Pietenpol-Archive.digest.vol-jv
- - - , 20- - December 14, 2010
      Michael Perez
      Karetaker Aero
      www.karetakeraero.com
      --- On Tue, 11/23/10, integritywood  wrote:
Subject: New Builder
Date: - - - , 20-
com> Hi all First the intro before the questions and off the wall comments. 25 years or so ago, as a kid, I dreamed of building and flying my own plane. Looking b ack it likely would have been built of 2x6 and 3/8 inch plywood, weighed in at 3500 lbs empty, and been powered by a snowmobile engine. Oh the optimis m of youth! Then came real life, having a family making a living, etc...- But the dream of flight stayed nestled quietly in the back of my mind, fan ned once in a while with a ride or even just watching a small plane fly by. A year and a half or so ago the ember started glowing brighter again and w ith a little encouragement burst into a flaming desire I can't seem to exti nguish (okay I'm not trying very hard). with a little research on the web I found building my own plane wasn't so o ff the wall (although with a slightly modified materials list). Then I foun d the Pietenpol. Ever since I first saw her I want her so bad I can taste i t. Ive lurked here daily in the last year trying to learn all I could about her but to shy to speak up till I could say Ive started building. Well Ive started. Finished my rib jig yest and started cutting pieces, What a feeli ng. My wife is doing very well with it considering small planes scare her. I tell her many Piets take 10 or more years to complete so she doesn't have to worry for a while [Wink]- Anyhow, thanks Cliff for your kindly reply to my email the other day and Michael for your hint video's. See you around Kim(ball) -------- "She is about as hot as you'll ever find a plane and I'll bet that 10 years from now the design will be pretty warm still."- B. H. Pietenp ol Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320629#320629 le, List Admin. ________________________________________________________________________________
Subject: Re: Salt Lake City Piet
Date: Nov 24, 2010
Pieti,if denver is on your way home,give a holler.Dave -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320879#320879 ________________________________________________________________________________
Date: Nov 24, 2010
Subject: latex aplication (paint, not the other things)
Charles, it is pretty easy to apply house paint (you have probably done it a 100 times).- The technique Dad and I used is to use a 3inch foam brush and apply all coats 90 degrees from the previous coat.- We used Sears Wea therbeater Plus, with Flotrol (a flowing agent) mixed in with the paint.- I believe the best way to mix in the flotrol is mix it in the qt cup you a re using and dipping the brush in (don't mix it in with the whole gallon al l at once, just my oppinion here).- We just used white as an undercoat, s ome say you have to use black, so it will block out the UV rays, do as you wish.- The 1st thing you need to buy, if you decide to commit and use lat ex, is a good pair of ear plugs so you don't have to listen to all th B.S. people will try to force feed you.- Some will say it's a great idea, othe rs will tell you your paint is going to come off in flight, the fabric will follow and you will be a 1929 lawn dart.- If I ever let the paint get that bad, the fabric that rotten, that I didn't notice it on a preflight -I guess I deserve to gravity plant a Corvair Spruce tree.- It Ain't th e Space Shuttle (Mike Cuy can verify that, he works for NASA).- In closin g, I think that poly fiber IS a better looking finish, Poly Fiber probably WILL last longer, and it-WILL cost you more.- You can probably eaisly c over and paint your piet twice with the Eco-bond, and latex, compared to us ing the complete Poly Fiber system.-The other good bennifit to using wate rbased adheasive and latex, is no toxic chemicals, fumes or clean-up.-The choice is Yours choose wisely. - "Views-and oppinions-expressed in this e-mail are the sole oppinions of Shad Bell, and in no way reflect the views of the pietenpol list." - Shad=0A=0A=0A ________________________________________________________________________________
Date: Nov 24, 2010
Dave Where in Denver? I'm in SE Denver and slowly working on a Piet... Cheers Jonathan A. -----Original Message----- From: Dangerous Dave <dsornbor(at)aol.com> Sent: Wed, Nov 24, 2010 12:45 pm Subject: Pietenpol-List: Re: Salt Lake City Piet Pieti,if denver is on your way home,give a holler.Dave -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320879#320879 ________________________________________________________________________________
Date: Nov 25, 2010
Subject: Re: latex aplication (paint, not the other things)
I just finished painting my fuselage using Behr latex paint. Check out my w eb site for details. Click on Pietenpol http://home.comcast.net/~mmorrison123/ Malcolm Morrison Pietenpol Air Camper Kolb MKII (for sale) ASW-15 ----- Original Message ----- From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Wednesday, November 24, 2010 8:36:12 PM Subject: Pietenpol-List: latex aplication (paint, not the other things) Charles, it is pretty easy to apply house paint (you have probably done it a 100 times). The technique Dad and I used is to use a 3inch foam brush and apply all coats 90 degrees from the previous coat. We used Sears Weatherbe ater Plus, with Flotrol (a flowing agent) mixed in with the paint. I believ e the best way to mix in the flotrol is mix it in the qt cup you are using and dipping the brush in (don't mix it in with the whole gallon all at once , just my oppinion here). We just used white as an undercoat, some say you have to use black, so it will block out the UV rays, do as you wish. The 1s t thing you need to buy, if you decide to commit and use latex, is a good p air of ear plugs so you don't have to listen to all th B.S. people will try to force feed you. Some will say it's a great idea, others will tell you y our paint is going to come off in flight, the fabric will follow and you wi ll be a 1929 lawn dart. If I ever let the paint get that bad, the fabric th at rotten, that I didn't notice it on a preflight I guess I deserve to grav ity plant a Corvair Spruce tree. It Ain't the Space Shuttle (Mike Cuy can v erify that, he works for NASA). In closing, I think that poly fiber IS a be tter looking finish, Poly Fiber probably WILL last longer, and it WILL cost you more. You can probably eaisly cover and paint your piet twice with the Eco-bond, and latex, compared to using the complete Poly Fiber system. The other good bennifit to using waterbased adheasive and latex, is no toxic c hemicals, fumes or clean-up. The choice is Yours choose wisely. "Views and oppinions expressed in this e-mail are the sole oppinions of Sha d Bell, and in no way reflect the views of the pietenpol list." Shad ________________________________________________________________________________
Date: Nov 24, 2010
Shad, - Your post is soild and agree with what you had to say! No issues form me an d frankly, I have seen many extremely nice latex painted planes throughout the years. The only thing I can add is I think all paint comes from two man ufacturer's in the country. So, not sure if the best is any different than the worst as not sure what is added to separate them form each other.... ot her than a label. - My 2Cents worth. - Ken Heide- - --- On Wed, 11/24/10, gliderx5(at)comcast.net wrote: From: gliderx5(at)comcast.net <gliderx5(at)comcast.net> Subject: Re: Pietenpol-List: latex aplication (paint, not the other things) Date: Wednesday, November 24, 2010, 10:17 PM #yiv1198058740 p {margin:0;} I just finished painting my fuselage using Behr latex paint.- Check out m y web site for details.- Click on Pietenpol http://home.comcast.net/~mmorrison123/ Malcolm Morrison Pietenpol Air Camper Kolb MKII (for sale) ASW-15 ----- Original Message ----- From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Wednesday, November 24, 2010 8:36:12 PM Subject: Pietenpol-List: latex aplication (paint, not the other things) Charles, it is pretty easy to apply house paint (you have probably done it a 100 times).- The technique Dad and I used is to use a 3inch foam brush and apply all coats 90 degrees from the previous coat.- We used Sears Wea therbeater Plus, with Flotrol (a flowing agent) mixed in with the paint.- I believe the best way to mix in the flotrol is mix it in the qt cup you a re using and dipping the brush in (don't mix it in with the whole gallon al l at once, just my oppinion here).- We just used white as an undercoat, s ome say you have to use black, so it will block out the UV rays, do as you wish.- The 1st thing you need to buy, if you decide to commit and use lat ex, is a good pair of ear plugs so you don't have to listen to all th B.S. people will try to force feed you.- Some will say it's a great idea, othe rs will tell you your paint is going to come off in flight, the fabric will follow and you will be a 1929 lawn dart.- If I ever let the paint get that bad, the fabric that rotten, that I didn't notice it on a preflight -I guess I deserve to gravity plant a Corvair Spruce tree.- It Ain't th e Space Shuttle (Mike Cuy can verify that, he works for NASA).- In closin g, I think that poly fiber IS a better looking finish, Poly Fiber probably WILL last longer, and it-WILL cost you more.- You can probably eaisly c over and paint your piet twice with the Eco-bond, and latex, compared to us ing the complete Poly Fiber system.-The other good bennifit to using wate rbased adheasive and latex, is no toxic chemicals, fumes or clean-up.-The choice is Yours choose wisely. - "Views-and oppinions-expressed in this e-mail are the sole oppinions of Shad Bell, and in no way reflect the views of the pietenpol list." - Shad _blank">www.aeroelectric.com " target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com =0A=0A=0A ________________________________________________________________________________
Subject: Model A Ford Engine Mount Dimension
Date: Nov 24, 2010
Does anyone have the distance between the Model A crankshaft centerline and the top of the engine bearer? (see attached sketch) I believe this is basically the thickness of the oil pan flange and the leather padding used between it and the engine bearer. Is this correct? Thanks Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320908#320908 Attachments: http://forums.matronics.com//files/crankcl1_210.gif http://forums.matronics.com//files/crankcl2_128.gif ________________________________________________________________________________
Subject: Wanted - BPA News Back Issues
Date: Nov 24, 2010
Wanted - Your unwanted issues of BPA News. Thanks Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320910#320910 ________________________________________________________________________________
Date: Nov 24, 2010
I will be using latex (white undercoat) and 3m Fastbond (instead of Eco-bond) I am 90% sure that the Fastbond is the same thing but less expensive. I have a friend that is covering with the complete Stewart system and we are going to do some experimenting and comparison. BTW If anyone is interested in spraying latex, I purchased a turbine HVLP sprayer from Harbor Freight for $70. When it came I thought it was just a toy. Sounds like a shop vac. I am quite impressed, however with the results. I painted my house with it this fall and it worked great on large flat areas. I am not an expert painter, but I found it had good control and used about 30 to 40% less paint. I may try it on the final coats on the Piet. -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320911#320911 ________________________________________________________________________________
Date: Nov 25, 2010
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Model A Ford Engine Mount Dimension
Date: Nov 25, 2010
Craig, Wish I had my engine back from Antique Engine Rebuilders in Skokie, IL. I c ould have walked out to the hangar and measured for you. Why do you need to know this? Building cowls? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Mr. Craig <acwelder(at)cableone.net> Sent: Wed, Nov 24, 2010 11:08 pm Subject: Pietenpol-List: Model A Ford Engine Mount Dimension Does anyone have the distance between the Model A crankshaft centerline and the op of the engine bearer? (see attached sketch) I believe this is basically the hickness of the oil pan flange and the leather padding used between it and the ngine bearer. Is this correct? Thanks Craig -------- goal without a plan is nothing more than a wish. -- orion ead this topic online here: http://forums.matronics.com/viewtopic.php?p=320908#320908 ttachments: http://forums.matronics.com//files/crankcl1_210.gif ttp://forums.matronics.com//files/crankcl2_128.gif -======================== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Date: Nov 25, 2010
helspersew(at)aol.com wrote: > Craig, > > Building cowls? > > Dan Helsper > Poplar Grove, IL. Yep. Trying to 3D model it in CAD and then extract a accurate sheet metal pattern. Thanks Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=320997#320997 ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Nov 25, 2010
Hi Malcolm, The Piet looks great in Behr paint, and good information on how you applied it. I've only used it for its 'official' usage, but it's tough stuff, should last well. If the lady on the left side side of the picture is your boss, then we both have beautiful red headed Beths for spouses. Can't say much about the three rouges in the background though - arggh! KIp Gardner On Nov 24, 2010, at 11:17 PM, gliderx5(at)comcast.net wrote: > I just finished painting my fuselage using Behr latex paint. Check out my web site for details. Click on Pietenpol > > http://home.comcast.net/~mmorrison123/ > > Malcolm Morrison > Pietenpol Air Camper > Kolb MKII (for sale) > ASW-15 > > ----- Original Message ----- > From: "shad bell" <aviatorbell(at)yahoo.com> > To: pietenpol-list(at)matronics.com > Sent: Wednesday, November 24, 2010 8:36:12 PM > Subject: Pietenpol-List: latex aplication (paint, not the other things) > > Charles, it is pretty easy to apply house paint (you have probably done it a 100 times). The technique Dad and I used is to use a 3inch foam brush and apply all coats 90 degrees from the previous coat. We used Sears Weatherbeater Plus, with Flotrol (a flowing agent) mixed in with the paint. I believe the best way to mix in the flotrol is mix it in the qt cup you are using and dipping the brush in (don't mix it in with the whole gallon all at once, just my oppinion here). We just used white as an undercoat, some say you have to use black, so it will block out the UV rays, do as you wish. The 1st thing you need to buy, if you decide to commit and use latex, is a good pair of ear plugs so you don't have to listen to all th B.S. people will try to force feed you. Some will say it's a great idea, others will tell you your paint is going to come off in flight, the fabric will follow and you will be a 1929 lawn dart. If I ever let the paint get that bad, the fabric that rotten, that I didn't notice it on a preflight I guess I deserve to gravity plant a Corvair Spruce tree. It Ain't the Space Shuttle (Mike Cuy can verify that, he works for NASA). In closing, I think that poly fiber IS a better looking finish, Poly Fiber probably WILL last longer, and it WILL cost you more. You can probably eaisly cover and paint your piet twice with the Eco-bond, and latex, compared to using the complete Poly Fiber system. The other good bennifit to using waterbased adheasive and latex, is no toxic chemicals, fumes or clean-up. The choice is Yours choose wisely. > > "Views and oppinions expressed in this e-mail are the sole oppinions of Shad Bell, and in no way reflect the views of the pietenpol list." > > Shad > > > > _blank">www.aeroelectric.com > " target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > _blank">http://www.matronics.com/contribution > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > > ________________________________________________________________________________
Date: Nov 25, 2010
I used the Behr paint on my fuselage, and it turned out a lot glossier than the Sherwin Williams I used on the wings and horiz. stab. It was at least 10 dollars a gallon cheaper too. Home Depot has it ready mixed in a real nice red. Ben Charvet 60 hours, and no paint has peeled off in flight. On 11/24/2010 11:17 PM, gliderx5(at)comcast.net wrote: > I just finished painting my fuselage using Behr latex paint. Check > out my web site for details. Click on Pietenpol > > http://home.comcast.net/~mmorrison123/ > <http://home.comcast.net/%7Emmorrison123/> > > Malcolm Morrison > Pietenpol Air Camper > Kolb MKII (for sale) > ASW-15 > > ----- Original Message ----- > From: "shad bell" <aviatorbell(at)yahoo.com> > To: pietenpol-list(at)matronics.com > Sent: Wednesday, November 24, 2010 8:36:12 PM > Subject: Pietenpol-List: latex aplication (paint, not the other things) > > Charles, it is pretty easy to apply house paint (you have probably > done it a 100 times). The technique Dad and I used is to use a 3inch > foam brush and apply all coats 90 degrees from the previous coat. We > used Sears Weatherbeater Plus, with Flotrol (a flowing agent) mixed in > with the paint. I believe the best way to mix in the flotrol is mix > it in the qt cup you are using and dipping the brush in (don't mix it > in with the whole gallon all at once, just my oppinion here). We just > used white as an undercoat, some say you have to use black, so it will > block out the UV rays, do as you wish. The 1st thing you need to buy, > if you decide to commit and use latex, is a good pair of ear plugs so > you don't have to listen to all th B.S. people will try to force feed > you. Some will say it's a great idea, others will tell you your paint > is going to come off in flight, the fabric will follow and you will be > a 1929 lawn dart. If I ever let the paint get that bad, the fabric > that rotten, that I didn't notice it on a preflight I guess I deserve > to gravity plant a Corvair Spruce tree. It Ain't the Space Shuttle > (Mike Cuy can verify that, he works for NASA). In closing, I think > that poly fiber IS a better looking finish, Poly Fiber probably WILL > last longer, and it WILL cost you more. You can probably eaisly cover > and paint your piet twice with the Eco-bond, and latex, compared to > using the complete Poly Fiber system. The other good bennifit to using > waterbased adheasive and latex, is no toxic chemicals, fumes or > clean-up. The choice is Yours choose wisely. > "Views and oppinions expressed in this e-mail are the sole oppinions > of Shad Bell, and in no way reflect the views of the pietenpol list." > Shad > > > * > > _blank">www.aeroelectric.com > " target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > _blank">http://www.matronics.com/contribution > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > * > * > > * ________________________________________________________________________________
Subject: Re: Fuselage Sides
Date: Nov 25, 2010
Hi Craig, As you said, I built the wooden fuselage, but I just took a look through the FGM reprint, and in the article, it says to "... tack weld each of the sides together. Then turn them bottom side up, and with the top longerons on the floor over the top view, tack in the cross members for the top." Sure sounds like the same method as used for the wooden fuselage. But then, I don't know whether that would be the "preferred" method, by today's standards. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321028#321028 Attachments: http://forums.matronics.com//files/fgm13_178.pdf ________________________________________________________________________________
Subject: Re: Newby
Date: Nov 25, 2010
[quote="cncampbell(at)windstream."]In the military anytime a new guy comes on the scene he is called a Newby. That's me. Name is Chuck Campbell. Dan Helsper led me to this list. I have been building an AirCamper since last May. Have all the ribs done, the tail surfaces done except for varnishing and covering/painting. Fuselage is about half done. Have the wood for the wing spars. Just need to rip them to the proper width. Am getting ready to installl the controls in the fuselage. As soon as that is complete I can put on the plywood sides, seats, turtle-back etc. I have just about all the metal pieces ready to go. Dan has been helping me by showing me how to get to the Stewart glue videos. I want some info from some of you guys (like Shad Bell and Rick Holland) who used house paint. I don't have access to a paint booth to use the Stewart paint system. All I have is a couple of paint brushes. Any word of advice from any of you would be appreciated. I've been flying about all of my adult life but am plowing new ground building this Piet. > [b] Howdy Chuck Sounds like you are doing great. As far as cover and paint goes I used lightweight uncertified fabric glued down with Stewart Ecobond (best to use the stuff above 60 degrees which ain't easy this time of year), very easy to use and no toxic vapors. Then I painted using the Bell Latex method, a cross coat of latex primer (I think Shad may have done 2) followed by 2 cross coats of exterior Satin latex (Sherwin Williams Super Paint in my case). I experimented a bit with thinning and ended up adding 10% distilled water and 10% Floetrol by weight if brushing (used 3" foam brushes). And if you have a sprayer and compressor it makes the job even easier. I sprayed my tail pieces but had to thin quit a bit more, I added 25% water and 10% Floetrol using a cheap Lowes HVLP sprayer. Attached a picture, keep up the good work. rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321033#321033 Attachments: http://forums.matronics.com//files/img_3510_104.jpg http://forums.matronics.com//files/img_3512_536.jpg ________________________________________________________________________________
Date: Nov 25, 2010
For some objective latex durability results. My latex test panel is still looking great after 6 years on a fencepost outside 365 days a year facing true South at 6700 feet altitude in Colorado (lots of UV and direct sun). Just 2 cross coats of Sherwin Williams Gloss Latex Super Paint. Tested with a punch tester 2 years ago and couldn't go through on one side and punched through at nearly the max tester reading on the other. Figure if you hanger your Piet and fly 100 hours a year it would take you (365 * 24 * 6)/100 = 525.6 years to get your cover/paint job to the same state as this test panel. rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321036#321036 Attachments: http://forums.matronics.com//files/img_2658_212.jpg http://forums.matronics.com//files/img_2657_205.jpg ________________________________________________________________________________
Subject: Re: Newby
Date: Nov 25, 2010
Rick, Same process on the aluminum? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (22 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of at7000ft Sent: Thursday, November 25, 2010 11:25 AM Subject: Pietenpol-List: Re: Newby [quote="cncampbell(at)windstream."]In the military anytime a new guy comes on the scene he is called a Newby. That's me. Name is Chuck Campbell. Dan Helsper led me to this list. I have been building an AirCamper since last May. Have all the ribs done, the tail surfaces done except for varnishing and covering/painting. Fuselage is about half done. Have the wood for the wing spars. Just need to rip them to the proper width. Am getting ready to installl the controls in the fuselage. As soon as that is complete I can put on the plywood sides, seats, turtle-back etc. I have just about all the metal pieces ready to go. Dan has been helping me by showing me how to get to the Stewart glue videos. I want some info from some of you guys (like Shad Bell and Rick Holland) who used house paint. I don't have access to a paint booth to use the Stewart paint system. All I have is a couple of paint brushes. Any word of advice from any of you would be appreciated.! I've been flying about all of my adult life but am plowing new ground building this Piet. > [b] Howdy Chuck Sounds like you are doing great. As far as cover and paint goes I used lightweight uncertified fabric glued down with Stewart Ecobond (best to use the stuff above 60 degrees which ain't easy this time of year), very easy to use and no toxic vapors. Then I painted using the Bell Latex method, a cross coat of latex primer (I think Shad may have done 2) followed by 2 cross coats of exterior Satin latex (Sherwin Williams Super Paint in my case). I experimented a bit with thinning and ended up adding 10% distilled water and 10% Floetrol by weight if brushing (used 3" foam brushes). And if you have a sprayer and compressor it makes the job even easier. I sprayed my tail pieces but had to thin quit a bit more, I added 25% water and 10% Floetrol using a cheap Lowes HVLP sprayer. Attached a picture, keep up the good work. rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321033#321033 Attachments: http://forums.matronics.com//files/img_3510_104.jpg http://forums.matronics.com//files/img_3512_536.jpg ________________________________________________________________________________
Date: Nov 25, 2010
dog67(at)aol.com wrote: > Dave Where in Denver? I'm in SE Denver and slowly working on a Piet... > Cheers > Jonathan A. > > > > > -- Jonathan - Am in Castle Rock if you want to come by some time and talk Piets (I'll show you mine if you'll show me yours ?:). Maybe we can get Dave to come down from Idaho Springs and make it a 3-some. rick at7000ft(at)gmail.com -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321038#321038 ________________________________________________________________________________
Date: Nov 25, 2010
Rick, Did you paint the aluminum the same way? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (22 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of at7000ft Sent: Thursday, November 25, 2010 11:47 AM Subject: Pietenpol-List: Re: latex aplication (paint, not the other things) For some objective latex durability results. My latex test panel is still looking great after 6 years on a fencepost outside 365 days a year facing true South at 6700 feet altitude in Colorado (lots of UV and direct sun). Just 2 cross coats of Sherwin Williams Gloss Latex Super Paint. Tested with a punch tester 2 years ago and couldn't go through on one side and punched through at nearly the max tester reading on the other. Figure if you hanger your Piet and fly 100 hours a year it would take you (365 * 24 * 6)/100 = 525.6 years to get your cover/paint job to the same state as this test panel. rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321036#321036 Attachments: http://forums.matronics.com//files/img_2658_212.jpg http://forums.matronics.com//files/img_2657_205.jpg ________________________________________________________________________________
Date: Nov 25, 2010
Hi Bill Building the sides and then trying to bend each in symmetrically is a real pain with a tube frame. Upper and lower longerons flex in different locations. The placement of tack weld is usually not perfectly symmetrical and the tack weld tend to crack when you start flexing the longerons. It is they way it was done for years and is still done that way, but there is a better way in my opinion. It is much easier to build the bottom and top symmetrically. Fixture them in place with the upper and lower cross members parallel to each other. Then add the vertical members. All tack welds are done with everything fixtured in place and there is no flexing of anything AFTER tacking that will break a tack weld. The book I referenced above is EXCELLENT in detailing how to build a steel tube fuselage using this method. Nothing wrong with the old way, it is just harder to get a square, symmetrical fuselage with that method. As this seems to be a rare path when building a Air Camper, I'm going to try and document every step so that others can see it as a build option that can be accomplished by the average craftsman. FYI - To anyone building a steel tube Pietenpol Air Camper fuselage. The one shown in the 1932 FGM is way different than the 1934 "Improved" wood fuselage in external size and shape. It doesn't show engine mounting and the cowling for the wood version is too big for the steel version shown. Upper front cross member is in wrong location for Model A Ford motor and magneto. I'll have drawings of the 1934 "Improved" size steel fuselage, with the 1932 structure and Model A Ford installation if anyone wants to build the later version also a big and tall version. Just shoot me an email. Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321049#321049 ________________________________________________________________________________
Date: Nov 25, 2010
Rick your plane is looking great. are you going to be able to fly it to Brodhead this year? do not archive Randy Bush NX294RB ________________________________________________________________________________
Subject: Re: Newby
Date: Nov 25, 2010
gboothe5(at)comcast.net wrote: > Rick, > > Same process on the aluminum? > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, Running! > Tail done, Fuselage on gear > (22 ribs down.) > > -- Yup. Except the aluminum is etched first. rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321063#321063 ________________________________________________________________________________
Date: Nov 25, 2010
[quote="RBush96589(at)aol.com"]Rick your plane is looking great. are you going to be able to fly it to Brodhead this year? do not archive Randy Bush NX294RB > [b] Thanks Randy, I guess the only things standing between me and flying to Broadhead is covering and painting two wings, flying off 40 hours, and getting the cahones to do an 820 mile cross country from Denver. rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321064#321064 ________________________________________________________________________________
Subject: N13691 Question Thread
Date: Nov 26, 2010
I'm wanting my build to have the same appearance as Allen Rudolf's N13691 Air Camper. I have lots of questions concerning various aspects of this aircraft. Has anyone here taken measurements of this aircraft? If so, is the distance from firewall to center of front cabane strut bolt 12 1/2" or 14 1/2"? Or something else? Is wing built according to the 1932 FGM dimensions or of the 1934 "Improved" Air Camper? Does it have the 1932 square horizontal stabilizer or the later one that is narrower in the front? Does anyone have any pictures of it with the cowl off? Or close up pictures of the magneto mount and radiator mount area? More questions later. :D Thanks Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321069#321069 ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Subject: Behr Paint
Date: Nov 26, 2010
Ben, I need to go by Home Depot today or tomorrow and thought I would check out the paint. Any particular TYPE I should look for or just latex primer and exterior paint? ________________________________________________________________________________
Date: Nov 26, 2010
Subject: Re: Behr Paint
the one I bought had a test panel on the shelf. It was a real nice red, and the test panel had a nice gloss to it. I think it was around $27. Unfortunately the can is out at my hangar. I only used less than one gallon for my fuselage and vertical stab, sprayed with an HVLP gun. I used some flat Sherwin Williams gray for a base coat to fill the fabric, 2 coats brushed in opposite directions Ben On 11/26/2010 9:59 AM, Charles Campbell wrote: > Ben, I need to go by Home Depot today or tomorrow and thought I would > check out the paint. Any particular TYPE I should look for or just > latex primer and exterior paint? > * > > * ________________________________________________________________________________
Subject: Re: N13691 Question Thread
Date: Nov 26, 2010
Can't answer all those, but here's a photo of it under a shade tree in Indiana after we pulled the engine to fix a cracked magneto mount, July 2009 No detail, but a photo of it the next day in a bean field in Illinois with a broken crankshaft... And Jack McCarthy's old engine going in July 2010 Others here can probably answer the questions, or you might have to get a hold of Frank Pavliga for measurements. - Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321091#321091 ________________________________________________________________________________
Date: Nov 26, 2010
I might have the measurement he's looking for from the Piet W&B data we collected at Brodhead this year. Travelling to visit family at the moment, I'll check later. ------Original Message------ From: Baldeagle Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: Pietenpol List Subject: Pietenpol-List: Re: N13691 Question Thread Sent: Nov 26, 2010 10:17 AM Can't answer all those, but here's a photo of it under a shade tree in Indiana after we pulled the engine to fix a cracked magneto mount, July 2009 No detail, but a photo of it the next day in a bean field in Illinois with a broken crankshaft... And Jack McCarthy's old engine going in July 2010 Others here can probably answer the questions, or you might have to get a hold of Frank Pavliga for measurements. - Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321091#321091 Ryan Mueller ________________________________________________________________________________
Date: Nov 26, 2010
[quote="cncampbell(at)windstream."]Ben, I need to go by Home Depot today or tomorrow and thought I would check out the paint. Any particular TYPE I should look for or just latex primer and exterior paint? > [b] Will need to decide if you want your finish coat flat, stain, semi-gloss, gloss, or high gloss and yes you want exterior. I used Satin to get a vintage dope finish look. Also most manufacturers have 4 or 5 quality levels from cheap to expensive, I went with one level below the expensive stuff. Its easy to fork over $100 for a couple gallons of paint when you think about the $2500 you are saving over a full PolyFiber job. rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321094#321094 ________________________________________________________________________________
Subject: More progress
Date: Nov 26, 2010
Howdy,Hope everyone had a good turkey day.Heres some pics of where I am at now.Dave -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321100#321100 Attachments: http://forums.matronics.com//files/2010_11_26_08_22_10_356_204.jpg http://forums.matronics.com//files/2010_11_26_13_15_59_866_443.jpg http://forums.matronics.com//files/2010_11_26_13_02_50_88_831.jpg ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Nov 26, 2010
Subject: Dave's Pietenpol progress photos
Your plane is looking really good Dave, thank you for sharing those photos. It looks as though you might be able to begin varnishing and fabric coming in 2011 even which his really commendable and you've stuck with the project quite a long, long way. You even look the part of a 1930's pilot with your beard, helmet, goggles, and the Stroh's brew can sitting far off in the background on one of your work tables. Good man. Great to see another Pietenpol getting birthed out of another quiet workshop where these amazing little fun wood, metal, and fabric planes are manufactured one by one all across this country and elsewhere around the world. You're doing a great job. Mike C. ________________________________________________________________________________
Subject: Re: More progress
Date: Nov 26, 2010
Hi Dave, Very nice work. Very exciting time for you as it all comes together.....fin ally. Looks like you are on track for Brodhead '11. See you there? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Dangerous Dave <dsornbor(at)aol.com> Sent: Fri, Nov 26, 2010 2:49 pm Subject: Pietenpol-List: More progress Howdy,Hope everyone had a good turkey day.Heres some pics of where I am at ow.Dave -------- uilding a Piet ead this topic online here: http://forums.matronics.com/viewtopic.php?p=321100#321100 ttachments: http://forums.matronics.com//files/2010_11_26_08_22_10_356_204.jpg ttp://forums.matronics.com//files/2010_11_26_13_15_59_866_443.jpg ttp://forums.matronics.com//files/2010_11_26_13_02_50_88_831.jpg -======================== - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Date: Nov 26, 2010
Thanks guys,figuring buy the first she'll be ready to cover.2011 that is.Trying to have the plane complete for a final weight and balance so I only have to make one engine mount once.I'll be the black and orange poet at Brodhead gods willing. -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321108#321108 ________________________________________________________________________________
Date: Nov 27, 2010
Subject: No "Black Friday" For List Fund Raiser...
