Pietenpol-Archive.digest.vol-lg
June 04, 2012 - June 21, 2012
      NX899KP
      Austin/San Marcos, TX
Subject: Re: Oops, I think
Date: Jun 04, 2012
John, I have to take my grandson to school. Stand by...I've been down this road... Gary ------Original Message------ From: John Francis Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Oops, I think Sent: Jun 4, 2012 7:01 AM I you can see in the attached picture, I have a problem. I have already glued/bolted my wing tips on without sliding the front aileron spar in place. I played around with this shorter scrap piece of wood to get some idea of how to overcome this without tearing anything apart. Would it be acceptable to make the spar in two pieces (laminated lengthwise) and glued into place after placing them in the rib? I would probably just cut the height of the spar 1/4 inch shorter and slide and glue a piece of 1/2 by 1/4 capstrip under it. Your thoughts. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374662#374662 Attachments: http://forums.matronics.com//files/dsc07573_145.jpg Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Date: Jun 04, 2012
I tried clicking on the attachment and there was a note that came up that said, "The webpage could not be shown." How about checking it and resend. C ----- Original Message ----- From: "John Francis" <Mrkringles(at)msn.com> Sent: Monday, June 04, 2012 10:01 AM Subject: Pietenpol-List: Oops, I think > > I you can see in the attached picture, I have a problem. I have already > glued/bolted my wing tips on without sliding the front aileron spar in > place. I played around with this shorter scrap piece of wood to get some > idea of how to overcome this without tearing anything apart. Would it be > acceptable to make the spar in two pieces (laminated lengthwise) and glued > into place after placing them in the rib? I would probably just cut the > height of the spar 1/4 inch shorter and slide and glue a piece of 1/2 by > 1/4 capstrip under it. Your thoughts. > > -------- > John Francis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=374662#374662 > > > Attachments: > > http://forums.matronics.com//files/dsc07573_145.jpg > > > ________________________________________________________________________________
Date: Jun 04, 2012
Perhaps a shorter (height) piece could be inserted and pushed snug to the top and clamped into place. The gap for the piano hinge could be established and the aileron cut loose. At that time the full size spar could be placed into place and glued in??? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374674#374674 ________________________________________________________________________________
Subject: Oops, I think
Date: Jun 04, 2012
John, I know the feeling well. With slumping of the shoulders, neck and head, and a sigh of resignation, one merely whispers, "F__k." Then it's off to fix-it mode... You may well find your own fix, but, placed in a very similar situation, I chose to carefully cut the glue joint at the trailing edge with thin back saw (and the mid spar). I then cut the wing tip bow at the rear spar, where it needs to be cut anyhow, ending up with a short piece of bow. Corrections can then be made, and the bow carefully replaced and glued. I used picture frame clamps. Aside from the fact that you just announced to practically the entire, world-wide Pietenpol building community (and dragged me along with you), no one will ever know!! Best of luck, Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of gboothe5(at)comcast.net Sent: Monday, June 04, 2012 7:17 AM Subject: Re: Pietenpol-List: Oops, I think John, I have to take my grandson to school. Stand by...I've been down this road... Gary ------Original Message------ From: John Francis Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Oops, I think Sent: Jun 4, 2012 7:01 AM --> I you can see in the attached picture, I have a problem. I have already glued/bolted my wing tips on without sliding the front aileron spar in place. I played around with this shorter scrap piece of wood to get some idea of how to overcome this without tearing anything apart. Would it be acceptable to make the spar in two pieces (laminated lengthwise) and glued into place after placing them in the rib? I would probably just cut the height of the spar 1/4 inch shorter and slide and glue a piece of 1/2 by 1/4 capstrip under it. Your thoughts. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374662#374662 Attachments: http://forums.matronics.com//files/dsc07573_145.jpg Sent on the SprintR Now Network from my BlackBerryR ________________________________________________________________________________
Subject: Westcoast Pietenpol flyin?
Date: Jun 04, 2012
Wow=2C what a pretty plane!!! If your Piet is anywhere near as nice as the Waiex you flew to Frazier lake it will be the best in the west. It was ni ce to visit with you saturday. I was hurting so bad with the back problem that I was not my normal self but still enjoyed having you there. Hope you come again next year=2C hopefully with the Piet=2C if not the Waiex is a g reat addition to any fly in. Vic > From: Raykrause(at)frontiernet.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Westcoast Pietenpol flyin? > Date: Fri=2C 1 Jun 2012 14:28:46 -0700 > .net> > > Plan to depart Colusa at around 8 AM ..... but in my Waiex. > > Thanks=2C > > Ray > ----- Original Message ----- > From: "Michael Groah" <dskogrover(at)yahoo.com> > To: > Sent: Friday=2C June 01=2C 2012 10:29 AM > Subject: Re: Pietenpol-List: Westcoast Pietenpol flyin? > > om> > > > > Yes. The west coast gathering is tomorrow. Are you going to make it? > > > > Mike Groah. > > > > Sent from my iPhone > > > > On Jun 1=2C 2012=2C at 10:07 AM=2C "Ray Krause" <Raykrause@frontiernet. net> > > wrote: > > > >> > >> > >> Dear group=2C > >> > >> Is it correct that the flyin at Fraiser Lake is tomorrow? I have heard > >> no mention about it lately. > >> > >> Thanks=2C > >> > >> Ray Krause > >> ----- Original Message ----- From: "Jim Markle" > >> > >> To: "Pietenpol List" > >> Sent: Friday=2C June 01=2C 2012 5:46 AM > >> Subject: Pietenpol-List: Fun Pietenpol video > >> > >> > >>> > >>> > >>> This is from the Pietenpol group on Facebook...for those of you NOT o n > >>> Facebook (and good for you!)....... > >>> > >>> http://www.youtube.com/watch?v=5OHxkjEn6IA&feature=colike > >>> > >>> If that link fails=2C search Youtube for: "Pietenpol gyroflyer582" > >>> > >>> Jim in Pryor > >>> NX1929J > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 04, 2012
Subject: Re: West Coast Pietenpol Gathering
Big dittos on my side too! Thanks to Charlie, Jody got her first ride in a Piet on Saturday, and she was still talking about it last night! That's not normal... This is what we call in sales "a buying signal". :-). She LOVED it, and is wanting me to "get on with it". So now I can remind her of that when I need money to keep building... Now, if I can get all of you west coast pieters to assemble in my barn to help out once a month for the next year, we might have one more Piet there next year too! (a guy can dream cant he?) I think many of us have been around other groups like this before, whether model airplane clubs, car clubs, etc., so we have a point of comparison. I have yet to meet any other group of loosely assembled folks that have the generosity, willingness to help others, and encouragement as this bunch of folks. Truly a unique atmosphere. I am not entirely sure how or why that is the case, but I am very glad I decided not to build an RV... Charlie again refused money for gas and food as my wife tried to foist it on him (through me in the old "put-it-in-the-palm-of-your-hand-when-you-shake-good-bye" trick). Could it be that building a plane from an era when people were not as busy, when neighbors helped neighbors (I hear Bernard kept gas in his tanks in case someone needed to fly somewhere in an emergency), when 24/7 news channels were not even dreamed about, could somehow bring out some of those same golden characteristics in it's builders like some kind of time warp? If it is, I hope it is the only warp I see in my Piet! Thanks again Charlie and Mike for organizing the event, and for all who contributed to a great day (again!) Mark and Jody Roberts Fresno Sent from my iPad NX308MB**** > > ** ** > > *From:* Darrel Jones [mailto:wd6bor(at)vom.com 'wd6bor(at)vom.com');>] > *Sent:* Sunday, June 03, 2012 9:28 PM > *To:* Michael Groah > *Cc:* ' Bob O' Hara' abohara(at)att.net 'abohara(at)att.net');>; ' Irwin Fust' ifust(at)digitalpath.net; > ' Mike Hardaway' papa.bike.mike(at)gmail.com 'papa.bike.mike(at)gmail.com');>; Chris Tracy; Chris Tracy; D.K. Philbin; > Gary Boothe; George Benson; Jim Markle; Jim Boyer; Jim Boyer; John Watson; > John Doig; john kerr; Jorge Lizarriga; Larry Jobe; Manuel Sparks; Mark > Roberts; Michael Weaver; Mike Bikle; Mike Bikle; Perry Shipman; Piet List; > Ray Krause; Scott De Bel; Scott Liefeld; Walt Bowe > *Subject:* Re: West Coast Pietenpol Gathering**** > > ** ** > > On 5/27/2012 8:15 AM, Michael Groah wrote: **** > > Ok, everyone... we're now less than a week away from our west coast > Pietenpol gathering.**** > > ** ** > > It's June 2nd at Frazier lake..... See the attached flyer for the > rest of the info....**** > > ** ** > > I'm looking forward to seeing you all there!**** > > ** ** > > Mike Groah**** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > I just wanted to thank Charlie and Cecilia Miller and their family for > hosting us at Frazier Lake this Saturday. It looks like Charlie burned > enough fuel hopping rides to make it a good way to Brodhead. I had been > meaning to get to Frazier Lake for about thirty years and am glad I finally > made the trip. It was great seeing the group and I want to thank Mike Groah > for sending the flier and reminders. I'm looking forward to my next return > visit. Now to get cracking on my Corvair engine so I can fly down there in > the Pfeifer. > > Darrel Jones > Pfeifer Sport N154JP > > Icing on the cake was seeing Charlie's beautiful Stinson. I knew he was a > great guy!**** > ________________________________________________________________________________
Subject: Re: Black and White Video on Drag
Date: Jun 04, 2012
That's it! Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374683#374683 ________________________________________________________________________________
Date: Jun 04, 2012
Hi Mike and all, Arlene and I really enjoyed being at Frazer Lake West Coast Piet Flyin (Mik e did fly in and Charlie did a lot of flying). It is always good to see others pictures and ask questions. Looking at all the real antiques was nice as well. Ray's airplane is certainly a beautiful machine as well; can't spell Wi.... (Sonex with a V tail). =C2- Congratulations to Charlie, Cecelia and Elsie and the helpers for the great BBQ. Now I have to get back tot he garage and put on the rocker arm covers ; and more. Thanks everyone, it was nice to see you all. Jim =C2- ________________________________________________________________________________
Subject: west coas Piet meet
Date: Jun 04, 2012
I my opinion the west coast Piet meet was a great success. We did not have a lot of Piet planes there but there was a large group of eager builders m aking great progress on their projects. I predict several more planes next year. Several are promised. Charlie Miller and his family went all out as usual to make it a roaring su ccess. He logged several hours of piet time giving rides to those who had not flown in a Piet. Great incentive to get ours done. Sadly my back was so bad I could not get into the plane that day and I missed out. Charlie and Mike Groah and their families made sure no one went away hungry . Charlie's wife and mom as well as Mandy and Linda Groah put out more tha n were could eat. The whole idea of the gathering is for fellowship=2C sharing ideas and toys . All of that was done. New friendships were made and old ones renewed. What a great bunch of folks. The Frazier Lake airport is a perfect place for the meet. There are many o pen hangers with amazing collector air craft on site=2C many more displayed on the grass field for open hanger day. The grass strip is perfect for us tail draggers and the 80 degree sunny days are just wonderful. The breeze was right down the strip. What more could one ask. If you are anywhere n ear next year you need to come to this event. We had people come from as f ar as southern Oregon. We are eager to come to next years event with our newly completed Piet. H ope to see you there. Vic Groah ________________________________________________________________________________
Date: Jun 04, 2012
Gary, I didnt quite follow your instructions but think you should know that I havent mounted my trailing edge yet. The least evasive (I should of stuck to brain surgery) I can see is to simply cut the wing tip bow where it is cut anyway and slide them in. Or remove the small solid panel from the center rib (marking beginning of aileron bay) and slide the spar in from the root side of the wing. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374687#374687 ________________________________________________________________________________
Date: Jun 04, 2012
That's even better yet! Yes, just cut the bow and carry on...for some reason, as Chuck said, the link did not work. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Francis Sent: Monday, June 04, 2012 10:43 AM Subject: Pietenpol-List: Re: Oops, I think --> Gary, I didnt quite follow your instructions but think you should know that I havent mounted my trailing edge yet. The least evasive (I should of stuck to brain surgery) I can see is to simply cut the wing tip bow where it is cut anyway and slide them in. Or remove the small solid panel from the center rib (marking beginning of aileron bay) and slide the spar in from the root side of the wing. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374687#374687 ________________________________________________________________________________
Subject: Re: Westcoast Pietenpol flyin?
Date: Jun 04, 2012
Vic, Thanks for the compliments on the Waiex. It was easy to build and a great pleasure as it was my first project after my 3rd retirement. It only took 14 months of mostly pure pleasure! Had a great trip down to Fraiser Lake and back, great flying conditions. I think you and Mike were co-hosts with Charlie for the fly in. You did a great job and I would like to contribute to the food fund (and other expenses), if it is possible. Would enjoy seeing your Piet someday, maybe next year at the fly in? I did not know about the back injury. Hope you recover completely, very soon! Thanks again, Ray Krause ----- Original Message ----- From: V Groah To: piet list Sent: Monday, June 04, 2012 9:46 AM Subject: RE: Pietenpol-List: Westcoast Pietenpol flyin? Wow, what a pretty plane!!! If your Piet is anywhere near as nice as the Waiex you flew to Frazier lake it will be the best in the west. It was nice to visit with you saturday. I was hurting so bad with the back problem that I was not my normal self but still enjoyed having you there. Hope you come again next year, hopefully with the Piet, if not the Waiex is a great addition to any fly in. Vic > From: Raykrause(at)frontiernet.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Westcoast Pietenpol flyin? > Date: Fri, 1 Jun 2012 14:28:46 -0700 > > > Plan to depart Colusa at around 8 AM ..... but in my Waiex. > > Thanks, > > Ray > ----- Original Message ----- > From: "Michael Groah" <dskogrover(at)yahoo.com> > To: > Sent: Friday, June 01, 2012 10:29 AM > Subject: Re: Pietenpol-List: Westcoast Pietenpol flyin? > > > > > > Yes. The west coast gathering is tomorrow. Are you going to make it? > > > > Mike Groah. > > > > Sent from my iPhone > > > > On Jun 1, 2012, at 10:07 AM, "Ray Krause" > > wrote: > > > >> > >> > >> Dear group, > >> > >> Is it correct that the flyin at Fraiser Lake is tomorrow? I have heard > >> no mention about it lately. > >> > >> Thanks, > >> > >> Ray Krause > >> ----- Original Message ----- From: "Jim Markle" > >> > >> To: "Pietenpol List" > >> Sent: Friday, June 01, 2012 5:46 AM > >> Subject: Pietenpol-List: Fun Pietenpol video > >> > >> > >>> > >>> > >>> This is from the Pietenpol group on Facebook...for those of you NOT on > >>> Facebook (and good for you!)....... > >>> > >>> http://www.youtube.com/watch?v=5OHxkjEn6IA&feature=colike > >>> > >>> If that link fails, search Youtube for: "Pietenpol gyroflyer582" > >>> > >>> Jim in Pryor > >>> NX1929J > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > >> > >> > > > > > > > > > > >=== > > > ________________________________________________________________________________
Date: Jun 04, 2012
Thanks, Charlie! The fly In was great this last Saturday. Thanks for hosting it! I really enjoyed seeing your Piet again and also Mike Madrid's. Both are beautiful and a great example of hard work and persistence. I know you did not build yours, Mike; but you do a great job maintaining it. It was great of you to fly it all the way from Lompoc..,... of course, that is not as far as going to Osh! Thanks for the great grub. I did not see a donation jug anywhere? Can we make a contribution to the food fund? I asked several people and nobody knew anything! Had a great trip home to Colusa. Let me know whenever anyone wants to get together, or fly somewhere together. I have foolishly planned a target date of next Summer to fly my Sky Scout! Thanks again for al the fun! Ray Krause Flying the Waiex and building the Sky Scout ----- Original Message ----- From: Darrel Jones To: Michael Groah Cc: &#39@z-mta04.roch.ny.frontiernet.net ; "Bob O'"@z-mta04.roch.ny.frontiernet.net ; Hara'(at)z-mta04.roch.ny.frontiernet.net ; abohara(at)att.net ; &#39@z-mta04.roch.ny.frontiernet.net ; "Irwin Fust'"(at)z-mta04.roch.ny.frontiernet.net ; ifust(at)digitalpath.net ; &#39@z-mta04.roch.ny.frontiernet.net ; "Mike Hardaway'"(at)z-mta04.roch.ny.frontiernet.net ; papa.bike.mike(at)gmail.com ; Chris Tracy ; Chris Tracy ; D.K. Philbin ; Gary Boothe ; George Benson ; Jim Markle ; Jim Boyer ; Jim Boyer ; John Watson ; John Doig ; john kerr ; Jorge Lizarriga ; Larry Jobe ; Manuel Sparks ; Mark Roberts ; Michael Weaver ; Mike Bikle ; Mike Bikle ; Perry Shipman ; Piet List ; Ray Krause ; Scott De Bel ; Scott Liefeld ; Walt Bowe Sent: Sunday, June 03, 2012 9:28 PM Subject: Re: West Coast Pietenpol Gathering On 5/27/2012 8:15 AM, Michael Groah wrote: Ok, everyone... we're now less than a week away from our west coast Pietenpol gathering. It's June 2nd at Frazier lake..... See the attached flyer for the rest of the info.... I'm looking forward to seeing you all there! Mike Groah I just wanted to thank Charlie and Cecilia Miller and their family for hosting us at Frazier Lake this Saturday. It looks like Charlie burned enough fuel hopping rides to make it a good way to Brodhead. I had been meaning to get to Frazier Lake for about thirty years and am glad I finally made the trip. It was great seeing the group and I want to thank Mike Groah for sending the flier and reminders. I'm looking forward to my next return visit. Now to get cracking on my Corvair engine so I can fly down there in the Pfeifer. Darrel Jones Pfeifer Sport N154JP Icing on the cake was seeing Charlie's beautiful Stinson. I knew he was a great guy! ________________________________________________________________________________
Subject: OK, gicving up ONE of my secrets. . . . .
Date: Jun 04, 2012
OK=2C as Brodhead is getting closer=2C and I am getting closer to finishing =2C I thought I would finally reveal one of my secrets. Since the "mean ma n" stole my paint scheme=2C I had to choose another. Here is what I have c hosen . . . . . /9j/4S/+RXhpZgAASUkqAAgAAAAFABoBBQABAAAASgAAABsBBQABAAAAUgAAACgBAwABAAAAAgAA ABMCAwABAAAAAQAAAGmHBAABAAAAWgAAAO4AAADoAwAAAQAAAOgDAAABAAAACAAAkAcABAAAADAy MjEBkQcABAAAAAECAwCGkgIALQAAAMAAAAAAoAcABAAAADAxMDABoAMAAQAAAAEAAAACoAQAAQAA AAEAAAADoAQAAQAAAAEAAAAGpAMAAQAAAAAAAAAAAAAASGFuZG1hZGUgU29mdHdhcmUsIEluYy4g SW1hZ2UgQWxjaGVteSB2MS4xMQoAAAYAAwEDAAEAAAAAAAYAGgEFAAEAAAA8AQAAGwEFAAEAAABE AQAAKAEDAAEAAAAAAAIAAQIEAAEAAABMAQAAAgIEAAEAAAAbKAAAAAAAAEgAAAABAAAASAAAAAEA AAD/2P/bAEMAAgEBAgEBAgIBAgICAgIDBQMDAwMDBgQEAwUHBgcHBwYGBgcICwkHCAoIBgYJDQkK CwsMDAwHCQ0ODQwOCwwMC//bAEMBAgICAwIDBQMDBQsIBggLCwsLCwsLCwsLCwsLCwsLCwsLCwsL CwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLC//AABEIAIMAoAMBIgACEQEDEQH/xAAfAAABBQEB AQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYT UWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZX WFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPE xcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAA AQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGh scEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlq c3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV 1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APqn/gs7/wAHEKf8Erfj3p3w28Jf DR/G+vXuhQ67Nd3Gr/YbW1SWeaJY9qxOzt+4Yn7oG5evNfHkP/B6zrvl4m/Z40tpDwCvjWQDP0+w f1ryT/g8j0yKz/4KP+Arq3BWW8+HFqJCP4tupaiB/P8AQV+kGjfsE/BO78H6TcXvwd+FcjyWkTOz +EdPZmJQZJJhyTnNAHxz/wARqviPBYfs76Vs7f8AFZS8fU/Yahuv+D1jxI8JFj+z7osUmOGfxhK4 H4CyH86+xYP2Avgfd37pP8GvhHHGOhbwhpo/9oVrp/wTW+AF4Qbj4PfCNs9/+ES07/4zQB8HX/8A wemfECSMjS/gf4PhbPBl1+5kA/ARLWRcf8HnvxfZz9k+EPw5Qdg95et/JxX6Gf8ADrz4AyAeV8G/ hIw9vCVh/wDGat2P/BKb4C3cwB+DXwlXPr4TsP8A4zQB+bdz/wAHm3xvcf6H8K/hWh/221B/5XAq lJ/weYftBZ/d/DX4OL9bbUj/AO3tfqHH/wAEjPgKzZT4NfCRxnnHhOw/+M0kP/BJD4AyTmKT4MfC beOoHhOwH/tGgD8tz/weXftEZH/FuvgxgHn/AELU+f8AyfpJ/wDg8r/aLaM/Z/h38FkfsWsNTYfl 9vH86/WC3/4I4/s+Sxhm+Dfwn5z/AMypY/8Axqq17/wR4/Z9VcwfBn4Utgfw+FbH/wCNfWgD8kNT /wCDxP8Aaivj/oXhT4J2WRj91omot+Pz6ieax5f+Du/9rCRyUtPhVGD2XQJ8D87o1+v1x/wR7/Z/ jiDJ8G/hTknGD4Vsj/7SrM1n/gkf8A9PiyPg58KS55wvhWx4H/fqgD8kG/4O6f2sn6RfC1fp4fm/ rc1FL/wdw/taODsPwyjyc5Xw9Jx+dwa/VqT/AIJP/AkEj/hT3wrQkD/mV7Ln8fKqKf8A4JNfBB1B Hwe+FueB/wAitZfn/qqAPygl/wCDtH9rqR8rf/D1Bj7q+HBj9Zart/wdi/tfGMKuteBFODz/AMI3 Hk/+P9q/WJ/+CT3wSiXn4QfCw/8AcrWOf/RVIf8Agk98EpF/d/CH4X/+ErY5/wDRVAH5HX3/AAdW ftj3jKbbxj4UtdvUReF7QhvrvVv0xVNv+Dpr9sxhIG+IPh/DrhceFtPBQ+oxF1+uR7V+tt7/AMEr Pg5C+bb4PfC0gHn/AIpSw5/8hVi6r/wTU+DtjK3/ABZz4XDjt4Tsf/jNAHxj/wAExP8AgrV+3P8A 8FFviT4j8OaP8fdC8PnQdM/tGS5u/AulXRYGQRhVSOCMDlhyT+Br9Af2Ffih+1Z4N/bg8K+Gf2xv jnoXxH8G+JoL63jsYvB9no9yLuK2lnXDQRqwCrC5PzEdBjmvUv8Agm3+yN8NPhb4u8SXHgj4c+A9 EubizjjllsPD9pbO6iTO1mjjBIyAcHuKyNes/wCzv+CmnwTtrCSbyIfE2vjYHPlRIdE1EbBjjGQh 29sD0yAD8m/+Dya4Zv8AgpV4CiJ+RPhnZMB7nVdVB/8AQRX7D2Vs8Hw20eY8IbSLB6ZGwHivyL/4 PMtL8n9vj4ZX2B/pHw/SDPc+XqN63/tWv1/1+6Ww+D3h9IhkmxUYHPJUev0/SgDz6/8AEfk3JWP7 ufvDj8aksvEsiOXmY7B0HIOf61zV/qIWaUFdr5IwOg/Gq02svcXDBFKoTkZPXpxj2oA9Cs/Gq5Hl zSqR33cVo2/jR0kw00p9ADXmtrctkcNn0xiug0seamSAcjuaAPQtM8fSpKoWSXg9ciujsfGkrkyR ync2AeMmvNLA5dRk8Hmul01W2DZ1HPFAHVS+M58/6+Trnn6UL4tuXZVgmYlm2gDr9AKwQhZgQSee tSmD5CuB1z6mgDZn8XXeWCSnIHO5tuP8aw9b8eTMnzSsTnruP4cdKgu7d1jIVj83asbV9PkUfvd3 +z/jQBFqPjq6dSZZGwp6E8H8qhf4m3CYPn/jisrVbRVBY+cc5G4DjPWsO7iMbH5uBjqMUAdpH8U7 hSMSjnr27f8A6qW4+L1zD92RSM9c4/Hp16/nXnssjqSGzweh7VQvJ2Oeen+NAHoqfGK634Mo3H0N WJPHX9sQ7LoAO3IYd68miuiZOtbthqhEAwRkGgD6N/YpBbxnrxOMG0TH/fdcP4v0Zf8Ah4r8H57U xhV13W3fA6k6VfjA575B/A9unY/sN6mL3xXrSqMYso9xPc+Yf8a47VWjj/4KF/DEyLcF5de1eMbx lc/2XfEEHr0XGO2fTFAH5M/8Hnaj/hsb4SkdT4MlB4/6fpa/ULVvGsfi/wCBng/VdJtruK11LS4b iFpQgbY6hlJCsx5BB4z71+XX/B5y+79tL4TL2HgqQ/nfTf4V9NXX/BWT4LaL8CPCuieENQ17Vxom lQWUaxaXLESsUaoOZtgP3aAPXr+9VFPm/IemW4z69etNsrhJAGDHGcqR0r5F8Tf8FavBs13aJpGk eLFiDvLIPstvmVNjhRua4wp3GM8DgKRk5zWNP/wVo0VZAdP8H6nOzH/lpPGnb2Lc/nQB92WUnmz5 dicnJORW9p6blXbn/Gvz3T/grlfBD/ZHgKJTjAlm1tm/8c8g/wA6dZf8FcvGtwk/2DwtolsIJNm6 eWSUEkZAO3b26c9j1waAP0l06EqTkY2cn2rbsL5baVCCVAPLDqK/MRv+Cs3xQmiItLXwfbFiPmXT 5mYc+rTkfpSH/go18YNYt7maw1axtktYvNleDTUKxIXRATv3ADdIg57nFAH6qprIazVfMaMk8Kp7 e5z2+g6mpZL/AHBfNdiGOQMk/jX5Baj/AMFH/i07P/bfxBvIiF/1cNrZQsG5CjiHPXkjk4571d8F ftDfGX4xakINA8beKtQmkjnuIxaOwDGCCS4ZWSMDGVhJxtORnAbkEA/WbUphDCWfgY6np+tc5r/i i1WNpL67sbaPIOZJUAYnGOpxk9h71+aHhv8AZ3+Ofj+LzvHnijW7SylYug17XLhCox/zxVncHORh lBqt42/Yb1q8jUSeJdEupcFS0r3AAHP8aqSCeece/HWgD778WfH3wDotkj6j458KQScsFfVYVZvc LuycdPevLPFn7evwmsZpCfF1sUiwrmC1mmLt3KiOM5BNfnT40+GniH4OWLx+K7KUQwxxxNPkTxTF gRhJAMZOxjggEbe3y1yKa9FdM4tpInC5Q4X5lbA4OCOnHB70AfoT4l/4KZ/DTRs/2W2vasiEgfZr EqZPcCVkx24ODXA+Jv8AgqvpW3PhbwRrlyrcqLu5it/MH1Uvj9a+KJ9Z8yY+e+93JYknknPJP50+ PUJIyuJU6fKpcHAz0Aycc9qAPpXxJ/wVZ8TpI50LwPo9jtG5fN1N7nj3xEn6f/XrkdT/AOCrnxS1 C0na3g8IabFGM4hspdy++55jn8MV89eLtX3rujMiGPjBU559B7nt71hzg3OnSFEcsOSo+XGO/J5o A/WH/g3c/bQ+Jf7R37WHjvSfiprNpe6LbeGftdtbLZRQsjrdwpuyqhuRK3Unjrgnj7D1XXzqH/BQ P4T28jK5i8QawCSCrKRpWo4GOhOCehxx0r85/wDg1u3t+2b4/Z/kYeDnUc7s5vbbt+A796/QDS79 Lj/goX8M7eRAJ08SazPvBD7gNL1JWBb1BZPl7DHrkgH5d/8AB55YeX+158H7r/nt4QuIv++b1z/7 PX53aV8Yph4ds1XTZAoTYuJtu8Be3y8V+kv/AAeiWi/8NGfBKWMEyHw3qAf2UXUeD+bGvp34m/sf /DHT/gn4d/4V78NPhrYauuk2d9aTL4cs4xLcJh9szrFuMchCo/UlWYjBwaAPxFtPi7cS3o86yjSM ReWFaY5XPBJO327DvVy2+Jd00m2K0jK5+Qlzj+Vfqp4P8PeBn+O15N4e8J6Fb2N14Ssrh7VtJt0a 1kF3dpIGjVfllUjY6DkFCOSMHprPw/pWn/HvSprTStNS2fRNQZY4rWPC/vtPIfgc9Tx6E460AflD p/xMv2KbUsBxxu3f/FCvrX4Ffs56p8Sf2KdZ8V6fZQ3Go3/iuxtrWT7UIFRBBOin52CMryu8QBO4 yeWAcE1+hvh9reDYbZIEV8bSqhVOehyK9O+BPgJE8ZeLtBupIzYpfiaRBFHvuQx3jcduRtfcwOcg uTk4GAD8obj9in4nRT6Os3hrUbT+0r1LWFXaJPOkZXZVbe/y52Hk46dQcV9Xfsl/8E/vFV94E+J3 h34mWA0PVdd0eK10wvNBOFdWedWYxuwCedb2wyfU45FezfG57pdN0WW50nU4rvRtRi1lrG9tHtpb yKONx5SLIAQ7bwACAMk8+vV+A/BF34+1bw34w+Pnw7u7Cxv7aTTmtdRi+1XOlxu8jRFyg3ASqoVg yq6sYgckvQB+NnxK8MS+F9Uk/wCEnSexmUnzFeM7lZWIK4xjOQRX1N/wROs4/FX7QOu6pf6pbaFp WlaPJaRXc0ygxXV3mOKQ7yEchVnOz256V1//AAVQ/wCCa2qfD3x5qnjvwVpq23wy1a7jmJjRom0e aXG+KSJlDIjSlthA2DcqcHG6f/gnj+x74G+KvwyfVPiTqUvgV7LVFiN2uq28TarHI3+tSKdcIsf3 AUB567skKAYPxz/bL8R/DHxhqfhzxFoVraappNzLa3Je7cW0hVsB42aMBo3GHVm2gqwOTmvKx+1D 4j8XX1jOs8FpayTSx30Fppry3FoA0flOWeVUKS7pQrA5/d98jP2N/wAFF/2B/D2j/D7QfFP7MGhX PiLQNP08w+IL60uo7lGMCRxJcHY+9XZY5PNKKEXarfKd1fA/w++HGpS+II4PhVHqFzqUMMss8caM U8kKC5mA+UJt2hmY7emTk8gH1V8M/wBmfWf2jf2M77+0fF1vc6h4m1TSZr+VNNEv2K0ELyLEsS7S xS4nCs+5Bjfk4QBuE+Gn/BKK2v8AxL4qttW8aIYdE1EWRVNIx9qY28MxK7pz5eBMnI3YPUEMRX6F fsV/CTTPDui2llNdXpsPswNtZTQxiK4iliiZGjYJudUJkAZH24YhuQAvl2m+GfF3wg/aG8U6B8Xt FisofFGoz6toeoW5Jtr+BILeAqpLNiQJbxMyEgg7yQFKZAPnLTf+CWHhKFRB4k8SeJDcoORAsMO7 3XcjgjrV66/4J0/DTw5aq1zJ4nvyWCqs16heVuoVRHEmc4P0AJJABNfUfiiCBrZYpVaS4fPkopw+ R/ED2AyMnoOOuQDxUttPpLmTxPIk9w3yC5jQrHGpOdgUk7RwMn+LjPCgAA8TsP2C/hdG/ma94XN5 IcFEfU7vbCPT5ZQCT3OMdgMZz1Gm/sffCnR4glt4F0a4llB8uKRWlL4xn/WMcKMjJPHI7kA9rrF2 0Ugt9PHm3LDdtz8sSn+Jz2HBwOpwcdCRueEtLSyTfcyh57jCvLIQC57KOwAycKPXPJJJAO//AOCW vwZ8NfDD9qWW48C+HtB0O4vvCupLdHTbCO1WQLeabsUlFBfbuf5mycsegwB6vr2jx2//AAUC+F8t sLgt/aerlmkw2f8AiX3nAOOAN3APr361zv7AtsLf9pnMf3f+EZ1BfxN3p5/oa7i8nXW/25fhxcG2 8sW8+sIrkYJZbeVT/wChMe45oA/Iv/g8zuUuP2ovhBbvJtNt4RvZto/2rwKPz2n8vxr3TxF+3/4B uPA3hu1v31OxNlpkDRtcQqFcqu1guxznaGPy9eRgcV80/wDB5jqG/wDbs+F1qBjyfAYl3Z679Qu1 x/5D/WvGfEnwo8R3HgbRJLvRNSAW2O0NbPgDaDyfx/rQB7lpf7WXgbSP2mfE2v6XqN3LptxoELbf sz+XFcfam37QB8gcyq5yMb2kJOW57KP9rzwRD8TtL1mLV2XTE0+5iuG+zSlYZJntWUDC9xA5I/2S Rz1+Hvh54b1Pw947nuNT0S+ntmiSK4gkhdTPFK0yyp067FyD1U7WHQV1d/4RuNAXVLSC0nlj+0Ws ysYivnRmOQqduDgEMDg9MYPNAH6HfBz9ojwZ8cPFdxofhpxrVtJY3NxNZzWzfZ7iNIXd9wPVSBgr jHzZPPFfUHx9tNY8E/BOHxB+zvoF5q2uR3kUU8kcU+qzWdkYZX8yG1cuJmEqQIIypXEhJKAGRPgf /gkX4OF78SvH15NZqkdl4Ov9kUpJC+Y8SsM4B6Eg47E+tfe/w2+I/ifwJq3gnRYLrTL/AP4Sq9Nr KiWjo1jHHAzvIoMx3BdrEjIOFPPOKANzxt4Z8UfGz9k3w9rPxQgOl+L/AA5q1lqE0KRNbMYRcquJ kZVZQ0DpLJGVXDAgquMD0XwbpniH46/s46ppul6qdF8QalYGKO8V2jaFy68bwGKblDIWAYrvJwSM Vua7aXPhnwt4ul17Uba4WfTiYQIPKRHdGjRSCxyS6Dkn+LHGKo+DvhrZeG/h9fppc99pkhsZBFN9 uuNsIA6qu/qAWI+npQB59o/wE1nwZ+y5488F/HKS3v4/EOlahcwW8V1JdQ2W22RSsbyAbP3gE6gD 5TIMfdJPLfCTwV4L8f8Aw7s3uPDeiXHiXQ7CHSsXcPmwxyWqzW8W6FspsAtoyQF6HpkV7v8ADTTI fGn7Pvhq88TA3d5rlh5VzcSSM8zxy7kwZWJYjaVPJ5wDXxl8ONH1fTv2UNd8UWd7q8Hi6exub/Nt dSO1m0TWySyoobayvuLgtu2q3ZtwoA92/Za8P/En4dDWIPjRPfCwie2XyLy6a5yR9pDzQSM7KIZP 9FAjTaFYMPLQcv8APn7HnwDT4N/tlfFHTtMMNnps+sS2lqpK7kskJnjjAYcq0bkZHJNuRwOv2/be CLDx14FsNWtUuYJ77Tra+iH2uaRQzgSMMO5BBB28g4znqBXyJ8FPCkPx21nx5rM8btNrc8wtJQoa e2Sa4aZfJLKcSCCeJA2P4V7dQD6G8b/s0+F/jto2mJ4Z1O58Lx6bI0sU/h6SGKOcO4MiSDayvkxp yMSKd2GAYhuY/ag+Dkdj+yLd+GfA011Jc/DG2t7vSZpJ3Fz5VpEiljIuG3GIuSVwCw6AcD0D9m/4 RW3w0+HTadcTWms6dBcyHTFltkJtYONsZcjLMSSWJ4yxwAOK37HS9JXxhqUKQQrb31nFBLEMGJlY yggJ0GcnOBg855oA/LH4d/tS+JfBdrfWPjS5g126eQNa3WofuJVj7RPKuQQBuIYjgtljyTXAfGH/ AIKC+MdC1a6sX8N2mlSJEEdJw0hUtkh1OcOrAggjII5BwRnV/aV8ID4cfFHVdH00yCztpy9u+Dkx Nyqg9GKj5S3IyDj2774EeD/Bv7TnwGbw38VdOjF/4akMUdy+2CaKGRiyOkmVJO4OuMkHyxkGgD4+ uv2yfHNmHisNVuYoriYSSlWAJbdu4444wOOwHpX0z+yx8NNd/aT+F+pfEn45eP5/Bvg7Rrn7JHN5 b3U91KCANkS45LyoqbVdnclFXpnzf43f8E3b/wAI+IrZ/CniC01Dw5PdLBJczqIptPjLYMkythSq jJLKfwr63uL/AEHwH8P9Gh+EsReP4ca3Y3l7aPazyW4s2sHtobmZoo2DrFJOs7MuWAt3bGRwAeq/ 8Ej/AAtrXhb9p/VrdPFg8b+EbXwzdW9jfT2E2m6jYT/arN2tb2znCywuEZGUuvzoQwOOF90hef8A 4bz8DRXxYCJ9YKK75OPI4xxyPmJB9DXmP/BOP4j6T8U/2y9dvPBesWmtTaX4SktNbuLW6S6hR2u7 c2dus6OyymNY71yQx2/aQeA4z6SZntP26fh6k1xLKHv9ZiWMEMId1nLJ17DEY49ce+QD8ZP+Dyq+ Vv8Agor8OrZfvxfDi2kPsH1TUgP/AEA18yfGnwd4+0jwFpuseBvEHiXV9HaMie2XUJvOsmVQSGUs Mhe4Ayp4I719A/8AB4jfNdf8FRfC0bnK23w306NfYHUdTb/2avI7v4z6ZdaBpt34h8Kata3Nr5aJ eS2sRyRkACTfnhgDx64wOKAPALf4ifFrTVUNJ8RYomUbNt9eogX1Hsa0bH9pn4o6Qc3fif4j2wU9 Trl6oH/j4r0zUvilbLIz/ZtVSFyGMzwMUbcQQSSTjOR9eOada/FmCHcq2upedJjaVtpM47k+uAR0 6UAekfsb/wDBU3xP8CvD3iiLUri98Qarrem3FhFNrd5cXTQxuE+WFi52NuXd8wwcDJFfsj8G/Ddr 8Z/DPw51V9SvdPuVmXV7SW0lUB22zqqurA5Qo+045+frjOfxH8M/Ee2upFkvYtROSGUvaykED0xk dP51+zX7BPjCTU/gD8KJ4hIbW+i+x5KlGieAMyjB7siy5B/u/hQB1P7Xum/EKLxdbXdjqcVn4F1C /wBKs5YQ6ySXDeehdPLIO0cM27IPAx1NfSPw5l/srwVZHOB5MYLLgCMll7emCOOfyrzj9p9DqnhL wvBJIqC48TWSktx822VlH1LKo/Gu/wDBmqR/8IJZyqflLY+7kMAxDKwOP7uD9KAMT9rn4cRaj+yV 4y0PwbAunGx0K4m0+O1HliKWCMzxBcdMyRIPxNeN/A/4YSXfwZ8J+Eddmlt5vEvhK90e/nVQZElu NPsZXYA8ZDAnnjj3r6W+JzA/DbVbaR3X7dbCwVs4JabEK89jmQV5hca9Y6D8V/Cgvbm2jjklnu4Z PNVY9racYsDtgtCP0oA6/wCE1jHoH7Pvhmx0+VwmmeH7W0jklbJIihRVLEYyflBJr5b/AOCUttqs vwH0u98bqz3t5e/MWREcCOUwRjaoxjbbRjAH8JPvX0B4K8VRXv7LdvfJNiNtEaRSOm1YzyPwArxT 9hH4heEfBXwd8PWV1rGj6dMzWtvb2v2pEkE0gubkxhCcmRo2MmOuHVuhoA+jfhHdRah4FMscZhgn 1G/aJSOiG5kC8fRc/XnvXwf/AMFoP2hviN+yf4j8K658F/EcmlWniC3ktJYY15hngYsXAPykOlwF wQceWT6EfaH7M3xH0nxh8CfDl5oOqadfvFZrb3TW9wkvk3ewPLE+DxIrFtynlTmvkT/g4D0ezH7O XhPXLmGKddP1hrcmSCORt00XUFlIHELdPwoA/Kf4j/8ABSj4na1rU9z4g1fS7m5myrPPoVhMcegL wEgcDv2HpXIN/wAFP/it4aunk8NeJrSwkaMQ5t9B06L5R/D8tvyAa8++IPiG3lmdLe2tginADW6M 35hea8vvx9vuiENlCB/FIoUfkBn9KAPoQ/8ABV742FgreOVK4KbW0XTiNp6jBt8dz+dUNO/4KI+P rCAt/anhyIRN5iiPwjo6YYdCMWnXpz7V5T4E8FaLdXzN4v1zSkhLYMccTZIKnlWKgAA4OOnqCOvU wfCTwF9gnn1HxIrJtUnDonJHY+WfpwPx4oA/VH/g2A/bZ8bftJfto/EPT/ilr0WpWdr4PM8KjSbK 1aNlvLdRh4IEbGHb5ScdCRwMfpN4HZNQ/bN8NTEOWivtTx833c29xyQB746/yr8s/wDg1G8I+D9J /bI+IsvhTV0u7weDzHIPNXay/bLbkDyk9MdjxyOa/U74KWE15+1ZbebAY49Ov7yZTt5IeGcA5HbE g5P95aAPw6/4O95hL/wVY00KxPl+AdMUj+7/AKVfHH6j868KuPgj4LGnW+7TIIpXfY5MkiHkE52o +MAv168d+BXtP/B3JcCf/grKqL1h8FaWh/7+XR/9mr4k1X9rbxNfaXDCYtNj2bRuETE8YAIyxA4A HGKAPUNU+FWgwlbWPSZlQy7VbzZQHAGVyC5yME8/mRiua8WfCy00aIy6Bo+q30EaZk8q+wVJYAKB sbPBHTPHvzXMwftU+IJoU86HS5ymAFaBjjBzx83Gec1qxftK65qd4zvaaRGrEEKY3bOAOBlxjgdP b6UARP4yi8I37W9/B4ltpo2HyS6typzxx5QyPev1f/4J+f8ABUX4e/Av9iX4aaP8Qdakt9Z07xDI bj7VbzsqW4vWeSUSJExciGcBVA+bDLuBXB/J3xL8WLHxZ5b+M9B06aSPKq9tK8MsfqEPzZ6dGyPz NYX/AAlNlcWssSW85ty2QrXREkQ9VYIFJwMcqaAP3W/bl/4LXfDi/wDCWkyfBO70rxJeaB4viu4I ba8kD3drFbh1unWSFTCPMkki8tstlN3RhXyhd/8ABdX4jeGPDDaXY2qxWeuaZHpn226urgXTtGz5 u4XRljS5cykSSBG3bU4BUE/m+njbT3UW1xZGSCORnVlvts5zjcDJswQdoIG0dOvXMv8AwkeiBFDW M0kEoDeWLoPMhDHgu8RGf4sqOhAzkEAA/T342f8ABwt45+L3gDVtMXRptAm1CewltptOvT5Nu1pL vdYyY9+JGCbiJCwKLggZU/Lfi/8A4KMfEG+0LTLNNdK2OgxMllZrZQpBaRty2wY6kkEgDP8AF2zX jfhj4reDb+0is/GXh/VZoLVWW28rVCjoCxZsttw3bHAxtHqa0vCXxT8C+HzeFvD2rRNeM6eZ9rjm eGItkKm8YU4IBYY6cdcUAe22P/BXP4lfDz4XR6D4X12GW3v9A/4Rq4im0iGJI7IK+yNcZRz/AKRO PM2h+mSRjHGaz+0z4u8PeAZJfh5488TTWUYRmjsJJbZLYohhVplRwFPlF0D7c7WwTg15w+t/DY3x kt7bxLdQlHU2935LhC2CpR0KbSuMdDwenq/w7ZeArDUp5v7Q8T3sYVhGl5BEEOQRtlWNssM9QGUE UAevfs+f8FTvih8JJrK60DxbfXdxpj3RsYdShjv0tzMo80oZgTGZDkEoVY8/NXq/xK/b/wDib+1p +zdaeAfGr6BZ2fhA2SaaUSeSZlRCivM8kr+Y21Cu4qW+Z+eefm3w/wCI9P0LT3sNI1r/AEOcs0lt d6KXjfcAG+5ICMjjqR14HWpvh7450nwTpzQ61qyTylVjE4t5AwUE9fkHOMeuCO/WgCDxP4X+IgWR LfV9Om8v5GXYMKOg6xZPGD6/lXA+IPAHjq4ljuLqTSpHmbhzboGH1Ji6cjj0PSvWNR+Jnhu/1DfZ 6mph/iRkkfvnBPln2xVGLxX4annFrcalb/Z/vFclEL4HJLdPc4zg9RgCgDzFfC/jmzaKWK68PM3A wyrhevVGjC4wfT+VN1Wx+Jdjo7efY6KYXbeMQWxLbtwBHH1H4elev6frfhkXy7b3S2lkyPmuVkAB 4AG4AKMeuenYVueLf7G0nQIFm1qxEg3LGItQhcPkg5UpL0wQD1XhuMcUAfWn/BqJp/jGz/bE+Ikm r6FpFvay+EDlooYVO/7dARllOTwW79q/X34Ca/cT/tJTWN7GIjEl62Hk3bv3ijcuCfQDkngYGAoB /NT/AINgJrRP2p/Hyx3ELyL4T28Txsx/0y3J3KozkFupPQgAYr9Efgwyt+2HavbRlFY6ihdR8soU kDOO/sRnjJ9SAfhB/wAHZ7h/+CuWogHJXwnpQPtxKf61+bhYmNFYLk9819+f8HRmr3Fx/wAFn/iX FfJIkNrpujW8DOnDodMtpCUPcb3YZ9QRX57reY5XZQBfUspPPTgc9K1NAg8ydBJPgSZAUnIJH14r DtNca2nR4lhJjYN8y7gec8gnBHsadca+stw720MMSlsqoJIT2GTQB1lyyRsoMqFgckL1ABx1J9un tVP+0N8TYeQI/LYxt/Hjiuc/t6VgMeSWAwW25JFJBr0tuSYmiGf9gH+dAHTWsKysrHeE6l2+Xjjr k/Xp6VZNg80fyPEyRDnD4z+Z6Z7gc1gw+MdRltNsaxyQo2f9VuAOMf5+g9KWPxjqEbg+RbMSSBut gc5x+f8AOgDYYeWqxwHJYHhHwRj2xxUPnSJGzPJII068AkjOPTFUbfxFq/2h2tLXLhcMFtidoB9O 1aWmP4x1SR20TS9UnN0pixBYPICCQ2FAU45A+7j8jQAlrqUs8ilQCuAQGyWJ/PP5Vr6Z4putJf8A f7S4PG8ZBH15GcU+w+DHxU1tgdK8C+Nbopgkw6DdSfTOIzWkP2RvjjeN5sXwm+Jzlzu3L4Uvzn8f KoApr8S3ZAq28hyB+825wR6gDBH4D+h3NB8b2WorGdUukt9zdHBCEeu4dMc+vXtioV/ZQ+PQVV/4 VP8AFMhBtGfCuodPf91zUtt+xn8fL+ZXtPgp8ULjAwVj8GagVc+pCw9f8KAN6z1XR7mVibxAnUCJ +E+91+Q5+px1qnr2r6IYy+nXEJ2FhskONwHG314BHPf045hX9g/9o+4uFa2+A/xi39QE8D6mf/aF XT/wTz/ag1M/u/2fvjhJk7sL4E1Vh+XkYoA47W/FMcds/wBmWUysRhQCueh9R6/muPpyWrXjXiF2 Z3VmywJOR6Fgc/n7V7Q3/BOb9qm9t0jf9nX44NtYnf8A8K/1UMc9ifs/Snj/AIJl/tVmQNL+zt8b ZCc/f8C6mSc9cnyc0AfbP/BpNLP/AMNtfEJrd2iRfBzBsAtkfbbfgcYHrX7Efs13p/4bNt7dYZQu zUHabb8rkcAE+vzN+Vfjd/wRC8E/Hz/gnv8AtC+LvEPxd+APxz0zTdb8PmxR7b4XapeM0n2mGQLh IAeiMRk4yPev2C/YB+IEPxt+OMmpS/Dn4w+Cr/SFuLuS78WeB7zQLO8WYsDHFJcBQzhnDbAvOM/w 8gH3Nd+FtN1No31Kxtrh4zuVpIwxU+oJ6Uz/AIQrSP8AoG2Xr/qV/wAKKKAAeDNJHTTbLn/pitKP CGlDGNPtBjp+6HFFFACN4M0l/v6dZnnPMQpf+EO0n/oHWfH/AEyFFFAEsGgWVnEY7S2iijY5KoNo P1AqT+xrXK/uE+Q5Xjp9KKKAH/2fCOin/vo0fYIj1U/99GiigBP7Mg/55j8zQdNgPVP1NFFAANOh GMJ09zSLp0IJ+T9TRRQA7+zof7n6mj+zof7n6miigA/s6H+5+po/s6H+5+poooAP7Oh/ufqaBp0O R8n6miigD//ZAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/2wBDAAYEBQYFBAYGBQYHBwYIChAK CgkJChQODwwQFxQYGBcUFhYaHSUfGhsjHBYWICwgIyYnKSopGR8tMC0oMCUoKSj/2wBDAQcHBwoI ChMKChMoGhYaKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCj/wAARCAIJAoADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QA tRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJ ipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx 8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcF BAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygp KjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJma oqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oA DAMBAAIRAxEAPwD6fZiCOnQdvajcfb8hSN94fQfyppIXG4gZOOT19qAH7j7fkKNx9vyFULjVbG3t pbi4uoYoYiRIztjbjrmudn+Jfgu3QNN4k05FxnJc9PXp7UAdjuPt+Qo3H2/IVzcfjjwo8ayDxLoo RgWUtexrkeuCc1YHivw7sVz4g0cI/Csb2LDfQ7uaANzcfb8hRuPt+QrHXxLoTFQut6Uxf7oF5Gc/ T5ueKjk8V+H45BG2t6Z5jHaqi6jJZs4IAzyR6dqANzcfb8hRuPt+QrBfxb4ejVmfXNMVVfYxN0gC nGcE54qJfG3hhnQDxDpJDjKuLuMqRx3z7/zoA6Pcfb8hRuPt+Qrn18ZeGGXcPEmiAdeb6L/4qhvG XhdThvEuhg4zg6hD/wDFUAdBuPt+Qo3H2/IVgx+L/DUrYi8R6I7dcLfxH/2amnxl4XBx/wAJNoWf +whD/wDFUAdBuPt+Qo3H2/IVzreNfCqg58TaFx/1EIv/AIqs1/ih4FSRYz4t0Xc3Axcg/rQB2m4+ 35Cjcfb8hXES/FXwHEPm8XaP+FwD/Kox8XPABAP/AAluk/8Af0/4UAd3uPt+Qo3H2/IV53L8aPh3 GOfFVieM/Ksjf+y1Rk+Pfw3jbafERJ9Usp2H57KAPUtx9vyFG4+35CvJpf2gvhwgYrrc8hHQLYzZ P0yoqvJ+0T8PEBK6hfvjsti/P50Aew7j7fkKNx9vyFeNH9o34f7Mi61PP937C2f501/2j/ACtgTa qw9RZHH86APZ9x9vyFG4+35CvFG/aU8BA4xrTfSzH/xVMP7S3gMbv3etnHTFovP/AI/QB7aGOO35 CgMfb8hXhbftN+CFyFs9dbHQ/Z0Gf/H6hf8Aaf8AByqSml64x9PLjH/s9AHve4+35Cjcfb8hXz8f 2o/CuzI0TWy2fu/uv57qZ/w1L4Z/6AOtf99Q/wDxVAH0JuPt+Qo3H2/IV88n9qXw0Omga0f+BRf/ ABVIf2pvDnbw9rP/AH3F/jQB9D7j7fkKNx9vyFfOh/an0Hdx4b1Xb7zRZpw/am8P8Z8O6uP+2sX+ NAH0TuPt+Qo3H2/IV84/8NT6N5a/8U3qW/HzDz48ZqSH9qbQT/rvDurKf9mWJv8ACgD6K3H2/IUb j7fkK+dG/an0HcAvhvVSvcmaIGnL+1N4fLEP4e1dR2KyxH+tAH0TuPt+Qo3H2/IV85N+1PoY+74c 1Q8d54hzVU/tV2QXjwldFve+UD/0CgD6X3H2/IUbj7fkK+Yj+1bFjjwc/wD4Mh/8bqpdftV3LE/Z PCUCf9db5m/kgoA+qNx9vyFG4+35Cvkp/wBqjXM/J4a0sfWaQ1WuP2pfE7svkaFo0ajqG81s/wDj woA+vtx9vyFJvPoPyFfHMn7UHjBs+Xpmhp9YpD/7PUDftOeODjFpoI/7dHP/ALUoA+ztx9B+Qo3H 0H5Cvi//AIab8df8+ug/+Aj/APxyk/4ab8df8+ug/wDgI/8A8coA+0dx9B+Qo3H0H5Cvi7/hpvx1 /wA+2gf+Aj//AByk/wCGmvHZH/HvoP8A4CP/APF0AfaW4+g/IUbj7fkK+Kz+0v48KFRHogJ6MLNs j/x+k/4aX8e9dui9v+XM/wDxdAH2oWPoPyFBY47fkK+K2/aX8elshNFUegsz/wDF0wftKePvLKk6 OSc/MbLkf+PYoA+2Nx9B+Qo3H0H5Cviab9pTx/JBsR9Iif8A56JZ5b9WI/Sov+GjviCIwv2nTM4x u+wrkn19M0Afb24+g/IUbz6D8hXw9/w0X8Q9gH2+wz6/YUyagl/aF+I7kbdZt48dlsYufrlaAPuf efb8hRv+n5CvhYftB/Ejfu/tuDGOn2GHH/oNO/4aD+I3fWLcnsfsUX+FAH3PvPoPyFG8+35Cvg2T 47/EZ7jzT4gwuMeULWIIfw21Zf8AaA+IrKM6zAHzkuLOIEj0IxjHfpmgD7q3n2/IUbj6D8q+DT8e fiPudv8AhIPvDGPssWF+ny8U24+O3xFnRlPiAxlhgtFbRI35haAPvTcfQf8AfIo3H0H/AHyK+BU+ N/xFSCSIeJrlg+PnaKMuuDng7eKgl+MvxCljKP4ovQpOTtRFz7ZC9PagD9Adzf3f/HaMt/d/8dr8 75vif46mdnfxZrILPvIS5ZBnGOAMAD2HFNi+JnjiI/J4t1vt968ZunTrQB+iWWxnb/47QCx/h/8A Ha/OsfErxut2Ln/hLNbMwOcm8cj/AL5zj9Kh/wCFheMjIjnxVrhZM4JvpCOQQeM47mgD9GS5HUAD rkqAKYLqI/8ALaH0+8tfnnafE7xpaIVt/Ed+oOCcspJwSR1HqTUF58Q/Ft3GY59fvSpznaQh568q Ae1AH6MfP/d/8dFHz/3f/Ha/Mh9U1BnZmv7ssxySZ3yT6nmpYdc1eFlMWqX8ZXoVuXGP1oA/TL5/ 7h/75o+f+7/47X5uweNvFVuCLfxNrkQbkhL+UZ/8eptz428UXSbbnxNrUqf3ZL+Vh/6FQB+knz/3 D/3zR8+Pu/8AjtfmUdW1FjltRvGJ7m4c/wBaVNW1KNw0eoXquDkETuCP1oA/TMsRjIx/wGhGJcdP yFfEfwD8c+K7j4o6Bps3iDU7qwuJWSe3nuWkVkCM3RicdO2PSvtqI5ZT60AK33h9B/KvAf2oviLr XhBdL03w5drZXN2rSTTAIz+WOgUEHAzkE/h617833h9B/Kvj79suVH+IOjookEiaYu4kDaQZHxg9 ++fwoA8Xv/EuuahceffaxqNxNwd8ly5PHTv2rKZmZy7MxZjkknJJ9SafboshKvIsZPQt0z7ntTWC bRtY7sfMCO/t+lAEZUHsPypdq+g/KiloATAx0H5UYHoPyop0ezP7zftx/DjP60AM2j0H5UbR6D8q cAueXI/CnoisQPNUZOMtkAe54oAi2j0H5UbR6D8qlMRy210fH91hzzjjOKYQR1oAbtHoPyo2j0H5 UuaM0AJtHoPypaWkzQAc0UZozQAYoozRmgAo5paSgApaKKACikozQAtFJRQAtFJRQAtFJmjNAC0U maM0ALRSZozQAtFFJQAtFFFABRRSUALRRQATnA6daACiiigAopKKAFopM0tABRRRQAUUUlAC0lFG aAFopKPxoAKKKWgApKWkoAWikzS0AFFJmigBaKSigBaKTNLQAUUmaM0ALSUUUAfRHwN8D6Hqngy3 1S80uzvNQmuJVWS6UyCMLwo2E7SOvUGvVJ/DGnSSwS3GnaPHbAhYQ9oig/knAwK5H9nJDL8NrdYW QP8AaJ1Y5GR82cH8K9QmeYIwYjyRhZBlSAOxIPr7elAHKT+DPC12rGTw5o5aQna4tFUZz94d8emf yrnfEfwy0Ce0Eeh+HdHgvJH8p57iSXEKd3VEPzN7Egc16JqFlIt3jTv9JilX5y52sq84bBPr3rOu bd3iaKLOTHhiR8+3J/8A1cZ7UAeZ+GdNg8IeI9Mlv5LSQWF/byJOliqyJHLJJD5Y2/MchgeAeR6D NfU8f3xXyr471NB4x06C1ciaCKxdlIJO5b+Pb+YJNfVg/wBcfrQAjfeH+6P5V8o/to2QXW/DV+qr l7eW3Ygc/KwYZP0b9a+rm+8PoP5V81ftpWyf2R4YuckSLcTR47YKKc/+OigD5XRtobjJIwPam5op D0oA+gdB+BGlal4d0rUJta1GKa8tYrhkWCMqpdQxA57Zq0/7Pek87fEOor7m0jP/ALNXrfgoZ8D+ HT/1Dbb/ANFrWuyg9M4oA8Ib9nzTe3iS+H1sUP8A7UpP+GfNOxn/AISe9/8AABP/AI5XuZQg/MCK TYOhH59qAPDG/Z80/HHie8z6HT0/+OU0/s+WCnH/AAk93nv/AKAv/wAcr3NwRkj0JzULLJ5jkGMx MBjjkcdvx/yKAPED+z7ZBgB4ouR9dPX/AOOUn/DPtuuCvimUfWwH/wAcr3PYQ4U5zgnIGCPTn3p+ zOMg89R3oA8Kf9n6GRsnxR/3zp2P5PUZ/Z7j/g8UfTNgf/i6982YbafvYyAOtOMR2j39+tAHz637 PZz8viiP8bFv/i6T/hnp+3ieH/wBb/4uvoQRcYNKYOmB26etAHzz/wAM9zdvE9vz0zZP/wDF0f8A DPVx/wBDNa/jZv8A/FV9C+SMAcUpj68c0AfPH/DPVx/0M1p/4Byf/FUf8M9XP/QzWf8A4Byf/FV9 ChDj0z7UpiGCPm56YoA+ef8Ahnm6/wChmsv/AAEk/wAaT/hnu77eJrP/AMBJP8a+iPK4+7x1oEeE yAOe1AHzwP2ebo/8zPZf+Akn+NL/AMM83XT/AISey/8AAST/ABr6FWI/nUhhzQB87H9ni67eKLH/ AMBJf8aT/hni7J48Uaf+NrLX0Ubc/wCTQIT6fl2oA+dh+zxef9DPYf8AgJLQP2d7o/8AM02A/wC3 WWvolouM4/Cni3+Q569KAPnP/hne5xn/AISmx/8AASX/ABpv/DPF3/D4osD6/wCiS19GCHJ5604Q eowfzoA+cv8Ahne8x/yM+n/+AstIf2eLzt4n04n/AK9Za+j/ACcA8f5xS/ZsLznNAHzf/wAM733/ AEM+nZ/69paP+Gdr/HHifTf/AAGl/wAK+kvs2ccU4WxH8NAHzX/wztqGOPE2mf8AgNN/hR/wztqH /QzaZ/4Dzf4V9KC2bBwOfz4pTbEEZFAHzT/wztqXbxLpn/fib/Cj/hnbUuP+Kl0zn/p3m/wr6WEH PAxTTbkZGKAPmn/hnfU8/L4k0sj3gmH9KD+zvqv/AEMelf8Afmb/AOJr6U8j8KaICzYAoA+bD+zz qg/5mTS/+/M3/wATR/wzxqmAf+Ek0v8A78zf/E19K/Zzlsjmka3wKAPmtf2eNTP3vEmlj6Qzf/E0 v/DO+p5A/wCEl0vB6fuJuv5V9IGEg8Dk0hi3dRznqKAPnD/hnjU+3iTSyfTyJv8ACk/4Z61Hv4l0 z/wHl/wr6PaNhzt4FN8g4yQTQB85H9nu/wC3iXTff/R5f8KT/hny/wD+hl00/wDbvL/hX0a9uQAM ZJHSo/JJUkK2O+KAPnQ/s/X2P+Rl03P/AF7y/wCFIf2f77Gf+El07/wHl/wr6J8olScdD1FIYvQc UAfPKfAC/BDDxNpoPb/R5f8ACm/8KAvh/wAzJp3/AIDy/wCFfQxgyckfSk8n5c8eooA+fY/gFqEb B08TaeGHQi2l4/SmH4AXwXjxJp2ewNvKP6V9CeV1zzQ0JI45oA+ej8Ar0fe8SaeP+3aWgfAK87+J LH/wFlr6DMGPSmmH25oA+fx8Arvj/ipLH/wFlo/4UHcZwfEtkD/16Sf417+ISCByTQ0JGc8fWgDw E/AK4HXxNZ/+Akn+NA+Adxkg+JbP/wABJP8AGvfzEMjJALds9fpSeR6UAeAf8KEnyB/wktp/4CSf 40p+Asw6+JbX/wAA5P8A4qvfzbkr05Aoe3OBkfjQB4AfgNIOviW3/Cyf/wCKpp+BDhlH/CSwfNx/ x5P/APFV9AC3JXpxTWgIYgj8KAPA/wDhQzggHxLCP+3F/wD4ugfAc4yfE0X0Fi3/AMXXvgiK9OOM HFRNCfTk0AeEn4DEf8zNEf8Atxb/AOLoHwGz/wAzNH05/wBBbj/x+vc2iwfU5pUQgHPr6UAeGD4C k4P/AAksWP8ArxbP/odMX4EEkA+JI+c8/YmwP/H694ChhjaQKh8vnp36elAHhw+A47+Jk/Cxb/4u j/hRIOc+JU/Cxb/4uvcVQkkHp700oMEnj60AeI/8KIX/AKGZCP8Arxb/AOLqRPgKjNgeJ1B/68T/ APF17RtAAz3qZE6FRz/OgC78Kfh43h3wRZaemrCYrNLL5q2+3IYn5SN3Y11q+FjsIlvi7EY3eVg4 yeOvvWj4X/5ANpkAHBzj6mtSgDhNbhTTLlIZm3qsXmb0Xyzg5GCecjgVSW9tpIZWmhMhdSJZSeHX JOCMdq3/ABhbC4uIOUUrETknnqf05/WuTREFlmCSO4UnKkEj5yQWBzz7Y70AeJeN9Sg0n4v+GJrR Zdwe28xSpUOBcKVAz3GO3tX2IBiXHoa+OficFT4y+CzHHC2Z4X2EDBJuO/8AntX2MP8AW/jQAjfe H0H8q+df2zyv/CJ+Hcwhn+3SASkcqPL5APvx+VfRTfeH0H8q+d/20CB4Q8OfMATfv8uOo8o8/h/W gD5IpD05paQ9KAPufwKP+KJ8Oqc86ZbHr0/dL/8AWrbwMf73WsbwSpHhLw712jTbbOP+uS9R3rcY K3ow6g9aAKzjJOefQHmkPAyOKmlwExxUDZOdp5HWgBnA7HA7/jVQRmKRZAsmecjzS20c/NjPOSf1 HFXHA3Hk4BwS3GDjr9O1MwiuGx8wG0HPbj/CgBYbaNCrJGoZNwBGeAxyRzzyQD+FWY0JHKkg96hV 9o3cHjnHFSi4PAAFAE+zC8NyentTivfgk1F5/YjinrKqvjAoAfsJAzjmnqqseRgjtUSzAN3PFOE2 VPSgCQRjHt2pDHyDxtJ703ztwGGICkE09XzwAT7UAMeMMfkxx3pTFhRnrTw3OR1xQN2M8YoAZ5WS M8CnLbjdg9CKl429OfalYgkbcEdKAGCD5M8Yz3qZLcYyaUEBsZz61OHXuRx70AQ/ZcdPTik+z4PG OOtWfMXGcgUqsC+R+NAFRoBztycUq2wVAO1XQF55H50AAZ70AURb44yaBCO4xn1q8+FXJ6VUJG4k lsE9+g9qAEWEHryacIBuAJ+Y8gf5+tSR9sdKnTbjHagCJbf26VKLcY6U/cRgYJHtUykev60AVxBw PlXPtS+QpGcAe1Tkj1/WlZlxQBV8hQOlN8jJO4D2qfzFYHbzikd2PHP19KAKpi2AjA2k88VE0KiU OBwavlQVGSCKa8YA9aAKhhQtkZx71KLcDBIyO3vUpwuOBinryoXAoAqPApzjv09qhEAGcDJ71ccB SADxTRgPxnB70AVltlPXJ5pTbgdqtk+oqOQ9floAoNGd42cY7+lVpEKMyhz7Y71f+Z95zgConKPi THzD+HHWgCpHATgLzu60025EhU7Q2ccmr6Mm5iRtPQAGo/L3NuAAPcUAQfZefmIA7e9MMB3Ar2qw CS2N2StPVlZjxjvQBS8hSeevc4pRb8ZHaruAedp56cUFR6/KetAFE2273pkdu7SOGjKhWAUlgd4w CTjtg8c+ma0du5iQQv0pCAOCTz6UAUPsw4J5PtQbc4BIwO2avkYGf6UdhxgUAUPs3T86a1v1wB9a vnHfI9M01gpBByO2R1FAFRo8xrjqOvHSj7OpGF7dR1q4qJFDhclm6szEk/WlVdvbBxzQBSWDuFzj qaQwDGT39qvlSvBGM9qXywMhsc+lAGW0BHPOKj8njIx+NahUemaaIhkFeh9KAMg2+Bjrj1pvkHcR itgxgmmtCM9OfegDJFvwF4FV5Ij8wwOtbEkOMcd81E8PHzZzQBlGIc+ppjRADjHNaLQ88ZqJosDm gCiq+vQ96kVQRyM9zUzL839KTnaRjn1x0oA7/wALkHQbXaQR83/oRrUrN8ObDo0BiLGPLbS3UjJ6 1pUAcz4uV/tVsYpArvGyLkZ57GudvJjZxyAbf9WAu0BtreoHX/8AVXS+K5oYJIXZS0xRlHYKuck/ niuQuYpLmVsh0Zmxy2cLx8309qAPCviSWHxu8GMrJIWktTtccZ8/HP6V9kj/AFv418g+MIPJ+Png CPyhIPOt1VC4O5fPOPpX16n3xQAN94fQfyr5w/bSm2+HvDEHZ7uZ/wAkA/8AZq+j2+8PoP5V8zft ruRYeEI8cNLdMTj0WP8AxoA+WaQ9DRQehoA+7PBmB4P8PE/9A22B/wC/S1tyglATkdxnqKxPB+4e D9A2jJGm2uOcf8slrbC5XawDdj6H8KAIJcZ4yKgZyp4zk8Cp52+QlTg+tV/mVTjv3zQBEwL/ACth lIxjHb3pDtHUsW7f1pCzZJB6elMd8cg/XNAEkh57fQUm8jCjOOtQ789Dz7UFsn6daALAkYN1HIoE nv8AjVfccgk7SPQ5ppnABJJCryT1xQBcLsSAMj8aejn7oPAPWqkTlm5BFTk7MYwRQBMJvLiOxuvH rSiYgYJxUB5IOMc0/JdNrbt3bjigCcTs7A9BUi3GTjoO9U14IJBXFKSzHJI/LpQBcWbp6UC5Iwc8 g1Uz0HWgP83yjHtQBdE53Biec04T7u559KpgE4I/nTkHqaALvmgdzx6mpFlCE7c8jHWqGCD1+lPA xjLc0AXll5+8RUyzdck/nWYu4981IpfI9KANIy5U85zUAkO5SV29cjrUCuRgGl8wdjQBfBjIB6H1 ziniTHBNZokJ6HpTtxx3oAvtOACfxpq3AIyGIH0qllic5wKQFjnFAF4zAj7xFAl44ycVnsTkfNgi l3AfxdaALqyiMHBIz1pRNyef1qiXIOOv0pQScYPFAF4z47mgzdck1QLMOaQuxU+ncigDREpbHIA7 84zSCZipbJxnFU0l8uLAPzE55Gaj8xhkk9Sc0AXzODwxyfeh5ucZHpVMZRhuKN8uetR+YxYBU59q ANA3IVGHBz3qE3DDhS3PrVVnPmZYAdyAKPtBdlwvC9eOtAE0tydjIQAw4PNRo4VVYMvXBU1DK6tE 0jje7dD6VBvCxhs89ODQBdM/PUYx6dKQzZXPpWfJK2SWPLDqe1NMnAIPA55oAuNMNpwgyeM56VGs h+Vj0PFVN5BycMTzj0pfNO4+x70AaJmcKMMcA9KcZcj5Tg96zPOOMDGKPOOcmgDR80565NO84nuK zPOb15pBOc9RQBqeaSM59sULKFI38j+VZvmsB296Xzzt5Ude5oA0xKOeN2TSiVXHyZ3d/asvzsJj cAOuKe0jpEHYgBvQ80AaQkyC/BwcUeYCN4YAr2NZsdwEZiDkY4Bpscpdgo+8efSgDVMplfJx/SkE qg/Pn8KzPM27w7DKnFIJ3kztxwPWgDS81SMDvTfMCtgjBrKMxzkEZB6GnNOWwQcE+tAGoJ48EggD vS+apHWssz/TPtSeccYxQBpuRgc/Som9AOKppPjGetTLOGHvQASABfmJA61XcgZzUzNuJOfoagbO 0Hj8aAICB9frzURPB7ew71K2c9s9qhwR1/GgD0DwtzoNt82fvcj61rY96yfCn/IBgOe7fzrWoA5n xWP9Ntmb7ixMGyDyM+1c9PGPMViQznc4bGMKMce/Brq/EMkYuYIpImYuh2Op/iz901zOohbctAwm ZU5ypH3vT6UAeIeLYw37Rfw/AmjK+dbspLcACUnHTqf5mvrFPvjtXyd45DL+0J8PmibzmM9u2BwM +ecgZHAr6yj++KABvvD6D+VfMP7bAPl+DvQm7/lFX0833h9B/KvmL9tjPkeDf968/lFQB8u0jcqa WkPSgD7u8H4bwloBUggabbYI/wCuS1uYOOmTyQMcVieBQf8AhDPDpPP/ABLbbJJ5/wBUtdIsZkTj G2gDNnjZpdp6HkVUkJ+bOSBzV+7YRru4+U9TVC5O3kfKT1A+tAEMrYxg9R+VVHYdcce9PdieT3qJ j/OgADY6CnK2EO3I4qPrjgHNJkhsc+mfSgCbKn/69KBk8DB7Y7VEBlgN2APUU5I3Dhm4B6kcUASp lCcfiaeJMDLcccVE75GAevp6Uwt3BPHXtQBZEvAB60puCcg5x7GqjOdvYYp2/AAJG30oAuLIXX27 0oYljgnHaqaNxjBGOTT1kxjsKALe/nkcU0ZVic5qLeB0JI60m/PU0AWvN7du9AlOfb2qoDzUg65y MUAWN5JoWU9cVDknHalHFAFhZCec/rUiyhmPzZx1x2qqpOMngmpFbJHP09qALiy55p67VyVz+NVF OKkRzigC1nnsT6Gk8wEA9BURfI4GM0oxtYEkMDxxQBKHBBPek8zpxzUY6ncccU3PHvQBLvGc4GaC 4J+7g1EzZHIH+NA5PT86AJ9+M+opFKl1Vm2g96hJ29Kcr4Rgy5Zjw3pQA5sYKhu/WlDuEZQ+E4JG epqLceDU9pGJn+cgKvJI60AAZQoAGeOaa2CCD060FVKOyuAF9e9RfPjcFyB1OOlACtknqeKPnjYb SVOM9KkjmcSFeGLDqw6Ux5mBYFgSRgnFADS7SNvc5akLlBhH68momYFhjrTSc8D/AOvQAMABznH1 70x2GTgDng5prkk+g96j3ZwRxQAvmkFT1we/OKYjhmbflgfu46ClY8DoAPakVgwwABjrigB2c8sf mPBqFcqxyaOF7nGaZIQXJA49zzQBPvHTjn1pC4z1qvk5H+TRuyTzjNAE5cAc9aBJ27VXJxyBxSbv zoAs7/fml8zHB4qqrZPWlLg9DQBNId4G2TYwOfughvYjrj6EdqkOWxlmOOme1Vc49PpRv96ALbMW fJI3dOOlMLFNxABJGBmoBJ0OeaPMJGM5oAeSAAFOfWgZONvGahZ/X1603zMYwaAJssB1BYUF8H61 AZM4waaXOfX60AWfMIHXP9KcJcdfSqvmEgA5PP4U4MCfQ0AWgw9aUOVPseKro3QA/gakBLgA9M9a ALUcuRjjH8qCRjBB+tVAxVsHpUytuGO5FAA/y+lRHI6HnHepSeMGmkDZkc45+lAHe+FBjQYATzub +da1ZPhX/kBQ/wC838616AMTX1k+02zgExAY7YDZ6n8M1g6iS93K4iKqONx5x05/+tW1r8hj1G1e OUAhMSITwYy3X8x1rDvpT/aMkLyHa0WQqtjC/wB4fkaAPE9ft2b9pDwDHArH5lc7cBjhnLE+2Bz7 V9Tp98V8w64Ta/tIfD5lfHytGCcn5SZF7+oPFfTyffFAA33h9B/Kvm79tNB/YXhaQg7luZ1B7YKK f6CvpFvvD6D+VfPf7Zy58EaA2ORqTDPpmJqAPkSkPQ0tI33T9KAPvDwLgeC/DgPbTbbP/fpa6wDE LDGARn8K5nwWI28KaAIjuUadbY5/6YpXTyZ+z4IHFAGNLySG/LNUL3GDgfnV+5bcMjIasy8YliCP rQBUcFSN3GfbrUR3Z5BAx1qdnjCAM2c8DPaq4kbIw2fSgBQTuJBpH56YpXb97lyDwBxxTZSFDD3o AnCmNcJjJyM/TvUWQwJbJz3Jp8+8WwYH7wycnPFQowBH9BQBI0qxoSWVc8fN/IeppgOVBHBIGMj+ Ypm8E9cY7+lCsAcigCTnG1yD68cUuck560xT9KU5wKAJB/kUqnOThhyRyMf5FMT3zkdjTlPWgCQH jnNL1GT/APqpo9sZFPUA8ZwTQA4cClI6HjqB7UD+vNSSMHPygAY6CgAGSB9O1OBLcYz3qNcZxnHP 5VIMEnnjtQAuc9aeOuQMZ6Zpg696eOpGfpntQBIAQASOD0qRT6/pUYYdGBznrUi5wR/KgB/Ruaej c84z71FnI5+lO75yKAHOfm7UEg9elJznJxz6Ud+1ABnGAB1607qeentTeD/KgAAjB4x6UAGTjJGc 8U+FPNkwX2Y5B96QcgDjjpRkYyuQwHXtQAsi7HK9QOhFM5HQn3p+enOTnnimt3NACYyMg4A9+tIH YKVydpxxQRSYxnjj65zQA5nZuO/rUbHgDv8ATpSnGeBxTHJz1oACccccdKYzYXI4PpSkcHP4U1sY oAjbJHH6UxSVORz3PpUoViCRwAPSmMFBUZOe/pQAyVi2CRg9OKjfG3I4/rUrj5jg4XPbikZQHILA Y/ioAgBzTc4PHSpfLLAlegHf9KY6YRTuBZj90dfxoAZn5zSd+fwofg4I/A9aafvDNACt0HekPGTj Io6jJzSdDwOMUALuAJ70KcHj8qaeT7c00N36fzNADyRuxnJHP4UmOCOvPSmgjOSe9Ljn160AKSQe OeO1NJ/SkPB/rSHGMdKAAmmqRnH5mkOM+3bFISSPX+VACk49cdKCSF4/LFN7H0pvOCAcfWgCQE/U U5WG7g89KjUkDkUqjHPQfTmgCwp546VKOMelVi2WHPepgRtI4BoAlyN2DxnvSqxXGKibBA9aXzDk c9OlAFgEtgYO4nvzSzqsRGCMFQeGztyOQf8APpUcbjcCSAOhJ7e9SXcaxyIExsK9MBSD0II7c5x/ jmgDv/DkckWjwpNG8bgn5WHIB6VpVleFiTocBZixy3JOe9atAHO+J7z7JNHujRkaFtxK5IGegxz+ Fcteqf7RmulbcxjVi23ICD+H1/Cur8Rl0u7dlYjKbRjscmuXu7Vo5Q7bQrncQHPDd/6fjQB5Xrsb XX7Svw/KjrFvHO3hfMP9OnfpX05H98V8z3qpB+0v4DWN2PySli55yUkH+FfTMf3loAG+8PoP5V4N +2NAJPhtps20Examgz6bo3Fe8t94fQfyrxP9rv8A5JIv/YSt/wCT0AfFdDcKaRaH+6fpQB98eClU eEtA2bzjTrU89f8AVLXSzMBDgema5nwdvHhbQQ2S39m2ucd/3KV0Vw22PO07RQBjyyBZMNnAH0rK uJOoxuya0b5gSGbBUnaP8/nWfOowSRkDvQBSkBUjcQehxihWPJHBJqSYbwTgnaPzqpxznigCVpCc jBDE9D1z6UyQsFwRweAaRuuTk55pQQUxIAc9D3FADlkLW21zwOneqwc7cZ56CpSNoIx8poCkdDkG gBE6YPWnj36fnimjnJApwG4HHbnrQAowP/r09yNzANuUHqOM01YyDjpnpxQAdvbOKAHqeQQeKN2c nH4YoVfxx0pyAY+hoAehyeDj2qQkBRk45Cjjqajj7Y5qVCAcA4NAD9pAPTpilIwP8KXdnPr14pQ3 YjmgBd2CrDr1p68qSceophOT8vHpQo5zQA8frUigBv8ACo06+3apFyaAJBngHmnjHrTATnucc57V KCDlsUAGd2eeaUd+OvSnREB8+3QjNKFLHA+tAAfu9TxwcGk5wBjI7Uh6E7ePWnAYAINADcdOue9O GM8/pR8ucgilwMZwcigA6DJHWgBdgYMd2eh9KfkuDuPA6elNznGTnA4oAAeVz0FIevXvSrhlwR0H WgDBx/k0ANIz9fejqP604DacjH0IpvsM0AMI9/zpjAVJgE4I5pFwXy4wuecCgBm1sAngdqjPQEY5 qyQhTdEWbGc554pHjiUbstnGcDpn0oArMOMqR78VEQCTzz2qZhv6Y4OMCmBeeME0AIf9XtyCM/dq PzFVtwQHIwQelK6MQWC8A4yKFjLrtjQ54DE9jQBC8riPaCQpNJKyOigLiQHlic5p80RUKW4zxntU RUhsEFgaAFjIWQ+aM4HOahyMnAwDUrKqnDB891qNgPXgUANK9Md/1pGHWns2VCkDI747VGvLDqBQ Ah6nnikz8xPXinum3ABDZ6kUzGfqfWgBMZz78UnA5P6049f85pDyDxQA05yO4pGznmlOc8jJpr8Y xzx+VABjqe3WmDuR0p+TggZxUa/eOOtACbunYGk57mgsVBBFB9+TQA5Scn654pwPr/KmDkDjpTgf x/GgB/IwDUqH5fbNQ5HB54NPjPHfFAEoPJGR70nO5gCOKbkc9qMjHUgigCbKknA4xxk5pXkdzmRi x9Tyfz71EPQEZ64xSg4GSKAPRPCJLaDDn++3862axvCP/ICiPq7/AM62aAOb8UtKL22EbfejIA25 2tk/MfYVz5vw1xEHzkKVwFIUnPLH6dM9K6PxFD5mo22FJDx+Wzk4VV3EkmuYe2SRlNu/l4VkVgfm ZM9f06mgDyvxTLt/aN+Hzqdq7toHTklu/fORX06n3xXy54o/0j4+fDaRDw0oYbT/AAh8/wCNfUaf fFAA33h9B/KvFv2t0Z/hEzKCQmo27NjsPnH9RXtLfeH0H8q8Y/a0bb8IpRj71/bjOPdjQB8TqBzk 44pH+6fpSjGRnOPamt9w/SgD758IfN4b0Ht/xLrX/wBEpW9eEbACTjjJxWD4PyfDuhYGM6dan/yC lbt2P9GAwc+tAGFcjJYZOxTkVmzSP5sgIUJgbSp5PHOfx/StG6ztrKkJ3HP5UARMSScDgcGm7VwW OPUClQ5G1eSe/wDSiX7uTjjgY9aAGLknAPzMetN5YE9MGpH2qDjGcc++ai4PG7Hc+9AAenp9e9Pj YrHjtTGJOAcH8aXoVOMgetABjuOtSRH5geAO+aDHtGQQQecg0gGe5GKALE7BnwCTj+ftUanODSFS Fyc47Uo9eaAHKelPHpmmKCSD/SnonHo3f2oAcp/pTwcZ5Hbmmj2xUikeXzyRQAZ+8ScfWnDsabj1 /OnLwOR1oAefvcYp6j5hnpnkA800j0HFOHSgB3YepNPX3pox25p69qAHD35A5p454wAaavepIypJ 3HHHFADo+HGP16VMjqqncoLduarDg9jUiAsnCnr17UAShVVC7LkduTUyGIo2Iunbd1qF2jjiVU+Y ty3HIp8c0SMSi59N1ADnliI3eTz296YZF3AmED8TTUUu/oST16U0gg56+4PSgCcSQ7QBFzz3oEkQ 6RD25pkYLL8qcgEk5600EnPWgB8pUuxjBC9cH1poPHHekPbpj+dC/wBKAA8fhSfToaUfe9P60hwB yM0ANwuG+bGOg9aaRjDZ4zggGnEbVBBAyOlRkjqfyoAsShVXdC2FP3siq6RvJkopbHf1p8TKuQ5I GchexqJpjhhGpBJzx6UAI5JIAxlDg4qIIPMwXHPegbh8wO0Z5NRgLljhjxx7/WgB/HmbDtK88A9a RN6ttiJDNjPNMmXaFI7859KsCJPJV5FZQB94nqfSgClIf3pDBiQM5xxnOOvrR5rKrKMDPB70owT8 3QmmSMFf5QOP1oAeYWcIxPLZySc5qB85Kg9OBmrNr5jCRIym08kGoLxDG2F6Ht6UAMfKkqxyV6c9 qi9cGgknBc59aRh1xwTQAhbAwcH2pwIG4DvSIq90DE8DNOk8sKAqkv8AxEmgBgOTnNIecADr2FGc jvxShipypAPbBoAYxIIwfrSHpnPPan4Ocnr15prkR5LOijrywH86AGE449qY3B44zTDeW5B2yBz6 RqX/AJA0+NmlA8u2u3H+zbSf1AoAawPUd6TOeopZPOVCWtzGB3uJEi/mc1mTa3ZWpIu9Q0W3I7Pq KsfyC0AacYIbg9e1PXBBOORXL3PjTw/ASG16xJ7rbxSy/rjFUJfiN4fiyVv9UuD/AHYrBF/VqAO5 xkDFSIGwcKxx2Aya80ufijppAEGn6xcDuZLiOEH8FrOuviUJ2Hl+GrT5RgG4uncj8gKAPXZAEH7z Cgddxxj86gkvLVM5uIyM87Du/lXkMnxE1R2Jt9M0aDJ4zA0hUdhyaqXHxE8WMAqanHbg8Zgt40x+ ODQB7XHcxOD5PnSL/sW8h/8AZakm+2PGPs1hMXyMtcDy1A7+pz+Ar52v/F3iO4JM/iDUW7ECfH8s VgX+tvnF5qF7KzdAZpGP160Afd/g3efD8HmIEIZhtDBu/qK2q8X/AGZ9TgPwwR0MhAvZxlh1O4f0 NeyROGUFhjPr3+lAGPrsn+lRx+Y8ZeP7w+6RuPyn3NYV7Lm3A/1EzRh0YRnbtJHBHY4q94qmeLV7 cFC0TRAceu49e2Ky7+XzbJEmCJscZbOckngY7c0AeR+LuPj58Nd6IreceFXAxu4r6cT74r5j8TTM nx/+HJY4P2h1+9jqcf1r6cT74oAG+8PoP5V43+1iQPg9cg5yb63Ax67j1r2RvvD6D+VeM/tZqD8H 58jJF/bkH05agD4lob7p+lLSN90/SgD7U8FeInuptO0W20qRvsek2c0tw1yqgKYowMLg8/MOMg45 ruL28zGoktL2IdA3lb1/NCcV5h8IWW71PVNRjK7H0+wiRcfdHl4/PCLXqt3xbjIH0NAHLy6nYStL El7AJIzsZJD5ZBxno2PWqsgyDtPB7rzWrft5kRSQb4z/AAyAMD+BrH8iAAKscaKOPkXbgfhigBh4 PBPFNJ5JJGaVosAlZJQvPOd3880zZMB9+Nuf4lxj8j/SgBTwRgU3Hy5x0prtKoGYlPukn+IFRtNh fnSVR7oT+ozQBPxn1+tAxkdu9V45YnbHnRk9MZwfxqdVIGAD+NAEse4KQFOD0wKFOevOO1RjOO5A pwPJ/lnmgCUHIx1570ox2pob8KAeufwz1oAeuPT8alU4OP5VGPb+dPB9qAHj06U/j8aYvY5xT057 84oAdjI/SnA8fTim8ce1SDJ6UAKBxzTh146U4gLjG3jjim/U/SgCQ8ksAQpP504DB4HNOKrjAY7c Z5FNZtxBxigB4IYjmhjyeuabuJJ5NA5B9aAHA81PDPIiGOJvkznnrmq4yWAYhe2aAxUkjkYwc0AS AlmbHVuT71ZV1VkEihF6EjqarCTHClhuHz5qTdmMhvmwemetAFi4ljZVSI5VfwqJCANpOATzioAS OcHFKpIOTQBPgEcHJ9Kcil87Tz0qJSd+VBAx2NPfb5Y2F9/f0oAUsTt3Z9celCnnjg9qhw2cGnKG B6frQA8jAFINrLycFe57+1OVSwJ9OmKayEHAHTn60AMJycZzmmTOTjgYAx8o60+T5OSQoHJJOOKg kngwD5sKjHaQc+/WgAeRlxhgcdCOcVGcnH8s0kd7ZEurTo3GeM8e/AqOPUbVnVQzMzLuX5MNj1we aALKIPKG5uWONvce9RMuxsBiR1U471We+SPB8uQHkjeyp+PU1np4hW6kkWBrSJIYWllkkuA5iRRk tsA56eoGaAN6NHjuAq7X45JXNKUllIYMojJyB2FcRH8RbDzeNRsnDNt/dQu+1exz3/D86iuPihpF vG6wyXdzKPkwLUxqPxOT+lAHcXKqGbYBz3H8qqFMYzknPIxXns/xNgkfbb6XeSKBxm58vk98g1Su vH94Ymki0q3CA4zPdySn8uKAPUDdfZQ2XijDjo7AY/OqTXEJ+9PGT7NuP6V47e+NNdmBWGa3gAbI 2Q5P5kms9PEeupuC6vdoWJJ8tguSe/AoA9x38bkt7p1JxmOEmleRof8AW28seR/y2KR4/Nq8JuNZ 1S5B+1arqUh/iD3L4P4Aist4YnbdKnmsehky/wDOgD3/AFLVtNsVQy6ro6bu0l6oI/Bc1jz+NPD8 SnOs2jvnGy3glmJ/QCvGlhWEjMCRk88IBmpAN6P0DD5hk9fagD1G68faEnKXGsS4OP3NqsYP/fVZ c/xItl/1Om6nNzn9/eJGP/HBXnir13Hj0FKVyOv0oA7C7+ItxINqaFpuB0M8rzY/Dis2Tx9r33bW PSrQdP3FkpI/FiawkXkjG4HjBFTSWTxR75FKrnv1zQBbufGXi2cYOuXir/dgCx4/BRWRdajq94Cb vVNRmB4O+5fH5ZqwEI6dO1KEyeR/9agDKaw85cO2T6uS386jFl5blcIGx2ArZIC9RxnrUUh4GR/h QBnpCATuBxTWt1VvkYke46VfG1lwOo6g1DIuOM8UAVQhznr7YqUAMQTgH1/xpGHsMUA89aAJRGF6 Hp61E4APTP1OM1ZilCNlgSMc1Su58PtgUGRs4UHoO5J7CgCrezpb7Tgyyy8RxLjc57/Qe/pVWGwC yPPeETXLA9B8qcdBViOMRs0jHfK4wzkdvQegpwJD849sUAfTP7JilfhWi4B3XczA46fMB/SvZ0jV SNowM8jtn1rxz9lKVpPhbDnkpdTx9uAGBFezrnFAHM+JLqCLVYkkQGbyfk3LlTlj+R96wrlVZI2W QlZfk2uBkMMf5B/WtjxeF/tC2YhQfKwdx6ruOQK5d1H2RVhVVzwnVsLkd/xNAHleqosfx7+HcbB3 CXDJuccsc8Hr7j8q+qU++K+WNelW3+PHw7ZN6qt40IOTzllXp6c4r6nT74oAG+8PoP5V4x+1qcfC CYcDN/bj68tXs7feH0H8q8V/a5I/4VGc99RtwPyegD4oWlboaRadQB9d/AVWbwxc3TZIlkhjBOMA JCOB7fPXq12c24I9MVwPwitGsfhvoCygCee3Fy4HGN/3R/3yFrupHzasB1B7mgDEu2BHesuUbWPr 6etalySWbmsyYndtXj3JoAgJAxnJ5x7Uiu27gmlAJJHOegxzmoLrUoIH8iFJri5AGYLdNzD3YnCo PdiKAHyHnHP51HnnIH4+lc74j1LVIdR8O2tpcW9nJqV55EqeUs7KoALHceMjPYY9zW2wviAIJbWV MYImiZS3/AlJ/wDQaAJs7xhwCP8AaGaYIoQdyxqh65TK/wAsUwtdRyMsli7KFBDxTKck9RtbaeOO aFuI2QFiYjjOJRgr9f8A9dAEvlkHKzSjPTJD/wAxTgZgAA0Tg9SyFf1B/pUMt3bRkeZcwpkDGXHN P+0wgAiZWB6Fctn8qAJhJJtG6Bj/ALsgJH4HFOM6ZPmLInqTGf5jNRRXKscIk+Pe3kUH6ErUjTsh Gy2unPqqAfqxFAE0U0UhISWM/wDAhmp9pA4B45ziqUs42ZmjT0xPJEMfmxrOudS01UdJrmxtUPBa DV1icfTYcigDoFPTFSDG0YPJHNclc+JdJUAJ4p0+DvhphOTx3/d5/DNH/CeaBF/rdbsnyR/x7207 ke5zQB2APtj3pVIyP85rhZPiJo0bkrfXEgHQLpzc+/JFRS/E3SNhCxawzescUUeR+JNAHojSbiSR kn8MU5eOoOfWvL2+J0OCsWmam4/vS3MYb81FQn4lnzQYdGYgD/lpqEn8gKAPW40ds/1pcEdeg715 DdfEy9ZNsOh6eE9JpZJPz6ZqkfiFq2cwafocIGD8tq3X8WoA9meeBWCtPCrejSKP60rTwr1mj9ch gRXisnxB8SuMI2nRL6x2KfzOagPjHxRLuP8Aavl56mO2iT3/ALtAHt0d7au+1Zgzem1j/SpTMdo2 JO6nnCRMc14K/i/xTIMP4j1IAdlkC/yFVJdW1p4wDrOpNgYAFy6jA+hoA+jFkd4lVrW8G0cEwFR9 STUMl55TtHJCd2N25nVeD6ZI/Kvmxri6dsy3t5Jkc5uHJ/nTGtxlSzPIrYJ3k0AfRz6rapw9zZRs D92W7jX+tVj4l0qNsTanpaDkFheKcY/CvnsWdvIcGNEJOd7kbR9SRxVyfSfIto591lJDIu9TDMrH G4rnb97GQRkCgD3K58beHIiQniDTFHqzM2B9FqjJ8SPDqH/kKwyrnkwwSce/NeIRRosochTtByD0 NAUB2Kghc8A9hQB7K/xP0bJEN5O47BbIn36mq2n/ABL0+8vJY9Qu5bC2RDJGywkNKR/yz6cMTnGM dOvNeVT+SWXyk2oBxn1o27lIJz2xjrQB38vxSbLE2F9kEZU3Cqg9hj+dVX+Jd05cW2kRqvUiS6Zg cduF6Yrzq7ilkjlubddlsi/6wHAbB/h74HTP1qO2MscMd0WkaMqQwP1PI7fgfzoA7m68farcPvt9 P063XjCYdxn8SKpP4v8AELuGjubaHuAlqvB9ctmsWJwyZHPsBgj6ipUPyAjlc4IoAujXdbmHlXOs 3jjBHREPI9VUVXub6/liRTql/JlcENOw/rTHVkYq/UjqOfpSY8wogTcRnpyTQBRk8vzFaYNJIo6M xbJ7dTVe8kSzEUqwje4OEDbSwHJzjsOOvtV8XUcLIxjQ7cszEZ/DFMjkBBkfmecYKEcRp1C/XqSf U+1AFKzupgkoZNkMjDcynKjP6j19Ktxt5RKoVZcEZAzwf89aq6VbKkUrxtICShVj7oCQR0Izmp5I FijE/C+Z0CN8qn19vpQBajZIhkbtsh2EkcHjnp0pL+CONyYZQ8ZwOO30qAXPljY6Dn+LqM/SlIGM jmgBUTzWZQyKT/hRFbmWVo1yJB0Ujkn0qMgcnODjjFR5eNvNR2Djp6igCVAIpz9pQlFOHGcGmhkB EqIxjyfvU1Lh3GH+YBt2D3NLc3Bl4VRHH1Kg8ZoAlvLlrlIjIQSoxxxioSBjuaiHPrmnZ9OaAHcH 6U09c4xQWwcZIz2o69M0ADHDbjkd81NLdzSqqyOSq9qrs3PHApN2MY7mgCeMkk559KeoxyRgD9Kr buTjP50pd9nD49qAHyAhuuV9abNIDCsYjUEc5HU09AwU859gaglyCcj8KAKxYq24EjFBcODz83fj 9abIeDwB+NQE4I2scYoAex57Y+lCgcGljkLdBzjHTtTdxLFIiOPvOei+w9TQAsshDGONQZcck9FH qar4WPO3knlnPVj71bKRom2MEL79SfU+9VnU4zj9aAIW9cD6UwHnn1pSQCemPekIHHIGaAPpf9k5 tvwyAJP/AB/zHI7civbtwyOa8T/ZQAX4YksR817PjJxzuFezSSwxjlixyOEUsc9ulAHLeM5I11O2 EkbgLGHEqHvuICkehP8AL2rnoYy5LTSBV6sBzhuOAT29a3vFqNJrNszOyoIR8hX7x3Egmsa+uIzv hJGUIWYIc7X4wMjoMHNAHlfiuKCP44/DlxICr33ALHjlNo/lX1En3x618w+MI2f42fDRRGjyLe7p NvAJDpkj6Dn8K+no/vigAb7w+g/lXif7Xf8AySVf+wlb/wDoL17Y33h9B/KvEv2u/wDkko/7CVv/ AOgyUAfFa0ppFpaAPtbwjqsFt4L8OmUwjGnW3MlzFGM+Wv8AeatW48VaJBCfO1jSYzjlXv4+Pyzm vkXSbeGW2tWKKzNGvO0HPAGK2hDbhQqLHtHRgoGT60Ae8X3j/QYn2vqenyE8j7O7yhf/AB0VzWpf EqwikBtUNyvfERX9Sa8sDAbCOo65NEqqAWI5H5UAeg6h8RrK/ga3urO/jgbhhbsAXHoc9vbNA+Jl hb2yw2+m6oYk4VVaGID8AOK86hO7O7DKeMGmzRgykR/MBQB2Evj22uL+2vZNClnuLRi1tJPfnMJO QSAox3qW6+IdzKiP/YtiwboHu5mx+RFcJFt88k9OhFWC52KFxj2HagDpx481d48RWOkxp/dMLyY/ 76Y1DJ4111SDC+nwN3aKwiU/mRmucyBxjigDsePQmgDbk8Z+Jn/5i8yZH/LKONP5LULeJfEEwIfX NSOfSYqP0rKf5c46dqkjQlMgrjp94Z/KgCzLqGpTndPqd9L/AL1y5/rVdleXHmPLJx0eRjTg2B17 elSqEKggkn0x/KgCutnCc7ol/EVKlrGn3Y0/75FTKvTg+1ICzfKjbD/E46r7D3/lQBXnDgv5JRUi Ul3I+UHso96ZatK6iaY5hztLDBCN23emavuiC3MYjBTgBR/vDpUOl/JbqjDAcMCD6qxGD+DD8qAL IiCkjkY6jpSlMYznA4qSWyksoLN5CBFdQ/aIE5LLHvZQT7Eq2BycDnGRTGYk5Lbie+aAH8c7Rj26 in53deSfWolP4H0pSemfSgCYAAelNUAyHI47UnJBG6ki4zjknjkdKALGBtwuAc0pHpTUzgBsZ+lP AIzg8dv/ANVAElvDJMk7JsIt4jM5kYAbdyrgepJYADvTI94JfOE9eq/StzQtGuNU8M+KJbYEy2tv FKiqOXMb+ayj/gCn9K5+NmaMOpO0nIx396AE3D51ZQD0II6fSnqWL7UDSH0AycU2RUQLNOQFJwIw cM/r9B71WvLtrjKxxRW8WOVyefr3b8aALiyJGS00sShVOYw5LHg8fL0P4imvPBOumxh5lW1s1hbz GLjzNzFio3cDn2+lVmv7aK0ECWgklx/rmfb69h+HftVRZAeANpHU5z/OgDZMPmPEkLwOcAgK21m/ BsZ+gps+5JpEkDB16h1KsPwPSs+EiRo1JQBjj5hgY/litzSrlrh47LUIzcw/wbm+eP3Ru305B/Wg CvJcfJG0iIeONpGePWtrxdp8ko0+eG3ht7CTTLS4jWJdpkDx/OWYfeO8Pkk57dKz9Q0eaI+XbFbl HyI3Q4L9uR2IzyP6c16p488EX1/p/hubSVtRBb2CWExmlKCPYdyNgD5gfmGBzyKAPH2llNuYwx8v K/Lj0INLosM95GYLG3munSSRNkMZfHznrjp+Nel6Z4J0q0RBeF9SkUciUlIu2fkByfxP4V0gaO3t xFbJHDEDxFEgRB+A4oA8rt/AmsThGZbWxReMSy7mX6BMkVvwfD6Mov2zWGdu5trUJ+rE/wAq697h RvO3ntsXAFQSXCcZ3EY9aAMVfBei+WvmyX0uP4jchcfUBaRvCegxYK29x5nYi6fNahuFYEHKnpmo Zpyy4I/eKeue1AGDc+D9ClIxFfIx5LJdE89uGBqtc+BreOLzbHVnBP8ABcxBv1XB/SuhlYIcAq3G c9qjEhOQOg5wKAPNbnw9q+mQySzQ+dabY/31u29RgYyV4YfiKzhJGyfLyG685Br1oTGJgY2cMOQe M/Suc8UaFb31vcXtoI7a9iQyyKPlSYAZOewbHQ+v50Acf5duNIebMi3CXccS7jmN0ZGJXpwylQeT 0bFUGmSOV1jkbAPKkYZf94f1rqtX0eeH4TaDqSxN5dzqs88zHI2qYxHEW/75P51yRUS7RKwWULjz B8pHt9PbvQBcWQOueDn060zb19Kp3E7WvEeZSRksgwfwHr7flTbS6MoIbO8DcBtO5lPfH59KALvA /hB9sU9pAs0cluojKYIzzyKgVgwyN209NvX8KcD6qxB70AJx+FNzxikYhepA+pFNaWMdXQkf7QzQ A8MOeh7Ubt3BU5+lQxzKScuDz2BP8qeH6AeaR7RtQA/I54bP6UDI+XbxjnnrQkm11bypmAOcbQM/ makuLgySAxWzp7F1H9aAGBT2AwB27Uuwgc4pqlxjbFEqjoPMxj8AtGJsnaIE55HzH+goAGaNOccD rjANNd43B2FgO3rTXWQrkyRqBn/lmePzaoGJLACY5HHyRjn9DQAsmM9DUDHPAGc/w+lSspIJLzYA zksqgfkKphGnIxJIIemTI3z/AE6ce9AEvzS8RDCDgyep9F/xqwi7FC7BGg/D+dVzBG2ATIQOAA5A H5Uqwwr0giye5XJ/M5oAe9xCAVM8RPoDuP5Cqks6Y+Ug/VlH9Sf0rRUgpjAHsABmoZiVJGSPegDM Zy3RseuEdyf0AppBYgM12M45Vdn4DgVZdjjBwQPYZ/PvTRjIPbOfagD6b/ZWQH4VQlo1c/brjAOO PmHPNe0bmCDK4/4FXi/7Kr7vhiqsOUv7gDPf5gePzr2YAFhnhscAjgCgDifGsVx/aMUiRtkxCOPH QcnnP9K595VSVPNQ4HDNj7x45x37/lXTeNZ9Sh1AfYN/lm3G7cm6NhuOQffHSua1EWmpWsZI+xzK +7CDhhjJGOwNAHnWvzef8d/hvHG7MqTPh27jd0x26Yr6gT74r5ULyyfHz4elwpUvIUUrggYPX34N fVcf31oAR/vD6D+VeKftdD/i0g/7CVv/ACevbG+8PoP5V41+1kpb4P3BGMLfW5ORnjJHHp1oA+I1 p1JRQB2mkKFt7d4gQrxKGHGCcYyPQ1rHGBgD6A8Vj6XIPsduGyR5akZPtzWlHyMqct6etACu5Byc k5yDjrTZJC/U4qORjjjGCevrQI8jJ3Z9qAJbY5Y5IB96UysG2gZ25OQKZFlOxx9KqXF4kLlJHVXK nigC1CqySccZNS3TDIVQAAMY6ZqnYSJ5bMXQKP4twqy8kCxAebH6sdwzQAgNSfMIwwxtz61WM8Aj ZvPiwvUBxmmLcwbhuuowf7oagC2xwCNoYnvTouBzx24qut3byZ/er8pwAAcn6Cka+tlxh2bPopoA vxFgVKcEHrmpG+8STk55FZv9owgcLKRnGdlB1SPgqko+mM/zoA0snkA/U+nsPenrweBgDoDWaNTj XAjgkIHqQKVdTG/CwE8fxMP8KANJmyg6YyMc+4qG3R1gKohWbzSFT0LYwPzNQQ3jzyJF5CqGPPzZ Pr0x7VufD+2W88SW8MhJEMjXTqcnKooxz/vbaANb4lvb2Pimy06ExhbHSrOBsHljsySfpntWBnBJ 5I9u1eufF6Kz1DQ4o4VibV9EhgvZ2dQHFpMWT5T3AcKSO2Qe9eQBhjmRfz/WgCX73OfpinA4xkZJ 9qYGTJOVHoBTy8YGXbAHU4z9KAEklCJl8Ajuewp1qQyoVycjPSs/UYWeNpWzuC8Lg/ICeMn16n8K s2tukGJYo5njlAJQjJXvx64/Ue9AGhGMYI+YfXgVNHhjt3bT19hUce2SNXiDujdCOh/WkcbUZjGw wN3Uen1oA9k+ENvHaaHHcuvmJdXE7kBcmRVQqBjvnYwx715Pqdra6fqF3FbOz2ay7rTIwJIGAaNj 6Day/ljrXung62Om+H/D0Z+V4Eg3exJ5/VjXk/xP0RtF8TPb7c2ciNc2TdMQvIWMX/bOQyY9nHtQ Byd0FZi5YsSOW29T/T6VmSZ6bSPXNaDxO2ASDkYADAVWljbdtfJY++aAKmABkA/hQrbZM7QQOgqT YO2DUaIdxDAAcduRQBKXeQtkjGc7e3PoKuWrkLtIG3HDd1+lRRwqhQzHtkqrc/j6U2bUIIyUjG8+ 3QUAdl4EuJrnxPp1kbeF4T5kzGUElWVCRIMdCOB75r6A1SSH/hFIY55FR5Yv3KnrI6qXwvqcIxx6 A14Z8FLc3muapqTAkQW626E9NznLfog/OvV/iTazP8NI7/TnZNQ0eWDVIMDjMTZbPsUZs+2aAMOV 8sPmBXGQVNNaQjlxnNZseoW90jXFsGjt2O9UY8op5AOPYjHqOajmvRsyzADtg4oA0DdB1CjGB29a rsfNXapAcds9R7Vmz3sSbS8iAHruOMfnWdLr2nKQftgYhvL+QFgW7DgY/wAaANeZsEgnGO3vVeaV Y8AyDPUcVhXXiixkkZEjuHkUdo9v6kjmsyXxTlv3Nic9vMcdfXgGgDrGnPrzmozOf7xzXAQeK7+5 Z3EVrCqtggZbjB9TjOQKuadrEl05tNQvXsXkYCO+iXKRtzgSJ3Q8ZI5HX1BAOz80445I7Vl+I5JJ 7e102NgJL+YRuM8rEvzMf8+9cKb6+nVGmu7lgUXIMp6nOeldd8LtLF5q0t1Jlm3JaRbjnLORvPPo v86APVPG9kqfCS90mCS3SSLT1laKRgCvzbkI/wCBIQPoa+dFTcAd5B4IO0Cva/i9Ekvj3TrS6M/2 DUtHaBRAFL+bFM0iBd3GS21fo9eLLLHH8sksYZTtYbxwRQBDeRAW0m1mJ2nkYqLTv39ujyF1lGGE gJB578fT/wDXVlriFg4WaIlgRgOD2qOzXMcQQFmKFSFBJODnoB7mgC9bWwu28vKJeE4Xe5VJz2BJ OEY9M/dJx92ojCqyPG9vslRijo6YZGHBVgeh9qmFlcsmDaXRVh0Nu44/EVu22l32tRfZ59P1BdWW MG2ma1cC4jUY2OSOwHysenTJGBQBzoVAflROf9kU7kDjgVs2PhTxDeRrLBo12Y26O+yNTjryzDp0 rRi8BeIpPvWlrFn/AJ63kf8A7KTQByZLYOSfxo5wenvmu2j+HOtMcS3Wlxen712/klSj4ZXhwX1m yU5/ht5G5+pIoA4UOCOucelL14AJye/FeiRfDaLA8/Wpj/1ytFH16uatR/DvSuTNqOpyj0BiQf8A oJoA8wYNySVA+lICGX77Edxux/KvWU8DaAuAY76U4/iujz/3yBUkHgvw3DIzf2WJGbtNcSuB9AWo A8hZAg3bVHrnn9ahlngwxaaNVUEnc4+WvaptK8OaZayXU2laXbwR43SNbBzk9AAckk9gOTUVnpsd 3cxXl/p1raxRHda2C28YKHs8xA+Z/Rei+5oA8PXbeDhwYD92Mcl/dh6e1TwwXV1KY4LS8lcfwx27 t/IV9D/aJM/JIV9dvH8qVbmU5BmkIP8AtGgDwSPw9rkvMeh6sw6Z+xuP5ircPg/xNIRt0G+Uer7E /wDQmFe3GQsTycj1pQRz37+lAHjsXgDxM7D/AECGMZ/5aXcK/wAmNSj4b+JJWbzBpsHP3nuw2fps Un869hUgc4PFKxI5J+hNAHka/CrVW/1ur6XGe4VJX/8AZRRN8Mngmt7U64lxfXDL5cFvZnJGfvEs /wAq+5/+vXpF/qDi4+xacizajjL7v9Xbr/ek9/8AZ/8A1G5olnFZTKVZ5rmZ1M1xL9+U5/QegoAu fst25g+Hl7AxBMOq3KFh3IKivZBwBXkX7M/Hg7WVA5GtXef++hXrtAHNeJbl4L6FQ8ixtFk4fAJD HjB4Oa5rWbezeSMxwtHLgM+0/IvAwB9cV1niGxhvp4xKZA6RgrtHU7uPfrWDf2ckSo2d2SNwAyuM AZ6cf/XoA8f1LMP7SPgLzDtBWTAfouVcYH+etfTqffFfMmoJ5f7TXgVGyU8uQqxPX5ZK+mo/vLQA rfeH0H8q8k/amj3/AAY1Zh/BPbMf+/oH9a9bb7w+g/lXln7Tw/4sj4g56Nbf+j0oA+EqKB1NHagD