________________________________________________
Subject: Re: Me and the Boys
Date: Sep 14, 2010
Wow. Hard to believe kids come that small - I barely remember those days and they weren't that long ago. Good lookin' brood ya got there, Shad. -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Sep 14, 2010, at 7:17 PM, shad bell wrote: > Here is a photo of the Bell Clan minus Grandpa, and his Pietenpol, "Little Joe", Me, and "Shakey Jake", Joe is 2 weeks, I am 32, and Jake is 22months. If I wasnt a lard Butt, that piet could carry my whole family!!!! > > Shad > > ________________________________________________________________________________
Date: Sep 14, 2010
All I'm getting is: Page Not Found Oops! Looks like you followed a bad link. -------- Dan Plett N28WH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312472#312472 ________________________________________________________________________________
Date: Sep 14, 2010
maybe this is it? http://www.flickr.com/photos/52843195@N03/sets/72157624958514006/with/4991002689/ -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312479#312479 ________________________________________________________________________________
Date: Sep 14, 2010
maybe this is it? http://www.flickr.com/photos/52843195@N03/sets/72157624958514006/with/4991002689/ -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312480#312480 ________________________________________________________________________________
Date: Sep 15, 2010
Hey Shad, Great family photo except where is momma and grandpa? Piet still really good looking too. Jim B. ----- Original Message ----- From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Tuesday, September 14, 2010 5:17:08 PM Subject: Pietenpol-List: Me and the Boys Here is a photo of the Bell Clan minus Grandpa, and his Pietenpol, "Little Joe", Me, and "Shakey Jake", Joe is 2 weeks, I am 32, and Jake is 22months. If I wasnt a lard Butt, that piet could carry my whole family!!!! Shad ________________________________________________________________________________
Subject: Brodhead 2011 dates
Date: Sep 14, 2010
Can someone give me the exact dates for Brodhead 2011? I am bidding for my vacation next year and I need to make sure I get the right dates. Gene ________________________________________________________________________________
Date: Sep 14, 2010
Thanks for sharing these - makes me wish I had been there. From: michael.d.cuy(at)nasa.gov Date: Tue=2C 14 Sep 2010 19:45:46 -0500 Subject: Pietenpol-List: 131 photos from Brodhead=2C 2010 Relive a fun=2C fun time. Wow=2C is it really September 14th already ? Mike C. http://www.flickr.com/photos/52843195@N03/sets/ ________________________________________________________________________________
Date: Sep 14, 2010
Subject: Re: Brodhead 2011 dates
Gene, Airventure is supposed to be on July 25-31, 2011, so the Piet reunion will be the July 21-24. How's covering coming? Dan On 09/14/2010 10:28 PM, Gene Rambo wrote: > Can someone give me the exact dates for Brodhead 2011? I am bidding for > my vacation next year and I need to make sure I get the right dates. > > Gene > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Sep 14, 2010
Gene, Checked on the BPA and 431 site, and they don't have any calendars or official announcements that far out yet. However, unless there is some unforeseen break from how it is usually scheduled it should be Thursday July 21 through Saturday July 23 (wrapping up/departing on Sunday July 24)....that is my educated guess. Ryan On Tue, Sep 14, 2010 at 10:28 PM, Gene Rambo wrote: > Can someone give me the exact dates for Brodhead 2011? I am bidding for > my vacation next year and I need to make sure I get the right dates. > > Gene > > * > > * > > ________________________________________________________________________________
Date: Sep 14, 2010
You are accessing the email list from the web-based forum. Mike sent his message to the list via email, and it appears when Matronics put it on the web-based forum it automatically replaced the @ symbol (on your keyboard, above the 2) from the link with "(at)". Replace the "(at)" in the link from Mike's post on the web-based forum with the @ symbol above the number 2 on your keyboard and the link will work fine. Everyone that received Mike's post via email should have had no problem with the link. See the attached pic.... Ryan On Tue, Sep 14, 2010 at 8:52 PM, Dan P wrote: > > All I'm getting is: > > Page Not Found > > Oops! Looks like you followed a bad link. > > -------- > Dan Plett > N28WH > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312472#312472 > > ________________________________________________________________________________
Subject: Piet for sale
Date: Sep 14, 2010
Sept. issue of Atlantic Flyer has a ready to bolt together piet and cont A65 engine for sale ($5000). http://www.aflyer.com/classified.html -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312490#312490 ________________________________________________________________________________
Subject: Parts for Piets?
Date: Sep 15, 2010
Found a link that may have an occasional hard to find part for a Piet builder. It's really a Cub site.. Larry http://www.j3-cub.com/smf/index.php?board=3.0 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312499#312499 ________________________________________________________________________________
Subject: Flight test report
Date: Sep 15, 2010
Hello all, Took the Piet up last evening. It was glorious weather and windless. She flies like a dream. Water temps are about 185 at cruise power. I am still having that same old problem, where on final the A wants to sputter and quit if I pull the throttle all the way back. I have not tried to change anything yet, but I think before the next flight I am going to restrict the carb heat can air-intake opening, in order to pick-up more heat from the #1 exhaust stack. That would address the possibility that the problem was carb ice. At present I am designing a killer logo that is going to be hand-painted to both the fuselage sides. I cannot reveal what it is quite yet, as I am sure Gene Rambo would steal it and show up at Brodhead right before me ne xt year. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Sep 15, 2010
Just in case it is difficult to see a neat shirt. a few left. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312513#312513 Attachments: http://forums.matronics.com//files/pietenpolie_girl_005_180.jpg ________________________________________________________________________________
Subject: FW: Save Big on EAA How-to Books!
