Pietenpol-Archive.digest.vol-mv
August 15, 2013 - August 25, 2013
      A75 power
      http://forums.matronics.com/viewtopic.php?p=406767#406767
Date: Aug 15, 2013
Subject: Re: step forward
Oscar, Okay, my apologies. Here's the head on top. I'll have to figure out where to hang those other gizmos you mention. Maybe Uncle Tony has some ideas for those :o) Ken On Thu, Aug 15, 2013 at 10:11 AM, taildrags wrote: > > Ken; shouldn't the head be on top? And where's the water pump and coolant > hoses? ;o) > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406767#406767 > > ________________________________________________________________________________
Subject: center flop hinges
Date: Aug 15, 2013
Earlier, I posted that I was reworking the hinge on my centersection flop. Since there has been discussion about piano hinges and mounting them (ailerons), I'll mention the reason why I'm redoing the hinge on the flop. The hinge is presently aluminum and the mounting holes were countersunk to receive flat-head screws, leaving everything flush. The result of countersinking the holes was that the aluminum got quite thin and the holes got very close to the edges of the hinge. When the flop is flopped and care is not taken, or if a breeze catches it in the flopped position, it can bounce and really put a strain on the edges of the holes. Several of the screws in my hinge had pulled through the metal because of this. I am replacing the aluminum hinge with a stainless steel one (from McMaster Carr) and re-mounting it with standard truss head AN526 machine screws into the nutplates. As several others have noted, there is no need for the screw heads to be countersunk if the screws are staggered on the two sides of the hinge such that they don't directly oppose one another... the hinge will not close tightly enough to require that the screw heads be flush. I don't know if anyone else has experienced pull-through on their flop hinges, but I have and I hope the steel hinge and no countersinking will cure that. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406769#406769 ________________________________________________________________________________
Subject: Re: Dynamic balancing ?
Date: Aug 15, 2013
There is nothing exact about hand carving a prop. Without going into detail, once the two blades are carved, on can only hope that they are very close to each other in thrust. There are an infinite number of ways to be off. To focus on thousands of an inch is a waste of time. After all the careful work, the only thing that counts is how well the prop performs. That applies to both hand carved and machine carved props, as various prop makers have different ways of measuring pitch. The reason for my comment was two-fold: 1) Real World: Most hand-carved prop makers have not had, and do not have precision machine equipment. Center hole is drilled on a drill press, which, at the best, will be squared and leveled with a t-square and/or a bubble level. 2) Two bladed hand carved props are difficult enough, and have always been balanced by eye. On a 1-10 scale of difficulty, Dan's 4-bladed prop is a....15! The very fact that he figured out how to get all of that through a band saw is incredible! The fact that it balances at all is a monumental success! Yet you choose to focus on the type of bubble level he used...therefore, my remark, "Are you kidding?" Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Thursday, August 15, 2013 7:32 AM Subject: Pietenpol-List: Re: Dynamic balancing ? Usually props are put on dummy hub and balanced on balancing ways. That's how they were balanced in the 30's, when they were ALL hand carved. Still, balance is balance, if you want a prop to run smoothly, it has to be balanced. The hub placed level requires EXTREME precision as there is very little movement for a significant change in balance. A good and simple system, but to be as effective as a balancing way system, that little vial has to be pretty decently manufactured. The balancing way system requires a more accurate hub. As with everything in life, it's always something... So, no, I'm not kidding. I will build a prop, not sure what that has to do with how to balance something effectively. What did I miss there? I have machined multi bolt hole patterns concentric with a precision hub for vertical head adapters for milling machines, the functional equivalent of a prop hub... does that count? I have also carved and balanced wood systems, large flat belt pulleys for line shaft driven machines... Not sure what part of the system I apparently don't have any knowledge about to apply the subject matter information to. Perhaps you do and can add to the discussion? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406758#406758 ________________________________________________________________________________
Date: Aug 15, 2013
After correcting the prop tracking and re-torqueing the prop bolts on Scout's wooden prop, I performed a dynamic balance using the DynaVibe instrument and procedure. Scout's prop balancing was written up in the current issue of Contact! Magazine, but that is irrelevant to my post. I agree with the "just do your best and go fly" when it comes to these airplanes, but being an engineer and having the instrument available to me, I just had to do it anyway. In order to get the engine/prop in better dynamic balance, I ended up fabricating a fairly considerable steel plate that is mounted under two of the prop bolts. My engine is an A75 with the flanged prop hub, not the tapered shaft. I called it good enough when I got the dynamic acceleration down to about 0.1 ips. With that said, I will also mention that I have since moved the airplane from hot and humid south Texas to milder and drier southern Oregon, so I have no expectation of the propeller tracking or bolt torque still being good, and I also have no expectation that the dynamic balance will be the same as it was when I made the adjustments. However, I do expect the out-of-balance to be minor once I deal with the prop tracking and bolt torques. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406773#406773 ________________________________________________________________________________
Date: Aug 15, 2013
Good work Ken. I can come up there and provide moral support on your first startup, it was great having Mr. Markle around for mine. rick h On Thu, Aug 15, 2013 at 9:30 AM, Ken Bickers wrote: > Another step forward. Tuesday, I mounted the motor on the fuselage for > the very first time. Lots of steps still to go. > > Cheers, Ken > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: step forward
Date: Aug 15, 2013
Nice, Ken! I'm assuming you have weight in the tail. I lived in perpetual fear that the weight would somehow slip out and the whole thing would nose over.. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Ken Bickers Sent: Thursday, August 15, 2013 8:30 AM Subject: Pietenpol-List: step forward Another step forward. Tuesday, I mounted the motor on the fuselage for the very first time. Lots of steps still to go. Cheers, Ken ________________________________________________________________________________
Date: Aug 15, 2013
Rick, thanks. I'll take you up on that offer. I still have a fair amount of work to go before the first run. I've just about finished fabricating the intake pipes. I think that only leaves exhaust, electricals, ignition, fuel, controls, baffling, cowlings ... Oh yeah, and prop balancing. Cheers, Ken On Thu, Aug 15, 2013 at 10:34 AM, Rick Holland wrote: > Good work Ken. I can come up there and provide moral support on your first > startup, it was great having Mr. Markle around for mine. > > rick h > > > On Thu, Aug 15, 2013 at 9:30 AM, Ken Bickers wrote: > >> Another step forward. Tuesday, I mounted the motor on the fuselage for >> the very first time. Lots of steps still to go. >> >> Cheers, Ken >> > > > -- > Rick Holland > Castle Rock, Colorado > NX6819Z > > > * > > * > > ________________________________________________________________________________
Date: Aug 15, 2013
Gary, yep. Two FAA certified 40 pound dumbbells, each attached separately. Ken On Thu, Aug 15, 2013 at 10:51 AM, Ken Bickers wrote: > Rick, thanks. I'll take you up on that offer. I still have a fair amount > of work to go before the first run. I've just about finished fabricating > the intake pipes. I think that only leaves exhaust, electricals, ignition, > fuel, controls, baffling, cowlings ... Oh yeah, and prop balancing. > Cheers, Ken > > > On Thu, Aug 15, 2013 at 10:34 AM, Rick Holland wrote: > >> Good work Ken. I can come up there and provide moral support on your >> first startup, it was great having Mr. Markle around for mine. >> >> rick h >> >> >> On Thu, Aug 15, 2013 at 9:30 AM, Ken Bickers wrote: >> >>> Another step forward. Tuesday, I mounted the motor on the fuselage for >>> the very first time. Lots of steps still to go. >>> >>> Cheers, Ken >>> >> >> >> >> -- >> Rick Holland >> Castle Rock, Colorado >> NX6819Z >> >> >> >> * >> >> * >> >> > ________________________________________________________________________________
Date: Aug 15, 2013
What not to love, your ship and a loving dog...looks good ken, can't wait to get there. Sent from my iPad Jack Textor On Aug 15, 2013, at 10:30 AM, Ken Bickers wrote: > Another step forward. Tuesday, I mounted the motor on the fuselage for the very first time. Lots of steps still to go. > > Cheers, Ken > ________________________________________________________________________________
Date: Aug 15, 2013
He's a hard working dog. Just look at how exhausted he is. But every single day, he's anxious to return the hangar to work on the Piet. I'm sure the jerky that I keep for him in the frig has little to do with it. On Thu, Aug 15, 2013 at 11:23 AM, Jack wrote: > > What not to love, your ship and a loving dog...looks good ken, can't wait > to get there. > > Sent from my iPad > Jack Textor > > On Aug 15, 2013, at 10:30 AM, Ken Bickers wrote: > > > Another step forward. Tuesday, I mounted the motor on the fuselage for > the very first time. Lots of steps still to go. > > > > Cheers, Ken > > > > ________________________________________________________________________________
Date: Aug 15, 2013
Subject: Re: simple prop balancer and tracking
Another one.. the same perhaps? http://vgmk1.blogspot.com/2013/04/helice-balanceo.html Mario Giacummo 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] < michael.d.cuy(at)nasa.gov> > Mike-- Last spring I refinished and balanced my prop. You are more > than welcome to borrow my simple rubber stopper prop balancer that I used > with a vise as a knife edge w/ angle irons sharpened. **** > > ** ** > > I simply added a dab of varnish to the 'light' blade over the course of 2 > days, let dry and it was in perfect balance. What is just as critical, i f > not moresoe, to a smooth running prop is tracking**** > > the blade which we can do together if you'd like. All we need is a brown > shopping bag to tear up and a torque wrench. These two methods will > result in a wonderfully smooth running prop. My Uncle**** > > Tony shows both of these methods in his books and they work great. **** > > ** ** > > Mike C.**** > > ** ** > > (I=92ll stop by the hangar tonight and pick this up for you) **** > > ** ** > > **** > > ** ** > > ** ** > > **** > > ** ** > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum > Sent: Thursday, August 15, 2013 10:40 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Dynamic balancing ? > > ** ** > > > ** ** > > ** ** > > ** ** > > On 08/15/2013 09:35 AM, AircamperN11MS wrote:**** > > ** ** > > > My three cents, Now lets go flying.**** > > ** ** > > Hear, hear!**** > > ** ** > > ** ** > ====================**** bsp; - The Pietenpol-List Email Forum -**** nd > much much more:**** tronics.com/Navigator?Pietenpol-List"> > http://www.matronics.com/Navigator?Pietenpol-List**** ====== ============= > **** bsp; - MATRONICS WEB FORUMS -**** eb Forums!**** .matronics.co m > ">http://forums.matronics.com**** ============= =======**** bsp; - > List Contribution Web Site -**** o:p>** bsp; -Matt > Dralle, List Admin.**** tronics.com/contribution"> > http://www.matronics.com/contribution**** ========== ==========**** > > ** ** > > ** ** > > ** ** > ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Aug 15, 2013
Here is another way to build your own static balance tool. I have not built one myself but had seen it printed somewhere and drew this up quickly from memory. I don't see any reason it wouldn't work. Please don't take me wrong on my last post. dynamic balancing is good and I think it has its place with metal and constant speed props but I really don't think we need it on our Piets. They are simple machines. Attached is the rough drawing I made. Has anyone ever used this method before? -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406787#406787 Attachments: http://forums.matronics.com//files/20130815095521067_571.pdf ________________________________________________________________________________
Subject: Re: leather flying helmet
Date: Aug 15, 2013
I got my genuine reproduction flying hat in the mail and I love it. -------- Building steel fuselage aircamper. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406788#406788 ________________________________________________________________________________
Date: Aug 15, 2013
Scott I have and I can't find the article, it looked pretty slick... Sent from my iPad Jack Textor On Aug 15, 2013, at 1:31 PM, "AircamperN11MS" wrote: > > Here is another way to build your own static balance tool. I have not built one myself but had seen it printed somewhere and drew this up quickly from memory. I don't see any reason it wouldn't work. > > Please don't take me wrong on my last post. dynamic balancing is good and I think it has its place with metal and constant speed props but I really don't think we need it on our Piets. They are simple machines. > > Attached is the rough drawing I made. Has anyone ever used this method before? > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406787#406787 > > > > > Attachments: > > http://forums.matronics.com//files/20130815095521067_571.pdf > > > > > > > ________________________________________________________________________________
Date: Aug 15, 2013
I think it was published in one of our Tech Counselor magazines. I am over fifty and my memory stinks. :) -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406790#406790 ________________________________________________________________________________
Date: Aug 15, 2013
