Pietenpol-Archive.digest.vol-lk
August 23, 2012 - September 12, 2012
Subject: Re: A65 /A75Tach
Date: Aug 23, 2012
Steve do you have a diagram of that setup? Jack Textor Sent from my iPad On Aug 23, 2012, at 3:33 PM, steve(at)wotelectronics.com wrote: > Michael, > > One more comment on the Westach electronic signal tach...you do need to ad d a simple Left/Right switch on the panel to control which mag the tach is m onitoring. It will work without this switch, but without the switch the tac h will go dead when you do your runup and switch to one mag. (i.e., it can o nly monitor one mag at a time). When on "both" this doesn't matter, but whe n you do your left/right mag check you kill one mag, if that is the one you a re monitoring the tach goes dead with it. The switch allows you to switch t he tach signal from one mag to the other so you can compare RPM between the t wo. I hope that makes sense. > > I used shielded wire for the signal wire from the tach to mag. Not sure i f that was necessary or not, I was doing it to help ensure that I wouldn't g et radio noise. Be careful with wire routing, unintentionally grounding a w ire could shut down a mag. > > Steve Ruse > Norman, OK > > > > On 2012-08-23 11:30, Michael Perez wrote: > >> I really like this idea better. Fortunately, it is not too late for me to switch! If i do, my brand new mechanical tach. and 90 deg. adapter will be for sale! >> >> Michael Perez >> Pietenpol HINT Videos >> Karetaker Aero >> www.karetakeraero.com >> >> --- On Thu, 8/23/12, steve(at)wotelectronics.com wrote: >> >> From: steve(at)wotelectronics.com >> Subject: Re: Pietenpol-List: A65 /A75Tach >> To: pietenpol-list(at)matronics.com >> Date: Thursday, August 23, 2012, 10:34 AM >> >> For my A-75 I use a Westach tachometer that just monitors the mag wires f or RPM. This eliminates the need for a cable to the engine. Better accurac y and less maintenance. No bouncing, no lubing of cables, etc. >> >> I believe this is the model I use, check their documentation to make sure this is the correct model: >> >> >> >> >> >> >> >> >> >> http://www.aircraftspruce.com/catalog/inpages/tachometer3at32.php >> >> >> >> Steve Ruse >> Norman, OK >> >> On 2012-08-23 08:40, Michael Perez wrote: >> >> I do not have my tach. in hand at the moment, but I can get you the part n umber, (ACS), if you like. I am also using the 90 deg. adapter from ACS, so t he rotation can be switched AND it makes running the tach cable easier in th e small instrument compartment. (My opinion.) >> >> Let me know. >> >> Michael Perez >> Pietenpol HINT Videos >> Karetaker Aero >> www.karetakeraero.com >> http://www.matronics.com/Navigator?Pietenpol-List-> http://forums.matroni cs.com >> >> >> >> http://www.matronics.c================= = >> http://www.matronics.com/Navigator?Pietenpol-List-> http://forums.matroni cs.com > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 23, 2012
First, from one of the persons looking for a tach. Thank you all. Good discussion. Regarding Westach, I just called there, and learned that the tachs in our discussion have two wires, one to a ground, and one to a p-lead. Another option is the buy and install a generator from Westach, which is a module that attaches the to the existing tach cable port on the engine case, then attach the tach wire to it. This leaves the mags out of the picture, but will measure engine rpm with each mag test. The part number for the generator is "303DGT". I spoke with Pete who answered the phone and who is the owner. The generator works on either clockwise or counterclockwise rotation. I'm on the fence as to which type of tach to use (tradition or Westach). thanks again, john On Thu, Aug 23, 2012 at 4:00 PM, Jack(at)textors.com wrote: > Steve do you have a diagram of that setup? > > Jack Textor > Sent from my iPad > > On Aug 23, 2012, at 3:33 PM, steve(at)wotelectronics.com wrote: > > Michael, > > One more comment on the Westach electronic signal tach...you do need to > add a simple Left/Right switch on the panel to control which mag the tach > is monitoring. It will work without this switch, but without the switch > the tach will go dead when you do your runup and switch to one mag. (i.e., > it can only monitor one mag at a time). When on "both" this doesn't > matter, but when you do your left/right mag check you kill one mag, if that > is the one you are monitoring the tach goes dead with it. The switch > allows you to switch the tach signal from one mag to the other so you can > compare RPM between the two. I hope that makes sense. > > I used shielded wire for the signal wire from the tach to mag. Not sure > if that was necessary or not, I was doing it to help ensure that I wouldn't > get radio noise. Be careful with wire routing, unintentionally grounding a > wire could shut down a mag. > > Steve Ruse > Norman, OK > > > On 2012-08-23 11:30, Michael Perez wrote: > > I really like this idea better. Fortunately, it is not too late for me > to switch! If i do, my brand new mechanical tach. and 90 deg. adapter will > be for sale! > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > --- On *Thu, 8/23/12, steve(at)wotelectronics.com *wrote: > > > From: steve(at)wotelectronics.com > Subject: Re: Pietenpol-List: A65 /A75Tach > To: pietenpol-list(at)matronics.com > Date: Thursday, August 23, 2012, 10:34 AM > > For my A-75 I use a Westach tachometer that just monitors the mag wires > for RPM. This eliminates the need for a cable to the engine. Better > accuracy and less maintenance. No bouncing, no lubing of cables, etc. > > I believe this is the model I use, check their documentation to make sure > this is the correct model: > > > http://www.aircraftspruce.com/catalog/inpages/tachometer3at32.php > > > Steve Ruse > Norman, OK > > On 2012-08-23 08:40, Michael Perez wrote: > > I do not have my tach. in hand at the moment, but I can get you the > part number, (ACS), if you like. I am also using the 90 deg. adapter from > ACS, so the rotation can be switched AND it makes running the tach cable > easier in the small instrument compartment. (My opinion.) > > Let me know. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > *http://www.matronics.com/Navigator?Pietenpol-List-> http://forums.matronics.com* > > > ** <http://forums.matronics.com/>*http://www.matronics.c================== * > > *http://www.matronics.com/Navigator?Pietenpol-List-> http://forums.matronics.com* > > <http://forums.matronics.com/> > > > <http://forums.matronics.com/> > > * > > * <http://forums.matronics.com/> > > * > > > * > > ________________________________________________________________________________
Subject: Re: Horn bend pictures.
Date: Aug 23, 2012
Here is a picture of my jig for forming the aileron horns. Ken Perkins described this to me at Brodhead a few years ago. It is a 3/8 inch round steel rod welded to a 3/4 X 3/4 inch angle iron 10 inches long. I simply hold the jig and one side of the horn in the vise and bend the leading edge of the horn around the rod with a hammer as shown in Jim's photo. I bent one up this morning just for the picture. This jig is so handy I also have a 1/2, 5/8,3/4, and 1 inch version. Note that I do not bend the tabs out. I weld a piece of channel in the opening so that the bolts run horizontally between the elevator and horizontal stabilizer. This one took about 10 minutes to cut and form. Any one have a tig welder... Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381649#381649 Attachments: http://forums.matronics.com//files/horn_jig_195.jpg ________________________________________________________________________________
Date: Aug 23, 2012
Subject: Re: Bending the aileron stick horn...
I used a- brake, by hand, the brake was not powered in any way. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 23, 2012
Thanks for the added intel. I would never have thought of that until I star ted the installation. (switching between the mags.) Did you figure this out , or did the tach. instructions tell you? - If you have pictures, I would be interested in seeing the tach, wiring and the "switch" switch. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com --- On Thu, 8/23/12, steve(at)wotelectronics.com wr ote: From: steve(at)wotelectronics.com <steve(at)wotelectronics.com> Subject: Re: Pietenpol-List: A65 /A75Tach Date: Thursday, August 23, 2012, 4:33 PM Michael, One more comment on the Westach electronic signal tach...you do need to add a simple Left/Right switch on the panel to control which mag the tach is m onitoring. -It will work without this switch, but without the switch the tach will go dead when you do your runup and switch to one mag. -(i.e., i t can only monitor one mag at a time). -When on "both" this doesn't matte r, but when you do your left/right mag check you kill one mag, if that is t he one you are monitoring the tach goes dead with it. -The switch allows you to switch the tach signal from one mag to the other so you can compare RPM between the two. -I hope that makes sense. I used shielded wire for the signal wire from the tach to mag. -Not sure if that was necessary or not, I was doing it to help ensure that I wouldn't get radio noise. -Be careful with wire routing, unintentionally groundin g a wire could shut down a mag. Steve Ruse Norman, OK- - On 2012-08-23 11:30, Michael Perez wrote: I really like this idea better. Fortunately, it is not too late for me to s witch!- If i do, my brand new mechanical tach. and 90 deg. adapter will b e for sale! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com --- On Thu, 8/23/12, steve(at)wotelectronics.com wrote: From: steve(at)wotelectronics.com Subject: Re: Pietenpol-List: A65 /A75Tach Date: Thursday, August 23, 2012, 10:34 AM For my A-75 I use a Westach tachometer that just monitors the mag wires for RPM. -This eliminates the need for a cable to the engine. -Better accu racy and less maintenance. -No bouncing, no lubing of cables, etc. I believe this is the model I use, check their-documentation-to make su re this is the correct model: - - - - http://www.aircraftspruce.com/catalog/inpages/tachometer3at32.php - Steve Ruse Norman, OK On 2012-08-23 08:40, Michael Perez wrote: I do not have my tach. in hand at the moment, but I can get you the part nu mber, (ACS), if you like. I am also using the 90 deg. adapter from ACS, so the rotation can be switched AND it makes running the tach cable easier in the small instrument compartment. (My opinion.) Let me know. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.comhttp://www.matronics.com/Navigator?Pietenpol-List-> ht tp://forums.matronics.com - -http://www.matronics.c================ == http://www.matronics.com/Navigator?Pietenpol-List-> http://forums.ma tronics.comDate: Aug 23, 2012
Subject: Re: Brodhead Report - Late
Kevin, If I make it up to Brodhead next year-we'll stuff your ass in 92GB and go flying.- I'm glad to hear you are starting to plan the new build. - If I run past any extra corvair pieces parts that we don't need I will let you know.- NOW HEAL UP AND GET BACK TO WORK! - Shad don't archive ________________________________________________________________________________
Date: Aug 23, 2012
Jim and Dan: Many thanks for the pictures! And no, that wasn't redundant for me... this is the mental hurdle I am getting over: learning to work with metal. So, the more pics and advice I get at this stage the better. I am on my way now to borrow a torch from a friend, and I hope my lovely wife will allow me to go rent tanks tomorrow, but I fear she's hit her limit on spending right now (as I AM still officially unemployed... ). Thanks again! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381656#381656 ________________________________________________________________________________
Date: Aug 24, 2012
Subject: eyebrows for Corvair
I am getting ready to make eyebrows for my corvair and was wondering how high the front of the eyebrow should be for efficient cooling. Those of you that have flying corvairs, how high did you go. I was looking at the eyebrows on a friends A65 powered J3 cub and the cross-sectional area on his eyebrows are about 28 sq. in. That would make the eyebrow on a corvair installation about 4-1/2 inches high. Does that seem about right. Rick Schreiber Valparaiso IN ________________________________________________________________________________
Date: Aug 24, 2012
Subject: Re: eyebrows for Corvair
I'm not to this stage just yet, but look forward to the suggestions and advice. Ken On Fri, Aug 24, 2012 at 7:04 AM, Rick Schreiber wrote: > > I am getting ready to make eyebrows for my corvair and was wondering how > high the front of the eyebrow should be for efficient cooling. Those of you > that have flying corvairs, how high did you go. I was looking at the > eyebrows on a friends A65 powered J3 cub and the cross-sectional area on his > eyebrows are about 28 sq. in. That would make the eyebrow on a corvair > installation about 4-1/2 inches high. Does that seem about right. > > Rick Schreiber > Valparaiso IN > > ________________________________________________________________________________
Subject: Re: Gladys Ingles
Date: Aug 24, 2012
One of the YouTube posters pointed out that in the first clip there was no one in the back seat but yet there was footage taken from there. Movie cameras back then were a rare commodity so shots from two different airplanes required landing and transfer so the performance was, most likely, a publicity stunt. Regardless of the setup, it was still a spectacular feat of bravery (or stupidity). A neat clip, all things considered. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381686#381686 ________________________________________________________________________________
Date: Aug 24, 2012
FYI, the bend I made does not need to be down the middle, biased towards the leading edge will yield a more "airfoil" shape. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 24, 2012
Rick; You can get an idea of intake area by looking at William Wynne's setup on his Piet as a starting point. Some pictures here: http://www.flysquirrel.net/piets/WWPiet.html This one is a good starting point for two reasons: (1) his scoops were rectangular, so you should be able to estimate the intake area pretty easily, and (2) his airplane was based in Florida, so if the cooling worked there, it should work anywhere. -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381698#381698 ________________________________________________________________________________
Date: Aug 24, 2012
Subject: Re: A65-75 Tach discussion
I can add a bit of experience with the traditional mechanical tach and the 90 degree drive. I have 135 hours on my Piet in 15 months, and am on my third angle drive. I think I have the problem licked now, but there appears to be a delicate balance between undergreasing and overgreasing the tach drive. And, the lubrication of the cable is also an issue. I found an excellent speedometer cable lube at the local NAPA auto parts store that is doing the job on the cable. It's a light machine oil with graphite in it. Nasty if it leaks out but very effective lube and seems to penetrate well. I have an 84" cable with a lot of bends. Taking the cable loose at both ends periodically and dripping in some cable lube is a part of my regular maintenance program now. I think I made the mistake of putting addtional white litium grease in the angle drive, which eventually caused more drag in the drive than lubrication, especially when it's cold. The third drive was installed about 45 hours ago, and I have't had the needle bobbing like I did with the previous drives. When I installed the latest one, I added no additiona grease beyond what came in the unit. Long story short, if I knew when I was installing the instruments what I know now, I would have gone with the Westach tachometer, particularly the one that uses the generator off the tach drive on the engine. If this angle drive gives me trouble in the future, that's the direction I'm going in. Matt Paxton NX629ML ________________________________________________________________________________
Date: Aug 24, 2012
Hi Rick - I think I did what Oscar said & based it on WW's intakes. 4.5 inches sounds about right. The highest CHT I ever saw was 360. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381703#381703 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Aug 24, 2012
Subject: a little flying---of possible interest
http://www.youtube.com/watch?v=A_y-zSvzGTs Mike C. ________________________________________________________________________________
Date: Aug 24, 2012
Hi Rick, I'm at the hangar changing my oil at the moment and don't have a tape measure but if I take a dollar bill and stand it on end with the end flat on the head where the old cooling shroud bolts on .the top of my eyebrow is at the (R) on the phrase one dollar under George Washington's picture. If that doesn't make since I think 4 to 4 1/2 is about right. Like Kevin my temps at cruise run around 275 to 300 and on climb out on a hot day 350 to 375 Randy Bush P S Kevin I meant every word Sent from my iPhone On Aug 24, 2012, at 8:04 AM, Rick Schreiber wrote: > > I am getting ready to make eyebrows for my corvair and was wondering how high the front of the eyebrow should be for efficient cooling. Those of you that have flying corvairs, how high did you go. I was looking at the eyebrows on a friends A65 powered J3 cub and the cross-sectional area on his eyebrows are about 28 sq. in. That would make the eyebrow on a corvair installation about 4-1/2 inches high. Does that seem about right. > > Rick Schreiber > Valparaiso IN > > > > ________________________________________________________________________________
Date: Aug 24, 2012
Subject: Operation Axel complete!
Hello good people, I am pleased to announce the results of Operation Axel! Your patience in awaiting this announcement is appreciated (I was waiting to receive and process the remaining contributions I knew were still on the way). Thank you on behalf of the organizers of Operation Axel, and most importantly on behalf of Kevin and Shelley, for the outpouring of support, well-wishes, prayers, and overall good karma that you all so generously gave. I am most excited to announce that due to the efforts of 46 contributors we have collected a grand total of $4,025.52! Once again, this unique brotherhood (and sisterhood) of Pietenpol builders, pilots, enthusiasts, and friends has demonstrated how fortunate we all are to be a part of it. Thank you all so very much! I have tonight issued the check electronically from the BoA account used to collect the contributions, and Kevin and Shelley should see it in their mailbox in about a week. I have included a screencap of the payment confirmation below. Since Operation Axel has drawn to a close, we are no longer asking for contributions. If any other contributions do show up in my mailbox after this point they will still be generously accepted and processed as before. Thank you all again, and have a great weekend! Ryan [image: Inline image 1] ________________________________________________________________________________
Date: Aug 24, 2012
VGhhdCdzIG5lYXIhCgpTZW50IHZpYSBzbWFydHBob25lLi4uIkN1eSwgTWljaGFlbCBELiAoR1JD LVJYRDApW1ZhbnRhZ2UgUGFydG5lcnMsIExMQ10iIDxtaWNoYWVsLmQuY3V5QG5hc2EuZ292PiB3 cm90ZTrCoApodHRwOi8vd3d3LnlvdXR1YmUuY29tL3dhdGNoP3Y9QV95LXpTdnpHVHMKwqAKwqAK TWlrZSBDLgrCoArCoAoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBQaWV0ZW5wb2wtTGlzdCBF bWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRv ciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9T dWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2Us IENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAg IC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1BpZXRlbnBvbC1MaXN0Cl8t PQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNh bWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpf LT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAg ICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5 b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1N YXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9jb250cmlidXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0KCg= ________________________________________________________________________________
Subject: Re: Operation Axel complete!
Date: Aug 25, 2012
Nice job Ryan and thank you all for your again generous gifts on behalf of another one of our own. Thanks again I'm sure all contributions will be put to good use. Thank you all, my friends your generosity and support is overwhelming. John Sent from my iPhone On Aug 24, 2012, at 9:58 PM, Operation Axel wrote: > Hello good people, > > I am pleased to announce the results of Operation Axel! Your patience in awaiting this announcement is appreciated (I was waiting to receive and process the remaining contributions I knew were still on the way). > > Thank you on behalf of the organizers of Operation Axel, and most importantly on behalf of Kevin and Shelley, for the outpouring of support, well-wishes, prayers, and overall good karma that you all so generously gave. I am most excited to announce that due to the efforts of 46 contributors we have collected a grand total of $4,025.52! Once again, this unique brotherhood (and sisterhood) of Pietenpol builders, pilots, enthusiasts, and friends has demonstrated how fortunate we all are to be a part of it. Thank you all so very much! > > I have tonight issued the check electronically from the BoA account used to collect the contributions, and Kevin and Shelley should see it in their mailbox in about a week. I have included a screencap of the payment confirmation below. Since Operation Axel has drawn to a close, we are no longer asking for contributions. If any other contributions do show up in my mailbox after this point they will still be generously accepted and processed as before. > > Thank you all again, and have a great weekend! > > Ryan > > > > > > ________________________________________________________________________________
Subject: Total time to build
Date: Aug 24, 2012
Just reviewing the records=85 According to KitLog Pro, at which I tried to be very diligent in my entries, Total Time was 1500.5 hrs. That means it cost me just a little over $10/hr to work on the plane. Breaking it down a little further=85 I spent an average of 6.4 hrs/week (4 =BD yrs, almost to the day). Gary Boothe NX308MB ________________________________________________________________________________
Date: Aug 24, 2012
Rick / Ken, I used the Van der Voort plans, and the attached bead wire process. I'll have to check tomorrow to be sure, but I think I increased the forward dimension by 2". That makes the ears stand a little taller. I also used .025 6061, 'cuz that's what I had on hand. WHAT A WORKOUT! Those ears took 40 hrs to make! Next time, I will use Dead Soft. I'll have cooling info in a couple days...but I also have a Niagra Cooler that has ram air introduced at the back of the cooling ear. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ken Bickers Sent: Friday, August 24, 2012 6:26 AM Subject: Re: Pietenpol-List: eyebrows for Corvair --> I'm not to this stage just yet, but look forward to the suggestions and advice. Ken On Fri, Aug 24, 2012 at 7:04 AM, Rick Schreiber wrote: > --> > > I am getting ready to make eyebrows for my corvair and was wondering > how high the front of the eyebrow should be for efficient cooling. > Those of you that have flying corvairs, how high did you go. I was > looking at the eyebrows on a friends A65 powered J3 cub and the > cross-sectional area on his eyebrows are about 28 sq. in. That would > make the eyebrow on a corvair installation about 4-1/2 inches high. Does that seem about right. > > Rick Schreiber > Valparaiso IN > > ________________________________________________________________________________
Date: Aug 25, 2012
Good job, Ryan! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Operation Axel Sent: Friday, August 24, 2012 6:58 PM Subject: Pietenpol-List: Operation Axel complete! Hello good people, I am pleased to announce the results of Operation Axel! Your patience in awaiting this announcement is appreciated (I was waiting to receive and process the remaining contributions I knew were still on the way). Thank you on behalf of the organizers of Operation Axel, and most importantly on behalf of Kevin and Shelley, for the outpouring of support, well-wishes, prayers, and overall good karma that you all so generously gave. I am most excited to announce that due to the efforts of 46 contributors we have collected a grand total of $4,025.52! Once again, this unique brotherhood (and sisterhood) of Pietenpol builders, pilots, enthusiasts, and friends has demonstrated how fortunate we all are to be a part of it. Thank you all so very much! I have tonight issued the check electronically from the BoA account used to collect the contributions, and Kevin and Shelley should see it in their mailbox in about a week. I have included a screencap of the payment confirmation below. Since Operation Axel has drawn to a close, we are no longer asking for contributions. If any other contributions do show up in my mailbox after this point they will still be generously accepted and processed as before. Thank you all again, and have a great weekend! Ryan Inline image 1 ________________________________________________________________________________
Date: Aug 25, 2012
To all those who gave and all those who gave well wishes many thanks for ma king this effort a success. I am sure this will be a blessing to Kevin and Shelley. This is a great and generous group of people I am proud to be a pa rt. A special thanks to Ryan Mueller for doing all the work. Good job! Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Aug 25, 2012
So who was the cheapskate that contributed 52=A2? Everybody else apparently contributed some kind of multiple of $25. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Operation Axel Sent: Friday, August 24, 2012 9:58 PM Subject: Pietenpol-List: Operation Axel complete! Hello good people, I am pleased to announce the results of Operation Axel! Your patience in awaiting this announcement is appreciated (I was waiting to receive and process the remaining contributions I knew were still on the way). Thank you on behalf of the organizers of Operation Axel, and most importantly on behalf of Kevin and Shelley, for the outpouring of support, well-wishes, prayers, and overall good karma that you all so generously gave. I am most excited to announce that due to the efforts of 46 contributors we have collected a grand total of $4,025.52! Once again, this unique brotherhood (and sisterhood) of Pietenpol builders, pilots, enthusiasts, and friends has demonstrated how fortunate we all are to be a part of it. Thank you all so very much! I have tonight issued the check electronically from the BoA account used to collect the contributions, and Kevin and Shelley should see it in their mailbox in about a week. I have included a screencap of the payment confirmation below. Since Operation Axel has drawn to a close, we are no longer asking for contributions. If any other contributions do show up in my mailbox after this point they will still be generously accepted and processed as before. Thank you all again, and have a great weekend! Ryan Inline image 1 ________________________________________________________________________________
Date: Aug 25, 2012
Yes Ryan, Thank you for giving us all the means to give back to friends in need.- This is one outstanding group of people. - Shad --- On Sat, 8/25/12, helspersew(at)aol.com wrote: From: helspersew(at)aol.com <helspersew(at)aol.com> Subject: Re: Pietenpol-List: Operation Axel complete! Date: Saturday, August 25, 2012, 7:29 AM - To all those who gave and all those who gave well wishes many thanks for ma king this effort a success. I am sure this will be a blessing to Kevin and Shelley. This is a great and generous group of people I am proud to be a pa rt. A special thanks to Ryan Mueller for doing all the work. Good job! Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Aug 25, 2012
Subject: MERFI fly-in today
I am getting ready to blast off for MERFI in Urbana OH in 30 min, hope to s ee another piet or two over there.- I will be flying in with a C-140, and Spacewalker, if they will slow down. - Shad don't archive ________________________________________________________________________________
Date: Aug 25, 2012
Great job Ryan. Well handled and communicated. Maybe I'll make you the CFO of my company. LOL Faith -----Original Message----- From: Operation Axel <operationaxel(at)gmail.com> Sent: Fri, Aug 24, 2012 11:50 pm Subject: Pietenpol-List: Operation Axel complete! Hello good people, I am pleased to announce the results of Operation Axel! Your patience in aw aiting this announcement is appreciated (I was waiting to receive and proce ss the remaining contributions I knew were still on the way). Thank you on behalf of the organizers of Operation Axel, and most important ly on behalf of Kevin and Shelley, for the outpouring of support, well-wish es, prayers, and overall good karma that you all so generously gave. I am m ost excited to announce that due to the efforts of 46 contributors we have collected a grand total of $4,025.52! Once again, this unique brotherhood ( and sisterhood) of Pietenpol builders, pilots, enthusiasts, and friends has demonstrated how fortunate we all are to be a part of it. Thank you all so very much! I have tonight issued the check electronically from the BoA account used to collect the contributions, and Kevin and Shelley should see it in their ma ilbox in about a week. I have included a screencap of the payment confirmat ion below. Since Operation Axel has drawn to a close, we are no longer aski ng for contributions. If any other contributions do show up in my mailbox a fter this point they will still be generously accepted and processed as bef ore. Thank you all again, and have a great weekend! Ryan ________________________________________________________________________________
Date: Aug 25, 2012
Hi Ryan: What an awesome group of people. Thanks for everything you did to make this a success. Bill - Sent: Fri, Aug 24, 2012 11:50 pm > Subject: Pietenpol-List: Operation Axel complete! > > Hello good people, > > I am pleased to announce the results of Operation Axel! Your patience in > awaiting this announcement is appreciated (I was waiting to receive and > process the remaining contributions I knew were still on the way). > > Thank you on behalf of the organizers of Operation Axel, and most > importantly on behalf of Kevin and Shelley, for the outpouring of support, > well-wishes, prayers, and overall good karma that you all so generously > gave. I am most excited to announce that due to the efforts of 46 > contributors we have collected a grand total of $4,025.52! Once again, this > unique brotherhood (and sisterhood) of Pietenpol builders, pilots, > enthusiasts, and friends has demonstrated how fortunate we all are to be a > part of it. Thank you all so very much! > > I have tonight issued the check electronically from the BoA account used > to collect the contributions, and Kevin and Shelley should see it in their > mailbox in about a week. I have included a screencap of the payment > confirmation below. Since Operation Axel has drawn to a close, we are no > longer asking for contributions. If any other contributions do show up in > my mailbox after this point they will still be generously accepted and > processed as before. > > Thank you all again, and have a great weekend! > > Ryan > > > [image: Inline image 1] > > ________________________________________________________________________________
Subject: Re: Total time to build
Date: Aug 25, 2012
