Pietenpol-Archive.digest.vol-ka
January 16, 2011 - January 24, 2011
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject:
Date: Jan 16, 2011
Don, I'm sticking with the wood gear, but I had to rebuild the wheels and axle because of the damage. While I was at it, I used the same basic brake design (a drum brake, inside the wire wheel, which I'm gonna cover this time round) except moved up from go-cart brakes to golf cart brakes, which are much better quality and larger, though I'm sure they still won't hold those big wheels. The only other thing I'm changing is my anti-rotation set up and changing to a travel limiting arched tube rather than a cable, as I've read about a cable swage giving way on one when someone's bungees broke. I'll try to get some photos this week, once I get the airbox back on the carb. Douwe ________________________________________________________________________________
Subject: Do back seat backs need to be glued?
Date: Jan 16, 2011
John, as Gary mentioned, the seats provide just about the only shear bracing in the entire fuselage (the firewall is the only other bracing). Mike Cuy made an access panel in his rear seatback, but as I recall he left the perimeter of the seatback intact and cut out an opening for access. Other people (myself included) have provided an access panel under the belly to allow access to the elevator bellcrank area. If you used enough screws to attach the seat back it would probably provide enough strength, but I found the rear seatback to be too far forward of the bellcrank to really allow easy access. I put the panel between the two bottom stringers that I added, spanning between the rear seat bulkhead and the next cross piece in the fuselage as shown in the picture below: This area is then covered with a sheet of .025" aluminum. A total of 18 screws hold the panel in place. It comes off every year for the Condition Inspection, to allow inspection and lubrication of the bellcrank area. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Kuhfahl Sent: Saturday, January 15, 2011 7:52 PM Subject: Pietenpol-List: Do back seat backs need to be glued? Hi, John here. I am new to list--looks great! I am restoring a Piet built in the 70's--having a ball and will have lots of questions. Can I screw the seat backs rather than glue as I found them? A lot easier access. Thanks in advance. BTW I am an A&P and specialize in Continental engines. -- John Kuhfahl, Lt Col USAF (Ret), PresIident, KUHLCOUPER LLC ________________________________________________________________________________
Date: Jan 16, 2011
Hello i'm new to the group. I'm Patrick ,my dad and I are restoring an old Piet. I'm in need of prop data so I can carve a prop for the model A. Can anyone help me find this ? We have thf fuselage and tail group ready for cover and will be starting on the wings soon. Thanks. Patrick ________________________________________________________________________________
Subject: Do seat backs need to be glued?
Date: Jan 16, 2011
John asked- > Can I screw the seat backs rather than glue as I found them? > A lot easier access. As others have mentioned, the seat backs are structural and add rigidity and diaphragm strength like bulkheads. But my rear seat back has a hinged cutout for access to the elevator walking beam, my ELT and antenna, and the small baggage pouch on the inside rear of my seat. Come on over and look at it this afternoon ;o) For others on the list who may not know, John lives at my home field of San Geronimo Airpark. We hope to fly together one of these days! Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jan 16, 2011
Patrick, You are at exactly right place!! And good for you & your dad! This time last year I carved my own prop, which you can see at www.westcoastpiet.com. I used the prop carving information available from Dan Helsper, helspersew(at)aol.com, who also carved his prop for a Model A powered Piet, and did an excellent job of cataloguing it. P.F. Beck is also an excellent resource, pfbeck(at)bellsouth.net, as he carved his prop for a Corvair powered Piet (and didn't even break the crank once, yet). My prop-carving project took about 40 hrs of work. Good luck to you, and don't forget to send The List pictures of your project and progress!! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of 69racerx(at)comcast.net Sent: Sunday, January 16, 2011 9:10 AM Subject: RE: Pietenpol-List: Do back seat backs need to be glued? Hello i'm new to the group. I'm Patrick ,my dad and I are restoring an old Piet. I'm in need of prop data so I can carve a prop for the model A. Can anyone help me find this ? We have thf fuselage and tail group ready for cover and will be starting on the wings soon. Thanks. Patrick ________________________________________________________________________________
Subject: Re: Do seat backs need to be glued?
Date: Jan 16, 2011
He shot at me. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327198#327198 ________________________________________________________________________________
Date: Jan 16, 2011
One of my favorite quotes from Winston Churchill is: "Nothing is so exhilarating as being shot at without result." Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Sunday, January 16, 2011 12:51 PM Subject: Pietenpol-List: Re: Do seat backs need to be glued? He shot at me. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327198#327198 ________________________________________________________________________________
Subject: Re: rudder bar
Date: Jan 16, 2011
far out... thanks for measuring jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327200#327200 ________________________________________________________________________________
Subject: Control surfaces
Date: Jan 16, 2011
Hoping to save a lot of research by throwing this question out there. What are the approximate degrees of deflection (up and down, left and right) on all control surfaces? Thanks in advance. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327209#327209 ________________________________________________________________________________
Subject: Re: pulley size
Date: Jan 16, 2011
I was about to order the two 2" pulleys in the wing center section for the aileron control cable. I found this post in the archives and it appears that people are using the MS24566 Phenolic Pulleys. In the aircraft spruce catalog it states "shall not be installed on frequently used aircraft controls to bend the cable more than 15 degrees from a straight line". It appears to me on the prints that the pulley would bend the cable somewhat just short of 90 degrees. Should they be used? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327211#327211 ________________________________________________________________________________
Date: Jan 16, 2011
Not to be flip, but it's not a certified aircraft so you can use those pulleys if you wish. I don't think I've ever heard of anyone having cable failure by using the pulleys specified in the plans. I hesitate to make a personal recommendation because I'm frightened the airplane may hear me and decide it's un-airworthy all of a sudden. (sorry) Let your conscious be your guide. This is another topic where we'll get responses ranging from "the plans are ok" to "you're going to die." Kevin -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327212#327212 ________________________________________________________________________________
Date: Jan 16, 2011
So what is the alternative? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327214#327214 ________________________________________________________________________________
Date: Jan 16, 2011
This is from Mike Cuy for the elevators. http://westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/images/Piet_elevato r_travel_sketch.jpg Aileron are limited by the stick hitting your knees. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of pineymb Sent: Sunday, January 16, 2011 1:20 PM Subject: Pietenpol-List: Control surfaces Hoping to save a lot of research by throwing this question out there. What are the approximate degrees of deflection (up and down, left and right) on all control surfaces? Thanks in advance. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327209#327209 ________________________________________________________________________________
Subject: Re: WW
Date: Jan 16, 2011
Hello Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327218#327218 ________________________________________________________________________________
Subject: Ryan Mueller
Date: Jan 16, 2011
Ryan I sent a message a couple of days ago to your gmail account. Did you get it? Chris Sacramento, Ca Westcoastpiet.com ________________________________________________________________________________
Date: Jan 16, 2011
Subject: Re: WW
I will have ,Just checking to see if i had this all working.=0A=0A=0A=0A=0A ________________________________=0AFrom: cdpratt <cdpratt(at)att.net>=0ATo: pi etenpol-list(at)matronics.com=0ASent: Sun, January 16, 2011 5:49:30 PM=0ASubje att" =0A=0AHello=0A=0A=0A=0A=0ARead this topic online here :=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=327218#327218=0A=0A=0A =================== ________________________________________________________________________________
Date: Jan 16, 2011
... or choosing a different aircraft to build, or not building an airplane at all and taking up needle point or flower arranging instead. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327222#327222 ________________________________________________________________________________
Date: Jan 16, 2011
I have never heard anyone complain about cable wear in the wings so I am using 2" pulleys and have no worries about it. I figure I will inspect the cables where they bend and replaces if necessary. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, January 16, 2011 1:33 PM Subject: Pietenpol-List: Re: pulley size I was about to order the two 2" pulleys in the wing center section for the aileron control cable. I found this post in the archives and it appears that people are using the MS24566 Phenolic Pulleys. In the aircraft spruce catalog it states "shall not be installed on frequently used aircraft controls to bend the cable more than 15 degrees from a straight line". It appears to me on the prints that the pulley would bend the cable somewhat just short of 90 degrees. Should they be used? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327211#327211 ________________________________________________________________________________
Date: Jan 16, 2011
Sorry, John. We're being cheeky again. I think many folks (including myself) use the 2" pulleys with no issues. If you're uncomfortable with that you'll need to redesign the system to accommodate the larger pulleys. I am NOT an expert on cable control systems, but I have successfully built and flown a Pietenpol with a plans-built control system. Up to you, my brother. If 2" pulleys is the only sin you commit I'll test fly it for you if you'll let me. Heck, I'll fly off the 40 hours. for what it's worth Kevin -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327228#327228 ________________________________________________________________________________
Subject: Re: Control surfaces
Date: Jan 16, 2011
I built it per the plans and I have no idea what the angles are. When I rack it over in an 80 degree bank the ailerons really don't deflect very much. It needs some rudder when I do that, though. Not sure what the angle on the rudder is, either. No idea on the elevator. I've never run out. I didn't answer your question specifically but I can say that I don't get anywhere close to full deflection and yet get pretty sprightly performance from an airplane I named "Fat Bottomed Girl." I'm out of town or I'd got measure it for you. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327229#327229 ________________________________________________________________________________
Date: Jan 16, 2011
I have no problems keeping with the plans. So the caution about using this pulley is because of cable issues and not the strength of the pulley? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327230#327230 ________________________________________________________________________________
Date: Jan 16, 2011
Since the empirical evidence says it is good to go....then maybe the catalog might be disregarded..... On Sun, Jan 16, 2011 at 6:42 PM, Kringle wrote: > > I have no problems keeping with the plans. So the caution about using this > pulley is because of cable issues and not the strength of the pulley? > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327230#327230 > > ________________________________________________________________________________
Date: Jan 16, 2011
Right. We can check with the A&Ps but I'm willing to bet it has nothing to do with the pulleys. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327231#327231 ________________________________________________________________________________
Subject: cooling eyebrows
Date: Jan 16, 2011
Cracking of aluminum eyebrows seems rampant, and I was wondering. would another thin metal be more crack resistant? Thin steel wouldn't add much weight, and might re less prone to harden and crack? I don't mind a little extra weight on the nose anyhow. I know the attach points to the cylinder nuts need to be steel so they don't crush over time, and I know the attach straps should rivet onto the shroud itself on a large surface using many rivets to distribute the vibration. Was just rethinking the whole material idea Douwe ________________________________________________________________________________
Date: Jan 16, 2011
Subject: Weight and balance calculations
Weighed the airplane today, and was real pleased that the empty weight came out out to be 634 lbs. In doing the weight and balance calculations back home, I find that I'm close to the rear limit of 20" aft of the leading edge when my big butt is in the rear seat. I used the center of the rear seat as the CG of the occupant but I'm seeing that a more accurate location of the occupant's CG is under the navel, or in my case, an inch or so aft of the front of the seat bottom. If that's the case, I'm within the aft limit. Any thoughts on this or am I just avoiding the fact that I really need to lose a few lbs myself? Matt Paxton ________________________________________________________________________________
Subject: Re: cooling eyebrows
Date: Jan 16, 2011
Sounds like a reasonable idea to me Douwe, but then again I'm not an A&P, metallurgist, or engineer. Other more knowledgeable list members should definitely comment on this. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327241#327241 ________________________________________________________________________________
Date: Jan 16, 2011
I doubled the thickness of the aluminum in my shrouds and went to 5052, which is a more fatigue resistant alloy that 3003. We'll see how long they last. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Sunday, January 16, 2011 8:22 PM Subject: Pietenpol-List: cooling eyebrows Cracking of aluminum eyebrows seems rampant, and I was wondering. would another thin metal be more crack resistant? Thin steel wouldn't add much weight, and might re less prone to harden and crack? I don't mind a little extra weight on the nose anyhow. I know the attach points to the cylinder nuts need to be steel so they don't crush over time, and I know the attach straps should rivet onto the shroud itself on a large surface using many rivets to distribute the vibration. Was just rethinking the whole material idea Douwe ________________________________________________________________________________
Date: Jan 16, 2011
Sounds like you're in good shape, Matt. The pilot's belt buckle is the accepted cg location of the pilot. Mine is a bit aft of 20" aft of the LE. I'm at 34% of chord, or about 20.4" aft of the LE, and it flies just fine. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Woodflier(at)aol.com Sent: Sunday, January 16, 2011 8:35 PM Subject: Pietenpol-List: Weight and balance calculations Weighed the airplane today, and was real pleased that the empty weight came out out to be 634 lbs. In doing the weight and balance calculations back home, I find that I'm close to the rear limit of 20" aft of the leading edge when my big butt is in the rear seat. I used the center of the rear seat as the CG of the occupant but I'm seeing that a more accurate location of the occupant's CG is under the navel, or in my case, an inch or so aft of the front of the seat bottom. If that's the case, I'm within the aft limit. Any thoughts on this or am I just avoiding the fact that I really need to lose a few lbs myself? Matt Paxton ________________________________________________________________________________
Date: Jan 16, 2011
Don't they all have that caveat? There I am, all that time ago, becoming consternated myself thinking, "OK, just what pulleys can I use then?" Including phenolic ones that looked just like the ones in the plans! So I said "The hell with it!" And was going to order the things anyway after returning from Arlington that year. As luck would have it I came back with all the pulleys in the plane and a couple extra for good measure! But they are all 3". If you're concerned though, take a look at that front pulley on the stick. That ain't no 15!! Something tells me you're right. It's probably that hairpin thing. Clif > Right. We can check with the A&Ps but I'm willing to bet it has nothing > to do with the pulleys. > Kevin "Axel" Purtee ________________________________________________________________________________
Subject: cloth used for Fiberglass fuel tank
Date: Jan 16, 2011
Anyone make their tank from fiberglass? What's the best cloth to use - see ms there are many advantages and disadvantages to each style. Tom B. ________________________________________________________________________________
Date: Jan 17, 2011
I'd use a satin weave=2C (more glass to resin ratio) and use a vinyl ester resin. (not affected by fuel). Just my .02 Doug Dever In beautiful Stow Ohio From: tmbrant(at)msn.com Subject: Pietenpol-List: cloth used for Fiberglass fuel tank Date: Sun=2C 16 Jan 2011 22:24:17 -0600 Anyone make their tank from fiberglass? What's the best cloth to use - see ms there are many advantages and disadvantages to each style. Tom B. ________________________________________________________________________________
Date: Jan 17, 2011
Douwe, With your ability you could make those eyebrows out of some appropriate all oy of brass. I can visualize a highly-polished cowling eyebrow assembly. Th at would be cool to see. Let's get some new ideas out there! Dan Helsper Poplar Grove, IL. -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Sun, Jan 16, 2011 7:23 pm Subject: Pietenpol-List: cooling eyebrows Cracking of aluminum eyebrows seems rampant, and I was wondering w ould another thin metal be more crack resistant? Thin steel wouldn =99t add much weight, and might re less prone to harden and crack? I don =99t mind a little extra weight on the nose anyhow. I know the attach points to the cylinder nuts need to be steel so they don =99t crush over time, and I know the attach straps should rivet onto the shroud itself on a large surface using many rivets to distribute the vi bration. Was just rethinking the whole material idea Douwe -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: Weight and balance calculations
Date: Jan 17, 2011
Matt, I agree with Jack about your W & B being fine. I am told the airplane actua lly flies better when the balance is toward the rear anyway. My airplane (m odel A) is actually nose heavy. I was very surprised because the convention al wisdom is that the Piet is always tail heavy. Walt Bowe (Model A, from C alifornia) told me his came out nose heavy also. I set my engine mount to t he plans, and I was very worried because of the conventional wisdom. Some m odel A fellows move the engine forward as much as 7 inches (Ken Perkins). I am able to trim it out in flight, but it still bugs me, and I am racking m y brain on how to actually add more tail weight (magically, without consequ ences) so the CG can move back. I am about 155# so I guess this is the reas on. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Jan 17, 2011
I didn't know that any grown man was ever that light -- 155? Wish I could say that! ----- Original Message ----- From: helspersew(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, January 17, 2011 6:35 AM Subject: Re: Pietenpol-List: Weight and balance calculations Matt, I agree with Jack about your W & B being fine. I am told the airplane actually flies better when the balance is toward the rear anyway. My airplane (model A) is actually nose heavy. I was very surprised because the conventional wisdom is that the Piet is always tail heavy. Walt Bowe (Model A, from California) told me his came out nose heavy also. I set my engine mount to the plans, and I was very worried because of the conventional wisdom. Some model A fellows move the engine forward as much as 7 inches (Ken Perkins). I am able to trim it out in flight, but it still bugs me, and I am racking my brain on how to actually add more tail weight (magically, without consequences) so the CG can move back. I am about 155# so I guess this is the reason. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Jan 17, 2011
Thanks Kevin, that pretty much answers my question as my concern was what appears to be minimal travel of the ailerons. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327269#327269 ________________________________________________________________________________
Date: Jan 17, 2011
I read one post where the writer said he glued small blocks of wood on the floor where the aileron activating control horn would be stopped so that it would limit aileron travel. Apparently he thought the aileron travel was too great. I think he wanted to stop the moving aileron spar from banging against the stationary one. ----- Original Message ----- From: "pineymb" <airltd(at)mts.net> Sent: Monday, January 17, 2011 7:46 AM Subject: Pietenpol-List: Re: Control surfaces > > Thanks Kevin, that pretty much answers my question as my concern was what > appears to be minimal travel of the ailerons. > > -------- > Adrian M > Winnipeg, MB > Canada > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327269#327269 > > > ________________________________________________________________________________
Date: Jan 17, 2011
Subject: Re: cloth used for Fiberglass fuel tank
Tom: On the advice of my son who works for Burt Rutan at Scaled Composites, I used the bidirectional "Rutan Fiberglass Cloth" from Aircraft Spruce http://www.aircraftspruce.com/menus/cm/fiberglass_cloth.html Compared to the other choices this cloth takes compound curves very well, wets out easily, and is only as prone to flying fiberglass fibers as every other cloth type out there. I took a lot of photos during the building of the tank and they are available here: http://www.eaa1344.com/Projects/Stine metze/wing_center_section.htm Disclaimer: The tank is still sitting dry on my shelf awaiting installation so I can't give any performance data or tell you how it held up to auto gas, etc. Tom Stinemetze N328X >>> TOM MICHELLE BRANT 1/16/2011 10:24 PM >>> Anyone make their tank from fiberglass? What's the best cloth to use - seems there are many advantages and disadvantages to each style. Tom B. ________________________________________________________________________________
Date: Jan 17, 2011
Subject: Re: Do back seat backs need to be glued?
