Pietenpol-Archive.digest.vol-kn
June 17, 2011 - - - - , 20-
      then adding gussets to each side.  This would indicate that the sticks are
      custom miter fitted on each end, then glued. This is NOT required on any gussetted
      aircraft rib. (emphasis mine)  The size of the gusset is engineered to
      have adequate shear glue strength to transfer the loads and more.  I recommend
      that the sticks be cut as long as you can to fit the location with 90 deg cuts
      on the ends such that one corner of the end of the stick contacts the adjacent
      one. Factory Pitts, Stearman and Staggerwing ribs have no inter-stick contact
      in places relying on the gussets only.  Just like the roof over your head.
      This can save bunch of build time.  Ribs built in this manner are still stronger
      than the required loads." (emphasis mine)
      I have three questions-
      1. Really? Are 90 cuts on the ends of the braces sufficient over mitered ends?
      If that were true, it sure would save me time, but I also know that the Internet
      is full of really bad ideas parading as "expert advice". FWIW, I have built
      and glued my first rib with the vertical braces mitered to probably within 1/16th.
      Am I in overkill, or doing what is the right way to construct?
      2. I am thinking about building my wing ribs using Semi-Circle and Quarter-Circle
      gussets (I just like the look, although, once built and covered, I won't see
      them again). Since they are not the original plans type of gusset, what size
      circle did some of you use for your gussets?
      3. I heard the instructor in an EAA workshop I attended ask the question, "Are
      you building a Timex, or a Rolex?" The point I felt he was making is that you
      can build and spend thousands of extra hours fitting tolerences that don't really
      make your aircraft any stronger, or you can build it using good practices
      and it will be just fine. That is not the same as "The Fisherman" school of aircraft
      construction, but yet it is a far cry from building a fine Swiss watch
      either. I guess that I am asking for words of advice in this regard as I begin
      building. Comments are appreciated.
      Thanks to everyone in advance for their advice. I count today in my Builder's Log
      as the day I began building my Pietenpol. Everything up until now has been
      "research", and I don't think the FAA or anyone else gives two hoots about how
      many hours of research I did. They are more interested in what I built, how I
      built it, and (at least to me) how many hours I spent building.
      Semper Fi,
      Terry
      http://forums.matronics.com/viewtopic.php?p=343267#343267
Subject: Avon tires and Johnson Airspeed indicator
Date: Jun 17, 2011
I have Avon Speedmasters on mine and have been very pleased with them. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Friday, June 17, 2011 8:13 AM Subject: Pietenpol-List: Avon tires and Johnson Airspeed indicator I bought a very nicely made "kit" form Kerri Ann Price a while back. Here's the last email I have keriannprice(at)hotmail.com Those Avon tires will work fine. Also ck out Avon "Speedmaster"s, very vintage as well. I've seen these tires on Piets, so know they work. Douwe ________________________________________________________________________________
Subject: Re: Building my first wing rib - the journey begins
Date: Jun 17, 2011
90 degree cuts are fine. I compromised and angled mine to give me a little more suface area to glue. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343270#343270 ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Subject: Re: Another Cable Question
Date: Jun 17, 2011
Jack, I ordered both ferrules swaging tool from ACS. The ferrules are 3/8-in long and the swager is 1/2-inch wide so the swage is done in just one crimp. I think the 1 vs 2 vs 3 crimps have reference to the crimping tool that has a much more narrow 'bite'. I think you are using much longer ferrules (copper colored vs plated) and a more narrow crimping tool. ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Friday, June 17, 2011 6:33 AM Subject: RE: Pietenpol-List: Another Cable Question Jim, I don't remember that reference in the book. I used three for my tail cables. I have seen some with one but wonder if the tool has a wider surface. See pictures. Jack DSM http://textors.com/DSCN4200_800x600.jpg http://textors.com/DSCN4199_800x600.jpg http://textors.com/DSCN4201_800x600.jpg http://textors.com/DSCN4202_800x600.jpg ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Boyer Sent: Thursday, June 16, 2011 11:01 AM To: pietenpol-list Subject: Pietenpol-List: Another Cable Question Another cable question; in Bingelis books and in AC43 it says that 3/32 copper oval cable sleeves only need to be crimped once. I am using 3/32 cable for the tail brace cables and I know I have seen other Piets with 3/32 tail brace cables but don't remember ever seeing just one crimp on the copper sleeve. Is that what those of you using 3/32 cable are doing just one crimp? Tried doing three last night as a test and it can be done but doesn't look well and just one crimp makes the ends swell up like you stepped in the middle of a balloon. Cheers, Jim B. http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 17, 2011
#2. I meant to attach a pic to the first post so if I can get it to come up here it is. ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Friday, June 17, 2011 6:33 AM Subject: RE: Pietenpol-List: Another Cable Question Jim, I don't remember that reference in the book. I used three for my tail cables. I have seen some with one but wonder if the tool has a wider surface. See pictures. Jack DSM http://textors.com/DSCN4200_800x600.jpg http://textors.com/DSCN4199_800x600.jpg http://textors.com/DSCN4201_800x600.jpg http://textors.com/DSCN4202_800x600.jpg ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Boyer Sent: Thursday, June 16, 2011 11:01 AM To: pietenpol-list Subject: Pietenpol-List: Another Cable Question Another cable question; in Bingelis books and in AC43 it says that 3/32 copper oval cable sleeves only need to be crimped once. I am using 3/32 cable for the tail brace cables and I know I have seen other Piets with 3/32 tail brace cables but don't remember ever seeing just one crimp on the copper sleeve. Is that what those of you using 3/32 cable are doing just one crimp? Tried doing three last night as a test and it can be done but doesn't look well and just one crimp makes the ends swell up like you stepped in the middle of a balloon. Cheers, Jim B. http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 17, 2011
Congratulations on your first wing rib, Terry. Like John, I miter the intercoastals but I've also read that the 90s are fine. As always, the engineers, A&Ps and IAs can correct as they see fit - that's my standard disclaimer since I routinely say dumb things. I like the "timex vs. rolex" analogy. Unfortunately, it's hard to know what right looks like when you're starting. That's why you develop your list of trusted people on this site and seek their advice. You also have your local technical counselors. Lemme see: "timex vs. rolex," "pole-vaulting over mouse turds," and, "it ain't the space shuttle." Not excuses to do sloppy work, but encouragement to do airworthy work and make progress. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343275#343275 ________________________________________________________________________________
Date: Jun 17, 2011
Take a look at the Help for Home Builders section of EAA.org. There are a number of videos there building a wood wing. All of them cut angles. I believe you will find most of the folks here also cut angles. Another advantage to cutting the angles, is you can remove the rib from the jig without first attaching one side of the gussets. This allowed me to always have a rib in the jig and two others at the "gusset station". Cleaner and neater. This also allows you smooth the joints out of the jig, which is much easier. You can check out my blog at: http://pietenpol-989cb.blogspot.com On the gussets themselves, I went with the rectangle. I ended up with 4 different sizes, but the mass majority of them are 1.5" x 1.0". The other sizes were 1.25" x 1.0" - only two of these per side. The other two sizes were specific for the nose and the tail. Trimmed on the router table. Video on the blog. Good luck and enjoy the time. If time is real important to save, your going to be in trouble. Chuck 989CB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343276#343276 ________________________________________________________________________________
Date: Jun 17, 2011
Didn't really answer a couple of your questions - standard disclaimer still applies: Do as good as you can on the woodwork. I try for 1/32" tolerances. For gusseted joints I'll go to 1/16". This obviously does not apply if you cut 90 degree angles on your rib intercoastals. Ask Gene Rambo about the size of the round gussets on the ribs. TLAR tells me that 1.25" radius would be ok. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343278#343278 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Jun 17, 2011
Thanks for everyone's input. Chuck, thanks for the advice about time. Flying is my job, so staying proficient is not a factor. I look at this as a journey, as I said. If the destination is the only goal, you will miss the joy of the journey. I am in no rush. I also saw the three step wing rib process on the westcoastpiet. com website. I like the ability to remove the rib from the jig and apply the gussets without staples or nails. So for that reason alone I think that I will stay with the mitered braces. I think that I will also stick with the rectangle gussets- easier to cut, and much less waste. I will send pictures as I get a little further on the trip! Thanks again to all. -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343282#343282 ________________________________________________________________________________
Date: Jun 17, 2011
Terry, I questioned the rib joints myself but found comfort in a bridge I passed over a few days later. I knew I was going that way again this morning so took some pictures for you. Check out their gussets. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343285#343285 Attachments: http://forums.matronics.com//files/bridge2_854.jpg http://forums.matronics.com//files/bridge1_170.jpg ________________________________________________________________________________
Subject: Re: [eaa1114-discuss] Letter from Capt. Ray Fowler,Chief
Pilot f
Date: Jun 17, 2011
Extremely well said...thanks for forwarding! A very sad loss of a piece of history, but thankfully not infinitely compounded by loss of life or injury. -------- --Randall 02xB || !02xB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343286#343286 ________________________________________________________________________________
Date: Jun 17, 2011
Great picture, John. Definitely worth a thousand words. Or a couple of beverages at Brodhead - my treat. -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343291#343291 ________________________________________________________________________________
Date: Jun 17, 2011
I used a 2" hole saw for my gussets. Then used an old school paper cutter t o cut those gussets in 1/2 and 1/4 pieces.- I believe I have pictures on my website. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 17, 2011
Since it hasn't been mentioned yet, I'll do it now: Refer to the Bingelis books. They will provide answers to all of your questions. Attached is a Tony Bingelis sketch showing various joint conditions, all deemed to be acceptable. If you don't own the set of Bingelis books, get one. If you have a set, read them. Such a wealth of homebuilt aircraft information. So, in response to your questions: 1. Yes, 90degree cuts on the ends of the braces are sufficient. They will be slightly less strong than mitered (less bonding area), but not significantly. Personally, I prefer mitered joints, but I enjoy woodworking, and take pride in nice fitting joints, whether anyone else knows about them or not - but that's just me. I'm not sure what you mean by your statement that your braces have been "mitered to probably within 1/16th". Do you mean you have 1/16" gaps between the sticks? Basically the sticks should butt against the top and bottom capstrips.I would avoid gaps. A disc sander is an invaluable tool in building ribs (and many other parts) . I use mine ALL the time. Probably less than $100. Get the biggest size you can find. Mine is 8 inch diameter. 2. I used circular gussets - just liked the look better (but that's me). I made mine 2" diameter, and cut them into halves and quarters with a thin blade (scroll saw). 3. Build the way you want to build, and are capable of. Some homebuilt aircraft have woodwork that looks like fine furniture, and some have woodwork that... doesn't. Strength will rely on proper techniques, and making sure that glue joints have proper contact (no gaps between wood pieces that are not filled with the proper amount of glue). How your aircraft performs will depend largely on the symmetry and squareness (wherever things are supposed to be square) of your construction, not how pretty it looks. Always remember "Keep it light". Personally, I think I'm aiming for a Seiko. A little nicer than a Timex, but much more reasonably priced than a Rolex. Lastly, I don't think that the FAA gives a hoot about how many hours you spent building your plane (unless someone else did more hours on your plane than you did). What they will care about is whether or not YOU built it. One rib down, and a bunch more to go. Before you know it you'll have a whole wing's worth of ribs (unless you get distracted, like another builder, whose name rhymes with Gary Boothe). Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343302#343302 Attachments: http://forums.matronics.com//files/bingelis_rib_joints_648.jpg ________________________________________________________________________________
Date: Jun 17, 2011
Hi Jack, thats what bothered me; it looked like some had one crimp but it was much wider. It could have been just that the 3 crimps blended together. Both AC43-13 and Bingelis books say just one for 3/32" and 3 for 1/8" sleeves. Thanks for the pictures, Jim B. ________________________________________________________________________________
Date: Jun 17, 2011
Not sure that it matters much, but I mitered (sanded) each diagonal and upright to fit precisely and I honestly don't think it took me any longer to go this route. I didn't custom fit each part to each assembly, rather I made a set of "master" parts as I laid out the first rib and used each of these master parts to make the remaining parts by marking the cut angles on long pieces of capstrip. Most of us do this anyway (mark lengths) in order to cut our parts to the correct length, even if we are cutting 90s. So, after I marked my parts I went to the band saw and rip, rip, rip, rip, rip. Now I've got a stack of parts with angles marked on each end, so I take them to my disk sander and sand, sand, sand, sand, sand them to match the markings. It actually went really quick, and each part was fabricated to the identical dimension as the original master part. Once I had all these built, which only took me a few work sessions, I had an entire assembly line set up. Making these parts in batches is a LOT quicker than making them as you go (marking each piece, walking to the saw each time, etc.). I still have all these master parts. They fit perfectly in my jig in the event that I need to make a repair, or build another Piet later on. I know that all this isn't necessary, but I just wanted to share the way I did mine. I would argue that their is some degree of added strength in the increased contact area. I used the same process with my fuse halves... all the diagonals and uprights were sanded to match. The fit is snug and leaves no voids. I think this serves to not only provide more surface area, but also better alignment... especially when doing a number of the same assemblies, such as ribs. My $.02 Some of the diagonals cut and sorted. Gussets ready to go. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343308#343308 ________________________________________________________________________________
Date: Jun 17, 2011
Wow! Bill nailed it. We must have been writing at the same time. I'll agree... the disc sander is an excellent tool. I got mine (6" with 4" belt) for $100. You can probably do much better than I did by scouring Craigslist. One more thing I want to agree with... I too enjoy woodworking and take pride in nicely fitting joints. Not to brag, but I had a 20+ year wood shop instructor and airplane builder come into my hangar the other night (he has 6 airplanes). I noticed him looking over my project while I talked to another guy. Later on I asked him what he thought and he said, "you are doing excellent work". Yep, I'm glad I've taken a little extra time (emphasis on little) to do my best work. Is it THE best work? Probably not, but I'm trying. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343311#343311 ________________________________________________________________________________
Date: Jun 17, 2011
What I meant about time is that, you are right that the FAA doesn't care how many hours I put into the airplane, as long as it is done right. I only meant a tally of hours would be meaningful to me. I appreciate all of the photos as it helps me as I go to get ideas. I think that the Seiko comparison may be the best goal - not to low end, not too high end, but built well and built to last. I do have the Bingelis books, but, frankly, I do not remember that diagram of the braces and gussets. Maybe it is a different edition. If you can tell me the book and page, I will go back and search for it. Back to work. -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343315#343315 ________________________________________________________________________________
Date: Jun 17, 2011
Terry, I mitred my rib spacers and cut square/rectangular gussets. Do what Mark did and cut multiple spacers and gussets. It's really nice to be able to make a rib a day without having to stop and cut individual pieces. Building the ribs was great--starting on the project and seeing progress each day. Every part of it was exciting. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343320#343320 Attachments: http://forums.matronics.com//files/rib_945.jpg http://forums.matronics.com//files/rib_gusset_166.jpg ________________________________________________________________________________
Date: Jun 17, 2011
I mitered my rib pieces. If you make them like an assembly line it doesn't take all that long if you have a power sander. I ended up with all the individual rib pieces numbered and rubber banded together on my workbench, so putting together a rib didn't take all that long, maybe an hour to glue and nail one side. In the long run it doesn't cost much more to build a Rolex. Its your time, so its up to you. I don't regret it myself. Ben Charvet Titusville, Fl On 6/17/2011 8:17 AM, jarheadpilot82 wrote: > --> Pietenpol-List message posted by: "jarheadpilot82" > > I am starting my first wing rib, and came across the following website- > > http://www.2wings.com/m12/faq/wingfaq.htm#04/19/01%20RIB%20CONSTRUCTION,%20GUSSETS,%20GLUE,%20EPOXY,%20STAPLER,%20CLAMP,%20JOINT,%20CLAMPING%20SPAR%20CRUSH%20PLATE > > This website is, apparently, is a Builder's area for Pitts Model 12 aircraft. In reading through I found interesting tidbits of information, but the following thread really caught my attention. I have cut and pasted it here to make it easier to read- > > "I re-read Cory's post, It does sound as though Cory is gluing the sticks together, then adding gussets to each side. This would indicate that the sticks are custom miter fitted on each end, then glued. This is NOT required on any gussetted aircraft rib. (emphasis mine) The size of the gusset is engineered to have adequate shear glue strength to transfer the loads and more. I recommend that the sticks be cut as long as you can to fit the location with 90 deg cuts on the ends such that one corner of the end of the stick contacts the adjacent one. Factory Pitts, Stearman and Staggerwing ribs have no inter-stick contact in places relying on the gussets only. Just like the roof over your head. This can save bunch of build time. Ribs built in this manner are still stronger than the required loads." (emphasis mine) > > I have three questions- > > 1. Really? Are 90 cuts on the ends of the braces sufficient over mitered ends? If that were true, it sure would save me time, but I also know that the Internet is full of really bad ideas parading as "expert advice". FWIW, I have built and glued my first rib with the vertical braces mitered to probably within 1/16th. Am I in overkill, or doing what is the right way to construct? > > 2. I am thinking about building my wing ribs using Semi-Circle and Quarter-Circle gussets (I just like the look, although, once built and covered, I won't see them again). Since they are not the original plans type of gusset, what size circle did some of you use for your gussets? > > 3. I heard the instructor in an EAA workshop I attended ask the question, "Are you building a Timex, or a Rolex?" The point I felt he was making is that you can build and spend thousands of extra hours fitting tolerences that don't really make your aircraft any stronger, or you can build it using good practices and it will be just fine. That is not the same as "The Fisherman" school of aircraft construction, but yet it is a far cry from building a fine Swiss watch either. I guess that I am asking for words of advice in this regard as I begin building. Comments are appreciated. > > Thanks to everyone in advance for their advice. I count today in my Builder's Log as the day I began building my Pietenpol. Everything up until now has been "research", and I don't think the FAA or anyone else gives two hoots about how many hours of research I did. They are more interested in what I built, how I built it, and (at least to me) how many hours I spent building. > > -------- > Semper Fi, > > Terry > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=343267#343267 > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Jun 17, 2011
Gary, I don't want to buy a bridge, I just like the visual... ;o) -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343325#343325 ________________________________________________________________________________
From: "Richard Schreiber" <lmforge(at)earthlink.net>
Date: Jun 17, 2011
Ben: Thats how I did my rib pieces and like you it took about 1 hour per rib to assemble. After assembling one rib, I took the staples out of the one I did the day before. I think on my best day one Saturday, I actually did 3 ribs. Rick Schreiber, Valparaiso In > [Original Message] > From: Ben Charvet <bencharvet(at)gmail.com> > To: > Date: 6/17/2011 1:32:44 PM > Subject: Re: Pietenpol-List: Building my first wing rib - the journey begins > > I mitered my rib pieces. If you make them like an assembly line it > doesn't take all that long if you have a power sander. I ended up with > all the individual rib pieces numbered and rubber banded together on my > workbench, so putting together a rib didn't take all that long, maybe an > hour to glue and nail one side. In the long run it doesn't cost much > more to build a Rolex. Its your time, so its up to you. I don't regret > it myself. > > Ben Charvet > Titusville, Fl > On 6/17/2011 8:17 AM, jarheadpilot82 wrote: > > --> Pietenpol-List message posted by: "jarheadpilot82" > > > > I am starting my first wing rib, and came across the following website- > > > > http://www.2wings.com/m12/faq/wingfaq.htm#04/19/01%20RIB%20CONSTRUCTION,%20G USSETS,%20GLUE,%20EPOXY,%20STAPLER,%20CLAMP,%20JOINT,%20CLAMPING%20SPAR%20CR USH%20PLATE > > > > This website is, apparently, is a Builder's area for Pitts Model 12 aircraft. In reading through I found interesting tidbits of information, but the following thread really caught my attention. I have cut and pasted it here to make it easier to read- > > > > "I re-read Cory's post, It does sound as though Cory is gluing the sticks together, then adding gussets to each side. This would indicate that the sticks are custom miter fitted on each end, then glued. This is NOT required on any gussetted aircraft rib. (emphasis mine) The size of the gusset is engineered to have adequate shear glue strength to transfer the loads and more. I recommend that the sticks be cut as long as you can to fit the location with 90 deg cuts on the ends such that one corner of the end of the stick contacts the adjacent one. Factory Pitts, Stearman and Staggerwing ribs have no inter-stick contact in places relying on the gussets only. Just like the roof over your head. This can save bunch of build time. Ribs built in this manner are still stronger than the required loads." (emphasis mine) > > > > I have three questions- > > > > 1. Really? Are 90 cuts on the ends of the braces sufficient over mitered ends? If that were true, it sure would save me time, but I also know that the Internet is full of really bad ideas parading as "expert advice". FWIW, I have built and glued my first rib with the vertical braces mitered to probably within 1/16th. Am I in overkill, or doing what is the right way to construct? > > > > 2. I am thinking about building my wing ribs using Semi-Circle and Quarter-Circle gussets (I just like the look, although, once built and covered, I won't see them again). Since they are not the original plans type of gusset, what size circle did some of you use for your gussets? > > > > 3. I heard the instructor in an EAA workshop I attended ask the question, "Are you building a Timex, or a Rolex?" The point I felt he was making is that you can build and spend thousands of extra hours fitting tolerences that don't really make your aircraft any stronger, or you can build it using good practices and it will be just fine. That is not the same as "The Fisherman" school of aircraft construction, but yet it is a far cry from building a fine Swiss watch either. I guess that I am asking for words of advice in this regard as I begin building. Comments are appreciated. > > > > Thanks to everyone in advance for their advice. I count today in my Builder's Log as the day I began building my Pietenpol. Everything up until now has been "research", and I don't think the FAA or anyone else gives two hoots about how many hours of research I did. They are more interested in what I built, how I built it, and (at least to me) how many hours I spent building. > > > > -------- > > Semper Fi, > > > > Terry > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=343267#343267 > > > > > > > > > > > > > > > > > > > > > > > > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > ________________________________________________________________________________
Subject: A engine
Date: Jun 17, 2011
Got a head for my engine this week... aluminum Thomas head 7:1... and made a decision on the ignition. got a mallory distributor and will run dual points like the corvair guys.. i've been driving my '30 AA a lot lately and even the original ignition it that old truck just works. no fabbing a mount and drive for the magneto... short wire runs.. and easy maintenance... i'm digging it. http://s1125.photobucket.com/albums/l593/jfaithbass/ got some photos up jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343339#343339 ________________________________________________________________________________
Subject: A engine
Date: Jun 17, 2011
Very nice looking work, Jeff! Are you coming to Brodhead this year? Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bender Sent: Friday, June 17, 2011 5:53 PM Subject: Pietenpol-List: A engine Got a head for my engine this week... aluminum Thomas head 7:1... and made a decision on the ignition. got a mallory distributor and will run dual points like the corvair guys.. i've been driving my '30 AA a lot lately and even the original ignition it that old truck just works. no fabbing a mount and drive for the magneto... short wire runs.. and easy maintenance... i'm digging it. http://s1125.photobucket.com/albums/l593/jfaithbass/ got some photos up jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343339#343339 ________________________________________________________________________________
Subject: Re: A engine
Date: Jun 17, 2011
thanks what is the date ?? i thought about riding a bike up... sold my 120 wish the piet was done ... but soon enough jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343350#343350 ________________________________________________________________________________
Date: Jun 17, 2011
Dates for Brodhead are Thursday 7/21 thru Saturday 7/23. On Sunday everybody either goes home or goes to Oshkosh. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bender Sent: Friday, June 17, 2011 7:17 PM Subject: Pietenpol-List: Re: A engine thanks what is the date ?? i thought about riding a bike up... sold my 120 wish the piet was done ... but soon enough jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343350#343350 ________________________________________________________________________________
Subject: Dillsburg Closing
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Jun 18, 2011
Saw this on the EAA site... http://www.eaa.org/news/2011/2011-06-16_dillsburg.asp Wayne Bressler Taildraggers, Inc. www.taildraggersinc.com ________________________________________________________________________________
Subject: Another Cable Question
Date: Jun 18, 2011
Thanks Chuck I wasn't sure that type tool worked well. Looks like it does. Jack _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Friday, June 17, 2011 8:24 AM Subject: Re: Pietenpol-List: Another Cable Question #2. I meant to attach a pic to the first post so if I can get it to come up here it is. ----- Original Message ----- From: Jack <mailto:jack(at)textors.com> Sent: Friday, June 17, 2011 6:33 AM Subject: RE: Pietenpol-List: Another Cable Question Jim, I don't remember that reference in the book. I used three for my tail cables. I have seen some with one but wonder if the tool has a wider surface. See pictures. Jack DSM http://textors.com/DSCN4200_800x600.jpg http://textors.com/DSCN4199_800x600.jpg http://textors.com/DSCN4201_800x600.jpg http://textors.com/DSCN4202_800x600.jpg _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Boyer Sent: Thursday, June 16, 2011 11:01 AM Subject: Pietenpol-List: Another Cable Question Another cable question; in Bingelis books and in AC43 it says that 3/32 copper oval cable sleeves only need to be crimped once. I am using 3/32 cable for the tail brace cables and I know I have seen other Piets with 3/32 tail brace cables but don't remember ever seeing just one crimp on the copper sleeve. Is that what those of you using 3/32 cable are doing just one crimp? Tried doing three last night as a test and it can be done but doesn't look well and just one crimp makes the ends swell up like you stepped in the middle of a balloon. Cheers, Jim B. http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Flight report- back in the air
Date: Jun 18, 2011
Hello Good People, NX929DH finally graced the skies again yesterday for 1 1/2 hrs yesterday at Poplar Grove. All went well and she is ready to go to Brodhead. Longer rep ort later next week when I can get back to TN and to my Internet connection (sitting here in McDonalds in Belvidere, IL.[famous hometown of Ryan Meull er]) Looking forward to seeing everybody. Pray for good weather. Dan Helsper (from) Poplar Grove, IL. ________________________________________________________________________________
Subject: Re: Flight report- back in the air
Date: Jun 18, 2011
That is good news Dan. You taking her to Tennessee or staying in Il. Are you running 1 mag or 2? -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343377#343377 ________________________________________________________________________________
Subject: negative G loading for Piet wing
Date: Jun 18, 2011
That story about a Piet that lost its wing trying to do a loop was used by BHP to explain why Jury Struts should be installed on a Pietenpol. Negative G loading will cause the lift struts to buckle if they are not braced near the midpoint with Jury Struts. I've never done anything more violent that a wingover in mine. A Pietenpol just would not be a good aerobatic platform - too slow a roll rate and way too much drag. If you want to build an aerobatic airplane, build a Pitts. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Wednesday, June 15, 2011 11:45 PM Subject: Pietenpol-List: negative G loading for Piet wing Mark asked- >Do you know what the negative-G stress loading is on a piet I'm not aeronautical engineer and I didn't sleep in a Holiday Inn last night, but my napkin sketches and calcs indicate that negative G loading is a weak point of the Piet structure. I may also be very mistaken when I write this, but I believe one of the few known structural failures of a Piet was when one fell out of a loop or attempted a negative-G maneuver and the struts collapsed. Normal category loading for certified aircraft is +3.8 and -1.52G and the Piet is certainly no better rated than that, IMHO. Oscar Zuniga Air Camper NX41CC Medford, OR ________________________________________________________________________________
Date: Jun 18, 2011
It works fine! Just takes a little longer than the one with the long handles -- like hedge clippers. When I was rebuilding a Piper TriPacer a few years ago I used that type. When you're working alone I believe the type with the two bolts is easier to use. ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Saturday, June 18, 2011 7:14 AM Subject: RE: Pietenpol-List: Another Cable Question Thanks Chuck I wasn't sure that type tool worked well. Looks like it does. Jack ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Friday, June 17, 2011 8:24 AM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Another Cable Question #2. I meant to attach a pic to the first post so if I can get it to come up here it is. ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Friday, June 17, 2011 6:33 AM Subject: RE: Pietenpol-List: Another Cable Question Jim, I don't remember that reference in the book. I used three for my tail cables. I have seen some with one but wonder if the tool has a wider surface. See pictures. Jack DSM http://textors.com/DSCN4200_800x600.jpg http://textors.com/DSCN4199_800x600.jpg http://textors.com/DSCN4201_800x600.jpg http://textors.com/DSCN4202_800x600.jpg ------------------------------------------------------------------------- --- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Boyer Sent: Thursday, June 16, 2011 11:01 AM To: pietenpol-list Subject: Pietenpol-List: Another Cable Question Another cable question; in Bingelis books and in AC43 it says that 3/32 copper oval cable sleeves only need to be crimped once. I am using 3/32 cable for the tail brace cables and I know I have seen other Piets with 3/32 tail brace cables but don't remember ever seeing just one crimp on the copper sleeve. Is that what those of you using 3/32 cable are doing just one crimp? Tried doing three last night as a test and it can be done but doesn't look well and just one crimp makes the ends swell up like you stepped in the middle of a balloon. Cheers, Jim B. http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-Listhref="http://forums.matronics.com">h ttp://forums.matronics.comhref="http://www.matronics.com/contribution"> http://www.matronics.com/c ________________________________________________________________________________
Subject: Re: Dillsburg Closing
Date: Jun 18, 2011
Someone at EAA better get their act together. Was Charlie a "WW 2 B-17 pilot" or was he the "Base Sergeant Major"? Don't believe he could have been a B-17 pilot as a Sergeant Major. ----- Original Message ----- From: "Wayne Bressler" <wayne(at)taildraggersinc.com> Sent: Saturday, June 18, 2011 6:14 AM Subject: Pietenpol-List: Dillsburg Closing > > > Saw this on the EAA site... > > http://www.eaa.org/news/2011/2011-06-16_dillsburg.asp > > Wayne Bressler > Taildraggers, Inc. > www.taildraggersinc.com > > > ________________________________________________________________________________
Subject: Piet fix
Date: Jun 18, 2011
I'm going to be in Bloomington, IN for a couple days and will be looking for a Piet fix on Monday night, June 27..anybody out there? Gary Cool, Ca. ________________________________________________________________________________
Date: Jun 18, 2011
Didn't know he did all the Indy & NASCAR stuff, too. > In addition to providing aircraft grade tubing, Dillsburg supplies all of Indy Car and NASCAR worldwide. This business will be picked up by somebody... - Pat -------- Patrick Hoyt 601XLb/Corvair N63PZ - 99.999% done.... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343384#343384 ________________________________________________________________________________
Date: Jun 18, 2011
Actually=2C warrant officers did tly fixed wing during WWII. In the movie " The Battle of Brittain" you will see some pilots with sergeant stripes. That part was historically accurate. Dunno about the rest of the movie. Doug Dever In beautiful Stow Ohio > From: cncampbell(at)windstream.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Dillsburg Closing > Date: Sat=2C 18 Jun 2011 08:34:09 -0400 > stream.net> > > Someone at EAA better get their act together. Was Charlie a "WW 2 B-17 > pilot" or was he the "Base Sergeant Major"? Don't believe he could have > been a B-17 pilot as a Sergeant Major. > > ----- Original Message ----- > From: "Wayne Bressler" <wayne(at)taildraggersinc.com> > To: > Sent: Saturday=2C June 18=2C 2011 6:14 AM > Subject: Pietenpol-List: Dillsburg Closing > > > > > > > > Saw this on the EAA site... > > > > http://www.eaa.org/news/2011/2011-06-16_dillsburg.asp > > > > Wayne Bressler > > Taildraggers=2C Inc. > > www.taildraggersinc.com > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 18, 2011
I don't know if EAA got it right, since they also had 4130 Aluminum tubing in the article, but for those interested in Flying Sergeants, refer to the following website- http://www.af.mil/news/story.asp?id=31103853 Interesting read for us History Geeks (I am one of those that love history and all of its minutiae) -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343395#343395 ________________________________________________________________________________
Subject: Twin Rivers Fly-In
Date: Jun 18, 2011
Just got back from the Twin Rivers Fly-in, in the Shenandoah Valley of Virginia. Matt Paxton keeps his brand new Pietenpol there and was flying it, although he can't give rides yet since he's still flying off the Phase I hours. I flew my Pietenpol in, with my wife, Karen, in the front seat. Gene Rambo had his 1928 Travel Air 2000 there, and his friend Pete Hays had his Skybolt. Both of them brought their sons - good to see young kids fooling around with airplanes. In addition there were various other airplanes there, including a Piper Comanche and a Light Sport called a Chinook, that looks something like a Titan Tornado. Since it was getting hot, and my Pietenpol doesn't climb all that well when heavily loaded, I asked Gene Rambo if he would mind bringing Karen back to Smith Mountain Lake in his Travel Air (partly because I wanted her to get her first ride in a biplane). It had taken us 20 minutes to climb from 900' to 3500' to get over the Blue Ridge mountains on the way there, and that was in the morning, when it was cool. Here is a picture of Matt's new Pietenpol. Those of you coming to Brodhead next month will get to see it there, if he can fly another 27 hours in the next month. Here are some other aircraft at the fly-in: And here is Gene's Travel Air in flight: Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia ________________________________________________________________________________
Date: Jun 18, 2011
Subject: Building a Piet on the farm.....
