Pietenpol-Archive.digest.vol-lb
February 22, 2012 - March 15, 2012
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Feb 22, 2012
Subject: Throttle Linkage
I used an 1/8" 4130 steel rod for my throttle control which is joined to a commercial (ACS or Wicks) throttle cable assembly via an aluminum connector that is threaded on both sides (like a t urnbuckle but with locking jamb nuts on either end) The connector was home made. The wooden ball (a drawer pull knob from Lowe's) is attached with an Adell clamp to the throttle rod. Mike C. (photo is of the passenger cockpit) [cid:image001.png(at)01CCF13C.75BF60F0] ________________________________________________________________________________
Subject: Re: Throttle Linkage
Date: Feb 22, 2012
Jack This is what I did on my first Piet project and although it was a bit of work making push-rods and a bell crank, it worked quite well. In hind site I would of used a different quadrant, but had these two on hand. The purpose of the bell-crank was twofold, it reversed the action of the throttle lever and also provided the transition from rod to cable. The throttle cable is a standard push/pull one from ACS with threaded ends. Hope this helps. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=366966#366966 Attachments: http://forums.matronics.com//files/dscn0049_192.jpg http://forums.matronics.com//files/dsc00339_755.jpg ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Subject: Re: More wing info
Date: Feb 22, 2012
Ben, where did you hinge your flop? My ribs have a reinforcing member running from the bottom cap strip forward to the top cap strip, the bottom member is about 18 inches from the trailing edge (see attachment). I was thinking of putting my flop in at that diagonal member. Do you think this would allow room for an OLD man to get in and out of the cockpit? Chuck > I built a flop into mine too. I don't use it getting in, but it sure > helps when its time to get out! > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > > > ________________________________________________________________________________
Date: Feb 22, 2012
Subject: Tony Bingelis: Firewall Forward Throttle Linkage
As you all know I get royalties every time I mention Tony's books (right!) but once again it dawned on me that these books are perfect for just about every question we face building airplanes including the throttle question. What I love is that Tony gives you two or three ways to tackle a particular task and then you can adapt whatever is best to your desires, airplane, and expenses. Mike C. ________________________________________________________________________________
Date: Feb 22, 2012
Jack, I obtained a generic choke cable from a local auto parts store and broke the plastic handle off and then flattened that end then drilled a hole in it for a clevis pin. The metal rod from the throttle quadrant terminates in a fork end into which the flattened end fits and a clevis pin goes through to hold them together. The choke cable provides an acceptable firewall penetration with its normal mounting hardware and you have a wire ending at the carburetor for mounting to the linkage. A clamp to hold the outer sheathing is simple to make allowing adjustment. Simple and cheap but may not be to standards for some. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=366987#366987 ________________________________________________________________________________
Date: Feb 22, 2012
Rick, I made the same decision at the same time. BHP has been quoted as stating that a cutout is equivalent to shortening the wings by two feet. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=366988#366988 ________________________________________________________________________________
Subject: Re: Tony Bingelis: Firewall Forward Throttle Linkage
Date: Feb 22, 2012
I agree Mike! I did check Tony out but I really appreciate other ideas as well. Thanks! Jack Textor Sent from my iPad On Feb 22, 2012, at 9:11 AM, "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" wrote: > > As you all know I get royalties every time I mention Tony's books (right!) > but once again it dawned on me that these books are perfect for just about > every question we face building airplanes including the throttle question. > > What I love is that Tony gives you two or three ways to tackle a particular > task and then you can adapt whatever is best to your desires, airplane, and > expenses. > > Mike C. > > > > > > > ________________________________________________________________________________
Date: Feb 22, 2012
Subject: My Flop cutout
I added a spar to the center section where the aileron spar is, Made the angled side pieces out of scrap 3/4 inch lumber routed out on the side that doesn't show to decrease weight. The flop itself is made out of aluminum and was pretty easy to fabricate with a small brake I borrowed from a friend. A simple piano hinge on the front edge, and a simple slide to hold it in place. Like I said in my previous post, my wing is 4 inches back from vertical and I can get into the pilots seat without opening the flop, but when getting out I open it and use the cabanes to pull myself upright before stepping out. Ben Charvet ________________________________________________________________________________
Subject: Re: My Flop cutout
Date: Feb 22, 2012
I did a similar thing with mine... installed a spar where the aileron spar would be, but I really didn't want a flop so I just left it open. One thing I did do was install a handle (a piece of 1.25x.049 4130 tube that will be pinned), but I'm not actually sure that it will be necessary or even useful. I didn't really think about using the cabane struts. The hole is no big deal... I suppose I could cover it with fabric and never worry about it. I'm not sure who all has a handle up there, but for those that do, does anyone find it useful? -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367020#367020 Attachments: http://forums.matronics.com//files/fp05092011a00048_586.jpg ________________________________________________________________________________
Date: Feb 22, 2012
Well, here's my flop. Open areas will be covered, top and bottom, with thin lexan. As for getting in and out, the process will be to put right foot in step right behind cockpit, swing left leg onto seat, bring right leg in, turn around and sit down. Reverse when necessary. One can even stand there and salute if the Majah happens by. Clif - STILL workin on the d#@ brakes! :-) > I did a similar thing with mine... installed a spar where the aileron spar > would be, but I really didn't want a flop so I just left it open. > Mark > Chouinard ________________________________________________________________________________
Subject: Air Camper NX13691
Date: Feb 22, 2012
Like Don and others, I find 13691 to be the perfect example of an Air Camper and what we all aspire to. So clean, so simple, so perfect in all her lines. And would you just zoom in on the tailwheel and notice the dried grass still hanging from the tail skid? Sigh. This is what Pietenpoling truly is all about. I miss my airplane. June can't come soon enough, when I will make my way down to Texas to retrieve Scout. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net/ ________________________________________________________________________________
Subject: Re: Naked Piet pics 2000 vintage
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Feb 23, 2012
Hi Earl, Thanks for that. I have never heard it explained. It clears it up for me. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367047#367047 ________________________________________________________________________________
Subject: Re: Pietenpol accesories
Date: Feb 23, 2012
Well, it probably oughta! Are you going to paint "Truck Rides" on the Piet? Fly around the countryside and see if you can drum up some business. I've never had a ride in a Model A pickup truck, I'd go for it... Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367076#367076 ________________________________________________________________________________
Date: Feb 23, 2012
Date: Feb 23, 2012
Very nice! Are you going to take the truck to shows or just enjoy it through driving around? Did you do a complete restoration, (frame off...if you will) or just cosmetically? Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Feb 23, 2012
Subject: Continental Teledyne Rant
So, feeling that a new, updated 2011 version of the A-65/75 Continental eng ine overhaul manual would be best, I went right to the source to check one out. On the website, the manual, (X30008,) is described as being 78 pages a nd in a three ring binder. I like the 3 ringed idea so that I could pop out the pages I needed for the work I would be doing that day, lay the pages o ut on the counter, and not have to touch them. (For $80.00, I would like to keep them clean.) A few days ago, the manual arrived. Noticing that the package was only abou t 3/4 of an inch thick, I knew it was no three ring binder. Upon opening, I saw a spiral wound manual.- (so much for taking out the pages.)- Flipp ing to the back, I see page number 68.- I was expecting to see 78, as adv ertised. Doing some quick math, it turns out that if I count EVERY FACE OF EVERY PAGE the manual is made of, I get 78 pages. This includes the cover, inside cover, index pages ,inside back cover and outside back cover. Oh...a nd...I also included the page(s) marked "This page left blank intentionally ."- I don't even think this/these pages even had a page number of any sor t. Anyhoo, I'm not pleased. So far Continental has not returned my inquiry ema il. Rant over...as you were. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Feb 23, 2012
Subject: Re: Pietenpol Accessories
Hold the phone upside down when you send them. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Feb 23, 2012
Subject: Re: Continental Teledyne Rant
Well, I know its too late now, but you could just print the pages in question off the pdf file that Don Emch posted last week: Ben Attachments: http://forums.matronics.com//files/a_65_overhaul_manual_193.pdf _- On 2/23/2012 2:23 PM, Michael Perez wrote: > So, feeling that a new, updated 2011 version of the A-65/75 > Continental engine overhaul manual would be best, I went right to the > source to check one out. On the website, the manual, (X30008,) is > described as being 78 pages and in a three ring binder. I like the 3 > ringed idea so that I could pop out the pages I needed for the work I > would be doing that day, lay the pages out on the counter, and not > have to touch them. (For $80.00, I would like to keep them clean.) > > A few days ago, the manual arrived. Noticing that the package was only > about 3/4 of an inch thick, I knew it was no three ring binder. Upon > opening, I saw a spiral wound manual. (so much for taking out the > pages.) Flipping to the back, I see page number 68. I was expecting > to see 78, as advertised. Doing some quick math, it turns out that if > I count EVERY FACE OF EVERY PAGE the manual is made of, I get 78 > pages. This includes the cover, inside cover, index pages ,inside back > cover and outside back cover. Oh...and...I also included the page(s) > marked "This page left blank intentionally." I don't even think > this/these pages even had a page number of any sort. > > Anyhoo, I'm not pleased. So far Continental has not returned my > inquiry email. > > Rant over...as you were. > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Feb 23, 2012
I understand your frustration Michael, especially when it was $80. However, I consider us all fortunate to have ANY support whatsoever from a manufacturer that developed and sold these engines about 80 years ago. After nearly a century, that in itself is impressive, especially considering the poor state of our legal system and the liability involved for the manufacturer. Continental certainly stands to make no profit from anything related to these engines, however they do create some new liability by printing these manuals. The people who did profit from the manufacture of these engines are mostly dead if not all dead. >From a purely business standpoint, it makes no sense to support these engines at all. They probably only do so because there are some airplane loving guys at Continental (they sure aren't there for the profits)! A strict businessman would've kicked us to the curb long ago. I'm not sure I can think of a manufacturer of any product who supports something they made 80 years ago. I'm sure they exist, but it is by far the exception, not the rule. Just my $.02. :) Steve Ruse Norman, OK > Well, I know its too late now, but you could just print the pages in question off the pdf file that Don Emch posted last week: > > Ben > > Attachments: > > http://forums.matronics.com//files/a_65_overhaul_manual_193.pdf [2] > > _- > > On 2/23/2012 2:23 PM, Michael Perez wrote: > >> So, feeling that a new, updated 2011 version of the A-65/75 Continental engine overhaul manual would be best, I went right to the source to check one out. On the website, the manual, (X30008,) is described as being 78 pages and in a three ring binder. I like the 3 ringed idea so that I could pop out the pages I needed for the work I would be doing that day, lay the pages out on the counter, and not have to touch them. (For $80.00, I would like to keep them clean.) >> >> A few days ago, the manual arrived. Noticing that the package was only about 3/4 of an inch thick, I knew it was no three ring binder. Upon opening, I saw a spiral wound manual. (so much for taking out the pages.) Flipping to the back, I see page number 68. I was expecting to see 78, as advertised. Doing some quick math, it turns out that if I count EVERY FACE OF EVERY PAGE the manual is made of, I get 78 pages. This includes the cover, inside cover, index pages ,inside back cover and outside back cover. Oh...and...I also included the page(s) marked "This page left blank intentionally." I don't even think this/these pages even had a page number of any sort. >> >> Anyhoo, I'm not pleased. So far Continental has not returned my inquiry email. >> >> Rant over...as you were. >> >> Michael Perez >> Karetaker Aero >> www.karetakeraero.com [1] > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > > Links: ------ [1] http://www.karetakeraero.com [2] http://forums.matronics.com//files/a_65_overhaul_manual_193.pdf ________________________________________________________________________________
Subject: Progress bragging! If you call it progress?
Date: Feb 23, 2012
Last weekend I went up to Iowa to visit the rest of my family in Boone. My dad and I made our down to the "Woodsmith Store" In Des Moines where I bought some 5/4 rough cut(6") Douglas fir. It cost $25.00 for a five foot length. I cut it and half and started my center section. My dad, who has no interest in aviation helped me use his planer and jointer to get the lumber to spec. After seeing the beauty of the wood after the first pass through the planer I will no doubt buy the remaining spars and longerons from this store. And best of all they come in 16 ft lengths at no charge for the "lengthy" boards. Here are some photos. The ribs are not done and I know they do not "match" but I am not sure if I am going to put the reinforced ribs on the center section as I plan on webbing them the plywood anyway. -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367096#367096 Attachments: http://forums.matronics.com//files/img_0408_104.jpg http://forums.matronics.com//files/img_0411_187.jpg ________________________________________________________________________________
Date: Feb 23, 2012
Kyle, Congrats on finding a local alternative! I, too, used DF spar material, with overall satisfaction. My only suggestion is to be very selective, and choose boards that all have similar (good) grain pattern. I was not so selective, and, though all my boards were within AC43.13 spec's, one was definitely of lesser quality...that one later warped. Best wishes... Gary from Cool NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kyle85 Sent: Thursday, February 23, 2012 2:41 PM Subject: Pietenpol-List: Progress bragging! If you call it progress? Last weekend I went up to Iowa to visit the rest of my family in Boone. My dad and I made our down to the "Woodsmith Store" In Des Moines where I bought some 5/4 rough cut(6") Douglas fir. It cost $25.00 for a five foot length. I cut it and half and started my center section. My dad, who has no interest in aviation helped me use his planer and jointer to get the lumber to spec. After seeing the beauty of the wood after the first pass through the planer I will no doubt buy the remaining spars and longerons from this store. And best of all they come in 16 ft lengths at no charge for the "lengthy" boards. Here are some photos. The ribs are not done and I know they do not "match" but I am not sure if I am going to put the reinforced ribs on the center section as I plan on webbing them the plywood anyway. -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367096#367096 Attachments: http://forums.matronics.com//files/img_0408_104.jpg http://forums.matronics.com//files/img_0411_187.jpg ________________________________________________________________________________
Subject: Re: Nice one Mr. Textor
Date: Feb 23, 2012
Hubba Hubba... Dooba Dooba! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367110#367110 ________________________________________________________________________________
Date: Feb 23, 2012
Jack, if you haven't already fabricated your throttle linkage setup and you're still fishing for ideas, there are some pictures of the setup that Ernie Moreno's Piet has, on my website. His is set up with no cables at all... all rods, bellcranks, and solid connections. Not advocating for that, just saying it may provide an idea or two. Not everyone will agree with the final link between the bellcrank on the firewall and the carb butterfly lever because it is not a straight rod; it has an offset bent into it. I can understand the need to avoid that in control linkages where you can fail a member by applying enough force to kink it at the bend, but I can't imagine ever developing that much force trying to open or close a carb butterfly. Anyway, if you go to http://www.flysquirrel.net/piets/piets.html and scroll down to the bottom, there's a link to the firewall forward pictures and one of them shows the throttle linkage. Go to the bottom of that page and there's a link to the cockpit pix and you'll see a couple that show how Ernie's is set up. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Feb 24, 2012
Subject: waterproofing hinge locations
I will have a baggage compartment in my center wing with a piano hinge at the front. Where have those of you using a center baggage compartment mounted the hinge, to what, and what (if any) fill material to keep water from leaking: -- under screws into wooden parts; -- through the hinge and into the compartment? In the same vein, what prevents water damage, seeping into screw holes in the wood under the aileron hinges? Tim in central TX ________________________________________________________________________________
Date: Feb 24, 2012
Subject: Re: waterproofing hinge locations
Tim, mine isn't flying yet so no real world experience with how well this works. What I did was to dab spar varnish into and around all of the holes where I attached the piano hinge to the flop section. I know some fellas prefer to use eye liner brushes. I used q-tips. Cheers, Ken On Fri, Feb 24, 2012 at 8:00 AM, Timothy Willis wrote: > > I will have a baggage compartment in my center wing with a piano hinge > at the front. Where have those of you using a center baggage > compartment mounted the hinge, to what, and what (if any) fill > material to keep water from leaking: > -- under screws into wooden parts; > -- through the hinge and into the compartment? > > In the same vein, what prevents water damage, seeping into screw holes > in the wood under the aileron hinges? > Tim in central TX > > ________________________________________________________________________________
Date: Feb 24, 2012
Tim, you might consider a plastic hinge and glueing it down. Gardiner ----- Original Message ---- From: Timothy Willis <timwillis01(at)gmail.com> Sent: Fri, February 24, 2012 10:00:36 AM Subject: Pietenpol-List: waterproofing hinge locations I will have a baggage compartment in my center wing with a piano hinge at the front. Where have those of you using a center baggage compartment mounted the hinge, to what, and what (if any) fill material to keep water from leaking: -- under screws into wooden parts; -- through the hinge and into the compartment? In the same vein, what prevents water damage, seeping into screw holes in the wood under the aileron hinges? Tim in central TX ________________________________________________________________________________
Date: Feb 24, 2012
Subject: Fuel system sealing
From: Andrew Eldredge <andrew.eldredge(at)gmail.com>
I'm working on sealing up my fuel system. I have a few slow leaks from my gascolator. ACS has EZTurn Lubricant, but I've found a local source for another fuel system sealant http://www.gsasupplyco.com/gaethse.html Can anyone tell me If this would be safe to use? The world of sealants and adhesives is strange to me. I can't seem to pin down equivalents. It seems like a world of "gray stuff in tube, blue stuff in can" Thanks for your help. -- Andrew Eldredge Provo, UT ________________________________________________________________________________
Subject: Re: Fuel system sealing
Date: Feb 24, 2012
Andrew the website specs look good. I use LocTite 567. It is pricey but I have a lot of experience with it and it is good stuff. I am not saying that the LocTite stuff is better. I have no idea about that. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 now covering and painting 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367144#367144 ________________________________________________________________________________
Date: Feb 24, 2012
Subject: Engine Push Rod Length
The engines I acquired have no log books. I see that I can buy standard pus h rods and +.030" push rods.- Any idea how I can determine what length pu sh rods I currently have? I see no specs. given in the manual. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Feb 24, 2012
Dip all screws in varnish right before you use them, screw them wet in to t he wood. This will avoid to some extend moisture getting in to the wood. Second varnish/ paint over the screw, seal it Thirdly, make sure water can drain out of any and all compartments ! your weight and balance will change with water collecting in low spots If your park your plane outside use cockpit covers. Lastly don't fly in the rain Hans NX 15KV -----Original Message----- From: Timothy Willis <timwillis01(at)gmail.com> Sent: Fri, Feb 24, 2012 9:04 am Subject: Pietenpol-List: waterproofing hinge locations > I will have a baggage compartment in my center wing with a piano hinge t the front. Where have those of you using a center baggage ompartment mounted the hinge, to what, and what (if any) fill aterial to keep water from leaking: - under screws into wooden parts; - through the hinge and into the compartment? In the same vein, what prevents water damage, seeping into screw holes n the wood under the aileron hinges? im in central TX -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 24, 2012
Tim, where is all this water coming from? Certainly you're not going to fly your Piet in the rain. If you tie it down outside (like I might have to for a while until I can get hanger space) cover everything up with plastic tarps. ----- Original Message ----- From: "Timothy Willis" <timwillis01(at)gmail.com> Sent: Friday, February 24, 2012 10:00 AM Subject: Pietenpol-List: waterproofing hinge locations > > > I will have a baggage compartment in my center wing with a piano hinge > at the front. Where have those of you using a center baggage > compartment mounted the hinge, to what, and what (if any) fill > material to keep water from leaking: > -- under screws into wooden parts; > -- through the hinge and into the compartment? > > In the same vein, what prevents water damage, seeping into screw holes > in the wood under the aileron hinges? > Tim in central TX > > > ________________________________________________________________________________
Date: Feb 24, 2012
Subject: Continental engine cooling eyebrow drawings--inexpensive!
Stumbled upon this at the Cub Club web site. This is a deal. This is f or DRAWINGS....not the actual parts to make the cooling eyebrows. https://www.cub-club.com/blueprint/Blueprint%20Listing.10.pdf See page 3. [cid:image001.png(at)01CCF304.8B617320] ________________________________________________________________________________
Date: Feb 24, 2012
Michael, that expensive overhaul manual you bought should have a Table of Limits in it. You'll find the information you need there. >From looking at mine, I find that the pushrods (new) should have a length of 10.797" to 10.827". The serviceable limit length is 10.785" To determine if you need the oversize pushrods, you will have to have the engine assembled, and measure the clearance between the valve stem and the rocker arm, with the hydraulic lifter fully deflated. The clearance is supposed to be between 0.030" and 0.110". If your clearance is more than 0.110" you will need the longer pushrod. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Friday, February 24, 2012 1:13 PM Subject: Pietenpol-List: Engine Push Rod Length The engines I acquired have no log books. I see that I can buy standard push rods and +.030" push rods. Any idea how I can determine what length push rods I currently have? I see no specs. given in the manual. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Feb 24, 2012
Scott - What airfoil section does your Air Camper use? I'm having a hard time envisioning that center section matching up smoothly with wings having any of the usual suspects, namely, Pietenpol FC-10, Clark Y, USA 35B, USA 27, NACA 4412, NACA 2412, Riblett 612, and Riblett 613.5. Incidentally, y'all can find find plots of a great many airfoil sections (though not the FC-10 nor any Riblett sections) here: http://www.ae.illinois.edu/m-selig/ads/coord_database.html And find out which airplanes use which sections (including the FC-10 and various Riblett sections) here: http://www.public.iastate.edu/~akmitra/aero361/design_web/airfoil_usage.htm -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367162#367162 ________________________________________________________________________________
Date: Feb 24, 2012
Hello Bill, Actually I used cub wings built from the REED Clipped Wing plans. Wood Spars and aluminum ribs and Piet style tips. I have a 27' span. The center center section is all wood and I have used foam and cloth to fare-in and shape the cut out above the pilot seat. I also have a Cessna 140 wing tank in the center section for fuel. The nose tank is from an Opal Cadet car and it holds 10 gallons. That gives me 22.5 Gallons usable. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367166#367166 Attachments: http://forums.matronics.com//files/p1010527_808.jpg http://forums.matronics.com//files/p1010496_735.jpg ________________________________________________________________________________
Date: Feb 24, 2012
What Hans said -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367167#367167 ________________________________________________________________________________
Subject: Pietenpol Air Camper boggled my mind.
Date: Feb 24, 2012
Happened across this while browsing the 'net for pictures of Pietenpols. http://www.abpic.co.uk/popup.php?q=1031240 Say it ain't so, with that anteater nose and peculiarly enclosed cockpit. My first impression was that someone had stolen the lower wings off one of those long-nosed Grumman/Schweizer Ag-Cats. http://www.airport-data.com/aircraft/photo/001892.html -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367172#367172 ________________________________________________________________________________
Subject: Re: Pietenpol Air Camper boggled my mind.
Date: Feb 24, 2012
Well, that's sad, even if the appearance was pretty far removed from the classic Model A powered Air Camper. -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367179#367179 ________________________________________________________________________________
Date: Feb 24, 2012
That's odd. The Piper Cub reportedly started with a standard USA 35B airfoil, but the airfoil was later modified - in 1943 according to some sources, but my March, 1941 Aero Digest Annual Digest states "USA 35B modified airfoil section." At any rate, the modification was apparently only to the upper surface, slightly raising the contour so the peak is at 9.36% of chord above the chord line rather than 9%. Here's a drawing of the modified airfoil (the dimensions are in inches rather than percentages of chord): http://www.supercubproject.com/drawings/pdfs/A3310184.pdf The characteristic undercamber of the original USA 35B is still there. It's not much, but I thought it would show up more clearly in those gorgeous pictures you posted. Even when I hold a straight edge up to the screen I can't really make out any deviation along the rib bottoms in that last picture. -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367180#367180 ________________________________________________________________________________
Date: Feb 24, 2012
Thank you Jack...I see it now. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Feb 25, 2012
Sent: Fri, Feb 24, 2012 12:17 pm Subject: Re: Pietenpol-List: waterproofing hinge locations Dip all screws in varnish right before you use them, screw them wet in to t he wood. This will avoid to some extend moisture getting in to the wood. Second varnish/ paint over the screw, seal it Thirdly, make sure water can drain out of any and all compartments ! your weight and balance will change with water collecting in low spots If your park your plane outside use cockpit covers. Lastly don't fly in the rain Hans NX 15KV -----Original Message----- From: Timothy Willis <timwillis01(at)gmail.com> Sent: Fri, Feb 24, 2012 9:04 am Subject: Pietenpol-List: waterproofing hinge locations > I will have a baggage compartment in my center wing with a piano hinge t the front. Where have those of you using a center baggage ompartment mounted the hinge, to what, and what (if any) fill aterial to keep water from leaking: - under screws into wooden parts; - through the hinge and into the compartment? In the same vein, what prevents water damage, seeping into screw holes n the wood under the aileron hinges? im in central TX -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Tire size
Date: Feb 25, 2012
Can anyone tell me the diameter of 600-6 tires? Thanks Jack Textor Sent from my iPad ________________________________________________________________________________
Subject: Re: Tire size
Date: Feb 25, 2012
15" Dave Nielsen sentuchows(at)aol.com -----Original Message----- From: Jack(at)textors.com <jack(at)textors.com> Sent: Sat, Feb 25, 2012 3:48 pm Subject: Pietenpol-List: Tire size Can anyone tell me the diameter of 600-6 tires? hanks Jack Textor ent from my iPad -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 25, 2012
Terry, I totally forgot to send you more pics of my door. If you look at the last pic you will see a little of it on the R/S of the Fuse. We get in and out of my plane on the R/S. I don't know why we do. Maybe from flying Cubs so much. Any way I am suppose to fly down to French Valley tomorrow to visit their EAA group and their Piet. I will try to take some more detailed pics then. Did you end up purchasing the steel tube project? -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367257#367257 ________________________________________________________________________________
Date: Feb 25, 2012
As you all may already know, this is my first go around with rebuilding my own AC engine. I am learning new things about the A65 every day. I tend to speed read through the manual trying to take it all in. Then I flip back an d forth from the parts breakdown pages, the table of limits and the Trade A Plane that have places selling parts.- Now that I am starting the overha ul/reassembly process, I will take my time and READ the manual.- I have o ther questions, but prior to posting, I will make sure the manual doesn't c over it! - As with others, I agree these are some very well thought out engines...the wide spec. range of the lifter/valve train assembly being one of them. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Feb 25, 2012
Subject: Engine Progress
Crew, I sent one crank shaft and one cam shaft on their way for inspection and re quired maintenance, they should arrive by this time next week. After inspec tion, I will get a call advising me of what needs to be done to the parts. - Monday or Tuesday, I will be taking a set of crank case halves and some oth er parts to a local AC overhaul facility for cleaning as well as steel part s for magnafluxing. Other items I am currently handling myself. I hope in a bout two weeks, I can start some re-assembly. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Gear Question
Date: Feb 25, 2012
Hello all hope you can help with a question. If you look at the attached picture you will see the bolt holding my gear spring assembly together is resting on the bolt head and nut. Should I use a longer bolt (rather not) so the stress is on the bolt shaft? Or fashion a pin with cotter keys on each end? If I do that should it be 4130 rod? I tried to cut the head off an AN bolt tonight and they are hard! If I do the pin, should I harden after cutting and drilling? Could it be soft steel? So many questions, thanks for your expertise! Jack Textor DSM NX1929T ________________________________________________________________________________
Date: Feb 25, 2012
Longer clevis pin, with washer and cotter on one end? Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Sent: Saturday, February 25, 2012 4:37 PM Subject: Pietenpol-List: Gear Question Hello all hope you can help with a question. If you look at the attached picture you will see the bolt holding my gear spring assembly together is resting on the bolt head and nut. Should I use a longer bolt (rather not) so the stress is on the bolt shaft? Or fashion a pin with cotter keys on each end? If I do that should it be 4130 rod? I tried to cut the head off an AN bolt tonight and they are hard! If I do the pin, should I harden after cutting and drilling? Could it be soft steel? So many questions, thanks for your expertise! Jack Textor DSM NX1929T <<...>> ________________________________________________________________________________
Subject: Re: Engine Progress
Date: Feb 25, 2012
Mike, I hope your engine project goes better then mine did. I took the engi ne apart and did what you did. It took six weeks for them to call and tell me my crank was cracked. Another three weeks to find and buy a second crank . Back down to Texas with it and four weeks later they called and said the need additional repair. Then they sent the wrong bearings. I had to send them back and get the righ t bearings. What a mess. It took until about a month ago to get it all back together. Just a whole series of bad breaks. It started on the third blad e. It sat there and ran, all the trouble was forgotten Dave Nielsen sentuchows(at)aol.com -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Sat, Feb 25, 2012 6:41 pm Subject: Pietenpol-List: Engine Progress Crew, I sent one crank shaft and one cam shaft on their way for inspection and re quired maintenance, they should arrive by this time next week. After inspec tion, I will get a call advising me of what needs to be done to the parts. Monday or Tuesday, I will be taking a set of crank case halves and some oth er parts to a local AC overhaul facility for cleaning as well as steel part s for magnafluxing. Other items I am currently handling myself. I hope in a bout two weeks, I can start some re-assembly. Michael Perez Karetaker Aero www.karetakeraero.com -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 25, 2012
From: Douwe Blumberg <douweblumberg(at)earthlink.net>
Subject: Thanks for all the encouragement boys, it's working!!
Thanks all for your pics and stories. I especially appreciated Dan's personalized video!! Well, it has all helped light the fire under me for the big final push. got the engine pretty much hooked up and once I get the pesky oil pressure hardware in and hooked up, and some prop bolts I can do an engine run!! Just want to run it while the fuse is bare so it's easy to fix any leaks or wiring mistakes. I anticipate being ready to run it within three weeks. Then it's basically finishing all my little fixes and mods on the fuse, cover the fuse and tail feathers, paint it and bolt her together!! I'm really going to aim for a first flight early summer. Douwe ________________________________________________________________________________
Subject: Re: Thanks for all the encouragement boys, it's working!!
Date: Feb 26, 2012
Douwe, Can't wait to see her. This airplane I am sure will be one of the most beau tiful and unique ever to grace the skies over Brodhead. I for one will grea tly appreciate seeing it. Dan Helsper Purear, TN -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Sat, Feb 25, 2012 7:58 pm Subject: Pietenpol-List: Thanks for all the encouragement boys, it's workin g!! nk.net> Thanks all for your pics and stories. I especially appreciated Dan's ersonalized video!! Well, it has all helped light the fire under me for the big final push. go t the ngine pretty much hooked up and once I get the pesky oil pressure hardware in nd hooked up, and some prop bolts I can do an engine run!! Just want to run it while the fuse is bare so it's easy to fix any leaks or iring mistakes. I anticipate being ready to run it within three weeks. Then it's basically finishing all my little fixes and mods on the fuse, cov er he fuse and tail feathers, paint it and bolt her together!! I'm really going to aim for a first flight early summer. Douwe -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: Gear Question
Date: Feb 26, 2012
Gear QuestionJack, all the drawings I have seen use a longer bolt. Not being a metalurgist I can't help with the pin bit. You're probably going to cover the whole thing up with some sort of cover so why the reluctance with using the longer bolt? That would be so much simpler. C ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Saturday, February 25, 2012 7:36 PM Subject: Pietenpol-List: Gear Question Hello all hope you can help with a question. If you look at the attached picture you will see the bolt holding my gear spring assembly together is resting on the bolt head and nut. Should I use a longer bolt (rather not) so the stress is on the bolt shaft? Or fashion a pin with cotter keys on each end? If I do that should it be 4130 rod? I tried to cut the head off an AN bolt tonight and they are hard! If I do the pin, should I harden after cutting and drilling? Could it be soft steel? So many questions, thanks for your expertise! Jack Textor DSM NX1929T <<...>> ________________________________________________________________________________
Subject: the small Continentals
Date: Feb 26, 2012
Jack wrote: >when I rebuilt my A65 I was somewhat astonished at the level >of sophistication the little engine has. Right you are, Jack. I really love these small Continentals and they continue to serve experimenters (and certified aircraft manufacturers as well, in the O200), long after their designers could have dreamed that they would. As I wrote in my article about them in Contact! magazine, they are reliable, simple, and straightforward engines but they do have their quirks and weaknesses. I'm no expert on engines in general, but I would have to agree with what one writer said about the earliest of the genre, the A45, when he stated that it may be one of the simplest 4-stroke engines ever devised. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: New Carb
Date: Feb 26, 2012
So i found a new carb for my A.. i had a tillotson and was having a little trouble stating it and getting it down to a good idle. I found some info on new model Zenith carbs and starting looking for one of two or three models. I picked up a new in the box Zenith 14995.. it has a better idle circuit from what i understand and better float.. there are 3 fuel ports..one on the back and one on each side..and the linkage can be attached on either side.. comes with nice linkage arms too.. only took three blade and it fired right up.. way rich at first but a simple adjustment and it was purring at 600rpm .. i was seeing about 1900 at full throttle.. i think the carb was a good purchase. http://youtu.be/jWCVSiBuPxg did a little fabric work too.. jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367306#367306 ________________________________________________________________________________
Subject: Re: New Carb
Date: Feb 26, 2012
Way cool Jeff. Sounds really nice and smooth (better than mine). That Zenit h carb, it is new?, or a newer version of an old carb? That 1900 RPM static I think is very good. Mine is 1860. Also, looks as though we may yet have another Black and Yellow German comin g down the line?..... Gene Rambo, you better hurry or you will be #3. Dan Helsper Puryear, TN -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Sun, Feb 26, 2012 3:33 pm Subject: Pietenpol-List: New Carb > So i found a new carb for my A.. i had a tillotson and was having a little rouble stating it and getting it down to a good idle. found some info on new model Zenith carbs and starting looking for one of two r three models. I picked up a new in the box Zenith 14995.. it has a better idle circuit f rom hat i understand and better float.. there are 3 fuel ports..one on the back and ne on each side..and the linkage can be attached on either side.. comes wit h ice linkage arms too.. only took three blade and it fired right up.. way rich at first but a simpl e djustment and it was purring at 600rpm .. i was seeing about 1900 at full hrottle.. i think the carb was a good purchase. http://youtu.be/jWCVSiBuPxg did a little fabric work too.. jeff ead this topic online here: http://forums.matronics.com/viewtopic.php?p=367306#367306 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 26, 2012
Subject: Re: the small Continentals
To clarify, that would be the A-40. Chet Peek, author of the excellent "The Pietenpol Story". He has also written a nice history of the A-40 entitled "Flying on 40 Horses". Like every one of his books, a good read, Ryan Sent from my iPad On Feb 26, 2012, at 11:11 AM, Oscar Zuniga wrote: > > > I'm no expert on engines > > in general, but I would have to agree with what one writer > > said about the earliest of the genre, the A45, when he stated > > that it may be one of the simplest 4-stroke engines ever devised. > > > Oscar Zuniga > Air Camper NX41CC "Scout" > Flying Squirrel N2069Z "Rocket" > Medford, OR > website at http://www.flysquirrel.net > > ________________________________________________________________________________
Date: Feb 26, 2012
it is a new carb.. its made for industrial applications.. they have a replacement for the model a pn 13922 but i found this site.. http://clubs.hemmings.com/clubsites/durant/Tech/ZENITHcarinfo.htm that explained some sizes.. and the model b ford garage site that showed sizes of original zenith carbs.. the 14995 has a little bigger venturi but the bore where it mounts is the same as the A carb.. same bolt holes too. i found mine after a little searching on ebay.. but their is a site that has them for sale... i'll dig it up the new ones are lighter... aluminum..i think and after the easy start and adjustment i had today i'm sold I found mine for $175.... the other place i found had them for about 100 more Dan my prop has less bite than yours.. 76-42 so maybe thats why i see more rpm.. And the color... its Charleston green.... really dark.. but not black ...its pretty close to the engine green on an A and the tan is close to another model a car color I'm not gonna be blamed for stealing paint jobs jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367332#367332 ________________________________________________________________________________
Date: Feb 27, 2012
My fortune with both of these engines has been great so far, I hope that wi ll continue through the processes I have to rely on others to do.- I like to think I am in no hurry, but if things start to get dragged out...well.. .-- Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Subject: Radiator pressure
Date: Feb 27, 2012
Do you model A guys use a pressure radiator cap ?? i know the cars didn't i had an old 16lb cap laying around and put it on the piet to run it and i'm getting quite a bit of pressure i guess... its blowing over some water at high rpm.. I'm concerned that there could be a head gasket problem.. the oil is ok.. don't see anything in the cylinders.. its not hot but its pushing a little water out.. just ran it again for a while.. never saw more than 165 deg and its holding pressure still in the hangar.. jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367364#367364 ________________________________________________________________________________
Date: Feb 27, 2012
How about adding a small sleeve that will space the bolt away?- see attac hed drawing for rough idea.- =0A=0A=0AMike Groah=0A=0A=0A=0A_____________ ___________________=0A From: Jack <jack(at)textors.com>=0ATo: pietenpol-list@m atronics.com =0ASent: Saturday, February 25, 2012 4:36 PM=0ASubject: Pieten pol-List: Gear Question=0A =0A=0AGear Question =0AHelloallhope you can help with a question.- If you look at the attached picture you will see the b olt holding my gear spring assembly together is resting on the bolt head an d nut.- Should I use a longer bolt (rather not) so the stress is on the b olt shaft? Or fashion a pin with cotter keys on each end?- If I do that s hould it be 4130 rod?- I tried to cut the head off an AN bolt tonight and they are hard!- If I do the pin, should I harden after cutting and drill ing?-Could it be soft steel?-So many questions, thanks for your experti se!=0AJack Textor=0ADSM=0ANX1929T=0A<<...>> ________________________________________________________________________________
Date: Feb 27, 2012
Why not leave it as is and let the bolt head be more support. Just my 2 cents worth--as stupid as it sounds. Gardiner ________________________________ From: Michael Groah <dskogrover(at)yahoo.com> Sent: Mon, February 27, 2012 11:47:20 AM Subject: Re: Pietenpol-List: Gear Question How about adding a small sleeve that will space the bolt away? see attached drawing for rough idea. Mike Groah ________________________________ From: Jack <jack(at)textors.com> Sent: Saturday, February 25, 2012 4:36 PM Subject: Pietenpol-List: Gear Question Gear Question Helloallhope you can help with a question. If you look at the attached picture you will see the bolt holding my gear spring assembly together is resting on the bolt head and nut. Should I use a longer bolt (rather not) so the stress is on the bolt shaft? Or fashion a pin with cotter keys on each end? If I do that should it be 4130 rod? I tried to cut the head off an AN bolt tonight and they are hard! If I do the pin, should I harden after cutting and drilling? Could it be soft steel? So many questions, thanks for your expertise! Jack Textor DSM NX1929T <<...>> ________________________________________________________________________________
Subject: Re: Radiator pressure
Date: Feb 27, 2012
I don't use a pressurized cap, same as the cars, and I don't recall seeing anyone use one. Larry ----- Original Message ----- From: "bender" <jfaith(at)solairusaviation.com> Sent: Monday, February 27, 2012 11:37 AM Subject: Pietenpol-List: Radiator pressure > > > Do you model A guys use a pressure radiator cap ?? > i know the cars didn't > i had an old 16lb cap laying around and put it on the piet to run it and > i'm getting quite a bit of pressure i guess... its blowing over some water > at high rpm.. > I'm concerned that there could be a head gasket problem.. the oil is ok.. > don't see anything in the cylinders.. its not hot but its pushing a little > water out.. > > just ran it again for a while.. never saw more than 165 deg > and its holding pressure still in the hangar.. > > jeff > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367364#367364 > > > ________________________________________________________________________________
Date: Feb 27, 2012
Jeff, I have an overflow, outlet in the neck of the radiator. So far I always get some blowing over of some water at full power. I think it is a function of the water pump throwing the water up there. I restricted the fitting down real small and that helped. I need to also create some kind of labyrinth to lesson the amount. Dan Helsper Puryear, TN -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Mon, Feb 27, 2012 10:38 am Subject: Pietenpol-List: Radiator pressure > Do you model A guys use a pressure radiator cap ?? know the cars didn't had an old 16lb cap laying around and put it on the piet to run it and i'm etting quite a bit of pressure i guess... its blowing over some water at hi gh pm.. 'm concerned that there could be a head gasket problem.. the oil is ok.. do n't ee anything in the cylinders.. its not hot but its pushing a little water o ut.. just ran it again for a while.. never saw more than 165 deg nd its holding pressure still in the hangar.. jeff ead this topic online here: http://forums.matronics.com/viewtopic.php?p=367364#367364 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 27, 2012
What I did. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367374#367374 Attachments: http://forums.matronics.com//files/img_4157_223.jpg ________________________________________________________________________________
Subject: Sun N Fun Question
Date: Feb 27, 2012
I have never been to Sun N Fun. I think I may be down in that area for work through Friday the 24th. Sun N Fun doesn't actually start until the 27th. Do any of the Sun n Fun regulars on here know if there is much going on or any arrivals on the Friday before. Thought I might drop by there if there was. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367377#367377 ________________________________________________________________________________
Date: Feb 27, 2012
Subject: Re: Sun N Fun Question
Don, My calender says Friday is the 23rd. Cinda and I plan to arrive shortly after noon Friday the 23. I think Dick N also plans to get there then. If you are in the area call my cell, if you don't still have it let me know. We will just be hanging out and setting up the wood shop. There will not be many venders around then and the 4 main vender buildings will be closed. There will be some planes there. Skip -----Original Message----- >From: Don Emch <EmchAir(at)aol.com> >Sent: Feb 27, 2012 1:51 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Sun N Fun Question > > >I have never been to Sun N Fun. I think I may be down in that area for work through Friday the 24th. Sun N Fun doesn't actually start until the 27th. Do any of the Sun n Fun regulars on here know if there is much going on or any arrivals on the Friday before. Thought I might drop by there if there was. > >Don Emch >NX899DE > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=367377#367377 > > ________________________________________________________________________________
Date: Feb 27, 2012
Jeff, What intake manifold are you running? Carb heat on full time? -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367380#367380 ________________________________________________________________________________
Date: Feb 27, 2012
Have you guys got any Piet stuff planned for the shop this year? -----Original Message----- >From: SKIP GADD <skipgadd(at)earthlink.net> >Sent: Feb 27, 2012 2:18 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Sun N Fun Question > > >Don, >My calender says Friday is the 23rd. Cinda and I plan to arrive shortly after noon Friday the 23. I think Dick N also plans to get there then. If you are in the area call my cell, if you don't still have it let me know. We will just be hanging out and setting up the wood shop. There will not be many venders around then and the 4 main vender buildings will be closed. There will be some planes there. >Skip > >-----Original Message----- >>From: Don Emch <EmchAir(at)aol.com> >>Sent: Feb 27, 2012 1:51 PM >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Sun N Fun Question >> >> >>I have never been to Sun N Fun. I think I may be down in that area for work through Friday the 24th. Sun N Fun doesn't actually start until the 27th. Do any of the Sun n Fun regulars on here know if there is much going on or any arrivals on the Friday before. Thought I might drop by there if there was. >> >>Don Emch >>NX899DE >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=367377#367377 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 27, 2012
Thanks Skip... I'd say you have the correct calendar. Don't know what I was looking at. I just might give you a ring. Not sure just yet exactly what my schedule will be. Really wishing I had to be there the following week.... [Rolling Eyes] Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367383#367383 ________________________________________________________________________________
Subject: Re: good to see folks STICKING with it!!!!!!
Date: Feb 27, 2012
Mike, I have been at it for just over 12 years now. Seems like yesterday when I got the plans from Don Pietenpol. I went into the man cave last weekend Friday morning and came out Sunday night, with the result being that I am finally assembling wings from ribs made in 1998. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367385#367385 Attachments: http://forums.matronics.com//files/img_4176_459.jpg ________________________________________________________________________________
Subject: My motivation
Date: Feb 27, 2012
Here is my motivation for finishing the piet. I designed and built these about 10 years ago specifically for the Piet. They will be finished with herringbone mahogany planking. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367387#367387 Attachments: http://forums.matronics.com//files/img_2781_201.jpg http://forums.matronics.com//files/img_2780_702.jpg ________________________________________________________________________________
Date: Feb 27, 2012
its an A intake... with a wedge instead of cutting it.. I keep my eyes open for a B intake but no luck yet. I do have full time heat..a muff on the front pipe http://i1125.photobucket.com/albums/l593/jfaithbass/IMG_20120208_110304.jpg jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367388#367388 ________________________________________________________________________________
Date: Feb 27, 2012
OK, I may try a stock "A" manifold this spring. I have a log type with the "B" carb and can't get an idle below 700rpm without it quitting. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367389#367389 Attachments: http://forums.matronics.com//files/img_2809_170.jpg ________________________________________________________________________________
Date: Feb 27, 2012
Jack, I would say that the arrangement in your photo is not ideal. I'm not crazy about the idea of that washer acting on the nut and the head of the bolt. Best not to impose bending loads on the bolt. Would be better to use a longer bolt, like you say, but what would prevent the bolt from sliding over to one end or the other?. I much prefer the arrangement shown in Mike's photo, with a sleeve, and hole located away from the washer. That way the bolt is only loaded in shear. The two designs (Bingelis and Buckeye) mentioned in this old thread utilize a similar method, with a sleeve. http://forums.matronics.com/viewtopic.php?p=329387#329387 Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367390#367390 ________________________________________________________________________________
Date: Feb 27, 2012
I had the same problem with my Model A pickup. I took it by to show one our local Model A experts, and he told me I was overfilling the radiator. The water pump really throws a lot of water up into the neck of the radiator, and the normal level is a lot lower than you may think. I was having similar temps...never went above 160. Ben On 2/27/2012 11:37 AM, bender wrote: > --> Pietenpol-List message posted by: "bender" > > Do you model A guys use a pressure radiator cap ?? > i know the cars didn't > i had an old 16lb cap laying around and put it on the piet to run it and i'm getting quite a bit of pressure i guess... its blowing over some water at high rpm.. > I'm concerned that there could be a head gasket problem.. the oil is ok.. don't see anything in the cylinders.. its not hot but its pushing a little water out.. > > just ran it again for a while.. never saw more than 165 deg > and its holding pressure still in the hangar.. > > jeff > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367364#367364 > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Feb 27, 2012
Terry, Please email me at (pietman(at)qnet.com) I will then reply to you with all the pics to took this morning. Your fuse looks great. Regards, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367397#367397 ________________________________________________________________________________
Date: Feb 27, 2012
Hi Jim, Yes, two guys from SC are bringing materials for two Piet fuselages. We may be a little busy. Skip -----Original Message----- >From: Jim Ash <ashcan(at)earthlink.net> >Sent: Feb 27, 2012 2:37 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Sun N Fun Question > > >Have you guys got any Piet stuff planned for the shop this year? > >-----Original Message----- >>From: SKIP GADD <skipgadd(at)earthlink.net> >>Sent: Feb 27, 2012 2:18 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Sun N Fun Question >> >> >>Don, >>My calender says Friday is the 23rd. Cinda and I plan to arrive shortly after noon Friday the 23. I think Dick N also plans to get there then. If you are in the area call my cell, if you don't still have it let me know. We will just be hanging out and setting up the wood shop. There will not be many venders around then and the 4 main vender buildings will be closed. There will be some planes there. >>Skip >> >>-----Original Message----- >>>From: Don Emch <EmchAir(at)aol.com> >>>Sent: Feb 27, 2012 1:51 PM >>>To: pietenpol-list(at)matronics.com >>>Subject: Pietenpol-List: Sun N Fun Question >>> >>> >>>I have never been to Sun N Fun. I think I may be down in that area for work through Friday the 24th. Sun N Fun doesn't actually start until the 27th. Do any of the Sun n Fun regulars on here know if there is much going on or any arrivals on the Friday before. Thought I might drop by there if there was. >>> >>>Don Emch >>>NX899DE >>> >>> >>> >>> >>>Read this topic online here: >>> >>>http://forums.matronics.com/viewtopic.php?p=367377#367377 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 27, 2012
I don't think I will make it to sun n fun this year. Ya'll have fun. Gardiner ----- Original Message ---- From: Don Emch <EmchAir(at)aol.com> Sent: Mon, February 27, 2012 1:51:38 PM Subject: Pietenpol-List: Sun N Fun Question I have never been to Sun N Fun. I think I may be down in that area for work through Friday the 24th. Sun N Fun doesn't actually start until the 27th. Do any of the Sun n Fun regulars on here know if there is much going on or any arrivals on the Friday before. Thought I might drop by there if there was. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367377#367377 ________________________________________________________________________________
Subject: Various parts questions
Date: Feb 27, 2012
We are building a Piet for static display. It has a straight (Jenny style) axle. We're wondering if any one could email me some photos showing the attachment of the gear, axle and shock cords along with drawings of the parts needed. we would like to know how many feet of shock cord we need to buy. We are in need of a carb, magneto, and an intake manifold for a Model A engine. [u]None of these parts need to be serviceable[/u]. If you have any, please email me your price. My email address is: jimbir(at)yahoo.com We have also rebuilt a 1917 Curtiss JN4 and have attached photos of the gear on it for comparison to what might be on found a Piet. -------- Thanks, Jim Birke Niagara Frontier Vintage Aircraft Group Assisting The Niagara Aerospace Museum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367403#367403 Attachments: http://forums.matronics.com//files/top_view_otb_copy_624.jpg http://forums.matronics.com//files/top_view_inb_copy_213.jpg http://forums.matronics.com//files/bottom_view_copy_210.jpg ________________________________________________________________________________