Hey Piet people--thanks for the info--what a great group! Still trying to figure out how to use this forum...Found the front seat back, although glued, was missing cross-bracing--looks pretty important. Fixed! For Steve--Ercoupe is great--140 hours now SMOH. Come by and visit when you get back--Piet is coming along nicely. John On Sun, Jan 16, 2011 at 7:34 AM, Dortch, Steven D MAJ NG NG FORSCOM < steven.d.dortch(at)us.army.mil> wrote: > > > Wow what a tiny world. John, I have been lurking this list for several > years. I would like to get a Piet someday. Oscar is the one who hooked me. > Where did you get the piet? and how is the Ercoupe doing (for the listers > John did a beautiful restoration of an Ercoupe and has piddled around with > several other older planes.) > Welcome to the list. > > Blue Skies, > Steve (Stuck in Basra, Iraq) D > > ----- Original Message ----- > From: John Kuhfahl <kuhlcouper(at)gmail.com> > Date: Sunday, January 16, 2011 4:04 > Subject: Pietenpol-List: Do back seat backs need to be glued? > To: pietenpol-list(at)matronics.com > > > > Hi, John here. I am new to list--looks great! > > I am restoring a Piet built in the 70's--having a ball and will > > have lots of > > questions. > > Can I screw the seat backs rather than glue as I found them? A lot > > easieraccess. > > Thanks in advance. > > BTW I am an A&P and specialize in Continental engines. > > > > -- > > John Kuhfahl, Lt Col USAF (Ret), > > PresIident, KUHLCOUPER LLC > > -- John Kuhfahl, Lt Col USAF (Ret), PresIident, KUHLCOUPER LLC ________________________________________________________________________________
Subject: Copper Primer Line
Date: Jan 17, 2011
I am currently routing a copper primer line from the rear cockpit to the left intake. This is 1/8" tubing. Can anyone tell me if a flexible joining between fuselage and engine is required, as with fuel lines? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) ________________________________________________________________________________
Subject: Re: Copper Primer Line
Date: Jan 17, 2011
Gary I have never seen anything other than the metal line. I would not tie it down very close to the engine. The flex in your mounts might fatigue the line. If it breaks in flight should not be a problem just a real small vacuum leak. It would have some effect on the idle. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327324#327324 ________________________________________________________________________________
Date: Jan 17, 2011
Good points Steve. Here is how my son had me do mine. Note that this needs to be done while you can still get to the inside of the tank as the "top hat" fittings drop into snug fitting holes with the hat flange on the inside of the tank and are then fiberglassed in place. The advantage of this is that should a fitting get knocked loose, it will stay inside the tank and help plug the hole. As you said, surface preparation is very important as fresh resin does not bond all that well to cured resin. Scuff up the cured surface well with coarse grit sandpaper but do not sand through the glass weave. Add two or three layers of glass inside over the top of the flange with a plug of some type in place where the finger strainer will go. The drawing is from memory so there are probably some minor discrepancies to be seen. Tom Stinemetze N328X >>> Steve Ruse 1/17/2011 11:12 AM >>> My point...if you are going to use fiberglass, be SURE your fitting is adequately built into the tank. The fitting should probably have layers of fiberglass on top...mine only had a pile of resin gouped over the aluminum "top hat" fitting. Fiberglass resin doesn't bond well to cured fiberglass layups, so if you do that, make SURE you properly prepare the surface, or better yet, build the fitting into the tank. I'm sure the Long-EZ & Vari-EZ plans have a good way to do this. ________________________________________________________________________________
Date: Jan 17, 2011
Gary, wind a couple of turns of the copper line in a circle about 2" or 3" in diameter (I think I wound mine around a spray can) to make a couple of loops that can give the line some "give" and flexibility. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Monday, January 17, 2011 2:07 PM Subject: Pietenpol-List: Copper Primer Line I am currently routing a copper primer line from the rear cockpit to the left intake. This is 1/8" tubing. Can anyone tell me if a flexible joining between fuselage and engine is required, as with fuel lines? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) ________________________________________________________________________________
Date: Jan 17, 2011
Gary. on my corvair with a marvel ma3sb carb you really don't need a primer because the accelerator pump does the same thing. Cheers, Gardiner, this assuming you have marvel carb. Plus it won't work with the Stromburg ----- Original Message ---- From: Jerry Dotson <jdotson(at)centurylink.net> Sent: Mon, January 17, 2011 3:42:05 PM Subject: Pietenpol-List: Re: Copper Primer Line Gary I have never seen anything other than the metal line. I would not tie it down very close to the engine. The flex in your mounts might fatigue the line. If it breaks in flight should not be a problem just a real small vacuum leak. It would have some effect on the idle. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327324#327324 ________________________________________________________________________________
Date: Jan 17, 2011
Jack, Three options as I see it: 1. Junk the continental and install a corvair with no colling eyebrows... 2. Use neighbors 16 ton press and make them out of 1/2" steel plates.... 3. Impregnated carbon fiber over a mold using acrylic resign 80/20 flex... Mr. Fargo --- On Sun, 1/16/11, Jack Phillips wrote: > From: Jack Phillips <pietflyr(at)bellsouth.net> > Subject: RE: Pietenpol-List: cooling eyebrows > To: pietenpol-list(at)matronics.com > Date: Sunday, January 16, 2011, 8:28 PM > > > > > > > > > > > > > > > > > > > > > > > I doubled > the thickness of the > aluminum in my shrouds and went to 5052, which is a more > fatigue resistant > alloy that 3003. Well see how long they > last. > > > > > Jack > Phillips > > NX899JP > Icarus Plummet > > Raleigh, > NC > > > > > > > > > > > > > > > > > From: > owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] > On Behalf Of > Douwe Blumberg > > Sent: Sunday, > January 16, 2011 > 8:22 PM > > To: > pietenpolgroup > > Subject: > Pietenpol-List: cooling > eyebrows > > > > > > Cracking of > aluminum eyebrows seems rampant, and I was > wondering would another thin metal be more crack > resistant? Thin > steel wouldnt add much weight, and might re less > prone to harden and > crack? I dont mind a little extra weight on > the nose anyhow. > > > > > I know the > attach points to the cylinder nuts need to be > steel so they dont crush over time, and I know the > attach straps should > rivet onto the shroud itself on a large surface using many > rivets to distribute > the vibration. Was just rethinking the whole material > idea > > > > > Douwe > > > > > > > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution > > > > > > > > > > ________________________________________________________________________________
Date: Jan 17, 2011
I see in the diagram a callout for 6 layers of glass for the outside and 3 layers for the inner.. What weight of glass were you using? About how thick was the final layup? Dave On 1/17/2011 4:30 PM, TOM STINEMETZE wrote: > *Good points Steve. Here is how my son had me do mine. Note that > this needs to be done while you can still get to the inside of the > tank as the "top hat" fittings drop into snug fitting holes with the > hat flange on the inside of the tank and are then fiberglassed in > place. The advantage of this is that should a fitting get knocked > loose, it will stay inside the tank and help plug the hole. As you > said, surface preparation is very important as fresh resin does not > bond all that well to cured resin. Scuff up the cured surface well > with coarse grit sandpaper but do not sand through the glass weave. > Add two or three layers of glass inside over the top of the flange > with a plug of some type in place where the finger strainer will go. > The drawing is from memory so there are probably some minor > discrepancies to be seen.* > ** > *Tom Stinemetze* > *N328X* > > > >>> Steve Ruse 1/17/2011 11:12 AM >>> > My point...if you are going to use fiberglass, be SURE your fitting is > adequately built into the tank. The fitting should probably have > layers of fiberglass on top...mine only had a pile of resin gouped > over the aluminum "top hat" fitting. Fiberglass resin doesn't bond > well to cured fiberglass layups, so if you do that, make SURE you > properly prepare the surface, or better yet, build the fitting into > the tank. I'm sure the Long-EZ & Vari-EZ plans have a good way to do > this. > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jan 17, 2011
Listen to Jack. That is how it is installed on NX18235. 250 hours without a problem. Greg Cardinal ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Monday, January 17, 2011 3:28 PM Subject: RE: Pietenpol-List: Copper Primer Line Gary, wind a couple of turns of the copper line in a circle about 2" or 3" in diameter (I think I wound mine around a spray can) to make a couple of loops that can give the line some "give" and flexibility. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Monday, January 17, 2011 2:07 PM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Copper Primer Line I am currently routing a copper primer line from the rear cockpit to the left intake. This is 1/8" tubing. Can anyone tell me if a flexible joining between fuselage and engine is required, as with fuel lines? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 17, 2011
AMEN--- Gardiner ----- Original Message ---- From: KM Heide CPO/FAAOP <kmheidecpo(at)yahoo.com> Sent: Mon, January 17, 2011 4:47:38 PM Subject: RE: Pietenpol-List: cooling eyebrows Jack, Three options as I see it: 1. Junk the continental and install a corvair with no colling eyebrows... 2. Use neighbors 16 ton press and make them out of 1/2" steel plates.... 3. Impregnated carbon fiber over a mold using acrylic resign 80/20 flex... Mr. Fargo --- On Sun, 1/16/11, Jack Phillips wrote: > From: Jack Phillips <pietflyr(at)bellsouth.net> > Subject: RE: Pietenpol-List: cooling eyebrows > To: pietenpol-list(at)matronics.com > Date: Sunday, January 16, 2011, 8:28 PM > > > > > > > > > > > > > > > > > > > > > > > I doubled > the thickness of the > aluminum in my shrouds and went to 5052, which is a more > fatigue resistant > alloy that 3003. Well see how long they > last. > > > > > Jack > Phillips > > NX899JP > Icarus Plummet > > Raleigh, > NC > > > > > > > > > > > > > > > > > From: > owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] > On Behalf Of > Douwe Blumberg > > Sent: Sunday, > January 16, 2011 > 8:22 PM > > To: > pietenpolgroup > > Subject: > Pietenpol-List: cooling > eyebrows > > > > > > Cracking of > aluminum eyebrows seems rampant, and I was > wondering would another thin metal be more crack > resistant? Thin > steel wouldnt add much weight, and might re less > prone to harden and > crack? I dont mind a little extra weight on > the nose anyhow. > > > > > I know the > attach points to the cylinder nuts need to be > steel so they dont crush over time, and I know the > attach straps should > rivet onto the shroud itself on a large surface using many > rivets to distribute > the vibration. Was just rethinking the whole material > idea > > > > > Douwe > > > > > > > > > > > > > > http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution >n > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 17, 2011
I remember now where I saw this setup with a coil in the line to take the vibration and motion. As usual, just about any question on how to build an airplane is covered in the Bingelis books. Look in Firewall Forward, on page 173, figure 5. You'll see exactly what I was talking about. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Monday, January 17, 2011 4:28 PM Subject: RE: Pietenpol-List: Copper Primer Line Gary, wind a couple of turns of the copper line in a circle about 2" or 3" in diameter (I think I wound mine around a spray can) to make a couple of loops that can give the line some "give" and flexibility. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Monday, January 17, 2011 2:07 PM Subject: Pietenpol-List: Copper Primer Line I am currently routing a copper primer line from the rear cockpit to the left intake. This is 1/8" tubing. Can anyone tell me if a flexible joining between fuselage and engine is required, as with fuel lines? Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 17, 2011
Tom, I have been studying the write-up and pictures of your fiberglass fuel tank. I have a couple of questions. 1). How does the tank get fastened into the center-section? Or do you just figure gravity and weight of fuel will hold it in place? 2). I notice you have assembled the center section without the metal butt joint straps and cabane fittings installed. How do you plan to weld the cabane fittings to the joint straps without setting your center section on fire? I was planning to weld the two together and fasten them to the spars before the butt ribs go on. Am I missing something here? Nice job on the tank. Another question -- 3). When joining the four sections together do you wet the mating surfaces or just let the additional layers of cloth hold them together? ----- Original Message ----- From: TOM STINEMETZE To: pietenpol-list(at)matronics.com Sent: Monday, January 17, 2011 9:42 AM Subject: Re: Pietenpol-List: cloth used for Fiberglass fuel tank Tom: On the advice of my son who works for Burt Rutan at Scaled Composites, I used the bidirectional "Rutan Fiberglass Cloth" from Aircraft Spruce http://www.aircraftspruce.com/menus/cm/fiberglass_cloth.html Compared to the other choices this cloth takes compound curves very well, wets out easily, and is only as prone to flying fiberglass fibers as every other cloth type out there. I took a lot of photos during the building of the tank and they are available here: http://www.eaa1344.com/Projects/Stinemetze/wing_center_section.htm Disclaimer: The tank is still sitting dry on my shelf awaiting installation so I can't give any performance data or tell you how it held up to auto gas, etc. Tom Stinemetze N328X >>> TOM MICHELLE BRANT 1/16/2011 10:24 PM >>> Anyone make their tank from fiberglass? What's the best cloth to use - seems there are many advantages and disadvantages to each style. Tom B. ________________________________________________________________________________
Date: Jan 17, 2011
Here's a link to some pics of my tank construction; http://www.clifdawson.ca/Homepage4-10-06/Pietenpol_Page_6.html Next go to page nine where I finaly got around to bolting the thing in. Rats! It looks like I didn't put up any pics of the filler cap! I bought this cap for $5.00 at Arlington and made the base for it. The base is brought up through from the inside and has a couple of layers of cloth over it extending out an inch. The black line you see in the glass are black marker used in the cutting process. It's Vinyl ester resin and "medium" cloth. That's all I can find on the bill I just looked up. Clif. ----- Original Message ----- From: Charles Campbell To: pietenpol-list(at)matronics.com Sent: Monday, January 17, 2011 4:23 PM Subject: Re: Pietenpol-List: cloth used for Fiberglass fuel tank Tom, I have been studying the write-up and pictures of your fiberglass fuel tank. I have a couple of questions. 1). How does the tank get fastened into the center-section? Or do you just figure gravity and weight of fuel will hold it in place? 2). I notice you have assembled the center section without the metal butt joint straps and cabane fittings installed. How do you plan to weld the cabane fittings to the joint straps without setting your center section on fire? I was planning to weld the two together and fasten them to the spars before the butt ribs go on. Am I missing something here? Nice job on the tank. Another question -- 3). When joining the four sections together do you wet the mating surfaces or just let the additional layers of cloth hold them together? ----- Original Message ----- From: TOM STINEMETZE To: pietenpol-list(at)matronics.com Sent: Monday, January 17, 2011 9:42 AM Subject: Re: Pietenpol-List: cloth used for Fiberglass fuel tank Tom: On the advice of my son who works for Burt Rutan at Scaled Composites, I used the bidirectional "Rutan Fiberglass Cloth" from Aircraft Spruce http://www.aircraftspruce.com/menus/cm/fiberglass_cloth.html Compared to the other choices this cloth takes compound curves very well, wets out easily, and is only as prone to flying fiberglass fibers as every other cloth type out there. I took a lot of photos during the building of the tank and they are available here: http://www.eaa1344.com/Projects/Stinemetze/wing_center_section.htm Disclaimer: The tank is still sitting dry on my shelf awaiting installation so I can't give any performance data or tell you how it held up to auto gas, etc. Tom Stinemetze N328X >>> TOM MICHELLE BRANT 1/16/2011 10:24 PM >>> Anyone make their tank from fiberglass? What's the best cloth to use - seems there are many advantages and disadvantages to each style. Tom B. href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jan 18, 2011
Gardiner could you expand why it won't work on a Stromburg? Thanks, Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Monday, January 17, 2011 3:39 PM Subject: Re: Pietenpol-List: Re: Copper Primer Line Gary. on my corvair with a marvel ma3sb carb you really don't need a primer because the accelerator pump does the same thing. Cheers, Gardiner, this assuming you have marvel carb. Plus it won't work with the Stromburg ----- Original Message ---- From: Jerry Dotson <jdotson(at)centurylink.net> Sent: Mon, January 17, 2011 3:42:05 PM Subject: Pietenpol-List: Re: Copper Primer Line Gary I have never seen anything other than the metal line. I would not tie it down very close to the engine. The flex in your mounts might fatigue the line. If it breaks in flight should not be a problem just a real small vacuum leak. It would have some effect on the idle. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327324#327324 ________________________________________________________________________________
Date: Jan 18, 2011
Jack, the stromburg does not have the accelerator pump so you do need the primer. Sorry I was not clear.Gardiner ----- Original Message ---- From: Jack <jack(at)textors.com> Sent: Tue, January 18, 2011 6:26:58 AM Subject: RE: Re: Pietenpol-List: Re: Copper Primer Line Gardiner could you expand why it won't work on a Stromburg? Thanks, Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Monday, January 17, 2011 3:39 PM Subject: Re: Pietenpol-List: Re: Copper Primer Line Gary. on my corvair with a marvel ma3sb carb you really don't need a primer because the accelerator pump does the same thing. Cheers, Gardiner, this assuming you have marvel carb. Plus it won't work with the Stromburg ----- Original Message ---- From: Jerry Dotson <jdotson(at)centurylink.net> Sent: Mon, January 17, 2011 3:42:05 PM Subject: Pietenpol-List: Re: Copper Primer Line Gary I have never seen anything other than the metal line. I would not tie it down very close to the engine. The flex in your mounts might fatigue the line. If it breaks in flight should not be a problem just a real small vacuum leak. It would have some effect on the idle. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327324#327324 ________________________________________________________________________________
Date: Jan 18, 2011
Gardiner, you may wish you had a primer in addition to the accelerator pump of the Marvel Schebler. My RV-4 has a Marvel Schebler carburetor, and no primer. It is almost impossible to start it when the temperature is below 30, and I sincerely wish the builder had added a primer (it would be a real pain to add it now). Of course, if it is below 30 you probably won't be doing much flying in a Pietenpol, but if you had a set of skis like Don Emch has, you might wish you had a primer. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Tuesday, January 18, 2011 8:31 AM Subject: Re: Re: Pietenpol-List: Re: Copper Primer Line Jack, the stromburg does not have the accelerator pump so you do need the primer. Sorry I was not clear.Gardiner ----- Original Message ---- From: Jack <jack(at)textors.com> Sent: Tue, January 18, 2011 6:26:58 AM Subject: RE: Re: Pietenpol-List: Re: Copper Primer Line Gardiner could you expand why it won't work on a Stromburg? Thanks, Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Monday, January 17, 2011 3:39 PM Subject: Re: Pietenpol-List: Re: Copper Primer Line Gary. on my corvair with a marvel ma3sb carb you really don't need a primer because the accelerator pump does the same thing. Cheers, Gardiner, this assuming you have marvel carb. Plus it won't work with the Stromburg ----- Original Message ---- From: Jerry Dotson <jdotson(at)centurylink.net> Sent: Mon, January 17, 2011 3:42:05 PM Subject: Pietenpol-List: Re: Copper Primer Line Gary I have never seen anything other than the metal line. I would not tie it down very close to the engine. The flex in your mounts might fatigue the line. If it breaks in flight should not be a problem just a real small vacuum leak. It would have some effect on the idle. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327324#327324 ________________________________________________________________________________
Subject: FW: Hand propping an airplane
Date: Jan 18, 2011
Y'all be careful out there, unless you want to become ventilated like this fellow: Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: Gene & Tammy [mailto:zharvey(at)bentoncountycable.net] Sent: Tuesday, January 18, 2011 10:43 AM Subject: Fw: Hand propping an airplane Good morning Jack. Received this photo this morning from a friend in Alaska. Wonder if it should be posted on the Piet sight? I love to hand prop. For me, it is all part of flying a Piet, but like flying, it can come back and bite you, if your not very careful. What do you think? Don't want to get anything started. If you think it should be posted, feel free to do so. Gene Hand propping an airplane ..OUCH !!!! ________________________________________________________________________________
Date: Jan 18, 2011
>>> "Charles Campbell" 1/17/2011 6:23 PM >>> Tom, I have been studying the write-up and pictures of your fiberglass fuel tank. I have a couple of questions. 1). How does the tank get fastened into the center-section? Or do you just figure gravity and weight of fuel will hold it in place? 2). I notice you have assembled the center section without the metal butt joint straps and cabane fittings installed. How do you plan to weld the cabane fittings to the joint straps without setting your center section on fire? I was planning to weld the two together and fasten them to the spars before the butt ribs go on. Am I missing something here? Nice job on the tank. Another question -- 3). When joining the four sections together do you wet the mating surfaces or just let the additional layers of cloth hold them together? Charles: I'll try to answer as best I can. 1) Stainless steel straps will wrap across the top and attach to the spars front and back. The bottom was formed to fit around the two wood formers on either side so will be held in place by them and by trays glued to the front and back spars. I may also decide that straps are needed on the bottom side as those two wood formers are just butt glued to the spars. There will also be a ply bottom glued around the perimeter that will cover the tank space. 2) You got me there. I haven't looked at that part of the project yet. 3) The four sections were still tacky when they were joined together. I screwed them together with drywall screws which were later removed at the same time that the connecting holes were made in the slosh plates. Note that after the four sections were joined there are still two layers of cloth/resin that cover the entire tank so the joints are not exposed. You could probably see that the four sections did not have squared off corners but have a 1/2", more or less, radius every place that the fiberglass has to wrap around. This is necessary to retain strength in the glass fibers and to help prevent wrinkles. Therefore when the pieces are brought together there is a substantial valley formed at the joints. These valleys were filled with S-Glass strand (roving) which is just a rope of long stranded glass which is wetted out with resin and wrapped around the seam until the surface is close to flush with the tank surface. The remainder of the valley is filled with a resin/floc mix which can be smoothed out with a putty knife, etc. so that the outer layers of cloth do not bridge the valley and create a void. You can see this in the photos but I did not provide much explanation to go along with it. Tom N328X ________________________________________________________________________________
Date: Jan 18, 2011
Jack I agree with you about the primer. It squirts the gas right in the intake port and makes for less work on the starter or proper man. Also less likely to have a carb fire. I was trying to hand prop a Cessna 140 I had years ago. It was cold and the starter wouldn't turn it over because it was so cold. It had no primer but pumped the throttle. It sort of spit back and the carb and aid filter caught fire......no fire extinguisher. The only damage was requiring a new air filter. I had a rag I tried to beat it out with but when the gas that was there burned up the fire went out. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327439#327439 ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Re: FW: Hand propping an airplane
Sure makes a good case for electroic start. Gardiner --- On Tue, 1/18/11, Jack Phillips wrote: From: Jack Phillips <pietflyr(at)bellsouth.net> Subject: Pietenpol-List: FW: Hand propping an airplane Date: Tuesday, January 18, 2011, 10:59 AM =0A=0A=0A =0A =0A=0A =0A=0A =0A=0A=0A=0A=0A=0A=0A=0AY=99all be carefu l out there, unless you=0Awant to become ventilated like this fellow: =0A =0A =C2- =0A=0AJack Phillips =0A=0ANX899JP=C2- =9CIcarus Plummet =9D =0A=0ARaleigh, NC =0A=0A =C2- =0A=0A=0A=0A=0A=0A=0A=0A=0A=0AFro m: Gene & Tammy [mailto:zharvey(at)bentoncountycable.net] =0ASent: Tuesday, January 18, 2011=0A10:43 AM =0ATo: Jack Phillips =0ASubject: Fw: Hand propping an=0Aairplane =0A=0A=0A=0A =C2- =0A=0A=0A =0A=0A=0A=0A=0AGood morning Jack. =0A=0A=0A=0A=0A=0AReceived this photo thi s morning=0Afrom a friend in Alaska .=C2-=0AWonder if it should be posted on the Piet sight?=C2- I love to hand=0Aprop.=C2- For me, it is all pa rt of flying a Piet, but like flying, it can=0Acome back and bite=C2- you , if your not very careful.=C2- What do you=0Athink?=C2- Don=99t want to get anything started.=C2- If you think it should=0Abe posted, fee l free to do so. =0A=0A=0A=0A=0A=0AGene =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=C2 - =0A=0A=0A=0A=0A=0A=0A=0A=0A=0AHand propping=0Aan airplane=0A.O UCH !!!! =0A=0A =C2- =0A=0A=C2- =0A=0A=C2- =0A=0A=0A=0A=0A=0A=C2- =0A=0A=0A=0A =0A=0A=0A=0A =C2- =0A=0A=0A=0A=0A=0A=0A=0A =0A=0A =0A=0A ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Where to locate rear bottom inspection plate
I want to put the plate in because you just can not get to anything through the two side inspection plates already there. I saw Oscar's yesterday, but wanted to see where other's have located it, how big, and how you supported the plate, etc. -- John Kuhfahl, Lt Col USAF (Ret), PresIident, KUHLCOUPER LLC ________________________________________________________________________________
From: "Gene & Tammy" <zharvey(at)bentoncountycable.net>
Date: Jan 18, 2011
Gardiner, yes it does or so thought this unlucky fellow. He never learned how to properly hand prop a plane and when his battery gave out and there wasn=99t anyone around to help, he gave it a try. Gene in wet Tennessee From: airlion Sent: Tuesday, January 18, 2011 11:31 AM Subject: Re: Pietenpol-List: FW: Hand propping an airplane Sure makes a good case for electroic start. Gardiner --- On Tue, 1/18/11, Jack Phillips wrote: From: Jack Phillips <pietflyr(at)bellsouth.net> Subject: Pietenpol-List: FW: Hand propping an airplane To: pietenpol-list(at)matronics.com Date: Tuesday, January 18, 2011, 10:59 AM Y=99all be careful out there, unless you want to become ventilated like this fellow: Jack Phillips NX899JP =9CIcarus Plummet=9D Raleigh, NC ------------------------------------------------------------------------ From: Gene & Tammy [mailto:zharvey(at)bentoncountycable.net] Sent: Tuesday, January 18, 2011 10:43 AM To: Jack Phillips Subject: Fw: Hand propping an airplane Good morning Jack. Received this photo this morning from a friend in Alaska . Wonder if it should be posted on the Piet sight? I love to hand prop. For me, it is all part of flying a Piet, but like flying, it can come back and bite you, if your not very careful. What do you think? Don=99t want to get anything started. If you think it should be posted, feel free to do so. Gene Hand propping an airplane .OUCH !!!! ________________________________________________________________________________
Date: Jan 18, 2011
Obviously he did it wrong. Here's the proper technique: On Tue, Jan 18, 2011 at 7:59 AM, Jack Phillips wrot e: > Y=92all be careful out there, unless you want to become ventilated like > this fellow: > > > Jack Phillips > > NX899JP =93Icarus Plummet=94 > > Raleigh, NC > ________________________________________________________________________________
Date: Jan 18, 2011
How in the world did he get it in the back?=C2- Turned his back on it i g uess, I was told never, NEVER turn you back on a prop in rotation, and for saftey sake I always (try) to walk way out towards the wing tip when passin g from fwd to behind the prop.=C2- I was lucky one time when I was younge r and stupid (a line boy) I was proping a 150 for a guy who left his master switch on, wet ramp, he never performed a handprop operation before, basic ally a recipe for disaster.=C2- 10, 15,20 blades later I sliped and went under the plane of rotation of the prop, thank God I thought enough to let go of the blade on the way down.=C2- After that I went in, changed my pan ts, and told him to have the fbo charge his battery.=C2- =C2- Could've been me!, or anyone who gets complacant. =C2- Shad --- On Tue, 1/18/11, mike Hardaway wrote: From: mike Hardaway <bkemike(at)gmail.com> Subject: Re: Pietenpol-List: FW: Hand propping an airplane Date: Tuesday, January 18, 2011, 2:39 PM Obviously he did it wrong.=C2- Here's the proper technique: On Tue, Jan 18, 2011 at 7:59 AM, Jack Phillips wro te: Y=99all be careful out there, unless you want to become ventilated li ke this fellow: =C2- Jack Phillips NX899JP=C2- =9CIcarus Plummet=9D Raleigh, NC =0A=0A=0A ________________________________________________________________________________
Date: Jan 18, 2011
Subject: Re: Where to locate rear bottom inspection plate
Mine is 15"x9" and directly under the bellcrank. With barrel nuts screwed into the wood and machine screws holding on the cover. Have seen some twice this size which may be a good idea. rick On Tue, Jan 18, 2011 at 10:26 AM, John Kuhfahl wrote: > I want to put the plate in because you just can not get to anything through > the two side inspection plates already there. I saw Oscar's yesterday, but > wanted to see where other's have located it, how big, and how you supported > the plate, etc. > > -- > John Kuhfahl, Lt Col USAF (Ret), > PresIident, KUHLCOUPER LLC > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Hand propping an airplane
Date: Jan 18, 2011
That's a nasty picture, and a good reminder! Attached is the correct way to hand start a Corvair powered Pietenpol... Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327490#327490 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Mike Cuy
Date: Jan 18, 2011
Hey all, Haven't seen any posts from Mike Cuy in a while, and was wondering if anyone knew if everything is okay with him? If you're there Mikee, we miss your posts! Douwe ________________________________________________________________________________
Subject: Mike Cuy
Date: Jan 18, 2011
I think Mikee was in Florida for the holidays, visiting his Mom. Now he's probably snowed under (literally and figuretively) at work. Jack Phillips _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Tuesday, January 18, 2011 8:15 PM Subject: Pietenpol-List: Mike Cuy Hey all, Haven't seen any posts from Mike Cuy in a while, and was wondering if anyone knew if everything is okay with him? If you're there Mikee, we miss your posts! Douwe ________________________________________________________________________________
Date: Jan 18, 2011
On 1/18/2011 7:59 AM, Jack Phillips wrote: > > Y'all be careful out there, unless you want to become ventilated like > this fellow: > > Jack Phillips > > NX899JP "Icarus Plummet" > > Raleigh, NC > > ------------------------------------------------------------------------ > We've got a one-armed pilot whose Champ got him after about 3,000 hours of experience. It only takes once. Tie the tail EVERY TIME, chock the wheels EVERY TIME, then get ready to run like crazy if you put the throttle in the wrong position JUST THIS ONCE. That's what got our guy, who is lucky to still be alive. Darrel Jones Pfeifer Sport Sonoma, CA ________________________________________________________________________________
Subject: Re: Mike Cuy
Date: Jan 18, 2011
He post regularly on facebook. Today as a matter of fact. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327500#327500 ________________________________________________________________________________
Subject: The Airplane Speaks
Date: Jan 18, 2011
Sometimes great stuff comes from the craziest places! http://etext.lib.virginia.edu/toc/modeng/public/BarAero.html Clif ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG FORSCOM" <steven.d.dortch(at)us.army.mil>
Date: Jan 19, 2011
Subject: Pfeifer Sport
Darrel, I notice that you list a Pfeifer Sport. What does the Pfeifer fly like? What are the numbers esp as compared to a Pietenpol. Blue Skies, Steve D ----- Original Message ----- From: Darrel Jones <wd6bor(at)vom.com> Date: Wednesday, January 19, 2011 4:43 Subject: Re: Pietenpol-List: FW: Hand propping an airplane > On 1/18/2011 7:59 AM, Jack Phillips wrote: > > > > Y'all be careful out there, unless you want to become ventilated > like > > this fellow: > > > > Jack Phillips > > > > NX899JP "Icarus Plummet" > > > > Raleigh, NC > > > > ----------------------------------------------------------------- > ------- > > > We've got a one-armed pilot whose Champ got him after about 3,000 > hours > of experience. It only takes once. Tie the tail EVERY TIME, chock > the > wheels EVERY TIME, then get ready to run like crazy if you put the > throttle in the wrong position JUST THIS ONCE. That's what got our > guy, > who is lucky to still be alive. > > Darrel Jones > Pfeifer Sport > Sonoma, CA ________________________________________________________________________________
Date: Jan 19, 2011
Thanks Rick. No one else responded to this, but I guess I'll just make my own decision. Thanks for your input. John On Tue, Jan 18, 2011 at 2:58 PM, Rick Holland wrote: > Mine is 15"x9" and directly under the bellcrank. With barrel nuts screwed > into the wood and machine screws holding on the cover. Have seen some twice > this size which may be a good idea. > > rick > > On Tue, Jan 18, 2011 at 10:26 AM, John Kuhfahl wrote: > >> I want to put the plate in because you just can not get to anything >> through the two side inspection plates already there. I saw Oscar's >> yesterday, but wanted to see where other's have located it, how big, and how >> you supported the plate, etc. >> >> -- >> John Kuhfahl, Lt Col USAF (Ret), >> PresIident, KUHLCOUPER LLC >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > -- John Kuhfahl, Lt Col USAF (Ret), PresIident, KUHLCOUPER LLC ________________________________________________________________________________
Date: Jan 19, 2011
John, I didn't respond because I had just posted a picture of my access panel last week and assumed you had seen it. Here it is again: Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Kuhfahl Sent: Wednesday, January 19, 2011 6:38 AM Subject: Re: Pietenpol-List: Where to locate rear bottom inspection plate Thanks Rick. No one else responded to this, but I guess I'll just make my own decision. Thanks for your input. John On Tue, Jan 18, 2011 at 2:58 PM, Rick Holland wrote: Mine is 15"x9" and directly under the bellcrank. With barrel nuts screwed into the wood and machine screws holding on the cover. Have seen some twice this size which may be a good idea. ________________________________________________________________________________
Subject: Flying to Brodhead
Date: Jan 19, 2011
Oscar, My son lives in Marion, IA. I let him base my Aeronca over there at the Mar ion Airport a few years ago, for the summer. This is a privately owned airp ort (the only one that is open to the public in the whole state they claim) and is run by a husband and wife team. As I remember, they generally have a few open T hangars available whenever I go over there. No great shakes bu t your Piet would be out of the rain and hail. You could give them a call a nd see what the situation is. Whenever I asked if I could leave my airplane there overnite (tie down) they were accommodating. The first names of the owners are Pat and Perry I believe. I hear they recently almost sold out to the city for an industrial park, but couldn't work out a deal. They have a nice fly-in there every June and the whole town comes out for breakfast. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Jan 19, 2011
Thanks Jack--new to list. I need to figure out how to use archives? Sorry to be a newbee pain. John On Wed, Jan 19, 2011 at 6:10 AM, Jack Phillips wrot e: > John, > > > I didn=92t respond because I had just posted a picture of my access panel > last week and assumed you had seen it. Here it is again: > > > Jack Phillips > > NX899JP =93Icarus Plummet=94 > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *John Kuhfahl > *Sent:* Wednesday, January 19, 2011 6:38 AM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: Where to locate rear bottom inspection > plate > > > Thanks Rick. No one else responded to this, but I guess I'll just make m y > own decision. Thanks for your input. John > > On Tue, Jan 18, 2011 at 2:58 PM, Rick Holland wrote: > > Mine is 15"x9" and directly under the bellcrank. With barrel nuts screwed into the wood and machine screws holding on the cover. Have seen some twic e this size which may be a good idea. > > > ** > > * * > > -- John Kuhfahl, Lt Col USAF (Ret), PresIident, KUHLCOUPER LLC ________________________________________________________________________________
Date: Jan 19, 2011
My inspection plate goes from the rear of the plywood floor, all the way back to the next cross-member where the bellcrank is. Its made of aluminum and provides excellent access to my bellcrank fittings and the pulleys on the seatback where the elevator cables come through. Its not nearly as elegant as Jack's, but it works. Ben Charvet NX866BC On 1/19/2011 6:38 AM, John Kuhfahl wrote: > Thanks Rick. No one else responded to this, but I guess I'll just > make my own decision. Thanks for your input. John > > On Tue, Jan 18, 2011 at 2:58 PM, Rick Holland > wrote: > > Mine is 15"x9" and directly under the bellcrank. With barrel nuts > screwed into the wood and machine screws holding on the cover. > Have seen some twice this size which may be a good idea. > > rick > > On Tue, Jan 18, 2011 at 10:26 AM, John Kuhfahl > > wrote: > > I want to put the plate in because you just can not get to > anything through the two side inspection plates already there. > I saw Oscar's yesterday, but wanted to see where other's have > located it, how big, and how you supported the plate, etc. > > -- > John Kuhfahl, Lt Col USAF (Ret), > PresIident, KUHLCOUPER LLC > > * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > > > -- > John Kuhfahl, Lt Col USAF (Ret), > PresIident, KUHLCOUPER LLC > * > > > * ________________________________________________________________________________
Subject: Center section butt ribs
Date: Jan 19, 2011
On the three piece wing center section ribs, I see nothing in the plans to indicate that they should be sheathed on one side with plywood or receive extra diagonals and gussets as the wing end ribs call for. However, in looking at all the pictures I could find, it appears many do so. What's up with that? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327537#327537 ________________________________________________________________________________
Date: Jan 19, 2011
I wonder what other builders of 3-piece wings have done on what I call the center section joint strap/cabane fittings problem? I just don't see how Tom is going to put that subassembly in place without practically destroying the butt ribs. ----- Original Message ----- From: TOM STINEMETZE To: pietenpol-list(at)matronics.com Sent: Tuesday, January 18, 2011 11:50 AM Subject: Re: Pietenpol-List: cloth used for Fiberglass fuel tank >>> "Charles Campbell" 1/17/2011 6:23 PM >>> Tom, I have been studying the write-up and pictures of your fiberglass fuel tank. I have a couple of questions. 1). How does the tank get fastened into the center-section? Or do you just figure gravity and weight of fuel will hold it in place? 2). I notice you have assembled the center section without the metal butt joint straps and cabane fittings installed. How do you plan to weld the cabane fittings to the joint straps without setting your center section on fire? I was planning to weld the two together and fasten them to the spars before the butt ribs go on. Am I missing something here? Nice job on the tank. Another question -- 3). When joining the four sections together do you wet the mating surfaces or just let the additional layers of cloth hold them together? Charles: I'll try to answer as best I can. 1) Stainless steel straps will wrap across the top and attach to the spars front and back. The bottom was formed to fit around the two wood formers on either side so will be held in place by them and by trays glued to the front and back spars. I may also decide that straps are needed on the bottom side as those two wood formers are just butt glued to the spars. There will also be a ply bottom glued around the perimeter that will cover the tank space. 2) You got me there. I haven't looked at that part of the project yet. 3) The four sections were still tacky when they were joined together. I screwed them together with drywall screws which were later removed at the same time that the connecting holes were made in the slosh plates. Note that after the four sections were joined there are still two layers of cloth/resin that cover the entire tank so the joints are not exposed. You could probably see that the four sections did not have squared off corners but have a 1/2", more or less, radius every place that the fiberglass has to wrap around. This is necessary to retain strength in the glass fibers and to help prevent wrinkles. Therefore when the pieces are brought together there is a substantial valley formed at the joints. These valleys were filled with S-Glass strand (roving) which is just a rope of long stranded glass which is wetted out with resin and wrapped around the seam until the surface is close to flush with the tank surface. The remainder of the valley is filled with a resin/floc mix which can be smoothed out with a putty knife, etc. so that the outer layers of cloth do not bridge the valley and create a void. You can see this in the photos but I did not provide much explanation to go along with it. Tom N328X ________________________________________________________________________________
Date: Jan 19, 2011
I plan on using a method called out in the Boredom Fighter plans by Don Wolf. Sew Dacron tape to each side of two 18-inch zippers with excess protruding past each end (to be trimmed at installation). Cover the teeth with masking tape and install during tape application of the covering process. When cover and painting is done, remove masking tape, open zippers and cut fabric underneath with a razor blade. I found that Polyfiber remained flexible enough not to crack after numerous annuals (or condition inspections) and this provided plenty of access. I tied the two zipper pulls together with rib-lacing cord during operation. I did no engineering or calculations and no numbers were harmed during application or use. Use at your own peril. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327551#327551 Attachments: http://forums.matronics.com//files/zippers_108.bmp ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: Center section butt ribs
The wingtip end ribs need the extra verticals to keep the covering from warping the rib down when the fabric is stretched. I put a 2 inch wide strip of 1/16 in plywood sheeting on the flight surfaces of my center section end ribs to keep the covering from pulling them outward when stretched. I still got a little bit of a warp on the top of the wing after the fabric was fully stretched. The butt end of the wing I just covered in fabric, and put the verticals in there too, but dont think they are necessary. Ben Charvet NX866BC Nearly time for my first annual condition insp. On 1/19/2011 8:10 AM, Kringle wrote: > --> Pietenpol-List message posted by: "Kringle" > > On the three piece wing center section ribs, I see nothing in the plans to indicate that they should be sheathed on one side with plywood or receive extra diagonals and gussets as the wing end ribs call for. However, in looking at all the pictures I could find, it appears many do so. What's up with that? > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327537#327537 > > ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: flying to Brodhead
Oscar I have some friends in the Stillwater, OK, area who might be able to help you out. Give me a shout - email - _dog67(at)aol.com_ (mailto:dog67(at)aol.com) Jonathan Apflebaum In a message dated 1/18/2011 8:50:56 P.M. Mountain Standard Time, taildrags(at)hotmail.com writes: --> Pietenpol-List message posted by: Oscar Zuniga Howdy, Low 'n' Slow fliers- It's looking real tough for me to take off the time needed to make it to Brodhead without some creative planning. I simply won't have enough vacation time saved up by July to do it the way I'd like. What I'm thinking now is that I may need to move the airplane up there in stages. First stage would be to fly up to Oklahoma some weekend this summer and leave the airplane with a 'friendly' somewhere. Fly commercial back to San Antonio. Flying commercial would mean I'd need to find a place around Tulsa probably, where I could park "Scout" for a couple of weekends and still have good commercial connections. Next leg would involve flying commercial back to OK and then flying Scout to the Cedar Rapids, Iowa area over a weekend... I have friends there but nobody with a hangar (yet). Best choice would be Marion Airport (C-17), Iowa. Anybody near there have a place I could stash a Piet for a few weeks this summer? I could catch a commercial flight out of Cedar Rapids back to San Antonio and then sit it out until the weekend of Brodhead, when I'd fly commercial back out and then make my triumphal entry into the hallowed Brodhead airspace in 41CC for the weekend. I have no idea how I'd ever get the airplane back, but what the heck- maybe I could sell it at Brodhead and be done with this low and slow business ;o) It's a lot of trigger-work but I don't know how else I can do it. My wife and I have worked out this understanding where I can play with airplanes as long as I take her on trips every couple of months, so that's been burning up my vacation time from work. Wish I could retire ;o) And for what it's worth, I only weigh 155 lbs. but it sure doesn't seem to be getting me anywhere in life to keep my weight, cholesterol, and blood pressure where the doc says they should be. I should just get me a little cabana on a beach in Belize, build me a cheap Air Camper out of hardware store stuff, and sit back on the beach, drink beer and eat fried calamari and forget about doctors and medicals from now on. Take a sunset flight in my junker Camper every now and then and never worry about feds, docs, or the IRS. do not archive Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Jan 19, 2011
Subject: whereabouts
Jack Phillips is correct, went to see my 87 year old Mom over the weekend w ith my brother down south and have been buried at work and after hours but do monitor the list from time to time but haven't read any posts lately. I'm in hibernation mode waiting for Ground Hog Day to see if I see my shado w or not :) Mike C. ________________________________________________________________________________
Date: Jan 19, 2011
Charles: This issue doe not seem to be substantially different than the problem of welding the bushings and anchor lugs on the lower front strut/landing gear fittings. In both cases it involves welding the fittings without starting the wood burning. The way I did the lower gear fittings was to jig it all up on the fuselage and then just "tack" weld the parts together with a MIG welder. By "tack" I mean to just touch it lightly. Then, you take the assembly back off, move to your weld table, and complete the weld. You may end up with a couple of little dark places in the wood but no serious charring. In the case of the strap/cabane fittings you could probably bolt everything in place for alignment and then put a dab of JB WELD on each side to hold the alignment for final finish welding if you wanted to do it all with gas. From experience the JB WELD will turn loose with the heat application and will come off easily. You will want to wear a respirator of some sort though since the JB WELD will turn loose some nasty gasses when heated. Stinemetze N328X >>> "Charles Campbell" 1/19/2011 8:32 AM >>> I wonder what other builders of 3-piece wings have done on what I call the center section joint strap/cabane fittings problem? I just don't see how Tom is going to put that subassembly in place without practically destroying the butt ribs. ________________________________________________________________________________
Date: Jan 19, 2011
Thanks Ben, that's pretty much how the plan looks. Do you glue the uprights to the spars? The plan shows nails only. If they are glued it would look to me to be a pretty messy job being how they have to slide on and the tight fit. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327603#327603 ________________________________________________________________________________
Date: Jan 19, 2011
I added 1/16-inch plywood to the center section end ribs in case I use it as a storage locker instead of a fuel tank. I did not use it on the wing panels. I added braces to the end ribs like the plans show. Also, I glued the ribs to the spars because I didn't know some people say not to. I'm not sure the correct answer. Chris -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327607#327607 ________________________________________________________________________________
Date: Jan 19, 2011
What are the pros and cons of putting a fuel tank in the wing or using it for storage? What are most doing? Attached a couple of pics of my progress. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327610#327610 Attachments: http://forums.matronics.com//files/progress_007_2_218.jpg http://forums.matronics.com//files/progress_001_2_692.jpg ________________________________________________________________________________
Date: Jan 19, 2011
Pros: 1) Center of Gravity does not change as fuel is burned. 2) You can always have a nose tank (header tank) in addition if you want extra range or put your storage area in the nose. Cons: 1) Any fuel you spill goes directly into the pilot's seat where it lies in wait; 2) You have to have a ladder to get the fuel up there. 3) Unsightly hoses, valves, fuel guage, etc. hanging down below the wing (and directly over the passenger's head.) Hum, that seems to come out in favor of putting the tank in the nose which is probably why I chose to put mine in the center section. Stinemetze >>> "Kringle" 1/19/2011 3:32 PM >>> What are the pros and cons of putting a fuel tank in the wing or using it for storage? What are most doing? ________________________________________________________________________________
Date: Jan 19, 2011
Hey John You may have thought this through already, but just in case: drill before gluing. It's a lot easier to drill the center section spars for the straps and other hardware BEFORE you glue the ribs and other bracing in place. I drilled after glueing and it was hard to measure and drill accurately with all that stuff in the way. Ken On Wed, Jan 19, 2011 at 3:32 PM, Kringle wrote: > > What are the pros and cons of putting a fuel tank in the wing or using it > for storage? What are most doing? > > Attached a couple of pics of my progress. > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327610#327610 > > > Attachments: > > http://forums.matronics.com//files/progress_007_2_218.jpg > http://forums.matronics.com//files/progress_001_2_692.jpg > > -- Ken Chambers 512-796-1798 ________________________________________________________________________________
Date: Jan 19, 2011
Good point Ken. That was my plan but I was trying to see how things were going to fit together. Kinda fun actually putting some parts together! -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327617#327617 ________________________________________________________________________________
Date: Jan 19, 2011
One other benefit to the tank in the CC is more fuel pressure, which is probably why I did a nose tank. Actually fuel pressure is plenty with a nose tank. On Wed, Jan 19, 2011 at 2:53 PM, TOM STINEMETZE wrote: > *Pros: 1) Center of Gravity does not change as fuel is burned. 2) You > can always have a nose tank (header tank) in addition if you want extra > range or put your storage area in the nose.* > *Cons: 1) Any fuel you spill goes directly into the pilot's seat where it > lies in wait; 2) You have to have a ladder to get the fuel up there. 3) > Unsightly hoses, valves, fuel guage, etc. hanging down below the wing (and > directly over the passenger's head.)* > ** > *Hum, that seems to come out in favor of putting the tank in the nose > which is probably why I chose to put mine in the center section.* > ** > *Stinemetze* > > > >>> "Kringle" 1/19/2011 3:32 PM >>> > What are the pros and cons of putting a fuel tank in the wing or using it > for storage? What are most doing? > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: Re: Come on!!!: flying to Brodhead
Date: Jan 19, 2011
Jim - I actually made it to southern KS last year on Day 1, though the intended stopover was vicinity OKC. If you're serious, we can go via Pryor this year. It's not out of the way. Shelley should be making the trip with me by car this time (solo last year on the way up, she was with me on the way back). If your friend is okay with me landing there we'd probably buy you guys dinner & reebs. We're set up to camp so we're self-sustaining. Have you met Shelley? Oh, heck, we've never met in person, have we! Well, we can fix that. All contingent on the valve-eating, crank-snapping corvair behaving, and not getting screwed by work! -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327627#327627 ________________________________________________________________________________
Date: Jan 19, 2011
Subject: Re: Pfeifer Sport
Steven, The Pfeifer Sport is a steel tube version of the Pietenpol. As such, it flies like a Bucker Jungmeister and is about fifty miles an hour faster. Just kidding. It flies just like a Piet, which is pretty nice. Darrel On 1/19/2011 1:55 AM, Dortch, Steven D MAJ NG NG FORSCOM wrote: > --> Pietenpol-List message posted by: "Dortch, Steven D MAJ NG NG FORSCOM" > > Darrel, I notice that you list a Pfeifer Sport. What does the Pfeifer fly like? What are the numbers esp as compared to a Pietenpol. > > Blue Skies, > Steve D > > ----- Original Message ----- > From: Darrel Jones<wd6bor(at)vom.com> > Date: Wednesday, January 19, 2011 4:43 > Subject: Re: Pietenpol-List: FW: Hand propping an airplane > To: pietenpol-list(at)matronics.com > > >> On 1/18/2011 7:59 AM, Jack Phillips wrote: >>> Y'all be careful out there, unless you want to become ventilated >> like >>> this fellow: >>> >>> Jack Phillips >>> >>> NX899JP "Icarus Plummet" >>> >>> Raleigh, NC >>> >>> ----------------------------------------------------------------- >> ------- >> We've got a one-armed pilot whose Champ got him after about 3,000 >> hours >> of experience. It only takes once. Tie the tail EVERY TIME, chock >> the >> wheels EVERY TIME, then get ready to run like crazy if you put the >> throttle in the wrong position JUST THIS ONCE. That's what got our >> guy, >> who is lucky to still be alive. >> >> Darrel Jones >> Pfeifer Sport >> Sonoma, CA > > ________________________________________________________________________________
Date: Jan 19, 2011
If I'm serious????? I couldn't be MORE serious! Of course I'm serious! Come on.... Using the airstrip will be fine. We've had a couple piet friends fly through the area and we're always welcome. Wish I had known you were flying anywhere near here (Kansas is...sorta) last year. I would have insisted you swing by this way. Ok, enough talk....you guys get your flight plans done and make SURE we're on the route. Plenty of room to stay and all are welcome. One tiny little issue maybe...I may be out of town that week. You're still welcome but I'll say my prayers just to be sure! Something tells me this is MY Brodhead year!!! Dang, I'm nowhere NEAR flying mine up there and all this talk is getting me excited! jm -----Original Message----- >From: kevinpurtee <kevin.purtee(at)us.army.mil> >Sent: Jan 19, 2011 7:00 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Come on!!!: flying to Brodhead > > >Jim - I actually made it to southern KS last year on Day 1, though the intended stopover was vicinity OKC. > >If you're serious, we can go via Pryor this year. It's not out of the way. Shelley should be making the trip with me by car this time (solo last year on the way up, she was with me on the way back). If your friend is okay with me landing there we'd probably buy you guys dinner & reebs. We're set up to camp so we're self-sustaining. > >Have you met Shelley? Oh, heck, we've never met in person, have we! Well, we can fix that. > >All contingent on the valve-eating, crank-snapping corvair behaving, and not getting screwed by work! > >-------- >Kevin "Axel" Purtee >NX899KP >Austin/Georgetown, TX > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=327627#327627 > > ________________________________________________________________________________
Date: Jan 19, 2011
I have a PDF copy of the March 1976 Sport Aviation article on Joe Pfiefer. Really interesting reading for anyone interested in the Pfiefer Sport (WITH a Corvair engine!). Let me know offlist if anyone wants a copy and I'll email it to you. jm -----Original Message----- >From: Darrel Jones <wd6bor(at)vom.com> >Sent: Jan 19, 2011 8:52 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Pfeifer Sport > > >Steven, > >The Pfeifer Sport is a steel tube version of the Pietenpol. As such, it >flies like a Bucker Jungmeister and is about fifty miles an hour faster. >Just kidding. It flies just like a Piet, which is pretty nice. > >Darrel > > >On 1/19/2011 1:55 AM, Dortch, Steven D MAJ NG NG FORSCOM wrote: >> --> Pietenpol-List message posted by: "Dortch, Steven D MAJ NG NG FORSCOM" >> >> Darrel, I notice that you list a Pfeifer Sport. What does the Pfeifer fly like? What are the numbers esp as compared to a Pietenpol. >> >> Blue Skies, >> Steve D >> >> ----- Original Message ----- >> From: Darrel Jones<wd6bor(at)vom.com> >> Date: Wednesday, January 19, 2011 4:43 >> Subject: Re: Pietenpol-List: FW: Hand propping an airplane >> To: pietenpol-list(at)matronics.com >> >> >>> On 1/18/2011 7:59 AM, Jack Phillips wrote: >>>> Y'all be careful out there, unless you want to become ventilated >>> like >>>> this fellow: >>>> >>>> Jack Phillips >>>> >>>> NX899JP "Icarus Plummet" >>>> >>>> Raleigh, NC >>>> >>>> ----------------------------------------------------------------- >>> ------- >>> We've got a one-armed pilot whose Champ got him after about 3,000 >>> hours >>> of experience. It only takes once. Tie the tail EVERY TIME, chock >>> the >>> wheels EVERY TIME, then get ready to run like crazy if you put the >>> throttle in the wrong position JUST THIS ONCE. That's what got our >>> guy, >>> who is lucky to still be alive. >>> >>> Darrel Jones >>> Pfeifer Sport >>> Sonoma, CA >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Model A Mag drive
Date: Jan 20, 2011
Listers, Here is a copy of an email I just sent to Larry Morlock detailing my 2nd ma g drive troubles, after he inquired about it. Hi Larry, I had 13 hours on her (in flight). Maybe another 10 on the ground. During t he flight the trouble occurred, I had checked the mags (in flight) individu ally before I left the proximity of the airport. All seemed well so I ventu red out. The engine started running rough, and I checked the mags to discov er that the cam gear-driven mag appeared to be completely dead. As of this date, I am still unsure why the engine continued running rough after I shut off that mag, and switched over to the crank mag. That is still a mystery to me. The only thing I can think of, is that in my panic, maybe I left the switch on "both" and the cam-driven mag was catching periodically (because of the partial tooth situation) and it was sending wild sparks in there. So I am not quite sure even now what happened, or exactly when. As you can see from the photos about 30% of the gear teeth are completely cracked off. The remaining teeth appear to be "worn" off. This is my speculation: There was insufficient clearance between the aluminum timing gear and the steel magneto gear. I had no trouble inserting and mounting that magneto at all, so no red flags were raised at that time. In my ignorance, I did not check the clearance between the gears. Over a period of hours, pressure was exert ed onto the aluminum gear teeth and the metal failed on a number of the tee th, either from fatigue, or just the continued "mooshing" of the steel mag gear teeth against the aluminum teeth. When I contacted Ken Perkins, he speculated the same, and said the fix was adding shims (or extra gasket thickness) between the mag housing (casting t hat the mag is bolted to) and the engine block to achieve a clearance of fo ur thousandths. This action would necessarily give more clearance between t he two gears in question. But upon further examination, this action creates another problem. It is kind of hard to explain in an email, but there are three bolt holes that would have to be elongated, in the flat timing gear c over, in order to allow those three timing gear cover bolts to line up with the holes in the back of the engine block. I guess this would not be that big of a deal because only a few thousands of an inch would be needed. I myself have decided to go in another direction as far as the 2nd (redunda nt) ignition system goes (mostly to satisfy my wife). The Model A car suppl iers sell an electronic ignition module that drops into a traditional distr ibutor body. It will appear to be a stock Model A ignition system. Downside for me, is that I need a battery. I found a light weight battery at Wicks (4.4 lbs) that I will use. Another hang up is how is it recharged? I will m aybe get a solar cell to put out when I am on the ground. Who knows, after you have proven the viability of the Perkins mag drive, I might go back to that! BTW Falluca told me that the aluminum gear should have had no problem with this set-up if clearances were correct. I think you would be wise to, during your on-ground break-in period, perio dically remove that mag and peer in there to closely inspect that gear to s ee how it is doing. BTW, there was no apparent wear or damage that I can de tect on the steel mag gear. I am willing to send you this aluminum gear for your close inspection. You may be able to glean some clues upon close examination. Let me know and I w ill UPS or mail it over to you. Please ask me more specific questions if you have them, and I will be more than glad to help however I can. Dan ________________________________________________________________________________
Date: Jan 20, 2011
Subject: Fuel tank placement. was Center section butt ribs
I have the nose tank, and the effect of fuel burn off is barely noticeable as far as pitch trim. Ben On 1/19/2011 4:53 PM, TOM STINEMETZE wrote: > *Pros: 1) Center of Gravity does not change as fuel is burned. 2) > You can always have a nose tank (header tank) in addition if you want > extra range or put your storage area in the nose.* > *Cons: 1) Any fuel you spill goes directly into the pilot's seat where > it lies in wait; 2) You have to have a ladder to get the fuel up > there. 3) Unsightly hoses, valves, fuel guage, etc. hanging down > below the wing (and directly over the passenger's head.)* > ** > *Hum, that seems to come out in favor of putting the tank in the nose > which is probably why I chose to put mine in the center section.* > ** > *Stinemetze* > * > * > >>> "Kringle" 1/19/2011 3:32 PM >>> > What are the pros and cons of putting a fuel tank in the wing or using > it for storage? What are most doing? > * > > > * ________________________________________________________________________________
Date: Jan 20, 2011
Subject: Re: access panel for bellcrank
John, I left the second bay behind the seat back on the bottom of the fuselage uncovered and made an cover out of aluminum sheet to cover it. I simply screwed it in with #6 x 1/2" stainless wood screws. It gives great access to those four elevator turnbuckles that I have directly connecting the elevator cables to the bellcrank. Matt Paxton On Tue, Jan 18, 2011 at 10:26 AM, John Kuhfahl wrote: > >> I want to put the plate in because you just can not get to anything >> through the two side inspection plates already there. I saw Oscar's >> yesterday, but wanted to see where other's have located it, how big, and how >> you supported the plate, etc. >> >> -- >> John Kuhfahl, Lt Col USAF (Ret), >> PresIident, KUHLCOUPER LLC ________________________________________________________________________________
Subject: Re: Model A Mag drive
Date: Jan 20, 2011
Hey Dan ... i was thinking the same thing... but with the FSI distributor... it has centrifugal advance that is a full 28 deg at 1750 rpm there is another distributor drive coming out from the secrets of speed guys... uses a VW distributor on the timing cover with a separate gear .. http://www.secretsofspeed.com/IGNITIONS.htm looks pretty cool.. i gave my engine to Rich from antique engine rebuilders at the local model a swap meet last weekend... we talked about your troubles a bit.. looking forward to hanging it on the nose jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327685#327685 ________________________________________________________________________________
Date: Jan 20, 2011
Got electronic ignition on my auto engine Piet, but its a CSC. rick On Thu, Jan 20, 2011 at 9:58 AM, bender wrote: > jfaith(at)solairusaviation.com> > > Hey Dan ... i was thinking the same thing... but with the FSI > distributor... it has centrifugal advance that is a full 28 deg at 1750 rpm > there is another distributor drive coming out from the secrets of speed > guys... uses a VW distributor on the timing cover with a separate gear .. > http://www.secretsofspeed.com/IGNITIONS.htm > looks pretty cool.. > i gave my engine to Rich from antique engine rebuilders at the local model > a swap meet last weekend... we talked about your troubles a bit.. > looking forward to hanging it on the nose > > jeff > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327685#327685 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 20, 2011
Here's another thought. The Aerovee guys run a very simple fixed advance s econdary. Don't know much about it except it's very simple. I believe the y only run one set of plugs too. Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Re: Model A Mag drive > From: jfaith(at)solairusaviation.com > Date: Thu=2C 20 Jan 2011 08:58:21 -0800 > To: pietenpol-list(at)matronics.com > om> > > Hey Dan ... i was thinking the same thing... but with the FSI distributor ... it has centrifugal advance that is a full 28 deg at 1750 rpm > there is another distributor drive coming out from the secrets of speed g uys... uses a VW distributor on the timing cover with a separate gear .. > http://www.secretsofspeed.com/IGNITIONS.htm > looks pretty cool.. > i gave my engine to Rich from antique engine rebuilders at the local mode l a swap meet last weekend... we talked about your troubles a bit.. > looking forward to hanging it on the nose > > jeff > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327685#327685 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jan 20, 2011
Aerovee uses dual electronic ignition and dual plugs. On Thu, Jan 20, 2011 at 12:57 PM, Doug Dever wrote: > Here's another thought. The Aerovee guys run a very simple fixed advance > secondary. Don't know much about it except it's very simple. I believe > they only run one set of plugs too. > > Doug Dever > In beautiful Stow Ohio > > > > Subject: Pietenpol-List: Re: Model A Mag drive > > From: jfaith(at)solairusaviation.com > > Date: Thu, 20 Jan 2011 08:58:21 -0800 > > To: pietenpol-list(at)matronics.com > > > > jfaith(at)solairusaviation.com> > > > > Hey Dan ... i was thinking the same thing... but with the FSI > distributor... it has centrifugal advance that is a full 28 deg at 1750 rpm > > there is another distributor drive coming out from the secrets of speed > guys... uses a VW distributor on the timing cover with a separate gear .. > > http://www.secretsofspeed.com/IGNITIONS.htm > > looks pretty cool.. > > i gave my engine to Rich from antique engine rebuilders at the local > model a swap meet last weekend... we talked about your troubles a bit.. > > looking forward to hanging it on the nose > > > > jeff > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=327685#327685 > > > > > = Archive Search & Download, 7-Day Browse, Chat, FAQ, > &g==================== > > _==== > > > > > > > > > * > > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 20, 2011
You are correct The Aerovee actually uses 4 modules and yes it uses dual p lugs. I was thinking of the Great Plains VW. They have a fixed secondary. Doug Dever In beautiful Stow Ohio Date: Thu=2C 20 Jan 2011 14:07:43 -0700 Subject: Re: Pietenpol-List: Re: Model A Mag drive From: at7000ft(at)gmail.com Aerovee uses dual electronic ignition and dual plugs. On Thu=2C Jan 20=2C 2011 at 12:57 PM=2C Doug Dever wrote: Here's another thought. The Aerovee guys run a very simple fixed advance s econdary. Don't know much about it except it's very simple. I believe the y only run one set of plugs too. Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Re: Model A Mag drive > From: jfaith(at)solairusaviation.com > Date: Thu=2C 20 Jan 2011 08:58:21 -0800 > To: pietenpol-list(at)matronics.com > om> > > Hey Dan ... i was thinking the same thing... but with the FSI distributor ... it has centrifugal advance that is a full 28 deg at 1750 rpm > there is another distributor drive coming out from the secrets of speed g uys... uses a VW distributor on the timing cover with a separate gear .. > http://www.secretsofspeed.com/IGNITIONS.htm > looks pretty cool.. > i gave my engine to Rich from antique engine rebuilders at the local mode l a swap meet last weekend... we talked about your troubles a bit.. > looking forward to hanging it on the nose > > jeff > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327685#327685 > > = Archive Search & Download=2C 7-Day Browse=2C Chat=2C FAQ=2C &g==================== > _===== > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock=2C Colorado "Logic is a wreath of pretty flowers=2C that smell bad" ________________________________________________________________________________
Date: Jan 21, 2011
Could the turtleneck be made to be removable Like on a Jenny? -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327804#327804 ________________________________________________________________________________
Date: Jan 21, 2011
It probably could be, Earl. I think someone here on this list has actually done that but I can't remember who. I've been thinking about doing the same thing when I get to the point of building my fuselage (which at the rate I'm going is YEARS down the road). -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327812#327812 ________________________________________________________________________________
Subject: Re: How about this idea?