Well that was fun! Larry Williams and Mark Chouinard came over yesterday and helped ME work on my Piet! I've always been a little hesitant to have someone work on it in the past. That was stupid. From now on, anyone that stops by gets a tool (NOT to take back to it's original owner!) and a project.... It was really great having friends in my workshop...especially fun how they pitched in and helped move my project forward a few giant steps. Thanks guys. Jim in Pryor.... ________________________________________________________________________________
Date: Jun 18, 2011
Very good news Dan! I too am curious to hear what you worked out. Whatever the solution, if it works, FLY IT! Brett Phillips NX311GP ________________________________________________________________________________
Subject: NX929DH update....Model A guys take note
Date: Jun 19, 2011
Well, I have put 4 hrs on her the last couple of days. This is really the first t ime I have had uninterrupted testing time so I could digest what is really happening to this engine. After numerous runnings I have discovered that th e carb was running really rich, so much so that it was puffing black smoke periodically and building up thick layers of carbon on the stacks and also on the plugs. (This was happening some last summer also). I lowered the fue l level in the float chamber, and this helped some to lean it out a little, but the problem still persisted and I could not go on with any confidence. BTW I have concluded that my engine problems from last Sept., were a direc t result of this phenominon, not related to ignition. As it turns out the g ood Lord was actually looking out for me that day, and allowed me to return the the airport to discover my other problem of the second mag drive falli ng apart. My new theory is this: When I had two functioning plugs per cylin der, there was just enough combustion to keep me from building carbon too f ast. On that last flight in Sept. when the 2nd mag did fail, the carbon beg an to build to the point of the very rough running, forcing me back to the airport to discover the timing gear disintegration. So here is the good news. Steve Thomas (owner and benevolent king of Poplar Grove Airport) suggested that I might try burning 100LL instead of the no- lead car gas he has there. I had nothing to loose so I gave it a try. Went to the pumps and filled the remaining 8 gallons of space in my tank with 10 0LL. So at that point I had about 80% 100LL in the tank. It made an immedia te difference. No more puffs of black smoke. No more sputtering. No more mi ssing. Plenty of power even with only the single ignition. I flew the heck out of it right over the airport, trying to burn some gas. Went back to the pumps again and refilled with 100LL. Flew for another hour. Had to stop be cause I discovered a small fuel tank leak (ARRRRG). Anyway, taxied back to the hangar and pulled the plugs to find nice, gray electrodes with NO carbo n anywhere. I am not smart enough to know why this switch of fuel solved t he problem. I am sure there are some on this list that can tell me. Also, Steve T. mounted one of those GO PRO cameras on my strut and cowl. He got some good video from that and he also took his Cub up with his son Bla ke and took some more great air-to-air video. I don't see it posted anywher e yet but I will watch for it and let y'all know. So now I am feeling ALOT better about my airplane and engine, with confiden ce levels rising. I only have to get my tank welded up and back in to be re ady for Brodhead. Since I have been without cable TV and Internet (we have it turned off in P G), I have been watching the first 15 minutes of TGWP every night on the DV D player. That has got to be the BEST movie ever. No real airplane nut coul d ever tire of watching that little boy Scooter, at the first sound of the airplane engine in the distance, put down his fishing rod, excitedly race w ith his dog over to the sound of the Jenny, and upon seeing it approach ove r the trees, fall on his back upside down to see the belly of the airplane wizzing a few feet above his face. Maybe I'm a sap, but it gives me chills every time. Dan Helsper Sitting in McDonalds. In PG till Tuesday ________________________________________________________________________________
Date: Jun 19, 2011
You are a sap.and don't call me Shirley. Good to hear you're solving your engine problems, Dan. I myself am now the proud owner of a CloudCars scimitar prop and saw an immediate improvement in climb and a slight improvement in cruise performance. With this prop the plane feels like a rocket climbing out on takeoff. I can hardly wait to fly it to Brodhead. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Sunday, June 19, 2011 8:36 AM Subject: Pietenpol-List: NX929DH update....Model A guys take note Well, I have put 4 hrs on her the last couple of days. This is really the first time I have had uninterrupted testing time so I could digest what is really happening to this engine. After numerous runnings I have discovered that the carb was running really rich, so much so that it was puffing black smoke periodically and building up thick layers of carbon on the stacks and also on the plugs. (This was happening some last summer also). I lowered the fuel level in the float chamber, and this helped some to lean it out a little, but the problem still persisted and I could not go on with any confidence. BTW I have concluded that my engine problems from last Sept., were a direct result of this phenominon, not related to ignition. As it turns out the good Lord was actually looking out for me that day, and allowed me to return the the airport to discover my other problem of the second mag drive falling apart. My new theory is this: When I had two functioning plugs per cylinder, there was just enough combustion to keep me from building carbon too fast. On that last flight in Sept. when the 2nd mag did fail, the carbon began to build to the point of the very rough running, forcing me back to the airport to discover the timing gear disintegration. So here is the good news. Steve Thomas (owner and benevolent king of Poplar Grove Airport) suggested that I might try burning 100LL instead of the no-lead car gas he has there. I had nothing to loose so I gave it a try. Went to the pumps and filled the remaining 8 gallons of space in my tank with 100LL. So at that point I had about 80% 100LL in the tank. It made an immediate difference. No more puffs of black smoke. No more sputtering. No more missing. Plenty of power even with only the single ignition. I flew the heck out of it right over the airport, trying to burn some gas. Went back to the pumps again and refilled with 100LL. Flew for another hour. Had to stop because I discovered a small fuel tank leak (ARRRRG). Anyway, taxied back to the hangar and pulled the plugs to find nice, gray electrodes with NO carbon anywhere. I am not smart enough to know why this switch of fuel solved the problem. I am sure there are some on this list that can tell me. Also, Steve T. mounted one of those GO PRO cameras on my strut and cowl. He got some good video from that and he also took his Cub up with his son Blake and took some more great air-to-air video. I don't see it posted anywhere yet but I will watch for it and let y'all know. So now I am feeling ALOT better about my airplane and engine, with confidence levels rising. I only have to get my tank welded up and back in to be ready for Brodhead. Since I have been without cable TV and Internet (we have it turned off in PG), I have been watching the first 15 minutes of TGWP every night on the DVD player. That has got to be the BEST movie ever. No real airplane nut could ever tire of watching that little boy Scooter, at the first sound of the airplane engine in the distance, put down his fishing rod, excitedly race with his dog over to the sound of the Jenny, and upon seeing it approach over the trees, fall on his back upside down to see the belly of the airplane wizzing a few feet above his face. Maybe I'm a sap, but it gives me chills every time. Dan Helsper Sitting in McDonalds. In PG till Tuesday ________________________________________________________________________________
Date: Jun 19, 2011
Subject: Re: NX929DH update....Model A guys take note
Great news, thanks for the update Dan. This note goes into my "engine hints" file! It's really great to hear you have everything running again and thanks for documenting the process. I had the same problem with carbon/black smoke on my A. When I get it back on the fuse and running I'm going to try the solutions you mention below. Now I'm thinking maybe I need to put my dual plug head on. Great info. Sorry to hear you'll be sitting in McDonalds at Poplar Grove until Tuesday. Well, you'll meet some interesting people and make some new friends. :-) REALLY looking forward to Brodhead this year..... Jim in Pryor.... -----Original Message----- From: helspersew(at)aol.com Sent: Jun 19, 2011 7:35 AM Subject: Pietenpol-List: NX929DH update....Model A guys take note Well, I have put 4 hrs on her the last couple of days. This is really the first time I have had uninterrupted testing time so I could digest what is really happening to this engine. After numerous runnings I have discovered that the carb was running really rich, so much so that it was puffing black smoke periodically and building up thick layers of carbon on the stacks and also on the plugs. (This was happening some last summer also). I lowered the fuel level in the float chamber, and this helped some to lean it out a little, but the problem still persisted and I could not go on with any confidence. BTW I have concluded that my engine problems from last Sept., were a direct result of this phenominon, not related to ignition. As it turns out the good Lord was actually looking out for me that day, and allowed me to return the the airport to discover my other problem of the second mag drive falling apart. My new theory is this: When I had two functioning plugs per cylinder, there was just enough combustion to keep me from building carbon too fast. On that last flight in Sept. when the 2nd mag did fail, the carbon began to build to the point of the very rough running, forcing me back to the airport to discover the timing gear disintegration. So here is the good news. Steve Thomas (owner and benevolent king of Poplar Grove Airport) suggested that I might try burning 100LL instead of the no-lead car gas he has there. I had nothing to loose so I gave it a try. Went to the pumps and filled the remaining 8 gallons of space in my tank with 100LL. So at that point I had about 80% 100LL in the tank. It made an immediate difference. No more puffs of black smoke. No more sputtering. No more missing. Plenty of power even with only the single ignition. I flew the heck out of it right over the airport, trying to burn some gas. Went back to the pumps again and refilled with 100LL. Flew for another hour. Had to stop because I discovered a small fuel tank leak (ARRRRG). Anyway, taxied back to the hangar and pulled the plugs to find nice, gray electrodes with NO carbon anywhere. I am not smart enough to know why this switch of fuel solved the problem. I am sure there are some on this list that can tell me. Also, Steve T. mounted one of those GO PRO cameras on my strut and cowl. He got some good video from that and he also took his Cub up with his son Blake and took some more great air-to-air video. I don't see it posted anywhere yet but I will watch for it and let y'all know. So now I am feeling ALOT better about my airplane and engine, with confidence levels rising. I only have to get my tank welded up and back in to be ready for Brodhead. Since I have been without cable TV and Internet (we have it turned off in PG), I have been watching the first 15 minutes of TGWP every night on the DVD player. That has got to be the BEST movie ever. No real airplane nut could ever tire of watching that little boy Scooter, at the first sound of the airplane engine in the distance, put down his fishing rod, excitedly race with his dog over to the sound of the Jenny, and upon seeing it approach over the trees, fall on his back upside down to see the belly of the airplane wizzing a few feet above his face. Maybe I'm a sap, but it gives me chills every time. Dan Helsper Sitting in McDonalds. In PG till Tuesday ________________________________________________________________________________
Date: Jun 19, 2011
Dan: It's always good to be able to take time to thoroughly analyze a problem and think through all possible repercussions. It sounds like you have done exactly that. I'm glad to hear that things are going your way again. With regard to the rich mixture condition, several folks over on the FordBarn Model A forum have complained about rich mixtures that can't be adjusted by normal means. Some say that this is the result of oversized jets that are being sold in rebuild kits, and others say that it is due to differences in modern fuels from those in use when the A was new. In any event, the usual fix is to solder the jets closed, then re-drill at a smaller size. This will require some experimentation, but you should end up with an engine with improved power, efficiency, and reliability. As a starting point, here's a link to a table of various rebuilders' jet size preferences and a short explanation of how they were originally designated: http://www.fordgarage.com/pages/jetflowrates.htm Assuming you also have a "B" carburetor, this is another good page from the same site in case you haven't seen it before: http://www.fordgarage.com/pages/bcarbassembly.htm It'll be great to see the videos! Brett Phillips NX311GP ________________________________________________________________________________
Date: Jun 19, 2011
Jack, Glad to hear someone else had the experience we had with a CC prop. What's the pitch and diameter? I put ours to good effect yesterday, 'rocketing' up through an inversion to get to smooth air. BTW, not you ever have to do these, but go-arounds became a non-event with our CC prop. Jeff On 6/19/11 9:27 AM, Jack Phillips wrote: > > You are a sap...and don't call me Shirley. > > Good to hear you're solving your engine problems, Dan. I myself am > now the proud owner of a CloudCars scimitar prop and saw an immediate > improvement in climb and a slight improvement in cruise performance. > With this prop the plane feels like a rocket climbing out on takeoff. > I can hardly wait to fly it to Brodhead. > > Jack Phillips > > NX899JP "Icarus Plummet" > > Smith Mountain Lake, Virginia > > ________________________________________________________________________________
Date: Jun 19, 2011
Great progress Jeff! You are clearly dedicating lots of time and effort to your Piet, and the workmanship looks great! The distributor ignition sounds like it will work out well. Do you have an alternator in mind? One of the little Kubota/Yanmar/John Deere units might work well. Lots of folks are using them with good success on other engines. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343442#343442 ________________________________________________________________________________
Subject: Trip review-Flight to Gardner, Kansas for WW1 replica
fly-in
Date: Jun 19, 2011
Flew the GN-1 on my first nice long cross country flight - from Marshalltown, Iowa to Gardner, Kansas (280 miles) on Thursday/Friday for the WW1 replica fly-in. Made it back last night at 9pm. 11.1 hours total flying time. Flight down had some huge headwinds(20-25mph+), was down to a ground speed of 38-39 mph at times. It took 6.1 hours - much of that was due to my flying partner's plane - he has a scratch built 6/10 scale WW1 Voison French Bomber that he built. It cruises at 50 mph. Much S-turning for me. We stopped at Corydon, Iowa to refuel - neat airport by some ponds with steel dinosaurs in the front yard - my 10 yr old loved it. We also stopped at Chillicothe, Missouri to ride out a storm (they were nice enough to stuff us in a big hanger), then headed west to Amelia Earhart airport in Kansas - cool place to fly into - and yes, it is the home of Amelia Earhart! We over-nighted in Lawrence, Ks due to darkness, then to Gardner the next morning (against 15mph winds). FYI, the Missouri river flooding is impressive! Massive thunderstorms down there last several days - the dog chain tie downs worked great! We had 40+ mph winds gusting upwards to 60 on Friday night. Unfortunately - the Voison spike tie downs came loose in the soft soil and he had to build a new lower rudder and rebuild his aileron due to hitting another airplane and a hanger I think. We found his plane in a drainage ditch several hundred yards away. He was in the air by 5:30 Saturday night on the way home. There were a bunch of really cool planes down there! A gorgeous Fokker DR-1 Triplane, many Nieuports/Sopwiths, a Siemens-Schukert, and others that I just had no clue what they were. Met Robert Baslee again (Aerdrome Airplanes - cool place to visit), Rick Bennet, Dick and Sharon Starks (they took a pic of my with my GN-1 right when I got there Friday morning) FYI- when I was at Baslee's place last year, ran into Mark Anderson who proceeded to give me a tour of his private aircraft museum which included no less than 8 Pietenpols. He knows model A engines extremely well. He actually has Bernie's original Corvair engine there also. He also has an original converted Henderson that he had just taken out of the shipping crate - it's in great condition. My flight back (by myself) was 4 hours exactly (went southerly/eastern route around thee Class B airspace). Rough down in Kansas city area - perfectly smooth from about Lexington on north. I highly recommend visiting Lexington if you ever get a chance. The owner is a total gear head that builds custom motorcycles in his back shop and they are total eye candy! He's also a licensed parachute rigger and jump instructor - used to compete on the US team and jumps at the Air Force academy with the cadets occasionally. If I remember correctly, his name is Tom Dolphin. I really appreciated having the extra fuel in this plane - have a 14 gallon header tank and a 4+ gallon center section tank. Made Gardner to Corydon, Iowa (190 miles) no problem. Could have made it the entire 280 mile trip almost on one tank - but would have been on fumes with absolutely nothing left for "just in case". Burns 4.5 g/hr with the A-75 and had an average cruise of about 74mph on way back with slight tailwind of 2-4 mph. Also - having an aviation GPS - while it isn't really required in a Piet/GN - and looks kind of funny in it - is invaluable - most especially when dealing with the Class B airspace and staying out of it. I've got an old Garmin Pilot III that works perfect. Oh yea - watched a Sonex in Gardner land short of the runway and ripped his titanium gear off in a shallow rain filled swamp. Owner walked away okay. He was coming in low and slow, got too low and hit the throttle - and the engine burped- and that was all she wrote. He'd been having carb adjustment issues just previously that morning. Later! Lorin -------- Lorin Miller Waiex N81YX GN-1 N30PP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343456#343456 ________________________________________________________________________________
Date: Jun 19, 2011
Subject: Re: Twin Rivers Fly-In
Hi Jack: If you had one of those 100hp crank snappers up front she could have flown home with you. Bill - On Sat, Jun 18, 2011 at 6:02 PM, Jack Phillips wrot e: > ** > > Just got back from the Twin Rivers Fly-in, in the Shenandoah Valley of > Virginia. Matt Paxton keeps his brand new Pietenpol there and was flying > it, although he can=92t give rides yet since he=92s still flying off the Phase I > hours. I flew my Pietenpol in, with my wife, Karen, in the front seat. > Gene Rambo had his 1928 Travel Air 2000 there, and his friend Pete Hays h ad > his Skybolt. Both of them brought their sons - good to see young kids > fooling around with airplanes. In addition there were various other > airplanes there, including a Piper Comanche and a Light Sport called a > Chinook, that looks something like a Titan Tornado.**** > > ** ** > > Since it was getting hot, and my Pietenpol doesn=92t climb all that well when > heavily loaded, I asked Gene Rambo if he would mind bringing Karen back t o > Smith Mountain Lake in his Travel Air (partly because I wanted her to get > her first ride in a biplane). It had taken us 20 minutes to climb from 9 00=92 > to 3500=92 to get over the **Blue Ridge mountains** on the way there, and > that was in the morning, when it was cool.**** > > ** ** > > Here is a picture of Matt=92s new Pietenpol. Those of you coming to Brod head > next month will get to see it there, if he can fly another 27 hours in th e > next month.**** > > ** ** > > **** > > ** ** > > ** ** > > Here are some other aircraft at the fly-in:**** > > ** ** > > **** > > ** ** > > And here is Gene=92s Travel Air in flight:**** > > ** ** > > **** > > ** ** > > Jack Phillips**** > > NX899JP =93Icarus Plummet=94**** > > Smith Mountain Lake, Virginia**** > ________________________________________________________________________________
Subject: Re: Building a Piet on the farm.....