St7m6WGMR3EmAuAvGBVuGa8IIN3OAfRqqWS5ROM5FakUO1TwPbHWgCuzzS5WSWU8kghjx/8AWqKV pFKx+ZK2B03nFSTRkyfN93GfrUgEeQCCExkEfwn/AAoArortg5OR/tGlkQLEzDHtmpnQo20keo9C PWmybfJcZBPH8xQA4xoEyUU+2BUsMJkyQqqOuAtRL1XPAxnipN56J0NAEknlqu0DLYwTUKgj5R0N PUYPTipAuBnpQBHx23ZqTZgctk0iIFyCKlXywCXYD0H+NACxrxkgNx0P86ftLAk4yTyaj3JgkuvX GSwqXzogqhpVxz0IoAVUzz0qRFH/AOuohPCD/ro8+7ipRcQj/ltHn/fFAFu2G24jxkEf4GvRvhLY FxrupnkswtYyD/wNv/ZBXm1rNE0q7ZFbrwGB7V7p4FtFsfBlkS5MlyTPKehUu/H6BaAG/F2GXTPF 2kaqjItnq2kz6PP5n3AArdR/wNWHuleY3NjeabNFb30bxM6CWNm+7MhAIdD0IOc8dOhxX0b8SNIt tW8E30N5aT3U9vbm7t47dgssTopO5CeM4yNp4YZFeb+E9d0bxJpT6Bqdq80Nuge080FmmQgf6thy JVJI4xlcHsaAPOumSxyPanLGxKlh908Z52/4mvYbHwN4dhUNNpglkyflmuZJNo9Cdw3H1P5ccm8/ hjw9HGFi0PT0eQhFJjLEZ6nknoAx/CgDwvUFH2CbdwXK+4ODxU9vIgtocyqB5YGGbuPWvSfitoWl 2XhOa8sLKCxdZ4IWEES4IZ+D6gg9x1Bwc8Y6P4fW1i3gvSGFnYPMkRilfyI2bcrNwxIznGDzQB4w HhVgYZELHlkMg+c+o9G/nVu3RL2eCGJw6zyrGCB0ywByOx5r6DMVu0Ria2gMbDBQRKAfyH8ulZOo hrESzSXEyGfbDJMq5F0g+6soA4lUdJAPmHB9AAa1yF+xOsYO0KNpAyRtwf6VT+K+h2+t+D55Wjka 909GvLZ41ywwo3LjjKleSOvygjkVoWsIurJl2Jh0JGQT1raZ5fJiLum1cYbgAn056+lAHyYoDqrA gqwznPtTbiIKchyGHXPH+etdX4t0OPTPG19pdiI0heaN4AzbQgmUME54GCW69ABWBqdpPC4B+YSc bpSH7+pOB+nFAGWBGxIWYOQedo7fjSSubZclSpxlcHLEe/oKhuYJLe8bzAVUAPk8/KVBH1yCKz7l 5JZ3kdiu7jJ549B+FAEs08kzAOcICSAP880QxFmJwFXGPmFV4ZCrfIp+pqZjIysFy0hHHfnt+tAH unwb042ngl7lOWuZprkkd1X5F/8AQD+dexaT5dzoVkJEEkU1qgdW6MrIAQfY5Irz3SdY8P8AhXRb HTLnVtPge2tEg8qUsrtgfMdoBOCSTnvmtTQvHnhm30u1hl1RU8qM/wCrt55F2hiB8wj6Yx1oA8c8 deGpPCPiJIbTVdyIAsQikzLHEMGNZV/3SVHByFz3xWTLqYeDbeSXKl2Ko8TFAAB7ex/nXr/xM0rR vGOgyeJ9E1W0n/suBzO0QyJQq7gjEcq6gnAP97pXirxhQwhZiWG1ccHPbFAEMFjZXE6Sx306yDJB kmLc/XqKgvGa3nls7rdLbSbE3227aT1Cn+8VH9RTZLd2di6KpYl2DRg9sk+oP0OKfDrFxYYhgli8 lDhC5KbvqDkA/U0ARG5eOOJhtlVMK0edsgPQ4HbIA68flXdeC9E8N6jok2q+I0v7K3tHWG6lN3sR GZQ8bYAyQykDA6EgDOeOFls11QxzqEsnHACR8Hn7xYcUhkW2by9QRZbNpPMGyf5vMGfnCqMEgMeo 4z19QCPRlhjsrhrm0+1SSgqMTtGEJVip+UckHaxB9AOMmuw0vUvCZkjGreDXETfelttSmm2+5Ryu fwNZiaE0mix6hYNJPZiR2AWMh3JxkjGfuhRx3ByPSmWiJLEHi2PGc8HBHvQBtfCXRbHW7u+t9Ys4 ryJLWKRUkLAB94AYbSCOCa9G8FWNkviSCHS7WG1srUTXiRRLwuf3SHnkk5Y5ry3wNdz2k8xto0ki mhEE/JXYpU7XGOpVscd8mvR/Cd5FaeLZDJcHbNZbApQqV2lcDkYPOelAHQfFfw3c694ehutJfZq+ lO1xbneELIVxIoY8A4AYE91x3qnpFug02yZdJ0xJPIQNIyR/MwUAkbUJPIPJxXVXcdpqul3NhfAS 2t3E0MqZzlWGDj39K5bw5pU+haBZaVdzRTy2SGHzY8hXXcSpwenykcUALraSr4c1dQ9tDH9huMx2 9sFB/dMcZJ/oK4T4YQQy+AdMu5C6ix1fzCqyMqBHCxPwPaXOfavQdZG7Q9UHGTZ3AwR/0yauF+Dc Zuvh9d2vH72Z0H1aMY/XBoA9GhItMhUCEcHaMH8+tVrtRc4EzSEqdysrEOh9VPY/oe+adDc/araG 4A/10ayn2LAE/rmmnnjGfxoAzpRJDMZGkiinlIHnldsNyegEoH3JOwYdenP3asxTiUyIVeKeMfPC /wB5PfjhlPZhx9DxU7jdGyMFZGGCrDIYHqD6is+e1aNEIWeW3hJMZjOZ7Y9zGTnevqhzxx8w4ABb B4APT+VNcYOM/rVeK4B8rzmiZZjiG4j/ANVN7f7D/wCyep6HsJ26lTng0ANOQcMfwpA3T6Uh49qQ kZJ5B7UAMY+vpVXUL2CwgWW5L/O2yOOMbpJnPREXu38up4pdSvEshEpje4upztt7WMjfKe/X7qju x4H5Cq9jYvFcG9v5En1JlKb0B8uBD/yziB6D1Y8t344oAjtbSea6TUNW2G7j5gtkbdHaA9cH+KT1 ft0XirxJHTOaUjCkHOPSmtyfT8aAEDcccCgYJBo7470gAB4waAJwacmMcfWok5PNTRqCMYHTPX/P pQA+MZIAyT2A6nPas+5vZ7qWS00lgGQ4nvMZSH/ZX+8/8v1EXnSavI8VjI0emg7ZbtRhpvVI/bsW /wD1HUSOKCAQ2yCOFBhFXt/iT696AKlnZxWNsIbZSozvZics7f3ie5rQtJH8yJNx2CQNtzxk4yce vA/KqzcE5OantABNGf8AaHf3oAvfs3Db4S1tR1XW7xf/AB8V61XlP7O42+HvEa4XjXbwfL/vjrXq 1AGLrhAu4CM+aqHGOeCfSuevJ5dypMysY1IRB1bOOvrXQ68geeHHEu3g+2eawb5YJSqKUV8EIfT1 /SgDyXUSD+054Axz/o0ufrsmr6Sj++K+b7iL/jJvwIWY+ULKVoi64J+WYY+tfSMf3xQAN94fQfyr y79ppS3wS8QgDPzWx/8AI6V6i33h9B/KvOP2iYxL8F/E4ZsBYUb8RIhoA+Bh1NFHelFAHuHgv4IX +taFpWqHxDZW0F7brcCMW7u6K2eDyBmunl+Baws0UninGFB+Sw69fV+39a9F+F5P/CuvCfp/ZkPb 2NbetMVlgfOArbT24bj+e2gDwvW/gqtnol/Lp+s3F7qMELSwwPbKiyleSuQSQSAcepwKg8H/AA18 OeIfCtlqsOq6q32mIb1VYh5Uq8OnQ9D09iK9ouJShDKSpU5BHY15nYSL4N+IV1prLt0PxDuvLJR0 iux9+Iem7oP95KAKknwm0HLpFd6pL5RX5XmRd7dSoIXjgj8TXM/ErwVoOgeE4tR0X+0BdPex2zi5 uN+wFXYgrgYOVFe0WyYgBMmTyzN2Zs/Nj8eK8/8AjjCp8J2UzKRI2oxKWH8Q2SYyO+PWgCxoXw38 J3Wi6Xdz2V3LLcWkMrk3jgFmQEnA6DJNXv8AhW/g9c/8Scuy8/NdzHI/767Vp+DbgS+D9CZJCClj CjgcEMFHGK1HkB+5wAT0OfzoA5qTwJ4XRVktfD9s7IuDC0sh8znsS3DenY9D6iNPCfhSWwu5LbQd PYGYxxsyNlc7Bt5OQQWPB5zXTkgDpWPeiY6hOLHIna6gE53AKw2IwUZ4EvyHB7D73agDkfBuhaZd eKvG1nNpNi8Fve7IWlhV/s0fmSjbGp6EgADsMZ54Fd5D4d8PrsVNB0hdo2gm1Q4GMdSOfrXJfDoo PF3joQo8cf2pcK4IYDzJOuec/Wu8zjAoArro+jox2aNpQ9xZxf8AxNSrp1gjsV03TxnGP9EiwMen y8Zz+lPBxg09eMkfxc9fwoAclvaLgrZWSn1FrH+f3anRYweILcfSBB/So1x1wKkBoAyPG9st94Q1 GzYiJZhFEzxxruVTNGCw+gyauWmltdaZH/Z8saRxlQFlRiQFxwwHIPHTH51L4isBN4Qu7mWQxr50 W3BxlQ4Dfj6f7tU/CL+IEvg1/wD2RfaMEEBS2ZoLqB1HTr8465JPuMdKAPRmlIVjIU81juIiRse3 UcelcrHo9hpBl/suBLaFnZzFECFWR/vEDOF3YAOPTHSpbRPEh1WVrvUtHk0EswEUVvIkqx84JcsS WHGeoPt1rbtdP87TZwEEfnDKjHQ/wk/570AYQPHpn9KF+e7PUiJdo/3m5P5KB/31SIy7SzEhQNzc 9AOv8qdboVhUuMSOTI3sTzj8OB+FAHK/FtWfwFcqoyReW3A/3zU3gO3kfwhp93p5SO+UyxOJOI7l RIcJJjpjPyuOV9xxVf4tjPgWYHgG8tuv+81Xvhc3/FHqr/eW5mXj1O0/1oA6ewuo7uJmRWjkjbZN DKMPC3XawH5gjgjkVkeOWQ+HijXE0LPNHtMIGWxk4598HP09a1tSgeTyb1JY7S8hTy0uJeI3Tr5c nTcn6qeR6HB8TLPqPhmDU4o1+yFPM8sNvIKSYYhhwy9we454oA5Pwp4b1WeaO5t7+6hjjfdM91Zr EcDrsLnexPQjG316V02v+Fry61u/ubtdavbGVR9ji0/ynC/KAFk3EMuG5yowfUdK29C1CXWtHAik Euq2X7yIyN/r0HWNifUZH1wa6/T5ImtFePzVD9phhlPoR2x0oA8F+I/hW88PNpV9LNK8N9AsJLtv aC4Rc+WT3+Xoc8bWHTFcS6FFEdxvBIO1Bl1b+6ADjA/PpX1N4r0WDxH4fu9JkIQyrugkP/LKZeUb /vrr7E18rSiTzHjuIfs9xCzRSxc5jcEhl59waAM+7Cg9mIAGO3HA/L0rPddzc5Zj2HU+la80IOPT 0FR2FmJNQQkYijYM/wBAef0oAq3NnJazCOTaHBO5Qc4xx1q5pMcz6lbQWamS4mcIiDGScjBz2Gec 9KsBLefWIRqk8lvZvIonljXc0ak5Ygfj+HXtXselWVjHa21l4Xt7FBd3ASSS1AZplRS4DzZJJyBx 3PpQB5wftlxf3M6C0k8yVnZZ9nlSDJ6lsEjryCCOMY4rS0s7prBYjEsTI0iPfXCL5a7iMeY4IyDn kjOMd66C9+GOrvds9hLEdNuFNyHRiFJK5ARe7E9jjBJ5q7pPwu168s1Et1Z6cY9zKkjM77jjAO3h R15BJHpQBjaBpWq65/wl2naHPa3E9xZ7HlhdY4rpd4PQKFL9VDgLkE54wa5axs7mCeaO5ikt7iM+ XJBOpDxn0I7Gvon4c+E/+ET06c3JjfUb1w87RuzqiqMIgY8nHJJ7kmmfEjweviWyM9nFEmtQJmCf p5wGf3L+oPY9jQB853tjMzNJlXjPBGSDj/Csu5K2TosW/eybnf1GeB7YrpEcTwB1DL3ww9D09uci mWp3JJuQYfPDdqAOOjiF5cy78NMqZXLZL4Gfr/XFS2qzwwShbVJo2OWBkDlQOM89B39asy2gfXLl o8KVbcueMrgCrr2abkeJTG2M7geooAp6RrFzpt3u04vBIMB4JMmOQAcKy54x2IwR2NdVcy2es2r6 tYwNFf26iS/tNwEjx9DKjY+Yr645HDDOK5edNpiXhisgXdjsOeaksbye0u7eeJpYLm2bMTYwUPp6 EEdR354oA6jwpBFZ6FZXt66W1pdGQm7YfIhRiPmPp/jXpulqL20s72zYXtmwIFzatvA+u336jqPS ubsdFmm+HWkw2jxtE1qDNZyvhJQfmBXPcZYEZ5GD1FbnhLw9oJ0C6httGayjulaK6S3uZFZzjG4t nOeTg54oA6lLZSqyOsMnYsMNtPocd/anX9jmx+0woMxHDbR1U/4f1rG8F+CdJ8MNPNpEU6yXKhHa RxhkB4+UALnP8WMmu8KeXamNeu3cR6nPSgDgb7P9mX4HU2s4xj/pk1cJ8DyR4PnKn/l6B/8AIYro vHHiCTQNautKXRpZong3xzm6VFKSKQMLtJ4O4fhXH/CTV7DS9KXTb+doJru4HkSOuImYKq7C/RWJ 6Z4PrQB6HYAJHNEOBBPIij0Unev/AI64H4VN34qMgx6nOjDHmRJJyO6ko36GOpscUAMHGO4HbNEh HRcgelOI4GefShgfrxQBRuLbJleFY90oxNDKMxXA/wBsdjgfeH4g1WilaHeAJ5IYh+8hf5p7Ydv+ uqehGSP9roNRgcccVXuYVm2Elkkj5jmjwHjz1x7eoPB9KAGKyvEskbLJG43I6HKsPUHuKpajem3k S1to1utRlXdHAWIVV6eZIf4UHr1PQVkXmrzWuvnSIIIbfV7iTCSOwNlOWUkMe8c/H+rP3j1yMGtf SYLeCKZITM1yWDXb3A/ftJjgye393Hy4+7QA2ysRaPLLLKbm+nAE9ywwWA5CqP4UHZR9TzU5ORx2 qQg89OvY5qM9O9ADDx0z+NHpjP4+tLgGkOeQfzoAaTk8fpSd+AKXjoOcfnUF3cw2lu1zcyCOJOrY zz2AHcn0oAsbxEjyTOsccY3M7HAUeprPQPriAyrLBpHVU+7Jd47n0T27/wAmwWkupyJcanGY7ZDu gsXPfs8vqfRf8naU7zk8n3oAfGqKiqoVVUBVVRgKB2A7U9lypPIz0pi/n+PWpdvXIAoArOp3lu+N uPxzU0I+de/zDpSFW3HPHenxYEifXORQBqfs+lv7C8TDkgeIL3kn/aFepV5b8AcjS/Fa84HiC84I 6cr0r1KgDK1iISSRsSQi4yR2+bjj0rD1qHzrTDZAz8zLgbBnt9cVuaidt6jbSwEfIAznnisbVCJI WYfdUhivOW9KAPHW8xv2pvCRlkDP9gkJBXgDbNwPT619Ip98V892Uh/4am0RXAB/saVeR7SHj/Pr X0In+sFAA33h9B/KvP8A4/Okfwb8VmQAg2m0A+pdQP1r0BvvD6D+Ved/tCuE+DPiknHNso595EoA +A+9LT7eF7i4SGMZkdgqjOMk9BTXVkfa6lWBwQRyKAPtz4W/8k68KZ76ZD/I1ta2nnFoySobK59O Ov4VgfC2UN8OvCmw5A02JT9Rnit/Vzlxz1PagDEkkMkSuRgsMsB2bof1BrkfH+iSeI9AeytG26jb H7bZyDhkmX7qg9t3I/AeldS5IlmUEAMRKM8cNwf1BP41SjYndOCwMjbh2wB939OfqaAMvwj4iXxL 4bsdTUbLkjZcxgY2TLgMMds8MPrXN/GuYp4Qsiyhj/acR5Gc/JJT1X/hFPiBziPRfEx3eiw3i9fp u3f+P+1VfjaSPCFopHP9pR5z1GI5KAOg8Jlrnwf4fuYNqXAsUXDH5XAJ+Vv6HtWzbzrPGcK0bKdr xn7yH0P+PesPwA//ABQmg8j/AI9iv5SMKvaktxcShNLmW2vIyFluSoIROuzHIZzxjP3QcnsCAW5Z HeR4LZtjrxLKv/LL2XsX/QdT2BgSNI79IY12xgrKAD0xFIMk9SckZJ6mpbOSJojHDGYfKO1oiclC fU989c96jxnW244FoCfqZCMfkKAOT8GiQePfHZt3HnLdAmNzhZR5j8H0Po3Y9cg13UE6Txl0DDad jKwwyN3Vh2P/AOvpXEeCDjx/49BI5uAcD/ro1djPCzSia3KrdBdp3H5JV7K39G6r7jIoAuDnHQY4 pykZ5+vtVa2nS4RigZWVtkkbj5o2/usP1BHBHIqwvbrQBKDwDyMjuakRWklSNB8zMFA9M96gzxnN SabcRf8ACS2NlOyIk0blN3G+TnYo9+D9TQBveJY7e48P3Fmw2wFRGACV9u341xelQLa3Flfw+Ybu 32iXJZ1HGCp6468Z4wcZ4xXda0mLFwONoIZh0zj17fpXH2V5pyyRQpf2jSAGF42u4+OeMqxyeMfl mgDvIYIZv3qIhjOONuMY7cH+lX2d38tEHcdM4rO0shYkjcKsgXbnkFgOhwf8K04sqc43YOTnv+P4 UAcKby1mQbZFZWkO/aCSAGOR+Yx+NSHUoQSQJGPrtwP1q3YeBPscMyf200iSTSToslpym9ixTIbk Ak81T1HQb2xDuu25hXkyQ9QPUqeR+GaAMzxHFbeJdFk0y4M0ERlSbzIyC2UJwoyMc59K5rVLq88K 6fa2mi3E8NrK7l2JVnMmF/ixwNo6D0rpIZfKYOp6DvzVTV7NdW0y4s+RI+DC/dZB90j+R9iaAPNt T1e5uCZbu5kmYcKZHLHPYDPqa9p8O6ksb6HoFxbySaeNM8h5ZBiKS4CpuhU/xMAZNxBwOlSeB/h7 p/h6JLi+WPUdZkX5ppFBjiHdY1PA9Nx5Pt0rsbmxt7uAwXUaSQ8fIw+7joVPYjsR0oA8tns5/BPi mEeY5spDlJM/eiPGfdlyAf8A9VeoWzqVbjBPOQM5/wAazvE3hqXXNJa2a8kluI1aS1d40Taw7FgM 4YcHn0PasbSdP8a+XHbA2enxRqE825VJHOPZd2T9cUAd1AqsMkcnoO1eO/E34cazqPiO/wBb0VLa eOdEaW0VykzSBdrEA/KxICnGQTXqNto1xtA1LXNSvG/uxsLaMe2IwDj/AIFWraWlvaweRawpFHng L6nvnqT7mgD5DfTp45JI54zBKjbHSThkPoV6g1Zt7aOJCoBy3DNivoX4leC4fE1g1zZKI9ct4z9n lGP34HPlP6g9j2J9MivnRbppAJIy4Dc4Y8j2+vb8KAKNwu6V3XncxI57V1HwejMfxQ8O+UzIHmkL qhIDgQueQOvOOtYlrBc3l7BZ2NvJc3c7bIYIhlnPt9O56DvXpPg6yh8LapaXt3Abi8hZjMYiMrwQ Y0J4wCeT35oA9Tmgn0u7lgTe2nSkyQjGfKYkkr9M9PrV7QS32WTuVYAfkP65rn5fiNoTjyru31KD sSYA4/NWNZFh8TvDu57aBNXfaxLu1mI1UDru3MMY6UAelu5IAiG49+gxVPUr+701IzYaTPqdyQWK xzRxKuMfeZyOv9DXHH4h6csZeGy1EqCOXREJ+g3E8+ldjaTyXFnbzy2z2s0yhzA5BaPPRWxxnFAH zHepd2eotb6lavp92JWmkgkQqQCxY47MMk8jIOKqXJdJ127lfHUHI2gD/GvqHXNE0zXrT7LqtnFc xdVzwye6sOVP0rwzx74KuvDFw1zEWutGkIRZ9vzQkn7koH4YbofY0AcVJNIw/egbU6leRg5PTr/O pAN0AeMq6sONrA9OPwNREACUkdW6fTtVWP5Lhtsmw+WWY44LYJxj64HrQA8fvZTH8hyRnPT3pbm2 mkvBHaRmVm4MSDPIPX2H6VpeGPD2o+KNQWC2RLeFcGe6cZWMH9WY4OB+ddvq/h8+GlitrPabaVcL cFctIR13dAD7elAHQ+Db6PTvBejxajJGrxo0TxPIrbgCy8Z69ula2gi0t5r0Wk8JsXcyQmFtwCnt 7HORWf4AubXUtGk0PUkglnt2aSHfGP3kTHcR9VbPTsfarVr4avtDvfM0WWG4tmBxb3RIMZPI2uBy B2z+tAHX2CCTdM+3bgHcp6+2avpuyXI5ZgRXP299qjxt9ttIrUxg7ghJ3f7ueDmtmxhkEEcaq5Qj IK4JOecUAeffETwjqF9c2tzoNkstvbpIGjWfMjFmz8injbx0znJPFeO6Lbo+jzWeoW7YErRTwSKV ZDxkFTyCK+rtoDEccVzHjrwTZeKYxOJGsNXRcR3sa7tw/uyr0df1HY0Aed+DdRmvNOtoL6QyXem3 BsZZW5aWKRMwufrsVSfVTXU/U15vpKalovim6s9Ut1gmNu1uzKxMbyxMJoiCemdpC56769LbmRiu Ch5B7+3H0oAjxxS7uq4980p6daaclgFBLHjgdaAGlePl56D8ay7m6murmSz0t1R4m23N6V3Lbn+4 nZ5fbovU+lElxJqjvDp8zw2CkpPexn5pCOscB/QydB0XJ5F2GGK1t44LaNIYIl2xxoOFH+e/egCq mn2kOmvp/wBnSSzfLSRy/P5rE5LOTyzE87uvpiq13GUKu7yskYIjuV+ea3B6hh/y0j9Qcn1z94aT Dp6VHkhsqTk9KAKiXHzRxz+Wsk3MLxnMdwMdUPrj+E8+m4c1IxyASfx9qhu7Qp5yRJGySHMtrIcR yH+8P7j989CeuD81V0uTGsjO8ktuhxI7r++t/aUdSP8AbHbk5HzUAXP5d6Q89qUHIUqQynkEHIIP Qgjt71T1G/FoY4Y4zcXsw/c26nlv9pv7qj1oANQvYrKJZJw7Mx2xxIMvK3oo/r2/nWtLKSW4S91U I1ynMVup3R230/vP6t+VTWNi0EzXV5ILjUHGGlAwsa/3Ix2Hv1NWj3xz2oAfGctnPep1A59O1Qx8 4INTR8jqR+FAEqKV4NSKMgZzUEkyQRmSVgqDqW4qSzvILhWMDhscEd6AB/vk8/iadEeh4601yGOV P605OoOD+PWgDS+A/Fv4wXnH/CQ3fX/gNepV5j8ElAHiwqMD+3boHnqcJzXp1AHN+I59l/EitiQx /KC2Ack5yKyb5WjRHUkNnhQeDxV/xVEJNUtiGZXCDkLnjccioDblmT5Y2RlwSxO5T2x27UAeX6Yx P7UWigBmA0SUEnrj95zX0Gn+sFeA2ShP2pdJVcEDRJgTj3kr35P9YKABvvD6D+Veb/tFNs+C/ic5 YAwxjj3lSvSG+8PoP5V5f+0y234JeIiO5tx+c8dAHwlAxSZWBwV+bP05od2kfc7Mzk5JJyTSwHDt kgfIw/Q0swi3IYiT8q7vlxhsc9znnv8AyoA+zfhpiDwB4Tcfcn02FG/2Xwdp/Hp9cV0urDKKfpXP fDdVl+GnhaJ87G0yIHH41uXkhNuBJzLGdj4HU9j9COaAOc1t3jNltI8uWf7NMcdI5BjPthgn/fVN bLNjp347e1WrpRceeD0KmJD/ADP/AH1j/vmqKSF4hKw+ZxnHoe4/MGgDH8Z6KviLw7daYCEuSBLa vn7ky/d+gPKn61514z1t/EPwt025uFK6hb6klvexsMMJUjkySP8AaHP1z6V6ux+bIBz614/8W9Oa w1aW8tC32LUGV7qNR8qXSq3X0LKxb8/UUAdx4BleXwLosNsxDLCwlmAz5X71+Bnq59Ow5PYHpYkW GJY4V2xp2ySfUknuSeSe5rnPh23/ABQeh/8AXKTH/f1/1roCcjk4GKAEnhMjrJE/l3KjCuRwR/dY d1/lVe1ufN1i4BUxtHaRq8RP3G8xjn3BDDn6Vb3BjwePWs9o/N1KWZXCTASRxyYz91YeD6ry1AGD 4OwPiJ47X1lB/wDIlduCCwzmuC8Gu5+I3jUyIEYlSyg5wd4zz6V3Kt1BNABPCXkWWBlS6RdoZvuu v9x8dV9O6nkdwZbaYTo3ytG6ELJEx+aNj0B9QeoI4I/KhGAIyPwqveg4je3G7UACIBnAcd1f/pn3 J6jqvPBALjy+UqALvlb/AFcakAse/wBAO57fpWN4l8K3/iO0hFjcD7TFKHmffsAX+HyyT8pU8j1J ya0NPcmKU3DA36KBcgDGDzjYOf3Z52+vU85roY7mTT72CDYu5J/s8qBsiWN4WdX9jvCj2yR0oAqW 1/4xitvs194ej1E7VQztOqFsAfM5VsE+4Ap8sHia8hEb+E9CK8ofPuo36jHT19Oe1dZBLmNd8RjP uc49quWx3ytjIzg5FAHGWFn4lgYRW3hjSLLaP9abhSqcn7p3E49hwK6TTtP14j/T9WswnXFvaBm+ m5uB/wB8mqnj7xNF4Q0MXZUXF3O3lW0TnhnwSS2OQigEnHJyB3ryPXL/AMcGx0vV9T1O9W31N8Ws NpPtx02/uojxu5wOTxycnFAH0HFGNoXk46sxyTSlUaTAyHBwK8l8NeJvEnhzX7PSPGpujDfqhjku nEjwljtDBx1AYgOpJIznPr6kkrG6nUrtZFQHPZzuBH6CgDzn4iQr4fkGowW0kmn3DKAqMo8uRv4e TwD1HBxg1leBL5tTt7/ULtPLltJI1ijVjtUPgZPqct9B6V3HxU0htQ8FahHFkzWRW8jH94ISSPy3 /mK4DwSog8FapcLgmVlm5I+7HNGP6k0AesJegyEYUKPkGeccnsPWtCIkjDEqfwH8q4a31IQ+JtUt JQWCSAxjBZsOgbAA7dR+GPr2NjITGpSOVkx12YC/nigC/CrNMVDFcRnp15YVxHjjxjfWerroHhiD 7TqrYWSTaGKMRkIikgbscktwua7vTmXdJI/Ayoyfx/xrwnU9Ia98f3djdXkdhJNqUg+0ygnYxk3o RjoxUjaSQM45oAt3ms+NtI142N3eai9/kEQIBMsoPOVULgr24xjB6V3/AID8Xf29YH7UEW6iABde A/Ug+2cH8QR9eJ0Z7q4vrifw1Bb3PiCx8y4lvY3DLckmVmJ2lGfezINu0qGQc4IqX4X+fLNr9/Mx czBFfICkyNIXZiowBjrgDjNAHreTuwpIYLkH3BNfP3xj8PRaJ4qivrGMRWerK0pRR8qXCkeYAO24 EN9d1e9wTefbJc4wZI1bHuQTj864X462EVx4EkuWOJrC5jmiPrn5HH4qSf8AgNAGZ8DNGt7fQ7nX G2te3UvlBiOYoVPAHsxBJ+grI1izvTqsyx2t6CWYriF/mG48jjkc9a2vhfdG2hs9MYkC4sVZAR/E Ar/yZ/yrvbuWQRSQ7mQA/Ke20gCgDypvCmvuDt0yd1Yc72QH9TWpofw186NLi+uUin3oZra2Tdlj jHzkkcDPIFei3LbIbg8Yjjkx26DFc/40vJ9N0XVTasVa4035GXqrpII2I/4DKPyoA52+8XeF/D1y 8GhaOdTntW/e3i4wjFsf6xgxOTxkADPStnwn8RNK1rUo7C4imsLp8LH50gZJGPRQwxhuwyPxzXn3 hua9tfDFxpmoQmDQ9Sldkkk8pDcbFKsqF8DaT5bBiRgqQPat4vv7E6HZ6JY2cO6xnmlttShURrLE HZA64J3lmT5mzjKgigD3wSBSkZ4kCnk9sf8A66h8uC+sZbe+iWa3nV1libkMjcEflWJJeyXdvpTC R4ru4jjZyh+8Nqs/OO4B/OtmzO4Qhj94c4+maAPmTxDpb+H9d1HSLhiz2srIjk/fQ8xt+KkfjmsA 4BJz068V638edMSHxHpOplTi8tzbuR03xHIz9Vf9K8vsLJtQ1GGzQ4aeTZ16L1J/IE0Ae4fDOzW1 8JWQQAzSr5zAHnc/OPwXaK6SW3tr9DbSJb3kZcJKrMGVDjP/AH1+XeuVsDJf+TY2twLaziH72SE4 kfAAWNPQAdW/Lrx0+i2NpBdJDY2yQxAb3Vc5JAxknuT6mgDNufBUCXcd/oF62nXKbRh4zNGT1yAS CO/cj6VvWenXyxQrda9K5bb/AMe9rFF1PqQxxWo7gZAxuOBx/jTLsrGEXb8jcnb2zwD7igDx7w/4 l8a6x4sntbG6tJ4rZ5ZJbC8EUW6JWYFMhQxI4GR0OCeKmg8QapPbzanC+p67DaxsmoafnyrdVWIb ipRQARI4GFLlkXI711vjX4dWPiCVr61uDp+quMSyqCY5jjaSwHIJGQSOo6g1y2k/DTxZpYuk0nV7 SyiukWKVoLpo96qeB9zI6npg44zQAfAu+um1TV7a3DLpSwm4S1EjSpC5cYCFju5G/vzj1FexwyrP ECAAT2HPGM5+mDmuS8JeGx4I0O7MTR3l7IRJNIVKq6pnEanORgFjk9Sc10FjKogAQ5+bA+mRj+dA HC/FXTUElnqMQy8hNrOrD5ZFAJXI/Bhz7Vx3h/xRNY6cyajb3VzFbfum2kNNCRjAySBIhGMHIK9O R09e8aad/afh67tYcmUR+bFjr5iHcPz5H414gLkGFnl2+QEB81W4H1FAHW6X4w8P6o6RW2pxRTOc CK7UwNn0+b5f1qaQPrWV/eQ6OeGblJL0eg7pD78F+2B18f17TxOrX9pAfIkHzqq5YqOrFT646dcD 8t7wR4n1HTjHY34e405hiJ3feYjjohznbxypzj2oA9RwqqqKgSNAFVVACqB0AA4AFNJ496z49ZtH iV3bZnp6Go11qykWQrMoZe1AGg/0qJ8/4GqA1u0IRQ43t+lY2teIltJY0TDHBJ5oA6Qk5ORVa8CA LP5rQzxjCTJ94Drgj+JfY/hg81ysfisvO6yFQvYdOay9Y8UzS2UsNqVEiyANP1EYx0Hq38qAN3VN Vn024WDSY4ZL9wWksGI+zkEZEsbkjy3P/PM8N3HRimm6xYW6SSWrTXFxKSLmacbJi46o6n7uOy9M YPIrgp7qQZijYm3zkqxyWb++T/e9+1LPezG6RpJmMgXYsvBOMdGHcf54oA9SbVrYad9pLgjGcZ5r Nt/EEBnDNKDFIMgf3favOjqDJYmF8q2MkA53e4qCxc+ZkdxyO3SgD1W412BJGjiYF1xkn1NU9Y8Q CNB5bk8gnFcX9ojiuPMZgy4VTg9ajkljlyS2EYjac9BmgDo7vxDcXimE8ICAo6Zqax1MxRSMzDeC VUDqB6f/AF65iRz/AGokNnBNPNuAVIlLs2fRRzXQnwd4tuIgYtDmiVQW2TSRxttPcgtmgC7oviLb qCRyMQr8EMa6+5vkhh8yLDqfT0rxrWdN1LTJIRqdpPZ7wGieVCFcEZ+V/un86v6Z4gu7IjzpPOgM XlmMjoMUAe8/Ax/Ns/FcoXAfXbkj8kr06vKP2eLhLnw/rk0alVfV5yAeoGxOtesUAc9rlwItQUTR pLCIw2CcFTk8is6+kWWCM2TZwMtnqo/rWl4gWF7jaSyzbFx+73BuTx+HvXOkSLeSxOCskK4b0cc8 A0AefaVI0v7UmmNJt3f2JL93/gdfQaf6wV8+aQB/w1NYbh8w0STkDGfvdfw4r6DT/WCgAb7w+g/l Xlf7TzBfgj4gBPJa2A9/36V6o33h9B/KvHP2r5fL+D14v/PS8t0/8eJ/pQB8W6UYRfIt0jPA4ZH2 nBAII3D3HX8KZerbpMv2OSV4tqnMigMDjkcU7THgW9j+1krA2Udgu4qCCN2O+M5qs4wxGQcHqO9A H1T4C8bWdr4K8OWjQytJBYxRt8vGcdav6t47HmRzLA0aDMb5AOV52n8D/OvNfDU5i8L6WI8bmtIx +laWpeXLZrlgNq80Ad5H4isZrSJ7eQOpGzH+fzqnFrVubueF5ABu3jPH3uv6g/nXl1pftZ9PXIyO T6U291P7TLuQ7D0ZvQH+Z6UAeo3mrW6NIkVwqsoBeXGfLB6Y9WPYdup7A8J8S9RtL3wZbR2GQiX+ 0pySf3b5Jz1JPU9TXNG5Cx4RiEx0Jz+NZesXBmtlRCWAkzj1+UigD1P4ZapBc+ELW3DKtxZM8Uik 9QWZ1b6EEj6qau3mrxea8azqrEHjOcV5x4WtTeW04tJGiv0i3x7WwJVBwVYfXbg9s56VTjuHVfM3 MWzznsfegD2XS7yCe2jSSQbh02kc/UUxL+2V4HkfAaS4/Xp/6CK8qs72ZCSJHWQ+/apDeSoiCWUb lJ+8emQf8aAOs8OBJfiF4vnjmERYhoZM9DuXqO4NdlY38VyZUJWOeHiRc8Y/vA9wa8ke3a1gtL+G Zg94rLLz1YMcH8hiqr3lzsMRnfdkkEMcj159KAPZrjU4IOBteU8ogbAPuT2Udz+HWqy63Y2yM7yG WRwGaQDlj2GOwHYf1ryW31CdFZWkZmIAJJyeOn4VYSZycB3GeSM8UAerJqltez28EjPa3rsEiYDn DEArjup7j8eozXT+Kh5M1rcNjdFq9sgYdVWS3CMuf7pwDj1ArynwVJNfeNdKeYh1t38456AID/Ui vXPiJbFPDLsuVYXFnNwM52OU7f8AAaAOggZnGWYdOmByfUmr9g/+mRpzyCOnOeorB0h1C7SMBegz xWvagLf2nTGWH/jjf4UAef8A7QkErW/h6eNXaKNp4SB2kZUZR9SEYfhXKJ/Y3hu20t7S907Xfttr HIEuAUS1ZpZGcsGjcRxE7VZeHypb3r3nVtLs9VsLnTby3imtJ0AMb5A3A5ByOQc4ORyDzXl1/wDB 9WlMuna0sds55S8tyzp6hnQgN9SKAOXv9D1E/EDTdB1LUl1C5RrOFXicMsKALlNo4UqFb6jDHrXv 0b+ZqF7JnLCVcjjjC5/qK5bwR8P7HwpdNdyzm/1F1KiVk2JHn721ck5I/iJzj0roIiYta1BduEMc Mob1LFlbH/fH60Aa1xCs6SRuAwZGQj1BGD+hrx34eWCnwbb2t0w2t9qhZh/cLFGP1HDf8Br2eM4d mHBDkf0rzlLcaJLJFKgS3jvLkkZ48p5S35bXJ/CgDLsTNJ4ruVmIlb+zoFmQqSA6fIc4I9CevfnN egWibbdFjQKAMABcAfQVx8cKr4i1eYyR+d50cJSXcAdkagsCAcnLHOe4rqbCVGkjUXiHGBsWNuPb OKAOisUAhkBAO0jnA7KK57xf4MtfER+0bhbXwUJ5wXckqjoJF4zjsQciuitmCo5APP8AhUyOhA2u D0BGeR9aAPHH+GWvLIywzWKROpieRLpwGjJGQVC7iDgcZ5xXaQ+HbTRPCM1lAWnkt0e7LhMF5VG7 OO33QoGeldbuVskOCPYZxTFAmPllT5TEKxf+LJwQB9KAMnSJkNlAFBaNQDgHttGP51z/AMVcTeH4 VfmCS4dZB6gxuB/Wr3hhDBo0UTHcVlePJHYSFVAz6KFH4VV+J2B4QJxki4RsntkN/jQB5+lw+g6t os28j7IkRkxzvjA2v/44xP4V6P4hnjltZnSQSIvlouOgLSgA/jkV534phWI6TdKvyzQDcOoLLgH8 x/Wti5u3XwVLKnzSwyW4JP8Aszx/0AoA7jVmH9nXL5wZHZMZ65kC1napZrqVzFY34LW0ss9vmPrs mic8j1BRSO1T3U4m0KxlRcJKySg/Qlj+oqW6LRyxXMbAOk1u7+pG8DP5MaAPH/EGn+KNG0l/D929 3LpCSlo3gBaOXJyAWGTgH5ghxgk9eK1rbTtf8cy6VDf6bHY6dYxBHuDCI3kJx5hHAzuIztUYB5Jr 2CS2t7xf3kYJI2N3/A+uOorC1Lw3a28iXdjc3EE4kXiOTaeSBwR0HJ46UALr8C2Vxp11HlR5jWhG MgeZHhP1TGfetBJAk8aqFbYSpYd8sFz/ADq2xZ7C5kucLBsO0Hq3TBP44xWMswMkCfKS9wArK24O uWfP6YP0oA5/432huPBbXCDLWF3HNkDna2Y2+g+cflXk3gXSje3l9e7kEdlau2T/AH3Gxf5tXufx AjjuPAniOKU4Q6fIxPoVXcP1Arx/w+JLTwHNNHgSalcMpB67YnTB9gWz+VAHW+Do91pcXzptaaUn b0CgAIAuecDb+tegadB9nt2ZsB5MFjnnHYfgO9cV9rttLtILeSWNfLAEjn7uep59+a7m7uIVMbpL GFlKskjOAjISSCD0xgfrQA8DfNGAQsakk7RnbwcZ/HFSSN51x5NwPLuFAYJnqMdVPcfSsCy8X6JB eRWtzclJWBkllCbo1JIAy31OM4xmtmeXTtRElvHfWcny7oZILlGaN8YwMH2H8qANDBZRngkYqVCX QnoRx6VDDJI0MZ8tnbYuRtPJwM4p6TROdpk2uf4X4zQAXAzAwycMpU49P8KytIOVgErEmPG/PX5Q Sc/jitSZ0KMQwZgOF9a58tHpt5qFqrNIyhHXP92UsTz3wVK0AbloWeOJs/MQSSe2TmvCPHGjLpvi q/jQ+XAZBdW0aLhV3c5I6EhtwHoAK90sHPkM0oIK459eM/1rzz4vWDZsNRCgAE20h7jPzJn8Qw/G gDzOaSR2Zpo/mJz5sHb6qefxqEfZUna6NrC28ZaaLjJ6ZK9M+/FXzHlwV4I/A1QuIRIrkfIWz8yc Z+vrQBoWt5CLR/LMNwofZNBIdu4Y9eqt3DDv6iqd1pTJBJd6U01zaISssTj/AEiA+jr3+o61EJJ9 sayRp8qAb4uGx7r/AIVNYanfWMxlP79txUOWG/bngEcBl9uo7UAc59rbfvEhxjGRUE9xJOwYsWI9 T0rvr7RdP8S6bdanYlbOa3JF0/Tymxn96vBwezcH615/eWc9vLGlwrxxSLujYAgTD1U+n60AVZJW mJ2sVj7v3PqB/jTWbCCNeIxyFB4FWpY12bSo6cVSx/ez+FADyxIwOc8momdgwIOCe+aeflfgYFNA LM4P1oArSbj8pORnp6VLC7RnJPy4+9/jQ4w/ToemaFbgbeDQBJuwenTpmuo8DeFLzxVeMFdrbTom xNcYzk4zsTPVvfoMj1Arlo4JrmeG2so2luJXEccS8ksegH+fyr3r4W2n9kyazY27rNpVtJGIyQfN 8zy082QjtlgcrjI4x3FAHYaBo1hoditrpVskEXdgcu/u7Hkn9K2Ui3ZCpk4yTjOBVO4nt7a2murm eOG0hQyySseEQDJP5V4Rq2reI/ifrL2WlQTppi/PFZh/LjjTOBLcN/ePoc46AHGaAPf5rWO5tJbe aGG5tGG2SJlEkZHoV5FeJfEz4cDR7abWPDqO2mIN1zZ5LG2H99D1MfqDyvuOlE/Cbxdo5W80S8sG vU+YLYXklvLnHYlVUn6nmuw+GfxBudVv18PeKkEevR70jldNjSkZ3QypjCyhRnjhx79QDZ/ZnH/F I6oe39qS45HPyJXsNef/AAo0m00STxPYacNtpHq7vEn/ADzV4YnC/QbsD2FegUAcz4lRkv4poyRL 5e1AD948/wAqw5Y3DgHgp8qjPU4PP05rq9chguyIWZkuETejAZwORx+NcxMJY7dgysy7SYpTwqkZ 5/8ArUAec+HEKftRW5Z927RpWHtyeP519Cp/rBXz54dn3ftN6fndhtDmQZGDgOxz+OK+g0/1goAG +8PoP5V4n+10cfCUD/qJW/8AJ69sb7w+g/lXh/7X8m34UwJ/f1OH9FkoA+L0p8jl33EKCeyjAptF AHqmgnOgaad7bUgQnqeMVsXUg+ysVBwR396xNALHRtMjA+UwKzHsOBjP4/yrXndnXyIgSyDdIe0Y xwD/ALR9PxoAwplYTbV4YLuYnsP8fSopImBC/wDLM857/WrMjNuKMMbc4/Oo5AYxtxjJyP8ACgCh eSHcVGcn9KrXcZW2UZBJbPPptPNW7lcyu2OBzxVLVCVt43O7O/HB5HBoA1NBurjTbqyv7PBngcSo pHDjup9iCR+NbvjXS0F7FrOnqTpWrJ9oiK/wSfxq3oe/1zWJDGy2Nu6KSAoOfw9a67wteDUtHvvD Vw3luwN5YSHjy5RyyjPY9f8AvqgDlljAiUgsHA/CoI13MrOe/Sr8aSTShcEPt+YY6etVmAVV2Llg Qee3PU0AbeoGGLw/oyhQ0pLNgdMbn5rHjgM0n7oHJPfqa1ta2HQNGdR+9cP5jevzMP8AIqhbnGMN g9j3oAgeIhhn5SDV63O/5W4bHT1+lTXUUAhDo4LHsKgjUFlA6DpjsaAPQPhJp5udX1SVR80Nqsan 0Z3zn8kr0f4lpLN4Fini+WWOWDfj+6ZEzn23Ba5D4KQZg1OZ0DbplUHHXav+Lmu7+IDi28CaxtTz fKtlYIxOGPnLgE/h1oAz9JlGGwwCD+L19fpW/ZXIMyMTloWIYD/dIP8AWuCsPF/h5Ll0ubtLFGY7 kmlXBHQgODnOORkdRz1q/ZeLPD0c28+IdKcPFskcTjBZd4DegyNp/EUAelB1mmG1seZF1zg5HKn+ Yp3mZXzAuI3+WRByB2yP89K4h/G3h+GGFm1OG5KF8rafvsKO+RwOxxnOM+lbEXiawkUC1uLi5DDp DZzSk8dcBe44/CgDfBCMYMbgD8oJztPXH0xn6c1R/ejxFKkkivG2nxAKOu4Ttk/ky8+1VF1lneEx 6Rrjyn5QpsDGHxyud5GKy9Na7Pjq8ubjTp7MvpKbnuWRixW44wqsQFwxGM9qAO2t5VkXCuC27JHf lqxfF0Chkmk2GM5Vg/CtgdD7FQw/Gta0XrIEC5YdOOnJP5msX4jSG38P/Im9pbmKEDHcsRQBxWkX eo2cUcaadLdkOzuwjZ3Y55OcjPtW+NSuzJvk0PXN8fZ7dVReMjHz/MeOgrTsxutrWExLI8EaoZXH XHt/jWlbR7pizvmUfxMMlf8AdHagCnY63e3NurR6Dq4V8rkxxxk/QO4I/EUmpa/JYRrLqOk6hbjB VZXaEBwASVbD9gM57V0NmH+zM0bksHZTnvwDz6HmuW8TSi/8U6HbKcSjAaI9csWzkemE/lQBLo3i efWbg2tlaot4I/NbzpiqFPUEIdx9cd81pNF4gkXL3em2ykfwRPMwHfGdoz+FcV4ZvNh8MSq5C20c drKOn35ZExn8P0r091Gw8HngZOaAMCKxbTpng+1SXDTXQuN7gKTuyWzjA6qT+NZPxITzvBl0Bk+T LETn/e28f99V094C1zbS5wkLNvUnlty4XH0J/Wq+sWqX+k6jYyrlbiB1H125H45AP4UAeQ6hq3m6 HaQz2zGXPmW4z8syFQsgU9nVlB2n1NO8O6pY6jpWr6NNIiSXKGW1eVtnlTLjCHPQEqv4/WsbQLoa t4S1qzOTc2F0uoxDd/yyOVfA7Yzz9BXR+C9DtNUhl1DVbGG5cRzPAJV3fLCvzNg8H52UDOfumgC1 o3irTxp8mmXl1sktZGdPLRp8hwQV/dhuQf5mtWTxlpIvY9MePU31GYxx/ZVsXWRWwDyr7fYj2Oa3 4LswaXfxBY4ktBGo8sBAUePcMgcdSR+FeKeLbaVV1m5kVhfp4guYxMM7x+4DKM9cDAIoA9qlvtTa Rlt/DurI7MSJJXtl2/QGX+dRXNzrYWML4eubmRX3Bp7i3AxgjBCyfNjPbFdDo18upaNp18pVvtVt HNx0yygn9aNSkeNIHiBO2eMtgfwltjfo36UAclPqniG4X/T9GvjAzxD5YolSL96mWIWViQBk59ul TacVa4s9rDaEmuM+zMFX/wBCb9a6+InzDvHG3BHrXI2tr9nvrm3jY4s1is0dvQLvz/4+tAGZ8XL7 7B8N9YY48y4WK1QdyXYZ/RTXB3scenRWFkYp5bS0t40eRD13fM5APXJLE10Hxrle4j8OaPCVM91d iZhzjC4QD6Zcn8Ky9Zt11DVkRiDDJMHBXjC5JP4YGKANTQtAvNSuGn1DVby2tWbKW1q2xih5G9+o z/dHSmeJLfRdFjFvZ6faI5tmbzZCztG+SVjVmyQSSCcY4B9a67w8GlmtlfgSSh/qD/8AWB/OuYu/ D174jsNJvLVrdYOtwzyH925JCsy46bcDg/gOtAHLWa2obUoFCyXcUERiQZO4Bt7H6AHv1zXtFjaa Tqun28slhptzG6RhsW0Z2ORznjI57V594jtP+EZ8IfYorsyCbUkjvJ9oUvtViAR6fKpwc9K0PhtZ Sz6lBqNqrpZtGyXUm9hvnQkFcYwylSpxjjHByKAOy/4RrRCsJOm28TE4BgZoSGH+4R6VIdAtE/1d 1qsI6jbfyEA/8CJrRiKvAqOCRj8ev8+lCOwVkc5kTgn+8Ox/GgDFl0+/iBW31iaQD+C+t0mX/vtd jD9aw9WupDPZWGoWhgu5ATviy8VyikksjHkYLcqeRn05rtNwxgjgdM1j+IBGujxzyuy/Zn3Lzjdu ypB/P9KAL2nxgW0To7MH+cAHjJ6/X/61UfGOmLq+h3lkxXMirtZhkKwIKn8DWhbqIobeNf4EVcH2 HNTypvt5kx/D0oA+chH5bujhopFYqyKxGCDggj8KiTK/xjaRgbhn+VdR49sVh1UXka4ivQWZehWQ fe49xg/nXLEBQwzkYFAFaRm84tsB5x8rf44pJJo1hke4kaJVHAdTk5/nRcTCDLMvLNhFUZLHHQf4 1XSNmZp7k7pv4FHKxj29T70AX/DSpP4hsTf4FkziPyg/QkEIxI7hipx0Hf0r0fU9I/tBXtdThTUI mJ3S4EU6H1YD5JMY6jY31rydo433MyBW7N0IOPbmvW9BuX1PRLS+hvrqN5IyJUZhMqyLww+cE9Rn G7vQB5pr3gm8t1ln0Rn1O0jyZIlUrcwf78RG4/XH51xAYM3y8jJBHofT619FyxXEhQyCxuXT7hYv byKf9lxu2/gRXOeIPDlpq8sr6xpl8s5OVvrcrJOOP4jGCrqPR1yeu4UAeNYG8k+nFI+POVjlV7EV 0Gt+GLuxZ3sZ4dTt1GSYVKTxD/ppA3zj6ruX3rnmUuysOQe4oAgdV3blPU4ANMKgsNpwOmfT/wCv Uuwk8DC9yDQlvLJNHDbx+ZNIwSNB/EzHAH5mgDuvhTocd3dXWr3Ct5Fr+5tyGKt5xHzOpHIKr0Pq 3tXoegwyWd5qd+05gnmv5YftsgBikC7FVZkGNvI4cY56FfumTQNLj0bRbPTYfmWBMMw/jkJy7fix J/Ktbwzg2F2So2S3t0TnkH98w5B+nSgDk/jTrTWngz+z3hktJ724VJ4G+YeUmZGKOPvIxVB27ggG uk8EaJceHvBFlDZRxf2tcLHdXTOMh3cAkdRwqkKBnsT3rhPjzZTQ6Do/lSn+zhLMi2xGfIkMf8Ld QhAPynO0jjjgd3d+IGtPD1rqNpcxXNlO8QS9t8FDkfcdf4H6AjofY8UAaWn6pfS6uNP1CxS3m8tp Q6MSGUY5A54JOOvavPvijpieJvDSeNfD6tb6ppT5llJCtJFGQQ+c8tGcEdyNw9K66W81O18QSvcW sdxqUFqUaGNSwCNjByvbOOareG7GOb4U31ldROEns7xZY3Uq2QjDv05UUAdN8INVGuWmr6uEWP8A tCeG4KD+Fvs0SuPbDKwxXoVeM/stymbwHcOzZb7Yx+mUQ/1r2fvQBzXiKRYdR89mRFiiDMzdf4sA VTivYL21FvcLtkCFmWM8d+c+vSrXi5YXK+duG2PPHO7JICkd+9YFzCY7Y4UqCCsihPvZ/rQBwWih Y/2nNJ3kKzaJMAGIyTuf8zX0Gn3xXzvpVul1+01oTXKMr22kzSRdVyw346deGPFfRC/6wUADfeH0 H8q8A/bLlK/D/RYx0fU+fwievf2+8PoP5V89/tnf8iPoH/YSb/0S1AHyJjJpKXpQDhhgA/WgD1Dw 8ZJtJsbeHmQ26b2DD90u3j6sRk4/Otu2T7HbRxQIVjXJO45JJ5JJ7mr/AIX8LXkvhfR5IRp4SWzj lCtIQ5LDOSMdfetyDwpq32Y+Zb2sKj/npMq5/AUAefTsJNzZO/dgDH61Xnid35DDHK/WusfwzqDX JwLV3JP+rc4/PGKgvfD2rRAs6Qtz92OVWPX0oA4uRy3luFIBbaQeMA8focVR19XSxG4YG48/8BNd bN4W1iXeklqEhmU7t8ioyEdCBnP/AOqs/W/DOuahYxwW9iZZg29wsi4X5f7xIFADPKnhs4io4Chf 0FS6ZNJBMs2G89Pmjcn7rDofp7Vo3WmajDHGkluwPdUKufyBNO/sHVwo2WU6ZH33QKE98EjP0oAu +IDAbm11bTY1S3vIQJox0gm+YEH0ztOB7VzZMmGOPlGOe55rsPDdncNLc6NqEch02+VjJKiBvJmC ERyEjpgnH4Cuau9LvrQSJdROpGeQpKsRxke3HFAFm7UvotmqBgyyuTlSB1bv+NZyxycEA1vXFhey 6PpyQ29zmMyF/wB0RyXbBPHpWeNOuVJUxXG4dQEJP6UAVo45GdiRnnvViKGRs1IbR4mHnrNGDyA6 Fc/nU8Nq75MQlkUd0Un+lAHsHwRtSNFcuCC0zEnPX73+C10PxHia48Da7AGx5tjksTjAEgP54/nW Z8FOPDl2SWHlXTRgt2IUE/8AoVbXjoY8NXasuVaAJg8f8tIwP50AZuiRWsF4y21tDGSxY4jUEkDr 0ySa6KzjiTzoVghVHu0jwIlwwZwcEY54YiufiBjud45Akce+elbUtx5NutxkDF7DICecASgZ/QUA ebeL0Goahd3t2A9mLWdLKFPkVZIHVA+BgHczSZ9cj0r0f4X6g83h42TStJHaTNEhB6LgOo6+hP5V 5lqw1ex0nS4NZ06KJbNLiOO4inWT7SzSJITwTgYz1wTnpxXs1jY2GkwwppEEVtZB2KrGcjcxycnk nOf5UAaz/Nuzz90D65z/AEqhqcSpfw3Ixu+zmIE9v3ikfzNXWxl+37xcflVLUXLarYQZ+RkeUjHo yD+tAGkibYwvPAwc+/Wuc8YyCafTLHf8rzSXTjviNcL/AOPuPyrpJGCoeTjrgVw1/frL44uAwJS3 t1tx7FjvY/mR+VAGxAqpt83AHYc5/LvWjbBNzMiAEjJO3JNVrWLLBhgd92c+9aCRYIPl7GPy5HpQ BPpT5iucjkTEEYx/AhqnqFjpltfv4lnV0vbW28vztxwFHbb0zzjPvU8EkcMsod3VpZMjg7TlVH9K zvFq3lz4cmg0yxkluZmQGGRwm1Qcljn0wOOtAHD6EyNoWoEyg3Yltfsy9GeT7SzYA78k8dhXr1zj J9Ca8n+GDWt1rsOI4x5cEs0aFfuOSDkZ6EBjz716mzZIGRxzQBRvUEkU68/MhH6ZH8qr6Yo8uHcc ndnBOTg1YuhvjkCk7ijYx9DUGnM8VpGSgAEQcHHP3c9aAPmvTpbnwrrUOpwQSTWSFkkYr8rxSZVk bHfkfkK920iwWwmvtOhC7LLSEs4sd2KNI5/EkV5npDTT3FlGyxFZpY1KhCcgsM9/evQ/DkjQ6ffX hBkEl7IGz1KBdg/QCgCZXEsPjFV6pLaAY9PJjJ/9Cry7xjdNNrmqQgMqTa/JPFIASWXYIXxj0wvH +1Xp2ibZ7j4gwryFmjA/C2Uf+y1w/wAStBGm3B12ZUFrJqEe2CN9xZMB5HJABBfaPlzkYPPPAB6H 8MZYz4LtraKYXEdlcXNkkgIO9I5nCHI4OV2n8a6C9B+yOVx8rIfrhgTXK/DIwJa+IrazCLaw6xM0 KoMKsbhWXA9MYrrrkH7MwBx0I/OgBwxuf0zis/U4y8kDqAMvtbjrgcH8q0B96THXOeaguUynAydw 2++aAPFfEs0ep/GkwmUh9NjAAKnGFgLMM+u5h+NSWO+TVWIG3bCsaDHJJYDP8+KzLaNbj4o+MNRi JaK3nlhRs8M7kL+WFb9K1/B6NdeJn2AFUkDtn23Y/X+VAHeaUghvJSPuwK+P+Aw9arWsUdnpGiSS xhrK8sI7W6Q8gtt3Rsfx4z9Kt6KPNVmxgXH2or7/AClR+gq5YWqX3grTQRh2tIMY5yVA/qKAGalp Vjqt08WsQLd2z3aShJegZowARj8Rz6mtLQoYrfT7OG2VEgCs0aIu0KMDoPxrIhuNuj3DOwZ4ohtL diidz1zkVu6coT7NFggpaISpHQkgH/0E0ASRjEKNx1I9O9RzthklHGPkbjHyn1+hqSM5hwemTye1 RjDRMrDggjNADnPv2zWLrZ36VDEApWa7iibP93fuJ+uFNaIlbA4Gc889+hrL1WaOKG3Sf5Vebhsn jAJzgf0oA1hLvaWQZ2glVH41ahYMX/vEgYNZolVFTLKzMcqV/iqzbNtC46Fs5+poA4bxJb/2to13 aW8XmTQMXj/eKSGVsEAA55GR+NeUXjlMBUZ5nGBH0x7t6Aeteua48U9/Pp9hY2NzfhyXklgRo7VT nDyHGS3onU968u17S7bTtavYIlZ8OC0rfKzkqGPC4AGSeBwKAMyOExM0szeZK2Qz9gPRfQUxQVOX BCsBg47U54xuADSrj0lbp+JqNkcOAJ5RzwCVP8xQBB5wjjw0c2TzuC5Xr65rsvh7q6293d6dKdiT oZoggZsSKAGBAB6rg/8AAa5CSKQAoLjcPQxD+mKdG93pl5Bd2skXmwsJVKqyEnPI4J6jIoA9ke8t Q21rlEy2Bv8Al4/GlF5blflubZs9P3q/41Da3GqyWkM8f2C6ilUSx4uZI2IIyBnyyOlRS3VwVUT6 WPMbgIbuIg8HoWCg0AXbqGG88tZlWYDlA2GwfVT2P0rk9f8ABNheqZEt3t5myTcWq7XY/wC3Fwkg 912t/vVtzpEWRptCuQ452xwwSEcj+7JQZLWIDdYX8YPPFlOMf98A4oA8g1jQ7rRyrXAie3Y7UnjX dG59M8FW9VYA+1bXw901ptTfUmtGmhs/kUxMv+tI4wGK5wMnA55Fdxqg0e6VGkvJrePBEiypOBIp GMEOMdcdfwxWBb6zpvhrS1hhu7eK1VyyulwHUlmAOQctu5zg9hwTQB2sV/aRsouXe1O4cXUbQ/8A jxG39an8Cu11oEskZWRFvrsHyznA89yMn6H8aw9O8TWrlGi8S6ciuQy/uQSR68sPftXBn/hKbFJo 9JuNDNuZTPFKYYxPukcM43h88b2JHTjigD034paM+seA9Sit0L3VkVv40HJfy871/FGf9K474eaf beLfD8VxY3qW2uacEguomiXyr6Ef6ppcDcQUGzcM4KjIPfvdOj8lLdLfxrNPKiKjySmOZZCCSW2O Dtz7EDGK8w1bw5rXgvxKdf8AC93aXkDMSyaWnmNEr9Ukti2TESDjDHHGMYFAHbxSanH4s1O50e2d GihVZ9LnIe4gTjLxAn97FkcFSeOmD8tWvGviJ7P4ZajqcrKt1ewvZ24jOd0shMYAzzkDcSO2D0rk Na+JltfWUQ1jw1e22p2v7y1uYJntWgkPVo3kj+X3Ulgw4INefXutX/xD8T2FprN/pen+YdpfIt4n fgM/cGZhgA8Dp24oA9//AGbrBtO8D7JAA9w4uwB2R1AXt1wvNes1yPgNrfdfrawG2gQQQxW5dZPK VIguAykgrxkHvmuuoA5zxKh+1wuquHCZWQHhSCf/AK1ZjMzoXk3u8mSRI3LNj/8AV+Vbesz/AGa+ jkTyjKI+BLyvU1zUsrSSllBIJIORt2nJ6D060AebSTNB+0v4NVGO2WxngJJxu4lyPfkV9FJ/rBXz jLCj/tH+BZNrLi3uWAQZGQsn3vTrzX0cv+sFACP94fQfyr58/bOOfA+gf9hJv/RLV9CN94fQfyr5 5/bPP/FF+Hx/1EWP/kJqAPkYDJHOKWThzyDjuO9Iudwx1zSHrQB6lofxB8V6fo2m20GphLS2t0jh T7LE21QPlGSM5q8nxM8Yu2f7StWHP3rCPPPXtWRZ6Qsmjaa1vOFuHtY3KSj5TkdmAyP1rIv4n069 e2u43ilHIIO5WHqp7igDfuPiT4rJyNSt94z/AMuaAcj2qi3jrxGu1/7SVHA48uEAZ965t5YvMJZw pz/FQ6IUyJUJzwNw/OgDp4fiL4kgO8vYzn+9Nahj/OrR+KGvOo8y20Rz15tSDn864wbM44OPcVHw lwArHDD+E/pQB3SfEjWPMMi2mlhsdBERn8qVviXqrOpXS9IQjOf3bHd9cmuMCbTwaNucn1oA72P4 oX4VFfQtJkCk42zTIPyDYP4+tSp8TrhAuPDOnqwOQyXUgx+dee44p6gHHTj3oA9F/wCFnCYnzvDU D/716/8AUVNH8T4Y1G3wyoHrHf4/9lrzjG3nnHvT0B9BQB6TH8SbOZy9z4eumHoL1SB+a1p6V48s dV1SzsU0jUUmuZFgRnuUKqWPUjHTvx6V5VjfycZ9sV0ngSaCx8Qf2ndybIdNtprwkpu3MAERcf7T SAfjQB9EfCMRxeHL0RkMW1C4kI7lfMKg/T5P0rQ+INxFb+HpZZ1cw74gwCgnmWMAYPXkj8q4HwT8 QdG0Xw7Z2zadrc4gdwLvZAqEyNuKLudWKhs4H61D8RPHuj63bx2OmXM77/LLGS3MSw7JkkKnPV2C 8EZAwOeaAO1R9kk28btku489Mcnn6ZrVkOzwysjYBWOKRgTgA71P+Ncwl0j2mqyA5IMuw4zkhf8A E12VzGBpNzGW2qsDge23IB/QUAed/ESWS41nT7YLLHam3dggdGCkvhjx1yu3HTvXeeE9Zh1Wylj4 SXygrAEbXZABvU985XI6g1g+KvCI8RySRMph1OC3ka3VJfLjmYP0Yj+Fhn8e9XvC/hy/0GzSW9aD z1YsIrd8pGpRQQTgAn5ccenegDugw/ek5zuDHH0rC1bXLCw15YNWvbGygFsskJmcB3csc4z2G0Vt wnMmQRhkHA+leTeN7uRfHeoHIkFvFFEik7cLsDYyO+WJ/GgD0i38TeHr9fJtNc0yaVyFCLcoHbno FJBJrgNOElxqk9xcHc88rSuB1AJJHT2Irm9ZnjurGYXFvy2UQMA4HI7np3qb4dxAalqYCjiGHGBz y7A/0oA9P0ZXguIMTtLEy4OeCOAMH8q6FQ3kF/m4ByPfP+BNc/pJYzkEAMjbCPXrXQCMnCBiSce2 OCaALULBQVJwpIIP8P3RwaLaV3t/3Z2ypxhj8uccZ9qW33uHyh3K2M556VAhyttODkn5TIo+ooA5 Xwx4TvdO15L/AFG4tSI0O1bZm+dyNpzkD5cdvXHpXanGR0H0pVLYxwwz1HGPwprHgcZwSaAK4QKT JJkhew6YrwbUNY1XR9S1HTVvr6JLa4kh8tbg42Bjt79MY/Ove5uLYg9XPNeC/Giw+x+OjcIuEv7S Oc/765jb9FWgCXwPLNfeJbaIfulgjkudw5I2L8v/AI8Vr0/wtG39hzxyqQwmfePqN3/s1eWfB63M mtapJjJFsluM/wAIZyzfpHj8a9c0fP8AxOxwMX7gY9NiUAZXgZg3ifxtbEktJKrDPsGUfpisD4yM x0nQUkcxQlzvByRuAUdPXGfzrS8K3HlfEvxLH/DKP14P9aX4p+H9Q12z0uKwjBiieRpZWI2xA7QC RkE9zx6UAUPgXPvtNcg7pJC/tyrL/wCy16bMcxBT0PNcH8MdMj0bWPEenxSNLHDMsSysACwVepx7 k13zAYB547e1ADYSFnbePlweKqzStDYTSRqGlhV3jBPBKhiB+Yq1HjczNzWbrk32XQNYnUFmghkb GO+w0AeLeCgkHhiPU71ki/tGRrx2dsdTwMnrwD7810Hw3SGSC4voPuyNIu7BH3VJJ5+jV4pChhjV UdgVGMgkdOP6V7h4OV4PBFjKM5lsnl2Drkhu/fIJNAHa+HE8q20pW6ojhwfcAk/+P1e8Nxj/AIRf T0zgLEBxjsTmoIykE8kOflWILuHoQnP5CrmlRGLSSm85JkCA4wvzt0/PNAHN+J7aS50m4h3hrqSF tj8LvIGUz6HGFzXV2UouZPtKDAkghIHpncxH5muc8X7FuNHwVjklOzOOWVWTP4ZP610liAIpB2Ds oGey4H880ACH92R6H8+ajkUBh19OlSdUyD0BOaLjJjJwD39KAKsse2TPQN78E1zWuavp2j3+lHV7 uC3idp/LEmSXYLjAwDk8103mGRPlypU8MR0yK8z+L8Yth4funCblnuN7gcn90D1+lAG9P458KWl3 ZrNqtvDGysQ/lybVPAwzBcL+NabeM/CgtluIPEGkujH5Nl0GLduAOf0r59k8TLb28ZQbpGDFgCQR npz7c8VzTapOl69zat9lcvvQwjayemCOh96APpHVL25sNT1C0gtIUQTGTzFi5dmAO5iWwTzjp6Vy ep6TNfzXckoYSXUqSsyqMoVXb8oz0IPI5rxe81jU7u5Ml5ql/NKQoLyXD7iAMDnPYVRe7unfBvrv 2zcPj+dAHtlt4StSjG6ubySTPCRoqBfqSOfwqO58JRICVurlADwJFQivD3urncGN7dlun+vf/Gon urnbt+23WPQzv/jQB7vZ+EbU5NxLdzpwAIyqD88Gm3nhmxMYJa6g28DzJlx+GTXg7XF3s4vrvHp5 7gD9aqtI4JPnTeZ1D+Y2R+OaAPpbRHudPsoLK2mN1bxZ8si3Mj4JJwSDjAyeoq9Jc6kVZRA7xtwR LbLg/XJFfLZmuhgtd3bLnp9oc/1qKWSTcCLm49x5zf40AfT6tqsb4UxJF0KhEIH03OcVJNLqIA2G SMgcAGPP16V8rMWY/NLKxHq5OKQvJnmec/8AbVv8aAPqVW10HKzqigY+aNM/kuKk1KyutX02ex1M C5guIzFKjME3A/jkfXqK+VQzE8TSnn/no3+NAXceXf8A77NAHv3/AAqbRFDBLeRB6G/yB+fNTQ/D TwtarvbTYryThQrzhhk8DjIFfPmxNpHzZ9cnNSKuQq7jgcjLGgD6Ff4ceH3IMunaapHJaGQx8/8A fWadpvgDw3Y3JuPKmGCCyjU3UHI74YV8+eVEz5IOfXOKkaGIIAe/PJoA+mI9IjgijWG7ubZ8ceVq