Dear Listers, Curiously, even though the number of List subscriptions are significantly up this year, support during this year's Fund Raiser is still substantially behind last year. There are only a couple more days left in November and the end of the Fund Raiser is quickly approaching. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid, other sources of income might be required including some sort of advertising. Please don't let that happen! Your personal Contribution of $20 or $30 goes a long ways to keeping the operation a float. Please make sure your name is on this year's List of Contributors published in December. The Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 27, 2010
Subject: Piet progress pix
Well, the Piet fuselage is more or less finished and moved to the strip where it'll make its first flights. The wings are in the paint booth and should be done in a couple of weeks. Of course, the weather just turned, 29 degrees and 40 mph gusts today. Sure wish I could roll back the calendar a couple of months, weather-wise. But 629ML should be ready to fly to Brodhead in 2011. Matt Paxton Fairfield, VA ________________________________________________________________________________
Date: Nov 27, 2010
Subject: Re: Piet progress pix
Wow Matt, it's beautiful! That's one of my favorite color combinations. Very nice...these kinds of notes/pics sure do help "the rest of us" keep our dream alive. Congrats! -----Original Message----- From: Woodflier(at)aol.com Sent: Nov 27, 2010 8:37 AM Subject: Pietenpol-List: Piet progress pix Well, the Piet fuselage is more or less finished and moved to the strip where it'll make its first flights. The wings are in the paint booth and should be done in a couple of weeks. Of course, the weather just turned, 29 degrees and 40 mph gusts today. Sure wish I could roll back the calendar a couple of months, weather-wise. But 629ML should be ready to fly to Brodhead in 2011. Matt Paxton Fairfield, VA ________________________________________________________________________________
Date: Nov 27, 2010
Yeah, someday we'll have to have a an exclusive blue/orange section at Brodhead. Mine's going to be that scheme too, similar to Shad's. Kip Gardner On Nov 27, 2010, at 10:12 AM, Jim Markle wrote: > > Wow Matt, it's beautiful! That's one of my favorite color combinations. > > Very nice...these kinds of notes/pics sure do help "the rest of us" keep our dream alive. > > Congrats! > > > -----Original Message----- > > From: Woodflier(at)aol.com > > Sent: Nov 27, 2010 8:37 AM > > To: pietenpol-list(at)matronics.com > > Subject: Pietenpol-List: Piet progress pix > > > > > > > > > Well, the Piet fuselage is more or less finished and moved to the strip > where it'll make its first flights. The wings are in the paint booth and should > be done in a couple of weeks. Of course, the weather just turned, 29 degrees and > 40 mph gusts today. Sure wish I could roll back the calendar a couple of months, > weather-wise. But 629ML should be ready to fly to Brodhead in 2011. > > Matt Paxton > Fairfield, VA > > > > > > ________________________________________________________________________________
Date: Nov 27, 2010
Beautiful Matt!!! But you forgot to build your elevators.. Jack DSM _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Woodflier(at)aol.com Sent: Saturday, November 27, 2010 8:38 AM Subject: Pietenpol-List: Piet progress pix Well, the Piet fuselage is more or less finished and moved to the strip where it'll make its first flights. The wings are in the paint booth and should be done in a couple of weeks. Of course, the weather just turned, 29 degrees and 40 mph gusts today. Sure wish I could roll back the calendar a couple of months, weather-wise. But 629ML should be ready to fly to Brodhead in 2011. Matt Paxton Fairfield, VA ________________________________________________________________________________
Date: Nov 27, 2010
Thanks guys. The pictures are excellent Baldeagle. Does anyone have contact info for Frank Pavliga? Is N13691 hangered at Brodhead or Frank's location? Thanks Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321252#321252 ________________________________________________________________________________
Date: Nov 27, 2010
We took a measurement labeled "Front Bay", and if I recall correctly that was measured from firewall to front cabane strut fitting: it came out to 14" for N13691. Ryan On Sat, Nov 27, 2010 at 8:40 PM, Mr. Craig wrote: > > Thanks guys. The pictures are excellent Baldeagle. > > Does anyone have contact info for Frank Pavliga? > > Is N13691 hangered at Brodhead or Frank's location? > > Thanks Craig > > -------- > A goal without a plan is nothing more than a wish. -- orion > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321252#321252 > > ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Just Three Days Left & Some Very Nice Comments...
Dear Listers, There are just three days left in this year's List Fund Raiser. Won't you take a monment and make a quick Contribution today to support the continued upgrade and operation of these Forum services. I've received some more really nice comments from Listers along with their List Support Contributions, and I've share a few below. There are some sweet gifts available this year, so browse the selections and pickup a nice item along with your qualifying Contribution. Contribution Web Site: http://www.matronics.com/contribution Or drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ------------------------------------------------------- Great resource, keep it coming... Marten V. Thanks for maintaining these essential lists! Rumen D. Great Service! Douglas D. Thanks for this great service! Peter T. Thanks for your enduring support of homebuilding communications! Daniel M. You do a great job and provide a valuable service. Mark B. It's really a great source I have used a lot. Robert K. Reading the RV-10 list is part of my morning routine... Perry C. Great job running these lists. Edward T. Thanks for doing a tough job. Mic T. Your List was such a great resource for me when I built in "98". Ron V. Its a very useful forum. Dave F. Really enjoy your list... William D. Great service, Gerald T. The list still is a valuable source of information and there are many worthwhile postings. Graham H. The list has seen me through an RV-9A, RV-10, and now an RV-12. Albert G. Thanks for a great resource! Barry H. Thank you for maintaining this excellent site. Bill W. The Matronics Email list are an invaluable service. William C. I appreciate the RV-10 list. Vijay P. Thanks for a great list and all of the work you do. Ian W. Thanks for keeping up this very useful list. George R. The list is excellent and I find it very handy for any problems I come up against during construction. Greg W. The lists are an important part of my day. I've met lots of people and made lots of friends. Dave S. It's really a great source I haved used a lot. Robert K. I read the Pietenpol List everyday. PF B. ________________________________________________________________________________
Date: Nov 28, 2010
Does anyone know if WW ever posted the results of the aircraft weighings at Brodhead? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Ryan Mueller <rmueller23(at)gmail.com> Sent: Sat, Nov 27, 2010 8:50 pm Subject: Re: Pietenpol-List: Re: N13691 Question Thread We took a measurement labeled "Front Bay", and if I recall correctly that w as measured from firewall to front cabane strut fitting: it came out to 14" for N13691. Ryan On Sat, Nov 27, 2010 at 8:40 PM, Mr. Craig wrote: Thanks guys. The pictures are excellent Baldeagle. Does anyone have contact info for Frank Pavliga? Is N13691 hangered at Brodhead or Frank's location? Thanks Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321252#321252 ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: - -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Subject: dhyedral
Date: Nov 28, 2010
Hllo What about the little dhyedral I saw in some piets? How affect the stability and performance?, it is good, it is bad... thank you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321356#321356 ________________________________________________________________________________
Subject: dhyedral
Date: Nov 28, 2010
Dhyedral always gives more stability unless its anhyedral which they use in fighter planes. Watch pigeons fly=2Cthey use dhyedral like crazy. > Subject: Pietenpol-List: dhyedral > From: mario.giacummo(at)gmail.com > Date: Sun=2C 28 Nov 2010 04:46:05 -0800 > To: pietenpol-list(at)matronics.com > m> > > Hllo > What about the little dhyedral I saw in some piets? > How affect the stability and performance?=2C it is good=2C it is bad... > > thank you. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321356#321356 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: WW
Date: Nov 28, 2010
Dan, the latest I know of was in the Oct issue of BPAN. It stated that WW would create a series of articles for BPAN covering the results of the measurements. Chuck ________________________________________________________________________________
Subject: Colors
Date: Nov 28, 2010
How about solid red with white sunburst on wing and tail? Where would you park it? ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Re: Piet pix
From: "Jack" <jack(at)textors.com> Subject: RE: Pietenpol-List: Piet progress pix Beautiful Matt!!! But you forgot to build your elevators.. Jack DSM ------ Naa, I just left them off for the ride. Didn't want them flapping around in the slipstream behind the pickup. They're installed now, but I did find that the addition of fabric brought the upper elevator cables in contact with the stabilizer, even with tension on them. I'll need leather pads for sure but considering a small ash sheave on either side attached to the front of the stabilizer. Hope to start laying out the 2 foot NX-numbers on the bottom of the left wing today. Matt ________________________________________________________________________________
Date: Nov 28, 2010
I believe the weighing results are coming in the next newsletter. I'm curious to hear what others think about the weights of their aircraft. NX18235 tipped the scales about 30 - 40 lbs more than I expected. Greg C. Minneapolis ----- Original Message ----- From: helspersew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Sunday, November 28, 2010 5:44 AM Subject: Re: Pietenpol-List: Re: N13691 Question Thread Does anyone know if WW ever posted the results of the aircraft weighings at Brodhead? Dan Helsper Poplar Grove, IL. -----Original Message----- From: Ryan Mueller <rmueller23(at)gmail.com> To: pietenpol-list Sent: Sat, Nov 27, 2010 8:50 pm Subject: Re: Pietenpol-List: Re: N13691 Question Thread We took a measurement labeled "Front Bay", and if I recall correctly that was measured from firewall to front cabane strut fitting: it came out to 14" for N13691. Ryan On Sat, Nov 27, 2010 at 8:40 PM, Mr. Craig wrote: Thanks guys. The pictures are excellent Baldeagle. Does anyone have contact info for Frank Pavliga? Is N13691 hangered at Brodhead or Frank's location? Thanks Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321252#321252 ========== ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== _blank>www.aeroelectric.com /" target=_blank>www.buildersbooks.com =_blank>www.homebuilthelp.com blank>http://www.matronics.com/contribution " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List p://forums.matronics.com ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG FORSCOM" <steven.d.dortch(at)us.army.mil>
Date: Nov 28, 2010
Subject: Simulator for piet
Does anyone have a Piet simulator add on for Microsoft Flight Sim X? If so what "Stick" do you use? Is there a fix to make it more Piet like. you know like tape a broomstick to the Joystick. Blue Skies Steve ________________________________________________________________________________
Subject: Colors
Date: Nov 28, 2010
Right next to Chuck Gantzer's N77CG Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Sunday, November 28, 2010 8:24 AM Subject: Pietenpol-List: Colors How about solid red with white sunburst on wing and tail? Where would you park it? ________________________________________________________________________________
Date: Nov 28, 2010
S2VlcCBhbiBleWUgb3V0IGZvciB0aGUgbmV4dCBpc3N1ZSBvZiB0aGUgQlBBIG5ld3NsZXR0ZXIs IHdoaWNoIHNob3VsZCBoYXZlIHRoZSBmaXJzdCBhcnRpY2xlIGluIHRoZSBzZXJpZXMgb24gdGhl IFcmQiB0aGF0IHdhcyBjb2xsZWN0ZWQNCg0KUnlhbiBNdWVsbGVyDQoNClNlbnQgZnJvbSBteSBC bGFja0JlcnJ5DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBoZWxzcGVyc2V3 QGFvbC5jb20NClNlbmRlcjogb3duZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5j b20NCkRhdGU6IFN1biwgMjggTm92IDIwMTAgMDY6NDQ6MTkgDQpUbzogPHBpZXRlbnBvbC1saXN0 QG1hdHJvbmljcy5jb20+DQpSZXBseS1UbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbVN1 YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDogUmU6IE4xMzY5MSBRdWVzdGlvbiBUaHJlYWQNCg0K DQpEb2VzIGFueW9uZSBrbm93IGlmIFdXIGV2ZXIgcG9zdGVkIHRoZSByZXN1bHRzIG9mIHRoZSBh aXJjcmFmdCB3ZWlnaGluZ3MgYXQgQnJvZGhlYWQ/DQoNCkRhbiBIZWxzcGVyDQpQb3BsYXIgR3Jv dmUsIElMLg0KDQoNCg0KDQoNCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206IFJ5 YW4gTXVlbGxlciA8cm11ZWxsZXIyM0BnbWFpbC5jb20+DQpUbzogcGlldGVucG9sLWxpc3QgPHBp ZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+DQpTZW50OiBTYXQsIE5vdiAyNywgMjAxMCA4OjUw IHBtDQpTdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IFJlOiBOMTM2OTEgUXVlc3Rpb24gVGhy ZWFkDQoNCg0KV2UgdG9vayBhIG1lYXN1cmVtZW50IGxhYmVsZWQgIkZyb250IEJheSIsIGFuZCBp ZiBJIHJlY2FsbCBjb3JyZWN0bHkgdGhhdCB3YXMgbWVhc3VyZWQgZnJvbSBmaXJld2FsbCB0byBm cm9udCBjYWJhbmUgc3RydXQgZml0dGluZzogaXQgY2FtZSBvdXQgdG8gMTQiIGZvciBOMTM2OTEu DQoNCg0KUnlhbg0KDQoNCk9uIFNhdCwgTm92IDI3LCAyMDEwIGF0IDg6NDAgUE0sIE1yLiBDcmFp ZyA8YWN3ZWxkZXJAY2FibGVvbmUubmV0PiB3cm90ZToNCg0KLS0+IFBpZXRlbnBvbC1MaXN0IG1l c3NhZ2UgcG9zdGVkIGJ5OiAiTXIuIENyYWlnIiA8YWN3ZWxkZXJAY2FibGVvbmUubmV0Pg0KDQpU aGFua3MgZ3V5cy4gVGhlIHBpY3R1cmVzIGFyZSBleGNlbGxlbnQgQmFsZGVhZ2xlLg0KDQpEb2Vz IGFueW9uZSBoYXZlIGNvbnRhY3QgaW5mbyBmb3IgRnJhbmsgUGF2bGlnYT8NCg0KSXMgTjEzNjkx IGhhbmdlcmVkIGF0IEJyb2RoZWFkIG9yIEZyYW5rJ3MgbG9jYXRpb24/DQoNClRoYW5rcyBDcmFp Zw0KDQotLS0tLS0tLQ0KQSBnb2FsIHdpdGhvdXQgYSBwbGFuIGlzIG5vdGhpbmcgbW9yZSB0aGFu IGEgd2lzaC4gLS0gb3Jpb24NCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0K DQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTMyMTI1MiMzMjEy NTINCg0KDQoNCg0KDQoNCg0KPSJfYmxhbmsiPnd3dy5hZXJvZWxlY3RyaWMuY29tDQpvb2tzLmNv bSIgdGFyZ2V0PSJfYmxhbmsiPnd3dy5idWlsZGVyc2Jvb2tzLmNvbQ0KZXQ9Il9ibGFuayI+d3d3 LmhvbWVidWlsdGhlbHAuY29tDQo9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbg0KbGUsIExpc3QgQWRtaW4uDQpzdCIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UGlldGVucG9sLUxpc3QNCmh0dHA6Ly9mb3J1bXMu bWF0cm9uaWNzLmNvbQ0KDQoNCg0KDQoNCg0KDQotPQ0KLT0gICAgICAgLS0gUGxlYXNlIFN1cHBv cnQgWW91ciBMaXN0cyBUaGlzIE1vbnRoIC0tDQotPSAgICAgICAgICAgKEFuZCBHZXQgU29tZSBB V0VTT01FIEZSRUUgR2lmdHMhKQ0KLT0NCi09ICAgTm92ZW1iZXIgaXMgdGhlIEFubnVhbCBMaXN0 IEZ1bmQgUmFpc2VyLiAgQ2xpY2sgb24NCi09ICAgdGhlIENvbnRyaWJ1dGlvbiBsaW5rIGJlbG93 IHRvIGZpbmQgb3V0IG1vcmUgYWJvdXQNCi09ICAgdGhpcyB5ZWFyJ3MgVGVycmlmaWMgRnJlZSBJ bmNlbnRpdmUgR2lmdHMgcHJvdmlkZWQNCi09ICAgYnk6DQotPQ0KLT0gICAgICogQWVyb0VsZWN0 cmljIHd3dy5hZXJvZWxlY3RyaWMuY29tDQotPSAgICAgKiBUaGUgQnVpbGRlcidzIEJvb2tzdG9y ZSB3d3cuYnVpbGRlcnNib29rcy5jb20NCi09ICAgICAqIEhvbWVidWlsdEhFTFAgd3d3LmhvbWVi dWlsdGhlbHAuY29tDQotPQ0KLT0gICBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZToNCi09DQot PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQotPQ0KLT0gICBU aGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCi09DQotPSAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCi09DQotPT09PT09PT09 PT09PT09PT09PT09PT09LT0gICAgICAgICAgLSBUaGUgUGlldGVucG9sLUxpc3QgRW1haWwgRm9y dW0gLQ0KLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJv d3NlDQotPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0 aW9uLA0KLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBG QVEsDQotPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQotPQ0KLT0gICAtLT4gaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdA0KLT0NCi09PT09 PT09PT09PT09PT09PT09PT09PT0tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JV TVMgLQ0KLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZv cnVtcyENCi09DQotPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCi09DQotPT09 PT09PT09PT09PT09PT09PT09PT09DQoNCg= ________________________________________________________________________________
Date: Nov 28, 2010
Great to see it progressing, Matt! Where will you base it? I'll have to come by to see it next time we're up at Smith Mountain Lake. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Woodflier(at)aol.com Sent: Saturday, November 27, 2010 9:38 AM Subject: Pietenpol-List: Piet progress pix Well, the Piet fuselage is more or less finished and moved to the strip where it'll make its first flights. The wings are in the paint booth and should be done in a couple of weeks. Of course, the weather just turned, 29 degrees and 40 mph gusts today. Sure wish I could roll back the calendar a couple of months, weather-wise. But 629ML should be ready to fly to Brodhead in 2011. Matt Paxton Fairfield, VA ________________________________________________________________________________
Date: Nov 28, 2010
I've seen (and flown) one for I think Microsoft Flight Simulator, but it didn't feel much like the real thing. To get any realism, you would need to set the joystick on the floor and tape a broomstick to it, have rudder pedals, have ineffective brakes (if simulating a wire wheel version), and make the ailerons much less sensitive than the elevators. Whenever I get out of my RV-4 and climb into the Pietenpol, on takeoff my first thought is that something in the controls is broken because the control movements are so large with so little happening. Flight simulators might work OK for a plane like an airliner that is flown pretty much by the numbers. I don't think they can do much to simulate a plane like a Pietenpol that is flown by the seat of the pants. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dortch, Steven D MAJ NG NG FORSCOM Sent: Sunday, November 28, 2010 8:47 AM Subject: Pietenpol-List: Simulator for piet Does anyone have a Piet simulator add on for Microsoft Flight Sim X? If so what "Stick" do you use? Is there a fix to make it more Piet like. you know like tape a broomstick to the Joystick. Blue Skies Steve ________________________________________________________________________________
Subject: Re: Cleaning the shop
Date: Nov 28, 2010
Awesome John... glad you are having some fun. Hope you have a productive buildapalooza season. I need to make some hay myself. I got my tubing order in... now I face a whole new set of challenges. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321400#321400 ________________________________________________________________________________
Date: Nov 28, 2010
I can't answer your question directly, but I have flown the Piet. in FS10. I use a complete HOTAS set-up when I fly ACM on the computer, but as mentioned, you would need to mount the stick on the floor and add a long handle of some sort. Still, for those of us who want to fly during the winter months, or fly the Piet. at places we would never get the chance, FS10 and and modified stick may be cool. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Re: Simulator for piet
I have found MS Flight Sim Piet models before, and they are kind of neat to fly. I have limited flight time in my Piet, but I feel safe in saying that while kind of neat, computer flight sim models have little to no relation to flying a real world Piet. Even if the flight model is accurate, you are missing the wind, noise, vibration, smell, and feeling of actually flying a Pietenpol. Since the Piet is not really a fly-by-the-numbers airplane there really is no corollary on the computer that can feel anything like flying a Piet (IMO). Ryan On Sun, Nov 28, 2010 at 4:07 PM, Michael Perez wrote: > I can't answer your question directly, but I have flown the Piet. in FS10. > I use a complete HOTAS set-up when I fly ACM on the computer, but as > mentioned, you would need to mount the stick on the floor and add a long > handle of some sort. Still, for those of us who want to fly during the > winter months, or fly the Piet. at places we would never get the chance, > FS10 and and modified stick may be cool. > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > * > > ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Re: Colors
Hey Chuck, can I park next to you? Mine is Caliente Red Fuse and creame win gs. =0AGardiner=0A=0A=0A=0A=0A________________________________=0AFrom: Jack Phillips =0ATo: pietenpol-list(at)matronics.com=0ASen t: Sun, November 28, 2010 11:11:14 AM=0ASubject: RE: Pietenpol-List: Colors =0A=0A =0ARight next to Chuck Gantzer=99s N77CG=0A =0AJack Phillips =0ANX899JP =9CIcarus Plummet=9D=0ARaleigh, NC=0A =0A=0A________ ________________________=0A =0AFrom:owner-pietenpol-list-server(at)matronics.c om =0A[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charl es Campbell=0ASent: Sunday, November 28, 2010 8:24 AM=0ATo: Piet People=0AS ubject: Pietenpol-List: Colors=0A =0AHow about solid red with white sunburs t on wing and tail? Where would you park =0Ait?=0A =0A =0Awww.buildersbo oks.com=0Ahttp://www.matronics.com/Navigator?Pietenpol-List=0Ahttp://forums ============= =0A ________________________________________________________________________________
Subject: color schemes
Date: Nov 28, 2010
Well, as long as we're all shouting out our favorite paint schemes for Piets, I guess I'll weigh in as well. One I've always liked is Steve Eldredge's... green fuselage, cream-white wings and tail surfaces, and of course the signature "Air Camper" graphic on the fuselage sides. It's the logo for the Piet list on matronics. I think if I were doing the Eldredge Piet, I would go for silver wings and tail to go with the cowling though. Then there are the gorgeous twins, Frank Pavliga's and Don Emch's Piets with the solid color fuselage and contrasting cream-color wings and wheel covers. I think the close formation in-flight picture of those two airplanes will be appearing in our EAA Chapter 35 December newsletter, if my inside sources are correct ;o) The red and green colors say "flying Christmas" in perfect harmony, together like that. Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Nov 28, 2010
Subject: Moment of silence please
http://www.montrealgazette.com/entertainment/Naked+star+Leslie+Nielsen+dead/3897138/story.html http://www.youtube.com/watch?v=0A5t5_O8hdA ________________________________________________________________________________
Date: Nov 29, 2010
OK so what I am hearing is (see I did learn from the "Active Listening class") A. I need to tie a broomstick to the "stick" B. I need a fan blowing in my face at 65-70 MPH. C. Mounting a lawnmower engine between me and the Screen will enhance the sound and smell (maybe I can use it to run the fan.)Also the chair and stick need to be hard connected to the engine to get the vibration. D. If I want a Model A Piet then I need to put an old car radiator between me and the screen. Anything else? ;+} Steve On 11/29/10, Ryan Mueller wrote: > I have found MS Flight Sim Piet models before, and they are kind of neat to fly. I have limited flight time in my Piet, but I feel safe in saying that while kind of neat, computer flight sim models have little to no relation to flying a real world Piet. > > > > > Even if the flight model is accurate, you are missing the wind, noise, vibration, smell, and feeling of actually flying a Pietenpol. Since the Piet is not really a fly-by-the-numbers airplane there really is nocorollaryon the computer that can feel anything like flying a Piet (IMO). > > > > > Ryan > > > On Sun, Nov 28, 2010 at 4:07 PM, Michael Perez wrote: > > > > > > > > > > > > I can't answer your question directly, but I have flown the Piet. in FS10. I use a complete HOTAS set-up when I fly ACM on the computer, but as mentioned, you would need to mount the stick on the floor and add a long handle of some sort. Still, for those of us who want to fly during the winter months, or fly the Piet. at places we would never get the chance, FS10 and and modified stick may be cool. > > > > > > > > > > Michael Perez > > Karetaker Aero > > www.karetakeraero.com(blockedhttp://www.karetakeraero.com) > > > > > > > > > > > > > > > > > > > > > > > > > > _blank">www.aeroelectric.com > > > .com" target="_blank">www.buildersbooks.com > > > ="_blank">www.homebuilthelp.com > > > _blank">http://www.matronics.com/contribution > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > > > tp://forums.matronics.com > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 29, 2010
Subject: Make Sure You're Listed!