Date: Jun 19, 2011
Yep, had a great time hanging out, and Tyler always likes coming out to see the chickens and other critters you've got running around. As for sanding... that Doug Fir is HARD stuff! I swear you must have sharpened those ribs before I came out just to give me something to do. HA! I've never felt wood so sharp! Note to self... self, don't use Doug Fir. Glad we could help out. Looking forward to the next time. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343471#343471 ________________________________________________________________________________
Date: Jun 19, 2011
Subject: Ohio piet fly-in washed out
Well Guys my little fly-in was a wash.- We had the nicest Pietenpol at th e fly-in (the only airplane there).- I am thinking of trying to do one in the fall, possibly september if there is any interest.- The weather in j une is so unstable, fall might be a better time to have it in the future. - We did bring dad's 1932 1.5 ton model A Ford truck over, and his teardr op camper he built, it will be the sleeping quarters for Brodhead.- The p eople who drove in admired the camper as much or more than the piet. - Sitting on 4 dozzen hot dogs, 5 cases of soda, and many bags of dog buns, Shad - - ________________________________________________________________________________
Subject: Re: Trip review-Flight to Gardner, Kansas for WW1 replica
fly-in
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Jun 19, 2011
That friend's name would'nt be Corey would it? if so I know him. Raymond. do not archive Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343473#343473 ________________________________________________________________________________
Date: Jun 19, 2011
Subject: Re: Ohio piet fly-in washed out
freeze them for later -- I promise to try. On Sun, Jun 19, 2011 at 4:44 PM, shad bell wrote: > Well Guys my little fly-in was a wash. We had the nicest Pietenpol at the > fly-in (the only airplane there). I am thinking of trying to do one in the > fall, possibly september if there is any interest. The weather in june is > so unstable, fall might be a better time to have it in the future. We did > bring dad's 1932 1.5 ton model A Ford truck over, and his teardrop camper he > built, it will be the sleeping quarters for Brodhead. The people who drove > in admired the camper as much or more than the piet. > > Sitting on 4 dozzen hot dogs, 5 cases of soda, and many bags of dog buns, > Shad > > > * > > * > > ________________________________________________________________________________
fly-in
Date: Jun 19, 2011
Yup - that would be Corey. -------- Lorin Miller Waiex N81YX GN-1 N30PP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343478#343478 ________________________________________________________________________________
Date: Jun 19, 2011
Hey Dan.. are you running a B carb ?? what did you do with the mixture adjustment ? on my '30 AA truck i only open the mixture when i get water in the fuel so it will have enough fuel to run.. otherwise the mixture is all the way closed to 1/4 turn open.. anything more and its rich i have a couple of aftermarket A carbs... a tillotson and a marvel ... lots of guys swear by the tillotson X and they are both aluminum ... way lighter than the Zenith cast iron carbs i plan to try both of them and see how they run.. i may put em on my truck first and see if one is better nice to hear you're flying.... i can't wait to hear mine run Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343481#343481 ________________________________________________________________________________
Subject: Throttle cover
Date: Jun 19, 2011
Here=99s picture of my throttle =9Cquadrant=9D cover before.... Here it is, after sending 3,000 miles to engraver for modification...(I=99ve added a primer set-up)... Why send it 3,000 miles for engraving, you ask? Fellow Piet builder, Jerry Dotson, does engraving as sort of a hobby, and offered! I think it=99s cool to have contributions from other builders! THANKS, JERRY!!! Gary ________________________________________________________________________________
Date: Jun 19, 2011
Jeff, My new prop is a 76" diameter and 38" pitch. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jeff Boatright Sent: Sunday, June 19, 2011 10:23 AM Subject: Re: Pietenpol-List: NX929DH update....Model A guys take note Jack, Glad to hear someone else had the experience we had with a CC prop. What's the pitch and diameter? I put ours to good effect yesterday, 'rocketing' up through an inversion to get to smooth air. BTW, not you ever have to do these, but go-arounds became a non-event with our CC prop. Jeff On 6/19/11 9:27 AM, Jack Phillips wrote: You are a sap.and don't call me Shirley. Good to hear you're solving your engine problems, Dan. I myself am now the proud owner of a CloudCars scimitar prop and saw an immediate improvement in climb and a slight improvement in cruise performance. With this prop the plane feels like a rocket climbing out on takeoff. I can hardly wait to fly it to Brodhead. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia ________________________________________________________________________________
Date: Jun 19, 2011
Not the kind of terrain I would fly over with anything but a reliable engine. I fixed th climb problem later in the day by installing a new Cloudcars prop. 33% improvement in climb rate and 3 mph faster cruise. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Princell Sent: Sunday, June 19, 2011 3:21 PM Subject: Re: Pietenpol-List: Twin Rivers Fly-In Hi Jack: If you had one of those 100hp crank snappers up front she could have flown home with you. Bill - On Sat, Jun 18, 2011 at 6:02 PM, Jack Phillips wrote: Just got back from the Twin Rivers Fly-in, in the Shenandoah Valley of Virginia. Matt Paxton keeps his brand new Pietenpol there and was flying it, although he can't give rides yet since he's still flying off the Phase I hours. I flew my Pietenpol in, with my wife, Karen, in the front seat. Gene Rambo had his 1928 Travel Air 2000 there, and his friend Pete Hays had his Skybolt. Both of them brought their sons - good to see young kids fooling around with airplanes. In addition there were various other airplanes there, including a Piper Comanche and a Light Sport called a Chinook, that looks something like a Titan Tornado. Since it was getting hot, and my Pietenpol doesn't climb all that well when heavily loaded, I asked Gene Rambo if he would mind bringing Karen back to Smith Mountain Lake in his Travel Air (partly because I wanted her to get her first ride in a biplane). It had taken us 20 minutes to climb from 900' to 3500' to get over the Blue Ridge mountains on the way there, and that was in the morning, when it was cool. Here is a picture of Matt's new Pietenpol. Those of you coming to Brodhead next month will get to see it there, if he can fly another 27 hours in the next month. Here are some other aircraft at the fly-in: And here is Gene's Travel Air in flight: Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia ________________________________________________________________________________
Date: Jun 19, 2011
U2hhZC4uLi4uZG8geW91IGhhdmUgYW55IHBpY3Mgb2YgdGhlIHRlYXIgZHJvcCBjYW1wZXI/IFRo ZSB3aWZlIGFuZCBJIGFyZSBpbiB0aGUgYmVnaW5uaW5nIHN0YWdlcyBvZiBidWlsZGluZyBvdXJz LiBCcmlhbiBpbiBTTEMsIFVUDQogDQoNCkZyb206IHN0ZXZlIGVtbyBbbWFpbHRvOnN0ZXZlLmVt bzU4QGdtYWlsLmNvbV0gDQpTZW50OiBTdW5kYXksIEp1bmUgMTksIDIwMTEgMDM6MzIgUE0NClRv OiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tIDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3Mu Y29tPiANClN1YmplY3Q6IFJlOiBQaWV0ZW5wb2wtTGlzdDogT2hpbyBwaWV0IGZseS1pbiB3YXNo ZWQgb3V0IA0KIA0KDQpmcmVlemUgdGhlbSBmb3IgbGF0ZXIgLS0gSSBwcm9taXNlIHRvIHRyeS4N Cg0KDQpPbiBTdW4sIEp1biAxOSwgMjAxMSBhdCA0OjQ0IFBNLCBzaGFkIGJlbGwgPGF2aWF0b3Ji ZWxsQHlhaG9vLmNvbT4gd3JvdGU6DQoNCg0KV2VsbCBHdXlzIG15IGxpdHRsZSBmbHktaW4gd2Fz IGEgd2FzaC4gIFdlIGhhZCB0aGUgbmljZXN0IFBpZXRlbnBvbCBhdCB0aGUgZmx5LWluICh0aGUg b25seSBhaXJwbGFuZSB0aGVyZSkuICBJIGFtIHRoaW5raW5nIG9mIHRyeWluZyB0byBkbyBvbmUg aW4gdGhlIGZhbGwsIHBvc3NpYmx5IHNlcHRlbWJlciBpZiB0aGVyZSBpcyBhbnkgaW50ZXJlc3Qu ICBUaGUgd2VhdGhlciBpbiBqdW5lIGlzIHNvIHVuc3RhYmxlLCBmYWxsIG1pZ2h0IGJlIGEgYmV0 dGVyIHRpbWUgdG8gaGF2ZSBpdCBpbiB0aGUgZnV0dXJlLiAgV2UgZGlkIGJyaW5nIGRhZCdzIDE5 MzIgMS41IHRvbiBtb2RlbCBBIEZvcmQgdHJ1Y2sgb3ZlciwgYW5kIGhpcyB0ZWFyZHJvcCBjYW1w ZXIgaGUgYnVpbHQsIGl0IHdpbGwgYmUgdGhlIHNsZWVwaW5nIHF1YXJ0ZXJzIGZvciBCcm9kaGVh ZC4gIFRoZSBwZW9wbGUgd2hvIGRyb3ZlIGluIGFkbWlyZWQgdGhlIGNhbXBlciBhcyBtdWNoIG9y IG1vcmUgdGhhbiB0aGUgcGlldC4NCiANClNpdHRpbmcgb24gNCBkb3p6ZW4gaG90IGRvZ3MsIDUg Y2FzZXMgb2Ygc29kYSwgYW5kIG1hbnkgYmFncyBvZiBkb2cgYnVucywNClNoYWQNCiANCiANCgkN CgkNCgkiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9y P1BpZXRlbnBvbC1MaXN0DQoJdHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KCV9ibGFuayI+aHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KCQ0KCQ0KDQoNCg0KDQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0K Xy09ICAgICAgICAgIC0gVGhlIFBpZXRlbnBvbC1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUg bWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFy Y2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBo b3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UGlldGVucG9sLUxpc3QNCl8tPQ0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAg ICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29u dGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAt IExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdl bmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCg0KDQo ________________________________________________________________________________
Date: Jun 19, 2011
Very nice, Gary! I can hardly wait to see your Pietenpol floating in over the corn at Brodhead. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Sunday, June 19, 2011 6:28 PM Subject: Pietenpol-List: Throttle cover Here's picture of my throttle "quadrant" cover before.... Throttle Link, 1 Here it is, after sending 3,000 miles to engraver for modification...(I've added a primer set-up)... Throttle - modified Why send it 3,000 miles for engraving, you ask? Fellow Piet builder, Jerry Dotson, does engraving as sort of a hobby, and offered! I think it's cool to have contributions from other builders! THANKS, JERRY!!! Gary ________________________________________________________________________________
Subject: Dan Helsper and his Pietenpol at the Poplar Grove Airport
Date: Jun 19, 2011
Check out this video on YouTube: http://www.youtube.com/watch?v=MiLcMV7N8r0&feature=youtube_gdata_player -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jun 19, 2011
Subject: Re: Dan Helsper and his Pietenpol at the Poplar Grove
Airport nice job Dan, really enjoyed it. Who was flying the camera ship? Brown, new guy? John In a message dated 6/19/2011 8:42:58 P.M. Eastern Daylight Time, yocum137(at)gmail.com writes: http://www.youtube.com/watch?v=MiLcMV7N8r0&feature=youtube_gdata_player ________________________________________________________________________________
Subject: Pietenpol Flying Video
Date: Jun 19, 2011
My lovely wife, Karen, flew with me to Matt Paxton's Twin Rivers Airport fly-in this weekend, This involved crossing over the Blue Ridge Mountains to get into the Shenandoah Valley of Virginia (the pass we flew through required us to get to about 3500' to get over it). It's nice having someone along to flim the trip - I'm usually too busy flying to take snapshots, much less video. This was the last flight made with my old propeller, which gave us a rate of climb with two people on board of between 100 and 200 fpm. My new Cloudcars prop gives a solid 500 fpm climb so such a trip would not be so arduous. Here's her video, showing the altitudes and airspeeds involved, The scenery was beautiful. Too bad the weather wasn't as nice, but it wasn't bad. For those building Pietenpols, maybe this will show you what you can expect once you have your bird flying and can take it to local fly-ins. There's nothing like it! http://www.youtube.com/watch?v=gAN3oZQvpVo Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia ________________________________________________________________________________
Airport
Date: Jun 19, 2011
I think Dan said it was Steve Thomas. -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Jun 19, 2011, at 7:51 PM, AMsafetyC(at)aol.com wrote: > nice job Dan, really enjoyed it. Who was flying the camera ship? Brown, ne w guy? > > John > > In a message dated 6/19/2011 8:42:58 P.M. Eastern Daylight Time, yocum137@ gmail.com writes: > http://www.youtube.com/watch?v=MiLcMV7N8r0&feature=youtube_gdata_playe r > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Waterdown Pietenpol Picnic
Date: Jun 19, 2011
Yesterday was the First Annual Waterdown Pietenpol Picnic. Filling in where the Brussels Pietenpol Picnic left off, after twenty consecutive years. The weather was excellent. Two Air Campers in attendance, and lots of Pietenpol fans and friends. Many in attendance got to experience first hand, the thrill of an open cockpit Pietenpol ride. Attached is a picture I took that I classify as one of those lucky shots - more dumb luck than planning or skill, especially with those stupid viewing screens on the back of the camera, as opposed to a proper viewfinder. Anyway, I like the shot. And yes, it's a big file. Sorry... well, not really. It was even bigger, but I reduced it to half size. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343504#343504 Attachments: http://forums.matronics.com//files/waterdown_410.jpg ________________________________________________________________________________
Subject: Re: Waterdown Pietenpol Picnic
Date: Jun 19, 2011
Nice pic! It's my new screen saver. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343506#343506 ________________________________________________________________________________
Date: Jun 19, 2011
That is a beautiful shot! Congratulations on your luck in getting it. Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343507#343507 ________________________________________________________________________________
Subject: Re: Throttle cover
Date: Jun 19, 2011
Nice...... Aircraft Spruce is gonna want to carry them...! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343513#343513 ________________________________________________________________________________
From: Matthew VanDervort <matthew.vandervort(at)gmail.com>
Date: Jun 20, 2011
Sorry shad, been really busy with work.. Can i make a donation to help with port-o-potty and what not? Let me know how! Sent from my iPhone On Jun 19, 2011, at 4:44 PM, shad bell wrote: > Well Guys my little fly-in was a wash. We had the nicest Pietenpol at the fly-in (the only airplane there). I am thinking of trying to do one in the fall, possibly september if there is any interest. The weather in june is s o unstable, fall might be a better time to have it in the future. We did br ing dad's 1932 1.5 ton model A Ford truck over, and his teardrop camper he b uilt, it will be the sleeping quarters for Brodhead. The people who drove i n admired the camper as much or more than the piet. > > Sitting on 4 dozzen hot dogs, 5 cases of soda, and many bags of dog buns, > Shad > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jun 20, 2011
Jeff, I am running the Zenith "B" carb. The mixture is 1 turn open. This was a re commendation by Ken Perkins. I tried adjusting that on the ground for bette r performance, and if I closed it I had a little roughness, but maybe now w ith the 100LL I can try to readjust to the closed or 1/4 turn open, and see . Thanks for the recommendation. I really appreciate the info. All the help from the guys on this list is priceless. BTW if you might recall the probl em I had last summer of the engine wanting to quit on final. The 100LL swit ch has helped that too. I still need to do some more testing of trying to c lose the throttle "over the numbers" and see if she quits now. When do you think you will have yours running? Dan Helsper In PG till tomorrow. Getting my aluminum tank welded this morning. Big T-st orms here today so probably can't fly. -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Sun, Jun 19, 2011 4:53 pm Subject: Pietenpol-List: Re: NX929DH update....Model A guys take note > Hey Dan.. are you running a B carb ?? hat did you do with the mixture adjustment ? on my '30 AA truck i only open the mixture when i get water in the fuel so it ill have enough fuel to run.. therwise the mixture is all the way closed to 1/4 turn open.. anything more and ts rich i have a couple of aftermarket A carbs... a tillotson and a marvel ... lots of uys swear by the tillotson X and they are both aluminum ... way lighter tha n he Zenith cast iron carbs i plan to try both of them and see how they run.. i may put em on my truck first nd see if one is better nice to hear you're flying.... i can't wait to hear mine run ead this topic online here: http://forums.matronics.com/viewtopic.php?p=343481#343481 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 20, 2011
Jack your report and Jeff Boatright's opinion of his Cloudcars prop does my heart good. I have one still in the box and looking forward to the day I can say how great the prop is! Note the 3/4" pipe engine mount. I still have not built the mount. The prop is 76X44. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343531#343531 Attachments: http://forums.matronics.com//files/a28_198.jpg ________________________________________________________________________________
Date: Jun 20, 2011
Gary, Beautiful work and attention to detail!! These are the little things that you will be very glad you took the time for. Very unique and elegant. Dan Helsper Poplar Grove, IL. ________________________________________________________________________________
Date: Jun 20, 2011
Wow, what a great picture! Thanks Bill. -----Original Message----- >From: Bill Church <billspiet(at)sympatico.ca> >Sent: Jun 19, 2011 9:09 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Waterdown Pietenpol Picnic > > >Yesterday was the First Annual Waterdown Pietenpol Picnic. Filling in where the Brussels Pietenpol Picnic left off, after twenty consecutive years. The weather was excellent. Two Air Campers in attendance, and lots of Pietenpol fans and friends. Many in attendance got to experience first hand, the thrill of an open cockpit Pietenpol ride. >Attached is a picture I took that I classify as one of those lucky shots - more dumb luck than planning or skill, especially with those stupid viewing screens on the back of the camera, as opposed to a proper viewfinder. Anyway, I like the shot. And yes, it's a big file. Sorry... well, not really. It was even bigger, but I reduced it to half size. > > >Bill C. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=343504#343504 > > >Attachments: > >http://forums.matronics.com//files/waterdown_410.jpg > > ________________________________________________________________________________
Date: Jun 20, 2011
Subject: Great YouTube video of Pietenpol flight
We have a "Holy Cow! It Flies" party on Saturday, with about 40 folks attending. Jack Phillips flew in with his Piet and Gene Rambo flew his 1929 Travel Air down from Culpeper. Al Tucker, a good friend and talented audio and video engineer, took a lot of photos which compiled into a great video, complete with appropriate music. Here's a link. _http://www.youtube.com/watch?v=DLE_ZpzzC9M_ (http://www.youtube.com/watch?v=DLE_ZpzzC9M) Matt Paxton ________________________________________________________________________________
Airport
Date: Jun 20, 2011
awesome !! is that the new prop Dan ?? is there a big difference in performance ?? jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343542#343542 ________________________________________________________________________________
Airport
Date: Jun 20, 2011
Jeff, Jack Phillips just got the new Cloudcar prop. I am running the same one I c arved. I need to study Jack's prop at Brodhead. Maybe I'll learn something. Dan Helsper Poplar Grove, IL. -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Mon, Jun 20, 2011 8:54 am Subject: Pietenpol-List: Re: Dan Helsper and his Pietenpol at the Poplar Gr ove Airport > awesome !! is that the new prop Dan ?? is there a big difference in performance ?? jeff ead this topic online here: http://forums.matronics.com/viewtopic.php?p=343542#343542 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 20, 2011
1928=2C please. Don't know why=2C but EVERYONE always defaults to '29 for no apparent reason. Had a blast! Gene From: Woodflier(at)aol.com Date: Mon=2C 20 Jun 2011 09:38:58 -0400 Subject: Pietenpol-List: Great YouTube video of Pietenpol flight We have a "Holy Cow! It Flies" party on Saturday=2C with about 40 folks att ending. Jack Phillips flew in with his Piet and Gene Rambo flew his 1929 Tr avel Air down from Culpeper. Al Tucker=2C a good friend and talented audio and video engineer=2C took a lot of photos which compiled into a great vide o=2C complete with appropriate music. Here's a link. http://www.youtube.com/watch?v=DLE_ZpzzC9M Matt Paxton ________________________________________________________________________________
Date: Jun 20, 2011
Subject: Steve Thomas, Dan Helsper and his Pietenpol at the Poplar
Grove Airport Dan, Do you know if Steve Thomas is heading here to ohio for the waco fly-in thi s week?- I always like to stop over and say hi to him and Tom Brown (Brow n Aero Aircamper), when they stop by.- Steve is a great guy, he helped us out when we had to trailer 92GB home in 2006, when we tried to make Brodhe ad.- Are you going to be at Poplar Grove this summer, or Tenn.- I will be stopping by for fuel thurs afternoon if everything goes well. --- On Sun, 6/19/11, Dan Yocum wrote: From: Dan Yocum <yocum137(at)gmail.com> Subject: Re: Pietenpol-List: Dan Helsper and his Pietenpol at the Poplar Gr ove Airport Date: Sunday, June 19, 2011, 9:40 PM I think Dan said it was Steve Thomas.- --- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Jun 19, 2011, at 7:51 PM, AMsafetyC(at)aol.com wrote: nice job Dan, really enjoyed it. Who was flying the camera ship? Brown, new guy? - John - In a message dated 6/19/2011 8:42:58 P.M. Eastern Daylight Time, yocum137@g mail.com writes: http://www.youtube.com/watch?v=MiLcMV7N8r0&feature=youtube_gdata_player 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: Re: Steve Thomas, Dan Helsper and his Pietenpol at the
Date: Jun 20, 2011
Shad, Here is Steves email steve(at)poplargroveairmotive.com. You could ask him abou t the Waco fly-in. I will be in PG on that Thirsday, but hopefully I mihght be at Brodhead already by then, if all goes well. Can't wait to see you an d your Piet again. Dan Helsper Poplar Grove, IL. -----Original Message----- From: shad bell <aviatorbell(at)yahoo.com> Sent: Mon, Jun 20, 2011 9:49 am Subject: Pietenpol-List: Steve Thomas, Dan Helsper and his Pietenpol at the Poplar Grove Airport Dan, Do you know if Steve Thomas is heading here to ohio for the waco fly-in thi s week? I always like to stop over and say hi to him and Tom Brown (Brown Aero Aircamper), when they stop by. Steve is a great guy, he helped us out when we had to trailer 92GB home in 2006, when we tried to make Brodhead. Are you going to be at Poplar Grove this summer, or Tenn. I will be stopp ing by for fuel thurs afternoon if everything goes well. --- On Sun, 6/19/11, Dan Yocum wrote: From: Dan Yocum <yocum137(at)gmail.com> Subject: Re: Pietenpol-List: Dan Helsper and his Pietenpol at the Poplar Gr ove Airport Date: Sunday, June 19, 2011, 9:40 PM I think Dan said it was Steve Thomas. -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Jun 19, 2011, at 7:51 PM, AMsafetyC(at)aol.com wrote: nice job Dan, really enjoyed it. Who was flying the camera ship? Brown, new guy? John In a message dated 6/19/2011 8:42:58 P.M. Eastern Daylight Time, yocum137@g mail.com writes: http://www.youtube.com/watch?v=MiLcMV7N8r0&feature=youtube_gdata_player 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D pol-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 20, 2011
I was just going to ask the list about others who have been using 100LL in the model A. I got the Airworthiness Certificate June 9, and waited till Fri the 17th for Barry Triplett to make the first flight. The engine hadn't been run for about a month and when I tried to start it just to get more time on it before starting taxi tests, I couldn't get it running. I decided that when Barry got here, we would get it running. We did, but it took 3 days and he had to leave after just making a couple of runs up and down the runway. On Fri we determined the Slick mag had died even though the engine had been running great the last time that I had it going. The first few times I ran the engine almost 2 years ago I fueled it with 91 octane auto gas without ethanol, and it was running fine. At the present time it is difficult to find auto gas without ethanol near my home, so I decided to switch to 100LL. I ran it a total of 2 hours on the 100LL before taking it to the airport. As soon as we decided the mag was not working, I ordered a new one overnight delivery and when we got it in the airplane, had to spend some time getting the impulse working reliably by shimming it back in the mounting. Once we had a good spark, it started and ran on 2 cylinders, 1&3. Cylinders 2&4 exhaust valves were stuck open. We pulled off the side cover and managed to loosen them up after a great deal of working them up and down with screwdrivers. After getting compression on all 4, it started after a great deal of priming and propping. I am sure that the sticking valves were caused by the lead in the fuel. If anyone has had experience with the 100LL in the A, I would like to hear about it. Don Lane ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG FORSCOM" <steven.d.dortch(at)us.army.mil>
Date: Jun 20, 2011
My 100LL VS AUTOFUEL experience is limited to Continental O200 (cessna 150) and Continental E-185-11 (205 HP 1948 Bonanza) Both engines were designed to be run on 80 octane avgas. Both have an STC for UL autofuel. Both would run fine on either 100LL or UL AUTOFUEL. However, Anytime I run 100LL I have to work to keep the plugs from leading up. I lean the plane aggressively on the ground to keep the plugs hot and I lean in the air as well. Seems that the lead likes the plugs. On Autofuel, I always run over 89 (or higher) octane autofuel with no ethanal. I always check every load of Autofuel for alcohol. If they screw up and put it in a car that is one thing. But that alcohol will eat up the gaskets in both carbs and the "Rubber" fuel tanks on the Bonanza. Having said all that it is at least a dollar or two cheaper per gallon and The planes run better on it. There is ZERO spark plug fowling and the planes made the same RPM/manifold pressures. I do fill up with 100LL before parking the plane for any length of time. It is better on the old Gas tanks and carbs. 100LL is much more stable over long term for storage (It does not seem to evaporate as much or leave varnish) Probably not much help but That is my knowledge of AVGAS vs AUTOFUEL. ON the sticking valves, I would run some Marvel Mystery Oil thru the oil and gas. I have had success with it. Blue Skies, Steve OT The Beech list guys are discussing the EPA proposal of dropping 100LL as a fuel and what the replacement might be. Lots of concern for planes that cannot drop to a lower octane without being grounded or a significant loss of HP(RPM). ----- Original Message ----- From: Donald Lane <dslane(at)embarqmail.com> Date: Monday, June 20, 2011 12:16 Subject: Subject: Pietenpol-List: NX929DH update....Model A guys take note > I was just going to ask the list about others who have been using > 100LL in the model A. > I got the Airworthiness Certificate June 9, and waited till Fri the > 17th for Barry Triplett to make the first flight. The engine > hadn't been run for about a month and when I tried to start it just > to get more time on it before starting taxi tests, I couldn't get > it running. I decided that when Barry got here, we would get it > running. We did, but it took 3 days and he had to leave after just > making a couple of runs up and down the runway. On Fri we > determined the Slick mag had died even though the engine had been > running great the last time that I had it going. The first few > times I ran the engine almost 2 years ago I fueled it with 91 > octane auto gas without ethanol, and it was running fine. At the > present time it is difficult to find auto gas without ethanol near > my home, so I decided to switch to 100LL. I ran it a total of 2 > hours on the 100LL before taking it to the airport. As soon as we > decided the mag was not working, I ordered a new one overnight > delivery and when we got it in the airplane, had to spend some > time getting the impulse working reliably by shimming it back in > the mounting. Once we had a good spark, it started and ran on 2 > cylinders, 1&3. Cylinders 2&4 exhaust valves were stuck open. We > pulled off the side cover and managed to loosen them up after a > great deal of working them up and down with screwdrivers. After > getting compression on all 4, it started after a great deal of > priming and propping. I am sure that the sticking valves were > caused by the lead in the fuel. If anyone has had experience with > the 100LL in the A, I would like to hear about it. > > Don Lane ________________________________________________________________________________
Date: Jun 20, 2011
Subject: Re: Building my first wing rib - the journey begins
Tom, When I finished my rib, I then used my table top router with trimming bit and cleaned up all the edges. My table sander took care of the front edge of the rib to keep it square and nicly finished. PS.. let me know your plans for Brodhead, WI as I used to live 7 miles away in Albany, WI for 5 years! I can assist with the area if needed. Hope to see you their. KMHeide Hawley, Mn --- On Fri, 6/17/11, tdudley(at)umn.edu wrote: > From: tdudley(at)umn.edu <tdudley(at)umn.edu> > Subject: Pietenpol-List: Re: Building my first wing rib - the journey begins > To: pietenpol-list(at)matronics.com > Date: Friday, June 17, 2011, 1:18 PM > --> Pietenpol-List message posted > by: "tdudley(at)umn.edu" > > > Terry, > > I mitred my rib spacers and cut square/rectangular > gussets. Do what Mark did and cut multiple spacers and > gussets. It's really nice to be able to make a rib a > day without having to stop and cut individual pieces. > > Building the ribs was great--starting on the project and > seeing progress each day. Every part of it was > exciting. > > Tom > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=343320#343320 > > > > > Attachments: > > http://forums.matronics.com//files/rib_945.jpg > http://forums.matronics.com//files/rib_gusset_166.jpg > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
From: "Amsafetyc(at)gmail.com" <amsafetyc(at)gmail.com>
Date: Jun 20, 2011
Subject: Re: Flight report- back in the air
Great news Dan Sent via DROID on Verizon Wireless -----Original message----- From: helspersew(at)aol.com Sent: Sat, Jun 18, 2011 11:42:12 GMT+00:00 Subject: Pietenpol-List: Flight report- back in the air Hello Good People, NX929DH finally graced the skies again yesterday for 1 1/2 hrs yesterday at Poplar Grove. All went well and she is ready to go to Brodhead. Longer report later next week when I can get back to TN and to my Internet connection (sitting here in McDonalds in Belvidere, IL.[famous hometown of Ryan Meuller]) Looking forward to seeing everybody. Pray for good weather. Dan Helsper (from) Poplar Grove, IL. ________________________________________________________________________________
Subject: Cloudcars Prop Performance
Date: Jun 20, 2011
OK, fellow Pieters, This weekend I received my new Cloudcars scimitar propeller for my Pietenpol, and yesterday I was able to get some accurate climb data to compare to the climb data I did with the old prop last week. My Pietenpol is heavy at 740 lbs empty and I've always been disappointed in its climb performance. I thought it was just due to the weight until I flew Ryan Mueller's Pietenpol to Brodhead last year with its new Cloudcars prop. What a difference! His Piet was about 60 lbs lighter than mine, but that couldn't account for the difference in performance. It had to be the prop. Knowing that my new prop was about to arrive, I flew some early morning tests this past Wednesday to measure exactly what kind of performance I was getting with the old prop. Then, yesterday morning I did the same test with the new prop. It was warmer yesterday and the density altitude was higher, but even so the results with the Cloudcars prop were impressive. Here are the data points. The first four runs were with the old prop, the last four (in red) with the Cloudcars: Run Speed Initial Altitude Final Altitude Time Rate of Climb Corrected Rate of Climb* 1 50 mph 1500' 2000' 1:24 357 fpm 357 fpm 2 55 mph 1500' 2000' 1:43 291 fpm 291 fpm 3 45 mph 1700' 2200' 1:54 263 fpm 263 fpm 4 52 mph 1500' 2000' 1:20 375 fpm 375 fpm 5 50 mph 1600' 2100' 1:08 441 fpm 539 fpm 6 55 mph 1500' 2000' 1:09 435 fpm 532 fpm 7 45 mph 1550' 2050' 1:23 361 fpm 441 fpm 8 52 mph 1500' 2000' 1:00 500 fpm 611 fpm Corrected rate of climb corrects for the difference in Density Altitude between the two days. The first 4 runs were made at a density altitude (on the ground) of 1800', and the second set of 4 runs were made at a density altitude of 2200'. So even uncorrected, the Cloudcars prop (76" x 38") performs 33% better than the old (72" x 40" ) prop. The numbers tell one story, but flying the new prop is incredible! The acceleration on takeoff is much brisker than the old prop, and the airplane leaps off the ground and climbs like a homesick angel. With the old prop, I always had to have a discussion with the airplane to make it leave the comfort of ground effect, and it did so only reluctantly. This is the first time I've ever seen 500 fpm sustained on my Vertical Speed Indicator. Here's a picture of the new prop on my airplane: I am SO looking forward to Brodhead now. Before, I was hesitant to take passengers because the climb rate was so abysmal. Now I'll be ready to take a lot more, particularly pretty female passengers. I still have little interest in taking fat old men. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia ________________________________________________________________________________
Date: Jun 20, 2011
Subject: Re: Cloudcars Prop Performance
Jack, I'm a big fan of data-driven analyses such as this. Your observations are of special value to those of us still a few steps back in the building process -- even those planning to fly behind crank snappers. :) Thanks, Ken On Mon, Jun 20, 2011 at 4:48 PM, Jack Phillips wrot e: > ****** > > OK, fellow Pieters,**** > > ** ** > > This weekend I received my new Cloudcars scimitar propeller for my > Pietenpol, and yesterday I was able to get some accurate climb data to > compare to the climb data I did with the old prop last week.**** > > ** ** > > My Pietenpol is heavy at 740 lbs empty and I=92ve always been disappointe d in > its climb performance. I thought it was just due to the weight until I f lew > Ryan Mueller=92s Pietenpol to Brodhead last year with its new Cloudcars p rop. > What a difference! His Piet was about 60 lbs lighter than mine, but that > couldn=92t account for the difference in performance. It had to be the p rop. > **** > > ** ** > > Knowing that my new prop was about to arrive, I flew some early morning > tests this past Wednesday to measure exactly what kind of performance I w as > getting with the old prop. Then, yesterday morning I did the same test w ith > the new prop. It was warmer yesterday and the density altitude was highe r, > but even so the results with the Cloudcars prop were impressive.**** > > ** ** > > Here are the data points. The first four runs were with the old prop, th e > last four (in red) with the Cloudcars:**** > > ** ** > > *Run* *Speed * *Initial Altitude* *Final Altitude* *Time* > *Rate of Climb* *Corrected Rate of Climb** > > ** ** > > 1 50 mph 1500=92 2000=92 1:24 > 357 fpm 357 fpm**** > > ** ** > > 2 55 mph 1500=92 2000=92 1:43 > 291 fpm 291 fpm**** > > ** ** > > 3 45 mph 1700=92 2200=92 1:54 > 263 fpm 263 fpm**** > > ** ** > > 4 52 mph 1500=92 2000=92 1:20 > 375 fpm 375 fpm**** > > ** ** > > 5 50 mph 1600=92 2100=92 1:08 > 441 fpm 539 fpm**** > > ** ** > > 6 55 mph 1500=92 2000=92 1:09 > 435 fpm 532 fpm**** > > ** ** > > 7 45 mph 1550=92 2050=92 1:23 > 361 fpm 441 fpm**** > > ** ** > > 8 52 mph 1500=92 2000=92 1:00 > 500 fpm 611 fpm**** > > ** ** > > Corrected rate of climb corrects for the difference in Density Altitude > between the two days. The first 4 runs were made at a density altitude ( on > the ground) of 1800=92, and the second set of 4 runs were made at a densi ty > altitude of 2200=92.**** > > ** ** > > So even uncorrected, the Cloudcars prop (76=94 x 38=94) performs 33% bett er > than the old (72=94 x 40=94 ) prop.**** > > ** ** > > The numbers tell one story, but flying the new prop is incredible! The > acceleration on takeoff is much brisker than the old prop, and the airpla ne > leaps off the ground and climbs like a homesick angel. With the old prop , I > always had to have a discussion with the airplane to make it leave the > comfort of ground effect, and it did so only reluctantly. This is the fi rst > time I=92ve ever seen 500 fpm sustained on my Vertical Speed Indicator.** ** > > ** ** > > Here=92s a picture of the new prop on my airplane:**** > > ** ** > > **** > > ** ** > > I am SO looking forward to Brodhead now. Before, I was hesitant to take > passengers because the climb rate was so abysmal. Now I=92ll be ready to take > a lot more, particularly pretty female passengers. I still have little > interest in taking fat old men.**** > > ** ** > > Jack Phillips**** > > NX899JP =93Icarus Plummet=94**** > > ****Smith Mountain Lake**, **Virginia******** > > ** ** > ________________________________________________________________________________
Date: Jun 21, 2011
A few years ago I had Ed Sterba carve a prop for me. After a lot of research I told him I wanted it to be a 76 x 38. When I replaced my 72 x 42 with it I was very surprised at the performance. Since then I've been able to get a hold of a Falcon prop that performs close to the same but I just love the looks of it with the brass leading edge and all. So I sold the Sterba. But the Pietenpol really does need a larger diameter flatter pitch prop for the engines that turn somewhere in the 2100 rpm range. All that drag out there really needs that large prop disk to be effective at the slower speeds. Glad you are happy with it Jack! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343627#343627 ________________________________________________________________________________
Date: Jun 21, 2011
- Hey Guys, - I've been following the discussion about Cloudcars- Props for a little ov er a year now. - Jack, thanks for the excellent data.- I have a Hegy semi scimitar 72 x 42 that I have not yet mounted and tested but now when I do finally get her f lying, I'll have some solid numbers to compare to. - -I have two different Piets I may be able to try it on. One is the chapte r project,-an 800 pound GN-1 witrh an 0-200, the other is my long fuse Pi et with an A-65. It may come in around 670 lbs.- - Jack, the main difference I see is your 38" pitch. Great climb performance but what is your cruise performance and what size engine are you using? - Jeff Wilson St. Louis N899WT 75% done, 74% to go. ________________________________________________________________________________
Subject: Re: Subject: NX929DH update....Model A guys take note
Date: Jun 21, 2011
Don I can give you my experiences from a few years of Ford and Funk engines. Only a touch ! I use fresh fuel only if it is "Auto", less than 1 year old. 100 Oct will hold out much longer 2 years in a can , and works. Now. I have mentioned a number of times the following. I used to mix Marvel with all fuel, and didn't have a problem, I have been using a different mix, with the hottest plugs available I.E.,& at the same mix ratio : Amsoil 2 cycle oil : , Clearances of all valves .012", 7.5:1 compression.Never a stuck valve ! ! I have run out of water an flew and added 30 min. oil temps over 350 Deg. and still never damaged my Ford. I run inserts and a few mods if you are interested in the old stuff. I am now trying a horizontal flow radiator, that allows 10" open area up to the wing, and fly very differently. Will be at brodhead again. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343634#343634 ________________________________________________________________________________
Date: Jun 21, 2011
Actually I think the 76" diameter has more effect than the lower pitch. It allows 11% more swept area, moving a larger column of air. Cruise performance with the Sensenich 72 x 40: 2150 RPM yields 65 mph Cruise performance with the Cloudcars: 2150 RPM yields 69 mph Calculating efficiencies based on the above gives an efficiency for the Sensenich of 79.83%. The Cloudcars has an efficiency of 89.20%. The combination of moving more air and doing it more efficiently is the key to the Cloudcars performance. Jack Phillips NX899JP "Icarus Plummet" Smith Mountin Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jeff wilson Sent: Tuesday, June 21, 2011 9:24 AM Subject: Pietenpol-List: Cloudcars Prop Performance Hey Guys, I've been following the discussion about Cloudcars Props for a little over a year now. Jack, thanks for the excellent data. I have a Hegy semi scimitar 72 x 42 that I have not yet mounted and tested but now when I do finally get her flying, I'll have some solid numbers to compare to. I have two different Piets I may be able to try it on. One is the chapter project, an 800 pound GN-1 witrh an 0-200, the other is my long fuse Piet with an A-65. It may come in around 670 lbs. Jack, the main difference I see is your 38" pitch. Great climb performance but what is your cruise performance and what size engine are you using? Jeff Wilson St. Louis N899WT 75% done, 74% to go. ________________________________________________________________________________
Date: Jun 21, 2011
Subject: Re: Cloudcars prop performance
Jack, glad you got the kind of performance improvement you were hoping for. I wonder what I would get with a longer prop like you got. Mine's 72 X 44 but I'm very satisfied with the performance. Now less worries about getting over those West Va mountains. Matt Paxton NX629ML ________________________________________________________________________________
Date: Jun 21, 2011
Subject: Re: Twin Rivers flying
Sorry Gene. With the Piet's first flight date in '29, I had that on the brain. Sure good to see you and the Travel Air and great that you brought Will, Peter and Peter. Matt ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Jun 21, 2011
Jack, Stunning! Your 30% performance increase may be even better than what we get ! No question, the CC prop was the biggest performance gain per dollar (and per unit of effort) that we've seen out our Piet. Jeff Boatright PS: It looks great, too! ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Jun 21, 2011
Subject: Diesel
I'm interested if anyone has found a diesel engine suitable for a Pietenpol.The name Chris Rusch came up as a possible diesel engine user.I don't see his name in the posts etc.Anyone know anything on this subject? ________________________________________________________________________________
Airport
Date: Jun 21, 2011
I think you are having way too much fun Dan! Very Nice!!! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343677#343677 ________________________________________________________________________________
Airport
Date: Jun 21, 2011
After watching that I got off my rear end and glued rib 31! Very inspirational! Thanks for posting that Dan! Scotty -------- Scotty Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Rudder, Vert stab, Elevators and 30 Ribs built... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343681#343681 ________________________________________________________________________________
Subject: Gasoline questions
Date: Jun 21, 2011
Ok, I guess I don't get it. In the last day or so there have been several posts detailing anecdotal exp eriences with the use of different gasolines, comparing 100LL, unleaded aut o fuel etc. Some of the posts blamed the lead for fouling of plugs, and als o sticking of valves, and the implication was that the lead was a "bad" thi ng. When I went to A&P school, oh those many years ago, I can recall that t he reason for the lead was that there was some advantage to scavenging of e xhaust gasses. Seeing that the addition of lead to gasoline was the norm fo r many decades, I can only assume that the lead was added for a reason, cre ating some advantage in engine performance. The old 100 octane aviation gas oline had much more lead than the modern 100LL. The "wizards of smart" that were responsible for such things must have had a good reason for leaving s ome lead in the 100LL. How can the little bit of lead that is now used be r esponsible for plug and valve problems, but for all those previous decades it was just fine and dandy? Anyone with an opinion, informed or not, please chime-in so I can be enligh tened (or entertained at least) :O) Dan Helsper Puryear, TN. ________________________________________________________________________________
Subject: Re: Gasoline questions
Date: Jun 21, 2011
Lead lubricates valves. The stuff on plugs is CARBON, not lead. Gene Rambo Sent from my iPhone On Jun 21, 2011, at 8:58 PM, helspersew(at)aol.com wrote: > Ok, I guess I don't get it. > > In the last day or so there have been several posts detailing anecdotal ex periences with the use of different gasolines, comparing 100LL, unleaded aut o fuel etc. Some of the posts blamed the lead for fouling of plugs, and also sticking of valves, and the implication was that the lead was a "bad" thing . When I went to A&P school, oh those many years ago, I can recall that the r eason for the lead was that there was some advantage to scavenging of exhaus t gasses. Seeing that the addition of lead to gasoline was the norm for many decades, I can only assume that the lead was added for a reason, creating s ome advantage in engine performance. The old 100 octane aviation gasoline ha d much more lead than the modern 100LL. The "wizards of smart" that were res ponsible for such things must have had a good reason for leaving some lead i n the 100LL. How can the little bit of lead that is now used be responsible f or plug and valve problems, but for all those previous decades it was just f ine and dandy? > > Anyone with an opinion, informed or not, please chime-in so I can be enlig htened (or entertained at least) :O) > > Dan Helsper > Puryear, TN. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jun 21, 2011
And, tetraethyl lead boosts octane, but I am no chemist. Gene Rambo Sent from my iPhone On Jun 21, 2011, at 8:58 PM, helspersew(at)aol.com wrote: > Ok, I guess I don't get it. > > In the last day or so there have been several posts detailing anecdotal ex periences with the use of different gasolines, comparing 100LL, unleaded aut o fuel etc. Some of the posts blamed the lead for fouling of plugs, and also sticking of valves, and the implication was that the lead was a "bad" thing . When I went to A&P school, oh those many years ago, I can recall that the r eason for the lead was that there was some advantage to scavenging of exhaus t gasses. Seeing that the addition of lead to gasoline was the norm for many decades, I can only assume that the lead was added for a reason, creating s ome advantage in engine performance. The old 100 octane aviation gasoline ha d much more lead than the modern 100LL. The "wizards of smart" that were res ponsible for such things must have had a good reason for leaving some lead i n the 100LL. How can the little bit of lead that is now used be responsible f or plug and valve problems, but for all those previous decades it was just f ine and dandy? > > Anyone with an opinion, informed or not, please chime-in so I can be enlig htened (or entertained at least) :O) > > Dan Helsper > Puryear, TN. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jun 21, 2011
Here are some links that might clear the air a little. I will state my opinion and it is no engine with a compression ratio of 7.0 or less needs any lead at all. Lead is an octane booster. Read the Shell link closely. http://www.shell.com/home/content/aviation/aeroshell/technical_talk/techart18_30071600.html http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343700#343700 ________________________________________________________________________________
Date: Jun 21, 2011
I have always heard that lead protected the valves and the valve seats, which is why cars manufactured prior to the introduction of unleaded gas did not use hardened valve seats. I've seen cylinder heads from the 1960's and 70's where the valve seats have receded into the heads from excessive running on no-lead fuel. It is recommended to have hardened valve seats installed in vintage cylinder heads if you plan to drive the car (or fly the plane, Corvair guys) a lot on today's formulation of automotive gasoline. I have also heard that the lead increased the 'knock-resistance" of the fuel, probably from creating a higher octane rating as Gene mentioned... Anybody who was driving in the 60's and early 70's will remember that the "low grade" gas was 94 octane, and "Super" 103-108 octane was common in gas stations back then. The owner's manual for my 1967 Ford Fairlane 500 with the 200hp 289 specifies that the car be run on a MINIMUM of 94 octane gas, and if the car were to have the 300 0r 325hp, 390 cubic inch engine, they recommended 97 or higher. At the pump today, 93 is about the BEST you'll find although I do occasionally see 95 octane available at some Shell stations. -------- Billy McCaskill Urbana, IL tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343708#343708 ________________________________________________________________________________
Subject: Re: Pietenpol Flying Video
Date: Jun 21, 2011
Makes me grin just watching...got the plans and starting to get the garage cleared out (and an A/C unit installed). :D -------- --Randall 02xB || !02xB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343723#343723 ________________________________________________________________________________
Date: Jun 22, 2011
Don't forget that some makers use the flat side of the blade as reference for pitch and others use the airfoil chord line. Two different 40" pitch props may not be the same pitch at all. That info is important for any meaningful comparison. Clif Cruise performance with the Sensenich 72 x 40: 2150 RPM yields 65 mph Cruise performance with the Cloudcars: 2150 RPM yields 69 mph Jack Phillips NX899JP "Icarus Plummet" Smith Mountin Lake, Virginia ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Jun 22, 2011
Thanks to everyone for the advice on fuel for the A engine. I have the engine down now to redo the exhaust stacks. I will keep the valves well oiled in the meantime and maybe put a little oil in the fuel when I restart it. Don L ________________________________________________________________________________
Date: Jun 22, 2011
I have a pretty good bit of auto gas experience but not in recent years. We ran auto gas in a Pawnee with an O-540 235 HP and a Stearman with a P&W 985 in the 70's. That gas had some lead in it. Then a Cessna 150 with an O-320 150 HP off a Piper Apache for several years with zero problems. The gas I ran in the Cessna 150 was unleaded 89 octane from Standard Oil. Filled it from my 500 gallon tank. I never got past the smell. The only difference I could tell between avgas and auto gas was the smell. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343742#343742 ________________________________________________________________________________
Date: Jun 22, 2011
I've heard lots of stories of sticking valves in small continentals like the A-65 when using 100LL. I've been told its because they don't run hot enough to prevent the lead from depositing on the shaft of the valve, causing it to bind in the guide. An old A&P that was expaining it to me called it 100*L*otsa *L*ead. I live in Florida, and rarely see my oil temps above 140. Another thing to consider is the difference in specific gravity between 100LL and auto gas. This effectively changes the float level, which changes your mixture. When I rebuilt my carb, I used non-ethanol auto gas to set the float level On 6/21/2011 8:58 PM, helspersew(at)aol.com wrote: Ben Charvet Expected 103 Heat index today. Probably 2000' density altitude at 35 msl Titusville, Fl > Ok, I guess I don't get it. > In the last day or so there have been several posts detailing > anecdotal experiences with the use of different gasolines, comparing > 100LL, unleaded auto fuel etc. Some of the posts blamed the lead for > fouling of plugs, and also sticking of valves, and the implication was > that the lead was a "bad" thing. When I went to A&P school, oh those > many years ago, I can recall that the reason for the lead was that > there was some advantage to scavenging of exhaust gasses. Seeing that > the addition of lead to gasoline was the norm for many decades, I can > only assume that the lead was added for a reason, creating some > advantage in engine performance. The old 100 octane aviation gasoline > had much more lead than the modern 100LL. The "wizards of smart" that > were responsible for such things must have had a good reason for > leaving some lead in the 100LL. How can the little bit of lead that is > now used be responsible for plug and valve problems, but for all those > previous decades it was just fine and dandy? > Anyone with an opinion, informed or not, please chime-in so I can be > enlightened (or entertained at least) :O) > Dan Helsper > Puryear, TN. > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Jun 22, 2011
I seem to remember a post a while back about these props having a "short li fe span". I don't remember any details other then the person was looking in to buying a new prop and said one draw back tothe Cloudcarse props was a sh ort life span.- Anyone have details on this? Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Jun 22, 2011
My airport coffee discussions lead me to believe that plug fowling is more of a problem on the early engines that were OK with 80 Octane than on engines that require the higher octane. While I will probably be able to fly my old Bonanza on anything with the octane of hair oil, There is concern that suddenly stopping the use of 100 LL with no replacement could ground 20 % of our fleet. That affects everyone who flies. We don't need a divot like that in our pilot population. Blue Skies, Steve D ----- Original Message ----- From: Ben Charvet <bencharvet(at)gmail.com> Date: Wednesday, June 22, 2011 7:18 Subject: Re: Pietenpol-List: Gasoline questions > I've heard lots of stories of sticking valves in small continentals > like > the A-65 when using 100LL. I've been told its because they don't > run > hot enough to prevent the lead from depositing on the shaft of the > valve, causing it to bind in the guide. An old A&P that was > expaining it > to me called it 100*L*otsa *L*ead. I live in Florida, and rarely > see > my oil temps above 140. Another thing to consider is the > difference in > specific gravity between 100LL and auto gas. This effectively > changes > the float level, which changes your mixture. When I rebuilt my > carb, I > used non-ethanol auto gas to set the float level > On 6/21/2011 8:58 PM, helspersew(at)aol.com wrote: > > Ben Charvet > Expected 103 Heat index today. Probably 2000' density altitude at > 35 msl > Titusville, Fl > > Ok, I guess I don't get it. > > In the last day or so there have been several posts detailing > > anecdotal experiences with the use of different gasolines, > comparing > > 100LL, unleaded auto fuel etc. Some of the posts blamed the lead > for > > fouling of plugs, and also sticking of valves, and the > implication was > > that the lead was a "bad" thing. When I went to A&P school, oh > those > > many years ago, I can recall that the reason for the lead was > that > > there was some advantage to scavenging of exhaust gasses. Seeing > that > > the addition of lead to gasoline was the norm for many decades, I > can > > only assume that the lead was added for a reason, creating some > > advantage in engine performance. The old 100 octane aviation > gasoline > > had much more lead than the modern 100LL. The "wizards of smart" > that > > were responsible for such things must have had a good reason for > > leaving some lead in the 100LL. How can the little bit of lead > that is > > now used be responsible for plug and valve problems, but for all > those > > previous decades it was just fine and dandy? > > Anyone with an opinion, informed or not, please chime-in so I can > be > > enlightened (or entertained at least) :O) > > Dan Helsper > > Puryear, TN. > > * > > > > > > * > > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > ________________________________________________________________________________
Date: Jun 22, 2011
The unsubstantiated "short life span" claim was regarding scimitar propellers in general, NOT Cloudcars propellers. However, Cloudcars did issue a response when the question was posed: http://forums.matronics.com/viewtopic.php?t=69612 Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343760#343760 ________________________________________________________________________________
Date: Jun 22, 2011
Thanks Bill. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 22, 2011
For those of us whom use these propellers, how do they compare in price to other appropriately sized propellers? I am very interested in using one when the time comes. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Jun 22, 2011
I am flying behind stock Cont. C-85-12F engine with the old style cylinder heads. I have an all metal fuel system except for an 8" piece of aircraft quality air-quip hose between the gascolator and carb. I have a metal float and needle and seat in my carb. Here is my experience with auto and 100LL. I have found that when I run pure auto gas that it is a little harder to start but still easy to do whether the engine is hot or cold. If I run the auto gas for a few hundred hours without the Marvel Mystery oil in the gas, I risk sticking an exhaust valve on the right front cylinder. The fix is to just remove the exhaust valve and run a 7/16" reamer through the guide, hand lap the valve and re assemble it. Now if I run 100LL it will start with less priming and will flood easier when hot. If pure 100LL is run for about 60 to 80hours I will be blessed with a lead fowled lower plug. All that being said, I typically will fill up with auto one time and 100LL the next time without the use of the Marvel Mystery oil. I have never had a problem with this method and it is easy to do if you are just flying locally. Out here on the west coast we don't have Mogas available at the airports. One other point I must make. Because I have an all metal fuel system and don't fly above 9000 feet, I have never been concerned with the auto gas additives (alcohol and ethanol) and have not had any engine problems related to them. Maybe I am just lucky. Your results may vary, [/b] -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343766#343766 ________________________________________________________________________________
Date: Jun 22, 2011
100 Octane (the green stuff) had 10 times the amount of lead that was in 80/87 (the old red stuff). 100LL (the blue stuff) has less lead that 100, but it still has 4 times as much as 80 Octane had. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Wednesday, June 22, 2011 8:11 AM Subject: Re: Pietenpol-List: Gasoline questions I've heard lots of stories of sticking valves in small continentals like the A-65 when using 100LL. I've been told its because they don't run hot enough to prevent the lead from depositing on the shaft of the valve, causing it to bind in the guide. An old A&P that was expaining it to me called it 100 Lotsa Lead. I live in Florida, and rarely see my oil temps above 140. Another thing to consider is the difference in specific gravity between 100LL and auto gas. This effectively changes the float level, which changes your mixture. When I rebuilt my carb, I used non-ethanol auto gas to set the float level On 6/21/2011 8:58 PM, helspersew(at)aol.com wrote: Ben Charvet Expected 103 Heat index today. Probably 2000' density altitude at 35 msl Titusville, Fl Ok, I guess I don't get it. In the last day or so there have been several posts detailing anecdotal experiences with the use of different gasolines, comparing 100LL, unleaded auto fuel etc. Some of the posts blamed the lead for fouling of plugs, and also sticking of valves, and the implication was that the lead was a "bad" thing. When I went to A&P school, oh those many years ago, I can recall that the reason for the lead was that there was some advantage to scavenging of exhaust gasses. Seeing that the addition of lead to gasoline was the norm for many decades, I can only assume that the lead was added for a reason, creating some advantage in engine performance. The old 100 octane aviation gasoline had much more lead than the modern 100LL. The "wizards of smart" that were responsible for such things must have had a good reason for leaving some lead in the 100LL. How can the little bit of lead that is now used be responsible for plug and valve problems, but for all those previous decades it was just fine and dandy? Anyone with an opinion, informed or not, please chime-in so I can be enlightened (or entertained at least) :O) Dan Helsper Puryear, TN. -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Subject: Lead on Skark plugs.
Date: Jun 22, 2011
I wish I had taken more pictures of all the "lead" I flaked out of the cylinders and out of these plugs. It filled the palm of my hand, twice! This is the result of a trip from Atlanta to Key West, Fl. One summer, Harold and I decided to fly to Key West, so off we went. Mike flew with me in the straight tail 150 and Paul rode along with Harold in his 100HP J3 Cub. On the trip I had to fly at 1900 to 2050 RPM to be able to fly beside the Cub. Normally I fly the Cessna at 2550 cruise. At this reduced setting, the engine never got up to operating temperature. We logged 25 hours of flying time on this trip over a 10 day period, but did not realize I was having a problem until about a month later. On landing at Huntsville, AL, I got 2 stuck valves on final at the airport. I got them unstuck and flew back home, but one valve stuck again when I reduced power at my home airport. I pulled the cylinders and cleaned about a half pint of chalky tan lead deposits out of the cylinders and had to really work on the spark plugs. Jump ahead 2 years - The first year that a couple of the Big Piets went to Sun n Fun, I flew the Cessna with spare parts and tools, just in case we had a problem. I had the same lead problem flying with the Piets. I had to fly at 1800 to 1900 RPM for 12 hours and got the same leading problem. this time I tried the "knock the valve into the cylinder" fix and everything is back to normal. (see article I wrote in the June Sport Aviation) So the moral of this story is: When the Cubs fly somewhere, I fly my Cub. When the Cessnas fly, I fly the Cessna, and for the Big Piets, same applies. Now I have no more lead fouling problems. Barry NX973BP ________________________________________________________________________________
Date: Jun 22, 2011
My brother has a Skyranger with 240 hours on the Rotax 912ULS running 93 octane with 10% ethanol with no problems to date. We can't find any gas without ethanol in it. The only difference we can tell between the non-ethanol and the 10% ethanol is it takes a little more per hour but not much more. He has been running the 10% ethanol since 2007. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343773#343773 ________________________________________________________________________________
Date: Jun 22, 2011
I didn't think you would catch on to my secret. Yes, the chickens have wings and wings create lift. That's why my plane climbs so well. Want to know another secret? If you remove the inspection plates from the bottom of the wings and then fly upside down, All the lift will fall out. Not good! Secrets are out. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343774#343774 ________________________________________________________________________________
Subject: Re: Lead on Skark plugs.
Date: Jun 22, 2011
Barry at that low of a power setting(1900 to 2050 RPM) you can lean your engine until it starts getting rough and push the mixture back in just far enough to smooth it up and really help with that problem. You can't hurt an engine at that low power. Just have to remember before landing to go back full rich in case of needing a go round. I spotted fish in a 150 Super Cub at just enough power to keep it airborne for hours at a time. It would gunk up like that if you didn't lean the heck out of it. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343777#343777 ________________________________________________________________________________
Subject: Corvair College #20
Date: Jun 22, 2011
This is a little late but I thought I would post anyway for those Corvair guys or those considering the Corvair engine. Early in the month I loaded my engine parts and drove some 650 miles to Corvair College #20 in hopes that I could assemble and run my engine. This was wishful thinking but the experience of attending was well worth it. I am reconverting an engine that came with a project and it was supposed to be ready to fly and actually had been run for 5 hrs static. I got wind of some things that had not been done so I decided to disassemble my engine and make some changes. I also saw the location of Corvair College #20 and decided it was happening about as close as I would find to my location, at least for the foreseeable future. My engine did not have a nitrided crank or forged pistons which was the main reason for me deciding to disassemble it. I want to add a pitch here. I found the name of Advanced Heat Treat Corp. on Mark Langford's website as a place that does nitriding. This is not the firm that William Wynn recommends but I decided to use them as they are a company with some 30 years of experience in the treatment of metals. They also had a competitive price. I sent them my crankshaft and picked it up at one of their facilities on my way to the CC#20. I cannot say enough good things about the way I was treated. They went out of their way to accomodate my situation and I was only getting one crank done by a facility that is set up to do production work for manufacturing. I even got a handwritten thank you for my business after I returned home. They would certainly be my choice again for magnafluxing and nitriding. Now some about the College. There were about 60 people there and I would say that there were 20 engines in various stages from disassembly to final running. I think 12 to 15 engines ran on the test stand. There were also flying examples of corvair powered aircraft there to look at and talk with the builders. The following are some of my thoughts. 1. The college did not include "lecture" sessions with handouts or diagrams but was very much a hands on workshop. That said I was glad I had my engine parts there to work on and I was not just an onlooker. One can get a lot out of watching, but the real value for me was actually working with the tools and getting a feel for what I was doing. 2. You will see a lot of different solution to the same problems so the opportunity to circulate around and talk to other builders is invaluable. One may have made up their mind on a particular part to buy or not to buy and the give and take with other builders is a big advantage. 3. There were 3 experts there and their time obviously got divided up among the various projects. At times is was necessary to be a little forward to get their attention, but doing so resulted in how to sessions that benefited the whole group. If you attend and see a group gathered go see what is going on. It likely will be something you will also need to do or have done. 4. There was a real sense of sharing of tools, parts, and expertise. My table mate was continually into my tool box and I was borrowing special tools from other tables. When I needed to start a particular phase the guy from the table next to me was there to show me the process as he had already done his. Parts that I had were used on other engines to get them on the test stand, and my table mate borrowed a whole starter assembly from another engine to get his on the test stand. 5. Some lasting friendship were created. I received 2 emails as soon as I got home from people I met inquiring about my return trip and with promised information. I got there the day before everything started and 5 of us who did not know each other went out to dinner together to get acquainted. 6. Food was good and no one went away hungry. 7. I enjoyed getting to know William Wynne, and Roy Szarafinski of Roy's Garageon on a more personal level which gave me a greater appreciation for their knowledge and mechanical skills. I now see them as being far more approachable for questions. Many people there had attended previous colleges, this was my first. If you are assembling a corvair engine or plan to consider one for your project then attending at least one Corvair College should be on your list. If anyone has particular question about my experience at this College, email me and I will be happy to respond. -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343783#343783 ________________________________________________________________________________
Date: Jun 22, 2011
I believe that was in response to scimitar props in general. A true scimitar prop does a lot of flexing and were used mainly on racers ba ck in the day. Modern scimitars are a semi- scimitars and more lasting. But I 'm not sure if they are more lasting than say your standard Sensenich. I have an email from cloud cars explaining this and I'll look it up and post it later today. Jeff Wilson N899WT St. Louis, MO Sent from my iPhone On Jun 22, 2011, at 8:28 AM, Michael Perez wrote: > I seem to remember a post a while back about these props having a "short l ife span". I don't remember any details other then the person was looking in to buying a new prop and said one draw back tothe Cloudcarse props was a sho rt life span. Anyone have details on this? > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Jun 22, 2011
Could someone explain to me the definition of "rather short life span"? Coming back into airplane flying that involves a propeller (it has been over 20 years since I consistently flew an aircraft with a propeller, and that one was metal), I have no real frame of reference. This discussion of the Scimitar prop has got me to thinkin' (a dangerous thing, to be sure). With a wooden prop, what are the indications that you are approaching the end of the prop's life span? I can imagine that there are preflight indications. Do indicators manifest themselves in flight? I certainly would hate to find out what it looks like AFTER the prop has exceeded its life span! What about metal or composite props? Does anyone fly composite or metal props on a Pietenpol? Thanks in advance for the information. -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343791#343791 ________________________________________________________________________________
Subject: Re: Corvair College #20
Date: Jun 22, 2011
Jon, Thanks for the really in depth description. Would it be advisable for someone without a Corvair to attend and just watch? Is an extra set of hands welcome if all I wanted to do was help someone with their project and learn a little at the same time? Thanks again. -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343792#343792 ________________________________________________________________________________
Date: Jun 22, 2011
NW Oklahoma all the stations have signs that say 100% Gasoline No ethanol. San Antonio, Texas you can't find ethanol free gas. ----- Original Message ----- From: Jerry Dotson <jdotson(at)centurylink.net> Date: Wednesday, June 22, 2011 10:11 Subject: Pietenpol-List: Re: Gasoline questions > > My brother has a Skyranger with 240 hours on the Rotax 912ULS running 93 octane with 10% ethanol with no problems to date. We can't find any gas > without ethanol in it. The only difference we can tell between the > non-ethanol and the 10% ethanol is it takes a little more per hour > but not much more. He has been running the 10% ethanol since 2007. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > wing, tailfeathers done, fuselage rolling > using Lycoming O-235 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=343773#343773 > > > > > > > > > > ________________________________________________________________________________
Subject: Osh - Brodhead
Date: Jun 22, 2011
Is anybody going up to OSH after Brodhead. It would be nice to a group fly thing like 2 years ago. I am going up on Sun am. if weather is good. Dick N. ________________________________________________________________________________
Subject: Re: Osh - Brodhead
Date: Jun 22, 2011
My family and I are going up, but we'll have to wave to you from Hwy 151. :-( -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343804#343804 ________________________________________________________________________________
Date: Jun 22, 2011
I am, but my Piet is still under construction, so it'll be in the yellow pl astic plane. But will still be drooling over the "real" planes Cheers Jon Apfelbaum (Glastar N767JA) -----Original Message----- From: Dick N <horzpool(at)goldengate.net> Sent: Wed, Jun 22, 2011 10:10 am Subject: Pietenpol-List: Osh - Brodhead Is anybody going up to OSH after Brodhead. It would be nice to a group fly thing like 2 years ago. I am going up on Sun am. if weather is good. Dick N. ________________________________________________________________________________
Date: Jun 22, 2011
Me too. And I think Matt Paxton will bring his new ship there after Brodhead. Randy Bush was talking about going as well, if we could get a group going. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dick N Sent: Wednesday, June 22, 2011 4:07 PM Subject: Pietenpol-List: Osh - Brodhead Is anybody going up to OSH after Brodhead. It would be nice to a group fly thing like 2 years ago. I am going up on Sun am. if weather is good. Dick N. ________________________________________________________________________________
Date: Jun 22, 2011
Subject: Cloud Car Scimitars
>From March of 2010 - In reply to the comments about our propellers' lifespan..... Before everyone goes into a panic, I'd like to clear up a possible misunder standing!!!! The Scimitars that we cut are NOT "true functioning" Scimitars. They are a "profile Scimitar" (basically like a club profile). All propeller blades will flex. A true functioning Scimitar is designed to flex a lot more than a conventio nal propeller, and along more of the blade span. On a true functioning Scim itar the lams are vertical instead of horizontal, so as to amplify the wood s flexing characteristics. This is not so with our Scimitars. Our lams are a conventional horizontal sandwich or stack, just like Senseni ch and others. The airfoil is cut the same also. There is a slight flexing at the tip, whi ch is common in all propellers, especially those with a blade sweep. I'm no t sure how someone came up with 500 hours.....all woods have different char acteristics and there is no way this could be applied in a concrete way. If any of you guys have knowledge of bow making/archery, especially long bows ...this might help to explain the different characteristics of wood elastic ity. You won't find us on the internet, we don't have a website, or advertise an y more. All of our business is by referral and word of mouth. If you have any questions or concerns, please contact me. Jay Anderson CLOUDCARS cloudcars(at)verizon.net 325-356-2810 ________________________________________________________________________________
Date: Jun 22, 2011
The main issue with short life span....is overthinking. There is no issue On Wed, Jun 22, 2011 at 1:12 PM, jarheadpilot82 wrote: > jarheadpilot82(at)hotmail.com> > > Could someone explain to me the definition of "rather short life span"? > Coming back into airplane flying that involves a propeller (it has been over > 20 years since I consistently flew an aircraft with a propeller, and that > one was metal), I have no real frame of reference. This discussion of the > Scimitar prop has got me to thinkin' (a dangerous thing, to be sure). > > With a wooden prop, what are the indications that you are approaching the > end of the prop's life span? I can imagine that there are preflight > indications. Do indicators manifest themselves in flight? I certainly would > hate to find out what it looks like AFTER the prop has exceeded its life > span! What about metal or composite props? Does anyone fly composite or > metal props on a Pietenpol? > > Thanks in advance for the information. > > -------- > Semper Fi, > > Terry > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=343791#343791 > > ________________________________________________________________________________
Date: Jun 22, 2011
You guys are making me want to just burn all my vacation time and go to OSH too! Hmmmm... decisions...decisions! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343841#343841 ________________________________________________________________________________
Date: Jun 22, 2011
Don Emch wrote: > You guys are making me want to just burn all my vacation time and go to OSH too! Hmmmm... decisions...decisions! > > Don Emch > NX899DE I'm burning most of mine... let's all go! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343844#343844 ________________________________________________________________________________
Subject: engine mounted
Date: Jun 22, 2011
i've watched Dan's flying video 50 times i'm sure....i'm jealous so i set my engine in place today after painting the intake and making a wedge for the carb out of aluminum instead of cutting the intake itself.... makes it look closer to done jeff in stormy louisville Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343850#343850 Attachments: http://forums.matronics.com//files/carb_135.jpg http://forums.matronics.com//files/engine_181.jpg ________________________________________________________________________________
Subject: clipped wing Stinson takeoff (off topic, but educational)
Date: Jun 22, 2011
It's a 108-3=2C with an 6A4-165-B3 Franklin in it. Go to http://tinyurl.com/3hx847q A short=2C but instructional=2C video concerning planning your takeoff. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford=2C OR (soon to be Eagle Point=2C Oregon) website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jun 22, 2011
There were 60 people in attendance and only 20 engines. Many were only lookers. If you wanted to team up with someone I am sure your help would be welcomed. Get there early and look for someone who is disassembling an engine or has lots of parts. They will be the ones that need the most help. Just ask if you can help for the experience. If you could do that I think the experience would be more beneficial. I am a hands on person and I retain more if I can actually do some work. One thing I failed to mention was that discussion of politics and religion were off limits. I thought that was a real breath of fresh air. -------- Jon Coxwell GN-1 Builder Recycle and preserve the planet Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343858#343858 ________________________________________________________________________________
Subject: Brodhead fuel status?