Date: Feb 27, 2012
We have a Busy shop planned this year. P.F. Beck has 2 friends who want to build fuselages and I will bring cap strip to build wing ribs. That all should keep us all moving pretty well. Also I'm getting ready to leave within the next week or so and I'll be there about a week early. It's kind of nice to get there early and watch everything come together. my cell ph #is 612-805-1742 for anyone coming looking for info or e mail me or Skip. Dick N. ----- Original Message ----- From: "Jim Ash" <ashcan(at)earthlink.net> Sent: Monday, February 27, 2012 1:37 PM Subject: Re: Pietenpol-List: Sun N Fun Question > > Have you guys got any Piet stuff planned for the shop this year? > > -----Original Message----- >>From: SKIP GADD <skipgadd(at)earthlink.net> >>Sent: Feb 27, 2012 2:18 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Sun N Fun Question >> >> >>Don, >>My calender says Friday is the 23rd. Cinda and I plan to arrive shortly >>after noon Friday the 23. I think Dick N also plans to get there then. If >>you are in the area call my cell, if you don't still have it let me know. >>We will just be hanging out and setting up the wood shop. There will not >>be many venders around then and the 4 main vender buildings will be >>closed. There will be some planes there. >>Skip >> >>-----Original Message----- >>>From: Don Emch <EmchAir(at)aol.com> >>>Sent: Feb 27, 2012 1:51 PM >>>To: pietenpol-list(at)matronics.com >>>Subject: Pietenpol-List: Sun N Fun Question >>> >>> >>>I have never been to Sun N Fun. I think I may be down in that area for >>>work through Friday the 24th. Sun N Fun doesn't actually start until the >>>27th. Do any of the Sun n Fun regulars on here know if there is much >>>going on or any arrivals on the Friday before. Thought I might drop by >>>there if there was. >>> >>>Don Emch >>>NX899DE >>> >>> >>> >>> >>>Read this topic online here: >>> >>>http://forums.matronics.com/viewtopic.php?p=367377#367377 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Various parts questions
Date: Feb 27, 2012
Jim 25 ft. will cover it and give you a tail to hang onto at the end. Also you can probably find most of that stuff you need at the parts mart at SNF. Dick N. ----- Original Message ----- From: "jimbir" <jimbir(at)yahoo.com> Sent: Monday, February 27, 2012 6:12 PM Subject: Pietenpol-List: Various parts questions > > We are building a Piet for static display. It has a straight (Jenny style) > axle. We're wondering if any one could email me some photos showing the > attachment of the gear, axle and shock cords along with drawings of the > parts needed. we would like to know how many feet of shock cord we need to > buy. > > We are in need of a carb, magneto, and an intake manifold for a Model A > engine. [u]None of these parts need to be serviceable[/u]. If you have > any, please email me your price. > > My email address is: jimbir(at)yahoo.com > > We have also rebuilt a 1917 Curtiss JN4 and have attached photos of the > gear on it for comparison to what might be on found a Piet. > > -------- > Thanks, Jim Birke > Niagara Frontier Vintage > Aircraft Group Assisting The > Niagara Aerospace Museum > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367403#367403 > > > Attachments: > > http://forums.matronics.com//files/top_view_otb_copy_624.jpg > http://forums.matronics.com//files/top_view_inb_copy_213.jpg > http://forums.matronics.com//files/bottom_view_copy_210.jpg > > > ________________________________________________________________________________
Date: Feb 27, 2012
I understand gardiner, we will miss seeing you at the wood shop. Skip -----Original Message----- >From: airlion <airlion(at)bellsouth.net> >Sent: Feb 27, 2012 7:07 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Sun N Fun Question > > >I don't think I will make it to sun n fun this year. Ya'll have fun. Gardiner > > >----- Original Message ---- >From: Don Emch <EmchAir(at)aol.com> >To: pietenpol-list(at)matronics.com >Sent: Mon, February 27, 2012 1:51:38 PM >Subject: Pietenpol-List: Sun N Fun Question > > >I have never been to Sun N Fun. I think I may be down in that area for work >through Friday the 24th. Sun N Fun doesn't actually start until the 27th. Do >any of the Sun n Fun regulars on here know if there is much going on or any >arrivals on the Friday before. Thought I might drop by there if there was. > >Don Emch >NX899DE > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=367377#367377 > > ________________________________________________________________________________
Date: Feb 27, 2012
I appreciate your vote of confidence Dan H. "Re-Piet" will be a cool plane, but my eye for detail won't be in the league of yours or some of you other guys. She outta be pretty solid and useful though and will have a unique thirties, "art-deco" feel. Douwe ________________________________________________________________________________
Subject: Floor Bracing on extended fuselage
Date: Feb 27, 2012
Hello everybody, First time here. I am building the extended fuselage version of the Piet and am confused about where to place the floor bracing. The original plans have the side bracing and struts starting at 10" back. The extended version starts at 12" back. The orignial plans start the floor bracing with white ash 10" back. I can not find where the floor bracing should be on the extended version. Seems to me it should be at the 12" mark like the side bracing and struts. Any help would be greatly appreciated! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367413#367413 ________________________________________________________________________________
Date: Feb 27, 2012
Whoops! Right you are, Ryan... it's the A40, not A45. Wonderfully simple engine; you can read a bit more about it here: http://en.wikipedia.org/wiki/Continental_A-40 -OZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367416#367416 ________________________________________________________________________________
Subject: Re: Floor Bracing on extended fuselage
Date: Feb 28, 2012
The floor cross members coincide with the fuselage uprights. Where are you located? Greg Cardinal Minneapolis ----- Original Message ----- From: "mhough" <mhough(at)bucksales.net> Sent: Monday, February 27, 2012 10:32 PM Subject: Pietenpol-List: Floor Bracing on extended fuselage > > Hello everybody, > > First time here. I am building the extended fuselage version of the Piet > and am confused about where to place the floor bracing. The original plans > have the side bracing and struts starting at 10" back. The extended > version starts at 12" back. The orignial plans start the floor bracing > with white ash 10" back. > I can not find where the floor bracing should be on the extended version. > Seems to me it should be at the 12" mark like the side bracing and struts. > Any help would be greatly appreciated! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367413#367413 > > > ________________________________________________________________________________
Date: Feb 28, 2012
I drive a 1930 AA and it won't idle as slow as the piet.. I'd bet there are are leaks around the throttle shaft in the carb i was using... that seems to be a common idle prob. I really thought about rebuilding the tillotson or a marvel i have around, then decided why mess with an 80 year old carb when i can get a brand new carb with better tolerances and now wear. I'd bet your intake is fine.. jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367428#367428 ________________________________________________________________________________
Date: Feb 28, 2012
Thanks Greg, Every image I looked at has the braces lined up with the uprights, but I could not confirm it on the drawings. I am located in Waterford, Michigan. My home airport is PTK. Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367433#367433 ________________________________________________________________________________
Date: Feb 28, 2012
Jack The print is right where I left it: http://mykitplane.com/Planes/PeoplesFil es/Landing%20gear%20spring.pdf And I use a AN 5 long bolt as seen on the print, 300+ landings. Inspected every year. Hans NX15KV Waller, TX -----Original Message----- From: Jack <jack(at)textors.com> Sent: Tue, Feb 28, 2012 6:11 am Subject: RE: Pietenpol-List: Re: Gear Question Thanks Bill, Chris and others for your thoughts! I used Han's design (can't ocate the print currently). Think I will use a longer bolt. Or... a ardened pin with cotter keys. hanks again! ack Jack Textor SM X1929T o not archive -----Original Message----- rom: owner-pietenpol-list-server(at)matronics.com mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Church ent: Monday, February 27, 2012 3:14 PM o: pietenpol-list(at)matronics.com ubject: Pietenpol-List: Re: Gear Question > Jack, I would say that the arrangement in your photo is not ideal. I'm not crazy bout the idea of that washer acting on the nut and the head of the bolt. est not to impose bending loads on the bolt. Would be better to use a onger bolt, like you say, but what would prevent the bolt from sliding over o one end or the other?. I much prefer the arrangement shown in Mike's hoto, with a sleeve, and hole located away from the washer. That way the olt is only loaded in shear. he two designs (Bingelis and Buckeye) mentioned in this old thread utilize similar method, with a sleeve. ttp://forums.matronics.com/viewtopic.php?p=329387#329387 Bill C. ead this topic online here: http://forums.matronics.com/viewtopic.php?p=367390#367390 -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 28, 2012
The floor braces are there to handle compression loads from the landing gea r. They should line up with the landing gear/ wing strut attach points, Hans NX15KV Waller, TX -----Original Message----- From: mhough <mhough(at)bucksales.net> Sent: Mon, Feb 27, 2012 10:33 pm Subject: Pietenpol-List: Floor Bracing on extended fuselage Hello everybody, First time here. I am building the extended fuselage version of the Piet a nd am onfused about where to place the floor bracing. The original plans have the ide bracing and struts starting at 10" back. The extended version starts at 12" ack. The orignial plans start the floor bracing with white ash 10" back. can not find where the floor bracing should be on the extended version. Se ems o me it should be at the 12" mark like the side bracing and struts. Any he lp ould be greatly appreciated! ead this topic online here: http://forums.matronics.com/viewtopic.php?p=367413#367413 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 28, 2012
Hans is correct. Make sure the ash cross braces line up with the landing gear/wing strut location. I had to add another piece for rear mount because the best location is bisected by the rear seat. http://www.westcoastpiet.com/images/Chris%20Tracy/images/06010002.JPG Chris -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367456#367456 ________________________________________________________________________________
Date: Feb 28, 2012
Subject: ford spewing water
Did you up the forward steam relief tube to the "front" of the head. mine did the same thing because I didn't think i needed to hook it up on the test stand and it would do the "old faithful" geyser thing from time to time at high rpm. it will definitely kick some out until the water level finds its' "happy place". MOST guys do not use pressure caps with the thinking that the added pressure can contribute to the occasional leaky or blown gasket somewhere in the system, and it doesn't need it. I know one guy who put a relief valve in the rad cap that was set at something like 3 lbs thinking that the pressure would help with with cooler running, but would be low enough to not stress the system. Douwe ________________________________________________________________________________
Subject: buying my first bit of wood. (probably a dumb question)
Date: Feb 28, 2012
Hey guys, so I'm about to order my first lot of wood, I'm going to start with the tail section. My question is, when I was looking for spruce at wicks and aircraft spruce, all I see is cap strips. is all the wood considered cap strip stock? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367488#367488 ________________________________________________________________________________
Subject: Re: Model-A starting problem
Date: Feb 28, 2012
Well, after a lot of propping, adjustments, rebuilding a new temporary ignition system, more propping and more adjustments plus following multiple paths of advise and opinions, it finally happened. ANNA (name taken from serial number) finally barked. My Model-A engine finally turned gasoline into noise and heat. Thank you all for the ideas and suggestions. And, as promised; http://youtu.be/i8TkYaS0zmE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367493#367493 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Feb 28, 2012
BEAUTIFUL!! That model A sounds great. Blue Skies, Steve D ----- Original Message ----- From: BYD <billsayre(at)ymail.com> Date: Tuesday, February 28, 2012 21:07 Subject: Pietenpol-List: Re: Model-A starting problem > > Well, after a lot of propping, adjustments, rebuilding a new temporary ignition system, more propping and more adjustments plus > following multiple paths of advise and opinions, it finally > happened. ANNA (name taken from serial number) finally barked. My > Model-A engine finally turned gasoline into noise and heat. Thank > you all for the ideas and suggestions. > > And, as promised; > > http://youtu.be/i8TkYaS0zmE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367493#367493 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 28, 2012
Great video! It looks like a distributor was ultimately the weapon of choice. During the last part I could almost watch the engine limber up as you propped and propped and propped away. Give it a couple hours of running and it will feel sloppy in comparison. Great job! Brett Phillips Strasburg, VA ________________________________________________________________________________
Date: Feb 29, 2012
Hi Bill, Terrific video. Needed a good laugh this morning. You got the right attitud e. Never give up. Congratulations!!!!! Dan Helsper Puryear, TN -----Original Message----- From: BYD <billsayre(at)ymail.com> Sent: Tue, Feb 28, 2012 9:01 pm Subject: Pietenpol-List: Re: Model-A starting problem Well, after a lot of propping, adjustments, rebuilding a new temporary igni tion ystem, more propping and more adjustments plus following multiple paths of dvise and opinions, it finally happened. ANNA (name taken from serial numb er) inally barked. My Model-A engine finally turned gasoline into noise and he at. hank you all for the ideas and suggestions. And, as promised; http://youtu.be/i8TkYaS0zmE ead this topic online here: http://forums.matronics.com/viewtopic.php?p=367493#367493 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 29, 2012
TOTALLY AGREE!!! That was SO much fun! Gave me goose bumps.... -----Original Message----- From: helspersew(at)aol.com Sent: Feb 29, 2012 7:10 AM Subject: Re: Pietenpol-List: Re: Model-A starting problem Hi Bill, Terrific video. Needed a good laugh this morning. You got the right attitude. Never give up. Congratulations!!!!! Dan Helsper Puryear, TN -----Original Message----- From: BYD <billsayre(at)ymail.com> Sent: Tue, Feb 28, 2012 9:01 pm Subject: Pietenpol-List: Re: Model-A starting problem Well, after a lot of propping, adjustments, rebuilding a new temporary ignition system, more propping and more adjustments plus following multiple paths of advise and opinions, it finally happened. ANNA (name taken from serial number) finally barked. My Model-A engine finally turned gasoline into noise and heat. Thank you all for the ideas and suggestions. And, as promised; http://youtu.be/i8TkYaS0zmE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367493#367493 " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 29, 2012
Subject: Model-A starting problem.
Ah-h-h-h Billy boy. A proper powerplant making proper noises on a proper ae roplane is always a sweet thing- to witness. Your video was a wonderful w ay to start my day, thank you for that. I was distressed that you didn't follow my advice for your helpers however. I remember specifically counselling you to use boys in their late teens to early twenties as they are usually good for up to 45 minutes of hand-propp ing whereas your choice of grey haired airport bums were probably only able to pull that thing through 10-15 times before giving up. The young guys sn ap the prop through much quicker too, which is how you get a magneto to put out enough spark to light-off the engine.. All in fun, buddy. I'm really happy for you and I know that sharing the tri als and eventual triumph with your friends at the airport is a large part o f what sport flying rewards us with. Congratulations.I'll see you soon- Larry W. (Top Curmudgeon) ________________________________________________________________________________
Date: Feb 29, 2012
Nice work Jim. Wish I could have been there as you were at my place to witness the first running of mine. However we crank-snapping corvair types prefer exercising our minds rather than our backs when it comes time to fly, we use a "relatively" modern invention called an electric starter (actually first patented in 1911). rick On Wed, Feb 29, 2012 at 5:37 AM, Jim Markle wrote: > jim_markle(at)mindspring.com> > > TOTALLY AGREE!!! That was SO much fun! Gave me goose bumps.... > > > -----Original Message----- > From: helspersew(at)aol.com > Sent: Feb 29, 2012 7:10 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Model-A starting problem > > > Hi Bill, > > Terrific video. Needed a good laugh this morning. You got the right > attitude. Never give up. Congratulations!!!!! > > Dan Helsper > Puryear, TN > > > -----Original Message----- > From: BYD <billsayre(at)ymail.com> > To: pietenpol-list > Sent: Tue, Feb 28, 2012 9:01 pm > Subject: Pietenpol-List: Re: Model-A starting problem > > > Well, after a lot of propping, adjustments, rebuilding a new temporary > ignition > system, more propping and more adjustments plus following multiple paths of > advise and opinions, it finally happened. ANNA (name taken from serial > number) > finally barked. My Model-A engine finally turned gasoline into noise and > heat. > Thank you all for the ideas and suggestions. > > And, as promised; > > http://youtu.be/i8TkYaS0zmE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367493#367493 > > > " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: Engine source
Date: Feb 29, 2012
I picked this up this morning on the Bearhawk list. This guy has a few engines available that would be perfect for a Pietenpol And at decent prices: Forwarded message: ________________ As those of you who follow my posts probably know, I am being rather frugal in building my Patrol. I had purchased an engine (in my price range) from a gu y in Texas named Dan Martinez. He seemed like a great guy to deal with, and all the members of the EAA chapter in San Antonio I checked with said he was a grea t mechanic. So I asked Dan if he would send me a list of the other things he was currently selling. He send me a hand-written list (says he is not computer-savvy) so I typed it out for him. So if anyone in the group would be interested ... I placed the list on my web server http://poplar.us/DanMartinez.pdf Bergy _________________________ Hans NX15KV Waller, TX ________________________________________________________________________________
Date: Feb 29, 2012
Great job loved the video the airplane stuff wasn't bad either. She sounds and looks great congrats John Sent from my iPhone On Feb 29, 2012, at 9:43 AM, Rick Holland wrote: > Nice work Jim. Wish I could have been there as you were at my place to wit ness the first running of mine. However we crank-snapping corvair types pref er exercising our minds rather than our backs when it comes time to fly, we u se a "relatively" modern invention called an electric starter (actually firs t patented in 1911). > > rick > > On Wed, Feb 29, 2012 at 5:37 AM, Jim Markle wr ote: m> > > TOTALLY AGREE!!! That was SO much fun! Gave me goose bumps.... > > > > -----Original Message----- > From: helspersew(at)aol.com > Sent: Feb 29, 2012 7:10 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Model-A starting problem > > > Hi Bill, > > Terrific video. Needed a good laugh this morning. You got the right attitu de. Never give up. Congratulations!!!!! > > Dan Helsper > Puryear, TN > > > > -----Original Message----- > From: BYD <billsayre(at)ymail.com> > To: pietenpol-list > Sent: Tue, Feb 28, 2012 9:01 pm > Subject: Pietenpol-List: Re: Model-A starting problem > > > > Well, after a lot of propping, adjustments, rebuilding a new temporary ign ition > system, more propping and more adjustments plus following multiple paths o f > advise and opinions, it finally happened. ANNA (name taken from serial nu mber) > finally barked. My Model-A engine finally turned gasoline into noise and h eat. > Thank you all for the ideas and suggestions. > > And, as promised; > > http://youtu.be/i8TkYaS0zmE > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367493#367493 > > > > > > > > " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > > > > > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > > -- > Rick Holland > Castle Rock, Colorado > NX6819Z > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 29, 2012
Subject: semi Piet related on color scheme and advertising
Just a thought, if I paint my Piet in the colors of my daughters company with advertising on the sides for free would than be considered a commercial use? _http://mikebrandolino.suite101.com/gelato-di-babbo---small-town-product-wit h-international-flair-a402254_ (http://mikebrandolino.suite101.com/gelato-di-babbo---small-town-product-with-international-flair-a402254) It looks like she's going to be moving her product line into the Chicago, Detroit and Midwest markets soon and maybe Florida. I think she needs a Piet to advertise for her ________________________________________________________________________________
Subject: Re: semi Piet related on color scheme and advertising
Date: Feb 29, 2012
I am shooting from the hip here, but I believe as long as you are not receiving Money or compensation you are fine to put whatever you want on your airplane. Again this is very gray ie. you could go to a fly in and park your plane and sit in front of it and get payed for having a display booth. Just make sure you don't get paid while flying. Hope this helps Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367540#367540 ________________________________________________________________________________
Subject: Piets in Sport Aviation
Date: Feb 29, 2012
Just skimming through the digital edition of Sport Aviation that arrived in my inbox, and a photo of Matt Paxton flying his Piet caught my eye. And then, next thing I know, there's a three page article written by Mark Chouinard, all about vacuum bagging. Mark even gave a nod to the bagmaster himself, the illustrious Mr. Markle. That's got to be a thrill to have a photo of your airplane (that you built with your own hands) appear in a magazine like this. Nice going, gents. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367545#367545 Attachments: http://forums.matronics.com//files/matt_126.jpg ________________________________________________________________________________
Subject: Re: Piets in Sport Aviation
Date: Feb 29, 2012
The bagmaster... Ha! I hope that the article reads well, and gives proper review of this neat process that Jim shared with us. It really is a fun and easy method. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367554#367554 ________________________________________________________________________________
Subject: Re: Model-A starting problem.
Date: Feb 29, 2012
Well Top Curmudgeon, I have found that when offering an opportunity to boys in their late teens to early twenties, unless said opportunity involves an X-Box or PS3 controller, they rarely have the interest or capability to achieve (there are exceptions I just couldnt find any quickly enough). The gray haired airport bums were at least enthusiastic although indeed, a few could not muster the task at hand. They also come with a plethora of ideas, some of which seem downright dangerous, that you didnt mention or warn me about. As illustrated in the video, all worked out and indeed, the rewards were great. Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367561#367561 ________________________________________________________________________________
Date: Feb 29, 2012
Mr. H. was always a hard sell... he had a screw or two loose. But the Bagmaster is easily impressed. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367569#367569 Attachments: http://forums.matronics.com//files/p9040914_132.jpg ________________________________________________________________________________
Date: Feb 29, 2012
Wow. What a beautiful sound. You're going to love that airplane=2C and you will quickly forgive her for all the pain she caused by wearing out all those starters =3Bo) Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford=2C OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Mar 01, 2012
Dang it Terry, ....I have a multiple-year contract with Mr. Loensloe to dis play his ad, and BTW he is paying me huge sums to do it. Please nobody sque el to the feds on this. I can really use the money right about now. Dan Helsper Puryear, TN -----Original Message----- From: jarheadpilot82 <jarheadpilot82(at)hotmail.com> Sent: Wed, Feb 29, 2012 7:36 pm Subject: Pietenpol-List: Re: semi Piet related on color scheme and advertis ing ail.com> Good People, I have spent way too much time this afternoon researching this, and if you isagree, you won't hurt my feelings. I believe under the definition of ommercial operation you are fine to paint it any way you want. The issue wi th ommercial use is this - are you paid in any way? For instance, Tools Danford can teach his son to fly his Pietenpol, as long as ools pays for the gas, and he is not reimbursed in any way (not that his eenage son is gonna pay him a dime!). If it is free, it ain't commercial peration, according to the FAA. I have attached a few links as well as a document I downloaded from AOPA. I t is OPA's info, and I give the full credit to them, so I hope they don't pop a cork f I make it available here. In my opinion, paint it any way you want, as long as you are not paid IN AN Y AY. I must say, though, I am not a lawyer, and I did not sleep in a Holiday Inn xpress last night. [Laughing] ommercial Operator. A person who, for compensation or hire, engages in the arriage by aircraft in air commerce of persons or property, other than as a n ir carrier or foreign air carrier or under the authority of Part 375 of thi s itle. Where it is doubtful that an operation is for =C3=A2=C2=C2=9Ccompe nsation or hire=C3=A2=C2=C2=9D, he test applied is whether the carriage by air is merely incidental to the erson's other business or is, in itself, a major enterprise for profit. l The FAA has consistently defined commercial operation in terms of whether the perator receives direct or indirect payment for the operation. It is not ecessary that the operation be conducted for profit or even that there be a ny ntent or ability to make a profit. The compensation is not just limited to onetary payments but includes anything of value. This broad definition of ompensation has been affirmed and adopted by both the NTSB and the federal ourts. Administrator v. Roundtree, 2 NTSB 1712 (1975); Administrator v. Mim s, TSB Order No. EA-3284, review denied 988 F.2d 1380; Consolidated Flower hipments, Inc., Bay Area, 16 C.A.B. 804 (1953), aff'd. 213 F.2d 814 (2nd Ci r. 954)." ommercial Aeronautical Activity: Any aeronautical activity intended to secu re arnings, income, compensation, or profit, whether or not such objectives ar e ccomplished. -------- o Not Archive Semper Fi, Terry Hand ead this topic online here: http://forums.matronics.com/viewtopic.php?p=367570#367570 ttachments: http://forums.matronics.com//files/123_546.pdf -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 01, 2012
Subject: Re: Piet Items in Sport Aviation
Great article, Mark! Those struts are beautiful! Can't wait to see them on a finished Piet. Matt Paxton ________________________________________________________________________________
Subject: Interview with Kevin Purtee
Date: Mar 01, 2012
http://www.dvidshub.net/video/138535/chief-warrant-officer-kevin-purtee#.T0- bNPGvJ8F Gary Boothe NX308MB ________________________________________________________________________________
Subject: Re: Interview with Kevin Purtee
Date: Mar 01, 2012
http://www.dvidshub.net/video/138545/michele-tumino#.T0-g-1FlrP0 Gary, how could you miss Kevin's other half Shelley? Curt Merdan NX***** Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367602#367602 ________________________________________________________________________________
Date: Mar 01, 2012
Thank you Kevin, its nice to know a little history of peoples accomplishments. Jim B. ________________________________________________________________________________
Date: Mar 01, 2012
I am even more honored now to know that my only Piet flight was provided by a bonafide war hero. It's just a shame that they did not get your name right Axel. (I am not worthy!) Tom Stinemetze McPherson, KS. >>> "Gary Boothe" 3/1/2012 9:54 AM >>> http://www.dvidshub.net/video/138535/chief-warrant-officer-kevin-purtee#.T0-bNPGvJ8F Gary Boothe NX308MB ________________________________________________________________________________
Date: Mar 01, 2012
Kevin, SALUTE! Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 01, 2012
Agreed! Kevin, I'm grateful that guys like you fight for us. Ken On Thu, Mar 1, 2012 at 10:35 AM, Michael Perez wrote: > Kevin, > > SALUTE! > > Michael Perez > Karetaker Aero > www.karetakeraero.com > > * > > * > > ________________________________________________________________________________
Subject: Progress on welded fuselage...
Date: Mar 01, 2012
Hello good Piet-ple... A week ago I had Mike from "Ready Weld" come by for another all-day welding marathon. He worked on the pilot and passenger control sticks, the passenger door (heaven forbid!!), the tabs where the wood floor will bolt to the fuselage frame, and the attach fittings for the seat belts & shoulder harnesses. I have attached (hopefully) an image of the fuselage with the tabs jigged in place, a picture of the door in the wooden jig, Mike welding away, and a couple of the fuselage which is now further along. Put it together, jig, take it apart, put it back together, take it back apart... repeat until finished (ha!) Lotsa funnn...!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367624#367624 Attachments: http://forums.matronics.com//files/4_pilot_stick_240.jpg http://forums.matronics.com//files/5_welded_118.jpg http://forums.matronics.com//files/3_ready_weld_137.jpg http://forums.matronics.com//files/2_passenger_door_and_hinges_642.jpg http://forums.matronics.com//files/1_floor_tabs_jigged_for_welding_306.jpg ________________________________________________________________________________
Subject: Re: Continental engine cooling eyebrow drawings--inexpensive!
Date: Mar 02, 2012
Just a heads up. You must be a member to order the plans... Jack Textor Sent from my iPad On Feb 24, 2012, at 1:56 PM, "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP ]" wrote: > Stumbled upon this at the Cub Club web site. This is a deal. This is f or DRAWINGS.not the actual parts > to make the cooling eyebrows. > > https://www.cub-club.com/blueprint/Blueprint%20Listing.10.pdf > > See page 3. > > > > > ________________________________________________________________________________
Subject: Matt paxton
Date: Mar 02, 2012
My new issue of Sport Aviation came today. There is a great pic of Matt and his Piet. Good job Matt, pic is great. Dick N. ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Mar 03, 2012
Now that is class- can't add anything more but it is good to know such capable and honorable folks still serve every day. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367670#367670 ________________________________________________________________________________
Subject: update on NX53WE
Date: Mar 04, 2012
Branson is still on the map.We got hit pretty hard down 76 highway with a lot of businesses,motels and restaurants destroyed. Our piet has the tail feathers and wings painted. I put the last fabric on the fuselage saturday so now a little clean up and start the finish. Hoping to see Brodhead this summer. The yellow and blue paint cannot be missed. Have a nice day, Bob ________________________________________________________________________________
Subject: Re: Aluminum for cowl and forward deck?
Date: Mar 04, 2012
> Dear friends, What type of aluminum have you folks been using for the cowl and forward decking from the pilot's seat to the cowl? I have some .025 6061 T6, but it may be too stiff. Any softer sheeting being used? I need to od=redr some plywood and thought I would include this in the order. Thanks so much, Ray Krause Sky Scout coming along. > > > > > > ________________________________________________________________________________
Date: Mar 05, 2012
Hi Ray, I used 2024 T3 0.025 for my cowlings and will also for the engine cowling. Jim B. ________________________________________________________________________________
Date: Mar 04, 2012
Thanks, Jim. I guess it was easy to work. Ray ----- Original Message ----- From: Jim Boyer To: pietenpol-list(at)matronics.com Sent: Sunday, March 04, 2012 7:45 PM Subject: Re: Pietenpol-List: Aluminum for cowl and forward deck? Hi Ray, I used 2024 T3 0.025 for my cowlings and will also for the engine cowling. Jim B. ________________________________________________________________________________
Subject: Aluminum for cowl and forward deck?
Date: Mar 04, 2012
That's what I had, and used, Ray. .025 isn't too bad to work with, but I wouldn't have used 6061 if I didn't already have it. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Sunday, March 04, 2012 7:15 PM Subject: Re: Pietenpol-List: Aluminum for cowl and forward deck? --> > Dear friends, What type of aluminum have you folks been using for the cowl and forward decking from the pilot's seat to the cowl? I have some .025 6061 T6, but it may be too stiff. Any softer sheeting being used? I need to od=redr some plywood and thought I would include this in the order. Thanks so much, Ray Krause Sky Scout coming along. > > > > > > ________________________________________________________________________________
Date: Mar 05, 2012
I used the same as Jim. 0.025" 2024-T3 Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Boyer Sent: Sunday, March 04, 2012 10:45 PM Subject: Re: Pietenpol-List: Aluminum for cowl and forward deck? Hi Ray, I used 2024 T3 0.025 for my cowlings and will also for the engine cowling. Jim B. ________________________________________________________________________________
Date: Mar 05, 2012
Ray, I used .032 3003 for the front engine cowl pieces. Soft enough to make a fe w bump-outs and bends I needed. Then I used .025 2024 from in front of the the radiator back to just behind the front cabane struts. Then changed to .032 2024 to surround both cockpits (stiff and tough for inadvertant abuse) . 2024 is fine for simple curving, but compound curves need a softer alloy. Dan Helsper Puryear, TN -----Original Message----- From: Ray Krause <raykrause(at)frontiernet.net> Sent: Sun, Mar 4, 2012 9:15 pm Subject: Re: Pietenpol-List: Aluminum for cowl and forward deck? et> > Dear friends, What type of aluminum have you folks been using for the cowl and forward ecking from the pilot's seat to the cowl? I have some .025 6061 T6, but t may be too stiff. Any softer sheeting being used? I need to od=redr som e lywood and thought I would include this in the order. Thanks so much, Ray Krause ky Scout coming along. > -======================== -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 05, 2012
I would ask if you plan to shape any of these parts. If not, then what you've got is probably ok. If you plan on forming it, I'd go with 3003. 6061 wouldn't be my first choice for formability. ASS has a neat little summary chart in their catalogs: http://www.aircraftspruce.com/catalog/pdf/aluminumalloy.pdf Note the 'Cold Workability' column. 1100 (pure Al), is the easiest to work, but it's not real strong. 3003 is still easy to work (only a nudge more difficult than 1100), but it's stronger. Regardless if you're forming or not, when you're doing tight bends, watch your bend radius, especially if you're using thicker sheet. Jim Ash -----Original Message----- >From: Ray Krause <raykrause(at)frontiernet.net> >Sent: Mar 4, 2012 10:14 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Aluminum for cowl and forward deck? > > >> Dear friends, > >What type of aluminum have you folks been using for the cowl and forward >decking from the pilot's seat to the cowl? I have some .025 6061 T6, but >it may be too stiff. Any softer sheeting being used? I need to od=redr some >plywood and thought I would include this in the order. > >Thanks so much, > > >Ray Krause >Sky Scout coming along. >> >> > >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: How should I.....
Date: Mar 05, 2012
Friends, My wing center section is going to be a storage compartment. Before I drill any holes in my spar I was wondering the best method for attaching my piano hinge to the backside of my fwd spar? Thanks, Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367783#367783 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Mar 05, 2012
Subject: center section storage lid hinge-to-front spar
Kyle, I just drilled a few pilot holes for some truss-head wood screws to attach my hinged cover for the center section storage compartment. The other 1/2 of my hinge is riveted to the aluminum cover. Mike C. for more photos please see: http://www.westcoastpiet.com/images/Mike%20Cuy %20A-65%20Piet/mike_cuy_2.htm (Thank you Chris Tracy!!!!) [cid:image003.jpg(at)01CCFAD1.6EDB0CA0] ________________________________________________________________________________
Date: Mar 05, 2012
Subject: In Carrollton for a couple days...today....
Sorry for the short notice but I ended up on a quick trip to Carrollton GA....and I'm in Carrollton now..leaving on Thursday... And would love to meet up for some Piet talk, dinner, whatever. Jim Markle ________________________________________________________________________________
Date: Mar 05, 2012
Thanks, everybody for the fast responses. I will be ordering today. More money for ASS! Ray Krause ----- Original Message ----- From: "Jim Ash" <ashcan(at)earthlink.net> Sent: Monday, March 05, 2012 6:21 AM Subject: Re: Pietenpol-List: Aluminum for cowl and forward deck? > > I would ask if you plan to shape any of these parts. If not, then what > you've got is probably ok. If you plan on forming it, I'd go with 3003. > 6061 wouldn't be my first choice for formability. ASS has a neat little > summary chart in their catalogs: > > http://www.aircraftspruce.com/catalog/pdf/aluminumalloy.pdf > > Note the 'Cold Workability' column. 1100 (pure Al), is the easiest to > work, but it's not real strong. 3003 is still easy to work (only a nudge > more difficult than 1100), but it's stronger. > > Regardless if you're forming or not, when you're doing tight bends, watch > your bend radius, especially if you're using thicker sheet. > > Jim Ash > > > -----Original Message----- >>From: Ray Krause <raykrause(at)frontiernet.net> >>Sent: Mar 4, 2012 10:14 PM >>To: pietenpol-list(at)matronics.com >>Subject: Re: Pietenpol-List: Aluminum for cowl and forward deck? >> >> >> >>> Dear friends, >> >>What type of aluminum have you folks been using for the cowl and forward >>decking from the pilot's seat to the cowl? I have some .025 6061 T6, but >>it may be too stiff. Any softer sheeting being used? I need to od=redr >>some >>plywood and thought I would include this in the order. >> >>Thanks so much, >> >> >> >>Ray Krause >>Sky Scout coming along. >>> >>> > >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 05, 2012
Jim The Big Piet Builders are on another project and our work night is Monday (tomight) We would love for you to come out and hang with us. We work from 6:30 till we get tired. We could even see some Big Piets. Why don't you call me and we can meet. I leave my office around 4:30. Barry Davis 770-301-8087 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Monday, March 05, 2012 1:22 PM Subject: Pietenpol-List: In Carrollton for a couple days...today.... --> Sorry for the short notice but I ended up on a quick trip to Carrollton GA....and I'm in Carrollton now..leaving on Thursday... And would love to meet up for some Piet talk, dinner, whatever. Jim Markle ________________________________________________________________________________
Date: Mar 05, 2012
Sounds great...but I would prefer running by the hotel and putting on some jeans and a work shirt....if you would consider letting me do some work... I'll call you after work...I'll probably work until around 5... Thanks Barry! -----Original Message----- >From: Barry Davis <bed(at)mindspring.com> >Sent: Mar 5, 2012 2:22 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: In Carrollton for a couple days...today.... > > >Jim >The Big Piet Builders are on another project and our work night is Monday >(tomight) >We would love for you to come out and hang with us. We work from 6:30 till >we get tired. We could even see some Big Piets. >Why don't you call me and we can meet. I leave my office around 4:30. >Barry Davis >770-301-8087 > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle >Sent: Monday, March 05, 2012 1:22 PM >To: Pietenpol List >Subject: Pietenpol-List: In Carrollton for a couple days...today.... > >--> > >Sorry for the short notice but I ended up on a quick trip to Carrollton >GA....and I'm in Carrollton now..leaving on Thursday... > >And would love to meet up for some Piet talk, dinner, whatever. > >Jim Markle > > ________________________________________________________________________________
Subject: Re: center section storage lid hinge-to-front spar
Date: Mar 05, 2012
Thanks Mike! I wasn't sure if I was going to use truss screws like you did or #8 machine screws with blind nut plates. I think your method will be my weapon of choice. . Thanks again! Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367795#367795 ________________________________________________________________________________
From: "Sutton, Mark" <msutton(at)unitedwayatlanta.org>
Date: Mar 05, 2012
Barry, I'm a Piet builder over in Locust Grove Ga. Would love to get some advice on finishing my project, can't make this Monday nite but would love to next Monday nite. Is that alright? -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Barry Davis Sent: Monday, March 05, 2012 2:23 PM Subject: RE: Pietenpol-List: In Carrollton for a couple days...today.... Jim The Big Piet Builders are on another project and our work night is Monday (tomight) We would love for you to come out and hang with us. We work from 6:30 till we get tired. We could even see some Big Piets. Why don't you call me and we can meet. I leave my office around 4:30. Barry Davis 770-301-8087 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Monday, March 05, 2012 1:22 PM Subject: Pietenpol-List: In Carrollton for a couple days...today.... --> Sorry for the short notice but I ended up on a quick trip to Carrollton GA....and I'm in Carrollton now..leaving on Thursday... And would love to meet up for some Piet talk, dinner, whatever. Jim Markle ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Date: Mar 05, 2012
I should know, but don't remember what a truss-head screw is. Could you enlighten me? Chuck ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] To: pietenpol-list(at)matronics.com Sent: Monday, March 05, 2012 1:11 PM Subject: Pietenpol-List: center section storage lid hinge-to-front spar Kyle, I just drilled a few pilot holes for some truss-head wood screws to attach my hinged cover for the center section storage compartment. The other 1/2 of my hinge is riveted to the aluminum cover. Mike C. for more photos please see: http://www.westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy_2.h tm (Thank you Chris Tracy!!!!) ________________________________________________________________________________
Date: Mar 05, 2012
Would enjoy you coming out to Carrollton. Just call me and we can arrange to meet. Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Sutton, Mark Sent: Monday, March 05, 2012 4:30 PM Subject: RE: Pietenpol-List: In Carrollton for a couple days...today.... --> Barry, I'm a Piet builder over in Locust Grove Ga. Would love to get some advice on finishing my project, can't make this Monday nite but would love to next Monday nite. Is that alright? -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Barry Davis Sent: Monday, March 05, 2012 2:23 PM Subject: RE: Pietenpol-List: In Carrollton for a couple days...today.... Jim The Big Piet Builders are on another project and our work night is Monday (tomight) We would love for you to come out and hang with us. We work from 6:30 till we get tired. We could even see some Big Piets. Why don't you call me and we can meet. I leave my office around 4:30. Barry Davis 770-301-8087 -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Monday, March 05, 2012 1:22 PM Subject: Pietenpol-List: In Carrollton for a couple days...today.... --> Sorry for the short notice but I ended up on a quick trip to Carrollton GA....and I'm in Carrollton now..leaving on Thursday... And would love to meet up for some Piet talk, dinner, whatever. Jim Markle ________________________________________________________________________________
Date: Mar 05, 2012
Chuck, Truss head screws have a larger head diameter, and lower profile than round head screws. They provide more bearing surface under the head, and protrude less. I've attached a handy old handmade chart that I used to use for drafting - back in the days when screws were drawn by hand (instead of computer). Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367802#367802 Attachments: http://forums.matronics.com//files/screw_sizes_170.pdf ________________________________________________________________________________
Date: Mar 05, 2012
Mark, I am rebuoilding my piet at the Lagrange airport. I would also like to meet sometime. Gardiner Mason --- On Mon, 3/5/12, Sutton, Mark wrote: > From: Sutton, Mark <msutton(at)unitedwayatlanta.org> > Subject: RE: Pietenpol-List: In Carrollton for a couple days...today.... > To: "'pietenpol-list(at)matronics.com'" > Date: Monday, March 5, 2012, 4:30 PM > --> Pietenpol-List message posted > by: "Sutton, Mark" > > Barry, I'm a Piet builder over in Locust Grove > Ga. Would love to get some advice on finishing my > project, can't make this Monday nite but would love to next > Monday nite. Is that alright? > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] > On Behalf Of Barry Davis > Sent: Monday, March 05, 2012 2:23 PM > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: In Carrollton for a couple > days...today.... > > > > Jim > The Big Piet Builders are on another project and our work > night is Monday > (tomight) > We would love for you to come out and hang with us. We work > from 6:30 till we get tired. We could even see some Big > Piets. > Why don't you call me and we can meet. I leave my office > around 4:30. > Barry Davis > 770-301-8087 > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] > On Behalf Of Jim Markle > Sent: Monday, March 05, 2012 1:22 PM > To: Pietenpol List > Subject: Pietenpol-List: In Carrollton for a couple > days...today.... > > --> > > Sorry for the short notice but I ended up on a quick trip to > Carrollton GA....and I'm in Carrollton now..leaving on > Thursday... > > And would love to meet up for some Piet talk, dinner, > whatever. > > Jim Markle > > > > > > > > > > > > > > Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Mar 05, 2012
Subject: My continental twirling muscle is sore.
From: Andrew Eldredge <andrew.eldredge(at)gmail.com>
Time to roll the dice an reveal my ignorance in public. First the story, then questions: I rolled the airplane out of the garage on Saturday night to run the engine for the first time in a few years since it has been down for repairs. Having pulled the engine through a few times to make sure things were lubricated, I switched on the left mag and gave the prop a turn. I repeated the process, a lot. The engine did not start or even act like it might. A whiff of the exhaust led me to believe that there was a fuel mixture reaching the cylinders, so I turned my attention to the ignition system. I decided to check the grounding of the p-leads and was alarmed (initially) that I found continuity between the post and the case. Removing the leads showed me the switch was good. In my state of alarm I took the top off the left mag to check for a short, cracking the sight window in the process. As I probed around in there, It occurred to me that there could be an inductive coupling to the case. A check of a general schematic supported that Idea. Rats, cracked window for what. A few youtube videos later I started wondering if something was wrong with the impulse coupling. Turning the prop yielded no audible click. Hmm. Thinking back, it seems other experienced pilots have seemed to have struggles starting my airplane, back before I had to fix it. They'd give it a few turns and express some dismay, Then I'd have them hold the airplane while I gave it my usual mighty heave (I've never known anything different, but sometimes it would be enough to get a full turn out of the prop.) So the possibility that I've never had a functional impulse coupling has now entered my head... Questions: --What can I use for or where can I get a timing sight window (and while I'm at it a lid gasket and other sundry parts) for m SF4RN --Should I be able to hear the impulse coupling click when pulling the propeller around? -- I could stick a bolt in a high tension terminal and feel for a shock, should that give me confidence that the mag is otherwise functional, or should I pull a plug and see if it sparks? --How likely is it that my cores need to be re-magnitized. Thanks for the help... -- Andrew Eldredge Provo, UT ________________________________________________________________________________
Date: Mar 06, 2012
Yes, you can cut it easily with tin snips. Jim B. ________________________________________________________________________________
Date: Mar 05, 2012
Date: Mar 05, 2012
Subject: Re: My continental twirling muscle is sore.
Some planes only had the impulse coupling on one Mag. Not sure why or what planes. But I have heard some old pilots/mechanics mention it. Blue Skies, Steve D ----- Original Message ----- From: Andrew Eldredge <andrew.eldredge(at)gmail.com> Date: Monday, March 5, 2012 18:05 Subject: Pietenpol-List: My continental twirling muscle is sore. > Time to roll the dice an reveal my ignorance in public. First the > story,then questions: I rolled the airplane out of the garage on > Saturday night > to run the engine for the first time in a few years since it has > been down > for repairs. Having pulled the engine through a few times to make > surethings were lubricated, I switched on the left mag and gave the > prop a > turn. I repeated the process, a lot. The engine did not start or > even act > like it might. A whiff of the exhaust led me to believe that there > was a > fuel mixture reaching the cylinders, so I turned my attention to the > ignition system. I decided to check the grounding of the p-leads > and was > alarmed (initially) that I found continuity between the post and > the case. > Removing the leads showed me the switch was good. In my state of > alarm I > took the top off the left mag to check for a short, cracking the sight > window in the process. As I probed around in there, It occurred to > me that > there could be an inductive coupling to the case. A check of a > generalschematic supported that Idea. Rats, cracked window for > what. A few > youtube videos later I started wondering if something was wrong > with the > impulse coupling. Turning the prop yielded no audible click. Hmm. > Thinking back, it seems other experienced pilots have seemed to have > struggles starting my airplane, back before I had to fix it. > They'd give > it a few turns and express some dismay, Then I'd have them hold the > airplane while I gave it my usual mighty heave (I've never known > anythingdifferent, but sometimes it would be enough to get a full > turn out of the > prop.) So the possibility that I've never had a functional impulse > coupling has now entered my head... > > Questions: > --What can I use for or where can I get a timing sight window > (and while > I'm at it a lid gasket and other sundry parts) for m SF4RN > --Should I be able to hear the impulse coupling click when > pulling the > propeller around? > -- I could stick a bolt in a high tension terminal and feel for > a shock, > should that give me confidence that the mag is otherwise > functional, or > should I pull a plug and see if it sparks? > --How likely is it that my cores need to be re-magnitized. > > Thanks for the help... > -- > Andrew Eldredge > Provo, UT ________________________________________________________________________________
Date: Mar 05, 2012
QW5kcmV3LAoKRG8gTk9UIHN0aWNrIGFueXRoaW5nIG1ldGFsbGljIGluIG9uZSBvZiB0aGUgbGVh ZHMgYW5kIHR1cm4gdGhlIHByb3AgdG8gc2VlIGlmIHRoZSBtYWdzIGFyZSBnb29kLCB5b3Ugd2ls bCBnZXQgYSBzZXJpb3VzIHNob2NrLiDCoEluc3RlYWQsIGZpbmQgYW4gYXNzaXN0YW50IHRvIGhv bGQgc29tZXRoaW5nIG1ldGFsbGxpYyBpbiB0aGUgbGVhZCB3aGlsZSB5b3UgdHVybiB0aGUgcHJv cC4KClllcywgeW91IHNob3VsZCBiZSBnZXR0aW5nIGEgbG91ZCBjbGljayBmcm9tIHRoZSBpbXB1 bHNlIG1hZy4KClN0ZXZlIFJ1c2UKTm9ybWFuLCBPSwoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2Fn ZSAtLS0tLS0tLQpTdWJqZWN0OiBQaWV0ZW5wb2wtTGlzdDogTXkgY29udGluZW50YWwgdHdpcmxp bmcgbXVzY2xlIGlzIHNvcmUuIApGcm9tOiBBbmRyZXcgRWxkcmVkZ2UgPGFuZHJldy5lbGRyZWRn ZUBnbWFpbC5jb20+IApUbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbSAKQ0M6ICAKClRp bWUgdG8gcm9sbCB0aGUgZGljZSBhbiByZXZlYWwgbXkgaWdub3JhbmNlIGluIHB1YmxpYy7CoCBG aXJzdCB0aGUgc3RvcnksIHRoZW4gcXVlc3Rpb25zOsKgIEkgcm9sbGVkIHRoZSBhaXJwbGFuZSBv dXQgb2YgdGhlIGdhcmFnZSBvbiBTYXR1cmRheSBuaWdodCB0byBydW4gdGhlIGVuZ2luZSBmb3Ig dGhlIGZpcnN0IHRpbWUgaW4gYSBmZXcgeWVhcnMgc2luY2UgaXQgaGFzIGJlZW4gZG93biBmb3Ig cmVwYWlycy7CoCBIYXZpbmcgcHVsbGVkIHRoZSBlbmdpbmUgdGhyb3VnaCBhIGZldyB0aW1lcyB0 byBtYWtlIHN1cmUgdGhpbmdzIHdlcmUgbHVicmljYXRlZCwgSSBzd2l0Y2hlZCBvbiB0aGUgbGVm dCBtYWcgYW5kIGdhdmUgdGhlIHByb3AgYSB0dXJuLsKgIEkgcmVwZWF0ZWQgdGhlIHByb2Nlc3Ms IGEgbG90LsKgIFRoZSBlbmdpbmUgZGlkIG5vdCBzdGFydCBvciBldmVuIGFjdCBsaWtlIGl0IG1p Z2h0LsKgIEEgd2hpZmYgb2YgdGhlIGV4aGF1c3QgbGVkIG1lIHRvIGJlbGlldmUgdGhhdCB0aGVy ZSB3YXMgYSBmdWVsIG1peHR1cmUgcmVhY2hpbmcgdGhlIGN5bGluZGVycywgc28gSSB0dXJuZWQg bXkgYXR0ZW50aW9uIHRvIHRoZSBpZ25pdGlvbiBzeXN0ZW0uwqAgSSBkZWNpZGVkIHRvIGNoZWNr IHRoZSBncm91bmRpbmcgb2YgdGhlIHAtbGVhZHMgYW5kIHdhcyBhbGFybWVkIChpbml0aWFsbHkp IHRoYXQgSSBmb3VuZCBjb250aW51aXR5IGJldHdlZW4gdGhlIHBvc3QgYW5kIHRoZSBjYXNlLsKg IFJlbW92aW5nIHRoZSBsZWFkcyBzaG93ZWQgbWUgdGhlIHN3aXRjaCB3YXMgZ29vZC7CoCBJbiBt eSBzdGF0ZSBvZiBhbGFybSBJIHRvb2sgdGhlIHRvcCBvZmYgdGhlIGxlZnQgbWFnIHRvIGNoZWNr IGZvciBhIHNob3J0LCBjcmFja2luZyB0aGUgc2lnaHQgd2luZG93IGluIHRoZSBwcm9jZXNzLsKg IEFzIEkgcHJvYmVkIGFyb3VuZCBpbiB0aGVyZSwgSXQgb2NjdXJyZWQgdG8gbWUgdGhhdCB0aGVy ZSBjb3VsZCBiZSBhbiBpbmR1Y3RpdmUgY291cGxpbmcgdG8gdGhlIGNhc2UuwqAgQSBjaGVjayBv ZiBhIGdlbmVyYWwgc2NoZW1hdGljIHN1cHBvcnRlZCB0aGF0IElkZWEuwqAgUmF0cywgY3JhY2tl ZCB3aW5kb3cgZm9yIHdoYXQuwqAgQSBmZXcgeW91dHViZSB2aWRlb3MgbGF0ZXIgSSBzdGFydGVk IHdvbmRlcmluZyBpZiBzb21ldGhpbmcgd2FzIHdyb25nIHdpdGggdGhlIGltcHVsc2UgY291cGxp bmcuwqAgVHVybmluZyB0aGUgcHJvcCB5aWVsZGVkIG5vIGF1ZGlibGUgY2xpY2suIEhtbS7CoCBU aGlua2luZyBiYWNrLCBpdCBzZWVtcyBvdGhlciBleHBlcmllbmNlZCBwaWxvdHMgaGF2ZSBzZWVt ZWQgdG8gaGF2ZSBzdHJ1Z2dsZXMgc3RhcnRpbmcgbXkgYWlycGxhbmUsIGJhY2sgYmVmb3JlIEkg aGFkIHRvIGZpeCBpdC7CoCBUaGV5J2QgZ2l2ZSBpdCBhIGZldyB0dXJucyBhbmQgZXhwcmVzcyBz b21lIGRpc21heSwgVGhlbiBJJ2QgaGF2ZSB0aGVtIGhvbGQgdGhlIGFpcnBsYW5lIHdoaWxlIEkg Z2F2ZSBpdCBteSB1c3VhbCBtaWdodHkgaGVhdmUgKEkndmUgbmV2ZXIga25vd24gYW55dGhpbmcg ZGlmZmVyZW50LCBidXQgc29tZXRpbWVzIGl0IHdvdWxkIGJlIGVub3VnaCB0byBnZXQgYSBmdWxs IHR1cm4gb3V0IG9mIHRoZSBwcm9wLinCoCBTbyB0aGUgcG9zc2liaWxpdHkgdGhhdCBJJ3ZlIG5l dmVyIGhhZCBhIGZ1bmN0aW9uYWwgaW1wdWxzZSBjb3VwbGluZyBoYXMgbm93IGVudGVyZWQgbXkg aGVhZC4uLgoKUXVlc3Rpb25zOgrCoMKgIC0tV2hhdCBjYW4gSSB1c2UgZm9yIG9yIHdoZXJlIGNh biBJIGdldCBhIHRpbWluZyBzaWdodCB3aW5kb3cgKGFuZCB3aGlsZSBJJ20gYXQgaXQgYSBsaWQg Z2Fza2V0IGFuZCBvdGhlciBzdW5kcnkgcGFydHMpIGZvciBtIFNGNFJOCsKgwqAgLS1TaG91bGQg SSBiZSBhYmxlIHRvIGhlYXIgdGhlIGltcHVsc2UgY291cGxpbmcgY2xpY2sgd2hlbiBwdWxsaW5n IHRoZSBwcm9wZWxsZXIgYXJvdW5kPwrCoMKgIC0tIEkgY291bGQgc3RpY2sgYSBib2x0IGluIGEg aGlnaCB0ZW5zaW9uIHRlcm1pbmFsIGFuZCBmZWVsIGZvciBhIHNob2NrLCBzaG91bGQgdGhhdCBn aXZlIG1lIGNvbmZpZGVuY2UgdGhhdCB0aGUgbWFnIGlzIG90aGVyd2lzZSBmdW5jdGlvbmFsLCBv ciBzaG91bGQgSSBwdWxsIGEgcGx1ZyBhbmQgc2VlIGlmIGl0IHNwYXJrcz8KwqDCoCAtLUhvdyBs aWtlbHkgaXMgaXQgdGhhdCBteSBjb3JlcyBuZWVkIHRvIGJlIHJlLW1hZ25pdGl6ZWQuCgpUaGFu a3MgZm9yIHRoZSBoZWxwLi4uCi0tIApBbmRyZXcgRWxkcmVkZ2UKUHJvdm8sIFVUCgoKCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 Cl8tPSAgICAgICAgICAtIFRoZSBQaWV0ZW5wb2wtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNo aXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rv c2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAg ICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNv IGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2ZvcnVt cy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1 dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQh Cl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1p bi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K Cg= ________________________________________________________________________________
Subject: Re: In Carrollton for a couple days...today....
Date: Mar 05, 2012
Jim, I'm probably an hour and a half to an hour and forty five north of you, but you're welcome to come up and see my shop and Piet. If the wx is good, we could go for a ride! I'm in Detroit at the moment but should be home before thursday (possibly tomorrow). Give me a shout and let me know if you might be interested. The plane is based in Lafayette GA (9a5) and I live in Chickamauga GA, just a few miles north of that. Tools, 423 580 1383 (aka Mike and I'm still up and will be a for a few hours) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367823#367823 ________________________________________________________________________________
Subject: Re: Sport Aviation - Mark's Struts
Date: Mar 05, 2012
Thanks Gary! -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367827#367827 ________________________________________________________________________________
Date: Mar 06, 2012
Some planes had/have none. When I lived in Illinois, I volunteered for the Young Eagles rallies at Aurora a few times. My plane was elsewhere, so I did ground support. Sometimes they had a dozen or two aircraft on three or four lines on the ramp, and flew between 200 and 300 kids in the course of 3 or 4 hours; it was a big affair. Only a few of us on ground crew knew how to hand-prop a plane, so we were a little busier than most. We had a guy who used to show up with a Cub sometimes, with no impulse couplings. With his engine hot (which was pretty much all the time), it was a bear to start. There was a sweet spot between none and flooding as to how much primer he used. If he missed it, you could pull until your arms fell off and nothing would happen. At least it was an A-65 and not something bigger. I remember once in the summer standing on the hot ramp and wailing away at it. His starter motor was about ready to overheat and fail when the engine finally caught. I was about ready to invite the pilot to start his own engine while I temporarily manned the controls, as an encouragement to put an impulse coupling on a mag. Jim Ash -----Original Message----- >From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil> >Sent: Mar 5, 2012 8:56 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: My continental twirling muscle is sore. > > >Some planes only had the impulse coupling on one Mag. Not sure why or what planes. But I have heard some old pilots/mechanics mention it. > >Blue Skies, >Steve D > >----- Original Message ----- >From: Andrew Eldredge <andrew.eldredge(at)gmail.com> >Date: Monday, March 5, 2012 18:05 >Subject: Pietenpol-List: My continental twirling muscle is sore. >To: pietenpol-list(at)matronics.com > > >> Time to roll the dice an reveal my ignorance in public. First the >> story,then questions: I rolled the airplane out of the garage on >> Saturday night >> to run the engine for the first time in a few years since it has >> been down >> for repairs. Having pulled the engine through a few times to make >> surethings were lubricated, I switched on the left mag and gave the >> prop a >> turn. I repeated the process, a lot. The engine did not start or >> even act >> like it might. A whiff of the exhaust led me to believe that there >> was a >> fuel mixture reaching the cylinders, so I turned my attention to the >> ignition system. I decided to check the grounding of the p-leads >> and was >> alarmed (initially) that I found continuity between the post and >> the case. >> Removing the leads showed me the switch was good. In my state of >> alarm I >> took the top off the left mag to check for a short, cracking the sight >> window in the process. As I probed around in there, It occurred to >> me that >> there could be an inductive coupling to the case. A check of a >> generalschematic supported that Idea. Rats, cracked window for >> what. A few >> youtube videos later I started wondering if something was wrong >> with the >> impulse coupling. Turning the prop yielded no audible click. Hmm. >> Thinking back, it seems other experienced pilots have seemed to have >> struggles starting my airplane, back before I had to fix it. >> They'd give >> it a few turns and express some dismay, Then I'd have them hold the >> airplane while I gave it my usual mighty heave (I've never known >> anythingdifferent, but sometimes it would be enough to get a full >> turn out of the >> prop.) So the possibility that I've never had a functional impulse >> coupling has now entered my head... >> >> Questions: >> --What can I use for or where can I get a timing sight window >> (and while >> I'm at it a lid gasket and other sundry parts) for m SF4RN >> --Should I be able to hear the impulse coupling click when >> pulling the >> propeller around? >> -- I could stick a bolt in a high tension terminal and feel for >> a shock, >> should that give me confidence that the mag is otherwise >> functional, or >> should I pull a plug and see if it sparks? >> --How likely is it that my cores need to be re-magnitized. >> >> Thanks for the help... >> -- >> Andrew Eldredge >> Provo, UT > > ________________________________________________________________________________
Date: Mar 06, 2012
Tools! thanks for the offer! I'm leaving out of Atlanta at 5am on Thursday morning so Lafayette will be a bit too far this time around....especially as late as this customer is keeping me onsite! I come through Atlanta fairly often and you have now been moved to the top of my list for a visit next time I'm here....like it or not! :-) Thank you. JM -----Original Message----- >From: tools <n0kkj(at)yahoo.com> >Sent: Mar 5, 2012 10:54 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: In Carrollton for a couple days...today.... > > >Jim, > >I'm probably an hour and a half to an hour and forty five north of you, but you're welcome to come up and see my shop and Piet. If the wx is good, we could go for a ride! > >I'm in Detroit at the moment but should be home before thursday (possibly tomorrow). Give me a shout and let me know if you might be interested. > >The plane is based in Lafayette GA (9a5) and I live in Chickamauga GA, just a few miles north of that. > >Tools, 423 580 1383 (aka Mike and I'm still up and will be a for a few hours) > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=367823#367823 > > ________________________________________________________________________________
Date: Mar 06, 2012
I like it! Looking good so far to head home today. If tomorrow is just one of those exception nice days, I wouldn't mind flying south to meet you somewhere as well. Haven't taken her anywhere but local since the big journey home. Just sitting here in a lounge on short call, don't really have anything better to do than go play around on runwayfinder... see what's on the way. When I'm home, I'm just home, no work schedule to work around on those days. I have a very eclectic schedule, so just call and see if I'm around next time around or whenever. I'm not the type who needs advance notice, however, if you do know ahead of time, I can try to play with my sked to increase the odds of being there. Cheers, Tools, or Notools, or Notyetools, or whatever! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367852#367852 ________________________________________________________________________________
Date: Mar 06, 2012
Wow another Piet close by! You could fly to Carrollton this Saturday, we are flying 125 or so Young Eagles (if the weather holds). Or we might fly up to see you at another time. Don't think we could get lost as it is just up US Hwy 27. Barry Davis NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Tuesday, March 06, 2012 9:54 AM Subject: Pietenpol-List: Re: In Carrollton for a couple days...today.... I like it! Looking good so far to head home today. If tomorrow is just one of those exception nice days, I wouldn't mind flying south to meet you somewhere as well. Haven't taken her anywhere but local since the big journey home. Just sitting here in a lounge on short call, don't really have anything better to do than go play around on runwayfinder... see what's on the way. When I'm home, I'm just home, no work schedule to work around on those days. I have a very eclectic schedule, so just call and see if I'm around next time around or whenever. I'm not the type who needs advance notice, however, if you do know ahead of time, I can try to play with my sked to increase the odds of being there. Cheers, Tools, or Notools, or Notyetools, or whatever! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367852#367852 ________________________________________________________________________________
Date: Mar 06, 2012
Andrew, Most SF4RN-8 Mags do not have a impulse coupling. There were a few but not many. If you hear a clank in the engine as it turns over then you h ave an impulse. If no clank you don't have an impulse. You will have to mod ify your Armstrong starter procedure. It requires a good hard twist to get the most fire outta you mags. Good luck Bro. Dave Dave Nielsen sentuchows(at)aol.com -----Original Message----- From: Andrew Eldredge <andrew.eldredge(at)gmail.com> Sent: Mon, Mar 5, 2012 6:58 pm Subject: Pietenpol-List: My continental twirling muscle is sore. Time to roll the dice an reveal my ignorance in public. First the story, t hen questions: I rolled the airplane out of the garage on Saturday night t o run the engine for the first time in a few years since it has been down f or repairs. Having pulled the engine through a few times to make sure thin gs were lubricated, I switched on the left mag and gave the prop a turn. I repeated the process, a lot. The engine did not start or even act like it might. A whiff of the exhaust led me to believe that there was a fuel mix ture reaching the cylinders, so I turned my attention to the ignition syste m. I decided to check the grounding of the p-leads and was alarmed (initia lly) that I found continuity between the post and the case. Removing the l eads showed me the switch was good. In my state of alarm I took the top of f the left mag to check for a short, cracking the sight window in the proce ss. As I probed around in there, It occurred to me that there could be an inductive coupling to the case. A check of a general schematic supported t hat Idea. Rats, cracked window for what. A few youtube videos later I sta rted wondering if something was wrong with the impulse coupling. Turning t he prop yielded no audible click. Hmm. Thinking back, it seems other exper ienced pilots have seemed to have struggles starting my airplane, back befo re I had to fix it. They'd give it a few turns and express some dismay, Th en I'd have them hold the airplane while I gave it my usual mighty heave (I 've never known anything different, but sometimes it would be enough to get a full turn out of the prop.) So the possibility that I've never had a fu nctional impulse coupling has now entered my head... Questions: --What can I use for or where can I get a timing sight window (and while I'm at it a lid gasket and other sundry parts) for m SF4RN --Should I be able to hear the impulse coupling click when pulling the p ropeller around? -- I could stick a bolt in a high tension terminal and feel for a shock, should that give me confidence that the mag is otherwise functional, or sh ould I pull a plug and see if it sparks? --How likely is it that my cores need to be re-magnitized. Thanks for the help... -- Andrew Eldredge Provo, UT -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 06, 2012
Subject: Bendix magneto starting issues
Andrew, Sorry to hear you're having starting issues. Dumb question but did you try starting the engine on the R mag only? Most small non-electric Continentals use an impulse on the L mag and non-impulse on the right and t hat's the way my Piet is setup but I always start on both because it just starts easier that way. You may in fact have an impulse mag on the L but the spring may be broken. A photo of the spring is shown in this web page. http://www.sacskyranch.com/bendix.htm Mike C. ________________________________________________________________________________
Date: Mar 06, 2012
Subject: Re: Bendix magneto starting issues
I did not try starting on the right mag only, but I did give it a few turns on "both." What are the consequences in terms of materials/tools needed if I decide to pull a mag to inspect for the coupling. Listening while the engine turns, I can hear air leaking around a bit and what sounds like the valve trains moving around, but no click or anything like what I think the coupling should sound like. Thanks, Andrew On Tue, Mar 6, 2012 at 11:10 AM, Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] wrote: > Andrew, **** > > ** ** > > Sorry to hear you=92re having starting issues. Dumb question but did you > try starting the engine on the R mag only? Most small non-electric** * > * > > Continentals use an impulse on the L mag and non-impulse on the right and > that=92s the way my Piet is setup but I always start on both because**** > > it just starts easier that way. **** > > ** ** > > You may in fact have an impulse mag on the L but the spring may be > broken. A photo of the spring is shown in this web page. **** > > ** ** > > http://www.sacskyranch.com/bendix.htm**** > > ** ** > > Mike C. **** > > * > =========== =========== =========== =========== > * > > -- Andrew Eldredge Provo, UT ________________________________________________________________________________
Date: Mar 06, 2012
Andrew, I have not worked on any magnetos since my A&P school years ago, ho wever, I WILL be soon as I go through and rebuild my engine. Do you have an overhaul/rebuild manual for your specific mag.?- From what I have seen i n my manuals, ( Eisemann )fixing/repairing mags. is pretty straight forward . I bet you could fix what ails your mag.(s) no problem. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 06, 2012
In the "real" plane world (Certified.) There can be only one. Slick seems to have taken over the world. My buddies 65HP Champ Had bendix mags. We could not find parts for them to overhaul them. So he bought new slick mags, wire harnesses, and plugs. Sure runs good.Sure was expensive (I think about $2300 after core exchange.) TCM (Continental) owns Bendix but seems to not be producing parts. Champion spark plugs owns Slick. Blue Skies, Steve D ----- Original Message ----- From: Michael Perez <speedbrake(at)sbcglobal.net> Date: Tuesday, March 6, 2012 17:13 Subject: Re: Pietenpol-List: Bendix magneto starting issues > Andrew, I have not worked on any magnetos since my A&P school years > ago, however, I WILL be soon as I go through and rebuild my engine. > Do you have an overhaul/rebuild manual for your specific mag.? > From what I have seen in my manuals, ( Eisemann )fixing/repairing > mags. is pretty straight forward. I bet you could fix what ails > your mag.(s) no problem. > > Michael Perez > Karetaker Aero > www.karetakeraero.com > ________________________________________________________________________________
Date: Mar 06, 2012
As Mike says, mags really are pretty simple devices. They come apart in a straight forward manner and actually do have a set of internal points like older cars for what is called "internal" timing. Remember "dwell"? In any event, the shop manual will tell you how to take them apart, inspect, and reassemble. Magnetos are very similar to the kind of ignition systems many of us grew up playing with in cars. A magnetic field is created in a coil and its collapse generates a spark. With cars, the power to create this field comes from the battery. In magnetos, the field is generated internally by what amounts to a permanent magnet generator. Same field collapsing principle creating a high voltage spark but the power source is different. In both cars and aircraft magnetos, this collapse is triggered by points. With cars, you effectively set the timing twice -- first internally by setting the points gap -- aka dwell -- and second externally by setting the distributor. Same with magnetos. You set the points and then set the external timing. In both cases the points have a capacitor across them to absorb the voltage spike when the points open and that prevents the points from burning up in a tiny imitation of an arc welder. Note that a defective condenser will mess up the process if it's either open ("not condensing") and causing the points to burn up, or if it's shorted out keeping the points from doing anything productive. I've seen both in the venerable Lucas ignition systems well known by fans of English cars, but I digress. The point of this rather long post is that it's probably worthwhile looking deeper into the guts of the magneto rather than fixating on the impulse coupling. If you've got it out, there's no excuse not to. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367909#367909 ________________________________________________________________________________
Date: Mar 07, 2012
Breaker points short out the condenser (capacitor) when closed. This allows the battery to directly (through a resistor, technically) 'charge' the coil, using the dc electricity from the battery to build up a magnetic field in the coil. In a magneto-driven system, the magnet wizzing by the coil induces an electric current in the coil when the points are closed, which in turn creates its own magnetic field. For this part of the discussion the coil behaves like an inductor. Inductors store energy using a magnetic field. In either system, it takes time to build up that magnetic field; it doesn't happen instantly. That's what the dwell is for - To give the system time to store some energy. In engine terms, this time is not trivial. When the points open, the condenser (which has been shorted out and is empty) is now a part of the circuit, in series with the coil/inductor. The magnetic field in the coil induces an electric current through the condenser, which stores it up (with some real-world losses). As the magnetic field pours it's energy into the condenser, it collapses (this is where the coil also behaves like a transformer) and induces a high voltage in the secondary windings, creating the spark. But the condenser is much more than a just an added doo-dad to keep your points from burning out (although it does that, too); it's an integral part of the system. The catch here is that the coil and the capacitor form a resonant circuit, known to the electronics types as an LC circuit, or a tank circuit. Mechanically, picture a weight suspended between two springs of the same size and strength. If you pull the weight to one side and let go, it will wangle back and forth at a specific frequency until real-world forces dampen it and stop it. Same deal with the coil and the condenser; it will cycle back and forth between storing current in the coil and storing voltage in the cap. If you hooked it up to an oscilloscope, you'd see a classic dampened harmonic motion. This repeated cycling induces a lot of alternating voltage at a specific frequency in the coil secondary over a decent period of time and is really where a good strong spark comes from. Without the condenser, the voltage in the coil would change once when the points closed and once when they opened, which, if you're lucky, might be enough to create a weak spark. The LC resonance is the key. This process requires that the condenser be matched to the coil to work most effectively. The coil has a certain inductance and the condenser has a certain capacitance. Each one of these has its own frequency characteristics. Pairing them up creates a specific resonant frequency dependent on both components. But if they're not matched (like a burned-out condenser), the resonant frequency changes. Picture the spring example with two different springs. Jim Ash -----Original Message----- >From: dgaldrich <dgaldrich(at)embarqmail.com> >Sent: Mar 7, 2012 12:17 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Bendix magneto starting issues > > >As Mike says, mags really are pretty simple devices. They come apart in a straight forward manner and actually do have a set of internal points like older cars for what is called "internal" timing. Remember "dwell"? In any event, the shop manual will tell you how to take them apart, inspect, and reassemble. > >Magnetos are very similar to the kind of ignition systems many of us grew up playing with in cars. A magnetic field is created in a coil and its collapse generates a spark. With cars, the power to create this field comes from the battery. In magnetos, the field is generated internally by what amounts to a permanent magnet generator. Same field collapsing principle creating a high voltage spark but the power source is different. In both cars and aircraft magnetos, this collapse is triggered by points. With cars, you effectively set the timing twice -- first internally by setting the points gap -- aka dwell -- and second externally by setting the distributor. Same with magnetos. You set the points and then set the external timing. > >In both cases the points have a capacitor across them to absorb the voltage spike when the points open and that prevents the points from burning up in a tiny imitation of an arc welder. Note that a defective condenser will mess up the process if it's either open ("not condensing") and causing the points to burn up, or if it's shorted out keeping the points from doing anything productive. I've seen both in the venerable Lucas ignition systems well known by fans of English cars, but I digress. > >The point of this rather long post is that it's probably worthwhile looking deeper into the guts of the magneto rather than fixating on the impulse coupling. If you've got it out, there's no excuse not to. > >Dave > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=367909#367909 > > ________________________________________________________________________________
Date: Mar 07, 2012
For a good review of Mags and mag problems check out this EAA video. http://www.eaavideo.org/video.aspx?v=1367499350001 The guy is truely an expert. Blue Skies, Steve D ________________________________________________________________________________
Subject: Landing gear type: Pros and Cons, Steel or wood?
Date: Mar 07, 2012
Please forgive me if this is redundant. I thought I had asked a while back, but my search proved futile. So, I wish to tap the wisdom of this collected intelligentsia... I am prepping for the Landing Gear install, thus I need to decide on the style I want. My wife and I both like the spoke'd tire look, so those would be the tire style we will use. I haven't seen those on a steel gear, so I'm not sure how it would look, or whether the added size would prove problematic to the gear strength. The main dis-advantage to the wooden gear to me is what I have heard about the 'wobble' of the axle in the platform that it rides on due to the shock cord mount. I have heard the axle will move slightly forward and rearward as you turn corners, making it slightly 'wiggly'. Other than that it looks like an easier option to build for me, and cheaper. But, this is the project of a lifetime, so the added work and money is not as important as the ultimate usefulness of the choice. I will fly almost exclusively from paved runways (can only think of one grass field I would fly to at the annual west coast piet fly-in...). I am looking for pros and cons, do's and don'ts, thoughts and suggestions regarding the choice from those that have thought about such things :o) Many thanks! BTW, The Mrs. in the first seat below :o) Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367931#367931 Attachments: http://forums.matronics.com//files/20120303_124947_160.jpg ________________________________________________________________________________
Subject: Re: Landing gear type: Pros and Cons, Steel or wood?