Jack; considering what you say you have in materials cost in your airplane and the fact that I bought Scout from Corky essentially new for $15,000, that means Corky and McKenley built it for free and Edwin did all the test flights for free. I think I got a good deal ;o) Moral of the story: buying a completed and flying Piet is a heckuva bargain. They are just SO much fun to build though! -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381798#381798 ________________________________________________________________________________
Subject: FW: First Flight
Date: Aug 25, 2012
List, I just posted this to family, and personal friends. To this list, I wish to add the following: I have not yet flown it, myself, for various reasons. Test pilot, Roy Richardson, flying a Pietenpol for the first time, reported that it flies beautifully, even hands off; this despite what we thought was a malfunctioning ASI. Since he was unsure of his airspeed (turns out he was cruising at 65mph), he tended to be a little conservative, and the engine being a little tight, oil temp was high. More later, as I work thru some stuff. Gary Boothe NX308MB From: Gary Boothe [mailto:gboothe5(at)comcast.net] Sent: Saturday, August 25, 2012 2:59 PM Reinthaler; 'wreinthaler(at)lwsupply.com'; Mary Neal; Natalie Boothe (flygirl5479(at)comcast.net); randy.farmer (randy.farmer(at)att.net); Richard Vetterli; Ryan Boothe; Sara Peitzmeier; Vicki Boothe; Woodymsi(at)aol.com; WilliamTCA(at)aol.com; whotchkiss(at)lwsupply.com; 'Brett Henry (Dryvit)' (brett.henry(at)dryvit.com); 'mbrand(at)lwsupply.com'; 'tstokely(at)lwsupply.com'; cpaterson(at)lwsupply.com; 'anelms(at)lwsupply.com'; 'gblanco(at)lwsupply.com'; 'Mike Studer'; Mike Weaver; lrtiger(at)sbcglobal.net; 'Mark.clough(at)fellertusa.com'; Kevin McDonald; 'jake(at)lightcreteinc.com'; 'cfagundes(at)lwsupply.com'; 'smwaud(at)gmail.com' Subject: First Flight Family & Friends (If you ever expressed an interest in my project, even if you faked interest, you made it to the Family & Friends List!..and, if you have received this circuitously, and think you should have been on the list, my apologies!), Here is a picture taken in 1972 at a fly-in/airshow in Madera, Ca., where I had flown my recently restored Taylorcraft BC12-D (inset). I was 19 years old.and hung-over for the first time (its own bittersweet story!). Bad as my headache was, I wasn't in such poor shape that I couldn't recognize the simple beauty of a Pietenpol, telling myself, "Someday." For those who may not know, this airplane was designed by Bernard Pietenpol in 1927. It has always only existed as a set of plans, by which aviation experimenters have been building Pietenpols around the world for the past 80+ years. Fast forward 40 years, after realizing the futility of staying in aviation and raising a family since 1985, my dream of building & flying that simple little airplane has been finally fulfilled! This airplane is a tribute to my father, a die-hard do-it-yourselfer. The FAA 'N' number, NX308MB, contains his initials, along with the month and year of his passing, which, not without coincidence, is the month and year that I began work on the Pietenpol. I miss you, Dad. FAA airworthiness inspection & certificate was granted on August 8, 2012, and first flight was today, August 25, 2012, by test pilot, Roy Richardson, without incident. Construction is wood and fabric, powered by a Corvair engine and my own hand-carved prop! This initial flight will be followed by 40 hours of solo test flight where I will establish the parameters of the aircraft operation (which is a fancy way of saying, "Stay in the air, when you want to.Land, when & where you want to.) Gary Boothe NX308MB ________________________________________________________________________________
Subject: Re: FW: First Flight
Date: Aug 25, 2012
Congratulations Gary! Ryan Mueller rmueller23(at)gmail.com On Aug 25, 2012, at 5:09 PM, "Gary Boothe" wrote: > List, > > I just posted this to family, and personal friends. To this list, I wish to add the following: > > I have not yet flown it, myself, for various reasons. Test pilot, Roy Richardson, flying a Pietenpol for the first time, reported that it flies beautifully, even hands off; this despite what we thought was a malfunctioning ASI. Since he was unsure of his airspeed (turns out he was cruising at 65mph), he tended to be a little conservative, and the engine being a little tight, oil temp was high. > > More later, as I work thru some stuff=85 > > Gary Boothe > NX308MB ________________________________________________________________________________
Date: Aug 25, 2012
Congratulations Gary; you have a beautiful Piet. Frazier Lake will=C2- be neat this year with three local Piets; yours, Mike and Vics and Charlies. Cheers, Jim B. ________________________________________________________________________________
Date: Aug 25, 2012
What a special day. Congratulations!!! On Aug 25, 2012, at 4:09 PM, "Gary Boothe" wrote: > List, > > I just posted this to family, and personal friends. To this list, I wish t o add the following: > > I have not yet flown it, myself, for various reasons. Test pilot, Roy Rich ardson, flying a Pietenpol for the first time, reported that it flies beauti fully, even hands off; this despite what we thought was a malfunctioning ASI . Since he was unsure of his airspeed (turns out he was cruising at 65mph), h e tended to be a little conservative, and the engine being a little tight, o il temp was high. > > More later, as I work thru some stuff > > Gary Boothe > NX308MB > > From: Gary Boothe [mailto:gboothe5(at)comcast.net] > Sent: Saturday, August 25, 2012 2:59 PM > To: Gail Boothe; Jan Bagnall; Jeff Zember; Jorge Busso; Leigh Ann Reinthal er; 'wreinthaler(at)lwsupply.com'; Mary Neal; Natalie Boothe (flygirl5479@comca st.net); randy.farmer (randy.farmer(at)att.net); Richard Vetterli; Ryan Boothe; Sara Peitzmeier; Vicki Boothe; Woodymsi(at)aol.com; WilliamTCA(at)aol.com; whotch kiss(at)lwsupply.com; 'Brett Henry (Dryvit)' (brett.henry(at)dryvit.com); 'mbrand@ lwsupply.com'; 'tstokely(at)lwsupply.com'; cpaterson(at)lwsupply.com; 'anelms@lwsu pply.com'; 'gblanco(at)lwsupply.com'; 'Mike Studer'; Mike Weaver; lrtiger@sbcgl obal.net; 'Mark.clough(at)fellertusa.com'; Kevin McDonald; 'jake(at)lightcreteinc. com'; 'cfagundes(at)lwsupply.com'; 'smwaud(at)gmail.com' > Subject: First Flight > > Family & Friends (If you ever expressed an interest in my project, even if you faked interest, you made it to the Family & Friends List!..and, if you h ave received this circuitously, and think you should have been on the list, m y apologies!), > > > > Here is a picture taken in 1972 at a fly-in/airshow in Madera, Ca., where I had flown my recently restored Taylorcraft BC12-D (inset). > > > > > > > > > > > > > > > > > > > > > > > I was 19 years oldand hung-over for the first time (its own bitte rsweet story!). Bad as my headache was, I wasn=99t in such poor shape t hat I couldn=99t recognize the simple beauty of a Pietenpol, telling m yself, =9CSomeday=9D For those who may not know, this a irplane was designed by Bernard Pietenpol in 1927. It has always only existe d as a set of plans, by which aviation experimenters have been building Piet enpols around the world for the past 80+ years. > > Fast forward 40 years, after realizing the futility of staying in aviation and raising a family since 1985, my dream of building & flying that simple l ittle airplane has been finally fulfilled! This airplane is a tribute to my f ather, a die-hard do-it-yourselfer. The FAA =98N=99 number, NX30 8MB, contains his initials, along with the month and year of his passing, wh ich, not without coincidence, is the month and year that I began work on the Pietenpol. I miss you, Dad > > > > FAA airworthiness inspection & certificate was granted on August 8, 2012, and first flight was today, August 25, 2012, by test pilot, Roy Richardson, without incident. Construction is wood and fabric, powered by a Corvair eng ine and my own hand-carved prop! This initial flight will be followed by 40 h ours of solo test flight where I will establish the parameters of the aircra ft operation (which is a fancy way of saying, =9CStay in the air, when you want toLand, when & where you want to.) > > Gary Boothe > NX308MB > ________________________________________________________________________________
Date: Aug 25, 2012
Congratulations Gary. It only gets better from here! Randy Bush NX294RB Sent from my iPhone On Aug 25, 2012, at 5:17 PM, Ryan Mueller wrote: > Congratulations Gary! > > Ryan Mueller > rmueller23(at)gmail.com > > > > > On Aug 25, 2012, at 5:09 PM, "Gary Boothe" wrote: > >> List, >> >> I just posted this to family, and personal friends. To this list, I wish t o add the following: >> >> I have not yet flown it, myself, for various reasons. Test pilot, Roy Ric hardson, flying a Pietenpol for the first time, reported that it flies beaut ifully, even hands off; this despite what we thought was a malfunctioning AS I. Since he was unsure of his airspeed (turns out he was cruising at 65mph), he tended to be a little conservative, and the engine being a little tight, oil temp was high. >> >> More later, as I work thru some stuff >> >> Gary Boothe >> NX308MB > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 25, 2012
Thanks, Randy! I have a question for you, but can=99t see your email herecan you contact me off-list? Gboothe5(at)comcast.net Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Robert Bush Sent: Saturday, August 25, 2012 4:16 PM Subject: Re: Pietenpol-List: FW: First Flight Congratulations Gary. It only gets better from here! Randy Bush NX294RB Sent from my iPhone On Aug 25, 2012, at 5:17 PM, Ryan Mueller wrote: Congratulations Gary! Ryan Mueller rmueller23(at)gmail.com On Aug 25, 2012, at 5:09 PM, "Gary Boothe" wrote: List, I just posted this to family, and personal friends. To this list, I wish to add the following: I have not yet flown it, myself, for various reasons. Test pilot, Roy Richardson, flying a Pietenpol for the first time, reported that it flies beautifully, even hands off; this despite what we thought was a malfunctioning ASI. Since he was unsure of his airspeed (turns out he was cruising at 65mph), he tended to be a little conservative, and the engine being a little tight, oil temp was high. More later, as I work thru some stuff Gary Boothe NX308MB ========= >http://www.matronics.com/Navigator?Pietenpol-List ========= cs.com ========= matronics.com/contribution ========= ________________________________________________________________________________
Subject: First Flight of NX308MB
Date: Aug 25, 2012
Better video is forth coming from another source. http://youtu.be/KE1lDlGO_P8 Gary Boothe NX308MB ________________________________________________________________________________
Date: Aug 25, 2012
Spoke too soon=85.47 contributors and $4,275.52. :) Thanks everyone! Ryan Mueller operationaxel(at)gmail.com ________________________________________________________________________________
Date: Aug 25, 2012
Awesome!...=C2- I'm so excited for you.=C2- It actually flies!=C2- I cant' wait to see it for myself.=0A=0A=0AMike Groah=0A=0A=0A=0A=0A_________ _______________________=0A From: Gary Boothe <gboothe5(at)comcast.net>=0ATo: p ietenpol-list(at)matronics.com =0ASent: Saturday, August 25, 2012 3:09 PM=0ASu bject: Pietenpol-List: FW: First Flight=0A =0A=0AList,=0A=C2-=0AI just po sted this to family, and personal friends. To this list, I wish to add the following:=0A=C2-=0AI have not yet flown it, myself, for various reasons. Test pilot, Roy Richardson, flying a Pietenpol for the first time, reporte d that it flies beautifully, even hands off; this despite what we thought w as a malfunctioning ASI. Since he was unsure of his airspeed (turns out he was cruising at 65mph), he tended to be a little conservative, and the engi ne being a little tight, oil temp was high. =0A=C2-=0AMore later, as I wo rk thru some stuff=0A=C2-=0AGary Boothe=0ANX308MB=0A=C2-=0AFro m:Gary Boothe [mailto:gboothe5(at)comcast.net] =0ASent: Saturday, August 25, 2 012 2:59 PM=0ATo: Gail Boothe; Jan Bagnall; Jeff Zember; Jorge Busso; Leigh Ann Reinthaler; 'wreinthaler(at)lwsupply.com'; Mary Neal; Natalie Boothe (fly girl5479(at)comcast.net); randy.farmer (randy.farmer(at)att.net); Richard Vetterl i; Ryan Boothe; Sara Peitzmeier; Vicki Boothe; Woodymsi(at)aol.com; WilliamTCA (at)aol.com; whotchkiss(at)lwsupply.com; 'Brett Henry (Dryvit)' (brett.henry(at)dryv it.com); 'mbrand(at)lwsupply.com'; 'tstokely(at)lwsupply.com'; cpaterson@lwsupply .com; 'anelms(at)lwsupply.com'; 'gblanco(at)lwsupply.com'; 'Mike Studer'; Mike We aver; lrtiger(at)sbcglobal.net; 'Mark.clough(at)fellertusa.com'; Kevin McDonald; 'jake(at)lightcreteinc.com'; 'cfagundes(at)lwsupply.com'; 'smwaud(at)gmail.com'=0ASu bject: First Flight=0A=C2-=0AFamily & Friends (If you ever expressed an i nterest in my project, even if you faked interest, you made it to the Famil y & Friends List!..and, if you have received this circuitously, and think y ou should have been on the list, my apologies!), =0A=C2-=0A=C2-=0A=C2 -=0AHere is a picture taken in 1972 at a fly-in/airshow in Madera, Ca., w here I had flown my recently restored Taylorcraft BC12-D (inset). =0A=C2- =0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2- =0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A=C2-=0A =C2-=0A=C2-=0A=0AI was 19 years oldand hung-over for the first time (its own bittersweet story!). Bad as my headache was, I wasn=99 t in such poor shape that I couldn=99t recognize the simple beauty of a Pietenpol, telling myself, =9CSomeday=9D For those who may not know, this airplane was designed by Bernard Pietenpol in 1927. It has always only existed as a set of plans, by which aviation experimente rs have been building Pietenpols around the world for the past 80+ years. =0A=C2-=0AFast forward 40 years, after realizing the futility of staying in aviation and raising a family since 1985, my dream of building & flying that simple little airplane has been finally fulfilled! This airplane is a tribute to my father, a die-hard do-it-yourselfer. The FAA =98N =99 number, NX308MB, contains his initials, along with the month and year o f his passing, which, not without coincidence, is the month and year that I began work on the Pietenpol. I miss you, Dad=0A=C2-=0A=C2-=0A FAA=C2- airworthiness inspection & certificate was granted on August 8, 2 012, and first flight was today, August 25, 2012, by test pilot, Roy Richar dson, without incident. Construction is wood and fabric, powered by a Corva ir engine and my own hand-carved prop! This initial flight will be followed by 40 hours of solo test flight where I will establish the parameters of t he aircraft operation (which is a fancy way of saying, =9CStay in the air, when you want toLand, when & where you want to.)=0A=C2-=0A Gary Boothe=0ANX308MB ________________________________________________________________________________
Date: Aug 25, 2012
Date: Aug 25, 2012
Gary, As Homer Simpson would say, "Woo-hoo!" Break out the donuts! Congratulations! Darrel (Second try. Looks like the first didn't go through) On 8/25/2012 3:09 PM, Gary Boothe wrote: > > List, > > I just posted this to family, and personal friends. To this list, I > wish to add the following: > > I have not yet flown it, myself, for various reasons. Test pilot, Roy > Richardson, flying a Pietenpol for the first time, reported that it > flies beautifully, even hands off; this despite what we thought was a > malfunctioning ASI. Since he was unsure of his airspeed (turns out he > was cruising at 65mph), he tended to be a little conservative, and the > engine being a little tight, oil temp was high. > > More later, as I work thru some stuff... > > Gary Boothe > > NX308MB > > ________________________________________________________________________________
Subject: Re: First Flight of NX308MB
Date: Aug 25, 2012
Gary. Way to go! Looks and sounds real nice my friend. She is a fine ship as Bernie would say! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381833#381833 ________________________________________________________________________________
Date: Aug 25, 2012
For me as well as others I'm sure, the building journey was fantastic. Could I have bought a project or a completed Piet and saved my labor, certainly but that was not the point. I knew going into this project that my labor was for free, I was building a plane for the sheer enjoyment. Now that the the project is coming to an end after roughly ten years, I would like to start on another. Regards, Rick Schreiber Valparaiso, IN ________________________________________________________________________________
Date: Aug 25, 2012
Wow Gary!....... I cant even imagine how this first flight felt. Congratulations! Regards, Rick Schreiber ________________________________________________________________________________
From: "John Greenlee" <jmgreenlee(at)sbcglobal.net>
Subject: Nicopress tools
Date: Aug 25, 2012
Hello all, When I originally built the Pietenpol, I used a manual swaging tool - I think it is called a Swage-it. It is the one where you tighten some bolts to crush the sleeves. I am interested in getting a bolt-cutter style swaging tool. The only sizes I should need to swage are 1/16, 3/32, and 1/8. I see a lot of previously owned Nicopress tools on ebay. However, I do not know how to identify the correct model number to do what I want to do. These should be relatively plentiful as they are really a telephone company technology. Does anybody have any information and experience on which model to get? Thanks! JMG ________________________________________________________________________________
Date: Aug 25, 2012
Subject: corvair eyebrows
Thanks to Oscar, Kevin, Randy and Gary for the response about the size of the eyebrows for a corvair installation. It looks like 4.5 inches is about the right height. Rick Schreiber Valparaiso, IN ________________________________________________________________________________
Date: Aug 25, 2012
12 step program ... my name is Rick. It has be three days and six hours since I last cut a gusset. On Sat, Aug 25, 2012 at 7:47 PM, Rick Schreiber wrote: > > For me as well as others I'm sure, the building journey was fantastic. Could > I have bought a project or a completed Piet and saved my labor, certainly > but that was not the point. I knew going into this project that my labor was > for free, I was building a plane for the sheer enjoyment. Now that the the > project is coming to an end after roughly ten years, I would like to start > on another. > > Regards, > Rick Schreiber > Valparaiso, IN > > ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Aug 25, 2012
Subject: Tail wheel check out.
Well, this morning we had a small break from high winds and thunderstorms, so I was able to get my tailwheel checkout. The plane was a 1947 Aeronca 7AC Champ with no electrics (and prop and handheld radio) and 65 roaring HP. The instructor, Vern Foster (95 Years Old) has somewhere around 6000 hours of tailwheel time. He started flying in 1939. Checkout took an hour with 8 landings. First thing he did was pull the engine at 30 feet and made me simulate a engine out landing. Then three point landings and wheel landings. Then cross wind TO and landings. The last thing was taxiing with the brakes on hard and the power up. This was to prepare me for landing in very high winds. He said I did well and complemented my instructor (Lonnie Gillespie) on doing a fine job. YA HOO! Blue Skies, Steve "taildragger" D. ________________________________________________________________________________
Date: Aug 25, 2012
Subject: Re: Tail wheel check out.
Way to go, Steve. I bet Vern has some good stories. Cheers, Ken On Sat, Aug 25, 2012 at 8:22 PM, Dortch, Steven D MAJ NG NG NGB wrote: > > Well, this morning we had a small break from high winds and thunderstorms, so I was able to get my tailwheel checkout. > > The plane was a 1947 Aeronca 7AC Champ with no electrics (and prop and handheld radio) and 65 roaring HP. > > The instructor, Vern Foster (95 Years Old) has somewhere around 6000 hours of tailwheel time. He started flying in 1939. > > Checkout took an hour with 8 landings. First thing he did was pull the engine at 30 feet and made me simulate a engine out landing. Then three point landings and wheel landings. Then cross wind TO and landings. The last thing was taxiing with the brakes on hard and the power up. This was to prepare me for landing in very high winds. He said I did well and complemented my instructor (Lonnie Gillespie) on doing a fine job. > > YA HOO! > > Blue Skies, > Steve "taildragger" D. > > ________________________________________________________________________________
Date: Aug 25, 2012
Steve; Good on ya! Maybe if you catch me when I'm down at San Geronimo before I take the wings off of Scout, you can take 'er up! -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381848#381848 ________________________________________________________________________________
Date: Aug 25, 2012
Fantastic, Gary! The only thing better will be when you fly yourself this airplane that you built from scratch. There is NO better feeling in the world, including sex. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Saturday, August 25, 2012 7:40 PM Subject: Pietenpol-List: First Flight of NX308MB Better video is forth coming from another source. http://youtu.be/KE1lDlGO_P8 Gary Boothe NX308MB ________________________________________________________________________________
Date: Aug 25, 2012
Way to go, Gary! Nice to see another shiny new Piet take to the skies. Brodhead in 2013? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381850#381850 ________________________________________________________________________________
Date: Aug 25, 2012
Vern has a great amount of aviation knowledge. He flew corporate and for the airlines. He related that the DC3/C47 was a great plane and after a 50 year break from flying it, He was able to do a greaser landing on his first landing. Describing the technique of holding brakes and using power, he kept a Lockheed Electra full of executives from flipping during a gust front. For 10 minutes, he held brakes, Throttled up, brought the tail up and kept the plane pinned to the tarmac. Then he taxied to takeoff. Great guy, I am very pleased to have his name in my log book. Blue Skies, Steve ----- Original Message ----- From: Ken Bickers <bickers.ken(at)gmail.com> Date: Saturday, August 25, 2012 21:31 Subject: Re: Pietenpol-List: Tail wheel check out. > > Way to go, Steve. I bet Vern has some good stories. Cheers, Ken > > On Sat, Aug 25, 2012 at 8:22 PM, Dortch, Steven D MAJ NG NG NGB > < wrote: > > > > Well, this morning we had a small break from high winds and thunderstorms, so I was able to get my tailwheel checkout. > > > > The plane was a 1947 Aeronca 7AC Champ with no electrics (and prop and handheld radio) and 65 roaring HP. > > > > The instructor, Vern Foster (95 Years Old) has somewhere around 6000 hours of tailwheel time. He started flying in 1939. > > > > Checkout took an hour with 8 landings. First thing he did was pull the engine at 30 feet and made me simulate a engine out landing. Then three point landings and wheel landings. Then cross wind TO and landings. The last thing was taxiing with the brakes on hard and the power up. This was to prepare me for landing in very high winds. He said I did well and complemented my instructor (Lonnie Gillespie) on doing a fine job. > > > > YA HOO! > > > > Blue Skies, > > Steve "taildragger" D. > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 25, 2012
Be careful what you offer. I am moving back to San Antonio this week and it looks like i have a hanger back at San Geronimo. I may get a chance to take you up on this offer. Blue Skies, Steve D ----- Original Message ----- From: taildrags <taildrags(at)hotmail.com> Date: Saturday, August 25, 2012 22:18 Subject: Pietenpol-List: Re: Tail wheel check out. > > Steve; > > Good on ya! Maybe if you catch me when I'm down at San Geronimo before I take the wings off of Scout, you can take 'er up! > > -------- > Oscar Zuniga > Medford/Ashland, OR > Air Camper NX41CC "Scout" > A75 power > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=381848#381848 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Nicopress tools
Date: Aug 25, 2012
Lowes has a tool for pressing sleeves on, you check that one out.[/b] -------- Building steel fuselage aircamper. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381854#381854 ________________________________________________________________________________
Subject: MyKitplane
Date: Aug 25, 2012
I must be barking up the wrong tree cause I still can't get Mykitplane, no matter how many times I try. -------- Building steel fuselage aircamper. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381855#381855 ________________________________________________________________________________
Date: Aug 25, 2012
A BIG Congradulations Gary From Cool. - Shad --- On Sat, 8/25/12, Rick Schreiber wrote: From: Rick Schreiber <lmforge(at)earthlink.net> Subject: Re: Pietenpol-List: FW: First Flight Date: Saturday, August 25, 2012, 9:54 PM > Wow Gary!....... I cant even imagine how this- first flight felt. Congratulations! Regards, Rick Schreiber le, List Admin. ________________________________________________________________________________
Subject: Re: MyKitplane
Date: Aug 26, 2012
Just married!! [IMG]http://i110.photobucket.com/albums/n91/VanDervort/7F9F267F-15EE-4FDD-BEB6-967B5E2DD2A0-2761-0000024B325C0ECB.jpg[/IMG] Sent from my iPhone On Aug 26, 2012, at 12:17 AM, "biplan53" wrote: > > I must be barking up the wrong tree cause I still can't get Mykitplane, no matter how many times I try. > > -------- > Building steel fuselage aircamper. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=381855#381855 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 26, 2012
I believe what your looking for is a Nicopress 64-CGMP. You can get one with a cable cutter which is a little more expensive. New they are around the $280USD from what I have found. I am looking for one also. I have been advised against using the cheaper models but im no expert so take that with a grain of salt. There is one on Ebay right now and has been on there for months. I looked in to it but it has had a hard life and it looks like bolts have been replaced. With all that they want too much for it. I would rather pay a little extra for a new one. Scotty -------- Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Tail and Ribs built...Building control system and about to start fuselage...Corvair engine at Roy's Garage waiting to be modified. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381862#381862 ________________________________________________________________________________
Date: Aug 26, 2012
Congrats! Nice pic.=0A=0A=0A________________________________=0A From: Matth ew =0ATo: "pietenpol-list(at)matronics.com" =0ASent: Sunday, August 26, 2012 2:25 AM=0ASubje ct: Re: Pietenpol-List: MyKitplane=0A =0A--> Pietenpol-List message posted by: Matthew =0A=0AJust married!!=0A=0A=0A[IMG ]http://i110.photobucket.com/albums/n91/VanDervort/7F9F267F-15EE-4FDD-BEB6- 967B5E2DD2A0-2761-0000024B325C0ECB.jpg[/IMG]=0ASent from my iPhone=0A=0AOn Aug 26, 2012, at 12:17 AM, "biplan53" wrote:=0A=0A> =0A> I must be barking- up the wrong tree cause I still can't get Mykitp lane, no matter how many times I try.=0A> =0A> --------=0A> Building steel fuselage aircamper.=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A > =0A> http://forums.matronics.com/viewtopic.php?p=381855#381855=0A> =0A> =- - - - - - - - - - - - - - - -Matt Dralle ======== ________________________________________________________________________________
Date: Aug 26, 2012
Gary, Sweet! A HUGE congratulations to you!! Woow a beautiful bird. You will go t o sleep with a grin on your face! Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sat, Aug 25, 2012 5:10 pm Subject: Pietenpol-List: FW: First Flight List, I just posted this to family, and personal friends. To this list, I wish to add the following: I have not yet flown it, myself, for various reasons. Test pilot, Roy Richa rdson, flying a Pietenpol for the first time, reported that it flies beauti fully, even hands off; this despite what we thought was a malfunctioning AS I. Since he was unsure of his airspeed (turns out he was cruising at 65mph) , he tended to be a little conservative, and the engine being a little tigh t, oil temp was high. More later, as I work thru some stuff Gary Boothe NX308MB From: Gary Boothe [mailto:gboothe5(at)comcast.net] Sent: Saturday, August 25, 2012 2:59 PM r; 'wreinthaler(at)lwsupply.com'; Mary Neal; Natalie Boothe (flygirl5479@comca st.net); randy.farmer (randy.farmer(at)att.net); Richard Vetterli; Ryan Boothe ; Sara Peitzmeier; Vicki Boothe; Woodymsi(at)aol.com; WilliamTCA(at)aol.com; whot chkiss(at)lwsupply.com; 'Brett Henry (Dryvit)' (brett.henry(at)dryvit.com); 'mbra nd(at)lwsupply.com'; 'tstokely(at)lwsupply.com'; cpaterson(at)lwsupply.com; 'anelms@ lwsupply.com'; 'gblanco(at)lwsupply.com'; 'Mike Studer'; Mike Weaver; lrtiger@ sbcglobal.net; 'Mark.clough(at)fellertusa.com'; Kevin McDonald; 'jake@lightcre teinc.com'; 'cfagundes(at)lwsupply.com'; 'smwaud(at)gmail.com' Subject: First Flight Family & Friends (If you ever expressed an interest in my project, even if you faked interest, you made it to the Family & Friends List!..and, if you have received this circuitously, and think you should have been on the list , my apologies!), Here is a picture taken in 1972 at a fly-in/airshow in Madera, Ca., where I had flown my recently restored Taylorcraft BC12-D (inset). I was 19 years oldand hung-over for the first time (its own bitter sweet story!). Bad as my headache was, I wasn=99t in such poor shape that I couldn=99t recognize the simple beauty of a Pietenpol, telling myself, =9CSomeday=9D For those who may not know, thi s airplane was designed by Bernard Pietenpol in 1927. It has always only ex isted as a set of plans, by which aviation experimenters have been building Pietenpols around the world for the past 80+ years. Fast forward 40 years, after realizing the futility of staying in aviation and raising a family since 1985, my dream of building & flying that simple little airplane has been finally fulfilled! This airplane is a tribute to m y father, a die-hard do-it-yourselfer. The FAA =98N=99 number, NX308MB, contains his initials, along with the month and year of his passin g, which, not without coincidence, is the month and year that I began work on the Pietenpol. I miss you, Dad FAA airworthiness inspection & certificate was granted on August 8, 2012, and first flight was today, August 25, 2012, by test pilot, Roy Richardson, without incident. Construction is wood and fabric, powered by a Corvair en gine and my own hand-carved prop! This initial flight will be followed by 4 0 hours of solo test flight where I will establish the parameters of the ai rcraft operation (which is a fancy way of saying, =9CStay in the air, when you want toLand, when & where you want to.) Gary Boothe NX308MB ________________________________________________________________________________
Date: Aug 26, 2012
If memory serves the holes are lettered and I believe I use the M hole for my 1/8 inch cables. Here is a table that shows what to use for each size. http://nicopress.com/C2.htm#_Hlk1143190811,351,404,0,,Nicopress Copper & Zinc Plated Just make sure you get the tool to check the fitting after it is swaged. I bought my off ebay used but from what I understand they are available in the wire rope section at some stores like lowas and home depot. ---- John Greenlee wrote: > Hello all, When I originally built the Pietenpol, I used a manualswaging tool I think it is called a Swage-it. It is the one where youtighten some bolts to crush the sleeves. I am interested in getting abolt-cutter style swaging tool. The only sizes I should need to swage are1/16, 3/32, and 1/8. I see a lot of previously owned Nicopress tools on ebay.However, I do not know how to identify the correct model number to do what Iwant to do. These should be relatively plentiful as they are really atelephone company technology. Does anybody have any information and experienceon which model to get? Thanks! ________________________________________________________________________________
Date: Aug 26, 2012
Congrats, Gary!!! Kevin & Shelley -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381893#381893 ________________________________________________________________________________
Subject: Thank you from Kevin & Shelley
Date: Aug 26, 2012
We're hard pressed to express our appreciation to those of you who contributed to Operation Axel. Your generosity is overwhelming. Thank you. If you look at the number of contributors and the amount of money contributed, the average donation is substantial. Given what we know about bell curves, some of you were extraordinarily generous. Again, thank you. Thanks to John Recine for the suggestion and particularly to Ryan Mueller for doing the leg work. Both good friends! We have decent health insurance, but this event still won't be cheap. We'd like you to know what your donations accomplished: - You got FBG back to her hangar, - You got us back home, - You've bought all the new wing spars and longerons:), - You paid the rockstars at Brodhead Fire Department their fee for coming to get my broken butt out of the FBG safely. All these expenses were out of pocket. We owe you. Not sure how to pay you back except to feed you spaghetti with joy and love in the coming years. Please make sure you contact us when you come through Austin so we can show you love here as well. A note of thanks to those of you who have e-mailed, called, prayed, Facebooked, sent gifts, visited (30 visitors in the hospital in Madison!!!!), and given other help. John Hoffman and Susan Rees were Shelley's lifeline and support system in Madison. Jim Markle has been extraordinary in several ways. Shelley's ex, Dammit-Jim, my husband-in-law, came to Madison, got the boy and the rental van and took them both back to Austin. We've received several offers of parts and pieces. Thank you all for your generosity. I haven't contacted everyone but I will. We love you! Kevin & Shelley -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381896#381896 ________________________________________________________________________________
Date: Aug 27, 2012
Subject: Gary Boothe
Gary,=0ACongratulations. Somehow I dumped the list from the 25th so I' am a little behind. Can you tell me how to get to the video? It must be a proud moment for you as you move to the next phase of enjoyment. =0A-=0AJoe Sw ithin=0AMorris, IL=0AHunting and Gathering Phase- ________________________________________________________________________________
Subject: Re: Piper Parts Fore Sale
Date: Aug 27, 2012
Seller never contacted me ..... O-well. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381938#381938 ________________________________________________________________________________
Subject: NX308MB Video
Date: Aug 27, 2012
Here's a much better video of the first flight, thanks to fellow airport bum, Ken Schwartz: http://youtu.be/9QoayV-MSPY My first flight is still a couple days away. Thanks, Ken!! Gary Boothe NX308MB ________________________________________________________________________________
Date: Aug 27, 2012
Beautiful, Gary! Looks like Christmas came 4 months early for you. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Monday, August 27, 2012 8:07 PM Subject: Pietenpol-List: NX308MB Video Here's a much better video of the first flight, thanks to fellow airport bum, Ken Schwartz: http://youtu.be/9QoayV-MSPY My first flight is still a couple days away. Thanks, Ken!! Gary Boothe NX308MB ________________________________________________________________________________
Date: Aug 27, 2012
Didn't know we were supposed to work so hard for Christmas presents, Jack! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Monday, August 27, 2012 5:17 PM Subject: RE: Pietenpol-List: NX308MB Video Beautiful, Gary! Looks like Christmas came 4 months early for you. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Monday, August 27, 2012 8:07 PM Subject: Pietenpol-List: NX308MB Video Here's a much better video of the first flight, thanks to fellow airport bum, Ken Schwartz: http://youtu.be/9QoayV-MSPY My first flight is still a couple days away. Thanks, Ken!! Gary Boothe NX308MB http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Personal Recovery at 1 Month
Date: Aug 27, 2012
Shelley=3B I fully understand your terse reply=2C "maybe not"... meaning=2C "when pigs fly!" as far as Kevin ferrying my airplane halfway across the country. Yo u need to understand that I just had to throw that out there =3Bo) My best friend up here in Oregon is a guy who will try anything on a dare=2C and m ore often than not we measure the daring-ness of a thing by asking ourselve s "is it something Mark might try?" However=2C it's that kind of attitude that has brought Mark through knee surgery=2C shoulder surgery=2C countless tumbles and scrapes=2C his wife leaving him=2C etc. etc.- and still loving life and staying younger than his age might indicate. So it is with Kevin - there has to be a plate for him to step up to=2C or he won't even feel li ke swinging at the ball. He swung =3Bo) There are others who have swung=3B most of us didn't have bandages or broke n bones in the mix=2C but a few have. Mostly it was just badly damaged air planes=2C and it is so difficult to look at your crashed handiwork and wond er if it's even worth thinking about starting over on it. Ask Gardiner "ai rlion" Mason and others who had to look at their pride and joy in a heap=2C and then pick through the remains of their airplanes and the ruins of thei r personal resolve. Heck=2C I had to look at Scout sitting in the corner o f a hangar all busted up and bent=2C and wondered if the airplane would eve r fly again or if I should just part it out and start building a widened=2C lengthened=2C electrified=2C higher-horsepower=2C instrumented=2C shiny pa inted=2C new Piet instead of putting heart and soul into the banged-up mess that I was looking at. The fact that 41CC is still in the FAA's books and still flying strong=2C should provide the answer. It's a good sign that Kevin took a swing at my wild pitch=2C but it's an ev en better sign that you put a stop to it =3Bo) I promise I won't tempt fat e again=2C or at least if I do I'll be sure to add a big *wink-wink* so you 'll know I'm not serious. Oscar Zuniga Air Camper NX41CC=2C "Scout" Medford=2C OR ________________________________________________________________________________
Subject: Re: NX308MB Video
Date: Aug 27, 2012
Billy can't wait to see it at Brodhead too. The list is growing, Gary. You have about 11 months to get your BFR, and to fly off the 40 hours... -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381966#381966 ________________________________________________________________________________
Date: Aug 27, 2012
Very very cool Gary! Second best feeling only to when you actually get to fly it yourself! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381969#381969 ________________________________________________________________________________
Date: Aug 28, 2012
I am sorry about that. He did email me to thank me for giving him your information. Perhaps he already sold the parts? Either way, no excuse. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 28, 2012
Gorgeous airplane Gary. I never really got to appreciate all the unique fea tures of this aircraft. Beautiful!! Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Mon, Aug 27, 2012 7:13 pm Subject: Pietenpol-List: NX308MB Video Here=99s a much better video of the first flight, thanks to fellow ai rport bum, Ken Schwartz: http://youtu.be/9QoayV-MSPY My first flight is still a couple days away Thanks, Ken!! Gary Boothe NX308MB ________________________________________________________________________________
Date: Aug 28, 2012
SnVzdCBsaWtlIHRoZSBidWlsZGVyL293bmVyLW9wZXJhdG9yIHlvdXIgdmlkZW8gb2YgeW91ciBm aXJzdCBmbGlnaHQgd2FzIHJlYWxseSBjbGFzc3kgR2FyeS4NCldheSB0byBnbyBpbiBhbGwgcmVn YXJkcyBhbmQgbXVjaCByZXNwZWN0IGFuZCBhZG1pcmF0aW9uIHRvIHlvdSwgeW91ciBzb24sIGFu ZCB5b3VyIHRlc3QgcGlsb3QhDQoNCk1pa2UgQy4NCg0KDQo ________________________________________________________________________________
Date: Aug 28, 2012
Awesome wings Gary! Looking forward to hearing your first hand flight report. -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381992#381992 ________________________________________________________________________________
Date: Aug 28, 2012
That is okay. If he still has them, I am still interested. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381993#381993 ________________________________________________________________________________
Date: Aug 28, 2012
Copy. I'll remind him. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
Subject: Straight Exhaust
Crew, I am ready to make my exhaust pipes. I am leaning towards making four straight pipes. (Maybe angled some or a small bend...)- I would prefer s tainless... My questions are: Diameter? Wall thickness? Minimal length? Flange thickness? (or should I buy?) I'll need heat muff ideas as well. Any other suggestions appreciated! Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
Michael, Heat muff will be a challenge, but not impossible. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 29, 2012 6:50 AM Subject: Pietenpol-List: Straight Exhaust Crew, I am ready to make my exhaust pipes. I am leaning towards making four straight pipes. (Maybe angled some or a small bend...) I would prefer stainless... My questions are: Diameter? Wall thickness? Minimal length? Flange thickness? (or should I buy?) I'll need heat muff ideas as well. Any other suggestions appreciated! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
Gary, do you have any material inside the muff, or did you just wrap the pipe only as shown in the picture? Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
Continental A65's use 1-1/2" diameter exhaust stacks. Lycomings use 1-3/4". For Stainless most use .035" wall. I would buy the flanges from ACS. Be sure you shield the inside of the tubing during the welding process. The argon from the TIG torch will shield the exterior of the weld but with such thin material the inside of the tube will be nearly as hot and unshielded unless you make provisions for it. Best way is to fill the tube with argon and plug the ends, then weld before the argon can leak out. To tell when the tube is full of argon, if you can stick a lit match inside the tube and it stays lit you still have oxygen in there. If you do not shield the tube interior, the exhaust system will crack in the first 50 hours (ask me how I know). Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 29, 2012 9:50 AM Subject: Pietenpol-List: Straight Exhaust Crew, I am ready to make my exhaust pipes. I am leaning towards making four straight pipes. (Maybe angled some or a small bend...) I would prefer stainless... My questions are: Diameter? Wall thickness? Minimal length? Flange thickness? (or should I buy?) I'll need heat muff ideas as well. Any other suggestions appreciated! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: Straight Exhaust
Date: Aug 29, 2012
Mike, 502Rocket has these stainless wraps on each rear pipe. They meet at a Y-connector then feed the carb heat box. I can take some detailed pictures this weekend when I am out at the hangar if you are interested. The straight pipes are good 'n loud too. Mikee told me when I made my arrival at Brodhead this year he could hear me for a bit before I popped over the trees. -john- > > > Crew, I am ready to make my exhaust pipes. I am leaning towards making four straight pipes. (Maybe angled some or a small bend...) I would prefer stainless... > > My questions are: > > Diameter? > Wall thickness? > Minimal length? > Flange thickness? (or should I buy?) > > I'll need heat muff ideas as well. > > Any other suggestions appreciated! > > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > ________________________________________________________________________________
Date: Aug 29, 2012
Understood Jack, thanks. I have made an internal purge line for some other SS welding I have done. On these larger tubes, I plan to plug one end and leave a very small hole. The other will be plugged, save for the inlet of the purge line. The purge can be set to supply a low flow through the entire SS tube. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
Thanks Gary. Pictures are great, I am interested in whatever you want to share. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
I made new straight stacks for my plane a year or two ago. I used these flanges from ACS: http://www.aircraftspruce.com/catalog/eppages/steelexauststackflanges.php I just bought the pipe from a local exhaust shop. It is 1.5", only one size will fit the flanges. Mine are about 15" long, I just made them long enough that I would be able to secure a heat muff. I used mild steel (not stainless) since I intended to ceramic coat them. I had them ceramic coated by a local shop and they look great (about $100). Easy to clean and they won't corrode or deteriorate at all for years. They look great but the ceramic coating isn't a very authentic look if you are going for period correctness. I have an awkward affinity for shiny metal and my plane isn't period correct so that is what I did. :) Pictures: http://www.wotelectronics.com/flying/salt/DSC_0620.JPG http://www.wotelectronics.com/flying/salt/DSC_0619.JPG (It has a wood prop now which looks much better) :) Steve Ruse Norman, OK On 2012-08-29 08:50, Michael Perez wrote: > Crew, I am ready to make my exhaust pipes. I am leaning towards making four straight pipes. (Maybe angled some or a small bend...) I would prefer stainless... > > My questions are: > > Diameter? > Wall thickness? > Minimal length? > Flange thickness? (or should I buy?) > > I'll need heat muff ideas as well. > > Any other suggestions appreciated! > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > HTTP://WWW.MATRONICS.COM/CONTRIBUTION ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Aug 29, 2012
John H. actually sounded like an 0-200 on a C-150 approaching from the Ea st of Brodhead and it sounded GREAT. I could hear him coming for a long time. Very unique sound to John's setup and I think the wind ca rried his engine sound nicely to Brodhead from his approach. His hands were freezing when I shook hands with him. Down low on the groun d it was fairly comfortable but up a few hundred feet John and other pilots that day said it was downright chilly! ________________________________________________________________________________
Date: Aug 29, 2012
Thanks John. Feel free to send me whatever pictures you like. At this point I am just gathering intel. and trying to decide how to make everything. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
Steve, I am considering using mild steel and ceramic coating!- Years ago I had the headers of my GTO coated at Jet Hot. They look today just as new as they did then. Nothing on my plane is "period correct" so coated pipes are a non-event... Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com =0A ________________________________________________________________________________
Date: Aug 29, 2012
Michael, for my first exhaust system I used stainless flanges, straight stacks and curves from Aircraft Spruce. They worked great for the first 40 hours then began cracking due to the lack of shielding during welding as mentioned before. I cut the pieces using a "Joint-Jigger" and fitted them in place using scraps of sheet steel and hose clamps. Here is a picture of the Joint-Jigger setup: And then test-fitting the cut: After it cracked 3 times I replaced it with a plain carbon steel setup which I've been flying with ever since. No ceramic coating, I just beadblast it and paint it with clear VHT paint every 3 years or so. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 29, 2012 12:28 PM Subject: Re: Pietenpol-List: Straight Exhaust Steve, I am considering using mild steel and ceramic coating! Years ago I had the headers of my GTO coated at Jet Hot. They look today just as new as they did then. Nothing on my plane is "period correct" so coated pipes are a non-event... Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
Did you bend the SS yourself Jack?- What type SS did you use?- Some wel d/machine better and others have better corrosion/heat tolerance.-- (Wh ich I am sure you already know, as do others...), ACS sells 321 SS tube, bu t wow...very, very pricey! I have 304, maybe 316 handy, but the wall is .065 and I am not sure either one would be suitable for this task.- I believe 316 is quite a bit harder to bend then 304...if I- were to decide on bends... This is all good stuff, keep it coming! Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
I bought pre-bent sections from ACS. I thought it was 304, but it might have been 321. I don't remember - it was 10 years ago. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 29, 2012 1:22 PM Subject: RE: Pietenpol-List: Straight Exhaust Did you bend the SS yourself Jack? What type SS did you use? Some weld/machine better and others have better corrosion/heat tolerance. (Which I am sure you already know, as do others...), ACS sells 321 SS tube, but wow...very, very pricey! I have 304, maybe 316 handy, but the wall is .065 and I am not sure either one would be suitable for this task. I believe 316 is quite a bit harder to bend then 304...if I were to decide on bends... This is all good stuff, keep it coming! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Aileron Capstrip
Date: Aug 29, 2012
I've slightly exaggerated the position of the cap strip on the aileron spar to demonstrate how it will not be on the same plane as the aileron spars if not shaped. Did those of you using the piano hinge shape this cap strip so the hinge will lay flush? Thanks -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382085#382085 Attachments: http://forums.matronics.com//files/dsc07696_131.jpg ________________________________________________________________________________
Subject: Re: Aileron Capstrip
Date: Aug 29, 2012
John your hinge will be inline with the top of the capstrip Jack Textor Sent from my iPad On Aug 29, 2012, at 2:38 PM, "John Francis" wrote: > > I've slightly exaggerated the position of the cap strip on the aileron spar to demonstrate how it will not be on the same plane as the aileron spars if not shaped. Did those of you using the piano hinge shape this cap strip so the hinge will lay flush? > > Thanks > > -------- > John Francis > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382085#382085 > > > > > Attachments: > > http://forums.matronics.com//files/dsc07696_131.jpg > > > > > > > ________________________________________________________________________________
Subject: Hinge
Date: Aug 29, 2012
Like this http://www.textors.com/Ailerons_002.jpg Jack Textor Sent from my iPad ________________________________________________________________________________
Date: Aug 29, 2012
Mild steel pipes ceramic coated, holding up after 150 hours. Heat muff seems to be adequate. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382092#382092 Attachments: http://forums.matronics.com//files/dsc00315_855.jpg ________________________________________________________________________________
Date: Aug 29, 2012
Thanks Jack and I understand what you are saying. When I cut out the aileron I will move the hinge flush to the top of the cap strip. But, the cap strip, when glued on without shaping, will not be flush with the sides of the aileron spars because the aileron spars are cut on top at an angle other than 90 degrees. I new this was going to be hard to explain and that is why I drew the box on the image. Clear as mud??? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382094#382094 ________________________________________________________________________________
Date: Aug 29, 2012
Thanks Jack and I understand what you are saying. When I cut out the aileron I will move the hinge flush to the top of the cap strip. But, the cap strip, when glued on without shaping, will not be flush with the sides of the aileron spars because the aileron spars are cut on top at an angle other than 90 degrees. I new this was going to be hard to explain and that is why I drew the box on the image. Clear as mud??? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382095#382095 ________________________________________________________________________________
Date: Aug 29, 2012
John, You would need to rip those strips wider than the spars, then rasp flat with the spar after the glue sets. Gary ------Original Message------ From: John Francis Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Aileron Capstrip Sent: Aug 29, 2012 2:33 PM Thanks Jack and I understand what you are saying. When I cut out the aileron I will move the hinge flush to the top of the cap strip. But, the cap strip, when glued on without shaping, will not be flush with the sides of the aileron spars because the aileron spars are cut on top at an angle other than 90 degrees. I new this was going to be hard to explain and that is why I drew the box on the image. Clear as mud??? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382094#382094 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Aug 29, 2012
Michael, I bought 'U-Bends' from Magnum Force, www.magnumforce.com, or http://www.magnumforce.com/store/results.asp?CategoryID=29. These are mild steel, but they sure make the process easy! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 29, 2012 9:28 AM Subject: Re: Pietenpol-List: Straight Exhaust Steve, I am considering using mild steel and ceramic coating! Years ago I had the headers of my GTO coated at Jet Hot. They look today just as new as they did then. Nothing on my plane is "period correct" so coated pipes are a non-event... Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 29, 2012
John When you install the aileron spar hold it back the thickness of the piano hinge so the aileron trailing edge lines up with the wing after you install the piano hinge. This should give you a little room between the aileron spar and the vertical plank in the wing. When you cut out the aileron, cut the cap strip flush with the vertical plank in the wing. This should leave enough cap strip overhanging to sand at an angle flush with the aileron spar. You will also need to add filler strips between the cap strips. These you sand flush with the spars so when the piano hinge is flush with the top of the aileron it will lay flush against the spar. http://www.westcoastpiet.com/images/Chris%20Tracy/images/IMG_0222a_9.JPG -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382101#382101 ________________________________________________________________________________
Date: Aug 29, 2012
Thanks all, I got it now. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382106#382106 ________________________________________________________________________________
Date: Aug 29, 2012
Mike, Check out JEGS high performance (Race shop mail order at jegs.com) Th ey have a lot of mandral bends, J bends, U bends etc.=C2- That is where w e got our stainless for the 1st exaust, and where I bought the mild steel j bends for the one that is on there now.=C2- They have quite a bit of exa ust tubing that is made in the USA. =C2- Shad --- On Wed, 8/29/12, Jack Phillips wrote: From: Jack Phillips <pietflyr(at)bellsouth.net> Subject: RE: Pietenpol-List: Straight Exhaust Date: Wednesday, August 29, 2012, 3:19 PM I bought pre-bent sections from ACS.=C2- I thought it was 304, but it mig ht have been 321. =C2-I don=99t remember =93 it was 10 years ago. =C2- Jack Phillips NX899JP Smith Mountain Lake, Virginia =C2- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, August 29, 2012 1:22 PM Subject: RE: Pietenpol-List: Straight Exhaust =C2- Did you bend the SS yourself Jack?=C2- What type SS did you use?=C2- So me weld/machine better and others have better corrosion/heat tolerance.=C2 -=C2- (Which I am sure you already know, as do others...), ACS sells 32 1 SS tube, but wow...very, very pricey! I have 304, maybe 316 handy, but the wall is .065 and I am not sure either one would be suitable for this task.=C2- I believe 316 is quite a bit har der to bend then 304...if I=C2- were to decide on bends... This is all good stuff, keep it coming! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com =C2- =C2-http://www.matronics.com/Navigator?Pietenpol-Listhttp://forum s.matronics.comhttp://www.matronics.com/contribution =C2- ________________________________________________________________________________
Subject: Re: "...you must be proud!"
Date: Aug 29, 2012
I'm proud to be associated with such a fine group of people - most of whom I have never met - who are enjoying so many of the same life experiences around building a plane of this era...... Thx Gary, very well written......... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382126#382126 ________________________________________________________________________________
Date: Aug 30, 2012
Subject: New Fabric
http://www.oracover.de/index.php/katalog/artikelinfo/10472-1-show-oratex_60 00_-_width_900_mm_lenght_1_m.html=0A-=0AI noticed Oracover now has fabric for full size aircraft (at least Pietenpol size)=0A-=0ANo dope, silver o r finsh color required, just glue on shrink and done.=0A-=0AJust like a m odel airplane.=0AThe model airplane market must be drying up for them, to s tart marketing to the experimental market.=0A-=0AWho wants to be the firs t to try this ?=0A-=0AFYI, I do not endorse this in anyway, just thought the information is interesting.=0A-=0AHans=0A-=0ANX15KV ________________________________________________________________________________
Date: Aug 30, 2012
Subject: Re: tailwheel spring
The first couple pictures gives you a little idea on my custom tail wheel s et up. The last two pictures shows that I machined down the bolt head to a thinner size, drilled out the length of the bolt and cross drilled it and t he nut for the cotter pin.- The tail assembly is very light weight. 4" wh eel from ACS. I bent the "A" arm to align the spring better and to be paral lel with the ground while sitting. Extensive details and procedures explained in my HINT Video.- I have all the dimensional prints as well...if interested. Not flight tested...yet. Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Aug 30, 2012
Subject: Re: New Fabric
Hans, do you have a web site for Oracover? In a message dated 8/30/2012 9:47:45 A.M. Eastern Daylight Time, nx15kv(at)yahoo.com writes: _http://www.oracover.de/index.php/katalog/artikelinfo/10472-1-show-oratex_60 00_-_width_900_mm_lenght_1_m.html_ (http://www.oracover.de/index.php/katalog/artikelinfo/10472-1-show-oratex_6000_-_width_900_mm_lenght_1_m.html) I noticed Oracover now has fabric for full size aircraft (at least Pietenpol size) No dope, silver or finsh color required, just glue on shrink and done. Just like a model airplane. The model airplane market must be drying up for them, to start marketing to the experimental market. Who wants to be the first to try this ? FYI, I do not endorse this in anyway, just thought the information is interesting. Hans NX15KV (http://www.matronics.com/Navigator?Pietenpol-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 30, 2012
I thought I did.=0A-=0ABut here it is again:=0A-=0Ahttp://www.oracover. de/downloads/Product_Information/Product-Information_2010_engl.pdf=0A=0AHan s=0A-=0ANX15KV =0A=0A________________________________=0A From: "SENTUCHOW S(at)aol.com" =0ATo: pietenpol-list(at)matronics.com =0ASent: Thursday, August 30, 2012 9:55 AM=0ASubject: Re: Pietenpol-List: New Fabri c=0A =0A=0A =0AHans, do you have a web site for Oracover? =0A=0AIn a messa ge dated 8/30/2012 9:47:45 A.M. Eastern Daylight Time, =0Anx15kv(at)yahoo.com writes: =0Ahttp://www.oracover.de/index.php/katalog/artikelinfo/10472-1-sho w-oratex_6000_-_width_900_mm_lenght_1_m.html- =0A>I noticed Oracover now has fabric for full size aircraft (at least Pietenpol size) =0A>=0A>No dop e, silver or finsh color required, just glue on shrink and done. =0A>=0A>J ust like a model airplane. =0A>The model airplane market must be drying up for them, to start marketing to the experimental market. =0A>=0A>Who wants to be the first to try this ? =0A>=0A>FYI, I do not endorse this in anyway , just thought the information is interesting. =0A>=0A>Hans =0A>=0A>NX15KV =0A>href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.m atronics.com/Navigator?Pietenpol-List s.matronics.com/">http://forums.matro nics.com=0Ap://www.matronics.com/contribution">http://www.matronics.com/con ===================== ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Date: Aug 30, 2012
I ran my hinge all the way up so that the "knuckle" was even with the top of the capstrip. I did all this after the aileron was cut away from the wing. Yes, the filler capstrip was shaped so that the hinge would lie flat. The filler capstrip was moved forward so that the top-forward edge was even with the front of the sloped side of the aileron spar. Clear as mud? C ----- Original Message ----- From: "John Francis" <Mrkringles(at)msn.com> Sent: Wednesday, August 29, 2012 3:38 PM Subject: Pietenpol-List: Aileron Capstrip > > I've slightly exaggerated the position of the cap strip on the aileron > spar to demonstrate how it will not be on the same plane as the aileron > spars if not shaped. Did those of you using the piano hinge shape this > cap strip so the hinge will lay flush? > > Thanks > > -------- > John Francis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382085#382085 > > > Attachments: > > http://forums.matronics.com//files/dsc07696_131.jpg > > > ________________________________________________________________________________
Date: Aug 30, 2012
Mike: I use scrap SS 1-1/2" OD that is used for milking machines, it is available in all lengths and 90 Degree bends that can be cut and welded to any angle required. There is piles of this type of Stainless West of Hartford Airport Wisconsin, If interested when you are ready and I will get the fellow pilot's name and contact info for you, Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382162#382162 ________________________________________________________________________________
Date: Aug 30, 2012
I would appreciate that information as soon as you can get it to me...thanks! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 30, 2012
Subject: Full Tail Wheel Disclosure! (Almost...)
Here are a few more details on my tail wheel mods.: - I never did like the idea of squishing the tubes on the tail wheel "A" arm where they attach to the fuselage brackets.- I did not like the fact that this now squished, thin area-gets a bolt brazed to-it, uses a cotter p in-and has to somehow handle the side loads put on it.- Further more, I did not like the idea of having-four holes drilled into the lower longer on, two horizontally and-two vertically, in very, very close proximity to each other. (Hole edge spacing) - So, I made my tube ends like I did for the control sticks. (Picture1 and 2) - -Picture 3 shows my template and brackets made to go around the longeron, and have two bolts run all the way through. - Picture 4 shows these brackets in place on the fuselage. Plywood is between the soft spruce and brackets. - Picture 5 shows how the "A" arm fits into these brackets. - My tubes are 5/8" .049" wall. - Flight test will show if all this was worth the effort... - Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 30, 2012
Subject: Re: Full Tail Wheel Disclosure! (Almost...)
From: Andrew Eldredge <andrew.eldredge(at)gmail.com>
On thing about the a-arm attachment is that the axes of the pivoting bolts do not line up naturally. The squished tube solution mitigates this somewhat because the attachment is "single point" on each side. It seems your solution might introduce some binding unless you made some effort to line up the bolt axes, but perhaps the angular travel is not enough to substantially exercise that pivot. I am curious to know how that works out. I do like that you have the attach point away from the truss junction. The bolting of of that fitting seemed a bit clunky. Andrew Eldredge Provo, UT On Thu, Aug 30, 2012 at 5:26 PM, Michael Perez wrote: > Here are a few more details on my tail wheel mods.: > > I never did like the idea of squishing the tubes on the tail wheel "A" arm > where they attach to the fuselage brackets. I did not like the fact that > this now squished, thin area gets a bolt brazed to it, uses a cotter > pin and has to somehow handle the side loads put on it. Further more, I > did not like the idea of having four holes drilled into the lower longeron, > two horizontally and two vertically, in very, very close proximity to each > other. (Hole edge spacing) > > So, I made my tube ends like I did for the control sticks. (Picture1 and 2) > > Picture 3 shows my template and brackets made to go around the longeron, > and have two bolts run all the way through. > > Picture 4 shows these brackets in place on the fuselage. Plywood is > between the soft spruce and brackets. > > Picture 5 shows how the "A" arm fits into these brackets. > > My tubes are 5/8" .049" wall. > > Flight test will show if all this was worth the effort... > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > ________________________________________________________________________________
Date: Aug 31, 2012
You are correct Andrew, as the spring compresses and the A arm swings towar ds the fuselage, the angle on the bolt tubes changes.- I was able to cons truct mine to minimize the binding at these locations.- It is only at the extreme end of travel, where the spring is almost fully compressed, that t here is any sign of binding.- In my mind, it is not going to be an issue, considering how often the gear gets compressed to that extreme. Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com =0A ________________________________________________________________________________
Date: Aug 31, 2012
I installed bronze bushings in the 2 a-arm attach-fittings (The ones bolt ed to the lower longeron).- I seem to have to change them almost once a y ear.- The holes in the fuse. fittings were getting sloppy so I figured I' d better do something so we didn't have to cut off fabric to install new fi ttings.- They probably wear fast due to flying off of grass almost exclus ively, and having a very small tailwheel.- What you say makes sense, abou t the binding, and the angle/ misalignment with compression of the t/w spri ng assembly.- Mabey in 5-10 years if and when I recover the piet, I will try to "Improve" some of those types of things, but untill then I will spen d the $3 per year and put new busings in , and keep flying untill the crank snaps. - Waiting on the remains of Issac to soak my weekend, Shad --- On Fri, 8/31/12, Michael Perez wrote: From: Michael Perez <speedbrake(at)sbcglobal.net> Subject: Re: Pietenpol-List: Full Tail Wheel Disclosure! (Almost...) Date: Friday, August 31, 2012, 9:11 AM You are correct Andrew, as the spring compresses and the A arm swings towar ds the fuselage, the angle on the bolt tubes changes.- I was able to cons truct mine to minimize the binding at these locations.- It is only at the extreme end of travel, where the spring is almost fully compressed, that t here is any sign of binding.- In my mind, it is not going to be an issue, considering how often the gear gets compressed to that extreme. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 31, 2012
On NX18235 we installed rod end bearings at the A-arm ends. No binding and no wear. Greg Cardinal ----- Original Message ----- From: shad bell To: pietenpol-list(at)matronics.com Sent: Friday, August 31, 2012 7:50 PM Subject: Re: Pietenpol-List: Full Tail Wheel Disclosure! (Almost...) I installed bronze bushings in the 2 a-arm attach fittings (The ones bolted to the lower longeron). I seem to have to change them almost once a year. The holes in the fuse. fittings were getting sloppy so I figured I'd better do something so we didn't have to cut off fabric to install new fittings. They probably wear fast due to flying off of grass almost exclusively, and having a very small tailwheel. What you say makes sense, about the binding, and the angle/ misalignment with compression of the t/w spring assembly. Mabey in 5-10 years if and when I recover the piet, I will try to "Improve" some of those types of things, but untill then I will spend the $3 per year and put new busings in , and keep flying untill the crank snaps. Waiting on the remains of Issac to soak my weekend, Shad --- On Fri, 8/31/12, Michael Perez wrote: From: Michael Perez <speedbrake(at)sbcglobal.net> Subject: Re: Pietenpol-List: Full Tail Wheel Disclosure! (Almost...) To: pietenpol-list(at)matronics.com Date: Friday, August 31, 2012, 9:11 AM You are correct Andrew, as the spring compresses and the A arm swings towards the fuselage, the angle on the bolt tubes changes. I was able to construct mine to minimize the binding at these locations. It is only at the extreme end of travel, where the spring is almost fully compressed, that there is any sign of binding. In my mind, it is not going to be an issue, considering how often the gear gets compressed to that extreme. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com " rel=nofollow target=_blank>http://www.matronics.com/Navigator?Pietenpol-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 01, 2012
The contact that I have for SS . Joel Gehring Cell : 262-224-5316 Email: Ask for Joel He will also be at Brodhead this next week-end , Sept.7-9,@ MAAC Fly-In. Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382276#382276 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: cool vintage style wool coveralls
Date: Sep 01, 2012
Hey all, If any of you are into vintage flying clothes. and aren't too large. Ck out Sportsman's guide. Just found the coolest set of vintage style wool blend Italian coveralls (WX2-206131 New Italian Military Issue Wool Coveralls, Gray) which are identical to those I've seen pictured being worn by aviators in the thirties. $23 just got me a pair and they are awesome! Even though they are marked large though, they are barely large enough for me, and I'm only 5'9" and weigh 155. The quality though seems excellent and the styling is perfect for those of us who like to look the part. Just ordered a second pair because these won't ever come back I'm guessing. Enjoy! Douwe http://www.sportsmansguide.com/net/cb/new-italian-military-issue-wool-covera lls-gray.aspx?a=891164 ________________________________________________________________________________
Subject: Sport plane construction techniques by Tony Bingelis
Date: Sep 01, 2012
So I FINALLY bought the rest of the series of How To books, and I am grateful to those on this list that have done 2 things for me: 1. NOT told me to shut up and look it up in these books first before asking here; 2. Patiently advised me of answers contained in these books. I'm only 50 pages not he yellow book and already answered a ton of metal questions I had about the fittings I am about to attempt. So, if you are just starting, get the whole set of books first! Don't buy them one at a time like I started out doing! I know the esteemed Mike Cuy has said he relied on these before there really was a list like this to turn to... I now know why. Mark (shrugging his shoulders and slapping his forehead in Fresno) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382286#382286 ________________________________________________________________________________
Subject: Re: cool vintage style wool coveralls
Date: Sep 01, 2012
Cool... too bad I'm 6' 4" extra fat. :-( -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382287#382287 ________________________________________________________________________________
Date: Sep 01, 2012
Subject: to all good guys from these list
hi guys, Im bery sorried for my mistake unsubscribe these great list ,Im tr ate to unsubscrib from aereovee grup and cansel all,like you know trate to sale my old never used aereov.w. in these grup ,was so big mistake was peop le from sonex aircraf or somthing, bery crude ,rasist and ofensive people i n there, that was all way be tanksfull from pietenpol comunity to have good person frienly and bery cain ,helping all way true to all we need somthing , tanks again people for by so nice and grat friens .again tanks-jorge f rom hanfor. ________________________________________________________________________________
Date: Sep 02, 2012
Milk piping SS welded on 3/16 SS plate Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382300#382300 Attachments: http://forums.matronics.com//files/horizontal_flow_radiator_001_194.jpg ________________________________________________________________________________
Date: Sep 02, 2012
Sorry guys wrong side Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382301#382301 Attachments: http://forums.matronics.com//files/radiator_shot_12_26_10_410.jpg ________________________________________________________________________________
Subject: to all grup
Date: Sep 02, 2012
hello guys , simple q these time is possible im the only one not get mail from matronic list tanks jorge from hanford [Embarassed] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382308#382308 ________________________________________________________________________________
Subject: Re: to all grup
Date: Sep 02, 2012
I think the activity has been slow this week... Maybe due to the holiday weekend. I have still been working to finish the large video project I have been working on, so I have not been very active on my project for a while... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382309#382309 ________________________________________________________________________________
Date: Sep 02, 2012
keeping workin mark and sooner you haved time for piet from my is like mixe d week som hours som not finished my 16 ribs in 38 days and attachet parts for my cylinder brakes well is some in one wheeck but need more metal work in those attachment parts jope seyou nex jorge from hanford=0A=0A=0AFrom: M ark Roberts =0ATo: pietenpol-list(at)matronics.com =0AS ent: Sunday, September 2, 2012 9:08 PM=0ASubject: Pietenpol-List: Re: to al s1(at)gmail.com>=0A=0AI think the activity has been slow this week... Maybe du e to the holiday weekend.=0A=0AI have still been working to finish the larg e video project I have been working on, so I have not been very active on m y project for a while...=0A=0A=0A=0A=0ARead this topic online here:=0A=0Aht tp://forums.matronics.com/viewtopic.php?p=382309#382309=0A=0A=0A=0A=0A=0A ================ ________________________________________________________________________________
Subject: lowell
Date: Sep 03, 2012
Hey Lowell (pieti) We'll miss your plane at Brodhead as she's been quite the institution for so many years. I hope you can get the "green light" from the docs to go flying again, but until then, keep coming yourself. It'll keep you young! Douwe ________________________________________________________________________________
From: "Barnwell Regional Airport" <barnwellairport(at)bellsouth.net>
Subject: Don Harpers Pietenpol
Date: Sep 03, 2012
Attached picture of of Don Harpers Piet making it's first engine run after filling fuel tank with gas. Taxi testing will start shortly. After the first flight, more info will be posted. ________________________________________________________________________________
Subject: Re: Don Harpers Pietenpol
Date: Sep 03, 2012
Looks like a mighty fine aircraft Don! Can't wait to hear the flying numbers. I took a nap while the picture was downloading on my computer! Just kidding, but here is a smaller version of the same for those with slow connections. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382328#382328 Attachments: http://forums.matronics.com//files/img_0976_110_136.jpg ________________________________________________________________________________
Date: Sep 03, 2012
Beautiful, Don! ------Original Message------ From: John Francis Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Don Harpers Pietenpol Sent: Sep 3, 2012 8:23 AM Looks like a mighty fine aircraft Don! Can't wait to hear the flying numbers. I took a nap while the picture was downloading on my computer! Just kidding, but here is a smaller version of the same for those with slow connections. -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382328#382328 Attachments: http://forums.matronics.com//files/img_0976_110_136.jpg Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Sep 03, 2012
Looks wonderful Don. When do you fly?Gardiner --- On Mon, 9/3/12, Barnwell Regional Airport wrote: From: Barnwell Regional Airport <barnwellairport(at)bellsouth.net> Subject: Pietenpol-List: Don Harpers Pietenpol Date: Monday, September 3, 2012, 11:02 AM Attached picture of of Don Harpers Piet making it's first engine run after filling fuel tank with gas. Taxi testing will start shortly. - After the first flight, more info will be posted. ________________________________________________________________________________
Date: Sep 03, 2012
Don: She is gorgeous, I have two questions, 1.Don, is the leading wing edge with more radii ? 2. Is the damaged pointing finger, aircraft related ? Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382347#382347 ________________________________________________________________________________
Date: Sep 03, 2012
Jealousy doesn't look good on me... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382358#382358 ________________________________________________________________________________
Subject: Don Harpers new Pietenpol
Date: Sep 04, 2012
Congratulations to Lowel for noting that the leading edge on Don's new Pietenpol is a little different . It is actualy a Riblet 612 airfoil. How does it fly? At this point, I've only done some high speed taxing. Several minor things were noted and are being corrected Don is working on getting paperwork together for inspected, scheduling a DAR, etc. More about flight information later. ________________________________________________________________________________
Subject: Re: Don Harpers new Pietenpol
Date: Sep 04, 2012
Hi P.F., Beautiful airplane indeed. The flight testing of Don's airplane will be the "final word" on the "airfoil wars", right? You and Don were telling me at Brodhead that his airplane is pretty much identical to yours with the excep tion of the Riblet airfoil, correct? Dan Helsper Puryear, TN -----Original Message----- From: Barnwell Regional Airport <barnwellairport(at)bellsouth.net> Sent: Tue, Sep 4, 2012 6:58 am Subject: Pietenpol-List: Don Harpers new Pietenpol Congratulations to Lowel for noting that the leading edge on Don's new Piet enpol is a little different . It is actualy a Riblet 612 airfoil. How does it fly? At this point, I've only done some high speed taxing. Several minor things were noted and are being corrected Don is working on getting paperwork together for inspected, scheduling a DA R, etc. More about flight information later. ________________________________________________________________________________
Date: Sep 04, 2012
Douwe: Thanks for the link. However the only size they offer is Large and if that is tight on your 155 lbs then it would be an impossible fit on my 220. Thanks for the dream though. Tom Stinemetze McPherson, KS. >>> "Douwe Blumberg" 9/1/2012 8:00 PM >>> Hey all, If any of you are into vintage flying clothes and arent too large Ck out Sportsmans guide. Just found the coolest set of vintage style wool blend Italian coveralls (WX2-206131 New Italian Military Issue Wool Coveralls, Gray) which are identical to those Ive seen pictured being worn by aviators in the thirties. $23 just got me a pair and they are awesome! Even though they are marked large though, they are barely large enough for me, and Im only 59 and weigh 155. The quality though seems excellent and the styling is perfect for those of us who like to look the part. Just ordered a second pair because these wont ever come back Im guessing. Enjoy! Douwe http://www.sportsmansguide.com/net/cb/new-italian-military-issue-wool-coveralls-gray.aspx?a=891164 ________________________________________________________________________________
Subject: Don't new Piet
Date: Sep 04, 2012
Congratulations Don! Nice looking plane!! Wow, a veritable tidal wave of Corvairs. ________________________________________________________________________________
Subject: Don's airplane
Date: Sep 04, 2012
Answers to two questions from Paul and Dan Paul-"little mufflers" are empty propane gas cylinders made internally like a car muffler- seem to work well- can tell you more after first flight Dan-After we get Don's plane flying, then I'll do a comparisin test and write it up for the Piet community. More to come later. All for now P. F. ________________________________________________________________________________
Date: Sep 04, 2012
Subject: good guys from these list
You're in good company here Jorge as there are many, many fine people on th is Pietenpol list that are helpful, positive, and have good hearts. Sorry to hear you didn't have such a good experience on the Sonex list. Glad you are back on the Pietenpol list. Best wishes on selling your Aero Vee engine. Maybe you can get some buyers for that engine on Barnstormers.com Keep us posted on your progress and send pictures when you can! Mike Cuy ________________________________________________________________________________
Date: Sep 04, 2012
Subject: a way to avoid routing spars
Curt--Many ways to make your spars including routing but I chose to go a di fferent 'route' if you'll excuse the pun. Here's what I did to fabricate my wing spars and the sketch also shows how I would do it over again next time. Mike C. Good to meet you and your daughter at Brodhead!!!!!! ________________________________________________________________________________
Subject: Latest visitor to my project.....
Date: Sep 04, 2012
About 10 feet away - walked out of the forest - I rolled him an apple....! Love having my condo workshop next to the greenbelt. We are truly fortunate to be involved with this creative endeavor of vintage aeroplane construction...! Time well spent...!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382392#382392 Attachments: http://forums.matronics.com//files/deer_pietenpol_199.jpg ________________________________________________________________________________
Date: Sep 04, 2012
Very Nice! How about a couple of pictures with the cowling off? Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382400#382400 ________________________________________________________________________________
Subject: Re: a way to avoid routing spars
Date: Sep 04, 2012
This is a great suggestion, Mike. Your proposed method would produce spars just as strong as solid ones that were routed, and at less cost than buying full 3/4" or 1" thick spar blanks. This post could also turn into a "what I would do differently next time" thread, compiled by those who have successfully built and flown their Piets. So who else has suggestions for what they would do differently if they were to build their plane again? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382401#382401 ________________________________________________________________________________
Date: Sep 04, 2012
Subject: what I would do differently, wing spars and other things
Thank you Billy! As I recall I (and others) have calculated that my built-up sitka spruce spars cost a little more than routed 'full figured' spars but to me the simple built up spars are so easy to build and you never have to worry about ruining a spar with your router. On my Piet I raised the pilot seat 2" for better forward visibility on takeoff and landing. I wouldn't do that again because in cruise there is too much of my upper body out of the cockpit and I have to slouch down to get out of the wind. If I wanted to I could have added seat cushions to be higher in the seat but as it is now I can't even add a seat cushion. (fortunately I have enough natural padding that I don't require a cushion. ) Mike C. ________________________________________________________________________________
Subject: Re: what I would do differently, wing spars and other
things
Date: Sep 04, 2012
Ok, so far we have built up spars and keeping the pilot seat at stock height. Others have said to lean the Pilot's seat back 2" to improve comfort. What else does anyone have to offer, aside from the time-tested advice to "build it to the plans", and "simplicate and add lightness"? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382406#382406 ________________________________________________________________________________
things
Date: Sep 04, 2012
1. I made my fuselage 1" wider than plans, in the belief that the standard size would be too tight. WRONG. I've flown several standard size Piets and fit just fine. Making it wider costs more in plywood and spruce and adds weight. It also changes the cabane strut to spar interface. 2. I used standard "medium weight" fabric. Next time I cover it I will use the light weight stuff. Not only is the fabric lighter, but it requires less polyspray and paint to fill the weave. 3. I used PolyFiber Aerothane polyurethane paint. Big Mistake. It is VERY heavy, is difficult to paint, is VERY expensive, and is very difficult to repair (the only way to remove it is to sand it off). Between the fabric and the paint I believe my Pietenpol is 60 lbs heavier than it needed to be. 4. I used the plans seatback angle for the rear seat. If I did it again, I would move the top of the rear seat 2" aft, keeping the bottom at the plans location. It would be much more comfortable. 5. I mounted my brake master cylinders in a position that makes bleeding the brakes one of my least favorite activities (right behind changing the bungees). Basically, in order to let air bubbles flow uphill, as they want to do, I have to literally stand the airplane on its nose with the tail way up in the air. Think about maintenance when you are installing things in your airplane. 6. The way I made my engine cowling requires that I disconnect my carb heat and cabin heat SCAT hoses before I can remove the lower cowling. I wish I had made it differently so cowling removal (and reinstallation) could be done by myself. I always have to have help with the current design. I'll have to think about what else I would do differently - these are the main things in my airplane that I would change. Now there are a few changes from the plans that I made that I would definitely do again: 1. Wider centersection (and larger fuel tank). More lift and more fuel is always a good thing. 2. Access panel under the belly, providing access to inspect and lubricate the elevator bellcrank. In my case, it also allows inspection of the trim system (see item 3), and replacing the batteries in the ELT 3. Elevator trim system. I used a variant of the Mike Cuy spring-type trim system and it works well. I rarely use it, but when I'm making a long trip (such as flying to Brodhead) and have a load in my baggage compartment in the nose, the need for trim becomes apparent. 4. Cabane struts 2-3/4" taller than plans. Makes for much greater ease of entry and exit, and better visibility. I've flown John Hofmann's "N502Rocket" and since I'm not as properly sized as John is, I find I have to lay down on the turtledeck and slide myself into the cockpit under the wing, sort of like sliding a letter into an envelope. 5. Circular Cutout for the trailing edge, again for ease of entry / egress. I suppose a flop would work as well, but I like the visibility the cutout gives me to search above me for black & yellow Germans 6. Avionics in the centersection. This is only necessary if you want avionics, but there is no other good place to put them and it works exceedingly well. 7. Access panel in the front seatback top, giving access to the rear instrument panel. I also installed a laminated copy of the entire airplane's wiring schematic (significant since I have a radio, a transponder, an intercom, a smoke system and a Ah-Ooooga horn in mine). Your mileage may vary. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Billy McCaskill Sent: Tuesday, September 04, 2012 4:56 PM Subject: Pietenpol-List: Re: what I would do differently, wing spars and other things Ok, so far we have built up spars and keeping the pilot seat at stock height. Others have said to lean the Pilot's seat back 2" to improve comfort. What else does anyone have to offer, aside from the time-tested advice to "build it to the plans", and "simplicate and add lightness"? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382406#382406 ________________________________________________________________________________
Subject: a little update
Date: Sep 04, 2012
i've been working the holiday weekend away and heres what i got.. its not black.. Charleston green.. there may be a logo or a stripe in the near future..we'll see its kinda fun putting the right hardware and fresh painted parts together jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382411#382411 Attachments: http://forums.matronics.com//files/gearpaint_659.jpg ________________________________________________________________________________
Date: Sep 04, 2012
Subject: Re: a little update
Beautiful!=0A=0A=0A=0A________________________________=0A From: bender <jfa ith(at)solairusaviation.com>=0ATo: pietenpol-list(at)matronics.com =0ASent: Tuesd ay, September 4, 2012 7:14 PM=0ASubject: Pietenpol-List: a little update=0A .com>=0A=0Ai've been working the holiday weekend away and heres what i got. .=0A=0Aits not black..=0ACharleston green..=0Athere may be a logo or a stri pe in the near future..we'll see=0A=0Aits kinda fun putting the right hardw are and fresh painted parts together=0A=0A=0Ajeff=0A=0A=0A=0A=0ARead this t opic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=382411 #382411=0A=0A=0A=0A=0AAttachments: =0A=0Ahttp://forums.matronics.com//files = ________________________________________________________________________________
things
Date: Sep 04, 2012
Great suggestions, Jack. Keep the ideas coming, good people! -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382415#382415 ________________________________________________________________________________
Date: Sep 04, 2012
Looks great, Jeff. This is one of the crowning moments of building an airplane Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ryan M Sent: Tuesday, September 04, 2012 7:29 PM Subject: Re: Pietenpol-List: a little update Beautiful! _____ From: bender <jfaith(at)solairusaviation.com> Sent: Tuesday, September 4, 2012 7:14 PM Subject: Pietenpol-List: a little update i've been working the holiday weekend away and heres what i got.. its not black.. Charleston green.. there may be a logo or a stripe in the near future..we'll see its kinda fun putting the right hardware and fresh painted parts together jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382411#382411 Attachments: http://forums.matronics.com//files/gearpaint_659.jpg /Navigator?Pietenpol-List" target="_blank">http://www.matronics.com/Navig - MATRONICS WEB FORUMS= --> ________________________________________________________________________________
Date: Sep 04, 2012
"So who else has suggestions for what they would do differently if they wer e to build their plane again?" Fellows, this is a dangerous road to begin walking down. OK, I resisted rep lying to Mikie's post, but this is going on too long, too far...........May I remind you that y'all are in jeopardy of being disqualified on being abl e to call your ship a "Pietenpol". There are no Pietenpol plans (that I kno w of) that mention anything but routed spars from solid spruce. Sorry, but don't kill the messenger................... Since the Top Curmudgeon has taken a leave of absence from this list, I fea r that there will be no one to herd the masses in the right direction. That is why I feel compelled to mention this. Dan Helsper Puryear, TN -----Original Message----- From: Billy McCaskill <billmz(at)cox.net> Sent: Tue, Sep 4, 2012 2:48 pm Subject: Pietenpol-List: Re: a way to avoid routing spars This is a great suggestion, Mike. Your proposed method would produce spars just as strong as solid ones that were routed, and at less cost than buying full 3/4" or 1" thick spar blanks. This post could also turn into a "what I would do differently next time" thread, compiled by those who have successfully built and flown their Piets . So who else has suggestions for what they would do differently if they were to build their plane again? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382401#382401 ________________________________________________________________________________
Date: Sep 04, 2012
Don't invest too much energy, Dan. I'm afraid you will be as successful as was he! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Tuesday, September 04, 2012 5:00 PM Subject: Re: Pietenpol-List: Re: a way to avoid routing spars "So who else has suggestions for what they would do differently if they were to build their plane again?" Fellows, this is a dangerous road to begin walking down. OK, I resisted replying to Mikie's post, but this is going on too long, too far...........May I remind you that y'all are in jeopardy of being disqualified on being able to call your ship a "Pietenpol". There are no Pietenpol plans (that I know of) that mention anything but routed spars from solid spruce. Sorry, but don't kill the messenger................... Since the Top Curmudgeon has taken a leave of absence from this list, I fear that there will be no one to herd the masses in the right direction. That is why I feel compelled to mention this. Dan Helsper Puryear, TN -----Original Message----- From: Billy McCaskill <billmz(at)cox.net> Sent: Tue, Sep 4, 2012 2:48 pm Subject: Pietenpol-List: Re: a way to avoid routing spars This is a great suggestion, Mike. Your proposed method would produce spars just as strong as solid ones that were routed, and at less cost than buying full 3/4" or 1" thick spar blanks. This post could also turn into a "what I would do differently next time" thread, compiled by those who have successfully built and flown their Piets. So who else has suggestions for what they would do differently if they were to build their plane again? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382401#382401 " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Sep 04, 2012
Oh My! ----- Original Message ----- From: gboothe5(at)comcast.net Date: Monday, September 3, 2012 10:56 Subject: Re: Pietenpol-List: Re: Don Harpers Pietenpol > > Beautiful, Don! > ------Original Message------ > From: John Francis > Sender: owner-pietenpol-list-server(at)matronics.com > To: pietenpol-list(at)matronics.com > ReplyTo: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Don Harpers Pietenpol > Sent: Sep 3, 2012 8:23 AM > > > Looks like a mighty fine aircraft Don! Can't wait to hear the flying numbers. > > I took a nap while the picture was downloading on my computer! Just kidding, but here is a smaller version of the same for those with slow connections. > > -------- > John Francis > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382328#382328 > > > > > Attachments: > > http://forums.matronics.com//files/img_0976_110_136.jpg > > > > > > > > > Sent on the Sprint Now Network from my BlackBerry > > > > > ________________________________________________________________________________
Date: Sep 05, 2012
Mike,- Any idea how much weight savings over the solid 3/4 spars?=0A- =0A-=0ADoug Dever=0Ain beautiful Stow Ohio=0A-=0A=0A=0A________________ ________________=0AFrom: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] " =0ATo: "pietenpol-list(at)matronics.com" =0ASent: Tuesday, September 4, 2012 2:16 PM=0ASubject: Pietenpol-List: a way to avoid routing spars=0A=0ACurt--Many ways to make y our spars including routing but I chose to go a different 'route' if you'll excuse=0Athe pun. =0A=0AHere's what I did to fabricate my wing spars and t he sketch also shows how I would do it over again next time. =0A=0AMike C. =0A=0AGood to meet you and your daughter at Brodhead!!!!!! ________________________________________________________________________________
From: "skipgadd(at)earthlink.net" <skipgadd(at)earthlink.net>
Subject: Piet parts to Brodhead
Date: Sep 05, 2012
Anybody going to the MAAC fly-in this weekend? Dave Stephens sold his Piet to someone in the Brodhead area and it has been taken apart, we took off the wings yesterday. Dave and I will deliver the Piet parts to Brodhead Airport this weekend. Mike Weeden is to help the new owner build an aircraft with the parts. I think they are going to send the Corvair back to WW for the 5th bearing. Skip ________________________________________________________________________________
Date: Sep 05, 2012
Calculate it. Sitka Spruce has a density of 21.86 lbs/ft3. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Doug Dever Sent: Wednesday, September 05, 2012 8:00 AM Subject: Re: Pietenpol-List: a way to avoid routing spars Mike, Any idea how much weight savings over the solid 3/4 spars? Doug Dever in beautiful Stow Ohio From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" Sent: Tuesday, September 4, 2012 2:16 PM Subject: Pietenpol-List: a way to avoid routing spars Curt--Many ways to make your spars including routing but I chose to go a different 'route' if you'll excuse the pun. Here's what I did to fabricate my wing spars and the sketch also shows how I would do it over again next time. Mike C. Good to meet you and your daughter at Brodhead!!!!!! ________________________________________________________________________________
Date: Sep 05, 2012
... ahh the archives. Here is what I posted back on 2/19/2011 under the subject line "Routed Spar Weight" >From time to time, the question of what spars to use arises. I thought it might be useful to share a bit of data on the amount of weight saved by using routed spars. For Christmas, my family ordered spar blanks from Aircraft Spruce for me -- proving yet again how lucky I am. After several weeks of anticipation, four beautiful Sitka Spruce planks arrived. Each was 1" x 5", 14' long. I deviated from the plans in two respects. One, I decided to take advantage of the extra length and opted to add 9" to each wing. So my outer wing panels, with the attached wing tip bows, will be 14' 0.5" long. This will produce a wing that is 30' 6" from wing tip to wing tip. Two, I also opted not to reduce the spar blanks to a 4.75" by 1" rectangle, but to bevel the top edge of each to match the interior space of the ribs. As a result, my front two spars are 4.75" tall on the forward face and 5" tall on the rear face. The rear two spars are 4.875" tall on the forward face and 4.75" on the aft face. The routed sections, however, ignore the extra material at the top of each spar. That is, were I to shave off the extra area, I would still have the flanges that are specified in the plans. Please keep these deviations in mind, because they will affect the specific weight savings that others might obtain. After much trepidation and construction of a set of simple jigs, I was ready to take my router to the spar blanks. To avoid sharp transitions, I used a bull nose router bit (i.e., shaped like a capital U) to make chamfered half circles at each end of the routed sections, as well as to chamfer the full straight edge that forms the upper and lower flanges. I then used a straight router bit to eat out the wood in the interior of the chamfered race track-like sections. I followed the plans in leaving the section where the strut fittings attach unrouted (18"), the 4.5" triangle-ish outboard section, and the 7" inboard section. I also left a section of about 5.5" unrouted where the jury strut fittings will attach. With that explanation, here are the data: Pre-routed Starboard Front Spar . . . 12 lbs 9.6 oz Routed Staboard Front Spar . . . 9 lbs 10.0 oz Pre-routed Port Front Spar . . . 12 lbs 13.8 oz Routed Port Front Spar . . . 9 lbs 13.6 oz Pre-routed Starboard Rear Spar . . . 12 lbs 5.4 oz. Routed Starboard Rear Spar . . . 9 lbs 6.6 oz. Pre-routed Port Rear Spar . . . 12 lbs 6.4 oz Routed Port Rear Spar . . . 9 lbs 7.4 oz For each spar, the routing saves almost exactly 3 lbs. The reduction is from approx 50 lbs of total spar weight to approx 38 lbs of total spar weight. As for the time involved, it took me about 2 hours per spar to do the routing, plus another 15 minutes or so for each one to vacuum up the mess. There was another 2 or 3 hours of sanding inivolved. I probably spent about the same total time, pondering, worrying, and jig building before I ever touched the router to the spar blanks. Cheers, Ken On Wed, Sep 5, 2012 at 7:43 AM, Jack Phillips wrote: > Calculate it. Sitka Spruce has a density of 21.86 lbs/ft3. > > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > > ________________________________ > > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Doug Dever > Sent: Wednesday, September 05, 2012 8:00 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: a way to avoid routing spars > > > Mike, Any idea how much weight savings over the solid 3/4 spars? > > > Doug Dever > > in beautiful Stow Ohio > > > From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" > > To: "pietenpol-list(at)matronics.com" > Sent: Tuesday, September 4, 2012 2:16 PM > Subject: Pietenpol-List: a way to avoid routing spars > > > Curt--Many ways to make your spars including routing but I chose to go a > different 'route' if you'll excuse > the pun. > > Here's what I did to fabricate my wing spars and the sketch also shows how I > would do it over again next time. > > Mike C. > > Good to meet you and your daughter at Brodhead!!!!!! > > > http://www.matronics.com/Navigator?Pietenpol-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Sep 05, 2012