Date: Jun 23, 2011
What is the status of fuel availability at Brodhead this year? Greg C. ________________________________________________________________________________
Subject: Re: engine mounted
Date: Jun 22, 2011
Beautiful......! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343861#343861 ________________________________________________________________________________
Subject: Re: clipped wing Stinson takeoff (off topic, but educational)
Date: Jun 23, 2011
I don't believe it! This is Raven Field, in the CFS ( Canada Flight Suppliment) as Quamichan Lake. Field elevation is only 130' and runway length is 1800'. This is Southern Vancouver Island, BC. The owner is John Howroyd. John's dad built Pietenpol CF-AOG in '32. http://www.ourairports.com/airports/CML2/ http://www.flyronline.com/airport/cml2.html It's a 108-3, with an 6A4-165-B3 Franklin in it. Go to http://tinyurl.com/3hx847q A short, but instructional, video concerning planning your takeoff.. Oscar Zuniga ________________________________________________________________________________
Date: Jun 23, 2011
Mine are a little different. They're internally mounted to prevent flutter at the high speeds. Kind of the ping pong ball effect. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343874#343874 ________________________________________________________________________________
Date: Jun 23, 2011
Amazing what one misspelled word will do to us. I think we are all a little sick. Must go flying to cure it. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343878#343878 ________________________________________________________________________________
Date: Jun 23, 2011
Its a Tillotson model X carb... an aftermarket A carb.. i have a Marvel atermarket carb too... they are both aluminum..or pot metal, a lot lighter than the Zenith A or B i figured i'd try all the carbs i had.. i have a Zenith on the AA truck that would fly just fine too Walt Bowe has a wedge in his too... i was looking at photos of his plane and picked it out.. looks like he has a tillotson carb..or a marvel.. not sure i know they are both popular for "drivers" not show cars i set the engine up there thinking about weather or not to cut the crank and water pump down.. it looks good so i'm leaving them stock.. i have a water pump housing painted ready for new parts... i have a local place called the Old Car Parts House... the guy just deals in A and T parts.. its a great resource... and the guy knows a lot its easy to run to his place and pick up parts jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343893#343893 ________________________________________________________________________________
Subject: Ethanol free gas station
Date: Jun 23, 2011
On a more serious note have a look at this link. It may be useful to some. http://pure-gas.org/index.jsp -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343907#343907 ________________________________________________________________________________
Subject: Re: Brodhead fuel status?
Date: Jun 23, 2011
Greg, According to the BPA website, fuel (100LL and ethanol-free Auto fuel) will be available. http://pietenpols.org/id12.html Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343923#343923 ________________________________________________________________________________
Date: Jun 23, 2011
The dearth of discussion about politics and religion is one of the endearing things about this board too. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343938#343938 ________________________________________________________________________________
Date: Jun 23, 2011
Thanks, again, Jon for all of the insight. -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343939#343939 ________________________________________________________________________________
Subject: Brodhead fuel status and fly-by patterns
Date: Jun 24, 2011
Good link, Bill. And for anyone interested, attached are pdf's of the fly-by patterns. Greg Cardinal > > > Greg, > According to the BPA website, fuel (100LL and ethanol-free Auto fuel) will > be available. > > http://pietenpols.org/id12.html > > Bill C. ________________________________________________________________________________
Subject: Re: Brodhead fuel status and fly-by patterns
Date: Jun 24, 2011
Thanks Greg! -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Jun 24, 2011, at 7:09 AM, "Greg Cardinal" wrote: > Good link, Bill. > > And for anyone interested, attached are pdf's of the fly-by patterns. > > Greg Cardinal > > >> >> Greg, >> According to the BPA website, fuel (100LL and ethanol-free Auto fuel) will be available. >> >> http://pietenpols.org/id12.html >> >> Bill C. > > ________________________________________________________________________________
Subject: wing spar dimensioms
Date: Jun 24, 2011
Can someone give me the spar dimension on the three piece wing. Specifically width. Does 3/4" sound right? I'm on a trip and can't Get to my drawings. Scott Read this topic online here: http://forums.matronics.com/viewtopic.php?p=343983#343983 ________________________________________________________________________________
Subject: Re: wing spar dimensioms
Date: Jun 24, 2011
3/4" x 4 3/4 iirc. -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Jun 24, 2011, at 8:20 AM, "Saver" wrote: > > Can someone give me the spar dimension on the three piece wing. > Specifically width. Does 3/4" sound right? I'm on a trip and can't > Get to my drawings. > Scott > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=343983#343983 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 24, 2011
Thanks Dan. So far we can only locate the 3/4 dimension For the center section spars. 1" for main wing spars. Scott Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344031#344031 ________________________________________________________________________________
Subject: Re: a little Friday humor
Date: Jun 25, 2011
that has to be one my all time favorites! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344052#344052 ________________________________________________________________________________
Date: Jun 25, 2011
Bernard recommended routing out the 1" to 3/4" essentially creating an I-beam. The Cub had a 3/4" spar, so that is probably a safe bet to go with. -- Dan Yocum yocum137(at)gmail.com "I fly because it releases my mind from the tyranny of petty things." On Jun 24, 2011, at 6:00 PM, "Saver" wrote: > > Thanks Dan. So far we can only locate the 3/4 dimension > For the center section spars. 1" for main wing spars. > Scott > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344031#344031 > > > > > > > > > > ________________________________________________________________________________
Subject: Corvair ignitions
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Jun 25, 2011
For you crank snappers out there. just wondering if some of you are running the distributor with the electronic pickup on one side W/W sells now. I have been having a big problem getting my 2 sets of points balanced to fire at the same degree advance on mine. I sent it back to him and have one of the new style distributors coming next week. but i am still running this Grand Rapids EIS in the panel that DJ installed. initially it was giving fairly decent readings on the one coil it is connected to but the last time or two I flew it after messing with the gaps to get the timing closer it was way off. I plan on connecting the electronic pickup to the EIS and maybe an electronic tach after getting it in. leaving the other point side clean with nothing else on it but the coil,condenser and ballast resistor.I'm just wondering if anybody else had any problems installing this style ignition pickup and any solutions if you did. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344101#344101 ________________________________________________________________________________
Date: Jun 25, 2011
Weather permitting - I'd also like to make my first flying trip to Osh this year. Was going to fly to Brodhead anyway. Was hoping to see a thread like this pop up. Lorin Miller -------- Lorin Miller Waiex N81YX GN-1 N30PP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344107#344107 ________________________________________________________________________________
Date: Jun 25, 2011
Subject: Re: Building my first wing rib - the journey begins
Sorry this response is a little late, but I've been gone awhile. One of the best articles about rib building is by Tony Bingelis in the "Sportplane Builder" column in the February, 1994 issue of Sport Aviation. It contains the illustration about possible ways to cut the rib pieces. It contains a lot of info about rib building which is not in his main books. I found it the most useful source when I was building my ribs. The old SA articles are available to all EAA members at the Oshkosh 365 website. John Fay in Peoria ________________________________________________________________________________
Subject: Re: Corvair ignitions
Date: Jun 26, 2011
Raymond, You should post this on the Corvair list: corvaircraft(at)mylist.net. Gary BTW - DJ sends best wishes... -----Original Message----- From: skellytown flyer Sent: Saturday, June 25, 2011 7:34 PM Subject: Pietenpol-List: Corvair ignitions For you crank snappers out there. just wondering if some of you are running the distributor with the electronic pickup on one side W/W sells now. I have been having a big problem getting my 2 sets of points balanced to fire at the same degree advance on mine. I sent it back to him and have one of the new style distributors coming next week. but i am still running this Grand Rapids EIS in the panel that DJ installed. initially it was giving fairly decent readings on the one coil it is connected to but the last time or two I flew it after messing with the gaps to get the timing closer it was way off. I plan on connecting the electronic pickup to the EIS and maybe an electronic tach after getting it in. leaving the other point side clean with nothing else on it but the coil,condenser and ballast resistor.I'm just wondering if anybody else had any problems installing this style ignition pickup and any solutions if you did. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344101#344101 ________________________________________________________________________________
Date: Jun 26, 2011
Here's a quick link to the article. http://www.oshkosh365.org/saarchive/eaa_articles/1994_02_24.pdf See y'all at Brodhead! Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344123#344123 ________________________________________________________________________________
Date: Jun 26, 2011
I may. got an email from him this morning. sent a couple poor pictures I had. I still don't have a good picture of it I am sure hoping this ridiculously hot windy weather will ease up this summer so I can fly once I got the distributor issue settled.it's supposed to be 105 again today. winds only about 20 now- 45 degrees to the runway but they are supposed to blow a lot more later on.guess it's just as well I am not ready to fly anyway-I'd just be frustrated and wondering whether to risk it or not. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344124#344124 ________________________________________________________________________________
Date: Jun 26, 2011
john and Curt, Thanks for the additional info. I did download the article to keep for future reference. I really appreciate all of the support provided by this Forum. See you in Brodhead! -------- Semper Fi, Terry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344129#344129 ________________________________________________________________________________
Date: Jun 26, 2011
Ramond, We are running the electronic/points distributer.- Ours is a wynn e distributer, and the 2 diferent ignition systems are not timed dead on wi th each other.- It is not much of a concern to me, the points are strictl y for backup only.- It will run to full power on either system, the idle speed is some what off between the 2 systems due to the timing being a-co uple of -degrees different.- - Shad- --- On Sun, 6/26/11, Gary Boothe wrote: From: Gary Boothe <gboothe5(at)comcast.net> Subject: Re: Pietenpol-List: Corvair ignitions Date: Sunday, June 26, 2011, 9:46 AM Raymond, You should post this on the Corvair list:- corvaircraft(at)mylist.net. Gary BTW - DJ sends best wishes... -----Original Message----- From: skellytown flyer Sent: Saturday, June 25, 2011 7:34 PM Subject: Pietenpol-List: Corvair ignitions .com> For you crank snappers out there. just wondering if some of you are running the distributor with the electronic pickup on one side W/W sells now. I ha ve been having a big problem getting my 2 sets of points balanced to fire a t the same degree advance on mine. I sent it back to him and have one of th e new style distributors coming next week. but i am still running this Gran d Rapids EIS in the panel that DJ installed. initially it was giving fairly decent readings on the one coil it is connected to but the last time or tw o I flew it after messing with the gaps to get the timing closer it was way off. I plan on connecting the electronic pickup to the EIS and maybe an el ectronic tach after getting it in. leaving the other point side clean with nothing else on it but the coil,condenser and ballast resistor.I'm just won dering if anybody else had any problems installing this style ignition pick up and any solutions if you did. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344101#344101 le, List Admin. ________________________________________________________________________________
Date: Jun 26, 2011
i just added a set of points to a mallory model a distributor and noticed the slight difference in timing and had the thought of one just being a backup so it would be ok i'm sure.. dual points distributors are made that way on purpose.. to get more dwell when running both sets to one coil i planned on the more advanced set being the backup... making starting easier.. i set the gap slightly less on the backup points... to get the timing closer.. still in tolorance but not in the middle of the range jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344141#344141 ________________________________________________________________________________
Date: Jun 26, 2011
COOL-JIM ----- Original Message ----- From: "coxwelljon" <coxwelljon(at)frontiernet.net> Sent: Thursday, June 23, 2011 12:20 AM Subject: Pietenpol-List: Re: Corvair College #20 > > > There were 60 people in attendance and only 20 engines. Many were only > lookers. If you wanted to team up with someone I am sure your help would > be welcomed. Get there early and look for someone who is disassembling an > engine or has lots of parts. They will be the ones that need the most > help. Just ask if you can help for the experience. If you could do that > I think the experience would be more beneficial. I am a hands on person > and I retain more if I can actually do some work. > > One thing I failed to mention was that discussion of politics and religion > were off limits. I thought that was a real breath of fresh air. > > -------- > Jon Coxwell > GN-1 Builder > Recycle and preserve the planet > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=343858#343858 > > > ________________________________________________________________________________
Date: Jun 26, 2011
Well per W/W's instructions I messed with mine by shifting the mount plate to the side some as it is loose enough on the screws it can be shifted some plus played with the gap.not having his distributor machine or patience I even devised a shadetree method of my own. I glued a couple small pieces of thin paper to a rubber band and put them in the points and held slight tension on it and rotated the shaft till they would release.got it to where they were close to the same- but still one set the timing mark would hunt fairly bad. I wondered if i had a bad cam lobe -could'nt find any real slop in the shaft. anyway I hope for better luck now. I am not satisfied with either the Datcon tach or the EIS. both were giving bad readings. again maybe bouncing points ? I contacted Mark Langford and he sent me a link to his site telling how he put a 27K ohm resistor in the circuit and it solved his problem.I do not have the manual for the EIS- have to guess that he meant in the coil- pickup wire and try it I guess. if I could find a decent electronic tach that worked properly I would soon remove the EIS. not because the info isn't valuable. but I have a mechanical oil gage and have satisfied my temps are good and not running any mixture control- that is wired full rich on the old Strombergh I don't think it's likely to go lean unless something breaks.and it just ain't natural in a Piet or wanna be Piet panel.th temp hit 111 here as I was coming back from town a little while ago. will likely be too hot to fly anyway today. may take a nap. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344143#344143 ________________________________________________________________________________
Date: Jun 26, 2011
Subject: Corvair Engine
Fellow Pieters: - I have a complete Corvair Engine removed from a working Corvair vehicle las t year. It is everything according to WIlliam Wynne rebuild book. I am inte rested in selling this motor for $600.00 to anyone on the list. Please cont act me off list if interested. The motor is complete and needs to be tron d own and rebuilt into an aircraft engine. - KMHeide ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Subject: Clevis
Date: Jun 26, 2011
I have a question for the forum. Anyone who wants to please chime in. I have 14 clevises (is that the correct plural?) to use at various places in the control system. Problem: some of the clevises will have a turnbuckle fork attach to it. The Clevis is 0.185 inch thick and the turnbuckle fork slot is only 0.156 inch. Would it be OK with the inspector if I ground down the clevis until the fork would go over it? According to my handy dandy calculator I would have to grind off about 0.03 inch for the fork to go on the clevis. Comments? Chuck ________________________________________________________________________________
Subject: Re: Corvair Engine
Date: Jun 26, 2011
SSBib3VnaHQgYSBjb21wbGV0ZSBydW5uaW5nIGNvcnZhaXIgd2l0aCBhbGwgdGhlIHJpZ2h0IG51 bWJlcnMuLi4uY2FyYnMuLi5zdGFydGVyLi5leGhhdXN0IGxvZ3MgZm9yICQxNTAuIFR1cm5lZCBh cm91bmQgYW5kIHNvbGQgdGhlIGNhcmJzIGFuZCBzdGFydGVyIG9uIGVCYXkuDQogDQoNCkZyb206 IFJ5YW4gTXVlbGxlciBbbWFpbHRvOnJtdWVsbGVyMjNAZ21haWwuY29tXSANClNlbnQ6IFN1bmRh eSwgSnVuZSAyNiwgMjAxMSAwMzo1MCBQTQ0KVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5j b20gPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+IA0KU3ViamVjdDogUmU6IEZ3OiBQaWV0 ZW5wb2wtTGlzdDogQ29ydmFpciBFbmdpbmUgDQogDQoNCkknZCBnaXZlIHlvdSBoYWxmIHRoYXQu Li4uaWYgSSB3YXMgbG9va2luZy4uLi4gIDpQDQoNClJ5YW4NCg0KZG8gbm90IGFyY2hpdmUNCg0K T24gU3VuLCBKdW4gMjYsIDIwMTEgYXQgMjoxNCBQTSwgS00gSGVpZGUgQ1BPL0ZBQU9QIDxrbWhl aWRlY3BvQHlhaG9vLmNvbT4gd3JvdGU6DQoNCg0KRmVsbG93IFBpZXRlcnM6DQogDQpJIGhhdmUg YSBjb21wbGV0ZSBDb3J2YWlyIEVuZ2luZSByZW1vdmVkIGZyb20gYSB3b3JraW5nIENvcnZhaXIg dmVoaWNsZSBsYXN0IHllYXIuIEl0IGlzIGV2ZXJ5dGhpbmcgYWNjb3JkaW5nIHRvIFdJbGxpYW0g V3lubmUgcmVidWlsZCBib29rLiBJIGFtIGludGVyZXN0ZWQgaW4gc2VsbGluZyB0aGlzIG1vdG9y IGZvciAkNjAwLjAwIHRvIGFueW9uZSBvbiB0aGUgbGlzdC4gUGxlYXNlIGNvbnRhY3QgbWUgb2Zm IGxpc3QgaWYgaW50ZXJlc3RlZC4gVGhlIG1vdG9yIGlzIGNvbXBsZXRlIGFuZCBuZWVkcyB0byBi ZSB0cm9uIGRvd24gYW5kIHJlYnVpbHQgaW50byBhbiBhaXJjcmFmdCBlbmdpbmUuDQogDQpLTUhl aWRlDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBQaWV0ZW5wb2wtTGlzdCBF bWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0 b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVu L1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93 c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0N Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1M aXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1T IC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9y dW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0g IFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0K ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 26, 2011
Chuck, You shouldn't have to do any grinding of terminals to make them fit. It sounds like you may be mismatching hardware. Here are a couple of pdf's of cable terminal fittings that may help you sort out what you need. http://www.gen-aircraft-hardware.com/images/pdf/an115_ms20115.pdf http://www.gen-aircraft-hardware.com/images/pdf/cable%20fittings.pdf Greg Cardinal ----- Original Message ----- From: Charles Campbell To: pietenpol-list(at)matronics.com Sent: Sunday, June 26, 2011 3:07 PM Subject: Pietenpol-List: Clevis I have a question for the forum. Anyone who wants to please chime in. I have 14 clevises (is that the correct plural?) to use at various places in the control system. Problem: some of the clevises will have a turnbuckle fork attach to it. The Clevis is 0.185 inch thick and the turnbuckle fork slot is only 0.156 inch. Would it be OK with the inspector if I ground down the clevis until the fork would go over it? According to my handy dandy calculator I would have to grind off about 0.03 inch for the fork to go on the clevis. Comments? Chuck ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Greg, I guess my original problem is that I didn't know that the data like that you sent is even available. I ordered cable shackles from ACS and all they listed was the AN# for 3/32 cable, use AN# thimble, and AN# Clevis pin -- no other dimensions. Same for turnbuckle forks. Until I spent my money and received the parts did I know that the two would not fit together. Oh well, I guess if I don't get any other posts, I'll just make do. ----- Original Message ----- From: Greg Cardinal To: pietenpol-list(at)matronics.com Sent: Monday, June 27, 2011 12:47 AM Subject: Re: Pietenpol-List: Clevis Chuck, You shouldn't have to do any grinding of terminals to make them fit. It sounds like you may be mismatching hardware. Here are a couple of pdf's of cable terminal fittings that may help you sort out what you need. http://www.gen-aircraft-hardware.com/images/pdf/an115_ms20115.pdf http://www.gen-aircraft-hardware.com/images/pdf/cable%20fittings.pdf Greg Cardinal ----- Original Message ----- From: Charles Campbell To: pietenpol-list(at)matronics.com Sent: Sunday, June 26, 2011 3:07 PM Subject: Pietenpol-List: Clevis I have a question for the forum. Anyone who wants to please chime in. I have 14 clevises (is that the correct plural?) to use at various places in the control system. Problem: some of the clevises will have a turnbuckle fork attach to it. The Clevis is 0.185 inch thick and the turnbuckle fork slot is only 0.156 inch. Would it be OK with the inspector if I ground down the clevis until the fork would go over it? According to my handy dandy calculator I would have to grind off about 0.03 inch for the fork to go on the clevis. Comments? Chuck href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 27, 2011
Subject: Re: Clevis
Maybe ACS messed up the order? It seems odd that if the parts are all for one size cable, that there are fitting issues. Michael Perez Karetaker Aero www.karetakeraero.com --- On Mon, 6/27/11, Charles Campbell wrote: > From: Charles Campbell <cncampbell(at)windstream.net> > Subject: Re: Pietenpol-List: Clevis > To: pietenpol-list(at)matronics.com > Date: Monday, June 27, 2011, 8:26 AM > > > > > > > > Greg, I guess my original > problem is that I didn't > know that thedata like that you sent is even > available. I ordered > cable shackles from ACS and all they listed was the AN# for > 3/32 cable, use AN# > thimble, and AN# Clevis pin -- no other dimensions. > Same for turnbuckle > forks. Until I spent my money and received the parts > did I know that the > two would not fit together. Oh well, I guess if I > don't get any other > posts, I'll just make do. > > ----- Original Message > ----- > From: > Greg > Cardinal > To: pietenpol-list(at)matronics.com > > > Sent: Monday, June > 27, 2011 12:47 > AM > Subject: Re: > Pietenpol-List: Clevis > > > Chuck, > > You shouldn't have to do any > grinding of terminals to > make them fit. It sounds like you may be mismatching > hardware. > Hereare a couple of > pdf's of cable terminal > fittings that may help you sort out what you > need. > > http://www.gen-aircraft-hardware.com/images/pdf/an115_ms20115.pdf > http://www.gen-aircraft-hardware.com/images/pdf/cable%20fittings.pdf > > Greg Cardinal > > ----- Original Message > ----- > From: > Charles > Campbell > To: pietenpol-list(at)matronics.com > > > Sent: Sunday, June > 26, 2011 3:07 > PM > Subject: > Pietenpol-List: Clevis > > > I have a question for > the forum. Anyone > who wants to please chime in. > > I have 14 clevises (is > that the correct > plural?) to use at various places in the control > system. > Problem: some of the clevises will have a > turnbuckle fork attach to > it. The Clevis is 0.185 inch thick and the > turnbuckle fork slot is > only 0.156 inch. Would it be OK with the > inspector if I ground down > the clevis until the fork would go over it? > According to my handy > dandy calculator I would have to grind off about 0.03 > inch for the fork to > go on the clevis. Comments? > Chuck > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2011
Subject: Re: Clevis
It sounds like something is wrong with that order.I got the wrong type of aluminum for a gyro plane mast from a reputable company .The stock I received should not have been in the warehouse.These things happen.At the very least I'd call them and speak to some one who is very familiar with the hardware.Or find someone else like an A&P or someone from the EAA. AT the very worst you may meet some nice people.I've worked on a lot of hang gliders and few aircraft people are going to fault you for being very cautious with cable and hardware. On Mon, Jun 27, 2011 at 7:05 AM, Michael Perez wrote: > speedbrake(at)sbcglobal.net> > > Maybe ACS messed up the order? It seems odd that if the parts are all for > one size cable, that there are fitting issues. > > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > > --- On Mon, 6/27/11, Charles Campbell wrote: > > > From: Charles Campbell <cncampbell(at)windstream.net> > > Subject: Re: Pietenpol-List: Clevis > > To: pietenpol-list(at)matronics.com > > Date: Monday, June 27, 2011, 8:26 AM > > > > > > > > > > > > > > > > Greg, I guess my original > > problem is that I didn't > > know that the data like that you sent is even > > available. I ordered > > cable shackles from ACS and all they listed was the AN# for > > 3/32 cable, use AN# > > thimble, and AN# Clevis pin -- no other dimensions. > > Same for turnbuckle > > forks. Until I spent my money and received the parts > > did I know that the > > two would not fit together. Oh well, I guess if I > > don't get any other > > posts, I'll just make do. > > > > ----- Original Message > > ----- > > From: > > Greg > > Cardinal > > To: pietenpol-list(at)matronics.com > > > > > > Sent: Monday, June > > 27, 2011 12:47 > > AM > > Subject: Re: > > Pietenpol-List: Clevis > > > > > > Chuck, > > > > You shouldn't have to do any > > grinding of terminals to > > make them fit. It sounds like you may be mismatching > > hardware. > > Here are a couple of > > pdf's of cable terminal > > fittings that may help you sort out what you > > need. > > > > http://www.gen-aircraft-hardware.com/images/pdf/an115_ms20115.pdf > > http://www.gen-aircraft-hardware.com/images/pdf/cable%20fittings.pdf > > > > Greg Cardinal > > > > ----- Original Message > > ----- > > From: > > Charles > > Campbell > > To: pietenpol-list(at)matronics.com > > > > > > Sent: Sunday, June > > 26, 2011 3:07 > > PM > > Subject: > > Pietenpol-List: Clevis > > > > > > I have a question for > > the forum. Anyone > > who wants to please chime in. > > > > I have 14 clevises (is > > that the correct > > plural?) to use at various places in the control > > system. > > Problem: some of the clevises will have a > > turnbuckle fork attach to > > it. The Clevis is 0.185 inch thick and the > > turnbuckle fork slot is > > only 0.156 inch. Would it be OK with the > > inspector if I ground down > > the clevis until the fork would go over it? > > According to my handy > > dandy calculator I would have to grind off about 0.03 > > inch for the fork to > > go on the clevis. Comments? > > Chuck > > > > href="http://www.matronics.com/Navigator?Pietenpol-List"> > http://www.matronics.com/Navigator?Pietenpol-List > > href="http://forums.matronics.com">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > > > href="http://www.matronics.com/Navigator?Pietenpol-List"> > http://www.matronics.com/Navigator?Pietenpol-List > > href="http://forums.matronics.com">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Charles What exactly are you trying to do? Which part of the controls are you trying to hook up? How about a diagram of what youre trying to accomplish? Please dont just make do. Something you are trying to do just doesnt sound correct. To me it sounds like your trying to connect two forked ends together which you shouldnt do. Fork ends (turnbuckle end or shackle) should go over a solid tab. If youre trying to attach a cable to a turnbuckle, use turnbuckle end fittings for connecting a cable directly to the turnbuckle. If you must connect two fork ends together, make a short connector out of metal with holes in both ends. Chris -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344272#344272 ________________________________________________________________________________
Date: Jun 27, 2011
Subject: Re: Clevis
By any chance do you have the Bingelis books....maybe a copy of A/C 43.13? You can even download AC 43.13 for free: http://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentid/99861 Although the print version is eminently more useful. Better to acquire the knowledge to know how to do things the right way instead of just "making do" with the wrong parts. Ryan On Mon, Jun 27, 2011 at 7:26 AM, Charles Campbell wrote: > ** > Greg, I guess my original problem is that I didn't know that the data like > that you sent is even available. I ordered cable shackles from ACS and all > they listed was the AN# for 3/32 cable, use AN# thimble, and AN# Clevis pin > -- no other dimensions. Same for turnbuckle forks. Until I spent my money > and received the parts did I know that the two would not fit together. Oh > well, I guess if I don't get any other posts, I'll just make do. > > ----- Original Message ----- > *From:* Greg Cardinal > *To:* pietenpol-list(at)matronics.com > *Sent:* Monday, June 27, 2011 12:47 AM > *Subject:* Re: Pietenpol-List: Clevis > > Chuck, > > You shouldn't have to do any grinding of terminals to make them fit. It > sounds like you may be mismatching hardware. > Here are a couple of pdf's of cable terminal fittings that may help you > sort out what you need. > > http://www.gen-aircraft-hardware.com/images/pdf/an115_ms20115.pdf > http://www.gen-aircraft-hardware.com/images/pdf/cable%20fittings.pdf > > Greg Cardinal > > ----- Original Message ----- > *From:* Charles Campbell > *To:* pietenpol-list(at)matronics.com > *Sent:* Sunday, June 26, 2011 3:07 PM > *Subject:* Pietenpol-List: Clevis > > I have a question for the forum. Anyone who wants to please chime in. > > I have 14 clevises (is that the correct plural?) to use at various places > in the control system. Problem: some of the clevises will have a > turnbuckle fork attach to it. The Clevis is 0.185 inch thick and the > turnbuckle fork slot is only 0.156 inch. Would it be OK with the inspector > if I ground down the clevis until the fork would go over it? According to > my handy dandy calculator I would have to grind off about 0.03 inch for the > fork to go on the clevis. Comments? Chuck > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Chris, My scanner is acting up so I can't send you a drawing of what I'm trying to do. If you have a set of Aircamper plans look on the one showing the cockpit controls. There is a clevis at each side of the rear control stick with a cable attached to each -- that one I can do. Now look at the elevator control bellcrank. There are four clevises attached to the bellcrank. The drawing shows the cables connecting directly to the clevises but there must be a turnbuckle in each cable. The fork end of the turnbuckle would have to attach to the clevis, top and bottom. On my turnbuckle fork the space between the 'tines' is only 0.150 inch. The diameter of the clevis is 0.185 inch. Thus, I would have to grind down the .185 dimension to less than 0.15 inch for the two to work together. Capish? Hope I am clearer than mud! Chuck ----- Original Message ----- From: "Catdesigns" <Catdesigns(at)att.net> Sent: Monday, June 27, 2011 2:55 PM Subject: Pietenpol-List: Re: Clevis > > Charles > > What exactly are you trying to do? Which part of the controls are you > trying to hook up? How about a diagram of what you?Tre trying to > accomplish? Please don?Tt just make do. Something you are trying to do > just doesn?Tt sound correct. > > To me it sounds like your trying to connect two forked ends together which > you shouldn?Tt do. Fork ends (turnbuckle end or shackle) should go over a > solid tab. If you?Tre trying to attach a cable to a turnbuckle, use > turnbuckle end fittings for connecting a cable directly to the turnbuckle. > If you must connect two fork ends together, make a short connector out of > metal with holes in both ends. > > > Chris > > -------- > Chris > Sacramento, CA > WestCoastPiet.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344272#344272 > > > ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