Date: Jan 21, 2011
What would be the benefits of steel strips embedded in wood? -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327818#327818 ________________________________________________________________________________
Subject: Re: cloth used for Fiberglass fuel tank
Date: Jan 21, 2011
My Fiberglas tank .... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327819#327819 Attachments: http://forums.matronics.com//files/ft0008_744.jpg ________________________________________________________________________________
Date: Jan 21, 2011
Do you have pics of how you made your tank? Looks real nice. Brian SLC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of womenfly2 Sent: Friday, January 21, 2011 2:36 PM Subject: Pietenpol-List: Re: cloth used for Fiberglass fuel tank My Fiberglas tank .... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327819#327819 Attachments: http://forums.matronics.com//files/ft0008_744.jpg ________________________________________________________________________________
Date: Jan 21, 2011
OK. Thanks. Sometimes it's hard to tell. At a forum on ornithopters I attended at Oskhosh some years ago, the presenter extolled the astounding performance of living birds, claiming at one point that some birds could maintain level flight indefinitely, in perfectly still air, without flapping their wings. I approached him after the forum and asked him how these birds could attain an infinite glide ratio, seemingly against the laws of aerodynamics. He responded, "Feathers." When I asked how feathers could do this, he clarified with great exuberance but also in perfect seriousness, "Negative drag!" I smiled courteously and walked off. -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327833#327833 ________________________________________________________________________________
Date: Jan 21, 2011
By the way, the idea in the OP would work. Really it would. Just use titanium instead of steel, by virtue of which you obtain "Negative Weight." 8) -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327834#327834 ________________________________________________________________________________
Date: Jan 22, 2011
Pilot78 ... see my Web Site. Cheers. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327867#327867 ________________________________________________________________________________
Date: Jan 22, 2011
Aluminum tube with riveted gusset plates ...... ? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327868#327868 ________________________________________________________________________________
Date: Jan 22, 2011
I do believe that some of these folks are beginning to show signs of cabin fever... Perhaps a foam and glass Piet would be best? (Cough, Cough, splutter, choke!) Brett ________________________________________________________________________________
Subject: Rib question
Date: Jan 22, 2011
Simple question, but need some help. I originally was planning on building the FGM wing or perhaps the one part wing which I understood as having 28 ribs. I've reconsidered and will be building the 3-piece wing and am waiting for the plans I ordered from Don Pietenpol. I have 30 ribs completed (2 more than were needed for the one-piece wing). Is this enough for the 3-piece wing or do I need to make a few more? For reference, I did build the rib from the full-size plan I received from Don Pietenpol last September. Thanks for any input. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327883#327883 ________________________________________________________________________________
Date: Jan 22, 2011
Yes, Tom, that's the correct count, however, I find it difficult to believe that you built 30 ribs since September. It's been almost 3 years and I'm only on #24...! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) -----Original Message----- From: Gboothe5 [mailto:gboothe5(at)comcast.net] Sent: Saturday, January 22, 2011 10:50 AM Subject: FW: Pietenpol-List: Rib question -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tdudley(at)umn.edu Sent: Saturday, January 22, 2011 7:52 AM Subject: Pietenpol-List: Rib question Simple question, but need some help. I originally was planning on building the FGM wing or perhaps the one part wing which I understood as having 28 ribs. I've reconsidered and will be building the 3-piece wing and am waiting for the plans I ordered from Don Pietenpol. I have 30 ribs completed (2 more than were needed for the one-piece wing). Is this enough for the 3-piece wing or do I need to make a few more? For reference, I did build the rib from the full-size plan I received from Don Pietenpol last September. Thanks for any input. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327883#327883 ________________________________________________________________________________
From: "Scott Knowlton " <flyingscott_k(at)hotmail.com>
Date: Jan 22, 2011
Subject: Re: Rib question
I just finished my ribs and the count is 14 per wing plus two full ribs in the center section plus an additional two tail ribs and one nose rib for the center section. Your 30 full ribs is fine but you need those nose and tail ribs eventually. Scott Knowlton -----Original Message----- From: tdudley(at)umn.edu Date: Sat, 22 Jan 2011 15:52:09 Subject: Pietenpol-List: Rib question Simple question, but need some help. I originally was planning on building the FGM wing or perhaps the one part wing which I understood as having 28 ribs. I've reconsidered and will be building the 3-piece wing and am waiting for the plans I ordered from Don Pietenpol. I have 30 ribs completed (2 more than were needed for the one-piece wing). Is this enough for the 3-piece wing or do I need to make a few more? For reference, I did build the rib from the full-size plan I received from Don Pietenpol last September. Thanks for any input. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327883#327883 ________________________________________________________________________________
Date: Jan 22, 2011
He must not have a kitchen... ;P Ryan Mueller -----Original Message----- From: "Gary Boothe" <gboothe5(at)comcast.net> Sender: owner-pietenpol-list-server(at)matronics.com Date: Sat, 22 Jan 2011 10:55:09 Yes, Tom, that's the correct count, however, I find it difficult to believe that you built 30 ribs since September. It's been almost 3 years and I'm only on #24...! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) -----Original Message----- From: Gboothe5 [mailto:gboothe5(at)comcast.net] Sent: Saturday, January 22, 2011 10:50 AM Subject: FW: Pietenpol-List: Rib question -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tdudley(at)umn.edu Sent: Saturday, January 22, 2011 7:52 AM Subject: Pietenpol-List: Rib question Simple question, but need some help. I originally was planning on building the FGM wing or perhaps the one part wing which I understood as having 28 ribs. I've reconsidered and will be building the 3-piece wing and am waiting for the plans I ordered from Don Pietenpol. I have 30 ribs completed (2 more than were needed for the one-piece wing). Is this enough for the 3-piece wing or do I need to make a few more? For reference, I did build the rib from the full-size plan I received from Don Pietenpol last September. Thanks for any input. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327883#327883 ________________________________________________________________________________
Date: Jan 22, 2011
You might want to build a few more, just to hang in the den or the hangar. Ribs are just cool to look at and they're great conversation starters. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327920#327920 ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Jan 22, 2011
I just went to the shop and counted. I have 31 built, 14 for each wing section and 3 for the center section. If you plan on putting a fuel tank in the centersection you will need 2 false ribs for the aft section (behind the rear spar) and one false nose rib in the place of the center rib of the centersection. Actually, the 3-piece wing plan covers mainly the center section and how the center section is connected to the wing sections. It does have dimensions of the wing spar and plans for the spar butt joint straps. Lots of luck. See you at Brodhead, the Mecca of Pietenpols. Chuck ----- Original Message ----- From: <tdudley(at)umn.edu> Sent: Saturday, January 22, 2011 10:52 AM Subject: Pietenpol-List: Rib question > > Simple question, but need some help. I originally was planning on > building the FGM wing or perhaps the one part wing which I understood as > having 28 ribs. I've reconsidered and will be building the 3-piece wing > and am waiting for the plans I ordered from Don Pietenpol. > > I have 30 ribs completed (2 more than were needed for the one-piece wing). > Is this enough for the 3-piece wing or do I need to make a few more? > > For reference, I did build the rib from the full-size plan I received from > Don Pietenpol last September. > > Thanks for any input. > > Tom > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327883#327883 > > > ________________________________________________________________________________
Date: Jan 22, 2011
Hey! That's an idea. Think I'll plan on putting in a centersection tank, build the false ribs, and hang my 31st one on the wall of the den. My wife would have an absolute conniption fit. Chuck ----- Original Message ----- From: "Billy McCaskill" <billmz(at)cox.net> Sent: Saturday, January 22, 2011 3:03 PM Subject: Pietenpol-List: Re: Rib question > > You might want to build a few more, just to hang in the den or the hangar. > Ribs are just cool to look at and they're great conversation starters. > > -------- > Billy McCaskill > Urbana, IL > tail section almost done, starting on ribs soon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327920#327920 > > > ________________________________________________________________________________
Date: Jan 22, 2011
Gary, I averaged one rib per day when I was in the rib mode. Of course I'm retired (retarded). I had kind of an assembly line going. First, I took yesterday's rib out of the jig, took the top rib cap for today's rib off the prebending jig and put it in the rib jig, then the bottom rib cap, then cut the connecting members per a prearranged plan, glued the members and installed the top-side gussets (precut). I then put the gussets on the back of yesterday's rib. Last I took a rib cap out of the soaker and put it in the prebending jig. Last I put another rib cap in the soaker, left the shop and closed the door. It was really the most enjoyable part of the project. ----- Original Message ----- From: "Gary Boothe" <gboothe5(at)comcast.net> Sent: Saturday, January 22, 2011 1:55 PM Subject: RE: Pietenpol-List: Rib question > > Yes, Tom, that's the correct count, however, I find it difficult to > believe > that you built 30 ribs since September. It's been almost 3 years and I'm > only on #24...! > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, Running! > Tail done, Fuselage on gear > (23 ribs down.) > > -----Original Message----- > From: Gboothe5 [mailto:gboothe5(at)comcast.net] > Sent: Saturday, January 22, 2011 10:50 AM > To: gboothe5(at)comcast.net > Subject: FW: Pietenpol-List: Rib question > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > tdudley(at)umn.edu > Sent: Saturday, January 22, 2011 7:52 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Rib question > > > Simple question, but need some help. I originally was planning on > building > the FGM wing or perhaps the one part wing which I understood as having 28 > ribs. I've reconsidered and will be building the 3-piece wing and am > waiting for the plans I ordered from Don Pietenpol. > > I have 30 ribs completed (2 more than were needed for the one-piece wing). > Is this enough for the 3-piece wing or do I need to make a few more? > > For reference, I did build the rib from the full-size plan I received from > Don Pietenpol last September. > > Thanks for any input. > > Tom > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327883#327883 > > > ________________________________________________________________________________
Date: Jan 22, 2011
Thanks for the insight. I'm right now soaking an additional two capstrips to bring the total to 32. Hard to believe how much fun cutting and glueing wood together can be. Gary, each night I read a chapter of the "Little House on the Prairie" books to my little girl. Last night there was a poem in the chapter: "Lost, between sunrise and sunset, One golden hour, set with sixty diamond minutes. No reward is offered, for it is gone forever." I don't know who came up with it (my background is more science and medicine, not literature), but it kind of gave me a boost of inspiration to keep building. My goal was one rib per day like some others have posted. It took me longer, but it sure is fun to keep plugging away. Again, thanks for the help. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327932#327932 ________________________________________________________________________________
Date: Jan 22, 2011
Charles, Seems like a great plan...worked good! Me? Takes 2 hours per rib, but I found them incredibly monotonous, thinking the whole time about other stuff! I now have the tail ready for cover, the fuselage and center section ready for cover, and almost ready to run the engine on the airframe...but those remaining 7 ribs just keep waiting! Now, as Billy suggested, I need to build an extra one just for gee-whiz! Heck, that's going to add another 3 months to my build time.... See you at Brodhead! (I'll be the guy in the ball cap with a camera) Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Saturday, January 22, 2011 2:29 PM Subject: Re: Pietenpol-List: Rib question Gary, I averaged one rib per day when I was in the rib mode. Of course I'm retired (retarded). I had kind of an assembly line going. First, I took yesterday's rib out of the jig, took the top rib cap for today's rib off the prebending jig and put it in the rib jig, then the bottom rib cap, then cut the connecting members per a prearranged plan, glued the members and installed the top-side gussets (precut). I then put the gussets on the back of yesterday's rib. Last I took a rib cap out of the soaker and put it in the prebending jig. Last I put another rib cap in the soaker, left the shop and closed the door. It was really the most enjoyable part of the project. ----- Original Message ----- From: "Gary Boothe" <gboothe5(at)comcast.net> Sent: Saturday, January 22, 2011 1:55 PM Subject: RE: Pietenpol-List: Rib question > > Yes, Tom, that's the correct count, however, I find it difficult to > believe > that you built 30 ribs since September. It's been almost 3 years and I'm > only on #24...! > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, Running! > Tail done, Fuselage on gear > (23 ribs down.) > > -----Original Message----- > From: Gboothe5 [mailto:gboothe5(at)comcast.net] > Sent: Saturday, January 22, 2011 10:50 AM > To: gboothe5(at)comcast.net > Subject: FW: Pietenpol-List: Rib question > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > tdudley(at)umn.edu > Sent: Saturday, January 22, 2011 7:52 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Rib question > > > Simple question, but need some help. I originally was planning on > building > the FGM wing or perhaps the one part wing which I understood as having 28 > ribs. I've reconsidered and will be building the 3-piece wing and am > waiting for the plans I ordered from Don Pietenpol. > > I have 30 ribs completed (2 more than were needed for the one-piece wing). > Is this enough for the 3-piece wing or do I need to make a few more? > > For reference, I did build the rib from the full-size plan I received from > Don Pietenpol last September. > > Thanks for any input. > > Tom > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327883#327883 > > > ________________________________________________________________________________
Date: Jan 22, 2011
Tom, I admire you for working on your dream while still raising young-uns! You make a great example... Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tdudley(at)umn.edu Sent: Saturday, January 22, 2011 2:37 PM Subject: Pietenpol-List: Re: Rib question Thanks for the insight. I'm right now soaking an additional two capstrips to bring the total to 32. Hard to believe how much fun cutting and glueing wood together can be. Gary, each night I read a chapter of the "Little House on the Prairie" books to my little girl. Last night there was a poem in the chapter: "Lost, between sunrise and sunset, One golden hour, set with sixty diamond minutes. No reward is offered, for it is gone forever." I don't know who came up with it (my background is more science and medicine, not literature), but it kind of gave me a boost of inspiration to keep building. My goal was one rib per day like some others have posted. It took me longer, but it sure is fun to keep plugging away. Again, thanks for the help. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327932#327932 ________________________________________________________________________________
Date: Jan 22, 2011
I'm now about half way on the ribs. My question is with ailerons. Do you just build the entire rib section then cut out the ailerons? What about the center sections....do you build special ribs or do most just cut standard ribs apart? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327957#327957 ________________________________________________________________________________
Date: Jan 22, 2011
Gary, Thanks for the kind words. Bedtime is at 8 o'clock and if there's anything residency taught me, it's to live on 4-5 hours sleep. My Piet is getting built when everyone in my house sleeps. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327959#327959 ________________________________________________________________________________
Date: Jan 22, 2011
Kringle, As I understand it, you build the wings on the spars first, then cut the ailerons out. Not certain about the center section, but I guess I'm planning on building full ribs and cutting them out. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327960#327960 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: wax solvent and trim tab size
Date: Jan 22, 2011
Hey all, Two questions. Firstly, I glassed my cowling over a waxed mold and now want to add a layer and glass some stiffners to the inside, but there is a fair amount of wax residue on the inside of the cowling from the mold. I've tried mineral spirits, MEK and Formbys furniture refinisher and nothing really removes it well. Was going to get some acetone, but thought I"d send it out to see what you guys would suggest. Secondly. What do you guys think is the minimal size a trim tab on the elevator could be to work? Don't think it takes much. Thanks, Douwe ________________________________________________________________________________
Date: Jan 22, 2011
Hey Tom.... - Lets see some photos of your progress! Sound like you have been very busy w ith all this cold weather! - Ken H Hawley,MN - --- On Sat, 1/22/11, tdudley(at)umn.edu wrote: From: tdudley(at)umn.edu <tdudley(at)umn.edu> Subject: Pietenpol-List: Re: Rib question Date: Saturday, January 22, 2011, 8:05 PM Gary, Thanks for the kind words.- Bedtime is at 8 o'clock and if there's anythi ng residency taught me, it's to live on 4-5 hours sleep.- My Piet is gett ing built when everyone in my house sleeps. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327959#327959 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Jan 22, 2011
Subject: Trim control
Can anyone tell me the amount of travel needed for the trim control? I am a dding a trim control knob under my seat that is connected to my bell crank for trimming out the plane for level flight. Photos are forth coming. Just need to know how much adjustment is needed for nose up and nose down. - Ken H Halwey, MN =0A=0A=0A ________________________________________________________________________________
Date: Jan 22, 2011
Subject: Brace cables, pulleys, wing supports
I have a few questions in regard to the center section. I am wondering why most have changed from the as drawn support cables for the center section to the streamline supports from the top of the center section to the top motor mounts? I am leaning towards using the 3/32" cables. Anyone have rub issues with the cables on the center section pulleys...side load rubbing? It appears that with the cabanes vertical, the cables and pulleys look fine. But when I rake the center section back, the cables then rub on the pulley sideways. (side load) I do not have the cables in, I am running string for now and just checking how it all goes together. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jan 22, 2011
Subject: Re: wax solvent and trim tab size
I measured tabs on several Cessnas and Pipers and ended up with an average of 12 x 3.5". Haven't flown yet so I can't say how it will work. rick On Sat, Jan 22, 2011 at 7:49 PM, Douwe Blumberg wrote: > > > Secondly. What do you guys think is the minimal size a trim tab on the > elevator could be to work? Don=92t think it takes much. > > > Thanks, > > > Douwe > > * > =========== =========== =========== =========== > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 22, 2011
Hey Ken, Hope your winter has been going well. Kind of hard to stomach the -16 degree weather we've had the last few days. Kind of cold in my garage so I've had to move to the basement. I've added a few pictures--nothing that hasn't been seen before dozens of times on this forum, but since you've asked. Maybe when the weather warms up I can swing up and take a look at your progress. I'm still interested in that Corvair engine. . . Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327976#327976 Attachments: http://forums.matronics.com//files/piet_pics_016_240.jpg http://forums.matronics.com//files/027_571.jpg http://forums.matronics.com//files/piet_pics_014_874.jpg http://forums.matronics.com//files/006_131.jpg ________________________________________________________________________________
Subject: Re: Brace cables, pulleys, wing supports
Date: Jan 23, 2011
Michael,The reason most folks are putting in the forward braces is because they take out the brace wires around the front cockpit and just bracing one side of the cockpit is not quite adequate.I will not have forward braces but rather cables the the motor mount and cables running from the rear cabanes to the sides of the cockpit.You need something to keep the wing from cantilevering forward in a crash-bad landing.Also if you just put your cabanes straight up and down,finish everything but the motor mount,do a weight and balance with the plane complete,covered etc. and put your motor in where it needs to be you will have perfect weight and balance,no rubbing cables,great fit on the cockpit cowls and no wondering if your CG is right or if you'll have to make a half dozen motor mounts instead of one.On the other hand you can always toss a couple of bricks in to make it balance,they're cheap.Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327986#327986 ________________________________________________________________________________
Date: Jan 23, 2011
Hi Tom, Thanks for sharing those pictures. Brings back fond memories. I built all t he ribs before I found this forum, and did not know I was supposed to soak or steam the top cap strips. When I found out, I got that "knot" that forms in the bottom of your stomach when things like this happen. Took a 5 gallo n bucket 1/2 full of water and soaked the noses of all the ribs overnite. I am sure this relieved all stresses because two of them actually broke just aft of the first diagonal, and I had to make new ones. The glue joints wer e unaffected. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Subject: Bending blocks
Date: Jan 23, 2011
I've decided to make my metal fittings by using steel bending blocks in my vise. Is there a source for a set of these with different radii already ground on them? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327988#327988 ________________________________________________________________________________
Date: Jan 23, 2011
Just make 'em Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, January 23, 2011 7:49 AM Subject: Pietenpol-List: Bending blocks I've decided to make my metal fittings by using steel bending blocks in my vise. Is there a source for a set of these with different radii already ground on them? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327988#327988 ________________________________________________________________________________
Date: Jan 23, 2011
This could be an option. Pretty sharp radius though. http://www.grizzly.com/products/6-Vise-Brake/H3245 Jack DSM -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, January 23, 2011 6:49 AM Subject: Pietenpol-List: Bending blocks I've decided to make my metal fittings by using steel bending blocks in my vise. Is there a source for a set of these with different radii already ground on them? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327988#327988 ________________________________________________________________________________
Date: Jan 23, 2011
I agree, that sharp radius is not good. I have one of those and just worked it with my grinder until I "blunted" the point. It ended up being a very handy tool I've used many times. jm -----Original Message----- >From: Jack <jack(at)textors.com> >Sent: Jan 23, 2011 7:40 AM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Bending blocks > > >This could be an option. Pretty sharp radius though. >http://www.grizzly.com/products/6-Vise-Brake/H3245 >Jack >DSM > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle >Sent: Sunday, January 23, 2011 6:49 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Bending blocks > > >I've decided to make my metal fittings by using steel bending blocks in my >vise. Is there a source for a set of these with different radii already >ground on them? > >-------- >John > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=327988#327988 > > ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Re: Bending blocks
Date: Jan 23, 2011
I have a grizzly vise brake, and had to increase the radius of the bending edge (pretty easy to file down). As it comes, it impresses marks on the bend that would be stress risers. Filed down (I did mine to work with steel in the .09 t0 .125 range), it works great. They are cheap enough that you might want to get several and file them down even more (or less) for thicker or thinner stock. The only issue I've found with this tool is that you have to be really careful that the stock is indexed exactly right before you bend it - there are no reference marks for alignment on the tool itself. Kip Gardner On Jan 23, 2011, at 8:40 AM, Jack wrote: > > This could be an option. Pretty sharp radius though. > http://www.grizzly.com/products/6-Vise-Brake/H3245 > Jack > DSM > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > Kringle > Sent: Sunday, January 23, 2011 6:49 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Bending blocks > > > I've decided to make my metal fittings by using steel bending blocks > in my > vise. Is there a source for a set of these with different radii > already > ground on them? > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327988#327988 > > ________________________________________________________________________________
Date: Jan 23, 2011
Agree with Billy. I cut out a 1/8" ply Scimitar propeller like Dan Helspar's and hung it on the wall over the patio door. I thought it was the neatest thing in that room! And yes, it WAS a great conversation starter. I quickly got tired of my wife's "conversations" about having it hanging up there and took it down. Sure looked cool though (up to the point where the "conversations" started). Jim -----Original Message----- >From: Charles Campbell <cncampbell(at)windstream.net> >Sent: Jan 22, 2011 4:04 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Rib question > > >Hey! That's an idea. Think I'll plan on putting in a centersection tank, >build the false ribs, and hang my 31st one on the wall of the den. My wife >would have an absolute conniption fit. Chuck >----- Original Message ----- >From: "Billy McCaskill" <billmz(at)cox.net> >To: >Sent: Saturday, January 22, 2011 3:03 PM >Subject: Pietenpol-List: Re: Rib question > > >> >> You might want to build a few more, just to hang in the den or the hangar. >> Ribs are just cool to look at and they're great conversation starters. >> >> -------- >> Billy McCaskill >> Urbana, IL >> tail section almost done, starting on ribs soon >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=327920#327920 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 23, 2011
Thanks Dave. So, the as drawn CS brace cables are not a good idea from a strength point of view? Your idea of wing position and CG calculations are worth keeping in mind. However, as I temp. mount my CS to trial fit cables,(string) cut access holes and make my instrument panel, I found that I can only move my C.S. forward only so much then the brace cables hit the back of the front seat back. Even at this position, there is some pulley side loading. I know most people rack their CS back for CG fixes. I was curious if anyone noticed the side load on the pulleys and how, if at all, they fixed it. There are a few ways that I can think of to fix this issue, but none of which would be easy or quick. What have you guys noticed and how did you fix it. (or not...) Michael Perez Karetaker Aero www.karetakeraero.com --- On Sun, 1/23/11, Dangerous Dave wrote: > From: Dangerous Dave <dsornbor(at)aol.com> > Subject: Pietenpol-List: Re: Brace cables, pulleys, wing supports > To: pietenpol-list(at)matronics.com > Date: Sunday, January 23, 2011, 7:23 AM > --> Pietenpol-List message posted > by: "Dangerous Dave" > > Michael,The reason most folks are putting in the forward > braces is because they take out the brace wires around the > front cockpit and just bracing one side of the cockpit is > not quite adequate.I will not have forward braces but rather > cables the the motor mount and cables running from the rear > cabanes to the sides of the cockpit.You need something to > keep the wing from cantilevering forward in a crash-bad > landing.Also if you just put your cabanes straight up and > down,finish everything but the motor mount,do a weight and > balance with the plane complete,covered etc. and put your > motor in where it needs to be you will have perfect weight > and balance,no rubbing cables,great fit on the cockpit cowls > and no wondering if your CG is right or if you'll have to > make a half dozen motor mounts instead of one.On the other > hand you can always toss a couple of bricks in to make it > balance,they're cheap.Dave > > -------- > Covering Piet > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327986#327986 > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Jan 23, 2011
Sounds like time to get a new wife... -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Sunday, January 23, 2011 8:46 AM Subject: Re: Pietenpol-List: Re: Rib question Agree with Billy. I cut out a 1/8" ply Scimitar propeller like Dan Helspar's and hung it on the wall over the patio door. I thought it was the neatest thing in that room! And yes, it WAS a great conversation starter. I quickly got tired of my wife's "conversations" about having it hanging up there and took it down. Sure looked cool though (up to the point where the "conversations" started). Jim -----Original Message----- >From: Charles Campbell <cncampbell(at)windstream.net> >Sent: Jan 22, 2011 4:04 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Rib question > > >Hey! That's an idea. Think I'll plan on putting in a centersection tank, >build the false ribs, and hang my 31st one on the wall of the den. My wife >would have an absolute conniption fit. Chuck >----- Original Message ----- >From: "Billy McCaskill" <billmz(at)cox.net> >To: >Sent: Saturday, January 22, 2011 3:03 PM >Subject: Pietenpol-List: Re: Rib question > > >> >> You might want to build a few more, just to hang in the den or the hangar. >> Ribs are just cool to look at and they're great conversation starters. >> >> -------- >> Billy McCaskill >> Urbana, IL >> tail section almost done, starting on ribs soon >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=327920#327920 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 23, 2011
I have a HF bender that is handy on larger projects but was too slow to get rigged up for the Piet jobs. I used various pieces of angle iron the I ground different radii on and my trusty vise. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328016#328016 Attachments: http://forums.matronics.com//files/bender_138.jpg ________________________________________________________________________________
Date: Jan 23, 2011
Jim Markle showed me the Grizzly break that he uses and I had to get one. I didn't like the idea of pounding metal to shape in my vise... this thing allows you much better control of the placement and angle of the bends. Simple device, and worth the money. I agree on the sharpness... it needs wider radius. I ran mine on a surface grinder and then rounded it of with a hand file. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328017#328017 ________________________________________________________________________________
Date: Jan 23, 2011
Keep in mind, as the numbers in the W&B article bear out, it is more effective to move the wing to correct for CG issues (or think of it as moving the fuselage under the wing) than it is to just move the engine forward. If you move the engine forward you are only moving the weight of the engine relation to the datum. On the other hand if you move the wing aft you are now shifting the weight of the engine, the fuselage, the pilot, and potentially a fuselage fuel tank forward in relation to the datum. This is going to be a more effective way to correct CG problems, and will also avoid the "anteater" look you could acquire by having to hang the engine so far out (especially with lighter small Continentals). Or, you could split the difference and shift the wing some, and move the engine forward some. Theoretically, it shouldn't require any more work than just figuring out engine placement. You can weigh your completed wing, weigh your completed fuselage, add in the weight of the engine at the proposed location, and then add in the weight of the wing at the proposed location. Play with the locations to see how the numbers come out.... Ryan On Sun, Jan 23, 2011 at 6:23 AM, Dangerous Dave wrote: > > Michael,The reason most folks are putting in the forward braces is because > they take out the brace wires around the front cockpit and just bracing one > side of the cockpit is not quite adequate.I will not have forward braces but > rather cables the the motor mount and cables running from the rear cabanes > to the sides of the cockpit.You need something to keep the wing from > cantilevering forward in a crash-bad landing.Also if you just put your > cabanes straight up and down,finish everything but the motor mount,do a > weight and balance with the plane complete,covered etc. and put your motor > in where it needs to be you will have perfect weight and balance,no rubbing > cables,great fit on the cockpit cowls and no wondering if your CG is right > or if you'll have to make a half dozen motor mounts instead of one.On the > other hand you can always toss a couple of bricks in to make it > balance,they're cheap.Dave > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327986#327986 > > ________________________________________________________________________________
Date: Jan 23, 2011
John, Instead of using steel bending blocks in my vice, I used 1/8" thick aluminum angle, because.....I had some, and it's very easy to shape the radii. Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, January 23, 2011 4:49 AM Subject: Pietenpol-List: Bending blocks I've decided to make my metal fittings by using steel bending blocks in my vise. Is there a source for a set of these with different radii already ground on them? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327988#327988 ________________________________________________________________________________
Subject: questions from a new guy...
Date: Jan 23, 2011
I just bought a set of plans from Don and am planning on starting on the project in a few months (I need to finish a boat I started on first). I have a couple of questions that I would like to throw out there and gain some practical knowledge. At this point I am heavily leaning toward the one piece wing, the steel tube fuselage, and a Continental engine (C85 or 0200) 1- Is there a benefit to start with one major component (wing, fuselage, tail feathers) before another? From a space standpoint I would build the tail and wing before the fuselage as they take up less room in the shop, but my building partner says to build the fuselage first so you can build everything to fit to it. 2- I am leaning toward the one piece wing because I am assuming it to be lighter or stronger and simpler to build. Are these assumptions correct? 3- I wanted to build the steel tube fuselage because it is another medium to work with in the build and I like working with metal, but I notice most of the sites and posts are from guys building a wood fuselage. I also can't help but think that it would be both lighter and stronger. I would love to hear opinions from both sides. Thanks for any information. I look forward to starting on the build, asking more questions and maybe someday being able to answer some... Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328021#328021 ________________________________________________________________________________
Subject: First Question
Date: Jan 23, 2011
Hi, Dave Schlieder and I have decided that we need to do something new and interesting so we have started down the Pietenpol Path :D. We have purchased the easy stuff first (tail feathers). With this and the future in mind I'd like to ask a few questions (note ... could find the answers via seach): 1) We went with T-88 glue ... are there any "gotchas" that we should know? 2) I can nowhere find a discussion on the pros and cons on the different styles of landing gear ... can someone point me to one and/or "stir the pot" [Twisted Evil] 3) I am guessing that the Ford installation puts the radiator above/behind the engine for W&B purposes ... has anyone ever built a radiator in front of the engine between the engine & the prop? Thanks Perry -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328027#328027 ________________________________________________________________________________
Date: Jan 23, 2011
Welcome, Mike! There is nothing wrong with your approach to build tail, wings, fuse, in that order. Nor is there anything wrong with wings, tail, fuse, or fuse, tail, wings, or fuse, wings, tail, or....you get the picture... Many builders start with the tail, just to get into the swing of things...or start with ribs. Since the wing is supported above the fuselage, all you need to do is follow the dimensions and it all hooks up just fine. I built the 3-piece wing because of building space reasons, but the one-piece builders say that the 1-piece wing is easier and lighter (makes sense). Wood is easy for me, but if you are comfortable with steel...go for it! I don't there's any reason not to, except maybe for material costs. I bought locally available poplar at a fraction of the price of spruce, saving close to $1,000. Can't say what 4130 tubing would have cost. In any case, you're at the right place for all questions. Be sure to let us know where you are located, and make sure to check out all the cool stuff at www.westcoastpiet.com. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MPB Sent: Sunday, January 23, 2011 8:05 AM Subject: Pietenpol-List: questions from a new guy... I just bought a set of plans from Don and am planning on starting on the project in a few months (I need to finish a boat I started on first). I have a couple of questions that I would like to throw out there and gain some practical knowledge. At this point I am heavily leaning toward the one piece wing, the steel tube fuselage, and a Continental engine (C85 or 0200) 1- Is there a benefit to start with one major component (wing, fuselage, tail feathers) before another? From a space standpoint I would build the tail and wing before the fuselage as they take up less room in the shop, but my building partner says to build the fuselage first so you can build everything to fit to it. 2- I am leaning toward the one piece wing because I am assuming it to be lighter or stronger and simpler to build. Are these assumptions correct? 3- I wanted to build the steel tube fuselage because it is another medium to work with in the build and I like working with metal, but I notice most of the sites and posts are from guys building a wood fuselage. I also can't help but think that it would be both lighter and stronger. I would love to hear opinions from both sides. Thanks for any information. I look forward to starting on the build, asking more questions and maybe someday being able to answer some... Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328021#328021 ________________________________________________________________________________
Date: Jan 23, 2011
Dave, The only gear worth considering is the wood, Jenny style gear with wire wheels! (ducking) Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman Sent: Sunday, January 23, 2011 8:31 AM Subject: Pietenpol-List: First Question Hi, Dave Schlieder and I have decided that we need to do something new and interesting so we have started down the Pietenpol Path :D. We have purchased the easy stuff first (tail feathers). With this and the future in mind I'd like to ask a few questions (note ... could find the answers via seach): 1) We went with T-88 glue ... are there any "gotchas" that we should know? 2) I can nowhere find a discussion on the pros and cons on the different styles of landing gear ... can someone point me to one and/or "stir the pot" [Twisted Evil] 3) I am guessing that the Ford installation puts the radiator above/behind the engine for W&B purposes ... has anyone ever built a radiator in front of the engine between the engine & the prop? Thanks Perry -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328027#328027 ________________________________________________________________________________
Subject: Re: First Question
Date: Jan 23, 2011
Gary, ! The only folks worth knowing have strong opinions, IMO! :D I was wondering, though, if the split gear might be better on rough/unimproved strips??? Perry (Dave is my partner in crime in this endeavor) -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328035#328035 ________________________________________________________________________________
Date: Jan 23, 2011
Perry (not Dave), I think I have heard that, but, just how rough a field are you talking about? BTW...Aren't you jealous of all those mid-west guys and their grassy strips? Then, again, you have the perfect weather where you are. Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman Sent: Sunday, January 23, 2011 8:52 AM Subject: Pietenpol-List: Re: First Question Gary, ! The only folks worth knowing have strong opinions, IMO! :D I was wondering, though, if the split gear might be better on rough/unimproved strips??? Perry (Dave is my partner in crime in this endeavor) -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328035#328035 ________________________________________________________________________________
Date: Jan 23, 2011
Gary... I think Perry should attend the West Coast Pietenpol Gathering June 4th at Frazier Lake . Mike Groah Tulare CA ________________________________ From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sun, January 23, 2011 9:02:38 AM Subject: RE: Pietenpol-List: Re: First Question Perry (not Dave), I think I have heard that, but, just how rough a field are you talking about? BTW...Aren't you jealous of all those mid-west guys and their grassy strips? Then, again, you have the perfect weather where you are. Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman Sent: Sunday, January 23, 2011 8:52 AM Subject: Pietenpol-List: Re: First Question Gary, ! The only folks worth knowing have strong opinions, IMO! :D I was wondering, though, if the split gear might be better on rough/unimproved strips??? Perry (Dave is my partner in crime in this endeavor) -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328035#328035 ________________________________________________________________________________
Date: Jan 23, 2011
Gary, After 30 years in Alaska, it is hard to be jealous of anyone :D. Yes, the sunshine is nice (though HOT at times) but it is great to be around my aging parents. Lots of private/hidden strips around the SW, though. As to rough ... I probably won't be landing on any more boulder strewn beaches in this lifetime ... just move interested in major differences between the two gear types. ALSO ... the split gear with tall balloon tiers is a little more like the 1930's Ryan look, which fits San Diego well, eh? Perry -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328041#328041 ________________________________________________________________________________
Date: Jan 23, 2011
OK=2C Ryan=2C I have got to call BS on this one. The location of the datum and moving anything in relationship to it is irrelevant. It is proper to say that to avoid the anteater look you might want to move the wing=2C but using the datum as a reason is incorrect. This is the big problem I have w ith the W&B project that was in the last newsletter. Rather than putting t he datum at a fixed point=2C such as the firewall or propeller flange=2C th e wing leading edge (a movable point) was used. Based on a fixed point=2C the information as to axle location and engine mount length would have been much more useful. As it stands=2C I do not see any use for the data as pu blished. Gene Rambo Date: Sun=2C 23 Jan 2011 09:51:53 -0600 Subject: Re: Pietenpol-List: Re: Brace cables=2C pulleys=2C wing supports From: rmueller23(at)gmail.com Keep in mind=2C as the numbers in the W&B article bear out=2C it is more ef fective to move the wing to correct for CG issues (or think of it as moving the fuselage under the wing) than it is to just move the engine forward. I f you move the engine forward you are only moving the weight of the engine relation to the datum. On the other hand if you move the wing aft you are n ow shifting the weight of the engine=2C the fuselage=2C the pilot=2C and po tentially a fuselage fuel tank forward in relation to the datum. This is go ing to be a more effective way to correct CG problems=2C and will also avoi d the "anteater" look you could acquire by having to hang the engine so far out (especially with lighter small Continentals). Or=2C you could split th e difference and shift the wing some=2C and move the engine forward some. Theoretically=2C it shouldn't require any more work than just figuring out engine placement. You can weigh your completed wing=2C weigh your completed fuselage=2C add in the weight of the engine at the proposed location=2C an d then add in the weight of the wing at the proposed location. Play with th e locations to see how the numbers come out.... Ryan On Sun=2C Jan 23=2C 2011 at 6:23 AM=2C Dangerous Dave wr ote: Michael=2CThe reason most folks are putting in the forward braces is becaus e they take out the brace wires around the front cockpit and just bracing o ne side of the cockpit is not quite adequate.I will not have forward braces but rather cables the the motor mount and cables running from the rear cab anes to the sides of the cockpit.You need something to keep the wing from c antilevering forward in a crash-bad landing.Also if you just put your caban es straight up and down=2Cfinish everything but the motor mount=2Cdo a weig ht and balance with the plane complete=2Ccovered etc. and put your motor in where it needs to be you will have perfect weight and balance=2Cno rubbing cables=2Cgreat fit on the cockpit cowls and no wondering if your CG is rig ht or if you'll have to make a half dozen motor mounts instead of one.On th e other hand you can always toss a couple of bricks in to make it balance =2Cthey're cheap.Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327986#327986 st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com le=2C List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 23, 2011
I'm going to look for some aluminum blocks tomorrow and radius them with my router bits. I hear high speed steel cuts it like butter. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328045#328045 ________________________________________________________________________________
Date: Jan 23, 2011
Wow ... that would be fun ... I presume you mean Frazier Lake, CA and not CA as in Canada -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328049#328049 ________________________________________________________________________________
Date: Jan 23, 2011
Michael, When you talk about the support cables for the center section, I assume you're referring to the diagonal bracing cables that run between the front and rear cabanes on the right side. (see attached image) The reason why most builders replace them with diagonal tubing running from the top of the front cabane struts down to the top engine mounts is because those cables make it very difficult to get into the front seat (as if it isn't difficult enough). BHP recommended using the diagonal tube braces, and included the modified engine mount brackets in the supplementary plans. The way things are designed, the aileron control cables will be pretty well vertical when the cabane struts are vertical. Shifting the wing back 4 inches (which is about as far as most builders go) results in a change of approximately 5 degrees. If the deflection seems to be too much, it would be pretty simple to add a wedge to the back side of the spar to account for the misalignment. Dave, Are you saying that you intend to install cables where others have installed the diagonal tubes AND also installing cables running from the tops of the rear cabanes back towards the rear cockpit? I don't see the benefit. Just sounds like more cables to me. Maybe I'm misunderstanding what you said. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328050#328050 Attachments: http://forums.matronics.com//files/cs_cables_672.jpg ________________________________________________________________________________
Date: Jan 23, 2011
Subject: Re: questions from a new guy...
Don't worry about not having enough metal cutting/grinding/welding to do. I built a wood fuselage and spent as much time on metal work as wood work (especially if you are building split gear). Most people start with ribs, as mentioned the wing is so independent of the fuselage there is no need to have the fuselage done first, but if you have the room go for it. (Would recommend building a mock fuselage first though). rick Wood is easy for me, but if you are comfortable with steel...go for it! I > don't there's any reason not to, except maybe for material costs. I bought > locally available poplar at a fraction of the price of spruce, saving close > to $1,000. Can't say what 4130 tubing would have cost. > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MPB > Sent: Sunday, January 23, 2011 8:05 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: questions from a new guy... > > > I just bought a set of plans from Don and am planning on starting on the > project in a few months (I need to finish a boat I started on first). I > have a couple of questions that I would like to throw out there and gain > some practical knowledge. At this point I am heavily leaning toward the > one > piece wing, the steel tube fuselage, and a Continental engine (C85 or 0200) > > 1- Is there a benefit to start with one major component (wing, fuselage, > tail feathers) before another? From a space standpoint I would build the > tail and wing before the fuselage as they take up less room in the shop, > but > my building partner says to build the fuselage first so you can build > everything to fit to it. > > 2- I am leaning toward the one piece wing because I am assuming it to be > lighter or stronger and simpler to build. Are these assumptions correct? > > 3- I wanted to build the steel tube fuselage because it is another medium > to > work with in the build and I like working with metal, but I notice most of > the sites and posts are from guys building a wood fuselage. I also can't > help but think that it would be both lighter and stronger. I would love to > hear opinions from both sides. > > Thanks for any information. I look forward to starting on the build, > asking > more questions and maybe someday being able to answer some... > > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328021#328021 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Subject: ford engine mount
Date: Jan 23, 2011
Am i reading the plans right ?? i'm working on the engine mount for the A.. looking at the ash engine supports , the drawing says the front should be 2 1/2 inches lower than the back ?? that seems like a lot but if its right then i'll build it that way jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328059#328059 Attachments: http://forums.matronics.com//files/mount_372.png ________________________________________________________________________________
Date: Jan 23, 2011
I don't know, Jack! I've had mine quite a few years and wouldn't want to break in a new one! ----- Original Message ----- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Sunday, January 23, 2011 9:48 AM Subject: RE: Pietenpol-List: Re: Rib question > > > Sounds like time to get a new wife... > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle > Sent: Sunday, January 23, 2011 8:46 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Rib question > > > > Agree with Billy. I cut out a 1/8" ply Scimitar propeller like Dan > Helspar's and hung it on the wall over the patio door. I thought it was > the > neatest thing in that room! > > And yes, it WAS a great conversation starter. I quickly got tired of my > wife's "conversations" about having it hanging up there and took it down. > > Sure looked cool though (up to the point where the "conversations" > started). > > Jim > > > -----Original Message----- >>From: Charles Campbell <cncampbell(at)windstream.net> >>Sent: Jan 22, 2011 4:04 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Re: Rib question >> > >> >>Hey! That's an idea. Think I'll plan on putting in a centersection tank, >>build the false ribs, and hang my 31st one on the wall of the den. My >>wife > >>would have an absolute conniption fit. Chuck >>----- Original Message ----- >>From: "Billy McCaskill" <billmz(at)cox.net> >>To: >>Sent: Saturday, January 22, 2011 3:03 PM >>Subject: Pietenpol-List: Re: Rib question >> >> >>> >>> You might want to build a few more, just to hang in the den or the > hangar. >>> Ribs are just cool to look at and they're great conversation starters. >>> >>> -------- >>> Billy McCaskill >>> Urbana, IL >>> tail section almost done, starting on ribs soon >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=327920#327920 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 23, 2011
Contrary to what would seem logical, the radius of the bend is NOT dependent on the radius of the "knife" die, but rather, on the opening size of the "vee" die, and the elasticity of the metal being bent. Provided the die is sized correctly for the thickness of the metal being bent, and that the bending is stopped before the knife is driven so far that the metal is being squished between the knife and the vee die, the result should be the same with a sharp "knife" as with a radius. When bending steel in this type of setup, the so-called bottom die (the v-shaped part) should have an opening that ideally measures 8 times the thickness of the metal being bent. The opening can be as small as 6 times, or as large as 10 times the metal thickness without negative effects. The metal will form a natural radius that is determined by the material elasticity, rather than the radius of the tool. Of course, if the vise is tightened too far (bottoming), the knife will cut into the metal. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328060#328060 Attachments: http://forums.matronics.com//files/bend_air_188.jpg ________________________________________________________________________________
Date: Jan 23, 2011
The only thing I have to say about the type of wheels is that it is a matter of taste. I, personally, don't like the looks of the wire, motorcycle type wheels but that is strictly a personal opinion. I'm sure you'll hear a lot of pros to the question. Can't give any opinion on the engine and the glue question was covered a couple of months back. Most seem to think the T88 is the (only)way to go. ----- Original Message ----- From: "PShipman" <perrytshipman(at)gmail.com> Sent: Sunday, January 23, 2011 11:31 AM Subject: Pietenpol-List: First Question > > Hi, > > Dave Schlieder and I have decided that we need to do something new and > interesting so we have started down the Pietenpol Path :D. We have > purchased the easy stuff first (tail feathers). With this and the future > in mind I'd like to ask a few questions (note ... could find the answers > via seach): > 1) We went with T-88 glue ... are there any "gotchas" that we should know? > 2) I can nowhere find a discussion on the pros and cons on the different > styles of landing gear ... can someone point me to one and/or "stir the > pot" [Twisted Evil] > 3) I am guessing that the Ford installation puts the radiator above/behind > the engine for W&B purposes ... has anyone ever built a radiator in front > of the engine between the engine & the prop? > > Thanks > > Perry > > -------- > Perry Shipman > Lakeside, CA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328027#328027 > > > ________________________________________________________________________________
Date: Jan 23, 2011
See what I mean? ----- Original Message ----- From: "Gary Boothe" <gboothe5(at)comcast.net> Sent: Sunday, January 23, 2011 11:37 AM Subject: RE: Pietenpol-List: First Question > > Dave, > > The only gear worth considering is the wood, Jenny style gear with wire > wheels! (ducking) > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, Running! > Tail done, Fuselage on gear > (23 ribs down.) > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman > Sent: Sunday, January 23, 2011 8:31 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: First Question > > > Hi, > > Dave Schlieder and I have decided that we need to do something new and > interesting so we have started down the Pietenpol Path :D. We have > purchased the easy stuff first (tail feathers). With this and the future > in > mind I'd like to ask a few questions (note ... could find the answers via > seach): > 1) We went with T-88 glue ... are there any "gotchas" that we should know? > 2) I can nowhere find a discussion on the pros and cons on the different > styles of landing gear ... can someone point me to one and/or "stir the > pot" > [Twisted Evil] > 3) I am guessing that the Ford installation puts the radiator above/behind > the engine for W&B purposes ... has anyone ever built a radiator in front > of > the engine between the engine & the prop? > > Thanks > > Perry > > -------- > Perry Shipman > Lakeside, CA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328027#328027 > > > ________________________________________________________________________________
Date: Jan 23, 2011
The location of the datum and moving anything in relationship to it is irrelevant? How could you ever possibly perform any CG adjustment if that is irrelevant. You move/add/subtract weight in order to bring the CG within limits, and in order to have a point of reference you have a datum. If you can move weights in relation to the datum, such as moving the engine farther forward, to cause a change in where the CG falls in relation the LE....then what is the problem with sliding the LE (and thusly datum) fore or aft to put the CG at an acceptable location? Sure, on most aircraft you cannot, but on a Piet you can, and it proves to be a more effective change. Prove me wrong, please... Ryan On Sun, Jan 23, 2011 at 11:39 AM, Gene Rambo wrote: > OK, Ryan, I have got to call BS on this one. The location of the datum > and moving anything in relationship to it is irrelevant. It is proper to > say that to avoid the anteater look you might want to move the wing, but > using the datum as a reason is incorrect. This is the big problem I have > with the W&B project that was in the last newsletter. Rather than putting > the datum at a fixed point, such as the firewall or propeller flange, the > wing leading edge (a movable point) was used. Based on a fixed point, the > information as to axle location and engine mount length would have been much > more useful. As it stands, I do not see any use for the data as published. > > Gene Rambo > > ------------------------------ > Date: Sun, 23 Jan 2011 09:51:53 -0600 > Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports > From: rmueller23(at)gmail.com > > To: pietenpol-list(at)matronics.com > > Keep in mind, as the numbers in the W&B article bear out, it is more > effective to move the wing to correct for CG issues (or think of it as > moving the fuselage under the wing) than it is to just move the engine > forward. If you move the engine forward you are only moving the weight of > the engine relation to the datum. On the other hand if you move the wing aft > you are now shifting the weight of the engine, the fuselage, the pilot, and > potentially a fuselage fuel tank forward in relation to the datum. This is > going to be a more effective way to correct CG problems, and will also avoid > the "anteater" look you could acquire by having to hang the engine so far > out (especially with lighter small Continentals). Or, you could split the > difference and shift the wing some, and move the engine forward some. > > Theoretically, it shouldn't require any more work than just figuring out > engine placement. You can weigh your completed wing, weigh your completed > fuselage, add in the weight of the engine at the proposed location, and then > add in the weight of the wing at the proposed location. Play with the > locations to see how the numbers come out.... > > Ryan > > On Sun, Jan 23, 2011 at 6:23 AM, Dangerous Dave wrote: > > > Michael,The reason most folks are putting in the forward braces is because > they take out the brace wires around the front cockpit and just bracing one > side of the cockpit is not quite adequate.I will not have forward braces but > rather cables the the motor mount and cables running from the rear cabanes > to the sides of the cockpit.You need something to keep the wing from > cantilevering forward in a crash-bad landing.Also if you just put your > cabanes straight up and down,finish everything but the motor mount,do a > weight and balance with the plane complete,covered etc. and put your motor > in where it needs to be you will have perfect weight and balance,no rubbing > cables,great fit on the cockpit cowls and no wondering if your CG is right > or if you'll have to make a half dozen motor mounts instead of one.On the > other hand you can always toss a couple of bricks in to make it > balance,they're cheap.Dave > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327986#327986 > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
Date: Jan 23, 2011
Check out: http://www.matronics.com/search/ <http://www.matronics.com/search/>Read the instructions to ensure you format your search for maximum effectiveness. Years and years worth of info on the archives. Probably the radiator installation is in that location because it is simple, easy, and effective. Ryan On Sun, Jan 23, 2011 at 10:31 AM, PShipman wrote: > > Hi, > > Dave Schlieder and I have decided that we need to do something new and > interesting so we have started down the Pietenpol Path :D. We have > purchased the easy stuff first (tail feathers). With this and the future in > mind I'd like to ask a few questions (note ... could find the answers via > seach): > 1) We went with T-88 glue ... are there any "gotchas" that we should know? > 2) I can nowhere find a discussion on the pros and cons on the different > styles of landing gear ... can someone point me to one and/or "stir the pot" > [Twisted Evil] > 3) I am guessing that the Ford installation puts the radiator above/behind > the engine for W&B purposes ... has anyone ever built a radiator in front of > the engine between the engine & the prop? > > Thanks > > Perry > > -------- > Perry Shipman > Lakeside, CA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328027#328027 > > ________________________________________________________________________________
Date: Jan 23, 2011
You don't have to do the Jenny gear to use big spoke wheels, you can go conventional or spoke with split gear, as on Don Emich's Piet. On Sun, Jan 23, 2011 at 12:12 PM, Charles Campbell < cncampbell(at)windstream.net> wrote: > cncampbell(at)windstream.net> > > The only thing I have to say about the type of wheels is that it is a > matter of taste. I, personally, don't like the looks of the wire, > motorcycle type wheels but that is strictly a personal opinion. I'm sure > you'll hear a lot of pros to the question. Can't give any opinion on the > engine and the glue question was covered a couple of months back. Most seem > to think the T88 is the (only)way to go. > ----- Original Message ----- From: "PShipman" <perrytshipman(at)gmail.com> > To: > Sent: Sunday, January 23, 2011 11:31 AM > Subject: Pietenpol-List: First Question > > >> > >> >> Hi, >> >> Dave Schlieder and I have decided that we need to do something new and >> interesting so we have started down the Pietenpol Path :D. We have >> purchased the easy stuff first (tail feathers). With this and the future in >> mind I'd like to ask a few questions (note ... could find the answers via >> seach): >> 1) We went with T-88 glue ... are there any "gotchas" that we should know? >> 2) I can nowhere find a discussion on the pros and cons on the different >> styles of landing gear ... can someone point me to one and/or "stir the pot" >> [Twisted Evil] >> 3) I am guessing that the Ford installation puts the radiator above/behind >> the engine for W&B purposes ... has anyone ever built a radiator in front of >> the engine between the engine & the prop? >> >> Thanks >> >> Perry >> >> -------- >> Perry Shipman >> Lakeside, CA >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=328027#328027 >> >> >> >> >> >> >> >> >> >> >> >> > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Jan 23, 2011
I definately agree about the mock fuselage bit. Wish I had known about it before I started -- I would probably have a nicer fuselage. ----- Original Message ----- From: Rick Holland To: pietenpol-list(at)matronics.com Sent: Sunday, January 23, 2011 1:27 PM Subject: Re: Pietenpol-List: questions from a new guy... Don't worry about not having enough metal cutting/grinding/welding to do. I built a wood fuselage and spent as much time on metal work as wood work (especially if you are building split gear). Most people start with ribs, as mentioned the wing is so independent of the fuselage there is no need to have the fuselage done first, but if you have the room go for it. (Would recommend building a mock fuselage first though). rick Wood is easy for me, but if you are comfortable with steel...go for it! I don't there's any reason not to, except maybe for material costs. I bought locally available poplar at a fraction of the price of spruce, saving close to $1,000. Can't say what 4130 tubing would have cost. -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MPB Sent: Sunday, January 23, 2011 8:05 AM To: pietenpol-list(at)matronics.com Subject: Pietenpol-List: questions from a new guy... I just bought a set of plans from Don and am planning on starting on the project in a few months (I need to finish a boat I started on first). I have a couple of questions that I would like to throw out there and gain some practical knowledge. At this point I am heavily leaning toward the one piece wing, the steel tube fuselage, and a Continental engine (C85 or 0200) 1- Is there a benefit to start with one major component (wing, fuselage, tail feathers) before another? From a space standpoint I would build the tail and wing before the fuselage as they take up less room in the shop, but my building partner says to build the fuselage first so you can build everything to fit to it. 2- I am leaning toward the one piece wing because I am assuming it to be lighter or stronger and simpler to build. Are these assumptions correct? 3- I wanted to build the steel tube fuselage because it is another medium to work with in the build and I like working with metal, but I notice most of the sites and posts are from guys building a wood fuselage. I also can't help but think that it would be both lighter and stronger. I would love to hear opinions from both sides. Thanks for any information. I look forward to starting on the build, asking more questions and maybe someday being able to answer some... Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328021#328021 -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 23, 2011
Subject: Re: Rib question
HA! Yup, putting up with my airplane stuff hanging on the living room wall would make her perfect in every way....hey wait a minute....if she was THAT perfect she wouldn't have to settle for me! jm -----Original Message----- >From: Jack Phillips <pietflyr(at)bellsouth.net> >Sent: Jan 23, 2011 8:48 AM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Re: Rib question > > >Sounds like time to get a new wife... > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle >Sent: Sunday, January 23, 2011 8:46 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Rib question > > >Agree with Billy. I cut out a 1/8" ply Scimitar propeller like Dan >Helspar's and hung it on the wall over the patio door. I thought it was the >neatest thing in that room! > >And yes, it WAS a great conversation starter. I quickly got tired of my >wife's "conversations" about having it hanging up there and took it down. > >Sure looked cool though (up to the point where the "conversations" started). > >Jim > > >-----Original Message----- >>From: Charles Campbell <cncampbell(at)windstream.net> >>Sent: Jan 22, 2011 4:04 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Re: Rib question >> > >> >>Hey! That's an idea. Think I'll plan on putting in a centersection tank, >>build the false ribs, and hang my 31st one on the wall of the den. My wife > >>would have an absolute conniption fit. Chuck >>----- Original Message ----- >>From: "Billy McCaskill" <billmz(at)cox.net> >>To: >>Sent: Saturday, January 22, 2011 3:03 PM >>Subject: Pietenpol-List: Re: Rib question >> >> >>> >>> You might want to build a few more, just to hang in the den or the >hangar. >>> Ribs are just cool to look at and they're great conversation starters. >>> >>> -------- >>> Billy McCaskill >>> Urbana, IL >>> tail section almost done, starting on ribs soon >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=327920#327920 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 23, 2011
Just kidding about the Jenny style gear. It was proven last year at Brodhead that a Piet can be landed perfectly well with a broken split axle gear... Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman Sent: Sunday, January 23, 2011 9:35 AM Subject: Pietenpol-List: Re: First Question Gary, After 30 years in Alaska, it is hard to be jealous of anyone :D. Yes, the sunshine is nice (though HOT at times) but it is great to be around my aging parents. Lots of private/hidden strips around the SW, though. As to rough ... I probably won't be landing on any more boulder strewn beaches in this lifetime ... just move interested in major differences between the two gear types. ALSO ... the split gear with tall balloon tiers is a little more like the 1930's Ryan look, which fits San Diego well, eh? Perry -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328041#328041 ________________________________________________________________________________
Date: Jan 23, 2011
Aluminum works very similar to wood, with same tools! Good luck... Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, January 23, 2011 9:44 AM Subject: Pietenpol-List: Re: Bending blocks I'm going to look for some aluminum blocks tomorrow and radius them with my router bits. I hear high speed steel cuts it like butter. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328045#328045 ________________________________________________________________________________
Date: Jan 23, 2011
Yes, Frazier Lake, CA. You are officially 'on the list!' We are working hard to build a West Coast Pietenpol Air Force to someday invade Brodhead...but don't tell anyone! Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (Just finished Rib #24!) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman Sent: Sunday, January 23, 2011 9:58 AM Subject: Pietenpol-List: Re: First Question Wow ... that would be fun ... I presume you mean Frazier Lake, CA and not CA as in Canada -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328049#328049 ________________________________________________________________________________
Date: Jan 23, 2011
Good thought, Mike! Just finished Rib #24, and running the primer line. Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (23 ribs down.) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Groah Sent: Sunday, January 23, 2011 9:34 AM Subject: Re: Pietenpol-List: Re: First Question Gary... I think Perry should attend the West Coast Pietenpol Gathering June 4th at Frazier Lake . Mike Groah Tulare CA _____ From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sun, January 23, 2011 9:02:38 AM Subject: RE: Pietenpol-List: Re: First Question Perry (not Dave), I think I have heard that, but, just how rough a field are you talking about? BTW...Aren't you jealous of all those mid-west guys and their grassy strips? Then, again, you have the perfect weather where you are. Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman Sent: Sunday, January 23, 2011 8:52 AM ________________________________________________________________________________
Date: Jan 23, 2011
Bill,heres what I am doing.It will give forward and rearward stability and no ugly forward cabane.Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328078#328078 Attachments: http://forums.matronics.com//files/2011_01_23_14_05_14_542_492.jpg ________________________________________________________________________________
Date: Jan 23, 2011
Perry,I'd do some serious consideration on what your going to do with your piet.T88 is great but I'd do some serious research on the 8 million ways to build a piet.Mine is a bush plane and built as such.Big motor,tundra tires, Supercub style gear,Ceconite 101 etc.You can build it however you see fit,but if your landing in the bush the wood gear and ford motor with bicycle wheels wont even get you of the ground let alone back on it.Its a 29' design that can use a pile of updating without changing the looks.Just my 3 cents,Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328079#328079 ________________________________________________________________________________
Date: Jan 23, 2011
If I was going to build another Piet I would definitly build everything out of steel except the wing and it would be one piece and 4' longer with a NACA64A410 airfoil,fuselage 4" wider and I'd stick with the long fuselage.Dave What order you build it in is irrelevant -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328080#328080 ________________________________________________________________________________
Date: Jan 23, 2011
Subject: Re: Brace cables, pulleys, wing supports
Gene, It's vector math! William could have picked the location of the right aileron horn if he really wanted to do the math in 3 dimensions (yuck!), but since the aircraft CG must be 25-33% of the wing cord (someone correct me if I'm wrong on that), picking the LE of the wing is FAR easier to take the rest of the measurements from. Let me say that again: the distance of the CG from the LE is a constant value. It is absolutely NOT incorrect, nor is it irrelevant, to pick that point from which to make all the other measurements. Additionally, take N8031 as a case in point against moving the engine (that's #2 in the list in case anyone was wondering). The second owner lengthened the motor mount - brace yourselves - 8 inches. EIGHT INCHES! And it still didn't completely fix the W&B balance of the plane. Supposedly, I only weigh 143 lbs. For the record, I'm 171 fully dressed and I've flown 'er about 55 hours. The previous owner was heavier than me by at least 25 lbs and he flew the plane about 180 tach hours. I have to say that sealing the elevator gaps helped the overall pitch handling A LOT. Now, I'm thinking about rebuilding the cabanes and shifting the wing back to get everything tuned up, but the way the center section attach points were created - the bolts are parallel to the fuselage - 90 degrees off from all other Piet's I've seen - it's going to take more work than just building new front cabanes with welded diagonal braces. But, since the plane flies, and flies pretty well (y'all saw that at B'head last year), I'm not all rip rarin' to get started on that project quite yet. Dan On 01/23/2011 11:39 AM, Gene Rambo wrote: > OK, Ryan, I have got to call BS on this one. The location of the datum > and moving anything in relationship to it is irrelevant. It is proper to > say that to avoid the anteater look you might want to move the wing, but > using the datum as a reason is incorrect. This is the big problem I have > with the W&B project that was in the last newsletter. Rather than > putting the datum at a fixed point, such as the firewall or propeller > flange, the wing leading edge (a movable point) was used. Based on a > fixed point, the information as to axle location and engine mount length > would have been much more useful. As it stands, I do not see any use for > the data as published. > > Gene Rambo > > ------------------------------------------------------------------------ > Date: Sun, 23 Jan 2011 09:51:53 -0600 > Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports > From: rmueller23(at)gmail.com > To: pietenpol-list(at)matronics.com > > Keep in mind, as the numbers in the W&B article bear out, it is more > effective to move the wing to correct for CG issues (or think of it as > moving the fuselage under the wing) than it is to just move the engine > forward. If you move the engine forward you are only moving the weight > of the engine relation to the datum. On the other hand if you move the > wing aft you are now shifting the weight of the engine, the fuselage, > the pilot, and potentially a fuselage fuel tank forward in relation to > the datum. This is going to be a more effective way to correct CG > problems, and will also avoid the "anteater" look you could acquire by > having to hang the engine so far out (especially with lighter small > Continentals). Or, you could split the difference and shift the wing > some, and move the engine forward some. > > Theoretically, it shouldn't require any more work than just figuring out > engine placement. You can weigh your completed wing, weigh your > completed fuselage, add in the weight of the engine at the proposed > location, and then add in the weight of the wing at the proposed > location. Play with the locations to see how the numbers come out.... > > Ryan > > On Sun, Jan 23, 2011 at 6:23 AM, Dangerous Dave > wrote: > > > > > Michael,The reason most folks are putting in the forward braces is > because they take out the brace wires around the front cockpit and > just bracing one side of the cockpit is not quite adequate.I will > not have forward braces but rather cables the the motor mount and > cables running from the rear cabanes to the sides of the cockpit.You > need something to keep the wing from cantilevering forward in a > crash-bad landing.Also if you just put your cabanes straight up and > down,finish everything but the motor mount,do a weight and balance > with the plane complete,covered etc. and put your motor in where it > needs to be you will have perfect weight and balance,no rubbing > cables,great fit on the cockpit cowls and no wondering if your CG is > right or if you'll have to make a half dozen motor mounts instead of > one.On the other hand you can always toss a couple of bricks in to > make it balance,they're cheap.Dave > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327986#327986 > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > ttp://forums.matronics.com > =_blank>http://www.matronics.com/contribution > > * > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jan 23, 2011
>From the "Builder's Questions" notes in the text available from the Pietenpol family, penned by Donald: -------------------------------- Question: "Why don't you up-date the plans?" Answer: "I'm not certain what is meant by up-dating the plans. The plans as designed by Mr. Pietenpol have proven to be correct so many times over and provide the builder with a successful project from the start. I can't think of any reason to change the design. The adage "if it ain't broke, don't fix it" applies in this case. If up-date means adding round wing tips. round tail, round rudder, etc, Mr. Pietenpol tried them all, in every instance the weight usually increase and the airplane's performance regressed. There is a reason for the square wing tip design on this airplane. It flies better and has better landing characteristics. As my father always concluded after his many experiments, "Keep it simple and keep it light"." -------------------------------- Just because you have a desire to try to turn it in to something it was never intended to be doesn't mean it can use a "pile of updating". Ryan On Sun, Jan 23, 2011 at 3:23 PM, Dangerous Dave wrote: > > Perry,I'd do some serious consideration on what your going to do with your > piet.T88 is great but I'd do some serious research on the 8 million ways to > build a piet.Mine is a bush plane and built as such.Big motor,tundra tires, > Supercub style gear,Ceconite 101 etc.You can build it however you see > fit,but if your landing in the bush the wood gear and ford motor with > bicycle wheels wont even get you of the ground let alone back on it.Its a > 29' design that can use a pile of updating without changing the looks.Just > my 3 cents,Dave > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328079#328079 > > ________________________________________________________________________________
Date: Jan 23, 2011
That's what I thought, but I don't know enough to argue. ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Sunday, January 23, 2011 2:16 PM Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports The location of the datum and moving anything in relationship to it is irrelevant? How could you ever possibly perform any CG adjustment if that is irrelevant. You move/add/subtract weight in order to bring the CG within limits, and in order to have a point of reference you have a datum. If you can move weights in relation to the datum, such as moving the engine farther forward, to cause a change in where the CG falls in relation the LE....then what is the problem with sliding the LE (and thusly datum) fore or aft to put the CG at an acceptable location? Sure, on most aircraft you cannot, but on a Piet you can, and it proves to be a more effective change. Prove me wrong, please... Ryan On Sun, Jan 23, 2011 at 11:39 AM, Gene Rambo wrote: OK, Ryan, I have got to call BS on this one. The location of the datum and moving anything in relationship to it is irrelevant. It is proper to say that to avoid the anteater look you might want to move the wing, but using the datum as a reason is incorrect. This is the big problem I have with the W&B project that was in the last newsletter. Rather than putting the datum at a fixed point, such as the firewall or propeller flange, the wing leading edge (a movable point) was used. Based on a fixed point, the information as to axle location and engine mount length would have been much more useful. As it stands, I do not see any use for the data as published. Gene Rambo ------------------------------------------------------------------------- --- Date: Sun, 23 Jan 2011 09:51:53 -0600 Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports From: rmueller23(at)gmail.com To: pietenpol-list(at)matronics.com Keep in mind, as the numbers in the W&B article bear out, it is more effective to move the wing to correct for CG issues (or think of it as moving the fuselage under the wing) than it is to just move the engine forward. If you move the engine forward you are only moving the weight of the engine relation to the datum. On the other hand if you move the wing aft you are now shifting the weight of the engine, the fuselage, the pilot, and potentially a fuselage fuel tank forward in relation to the datum. This is going to be a more effective way to correct CG problems, and will also avoid the "anteater" look you could acquire by having to hang the engine so far out (especially with lighter small Continentals). Or, you could split the difference and shift the wing some, and move the engine forward some. Theoretically, it shouldn't require any more work than just figuring out engine placement. You can weigh your completed wing, weigh your completed fuselage, add in the weight of the engine at the proposed location, and then add in the weight of the wing at the proposed location. Play with the locations to see how the numbers come out.... Ryan On Sun, Jan 23, 2011 at 6:23 AM, Dangerous Dave wrote: Michael,The reason most folks are putting in the forward braces is because they take out the brace wires around the front cockpit and just bracing one side of the cockpit is not quite adequate.I will not have forward braces but rather cables the the motor mount and cables running from the rear cabanes to the sides of the cockpit.You need something to keep the wing from cantilevering forward in a crash-bad landing.Also if you just put your cabanes straight up and down,finish everything but the motor mount,do a weight and balance with the plane complete,covered etc. and put your motor in where it needs to be you will have perfect weight and balance,no rubbing cables,great fit on the cockpit cowls and no wondering if your CG is right or if you'll have to make a half dozen motor mounts instead of one.On the other hand you can always toss a couple of bricks in to make it balance,they're cheap.Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327986#327986 ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 23, 2011
Dave, what size cable do you use on the rear one? ----- Original Message ----- From: "Dangerous Dave" <dsornbor(at)aol.com> Sent: Sunday, January 23, 2011 4:10 PM Subject: Pietenpol-List: Re: Brace cables, pulleys, wing supports > > Bill,heres what I am doing.It will give forward and rearward stability and > no ugly forward cabane.Dave > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328078#328078 > > > Attachments: > > http://forums.matronics.com//files/2011_01_23_14_05_14_542_492.jpg > > > ________________________________________________________________________________
Date: Jan 23, 2011
Maybe look at it this way...you can drive a car on the stationary road, or leave the car standing still and move the road below it. You can move individual pieces below the wing around, ( gear, engine...) or move the wing. As stated, moving the wing has the same effect as moving everything below it at once. Michael Perez Karetaker Aero www.karetakeraero.com --- On Sun, 1/23/11, Dan Yocum wrote: > From: Dan Yocum <yocum(at)fnal.gov> > Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports > To: pietenpol-list(at)matronics.com > Date: Sunday, January 23, 2011, 4:37 PM > --> Pietenpol-List message posted > by: Dan Yocum > > Gene, > > It's vector math! William could have picked the > location of the right > aileron horn if he really wanted to do the math in 3 > dimensions (yuck!), > but since the aircraft CG must be 25-33% of the wing cord > (someone > correct me if I'm wrong on that), picking the LE of the > wing is FAR > easier to take the rest of the measurements from. Let > me say that > again: the distance of the CG from the LE is a > constant > value.It is > absolutely NOT incorrect, nor is it > irrelevant, to pick that point from which to make all the > other > measurements. > > Additionally, take N8031 as a case in point against moving > the engine > (that's #2 in the list in case anyone was wondering). > The second owner > lengthened the motor mount - brace yourselves - 8 > inches. EIGHT INCHES! > And it still didn't completely fix the W&B > balance of the plane. > Supposedly, I only weigh 143 lbs. For the record, I'm > 171 fully dressed > and I've flown 'er about 55 hours. The previous owner > was heavier than > me by at least 25 lbs and he flew the plane about 180 tach > hours. > > I have to say that sealing the elevator gaps helped the > overall pitch > handling A LOT. Now, I'm thinking about rebuilding > the cabanes and > shifting the wing back to get everything tuned up, but the > way the > center section attach points were created - the bolts are > parallel to > the fuselage - 90 degrees off from all other Piet's I've > seen - it's > going to take more work than just building new front > cabanes with welded > diagonal braces. > > But, since the plane flies, and flies pretty well (y'all > saw that at > B'head last year), I'm not all rip rarin' to get started on > that project > quite yet. > > Dan > > > On 01/23/2011 11:39 AM, Gene Rambo wrote: > > OK, Ryan, I have got to call BS on this one. The > location of the datum > > and moving anything in relationship to it is > irrelevant. It is proper to > > say that to avoid the anteater look you might want to > move the wing, but > > using the datum as a reason is incorrect. This is the > big problem I have > > with the W&B project that was in the last > newsletter. Rather than > > putting the datum at a fixed point, such as the > firewall or propeller > > flange, the wing leading edge (a movable point) was > used. Based on a > > fixed point, the information as to axle location and > engine mount length > > would have been much more useful. As it stands, I do > not see any use for > > the data as published. > > > > Gene Rambo > > > > > ------------------------------------------------------------------------ > > Date: Sun, 23 Jan 2011 09:51:53 -0600 > > Subject: Re: Pietenpol-List: Re: Brace cables, > pulleys, wing supports > > From: rmueller23(at)gmail.com > > To: pietenpol-list(at)matronics.com > > > > Keep in mind, as the numbers in the W&B article > bear out, it is more > > effective to move the wing to correct for CG issues > (or think of it as > > moving the fuselage under the wing) than it is to just > move the engine > > forward. If you move the engine forward you are only > moving the weight > > of the engine relation to the datum. On the other hand > if you move the > > wing aft you are now shifting the weight of the > engine, the fuselage, > > the pilot, and potentially a fuselage fuel tank > forward in relation to > > the datum. This is going to be a more effective way to > correct CG > > problems, and will also avoid the "anteater" look you > could acquire by > > having to hang the engine so far out (especially with > lighter small > > Continentals). Or, you could split the difference and > shift the wing > > some, and move the engine forward some. > > > > Theoretically, it shouldn't require any more work than > just figuring out > > engine placement. You can weigh your completed wing, > weigh your > > completed fuselage, add in the weight of the engine at > the proposed > > location, and then add in the weight of the wing at > the proposed > > location. Play with the locations to see how the > numbers come out.... > > > > Ryan > > > > On Sun, Jan 23, 2011 at 6:23 AM, Dangerous Dave > > > wrote: > > > > --> Pietenpol-List message > posted by: "Dangerous Dave" > > > > > > > Michael,The reason most folks > are putting in the forward braces is > > because they take out the > brace wires around the front cockpit and > > just bracing one side of the > cockpit is not quite adequate.I will > > not have forward braces but > rather cables the the motor mount and > > cables running from the rear > cabanes to the sides of the cockpit.You > > need something to keep the > wing from cantilevering forward in a > > crash-bad landing.Also if you > just put your cabanes straight up and > > down,finish everything but the > motor mount,do a weight and balance > > with the plane > complete,covered etc. and put your motor in where it > > needs to be you will have > perfect weight and balance,no rubbing > > cables,great fit on the > cockpit cowls and no wondering if your CG is > > right or if you'll have to > make a half dozen motor mounts instead of > > one.On the other hand you can > always toss a couple of bricks in to > > make it balance,they're > cheap.Dave > > > > -------- > > Covering Piet > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=327986#327986 > > > > > > > > > > > > > > > > ========== > > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > > ========== > > http://forums.matronics.com > > ========== > > le, List Admin. > > ="_blank">http://www.matronics.com/contribution > > ========== > > > > > > > > > > * > > > > st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > > ttp://forums.matronics.com > > =_blank>http://www.matronics.com/contribution > > > > * > > > > * > > > > > > * > > -- > Dan Yocum > Fermilab 630.840.6509 > yocum@fnal.gov, http://fermigrid.fnal.gov > "I fly because it releases my mind from the tyranny of > petty things." > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Jan 23, 2011
Thanks to those who submitted some answers and suggestions. I will go with the CS-to- top engine mount supports. As for the pulley side load...as I get more built and can start to get a handle on where the CS needs to be located, I will then attend to the pulley/cable issue...if there still is one. Thanks again. Michael Perez Karetaker Aero www.karetakeraero.com --- On Sun, 1/23/11, Charles Campbell wrote: > From: Charles Campbell <cncampbell(at)windstream.net> > Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports > To: pietenpol-list(at)matronics.com > Date: Sunday, January 23, 2011, 4:46 PM > --> Pietenpol-List message posted > by: "Charles Campbell" > > Dave, what size cable do you use on the rear one? > ----- Original Message ----- > From: "Dangerous Dave" <dsornbor(at)aol.com> > To: > Sent: Sunday, January 23, 2011 4:10 PM > Subject: Pietenpol-List: Re: Brace cables, pulleys, wing > supports > > > Dave" > > > > Bill,heres what I am doing.It will give forward and > rearward stability and > > no ugly forward cabane.Dave > > > > -------- > > Covering Piet > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=328078#328078 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/2011_01_23_14_05_14_542_492.jpg > > > > > > > > > > > > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Subject: Re: ford engine mount
Date: Jan 23, 2011
Yes, you're reading the plans correctly. I can't recall ever seeing anyone on this list having any issues with the downthrust of the engine as mounted per the plans. It's been working fairly well for over 80 years now as it was designed, I don't see any point in changing it now. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328090#328090 ________________________________________________________________________________
Subject: questions from a new guy...