Here's some considerations around spar construction that don't seem to have been addressed very much. First, wt savings 1" routed vs 3/4" solid. Calculating it out, going to be about a toss up. I suspect the 1" routed (I beam) is stronger than a 3/4" solid... by enough to be worthwhile.. no clue. Given how many champ wings are out there with 3/4 solid, I'd say probably not enough to matter. Here's some lesser known issues around wood purchasing. Frequently there is a premium on buying wood that isn't a "standard" size. What that means is that 4/4 (one inch thick before surfacing) is the most common thickness available. You should be able to yield a 3/4" solid spar out of that stock if you're buying rough (as in from McCormicks or somewhere). That's probably going to be the most economical all around and for not super well equipped wood shops. Many places sell 1/2" at the same price or MORE than 3/4, as they simply plane 4/4 stock down to half of what it was. Takes longer, more passes through the planer, so it cost more. If you can find some 5/4 (1 1/4" before surfacing), you can plane to 1" finished and rout, or more economical yet, resaw to 5/8 then plane to 1/2" (if you're careful and good at resawing). >From somewhere like aircraft spruce, 5/4 is probably prohibitive. From a lumber supplier, probably very little if any premium for 5/4 over 4/4, you'll just have less to select from and it'll be about 25 percent more expensive, because you're getting 25 percent more lumber. The price per board foot, is usually the same. A board foot is 144 cubic inches, 12x12x1. Mike's built up spars will definitely make the most out of the lumber you have, but you'll need a good cabinet shop full of tools to get the most out of it. If you have that, great! If not, factor in shop services. Quick question for Mike, what are you doing to build up the sections where fittings hook up? Using plywood, or spruce? The bottom line is that you're paying for spruce (or nice doug fir) by the cubic inch. The less of them you turn into sawdust, router or planer shavings, the cheaper. As we know from the weight savings posts (about a very consistent 12 lbs per spar set), you're turning about 25 percent of your spruce into dust. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382445#382445 ________________________________________________________________________________
Subject: Article on Brodhead in current Atlantic Flyer
Date: Sep 05, 2012
The Atlantic Flyer has a nice article on the July Brodhead Pietenpol Flyin. Dan Helsper's Yellow German and Dan Luke/Rob Bach's airplane got mentioned and there were some pics that brought back memories. Here's a link to the article online: http://www.aflyer.com/1209_c_antiqueattic.html Matt Paxton NX629ML ________________________________________________________________________________
Subject: Re: Piet parts to Brodhead
Date: Sep 05, 2012
Skip, I will be there all weekend. Do you need help with anything? Mike Cushway -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382448#382448 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Sep 05, 2012
Subject: filling up the spar web sections---with 1/4" thick mahogany
or birch ply Tools, I built up the areas where I had to attach wing fittings with 1/4" mahogany plywood on each side of the web area. I chamfered the ends of those filler plates on the advice o f an aeronautical engineer. I attached an example in the form of a sketch which should help to illustra te how I did this. Mike C. ________________________________________________________________________________
Date: Sep 05, 2012
Subject: Re: filling up the spar web sections---with 1/4" thick
mahogany or birch ply I like that design. Worked out really well (so far) for me. Also wonder if it might be good to add some curve to those filler pieces, as shown on in the attached? Maybe eliminate a stress riser at point A on the dwg? Where the filler ply meets the cap filler strip at 90 degrees? Personally, I don't think it's worth the effort but certainly worth thinking about. JM -----Original Message----- >From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov> >Sent: Sep 5, 2012 11:14 AM >To: "pietenpol-list(at)matronics.com" >Subject: Pietenpol-List: filling up the spar web sections---with 1/4" thick mahogany or birch ply > >Tools, > >I built up the areas where I had to attach wing fittings with 1/4" mahogany plywood on each side of >the web area. I chamfered the ends of those filler plates on the advice of an aeronautical engineer. > >I attached an example in the form of a sketch which should help to illustrate how I did this. > >Mike C. > ________________________________________________________________________________
Date: Sep 05, 2012
Dang, I'm stating to get that old familiar "we're going to Brodhead and you're not..." feeling...again. I hate that.... -----Original Message----- >From: 899PM <rockriverrifle(at)hotmail.com> >Sent: Sep 5, 2012 10:51 AM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: Piet parts to Brodhead > > >Skip, > >I will be there all weekend. Do you need help with anything? > >Mike Cushway > >-------- >PAPA MIKE > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=382448#382448 > > ________________________________________________________________________________
Date: Sep 05, 2012
Mike, Thanks for the offer. When you see the attached, pulling a trailer with wings, come on over. Though I belive Mike Weeden will have necessary help lined up. Skip > [Original Message] > From: 899PM <rockriverrifle(at)hotmail.com> > To: > Date: 9/5/2012 11:53:54 AM > Subject: Pietenpol-List: Re: Piet parts to Brodhead > > > Skip, > > I will be there all weekend. Do you need help with anything? > > Mike Cushway > > -------- > PAPA MIKE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382448#382448 > > ________________________________________________________________________________
Date: Sep 05, 2012
Jim, Know what you mean. When David said he was going to deliver his Piet to Brodhead, I thought gee I'll bet he could use some help. The MAAC fly-in is just icing on the cake. Skip > [Original Message] > From: Jim Markle <jim_markle(at)mindspring.com> > To: > Date: 9/5/2012 12:38:15 PM > Subject: Re: Pietenpol-List: Re: Piet parts to Brodhead > > > Dang, I'm stating to get that old familiar "we're going to Brodhead and you're not..." feeling...again. > > I hate that.... ________________________________________________________________________________
Subject: Re: Looking for a steel tube piet
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Sep 05, 2012
Greg, I happened to see this today on Barnstormers. Don't know anything about it, but I thought I would pass it along. Hope it helps. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382466#382466 ________________________________________________________________________________
Date: Sep 05, 2012
So, Tools, are there savings to be gained (Both in your wallet as well as your aircraft's gross weight) in building up an I-beam type spar or is it about even with buying a solid spar and routing it. Or just leaving it alone and accepting an extra 12 pounds of weight and no extra work. Your thoughts? -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382471#382471 ________________________________________________________________________________
Date: Sep 05, 2012
Time or money... The best for me is going to be culling through McCormick's for a nice 1 1/8" board that's in the 4/4 pile (which they have), then resaw and make 1/2" planks, and build up to an i-beam. I'll do like Mike's "next time" but make the parts added a bit wider, use spruce instead of plywood (to avoid cross grain construction) and then rout to give the requisite filets to avoid stress risers. The down side is it's an enormous amount of work and will require a ton of tools, which I'm lucky enough to have. Based on the wood I bought there for my tail feathers, my 4 spars will cost around $160 total. It's ABSOLUTELY not worth carrying around the extra 12 lbs no matter how you do it. Routing the spars is easy. If you don't want to rout, then use 3/4 solid. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382474#382474 ________________________________________________________________________________
Date: Sep 05, 2012
Oh ya, the other part of the question. Just buying and routing is the easiest, but will require me buying 4 boards so will be about $320. Not having access to a bandsaw that resaws well, a planer, tablesaw, a bazillion clamps, a jointer and a place to build up a 30' long spar might make the solid and rout option cheaper at $320. Building up without resawing is kind of the worst of both worlds unless you can get 1/2" (surfaced, 3/4 rough, which is rare) by the bdft. Having access to planers and jointers allows the use of rough lumber. I'm not sure if you can buy certified aircraft spruce rough or not. Presurfaced and certified from AC Spruce is probably $20/bdft, where good spar grade (but not officially certified) sitka from McCormicks is about $8/bdft. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382475#382475 ________________________________________________________________________________
Subject: Stromberg NA-S3A1
Date: Sep 05, 2012
I'm sure there are several of you that fly, or have flown, with this carb. I am wondering if it is characteristic for it to stumble if the throttle is advanced too quickly. Gary Boothe NX308MB ________________________________________________________________________________
Subject: Re: Stromberg NA-S3A1
Date: Sep 05, 2012
No accelerator pump. So, yes, it is. It goes lean. I mitigate it by advancing the throttle (on a go around or touch and go) with the carb heat still on (which richens the mixture), then after the power is up, pulling it off. Mine started popping on one flight. Thought I was just getting lazy and advancing much too quickly. Turns out, one of my primer lines broke, allowing a cylinder to lean out... So, hesitation seems normal and is mentioned by most who fly that carb, but backfiring is NOT. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382479#382479 ________________________________________________________________________________
Date: Sep 05, 2012
Thanks, Tools! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Wednesday, September 05, 2012 7:10 PM Subject: Pietenpol-List: Re: Stromberg NA-S3A1 No accelerator pump. So, yes, it is. It goes lean. I mitigate it by advancing the throttle (on a go around or touch and go) with the carb heat still on (which richens the mixture), then after the power is up, pulling it off. Mine started popping on one flight. Thought I was just getting lazy and advancing much too quickly. Turns out, one of my primer lines broke, allowing a cylinder to lean out... So, hesitation seems normal and is mentioned by most who fly that carb, but backfiring is NOT. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382479#382479 ________________________________________________________________________________
From: Gerry Holland <gholland@content-stream.co.uk>
Date: Sep 06, 2012
Gary...Yes it stumbles. Occasionally it even stops after a landing run. I blocked a runway two weeks ago! Tools method of using 'Carb Hot Air' is one I haven't tried so that is worth knowing. Mine is also reported as 'popping' when descending over Strip throttled back with Carb Hot Air on. Other than that, it's a real old A75! Gerry ________________________________________________________________________________
Date: Sep 05, 2012
Uh, Jack, I think you'll find that to be 31 lb at 12% moisture content. At least according to the US Forest Products Lab. The closest you're going to get to that is Western Red Cedar with a corresponding reduction in strength. Clif Calculate it. Sitka Spruce has a density of 21.86 lbs/ft3. Jack Phillips NX899JP Smith Mountain Lake, Virginia ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Sep 06, 2012
Thanks, Gerry. I can stop chasing ghosts! ------Original Message------ From: Gerry Holland Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Stromberg NA-S3A1 Sent: Sep 5, 2012 10:37 PM Gary...Yes it stumbles. Occasionally it even stops after a landing run. I blocked a runway two weeks ago! Tools method of using 'Carb Hot Air' is one I haven't tried so that is worth knowing. Mine is also reported as 'popping' when descending over Strip throttled back with Carb Hot Air on. Other than that, it's a real old A75! Gerry Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Sep 06, 2012
After a few stumbles like that you get used to advancing the throttle slowly. You don't want to disconcert the masses (or your passengers) Ben Charvet NX866BC A-65 On 9/5/2012 9:58 PM, Gary Boothe wrote: > > I'm sure there are several of you that fly, or have flown, with this > carb. I am wondering if it is characteristic for it to stumble if the > throttle is advanced too quickly. > > Gary Boothe > > NX308MB > > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Sep 06, 2012
Gary, I have no accelerator pump on my NA-S3A1 and it does not stumble unless it is cooler weather (55F or colder) and I haven't warmed up the engine thoroughly. (of course your engine and induction system are completely different than my A-65 setup) If I advance the throttle smoothly on takeoff or in flight after some slow flight the engine never stumbles. (thankfully) Mike C. ________________________________________________________________________________
Date: Sep 06, 2012
Here's another tidbit I just learned. Apparently aircraft carbs run very rich at full idle, to help with cooling (since the prop is so slow, not nearly as much cooling there). If you open the throttle just a tad, it gets it off the idle circuit, where it's more like a regular carb. Sure enough, when it's hot and I'm flying young eagles in a Glastar, on the rollout the engine gets VERY rough and is on the verge of quitting. I advance the throttle just a bit and get it off idle circuit and that helps a ton. Also, when trying to hot start, I'll keep it off the idle circuit to avoid or lessen the effects of flooding. Hand propping is a different matter. I'd NEVER try that while hand propping alone. I haven't flown the piet enough repetitively on a hot day like that to be a problem. I have found that it's easier to flood on hot days and I go through the standard a65 unflood routine, and it starts first flip afterwards. Because of the success there, I haven't tried hand propping with someone else in the cockpit with the carb off the idle circuit. Now, how this affects cold starting and prime is... EVERY time I've had the engine catch and run a few revolutions, I can't get it started easily after that point. Well, it's just like pulling it through, and with the engine on the extra rich idle circuit, it floods. Now, every time it catches a few revs and quits, I just turn the mags off, open the throt and pull it backwards a dozen pulls, reset everything and viola, easy start 1st pull after that. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382495#382495 ________________________________________________________________________________
Date: Sep 06, 2012
Thanks, Mike! There was some talk on the Piper Super Cub list about slightly enrichening the mixture to help ease the problem. You may already be there. Gary ------Original Message------ From: Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Stromberg NA-S3A1 Sent: Sep 6, 2012 6:07 AM Gary, I have no accelerator pump on my NA-S3A1 and it does not stumble unless it is cooler weather (55F or colder) and I haven't warmed up the engine thoroughly. (of course your engine and induction system are completely different than my A-65 setup) If I advance the throttle smoothly on takeoff or in flight after some slow flight the engine never stumbles. (thankfully) Mike C. Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Sep 06, 2012
The Stromberg carb is a good one. It shouldn't stumble if adjusted properly. Please read Harry Fenton's Advice on the Flybaby site. I just reb uilt an A-65 and the stromberg carb that is on it. and It doesn't stumble. Dave In a message dated 9/6/2012 9:22:41 A.M. Eastern Daylight Time, gboothe5(at)comcast.net writes: --> Pietenpol-List message posted by: gboothe5(at)comcast.net Thanks, Mike! There was some talk on the Piper Super Cub list about slightly enrichening the mixture to help ease the problem. You may already be there. Gary ------Original Message------ From: Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Stromberg NA-S3A1 Sent: Sep 6, 2012 6:07 AM --> Pietenpol-List message posted by: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" Gary, I have no accelerator pump on my NA-S3A1 and it does not stumble unless it is cooler weather (55F or colder) and I haven't warmed up the engine thoroughly. (of course your engine and induction system are completely different than my A-65 setup) If I advance the throttle smoothly on takeoff or in flight after some slow flight the engine never stumbles. (thankfully) Mike C. Sent on the Sprint=AE Now Network from my BlackBerry=AE ________________________________________________________________________________
Date: Sep 06, 2012
Dick bought my carb at Sun-n-fun and just sent it out for a complete rebuild. And in it's defense, it NEVER stumbled on me (except for the broke primer line) except while adding power to taxi IMMEDIATELY after startup. However, I was warned (by quite a few people) that just firewalling it with no regard wasn't a good idea, and knowing it has no accelator pump, it made sense. I started the carb heat routine while I was troubleshooting the backfiring (lean condition) caused by the broke primer line, and it helped quite a bit, which lets me know it would help with a lean condition caused by quick acceleration and no accelerator pump. Also, it didn't make sense to waste time taking my hand off the throttle, moving to the carb heat (all while slowing down and wasting runway), then back to the throttle to go around. So it's a routine I use ALL the time. While a good carb, it is old... I'm going to go read the article you mention. I do have a question for you and Mike. Can you get your carbs to hesitate? If it's adjusted properly, will it hesitate at all? Under any normal condition? I guess the whole point is this. If SOME hesitation under an extremely quick advance of the throttle from a full idle is normal, then you can experience it knowing things are probably alright with your carb. As how these things go, I was warned of it and after I JUST became a little comfortable with it, I did advance the throttle more quickly (I would advance the throttle VERY slowly at first because I wasn't much used to a taildragger, rather than trying to overcome a difficulty with the carb) and found that hesitation so assumed it normal. As it turned out, it wasn't! A technique I use with jet engines is to never let the engine "go to sleep". Especially with pure jets (no fan) and older jets, the response time from a developed idle can be dangerously slow. If you jockey the engines just enough, you'll keep them in a position where you have good response, without adding any significant thrust that would compromise the approach. Same applies to a piet. I notice many light civil pilots basically fly a no power final approach (which guarantees making the field with an engine failure, not a bad idea). Now if you fly that approach at a close to touchdown speed, if you do get low and add power with hesitation, you're in bad shape. If you fly that approach at a higher speed, short of touchdown and glide into it, you have margin for error, enough time (speed) to get through a hesitation. I, on the other hand, with a huge lack of experience in light civil planes, and YEARS AND YEARS of "bad habits", fly a lower power on approach, which keeps my engine out of the region where it would hesitate with a quick advance anyway. As I mentioned, the whole point of the discussion (in my mind) is to help us understand what the limitations of our carbs are so that we can determine if something isn't right. It's quite possible it SHOULDN'T ever hesitate and my flying habits would mask that condition and I'd never know if my carb was adjusted right in that regime or not. Lastly, the old drip from these old carbs. I'm on the verge of buying a little Chief with an A65. The owner just had the carb totally overhauled (to the tune of $600) because it would drip. I was told that was silly, because they all drip... I'm of the opinion that no good carb should just drip. Something is wrong in there if it does. May not really matter because it won't drip while running, but still... Oh ya, one more thing. When I was buying n2rn it was being inspected. A cylinder had to be pulled for some work. After we put it together and ran it, it had a little pop on acceleration. Dick wasn't happy and we thought maybe leaking a little air somewhere and we went about tightening all the hose clamps on the intake system. Problem went away. None of them seemed loose. It does seem that this engine is quite sensitive to any leaks in the intake system. So don't confuse that problem with a POSSIBLE propensity for hesitating due to a lack of complexity. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382499#382499 ________________________________________________________________________________
Date: Sep 06, 2012
I agree that the Stromberg is a good Carb. and widely used but there are some 'stumblers' out there including mine. One of the FAA Notices I came across whilst investing this was Continental Engines M64-6. You might all know of it? I've attached it for information. I am going to try it towards winter time. As for the stumbling....going tinker about but open throttle carefully until I feel happy about it. Gerry ________________________________________________________________________________
Date: Sep 06, 2012
Dick, One of the major problems with older Stromberg is the fit between the carb and the throttle shaft. As this area becomes warn, outside air leaks in around the shaft. You have a lean condition that cannot be adjusted out. . Lean on idle means hesitation and engine stoppage. Just my experience. Dave In a message dated 9/6/2012 10:39:49 A.M. Eastern Daylight Time, n0kkj(at)yahoo.com writes: --> Pietenpol-List message posted by: "tools" Dick bought my carb at Sun-n-fun and just sent it out for a complete rebuild. And in it's defense, it NEVER stumbled on me (except for the broke primer line) except while adding power to taxi IMMEDIATELY after startup. However, I was warned (by quite a few people) that just firewalling it with no regard wasn't a good idea, and knowing it has no accelator pump, it made sense. I started the carb heat routine while I was troubleshooting the backfiring (lean condition) caused by the broke primer line, and it helped quite a bit, which lets me know it would help with a lean condition caused by quick acceleration and no accelerator pump. Also, it didn't make sense to waste time taking my hand off the throttle, moving to the carb heat (all while slowing down and wasting runway), then back to the throttle to go around. So it's a routine I use ALL the time. While a good carb, it is old... I'm going to go read the article you mention. I do have a question for you and Mike. Can you get your carbs to hesitate? If it's adjusted properly, will it hesitate at all? Under any normal condition? I guess the whole point is this. If SOME hesitation under an extremely quick advance of the throttle from a full idle is normal, then you can experience it knowing things are probably alright with your carb. As how these things go, I was warned of it and after I JUST became a little comfortable with it, I did advance the throttle more quickly (I would advance the throttle VERY slowly at first because I wasn't much used to a taildragger, rather than trying to overcome a difficulty with the carb) and found that hesitation so assumed it normal. As it turned out, it wasn't! A technique I use with jet engines is to never let the engine "go to sleep". Especially with pure jets (no fan) and older jets, the response time from a developed idle can be dangerously slow. If you jockey the engines just enough, you'll keep them in a position where you have good response, without adding any significant thrust that would compromise the approach. Same applies to a piet. I notice many light civil pilots basically fly a no power final approach (which guarantees making the field with an engine failure, not a bad idea). Now if you fly that approach at a close to touchdown speed, if you do get low and add power with hesitation, you're in bad shape. If you fly that approach at a higher speed, short of touchdown and glide into it, you have margin for error, enough time (speed) to get through a hesitation. I, on the other hand, with a huge lack of experience in light civil planes, and YEARS AND YEARS of "bad habits", fly a lower power on approach, which keeps my engine out of the region where it would hesitate with a quick advance anyway. As I mentioned, the whole point of the discussion (in my mind) is to help us understand what the limitations of our carbs are so that we can determine if something isn't right. It's quite possible it SHOULDN'T ever hesitate and my flying habits would mask that condition and I'd never know if my carb was adjusted right in that regime or not. Lastly, the old drip from these old carbs. I'm on the verge of buying a little Chief with an A65. The owner just had the carb totally overhauled (to the tune of $600) because it would drip. I was told that was silly, because they all drip... I'm of the opinion that no good carb should just drip. Something is wrong in there if it does. May not really matter because it won't drip while running, but still... Oh ya, one more thing. When I was buying n2rn it was being inspected. A cylinder had to be pulled for some work. After we put it together and ran it, it had a little pop on acceleration. Dick wasn't happy and we thought maybe leaking a little air somewhere and we went about tightening all the hose clamps on the intake system. Problem went away. None of them seemed loose. It does seem that this engine is quite sensitive to any leaks in the intake system. So don't confuse that problem with a POSSIBLE propensity for hesitating due to a lack of complexity. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382499#382499 ________________________________________________________________________________
Date: Sep 06, 2012
The carb in n2rn was totally overhauled to the tune of $600 also, by a well respected aviation carb shop (got all the receipts). I assume (though I havn't pulled and checked) that the throttle shaft issue would be resolved if worn for that sort of rebuild and yellow tagging. Also, it would never quit while idling and starts well, both indicating that it isn't a worn throttle shaft. I've had problems with worn throttle shafts on tractors (very similar carbs) and old skid steers with Wisconsin VH4D's. That bulletin aforementioned is really interesting! Also hadn't yet found the incredible wealth of info on the fly baby website about little airplane engines. Super useful info. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382503#382503 ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Date: Sep 06, 2012
My chart from Bruhn's " Analysis and Design of Airplane Structures" shows spruce at 15% moisture content at 27 Pounds per cubic foot. Of course, this book was printed in 1949 -- figures might be different now. Chuck ----- Original Message ----- From: Clif Dawson To: pietenpol-list(at)matronics.com Sent: Thursday, September 06, 2012 2:19 AM Subject: Re: Pietenpol-List: a way to avoid routing spars Uh, Jack, I think you'll find that to be 31 lb at 12% moisture content. At least according to the US Forest Products Lab. The closest you're going to get to that is Western Red Cedar with a corresponding reduction in strength. Clif Calculate it. Sitka Spruce has a density of 21.86 lbs/ft3. Jack Phillips NX899JP Smith Mountain Lake, Virginia ------------------------------------------------------------------------- --- ________________________________________________________________________________
Date: Sep 06, 2012
Ref the drip on Stromberg carbs, there was a guy at OSH who seems to know EVERYTHING about the Stromberg and showed us a mod right from the NAS3 overhaul manual that permanently fixes the leak. It involves plugging a port that ends up below float level when a tail wheel aircraft is on the ground and drilling a small hole "higher" up on the carb body. Easy to do and a permanent fix or so he said. What he warned about was the typical "Must be the float cover gasket. I'll just lean on the screws and tighten it a bit more." response from many mechanics. That does nothing useful if the gasket is correctly installed and can warp the cover if done to an extreme. Same guy said he was close to FAA-PMA approval for replacement float needle and seats. That would be a good thing since the steel ones are pretty much NLA. As an unrelated data point, my Piper Cherokee has an FAA warning on the instrument panel about not rapidly advancing the throttle even though the O-320 uses a Marvel Dribbler MA4-SPA with an accelerator pump. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382505#382505 ________________________________________________________________________________
Date: Sep 06, 2012
I get a stumble sometimes in the 1000-1200 rpm range. I think it may have something to do with the transition from the idle jet to the main jet. I've experienced this on other carbs too. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382507#382507 ________________________________________________________________________________
things
Date: Sep 06, 2012
So Oscar, you know that despite the fact that I'm recovering I can still kick your butt, right?:) Just kidding, of course. On the rebuild, we will do the following: - 3 piece wing, - Use a Gary Boothe fuel tank (~16 gallons), - Move the fuel tank filler port forward a little for ease of refueling, - Probably use the lightweight fabric as Jack mentioned, - Slant the back seat back a little as Jack mentioned, - Figure out a way to make Shelley more comfortable in the front seat, raise the seat, figure out better cushions, whatever, - Maybe raise the turtle deck an inch? We'll see, - Use fittings at the top of the rear cabanes as an attach point for the front seat shoulder harness attach cable vs. the through-the-cabane eyebolts we used, - Maybe use a head rest to raise the back seat shoulder harness, - I loved the brakes, but need to figure out a way to quit popping spokes. May just use Jack's design. We'll see, - Maybe a cutout in the wing? - Add a sump to the fuel tank, of course.... I loved the airplane and it performed nicely. These are changes for convenience (except for the sump in the fuel tank, of course...). -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382508#382508 ________________________________________________________________________________
Date: Sep 06, 2012
Exactly where I'm getting it! ------Original Message------ From: Don Emch Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: Stromberg NA-S3A1 Sent: Sep 6, 2012 8:37 AM I get a stumble sometimes in the 1000-1200 rpm range. I think it may have something to do with the transition from the idle jet to the main jet. I've experienced this on other carbs too. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382507#382507 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Sep 06, 2012
NoKK. try this, _http://www.bowersflybaby.com/tech/fenton.htm#nologs_ (http://www.bowersflybaby.com/tech/fenton.htm#nologs) In a message dated 9/6/2012 11:25:34 A.M. Eastern Daylight Time, n0kkj(at)yahoo.com writes: --> Pietenpol-List message posted by: "tools" The carb in n2rn was totally overhauled to the tune of $600 also, by a well respected aviation carb shop (got all the receipts). I assume (though I havn't pulled and checked) that the throttle shaft issue would be resolved if worn for that sort of rebuild and yellow tagging. Also, it would never quit while idling and starts well, both indicating that it isn't a worn throttle shaft. I've had problems with worn throttle shafts on tractors (very similar carbs) and old skid steers with Wisconsin VH4D's. That bulletin aforementioned is really interesting! Also hadn't yet found the incredible wealth of info on the fly baby website about little airplane engines. Super useful info. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382503#382503 ________________________________________________________________________________
Date: Sep 06, 2012
From: Andrew Eldredge <andrew.eldredge(at)gmail.com>
My stromberb stumbles when advanced quickly. The stumble was a contributing factor to 7229R's appearance in the NTSB database. In my "oral counseling" with the FAA, we talked about not bein so quick on the throttle. ________________________________________________________________________________
Date: Sep 06, 2012
Subject: Fly Baby page
Here is the addy for the bowers fly baby site. There is a lot of info on engines and wood working. You can learn from this site. Dave _http://www.bowersflybaby.com/tech/index.html#woodi_ (http://www.bowersflybaby.com/tech/index.html#woodi) ________________________________________________________________________________
Date: Sep 06, 2012