The link sent me to 43.13 1B in which I could not find anything about clevises and turnbuckles. ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Monday, June 27, 2011 3:36 PM Subject: Re: Pietenpol-List: Clevis By any chance do you have the Bingelis books....maybe a copy of A/C 43.13? You can even download AC 43.13 for free: http://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/d ocument.information/documentid/99861 Although the print version is eminently more useful. Better to acquire the knowledge to know how to do things the right way instead of just "making do" with the wrong parts. Ryan On Mon, Jun 27, 2011 at 7:26 AM, Charles Campbell wrote: Greg, I guess my original problem is that I didn't know that the data like that you sent is even available. I ordered cable shackles from ACS and all they listed was the AN# for 3/32 cable, use AN# thimble, and AN# Clevis pin -- no other dimensions. Same for turnbuckle forks. Until I spent my money and received the parts did I know that the two would not fit together. Oh well, I guess if I don't get any other posts, I'll just make do. ----- Original Message ----- From: Greg Cardinal To: pietenpol-list(at)matronics.com Sent: Monday, June 27, 2011 12:47 AM Subject: Re: Pietenpol-List: Clevis Chuck, You shouldn't have to do any grinding of terminals to make them fit. It sounds like you may be mismatching hardware. Here are a couple of pdf's of cable terminal fittings that may help you sort out what you need. http://www.gen-aircraft-hardware.com/images/pdf/an115_ms20115.pdf http://www.gen-aircraft-hardware.com/images/pdf/cable%20fittings.pdf Greg Cardinal ----- Original Message ----- From: Charles Campbell To: pietenpol-list(at)matronics.com Sent: Sunday, June 26, 2011 3:07 PM Subject: Pietenpol-List: Clevis I have a question for the forum. Anyone who wants to please chime in. I have 14 clevises (is that the correct plural?) to use at various places in the control system. Problem: some of the clevises will have a turnbuckle fork attach to it. The Clevis is 0.185 inch thick and the turnbuckle fork slot is only 0.156 inch. Would it be OK with the inspector if I ground down the clevis until the fork would go over it? According to my handy dandy calculator I would have to grind off about 0.03 inch for the fork to go on the clevis. Comments? Chuck href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Chuck - You can put extension tabs on the elevator bellcrank holes. Bend them out slightly and everything will clear just fine. Kevin -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344282#344282 ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
By 'making do' I meant that I won't use the clevises that I have -- I'll make up something else. ----- Original Message ----- From: Ryan Mueller To: pietenpol-list(at)matronics.com Sent: Monday, June 27, 2011 3:36 PM Subject: Re: Pietenpol-List: Clevis By any chance do you have the Bingelis books....maybe a copy of A/C 43.13? You can even download AC 43.13 for free: http://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/d ocument.information/documentid/99861 Although the print version is eminently more useful. Better to acquire the knowledge to know how to do things the right way instead of just "making do" with the wrong parts. Ryan On Mon, Jun 27, 2011 at 7:26 AM, Charles Campbell wrote: Greg, I guess my original problem is that I didn't know that the data like that you sent is even available. I ordered cable shackles from ACS and all they listed was the AN# for 3/32 cable, use AN# thimble, and AN# Clevis pin -- no other dimensions. Same for turnbuckle forks. Until I spent my money and received the parts did I know that the two would not fit together. Oh well, I guess if I don't get any other posts, I'll just make do. ----- Original Message ----- From: Greg Cardinal To: pietenpol-list(at)matronics.com Sent: Monday, June 27, 2011 12:47 AM Subject: Re: Pietenpol-List: Clevis Chuck, You shouldn't have to do any grinding of terminals to make them fit. It sounds like you may be mismatching hardware. Here are a couple of pdf's of cable terminal fittings that may help you sort out what you need. http://www.gen-aircraft-hardware.com/images/pdf/an115_ms20115.pdf http://www.gen-aircraft-hardware.com/images/pdf/cable%20fittings.pdf Greg Cardinal ----- Original Message ----- From: Charles Campbell To: pietenpol-list(at)matronics.com Sent: Sunday, June 26, 2011 3:07 PM Subject: Pietenpol-List: Clevis I have a question for the forum. Anyone who wants to please chime in. I have 14 clevises (is that the correct plural?) to use at various places in the control system. Problem: some of the clevises will have a turnbuckle fork attach to it. The Clevis is 0.185 inch thick and the turnbuckle fork slot is only 0.156 inch. Would it be OK with the inspector if I ground down the clevis until the fork would go over it? According to my handy dandy calculator I would have to grind off about 0.03 inch for the fork to go on the clevis. Comments? Chuck href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Chuck, Here's a photo showing how I handled this area (for purposes of this discussion, ignore the spring driven trim system): If you look closely you can see that where the turnbuckles attach I made a pair of joggled straps of .062=94 4130 which fit into the fork end of the turnbuckles and fit around the bellcrank. You=92re right, the plans don=92t mention this, but it has to be done somehow. This is one way to do it. Jack Phillips NX899JP =93Icarus Plummet=94 Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Monday, June 27, 2011 4:03 PM Subject: Re: Pietenpol-List: Re: Clevis Chris, My scanner is acting up so I can't send you a drawing of what I'm trying to do. If you have a set of Aircamper plans look on the one showing the cockpit controls. There is a clevis at each side of the rear control stick with a cable attached to each -- that one I can do. Now look at the elevator control bellcrank. There are four clevises attached to the bellcrank. The drawing shows the cables connecting directly to the clevises but there must be a turnbuckle in each cable. The fork end of the turnbuckle would have to attach to the clevis, top and bottom. On my turnbuckle fork the space between the 'tines' is only 0.150 inch. The diameter of the clevis is 0.185 inch. Thus, I would have to grind down the .185 dimension to less than 0.15 inch for the two to work together. Capish? Hope I am clearer than mud! Chuck ----- Original Message ----- From: "Catdesigns" <Catdesigns(at)att.net> Sent: Monday, June 27, 2011 2:55 PM Subject: Pietenpol-List: Re: Clevis > > Charles > > What exactly are you trying to do? Which part of the controls are you > trying to hook up? How about a diagram of what you?Tre trying to > accomplish? Please don?Tt just make do. Something you are trying to do > just doesn?Tt sound correct. > > To me it sounds like your trying to connect two forked ends together which > you shouldn?Tt do. Fork ends (turnbuckle end or shackle) should go over a > solid tab. If you?Tre trying to attach a cable to a turnbuckle, use > turnbuckle end fittings for connecting a cable directly to the turnbuckle. > If you must connect two fork ends together, make a short connector out of > metal with holes in both ends. > > > > Chris > > -------- > Chris > Sacramento, CA > WestCoastPiet.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344272#344272 > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2011
Subject: Re: Clevis
Chuck where the two elevator cables attach to the belcrank use a large cable shackle. Two thimbles, AN100-4 will fit over a large shackle. When I asked about making up cables a week or so ago someone sent me a picture of exactly that. I made up my tail brace cables using four larger cable shackles; one for the left hand upper brace cables, one for the right hand upper brace cables and the same for the bottom four brace cables. Eight cables come together at four cable shackles. I am going to do the same thing for the elevator cables where they meet at the belcrank. Cheers, Jim B. ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Jack, I notice you do not have turnbuckles on the 'elevator' side of the bellcrank. Are your turnbuckles back at the elevator horns? ----- Original Message ----- From: Jack Phillips To: pietenpol-list(at)matronics.com Sent: Monday, June 27, 2011 4:27 PM Subject: RE: Pietenpol-List: Re: Clevis Chuck, Here's a photo showing how I handled this area (for purposes of this discussion, ignore the spring driven trim system): If you look closely you can see that where the turnbuckles attach I made a pair of joggled straps of .062" 4130 which fit into the fork end of the turnbuckles and fit around the bellcrank. You're right, the plans don't mention this, but it has to be done somehow. This is one way to do it. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Monday, June 27, 2011 4:03 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: Clevis Chris, My scanner is acting up so I can't send you a drawing of what I'm trying to do. If you have a set of Aircamper plans look on the one showing the cockpit controls. There is a clevis at each side of the rear control stick with a cable attached to each -- that one I can do. Now look at the elevator control bellcrank. There are four clevises attached to the bellcrank. The drawing shows the cables connecting directly to the clevises but there must be a turnbuckle in each cable. The fork end of the turnbuckle would have to attach to the clevis, top and bottom. On my turnbuckle fork the space between the 'tines' is only 0.150 inch. The diameter of the clevis is 0.185 inch. Thus, I would have to grind down the .185 dimension to less than 0.15 inch for the two to work together. Capish? Hope I am clearer than mud! Chuck ----- Original Message ----- From: "Catdesigns" <Catdesigns(at)att.net> To: Sent: Monday, June 27, 2011 2:55 PM Subject: Pietenpol-List: Re: Clevis > > Charles > > What exactly are you trying to do? Which part of the controls are you > trying to hook up? How about a diagram of what you?Tre trying to > accomplish? Please don?Tt just make do. Something you are trying to do > just doesn?Tt sound correct. > > To me it sounds like your trying to connect two forked ends together which > you shouldn?Tt do. Fork ends (turnbuckle end or shackle) should go over a > solid tab. If you?Tre trying to attach a cable to a turnbuckle, use > turnbuckle end fittings for connecting a cable directly to the turnbuckle. > If you must connect two fork ends together, make a short connector out of > metal with holes in both ends. > > > > Chris > > -------- > Chris > Sacramento, CA > WestCoastPiet.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344272#344272 > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Yes. Easier to adjust them there. Jack Phillips NX899JP =93Icarus Plummet=94 Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Monday, June 27, 2011 6:34 PM Subject: Re: Pietenpol-List: Re: Clevis Jack, I notice you do not have turnbuckles on the 'elevator' side of the bellcrank. Are your turnbuckles back at the elevator horns? ----- Original Message ----- From: Jack <mailto:pietflyr(at)bellsouth.net> Phillips Sent: Monday, June 27, 2011 4:27 PM Subject: RE: Pietenpol-List: Re: Clevis Chuck, Here's a photo showing how I handled this area (for purposes of this discussion, ignore the spring driven trim system): If you look closely you can see that where the turnbuckles attach I made a pair of joggled straps of .062=94 4130 which fit into the fork end of the turnbuckles and fit around the bellcrank. You=92re right, the plans don=92t mention this, but it has to be done somehow. This is one way to do it. Jack Phillips NX899JP =93Icarus Plummet=94 Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Charles Campbell Sent: Monday, June 27, 2011 4:03 PM Subject: Re: Pietenpol-List: Re: Clevis Chris, My scanner is acting up so I can't send you a drawing of what I'm trying to do. If you have a set of Aircamper plans look on the one showing the cockpit controls. There is a clevis at each side of the rear control stick with a cable attached to each -- that one I can do. Now look at the elevator control bellcrank. There are four clevises attached to the bellcrank. The drawing shows the cables connecting directly to the clevises but there must be a turnbuckle in each cable. The fork end of the turnbuckle would have to attach to the clevis, top and bottom. On my turnbuckle fork the space between the 'tines' is only 0.150 inch. The diameter of the clevis is 0.185 inch. Thus, I would have to grind down the .185 dimension to less than 0.15 inch for the two to work together. Capish? Hope I am clearer than mud! Chuck ----- Original Message ----- From: "Catdesigns" <Catdesigns(at)att.net> Sent: Monday, June 27, 2011 2:55 PM Subject: Pietenpol-List: Re: Clevis > > Charles > > What exactly are you trying to do? Which part of the controls are you > trying to hook up? How about a diagram of what you?Tre trying to > accomplish? Please don?Tt just make do. Something you are trying to do > just doesn?Tt sound correct. > > To me it sounds like your trying to connect two forked ends together which > you shouldn?Tt do. Fork ends (turnbuckle end or shackle) should go over a > solid tab. If you?Tre trying to attach a cable to a turnbuckle, use > turnbuckle end fittings for connecting a cable directly to the turnbuckle. > If you must connect two fork ends together, make a short connector out of > metal with holes in both ends. > > > > Chris > > -------- > Chris > Sacramento, CA > WestCoastPiet.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344272#344272 > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2011
looks like a short wheel base corvair. Date: Sun=2C 26 Jun 2011 12:14:25 -0700 From: kmheidecpo(at)yahoo.com Subject: Fw: Pietenpol-List: Corvair Engine Fellow Pieters: I have a complete Corvair Engine removed from a working Corvair vehicle las t year. It is everything according to WIlliam Wynne rebuild book. I am inte rested in selling this motor for $600.00 to anyone on the list. Please cont act me off list if interested. The motor is complete and needs to be tron d own and rebuilt into an aircraft engine. KMHeide ________________________________________________________________________________
Date: Jun 27, 2011
I thought that, too. ----- Original Message ----- From: TOM MICHELLE BRANT To: pietenpol-list(at)matronics.com Sent: Monday, June 27, 2011 8:23 PM Subject: RE: Pietenpol-List: Corvair Engine looks like a short wheel base corvair. ------------------------------------------------------------------------- ----- Date: Sun, 26 Jun 2011 12:14:25 -0700 From: kmheidecpo(at)yahoo.com Subject: Fw: Pietenpol-List: Corvair Engine To: Pietenpol-List(at)matronics.com Fellow Pieters: I have a complete Corvair Engine removed from a working Corvair vehicle last year. It is everything according to WIlliam Wynne rebuild book. I am interested in selling this motor for $600.00 to anyone on the list. Please contact me off list if interested. The motor is complete and needs to be tron down and rebuilt into an aircraft engine. KMHeide ________________________________________________________________________________
Subject: Stab Leading Edge
Date: Jun 27, 2011
Got the horizontal stab leading edge glued on and mostly sanded today- will match up the elevator ends and finish it up this week. Vertical/rudder are done, will be starting on the fuse soon! :D -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344316#344316 Attachments: http://forums.matronics.com//files/dsc_0001_167.jpg http://forums.matronics.com//files/dsc_0003_152.jpg http://forums.matronics.com//files/dsc_0007_138.jpg ________________________________________________________________________________
Subject: Re: Stab Leading Edge
Date: Jun 27, 2011
looks nice... pretty work jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344320#344320 ________________________________________________________________________________
Date: Jun 27, 2011
The fuselage is the most fun build of the entire project! Interesting how you made the leading edge corners with the cut curves. Michael Perez Karetaker Aero www.karetakeraero.com --- On Mon, 6/27/11, bender wrote: > From: bender <jfaith(at)solairusaviation.com> > Subject: Pietenpol-List: Re: Stab Leading Edge > To: pietenpol-list(at)matronics.com > Date: Monday, June 27, 2011, 9:30 PM > --> Pietenpol-List message posted > by: "bender" > > looks nice... pretty work > > jeff > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344320#344320 > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Subject: Re: Clevis
Date: Jun 27, 2011
Just to throw a monkey wrench in it here's my solution at the bellcrank. :-) Clif Now look at the > elevator control bellcrank. There are four clevises attached to the > bellcrank. The drawing shows the cables connecting directly to the > clevises but there must be a turnbuckle in each cable. The fork end of > the turnbuckle would have to attach to the clevis, top and bottom. > Hope > I am clearer than mud! Chuck ________________________________________________________________________________
Date: Jun 28, 2011
ok, yes, it was an after thought! the corners had already been cut when i decided to add the other pieces! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344361#344361 ________________________________________________________________________________
Subject: Gusset Dimension
Date: Jun 28, 2011
I've been searching the archives to find the dimensions of the aft fuselage gusset without any luck. Am I missing something in the plans? Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344367#344367 Attachments: http://forums.matronics.com//files/aft_fuselage_gusset_756.jpg ________________________________________________________________________________
Subject: Re: Gusset Dimension
Date: Jun 28, 2011
I measured the 18-inch dimension from the plans as 1.5 inches. Top dim of gusset = .25 and bottom = .5. 18/1.5 = top/.25 = 3 inches. Bottom is twice that or 6 inches. ----- Original Message ----- From: "Piet2112" <curtdm(at)gmail.com> Sent: Tuesday, June 28, 2011 8:12 AM Subject: Pietenpol-List: Gusset Dimension > > I've been searching the archives to find the dimensions of the aft > fuselage gusset without any luck. Am I missing something in the plans? > > Curt Merdan > Flower Mound, TX > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344367#344367 > > > Attachments: > > http://forums.matronics.com//files/aft_fuselage_gusset_756.jpg > > > ________________________________________________________________________________
Date: Jun 28, 2011
Forgot to pull out the plans when I got back in to town this weekend.... On the 3-piece wing drawing, top left, there is a notation stating "CENTER SECTION SPAR 3/4" SPRUCE". Look directly over to the top right and you will see a notation stating "WING PANEL SPAR 3/4" SPRUCE". Ryan On Fri, Jun 24, 2011 at 6:00 PM, Saver wrote: > > Thanks Dan. So far we can only locate the 3/4 dimension > For the center section spars. 1" for main wing spars. > Scott > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344031#344031 > > ________________________________________________________________________________
Date: Jun 28, 2011
No Curt, the dimensions are not in the plans for that gusset. I don't recall any previous discussion about it, though. You can just scale the plans (which I think is what Chuck was saying). It's not that fussy. I used 7" for the bottom dimension - matching the gusset on the bottom (see attached photo), and the top was about 4 inches or so. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344383#344383 Attachments: http://forums.matronics.com//files/20100524_002_230.jpg ________________________________________________________________________________
Subject: Brodhead
Date: Jun 28, 2011
For those that have not seen this Pietenpol Fly-in information page... http://www.eaa431.org/?page_id 1 The folks in EAA 431 sure are proactive! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344391#344391 ________________________________________________________________________________
Date: Jun 28, 2011
Don, are you flying to Brodhead this year?- Dad and I are planning on lea ving here thursday morning, and hopefully getting to brodhead around 5-6 pm weather permitting.- If we are able we might even try wednesday morning. - I will be heading home around 8-9 am sunday, to hopefully be home befor e dark. - Shad --- On Tue, 6/28/11, Don Emch wrote: From: Don Emch <EmchAir(at)aol.com> Subject: Pietenpol-List: Brodhead Date: Tuesday, June 28, 2011, 4:21 PM For those that have not seen this Pietenpol Fly-in information page... http://www.eaa431.org/?page_id 1 The folks in EAA 431 sure are proactive! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344391#344391 le, List Admin. ________________________________________________________________________________
Subject: I love my job....sometimes
Date: Jun 28, 2011
List, Normally my company does not send me around the country, but I do go on occasion. Last time they sent me to East Texas, I ended up buying a lot on an airstrip, thanks to Piet Builder, Robert Caldwell! This time I went to Indiana. After putting out the Word that I was looking for local Pietenpolers, I got a few responses, and chose the closest one to the town where I was working. It was about an hour's drive to Elizabethtown, very near Columbus, Indiana. After GPS'ing my way down the country roads, I turned into a driveway, up a hill, and one glance thru the open barn doors told me I was at the right address. There sat Larry Morlock's almost done Piet! Larry Morlock 1.jpg Larry Morlock 4.jpg Besides the interesting fact that Larry's Piet now sports Douwe's old 'A' engine. Larry Morlock 2.jpg It also has a somewhat interesting history: Larry bought it as a project in '92, although certain aspects of the plane led him to believe that it actually had some air time. It's an earlier version, with external aileron cables, but the former owner had died in an auto accident, and no one seemed to know anything about the plane. We can give Larry a little slack for taking so long to get to this point, as he also owns a V-duster, and a Bonanza. He has been to Brodhead, and many of you have probably met him, and may know that he is very proud of having retired from Cummins Diesel, and he is equally proud of the philanthropic benefit that Cummins has had to his hometown, Columbus, Ind. Although he did not show me any airstrip lots for sale, he did show me the oldest ice cream parlor in Columbus, close to 100 yrs old! Larry Morlock 10.jpg Larry Morlock 6.jpg Larry's last words, as we exited the barn, were, "You didn't Markle anything, did you?" I explained that, if I had, and admitted it, it wouldn't be Markle-ing. Gary Cool, Ca. ________________________________________________________________________________
Date: Jun 28, 2011
Subject: Re: I love my job....sometimes
Wow, neat trip Gary! Isn't visiting other Piet builders the most fun!? And what great people. The thought of so many Piets being completed and flying in the next few years (some sooner!) is really encouraging.... jm..... -----Original Message----- From: Gboothe5 Sent: Jun 28, 2011 9:57 PM Subject: Pietenpol-List: I love my job....sometimes List, Normally my company does not send me around the country, but I do go on occasion. Last time they sent me to East Texas, I ended up buying a lot on an airstrip, thanks to Piet Builder, Robert Caldwell! This time I went to Indiana. After putting out the Word that I was looking for local Pietenpolers, I got a few responses, and chose the closest one to the town where I was working. It was about an hours drive to Elizabethtown, very near Columbus, Indiana. After GPSing my way down the country roads, I turned into a driveway, up a hill, and one glance thru the open barn doors told me I was at the right address. There sat Larry Morlocks almost done Piet! Besides the interesting fact that Larrys Piet now sports Douwes old A engine It also has a somewhat interesting history: Larry bought it as a project in 92, although certain aspects of the plane led him to believe that it actually had some air time. Its an earlier version, with external aileron cables, but the former owner had died in an auto accident, and no one seemed to know anything about the plane. We can give Larry a little slack for taking so long to get to this point, as he also owns a V-duster, and a Bonanza. He has been to Brodhead, and many of you have probably met him, and may know that he is very proud of having retired from Cummins Diesel, and he is equally proud of the philanthropic benefit that Cummins has had to his hometown, Columbus, Ind. Although he did not show me any airstrip lots for sale, he did show me the oldest ice cream parlor in Columbus, close to 100 yrs old! Larrys last words, as we exited the barn, were, You didnt Markle anything, did you? I explained that, if I had, and admitted it, it wouldnt be Markle-ing Gary Cool, Ca. ________________________________________________________________________________
Subject: Re: Brodhead
Date: Jun 29, 2011
Hey Shad, I am planning on flying up. I was thinking about joining the flying circus for a few days before, but now I'm not completely sure what I'll be doing. If I don't, I want to try to head out on Wednesday morning. If not, no later than than Thursday morning. Frank is planning to go too. He hasn't finalized his plans yet. I may try to hang with him, even though the Rudolph Piet is quite a bit slower. It sounds like we might be able to catch up to each other at some point though. I believe Jack P. will be heading up through our way around that same time too. Right Jack? In the next week or so I think I'll have better plans made. I do have a bit of a dilemma, the Chief sure would make for a comfortable ride to Brodhead! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344424#344424 ________________________________________________________________________________
Subject: Piet Items available
Date: Jun 29, 2011
I will have the following for Piet builders, Maple forms to make fuel tank end plates Ken Perkins, full swiveling tail wheel assembly. Ford crank extension, to mount taper hub.with fitted prop nut. Pietenpolie Girl T shirts and more at Brodhead fly-in. Pieti Lowell Do-not archive Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344429#344429 ________________________________________________________________________________
Date: Jun 29, 2011
Nice looking Piet Larry, but did you even consider putting a Cummins diesel on the nose? You know how we all like to brag that the Pietenpol has flown with more different engines than any other airplane - EVER. Tom Stinemetze N328X >>> "Gboothe5" 6/28/2011 8:57 PM >>> Besides the interesting fact that Larrys Piet now sports Douwes old A engine ________________________________________________________________________________
Date: Jun 29, 2011
I have to agree with the comfort issue Don, 7-10 hrs in 1 day is a real but t, and back buster for me, not to mention the deafness that follows from ru nning short stacks on a crank snapper.- But when you get there it is all worth it, especially sat evening when there are 10 or more pietenpols buzzi ng around.- To Jack P., what route do you usually take? If you don't mind flying beside......hu hummmmm... behind... a yankee corvair we could tromp along accross Indiana to Brodhead togeather.- # weeks and counting down by the day. - Shad Hey Shad, I am planning on flying up.- I was thinking about joining the flying circ us for a few days before, but now I'm not completely sure what I'll be doin g.- If I don't, I want to try to head out on Wednesday morning.- If not , no later than than Thursday morning.- Frank is planning to go too.- H e hasn't finalized his plans yet.- I may try to hang with him, even thoug h the Rudolph Piet is quite a bit slower.- It sounds like we might be abl e to catch up to each other at some point though.- I believe Jack P. will be heading up through our way around that same time too.- Right Jack?- In the next week or so I think I'll have better plans made.- I do have a bit of a dilemma, the Chief sure would make for a comfortable ride to Brod head! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344424#344424 le, List Admin. ________________________________________________________________________________
Subject: Re: T-shirts
Date: Jun 29, 2011
> Only way to be sure is to come to Brodhead! > Don't rub it in!! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344461#344461 ________________________________________________________________________________
Date: Jun 30, 2011
Believe it or not, I have thought about putting a Cummins diesel in a Pietenpol. They have a 3.3 liter engine, same displacement and similar size as a Model A engine, 65 HP @ 2600 rpm, but very heavy (and expensive). It probably could be done - but not by me! Larry ----- Original Message ----- From: TOM STINEMETZE To: pietenpol-list(at)matronics.com Sent: Wednesday, June 29, 2011 9:17 AM Subject: Re: Pietenpol-List: I love my job....sometimes Nice looking Piet Larry, but did you even consider putting a Cummins diesel on the nose? You know how we all like to brag that the Pietenpol has flown with more different engines than any other airplane - EVER. Tom Stinemetze N328X >>> "Gboothe5" 6/28/2011 8:57 PM >>> Besides the interesting fact that Larry=99s Piet now sports Douwe=99s old =98A=99 engine ________________________________________________________________________________
Date: Jun 30, 2011
Darn shame Larry. You could have called it a "Pietenbuilt" and had a real collector's item there. Tom S. >>> "l.morlock" 6/30/2011 9:36 AM >>> Believe it or not, I have thought about putting a Cummins diesel in a Pietenpol. They have a 3.3 liter engine, same displacement and similar size as a Model A engine, 65 HP @ 2600 rpm, but very heavy (and expensive). It probably could be done - but not by me! Larry ________________________________________________________________________________
Date: Jun 30, 2011
Subject: Bill Church photo featured on AVweb, today
Great photo, Bill! http://www.avweb.com/avwebflash/potw/PictureOfTheWeek_204899-1.html -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jun 30, 2011
On 06/30/2011 10:36 AM, l.morlock wrote: > Believe it or not, I have thought about putting a Cummins diesel in a > Pietenpol. They have a 3.3 liter engine, same displacement and similar > size as a Model A engine, 65 HP @ 2600 rpm, but very heavy (and > expensive). It probably could be done - but not by me! However, the late Bob Hoover (the VW expert and blogger, not the aerobatics pilot) pointed out that GM has a 65-horse industrial engine that is almost an exact match for the Model A, including weight. Rebuilt, it's dirt cheap. Sorely tempting. Owen ________________________________________________________________________________
Date: Jun 30, 2011
Subject: passing through
If any of you are going to pass through the Morris, IL area let me know. If you stop for a break It would be nice meet any of you. If you need assistance I will do what I can to be of help. I have taken a couple of days off so Thursday I will be free and Friday I will drive up to Brodhead in the a.m. If interested contact me via joeswithin(at)yahoo.com and we can trade info. I'am just getting started on my project so I do not have anything to show yet other than a keen desire to build and learn form others. Joe ________________________________________________________________________________
Subject: Re: Bill Church photo featured on AVweb, today
Date: Jun 30, 2011
Thanks Dan. It was only after Ryan suggested that I submit it, that I did submit it. Funny thing is that AVweb didn't even notify me that the photo was selected. So, thanks for the heads-up as well. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344508#344508 ________________________________________________________________________________
Date: Jun 30, 2011
On 06/30/2011 12:18 PM, Dan Yocum wrote: > 3.0l Vortec is my guess. It says it ships at 363lbs, but that could > include the crate weight, too. It has at least five years since Bob and I exchanged messages about this, and I have lost a lot of material to a dying hard drive since then. However, it was the 3.0l Vortec he had in mind. The horsepower, weight, and I believe cruise RPM (not sure about that last) almost exactly matched the Model A. Weight assumed replacing the cast iron manifold with welded steel tubing. (Pretty sure the shipping weight does include the crate.) The details may have changed since they switched from a carb to fuel injection, but it should still be pretty close. What made this engine so attractive, of course, was the price for a rebuilt engine. I remember (to the limited extent that verb describes what I actually do!) it as being around $800. It's probably a bit more now. Owen ________________________________________________________________________________
Date: Jun 30, 2011
Unless the manifold and crate weigh 120 lbs combined, that engine is a fair amount heavier than a Model A at ~244lbs.. On Thu, Jun 30, 2011 at 12:42 PM, Owen Davies wrote: > > On 06/30/2011 12:18 PM, Dan Yocum wrote: > > 3.0l Vortec is my guess. It says it ships at 363lbs, but that could >> include the crate weight, too. >> > > It has at least five years since Bob and I exchanged messages about this, > and I have lost a lot of material to a dying hard drive since then. However, > it was the 3.0l Vortec he had in mind. The horsepower, weight, and I believe > cruise RPM (not sure about that last) almost exactly matched the Model A. > > Weight assumed replacing the cast iron manifold with welded steel tubing. > (Pretty sure the shipping weight does include the crate.) The details may > have changed since they switched from a carb to fuel injection, but it > should still be pretty close. > > What made this engine so attractive, of course, was the price for a rebuilt > engine. I remember (to the limited extent that verb describes what I > actually do!) it as being around $800. It's probably a bit more now. > > Owen > > ________________________________________________________________________________
Subject: Re: passing through
Date: Jun 30, 2011
Hi Joe, You are already fitting nicely into this group. You know you are one of us when you start quoting lines from The Great Waldo Pepper ;o) ........."passing through, just passing through"..............(Axel Olsson, waving his arm, when Waldo showed up at "his" party) Dan Helsper Puryear, TN -----Original Message----- From: JOSEPH SWITHIN <joeswithin(at)yahoo.com> Sent: Thu, Jun 30, 2011 11:35 am Subject: Pietenpol-List: passing through If any of you are going to pass through the Morris, IL area let me know. If you stop for a break It would be nice meet any of you. If you need assista nce I will do what I can to be of help. I have taken a couple of days off s o Thursday I will be free and Friday I will drive up to Brodhead in the a.m . If interested contact me via joeswithin(at)yahoo.com and we can trade info. I'am just getting started on my project so I do not have anything to show y et other than a keen desire to build and learn form others. Joe -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 30, 2011
Subject: Is White Pine Acceptable?