Date: Sep 15, 2010
For those just getting started building a Pietenpol, all of these items are worth having, and the Bingelis books are =93must have=94 items. The Aircraft wWelding book has a lot of good information, including the key steps to produce the flattened tubing parts that are used to a great extent in building a Pietenpol. Even the Sheet Metal book and DVD are useful, as there is a fair amount of riveting involved in making a Pietenpol cowling. Jack Phillips NX899JP Raleigh, NC _____ From: EAA Aeronautica [mailto:membership(at)eaa.mmsend.com] On Behalf Of EAA Aeronautica Sent: Wednesday, September 15, 2010 10:06 AM Subject: Save Big on EAA How-to Books! <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701358&m=1109092 &u=ExAA2& s=http://www.eaa.org/newsletters/1009_merchandise.html> Click to view this email online <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701360&m=1109092 &u=ExAA2& s=http://www.shopeaa.com> Aeronautica - official EAA Merchandise Save up to 20% on Select How-to Books But hurry-this offer ends Tuesday, September 21! Choose from: <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701362&m=1109092 &u=ExAA2& s=http://www.shopeaa.com/bingelissetof4.aspx> How-to books Bingelis <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701364&m=1109092 &u=ExAA2& s=http://www.shopeaa.com/bingelissetof4.aspx> Set of 4 Books <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701366&m=1109092 &u=ExAA2& s=http://www.shopeaa.com/weldingbookanddvdcombo.aspx> <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701368&m=1109092 &u=ExAA2& s=http://www.shopeaa.com/eaasheetmetalbuildingbasics.aspx> EAA <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701369&m=1109092 &u=ExAA2& s=http://www.shopeaa.com/weldingbookanddvdcombo.aspx> Aircraft Welding Book and Welding/Corrosion DVD Combo Sheet <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701371&m=1109092 &u=ExAA2& s=http://www.shopeaa.com/eaasheetmetalbuildingbasics.aspx> Metal Building Basics Book And more! Go <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701372&m=1109092 &u=ExAA2& s=http://www.shopeaa.com/publications_technical.aspx> to EAA's web store to view other great deals on how-to books. 100% OF THE PROFITS DIRECTLY SUPPORT EAA PROGRAMS. http://www.shopeaa.com <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701373&m=1109092 &u=ExAA2& s=http://www.shopeaa.com > For orders outside the USA, please call 920-426-5912 or e-mail for shipping charges and schedules. If you do not wish to receive further emails from EAA, please email membership(at)eaa.org. We welcome your questions, comments and suggestions to webmaster(at)eaa.org. =A9 Copyright 2010 Experimental Aircraft Association, Inc. 3000 Poberezny Road, Oshkosh, WI 54902 920-426-4800 Click here <http://www.mmsend2.com/link.cfm?r=221352930&sid=10701374&m=1109092 &u=ExAA2& s=http://unsubscribe.magnetmail.net/Actions/unsubscribe.cfm?message_id= 11090 92&user_id=ExAA2&recipient_id=221352930&email=pietflyr(at)bellsouth.ne t&group_i d=318845> to unsubscribe. <http://www.mmsend2.com/spacer.cfm?tracking_id=6543987986> ________________________________________________________________________________
Date: Sep 15, 2010
Mom was taking the picture.- She got home with the boys and came out to s ee what I was into.- Just thought it was a good photo op, get him started early into aviation. - Shad --- On Tue, 9/14/10, Jim Boyer wrote: From: Jim Boyer <boyerjrb(at)comcast.net> Subject: Re: Pietenpol-List: Me and the Boys Date: Tuesday, September 14, 2010, 11:02 PM Hey Shad, Great family photo except where is momma and grandpa? Piet still really good looking too. Jim B. ----- Original Message ----- From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Tuesday, September 14, 2010 5:17:08 PM Subject: Pietenpol-List: Me and the Boys Here is a photo of the Bell Clan minus Grandpa, and his Pietenpol, "Little Joe", Me, and "Shakey Jake", Joe is 2 weeks, I am 32, and Jake is 22months. - If I wasnt a lard Butt, that piet could carry my whole family!!!! - Shad le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Sep 15, 2010
Very nice Shad! One question...what size/material struts did you use for the cabane to engine mounts? Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Auxillary Fuel System
Date: Sep 15, 2010
I'd like your thoughts on ways to add the redneck Extended Range Fuel System (ERFS) to the airplane. The design I'm currently considering is as follows: - A 3 to 5 gallon can securely strapped in the front seat, - A small pump driven by two D batteries with a dead-man switch (this pump may not have enough power, but it was only $13 so I felt it worth the experiment), - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, - Modified gas cap to accept the inlet line. Assumptions: - No permanent mods to the airplane, - No passengers, - Portable and removable in 30 minutes with hand tools, - Used only on long cross-country flights. We have an outstanding safety culture on this list. If you're concerned about the gas, be advised that I fly with 11 gallons 6" above my head every time I take off. A well-secured auxillary tank with equally well-secured hardware and plumbing is acceptable to me. I welcome any suggestions or ideas to do it better. Thanks, Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312541#312541 ________________________________________________________________________________
Date: Sep 15, 2010
Kevin, When I put the smoke system in my Pietenpol, I used a 3 gallon portable fuel tank for an outboard motor, which I purchased at West Marine. If fits perfectly on the floorboard between the front rudder pedals, and is secured by using a bungee cord stretched over the tank behind the filler neck and attached to a pair of eyebolts in the ash crossmember behind the rudder pedals. Here is the website for the fuel tank: http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId =27615&catalogId=10001&langId=-1&storeId=11151&storeNum=10106&subdeptNum=104 43&classNum=10444 I think I would use a tank such as this rather than a can. It has a gage built in, has a good sealing cap and a closeable vent. If you use an outboard type fuel line, it also has a quick disconnect and a priming bulb, to get the fuel from the tank to your pump. I think I would use your main tank until you have flown out at least 3 gallons, then use this tank to re-fill the main tank. Jack Phillips NX899JP Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Wednesday, September 15, 2010 2:52 PM Subject: Pietenpol-List: Auxillary Fuel System I'd like your thoughts on ways to add the redneck Extended Range Fuel System (ERFS) to the airplane. The design I'm currently considering is as follows: - A 3 to 5 gallon can securely strapped in the front seat, - A small pump driven by two D batteries with a dead-man switch (this pump may not have enough power, but it was only $13 so I felt it worth the experiment), - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, - Modified gas cap to accept the inlet line. Assumptions: - No permanent mods to the airplane, - No passengers, - Portable and removable in 30 minutes with hand tools, - Used only on long cross-country flights. We have an outstanding safety culture on this list. If you're concerned about the gas, be advised that I fly with 11 gallons 6" above my head every time I take off. A well-secured auxillary tank with equally well-secured hardware and plumbing is acceptable to me. I welcome any suggestions or ideas to do it better. Thanks, Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312541#312541 ________________________________________________________________________________
Date: Sep 15, 2010
I would have to check with Dad, I believe it is 3/4 od, not sure on the wal l thickness, probably at least .049".- There is a hole drilled through th e bottom end with a bushing welded in, and you can probably see the fork en d on top.- It is a little bit of a sharp angle, not the best angle in the event of a sudden stoppage crash, it would probably be better if it was a little flatter of an angle.- Be glad the piet cabanes are simple to fabri cate, my jungster 1 struts are a real pain, lots of compound angles and lot s of welding opperations in comparison. - Shad --- On Wed, 9/15/10, Michael Perez wrote: From: Michael Perez <speedbrake(at)sbcglobal.net> Subject: Re: Pietenpol-List: Me and the Boys Date: Wednesday, September 15, 2010, 2:13 PM Very nice Shad! One question...what size/material struts did you use for th e cabane to engine mounts? Michael Perez Karetaker Aero www.karetakeraero.com =0A=0A=0A ________________________________________________________________________________
Date: Sep 15, 2010
Subject: Re: Auxillary Fuel System