Dear Listers, The List of Contributors (LOC) is just around the corner with just two more days in this year's Fund Raiser! Later in December I will post a list of everyone that so generously made a Contribution to support the Lists this year. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Colors
Date: Nov 29, 2010
Not familiar with N77CG. Is there a picture of it anywhere so that when I eventually get to Brodhead I'll know where to park? ________________________________________________________________________________
Subject: Simulator
Date: Nov 29, 2010
Steven, don't use a lawnmower engine -- use a gasoline powered generator and then you could plug the fan (as well as the computer) into it. ________________________________________________________________________________
Date: Nov 29, 2010
Jack, I don't know if BPA can stan two tarheels. I live in Winston-Salem. In fact after reading the Jan 2009 issue of BPAN I started to call and see about a visit to New Hill to see you and the Piet, but I never got around to it. I would have to drive -- my Piet is barely off the drawing board. ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Sunday, November 28, 2010 11:13 AM Subject: RE: Pietenpol-List: Piet progress pix Great to see it progressing, Matt! Where will you base it? I'll have to come by to see it next time we're up at Smith Mountain Lake. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Woodflier(at)aol.com Sent: Saturday, November 27, 2010 9:38 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Piet progress pix Well, the Piet fuselage is more or less finished and moved to the strip where it'll make its first flights. The wings are in the paint booth and should be done in a couple of weeks. Of course, the weather just turned, 29 degrees and 40 mph gusts today. Sure wish I could roll back the calendar a couple of months, weather-wise. But 629ML should be ready to fly to Brodhead in 2011. Matt Paxton Fairfield, VA ________________________________________________________________________________
Subject: Re: Colors
Date: Nov 29, 2010
I'm not senior enough to be able to assign parking places. Maybe you need to talk to Jack -- he was assigning me to be next to N77CG. ----- Original Message ----- From: airlion To: pietenpol-list(at)matronics.com Sent: Sunday, November 28, 2010 6:28 PM Subject: Re: Pietenpol-List: Colors Hey Chuck, can I park next to you? Mine is Caliente Red Fuse and creame wings. Gardiner ------------------------------------------------------------------------- ----- From: Jack Phillips <pietflyr(at)bellsouth.net> To: pietenpol-list(at)matronics.com Sent: Sun, November 28, 2010 11:11:14 AM Subject: RE: Pietenpol-List: Colors Right next to Chuck Gantzer=99s N77CG Jack Phillips NX899JP =9CIcarus Plummet=9D Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Sunday, November 28, 2010 8:24 AM To: Piet People Subject: Pietenpol-List: Colors How about solid red with white sunburst on wing and tail? Where would you park it? www.buildersbooks.comhttp://www.matronics.com/Navigator?Pietenpol-Listhtt p://forums.matronics.comwww.buil"_blank" href="http://www.homebuilthelp.com">www.homebuilthelp.comhttp://nofollo w" target="_blank" href="http://www.matronics.com/Navigator?Piet====== ________________________________________________________________________________
Date: Nov 29, 2010
Subject: Re: Colors
Lots of pics: westcoastpiet.com -----Original Message----- From: Charles Campbell Sent: Nov 29, 2010 4:35 AM Subject: Pietenpol-List: Colors Not familiar with N77CG. Is there a picture of it anywhere so that when I eventually get to Brodhead I'll know where to park? ________________________________________________________________________________
Date: Nov 29, 2010
Subject: RE: Basing Pietenpol
From: "Jack Phillips" <pietflyr(at)bellsouth.net> Subject: RE: Pietenpol-List: Piet progress pix Great to see it progressing, Matt! Where will you base it? I'll have to come by to see it next time we're up at Smith Mountain Lake. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ---- Jack, it's going to be at VA63, Twin Rivers Airstrip, initially. There's a 3000' grass strip and completely enclosed t-hangar with paved floor. Fly on up when the weather warms up, it shouldn't be more than an hour from Moneta by Piet. I've had the Bellanca in there with no problems. Here's a link on Airnav: _http://www.airnav.com/airport/VA63_ (http://www.airnav.com/airport/VA63) Matt ________________________________________________________________________________
Date: Nov 29, 2010
Charles, you're welcome to come look at my Pietenpol, but it is not in New Hill. I keep it in my hangar at Smith Mountain Lake, Virginia (W91), where we will eventually move and run a Bed & Breakfast for pilots once we get our house in New Hill sold. I'll be up there every weekend from the end of January through May, so give me a call if you want to come look at it. My cellphone is (919) 427-4440. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Monday, November 29, 2010 5:48 AM Subject: Re: Pietenpol-List: Piet progress pix Jack, I don't know if BPA can stan two tarheels. I live in Winston-Salem. In fact after reading the Jan 2009 issue of BPAN I started to call and see about a visit to New Hill to see you and the Piet, but I never got around to it. I would have to drive -- my Piet is barely off the drawing board. ----- Original Message ----- From: Jack <mailto:pietflyr(at)bellsouth.net> Phillips Sent: Sunday, November 28, 2010 11:13 AM Subject: RE: Pietenpol-List: Piet progress pix Great to see it progressing, Matt! Where will you base it? I'll have to come by to see it next time we're up at Smith Mountain Lake. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Woodflier(at)aol.com Sent: Saturday, November 27, 2010 9:38 AM Subject: Pietenpol-List: Piet progress pix Well, the Piet fuselage is more or less finished and moved to the strip where it'll make its first flights. The wings are in the paint booth and should be done in a couple of weeks. Of course, the weather just turned, 29 degrees and 40 mph gusts today. Sure wish I could roll back the calendar a couple of months, weather-wise. But 629ML should be ready to fly to Brodhead in 2011. Matt Paxton Fairfield, VA href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com /Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 29, 2010
Subject: Ohio piet gathering
Hello Guys and Gals, I am starting to plan for my 2011 Ohio Piet Gathering (can't call it a fly in for liability reasons, I guess).- I am shooting f or Father's Day weekend again, but I will have to see what vacation weekend I got awarded on my bid.- It will be like last year, just fly in here an d have fun, camp out fri, sat night if you want to, I will rent- a turd c loset and supply lunch on sat, if enough people show up, early enough, frid ay night we can head down to the local watering hole/ grill for supper, Ski pp, and Ed came in last year on friday evening, and set up their tents 2 ti mes, once outside, then in the neighbor's hangor (I forgot to check the wea ther forcast that night).- I know this is a busy weekend, but if you have any comments, fire when ready.- I might just pull off a fly-in here at h ome, and go to Brodhead in 2011, I just have to keep the ole lady happy.- I am assuming Skipp, Ed, Don, Mike C., and Frank P. could make it, as it is only an hour or Hour 1/2 flight for them, if any are in Columbus etc fo r buisness reasons feel free to drive in.- We might just have to start up the Buckeye Pietenpol Assosiation,- Again. - Happy building (and flying to you "Snow Birds") - Shad=0A=0A=0A ________________________________________________________________________________
Subject: Re: dhyedral
Date: Nov 29, 2010
So, why some airplanes have and some no? how much is too much, which things you have to take in account to do it with or without? I do not find anything about this configuration... Regards Mario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321657#321657 ________________________________________________________________________________
Date: Nov 30, 2010
It's really up to you as to how much or how little you want.A couple of inc hes is really all you'll ever need just to give you some stability.If you g o to far like about 6 inches then you have more than enough and the plane w ill be so stable that you'll fall asleep flying it.Fighter planes have anhy edral because they want them very unstable for doing things in the air that fighters have to do to get out of situations.The first plane I ever flew w as a Quicksilver ultralight and it had a lot of dhyedral.Probably too much. As I recall it would practically fly itself. It's your personal preference really.It's your airplane.What do you want it to do? > Subject: Pietenpol-List: Re: dhyedral > From: mario.giacummo(at)gmail.com > Date: Mon=2C 29 Nov 2010 16:47:23 -0800 > To: pietenpol-list(at)matronics.com > m> > > So=2C why some airplanes have and some no? how much is too much=2C which things you have to take in account to do it with or without? I do not find anything about this configuration... > > Regards > > Mario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321657#321657 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Nov 29, 2010
Get the cheapest gamepad you can find, configure the stick controls like that of an RC control box(i.e. right side for ail/elev, left for rudder). Go into FS control settings (sensitivity) and set them (especially ailerons) less responsive, and you gotta Piet. Generally, the more expensive the joystick, the crappier the 'feel'.... then when ur online, go to weather and click on the static 'actual wx' box and download the 'live' wx.. actual winds, etc.. fly outta ur home field. Then see how close it compares to reality. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321673#321673 ________________________________________________________________________________
Date: Nov 29, 2010
I think you mean dihedral. right? On Nov 29, 2010, at 6:47 PM, giacummo wrote: > > So, why some airplanes have and some no? how much is too much, which things you have to take in account to do it with or without? I do not find anything about this configuration... > > Regards > > Mario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321657#321657 > > > > > > > > > > ________________________________________________________________________________
Date: Nov 30, 2010
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means at least two things. For better or worse, its my 47th birthday! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been drooling over one of the really nice gifts that are available this year with a qualifying Contribution, then now is the time to jump on one!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. Hopefully everyone feels the same. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2010
I=92ve flown Pietenpols with and without dihedral and can=92t tell much difference in stability. I have about =BD=94 dihedral per side in my Pietenpol, and its stability is no better than the straight wing Piets I=92ve flown. You would probably need several inches per side to be able to get much stability, and that much would look funny, like a model airplane. Jack Phillips NX899JP =93Icarus Plummet=94 Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Harvey Rule Sent: Monday, November 29, 2010 10:20 PM Subject: RE: Pietenpol-List: Re: dhyedral It's really up to you as to how much or how little you want.A couple of inches is really all you'll ever need just to give you some stability.If you go to far like about 6 inches then you have more than enough and the plane will be so stable that you'll fall asleep flying it.Fighter planes have anhyedral because they want them very unstable for doing things in the air that fighters have to do to get out of situations.The first plane I ever flew was a Quicksilver ultralight and it had a lot of dhyedral.Probably too much.As I recall it would practically fly itself. It's your personal preference really.It's your airplane.What do you want it to do? > Subject: Pietenpol-List: Re: dhyedral > From: mario.giacummo(at)gmail.com > Date: Mon, 29 Nov 2010 16:47:23 -0800 > To: pietenpol-list(at)matronics.com > > > So, why some airplanes have and some no? how much is too much, which things you have to take in account to do it with or without? I do not find anything about this configuration... > > Regards > > Mario > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321657#321657 > > > ==================== > _======== > > > ________________________________________________________________________________
Date: Nov 30, 2010
OK, thanks all for the answers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321763#321763 ________________________________________________________________________________
Date: Nov 30, 2010
Tarheels, hmmmm. You want a unique paint scheme? One that has history to boot? http://www.bentwings.com/vf/tarheel/tarheelhal.htm ----- Original Message ----- From: Charles Campbell Jack, I don't know if BPA can stan two tarheels. I live in Winston-Salem. ________________________________________________________________________________
Date: Nov 30, 2010
Mario, Not having dihedral does not mean the plane is unstable. There are other ways to attain stability. For our purposes, a Piet being a high wing airplane has a center of gravity lower than the wing. This will reduce over banking and make it easy to return back to wing level. As an extreme example. Take a look at a powered parachute. The thing has an anhedral like you've never seen before, but stability is not compromised at all due to the extremely low center of gravity relative to he wing. For a low wing aircraft having a dihedral becomes essential because the center of gravity is slightly higher than the wings. If no dihedral is used the airplane could be more comfortable flying upside down. For low wing aircraft typically 6-8 degrees is used. A lot depends on where the CG is. I haven't got in to the reason why dihedral helps stability, but just want to illustrate that the Piet does not need it due to the inherent stability of the high wing and the very good track record of more than 80 years. Having said that, if you were to put a slight dihedral (I would say less than 2 degrees) it would not hurt anything other than your construction time line. ;) I hope that helps. Ameet Savant Omaha, NE On Mon, Nov 29, 2010 at 6:47 PM, giacummo wrote: > > > > So, why some airplanes have and some no? how much is too much, which things > you have to take in account to do it with or without? I do not find anything > about this configuration... > > Regards > > Mario > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321657#321657 > > ________________________________________________________________________________
Date: Nov 30, 2010
I built 1 degree into my one piece wing which amounts to the tips being 3 inches higher than the center. The reason I did that was from an experience with a Stinson 108 that I owned. A prior owner had shortened the struts so the wing had ZERO dihedral. As long as you were doing air work or in the pattern it was great. Even a short cross country was a bit aggravating because it flew like sitting on a basketball. Look down at the Sectional, look back up and you were turning one way or the other. The dihedral makes it a lot harder to handle on the workbench. I hope to put it on an airplane one day ! -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321773#321773 Attachments: http://forums.matronics.com//files/dsc00251_337.jpg http://forums.matronics.com//files/stinson_108_264.jpg ________________________________________________________________________________
Date: Nov 30, 2010
Unless I am missing a important point here, I trained on all Cessna's 150,152,172 so if I want that same performance style ad stability I should look up the Cessna design ad add that exact amount to my build ad it will act or closely approximate similar flight qualities as the Cessna's that I am more used to flying and better acquainted with. Is that an accurate assessment? And if so how much does Cessna typically use in their designs? Additionally is that a value that's proportionate to the total wing span such that wings having a shorter or longer than the Cessna wing span has more or less dihedral and at what rate or ratio? I know that if want a Cessna should buy one of those, however that's not what am asking, so I would short cut the typical answers, but thanks anyway. I am more looking for comparative information and the relationship to something I am most familiar with. Thanks John In a message dated 11/30/2010 8:01:09 A.M. Eastern Standard Time, jdotson(at)centurylink.net writes: --> Pietenpol-List message posted by: "Jerry Dotson" I built 1 degree into my one piece wing which amounts to the tips being 3 inches higher than the center. The reason I did that was from an experience with a Stinson 108 that I owned. A prior owner had shortened the struts so the wing had ZERO dihedral. As long as you were doing air work or in the pattern it was great. Even a short cross country was a bit aggravating because it flew like sitting on a basketball. Look down at the Sectional, look back up and you were turning one way or the other. The dihedral makes it a lot harder to handle on the workbench. I hope to put it on an airplane one day ! -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321773#321773 Attachments: http://forums.matronics.com//files/dsc00251_337.jpg http://forums.matronics.com//files/stinson_108_264.jpg ________________________________________________________________________________
Date: Nov 30, 2010
My experience with dihedral is in model planes, as Jack mentions below. We would put a lot of dihedral in a model plane to enable it to fly without ailerons. My understanding is that the Piet doesn't necessarily need it because it is a parasol wing, with the CG sitting much lower than the wing. That makes the plane act like it is a pendulum, self-stabilizing to some extent. Dihedral is more critical in a low wing plane, as the CG is sitting on top of the wing. Gary Wilson On Tue, Nov 30, 2010 at 3:28 AM, Jack Phillips wrot e: > I=92ve flown Pietenpols with and without dihedral and can=92t tell much > difference in stability. I have about =BD=94 dihedral per side in my Pie tenpol, > and its stability is no better than the straight wing Piets I=92ve flown. You > would probably need several inches per side to be able to get much > stability, and that much would look funny, like a model airplane. > > > Jack Phillips > > NX899JP =93Icarus Plummet=94 > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Harvey Rule > *Sent:* Monday, November 29, 2010 10:20 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* RE: Pietenpol-List: Re: dhyedral > > > It's really up to you as to how much or how little you want.A couple of > inches is really all you'll ever need just to give you some stability.If you > go to far like about 6 inches then you have more than enough and the plan e > will be so stable that you'll fall asleep flying it.Fighter planes have > anhyedral because they want them very unstable for doing things in the ai r > that fighters have to do to get out of situations.The first plane I ever > flew was a Quicksilver ultralight and it had a lot of dhyedral.Probably t oo > much.As I recall it would practically fly itself. > It's your personal preference really.It's your airplane.What do you want it > to do? > > Subject: Pietenpol-List: Re: dhyedral > > From: mario.giacummo(at)gmail.com > > Date: Mon, 29 Nov 2010 16:47:23 -0800 > > To: pietenpol-list(at)matronics.com > > > mario.giacummo(at)gmail.com> > > > > So, why some airplanes have and some no? how much is too much, which > things you have to take in account to do it with or without? I do not fin d > anything about this configuration... > > > > Regards > > > > Mario > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=321657#321657 > > > > > > ==================== > > _======== > > > > > > > > * * > > * * > > ** > > ** > > ** > > ** > > *www.buildersbooks.com* > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > * > =========== =========== =========== ============* > > ________________________________________________________________________________
Date: Nov 30, 2010
John, Taking one design element from a Cessna (i.e. amount of dihedral) and applying it to a Piet won't have the same affect. We're also talking about high wing vs. a parasol. If I remember my ancient history (meaning the Aero classes I took 35+ years ago) positive dihedral will IN GENERAL affect a parasol more than a closed cabin high wing like a Cessna. In other words a parasol probably has more inherent stability than a high wing cabin monoplane with equivalent dihedral. In reality however, you have to take in account the whole aircraft - where's the CG in relation to the wing, configuration (parasol, high wing, low wing), wing planform, aileron configuration (frieze type vs hinged flap, sealed vs unsealed, etc.), and I'd guess even the effects of the tail (tail arm, rudder & fin size) - to decide how much dihedral is appropriate. Remember, no part of the airplane flys by itself. =46rom evidence presented here, it sounds like Piet's have flown with either no, or from 1 - 2 degrees, dihedral. I'd bet that sealing the aileron gap has more affect on overall handling than adding a degree if dihedral. I'll probably put in a degree or so on mine, but I'm not close to that point yet. Happy building, Ken On Nov 30, 2010, at 7:29 AM, amsafetyc(at)aol.com wrote: > Unless I am missing a important point here, I trained on all Cessna's 150,152,172 so if I want that same performance style ad stability I should look up the Cessna design ad add that exact amount to my build ad it will act or closely approximate similar flight qualities as the Cessna's that I am more used to flying and better acquainted with. Is that an accurate assessment? And if so how much does Cessna typically use in their designs? Additionally is that a value that's proportionate to the total wing span such that wings having a shorter or longer than the Cessna wing span has more or less dihedral and at what rate or ratio? > > I know that if want a Cessna should buy one of those, however that's not what am asking, so I would short cut the typical answers, but thanks anyway. I am more looking for comparative information and the relationship to something I am most familiar with. > > Thanks > > John > > > > In a message dated 11/30/2010 8:01:09 A.M. Eastern Standard Time, jdotson(at)centurylink.net writes: > > I built 1 degree into my one piece wing which amounts to the tips being 3 inches higher than the center. The reason I did that was from an experience with a Stinson 108 that I owned. A prior owner had shortened the struts so the wing had ZERO dihedral. As long as you were doing air work or in the pattern it was great. Even a short cross country was a bit aggravating because it flew like sitting on a basketball. Look down at the Sectional, look back up and you were turning one way or the other. The dihedral makes it a lot harder to handle on the workbench. I hope to put it on an airplane one day ! > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > wing, tailfeathers done > using Lycoming O-235 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321773#321773 > > > > > Attachments: > > http://forums.matronics.com//files/dsc00251_337.jpg > http://fo===================== ==nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP b k you for p; -Matt Dralle, List ======================== Use the ties Day =================== ==== - MATRONICS WEB FORUMS > > > > > ________________________________________________________________________________
Date: Nov 30, 2010
Thanks guys, I appreciate the insight especially in attempting to gain a perspective on the entire issue and its effect on the Piet as opposed t other popular aircraft designs. John In a message dated 11/30/2010 11:54:47 A.M. Eastern Standard Time, ken@cooper-mtn.com writes: John, Taking one design element from a Cessna (i.e. amount of dihedral) and applying it to a Piet won't have the same affect. We're also talking about high wing vs. a parasol. If I remember my ancient history (meaning the Aero classes I took 35+ years ago) positive dihedral will IN GENERAL affect a parasol more than a closed cabin high wing like a Cessna. In other words a parasol probably has more inherent stability than a high wing cabin monoplane with equivalent dihedral. In reality however, you have to take in account the whole aircraft - where's the CG in relation to the wing, configuration (parasol, high wing, low wing), wing planform, aileron configuration (frieze type vs hinged flap, sealed vs unsealed, etc.), and I'd guess even the effects of the tail (tail arm, rudder & fin size) - to decide how much dihedral is appropriate. Remember, no part of the airplane flys by itself. >From evidence presented here, it sounds like Piet's have flown with either no, or from 1 - 2 degrees, dihedral. I'd bet that sealing the aileron gap has more affect on overall handling than adding a degree if dihedral. I'll probably put in a degree or so on mine, but I'm not close to that point yet. Happy building, Ken On Nov 30, 2010, at 7:29 AM, _amsafetyc(at)aol.com_ (mailto:amsafetyc(at)aol.com) wrote: Unless I am missing a important point here, I trained on all Cessna's 150,152,172 so if I want that same performance style ad stability I should look up the Cessna design ad add that exact amount to my build ad it will act or closely approximate similar flight qualities as the Cessna's that I am more used to flying and better acquainted with. Is that an accurate assessment? And if so how much does Cessna typically use in their designs? Additionally is that a value that's proportionate to the total wing span such that wings having a shorter or longer than the Cessna wing span has more or less dihedral and at what rate or ratio? I know that if want a Cessna should buy one of those, however that's not what am asking, so I would short cut the typical answers, but thanks anyway. I am more looking for comparative information and the relationship to something I am most familiar with. Thanks John In a message dated 11/30/2010 8:01:09 A.M. Eastern Standard Time, _jdotson(at)centurylink.net_ (mailto:jdotson(at)centurylink.net) writes: <_jdotson(at)centurylink.net_ (mailto:jdotson(at)centurylink.net) > I built 1 degree into my one piece wing which amounts to the tips being 3 inches higher than the center. The reason I did that was from an experience with a Stinson 108 that I owned. A prior owner had shortened the struts so the wing had ZERO dihedral. As long as you were doing air work or in the pattern it was great. Even a short cross country was a bit aggravating because it flew like sitting on a basketball. Look down at the Sectional, look back up and you were turning one way or the other. The dihedral makes it a lot harder to handle on the workbench. I hope to put it on an airplane one day ! -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done using Lycoming O-235 Read this topic online here: _http://forums.matronics.com/viewtopic.php?p=321773#321773_ (http://forums.matronics.com/viewtopic.php?p=321773#321773) Attachments: http://forums.matronics.com//files/dsc00251_337.jpg http://fo=======================nbsp; (And Get Some AWESOME FREE to find Gifts ilder's ELP b k you for p; -Matt Dralle, List ======================== Use the ties Day ======================= - MATRONICS WEB FORUMS href="http://www.aeroelectric.com/">www.aeroelectric.com href="http://www.buildersbooks.com/">www.buildersbooks.com href="http://www.homebuilthelp.com/">www.homebuilthelp.com href="http://www.ma tronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-L ist href="http://forums.matronics.com/">http://forums.matronics.com (http://www.aeroelectric.com/) (http://www.buildersbooks.com/) (http://www.homebuilthelp.com/) (http://www.matronics.com/contribution) (http://www.matronics.com/Navigator?Pietenpol-List) ________________________________________________________________________________
Date: Nov 30, 2010
Subject: rib fabircators
Is anyone making / selling pietenpol ribs anymore? ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: ready to go smoke system
Date: Nov 30, 2010
FYI everyone, If you're considering a smoke system, ck out aeroconversions.com and go to "accessories". They make a nice 1.7 gal aluminum tank that mounts to the firewall and comes with the associated pumps, switches etc. It's much more pricey than doing it yourself, but it might be worth it as a time savor for some. Douwe ________________________________________________________________________________
Subject: Re: rib fabircators
Date: Nov 30, 2010
http://www.westernaircraftspruce.com/aboutus.php try these guys,they are good folks and have been building Piet kits for a long time.They build ribs as far as I know.Dave -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321861#321861 ________________________________________________________________________________
Date: Nov 30, 2010
FWIW I called them this fall and they are having a hard time getting material around as the large multinational companies have the timber rights tied up, also the government branch in charge of forestry isn't interested in working with small companies As a result most of our high quality wood tends to get exported. I ended up ordering from aircraft spruce as he didn't know when he'd have wood. Kim On 2010-11-30 4:56 PM, "Dangerous Dave" wrote: > > http://www.westernaircraftspruce.com/aboutus.php > try these guys,they are good folks and have been building Piet kits for a long time.They build ribs as far as I know.Dave > > -------- > Building a Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=321861#321861 > > ________________________________________________________________________________
Date: Nov 30, 2010
Subject: Re: ready to go smoke system
waaauuu is about another wood for allmos another fuselaje if you look in au toparts the sistem motor cables and houses for winshiel wiper sistem at wal mart lessat 10 usd. and the reservir tsank from any smal car in perfect sha pe in clude electrc motor in junk yard is 5.00 true 7.50 i stic whit that a nd work perfect I saw my self these way in airplane just perfect corse if y ou have extra 220 you cand duet alot thinks seyou , like you guys say my se ns work penny --- On Tue, 11/30/10, Douwe Blumberg wrote: From: Douwe Blumberg <douweblumberg(at)earthlink.net> Subject: Pietenpol-List: ready to go smoke system Date: Tuesday, November 30, 2010, 4:24 PM FYI everyone, =C2- If you=99re considering a smoke system, ck out aeroconversions.com an d go to =9Caccessories=9D.=C2- They make a nice 1.7 gal alumi num tank that mounts to the firewall and comes with the associated pumps, s witches etc.=C2- It=99s much more pricey than doing it yourself, bu t it might be worth it as a time savor for some. =C2- Douwe =0A=0A=0A ________________________________________________________________________________
Date: Nov 30, 2010
OK, this may sound like a dumb question, but to be able to put in a little dihedral, are you shaping the spar to do it on a one piece wing, or something else. on a 3 piece wing, I would think you could build the dihedral in when the attach brackets were built or attached. Since I've never built a flying model airplane, and the only aircraft I have built was a hot air balloon, I don't have any experience to fall back on. -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321889#321889 ________________________________________________________________________________
Date: Dec 01, 2010
Mike, I cut the angles on the spar splice and the plates of 1/4" plywood. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321899#321899 ________________________________________________________________________________
Date: Dec 01, 2010
I dont have theories or a lot of book learning to back up the dihedral debate, but I have owned and operated a Pietenpol with anhyedral and can say that it is definitely undesirable. It would fall off to one side or the other (not very predictable) during every stall and that included landings. Many exciting times occurred as a result. Most of the time things went well. I have been told (but can not verify that source has since passed away) that Bernard had two people lift up on the wingtips when he measured for the strut lengths on his one-piece wings to obtain a little dihedral. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321928#321928 ________________________________________________________________________________
Date: Dec 01, 2010
Last year at Brodhead, there were two complete sets of original ribs that looked nicely fabricated. $300 is the price that I remember. Can't guarantee what will be there this year but at least it's a data point. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=321936#321936 ________________________________________________________________________________
Subject: dihedral
Date: Dec 01, 2010
Scout has 3" of dihedral. I wish I could find the picture that Kevin posted where our two airplanes appear in the same picture so you can see the marked difference between Fat Girl with zero dihedral and Scout with 3". Although I always thought the dihedral on my airplane was hardly noticeable, in a side-by-side photo it's remarkable. I've never flown another Piet so I have no idea how it affects the handling qualities. To the comment about rigging like a Cessna 150, besides the other comments already offered I would add that there are a whole lot of other differences between the two wings... the Cessna has a good deal of washout, the wing planform is tapered at its outboard end, and it's a different airfoil. Anyway, it's another case of the same old "less filling... more taste" discussion, so I guess we'll have another round ;o) Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Dec 01, 2010
Edgar Howe from NW Indiana was one of the people at Brodhead who had ribs for sale. He can be reached at 219-508 -6880. I am sure he has a set available. Rick Schreiber Valparaiso Indiana ----- Original Message ----- From: early builder Sent: 11/30/2010 2:20:28 PM Subject: Pietenpol-List: rib fabircators Is anyone making / selling pietenpol ribs anymore? ________________________________________________________________________________
Subject: Re: dihedral
Date: Dec 01, 2010
This photo shows the difference in dihedral between the two aircraft pretty well. If it's a calm day Fat Girl can fly hands off for several seconds at a time. If there are any bumps its hands-on all the way. It's been years since I've flown another Piet. I don't remember how they handled so I cannot offer a comparison. I am biased, but I do not find the aircraft particularly difficult or tedious to fly in regards to stability. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322023#322023 Attachments: http://forums.matronics.com//files/fat_girl_and_scout_dihedral_145.jpg ________________________________________________________________________________
Date: Dec 02, 2010
Has anyone purchased ribs from Edgar Howe?- if so please send an email to me at nx797rd(at)yahoo.com - Thanks - Bob Dewenter Dayton OH Corvair /Pietenpol builder. 1% done --- On Wed, 12/1/10, Richard Schreiber wrote: From: Richard Schreiber <lmforge(at)earthlink.net> Subject: RE: Pietenpol-List: rib fabircators Date: Wednesday, December 1, 2010, 10:14 PM Edgar Howe from NW Indiana was one of the people at Brodhead who had ribs f or sale. He can be reached at 219-508 -6880. I am sure he has a set availab le. - Rick Schreiber Valparaiso Indiana - - ----- Original Message ----- From: early builder Sent: 11/30/2010 2:20:28 PM Subject: Pietenpol-List: rib fabircators Is anyone making / selling pietenpol ribs anymore? =0A=0A=0A ________________________________________________________________________________
Date: Dec 02, 2010
Subject: For Sale: Flightcom Classic ANR headset (new in box)
In case anyone is looking to treat themselves (or someone else) to a new headset this Christmas, I've got a brand new, in the box, Flightcom Classic ANR headset for sale (carrying case as well). Approximately 2.5 months old, they were tried on once and the ANR was tested (it works). Otherwise they have had no use. I am asking $300 plus the cost shipping. Please let me know if you would be interested via email and we can go from there. Have a good day! Ryan ________________________________________________________________________________
Date: Dec 02, 2010
Subject: Re: For Sale: Flightcom Classic ANR headset (new in box)
Ryan: Have you tried that ANR headset out in the open cockpit environment to see how it works? I have heard that ANR does not function too well with that kind of active environment. Tom Stinemetze >>> Ryan Mueller 12/2/2010 8:22 AM >>> In case anyone is looking to treat themselves (or someone else) to a new headset this Christmas, I've got a brand new, in the box, Flightcom Classic ANR headset for sale (carrying case as well). Approximately 2.5 months old, they were tried on once and the ANR was tested (it works). Otherwise they have had no use. I am asking $300 plus the cost shipping. Please let me know if you would be interested via email and we can go from there. Have a good day! Ryan ===================== ________________________________________________________________________________
Date: Dec 02, 2010
Hi Tom, I have not tried them in the airplane; as mentioned, they have not been used (other than test fit and making sure the ANR turned on). I would refer to an excerpt from a post Mike Cuy put up a couple years back when he picked up a set; that was part of reason I went ahead and bought them: "I have a 9 volt battery powered 2-place Sigtronics intercom w/ squelch and volume control. Microphone sponges/covers are a must to cut wind noise and if possible use noise cancelling head sets. I just purchased a Flightcom Classic ANR (active noise reduction) headset to replace my very old Pilot Avionics at Oshkosh and tried it last weekend and could hear unicom frequencies 75% better than I did with my old Pilot Avionics units. Transmissions were so much more clear as well. I'm sold on ANR headsets." Ryan On Thu, Dec 2, 2010 at 8:33 AM, TOM STINEMETZE wrote: > *Ryan:* > ** > *Have you tried that ANR headset out in the open cockpit environment to > see how it works? I have heard that ANR does not function too well with > that kind of active environment.* > ** > *Tom Stinemetze* > > > >>> Ryan Mueller 12/2/2010 8:22 AM >>> > > In case anyone is looking to treat themselves (or someone else) to a new > headset this Christmas, I've got a brand new, in the box, Flightcom Classic > ANR headset for sale (carrying case as well). Approximately 2.5 months old, > they were tried on once and the ANR was tested (it works). Otherwise they > have had no use. I am asking $300 plus the cost shipping. Please let me know > if you would be interested via email and we can go from there. Have a good > day! > > Ryan > > * > ectric.com > ">www.buildersbooks.combuilthelp.com > .matronics.com/contribution > > ">http://www.matronics.com/Navigator?Pietenpol-List > ics.com* > > * > > ________________________________________________________________________________
Subject: latex on sheet metal/fiberglass
Date: Dec 02, 2010
Who here has painted their sheet metal/fiberglass components with latex? And how did it work for you and what did it look like and how is it holding up. I tried a test panel over some epoxy primer, and even after a month drying, I can still scrape the latex off with my fingernail. I'm wondering if I needed to scuff the epoxy primer or use a dedicated latex primer for metal. Douwe ________________________________________________________________________________
Date: Dec 02, 2010
Subject: Re: latex on sheet metal/fiberglass
I sprayed my aluminum cowling and turtle deck with latex primer and latex satin. Latex paint stays fairly soft and does not get hard like auto urethane or epoxy paint. It is easily scratched although I found that auto urethane scratches fairly easy also (I painted my landing gear with urethan e and if I was going to do it again would powder coat all exterior tubing). I figure if the scratches start to bother me, once each year I can remove my cowl and turtle deck in a couple minutes and spray on a other coat of latex in another 15 minutes (including water cleanup) for a total cost of a buck or two. If you want a more indestructible finish on your Piet use the expensive stuff. Latex finish coat may stick to latex primer better than epoxy primer (and of course you will want to etch your aluminum first). rick On Thu, Dec 2, 2010 at 8:04 AM, Douwe Blumberg wrote: > Who here has painted their sheet metal/fiberglass components with latex? > And how did it work for you and what did it look like and how is it holdi ng > up. > > > I tried a test panel over some epoxy primer, and even after a month dryin g, > I can still scrape the latex off with my fingernail. I=92m wondering if I > needed to scuff the epoxy primer or use a dedicated latex primer for meta l. > > > Douwe > > * > =========== =========== =========== ============* > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Dec 02, 2010
box) And not only was THAT ANR headseat great for the Pietenpol but the Gulfcoas t Avionics ANR (David Clark look-alike but all black) one is excellent too. I had excellent results hearing/taking with the controllers at OSH in 2009 and more recently when flying into a controlled airport a few weeks ago us ing the Flightcom ANR headset. The ANR really mutes the engine noise and wind noise plus in addition to the must-have foam over the microphone condom thingy that you can purchase as an accessory if the headset doesn't come wi th it. The only issues you have in an open cockpit are when your passengers lean o ut over the side to look down, then you get a blast of prop blast wind nois e in your ears and it usually startles the passenger and they stop doing it p retty quickly ! Carry on good people, Mike C. [cid:image001.jpg(at)01CB921F.F697B510] ________________________________________________________________________________
Date: Dec 02, 2010
benjamin moores makes a good metal primer for latex. cheers, Gardiner Mason =0A=0A=0A=0A=0A________________________________=0AFrom: Douwe Blumberg <dou weblumberg(at)earthlink.net>=0ATo: pietenpolgroup =0ASent: Thu, December 2, 2010 10:04:09 AM=0ASubject: Pietenpol-List: lat ex on sheet metal/fiberglass=0A=0A =0AWho here has painted their sheet meta l/fiberglass components with latex? And how =0Adid it work for you and what did it look like and how is it holding up. =0A=0A =0AI tried a test panel over some epoxy primer, and even after a month drying, I =0Acan still scrap e the latex off with my fingernail. I=99m wondering if I needed to =0Ascuff the epoxy primer or use a dedicated latex primer for metal.=0A =0A ========== =0A ________________________________________________________________________________
Date: Dec 02, 2010
Thanks for the info Mikee. And yes, this one did come with the foam microphone condom thingy. :P (I just doublechecked) The warranty card is in the carrying case, so the new owner will be the recipient of the warranty if they send that in. ACS is selling them for $346.50 right now, so I think it's a pretty good deal for exactly the same thing. Have a good day! Ryan On Thu, Dec 2, 2010 at 11:53 AM, Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] wrote: > And not only was THAT ANR headseat great for the Pietenpol but the > Gulfcoast Avionics ANR (David Clark look-alike but all black) one > > is excellent too. > > * * > > I had excellent results hearing/taking with the controllers at OSH in 20 09 > and more recently when flying into a controlled airport a few weeks ago > using > > the Flightcom ANR headset. The ANR really mutes the engine noise and wi nd > noise plus in addition to the must-have foam over the microphone condom > > thingy that you can purchase as an accessory if the headset doesn=92t com e > with it. > > > The only issues you have in an open cockpit are when your passengers lean > out over the side to look down, then you get a blast of prop blast wind > noise > > in your ears and it usually startles the passenger and they stop doing it > pretty quickly ! > > > Carry on good people, > > > Mike C. > > > [image: HUGHES.JPG] > > > * * > ________________________________________________________________________________
Date: Dec 02, 2010
Ryan: If you can guarantee that it also work on Crank Snappin' Corvair noises I will take it off your hands. I think I still have your address around somewhere. By the way, are you doing any of your own Piet flying yet? Stinemetze N328X do not archiv ____ | ____ \8/ / \e >>> Ryan Mueller 12/2/2010 12:15 PM >>> Thanks for the info Mikee. And yes, this one did come with the foam microphone condom thingy. :P (I just doublechecked) The warranty card is in the carrying case, so the new owner will be the recipient of the warranty if they send that in. ACS is selling them for $346.50 right now, so I think it's a pretty good deal for exactly the same thing. Have a good day! Ryan ________________________________________________________________________________
Date: Dec 02, 2010
The flying and glider manual for 1933 with the scout plans actually says that exactly on page 40... " Next have someone hold up the end of the wing so it will have a little dihedral, and measure the length of the front struts. these should both be exactly the same length" jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322091#322091 ________________________________________________________________________________
Date: Dec 02, 2010
This "dhyedral" thread kind of reminds me of the "plnas" thread that ran so long back in August for some reason. rick On Thu, Dec 2, 2010 at 1:57 PM, bender wrote: > jfaith(at)solairusaviation.com> > > The flying and glider manual for 1933 with the scout plans actually says > that exactly on page 40... > " Next have someone hold up the end of the wing so it will have a little > dihedral, and measure the length of the front struts. these should both be > exactly the same length" > > jeff > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322091#322091 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 02, 2010
Hi Tom, Haha...I would think it would quiet the purr of a CSC just as well as the bleating of an A-65. :) I've got your address, I will ship it from the local UPS store on Saturday (I'm in the Detroit area now for work 'til tomorrow night). Once it ships I'll have the total plus shipping and you can drop a check in the mail. I'll shoot you my address with the total. Thanks, long travel day, time for bed. Have a good evening, Ryan On Thu, Dec 2, 2010 at 2:59 PM, TOM STINEMETZE wrote: > *Ryan:* > ** > *If you can guarantee that it also work on Crank Snappin' Corvair noises I > will take it off your hands. I think I still have your address around > somewhere.* > *By the way, are you doing any of your own Piet flying yet?* > ** > *Stinemetze* > *N328X > * > *do not archiv* > > *____ | ____ > \8/ > / \e > *>>> Ryan Mueller 12/2/2010 12:15 PM >>> > > Thanks for the info Mikee. > > And yes, this one did come with the foam microphone condom thingy. :P (I > just doublechecked) > > The warranty card is in the carrying case, so the new owner will be the > recipient of the warranty if they send that in. ACS is selling them for > $346.50 right now, so I think it's a pretty good deal for exactly the same > thing. > > Have a good day! > > Ryan > ________________________________________________________________________________
Subject: Welding Question
Date: Dec 02, 2010
This might be really dumb question but when I'm tack welding parts together that are bolted to wood structure, for example the landing gear mounts on the bottom longerons, how do I prevent scorching of the wood or damaging the glue joint? Thanks for the help. This is my first wood airplane. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322132#322132 ________________________________________________________________________________
Subject: Re: Welding Question
Date: Dec 03, 2010
I would build up a dummy of that particular section and tack them up off of that,you will mess something up if you weld on the fuselage.Dave -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322147#322147 ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Dec 03, 2010
That was my first thought -- but it would be a lot of trouble. ----- Original Message ----- From: "Dangerous Dave" <dsornbor(at)aol.com> Sent: Friday, December 03, 2010 7:11 AM Subject: Pietenpol-List: Re: Welding Question > > I would build up a dummy of that particular section and tack them up off > of that,you will mess something up if you weld on the fuselage.Dave > > -------- > Building a Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322147#322147 > > > ________________________________________________________________________________
Date: Dec 03, 2010
Dave, I've been having a bit of a problem with E-mails to the Piet list being returned. If this one goes through I guess the problem has been corrected. See you! ----- Original Message ----- From: "Dangerous Dave" <dsornbor(at)aol.com> Sent: Friday, December 03, 2010 7:11 AM Subject: Pietenpol-List: Re: Welding Question > > I would build up a dummy of that particular section and tack them up off > of that,you will mess something up if you weld on the fuselage.Dave > > -------- > Building a Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322147#322147 > > > ________________________________________________________________________________
Date: Dec 03, 2010
Al: I just got through figuring out that very problem with my landing gear fittings. I tried to tack the parts while jigged up on the airplane with my gas welding rig. It took too long to spot heat the fittings and the wood underneath started to scorch in spite of all my wet rags and sheet metal shields. So, I got a friend with a portable mig welder to come over and he was able to just hit the parts quickly with a minimum of area heating to tack the parts together. (minimal scorching beneath the area of the weld) Then I disassembled everything and moved it to my welding table where I could complete the weld by gas without problem. Note that the previously perfectly sized holes have to be resized after the final weld. Tom Stinemetze N328X >>> "AlRice" 12/2/2010 10:29 PM >>> This might be really dumb question but when I'm tack welding parts together that are bolted to wood structure, for example the landing gear mounts on the bottom longerons, how do I prevent scorching of the wood or damaging the glue joint? ________________________________________________________________________________
Date: Dec 03, 2010
What I recommend: "dry" fit the parts to each other and to the plane. Use t he bolt holes if there are any, or clamps, etc. to hold the part(s) in plac e on the plane. Continue to bend, drill, dry fit until you are happy with h ow they go together. Once bolted/clamped on the plane, I usually will mark reference lines on the parts where they meet/touch/bolt to each other. Then I remove from the plane, line up the marks and tack weld.- Re-fit to pla ne to check. If happy, remove and final weld. Some fixturing/jigging may be necessary for tack/final weld. (see pic.) Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Dec 03, 2010
Many times I will tack parts while still attached to the airframe. Just make sure you remove them before things get too hot and burn some wood. My mock fuselage, turned upside down was real handy for tack welding my landing gear parts. rick On Fri, Dec 3, 2010 at 5:11 AM, Dangerous Dave wrote: > > I would build up a dummy of that particular section and tack them up off of > that,you will mess something up if you weld on the fuselage.Dave > > -------- > Building a Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322147#322147 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 03, 2010
Just what I did with a tig. On Fri, Dec 3, 2010 at 7:17 AM, TOM STINEMETZE wrote: > *Al:* > ** > *I just got through figuring out that very problem with my landing gear > fittings. I tried to tack the parts while jigged up on the airplane with my > gas welding rig. It took too long to spot heat the fittings and the wood > underneath started to scorch in spite of all my wet rags and sheet metal > shields. So, I got a friend with a portable mig welder to come over and he > was able to just hit the parts quickly with a minimum of area heating to > tack the parts together. (minimal scorching beneath the area of the weld) > Then I disassembled everything and moved it to my welding table where I > could complete the weld by gas without problem. Note that the previously > perfectly sized holes have to be resized after the final weld.* > ** > *Tom Stinemetze* > *N328X* > ** > > > >>> "AlRice" 12/2/2010 10:29 PM >>> > > > This might be really dumb question but when I'm tack welding parts together > that are bolted to wood structure, for example the landing gear mounts on > the bottom longerons, how do I prevent scorching of the wood or damaging the > glue joint? > > * > > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: tack welding
Date: Dec 03, 2010
Hey Al, My first question is are you gas or tig welding? I'm not sure you could even do this with gas as the metal has to heat up and there would be no way to protect the underlying wood and glue from scorching. I have done this by protecting the surrounding areas with a heat shield of thin aluminum or something like that and making small, very quick tacks using a tig, then removing the assembly and welding it solid. Gotta be careful and only make one or two tacks per area before letting it cool down and starting again. Douwe ________________________________________________________________________________
Date: Dec 03, 2010
That's a really good use for a mock fuse. The other is that you WILL want to check out how it feels to actually SIT in the fuse you're building. A mock fuse resolves both.... I don't think anyone should ever build a Pietenpol without building a mock fuse.... jm -----Original Message----- From: Rick Holland Sent: Dec 3, 2010 8:55 AM Subject: Re: Pietenpol-List: Re: Welding Question Many times I will tack parts while still attached to the airframe. Just make sure you remove them before things get too hot and burn some wood. My mock fuselage, turned upside down was real handy for tack welding my landing gear parts. rick On Fri, Dec 3, 2010 at 5:11 AM, Dangerous Dave wrote: I would build up a dummy of that particular section and tack them up off of that,you will mess something up if you weld on the fuselage.Dave -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322147#322147 ========== ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 03, 2010
What is a mock fuselage? ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Sent: Friday, December 03, 2010 1:18 PM Subject: Re: Pietenpol-List: Re: Welding Question > > > That's a really good use for a mock fuse. The other is that you WILL want > to check out how it feels to actually SIT in the fuse you're building. A > mock fuse resolves both.... > > I don't think anyone should ever build a Pietenpol without building a mock > fuse.... > > jm > > > -----Original Message----- > > From: Rick Holland > > Sent: Dec 3, 2010 8:55 AM > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: Re: Welding Question > > > Many times I will tack parts while still attached to the airframe. Just > make sure you remove them before things get too hot and burn some wood. My > mock fuselage, turned upside down was real handy for tack welding my > landing gear parts. > > > rick > > On Fri, Dec 3, 2010 at 5:11 AM, Dangerous Dave wrote: > > > I would build up a dummy of that particular section and tack them up off > of that,you will mess something up if you weld on the fuselage.Dave > > > -------- > > Building a Piet > > > Read this topic online here: > > > http://forums.matronics.com/viewtopic.php?p=322147#322147 > > > ========== > > ="_blank">www.aeroelectric.com > > ooks.com" target="_blank">www.buildersbooks.com > > et="_blank">www.homebuilthelp.com > > ="_blank">http://www.matronics.com/contribution > > le, List Admin. > > ========== > > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > > ========== > > http://forums.matronics.com > > ========== > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > > > ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Dec 03, 2010
A fuselage (some just make the cockpit areas) made full size out of whatever materials you want (i.e. inexpensive) for the purpose of using it to "try things on for size" or as a fabrication jig. NOT EVER intended to be flown (although there have been a few notables on this list in the past who made what were essentially mock fuselages that they insisted were airworthy). Not to be confused with Mock Turtle Soup :). Kip Gardner On Dec 3, 2010, at 1:41 PM, Charles Campbell wrote: > > What is a mock fuselage? > > ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> > To: > Sent: Friday, December 03, 2010 1:18 PM > Subject: Re: Pietenpol-List: Re: Welding Question > > >> >> That's a really good use for a mock fuse. The other is that you WILL want to check out how it feels to actually SIT in the fuse you're building. A mock fuse resolves both.... >> >> I don't think anyone should ever build a Pietenpol without building a mock fuse.... >> >> jm >> >> >> -----Original Message----- >> >> From: Rick Holland >> >> Sent: Dec 3, 2010 8:55 AM >> >> To: pietenpol-list(at)matronics.com >> >> Subject: Re: Pietenpol-List: Re: Welding Question >> >> >> >> Many times I will tack parts while still attached to the airframe. Just make sure you remove them before things get too hot and burn some wood. My mock fuselage, turned upside down was real handy for tack welding my landing gear parts. >> >> >> rick >> >> On Fri, Dec 3, 2010 at 5:11 AM, Dangerous Dave wrote: >> >> >> >> >> I would build up a dummy of that particular section and tack them up off of that,you will mess something up if you weld on the fuselage.Dave >> >> >> >> -------- >> >> Building a Piet >> >> >> >> >> >> >> >> >> >> Read this topic online here: >> >> >> >> http://forums.matronics.com/viewtopic.php?p=322147#322147 >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> ========== >> >> ="_blank">www.aeroelectric.com >> >> ooks.com" target="_blank">www.buildersbooks.com >> >> et="_blank">www.homebuilthelp.com >> >> ="_blank">http://www.matronics.com/contribution >> >> le, List Admin. >> >> ========== >> >> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> >> ========== >> >> http://forums.matronics.com >> >> ========== >> >> >> >> >> >> >> >> >> >> >> -- >> Rick Holland >> Castle Rock, Colorado >> >> "Logic is a wreath of pretty flowers, that smell bad" >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: Fuselage Mockup
Date: Dec 03, 2010
This is the mockup we made the first night of the Big Piet Project. We soon found out that we needed a bigger fuselage for some or our fluffier builders. It was a couple of 2x4s ripped down to 1x1 and some scrap luan plywood. It took about an hour and a half to build and adjust to our needs. We made the luan "gussets" large so we could adjust as needed and screwed it together with sheetrock screws and a battery drill. I think total cost was under $10 and was the best money spent on the whole project of 5 Big Piets. It's a good idea to check for fit and use a cushion under your butt and back to see how it will really fit. Also see if you can read the instruments with your bifocals inside your goggles. (this is only for the older builders like me) Barry Davis ________________________________________________________________________________
Date: Dec 03, 2010
Subject: Welding Question NOW physiological fuselages...
My fuselage should feel pretty lucky then...I'M the one who takes all those physiological barbs, opinions, insults, rude comments, etc. while out ther e with it...it just gets the praise...- Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Dec 03, 2010
Subject: Re: Fuselage Mockup
The prop on front was a nice touch Barry. Here is mine after several winters out in the South 40... rick On Fri, Dec 3, 2010 at 3:47 PM, Barry Davis wrote: > This is the mockup we made the first night of the Big Piet Project. We > soon found out that we needed a bigger fuselage for some or our fluffier > builders. It was a couple of 2x4s ripped down to 1x1 and some scrap luan > plywood. It took about an hour and a half to build and adjust to our needs. > We made the luan "gussets" large so we could adjust as needed and screwed it > together with sheetrock screws and a battery drill. I think total cost was > under $10 and was the best money spent on the whole project of 5 Big Piets. > It's a good idea to check for fit and use a cushion under your butt and back > to see how it will really fit. Also see if you can read the instruments with > your bifocals inside your goggles. (this is only for the older builders like > me) > Barry Davis > > > ** > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 03, 2010
----- Original Message ----- From: Barry Davis To: pietenpol-list(at)matronics.com Sent: Friday, December 03, 2010 5:47 PM Subject: Pietenpol-List: Fuselage Mockup This is the mockup we made the first night of the Big Piet Project. We soon found out that we needed a bigger fuselage for some or our fluffier builders. It was a couple of 2x4s ripped down to 1x1 and some scrap luan plywood. It took about an hour and a half to build and adjust to our needs. We made the luan "gussets" large so we could adjust as needed and screwed it together with sheetrock screws and a battery drill. I think total cost was under $10 and was the best money spent on the whole project of 5 Big Piets. It's a good idea to check for fit and use a cushion under your butt and back to see how it will really fit. Also see if you can read the instruments with your bifocals inside your goggles. (this is only for the older builders like me) Barry Davis ________________________________________________________________________________
Date: Dec 03, 2010
After reading the Oct 2010 issue of BPAN, I wrote Doc with a simple question -- what is a 'Big Piet'? I think Doc must have been busy or something 'cause I never heard back. Now you are talking about the Big Piet. Now I'll ask you -- what is a Big Piet? ----- Original Message ----- From: Barry Davis To: pietenpol-list(at)matronics.com Sent: Friday, December 03, 2010 5:47 PM Subject: Pietenpol-List: Fuselage Mockup This is the mockup we made the first night of the Big Piet Project. We soon found out that we needed a bigger fuselage for some or our fluffier builders. It was a couple of 2x4s ripped down to 1x1 and some scrap luan plywood. It took about an hour and a half to build and adjust to our needs. We made the luan "gussets" large so we could adjust as needed and screwed it together with sheetrock screws and a battery drill. I think total cost was under $10 and was the best money spent on the whole project of 5 Big Piets. It's a good idea to check for fit and use a cushion under your butt and back to see how it will really fit. Also see if you can read the instruments with your bifocals inside your goggles. (this is only for the older builders like me) Barry Davis ________________________________________________________________________________
Subject: Trouble with the Piet list
Date: Dec 03, 2010
One of our newest members, Charles Campbell, sent me this message off-line. Does anyone have any words of wisdom to rectify this situation? Thanks. Dan, I am having some trouble with the Piet list. I am receiving E-mail OK but all my outgoing E-mails are being blocked. I can't send a message to matronics at all. In fact, when you asked for an E-mail address to contact BPAN I sent you an E-mail that was rejected. Could you investigate this f or me? I paid my "dues" last month so that shouldn't be the problem. Thank s for anything you can do for me. Chuck cncampbell(at)windstream.net Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Re: Welding Question: need for a mock fuse
Date: Dec 03, 2010
Mock fuselage? Mock fuselage? We don' need no stink'n mock fuselages!! You should all be ashamed of yourselves, expressing the "need" for a mock fusel age. Any self-respecting genuine devote' of Bernerd Pietenpol would never c onsider second guessing the original design of the BHP Aircamper. Just buil d it to plans, and you will be assured, the results will be superb. Dan Helsper, purist Poplar Grove, IL. -----Original Message----- From: Jim Markle <jim_markle(at)mindspring.com> Sent: Fri, Dec 3, 2010 12:29 pm Subject: Re: Pietenpol-List: Re: Welding Question > That's a really good use for a mock fuse. The other is that you WILL want to heck out how it feels to actually SIT in the fuse you're building. A mock fuse esolves both.... I don't think anyone should ever build a Pietenpol without building a mock use.... jm ----Original Message----- From: Rick Holland Sent: Dec 3, 2010 8:55 AM Subject: Re: Pietenpol-List: Re: Welding Question Many times I will tack parts while still attached to the airframe. Just mak e ure you remove them before things get too hot and burn some wood. My mock uselage, turned upside down was real handy for tack welding my landing gear arts. ick On Fri, Dec 3, 2010 at 5:11 AM, Dangerous Dave wrote: I would build up a dummy of that particular section and tack them up off of hat,you will mess something up if you weld on the fuselage.Dave -------- Building a Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322147#322147 ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com - ick Holland astle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Subject: It flies again for the first time
Date: Dec 03, 2010
N1709R is finally back in the air. After 600hrs of labor and a few thousand dollars, the airplane flew for the first time (again) after being brought back to life from being neglected for the past 10 or so years. (It is interesting to note the size of the giant tail. The original builder didn't think it had enough rudder control, so he enlarged it to over double the normal size. Now it has lots of rudder authority, but looks somewhat cartoonish in flight. At first, I didn't like it, but it is growing on me (no pun intended). Thanks for everyone's input and help. Looking through some very old photos from my wife's grandparents, we noticed a picture of a barnstormer who landed in a field in a Jenny and took my wife's aunt for a ride. The next year he was back in a Ford Tri-motor in the same field in the Amarillo area. So, for our Christmas cards to the family this year, we re-enacted the photo with the Piet and had them printed in the Sepia color to look old. They turned out pretty good. Charlie Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322228#322228 Attachments: http://forums.matronics.com//files/stephen_thanksgiving_pic_611.jpg http://forums.matronics.com//files/stephen_sepia_piet_727.jpg ________________________________________________________________________________
Date: Dec 03, 2010
So, besides the mock fuselage, I guess we'll have to fab a jig for a mock aileron pulley mount and probably several others. I guess Tucker and I better get movin'. Thanks for the help from everyone. BTW, Tucker finished up his ribs today. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322230#322230 ________________________________________________________________________________
Date: Dec 03, 2010
Subject: Re: Welding Question2
ok in the way i weld my metal parts special landingear attachment plate and lungs is make a fake bely botom from my fuselaje mesurament adn atach plat es in plase and wel by gas and acetilene the jig wood is burd but the plate s is weld others pert like elevator bellcrank I used pliers or metal clamps for my landingear leg made from metal tubing make a plywood jig riced from base wood about 1inch or so make the tigh joint and welds work bery well a nd is bery safe I never trate to well anie pert attach from my real airplan e I jope these ideas help you tanks all jorge from hanford --- On Thu, 12/2/10, AlRice wrote: From: AlRice <Allen(at)allenrice.net> Subject: Pietenpol-List: Welding Question Date: Thursday, December 2, 2010, 8:29 PM This might be really dumb question but when I'm tack welding parts together that are bolted to wood structure, for example the landing gear mounts on the bottom longerons, how do I prevent scorching of the wood or damaging th e glue joint? Thanks for the help.- This is my first wood airplane. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322132#322132 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Dec 03, 2010
ok in the way i weld my metal parts special landingear attachment plate and lungs is make a fake belly bottom from my fuselaje mesurament and atached plates in plase and weld by gas and acetylene the jig wood is burn but the plates is weld others part like elevator bellcrank I used pliers or metal c lamps for my landingear leg made from metal tubing make a plywood jig riced from base wood about 1inch or so make the tigh joint and welds work bery w ell and is bery safe, I never trate to well anie part attach from my real a irplane. I jope these ideas help you tanks all jorge from hanford --- On Thu, 12/2/10, AlRice wrote: From: AlRice <Allen(at)allenrice.net> Subject: Pietenpol-List: Welding Question Date: Thursday, December 2, 2010, 8:29 PM This might be really dumb question but when I'm tack welding parts together that are bolted to wood structure, for example the landing gear mounts on the bottom longerons, how do I prevent scorching of the wood or damaging th e glue joint? Thanks for the help.- This is my first wood airplane. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322132#322132 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Dec 03, 2010
Barry Davis (see above poster) and 5 others got together and built 6 identical airplanes based on the Pietenpol design. IIRC, they were about 10% bigger than the standard and build mostly out of metal rather than wood. All used Corvair engines. There was an article on them in Sport Aviation several years ago. After they were mostly built, the group drew names out of a hat to figure out who got which project. That's the legend anyway. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322237#322237 ________________________________________________________________________________
Subject: Re: tack welding
Date: Dec 04, 2010
It's been a while since I did any welding on these parts next to wood so I forgot something until just now. I found this stuff in the welding supply before doing that You paint on the parts near the weld and it acts as a heat sink. My supply is long gone now but I'm sure a supply company or welder would know what it is and where to get it. Clif My first question is are you gas or tig welding? I'm not sure you could even do this with gas as the metal has to heat up and there would be no way to protect the underlying wood and glue from scorching. Douwe ________________________________________________________________________________
Subject: Re: It flies again for the first time
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Dec 04, 2010
You mention the Amarillo area- are you around here now? that is a fine looking airplane! Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322244#322244 ________________________________________________________________________________
Subject: Re: Trouble with the Piet list
Date: Dec 04, 2010
he should make sure he is sending a message to the list with the same e mail address that he signed up with..I had that trouble until I realized I was reading the list at my shop with a different email heading then the one I signed on with 73 Don w8zrz ________________________________________________________________________________
Subject: FOR SALE - Pietenpol Air Camper Builders Manual & Sup
P
Date: Dec 04, 2010
I accidentally ended up with two copies of the Builders Manual. My cost was $37. Anyone needing one can have my extra copy for $33 with free shipping. Also have a set of new Original Pietenpol Air Camper Supplemental Plans I have no need of, for $55 with free shipping. Following is description from the Pietenpol Family web site. -- Original Pietenpol Air Camper & Sky Scout Builders Manual Original Builders manual that contains the text written by Mr. Pietenpol for the Flying & Glider Manual and Popular Aviation magazines of the 1930's. This is the information pertinent to building the Air Camper and the Sky Scout in the1930's. Also included is history about the planes that Mr. Pietenpol built and construction notes to assist the first time builder to better understand why it's built as it is. A good head start! Bernard wrote much of this manual himself and documents the how to's! Chapter I The Amateur Airplane Builder Chapter II Modern Mechanics and Inventions Ford A Powered 2-Seat Monoplane Pietenpol Steel Tube Fuselage Mounting the Motor on your Air Camper The Pietenpol-Ford Motor Conversion Chapter III Sky Scout The Pietenpol Sky Scout Tail Group and Fuselage Fittings Chapter IV Converting Ford Model A Engines For Flight Chapter V Itemized Parts List Chapter VI Airplane Chronology Chapter VII Converting the Corvair Engine For Flight Chapter VIII Sixty-five Years Of Post Flight Chapter IX Builders Notes Chapter X Builders Questions Original Air Camper & Sky Scout Builders Manual $37.00 US Dollars *Free Shipping ----------------------------------------------------------- Original Pietenpol Air Camper Supplemental Plans Includes drawings showing the installation of the Corvair engine. This packet of plans includes drawing for a longer fuselage, Corvair motor mount drawing, Corvair propeller hub drawing, 65 hp Continental engine motor mount drawing. Original Air Camper Supplemental Drawings (Extended Fuselage to be used with A-65's and modern engines) $60.00 US Dollars *Free Shipping -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322260#322260 ________________________________________________________________________________
Subject: Re: BPA Newsletter email
Date: Dec 04, 2010
Dan I've sent several emails to the address Jack posted. Never a a reply. Craig -------- A goal without a plan is nothing more than a wish. -- orion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322279#322279 ________________________________________________________________________________
Subject: Hey, Got My Ribs Done
Date: Dec 04, 2010
Got my ribs all done. Hooray! Now onto the fuselage. Captain says that we have to build a mock fuselage first. I guess we'll do that when I'm out of school for the Christmas break. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322293#322293 Attachments: http://forums.matronics.com//files/img_0002_134.jpg ________________________________________________________________________________
Date: Dec 04, 2010
I'm using TIG which does the best job of keeping the heat localized and minimized but it is still too much heat for wood and glue joints. I'll build a throw away fuse for mock-up. -------- Tucker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322294#322294 ________________________________________________________________________________
Subject: Re: Hey, Got My Ribs Done
Date: Dec 04, 2010
Tucker, You make me proud. Keep on a keepin' on and one day you will fly your OWN airplane. In the process you are learning things that no one can take away from you. The skills you learn while building will pass on to adult life as a way to get a job if you want to work with your hands. I would love to have you for a grandson. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322299#322299 ________________________________________________________________________________
Subject: another fine day
Date: Dec 04, 2010
Put another 2.4 hrs. in the logbook today at the controls of "Scout". Beautiful day for flying... practically CAVU in advance of a cold front, just barely jacket weather at 2500 ft. but we were glad we had jackets after 30 minutes at 3000 ft. There was an open house and fly-in at Castroville today, just 10 minutes south of my home field. Flew over there to fuel up and to see who was on the field, only to find a very quiet day there. Fueled up, then the airport guys took my brother and I over to the hangar where a fellow is building a scale Nieuport 12 replica with a 9-cylinder Rotec radial. Gorgeous airplane! While we were getting ready to head out, traffic called "North American xxx entering downwind..." and we knew it was something special. It was. A stunning SNJ! He landed, fueled up, and then we taxied out for our takeoff, headed to Medina Lake and then to Boerne Stage Airport to drop off my brother. While we were climbing out toward Medina Lake, I see the SNJ clawing up towards us! He formed up on our starboard wing, they waved through the open canopies, then zoomed off. We were at cruise at 70MPH and the SNJ smoked past us like we were tied down ;o) Sun was on our port side and illuminated his broadside in our view, so itlit up the SNJ in a picture-perfect way our wing. I got some pix of it on the ground, but not in the air, doggone it. I love flying this airplane, even if I did notice that yet another of the cooling eyebrow mounting tabs has now fatigued clear through. Sigh. I replace about one every 6 months... Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Dec 04, 2010
Subject: Re: physiological fuselages
Well, I was referring to my actual fuselage...I did not make a mock up of it. However, I make A LOT of templates...I use a CAD type program and print out the various metal parts, (and my own designs) to see how they all look/fit together. I am more of a "Template Builder" I guess. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Dec 04, 2010
Good for you. Smart to get that most tedious task out of the way right up front when you are highly motivated. Building the fuselage has bee my favorite part so far! Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Dec 04, 2010
Congratulations Tucker, you have accomplished a lot. Just keep at it and before you know it you will have the makings of a real airplane. Jon Coxwell -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322311#322311 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG FORSCOM" <steven.d.dortch(at)us.army.mil>
Date: Dec 05, 2010
Subject: Re: another fine day
Man, I wish I was there. I am getting "Horny for aviation." In the 1990s I was "Shot down" in my Cessna 150 by a P51 over Galveston. The P51 was on a photoshoot with a B17. When I saw him I announced my position. He called TallyHO rolled off and did a "Gun run" straight at me while doing aleron rolls. He passed by my right wing. I got one photo. A winged blur. Then he formed up on the B17 and went on his way. Way Cool. Blue Skies, Steve D On 12/05/10, Oscar Zuniga wrote: > > > Put another 2.4 hrs. in the logbook today at the controls of > "Scout". Beautiful day for flying... practically CAVU in advance > of a cold front, just barely jacket weather at 2500 ft. but > we were glad we had jackets after 30 minutes at 3000 ft. > > There was an open house and fly-in at Castroville today, just 10 > minutes south of my home field. Flew over there to fuel up and > to see who was on the field, only to find a very quiet day there. > Fueled up, then the airport guys took my brother and I over to > the hangar where a fellow is building a scale Nieuport 12 replica > with a 9-cylinder Rotec radial. Gorgeous airplane! While we > were getting ready to head out, traffic called "North American xxx > entering downwind..." and we knew it was something special. It was. > A stunning SNJ! He landed, fueled up, and then we taxied out > for our takeoff, headed to Medina Lake and then to Boerne Stage > Airport to drop off my brother. While we were climbing out toward > Medina Lake, I see the SNJ clawing up towards us! He formed up on > our starboard wing, they waved through the open canopies, then > zoomed off. We were at cruise at 70MPH and the SNJ smoked past us > like we were tied down ;o) Sun was on our port side and illuminated > his broadside in our view, so itlit up the SNJ in a picture-perfect > way our wing. I got some pix of it on the ground, but not in the air, > doggone it. > > I love flying this airplane, even if I did notice that yet another > of the cooling eyebrow mounting tabs has now fatigued clear through. > Sigh. I replace about one every 6 months... > > Oscar Zuniga > Air Camper NX41CC "Scout" > San Antonio, TX > website at http://www.flysquirrel.net > ________________________________________________________________________________
Date: Dec 04, 2010
Subject: Re: another fine day2
I whisch haved in these moment at bf 109K to shot dow another P51 mustang a nd make a few past in those B 17 engines too seyou. --- On Sat, 12/4/10, Dortch, Steven D MAJ NG NG FORSCOM <steven.d.dortch@us .army.mil> wrote: From: Dortch, Steven D MAJ NG NG FORSCOM <steven.d.dortch(at)us.army.mil> Subject: Re: Pietenpol-List: another fine day Date: Saturday, December 4, 2010, 9:26 PM Man, I wish I was there. I am getting "Horny for aviation." In the 1990s I was "Shot down" in my Cessna 150 by a P51 over Galveston. Th e P51 was on a photoshoot with a B17. When I saw him I announced my positio n. He called TallyHO rolled off and did a "Gun run" straight at me while do ing aleron rolls. He passed by my right wing. I got one photo. A winged blu r. Then he formed up on the B17 and went on- his way. Way Cool. Blue Skies, Steve D On 12/05/10, Oscar Zuniga- wrote: > > > > Put another 2.4 hrs. in the logbook today at the controls of > "Scout".- Beautiful day for flying... practically CAVU in advance > of a cold front, just barely jacket weather at 2500 ft. but > we were glad we had jackets after 30 minutes at 3000 ft. >- > There was an open house and fly-in at Castroville today, just 10 > minutes south of my home field.- Flew over there to fuel up and > to see who was on the field, only to find a very quiet day there. > Fueled up, then the airport guys took my brother and I over to > the hangar where a fellow is building a scale Nieuport 12 replica > with a 9-cylinder Rotec radial.- Gorgeous airplane!- While we > were getting ready to head out, traffic called "North American xxx > entering downwind..." and we knew it was something special.- It was. > A stunning SNJ!- He landed, fueled up, and then we taxied out > for our takeoff, headed to Medina Lake and then to Boerne Stage > Airport to drop off my brother.- While we were climbing out toward > Medina Lake, I see the SNJ clawing up towards us!- He formed up on > our starboard wing, they waved through the open canopies, then > zoomed off.- We were at cruise at 70MPH and the SNJ smoked past us > like we were tied down ;o)- Sun was on our port side and illuminated > his broadside in our view, so itlit up the SNJ in a picture-perfect > way our wing.- I got some pix of it on the ground, but not in the air, > doggone it. >- > I love flying this airplane, even if I did notice that yet another > of the cooling eyebrow mounting tabs has now fatigued clear through. > Sigh.- I replace about one every 6 months... > > Oscar Zuniga > Air Camper NX41CC "Scout" > San Antonio, TX > website at http://www.flysquirrel.net- - - - - - - - - - - - - - - - - - - - - - --- > le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Dec 05, 2010
I have friends in Salt Lake City who are scratch building an LSA, and they had some special needs on the airplane. I think they ended up building at least 3 mock fuselages to be able to get everything to be workable on space in the cabin, and accessibility. My wife didn't understand why they would need a mock fuselage at all, much less multiples. Sitting down and measuring what you think you need sounds like it should work, however, getting in and out of, and sitting in something exactly like you are building works better. Use cheap lumber, but not so cheap it breaks! :? I am thinking I may build a few ribs for pracitce before I start using the good stuff. -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322340#322340 ________________________________________________________________________________
Date: Dec 05, 2010
Excellent Tucker. Good job! :D -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322341#322341 ________________________________________________________________________________
Subject: mock fuselage
Date: Dec 05, 2010
What's really good about building a mock fuselage is that it can be put together very quickly and easily, doesn't require a lot of precise fitting, but gives tremendous seat-of-the-pants feedback. Very rewarding. You can use any scrap materials laying around the garage or hangar, doesn't have to be aircraft grade. Gussets can be 1/4" or 3/16" plywood, lumber can be from packing crates or wood pallets, you can shoot it all together with an air stapler without fussing about the joints or worrying about weight. The instrument boards don't have to be perfectly shaped or sanded, nothing needs to be exact... build it to the nearest 1/16" tick mark on your measuring tape and get some Elmer's yellow glue or Gorilla Glue (an excellent use for it!) and wham it together in a weekend. >From there, it becomes a very useful tool for fitting a whole host of things without having to permanently change or make holes in your "real" fuselage. You can easily try out changes in geometry, controls, instruments, or anything else. Drill multiple sets of holes as you adjust the location of controls or fittings or mounts- it won't matter because it was never intended to be airworthy. But best of all, you can sit in it and so can your friends, family, or visitors- and get an instant feel for what it's like in the real airplane. In fact, if you wanted to, you could build it on sawhorses in the 3-point configuration or in level cruise configuration (or, if you're clever, you can mount the front on pins or dowels that allow the mock-up to rotate from one position to the other), using an old broomhandle or piece of conduit as a pivot and having two different mounting points at the aft sawhorse. That way, you can do all sorts of other things like checking how things sit using different wheels or landing gear. Yes, you can even throw a coat of paint on it ;o) Pull out that old half-gallon of paint that's getting hard in the garage... whatever color it happens to be. That way, it can be put outdoors out of the way if you don't have room for it in your shop. If you have kids, it is absolutely the best plaything they will have around, and it will give them an introduction to the cockpit without any worry about breaking anything. Go one step further? Set that old orphaned big-screen TV in front of it and pop in Mike Cuy's DVD flying scenes ;o) Walmart sells a super-dependable little Magnavox DVD player for $29 that will play even the most scratched DVDs. I think you could rig a smoke system, too... Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Dec 05, 2010
Subject: Re: mock fuselage
The mock fuse helped me figure out the plans in 3D space and make several mistakes before I started cutting and gluing the expensive wood. And a great landing gear/welding jig. (And its been a lot of fun at parties having friends and family sit in and take stupid pictures). rick On Sun, Dec 5, 2010 at 9:29 AM, Oscar Zuniga wrote: > > > What's really good about building a mock fuselage is that > it can be put together very quickly and easily, doesn't > require a lot of precise fitting, but gives tremendous > seat-of-the-pants feedback. Very rewarding. You can use > any scrap materials laying around the garage or hangar, > doesn't have to be aircraft grade. Gussets can be 1/4" or > 3/16" plywood, lumber can be from packing crates or wood > pallets, you can shoot it all together with an air > stapler without fussing about the joints or worrying about > weight. The instrument boards don't have to be perfectly > shaped or sanded, nothing needs to be exact... build it > to the nearest 1/16" tick mark on your measuring tape and > get some Elmer's yellow glue or Gorilla Glue (an excellent > use for it!) and wham it together in a weekend. > > >From there, it becomes a very useful tool for fitting a > whole host of things without having to permanently change > or make holes in your "real" fuselage. You can easily > try out changes in geometry, controls, instruments, or > anything else. Drill multiple sets of holes as you > adjust the location of controls or fittings or mounts- it > won't matter because it was never intended to be airworthy. > But best of all, you can sit in it and so > can your friends, family, or visitors- and get an instant > feel for what it's like in the real airplane. In fact, if > you wanted to, you could build it on sawhorses in the > 3-point configuration or in level cruise configuration (or, > if you're clever, you can mount the front on pins or > dowels that allow the mock-up to rotate from one position > to the other), using an old broomhandle or piece of conduit > as a pivot and having two different mounting points at the > aft sawhorse. That way, you can do all sorts of other things > like checking how things sit using different wheels or > landing gear. > > Yes, you can even throw a coat of paint on it ;o) Pull out > that old half-gallon of paint that's getting hard in the > garage... whatever color it happens to be. That way, > it can be put outdoors out of the way if you don't have room > for it in your shop. If you have kids, it is absolutely the > best plaything they will have around, and it will give them > an introduction to the cockpit without any worry about breaking > anything. > > Go one step further? Set that old orphaned big-screen TV in > front of it and pop in Mike Cuy's DVD flying scenes ;o) Walmart > sells a super-dependable little Magnavox DVD player for $29 > that will play even the most scratched DVDs. I think you could > rig a smoke system, too... > > Oscar Zuniga > Air Camper NX41CC "Scout" > San Antonio, TX > website at http://www.flysquirrel.net > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 05, 2010
Subject: Slave to fashion
The wife needs to know what I need for Christmas and being a slave to fashion that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of helmet? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 05, 2010
Hi Rick, I bought a fairly high-dollar leather helmet with headset built in that I've been very happy with. It's pricey (nearly $400) but when you consider that the price includes a headset, it's pretty reasonable. I've had a lot of comments from people I've talked with over the radio that said they would never have believed I was in an open cockpit. It's that good. Here's the link: http://www.gibson-barnes.com/Communications+Helmet/id/18/cat_id/23/prod_id/1 61/ They also make flying helmets, both leather and cloth, without comm capability. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Sunday, December 05, 2010 7:24 PM Subject: Pietenpol-List: Slave to fashion The wife needs to know what I need for Christmas and being a slave to fashion that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of helmet? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
From: "Scott Knowlton " <flyingscott_k(at)hotmail.com>
Date: Dec 06, 2010
Subject: Re: Slave to fashion
There was a great Australian company at Oshkosh a few years ago with a fantastic leather helmet with an interior shell made of kevlar. Probably not protective in a bad crash but at least better then leather as armour for the noggin. They were meant to be used with a David Clark or similar headseat. I'm sure you'll find them If you google. Good luck. Scott Knowlton Slow builder in Burlington -----Original Message----- From: Rick Holland <at7000ft(at)gmail.com> Date: Mon, 6 Dec 2010 00:23:52 Subject: Pietenpol-List: Slave to fashion The wife needs to know what I need for Christmas and being a slave to fashion that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of helmet? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 05, 2010
Hi Rick I bought a Aircraft Spruce leather helmet with fleece ling. It is ver comfortable. I have their 2008-09 cataloug, it is on page 571 model 711L. For glasses, I went to a Harley Davidson dealer. They have some nice sets of goggles. Dick N. ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Sunday, December 05, 2010 6:23 PM Subject: Pietenpol-List: Slave to fashion The wife needs to know what I need for Christmas and being a slave to fashion that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of helmet? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 05, 2010
Rick - I bought a cheap canvas rig from aircraft spruce. Was made for dave clark but i put my brand in (lightspeed). Not fancy, not warm, but it works. I use ski goggles for eye protection. There are more aesthetic options out there. Those of you who I've had the pleasure of meeting in person know that I cannot be accused of being a slave to fashion. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322411#322411 ________________________________________________________________________________
Subject: Ford Radiators
Date: Dec 05, 2010
I have tried several radiators and found that the more efficient they are the more pump presser is required, such as the vertical tubed type requires nothing more than a boost to thermo siphon , Water movement in a 100 % efficient cross flow type requires a pump impeller that is at least 2 " Diameter an turns 2 times engine speed, The leak-less type has an axial flow vane type impeller that is around one inch Dia. on a half inch shaft. in order to double the flow and eliminate cavitation one must extend the shaft 6.5 " and locate the vane impeller close to the pump outlet. This type of pump has 2 sealed ball bearings with spacers between, One setscrew is used. If two setscrews are used my test pump started to leak. I will keep you all posted on the performance of a 10 " high cross flow as today at 25 Degree the chill factor was a bit to much.But take-off was very surprising. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322413#322413 ________________________________________________________________________________
Date: Dec 05, 2010
Hey Kevin... how do your Lightspeeds work in the open cockpit? I've got a pair of Zulus that I would like to use, but some have told me that ANR headsets are crap in open environment... true or no? -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322414#322414 ________________________________________________________________________________
Date: Dec 05, 2010
Hi Mark - They're not active noise canceling - just regular headsets. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322420#322420 ________________________________________________________________________________
Date: Dec 05, 2010
http://www.garciaaviation.com/cgi-local/storepro5/agora.cgi? Helmets, goggles and silk scarves, me lads, helmets, goggles and scarves........... :-) Clif "I had a pilots breakfast. A coffee and a piss, a donut and a dump." > > > Hi Mark - They're not active noise canceling - just regular headsets. ________________________________________________________________________________
Date: Dec 06, 2010
http://www.flying-jacket.com/product-details.aspx?id=13 Rick,these ones are really nice.By the way,was good visiting yesterday,your planes is looking beautiful.Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322435#322435 ________________________________________________________________________________
Date: Dec 06, 2010
http://www.campbellaeroclassics.com/ -------- Scotty Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322436#322436 ________________________________________________________________________________
Subject: Dash pix
Date: Dec 06, 2010
Howdy,Heres the 95% done dash,dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322437#322437 Attachments: http://forums.matronics.com//files/2010_12_05_14_03_52_900_web_162.jpg ________________________________________________________________________________
Date: Dec 06, 2010
Rick, I recommend Pop's Leather, popsleather.com. I ran into them at Oshkosh a f ew years ago. Very cheap and excellent quality. Dan Helsper Poplar Grove, IL. -----Original Message----- From: Rick Holland <at7000ft(at)gmail.com> Sent: Sun, Dec 5, 2010 6:27 pm Subject: Pietenpol-List: Slave to fashion The wife needs to know what I need for Christmas and being a slave to fashi on that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of hel met? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: - -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Date: Dec 06, 2010
Rick, I use a fabric welding hat that is lined and also covers the back of my neck. It works very well with my lightspeed earphones. Gardiner ----- Original Message ---- From: kevinpurtee <kevin.purtee(at)us.army.mil> Sent: Sun, December 5, 2010 10:24:26 PM Subject: Pietenpol-List: Re: Slave to fashion Rick - I bought a cheap canvas rig from aircraft spruce. Was made for dave clark but i put my brand in (lightspeed). Not fancy, not warm, but it works. I use ski goggles for eye protection. There are more aesthetic options out there. Those of you who I've had the pleasure of meeting in person know that I cannot be accused of being a slave to fashion. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322411#322411 ________________________________________________________________________________
Date: Dec 06, 2010
Scott wrote- >There was a great Australian company at Oshkosh a few years ago >with a fantastic leather helmet with an interior shell made of >kevlar. Probably not protective in a bad crash but at least better >then leather as armour for the noggin. They were meant to be used >with a David Clark or similar headseat. I'm sure you'll find them >If you google. Good luck. The company is actually from New Zealand (Kiwis, not Aussies), and their product is extremely nice. Also quite pricey. I sent for their info pack and can vouch for the very, very nice product and details and if I had the money, I would certainly buy one of their helmets. I can tell you that the cost of a good ANR headset is completely lost in the cost of their helmets, though... in the FOUR figures, if I remember the brochure pricing. I have the brochure if anyone is interested. My day-to-day flying helmet is a Navy carrier flight deck crew helmet that I got on eBay, complete with goggles and David Clark hearing protectors, for less than $50. Ordinary headsets fit right in the same earcups (like my Pacific Avionics headset)- but since I'm usually NORDO, I only use the hearing protectors. Here's a pic. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322448#322448 Attachments: http://forums.matronics.com//files/oz_piet_125.jpg ________________________________________________________________________________
Date: Dec 06, 2010
Rick, My wife has the same plan for me and I pointed her to Aircraft Spruce. Their stuff is always good and easy to return if necessary. Plus the prices are reasonable and shipping is fast. Also a Google search will turn up all kinds of stuff if you just want to browse. If you want something unique, follow this link. http://www.etsy.com/listing/59673002/tank-girl-leather-flying-helmet Jeff Wilson --- On Sun, 12/5/10, Rick Holland wrote: From: Rick Holland <at7000ft(at)gmail.com> Subject: Pietenpol-List: Slave to fashion Date: Sunday, December 5, 2010, 6:23 PM The wife needs to know what I need for Christmas and being a slave to fashion that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of helmet? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Mitsubishi Engine ready to get installed...
Date: Dec 06, 2010
If you wan to see one of the dyno pulls, go here and watch it. It made 87hp at 3000rpm, but its needs some more tuning. it feels like there is allot more left. We are having some issues with the marvin schebler carb (MA3SPA), it needs to be jetted a little leaner, are there different jets available for that carb? i am coming up with nothing. http://www.youtube.com/watch?v=IYW8tQ4TSBg Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322476#322476 ________________________________________________________________________________
Date: Dec 06, 2010
Thanks for the info Jack, hadn't thought about a helmet with a built-in headset (which I also need). One other question about headsets, with a straight-out exhaust and open cockpit is an ANR type headset a necessity? O r just nice to have? I read Mike C's recommendation for the Flightcom ANR and they seem to be one of the more reasonable models. rick On Sun, Dec 5, 2010 at 5:34 PM, Jack Phillips wrote : > Hi Rick, > > > I bought a fairly high-dollar leather helmet with headset built in that > I=92ve been very happy with. It=92s pricey (nearly $400) but when you co nsider > that the price includes a headset, it=92s pretty reasonable. I=92ve had a lot > of comments from people I=92ve talked with over the radio that said they would > never have believed I was in an open cockpit. It=92s that good. > > > Here=92s the link: > http://www.gibson-barnes.com/Communications+Helmet/id/18/cat_id/23/prod_i d/161/ > > > They also make flying helmets, both leather and cloth, without comm > capability. > > > Jack Phillips > > NX899JP > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Rick Holland > *Sent:* Sunday, December 05, 2010 7:24 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: Slave to fashion > > > The wife needs to know what I need for Christmas and being a slave to > fashion that I am (like most of my fellow Piet builders), I figure I have to > get one of those cool leather flying helmets/goggles before I can ever ma ke > my first flight. So can anyone recommend a good website/brand that you li ke? > Also if you are going to use headphones do you need a different type of > helmet? > > thanks > > rick > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > > * * > > * * > > ** > > ** > > ** > > ** > > *www.buildersbooks.com* > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > * > =========== =========== =========== ============* > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 06, 2010
Sounds great! Mostly stock? Or some mods? Did you ever find a good source for the forklift engine without the balance shaft? And what can you tell us about the bearing you've added? Ken On Mon, Dec 6, 2010 at 10:49 AM, Chris Rusch wrote: > > > > If you wan to see one of the dyno pulls, go here and watch it. > It made 87hp at 3000rpm, but its needs some more tuning. it feels like > there is allot more left. > We are having some issues with the marvin schebler carb (MA3SPA), it needs > to be jetted a little leaner, are there different jets available for that > carb? i am coming up with nothing. > > > http://www.youtube.com/watch?v=IYW8tQ4TSBg > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322476#322476 > > -- Ken Chambers 512-796-1798 ________________________________________________________________________________
Date: Dec 06, 2010
Here is a good shot of my bearing housing, it uses 2 timken bearings. The engine is basically stock except for forged pistons, stainless valves and a mild porting job. i also used studs for the main bearing and the head. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322490#322490 Attachments: http://forums.matronics.com//files/img_0942_201.jpg ________________________________________________________________________________
Date: Dec 06, 2010
How did you decide that a bearing housing was necessary? Looks like a great idea, but I thought the forged crank and beefy mains on that engine would handle the prop loads. On Mon, Dec 6, 2010 at 12:48 PM, Chris Rusch wrote: > > > > Here is a good shot of my bearing housing, it uses 2 timken bearings. > The engine is basically stock except for forged pistons, stainless valves > and a mild porting job. i also used studs for the main bearing and the head. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322490#322490 > > > Attachments: > > http://forums.matronics.com//files/img_0942_201.jpg > > -- Ken Chambers 512-796-1798 ________________________________________________________________________________
Date: Dec 06, 2010
I don't have ANR in mine, and it works fine. ANR would be nice, but it costs more. Here's a picture so you can see what it looks like. Karen and I are each wearing one. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, December 06, 2010 12:08 PM Subject: Re: Pietenpol-List: Slave to fashion Thanks for the info Jack, hadn't thought about a helmet with a built-in headset (which I also need). One other question about headsets, with a straight-out exhaust and open cockpit is an ANR type headset a necessity? Or just nice to have? I read Mike C's recommendation for the Flightcom ANR and they seem to be one of the more reasonable models. rick On Sun, Dec 5, 2010 at 5:34 PM, Jack Phillips wrote: Hi Rick, I bought a fairly high-dollar leather helmet with headset built in that I've been very happy with. It's pricey (nearly $400) but when you consider that the price includes a headset, it's pretty reasonable. I've had a lot of comments from people I've talked with over the radio that said they would never have believed I was in an open cockpit. It's that good. Here's the link: http://www.gibson-barnes.com/Communications+Helmet/id/18/cat_id/23/prod_id/1 61/ They also make flying helmets, both leather and cloth, without comm capability. Jack Phillips NX899JP Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Sunday, December 05, 2010 7:24 PM Subject: Pietenpol-List: Slave to fashion The wife needs to know what I need for Christmas and being a slave to fashion that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of helmet? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" www.buildersbooks.com <http://www.matronics.com/Navigator?Pietenpol-List> http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 06, 2010
Prescription goggles: http://www.prescriptiongoggles.com/ Leather helmet: www.Ebay.com Go Nordo to keep things simple. Greg C. ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Sunday, December 05, 2010 6:23 PM Subject: Pietenpol-List: Slave to fashion The wife needs to know what I need for Christmas and being a slave to fashion that I am (like most of my fellow Piet builders), I figure I have to get one of those cool leather flying helmets/goggles before I can ever make my first flight. So can anyone recommend a good website/brand that you like? Also if you are going to use headphones do you need a different type of helmet? thanks rick -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Dash pix
Date: Dec 06, 2010
Jack,PANEL sounds to much like glass...a highly repulsive addition to my 30 year passion.I will stick with Steam Dash.dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322534#322534 ________________________________________________________________________________
Date: Dec 06, 2010
Subject: Re: Mitsubishi Engine ready to get installed.2..
hey Kent your engine look like almost ford model A these is whater cooler too and like to now howmany horse power have if cand sen resourses to get one and con vertion I thinken about options tanks and good look jorge fro hanford --- On Mon, 12/6/10, Ken Chambers wrote: From: Ken Chambers <ken.riffic(at)gmail.com> Subject: Re: Pietenpol-List: Re: Mitsubishi Engine ready to get installed... Date: Monday, December 6, 2010, 11:40 AM How did you decide that a bearing housing was necessary? Looks like a great idea, but I thought the forged crank and beefy mains on that engine would handle the prop loads. On Mon, Dec 6, 2010 at 12:48 PM, Chris Rusch wrote: Here is a good shot of my bearing housing, it uses 2 timken bearings. The engine is basically stock except for forged pistons, stainless valves and a mild porting job. i also used studs for the main bearing and the head. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322490#322490 Attachments: http://forums.matronics.com//files/img_0942_201.jpg ========== ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com ="_blank">http://www.matronics.com/contribution le, List Admin. ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== -- Ken Chambers 512-796-1798 ________________________________________________________________________________
From: Matthew VanDervort <matthew.vandervort(at)gmail.com>
Date: Dec 06, 2010
Looks good! I gotta ask, cabin heat? How do ya have that plumbed? Sent from my iPhone On Dec 6, 2010, at 7:24 AM, "Dangerous Dave" wrote: > > Howdy,Heres the 95% done dash,dave > > -------- > Covering Piet > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322437#322437 > > > > > Attachments: > > http://forums.matronics.com//files/2010_12_05_14_03_52_900_web_162.jpg > > > > > > > ________________________________________________________________________________
Subject: Horizontal flow Radiator
Date: Dec 06, 2010
With a radiator only 10" high gives more lifting space on the center wing section and using a horizontal flow, high efficiency design by the Brodhead radiator people allows a much smaller cooling system. So far it has excellent possibilities, What would be an objection, other than Bernie's half A radiator doesn't look the same.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322549#322549 Attachments: http://forums.matronics.com//files/radiator_close_up_108.jpg ________________________________________________________________________________
Date: Dec 07, 2010
Howdy,On the cabin heat.I am fabing aluminum covers that go from the side of the front seat to the fuselage,rounded on top so as theres room for my rudder pedals and feet with the front capped of with an aluminum plate with a 2" stub at the bottom.I'm running 2" flex back from the firewall to a Y and 2" flex to each side.Should keep at least the lower half of me toasty.Will post some pics when I'm done with it,Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322567#322567 ________________________________________________________________________________
Subject: Re: FOR SALE - Pietenpol Air Camper Builders Manual &
Sup P
Date: Dec 07, 2010
I'll take the Corvair supplement. Am at airport, please send me your contact info and I'll get payment to yuo -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322568#322568 ________________________________________________________________________________
Subject: Image Size
Date: Dec 07, 2010
Hello, I do not know what you think about, but in few years the cameras are going to have too many Megapixels. If the images posted here are in the original format we will need a very very big monito, today is very difficult see the images here, and one have to go from left to right to see them and read the post... Why dont put them just 800x600 as max size and a link to the original?.. I think it will be more comfortable follow a topic. just an opinion. regards Mario Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322570#322570 ________________________________________________________________________________
Subject: Re: Image Size
Date: Dec 07, 2010
Image resizers are free online. I use JPeg Resizer. Get it free at: http://www.brothersoft.com/jpeg-resizer-3357.html An image 700 pixels wide is perfect for the forum. When you reduce the size of the image, you also reduce the size of the file drastically making it upload faster. -------- Al Rice Skybolt 260 RV-9A Helping with my grandson's Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322573#322573 ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Subject: Jury strut attachment
Date: Dec 07, 2010
Good People, I'm fabricating my jury strut attachment for the spar ala Mike Cuy and Jack Phillips. I was wondering what size bolts everyone has used to hold the fitting to the spar. The Grega plans, which appear to be a copy of the Baby Ace design, uses AN4's. The attachment to the lift strut is only an AN3. It looks to me that AN4's through the spar is overkill, not to mention weakening the spar even more. Rick Schreiber ________________________________________________________________________________
Subject: Outside My Window - Need Skis
Date: Dec 07, 2010
Where did summer go? Seems like just a few days ago we were being rained upon at Brathead. I just snapped this outside my office. If anyone has a line on Federal 1500 skis let me know. Looking for a set for the Cub. "That all you going to do with your life, cash for rides?" -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com ________________________________________________________________________________
Subject: Re: Jury strut attachment
Date: Dec 07, 2010
Rick AN 3 is enough, the jury strut is only to avoid a harmonic and flexing in t he main strut. There should hardly be any load on it. Do make sure that the jury strut is not centered on the main strut but a fe w inches off to one site. Hans NX 15KV -----Original Message----- From: Richard Schreiber <lmforge(at)earthlink.net> Sent: Tue, Dec 7, 2010 12:40 pm Subject: Pietenpol-List: Jury strut attachment Good People, I'm fabricating my jury strut attachment for the spar ala Mike Cuy and Jack Phillips. I was wondering what size bolts everyone has used to hold the fi tting to the spar. The Grega plans, which appear to be a copy of the Baby A ce design, uses AN4's. The attachment to the lift strut is only an AN3. It looks to me that AN4's through the spar is overkill, not to mention weakeni ng the spar even more. Rick Schreiber - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Subject: radiator size
Date: Dec 07, 2010
How big or small are the radiators that you for guys are using...? they all look pretty narrow.. just a bit wider than the engine head.. and the space between the wing and cowl is pretty short. thanks in advance jeff ribs done fuselage 90% looking forward to the gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322632#322632 ________________________________________________________________________________
Date: Dec 07, 2010
I used AN3's Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Richard Schreiber Sent: Tuesday, December 07, 2010 1:38 PM Subject: Pietenpol-List: Jury strut attachment Good People, I'm fabricating my jury strut attachment for the spar ala Mike Cuy and Jack Phillips. I was wondering what size bolts everyone has used to hold the fitting to the spar. The Grega plans, which appear to be a copy of the Baby Ace design, uses AN4's. The attachment to the lift strut is only an AN3. It looks to me that AN4's through the spar is overkill, not to mention weakening the spar even more. Rick Schreiber ________________________________________________________________________________
Date: Dec 08, 2010
Subject: Cheer up the winter blues.
From: Gerry Holland <gholland@content-stream.co.uk>
Hi! Take a look at this from Corben group this morning. A very nice Pietenpol in some shots. Regards Gerry http://www.youtube.com/watch?v=76aH_04T7cc ________________________________________________________________________________
Subject: Re: radiator size
Date: Dec 08, 2010
Jeff, The radiator I have is one of the last batch from Forest Lovely (sp?). It measures 19-3/4" high (not including neck) x 12" wide. Dan Helsper Poplar Grove, IL. -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Tue, Dec 7, 2010 7:14 pm Subject: Pietenpol-List: radiator size > How big or small are the radiators that you for guys are using...? hey all look pretty narrow.. just a bit wider than the engine head.. nd the space between the wing and cowl is pretty short. hanks in advance eff ribs done uselage 90% ooking forward to the gear ead this topic online here: http://forums.matronics.com/viewtopic.php?p=322632#322632 - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Sup P
Date: Dec 08, 2010
If you still have the manual, send me your contact info, and how you want to get paid, and I'll take them. I can send a check, or do PayPal if you can take PayPal. Send the information to glidermikeg at yahoo dot com I've started the preparations for building ribs, and have the rib drawings. Ordering wood next Monday. -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322651#322651 ________________________________________________________________________________
Sup P
Date: Dec 08, 2010
Thanks Craig. I'm one more step closer to being finished. 0.01 % complete, 150% to go! [Rolling Eyes] -------- HOMEBUILDER Will WORK for Spruce Long flights, smooth air, and soft landings, GliderMike, aka Mike Glasgow Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322655#322655 ________________________________________________________________________________
Subject: Re: Outside My Window - Need Skis
Date: Dec 08, 2010
We've got a few inches on the ground. Maybe more on the way over the next couple of days. Skis going on the Piet tonight. :D Don Emch NX899DE P.S. John, it seems like I just saw a set of Federals on Barnstormers. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322657#322657 ________________________________________________________________________________
Date: Dec 08, 2010
thanks Dan.. as much as i love the Brass i may be thinking aluminum i was looking at my motorcycle the other day and it hit me... a lot of bikes are water cooled including my vtx..there may be a ready made bike radiator that would work jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322667#322667 ________________________________________________________________________________
Date: Dec 08, 2010
Subject: RE: Jury Strut Attach
I used two AN3 bolts through the U fitting I made and the spar. Should be more than adequate. Matt Paxton From: "Richard Schreiber" <lmforge(at)earthlink.net> Subject: Pietenpol-List: Jury strut attachment Good People, I'm fabricating my jury strut attachment for the spar ala Mike Cuy and Jack Phillips. I was wondering what size bolts everyone has used to hold the fitting to the spar. The Grega plans, which appear to be a copy of the Baby Ace design, uses AN4's. The attachment to the lift strut is only an AN3. It looks to me that AN4's through the spar is overkill, not to mention weakening the spar even more. Rick Schreiber ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Dec 08, 2010
Subject: jury strut attach idea I saw on Will Graff's Pietenpol
And copied it. Sketch attached. Works well, was easy to fabricate. Mike C. [cid:image001.jpg(at)01CB96C0.F22CA350] rsbooks.com> m> ________________________________________________________________________________
Date: Dec 08, 2010
Mike, Thats the design I plan on using. I plan on working on the cowling from the firewall rearward this month. I only want to pay shipping once, so I hope that a full 4x12 ft sheet will be enough to do the cockpits and the engine cowl. I'm using .025 2024T3. I saw Jim Hacklin and his Piet a couple of days ago. I am sure he will be flying this spring. He has just about finished his Corvair. I think all he has left to do is install the carb and then cowl the engine. The day I saw him we were due to get about 10 inches of lake effect snow. Our conversation naturally gravitated to open cockpit flying in the winter and how much we would actually do it. If I had skis like Don, I might be more inclined to do it. Rick Schreiber ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] Sent: 12/8/2010 9:29:51 AM Subject: Pietenpol-List: jury strut attach idea I saw on Will Graff's Pietenpol And copied it. Sketch attached. Works well, was easy to fabricate. Mike C. n link below to find out more about www.buildersbooks.com <http://www.matronics.com/Navigator?Pietenpol-List - MATRONICS WEB FORUMS - ________________________________________________________________________________
Subject: winter weather
Date: Dec 08, 2010
Hey John Check this out. Dick N. ________________________________________________________________________________
Subject: Re: jury strut attach idea I saw on Will Graff's Pietenpol
Date: Dec 08, 2010
Not to get too picky, but didn't Will Graff's Air Camper (N1492G) have wooden lift struts and jury struts? http://westcoastpiet.com/images/Will%20Graff/pictures.htm Just wondering what kind of filler rod would be recommended for welding steel to wood. :) Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322694#322694 ________________________________________________________________________________
Date: Dec 08, 2010
Subject: Q: Charlie Rubeck's Piet
Guys, A number of years ago when I lived in Bloomington, Indiana, I got to know Charlie Rubeck. He was very helpful to me when I was in the early stages of my project. My understanding is that he died awhile back. I'm wondering whatever became of his Pietenpol. Do anyone of you know? He took me to see it on one my visits to his home outside Spencer, Indiana. It had been rebuilt after the accident when he inadvertantly stall/spun it in. Though it appeared it had been hangared for a number of years with little or no flying, it was really quite a nice airplane. I wonder who, if anyone, now owns it. Cheers, Ken ________________________________________________________________________________
Date: Dec 08, 2010
Subject: Front seat back
Pieters.... -The v-brace supports for the front seat back....are they on the back sid e of the front-seat facing the pilot or are they on the front side of the seat back facing the engine? - I am understanding the plans to say the v-brace go on the front side of the front seat back... - Correct? - KMHeide=0A=0A=0A ________________________________________________________________________________
Date: Dec 08, 2010
Correct. The V-brace go on the front of the font seat. I put mine on the back like a bunch of other people have done but they will interfere with mounting the center strut lower fittings. Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Wednesday, December 08, 2010 9:30 PM Subject: Pietenpol-List: Front seat back Pieters.... The v-brace supports for the front seat back....are they on the back side of the front seat facing the pilot or are they on the front side of the seat back facing the engine? I am understanding the plans to say the v-brace go on the front side of the front seat back... Correct? KMHeide ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Subject: Re: Front seat back
Date: Dec 09, 2010
----- Original Message ----- From: KM Heide CPO/FAAOP To: Pietenpol Sent: Thursday, December 09, 2010 12:30 AM Subject: Pietenpol-List: Front seat back Pieters.... The v-brace supports for the front seat back....are they on the back side of the front seat facing the pilot or are they on the front side of the seat back facing the engine? I am understanding the plans to say the v-brace go on the front side of the front seat back... Correct? KMHeide ________________________________________________________________________________
Subject: T-88 On Sale
Date: Dec 09, 2010
www.grizzly.com 800-523-4777, H9698 pint kit, $14.95. It's in a special catalog, pricing code CLRFLY 2010. Normally $25 at AC Spruce. I've been very happy with Grizzly products, especially my new 2HP mill Jack DSM www.textors.com ________________________________________________________________________________
Date: Dec 09, 2010
Sorry about that. I must have hit the 'reply' button by mistake. Incidentally, I'm going to put the braces on the back of the seat and move the attachments for the cabane struts back about an inch to clear the braces I think that will also help in the weight and balance problem of having the plane too tail heavy. Chuck ----- Original Message ----- From: Charles Campbell To: pietenpol-list(at)matronics.com Sent: Thursday, December 09, 2010 6:47 AM Subject: Re: Pietenpol-List: Front seat back ----- Original Message ----- From: KM Heide CPO/FAAOP To: Pietenpol Sent: Thursday, December 09, 2010 12:30 AM Subject: Pietenpol-List: Front seat back Pieters.... The v-brace supports for the front seat back....are they on the back side of the front seat facing the pilot or are they on the front side of the seat back facing the engine? I am understanding the plans to say the v-brace go on the front side of the front seat back... Correct? KMHeide href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Piet logo
Date: Dec 09, 2010
Does anyone know the originator of the logo in the picture I've attached? I'd like to give them proper credit for my use of it. I've always liked the logo and when I saw a discarded piece of plywood, in my mind the logo fit the plywood perfectly so I plotted the logo out the size of the wood, cut out the pieces and outlined them onto it with a pencil, and used a couple of leftover paints to paint it. Took me a couple of enjoyable evenings in the garage with some good blues music playing. Just something to decorate our hangar. The original logo uses different colors than my "artwork"... I just used what I had (antique white cabinet enamel, satin black latex house paint, and 'ripe avocado' flat latex). Original logo also attached. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322735#322735 Attachments: http://forums.matronics.com//files/96tee_200.gif http://forums.matronics.com//files/p1010027_125.jpg ________________________________________________________________________________
Subject: Piet logo
Date: Dec 09, 2010
Hey Oscar, I think it is Grant Maclaren. That logo was on a T-shirt he sold at Brodhead a couple of years. I think it was also on the BPA newsletter while he was editor. Skip > > > Does anyone know the originator of the logo in the picture I've attached? I'd like to give them proper credit for my use of it. ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Subject: Re: Piet logo
Date: Dec 09, 2010
Oscar, Looks great! Gene in beautiful cold Tennessee Past caretaker of N502R -------------------------------------------------- From: "taildrags" <taildrags(at)hotmail.com> Sent: Thursday, December 09, 2010 8:11 AM Subject: Pietenpol-List: Piet logo > > Does anyone know the originator of the logo in the picture I've attached? > I'd like to give them proper credit for my use of it. I've always liked > the logo and when I saw a discarded piece of plywood, in my mind the logo > fit the plywood perfectly so I plotted the logo out the size of the wood, > cut out the pieces and outlined them onto it with a pencil, and used a > couple of leftover paints to paint it. Took me a couple of enjoyable > evenings in the garage with some good blues music playing. Just something > to decorate our hangar. > > The original logo uses different colors than my "artwork"... I just used > what I had (antique white cabinet enamel, satin black latex house paint, > and 'ripe avocado' flat latex). Original logo also attached. > > -------- > Oscar Zuniga > San Antonio, TX > Air Camper NX41CC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322735#322735 > > > Attachments: > > http://forums.matronics.com//files/96tee_200.gif > http://forums.matronics.com//files/p1010027_125.jpg > > > ________________________________________________________________________________
Subject: Christmas Miracle
Date: Dec 09, 2010
As many on this list know, Gene Pennington, who signs his posts as "Gene in Beautiful Tennessee", was diagnosed last spring with an incurable, aggressive form of cancer called leiomyosarcoma. He sold his Pietenpol to Ryan Mueller and I ferried it from Tennessee to Brodhead for Ryan, flying in formation with Randy Bush. I had not heard from Gene in several months so I gave him a call last week to see how he was doing. I did not get him, but left a message on his voicemail, and feared that his health was deteriorating. Yesterday he called me, and to my great surprise and delight, he sounded wonderful and strong. He told me that he had been so sick from his previous chemotherapy treatments that he had just about decided to stop the treatments and let the disease run its course (his initial prognosis from Vanderbilt Hospital last spring had given him 2 - 3 months to live). He went to see his Oncologist in Louisville, KY, who put him on a new chemo drug. Monday, he went back for a CT Scan and checkup and the doctor literally came jumping up and down in his office with the scan results. The tumors were shrinking! Bear in mind that this cancer is very rare, and has always been considered untreatable. Remission is not possible. Until now. Gene feels like he suddenly has a future again! He is already discussing the possibility of building a Pietenpol, and may make the trek to Brodhead this coming July. He flies every day the weather permits (he bought a Kolb Slingshot shortly after he sold his Pietenpol), and feels better than he has felt in months. I told him this was the best news I had received all year. Just wanted to pass this on to the best group of people on the internet. Merry Christmas! Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ________________________________________________________________________________
Subject: Re: Christmas Miracle
Date: Dec 09, 2010
He sounds like a cool guy so lets all send him a greeting since he is on a good health roll. Don in Ohio ________________________________________________________________________________
Date: Dec 09, 2010
I put mine on the back side where they don't get in the way of anything and make the front seat more comfortable. Jim do no archive ----- Original Message ----- From: "KM Heide CPO/FAAOP" <kmheidecpo(at)yahoo.com> Sent: Wednesday, December 8, 2010 9:30:16 PM Subject: Pietenpol-List: Front seat back Pieters.... The v-brace supports for the front seat back....are they on the back side of the frontseat facing the pilot or are they on the front side of the seat back facing the engine? I am understanding the plans to say the v-brace go on the front side of the front seat back... Correct? KMHeide ________________________________________________________________________________
Date: Dec 09, 2010
I sincerely believe that miracles do happen. Hang in there Gene!! =C2- Dan Helsper Poplar Grove, IL. -----Original Message----- From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Thu, Dec 9, 2010 10:35 am Subject: Pietenpol-List: Christmas Miracle As many on this list know, Gene Pennington, who signs his posts as =9CGene in Beautiful Tennessee=9D, was diagnosed last spring with an incurable, aggressive form of cancer called leiomyosarcoma.=C2- He sold h is Pietenpol to Ryan Mueller and I ferried it from Tennessee to Brodhead fo r Ryan, flying in formation with Randy Bush. I had not heard from Gene in several months so I gave him a call last week to see how he was doing.=C2- I did not get him, but left a message on his voicemail, and feared that his health was deteriorating. Yesterday he called me, and to my great surprise and delight, he sounded wo nderful and strong.=C2- He told me that he had been so sick from his prev ious chemotherapy treatments that he had just about decided to stop the tre atments and let the disease run its course (his initial prognosis from Vand erbilt Hospital last spring had given him 2 =93 3 months to live).=C2 - He went to see his Oncologist in Louisville, KY, who put him on a new c hemo drug.=C2- Monday, he went back for a CT Scan and checkup and the doc tor literally came jumping up and down in his office with the scan results. =C2- The tumors were shrinking!=C2- Bear in mind that this cancer is very rare, and has always been considered untreatable.=C2- Remission is not possible.=C2- Until now. Gene feels like he suddenly has a future again!=C2- He is already discuss ing the possibility of building a Pietenpol, and may make the trek to Brodh ead this coming July.=C2- He flies every day the weather permits (he boug ht a Kolb Slingshot shortly after he sold his Pietenpol), and feels better than he has felt in months.=C2- I told him this was the best news I had r eceived all year. Just wanted to pass this on to the best group of people on the internet.=C2 - Merry Christmas! Jack Phillips NX899JP =9CIcarus Plummet=9D Raleigh, NC ================== ________________________________________________________________________________
Date: Dec 09, 2010
Subject: Salute to the healing in Gene Pennington's body ! A
Christmas Miracle What fantastic news that is indeed Jack and I'm THRILLED to hear your repor t about how good Gene is doing in light of such a grave prognosis last spring. What a Merry Christmas this will be for Gene and his family. Time to kee p him in even more prayer that his tumors will continue to shrink and that he'll be healed of this disease. Mike C. ________________________________________________________________________________
Date: Dec 09, 2010
Ditto rick On Thu, Dec 9, 2010 at 10:40 AM, Jim Boyer wrote: > > I put mine on the back side where they don't get in the way of anything and > make the front seat more comfortable. > Jim > > do no archive > > > ----- Original Message ----- > From: "KM Heide CPO/FAAOP" <kmheidecpo(at)yahoo.com> > To: "Pietenpol" > Sent: Wednesday, December 8, 2010 9:30:16 PM > Subject: Pietenpol-List: Front seat back > > Pieters.... > > > The v-brace supports for the front seat back....are they on the back side > of the front seat facing the pilot or are they on the front side of the seat > back facing the engine? > > I am understanding the plans to say the v-brace go on the front side of the > front seat back... > > Correct? > > KMHeide > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 09, 2010
This is indeed good news and entirely appropriate for this Christmas season! GOD IS GOOD! Gene, your fight is not without purpose - you are an inspiration to us all. Because of your struggle Ryan and Jess have a beautiful new Pietenpol and I reaped the benefit of Ryan's Corvair project, plus got to make a very enjoyable trip to Chicago to pick it up and meet the Muellers. Jack P. was blessed with a memorable flight to deliver your Piet to Brodhead which produced several photos that grace desktops across the Matronics list. Lest it seem too maudlin - we are thinking of you and our prayers are with you. Tom Stinemetze McPherson, KS. >>> "Jack Phillips" 12/9/2010 10:31 AM >>> As many on this list know, Gene Pennington, who signs his posts as Gene in Beautiful Tennessee, was diagnosed last spring with an incurable, aggressive form of cancer called leiomyosarcoma. He sold his Pietenpol to Ryan Mueller and I ferried it from Tennessee to Brodhead for Ryan, flying in formation with Randy Bush. ________________________________________________________________________________
Date: Dec 09, 2010
Oscar, You can search "LOGO" and find some answers. Pretty sure there was an issue with this logo in that Grant WOULD NOT allow it's copy or use. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322773#322773 ________________________________________________________________________________
Date: Dec 09, 2010
God is Good. I am so proud for you Gene. I like the sound of that! I have a friend that got a similar prognosis with a brain tumor. It was inoperable so he got treatments. He is still living a good life after 10 or so years. You are in my prayers -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322774#322774 ________________________________________________________________________________
Date: Dec 09, 2010
The people and miracles and attitudes and friendliness and honor and selflessness.....of the people in this community just keeps shining beyond belief. I can't even imagine how wonderful Gene and his family must feel right now. What wonderful news. Really helps put life's "little" annoyances in perspective. JM -----Original Message----- From: Jack Phillips Sent: Dec 9, 2010 10:31 AM Subject: Pietenpol-List: Christmas Miracle As many on this list know, Gene Pennington, who signs his posts as Gene in Beautiful Tennessee, was diagnosed last spring with an incurable, aggressive form of cancer called leiomyosarcoma. He sold his Pietenpol to Ryan Mueller and I ferried it from Tennessee to Brodhead for Ryan, flying in formation with Randy Bush. I had not heard from Gene in several months so I gave him a call last week to see how he was doing. I did not get him, but left a message on his voicemail, and feared that his health was deteriorating. Yesterday he called me, and to my great surprise and delight, he sounded wonderful and strong. He told me that he had been so sick from his previous chemotherapy treatments that he had just about decided to stop the treatments and let the disease run its course (his initial prognosis from Vanderbilt Hospital last spring had given him 2 3 months to live). He went to see his Oncologist in Louisville, KY, who put him on a new chemo drug. Monday, he went back for a CT Scan and checkup and the doctor literally came jumping up and down in his office with the scan results. The tumors were shrinking! Bear in mind that this cancer is very rare, and has always been considered untreatable. Remission is not possible. Until now. Gene feels like he suddenly has a future again! He is already discussing the possibility of building a Pietenpol, and may make the trek to Brodhead this coming July. He flies every day the weather permits (he bought a Kolb Slingshot shortly after he sold his Pietenpol), and feels better than he has felt in months. I told him this was the best news I had received all year. Just wanted to pass this on to the best group of people on the internet. Merry Christmas! Jack Phillips NX899JP Icarus Plummet Raleigh, NC ________________________________________________________________________________
Date: Dec 09, 2010
Best news I have heard all year. Will be praying for your complete recovery Gene. rick On Thu, Dec 9, 2010 at 9:31 AM, Jack Phillips wrote : > As many on this list know, Gene Pennington, who signs his posts as =93Ge ne > in Beautiful Tennessee=94, was diagnosed last spring with an incurable, > aggressive form of cancer called leiomyosarcoma. He sold his Pietenpol t o > Ryan Mueller and I ferried it from Tennessee to Brodhead for Ryan, flying in > formation with Randy Bush > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Chistmas miracle
Date: Dec 09, 2010
My best friend's mother was diagnosed with breast cancer back in 1978. She had treatments and after awhile was told there was nothing more to do but p ray. Many people indeed did that- and she proceeded to live until 2009, die ing of old age!! God's ways are not our ways. Dan Helsper Poplar Grove, IL ________________________________________________________________________________
Subject: Corvair Donation
Date: Dec 09, 2010
Howdy,I have a corvair engine stripped down and bead blasted.All correct numbers and in good shape.I will donate it to a worthy kid building a Piet.It has not been built.Its Corvair parts to build it.William Wynne book never registered in mint condition.I will crate it up on my dime if you'll pay for it to be shipped.Know a worthy Kid? Must be a youngster under 21! Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322789#322789 ________________________________________________________________________________
Date: Dec 09, 2010
Gene, In addition to Tom, I also was the favorable recipient of parts that Ryan & Jess did not need after the purchase of your Piet. The carburetor that they had intended to use is now on my Corvair, which fired up for the first time (after 6 years) last October! I=99ll be at Brodhead in 2011 (by ground transportation), and expect to meet you then. Prayers for your continuing recovery, Gary Boothe From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of TOM STINEMETZE Sent: Thursday, December 09, 2010 11:02 AM Subject: Re: Pietenpol-List: Christmas Miracle This is indeed good news and entirely appropriate for this Christmas season! GOD IS GOOD! Gene, your fight is not without purpose - you are an inspiration to us all. Because of your struggle Ryan and Jess have a beautiful new Pietenpol and I reaped the benefit of Ryan's Corvair project, plus got to make a very enjoyable trip to Chicago to pick it up and meet the Muellers. Jack P. was blessed with a memorable flight to deliver your Piet to Brodhead which produced several photos that grace desktops across the Matronics list. Lest it seem too maudlin - we are thinking of you and our prayers are with you. Tom Stinemetze McPherson, KS. >>> "Jack Phillips" 12/9/2010 10:31 AM >>> As many on this list know, Gene Pennington, who signs his posts as =9CGene in Beautiful Tennessee=9D, was diagnosed last spring with an incurable, aggressive form of cancer called leiomyosarcoma. He sold his Pietenpol to Ryan Mueller and I ferried it from Tennessee to Brodhead for Ryan, flying in formation with Randy Bush. ________________________________________________________________________________
Date: Dec 10, 2010
Jim and Rick Yes it seems to be a point of confusion and that is the reason I asked. It clearly says 3/4"x3 filler for strut fitting on the long fuselage plans but if you move the fitting back your center struts (front and back) will no longer be parallel. Then if you swing your wing back to adjust the CG you will also change the angle of incidence. Not what we want. What we want is to keep them parallel. The important measurement is the 28.5" measurement which happens to be the center to center measurement of the wing spars and the distance between the verticals in the fuselage sides, which is where the plans show to attach the fitting. I think regardless of where the rear fitting is mounted, the front should be 28.5 inches away. I plan on putting the fitting on the filler block and measuring forward 28.5 and if needed install another filler block. In reality, I bet there are a bunch of Piets out there flying with the fittings in various locations. Anyone have a picture of the last original that shows this fitting (on the inside under the instrument panel)? All the pictures I have on the website do show this area. Chris Sacramento, Ca Westcoastpiet.com ________________________________________________________________________________
Date: Dec 10, 2010
Chris, that is what I intend to do -- move both the fittings back the same distance to keep the two cabane struts the same distance apart as the spars in the wing. Chuck ----- Original Message ----- From: Chris To: pietenpol-list(at)matronics.com Sent: Friday, December 10, 2010 3:16 AM Subject: RE: Pietenpol-List: Front seat back Jim and Rick Yes it seems to be a point of confusion and that is the reason I asked. It clearly says 3/4"x3 filler for strut fitting on the long fuselage plans but if you move the fitting back your center struts (front and back) will no longer be parallel. Then if you swing your wing back to adjust the CG you will also change the angle of incidence. Not what we want. What we want is to keep them parallel. The important measurement is the 28.5" measurement which happens to be the center to center measurement of the wing spars and the distance between the verticals in the fuselage sides, which is where the plans show to attach the fitting. I think regardless of where the rear fitting is mounted, the front should be 28.5 inches away. I plan on putting the fitting on the filler block and measuring forward 28.5 and if needed install another filler block. In reality, I bet there are a bunch of Piets out there flying with the fittings in various locations. Anyone have a picture of the last original that shows this fitting (on the inside under the instrument panel)? All the pictures I have on the website do show this area. Chris Sacramento, Ca Westcoastpiet.com ________________________________________________________________________________
Subject: Flying like a Peregrine Falcon
Date: Dec 10, 2010
The video in this link is about the fastest two birds on the planet... ENJOY! http://wimp.com/camerabirds/ -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322824#322824 ________________________________________________________________________________
Date: Dec 10, 2010
My sincere thanks to all for your best wishes and Prayers. Looking forward to seeing all of you at Broadhead 2011. Gene in Beautiful Tennessee ________________________________________________________________________________
Date: Dec 10, 2010
Gene, We are all elated that you are doing so much better. Keep up the good fight. Merry Christmas, Tim in central TX -----Original Message----- From: Gene & Tammy Sent: Dec 10, 2010 10:38 AM Subject: Re: Pietenpol-List: Christmas Miracle My sincere thanks to all for your best wishes and Prayers. Looking forward to seeing all of you at Broadhead 2011. Gene in Beautiful Tennessee ________________________________________________________________________________
Date: Dec 10, 2010
I've never had a passenger complain about the diagonals bothering them on the front of the seat back. I think they angle up to the longeron enough to not be a problem. One of the things about the Piet that adds character I guess. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322845#322845 ________________________________________________________________________________
Date: Dec 10, 2010
Subject: Re: Flying like a Peregrine Falcon
Wow, if reincarnation is true then I want to come back as one of those when I kick the bucket. Makes you think though if a Pietenpol was a bird what kind of bird would it be? Probably not a Falcon. rick On Fri, Dec 10, 2010 at 6:19 AM, tkreiner wrote: > > The video in this link is about the fastest two birds on the planet... > > ENJOY! > > http://wimp.com/camerabirds/ > > -------- > Tom Kreiner > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322824#322824 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 10, 2010
I have seen a few PBS shows on the Peregrine, but this video is awesome! Pr oblem is, now I have another mod that I want to do...variable geometry wing s.- Maybe I'll just tell myself doing so will just add weight and forget about it. - Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Dec 10, 2010
Chris, I don't have my cabane strut fittings in place yet, but I did notice this apparent oversight in the plans when I was putting my fuselage sides together. The filler block makes sense, since there will be interference between wood and metal at that location IF the cabane fittings are fastened to the vertical sticks. Therefore it makes sense to shift the fittings about an inch to the rear - hence the filler block. But as you noted, if a filler is only added at the rear fitting, the cabanes will not end up parallel. That's why I also put filler blocks in at the front attachment points as well. Notes and photos can be found here: http://mykitplane.com/Planes/buildLogReportDetail.cfm?BuildLogID=2535&PlaneID=510&FName=Bill&LName=Church&PlaneName=Air Camper Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=322880#322880 ________________________________________________________________________________
Date: Dec 10, 2010
God Bless You Gene, NOTHING can keep a good man down!=C2- It's up to the Man upstairs, and our will to get better, that keeps us strong.=C2- I wil l remember you in my prayers, and hope to meet you in Brodhead 2011. =C2- Shad --- On Thu, 12/9/10, Jack Phillips wrote: From: Jack Phillips <pietflyr(at)bellsouth.net> Subject: Pietenpol-List: Christmas Miracle Date: Thursday, December 9, 2010, 11:31 AM As many on this list know, Gene Pennington, who signs his posts as =9CGene in Beautiful Tennessee=9D, was diagnosed last spring with an incurable, aggressive form of cancer called leiomyosarcoma.=C2- He sold h is Pietenpol to Ryan Mueller and I ferried it from Tennessee to Brodhead fo r Ryan, flying in formation with Randy Bush. I had not heard from Gene in several months so I gave him a call last week to see how he was doing.=C2- I did not get him, but left a message on his voicemail, and feared that his health was deteriorating. Yesterday he called me, and to my great surprise and delight, he sounded wo nderful and strong.=C2- He told me that he had been so sick from his prev ious chemotherapy treatments that he had just about decided to stop the tre atments and let the disease run its course (his initial prognosis from Vand erbilt Hospital last spring had given him 2 =93 3 months to live).=C2 - He went to see his Oncologist in Louisville, KY, who put him on a new c hemo drug.=C2- Monday, he went back for a CT Scan and checkup and the doc tor literally came jumping up and down in his office with the scan results. =C2- The tumors were shrinking!=C2- Bear in mind that this cancer is very rare, and has always been considered untreatable.=C2- Remission is not possible.=C2- Until now. Gene feels like he suddenly has a future again!=C2- He is already discuss ing the possibility of building a Pietenpol, and may make the trek to Brodh ead this coming July.=C2- He flies every day the weather permits (he boug ht a Kolb Slingshot shortly after he sold his Pietenpol), and feels better than he has felt in months.=C2- I told him this was the best news I had r eceived all year. Just wanted to pass this on to the best group of people on the internet.=C2 - Merry Christmas! Jack Phillips NX899JP =9CIcarus Plummet=9D Raleigh, NC =0A=0A=0A ________________________________________________________________________________
Subject: Fw: Oh Holy Night -Celtic Woman
Date: Dec 11, 2010
FW: Oh Holy Night -Celtic WomanIf this doesn't get you in the REAL CHRISTmas spirit -- nothing will. MERRY CHRISTMAS everyone. Hope your's is as wonderful as the Lord can make it!!! Chuck Subject: Oh Holy Night -Celtic Woman Celtic Woman live from the Helix Center in Dublin, Ireland performing A Christmas Celebration. THIS IS JUST BEAUTIFUL!!!! Http://www.youtube.com/watch?v=sDeXUvWbLp8 <http://www.youtube.com/watch?v=sDeXUvWbLp8> Click here =EF=BB =EF=BB =EF=BB =EF=BB ------------------------------------------------------------------------- ------- Checked by AVG - www.avg.com <http://www.avg.com/> 07:34:00 ------ End of Forwarded Message ________________________________________________________________________________
Subject: Re: Corvair Donation
Date: Dec 11, 2010
Dave, if you can't find a kid under 21 how about an old man over 85? I'll take it in a heart beat! ----- Original Message ----- From: "Dangerous Dave" <dsornbor(at)aol.com> Sent: Thursday, December 09, 2010 7:17 PM Subject: Pietenpol-List: Corvair Donation > > Howdy,I have a corvair engine stripped down and bead blasted.All correct > numbers and in good shape.I will donate it to a worthy kid building a > Piet.It has not been built.Its Corvair parts to build it.William Wynne > book never registered in mint condition.I will crate it up on my dime if > you'll pay for it to be shipped.Know a worthy Kid? Must be a youngster > under 21! > Dave > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=322789#322789 > > > ________________________________________________________________________________
Date: Dec 11, 2010
Subject: FW: Pietenpol Preamble
> > Members: > > Here is the Pietenpol > Preamble for your garage wall! Thanks to Mike Cuy for his > Wisdom, insights, and garage logic! > > > Ken Heide > Hawley, MN > > > - - - - - - =0A=0A=0A ________________________________________________________________________________
Date: Dec 11, 2010
Subject: Push-pull control rod
Fellow pieters: - Any members have photos thay can share on the push-pull rods. I am looking for control stick connections, behind the seat set-up and bell crank connec tion. Any assistance in the size, material, and-parts used for this set-u p is much appreicated. - KMHeide Hawley, MN- - =0A=0A=0A ________________________________________________________________________________
Date: Dec 11, 2010
KM, These 3 may show mine the best. Let me know what questions may arise. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Saturday, December 11, 2010 10:25 AM Subject: Pietenpol-List: Push-pull control rod Fellow pieters: Any members have photos thay can share on the push-pull rods. I am looking for control stick connections, behind the seat set-up and bell crank connection. Any assistance in the size, material, and parts used for this set-up is much appreicated. KMHeide Hawley, MN ________________________________________________________________________________
Date: Dec 11, 2010
Subject: Re: FW: Pietenpol Preamble
I feel honoured that I was the first to receive Mike's very well worded "Wisdom,insight, and garage logic" in reply to my introduction. I have printed this to have it handy for reference and when I need encouragement. Thanks again Mike, and also thanks to Ken for putting it together in a nice formatting for printing and sharing. On 2010-12-11 10:09 AM, "KM Heide CPO/FAAOP" wrote: > > >> > >> > Members: >> > >> > Here is the Pietenpol >> > Preamble for your garage wall! Thanks to Mike Cuy for his >> > Wisdom, insights, and garage logic! >> > >> > >> > Ken Heide >> > Hawley, MN >> > >> > >> > >> >> >> > > ________________________________________________________________________________
Date: Dec 12, 2010
I have some pictures on my web site of the control tubes etc. Have a look at http://www.cpc-world.com/main.php?insert_file=photos103.php. The only thing I did notice was that the rod ends on the tube under the rear seat did not allow full stick side by side movement with out undoing the rod end a fraction of a turn. There were plenty of threads left and there was no way it was going to fall out so I left it as is. Not problems in use. I think I used 1/2 inch tubing if I remember correctly. Cheers Peter Wonthaggi Australia http://www.cpc-world.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Sunday, 12 December 2010 5:25 AM Subject: Pietenpol-List: Push-pull control rod Fellow pieters: Any members have photos thay can share on the push-pull rods. I am looking for control stick connections, behind the seat set-up and bell crank connection. Any assistance in the size, material, and parts used for this set-up is much appreicated. KMHeide Hawley, MN ________________________________________________________________________________
Subject: Re: Push-pull control rod
Date: Dec 11, 2010
Ken. 1/2" .035 tubing will be sufficient. Use quality rod-end bearings. Keep the control movement ratio the same as the plans. On NX18235 we constructed the pivot point aft of the seat to resist lateral movment. Sorry, no pictures. Greg C. Digging out from 20" of fresh snow in Minneapolis. ----- Original Message ----- From: KM Heide CPO/FAAOP To: Pietenpol Sent: Saturday, December 11, 2010 12:24 PM Subject: Pietenpol-List: Push-pull control rod Fellow pieters: Any members have photos thay can share on the push-pull rods. I am looking for control stick connections, behind the seat set-up and bell crank connection. Any assistance in the size, material, and parts used for this set-up is much appreicated. KMHeide Hawley, MN ________________________________________________________________________________
Date: Dec 11, 2010
My computer tells me it can't open this thing. Clif > Here is the Pietenpol > Preamble for your garage wall! Thanks to Mike Cuy for his > Wisdom, insights, and garage logic! > Ken Heide > Hawley, MN ________________________________________________________________________________
Date: Dec 11, 2010
Cliff I opened it with Microsoft word Kim On 2010-12-11 7:42 PM, "Clif Dawson" wrote: > My computer tells me it can't open this thing. > > Clif > > > > Here is the Pietenpol > > Preamble for your garage wall! Thanks to Mike Cuy for his > > Wisdom, insights, and garage logic! > > Ken Heide > > Hawley, MN > > ________________________________________________________________________________
Date: Dec 11, 2010
Try this one.... -----Original Message----- From: Clif Dawson Sent: Dec 11, 2010 9:37 PM Subject: Re: Pietenpol-List: FW: Pietenpol Preamble My computer tells me it can't open this thing. Clif > Here is the Pietenpol > Preamble for your garage wall! Thanks to Mike Cuy for his > Wisdom, insights, and garage logic! > Ken Heide > Hawley, MN ________________________________________________________________________________
From: "amsafetyc(at)aol.com" <amsafetyc(at)aol.com>
Date: Dec 12, 2010
Certainly worthy of printing.sharing and posting in our shops it captures the essence of who and what we are. John Sent via DROID on Verizon Wireless -----Original message----- From: Jim Markle <jim_markle(at)mindspring.com> Sent: Sun, Dec 12, 2010 03:59:31 GMT+00:00 Subject: Re: Pietenpol-List: FW: Pietenpol Preamble Try this one.... -----Original Message----- From: Clif Dawson Sent: Dec 11, 2010 9:37 PM Subject: Re: Pietenpol-List: FW: Pietenpol Preamble My computer tells me it can't open this thing. Clif > Here is the Pietenpol > Preamble for your garage wall! Thanks to Mike Cuy for his > Wisdom, insights, and garage logic! > Ken Heide > Hawley, MN ________________________________________________________________________________
Date: Dec 11, 2010
Thanks Jim. ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Sent: Saturday, December 11, 2010 7:55 PM Subject: Re: Pietenpol-List: FW: Pietenpol Preamble > Try this one.... > > -----Original Message----- > > From: Clif Dawson > > Sent: Dec 11, 2010 9:37 PM > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: FW: Pietenpol Preamble > > > > > > > > > > > My computer tells me it can't open this > thing. > > Clif > > > > > > > > > > > Here is the Pietenpol >> Preamble for > your garage wall! Thanks to Mike Cuy for his >> Wisdom, insights, > and garage logic! >> Ken Heide >> Hawley, > MN > > > > > > > > ________________________________________________________________________________
Date: Dec 12, 2010
Peter, In the photo of the push rod attached to the bell crank, which of the three holes gave you the best fore/aft stick movement for elevator control? Also are the bell crank holes for the elevator cables the same distance apart as the elevator control horn holes? This would alleviation the slack cable syndrome reported by many. The same would hold true of the rudder cables. Simple geometry. JohnW Perth West Aust ----- Original Message ----- From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> Sent: Sunday, 12 December, 2010 8:09:01 AM GMT +08:00 Beijing / Chongqing / Hong Kong / Urumqi Subject: RE: Pietenpol-List: Push-pull control rod I have some pictures on my web site of the control tubes etc. Have a look at http://www.cpc-world.com/main.php?insert_file=photos103.php . The only thing I did notice was that the rod ends on the tube under the rear seat did not allow full stick side by side movement with out undoing the rod end a fraction of a turn. There were plenty of threads left and there was no way it was going to fall out so I left it as is. Not problems in use. I think I used 1/2 inch tubing if I remember correctly. Cheers Peter Wonthaggi Australia http://www.cpc-world.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Sunday, 12 December 2010 5:25 AM Subject: Pietenpol-List: Push-pull control rod Fellow pieters: Any members have photos thay can share on the push-pull rods. I am looking for control stick connections, behind the seat set-up and bell crank connection. Any assistance in the size, material, and parts used for this set-up is much appreicated. KMHeide Hawley, MN ________________________________________________________________________________
Date: Dec 12, 2010
John, I left the push rod in the hole shown. The stick was right in the gut on landing (except when I fluffed it!!!) and felt fine in general flying. The bell crank holes were as plans. Cheers Peter From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of johnwoods(at)westnet.com.au Sent: Sunday, 12 December 2010 8:43 PM Subject: Re: Pietenpol-List: Push-pull control rod Peter, In the photo of the push rod attached to the bell crank, which of the three holes gave you the best fore/aft stick movement for elevator control? Also are the bell crank holes for the elevator cables the same distance apart as the elevator control horn holes? This would alleviation the slack cable syndrome reported by many. The same would hold true of the rudder cables. Simple geometry. JohnW Perth West Aust ----- Original Message ----- From: "Peter W Johnson" <vk3eka(at)bigpond.net.au> Sent: Sunday, 12 December, 2010 8:09:01 AM GMT +08:00 Beijing / Chongqing / Hong Kong / Urumqi Subject: RE: Pietenpol-List: Push-pull control rod I have some pictures on my web site of the control tubes etc. Have a look at http://www.cpc-world.com/main.php?insert_file=photos103.php. The only thing I did notice was that the rod ends on the tube under the rear seat did not allow full stick side by side movement with out undoing the rod end a fraction of a turn. There were plenty of threads left and there was no way it was going to fall out so I left it as is. Not problems in use. I think I used 1/2 inch tubing if I remember correctly. Cheers Peter Wonthaggi Australia http://www.cpc-world.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Sunday, 12 December 2010 5:25 AM Subject: Pietenpol-List: Push-pull control rod Fellow pieters: Any members have photos thay can share on the push-pull rods. I am looking for control stick connections, behind the seat set-up and bell crank connection. Any assistance in the size, material, and parts used for this set-up is much appreicated. KMHeide Hawley, MN www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com _blank">www.aeroelectric.com " target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com ________________________________________________________________________________
Subject: Re: Mitsubishi Engine ready to get installed...
Date: Dec 12, 2010
All done on the Dyno, the results are posted below as well as another video link of run #8. we installed and electronic ignition on these last runs and it made a huge difference on how smooth the engine is now. it starts and idles smooth as glass now, and gained a few more hp. http://www.youtube.com/watch?v=tLOP01rFf_k DYNO RESULTS 12-11-10 ADDED ELECTROMOTIVE ELECTRONIC IGNITION RPM LBFT HP 2000 132.8 50.6 2100 143.8 57.5 2200 150.3 63.0 2300 154.8 67.8 2400 157.4 71.9 2500 158.9 75.6 2600 158.9 78.7 2700 159.3 81.9 2800 159.0 84.8 2900 158.3 87.4 3000 157.1 89.7 3100 155.2 91.6 2550 153.8 75.0 AVERAGE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323113#323113 ________________________________________________________________________________
Date: Dec 12, 2010
Looks good Chris, what does it weigh? rick On Sun, Dec 12, 2010 at 5:31 PM, Chris Rusch wrote: > > > > All done on the Dyno, the results are posted below as well as another video > link of run #8. we installed and electronic ignition on these last runs and > it made a huge difference on how smooth the engine is now. it starts and > idles smooth as glass now, and gained a few more hp. > > > http://www.youtube.com/watch?v=tLOP01rFf_k > > > DYNO RESULTS > 12-11-10 > ADDED ELECTROMOTIVE ELECTRONIC IGNITION > > RPM LBFT HP > > 2000 132.8 50.6 > 2100 143.8 57.5 > 2200 150.3 63.0 > 2300 154.8 67.8 > 2400 157.4 71.9 > 2500 158.9 75.6 > 2600 158.9 78.7 > 2700 159.3 81.9 > 2800 159.0 84.8 > 2900 158.3 87.4 > 3000 157.1 89.7 > 3100 155.2 91.6 > > > 2550 153.8 75.0 AVERAGE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=323113#323113 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Dec 12, 2010
247, almost identical to the model A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323116#323116 Attachments: http://forums.matronics.com//files/img_1235_172.jpg http://forums.matronics.com//files/img_1236_431.jpg ________________________________________________________________________________
Date: Dec 12, 2010
Can it be run inverted? > >247, almost identical to the model A > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=323116#323116 > > >Attachments: > >http://forums.matronics.com//files/img_1235_172.jpg >http://forums.matronics.com//files/img_1236_431.jpg > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Subject: Another Piet back in the air
Date: Dec 12, 2010
Lowell Durham of Milaca, Mn built and flew this Pietenpol a number of years ago. It sat in a barn for 9 years until purchased earlier this year by Bob Poore. Bob got it back in flying condition as you can see in the attached picture. Will we see it a Brodhead this year Bob? Greg C. ________________________________________________________________________________
Date: Dec 12, 2010
Subject: Re: Another Piet back in the air
That's a great picture. And congrats to Bob! jm -----Original Message----- From: Greg Cardinal Sent: Dec 12, 2010 8:07 PM Subject: Pietenpol-List: Another Piet back in the air Lowell Durham of Milaca, Mn built and flew this Pietenpol a number of years ago. It sat in a barn for 9 years until purchased earlier this year by Bob Poore. Bob got it back in flying condition as you can see in the attached picture. Will we see it a Brodhead this year Bob? Greg C. ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: mitsubishi engine
Date: Dec 13, 2010
Congratulations Chris on completing this project, and beautiful work!! Since your plane isn't ready to fly yet, can you get a hold of a couple of props to bolt use so we can see what she can really do? I'd love to see how she'd spin up something like a 76X42 as a baseline. Douwe ________________________________________________________________________________
Date: Dec 13, 2010
it would need a dry sump oiling system and a return line in the valve cover.......i am not sure how good the cooling would work. I never could figure out how they kept oil out of the cylinders with inverted systems, i would think hydraulic locking would be a problem while the engine sits for awhile. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323154#323154 ________________________________________________________________________________
Subject: Re: mitsubishi engine
Date: Dec 13, 2010
Thanks Douwe! I have a brand new 76 x 42 prop from Culver just waiting to be spun, that is the next step. I need to throw the engine on the mount and wire everything thing up for good. I have all the pieces of the puzzle, just need to assemble everything. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323158#323158 ________________________________________________________________________________
Date: Dec 13, 2010
I always wondered about the oil accumulation issue, too. From what I've read, when DeHavilland created the Gypsy engine, they simply inverted a Cirrus, did a few mods similar to what you describe but not much else, and they were surprised it all worked so easily. Does anyone here on the list know about such? I don't have the information in front of me or I'd give a source. Surely it can't be that simple? > >it would need a dry sump oiling system and a return line in the >valve cover.......i am not sure how good the cooling would work. I >never could figure out how they kept oil out of the cylinders with >inverted systems, i would think hydraulic locking would be a problem >while the engine sits for awhile. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=323154#323154 > > -- Jeff Boatright "Now let's think about this..." ________________________________________________________________________________
Subject: Re: looking for Fairchild N81288 (off-topic)
Date: Dec 13, 2010
Here you go....... http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=81288 -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323168#323168 ________________________________________________________________________________
Subject: Old Technologyies meet
Date: Dec 13, 2010
Brought my completely rebuilt C85-12 engine back to the shop today to be mounted on the Piet. A morality boost to continue forward. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323229#323229 Attachments: http://forums.matronics.com//files/dsc00315_172.jpg http://forums.matronics.com//files/dsc00313_154.jpg ________________________________________________________________________________
Date: Dec 13, 2010
Inverting a Ford B is very simple, Check out the Funk Akron 200 Engine. If anyone is interested check out the Pietenpol that I flew to Oshkosh in 1988 and JoBeth Barret flew to Oshkosh in 1999. Oil is kept out of the cylinders by a 1 " high S.S. ring bolted to the cylinder opening by 2 each, 10-32 screws. After the Funk engine sat in storage for 5 years, I pulled it out and with good gas and a few blades to check for lock,It started 2Nd blade. With a little smoke it cleared very soon. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323233#323233 ________________________________________________________________________________
Date: Dec 13, 2010
He could put some ski's on it... - Pat -------- Patrick Hoyt XLb/650 Canopy/BRS/Corvair N63PZ - 99.999% done.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=323234#323234 ________________________________________________________________________________
Date: Dec 13, 2010
Pieti, Excellent information! Thanks, Jeff > >Inverting a Ford B is very simple, Check out the Funk Akron 200 >Engine. If anyone is interested check out the Pietenpol that I flew >to Oshkosh in 1988 and JoBeth Barret flew to Oshkosh in 1999. >Oil is kept out of the cylinders by a 1 " high S.S. ring bolted to >the cylinder opening by 2 each, 10-32 screws. >After the Funk engine sat in storage for 5 years, I pulled it out >and with good gas and a few blades to check for lock,It started 2Nd >blade. With a little smoke it cleared very soon. >Pieti Lowell > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=323233#323233 > > -- --- Jeffrey H. Boatright, Ph.D. Associate Professor of Ophthalmology Emory University School of Medicine Editor-in-Chief Molecular Vision ________________________________________________________________________________
Date: Dec 14, 2010
Subject: Re: Soon will be building
Not being the purest as many I guess I suppose you can considered I cheated, however in terms of my own self satisfaction I used West System epoxy, close fitting joints and clamps along with brads and staples shot from a pneumatic gun. I wanted to be well assured that the pins would help my clamps and joints stay tight and strong. Not that I would be critical of others using just clamps and epoxy, or rubber bands with flour and water paste, its just me and who I am.
- - - , 20- - December 14, 2010
Pietenpol-Archive.digest.vol-jv