sqYBPGQXI6YrM1PS9PuIVg1fUTcWrArsuLgXAI647kfp0FfOE8ERJJyTnqTVI28YJKDGelAH3z8L tE0LRfDQTw5bW8VtJJudoVI3PtGc55yOBmuwzXhH7JULr8O7s7kydSlyRnn5V7dq9y27iNxI9SKA OZ8XyKk4LsBGIwZOcYGWxWHfq0cbSJscsMN+8PK8nP1/pW34tyLheeVVScDO9fmBB/pWHcQgEFW/ d4OFUDLE5yuO/HagDjdPJP7QnhY4Cg6Vd4CnquDgn/Cve1/1grxPSLcv8c/DhcktDo945H9351XB /OvbE/1goAG+8PoP5V84ftpyY8PeGIv713M35Iv+NfR7feH0H8q+ZP22HItfB6Doz3Z/IRf40AfL Y6ikooFAHsPhyKKXRdLYHpBHljyOn9K077R7O/smjulZkycSL95G9QfX9DWDpcc+h6RYzxF59Jnt 45JkT5ntnIG4/wC4f07+tdZpclnfIfslwJhgZROq465HUdvagDyHXbK50e78qf54m/1Uy/dkH0PQ +orND2zgiZCTj7ygA5r2DU7OG5VreWJZoG48txx/9Y1xuv6D4dsZkQ3F5bzMMiCEiVyfQKeR+JoA 4toVVMggqPWmDHYY9q66y8ISSwebfz/ZGbDRw4DHb6vz19hTpvCi5O3UC7+pi6frQByHOTkc09dy nIcg+oY10q+FZTJ5f26235OMow4FI/hidQcTW7jpwWGf0oA50O+Mb346fNTw7qOJHz9a15PDt+jn y1hfHbzQD/So28O6rxizLZ6FZFOf1oAzxLMn8bg+malE8vdz+Iqy+kX4HNvMWHGNhNQfZLndta1u FYdQYm/woAkW4l67h+QrR07Wb2ygvooJECX0H2acPGrZj3K+Bnp8yryOeKy/JlUfNFMP+2bf4VKi sBko2B7UAdrot7NqGj29tEUe8t7kP5LceZH3wPbIPfpWdrq/Y7ll8yKSZgZZYVQjyWJyEz34xWBE yZB3DOcgg/1q5Gdx5bcT1JOTQB9C6TKLnQJZj8zTTQkEc58zC5/EJz9a9H1bd/Yd8UHzG0lZQO52 k15N8Obn7R4R0xGx/wAfFtH24ZZJMfoK9Z1CQ/8ACO3bImWFnMQMdcRnigCtJdNa6haXkoDRIzRy MvOxWI6+3fI7iuoljWa3lHytjua5WO5+0fZisDRxzLsKsQfMQoCGxngcnHfpXS6U5kskUkH5AMgd QVH+NADrclYoy4G9V2sQO4OP8DXmnjLwx4gvfFt3d2ln5trcSwRxssilSoQDLDOQqlSSfcda9NXl MEEE5z+I/wARU8R3KMjtQB5Ld+F73SfCWq32smD7XJ9nhhiRt3kjzRvyRxuOAOM8D3qL4fI0N/qM y/xwxxgEej5P6V3XxKGfBt4P+msH/oxa4rwKhVZ885JPp0AoA7zSwzSl8YYsWwOec4GPwzW8+WJO 0q3Ix2PoR+dYuikgr1CgFyO3dq2LYl4kY8YQAnP50AO84W9xIJQ3ksy/NjgfKB1pNPYyWe1ioZZD nb0JyOf1qaLYVCEAb1HOORnpVCF2t7p4nQK0nII6Nx1x2PFAGsijBK9+c0xv9nqKlIHJPQ1GeH4H Tj8KAIrhso4Cn93xz/OvLPj7aEWugX4UHZLLbN9HUOP1Q16rIAyNmuI+NVus3w5uZ34+y3NvOD05 37D+jGgDmPgnaf6Pqt2RtWSYQp6ZVMn/ANCrvdEx9r8QxjP/AB/7sf70MR/rWL8KrRbfwRpmPvzK 10/1kJI/8dwK2tEB/tzxPGSBi5hcf8Ct4/8A4mgDmNO/d/FPV0AGJFU5H+4hr0G5XfYyoF+Yhuff rXns5MfxSnfoSkI/NFr0UhvMfJwvYD17/wBKAOV8JEHXdYlBG2WZ3z6/NiusYnAPTgn/ABrkPCZz ql4M87S31+c/4iusxkcnof6UAPQZjk+U56cjHNUtYjWfQtSQj/W2sin/AL9tVxixhfJ5xmqGqziP Qr6Q87YJSQD/ANM24oA+SpMCN+oA3Z9K998Nxs3hvQogCrPb28ZA6jeozx7ZrySbS9MewDSSlWf9 02Z8ASHA249cnpXt0KrHcaPFEOl0FUYwdqxHH5FDQBqSI898TECGksuB1yySYx+Kk/lWnpJZ9Oj6 llkcDPB69KrKwj1qCQLxI0tsPbKhx+oNTaPHiCaAOdofdyckBh0/Q0Acn4ouI5PH/h233hljHIHO 0s5/+JFdtpjf6FAzZ+cFyf8AeYn+tcD4hjEvxICJlPLsVKbRwp2nH4ZNegsgihKIDiNAoHsAB/Sg BqELGN3QLg/nUh24A4Ld8HpxUTkbgMgBu/6mkU7VXBGBk47Z6UANCBmIXJI+UkdqyPE2kWWvaVPZ X0YkUEPE38ULkEK49xn8ea1Z1G/O84PG3tn14qCdiYZCowzEc+vIGfyoA+Rdej8jW9SgbaWhuZIS VGASrFSR7ZFZbnHoQO1dD48jEPjrxJGuNo1KcgemWz/WuekagCtK3DEkZHvVYye/HTFWZDkEDkde aoy4BOBznpigBGfJ46e9MaTIwPpUUjfrUZcc+lAFmOYrzkcVC8vtj3qKRwchSdp9agZvyoAstO3Q Hn2qFpMnLGoXLDBYEZ5Ge9NDcjNAE5bP/wBajcB9B+VV889c/SkD46jrQBYJGBnpTlbAqpv9OlOE nA5I9KALTOPbPHWnpJznH5VSLg4z+lOEhXGDyaANETAD2qOSYgZPH41UEox69/eoJpQw4AxQBPJc Akg9frUHnZ+7iqsjdR1FNVvSgD7B/ZHIPw9vG4ydSl4/4Ale7A4xwMdq8A/ZHkx8PL7BAI1KTn22 JXu4dg+WbII/CgDlfFzFtSKqjeY0SqmD1+8efbisidWJC4Ib5mAPzYYDoccn61reKiG1MKFHmvAq gscYGW6Gsct5LLIiHcQYpADgqOfmH+eaAMDTVcfHnw2Ucsv9lXu85PJyuc+vOPavbU/1grxPRlt3 +N3hyWWWRZf7MvRCgXKucrk5z8vBJ/AV7Yv+sFAA33h9B/Kvl79tiQE+D4v4h9qf8D5Q/pX1C33h 9B/KvlH9tSQHXPC0eelrO2Pq6j+lAHzdSHpS0h6UAe1aNIi6NYMGmcpBGAEOD9wZpdT0DSLy489L eSymGdtzaSGNwAM5wOOpPamaFM0Ok2W5yY/JjxtX7p2DOfwrVtpZpLgSSKFQAEtjG3t+PagDlpNH ONs+ta7IgyQhl25GOOataVZ2WmiR7O0ETEB/Nc75H9Ru/HtV/UZZorjzGcsATu+Xtjj8aikAii2M i/OA3H8Iz09j0oAo3V3HPhfKXaR0NRLcJEowu0MeQKn85nlRWSKNFO7d3xmmXEzKJSjwyFcMC38Q PH40AG4o7eY+ATwAMHpUafM/AKA5YDtgf1phdvmwziTAUEchh/hjj8KaGeMGRpWPG35ePyoAnllO H2KWUAsTg59KQDy5F8xtiH15pnmBQ7OzogGCfX0/Wl+0sxQBcbuPmFAFhbiLKrA+QeNu05P/ANen +ay7NxcgjJXcex/SlXYsQlSSTz1HK4HTHt+NVDMVO8kK3Ubh2x/OgC4tzKBtZ3z2G48fjUQupM4U DI75qFpTggIzHdkKRwPepFkPkuuI/m53Yx+H0oAmLbigfYvoNin6dqmhWBmk3QwPjpiNfz6U1Zig yFCgYYYP/wBapo2LE7VUo/QkdB/9f+lAHa/DsxqywW6Kqfb7Zwo4HSUnj/gP6165cz/ZfDV3cDkQ Wtw3TqFjY/0FeMfD67WPxNp8J5E0ykHG3G1JDn36mvYL2FpvCeq2653PY3CjHcmNx/hQBaug6W1n FDGvmW4ikj2gAMAnTPocY9ia0dElWSz+TICEYz6EcZ9+orE0TUYdRtfD86uN8kAI7kjywSpHfBzz mtfSUMEEhAIG4Dn+IZYf0FAGsx3EHggdjSxADgE8ZxUAOVDAkhjg1IvEnU4z09OKAOe+JR/4o+86 8zQYx/10WuV8IJ5dpcsxBJtVkOeB8y7v5V0XxWl8rwPdOAM+dCAP+B5/pWJo0Pkpr8BOfIhihyPU W4BFAHXWoMT3HygbI1X6HCg/zNbdsNtsvrgfzrDH/H3eDu10qEj2Xr+lbkTbgqgkEEcZ4/zxQA4h 0kUiN2RkUZXHBBPXNM8uO+s2jfDMBlWxgqc5FLcSSRyxkMwXbyAN2ee4/wADUNgXS8RSQ8bgqHBz 24H6UAXLV2a3iMn3ioz9e9O6ueuelMtl2oUBJC4PPXFSDgr6nP40AOYgoy4HQ5rkfidcsPB4t4+G mnAHvtBb+eK6wkbTx16Ed65XxWou9T0jTyCUeUyHj0df6BqANHSrc2kKwdPKWOHH+6gH9KraQw/4 S/xKnA3CzYf9+cVc01iwYufm3Md3qc4/pWdYqY/HuqqDkzWVpL+XmJ/7LQBzGvfu/HzTBWG5LZsO pB4O3p+FemSEecwxgBv/AK1efeJYw3j+2T5Qfs0Gdx4/1r16BN8txye9AHGeESRrEoP8UJxj1D8/ o36V1y5CAdOAOtcT4TlLajGfWNv1XOf0rsucDGAcCgCfdwy8nPH6VgeLX8nwfrjjH/HuwA92+X/2 atsBlUYB4zjNc/4y2t4K1zJ4EBOPTkf1oA8AsdGub7xfEwgH2ZbuORnk4DKCGIXuTxivcIm367oy 84xdXQ4x8pVV/m5P515x4Zk3eIIR5bHYkjB8fKPlPGfX6V6Ah8rxVpSE/LDprbh6q8uGH1wD+QoA 6DUgyws6H54mW5UZ6lXGR+KnFaUDKt2zoQUeMHPrzx/PrTZId08KSjli0T47gjr+BAqHRcyLFE/D xqEJ9RnH8xQByUMi3HxR1VgcLbokWSfvFQo/nkV30qhw5BKqRgBTzXnfguX7X4g17UsfLLegrgZG 0Fz/AFH5V6AuAqgKAB3Ax+NAEUIYzANwVGCR+pqeQYPTOegz6VFHnfJjI98570k4ypyCcnBJY0AD 7I18xxsIGN3pUQt8wPlt6HkNuzU1vCi7XEr5PTNL5ZTcS+4EdAu3r+NAHy/8QdDMvjXxBObg/vb6 RgPKyB0zk59q5efRZhAxinV3yMIY8Z/HJxXefEqK5fxbr9pFwyXgnQjjcrKufr1H5VwUtrejeds3 P3gTz1+vrQBmDTb+RiPsU+R1JAAH45xUcui6mMk2NwBnGcD8utXLi0u1BDqwbPMZblh6gVmzPMmV cyj/AGScUAQXGk30Azc2c8Q9WA/xqtJo+pbTIlhcug6sq5qWSVs4POeOWz+lV3bG4bPmPXpz9aAI f7Pv2I2Wc5zj+D1qu9pdqcNbSjt0qUnGSBgHk8DFQs45yvsDxkUAMNtPziGTjrxSC1uS+0W05b0C E0hkQZ+VefamB+OgA9OlAD57a4gbZNbzI552vGRTUikkbasb7uwCmmmRi2RwexNNjlO7kN+dAFka ddKN0lpcKo5yYiB9cmmrA9w2LdHk/wBxSe/FLEk8yqVR/KYlVJB25789K6QWS3nhqwFjH5YhlkBU jDux/iPc8BcfnQBzUlrcRSGMwyBhxjHfpURjkHWNgTzyK2E0G7Zwkk1qH68y5DZOMdOvWnR6HdFi qeW9wCcKgyuR3J9+cfSgDLFhfO6qlpOzEBgAhzj1qvLbXYYJJbTBuuCh/SukttCkmL4u43cL1hQu oY9QT049e3HNSP4ai2tIZ5FhUhQwjDA8ZJIHrzQBy6abeyBilrNgdTtqv5ExyBE2RXQnw4HXK3m5 icbDEcsM9QBnnoMdasy+FypeNrWeGSFVWZnITacjnaTySP8AGgD6N/ZKgkHw9vhsbcNSk3Z/3E4F e6ur7D8jbgOWxwfavH/2X9ISx8B3MY81W/tCUndgbuF7emMc17MsKDYckhegJ4oA4bxUkkmtgOSg WAGTgFjy2APxqlOhQSoi7meL5nDYyBnA/U1o+M0ePWFliZAUhQKpGc/e4H4ZrGSV/ORQu6AAkgnk Hn5Qf89aAMyzjji+MfhAwxI2+0vw0q5OPkXg+nTNezr/AKwV5Do8sb/Frw/EsYCR2N5L55j3K7ts BjRh0YAEnPUCvXk/1goAG+8PoP5V8kfto5/4Szw3/wBeEn/o019bt94fQfyr5G/bPbPjHw6ncae5 /OU/4UAfPFHUfWl5JwBk0jgDODQB2lh4heO0tkliErBVXLPgFRxj8K1JvFMkrEWsBhDkk7myNvXA /TFV7PS9KkNp5pWOWSNGbZIFxgLkc9z6VfOgWUy+bJcPDIsud5IBdQAOB6Z4oASbxPG6p51owIGN ocMM+nPNNXxBbhTHNEFXJJ2jkc8c1DqVjYpaEWd2DKJfvSMOck4B/Lisq2bT0g23RYXCuQyod28H PIPYjg0Abr6xatgeaVBUFm2EjP8ASqTatZooZEkfPHK9vr6ZqC1t9LuWnjivP3yYCuf41OPuj1Ge aQ6ZGxlCk7Rk5Rs7vwoAtDWLLySpWRDkY+Xpx61JDe6cskf2q8Z1OTlQSMnt+dUTpEbQSMjyyyKr YwmACASRz3qiqQpbSy7i6rtMe3uD3/n+VAGy19ZncEuF2Eg8k8e3rT1vrNiAbiPcQQMc4rOgsYJS my63B8g8cg4zz6UxNHu3JI8tFGSWLcY9vrQBqnVLYIoE+CrE7WXv/hTbXUNPlmYyzHyyOCCc89x+ NZSW1u8rwyPPE64bcyZxn/61T/2TMpzDIMg8Kw2/54oA0v7RtlnZQ5Q9d/UNwMZFTjULcBSJ0bkj OeQOx/WsaPT3KSG4HltxtJ6Hnqf1+v4VYXR5DESJ4/NXH7tsqCMev5UAbyXdq8CAzoH2gAAjJx1p 8E9spZTcBmIODvHA/l3rAGk3B6JB06rJyAPWp20uSJWJMXyqHK7sHngDHrnjj1FAHeeCLiCTxnoZ hdTm5VdoOTkoynj8RXvmiENbWxfBV1KnjqCM182eB7Ke08aaFO4X5L6MNgdAXC/1r6P0M/8AEngJ 429/z4oA5bTWisZNGtIm2yw3BjjVgdpR4nCnPpjaPXiu50iUmIO6mP5NrBscFW5ye/Y/jXHeLIvs SaBcqEMO+BZOOVdcDn6hs12dmobz0cEgOyE9eOCPx5/KgC4CFyUx5Z4YDop9f8+1SNgnj06/Sook ESMNoBznAON30NOUkhBkEE8EHqKAOV+LKmXwvaW0Y+e61K2hUeuS1Q6JAsz+ImU7kn1GZFJ7qHVB /Wrfjx1fVvBds38esJKQfRF/+vWf8OZjcaK0p+YtcySHvn95u/rQBvWxWa6kaN1YG5kYnpg/MP51 uqrLMFJ6ZBH4c1ygK2WopI68CaVWB43Dk11sS8KfMeVXGRuwcDpjP0A6+lAD5Zz8iLESQOCrBcc9 MfhVVXxdxyMgA+VgynjO73+tOuHP21RDtykQLg9PvcE989ar/NDIhdt6l92W54PUD9KANSLlNvHG VyfXNJksQew44p0Q+Vx0YOwJ+hpFxhQMACgB7Z2YYAY9K5e7fzvH0EXUWll5/HYsWUf+hV074VM8 n6VyOlP9p8VeKLqP5jDLDZDJ/uJlgPxNAG3aKI3uiOBv4z9KyhmPx7Gw4Euld/VZ2/8AiqsWuraf dane6Rb3kUmpW4V7i2U/Oqtzn3wMZx0yM4zUWpEJ4m06YA5NtLEfYb1IoA5nxOf+LgxnrmG1H/j7 16JcNiYs3bdXlniG9hf4oC28xPO+zWkgjB5273BP613F14l0tvEs+gJeL/a0aCUw44Of4QehcDkr 1wQfWgDlvCUwe5tCOhUpnPqoI/l+teg8nafXmvKvBl0kl3LDFKpe0uhHIit93qCPqOK9Ti/hx19K AJHkDEEHjHH5Vzfj3CeDdZI43QqvHf8AeKP61tI5WXyyuAOh9R/kmuZ+JrtB4F1I5GWMKZz1HnL/ AIUAeZ+Hm23F7MMK0VsX3Z9xkV6TeK0fjy0HIRtORSe3+tbP868y8HmOS61KOdisDWUnmPn7ihWY n8Ntb3hnxrZeJvFmlTRxzQXEUMkEiydWQSExSbh1zlcg8g5HvQB6rqcz232e6Zh5KsBKeuwgfK49 ugNSFhbXV5cHGxYTNjPsScH6ivN/il8QrzQLh9C0rTkN+1usj3V4Mw7XBx5aA5fkEEnABHQ1taN4 gh1X4aTapGxEYsLhMg58shGBRvcHj8qAM74SxmbRppVbEhucMc9QVX+WP1r0ZWEp2qfqR0FeC6R4 1/4RHwhFbWNmZ9Y1KWSWCS4B+zxxqQm84++cj7oPoT159T8DeJ4fE/hmO+j8tbpGMN3CG4hmA5B9 jkMPYigDpUOyXhtwYYz602Vj5ahlxgg47VBcX9lBf2WnSXEMd/MheK3ZgHkVRksF9B1zSyTEKQ+B g/ge9AFqL5kyDx0BJ44ozhXeVkKAfwnI+lQKTJtUgAAZb6e1O2sVUKAAzcKPrxQB4l8YoDH45WWJ yv2y0QZzj5tpTP6V48t7O6BhM5OzqO3Fe3/HBGXXNGuTnLRAZPqsn+DV4LJhXkROqsygZ9Djj8qA I5ZNzEtk+pJzn86qSFdrAIOnrUshDOVJVAf4mIGPqaouQAfmBycA9c49KAFkOM4YHA4I/pUDv0HJ 5496WQneVIKNg+gAx/8AqNQhGZiFBJHJwOcUAMkAJPP0z2qB3UZBI49qe45AI2j16Y5pu7yi5WNH YNjc4Jxz6dKAGRRvcOFgjLsSF4HGTwBmrQ0fUCSTalVXli5xgZAz+ZxTPt11n5WjjweiwhQQex9u 9Ma8uGYuHVHUg5SNVz9cdulAF4aQi5E9yowMEoDjOcYyfz6VatdIsljxKN0qgNgt97ORzyMfQelZ X224kxl1ZshuE5yKaLmdCq+cygDgYzgZyMf57mgDr7qxEUYVEaGIqrLgdgSDgdevOPYZq7Etus4U 8SRptIXLKpA+9ntxnj1rjl1e+SJEind2HIc5zk8dc8dqfDq18sZQtEQVI5XoPXFAHWW0EclrJIr2 +Yxnbl8BSTkg+/J9sURxKRbtbsFkfCqmCAWJ6H8AeuPpXLDWZzGyIbVFwoBjHOATyfXk08alehiH mR0bqm1SvUkH+fPpQB2E4kluAjK4jU7UcgrnHRto4z05PfFVpbG2jYPL5WZQQ4dmUcjnJ5Hcc1hT a/qARvLmXLMC7AbmOOnJ/P8AGsuXWbzEY2wkoRwVBBPJ56c0AdNLpYtJ3u42hu4osIyNnY5Iwirt IYjAY5OM7aLWFp7cqLZZFZ0y5XG/lvlxycjnn3rkG1e980MjRgYA2jpx2xUbatqAIMlwSmACv3gc DHPfPrQB9mfs0QyReAJ/MeN917IUK4+7gDJx0JxnnmvWv0rw79lfU5pfh5cfam3lL6Rf+AlUIP61 7ULglc7Vzjn5ulAHE+OHli1vekjYaGNQgOMHLc1zqzwLD5bB0dWfbmMhlOTkn3rr9dt4rrxCfPDA PbRq5XPABbp+Ncx5Dm+eBlKopwxZs46hSD7c0AT6NbovjPw5KCwObnagXAH7k5J+p6e3evUk/wBY K840GCd/HFhBM5R7CGdyvBEikbAeuRgt716On3xQAN94fQfyr4+/bLk3fEHRkz9zTB29ZHr7Bb7w +g/lXx3+2UuPiJpLZ5OmKMY6fvHoA8EpDS0h5FAG3/ZWoNBA8kQj3AeWJDgsuMg88fSlvLKa1itn ujKXuEMipyNmGIKt74G7jsfeuzt0hntLL93cI2EjIZGZchELHB7cnHbitSITQQBdoKyIVcAhcnBz jjgngZPGKAPNpI5UtI5nDJEw43DOc9Pzx+lMkTy96sAGVtvBzg49+eO9eg3y5Xb5YkAIdFYANtOM HOMdevGOlMuhFIpkksoCrR5VioBG45xx1J559uaAOAgMkkqqHAYHhx29yew75qa4mmDeWs80pDeh x+H55rsLuVUkaOGKJgx27WjyMduPrxUlo+xN0tvH5sQ8rkDpxkfl/KgDj7ma+aISXDzmMnCsf4sd cevWqm11j3ZZVOSFJxkdz9P8K7Jhb3NyBIbVW2mPcY8ZBOfvdutR+TFGkkaQK4yNu5sA4P8AUHNA HIRzNE2+Ns45BB/rThPI24tMxkbqxYkmupuNHs5yMwtExQOpj7dO/TuKS60exYsxhl5OAQxyzHPO P5/WgDl/tUqnKSMGPucf/XpzSzbslnBB4IY8+mK3l0ewjA81ZFU/KSXIwR2+v86UaNZrdQvBJK2M MYnjIBGORmgDNj1u7VQvnKSOCxXkjHA/Cp01q7UAZV1B+56+3XvVqbw9BEAPtDxkAnLfNnpzjjk0 6Pw/D93z5myD85jGAc8HGenvmgCKPW7qN0eKOKEBcBdu4HPf681Nb6zOqAEKz7wxdsljznH0pz6U jC6T7Q+6MFUJiAwQ2WBGfpz6GnNp1hFDI/25mYcDIGG55Kn9PegDQ0fWbmPV9Ikkl2W0d7A4RABk CRc89a+stFG3SpVJyV87Bx02lq+NlWIyM8dym+HDqrKV3FSDgHOK+wdMmA0e6kZvL2rLkt/DuBI/ mKAHeI7T7XaadauR5M8Qjm3DIXcm1Wz2waveGLh7rS4bicFLkoqzrnI8xMq/6gH+VUNYDB5M58qC SNGKfwoU2lvbBOSegxUPgLUILx3ktZUltbyMzxuhBVzk5I/75YZH90UAdaVO4k9DwSelLFFmXJyR 1JI/Kn4zjON2MtUsZAGWIByeTxmgDz74hTEePvA0J6NcMx/Jv/iag+FW5/C0eOjSkN82PQ5/WoPH d3bp8VvDCXVzDbw29rLI0ksgRVyk+3k8ZLbRWN4S1rwvb+BLrTtf1i1t4ruExyRrNiVkYDJXZk5x n8qAOjh8Q6T4tXVLXRb1mltLofMRgsuNomT+9GWwM/4ipfEfjeHwZZWiXUZurmafKW0TDelvkl3I 7begB+8enfHlnge98OeENZudT1LU7i/2NLaWYs7OQFomBzK24KASFAC545PpV3xf4n8NeKbC0nbS 9US6jkVWusQxNNb7sNG3zHtnB/hJz3IIB7vFdxXjw3enutzBPaxyxyoPlaNixB/KuP8AFHjfSPD+ vW2has+dyFp7pGylmCf3fmAc89Tj7owSMGuItvjRbwagNvh0LZmKKKKKHUFAgClsYGwDuOO2K5zX 9a8Ka34qg1ltJ1e2hnmWbUbNJIZI7rjOQd2UJIUMOhGQMGgD6atZVmhWSNldJVWUMpyGBHUHvVKT WNPi1yDRXuoxqtxA1xHb5+YxrwW9u+O5wcdDXFWHxc8OG2LyW+rQICRj7GGCjPQbWNcXrlz4Zv8A 4kWPiS11+awtPMiuLwy2c8cqSxjCBCyY2uoAbsoDdd1AHul3dW9nA93eTJDawK00sjnCoijLEn6C vFvCfxB0fR4LiPUBf+fe3Ml951tEsilZcFcfMDkD2ro/iLr3hrxT4QudO0/xdpkEzMsiKJPknKjI icYztJwePQdeleCaHq1vYaMyXVw7Sggm38rd5HB+UEjj1OD3oA7fwzD4WtfG0d/deJpP7MtH+1wS 3MM0NxLMSflkYDoOpIPz5x3Nek6n448LnVI3GvaTJGi/eE+CCQegxXzg+sF8/Zty45O+JSD+XQVS n1SYuFdYg54G1Dz+uKAPS77V9IPxpm12fXYr7T1dXjlihclB5YCxhVHKqGPI6kHirYvvBVv46s9c g1DVmsRI93PA1nIzfaTkbkc87csWIPIwMccDyCa6lEnmBtsjHrj2xSf2nelMi5bYDjb8vX8smgD1 r4SRW4v9ZtbW+iuSlwZLcqpfzos4Lc4IJBU56nBrsvjDqniXTrTTRp13cWmlXqG3lktYytx54ydu 8ZYBl6BQDlWr5wtrpvO3q7CQnqjFDn6it+y8UaskypBqWtCXORsvpCcgcH73Bx3oA+pPCV7qV/4Z 02fW7KW01IR7Z45RtckceZt6gOMNg8jJrj/2gvt7fD4mzdPsX2yL7YmDveM/c2n0DcsO4/HPiUfx B1lyC3ibxBCvXPns5P5HNZev+Kr7VoPs0+r6vewh1f8A0md9pIzzsLdeetAHS+F9Ut7LTL6HW2uS 1zb/AGeOOBS0jQnOcnIAPQAntU2j+IdO8OEPp2lX95eus4ae5lSI7CwESgIGHy7ST6k/SuCjQrbr MbnPzEeVzz6mkiuXi3PEzD5cFc8D8PWgD1XxT49t/FUlhLrOgWG6yZigF5Ku9GAJRyACUzg445H1 qtrPxTnn8O32j6ZpmjWVpdR+QY7UybUQkElV4A7jNecGSeSOU+bEyplSwHp1xWWsw805JwD3H6UA ekXPjSDV/D+maRqllZSR2UquksTNaygAbWG4Ar8ygAnGcgHqK9N8N/FDw3YabBYxaDd6VaIuFSyK XCLz1OCGYnrk8mvm/eQcPxxmrFlLsYso68AjjpQB7vo2kNr3xkPiPwvqthJp/mxX8kks2ZSGQpJb iI/Pnhhg8KGH0r2O/MtvDO0dpLczRxvJDbE7TKwUkJk+p4/GvjS0uEubxRO2cdGKgsuPT863IPGm uaBdtb6drOqwxx7SoS5LKQQD9x8gen4UAezfBLxdq/iOTXLbVVe5iiYXQuVTYluznBtsHoBjKjqA Gz2r1SaeK1iknuSy28EZmlZQWwijJ4HJ4FfLmhfFnXNFSeO0ksPKuJ2uJlm05Rvkb7zkoV5NbUPx 110TL5tpokr5ARRFNGSeg6P1yQKAOg8f6tD4p8G+EdfsfljupJUCNxj5gCD9Nv6149CNPmV3eRgH lbAduThmz07Guv1TxNcXNhFZTeH4dKghu5tVRrZ2EYYr86hWzgEgtgHrmvK0kdI4ydxO3Jz6kUAd VBcWyWspEsMeVEZWPBwfXA/hGBzz1+tMmlSNXSFXcMflUupBJ4znj1H51yMr9Pu8DH41A4XazhBt QjHfk/z6UAdjJ5RKyARbiFCO/AT19cAntVe6RMGaeESRkjcxG888g56deB19fSuRdsoUJPPPXj61 G8h25+YZ55Y0Adc0XlzwCSPyxJIQCu0bR0zn1A96zZ9Nhl8yRZXBdyVK4w3B6enP+TXPu+07kJDE ZyCRimec3UO+SSckn/GgDbn0x4UZZZLd8YwXzjryMr35FLb2UM1uN1vGmBuLrJuzzgL14yf8msEs zAqzFgTz83Wmb3AwrNz6HigDqhpogiMkUEdyCQCo3k4PQZ7k/nj6VFLFaW8kIu7NIyBiSJi4B56F h3xxkdMVzYlJGCSVHqxqZ7+4EflrPIqY4UHAH+FAG/NBpMMgkkiaKPOABIwBPZefT6f41otpVpJH 5sTJBEQFZlTAJJIAzyxztz34rj31G6cMslxI6tw245yPQ5pi3kyKUErBeSF7Z+nTmgDrp9LsyqI3 nmRDn7v3iOMcDPWp4NKVVlQWrr5hB3GPdtU/qv4HgZ4Oa4qW9nkT5pp2/wCBkVKdUu1TC3NwCSDk ydPpQB2Nxo6FI5rqOMBHkU+U/U5yQBnHUjke1VLnQ4S3kpC6lGKktLgjHIGQCO4yegBFcrLqF3MN z3Vw2FCcyE8en0qN7+6OwfaJSqZ2hmyOTk8dDkgdfSgDcutCLyFbRJ8hFdkfbjGSPlbjd9ce3anN 4beWQMTJHGSd7yDO0KOSMdQB349Kx5NZvnSNWmUrHkJlB8oPUD29qZNq9/Ngy3Mj4wF3c7QMYA9B wOPYUAfZX7NenGHwPcB2gZGujgxtuBwiKT09Vz+NeurCCu3dJwdxyMZ/+tXhP7KWq3lz4Gu/NkEj C/kXLKAD8qnt35Ne2i8lEm3anJ4L/L/X2oA5vxDqJsPF0PmjbZ/Z1898Ekqd4AGO+efao0kTSrSa MubpTKZowqbvlOcZPc80/wAR3avq5huo/MtngTYV67vnyVP4D9KpPEZLR/sNx5i7w6DJ3BuhUj/C gC34TEEniaWZlzeNasdzD5ghdDjP1x+Ndwn3xXA+Db9ZPEUkMhjQmJolXu7rtLYz1xg13yffFAA3 3h/uj+VfHf7ZRJ+Imkg9Bpi45/6aPX2I33h9B/KvjL9sR8/FKzX+7pUP6vJQB4bSN90/SlFIeh+l AHrGn30htbSKNy6CJEZGbBAPoeuMHGfQ47VYtp0uJZJRtIPyhBHyVPHc+n15qmAw0yDzEYyCCLLA FSg28Zx/kD8aks5VVYj80kbgrkHD7do4U5246dqAHTwSfZXuG2uwzHvP3c9AB/tYPT2otkhmcQhZ YkUKhlQgnHzBgQfXP6Cqcs6v8m5dkZzsXa25dowwz1+nXFEEspYrIs7s+dplBUAdRk/Tn6igB120 ZuQqpCbof60BSOABjI7deeaqwyzMFA3xpknAGc4zj36evPHFWhbGQsw2xsmA28HcOMce/Oc89vSq 8NlHCxyEkl25CkHJxke3XBH6UAVTciWEmOQkF2BRGy2zsRkdR0I/GpvnEbbllaPOwEn5W285GDyR UdyspnWSTzUfZhVTHTgjj1/xqxbJeW8bFN0UcpZwDHuJwMfUDHOAe1ADGmwd0rzwybVQ7Y+GAXH0 xx71W1REeSCPzEaWZiEK5Cj5TyfT8Kuo5YJgyqZcooUsFBbOMAnGM85471HaxrNdWqzSKscYcxMC fvlTtJznuR25oA5eGK4CSlJDiLahXeSxz6D36/SqxLbsFnx6FiTnvmu6it7M6ZBCYy7/AOtlUBQF bpj3A3Vhf2HM9+AjRrEW8zeqllRc9D3/AMc0AZAluJEIaedwDyN544wcn6cUkrl1bfLM78Z+fI+h rop9OsltrWOa5kSQEAeaMBwTwdnp0HqcVz17A9rOyOAApHzpLkNnJB/HH6UAEc06AiF5I1Jzs3kA dRz+HGKfFKdoVnDYPAyQKgkfzNqxoBwOS2ScelMiLKfkyMDrmgDYnkDWdyC0ZjaMrGiqMA4/xr6s 8Na9p154XTULe+t/7MlntYZppiFWIFkVw+fusMHg+oPPFfIyCWXYpI2AgA5AFegaHeaNa+C7/SDf SPq2qXdvIxgt2kiWOIZRCSVG9mZsnkDb9KAPcPG/inwt4q8Jalaad4ms7PUrmMQhmcwecd2fLJYA lGwFJBwQeuKo/BG2udN0mwS6ltyLq7M0FvHLHI1vG8bAhirHbludvbPqTj53uLq8tZTaXDQsMZwW 8zH49unSmw38YkWZoLRWTDA+WR0/GgD7T8dWviCXwrejwp8mqbQRlSGKD74jboJCPuk8fjg1558A bfXxFfxvHKvhuPf8tyrBhdludmeRgZ354zj+LNeDR+Jbm3t1lTcAdrFUu5kH04apv+E81Jgdst3G w4/dajMvOc+tAHoXx7vjb+O5Qm5XhtoIBgZy2xn6HjowrzG1vmtogJbdvKZcDbxk8c4qDUtWn1i9 e8u5Z3mbarNLO0xYgBc5J64GPwqtJIiMCmS5BGFbI47/AI8cdqAL0l8biUsfO2DGEdjgcdQO1QNI rBgVXO09jVaE+cyqGIGccsM59OTj8elasmi3LW/nWcsN8A5RkgcSFSPQrkMfpmgDM87cq91A4HpT 42RnAAA7fUVkNcKu4BuhIH0qWxmMlyoB6+tAGn55QkI7Lg5+VyKEubhciG4nBbqBKcH8Ko3tyTck g7yQOF/lirP9l3UiZcpCfRic/p0oAvrrN1FApW7l3EZbGCxP/wCriqU9zPc3HmXTs74x8xzjHSqo DlRsxgYHA5pnlk5LHkdfY0AaCzAAbXYcf3qd9qgQNuiZ5COC0g2/iMciqCITkkIQDhgXwaiMbHkL kDoA3WgC1f3MMwjMMfltuO/acqR2AHbvVUzAqB8uBnt1+vrUlrMYHeN4WlSYeWUXqfcZ4qjdDyJm jYqSOjD+Iev1oA3dF1UWKOjLEoeTeZCm5hhcADvjrx3rb0rxAZb5I7iMCOVhzHMVHXglTgev1rjI NzRZLMVBPApzxHo7YHfjNACzzfv5sdDIxH/fRqKaVQQUyF44PJqGc+XKUznHf60xHG9OSQCOO4oA 9BF1pSKsaositmSIkBU+bGflOPfippotINmZbmCFLdRuEgj28g5xkc9D061wMbqro4UTAZ+SQHA+ h9K2Y9R0iVYTc2t1A4ADKkhZTyORxjHfH1oAludU0gtKIdMM29SoeRyuHJHzYyeOvHHWsS9ZfPLp IreYzOVUY25PSujm0y2vJ4JrS6jVsFcqi4ACnDEDGee/P9K5e+tJtPvFS8wdyiUFDkMp7g/XI/Cg A87Le1aOkuji4DxNL02gNhe+c96xGYFiRkDPGasQS+XHIfMYFuQF6nA7nsOfrxQBs/bIQkPlRNHJ ESeHyGBznj8qdqd0J3icbclACR1BGRzn2xWOFlRmjaNmZcFtuSBwPT6jmrcTOsVvI4XAcqrZ5IIP 9VPNAEwikZSfLcDtxyfwqxo0LPrOn+au1BcxFyxxxuGf5VYVt2057GoZGe1miuo13CNwWzjpn0oA 7LWi2p/alUFYWXyztOCFyOn4Z/M1z7aLZzStHFLKqEnEiAk9sA/wgcHnOea3rm6jbDWUsiW0fyId vJJGQx7HOefp2qmI7h50MeA8h3jzOWJPHTnpknr6UAYVz4e2qjpcSkbSWUQ5HA7EHBz+HP50yfQ4 xHGiuzNEcyBTgMeBjHb88/N0rojFEJEglg3TE7ACT+75xk84JOOmO9U1REG8xH5WAwSMsScjHp2P IoA52fw/NsV4ZlVSxGJcKV5xz26gnNVm0F8Pm4UFTyOSMZ9QPb9a7BFW3cxXrBoujoNo4GPmOOf/ AK+Dmq7xQQkhJVBBw3mADcPbrzxz9KAOU/sbc+Fn8zjc+0EbR69OnrSvoQIz9oOCB82BgE9O/T9f 5V0aQIcnMY8xwI0kUYbnOccYHpnqfYGpls/NtAX2mZJfI+Vi2CTuXHOOckHrjb9KAOMudDvIyTiG QdPlcZHtjimxaNO0jLIyKAM8OGyPbFdQ6OskiTvvaMjeFXcE56enBohEka5kVdmMk4+ZQOxGfX16 kccUAc7DoE0rfPcRD5uFUFjtxnOAPSnyeG5dkxhuoH8riRcMGU5xjkY5/wA9K3ELLGwExjUg5beS Twvuf/r8Yp/mT+Rs8wg4wpRsgD3yMg9sjnigDmZNBnjjL+bA55+VGO7jHt7/AKUxPD+oFnMlu0ax gsxY/wAv8a6d5oxb+X/pDY5YSkFhxwAeuOvf0oNyIJJfIeVWACKZCF5yeNo6nDHr1waAOOOm34zm yuMgc5jNNhsp5TEvlsNxGOOQD3x6V3toZJrmMQBlwxKbMDa3U4yenUCpL2S7k2TM7O8hYRJFDt2n OODycDHHTp0oA89ks3S1ilbiSViEQ5BIHHTHc9KhuLaa2d1ljZChww64PpxXotybnFu3ly4mHm+W pLMoUnAwR7Z/KstI5yytC8qeYCAvoOuCT+HGOMfmAcQqtJkoC2PQZqRbeZmISJmYAscDsOprtwhe ZI99qlufnJkbDYP8RQAc54/CpWiSWGSK4UsXZUUjbk7X+8V/McZPrQB7d+yrbTQeB9RWSN0c35Iy D8uY0IJ+or3OJGn2srg5bbtzwuM8159+zXbxweApiskTJJeysmxiTtwoI56H1FetbRuyAM0AefeL 7jZf+VIxheWNEVe6kbju9unWsdZzOonhLQkNtjIGBuwRn/69dX4w8p7yUSwLIYYUJyOdrFs4I5zx muc1B1jdFjMbB1yMckDnjA79KAL/AIMTzvEylSFS2hclHjBJY4ViG6g5P5cV6Kn+sFeb+BZQfFrR uoSQWchUDILKHjGSPXnvXpCf6wUADfeH0H8q+L/2wufivbf9gqD/ANDlr7Qb7w+g/lXxd+2Ac/Fi 39tLg/8AQ5KAPEaQ/dP0paQ9DQB6tp8pSKOVpFmaSCOSVYFzlgMAHp0G05zwakWSKfzI5PMfznDh Rtw0nIGQoJOc9sdBXHWWvxxxiOSJyhQLzKQM4Az09qsz+KZljiWxijWQSb/NAw2MMoG4YPG6gDob mITGQBIl8iP5QH+8Op9PQnHQDoaqCX5fK8yMsy+UUXb8xIOcEZJ6kZyBXPTa/KV5ihUgk7Y8444/ lVFNauUlYqQUI+6wGetAHbJNEkgZnBYSbAwQttbd09jjJ565HYVNJKzAgIyTNI2GjIG0HGMEg+vP TpnrXGw+I7lJkcKikHLFflJ9ecdcHFSLrjNMss8IMiHcjAHcOexzjH1oA6m4tbaMXjCRgbd1iSPz MFhk5YZOdoA5J7/Wo7e3muI3uIQ5UE5bzMqr4zgHJ9Rxg1zsfiBY5pDJYqzM7SFpCS2WPJP6U5Nf LylZlcRO4do45NqqRkAgduDQB1sQgtfL2Dy2kUMsTDIBHIYH7wHPfkY71Q3O7SCCMKZVDsr4KswJ PPPQ8fTNZ8niSFiAdrIdoGV3fmO/bGCO9VDr8CxRiKBlZeCQQFJz9Dz079qAN+Q+WUm2qxcBlEsW ACM9w3TofQ0JAzu6PvmYZJVQNoIOc479Dz9awF8RtjyxaIxAC5f7x55zgZ6+lLb+Iv3/AJl3HIwV RklyxYY46nOeevb9KAN5Y2LyLFhGKlNrA565Jb2/XJqpe6VFqPyNsEpwiNCQec/xf3h6nqPeof8A hKknRRLE/wAuVDfecD03ewGKdJqmnt5jRxSbgoDSMuPQ89OP896AOXmsZre4kiliaN0YqwJ+7j0P pjv9PWkjDbgOTt6E9q7L+2NMmheOQLceWAsS7SFHr0wSO9Rzafp16+62k8qRjw8C5AHOWAJ5H3R6 /MeOKAOatypYBwxwMnIx+XrVi2uWSQBCMN1z0GO2atX+lW8M8YtdRh2PwRcNs+bnuBgdvx/CqX2e KzUSXVzFP5ikKkDs4X0Z8D9KAG3Mw8ppEwRux7cjoKrefmRC/Q8H2rbj1P8AclY/JEQwVCIqqT6M v9arDSrO5lDiYBgAzW8YwC3cEsQFB7YzQBTmuN8KhQqxlSAT1OO/06VqaXZ208AP2dnk6lpHKhuv QA57HoKS40mxktLqaS4nQsoeOdwCo4J2ABif7o55HpUcF6ba2jjW3Xy+hxISx47jp1/pQBRhbyml aQKjb2IVsnaByBgfUc+1Me5Qg7OUZQORx71sziDUpczK0KouUZcbn/PnHNSWmjaQxUzzXDxkmPaJ FzxySDjqeOAOMnrQBz8lznaGKgAABTwKmEjKtu9u7i5mZgqxcHAIA59zn6AVvHQ9KFs7QCSSVgY0 EUm857scjAGD1qisCW16tutqY/lMX2iZy20ZJyOF+Uk/j2NAELaXALAylp1ZWK+YcEZ6dB2z3qgl vJC4kMkbqnzFRkHb6gHtWsdPmn+ZWMduw8seWu4gZJwAD2Prjg1ZTQ0Z/tL3Q2naWSRSBz2yAfz/ ACoAzLadxOSqs+FKkgjOCPX610pLyCNY0Xe6b1BJy3Tp61Df6JAt4r6TBM0csqgW4lVlTKncpI5P JHJHt1FXGl1FobIiCweMFikTyYdBkAdCDHjA70AcklxI8ZGMKOWbHI/z70GXa2124wDtPGMivSX8 PaLdecb+xZZC2WkEjR5LEnHPAyxbOMngfSnyeHdHn2pHAsVpI6sxjjG9lIGU8zcSBjnJOeuKAPMp nktmEU4dZlw5DLyARkAj6EEfWmmcDqQvGQQP1rt/EelaFBcz3d9cGWS6nZlD3ACoM89PYAe4Ix3q S30HTWlWW1SzljCh0uUkZ48gEngdTwevegDG8OaDe6hcxLAg3SoGBfKovIyD3z+FTatZNa3clqyQ 3QAwTAd6OD9QCK6We3vVs1uIMRWe4j7TKpxI+QGAA5JHrwPftVFNGvLqFXuLuKNpeI4wBucYyGIO Dg9sUAcPJGLO4eJRsH3lRyMpkDoeQeBTVlOMhWX2B5P0P1rr7vwa0gt5P7VgSWRdsZiwwbH8OdwO eTkY6YqoPCAVZWnnZ8AYaGQMxx94be5xz26UAcxDZPeXUo3bJHJZQwzk9eT2HamGyvbRo5p4CqBs AnDAnpitvSLWbT7m8e5jbZFKIsqMHI53EHjb710N5awT6dNFdxvAGRgTtwoJPBDdCc4OOtAHCfaS CRj7vQ56exNN3tu5wRwWH+Nak3hDVgN8Ci4iZjtwrKze+0jp+JqtZeHr2aeC3uVWza4H7sTsFBwd vOSNoz3NAEEUhidZFRSe2SV5/A+9W7mGbUnSe6wNilFjjGDjJPJ59a1IPB+qR3jRNZXHysVdz5YV QD8zK27aQBnvWjdnRtK0NbK9tZH1syhxPbSFQkRB2jbghs5B/DHNAHMNZW3kkGIIeocdR/jXQ+EY LRtLkhuLCyuLqGaRleZA25SEIBGcjqen0rFaG/KM32QeWDjzWBUnPYjnnp+dKbXUDH5sSSxyx8FY 2Ibg9cdzyMAdqAOruGjmkMIjib5hhNqqqdeSSRx1rO13TbSTTCIY4oLmKFpkMT8SEAdQT1woGPfi sQavc2k5GoiWRZGw6eXgcEgEMw9eauw+JLSK28qG0n2SOHAbDApkFhnPsf1oAqabP5qxnGd471dm iBjYNnGMGuftVi+0iOCeSa1UKSrrs69QRnBx69K3YQqrHLFbYQsPujaGx25xmgDcsxPaWkcLSxqA isSx3Aj+7t9cEn34p5kWJlltZZA4A2ZZguCSAR1wT9fTpT/MiXY0MsmyUArnkZxjAHUcZFVo2la6 CxS4CEYWQZbAPrjpnv70ANeTfLvWFQp+YFSwwwxkHj+WOvtUczRxo2HlVsjYVwMZPGR2PAz9a0rj yPlae5ulkJxlI42RmPYDcCAMjnvyaz7yFASqLPsU8h1HY/3jyOfX/CgCNGJDeXJGAGC56N15wev9 KYIkMRw6ANJyQGLA8E5Pucc00xQspfPmh8kKGDhTnrxzjpVi3jR5SrLaw7lBcup4XPJQknn0784o AzyqmKRWZAvJB8sDnjIJHU4HTI6VNZzvaLlZ0MZJJErBdpH93H1+nPftNbTOIvLaWKNCrKyyFkxj 3Hb2pieYjJ5oWJWzjZ/u9GI9+RzQA25dppy0syJj5SrsX2EdxgDHPX6VSZLRlVpS0p43sF2Y9e7c e+BV2yV5rh/MRyArbWdyFcEjOc8dDnnP0NWoLdLW6U2bNdMrg/LEXSUqedxHGO2f8aAM8rZw7P8A RYW/eKwXzHAIxwC2cnrkgYGajECtvdd6lnyjAn5CccFcZAwR161rTW80jSbLRtu07vLAZev3mCnj r1JH40f2VLbu2JmaZxhzaXCsVP8AcJBxyP5UAZa2UIjuIpSqumxV+8VA5yDge44q5JZWxfCXDkFQ u3GcvjrzzjJHIFTF4RcpFBHLPHu3ldzMJD6nPQj69qeVEsgEGEJP8all6YO3A6+4FAFJsQKwmBfZ yAQQCTznpnB9enA9a042lWKBUil8wBlASTdzj5ieRnGcDJ9aqTNFb5EQLbwC0mFIUY5AI757HBq/ dW0aCN3aKZAEjwQVO7bu+Vy2M89MDJHWgDIeSSFRIshlQJtLQsdpVs8FeqnPpn6VEdRS7gj8wKsi MMMh3ZTnHJORjoeKvmPyJpP3DQKSVKoPLKnOPvEkZzg9fpVWf7Nclrdgn2rBBZEb96x7ZA5ye/60 AVWjgJJW2ea6kJYIkhbeowPmOcqfxPbirV5bNb38kUs8c0bgxYLeYA3UEDPpjof5VXWx3SugkVkw o3bynlAgH5vbII5PofarUNnHKJJC/kQMudw2Oc+oYY54/wARQB9Lfs1fZ38D3RtyMreuJAoAG7C+ nbvkkmvWyCSCD0ryn9m+1uLXwNcC4leWVr2R2Z2Dk5C9xXq9AHF+KIGn1+cRzGNltYmZT/GuX4Hv XMXsUsWoeSvnIFjD7nXgsWOYx3/Piun8XRKdeilCMJVjTa+Rj+PjnvWPqcgksn+0bicgJIOCHByB n0oAqeB58fEmGDl92k3T75OXGJ4AFB9Bn9K9YT74ryHwKZG+KVr5pR2GiXWWXsfPt8r+nWvXk++K ABvvD/dH8q+KP2uZN/xd2/3NOt1/9CP9a+12+8P90fyr4h/axOfjFdDriztxj0+WgDx6k7UtIaAJ jkgcjp2NSRzMo4xjbtyBzTE+7wME+/NPzwwDDHfJ4NAEbA45Jz0oB55A/lQMbcHqPSm5Az1oAlDM rEAYPfPNTRs3Y+nfdiqwPAHT3FKDuwpHTgdsUATAn5iCrADg0wlC3PC98ClJJUbUxgcmlCyfKRuJ 44A6UAPwoHQnAwdyZx6CiIBQWy23s23pQok8zK5MvQnHIp6mNgoLAqMnBGecen1oAlj2OFGHbsoC gkf560/zVKgYGVYBQ3PHoPeojLGmC0eWByCBtKn8PepgwE20bI8Lk7s9PwHWgBm2Lyjt8sLgBsAn Bz6+uPWnM5G5CS7SBduT6HI/CmyOzSBmkeTBIAyQB+dAcPI24eYehxzu/LsBQA4wwmUxrKJtoyFG SM9x7/nTQWVQoOEHJDe2f5c1DLKS4EYCDH+6R9fzxSNuVMiXnj5QD6+tAEhG7YZWIymSuMn16fj3 qaF7ZiOHGSAXVfuj1+vtVNA7InHBJywPJ9jSshZu5kPYk8j8qALM8cRGPMV2GSH2lcj/ADzTEiby /vnae6jrzx/+qgqY5AWgCsANoPHy/wCPemzudqgOyHGR/eYdvTtQA+SFt2Zt/TcDn73+elIkbKFI PzMecJz/AJ701rl5ZMyudq9G43fWozLIsh6rxznnPfntzQBMIyeccL12+n1ojwhjaJpS33sKcYHb /wDVUXmEAbvmXGQAe/1qUyclooUGDja5zz6j/PFAAZTv2I8gQ8Fy+flz1IrT1ayvdOCyx3Jms5vu yjg9e/Pcg47VlB2wwcgOBnejY4zzRu8ouC0pDKEIcZAA6Af54oAsK0+47bmUMy85Y5bj19DTftF+ WZfOndF+Y7mYg9B/IAVEGHmxuULBc/LnHT1xzQACr7WdD3GfccDvznP50ATC7uY1IimuFDYLbSV5 AzjP45qa3vtQi+ZbiZA/BYMATj17f1qmrgMSd/Qgj8OOM96UDDqSwJGMp1P0P5UAbVtqt9CwQSRO 0ZwoKhsnPXnj1Ge+T1qwNZu0MmbkZJCNkDc3qB045Fc8GHMjKzsSTlj29h2+tWDMy7VLbdq4Kup2 4+g6f5NAFmXULx54pFKgw4Kcrn8QR9asWWv6rb71sbxo1fIbyyArEnGdvQVmlo2kLFYuc4DD8QOD zS7zwpIYY4HGD6UAaltrmqoYP9KlQwBAuTx+7HH498evWrjeLtUupZHnKSTPtwxQZUjofcg45zXO 7nkUb0DENknPJz3FKZFBRAjqwwRuYZwe3+TQB00fie9VPlhh++rZCgNnPIBHOOOlSHxU0k7zSWxg Z1wWj43Dk5b1z1JrlFkbG4KFz0DAZPbPsKZvVsCVFUpx/qw3Gcc/lQB1c3im62yeSsBSRNgR8MAM Y57c4OahufE99durkW5RQpWILtHy4y2OhPA5rnVz8pVySxPOcg/h29aeJPMJ3EB889sf54oA7U+O DKvlzQ+VFuziNRkLjbnnqR7Yzmqsmu6XJIQ2mpJMx4uCWDOvH3h/FiuVm2Mq5GPkwB6gdsdqeWO3 5o/lYfKrEYDY6juKAOsj1jTpIo8WdvBhy5LRb8EAjp0wfTH8qmm162kaJl4kjUIkjEbkx0Uf7PXH oDXIhFj+ZACV+YqxyQOMg+3JpclY8Encw24yDweMnHT/AOtQB1sHiCKKYGR0VACCqphZNy8g449+ hpE1PTZHEf2shkIUOQSEHXj17dfSuYEZO0S4V2OOOmf7tJLF5Q8pwQxI+foSOmPr/wDXoA6yDVbN 1REvPLYhsNKCrZPXce+fTpxSpdRs/wA9zGYmJTbEuMcYHf8AzkmuS2IHYSSs2VBwOQR3IP8AT2qV IUO2OUopOSZGxkD1PY/hQBq3GmaNczLJbzxWsoQqY1b93u/hB7gdM496sA3Ri+y/b7WW1ByEWN1w wHJHzYFc9mFZCILiI4bGAcbvz60xtu9nSRmXGGZ/l9jz+GKAOrjZYBsWRflb5jI6tzjJwO4NS28l u4bMpVgMtGpGGGOAByPfjHp61x0ojRXZi5TKkN3A+tRmSNo1279q5IQgjHfrQB2shgaQbiERyCOT s46+3/6qbIsYfZvMbKeTtwP559+K45Z2XDxl0JByQSM/5NILqUg4eUY4+9gAe1AHWfZ4HYkxRs+/ cqMNvbr7ipPssyQogysHLLtUbj8vb2wPbGOlcknnHEyzSq+3G8ttxS77p5A/nyso4zuGR6/jjNAH VhVFwWjLXMIzyz43EAcEZOMk5yahbyGUrhlYZ/dLnhv94cn8u3vXPi+u7fzCHC4G0EKBxUEV7K+0 iRkCtu6En8KAOnhmWaIAxNHHESSJBgHpjH1PerEylwIpLYsoYBRPJwAwzkNnH9DkVyY1C4aRZCE3 kgZYcZz6dx3qymsyx5QRwuTg+uPz6UAbcljCoCCVdqHb5Ywe2emCO/bvUi2brEieWGVVyGCtkYyR jnHpWEutTlTsbyx3Ktj0PYeozTX1+93BWYSqDuIC5yc8/hQB0FvFOil1tSQrdRKTgnHOD8p6nins zx4imWdgSS4ZiuRjKrx24HTmubGtXUkjea0gUKcICcdcjB9s1fstfaCeF5lFwyESBGGQcHO0juPb 8KANyOaNnTypMTBjgFzg4Hytgt82OP8ACp4WgksJl+y2/wBnVzIxmnBxzgNtz178D09ahj+IepTS SQxX72ce4OI9Nijs4xz6IobP4mo4vF0sBeSfVby5JUg+azk+oAOcigCaW4Els7QNKvlcqsRA81SO WPUEc9CMj0rMuW+0IZZtLnC5/wBYcxDnGGG3qOOoqpceKGnKM/mvv+9I8nzZGfvZxng44/OqttrV vCIwss2VJ+UyEFfYHuOv50AX7cW6tKWhZXOfmZ5CJOeuQfr9ajRZJ4vIhaSRQCyCPLFRnkEdPXji mS6tYxNK8dyI9pJwsWWY+pBP8qfb6/b3LyssrGYR/K8zFScdfm7jB6NQB9Rfs2xTQeBJ451ZXF6/ ylduBtXHFesV49+zLfJcfD+cySIdl7IByMgYU4J79a9cWeJmwrgnHbpQBx/jSPGsJOWdlWFcKrcI fm+Yjp+Nc8J8wTRPC6gEoEXqOuD+fNbHjKRV8Tpn5l+zI0ynO3yxuznsPrVG4hWWdTalTJgESZ+Z oiDwP9oYI96AM/wIXb4nWpdFjZNFuoyu4MTie35+leup98V5F4Jjhj+K1ssYIcaHcls8k5uIcE98 4r11PvigAb7w+g/lXw3+1ST/AMLo1X0+z22Pp5Qr7jf7w/3R/Kvhv9qhcfGnViRjMFsRz1/crQB5 LSGlpDQBMvKjI445pcZAwp9BTQxAwPpxUqSMu7kKQOoGTn60AMKkDLdBTeMhvxoPHBGaP0oAVSAc kcegNK8hJJ4UdMKO1ITtxyPwFIGUE9aAHZ4O3cD7f405XCnP3u3PTFNBOeQST2/+tSOc44Ax0xQA 4TuANrY9cUqz7WBcBjTOnVQacMj7vfptoAseaSSVR4z2YDt9aeibk3CQkZxlk5zVeNfMLDf8xwBk 9amVMhUeTGOAAOB/jQBJE5h/eBxxng9Qe2aaC5Ys0rB2wMAdfw4+tLKwicYABx0BwPyo3k52omPb jA+tADXyhZlcnDc5HU0qlmUkICzjKrkkn8O55pp8t2Abczg8EMePeljUOAFKIW77sk8e1ADgY/kL 5+XkjGPw9ulNikQK2FbcQC2AeB3/AM+9Ido43AE46jPHrSbNwzGy4YZwx9+lAFhXV43kdXD54ycc 9qgkPzcHDHPft/kUyVVzgbtxAAwuM/WlSBQV3iTB5IPb0980AAZgh68Hg5601UcqCIjt6ZHr/kUC PlQCASc7c8Cnh4xGx6DAAXrkn39P8aAGoZHyseCRngHmlVmVwxVVHfJyDn+tK5373Y9AME9Bx3xT kWQQtIVOwMBu29TycfpQA1W3lV3bucYHGB/n8sU/zCrgvF8w/vcbvSmGZgMoyhSMeh69P1qQ3Mjn znQSMrglgOD7UARDYzhAMHg8E8e1EiLzhFB6DgfnTVfzWxsAOeuMAVIkaplZCGOM8Z/Ie9AEeCpy WPAztYdfSpSI2JZUy5bOCQM/nSKS0m7adgHPXmnbUESszIjZxgjqPegBysoZm3Bsgg4Xgj1/SohO i7sBmOOpHQ+tO2bwCxUgDaCeM+wFEkQX5SDkHgDB+tAApwoAUqVPTnkHv705ZEGCztgep4x6fWoD Em4bWbPOGz+XNKyHO4EsF9QKAJQ8R3mNB1BU7iSvsKVkU4Zdoz95cn86rnewDB+RztOOlKsbEbt/ ygd/T0oAnaVBjZkKfvjOTnn9KUSRtdKXUkDsO+P/AK9MiBBBkCsO4GPy5phmXZgJt9qAJjnIVCsc W4feIIz2H4UI7phlBHPABz/XvUKyIikNllxn5eQD6VLFdICWKrsB43KDgnv/ADoAsRytMsiyYEo5 TaQO4608bo5SskO07yRj1H+RWe0pICh1UE5+UYB9fxqdJB5isd+4AYJyMn60AaAJEQEhBUHPoCOp +nWrMccJt8F0R84XB5JHes1Z0UFfMw4AwkgwR06+3enLNHJKzSRKhVudvXHselAF2HzFeJ0lLyli 23cOv09aZzngN35PB61WhQIBLE7HecrJgnn6dqlS5DMd8bMpJ5X5Sp/zmgCckPuV025/eYxtPTqK SERyMPs8i56hXPv0ApgdXQI0ckSqSWcneH7deo47Cq0plWFQyrIg+6c8H/69AF+YNGq+Y3JbIXPQ e+aVwHjYhcBjg85Pbp9aqBvlZmAYZHG7rkdc1NBGWXLiNJOWySMHtjP0oAkeRDHGVDAsCu3P8XvT FY8mQrIwOCRwB6E/lUUcyJPIp4ReA+DjnOf/ANdXEaJrpQjjygB8w6sfQUAQ7C4UliCeck4/yKc0 JAIYttTj5mB3e4qzOrtFLJgOyhuw4Ax61V8tnmEybdmNv+99c0AErGXYzoFds8Nn5scc/wAqdwGK bTGCOxB3HHIx61ObB43LQuXwPuMeo/z+lK9hL52Xlk80HLqRgrx27UAVICERREzOP4i6Dj/PFMdM YkyV6gNtyfpWleIsYVlm+UoNwHHPQ02O3EiFWmVQBnKHODjp79qAMxhEQgXl2JJyvIPrTXj/AHiK Ml/RTgn6VJcKqk5G3y2wTnn1NS+eGO5lkCxKF8yM569vyoAhMcsQVo7d3VhgnOMj8e9RPhCN+4EY 24Udv61IZEUMB5pHpjqaYzqYhICY5TkEE8+vPrQA7zlhi2lWy4wC+TjPqKrLKFd8o/lkgFScruHT B6j2qxMXK7ztIlOASSTjsMVVkujtTftcFcYx79aAEe48xULIyjJ2swzk45zVZ5HjZlIGWAGCc5Hq KdNKvmdvXA7UxmXy8MeAcAY7fWgAeUyKocOFRNgGcACq6qcFhuwOhqSRQx3KzYyetIyfu9wIA9jQ Aw5Xkk8jGDS7k64Ax2xkH60DqA/I96bgbuRge1AH1l+yfIo+H90Qqgf2lJwP9xK9zaRNzSJkg9we O/FfP/7Lzs3w9uIodgk/tKTaXHX5U/pXu0IWVFMYOeV6Y55ycUAcp4rYSawYsEr9nQsCfv5LjGfb risWSJmaOVJmkiQs0gUgN3wvHbmtnxQp/tfCDBEC7DjjPzn8ehrOIjkHlkBYwdwHYnnP9etAD/CT E/F22MpBmfQLh2HsbmHH416yn3xXjvg1t3xqTaCUTw7Mu7rk/ao+9exJ98UADfeH+6P5V8MftTHP xr1nAAxDbfj+5WvudvvD6D+VfCn7UEyy/GvXAuP3aW6HHqIUzmgDysHByKQ0tJQA8U/hemM+1Aco wZQQwHFKzZCjJJ9aAGZ4AJ79TSgbupA96CxBwaUeoANAAFLZ2g/L1NAHA5A54pWK56nHGc0gOCSO noRQAvTvyOmO9HVe2aBwMgY98UAqBgg59SKAF6HoPwPSp/LBJCBsA4wQSB/jVdiOwAqZHZdpZz+8 54Pv3oAkRcIwlVQ2RtOcHHfAqwRuk2W4VWIwJCf1zVLfli26QHPIGMVdtrhC671CKF5JXP0FADSk O5SHTdxkg/yqSMBiTIAVjDcZyFHUfzzUFyxXgqSoI+QHt746Uk84lhjKkBiT8p5OfX+lAClj95Cx iGRk9yT1x78U1JNkbNs2AjaMDn3NMWXELeWTuzx/dUUrSSFcl8pgDpj8BQA1XZd2GBbBxj+I9uO9 LgRp8y/vicEdQPr71CTwR8x7j2qRVkfG0dDnOepoAXzHG5zvwTyTxnilJMkiiM5I6ikVHAIYoVzk g9TTDgYOxdpJH3sCgCdJSJRsOWwOpHXP8u1N3Rb8yHG0445Hf+tRCLOf3ttjONxfAx9MVMY5YYjL NHlH+46kMPTP0xmgBsUu1QDGuMhjuY4PHTFTRb5CwiGFfDE9FTjv+FIY1RQQjT5GVGW4PoeP0/Wh 55jIGmYDOSI04Ue4A6cUAPRII9zMWuZcdACFz/UVGYvNKksXxwBuwB+GOBRJIJj+7yODxk4P4/lT t8SIxKkgj7o745xjsOlACFeBxgZLEZJH4VHiUgBMpgZ47n0q6ssOxmI2uSDkknp6evNQvKXiIdf4 sgnIzk9OvHegCPDBoozuz3GeMZ9fSnFfMJWNhgnbjB/z60wFlVnZRg8gEH8OPSgzPLjEYLDB4HPX PP50ARCMgMHxwADyfXtSlXglxvYMBu+U84oG5pSWiIBP3c8HmphGzFnyd38Sk449zQBCxLopBO4E 9fTt/WkRWJL71XnkE9TSldwGPUjhccD/AOvTmjUbPMiIcDLFGGFGepoAVljikAMsZ9fTPp701pE8 0iMEjsQcdjUkKWoBO8uvpjGKqybNxMQJXPXoaAHrIjNgAEHGQ1BDKxKbVwSOB0pkYUY+bHHcZGKl G0RbnYkHpj2oAIuv+swrDnnHSnlFVSxwY+GYY4NNjdCAxG3jPb5sU+OISsxDZBPTocf/AKqAI5WT cQIxCRjjuOKcHG1lRnZyc81Y3pgg9COcfeOPSoTFHuyu8IeSxA4HpQBJl2Y4O4suF3LyB3pgN0VJ UqVz6DgfT0qIhSQMvkZHB6CnrIoKCHO8/ePT60AAluLcvEi7VYcgdDznillneVcvJMfUkjFQZYAj exwcjnpTkjzIiys6lsYJGeD3oAFnZmyXZFAwAORirH2hGJz8qoAF44qusXLBnA4yvGc0CFyh2PlR jIz3oAsmQCQu7lVY4KqOlXIztV4wx+bD+Z2bP9PashN+AFU5HG7HUelWV8xEAj2buBz25zwaAN64 ufMbdFncPmIz8ue4FSRW/LESLggZ2rx061zSSSI7BZHG4n5uoNWBqV5GcRMPnXaR6/40AbSRlFys ymNnONyEZ7f/AFs0TJbrFG207+d6qxI/KsY3RcxFomOOPl6k/wBale/ztjkiOwnksO3vQBsvDBAi YfhQNrb+Ce4qTYrxqjsEyQUyxGR+FYu9jCuDDyf4ePx5p81x5YCNIzK3bFAGsZIIYUiVUXAKiRhu z7fSo7krJ5RYmERncQoG1jjB/CsS4lYwIY9xC87euO3AqRLxzZyG5ABb7rfxA+tAGm8mYmkEYAQY 3qg5/CqN0kphJT7pA4VcZ+tV49SKuylw0eO/GahluBJJgcgjGFPagC3HKVQMwkUhuUIz+NNjuLbE jRlvOyADjj9arKrROSZM7R8uepHaozG8KOH/AIv880AWPtkMTFSkjyj7u5cYz2x2NZ6zFVcMmRnt wRUpkJUbm527dxHakwZIwBnfnn1+ooAHlhlkBw4X2A604Wyzg7G2oBncxqADnlyRnkU4krEU52n8 qAIzgYG/p6UbclgrcdalaOJlLI3IA49agZRwQD7g0ANYKehOfegdPalYc46UoXcuR1HUUAfVv7K1 uJPhzekttzqEgz6fKvNe5hjhRyqtwcdK8O/ZXt5P+Fd3Mi/dbUJSc8ZAVa9vjh8qRXdFAXnGTjFA HKeJgJtYI5KfZkyo4YYZuRXNT3VyL4ABxI3yqqkHnJw2PTiuh8VMx1uPDKHaFT0IITc2Bj61h3lo WieVki+0FSQWOSIxnnjn0/PFAEfw9uZpfjTMku4qdAkdSe/+kx5P55r2tP8AWCvGvAtssXxihn3j zJPDsqtERypFzHk8duenWvZU++KABvvL9BX59fHaf7R8YPFj/NxfMnzDB+UBf6V+g3/LRPw/pX5w fEiUT/ETxRKpyr6pdFT7ea1AGJZx+ddRx/3jUcwQOfL3Y/2qRGKMCACR6ikOe+fxoAdjgd6X39aQ Owxhjx70m5s9T+dADhjnkfnTtoA6g/jTN74wGOKBI46OR9KAHZ7jA9zTgDt3DsetNeeVyC8jMQMD PanC7nUACZ8DkCgBQ2GYg49uufrVzSrY3V2kLAqJFZQfK3clTjjjqcD8aoC5mDMwlcFuCQetOhvb