Strombergs are excellent carbs, simple tech that has been proven over many years on god knows how many different production/experimental aircraft and engines. As Dave mentioned, the dripping is a simple issue of where the float bowl vent port is relative to the level of fuel in the bowl when the carburetor is installed on a taildragger. This was addressed over 50 years ago by a Service Bulletin.....shops/people don't know about or don't perform the SB, and they still drip....from D&G Supply's page: "For Stromberg/NAS model carburetors utilized on "taildraggers", care must be taken to control the fuel level in the bowl to accommodate the slanted mounting of this unit on the engine to prevent overflow leakage. There is a modification to this carburetor per Service Bulletin #73 dated 6/58 that removes a potential leaking air bleed hole located low in the throat by plugging and re-drilling a new one further up". Simple resolution. I just happened to stumble upon the gentleman Dave mentioned in the Vintage Barn (Bob Kachergius), and sat in on his talk.....he definitely knows what he's talking about. He went through the carb top to bottom, with samples, cutaway carbs, etc, pointing out all the different little details of an overhaul that might get missed: SB 73, the warping from overtightening the screws, looking for evidence of corrosion from water at in the bottom of the float bowl, how the float needle seat hole many times was not drilled deep enough at the factory, so the seat is too proud and you can't properly set the float level unless you machine it properly, etc etc, and how he addresses them. His overhaul price was a little more than some other shops, but I'd be hard pressed to imagine you could find a more thorough overhaul. Steve Krog interviewed him for an article in the August 2011 VAA mag, and he's apparently written numerous articles in various type club publications (Cub Club, etc). Anywho, he's got an ad up on Barnstormers: http://www.barnstormers.com/classified_392052_STROMBERG+NA-S3++CARBURETORS.html Ryan ryan(at)rmueller.org On Thu, Sep 6, 2012 at 9:37 AM, tools wrote: > > Dick bought my carb at Sun-n-fun and just sent it out for a complete > rebuild. And in it's defense, it NEVER stumbled on me (except for the > broke primer line) except while adding power to taxi IMMEDIATELY after > startup. > > However, I was warned (by quite a few people) that just firewalling it > with no regard wasn't a good idea, and knowing it has no accelator pump, it > made sense. I started the carb heat routine while I was troubleshooting > the backfiring (lean condition) caused by the broke primer line, and it > helped quite a bit, which lets me know it would help with a lean condition > caused by quick acceleration and no accelerator pump. > > Also, it didn't make sense to waste time taking my hand off the throttle, > moving to the carb heat (all while slowing down and wasting runway), then > back to the throttle to go around. So it's a routine I use ALL the time. > > While a good carb, it is old... I'm going to go read the article you > mention. I do have a question for you and Mike. Can you get your carbs to > hesitate? If it's adjusted properly, will it hesitate at all? Under any > normal condition? > > I guess the whole point is this. If SOME hesitation under an extremely > quick advance of the throttle from a full idle is normal, then you can > experience it knowing things are probably alright with your carb. > > As how these things go, I was warned of it and after I JUST became a > little comfortable with it, I did advance the throttle more quickly (I > would advance the throttle VERY slowly at first because I wasn't much used > to a taildragger, rather than trying to overcome a difficulty with the > carb) and found that hesitation so assumed it normal. As it turned out, it > wasn't! > > A technique I use with jet engines is to never let the engine "go to > sleep". Especially with pure jets (no fan) and older jets, the response > time from a developed idle can be dangerously slow. If you jockey the > engines just enough, you'll keep them in a position where you have good > response, without adding any significant thrust that would compromise the > approach. Same applies to a piet. > > I notice many light civil pilots basically fly a no power final approach > (which guarantees making the field with an engine failure, not a bad idea). > Now if you fly that approach at a close to touchdown speed, if you do get > low and add power with hesitation, you're in bad shape. If you fly that > approach at a higher speed, short of touchdown and glide into it, you have > margin for error, enough time (speed) to get through a hesitation. > > I, on the other hand, with a huge lack of experience in light civil > planes, and YEARS AND YEARS of "bad habits", fly a lower power on approach, > which keeps my engine out of the region where it would hesitate with a > quick advance anyway. > > As I mentioned, the whole point of the discussion (in my mind) is to help > us understand what the limitations of our carbs are so that we can > determine if something isn't right. It's quite possible it SHOULDN'T ever > hesitate and my flying habits would mask that condition and I'd never know > if my carb was adjusted right in that regime or not. > > Lastly, the old drip from these old carbs. I'm on the verge of buying a > little Chief with an A65. The owner just had the carb totally overhauled > (to the tune of $600) because it would drip. I was told that was silly, > because they all drip... > > I'm of the opinion that no good carb should just drip. Something is wrong > in there if it does. May not really matter because it won't drip while > running, but still... > > Oh ya, one more thing. When I was buying n2rn it was being inspected. A > cylinder had to be pulled for some work. After we put it together and ran > it, it had a little pop on acceleration. Dick wasn't happy and we thought > maybe leaking a little air somewhere and we went about tightening all the > hose clamps on the intake system. Problem went away. None of them seemed > loose. It does seem that this engine is quite sensitive to any leaks in > the intake system. So don't confuse that problem with a POSSIBLE > propensity for hesitating due to a lack of complexity. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382499#382499 > > ________________________________________________________________________________
Date: Sep 06, 2012
Dave and Gary, I had the old hole plugged and new drilled in mine at overhaul. Supposed to be better for sitting in the 3 point at a steeper angle like mine does. Never leaks. As far as the stumble goes... it is very faint and since I've noticed it in so many other airplanes, I've never given it much thought. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382516#382516 ________________________________________________________________________________
Date: Sep 06, 2012
Ah, my favorite old carb! I've worked with probably a half-dozen different ones now, and the one that is presently on Scout (A75) behaves precisely as Tools describes. So I do what Tools does... when I get ready to take off, I apply carb heat and leave it on till the engine is running strong and we're ready to unstick from the runway (just a couple of seconds, really). I have not tried the trick of easing in just a little throttle to get it off the idle circuit first, but that's another one I'll try. A quick shove on the throttle, hot or cold, without carb heat applied is a guarantee of stumble, hesitation, and hard swallowing on my part. As to the dribble, I've ended that problem by carefully setting the float level per the information that is also found on the FlyBaby site. It's a bit tedious but if done slowly and carefully and with the simple little measuring tool, it will be correct and you won't get dribble out the air box. I also don't fly auto gas... the Stromberg on my old A65 would drool fuel every time I tried auto gas if I set the float level for avgas, so I stopped flying with car gas. -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382560#382560 ________________________________________________________________________________
Date: Sep 06, 2012
Tools said: "Now, how this affects cold starting and prime is... EVERY time I've had the engine catch and run a few revolutions, I can't get it started easily after that point. Well, it's just like pulling it through, and with the engine on the extra rich idle circuit, it floods. Now, every time it catches a few revs and quits, I just turn the mags off, open the throt and pull it backwards a dozen pulls, reset everything and viola, easy start 1st pull after that." I've had this expeirence several times, last time was labor day attempting a hot start, but I did not know this procedure. To be clear, is this the "flood clearing" procecure? Usually on a hot start, I'll not bother "priming" with any pulls before the mags go on, the compression is tight and it will usually fire up on the first turn, but from time to time, "that" will happen, and I don't have a better solution than to shut off the fuel and wait a while. Andrew Eldredge Provo, UT On Thu, Sep 6, 2012 at 11:11 AM, Ryan Mueller wrote: > Strombergs are excellent carbs, simple tech that has been proven over many > years on god knows how many different production/experimental aircraft and > engines. > > As Dave mentioned, the dripping is a simple issue of where the float bowl > vent port is relative to the level of fuel in the bowl when the carburetor > is installed on a taildragger. This was addressed over 50 years ago by a > Service Bulletin.....shops/people don't know about or don't perform the SB, > and they still drip....from D&G Supply's page: "For Stromberg/NAS model > carburetors utilized on "taildraggers", care must be taken to control the > fuel level in the bowl to accommodate the slanted mounting of this unit on > the engine to prevent overflow leakage. There is a modification to this > carburetor per Service Bulletin #73 dated 6/58 that removes a potential > leaking air bleed hole located low in the throat by plugging and > re-drilling a new one further up". Simple resolution. > > I just happened to stumble upon the gentleman Dave mentioned in the > Vintage Barn (Bob Kachergius), and sat in on his talk.....he definitely > knows what he's talking about. He went through the carb top to bottom, with > samples, cutaway carbs, etc, pointing out all the different little details > of an overhaul that might get missed: SB 73, the warping from > overtightening the screws, looking for evidence of corrosion from water at > in the bottom of the float bowl, how the float needle seat hole many times > was not drilled deep enough at the factory, so the seat is too proud and > you can't properly set the float level unless you machine it properly, etc > etc, and how he addresses them. > > His overhaul price was a little more than some other shops, but I'd be > hard pressed to imagine you could find a more thorough overhaul. Steve Krog > interviewed him for an article in the August 2011 VAA mag, and he's > apparently written numerous articles in various type club publications (Cub > Club, etc). Anywho, he's got an ad up on Barnstormers: > > > http://www.barnstormers.com/classified_392052_STROMBERG+NA-S3++CARBURETORS.html > > Ryan > ryan(at)rmueller.org > > > On Thu, Sep 6, 2012 at 9:37 AM, tools wrote: > >> >> Dick bought my carb at Sun-n-fun and just sent it out for a complete >> rebuild. And in it's defense, it NEVER stumbled on me (except for the >> broke primer line) except while adding power to taxi IMMEDIATELY after >> startup. >> >> However, I was warned (by quite a few people) that just firewalling it >> with no regard wasn't a good idea, and knowing it has no accelator pump, it >> made sense. I started the carb heat routine while I was troubleshooting >> the backfiring (lean condition) caused by the broke primer line, and it >> helped quite a bit, which lets me know it would help with a lean condition >> caused by quick acceleration and no accelerator pump. >> >> Also, it didn't make sense to waste time taking my hand off the throttle, >> moving to the carb heat (all while slowing down and wasting runway), then >> back to the throttle to go around. So it's a routine I use ALL the time. >> >> While a good carb, it is old... I'm going to go read the article you >> mention. I do have a question for you and Mike. Can you get your carbs to >> hesitate? If it's adjusted properly, will it hesitate at all? Under any >> normal condition? >> >> I guess the whole point is this. If SOME hesitation under an extremely >> quick advance of the throttle from a full idle is normal, then you can >> experience it knowing things are probably alright with your carb. >> >> As how these things go, I was warned of it and after I JUST became a >> little comfortable with it, I did advance the throttle more quickly (I >> would advance the throttle VERY slowly at first because I wasn't much used >> to a taildragger, rather than trying to overcome a difficulty with the >> carb) and found that hesitation so assumed it normal. As it turned out, it >> wasn't! >> >> A technique I use with jet engines is to never let the engine "go to >> sleep". Especially with pure jets (no fan) and older jets, the response >> time from a developed idle can be dangerously slow. If you jockey the >> engines just enough, you'll keep them in a position where you have good >> response, without adding any significant thrust that would compromise the >> approach. Same applies to a piet. >> >> I notice many light civil pilots basically fly a no power final approach >> (which guarantees making the field with an engine failure, not a bad idea). >> Now if you fly that approach at a close to touchdown speed, if you do get >> low and add power with hesitation, you're in bad shape. If you fly that >> approach at a higher speed, short of touchdown and glide into it, you have >> margin for error, enough time (speed) to get through a hesitation. >> >> I, on the other hand, with a huge lack of experience in light civil >> planes, and YEARS AND YEARS of "bad habits", fly a lower power on approach, >> which keeps my engine out of the region where it would hesitate with a >> quick advance anyway. >> >> As I mentioned, the whole point of the discussion (in my mind) is to help >> us understand what the limitations of our carbs are so that we can >> determine if something isn't right. It's quite possible it SHOULDN'T ever >> hesitate and my flying habits would mask that condition and I'd never know >> if my carb was adjusted right in that regime or not. >> >> Lastly, the old drip from these old carbs. I'm on the verge of buying a >> little Chief with an A65. The owner just had the carb totally overhauled >> (to the tune of $600) because it would drip. I was told that was silly, >> because they all drip... >> >> I'm of the opinion that no good carb should just drip. Something is >> wrong in there if it does. May not really matter because it won't drip >> while running, but still... >> >> Oh ya, one more thing. When I was buying n2rn it was being inspected. A >> cylinder had to be pulled for some work. After we put it together and ran >> it, it had a little pop on acceleration. Dick wasn't happy and we thought >> maybe leaking a little air somewhere and we went about tightening all the >> hose clamps on the intake system. Problem went away. None of them seemed >> loose. It does seem that this engine is quite sensitive to any leaks in >> the intake system. So don't confuse that problem with a POSSIBLE >> propensity for hesitating due to a lack of complexity. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=382499#382499 >> >> >> >> >> >> >> >> ========== >> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > * > > ________________________________________________________________________________
Date: Sep 06, 2012
Yep, classic a65 flood clearing procedure from what I've heard from a few different sources. Mags - off Throt - wide open Blades - pull through BACKWARDS, about a dozen Throt - closed (EASY to screw this up, be VERY careful) Carb heat - off Mags - on Start as usual. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382569#382569 ________________________________________________________________________________
Date: Sep 06, 2012
Andrew; my experience with the Stromberg when it floods is EXACTLY the same as Tools'... but when I smell gas and the engine isn't starting I turn the fuel 'off', open the throttle wide, then slowly and patiently pull the prop through BACKWARDS a blade at a time, maybe 10-12 blades. What you're trying to do is evaporate excess fuel that's in the combustion chambers so don't hurry pulling those blades through. When you think that the excess fuel is all gone, turn the fuel valve back on and crack the throttle and try propping it normally again. BRAKES SET OR WHEELS CHOCKED! It can happen that the engine will fire with excess fuel available in the intake tubes, which means that it will catch and accelerate, and you need to be ready for that eventuality. It'll settle down quickly. If it starts, it will be normal. If it doesn't (and this happened to me many times in hot weather with the engine hot), repeat the above procedure and don't be in a hurry. In fact, I had almost as good results as the above by just shutting off the fuel, opening the throttle wide, and going back into the hangar or FBO to do other stuff for awhile until I thought the excess fuel had evaporated and I had another chance to fire up the engine. Cessna drivers wondered what the heck I was doing ;o) I have never flooded the 75, for some reason. It seems to want more fuel on starting than the 65 did, but then again they run two different Strombergs and we all know that Strombergs are like women: you have to treat them right and treat them like individuals, and they will reward you if you do that. My 65 had a temperamental (starting) but utterly reliable (running) brunette Stromberg; my 75 has a quick-starting but cold-natured redhead Stromberg. Heaven help us if I ever have an engine with a hot-blooded and wild blonde Stromberg! Oh, and if it has a mixture control-! Look out, Marilyn Monroe! Marvel-Scheblers are more like men, I guess... all alike in the basics, and always ready for action if stroked a time or two since stroking shoots some fuel in there to get the juices flowing every time. I can't tell you how many times I have stroked the throttle on Scout out of habit and inattention on starting, then realized that it does absolutely nothing for the Stromberg to open and close the butterfly in the venturi in that carb if no air is flowing through it. -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382572#382572 ________________________________________________________________________________
Date: Sep 07, 2012
If they didn't get this with the airplane, might be worth a couple of bucks just for the backstory on what they bought: http://www.ebay.com/itm/Building-Pietenpol-NX925GP-Air-Camper-Notes-Pictures-DVD-R-David-Stephens-/320977644291?pt=US_Nonfiction_Book&hash=item4abbc22b03 On Wed, Sep 5, 2012 at 1:19 PM, skipgadd(at)earthlink.net < skipgadd(at)earthlink.net> wrote: > skipgadd(at)earthlink.net> > > Jim, > Know what you mean. When David said he was going to deliver his Piet to > Brodhead, I thought gee I'll bet he could use some help. The MAAC fly-in is > just icing on the cake. > Skip > > > > [Original Message] > > From: Jim Markle <jim_markle(at)mindspring.com> > > To: > > Date: 9/5/2012 12:38:15 PM > > Subject: Re: Pietenpol-List: Re: Piet parts to Brodhead > > > > > > > Dang, I'm stating to get that old familiar "we're going to Brodhead and > you're not..." feeling...again. > > > > I hate that.... > > ________________________________________________________________________________
Date: Sep 07, 2012
Since the mixture control in the Stromberg is vacuum operated, not to mention the venturi, I've decided that the speed of the pull is important when I am pulling in advance of a start. When pulling backward, is the process sensitive to blade speed? Andrew Eldredge Provo, UT On Thu, Sep 6, 2012 at 9:58 PM, tools wrote: > > Yep, classic a65 flood clearing procedure from what I've heard from a few > different sources. > > Mags - off > Throt - wide open > Blades - pull through BACKWARDS, about a dozen > > Throt - closed (EASY to screw this up, be VERY careful) > Carb heat - off > Mags - on > > Start as usual. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382569#382569 > > ________________________________________________________________________________
Date: Sep 07, 2012
No, it is not. And a dozen blades is a bit excessive, unless you like the exercise. 4 or 5, and give her a go. Not entirely sure why it's so easy to screw up closing the throttle....if you have to be VERY careful about pulling something to the rear until it stops, maybe this whole airplane thing is not your recommended hobby.... Ryan On Fri, Sep 7, 2012 at 7:20 AM, Andrew Eldredge wrote: > Since the mixture control in the Stromberg is vacuum operated, not to > mention the venturi, I've decided that the speed of the pull is important > when I am pulling in advance of a start. When pulling backward, is the > process sensitive to blade speed? > > Andrew Eldredge > Provo, UT > > > On Thu, Sep 6, 2012 at 9:58 PM, tools wrote: > >> >> Yep, classic a65 flood clearing procedure from what I've heard from a few >> different sources. >> >> Mags - off >> Throt - wide open >> Blades - pull through BACKWARDS, about a dozen >> >> Throt - closed (EASY to screw this up, be VERY careful) >> Carb heat - off >> Mags - on >> >> Start as usual. >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=382569#382569 >> >> >> >> >> >> >> >> >> ========== >> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > > * > > ________________________________________________________________________________
Date: Sep 07, 2012
Greg, there is a flyer in Woodstock, GA for sale, it is on Barnstormers, it is at the grass field I fly out of, gary=0A=0A=0A=0A______________________ __________=0AFrom: Greg Bacon <gbacon67(at)gmail.com>=0ATo: pietenpol-list@mat ronics.com =0ASent: Tuesday, September 4, 2012 9:57 PM=0ASubject: Pietenpol -List: Looking for a steel tube piet=0A=0A=0AGents,=0AThere is a fellow in Australia that is looking to purchase a steel tube piet (flying - not a pro ject). -Please contact me if you know of anyone interested in selling one =============== ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Sep 07, 2012
Steve, I have quit using the method you have described when clearing my flooded Cont. A friend of mine who use to investigate AC accidents for Cont. powered aircraft showed me a better method and it works every time. I'm sure that you have noticed that when you clear it with your procedures that it will not always work every time. I'll describe the way I do it now. First make sure the planes tail is tied down for safety. With the Mags off and the throttle in the wide open position, Pull the prop through about 10 blades in the forward direction. This does a couple of things. It pushes the raw fuel out the exhaust rather than putting it back into the intake system (reducing the chance of a backfire into the carburetor and fire) and it also keeps the engine oil in the oil pump (preventing oil cavitation). After pulling it through, reduce the throttle to the idle or cracked position (whatever works best for you), Flip on the mags and it will start on the first pull. Works every time. The only scary part is pulling it through at WOT and hoping that the mag switches work. Keep mindful that Switches can fail and you could have an unintentional engine start when pulling it through. But we all know that we must be prepare for that anytime we touch a prop. I am one who shuts my engine down with the mag switches and I am fairly confident that my switches always work. Give it a try, I think it is a better alternative and better for the engine. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382594#382594 ________________________________________________________________________________
Date: Sep 07, 2012
Funny how quirky each one can be....502Rocket takes 2 shots of prime and four blades, and starts every time. Turn the switch off, and it quits. Pretty simple On Fri, Sep 7, 2012 at 9:25 AM, AircamperN11MS wrote: > Scott.liefeld(at)lacity.org> > > Steve, > > I have quit using the method you have described when clearing my flooded > Cont. A friend of mine who use to investigate AC accidents for Cont. > powered aircraft showed me a better method and it works every time. I'm > sure that you have noticed that when you clear it with your procedures that > it will not always work every time. > > > I'll describe the way I do it now. First make sure the planes tail is > tied down for safety. With the Mags off and the throttle in the wide open > position, Pull the prop through about 10 blades in the forward direction. > This does a couple of things. It pushes the raw fuel out the exhaust > rather than putting it back into the intake system (reducing the chance of > a backfire into the carburetor and fire) and it also keeps the engine oil > in the oil pump (preventing oil cavitation). After pulling it through, > reduce the throttle to the idle or cracked position (whatever works best > for you), Flip on the mags and it will start on the first pull. Works > every time. The only scary part is pulling it through at WOT and hoping > that the mag switches work. Keep mindful that Switches can fail and you > could have an unintentional engine start when pulling it through. But we > all know that we must be prepare for that anytime we touch a prop. I am > one who shuts my engine down with the ! > mag switches and I am fairly confident that my switches always work. > > Give it a try, I think it is a better alternative and better for the > engine. > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382594#382594 > > ________________________________________________________________________________
Date: Sep 07, 2012
I seem to recall a knowledgeable person (the guy on the Bower's list??) positing that flooding was caused by using the mags to shut the engine down. Because the engine is still sucking fuel, the plugs get fouled. He suggested shutting the engine down using a fuel shutoff valve close to the carb fuel supply and opening the throttle as it dies to get more air through. Also has the advantage of stopping any dripping due to float level issues. Something to think... Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382596#382596 ________________________________________________________________________________
Subject: Re: Spar Routing
Date: Sep 07, 2012
Mr. Pietenpol did use 3/4" laminated spars at some point later on. I would think a 3/4" laminated spar would inherently be a little stronger than a 3/4" solid spar because of doing away with the possible voids in a solid spar. Often times I hear people mention that a 3/4" solid spar is as strong as a routed 1" spar. I don't believe this to be the case. The strength of the spar is in the top and bottom where it is in tension and compression. That is why so many of the older airplanes have routed spars... to get that larger cross-section at the top and bottom of the spar. As far as the cost goes the difference between a 3/4" thick spar and a 1" thick spar is peanuts compared to the entire project. Obviously 3/4" solid spars are fine because there are many Piets flying with them. The Cubs, Champs, etc. that have less than 1" thick spars are quite a bit taller than the Piet's 4 3/4", giving more strength. One thing to remember... when many of the manufacturers from this era went to a more powerful engine, they almost always increased the thickness of the spar...(Waco, American Eagle, Swallow, etc.) Keep in mind many of our Piets are flying around with at least 50% more power than the original plans call for. I know this topic has been beaten to death but I just thought I'd share my thoughts. :) Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382600#382600 ________________________________________________________________________________
Date: Sep 07, 2012
You're at idle when you turn off the mags, not bringing in much fuel for a few seconds, how would that contribute to flooding? How do plugs get fouled if they are not sparking for a few seconds? Sure, if you turn off the fuel and want to wait until the engine consumes the fuel in the bowl and dies, go ahead. Or just have SB 73 done to the carb, and don't worry about it. On Fri, Sep 7, 2012 at 10:09 AM, dgaldrich wrote: > dgaldrich(at)embarqmail.com> > > I seem to recall a knowledgeable person (the guy on the Bower's list??) > positing that flooding was caused by using the mags to shut the engine > down. Because the engine is still sucking fuel, the plugs get fouled. He > suggested shutting the engine down using a fuel shutoff valve close to the > carb fuel supply and opening the throttle as it dies to get more air > through. Also has the advantage of stopping any dripping due to float > level issues. Something to think... > > Dave > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382596#382596 > > ________________________________________________________________________________
Date: Sep 07, 2012
Just curious.....how is your Piet doing? Nice ship, hope she'll be back in the air soon.... On Thu, Sep 6, 2012 at 9:37 AM, tools wrote: > > I'm on the verge of buying a little Chief with an A65 ________________________________________________________________________________
Date: Sep 07, 2012
I don't have much problem with flooding anyway. My plane requires different priming procedures depending on which fuel I am running. 100LL takes a lot less priming than auto gas does. Due to the specific gravity of the fuels, I guess. I also shut my fuel off as I turn the corner for my hanger. I guess about 10 seconds before I shut the mags off. This just empties the fuel bowl a little before shut down. I have a steel needle and seat in the carb and have no trouble with dripping. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382602#382602 ________________________________________________________________________________
Subject: Piet album website
Date: Sep 07, 2012
This is interesting. This adds up to a lot of history. http://www.abpic.co.uk/search.php?q=Pietenpol%20AirCamper&u=type&sort=&page=0&limit=10 Enjoy -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382608#382608 ________________________________________________________________________________
Date: Sep 07, 2012
Subject: Re: Piet album website
Also, Chris Tracy's excellent site, a bit more accessible: http://www.westcoastpiet.com/ On Fri, Sep 7, 2012 at 11:13 AM, AircamperN11MS wrote: > Scott.liefeld(at)lacity.org> > > This is interesting. This adds up to a lot of history. > > > http://www.abpic.co.uk/search.php?q=Pietenpol%20AirCamper&u=type&sort=&page=0&limit=10 > > Enjoy > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382608#382608 > > ________________________________________________________________________________
Date: Sep 07, 2012
Don, when I was trying to decide on what spar option to take, I used the formulas in the publications found on the WestCoastPiet site. Based on my calculations of 3/4" versus routed 1" spars using Sitka Spruce, I found that the 1" routed spar should be approximately 11% stronger than the 3/4" solid spar. Notice that I didn't try to calculate the strength of built up 3/4" spars. It also appeared that the weight would be essentially the same. The built up 3/4" spars would presumably be heavier, as they would have several glue joints that neither of the other two spar options would require. Cheers, Ken On Fri, Sep 7, 2012 at 9:24 AM, Don Emch wrote: > > Mr. Pietenpol did use 3/4" laminated spars at some point later on. I would think a 3/4" laminated spar would inherently be a little stronger than a 3/4" solid spar because of doing away with the possible voids in a solid spar. Often times I hear people mention that a 3/4" solid spar is as strong as a routed 1" spar. I don't believe this to be the case. The strength of the spar is in the top and bottom where it is in tension and compression. That is why so many of the older airplanes have routed spars... to get that larger cross-section at the top and bottom of the spar. As far as the cost goes the difference between a 3/4" thick spar and a 1" thick spar is peanuts compared to the entire project. Obviously 3/4" solid spars are fine because there are many Piets flying with them. The Cubs, Champs, etc. that have less than 1" thick spars are quite a bit taller than the Piet's 4 3/4", giving more strength. One thing to remember... when many of the manufacturers from this! > era went to a more powerful engine, they almost always increased the thickness of the spar...(Waco, American Eagle, Swallow, etc.) Keep in mind many of our Piets are flying around with at least 50% more power than the original plans call for. > > I know this topic has been beaten to death but I just thought I'd share my thoughts. :) > > Don Emch > NX899DE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382600#382600 > > ________________________________________________________________________________
Date: Sep 07, 2012
Ken, I would agree with you. Thanks for the input! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382615#382615 ________________________________________________________________________________
Date: Sep 07, 2012
Curt, I'm not arguing in any way. I'm just sharing my thoughts on it and what I have seen in building up different wings. The manufacturers had something in mind in the late 20's when they were going from the heavy, big 90hp OX5 to the more powerful radials because many of them increased the spar thickness. Just reporting on what I've seen. Carry on... Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382619#382619 ________________________________________________________________________________
Date: Sep 07, 2012
Subject: How would you position the control stick?
Where would you recommend the control stick rest in neutral/cruising position? Tony B says it should move freely around a 10" square but I'm wondering if the center of that box should maybe be a bit in front of straight up and down. Or would you recommend I just sit in it and put the stick at a "neutral feeling" position for me? (That makes the most sense.) I've seen a couple that had bends in them that moved the actual grip forward a few inches. Mine is already built so I'm not adding an offset but would like to finish hooking up the control cables. But I figure now is a good time to sit in it and also consider the input of some of you with Air Camper flying experience. Sort of unrelated picture of recent cable completions attached. Thanks! Jim in Pryor ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Date: Sep 07, 2012
Subject: two niceset guys you'd ever want to meet
Curt Merdan and Don Emch. Two of the most pleasant people I've ever had the pleasure of meeting at Brodhead. Shame you two don't get along. :) (line from Ann Nelson to Elaine and Te d Striker) [cid:image001.jpg@01CD8D08.B5562970]<http://www.aveleyman.com/FilmCredit.as px?FilmID=355> Mike C. ________________________________________________________________________________
Date: Sep 07, 2012
Or would you recommend I just sit in it and put the stick at a "neutral feeling" position for me? (That makes the most sense.) Jim--exactly. I would do just what you described above. No needs to bend the stick or move it forward or aft. Glad to hear of your excellent progress! And the 'circle' of movement for a Pietenpol stick is plenty big, even if you have big thighs (like us full figured girls) if you build the horns and control system to plans---what I'm saying is there is plenty of room for "throw" as-designed. The only time I use full throw is when taxiing in a strong crosswind or in full flare on landings. Mike C. ________________________________________________________________________________
Date: Sep 07, 2012
Subject: Re: two niceset guys you'd ever want to meet
Don't forgot Curt's daughter....well mannered and enthusiastic.....dunno where she gets it from. ;-) Ryan On Sep 7, 2012 1:59 PM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" wrote: > Curt Merdan and Don Emch. Two of the most pleasant people I've ever had > the pleasure of meeting**** > > at Brodhead. **** > > ** ** > > Shame you two don't get along. :) (line from Ann Nelson to Elaine and > Ted Striker) **** > > ** ** > > [image: Description: > http://www.wearysloth.com/Gallery/ActorsN/12726-355.jpg]> > **** > > ** ** > > Mike C.**** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > ________________________________________________________________________________
Date: Sep 07, 2012
Great, thanks! -----Original Message----- >From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov> >Sent: Sep 7, 2012 2:21 PM >To: "pietenpol-list(at)matronics.com" >Subject: RE: Pietenpol-List: How would you position the control stick? > > >Or would you recommend I just sit in it and put the stick at a "neutral feeling" position for me? (That makes the most sense.) > > >Jim--exactly. I would do just what you described above. No needs to bend the stick or move it forward or aft. Glad to hear >of your excellent progress! > >And the 'circle' of movement for a Pietenpol stick is plenty big, even if you have big thighs (like us full figured girls) if you build >the horns and control system to plans---what I'm saying is there is plenty of room for "throw" as-designed. The only time I use >full throw is when taxiing in a strong crosswind or in full flare on landings. > >Mike C. > > ________________________________________________________________________________
Date: Sep 07, 2012
The only person I know who is NICER than Don or Curt is Larry Williams:) Mike C. Too bad he's not on the list and out flying those powered deathtrap parachu tes somewhere over Maui to vent his frustrations over Snowflakes and GN-1 builders and non-purists. Poor guy worked himsel f up into an Bernie Ulcer. And as long as I've had too much coffee, has ANYONE ever seen a picture of Bernie (okay Bernard for those of you who take offense to me calling him Bernie) smiling? Maybe after building 26 airplanes I would n't be smiling much either. Think of all the wood slivers and near-death experiences? ________________________________________________________________________________
Date: Sep 07, 2012
Good point Mike! I think I saw a picture of him once where he was just starting to work up a smile. It's gotta have something to do with building that many airplanes. Someday when I grow up I want to be just like Larry Williams. He's about as classy and nice as they come! Don Emch NX899DE Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=382640#382640 ________________________________________________________________________________
Date: Sep 07, 2012
Larry Williams really is a peach of a guy Don---he just likes to try to come across on the list as a grumpy old man. He doesn't do a very convincing job of it....too nice! Mike C. ________________________________________________________________________________
Date: Sep 07, 2012
Larry likes to amuse himself and I think acting as the Top Curmudgeon is lots of fun to him! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382643#382643 ________________________________________________________________________________
Subject: Re: How would you position the control stick?