Hey Axel, Put a probe on top of your center section and call for a tanker. Cheers, Gardiner ----- Original Message ---- From: kevinpurtee <kevin.purtee(at)us.army.mil> Sent: Wed, September 15, 2010 2:51:40 PM Subject: Pietenpol-List: Auxillary Fuel System I'd like your thoughts on ways to add the redneck Extended Range Fuel System (ERFS) to the airplane. The design I'm currently considering is as follows: - A 3 to 5 gallon can securely strapped in the front seat, - A small pump driven by two D batteries with a dead-man switch (this pump may not have enough power, but it was only $13 so I felt it worth the experiment), - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, - Modified gas cap to accept the inlet line. Assumptions: - No permanent mods to the airplane, - No passengers, - Portable and removable in 30 minutes with hand tools, - Used only on long cross-country flights. We have an outstanding safety culture on this list. If you're concerned about the gas, be advised that I fly with 11 gallons 6" above my head every time I take off. A well-secured auxillary tank with equally well-secured hardware and plumbing is acceptable to me. I welcome any suggestions or ideas to do it better. Thanks, Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312541#312541 ________________________________________________________________________________
Subject: Re: Flight test report
Date: Sep 15, 2010
Don, was that you flying over Roscoe just before the Fall Festival parade last Sunday? -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312554#312554 ________________________________________________________________________________
Date: Sep 15, 2010
Thank you ! Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Sep 15, 2010
Subject: rear torque tube bearing, wear
Has anyone else noticed any wear to the rear torque tube support sleeve bea ring (the one right under the front of the rear cockpit seat).- I noticed it last night while taking out the front stick in preperation for the lee bottom fly-in.- It is just starting to get a little bit of radial play, s o I had to take it apart to inspect how much wear there was.- It is worn but not worn out yet ( about 5/1000 or so), I think I will see if dad wants to redesign it with a small roller bearing to illiminate the problem, if i t were to wear too much the aft end of the aileron torque tube-could be c ut off, causing a possible loss of control.- Just thought I would throw t his out there, and see if any of you have noticed any similar wear.- The way I found the wear was to grab the- torque tube (on the floor in the re ar cockpit) and move it from side to side, up and down, and see if it moves in the ----O---- looking suport.- You will have to pull the seat bottom to be able to see the- rear bearing support, but you will hear the tube moving around if it has any play in it.- - Let me know if anyone finds anything, - Shad=0A=0A=0A ________________________________________________________________________________
Date: Sep 15, 2010
Kevin, When you get that extra tank figgered out, you'll need the civilian version of the Human Element Range Extender. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Wednesday, September 15, 2010 11:52 AM Subject: Pietenpol-List: Auxillary Fuel System I'd like your thoughts on ways to add the redneck Extended Range Fuel System (ERFS) to the airplane. The design I'm currently considering is as follows: - A 3 to 5 gallon can securely strapped in the front seat, - A small pump driven by two D batteries with a dead-man switch (this pump may not have enough power, but it was only $13 so I felt it worth the experiment), - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, - Modified gas cap to accept the inlet line. Assumptions: - No permanent mods to the airplane, - No passengers, - Portable and removable in 30 minutes with hand tools, - Used only on long cross-country flights. We have an outstanding safety culture on this list. If you're concerned about the gas, be advised that I fly with 11 gallons 6" above my head every time I take off. A well-secured auxillary tank with equally well-secured hardware and plumbing is acceptable to me. I welcome any suggestions or ideas to do it better. Thanks, Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312541#312541 ________________________________________________________________________________
Date: Sep 15, 2010
Just a few more questions: I really like the idea of incorporating a "gap less" aileron on our wing as seen here: https://sites.google.com/site/pietenpolplanpackages/pietenpol-plan-packages How does the riblet design work in the ailerons? Do i still need gap tape? Would this kit work on the new wing? And to summarize the riblet wing will provide better stall, lift, and cruise performance? Thanks for the help Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312590#312590 ________________________________________________________________________________
Date: Sep 16, 2010
Sealing your aileron, and elevator gaps is a Very Good Idea! The plane handles much better. Jack, Mike, and others use piano hinge to get the effect. I'm using strips of Naugahyde and contact cement to perform the same thing. Heck, painters and duct tape work well, too. Just my 2 cents. Dan -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Sep 15, 2010, at 10:46 PM, j_dunavin wrote: > ________________________________________________________________________________
Date: Sep 16, 2010
Kevin, Have you considered the pressure head requirement to pump fuel the distance from floor or seat to the wing tank? Personally I'd run a simple test to see if the batteries and pump had sufficient power to do the job and exactly how many gallons they would pump prior to exhaustion. Kinda hard to swap batteries at 85 K and 2500ft Just my .02. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312600#312600 ________________________________________________________________________________
Date: Sep 16, 2010
If you were to use the boat fuel tank, you could probably do the transfer with the primer bulb. Give you something to do as the scenery went by and some exercise too! Ben On 9/16/2010 7:56 AM, tkreiner wrote: > --> Pietenpol-List message posted by: "tkreiner" > > Kevin, > > Have you considered the pressure head requirement to pump fuel the distance from floor or seat to the wing tank? > > Personally I'd run a simple test to see if the batteries and pump had sufficient power to do the job and exactly how many gallons they would pump prior to exhaustion. > > Kinda hard to swap batteries at 85 K and 2500ft > > Just my .02. > > -------- > Tom Kreiner > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312600#312600 > > ________________________________________________________________________________
Date: Sep 16, 2010
Thanks for the comments. Particularly like Gardiner's idea:). The total lift will be 4-5 feet. Not sure the $13 double D battery pump's going to do that. Not much lost if it doesn't work, though. I thought about the hand squeeze bulb. I did the calc's and that looks like it will take a LOOOONNNGGG time to work. Also not sure it'll have the power to lift that high. I do have one and will run the experiment. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312610#312610 ________________________________________________________________________________
Date: Sep 16, 2010
Kevin, I've been traveling the last couple days, and not sure I fully understood your inquiry, but the 601 guys use a little 'facet' pump, supplying positive carb pressure from a low-wing wing tank, that would easily run off your electric system. Gary Boothe Cool, CA Pietenpol WW Corvair Conversion Tail done, Fuselage on gear 20 ribs done -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Thursday, September 16, 2010 6:06 AM Subject: Pietenpol-List: Re: Auxillary Fuel System Thanks for the comments. Particularly like Gardiner's idea:). The total lift will be 4-5 feet. Not sure the $13 double D battery pump's going to do that. Not much lost if it doesn't work, though. I thought about the hand squeeze bulb. I did the calc's and that looks like it will take a LOOOONNNGGG time to work. Also not sure it'll have the power to lift that high. I do have one and will run the experiment. -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312610#312610 ________________________________________________________________________________
Date: Sep 16, 2010
kevinpurtee wrote: > > - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, > - Modified gas cap to accept the inlet line. > > > Axel I would add that you should be very careful with your connection to the gas cap. I have heard of engine stoppage and even depletion of fuel out the cap due to improper venting of wing tanks. There is a lot of negative pressure there. You could extend your range by a negative 2 hrs especially if the temporary fuel line came loose. My $0.02 Jon -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312618#312618 ________________________________________________________________________________
Date: Sep 16, 2010
Joe, The "Riblett design" is simply an airfoil, not a whole wing design. You're really on your own to figure out all the little details. My assumption would be that the truss structure of a Riblett rib would mimic the structure shown in the Pietenpol plans, and everything else (e.g. ailerons) would follow suit. Therefore, if the Pietenpol wing benefits from gap sealing, then the Riblett would also benefit in the same manner. The easiest method to seal the aileron gaps is to use a piano hinge, like Dan said. Your summary regarding the Riblett airfoils is basically what is being claimed. As far as I know, Pieti Lowell's is the only flying example of a Riblett airfoil on a Piet (I may be wrong on that, though), and he claims improved performance. Anecdotally, I overheard someone at Brodhead a couple of years ago saying that the Riblett airfoil will provide twice the lift, and double the cruise speed, and cut the stall speed in half... I took ALL of that with a BIG grain of salt. No doubt a different airfoil will result in different performance. Just how much different is the question, and whether it is an improvement is another. It seems that there are quite a few new builders constructing their Piets with Riblett airfoils. So, if and when they get them flying, we'll have some more flying examples to refer to. As it stands now, it is really difficult to tell, since there can be so much difference in performance from one Piet to another, due to all the design changes that builders make, as well as powerplant, propeller and other choices available. Would be really good to have another builder or two do what Lowell did, and fly the exact same aircraft with the two different airfoils, and compare the performances. But that means a LOT of work - most of us have enough challenge just getting one wing built (right, Gary?). In short, either airfoil will fly the plane just fine. If you want "tried and true", stick with the plans. If you want to experiment with possible performance improvements, and are willing to work out more little details on your own, then give the Riblett a go. (the choice of Riblett airfoils is up to you, as there were two suggested by Mr. Riblett as being suitable for the Piet). Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312625#312625 ________________________________________________________________________________
Date: Sep 16, 2010
Kevin, This $ 13 pump better be spark proof and specially made for gasoline type fuels. Diesel pumps are no good in this application, flash point of diesel is muc h higher than gasoline. Suggest you look into a simple electric booster pump, try Summit racing fo r some product ideas. You will need 12 Volts but small rechargeable batteries are cheap. Hans NX15KV Waller, TX ----- Original Message ---- From: kevinpurtee <kevin.purtee(at)us.army.mil> Sent: Wed, September 15, 2010 2:51:40 PM Subject: Pietenpol-List: Auxillary Fuel System mil> I'd like your thoughts on ways to add the redneck Extended Range Fuel Syst em (ERFS) to the airplane. The design I'm currently considering is as follow s: - A 3 to 5 gallon can securely strapped in the front seat, - A small pump driven by two D batteries with a dead-man switch (this pump may not have enough power, but it was only $13 so I felt it worth the experime nt), - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, - Modified gas cap to accept the inlet line. Assumptions: - No permanent mods to the airplane, - No passengers, - Portable and removable in 30 minutes with hand tools, - Used only on long cross-country flights. We have an outstanding safety culture on this list. If you're concerned about the gas, be advised that I fly with 11 gallons 6" above my head every time I take off. A well-secured auxillary tank with equally well-secured hardwar e and plumbing is acceptable to me. I welcome any suggestions or ideas to do it better. Thanks, Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312541#312541 ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Sep 16, 2010
I have 20.5 gallons in my center section wing tank and don't need any more. But if you do not have a wide center section why not go the tiger moth way and put one on top. Gravity feed works great. I had a header tank at first and could not get enough head pressure to the carb. Gardiner ________________________________ From: "hvandervoo(at)aol.com" <hvandervoo(at)aol.com> Sent: Thu, September 16, 2010 11:17:32 AM Subject: Re: Pietenpol-List: Auxillary Fuel System Kevin, This $ 13 pump better be spark proof and specially made for gasoline type fuels. Diesel pumps are no good in this application, flash point of diesel is much higher than gasoline. Suggest you look into a simple electric booster pump, try Summit racing for some product ideas. You will need 12 Volts but small rechargeable batteries are cheap. Hans NX15KV Waller, TX ----- Original Message ---- From: kevinpurtee <kevin.purtee(at)us.army.mil> Sent: Wed, September 15, 2010 2:51:40 PM Subject: Pietenpol-List: Auxillary Fuel System I'd like your thoughts on ways to add the redneck Extended Range Fuel System (ERFS) to the airplane. The design I'm currently considering is as follows: - A 3 to 5 gallon can securely strapped in the front seat, - A small pump driven by two D batteries with a dead-man switch (this pump may not have enough power, but it was only $13 so I felt it worth the experiment), - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, - Modified gas cap to accept the inlet line. Assumptions: - No permanent mods to the airplane, - No passengers, - Portable and removable in 30 minutes with hand tools, - Used only on long cross-country flights. We have an outstanding safety culture on this list. If you're concerned about the gas, be advised that I fly with 11 gallons 6" above my head every time I take off. A well-secured auxillary tank with equally well-secured hardware and plumbing is acceptable to me. I welcome any suggestions or ideas to do it better. Thanks, Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312541#312541 =================================== l-List Email Forum - tenpol-List" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List =================================== sp; - MATRONICS WEB FORUMS - =_blank>http://forums.matronics.com =================================== sp; - List Contribution Web Site - sp; -Matt Dralle, List Admin. target=_blank>http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Sep 16, 2010
________________________________ From: airlion <airlion(at)bellsouth.net> Sent: Thu, September 16, 2010 12:14:24 PM Subject: Re: Pietenpol-List: Auxillary Fuel System I have 20.5 gallons in my center section wing tank and don't need any more. But if you do not have a wide center section why not go the tiger moth way and put one on top. Gravity feed works great. I had a header tank at first and could not get enough head pressure to the carb. Gardiner ________________________________ From: "hvandervoo(at)aol.com" <hvandervoo(at)aol.com> Sent: Thu, September 16, 2010 11:17:32 AM Subject: Re: Pietenpol-List: Auxillary Fuel System Kevin, This $ 13 pump better be spark proof and specially made for gasoline type fuels. Diesel pumps are no good in this application, flash point of diesel is much higher than gasoline. Suggest you look into a simple electric booster pump, try Summit racing for some product ideas. You will need 12 Volts but small rechargeable batteries are cheap. Hans NX15KV Waller, TX ----- Original Message ---- From: kevinpurtee <kevin.purtee(at)us.army.mil> Sent: Wed, September 15, 2010 2:51:40 PM Subject: Pietenpol-List: Auxillary Fuel System I'd like your thoughts on ways to add the redneck Extended Range Fuel System (ERFS) to the airplane. The design I'm currently considering is as follows: - A 3 to 5 gallon can securely strapped in the front seat, - A small pump driven by two D batteries with a dead-man switch (this pump may not have enough power, but it was only $13 so I felt it worth the experiment), - Hoses secured appropriately from can to pump, up and over the wing, then to the fuel tank filler on top of wing, - Modified gas cap to accept the inlet line. Assumptions: - No permanent mods to the airplane, - No passengers, - Portable and removable in 30 minutes with hand tools, - Used only on long cross-country flights. We have an outstanding safety culture on this list. If you're concerned about the gas, be advised that I fly with 11 gallons 6" above my head every time I take off. A well-secured auxillary tank with equally well-secured hardware and plumbing is acceptable to me. I welcome any suggestions or ideas to do it better. Thanks, Axel -------- Kevin Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312541#312541 =================================== l-List Email Forum - tenpol-List" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List =================================== sp; - MATRONICS WEB FORUMS - =_blank>http://forums.matronics.com =================================== sp; - List Contribution Web Site - sp; -Matt Dralle, List Admin. target=_blank>http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Sep 16, 2010
Hi Kevin, I know you are looking at easy/simple and as safe as possible....but just out of curiosity what do you have going on under the sheet metal between the firewall and front panel? Coils, battery, etc? Empty space? If you are only looking at only a 3 to 5 gallon tank maybe it would be worth the time to install a small header tank properly plumbed into the system. You get the extra range, still retain the ability to carry a passenger, should be able to get away without a pump, and it would be a bit more safe than strapping a can in the front seat. Just thinking.... Ryan On Wed, Sep 15, 2010 at 1:51 PM, kevinpurtee wrote: > kevin.purtee(at)us.army.mil> > > I'd like your thoughts on ways to add the redneck Extended Range Fuel > System (ERFS) to the airplane. ________________________________________________________________________________
Subject: Re: Wing education, please advise..
Date: Sep 16, 2010
The problem I see is not the airfoil. This was discussed in depth about a year ago. I brought up the idea of putting a piet on floats. It does not have enough wing area. I have a fair amout of short wing Piper experience on floats and they make good speed boats. If you compare a similar weight airplane=2C the J-3 cub. The cub climbs better and is a good performer on floats with 65hp. It certainly doesn't have a superior airfoil I don't bel ieve. But it does have 178sqft of wing area compaired to the piet's 145 or so. Incidentally the tripacer is a good performer on floats if you extend the wing. You must extend the fuse. also. I believe to compensate for mo re pitching moment. (Someone correct me on this if I'm wrong.) I feel pret ty comfortable doing the loading analysis for the longer wing=2C but not th e aerodynamics. I personally think any improvement with a new airfoil woul d be marginal. (Yes I have my armor on for that statement) Lowell also has more hp as well as the Riblett airfoil. SO=2C if you have to extend the f use as well as the wing=2C then you don't have a Pietenpol any more. I say if you want more permance...get more horse power. To quote my dad=2C "You can never have to much horse power." Hence the reason for 220hp in o ur 172. Didn't cruise much faster than a stock 172. But=2C it would lift off at 45mph and climb 2000ft/min. far more performance than changing the airfoil. Just my long winded .02 Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Re: Wing education=2C please advise.. > From: billspiet(at)sympatico.ca > Date: Thu=2C 16 Sep 2010 07:28:33 -0700 > To: pietenpol-list(at)matronics.com > ca> > > Joe=2C > > The "Riblett design" is simply an airfoil=2C not a whole wing design. You 're really on your own to figure out all the little details. > My assumption would be that the truss structure of a Riblett rib would mi mic the structure shown in the Pietenpol plans=2C and everything else (e.g. ailerons) would follow suit. Therefore=2C if the Pietenpol wing benefits f rom gap sealing=2C then the Riblett would also benefit in the same manner. The easiest method to seal the aileron gaps is to use a piano hinge=2C like Dan said. > > Your summary regarding the Riblett airfoils is basically what is being cl aimed. As far as I know=2C Pieti Lowell's is the only flying example of a R iblett airfoil on a Piet (I may be wrong on that=2C though)=2C and he claim s improved performance. > > Anecdotally=2C I overheard someone at Brodhead a couple of years ago sayi ng that the Riblett airfoil will provide twice the lift=2C and double the c ruise speed=2C and cut the stall speed in half... I took ALL of that with a BIG grain of salt. No doubt a different airfoil will result in different p erformance. Just how much different is the question=2C and whether it is an improvement is another. It seems that there are quite a few new builders c onstructing their Piets with Riblett airfoils. So=2C if and when they get t hem flying=2C we'll have some more flying examples to refer to. As it stand s now=2C it is really difficult to tell=2C since there can be so much diffe rence in performance from one Piet to another=2C due to all the design chan ges that builders make=2C as well as powerplant=2C propeller and other choi ces available. Would be really good to have another builder or two do what Lowell did=2C and fly the exact same aircraft with the two different airfoi ls=2C and compare the performances. But th! > at means a LOT of work - most of us have enough challenge just getting on e wing built (right=2C Gary?). > > In short=2C either airfoil will fly the plane just fine. If you want "tri ed and true"=2C stick with the plans. If you want to experiment with possib le performance improvements=2C and are willing to work out more little deta ils on your own=2C then give the Riblett a go. (the choice of Riblett airfo ils is up to you=2C as there were two suggested by Mr. Riblett as being sui table for the Piet). > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312625#312625 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Photo: Axel's Piet at home
Date: Sep 16, 2010
Stumbled across this nice shot of Kevin's Piet, sitting in the hangar, with the cowling off, apparently about a month prior to Brodhead. http://www.airport-data.com/aircraft/photo/522835L.html Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312673#312673 ________________________________________________________________________________
Date: Sep 16, 2010
Subject: Axle Angle
Question concerning axle alignment on a split axle gear. (Not a split Axel which is a different situation altogether.) The plans for the split axle gear show the use of aircraft style balloon tires. Those plans indicate the axles should be set with a 2 angle from vertical when the bungees are fully extended. I am using 19" motorcycle tires and die springs instead of the balloons and bungees. Is the 2 angle still appropriate? Is any toe-in or toe-out desirable? I'm almost ready to weld these up so any useful information would be very welcome. Tom Stinemetze N328X ________________________________________________________________________________
Subject: Re: Axle Angle
Date: Sep 16, 2010
Going strictly by intuition and not from experience, I would say that the 2 degree camber angle would be fine, but I don't think that you want any toe-in or toe-out between the wheels. From what I've read, this is where the Jenny style wood gear has a slight advantage in that it can not have any toe-in or toe-out unless the axle has taken a severe impact and it's bent. However, in this case something else in your airplane is probably bent or broken too, rendering the toe-in or toe-out as something of secondary importance at that point... -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312692#312692 ________________________________________________________________________________
Date: Sep 16, 2010
I have used a product that the sailors have used for years to give excellent adhesion and sealing qualities, and ease of application, called Rip Stop, 2" wide applied from below with elevator up. Riblett full length wings will be a surprise to me, if the next wing flown does not impress it's new owner. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312693#312693 ________________________________________________________________________________
Date: Sep 16, 2010
Subject: lee bottom fly-in
Hello group, Just checking to see if anyone wants to meet up on friday the 24th and fly down to lee bottom's fly-in.- I will plan on being in southw estern ohio area (Dayton, Cincinatti) around 12-1 pm friday the 24th.- I might have a Champ, and Chief in tow.- Matt Vandervort, are you planning on going down?- I was also wondering if anyone had Steve Emo's contact in fo (out of New Carlisle).- And can someone on the list reply to this e-ma il, my computer is not working right, and not sure if mail is going out. - - Shad=0A=0A=0A ________________________________________________________________________________
Date: Sep 16, 2010
Lowell=2C I'm suprised you didn't hit me harder. I was in full armor. I don't know any of you except through this list so I don't hit very hard e ither. I just think your hp makes more difference (I will be looking you u p when I get to the Model A stage) than the airfoil. The NACA2412? on the 172 is not a high lift airfoil but=2C you can put a leading edge cuff on i t and droop the ailerons turning it into a high lift airfoil and I'll just add 33% more hp and I'll win every time. Now... I always wondered what do ing both would do. May turn into a cheap fast helicopter! Not stirring the pot too much. Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Re: Wing education=2C please advise.. > From: Lowellcfrank(at)yahoo.com > Date: Thu=2C 16 Sep 2010 16:18:45 -0700 > To: pietenpol-list(at)matronics.com > com> > > I have used a product that the sailors have used for years to give excell ent adhesion and sealing qualities=2C and ease of application=2C called Rip Stop=2C 2" wide applied from below with elevator up. > Riblett full length wings will be a surprise to me=2C if the next wing fl own does not impress it's new owner. > Pieti Lowell > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=312693#312693 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Pietenpol still making history today?