Date: Mar 07, 2012
Kevin Purtee has spoke wheels with steel gear. I got a ride and thought it felt great. I know he's not a fan of bungee, as he had problems with it and switched to a spring. My Piet is the classic Harley wheel with wood gear. Many aren't sure about the suitability of a stock motorcycle wheel. I learned to fly a tailwheel in this plane and taught my son... needless to say it's got a workout and is holding up fine. I don't mind the wobble at all, and never really noticed it until you mentioned it. Again, the bungee is a bit of a pain in that it does regularly wear out, but not that hard to replace, nor very expensive. While I thought I'd fly mostly grass, the truth is that I'm about 95 percent on pavement and the wood gear/straight axle hasn't proved problematic in that venue at all. Lastly, I did have to replace one of the wood members of my gear as I noticed some cracking. I'm quite certain that damaged occurred as a result of an aborted takeoff that went off runway. The point is, I noticed the damage well before the gear failed and it was easy to fix. Had it been a weldment that wasn't up to the task (either faulty weld or excessive force) I'm not sure that would be the case. Having pushed around a few cubs, champs and chiefs, I think the larger diameter wheels are easier if that's a concern. Things to consider. Pretty sure either would be fine! Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367933#367933 ________________________________________________________________________________
Date: Mar 07, 2012
Big Wheels...spokes hiding under covers. My intent was to create a faux Bendix look. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367935#367935 Attachments: http://forums.matronics.com//files/img_4163_388.jpg http://forums.matronics.com//files/img_4168_686.jpg ________________________________________________________________________________
Date: Mar 07, 2012
Mark that is looking good.-- I'm going to have to find some time to com e up to Fresno and see that thing.- =0A=0A=0AMike Groah=0A=0Ado not archi ve=0A=0A=0A________________________________=0A From: Mark Roberts <mark.rbr ts1(at)gmail.com>=0ATo: pietenpol-list(at)matronics.com =0ASent: Wednesday, March 7, 2012 10:55 AM=0ASubject: Pietenpol-List: Landing gear type: Pros and Co s" =0A=0APlease forgive me if this is redundant. I t hought I had asked a while back, but my search proved futile. So, I wish to tap the wisdom of this collected intelligentsia...=0A=0AI am prepping for the Landing Gear install, thus I need to decide on the style I want. My wif e and I both like the spoke'd tire look, so those would be the tire style w e will use. I haven't seen those on a steel gear, so I'm not sure how it wo uld look, or whether the added size would prove problematic to the gear str ength.=0A=0AThe main dis-advantage to the wooden gear to me is what I have heard about the 'wobble' of the axle in the platform that it rides on due t o the shock cord mount. I have heard the axle will move slightly forward an d rearward as you turn corners, making it slightly 'wiggly'. Other than tha t it looks like an easier option to build for me, and cheaper. But, this is the project of a lifetime, so the added work and money is not as important as the ultimate usefulness of the choice. I will fly almost exclusively fr om paved runways (can only think of one grass field I would fly to at the a nnual west coast piet fly-in...).=0A=0AI am looking for pros and cons, do's and don'ts, thoughts and suggestions regarding the choice from those that have thought about such things :o)=0A=0AMany thanks!=0A=0ABTW, The Mrs. in the first seat below :o)=0A=0AMark=0A=0A=0A=0A=0ARead this topic online her e:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=367931#367931=0A=0A =0A=0A=0AAttachments: =0A=0Ahttp://forums.matronics.com//files/20120303_124 = ________________________________________________________________________________
Date: Mar 07, 2012
The main disadvantage to the wooden straight axle gear is actually the weight. That axle is heavy, as are the wire wheels (but if you are doing wire wheels regardless, then that doesn't matter). As for "wobble", I've never noticed it in 260 hours of flying. I have guide pins on my axle to restrain it from rotating when braking, and it does moved around fore and aft a bit when braking, but nothing that is any problem at all. The wooden gear is extremely rugged (which is why Curtiss JN-4's used it). The biggest advantage to the straight axle is that camber and toe-in problems simply don't exist. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Wednesday, March 07, 2012 1:55 PM Subject: Pietenpol-List: Landing gear type: Pros and Cons, Steel or wood? Please forgive me if this is redundant. I thought I had asked a while back, but my search proved futile. So, I wish to tap the wisdom of this collected intelligentsia... I am prepping for the Landing Gear install, thus I need to decide on the style I want. My wife and I both like the spoke'd tire look, so those would be the tire style we will use. I haven't seen those on a steel gear, so I'm not sure how it would look, or whether the added size would prove problematic to the gear strength. The main dis-advantage to the wooden gear to me is what I have heard about the 'wobble' of the axle in the platform that it rides on due to the shock cord mount. I have heard the axle will move slightly forward and rearward as you turn corners, making it slightly 'wiggly'. Other than that it looks like an easier option to build for me, and cheaper. But, this is the project of a lifetime, so the added work and money is not as important as the ultimate usefulness of the choice. I will fly almost exclusively from paved runways (can only think of one grass field I would fly to at the annual west coast piet fly-in...). I am looking for pros and cons, do's and don'ts, thoughts and suggestions regarding the choice from those that have thought about such things :o) Many thanks! BTW, The Mrs. in the first seat below :o) Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367931#367931 Attachments: http://forums.matronics.com//files/20120303_124947_160.jpg ________________________________________________________________________________
Date: Mar 07, 2012
Skip: Yes, Sue and are are planning on being at Sun n Fun the whole time. Jim: I think the LC resonance frequency is much higher than the system cycle frequency which is 2 times engine speed and actually needs to be. Ignition systems are, as you describe, an LC circuit but it isn't in resonance. Look at it this way. The points close. This discharges the capacitor almost instantly and current starts flowing in the inductor. Note that the capacitor is not electrically present since it's shorted. The field builds up. If you put an oscilloscope on it and watched CURRENT, it would start from 0 and rise on a parabolic curve to the point where, given enough time, it would hit a maximum determined by the ohmic resistance of the coil. If there were a large iron core (picture a wire wrapped around a nail in science class), you'd have an electromagnet. Some time before this steady state maximum occurs, the points open. Current flow stops almost instantaneously. With no voltage present, the field collapses but the energy has to go somewhere. The low voltage winding of the coil sees a, maybe .016 air gap, but the 14 volts can't jump that. The secondary coil, on the other hand can generate several thousand volts and can jump your .032 spark plug gap with ease. It's the path of least resistance. Note that when the points first open, the gap is VERY small and the collapsing field from the low voltage winding CAN jump it. The condenser absorbs just enough of the the current to allow the points to fully open without excessive arcing. There is no resonance in the "tuned circuit" sense like you find in radios. The better analogy is that the coil is an AC transformer. If you look at the current waveform in the low voltage side, it really is a sawtooth but with curved "sides". The frequency is determined by the physical speed of the rotating cam opening and closing the points. I'm hoping the drawing attached makes sense. Note that as the rpm increases, the amount of time available to build up the field goes down and the spark gets weaker You are correct that the condenser and coil must be compatible. If the condenser is too small, it won't be able to absorb enough energy to allow the points to open cleanly. If it is too large, the current flowing when the points close and discharge it will also burn them. Again, it's not a "tuned" circuit. Hope this helps. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367946#367946 Attachments: http://forums.matronics.com//files/points_1_198.jpg ________________________________________________________________________________
Date: Mar 07, 2012
Mark I was in the same boat as you a few years ago. I did the same kind of mission evaluation and have a similar paved runway outlook as you. It made me think the split axle would be better. However, after asking around I could find no reason not to build the wood gear. One big deciding factor for me was I just didnt have the confidence to build the steel gear and I needed to get the project moving as other parts had frustrated me to the point where I wasnt working on the plane anymore. While trying to decide between the two I modified the attached pictures to give me an idea how the landing gear choice would change the overall appearance of the plane. For me the final look of the plane is very important. Basically I would pick the one you think looks the best. Wood Gear Pros: Vintage look Unique No toe in or toe out problems. Simpler to build. People question your sanity. Cons: The axel and spreader bar are close to the ground and might catch on tall grass or other things like runway lights if you find yourself in a bad situation. Need to stop axel rotation if you use brakes. Heavy People question your sanity If you like to be unique, everyone seems to be building the wood gear lately. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367948#367948 Attachments: http://forums.matronics.com//files/picture1_504.jpg http://forums.matronics.com//files/picture2_178.jpg http://forums.matronics.com//files/picture3_151.jpg http://forums.matronics.com//files/picture4_964.jpg ________________________________________________________________________________
Date: Mar 07, 2012
There are quite a few out there that have the wire wheels and the split axle gear. I chose to cover mine. Mr. Pietenpol went this route with 12988 and left them uncovered. I'm happy with the set up. Other than changing bungees every couple of years it works out well. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367949#367949 Attachments: http://forums.matronics.com//files/wheel08_435.png http://forums.matronics.com//files/piet08_171.png ________________________________________________________________________________
Date: Mar 07, 2012
Unfortunately, Don, the straight axle version also requires changing the bungees every couple of years - my least favorite airplane task in the world. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Don Emch Sent: Wednesday, March 07, 2012 5:41 PM Subject: Pietenpol-List: Re: Landing gear type: Pros and Cons, Steel or wood? There are quite a few out there that have the wire wheels and the split axle gear. I chose to cover mine. Mr. Pietenpol went this route with 12988 and left them uncovered. I'm happy with the set up. Other than changing bungees every couple of years it works out well. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367949#367949 Attachments: http://forums.matronics.com//files/wheel08_435.png http://forums.matronics.com//files/piet08_171.png ________________________________________________________________________________
Date: Mar 07, 2012
Yeah... I'm up for it this year. [Crying or Very sad] Been preparing...mentally and physically! Ha! Not a fun task. I have streamlined the process a little though. The main requirement is cussing. Unfortunately because of that I can't train the kids to help for a few more years. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367952#367952 ________________________________________________________________________________
Date: Mar 07, 2012
Subject: bungees
We use the straight bungee, with home made loops on the ends, not too bad o f a job installing them, just getting them the right length, and getting bo th the same so the airplane does not list one way-or the other, thats the tuffy. (wow what a run on sentence)- Looking forward to the warm weather , havn't flown since December 15th or so, and the new job should let me fly on the weekends. - Shad ________________________________________________________________________________
Date: Mar 07, 2012
FWIW. 280 hours since 9/09 including two trips from Austin, TX to Brodhead. Only issues were the result of my welding. I changed from bungees to springs as Mike Danforth mentioned, for good, solid reasons. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367961#367961 Attachments: http://forums.matronics.com//files/wire_wheels_145.jpg ________________________________________________________________________________
Date: Mar 07, 2012
Hey Guys! Many, Many thanks for these comments. It is EXACTLY what I was hoping to learn from ya'll. I am encouraged to know others have thought this one out ahead of time (Duh... It IS an 80 year old design after all :o) My main concern is my inexperience with metal. I am going to take the plans to my welding friend soon and ask him about it. The best metal gear I've seen is Charlie Millers' gear with the streamlined tubing for the legs. Very sturdy, but re-designing stuff like this isn't my cup of tea. So, I'm going to re-read all of this again, but want to thank ya'll again for the help. It is this kind of interaction that really makes this group special. And, thanks for the kind words about the Mrs. in the front seat! :o) She's only 5'2", so I need to raise the seat a bit when I put it in... Ha! She'll get all the bugs in the teeth for me ! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367964#367964 ________________________________________________________________________________
Date: Mar 08, 2012
Mark, Both gear systems have there advantages and disadvantages as has been reported. I'm currently destroying a lot of 4130 on my split gear. Despite all the measuring, fitting and cutting I'm still having problems getting perfect fits. After a week I only have the left front V done. All part of the fun. Jack Textor DSM NX1929T -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Wednesday, March 07, 2012 11:26 PM Subject: Pietenpol-List: Re: Landing gear type: Pros and Cons, Steel or wood? Hey Guys! Many, Many thanks for these comments. It is EXACTLY what I was hoping to learn from ya'll. I am encouraged to know others have thought this one out ahead of time (Duh... It IS an 80 year old design after all :o) My main concern is my inexperience with metal. I am going to take the plans to my welding friend soon and ask him about it. The best metal gear I've seen is Charlie Millers' gear with the streamlined tubing for the legs. Very sturdy, but re-designing stuff like this isn't my cup of tea. So, I'm going to re-read all of this again, but want to thank ya'll again for the help. It is this kind of interaction that really makes this group special. And, thanks for the kind words about the Mrs. in the front seat! :o) She's only 5'2", so I need to raise the seat a bit when I put it in... Ha! She'll get all the bugs in the teeth for me ! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367964#367964 ________________________________________________________________________________
Date: Mar 08, 2012
raykrause(at)frontiernet. wrote: > Papa Mike, > > How did you make the wheel covers, and how are they attached to the wheel? > Surely they are not riveted to the rim? > > Thanks, > > Ray Krause > Sky Scout in progress > --- Ray, The wheel covers are a conic development. Started with flat sheet and calculated the diameters to produce the desired "cone". The covers are bolted to the flanges of the hub. The rivets in the periphery are purely cosmetic. The wheels shown in the pic were my prototypes. The attached pics show the final version. A lot of work....but they sure look neat! I designed them to use the early Tri-Pacer mechanical brakes. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367973#367973 Attachments: http://forums.matronics.com//files/wheel7_183.jpg http://forums.matronics.com//files/wheel6_150.jpg http://forums.matronics.com//files/wheel3_140.jpg ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: tornado near miss...
Date: Mar 08, 2012
Thanks for asking Larry, We were VERY blessed here. As best I can tell, the storm came right at our house and a few miles out split in two. A tornado touched town a couple miles south of us and one touched down a couple miles north and killed five people and destroyed a LOT of homes and property. Just drove through it yesterday and it was amazing. We on the other hand got some powerful wind for about fifteen minutes and then sunshine. We're off helping our neighbors, some of which don't have home insurance. Progress report. Am waiting on my fourth ACS order trying to get the right AN fittings to hook up the oil pressure gauge (don't ask.) then I can run this baby!! Douwe ________________________________________________________________________________
Date: Mar 08, 2012
If I may make a suggestion Mark, leave that front seat at the height shown and just add a cushion(s) as needed. She will then be comfy and you still have the option of fitting taller people in there for quick rides. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 08, 2012
How do you go about matching the condenser to the coil to work most effectively? Bill Princell - This process requires that the condenser be matched to the coil to work most effectively. The coil has a certain inductance and the condenser has a certain capacitance. Each one of these has its own frequency characteristics. Pairing them up creates a specific resonant frequency dependent on both components. But if they're not matched (like a burned-out condenser), the resonant frequency changes. On Wed, Mar 7, 2012 at 1:52 PM, Dortch, Steven D MAJ NG NG NGB < steven.d.dortch(at)us.army.mil> wrote: > steven.d.dortch(at)us.army.mil> > > For a good review of Mags and mag problems check out this EAA video. > > http://www.eaavideo.org/video.aspx?v=1367499350001 > > The guy is truely an expert. > > Blue Skies, > Steve D > > ________________________________________________________________________________
Date: Mar 08, 2012
Ha! Thanks Michael! I didn't even think about the fact I'd be cutting others out of the comfort of the windscreen by jacking the seat up a few inches! Funny, but that just saved me a serious "Oops" that wouldn't have been easy to correct! Love the wheel covers too Papa Mike! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368017#368017 ________________________________________________________________________________
Date: Mar 08, 2012
I'm still digesting Dave Galdrich's note on this from yesterday and formulating a response, so I'm questioning my understanding of the concepts at this point and hesitate to answer. If Dave is right, then the capacitance of the condenser will be a lot different (probably lower-valued) than what I thought, and I owe you all an apology for my incorrect email. My short, somewhat flippant answer to you would be 'Whatever the book tells you', which unfortunately leaves the engineering to some ominous 'them'. Most automotive condensers I can recall have been around around .2uF to .3uF. If you want to get into tank circuit theory, we can do that, but if this system isn't really a tank, it's only a cute academic exercise. I've been running through my head on where I can find a breaker-point-driven engine and hook an oscilloscope to it to check it out. I just got a boat engine (140 hp 4-cyl GM block on a Merc I/O drive) to run for a friend a couple weeks ago and got to thinking about breaker point systems again, so I did some web surfing last week on it to refresh myself. Rather timely considering this recent discussion. That's where I ran across the theory that it was a tank circuit, but I haven't so far been able to find that page again. I'm familiar with tank circuits, I just didn't realize this was one of them, and now Dave is saying it ain't. My scopes are off in a corner of my basement and not set up right now; they're old and not real portable. I suppose I could drag one out and hook it to my snow blower; this winter has really sucked for snow (I ski and snowboard) and I'm not expecting to need it again until next winter anyhow. Jim Ash -----Original Message----- From: Bill Princell Sent: Mar 8, 2012 12:02 PM Subject: Re: Pietenpol-List: Re: Bendix magneto starting issues How do you go about matching the condenser to the coil to work most effectively? Bill Princell - This process requires that the condenser be matched to the coil to work most effectively. The coil has a certain inductance and the condenser has a certain capacitance. Each one of these has its own frequency characteristics. Pairing them up creates a specific resonant frequency dependent on both components. But if they're not matched (like a burned-out condenser), the resonant frequency changes. On Wed, Mar 7, 2012 at 1:52 PM, Dortch, Steven D MAJ NG NG NGB wrote: For a good review of Mags and mag problems check out this EAA video. http://www.eaavideo.org/video.aspx?v=1367499350001 The guy is truely an expert. Blue Skies, Steve D ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Re: center section storage lid hinge-to-front spar
Date: Mar 08, 2012
Just would like to thank Mr. Cuy for giving me this idea for the center wing lid. Here is my version so far.. -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368032#368032 Attachments: http://forums.matronics.com//files/img_0443_640x478_181.jpg http://forums.matronics.com//files/img_0445_640x478_571.jpg http://forums.matronics.com//files/img_0447_640x478_3_168.jpg ________________________________________________________________________________
Date: Mar 08, 2012
You're welcome. - -I actually lowered my seat because I will always fly with a seat cushion .- I left the front seat- alone, but will have a-cushion for those wh o want one, or for shorter passengers. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 08, 2012
Thanks, Mike! Beautiful work. Is that wheel convex on only the outside? In bicycles that is called "dished", as in the rear wheel with an 8-10 speed cog. Looks as though only the outside of you disc is convex. Thanks again for the wonderful pictures. Now I have another project. Ray Krause ----- Original Message ----- From: "899PM" <rockriverrifle(at)hotmail.com> Sent: Thursday, March 08, 2012 6:09 AM Subject: Pietenpol-List: Re: Landing gear type: Pros and Cons, Steel or wood? > > > raykrause(at)frontiernet. wrote: >> Papa Mike, >> >> How did you make the wheel covers, and how are they attached to the >> wheel? >> Surely they are not riveted to the rim? >> >> Thanks, >> >> Ray Krause >> Sky Scout in progress >> --- > > > Ray, > > The wheel covers are a conic development. Started with flat sheet and > calculated the diameters to produce the desired "cone". The covers are > bolted to the flanges of the hub. The rivets in the periphery are purely > cosmetic. The wheels shown in the pic were my prototypes. The attached > pics show the final version. A lot of work....but they sure look neat! I > designed them to use the early Tri-Pacer mechanical brakes. > > -------- > PAPA MIKE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367973#367973 > > > Attachments: > > http://forums.matronics.com//files/wheel7_183.jpg > http://forums.matronics.com//files/wheel6_150.jpg > http://forums.matronics.com//files/wheel3_140.jpg > > > ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Subject: Center Section Cover
Date: Mar 09, 2012
This week, someone sent an E-mail on the list about his cover for his center-section storage compartment. I also am in the process of building my center-section and want to build a similar cover. I mistakenly deleted the E-mail rather than saving it. Will the kind person re-send the E-mail with the pictures of his cover -- you might send a couple more pictures if you can. I need all the help I can get. Thanks a bunch, Chuck ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Mar 09, 2012
Subject: Kyle's center section cargo area cover
Very nicely fabricated Kyle. It appears as though your workmanship is real ly top notch. I'm very impressed at how the standard of Pietenpol craftsmansh ip has continually gotten better over the past ten years or so. Outstanding w ork going on out there in little shops, garages, and basements around this land and far off lands. Beauuutiful work. Mike C. ________________________________________________________________________________
Subject: Re: Kyle's center section cargo area cover
Date: Mar 09, 2012
Michael, thanks for the reply. I was going to ask Kyle but I'll ask you instead, what thickness aluminum sheet did you use? I was thinkiing of ordering enough to do both the cover and the cowling around my Corvair engine as well as the cowls on the fuselage. I have Hans Van DerVoort's drawings for his engine cowl, but he doesn't stipulate the thickness of the material. Chuck ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] To: pietenpol-list(at)matronics.com Sent: Friday, March 09, 2012 8:32 AM Subject: Pietenpol-List: Kyle's center section cargo area cover Very nicely fabricated Kyle. It appears as though your workmanship is really top notch. I'm very impressed at how the standard of Pietenpol craftsmanship has continually gotten better over the past ten years or so. Outstanding work going on out there in little shops, garages, and basements around this land and far off lands. Beauuutiful work. Mike C. ------------------------------------------------------------------------- ----- ------------------------------------------------------------------------- ----- ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Mar 09, 2012
Michael, Chuck again. I just went to your pictures on the west coast web site and saved a bunch of your pictures for future reference. You might just expect a bunch of questions later on. C ----- Original Message ----- From: Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] To: pietenpol-list(at)matronics.com Sent: Monday, March 05, 2012 1:11 PM Subject: Pietenpol-List: center section storage lid hinge-to-front spar Kyle, I just drilled a few pilot holes for some truss-head wood screws to attach my hinged cover for the center section storage compartment. The other 1/2 of my hinge is riveted to the aluminum cover. Mike C. for more photos please see: http://www.westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy_2.h tm (Thank you Chris Tracy!!!!) ________________________________________________________________________________
Date: Mar 09, 2012
Chuck, I used 2024 T3 .032 throughout my lid. It worked nicely for me. Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368062#368062 ________________________________________________________________________________
Subject: Sun and Fun
Date: Mar 09, 2012
I'm going to be down here in Lakeland for a work contract, but will be at the show. Is there anyone coming down here, that I may be able to get together with. I would like to take some pictures, ask questions, and maybe get a ride. Thanks guys! J_Dunavin(at)hotmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368067#368067 ________________________________________________________________________________
Date: Mar 09, 2012
Subject: Aluminum thickness: Kyle's center section cargo area
cover Chuck- I used .025" 2024T3 for everything sheet aluminum wise on my Pietenpol including the center section cargo cover lid. Mike C. ________________________________________________________________________________
Date: Mar 09, 2012
Chuck, Hans' drawing actually does specify the thickness (.025), just above the Bill of Materials chart. http://mykitplane.com/Planes/PeoplesFiles/Cowling%20drawing.pdf Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368076#368076 ________________________________________________________________________________
Date: Mar 09, 2012
Chuck, Here is a picture of my trial fit. Still need to figure out a way to mount the piano hinge to my front spar in order for my piano hinge to mount flush with the "skin" I may need to bond a strip of wood to the top of my spar to take up the gap and then mount to that. My method of attaching will still be truss screws. Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368081#368081 Attachments: http://forums.matronics.com//files/img_0448_640x478_965.jpg ________________________________________________________________________________
Date: Mar 09, 2012
Jim: Think about this from a theory point of view. When the points CLOSE, the C is out of the picture -- it's shorted out -- so you have an RL circuit. As the field builds up, the current goes from 0 toward a steady state that is determined solely by the R in the circuit. That R is a function of the ballast resistor and the internal resistance of the coil. The RL time constant determines the shape of the first part of the curve I drew. Side note: Notice that the faster the engine runs, the earlier on that curve the points open. That means less energy stored in the coil to produce a spark. As a conventional system speeds up, the spark actually becomes weaker. Not so with magnetos. The faster the magneto turns (up to a point) the more energy is available. The faster a wire moves through a magnetic field, the more induced voltage. The slower the movement, the less voltage. That's why magnetos can sometimes be hard to start and why impulse couplings were developed. The impulse coupling accelerates the magnets through the windings in a ratchet kind of motion. Now the points open. You have a series RLC circuit with a DC supply voltage. That is a circuit that cannot resonate and is what is called a band pass filter. Only frequencies in a range around the square root of 2*Pi*L*C if memory serves, will get through. DC will not. The graph I drew is actually incorrect. The current in the low voltage/primary winding actually drops to zero almost immediately. The energy stored in the magnetic field of both coil windings has only one way to dissipate and that's through the high voltage/secondary side via the spark plug which has much less effective resistance than the primary side. What you may have read about is some of the solid state systems may have a resonant circuit used to charge a capacitor in a system commonly known as a CDI for Capacitor Discharge Ignition. There is no such thing as a DC transformer so in order to get a higher than 14 v supply, the system either uses a resonant circuit or chops dc in very short on/off pulses. These look like AC to a transformer and by proper selection of windings, you can get almost any AC voltage you want. Rectify it and - voila - high(er) voltage DC. That's the principle the 110 v adapters you plug in your cigarette lighter work on. This is probably one of those cases of "ask me what time it is and I'll tell you how to build a watch". Hope this helps. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368085#368085 ________________________________________________________________________________
Date: Mar 09, 2012
Yeah, Kyle, that's what I did to make everything line up. I just cut a piece approximately the shape I needed, glued it on, and then shaped it with a block plane so that everything lines up. Your pic looks great. I was originally planning to cover just the area between the main spars. I'm about to run it on back to where the aileron spar goes -- like Mike and, apparently, you did. I also liked Mike's design of the little compartment where he can get to the aileron cables and pulleys. Thanks for your help. Chuck ----- Original Message ----- From: "Kyle85" <boschkyle(at)hotmail.com> Sent: Friday, March 09, 2012 6:57 PM Subject: Pietenpol-List: Re: center section storage lid hinge-to-front spar > > Chuck, > Here is a picture of my trial fit. Still need to figure out a way to mount > the piano hinge to my front spar in order for my piano hinge to mount > flush with the "skin" I may need to bond a strip of wood to the top of my > spar to take up the gap and then mount to that. My method of attaching > will still be truss screws. > Kyle > > -------- > Airspeed, altitude or brains: Two are always needed to successfully > complete the flight. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=368081#368081 > > > Attachments: > > http://forums.matronics.com//files/img_0448_640x478_965.jpg > > > ________________________________________________________________________________
Date: Mar 10, 2012
Attached are two pictures that may, or may not be of any help. The first- shows the way I mounted my hinges, the second the rear view of my divider t o keep items out of the pulleys/cables. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 11, 2012
Very nice work, and good details. Wish Scout had such a wing storage compartment. Maybe someday I'll do a retrofit. By the way, my old "coffee grinder" pencil sharpener is one of the most used 'tools' in my shop, and it really helps when laying out lines on wood. Nothing like a sharp pencil to lay down clean lines. However, I have my sharpener oriented such that gravity carries the shavings and dust to the bottom. I don't rely on centrifugal force to throw the particles horizontally like you do with yours ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368159#368159 ________________________________________________________________________________
Subject: Got in some flying last evening.
Date: Mar 11, 2012
While the setting sun generally was screwing up the photo op, this one turned out pretty cool. My son is in the back, I'm in the front. Having a hard time finding nice steady cross winds, so here he is setting her down on one wheel for practice during calm conditions. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368165#368165 ________________________________________________________________________________
Date: Mar 11, 2012
Very cool! Nice to see you enjoying Dick's old Pietenpol. I'm sure it is still a bit chilly in Minnesota for aviating. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Sunday, March 11, 2012 3:24 PM Subject: Pietenpol-List: Got in some flying last evening. While the setting sun generally was screwing up the photo op, this one turned out pretty cool. My son is in the back, I'm in the front. Having a hard time finding nice steady cross winds, so here he is setting her down on one wheel for practice during calm conditions. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368165#368165 ________________________________________________________________________________
Subject: Re: Sun and Fun
Date: Mar 11, 2012
Stop by the Wood workshop, several of us are going to build stuff for a Pietenpol at the show. I just got to Fla and will relax a bit and be ready to go. Dick N. ----- Original Message ----- From: "j_dunavin" <j_dunavin(at)hotmail.com> Sent: Friday, March 09, 2012 12:35 PM Subject: Pietenpol-List: Sun and Fun > > I'm going to be down here in Lakeland for a work contract, but will be at > the show. Is there anyone coming down here, that I may be able to get > together with. I would like to take some pictures, ask questions, and > maybe get a ride. > Thanks guys! > J_Dunavin(at)hotmail.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=368067#368067 > > > ________________________________________________________________________________
Date: Mar 11, 2012
Dave - I'm basically with you on all the theory. I think your initial graph threw me for a loop, which is what got me going. All the stuff I've seen shows current diving at points-open time, which makes the graph look roughly like a rounded-back sawtooth. The field collapse is what gets this little beastie going. My only unknown really just comes down to the value chosen for the condenser. If the reactance of the cap is the same as for the coil, it becomes a tank. An ideal tank is an LC loop, which in theory will cycle forever. But in the real world, there's going to be some R components to dampen it, the most significant in this circuit being the load from the secondary, which is kinda the goal anyhow. I'm guessing ESR and other parasitics are there, but I doubt they're significant compared to that. The 2pi sqrt(L*C) is actually the time constant for the circuit (technically, the 2pi is outside the radical - I normally try to stick with the omega notation to keep my life simpler when doing the math, then use omega = 2pi f when I care about applying it to real-world frequencies). Invert it to get the frequency, but you've got the idea. My RLC filter theory is rusty (my RC theory isn't - I use that one a lot more often doing digital stuff. I generally try to avoid magnetics when I can - Too much mass, too much space, too much copper), but the natural frequency for a band-pass (or notch) is going to be the same as for a tank of the same frequency; they're the same formula. The difference is that the components in a tank are matched to store the same amount of energy, so it just keeps bouncing between the two. If they're not matched, it won't be a true tank, but every system like this has to have some natural frequency and it will ring about it (overdampened), so I'm not quite with you on the 'cannot resonate' statement. My guess is that the sudden current drop-off on the graph is going to show some ringing about zero. The how-much part was my misunderstanding. I was led to believe it rang significantly (on a 30-40kHz natural frequency), and the current swings were enough to get the plug to fire more than once in rapid succession before enough energy was bled out of the system the secondary couldn't reach ionization energy any more. With that not being true, then I don't have a clue what the criteria are to drive ideal condenser selection. So what time is it? Sometimes watch works are cool. Jim -----Original Message----- >From: dgaldrich <dgaldrich(at)embarqmail.com> >Sent: Mar 9, 2012 9:47 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Bendix magneto starting issues > > >Jim: > >Think about this from a theory point of view. When the points CLOSE, the C is out of the picture -- it's shorted out -- so you have an RL circuit. As the field builds up, the current goes from 0 toward a steady state that is determined solely by the R in the circuit. That R is a function of the ballast resistor and the internal resistance of the coil. The RL time constant determines the shape of the first part of the curve I drew. > >Side note: Notice that the faster the engine runs, the earlier on that curve the points open. That means less energy stored in the coil to produce a spark. As a conventional system speeds up, the spark actually becomes weaker. Not so with magnetos. The faster the magneto turns (up to a point) the more energy is available. The faster a wire moves through a magnetic field, the more induced voltage. The slower the movement, the less voltage. That's why magnetos can sometimes be hard to start and why impulse couplings were developed. The impulse coupling accelerates the magnets through the windings in a ratchet kind of motion. > >Now the points open. You have a series RLC circuit with a DC supply voltage. That is a circuit that cannot resonate and is what is called a band pass filter. Only frequencies in a range around the square root of 2*Pi*L*C if memory serves, will get through. DC will not. > >The graph I drew is actually incorrect. The current in the low voltage/primary winding actually drops to zero almost immediately. The energy stored in the magnetic field of both coil windings has only one way to dissipate and that's through the high voltage/secondary side via the spark plug which has much less effective resistance than the primary side. > >What you may have read about is some of the solid state systems may have a resonant circuit used to charge a capacitor in a system commonly known as a CDI for Capacitor Discharge Ignition. There is no such thing as a DC transformer so in order to get a higher than 14 v supply, the system either uses a resonant circuit or chops dc in very short on/off pulses. These look like AC to a transformer and by proper selection of windings, you can get almost any AC voltage you want. Rectify it and - voila - high(er) voltage DC. That's the principle the 110 v adapters you plug in your cigarette lighter work on. > >This is probably one of those cases of "ask me what time it is and I'll tell you how to build a watch". > >Hope this helps. > >Dave > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=368085#368085 > > ________________________________________________________________________________
Date: Mar 11, 2012
Subject: center section storage lid hinge-to-front spar
Perez- Judging by the ends of your center section spars, your dihedral angle will be about 23 degrees. Just curious about the length of your struts and how much lift you're going to sacrifice. Should be stable as all get-out, though. Larry (Top Curmudgeon) Williams ________________________________________________________________________________
Date: Mar 11, 2012
Subject: SunNFun plans
Hi all, I've been staying in a friend's motorhome the last 2 or 3 years at Sun-N-Fun. This year he isn't going, so I'm planning some Air-camping, loading all the camping gear I can fit into my front cockpit and center section and flying over. Anybody else planning to camp this year so I'm not hanging out by myself? -- Ben Charvet Titusville, Fl Really hoping his Pietenpol finally makes it to Lakeland ________________________________________________________________________________
Date: Mar 11, 2012
Jim, Now THAT would take some serious hand-eye coordination. Unless you mean doing the two activities separately. :) Jim Ash wrote: > My bucket list includes (amongst a hundred other things) playing the banjo and painting a landscape. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368201#368201 ________________________________________________________________________________
Date: Mar 11, 2012
First, I've reread my posts on this subject and I must admit that they do sound pedantic. That was not my intent. I probably would have made a terrible teacher. I'm also with you on the banjo. Did some more research on the subject and it turns out we are both correct. The basic theory as we have both described it is correct. Points open, field collapses, spark occurs. The selection of correct values for coil and condenser values require an analysis of the type you describe. There ARE alternating current harmonics generated, as there are any time you open or close a DC switch. R, L, and C are chosen to control/dampen that oscillation as fast as possible -- 3 to 4 oscillations max --and still have a rapid, controlled field collapse/hot spark. The field collapse that produces the spark is pretty much a single DC only event. The oscillation really is more of an unwanted by-product of physics than it is necessary for the function of spark production since the circuits do not continue to oscillate past the 3 or 4 damped cycles. I found some typical L and C numbers and the resonant frequency for the primary circuit is something like 10 khz. Considering a 4 cylinder engine at 3000 rpm fires at a 100 hz rate, the time spent oscillating is close to inconsequential. That was (sort of) my point. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368207#368207 ________________________________________________________________________________
Date: Mar 11, 2012
That's funny - I had to read the posting again. I'll post a youtube video for you when I get that far. ... but don't hold your breath for too long. Jim -----Original Message----- >From: Bill Church <billspiet(at)sympatico.ca> >Sent: Mar 11, 2012 9:15 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Bendix magneto starting issues > > >Jim, >Now THAT would take some serious hand-eye coordination. >Unless you mean doing the two activities separately. :) > >Jim Ash wrote: > >> My bucket list includes (amongst a hundred other things) playing the banjo and painting a landscape. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=368201#368201 > > ________________________________________________________________________________
Subject: CONTACT!!!!!!