#2 is to your question, Scott. These two photos show almost all one needs to know about prop balancing tools...from the prop carving demo's at Air Venture. I should point out, the attached is from a prop carving essay that I got from Dan Helsper, and wish to emphasize that ANYONE capable of building a Pietenpol is capable of making their own prop...with the tools they already have! Do not be misled by claims of machinest type tools, or terms like "a thousandth of an inch", or dynamic balancing. #3 is a picture of my Piet with the current prop, made from poplar. I confess, that I am purchasing a Culver prop, as I need a bench mark for future carvings. My goal will be to make my Piet fly as well as Mike Groah's, so I am working to change things to be similar to his. I have the same engine, but also want the same climb, cruise and cooling numbers. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Thursday, August 15, 2013 11:32 AM Subject: Pietenpol-List: Re: Dynamic balancing ? --> Here is another way to build your own static balance tool. I have not built one myself but had seen it printed somewhere and drew this up quickly from memory. I don't see any reason it wouldn't work. Please don't take me wrong on my last post. dynamic balancing is good and I think it has its place with metal and constant speed props but I really don't think we need it on our Piets. They are simple machines. Attached is the rough drawing I made. Has anyone ever used this method before? -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406787#406787 Attachments: http://forums.matronics.com//files/20130815095521067_571.pdf ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: simple prop balancer and tracking
Date: Aug 15, 2013
That's it Mario! Super simple and it will give you a very smooth running prop. I LOVE that wood prop with the metal hub. You have a very rare thing in that from what little I know about those kinds of prop s. Way cool. Great look!!! From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Mario Giacummo Sent: Thursday, August 15, 2013 2:20 PM Subject: Re: Pietenpol-List: simple prop balancer and tracking Another one.. the same perhaps? http://vgmk1.blogspot.com/2013/04/helice-balanceo.html Mario Giacummo 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] <michael.d.cuy@ nasa.gov> Mike-- Last spring I refinished and balanced my prop. You are more than w elcome to borrow my simple rubber stopper prop balancer that I used with a vise as a knife edge w/ angle irons sharpened. I simply added a dab of varnish to the 'light' blade over the course of 2 d ays, let dry and it was in perfect balance. What is just as critical, if n ot moresoe, to a smooth running prop is tracking the blade which we can do together if you'd like. All we need is a brown s hopping bag to tear up and a torque wrench. These two methods will resul t in a wonderfully smooth running prop. My Uncle Tony shows both of these methods in his books and they work great. Mike C. (I'll stop by the hangar tonight and pick this up for you) [cid:image001.jpg(at)01CE99CA.A2F14F10] [cid:image002.jpg(at)01CE99CA.A2F14F10] -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com<mailto:owner-pietenpol-list -server(at)matronics.com> [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum Sent: Thursday, August 15, 2013 10:40 AM Subject: Re: Pietenpol-List: Re: Dynamic balancing ? yocum137(at)gmail.com>> On 08/15/2013 09:35 AM, AircamperN11MS wrote: > My three cents, Now lets go flying. Hear, hear! ==================== bsp; - The Pi etenpol-List Email Forum - nd much much more: tronics.com/Navigator?Pietenp ol-List<http://tronics.com/Navigator?Pietenpol-List>"> http://www.matronics .com/Navigator?Pietenpol-List =============== ===== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.c om<http://matronics.com>">http://forums.matronics.com ======= ============= bsp; - List Contribution Web Si te - o:p> bsp; -Matt Dralle, List Admin. tronics.com/c ontribution<http://tronics.com/contribution>"> http://www.matronics.com/con tribution =================== ________________________________________________________________________________
Subject: Re: Upcoming Corvair Colleges
Date: Aug 15, 2013
I have my engine to a point that at the next Corvair College I attend (2014) it should be ready to run. I've enjoyed every part of building it and look forward to the day it runs and is mounted on my Piet. HOWEVER, I still have problems contacting William Wynne. I sent my distributor to him in early Feb. for rebuild. In the box was a letter with my contact information. I heard nothing. I followed up with emails and phone calls (left messages) and still nothing. He accepted my money vial paypal in early May (I thought maybe this was the problem as I wasn't sure what the final cost would be in Feb) but still no response. Alarm bells are starting to sound in my head. Today I called again and left another message. I also sent another email. We'll see what happens. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406794#406794 ________________________________________________________________________________
Subject: Scott's method for prop balancing.
Date: Aug 15, 2013
That is another great way to balance a prop Scott and I've used that method . I made up a gidgee (technical term for prop hub fitting) whereby I hung my Corby Starlet prop assembly from a cable and simply drilled a hol e and put a bolt, lockwasher, and nut on the spinner back plate at a position which brought the cable into the center of my gidgee and balanced the whole deal very nicely. Mike C. ________________________________________________________________________________
Date: Aug 15, 2013
Gary, I love those pics and writeups. Superbly elegant and simple. However, it doesn't address the inital question... If you have the luxury of drilling your bolt hole pattern AFTER you balance it, it is indeed a simple matter of indexing it off where you have determined the prop will balance. However, if you balance AFTER, it's critical that you balance at the exact center of the bolt hole pattern or it just doesn't matter. Indeed, for practical purposes none of this matters... Hell, the easy way would be to mock up the prop on the crank, without pistons installed and use the crank shaft as your hub, and the crank bearings as your balancing ways. You'll be ahead of the game as in that stead, how you mount it IS how it'll mount in use. But, if you ARE going to balance, and spend any time doing it, may as well do it as correctly as possible. If you don't, you could be making things worse, or just never really fixing anything which is frustrating and time wasting. If you're relying on a bubble, and the bubble isn't repeatable, it's a doomed cause. You MIGHT get good results, and if you do, great. But if you don't, and you don't realize the level on which you base your results is a causal factor, how could you proceed? Dynamic balancing is a GREAT way to check and correct stuff. Things in balance last longer and are more reliable. There are non phase methods of dynamic balancing that means decent dynamic balancing is possible with a cell phone app! AND a fair amount of knowing what's going on, which while a little esoteric, isn't difficult to pick up on. There are quite a few EAA chapters and such who own dynamic balancing set ups and break out their equipment and play around at fly-in's and such. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406797#406797 ________________________________________________________________________________
Subject: Re: Scott's method for prop balancing.
Date: Aug 15, 2013
Thanks Mike, Pictures are worth a thousand words. Yours looks great. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406800#406800 ________________________________________________________________________________
Date: Aug 15, 2013
If you had ever made a prop, you would know that the center hole, 1/4", is the first thing done...in every board, prior to laminating! A simple jig with the bolt pattern is used, at any time after laminating, to drill the holes. You are complicating this whole issue, which does little to help others who may be contemplating this endeavor. Why don't you first make a prop, fly it on your Piet, then tell us how you did it? Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tools Sent: Thursday, August 15, 2013 12:43 PM Subject: Pietenpol-List: Re: Dynamic balancing ? Gary, I love those pics and writeups. Superbly elegant and simple. However, it doesn't address the inital question... If you have the luxury of drilling your bolt hole pattern AFTER you balance it, it is indeed a simple matter of indexing it off where you have determined the prop will balance. However, if you balance AFTER, it's critical that you balance at the exact center of the bolt hole pattern or it just doesn't matter. Indeed, for practical purposes none of this matters... Hell, the easy way would be to mock up the prop on the crank, without pistons installed and use the crank shaft as your hub, and the crank bearings as your balancing ways. You'll be ahead of the game as in that stead, how you mount it IS how it'll mount in use. But, if you ARE going to balance, and spend any time doing it, may as well do it as correctly as possible. If you don't, you could be making things worse, or just never really fixing anything which is frustrating and time wasting. If you're relying on a bubble, and the bubble isn't repeatable, it's a doomed cause. You MIGHT get good results, and if you do, great. But if you don't, and you don't realize the level on which you base your results is a causal factor, how could you proceed? Dynamic balancing is a GREAT way to check and correct stuff. Things in balance last longer and are more reliable. There are non phase methods of dynamic balancing that means decent dynamic balancing is possible with a cell phone app! AND a fair amount of knowing what's going on, which while a little esoteric, isn't difficult to pick up on. There are quite a few EAA chapters and such who own dynamic balancing set ups and break out their equipment and play around at fly-in's and such. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406797#406797 ________________________________________________________________________________
Date: Aug 15, 2013
John, This is nothing new; it can take time to get parts from William, that's just the way it is. They are a small operation, and have to divide their time between production, builder assistance, traveling, and so on. For example, since you sent your distributor in there has been a Corvair College, Sun-N-Fun, Brodhead, and Oshkosh (see the Aug 12 write-up at http://flycorvair.net regarding their 3,500 mile 20-state 21-day road trip to OSH). You may also find that getting to the point of needing the given parts may expedite your order, e.g. you are waiting on the distributor to run your engine as opposed to just wanting the parts; YMMV. That being said, do not fear: they are a legitimate business, you will eventually get your parts. Cheers, Ryan On 8/15/2013 2:18 PM, John Francis wrote: > > I have my engine to a point that at the next Corvair College I attend (2014) it should be ready to run. I've enjoyed every part of building it and look forward to the day it runs and is mounted on my Piet. HOWEVER, I still have problems contacting William Wynne. I sent my distributor to him in early Feb. for rebuild. In the box was a letter with my contact information. I heard nothing. I followed up with emails and phone calls (left messages) and still nothing. He accepted my money vial paypal in early May (I thought maybe this was the problem as I wasn't sure what the final cost would be in Feb) but still no response. > > Alarm bells are starting to sound in my head. Today I called again and left another message. I also sent another email. We'll see what happens. > > John > > -------- > John Francis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406794#406794 > > ________________________________________________________________________________
Date: Aug 15, 2013
Agree, WW always delivers. rick h On Thu, Aug 15, 2013 at 1:18 PM, John Francis wrote: > > I have my engine to a point that at the next Corvair College I attend > (2014) it should be ready to run. I've enjoyed every part of building it > and look forward to the day it runs and is mounted on my Piet. HOWEVER, I > still have problems contacting William Wynne. I sent my distributor to him > in early Feb. for rebuild. In the box was a letter with my contact > information. I heard nothing. I followed up with emails and phone calls > (left messages) and still nothing. He accepted my money vial paypal in > early May (I thought maybe this was the problem as I wasn't sure what the > final cost would be in Feb) but still no response. > > Alarm bells are starting to sound in my head. Today I called again and > left another message. I also sent another email. We'll see what happens. > > John > > -------- > John Francis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406794#406794 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: Re: New photo emerges from Brodhead 2012
Date: Aug 15, 2013
Helsper has his Corvair mounted funny in there... one of the heads and valve cover is sticking up out of the top of the cowling, and he has his crankcase breather vents going to some sort of a cooler. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406808#406808 ________________________________________________________________________________
Date: Aug 15, 2013
He thinks outside the box... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Thursday, August 15, 2013 3:30 PM Subject: Pietenpol-List: Re: New photo emerges from Brodhead 2012 --> Helsper has his Corvair mounted funny in there... one of the heads and valve cover is sticking up out of the top of the cowling, and he has his crankcase breather vents going to some sort of a cooler. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406808#406808 ________________________________________________________________________________
Date: Aug 15, 2013
Yea, and the grass isn't alive. Dan Helsper Puryear, TN -----Original Message----- From: Bill Church <billspiet(at)sympatico.ca> Sent: Thu, Aug 15, 2013 10:05 am Subject: Pietenpol-List: Re: New photo emerges from Brodhead 2012 > You can tell that the photo wasn't from 2013, because nobody is wearing a p arka. BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406755#406755 ________________________________________________________________________________
Date: Aug 15, 2013
John you might just show up at corvair college 27 in barn well sc in November. Let wunnerful know you will be there and I will Bet he will have your districbutor . Gardiner Sent from my iPhone On Aug 15, 2013, at 4:41 PM, Ryan Mueller wrote: > > John, > > This is nothing new; it can take time to get parts from William, that's > just the way it is. They are a small operation, and have to divide their > time between production, builder assistance, traveling, and so on. For > example, since you sent your distributor in there has been a Corvair > College, Sun-N-Fun, Brodhead, and Oshkosh (see the Aug 12 write-up at > http://flycorvair.net regarding their 3,500 mile 20-state 21-day road > trip to OSH). > > You may also find that getting to the point of needing the given parts > may expedite your order, e.g. you are waiting on the distributor to run > your engine as opposed to just wanting the parts; YMMV. That being said, > do not fear: they are a legitimate business, you will eventually get > your parts. Cheers, > > Ryan > > On 8/15/2013 2:18 PM, John Francis wrote: >> >> I have my engine to a point that at the next Corvair College I attend (2014) it should be ready to run. I've enjoyed every part of building it and look forward to the day it runs and is mounted on my Piet. HOWEVER, I still have problems contacting William Wynne. I sent my distributor to him in early Feb. for rebuild. In the box was a letter with my contact information. I heard nothing. I followed up with emails and phone calls (left messages) and still nothing. He accepted my money vial paypal in early May (I thought maybe this was the problem as I wasn't sure what the final cost would be in Feb) but still no response. >> >> Alarm bells are starting to sound in my head. Today I called again and left another message. I also sent another email. We'll see what happens. >> >> John >> >> -------- >> John Francis >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=406794#406794 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Aug 15, 2013
Mike, Are you sure it wouldn't it be better to make it out of stainless? Dan Helsper Puryear, TN -----Original Message----- From: Michael Perez <speedbrake(at)sbcglobal.net> Sent: Thu, Aug 15, 2013 10:27 am Subject: Re: Pietenpol-List: simple prop balancer and tracking I'm with you Mike. As we discussed, I'll take what you have. However, betwe en now and Monday, I may make up my own set of tapered plugs and balance sh aft, (machined aluminum) and support fixture for the prop. If I do, it wou ld be neat to compare each balance system to one another. Oh and don't forget the templates. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Aug 15, 2013
No doubt William is a knowledgable authority on Corvairs. That said, early on I considered going that direction, ordered his book and started to look for engines. After learning about his slow response I went with a C-85. That's not the only reason but I will stop there... Sent from my iPad Jack Textor On Aug 15, 2013, at 3:41 PM, Ryan Mueller wrote: > > John, > > This is nothing new; it can take time to get parts from William, that's > just the way it is. They are a small operation, and have to divide their > time between production, builder assistance, traveling, and so on. For > example, since you sent your distributor in there has been a Corvair > College, Sun-N-Fun, Brodhead, and Oshkosh (see the Aug 12 write-up at > http://flycorvair.net regarding their 3,500 mile 20-state 21-day road > trip to OSH). > > You may also find that getting to the point of needing the given parts > may expedite your order, e.g. you are waiting on the distributor to run > your engine as opposed to just wanting the parts; YMMV. That being said, > do not fear: they are a legitimate business, you will eventually get > your parts. Cheers, > > Ryan > > On 8/15/2013 2:18 PM, John Francis wrote: >> >> I have my engine to a point that at the next Corvair College I attend (2014) it should be ready to run. I've enjoyed every part of building it and look forward to the day it runs and is mounted on my Piet. HOWEVER, I still have problems contacting William Wynne. I sent my distributor to him in early Feb. for rebuild. In the box was a letter with my contact information. I heard nothing. I followed up with emails and phone calls (left messages) and still nothing. He accepted my money vial paypal in early May (I thought maybe this was the problem as I wasn't sure what the final cost would be in Feb) but still no response. >> >> Alarm bells are starting to sound in my head. Today I called again and left another message. I also sent another email. We'll see what happens. >> >> John >> >> -------- >> John Francis >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=406794#406794 > > > > > ________________________________________________________________________________
Date: Aug 15, 2013
Hold me back, Ryan!! Gary Sent from my iPhone On Aug 15, 2013, at 5:33 PM, Jack wrote: > > No doubt William is a knowledgable authority on Corvairs. That said, early on I considered going that direction, ordered his book and started to look for engines. After learning about his slow response I went with a C-85. That's not the only reason but I will stop there... > > Sent from my iPad > Jack Textor > > On Aug 15, 2013, at 3:41 PM, Ryan Mueller wrote: > >> >> John, >> >> This is nothing new; it can take time to get parts from William, that's >> just the way it is. They are a small operation, and have to divide their >> time between production, builder assistance, traveling, and so on. For >> example, since you sent your distributor in there has been a Corvair >> College, Sun-N-Fun, Brodhead, and Oshkosh (see the Aug 12 write-up at >> http://flycorvair.net regarding their 3,500 mile 20-state 21-day road >> trip to OSH). >> >> You may also find that getting to the point of needing the given parts >> may expedite your order, e.g. you are waiting on the distributor to run >> your engine as opposed to just wanting the parts; YMMV. That being said, >> do not fear: they are a legitimate business, you will eventually get >> your parts. Cheers, >> >> Ryan >> >> On 8/15/2013 2:18 PM, John Francis wrote: >>> >>> I have my engine to a point that at the next Corvair College I attend (2014) it should be ready to run. I've enjoyed every part of building it and look forward to the day it runs and is mounted on my Piet. HOWEVER, I still have problems contacting William Wynne. I sent my distributor to him in early Feb. for rebuild. In the box was a letter with my contact information. I heard nothing. I followed up with emails and phone calls (left messages) and still nothing. He accepted my money vial paypal in early May (I thought maybe this was the problem as I wasn't sure what the final cost would be in Feb) but still no response. >>> >>> Alarm bells are starting to sound in my head. Today I called again and left another message. I also sent another email. We'll see what happens. >>> >>> John >>> >>> -------- >>> John Francis >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=406794#406794 > > > > > ________________________________________________________________________________
Date: Aug 15, 2013
Let it out Gary! Missed you at the Brat Fest this year. I will behave now... Sent from my iPad Jack Textor On Aug 15, 2013, at 7:41 PM, Gary Boothe wrote: > > Hold me back, Ryan!! > > Gary > > Sent from my iPhone > > On Aug 15, 2013, at 5:33 PM, Jack wrote: > >> >> No doubt William is a knowledgable authority on Corvairs. That said, early on I considered going that direction, ordered his book and started to look for engines. After learning about his slow response I went with a C-85. That's not the only reason but I will stop there... >> >> Sent from my iPad >> Jack Textor >> >> On Aug 15, 2013, at 3:41 PM, Ryan Mueller wrote: >> >>> >>> John, >>> >>> This is nothing new; it can take time to get parts from William, that's >>> just the way it is. They are a small operation, and have to divide their >>> time between production, builder assistance, traveling, and so on. For >>> example, since you sent your distributor in there has been a Corvair >>> College, Sun-N-Fun, Brodhead, and Oshkosh (see the Aug 12 write-up at >>> http://flycorvair.net regarding their 3,500 mile 20-state 21-day road >>> trip to OSH). >>> >>> You may also find that getting to the point of needing the given parts >>> may expedite your order, e.g. you are waiting on the distributor to run >>> your engine as opposed to just wanting the parts; YMMV. That being said, >>> do not fear: they are a legitimate business, you will eventually get >>> your parts. Cheers, >>> >>> Ryan >>> >>> On 8/15/2013 2:18 PM, John Francis wrote: >>>> >>>> I have my engine to a point that at the next Corvair College I attend (2014) it should be ready to run. I've enjoyed every part of building it and look forward to the day it runs and is mounted on my Piet. HOWEVER, I still have problems contacting William Wynne. I sent my distributor to him in early Feb. for rebuild. In the box was a letter with my contact information. I heard nothing. I followed up with emails and phone calls (left messages) and still nothing. He accepted my money vial paypal in early May (I thought maybe this was the problem as I wasn't sure what the final cost would be in Feb) but still no response. >>>> >>>> Alarm bells are starting to sound in my head. Today I called again and left another message. I also sent another email. We'll see what happens. >>>> >>>> John >>>> >>>> -------- >>>> John Francis >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=406794#406794 > > > > > ________________________________________________________________________________
Subject: Re: Pietenpol T-shirts from Brodhead 2013
Date: Aug 15, 2013
I found a 2XL shirt and a SMALL (one of each) in my stash. They have been added to the store. And no sweatshirts, sorry. It's a one weekend event in July in Wisconsin. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406819#406819 ________________________________________________________________________________
Date: Aug 15, 2013
Mario, wish you could bring it to the states! Sent from my iPad Jack Textor On Aug 15, 2013, at 2:18 PM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, L LC]" wrote: > That=99s it Mario! Super simple and it will give you a very smooth running prop. I LOVE that wood prop with the metal hub. You have > a very rare thing in that from what little I know about those kinds of pro ps. Way cool. Great look!!! > > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Mario Giacummo > Sent: Thursday, August 15, 2013 2:20 PM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: simple prop balancer and tracking > > Another one.. the same perhaps? > > http://vgmk1.blogspot.com/2013/04/helice-balanceo.html > > > > > > Mario Giacummo > > > > 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] @nasa.gov> > Mike-- Last spring I refinished and balanced my prop. You are more than w elcome to borrow my simple rubber stopper prop balancer that I used with a v ise as a knife edge w/ angle irons sharpened. > > > > I simply added a dab of varnish to the 'light' blade over the course of 2 d ays, let dry and it was in perfect balance. What is just as critical, if no t moresoe, to a smooth running prop is tracking > > the blade which we can do together if you'd like. All we need is a brown s hopping bag to tear up and a torque wrench. These two methods will result in a wonderfully smooth running prop. My Uncle > > Tony shows both of these methods in his books and they work great. > > > > Mike C. > > > > (I=99ll stop by the hangar tonight and pick this up for you) > > > > > > > > > > > > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Dan Yocum > Sent: Thursday, August 15, 2013 10:40 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Dynamic balancing ? > > > > > > > > > > > On 08/15/2013 09:35 AM, AircamperN11MS wrote: > > > > > My three cents, Now lets go flying. > > > > Hear, hear! > > > > > > ==================== bsp; - The P ietenpol-List Email Forum - nd much much more: tronics.com/Navigator?Pietenp ol-List"> http://www.matronics.com/Navigator?Pietenpol-List ====== ============== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.com">http://forums.matronics.com ====== ============== bsp; - List Contribution Web S ite - o:p> bsp; -Matt Dralle, List Admin. tronics.com/c ontribution"> http://www.matronics.com/contribution ======== =========== > > > > > > > ________________________________________________________________________________
Date: Aug 15, 2013
The loss was all mine, Jack! Next year is looking much better... Gary Sent from my iPhone On Aug 15, 2013, at 6:33 PM, Jack wrote: > > Let it out Gary! Missed you at the Brat Fest this year. > I will behave now... > > Sent from my iPad > Jack Textor > > On Aug 15, 2013, at 7:41 PM, Gary Boothe wrote: > >> >> Hold me back, Ryan!! >> >> Gary >> >> Sent from my iPhone >> >> On Aug 15, 2013, at 5:33 PM, Jack wrote: >> >>> >>> No doubt William is a knowledgable authority on Corvairs. That said, early on I considered going that direction, ordered his book and started to look for engines. After learning about his slow response I went with a C-85. That's not the only reason but I will stop there... >>> >>> Sent from my iPad >>> Jack Textor >>> >>> On Aug 15, 2013, at 3:41 PM, Ryan Mueller wrote: >>> >>>> >>>> John, >>>> >>>> This is nothing new; it can take time to get parts from William, that's >>>> just the way it is. They are a small operation, and have to divide their >>>> time between production, builder assistance, traveling, and so on. For >>>> example, since you sent your distributor in there has been a Corvair >>>> College, Sun-N-Fun, Brodhead, and Oshkosh (see the Aug 12 write-up at >>>> http://flycorvair.net regarding their 3,500 mile 20-state 21-day road >>>> trip to OSH). >>>> >>>> You may also find that getting to the point of needing the given parts >>>> may expedite your order, e.g. you are waiting on the distributor to run >>>> your engine as opposed to just wanting the parts; YMMV. That being said, >>>> do not fear: they are a legitimate business, you will eventually get >>>> your parts. Cheers, >>>> >>>> Ryan >>>> >>>> On 8/15/2013 2:18 PM, John Francis wrote: >>>>> >>>>> I have my engine to a point that at the next Corvair College I attend (2014) it should be ready to run. I've enjoyed every part of building it and look forward to the day it runs and is mounted on my Piet. HOWEVER, I still have problems contacting William Wynne. I sent my distributor to him in early Feb. for rebuild. In the box was a letter with my contact information. I heard nothing. I followed up with emails and phone calls (left messages) and still nothing. He accepted my money vial paypal in early May (I thought maybe this was the problem as I wasn't sure what the final cost would be in Feb) but still no response. >>>>> >>>>> Alarm bells are starting to sound in my head. Today I called again and left another message. I also sent another email. We'll see what happens. >>>>> >>>>> John >>>>> >>>>> -------- >>>>> John Francis >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=406794#406794 > > > > > ________________________________________________________________________________
Date: Aug 15, 2013
William is nothing if not controversial. Despite his idiosyncrasies, this is what I know: 1) When I need a part to get the motor running he's on top of it, 2) When I need help diagnosing a problem he's on top of it, 3) He's one of the smartest people I've ever met, no exaggeration, 4) If you want to discuss basic, practical, no-kidding small airplane design he's a wealth of knowledge, 5) I've been doing aviation and industrial safety professionally since 1989. I've got credentials and everything. William has helped me clarify and refine my philosophy on aviation safety. This despite the fact that I've got a butt-load more flight time than he has, 6) If you want to really know how your motor works, he'll help you learn, 7) I am one of the most active Piet builders/flyers in the community and I am confident in my choice to rebuild FBG with a Corvair engine. Corvair Colleges are educational and entertaining, even if you don't plan to use a Corvair. They're worth going to just to see what he's going to come up with next. WW's a heckuvalot better source of information than many of the internet geniuses you'll find dispensing sage advice. You know who I'm talking about: the guys who didn't build their airplane and barely fly it but tell you all about how to do both. See you at CC28. -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406828#406828 ________________________________________________________________________________
Date: Aug 15, 2013
I didn't build my airplane, I barely fly it, and I tell you about how to do both. ;) With that out of the way, I'll say a couple of things: (1) my airplane has a Continental engine on it; (2) I have been working on my Corvair conversion for 14 years now, and it is still just a short block and two big boxes of prepped parts. Oh, and I still need to take the short block back apart so I can get a nitrided crank into it and prep the cases for a 5th bearing; (3) I consider William to be a close personal friend and one of the best and most down-to-earth engine and aircraft technicians and mechanics I have ever met. He is also extremely clever and practical, has a great sense of humor, and can talk so long that he should rent himself out as a professional filibuster speaker on Capitol Hill. Sometimes you get things back from William & Grace practically overnight, but other times it takes weeks or months. I got an engine mount from him the same week I spoke to him on the phone about it, before I sent him a penny in payment, and we are on opposite coasts of the U.S. The one thing William & Grace are *not*, are swindlers, charlatans, or cheats. I will stand behind that statement unconditionally. Off soapbox now; disclaimer: this has been a biased commentary and personal observation and is not intended to create heated discussion. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406830#406830 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Aug 16, 2013
Except this year it was in February... Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bill Weeden Sent: Thursday, August 15, 2013 9:34 PM Subject: Pietenpol-List: Re: Pietenpol T-shirts from Brodhead 2013 I found a 2XL shirt and a SMALL (one of each) in my stash. They have been added to the store. And no sweatshirts, sorry. It's a one weekend event in July in Wisconsin. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406819#406819 ________________________________________________________________________________
Subject: C85-12F For Sale on eBay $4500
Date: Aug 16, 2013
Know nothing about it, looks to be a good engine and price... http://www.ebay.com/itm/300949544643?item=300949544643&viewitem=&sspagename ADME:B:SS:US:3160&vxp=mtr Jack Textor Des Moines, IA ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: flop hinge
Date: Aug 16, 2013
Oscar, I too have been surprised by my flop. I routinely forget to lower it when I start the engine and the propwash will "wang" the flop down hard. Each time this happens, the forces in essence want to pull the hinge screws out. I had to retighten them after only thirty hours or so due to my forgetfulness. I used longer screws, a little glue on each and added more foam padding so when it bangs down, I still have to pull it a little further into the foam to get the latch to catch, AND I'm trying to be more careful. Now I only forget about 25% of the time. Douwe Ps. Does anyone know anything about dynamically balancing a prop??? ________________________________________________________________________________
Date: Aug 16, 2013
If you have any doubt another "little help" http://bcove.me/axgovbmt Mario Giacummo 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] < michael.d.cuy(at)nasa.gov> > That is another great way to balance a prop Scott and I've used that > method. I made up a gidgee (technical term for prop hub fitting) whereby > I hung my Corby Starlet prop assembly from a cable and simply drilled a > hole and put a bolt, lockwasher, and nut on the spinner back plate at a > position which brought the cable into the center of my gidgee and balanced > the whole deal very nicely. > > > Mike C. > > ________________________________________________________________________________
Date: Aug 16, 2013
Yes, with tha plane behind ;0))) Two things about balancing it; instance of using two sharp blades, I use a couple of al tubes, very easy to find (or something similar) and in the contact point with the prop axis, very, very, very sharp, may be more sharp than a sharp blade, mathematicaly just 1 point. you have to see it balancing side to side until stop, lots of minuets. regards Mario Giacummo 2013/8/15 Jack > Mario, wish you could bring it to the states! > > Sent from my iPad > Jack Textor > > On Aug 15, 2013, at 2:18 PM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners , > LLC]" wrote: > > That=92s it Mario! Super simple and it will give you a very smooth > running prop. I LOVE that wood prop with the metal hub. You have**** > > a very rare thing in that from what little I know about those kinds of > props. Way cool. Great look!!!**** > > ** ** > > ** ** > > *From:* owner-pietenpol-list-server(at)matronics.com [ > mailto:owner-pietenpol-list-server(at)matronics.com] > *On Behalf Of *Mario Giacummo > > *Sent:* Thursday, August 15, 2013 2:20 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: simple prop balancer and tracking**** > > ** ** > > Another one.. the same perhaps?**** > > ** ** > > http://vgmk1.blogspot.com/2013/04/helice-balanceo.html**** > > ** ** > > ** ** > > ** ** > > > **** > > ** ** > > Mario Giacummo**** > > ** ** > > ** ** > > 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] < > michael.d.cuy(at)nasa.gov>**** > > Mike-- Last spring I refinished and balanced my prop. You are more than > welcome to borrow my simple rubber stopper prop balancer that I used with a > vise as a knife edge w/ angle irons sharpened. **** > > **** > > I simply added a dab of varnish to the 'light' blade over the course of 2 > days, let dry and it was in perfect balance. What is just as critical, i f > not moresoe, to a smooth running prop is tracking**** > > the blade which we can do together if you'd like. All we need is a brown > shopping bag to tear up and a torque wrench. These two methods will > result in a wonderfully smooth running prop. My Uncle**** > > Tony shows both of these methods in his books and they work great. **** > > **** > > Mike C.**** > > **** > > (I=92ll stop by the hangar tonight and pick this up for you) **** > > **** > > **** > > **** > > **** > > **** > > **** > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum > Sent: Thursday, August 15, 2013 10:40 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Dynamic balancing ?**** > > **** > > > **** > > **** > > **** > > On 08/15/2013 09:35 AM, AircamperN11MS wrote:**** > > **** > > > My three cents, Now lets go flying.**** > > **** > > Hear, hear!**** > > **** > > **** > > ==================== bsp; - The Pietenpol-List Email Forum - nd much much > more: tronics.com/Navigator?Pietenpol-List"> > http://www.matronics.com/Navigator?Pietenpol-List ======= ============ > bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.com"> > http://forums.matronics.com =============== ===== bsp; - List > Contribution Web Site - o:p> bsp; -Matt Dralle, List > Admin. tronics.com/contribution"> http://www.matronics.com/contribution =================== > **** > > **** > > **** > > **** > > ** ** > > * > =========== > =========== =========== =========== > > * > > ________________________________________________________________________________
Date: Aug 16, 2013
For those of you showing interest in this "strange" prop. https://docs.google.com/file/d/1dC6y4e-0MFBLxlMm95OtAl5OWFdmCpnBx0l_E2HsfSc GiMt3npKBLXZVKruG/edit?usp=sharing Mario Giacummo 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] < michael.d.cuy(at)nasa.gov> > That=92s it Mario! Super simple and it will give you a very smooth > running prop. I LOVE that wood prop with the metal hub. You have**** > > a very rare thing in that from what little I know about those kinds of > props. Way cool. Great look!!!**** > > ** ** > > ** ** > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Mario Giacummo > *Sent:* Thursday, August 15, 2013 2:20 PM > *To:* pietenpol-list(at)matronics.com > *Subject:* Re: Pietenpol-List: simple prop balancer and tracking**** > > ** ** > > Another one.. the same perhaps?**** > > ** ** > > http://vgmk1.blogspot.com/2013/04/helice-balanceo.html**** > > ** ** > > ** ** > > ** ** > > > **** > > ** ** > > Mario Giacummo**** > > ** ** > > ** ** > > 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] < > michael.d.cuy(at)nasa.gov>**** > > Mike-- Last spring I refinished and balanced my prop. You are more than > welcome to borrow my simple rubber stopper prop balancer that I used with a > vise as a knife edge w/ angle irons sharpened. **** > > **** > > I simply added a dab of varnish to the 'light' blade over the course of 2 > days, let dry and it was in perfect balance. What is just as critical, i f > not moresoe, to a smooth running prop is tracking**** > > the blade which we can do together if you'd like. All we need is a brown > shopping bag to tear up and a torque wrench. These two methods will > result in a wonderfully smooth running prop. My Uncle**** > > Tony shows both of these methods in his books and they work great. **** > > **** > > Mike C.**** > > **** > > (I=92ll stop by the hangar tonight and pick this up for you) **** > > **** > > **** > > **** > > **** > > **** > > **** > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dan Yocum > Sent: Thursday, August 15, 2013 10:40 AM > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Dynamic balancing ?**** > > **** > > > **** > > **** > > **** > > On 08/15/2013 09:35 AM, AircamperN11MS wrote:**** > > **** > > > My three cents, Now lets go flying.**** > > **** > > Hear, hear!**** > > **** > > **** > > ==================== bsp; - The Pietenpol-List Email Forum - nd much much > more: tronics.com/Navigator?Pietenpol-List"> > http://www.matronics.com/Navigator?Pietenpol-List ======= ============ > bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.com"> > http://forums.matronics.com =============== ===== bsp; - List > Contribution Web Site - o:p> bsp; -Matt Dralle, List > Admin. tronics.com/contribution"> http://www.matronics.com/contribution =================== > **** > > **** > > **** > > **** > > ** ** > ________________________________________________________________________________
Subject: Missing posts
Date: Aug 16, 2013
Seems like some posts are getting to some people, but not others. I assume that the messages went through to those getting the "real time" emails, but they're missing on the Forum. For example: http://forums.matronics.com/viewtopic.php?t=98974 There are several responses to messages that don't appear in the thread (yet, the missing messages are quoted in the responses). BC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406846#406846 ________________________________________________________________________________
Date: Aug 16, 2013
The Pietenpol Gods must have intervened. I just received an email from WW that my distributor was being mailed today. Not which one of you is God? John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406847#406847 ________________________________________________________________________________
Subject: Re: ford oil pressure
Date: Aug 16, 2013
Classic summery Oscar.. the way the oil drain from the front main into the dipper pan i'm sure I can eliminate the one tube. I got it all together and running ..again ..and the front main seal is leaking again... during the running it appears to have turned under I guess.. a bit of the seal is sticking out the wrong way and it wasn't when I first started it... it's just about to win. This whole business of disassembly and reassembly for a "modern" $12 seal is killing me. wish it still had a slinger on it. oil steam.. and iron.. jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406849#406849 ________________________________________________________________________________
Date: Aug 16, 2013
Thanks Mario! Sent from my iPad Jack Textor On Aug 16, 2013, at 7:31 AM, Mario Giacummo wrote : > If you have any doubt another "little help" http://bcove.me/axgovbmt > > > > > Mario Giacummo > > > > 2013/8/15 Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] @nasa.gov> >> That is another great way to balance a prop Scott and I've used that meth od. I made up a gidgee (technical term for prop hub fitting) whereby >> I hung my Corby Starlet prop assembly from a cable and simply drilled a h ole and put a bolt, lockwasher, and nut on the spinner back plate at a >> position which brought the cable into the center of my gidgee and balance d the whole deal very nicely. >> >> >> Mike C. >> >> >> >> >> >> > ________________________________________________________________________________
Date: Aug 16, 2013
I think William... Sent from my iPad Jack Textor On Aug 16, 2013, at 9:13 AM, "John Francis" wrote: > > The Pietenpol Gods must have intervened. I just received an email from WW that my distributor was being mailed today. Not which one of you is God? > > John > > -------- > John Francis > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406847#406847 > > > > > > > > > > ________________________________________________________________________________
Subject: For those of you who finished where did you start building?
Date: Aug 16, 2013
I am preparing to start building a Pietenpol in February. I deciding where to start I thought it might be helpful to get some feedback from those of you who have completed or are nearing completion of their aircraft. My initial thought was to do the wings since it seems be the single most time consuming task, but it might also be nice to get something done (relatively) quickly when starting out. Suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406855#406855 ________________________________________________________________________________
Date: Aug 16, 2013
It's Friday...You can't provoke me! Gary Sent from my iPhone On Aug 16, 2013, at 8:38 AM, Jack wrote: > > I think William... > > Sent from my iPad > Jack Textor > > On Aug 16, 2013, at 9:13 AM, "John Francis" wrote: > >> >> The Pietenpol Gods must have intervened. I just received an email from WW that my distributor was being mailed today. Not which one of you is God? >> >> John >> >> -------- >> John Francis >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=406847#406847 > > > > > ________________________________________________________________________________
Date: Aug 16, 2013
Subject: Re: For those of you who finished where did you start
building? Anywhere, even in the kitchen; belive it or not ;o) Mario Giacummo 2013/8/16 Toddster > > > > I am preparing to start building a Pietenpol in February. > I deciding where to start I thought it might be helpful to get some > feedback from those of you who have completed or are nearing completion of > their aircraft. > > My initial thought was to do the wings since it seems be the single most > time consuming task, but it might also be nice to get something done > (relatively) quickly when starting out. > > Suggestions? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406855#406855 > > ________________________________________________________________________________
Date: Aug 16, 2013
building?
Start with the ribs, only need a 6'x2' table top/workbench somewhere. Why wait till Feb? Your initial investment (after buying the plans) would be a couple hundred bucks worth of 1/4" x 1/2" strips, a 2'x2' piece of 1/16" ply and some T-88 epoxy (and a 2x6' piece of 3/4" ply from a construction dumpster for your rib jig). rh On Fri, Aug 16, 2013 at 9:58 AM, Toddster wrote: > > > > I am preparing to start building a Pietenpol in February. > I deciding where to start I thought it might be helpful to get some > feedback from those of you who have completed or are nearing completion of > their aircraft. > > My initial thought was to do the wings since it seems be the single most > time consuming task, but it might also be nice to get something done > (relatively) quickly when starting out. > > Suggestions? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406855#406855 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Aug 16, 2013
building? Todd: I found it inspiring to do the tail feathers first. They are smaller to work with but are composed of the same elements that you will be dealing with in all the other parts of the aircraft. Pretty quickly you will have something to hang on the wall and look at proudly while you are working on other things. Second, do your rib jig and start fabricating wing ribs. This is a project that will take a long time to complete but you will be able to jig up and glue up a rib in an evening and then be able to work on other things while that rib is curing. To each his own but that worked out well for me. Tom Stinemetze McPherson, KS. N328X (maybe 2-years out yet) >>> "Toddster" 8/16/2013 10:58 AM >>> I am preparing to start building a Pietenpol in February. I deciding where to start I thought it might be helpful to get some feedback from those of you who have completed or are nearing completion of their aircraft. My initial thought was to do the wings since it seems be the single most time consuming task, but it might also be nice to get something done (relatively) quickly when starting out. Suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406855#406855 ________________________________________________________________________________
building?
Date: Aug 16, 2013
Start where you like. We built the Fuse first. It gave us someplace to sit (insert airplane noises here) and decide how next to proceed. None of the components take up much space when completed. The ribs make for great winter work since those can be built in the house where is is typically warmer than the garage or basement. What ever you start with have fun. The biggest pointer I can give you is the do something each and every day no matter how small, soon you will be flying. Happy building, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406859#406859 ________________________________________________________________________________
building?
Date: Aug 16, 2013
Toddster, You asked the question correctly..."... those of you who have completed or are nearing completion...". I have no idea of your background, but am assuming this is your first hand made A/C...maybe even your first personally owned A/C. A good habit to start right now is to always filter the advice you get. Even from this fine group of builders and flyers, you will get advice from someone who is eager to tell you how to do something that they have never done. When you get to the airport with your brand new Pietenpol, that input will be multiplied ten-fold! Ask questions, but be wary. On this subject, you will get opinions all over the board. There's no right answer. I can only say that I started with tail parts, then moved to fuselage, then wings. Next time I might put the wings ahead of fuselage, as they are easy to store. The tail parts are fun and easy, and you can proudly carry any one of them into the house, remove your wife's quilt from the living room wall, and hang something interesting! :-0 Have you looked at www.westcoastpiet.com? Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Toddster Sent: Friday, August 16, 2013 8:58 AM Subject: Pietenpol-List: For those of you who finished where did you start building? --> I am preparing to start building a Pietenpol in February. I deciding where to start I thought it might be helpful to get some feedback from those of you who have completed or are nearing completion of their aircraft. My initial thought was to do the wings since it seems be the single most time consuming task, but it might also be nice to get something done (relatively) quickly when starting out. Suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406855#406855 ________________________________________________________________________________
Date: Aug 16, 2013
building?
I started with the vertical stabilizer because it was easy and a way to begin to develop my knowledge and skills. Then I finished all the tail feathers before starting on ribs. The fuse came last. 13 years to first flight last November. If I didn't have to work for a living and get 6 kids through college I'm sure I could have done it quicker; like maybe 12 years.... On Fri, Aug 16, 2013 at 10:58 AM, Toddster wrote: > > > > I am preparing to start building a Pietenpol in February. > I deciding where to start I thought it might be helpful to get some > feedback from those of you who have completed or are nearing completion of > their aircraft. > > My initial thought was to do the wings since it seems be the single most > time consuming task, but it might also be nice to get something done > (relatively) quickly when starting out. > > Suggestions? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406855#406855 > > ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Aug 16, 2013
Ryan, Oscar, and others have said as much, but I will add my 2 and 1/2 cents, and I will keep it short (Honest, Ryan. I promise. [Wink] ) In my limited experience with William he is all that Kevin and others have said and more. I have learned much from just speaking with him and reading his blog, and not just about Corvairs. Philosophy of building and maintaining, among other things. But the one thing he is not is a Johnny-on-the-spot communicator for all of the reasons Ryan wrote. If that is what you must have to do business with him then you should probably move on. But you will miss out on your aviation education by doing so. However, if you can be patient and accepting of William's way of doing things, it will be well worth it. And if you need a part ASAP, let him know and he will make it happen Sorry, Ryan. I went longer than I meant to, but it was for a mutual friend. :D -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406865#406865 ________________________________________________________________________________
building?
Date: Aug 16, 2013
That's what worked for me. I made up my rib jig and did the ribs and then the tail feathers. Rick Schreiber Sent from my iPad On Aug 16, 2013, at 11:18 AM, "TOM STINEMETZE" wrote: > > Todd: > > I found it inspiring to do the tail feathers first. They are smaller to work with but are composed of the same elements that you will be dealing with in all the other parts of the aircraft. Pretty quickly you will have something to hang on the wall and look at proudly while you are working on other things. Second, do your rib jig and start fabricating wing ribs. This is a project that will take a long time to complete but you will be able to jig up and glue up a rib in an evening and then be able to work on other things while that rib is curing. > > To each his own but that worked out well for me. > Tom Stinemetze > McPherson, KS. > N328X (maybe 2-years out yet) > >>>> "Toddster" 8/16/2013 10:58 AM >>> > > I am preparing to start building a Pietenpol in February. > I deciding where to start I thought it might be helpful to get some feedback from those of you who have completed or are nearing completion of their aircraft. > > My initial thought was to do the wings since it seems be the single most time consuming task, but it might also be nice to get something done (relatively) quickly when starting out. > > Suggestions? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406855#406855 > > > > > > > > > > > > > > > > ________________________________________________________________________________
building?
Date: Aug 16, 2013
Todd, You've already gotten lot's of good advice. It doesn't really matter where you start. I did ribs first, then wings, then tail, then centersection, then fuselage, but it really doesn't matter. Just break it down into a bunch of small manageable projects. It's a whole lot easier to think about building a rib than the enormity of building a whole airplane. As Scott said, try to do something on it every day, just to keep your mind in it. If you stop working on it for a few days, that can easily turn into a few weeks or months and pretty soon you don't know what you were working on last and it becomes difficult to get back into it. I've got a brother who has had a Hatz biplane almost ready to cover for 27 years, because he "took a break" from it back in 1986 when his daughter was born. Now it looks like an enormous project to him. One thing to consider if you are getting your wood from one of the big companies like Aircraft Spruce or Wicks is that shipping is very expensive, so it might pay to order all your long pieces (spars and longerons, and big sheets of aircraft plywood) together if possible, to reduce the shipping costs. Tail pieces are easy to store, as are wing ribs. A completed wing can be hung from a wall or the ceiling. The fuselage is the most cumbersome of the main pieces of the airplane so if you have cramped building quarters, that might be the deciding factor as to where to start. As for doing the wings first because it seems to be the most time consuming task, what you will find is that building all the structure takes less than half the time to finish the airplane. Builders commonly are at the point in their project where they are "90% done and 90% to go". That happens about the point where all the structure is complete. Designing, fabricating and installing all the systems (fuel system, brakes, controls, electrical system if so equipped, instruments, etc.) takes a large amount of time, as does covering and painting. Just enjoy the process. Don't be in too big of a hurry to get it flying - there will be plenty of time for that. You may find, as several of us have, that without an airplane project to work on you feel a bit lost, after your Pietenpol is done and flying. I'm now building one of the Van's RV's (Ramp Vermin), but I find building a kit to be much less satisfying than building from scratch. Before Mike Cuy can say it, I'll advise that you buy at least the first two of the Tony Bingelis books (available from EAA), The Sportplane Builder and Sportplane Construction Techniques. There you will find many of your questions answered in generous detail. And attend the annual Pietenpol Fly-in in Brodhead, Wisconsin. There you will typically see a couple of dozen Pietenpols, and no two are alike. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Toddster Sent: Friday, August 16, 2013 11:58 AM Subject: Pietenpol-List: For those of you who finished where did you start building? I am preparing to start building a Pietenpol in February. I deciding where to start I thought it might be helpful to get some feedback from those of you who have completed or are nearing completion of their aircraft. My initial thought was to do the wings since it seems be the single most time consuming task, but it might also be nice to get something done (relatively) quickly when starting out. Suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406855#406855 ________________________________________________________________________________
building?
Date: Aug 16, 2013
Todd=2C I started on the tail surfaces. Next=2C I did the wing ribs -- the n started on the fulelage. Stopped the fuse to build the wings. Listen to Jack's advice -- I last worked on my project last October. Wife and I bot h had cancers removed and we bought a new house nearer to our kids. Am now in the process of selling the old house. The "project" is now in storage in a grandson's garage. Gotta get started back on it. Maybe this fall aft er the closing on our house. Chuck From: jack(at)bedfordlandings.com Subject: RE: Pietenpol-List: For those of you who finished where did you st art building? Date: Fri=2C 16 Aug 2013 15:51:56 -0400 =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Todd=2C=0A =0A =0A =0A You've=0A already gotten lot's of good advice. It doesn't really matter where you=0A start. I did ribs first=2C then wings=2C then tail=2C then centersection =2C then=0A fuselage=2C but it really doesn't matter. Just break it down into a bunch =0A of small manageable projects. It's a whole lot easier to think about=0A building a rib than the enormity of building a whole airplane.=0A =0A =0A =0A As=0A Scott said=2C try to do something on it every day=2C just to keep your mind in=0A it. If you stop working on it for a few days=2C that can easily turn into a=0A few weeks or months and pretty soon you don't know what you were working on =0A last and it becomes difficult to get back into it. I've got a brother who =0A has had a Hatz biplane almost ready to cover for 27 years=2C because he=0A "took a break" from it back in 1986 when his daughter was born. =0A Now it looks like an enormous project to him.=0A =0A =0A =0A One=0A thing to consider if you are getting your wood from one of the big companie s=0A like Aircraft Spruce or Wicks is that shipping is very expensive=2C so it m ight=0A pay to order all your long pieces (spars and longerons=2C and big sheets of =0A aircraft plywood) together if possible=2C to reduce the shipping costs. =0A Tail pieces are easy to store=2C as are wing ribs. A completed wing can be =0A hung from a wall or the ceiling. The fuselage is the most cumbersome of=0A the main pieces of the airplane so if you have cramped building quarters=2C that=0A might be the deciding factor as to where to start.=0A =0A =0A =0A As=0A for doing the wings first because it seems to be the most time consuming ta sk=2C=0A what you will find is that building all the structure takes less than half the=0A time to finish the airplane. Builders commonly are at the point in their =0A project where they are "90% done and 90% to go". That happens=0A about the point where all the structure is complete. Designing=2C=0A fabricating and installing all the systems (fuel system=2C brakes=2C contro ls=2C=0A electrical system if so equipped=2C instruments=2C etc.) takes a large amou nt of=0A time=2C as does covering and painting.=0A =0A =0A =0A Just=0A enjoy the process. Don't be in too big of a hurry to get it flying=0A - there will be plenty of time for that. You may find=2C as several of us =0A have=2C that without an airplane project to work on you feel a bit lost=2C after=0A your Pietenpol is done and flying. I'm now building one of the Van's RV's =0A (Ramp Vermin)=2C but I find building a kit to be much less satisfying than =0A building from scratch.=0A =0A =0A =0A Before=0A Mike Cuy can say it=2C I'll advise that you buy at least the first two of t he=0A Tony Bingelis books (available from EAA)=2C The Sportplane Builder and Spor tplane=0A Construction Techniques. There you will find many of your questions=0A answered in generous detail. And attend the annual Pietenpol Fly-in in Bro dhead=2C Wisconsin. =0A There you will typically see a couple of dozen Pietenpols=2C and no two are =0A alike.=0A =0A =0A =0A Jack=0A Phillips=0A =0A NX899JP=0A =0A Smith Mountain Lake=2C=0A Virginia=0A =0A =0A =0A -----Original=0A Message----- =0A From: owner-pietenpol-list-server(at)matronics.com=0A [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Toddster =0A =0A Sent: Friday=2C August 16=2C 2013 11:58 AM =0A =0A Subject: Pietenpol-List: For those of you who finished where did you start =0A building?=0A =0A =0A =0A -->=0A Pietenpol-List message posted by: "Toddster"=0A =0A =0A =0A =0A I=0A am preparing to start building a Pietenpol in February. =0A =0A I=0A deciding where to start I thought it might be helpful to get some feedback from=0A those of you who have completed or are nearing completion of their aircraft .=0A =0A =0A =0A My=0A initial thought was to do the wings since it seems be the single most time =0A consuming task=2C but it might also be nice to get something done (relative ly)=0A quickly when starting out. =0A =0A =0A =0A Suggestions?=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Read=0A this topic online here:=0A =0A =0A =0A http://forums.matronics.com/viewtopic.php?p=406855#406855=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
building?
Date: Aug 16, 2013
Todd, Build the ribs first, then the tail feathers, then wings, then fuselage las t. Dan Helsper Puryear, TN -----Original Message----- From: Toddster <ToddKammerdiener(at)msn.com> Sent: Fri, Aug 16, 2013 12:05 pm Subject: Pietenpol-List: For those of you who finished where did you start building? I am preparing to start building a Pietenpol in February. I deciding where to start I thought it might be helpful to get some feedbac k from those of you who have completed or are nearing completion of their aircraft. My initial thought was to do the wings since it seems be the single most ti me consuming task, but it might also be nice to get something done (relatively ) quickly when starting out. Suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406855#406855 ________________________________________________________________________________
Date: Aug 16, 2013
building? Welcome to the group, Todd I made a mock-up fuselage first out of some cheap lumber, just to get my carpentry skills up. After I cut that up I started on the wing ribs, thinking that if I had the stamina to finish those, I could complete the whole project. I think it took me about 40 days to get them complete, then I started on the real fuselage. Be sure to make lots of practice ribs. I have extras hanging in my living room, office, and hangar now. I milled my own lumber and built my Piet out of Douglas Fir. It takes a little longer but saved me a lot of money and my final weight was a little under 700 lbs. As Jack Mentioned, the woodworking goes fast, and doesn't cost much. Its the other 90% where 90% of the money goes. Keep plugging away and before you know it you are committing vintage aviation Ben Charvet NX866BC A-65 180 hrs in 3 years On 8/16/2013 11:58 AM, Toddster wrote: > > I am preparing to start building a Pietenpol in February. > I deciding where to start I thought it might be helpful to get some feedback from those of you who have completed or are nearing completion of their aircraft. > > My initial thought was to do the wings since it seems be the single most time consuming task, but it might also be nice to get something done (relatively) quickly when starting out. > > Suggestions? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406855#406855 > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
building?
Date: Aug 16, 2013
Jack, a friend of mine here building a gn needs a prop for his a65 . I sugge sted. A cloud cars. Don t you have one and what kind of performance do you g et out of it? Cheers, gardiner Sent from my iPad On Aug 16, 2013, at 3:51 PM, "Jack Phillips" wrot e: > Todd, > > You've already gotten lot's of good advice. It doesn't really matter wher e you start. I did ribs first, then wings, then tail, then centersection, t hen fuselage, but it really doesn't matter. Just break it down into a bunch of small manageable projects. It's a whole lot easier to think about build ing a rib than the enormity of building a whole airplane. > > As Scott said, try to do something on it every day, just to keep your mind in it. If you stop working on it for a few days, that can easily turn into a few weeks or months and pretty soon you don't know what you were working o n last and it becomes difficult to get back into it. I've got a brother who has had a Hatz biplane almost ready to cover for 27 years, because he "took a break" from it back in 1986 when his daughter was born. Now it looks lik e an enormous project to him. > > One thing to consider if you are getting your wood from one of the big com panies like Aircraft Spruce or Wicks is that shipping is very expensive, so i t might pay to order all your long pieces (spars and longerons, and big shee ts of aircraft plywood) together if possible, to reduce the shipping costs. Tail pieces are easy to store, as are wing ribs. A completed wing can be h ung from a wall or the ceiling. The fuselage is the most cumbersome of the m ain pieces of the airplane so if you have cramped building quarters, that mi ght be the deciding factor as to where to start. > > As for doing the wings first because it seems to be the most time consumin g task, what you will find is that building all the structure takes less tha n half the time to finish the airplane. Builders commonly are at the point i n their project where they are "90% done and 90% to go". That happens about the point where all the structure is complete. Designing, fabricating and i nstalling all the systems (fuel system, brakes, controls, electrical system i f so equipped, instruments, etc.) takes a large amount of time, as does cove ring and painting. > > Just enjoy the process. Don't be in too big of a hurry to get it flying - there will be plenty of time for that. You may find, as several of us have , that without an airplane project to work on you feel a bit lost, after you r Pietenpol is done and flying. I'm now building one of the Van's RV's (Ram p Vermin), but I find building a kit to be much less satisfying than buildin g from scratch. > > Before Mike Cuy can say it, I'll advise that you buy at least the first tw o of the Tony Bingelis books (available from EAA), The Sportplane Builder an d Sportplane Construction Techniques. There you will find many of your ques tions answered in generous detail. And attend the annual Pietenpol Fly-in i n Brodhead, Wisconsin. There you will typically see a couple of dozen Piete npols, and no two are alike. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Toddster > Sent: Friday, August 16, 2013 11:58 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: For those of you who finished where did you start building? > > > > I am preparing to start building a Pietenpol in February. > I deciding where to start I thought it might be helpful to get some feedba ck from those of you who have completed or are nearing completion of their a ircraft. > > My initial thought was to do the wings since it seems be the single most t ime consuming task, but it might also be nice to get something done (relativ ely) quickly when starting out. > > Suggestions? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406855#406855 > > > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 17, 2013
building?
Todd, Some things to consider: There are often good deals to be found on unfinished piet projects. Picking up where someone lost interested can save time and money (see attached). You can often find these advertised on Barnstormers ( www.barnstormers.com) and in the Brodhead Pietenpol Association newsletter ( http://www.pietenpols.org/index.html). Over the years, I've seen some good projects sell with lots of extra parts for little money, sometimes cheaper than the cost of the materials! But, be wary of build quality and deviations from the plans. The BPA newsletter is a great resource as well. Subscribe to this. It's a great source of inspiration and building tips. You can also purchase back issues of the newletters. Lastly, check out the suggested reading list here - http://www.pietenpols.org/id1.html. The old "Flying and Glider Manuals" from 1929 thru 1933 are fun reading and full of interesting info. Greg Bacon NX114D, Mountain Piet On Fri, Aug 16, 2013 at 3:29 PM, Chuck Campbell wrote: > Todd, I started on the tail surfaces. Next, I did the wing ribs -- then > started on the fulelage. Stopped the fuse to build the wings. Listen to > Jack's advice -- I last worked on my project last October. Wife and I both > had cancers removed and we bought a new house nearer to our kids. Am now > in the process of selling the old house. The "project" is now in storage > in a grandson's garage. Gotta get started back on it. Maybe this fall > after the closing on our house. Chuck > > ------------------------------ > From: jack(at)bedfordlandings.com > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: For those of you who finished where did you > start building? > Date: Fri, 16 Aug 2013 15:51:56 -0400 > > > Todd, > > > You've already gotten lot's of good advice. It doesn't really matter > where you start. I did ribs first, then wings, then tail, then > centersection, then fuselage, but it really doesn't matter. Just break it > down into a bunch of small manageable projects. It's a whole lot easier to > think about building a rib than the enormity of building a whole airplane. > > > As Scott said, try to do something on it every day, just to keep your mind > in it. If you stop working on it for a few days, that can easily turn into > a few weeks or months and pretty soon you don't know what you were working > on last and it becomes difficult to get back into it. I've got a brother > who has had a Hatz biplane almost ready to cover for 27 years, because he > "took a break" from it back in 1986 when his daughter was born. Now it > looks like an enormous project to him. > > > One thing to consider if you are getting your wood from one of the big > companies like Aircraft Spruce or Wicks is that shipping is very expensive, > so it might pay to order all your long pieces (spars and longerons, and big > sheets of aircraft plywood) together if possible, to reduce the shipping > costs. Tail pieces are easy to store, as are wing ribs. A completed wing > can be hung from a wall or the ceiling. The fuselage is the most > cumbersome of the main pieces of the airplane so if you have cramped > building quarters, that might be the deciding factor as to where to start. > > > As for doing the wings first because it seems to be the most time > consuming task, what you will find is that building all the structure takes > less than half the time to finish the airplane. Builders commonly are at > the point in their project where they are "90% done and 90% to go". That > happens about the point where all the structure is complete. Designing, > fabricating and installing all the systems (fuel system, brakes, controls, > electrical system if so equipped, instruments, etc.) takes a large amount > of time, as does covering and painting. > > > Just enjoy the process. Don't be in too big of a hurry to get it flying > - there will be plenty of time for that. You may find, as several of us > have, that without an airplane project to work on you feel a bit lost, > after your Pietenpol is done and flying. I'm now building one of the Van's > RV's (Ramp Vermin), but I find building a kit to be much less satisfying > than building from scratch. > > > Before Mike Cuy can say it, I'll advise that you buy at least the first > two of the Tony Bingelis books (available from EAA), *The Sportplane > Builder* and *Sportplane Construction Techniques*. There you will find > many of your questions answered in generous detail. And attend the annual > Pietenpol Fly-in in Brodhead, Wisconsin. There you will typically see a > couple of dozen Pietenpols, and no two are alike. > > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] On Behalf Of Toddster > Sent: Friday, August 16, 2013 11:58 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: For those of you who finished where did you start > building? > > > > > > > I am preparing to start building a Pietenpol in February. > > I deciding where to start I thought it might be helpful to get some > feedback from those of you who have completed or are nearing completion of > their aircraft. > > > My initial thought was to do the wings since it seems be the single most > time consuming task, but it might also be nice to get something done > (relatively) quickly when starting out. > > > Suggestions? > > > Read this topic online here: > > > http://forums.matronics.com/viewtopic.php?p=406855#406855 > > > * > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ===========http://forums.matronics.com > ========== > ="_blank">http://www.matronics.com/contribution > ========== > * > > * > > > * > > -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
Subject: fuselage mockup
Date: Aug 17, 2013
The idea of building a simple fuselage mockup is excellent. If you don't p lan to start your actual build for several months and you have some basic t ools=2C just go down and buy some inexpensive pine planks and plywood=2C pl us some wood glue=2C and spend a couple of weekends building a fuselage moc kup. It only needs to be from firewall to pilot's seat back and only needs to include enough of the framing to give you a sturdy mockup that you can sit in and get an idea of the fit. You could get fancier and assemble a si mple rudder bar and walking beam with control sticks out of broomsticks or scrap tubing so you can feel the control geometry as well=2C but that's ext ra work. No need for precision=2C no need to take care with glue drips=2C and you co uld get it into shape pretty quickly if you have a staple gun. If you have a shop with a scrap bin=2C you could probably build it out of things that you already have in your scrap bin and lumber cutoff pile. Oscar Zuniga Medford=2C OR Air Camper NX41CC "Scout" A75 power ________________________________________________________________________________
Date: Aug 17, 2013
Subject: Re: fuselage mockup
Thats what I did. Ripped the 1X1 longerons from 2X4's, cheap door skin plywood and wood glue. I was able to reuse the jig for the actual fuse sides too. Ben On 8/17/2013 12:50 PM, Oscar Zuniga wrote: > > The idea of building a simple fuselage mockup is excellent. If you > don't plan to start your actual build for several months and you have > some basic tools, just go down and buy some inexpensive pine planks > and plywood, plus some wood glue, and spend a couple of weekends > building a fuselage mockup. It only needs to be from firewall to > pilot's seat back and only needs to include enough of the framing to > give you a sturdy mockup that you can sit in and get an idea of the > fit. You could get fancier and assemble a simple rudder bar and > walking beam with control sticks out of broomsticks or scrap tubing so > you can feel the control geometry as well, but that's extra work. > > No need for precision, no need to take care with glue drips, and you > could get it into shape pretty quickly if you have a staple gun. If > you have a shop with a scrap bin, you could probably build it out of > things that you already have in your scrap bin and lumber cutoff pile. > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Aug 17, 2013
Cool idea. Put as much realism as possible. Even in a re-build,I put my instruments right where the wing cross brace wires needed to go.John On Sat, Aug 17, 2013 at 1:42 PM, Ben Charvet wrote: > Thats what I did. Ripped the 1X1 longerons from 2X4's, cheap door skin > plywood and wood glue. I was able to reuse the jig for the actual fuse > sides too. > > Ben > > On 8/17/2013 12:50 PM, Oscar Zuniga wrote: > > > The idea of building a simple fuselage mockup is excellent. If you don't > plan to start your actual build for several months and you have some basic > tools, just go down and buy some inexpensive pine planks and plywood, plus > some wood glue, and spend a couple of weekends building a fuselage mockup. > It only needs to be from firewall to pilot's seat back and only needs > to include enough of the framing to give you a sturdy mockup that you can > sit in and get an idea of the fit. You could get fancier and assemble a > simple rudder bar and walking beam with control sticks out of broomsticks > or scrap tubing so you can feel the control geometry as well, but that's > extra work. > > No need for precision, no need to take care with glue drips, and you could > get it into shape pretty quickly if you have a staple gun. If you have a > shop with a scrap bin, you could probably build it out of things that you > already have in your scrap bin and lumber cutoff pile. > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > * > > * > > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > > * > > * > > -- John Kuhfahl, Lt Col USAF (Ret), President, KUHLCOUPER LLC ________________________________________________________________________________
Date: Aug 17, 2013
It is a great idea, and you can prevent screwing up some expensive spruce by having already going through the motions one time on the mock fuse. And the kids can play with it when you are done, it the summer you can make a swing out of it and in the winter with that curved bottom it makes a kind of weird sled. rick h On Sat, Aug 17, 2013 at 10:50 AM, Oscar Zuniga wrote: > > The idea of building a simple fuselage mockup is excellent. If you don't > plan to start your actual build for several months and you have some basic > tools, just go down and buy some inexpensive pine planks and plywood, plus > some wood glue, and spend a couple of weekends building a fuselage mockup. > It only needs to be from firewall to pilot's seat back and only needs > to include enough of the framing to give you a sturdy mockup that you can > sit in and get an idea of the fit. You could get fancier and assemble a > simple rudder bar and walking beam with control sticks out of broomsticks > or scrap tubing so you can feel the control geometry as well, but that's > extra work. > > No need for precision, no need to take care with glue drips, and you could > get it into shape pretty quickly if you have a staple gun. If you have a > shop with a scrap bin, you could probably build it out of things that you > already have in your scrap bin and lumber cutoff pile. > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > * > > * > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Aug 18, 2013
All this talk about building fake fuselages. My building time was so precio us I couldn't stand the thought of spending time making something fake and unairworthy. Its not that complicated. Just look at the plans and start cut ting the real stuff. That's why I say make the ribs first. That is where th e learning curve is achieved. Sorry guys. (Designated Curmudgeon while Larry is gone) Dan Helsper Puryear, TN -----Original Message----- From: Rick Holland <at7000ft(at)gmail.com> Sent: Sat, Aug 17, 2013 7:44 pm Subject: Re: Pietenpol-List: fuselage mockup It is a great idea, and you can prevent screwing up some expensive spruce by having already going through the motions one time on the mock fuse. And the kids can play with it when you are done, it the summer you can make a s wing out of it and in the winter with that curved bottom it makes a kind of weird sled. rick h On Sat, Aug 17, 2013 at 10:50 AM, Oscar Zuniga wrot e: The idea of building a simple fuselage mockup is excellent. If you don't p lan to start your actual build for several months and you have some basic t ools, just go down and buy some inexpensive pine planks and plywood, plus s ome wood glue, and spend a couple of weekends building a fuselage mockup. It only needs to be from firewall to pilot's seat back and only needs to in clude enough of the framing to give you a sturdy mockup that you can sit in and get an idea of the fit. You could get fancier and assemble a simple r udder bar and walking beam with control sticks out of broomsticks or scrap tubing so you can feel the control geometry as well, but that's extra work. No need for precision, no need to take care with glue drips, and you could get it into shape pretty quickly if you have a staple gun. If you have a s hop with a scrap bin, you could probably build it out of things that you al ready have in your scrap bin and lumber cutoff pile. Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Aug 18, 2013
I agree Dan. Also if you make the fuse wider like I did at 26 inches you won ,t have to worry about getting in. Cheers, gardiner Sent from my iPad On Aug 18, 2013, at 7:44 AM, danhelsper(at)aol.com wrote: > All this talk about building fake fuselages. My building time was so preci ous I couldn't stand the thought of spending time making something fake and u nairworthy. Its not that complicated. Just look at the plans and start cutti ng the real stuff. That's why I say make the ribs first. That is where the l earning curve is achieved. Sorry guys. > > (Designated Curmudgeon while Larry is gone) > > Dan Helsper > Puryear, TN > -----Original Message----- > From: Rick Holland <at7000ft(at)gmail.com> > To: pietenpol-list > Sent: Sat, Aug 17, 2013 7:44 pm > Subject: Re: Pietenpol-List: fuselage mockup > > It is a great idea, and you can prevent screwing up some expensive spruce by having already going through the motions one time on the mock fuse. And t he kids can play with it when you are done, it the summer you can make a swi ng out of it and in the winter with that curved bottom it makes a kind of we ird sled. > > rick h > > > On Sat, Aug 17, 2013 at 10:50 AM, Oscar Zuniga wro te: >> >> The idea of building a simple fuselage mockup is excellent. If you don't plan to start your actual build for several months and you have some basic t ools, just go down and buy some inexpensive pine planks and plywood, plus so me wood glue, and spend a couple of weekends building a fuselage mockup. It only needs to be from firewall to pilot's seat back and only needs to inclu de enough of the framing to give you a sturdy mockup that you can sit in and get an idea of the fit. You could get fancier and assemble a simple rudder bar and walking beam with control sticks out of broomsticks or scrap tubing so you can feel the control geometry as well, but that's extra work. >> >> No need for precision, no need to take care with glue drips, and you coul d get it into shape pretty quickly if you have a staple gun. If you have a s hop with a scrap bin, you could probably build it out of things that you alr eady have in your scrap bin and lumber cutoff pile. >> >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution > > > > -- > Rick Holland > Castle Rock, Colorado > NX6819Z > > > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 18, 2013
Dan just beat me to the thought. If this was a new design it would be a different story, or if you plan on redesigning the airplane (not recommended). I started with the ribs. You can start the project with less than two hundred dollars, build the jig and go at it. I did not build a mock up and would have felt I was wasting building time. I drew out the larger parts on brown paper and ordered very specific cuts from Spruce and Wicks. They are very accommodating and it saves a lot of waste. Don't over analyze and don't over plan. Order some cap strip (5 foot pieces), 16th inch ply, ask them to cut it for cheapest shipping, buy the T-88 local and go to it. Plenty of examples of rib jigs on the web. Jump in with the ribs and rest will take care of it self. The EAA website has some good tips in their Hints for Homebuilders section. Have fun. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406957#406957 ________________________________________________________________________________
Subject: Brodhead 2012
Date: Aug 18, 2013
A few shots of some favorite airplanes for your viewing pleasure. Kevin - I'm sure Edition2 will looks as great as the first. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406958#406958 Attachments: http://forums.matronics.com//files/dsc00276_121.jpg http://forums.matronics.com//files/dsc00266_154.jpg http://forums.matronics.com//files/dsc00257_113.jpg http://forums.matronics.com//files/dsc00246_113.jpg http://forums.matronics.com//files/dsc00243_443.jpg ________________________________________________________________________________
Date: Aug 18, 2013
Great post Dan, I;m with you. Dick N. ----- Original Message ----- From: danhelsper(at)aol.com To: pietenpol-list(at)matronics.com Sent: Sunday, August 18, 2013 6:44 AM Subject: Re: Pietenpol-List: fuselage mockup All this talk about building fake fuselages. My building time was so precious I couldn't stand the thought of spending time making something fake and unairworthy. Its not that complicated. Just look at the plans and start cutting the real stuff. That's why I say make the ribs first. That is where the learning curve is achieved. Sorry guys. (Designated Curmudgeon while Larry is gone) Dan Helsper Puryear, TN -----Original Message----- From: Rick Holland <at7000ft(at)gmail.com> To: pietenpol-list Sent: Sat, Aug 17, 2013 7:44 pm Subject: Re: Pietenpol-List: fuselage mockup It is a great idea, and you can prevent screwing up some expensive spruce by having already going through the motions one time on the mock fuse. And the kids can play with it when you are done, it the summer you can make a swing out of it and in the winter with that curved bottom it makes a kind of weird sled. rick h On Sat, Aug 17, 2013 at 10:50 AM, Oscar Zuniga wrote: The idea of building a simple fuselage mockup is excellent. If you don't plan to start your actual build for several months and you have some basic tools, just go down and buy some inexpensive pine planks and plywood, plus some wood glue, and spend a couple of weekends building a fuselage mockup. It only needs to be from firewall to pilot's seat back and only needs to include enough of the framing to give you a sturdy mockup that you can sit in and get an idea of the fit. You could get fancier and assemble a simple rudder bar and walking beam with control sticks out of broomsticks or scrap tubing so you can feel the control geometry as well, but that's extra work. No need for precision, no need to take care with glue drips, and you could get it into shape pretty quickly if you have a staple gun. If you have a shop with a scrap bin, you could probably build it out of things that you already have in your scrap bin and lumber cutoff pile. Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rick Holland Castle Rock, Colorado NX6819Z " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 18, 2013
On the fuselage mock-up, that's just what I did..(that was the original question) Wasn't suggesting everyone do it... Ben On 8/18/2013 12:47 PM, Dick N wrote: > Great post Dan, I;m with you. > Dick N. > > ----- Original Message ----- > *From:* danhelsper(at)aol.com > *To:* pietenpol-list(at)matronics.com > > *Sent:* Sunday, August 18, 2013 6:44 AM > *Subject:* Re: Pietenpol-List: fuselage mockup > > All this talk about building fake fuselages. My building time was > so precious I couldn't stand the thought of spending time making > something fake and unairworthy. Its not that complicated. Just > look at the plans and start cutting the real stuff. That's why I > say make the ribs first. That is where the learning curve is > achieved. Sorry guys. > (Designated Curmudgeon while Larry is gone) > Dan Helsper > Puryear, TN > -----Original Message----- > From: Rick Holland <at7000ft(at)gmail.com> > To: pietenpol-list > Sent: Sat, Aug 17, 2013 7:44 pm > Subject: Re: Pietenpol-List: fuselage mockup > > It is a great idea, and you can prevent screwing up some > expensive spruce by having already going through the motions one > time on the mock fuse. And the kids can play with it when you are > done, it the summer you can make a swing out of it and in the > winter with that curved bottom it makes a kind of weird sled. > > rick h > > > On Sat, Aug 17, 2013 at 10:50 AM, Oscar Zuniga > > wrote: > > > The idea of building a simple fuselage mockup is excellent. > If you don't plan to start your actual build for several > months and you have some basic tools, just go down and buy > some inexpensive pine planks and plywood, plus some wood > glue, and spend a couple of weekends building a fuselage > mockup. It only needs to be from firewall to pilot's seat > back and only needs to include enough of the framing to give > you a sturdy mockup that you can sit in and get an idea of the > fit. You could get fancier and assemble a simple rudder bar > and walking beam with control sticks out of broomsticks or > scrap tubing so you can feel the control geometry as well, but > that's extra work. > > No need for precision, no need to take care with glue drips, > and you could get it into shape pretty quickly if you have > a staple gun. If you have a shop with a scrap bin, you could > probably build it out of things that you already have in your > scrap bin and lumber cutoff pile. > > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > -- > Rick Holland > Castle Rock, Colorado > NX6819Z > > * > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > * > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matronics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Aug 18, 2013
Nice shots, Adrian! I especially like the picture of Dan Yocum's Piet! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of pineymb Sent: Sunday, August 18, 2013 6:41 AM Subject: Pietenpol-List: Brodhead 2012 A few shots of some favorite airplanes for your viewing pleasure. Kevin - I'm sure Edition2 will looks as great as the first. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406958#406958 Attachments: http://forums.matronics.com//files/dsc00276_121.jpg http://forums.matronics.com//files/dsc00266_154.jpg http://forums.matronics.com//files/dsc00257_113.jpg http://forums.matronics.com//files/dsc00246_113.jpg http://forums.matronics.com//files/dsc00243_443.jpg ________________________________________________________________________________
Subject: Re: Brodhead 2012
Date: Aug 18, 2013
Yea me too. I gave that kid (in the background) with the Mohawk a free ride !! Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sun, Aug 18, 2013 4:42 pm Subject: RE: Pietenpol-List: Brodhead 2012 Nice shots, Adrian! I especially like the picture of Dan Yocum's Piet! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of pineymb Sent: Sunday, August 18, 2013 6:41 AM Subject: Pietenpol-List: Brodhead 2012 A few shots of some favorite airplanes for your viewing pleasure. Kevin - I'm sure Edition2 will looks as great as the first. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406958#406958 Attachments: http://forums.matronics.com//files/dsc00276_121.jpg http://forums.matronics.com//files/dsc00266_154.jpg http://forums.matronics.com//files/dsc00257_113.jpg http://forums.matronics.com//files/dsc00246_113.jpg http://forums.matronics.com//files/dsc00243_443.jpg ________________________________________________________________________________
Date: Aug 18, 2013
...'cuz he didn't like the first? Gary Sent from my iPhone On Aug 18, 2013, at 3:18 PM, danhelsper(at)aol.com wrote: > Yea me too. I gave that kid (in the background) with the Mohawk a free rid e!! > > Dan Helsper > Puryear, TN > > > -----Original Message----- > From: Gary Boothe <gboothe5(at)comcast.net> > To: pietenpol-list > Sent: Sun, Aug 18, 2013 4:42 pm > Subject: RE: Pietenpol-List: Brodhead 2012 > > > Nice shots, Adrian! I especially like the picture of Dan Yocum's Piet! > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of pineymb > Sent: Sunday, August 18, 2013 6:41 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Brodhead 2012 > > > A few shots of some favorite airplanes for your viewing pleasure. > Kevin - I'm sure Edition2 will looks as great as the first. > > -------- > Adrian M > Winnipeg, MB > Canada > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406958#406958 > > > > > Attachments: > > http://forums.matronics.com//files/dsc00276_121.jpg > http://forums.matronics.com//files/dsc00266_154.jpg > http://forums.matronics.com//files/dsc00257_113.jpg > http://forums.matronics.com//files/dsc00246_113.jpg > http://forums.matronics.com//files/dsc00243_443.jpg > > > > > > > > > " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 18, 2013
Yep!! always liked Dan's plane - maybe a little bias, has a lot of similarities to mine I think. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406996#406996 ________________________________________________________________________________
Date: Aug 18, 2013
Subject: More Latex Paint
Hi Guys, Me again. I will be doing a webinar version of the forum that I presented at Oshkosh on painting with Latex paint. The forum was well attended and I have received a lot of inquiries from builders that could not make it to Airventure. The EAA's webinars seems to be a good solution to share the information with anyone else that is interested. "Latex Paint for Your Homebuilt Aircraft" You can go to http://www.eaa.org/webinars to see upcoming presentations and to register to participate. It will be basically the same slides that are on my web site, with my droning dialog added of course. Keep it cheap Malcolm Morrison ________________________________________________________________________________
Subject: A Question About Lift Strut Fittings
Date: Aug 18, 2013
I am getting ready to start making metal fittings. I have a question specifically about the fittings that connect the top of the lift strut to the spar. I have seen or read other people's discussions about these lift strut fittings, where people said the original design left little working room when trying to work at that fitting once the wing is covered. So my question is this- did you build your fittings to plans, and if not, how far do you recommend the fitting should stick out below the lower capstrip of the ribs? Thanks! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407005#407005 ________________________________________________________________________________
Date: Aug 18, 2013
Now, now... everyone play nice ;o) Not everyone gets to work in the shop frequently, and not everyone has ever built something like an airplane. My suggestion was to a particular individual who stated that they won't be starting the construction of their actual Air Camper until next year (for whatever their reasons), so I suggested that in the meantime it might be a fun and low-stress project of a weekend or two to put together a very simple and low-cost mockup. This would serve two purposes: (1) at a very minimal outlay of time and money, it would allow the prospective builder to get a feel for how the airplane is constructed and how it fits, and (2) if it fires some enthusiasm based on how simple and straightforward it is, it may advance their program to just get started now rather than waiting until February. If this builder is like me, he is very unsure of his building skills and very concerned about doing something inaccurately or "wrong", so just playing with some Doug fir or pine studs and some cheap plywood means that nothing happens if the fake longeron has some wowies or blade burns in it when it gets ripped, and nothing happens if a crosscut goes too far. It all goes together with Elmer's glue and staples (or even drywall screws), and nobody is going to inspect it. If it doesn't work out, you spray paint it with camouflage paint for the kids, or you smash it into kindling and enjoy the fire one evening. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407009#407009 ________________________________________________________________________________
Subject: Re: A Question About Lift Strut Fittings
Date: Aug 18, 2013
Terry; I'm sorry I can't offer exact dimensions and I don't know whether the fittings on 41CC are to plans or not, but perhaps you can look at the pictures here: http://www.flysquirrel.net/piets/repairs/inspection.html The 2nd and 6th images on that page will give you some idea of what you have to deal with in that area. Besides the heads of the strut attach bolts, you have to slip on the tangs that the X-brace wires attach to. Another consideration, albeit minor, is that the inspection covers need to be accessed and they are right at the bolt heads. You can see a very nice arrangement here: http://www.flysquirrel.net/piets/John_piet.html Look at the 5th image from the bottom. John Dilatush installed wing tiedowns at those strut attach points and also extended the fittings generously below the bottom wing skin so that a box-end wrench or socket could be put over the nuts on the attach fitting bolts. You might put a socket on your ratchet and see how much space you need to get it onto a nut that is tight up against a surface. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407010#407010 ________________________________________________________________________________
Date: Aug 18, 2013
Scout's nemesis will always be Niner Niner Kilo Papa. We don't stand a snowball's chance in hell of ever catching him, much less with his eyes blinded by the sun, but Fat Bottomed Girl smoked my tail so badly that I will never forget it. Me and my buddy took off from Old Kingsbury Aerodrome so pleased with ourselves and the next thing we know as we are leveled off in cruise, "HONK, HONK!"- there's Niner Kilo Papa climbing up our tailpipe like we were standing still. Dang it, Axel! One of these days I'll get even. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407012#407012 ________________________________________________________________________________
Subject: Re: Missing posts
Date: Aug 18, 2013
Yep... this was brought up a while back... not sure what the fix is. -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407013#407013 ________________________________________________________________________________
Date: Aug 18, 2013
Terry, the new improved plans from 1934 show both the original strut attach strap design and a new design that Mr. Pietenpol recommended as a replacement. The 'new' design can be easily lengthened by a small amount. On Aug 18, 2013, at 7:11 PM, "jarheadpilot82" wrote: > > I am getting ready to start making metal fittings. I have a question specifically about the fittings that connect the top of the lift strut to the spar. > > I have seen or read other people's discussions about these lift strut fittings, where people said the original design left little working room when trying to work at that fitting once the wing is covered. So my question is this- did you build your fittings to plans, and if not, how far do you recommend the fitting should stick out below the lower capstrip of the ribs? > > Thanks! > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407005#407005 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 19, 2013
No....I was trying to get him to carry my gas can into town..... Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sun, Aug 18, 2013 5:34 pm Subject: Re: Pietenpol-List: Brodhead 2012 ...'cuz he didn't like the first? Gary Sent from my iPhone On Aug 18, 2013, at 3:18 PM, danhelsper(at)aol.com wrote: Yea me too. I gave that kid (in the background) with the Mohawk a free ride !! Dan Helsper Puryear, TN -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sun, Aug 18, 2013 4:42 pm Subject: RE: Pietenpol-List: Brodhead 2012 Nice shots, Adrian! I especially like the picture of Dan Yocum's Piet! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of pineymb Sent: Sunday, August 18, 2013 6:41 AM Subject: Pietenpol-List: Brodhead 2012 A few shots of some favorite airplanes for your viewing pleasure. Kevin - I'm sure Edition2 will looks as great as the first. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406958#406958 Attachments: http://forums.matronics.com//files/dsc00276_121.jpg http://forums.matronics.com//files/dsc00266_154.jpg http://forums.matronics.com//files/dsc00257_113.jpg http://forums.matronics.com//files/dsc00246_113.jpg http://forums.matronics.com//files/dsc00243_443.jpg " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Aug 19, 2013
Subject: Re: For those of you who finished where did you start
building? Hello Todd and welcome.=0A=0AI started- my project building ribs for two reasons. To me, repetitive work gets really boring really fast, so I chose to start with making ribs because I knew my motivation level would be quite high at the start of this new project.- I left the work I was looking fo rward to the most for last, building the fuselage. Second, I chose to make my own ribs from scratch using rough cut spruce purchased in bulk. This was less expensive to purchase and I like making my own parts anyway, so it wa s fun for me.- As long as you start...and hopefully finish, what/how you begin doesn't matter.=0A=0A=0A-=0AMichael Perez=0APietenpol HINT Videos =0AKaretaker Aero=0Awww.karetakeraero.com=0A ________________________________________________________________________________
Subject: Re: More Latex Paint
Date: Aug 19, 2013
Just registered. Thanks, ~WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407024#407024 ________________________________________________________________________________
Date: Aug 19, 2013
Thanks Malcolm. I just registered as well. Greg Bacon NX114D On Sun, Aug 18, 2013 at 6:33 PM, wrote: > Hi Guys, Me again. > > I will be doing a webinar version of the forum that I presented at Oshkosh > on > painting with Latex paint. The forum was well attended and I have received > a > lot of inquiries from builders that could not make it to Airventure. The > EAA's > webinars seems to be a good solution to share the information with anyone > else > that is interested. > > "Latex Paint for Your Homebuilt Aircraft" > > You can go to http://www.eaa.org/webinars to see upcoming presentations > and to > register to participate. It will be basically the same slides that are on > my > web site, with my droning dialog added of course. > > Keep it cheap > Malcolm Morrison > > * > > * > > -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
Date: Aug 19, 2013
Subject: T.C. is back
Mr. Helsperetal, It is true, I Larry Williams (aka. Top Curmudgeon) have returned to actively scanning the daily digest ;ever vigilant for some poor soul who inadvertently posts a question that has been answered 500 times in the past 6 months or asks something so off-base that his ability to build a true flying machine is doubtful. (for those....well, we banish them to Belize!) As I have been on sabbatical, I have come closer to being "one with the sky" and have therefore gained a sense of clarity, charity and compassion. As a result, the fiery barbs from my keyboard will likely be much more infrequent and less harsh than what was the norm in days gone by. Not by any means nice, just gentler............maybe. Larry (TC) