Pietenpol-Archive.digest.vol-kx
December 13, 2011 - January 08, 2012
      Where's a good place to get 8.50x6 tires for an experimental airplane?
      http://forums.matronics.com/viewtopic.php?p=360890#360890
Date: Dec 13, 2011
From: Marvin Haught <handainc(at)madisoncounty.net>
Subject: Re: Tires
I've been using Desser Recaps for years - I've got a set of 8.50 x 6 recaps I use on my Pacer when I fly out to the desert. They have been great. http://www.desser.com/ A lot cheaper than new tires and I've run at least 10 pairs over the years - got one bad tire. M. Haught On 12/13/2011 9:38 PM, Baldeagle wrote: > --> Pietenpol-List message posted by: "Baldeagle" > > Where's a good place to get 8.50x6 tires for an experimental airplane? > > > - > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=360890#360890 > > -- H.Marvin Haught Jr. Haught& Associates, Inc Huntsville, AR 72740 ________________________________________________________________________________
Date: Dec 14, 2011
Subject: 15 inch tires on my Piet
Has anyone used 15 inch 600-6 (low profile) tires on Cleveland wheels? The standard 600-6 is 16 inches.I found a new pair and would like to use them as they would lower the Piet a little and they were cheap. John -- ________________________________________________________________________________
Date: Dec 15, 2011
Subject: Re: Piet builders in northern ill southern wi.
N8031 is at LL53, near Elgin if you're close. Dan On 12/11/2011 08:27 PM, schuerrman wrote: > --> Pietenpol-List message posted by: "schuerrman" > > Hey, I have my fuse mostly done and I was wondering if there's anyone that has a plane I could look at. I've got a stack of visual questions. Thanks. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=360717#360717 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Dec 15, 2011
From: "bradandlinda tds.net" <bradandlinda(at)tds.net>
Your are welcome to look at my Air Camper NX29NX at Burlington Wi. (BUU) Brad Williams 262 534-6054 On Thu, Dec 15, 2011 at 10:13 AM, Dan Yocum wrote: > > N8031 is at LL53, near Elgin if you're close. > > Dan > > On 12/11/2011 08:27 PM, schuerrman wrote: > >> --> Pietenpol-List message posted by: "schuerrman" >> > >> >> Hey, I have my fuse mostly done and I was wondering if there's anyone >> that has a plane I could look at. I've got a stack of visual questions. >> Thanks. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=360717#360717> >> >> >> >> >> >> >> >> >> >> >> > -- > Dan Yocum > Fermilab 630.840.6509 > yocum@fnal.gov, http://fermigrid.fnal.gov > "I fly because it releases my mind from the tyranny of petty things." > > ________________________________________________________________________________
Subject: A65 on eBay
Date: Dec 16, 2011
http://www.ebay.com/itm/250955430013?item=250955430013&viewitem=&sspagename ADME:B:SS:MOTORS:1123&vxp=mtr Jack DSM NX1929T ________________________________________________________________________________
Date: Dec 16, 2011
Not sure what this is, but it's NOT a typical A65-8. Listed as an A65-1. Note the exhaust ports coming out of the tops of the cylinder heads, and the spark plugs relatively far down the cylinder head, and going in at right angles to the cylinder bore. Also, max RPM is listed as 2850, rather than the 2350 of an A65-8. Of course, with only a 54" diameter on the prop, 2850 RPM might be possible, for a while. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____________________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Friday, December 16, 2011 6:59 AM Subject: Pietenpol-List: A65 on eBay http://www.ebay.com/itm/250955430013?item=250955430013&viewitem=&sspagename ADME:B:SS:MOTORS:1123&vxp=mtr Jack DSM NX1929T ________________________________________________________________________________
Subject: Re: A65 on eBay
Date: Dec 16, 2011
I suspect the 2850 is either a typo, or mis-reading of the data plate. >From the following (page 5) the A-65-1 is rated at 65HP at 2350 RPM. http://www.aeronca.com/manuals/Continental_A50_A65_A75_Operators_Handbook.pdf Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361038#361038 ________________________________________________________________________________
Date: Dec 16, 2011
Bill Do you have a manual for the C-85 that is scanned like this? Barry NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church Sent: Friday, December 16, 2011 10:27 AM Subject: Pietenpol-List: Re: A65 on eBay --> I suspect the 2850 is either a typo, or mis-reading of the data plate. >From the following (page 5) the A-65-1 is rated at 65HP at 2350 RPM. http://www.aeronca.com/manuals/Continental_A50_A65_A75_Operators_Handbook.pd f Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361038#361038 ________________________________________________________________________________
Date: Dec 16, 2011
Barry, >From the same website: http://www.aeronca.com/manuals/Continental_C75_C87_Instruction_and_Service_Manual.pdf and http://www.aeronca.com/manuals/Continental_Aircraft_Engine_Service_Parts_Catalog_C75_C85_C90_O200_1975.pdf Lots of other good stuff available (carbs, magneto manuals): http://www.aeronca.com/manuals/ Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361053#361053 ________________________________________________________________________________
Date: Dec 16, 2011
I don't think this was an engine for a GPU. We've discussed these engines before and there's at least one Piet with this model. It's red with squared off wingtips somewhere on the west coast... -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Dec 16, 2011
Its an early model. There's a Fly Baby at Sackman (H49) that has an engine just like it but it is a 'dash' 3.=0AThe more common A-65-8 most of us are familiar with were mostly made post war.=0A=0AJeff Wilson=0AN899WT=0ASt. Lo uis, MO=0A=0A=0A=0A________________________________=0A From: Dan Yocum <yoc um(at)fnal.gov>=0ATo: pietenpol-list(at)matronics.com =0ASent: Friday, December 1 6, 2011 2:34 PM=0ASubject: Re: Pietenpol-List: Re: A65 on eBay=0A =0A--> Pi etenpol-List message posted by: Dan Yocum =0A=0AI don't thi nk this was an engine for a GPU.=0A=0AWe've discussed these engines before and there's at least one Piet with this model.- It's red with squared off wingtips somewhere on the west coast...=0A=0A-- Dan Yocum=0AFermilab- 63 0.840.6509=0Ayocum@fnal.gov, http://fermigrid.fnal.gov=0A"I fly because it ================== ________________________________________________________________________________
Date: Dec 16, 2011
That may have "-1" on the data plate, but it looks like it has been converted into a "-3". The "-1" is only single ignition. Continental built this up until 1939. There are very few of the actual "-1"'s because they had just come out with the 65hp that year and the feds came out with the requirement for dual ignition. I think some time in June of that year. So there was only a couple of months, i think, that the A65-1 was built. They then went to the "-3". The "-3" is the same as the "-8" only it has up exhaust. This one has been converted into the dual ignition "-3". Aeronca was the one that used this the most. The prewar Chiefs used them. A couple of the other manufacturers used them for a short time too. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361073#361073 ________________________________________________________________________________
Subject: Re: A few pics of today's cold flight
Date: Dec 17, 2011
Let it Snow, Let it Snow, Let it Snow!!! December 17 and hardly a skiff on the ground what's up with that? -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361093#361093 Attachments: http://forums.matronics.com//files/dsc00631_190.jpg ________________________________________________________________________________
Date: Dec 18, 2011
Hi Adrian, I am from Watertown SD just South of you. Used to fly my dad's Aeronca Cham p on skis all winter. It wasn't warm but=C2- bet it was warmer than flyin g a Piet in the winter. Nice looking Piet and ski installation. Cheers, Jim B. ________________________________________________________________________________
Subject: Piet Project on eBay
Date: Dec 18, 2011
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180778018592&s sPageName=ADME:B:SS:MOTORS:1123 Jack DSM NX1929T ________________________________________________________________________________
Subject: Jeff Faith's Pietenpol
Date: Dec 18, 2011
I wanted to thank Jeff Faith for letting me come look at his Pietenpol last week, I should have wrote sooner but I could not remember my username so I had to re-register on the list. Jeff was very nice answering all my questions and he made me feel very welcome and not quite so dumb. Jeff gave me lots of pointers and lots of good ideas. Jeff's Pietenpol is very clean and his prop (that he made) is a work of art, it should be in a gallery it is so beautiful. Again Jeff Thanks so much for letting me come and look and I look forward to my next visit. Thanks Walter Allen Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361145#361145 ________________________________________________________________________________
Date: Dec 18, 2011
[quote="boyerjrb(at)comcast.net"]Hi Adrian, I am from Watertown SD just South of you. Used to fly my dad's Aeronca Champ on skis all winter. It wasn't warm but bet it was warmer than flying a Piet in the winter. Nice looking Piet and ski installation. Cheers, Jim B. > [b] Thanks Jim Been through Watertown numerous times, (at least down the interstate) I'm not sure how flying the Piet in the winter will be but will have to pick a warmer day, hopefully around the freezing mark, don't suppose it can be worst then driving a snow machine at 80 mph. Did a lot of ski flying in C-IHJX which had a good heater in it. Great way to get around to do some ice fishing where no one else has been. That's my buddy showing off his fish. Tough to beat a Champ or Cub on skis. Do you own a Piet? -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361149#361149 Attachments: http://forums.matronics.com//files/img_0159_703.jpg http://forums.matronics.com//files/img_0150_175.jpg ________________________________________________________________________________
Subject: A few pics of today's cold flight
Date: Dec 18, 2011
One thing I noticed while flying Scout in colder weather without a cover on the front cockpit is that you get some serious air into the rear cockpit from that front hole. One thing I would be sure to do is to somehow make sure air can't come shooting up your pants legs, because it will. If you don't have drawstrings or can't tuck the legs of your pants into your boots, wrapping with duct tape would be advised if you'll be in the air any length of time. Just my observation on the Texas version of "cold weather" flying. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Center Section Mounted!
Date: Dec 18, 2011
Hey Guys, Thought I would send some updated pictures. I was able to get my center section mounted. Also got the hardware on the wings. I will try and get it out in the yard this week and get the wings on. You gotta love progress! Chuck Raleigh NC 989CB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361164#361164 Attachments: http://forums.matronics.com//files/plane_12_18_11_026r_849.jpg http://forums.matronics.com//files/plane_12_18_11_024r_341.jpg http://forums.matronics.com//files/plane_12_18_11_018r_161.jpg http://forums.matronics.com//files/plane_12_18_11_004r_890.jpg http://forums.matronics.com//files/plane_12_18_11_010r_158.jpg http://forums.matronics.com//files/plane_12_18_11_037r_182.jpg ________________________________________________________________________________
Date: Dec 18, 2011
Looks great, Chuck! Do you need a Technical Counselor inspection anytime soon? I need to get over and see your project again. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of cjborsuk Sent: Sunday, December 18, 2011 7:03 PM Subject: Pietenpol-List: Center Section Mounted! Hey Guys, Thought I would send some updated pictures. I was able to get my center section mounted. Also got the hardware on the wings. I will try and get it out in the yard this week and get the wings on. You gotta love progress! Chuck Raleigh NC 989CB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361164#361164 Attachments: http://forums.matronics.com//files/plane_12_18_11_026r_849.jpg http://forums.matronics.com//files/plane_12_18_11_024r_341.jpg http://forums.matronics.com//files/plane_12_18_11_018r_161.jpg http://forums.matronics.com//files/plane_12_18_11_004r_890.jpg http://forums.matronics.com//files/plane_12_18_11_010r_158.jpg http://forums.matronics.com//files/plane_12_18_11_037r_182.jpg ________________________________________________________________________________
Subject: building table with most miles on it
Date: Dec 18, 2011
Howdy, Pieters- Two years ago at Christmas, my wife and I drove to Shreveport to collect some building materials from Corky Corbett, who built NX41CC- the Piet that I now own and fly. Among the materials that Corky relieved himself of was a building table upon which he constructed two other Piet airframes (I believe). Anyway, we took that table home to San Antonio with us along with enough raw stock to construct a complete Piet fuselage with plywood sides, wing spars, and rib stock. Last Saturday, Dec. 10, I loaded up that building table and all the raw stock along with everything else in my hangar in San Antonio except for Scout (who will have to wait till spring 2012 to fly back up here to Oregon with me) and spent the last week driving from Texas to Oregon and just this weekend unloaded everything and got the building table all set up, along with tools and materials. I hereby lay claim to the Air Camper building table with the most miles on it: 2,540 miles. Picture attached, showing the table in its new location under my temporary "aircraft factory". Very faintly visible on the plywood are the outlines, in pencil, of the Improved Air Camper fuselage framing along with various pencil notes that Corky has made. I'm happy to own this piece of Pietenpol construction history. -------- Oscar Zuniga San Antonio, TX Air Camper NX41CC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361186#361186 Attachments: http://forums.matronics.com//files/p1010037_179.jpg ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Subject: Re: Hardware
Date: Dec 19, 2011
OK, Gary. I received your Christmas present late Saturday, Dec 17. Thank you so very much. I would be willing to at least pay the shipping charges. You are so kind. I looked on our US road atlas yesterday to see if I could find Cool, Cal. It's not listed in the back of the book. It must be just a "wide place in the road." Can you tell me where it is? Did you have any problems laying out the holes in the crush plate to get them to line up perfectly with the holes in the prop? I'm not a machinist and I want to be sure I get it right. What method did you use? Until you are better paid, Chuck ----- Original Message ----- From: "Gboothe5" <gboothe5(at)comcast.net> Sent: Thursday, December 08, 2011 9:44 PM Subject: RE: Pietenpol-List: Re: Hardware > Homemade crush plate...1/4" 6061. > > Gary from Cool > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill > Church > Sent: Thursday, December 08, 2011 6:24 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Hardware > > > > For those who use the Forum, rather than the email version of the > Pietenpol > List, Chuck's message likely didn't make any sense, because the message he > tried to forward did not get posted. I have retrieved it from the > Matronics > site and attached it below: > > ----- Original Message ----- > From: Jay & Carmen > To: C N Campbell > Sent: Thursday, December 08, 2011 2:21 PM > Subject: Re: Hardware > > > Chuck~ > If you're talking about a Crush Plate.... ALL WOOD PROPS should > have a crush plate. > NEVER bolt up or even turn up a wood prop without a crushplate!!! > > The thickness of the crushplate will depend on the type of metal used to > make it... > Could be anywhere from 3/16" to 1/2", depending on the > material it's made from. > Naturally the steel would be on the thinner side of the figure. > > Try Aircraft Spruce, Wicks or maybe Barnstormers.... you have a SAE1 > bolt pattern. > > Please show this to the other guys on your chat group, to make sure > NO-ONE is trying to > bolt up WOOD props without a crushplate. > > Jay > > From: C N Campbell > Sent: Thursday, December 08, 2011 12:46 PM > To: Carmen > Subject: Fw: Hardware > > Carmen, Roger and I have been discussing the type and length of bolts > for my Cloudcars prop and he sent me the E-mail which I am forwarding to > you. Do I need a face plate on my prop. If so, how thick should it be > and where do I get one? Chuck . > ----- Original Message ----- > From: Rogpoldodson(at)aol.com > To: cncampbell(at)windstream.net > Sent: Thursday, December 08, 2011 8:43 AM > Subject: Re: Hardware > > Chuck . Something else you might want to take into account is if you > need a face plate on that prop. Check with the builder of the prop. If > so you will need to take into account the thickness of the plate. Rog. > No virus found in this message. > Checked by AVG - www.avg.com > 12/08/11 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=360492#360492 > > > ________________________________________________________________________________
Subject: Re: Center Section Mounted!
Date: Dec 19, 2011
Awesome! ... the fun part is sitting in her! -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361195#361195 ________________________________________________________________________________
Subject: Re: building table with most miles on it
Date: Dec 19, 2011
Sorry Oscar I carried my table to Sun n Fun and back 1650 mi each way and built my fuselage there. Dick N. ----- Original Message ----- From: "taildrags" <taildrags(at)hotmail.com> Sent: Sunday, December 18, 2011 11:43 PM Subject: Pietenpol-List: building table with most miles on it > > Howdy, Pieters- > > Two years ago at Christmas, my wife and I drove to Shreveport to collect > some building materials from Corky Corbett, who built NX41CC- the Piet > that I now own and fly. Among the materials that Corky relieved himself > of was a building table upon which he constructed two other Piet airframes > (I believe). Anyway, we took that table home to San Antonio with us along > with enough raw stock to construct a complete Piet fuselage with plywood > sides, wing spars, and rib stock. > > Last Saturday, Dec. 10, I loaded up that building table and all the raw > stock along with everything else in my hangar in San Antonio except for > Scout (who will have to wait till spring 2012 to fly back up here to > Oregon with me) and spent the last week driving from Texas to Oregon and > just this weekend unloaded everything and got the building table all set > up, along with tools and materials. > > I hereby lay claim to the Air Camper building table with the most miles on > it: 2,540 miles. Picture attached, showing the table in its new location > under my temporary "aircraft factory". Very faintly visible on the > plywood are the outlines, in pencil, of the Improved Air Camper fuselage > framing along with various pencil notes that Corky has made. I'm happy to > own this piece of Pietenpol construction history. > > -------- > Oscar Zuniga > San Antonio, TX > Air Camper NX41CC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361186#361186 > > > Attachments: > > http://forums.matronics.com//files/p1010037_179.jpg > > > ________________________________________________________________________________
Date: Dec 19, 2011
Oo! Oo! My turn! my turn! I have a big windscreen and it's not a bad ride at all. Let it snow, let is snow, let it snow! Dan ________________________________________________________________________________
Date: Dec 19, 2011
Winter just might be my favorite time to fly.... for about 10 minutes at a time! I think I left nose prints on my windshield from trying to get in too close. Dan, you need to get some skis! Hey, why don't we have a Pietenpol Ski Fly-in? I'll host..... in Ohio. Ha! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361209#361209 ________________________________________________________________________________
Date: Dec 19, 2011
I had a 20+ mph tailwind at 500' AGL heading up to Poplar Grove, yesterday. Of course, that same wind was waiting for me on the way back, so I kept it down on the deck for most of the trip - <100' AGL (while maintaining 500' from structures and people, of course). I got to wave back and forth with a farmer fixing his fence, which is always nice. Gosh, I really like this plane! Skis only work when there's snow and the skiff we got 2 days ago is already gone. :-( Dan On 12/19/2011 12:30 PM, Don Emch wrote: > --> Pietenpol-List message posted by: "Don Emch" > > Winter just might be my favorite time to fly.... for about 10 minutes at a time! I think I left nose prints on my windshield from trying to get in too close. > > Dan, you need to get some skis! Hey, why don't we have a Pietenpol Ski Fly-in? I'll host..... in Ohio. Ha! > > Don Emch > NX899DE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361209#361209 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Dec 19, 2011
Lucky you, to be able to fly. Here at Smith Mountain Lake it's 56=B0, with no wind, clear skies and unlimited visibility ' and the runway=92s closed with heavy equipment all over it, sealing cracks in the asphalt. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum Sent: Monday, December 19, 2011 1:52 PM Subject: Re: Pietenpol-List: Re: A few pics of today's cold flight I had a 20+ mph tailwind at 500' AGL heading up to Poplar Grove, yesterday. Of course, that same wind was waiting for me on the way back, so I kept it down on the deck for most of the trip - <100' AGL (while maintaining 500' from structures and people, of course). I got to wave back and forth with a farmer fixing his fence, which is always nice. Gosh, I really like this plane! Skis only work when there's snow and the skiff we got 2 days ago is already gone. :-( Dan On 12/19/2011 12:30 PM, Don Emch wrote: > --> Pietenpol-List message posted by: "Don Emch" > > Winter just might be my favorite time to fly.... for about 10 minutes at a time! I think I left nose prints on my windshield from trying to get in too close. > > Dan, you need to get some skis! Hey, why don't we have a Pietenpol Ski Fly-in? I'll host..... in Ohio. Ha! > > Don Emch > NX899DE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361209#361209 > > > > > > > > > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Dec 19, 2011
Subject: Tire Size
For all--what size tires are you usin gon Cleveland wheels--standard 600-6? I researched the archives and could not find anytthng on this. Anybody use 800-6--too big? Niice for off-field? John -- John Kuhfahl, Lt Col USAF (Ret), FAA A/P--{freaking trainie compared to you guys} President, KUHLCOUPER LLC ________________________________________________________________________________
Subject: Tire Size
Date: Dec 19, 2011
I have standard Cleveland brakes and 21" x 3.00" wheels Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Kuhfahl Sent: Monday, December 19, 2011 4:08 PM Subject: Pietenpol-List: Tire Size For all--what size tires are you usin gon Cleveland wheels--standard 600-6? I researched the archives and could not find anytthng on this. Anybody use 800-6--too big? Niice for off-field? John -- John Kuhfahl, Lt Col USAF (Ret), FAA A/P--{freaking trainie compared to you guys} President, KUHLCOUPER LLC ________________________________________________________________________________
Subject: Re: Tire Size 8.00 X 6
Date: Dec 19, 2011
John I'm running 8.00X6 Carlyle "turf saver" AMF Harley golf cart tires. They're 4ply & @ 17psi, seem to be holding up well even after 40hrs on my Piet, ev en on the paved surface here @ Lakeville Mn. I also liked the $39.00 a piec e price tag thru a golf cart mail order place, don't remember the name, fou nd them on the internet. Good luck, Bob Poore, Piet NX29LD. -----Original Message----- From: John Kuhfahl <kuhlcouper(at)gmail.com> Sent: Mon, Dec 19, 2011 3:12 pm Subject: Pietenpol-List: Tire Size For all--what size tires are you usin gon Cleveland wheels--standard 600-6? I researched the archives and could not find anytthng on this. Anybody use 800-6--too big? Niice for off-field? John -- John Kuhfahl, Lt Col USAF (Ret), FAA A/P--{freaking trainie compared to you guys} President, KUHLCOUPER LLC - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: - -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Dec 19, 2011
Sounds like it is time for floats Jack.Gardiner=0A=0A=0A=0A=0A_____________ ___________________=0AFrom: Jack Phillips <pietflyr(at)bellsouth.net>=0ATo: pi etenpol-list(at)matronics.com=0ASent: Mon, December 19, 2011 2:09:36 PM=0ASubj ect: RE: Pietenpol-List: Re: A few pics of today's cold flight=0A=0A =0ALuc ky you, to be able to fly. Here at Smith Mountain Lake it's 56=C2=B0, w ith no =0Awind, clear skies and unlimited visibility =93 and the runw ay=99s closed with heavy =0Aequipment all over it, sealing cracks in the asphalt. =0A=0A =0AJack Phillips=0ANX899JP=0ASmith Mountain Lake, Virg inia=0A =0A-----Original Message-----=0AFrom: owner-pietenpol-list-server@m atronics.com =0A[mailto:owner-pietenpol-list-server(at)matronics.com] On Behal f Of Dan Yocum=0ASent: Monday, December 19, 2011 1:52 PM=0ATo: pietenpol-li st(at)matronics.com=0ASubject: Re: Pietenpol-List: Re: A few pics of today's c l.gov>=0A =0AI had a 20+ mph tailwind at 500' AGL heading up to Poplar Grov e, =0Ayesterday.=0A =0AOf course, that same wind was waiting for me on the way back, so I kept =0Ait down on the deck for most of the trip - <100' AGL (while maintaining =0A500' from structures and people, of course). I got to wave back and =0Aforth with a farmer fixing his fence, which is always n ice. Gosh, I =0Areally like this plane!=0A =0ASkis only work when there's snow and the skiff we got 2 days ago is =0Aalready gone. :-(=0A =0ADan=0A =0A =0AOn 12/19/2011 12:30 PM, Don Emch wrote:=0A> --> Pietenpol-List mess age posted by: "Don Emch"=0A> =0A> Winter just might be m y favorite time to fly.... for about 10 minutes at a =0A>time! I think I l eft nose prints on my windshield from trying to get in too =0A>close.=0A> =0A> Dan, you need to get some skis! Hey, why don't we have a Pietenpol Sk i =0A>Fly-in? I'll host..... in Ohio . Ha!=0A> =0A> Don Emch=0A> NX899DE =0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http:// forums.matronics.com/viewtopic.php?p=361209#361209=0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A> =0A =0A-- =0ADan Yocum=0AFermilab 630 .840.6509=0Ayocum@fnal.gov, http://fermigrid.fnal.gov=0A"I fly because it r ============ =0A ________________________________________________________________________________
Subject: Thrust Angle
Date: Dec 19, 2011
Regardless of the engine choice has anyone ever altered ( moved ) the thrust line of their PIETENPOL . Either the Angle ( Up, Down, Left, Right) or height of thrust line in relationship to the top longeron ? What was the result ? Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361243#361243 ________________________________________________________________________________
Date: Dec 19, 2011
Subject: 2011 List of Contributors
Dear Listers, The 2011 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and its time that I publish this year's List of Contributors. Its the people on this list that directly make the Email Lists and Forums possible. Their generous contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some great products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com And finally, I'm proud to present The 2011 Fund Raiser List of Contributors: http://www.matronics.com/loc/2011.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Father/son build team with engine question
Date: Dec 19, 2011
Hello everybody Just wanted to say hi. saw this list and it seems pretty cool. my 7 year old son and just started building a Piet tonight. Standard one piece wing, Model A engine and wood gear. We do have one question to ask. We want a Model-A engine but that wont be for a while. In the mean time I want to keep my eyes peeled for an engine when I come across one. Anything I should be careful for? Any advice on this matter? Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361324#361324 ________________________________________________________________________________
Date: Dec 19, 2011
Really nice job Chuck! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361325#361325 ________________________________________________________________________________
Subject: Re: Father/son build team with engine question
Date: Dec 20, 2011
A one-piece wing requires about 5 people to move it. I am in the process of building my wings and I HIGHLY recommend the 3-piece version. I know nothing of the model A engine. I'm using a Corvair, which I also highly recommend. Good fortune on your project -- whichever way you decide to go. Chuck ----- Original Message ----- From: "MKJ1928" <mike(at)oconomowocplumbing.com> Sent: Monday, December 19, 2011 11:06 PM Subject: Pietenpol-List: Father/son build team with engine question > > > Hello everybody > > Just wanted to say hi. saw this list and it seems pretty cool. my 7 year > old son and just started building a Piet tonight. Standard one piece wing, > Model A engine and wood gear. > > We do have one question to ask. We want a Model-A engine but that wont be > for a while. In the mean time I want to keep my eyes peeled for an engine > when I come across one. Anything I should be careful for? Any advice on > this matter? > > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361324#361324 > > > ________________________________________________________________________________
Date: Dec 20, 2011
I have 2 engine blocks and other parts if you're interested Welcome to the build John Sent from my iPhone On Dec 19, 2011, at 11:06 PM, "MKJ1928" wrote: > > Hello everybody > > Just wanted to say hi. saw this list and it seems pretty cool. my 7 year old son and just started building a Piet tonight. Standard one piece wing, Model A engine and wood gear. > > We do have one question to ask. We want a Model-A engine but that wont be for a while. In the mean time I want to keep my eyes peeled for an engine when I come across one. Anything I should be careful for? Any advice on this matter? > > Mike > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361324#361324 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: 15 inch tires on my Piet
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Dec 20, 2011
I have Wire wheels on mine but my dad has 8.50- 6's on his. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361338#361338 ________________________________________________________________________________
Date: Dec 20, 2011
Subject: Watch out for the bad guys out there
I know few of you would consider parting with your Piet or project, but if you are trying to sell some other form of "inferior" aircraft, beware of the scam buyers out there. I've been trying to sell our Bellanca for a while and got an email from someone claiming to be interested. They didn't try to bargain on the asking price. They claimed to out of the country in the military, and wanted to send an agent/mechanic to check out the airplane. They would send a certified check "guaranteed", paying 10% down with an additional amount for the mechanic, which I was to pass on to him. The catch is that the 'cashiers check' is bogus. If you deposit it in your bank, and then pay out funds, eventually, the check is returned, and you're out whatever you paid the 'mechanic.' If someone wants to buy your airplane, insist on a cashiers check drawn on a US bank for a deposit, to be held in escrow pending the clearance of the check. A bank wire transfer is even better, and you have collected funds pretty much immediately. I'd heard about this before, and when I emailed back asking for payment as above, I, of course, got no response. The thing that pissed me off the worst was that this jerk claimed to be a Marine. When he eventually goes to his reward, may he get poked for all eternity by a squad of Marines with bayonettes. Matt Paxton NX629ML ________________________________________________________________________________
From: "Dortch, Steven D MAJ MIL USA FORSCOM" <steven.d.dortch(at)us.army.mil>
Date: Dec 20, 2011
Subject: Re: Watch out for the bad guys out there
Just for Further INFO. Anyone in the US Military has a US bank account. We have to in order to receive our pay. So anyone claiming to be US Military, even overseas, has a US account. Blue Skies, Steve D ----- Original Message ----- From: Woodflier(at)aol.com Date: Tuesday, December 20, 2011 10:43 Subject: Pietenpol-List: Watch out for the bad guys out there > I know few of you would consider parting with your Piet or project, > but if > you are trying to sell some other form of "inferior" aircraft, > beware of > the scam buyers out there. I've been trying to sell our Bellanca > for a while > and got an email from someone claiming to be interested. They > didn't try to > bargain on the asking price. They claimed to out of the country in > the > military, and wanted to send an agent/mechanic to check out the > airplane. They > would send a certified check "guaranteed", paying 10% down with an > additional amount for the mechanic, which I was to pass on to him. > > The catch is that the 'cashiers check' is bogus. If you deposit it > in your > bank, and then pay out funds, eventually, the check is returned, > and > you're out whatever you paid the 'mechanic.' If someone wants to > buy your > airplane, insist on a cashiers check drawn on a US bank for a > deposit, to be held > in escrow pending the clearance of the check. A bank wire transfer > is even > better, and you have collected funds pretty much immediately. I'd > heard > about this before, and when I emailed back asking for payment as > above, I, of > course, got no response. > > The thing that pissed me off the worst was that this jerk claimed > to be a > Marine. When he eventually goes to his reward, may he get poked for > all > eternity by a squad of Marines with bayonettes. > > Matt Paxton > NX629ML ________________________________________________________________________________
Subject: metal vs wood prop
Date: Dec 20, 2011
I'm getting 1950 rpm static with a wood Sensenich 72x42 on a A65. Flies great, but doesn't climb very well, especially with two pax. Was told I'd do better with a metal prop. A friend with a Taylorcraft and a A65 timed up to a A75 had the same prop and same experience. He went to a metal 72x40 and got a lot better performance. So, another friend, the A and P (IA) who built my friend's A75, had a 72x44 laying around and said to give it a try, he thought I'd do better even though it had more pitch. Put it on today and got 2100 static. Can't fly it, the airport is closed... arg. Can't explain why a metal prop does so much better even with more pitch. I brought both props home and laid them on the dining room table (need to make some bushings for the back of the metal prop) while I do that. I did notice that the metal prop being so much stronger had a cross section about half the size (or less especially as you get to the hub) of the wood prop and wonder if that loss of "frontal area" is what gives so much more performance. We'll see how it flies soon. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361355#361355 ________________________________________________________________________________
Date: Dec 20, 2011
Subject: Re: metal vs wood prop
On 12/20/2011 02:01 PM, tools wrote: > --> Pietenpol-List message posted by: "tools" > > I'm getting 1950 rpm static with a wood Sensenich 72x42 on a A65. The tach is probably off. Mine is. Get a hand-held optical tach reader and point it at the prop. They're $35 at ACS. Flies great, but doesn't climb very well, especially with two pax. > Well, what did you expect from a little old A65, huh? A4 performance? > Was told I'd do better with a metal prop. A friend with a Taylorcraft and a A65 timed up to a A75 had the same prop and same experience. He went to a metal 72x40 and got a lot better performance. > > So, another friend, the A and P (IA) who built my friend's A75, had a 72x44 laying around and said to give it a try, he thought I'd do better even though it had more pitch. > > Put it on today and got 2100 static. Can't fly it, the airport is closed... arg. > > Can't explain why a metal prop does so much better even with more pitch. I brought both props home and laid them on the dining room table (need to make some bushings for the back of the metal prop) while I do that. I did notice that the metal prop being so much stronger had a cross section about half the size (or less especially as you get to the hub) of the wood prop and wonder if that loss of "frontal area" is what gives so much more performance. > Here, let me give ya a hand: http://lmgtfy.com/?q=metal+prop+OR+propellor+efficiency ________________________________________________________________________________
Date: Dec 20, 2011
Ok, I'll double check the tach, but still, isn't it relative? I was surprised I got MORE rpm from a heavier and higher pitched prop. That's what I'm trying to figure out. I never really hoped for A4 performance, but this is different. We're picking our way through the trees! Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361358#361358 ________________________________________________________________________________
Date: Dec 20, 2011
I am using the warp drive prop on my corvair piet qnd it works great and is ground adjustable. Wm Wynne says it is the most efficient. I don't know how it would work on an A65, but would it be worth a try? Cheers, Gardiner ----- Original Message ---- From: tools <n0kkj(at)yahoo.com> Sent: Tue, December 20, 2011 6:22:48 PM Subject: Pietenpol-List: Re: metal vs wood prop Ok, I'll double check the tach, but still, isn't it relative? I was surprised I got MORE rpm from a heavier and higher pitched prop. That's what I'm trying to figure out. I never really hoped for A4 performance, but this is different. We're picking our way through the trees! Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361358#361358 ________________________________________________________________________________
Subject: My table built with steel studs
Date: Dec 20, 2011
Hey guys, thought I would share with you the table top I built. It's 25" x 8' and it's going to be used to build ribs, the tail section, and miscellaneous metal parts. I looked at wood studs but they seemed to be warped. I went to a commercial builders supply house and bought 18ga steel studs and sandwiched it between two 1/4" solid phenolic sheets. Plywood would work but I just happen to have these laying around and they already had holes in them. The steel studs made it perfectly flat and its as still as can be. If any of you need to build a table I'm convinced it would work well for you. The studs were about $6 each and come 16 feet long if you need it. Mike -------- Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361360#361360 Attachments: http://forums.matronics.com//files/table2_748.jpg http://forums.matronics.com//files/table1_154.jpg ________________________________________________________________________________
Date: Dec 20, 2011
Ah, well that explains it then. I agree, the wood looks LOTS and LOTS better, but as I mentioned, not going for any records other than a perfect not fly into trees sort of record! I think the wood prop worked great for Dick (builder and prior owner) as he usually flew it alone and up there (Minnesota) most fields have really nice unobstructed approach and departure paths. Down here in the great hardwood forest, not so much. There's TONS of neat little fields, but they ALL have a wall of trees to get past. Also, I guess the aluminum prop can be re-pitched, rather than have to look for a new prop altogether. Gonna final install the metal 72-44 and see how it does flying. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361367#361367 ________________________________________________________________________________
Subject: Re: My table built with steel studs
Date: Dec 20, 2011
Well Mike, I don't doubt that your work table is "stiff as can be". That's a pretty robust structure. You mention the cost of the studs at $6 each, but there's no mention of the cost of the phenolic sheets. I just did a quick internet search, and if you kept the width down to 24", rather than 25", the phenolic material will probably run about $350 (depending on the grade of phenolic sheets - you could spend $1000 if you felt so inclined). I would hazard a guess that you were given the material. Aside from the cost, I'm just wondering about the practicality of using phenolic sheets as a work table surface. Phenolic is pretty hard stuff - not so easy for driving screws into, and also not so good for drawing on (to loft your rib jig or tail parts). (my 2 cents) Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361368#361368 ________________________________________________________________________________
Date: Dec 20, 2011
Hi Bill Sorry I didn't make it more clear, I just happened to have the phenolic available because my Dad owns a company that manufactures it. The sheets are 4' x 8' out of the press but the sheets I had on hand were from an old pipe rack I made years ago. Plywood makes more sense as I indicated. Your right about the ability to mark it though and I will end up putting a sheet of plywood over it when I'm done to make life easier. They do make special industrial screws exclusively for phenolic but it's not worth the hassle of pre-drilling. The post was meant to be about the steel studs instead of wood ones. It really worked well and because they are near perfect it makes out for a nice and sturdy flat surface. I just wasn't sure if anybody used steel studs so I figured I would offer it up as an option. -------- Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361376#361376 ________________________________________________________________________________
Date: Dec 20, 2011
Okay, it all makes sense now. I agree that finding nice straight wood studs can sometimes be challenging these days. Steel studs are always consistently straight and are not affected by moisture or prone to twisting and warping like wood can be. The heavier gauge ones like you have chosen would be the ones to use for a work surface (as opposed to the light gauge standard studs - they're not so sturdy). Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361378#361378 ________________________________________________________________________________
Date: Dec 20, 2011
I used those steel studs. Riveted two together to make a stiff tube, one on each long edge of the table.Screwed cross members of the same every two feet. Legs with more studding to hold up ply shelves underneath. Top is 3/4" K3,or whatever it's called down your way. This top can be leveled six ways from Sunday with those cedar shingle wedges, depending on how anal you want to be. :-) The table is 4' wide by 14' long. Oh, and I made the frame width a couple of inches less so that the overhang would make for easy clamping of stuff. Also I bought a roll of heavy white paper/cardboard to lay on top for lofting. When you finish a bunch of parts and have that surface covered in lines ( and glue! ) you take it up and lay a fresh sheet for the next batch. Good Lord! THAT was eleven years ago!!! Clif Pilots are a rare kind of human. They leave the ordinary surface of the world, to purify their soul in the sky, and they come down to earth, only after receiving the communion of the infinite." Jos Maria Velasco Ibarra, President of Ecuador > > Well Mike, I don't doubt that your work table is "stiff as can be". That's > a pretty robust structure. You mention the cost of the studs at $6 each, > but there's no mention of the cost of the phenolic sheets.> Bill C. ________________________________________________________________________________
Date: Dec 20, 2011
@ Bill Your 100% accurate about the 18ga. I looked at the 20ga first and the difference is unbelievable. The 18ga feels like a steel beam compared to the 22 or 24. ------- I like the idea of riveting two together, I didn't think of that. I bet that would make out for one heck of a strong unit. -------- Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361383#361383 ________________________________________________________________________________
Date: Dec 20, 2011
Thanks Chuck and John -------- Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361384#361384 ________________________________________________________________________________
Date: Dec 20, 2011
So does this 'mechanic' actually turn up in person to claim his money? If so then I think you've come face to face with the perpetuator. This scam has been around for years. The first time I ran across it was seven years ago. Someone moving from their temporary home in California wanted one of my paintings. they wanted me to ship the painting to the headquarters of their moving company, a PO addy in London, England. The money order arrived but for twice the amount. When querried I was told the guy's wife had misunderstood his instructions and could I please send the extra on to the shipping company in England.Fortunately alarm bells were sounding in my head and I held off long enough to be made aware of the nature of the beast. I gave all the info to the RCMP. Never did find out the outcome. Pretty ballsy of the guy to actually turn up as a mechanic! Clif They didn't try to bargain on the asking price. They claimed to out of the country in the military, and wanted to send an agent/mechanic to check out the airplane. They would send a certified check "guaranteed", paying 10% down with an additional amount for the mechanic, which I was to pass on to him. The catch is that the 'cashiers check' is bogus. Matt Paxton NX629ML ________________________________________________________________________________
Date: Dec 21, 2011
I have a wood Sensenich 72-40 on my A-65 Piet. It has great performance with 2 on board. Have you considered the w&b issues when switching to a metal prop? I know it is on the nose of the plane, but you will be giving up 10 pounds of gross wt. Ben Charvet On 12/20/2011 8:38 PM, tools wrote: > --> Pietenpol-List message posted by: "tools" > > Ah, well that explains it then. I agree, the wood looks LOTS and LOTS better, but as I mentioned, not going for any records other than a perfect not fly into trees sort of record! > > I think the wood prop worked great for Dick (builder and prior owner) as he usually flew it alone and up there (Minnesota) most fields have really nice unobstructed approach and departure paths. Down here in the great hardwood forest, not so much. There's TONS of neat little fields, but they ALL have a wall of trees to get past. > > Also, I guess the aluminum prop can be re-pitched, rather than have to look for a new prop altogether. > > Gonna final install the metal 72-44 and see how it does flying. > > Tools > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361367#361367 > > > _- ________________________________________________________________________________
Date: Dec 21, 2011
I'd like to try a 72-40 wood prop, but have this metal prop available to at least diagnose and experiment. It is about 10 to 15 lbs heavier, but my plane has a battery installed on the firewall to HELP with w and b. I'd be happy to remove the battery to gain the climb performance, so the weight is not an issue. I was doing some research and found a great PDF file from Sensenich talking about prop suitability. It mentioned that a standard prop should allow the engine to develop rated rpm in level flight. My engine has only ever seen almost 2100 rpm in level flight and I think it's rated (still some more reading to do) for 23 to 2400. I saw 2300 once in a full power decent. A cruise prop should allow 150 under rated, a climb prop 150 over, all at full power, level flight. My son and I are having a difficult time with these down in the trees fields with moderate temps. I can't imagine us in the summer when it's HOT and HUMID! And he's pretty light. I flew with Kevin Purtee last summer at Brodhead, he had NO PROBLEM with him and I at 80 degrees. I know it's an entirely different setup, but I'm thinking I should have more climb than I do now. Single occupant, it's no problem as is, though needing such high power settings for so long on climb out seems as though I'm probably paying for more fuel than I really need as well. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361402#361402 ________________________________________________________________________________
Date: Dec 21, 2011
Props really seem to differ quite a bit from one to the next. Pitches can't really be trusted that much from one to the next either. I have a Sensenich 72 X 40 on my Chief and really like it. I had a 72 x 44 Hegy that was repitched to 42 by Hegy on my Piet for a while. I did a lot of prop research a few years back and had Ed Sterba carve a 76 x 36 prop. The Piet didn't lose any cruise and climb was much, much better. The draggy airgrame does much better with a lower pitch larger diameter prop. The gain in disk area from 72" to 76" is about 11% I believe. Shorter takeoffs and greater climb for sure. Then I bought Frank Pavliga's Falcon prop mainly because of the looks and the reputation they have as a good performer. It is a 72 x 44. The performance is almost identical to the Sterba prop...go figure. Airfoil and how the pitch changes over the length of the prop must be big variables. I still think, though for the many manufacturers out there, the ideal Piet prop is something like a 76 x 36 or a 76 x 38. Although it is the standard for many airplanes, I really don't think the Sensenich 72 x 42 is the ideal prop for the Piet. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361404#361404 ________________________________________________________________________________
Date: Dec 21, 2011
My A-65 turns 2300 during climb out, and just goes a hair over that straight and level. If you are only turning 2100 rpm you aren't really seeing 65 hp, and you have to remember Kevin Purtee is seeing close to 100 hp. In spite of being heavier than a lot of Piets, his Corvair really pulls it along well. I bought my Sensenich 72x40 at a swap meet and was worried that it really should have had a 42 pitch, but it seems to be the perfect prop for my setup. Having said all that, if you have a prop that is close to recommended parameters, I don't see any problem with giving it a shot. Question for the list...Does this constitute a change that should be reported to the FAA, and require a short phase 1 test period. Seems like my airworthiness inspector said that it did. Ben I was doing some research and found a great PDF file from Sensenich talking about prop suitability. It mentioned that a standard prop should allow the engine to develop rated rpm in level flight. My engine has only ever seen almost 2100 rpm in level flight and I think it's rated (still some more reading to do) for 23 to 2400. I saw 2300 once in a full power decent. A cruise prop should allow 150 under rated, a climb prop 150 over, all at full power, level flight. My son and I are having a difficult time with these down in the trees fields with moderate temps. I can't imagine us in the summer when it's HOT and HUMID! And he's pretty light. I flew with Kevin Purtee last summer at Brodhead, he had NO PROBLEM with him and I at 80 degrees. I know it's an entirely different setup, but I'm thinking I should have more climb than I do now. ________________________________________________________________________________
Date: Dec 21, 2011
Dick wrote: >Sorry Oscar >I carried my table to Sun n Fun and back 1650 mi each way and built >my fuselage there. I hereby withdraw my claim to having the building table with the most miles on it, and bow at the feet of a better-traveled Piet builder! Dick, you're amazing. I know that you and the other folks who take on the building project year after year are planting seeds, kicking off new projects for new Piet builders, and showing how it's done. My hat is off to you, sir! Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Dec 21, 2011
Dan asked- > Regardless of the engine choice has anyone ever altered ( moved ) the thrust line > of their PIETENPOL . Either the Angle ( Up, Down, Left, Right) or height > of thrust line in relationship to the top longeron ? What was the result ? Scout's engine mount places the engine thrustline close to where the A65-style mount calls for it to be, but I have since changed the thrust angles on it by adding washers, shims, and then eventually (when it was dialed in), spacers. Specifically, I added downthrust and offset, and the result has been that the airplane is more nearly a hands-off cruiser than I could ever have imagined. Here are some re-postings of two of my earlier posts on the subject. From 10/6/10: ================== I'm just doing this to 41CC now, incrementally. First increment was to offset the stab in the direction Jack has stated (to the left, looking forward), by about 3/8". I then removed the bent-metal trim tab at the trailing edge of the rudder. Flew pretty well but still yawed to the left. Should have offset the stab by 1/2" but no more than that. Next increment was to check engine thrustline and it was zero-zero. I have now offset the engine thrustline 2 degrees right and 2 degrees down and although it still yaws to the left, it's getting very close now and the stick forces (elevator) in cruise are improved as well. These adjustments were done using engine mount washers, but after I add another 1/2 degree of right thrust, we're going to machine some aluminum spacers to replace the washers and we're done. Next will be to play with the bungee tension that I have on the elevator bellcrank for nose up trim. I never imagined that 41CC might be a hands-off airplane, but it's looking like it might be possible, in smooth air, with just the right amount of fuel in the tank ;o) ================ >From 12/26/10: ================ I concluded vibration testing on my A75 today, with good results. Recall that before balancing, the Dynavibe was showing 0.51 IPS imbalance at 2150 RPM, which was maximum static at the condition on Dec. 18. We ran some other tests using a different carb venturi and adjusted the engine thrust line, but those had nothing to do with the vibration work. An interim test run using longer AN6 prop bolts with four stacked washers under the heads resulted in a reduction of vibration to 0.27 IPS at 2150 RPM, with just a slight radial change in location of the heavy side of the prop. We were on the right track. Today we added a small 'flyweight' clamped between the two prop bolts across from the side of the prop that the Dynavibe had identified as heavy. It was purposely made a bit heavier than we think will be the final shape of it, allowing for rounding of the edges and then applying paint (it's 4130 steel). Warmed up the engine and ran the Dynavibe averaging again, and achieved 0.07 IPS and now the heavy side has shifted radially on the hub, indicating that we would be chasing small changes from here on, with very limited ways of offsetting the heaviness. So, we called it more than just good (Dynavibe says to shoot for no more than 0.1 IPS). Cowlings back on, engine warmed up, and a test flight in "Scout" was just deee-lightful!!! What a joy, not only in the buttery smoothness of the engine, but leveling out at cruise, the change in engine thrustline offset was very rewarding. Hands off, feet off, half tank of fuel, and the yaw is almost gone... a half-ball of left turning, which a very light touch on the right rudder would stop instantly. I never thought this would be a hands-off airplane, but it's getting very close! We'll reinstall the bent-metal trim tab on the rudder and I'll bet the next flight will show NO yawing tendency with feet off the rudders. This airplane is getting sweeter with every tweak we give it. Of course, it was clear and COLD here today (mid-40s) so Scout climbed wonderfully, but still- the improvements are noticeable and useful. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: EAA Work Bench
From: "johnnysdrop" <johnnysdrop(at)googlemail.com>
Date: Dec 22, 2011
Kringle How do you level the tables and how will you join them together? They look good! English Johnny On rib 13 now. -------- The only way is UP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361462#361462 ________________________________________________________________________________
Date: Dec 22, 2011
Sweet looking tables!- Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Dec 22, 2011
Subject: Operation Arrow Fest Update #1
Today is the start of day six of my Holiday build fest.- After spending a few days with family, I really got started last Monday on the covering of the tail pieces. So far it has been fantastic!- To date I have the vert.s tab. finished, the rudder 98% finished and one elevator underway. Today, I will finish the rudder, continue on elevator #1 and start elevator #2. Once these and the horizontal stabilizer-are finished, I will move on to the ailerons. - It was slow at first, being sure I had the processes and order of operation correct, but now things-progress a little faster. Having a good temperat ure in the shop helps the glue to dry and working multiple items at a time -keep things moving.- Once I learned the proper methods for glueing fab ric to wood and fabric to fabric, it was time to learn how to handle curves and tape curves. Then I moved on to learning rib stitching layout and stit ching knots. Now I know how to do all of the above, use the iron to do the curving and tape work and rib stitch.- It is a great feeling to learn new skills and actually be faily good at them! - My ambitious plan was to have the tail pieces completely done, painted and ready for flight by the end of my three weeks off.- Right now, it appears that I may just make it! Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Dec 22, 2011
Subject: Re: Operation Arrow Fest Update #1
On 12/22/2011 9:23 AM, Michael Perez wrote: > Today is the start of day six of my Holiday build fest. After > spending a few days with family, I really got started last Monday on > the covering of the tail pieces. So far it has been fantastic! To > date I have the vert.stab. finished, the rudder 98% finished and one > elevator underway. Today, I will finish the rudder, continue on > elevator #1 and start elevator #2. Once these and the horizontal > stabilizer are finished, I will move on to the ailerons. > It was slow at first, being sure I had the processes and order of > operation correct, but now things progress a little faster. Having a > good temperature in the shop helps the glue to dry and working > multiple items at a time keep things moving. Once I learned the > proper methods for glueing fabric to wood and fabric to fabric, it was > time to learn how to handle curves and tape curves. Then I moved on to > learning rib stitching layout and stitching knots. Now I know how to > do all of the above, use the iron to do the curving and tape work and > rib stitch. It is a great feeling to learn new skills and actually be > faily good at them! > My ambitious plan was to have the tail pieces completely done, painted > and ready for flight by the end of my three weeks off. Right now, it > appears that I may just make it! > > Michael Perez > Karetaker Aero > www.karetakeraero.com > The Stewart System glue sure makes it easy to handle the curves, doesn't it! -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Subject: Covering question
Date: Dec 22, 2011
Some of you may remember that back in October/November, Barnstormers had an ad for a Pietenpol project that was up in Warren, ME. 6 months of the year, I live about 35 miles from there so road trip it is. Bought the project on the spot for several reasons. 1. The fellow and his son who built the thing also restored and built classy wooden canoes; Old Town and the like. I saw the level of craftsmanship on them and on the Piet was, embarrassingly, better than mine and not just a little. 2. The guy who did the welding of the landing gear, engine mount, and so on, is the head guy in the restoration shop at Owl's Head Transportation Museum (ohtm.org). They fly rides in a Waco and Stearman and have made FLYING replicas of a Bleriot, a Taube, a Curtiss D, and a bunch of others. He knows how to weld. 3. The father and son did not work in a vacuum. Some of you may know Karl Erickson. He's been around Piets for years and has owned, I think, 3. He provided the equivalent of Tech Counselor advice. 4. The project was essentially ready for cover, saving me probably 2 years. The plane had been assembled and the control rigging done so the major project groups left are covering, FWF, and instruments. This is all by way of preface. The duo covered the tail feathers and ailerons with ceconite and butyrate dope using 1.7 oz fabric and there is enough 1.7 oz fabric to do the rest of the plane. Meanwhile, I have purchased enough 2.7 oz fabric to do an entire airplane and gotten a start on purchasing the Stewart system glue and stuff. Finally, the question. What do I do with the tail feathers and 1.7 oz fabric? Looks like I have several choices. 1. Leave the tail feathers as is and do the rest of the plane with either 1.7 or 2.7 fabric A local A&P says that you shouldn't mix em. 2. Strip the old dope and fabric off and start over with either 1.7 or 2.7 oz fabric. 3. Just continue with the dope and use the Stewart another day. All choices imply a question of which fabric is preferable. I am inclined to option 2 with the heavier fabric on at least the fuselage. Any inputs are appreciated. I've looked at the archives for fabric preference and found a spectrum of opinions. Does the use of the Stewart system change any of them? Included in the pile o stuff was a set (4) of cub lift struts. For those of you who have used them, would you do it again or just start with new? Again, the archives are ambivalent. Thanks in advance. Dave Aldrich Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361493#361493 ________________________________________________________________________________
Subject: Re: Covering question
Date: Dec 22, 2011
Dave If I had bought an airframe ready to cover it would have saved me 11 (and still counting) years of building not two years. To name a few long time flyers Mike Cuy, Earl Myers and Steve Eldredge used 1.7 oz. on their whole plane. I plan on using it too because I will eventually get to that point. >From the archives Greg- Superflite was pretty good to deal with in sending me their 1.7 oz non-cert. fabric. They have a web site too which is: http://www.superflite.com/cov.html#fabric They are located in IL. PS- the only thing I had to hunt around for was matching 1.7 oz. finishing tapes....the pinked edged stuff you put over ribs, leading edges, trailing edges etc. that comes in all kinds of various widths depending on your need. I had to order those hit and miss from whomever had them in the 1.7 oz weight. Wicks, ACS, some independent Polyfiber dealers. If you use the 1.7 oz. try to use 1.7 oz tapes too. The reason for this is that the 1.7 oz has a fine weave that will fill nicely. (read less coats, less sanding, less weight, nicer finished appearance) If you use heavier grades of fabric for your finishing tapes you'll find number one, they are more stiff and don't lay down or curve around as easy as the lighter tapes, and number two, they have a more coarse weave to them and will take more schtuff to fill the weave to match the rest of your finish. It is fine to do though......just some observations. Mike C. David; I always use the 1.7oz fabric with the textbook Stits or now the Polyfiber process. It gives a nice low luster finish plus I used the flat rib chord with the knots pulled inside the fabric. That makes for a really nice final finish to the rib stitching, no knots. Mike Cuy had a standard dope finish with a brightener added in his final coat to give it a VERY high gloss...........I just wanted to stay with an antique finish which mostly were low luster even then except for the high-priced ships with hand rubbed Nitrate/Butyrate (dope) finishes..... Earl Myers I used the 1.7oz generic dacron from As&S. It was about $3.65 a yard. I used the generic tapes, and poly fiber products to glue it down. rib stitching was with round cord, not flat. Steve E. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361499#361499 ________________________________________________________________________________
Date: Dec 22, 2011
It really does! The Ekobond and some heat work great! Michael Perez Karetaker Aero www.karetakeraero.com --- On Thu, 12/22/11, Ben Charvet wrote: > From: Ben Charvet <bencharvet(at)gmail.com> > Subject: Re: Pietenpol-List: Operation Arrow Fest Update #1 > To: pietenpol-list(at)matronics.com > Date: Thursday, December 22, 2011, 11:01 AM > > > > > > > On 12/22/2011 9:23 AM, Michael Perez wrote: > > > > > > Today is the start of day six of my > Holiday build > fest. After spending a few days with > family, I really > got started last Monday on the covering of > the tail > pieces. So far it has been fantastic! > To date I have > the vert.stab. finished, the rudder 98% > finished > and one elevator underway. Today, I will > finish the > rudder, continue on elevator #1 and start > elevator #2. > Once these and the horizontal > stabilizerare finished, I > will move on to the ailerons. > > It was slow at first, being sure I had > the processes > and order of operation correct, but now > thingsprogress > a little faster. Having a good temperature > in the shop > helps the glue to dry and working multiple > items at a > timekeep things moving. Once I > learned the proper > methods for glueing fabric to > wood and > fabric to fabric, it was time to learn how > to handle > curves and tape curves. Then I moved on to > learning rib > stitching layout and stitching knots. Now I > know how to > do all of the above, use the iron to do the > curving and > tape work and rib stitch. It is a > great feeling to > learn new skills and actually be faily good > at them! > > My ambitious plan was to have the tail > pieces > completely done, painted and ready for > flight by the end > of my three weeks off. Right now, it > appears that I may > just make it! > > > > Michael Perez > > Karetaker Aero > > www.karetakeraero.com > > > > > > The Stewart System glue sure makes it easy to handle > the curves, > doesn't it! > > > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > > > > > > > provided > > ________________________________________________________________________________
Date: Dec 22, 2011
Well, I am covering now and only have limited experience with Superflite's 104 fabric. (1.7 oz) Their fabric comes 72" wide which is perfect to cover the wings, other places have 60" I believe. Any idea how wide your 1.7 is? They also sell an entire line of 1.7 oz tapes. If you decide to keep the 1.7 oz fabric and need tapes, check them out. (If you decide to sell said fabric, I would be interested...I need more to do the fuselage and wings.) If it were my decision, I would go for lighter weight. Since the tail is done, continue to do the rest of the plane with the 1.7. If you use it, I think you'll love the Ekobond. Michael Perez Karetaker Aero www.karetakeraero.com --- On Thu, 12/22/11, dgaldrich wrote: > From: dgaldrich <dgaldrich(at)embarqmail.com> > Subject: Pietenpol-List: Covering question > To: pietenpol-list(at)matronics.com > Date: Thursday, December 22, 2011, 5:55 PM > --> Pietenpol-List message posted > by: "dgaldrich" > > Some of you may remember that back in October/November, > Barnstormers had an ad for a Pietenpol project that was up > in Warren, ME. 6 months of the year, I live about 35 > miles from there so road trip it is. Bought the > project on the spot for several reasons. 1. The > fellow and his son who built the thing also restored and > built classy wooden canoes; Old Town and the like. I > saw the level of craftsmanship on them and on the Piet was, > embarrassingly, better than mine and not just a > little. 2. The guy who did the welding of the > landing gear, engine mount, and so on, is the head guy in > the restoration shop at Owl's Head Transportation Museum > (ohtm.org). They fly rides in a Waco and Stearman and > have made FLYING replicas of a Bleriot, a Taube, a Curtiss > D, and a bunch of others. He knows how to weld. > 3. The father and son did not work in a vacuum. > Some of you may know Karl Erickson. He's been around > Piets for years and has owned, I think, 3. He provided > the equivalent ! > of Tech Counselor advice. 4. The project was > essentially ready for cover, saving me probably 2 > years. The plane had been assembled and the control > rigging done so the major project groups left are covering, > FWF, and instruments. > > This is all by way of preface. The duo covered the > tail feathers and ailerons with ceconite and butyrate dope > using 1.7 oz fabric and there is enough 1.7 oz fabric to do > the rest of the plane. Meanwhile, I have purchased > enough 2.7 oz fabric to do an entire airplane and gotten a > start on purchasing the Stewart system glue and stuff. > > Finally, the question. What do I do with the tail > feathers and 1.7 oz fabric? Looks like I have several > choices. 1. Leave the tail feathers as is and do > the rest of the plane with either 1.7 or 2.7 fabric A > local A&P says that you shouldn't mix em. 2. > Strip the old dope and fabric off and start over with either > 1.7 or 2.7 oz fabric. 3. Just continue with the > dope and use the Stewart another day. All choices > imply a question of which fabric is preferable. I am > inclined to option 2 with the heavier fabric on at least the > fuselage. > > Any inputs are appreciated. I've looked at the > archives for fabric preference and found a spectrum of > opinions. Does the use of the Stewart system change > any of them? > > Included in the pile o stuff was a set (4) of cub lift > struts. For those of you who have used them, would you > do it again or just start with new? Again, the > archives are ambivalent. > > Thanks in advance. > > Dave Aldrich > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361493#361493 > > > > > > > > Lists This Month -- > Some AWESOME FREE Gifts!) > Raiser. Click on > out more about > Gifts provided > www.aeroelectric.com > www.buildersbooks.com > www.homebuilthelp.com > -Matt > Dralle, List Admin. > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Dec 22, 2011
Covered NX929DH in 1.7 oz. fabric. Glad I did. Dan Helsper Puryear, TN -----Original Message----- From: dgaldrich <dgaldrich(at)embarqmail.com> Sent: Thu, Dec 22, 2011 4:58 pm Subject: Pietenpol-List: Covering question > Some of you may remember that back in October/November, Barnstormers had an ad or a Pietenpol project that was up in Warren, ME. 6 months of the year, I live bout 35 miles from there so road trip it is. Bought the project on the spo t or several reasons. 1. The fellow and his son who built the thing also estored and built classy wooden canoes; Old Town and the like. I saw the l evel f craftsmanship on them and on the Piet was, embarrassingly, better than mi ne nd not just a little. 2. The guy who did the welding of the landing gear, ngine mount, and so on, is the head guy in the restoration shop at Owl's He ad ransportation Museum (ohtm.org). They fly rides in a Waco and Stearman and ave made FLYING replicas of a Bleriot, a Taube, a Curtiss D, and a bunch of thers. He knows how to weld. 3. The father and son did not work in a vac uum. ome of you may know Karl Erickson. He's been around Piets for years and ha s wned, I think, 3. He provided the equivalent ! of Tech Counselor advice. 4. The project was essentially ready for cover, aving me probably 2 years. The plane had been assembled and the control igging done so the major project groups left are covering, FWF, and nstruments. This is all by way of preface. The duo covered the tail feathers and ailer ons ith ceconite and butyrate dope using 1.7 oz fabric and there is enough 1.7 oz abric to do the rest of the plane. Meanwhile, I have purchased enough 2.7 oz abric to do an entire airplane and gotten a start on purchasing the Stewart ystem glue and stuff. Finally, the question. What do I do with the tail feathers and 1.7 oz fabr ic? ooks like I have several choices. 1. Leave the tail feathers as is and do the est of the plane with either 1.7 or 2.7 fabric A local A&P says that you houldn't mix em. 2. Strip the old dope and fabric off and start over with ither 1.7 or 2.7 oz fabric. 3. Just continue with the dope and use the tewart another day. All choices imply a question of which fabric is referable. I am inclined to option 2 with the heavier fabric on at least t he uselage. Any inputs are appreciated. I've looked at the archives for fabric prefere nce nd found a spectrum of opinions. Does the use of the Stewart system change any f them? Included in the pile o stuff was a set (4) of cub lift struts. For those o f you ho have used them, would you do it again or just start with new? Again, th e rchives are ambivalent. Thanks in advance. Dave Aldrich ead this topic online here: http://forums.matronics.com/viewtopic.php?p=361493#361493 - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Metal primer
Date: Dec 22, 2011
Like a few others on the list I've got a few holiday "days" off. I'm going to weld my wing cabane fittings and want to get them primed. I know Bingelis says zinc chromate for priming the metal. I've found it available at Aircraft Spruce and Wicks, but was wondering if it was an item I might find (or substitute) locally. I live in a small town but it has 3 autobody shops that have auto metal primers, but the ones I've seen don't have zinc chromate as an ingredient. Is it okay to use a metal primer (such as for autos) that doesn't have zinc chromate (or phosphate) as a component? Or is this something I need to order from an aircraft supply company (like I've done for all wood, metals, glues, bolts, cables, etc.) Thanks, Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361513#361513 ________________________________________________________________________________
Date: Dec 22, 2011
For what it's worth, zinc chromate doesn't offer very good protection compared to one of the newer 2-part epoxy primers. I'd go ahead and order one of them made by Randolph or Poly Fiber and get it from Aircraft Spruce rather than just using a rattle can primer. A lot of the metal parts on a Pietenpol are not easy to get to for inspection and may have undetected rust. I'd use the best primer money can buy, which is epoxy. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tdudley(at)umn.edu Sent: Thursday, December 22, 2011 10:05 PM Subject: Pietenpol-List: Metal primer Like a few others on the list I've got a few holiday "days" off. I'm going to weld my wing cabane fittings and want to get them primed. I know Bingelis says zinc chromate for priming the metal. I've found it available at Aircraft Spruce and Wicks, but was wondering if it was an item I might find (or substitute) locally. I live in a small town but it has 3 autobody shops that have auto metal primers, but the ones I've seen don't have zinc chromate as an ingredient. Is it okay to use a metal primer (such as for autos) that doesn't have zinc chromate (or phosphate) as a component? Or is this something I need to order from an aircraft supply company (like I've done for all wood, metals, glues, bolts, cables, etc.) Thanks, Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361513#361513 ________________________________________________________________________________
Subject: Re: Metal primer
Date: Dec 22, 2011
Tom, Another alternative to consider is powder coating your metal parts (as opposed to using wet paint). If you're going to powder coat, there's no primer required - the powder basically melts directly onto the surface of the steel, forming a very strong mechanical bond. Powder coating is extremely durable, and environmentally friendly (no solvents). Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361516#361516 ________________________________________________________________________________
Date: Dec 23, 2011
I was going to suggest both of those, instead I will second them both. I used to paint in the USAF, we used two part epoxy primer. I reckon if it's good enough for 400 KTS, it's good enough for 80. After watching a friend of mine powder coat a few car parts I was impressed with just how simple and fast it was. He used an old second hand oven in his work shop set to the highest temp. HF has a powder coating setup for 75 bucks and the powder for 5. If you're already setup for paint, then I'd look at a two part epoxy primer. If you need to go shopping, then consider powder coating. 80 for the equipment and the powder of your choice and the cost of an old oven from Craigslist, the process was simple too, preheat the part, apply powder, bake on and cool. Jim. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361522#361522 ________________________________________________________________________________
Subject: New Member, NW Arkansas
From: "RickBright" <brightwellrichard(at)yahoo.com>
Date: Dec 23, 2011
Just a guy who wants to fly here, I recently found this site and saw a picture of an Pietenpol for my first time a few weeks ago and am in the very early stages of fullfilling a life long dream... I have a 80 acre pasture behind my house and for years have thought of flying something out of it. I learned to fly in 1973 when I was 17, took lessons and did a few cross countries in a Cessna, spent 12 years in the Navy, married, allowed life to get in the way and have not flown in years. I wrote down the name Pietenpol on a piece of paper a week ago, went to an elderly neighbor of mine who is a master mechinic, machinist, Model A nut and asked him if he had ever heard of one. He gave me that look, said come in the shop, went to a desk started pulling old aviation clippings and articles, several on Pietenpol's. Knew all about them. I am a former cabinet maker, do metal work and blacksmithing, have a shop full of metal and woodworking machines, all my machines are old school manual machines but they seem to get the work done. Are there any members in the Arkansas, Missouri Oklahoma area who would like a visitor? I would appreciate getting to see a project or a completed aircraft. Also I am looking at the project presently on E-Bay, any thoughts or comments appreciated. I know this would advance me a couple of years. The project is wider and some {4") has been added to the length. Can someone tell me if extra length would prevent me from going with the Model A Engine? Thanks in advance Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361524#361524 ________________________________________________________________________________
Date: Dec 23, 2011
I have a little of both on my Piet, 1.7 oz and 2.7 oz. I've used both Poly Fiber and dope on different projects. I'm a fan of dope. But that's just my preference. Darn dope prices really jumped a couple of months ago. Just placed an order and was really shocked compared to an order I placed back in the summer... Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361527#361527 ________________________________________________________________________________
Date: Dec 23, 2011
Another thought is to head down to the local NAPA. They sell a two part epoxy primer that is very similar to the Randolph and Poly Fiber. Can be sprayed with thinning or just brushed on for pretty good results. Covering materials won't bother it... Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361528#361528 ________________________________________________________________________________
Subject: Re: New Member, NW Arkansas
Date: Dec 23, 2011
Rick... Sounds like you are really set up to build a Piet. Just something to consider... if you are going to use a Model A it is best to really adhere to the plans and really keep it light. Just ask the guys that have built and are flying Model A Piets. I think you would be happier if you built from the beginning. Just my thoughts though. If you are ever in the NE Ohio or Western PA area, look me up. I could show you mine or a little ways off are Frank Pavliga's Sky Gypsy and Alan Rudolph's '33 example with a Model A. All three could be seen in a matter of a couple hours. Don Emch NX899DE (330) 429-5265 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361529#361529 ________________________________________________________________________________
Subject: Terne Plate Tank Builders FYI
Date: Dec 23, 2011
For any of you that are building a terneplate tank like in the plans, I have a resource for you. While repairing some 70 year old Taylorcraft terneplate tanks I came across these guys... http://josephjenkins.com/store/ They stock the old hand irons, tin, the correct solder, and flux. Great prices. Really great people to talk to, too, about soldering. Now if you can just find Larry Williams' old article about soldering up a tank, you're all set to build a cheap functional tank. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361530#361530 ________________________________________________________________________________
Date: Dec 23, 2011
Rick, I agree with Don. I purchased a partially completed Piet and ended up using very little of the project. I sold the ribs, tail and gave the fuselage to a friend. I'm redoing the wheels to make them acceptable. Jack DSM NX1929T -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Don Emch Sent: Friday, December 23, 2011 6:28 AM Subject: Pietenpol-List: Re: New Member, NW Arkansas Rick... Sounds like you are really set up to build a Piet. Just something to consider... if you are going to use a Model A it is best to really adhere to the plans and really keep it light. Just ask the guys that have built and are flying Model A Piets. I think you would be happier if you built from the beginning. Just my thoughts though. If you are ever in the NE Ohio or Western PA area, look me up. I could show you mine or a little ways off are Frank Pavliga's Sky Gypsy and Alan Rudolph's '33 example with a Model A. All three could be seen in a matter of a couple hours. Don Emch NX899DE (330) 429-5265 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361529#361529 ________________________________________________________________________________
Date: Dec 23, 2011
Last time I painted anything aircraft I used Epoxy Zinc Chromate. Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Metal primer > From: tdudley(at)umn.edu > Date: Thu=2C 22 Dec 2011 19:04:51 -0800 > To: pietenpol-list(at)matronics.com > > > Like a few others on the list I've got a few holiday "days" off. I'm goin g to weld my wing cabane fittings and want to get them primed. > > I know Bingelis says zinc chromate for priming the metal. I've found it a vailable at Aircraft Spruce and Wicks=2C but was wondering if it was an ite m I might find (or substitute) locally. I live in a small town but it has 3 autobody shops that have auto metal primers=2C but the ones I've seen don' t have zinc chromate as an ingredient. > > Is it okay to use a metal primer (such as for autos) that doesn't have zi nc chromate (or phosphate) as a component? Or is this something I need to o rder from an aircraft supply company (like I've done for all wood=2C metals =2C glues=2C bolts=2C cables=2C etc.) > > Thanks=2C > > Tom > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361513#361513 > > > > > > > =========== =========== =========== =========== =========== > > > ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Date: Dec 23, 2011
Jim said, ......... consider powder coating. 80 for the equipment and the powder of your choice and the cost of an old oven from Craigslist, the process was simple too, preheat the part, apply powder, bake on and cool. OK. I'll ask the question ---- "Where do we get the instructions on how to Powder Coat?" Chuck ________________________________________________________________________________
Date: Dec 23, 2011
Jim now says: There are a lot of articles out there on the world wide interweb on how people have done it... Here's one (didn't read the entire article but it looks like good info) I found after doing a quick google search: http://homemetalshopclub.org/projects/powder.pdf There's really not much to the process. Sandblast the parts...spray on the powder....bake. If you decide to move forward, let me know and I'll take some pics of my setup, add some comments and send them to you. Or contact me offlist and we can get on the phone. I may be coming out to Raleigh in late January (don't know for sure yet...) so get your stuff setup and we an do some powder coating when I get there! :-) Happy holidays to everyone! JM -----Original Message----- >From: C N Campbell <cncampbell(at)windstream.net> >Sent: Dec 23, 2011 7:22 AM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Re: Metal primer > > >Jim said, >......... consider powder coating. 80 for the equipment and the powder of >your choice and the cost of an old oven from Craigslist, the process was >simple too, preheat the part, apply powder, bake on and cool. > >OK. I'll ask the question ---- "Where do we get the instructions on how to >Powder Coat?" Chuck > > ________________________________________________________________________________
Date: Dec 23, 2011
Subject: Old Member....NE Oklahoma
Hi Rick! Welcome to the list. To say that you will not find a better group of people anywhere is a bit of an understatement. Mr Pietenpol's wonderful design and the friends you'll make here all adds up to what can be an incredible adventure. If you'll build to the plans and stick with it. If you're the Richard Brightwell in the Harrison area, I'm just about straight west of you, between Tulsa and Joplin. Not far as the crow flys but as we know, it can take forever to drive those roads in your area! I have a Model A Piet, almost ready to cover. So you better hurry and get over here and....nah, you have plenty of time! :-) I just went from "part time" to "full time" employment and haven't been getting much done lately. And Mark Chouinard is building a Piet (I'm sure he'll also respond to your note) near Tulsa. I'm sure I can speak for both of us and say please come over for a visit! Check out westcoastpiet.com for a wealth of Pietenpol information, primarily the pictures. Contact me offlist whenever you're in the are and let's get together for a visit! Jim Markle -----Original Message----- >From: RickBright <brightwellrichard(at)yahoo.com> >Sent: Dec 23, 2011 4:50 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: New Member, NW Arkansas > > >Just a guy who wants to fly here, I recently found this site and saw a picture of an Pietenpol for my first time a few weeks ago and am in the very early stages of fullfilling a life long dream... I have a 80 acre pasture behind my house and for years have thought of flying something out of it. I learned to fly in 1973 when I was 17, took lessons and did a few cross countries in a Cessna, spent 12 years in the Navy, married, allowed life to get in the way and have not flown in years. > I wrote down the name Pietenpol on a piece of paper a week ago, went to an elderly neighbor of mine who is a master mechinic, machinist, Model A nut and asked him if he had ever heard of one. He gave me that look, said come in the shop, went to a desk started pulling old aviation clippings and articles, several on Pietenpol's. Knew all about them. > I am a former cabinet maker, do metal work and blacksmithing, have a shop full of metal and woodworking machines, all my machines are old school manual machines but they seem to get the work done. > Are there any members in the Arkansas, Missouri Oklahoma area who would like a visitor? I would appreciate getting to see a project or a completed aircraft. > Also I am looking at the project presently on E-Bay, any thoughts or comments appreciated. I know this would advance me a couple of years. The project is wider and some {4") has been added to the length. Can someone tell me if extra length would prevent me from going with the Model A Engine? > >Thanks in advance >Rick > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=361524#361524 > > ________________________________________________________________________________
Date: Dec 23, 2011
Here are a couple of videos demonstrating the process: http://www.youtube.com/watch?v=T01zIKxP0Ms&feature=related http://www.youtube.com/watch?v=NS0LCiDaqUc Bill (not a Jim) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361543#361543 ________________________________________________________________________________
Subject: Re: Old Member....NE Oklahoma
Date: Dec 23, 2011