I am new to this list and was wondering, is white pine acceptable to use in building the Pietenpol? Its my understanding that spruce is what most builders are using but I have a good supply of close grained white pine. Thanks Bryce Oklahoma City Started on fuselage and wing ribs ________________________________________________________________________________
Date: Jun 30, 2011
Subject: Re: Is White Pine Acceptable?
The short answer is "maybe." Per: http://www.sportair.com/articles/Aircraft%20Wood%20-%20Part%20One.html "The primary source of information for the builder may be obtained from FAA Advisory Circular 43-13, government bulletin ANC-19, and from a copy of Mil-Spec-6073. Advisory Circular 43-13 lists a number of different types of wood that may be used in an aircraft structure..." "As you can see from the chart White Pine is 85-96% as strong as spruce. It is easy to work with and is somewhat available. A number of kit manufacturers are using White Pine successfully within their designs. It is low in hardness and shock resisting capability. It cannot be used as a direct substitute for spruce without an increase in size to compensate for the lesser strength." Finding the minimum rings-per-inch (6) and maximum grain slope (1:15) at your local big box home improvement store will be nearly impossible, though some people have been able to do it given enough time and effort to sift through the stacks and stacks of wood and then coming back the following week and doing it again. And again. And again. Dan On 06/30/2011 01:49 PM, Bryce Reid wrote: > > > I am new to this list and was wondering, is white pine acceptable to use > in building the Pietenpol? > > Its my understanding that spruce is what most builders are using but I > have a good supply of close grained white pine. > > Thanks > Bryce > > Oklahoma City > Started on fuselage and wing ribs > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jun 30, 2011
QnJ5Y2UsDQoNCkknbSAnaW4gdGhlIGZpZWxkJywgYW5kIHNob290aW5nIGZyb20gdGhlIGhpcCwg YnV0IEkgdGhlIGV4YWN0IHdvcmRpbmcgaXMgdGhhdCBIZW1sb2NrIFBpbmUgaXMgYWNjZXB0YWJs ZS4gVGhlIHRlcm0gIndoaXRlIHBpbmUiIGlzIGdlbmVyaWMuIA0KDQpGV0lXLi4ubW9zdCBvZiBt eSB0YWlsIGlzIGJ1aWx0IHdpdGggSGVtbG9jay4NCg0KR2FyeQ0KU2VudCBvbiB0aGUgU3ByaW50 riBOb3cgTmV0d29yayBmcm9tIG15IEJsYWNrQmVycnmuDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2Fn ZS0tLS0tDQpGcm9tOiBCcnljZSBSZWlkIDwxcmNpb2tjQGdtYWlsLmNvbT4NClNlbmRlcjogb3du ZXItcGlldGVucG9sLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20NCkRhdGU6IFRodSwgMzAgSnVu IDIwMTEgMTM6NDk6MzAgDQpUbzogPHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb20+DQpSZXBs eS1UbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbVN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0 OiBJcyBXaGl0ZSBQaW5lIEFjY2VwdGFibGU/DQoNCkkgYW0gbmV3IHRvIHRoaXMgbGlzdCBhbmQg d2FzIHdvbmRlcmluZywgaXMgd2hpdGUgcGluZSBhY2NlcHRhYmxlIHRvIHVzZSBpbg0KYnVpbGRp bmcgdGhlIFBpZXRlbnBvbD8NCg0KSXRzIG15IHVuZGVyc3RhbmRpbmcgdGhhdCBzcHJ1Y2UgaXMg d2hhdCBtb3N0IGJ1aWxkZXJzIGFyZSB1c2luZyBidXQgSSBoYXZlDQphIGdvb2Qgc3VwcGx5IG9m IGNsb3NlIGdyYWluZWQgd2hpdGUgcGluZS4NCg0KVGhhbmtzDQpCcnljZQ0KDQpPa2xhaG9tYSBD aXR5DQpTdGFydGVkIG9uIGZ1c2VsYWdlIGFuZCB3aW5nIHJpYnMNCg0K ________________________________________________________________________________
Date: Jun 30, 2011
Subject: Re: Piet Items available
> > Pieti I am coming to Brodhead (with my Lady) from England, will you have the tailwheel assembly there as I am interested in purchasing it? What are you asking for it? John Theron > > Subject: Pietenpol-List: Piet Items available > From: "Pieti Lowell" <Lowellcfrank(at)yahoo.com> > > > I will have the following for Piet builders, > Maple forms to make fuel tank end plates > Ken Perkins, full swiveling tail wheel assembly. > Ford crank extension, to mount taper hub.with fitted prop nut. > Pietenpolie Girl T shirts > and more at Brodhead fly-in. > Pieti Lowell > > Do-not archive > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344429#344429 > > ________________________________________________________________________________
Date: Jun 30, 2011
There are 3 Vortec engines that might fit the bill. A 1.6l, 2.4l, and the 3.0l. I think the 2.4l is probably the one Bob was talking about. It comes in at 247lbs and provides the most torque at 3200RPM and about 90hp. http://industrial-irrigation.com/assets/files/REV_2011_2400_Industrial.pdf The 1.6l comes in at 220lbs and provides the top torque at 3200RPM and 70hp: http://www.bucksengines.com/Data/32.pdf $800 for an overhaul does sound appealing. Dan On 06/30/2011 12:42 PM, Owen Davies wrote: > > On 06/30/2011 12:18 PM, Dan Yocum wrote: > >> 3.0l Vortec is my guess. It says it ships at 363lbs, but that could >> include the crate weight, too. > > It has at least five years since Bob and I exchanged messages about > this, and I have lost a lot of material to a dying hard drive since > then. However, it was the 3.0l Vortec he had in mind. The horsepower, > weight, and I believe cruise RPM (not sure about that last) almost > exactly matched the Model A. > > Weight assumed replacing the cast iron manifold with welded steel > tubing. (Pretty sure the shipping weight does include the crate.) The > details may have changed since they switched from a carb to fuel > injection, but it should still be pretty close. > > What made this engine so attractive, of course, was the price for a > rebuilt engine. I remember (to the limited extent that verb describes > what I actually do!) it as being around $800. It's probably a bit more now. > > Owen > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Date: Jun 30, 2011
Could it be dry-sumped and mounted upside down? Jeff Boatright ________________________________________ From: owner-pietenpol-list-server(at)matronics.com [owner-pietenpol-list-server(at)matronics.com] on behalf of Dan Yocum [yocum(at)fnal.gov] Sent: Thursday, June 30, 2011 4:32 PM Subject: Re: Pietenpol-List: I love my job....sometimes There are 3 Vortec engines that might fit the bill. A 1.6l, 2.4l, and the 3.0l. I think the 2.4l is probably the one Bob was talking about. It comes in at 247lbs and provides the most torque at 3200RPM and about 90hp. http://industrial-irrigation.com/assets/files/REV_2011_2400_Industrial.pdf The 1.6l comes in at 220lbs and provides the top torque at 3200RPM and 70hp: http://www.bucksengines.com/Data/32.pdf $800 for an overhaul does sound appealing. Dan ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Jun 30, 2011
Best do the engineering on both for comparison. There is a big difference. Also, justify your findings with real load test to verify. " ...don't fly any higher then you would like to fall! " -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344530#344530 ________________________________________________________________________________
Date: Jun 30, 2011
As the others have said, "it depends". As the builder, if you are selecting your own wood, it is very important that you know exactly what species you are actually choosing. You mentioned "white pine", but do you know the true species? There are different varieties of white pine, with different physical characteristics. And, just to make things even more complicated, as can be seen in the two attachments, one species of wood (Pinus strobus) is referred to as Northern White Pine in AC43.13-1B, but also referred to as Eastern White Pine in ANC-18. The white pine species shown in the chart clearly have lower strength values compared to Sitka; some more significant than others. The short answer is exactly what AC43.13-1B says; "Cannot be used as a substitute for spruce without increase in sizes to compensate for lesser strength." Which doesn't mean that you couldn't build a successful Piet from "white pine"; it just means that you would need to know exactly what you are working with, and you would also need to know how to adjust the sizes of the members to appropriately allow for the lesser strength. And you should also do some actual testing of the wood you intend to use, to ensure that it has properties in line with the published values. Seems like a lot of work to me. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344535#344535 Attachments: http://forums.matronics.com//files/4313_1b_207.pdf http://forums.matronics.com//files/anc_18_191.pdf ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG FORSCOM" <steven.d.dortch(at)us.army.mil>
Date: Jun 30, 2011
Are you the Bryce who was in Enid, OK this last weekend with Lonnie G? Steve D ________________________________________________________________________________
From: "Amsafetyc(at)gmail.com" <amsafetyc(at)gmail.com>
Date: Jun 30, 2011
SSBhbSBzbyBiZWhpbmQgaW4gbXkgd3JpdGluZ3Mgb2YgbWVldCBhbmQgZ3JlZXRzLiBJIGhhZCB0 aGUgcGxlYXN1cmUgb2YgZGluaW5nIHdpdGggR2FyeSBCb290aCBhbmQgQ2hyaXMgVHJhY3kgbGFz dCB3ZWVrLiAgRGlubmVyIG91dCBhIGZldyBiZWVycyBhbmQgYSByZWFsbHkgbmljZSBldmVuaW5n LiBGb2xsb3dlZCBieSBhIHRyaXAgdG8gUG9ydGxhbmQgZ290IGEgY2hhbmNlIHRvIHZpc2l0IDIg bXVzZXVtcyBpbiB0aGUgYXJlYSBncmVhdCBmbHlpbmcgbWFjaW5lcyBvbiBkaXNwbGF5IGluIFZh bmNvdXZlciBhbmQgSG9vZCByaXZlciB3b3cgc3BlY3RhY3VsYXIgZGlzcGxheXMgaXYgYXZpYXRp b24gaGlzdG9yeSBncmVhdCB0cmlwLiBPaCB5YSBJIHdvcmtlZCBzb21lIHRvby4gSSBndWVzcyBh bGwgbGlmZSBjYW4ndCBiZSBhYm91dCBhaXJwbGFuZXMuICBUaGUgaG9vZCByaXZlciBvbmUgaGFk IGEgc2t5IHNjb3V0IG9uIGRpc3BsYXkganVzdCBmZWV0IGF3YXkgZnJvbSB0aGUgMTkxNyBDdXJ0 aXMgamVubnkgd293IGEgcmVhbCBzaXRlIHRvIHNlZS4KCkFuZCBhIGdvb2QgdHJpcCB3YXMgaGFk IGJ5IGFsbC4gSWxsIHRlbGwgdGhlIE1hcmtsZSBzdG9yeSBJIGdvdCBmcm9tIHRoZSB3ZXN0IGNv YXN0IGd1eXMgd2hlbiBJIHNlZSB5b3UgYWxsIGF0IENocmlzdG1hcyBvciB0aGUgbXVuY2llIGZh aXIKCkpvaG4gCgpEbyBub3QgYXJjaGl2ZSAKClNlbnQgdmlhIERST0lEIG9uIFZlcml6b24gV2ly ZWxlc3MKCi0tLS0tT3JpZ2luYWwgbWVzc2FnZS0tLS0tCkZyb206IEppbSBNYXJrbGUgPGppbV9t YXJrbGVAbWluZHNwcmluZy5jb20+ClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tClNl bnQ6IFdlZCwgSnVuIDI5LCAyMDExIDAzOjUxOjIwIEdNVCswMDowMApTdWJqZWN0OiBSZTogUGll dGVucG9sLUxpc3Q6IEkgbG92ZSBteSBqb2IuLi4uc29tZXRpbWVzCgotLT4gUGlldGVucG9sLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEppbSBNYXJrbGUgPGppbV9tYXJrbGVAbWluZHNwcmluZy5j b20+CgpXb3csIG5lYXQgdHJpcCBHYXJ5ISAgSXNuJ3QgdmlzaXRpbmcgb3RoZXIgUGlldCBidWls ZGVycyB0aGUgbW9zdCBmdW4hPyAgQW5kIHdoYXQgZ3JlYXQgcGVvcGxlLgoKVGhlIHRob3VnaHQg b2Ygc28gbWFueSBQaWV0cyBiZWluZyBjb21wbGV0ZWQgYW5kIGZseWluZyBpbiB0aGUgbmV4dCBm ZXcgeWVhcnMgKHNvbWUgc29vbmVyISkgaXMgcmVhbGx5IGVuY291cmFnaW5nLi4uLgoKam0uLi4u LgoKLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0KCkZyb206IEdib290aGU1IAoKU2VudDogSnVu IDI4LCAyMDExIDk6NTcgUE0KClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tCgpTdWJq ZWN0OiBQaWV0ZW5wb2wtTGlzdDogSSBsb3ZlIG15IGpvYi4uLi5zb21ldGltZXMKCgoKCgoKCgoK CgoKCgoKIAoKIAogIAogCgoKCgoKCkxpc3QsCgogCgpOb3JtYWxseSBteSBjb21wYW55IGRvZXMg bm90IHNlbmQgbWUgYXJvdW5kIHRoZSBjb3VudHJ5LCBidXQKSSBkbyBnbyBvbiBvY2Nhc2lvbi4g TGFzdCB0aW1lIHRoZXkgc2VudCBtZSB0byBFYXN0IFRleGFzLCBJIGVuZGVkIHVwIGJ1eWluZyBh CmxvdCBvbiBhbiBhaXJzdHJpcCwgdGhhbmtzIHRvIFBpZXQgQnVpbGRlciwgUm9iZXJ0IENhbGR3 ZWxsIQoKIAoKVGhpcyB0aW1lIEkgd2VudCB0byBJbmRpYW5hLiBBZnRlciBwdXR0aW5nIG91dCB0 aGUgV29yZCB0aGF0Ckkgd2FzIGxvb2tpbmcgZm9yIGxvY2FsIFBpZXRlbnBvbGVycywgSSBnb3Qg YSBmZXcgcmVzcG9uc2VzLCBhbmQgY2hvc2UgdGhlCmNsb3Nlc3Qgb25lIHRvIHRoZSB0b3duIHdo ZXJlIEkgd2FzIHdvcmtpbmcuIEl0IHdhcyBhYm91dCBhbiBob3Vy4oCZcyBkcml2ZQp0byBFbGl6 YWJldGh0b3duLCB2ZXJ5IG5lYXIgQ29sdW1idXMsIEluZGlhbmEuIEFmdGVyIEdQU+KAmWluZyBt eSB3YXkgZG93bgp0aGUgY291bnRyeSByb2FkcywgSSB0dXJuZWQgaW50byBhIGRyaXZld2F5LCB1 cCBhIGhpbGwsIGFuZCBvbmUgZ2xhbmNlIHRocnUgdGhlCm9wZW4gYmFybiBkb29ycyB0b2xkIG1l IEkgd2FzIGF0IHRoZSByaWdodCBhZGRyZXNzLgoKIAoKVGhlcmUgc2F0IExhcnJ5IE1vcmxvY2vi gJlzIGFsbW9zdCBkb25lIFBpZXQhIAoKIAoKIAoKQmVzaWRlcyB0aGUgaW50ZXJlc3RpbmcgZmFj dCB0aGF0IExhcnJ54oCZcyBQaWV0IG5vdwpzcG9ydHMgRG91d2XigJlzIG9sZCDigJhB4oCZIGVu Z2luZeKApgoKCgogCgpJdCBhbHNvIGhhcyBhIHNvbWV3aGF0IGludGVyZXN0aW5nIGhpc3Rvcnk6 ICBMYXJyeQpib3VnaHQgaXQgYXMgYSBwcm9qZWN0IGluIOKAmTkyLCBhbHRob3VnaCBjZXJ0YWlu IGFzcGVjdHMgb2YgdGhlIHBsYW5lIGxlZApoaW0gdG8gYmVsaWV2ZSB0aGF0IGl0IGFjdHVhbGx5 IGhhZCBzb21lIGFpciB0aW1lLiBJdOKAmXMgYW4gZWFybGllcgp2ZXJzaW9uLCB3aXRoIGV4dGVy bmFsIGFpbGVyb24gY2FibGVzLCBidXQgdGhlIGZvcm1lciBvd25lciBoYWQgZGllZCBpbiBhbiBh dXRvCmFjY2lkZW50LCBhbmQgbm8gb25lIHNlZW1lZCB0byBrbm93IGFueXRoaW5nIGFib3V0IHRo ZSBwbGFuZS4gV2UgY2FuIGdpdmUgTGFycnkKYSBsaXR0bGUgc2xhY2sgZm9yIHRha2luZyBzbyBs b25nIHRvIGdldCB0byB0aGlzIHBvaW50LCBhcyBoZSBhbHNvIG93bnMgYQpWLWR1c3RlciwgYW5k IGEgQm9uYW56YS4gSGUgaGFzIGJlZW4gdG8gQnJvZGhlYWQsIGFuZCBtYW55IG9mIHlvdSBoYXZl IHByb2JhYmx5Cm1ldCBoaW0sIGFuZCBtYXkga25vdyB0aGF0IGhlIGlzIHZlcnkgcHJvdWQgb2Yg aGF2aW5nIHJldGlyZWQgZnJvbSBDdW1taW5zCkRpZXNlbCwgYW5kIGhlIGlzIGVxdWFsbHkgcHJv dWQgb2YgdGhlIHBoaWxhbnRocm9waWMgYmVuZWZpdCB0aGF0IEN1bW1pbnMgaGFzCmhhZCB0byBo aXMgaG9tZXRvd24sIENvbHVtYnVzLCBJbmQuIEFsdGhvdWdoIGhlIGRpZCBub3Qgc2hvdyBtZSBh bnkgYWlyc3RyaXAKbG90cyBmb3Igc2FsZSwgaGUgZGlkIHNob3cgbWUgdGhlIG9sZGVzdCBpY2Ug Y3JlYW0gcGFybG9yIGluIENvbHVtYnVzLCBjbG9zZSB0bwoxMDAgeXJzIG9sZCEKCiAKCiAKCiAK CkxhcnJ54oCZcyBsYXN0IHdvcmRzLCBhcyB3ZSBleGl0ZWQgdGhlIGJhcm4sIHdlcmUsIOKAnFlv dQpkaWRu4oCZdCBNYXJrbGUgYW55dGhpbmcsIGRpZCB5b3U/4oCdIEkgZXhwbGFpbmVkIHRoYXQs IGlmIEkgaGFkLCBhbmQKYWRtaXR0ZWQgaXQsIGl0IHdvdWxkbuKAmXQgYmUgTWFya2xlLWluZ+KA pgoKIAoKR2FyeQoKQ29vbCwgQ2EuCgoKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVu cG9sLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJl cyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFz IExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1E YXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6 Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5w b2wtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVN UyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9y dW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Xy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCg= ________________________________________________________________________________
Date: Jul 01, 2011
Subject: Happy 4th
Friends, I cannot find better words. This was produced in 1969 and is more relevant today than it was back then. Stu http://www.youtube.com/watch?v=BY4YlqZsaqU&feature=related ________________________________________________________________________________
Date: Jul 01, 2011
Shameless Plug on behalf of the Brodhead EAA chapter.... If you want a real head start on a fuselage made out of real spruce, bring a truck (and some money) to Brodhead and buy the fuselage that EAA431 is selling to raise money. It includes a set of tail feathers and control horns. The chapter flyer cited in other posts has some more information. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344582#344582 ________________________________________________________________________________
Subject: Nutz!