mGaOaGeVJY2Dqytggg5B/MCgB4jbGdjEEZ6dKacjO5WyenFX9RvorjZNb3N1FK4zNExyvmd2UjHy k9jyPeqBupMrm4lbHQ9MUABU/d2sD3AU09FkUDEbKc8sw4NMackE+bcbjwctwaYZ5SMGWQj3agCw jupyu484bHQ/hTWgbauyGUblzkjr71XWaRAQjuAfQ1ILy4ClRPKFPbecflQBKsDqGJR8AAk4P5Ub JlbaEbcewXtVZpXbgsxHpmgSuEKBmCnkjPWgCXbJjiNj7gGlSN89CGHI45qHzXxjccfWkDsBwSKA LwikOMyqNwyQGzTlhPkqxjUktjdn+QrPDsO9KHYdGIoA0oztfoNoIOQverFpcCBhFOTLabizpxhQ e6/1HesgXMqgAP09hTvtk/GWBx32j/CgDTvo44Lw2y+YYvLyu44Izz1zyMdDUbQAoTGAURcuQVPf 61nteTMqKWB2fd+UZH6UpvrkjHnMB7AD+lAF8wmU+Wu7d2VQMHgY6VI1lcJ/rbcLtIwZCOMjI6n6 VlteXD/fuJGxx8zZojvJ4wRHKQCMEDHNAGjBaTOXB2bVUnKyrgY/GpTpxSFmeeAsXUFUcNgfhmso XtyAQJnGeuD1pf7Qu+f9Ikwe2aAL5iTafKmcnHIAxz1xkn+lQygLMME9MMQy/pVU31yX3mZ93rTZ bqaUkySFyTnkCgDUhUMreZ5wQf7uR+Oak2GS7hghkd3YgKxcBe/LdvSsn7dc4AMzYByOnXGKRLyd GZlk5ZSh4GCD2xj2FAGxdRSRMX3rcPESWdXG7kZxg8/lUFxdwm0KwwOF4GZH+Y/gOtZz3lw67XmZ hkHk+lNa6mYgtKxIoA6Lw7b6PcpJ/aElzvSMuU3oqZAG0E/exnOcYOO9V5TZHUI3htE+yLHtfEhO 5sdc+tYnmuxxnP4CiSeVwFkkJC9Ae1AGoxstj/uXUnglJ8Z568g00pbqSoRwV675O34Cs5bmZd22 Vl3fewetDXErNuaVi3rmgDQP2RbxVkUGEDLHzSN3HQfjSp5EVxLHH+8TAKtuI9/xxWZJI0jZkYk4 xSrM0agRtjuTtGc0AaF04GAyEqf495IOO/SoNq7SNuD1/wBZ1H5c1W+0SnblywXgA8gUjTO33m75 7UAWSiAgldoPrJ/9apP3aHlGJZc5Dj/CqRmc4y2cetIJGHRqANGB7PYGkglDLgHEvDDPP8NWZZoz EkihiynA+cDA9ORWMZn27d/HpTvtEhGC+R05AoA0RMis3mRMVK9pVH9P0pxe0IwUuMt8pxtIA9Og rM8+TGN3H0FDTyswYudwwM9OlAGmbaGRR5E2D08uX5Ppzkj+VV2iKzLGw+U4JB4Iqmk8iHKtg+vF SXF7cXCxiaTf5Y2qSBkDOcfmTQBYDjHlxtkA8+9OSCQupTJUDcAT1+lUVmdOhX8VBqddSulAAlAx 0+UcfpQBa2OsaGNmWQH7p4+lRMHd2I3hwcctzVeS9uJG3PKd3qABmg3lwTlpWY+/NAFhQG3LMxZX 6846VLAW81U2sykcBsEiswyMRgnini4lBBDkEd+KANS4ZlCOvmAsNuFIGPfpUbXatnzQzjrzjn9K om8nLBjJkgYGQKX7bP3dT9UFAFqR7SR8CGRGPOcgf0pqC3yfmk2jtkAj9KqNPI55K/goFJ5zjHI4 9QKANUmGRUaRpjyBkMuePwqaG1t7sIY/NGchsuox+lYfnPzyvJz90VYTULhEKoUUHuEGaALM6QRH YPOZgecbeP0pgKHlln3HOANtVZLuVypOwEDGVUCm/aJN27K5xj7ooAv3D2Pmt5UE6L1TdIrH8TtF AFs9uCXnDgnjK4x+VZ/nNnJCE/7tJ5jYI+XHXpQBdSO3eQD9/wA+hSnz/ZGkG37VvyAc7SPwqgJ2 DBgEBHoKlS9lR96iIMDkHb0NAE728JJAmKMCRtcYP86fDYJKxC3cXHJ/w/nVKe4eZtzrGG7lVwT9 aj8xsY4x1xigD7G/ZbVk+HUsEs5mRL2QR7QMYwpwMH1J616/0X5Xb1AK4z7da+bf2cNYvbbwTcR2 zW641FlXfEDklFJzk168fEupSw7oHtZgrssa+T/EM557Y9jQA/xnHImv2hjuGjfylYL5O7cAzbhk MPwH5VlXKxBVhEkzBgWysX8OD8n3hz6c9zVzUpZr+4hu2MM0uAixyJsGRuJwfung9Gx+daFoqzER GNklJ2Oz9mx/nn3FAHOeGPJsPjnaKzyH7boE8cLOOWKXCt0/h+VTnPp1r2ZPvivM9Pt7RfjTaILa RZrTQpTG8iYHzzJ8yNn5sgMDgcd8ZGfTE++KAFxmRB9P6V+Z/iWdrnxJqs8hLPLeTSMT3JkY1+mH SRPwr83PGuh6lovifUrXUrG6tpllaULLGQ2xmJVjjjkEUAYVOZsrjaPY+nt9KZkZxkZpucngj86A H0UzPuPzFO3D1H50ALRSZHqPzpAR3I/OgB1FMz7j86N3uPzoAfToygkUyKWjBBZVOCR3APaowR3I /OgnnqPzoAccZJGQPQ9qKZn3H5ijPuPzoAfRTM+4/MUvP+TQA6imZ9x+dGfcfmKAH0U0Hnkj86CR 2I/OgB1FMz7j86M+4/OgB9FMz7j86M+4/OgB1LTM+4/MVJHG8pxEjSH0Qbv5UAN70VZNheAZNpcg evlN/hURgmU4aGUH0KEGgBlFO8mXOPKkzjONp6etOFtcHOIJjjn/AFbf4UAR0UpjdSQyOCOoKnj6 0+K2uJseTBNICcAohbP5CgCOirEmn30ahpLO6VSMgtCwBH5VH9lucA/Z5uen7tv8KAI6T8KuwaTq U/8AqNPvJP8Act3b+QpX0jU44xI+nXqxn+I27gfnigClRV6HRtVnj8yHTL6SMnG5LZyM/XFXIPCP iW4QPB4e1mVD0ZLGVgfxC0AYtIK6FPBHit0Dr4Z1wqehFhLz/wCO1dtvhp43uX2w+FNaLe9oy9s9 xQByVJ/Ku7T4Q/EFwxHhPVflxnMYH5c81JD8HfiFNII18KakrE4y6qo/MnFAHA0V6hF8A/iVIu4e HQOcYa8gU/q9Sp+z98SGdVOhRKD1Zr6DA/8AHqAPKfbtS54r2GL9nL4hMQGs9OTOeWvUwPyzVkfs 1ePTg7tFHt9sPH/jtAHinFFe1j9mnx6QMtow/wC3w/8AxNO/4Zo8d/39F/8AAw//ABFAHiVFe2f8 M0eO/wDnpov/AIGH/wCIo/4Zo8d/89NE/wDAw/8AxFAHilFe1/8ADNHjz/npov8A4GH/AOIpf+Ga fHf9/Rf/AAMP/wARQB4nRXtn/DNPjv8A56aL/wCBh/8AiKmT9mTxuVy13oa+32lz/wCyUAeG0V7w P2YPGOedT0TH/XWT/wCIqZf2XPFZ66zoY/4FL/8AE0AeA0V9Br+y14l25bXtFB9Nsx/9lpf+GWvE n/QwaL/3zN/8TQB890V9DL+yz4iwd3iHRwe2ElP9Km/4ZX1rH/IzaZnI/wCXeT8aAPnOivpBP2Vt UOd/iiwHPa1kP9ak/wCGVb/P/I12eP8Arzf/AOKoA+a6K+l1/ZTus/N4utwPawb/AOLqVf2Upf4v GMY+mnE/+1KAPmOivpz/AIZSf/ock/8ABaf/AI5Th+yk3fxkv/gtP/x2gD5hpK+oR+ykM8+MePbT v/tlPT9lKH+Pxe5+mn4/9qUAfLlFfVA/ZUs+M+Lbj8LFf/i6cf2VbDt4ru8+9mv/AMVQB8q0V9T/ APDKlphceLLjPf8A0Jefp89P/wCGVbDP/I13X/gEv/xVAHyrSHpX1Sf2VLPPHiy5A9TYr/8AF1FN +ynESPJ8XuF7h9Pyf0kFAHE/AjxRo+jeH7221fULO1Y3TSBJpNjEeWvIyPUYr08fE/wnZPtfWtPc PwBCzNsxnknHf0GetYkf7Kag/vPGGR6Lp+P/AGoaQ/spj+HxgQMd9Ozz/wB/OlAG2/xc8G/Msutw FQeAIZZAD1z9ypIPjl4U+128M17AsZkH+kRxynylGeo2dCOw9a54/spHA2+MRn303/7ZVq2/ZVsg R9p8V3LjHIjslXJ/FjxQB7H4S8WaF40ubW88MzxXdnamSJpWR0kRgnK/MBkYK/mK7RP9YK4n4afD rSfAWmw2+nyTXFwkbxvcS8Fwz7ido4BOFGfRF9K7Zf8AWCgAb7w+g/lUJtYWkLtDGXK7CSo5XOce 4zzzV1Pup/uinUAc9ceF9AuQRcaFpUoPXfZxnP6VLb6Bo9sgW30jTolHQJaxgD9K3KKAMX+xNK/6 Bdh/4Cx/4Uf2HpQ6aXYf+Asf+FbVFAGJJoGkSKVfSrBlPb7Mn+FKND0oD/kF2H/gMn+FbVFAGL/Y elf9Auw/8BY/8KQaFpIJP9lafuPf7LH/AIVt0UAY39iaX/0C7D/wFT/Cj+xNL/6Bdh/4DJ/hWzRQ Bjf2Jpf/AEC7D/wFT/Cnf2Rpu3aNNstvp9nT/CteigDGOiaX/wBAyw/8BU/wp40rTwFA0+zAUkgC 3Tgnqela1FAGOdH01gobTbEhRgZtk4+nFH9i6Zgj+zLHB6/6Mn+FbFFAGLJoelSqVl0rT3UjaQ1q h49OlImhaSiKiaVp6qowALWPAHp0rbooAxl0TSlGF0uwA9rVP8KU6Nph66bYkf8AXsn+FbFFAGN/ Yml/9Auw/wDAVP8ACj+xNLx/yC7D/wABU/wrZooAxv7E0v8A6Bdh/wCAyf4VYtbG1tCTaWtvAT3i iVD+grRooArBmx95vzqN4kkbdJGjN/eZQTVwdKBQBS+zw7t3kxbsbd2wZx6fSpAoU5UAduB2q1RQ BntZ27Fy1tAWfBYmJSWxxzxzUkESQJsgjSJOu2NQo/IVcooArEswwSSD196ACMY4x09qs0UAV9zf 3m/Ojc/95vzqxRQBX3N6t+dGW/vN+dWKKAK+5vVvzpOe+TVmigCrt9qMe1WqKAKuPajHtVqigCtg 0fhVmigCrg0YNWqKAKuDS8+9WaKAKuDS8+9WaKAKpzQenSrJoPSgCvijFWaKAK2KMVZooArYoxVm igCtijFWaKAK2KMVZooArYoxVmigCtijFWaKAK2KMVZooArYoxVmigCtijFWaKAK2KMVZooArYox VmigCtihB+8FWaB96gD/2Q= ________________________________________________________________________________
Subject: Re: Oops, I think
Date: Jun 04, 2012
John, For what it is worth, I have had a bugger of a time with the aileron front spar. I cut it to fit, and it was a real tight interference fit. I had cuts on my fingers for two weeks having slid it into place. That being said, the fit was so "interference" and tight that there was not enough play to epoxy it into place. I have decided to build my wing and aileron to completion. When ready, I plan to cut the aileron out (leaving the hinge width relative to the middle aileron spar), and then epoxy the leading aileron spar in place. I think you mentioned that as one of the ideas you were considering. I guess, having considered your problem (and in a way running into it myself), that is the way I am going to tackle it. I hope my thinking is correct! My guess is you'll get the problem solved. By the way, I am a fan of your mykitplane site; it helps to follow as we are working on the same parts. Will you be attending Brodhead? Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374744#374744 ________________________________________________________________________________
Date: Jun 05, 2012
Thanks all as I have received some good ideas. I am still waiting on my spruce order from acs so I have some time to think about it. Ill have it resolved by the time I get to Brodhead! -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374749#374749 ________________________________________________________________________________
Date: Jun 05, 2012
Im favoring the capstrip idea. I would just cut the spar a little short (that would allow me to slide it in without cutting anything else) and then sliding a piece of capstrip the full length. It would be glued and nailed in place. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374751#374751 Attachments: http://forums.matronics.com//files/dsc07578_110.jpg ________________________________________________________________________________
Subject: t-nuts vs anchor nuts
Date: Jun 05, 2012
For the ailerons is anyone using t-nuts over the standard anchor nuts? The biggest difference I find is price. t-nuts .29 each vs. anchor nuts (with plastic insert) 3.30 each. Perhaps I could go with anchor nuts (which my technical advisor is telling me to do) without the plastic inserts. If so, do you use loctite to hold the screws in? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374759#374759 ________________________________________________________________________________
Date: Jun 05, 2012
Subject: Re: t-nuts vs anchor nuts
I assume you mean to mount the hinges...if so, I used T nuts. I epoxied the nuts into the wood and when I install the ailerons, I plan to put a dab of thread lock on the screws or epoxy. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 05, 2012
Yes, to mount the piano hinge. Thanks. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374762#374762 ________________________________________________________________________________
Date: Jun 05, 2012
Sm9obiwNCg0KSSBkaWQgdGhlIHNhbWUgYXMgTWlrZS4NCg0KR2FyeQ0KU2VudCBvbiB0aGUgU3By aW50riBOb3cgTmV0d29yayBmcm9tIG15IEJsYWNrQmVycnmuDQoNCi0tLS0tT3JpZ2luYWwgTWVz c2FnZS0tLS0tDQpGcm9tOiBNaWNoYWVsIFBlcmV6IDxzcGVlZGJyYWtlQHNiY2dsb2JhbC5uZXQ+ DQpTZW5kZXI6IG93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tDQpEYXRl OiBUdWUsIDUgSnVuIDIwMTIgMDk6MTU6MDggDQpUbzogPHBpZXRlbnBvbC1saXN0QG1hdHJvbmlj cy5jb20+DQpSZXBseS1UbzogcGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbVN1YmplY3Q6IFJl OiBQaWV0ZW5wb2wtTGlzdDogdC1udXRzIHZzIGFuY2hvciBudXRzDQoNCkkgYXNzdW1lIHlvdSBt ZWFuIHRvIG1vdW50IHRoZSBoaW5nZXMuLi5pZiBzbywgSSB1c2VkIFQgbnV0cy4gSSBlcG94aWVk IHRoZSBudXRzIGludG8gdGhlIHdvb2QgYW5kIHdoZW4gSSBpbnN0YWxsIHRoZSBhaWxlcm9ucywg SSBwbGFuIHRvIHB1dCBhIGRhYiBvZiB0aHJlYWQgbG9jayBvbiB0aGUgc2NyZXdzIG9yIGVwb3h5 Lg0KDQpNaWNoYWVsIFBlcmV6DQoNClBpZXRlbnBvbCBISU5UIFZpZGVvcw0KDQpLYXJldGFrZXIg QWVybw0KDQp3d3cua2FyZXRha2VyYWVyby5jb20NCg0KDQo ________________________________________________________________________________
Date: Jun 05, 2012
I used T-nuts and epoxied them in. Cheers, Gardiner ----- Original Message ---- From: John Francis <Mrkringles(at)msn.com> Sent: Tue, June 5, 2012 11:55:13 AM Subject: Pietenpol-List: t-nuts vs anchor nuts For the ailerons is anyone using t-nuts over the standard anchor nuts? The biggest difference I find is price. t-nuts .29 each vs. anchor nuts (with plastic insert) 3.30 each. Perhaps I could go with anchor nuts (which my technical advisor is telling me to do) without the plastic inserts. If so, do you use loctite to hold the screws in? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374759#374759 ________________________________________________________________________________
Subject: NX510JD IS FLIGHT READY
Date: Jun 05, 2012
The DAR came and certified my Pietenpol this morning. The weather is not cooperating. The forecasts look like it will be Saturday at least before this windy low passes out of here. Lots of covers to put on before then any way. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374770#374770 ________________________________________________________________________________
Date: Jun 05, 2012
I'm not at that point yet, so I couldn't say for for sure how I will do mine, BUT if your technical advisor says to use anchor nuts or nut plates, then I would. There is no way to saftey a tee nut, unless you used lock tight. These nut plates are all metal and not too expensive: http://www.aircraftspruce.com/catalog/hapages/anchornuts4.php and if you look at this doc: http://www.coastfab.com/images/pdf/2010/nutplates_ms21059_ms21061.pdf They self lock due to the fact that the hole is a little out of round. If all else fails, this is actual AN hardware, not true value hardware. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374771#374771 ________________________________________________________________________________
Date: Jun 05, 2012
Subject: Re: NX510JD IS FLIGHT READY
Jerry, good luck on your first flight. You won't have any trouble as I have seen your work. You might want to go up with your brother just to get the feel of flying. Gardiner ----- Original Message ---- From: Jerry Dotson <jdotson(at)centurylink.net> Sent: Tue, June 5, 2012 1:35:37 PM Subject: Pietenpol-List: NX510JD IS FLIGHT READY The DAR came and certified my Pietenpol this morning. The weather is not cooperating. The forecasts look like it will be Saturday at least before this windy low passes out of here. Lots of covers to put on before then any way. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374770#374770 ________________________________________________________________________________
Date: Jun 05, 2012
Excellent news! On 06/05/2012 12:31 PM, Jerry Dotson wrote: > --> Pietenpol-List message posted by: "Jerry Dotson" > > The DAR came and certified my Pietenpol this morning. The weather is not cooperating. The forecasts look like it will be Saturday at least before this windy low passes out of here. Lots of covers to put on before then any way. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > thru covering and painting, now in final assembly > 21" wheels > Lycoming O-235 C2C > Jay Anderson CloudCars prop 76 X 44 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=374770#374770 > > -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Date: Jun 05, 2012
Woo-hoo!!! ------Original Message------ From: Jerry Dotson Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: NX510JD IS FLIGHT READY Sent: Jun 5, 2012 10:31 AM The DAR came and certified my Pietenpol this morning. The weather is not cooperating. The forecasts look like it will be Saturday at least before this windy low passes out of here. Lots of covers to put on before then any way. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374770#374770 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Jun 05, 2012
Great News, Jerry! Good luck with the first flight. Be prepared to have the very best feeling you've ever had with your clothes on. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jerry Dotson Sent: Tuesday, June 05, 2012 1:32 PM Subject: Pietenpol-List: NX510JD IS FLIGHT READY The DAR came and certified my Pietenpol this morning. The weather is not cooperating. The forecasts look like it will be Saturday at least before this windy low passes out of here. Lots of covers to put on before then any way. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374770#374770 ________________________________________________________________________________
Subject: Formation Flying
From: Gerry Holland <gholland@content-stream.co.uk>
Date: Jun 05, 2012
Not low and slow flying but still fun. This is a video of BAE Hawks (Goshawks in USA) preparing and then flying a formation of London for the Queens 60th Anniversary. For any ex-Service Pilot they will know how much preparation was required to get 27 aircraft into formation. 3 is enough! http://vimeo.com/42489364 As an aside . YOu may notice instead of the Air Force spending tens of thousands per aircraft for GPS System they use the Bendix SkyMap III at $1000 a time. Off the shelf too. Hope I havent offended anyone with a off Piet topic but the weather is crass here in England! Regards Gerry ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Jun 05, 2012
Subject: 1st flight--flaring high in a Pietenpol
Congratulations Jerry! One man's observation is that we sit LOW on the ground in a Pietenpol and the sensation when getting close to the ground is that you're too low. Don't let that fool you. We are just not used to sitting that low in an airplane while trying to touch down. Get a good 'sight image' of where the horizon crosses thru your nose while you're doing your taxi testing and stamp that in your memory. When you get into your first landing my advice would be to carry a little power because these draggy things loose airspeed fast and stalling in high bites:) An old instructor told me to keep my vision 2/3rds the way down the runway during landing. Boy does that ever help with directional control. Ah well, for all I know Jerry you've got 2,000 hours of tailwheel time. I think I'm just giving myself a refresher since I only have a few landings this year under my belt and not all were pretty! Best wishes--you've come a long, long way. The next phase of your adventure is soon to begin! Mike C. ________________________________________________________________________________
Date: Jun 05, 2012
You could try crimping the T nut a little bit, to a slight oval shape to ma ke it more like a lock-nut.- I have never tried it (just popped in my hea d after replacing a couple nutplates at work today) but it might be worth e xperimenting.- Otherwise just use some good locktight. We have 304+hrs with T-nuts on the aileron hinges and no problems. - Shad --- On Tue, 6/5/12, John Francis wrote: From: John Francis <Mrkringles(at)msn.com> Subject: Pietenpol-List: Re: t-nuts vs anchor nuts Date: Tuesday, June 5, 2012, 12:29 PM Yes, to mount the piano hinge.- Thanks. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374762#374762 le, List Admin. ________________________________________________________________________________
Subject: cable guides
Date: Jun 05, 2012
The plans seem to show cable guides just outboard of the pulley going to the stick and another in the area where the strut joins the spar. Are just these two required or have people included more guides along the distance? Ralph in South Dakota ________________________________________________________________________________
Date: Jun 05, 2012
Congratulations, Jerry. Only 3 years, start to finish! Quite an accomplishment. Be patient with that first flight. Hold off for decent weather. (Right, Douwe?) Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374811#374811 ________________________________________________________________________________
Date: Jun 05, 2012
What spacing did you use with the T nuts/screws on the ailerons? When using the piano MS--- type hinges on an aluminum plane, we put one rivet at each hinge extension (the attach point). I am using the 1" wide MS --- aluminum piano hinges and have installed 8-24 screws and the self locking nut plates at every 3rd hinge extension. This does not seem as good as, or as stable, as having an anchor at each hinge extension. Placing the nut plate/screws any closer together may create a "fault line", or weak point, along the aileron beams (spars). Also, the self locking (slightly ovaled) nut plates work very well with bolts with hex heads. But TOO well with Phillip head screws. The nut plates are so tight they cause the heads to strip out before the screw can be secured. I have opened the nut plates with an 8-24 tap before installation so the oval is not so severe. I will use loctite when I make the final installation. Suggestions would help. Thanks in advance..... Ray Krause Building the Sky Scout. ----- Original Message ----- From: shad bell To: pietenpol-list(at)matronics.com Sent: Tuesday, June 05, 2012 6:00 PM Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts You could try crimping the T nut a little bit, to a slight oval shape to make it more like a lock-nut. I have never tried it (just popped in my head after replacing a couple nutplates at work today) but it might be worth experimenting. Otherwise just use some good locktight. We have 304+hrs with T-nuts on the aileron hinges and no problems. Shad --- On Tue, 6/5/12, John Francis wrote: From: John Francis <Mrkringles(at)msn.com> Subject: Pietenpol-List: Re: t-nuts vs anchor nuts To: pietenpol-list(at)matronics.com Date: Tuesday, June 5, 2012, 12:29 PM Yes, to mount the piano hinge. Thanks. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374762#374762 http://forums.matronbsp; - List Contribution Web Site - ________________________________________________________________________________
Date: Jun 06, 2012
Ray Mine are on 7 to 8 inch centers. Not flight tested but I have tugged on the aileron and have not noticed any problem. I was more worried about making a weak spot along the aileron spar if I put them closer. If you look at mike Cuy's aileron hinges his are spread apart too. Remember the flight speed between the aluminum plane and the Pietenpol is way different. On a faster plane I would want them closer. Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Tuesday, June 05, 2012 8:03 PM Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts What spacing did you use with the T nuts/screws on the ailerons? When using the piano MS--- type hinges on an aluminum plane, we put one rivet at each hinge extension (the attach point). I am using the 1" wide MS --- aluminum piano hinges and have installed 8-24 screws and the self locking nut plates at every 3rd hinge extension. This does not seem as good as, or as stable, as having an anchor at each hinge extension. Placing the nut plate/screws any closer together may create a "fault line", or weak point, along the aileron beams (spars). Also, the self locking (slightly ovaled) nut plates work very well with bolts with hex heads. But TOO well with Phillip head screws. The nut plates are so tight they cause the heads to strip out before the screw can be secured. I have opened the nut plates with an 8-24 tap before installation so the oval is not so severe. I will use loctite when I make the final installation. Suggestions would help. Thanks in advance..... Ray Krause Building the Sky Scout. ----- Original Message ----- From: shad <mailto:aviatorbell(at)yahoo.com> bell Sent: Tuesday, June 05, 2012 6:00 PM Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts You could try crimping the T nut a little bit, to a slight oval shape to make it more like a lock-nut. I have never tried it (just popped in my head after replacing a couple nutplates at work today) but it might be worth experimenting. Otherwise just use some good locktight. We have 304+hrs with T-nuts on the aileron hinges and no problems. Shad --- On Tue, 6/5/12, John Francis wrote: From: John Francis <Mrkringles(at)msn.com> Subject: Pietenpol-List: Re: t-nuts vs anchor nuts Date: Tuesday, June 5, 2012, 12:29 PM <http://us.mc1621.mail.yahoo.com/mc/compose?to=Mrkringles@msn.com> > Yes, to mount the piano hinge. Thanks. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374762#374762 http://forums.matronbsp; - List Contribution Web Site - href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 06, 2012
Ralph Don't forget to add cable guards to the pulleys Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ralph Sent: Tuesday, June 05, 2012 7:08 PM Subject: Pietenpol-List: cable guides The plans seem to show cable guides just outboard of the pulley going to the stick and another in the area where the strut joins the spar. Are just these two required or have people included more guides along the distance? Ralph in South Dakota ________________________________________________________________________________
Date: Jun 06, 2012
Mine are on 2" centers, and I also used # 8 MS24693 screws to attach into nutplates. I did exactly the same as Ray - used a tap to partially open the self-locking feature, otherwise the heads would strip before I got the screws all the way in. No problems yet, with 260 hours and 7 years on them. I do inspect the screws on each preflight inspection - easy to do, just lift the aileron and look to see that all screws are flush. Takes about 2 seconds per side. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Chris Sent: Wednesday, June 06, 2012 5:04 AM Subject: RE: Pietenpol-List: Re: t-nuts vs anchor nuts Ray Mine are on 7 to 8 inch centers. Not flight tested but I have tugged on the aileron and have not noticed any problem. I was more worried about making a weak spot along the aileron spar if I put them closer. If you look at mike Cuy's aileron hinges his are spread apart too. Remember the flight speed between the aluminum plane and the Pietenpol is way different. On a faster plane I would want them closer. Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Tuesday, June 05, 2012 8:03 PM Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts What spacing did you use with the T nuts/screws on the ailerons? When using the piano MS--- type hinges on an aluminum plane, we put one rivet at each hinge extension (the attach point). I am using the 1" wide MS --- aluminum piano hinges and have installed 8-24 screws and the self locking nut plates at every 3rd hinge extension. This does not seem as good as, or as stable, as having an anchor at each hinge extension. Placing the nut plate/screws any closer together may create a "fault line", or weak point, along the aileron beams (spars). Also, the self locking (slightly ovaled) nut plates work very well with bolts with hex heads. But TOO well with Phillip head screws. The nut plates are so tight they cause the heads to strip out before the screw can be secured. I have opened the nut plates with an 8-24 tap before installation so the oval is not so severe. I will use loctite when I make the final installation. Suggestions would help. Thanks in advance..... Ray Krause Building the Sky Scout. ----- Original Message ----- From: shad bell <mailto:aviatorbell(at)yahoo.com> Sent: Tuesday, June 05, 2012 6:00 PM Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts You could try crimping the T nut a little bit, to a slight oval shape to make it more like a lock-nut. I have never tried it (just popped in my head after replacing a couple nutplates at work today) but it might be worth experimenting. Otherwise just use some good locktight. We have 304+hrs with T-nuts on the aileron hinges and no problems. Shad --- On Tue, 6/5/12, John Francis wrote: From: John Francis <Mrkringles(at)msn.com> Subject: Pietenpol-List: Re: t-nuts vs anchor nuts Date: Tuesday, June 5, 2012, 12:29 PM <http://us.mc1621.mail.yahoo.com/mc/compose?to=Mrkringles@msn.com> > Yes, to mount the piano hinge. Thanks. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374762#374762 http://forums.matronbsp; - List Contribution Web Site - href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 06, 2012
Subject: landing a Piet
Great words from Jack and Shad on their experiences flying an approach and landing a Pietenpol. I too fly my final approach at 55 mph with a little power held in to pretty close to the runway. Like jack said, unless you have the wheels within 12" of the runway there will probably be a thunk. The plane three points wonderfully too and even in crosswinds I three point. I've never been able to master the wheel landing except in the Corby Starlet I owned for a few years. The Piet is a surprisingly good crosswind airplane. So glad you're getting a good feel for the ground handling Jerry. I did the same thing and it paid off getting that view and training my feet. I like the fact that you're patient for weather too--so many videos of 1st flights I see show trees blowing around and wind noise in the microphone. I don't get that. It takes 3, 6, 10, 20 years to build a plane but some have to fly it right away after it gets legal in lousy weather conditions. Glad I have a little chicken in me. Mike C. ________________________________________________________________________________
Subject: Another Pietenpol Certified
Date: Jun 06, 2012
Congratulations, Jerry! Ain't that a terrific feeling. I had the same probl em last year when I got my airworthiness. It was pouring rain during the inspection and I cou ldn't do the first flight for several days. It was worth the wait. Can't wait to hear ho w it goes. Matt Paxton NX629ML The DAR came and certified my Pietenpol this morning. The weather is not cooperating. The forecasts look like it will be Saturday at least before this windy low passes out of here. Lots of covers to put on before then any way. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 ________________________________________________________________________________
Subject: Re: Cable guides
Date: Jun 06, 2012
My Technical Adviser said I needed cable guides on all pulleys where the ca ble turned more than a few degrees. I installed a bunch of them. The consequence of a jamme d control cable is not one I care to consider. I used pulleys for the bend the aileron cables make at the back seat and they all got cable guards there also. Matt Paxton NX629ML From: "Ralph" <ralphhsd(at)itctel.com> Subject: Pietenpol-List: cable guides The plans seem to show cable guides just outboard of the pulley going to the stick and another in the area where the strut joins the spar. Are just these two required or have people included more guides along the distance? Ralph in South Dakota ________________________________________________________________________________
Subject: Re: Hegy prop; engine offset washers
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Jun 06, 2012
Thanks for the reply Oscar. That prop works very well with my C-85 on my Piet. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374850#374850 ________________________________________________________________________________
Date: Jun 06, 2012
Gary, I am looking forward to next year. My wife had family show up from Florida so I needed to stay behind this year. It looks like you had good weather which makes me feel that much worse about not going. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374853#374853 ________________________________________________________________________________
Date: Jun 06, 2012
Great stuff Jerry - Congrats.......!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374857#374857 ________________________________________________________________________________
Date: Jun 06, 2012
Good to hear another builder has persevered and finished quite the long pro ject!- I wish you the best on your first flight...I am sure it will be a thrill! Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Jun 06, 2012
> Actually, you can safety tee nuts. I epoxied mine in, but at the last minute before covering I cut a bunch of strips of thinplywood say, 1/2" by 1" and drilled a hole in the middle for the screw to protrude through. Then I glued and nailed one across each tee nut. They won't push out now . . . AH got it! 8) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374867#374867 ________________________________________________________________________________
Subject: Re: Formation Flying
Date: Jun 06, 2012
that is way awesome! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374870#374870 ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Subject: Re: cable guides
Date: Jun 06, 2012
Hey! This is an experimental airplane. You can build it any way you want. C ----- Original Message ----- From: Ralph To: pietenpol-list(at)matronics.com Sent: Tuesday, June 05, 2012 10:08 PM Subject: Pietenpol-List: cable guides The plans seem to show cable guides just outboard of the pulley going to the stick and another in the area where the strut joins the spar. Are just these two required or have people included more guides along the distance? Ralph in South Dakota ________________________________________________________________________________
Subject: Re: passengers
Date: Jun 06, 2012
Perhaps a video on how to properly enter and exit a Pietenpol is in order here? Just a thought...and a good one! -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374886#374886 ________________________________________________________________________________