Jim, Thanks for the reply and the invitation, you and Mark will be hearing from me. Yes I am just SW of Harrison. Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361550#361550 ________________________________________________________________________________
Date: Dec 23, 2011
Jack&Don, Thanks for the reply, you both are saying what I am thinking....At the end of what I know will be a very involved project it wll be nice to look at the Pietenpol and say "I built it" rather than "I built it, well part of it" and that will be I suspect worth a lot. Don, thanks for the invitation, if I am ever in your area I will contact you. Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361552#361552 ________________________________________________________________________________
Date: Dec 23, 2011
Also check out westcoastpiet dot com. Thousands of pictures of hundreds projects in every imaginable stage of construction. I also think that if you have enough of an interest in wood/metal working that you have an entire shop, then just building one from the ground up would probably make you happier. The construction is very simple and fast even for a novice, for a person with some skills and some time construction would be very very fast. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361553#361553 ________________________________________________________________________________
Subject: Re: Father/son build team with engine question
Date: Dec 23, 2011
Mike, The same offer goes out to you too. If you are ever in the NE Ohio or Western PA area, please look me up. I think it's awesome that you are looking at this as a father and son project. I try to include my kids as much as possible. My daughters do prretty good at putting up with me, but my son really seems to enjoy the Piet and airplanes in general. Lots of great memories. That's what it's all about! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361554#361554 ________________________________________________________________________________
Date: Dec 23, 2011
I don't think you can buy REAL zinc chromate primer any longer thanks to the EPA. Maybe Chromium is a toxic heavy metal? The "new" stuff seems to be no better than weak green paint. Jack Phillips has the correct answer, just use a self-etching epoxy primer available at any auto paint store. The brand we use is Variprime. It works great and gives great "tooth" for the topcoat to stick to. Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tdudley(at)umn.edu Sent: Thursday, December 22, 2011 10:05 PM Subject: Pietenpol-List: Metal primer --> Like a few others on the list I've got a few holiday "days" off. I'm going to weld my wing cabane fittings and want to get them primed. I know Bingelis says zinc chromate for priming the metal. I've found it available at Aircraft Spruce and Wicks, but was wondering if it was an item I might find (or substitute) locally. I live in a small town but it has 3 autobody shops that have auto metal primers, but the ones I've seen don't have zinc chromate as an ingredient. Is it okay to use a metal primer (such as for autos) that doesn't have zinc chromate (or phosphate) as a component? Or is this something I need to order from an aircraft supply company (like I've done for all wood, metals, glues, bolts, cables, etc.) Thanks, Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361513#361513 ________________________________________________________________________________
Subject: Re: Terne Plate Tank Builders FYI
Date: Dec 23, 2011
Don: Thanks for the tool source. Can you suggest a source for terne plate? I have looked pretty hard, and short of buying a 40,000 lb truckload I haven't had much luck finding it. I was thinking that galvanized sheet was going to be the best I could do. Brett Phillips Strasburg, VA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361558#361558 ________________________________________________________________________________
Date: Dec 23, 2011
Jim, Thanks for the info. After reading that article I think I will stick to painting. The paint will last as long as I do and I don't really need it to be that pretty. You are welcome here anytime but I'm more than a hundred miles west of Raleigh. If you're ever in Winston-Salem (even Greensboro) call me. Would love to get together. I'll protect all my tools! ;>) Chuck > http://homemetalshopclub.org/projects/powder.pdf > > > ________________________________________________________________________________
Date: Dec 23, 2011
Rick I live east of JM and just north of Tulsa. I have a corvair powered Piet. Welcome. If you are over this way maybe we can get together . Merry Christmas all. Jim Ballew N38B In a message dated 12/23/2011 4:53:05 A.M. Central Standard Time, brightwellrichard(at)yahoo.com writes: --> Pietenpol-List message posted by: "RickBright" Just a guy who wants to fly here, I recently found this site and saw a picture of an Pietenpol for my first time a few weeks ago and am in the very early stages of fullfilling a life long dream... I have a 80 acre pasture behind my house and for years have thought of flying something out of it. I learned to fly in 1973 when I was 17, took lessons and did a few cross countries in a Cessna, spent 12 years in the Navy, married, allowed life to get in the way and have not flown in years. I wrote down the name Pietenpol on a piece of paper a week ago, went to an elderly neighbor of mine who is a master mechinic, machinist, Model A nut and asked him if he had ever heard of one. He gave me that look, said come in the shop, went to a desk started pulling old aviation clippings and articles, several on Pietenpol's. Knew all about them. I am a former cabinet maker, do metal work and blacksmithing, have a shop full of metal and woodworking machines, all my machines are old school manual machines but they seem to get the work done. Are there any members in the Arkansas, Missouri Oklahoma area who would like a visitor? I would appreciate getting to see a project or a completed aircraft. Also I am looking at the project presently on E-Bay, any thoughts or comments appreciated. I know this would advance me a couple of years. The project is wider and some {4") has been added to the length. Can someone tell me if extra length would prevent me from going with the Model A Engine? Thanks in advance Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361524#361524 ________________________________________________________________________________
Date: Dec 23, 2011
Brett=2C there is s sheet metal place right by my house that sells it. We should talk=2C I might be remaking my tank also. Gene > Subject: Pietenpol-List: Re: Terne Plate Tank Builders FYI > From: bphillip(at)shentel.net > Date: Fri=2C 23 Dec 2011 11:01:25 -0800 > To: pietenpol-list(at)matronics.com > net> > > Don: > Thanks for the tool source. Can you suggest a source for terne plate? I have looked pretty hard=2C and short of buying a 40=2C000 lb truckload I h aven't had much luck finding it. I was thinking that galvanized sheet was going to be the best I could do. > > Brett Phillips > Strasburg=2C VA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361558#361558 > > > > > > > =========== =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 23, 2011
The old ZInc Chromate primer contained lead. This is no longer true. If y ou use a "self etching primer" make sure it containes zinc tetroxychromate otherwise it contains not anti corrosive qualities. I have found that rust will come right through self etching primer in just a few days unless the steel is etched with phosphoric acid. IMHO "self etching primer isn't wort h much. The best procedure would be to etch with phosporic acid then prime with an epoxy zinc chromate. Just my .02 Doug Dever In beautiful Stow Ohio > From: bed(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Metal primer > Date: Fri=2C 23 Dec 2011 12:56:51 -0500 > > > I don't think you can buy REAL zinc chromate primer any longer thanks to the > EPA. Maybe Chromium is a toxic heavy metal? The "new" stuff seems to be n o > better than weak green paint. > Jack Phillips has the correct answer=2C just use a self-etching epoxy pri mer > available at any auto paint store. The brand we use is Variprime. It work s > great and gives great "tooth" for the topcoat to stick to. > Barry > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > tdudley(at)umn.edu > Sent: Thursday=2C December 22=2C 2011 10:05 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Metal primer > > --> > > Like a few others on the list I've got a few holiday "days" off. I'm goin g > to weld my wing cabane fittings and want to get them primed. > > I know Bingelis says zinc chromate for priming the metal. I've found it > available at Aircraft Spruce and Wicks=2C but was wondering if it was an item > I might find (or substitute) locally. I live in a small town but it has 3 > autobody shops that have auto metal primers=2C but the ones I've seen don 't > have zinc chromate as an ingredient. > > Is it okay to use a metal primer (such as for autos) that doesn't have zi nc > chromate (or phosphate) as a component? Or is this something I need to > order from an aircraft supply company (like I've done for all wood=2C met als=2C > glues=2C bolts=2C cables=2C etc.) > > Thanks=2C > > Tom > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361513#361513 > > > > > > > > > > > > =========== =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 23, 2011
Hmmm, acid etch, then epoxy primer, then finish paint. Looks like powder coating might be the easier method. BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361570#361570 ________________________________________________________________________________
Date: Dec 23, 2011
Sign painters paint: One Shot. Lead based applied with a brush! Really tough stuff! Kenneth M. Heide Sent from my iPhone On Dec 23, 2011, at 7:56 PM, "Bill Church" wrote: > > Hmmm, acid etch, then epoxy primer, then finish paint. Looks like powder coating might be the easier method. > > BC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361570#361570 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 24, 2011
Subject: Pietenpols and Movies
I'm looking for input on some good flying movies for viewing this holiday season. I bought a copy of "Barnstormers" (featuring a nice Pietenpol) and had it autographed at Oshkosh. What a great story, I loved it. My favorite flying movie of all time, "One Six Right" is almost memorized now. The video work and music are amazing, and it tells an important story. I even bought "One Six Left", which is about the making of "One Six Right". A nice movie on it's own. I have seen a few nice gliding movies like "Masters of the Wave", and I have a copy of the Wonderful World of Disney's "The Boy Who Flew with Condors" circa 1970. This movie got me started in gliding when I was 13 years old. But now I'm looking for something else to watch. Any thoughts? Malcolm Morrison http://home.comcast.net/~mmorrison123/ ________________________________________________________________________________
Date: Dec 23, 2011
Well, there's always TGWP, otherwise known as The Great Waldo Pepper. My favorites also include The Spirit of Saint Louis, starring Jimmy Stewart, and Those Magnificent Men in their Flying Machines. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of gliderx5(at)comcast.net Sent: Friday, December 23, 2011 9:35 PM Subject: Pietenpol-List: Pietenpols and Movies I'm looking for input on some good flying movies for viewing this holiday season. I bought a copy of "Barnstormers" (featuring a nice Pietenpol) and had it autographed at Oshkosh. What a great story, I loved it. My favorite flying movie of all time, "One Six Right" is almost memorized now. The video work and music are amazing, and it tells an important story. I even bought "One Six Left", which is about the making of "One Six Right". A nice movie on it's own. I have seen a few nice gliding movies like "Masters of the Wave", and I have a copy of the Wonderful World of Disney's "The Boy Who Flew with Condors" circa 1970. This movie got me started in gliding when I was 13 years old. But now I'm looking for something else to watch. Any thoughts? Malcolm Morrison http://home.comcast.net/~mmorrison123/ ________________________________________________________________________________
Subject: Re: Pietenpols and Movies
Date: Dec 23, 2011
The Great Waldo Pepper. Jim. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361574#361574 ________________________________________________________________________________
From: "Dortch, Steven D MAJ MIL USA FORSCOM" <steven.d.dortch(at)us.army.mil>
Date: Dec 23, 2011
The rocketeer, for some great 1930s footage. Amelia has some great footage in an otherwise boring movie. Blue Skies, Steve D ----- Original Message ----- From: Jack Phillips <pietflyr(at)bellsouth.net> Date: Friday, December 23, 2011 21:01 Subject: RE: Pietenpol-List: Pietenpols and Movies > Well, there's always TGWP, otherwise known as The Great Waldo Pepper. > > > > My favorites also include The Spirit of Saint Louis, starring Jimmy > Stewart,and Those Magnificent Men in their Flying Machines. > > > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > > > _____ > > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > gliderx5(at)comcast.net > Sent: Friday, December 23, 2011 9:35 PM > To: Pietenpol > Subject: Pietenpol-List: Pietenpols and Movies > > > > I'm looking for input on some good flying movies for viewing this > holidayseason. I bought a copy of "Barnstormers" (featuring a nice > Pietenpol) and > had it autographed at Oshkosh. What a great story, I loved it. My > favoriteflying movie of all time, "One Six Right" is almost > memorized now. The > video work and music are amazing, and it tells an important story. > I even > bought "One Six Left", which is about the making of "One Six > Right". A nice > movie on it's own. I have seen a few nice gliding movies like > "Masters of > the Wave", and I have a copy of the Wonderful World of Disney's > "The Boy Who > Flew with Condors" circa 1970. This movie got me started in > gliding when I > was 13 years old. But now I'm looking for something else to watch. > Any > thoughts? > > Malcolm Morrison > http://home.comcast.net/~mmorrison123/ > > > > ________________________________________________________________________________
Date: Dec 23, 2011
My favorites for good flying scenes not already mentioned: Air America Always Top Gun These days you could probably find the NBC series Ba Ba Black Sheep. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361579#361579 ________________________________________________________________________________
Date: Dec 23, 2011
I don't think you want to be using sign painter's paint to paint all of the metal parts - and especially on bare metal. This was a question about metal primer wasn't it? Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361582#361582 ________________________________________________________________________________
Date: Dec 23, 2011
Thanks for all the input. I hope to put it to good use. I did check the local NAPA today and found an etching primer and a primer coat (in a rattle-bottle). I also saw the two part epoxy. Powder coating the metal seems like a great idea, but I don't have a "garage" oven available. I guess I'll end up ordering primer from AS or Wick's to keep everything as "safe" as I can. Besides, I worked pretty hard today and wouldn't want to ruin these things: (I have never figured out how to make the pictures smaller, but I have tried.) Thanks again, Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361583#361583 Attachments: http://forums.matronics.com//files/104_129.jpg ________________________________________________________________________________
Date: Dec 23, 2011
Hey Rick, welcome to the forum. I too live in the Tulsa area, just south of Jim Ballew and about 30 minutes west of Jim Markle in Pryor, OK. A little planning and you could probably see several examples in an afternoon. There are 3 on my field alone (O38). Give us a shout if you get over this way. Mine is still in progress, but I'd be glad to show it to ya. Mark -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361584#361584 ________________________________________________________________________________
Date: Dec 24, 2011
I'd still etch before powder coating=2C but=2C yes that'd be the way to go if you have the stuff. Etched metal=2C even when left bare won't rust for several months. The phosphoric acid reacts with iron oxide and turns it in to iron phosphate which is inert Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Re: Metal primer > From: billspiet(at)sympatico.ca > Date: Fri=2C 23 Dec 2011 20:20:10 -0800 > To: pietenpol-list(at)matronics.com > ca> > > I don't think you want to be using sign painter's paint to paint all of t he metal parts - and especially on bare metal. This was a question about me tal primer wasn't it? > > Bill C. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361582#361582 > > > > > > > =========== =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 24, 2011
Military based.Strategic Air Command, The Blue Max, Bombers B 52 and Dr Strangelove. Jack DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of gliderx5(at)comcast.net Sent: Friday, December 23, 2011 8:35 PM Subject: Pietenpol-List: Pietenpols and Movies I'm looking for input on some good flying movies for viewing this holiday season. I bought a copy of "Barnstormers" (featuring a nice Pietenpol) and had it autographed at Oshkosh. What a great story, I loved it. My favorite flying movie of all time, "One Six Right" is almost memorized now. The video work and music are amazing, and it tells an important story. I even bought "One Six Left", which is about the making of "One Six Right". A nice movie on it's own. I have seen a few nice gliding movies like "Masters of the Wave", and I have a copy of the Wonderful World of Disney's "The Boy Who Flew with Condors" circa 1970. This movie got me started in gliding when I was 13 years old. But now I'm looking for something else to watch. Any thoughts? Malcolm Morrison http://home.comcast.net/~mmorrison123/ ________________________________________________________________________________
Date: Dec 24, 2011
I had found a documentary video at Walmart called Victory By Air. It is a 5 part series on one disk, over four hours long. The entire video is all vintage footage starting prior to the Wright brothers. It is by far the best aviation documentary I have seen. Michael Perez Karetaker Aero www.karetakeraero.com --- On Sat, 12/24/11, Jack wrote: > From: Jack <jack(at)textors.com> > Subject: RE: Pietenpol-List: Pietenpols and Movies > To: pietenpol-list(at)matronics.com > Date: Saturday, December 24, 2011, 6:29 AM > > > > > > > > > > > > > > > > > > > > > Military > basedStrategic Air > Command, The Blue Max, Bombers B 52 and Dr > Strangelove > > Jack > > > DSM > > > NX1929T > > > > > > > > > > > > > > From: > owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > gliderx5(at)comcast.net > > Sent: Friday, > December 23, 2011 > 8:35 PM > > To: > Pietenpol > > Subject: > Pietenpol-List: Pietenpols > and Movies > > > > > > > > I'm > looking for input on some good flying > movies for viewing this holiday season. I bought a > copy of > "Barnstormers" (featuring a nice Pietenpol) and > had it autographed at > Oshkosh . > What a great story, I loved it. My favorite flying > movie of all time, > "One Six Right" is almost memorized now. > The video work and > music are amazing, and it tells an important story. I > even bought > "One Six Left", which is about the making of > "One Six > Right". A nice movie on it's own. I > have seen a few nice > gliding movies like "Masters of the Wave", and I > have a copy of the > Wonderful World of Disney's "The Boy Who Flew with > Condors" circa > 1970. This movie got me started in gliding when I was > 13 years old. > But now I'm looking for something else to watch. > Any thoughts? > > > > Malcolm Morrison > > http://home.comcast.net/~mmorrison123/ > > > > > > www.buildersbooks.comhttp://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution > > > > > > > > > provided > > ________________________________________________________________________________
Date: Dec 24, 2011
Subject: Arrow Fest Time Off
Today will be my last build day, for a few days, to enjoy Christmas. I will be back at my build fest either Tuesday or Wednesday...by then, I should have a couple more pictures as well. Merry Christmas all! Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Dec 24, 2011
Really liked the Spirit of St. Louis with Jimmy Stewart. Top Gun is reliably inspirational (my first date, the girl had to drive because I was too young). I haven't seen the Great Waldo Pepper but hinted a lot so I hope it is beneath the tree tomorrow. My all time favorite for the American flying enthusiast, The Right Stuff. I could watch it over and over again. Merry Christmas all. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361591#361591 ________________________________________________________________________________
Subject: Merry Christmas
Date: Dec 24, 2011
But they that wait upon the LORD shall renew their strength; they shall mount up with wings as eagles; they shall run, and not be weary; and they shall walk, and not faint. A very merry Christmas to all!! Kelly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361593#361593 ________________________________________________________________________________
From: "Paul N. Peckham" <peckham9(at)countryspeed.com>
Date: Dec 24, 2011
Two of my favorites are the often mentioned The Great Waldo Pepper, and the rarely mentioned High Road to China, starring Tom Selleck and 2 very ratty looking Stampe biplanes. Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361595#361595 ________________________________________________________________________________
Date: Dec 24, 2011
Birds of Prey, David Janssen. Round wing stuff. Not a great plot, but some groundbreaking aerial stunts that hadn't been tried before (at the time - 1973). Maybe Cloud Dancer, also. While we're on this, what happened to Red Betsy? I've looked for it off and on for years, but it's like the people holding the rights have eradicated it from public access. Jim Ash -----Original Message----- >From: tools <n0kkj(at)yahoo.com> >Sent: Dec 23, 2011 11:06 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Pietenpols and Movies > > >My favorites for good flying scenes not already mentioned: > >Air America >Always >Top Gun > >These days you could probably find the NBC series Ba Ba Black Sheep. > >Tools > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=361579#361579 > > ________________________________________________________________________________
Date: Dec 24, 2011
Subject: Tire size again and shock cord fastener
I asked a few days ago about using 15 inch tires on 6 in rims--most said to stay 600-6 which are about 16 jnch. My plans actually call for 19 inch, I have a pair of 800-6 that are about 18 inch. Any thought? Second thought, my plans call for 5/8 inch bungee cable..I would like to use those metal shock cord fasteners but i cannot find anything bigger than 1/2 inch. Again, any thoughts here. I have been flying for over 40 years, but am a new time taildragger--would like to have as few surprises as possible -- John Kuhfahl President KUHLCOUPER LLC ________________________________________________________________________________
Date: Dec 24, 2011
It's my understanding phosphoric acid is widely used in the auto manufacturi ng industry as well as many other industries. Where would one source phospho ric acid for paint prep? Greg Bacon On Dec 23, 2011, at 6:45 PM, Doug Dever wrote: > The old ZInc Chromate primer contained lead. This is no longer true. If y ou use a "self etching primer" make sure it containes zinc tetroxychromate o therwise it contains not anti corrosive qualities. I have found that rust w ill come right through self etching primer in just a few days unless the ste el is etched with phosphoric acid. IMHO "self etching primer isn't worth mu ch. The best procedure would be to etch with phosporic acid then prime with an epoxy zinc chromate. Just my .02 > > Doug Dever > In beautiful Stow Ohio > > > > From: bed(at)mindspring.com > > To: pietenpol-list(at)matronics.com > > Subject: RE: Pietenpol-List: Metal primer > > Date: Fri, 23 Dec 2011 12:56:51 -0500 > > > > > > I don't think you can buy REAL zinc chromate primer any longer thanks to the > > EPA. Maybe Chromium is a toxic heavy metal? The "new" stuff seems to be n o > > better than weak green paint. > > Jack Phillips has the correct answer, just use a self-etching epoxy prim er > > available at any auto paint store. The brand we use is Variprime. It wor ks > > great and gives great "tooth" for the topcoat to stick to. > > Barry > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > > tdudley(at)umn.edu > > Sent: Thursday, December 22, 2011 10:05 PM > > To: pietenpol-list(at)matronics.com > > Subject: Pietenpol-List: Metal primer > > > > --> > > > > Like a few others on the list I've got a few holiday "days" off. I'm goi ng > > to weld my wing cabane fittings and want to get them primed. > > > > I know Bingelis says zinc chromate for priming the metal. I've found it > > available at Aircraft Spruce and Wicks, but was wondering if it was an i tem > > I might find (or substitute) locally. I live in a small town but it has 3 > > autobody shops that have auto metal primers, but the ones I've seen don' t > > have zinc chromate as an ingredient. > > > > Is it okay to use a metal primer (such as for autos) that doesn't have z inc > > chromate (or phosphate) as a component? Or is this something I need to > > order from an aircraft supply company (like I've done for all wood, meta ls, > > glues, bolts, cables, etc.) > > > > Thanks, > > > > Tom > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=361513#361513 > > > > > > > > > > > > > > > > > _================= > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Dec 24, 2011
My two favorite scenes of the kind of flying we're likely to do in Pietenpols come from Out of Africa and Never Cry Wolf Mike Hardaway ________________________________________________________________________________
Date: Dec 24, 2011
The Blue Max ________________________________ From: mike Hardaway <bkemike(at)gmail.com> Sent: Saturday, December 24, 2011 2:19 PM Subject: Re: Pietenpol-List: Re: Pietenpols and Movies My two favorite scenes of the kind of flying we're likely to do in Pietenpols come from Out of Africa and Never Cry Wolf Mike Hardaway ________________________________________________________________________________
Subject: Pietenpols and movies
Date: Dec 24, 2011
Another great movie is "Second Hand Lions" not really a flying movie but the opening and closing scenes are worth it. Dick N. ________________________________________________________________________________
Date: Dec 24, 2011
Subject: Re: Pietenpols and movies
"Fly Away Home" with Jeff Daniels is very good from a grass roots flying standpoint. It's also good from a homebuilt aviation standpoint. It'll make you cry!! Greg Bacon On Sat, Dec 24, 2011 at 2:51 PM, Dick N wrote: > ** > Another great movie is "Second Hand Lions" not really a flying movie but > the opening and closing scenes are worth it. > Dick N. > > * > > * > > -- Greg Bacon ________________________________________________________________________________
Date: Dec 25, 2011
Greg=2C It's becoming harder to find with the advent of the self etching primers. Some autobody suppliers still carry it. Believe it or not Home Depot carri es it. The trade name is Must For Rust made by Krud Kutter. You can also order it through most Ace hardware stores and avoid shipping charges. Very few of the Ace stores stock it=2C but they carry the Krud Kutter brand. Use it full strength as it's already reduced. We often use Naval Jelly for rust removal on vertical surfaces=2C but I'm not sure if the thickening ag ent in it affects adhesion. Hope this helps. Doug Dever In beautiful Stow Ohio Subject: Re: Pietenpol-List: Metal primer From: gbacon67(at)gmail.com Date: Sat=2C 24 Dec 2011 12:09:37 -0600 It's my understanding phosphoric acid is widely used in the auto manufactur ing industry as well as many other industries. Where would one source phosp horic acid for paint prep? Greg Bacon On Dec 23=2C 2011=2C at 6:45 PM=2C Doug Dever wrote: The old ZInc Chromate primer contained lead. This is no longer true. If y ou use a "self etching primer" make sure it containes zinc tetroxychromate otherwise it contains not anti corrosive qualities. I have found that rust will come right through self etching primer in just a few days unless the steel is etched with phosphoric acid. IMHO "self etching primer isn't wort h much. The best procedure would be to etch with phosporic acid then prime with an epoxy zinc chromate. Just my .02 Doug Dever In beautiful Stow Ohio > From: bed(at)mindspring.com > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Metal primer > Date: Fri=2C 23 Dec 2011 12:56:51 -0500 > > > I don't think you can buy REAL zinc chromate primer any longer thanks to the > EPA. Maybe Chromium is a toxic heavy metal? The "new" stuff seems to be n o > better than weak green paint. > Jack Phillips has the correct answer=2C just use a self-etching epoxy pri mer > available at any auto paint store. The brand we use is Variprime. It work s > great and gives great "tooth" for the topcoat to stick to. > Barry > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > tdudley(at)umn.edu > Sent: Thursday=2C December 22=2C 2011 10:05 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Metal primer > > --> > > Like a few others on the list I've got a few holiday "days" off. I'm goin g > to weld my wing cabane fittings and want to get them primed. > > I know Bingelis says zinc chromate for priming the metal. I've found it > available at Aircraft Spruce and Wicks=2C but was wondering if it was an item > I might find (or substitute) locally. I live in a small town but it has 3 > autobody shops that have auto metal primers=2C but the ones I've seen don 't > have zinc chromate as an ingredient. > > Is it okay to use a metal primer (such as for autos) that doesn't have zi nc > chromate (or phosphate) as a component? Or is this something I need to > order from an aircraft supply company (like I've done for all wood=2C met als=2C > glues=2C bolts=2C cables=2C etc.) > > Thanks=2C > > Tom > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=361513#361513 > > > > > > > > > _================= > > > ========= ctric.com >www.buildersbooks.com uilthelp.com matronics.com/contribution ========= >http://www.matronics.com/Navigator?Pietenpol-List ========= cs.com ========= matronics.com/contribution ========= ________________________________________________________________________________