Date: Jan 23, 2011
Hi Mike, Good to have you as a new Pietenpol builder. Welcome to the best group of people on the internet..This is a bunch that has opinions on every subject - Pietenpol or otherwise. Some of these opinions are even useful! As for your questions, I'll give MY opinions, and please remember what they say about opinions - Opinions are like rectums. Everybody has one and most of them are full of crap. 1. The only real benefit to building one component before the other is personal preference. I did wings, then tail, then fuselage. The advantage to doing it that way is that the wings and tail tend to be relatively flat pieces that are easy to store. Once you build the fuselage, you are stuck with it taking up a good deal of floor space. However this is offset by the fact that you can sit in it and make airplane noises, which can be done with the wing and tail but they are just not as efficient for that task. Your building partner is partially correct in saying that you need to build things to fit the fuselage (the strut fittings, primarily), but the same can be said for the wing. Build BOTH before making the fittings. And as Mike Cuy points out in his video (the best $20 you can spend, by the way, apart from the $80 you need to spend for the four Tony Bingelis books), all of the fittings for the Pietenpol should be lengthened by at least 1/2" to make it easier to fit the clevis pins in past the fabric. 2. The one piece wing is definitely lighter. It is also a pain in the rear to move and store, and even picking it up really needs 3 people so it doesn't deflect too much in the middle. I'm not sure how much lighter it is than the 3-piece, but my guess is somewhere around 10 lbs., when you count the extra wood, the extra fittings and bolts, and the fairings which cover the gap between the outer panels and the centersection. 3. I think the steel fuselage is probably lighter and stronger, but it also is a lot of trouble to plan ahead for every little fitting and attachment, and welding on tabs so you can something. There are a number of steel fuse Piets flying, including Roman Buckholts (sp? - sorry Roman) and the Big Piets from Georgia. It basically depends on how comfortable you are with welding. Many Pietenpol builders are attracted to the design because it looks simple and they are familiar with woodworking, little realizing just how much welding is involved with building a wooden airplane. Build what you want. As long as you don't try to "improve" the design much, you'll end up with a great airplane Good luck, Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MPB Sent: Sunday, January 23, 2011 11:05 AM Subject: Pietenpol-List: questions from a new guy... I just bought a set of plans from Don and am planning on starting on the project in a few months (I need to finish a boat I started on first). I have a couple of questions that I would like to throw out there and gain some practical knowledge. At this point I am heavily leaning toward the one piece wing, the steel tube fuselage, and a Continental engine (C85 or 0200) 1- Is there a benefit to start with one major component (wing, fuselage, tail feathers) before another? From a space standpoint I would build the tail and wing before the fuselage as they take up less room in the shop, but my building partner says to build the fuselage first so you can build everything to fit to it. 2- I am leaning toward the one piece wing because I am assuming it to be lighter or stronger and simpler to build. Are these assumptions correct? 3- I wanted to build the steel tube fuselage because it is another medium to work with in the build and I like working with metal, but I notice most of the sites and posts are from guys building a wood fuselage. I also can't help but think that it would be both lighter and stronger. I would love to hear opinions from both sides. Thanks for any information. I look forward to starting on the build, asking more questions and maybe someday being able to answer some... Mike ________________________________________________________________________________
Date: Jan 23, 2011
Ryan, you and Gene are arguing over two different things. Gene is referring to the choice of datum for comparing various different airplanes. Obviously, what matters most (and the reason we even compute weight and balance) is the relationship of the center of gravity to the center of pressure (or center of lift, as it is sometimes called). This is usually stated as the CG falling in some range as a percentage of wing chord, and the easiest way to relate that is a distance from the leading edge. But when you are doing the w&b on your airplane and trying to decide how much to move the wing, it is much easier if a FIXED point of the airframe is used as the datum. I used the firewall on mine, and since that point is pretty close to being the same for all Pietenpols, it makes sense to use it if you are trying to compare several different airplanes. Manufacturers typically pick a point in front of the airplane (sometimes the prop hub, sometimes a point in space in front of any part of the airplane) so that all arms are positive. If you pick a point on the plane such as the firewall or the leading edge, anything forward of that has a negative arm which can lead to calculation errors if not recognized. I tend to agree with Gene that picking the leading edge of a wing that you intend to possibly move is not the best choice, since all the variable weights such as pilot, passenger, baggage, fuel, etc. now will have a different arm as soon as you move the wing. But choosing the LE is not wrong, just more work. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan Mueller Sent: Sunday, January 23, 2011 2:17 PM Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports The location of the datum and moving anything in relationship to it is irrelevant? How could you ever possibly perform any CG adjustment if that is irrelevant. You move/add/subtract weight in order to bring the CG within limits, and in order to have a point of reference you have a datum. If you can move weights in relation to the datum, such as moving the engine farther forward, to cause a change in where the CG falls in relation the LE....then what is the problem with sliding the LE (and thusly datum) fore or aft to put the CG at an acceptable location? Sure, on most aircraft you cannot, but on a Piet you can, and it proves to be a more effective change. Prove me wrong, please... Ryan On Sun, Jan 23, 2011 at 11:39 AM, Gene Rambo wrote: OK, Ryan, I have got to call BS on this one. The location of the datum and moving anything in relationship to it is irrelevant. It is proper to say that to avoid the anteater look you might want to move the wing, but using the datum as a reason is incorrect. This is the big problem I have with the W&B project that was in the last newsletter. Rather than putting the datum at a fixed point, such as the firewall or propeller flange, the wing leading edge (a movable point) was used. Based on a fixed point, the information as to axle location and engine mount length would have been much more useful. As it stands, I do not see any use for the data as published. Gene Rambo _____ Date: Sun, 23 Jan 2011 09:51:53 -0600 Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports From: rmueller23(at)gmail.com Keep in mind, as the numbers in the W&B article bear out, it is more effective to move the wing to correct for CG issues (or think of it as moving the fuselage under the wing) than it is to just move the engine forward. If you move the engine forward you are only moving the weight of the engine relation to the datum. On the other hand if you move the wing aft you are now shifting the weight of the engine, the fuselage, the pilot, and potentially a fuselage fuel tank forward in relation to the datum. This is going to be a more effective way to correct CG problems, and will also avoid the "anteater" look you could acquire by having to hang the engine so far out (especially with lighter small Continentals). Or, you could split the difference and shift the wing some, and move the engine forward some. Theoretically, it shouldn't require any more work than just figuring out engine placement. You can weigh your completed wing, weigh your completed fuselage, add in the weight of the engine at the proposed location, and then add in the weight of the wing at the proposed location. Play with the locations to see how the numbers come out.... Ryan On Sun, Jan 23, 2011 at 6:23 AM, Dangerous Dave wrote: Michael,The reason most folks are putting in the forward braces is because they take out the brace wires around the front cockpit and just bracing one side of the cockpit is not quite adequate.I will not have forward braces but rather cables the the motor mount and cables running from the rear cabanes to the sides of the cockpit.You need something to keep the wing from cantilevering forward in a crash-bad landing.Also if you just put your cabanes straight up and down,finish everything but the motor mount,do a weight and balance with the plane complete,covered etc. and put your motor in where it needs to be you will have perfect weight and balance,no rubbing cables,great fit on the cockpit cowls and no wondering if your CG is right or if you'll have to make a half dozen motor mounts instead of one.On the other hand you can always toss a couple of bricks in to make it balance,they're cheap.Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=327986#327986 ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com =_blank>http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 23, 2011
Thanks for contributing your thoughts Jack, always valuable. I won't pick your post apart, but mainly focus on the final statement: "...choosing the LE is not wrong, just more work". Well, it may be a bit more work than just moving one item and recalculating your numbers, but as long as you understand what you have to recalculate when you move the LE....it's not much more work. Grab a freely available W&B spreadsheet, and understand wha t you are doing, and you can calculate the results just fine. I don't believe it's any more difficult than any of the math or building that you have to d o in the build.....so no reason to shy away from it. Thanks, Ryan On Sun, Jan 23, 2011 at 4:59 PM, Jack Phillips wrot e: > Ryan, you and Gene are arguing over two different things. Gene is > referring to the choice of datum for comparing various different airplane s. > Obviously, what matters most (and the reason we even compute weight and > balance) is the relationship of the center of gravity to the center of > pressure (or center of lift, as it is sometimes called). This is usually > stated as the CG falling in some range as a percentage of wing chord, and > the easiest way to relate that is a distance from the leading edge. > > > But when you are doing the w&b on your airplane and trying to decide how > much to move the wing, it is much easier if a FIXED point of the airframe is > used as the datum. I used the firewall on mine, and since that point is > pretty close to being the same for all Pietenpols, it makes sense to use it > if you are trying to compare several different airplanes. Manufacturers > typically pick a point in front of the airplane (sometimes the prop hub, > sometimes a point in space in front of any part of the airplane) so that all > arms are positive. If you pick a point on the plane such as the firewall or > the leading edge, anything forward of that has a negative arm which can l ead > to calculation errors if not recognized. > > > I tend to agree with Gene that picking the leading edge of a wing that yo u > intend to possibly move is not the best choice, since all the variable > weights such as pilot, passenger, baggage, fuel, etc. now will have a > different arm as soon as you move the wing. But choosing the LE is not > wrong, just more work. > > > Jack Phillips > > NX899JP =93Icarus Plummet=94 > > Raleigh, NC > > > ------------------------------ > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Ryan Mueller > *Sent:* Sunday, January 23, 2011 2:17 PM > > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports > > > The location of the datum and moving anything in relationship to it is > irrelevant? How could you ever possibly perform any CG adjustment if that is > irrelevant. You move/add/subtract weight in order to bring the CG within > limits, and in order to have a point of reference you have a datum. > > > If you can move weights in relation to the datum, such as moving the engi ne > farther forward, to cause a change in where the CG falls in relation the > LE....then what is the problem with sliding the LE (and thusly datum) for e > or aft to put the CG at an acceptable location? Sure, on most aircraft yo u > cannot, but on a Piet you can, and it proves to be a more effective chang e. > Prove me wrong, please... > > > Ryan > > On Sun, Jan 23, 2011 at 11:39 AM, Gene Rambo wrote: > > OK, Ryan, I have got to call BS on this one. The location of the datum a nd > moving anything in relationship to it is irrelevant. It is proper to say > that to avoid the anteater look you might want to move the wing, but usin g > the datum as a reason is incorrect. This is the big problem I have with the > W&B project that was in the last newsletter. Rather than putting the dat um > at a fixed point, such as the firewall or propeller flange, the wing lead ing > edge (a movable point) was used. Based on a fixed point, the information as > to axle location and engine mount length would have been much more useful . > As it stands, I do not see any use for the data as published. > > Gene Rambo > > ------------------------------ > > Date: Sun, 23 Jan 2011 09:51:53 -0600 > Subject: Re: Pietenpol-List: Re: Brace cables, pulleys, wing supports > From: rmueller23(at)gmail.com > > > To: pietenpol-list(at)matronics.com > > Keep in mind, as the numbers in the W&B article bear out, it is more > effective to move the wing to correct for CG issues (or think of it as > moving the fuselage under the wing) than it is to just move the engine > forward. If you move the engine forward you are only moving the weight of > the engine relation to the datum. On the other hand if you move the wing aft > you are now shifting the weight of the engine, the fuselage, the pilot, a nd > potentially a fuselage fuel tank forward in relation to the datum. This i s > going to be a more effective way to correct CG problems, and will also av oid > the "anteater" look you could acquire by having to hang the engine so far > out (especially with lighter small Continentals). Or, you could split the > difference and shift the wing some, and move the engine forward some. > > > Theoretically, it shouldn't require any more work than just figuring out > engine placement. You can weigh your completed wing, weigh your completed > fuselage, add in the weight of the engine at the proposed location, and t hen > add in the weight of the wing at the proposed location. Play with the > locations to see how the numbers come out.... > > > Ryan > > On Sun, Jan 23, 2011 at 6:23 AM, Dangerous Dave wrote: > > > Michael,The reason most folks are putting in the forward braces is becaus e > they take out the brace wires around the front cockpit and just bracing o ne > side of the cockpit is not quite adequate.I will not have forward braces but > rather cables the the motor mount and cables running from the rear cabane s > to the sides of the cockpit.You need something to keep the wing from > cantilevering forward in a crash-bad landing.Also if you just put your > cabanes straight up and down,finish everything but the motor mount,do a > weight and balance with the plane complete,covered etc. and put your moto r > in where it needs to be you will have perfect weight and balance,no rubbi ng > cables,great fit on the cockpit cowls and no wondering if your CG is righ t > or if you'll have to make a half dozen motor mounts instead of one.On the > other hand you can always toss a couple of bricks in to make it > balance,they're cheap.Dave > > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=327986#327986 > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * * > > * * > > *st" target=_blank>http://www.matronics.com/Navigator?Pietenpol-List* > > *ttp://forums.matronics.com* > > *=_blank>http://www.matronics.com/contribution* > > * * > > * * > > * * > > *" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List* > > *tp://forums.matronics.com* > > *_blank">http://www.matronics.com/contribution* > > * * > > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jan 23, 2011
So you replace two "ugly" forward cabanes with four cables, two fore and aft? Ryan On Sun, Jan 23, 2011 at 3:10 PM, Dangerous Dave wrote: > > Bill,heres what I am doing.It will give forward and rearward stability and > no ugly forward cabane.Dave > > -------- > Covering Piet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328078#328078 > > > Attachments: > > http://forums.matronics.com//files/2011_01_23_14_05_14_542_492.jpg > > ________________________________________________________________________________
Subject: Re: First Question
Date: Jan 23, 2011
Ryan,If a steerable tailwheel,brakes landing gear in the proper position,pulleys with bearings,4130 steel,synthetic fabric,a real motor,required instuments,seatbelts,nose fuel and elt aren't updates then I guess the plans are perfect and you should strictly adhere to them,Dave -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328104#328104 ________________________________________________________________________________
Date: Jan 23, 2011
The drag coefficient of 4 3/32" cables is 1/8 that of 2- 7/8 x 2 1/2 struts-math -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328105#328105 ________________________________________________________________________________
Date: Jan 23, 2011
Who would make the diagonals out of 7/8" x 2-1/2" tubing? Mine are 1/2" x 1-3/8". And yes, they have a lower drag coefficient than 4 3/32" cables (a round shape is one of the worst shapes you can try to push through the air - out of all proportion to its actual frontal area) Check out this video, which demonstrates pretty graphically the drag of a round object. http://www.youtube.com/watch?v=ftq8jTQ8ANE Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dangerous Dave Sent: Sunday, January 23, 2011 7:08 PM Subject: Pietenpol-List: Re: Brace cables, pulleys, wing supports The drag coefficient of 4 3/32" cables is 1/8 that of 2- 7/8 x 2 1/2 struts-math -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328105#328105 ________________________________________________________________________________
Date: Jan 23, 2011
Apparently physics and aeronautical engineering don't apply to Piets guess I should have built unicycle -------- Covering Piet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328116#328116 ________________________________________________________________________________
Date: Jan 23, 2011
Dave, For whatever it might be worth, Dan Helsper and numerous other builders here have adhered extremely closely to the plans, and their airplanes are perfectly flyable just the way they are. Some people just like to try to re-invent the wheel, while others are quite happy with the wheel as it is. As the Piet is designed, the wheel seems perfectly round to me. Ford Model A engines (and Corvairs too) really are real engines, they certainly aren't just figments of the imagination bolted to the firewalls. Lycomings and Continentals are NOT immune to failure either... ANY mechanical device is subject to fail without notice, there is no special dispensation from the FAA stating that Ly-Cons are not subject to the laws of nature or physics. The landing gear as it is drawn in the plans is in the correct position if you are not using brakes. Not everyone puts brakes on their Piet, not everyone needs them depending on where they choose to fly from. And when is the last time you or anyone else you know actually used 80lb Irish linen and nitrocellulose dope to cover an airplane? Some changes are made due to availability of materials, cost considerations, common sense (casein glue, anybody?), and some just to meet FAA requirements. This doesn't mean the plane needs to be "updated" (redesigned). If you feel the need to deviate from the plans or change something on your plane, feel free to do so, it is YOUR plane. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328127#328127 ________________________________________________________________________________
Subject: Re: Bending blocks
Date: Jan 23, 2011
I've posted this before, here is my homemade brake. Cost about 20 bucks to build. Great Radius bends, will bend everything you need for most homebuilt fittings. I've bent a piece of .250 - 6 inches wide at 90 degrees. It does take a little muscle. The lighter stuff .10 and thinner is pretty easy. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328130#328130 Attachments: http://forums.matronics.com//files/dscn4555_797.jpg ________________________________________________________________________________
Date: Jan 23, 2011
Losts of good thoughts here ... appreciate all the support and ideas! As to a bush version ... nah ... that is behind me, though that R2800 sure would be fun out front! I think at this point I want to keep Dave's wife happy with slow and "stick around home" type of power ... though the Lion Speed Head on the Ford might make it a little more fun. -------- Perry Shipman Lakeside, CA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328133#328133 ________________________________________________________________________________
Date: Jan 23, 2011
Gary!!! It's looking great! I'm glad to see you're working on that thing. I've been slowed down a little this past week because of a daughter with a respiratory virus. But I'll be back at it soon. I can't let you get ahead o f me. Mike Groah On Jan 23, 2011, at 12:48 PM, "Gary Boothe" wrote: > Good thought, Mike! Just finished Rib #24, and running the primer line > > Gary Boothe > Cool, Ca. > Pietenpol > WW Corvair Conversion, Running! > Tail done, Fuselage on gear > (23 ribs down) > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Michael Groah > Sent: Sunday, January 23, 2011 9:34 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: First Question > > Gary... > > I think Perry should attend the West Coast Pietenpol Gathering June 4th a t Frazier Lake . > > > Mike Groah > Tulare CA > > From: Gary Boothe <gboothe5(at)comcast.net> > To: pietenpol-list(at)matronics.com > Sent: Sun, January 23, 2011 9:02:38 AM > Subject: RE: Pietenpol-List: Re: First Question > > > Perry (not Dave), > > I think I have heard that, but, just how rough a field are you talking > about? BTW...Aren't you jealous of all those mid-west guys and their grass y > strips? Then, again, you have the perfect weather where you are. > > Gary > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of PShipman > Sent: Sunday, January 23, 2011 8:52 AM > To: > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ________________________________________________________________________________
Date: Jan 23, 2011
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Subject: ford engine mount
Jeff,-that's an error in the-F&GM,-should be 2 1/2 degrees, not inche s. The "new" improved plans says 1" drop. Also, the bolts and tubes are of different sizes. Saludos - Santiago=0A=0A=0A ________________________________________________________________________________
Subject: Brace cables, pulleys, wing supports
Date: Jan 23, 2011
Michael; This has probably already been answered, but the reason most folks go with cabane braces forward to the firewall instead of the X-brace cables between the cabanes is that it makes it easier for passengers to get in and out of the front cockpit if those X-brace cables are not there. Either method is fine structurally. I have seen more than one Air Camper with the X-brace cables only on one side of the cockpit (the starboard side, or 'far side' if you're trying to climb into the front cockpit) though. If you do go with cabane brace tubes, you would do well to read and heed what William Wynne opined on the subject recently, on his website here: http://www.flycorvair.com/osh2010.html , photos 4 and 5 from the top. Oscar Zuniga Air Camper NX41CC "Scout" San Antonio, TX website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Ah, opinions...
Date: Jan 23, 2011
So far I've heard comments ranging from, "That's an absolutely beautiful airplane" to "That prop looks like crap!" Fortunately, most comments have been complimentary. I recently read that chrome spoked wheels on a 1920s airplane make her look like a "tart." That one made me smile. Fat-Bottomed-Girl is a tart! That's wonderful. That's what I want her to be. I've also been told that I'm remiss for allowing the case nuts to rust on the dreaded crank-snappin'-valve-eatin'-corvair. I've been called a liar for claiming an initial rate of climb of 700 fpm on a cool morning at sea level with the ugly prop. I didn't hit that guy. The guy who commented on some metal work that was in process, "Not much of a metal worker, are you?" came REAL close to getting smacked. Those of you who know me well know that I'm willing and able, though not likely, to do that:). I've been told that my welds look "cold." There's certainly some precedent to question my welding, but that specifically was not the issue. My point? Be careful who you listen to. The guys who have built their planes and have flown them a bunch are probably reliable sources of information. Like Jack said, there are a lot of opinions out there. In the Pietenpol world, I personally seek the advice of people like Jack Phillips (engineer & builder), Hans van der Voort (engineer & builder), Mike Cuy (builder & teacher), Don Emch (builder) and Dan Helsper (builder). There are several others, but those guys are a good start. I also listen closely to guys like Gary Boothe and Rick Holland. Their work speaks for itself. For what it's worth. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328154#328154 ________________________________________________________________________________
Date: Jan 23, 2011
Is there not reference somewhere to BHP himself having to land in a plowed field, ACROSS the rows and then taking off again later. All with no damage to the wood gear? Clif Wood - The original composite. That doesn't weaken in summer heat. > > Perry (not Dave), > > I think I have heard that, but, just how rough a field are you talking > Gary > > Gary, > > ! The only folks worth knowing have strong opinions, IMO! :D > > I was wondering, though, if the split gear might be better on > rough/unimproved strips??? > Perry Shipman > Lakeside, CA ________________________________________________________________________________
Date: Jan 23, 2011
Subject: Bending jig
Here is a photo of the bender my father built several years ago. He made th ree of these and they work perfect. I also have an angle bender which slide s over the top of the center bending iron. If anyone is interested, I have a bench mount one very similar to this one I can take pictures of... surely we can negotiate a price. - Ken H Fargo, ND - =0A=0A=0A ________________________________________________________________________________
Date: Jan 23, 2011
Subject: Trim set-up
Members: - Here is a couple photos of my trim assemble for the stick pressure. I have not completed the rest of the set-up for the springs ect.. but seeking info rmation as to how much travel should be allowed for. Jack, Mike, any ideas? -I am fabricating-and attaching the spring to my bell crank. - Ken H. Fargo, ND- - =0A=0A=0A ________________________________________________________________________________
Date: Jan 23, 2011
Of no comparison to the fine brake that Dan is illustrating, but functional for an 8' bend, is this brake I built out of angle iron and a piano hinge (for a previous project). I have since cut it down to 5', which is still longer than I need for the Piet cowling. Fortunately, I have returned from the Dark Side, and am at home with wood and fabric... Gary Boothe Cool, Ca. Pietenpol WW Corvair Conversion, Running! Tail done, Fuselage on gear (24 ribs down.) -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of dwilson Sent: Sunday, January 23, 2011 5:50 PM Subject: Pietenpol-List: Re: Bending blocks I've posted this before, here is my homemade brake. Cost about 20 bucks to build. Great Radius bends, will bend everything you need for most homebuilt fittings. I've bent a piece of .250 - 6 inches wide at 90 degrees. It does take a little muscle. The lighter stuff .10 and thinner is pretty easy. Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328130#328130 Attachments: http://forums.matronics.com//files/dscn4555_797.jpg ________________________________________________________________________________
Subject: Re: Lively Forum Today!
Date: Jan 23, 2011
Yep, lively indeed. I'm getting my mind geared up to get going again too... cold or not, cabin fever is setting in. Helps that we had EAA pancakes this weekend... now we are talking Brodhead and Oshkosh plans. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328168#328168 ________________________________________________________________________________
Date: Jan 23, 2011
Don't forget why it was done in the first place. The Ford has quite low HP and in takeoff the plane ( well, all AC ), mush through the air. Having the engine point downwards compensates for this somewhat by aligning the axis of the prop closer to the line of flight. Clif > > Yes, you're reading the plans correctly. I can't recall ever seeing > anyone on this list having any issues with the downthrust of the engine as > mounted per the plans. It's been working fairly well for over 80 years > now as it was designed, I don't see any point in changing it now. > > -------- > Billy McCaskill ________________________________________________________________________________
Subject: Re: questions from a new guy...