Date: Jun 06, 2012
Subject: Wing attachment
Its beginning to look almost like an airplane. I started the initial mating of the wings to the fuselage last evening. Cheers, Ken ________________________________________________________________________________
Date: Jun 06, 2012
Not a video but a step-by-step procedure is in the archives. Search "How to be a Proper Pietenpol Passenger" Greg Cardinal Minneapolis ----- Original Message ----- From: "John Francis" <Mrkringles(at)msn.com> Sent: Wednesday, June 06, 2012 2:48 PM Subject: Pietenpol-List: Re: passengers > > Perhaps a video on how to properly enter and exit a Pietenpol is in order > here? Just a thought...and a good one! > > -------- > John Francis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=374886#374886 > > > ________________________________________________________________________________
Date: Jun 06, 2012
Subject: Re: Wing attachment
Looks a lot like an airplane. Nice work area too! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 06, 2012
whats a good source for the t nuts. paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374908#374908 ________________________________________________________________________________
Date: Jun 06, 2012
Thanks to Chris and all the others who responded to my question. It is hard to remember that the Sky Scout will not be the same as the Waiex in speed and performance! My spacing measures about 3 inches, so I should be OK. I have epoxied in the anchor nuts and will go back and maybe apply the plywood covers to be sure. Sure don't want the nuts to come loose in there! I agree, it will be easy to check before each flight to see if the ailerons are still attached well. Thanks again for the speedy response. Sure missed you at Fraiser Lake, Chris. Ray Krause ----- Original Message ----- From: Chris To: pietenpol-list(at)matronics.com Sent: Wednesday, June 06, 2012 2:04 AM Subject: RE: Pietenpol-List: Re: t-nuts vs anchor nuts Ray Mine are on 7 to 8 inch centers. Not flight tested but I have tugged on the aileron and have not noticed any problem. I was more worried about making a weak spot along the aileron spar if I put them closer. If you look at mike Cuy's aileron hinges his are spread apart too. Remember the flight speed between the aluminum plane and the Pietenpol is way different. On a faster plane I would want them closer. Chris Sacramento, Ca Westcoastpiet.com ------------------------------------------------------------------------- ----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ray Krause Sent: Tuesday, June 05, 2012 8:03 PM To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts What spacing did you use with the T nuts/screws on the ailerons? When using the piano MS--- type hinges on an aluminum plane, we put one rivet at each hinge extension (the attach point). I am using the 1" wide MS --- aluminum piano hinges and have installed 8-24 screws and the self locking nut plates at every 3rd hinge extension. This does not seem as good as, or as stable, as having an anchor at each hinge extension. Placing the nut plate/screws any closer together may create a "fault line", or weak point, along the aileron beams (spars). Also, the self locking (slightly ovaled) nut plates work very well with bolts with hex heads. But TOO well with Phillip head screws. The nut plates are so tight they cause the heads to strip out before the screw can be secured. I have opened the nut plates with an 8-24 tap before installation so the oval is not so severe. I will use loctite when I make the final installation. Suggestions would help. Thanks in advance..... Ray Krause Building the Sky Scout. ----- Original Message ----- From: shad bell To: pietenpol-list(at)matronics.com Sent: Tuesday, June 05, 2012 6:00 PM Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts You could try crimping the T nut a little bit, to a slight oval shape to make it more like a lock-nut. I have never tried it (just popped in my head after replacing a couple nutplates at work today) but it might be worth experimenting. Otherwise just use some good locktight. We have 304+hrs with T-nuts on the aileron hinges and no problems. Shad --- On Tue, 6/5/12, John Francis wrote: From: John Francis <Mrkringles(at)msn.com> Subject: Pietenpol-List: Re: t-nuts vs anchor nuts To: pietenpol-list(at)matronics.com Date: Tuesday, June 5, 2012, 12:29 PM Yes, to mount the piano hinge. Thanks. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374762#374762 http://forums.matronbsp; - List Contribution Web Site - href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 06, 2012
You know=2C even without any provisions to prevent loosening=2C the aileron hinges have a screw every say 6"=2C so there are something like ten in eac h aileron. The screws are about an inch and a quarter=2C or half. How in the world could enough of the ten back out far enough to do any harm at all without you noticing it? Carry a screwdriver=2C put a drop of glue of som e kind=2C or even locktite on the screws=2C and don't worry about it. 8) From: cncampbell(at)windstream.net Subject: Re: Pietenpol-List: Re: t-nuts vs anchor nuts Date: Wed=2C 6 Jun 2012 14:39:14 -0400 Gene=2C I also used T-nuts. I had some #4X1/2-inch sheet metal screws on hand so I drilled a small pilot hole beside each t-nu t on each side and ran a screw into each so that the heads of the screws overlap ped the flange of the T-nut. Those screws prevent the t-nut from coming out when the #10 flat-head screw goes in. Just wonder if I should use Loc-tite on the threads of the flat-head screws. I'm planning to do that -- just looking for confirmation that it's necessary. Chuck ----- Original Message ----- From: Gene Rambo To: pietenpol-list Sent: Tuesday=2C June 05=2C 2012 4:15 PM Subject: RE: Pietenpol-List: Re: t-nuts vs anchor nuts Actually=2C you can safety tee nuts. I epoxied mine in=2C but at the last minute before covering I cut a bunch of strips of thin plywood say=2C 1/2" by 1" and drilled a hole in the middle for the screw to protrude through. Then I glued and nailed one across each tee nut. They won't push out now . . . Gene do not archive > Subject: Pietenpol-List: Re: t-nuts vs anchor nuts > From: j_dunavin(at)hotmail.com > Date: Tue=2C 5 Jun 2012 > To: pietenpol-list(at)matronics.com > > > > I'm not at that point yet=2C so I couldn't say for for sure how I will do mine=2C BUT if your technical adv isor says to use anchor nuts or nut plates=2C then I would. There is no way to saftey a tee nut=2C unless you used lock tight. > These nut plates are all metal and not too expensive: > http://www.aircraftspruce.com/catalog/hapages/anchornuts4.php > and if you look at this doc: > http://www.coastfab.com/images/pdf/2010/nutplates_ms21059_ms21061.pdf > They self lock due to the fact that the hole is a little out of round. > > If all else fails=2C this is actual AN hardware=2C not true value hardware. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=374771#374771 > > > > > > <============= > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 06, 2012
Mike C -- good eyes. Yes, I'm planning on the Corvair. The bottom end is at Roy's Garage in Michigan having a 5th bearing installed. Mike P -- thanks. Our hangar makes a nice shop. But usually there is a Piper Pacer living in it, too. For the next couple weeks, it is having a stay-over at a friend's hangar, giving me a chance to start the work on mating the wings on the Pietenpol. Cheers, Ken On Wed, Jun 6, 2012 at 5:43 PM, Michael Perez wrote: > Looks a lot like an airplane. Nice work area too! > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > * > > * > > ________________________________________________________________________________
Subject: flight advice
Date: Jun 07, 2012
Jerry=3B You will get varying advice=2C but for first flights mine is: lift it off a t 50-55 or so. Climb out at 65 so the controls are responsive and you don' t mush. Fly your pattern at 65. Hold final at 65 till you're on short fina l=2C calm air=2C then let it bleed to 55 as you come over the threshold. I f there is a cross-wind=2C you are on your own! Taildragger pilot=2C do wh at you know how to do with these airplanes because this one is a stick and rudder airplane and it likes to come down when the power comes off. Over the numbers=2C if you have the nerve to look at the airspeed indicator =2C let 55 bleed on down to 45 when the lift will be all gone and you'd bet ter be able to reach out from the cockpit and touch the numbers painted on the runway because... any slower than that... you'll be squeaking the tires on the ground. And if you don't=2C get ready for a bounce! The ASI is all but useless beginning from when you're over the numbers=2C s o don't bother looking at it. You fly this airplane by feel and by sound an d by peripheral vision when you're down by the numbers. This airplane is a lways instructing and it doesn't care about you as a pilot at all. It's go ing to fly like a stick and rudder airplane no matter what you do! If you' re a good taildragger pilot=2C you and the Piet will quickly be great frien ds. If you're not a good taildragger pilot=2C you'll soon learn and THEN y ou'll be great friends! This airplane is so much fun to fly. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford=2C OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Jun 07, 2012
ebay right now--#8-32,$10.00/100,free ship. John On Wed, Jun 6, 2012 at 8:10 PM, nightmare wrote: > pauldonahuepilot(at)yahoo.com> > > whats a good source for the t nuts. paul > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=374908#374908 > > -- John Kuhfahl, Lt Col USAF (Ret), President, KUHLCOUPER LLC ________________________________________________________________________________
Subject: Re: flight advice
Date: Jun 07, 2012
Thanks Oscar. I will respect her. Way back when I flew the Stearman so much I hardly ever looked at the airspeed. I could tell from the song of the wires how it was doing. I sure appreciate the advice. When are you going to get Scout home? -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374928#374928 ________________________________________________________________________________
Date: Jun 07, 2012
Subject: tire pressure on motorcycle wheeled Piets
Is that a good-looking Pietenpol of Jerry's or what? That's going to get up and climb with that big engine. One thing that crossed my mind due to recent experience is adjusting tire p ressure to get grandma's feather bed just right. Or is that Goldilocks? Never no mind, but a few pounds too much tire pressure in our motorcycle tires can make the plane bounce pretty good on landing-especially if your b ungees don't have much give. I like to keep my bungee cords pretty tight so I have aileron authority in crosswinds. If the bungees are too loose you can actually have a strong crosswind get under one wing instead of bein g able to dig into it. Enough about that. I've found that 18 to 20 psi in the motorcycle wheels works well on pavemen t. Your mileage may vary. The plus side to higher tire pressures is that your takeoff roll will be fa ster. You play with the pressures and find out what works best for your suspension and runway environment. This all mak es me want to go fly. Think I'll burn some hydrocarbons soon. Mike C. [cid:image001.png(at)01CD448E.18CD1270] ________________________________________________________________________________
Subject: Re: tire pressure on motorcycle wheeled Piets
Date: Jun 07, 2012
I was wondering about that just the other day as i rolled the piet around the hangar...i would think a little resistance from the lower pressure would be good on asphalt... thanks Mike jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374937#374937 ________________________________________________________________________________
Date: Jun 07, 2012
Looks great Ken! Can't wait to see it! Curt Merdan Flower Mound Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374941#374941 ________________________________________________________________________________
Date: Jun 07, 2012
Subject: taxi testing in Florida and FAA's 1st Flight Test Guide--really
good Good report Jerry! I see scattered thunderstorms hit or miss across Flor ida on the radar. Good to hear you've got some decent weather to taxi test in. T he day is still young:) Mike C. By the way, for all who are getting close to flight testing or might be in the next year or so this is an outstanding guide by the FAA. Just paging thru this document I found a section that describes in detail how to determine the unusable fuel for you fuel system and engine combination. There is a great section on weight and balance calculations too. http://www.faa.gov/library/manuals/aircraft/media/ac90-89a.pdf Fuel Flow and Unusable Fuel Check: This is a field test to ensure the aircraft engine will get enough fuel to run properly, even if the aircraft is in a steep climb or stall attitude. (1) First, place the aircraft's nose at an angle 5 degrees above the highest anticipated climb angle. The easiest and safest way to do this with a conventional gear aircraft is to dig a hole and place the aircraft's tail in it. For a nose gear aircraft, build a ramp to raise the nose gear to the proper angle. (2) Make sure the aircraft is tied-down and chocked. With minimum fuel in the tanks, disconnect the fuel line to carburetor. The fuel flow with a gravity flow system should be 150 percent of the fuel consumption of the engine at full throttle. With a fuel system that is pressurized, the fuel flow should be at least 125 percent. When the fuel stops flowing, the remaining fuel is the ''unusable fuel'' quantity. (3) Since the fuel consumption of most modern engines is approximately .55 pounds per brake horsepower per hour for a 100 horsepower engine, the test fuel flow should be 82.5 pounds (13.7 gallons) per hour for gravity feed, or 68.75 pounds (11.5 gallons) per hour for a pressurized system. The pounds per hour divided by 60 equals 1.4 pounds and 1.15 pounds per minute fuel rate respectively. NOTE: Formula for fuel flow rate gravity feed is .55 x engine horsepower x 1.50 pounds of fuel per hour divided by 60 to get pounds per minute, divided by 6 to get gallons per minute. For a pressurized system, substitute 1.25 for 1.50 to....... ________________________________________________________________________________
Date: Jun 07, 2012
Jerry - My landing gear is configured differently and my plane's a little lighter, but I've used 35 psi to good effect. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374961#374961 ________________________________________________________________________________
Date: Jun 07, 2012
I don't know about y'all, but my Piet reeeeeally likes to roll on those big wheeels. Its hard to hold her back even in the grass at idle. I recently s witched brake lining material (Piet-ish band brakes) and the new stuff work s great and really bites in, so much so that I can hold it back on run-up. Dan Helsper Puryear, TN -----Original Message----- From: Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] (GRC-RXD0)[Vantage Partners, LLC] Sent: Thu, Jun 7, 2012 11:11 am Subject: Pietenpol-List: tire pressure on motorcycle wheeled Piets Is that a good-looking Pietenpol of Jerry=99s or what? That =99s going to get up and climb with that big engine. One thing that crossed my mind due to recent experience is adjusting tire p ressure to get grandma=99s feather bed just right. Or is that Goldilocks? Never no mind, but a few pounds too much tire pressure in our motorcycle tires can make the plane bounce pretty good on landing=94especially i f your bungees don=99t have much give. I like to keep my bungee cords pretty tight so I have aileron authority in crosswinds. If the bungees are too loose you can actually have a strong crosswind get under one wing instead of bein g able to dig into it. Enough about that. I=99ve found that 18 to 20 psi in the motorcycle wheels works well on pavement. Your mileage may vary. The plus side to higher tire pressures is that your takeoff roll will be fa ster. You play with the pressures and find out what works best for your suspension and runway environment. This all mak es me want to go fly. Think I=99ll burn some hydrocarbons soon. Mike C. ________________________________________________________________________________
Date: Jun 07, 2012
Yeah, mine likes to roll, too. My brakes (Cleveland hydraulic disc brakes) will barely hold it for a runup and cannot hold it at full throttle. Airplanes quit using big wheels about the time they started putting brakes on them. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Thursday, June 07, 2012 3:33 PM Subject: Re: Pietenpol-List: tire pressure on motorcycle wheeled Piets I don't know about y'all, but my Piet reeeeeally likes to roll on those big wheeels. Its hard to hold her back even in the grass at idle. I recently switched brake lining material (Piet-ish band brakes) and the new stuff works great and really bites in, so much so that I can hold it back on run-up. Dan Helsper Puryear, TN -----Original Message----- From: Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] (GRC-RXD0)[Vantage Partners, LLC] Sent: Thu, Jun 7, 2012 11:11 am Subject: Pietenpol-List: tire pressure on motorcycle wheeled Piets Is that a good-looking Pietenpol of Jerry's or what? That's going to get up and climb with that big engine. One thing that crossed my mind due to recent experience is adjusting tire pressure to get grandma's feather bed just right. Or is that Goldilocks? Never no mind, but a few pounds too much tire pressure in our motorcycle tires can make the plane bounce pretty good on landing-especially if your bungees don't have much give. I like to keep my bungee cords pretty tight so I have aileron authority in crosswinds. If the bungees are too loose you can actually have a strong crosswind get under one wing instead of being able to dig into it. Enough about that. I've found that 18 to 20 psi in the motorcycle wheels works well on pavement. Your mileage may vary. The plus side to higher tire pressures is that your takeoff roll will be faster. You play with the pressures and find out what works best for your suspension and runway environment. This all makes me want to go fly. Think I'll burn some hydrocarbons soon. Mike C. ________________________________________________________________________________
Subject: Re: taxi testing in Florida and FAA's 1st Flight Test
Guide--rea
Date: Jun 07, 2012
I have that publication. It is good stuff. Thanks. I have been reading it for a month now. I took the gas line off the carb and let it flow into a gallon milk jug. It took 75 seconds to fill so that figures 48 gallons an hour. It is raining kittens and puppies right now but will taxi more tomorrow. I am going to tie her down and run the engine at full power for 1 minute just to build my confidence in it some more. You see I know the mechanic that overhauled it and he looked a lot like me. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374964#374964 ________________________________________________________________________________
Date: Jun 07, 2012
Subject: Sorry, but I couldn't find a beet field...
From: Dale Mccleskey <dale.mccleskey(at)lifeway.com>
Well guys, I put N7035N down on a farm turn row in OK last saturday. Hung a wing on the corn and did the slickest "hide the airplane in the corn" trick you ever saw. Pictures attached. I've always told my wife that if I ever had to set the piet down in an emergency that I might bend the plane but wouldn't bend me. Proved the plane is a very tough little critter. Only broke the tailwheel and tailpost. It never did back up well and I guess backing into a muddy corn field is even worse. Funny part is as much as I've enjoyed the plane, I haven't flown it enough to justify the costs of housing and insuring it. June 2 was our 40th wedding anniversary, so my gift to my wife was getting rid of the plane. I determined to sell it when I got back from flight to Texas and back from Tennessee. On leg out of Davis Field, Muskogee, OK (MKO) I was climbing out and lost power. Just like I'd pulled the throttle. The FAA folks at the FSDO have convinced me it was carb ice. I've always pulled carb heat landing, but never on takeoff. Conditions were just perfect for ice. Super high humidity with unseasonable cold after thundershowers. I had to wait on the ramp for traffic to clear so had been running it a bit. Anyway, that's my story and I'm sticking to it. If anybody wants to shortcut building a GN1 variant of the Pietenpol, do I have a deal for you. I just didn't want to sell the plane and look over my shoulder with liability issues for the next 20 years. So I'm decertifying it and selling it for parts. Catch is it's a complete plane with A65, wings completely unharmed. Only damage to the fuse is the the tailwheel/tailpost, and a bent carb heat box. No prop strike and I have a brand new Cloudcars prop, only flown to Texas and part way back. I took the prop off to hang on the wall but could be talked out of it. Can't imagine anything better than building and flying the Aircamper, and you guys (including of the female type category) are great. I'm gonna keep a toe in the Piet community. Thanks guys. Give me a scream if your interested in the plane 615-754-9159 Dale McCleskey -- Dale McCleskey, Editor Adult Ministry Publishing MS# 152 LifeWay Christian Resources One LifeWay Plaza Nashville, Tennessee 37234 (615)251-3670 We will serve churches in their mission of making disciples. ________________________________________________________________________________
Date: Jun 07, 2012
Jerry, with your experience you won't have any trouble. Just fly it like you flew your crop dusters. My first flight I didn't even have an airspeed indicator. Believe it or not I had my AS hooked up to the wrong port I can't believe admitted that. By the way, what id your empty weight come out to be? Gardiner ----- Original Message ---- From: Jerry Dotson <jdotson(at)centurylink.net> Sent: Thu, June 7, 2012 8:24:18 AM Subject: Pietenpol-List: Re: flight advice Thanks Oscar. I will respect her. Way back when I flew the Stearman so much I hardly ever looked at the airspeed. I could tell from the song of the wires how it was doing. I sure appreciate the advice. When are you going to get Scout home? -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=374928#374928 ________________________________________________________________________________
Date: Jun 07, 2012
Subject: Re: Sorry, but I couldn't find a beet field...
Subject: books to buy
Date: Jun 08, 2012
purchasing the four set of bingelis books. was wondering if i should also purchase the " wood building techniques", or do the bingelis books cover what i need to know? thanks; paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375017#375017 ________________________________________________________________________________
Date: Jun 08, 2012
Buy it.....good info. Brian SLC-ut -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of nightmare Sent: Friday, June 08, 2012 10:11 AM Subject: Pietenpol-List: books to buy --> purchasing the four set of bingelis books. was wondering if i should also purchase the " wood building techniques", or do the bingelis books cover what i need to know? thanks; paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375017#375017 ________________________________________________________________________________
Date: Jun 08, 2012
The EAA wood book is worth havng, as is their aircraft welding book. Among other things, their welding book tells how to flatten the ends of tubing and there are several places on a Pietenpol where this technique is required. With those 6 books, virtually everything you need to know to build a Pietenpol is covered. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of nightmare Sent: Friday, June 08, 2012 12:11 PM Subject: Pietenpol-List: books to buy purchasing the four set of bingelis books. was wondering if i should also purchase the " wood building techniques", or do the bingelis books cover what i need to know? thanks; paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375017#375017 ________________________________________________________________________________
Date: Jun 08, 2012
Glad to hear you=92re safe, Dale. Planes can be rebuilt ' people can=92t. I=92ll bet it was carb ice ' I=92ve had similar experiences with a 65 Continental on my J-3 Cub years ago. It seems just about the worst set of conditions are high humidity and about 50=B0. I taxied a long way in such conditions once and the engine just quit as I started to do my runup. After a couple of minutes it ran fine again. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dale Mccleskey Sent: Thursday, June 07, 2012 6:47 PM Subject: Pietenpol-List: Sorry, but I couldn't find a beet field... Well guys, I put N7035N down on a farm turn row in OK last saturday. Hung a wing on the corn and did the slickest "hide the airplane in the corn" trick you ever saw. Pictures attached. I've always told my wife that if I ever had to set the piet down in an emergency that I might bend the plane but wouldn't bend me. Proved the plane is a very tough little critter. Only broke the tailwheel and tailpost. It never did back up well and I guess backing into a muddy corn field is even worse. Funny part is as much as I've enjoyed the plane, I haven't flown it enough to justify the costs of housing and insuring it. June 2 was our 40th wedding anniversary, so my gift to my wife was getting rid of the plane. I determined to sell it when I got back from flight to Texas and back from Tennessee. On leg out of Davis Field, Muskogee, OK (MKO) I was climbing out and lost power. Just like I'd pulled the throttle. The FAA folks at the FSDO have convinced me it was carb ice. I've always pulled carb heat landing, but never on takeoff. Conditions were just perfect for ice. Super high humidity with unseasonable cold after thundershowers. I had to wait on the ramp for traffic to clear so had been running it a bit. Anyway, that's my story and I'm sticking to it. If anybody wants to shortcut building a GN1 variant of the Pietenpol, do I have a deal for you. I just didn't want to sell the plane and look over my shoulder with liability issues for the next 20 years. So I'm decertifying it and selling it for parts. Catch is it's a complete plane with A65, wings completely unharmed. Only damage to the fuse is the the tailwheel/tailpost, and a bent carb heat box. No prop strike and I have a brand new Cloudcars prop, only flown to Texas and part way back. I took the prop off to hang on the wall but could be talked out of it. Can't imagine anything better than building and flying the Aircamper, and you guys (including of the female type category) are great. I'm gonna keep a toe in the Piet community. Thanks guys. Give me a scream if your interested in the plane 615-754-9159 Dale McCleskey -- Dale McCleskey, Editor Adult Ministry Publishing MS# 152 LifeWay Christian Resources One LifeWay Plaza Nashville, Tennessee 37234 (615)251-3670 We will serve churches in their mission of making disciples. ________________________________________________________________________________
Subject: Carb Icing
Date: Jun 08, 2012
Here is a link to an Air Accident Investigation Branch Report on an engine failure I had just after take off in February this year here in UK I too thought that descent was the real 'catch me' for Carb icing. It isn't as you can read. My engine is a standard Continental A75 in a Corben Junior. Regards Gerry http://www.aaib.gov.uk/publications/bulletins/may_2012/corben_junior_ace_model_e__g_bsdi.cfm ________________________________________________________________________________
Date: Jun 08, 2012
Glad to hear that ultimately, it worked out.- I am curious, how far into the corn field did the truck need to drive in to get to the plane? Was the owner of the field upset? The reason I ask is because I have thought about those kinds of situations and wondered how the owners of the fields act... with or without a shotgun in hand... Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com =0A ________________________________________________________________________________
Subject: Re: Carb Icing
Date: Jun 08, 2012
I had a Cessna 120 for about ten years.. the manual actually had you turn the carb heat on before takeoff and off as you got to full power on the roll. it had a c90 and it was an ice maker... twice i thought i was going to land prematurely ... once over a plowed field near toledo and another time i was 7000 feet above an airport in indiana.. no fear on that one. both times with heat and sinking to warmer air things cleared up... it happens fast when conditions are right i hope the full time heat on my A works ! jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375031#375031 ________________________________________________________________________________
Date: Jun 08, 2012
Subject: Willy Nilly about carb heat
So glad you're okay Dale. Congratulations on a fantastic job of 'planting' (forgive that one, please..) your plane on that narrow dirt corn path. Wow...that's tight but you did g reat. I used my carb heat cable (okay abused!) control so much in the first 6 yea rs of flying that it broke one fine day so I replaced it. (there was a bind somewhere that I worked out and it was n't lubed fully) Being the willy nilly flyer that I am I always leave my carb heat on after I check in on runup before takeoff. Most times I'll actually start the takeoff roll with carb heat on and within the first 100 feet I make it cold. Just a precaution almost no matter what the weather conditions are. In other news I wonder if anyone has ever put a full-open spring on their t hrottle arms in case their throttle linkage would ever fail? I did this on the Corby Starlet I owned because I didn't like the ball and socket setup that was required with the linkage geometry. The airflow in the cowling would have pushed the t hrottle arm to idle should that link have ever busted. Just some thoughts. Mike C. ________________________________________________________________________________
Subject: Re: books to buy
Date: Jun 08, 2012
thanks Jack. Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375039#375039 ________________________________________________________________________________
Date: Jun 08, 2012
Subject: Anyone in the Omaha area???
Subject: STATIC THRUST TESTS
Date: Jun 08, 2012
We ran some static thrust tests on my Piet this evening. Now realize these results are not official as I did not have the OFFICIAL FISH SCALE so we borrowed one. I did a 1 minute 20 second run at full power(2300 RPM). It stayed over 380# all the time. 404 was seen several times but 380's most of the time. After that run let it idle a bit to cool down then checked the thrust at 2000 RPM just for the curiosity in me. It read 310# to 320#. That was surprising. I figured it would be 200-250. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375059#375059 Attachments: http://forums.matronics.com//files/a55_155.jpg ________________________________________________________________________________
Date: Jun 08, 2012
Subject: Re: STATIC THRUST TESTS
Jerry That's good news as being better than your expectations, I am liking the 0235 even more. Good luck tomorrow, we want all the details even though we can be there, were are with you. Please be sure to get video. Great flight, safe trip John don't care you decide to archive or not ________________________________________________________________________________
Date: Jun 08, 2012
Subject: Re: 37 Days
we are planning on a Thursday arrival John Recine ________________________________________________________________________________
Date: Jun 08, 2012
I'm coming! -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375068#375068 ________________________________________________________________________________
Date: Jun 09, 2012
Subject: Paasin through to Brodhead
I will be off work that Thursday and available by cell phone, 630.306.9982. I live in Morris, IL which is just west of Joliet and just north of Dwight. If any of you are coming from the east or south and you encounter problems or you just want to take a break, give me a call. I will be driving up on Friday morning so worst case scenario you could ride with me. Need to leave Saturday night for home. We have an apartment over the garage if you get pinned down in the area either going or coming. Joe ________________________________________________________________________________
Subject: Original black and yellow
Date: Jun 09, 2012
Here is Jimmy's plane. One of the most beautiful Piets out there in my opin ion. Dan Helsper Puryear, TN ________________________________________________________________________________
Subject: Got some work done in the ward today
Date: Jun 09, 2012
Got the fuse out of the jig and outside for some sanding! 2 Years as of Friday- -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375133#375133 Attachments: http://forums.matronics.com//files/dsc_0132_182.jpg http://forums.matronics.com//files/dsc_0133_151.jpg ________________________________________________________________________________
Date: Jun 09, 2012
Jerry Great numbers! The best I've got so far with my Corvair is 280 lbs at 2500 RPM (WOT) 66x35. Maybe there's something to those certified engines! Malcolm Morrison http://home.comcast.net/~mmorrison123/Airplanes.htm ----- Original Message ----- From: "Jerry Dotson" <jdotson(at)centurylink.net> Sent: Friday, June 8, 2012 8:52:10 PM Subject: Pietenpol-List: STATIC THRUST TESTS We ran some static thrust tests on my Piet this evening. Now realize these results are not official as I did not have the OFFICIAL FISH SCALE so we borrowed one. I did a 1 minute 20 second run at full power(2300 RPM). It stayed over 380# all the time. 404 was seen several times but 380's most of the time. After that run let it idle a bit to cool down then checked the thrust at 2000 RPM just for the curiosity in me. It read 310# to 320#. That was surprising. I figured it would be 200-250. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375059#375059 Attachments: http://forums.matronics.com//files/a55_155.jpg ________________________________________________________________________________
Date: Jun 09, 2012
Jerry, with that much thrust you will be able to get a takeoff roll of about 25 ft. Gardiner. Also what is the plane your brother has? --- On Fri, 6/8/12, Jerry Dotson wrote: > From: Jerry Dotson <jdotson(at)centurylink.net> > Subject: Pietenpol-List: STATIC THRUST TESTS > To: pietenpol-list(at)matronics.com > Date: Friday, June 8, 2012, 8:52 PM > --> Pietenpol-List message posted > by: "Jerry Dotson" > > We ran some static thrust tests on my Piet this evening. Now > realize these results are not official as I did not have the > OFFICIAL FISH SCALE so we borrowed one. I did a 1 minute 20 > second run at full power(2300 RPM). It stayed over 380# all > the time. 404 was seen several times but 380's most of the > time. After that run let it idle a bit to cool down then > checked the thrust at 2000 RPM just for the curiosity in me. > It read 310# to 320#. That was surprising. I figured it > would be 200-250. > > -------- > Jerry Dotson > 59 Daniel Johnson Rd > Baker, FL 32531 > > Started building NX510JD July, 2009 > thru covering and painting, now in final assembly > 21" wheels > Lycoming O-235 C2C > Jay Anderson CloudCars prop 76 X 44 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=375059#375059 > > > > > Attachments: > > http://forums.matronics.com//files/a55_155.jpg > > > > > Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Jun 09, 2012
Malcom, He=99s got more hp, too! I haven=99t flown mine, yet, but I did look at the props on all the Corvair Piets in 2009 at Brodhead. As I recall, none were over 64=9D. You=99d gain some more rpm by cutting off a couple inches.just sayin=99 Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of gliderx5(at)comcast.net Sent: Saturday, June 09, 2012 2:16 PM Subject: Re: Pietenpol-List: STATIC THRUST TESTS Jerry Great numbers! The best I've got so far with my Corvair is 280 lbs at 2500 RPM (WOT) 66x35. Maybe there's something to those certified engines! Malcolm Morrison http://home.comcast.net/~mmorrison123/Airplanes.htm _____ From: "Jerry Dotson" <jdotson(at)centurylink.net> Sent: Friday, June 8, 2012 8:52:10 PM Subject: Pietenpol-List: STATIC THRUST TESTS We ran some static thrust tests on my Piet this evening. Now realize these results are not official as I did not have the OFFICIAL FISH SCALE so we borrowed one. I did a 1 minute 20 second run at full power(2300 RPM). It stayed over 380# all the time. 404 was seen several times but 380's most of the time. After that run let it idle a bit to cool down then checked the thrust at 2000 RPM just for the curiosity in me. It read 310# to 320#. That was surprising. I figured it would be 200-250. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375059#375059 Attachments: http://forums.= - MATRONICS WEB FORUMS===== ________________________________________________________________________________
Date: Jun 09, 2012
First: Dale=2C sorry to hear about the corn field=2C but glad that the airp lane won and you walked away. Like I said before=2C these old airplanes ju st seem to change hands and live on forever=2C and I hope that yours does =2C too. On the tire pressure issue=2C the best advice I ever got was from Mike Cuy- inflate the tires until the tire tread is just visible above the hangar fl oor when you're looking at the tire from the side. Scout has 6.00x6s on Cl eveland wheels and brakes (from a Cessna) and it operates just right with t hat tire pressure. I've measured it a time or two but after getting Mikee' s advice I don't bother with the gauge. It is WAY less than the 32-35 psi that others have stated. I can fly it with that much pressure but it seems to behave like it's had too much coffee... bouncy=2C jittery. Anyway=2C S cout weighs something like 640 empty=2C so it's a light airplane. Last bit: Jerry=2C after you're done testing the fuel flow with that gallon jug=2C save it for Corky. He's saving them up to add buoyancy in the fuse lage for that loooonnnnggg overwater flight from Louisiana to Belize. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford/Ashland=2C OR website at http://www.flysquirrel.net ________________________________________________________________________________
Subject: Re: Got some work done in the yard today
Date: Jun 09, 2012
Earl, Looks real nice. I hope to start and complete my fuse over the winter months. Do you have your wings finished? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375152#375152 ________________________________________________________________________________
Date: Jun 09, 2012
Not yet- ribs are all done- tail woodwork is done so wings are next on the list! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375153#375153 ________________________________________________________________________________
Subject: NX53WE in the air
Date: Jun 09, 2012
NX53WE left the ground about 8:00 pm saturday evening and flew about 15 min. with no surprises. Twenty two months and about 2500 hours and it was all worth it. It flew at 30 mph to 90 mph very stable, Very exciting! Now to fly off the 25 hours. Bob ________________________________________________________________________________
Subject: For sale in UK
From: Gerry Holland <gholland@content-stream.co.uk>
Date: Jun 10, 2012
FYI. Pietenpol on eBay from UK. http://www.ebay.co.uk/itm/Pietenpole-Air-camper-Complete-airframe-wings-tail-feathers-landing-gear-eng-/251081803377?pt=UK_CPV_Aviation_SM&hash=item3a75a44671#ht_500wt_1348 ________________________________________________________________________________
Date: Jun 10, 2012
Outstanding, Bob! Great feeling, isn't it? Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bob edson Sent: Saturday, June 09, 2012 10:49 PM Subject: Pietenpol-List: NX53WE in the air NX53WE left the ground about 8:00 pm saturday evening and flew about 15 min. with no surprises. Twenty two months and about 2500 hours and it was all worth it. It flew at 30 mph to 90 mph very stable, Very exciting! Now to fly off the 25 hours. Bob ________________________________________________________________________________
From: "woodflier(at)aol.com" <woodflier(at)aol.com>
Date: Jun 10, 2012
I' m leaving Wed. and plan on getting to Brodhead by Thurs. Will fly with Rambo if he's ready, and Jack Phillips if he flies his Piet. Probably can' t convince him to fly the RV at 72 mph. Matt Paxton Connected by DROID on Verizon Wireless ________________________________________________________________________________
Subject: Roman Bukolt
Date: Jun 10, 2012
I just received news that Roman passed away Thursday from cancer. He was a good addition to the Pietenpol community. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com ________________________________________________________________________________
Subject: Re: NX53WE in the air
Date: Jun 10, 2012
Very Nice-Congratulations!! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375192#375192 ________________________________________________________________________________
Date: Jun 10, 2012
Subject: Re: Roman Bukolt
My condolences to his friends and family. Roman was a nice guy, in met him at Broadhead in 2007 -when he sold me a set of ribs. I later sold them to another builder in-Australia but always-wished I had kept them because the workmanship was fantastic.=0A=0ARyan Michals=0A=0A=0A_________________ _______________=0A From: John Hofmann <jhofmann(at)reesgroupinc.com>=0ATo: pie tenpol-list(at)matronics.com =0ASent: Sunday, June 10, 2012 10:04 AM=0ASubject : Pietenpol-List: Roman Bukolt=0A =0A=0AI just received news that Roman pas sed away Thursday from cancer. He was a good addition to the Pietenpol comm unity.=0A=0A-john-=0A=0A=0AJohn Hofmann=0AVice-President, Information Techn ology=0AThe Rees Group, Inc.=0A2424 American Lane=0AMadison, WI 53704=0APho ne: 608.443.2468 ext 150=0AFax: 608.443.2474=0AEmail:-jhofmann@reesgroupi ===================== ________________________________________________________________________________
Date: Jun 10, 2012
So sorry to hear that. Roman and I had two connections. Not only did we both own Pietenpols, but we were both building RV-10's. I'll miss him. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Hofmann Sent: Sunday, June 10, 2012 10:04 AM Subject: Pietenpol-List: Roman Bukolt I just received news that Roman passed away Thursday from cancer. He was a good addition to the Pietenpol community. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com ________________________________________________________________________________
Date: Jun 10, 2012
Congrats, Bob! It's always inspiring to see yet another one take to the air. -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375214#375214 ________________________________________________________________________________
Date: Jun 10, 2012
Wow, so sad to hear that Roman went west. Condolences to his family and friends. -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375215#375215 ________________________________________________________________________________
Date: Jun 10, 2012
I'll be there, but driving in from Baton Rouge, LA. Might get there Thursday night, but will definitely be there for Friday morning's Bratfest II. Jack T, is there anything that any one of us can bring to help out? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375216#375216 ________________________________________________________________________________
Date: Jun 10, 2012
Billy thanks we have it covered. Just bring a chair and you choice of beverage. Jack Textor Sent from my iPad On Jun 10, 2012, at 1:51 PM, "Billy McCaskill" wrote: > > I'll be there, but driving in from Baton Rouge, LA. Might get there Thursday night, but will definitely be there for Friday morning's Bratfest II. Jack T, is there anything that any one of us can bring to help out? > > -------- > Billy McCaskill > Baker, LA > tail section almost done, starting on ribs soon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=375216#375216 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2012
Fantastic Bob!!!!....And you have a really nice looking aeroplane!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375220#375220 ________________________________________________________________________________
Subject: Hardware Size
Date: Jun 10, 2012
Can anyone please share with me what size hardware they used on the forward rudder pedal brackets and control stick bearing mounts? I've searched the archives and looked over the drawings with no luck. AN3s seem way too thick for the copilots rudder pedals considering they are only going thru plywood. Thanks, Ryan Sent from my iPhone On Jun 10, 2012, at 3:53 PM, "moondogman" wrote: > > Fantastic Bob!!!!....And you have a really nice looking aeroplane!!! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=375220#375220 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2012
AN3's, but with AN970 washers (large). Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aircamperace(at)yahoo.com Sent: Sunday, June 10, 2012 4:26 PM Subject: Pietenpol-List: Hardware Size Can anyone please share with me what size hardware they used on the forward rudder pedal brackets and control stick bearing mounts? I've searched the archives and looked over the drawings with no luck. AN3s seem way too thick for the copilots rudder pedals considering they are only going thru plywood. Thanks, Ryan Sent from my iPhone On Jun 10, 2012, at 3:53 PM, "moondogman" wrote: > --> > > Fantastic Bob!!!!....And you have a really nice looking aeroplane!!! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=375220#375220 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 11, 2012
Hi John, Thanks for the note about Roman . I met him a couple of years ago at Brodhead; he was a good guy and very nice to talk to. Jim B. ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Brodhead
Date: Jun 10, 2012
Marci and I plan to be there Thursday! And remember all, They don't like campers and generators on the far side of the runway, only tent camping. Douwe ________________________________________________________________________________
Subject: Who's planes are attending Brodhead?
Date: Jun 10, 2012
I'm wondering who IS flying their Piets to Brodhead this year? Sounds like Jack P, Don Emch and Greg C probably won't for various reasons, so there's three regulars gone. Who else is coming up? Sounding a bit skimpy. Douwe ________________________________________________________________________________
Date: Jun 11, 2012
Way to go Bob, you have a beautiful Piet. Have fun and enjoy the 25 hour fly off. Jim B. ________________________________________________________________________________
Subject: Re: Who's planes are attending Brodhead?
Date: Jun 10, 2012
I am still hoping to be in attendance but that could change. NX18235 will be there for sure but it may have a back-up pilot at the controls. Greg Cardinal ----- Original Message ----- From: Douwe Blumberg To: pietenpolgroup Sent: Sunday, June 10, 2012 8:51 PM Subject: Pietenpol-List: Who's planes are attending Brodhead? I'm wondering who IS flying their Piets to Brodhead this year? Sounds like Jack P, Don Emch and Greg C probably won't for various reasons, so there's three regulars gone. Who else is coming up? Sounding a bit skimpy. Douwe ________________________________________________________________________________
Date: Jun 10, 2012
502R will be there for a couple of days. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Jun 10, 2012, at 8:51 PM, Douwe Blumberg wrote: > I=92m wondering who IS flying their Piets to Brodhead this year? > > Sounds like Jack P, Don Emch and Greg C probably won=92t for various reasons, so there=92s three regulars gone. > > Who else is coming up? Sounding a bit skimpy=85 > > Douwe > > > > > > ________________________________________________________________________________
Date: Jun 10, 2012
Roman was a character. I found out his wife passed away just a month before he did. I think cancer is not the only ailment that took him in the end. I don't know if many remember Ryder Olson but he used to hang out on this list and Brodhead for a few years. I received word from his family via a MAAC mailing that he passed a few months ago as well. Not a good day and sorry to be the bearer of the news. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Jun 10, 2012, at 8:43 PM, Jim Boyer wrote: > Hi John, > Thanks for the note about Roman. I met him a couple of years ago at Brodhead; he was a good guy and very nice to talk to. > Jim B. > > > > > > ________________________________________________________________________________
Date: Jun 11, 2012
Roman was the first Pietenpol builder with whom I emailed back and forth offsite, and the first I talked with on the phone. He was very helpful in all respects. We met at Brodhead in 2006 and 2008 and he was even more congenial and informative in person. The Pietenpol community will miss him. Here is a Roman story you may not know. My friend Tom visited Roman at his home while Roman's Piet build was in early stages. Roman told Tom that he had looked at over twenty houses before buying that one; in each case the first criterion was seeing if a basement window was large enough to pass a finished Piet fuselage. (No, I don't know if his spec. included the turtledeck.) Condolences to his friends and family. ________________________________________________________________________________
Date: Jun 11, 2012
I used AN3's, with AN 970 washers under the nuts. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aircamperace(at)yahoo.com Sent: Sunday, June 10, 2012 7:26 PM Subject: Pietenpol-List: Hardware Size Can anyone please share with me what size hardware they used on the forward rudder pedal brackets and control stick bearing mounts? I've searched the archives and looked over the drawings with no luck. AN3s seem way too thick for the copilots rudder pedals considering they are only going thru plywood. Thanks, Ryan Sent from my iPhone On Jun 10, 2012, at 3:53 PM, "moondogman" wrote: > > Fantastic Bob!!!!....And you have a really nice looking aeroplane!!! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=375220#375220 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 11, 2012
NX929DH will be there God willing, probably Thursday sometime. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Jun 11, 2012
NX294RB will be there Thursday afternoon I hope Sent from my iPhone On Jun 11, 2012, at 6:27 AM, helspersew(at)aol.com wrote: > NX929DH will be there God willing, probably Thursday sometime. > > Dan Helsper > Puryear, TN > > > > > ________________________________________________________________________________
Date: Jun 11, 2012
NX899DE hasn't been much of a regular the past couple of years... and this year my youngest daughter is in a wedding on that Saturday. Of all the 52 Saturdays it had to be that one.....!! This would have been my 20th consecutive Brodhead attendance! Oh well... it'll be worth missing I'm sure. I will be barnstorming the Piet around Ohio and Indiana the week of Brodhead though. Right up until Thursday or Friday... just can't head up that way. Next year..... Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375266#375266 ________________________________________________________________________________
Date: Jun 11, 2012
I will not be able to make it this year. I have one wing to cover and two w ings to rib stitch. Then I have to put everything together and see if it st ill flies. Cheers, Gardiner. --- On Sun, 6/10/12, Douwe Blumberg wrote: From: Douwe Blumberg <douweblumberg(at)earthlink.net> Subject: Pietenpol-List: Who's planes are attending Brodhead? Date: Sunday, June 10, 2012, 9:51 PM =0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0AI=99m wondering who IS flying their Piets to Brodhead=0Athis year? =0A=0A =C2- =0A=0ASounds lik e Jack P, Don Emch and Greg C probably won=99t=0Afor various reasons, so there=99s three regulars gone. =0A=0A =C2- =0A=0AWho else is co ming up?=C2- Sounding a bit skimpy =0A=0A =C2- =0A=0ADouwe =0A -======================== ============0A=0A ________________________________________________________________________________
Date: Jun 11, 2012
That is good news Bob!- Fast build time, great speed range and it flies.. .mission accomplished. Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Jun 11, 2012
Of course, N8031 will be there. Dan On 06/10/2012 08:51 PM, Douwe Blumberg wrote: > Im wondering who IS flying their Piets to Brodhead this year? > > Sounds like Jack P, Don Emch and Greg C probably wont for various > reasons, so theres three regulars gone. > > Who else is coming up? Sounding a bit skimpy > > Douwe > > * > > > * -- Dan Yocum Fermilab 630.840.6509 yocum@fnal.gov, http://fermigrid.fnal.gov "I fly because it releases my mind from the tyranny of petty things." ________________________________________________________________________________
Subject: did Jerry fly yet?
Date: Jun 11, 2012
I seem to have missed one day of the list. Did Jerry fly yet?? Douwe ________________________________________________________________________________
Subject: Re: Piets flying to Brodhead
Date: Jun 11, 2012
Douwe, I'm planning on flying my Piet to Brodhead. Weather permitting, I ho pe to be there by Thurday afternoon. Matt Paxton NX629ML From: "Douwe Blumberg" <douweblumberg(at)earthlink.net> Subject: Pietenpol-List: Who's planes are attending Brodhead? I'm wondering who IS flying their Piets to Brodhead this year? Sounds like Jack P, Don Emch and Greg C probably won't for various reasons, so there's three regulars gone. Who else is coming up? Sounding a bit skimpy. Douwe ________________________________________________________________________________
Subject: My first Pietenpol flight
Date: Jun 11, 2012
I flew C-GFQY for the first time last evening. After attending to a few details since I bought her in the spring she was ready to go this weekend. Then it was windy and then it rained, but Sunday about supper time, it promised to be good so I drove out to the field. On top of the elevator in town the national flag was fluttering with about 1/2 enthusiasm from the southwest. I wanted the use the NW-SE runway though for the first flight, since the N-S one has houses at the south end and tall trees and there is a forest at the north end but the other runway has large fields off each end. We decided to sit and wait for the evening lull. During some conversation about my nerves and other things I noticed the flag hanging limp. It was now or never. But on starting the engine I got no oil pressure. Uh oh, was this a sign? My nerves were acting up again. Jim Armstrong came out and offered some advice on getting the pump primed by adding an extra quart of oil and raising the tail while turning the prop. This trick worked like a charm. Drained the excess oil and off I went. I climbed to about 1000 feet and flew around for about half an hour over large expanses of farm land with young crops gradually relaxing and getting the feel of the piet. Then while heading west looking at the sparkle of the lowering sun on Lake Huron I became aware of a significant drift to the North in my track. I turned back to the the field and sure enough the flag was standing out indicating the onshore breeze from the SW had kicked up again. Hmmm. What to do? I decided to do a dry run on the approach so I could see how things might go with a light 90 deg cross on my preferred runway hoping that it was calm close to ground level. With a wing low I had no trouble tracking straight down the runway and sure enough the wind seemed to die off at tree top height and I could have continued on and landed but I don't like to deviate from a plan so I went around and did it again. I carried a little power till just over the threshold! and had a nice smooth landing and roll out. What a charming airplane was the first reaction I had to the question How was it? from the folks gathered at the hangar. And that is just how I felt when I flew her looking over the nose past those eyebrows on the horizon. Charmed. It's just like stepping back in time to an earlier era of aviation to fly one of these isn't it? I look forward to many more. Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375299#375299 ________________________________________________________________________________
Date: Jun 11, 2012
Fantastic, Joe! Will you bring it to Brodhead next month? Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of scudrun Sent: Monday, June 11, 2012 12:53 PM Subject: Pietenpol-List: My first Pietenpol flight I flew C-GFQY for the first time last evening. After attending to a few details since I bought her in the spring she was ready to go this weekend. Then it was windy and then it rained, but Sunday about supper time, it promised to be good so I drove out to the field. On top of the elevator in town the national flag was fluttering with about 1/2 enthusiasm from the southwest. I wanted the use the NW-SE runway though for the first flight, since the N-S one has houses at the south end and tall trees and there is a forest at the north end but the other runway has large fields off each end. We decided to sit and wait for the evening lull. During some conversation about my nerves and other things I noticed the flag hanging limp. It was now or never. But on starting the engine I got no oil pressure. Uh oh, was this a sign? My nerves were acting up again. Jim Armstrong came out and offered some advice on getting the pump primed by adding an extra quart of oil and raising the! tail while turning the prop. This trick worked like a charm. Drained the excess oil and off I went. I climbed to about 1000 feet and flew around for about half an hour over large expanses of farm land with young crops gradually relaxing and getting the feel of the piet. Then while heading west looking at the sparkle of the lowering sun on Lake Huron I became aware of a significant drift to the North in my track. I turned back to the the field and sure enough the flag was standing out indicating the onshore breeze from the SW had kicked up again. Hmmm. What to do? I decided to do a dry run on the approach so I could see how things might go with a light 90 deg cross on my preferred runway hoping that it was calm close to ground level. With a wing low I had no trouble tracking straight down the runway and sure enough the wind seemed to die off at tree top height and I could have continued on and landed but I don't like to deviate from a plan so I went around and did it! again. I carried a little power till just over the threshold! and had a nice smooth landing and roll out. What a charming airplane was the first reaction I had to the question How was it? from the folks gathered at the hangar. And that is just how I felt when I flew her looking over the nose past those eyebrows on the horizon. Charmed. It's just like stepping back in time to an earlier era of aviation to fly one of these isn't it? I look forward to many more. Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375299#375299 ________________________________________________________________________________
Date: Jun 11, 2012
Subject: Re: My first Pietenpol flight
Sounds like a fantastic flight Joe, congratulations on flying the Piet and have many more just like it. Jim B. ________________________________________________________________________________
Subject: Fuel primer "A"
Date: Jun 11, 2012
You guys with Ford A's... it looks like most have drilled a hole at the top of the intake manifold for a primer line..centered above the down tube. is this any kind of special fitting or just 1/8" pipe with a line to it ? i was thinking maybe it should be more toward the front or back... but if it works good in the middle i'm cool with that, the other thing is the primer itself.... i was thinking about putting it out by the engine.. just above the cascolator...short lines.. and i'll be out there starting it anyway.. thanks.. jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375344#375344 ________________________________________________________________________________
Date: Jun 11, 2012
My wife and I will be driving out and arriving Thursday afternoon. I am looking forward to inspecting a lot of planes for ideas as I move forward on the cable installations. Ralph and Carol in South Dakota ________________________________________________________________________________
Subject: Re: Anyone in the Omaha area????
Date: Jun 11, 2012
Jim email me at crhill74(at)yahoo.com. I live in Bellevue, NE. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375352#375352 ________________________________________________________________________________
Subject: Re: Fuel primer "A"
Date: Jun 11, 2012
Most of the Ford conversions that I have been around did not need a primer for starting in normal flying temperatures. From my experience, the starting drill has been: switch off, fuel on, throttle closed, pull through 4 leisurely blades, then make it hot and it will go. Alternately, do all as above, except when you hear it sucking on the intake stroke, rock the prop back and forth a few times to load the intake until it drips (not my favorite due to fire danger), then make it hot and it will go. Depending on the temperature, you might or might not need to crack the throttle after pulling it through. This has been the drill with NX311GP, another engine that my dad and I built 25 years ago, and as I recall, that was the way Allen Rudolf started N13691. NX311GP has a B carb, the engine from my childhood has an A carb, and Mr Rudolf used a B carb. I would imagine that the Tillotson would be similar. BTW, the B carbs are designed to run with the "Gas Adjusting Valve" (main mixture needle) closed after warm up, but the A carbs usually need to be opened a bit. Since these carbs are now 80 years old, this shouldn't be taken as gospel, but it might be useful as a guideline. Brett Phillips "simplicate and add lightness" ________________________________________________________________________________
Subject: Piano hinge?
Date: Jun 11, 2012
Hey all, I need to place an order for aileron piano hinges. Does anyone have either an Aircraft Spruce or Wick's parts number on what they used? I looked through the online catalog and didn't see exactly what I thought I need. Any help would be appreciated. Thanks, Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375355#375355 ________________________________________________________________________________
Date: Jun 12, 2012
Subject: Re: Piano hinge?
About 5 minutes searching in the archives reveals: http://www.matronics.com/searching/getmsg_script.cgi?INDEX=27091722?KEYS=piano_hinge?LISTNAME=Pietenpol?HITNUMBER=240?SERIAL=22460831284X?SHOWBUTTONS=YES And: http://www.aircraftspruce.com/catalog/mepages/pianohinge.php http://www.matronics.com/search Choose the Piet archive, follow the instructions to properly format your search. Play around with it for a while, a wealth of info in there... Ryan On Mon, Jun 11, 2012 at 11:49 PM, tdudley(at)umn.edu wrote: > > Hey all, > > I need to place an order for aileron piano hinges. Does anyone have > either an Aircraft Spruce or Wick's parts number on what they used? I > looked through the online catalog and didn't see exactly what I thought I > need. Any help would be appreciated. > > Thanks, > > Tom > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=375355#375355 > > ________________________________________________________________________________
Date: Jun 12, 2012
But, that is not what Jack recommends. Adrian, Having flown Pietenpols with and without the aileron gaps sealed, I would strongly urge you to use aluminum piano hinges the full length of the aileron. Without the gaps sealed, the ailerons are sluggish and borderline ineffective. With full span piano hinges, you have a nice strong hinge and get the gap sealed for free. One word of advice - it is far easier if you use one 6 foot piece of piano hinge per aileron. I followed the advice given by Tony Bingelis and broke my hinges up into 6 12" sections so that if the wing was flexed while I was inputting aileron, the hinges would not bind. Totally unnecessary, and it really makes keeping all those hinges properly aligned very difficult. Mike Cuy used one long hinge per aileron and it works just fine. Also, I would use the cheaper AN257 rather than the MS20001 type. Plenty strong enough and 1/5th the price. I used the more expensive (and stronger) MS20001 type but would not do so if I were to do it over. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -- - The Matronics Pietenpol-List Email Forum - Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more: http://www.matronics.com/Navigator?Pietenpol-List -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375365#375365 ________________________________________________________________________________
Date: Jun 12, 2012
I have found that at times it takes a squirt of primer to get going. But wh at Brett says is probably right, as he has more experience than I. Maybe yo u could leave it off until you decide for yourself? Only reason I put one o n is I saw that Ken Perkins had one, and also I bought my whole induction s et-up from him and the fitting was on there already. It is an 1/8" tube fit ting to accept a primer line. Primer by the gascolator should be fine. The primer fitting off to one side is probably better, since if I give it too m uch she drips out from that drain hole on the bottom of the carb, leaving f uel stains down the outside of the cowl. Dan Helsper Puryear, TN -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Mon, Jun 11, 2012 5:21 pm Subject: Pietenpol-List: Fuel primer "A" > You guys with Ford A's... t looks like most have drilled a hole at the top of the intake manifold for a rimer line..centered above the down tube. s this any kind of special fitting or just 1/8" pipe with a line to it ? was thinking maybe it should be more toward the front or back... but if it orks good in the middle i'm cool with that, he other thing is the primer itself.... i was thinking about putting it out by he engine.. just above the cascolator...short lines.. and i'll be out there tarting it anyway.. thanks.. eff ead this topic online here: http://forums.matronics.com/viewtopic.php?p=375344#375344 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 12, 2012
Hi Joe, An eloquent story to inspire the masses! Fantastic! Can't wait to see her. Congrats!! Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Jun 12, 2012
Dan: While I have some experience with A's on the ground, I do not have experience in the all important flight mode! I think you have me beat there for sure. A flying Ford powered Piet has been a goal of mine for a long time now (over 25 years), and while it is now much closer to hand than it was, I still have a ways to go. Brett On Tue, Jun 12, 2012 at 7:25 AM, wrote: > I have found that at times it takes a squirt of primer to get going. But > what Brett says is probably right, as he has more experience than I. Maybe > you could leave it off until you decide for yourself? Only reason I put one > on is I saw that Ken Perkins had one, and also I bought my whole induction > set-up from him and the fitting was on there already. It is an 1/8" tube > fitting to accept a primer line. Primer by the gascolator should be fine. > The primer fitting off to one side is probably better, since if I give it > too much she drips out from that drain hole on the bottom of the carb, > leaving fuel stains down the outside of the cowl. > > Dan Helsper > Puryear, TN > * * > ________________________________________________________________________________
Date: Jun 12, 2012
NX92GB has the rolled piano hinge (the cheaper one) and has over 300hrs of flight time with no problems.- Dad used 1 long hinge section and there ar e no binding issues. - Shad --- On Tue, 6/12/12, John Francis wrote: From: John Francis <Mrkringles(at)msn.com> Subject: Pietenpol-List: Re: Piano hinge? Date: Tuesday, June 12, 2012, 4:48 AM But, that is not what Jack recommends. Adrian, Having flown Pietenpols with and without the aileron gaps sealed, I would strongly urge you to use aluminum piano hinges the full length of the aileron. Without the gaps sealed, the ailerons are sluggish and borderline ineffective. With full span piano hinges, you have a nice strong hinge and get the gap sealed for free. One word of advice - it is far easier if you use one 6 foot piece of piano hinge per aileron. I followed the advice given by Tony Bingelis and broke my hinges up into 6 12" sections so that if the wing was flexed while I was inputting aileron, the hinges would not bind. Totally unnecessary, and it really makes keeping all those hinges properly aligned very difficult. Mike Cuy used one long hinge per aileron and it works just fine. Also, I would use the cheaper AN257 rather than the MS20001 type. Plenty strong enough and 1/5th the price. I used the more expensive (and stronger) MS20001 type but would not do so if I were to do it over. Jack Phillips NX899JP "Icarus Plummet" Raleigh, NC -- - The Matronics Pietenpol-List Email Forum - =C2- Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Brow se, Chat, FAQ, Photoshare, and much more: http://www.matronics.com/Navigator?Pietenpol-List -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375365#375365 le, List Admin. ________________________________________________________________________________
Date: Jun 12, 2012
Dan=2C if you recall a couple of years ago at Brodhead I asked whether the primer was necessary=2C as I was not planning on putting one on mine. You and I tried propping yours bopth hot and cold without prime and determined that it was not necessary. Gene To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Fuel primer "A" From: helspersew(at)aol.com Date: Tue=2C 12 Jun 2012 07:25:57 -0400 I have found that at times it takes a squirt of primer to get going. But wh at Brett says is probably right=2C as he has more experience than I. Maybe you could leave it off until you decide for yourself? Only reason I put one on is I saw that Ken Perkins had one=2C and also I bought my whole inducti on set-up from him and the fitting was on there already. It is an 1/8" tube fitting to accept a primer line. Primer by the gascolator should be fine. The primer fitting off to one side is probably better=2C since if I give it too much she drips out from that drain hole on the bottom of the carb=2C l eaving fuel stains down the outside of the cowl. Dan Helsper Puryear=2C TN -----Original Message----- From: bender <jfaith(at)solairusaviation.com> Sent: Mon=2C Jun 11=2C 2012 5:21 pm Subject: Pietenpol-List: Fuel primer "A" > You guys with Ford A's... it looks like most have drilled a hole at the top of the intake manifold fo r a primer line..centered above the down tube. is this any kind of special fitting or just 1/8" pipe with a line to it ? i was thinking maybe it should be more toward the front or back... but if i t works good in the middle i'm cool with that=2C the other thing is the primer itself.... i was thinking about putting it ou t by the engine.. just above the cascolator...short lines.. and i'll be out ther e starting it anyway.. thanks.. jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375344#375344 " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 12, 2012
Tom, As much as I respect Jack Phillips suggestions, I too went with the MS extruded aluminum hinge vs. the rolled version. As I understand it, it is more than just the strength of the rotating part of the hinge but the material that you will drill through to mount it is much stronger on the MS version. I am reading that some of these holes are drilled low on the hinge to mount it and the extra strength is needed in the material to prevent the hinge from bending over. My technical advisor also suggested the stronger hinge. He also suggested I put several smaller sections in as Tony Bingelis suggests, but I am not going to do that for several reasons. A couple are that some (Jack Phillips, Mike Cuy) and numerous others are running one continuous piece which is easier to align and gives you the gapless hinge you need on the ailerons. My technical advisor felt several smaller hinges would give some redundancy if one section should fail and that is the way many certified aircraft ailerons are hinged. Just my thoughts. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375387#375387 ________________________________________________________________________________
Subject: Brodhead and progress
Date: Jun 12, 2012
Of course, we're all hoping Greg can come, but I'm glad I'll be able to see their lovely plane again. One of my favorites. I'll miss Don as well, though choosing his daughter's wedding over Brodhead does make one question his priorities. :-) Sounds like we might see some new ones, which is very exciting, and if all goes well we should see a LOT of new ones in the next year or two. I'm really thinking 2013 will be the year for 799B "Re-PIET" will make it. Progress report. Cowling finally finished, came out pretty well. Am now ripping through covering the empennage and fuselage (ever noticed how many French words there are re planes??, they were quite the pioneers early on) am hoping to get Marci in on stitching to help speed things along and give her a sense of involvement. Douwe ________________________________________________________________________________
Date: Jun 12, 2012
I used multiple short hinges on mine rather than a continuous 6' length - unnecessary, and much more difficult in my opinion. I used the stronger (and much more expensive) MS20001 hinges. Again,unnecessary. As your Technical Counselor noted many certified aircraft use short pieces of piano hinges. Look at the hinges on a Piper Cherokee, and note that they use the cheaper and weaker AN257 rolled type hinges. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Francis Sent: Tuesday, June 12, 2012 9:54 AM Subject: Pietenpol-List: Re: Piano hinge? --> Tom, As much as I respect Jack Phillips suggestions, I too went with the MS extruded aluminum hinge vs. the rolled version. As I understand it, it is more than just the strength of the rotating part of the hinge but the material that you will drill through to mount it is much stronger on the MS version. I am reading that some of these holes are drilled low on the hinge to mount it and the extra strength is needed in the material to prevent the hinge from bending over. My technical advisor also suggested the stronger hinge. He also suggested I put several smaller sections in as Tony Bingelis suggests, but I am not going to do that for several reasons. A couple are that some (Jack Phillips, Mike Cuy) and numerous others are running one continuous piece which is easier to align and gives you the gapless hinge you need on the ailerons. My technical advisor felt several smaller hinges would give some redundancy if one section should fail and that is the way many certified aircraft ailerons are hinged. Just my thoughts. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375387#375387 ________________________________________________________________________________
Subject: Re: BPA sculpture donation
Date: Jun 12, 2012
Here are some pics. Just scroll down. They look great! http://www.pietenpols.org/id17.html -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375397#375397 ________________________________________________________________________________
Date: Jun 12, 2012
Mine are the MS version, all one piece. But that's when I had money to burn . Dan Helsper Puryear, TN -----Original Message----- From: John Francis <Mrkringles(at)msn.com> Sent: Tue, Jun 12, 2012 8:54 am Subject: Pietenpol-List: Re: Piano hinge? Tom, As much as I respect Jack Phillips suggestions, I too went with the MS extr uded luminum hinge vs. the rolled version. As I understand it, it is more than ust the strength of the rotating part of the hinge but the material that yo u ill drill through to mount it is much stronger on the MS version. I am rea ding hat some of these holes are drilled low on the hinge to mount it and the ex tra trength is needed in the material to prevent the hinge from bending over. My technical advisor also suggested the stronger hinge. He also suggested I put everal smaller sections in as Tony Bingelis suggests, but I am not going to do hat for several reasons. A couple are that some (Jack Phillips, Mike Cuy) and umerous others are running one continuous piece which is easier to align an d ives you the gapless hinge you need on the ailerons. My technical advisor felt everal smaller hinges would give some redundancy if one section should fail and hat is the way many certified aircraft ailerons are hinged. Just my thoughts. -------- ohn Francis ead this topic online here: http://forums.matronics.com/viewtopic.php?p=375387#375387 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 12, 2012
Jeff, Keep in mind that I am not a Model-A expert by any means but I have some thoughts that may help. Its funny that you say it looks like most have drilled a hole at the top of the intake manifold for a primer because I can only think of one that does (need to pay better attention I guess seems theres at least three from reading this thread). Most installations Im aware of do not have a primer. Are you having difficulty starting your engine? One Model-A engine I propped on a Pietenpol had an open intake you could choke by placing your hand over it. Most Pietenpols have the enrichener safety wired with the butterfly open but on mine I have it spring loaded open and place a small piece of tubing on the shaft to close the butterfly and choke it while I turn 4 blades. I then remove the tube (placing it on the throttle linkage just to store it) and turn the prop through 4 to 6 blades to pull the rich mixture into the cylinders. After that, make it hot and give it a throw. For reference, I have an early (1927) engine with babbit bearings, 6.5:1 aluminum head, Vertex magneto and a washing machine water pump. Disclaimer: My engine has less than 10 hours on it and has not flown yet. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375427#375427 ________________________________________________________________________________
Date: Jun 12, 2012
Mine starts ok if I do just what you describe.... choke, turn a couple of blades then ignition on... and it goes.... the problem is the gas coming out the bottom of the carb when i choke it... i was thinking a primer line above the carb with a very small hole so it mists into the intake would make it start easier without the leak or the choke... i'm all about keeping it simple... maybe i'll take it out and run it some more and see how it goes.. I can always add a primer after its covered if needed. thanks jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375446#375446 ________________________________________________________________________________
Subject: Re: t-nuts vs anchor nuts
Date: Jun 12, 2012
Got mine from Tower Hobbies... 10-32 type. Mine are also not flight tested either (full scale), but I've flown many high performance R/C aircraft and they have never given me trouble backing our or loosening when properly installed. Based upon the rib spacing, I would guess that mine are 7-8" apart too. -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375453#375453 ________________________________________________________________________________
Subject: Re: turnbuckle size
Date: Jun 12, 2012
Finally an answer to all your turnbuckle questions. Curt Merdan Flower Mound, TX Please Print and Archive!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375456#375456 Attachments: http://forums.matronics.com//files/turnbuckles_627.png ________________________________________________________________________________
Date: Jun 12, 2012
Jeff, I too was worried when I first saw fuel leaking from the carb, but I found this is normal and in the case of starting the engine desirable after reading about how to hand-crank the Model-A automobile. Read steps 5 through 7 at http://www.abarnyard.com/workshop/handcrank.htm With the ignition OFF, hold the choke out (fully closed). This will require either a helper, a pull cord from the lever on the carburetor to the front of the vehicle, or one of those modern undersized and sticky choke rod grommets. (This is where I use a piece of hose) Carefully position the crank in place engaging the ratchet with the crank left of center in the lower of the two possible positions. Grasp the crank as shown in the photo above, paying close attention to the thumb position below the handle. Pull the crank to the top briskly but carefully. Repeat with a second pull. At this point there should be gas running slightly from the carburetor to the floor. Release the choke and turn ON the ignition. This is basically what Im doing with the Piet. Like you, I felt the idea of spilling gas doesnt fit well in todays way of looking at things, but its a small amount, and if care is taken it shouldn't present a problem. (IMHO) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375460#375460 ________________________________________________________________________________
Date: Jun 12, 2012
thanks.... i drive a 30 AA truck all the time... and it almost won't start without choking it.. I'll give it i whirl so to speak.. i'm using a modern zenith and it doesn't just have a hole like the a and b carbs. it has a 3/8 inch boss in the bottom with a kind of a mesh in it.. it leaks out there... i considered adding a hose so it would run to the ground and not on the cowl.. maybe i can find the right amount of spins with the choke on to only get a drop or two.. thanks gentlemen jeff in lou ky Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375473#375473 ________________________________________________________________________________
Date: Jun 12, 2012
Subject: =?utf-8?q?Progress_tonight_Just_2_more_stringers?
Subject: Elevator control trim
Date: Jun 13, 2012
Since I can't sleep tonight thinking about my build, I want to ask a question regarding trim on the elevator controls. I have seen Mike Cuy's treatment on the elevator trim, and have planned to imitate it (best form of flattery Mike!). I thought I'd ask if there were other forms of trim being used by you pieters, and if there are pics anywhere. I am at the point of building my seat and pilot's 'perch' so I want to plan out the trim arrangement. I am going to buy the rest of the Bingalis books soon, so if there is a good reference on this in one of them, point me in the right direction coach! Thanks! Mark ________________________________________________________________________________
Date: Jun 13, 2012
Mark, This is what I did. Cockpit end http://www.cpc-world.com/new_card_images/images/IMG_0710_JPG.jpg Bell crank end http://www.cpc-world.com/images/IMG_1102_JPG.jpg Hope that helps. Peter Wonthaggi Australia http://www.cpc-world.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Wednesday, 13 June 2012 6:45 PM Subject: Pietenpol-List: Elevator control trim --> Since I can't sleep tonight thinking about my build, I want to ask a question regarding trim on the elevator controls. I have seen Mike Cuy's treatment on the elevator trim, and have planned to imitate it (best form of flattery Mike!). I thought I'd ask if there were other forms of trim being used by you pieters, and if there are pics anywhere. I am at the point of building my seat and pilot's 'perch' so I want to plan out the trim arrangement. I am going to buy the rest of the Bingalis books soon, so if there is a good reference on this in one of them, point me in the right direction coach! Thanks! Mark ________________________________________________________________________________
Subject: Re: Elevator control trim
Date: Jun 13, 2012
Mark My Piet originally had a push/pull cable operating a trim tab on the elevator. The problem was constantly having to adjust the trim in flight due to drift in the cable. The solution was to bust off the plastic knob and add threads to attach a turnbuckle which works absolutely flawless and allows for very small adjustments which comes in handy if you have a header fuel tank. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375504#375504 Attachments: http://forums.matronics.com//files/dsc00556_154.jpg http://forums.matronics.com//files/dsc00216_208.jpg ________________________________________________________________________________
Subject: BPA sculpture
Date: Jun 13, 2012
Hopefully the link posted allowed people to see the sculptures I'm donating. I think you can also see them on my website under limited editions. www.douwestudios.com <http://www.douwestudios.com/> They are for sale privately, and I'll still make a BPA donation from those sales if anyone is interested, but can't make Brodhead. I kind of did them for fun and have only displayed them once, so only one has sold of each. I'll have to go back and find the pricing, but anyone interested can contact me offline. Douwe Progress report. Got Marci to help last night and got all the stitching done on the tail surfaces. Taping for the next few days, then start on the fuse! Called my hangar owner and told him to make plans to move his big ugly Waco over and make room for a real airplane!! ________________________________________________________________________________
Date: Jun 13, 2012
Here's (attached picture) about the neatest solution for an easily adjustable and stable trim tab adjustment on a Piet....it's just an RV window crank....cool idea. Jim in Pryor...counting the days..... ________________________________________________________________________________
Subject: weight and CG
Date: Jun 13, 2012
Hey guys.. I weighed the piet today... all together but with fabric only on the control surfaces.. I'm wishing it was lighter but i'm at 649 lb's .. empty with oil and water.. cg is 10.65 with me in the back and no fuel cg is at 19.92 with fuel it moves forward less than a half inch. I'm thinking with the rest of the fabric and paint i'm looking at an another 35-40 lbs.. based on the polyfober manual number of 43 lbs to cover a cub. i'm thinking most of that fabric and paint are behind the CG so its gonna move back a bit more.. a bit of wing moving may be in order jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375588#375588 ________________________________________________________________________________
Subject: Re: reminder
Date: Jun 13, 2012
V2hldyEgVGhhbmtzLCBSeWFuISBJIG1hZGUgc2V2ZXJhbCBwb3N0cyB0aGlzIHdlZWssIGZyb20g bXkgY29ycCBCbGFja0JlcnJ5LCBjb21wbGV0ZSB3aXRoIGxlZ2FsIG11bWJvLWp1bWJvLCBhbmQg d2FzIGFmcmFpZCBJIG1pZ2h0IGhhdmUgYmVlbiBhbiBvZmZlbmRpbmcgcGFydHkuDQoNCkdhcnkg ZnJvbSBDb29sDQpEbyBub3QgYXJjaGl2ZQ0KU2VudCBvbiB0aGUgU3ByaW50riBOb3cgTmV0d29y ayBmcm9tIG15IEJsYWNrQmVycnmuDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9t OiBSeWFuIE0gPGFpcmNhbXBlcmFjZUB5YWhvby5jb20+DQpTZW5kZXI6IG93bmVyLXBpZXRlbnBv bC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tDQpEYXRlOiBXZWQsIDEzIEp1biAyMDEyIDE2OjI1 OjE3IA0KVG86IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb208cGlldGVucG9sLWxpc3RAbWF0 cm9uaWNzLmNvbT4NClJlcGx5LVRvOiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tU3ViamVj dDogUmU6IFBpZXRlbnBvbC1MaXN0OiBSZTogcmVtaW5kZXINCg0KQ2FuIHNvbWUgb25lIHBsZWFz ZSB0ZWxsIG1lIHdoYXQgdGhpcyAiZG8gbm90IGFyY2hpdmUiIHRoaW5nIGlzIGFsbCBhYm91dD8g SSd2ZSBzcGVudCB0aGUgcmVxdWlyZWQgaG91ciBzZWFyY2hpbmcgdGhlIGFyY2hpdmVzIGJlZm9y ZSBhc2tpbmcgdGhpcyBxdWVzdGlvbiBhbmQgY2FtZSB1cCBhYnNvbHV0ZWx5IG5vdGhpbmchIDsp CgoKUnlhbiBNCgpEbyBub3QgYXJjaGl2ZQoKX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X18KIEZyb206IERPIE5PVCBBUkNISVZFIDxicGhpbGxpcEBzaGVudGVsLm5ldD4KVG86IHBpZXRl bnBvbC1saXN0QG1hdHJvbmljcy5jb20gClNlbnQ6IFdlZG5lc2RheSwgSnVuZSAxMywgMjAxMiA0 OjQyIFBNClN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBSZTogcmVtaW5kZXIKIAotLT4gUGlldGVu cG9sLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJETyBOT1QgQVJDSElWRSIgPGJwaGlsbGlwQHNo ZW50ZWwubmV0PgoKRGVhciBTaXI6Ck15IHVzZXIgbmFtZSBhbmQgc2lnbmF0dXJlIGhhdmUgYmVl biBhZGp1c3RlZCBpbiBhY2NvcmRhbmNlIHdpdGggeW91ciB3aXNoZXMuoCBJIGhvcGUgdG8gbmV2 ZXIgYmUgZ3VpbHR5IG9mIHBvbGx1dGluZyB0aGUgZGF0YWJhc2Ugd2l0aCB3b3J0aGxlc3MgZHJp dmVsIGFnYWluLgoKSHVtYmx5IFlvdXJzLAoKRE8gTk9UIEFSQ0hJVkUKCi0tLS0tLS0tCkJyZXR0 IFBoaWxsaXBzClBMRUFTRSBETyBOT1QgQVJDSElWRSEKCgoKClJlYWQgdGhpcyB0b3BpYyBvbmxp bmUgaGVyZToKCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9Mzc1 NTg2IzM3NTU4NgoKPT09PT09PT09PT09PT09PT09PT09PT09Cj09PT09PT09PT09PT09PT09PT09 PT09DQo ________________________________________________________________________________
Subject: NX53WE has 2 hours
Date: Jun 13, 2012
Our instructor flew again wednesday eve for over an hour and all went good. Low speed pass at 30 mph - high speed at 103 mph and stalls at 27. It weighs in at 805 empty with an 0-200 and a 72-44 wood prop. He made several landings and said he likes wheel landings with a little power. What a thrill to see it fly. Bob ________________________________________________________________________________
Subject: Re: Progress =?ISO-8859-1?Q?tonight=85?= Ju st 2 more
stringers
Date: Jun 13, 2012
Thanks Guys! Believe it or not, the hardest part isn't the building, it is the compilation of the steel parts needed to order from ACS! I have spent the last few hours looking at all I need to order to build the fuse control stuff. Part of the fun! Vic, I will call you tonight as I see you called when I was away. Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375623#375623 ________________________________________________________________________________
Date: Jun 13, 2012
Subject: AN Bolt deciphering - Resource
The hardest part of this build (OK, for me perhaps who is so ADD that I am still trying to remember where my meds are located...) is the stinkin' hardware. I have compiled a list of metal, and am now "bolting"... I am assuming that most of the bolts I get could have a hole in the shaft to use if necessary. Is there any potential down side to this idea of ordering all the bolts with holes in the threaded end. I can bet there would be a problem if I needed the hole and didn't have it... Thoughts? Here's a link to what I thought was a helpful chart. I hope it might help others with my same affliction (Harumph!) http://www.gen-aircraft-hardware.com/images/pdf/an3_thru_an20.pdf Mark ________________________________________________________________________________
Date: Jun 13, 2012
Subject: Re: AN Bolt deciphering - Resource
Sorry guys... Just found the bolt selector tool on ACS. Geez... that helps a lot. On Wed, Jun 13, 2012 at 10:46 PM, Mark Roberts wrote: > The hardest part of this build (OK, for me perhaps who is so ADD that I am > still trying to remember where my meds are located...) is the stinkin' > hardware. I have compiled a list of metal, and am now "bolting"... > > I am assuming that most of the bolts I get could have a hole in the shaft > to use if necessary. Is there any potential down side to this idea of > ordering all the bolts with holes in the threaded end. I can bet there > would be a problem if I needed the hole and didn't have it... > > Thoughts? > > Here's a link to what I thought was a helpful chart. I hope it might help > others with my same affliction (Harumph!) > > http://www.gen-aircraft-hardware.com/images/pdf/an3_thru_an20.pdf > > Mark > > * > > * > > ________________________________________________________________________________
Date: Jun 14, 2012
You need a lot of bolts, and the ones with the holes are more expensive, so I only used the drilled bolts where I needed them. I started out just ordering the bolts I thought I needed, but eventually ended up buying 10 of a variety of lengths of AN-3 and AN-4bolts, because when you go to doing assembly you sometimes need to move up or down a size to get the proper number of threads. I just bought 100 of the self-locking nuts in AN-3, and the same for both sizes of washers. Costs very little in the whole scheme of things, and you avoid getting stumped because you are 1 bolt short (or long:-) ). I don't remember the part number of the pulleys, but there is a pulley in the ACS catalog with a ball-bearing hub that takes a 1/4 inch bolt and takes 1/8 inch cable. They cost around $10 each, and you need a bunch of them. Someone will chime in with the part number I'm sure Ben Charvet NX866BC 130 hrs so far OK to archive? Ben On 6/14/2012 1:46 AM, Mark Roberts wrote: > The hardest part of this build (OK, for me perhaps who is so ADD that > I am still trying to remember where my meds are located...) is the > stinkin' hardware. I have compiled a list of metal, and am now > "bolting"... > > I am assuming that most of the bolts I get could have a hole in the > shaft to use if necessary. Is there any potential down side to this > idea of ordering all the bolts with holes in the threaded end. I can > bet there would be a problem if I needed the hole and didn't have it... > > Thoughts? > > Here's a link to what I thought was a helpful chart. I hope it might > help others with my same affliction (Harumph!) > > http://www.gen-aircraft-hardware.com/images/pdf/an3_thru_an20.pdf > > Mark > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Jun 14, 2012
Subject: Engine Mount Complete-Work Continues
Crew, I finished my A-65 mount Tuesday. I believe I am finished with all the required welding on the plane now. Building the jig and fabricating the mount was reminiscent of building the straight axle landing gear. Engine work will now continue. I have a Fresno Airparts order on it's way and I hope to start engine assembly as soon as the parts arrive. I also have my fire wall finished as of last night. It is 1/8" plywood, 1/16" Fiberfrax and .030" aluminum. I need to figure out if/how I can store my wings at home once they are covered. Once I do that, I may buy more fabric and start on them prior to winter. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: elevator (flipper) trim
Date: Jun 14, 2012
I lifted this idea from Rick Holland, and have mentioned it before, but since you ask. If you have a battery, or even if you don't, you can use a small rechargeable. I purchased a Ray Allen trim servo which weighs a few ounces and mounts in the elevator to actuate a tab. Two tiny wires run up to a rocker switch and "Bob's your Uncle!!" you're done!! Light, nothing seen cluttering the cockpit and. Easey Peasey, Lemon Squeezey. Very un-original, BUT so is anything else, but it's much easier to hide than any other system other than a ground adjustable (bend) tab. Available through ACS and many others. Douwe ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Date: Jun 14, 2012
Mark, the main difference is price. In the ACS listing an AN3-7A (undrilled) is $0.12 -- an AN3-7 (drilled) is $0.52. That 40-cent difference would build up when you start ordering your hardware. Chuck ----- Original Message ----- From: Mark Roberts To: pietenpol-list Sent: Thursday, June 14, 2012 1:46 AM Subject: Pietenpol-List: AN Bolt deciphering - Resource The hardest part of this build (OK, for me perhaps who is so ADD that I am still trying to remember where my meds are located...) is the stinkin' hardware. I have compiled a list of metal, and am now "bolting"... I am assuming that most of the bolts I get could have a hole in the shaft to use if necessary. Is there any potential down side to this idea of ordering all the bolts with holes in the threaded end. I can bet there would be a problem if I needed the hole and didn't have it... Thoughts? Here's a link to what I thought was a helpful chart. I hope it might help others with my same affliction (Harumph!) http://www.gen-aircraft-hardware.com/images/pdf/an3_thru_an20.pdf Mark ________________________________________________________________________________
Date: Jun 14, 2012
Mark, Aside from the cost difference, my earlier version of AC43.13 states, ".Bolts 5/16" diameter and over with cotter pinholes may be used with self-locking nuts." Inference from that, along with my recollection from A&P school, is that smaller bolts with cotter pinholes would not be used with fiber locknuts. Gary from Cool _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of C N Campbell Sent: Thursday, June 14, 2012 9:42 AM Subject: Re: Pietenpol-List: AN Bolt deciphering - Resource Mark, the main difference is price. In the ACS listing an AN3-7A (undrilled) is $0.12 -- an AN3-7 (drilled) is $0.52. That 40-cent difference would build up when you start ordering your hardware. Chuck ----- Original Message ----- From: Mark Roberts <mailto:mark.rbrts1(at)gmail.com> Sent: Thursday, June 14, 2012 1:46 AM Subject: Pietenpol-List: AN Bolt deciphering - Resource The hardest part of this build (OK, for me perhaps who is so ADD that I am still trying to remember where my meds are located...) is the stinkin' hardware. I have compiled a list of metal, and am now "bolting"... I am assuming that most of the bolts I get could have a hole in the shaft to use if necessary. Is there any potential down side to this idea of ordering all the bolts with holes in the threaded end. I can bet there would be a problem if I needed the hole and didn't have it... Thoughts? Here's a link to what I thought was a helpful chart. I hope it might help others with my same affliction (Harumph!) http://www.gen-aircraft-hardware.com/images/pdf/an3_thru_an20.pdf Mark href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronic s.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: NX53WE specs
Date: Jun 14, 2012
We built the long fuselage and made it 2 inches wider and the pilot cockpit 2 inches longer. For the wheels we used 21 inch rims and made 6 inch hubs. My son did all the metal work. It has disc brakes with gocart cylinders. Tha wings are Riblett 612 airfoil and the cabanes are the same length.The stall is at 27 and is not a sharp break but a kind of a mush. It slow flies at 30 and he had it up to 103. It weighed in at 805 empty and is very stable. We are pleased with this airfoil and the overall preformance.23 hours yet to go. Bob ________________________________________________________________________________
Date: Jun 14, 2012
Michael, I'm a little surprised at your choice for the firewall metal. I've never known of an airplane with an aluminum firewall. All I've ever seen were steel. Aluminum melts at about 1100 degrees F, and a gasoline fed fire will easily melt it. I don't think it would offer much protection, even with a fiberfrax backing. I though you loved stainless steel? Anyway, you might want to rethink aluminum for a firewall. I assume you've been reading your Bingelis books, but if not, here is what Mike Cuy's Uncle Tony has to say about firewall materials: Acceptable Firewall Materials The following materials may be used in firewalls WITHOUT BEING TESTED; . Stainless steel sheet - .015 inch thick (.284 lb./cu. in.) . Mild steel sheet (coated with aluminum or otherwise corrosion protected) - .018 inch thick . Terne plate - .018 inch thick . Steel or copper base alloy fittings . Other materials may be used if they can pass the fireproof test. The Fireproof Test If you want to use some other material for your firewall, you may have to prove its ability to meet certain criteria for compliance as a fireproof material. Simply stated, the material must be given a flame test, in which a piece of it, approximately 10 inches in diameter, is subjected to a five-inch diameter flame. Firewall materials and fittings must resist flame penetration for at least 15 minutes. That's all there is to that. Compliance is relatively easy and no homebuilder wanting to try a new firewall treatment should slight the requirement. Choosing Your Firewall Material Galvanized sheet is the most common, most economical of the acceptable materials used in small general aviation aircraft. It gets its corrosion resistance from a zinc or hot-dip galvanizing coating obtained by immersing the sheet steel in a mixture of molten zinc at a temperature of approximately 865 degrees F. until the base metal temperature of the immersed steel sheet reaches that of the hot-dip bath. Local sources for galvanized sheet include metal shops and air conditioning duct fabricators. Don't be surprised if the folks operating these metal shops refer to the thickness of their galvanized sheets in term of gauges rather than inch sizes such as .018 inch or .015 inch. If that be the case, 26 gauge is pretty close to what you want (about .018 inch thick). You could assure yourself that you are obtaining the correct thickness if you bring your own micrometer to check the various sheets. There are a number of so-called "standard gauges" and some variations in the actual thickness for the same gauge number may crop up. No useful purpose would be served by using a heavier firewall sheet than that required to meet acceptable minimums. Never lose sight of the fact that the addition of unnecessary weight, no matter how slight, degrades the aircraft's performance. The firewall metal for a two-seat aircraft will probably weigh as much as 4-1/2 pounds anyway, so why make it seven? In order of preference for firewall material, stainless steel gets top billing in both quality and appearance. It also costs two to four times more than galvanized sheet. However, as the "cadillac" of firewall materials, it is the first choice among builders who want a "show airplane." Builders with economy in mind will ordinarily use galvanized sheet for their firewall and may console themselves by claiming that galvanized sheet is lighter than stainless. I doubt that the weight difference could be measured on the crude scales most of us have around our shops, but there is that difference. Another fireproof material, often used in the past and sometimes still found on older aircraft, is terne plate. It is not used much today because it isn't as commonly available as galvanized. Monel and Inconel, although acceptable as firewall materials, are difficult to obtain. As far as homebuilders are concerned, these may be regarded as rare materials. Concern over weight leads some builders to consider the use of aluminum. However, using aluminum sheet by itself for firewall material is not acceptable to most FAA inspectors. The official reason is, aluminum will not pass the flame test because its melting point is just slightly above 1,200 degrees F. In some applications . . . for very slow, light aircraft (ultralights) with small engines, it might be considered sufficient. However, before you decide to use it in your own aircraft, check it out with your local FAA inspector. Although the standards established by regulation for production-line aircraft do not necessarily apply to experimental aircraft, deviation from accepted practices may result in your having to get into a proof testing demonstration. Is it worth the trouble? So, before going much further, I would strongly urge you to consider glavanized iron or stainless steel. Best of luck, Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Thursday, June 14, 2012 10:01 AM Subject: Pietenpol-List: Engine Mount Complete-Work Continues Crew, I finished my A-65 mount Tuesday. I believe I am finished with all the required welding on the plane now. Building the jig and fabricating the mount was reminiscent of building the straight axle landing gear. Engine work will now continue. I have a Fresno Airparts order on it's way and I hope to start engine assembly as soon as the parts arrive. I also have my fire wall finished as of last night. It is 1/8" plywood, 1/16" Fiberfrax and .030" aluminum. I need to figure out if/how I can store my wings at home once they are covered. Once I do that, I may buy more fabric and start on them prior to winter. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Corvair Motor Mount Jig
Date: Jun 15, 2012
A couple of us Ohioans are about to build our corvair engine mounts. Are there any jigs out there that someone would be willing to lend us? Could pick up in Brodhead if that works. Thanks -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375720#375720 ________________________________________________________________________________
Subject: Re: Brodhead
Date: Jun 15, 2012
Gary, I'm leaving the Brodhead area early Sunday morning for home and can give you a lift then. Will that work? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375722#375722 ________________________________________________________________________________
Date: Jun 15, 2012
Subject: Re: NX53WE specs
That is good intell, Bob. Very pleased to hear about the Riblett 612...that is the airfoil NX992WD has. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 15, 2012
Great information, im running the Riblett 612 also and am wondering if you put in and dihedral? My weight will be real close to yours as well. Thanks in advance! -------- NX321LR Fully Assembled less covering Mistubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375732#375732 ________________________________________________________________________________
Date: Jun 15, 2012
Hello Jack.=C2- Here is the intell. I got from T.B's Firewall Forward, in so many words: =C2- Fiberfrax withstands temps. of about 2,300 deg. F.=C2- and may be conside red as effective a fire barrier as stainless.=C2-=C2- ...it saves 2-3 p ounds over SS or galvanized sheet normally installed. (page 60) =C2- The technique for using it: Attach Fiberfrax to wood or composite firewall, overlay with .016" 2024 T3 to protect it. Although aluminum is deficient when used alone, with Fiberfr ax it is acceptable. (page 60) I used .030"=C2-because I had it on hand. =C2- Before firewall is attached on a wood or composite aircraft I recommend the firewall be protected with asbestos, Zetex or Fiberfrax paper. (page 63) =C2- Page=C2-58 figure1 and page 78=C2-Figure 2 shows Fiberfrax used on wood firewalls. =C2- ACS catalog, page 114: ...Fiberfrax withstands temps. up to 2,300 deg. F. excellent for aircraft f irewalls. =C2- The intell. you provided is sound and from the same book. (Pages 56 and 57) However, if you read further it gets into wood and composite aircraft and the above statements. =C2- I do like the quote below from your reply: =C2- "No useful purpose would be served by using a heavier firewall sheet than t hat required to meet acceptable minimums. Never lose sight of the fact that the addition of unnecessary weight, no matter how slight, degrades the air craft=99s performance. The firewall metal for a two-seat aircraft wil l probably weigh as much as 4-1/2 pounds anyway, so why make it seven?" =C2- I=C2-like SS, but a sheet of it as a firewall seems a bit heavy, expensiv e=C2-and unnecessary. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 15, 2012
Date: Jun 15, 2012
Subject: Re: Engine Mount Complete-Work Continues
As I understand the firewall is the Fiberfax not the metal thing I put in front of it to hold it in place?... If this is the case, we can use just a simple woven wire in front of the Fiberfax... can't we? Mario Giacummo ... .. .-.. .- .- ...- . -. - ..- .-. .- . ... .--. . .-.. .. --. .-. --- ... .- --..-- .--. .-. --- -... .- .-.. .- .-. ..- - .. -. .- --..-- . ... -- --- .-. - .- .-.. !!!!! 2012/6/15 Michael Perez > Hello Jack. Here is the intell. I got from T.B's Firewall Forward, in so > many words: > > Fiberfrax withstands temps. of about 2,300 deg. F. and may be considered > as effective a fire barrier as stainless. ...it saves 2-3 pounds over S S > or galvanized sheet normally installed. (page 60) > > The technique for using it: > Attach Fiberfrax to wood or composite firewall, overlay with .016" 2024 T 3 > to protect it. Although aluminum is deficient when used alone, with > Fiberfrax it is acceptable. (page 60) > I used .030" because I had it on hand. > > Before firewall is attached on a wood or composite aircraft I recommend > the firewall be protected with asbestos, Zetex or Fiberfrax paper. (page > 63) > > Page 58 figure1 and page 78 Figure 2 shows Fiberfrax used on wood > firewalls. > > ACS catalog, page 114: > ...Fiberfrax withstands temps. up to 2,300 deg. F. excellent for aircraft > firewalls. > > > The intell. you provided is sound and from the same book. (Pages 56 and > 57) However, if you read further it gets into wood and composite aircraft > and the above statements. > > I do like the quote below from your reply: > > "No useful purpose would be served by using a heavier firewall sheet than > that required to meet acceptable minimums. Never lose sight of the fact > that the addition of unnecessary weight, no matter how slight, degrades t he > aircraft=92s performance. The firewall metal for a two-seat aircraft will > probably weigh as much as 4-1/2 pounds anyway, so why make it seven?" > > I like SS, but a sheet of it as a firewall seems a bit heavy, > expensive and unnecessary. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: My Babe Magnet
Date: Jun 15, 2012
Hello Chaps, Just a quick piccie of what to expect when you get to the end of your proje ct! In reality, some arty girlies from a local college had seen me wobbling aro und and wanted to borrow my "Lovely Little Aeroplane" for a photo shoot. My calculations show that if I had started building at the age of ten I wou ld have been in with more of a chance! Regards, Mike Mike Hayes Applications Specialist GEA Heat Exchangers Ltd GEA Heat Exchangers Phone. +44 1432 277277, Fax. +44 1432 355988 Mob. +44 7831 409622 mike.hayes(at)gea.com www.gea.com<http://www.gea.com/> We live our values. Excellence * Passion * Integrity * Responsibility * GEA-versity Regional Address Registered Office: Dolphin House, Moreton Business Park, Moreton-on-Lugg, H ereford. HR4 8DS. UK VAT ID No. GB 931 1150 71 Registered in England No. 4057753 Confidentiality note This e-mail, including any attachment, may contain confidential and privile ged information. If you have received it by mistake, please notify us by re ply e-mail and then delete this e-mail and any attachment from your system. Thank you! ________________________________________________________________________________
Date: Jun 15, 2012
Mario, the Fiberfrax is the fire resistive material and it is fragile. You need a structure to attach it too, (plywood) and some type of protecting ba rrier to keep it from abrasion. (Aluminum) I would only be guessing what ot her material could be used as a "cover" for the Fiberfrax. - Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 15, 2012
Subject: Rod Cap Hole Orientation
I neglected to note in which direction the holes on the connecting rod caps should face while installed on the crank during disassembly. The manual st ates to have all conn. rod numbers facing up, but depending on which way th e crank is laying, that would have the oil holes squirting either forward o r aft.- Should the holes face forward, aft, or does it matter? Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 15, 2012
Subject: Re: Rod Cap Hole Orientation
Numbers up is in regard to the crank being vertical on a stand.....flange down, rear up.....so orient the rods with that in mind..... On Fri, Jun 15, 2012 at 11:45 AM, Michael Perez wrote: > I neglected to note in which direction the holes on the connecting rod > caps should face while installed on the crank during disassembly. The > manual states to have all conn. rod numbers facing up, but depending on > which way the crank is laying, that would have the oil holes squirting > either forward or aft. Should the holes face forward, aft, or does it > matter? > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > * > > * > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Jun 15, 2012
Subject: Mike Hayes Pietenpol attraction
Very good Mike! These things happen around Pietenpols. I mostly get th e 80 and older women checking out my Pietenpol but occasionally an accidentally younger one will stop by to look at it. Mike C. ________________________________________________________________________________
Subject: W&B
Date: Jun 15, 2012
Conducted W&B today.aft CG came in at 19"!! Empty weight is 718 lbs..I'm happy. Note the Jack Phillips style wing jacks.that made it sooo easy! Gary Boothe NX308MB ________________________________________________________________________________
Date: Jun 16, 2012
Subject: Re: W&B
Gary, Congratulations! That is a beautiful airplane. How soon will you be making your tour of Northern California so we can get to see it in action? Darrel ________________________________________________________________________________
Date: Jun 16, 2012
Subject: Conn. Rod Oil Hole Orientation
Crew, I believe I have found the answer to my original question. Thanks for the help. - Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Bungee Installation
Date: Jun 16, 2012
Took about 1 hour for the first bungee, with the help of my son. Tie-offs were done with safety wire, a la Jack Phillips and the archives! Bungee wrapping was easy, but the wire ties take some time. Gary Boothe NX308MB ________________________________________________________________________________
Subject: Bungees
Date: Jun 16, 2012
After removing the wings from yesterday's W&B, my son is going to help with the ever-loving bungees. Advice is encouraged. Gary Boothe NX308MB ________________________________________________________________________________
Subject: W&B
Date: Jun 16, 2012
Looking good, Gary! Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Saturday, June 16, 2012 12:50 AM Subject: Pietenpol-List: W&B Conducted W&B today.aft CG came in at 19"!! Empty weight is 718 lbs..I'm happy. Note the Jack Phillips style wing jacks.that made it sooo easy! Gary Boothe NX308MB ________________________________________________________________________________
Date: Jun 16, 2012
Subject: Re: My Babe Magnet
Mike, nice picture!=C2-=C2- To me, your plane looks like it sits low an d "flat". Any idea what your deck angle, (angle between level ground and to p longeron) might be?=C2-=C2- Quite a few Pietenpols I have seen seem t o sit high on the landing gear...plenty of ground clearance and deck angle. Perhaps it is just the camera angle. =C2- I like that look a lot and built mine to be the same. If it would not be to o much trouble, could you provide me with your deck angle, distance from gr ound to crank/prop. center and distance from ground to bottom of tail post? =C2- How long is that propeller? I am just curious to see how your number s compare to mine. =C2- Thanks . =C2- Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com --- On Fri, 6/15/12, Hayes, Mike wrote: From: Hayes, Mike <Mike.Hayes(at)gea.com> Subject: Pietenpol-List: My Babe Magnet Date: Friday, June 15, 2012, 11:46 AM Hello Chaps, =C2- Just a quick piccie of what to expect when you get to the end of your proje ct! In reality, some arty girlies from a local college had seen me wobbling aro und and wanted to borrow my =9CLovely Little Aeroplane=9D for a photo shoot. My calculations show that if I had started building at the age of ten I wou ld have been in with more of a chance! =C2- Regards, =C2- Mike =C2- Mike Hayes Applications Specialist GEA Heat Exchangers Ltd GEA Heat Exchangers Phone. +44 1432 277277, Fax. +44 1432 355988 Mob. +44 7831 409622 mike.hayes(at)gea.com www.gea.com We live our values. Excellence =A2 Passion =A2 Integrity =A2 Responsibility =A2 GEA-versity Regional Address Registered Office: Dolphin House, Moreton Business Park, Moreton-on-Lugg, H ereford. HR4 8DS. UK =C2- VAT ID No. GB 931 1150 71 Registered in England No. 4057753 Confidentiality note This e-mail, including any attachment, may contain confidential and privile ged information. If you have received it by mistake, please notify us by re ply e-mail and then delete this e-mail and any attachment from your system. Thank you! =C2- ________________________________________________________________________________
Date: Jun 16, 2012
Ryan, the numbers on my connecting rods are stamped on the sides of the cap s, where the bolts go through. With the crank vertical, all rod numbers wou ld be sideways in relation to the crank...no "up" or "down" orientation.- I wonder if the manual is referring to "point up" as being towards the top of the engine case, opposite of the carburetor? Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: Bungee Installation
Date: Jun 16, 2012
Gary, Did you wrap the underside of the ash piece with leather? If so, how did yo u secure it from movement? Quite simple and ingenious (not like me, over-th ink everything). Wish I had thought of it! Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sat, Jun 16, 2012 2:08 pm Subject: Pietenpol-List: Bungee Installation Took about 1 hour for the first bungee, with the help of my son. Tie-offs w ere done with safety wire, a la Jack Phillips and the archives! Bungee wrap ping was easy, but the wire ties take some time. Gary Boothe NX308MB ________________________________________________________________________________
Subject: Re: W&B
Date: Jun 16, 2012
Very cool Gary. Your airplane has it's own unique look, kind of sleek and s wept. Must be fast! Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Fri, Jun 15, 2012 11:53 pm Subject: Pietenpol-List: W&B Conducted W&B todayaft CG came in at 19=9D!! Empty weight is 718 lbs.I=99m happy. Note the Jack Phillips style wing jack sthat made it sooo easy! Gary Boothe NX308MB ________________________________________________________________________________
Date: Jun 16, 2012
Just got a hole thru it for the anti-rotation rod. Easy to put a few screws thru it if it looks like it's going to move. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Saturday, June 16, 2012 2:21 PM Subject: Re: Pietenpol-List: Bungee Installation Gary, Did you wrap the underside of the ash piece with leather? If so, how did you secure it from movement? Quite simple and ingenious (not like me, over-think everything). Wish I had thought of it! Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe < <mailto:gboothe5(at)comcast.net> gboothe5(at)comcast.net> pietenpol-list(at)matronics.com> Sent: Sat, Jun 16, 2012 2:08 pm Subject: Pietenpol-List: Bungee Installation Took about 1 hour for the first bungee, with the help of my son. Tie-offs were done with safety wire, a la Jack Phillips and the archives! Bungee wrapping was easy, but the wire ties take some time. Gary Boothe NX308MB http://www.matronics.com/Navigator?Pietenpol-List http://www.matronics.com/contribution ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Jerry's first flight
Date: Jun 17, 2012
CONGRATULATIONS JERRY! I concur with others that each "first flight" announcement spurs me on towards the finish line!! All covered up!!! Am taping now. I'm hoping to be spraying next week. Douwe ________________________________________________________________________________
Date: Jun 17, 2012
Subject: Re: First flight
Nice job for sure!- I concur...you first time fliers keep me motivated to get there myself and join the ranks of builder/flier Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 17, 2012
Checked out the videos on Facebook! You have built a fine looking airplane. Your aviator skills appear to match your craftsmanship. Just got in from gluing up a few parts. Figure I will be where you are in 5 years or so, thanks for helping us aspiring Piet pilots keep our eye on the prize! Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375927#375927 ________________________________________________________________________________
Subject: How it's made: Airplanes
Date: Jun 17, 2012
Funny... I didn't see ONE piece of spruce in the whole thing... NOT ONE! And they call it an airplane??! http://www.youtube.com/watch?v=4LhN_T5tGK8&feature=youtube_gdata_player ________________________________________________________________________________
Date: Jun 18, 2012
Congratulations on a successful first flight Don L ________________________________________________________________________________
Date: Jun 18, 2012
Subject: Re: How it's made: Airplanes
Looks like the same process as a canoe !! - http://www.youtube.com/watch?v=rGespWiyB3E --- On Sun, 6/17/12, Mark Roberts wrote: From: Mark Roberts <mark.rbrts1(at)gmail.com> Subject: Pietenpol-List: How it's made: Airplanes Date: Sunday, June 17, 2012, 10:18 PM Funny... I didn't see ONE piece of spruce in the whole thing... NOT ONE! And they call it an airplane??! http://www.youtube.com/watch?v=4LhN_T5tGK8&feature=youtube_gdata_player le, List Admin. ________________________________________________________________________________
Date: Jun 18, 2012
Congrats and also a nice looking airplane! Many happy returns. Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376002#376002 ________________________________________________________________________________
Date: Jun 18, 2012
Subject: What welding rod did you use for 4130?
I see some $65 per pound welding rod on ACS... surely there is something cheaper? Being a newbie at welding, I plead ignorance ... thanks guys! ________________________________________________________________________________
Subject: Re: What welding rod did you use for 4130?
Date: Jun 18, 2012
For Oxy/Acetylene... I'm using RG-65 (N0. 32CMS). It is recommended for 4130 and is much cheaper that what you have found. https://www.aircraftspruce.com/catalog/mepages/oxweld.php -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376012#376012 ________________________________________________________________________________
Date: Jun 18, 2012
Did they mention vacuum bagging? What the heck is the world coming to? -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376013#376013 ________________________________________________________________________________
Date: Jun 18, 2012
Mark, 4130 is best gas or TIG welded with mild steel rod. The additional thickness of filler makes up the difference in unit strength. A local welding shop will have 1/16 and 3/32 copper coated rod you need for 8$-$12 per pound. "True Pietenpolers" (those who've flown their airplanes already) can tell you how few pounds you need for the welding on a Piet. Mike Hardaway On Mon, Jun 18, 2012 at 12:37 PM, Mark Roberts wrote: > I see some $65 per pound welding rod on ACS... surely there is something > cheaper? Being a newbie at welding, I plead ignorance ... thanks guys! > > * > > * > > ________________________________________________________________________________
From: "Scott Knowlton " <flyingscott_k(at)hotmail.com>
Date: Jun 18, 2012
I was trained to use my oxy torch by some Canadian Recreational Aircraft Association folks who recommended mild steel welding rod for filler rod with 4130. My entire control system was welded with mild steel rod from Princess Auto (your Harbour Frieght I would guess). Scott Knowlton Burlington ON -----Original Message----- From: Mark Roberts <mark.rbrts1(at)gmail.com> Date: Mon, 18 Jun 2012 19:37:55 Subject: Pietenpol-List: What welding rod did you use for 4130? ________________________________________________________________________________
Date: Jun 18, 2012
Mark, There is an EAA Homebuilder Hints video on this subject and they say that mild steel welding rod is acceptable for 4130. One of them is the RG-65 that Mark Chouinard mentioned. Regards, John Franklin Prairie Aire 4TA0 -----Original Message----- From: Mark Roberts Sent: Jun 18, 2012 2:37 PM Subject: Pietenpol-List: What welding rod did you use for 4130? I see some $65 per pound welding rod on ACS... surely there is something cheaper? Being a newbie at welding, I plead ignorance ... thanks guys! ________________________________________ ________________________________________________________________________________
Date: Jun 18, 2012
Funny that Jeff should mention that... I was just looking for that video. http://www.eaavideo.org/video.aspx?v=1553988082001 -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376018#376018 ________________________________________________________________________________
Date: Jun 18, 2012
Mark, Thanks for the welcomed distraction from work! Gave me a chance to thumb thru ALL those receipts..but, anything for you, buddy! I am looking at a receipt from 2006, from a local welding supply, for 10 lbs of 3/32" 4130 welding rod.$8.832/lb!!! Curious, I just called them and was quoted $20.52/lb. I originally bought 10lbs, and have wood gear, and I think I may have used about 3lbs. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Monday, June 18, 2012 12:38 PM Subject: Pietenpol-List: What welding rod did you use for 4130? I see some $65 per pound welding rod on ACS... surely there is something cheaper? Being a newbie at welding, I plead ignorance ... thanks guys! ________________________________________________________________________________
Date: Jun 18, 2012
what model welder and type? Barry _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Monday, June 18, 2012 3:38 PM Subject: Pietenpol-List: What welding rod did you use for 4130? I see some $65 per pound welding rod on ACS... surely there is something cheaper? Being a newbie at welding, I plead ignorance ... thanks guys! ________________________________________________________________________________
Date: Jun 18, 2012
SGUncyB0YWxraW5nIGdhcywgQmFycnkuDQoNCg0KU2VudCBvbiB0aGUgU3ByaW50riBOb3cgTmV0 d29yayBmcm9tIG15IEJsYWNrQmVycnmuDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpG cm9tOiAiQmFycnkgRGF2aXMiIDxiZWRAbWluZHNwcmluZy5jb20+DQpTZW5kZXI6IG93bmVyLXBp ZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tDQpEYXRlOiBNb24sIDE4IEp1biAyMDEy IDE3OjIyOjI0IA0KVG86IDxwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tPg0KUmVwbHktVG86 IHBpZXRlbnBvbC1saXN0QG1hdHJvbmljcy5jb21TdWJqZWN0OiBSRTogUGlldGVucG9sLUxpc3Q6 IFdoYXQgd2VsZGluZyByb2QgZGlkIHlvdSB1c2UgZm9yIDQxMzA/DQoNClRoaXMgaXMgYSBtdWx0 aS1wYXJ0IG1lc3NhZ2UgaW4gTUlNRSBmb3JtYXQuDQoNCg= ________________________________________________________________________________
Date: Jun 18, 2012
Miller recommends Filler Material ER70S-2 or ER80S-D2. 3 lbs. $27.70. Free fright Cyberweld -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376036#376036 ________________________________________________________________________________
Date: Jun 18, 2012
________________________________ From: Barry Davis <bed(at)mindspring.com> Sent: Mon, June 18, 2012 5:20:49 PM Subject: RE: Pietenpol-List: What welding rod did you use for 4130? what model welder and type? Barry ________________________________ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Monday, June 18, 2012 3:38 PM Subject: Pietenpol-List: What welding rod did you use for 4130? I see some $65 per pound welding rod on ACS... surely there is something cheaper? Being a newbie at welding, I plead ignorance ... thanks guys! href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 19, 2012
Hi Bob, Congratulations on achieving flight. For us Riblett 612 outlaws, could you=C2-give us=C2-some insight with r egards to =C2-your CoG for your initial flights ? Best regards, John Woods Perth, Western Australia ________________________________________________________________________________
Date: Jun 19, 2012
Mark, Actually I found TIG to be much easier. The hand coordination is very simil ar to gas welding. The advantage is no pre-heating needed, it is quicker, a nd I believe easier to control the heat. Very clean- no soot/sparks etc. Al so I can do some aluminum welding with TIG whereas as hard as I tried, I co uld never gas weld aluminum. The disadvantage is the cost of the equipment . After you start TIG you would never go back to gas. Dan Helsper Puryear, TN -----Original Message----- From: Mark Roberts <mark.rbrts1(at)gmail.com> Sent: Mon, Jun 18, 2012 7:40 pm Subject: Pietenpol-List: Re: What welding rod did you use for 4130? > I'll be oxyacetylene welding the necessary parts. To unskilled for TIG! (or oxy at this point.... Practice needed...) -------- o not archive ead this topic online here: http://forums.matronics.com/viewtopic.php?p=376041#376041 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 19, 2012
I'll second what Dan says about TIG. Also WAY easier for really thin metals, like a lot of the fittings on the Piet. Rigbt now, it seems there's lots of TIG welders being sold via ebay, craigslist, etc, for a really good deal. Welding stainless is also really easy with TIG. In all fairness though, gas welding is probably the most versatile. Not easy, but you can weld aluminum, you can also heat things up to get them apart, braze and cut steel with it. Just don't not consider TIG because of it's "complexity". It's quite easy to pick up I thought. And by the way, you'll need er70s-2 filler rod for 4130. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376065#376065 ________________________________________________________________________________
Subject: Heel Brake Question
Date: Jun 19, 2012
I picked up some old Gerdes A-049 brake master cylinders that are of the toe brake type that need to sit fairly close to vertical. I am thinking of using these, but as a heel brake with the cylinders mounted upright under the front seat. I am just starting mock-up the geometry of the brake pedal and there are a few complicating factors that I am trying to work through. Has anyone tried this set-up? An archive search did not turn anything up. Thanks, -------- David Gallagher Zodiac 601 XL-B: flying, 200+ hours now Next project under construction: Aircamper Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376068#376068 ________________________________________________________________________________
Date: Jun 19, 2012
The only other difficulty with TIG (so I've heard and read) is the fact that you'll need to normalize after welding. I'm not saying that TIG is the wrong way to go... heck, I'd like to try it sometime... but the heat effected zone is so small compared to gas that much of the stress is concentrated in a small area, requiring heat treating or normalizing to reduce or disburse the potential for damage or failure. This could be as simple as breaking out the ol rosebud and heating the cluster or part to a dark cherry red and letting it air cool... but none the less, you are right back to your ol buddy, the oxy/acetylene torch. Not an expert, just relaying what I've been told. -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376069#376069 ________________________________________________________________________________
Date: Jun 19, 2012
Mark, I took one of those SportAir workshops (TIG welding) sponsored by EAA. Acco rding to the instructor (he was from Lincoln Welders) and all the written i nfo that they provided, normalizing is not needed on the thinner metals suc h as we use on aircraft. I would highly recommend attendance at any of the Sportair workshops. Went to the fabric covering one also. BTW I met Gary Bell there for the first time. Dan Helsper Puryear, TN -----Original Message----- From: K5YAC <hangar10(at)cox.net> Sent: Tue, Jun 19, 2012 8:02 am Subject: Pietenpol-List: Re: What welding rod did you use for 4130? The only other difficulty with TIG (so I've heard and read) is the fact tha t ou'll need to normalize after welding. I'm not saying that TIG is the wron g ay to go... heck, I'd like to try it sometime... but the heat effected zone is o small compared to gas that much of the stress is concentrated in a small rea, requiring heat treating or normalizing to reduce or disburse the poten tial or damage or failure. This could be as simple as breaking out the ol roseb ud nd heating the cluster or part to a dark cherry red and letting it air cool ... ut none the less, you are right back to your ol buddy, the oxy/acetylene to rch. ot an expert, just relaying what I've been told. -------- ark Chouinard ings, Center Section and Empannage and Fuse framed up - Working on Landing Gear ead this topic online here: http://forums.matronics.com/viewtopic.php?p=376069#376069 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jun 19, 2012
David, I designed my own heel brakes, which are mechanical, but I am sure you could easily adapt cylinders for hydraulics. There are a few pics on www.westcoastpiet.com, but let me know if you need more... http://westcoastpiet.com/images/Gary%20Boothe/images/IMG_2992.JPG http://westcoastpiet.com/images/Gary%20Boothe/images/Brake_Pedal_Hook-up_2.j pg Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of DaveG601XL Sent: Tuesday, June 19, 2012 5:52 AM Subject: Pietenpol-List: Heel Brake Question --> I picked up some old Gerdes A-049 brake master cylinders that are of the toe brake type that need to sit fairly close to vertical. I am thinking of using these, but as a heel brake with the cylinders mounted upright under the front seat. I am just starting mock-up the geometry of the brake pedal and there are a few complicating factors that I am trying to work through. Has anyone tried this set-up? An archive search did not turn anything up. Thanks, -------- David Gallagher Zodiac 601 XL-B: flying, 200+ hours now Next project under construction: Aircamper Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376068#376068 ________________________________________________________________________________
Date: Jun 19, 2012
And if that second picture link below returns an error when you click on it (as mine did...), just add "pg" (without the quotes) to the link in the browser window.... http://westcoastpiet.com/images/Gary%20Boothe/images/Brake_Pedal_Hook-up_2.j pg -----Original Message----- >From: Gary Boothe <gboothe5(at)comcast.net> >Sent: Jun 19, 2012 8:24 AM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Heel Brake Question > > >David, > >I designed my own heel brakes, which are mechanical, but I am sure you could >easily adapt cylinders for hydraulics. There are a few pics on >www.westcoastpiet.com, but let me know if you need more... > >http://westcoastpiet.com/images/Gary%20Boothe/images/IMG_2992.JPG >http://westcoastpiet.com/images/Gary%20Boothe/images/Brake_Pedal_Hook-up_2.j >pg > > >Gary Boothe >NX308MB > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of DaveG601XL >Sent: Tuesday, June 19, 2012 5:52 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Heel Brake Question > >--> > >I picked up some old Gerdes A-049 brake master cylinders that are of the toe >brake type that need to sit fairly close to vertical. I am thinking of >using these, but as a heel brake with the cylinders mounted upright under >the front seat. I am just starting mock-up the geometry of the brake pedal >and there are a few complicating factors that I am trying to work through. > >Has anyone tried this set-up? An archive search did not turn anything up. > >Thanks, > >-------- >David Gallagher >Zodiac 601 XL-B: flying, 200+ hours now >Next project under construction: Aircamper > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=376068#376068 > > ________________________________________________________________________________
Date: Jun 19, 2012
Subject: String Theory (Crankcase)
I know about using string to help seal the case halves of a Continental A-6 5 upon reassembly. My particular manual, (2011) does not mention this strin g. It merely states to apply a thin coating of sealant to the mating surfac es.- My concern is that my "thin coating" may squish out when the bolts a re torqued and end up coming looses inside the engine. Anyone NOT using the string and if so...any issues without it? Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Jun 19, 2012
That's the key Mike-a thin coating of Titeseal will do the job. Thick an d you'll get squeeze out which you don't want for the reason you cited. The silk thread is an insurance policy to help prevent oil leaks. I don't know of anyone who hasn't used the string (in our local area at least) and it is recommended by the b est-of-the best small Continental engine rebuilders that I know of personally-Bill Klosz and Don Helmick and by the well-respec ted Harry Fenton. I don't know of anyone who hasn't used the string. You can be the first and tell us if you get oil leaks or not but obviously it is much easier to install it now than to wish you had it later. Again , your choice-that's the beauty of homebuilding and experimental aircraft building in the United States. Mike C. http://textors.com/PietProject.html Photos from Jack Textor's fantastic photo documentary of his engine overhau l-thank you Jack! [cid:image001.jpg(at)01CD4E06.88215AB0] [cid:image002.jpg(at)01CD4E06.88215AB0] ________________________________________________________________________________
Subject: Re: String Theory (Crankcase)
Date: Jun 19, 2012
Michael, This weekend I mounted a 5th bearing on my Corvair engine. The directions tell you to apply enough sealant (Permatex Anaerobic Gasket Maker) so you squeeze some out around the assembly, but try to not get any into the engine. A tall order. I called Permatex tech support and he told me it will simply dissolve into the oil. Another reason to change your oil often in the beginning. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376080#376080 ________________________________________________________________________________
Date: Jun 19, 2012
The string is going in for sure, I was just curious since my manual did not say to use it, I wondered if people have, in fact, not used it and what the effect was. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 19, 2012
Thanks John. Didn't consider the Corvair rebuilds. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: W&B
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Jun 19, 2012
Hi Mike, Your plane is looking great. When all is said and done, We will have the green team here on the west coast. Keep me informed so I can try to make it up north to fly with you and Gary. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376085#376085 Attachments: http://forums.matronics.com//files/p1010467_189.jpg ________________________________________________________________________________
Date: Jun 19, 2012
Subject: silk thread crank sealing, Continental engines.
There is a service bulletin evidently (I found the one below that calls out for the silk thread for the IO-360) that calls out a part number for the thread (see below, PN 641543). I found some for sale in a quick search too. What Harry Fenton's words say from his web page: [cid:image001.png(at)01CD4E0B.2E52AF70] [cid:image004.jpg(at)01CD4E0B.2E766410] ________________________________________________________________________________
Subject: Re: W&B
Date: Jun 19, 2012
I wish that was my hanger. We can all dream. That one is in San Diego at SEE. Went to an antique show there a few years ago. Just think how good we will look in a tight / loose formation at mach 0.00001 and 500 AGL. Just thinking about it lowers my blood pressure. What a great feeling. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376089#376089 ________________________________________________________________________________
Date: Jun 19, 2012
I work with the guys at EAA's Week's hangar where they do all sorts of welding on their aircraft with TIG and don't normalize either. Furthermore, doing a LOT of reading on the matter, the process of normalizing is rather complicated, requiring close temp control, times and cool down rates for it to be effective, none which can be done without rather weird equipment and know how. Like usual, ask one question from three guys and get a dozen answers! It's the kind of thing that keeps me awake at nights... I'm finally firmly in the camp (mostly after having seen it in person a lot) that TIG is fine, easier for me, no normalizing is required. With that said, do some reading on the subject of brazing 4130... You'll get twice the number of theories still! Something like two dozen ideas from three guys. Still, an oxy/acet rig is REALLY handy. If you can oxy/acet to aircraft standards, going TIG later is going to be a piece of cake. I agree the sportair workshops are great. Dr. Joe (can't remember his last name) who does a lot of teaching of them is really a good instructor. I've sat through a lot of this lecturing during Air Venture (Oshkosh). I also have sat through his gas welding aluminum seminars, which are really really good. There's a short video of his on oxy/acet and 4130 on the EAA website (or there's a link). It's short and really really really (that's THREE reallys) a good place to start. Explains a simple rule of thumb procedure (1/8", 45 degrees and 90 degrees) for oxy/acet of 4130. This whole welding thing is very cumulative. It's a matter of burning some gas, rods and metal. Like lead poisoning, your brain just collects the info and one day it'll seem a lot easier than before, for no good reason. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376091#376091 ________________________________________________________________________________
Date: Jun 19, 2012
The research that I've done on TIG welding 4130 indicates that post weld normalizing is only needed for metal thicknesses over 1/8". Therefore, for the metal parts on a Pietenpol, very few welds (if any) would require normalizing. Just be sure to allow the welds to cool slowly, in still air. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376093#376093 ________________________________________________________________________________
Date: Jun 19, 2012
Michael I used LOCTITE-515 on my Lycoming. They came out with a service bulletin that says you can use this as well as General Electric Companys RTV-102. I only have 3 hours on my O-235 but so far it is dusty dry. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 First flight June 16,2012 Started building July, 2009 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376096#376096 Attachments: http://forums.matronics.com//files/lycoming_cc_sealant_si1125d_112.pdf ________________________________________________________________________________
Date: Jun 19, 2012
Subject: Re: What is this thingy called??
Hi Mark, Its called a cable shackle. Look in ACS catalog for cable shackles. Jim B. ________________________________________________________________________________
Date: Jun 19, 2012
Found this picture posted some time ago by Clif Dawson -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376103#376103 Attachments: http://forums.matronics.com//files/copy_of_outer_top_brace_fit_100_179.jpg ________________________________________________________________________________
Date: Jun 19, 2012
I'll be darned! Thanks for the info gents! -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376108#376108 ________________________________________________________________________________
Date: Jun 19, 2012
I used the string. No leaks after 7 years and 260 hours. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Tuesday, June 19, 2012 10:05 AM Subject: Pietenpol-List: String Theory (Crankcase) I know about using string to help seal the case halves of a Continental A-65 upon reassembly. My particular manual, (2011) does not mention this string. It merely states to apply a thin coating of sealant to the mating surfaces. My concern is that my "thin coating" may squish out when the bolts are torqued and end up coming looses inside the engine. Anyone NOT using the string and if so...any issues without it? Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Jun 19, 2012
Subject: Cable making
With the discussions of cable making over the past couple of weeks, I thought I might pass along a tip that was passed along to me by some of the old timers here at my local airport. Maybe everyone else knows this tip, but it was news to me. Attached is a photo of a connector that they recommended for me to use when fabricating cables. I picked up this connector at Home Depot for about 3 bucks or so. It works like a charm in sizing and holding cable lengths with precision. It acts like a third hand, but without any of the complaining. Together with the set of cable cutters that I bought at the local mountain bike repair station for about $20-$25, cable making has shifted from a dreaded task to something that is simple and easy. Cheers, Ken ________________________________________________________________________________
Subject: shackles
Date: Jun 20, 2012
For those of you who want to use shackles, I picked up a bunch from B&B for a good price last time I bought some turnbuckles. Douwe ________________________________________________________________________________
Subject: Turnbuckles for sale
Date: Jun 20, 2012
I have over (100) AN140-16S turnbuckles for sale. They are used and have (2) cable eyes. I used motorcycle chain sideplates/links to create a "fork" and used these throughout my Air Camper. $8ea plus $5 shipping via USPS Priority small flat rate box. Please PM me with orders. Check, MO or PayPal all work fine. Thanx.......Mike -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376124#376124 Attachments: http://forums.matronics.com//files/img_4302_811.jpg http://forums.matronics.com//files/img_4299_207.jpg ________________________________________________________________________________
Date: Jun 20, 2012
I bought this TIG welder on E-Bay and it does everything as advertized and I think is a very good deal. http://www.ebay.ca/itm/ws/eBayISAPI.dll?ViewItem&item=250810415089&ssPageName=ADME:L:OC:CA:1123#ht_7441wt_952 It was delivered in 3 days, and worked like a charm out of the box. I have done mostly stainless welding with it but did some aluminum for testing and it worked great with blunt zirconiated electrodes in AC pulsed mode. Nice cleaning action. One other quick note which will be valuable for those welding thin materials. I learned to chemically sharpen my tungsten using sodium nitrite which is an inexpensive chemical salt available from chemical supplies (or you could buy a product called chemsharp which is the same thing sold in expensive jars!) For thin metals in DC mode you can't beat the fine tip you get with this method and no arc wandering! Joe tools wrote: > I'll second what Dan says about TIG. Also WAY easier for really thin metals, like a lot of the fittings on the Piet. > > Rigbt now, it seems there's lots of TIG welders being sold via ebay, craigslist, etc, for a really good deal. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376126#376126 ________________________________________________________________________________
Date: Jun 20, 2012
"I'm finally firmly in the camp (mostly after having seen it in person a =0Alot) that TIG is fine, easier for me, no normalizing is required." I agree.- Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Jun 20, 2012
Mark, I have no real experience with oxy. welding, however, I have done my fair share of tig...most of it on my plane. I did do some years ago as well .- If you go the tig route, I believe you will find that you will come up to speed very fast and be quite confident. I shied away from welding at fi rst too, on my plane. It had been so long since I welded, I felt like I wou ld be starting all over.- Turns out, the welding was one of the most fun aspects of my build. Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Subject: Re: Heel Brake Question
Date: Jun 20, 2012
great design Gary. i may be copying it myself. how good do the band brakes work? and whats a good supplier for them?Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376137#376137 ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Jun 20, 2012
Regarding Heel brakes. I am a convert as far as using them on taildraggers. I have spent a lot of time in my buddies Aeronca Champ the last few months. At first I found the heel brakes to be almost counter intuitive. It felt strange to push with my heel and flex my toes up in order to stop. (Remember I was raised in a Cessna 150 with the training wheel up front and toe brakes.) However, I have become a fan of them on this taildragger. If they were as easy to get to as toe brakes I would probably have ground looped the plane by now. If I had not locked the brakes and put the plane on it's nose. In the Champ, my feet don't rest on the heel brakes. So heel brakes require just enough more effort that I have to reach for them and I am too busy keeping the plane straight to do that without real thought. It keeps me out of trouble. Blue Skies, Steve D ----- Original Message ----- From: nightmare <pauldonahuepilot(at)yahoo.com> Date: Wednesday, June 20, 2012 9:24 Subject: Pietenpol-List: Re: Heel Brake Question > > great design Gary. i may be copying it myself. how good do the band brakes work? and whats a good supplier for them?Paul > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376137#376137 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 20, 2012
Thanks, Paul. Taxi tests will start in about a month. I'm not expecting much! ------Original Message------ From: nightmare Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Heel Brake Question Sent: Jun 20, 2012 7:20 AM great design Gary. i may be copying it myself. how good do the band brakes work? and whats a good supplier for them?Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376137#376137 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Jun 20, 2012
Her is where I bought mine: http://www.gokartgalaxy.com/4_band_brakes_and_components.htm Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: Hey! Pulley my finger! A pulley question...
Date: Jun 20, 2012
How about MS24566-3B, available from Aircraft Spruce, for $17.50 a piece? Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376173#376173 ________________________________________________________________________________
Subject: Horn mistake....
Date: Jun 20, 2012
Hello, I did a mistake and I have two choices to correct it. I am covering the rudder and stabilizer of the piet to practice with the process and .. finish some parts. When I cover the rudder, I put the elevator horn in place of the rudder horn... two or three months ago, and I just discover the error ( I dcide to cover the stabilizer now and when I was searchin for the horns I saw I have two of different size!!). The solution of course is replace the horn .. of course, but for that I have to cut the cover (it is painted now) and recover this place.. The other option is make an other horn, and keep the rudder horn smaller than the one designed for the Piet. My question is.. is there any trouble in keeping the small horn in the rudder or I have to change it?.. Lots of you have flown the Piet..may be you can guide me about this little problem. Thank you and regards Mario -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376178#376178 ________________________________________________________________________________
Subject: Re: Turnbuckles for sale
Date: Jun 20, 2012
Papa Mike, I will take 20 of them, if they are still available. If OK with you, I will send a check whenever you say to do so. Thanks a Million for the offer! Ray Krause 843 Jay Street Colusa, Ca 95932 530-458-7097 (home) 530-736-2627 (cell) Building Sky Scout ----- Original Message ----- From: "899PM" <rockriverrifle(at)hotmail.com> Sent: Wednesday, June 20, 2012 5:36 AM Subject: Pietenpol-List: Turnbuckles for sale > > I have over (100) AN140-16S turnbuckles for sale. They are used and have > (2) cable eyes. I used motorcycle chain sideplates/links to create a > "fork" and used these throughout my Air Camper. $8ea plus $5 shipping > via USPS Priority small flat rate box. Please PM me with orders. Check, MO > or PayPal all work fine. > > Thanx.......Mike > > -------- > PAPA MIKE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376124#376124 > > > Attachments: > > http://forums.matronics.com//files/img_4302_811.jpg > http://forums.matronics.com//files/img_4299_207.jpg > > > ________________________________________________________________________________
Date: Jun 20, 2012
Chemical sharpening: You get a jar of sodium nitrite. Hold your electrode in a pair of pliers and fire up a propane torch and just heat the tip of the tungsten until it glows red in the flame. Then quickly before it cools dip it in the sodium nitrite powder, moving it in small circles and up and down a little. A reaction takes place as the oxydizing salt reacts with the hot tungsten and the tungsten is removed forming a beautiful smooth sharp tip. You quickly learn that you can control the angle of the sharpening by how far you dip the tungsten into the pool that forms on the poweder as it melts and reacts. There are no grinding marks on the electrode which is what makes the arc wander and difficult to control on low power thin metal welding where you need fine control. Also grinding releases fine dust which you don't want to breathe especially if you are using thoriated tungsten which contains a few percent radioactive thorium. Here's a photo of a 1/16" lanthanated electrode I chemically sharpened using this technique. Look at the fine tip on it! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376187#376187 Attachments: http://forums.matronics.com//files/sharpened_with_sodium_nitrite_191.jpg ________________________________________________________________________________
Subject: Re: Horn mistake....
Date: Jun 20, 2012
Mario, Do the right thing. Uncover the rudder enough to remove the incorrectly installed horn. Not only will this be easier than making a new horn but leaving the smaller horn on the rudder will change the geometry of the rudder control. Greg Cardinal ----- Original Message ----- From: "giacummo" <mario.giacummo(at)gmail.com> Sent: Wednesday, June 20, 2012 8:50 PM Subject: Pietenpol-List: Horn mistake.... > > > Hello, > > I did a mistake and I have two choices to correct it. I am covering the > rudder and stabilizer of the piet to practice with the process and .. > finish some parts. When I cover the rudder, I put the elevator horn in > place of the rudder horn... two or three months ago, and I just discover > the error ( I dcide to cover the stabilizer now and when I was searchin > for the horns I saw I have two of different size!!). > The solution of course is replace the horn .. of course, but for that I > have to cut the cover (it is painted now) and recover this place.. > The other option is make an other horn, and keep the rudder horn smaller > than the one designed for the Piet. > > My question is.. is there any trouble in keeping the small horn in the > rudder or I have to change it?.. Lots of you have flown the Piet..may be > you can guide me about this little problem. > > Thank you and regards > > Mario > > -------- > Mario Giacummo > http://vgmk1.blogspot.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376178#376178 > > > ________________________________________________________________________________
Date: Jun 21, 2012
I agree with Greg, Mario. If you put a smaller horn on the rudder than it was designed for, two things will happen: Rudder pedal forces will go up, and rudder sensitivity will increase. I can't predict how this will affect the handling of the airplane, but I can say that if built as designed, the rudder on this airplane feels just about perfect - light forces on the rudder bar and just the right sensitivity and rudder authority. I would not recommend changing the design, but would cut the fabric off and do it correctly. Don't worry - you are not the first to make a mistake building this (or any other) airplane. I'm in the process of packing to move from my house in North Carolina to our new home at Smith Mountain Lake, Virginia and as I packed up my workshop I found a whole box of scrap parts I produced while building my Pietenpol. I actually built about one and a half Pietenpols, judging from all the parts that I made that I later determined were not good enough to trust my life to. Part of the educational process in building a plane is learning through painful experience that mistakes must be corrected, even if it means doing some tasks over again. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Greg Cardinal Sent: Thursday, June 21, 2012 12:31 AM Subject: Re: Pietenpol-List: Horn mistake.... --> Mario, Do the right thing. Uncover the rudder enough to remove the incorrectly installed horn. Not only will this be easier than making a new horn but leaving the smaller horn on the rudder will change the geometry of the rudder control. Greg Cardinal ----- Original Message ----- From: "giacummo" <mario.giacummo(at)gmail.com> Sent: Wednesday, June 20, 2012 8:50 PM Subject: Pietenpol-List: Horn mistake.... > > > Hello, > > I did a mistake and I have two choices to correct it. I am covering the > rudder and stabilizer of the piet to practice with the process and .. > finish some parts. When I cover the rudder, I put the elevator horn in > place of the rudder horn... two or three months ago, and I just discover > the error ( I dcide to cover the stabilizer now and when I was searchin > for the horns I saw I have two of different size!!). > The solution of course is replace the horn .. of course, but for that I > have to cut the cover (it is painted now) and recover this place.. > The other option is make an other horn, and keep the rudder horn smaller > than the one designed for the Piet. > > My question is.. is there any trouble in keeping the small horn in the > rudder or I have to change it?.. Lots of you have flown the Piet..may be > you can guide me about this little problem. > > Thank you and regards > > Mario > > -------- > Mario Giacummo > http://vgmk1.blogspot.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376178#376178 > > > ________________________________________________________________________________
Date: Jun 21, 2012
Greg, Jack, thank you.. it's enough, let's replace it and learn how to make a patch over the cover.. uffff.... Regards. -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376192#376192 ________________________________________________________________________________
Date: Jun 21, 2012
Ray, I will save you (20) and call you tonight with info. Thanx. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376198#376198 ________________________________________________________________________________
Date: Jun 21, 2012
There is also this advert for a product called chemsharp but it is just sodium nitrite in an expensive bottle: http://www.youtube.com/watch?v=drgaJVKxJxw Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376208#376208 ________________________________________________________________________________
Subject: Log Book
Date: Jun 21, 2012
I have not flown since 1985, and my old log book was partially damaged in flood. The entries are still legible, and I am assuming that I should just start a new one. Anyone have any bright ideas? Gary Boothe NX308MB ________________________________________________________________________________
Date: Jun 21, 2012
Hi, Mike I don't know if you received my attempt to email you direct, but I would like to buy 25 of the turnbuckles you offered. Contact me at 541-840-9484 or glenf(at)ccountry.com Thanks Glen Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376214#376214 ________________________________________________________________________________
Subject: Re: Log Book
Date: Jun 21, 2012
If it's usable, no need to start a new one. It's ONLY for formality anyway. Be sure and have an accurate hours flown entry on your physical, as you can use that to reestablish time in the event of a lost logbook. When I got my piet, I found my little logbook from where I soloed back in high school. My tailwheel hours and endorsement were the first entries since the early 80's! However, it's just fine to keep my piet hours which are primarily logged for insurance. I haven't kept a log of my commercial hours since I flew for American Eagle for a few months. I only kept that to have a nice professional looking logbook when I interviewed for major airlines. The records the company keeps makes everything legal and I can't even imagine ever having to interview for a flying job again. If this one doesn't work out, I'll find something else to do! All of my military hours are in yet different logbooks. You only have to have proof of flying for currency, insurance, requirements for tickets, records of endorsements, etc. Other than wording of endorsements, there's really no guidance from the FAA. I've used the whole stack of logbooks even recently to get my CFI. The inspectors don't seem to care that some hours are in this log, others are in that log, just as long as it's fairly obvious they're MY records. Honestly, it's still quite a gentleman's system. Probably one of the last... Personally, I'd keep using the damaged one if possible, kind of neat to still have that. I'm the sentimental sort. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376215#376215 ________________________________________________________________________________
Subject: Log Book
Date: Jun 21, 2012
Keep the old one. Even damaged, it would still show some continuity. Allied Van Lines lost my first logbook (I had already started the second one and managed to keep it). Life would be simpler if I still had it. You'll need a BFR from a Certified Flight Instructor and a medical if you are going to fly as a Private Pilot and carry passengers. If you will be flying as a Sport Pilot, you'll still need a BFR before carrying passengers (I think - I've never dealt with Light Sport pilots as a CFI), but it can be administered by a Light Sport Instructor, or by a CFI. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Thursday, June 21, 2012 11:34 AM Subject: Pietenpol-List: Log Book I have not flown since 1985, and my old log book was partially damaged in flood. The entries are still legible, and I am assuming that I should just start a new one. Anyone have any bright ideas? Gary Boothe NX308MB ________________________________________________________________________________
Subject: Log Book
Date: Jun 21, 2012
Forgot to attach the picture. Thanks, Jack & Tools. I'm leaning toward the sentimental comment that Tools made..Duct tape may be the best fix. The binding took the worst of the damage. If no one pops up with a better idea, then it'll be duct tape. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Thursday, June 21, 2012 9:03 AM Subject: RE: Pietenpol-List: Log Book Keep the old one. Even damaged, it would still show some continuity. Allied Van Lines lost my first logbook (I had already started the second one and managed to keep it). Life would be simpler if I still had it. You'll need a BFR from a Certified Flight Instructor and a medical if you are going to fly as a Private Pilot and carry passengers. If you will be flying as a Sport Pilot, you'll still need a BFR before carrying passengers (I think - I've never dealt with Light Sport pilots as a CFI), but it can be administered by a Light Sport Instructor, or by a CFI. Jack Phillips NX899JP
June 04, 2012 - June 21, 2012
Pietenpol-Archive.digest.vol-lg