From: "Peter Bichier" <pbichie(at)UTNet.UToledo.Edu>
Date: Sep 16, 2010
Hello All, I have posted this a couple of weeks ago, and have not received any comments. The topic shows as viewed 70 times, is this silence because no one knows? Meanwhile we are going to claim we are the first ones... Here is our formal letter to the EAA and below my original question to this group. From: William J. David [mailto:wjdavid582(at)embarqmail.com] Sent: Friday, September 10, 2010 10:26 AM Cc: taildragger@go-concepts.com; Andre Abreu; Peter Bichier; Martha Lunken; Joe Deaton; Richard Martin Subject: Ratings To Whom it may concern, On the morning of August 14, at Red Stewart Airport in Waynesville, Ohio, Andre Abreu and Peter Bichier of the Toledo Buzzards Light Sport Aircraft Club (TBLSACI) successfully completed their check rides for a Sport Pilot Certificate in a Pietenpol Aircamper N6186L. The evaluations were given by Martha Lunken and TBLSACI is based out of Toledo Executive Airport, TDZ, formerly Toledo Metcalf. After a little investigation we believe that they are the first persons to do so in a Pietenpol and are laying claim to this feat at this time. Anyone disputing this should contact me with evidence that shows otherwise. Other points of interest on these two guys are that they have never touched a starter button, they hand prop. They have never flown anything with a nose wheel, and they don't even know how to spell GPS let alone use one. Peter is an Ornithologist and researcher, and Andy Is a mechanical engineer for the automobile industry. William J. David President TBLSACI 20526 Caris Road Bowling Green, Ohio 43402 419-494-5843 wjdavid582(at)embarqmail.com Thu Sep 02, 2010 8:33 am Post subject: Flying on Labor Day? Gents, Ladies? I guess I'll join the old? or new! tradition to fly the Piet on Labor Day. Good to read some of the postings! I'm new, but 'me gusta volar el Pietenpol' (that's the only Spanish I was able to teach to my great instructor who taught me how to fly the Piet; "I like to Fly the Piet.") So SERIOUSLY to the knowledge of this group, have ANY one, in the HISTORY of the Pietenpol been checked out ie have done their checkride on the Piet to get their ticket? I guess Piet himself probably just taught himself how to fly, but any one else? on a 'formal' flight? Hope you can share what you know about it or what's your guesses. We are based in TDZ (Toledo, OH) and we are about a gang of 5 flying the Piet and for some of us it's the only plane we've ever flown. I'd love to fly to Foggy Bottom, I just flew to 40I (Red Stewart 215 miles if you can fly in a straight line) the old fashion way (few hours in my belt flying it alone, no radios, no GPS, just a sectional) what a blast! hope to read some more, Peter Bichier A blosoming Pietenpol pilot -------- 560 Dreamer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312701#312701 ________________________________________________________________________________
From: Matthew VanDervort <matthew.vandervort(at)gmail.com>
Subject: Re: lee bottom fly-in
Date: Sep 16, 2010
Shad, Wish I was going! But the tcraft is acting up and haven't had time to go look at it yet :( I will call a buddy of mine tomorow and see if he has ste ve's number for ya thou. If ya stop in new Carlisle let me know and I'll try and run down for a minute! I'm about 20 minutes drive from there and 5 fro W aco field. I'll let ya know tomorrow if I find his info Sent from my iPhone On Sep 16, 2010, at 8:18 PM, shad bell wrote: > Hello group, Just checking to see if anyone wants to meet up on friday the 24th and fly down to lee bottom's fly-in. I will plan on being in southwes tern ohio area (Dayton, Cincinatti) around 12-1 pm friday the 24th. I might have a Champ, and Chief in tow. Matt Vandervort, are you planning on going down? I was also wondering if anyone had Steve Emo's contact info (out of N ew Carlisle). And can someone on the list reply to this e-mail, my computer is not working right, and not sure if mail is going out. > > > Shad > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: what I've never seen at Brodhead
Date: Sep 16, 2010
In this day and age=2C I'm so thankful there's a place you can go and see c hildren and adults getting an airplane ride - for free - without signing a waiver. I've never seen a waiver or liability release statement signed at Brodhead but I guess that's why the FAA has us put "Experimental" on the en trance to the airplane isn't it. Tom B. ________________________________________________________________________________
Subject: Re: what I've never seen at Brodhead
Date: Sep 17, 2010
Tom, Don't forget that a ( X )Next to the ( N ) number, does then not require the word EXPERIENTIAL anywhere on the airplane. And you are very much correct,Brodhead is unique. I have never ever missed a year since 1976, Have met great people. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312732#312732 ________________________________________________________________________________
Subject: Re: Lee Bottom Fly-In
Date: Sep 17, 2010
I (with my two sons) will be coming to see and hopefully photograph some Piets at Lee Bottom. I'm only three hours away (driving). I'm building a GN-1. On the gear, instruments installed, tail feathers on, seats, floor boards, rudder pedals etc. all done. Working on cabanes and center section now. All ribs are done. I'm hoping to be flying by next fall. Scott Robison (Central Illinois) -------- SR78 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312734#312734 ________________________________________________________________________________
Date: Sep 17, 2010
Subject: 54th Annual Tulsa Fly-In Saturday - anyone going?
I'll be there around 9AM...departing O44 at first light. Anyone else going? Jim? Does Chuck Gantzer still read our list? I ran into him at BVO once. http://www.tulsaflyin.com/ Steve Ruse Norman, OK ________________________________________________________________________________
Date: Sep 17, 2010
Subject: Re: 54th Annual Tulsa Fly-In Saturday - anyone going?
I talked to Chuck and when we talked he was planning on going...as I am....probably sometime Saturday afternoon. If I can make it (seems like most plans I make these days get changed!) I'll find you! jm -----Original Message----- >From: Steve Ruse <steve(at)wotelectronics.com> >Sent: Sep 17, 2010 7:05 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: 54th Annual Tulsa Fly-In Saturday - anyone going? > > >I'll be there around 9AM...departing O44 at first light. Anyone else >going? Jim? Does Chuck Gantzer still read our list? I ran into him >at BVO once. > >http://www.tulsaflyin.com/ > >Steve Ruse >Norman, OK > > ________________________________________________________________________________
Date: Sep 17, 2010
Subject: Re: My Piet is Famous