Date: Dec 25, 2011
Subject: phosphoric acid
Try any local paint store. I bought a gallon here in Texas at either Kelly-Moore or Sherwin Williams years ago for $8. People commonly use it to etch their iron fences, etc. here before painting. In fact, that is what I did with most of it. Brush it on, or carefully use a little hand squeeze sprayer. Clean up well around kids or pets. Merry Christmas to all, Tim in central TX ________________________________________________________________________________
Subject: tire size again
Date: Dec 25, 2011
John wrote- >I asked a few days ago about using 15 inch tires on 6 in rims-- >most said to stay 600-6 which are about 16 inch. My plans actually >call for 19 inch, I have a pair of 800-6 that are about 18 inch. >Any thought? John, one of the posts in response to yours was a reference to the Carlisle "Turf Glide" tires, 8.00x6, which have an outside diameter of close to 18". Info here: http://www.carlisletire.com/products/golf_gliders/turfglide/index.html These are the tires that are recommended for use on the airplane that I'm building, the Flying Squirrel. Quite a few other light sport and ultralight aircraft use these. I only have two concerns with them: (1) the catalog shows them rated for golf carts and utility ATVs, which are certainly not going to be running at anything like our landing speeds of 55-60 MPH, and (2) load rating is 420 lbs., which means a pair of them should be good for 840 lbs., and we fly our airplanes at up to 1100 lbs. gross weight. They will see more load than that on a good firm landing or a bounce. Granted, the manufacturer rates them conservatively for purposes of lawsuit avoidance, so they are probably just fine for this duty. The proof would be to mount them and go fly. At least one post in reply to your question was from a guy who has been flying with these tires for a good amount of time. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Dec 25, 2011
Okay, so this doesn't directly address the issue of metal primer, but it may be that if you use some of these metal treatments, you may decide not to put any other finish on them. Besides the Naval Jelly phosphate treatment, there are things like rust bluing and cold bluing that may be of interest. The one that I have used and like pretty well in locations where the part will not be visible (or where you want the zinc chromate look) is green rebar epoxy. There are several manufacturers, Krylon is one, but the one I've used is Aervoe. I just did a quick search and places like toolauthority.com have it for $6.25 for a 16 oz. spray can. I don't think it is intended as a primer, since it has a fairly smooth cured surface. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Dec 25, 2011
"The War Lover"... circa 1962 I think. Steve McQeen... no fake cardboard cockpits...very realistic Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361653#361653 ________________________________________________________________________________
Subject: Rotating wing mechanism
Date: Dec 25, 2011
Well, they say, "Laziness is the Mother of Invention." They don't say that? Well..they should! I definitely did not want to crawl under my wing every time the need arose, so I came up with this simple contraption.. Let me know if you want any more pics or descriptions.. Merry Christmas Gary from Cool NX308MB ________________________________________________________________________________
Date: Dec 26, 2011
Subject: On tire size
I used 500X5 Cleveland wheels and brakes on my Piet. They're a bit smaller but I've had no problems on any grass strip I've landed on and they're a bit lighter than the 600X6s. I know they probably don't look as 'authentic' as the larger wheels but the price was right at the time and the weight saving was a consideration to me. Matt Paxton ________________________________________________________________________________
Date: Dec 26, 2011
Subject: Re: Rotating wing mechanism
Looking good Gary Fom Cool!- You should be flying that thing before next winter.- Kep up the good work.- Hope to see you at Brodhead 2013. - Shad - ________________________________________________________________________________
Date: Dec 26, 2011
From: santiago morete <moretesantiago(at)yahoo.com.ar>
http://www.youtube.com/watch?v=DSzI1yKPxhU-=0A ________________________________________________________________________________
Date: Dec 27, 2011
Gary that wing looks so good; it would be really neat to just put on clear so yodu could see all that woodwork it tooks so long to do. I'm working on the front tank now; it is small probably about 3 to 4 gallons. Jim B. ________________________________________________________________________________
Date: Dec 27, 2011
Subject: Re: 2012 Ohio Piet Fly-in
--- On Mon, 12/26/11, shad bell wrote: From: shad bell <aviatorbell(at)yahoo.com> Subject: 2012 Ohio Piet Fly-in Date: Monday, December 26, 2011, 12:31 PM Hello Group, Just wondering if there is any interest in a Piet Fly-in here in Ohio.- This would be the 3rd time I hosted one, but the turn out has n ot been great the past couple years.- Last year was a wash due to weather , and possibly hosting it on Fathers Day weekend.- I am thinking of movin g it back in the year a little to get more stable summer weather vs the unp redictable spring patterns.- I am looking at hosting a fly-in with my nei ghbor regardless.- If any of you have any input let me know, I am trying to plan it when it won't interfere with other big fly-ins, events.- I kno w of at least 4 piets within 1-2 hr flight time, and it would be an easy sh ake down cruise to prep for brodhead. - Let MeKnow, - Shad ________________________________________________________________________________
Subject: Greetings and a blog about Piet's
Date: Dec 27, 2011
Hello, A little bird told me you guys might enjoy my blog about pietenpol's. http://writingsofjon.blogspot.com/2011/12/aviation-god-bless-pietenpol.html Enjoy! Jon P.S. the occasional ad click is greatly appreciated. -------- http://writingsofjon.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361758#361758 ________________________________________________________________________________
Subject: Landing Gear Question - Heighth
Date: Dec 27, 2011
Hope everyone had a great Christmas! I=92m building the split gear, long fuselage with brakes. The archives suggest (Bill Rewey) moving the gear forward 3 inches. The plans call for the Vees to be 22 =BC=94 long with 19=94 wheels. My wheels are 25=94. I assume I don=92t shorten them by 6=94 because they exit the fuselage at about 45 degrees. Can anyone assist here? Thanks! DSM NX1929T ________________________________________________________________________________
Subject: Re: Landing Gear Question - Heighth
Date: Dec 27, 2011
Jack I just went out to the hangar to look at my drawing to be sure of the measurement. On the original fuselage drawing in the upper right hand is the dimension 51" tall to the top of the top longeron with the longeron level. That is what I used to make my landing gear. My tires are 26" diameter(21" rims). I think that is what B H Pietenpol had in mind. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 now covering 21" wheels Lycoming O-235 C 2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361787#361787 ________________________________________________________________________________
Date: Dec 27, 2011
Thanks for checking Jerry, that will be a good reference point. Not being a geometry guy, any idea on the amount to shorten the vees because of the "squat" of the gear? It can't amount to much. Thanks! Jack -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Tuesday, December 27, 2011 3:09 PM Subject: Pietenpol-List: Re: Landing Gear Question - Heighth Jack I just went out to the hangar to look at my drawing to be sure of the measurement. On the original fuselage drawing in the upper right hand is the dimension 51" tall to the top of the top longeron with the longeron level. That is what I used to make my landing gear. My tires are 26" diameter(21" rims). I think that is what B H Pietenpol had in mind. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 now covering 21" wheels Lycoming O-235 C 2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361787#361787 ________________________________________________________________________________
Date: Dec 28, 2011
Shad I'm always up for a fly-in. I will not have my Piet ready for this season so hopefully a Titan Tornado would still be welcome. I plan to fly the Titan to Brodhead and Oshkosh in 2012 and as you say, it would be a good shake down cruise. Fathers Day is a tough one due to family commitments, but other weekends might work. This past year was really bad, weather wise that is, for fly-ins here on PA. Malcolm Morrison http://home.comcast.net/~mmorrison123/Airplanes.htm ----- Original Message ----- From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Tuesday, December 27, 2011 12:42:17 PM Subject: Pietenpol-List: Re: 2012 Ohio Piet Fly-in --- On Mon, 12/26/11, shad bell wrote: From: shad bell <aviatorbell(at)yahoo.com> Subject: 2012 Ohio Piet Fly-in Date: Monday, December 26, 2011, 12:31 PM Hello Group, Just wondering if there is any interest in a Piet Fly-in here in Ohio. This would be the 3rd time I hosted one, but the turn out has not been great the past couple years. Last year was a wash due to weather, and possibly hosting it on Fathers Day weekend. I am thinking of moving it back in the year a little to get more stable summer weather vs the unpredictable spring patterns. I am looking at hosting a fly-in with my neighbor regardless. If any of you have any input let me know, I am trying to plan it when it won't interfere with other big fly-ins, events. I know of at least 4 piets within 1-2 hr flight time, and it would be an easy shake down cruise to prep for brodhead. Let MeKnow, Shad ________________________________________________________________________________
Subject: Movies
Date: Dec 27, 2011
Amazing flight videoCheck out this video. It is one of the best I've seen. Dick N. NOTICE THE "DUST OFF" ON THE HELO!! http://www.youtube.com/watch?v=RU1oB8sGyYM __._,_.___ Reply to sender | Reply to group | Reply via web post | Start a New Topic Messages in this topic (1) Recent Activity: Visit Your Group MARKETPLACE Stay on top of your group activity without leaving the page you're on - Get the Yahoo! Toolbar now. Switch to: Text-Only, Daily Digest =A2 Unsubscribe =A2 Terms of Use. __,_._,___ ________________________________________________________________________________
Subject: Fwd: When the Northwest logging industry was still young
Date: Dec 27, 2011
Date: Dec 27, 2011
Jack, Someone else would have a mathematical formula, for sure, but why not just prop up your fuselage on a saw horse, set the deck angle how you want it, then place the wheels and measure the legs? Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Tuesday, December 27, 2011 11:03 AM Subject: Pietenpol-List: Landing Gear Question - Heighth Hope everyone had a great Christmas! I=92m building the split gear, long fuselage with brakes. The archives suggest (Bill Rewey) moving the gear forward 3 inches. The plans call for the Vees to be 22 =BC=94 long with 19=94 wheels. My wheels are 25=94. I assume I don=92t shorten them by 6=94 because they exit the fuselage at about 45 degrees. Can anyone assist here? Thanks! DSM NX1929T ________________________________________________________________________________
Date: Dec 28, 2011
Shad as long as old man weather is good count me in, but I could be overruled by the boss. On Tue, Dec 27, 2011 at 8:04 PM, wrote: > Shad > > I'm always up for a fly-in. I will not have my Piet ready for this season > so hopefully a Titan Tornado would still be welcome. I plan to fly the > Titan to Brodhead and Oshkosh in 2012 and as you say, it would be a good > shake down cruise. Fathers Day is a tough one due to family commitments, > but other weekends might work. This past year was really bad, weather wise > that is, for fly-ins here on PA. > > Malcolm Morrison > http://home.comcast.net/~mmorrison123/Airplanes.htm > > > ------------------------------ > *From: *"shad bell" <aviatorbell(at)yahoo.com> > *To: *pietenpol-list(at)matronics.com > *Sent: *Tuesday, December 27, 2011 12:42:17 PM > *Subject: *Pietenpol-List: Re: 2012 Ohio Piet Fly-in > > > --- On *Mon, 12/26/11, shad bell * wrote: > > > From: shad bell <aviatorbell(at)yahoo.com> > Subject: 2012 Ohio Piet Fly-in > Date: Monday, December 26, 2011, 12:31 PM > > Hello Group, Just wondering if there is any interest in a Piet Fly-in > here in Ohio. This would be the 3rd time I hosted one, but the turn out > has not been great the past couple years. Last year was a wash due to > weather, and possibly hosting it on Fathers Day weekend. I am thinking of > moving it back in the year a little to get more stable summer weather vs > the unpredictable spring patterns. I am looking at hosting a fly-in with > my neighbor regardless. If any of you have any input let me know, I am > trying to plan it when it won't interfere with other big fly-ins, events. > I know of at least 4 piets within 1-2 hr flight time, and it would be an > easy shake down cruise to prep for brodhead. > > Let MeKnow, > > Shad > > * > > _blank">www.aeroelectric.com > " target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > _blank">http://www.matronics.com/contribution > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > * > > * > > ________________________________________________________________________________
From: "H. Marvin Haught" <handainc(at)madisoncounty.net>
Subject: Stewart System Clean up prior to paint
Date: Dec 28, 2011
Just a heads up for those of you using or going to use Stewart system products in your covering and painting of your project. We are now using isopropyl alcohol for the final clean up and prep prior to paint, and in between the spray coats of EkoFill. The protocol is to first wipe and blow the part with a virgin terry cloth towel and filtered air. Then move to the clean room where you use a good waterborne tack cloth like the Gerson dry tack cloth to remove the fine particles remaining. Then, with a lint free synthetic wipe, dampened with isopropyl alcohol, gently wipe down the part. The alcohol helps as an antistatic agent to stop the static cling, dries quickly and helps remove the very last particles. Look over the part in strong light, and if needed, wipe down again lightly with the Gerson tack cloth. I have had a problem with residual particles in my paint surface, no matter how much I clean my booth and paint surfaces. This seems to solve the problem as static electricity was drawing particles back the the surface. I buy from WalMart - the local pharmacy special ordered gallon jugs for me of 98% Isoprophyl at $38 per gallon. M. Haught aircraftfinishes(at)gmail.com ________________________________________________________________________________
Subject: Re: Stewart System Clean up prior to paint
Date: Dec 28, 2011
DQoNCiANCg0KRnJvbTogSC4gTWFydmluIEhhdWdodCBbbWFpbHRvOmhhbmRhaW5jQG1hZGlzb25j b3VudHkubmV0XSANClNlbnQ6IFdlZG5lc2RheSwgRGVjZW1iZXIgMjgsIDIwMTEgMTA6MDggQU0N ClRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tIDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25p Y3MuY29tPiANClN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBTdGV3YXJ0IFN5c3RlbSBDbGVhbiB1 cCBwcmlvciB0byBwYWludCANCiANCg0KSnVzdCBhIGhlYWRzIHVwIGZvciB0aG9zZSBvZiB5b3Ug dXNpbmcgb3IgZ29pbmcgdG8gdXNlIFN0ZXdhcnQgc3lzdGVtIHByb2R1Y3RzIGluIHlvdXIgY292 ZXJpbmcgYW5kIHBhaW50aW5nIG9mIHlvdXIgcHJvamVjdC4gIFdlIGFyZSBub3cgdXNpbmcgaXNv cHJvcHlsIGFsY29ob2wgZm9yIHRoZSBmaW5hbCBjbGVhbiB1cCBhbmQgcHJlcCBwcmlvciB0byBw YWludCwgYW5kIGluIGJldHdlZW4gdGhlIHNwcmF5IGNvYXRzIG9mIEVrb0ZpbGwuICBUaGUgcHJv dG9jb2wgaXMgdG8gZmlyc3Qgd2lwZSBhbmQgYmxvdyB0aGUgcGFydCB3aXRoIGEgdmlyZ2luIHRl cnJ5IGNsb3RoIHRvd2VsIGFuZCBmaWx0ZXJlZCBhaXIuICBUaGVuIG1vdmUgdG8gdGhlIGNsZWFu IHJvb20gd2hlcmUgeW91IHVzZSBhIGdvb2Qgd2F0ZXJib3JuZSAgdGFjayBjbG90aCBsaWtlIHRo ZSBHZXJzb24gZHJ5IHRhY2sgY2xvdGggdG8gcmVtb3ZlIHRoZSBmaW5lIHBhcnRpY2xlcyByZW1h aW5pbmcuICBUaGVuLCB3aXRoIGEgbGludCBmcmVlIHN5bnRoZXRpYyB3aXBlLCBkYW1wZW5lZCB3 aXRoIGlzb3Byb3B5bCBhbGNvaG9sLCBnZW50bHkgd2lwZSBkb3duIHRoZSBwYXJ0LiAgVGhlIGFs Y29ob2wgaGVscHMgYXMgYW4gYW50aXN0YXRpYyBhZ2VudCB0byBzdG9wIHRoZSBzdGF0aWMgY2xp bmcsIGRyaWVzIHF1aWNrbHkgYW5kIGhlbHBzIHJlbW92ZSB0aGUgdmVyeSBsYXN0IHBhcnRpY2xl cy4gIExvb2sgb3ZlciB0aGUgcGFydCBpbiBzdHJvbmcgbGlnaHQsIGFuZCBpZiBuZWVkZWQsIHdp cGUgZG93biBhZ2FpbiBsaWdodGx5IHdpdGggdGhlIEdlcnNvbiB0YWNrIGNsb3RoLiAgDQoNCkkg aGF2ZSBoYWQgYSBwcm9ibGVtIHdpdGggcmVzaWR1YWwgcGFydGljbGVzIGluIG15IHBhaW50IHN1 cmZhY2UsIG5vIG1hdHRlciBob3cgbXVjaCBJIGNsZWFuIG15IGJvb3RoIGFuZCBwYWludCBzdXJm YWNlcy4gIFRoaXMgc2VlbXMgdG8gc29sdmUgdGhlIHByb2JsZW0gYXMgc3RhdGljIGVsZWN0cmlj aXR5IHdhcyBkcmF3aW5nIHBhcnRpY2xlcyBiYWNrIHRoZSB0aGUgc3VyZmFjZS4gIA0KDQpJIGJ1 eSBmcm9tIFdhbE1hcnQgLSB0aGUgbG9jYWwgcGhhcm1hY3kgc3BlY2lhbCBvcmRlcmVkIGdhbGxv biBqdWdzIGZvciBtZSBvZiA5OCUgSXNvcHJvcGh5bCAgYXQgJDM4IHBlciBnYWxsb24uDQoNCk0u IEhhdWdodCANCmFpcmNyYWZ0ZmluaXNoZXNAZ21haWwuY29tDQoNCg0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPQ0KXy09 ICAgICAgIC0tIFBsZWFzZSBTdXBwb3J0IFlvdXIgTGlzdHMgVGhpcyBNb250aCAtLQ0KXy09ICAg ICAgICAgICAoQW5kIEdldCBTb21lIEFXRVNPTUUgRlJFRSBHaWZ0cyEpDQpfLT0NCl8tPSAgIE5v dmVtYmVyIGlzIHRoZSBBbm51YWwgTGlzdCBGdW5kIFJhaXNlci4gIENsaWNrIG9uDQpfLT0gICB0 aGUgQ29udHJpYnV0aW9uIGxpbmsgYmVsb3cgdG8gZmluZCBvdXQgbW9yZSBhYm91dA0KXy09ICAg dGhpcyB5ZWFyJ3MgVGVycmlmaWMgRnJlZSBJbmNlbnRpdmUgR2lmdHMgcHJvdmlkZWQNCl8tPSAg IGJ5Og0KXy09ICAgDQpfLT0gICAgICogQWVyb0VsZWN0cmljIHd3dy5hZXJvZWxlY3RyaWMuY29t DQpfLT0gICAgICogVGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3LmJ1aWxkZXJzYm9va3MuY29t DQpfLT0gICAgICogSG9tZWJ1aWx0SEVMUCB3d3cuaG9tZWJ1aWx0aGVscC5jb20NCl8tPQ0KXy09 ICAgTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT0NCl8tPSAgIFRoYW5rIHlvdSBmb3IgeW91 ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09DQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBU aGUgUGlldGVucG9sLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExp c3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0 aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBE b3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11 Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9QaWV0ZW5wb2wtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBN QVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxh YmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0 cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRp b24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEN Cl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1p bi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KDQoNCg= ________________________________________________________________________________
Subject: Where have the Models Gone?
Date: Dec 28, 2011
http://writingsofjon.blogspot.com/2011/12/aviation-where-have-models-gone.html Enjoy! Jon P.S. The occasional ad click is always greatly appreciated. -------- http://writingsofjon.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361856#361856 ________________________________________________________________________________
Date: Dec 28, 2011
Sounds good Steve, if I can get at least 3-4 or more "commited " piets(or o ther types as well) I will proceede with planning. - Shad --- On Wed, 12/28/11, steve emo wrote: From: steve emo <steve.emo58(at)gmail.com> Subject: Re: Pietenpol-List: Re: 2012 Ohio Piet Fly-in Date: Wednesday, December 28, 2011, 7:22 AM Shad as long as old man weather is good count me in, but I could be overrul ed by the boss.- On Tue, Dec 27, 2011 at 8:04 PM, wrote: Shad I'm always up for a fly-in.- I will not have my Piet ready for this seaso n so hopefully a Titan Tornado would still be welcome.- I plan to fly the Titan to Brodhead and Oshkosh in 2012 and as you say, it would be a good s hake down cruise.- Fathers Day is a tough one due to family commitments, but other weekends might work.- This past year was really bad, weather wi se that is, for fly-ins here on PA. Malcolm Morrison http://home.comcast.net/~mmorrison123/Airplanes.htm From: "shad bell" <aviatorbell(at)yahoo.com> Sent: Tuesday, December 27, 2011 12:42:17 PM Subject: Pietenpol-List: Re: 2012 Ohio Piet Fly-in --- On Mon, 12/26/11, shad bell wrote: From: shad bell <aviatorbell(at)yahoo.com> Subject: 2012 Ohio Piet Fly-in Date: Monday, December 26, 2011, 12:31 PM Hello Group, Just wondering if there is any interest in a Piet Fly-in here in Ohio.- This would be the 3rd time I hosted one, but the turn out has n ot been great the past couple years.- Last year was a wash due to weather , and possibly hosting it on Fathers Day weekend.- I am thinking of movin g it back in the year a little to get more stable summer weather vs the unp redictable spring patterns.- I am looking at hosting a fly-in with my nei ghbor regardless.- If any of you have any input let me know, I am trying to plan it when it won't interfere with other big fly-ins, events.- I kno w of at least 4 piets within 1-2 hr flight time, and it would be an easy sh ake down cruise to prep for brodhead. - Let MeKnow, - Shad _blank">www.aeroelectric.com " target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution "_blank">www.aeroelectric.com .com/" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Dec 29, 2011
Here's a little something you might like: http://www.cbc.ca/video/player.html?clipid=2179622316&site=cbc.news.c a ________________________________________________________________________________
Subject: Stewart system Clean up prior to Paint
Date: Dec 28, 2011
Just a heads up for those of you using or going to use Stewart system products in your covering and painting of your project. We are now using isopropyl alcohol for the final clean up and prep prior to paint, and in between the spray coats of EkoFill. The protocol is to first wipe and blow the part with a virgin terry cloth towel and filtered air. Then move to the clean room where you use a good waterborne tack cloth like the Gerson dry tack cloth to remove the fine particles remaining. Then, with a lint free synthetic wipe, dampened with isopropyl alcohol, gently wipe down the part. The alcohol helps as an antistatic agent to stop the static cling, dries quickly and helps remove the very last particles. Look over the part in strong light, and if needed, wipe down again lightly with the Gerson tack cloth. I have had a problem with residual particles in my paint surface, no matter how much I clean my booth and paint surfaces. This seems to solve the problem as static electricity was drawing particles back the the surface. M. Haught aircraftfinishes(at)gmail.com ________________________________________________________________________________
Date: Dec 29, 2011
Great timing Marvin. I am starting some covering now and was curious how to clean prior to paint. Thanks! Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
From: "H.Marvin Haught" <handainc(at)madisoncounty.net>
Subject: Dealing with pinks
Date: Dec 29, 2011
Another tip for aircraft covering - One of my customers called a day or so ago and was having trouble getting the pinked edges of his tapes to iron down flat. When you finish applying your tapes, be sure to go back with a medium hot iron (not hot enough to shrink the tape) and iron down all of the pinked edges prior to applying your first coat of filler / UV block. In the Stewart System, that product is call EkoFill. Then after you have your first cross coat of EkoFill applied to the surface, iron those edges down again using a piece of teflon to keep the EkoFill from transfering to your iron and smearing on the tapes. If you can't find teflon, buy a box of turkey basting bags (plastic bags used to cook a turkey in the oven) at your local grocery or Wal Mart. Cut a piece of the bag out to used as a shield as you iron the pinks flat. You can do this all the way up to prepping to apply the topcoat. Detail work is what makes for an attractive covering job! M. Haught ________________________________________________________________________________
Date: Dec 29, 2011
Subject: Re: Where have the Models Gone?
A balsa fuse/foam wing kit. Saves the frustration of all those fiddly wing ribs, but teaches the basics of balsa construction. http://www.mountainmodels.com/product_info.php?products_id=223 On Thu, Dec 29, 2011 at 2:03 PM, K5YAC wrote: > > He also wanted an R/C airplane... I was initially opposed to getting > him an RTF (Ready To Fly for those unfamiliar)... I wanted him to learn to > build before he was allowed to fly, but at 7 he just doesn't have the skill > or knowledge required to build from a kit. He is really good on the > simulator and he is INTERESTED in the hobby, so I hate to discourage him or > miss out on this window of opportunity. My hope is that through plastic > models, ! > model rockets, etc. that he will progress to a simple kit trainer and > beyond, much like I did. My first airplane didn't fly well (or for very > long), but I learned a ton. > -- "The problem with America is stupidity. I'm not saying there should be capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?" (anon) Boones Mill, VA ________________________________________________________________________________
Date: Dec 29, 2011
Bryan, I'm sure that my brush seems somewhat broad, but I really didn't mean to suggest that ALL parents are lazy or unwilling to work with their kids. In addition to that, I have been very fortunate that my wife and son have taken an interest in my hobby, which makes it much easier for me to enjoy AND teach. I do often times have to tell my son to get off the video games when he's been on too long, but I also know of kids who are allowed to disappear to their rooms for hours on end to play their video games, and the parents are fine with that as long as it doesn't disturb what THEY want to do. Good for you for threatening to throw them out. Ha! My son prefers to see what is going on up front during an airplane ride... he seems to be soaking all this stuff up. He's never even asked for a portable game... again, I guess I'm lucky, or perhaps he just knows that I'm not likely to get him one. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361924#361924 ________________________________________________________________________________
Date: Dec 29, 2011
bkemike(at)gmail.com wrote: > A different experience was watching Jim Markle's 11 year old son get his first ride at Brodhead this year. I have never seen anyone so completely stoked on flying after having been reluctant to fly at all. You could have read a book by the light from his face after he landed. > > Mike Hardaway That is a fact Mike. Ol Ben was indeed stoked! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361928#361928 ________________________________________________________________________________
Subject: Rib Stitching
Date: Dec 29, 2011
HONK..if you have ever experienced rib-stitching a wing solo! Stitches only, excluding marking and re-enforcing tape, 8 hrs 40 minutes. That wasn't so bad, considering that I have 10 times that much in my cowling.or 5 times that much in the wind screens! Gary Boothe NX308MB ________________________________________________________________________________
Subject: Re: Rib Stitching
Date: Dec 29, 2011
Hey man, nice picture, good job. HONK HONK "Bat Cave" Dave -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Thu, Dec 29, 2011 5:58 pm Subject: Pietenpol-List: Rib Stitching HONK.if you have ever experienced rib-stitching a wing solo! Stitc hes only, excluding marking and re-enforcing tape, 8 hrs 40 minutes. That w asn=99t so bad, considering that I have 10 times that much in my cowl ingor 5 times that much in the wind screens! Gary Boothe NX308MB ________________________________________________________________________________
Date: Dec 29, 2011
I am impressed Gary. I'm sure that it will take me 5 times longer than that . =0APlus hours just thinking about it. Cheers and happy newyear, Gardiner =0A=0A=0A=0A=0A=0A________________________________=0AFrom: Gary Boothe <gbo othe5(at)comcast.net>=0ATo: pietenpol-list(at)matronics.com=0ASent: Thu, December 29, 2011 5:55:57 PM=0ASubject: Pietenpol-List: Rib Stitching=0A=0A=0AHONK .if you have ever experienced rib-stitching a wing solo! Stitches only, =0Aexcluding marking and re-enforcing tape, 8 hrs 40 minutes. That wa sn=99t so bad, =0Aconsidering that I have 10 times that much in my co wlingor 5 times that much in =0Athe wind screens!=0A =0A =0AGary B oothe=0ANX308MB ________________________________________________________________________________
Subject: Re: Floorboards and rudder pedals...
Date: Dec 29, 2011
Hello Hans, I am building an Avid Flyer and wanted to check the place you sourced your floor board? I wanted to install a wood grain floor board pattern for my aircraft, just like yours! Your pictures look good! Thanks! Mahesh Utah Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361941#361941 ________________________________________________________________________________
Date: Dec 29, 2011
That sounds very similar to my experience. The wing rotator helps alot. I ha d a similar setup. After a few ribs i figured out how much cord it took to d o the whole rib with one piece. Lots more fun than i thought it would be Ben Charvet NX966BC Sent from my iPhone On Dec 29, 2011, at 5:55 PM, "Gary Boothe" wrote: > HONK.if you have ever experienced rib-stitching a wing solo! Stit ches only, excluding marking and re-enforcing tape, 8 hrs 40 minutes. That w asn=99t so bad, considering that I have 10 times that much in my cowli ngor 5 times that much in the wind screens! > > > > Gary Boothe > NX308MB > ________________________________________________________________________________
Date: Dec 29, 2011
Awesome Gary... I had my dad to pass the needle back to me so I didn't have to do it alone but I can imagine the amount of extra work involved.=C2- Great job.=C2-=C2- So ... just one more to go?=C2- I spent a little t ime finishing my radio installation today.=C2- Now I can put on the leath er helmet my wife got me for Christmas and talk on the radio!=C2- Tomorro w I'll work on my final wing's fabric work.=C2- I've gotta get working or you'll fly before me!=0A=0AMike Groah=0ATulare CA=0A=0A=0A=0A_____________ ___________________=0A From: Ben Charvet <bencharvet(at)gmail.com>=0ATo: "piet enpol-list(at)matronics.com" =0ASent: Thursday, December 29, 2011 4:29 PM=0ASubject: Re: Pietenpol-List: Rib Stitching=0A =0A=0AThat sounds very similar to my experience. The wing rotator helps alo t. I had a similar setup. After a few ribs i figured out how much cord it t ook to do the whole rib with one piece. Lots more fun than i thought it wou ld be=0A=0ABen Charvet=0ANX966BC=0A=0A=0A=0ASent from my iPhone=0A=0AOn Dec 29, 2011, at 5:55 PM, "Gary Boothe" wrote:=0A=0A=0A HONK.if you have ever experienced rib-stitching a wing solo! Stitc hes only, excluding marking and re-enforcing tape, 8 hrs 40 minutes. That w asn=99t so bad, considering that I have 10 times that much in my cowl ingor 5 times that much in the wind screens!=0A>=C2-=0A>From: "Jack Phillips" <pietflyr(at)bellsouth.net>
Date: Dec 29, 2011
I did mine laying flat, without a wing rotator. Took about 12 hours per wing, which is a lot of trips under the wing. My back was sore for weeks. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Thursday, December 29, 2011 7:30 PM Subject: Re: Pietenpol-List: Rib Stitching That sounds very similar to my experience. The wing rotator helps alot. I had a similar setup. After a few ribs i figured out how much cord it took to do the whole rib with one piece. Lots more fun than i thought it would be Ben Charvet NX966BC Sent from my iPhone On Dec 29, 2011, at 5:55 PM, "Gary Boothe" wrote: HONK..if you have ever experienced rib-stitching a wing solo! Stitches only, excluding marking and re-enforcing tape, 8 hrs 40 minutes. That wasn't so bad, considering that I have 10 times that much in my cowling.or 5 times that much in the wind screens! Gary Boothe NX308MB ________________________________________________________________________________
Date: Dec 29, 2011
5 arm stretches per rib. 4 for the short ones. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Thursday, December 29, 2011 4:30 PM Subject: Re: Pietenpol-List: Rib Stitching That sounds very similar to my experience. The wing rotator helps alot. I had a similar setup. After a few ribs i figured out how much cord it took to do the whole rib with one piece. Lots more fun than i thought it would be Ben Charvet NX966BC Sent from my iPhone On Dec 29, 2011, at 5:55 PM, "Gary Boothe" wrote: HONK.if you have ever experienced rib-stitching a wing solo! Stitches only, excluding marking and re-enforcing tape, 8 hrs 40 minutes. That wasn=99t so bad, considering that I have 10 times that much in my cowlingor 5 times that much in the wind screens! Gary Boothe NX308MB ________________________________________________________________________________
Date: Dec 30, 2011
I'm really glad you are getting all this valuable experience Gary. Its looking really good and I just have to find out the right bribe to get you and Ryan to stop by for a weekend or two!!! Cheers, Jim B. ________________________________________________________________________________
Date: Dec 30, 2011
Mike what is with this radio installation in a Piet? You are supposed to know what green and red lights are for. Where are the pictures? Say Hi to Vic. Jim B. ________________________________________________________________________________
Date: Dec 29, 2011
Awesome Gary... you are really getting it together! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=361958#361958 ________________________________________________________________________________
Date: Dec 29, 2011
Just say the Word, Jim! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Boyer Sent: Thursday, December 29, 2011 6:45 PM Subject: Re: Pietenpol-List: Rib Stitching I'm really glad you are getting all this valuable experience Gary. Its looking really good and I just have to find out the right bribe to get you and Ryan to stop by for a weekend or two!!! Cheers, Jim B. ________________________________________________________________________________
Subject: seafoam
Date: Dec 30, 2011
Anybody ever encountered this stuff? http://www.seafoamsales.com/ ________________________________________________________________________________
Subject: RE: Rib stiching
Date: Dec 30, 2011
Gary you are fast. Took me two hours to figure out how to tie the knot. Th en inevitably there are ribs and structure in the way in certain places. Lo oks great!!! Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Dec 30, 2011
Hi Pieters, The model situation in Japan is the same. If you go to a one stop shop/ plaza place, 99% of the plastic models available are of characters from japanese 'manga' (comic books), with aircraft, ships etc being a very rare find. There are however still stores dedicated to scale plastic models and they do supply a wide range of kits. As far as flying models go, the old fashioned model shop is hard to find and most of the newer generation ones mostly stock ARF/RTF models . I go to one old shop in a small town owned and run by a very old couple to get my balsa supplies and stuff. Model fields are also being shutdown mainly due to urban swelling so that makes things harder as well. I am lucky enough to be able to use a site that dosn't bother people too much. During October this year (2011) I took my R/C Piet out for it's 10th year anniversary flight. The morning was perfect, no wind and silky smooth air. Took a quick shot after the flight (it was 5.42 a.m.). This is a modified kit model, all balsa and loads of fun to fly (slow & relaxing)......hopefully I can sit in my 'other Piet' and fly it on it's 10 anniversary....someday! Cheers! Mark S ________________________________________________________________________________
Subject: Re: seafoam
Date: Dec 30, 2011
I am a total believer in the stuff! I usually buy auto fuel when prices are good and store it in 2 55 gallon barrels. I treat the fuel with Sea Foam. I had an 18 hp Lawnmower that started running quite badly with sticking valves. My neighbor caught me just as I was laying everything out to pull the head, asking if I had tried Sea Foam. Ran to the store, got a can, poured it in the fuel. In about 5 minutes running time, the engine smoothed out and has run fine ever since. And that's been about 2 years. My Pacer has a 125 Lyc and the typical carburetor. Every time I run Aviation gas in it, the needle valve sticks. Coming back from Oshkosh, the valve stuck, causing a run rich condition. When I got home, I poured in a bottle of Sea Foam. Again five minutes of running time and the mixture worked fine. Sea Foam is good stuff - equal to Marvel Mystery oil. M. Haught On Dec 30, 2011, at 2:05 AM, Clif Dawson wrote: > Anybody ever encountered this stuff? > > > http://www.seafoamsales.com/ > > > > ________________________________________________________________________________
Date: Dec 30, 2011
Mahesh, Those picture are from Jake Schultz, steel tube Pietenpol. I believe they are 1/4" Mahogany Plywood. Regards Hans NX 15KV Waller,TX -----Original Message----- From: miyer2u <miyer2u(at)yahoo.com> Sent: Thu, Dec 29, 2011 5:58 pm Subject: Pietenpol-List: Re: Floorboards and rudder pedals... Hello Hans, am building an Avid Flyer and wanted to check the place you sourced your f loor oard? I wanted to install a wood grain floor board pattern for my aircraft , ust like yours! Your pictures look good! Thanks! Mahesh tah ead this topic online here: http://forums.matronics.com/viewtopic.php?p=361941#361941 - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Dec 30, 2011
From: "bradandlinda tds.net" <bradandlinda(at)tds.net>
Mike, Nice looking model. I like the Model A and radiator. Its amazing you've flown it for ten years. What type of engine do you have in it? Brad Williams NX29NX On Fri, Dec 30, 2011 at 7:45 AM, Mark Stanley wrote: > Hi Pieters, > > The model situation in Japan is the same. > If you go to a one stop shop/ plaza place, 99% of the plastic models > available are of characters from japanese 'manga' (comic books), with > aircraft, ships etc being a very rare find. > There are however still stores dedicated to scale plastic models and they > do supply a wide range of kits. > As far as flying models go, the old fashioned model shop is hard to find > and most of the newer generation ones mostly stock ARF/RTF models . I go to > one old shop in a small town owned and run by a very old couple to get my > balsa supplies and stuff. > Model fields are also being shutdown mainly due to urban swelling so that > makes things harder as well. > I am lucky enough to be able to use a site that dosn't bother people too > much. > During October this year (2011) I took my R/C Piet out for it's 10th year > anniversary flight. The morning was perfect, no wind and silky smooth air. > Took a quick shot after the flight (it was 5.42 a.m.). This is a modified > kit model, all balsa and loads of fun to fly (slow & > relaxing)......hopefully I can sit in my 'other Piet' and fly it on it's 10 > anniversary....someday! > > Cheers! > Mark S > > ________________________________________________________________________________
Date: Dec 31, 2011
Hi Brad, Thanks for the comments on the model. I too like the Model A and radiator. They are fairly roughly fashioned to look like the real thing and I am always amazed when people (non-modellers) think the model A actually runs, it gives me a smile. The model was origionally designed for a Cox .049, but I modified it to take a =98Speed 400=99 electric motor with gear reduction to run an 8x4 prop. The electric motor allows me to fly it in a few more areas and not annoy anybody with the noise. It is really a little underpowered but I like to think it is how the full size would fly with a Model A up front, so I don=99t mind. If I ever get the full size Piet finished, I would like a Model A in it as well, love the look! Cheers Mark S From: bradandlinda tds.net Sent: Friday, December 30, 2011 11:47 PM Subject: Re: Pietenpol-List: Where have the Models Gone? Mike, Nice looking model. I like the Model A and radiator. Its amazing you've flown it for ten years. What type of engine do you have in it? Brad Williams NX29NX ________________________________________________________________________________
Date: Dec 30, 2011
Fantastic stuff. I have a friend with 2 real old tractors that were running real rough. He was getting ready to overhaul the engines when I told him about Sea Foam, and after a short running time they smoothed out. He calls it "tune-up" in a can. I believe it also prevents varnishing in stored gas/engines. Brad Williams NX29NX On Fri, Dec 30, 2011 at 7:52 AM, H. Marvin Haught < handainc(at)madisoncounty.net> wrote: > I am a total believer in the stuff! I usually buy auto fuel when prices > are good and store it in 2 55 gallon barrels. I treat the fuel with Sea > Foam. I had an 18 hp Lawnmower that started running quite badly with > sticking valves. My neighbor caught me just as I was laying everything out > to pull the head, asking if I had tried Sea Foam. Ran to the store, got a > can, poured it in the fuel. In about 5 minutes running time, the engine > smoothed out and has run fine ever since. And that's been about 2 years. > My Pacer has a 125 Lyc and the typical carburetor. Every time I run > Aviation gas in it, the needle valve sticks. Coming back from Oshkosh, the > valve stuck, causing a run rich condition. When I got home, I poured in a > bottle of Sea Foam. Again five minutes of running time and the mixture > worked fine. Sea Foam is good stuff - equal to Marvel Mystery oil. > > M. Haught > On Dec 30, 2011, at 2:05 AM, Clif Dawson wrote: > > Anybody ever encountered this stuff? > > > http://www.seafoamsales.com/ > > * > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.homebuilthelp.com">www.homebuilthelp.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > * > > > * > > * > > ________________________________________________________________________________
Subject: Bronze-Brass Bearings
Date: Dec 30, 2011
Happy New Year Friends! Awhile back I had questions regarding "oiled" bearings. I've had trouble locating these in the correct size. I don't mind turning down the outside of the material for a fit but hesitate turning the inside because if not done correctly it can impair the oil properties of the bearings. My question.is anybody flying with plain brass or bronze bearings? Thanks, Jack DSM NX1929T ________________________________________________________________________________
Date: Dec 30, 2011
Subject: Re: Bronze-Brass Bearings
Jack Where are you using these bearings?=C2-=C2- I am going to use high density plastic busings for my biplane aileron hinges( 1/4 od, 3/16 id and 1/16 flange thickness)=C2- They are commonly used in industrial applicat ions, and claimed to have better wear properties than oil-lite bearings/bus hings.=C2- I found them at igus.com .=C2- Let me knwow what you decide. =C2- I haven't ordered mine yet but need to get them so I can procede wit h my aileron cable routing. =C2- Shad --- On Fri, 12/30/11, Jack wrote: From: Jack <jack(at)textors.com> Subject: Pietenpol-List: Bronze-Brass Bearings Date: Friday, December 30, 2011, 11:05 AM Happy New Year Friends!=C2- Awhile back I had questions regarding =9Coiled=9D bearings.=C2- I=99ve had trouble locating these i n the correct size.=C2- I don=99t mind turning down the outside of the material for a fit but hesitate turning the inside because if not done correctly it can impair the oil properties of the bearings.=C2- My questi onis anybody flying with plain brass or bronze bearings? Thanks, Jack DSM NX1929T ________________________________________________________________________________
Date: Dec 30, 2011
The axels Jack Textor Sent from my iPhone On Dec 30, 2011, at 10:05 AM, "Jack" wrote: > Happy New Year Friends! Awhile back I had questions regarding =9Coi led=9D bearings. I=99ve had trouble locating these in the corre ct size. I don=99t mind turning down the outside of the material for a fit but hesitate turning the inside because if not done correctly it can im pair the oil properties of the bearings. My questionis anybody fly ing with plain brass or bronze bearings? > > Thanks, > > Jack > > DSM > > NX1929T > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Dec 30, 2011
I guess plastic won't work for those!, Are you using the big spoked wheels? =C2- I will see if I can find any sources online if you can give me some specs/sizes. =C2- Shad --- On Fri, 12/30/11, Jack wrote: From: Jack <jack(at)textors.com> Subject: Re: Pietenpol-List: Bronze-Brass Bearings Date: Friday, December 30, 2011, 12:23 PM The axels Jack TextorSent from my iPhone On Dec 30, 2011, at 10:05 AM, "Jack" wrote: Happy New Year Friends!=C2- Awhile back I had questions regarding =9Coiled=9D bearings.=C2- I=99ve had trouble locating these i n the correct size.=C2- I don=99t mind turning down the outside of the material for a fit but hesitate turning the inside because if not done correctly it can impair the oil properties of the bearings.=C2- My questi onis anybody flying with plain brass or bronze bearings? Thanks, Jack DSM NX1929T ========= ctric.com >www.buildersbooks.com uilthelp.com matronics.com/contribution ========= >http://www.matronics.com/Navigator?Pietenpol-List ========= cs.com ========= matronics.com/contribution ========= ________________________________________________________________________________
Date: Dec 30, 2011
Mark, awesome looking model. The photo looks like a painting! Wayne, my thoughts exactly. Gotta hold their hands a little, but get them started early and let them make some mistakes along the way. I gave my son (Tyler) his first knife last year for Christmas... a little 2" blade Swiss Army knife... you know, the scissors, knife, tweezers, etc. Good enough to cut a few things, but hopefully not too much. I told him to be careful because the blade was sharp... sure enough a little while later I walk back to his room where he is holding toilet paper around his finger... he just looked at me and said, "I'm ok". Yep, he was bleeding, but not bad. Enough to know what I meant when I said, "be careful, it's sharp". Can't even count how many times I've sliced or poked myself with an exact-o knife. Ha! Since others are sharing photos, here is one of "Mr. Reliable" as they were calling him at the launch site. His Estes Hornet lit off on all three attempts and flew straight and true. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362014#362014 Attachments: http://forums.matronics.com//files/p3132430_138.jpg ________________________________________________________________________________
Date: Dec 30, 2011
Thanks Shad, I did check many including Bunting, National Bronze and McMaster. Tarbell would machine them for $250 which is too high. Bunting sent me a cylinder 1.5 ID and 2.5 OD for $100 but it was =BC =93over tolerance and they want a $20 restock fee. I=92m looking for 1.5=94 ID and 2.3125 OD about 6=94 long. I can turn the OD down but hesitate enlarging the ID. Thanks again, Jack DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of shad bell Sent: Friday, December 30, 2011 11:45 AM Subject: Re: Pietenpol-List: Bronze-Brass Bearings I guess plastic won't work for those!, Are you using the big spoked wheels? I will see if I can find any sources online if you can give me some specs/sizes. Shad --- On Fri, 12/30/11, Jack wrote: From: Jack <jack(at)textors.com> Subject: Re: Pietenpol-List: Bronze-Brass Bearings Date: Friday, December 30, 2011, 12:23 PM The axels Jack Textor Sent from my iPhone On Dec 30, 2011, at 10:05 AM, "Jack" http://us.mc657.mail.yahoo.com/mc/compose?to=jack@textors.com> > wrote: Happy New Year Friends! Awhile back I had questions regarding =93oiled=94 bearings. I=92ve had trouble locating these in the correct size. I don=92t mind turning down the outside of the material for a fit but hesitate turning the inside because if not done correctly it can impair the oil properties of the bearings. My question=85is anybody flying with plain brass or bronze bearings? Thanks, Jack DSM NX1929T ========= ctric.com >www.buildersbooks.com uilthelp.com matronics.com/contribution ========= >http://www.matronics.com/Navigator?Pietenpol-List ========= cs.com ========= matronics.com/contribution ========= ollow target=_blank>www.aeroelectric.com /" rel=nofollow target=_blank>www.buildersbooks.com ofollow target=_blank>www.homebuilthelp.com llow target=_blank>http://www.matronics.com/contribution " rel=nofollow target=_blank>http://www.matronics.com/Navigator?Pietenpol-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Dec 30, 2011
My plans are in the mail Jake, and I have been considering a steel tube fuselage for nearly two years now. Post more pics of your progress as you go, as there is a serious lack of steel tube fuselage construction pics. Kelly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362031#362031 ________________________________________________________________________________
Date: Dec 30, 2011
Speaking of the lack of models, looking at the pic of your daughter using blocks to build a "project" jogged a memory. When was the last time you saw a set of Tinkertoys or an Erector set in the store? These prompted several budding engineers a few decades ago. Lego's just don't quite measure up. On Fri, Dec 30, 2011 at 9:23 AM, Wayne Bressler wrote: > > > My daughter is almost four, and she loves to spend time with me in the > garage. We have built a beginner level rocket together, and are working on > a harder one. Even when we don't have a task in mind, she builds her own > "projects" from my scrap box. Mostly just stacking blocks, but she really > enjoys it. > > Wayne Bressler > Taildraggers, Inc. > www.taildraggersinc.com > > -- "The problem with America is stupidity. I'm not saying there should be capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?" (anon) Boones Mill, VA ________________________________________________________________________________
Date: Dec 30, 2011
My girls insisted I make an AirCamper out of Legos. I only had pics of the the Continental powered one. The black and yellow one had a Model A. Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362040#362040 Attachments: http://forums.matronics.com//files/ac2_262.jpg http://forums.matronics.com//files/ac1_101.jpg ________________________________________________________________________________
Date: Dec 30, 2011
Jack, I have plain bronze bushings in mine. Mainly because it is what I had when I made my hubs and didn't want to buy the oilite. As long as you have about .003"-.004" clearance fit and scribe a few lines in the I.D. across the length of them to hold grease you'll be fine. I have never had any issues with mine. I probably have somewhere around 600-700 landings and they've always spun fine. Every annual I take them off and inspect and grease them well. They seem to be wearing really well. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362043#362043 ________________________________________________________________________________
Date: Dec 30, 2011
Thank you so much Don, just what I needed. The tolerance data is most helpful. When you say scribe, literally? As opposed to milling or filing a groove? -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Don Emch Sent: Friday, December 30, 2011 5:18 PM Subject: Pietenpol-List: Re: Bronze-Brass Bearings Jack, I have plain bronze bushings in mine. Mainly because it is what I had when I made my hubs and didn't want to buy the oilite. As long as you have about .003"-.004" clearance fit and scribe a few lines in the I.D. across the length of them to hold grease you'll be fine. I have never had any issues with mine. I probably have somewhere around 600-700 landings and they've always spun fine. Every annual I take them off and inspect and grease them well. They seem to be wearing really well. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362043#362043 ________________________________________________________________________________
From: Wayne Bressler <wayne(at)taildraggersinc.com>
Date: Dec 30, 2011
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Dec 30, 2011
On a Beechcraft list there was much discussion of "mechanic in a can" chemicals. IE Marvel Mystery Oil and Sea Foam. The general consensus on MMO is either you are a believer or not. Analysis shows it to be a high quality/grade of 5 weight oil (some say 3 wt) with 20% solvent (mineral spirits and Naptha), phosphorus and some wintergrean for smell. It was developed when oil and fuels were varying qualities and often gunked up carbs and engines. Seafoam is light hydrocarbon oil, petroleum naphtha, isopropyl alcohol; and water10%. My experience with both is that they are good for stabilization of fuel and MMO is good for unsticking valves. I also use it to "Prelube" my cylinders when I start my engine after long storage. Good for use on old engines that have been setting (IE old tractors.). and spray lubricants such as WD40, LPS and Corrosion X. WD40 was designed for Water Displacement. It is also a marginal lube. can clean some parts, Rust preventative (marginal) and a penetrating oil. LPS has different products. I like LPS 2 does what WD40 claims but better, especially at lubricating. LPS3 his a heavy Waxy spray that has some lube properties but is really good as a protective coating. Corrosion X is an electrician in a spray can. Well OK, It is good a freeing up electrical components and stopping corrosion. I spray the interior of my 1948 Bonanza with Corrosion X at every annual. I have it leaking out the seams of the plane. Blue Skies, Steve D ----- Original Message ----- From: "bradandlinda tds.net" <bradandlinda(at)tds.net> Date: Friday, December 30, 2011 9:39 Subject: Re: Pietenpol-List: seafoam > Fantastic stuff. I have a friend with 2 real old tractors that were > running real rough. He was getting ready to overhaul the engines > when I > told him about Sea Foam, and after a short running time they > smoothed out. > He calls it "tune-up" in a can. I believe it also prevents > varnishing in > stored gas/engines. Brad Williams NX29NX > > On Fri, Dec 30, 2011 at 7:52 AM, H. Marvin Haught wrote: > > > I am a total believer in the stuff! I usually buy auto fuel when prices > > are good and store it in 2 55 gallon barrels. I treat the fuel with Sea > > Foam. I had an 18 hp Lawnmower that started running quite badly with > > sticking valves. My neighbor caught me just as I was laying everything out > > to pull the head, asking if I had tried Sea Foam. Ran to the store, got a > > can, poured it in the fuel. In about 5 minutes running time, the engine > > smoothed out and has run fine ever since. And that's been about 2 years. > > My Pacer has a 125 Lyc and the typical carburetor. Every time I run > > Aviation gas in it, the needle valve sticks. Coming back from Oshkosh, the > > valve stuck, causing a run rich condition. When I got home, I poured in a > > bottle of Sea Foam. Again five minutes of running time and the mixture > > worked fine. Sea Foam is good stuff - equal to Marvel Mystery oil. > > > > M. Haught > > On Dec 30, 2011, at 2:05 AM, Clif Dawson wrote: > > > > Anybody ever encountered this stuff? > > > > > > http://www.seafoamsales.com/ > > > > * > > > > href="blockedhttp://www.aeroelectric.com">www.aeroelectric.com > > href="blockedhttp://www.buildersbooks.com">www.buildersbooks.com > > href="blockedhttp://www.homebuilthelp.com">www.homebuilthelp.com > > href="blockedhttp://www.matronics.com/contribution">http://www.matronics.com/contribution > > href="blockedhttp://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > > href="blockedhttp://forums.matronics.com">http://forums.matronics.com > > href="blockedhttp://www.matronics.com/contribution">http://www.matronics.com/contribution > > * > > > > > > > > * > > > > * > > > > ________________________________________________________________________________
Date: Dec 30, 2011
Howdy... I post photos on the ROTEC site as well as Matronics... http://www.rotecengines.com/Projects/JakeSchultz.html but I will also post some more here in a week or so......... you are right that the plans are not nearly as detailed for the steel version. I used two layers of 1/8 inch marine plywood and a top layer of "bubinga" veneer.... All laminated together in a jig to follow the curve of the bottom of the fuselage. I am working on many, many metal fittings these days, for the control system, the seat belt attach points, and everywhere else where someting attaches to the fuselage. -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362070#362070 ________________________________________________________________________________
Date: Dec 31, 2011
Hi Curt, Hadn't thought about making a Piet out of Lego, it looks pretty good! Cheers Mark S -----Original Message----- From: Piet2112 Sent: Saturday, December 31, 2011 8:02 AM Subject: Pietenpol-List: Re: Where have the Models Gone? My girls insisted I make an AirCamper out of Legos. I only had pics of the the Continental powered one. The black and yellow one had a Model A. Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362040#362040 Attachments: http://forums.matronics.com//files/ac2_262.jpg http://forums.matronics.com//files/ac1_101.jpg ________________________________________________________________________________
Date: Dec 30, 2011
I'm CRUSHED! No 'vair powered Piets? Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2112 Sent: Friday, December 30, 2011 3:02 PM Subject: Pietenpol-List: Re: Where have the Models Gone? My girls insisted I make an AirCamper out of Legos. I only had pics of the the Continental powered one. The black and yellow one had a Model A. Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362040#362040 Attachments: http://forums.matronics.com//files/ac2_262.jpg http://forums.matronics.com//files/ac1_101.jpg ________________________________________________________________________________
Subject: Piet on eBay
Date: Dec 31, 2011
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130624037587&s sPageName=ADME:B:SS:MOTORS:1123 Jack DSM NX1929T ________________________________________________________________________________
Date: Dec 31, 2011
Filing or scribing. As long as you have something there to hold a little grease. Having the clearance is VERY important. You don't want them to run tight. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362082#362082 ________________________________________________________________________________
Subject: Happy 2012!
Date: Jan 01, 2012
Hi Pieters, It's a bit after 12 midnight here in Japan land. Just want to wish you all a safe and happy New Year! Safe Flying (and building) Cheers Mark S Japan ________________________________________________________________________________
Subject: Netflix for Pilots
Date: Dec 31, 2011
http://writingsofjon.blogspot.com/2011/12/aviation-netflix-for-pilots.html Enjoy Ya'll. P.S. The occasional ad click helps keep me blogging. -------- http://writingsofjon.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362106#362106 ________________________________________________________________________________
Date: Dec 31, 2011
Subject: Operation Arrow Fest Update #2
Crew, after taking some time off for Christmas and doing some computer ACM with a friend a few days, I am back in action.- To date I have the vert. stab., rudder and both elevators finished. I have one side of the horizonta l stabilizer done, (I don't have a piece of fabric long enough to do the ot her side.)--One aileron is covered and ready for stitching.-- I hav e enough fabric to cover one side of the other aileron, but that will be it until I purchase more. - Once I wrap up the covering that I can do now, I will work on my insignias and prepare for paint.- Colors have already been chosen and I expect to s tart laying out/painting the tail pieces Monday or Tuesday. - Happy, blessed new year all! Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Pre Cover empty weight
Date: Dec 31, 2011
I have my Piet pre assembled and finally able to get an initial weight. comes in at 720 empty. from my reading a covering job is about 35-40 lbs, so i am still hoping to come in under 800 lbs. I plan to use stewarts and 1.7 oz fabric. It's looking a bit nose heavy, but i am going to wait until the rear is covered, that should correct some of that. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362134#362134 Attachments: http://forums.matronics.com//files/img_2083_374.jpg http://forums.matronics.com//files/img_2082_195.jpg http://forums.matronics.com//files/img_2081_688.jpg http://forums.matronics.com//files/img_2080_134.jpg ________________________________________________________________________________
Subject: Re: Last flight of 2011
Date: Dec 31, 2011
Wow, how poetic! Was hoping to go flying today, the weather near Chattanooga sounds the same as yours. However, the plane had a couple landing gear issues which needed addressing. Good news, got all that fixed and she's a total up bird for the new year. But it took a while and I had to leave to position myself for work tomorrow morning. So my last flight of the year turned out to be about a week ago. Dismal weather really, dull and gloomy, overcast, cold. But, it turned out to be the first time in my short Piet history that I left the pattern solo. Just flew around looking at people and things, did a couple touch and gos at friend's fields nearby. I was in a rather dull mood before the flight, but was happy and care free by the end. This whole genre of flying has REALLY opened my eyes and I'm enjoying it a lot more than I could have ever imagined. Happy New Year to all. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362149#362149 ________________________________________________________________________________
Date: Dec 31, 2011
Does anyone have a the procedure or diagram of how the axel is held in place using bungee cords; Jenny style gear. Sent from my iPhone On Dec 31, 2011, at 4:52 PM, "tools" wrote: > > Wow, how poetic! Was hoping to go flying today, the weather near Chattanooga sounds the same as yours. However, the plane had a couple landing gear issues which needed addressing. Good news, got all that fixed and she's a total up bird for the new year. But it took a while and I had to leave to position myself for work tomorrow morning. > > So my last flight of the year turned out to be about a week ago. Dismal weather really, dull and gloomy, overcast, cold. But, it turned out to be the first time in my short Piet history that I left the pattern solo. Just flew around looking at people and things, did a couple touch and gos at friend's fields nearby. I was in a rather dull mood before the flight, but was happy and care free by the end. > > This whole genre of flying has REALLY opened my eyes and I'm enjoying it a lot more than I could have ever imagined. > > Happy New Year to all. > > Tools > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=362149#362149 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 31, 2011
Happy New Year!! Report from Loensloe Airfield: Just got back down from a one hour flight with the Aeronca Sedan. An absolutely gorgeous day down here, in amongst th e hills and hollers of west Tennessee on the last day of the year- 62 degre es F, windless, and CAVU. Flew west for about 1/2 an hour to investigate th e location of a fly-in restaurant I need to go to. Fatty's Diner in Latham, TN. Latham is so small it doesn't even show up on my Garman 195 GPS. Short grass strip with wires (with orange balls) at one end. Can't wait to try i t out. Dan Helsper Puryear, TN -----Original Message----- From: tools <n0kkj(at)yahoo.com> Sent: Sat, Dec 31, 2011 3:55 pm Subject: Pietenpol-List: Re: Last flight of 2011 Wow, how poetic! Was hoping to go flying today, the weather near Chattanoo ga ounds the same as yours. However, the plane had a couple landing gear issu es hich needed addressing. Good news, got all that fixed and she's a total up ird for the new year. But it took a while and I had to leave to position yself for work tomorrow morning. So my last flight of the year turned out to be about a week ago. Dismal we ather eally, dull and gloomy, overcast, cold. But, it turned out to be the first ime in my short Piet history that I left the pattern solo. Just flew aroun d ooking at people and things, did a couple touch and gos at friend's fields earby. I was in a rather dull mood before the flight, but was happy and ca re ree by the end. This whole genre of flying has REALLY opened my eyes and I'm enjoying it a lot ore than I could have ever imagined. Happy New Year to all. Tools ead this topic online here: http://forums.matronics.com/viewtopic.php?p=362149#362149 - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: -= -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Dec 31, 2011
Here is one way to put the finishing touch on you plane! http://biggeekdad.com/2011/12/best-airplane-mechanic-ever/ ________________________________________________________________________________
Date: Dec 31, 2011
Thanks Jake, I enjoyed the pics, and looking forward to more. I see you widened the fuselage by two inches, is it built to plans, other than that, or did you make other mods? Kelly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362162#362162 ________________________________________________________________________________
Subject: Re: 2012 Ohio Piet Fly-in
Date: Jan 01, 2012
Shad, My Aircamper is still under construction, but count me in. My Zenith loves grass strips. -------- David Gallagher 601 XL-B: flying, 200+ hours now Next project: Pietenpol/GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362182#362182 ________________________________________________________________________________
Date: Jan 01, 2012
I flew mine for a bit late Friday afternoon. Temperature was 51=B0 and the winds were light. I put about 30 minutes on it ' long enough to get the oil temp up to about 130, which is about all I ever get it to in the winter. This was the first time I=92ve been able to fly it since Thanksgiving, so was glad to blow the dust off it. Happy New Year, everyone! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Saturday, December 31, 2011 4:52 PM Subject: Pietenpol-List: Re: Last flight of 2011 Wow, how poetic! Was hoping to go flying today, the weather near Chattanooga sounds the same as yours. However, the plane had a couple landing gear issues which needed addressing. Good news, got all that fixed and she's a total up bird for the new year. But it took a while and I had to leave to position myself for work tomorrow morning. So my last flight of the year turned out to be about a week ago. Dismal weather really, dull and gloomy, overcast, cold. But, it turned out to be the first time in my short Piet history that I left the pattern solo. Just flew around looking at people and things, did a couple touch and gos at friend's fields nearby. I was in a rather dull mood before the flight, but was happy and care free by the end. This whole genre of flying has REALLY opened my eyes and I'm enjoying it a lot more than I could have ever imagined. Happy New Year to all. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362149#362149 ________________________________________________________________________________
Date: Jan 01, 2012
Dave, You're more than welcome, I still am not sure on a date or even a mon th as of yet, but stay tuned.- I was hoping for some recomendations for d ates, times of year to host.- Many people are busy during the summer with vacations etc.- I am looking for people to chime in here, I will pick a date that best suits the majority, and matches my scedule, I can plan ahead to get the days off if need be.- - - TO ALL, LET ME KNOW WHEN YOU ALL WOULD LIKE TO HAVE AN OHIO PIET/TAILDRAGER FLY-IN, I NEED TO KNOW WHEN MOST OF YOU COULD MAKE IT, TO MAKE IT WORTH TH E PLANNING AND EXPENSE OF PUTING THIS THING TOGEATHER. - Shad --- On Sun, 1/1/12, DaveG601XL wrote: From: DaveG601XL <david.m.gallagher(at)ge.com> Subject: Pietenpol-List: Re: 2012 Ohio Piet Fly-in Date: Sunday, January 1, 2012, 12:51 PM m> Shad, My Aircamper is still under construction, but count me in.- My Zenith lov es grass strips. -------- David Gallagher 601 XL-B: flying, 200+ hours now Next project: Pietenpol/GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362182#362182 le, List Admin. ________________________________________________________________________________
Date: Jan 02, 2012
Subject: Poem to Live By
Here is a poem my Dad had in his shop while building his Pietenpol, and Cor vair and is now in my shop where I am building my airplane. - It Couldn't Be Done---By Edgar A. Guest - Somebody said it couldn't be done' But he with a chuckle replied That "Mabe it couldn't", but he would be one who wouldn't say so till he'd tried. So he buckled right in with the trace of a grin, and if he worried, he certinly hid hid it. He started to sing as he tackled the thing that couldn't be done and he did it. Somebody scoffed; "Oh you'll never do that; at least no one ever has done i t;" But he took off his coat and he took off his hat, and the first thing we kn ew he'd begun it. With-a lift of his chin and a bit of a grin, without any doubt or quit it , He started to sing as he tackled the thing that couldn't be done and he d id it. There are thousands to tell you it cannot be done, There are thousands to p rophsy failure; There are thousands to point out to you one by one the dangers that wait to asail you. But just buckle right in with a bit of a grin, just take off your coat and go to it;- Just start to sing as you tackle the thing that "cannot be don e" and you'll do it. - Shad P.S.- This i for all you builders who might have some sceptical friends o r aquaintances.- You CAN do it, Corvair, Continental, Ford, Suburu or wha t ever, keep at it it will fly some day! ________________________________________________________________________________
Date: Jan 02, 2012
Date: Jan 02, 2012
Nuthin' there, Dan -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Monday, January 02, 2012 6:40 AM Subject: Re: Pietenpol-List: Rib Stitching ________________________________________________________________________________
Date: Jan 02, 2012
Date: Jan 02, 2012
I used the oiled bearings from MC. One thing I did do is use some Loctite 640 Bearing Retainer to set the bearing into the wheel hub. If using the oil type bearings just wipe the surface with alcohol to remove the oil and then apply the Loctite. This will keep the bearing from spinning in the wheel hub and wearing it out. The oiled bearings can be replaced by heating the bearing some and pressing them out. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362220#362220 ________________________________________________________________________________
Date: Jan 02, 2012
...still nuthin'... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Monday, January 02, 2012 4:44 AM Subject: Pietenpol-List: Rib Stitching ________________________________________________________________________________
Date: Jan 02, 2012
Subject: Brodhead 2012
First act of 1-1-12 I marked my new calendar with Brodhead Hatz/Piet Fest dates: Thu 7-19 to Sun 7-22. Happy New Year, Tim in central TX ________________________________________________________________________________
Date: Jan 02, 2012
Subject: Re: Last flight of the year.
I'm enjoying reading about people's last flights of 2011 and first of 2012. Like Jack Phillips, I got in a nice late-afternoon flight on Friday, but I had to work for it. The hangar where the Piet stays is one of those Port-a-port hangars, with side doors that bifold on rollers horizontally, and a single center door that pushes up and latches, and is counterbalanced with big springs and cables. Last week, I went down to the strip and the springs on one side has snapped. That center door is way heavy. Friday, I didn't have anyone to help me so I tried pushing the door up as far as I could and bracing it with a 4 foot piece of steel pipe. Then I pushed it up farther by walking a longer 2X4 up wedged between the asphalt floor and the door. Finally, I got it up and latched but using a still longer 2X4. Replacement springs are ordered - Ben Gay has been applied! Friday was warm - high 50s but breezy. Flying north with the wind was a lot of fun but it was slow coming back south. Still it was a great way to end the year, and after landing I realized that it was a year to the day that we'd trucked the wings down to Twin Rivers and attached them to the fuselage, and made it into a real airplane. Happy New Year, Good People! Matt Paxton NX629ML ________________________________________________________________________________
Date: Jan 02, 2012
Subject: Re: Brodhead 2012
Tim,mine is marked too. If I can just get my wings done. Ribs are done, Spars are cut Leading edge cut, but nothing put together yet Happy New Year. Gardiner ________________________________ From: Timothy Willis <timwillis01(at)gmail.com> Sent: Mon, January 2, 2012 11:22:01 AM Subject: Pietenpol-List: Brodhead 2012 First act of 1-1-12 I marked my new calendar with Brodhead Hatz/Piet Fest dates: Thu 7-19 to Sun 7-22. Happy New Year, Tim in central TX ________________________________________________________________________________
Subject: Powder Coat Supplier
Date: Jan 02, 2012
A few weeks ago someone mentioned a powder coat supplier. I couldn't find in the archive. Could you share again? Thanks, Jack DSM ________________________________________________________________________________
Subject: Re: Powder Coat Supplier
Date: Jan 03, 2012
I got my setup @ Eastwood. Eastwood.com JM -----Original Message----- From: "Jack" <jack(at)textors.com> Sender: owner-pietenpol-list-server(at)matronics.com Date: Mon, 2 Jan 2012 19:24:29 Subject: Pietenpol-List: Powder Coat Supplier This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Jan 02, 2012
Hey Jack! I bought a kit from Eastwood.com About $150 or maybe $199 for everything needed to get started. Well, except a small compressor and an electric oven..... Worked great... JM -----Original Message----- From: Jack Sent: Jan 2, 2012 7:24 PM Subject: Pietenpol-List: Powder Coat Supplier A few weeks ago someone mentioned a powder coat supplier. I couldnt find in the archive. Could you share again? Thanks, Jack DSM ________________________________________________________________________________
Date: Jan 03, 2012
I've been replacing journal bearings for forty years. It's been my experience and is industry practice to heat the surounding metal to enlarge the hole. Heating the bearing directly will enlarge the bearing itself thus jamming it tighter. If the bearing is small, od 1" or less, and accessible from the other side, you can hammer it out with a brass drift, carefully. Larger ones should be pulled out with an "inside" puller.You can make one yourself to fit the application with iron plumbing parts, a long bolt and nut and a thick washer to fit the bearing. The pipe and a cap form a recepticle for the bearing to slide into. Clif Life is not a matter of holding good cards, but rather, of playing a bad hand well!" Robert Louis Stevenson > > The oiled bearings can be replaced by heating the bearing some and > pressing them out. > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=362220#362220 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Jan 03, 2012
Hi Jim, I have a sprayer; I'm searching for a very special color. I've tried paint from Eastwood and NIC. Someone mentioned a supplier in the last two weeks I had not tried. Thanks! Jack DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jim_markle(at)mindspring.com Sent: Monday, January 02, 2012 7:48 PM Subject: Re: Pietenpol-List: Powder Coat Supplier I got my setup @ Eastwood. Eastwood.com JM _____ From: "Jack" <jack(at)textors.com> Sender: owner-pietenpol-list-server(at)matronics.com Date: Mon, 2 Jan 2012 19:24:29 -0600 ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Powder Coat Supplier A few weeks ago someone mentioned a powder coat = supplier. I couldn't find in the archive. Could you share = again? Thanks, Jack DSM ________________________________________________________________________________
Date: Jan 03, 2012
... you heat the bearing to just soften the retaining compound, then press it out. Sorry if I was not clear enough on that. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362316#362316 ________________________________________________________________________________
Date: Jan 03, 2012
Subject: Classic Aviation footage
Ladies and Gentlemen: Just so I don't start out the year by gettng flamed for un-Pietenpolish conduct, let me say that if you watch this classic aviation footage all the way through you will find a "sort of" Pietenpol connection. Note in particular the open cockpit and the use of a doorbell ringer that cost $2. http://www.aircraftowner.com/videos/view/americas-first-jet-flight-october- 1942_1617.html Stinemetze N328X ________________________________________________________________________________
Date: Jan 03, 2012
I'm not sure what was mentioned before but I've used Pendry powder coatings f or my powder before. They have some variety of materials. www.pendrypowdercoatings.com/ Mike Groah Sent from my iPhone On Jan 3, 2012, at 3:24 AM, "Jack" wrote: > Hi Jim, > I have a sprayer; I=99m searching for a very special color. I =99ve tried paint from Eastwood and NIC. Someone mentioned a supplier in th e last two weeks I had not tried. > Thanks! > Jack > DSM > NX1929T > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of jim_markle(at)mindspring.com > Sent: Monday, January 02, 2012 7:48 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Powder Coat Supplier > > I got my setup @ Eastwood. > > Eastwood.com > > JM > From: "Jack" <jack(at)textors.com> > Sender: owner-pietenpol-list-server(at)matronics.com > Date: Mon, 2 Jan 2012 19:24:29 -0600 > To: > ReplyTo: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Powder Coat Supplier > > A few weeks ago someone mentioned a powder coat = supplier. I couldn =99t find in the archive. Could you share = again? > > Thanks, > > Jack > > DSM > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 04, 2012
Mike thanks but that is not the one mentioned. It does have a lot of good ideas though. It's driving me nuts. It was posted a few weeks ago, I believe in the metal priming thread. I looked at the site quickly and it had the color I'm seeking on the front page. I either didn't bookmark it or can't find the bookmark. I've read every thread in the archives with no luck. Thanks again Mike Jack DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Groah Sent: Tuesday, January 03, 2012 11:46 PM Subject: Re: Pietenpol-List: Powder Coat Supplier I'm not sure what was mentioned before but I've used Pendry powder coatings for my powder before. They have some variety of materials. www.pendrypowdercoatings.com/ Mike Groah Sent from my iPhone On Jan 3, 2012, at 3:24 AM, "Jack" wrote: Hi Jim, I have a sprayer; I'm searching for a very special color. I've tried paint from Eastwood and NIC. Someone mentioned a supplier in the last two weeks I had not tried. Thanks! Jack DSM NX1929T _____ From: <mailto:owner-pietenpol-list-server(at)matronics.com> owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jim_markle(at)mindspring.com Sent: Monday, January 02, 2012 7:48 PM Subject: Re: Pietenpol-List: Powder Coat Supplier I got my setup @ Eastwood. Eastwood.com JM _____ From: "Jack" <jack(at)textors.com> Sender: owner-pietenpol-list-server(at)matronics.com Date: Mon, 2 Jan 2012 19:24:29 -0600 ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Powder Coat Supplier A few weeks ago someone mentioned a powder coat = supplier. I couldn't find in the archive. Could you share = again? Thanks, Jack DSM ================================== >http://www.matronics.com/Navigator?Pietenpol-List ================================== cs.com ================================== matronics.com/contribution ================================== ________________________________________________________________________________
Date: Jan 04, 2012
Finally found it, thanks to all. http://www.columbiacoatings.com <http://www.columbiacoatings.com/> they changed their front page which threw me off. Jack DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Wednesday, January 04, 2012 5:41 AM Subject: RE: Pietenpol-List: Powder Coat Supplier Mike thanks but that is not the one mentioned. It does have a lot of good ideas though. It's driving me nuts. It was posted a few weeks ago, I believe in the metal priming thread. I looked at the site quickly and it had the color I'm seeking on the front page. I either didn't bookmark it or can't find the bookmark. I've read every thread in the archives with no luck. Thanks again Mike Jack DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Groah Sent: Tuesday, January 03, 2012 11:46 PM Subject: Re: Pietenpol-List: Powder Coat Supplier I'm not sure what was mentioned before but I've used Pendry powder coatings for my powder before. They have some variety of materials. www.pendrypowdercoatings.com/ Mike Groah Sent from my iPhone On Jan 3, 2012, at 3:24 AM, "Jack" wrote: Hi Jim, I have a sprayer; I'm searching for a very special color. I've tried paint from Eastwood and NIC. Someone mentioned a supplier in the last two weeks I had not tried. Thanks! Jack DSM NX1929T _____ From: <mailto:owner-pietenpol-list-server(at)matronics.com> owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jim_markle(at)mindspring.com Sent: Monday, January 02, 2012 7:48 PM Subject: Re: Pietenpol-List: Powder Coat Supplier I got my setup @ Eastwood. Eastwood.com JM _____ From: "Jack" <jack(at)textors.com> Sender: owner-pietenpol-list-server(at)matronics.com Date: Mon, 2 Jan 2012 19:24:29 -0600 ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Powder Coat Supplier A few weeks ago someone mentioned a powder coat = supplier. I couldn't find in the archive. Could you share = again? Thanks, Jack DSM ================================== >http://www.matronics.com/Navigator?Pietenpol-List ================================== cs.com ================================== matronics.com/contribution ================================== http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 04, 2012
Powder Coat Supplierwas it eastwood?? From: Jack Sent: Wednesday, January 04, 2012 6:41 AM Subject: RE: Pietenpol-List: Powder Coat Supplier Mike thanks but that is not the one mentioned. It does have a lot of good ideas though. It=99s driving me nuts. It was posted a few weeks ago, I believe in the metal priming thread. I looked at the site quickly and it had the color I=99m seeking on the front page. I either didn=99t bookmark it or can=99t find the bookmark. I=99ve read every thread in the archives with no luck. Thanks again Mike Jack DSM NX1929T ------------------------------------------------------------------------- ------- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Groah Sent: Tuesday, January 03, 2012 11:46 PM Subject: Re: Pietenpol-List: Powder Coat Supplier I'm not sure what was mentioned before but I've used Pendry powder coatings for my powder before. They have some variety of materials. www.pendrypowdercoatings.com/ Mike Groah Sent from my iPhone On Jan 3, 2012, at 3:24 AM, "Jack" wrote: Hi Jim, I have a sprayer; I=99m searching for a very special color. I=99ve tried paint from Eastwood and NIC. Someone mentioned a supplier in the last two weeks I had not tried. Thanks! Jack DSM NX1929T ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jim_markle(at)mindspring.com Sent: Monday, January 02, 2012 7:48 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Powder Coat Supplier I got my setup @ Eastwood. Eastwood.com JM ------------------------------------------------------------------------- ----- From: "Jack" <jack(at)textors.com> Sender: owner-pietenpol-list-server(at)matronics.com Date: Mon, 2 Jan 2012 19:24:29 -0600 To: ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Powder Coat Supplier A few weeks ago someone mentioned a powder coat = supplier. I couldn=99t find in the archive. Could you share = again? Thanks, Jack DSM ==========>http://www.matronics.com/Navigator?Pietenp ol-List====================== =============cs.com========== matronics.com/contribution================ =================== http://www.matronics.com/Navigator?Pietenpol-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Subject: Riblet 612 cg range?
Date: Jan 04, 2012
I am finishing up my pre cover w/b and it is working out real nice, should be able to keep the cabanes vertical. Does anyone have the published cg range for the Riblett airfoil? i was going to use 15-20" aft of the leading edge. Has anyone else other than Lowel flown the Riblett yet? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362388#362388 ________________________________________________________________________________
Date: Jan 05, 2012
Subject: Re: Riblet 612 cg range?
Hi Chris, I'm also building a Riblett 612 wing. A fellow builder over here was advised by Mr Riblett to keep the CoG range between 10.8" and 16.8" aft of LE. For the initial flight the aft limit should be only 15 inches, if OK this may be increased to 16.8 in increments. Others may be able to confirm these figures or present alternate CoG range. JohnW Perth Western Australia ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Jan 04, 2012
I have brass bushing in my Piet. I just changed the Bungee cords on a friends Piet and she has the plastic automotive Kingpin bushings in hers. The plane was built in the 70's and the bushings still look new. Seems like a great alternative to me. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362412#362412 ________________________________________________________________________________
Date: Jan 04, 2012
I hope for the sake of safety that all of the Riblett wing builders are aware of that statement from Mr. Riblett. That range could prove to be difficult to obtain on the Pietenpol. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362415#362415 ________________________________________________________________________________
Date: Jan 04, 2012
Subject: Re: Classic Aviation footage
Is that Stan Laurel at 5:56? Jim Ash -----Original Message----- From: TOM STINEMETZE Sent: Jan 3, 2012 11:13 AM Subject: Pietenpol-List: Classic Aviation footage Ladies and Gentlemen: Just so I don't start out the year by gettng flamed for un-Pietenpolish conduct, let me say that if you watch this classic aviation footage all the way through you will find a "sort of" Pietenpol connection. Note in particular the open cockpit and the use of a doorbell ringer that cost $2. http://www.aircraftowner.com/videos/view/americas-first-jet-flight-october-1942_1617.html Stinemetze N328X ________________________________________________________________________________
From: "RickBright" <brightwellrichard(at)yahoo.com>
Date: Jan 04, 2012
Am planning on attending this year for our first visit, I ordered the Pietenpol plans and and am in the process of making room in the shop for the Air Camper Project.. One of my other passions is old GM Converted buses, I have a converted 1959 4104 GM Coach, can anyone recommend a campground with water/electric hookups close to the airport, could get by with no water or sewer but an electric cord would be nice. I probably will now tow a car so close would be great...I understand there is camping on site but no hookups? Thanks Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362445#362445 ________________________________________________________________________________
Date: Jan 04, 2012
Hi Rick Brodhead is a simple small town, but it has good facilities. The airport is about a mile out of town. You can bring your camper in and park it in the airport parking lot for a total charge of $5. There is no electricity or water sewer hookups. Dick N. ----- Original Message ----- From: "RickBright" <brightwellrichard(at)yahoo.com> Sent: Wednesday, January 04, 2012 7:25 PM Subject: Pietenpol-List: Re: Brodhead 2012 > > > Am planning on attending this year for our first visit, I ordered the > Pietenpol plans and and am in the process of making room in the shop for > the Air Camper Project.. > > One of my other passions is old GM Converted buses, I have a converted > 1959 4104 GM Coach, can anyone recommend a campground with water/electric > hookups close to the airport, could get by with no water or sewer but an > electric cord would be nice. I probably will now tow a car so close would > be great...I understand there is camping on site but no hookups? > > Thanks > Rick > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=362445#362445 > > > ________________________________________________________________________________
Date: Jan 05, 2012
Crazy Horse Campground on the northwest side of Broadhead. All the hookups and maybe 3 miles from the airport. If you tow a car, it works great. Perry Rhoads N12939 ----- Original Message ----- From: "RickBright" <brightwellrichard(at)yahoo.com> Sent: Wednesday, January 4, 2012 7:25:57 PM Subject: Pietenpol-List: Re: Brodhead 2012 Am planning on attending this year for our first visit, I ordered the Pietenpol plans and and am in the process of making room in the shop for the Air Camper Project.. One of my other passions is old GM Converted buses, I have a converted 1959 4104 GM Coach, can anyone recommend a campground with water/electric hookups close to the airport, could get by with no water or sewer but an electric cord would be nice. I probably will now tow a car so close would be great...I understand there is camping on site but no hookups? Thanks Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362445#362445 ________________________________________________________________________________
Date: Jan 04, 2012
If you do the math, the BH airfoil has a range of 25-40% MAC (mean aerodynamic chord). The Riblett recommendation is for 18-28% MAC. For reference, Beech has a CG range of 21-37% MAC for the Bonanza, slightly more restrictive than BH but wider than Riblett. The Beech 18 is unstable with a CG aft of 30.5 which is in line with the Riblett. The swept wing aircraft I've flown have run in the 16-35% range. The point of all this is that there is no good rule of thumb for CG limits but they need to be determined by flight testing in an organized, scientific manner if you're flying serial number 1. Sounds like fun!!! For those who are close to flying the Riblett, this would be an excellent use of the 25/40 hour fly off rather than boring holes in the sky. Dave Aldrich Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362452#362452 ________________________________________________________________________________
Date: Jan 04, 2012
My estimates put the cg at 18" the way i have it rigged now.....i did some archive searching and pieti lowell says the cg range is real similar to the original piet airfoil. I was really hoping some more people would be flying the ribletts by now, i dont want to be first!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362463#362463 ________________________________________________________________________________
Date: Jan 05, 2012
Tom, That was really interesting and enjoyable. Thanks for sharing it. Greg Bacon Prairie Home, MO On Tue, Jan 3, 2012 at 10:13 AM, TOM STINEMETZE wrote: > *Ladies and Gentlemen:* > ** > *Just so I don't start out the year by gettng flamed for un-Pietenpolish > conduct, let me say that if you watch this classic aviation footage all the > way through you will find a "sort of" Pietenpol connection. Note in > particular the open cockpit and the use of a doorbell ringer that cost $2. > * > ** > > http://www.aircraftowner.com/videos/view/americas-first-jet-flight-october-1942_1617.html > > *Stinemetze* > *N328X* > > * > > * > > -- Greg Bacon ________________________________________________________________________________
Subject: Re: Where have the Models Gone?
Date: Jan 05, 2012
It warmed my heart too, so much so that I asked Ben to use it on the original article. He has graciously agreed. Thank You Ben! That picture reminds me so much of me and my father when I was little! -------- http://writingsofjon.blogspot.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362479#362479 ________________________________________________________________________________
Date: Jan 05, 2012
Subject: "First Air Camper?"
This has nothing to do with building or flying Pietenpols, but much to do with Air Camper history. When did BHP build the first "Air Camper" and what was its engine? I have seen conflicting claims on various sites as to when Mr. Pietenpol built his first Air Camper, and what he used for an engine. My mindset tells me it was in 1929 and it used a Model A Ford: "Low & Slow since 1929." But that conclusion is what I recall from various sites, including this board, and from memory. However I have seen references to a 1928 date and an Ace water cooled engine. Was there such an earlier plane, and if so, did it look like an Air Camper? Was it called an "Air Camper?" Did it fly? I have seen references to "an earlier plane" than the Air Camper that "did not fly/did not fly well." Was that the Ace-powered plane? Wikipedia has somewhat different info from what I recall from our site. The Pietenpol family website now has less historical information than the version from 2008 and before. What is the best source for this info? Is it Chet Peek's book, and if so, if you have it, would you take a look? If so, please post here, if you like. Otherwise if you would like to post to me offline, I will look over responses and post results. I am hoping the answer is clear and not controversial. Thanks, Tim in central TX ________________________________________________________________________________
Date: Jan 05, 2012
Subject: Re: "First Air Camper?"
Hi Tim, Kevin Holcomb put together a spreadsheet of the history of aircraft that Bernard built. It is here: http://www.airminded.net/piet/piet_list.xls Which is linked to from this page: http://www.airminded.net/piet/piet.html It gives a pretty good run down of what Bernard built, when, and what he powered it with. I can not vouch for its accuracy but Kevin did include references so I think it's pretty legit. Hope this helps, Dan On 01/05/2012 11:38 AM, Timothy Willis wrote: > --> Pietenpol-List message posted by: Timothy Willis > > This has nothing to do with building or flying Pietenpols, but much to > do with Air Camper history. > When did BHP build the first "Air Camper" and what was its engine? > > I have seen conflicting claims on various sites as to when Mr. > Pietenpol built his first Air Camper, and what he used for an engine. > My mindset tells me it was in 1929 and it used a Model A Ford: "Low& > Slow since 1929." > But that conclusion is what I recall from various sites, including > this board, and from memory. > > However I have seen references to a 1928 date and an Ace water cooled engine. > Was there such an earlier plane, and if so, did it look like an Air Camper? > Was it called an "Air Camper?" Did it fly? > I have seen references to "an earlier plane" than the Air Camper that > "did not fly/did not fly well." Was that the Ace-powered plane? > > Wikipedia has somewhat different info from what I recall from our site. > The Pietenpol family website now has less historical information than > the version from 2008 and before. > What is the best source for this info? Is it Chet Peek's book, and if > so, if you have it, would you take a look? > > If so, please post here, if you like. Otherwise if you would like to > post to me offline, I will look over responses and post results. I am > hoping the answer is clear and not controversial. > Thanks, > Tim in central TX > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jan 05, 2012
Chris, The GA30U-612 is used on the Skystar Kitfox Lite and Kitfox Speedster. See here: http://www.ae.illinois.edu/m-selig/ads/aircraft.html Here's a page I found on the Speedster that lists the most forward CG position of 20% of MAC and most rearward at 31.3% of MAC. See near the bottom of the page: http://www.wefly4fun.com/Kitfox-01.htm That seems to be pretty much in line with the FC-10... In a similar vein, I've been meaning to plug N8031s data into the following calculator, but I just haven't found the time, yet: http://www.geistware.com/rcmodeling/cg_super_calc.htm Cheers, Dan On 01/04/2012 10:20 PM, Chris Rusch wrote: > --> Pietenpol-List message posted by: "Chris Rusch" > > My estimates put the cg at 18" the way i have it rigged now.....i did some archive searching and pieti lowell says the cg range is real similar to the original piet airfoil. I was really hoping some more people would be flying the ribletts by now, i dont want to be first!! > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jan 05, 2012
Dan, Wow! Thanks. That seems to cover it for me. Great resource. I have saved it. Tim in central TX ================== On Thu, Jan 5, 2012 at 12:20 PM, Dan Yocum wrote: > Hi Tim, > > Kevin Holcomb put together a spreadsheet of the history of aircraft that > Bernard built. It is here: > > http://www.airminded.net/piet/piet_list.xls > > Which is linked to from this page: > > http://www.airminded.net/piet/piet.html > > It gives a pretty good run down of what Bernard built, when, and what he > powered it with. I can not vouch for its accuracy but Kevin did include > references so I think it's pretty legit. > > Hope this helps, > Dan > > > On 01/05/2012 11:38 AM, Timothy Willis wrote: >> >> Willis >> >> This has nothing to do with building or flying Pietenpols, but much to >> do with Air Camper history. >> When did BHP build the first "Air Camper" and what was its engine? >> >> I have seen conflicting claims on various sites as to when Mr. >> Pietenpol built his first Air Camper, and what he used for an engine. >> My mindset tells me it was in 1929 and it used a Model A Ford: "Low& >> Slow since 1929." >> But that conclusion is what I recall from various sites, including >> this board, and from memory. >> >> However I have seen references to a 1928 date and an Ace water cooled >> engine. >> Was there such an earlier plane, and if so, did it look like an Air >> Camper? >> Was it called an "Air Camper?" Did it fly? >> I have seen references to "an earlier plane" than the Air Camper that >> "did not fly/did not fly well." Was that the Ace-powered plane? >> >> Wikipedia has somewhat different info from what I recall from our site. >> The Pietenpol family website now has less historical information than >> the version from 2008 and before. >> What is the best source for this info? Is it Chet Peek's book, and if >> so, if you have it, would you take a look? >> >> If so, please post here, if you like. Otherwise if you would like to >> post to me offline, I will look over responses and post results. I am >> hoping the answer is clear and not controversial. >> Thanks, >> Tim in central TX >> >> >> >> > > -- > Dan Yocum > Fermilab 630.840.6509 > yocum@fnal.gov, http://fermigrid.fnal.gov > "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Pietenpol Story
Date: Jan 05, 2012
Group, Does anyone have Chet Peeks contact info, I would like to get one of his books. I would rather pay him than pay Amazon or EBay sellers. Thanks. Brian SLC-UT ________________________________________________________________________________
Subject: Re: Pietenpol Story
Date: Jan 05, 2012
Chet has a website: http://www.threepeakspub.com/ Good reading. John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Jan 5, 2012, at 3:00 PM, brian.e.jardine@l-3com.com wrote: > > > Group, > Does anyone have Chet Peeks contact info, I would like to get one of his > books. I would rather pay him than pay Amazon or EBay sellers. Thanks. > > Brian > SLC-UT > > > > > ________________________________________________________________________________
Date: Jan 05, 2012
His website is: http://www.threepeakspub.com/ listing all his books Barry D -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of brian.e.jardine@l-3com.com Sent: Thursday, January 05, 2012 4:00 PM Subject: Pietenpol-List: Pietenpol Story Group, Does anyone have Chet Peeks contact info, I would like to get one of his books. I would rather pay him than pay Amazon or EBay sellers. Thanks. Brian SLC-UT ________________________________________________________________________________
Date: Jan 05, 2012
Where is mine and where is yours? Gardiner ----- Original Message ---- From: Dan Yocum <yocum(at)fnal.gov> Sent: Thu, January 5, 2012 1:20:02 PM Subject: Re: Pietenpol-List: "First Air Camper?" Hi Tim, Kevin Holcomb put together a spreadsheet of the history of aircraft that Bernard built. It is here: http://www.airminded.net/piet/piet_list.xls Which is linked to from this page: http://www.airminded.net/piet/piet.html It gives a pretty good run down of what Bernard built, when, and what he powered it with. I can not vouch for its accuracy but Kevin did include references so I think it's pretty legit. Hope this helps, Dan On 01/05/2012 11:38 AM, Timothy Willis wrote: > --> Pietenpol-List message posted by: Timothy Willis > > This has nothing to do with building or flying Pietenpols, but much to > do with Air Camper history. > When did BHP build the first "Air Camper" and what was its engine? > > I have seen conflicting claims on various sites as to when Mr. > Pietenpol built his first Air Camper, and what he used for an engine. > My mindset tells me it was in 1929 and it used a Model A Ford: "Low& > Slow since 1929." > But that conclusion is what I recall from various sites, including > this board, and from memory. > > However I have seen references to a 1928 date and an Ace water cooled engine. > Was there such an earlier plane, and if so, did it look like an Air Camper? > Was it called an "Air Camper?" Did it fly? > I have seen references to "an earlier plane" than the Air Camper that > "did not fly/did not fly well." Was that the Ace-powered plane? > > Wikipedia has somewhat different info from what I recall from our site. > The Pietenpol family website now has less historical information than > the version from 2008 and before. > What is the best source for this info? Is it Chet Peek's book, and if > so, if you have it, would you take a look? > > If so, please post here, if you like. Otherwise if you would like to > post to me offline, I will look over responses and post results. I am > hoping the answer is clear and not controversial. > Thanks, > Tim in central TX > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: Bronze-Brass Bearings
Date: Jan 05, 2012
The bearing or the casing around it? Clif > > ... you heat the bearing to just soften the retaining compound, then press > it out. Sorry if I was not clear enough on that. ________________________________________________________________________________
Date: Jan 06, 2012
Dan, The Kitfox has flaperons. I was wondering if the flaps would allow a wider CoG range as the aerofoil section is altered when flaps are extended. Just a thought. JohnW Perth Western Australia ----- "Dan Yocum" wrote: Chris, The GA30U-612 is used on the Skystar Kitfox Lite and Kitfox Speedster. ________________________________________________________________________________
Date: Jan 05, 2012
Only if you intend to engineer, install, test, debug, and ultimately fly with the flaps extended the entire time... On Thu, Jan 5, 2012 at 10:14 PM, wrote: > Dan, > > The Kitfox has flaperons. > I was wondering if the flaps would allow a wider CoG range as the aerofoil > section is altered when flaps are extended. > Just a thought. > > JohnW > Perth Western Australia > > ----- "Dan Yocum" wrote: > > Chris, > > The GA30U-612 is used on the Skystar Kitfox Lite and Kitfox Speedster. > > * > > > * > > ________________________________________________________________________________
Date: Jan 06, 2012
.. you heat the BEARING. Since the wheel rims maybe painted an or fabric covered. Does not take much heat to soften the retaining compound. I would be careful about the loading forces on the plastic bearings vs. wall thickness and length. Just make sure you pick the correct one for the application. A bearing disintegrating in a wheel housing on landing or take-off can be down right exciting! -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362567#362567 ________________________________________________________________________________
Subject: Brake anti-rotation
Date: Jan 06, 2012
Hey Guys.. I'm messing with brakes today.. i decided i like the method of anti-rotation on wood gear axle that Dan and Mike used...but.. What size material is appropriate here ? i have tubing around to weld to the inside gear plate for the "pin" to ride in..and kinda feel like 1/2" tubing would be big enough but the "pin" that slides inside that is attached to the axle.. ? not sure... solid ?.. tube ? it looks like 3 inches of travel is about right so were not talking about lots of leverage forces and i'm using external band brakes.. which i know are not very effective... just need to be able stop while taxiing.. can't image needing really big stuff here jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362579#362579 ________________________________________________________________________________
Subject: Re: Brake anti-rotation
Date: Jan 06, 2012
Hi Jeff, I don't have my Piet here to look at, but I believe I used 3/8" O.D. tube f or the "pin" (quite heavy wall thickness). The "sheath" tube was a bit over size, and I actually "squished" this tube into an oval shape, in anticipati on of unequal forces from side to side (in other words, if one wheel hits a pot hole and the other doesn't, the axle will raise up on one side but not the other. No issues so far, but I have a limited number of landings, mayb e 100. Dan Helsper Puryear, TN -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Fri, Jan 6, 2012 11:41 am Subject: Pietenpol-List: Brake anti-rotation > Hey Guys.. 'm messing with brakes today.. decided i like the method of anti-rotation on wood gear axle that Dan and Mike sed...but.. hat size material is appropriate here ? have tubing around to weld to the inside gear plate for the "pin" to ride n..and kinda feel like 1/2" tubing would be big enough but the "pin" that lides inside that is attached to the axle.. ? not sure... solid ?.. tube ? it looks like 3 inches of travel is about right so were not talking about l ots f leverage forces and i'm using external band brakes.. which i know are not ery effective... just need to be able stop while taxiing.. can't image need ing eally big stuff here jeff ead this topic online here: http://forums.matronics.com/viewtopic.php?p=362579#362579 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: Piet on eBay
Date: Jan 06, 2012
Looks like someone got a deal (the purchaser - not the seller). The only oddity I see is a very odd aileron cable routing. From the photos it appears that the aileron control cables have been rerouted so that they don't pass through the instrument area. That could be a nice feature, BUT... the new route has the cables seriously impeding access to the front seat. Not sure how anyone would manage to get in that front seat. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362603#362603 Attachments: http://forums.matronics.com//files/aileron_cable_197.jpg ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Jan 06, 2012
Subject: new subscriber questions--okay, old subscriber, old questions
I was wondering about building a Grega vs. a Pietenpol....if I should use l atex or Stitts, and if I can use hardware store bolts and cables. Can I make it a nose gear with a second wing? Is there a four seat version? What if I'm 6' 4" and weigh 260 pounds...will a 65 Continental be good enou gh. I have a short backyard strip, 1500' with trees at both ends. Happy New Year to the group, Mike C. ________________________________________________________________________________
Date: Jan 06, 2012
Subject: Re: new subscriber questions--okay, old subscriber, old
questions
I don't know about the rest but I am sure picture hanging wire should suffice and make sure ya use the good stuff at the hardware store. Nuttin but good old hard grade 8. ; ( Heck if'n its good nuff for bicycles it should be fine on a light aeroplane. No archive Bryan On Fri, Jan 6, 2012 at 2:06 PM, Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] wrote: > I was wondering about building a Grega vs. a Pietenpol=85.if I should use > latex or Stitts, and if I can use**** > > hardware store bolts and cables. **** > > ** ** > > Can I make it a nose gear with a second wing?**** > > ** ** > > Is there a four seat version? **** > > ** ** > > What if I=92m 6=92 4=94 and weigh 260 pounds=85will a 65 Continental be g ood > enough. I have a short backyard strip, 1500=92 with trees at both ends. * > *** > > ** ** > > Happy New Year to the group, **** > > ** ** > > Mike C. **** > > ** ** > > ** ** > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
questions
Date: Jan 06, 2012
Well spoken, after all is completed fly and never look back! Kenneth M. Heide Sent from my iPhone On Jan 6, 2012, at 4:06 PM, "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] " wrote: > I was wondering about building a Grega vs. a Pietenpol.if I shoul d use latex or Stitts, and if I can use > hardware store bolts and cables. > > Can I make it a nose gear with a second wing? > > Is there a four seat version? > > What if I=99m 6=99 4=9D and weigh 260 poundswil l a 65 Continental be good enough. I have a short backyard strip, 1500 =99 with trees at both ends. > > Happy New Year to the group, > > Mike C. > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 06, 2012
Hi Gardiner, Yeah, I wouldn't call the list complete by any stretch of the imagination, but the top portion that contains Bernards a/c looks pretty good. Dan On 01/05/2012 05:30 PM, airlion wrote: > --> Pietenpol-List message posted by: airlion > > Where is mine and where is yours? Gardiner ________________________________________________________________________________
Date: Jan 06, 2012
>From this photo it looks like he has a quick release in the cable... safety pin style wire keeper on the pin. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362626#362626 Attachments: http://forums.matronics.com//files/aileron_cable_214.jpg ________________________________________________________________________________
Date: Jan 06, 2012
>From this photo it looks like he has a quick release in the cable... safety pin style wire keeper on the pin. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362627#362627 Attachments: http://forums.matronics.com//files/aileron_cable_170.jpg ________________________________________________________________________________
Date: Jan 06, 2012
questions how about flour and water. thats a pretty good glue for a piet.he he he. =0Agardiner=0A=0A=0A=0A=0A________________________________=0AFrom: Kip and Beth Gardner =0ATo: pietenpol-list(at)matronics.com =0ASent: Fri, January 6, 2012 8:50:07 PM=0ASubject: Re: Pietenpol-List: new subscriber questions--okay, old subscriber, old =0Aquestions=0A=0AAww, why not Elmers? Good enough for a boat in a hurricane in Belize, after =0Aall ....=0A=0A=0AOn Jan 6, 2012, at 7:55 PM, Jack wrote:=0A=0A =0A>Mike Happy N ew Year to you too!=0A>I=99m using gorilla glue throughout, bed sheet s to cover with varnish=0A>Jack=0A>DSM=0A>NX1929T=0A>DO NOT ARCHIV E=0A> =0A>=0A________________________________=0A =0A>From:owner-pietenpol-l ist-server(at)matronics.com =0A>[mailto:owner-pietenpol-list-server(at)matronics. com ] On Behalf Of Cuy, Michael D. =0A>(GRC-RXD0)[ASRC AEROSPACE CORP]=0A>S ent: Friday, January 06, 2012 3:07 PM=0A>To: pietenpol-list(at)matronics.com =0A>Subject: Pietenpol-List: new subscriber questions--okay, old subscriber , old =0A>questions=0A> =0A>I was wondering about building a Grega vs. a Pi etenpol.if I should use latex or =0A>Stitts, and if I can use=0A>h ardware store bolts and cables. =0A> =0A>Can I make it a nose gear with a second wing?=0A> =0A>Is there a four seat version? =0A> =0A>What if I =99m 6=99 4=9D and weigh 260 poundswill a 65 Contin ental be good enough. I =0A>have a short backyard strip, 1500=99 wi th trees at both ends. =0A>=0A> =0A>Happy New Year to the group, =0A> =0A> Mike C. =0A> =0A> =0A> =0A> =0A>http://www.matronics.com/Navigator?Pieten pol-List=0A>http://forums.matronics.com=0A>http://www.matronics.com/contrib ution=0A> =0A> =0A>href="http://www.matronics.com/Navigator?Pietenpol-L ist">http://www.matronics.com/Navigator?Pietenpol-List=0A> href="http://f orums.matronics.com">http://forums.matronics.com =0A>href="http://www.mat ronics.com/contribution">http://www.matronics.com/contribution=0A> =0A>=0A ================ =0A ________________________________________________________________________________
Subject: Update on my steel-tube Pietenpol project...
Date: Jan 06, 2012
Hello good Piet-ple... Thought Id post an update on my project I was able to spend 8 of the 9 days off during the holiday break in my workshop mostly fabricating small pieces and parts. There are lots more to go and yet Im fine with that as I am enjoying the adventure/experience/journey. Part of the challenge with the Pietenpol design, especially with the steel-tube fuselage version, is that so much of it is not defined on the plans. I therefore spend a great deal more time designing certain elements than I actually do fabricating the parts. An example of this is where the shoulder harness and seat belts attach to the frame. The photos show that my solution in this area has been to form a 4130 steel tube bow behind the pilot and passenger seats. The nylon shoulder harness straps will wrap around these tubes and should not interfere with the other things that share that same volume such as the back of the instruments, the cross bracing, aileron control cables, and instrument wires & pitot tubing. Mocking the area up with string and cardboard parts has really helped to visualize this volume. The pilots shoulder harness may still route back to fittings under the turtle deck aft of the seat, but the bow will share the load and provide support under the turtledeck structure in case someone sits on it while climbing into the pilots seat. I have been asked how much of the design I changed from the original plans. My best answer may be to say that from the side view, it is dimensionally EXACTLY the short fuselage steel-tube Pietenpol dimensions taken directly from an original copy of the 1932 Flying and Glider Manual. The fuselage was made two inches wider than plans and I increased the diameter and number of tubing segments to carry structural loads around the area of my left side door cutout. Ive included a screen shot of the fuselage truss I created in CAD which shows the exact lengths of the cross members (centerline-to-centerline dimensions) because when you make the fuselage two inches wider than plans, all the dimensions in the tapered (aft fuselage) section are different than the plans. In addition, I have installed more structure than that image shows to attach things like rudder pedals, seats, and control bar fittings. Everywhere a critical part mounts to the airplane, there will be a tab welded to the frame so all critical parts are attached to the structure itself, not secondary structure such as the plywood floor. All this redesign adds some weight but the tubing itself is surprisingly light (overall lighter than the wood fuselage by about 30 pounds if my numbers are correct) and the few times I may add a bit of weight to my airplane I want it to be for a conscious purpose. Note: As a caveat, I have not yet completed this plane, so all things at this point (January 2012) are just my current solutions/thinking and are subject to change(!) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362636#362636 Attachments: http://forums.matronics.com//files/5_iso_fuselage_rev_a_174.jpg http://forums.matronics.com//files/4_pax_seat_arch_126.jpg http://forums.matronics.com//files/3_pilot_seat_arch_326.jpg http://forums.matronics.com//files/2_torque_tube_143.jpg http://forums.matronics.com//files/1_control_sticks_695.jpg ________________________________________________________________________________
Subject: Re: Update on my steel-tube Pietenpol project...
Date: Jan 06, 2012
Thanks Jake. The pictures and work are great, and I can see the amount of designing you have incorporated so far, such as the brakes, rudder pedals and seats. I came home today, and my plans were in the mail box. I have lurked about the site for many years, and met several piet folks over the last year. I have been interested in building a steel tube piet with possibly an 0-200 for power. I was thinking of using a form of the long fuselage by stretching the steel tube planand possibly increseing the tube size.. Keep up the great work! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362649#362649 ________________________________________________________________________________
Date: Jan 06, 2012
Thanks Terry.... We'll fly our Piets in formation one day....! Congrats on the plans arriving Chief...... The start of your adventure.....!! The 0-200 would be a good engine choice..... J -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362651#362651 ________________________________________________________________________________
Date: Jan 07, 2012
thanks gentleman... did some welding..here it is i had some 5/16 bungee around so i put 14 feet on each side just to check things out...easier to preload it won't move with just me on board.. jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362660#362660 Attachments: http://forums.matronics.com//files/bungee_970.jpg http://forums.matronics.com//files/brake_207.jpg ________________________________________________________________________________
Subject: center secting wing ribs
Date: Jan 07, 2012
My 7th and 8th grade students have finally finished making the outboard wing section ribs (3-piece wing, 26 ribs-needless to say, they are ready to move on) to our AirCamper. We constructed the ribs with vertical supports on the fore and aft sides of the front and rear spar locations. We don't know how to support the spar locations on the ribs that form the butt joint between the outer and center wing sections. Those locations are filled with plywood, steel straps, and pulleys. Those of you that built a 3-piece wing, how did you build those 4 butt ribs in the spar locations? Thanks, Scott Cutler ________________________________________________________________________________
Date: Jan 07, 2012
Scott, Just trace the rib on to a piece of plywood, cut and glue. You can rasp & sand the plywood to fit after the glue is hard. Does that answer your question? Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Scott Cutler Sent: Saturday, January 07, 2012 12:20 PM Subject: Pietenpol-List: center secting wing ribs My 7th and 8th grade students have finally finished making the outboard wing section ribs (3-piece wing, 26 ribs-needless to say, they are ready to move on) to our AirCamper. We constructed the ribs with vertical supports on the fore and aft sides of the front and rear spar locations. We don't know how to support the spar locations on the ribs that form the butt joint between the outer and center wing sections. Those locations are filled with plywood, steel straps, and pulleys. Those of you that built a 3-piece wing, how did you build those 4 butt ribs in the spar locations? Thanks, Scott Cutler ________________________________________________________________________________
Date: Jan 07, 2012
Jeff, Will you be installing anything to prevent chafing of the bungee's on the fasteners? The bungees on NX18235 were being replaced annually (my least favorite job) until we installed a leather cuff to protect the bungees. Greg Cardinal Minneapolis -----Original Message----- From: bender <jfaith(at)solairusaviation.com> To: pietenpol-list Sent: Sat, Jan 7, 2012 9:51 am Subject: Pietenpol-List: Re: Brake anti-rotation thanks gentleman... did some welding..here it is i had some 5/16 bungee around so i put 14 feet on each side just to check things out...easier to preload it won't move with just me on board.. jeff ________________________________________________________________________________
Subject: New Builder to the Piet Family
Date: Jan 07, 2012
Hey Guys. I just wanted to peak in and say hello to all and thanks for the abundance of information on hear. My father and I have decided to build a Piet, the plans are ordered as well as some spruce. My father is actually in the middle of an Rv-8 build right now and when I went to the him with the idea of building a Piet together, he didnt know what a Piet was and after a days research, he got back to me and was all in putting the RV on the back burner. I am so excited to be able to do this with my dad and cant wait until the plans arrive in the mail Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362694#362694 ________________________________________________________________________________
Date: Jan 07, 2012
Well, as one who has built a Pietenpol and is currently building an RV-10, I can say you and your Dad will thoroughly enjoy the experience of building the Pietenpol. Don't get me wrong, Van's builds fine kits, but the experience of assembling (not BUILDING) a kit is simply not as rewarding as that of making every piece of the airplane yourself. With an RV, there is no time spent in looking at the plans and trying to figure out the best way to make the parts shown in what seems to be way too few drawings, nor is there any satisfaction of knowing that your airplane is not quite like any other. Once your Pietenpol is finished, you'll have the pleasure of seeing it draw crowds wherever you fly. I own an RV-4 (that I bought, not one I built myself) that I fly regularly. It never creates any curiosity at all, the way my Pietenpol does. RV stands for Ramp Vermin. They are fine airplanes, and truly do everything well, but there are an awful lot of them. They are becoming as ubiquitous as Cessnas. So welcome to the wonderful world of Pietenpols, and of building your own airplane from scratch. The people here are wonderful, and the airplanes are honest and interesting, and fly like what they are - a 1929 design. Plan to attend Brodhead this July, to see just how many variations on the type are possible. Truly no two are alike. Good Luck! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of FandS_Piet Sent: Saturday, January 07, 2012 9:35 PM Subject: Pietenpol-List: New Builder to the Piet Family Hey Guys. I just wanted to peak in and say hello to all and thanks for the abundance of information on hear. My father and I have decided to build a Piet, the plans are ordered as well as some spruce. My father is actually in the middle of an Rv-8 build right now and when I went to the him with the idea of building a Piet together, he didnt know what a Piet was and after a days research, he got back to me and was all in putting the RV on the back burner. I am so excited to be able to do this with my dad and cant wait until the plans arrive in the mail Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362694#362694 ________________________________________________________________________________
Date: Jan 07, 2012
Subject: Re: center secting wing ribs
Scott, There are probably a thousand different ways to do this, but I'll share with you the sequence I used to help get you thinking about it. First, attach the metal fitting to the CS spar pieces. Attach the CS spar pieces to the wing panels. I made up a "skeleton" stand to support the center. The wing panel ends were sitting on saw horses covered with carpet remnants. By the way, make sure the wing panels are squared up first by adjusting the drag/anti-drag cables accordingly. Essentially, you are using the wing panels as jigs to make sure everything fits together perfectly. Next, position and epoxy the ribs in place. You will have to chisel away small portions of the rib vertical truss members to clear the metal fittings. Next, scribe and cut plywood to fit the wing curve and epoxy in place. I only applied "butt-rib" plywood to the ribs in-between the spars. I sanded off all the rib gussets in this area then epoxied the plywood to the side of the rib, again, in-between the front and rear spars. Next, attach your leading and trailing edges. Sand and shape everything accordingly. Next, apply the bottom plywood skin. Now, you can remove wing panels (your jig) since the bottom skin will keep the CS square. You may want to go ahead and varnish those areas that will be difficult or next to impossible to varnish after applying the top plywood skin. Lastly, apply the top plywood skin and varnish the rest of the CS. I would reference the Tony Bingelis wood working book for how to glue up the plywood skins. Anyway, this is the general sequence I used. Oh, and I did not apply plywood to the butt ribs on the wing panels. I left them open and reinforced the bit ribs with scrap 1/2" by 1/2" spruce pieces. If you want, I can send you some photos off-line. Hope this helps. Greg Bacon Prairie Home, MO On Sat, Jan 7, 2012 at 2:19 PM, Scott Cutler wrote: > My 7th and 8th grade students have finally finished making the outboard > wing section ribs (3-piece wing, 26 ribs-needless to say, they are ready to > move on) to our AirCamper. We constructed the ribs with vertical support s > on the fore and aft sides of the front and rear spar locations. We don =92t > know how to support the spar locations on the ribs that form the butt joi nt > between the outer and center wing sections. Those locations are filled > with plywood, steel straps, and pulleys. Those of you that built a 3-pie ce > wing, how did you build those 4 butt ribs in the spar locations? Thanks, > Scott Cutler**** > > * > =========== =========== =========== =========== > * > > -- Greg Bacon ________________________________________________________________________________
Date: Jan 08, 2012
Scott, I commend you for doing the project with the kids. Not sure of you question but maybe some pictures will help. See here, http://textors.com/PietProject.html most of the wing pictures are at the bottom of the page. Jack DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Greg Bacon Sent: Saturday, January 07, 2012 11:07 PM Subject: Re: Pietenpol-List: center secting wing ribs Scott, There are probably a thousand different ways to do this, but I'll share with you the sequence I used to help get you thinking about it. First, attach the metal fitting to the CS spar pieces. Attach the CS spar pieces to the wing panels. I made up a "skeleton" stand to support the center. The wing panel ends were sitting on saw horses covered with carpet remnants. By the way, make sure the wing panels are squared up first by adjusting the drag/anti-drag cables accordingly. Essentially, you are using the wing panels as jigs to make sure everything fits together perfectly. Next, position and epoxy the ribs in place. You will have to chisel away small portions of the rib vertical truss members to clear the metal fittings. Next, scribe and cut plywood to fit the wing curve and epoxy in place. I only applied "butt-rib" plywood to the ribs in-between the spars. I sanded off all the rib gussets in this area then epoxied the plywood to the side of the rib, again, in-between the front and rear spars. Next, attach your leading and trailing edges. Sand and shape everything accordingly. Next, apply the bottom plywood skin. Now, you can remove wing panels (your jig) since the bottom skin will keep the CS square. You may want to go ahead and varnish those areas that will be difficult or next to impossible to varnish after applying the top plywood skin. Lastly, apply the top plywood skin and varnish the rest of the CS. I would reference the Tony Bingelis wood working book for how to glue up the plywood skins. Anyway, this is the general sequence I used. Oh, and I did not apply plywood to the butt ribs on the wing panels. I left them open and reinforced the bit ribs with scrap 1/2" by 1/2" spruce pieces. If you want, I can send you some photos off-line. Hope this helps. Greg Bacon Prairie Home, MO On Sat, Jan 7, 2012 at 2:19 PM, Scott Cutler wrote: My 7th and 8th grade students have finally finished making the outboard wing section ribs (3-piece wing, 26 ribs-needless to say, they are ready to move on) to our AirCamper. We constructed the ribs with vertical supports on the fore and aft sides of the front and rear spar locations. We don't know how to support the spar locations on the ribs that form the butt joint between the outer and center wing sections. Those locations are filled with plywood, steel straps, and pulleys. Those of you that built a 3-piece wing, how did you build those 4 butt ribs in the spar locations? Thanks, Scott Cutler " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Greg Bacon ________________________________________________________________________________
Date: Jan 08, 2012
Greg, Do you have a photo of that leather cuff? My bungees also get chafed by get ting pinched by the spruce "V" pieces during routine stretching during taxi , landing etc. Dan Helsper Puryear, TN -----Original Message----- From: Greg Cardinal <gcardinal(at)comcast.net> Sent: Sat, Jan 7, 2012 8:16 pm Subject: Re: Pietenpol-List: Re: Brake anti-rotation Jeff, Will you be installing anything to prevent chafing of the bungee's on the f asteners? The bungees on NX18235 were being replaced annually (my least favorite job) until we installed a leather cuff to protect the bungees.
December 13, 2011 - January 08, 2012
Pietenpol-Archive.digest.vol-kx