Date: Sep 07, 2012
I've been stop to stop a few times about tree top level into and out of fields (surrounded by trees) on gusty days, but see no reason that just centered is anything other than you'd want (side to side). I had to rerig the ailerons once and got the stick out of centered and it bothered me IMMEDIATELY, but was an easy fix. Otherwise, I'd sit in it and see where neutral feels good for you (fore and aft). Then trim the plane to where that's actually the case. Maybe a slight forward bent stick might be advantageous for some folks. You DEFINITELY want full aft available. I lost some with a experimental seat cushion... not good. Another easy fix. BETTER YET, go get a ride! Seriously. When I bought Dick N's NX2RN, I was ready to cancel the deal as soon as I sat in it. Thought there was NO WAY I could operate that rudder bar. Then he let me taxi it and that saved the deal. Was no problem, but that wasn't obvious by just sitting. If you're gonna cross country at all, a nice comfortable neutral is a good thing... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382644#382644 ________________________________________________________________________________
Date: Sep 07, 2012
I would say you need more up than down, if you need to move the stick forward a bit... Only use down of any significance to get the tailwheel off the ground. And doing that early never worked out well for me, meaning if you have enough speed, don't need that much throw. FWIW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382646#382646 ________________________________________________________________________________
Date: Sep 07, 2012
Then, lucky me! I'm meeting Curt for breakfast tomorrow!! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] Sent: Friday, September 07, 2012 11:55 AM Subject: Pietenpol-List: two niceset guys you'd ever want to meet Curt Merdan and Don Emch. Two of the most pleasant people I've ever had the pleasure of meeting at Brodhead. Shame you two don't get along. :) (line from Ann Nelson to Elaine and Ted Striker) <http://www.aveleyman.com/FilmCredit.aspx?FilmID=355> Description: http://www.wearysloth.com/Gallery/ActorsN/12726-355.jpg Mike C. ________________________________________________________________________________
Date: Sep 07, 2012
Subject: Re: Stromberg NA-S3A1
The plugs get fouled because shutting off with the throttle closed is the equivalent of about 12 blades of priming. I shut off with the mag switch, but advance the throttle at the same time to avoid that problem. Ben On 9/7/2012 11:28 AM, Ryan Mueller wrote: > You're at idle when you turn off the mags, not bringing in much fuel > for a few seconds, how would that contribute to flooding? > > How do plugs get fouled if they are not sparking for a few seconds? > > Sure, if you turn off the fuel and want to wait until the engine > consumes the fuel in the bowl and dies, go ahead. Or just have SB 73 > done to the carb, and don't worry about it. > > > On Fri, Sep 7, 2012 at 10:09 AM, dgaldrich > wrote: > > > > > I seem to recall a knowledgeable person (the guy on the Bower's > list??) positing that flooding was caused by using the mags to > shut the engine down. Because the engine is still sucking fuel, > the plugs get fouled. He suggested shutting the engine down using > a fuel shutoff valve close to the carb fuel supply and opening the > throttle as it dies to get more air through. Also has the > advantage of stopping any dripping due to float level issues. > Something to think... > > Dave > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382596#382596 > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Subject: Steel Fittings and Prep questions
Date: Sep 08, 2012
I began cutting steel last night and I made my first Cabane fittings that will go on the Fuse to hold the center Cabanes onto the fuselage. Drilled the holes with a borrowed MicroLux mill so it is all accurate down to the .001 (sure makes it easy to just turn a crank handle ever so many turns to dial in a measurement!) I have been reading Tony B's chapter on fittings and have a few questions: He mentions having NO scratches on the steel, and to keep the edges of the steel rather sharp. I rounded the edges of the flat stock with the grinder. I hate to sound naive, but I am with steel: is rounded edges on the straps a problem? Polishing the faces of the steel: I bought a grinder that has 2 wheels- a rough and a fine wheel. BUT, the wheels are about 3/4" wide, and so I have used the side of the wheels to grind the round edges, otherwise I would get a series of 3/4" marks all down the side, and would not be smooth or consistant. So, what do you use to polish the FACE of the part to prep it for the Zinc paint? I got some very small marks in the steel from filing the edges off of the holes I drilled, so I'd like to polish them out. Nothing deep, just the standard scratches in the face of the steel when you run a file over it. Also, when fitting these to the fuselage, I am assuming the 2 holes that are drilled in the fuse to mount these fittings (again, to hold the center cabanes to the fuse) are drilled as such: the first hole at the bottom of the fitting is drilled through the side strut leading to the top longeron, and the second hole through the center line of the side of the top longeron. Is this correct? How far up should the 1/4" hole be above the top longeron to safely fit the cabane strut? I am comfortable with the wood, but haven't found my sea legs yet with the steel. However, I DO have 8 new fittings that look pretty good, I just need to figure how smooth to make them without over doing it! Thanks for the help. I feel these questions are a bit juvenile, but they caused me some angst last night whilst trying to fall asleep! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382682#382682 ________________________________________________________________________________
Subject: Re: Steel Fittings and Prep questions
Date: Sep 08, 2012
Rounded edges on the steel fittings is no problem. Polish them using a Scotchbrite wheel on your grinder. It is especially important to polish the edges before you do any bending. When drilling holes use an undersized twist drill and use a reamer for final hole sizing. Greg Cardinal ----- Original Message ----- From: "Mark Roberts" <mark.rbrts1(at)gmail.com> Sent: Saturday, September 08, 2012 1:47 PM Subject: Pietenpol-List: Steel Fittings and Prep questions > > > I began cutting steel last night and I made my first Cabane fittings that > will go on the Fuse to hold the center Cabanes onto the fuselage. Drilled > the holes with a borrowed MicroLux mill so it is all accurate down to the > .001 (sure makes it easy to just turn a crank handle ever so many turns to > dial in a measurement!) > > I have been reading Tony B's chapter on fittings and have a few questions: > > He mentions having NO scratches on the steel, and to keep the edges of the > steel rather sharp. I rounded the edges of the flat stock with the > grinder. I hate to sound naive, but I am with steel: is rounded edges on > the straps a problem? > > Polishing the faces of the steel: I bought a grinder that has 2 wheels- a > rough and a fine wheel. BUT, the wheels are about 3/4" wide, and so I have > used the side of the wheels to grind the round edges, otherwise I would > get a series of 3/4" marks all down the side, and would not be smooth or > consistant. So, what do you use to polish the FACE of the part to prep it > for the Zinc paint? I got some very small marks in the steel from filing > the edges off of the holes I drilled, so I'd like to polish them out. > Nothing deep, just the standard scratches in the face of the steel when > you run a file over it. > > Also, when fitting these to the fuselage, I am assuming the 2 holes that > are drilled in the fuse to mount these fittings (again, to hold the center > cabanes to the fuse) are drilled as such: the first hole at the bottom of > the fitting is drilled through the side strut leading to the top longeron, > and the second hole through the center line of the side of the top > longeron. Is this correct? How far up should the 1/4" hole be above the > top longeron to safely fit the cabane strut? > > I am comfortable with the wood, but haven't found my sea legs yet with the > steel. However, I DO have 8 new fittings that look pretty good, I just > need to figure how smooth to make them without over doing it! > > Thanks for the help. I feel these questions are a bit juvenile, but they > caused me some angst last night whilst trying to fall asleep! > > Mark > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382682#382682 > > > ________________________________________________________________________________
Date: Sep 08, 2012
Mark do you have any pics of the MicroLux in action?=0A=0ARyan=0A=0A=0A____ ____________________________=0A From: Mark Roberts <mark.rbrts1(at)gmail.com> =0ATo: pietenpol-list(at)matronics.com =0ASent: Saturday, September 8, 2012 2: 47 PM=0ASubject: Pietenpol-List: Steel Fittings and Prep questions=0A =0A-- =0A=0AI began cutting steel last night and I made my first Cabane fittings that will go on the Fuse to hold the center Cabanes onto the fuselage. Dril led the holes with a borrowed MicroLux mill so it is all accurate down to t he .001 (sure makes it easy to just turn a crank handle ever so many turns to dial in a measurement!)=0A=0AI have been reading Tony B's chapter on fit tings and have a few questions:=0A=0AHe mentions having NO scratches on the steel, and to keep the edges of the steel rather sharp. I rounded the edge s of the flat stock with the grinder. I hate to sound naive, but I am with steel: is rounded edges on the straps a problem?=0A=0APolishing the faces o f the steel: I bought a grinder that has 2 wheels- a rough and a fine wheel . BUT, the wheels are about 3/4" wide, and so I have used the side of the w heels to grind the round edges, otherwise I would get a series of 3/4" mark s all down the side, and would not be smooth or consistant. So, what do you use to polish the FACE of the part to prep it for the Zinc paint? I got so me very small marks in the steel from filing the edges off of the holes I d rilled, so I'd like to polish them out. Nothing deep, just the standard scr atches in the face of the steel when you run a file over it.=0A=0AAlso, whe n fitting these to the fuselage, I am assuming the 2 holes that are drilled in the fuse to mount these fittings (again, to hold the center cabanes to the fuse) are drilled as such: the first hole at the bottom of the fitting is drilled through the side strut leading to the top longeron, and the seco nd hole through the center line of the side of the top longeron. Is this co rrect? How far up should the 1/4" hole be above the top longeron to safely fit the cabane strut?=0A=0AI am comfortable with the wood, but haven't foun d my sea legs yet with the steel. However, I DO have 8 new fittings that lo ok pretty good, I just need to figure how smooth to make them without over doing it!=0A=0AThanks for the help. I feel these questions are a bit juveni le, but they caused me some angst last night whilst trying to fall asleep! =0A=0AMark=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.ma ============= ________________________________________________________________________________
Date: Sep 08, 2012
Mark, You mention polishing, then mention you have a grinder with a fine and coarse wheel... Several things come to mind here. First, a "grinder" is a nebulous term. You have a grinder motor (?) with a couple of grinding wheels on it most likely. Those wheels, coarse and fine, 3/4" wide, are most likely aluminum oxide wheels. They are good for actually shaping parts you are making, as well as "polishing" to the extent of maybe removing saw marks (hack saw, contour saw, horiz metal cutting saw, etc) from the edges of parts before you polish them. In the big scheme of things, those things are pretty coarse and generally leave a scratch pattern deep enough to create stress risers. Which is how they can shape metal. Things that polish, for the most part, don't change the shape of the metal significantly. So, what Greg mentions is a "scotchbrite" wheel. It'll look quite like the wheels on your "grinder", but it's made of a propietary stuff that really is just a fine abrasive that will take out grinder marks. Probably not quite aggressive enough to take out most saw marks. Does that make sense? Those scotchbrite wheels are about a hundred bucks, though they'll last for a dozen or so piets... You would mount it on your grinder, which is why I call "grinders" nebulous, because once you do that, it's kind of a polisher, ya know? Really, it's just a motor, what it does depends on what you have mounted on it. A quick safety note. Those gray aluminum oxide wheels aren't really meant to be used on the sides, though about everyone does. Just be careful and don't put a lot of pressure when using the sides. You can also use sanders to do the polishing you need for these metal fittings. They're called sanders because the most common use for them is to mount a belt of sandpaper and sand wood. However, you can get "sandpaper" in all sorts of configurations. Stuff specifically made to withstand the harshness of "sanding" metal, sufficiently fine, will do the same polishing as the scotchbrite wheel. Sufficiently coarse, will shape metal easily. The most common sanders for this sort of thing is a little benchtop sander that uses 1"x30" or 1"x42" belts, or one that uses a 4"x36" or 4"x48" belt, or ones that use various sized discs. Aluminum oxide sanding belts are generally used for woodworking (and are reddish) but will work. Better (and more expensive) are blue ones made of Zirconium Oxide. Coarse ones are good enough to shape metal, really fine ones do a grand job of polishing out saw marks and deep scratches left by the coarser belts (or grinding wheels). Google a company called Klingspor, or "the sanding company" for some great info on sanding products. So, generally, and for a quick efficient job, it's a couple of steps. Cut out the part (with some sort of saw). Do further shaping (files, grinders or coarse sanding belts). Use the same gizmo you used for "further shaping" to get ride of really coarse saw marks (or milling machine marks, whatever). Then use fine products (belts, scotchbrite wheels, or even really fine files) to just get rid of any obvious easily visible scratches. Keep in mind how you use any given method of sanding, or grinding (which are also merely methods of cutting) matters. A coarse medium applied randomly, will produce a smoother surface, hence the effectiveness of random orbit (or dual action) sanders. Although it's a bit deceiving. The size of the particle doing the cutting really is the governing factor. But when applied randomly, there aren't really any long deep straight scratches. Pay close attention when you use a file. When used one way, there's an obvious scratch pattern left behind (bad for stress risers and eventual cracks), but used another way (as in drawfiling) a smooth surface is left behind. The goal of all of this is to NOT leave behind a scratch pattern that is conducive to metal cracking with exposure to vibration (or while bending). If you keep that in mind, it makes more sense. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382688#382688 ________________________________________________________________________________
Date: Sep 08, 2012
Not yet, but I'll take some. I don't have it connected to any stepper motors to use it as a CNC, but I am thinking about it. Wouldn't be too hard... But, for just boring holes in a straight line, I am 'counting the turns' manually! :D I'll post some soon... aircamperace(at)yahoo.com wrote: > Mark do you have any pics of the MicroLux in action? > > > Ryan > > > From: Mark Roberts > To: pietenpol-list(at)matronics.com > Sent: Saturday, September 8, 2012 2:47 PM > Subject: Pietenpol-List: Steel Fittings and Prep questions > > > > I began cutting steel last night and I made my first Cabane fittings that will go on the Fuse to hold the center Cabanes onto the fuselage. Drilled the holes with a borrowed MicroLux mill so it is all accurate down to the .001 (sure makes it easy to just turn a crank handle ever so many turns to dial in a measurement!) > > I have been reading Tony B's chapter on fittings and have a few questions: > > He mentions having NO scratches on the steel, and to keep the edges of the steel rather sharp. I rounded the edges of the flat stock with the grinder. I hate to sound naive, but I am with steel: is rounded edges on the straps a problem? > > Polishing the faces of the steel: I bought a grinder that has 2 wheels- a rough and a fine wheel. BUT, the wheels are about 3/4" wide, and so I have used the side of the wheels to grind the round edges, otherwise I would get a series of 3/4" marks all down the side, and would not be smooth or consistant. So, what do you use to polish the FACE of the part to prep it for the Zinc paint? I got some very small marks in the steel from filing the edges off of the holes I drilled, so I'd like to polish them out. Nothing deep, just the standard scratches in the face of the steel when you run a file over it. > > Also, when fitting these to the fuselage, I am assuming the 2 holes that are drilled in the fuse to mount these fittings (again, to hold the center cabanes to the fuse) are drilled as such: the first hole at the bottom of the fitting is drilled through the side strut leading to the top longeron, and the second hole through the center line of the side of the top longeron. Is this correct? How far up should the 1/4" hole be above the top longeron to safely fit the cabane strut? > > I am comfortable with the wood, but haven't found my sea legs yet with the steel. However, I DO have 8 new fittings that look pretty good, I just need to figure how smooth to make them without over doing it! > > Thanks for the help. I feel these questions are a bit juvenile, but they caused me some angst last night whilst trying to fall asleep! > > Mark > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopicmatronics.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382689#382689 ________________________________________________________________________________
Date: Sep 08, 2012
Wow! Thanks guys for the good replies. I am doing some further research on the Scotch-Brite wheels mentioned and there appears to be a series of them. Not to beat a dead horse, as I bet all of them would work well, but do you have any idea which might e better at this on 4130 than perhaps another? Here are a couple of links on amazon: http://www.amazon.com/Scotch-Brite-Multi-Finishing-Wheel-PRICE-WHEEL/dp/B0006N7KZE http://www.amazon.com/Scotch-Brite-Deburring-Wheel-PRICE-WHEEL/dp/B0012ISZOM/ref=pd_sbs_indust_3 and finally: http://www.amazon.com/Scotch-Brite-Deburring-Wheel-PRICE-WHEEL/dp/B0012ISZOM/ref=pd_sbs_indust_3 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382690#382690 ________________________________________________________________________________
Date: Sep 08, 2012
BTW, Thanks Tools for the very detailed help... I am off to look for stuff at http://www.klingspor.com/ (Always wondered where the Klingons came from... This being the 46th anniversary of Star Trek) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382691#382691 ________________________________________________________________________________
Date: Sep 08, 2012
Mark, don't forget to very lightly chamfer/deburr any holes that you drill or ream in your steel fittings. This will also help prevent stress risers. -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382695#382695 ________________________________________________________________________________
Subject: Routed Rib Jig
Date: Sep 08, 2012
Here is a picture of our rib jig. We drew up the rib in autocad and had it routed it out on a cnc. The reason we came up with this ideas is being that my father and I are both building together we wanted to be able to both make ribs in our own garages at our leisure as we continue to focus on other parts of the build when we get together. We wanted to ensure that they where exactly the same. All the gusset areas are routed down about 1/32 so you can inlay and snap the bottom gussets in place, that way we can glue both sides of the rib up at once and complete a whole rib per night instead of just one side. After the first rib my dad came up with the clever idea of making a peg board to remove the completed rib once dry. -------- Fred Kim Pittsburgh, Pa Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382701#382701 Attachments: http://forums.matronics.com//files/gedc1585_135.jpg http://forums.matronics.com//files/gedc1564_957.jpg ________________________________________________________________________________
Date: Sep 08, 2012
J...F...C... Tools=2C write a book or something . . . . > Subject: Pietenpol-List: Re: Steel Fittings and Prep questions > From: n0kkj(at)yahoo.com > Date: Sat=2C 8 Sep 2012 13:22:15 -0700 > To: pietenpol-list(at)matronics.com > > > Mark=2C > > You mention polishing=2C then mention you have a grinder with a fine and coarse wheel... > > Several things come to mind here. First=2C a "grinder" is a nebulous ter m. You have a grinder motor (?) with a couple of grinding wheels on it mos t likely. Those wheels=2C coarse and fine=2C 3/4" wide=2C are most likely aluminum oxide wheels. They are good for actually shaping parts you are ma king=2C as well as "polishing" to the extent of maybe removing saw marks (h ack saw=2C contour saw=2C horiz metal cutting saw=2C etc) from the edges of parts before you polish them. > > In the big scheme of things=2C those things are pretty coarse and general ly leave a scratch pattern deep enough to create stress risers. Which is h ow they can shape metal. Things that polish=2C for the most part=2C don't change the shape of the metal significantly. > > So=2C what Greg mentions is a "scotchbrite" wheel. It'll look quite like the wheels on your "grinder"=2C but it's made of a propietary stuff that r eally is just a fine abrasive that will take out grinder marks. Probably n ot quite aggressive enough to take out most saw marks. Does that make sens e? > > Those scotchbrite wheels are about a hundred bucks=2C though they'll last for a dozen or so piets... You would mount it on your grinder=2C which is why I call "grinders" nebulous=2C because once you do that=2C it's kind of a polisher=2C ya know? Really=2C it's just a motor=2C what it does depend s on what you have mounted on it. > > A quick safety note. Those gray aluminum oxide wheels aren't really mean t to be used on the sides=2C though about everyone does. Just be careful a nd don't put a lot of pressure when using the sides. > > You can also use sanders to do the polishing you need for these metal fit tings. They're called sanders because the most common use for them is to m ount a belt of sandpaper and sand wood. However=2C you can get "sandpaper" in all sorts of configurations. Stuff specifically made to withstand the harshness of "sanding" metal=2C sufficiently fine=2C will do the same polis hing as the scotchbrite wheel. Sufficiently coarse=2C will shape metal eas ily. > > The most common sanders for this sort of thing is a little benchtop sande r that uses 1"x30" or 1"x42" belts=2C or one that uses a 4"x36" or 4"x48" b elt=2C or ones that use various sized discs. > > Aluminum oxide sanding belts are generally used for woodworking (and are reddish) but will work. Better (and more expensive) are blue ones made of Zirconium Oxide. Coarse ones are good enough to shape metal=2C really fine ones do a grand job of polishing out saw marks and deep scratches left by the coarser belts (or grinding wheels). > > Google a company called Klingspor=2C or "the sanding company" for some gr eat info on sanding products. > > So=2C generally=2C and for a quick efficient job=2C it's a couple of step s. Cut out the part (with some sort of saw). Do further shaping (files=2C grinders or coarse sanding belts). Use the same gizmo you used for "furth er shaping" to get ride of really coarse saw marks (or milling machine mark s=2C whatever). Then use fine products (belts=2C scotchbrite wheels=2C or even really fine files) to just get rid of any obvious easily visible scrat ches. > > Keep in mind how you use any given method of sanding=2C or grinding (whic h are also merely methods of cutting) matters. A coarse medium applied ran domly=2C will produce a smoother surface=2C hence the effectiveness of rand om orbit (or dual action) sanders. Although it's a bit deceiving. The siz e of the particle doing the cutting really is the governing factor. But wh en applied randomly=2C there aren't really any long deep straight scratches . > > Pay close attention when you use a file. When used one way=2C there's an obvious scratch pattern left behind (bad for stress risers and eventual cr acks)=2C but used another way (as in drawfiling) a smooth surface is left b ehind. > > The goal of all of this is to NOT leave behind a scratch pattern that is conducive to metal cracking with exposure to vibration (or while bending). > > If you keep that in mind=2C it makes more sense. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382688#382688 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 08, 2012
Hey guys, slightly off topic, but I am really impressed and grateful to be a part of this list.... Let me BRIEFLY (I tend to ramble) explain: Looked for years to decided what to build. Didn't look at the support groups or lists like this to determine what to build, but I should have. I have a link directly to this list that I use to log in. Tonight I had to log on via the forums.matronics.com site and navigate to this group. On the way I slowly scrolled through the main page of groups to see what other groups are active. I had NO idea that this group was far away the most active and helpful! Have you guys seen the difference in the amount of posts here versus the other popular builds? I was very surprised and very pleased. You know, it could be somewhat intimidating to see how much this forum is read, but you guys make it so comfortable to ask a question, and are so supportive and non-cliquish that I haven't thought about asking a question or two. I'd like to again say thanks for the help. So I'll be ordering a scotch-brite wheel soon. But until then, I sure appreciate the advice and moral support. I hope I can afford a Brodhead trip next year! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382715#382715 ________________________________________________________________________________
Date: Sep 08, 2012
Quick follow up on the first post question that I didn't see addressed is placement of the drilled holes for the cabana fittings: Also, when fitting these to the fuselage, I am assuming the 2 holes that are drilled in the fuse to mount these fittings (again, to hold the center cabanes to the fuse) are drilled as such: the first hole at the bottom of the fitting is drilled through the side strut leading to the top longeron, and the second hole through the center line of the side of the top longeron. Is this correct? How far up should the 1/4" hole be above the top longeron to safely fit the cabane strut? Thanks again. Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382718#382718 ________________________________________________________________________________
Date: Sep 09, 2012
Subject: landing gear
After looking at the Sky Scout and the Aircamper, today's question is: Would the landing gear used on the Sky Scout work on the Aircamper? Has anyone tried this, or is there a flaw/design issue that would not allow this to work? Joe Swithin Morris, IL ________________________________________________________________________________
Date: Sep 09, 2012
Oooo.A Sky-camper! You take advantage of the fact that TC has left the building, although I'm sure this is merely the Sunday morning musings of an idle mind. Joe - Please explain yourself before you invoke the wrath of his deputy, Safety Dan! I suspect that this falls into the category of 'some things you just don't do', like pee into the wind, or kick sand in Chuck Norris' face. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of JOSEPH SWITHIN Sent: Sunday, September 09, 2012 4:48 AM Subject: Pietenpol-List: landing gear After looking at the Sky Scout and the Aircamper, today's question is: Would the landing gear used on the Sky Scout work on the Aircamper? Has anyone tried this, or is there a flaw/design issue that would not allow this to work? Joe Swithin Morris, IL ________________________________________________________________________________
Date: Sep 09, 2012
I looked at doing this -(not the peeing into the wind part) - The vertical strut that goes up to the top longeron seems to be the problem for the airc amper. The point that it meets the longeron in the scout is braced horizon tally across the fuselage where as in the aircamper=2C it wouldn't be due t o the location of the front seat. Of course this was after looking at it f or 5-10 minutes so It's possible that I missed something and someone might be able to figure something out. Tom B. From: gboothe5(at)comcast.net Subject: RE: Pietenpol-List: landing gear Date: Sun=2C 9 Sep 2012 05:22:51 -0700 Oooo=85A Sky-camper! You take advantage of the fact that TC has left the bu ilding=2C although I=92m sure this is merely the Sunday morning musings of an idle mind. Joe ' Please explain yourself before you invoke the wrath o f his deputy=2C Safety Dan! I suspect that this falls into the category of =91some things you just don=92t do=92=2C like pee into the wind=2C or kick sand in Chuck Norris=92 face=85 Gary BootheNX308MB From: owner-pietenpol-li st-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of JOSEPH SWITHIN Sent: Sunday=2C September 09=2C 2012 4:48 AM Subject: Pietenpol-List: landing gear After looking at the Sky Scout and th e Aircamper=2C today's question is: Would the landing gear used on the Sky Scout work on the Aircamper? Has anyone tried this=2C or is there a flaw/de sign issue that would not allow this to work? Joe Swithin Morris=2C IL http://www.matronics.com/Navigator?Pietenpol-Listhttp://foru ms.matronics.comhttp://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 09, 2012
Mine are about a half inch I'd say (I'm not where the plane is now to check for sure). That upper hole being located on the centerline of the longeron should set things where they were designed to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382729#382729 ________________________________________________________________________________
Subject: Re: landing gear
Date: Sep 09, 2012
yep- been done Walter Argenbright- pics on west coast piet -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382732#382732 ________________________________________________________________________________
Date: Sep 09, 2012
Subject: First Flight of VH-XHE
Dear List, I am please to report that o n Monday 27th August at 0700, Aircamper VH-XHE took first flight with builder Graham Hewitt, aged 84, at the controls. The 20 minute flight was completed safely at Jandakot airport in Western Australia. This morning, 9th Sept at 0700, Graham took to the skies for a second time completing two circuits and landing safely on the grass strip adjacent to the runway. Those of you who have been on the list for a while may remember Graham. He started the project about 7 years ago. The Pietenpol being his third homebuilt. Graham is a retired airline pilot with many thousands of hours flying single and multi engine conventional U/C aircraft and holds a low level aerobatic rating. Graham's Aircamper is the long fuselage variant with Riblette 612 aerofoil and powered by an O-235 Lycoming. The wing, incorporating built-up spars and Piper style landing gear construction are from Jim Wills plans. Graham has also incorporated a door for the front seat. Empty weight at 740lbs, initial flight reports indicate an excellent ROC and 85 kts at 2500 RPM with a 68x45 prop and at 33 kts she was still flying but had a high ROD and wings stayed level. Initial flight problem was a nose heavy tendency possibly caused by wash-in at the tips of the stabiliser. This was corrected prior to the second flight however back stick was still required to keep the nose from dropping in level flight. To be resolved first before more extensive flight testing can continue. The wing is shifted back 2" from vertical and the CoG was with in range for the 612. See attached photo of VH-XHE resting after her second flight. Hopefully a video will be posted in time and I can provide updates as to flight performance, especially for those interested in the 612. Best regards, John Woods Perth, Western Australia ________________________________________________________________________________
Date: Sep 09, 2012
Subject: Re: what I would do differently, wing spars and other
things Kevin, you might consider putting an aluminum pan for the back seat.. It confrms to my bottom and is quiet comfy.. I did and it dropped me 1.5 inches. You might try and figure out how you can do it to the front pit. I have a cut out in the center section and that is where I anchor the front shoulder harness. It also gives the right angle. The aluminum pan is also suggested b Tony Bengelis. My center section fuel tank is 20.5 gallons and I drain from the front for flying downhill and a drain in the back for flying uphill. Both drains flow down with the tail on the ground to the gasculator. Cheers, Gardiner --- On Thu, 9/6/12, kevinpurtee wrote: > From: kevinpurtee <kevin.purtee(at)us.army.mil> > Subject: Pietenpol-List: Re: what I would do differently, wing spars and other things > To: pietenpol-list(at)matronics.com > Date: Thursday, September 6, 2012, 11:48 AM > --> Pietenpol-List message posted > by: "kevinpurtee" > > So Oscar, you know that despite the fact that I'm recovering > I can still kick your butt, right?:) > > Just kidding, of course. > > On the rebuild, we will do the following: > > - 3 piece wing, > - Use a Gary Boothe fuel tank (~16 gallons), > - Move the fuel tank filler port forward a little for ease > of refueling, > - Probably use the lightweight fabric as Jack mentioned, > - Slant the back seat back a little as Jack mentioned, > - Figure out a way to make Shelley more comfortable in the > front seat, raise the seat, figure out better cushions, > whatever, > - Maybe raise the turtle deck an inch? We'll see, > - Use fittings at the top of the rear cabanes as an attach > point for the front seat shoulder harness attach cable vs. > the through-the-cabane eyebolts we used, > - Maybe use a head rest to raise the back seat shoulder > harness, > - I loved the brakes, but need to figure out a way to quit > popping spokes. May just use Jack's design. > We'll see, > - Maybe a cutout in the wing? > - Add a sump to the fuel tank, of course.... > > I loved the airplane and it performed nicely. These > are changes for convenience (except for the sump in the fuel > tank, of course...). > > -------- > Kevin "Axel" Purtee > NX899KP > Austin/San Marcos, TX > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382508#382508 > > > > > > > > Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Sep 09, 2012