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Jul 01, 2011
Well Kevin I hope you have enough distributors! : Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344617#344617 ________________________________________________________________________________
Subject: Head start on a project
Date: Jul 01, 2011
Parting out a Pietenpol. From a previously flying airplane. I have the fuselage on the gear with the tail assemblies. I would recover it on general principle but it's a way to cut your build time by about 1/2. If you're interested reply to wyliejohnson45(at)gmail.com and I'll send pictures. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344638#344638 ________________________________________________________________________________
From: "amsafetyc(at)aol.com" <amsafetyc(at)aol.com>
Date: Jul 02, 2011
Subject: lycoming 0235 C1B experts
Okay sports fans here's how it goes. I located an A&P who was willing to help teach supervise and mentor me in the tear down and overhaul of my engine. Just as i get ready to order parts he gives one of the female we need to talk phone messages, knowing nothing good ever comes out of conversations that begin that way I was skeptical to say the least. Following all the lawyer excuses it came down to the fact he wasn't comfortable doing what he had agreed to for legal reasons, again with the lawyers. Long and short he took a powder on me. Anyone have any good and reasonable suggestions or resources. I still want to learn the engine by building it but prefer that be done under the supervision of a trained and experienced person rather thn my working in a vacuum and hoping I did it right. This is not my first engine build just my first aircraft engine build. I have built enough to know they all have their little tricks and nuances that mean the difference between a solid reliable build and an accident waiting to happen. My preference is in the solid reliable trouble free build category unless there was any confusion as to my goal and preference. Any suggestions or resources you can suggest in helping me achieve my goal. Please advise John No reasonable offer refused Sent via DROID on Verizon Wireless ________________________________________________________________________________
Subject: Re: lycoming 0235 C1B experts
Date: Jul 02, 2011
John, I'm about to tear down my C85 and my A&P/IA friend gave me a book to read first. It was extremely informative and even though it is geared more towards the Lycomings, it's a great resource for any engine. It's the Sky Ranch Engineering Manual. There are several different sources for the book and AS&S has it for about $23. As far as gaskets, seals, bearings,etc. www.airpowerinc.com seems to have the best prices I could find. If you find something better, please pass it along. I attached a sample from the book. Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344685#344685 Attachments: http://forums.matronics.com//files/engineering_manual_570.pdf ________________________________________________________________________________
Date: Jul 02, 2011
John, I just built an O-235 C2C which is very close to being exactly the same. There are some AD's that need to be tended to oil pump gears,push rod material, carb venturi and float material, maybe some more. I remember the pushrods and float being reading the AD's closely to determine if it applied. The oil pump is very clear in that it requires 2 hardened steel gears. My log book lied. It was written that the oil pump AD had been done and it had not. Make sure you knock the sludge tubes out of the crank and clean the krud out. If you are very careful you can reuse them as it is experimental. I bought an oak dowel the same OD as the sludge tube and sanded it to fit. Measure them to make sure they are still a press fit before you reuse them. If they are not removed and cleaned odds are very great you will have bearing problems as the oil distribution goes around the OD of those tubes. They make like a centrifuge when the engine is running. Some of the krud the filters miss is captured within that cavity. That was not Lycoming's intent. They figured out how to make the crank without those things in later years. I can really find fault though as my crank was in great condition after 2050 hours. I found Dart Aircraft Parts in Waco, Tx the most reasonable. A guy named Steve was nice to deal with. Note I didn't say cheap. Piston rings were $110 per cylinder ! The big picture was intentional as I wanted you to see what collects in there. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 wing, tailfeathers done, fuselage rolling using Lycoming O-235 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344716#344716 Attachments: http://forums.matronics.com//files/dsc00295_155.jpg ________________________________________________________________________________
Subject: model a prop
Date: Jul 02, 2011
I have wood on the way and a pattern scaled down from a sopwith camel propeller...i also have Dan's prop carving info... love the info Dan now i'm wondering after reading all the post about pitch what pitch to use ?? the F&G manual for '33 says a model a uses a 72x42... same as a lot of you guys use on the 65 cont.. i know Dan carved a 76x46... hows the climb Dan ? i'm thinking 76x 42 or 43 maybe... i have an A with new rods chevy pistons...B grind cam. insert bearings.1.7 inch intake valves and a thomas high compression 6.7:1 head got to be more power than Henry made jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344723#344723 ________________________________________________________________________________
Subject: Re: The hits just keep on coming
Date: Jul 02, 2011
John, you have seen my hangar. When I first spoke to Roger (airport owner) about renting, my first question was, do you mind if I set up shop and build an airplane in there? He said, no problem at all, in fact we encourage that kind of activity. He has seen my empty hangar evolve from two workbenches and a few power/hand tools to the shop it is now. He has no problem with it at all. I don't leave lights burning all night (he pays the electric), but I did have a full size fridge/kegerator in there for a year... he didn't even mind that. I felt kind of guilty having him keep my keg cold all summer during those 100+ degree days, so I downsized to a small fridge and I kill the power on everything except the fridge before I leave each day... he didn't ask me to, but I do... it just makes sense. Knowing you, I'm sure that you have a similar setup... not sure what is so dangerous about that. Sorry it doesn't seem to be working out. I know that this doesn't help your situation in the least, but I guess I'm just trying to say it just depends who you are dealing with. Perhaps there is another field you could check in to? Best of luck! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344727#344727 ________________________________________________________________________________
Subject: Re: model a prop
Date: Jul 02, 2011
Jeff, as a point of reference, I just ran the Model A engine in my Piet last week up in Columbus, IN. It has a 76 X44 Hegy prop. I got 1845 static RPM with a Tillotson carb (which I think you said you are planning to use) and 1860 static RPM with a Model B carb. Your plan of using 76 x 42 sounds pretty good. I could use more revs. Larry ----- Original Message ----- From: "bender" <jfaith(at)solairusaviation.com> Sent: Saturday, July 02, 2011 6:33 PM Subject: Pietenpol-List: model a prop > > > I have wood on the way and a pattern scaled down from a sopwith camel > propeller...i also have Dan's prop carving info... love the info Dan > > now i'm wondering after reading all the post about pitch what pitch to use > ?? > > the F&G manual for '33 says a model a uses a 72x42... same as a lot of you > guys use on the 65 cont.. > i know Dan carved a 76x46... hows the climb Dan ? > > i'm thinking 76x 42 or 43 maybe... > i have an A with new rods chevy pistons...B grind cam. insert bearings.1.7 > inch intake valves and a thomas high compression 6.7:1 head got to be > more power than Henry made > > jeff > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344723#344723 > > > ________________________________________________________________________________
Date: Jul 02, 2011
Hi Jeff, Now that I have my engine running better, the next agenda item is to test t he climb performance and record. Won't fly her again till about 7/19. I'll let y'all know. Dan Helsper Puryear, TN -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Sat, Jul 2, 2011 5:36 pm Subject: Pietenpol-List: model a prop > I have wood on the way and a pattern scaled down from a sopwith camel ropeller...i also have Dan's prop carving info... love the info Dan now i'm wondering after reading all the post about pitch what pitch to use ?? the F&G manual for '33 says a model a uses a 72x42... same as a lot of you guys se on the 65 cont.. know Dan carved a 76x46... hows the climb Dan ? i'm thinking 76x 42 or 43 maybe... have an A with new rods chevy pistons...B grind cam. insert bearings.1.7 i nch ntake valves and a thomas high compression 6.7:1 head got to be more power han Henry made jeff ead this topic online here: http://forums.matronics.com/viewtopic.php?p=344723#344723 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Hangar work
Date: Jul 02, 2011
John=2C I have been through all of this before. Any airport that accepts F ederal funds cannot preclude an owner from performing his own work. That b eing said=2C they can also place reasonable safety restrictions on your act ivities. Open flames or electrical wiring that poses a potential fire haza rd are probably reasonable. I know that if I was to be responsible for eve ry airplane in my hangar row=2C I would be pretty damned careful. Also=2C when I think of some of the doofuses in my hangar row=2C all I can say is t hey better never burn up my Travel Air and Pietenpol for their stupidity! I KNOW they are not insured enough. Nonetheless=2C there are some who stor e fuel in plastic 55 gallon drums in their hangar. I'd hate to have to kil l them!! If I can help in any way=2C please contact me=2C Gene ________________________________________________________________________________
Date: Jul 03, 2011
Subject: Re: Hangar work
Gene Thanks for the info,insight and offer. Rather than win a small victory and make an advesary I would prefer to meet the restrictions and maybe make a friend. Ultimately I just want to be left alone to build my airplane without toothless tommy and the airport manager looking over my shoulder. As it is I am at an end row T hangar with no flammable storage in a metal structure. The most flammable item in the hangar is my uncovered fuse wings and til feathers in the event of an electrical event the worst is a spark short to ground and a kicked breaker. The 220 line is 30 amp and is not a pure 220 in serious need of a double pole breaker. I am the only one connected to it or has access to a dedicated welder connection from a previous tennant. All that wire is in conduit all the way to the welder plug. So again any over heating or short goes directly to ground and trips the breaker still no threat to the row. Having a manager that doesn't quite understand electric makes for irrational fears and over rections. Oh well it takes all kinds Thanks again for the help Looking forward to seeing ya at Brodhead this month Fly safe John Sent via DROID on Verizon Wireless -----Original message----- From: Gene Rambo <generambo(at)msn.com> Sent: Sun, Jul 3, 2011 03:50:32 GMT+00:00 Subject: Pietenpol-List: Hangar work John, I have been through all of this before. Any airport that accepts Federal funds cannot preclude an owner from performing his own work. That being said, they can also place reasonable safety restrictions on your activities. Open flames or electrical wiring that poses a potential fire hazard are probably reasonable. I know that if I was to be responsible for every airplane in my hangar row, I would be pretty damned careful. Also, when I think of some of the doofuses in my hangar row, all I can say is they better never burn up my Travel Air and Pietenpol for their stupidity! I KNOW they are not insured enough. Nonetheless, there are some who store fuel in plastic 55 gallon drums in their hangar. I'd hate to have to kill them!! If I can help in any way, please contact me, Gene ________________________________________________________________________________
Date: Jul 03, 2011
Subject: more
Last year the company I worked for decided that after 115 years in business it was time to close. Being in the building materials business and the state of the economy, there was no place to land. I put my safety background to work on the grain business. Very fertile ground for a safety person. Look forward to meeting you at Brodhead and we can exchange information. If need be contact me off line. Joe Swithin Morris, IL ________________________________________________________________________________
Date: Jul 03, 2011
John, The Hatz I was looking at has a 0-235-C1 and I looked up all the ADs and SBs on it. I've attached it for your review. The AD search page at http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/Frameset?OpenPage is pretty easy to navigate. Enjoy! Dan On 07/02/2011 03:34 PM, Jerry Dotson wrote: > --> Pietenpol-List message posted by: "Jerry Dotson" > > John, > I just built an O-235 C2C which is very close to being exactly the same. There are some AD's that need to be tended to oil pump gears,push rod material, carb venturi and float material, maybe some more. I remember the pushrods and float being reading the AD's closely to determine if it applied. The oil pump is very clear in that it requires 2 hardened steel gears. My log book lied. It was written that the oil pump AD had been done and it had not. Make sure you knock the sludge tubes out of the crank and clean the krud out. If you are very careful you can reuse them as it is experimental. I bought an oak dowel the same OD as the sludge tube and sanded it to fit. Measure them to make sure they are still a press fit before you reuse them. If they are not removed and cleaned odds are very great you will have bearing problems as the oil distribution goes around the OD of those tubes. They make like a centrifuge when the engine is running. Some of the krud the filters miss is c ap! > tured within that cavity. That was not Lycoming's intent. They figured out how to make the crank without those things in later years. I can really find fault though as my crank was in great condition after 2050 hours. > > I found Dart Aircraft Parts in Waco, Tx the most reasonable. A guy named Steve was nice to deal with. Note I didn't say cheap. Piston rings were $110 per cylinder ! > > The big picture was intentional as I wanted you to see what collects in there. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > wing, tailfeathers done, fuselage rolling > using Lycoming O-235 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344716#344716 > > > Attachments: > > http://forums.matronics.com//files/dsc00295_155.jpg > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." Lycoming Service Bulletins SB582A Float in float carb needs attention SB530B Application of Protective Coating on Crankshaft SB524 Replacement of Sintered Iron or Al Oil Pump Impellers within 100hrs or 5yrs of AD SB505B Inspection of Crankshaft I.D. for Corrosion SB475C Crankshaft Gear Modification and Assembly Procedures Damage to the crankshaft gear and the counterbored recess in the rear of the crankshaft, as well as badly worn or broken gear alignment dowels are the result of improper assembly techniques or the reuse of worn or damaged parts during reassembly. Since a failure of the gear or the gear attaching parts would result in complete engine stoppage, the proper inspection and reassembly of these parts is very important. The procedures described in the following steps are mandatory. SB388C Procedure to Determine Exhaust Valve and Guide Condition 400hr intervals if valve sticking is suspected Excessive carbon build-up in valve train SB366B Carburetor Throttle Body Screw Inspection All Marvell Schebler carbs. Look for fuel stains around body and bowl. SB240V Mandatory Parts Replacement at OH and During Repair or Maintenance O-235-C1 Airworthiness Directives 2004-10-14 Crankshaft gear after a propeller strike, sudden stoppage, at overhaul, or whenever gear train repair is required 96-09-10 Oil pump - see SB524, above within 100hrs of AD 95-03-10 Push Rods - All push rods with P/N 73806 and revision letters "V" or "W" must be replaced with serviceable parts within 5hrs 80-25-02 R2 Pushrods - when was the engine OH'd? within 25hrs 75-08-09 Oil Pump Drive Shaft - To prevent oil pump failures, inspect, replace and assemble the oil pump drive shaft and drive impeller in accordance with the inspection and procedure paragraphs of Lycoming Service Bulletin No. 381B or No. 385C or later revision. within 50hrs or first 400hrs, whichever is later Bendix Mags S4LN 20 (right) part no 10-51360-29 A1 s/n 787726 S4LN 21 (left) part no 10-51360-10 s/n 321279 Airworthiness Directives 2005-12-06 see MSB645 INSPECTION OF RIVETED IMPULSE COUPLINGS AND STOP PINS 82-20-01 S4LN-21 series, SNs B-001171 or A297043 - To prevent failure of impulse coupling due to improperly heat treated (soft) flyweights resulting in engine damage or failure, accomplish the following: (Ref. Bendix Service Bulletin No. 623 dated September 1982.) within 10hrs 74-26-09 S-20 series - insure that the affected magnetos incorporate a solid steel drive shaft bushing within 90d after AD ________________________________________________________________________________
Date: Jul 03, 2011
Good post, Gene. I know many FBO's who would rather that this knowledge didn't get about. Jack Phillips NX899JP "Icarus Plummet" Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gene Rambo Sent: Saturday, July 02, 2011 11:42 PM Subject: Pietenpol-List: Hangar work John, I have been through all of this before. Any airport that accepts Federal funds cannot preclude an owner from performing his own work. That being said, they can also place reasonable safety restrictions on your activities. Open flames or electrical wiring that poses a potential fire hazard are probably reasonable. I know that if I was to be responsible for every airplane in my hangar row, I would be pretty damned careful. Also, when I think of some of the doofuses in my hangar row, all I can say is they better never burn up my Travel Air and Pietenpol for their stupidity! I KNOW they are not insured enough. Nonetheless, there are some who store fuel in plastic 55 gallon drums in their hangar. I'd hate to have to kill them!! If I can help in any way, please contact me, Gene ________________________________________________________________________________
From: "skipgadd(at)earthlink.net" <skipgadd(at)earthlink.net>
Subject: Center section handle bracket
Date: Jul 03, 2011
The list is slow this morning, so I will put this out for comment and general information. Don't know how others have handled(pun intended) this problem. I thought a long time about how to reinforce the handle the pilot grabs as he gets in or out of the back pit. My Grega has a similar handle but I can't look inside the C/S to see how it is reinforced. The brackets are .058X5/8 tube and 16ga plate. They are screwed to the handle through the ply and spruce and bolted to the C/S spar(vertical center only) with AN3 hardware. Skip skipgadd(at)earthlink.net ________________________________________________________________________________
Date: Jul 03, 2011
Skipp, that certainly looks more than adequate. That is certainly a very high load area as the pilot puts his entire weight on it during ingress and egress. I made mine as a =BC=94 plwood box, going to a laminated spruce bow as shown below, and I believe you could use it to pick up the entire airplane. Jack Phillips NX899JP =93Icarus Plummet=94 Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of skipgadd(at)earthlink.net Sent: Sunday, July 03, 2011 9:21 AM Subject: Pietenpol-List: Center section handle bracket The list is slow this morning, so I will put this out for comment and general information. Don't know how others have handled(pun intended) this problem. I thought a long time about how to reinforce the handle the pilot grabs as he gets in or out of the back pit. My Grega has a similar handle but I can't look inside the C/S to see how it is reinforced. The brackets are .058X5/8 tube and 16ga plate. They are screwed to the handle through the ply and spruce and bolted to the C/S spar(vertical center only) with AN3 hardware. Skip skipgadd(at)earthlink.net ________________________________________________________________________________
Date: Jul 03, 2011
Jack, Thanks for the picture, it looks really stout. My fuel tank is next, are there any baffles side to side? Skip ----- Original Message ----- From: Jack Phillips Sent: 7/3/2011 12:29:03 PM Subject: RE: Pietenpol-List: Center section handle bracket Skipp, that certainly looks more than adequate. That is certainly a very high load area as the pilot puts his entire weight on it during ingress and egress. I made mine as a plwood box, going to a laminated spruce bow as shown below, and I believe you could use it to pick up the entire airplane. Jack Phillips NX899JP Icarus Plummet Smith Mountain Lake, Virginia ________________________________________________________________________________
Date: Jul 03, 2011
Subject: Re: Center section handle bracket
I ended up building a flap in the rear of my center section to make it easier to exit. I also have an active Sky-dive business at my home airport, so I thought it would be a good idea to be able to look straight up to make sure all the jumpers were down before I took off. I didn't put any handle at all on my center section. The two rear cabane struts make a perfect place to grab to pull myself out of the seat, and allow me to use both arms for the effort. Your center section looks beautiful, but I think it would look even better without the handle, and the added stress it puts on all that 1/4 x 1/2 inch structure. Just my $.02 Ben Charvet 85 hours since 2/19/2010 On 7/3/2011 9:20 AM, skipgadd(at)earthlink.net wrote: > > The list is slow this morning, so I will put this out for comment and > general information. Don't know how others have handled(pun intended) > this problem. I thought a long time about how to reinforce the handle > the pilot grabs as he gets in or out of the back pit. My Grega has a > similar handle but I can't look inside the C/S to see how it is > reinforced. The brackets are .058X5/8 tube and 16ga plate. They are > screwed to the handle through the ply and spruce and bolted to the C/S > spar(vertical center only) with AN3 hardware. > Skip > skipgadd(at)earthlink.net ________________________________________________________________________________
Subject: another West Coast Piet
Date: Jul 03, 2011
Howdy, low 'n' slow fliers; While I've been sitting here twiddling my thumbs waiting to find a house and hangar, I had a nice email from Doc Mosher, forwarding another email to me. Seems that the folks up in McMinnville at the Evergreen Aviation and Space Museum (home of the Howard Hughes 'Spruce Goose') are about 80% progressed on building a Piet for the museum! I don't know if their intent is to fly it, but I sure hope so. And knowing the quality of displays in most museums, I'll bet their Air Camper will be a beauty. Doc forwarded the email to me because the builders were looking for one of the brass data plates that I sell, and I'll be donating one to the project (they are all volunteers and everything is done by contributions). I'm anxious to start some low and slow flying up and down the I-5 corridor, if I can just get Scout up here. But being the loyal husband that I am, I've promised to focus on getting us into a permanent residence first, and then worrying about airplanes and hangars. I hope I get some brownie points or a gold star by my name or something ;o) Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: another West Coast Piet
Date: Jul 03, 2011
here it is oscar any one who waits to get a apt for honey deserves a star. -----Original Message----- From: Oscar Zuniga Sent: Sunday, July 03, 2011 4:20 PM Subject: Pietenpol-List: another West Coast Piet Howdy, low 'n' slow fliers; While I've been sitting here twiddling my thumbs waiting to find a house and hangar, I had a nice email from Doc Mosher, forwarding another email to me. Seems that the folks up in McMinnville at the Evergreen Aviation and Space Museum (home of the Howard Hughes 'Spruce Goose') are about 80% progressed on building a Piet for the museum! I don't know if their intent is to fly it, but I sure hope so. And knowing the quality of displays in most museums, I'll bet their Air Camper will be a beauty. Doc forwarded the email to me because the builders were looking for one of the brass data plates that I sell, and I'll be donating one to the project (they are all volunteers and everything is done by contributions). I'm anxious to start some low and slow flying up and down the I-5 corridor, if I can just get Scout up here. But being the loyal husband that I am, I've promised to focus on getting us into a permanent residence first, and then worrying about airplanes and hangars. I hope I get some brownie points or a gold star by my name or something ;o) Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jul 03, 2011
I know it's not a truly all wood idea- but what I ended up doing after looking at the wing flop I had with my project a while was- scrap it and get some light 1/2" galvanized EMT I think it's called conduit. kept working it into a bow till I had a curve I liked that went from one root rib to the other on the wings.bent some light steel to make clips that could be screwed into the rib tails so it all faired in.and made 2 short ribs from Aluminum sheet- (actually cut em out from some surplus aluminum signs I had)that fit the back of the rear center section spar and tapered to the width of the EMT. left tabs on them that lapped the top and bottom of the conduit and riveted them to it with stainless steel pop rivets. and a couple bolts from the ribs to the spar give lots of strength. also used a straight piece to bridge across the bow in the center with enough width and room for a grab handle - brazed it on after fitting the ends,and after final installing the wings and rigging- doped and fabric covered the area as well as the root gaps on the wing.looks like a one piece wing now. would take a little more work to get the wings off but unless I need to do serious work i don't plan on that anyway.did away with gap seals and came out pretty clean and simple-I wouldn't want to swing my 210#'s from it but sure feels strong and solid using it to steady myself getting in and out.not to Grega drawings but it works for me Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344810#344810 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: high altitude Piet
Date: Jul 03, 2011
Hey all, Not sure if it'll ever happen, but a move to the high country of Colorado MIGHT take place one year in the future. The closest airports are Buena Vista at 7900 feet and Salida at 7400 feet elevation. (8000ft and 7000ft long respectively!) My piet has standard wings, but a new C-90 turning a Cloud Car prop. The approaches to both these fields open as they're in the middle of the same valley. Do you think I'd be okay? I remember "Mountain Piet" was based out of Buena Vista, and with his reduced Subaru, he did fine while it flew, though it was turbocharged. I'm sure I could find lower fields, but they start getting farther and farther away, which makes things less enjoyable and convenient. Douwe ________________________________________________________________________________
Date: Jul 03, 2011
Subject: Re: high altitude Piet
It's a long way to anything lower from there.If you can deal with the altitude it's a great area. On Sun, Jul 3, 2011 at 3:28 PM, Douwe Blumberg wrote: > ** > > Hey all,**** > > ** ** > > Not sure if it=92ll ever happen, but a move to the high country of Colora do > MIGHT take place one year in the future. The closest airports are **Buen a > Vista** at 7900 feet and Salida at 7400 feet elevation. (8000ft and 7000f t > long respectively!)**** > > ** ** > > My piet has standard wings, but a new C-90 turning a Cloud Car prop. The > approaches to both these fields open as they=92re in the middle of the sa me > valley. **** > > ** ** > > Do you think I=92d be okay? **** > > ** ** > > I remember =93Mountain Piet=94 was based out of **Buena Vista**, and with his > reduced Subaru, he did fine while it flew, though it was turbocharged.*** * > > ** ** > > I=92m sure I could find lower fields, but they start getting farther and > farther away, which makes things less enjoyable and convenient.**** > > ** ** > > Douwe**** > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: Turnbuckles
Date: Jul 03, 2011
I'm looking to order the turnbuckles for the aileron and tail brace wires. Got very confused looking at the AC catalog offerings. Help! What do I need to order? Thanks, Jim ________________________________________________________________________________
Subject: Re: Don flying his Chief up instead of Piet
Date: Jul 04, 2011
Ha! My wife Gretchen, of all people, told me it just wouldn't be right. She said if I'm "flyin' to Brodhead it better be in the Piet". (umm...not that us Piet guys let our wives tell us what to do...) Don't know what I was thinking! Douwe, looks like we get to stay friends!! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=344847#344847 ________________________________________________________________________________
Date: Jul 04, 2011
Subject: Insurance
Since moving into the hangar I contacted my Allstate insurance agent to find out about coverage for my almost an airplane. I wasn certain if it woul be considered an airplane or content. They were going to contact home office and get back to me,still waiting..... So the question in my mind is at what point does it become an airplane? Like everyone else I too am highly protective of my thousands of hours of work and up to date accomplishments and would like to bind appropriate coverage for all non act of God perils. Anyone have any suggestions or is that a carrier and or EAA question? I would doubt the leesor would have any coverage beyond structure to protect its assets. So how would I protect mine. Allstate says if its content it could be covered under my homeowners policy but that would be more content and pay only for base materials since its not an airplane yet When it becomes an airplane it would have a policy similar to an auto or motor vehicle policy. As a project its neither an airplane nor a pile of lumber. I am interested to learn the legal aspects of it and anyone elses experience in this area. Not wanting to admit it but I am perplexed and concerned about other remnants in my row Please advise John Sent via DROID on Verizon Wireless ________________________________________________________________________________
Date: Jul 04, 2011
Subject: Re: Turnbuckles
Jim You may want to order them from B & B you can speak to them and the will help with your application selection. They are if not already preping for Oshkosh so call soon. Great folks to work with helpful and priced much better than others John Happy independance day celebrating by building my Piet no better way to honor those that bought and paid for our freedom Please archive Sent via DROID on Verizon Wireless -----Original message----- From: jim <quinnj(at)sbcglobal.net> Sent: Mon, Jul 4, 2011 00:50:13 GMT+00:00 Subject: Pietenpol-List: Turnbuckles I'm looking to order the turnbuckles for the aileron and tail brace wires. Got very confused looking at the AC catalog offerings. Help! What do I need to order? Thanks, Jim ________________________________________________________________________________
From: "Perry Rhoads" <prhoads61(at)frontiernet.net>
Subject: Re: Insurance
Date: Jul 04, 2011
John, Your homeowners insurance excludes aircraft and aircraft parts. You need to contact the EAA insurance program.They have coverage available for projects in progress. I believe a few other companies also offer this coverage. Perry Rhoads Piet N12939 ----- Original Message ----- From: amsafetyc(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, July 04, 2011 8:19 AM Subject: Pietenpol-List: Insurance Since moving into the hangar I contacted my Allstate insurance agent to find out about coverage for my almost an airplane. I wasn certain if it woul be considered an airplane or content. They were going to contact home office and get back to me,still waiting..... So the question in my mind is at what point does it become an airplane? Like everyone else I too am highly protective of my thousands of hours of work and up to date accomplishments and would like to bind appropriate coverage for all non act of God perils. Anyone have any suggestions or is that a carrier and or EAA question? I would doubt the leesor would have any coverage beyond structure to protect its assets. So how would I protect mine. Allstate says if its content it could be covered under my homeowners policy but that would be more content and pay only for base materials since its not an airplane yet When it becomes an airplane it would have a policy similar to an auto or motor vehicle policy. As a project its neither an airplane nor a pile of lumber. I am interested to learn the legal aspects of it and anyone elses experience in this area. Not wanting to admit it but I am perplexed and concerned about other remnants in my row Please advise John Sent via DROID on Verizon Wireless =B7>~?=ED=B2,=DE=03g(-S=D3M=D3Gq=A2z=C1=AE ________________________________________________________________________________
Date: Jul 04, 2011
Start by selecting the cable you will use, then select the appropriate components. It helps to draw it out on paper. Attached are a couple of pdf's to get you going. Greg Cardinal Pursuing liberty and happiness this afternoon by going flying..... ----- Original Message ----- From: jim To: Piet list Sent: Sunday, July 03, 2011 7:38 PM Subject: Pietenpol-List: Turnbuckles I'm looking to order the turnbuckles for the aileron and tail brace wires. Got very confused looking at the AC catalog offerings. Help! What do I need to order? Thanks, Jim ________________________________________________________________________________
From: "Charles Campbell" <cncampbell(at)windstream.net>
Date: Jul 04, 2011
Yes! I bought my turnbuckles from B & B for $7.50 each -- about 1/4th what AS charges. In case you don't have it, their address is: B & B Aircraft Supplies, PO Box 37, 202 South Center, Gardner, KS 66030, phone (913) 884-5930, fax (913) 884-6533. Hope that helps. Don't know if they have turnbuckles right now, but you can certainly not go wrong by checking. Good Fortune (I don't believe in Luck). Chuck ----- Original Message ----- From: amsafetyc(at)aol.com To: pietenpol-list(at)matronics.com Sent: Monday, July 04, 2011 9:30 AM Subject: Re: Pietenpol-List: Turnbuckles Jim You may want to order them from B & B you can speak to them and the will help with your application selection. They are if not already preping for Oshkosh so call soon. Great folks to work with helpful and priced much better than others John Happy independance day celebrating by building my Piet no better way to honor those that bought and paid for our freedom Please archive Sent via DROID on Verizon Wireless -----Original message----- From: jim <quinnj(at)sbcglobal.net> To: Piet list Sent: Mon, Jul 4, 2011 00:50:13 GMT+00:00 Subject: Pietenpol-List: Turnbuckles I'm looking to order the turnbuckles for the aileron and tail brace wires. Got very confused looking at the AC catalog offerings. Help! What do I need to order? Thanks, Jim ~=B2=03 ________________________________________________________________________________
Date: Jul 04, 2011
Just for reference. I have a 1948 V tail bonanza. It is currently being hangered/stored in a flight school hanger. They requested that I have insurance. I was able to get it insured for hull and all for $1000 per year. That is whether or not it is flying or in the hanger. (it was only $50 less for non flying insurance.) That is about as cheap as my auto insurance for my 4 cars. Having said that If I rolled my old plane up in a ball it is worth about $20,000 in today's depressed market. At one point it was worth just under $60,000. "Vintage" airplanes have recovered even less than the regular airplane market. Blue Skies, Steve PS Today a group of Cessna pilots will do a "low level" fly around Enid, OK. Clyde Cessna was an Overland car salesman in Enid and built his first plane here. He learned to fly and tested his plane NW of here at the Great Salt Planes. Taking off and crashing 12 times before having a successful flight on his 13th try. He was going to fly this plane at it's first public exhibition in Enid on 4 July 100 years ago. But he did not have the plane ready as fast as he thought he would (sound familiar? )
June 17, 2011 - - - - , 20-
Pietenpol-Archive.digest.vol-kn