Gary: The only thing wrong with that photo is the lack of engine noises. My grandson helps me with mine. Tom Stinemetze N328X >>> "Gary Boothe" 9/17/2010 9:13 AM >>> >>>My Pietenpol has joined a very select groupand its not even out of the hanger yet! >>>Gary Boothe ________________________________________________________________________________
Subject: Sticker
Date: Sep 17, 2010
I think I read somewhere that Jack Phillips was going to San Francisco for business, or personal. Anyone going to that part of California would have about a 4-4 =BD hour drive down to Tulare, where Mike & Vic Groah are building their Piet. Vic also restores old (really, really old) cars and has a very neat personal show room. If you treat the Groah=92s nicely and give them lots of compliments on their Piet, they most likely will bestow upon you a really cool sticker for your back window. Thanks, Mike & Vic! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (20 ribs down=85) ________________________________________________________________________________
Date: Sep 17, 2010
You are just lucky that it wouldn't fit in his pocket! -------- Mark Chouinard Wings and Center Section framed up - Working on Empannage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312767#312767 ________________________________________________________________________________
Date: Sep 17, 2010
I'll be there... parking the warbirds after the 11am fly-bys. I'll have my "Warbirds Flightline" shirt on and will be looking for you guys. -------- Mark Chouinard Wings and Center Section framed up - Working on Empannage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312769#312769 ________________________________________________________________________________
Date: Sep 17, 2010
Subject: Re: Sticker
I'd love one of those stickers... Ben On 9/17/2010 11:49 AM, Gary Boothe wrote: > > I think I read somewhere that Jack Phillips was going to San Francisco > for business, or personal. Anyone going to that part of California > would have about a 4-4 hour drive down to Tulare, where Mike & Vic > Groah are building their Piet. Vic also restores old (really, really > old) cars and has a very neat personal show room. > > If you treat the Groah's nicely and give them lots of compliments on > their Piet, they most likely will bestow upon you a really cool > sticker for your back window. > > Thanks, Mike & Vic! > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, mounted > Tail done, Fuselage on gear > (20 ribs down...) > ________________________________________________________________________________
Date: Sep 17, 2010
SWxsIGJlIGluIFNhY3JhbWVudG8gYW5kIFN0b2NrdG9uIDEwLzMxIGFuZCAxMS8xIGRvZXMgdGhh dCBoZWxwPyBvciBhdCAgCmxlYXN0IGdldCBtZSBhIHZpc2l0IG9yIG5lYXIgdG8gYSB2aXNpdCBs b2NhdGlvbiAgb24gU3VuZGF5ICAxMC8zMQogCmRvIG5vdCBhcmNoaXZlCiAKU2FmZXR5IG1hbiBj b21pbmcgdG8gYW4gYWlycG9ydCBuZWFyIHlvdSEKIApKb2huCiAKIApJbiBhIG1lc3NhZ2UgZGF0 ZWQgOS8xNy8yMDEwIDI6NTg6MTIgUC5NLiBFYXN0ZXJuIERheWxpZ2h0IFRpbWUsICAKYmVuY2hh cnZldEBnbWFpbC5jb20gd3JpdGVzOgoKSSdkIGxvdmUgIG9uZSBvZiB0aG9zZSBzdGlja2Vycy4u LgoKQmVuCk9uIDkvMTcvMjAxMCAxMTo0OSBBTSwgR2FyeSBCb290aGUgIHdyb3RlOiAgCiAKSSB0 aGluayBJIHJlYWQgc29tZXdoZXJlIHRoYXQgIEphY2sgUGhpbGxpcHMgd2FzIGdvaW5nIHRvIFNh biAgRnJhbmNpc2NvIApmb3IgYnVzaW5lc3MsIG9yIHBlcnNvbmFsLiBBbnlvbmUgZ29pbmcgdG8g IHRoYXQgcGFydCBvZiBDYWxpZm9ybmlhIHdvdWxkIGhhdmUgCmFib3V0IGEgIDQtNCDCvSBob3Vy IGRyaXZlIGRvd24gdG8gVHVsYXJlLCB3aGVyZSBNaWtlICYgVmljIEdyb2FoIGFyZSAgCmJ1aWxk aW5nIHRoZWlyIFBpZXQuIFZpYyBhbHNvIHJlc3RvcmVzIG9sZCAocmVhbGx5LCByZWFsbHkgb2xk KSBjYXJzIGFuZCBoYXMgIGEgCnZlcnkgbmVhdCBwZXJzb25hbCBzaG93IHJvb20uICAKSWYgeW91 IHRyZWF0IHRoZSBHcm9haOKAmXMgbmljZWx5ICBhbmQgZ2l2ZSB0aGVtIGxvdHMgb2YgY29tcGxp bWVudHMgb24gdGhlaXIgClBpZXQsIHRoZXkgbW9zdCBsaWtlbHkgd2lsbCAgYmVzdG93IHVwb24g eW91IGEgcmVhbGx5IGNvb2wgc3RpY2tlciBmb3IgeW91ciAKYmFjayAgd2luZG93LiAKVGhhbmtz LCBNaWtlICYgIFZpYyEgCkdhcnkgQm9vdGhlICAKQ29vbCwgQ2EuICAKUGlldGVucG9sICAKV1cg Q29ydmFpciBDb252ZXJzaW9uLCAgbW91bnRlZCAKVGFpbCBkb25lLCBGdXNlbGFnZSBvbiAgZ2Vh ciAKKDIwIHJpYnMgZG93buKApikgICAKCgoKIAogXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KIF8tPSAgICAgICAgICAtIFRoZSBQ aWV0ZW5wb2wtTGlzdCBFbWFpbCBGb3J1bSAtCiBfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCiBfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMg c3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKIF8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25s b2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKIF8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBt dWNoIG1vcmU6CiBfLT0KIF8tPSAgIC0tPiBfaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmln YXRvcj9QaWV0ZW5wb2wtTGlzdF8gCihodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9y P1BpZXRlbnBvbC1MaXN0KSAKIF8tPQogXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KIF8tPSAgICAgICAgICAgICAgIC0gTUFUUk9O SUNTIFdFQiBGT1JVTVMgLQogXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2 aWEgdGhlIFdlYiBGb3J1bXMhCiBfLT0KIF8tPSAgIC0tPiBfaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tXyAoaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLykgCiBfLT0KIF8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CiBfLT0g ICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCiBfLT0gIFRoYW5rIHlv dSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQogXy09ICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgogXy09ICAgLS0+IF9odHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uXyAKKGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250 cmlidXRpb24pIAogXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KIAoKCgo ________________________________________________________________________________
Date: Sep 17, 2010
d3d3LnBlbGljYW4uY29tDQoNCkdvb2QgbHVjayB0byB5b3UhDQoNCkdhcnkgQm9vdGhlDQpEbyBu b3QgYXJjaGl2ZQ0KU2VudCBvbiB0aGUgU3ByaW50wq4gTm93IE5ldHdvcmsgZnJvbSBteSBCbGFj a0JlcnJ5wq4NCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206ICJhbXNhZmV0eWNA YW9sLmNvbSIgPGFtc2FmZXR5Y0Bhb2wuY29tPg0KU2VuZGVyOiBvd25lci1waWV0ZW5wb2wtbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbQ0KRGF0ZTogRnJpLCAxNyBTZXAgMjAxMCAxNjo0ODowNiAN ClRvOiA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4NClJlcGx5LVRvOiBwaWV0ZW5wb2wt bGlzdEBtYXRyb25pY3MuY29tU3ViamVjdDogUkU6IFBpZXRlbnBvbC1MaXN0OiBSZTogTXkgUGll dCBpcyBGYW1vdXMNCg0KS2V2aW4gYW5kIGkgcGxhbiBvbiB2aXNpdGluZyBIYW5zIG9uIHRodXJz ZGF5IGV2ZW5pbmcuIElmIGFsbCBnb2VzIHdlbGwgd2UgIA0Kd2lsbCBuZWVkIGV4dHJhIGx1Z2dh Z2UgdG9vIHdoZXJlIGRvIHlvdSByZWNjb21lbmQgaSBwaWNrIHVwIGEgbGFyZ2UgIA0KY2FwYWNp dHkgYmFnIGZvciBoZWF2eSBkdXR5IGxvYWRpbmc/DQoNCkRvIG5vdCBhcmNoaXZlDQoNCkpvaG4N Cg0KU2VudCB2aWEgRFJPSUQgb24gVmVyaXpvbiBXaXJlbGVzcw0KDQotLS0tLU9yaWdpbmFsIG1l c3NhZ2UtLS0tLQ0KRnJvbTogSmltIE1hcmtsZSA8amltX21hcmtsZUBtaW5kc3ByaW5nLmNvbT4N ClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tDQpTZW50OiBGcmksIFNlcCAxNywgMjAx MCAyMDowODoyMSBHTVQrMDA6MDANClN1YmplY3Q6IFJFOiBQaWV0ZW5wb2wtTGlzdDogUmU6IE15 IFBpZXQgaXMgRmFtb3VzDQoNCi0tPiBQaWV0ZW5wb2wtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog SmltIE1hcmtsZSA8amltX21hcmtsZUBtaW5kc3ByaW5nLmNvbT4NCg0KWWVhaCBhbmQgSSdtIGhh dmluZyB0byBjaGVjayBhbiBleHRyYSBiYWcgZm9yIHRoZSBmbGlnaHQgaG9tZSB0b25pZ2h0Li4u DQoNCkNvaW5jaWRlbmNlPw0KDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQo+RnJvbTog R2FyeSBCb290aGUgPGdib290aGU1QGNvbWNhc3QubmV0Pg0KPlNlbnQ6IFNlcCAxNywgMjAxMCAx MDozMCBBTQ0KPlRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tDQo+U3ViamVjdDogUkU6 IFBpZXRlbnBvbC1MaXN0OiBSZTogTXkgUGlldCBpcyBGYW1vdXMNCj4NCj5ZZWFoLCBidXQgY2hl Y2sgdGhpcyBvdXQuLi5JbiB0aGUgYXR0YWNoZWQgJzE5NzcnIHRoZSBlbmdpbmUgaXMgY2xlYXJs eQ0KPm1vdW50ZWQgb24gdGhlIHBsYW5lLiBJIHdlbnQgaW4gdG8gdGhlIGhvdXNlIGFuZCBjYW1l IG91dCBhIGZldyBtaW51dGVzDQo+bGF0ZXIuLi50aGV5IGhhZCByb2xsZWQgdGhlIHBsYW5lIGlu IHRvIHRoZSBnYXJhZ2UgYW5kIGxlZnQuIEkgdG9vayB0aGUNCj5waWN0dXJlICMxOTc4Li4uc29t ZXRoaW5nJ3MgbWlzc2luZy4uLg0KPg0KPkdhcnkgQm9vdGhlIA0KPkNvb2wsIENhLiANCj5QaWV0 ZW5wb2wgDQo+V1cgQ29ydmFpciBDb252ZXJzaW9uLCBtb3VudGVkIA0KPlRhaWwgZG9uZSwgRnVz ZWxhZ2Ugb24gZ2VhciANCj4oMjAgcmlicyBkb3duLikgDQo+RG8gbm90IGFyY2hpdmUNCj4NCj4N Cj4tLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KPkZyb206IG93bmVyLXBpZXRlbnBvbC1saXN0 LXNlcnZlckBtYXRyb25pY3MuY29tDQo+W21haWx0bzpvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2 ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIEs1WUFDDQo+U2VudDogRnJpZGF5LCBTZXB0 ZW1iZXIgMTcsIDIwMTAgOToyOCBBTQ0KPlRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29t DQo+U3ViamVjdDogUGlldGVucG9sLUxpc3Q6IFJlOiBNeSBQaWV0IGlzIEZhbW91cw0KPg0KPi0t PiBQaWV0ZW5wb2wtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIks1WUFDIiA8aGFuZ2FyMTBAY294 Lm5ldD4NCj4NCj5Zb3UgYXJlIGp1c3QgbHVja3kgdGhhdCBpdCB3b3VsZG4ndCBmaXQgaW4gaGlz IHBvY2tldCENCj4NCj4tLS0tLS0tLQ0KPk1hcmsgQ2hvdWluYXJkDQo+V2luZ3MgYW5kIENlbnRl ciBTZWN0aW9uIGZyYW1lZCB1cCAtIFdvcmtpbmcgb24gRW1wYW5uYWdlDQo+DQo+DQo+DQo+DQo+ DQo+UmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KPg0KPmh0dHA6Ly9mb3J1bXMubWF0cm9u aWNzLmNvbS92aWV3dG9waWMucGhwP3A9MzEyNzY3IzMxMjc2Nw0KPg0KPg0KPg0KPg0KPg0KPg0K Pg0KPg0KPg0KDQoNCg0KDQoNCg0KDQoNCg0K ________________________________________________________________________________
Date: Sep 17, 2010
I think every one that has a Pietenpol should have a sticker like that,on their wind screen. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312805#312805 ________________________________________________________________________________
Date: Sep 18, 2010
VW5mb3J0dW5hdGVseSwgSSdsbCBiZSBhdCBDb3J2YWlyIENvbGxlZ2UgIzE4IHRoYXQgd2Vla2Vu ZCwgaG9wZWZ1bGx5IHJ1bm5pbmcgbXkgZW5naW5lIHRoZSAxc3QgdGltZSEgDQoNCkdhcnkgQm9v dGhlDQpEbyBub3QgYXJjaGl2ZQ0KU2VudCBvbiB0aGUgU3ByaW50wq4gTm93IE5ldHdvcmsgZnJv bSBteSBCbGFja0JlcnJ5wq4NCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206IEFN c2FmZXR5Q0Bhb2wuY29tDQpTZW5kZXI6IG93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tDQpEYXRlOiBGcmksIDE3IFNlcCAyMDEwIDE2OjM3OjI4IA0KVG86IDxwaWV0ZW5w b2wtbGlzdEBtYXRyb25pY3MuY29tPg0KUmVwbHktVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmlj cy5jb21TdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IFN0aWNrZXINCg0KDQo ________________________________________________________________________________
Date: Sep 18, 2010
Subject: Sticker
Date: Sep 17, 2010
I=92ll be in San Francisco the last week of October. Unfortunately, I=92ll be in training all week with no ground transportation so I won=92t be able to leave Moffet Field. How do I get one of those stickers? Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Friday, September 17, 2010 11:49 AM Subject: Pietenpol-List: Sticker I think I read somewhere that Jack Phillips was going to San Francisco for business, or personal. Anyone going to that part of California would have about a 4-4 =BD hour drive down to Tulare, where Mike & Vic Groah are building their Piet. Vic also restores old (really, really old) cars and has a very neat personal show room. If you treat the Groah=92s nicely and give them lots of compliments on their Piet, they most likely will bestow upon you a really cool sticker for your back window. Thanks, Mike & Vic! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, mounted Tail done, Fuselage on gear (20 ribs down=85) ________________________________________________________________________________
Subject: Axle Angle
Date: Sep 17, 2010
Tom, Not sure about the angle, my split axle has springs and they are adjustable so I can make that decision later. I am sure that you do not want any toe-in. Exactly straight is best, err on the side of toe-out. Skip ----- Original Message ----- From: TOM STINEMETZE Sent: 9/16/2010 5:09:01 PM Subject: Pietenpol-List: Axle Angle Question concerning axle alignment on a split axle gear. (Not a split Axel which is a different situation altogether.) The plans for the split axle gear show the use of aircraft style balloon tires. Those plans indicate the axles should be set with a 2 angle from vertical when the bungees are fully extended. I am using 19" motorcycle tires and die springs instead of the balloons and bungees. Is the 2 angle still appropriate? Is any toe-in or toe-out desirable? I'm almost ready to weld these up so any useful information would be very welcome. Tom Stinemetze N328X ________________________________________________________________________________
Subject: Re: Got an engine!
Date: Sep 17, 2010
I received my crankshaft back today from Moldex and picked up my case from a local transmission shop after cleaning. Things are looking better! -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312815#312815 Attachments: http://forums.matronics.com//files/clean_case_649.jpg http://forums.matronics.com//files/finished_crank_826.jpg ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Sep 17, 2010
has anyone tried the half acetone half auto trans fluid home brew on those rusty cylinders yet? it supposedly is as good or better than the penetrating oils. I never mixed the stuff up but it wouldn't cost a whole lot to have quite a bit of fluid to fill some cylinders.might be a place for it to be tried.Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=312816#312816 ________________________________________________________________________________
Date: Sep 17, 2010
Jack, Moffet's about 40 miles from SF. I pass by Vic Groah's place a couple of times a week. I can stop in and snag a couple of stickers if any are available (Mike, Vic?). Tell me where you're staying while at Moffet and we can meet for dinner and a sticker hand-off. Mike Hardaway On Fri, Sep 17, 2010 at 6:00 PM, Jack Phillips wrot e: > I=92ll be in San Francisco the last week of October. Unfortunately, I =92ll > be in training all week with no ground transportation so I won=92t be abl e to > leave Moffet Field. How do I get one of those stickers? > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Gary Boothe > *Sent:* Friday, September 17, 2010 11:49 AM > > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: Sticker > >
September 03, 2010 - September 18, 2010
Pietenpol-Archive.digest.vol-jp