Excellent news, John and congratulations to Graham! It'll be interesting to get the flight data from the Riblett, although with an O-235, a barn door would produce a good climb rate. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of johnwoods(at)westnet.com.au Sent: Sunday, September 09, 2012 11:53 AM Subject: Pietenpol-List: First Flight of VH-XHE Dear List, I am please to report that on Monday 27th August at 0700, Aircamper VH-XHE took first flight with builder Graham Hewitt, aged 84, at the controls. The 20 minute flight was completed safely at Jandakot airport in Western Australia. This morning, 9th Sept at 0700, Graham took to the skies for a second time completing two circuits and landing safely on the grass strip adjacent to the runway. Those of you who have been on the list for a while may remember Graham. He started the project about 7 years ago. The Pietenpol being his third homebuilt. Graham is a retired airline pilot with many thousands of hours flying single and multi engine conventional U/C aircraft and holds a low level aerobatic rating. Graham's Aircamper is the long fuselage variant with Riblette 612 aerofoil and powered by an O-235 Lycoming. The wing, incorporating built-up spars and Piper style landing gear construction are from Jim Wills plans. Graham has also incorporated a door for the front seat. Empty weight at 740lbs, initial flight reports indicate an excellent ROC and 85 kts at 2500 RPM with a 68x45 prop and at 33 kts she was still flying but had a high ROD and wings stayed level. Initial flight problem was a nose heavy tendency possibly caused by wash-in at the tips of the stabiliser. This was corrected prior to the second flight however back stick was still required to keep the nose from dropping in level flight. To be resolved first before more extensive flight testing can continue. The wing is shifted back 2" from vertical and the CoG was with in range for the 612. See attached photo of VH-XHE resting after her second flight. Hopefully a video will be posted in time and I can provide updates as to flight performance, especially for those interested in the 612. Best regards, John Woods Perth, Western Australia ________________________________________________________________________________
Subject: Re: First Flight of VH-XHE
Date: Sep 09, 2012
Thank you for the info John. pass along to Graham a hearty congrats on a beautiful airplane. there are around 10 or so (that i know of) who are planning, building, or flying with the riblett wing. more are probably contemplating the option. I've been gathering info about the setup but would love to get as much info as possible so that we all can have our riblett piets setup correctly the first time if at all possible. with that said, I'd like to request the following details. 1. are the fore and aft cabane struts the same length? (angle of incidence) 2. what cg range is Graham using? 3. how much does he or who ever was flight testing weigh? 4. are the motor mounts extended beyond standard? 5. nose tank, wing tank, or both? and were they all filled for test flight? 6. starter? battery location? any other questions or enlightened facts that fellow Riblett piet builders would like to pass along would also be helpful. Hopefully you guys down under can give us the down low. Thanks; Paul pauldonahuepilot(at)yahoo.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382749#382749 ________________________________________________________________________________
Date: Sep 09, 2012
Oh yea; here's another; 7. did Graham build in any dihedral or washout? Thanks; Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382750#382750 ________________________________________________________________________________
Date: Sep 09, 2012
Thanks Tools! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382754#382754 ________________________________________________________________________________
Date: Sep 09, 2012
Joe You mean something like this? One thing you learn after being involved with Pietenpol for a while is, if you can think of it someone already tried it. Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of JOSEPH SWITHIN Sent: Sunday, September 09, 2012 4:48 AM Subject: Pietenpol-List: landing gear After looking at the Sky Scout and the Aircamper, today's question is: Would the landing gear used on the Sky Scout work on the Aircamper? Has anyone tried this, or is there a flaw/design issue that would not allow this to work? Joe Swithin Morris, IL ________________________________________________________________________________
Date: Sep 09, 2012
An exception I can think of is if you're making wood struts or something and designed those fittings differently than original and need the hole a little further away from the longeron or something. Also, there's a BUNCH of fittings on the plans for brace wiring where the hole really isn't far enough away from the fuse to allow putting in the clevis pin in the correct orientation (ie from the top) or easily. Knowing this ahead of time and making them a tad longer (sometimes as little as a 1/4") would make a world of difference. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382762#382762 ________________________________________________________________________________
Date: Sep 09, 2012
kevinpurtee wrote: > When you take your hand drill and use a technique called "wallering" to get the bolts to go through... Man ain't this the truth! In all fairness, will probably have to "waller" a bit less though. waller (n. wall-er latin) 1. art of making bolts fit close tolerance holes sp. wallo, wallos, wallamos, wallas, wallan Is it too late to get this in the Tony B. glossary of homebuilding terms? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382763#382763 ________________________________________________________________________________
Date: Sep 09, 2012
You're just custom fitting each hole to the bolt....picking up the slack from the manufacturing tolerances....ahem Sent from my iPhone On Sep 9, 2012, at 3:45 PM, tools wrote: > > > kevinpurtee wrote: >> When you take your hand drill and use a technique called "wallering" to get the bolts to go through... > > > Man ain't this the truth! In all fairness, will probably have to "waller" a bit less though. > > waller (n. wall-er latin) 1. art of making bolts fit close tolerance holes > > sp. wallo, wallos, wallamos, wallas, wallan > > Is it too late to get this in the Tony B. glossary of homebuilding terms? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=382763#382763 > > ________________________________________________________________________________
Date: Sep 09, 2012
Pietenwhatinthheckisthat? I like his cargo pods on the lift struts, though. -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382768#382768 ________________________________________________________________________________
Date: Sep 09, 2012
It is great to hear of all these success stories. Gary in California=2C no w another new one. Good stuff!!! Mike Groah is back in the air with his i n California as well. From: pietflyr(at)bellsouth.net Subject: RE: Pietenpol-List: First Flight of VH-XHE Date: Sun=2C 9 Sep 2012 14:02:58 -0400 Excellent news=2C John and congratulations to Graham! It=92ll be interesti ng to get the flight data from the Riblett=2C although with an O-235=2C a b arn door would produce a good climb rate. Jack Phillips NX899JP Smith Mountain Lake=2C Virginia From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of johnwoods(at)westnet.com.au Sent: Sunday=2C September 09=2C 2012 11:53 AM Subject: Pietenpol-List: First Flight of VH-XHE Dear List=2C I am please to report that on Monday 27th August at 0700=2C Aircamper VH-XH E took first flight with builder Graham Hewitt=2C aged 84=2C at the control s. The 20 minute flight was completed safely at Jandakot airport in Western Au stralia. This morning=2C 9th Sept at 0700=2C Graham took to the skies for a second t ime completing two circuits and landing safely on the grass strip adjacent to the runway. Those of you who have been on the list for a while may remember Graham. He started the project about 7 years ago. The Pietenpol being his third homebu ilt. Graham is a retired airline pilot with many thousands of hours flying singl e and multi engine conventional U/C aircraft and holds a low level aerobati c rating. Graham's Aircamper is the long fuselage variant with Riblette 612 aerofoil and powered by an O-235 Lycoming. The wing=2C incorporating built-up spars and Piper style landing gear const ruction are from Jim Wills plans. Graham has also incorporated a door for t he front seat. Empty weight at 740lbs=2C initial flight reports indicate an excellent ROC and 85 kts at 2500 RPM with a 68x45 prop and at 33 kts she was still flying but had a high ROD and wings stayed level. Initial flight problem was a nose heavy tendency possibly caused by wash-in at the tips of the stabiliser. This was corrected prior to the second flight however back stick was still required to keep the nose from dropping in level flight. To be resolved fir st before more extensive flight testing can continue. The wing is shifted back 2" from vertical and the CoG was with in range for the 612. See attached photo of VH-XHE resting after her second flight. Hopefully a video will be posted in time and I can provide updates as to fl ight performance=2C especially for those interested in the 612. Best regards=2C John Woods Perth=2C Western Australia ________________________________________________________________________________
Date: Sep 09, 2012
Actually when I was working at General Dynamics, I learned that the correct terminology is to "Obligate" the hole, so that it's obligated to accept the bolt. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Sunday, September 09, 2012 4:41 PM Subject: Pietenpol-List: Re: Steel Fittings and Prep questions kevinpurtee wrote: > When you take your hand drill and use a technique called "wallering" to get the bolts to go through... Man ain't this the truth! In all fairness, will probably have to "waller" a bit less though. waller (n. wall-er latin) 1. art of making bolts fit close tolerance holes sp. wallo, wallos, wallamos, wallas, wallan Is it too late to get this in the Tony B. glossary of homebuilding terms? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382763#382763 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Sep 09, 2012
Billy, I believe "the ordnance" are actually small cargo compartments. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382773#382773 ________________________________________________________________________________
From: "Daniel Engelkenjohn" <mushface1(at)gmail.com>
Subject: bottom fitting plate
Date: Sep 09, 2012
On pg. 3 of the plans in the lower left corner =9Cbottom fitting plate=9D that goes on the bottom of the fuselage. My question: should the 5/16=9D holes be 28 3/4=9D apart, as that would be the center to center width of the wing spars? Dennis ________________________________________________________________________________
Date: Sep 09, 2012
Check out the RV-10 list sometime. What a bunch of whiners! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Mark Roberts Sent: Sunday, September 09, 2012 12:52 AM Subject: Pietenpol-List: Re: Steel Fittings and Prep questions Hey guys, slightly off topic, but I am really impressed and grateful to be a part of this list.... Let me BRIEFLY (I tend to ramble) explain: Looked for years to decided what to build. Didn't look at the support groups or lists like this to determine what to build, but I should have. I have a link directly to this list that I use to log in. Tonight I had to log on via the forums.matronics.com site and navigate to this group. On the way I slowly scrolled through the main page of groups to see what other groups are active. I had NO idea that this group was far away the most active and helpful! Have you guys seen the difference in the amount of posts here versus the other popular builds? I was very surprised and very pleased. You know, it could be somewhat intimidating to see how much this forum is read, but you guys make it so comfortable to ask a question, and are so supportive and non-cliquish that I haven't thought about asking a question or two. I'd like to again say thanks for the help. So I'll be ordering a scotch-brite wheel soon. But until then, I sure appreciate the advice and moral support. I hope I can afford a Brodhead trip next year! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382715#382715 ________________________________________________________________________________
Date: Sep 10, 2012
List, A correction to my report on Graham's engine of choice. It is a Continental O-200. To those with inquiring minds, I will pass the questions on to Graham for answers. Best regards, > John Woods Perth , Western Australia > ________________________________________________________________________________
Date: Sep 09, 2012
Hey guys, slightly off topic, but I am really impressed and grateful to be a part of this list.... Let me BRIEFLY (I tend to ramble) explain: Looked for years to decided what to build. Didn't look at the support groups or lists like this to determine what to build, but I should have. I have a link directly to this list that I use to log in. Tonight I had to log on via the forums.matronics.com site and navigate to this group. On the way I slowly scrolled through the main page of groups to see what other groups are active. I had NO idea that this group was far away the most active and helpful! Have you guys seen the difference in the amount of posts here versus the other popular builds? I was very surprised and very pleased. You know, it could be somewhat intimidating to see how much this forum is read, but you guys make it so comfortable to ask a question, and are so supportive and non-cliquish that I haven't thought about asking a question or two. I'd like to again say thanks for the help. So I'll be ordering a scotch-brite wheel soon. But until then, I sure appreciate the advice and moral support. I hope I can afford a Brodhead trip next year! Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382782#382782 ________________________________________________________________________________
Date: Sep 09, 2012
That's how I installed mine. Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Daniel Engelkenjohn Sent: Sunday, September 09, 2012 5:43 PM Subject: Pietenpol-List: bottom fitting plate On pg. 3 of the plans in the lower left corner "bottom fitting plate" that goes on the bottom of the fuselage. My question: should the 5/16" holes be 28 3/4" apart, as that would be the center to center width of the wing spars? Dennis ________________________________________________________________________________
Date: Sep 09, 2012
She's a beauty, mate! Glad to hear that the first flights have been safe and successful so far. Carry on! It will be of great interest to all on this list to hear how the airplane handles and performs with the Riblett. The more data that can be carefully acquired while flight testing, the better. In fact, I'll bet that Doc Mosher would welcome a semi-technical article for the BPA Newsletter on performance with the Riblett vs. the tried-and-true Pietenpol wing. In this case, the best comparison would be between O-200 powered Piets, but any data would be good. Stall speed, cruise speed, time to climb, speed vs. RPM, trim force required. Input! Data points! Once the initial rigging tweaks are made and the test pilot is comfortable with the airplane, it would be nice to see data start coming in. I note that the aileron horns have lightening holes in them, thus I assume that they were not fabricated as hollow airfoil shapes as the plans call for, but rather from flat metal stock. Are they aluminum? Cheers! -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382783#382783 ________________________________________________________________________________
Date: Sep 09, 2012
Subject: Re: First Flight of VH-XHE?????//
hi Oscar were I cand see these video jorge from hanford=0A=0A=0AFrom: taild rags =0ATo: pietenpol-list(at)matronics.com =0ASent: Su nday, September 9, 2012 9:37 PM=0ASubject: Pietenpol-List: Re: First Flight s(at)hotmail.com>=0A=0AShe's a beauty, mate!- Glad to hear that the first fl ights have been safe and successful so far.- Carry on!=0A=0AIt will be of great interest to all on this list to hear how the airplane handles and pe rforms with the Riblett.- The more data that can be carefully acquired wh ile flight testing, the better.- In fact, I'll bet that Doc Mosher would welcome a semi-technical article for the BPA Newsletter on performance with the Riblett vs. the tried-and-true Pietenpol wing.- In this case, the be st comparison would be between O-200 powered Piets, but any data would be g ood.- Stall speed, cruise speed, time to climb, speed vs. RPM, trim force required.- Input!- Data points!- Once the initial rigging tweaks are made and the test pilot is comfortable with the airplane, it would be nice to see data start coming in.=0A=0AI note that the aileron horns have light ening holes in them, thus I assume that they were not fabricated as hollow airfoil shapes as the plans call for, but rather from flat metal stock.- Are they aluminum?=0A=0ACheers!=0A=0A--------=0AOscar Zuniga=0AMedford/Ashl and, OR=0AAir Camper NX41CC "Scout"=0AA75 power=0A=0A=0A=0A=0ARea d this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p =========================0A == ________________________________________________________________________________
Date: Sep 09, 2012
I vote for this one! I bet they used it on sailing ships when the gronicle just refused to fit the binnicle gimp. Clif The Early Bird may get the worm but the second mouse gets the cheese. > > Actually when I was working at General Dynamics, I learned that the > correct > terminology is to "Obligate" the hole, so that it's obligated to accept > the > bolt. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia ________________________________________________________________________________
Date: Sep 10, 2012
Subject: Landing Gear
Thanks for the info and photos. I knew I would get some great intel form th is group. (I also factored in more good natured abuse.)=0A-=0AJoe Swithin =0AMorris, IL=0AHunting and Gathering Mode ________________________________________________________________________________
Date: Sep 10, 2012
Subject: Mtn Piet wing repair update
Hey Guys, Here's a quick update: This weekend I covered the center section (see attached photos). I switched from Poly Fiber to Stewart Systems. I met Rick (last name Schreiber I think) at Brodhead this year, and he sold me on the Stewart Systems covering process. Because of the fumes from the Poly Fiber products, I was planning to move the wing out of the basement and into the barn. This presented a hold up until I made the barn suitable for wing work. There are no fumes with the Stewart Systems stuff, so I'm carrying on with the covering process in our basement. This saved a bunch of work for me. Thank you Rick!! By the way, I'll make someone a good deal on some unopened Poly Fiber products. Paint will be latex to match the rest of the plane. John Dilatush (Mtn Piet builder) used latex with a flexing agent additive. Another plug for Stewart Systems - The 6 disk video set is very good, and I've spoken with Dan Stewart a couple of times. He's patient and very willing to help. Overall, I'm pleased with the result so far. I still have to apply finish tape around the edges. The trailing edge cutout was a challenge. Hope it looks ok when painted. -- Greg Bacon ________________________________________________________________________________
Date: Sep 10, 2012
For the curious minds, Graham has provided the following information: Re cabanes: I will measure these but were cut to give exact incidence Harry Riblett stated. i.e. one degree positive. Ribletts C/G range is Fwd limit 18% MAC or 10.8 inches from Wing LE Aft limit 28 % MAC or 16.8 inches from Wing LE But for initial first flight he suggest an Aft limit of 25% or 15 inches then move in increment to 28% Really looking fwd to doing more on stalls but not till the trim prob is resolved & the ASI is checked out properly I weigh 85 Kgs & had 45 litres of fuel for the first flight so the AUW would have been close to 970 Lbs Motor mount extended 1.5 inches Fuel tank in nose holds 62 Lts. 45 lts for initial flight Starter is a very heavy Delco Remy weighs 17 lbs mounted rear housing of 0200 engine suggest a lite weight B&C Tail wheel a very heavy 6 inch Swivel from AC Spruce. Battery small Odyesy mounted on fire wall Booster pump fitted as gravity flow was marginal when near empty small Alternator fitted to fuel pump pad of 0200 Wing has 1 degree dihedral & 1 degree of wash out so far seems to be very docile with no sign of much sink after stall but early days here The only other Piet I have flown is the original Scout with model A built by Bernie in 1934 now based in Perth would you believe. Should have some pics & U Tube soon if any one wishes to email me direct. grhewitt(at)globaldial.com Regards Graham remember this Piet has less than one hours flight time so all data very provisional. To answer Oscar's question, the control horns are flat 4130 I believe. The aileron horns pass through as per original plans but the rudder and elevator horns are bolted onto the outside surfaces. Best regards, John Woods Perth Western Australia ----- "taildrags" wrote: She's a beauty, mate! Glad to hear that the first flights have been safe and successful so far. Carry on! It will be of great interest to all on this list to hear how the airplane handles and performs with the Riblett. The more data that can be carefully acquired while flight testing, the better. In fact, I'll bet that Doc Mosher would welcome a semi-technical article for the BPA Newsletter on performance with the Riblett vs. the tried-and-true Pietenpol wing. In this case, the best comparison would be between O-200 powered Piets, but any data would be good. Stall speed, cruise speed, time to climb, speed vs. RPM, trim force required. Input! Data points! Once the initial rigging tweaks are made and the test pilot is comfortable with the airplane, it would be nice to see data start coming in. I note that the aileron horns have lightening holes in them, thus I assume that they were not fabricated as hollow airfoil shapes as the plans call for, but rather from flat metal stock. Are they aluminum? Cheers! -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382783#382783 ________________________________________________________________________________
Date: Sep 10, 2012
For the curious minds, Graham has provided the following information: blah blah blah..... Wing has 1 degree dihedral & 1 degree of wash out so far seems to be very docile with no sign of much sink after stall but early days here 1 degree puts the tip approx 2-3/4" higher than the root at around 13 feet....is the dihedral pretty noticiable or just barely or what's your opinion? Regards and congrats to Graham! ________________________________________________________________________________
Date: Sep 10, 2012
Subject: Re: Mtn Piet wing repair update
As usual, the postings here are quite timely as I moved my CS into the shop and will start the covering process of it in a few days. Greg, it appears that you glued all of the fabric to the CS, is that correc t? Did you shrink any of it? I have used the Ekobond on all of my fabric so far and agree...good stuff a nd I will use nothing else. CS looks really nice. If the parts look that nice in bare fabric, you can i magine how nice after paint! Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com --- On Mon, 9/10/12, Greg Bacon wrote: From: Greg Bacon <gbacon67(at)gmail.com> Subject: Pietenpol-List: Mtn Piet wing repair update Date: Monday, September 10, 2012, 9:42 AM Hey Guys, Here's a quick update: This weekend I covered the center section (see attached photos). -I switc hed from Poly Fiber to Stewart Systems. -I met Rick (last name Schreiber I think) at Brodhead this year, and he sold me on the Stewart Systems cover ing process. -Because of the fumes from the Poly Fiber products, I was pl anning to move the wing out of the basement and into the barn. -This pres ented a hold up until I made the barn suitable for wing work. -There are no fumes with the Stewart Systems stuff, so I'm carrying on with the coveri ng process in our basement. -This saved a bunch of work for me. -Thank you Rick!! -By the way, I'll make someone a good deal on some unopened Po ly Fiber products. -Paint will be latex to match the rest of the plane. -John Dilatush (Mtn Piet builder) used latex with a flexing agent additiv e. -Another plug for Stewart Systems - The 6 disk video set is very good, and I've spoken with Dan Stewart a couple of times. -He's patient and ve ry willing to help.=0A Overall, I'm pleased with the result so far. -I still have to apply finis h tape around the edges. -The trailing edge cutout was a challenge. -Ho pe it looks ok when painted. =0A-- Greg Bacon =0A=0A ________________________________________________________________________________
Date: Sep 10, 2012
Mike, yes all the fabric is 100% glued to the wood. And yes, I did run the iron (light heat 250F) over it to remove wrinkles. This is how Dan Stewart described the procedure to me (this is not in the video). And he recommended I use the 1.87 oz fabric as it is easier when covering wood surfaces and looks better. Dilute the Ekobond 5% with distilled water. Coat all wood you are about to cover. Let dry for a few minutes till it is tacky. Apply the fabric. It will cling to the tacky surface. On areas that were a bit too dry, I used the iron to tack it in place. When everything was smoothed out and tacked in place, I ironed out the wrinkles or creases in the fabric that came from being folded up. Next, I applied the 5% diluted Ekobond to the top of the fabric, wiping off the excess with a paper towel. The wiping has to be fairly frequent as the Ekobond dries quickly. In my case, I covered an area about the size of a dinner plate then wiped excess. Wait too long and you will get stringers. Finally, let dry then trim excess fabric. Greg On Mon, Sep 10, 2012 at 10:49 AM, Michael Perez wrote: > As usual, the postings here are quite timely as I moved my CS into the > shop and will start the covering process of it in a few days. > > Greg, it appears that you glued all of the fabric to the CS, is that > correct? Did you shrink any of it? > > I have used the Ekobond on all of my fabric so far and agree...good stuff > and I will use nothing else. > > CS looks really nice. If the parts look that nice in bare fabric, you can > imagine how nice after paint! > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > --- On *Mon, 9/10/12, Greg Bacon * wrote: > > > From: Greg Bacon <gbacon67(at)gmail.com> > Subject: Pietenpol-List: Mtn Piet wing repair update > To: pietenpol-list(at)matronics.com > Date: Monday, September 10, 2012, 9:42 AM > > > Hey Guys, > > Here's a quick update: > > This weekend I covered the center section (see attached photos). I > switched from Poly Fiber to Stewart Systems. I met Rick (last name > Schreiber I think) at Brodhead this year, and he sold me on the Stewart > Systems covering process. Because of the fumes from the Poly Fiber > products, I was planning to move the wing out of the basement and into the > barn. This presented a hold up until I made the barn suitable for wing > work. There are no fumes with the Stewart Systems stuff, so I'm carrying > on with the covering process in our basement. This saved a bunch of work > for me. Thank you Rick!! By the way, I'll make someone a good deal on > some unopened Poly Fiber products. Paint will be latex to match the rest > of the plane. John Dilatush (Mtn Piet builder) used latex with a flexing > agent additive. Another plug for Stewart Systems - The 6 disk video set is > very good, and I've spoken with Dan Stewart a couple of times. He's > patient and very willing to help. > > Overall, I'm pleased with the result so far. I still have to apply finish > tape around the edges. The trailing edge cutout was a challenge. Hope it > looks ok when painted. > > -- > Greg Bacon > > > * > > * > > -- Greg Bacon ________________________________________________________________________________
Date: Sep 10, 2012
Copy- Greg, thanks!- Does not sound too different than covering the oth er parts.- I may get started on the CS this weekend...I am just now start ing to reassemble the mags and carburetor. Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com =0A ________________________________________________________________________________
Date: Sep 10, 2012
things
Regarding useful mods to the pietenpol fuselage: >From sitting in the pilot's seat with a light winter jacket on, it seemed very tight in the shoulders. Therefore I am widening the cockpit at that point by keeping the fuselage the full 24 inch width until it reaches the pilot's seatback, and then narrowing to the tail. (Vi Kapler said this should work fine, and it does not add as much weight as widening the whole fuselage.) Also to help the w&b, and give more legroom in the front pit and the baggage compartment, we are moving the corvair motor 4 inches forward by moving the firewall four inches ahead. But I am just getting ready to assemble the fuselage from the two sides I have built, so this recommendation is only worth what you are paying for it. John Fay in Peoria ________________________________________________________________________________
Date: Sep 10, 2012
John Woods wrote: > The only other Piet I have flown is the original Scout with model A built by Bernie in 1934 now based in Perth would you believe. > No, I would not believe... because the original was built in 1931 and had a Model T. In fact, it made a stop at Brodhead this year on it's way to the Ford Museum. Perhaps you meant "an" original, not "the" original? :-) -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382828#382828 ________________________________________________________________________________
Date: Sep 10, 2012
Oh yeah, congratulations on getting another Piet in the air! -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382829#382829 ________________________________________________________________________________
Date: Sep 10, 2012
>1 degree puts the tip approx 2-3/4" higher than the root at around 13 feet....is the dihedral pretty noticiable Jim: Scout has the dihedral set where the tips are 3" higher than the roots and it's noticeable, but not excessive. See how noticeable it is by looking at the top three pictures here: http://www.flysquirrel.net/piets/CorkyPiet.html -------- Oscar Zuniga Medford/Ashland, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=382843#382843 ________________________________________________________________________________
Date: Sep 10, 2012
thanks Oscar....well, that doesn't seem too bad. 3" just sounds like a lot. appreciate it.... -----Original Message----- >From: taildrags <taildrags(at)hotmail.com> >Sent: Sep 10, 2012 10:34 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Re: First Flight of VH-XHE > > >>1 degree puts the tip approx 2-3/4" higher than the root at around 13 feet....is the dihedral pretty noticiable > >Jim: Scout has the dihedral set where the tips are 3" higher than the roots and it's noticeable, but not excessive. See how noticeable it is by looking at the top three pictures here: > > http://www.flysquirrel.net/piets/CorkyPiet.html > >-------- >Oscar Zuniga >Medford/Ashland, OR >Air Camper NX41CC "Scout" >A75 power > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=382843#382843 > > ________________________________________________________________________________
Date: Sep 11, 2012
Subject: Re: Steel Fittings and Prep questions
I'm with you Oscar! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
From: "John Greenlee" <jmgreenlee(at)sbcglobal.net>
Subject: wing hoist
Date: Sep 12, 2012
Hello all, I need to hoist a set of (covered) Piet wings into the rafters of my hangar for some mid term storage. Any advice on how/how not to do this so that I can get them up and down without damage? Thx! JMG ________________________________________________________________________________
From: "Scott Knowlton " <flyingscott_k(at)hotmail.com>
Date: Sep 12, 2012
Subject: Re: wing hoist
If you have sufficient space above might I suggest you build a rolling wing stand (EAA has plans as does Tony B). Put two large bolted eyelits on the top of the stand either side and hoist the entire works with the wings on up into the rafters. Worked great for a set of wings for me and I am able to break down the wing stand. It has been loaned out to other builders on occasion. Less than a hundred bucks of wood and hardware to build. Scott Knowlton -----Original Message----- From: John Greenlee <jmgreenlee(at)sbcglobal.net> Date: Wed, 12 Sep 2012 15:27:28 Subject: Pietenpol-List: wing hoist Hello all, I need to hoist a set of (covered) Piet wings into the rafters of my hangar for some mid term storage. Any advice on how/how not to do this so that I can get them up and down without damage? Thx!
August 23, 2012 - September 12, 2012
Pietenpol-Archive.digest.vol-lk