Date: Mar 12, 2012
Did the first engine run in the airframe yesterday!! (the guy that built it ground ran it) Very uneventful. Ran beautifully, pressure good, no leaks and the wiring SEEMS correct. Just did a few short runs to ck the installation. Sure sounded nice with those mufflers and long pipes. She's back in the shop and now that I know the installation is sound, it's full speed ahead with finishing the airframe stuff. Douwe ________________________________________________________________________________
Date: Mar 12, 2012
Subject: Re: CONTACT!!!!!!
Douwe! That's outstanding! Congrats! -----Original Message----- From: Douwe Blumberg Sent: Mar 12, 2012 6:42 AM Subject: Pietenpol-List: CONTACT!!!!!! Did the first engine run in the airframe yesterday!! (the guy that built it ground ran it) Very uneventful. Ran beautifully, pressure good, no leaks and the wiring SEEMS correct. Just did a few short runs to ck the installation. Sure sounded nice with those mufflers and long pipes. Shes back in the shop and now that I know the installation is sound, its full speed ahead with finishing the airframe stuff. Douwe ________________________________________________________________________________
Date: Mar 12, 2012
Great news Douwe!!! Congratulations! Get ready to be thrown back in your se at with all that HP! Dan Helsper Puryear, TN -----Original Message----- From: Douwe Blumberg <douweblumberg(at)earthlink.net> Sent: Mon, Mar 12, 2012 6:39 am Subject: Pietenpol-List: CONTACT!!!!!! Did the first engine run in the airframe yesterday!! (the guy that built it ground ran it) Very uneventful. Ran beautifully, pressure good, no leaks and the wiring S EEMS correct. Just did a few short runs to ck the installation. Sure soun ded nice with those mufflers and long pipes. She=99s back in the shop and now that I know the installation is soun d, it=99s full speed ahead with finishing the airframe stuff. Douwe -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 12, 2012
So how about a YouTube so we can all hear what it sounds like? Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Monday, March 12, 2012 7:42 AM Subject: Pietenpol-List: CONTACT!!!!!! Did the first engine run in the airframe yesterday!! (the guy that built it ground ran it) Very uneventful. Ran beautifully, pressure good, no leaks and the wiring SEEMS correct. Just did a few short runs to ck the installation. Sure sounded nice with those mufflers and long pipes. She's back in the shop and now that I know the installation is sound, it's full speed ahead with finishing the airframe stuff. Douwe ________________________________________________________________________________
Date: Mar 12, 2012
Douwe, glad to hear it all coming together. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 12, 2012
Williams, - I don't know what the angle is on the spar cuts. My calculations show a 1 d egree dihedral angle on a 158.5" wing section yields about a 2.766" rise at the wing tip.- My dihedral, if any, will be a lot less then this. - My strut length will be what is required to achieve the required dihedral.. .if any. - Sacrificial lift will be zero. - I agree, the plane will be stable. - - Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: SunNFun plans
Date: Mar 12, 2012
Hi Ben You can come over and hang out with me and Skip Gadd and whoever else shows up. I will have some cold beer. I'm already in Fla. Camping on the Okachabee waterway at the St. Locks. Dick N. 612-805-1742 ----- Original Message ----- From: "Ben Charvet" <bencharvet(at)gmail.com> Sent: Sunday, March 11, 2012 8:14 PM Subject: Pietenpol-List: SunNFun plans > > Hi all, > I've been staying in a friend's motorhome the last 2 or 3 years at > Sun-N-Fun. This year he isn't going, so I'm planning some Air-camping, > loading all the camping gear I can fit into my front cockpit and center > section and flying over. Anybody else planning to camp this year so I'm > not hanging out by myself? > > > -- > Ben Charvet > Titusville, Fl > > Really hoping his Pietenpol finally makes it to Lakeland > > > ________________________________________________________________________________
Date: Mar 12, 2012
Ben Sorry, no Big Piets at Sun n Fun this year, especially after they sent us a bill for $28,000 for moving and cleanup. Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Sunday, March 11, 2012 9:15 PM Subject: Pietenpol-List: SunNFun plans Hi all, I've been staying in a friend's motorhome the last 2 or 3 years at Sun-N-Fun. This year he isn't going, so I'm planning some Air-camping, loading all the camping gear I can fit into my front cockpit and center section and flying over. Anybody else planning to camp this year so I'm not hanging out by myself? -- Ben Charvet Titusville, Fl Really hoping his Pietenpol finally makes it to Lakeland ________________________________________________________________________________
Date: Mar 12, 2012
Ben, how about planning on joining with us at Tripple Tree Aerodrome just after labor day.Gardiner Mason ----- Original Message ---- From: Barry Davis <bed(at)mindspring.com> Sent: Mon, March 12, 2012 4:51:09 PM Subject: RE: Pietenpol-List: SunNFun plans Ben Sorry, no Big Piets at Sun n Fun this year, especially after they sent us a bill for $28,000 for moving and cleanup. Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ben Charvet Sent: Sunday, March 11, 2012 9:15 PM Subject: Pietenpol-List: SunNFun plans Hi all, I've been staying in a friend's motorhome the last 2 or 3 years at Sun-N-Fun. This year he isn't going, so I'm planning some Air-camping, loading all the camping gear I can fit into my front cockpit and center section and flying over. Anybody else planning to camp this year so I'm not hanging out by myself? -- Ben Charvet Titusville, Fl Really hoping his Pietenpol finally makes it to Lakeland ________________________________________________________________________________
Date: Mar 12, 2012
I'm still firming up how long I can stay. I have my own tent and stuff, just want some guys to hang out with at night. I can bring cash for beer! Ben On 3/12/2012 2:51 PM, Dick N wrote: > > Hi Ben > You can come over and hang out with me and Skip Gadd and whoever else > shows up. I will have some cold beer. > I'm already in Fla. Camping on the Okachabee waterway at the St. Locks. > Dick N. > 612-805-1742 > ----- Original Message ----- From: "Ben Charvet" <bencharvet(at)gmail.com> > To: "Pietenpol list" > Sent: Sunday, March 11, 2012 8:14 PM > Subject: Pietenpol-List: SunNFun plans > > >> >> Hi all, >> I've been staying in a friend's motorhome the last 2 or 3 years at >> Sun-N-Fun. This year he isn't going, so I'm planning some >> Air-camping, loading all the camping gear I can fit into my front >> cockpit and center section and flying over. Anybody else planning to >> camp this year so I'm not hanging out by myself? >> >> >> -- >> Ben Charvet >> Titusville, Fl >> >> Really hoping his Pietenpol finally makes it to Lakeland >> >> >> >> >> > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Mar 12, 2012
Yee haw! On 03/12/2012 06:42 AM, Douwe Blumberg wrote: > Did the first engine run in the airframe yesterday!! (the guy that built > it ground ran it) > > Very uneventful. Ran beautifully, pressure good, no leaks and the wiring > SEEMS correct. Just did a few short runs to ck the installation. Sure > sounded nice with those mufflers and long pipes. > > Shes back in the shop and now that I know the installation is sound, > its full speed ahead with finishing the airframe stuff. > > Douwe > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Re: Of electronics and banjos
Date: Mar 13, 2012
Jealousy. :-) http://www.youtube.com/watch?v=lKK_n4Ac0Bk&feature=related Clif Dem's da brakes! I wonder why there are so many jokes about banjos and banjo players? Jack Phillips ________________________________________________________________________________
Date: Mar 13, 2012
Subject: dimple
Hi all, on my newly installed 1/16 ply on one bay of my leading edge I noticed a dimple about the size of a coffee can. Is there a way to get that out? I wonder if wetting it down and putting an iron to it will work. Gardiner ________________________________________________________________________________
Subject: Re: dimple
Date: Mar 13, 2012
Gardiner, I have them also and hoping the fabric will pull them down when shrunk. Jack Textor Sent from my iPad On Mar 13, 2012, at 8:16 AM, airlion wrote: > > Hi all, on my newly installed 1/16 ply on one bay of my leading edge I noticed a > dimple about the size of a coffee can. Is there a way to get that out? I wonder > if wetting it down and putting an iron to it will work. Gardiner > > > > > ________________________________________________________________________________
Subject: Corvair College 22
Date: Mar 13, 2012
CC 22 was a great success. Thanks to our Piet friends for attending. Thanks especially to Tim Willis, Gary Boothe and Mark Chouinard for their extra efforts. Lots of pics on Facebook: https://www.facebook.com/#!/pages/Corvair-College-22/320305497999282?sk=wall In the attached photo: Mark Chouinard, Bill & David Roach, Kevin & Shelley, John Franklin (congrats on your first engine run, John!), Gary Boothe, Robert Caldwell, Buddy Linder -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368354#368354 Attachments: http://forums.matronics.com//files/piet_people_cc22_156.jpg ________________________________________________________________________________
Subject: Re: Corvair College 22
Date: Mar 13, 2012
Had a great time and learned a lot. Question... is that big guy on the far left building a Pietenpol? -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368363#368363 ________________________________________________________________________________
Date: Mar 13, 2012
Subject: Re: dimple
Jack, my dimples are concave and the water treatment did not work. So I scruffed the area up and smothed it out with liteweight body filler. It will be covered with fabric so I hope this works. Gardiner ----- Original Message ---- From: "Jack(at)textors.com" <jack(at)textors.com> Sent: Tue, March 13, 2012 9:40:14 AM Subject: Re: Pietenpol-List: dimple Gardiner, I have them also and hoping the fabric will pull them down when shrunk. Jack Textor Sent from my iPad On Mar 13, 2012, at 8:16 AM, airlion wrote: > > Hi all, on my newly installed 1/16 ply on one bay of my leading edge I noticed >a > > dimple about the size of a coffee can. Is there a way to get that out? I wonder > > if wetting it down and putting an iron to it will work. Gardiner > > > > > ________________________________________________________________________________
From: "Creative Eagles Corp" <info@creative-eagles.com>
Subject: First Composite Pedal Kitplane
Date: Mar 13, 2012
Good day everyone! I thought that I mention here that the First Composite Pedal Kitplane is now available! The first model they called GOTCHA! Gotcha3.jpg Gotcha Composite Pedal Kitplane turns your kids tricycle into something wonderful and exciting rides. The Gotcha composite pedal kitplane is a bolt-in project into your kids existing tricycle. The kit consist of the fuselage, the propeller, seat back, wings, horizontal stabilizer and hardwares. Build your Gotcha now and enjoy watching your young pilots as they fly around the neighborhood. Their smile will touch your heart! Their website www.creative-eagles.com or contact at info@creative-eagles.com Gotcha Pedal Plane.JPG Unleash your young eagles and let them enjoy the power of flight. Enjoy! ________________________________________________________________________________
Subject: Continental C85-12 0-SMOH "For Sale"
Date: Mar 13, 2012
Group, This showed up on our local KSL.com classifieds under Aviation so I thought I would pass it along. I do not have any affiliation with listed engine or seller. http://www.ksl.com/index.php?nid=218&ad=19569820&cat=151&lpid=&se arch Brian SLC-UT ________________________________________________________________________________
Subject: Wire Wheels
Date: Mar 13, 2012
The long and the short...I started a business 8 years ago and when I did, it pretty much stopped the Piet project. The business has finally setteled down a little and I'm now able to get back to building. I've owned and flown a Cessna 170 for years and now I think it's time to move up, so it's back to work on the Pietenpol I'm getting ready to build the straight axle gear and I'm looking for a good option for 21" wire wheels. I've spent a lot of time looking through the posts and I'm not crazy about making my own wheels. The 21" Harley spoke wheels sound like something I'd be interested in and if anyone who has them would be willing to share some information, it would really be appreciated. (Or if anyone could offer a better option, I'm all ears). Information such as: Where you got them What kind of cost am I looking at What did you do for breaks What size axle did you use Are you glad you used them What tires did you use Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368399#368399 ________________________________________________________________________________
Date: Mar 13, 2012
Subject: Re: Wire Wheels
Here's what I did (well, the wheels/brakes part).... http://mykitplane.com/Planes/PeoplesFiles/wheels.doc Hope that helps. It was a while back so the prices have probably changed.... -----Original Message----- >From: indyaquanaut <dave(at)granitebydesign.us> >Sent: Mar 13, 2012 3:46 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Wire Wheels > > >The long and the short...I started a business 8 years ago and when I did, it pretty much stopped the Piet project. The business has finally setteled down >a little and I'm now able to get back to building. I've owned and flown a Cessna 170 for years and now I think it's time to move up, so it's back to work on the Pietenpol > >I'm getting ready to build the straight axle gear and I'm looking for a good option for 21" wire wheels. I've spent a lot of time looking through the posts and I'm not crazy about making my own wheels. The 21" Harley spoke wheels sound like something I'd be interested in and if anyone who has them would be willing to share some information, it would really be appreciated. (Or if anyone could offer a better option, I'm all ears). > >Information such as: >Where you got them >What kind of cost am I looking at >What did you do for breaks >What size axle did you use >Are you glad you used them >What tires did you use > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=368399#368399 > > ________________________________________________________________________________
Date: Mar 13, 2012
Oops, that link should have been: http://mykitplane.com/Planes/filesList2.cfm?AlbumID=67 -----Original Message----- >From: Jim Markle <jim_markle(at)mindspring.com> >Sent: Mar 13, 2012 4:17 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Wire Wheels > >Here's what I did (well, the wheels/brakes part).... > >http://mykitplane.com/Planes/PeoplesFiles/wheels.doc > >Hope that helps. It was a while back so the prices have probably changed.... > > >-----Original Message----- >>From: indyaquanaut <dave(at)granitebydesign.us> >>Sent: Mar 13, 2012 3:46 PM >>To: pietenpol-list(at)matronics.com >>Subject: Pietenpol-List: Wire Wheels >> >> >>The long and the short...I started a business 8 years ago and when I did, it pretty much stopped the Piet project. The business has finally setteled down >>a little and I'm now able to get back to building. I've owned and flown a Cessna 170 for years and now I think it's time to move up, so it's back to work on the Pietenpol >> >>I'm getting ready to build the straight axle gear and I'm looking for a good option for 21" wire wheels. I've spent a lot of time looking through the posts and I'm not crazy about making my own wheels. The 21" Harley spoke wheels sound like something I'd be interested in and if anyone who has them would be willing to share some information, it would really be appreciated. (Or if anyone could offer a better option, I'm all ears). >> >>Information such as: >>Where you got them >>What kind of cost am I looking at >>What did you do for breaks >>What size axle did you use >>Are you glad you used them >>What tires did you use >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=368399#368399 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 13, 2012
Where you got them - Paughco, Inc.; www.paughco.com; 21" Harley Sportster. Ask for "Troy" and tell him you want the same wheels that he supplied to Gary Boothe for his airplane. What kind of cost am I looking at - I got a special price...so not sure...you can call. What did you do for breaks - go cart What size axle did you use - 1 1/2" stepped down to 1". Paughco puts 1" bearings in all their wheels. Are you glad you used them - OH YEAH!!! I am told that I need to pack stick to beat the ladies back... What tires did you use - Whatever Paughco installed. Dave - you can see most of what I have done on www.westcoastpiet.com. Let me know if you want any answers... Gary from Cool -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of indyaquanaut Sent: Tuesday, March 13, 2012 1:46 PM Subject: Pietenpol-List: Wire Wheels The long and the short...I started a business 8 years ago and when I did, it pretty much stopped the Piet project. The business has finally setteled down a little and I'm now able to get back to building. I've owned and flown a Cessna 170 for years and now I think it's time to move up, so it's back to work on the Pietenpol I'm getting ready to build the straight axle gear and I'm looking for a good option for 21" wire wheels. I've spent a lot of time looking through the posts and I'm not crazy about making my own wheels. The 21" Harley spoke wheels sound like something I'd be interested in and if anyone who has them would be willing to share some information, it would really be appreciated. (Or if anyone could offer a better option, I'm all ears). Information such as: Where you got them What kind of cost am I looking at What did you do for breaks What size axle did you use Are you glad you used them What tires did you use Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368399#368399 ________________________________________________________________________________
Date: Mar 13, 2012
Here's a different option. http://www.airdromeaeroplanes.com/heavydutywheels.html However, I think they're only 19" rims, not 21". The hubs come fully fabricated, and I think you need to assemble the wheels, but the price seems pretty reasonable. I believe a few builders have used these wheels. If any of those guys are reading this thread they might be able to shine a little light on the product and the service. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368420#368420 ________________________________________________________________________________
Subject: Brodhead plans
Date: Mar 13, 2012
Greetings all, I am planning to attend the fly-in this summer. I will be flying by airline from Corvallis, Oregon. I would appreciate any advise some of you might have regarding flights, car rental etc. I would like to camp while there and was thinking it would be handy if I could UPS a small box of camping gear to someone at Brodhead. Thanks in advance and I look forward to meeting some of you there. Mark Baxter Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368421#368421 ________________________________________________________________________________
Date: Mar 13, 2012
Got mine from "Airdromes & Airplanes " in Missouri. He does wheels and WW1 replicas. I had left over Grove brakes from a unfinished float project. The drums bolt on to the hubs, not the spokes. He took pity on me and threaded the spokes for me. I understand that is a chore. I took them to a local motorcycle shop for the tires. Not cheep ... 8 bills- plus. Dave- Inverness, Fl- N1QZ-- --- On Tue, 3/13/12, indyaquanaut wrote: From: indyaquanaut <dave(at)granitebydesign.us> Subject: Pietenpol-List: Wire Wheels Date: Tuesday, March 13, 2012, 8:46 PM us> The long and the short...I started a business 8 years ago and when I did, i t pretty much stopped the Piet project. The business has finally setteled d own a little and I'm now able to get back to building.- I've owned and flown a Cessna 170 for years and now I think it's time to move up, so it's back t o work on the Pietenpol I'm getting ready to build the straight axle gear and I'm looking for a goo d option for 21" wire wheels. I've spent a lot of time looking through the posts and I'm not crazy about making my own wheels. The 21" Harley spoke wh eels sound like something I'd be interested in and if anyone who has them w ould be willing to share some information, it would really be appreciated. - (Or if anyone could offer a better option, I'm all ears). Information such as: Where you got them What kind of cost am I looking at What did you do for breaks What size axle did you use Are you glad you used them What tires did you use Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368399#368399 le, List Admin. ________________________________________________________________________________
Subject: You Tube link to Douwe's C-90 First Run-up in Airframe
Date: Mar 13, 2012
Hey all, Due to overwhelming demand... http://www.youtube.com/watch?v=zlQXwjuoVKA&feature=youtube_gdata_player If that link doesn't get you there, just search for "Douwe's C-90 first run-up in airframe", and that outta do it. Working away now on lots of persnickety stuff. Douwe ________________________________________________________________________________
Date: Mar 13, 2012
This is a copy of a message that I posted in a related thread last year on Feb. 2: "One word of warning about Robert Baslee and Airdrome Aeroplanes. I bought my wheels from him, but he never delivered on the tubes and tires. I emailed, called, emailed, called. At first, he told me they would be coming in a separate shipment, then after repeated efforts to get him to send them, he quit responding all together.I'll say this, the hubs and wheels look beautiful. But the hubs are not straight enough to just bolt brakes to, even though he indicated they would be. The cost of coming up with an option to fix that isn't trivial. Worse, I'm not sure, and won't be until the aircraft is moving, whether my solution solves that problem. And I ended up buying tubes and tires from a motorcycle website and having a local motorcycle shop mount them for me.That added to the cost even more. If I had the option to replay history, I wouldn't have dealt with Baslee. Your mileage might differ and I'm sure others have had good experiences with him, but that was my experience." Hopefully, Baslee has improved on his customer service by now. Cheers, Ken On Tue, Mar 13, 2012 at 6:04 PM, Bill Church wrote: > > Here's a different option. > > http://www.airdromeaeroplanes.com/heavydutywheels.html > > However, I think they're only 19" rims, not 21". > The hubs come fully fabricated, and I think you need to assemble the wheels, but the price seems pretty reasonable. I believe a few builders have used these wheels. If any of those guys are reading this thread they might be able to shine a little light on the product and the service. > > Bill C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=368420#368420 > > ________________________________________________________________________________
Date: Mar 14, 2012
Yep. It's all mine. Actually though, I thought I had put up the presently attached pic which shows the "anti windup" bracket and arm. Next up, the heel pedal system. No wonder it's been 11 years and counting!! Clif Life is uncertain. Eat dessert first. > Clif the brake is impressive. Is it your own design? Does it warp there at > the cable to actuate? I have more questions than answers! > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 ________________________________________________________________________________
Date: Mar 14, 2012
I purchased the hubs from Ken Perkins and the 21" rims and stainless spokes from Buchanans. You will need to sell your first born to pay for them but dam they are sexy! Have a look at them on my site. www.scottyspietenpol.com Scotty -------- Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Rudder, Vert stab, Elevators, Hor Stab and Ribs built...About to start fuselage...Corvair engine at Roy's Garage waiting to be modified. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368446#368446 ________________________________________________________________________________
Date: Mar 14, 2012
Very cool, Douwe. Can't wait to see her fly! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Tuesday, March 13, 2012 10:31 PM Subject: Pietenpol-List: You Tube link to Douwe's C-90 First Run-up in Airframe Hey all, Due to overwhelming demand... http://www.youtube.com/watch?v=zlQXwjuoVKA&feature=youtube_gdata_player If that link doesn't get you there, just search for "Douwe's C-90 first run-up in airframe", and that outta do it. Working away now on lots of persnickety stuff. Douwe ________________________________________________________________________________
Date: Mar 14, 2012
Mark, The closest airport to fly into is probably Madison (MSN), which is about 35 miles away. I know American serves MSN and I think Delta does as well. Or you could fly into Chicago or Milwaukee, but they are further. Shipping camping gear is a good idea, if you can find someone in Brodhead who would volunteer to handle it for you. Perhaps you can contact someone in EAA chapter 431, that runs the field there. Good luck and hope to see you there, Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Baxter Sent: Tuesday, March 13, 2012 8:10 PM Subject: Pietenpol-List: Brodhead plans Greetings all, I am planning to attend the fly-in this summer. I will be flying by airline from Corvallis, Oregon. I would appreciate any advise some of you might have regarding flights, car rental etc. I would like to camp while there and was thinking it would be handy if I could UPS a small box of camping gear to someone at Brodhead. Thanks in advance and I look forward to meeting some of you there. Mark Baxter Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368421#368421 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Mar 14, 2012
Subject: Enid, OK fly-in
Flyin at WDG, Enid, OK Saturday 24 March, 2012 Barnstormers is serving breakfast! 8-10am $7.00 .50 cent discount on fuel. Hope y'all can come. Steve D ________________________________________________________________________________
Date: Mar 14, 2012
Where you got them: Aerodrome Aircraft (www.airdromeaeroplanes.com). What kind of cost am I looking at: ~$900. What did you do for brakes: Motorcycle disks, go-cart parts from calipers up to foot pedals. What size axle did you use: 1.25" I think? Are you glad you used them: Yes. What tires did you use: Ones that fit. Ken's right that Robert at Airdrome can be unresponsive. I got my own tubes and tires before Robert sent me his versions. I like them better than what he sent so it worked out. Ken's also right that the hubs are not perfectly square. Somehow, though, they have rolled and stopped pretty darn well over 700 takeoffs and landings. They are also extremely durable. Look at www.westcoastpiet.com for ideas. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368475#368475 ________________________________________________________________________________
Date: Mar 14, 2012
I made my own hubs (well, I designed them and had a machine shop turn them for me), then sent them to Buchanan's, had them choose 21" aluminum rims, make custom spokes and then lace them up for me. Bought Avon Speedmaster Tyres (they're English, hence the spelling) on the advice of Mike Cuy. Total cost was about $900. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of kevinpurtee Sent: Wednesday, March 14, 2012 10:37 AM Subject: Pietenpol-List: Re: Wire Wheels Where you got them: Aerodrome Aircraft (www.airdromeaeroplanes.com). What kind of cost am I looking at: ~$900. What did you do for brakes: Motorcycle disks, go-cart parts from calipers up to foot pedals. What size axle did you use: 1.25" I think? Are you glad you used them: Yes. What tires did you use: Ones that fit. Ken's right that Robert at Airdrome can be unresponsive. I got my own tubes and tires before Robert sent me his versions. I like them better than what he sent so it worked out. Ken's also right that the hubs are not perfectly square. Somehow, though, they have rolled and stopped pretty darn well over 700 takeoffs and landings. They are also extremely durable. Look at www.westcoastpiet.com for ideas. -------- Kevin "Axel" Purtee NX899KP Austin/Georgetown, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368475#368475 ________________________________________________________________________________
Date: Mar 14, 2012
I believe your biggest hurdle will be the hubs.- Rims, spokes, tires, etc are readily available in a variety of materials, sizes, colors, etc. You s aid you were not too keen on making your own wheels, but if you change your mind, you have some options, most of which have been posted. I made my own hubs and did my own lacing/truing. If you are interested in g iving any of that a shot, I may be able to help you. Michael Perez =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Mar 14, 2012
Clif, Top-notch construction. Beautifully made. But... how do they work? That's a solid piece of metal between those 2 lever arms - there's not any hinge point to press the pad to the disk that I can see... Thanks, Dan On 03/14/2012 02:30 AM, Clif Dawson wrote: > Yep. It's all mine. Actually though, I thought I had > put up the presently attached pic which shows > the "anti windup" bracket and arm. > > Next up, the heel pedal system. > > No wonder it's been 11 years and counting!! > > Clif > > Life is uncertain. Eat dessert first. > >> Clif the brake is impressive. Is it your own design? Does it warp >> there at the cable to actuate? I have more questions than answers! >> Jerry Dotson >> 59 Daniel Johnson Rd >> Baker, FL 32531 -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: Wooden wing spars
Date: Mar 14, 2012
A few years ago I saw an article on wooden wing spars. I think it was by R on Alexander...but then again I'm not the sharpest knife in the set, so it could have been someone else. Please help me find this piece. Thanks. Ron ________________________________________________________________________________
Subject: Re: Wooden wing spars
Date: Mar 14, 2012
Ron, Not sure what type of info you're looking for, but there were a series of articles by Ron Alexander on wood aircraft construction, Sport Aviation, Dec. '98-April '99. That's what I found with a quick search thru the online SA archives. There were also some earlier articles on structural analysis by, I think, Molt Taylor. Those were from the 60's if my memory's correct. Ken On Mar 14, 2012, at 8:58 AM, Ron Eisaman wrote: > A few years ago I saw an article on wooden wing spars. I think it was by Ron Alexander...but then again I'm not the sharpest knife in the set, so it could have been someone else. Please help me find this piece. Thanks. > Ron > > > > ________________________________________________________________________________
Subject: Re: Enid, OK fly-in
Date: Mar 14, 2012
Chapter 10 pancakes and a Gas Welding Workshop that same day, otherwise I'd think about it. Barnstormers throws down some good grub. Too many flying events... such a problem to have this early in the season. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368490#368490 ________________________________________________________________________________
Subject: Piet for sale in TX
Date: Mar 14, 2012
For anyone looking to get into a complete and flying Ford A-powered Piet, there is a nice one for sale in south Texas; a couple of pix attached. Now owned by Ron Hollmer, this airplane was originally built by Howard Henderson and was written up in the old BPA newsletter, here: http://www.grantmaclaren.com/444mh/index.html I have no affiliation with this airplane or its owner other than knowing them as "good people". I believe Ron keeps the airplane in Aransas Pass (Corpus Christi area). He is asking $12,000 for it, which I believe is a very good price. His phone number is (210) 401-7148 and you can email he or Pat at pestfromfl(at)tampabay.rr.com . Please don't contact me about the airplane! As Schultz from "Hogan's Heroes" used to say, "I know NOTHING!" -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368491#368491 Attachments: http://forums.matronics.com//files/dscn1068_136.jpeg http://forums.matronics.com//files/061_61_858.jpeg http://forums.matronics.com//files/010_10_250.jpeg ________________________________________________________________________________
Date: Mar 14, 2012
Subject: Is there ANYTHING better...
than a package from Wicks Aircraft???? I say NOT!! :-) ________________________________________________________________________________
Date: Mar 14, 2012
First of all, thanks to everyone who has replied. Great information. Gary I contacted Paugho but Troy no longer works there and they have no record of your purchase, so without part numbers they couldnt help me. If you happen to have them it would really help. Michael, I can make the hubs and with a little guidance could lace and true them. Where did you get your rims and spokes and what did you do for your brakes. Again thanks to all, its very helpful Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368497#368497 ________________________________________________________________________________
Subject: Re: Piet for sale in TX
Date: Mar 14, 2012
Axel: maybe he will need someone to ferry the airplane to the new buyer ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368498#368498 ________________________________________________________________________________
Date: Mar 14, 2012
I was driveing south past the Georgetown airport heading to drop a load in Austin on Sunday, and look up and I swear I see a Piet crossing over I-35. Not easy to do when your suppossed to be driveing a semi and trying to see a small plane overhead. I was bobtail later that day and am still kicking myself for not heading to the airport to see if a piet was really circleing in the pattern. Any idea who it was? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368499#368499 ________________________________________________________________________________
Date: Mar 14, 2012
Subject: Re: Is there ANYTHING better...
The same thing, for free? -----Original Message----- >From: Jim Markle <jim_markle(at)mindspring.com> >Sent: Mar 14, 2012 1:07 PM >To: Pietenpol List >Subject: Pietenpol-List: Is there ANYTHING better... > >than a package from Wicks Aircraft???? I say NOT!! :-) > > ________________________________________________________________________________
Date: Mar 14, 2012
Dave, my 21" aluminum rims, aluminum nipples and stainless spokes came from Buchanan's. He, (I forget his name) is quite knowledgeable and understands what is required-for aircraft use and recommended the type of spokes to use. - What ended up happening was this: - I sent one of my hubs to Buchanan's. They made the custom spokes to fit the rim of my choice and loose-laced one rim to one hub. They sent that assemb ly along with the rim, nipples and spokes for the other hub. I just copied the lacing from the completed assembly.- Those spokes were nicely labeled and there were instructions included as to which set of spokes go where... it was a non-event really.- I then tightened and trued both wheel assembl ies. - I am using band type go-kart brakes. I want to stay as light as I can and I am really only interested in preventing the plane from rolling down hill-s ay into another plane or fuel pit. - See attached pictures. - If you want to discuss this further, please email me off list and I'll help as much as I can. Michael Perez Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Mar 14, 2012
Jim (M), congratulations. I wish I were to the same point of fabric covering. Soon, soon. Cheers, Ken On Wed, Mar 14, 2012 at 12:44 PM, Jim Ash wrote: > > The same thing, for free? > > -----Original Message----- >>From: Jim Markle <jim_markle(at)mindspring.com> >>Sent: Mar 14, 2012 1:07 PM >>To: Pietenpol List >>Subject: Pietenpol-List: Is there ANYTHING better... >> >>than a package from Wicks Aircraft???? I say NOT!! :-) >> >> >> > > ________________________________________________________________________________
Date: Mar 14, 2012
Thanks Ken (AND Jim!)... Actually, I'm barely at that point but I just need to see some progress...and the tail feathers and center section have just been sitting collecting dust for several years..I'm tired of seeing so many parts "just one step away from completion".... Plus, on a recent trip to Georgia I got to spend a couple evenings with Barry Davis and the rest of the "big Piet" folks...what a pleasure! Except the part where they brainwashed me (I still don't know how/when it happened) into ordering materials and coming home all motivated to get to work on my Piet! -----Original Message----- >From: Ken Bickers <bickers.ken(at)gmail.com> >Sent: Mar 14, 2012 3:46 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: Is there ANYTHING better... > > >Jim (M), congratulations. I wish I were to the same point of fabric >covering. Soon, soon. Cheers, Ken > >On Wed, Mar 14, 2012 at 12:44 PM, Jim Ash wrote: >> >> The same thing, for free? >> >> -----Original Message----- >>>From: Jim Markle <jim_markle(at)mindspring.com> >>>Sent: Mar 14, 2012 1:07 PM >>>To: Pietenpol List >>>Subject: Pietenpol-List: Is there ANYTHING better... >>> >>>than a package from Wicks Aircraft???? I say NOT!! :-) >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Spar weight
Date: Mar 14, 2012
Wow, that's a 41% increase in weight. What is the species of wood and what are the exact dimensions of these pieces? -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368526#368526 ________________________________________________________________________________
Date: Mar 14, 2012
Subject: Model A radiator....
Doing some cleaning and would like to say goodbye to an old Model A radiator I've had for several years. It got banged up during shipping and I'm not even sure if it's fixable. But I don't want to trash it..... So, it's available for the cost of shipping (from 74361). Let me know (offlist) if you're interested. Jim ________________________________________________________________________________
Date: Mar 14, 2012
Subject: Model A radiator available....
Subject: Wing wires and ribs
Date: Mar 14, 2012
Hello, I am finishing the first wing, and today I put 2 threads to see where the wires will go through in between the ribs. Look this photo (if you want ;o) ) https://picasaweb.google.com/lh/photo/EhUVMWzpvDw_ZNBZpDdRX9MTjNZETYmyPJy0liipFm0?feat=directlink and this one https://picasaweb.google.com/lh/photo/9eUA3QFSTDaK3zodEdH-cdMTjNZETYmyPJy0liipFm0?feat=directlink here are two or thre more photos: https://picasaweb.google.com/105721238882545681618/ConstruccionDeUnPietenpolAirCamper# I can move them a little far from the rib, but not to much adding something in the wire end support, but anyway I think the vibration can touch the rib. How far the wires pass?, I did something wrong?. regards. -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368552#368552 ________________________________________________________________________________
Date: Mar 14, 2012
I'm sure Ron would administer a test before permitting a pilot to ferry his airplane. You would have to know what to put in the radiator (radiator?!), how to say 'pocketa-pocketa-pocketa' real slowly, and be able to tell time with a sundial or hourglass. Corvair guys might have a hard time with those kinds of things ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368560#368560 ________________________________________________________________________________
Date: Mar 14, 2012
Dan, Thanks, The pivot, as per the drawing, is the two clevis pins at the bottom. The L arm rotates around the point of the L which lies above the center of the pads. As the top of the L is sucked in by the cable the two bolts that go through to the rear plate and pad pull that plate outwards. Thus the the pads are pulled toward each other onto the disc. There's less than 1/16" total clearance between the pads and disc ( 1/32" each side) .the back plate is 1/4" thick and doesn't flex at all. The main plate is 1/8" and flexes a tiny bit, hardly visible at all. I have to appologize as I forgot to reduce the rather large size of the drawing. I always scan and take pics at high rez then reduce them. This makes a huge difference when someone wants to enlarge them. They go a lot larger before becoming fuzzy than if you start small. Anyway, here it is again in more reasonable size. The pivot is the clevis on the left. Clif A mile of road will take you a mile, but a mile of runway will take you anywhere. > > Clif, > how do they work? > Thanks, > Dan ________________________________________________________________________________
Date: Mar 14, 2012
Mario No you did not do anything wrong. Ii is quite common for the cross wire to hit the rib upright. You can move the rib over a bit so it will clear. I didn't notice this until it was too late and I had to cut away the rib brace then add a reinforcement to the upright. Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of giacummo Sent: Wednesday, March 14, 2012 6:22 PM Subject: Pietenpol-List: Wing wires and ribs --> Hello, I am finishing the first wing, and today I put 2 threads to see where the wires will go through in between the ribs. Look this photo (if you want ;o) ) https://picasaweb.google.com/lh/photo/EhUVMWzpvDw_ZNBZpDdRX9MTjNZETYmyPJy0li ipFm0?feat=directlink and this one https://picasaweb.google.com/lh/photo/9eUA3QFSTDaK3zodEdH-cdMTjNZETYmyPJy0li ipFm0?feat=directlink here are two or thre more photos: https://picasaweb.google.com/105721238882545681618/ConstruccionDeUnPietenpol AirCamper# I can move them a little far from the rib, but not to much adding something in the wire end support, but anyway I think the vibration can touch the rib. How far the wires pass?, I did something wrong?. regards. -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368552#368552 ________________________________________________________________________________
Subject: Re: Model A radiator available....
From: "RickBright" <brightwellrichard(at)yahoo.com>
Date: Mar 15, 2012
Hello Jim, Sent you a PM, sounds like an excuse for me to get over there, Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368574#368574 ________________________________________________________________________________
Subject: Re: Wing wires and ribs
Date: Mar 15, 2012
Mario, Very nice. I had a few places with some interference also. I did a little s anding with a round file, and added some support on the opposite side of th e rib member by gluing on another stick of spruce. Anybody disagree with t his? PS Please remind me what country you are from? Dan Helsper Puryear, TN -----Original Message----- From: giacummo <mario.giacummo(at)gmail.com> Sent: Wed, Mar 14, 2012 8:24 pm Subject: Pietenpol-List: Wing wires and ribs Hello, I am finishing the first wing, and today I put 2 threads to see where the w ires ill go through in between the ribs. Look this photo (if you want ;o) ) ttps://picasaweb.google.com/lh/photo/EhUVMWzpvDw_ZNBZpDdRX9MTjNZETYmyPJy0li ipFm0?feat=directlink and this one https://picasaweb.google.com/lh/photo/9eUA3QFSTDaK3zodEdH-cdMTjNZETYmyPJy0l iipFm0?feat=directlink ere are two or thre more photos: https://picasaweb.google.com/1057212388825 45681618/ConstruccionDeUnPietenpolAirCamper# I can move them a little far from the rib, but not to much adding something in he wire end support, but anyway I think the vibration can touch the rib. How far the wires pass?, I did something wrong?. regards. -------- ario Giacummo ttp://vgmk1.blogspot.com ead this topic online here: http://forums.matronics.com/viewtopic.php?p=368552#368552 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Pietenpol Ski Flying
Date: Mar 15, 2012
I gave up on any hope of more snow this year...(not that I'm complaining!)...and pulled the skis off and put the wheels back on. But I did fly it once back in January with my daughter. Here is a quick video of it from my buddy and airport owner Stan. http://www.youtube.com/watch?v=YByVOzQbWvs Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368576#368576 ________________________________________________________________________________
Date: Mar 15, 2012
Reading your post makes me more calm. Thank you. Dan; from Uruguay... Ciudad de la costa. faaaar away ;o) -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368578#368578 ________________________________________________________________________________
Date: Mar 15, 2012
I did the same as Dan, and so far so good.... Ben On 3/15/2012 7:01 AM, helspersew(at)aol.com wrote: > Mario, > Very nice. I had a few places with some interference also. I did a > little sanding with a round file, and added some support on the > opposite side of the rib member by gluing on another stick of spruce. > Anybody disagree with this? > PS Please remind me what country you are from? > Dan Helsper > Puryear, TN > > > -----Original Message----- > From: giacummo <mario.giacummo(at)gmail.com> > To: pietenpol-list > Sent: Wed, Mar 14, 2012 8:24 pm > Subject: Pietenpol-List: Wing wires and ribs > > --> Pietenpol-List message posted by: "giacummo"> > > Hello, > > I am finishing the first wing, and today I put 2 threads to see where the wires > will go through in between the ribs. Look this photo (if you want ;o) ) > > > https://picasaweb.google.com/lh/photo/EhUVMWzpvDw_ZNBZpDdRX9MTjNZETYmyPJy0liipFm0?feat=directlink > > and this one > > https://picasaweb.google.com/lh/photo/9eUA3QFSTDaK3zodEdH-cdMTjNZETYmyPJy0liipFm0?feat=directlink > > > here are two or thre more photos:https://picasaweb.google.com/105721238882545681618/ConstruccionDeUnPietenpolAirCamper# > > I can move them a little far from the rib, but not to much adding something in > the wire end support, but anyway I think the vibration can touch the rib. > > How far the wires pass?, I did something wrong?. > > regards. > > -------- > Mario Giacummo > http://vgmk1.blogspot.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=368552#368552 > > > " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Subject: Re: You Tube link to Douwe's C-90 First Run-up in Airframe
Date: Mar 15, 2012
Great Douwe! Love the wheels! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368581#368581 ________________________________________________________________________________
Date: Mar 15, 2012
Mario I had a similar problem. It was not touching but was real close. I wrapped the stick and the cable with Scotch 130C which is a vulcanizing rubber electrical tape. The I wrapped the stick and the cable so it couldn't vibrate. Not real pretty but works . do not archive -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 now covering and painting 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368582#368582 ________________________________________________________________________________
Date: Mar 15, 2012
Jerry, yes it is, it came with the engine I bought, I do not assembled it yet but evrything looks very very nice. Jerry Dotson wrote: > Mario I had a similar problem. It was not touching but was real close. I wrapped the stick and the cable with Scotch 130C which is a vulcanizing rubber electrical tape. The I wrapped the stick and the cable so it couldn't vibrate. Not real pretty but works . > You project is very nice, beautiful. Is the propeller a Beech Roby? > > do not archive -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368584#368584 ________________________________________________________________________________
Subject: Re: Pietenpol Ski Flying
Date: Mar 15, 2012
Excellent footage Don!!!!! I can relate - was only able to get up twice myself due to lack of snow and warm temperatures. Took the skis off yesterday and put on the wheels, should be good to go this weekend off our grass strip, expecting temps in the 20 deg C range. Gotta like that virgin snow where no other machine has gone. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368585#368585 ________________________________________________________________________________
Date: Mar 15, 2012
80 plus years and no one has documented which sticks need to be moved during the rib building phase so there is no interference during wing assembly?????? "An ounce of prevention is worth a pound of cure." -- Benjamin Franklin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368588#368588 ________________________________________________________________________________
Date: Mar 15, 2012
I guess the short answer is, "NO." The practical answer is, "Once the offending uprights are filed and re-enforced, there is no interference." Every Piet is different, and identifying which sticks should be moved would be a waste of time. Furthermore, some builders prefer to anchor their ribs at set dimensions on the spar, while others let them float until the wires are placed. Sorry, I do not see your name on your post. It would also be nice to know at what stage you are in your project, where you are from, and, most importantly, "How will you handle this part of the construction?" Gary from Cool -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Piet2015 Sent: Thursday, March 15, 2012 5:53 AM Subject: Pietenpol-List: Re: Wing wires and ribs 80 plus years and no one has documented which sticks need to be moved during the rib building phase so there is no interference during wing assembly?????? "An ounce of prevention is worth a pound of cure." -- Benjamin Franklin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368588#368588 ________________________________________________________________________________
Date: Mar 15, 2012
Jim...........looks like you got a quart of cement. Look to buy 3 more. I bought a gallon and only had less than a pint left over. Your mileage may vary. You are getting to a fun part of the build.. at least it was for me. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 now covering and painting 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368596#368596 ________________________________________________________________________________
Date: Mar 15, 2012
gboothe5(at)comcast.net wrote: > I guess the short answer is, "NO." The practical answer is, "Once the offending uprights are filed and re-enforced, there is no interference." > Every Piet is different, and identifying which sticks should be moved would > be a waste of time. Furthermore, some builders prefer to anchor their ribs > at set dimensions on the spar, while others let them float until the wires > are placed. > > Gary from Cool > > -- The mantra here seems to be "build according to the plans". If so, this would indicate the ribs would be fixed at the locations shown on the plans. If the ribs are fixed at their proper location, figuring out what sticks to move wouldn't be a "waste of time", it would help countless future builders get it right without having to shift rib locations or remove and whittle sticks. A forum like this is in a position to help builders correct plans errors BEFORE construction begins. Instead, it seems every new Piet builder must make the same flawed build that everyone else did and then everyone here will tell them how to fix it AFTER the fact. Go through the archives here. Same questions over and over and over. Seems that building it wrong and then correcting it or rebuilding it is some kind of "Pietenpol right of passage". The thing one must do to be accepted into the "club". If someone post a question prior to some stage of building, they get the "build it according to the plans" or you are "over thinking this". You asked how am I going to solve the problem. Very easy with the modern tools we have available. I'm building a Riblett wing. When I designed my rib truss, I modeled it in 3D CAD and made sure there where no bracing wire to stick interference. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368606#368606 ________________________________________________________________________________
Date: Mar 15, 2012
Subject: Model A radiator has been "claimed"
We have a couple details to work out but for now, it's "off the market". thanks all.... ________________________________________________________________________________
Date: Mar 15, 2012
Ryan Mueller wrote: > Apparently you do not know how to search the Matronics archives, > > RM Obviously everyone posting above that had to move ribs and carve on sticks didn't know how to search the archives properly either. Instead of making a post that is of little practical help, why not tell us the search term or phrase that will lead us to the archived threads that will show us which sticks need moved on the full size rib drawing? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368608#368608 ________________________________________________________________________________
Subject: wondering
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Mar 15, 2012
Well I can't remember the status of the Mountain Piet.I know it was being rebuilt but cannot remember if it was finished how it is performing.anyway also thought I'd see if I could sign in from this computer I am switching over to.I'm going to a different email address so even if I get this posted I'm not sure how I'll be able to switch my email address in the sit. Raymond Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368623#368623 ________________________________________________________________________________
Date: Mar 15, 2012
Subject: Re: Model A radiator has been "claimed"
Congratulations Jim.=0A-=0AHans=0A =0A=0A________________________________ =0A From: Jim Markle <jim_markle(at)mindspring.com>=0ATo: Pietenpol List <piet enpol-list(at)matronics.com> =0ASent: Thursday, March 15, 2012 10:01 AM=0ASubj ect: Pietenpol-List: Model A radiator has been "claimed"=0A =0A--> Pietenp ol-List message posted by: Jim Markle =0A=0AWe h ave a couple details to work out but for now, it's "off the market".=0A=0At = ________________________________________________________________________________
Date: Mar 15, 2012
That would be great Kevin. I got to meet a bunch of the california guys last year when I was working out there. Its great to meet folks in person building or flying. I am in Austin usually on a weekly basis, one of our biggest customers right on tech drive. I will give a shout next time I am heading that way. Kelly Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368628#368628 ________________________________________________________________________________
Date: Mar 15, 2012
Dave, Apologies for the delay...I needed to return home and happily wade through all those receipts! My relationship with Paugcho is..."special"...so I'm not surprised that they did not find a receipt. Now that I look at it, I see that my name is nowhere. I am sorry, though, to hear that Troy is no longer there. Sign of the times, I guess. The exact description is: "WHEEL, 21X2.15-NARROW FXD-XL 2000-UP" There is also on the left margin, a Part Number which is only partially legible: ??6-731 There is also a line item that suggests that the retail price, as you see below, is $339.57, for both (in Dec.=9908). 000_1185.jpg Best wishes in your quest for the =98perfect=99 set up! Gary -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of indyaquanaut Sent: Wednesday, March 14, 2012 10:48 AM Subject: Pietenpol-List: Re: Wire Wheels First of all, thanks to everyone who has replied. Great information. Gary I contacted Paugho but Troy no longer works there and they have no record of your purchase, so without part numbers they couldn=C3=A2=82=AC=84=A2t help me. If you happen to have them it would really help. Michael, I can make the hubs and with a little guidance could lace and true them. Where did you get your rims and spokes and what did you do for your brakes. Again thanks to all, it=C3=A2=82=AC=84=A2s very helpful Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368497#368497 ________________________________________________________________________________
Date: Mar 15, 2012
The topic is closed, everybody go home. Thanks to all, be frendly, Best regards. Mario, el de aya abajo, que anda casi solo en esto de fabricar avionsitos. -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368648#368648 ________________________________________________________________________________
Date: Mar 15, 2012
I little sight here and I saw someone with the same problems like me... I have a lots of semi finished parts, vertical and horizontal tail pieces finished (or quasi finished) months ago, now in the covering process, finishing a wing (5 month) a beginin with the second on, the center section, in the same stata as 6 month ago, the fuselage.... ataching the iron plates, my father making and remaking some iron parts (landing gear is near the end, the engine mount waiting for soldering, remaking the upper front fusselage iron plates of the engine support) , and so on.. a lot of things are there.. but not finished yet.. what a job!!!!! regards mario -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368651#368651 ________________________________________________________________________________
Date: Mar 15, 2012
Hello, Today I am very ..... interested in everything I red... talking about the wheels, I am going to operate the airplane over grass fields, and eventualy those fields are rought; I ask you, is there any difference between thick and thin wheels?... thank you, mario -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368652#368652 ________________________________________________________________________________
Date: Mar 15, 2012
Mario, Big diameter wheels will roll over those rough fields a little easier. They are heavy, though. My wheels weigh close to 25lbs each! I would not want the rims to be any wider. I understand that the aluminum wheels from Baslee are considerably lighter...but more expensive. Not sure if that answers your question... Gary from Cool NX308MB
February 22, 2012 - March 15, 2012
Pietenpol-Archive.digest.vol-lb