Date: Jan 23, 2011
thanks all for the feedback! It did bring up a couple questions. Why a "mock" fuselage? space? layout? I have also seen a little going around about different airfoils and it was brought up by Dave here. I have to admit that the one on the plan looks a little primitive. I downloaded a pdf of the "ribblet 612" airfoil. do you know if this is the same one you recommended? Is there a lot of discussion on which airfoil to use? Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328176#328176 ________________________________________________________________________________
Date: Jan 23, 2011
Mark, Cold? I'd bet Oklahoma cold ain't all too bad--it's been downright awful up in Minnesota; -22 F last night. You don't know of any good property down there, do you? Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328177#328177 ________________________________________________________________________________
Subject: Re: Gary Boothe's Ribs
Date: Jan 23, 2011
Really! After the pictures you posted of your fantastic craftsmanship, you need to finish those last few ribs (and the wall-hanging one). If you'd like, I'm sure you could find 7 or 8 of us to help! Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328178#328178 ________________________________________________________________________________
Date: Jan 24, 2011
The primary reason for a mock fuselage is to see if you can comfortably fit in a Pietenpol. Pietenpol builders are larger now than they were back in the day of Bernard and Don Finke (and they seem to be getting larger all the time). If you fly a Pietenpol any distance, you will be sitting in it for a long time. When I fly mine from North Carolina to Brodhead, it is about 13 hours of flying, and I have done that in one day (once). That's a long time to sit in first class, much less in a cramped cockpit where there is exactly ONE position you can sit. So many people build a "mockpit". I think a better alternative is to go to Brodhead before you start building and sit in as many different Piets as the owners will allow and make your decision from that. As for the airfoil, a Pietenpol is a 1929 airplane. If that is what you want, build it to the plans. If you want something more modern, build a Sonex. Seriously, there are some under construction with the Riblett airfoil. To my eye, they don't look like Pietenpols (the leading edge doesn't look right - too fat). There is a lot of discussion about airfoils but not enough Ribletts are flying to give good data. Build a Pietenpol to the plans, and build it light and it will fly well. Modify the design, make it heavy, it may or may not (probably won't). There have been a huge number of Pietenpols built, with a lot of variations from the plans. I don't know of any of them that fly any better than a strictly plans built airplane. Just my opinions. Take them with a grain of salt. Jack Phillips NX899JP "Icarus Plummet" (A Pietenpol built pretty close to the plans. I wish I'd built it closer to the plans. It would fly better) Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MPB Sent: Monday, January 24, 2011 12:46 AM Subject: Pietenpol-List: Re: questions from a new guy... thanks all for the feedback! It did bring up a couple questions. Why a "mock" fuselage? space? layout? I have also seen a little going around about different airfoils and it was brought up by Dave here. I have to admit that the one on the plan looks a little primitive. I downloaded a pdf of the "ribblet 612" airfoil. do you know if this is the same one you recommended? Is there a lot of discussion on which airfoil to use? Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328176#328176 ________________________________________________________________________________
Date: Jan 24, 2011
Ken, I think mine gives a travel at the bellcrank that the springs attach to of about 6" total. Of course the travel required is entirely dependent on the strength of the spring used. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of KM Heide CPO/FAAOP Sent: Sunday, January 23, 2011 11:16 PM Subject: Pietenpol-List: Trim set-up Members: Here is a couple photos of my trim assemble for the stick pressure. I have not completed the rest of the set-up for the springs ect.. but seeking information as to how much travel should be allowed for. Jack, Mike, any ideas? I am fabricating and attaching the spring to my bell crank. Ken H. Fargo, ND ________________________________________________________________________________
Date: Jan 24, 2011
i sure thought 2 1/2 inches was too much.... 2 1/2 degrees sounds better.. thanks for the replies Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328190#328190 ________________________________________________________________________________
Date: Jan 24, 2011
Its funny. You always hear that advise from experienced builders "stick to the plans". The RV crowd says it, boats designs, etc. Yet we can never seem to avoid "tinkering" with the design (I'll refrain from saying "improving"). I guess its part of what draws someone to building, but I appreciate the advise. Like so many discussions the airfoil one seems to have strong opinions on both sides that will warant some more research. Thanks again, Mike BTW- Gary asked where I am located and I noticed he is from Cool, CA. I live in Prunedale near Monterey Bay. I have family in Placerville. Small world... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328192#328192 ________________________________________________________________________________
Date: Jan 24, 2011
Subject: Re: Brace cables, pulleys, wing supports
Thanks Oscar. My cabane attach fittings at the center section were made with extra bolt holes to attach the supports from the center section to the top engine mount. My plan is to weld metal brackets to the support struts then bolt those to the center section fittings at the cabane attach fitting. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: Trim set ups
Date: Jan 24, 2011
Hi Guys, Long time Lurker (spelling), love the info flowing on this forum, by far the best on the net. I have had the Ray Allen system in my Hatz for the last ten years and it has been flawless. It is setup just like the piet pictures above and I cannot imagine a trim system that could weigh less if you all ready have an electrical system. Luke Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328199#328199 ________________________________________________________________________________
Date: Jan 24, 2011
I think "plans builders" are born with the "tinkerers gene". We can't help ourselves. Otherwise we would just have purchased a quick build kit. Now please excuse me, I just thought of a "better" way to attach my cabane brace tubes. rick On Mon, Jan 24, 2011 at 7:27 AM, MPB wrote: > > Its funny. You always hear that advise from experienced builders "stick to > the plans". The RV crowd says it, boats designs, etc. Yet we can never > seem to avoid "tinkering" with the design (I'll refrain from saying > "improving"). I guess its part of what draws someone to building, but I > appreciate the advise. Like so many discussions the airfoil one seems to > have strong opinions on both sides that will warant some more research. > Thanks again, > Mike > > BTW- Gary asked where I am located and I noticed he is from Cool, CA. I > live in Prunedale near Monterey Bay. I have family in Placerville. Small > world... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328192#328192 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 24, 2011
Three other benefits of the mock cockpit: - figuring out how things go together before cutting up your expensive wood - turned upside down makes a great welding jig for the landing gear, and if some wood starts smoking while tack welding some brackets, who cares? - great conversation piece and amusement for the kids in the back yard On Mon, Jan 24, 2011 at 5:34 AM, Jack Phillips wrote: > pietflyr(at)bellsouth.net> > > The primary reason for a mock fuselage is to see if you can comfortably fit > in a Pietenpol. Pietenpol builders are larger now than they were back in > the day of Bernard and Don Finke (and they seem to be getting larger all > the > time). If you fly a Pietenpol any distance, you will be sitting in it for > a > long time. When I fly mine from North Carolina to Brodhead, it is about 13 > hours of flying, and I have done that in one day (once). That's a long > time > to sit in first class, much less in a cramped cockpit where there is > exactly > ONE position you can sit. So many people build a "mockpit". I think a > better alternative is to go to Brodhead before you start building and sit > in > as many different Piets as the owners will allow and make your decision > from > that. > > As for the airfoil, a Pietenpol is a 1929 airplane. If that is what you > want, build it to the plans. If you want something more modern, build a > Sonex. Seriously, there are some under construction with the Riblett > airfoil. To my eye, they don't look like Pietenpols (the leading edge > doesn't look right - too fat). There is a lot of discussion about airfoils > but not enough Ribletts are flying to give good data. > > Build a Pietenpol to the plans, and build it light and it will fly well. > Modify the design, make it heavy, it may or may not (probably won't). > There > have been a huge number of Pietenpols built, with a lot of variations from > the plans. I don't know of any of them that fly any better than a strictly > plans built airplane. > > Just my opinions. Take them with a grain of salt. > > Jack Phillips > NX899JP "Icarus Plummet" (A Pietenpol built pretty close to the plans. I > wish I'd built it closer to the plans. It would fly better) > Raleigh, NC > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of MPB > Sent: Monday, January 24, 2011 12:46 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: questions from a new guy... > > > thanks all for the feedback! > It did bring up a couple questions. Why a "mock" fuselage? space? layout? > I have also seen a little going around about different airfoils and it was > brought up by Dave here. I have to admit that the one on the plan looks a > little primitive. I downloaded a pdf of the "ribblet 612" airfoil. do you > know if this is the same one you recommended? Is there a lot of discussion > on which airfoil to use? > > Thanks, > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328176#328176 > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 24, 2011
Gene wrote: >it is important to move weight in relation to the ham sandwich >in my back pocket (when seated in the aircraft Say, Gene... are you gonna eat that sandwich or is it extra? -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328214#328214 ________________________________________________________________________________
Subject: Re: Ah, opinions...
Date: Jan 24, 2011
Gene Rambo's on that named list, too. When he told me that he'd looked over the airplane last year after the crash I knew we were in good shape. Sorry Gene! Kevin -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328218#328218 ________________________________________________________________________________
Subject: Trim
Date: Jan 24, 2011
Rick, A few days ago you posted some pics of your electric trim. I have that exact actuator from my abandoned 601HDS project. I have been fighting such luxuries (along with the 5th bearing), but I am now resigned to the fact that I am building a "tinkered with" Piet. Hope Mr. Pietenpol is smiling upon me. Furthermore, I already have a full blown electric system, complete with switches, knobs and fuses. Regrettably, I deleted your pics. Would you mind re-posting? Gary Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Jan 24, 2011
Check over on the KR forum. There have been several trim systems made with a salvaged automobile electric mirror motor. Required installing in the elevator like the pictures show, but the users are happy with their performance. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328224#328224 ________________________________________________________________________________
Date: Jan 24, 2011
Did you forget the "fisherman"? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328225#328225 ________________________________________________________________________________
Date: Jan 24, 2011
You are right Tom... cold is a relative term. Cold to us is teens and 20s overnight with the occasional single digits, but it makes me want to stay away from my non insulated hangar. About this time of year I just can't stand it anymore, so I'll add a few layers and find a way to get something done. Property? Sure, lots of it around here. The future job market isn't looking too bad for us either... come on down! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328227#328227 ________________________________________________________________________________
Date: Jan 24, 2011
+1 on Kevin's comments. I'm trying my best to keep to myself and build to the plans, but occasionally I am unable to find the answers I need so I ask here. All in all there are good folks here and you'll find out who knows what they are talking about pretty quick. Kevin... "Liar" and "Not much of a metal worker"? Hmm, I might not make a fist either, but I would verbally embarrass someone for being so rude. I know, some would say that I am a hot head, or that I have poor communication skills for doing such a thing... oh well. For what it's worth, I really dig your airplane. I hope for mine to be very similar. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328235#328235 ________________________________________________________________________________
Date: Jan 24, 2011
I still consider myself a newbie here but have learned to respect the opinions of the same people you have listed. Two of those individuals share private emails with me and answer the questions I have but don't want to post on the list. Jack Phillips would be another one I would put my trust in but he hates corvair engines. This weekend a friend of mine told me to avoid using T-88 epoxy as it will break down at 110 degrees F. So on the tarmac at Phoenix in the summer your plane could fall apart. I emailed threesystems about heat limits of T-88 and this is their reply. An upper limit would be around 160-180F. The T-88 itself will not fail. Failure comes from a combination of stresses from the wood shrinking combined with the fact that the Glass Transition Temperature for T-88 is around 150F. System Three Resins, Inc. Technical Support 253-333-8118 www.systemthree.com -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328237#328237 ________________________________________________________________________________
Date: Jan 24, 2011
Subject: Re: Trim
No problemo Gary, I am also trying to resist spending the extra $1100 for a Weseman 5th bearing also. rick On Mon, Jan 24, 2011 at 10:15 AM, wrote: > > Rick, > > A few days ago you posted some pics of your electric trim. I have that > exact actuator from my abandoned 601HDS project. I have been fighting suc h > luxuries (along with the 5th bearing), but I am now resigned to the fact > that I am building a "tinkered with" Piet. Hope Mr. Pietenpol is smiling > upon me. Furthermore, I already have a full blown electric system, comple te > with switches, knobs and fuses. > > Regrettably, I deleted your pics. Would you mind re-posting? > > Gary > Sent on the Sprint=AE Now Network from my BlackBerry=AE > > =========== =========== =========== =========== > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 24, 2011
Empirical evidence and a boatload of hours accumulated have shown that a Piet built with T-88 is not going to fall apart when it gets hot outside.... Ryan On Mon, Jan 24, 2011 at 12:27 PM, Kringle wrote: > > I still consider myself a newbie here but have learned to respect the > opinions of the same people you have listed. Two of those individuals share > private emails with me and answer the questions I have but don't want to > post on the list. Jack Phillips would be another one I would put my trust > in but he hates corvair engines. > > This weekend a friend of mine told me to avoid using T-88 epoxy as it will > break down at 110 degrees F. So on the tarmac at Phoenix in the summer your > plane could fall apart. I emailed threesystems about heat limits of T-88 > and this is their reply. > > An upper limit would be around 160-180F. The T-88 itself will not fail. > Failure comes from a combination of stresses from the wood shrinking > combined with the fact that the Glass Transition Temperature for T-88 is > around 150F. > > System Three Resins, Inc. > Technical Support > 253-333-8118 > www.systemthree.com > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=328237#328237 > > ________________________________________________________________________________
Date: Jan 24, 2011
Subject: Re: Trim
You shouldn't worry, Gary. Mr. Pietenpol was the supreme tinkerer; from what I understand, no two of his airplanes were ever exactly alike. On Mon, Jan 24, 2011 at 9:15 AM, wrote: > > Rick, > > A few days ago you posted some pics of your electric trim. I have that > exact actuator from my abandoned 601HDS project. I have been fighting suc h > luxuries (along with the 5th bearing), but I am now resigned to the fact > that I am building a "tinkered with" Piet. Hope Mr. Pietenpol is smiling > upon me. Furthermore, I already have a full blown electric system, comple te > with switches, knobs and fuses. > > Regrettably, I deleted your pics. Would you mind re-posting? > > Gary > Sent on the Sprint=AE Now Network from my BlackBerry=AE > > =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Re: Trim
Date: Jan 24, 2011
TWUgdGhpbmtzIHRoZXJlJ3MgYSBjb25zcGlyYWN5LCBoZXJlLiBObyB3b3JyaWVzLiBJIGFscmVh ZHkgcmFuIGl0IHVwIHRoZSBmbGFncG9sZSBhbmQganVzdCBnb3QgYSBibGFuayBzdGFyZS4uLnRo YXQncyBqdXN0IGxpa2UgcGVybWlzc2lvbiwgcmlnaHQ/DQoNCkdhcnkNCkRvIG5vdCBhcmNoaXZl DQpTZW50IG9uIHRoZSBTcHJpbnSuIE5vdyBOZXR3b3JrIGZyb20gbXkgQmxhY2tCZXJyea4NCg0K LS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206IFJ5YW4gTXVlbGxlciA8cm11ZWxsZXIy M0BnbWFpbC5jb20+DQpTZW5kZXI6IG93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25p Y3MuY29tDQpEYXRlOiBNb24sIDI0IEphbiAyMDExIDEzOjE1OjQzIA0KVG86IDxwaWV0ZW5wb2wt bGlzdEBtYXRyb25pY3MuY29tPg0KUmVwbHktVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5j b21TdWJqZWN0OiBSZTogUGlldGVucG9sLUxpc3Q6IFRyaW0NCg0KV2hpY2ggaXMgaGFyZGVyLi4u LnJlc2lzdGluZyBzcGVuZGluZyB0aGUgJDExMDAgb24gdGhlIGZpZnRoIGJlYXJpbmcuLi4ub3IN CnJlc2lzdGluZyB0aGUgZm9yY2VkIGxhbmRpbmcgaWYgdGhlIGNyYW5rIHNuYXBzPyAgIChtZXRo aW5rcyBKYWNrIHdpbGwgbGlrZQ0KdGhpcyA6UCkNCg0KUnlhbg0KDQpkbyBub3QgYXJjaGl2ZQ0K DQpPbiBNb24sIEphbiAyNCwgMjAxMSBhdCAxMjoxNSBQTSwgUmljayBIb2xsYW5kIDxhdDcwMDBm dEBnbWFpbC5jb20+IHdyb3RlOg0KDQo+IE5vIHByb2JsZW1vIEdhcnksIEkgYW0gYWxzbyB0cnlp bmcgdG8gcmVzaXN0IHNwZW5kaW5nIHRoZSBleHRyYSAkMTEwMCBmb3IgYQ0KPiBXZXNlbWFuIDV0 aCBiZWFyaW5nIGFsc28uDQo+DQo+IHJpY2sNCj4NCj4gT24gTW9uLCBKYW4gMjQsIDIwMTEgYXQg MTA6MTUgQU0sIDxnYm9vdGhlNUBjb21jYXN0Lm5ldD4gd3JvdGU6DQo+DQo+PiAtLT4gUGlldGVu cG9sLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IGdib290aGU1QGNvbWNhc3QubmV0DQo+Pg0KPj4g UmljaywNCj4+DQo+PiBBIGZldyBkYXlzIGFnbyB5b3UgcG9zdGVkIHNvbWUgcGljcyBvZiB5b3Vy IGVsZWN0cmljIHRyaW0uIEkgaGF2ZSB0aGF0DQo+PiBleGFjdCBhY3R1YXRvciBmcm9tIG15IGFi YW5kb25lZCA2MDFIRFMgcHJvamVjdC4gSSBoYXZlIGJlZW4gZmlnaHRpbmcgc3VjaA0KPj4gbHV4 dXJpZXMgKGFsb25nIHdpdGggdGhlIDV0aCBiZWFyaW5nKSwgYnV0IEkgYW0gbm93IHJlc2lnbmVk IHRvIHRoZSBmYWN0DQo+PiB0aGF0IEkgYW0gYnVpbGRpbmcgYSAidGlua2VyZWQgd2l0aCIgUGll dC4gSG9wZSBNci4gUGlldGVucG9sIGlzIHNtaWxpbmcNCj4+IHVwb24gbWUuIEZ1cnRoZXJtb3Jl LCBJIGFscmVhZHkgaGF2ZSBhIGZ1bGwgYmxvd24gZWxlY3RyaWMgc3lzdGVtLCBjb21wbGV0ZQ0K Pj4gd2l0aCBzd2l0Y2hlcywga25vYnMgYW5kIGZ1c2VzLg0KPj4NCj4+IFJlZ3JldHRhYmx5LCBJ IGRlbGV0ZWQgeW91ciBwaWNzLiBXb3VsZCB5b3UgbWluZCByZS1wb3N0aW5nPw0KPj4NCj4+IEdh cnkNCj4+IFNlbnQgb24gdGhlIFNwcmludK4gTm93IE5ldHdvcmsgZnJvbSBteSBCbGFja0JlcnJ5 rg0KPj4NCj4+DQo+PiA9PT09PT09PT09PQ0KPj4gc3QiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1MaXN0DQo+PiA9PT09PT09PT09 PQ0KPj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+PiA9PT09PT09PT09PQ0KPj4gbGUs IExpc3QgQWRtaW4uDQo+PiA9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRy aWJ1dGlvbg0KPj4gPT09PT09PT09PT0NCj4+DQo+Pg0KPj4NCj4+DQo+DQo+DQo+IC0tDQo+IFJp Y2sgSG9sbGFuZA0KPiBDYXN0bGUgUm9jaywgQ29sb3JhZG8NCj4NCj4gIkxvZ2ljIGlzIGEgd3Jl YXRoIG9mIHByZXR0eSBmbG93ZXJzLCB0aGF0IHNtZWxsIGJhZCINCj4NCg0K ________________________________________________________________________________
Subject: Trim
Date: Jan 24, 2011
Thanks, Rick! To heck with it.I'm going full IFR, while I'm at it.. Gary From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Monday, January 24, 2011 10:15 AM Subject: Re: Pietenpol-List: Trim No problemo Gary, I am also trying to resist spending the extra $1100 for a Weseman 5th bearing also. rick On Mon, Jan 24, 2011 at 10:15 AM, wrote: Rick, A few days ago you posted some pics of your electric trim. I have that exact actuator from my abandoned 601HDS project. I have been fighting such luxuries (along with the 5th bearing), but I am now resigned to the fact that I am building a "tinkered with" Piet. Hope Mr. Pietenpol is smiling upon me. Furthermore, I already have a full blown electric system, complete with switches, knobs and fuses. Regrettably, I deleted your pics. Would you mind re-posting? Gary Sent on the SprintR Now Network from my BlackBerryR ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 24, 2011
I don't hate Corvair engines. They have their place in aviation. You see, amphibs and floatplanes occasionally need to be secured off shore and the best way to do that is to sink a heavy and useless object with a rope tied to it, that can then be used to secure the airplane. Corvair engines are perfect for this task! Just kidding, of course. Now about this "friend" who told you that T-88 will break down at 110 degrees, BE WARY. Every airport has at least one "expert" who has never built an airplane but knows everything about building one, and is sure to point out that what you are doing is wrong. The best way to handle them is to keep your head down and keep working, and if they persist, you can say either "that turns out not to be the case" or "Bullsh*t", depending on a number of factors: a) Your mood at the time b) Whether you care to maintain this idiot as a friend c) Young ladies or children are present Wait till you start covering it with fabric. The smell of dope or PolyBrush seems to draw these folks like a pig pickin' draws flies. And they're all Experts, although they have never covered an airplane. Their "...uncle covered one with Irish Linen, back in '48, and he said you had to...". Don't listen to them. Don't pay attention to half of what you read on this forum. Read Tony Bingelis, and CAM18 (AC 43.13) and the manufacturer's info and directions, and make up your own mind. Talk to your local EAA Technical Counselor, but vette him first to make sure he actually knows something about wood and fabric airplanes. The EAA is not too particular about the experience required to become a TC, although they DO require that you must have built at least one airplane. A good TC will disqualify himself from questions where he knows nothing. For example, I'm the TC for our local EAA Chapter, and I was recently asked a question regarding carbon fiber layups on a Lancair. I disqualified myself because I simply have no experience or knowledge about composite materials and work. I will be gaining some of that when I get to the cabin top and doors on the RV-10 I'm building, but until I have worked with it myself, I won't offer an opinion. And before you ask, yes, I have had a Corvair. A 1966 model, with a 110 hp engine and a 4 on the floor. First car I ever wrecked. My Machine Design class in college used the Corvair as the example of how NOT to design a belt drive system. The design of that system was consistent with the design of the rest of the car. Remember, this car was designed to be Cheap. It was targeted squarely at the first real threat Detroit felt from foreign cars - a car that also had an air cooled engine mounted in the rear of the car, and sold for a very low price. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Monday, January 24, 2011 1:27 PM Subject: Pietenpol-List: Re: Ah, opinions... I still consider myself a newbie here but have learned to respect the opinions of the same people you have listed. Two of those individuals share private emails with me and answer the questions I have but don't want to post on the list. Jack Phillips would be another one I would put my trust in but he hates corvair engines. This weekend a friend of mine told me to avoid using T-88 epoxy as it will break down at 110 degrees F. So on the tarmac at Phoenix in the summer your plane could fall apart. I emailed threesystems about heat limits of T-88 and this is their reply. An upper limit would be around 160-180F. The T-88 itself will not fail. Failure comes from a combination of stresses from the wood shrinking combined with the fact that the Glass Transition Temperature for T-88 is around 150F. System Three Resins, Inc. Technical Support 253-333-8118 www.systemthree.com -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328237#328237 ________________________________________________________________________________
Date: Jan 24, 2011
A 1966 with a 110 motor eh? That may very well be, but did you have an RH case? [Laughing] -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328289#328289 ________________________________________________________________________________
Date: Jan 24, 2011
Subject: Re: Trim
I didn't think about that, that's another $50,000 for a Garmin G1000 with the "highway in the sky" in case you accidently fly into a cloud and can't tell which way is up (or down). I'll just strap the 2 screens on my left an d right rear cabanes. On Mon, Jan 24, 2011 at 2:10 PM, Gboothe5 wrote: > Thanks, Rick! To heck with it=85I=92m going full IFR, while I=92m at it =85. > > > Gary > > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Rick Holland > *Sent:* Monday, January 24, 2011 10:15 AM > > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: Trim > > > No problemo Gary, I am also trying to resist spending the extra $1100 for a > Weseman 5th bearing also. > > rick > > On Mon, Jan 24, 2011 at 10:15 AM, wrote: > > > Rick, > > A few days ago you posted some pics of your electric trim. I have that > exact actuator from my abandoned 601HDS project. I have been fighting suc h > luxuries (along with the 5th bearing), but I am now resigned to the fact > that I am building a "tinkered with" Piet. Hope Mr. Pietenpol is smiling > upon me. Furthermore, I already have a full blown electric system, comple te > with switches, knobs and fuses. > > > Regrettably, I deleted your pics. Would you mind re-posting? > > Gary > Sent on the Sprint=AE Now Network from my BlackBerry=AE > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > -- > Rick Holland > Castle Rock, Colorado > > "Logic is a wreath of pretty flowers, that smell bad" > > * > =========== > =========== ========= > = =========== > * > > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 24, 2011
That reminds me, I still need to order my "Unsafe At Any Speed" labels for the sides of my fuselage. rick > I don't hate Corvair engines. They have their place in aviation. > > You see, amphibs and floatplanes occasionally need to be secured off shore > and the best way to do that is to sink a heavy and useless object with a > rope tied to it, that can then be used to secure the airplane. Corvair > engines are perfect for this task! > -- Rick Holland Castle Rock, Colorado "Logic is a wreath of pretty flowers, that smell bad" ________________________________________________________________________________
Date: Jan 24, 2011
Jack, Good advice as usual. I'll be visiting your beautiful state for a few days at
January 16, 2011 - January 24, 2011
Pietenpol-Archive.digest.vol-ka
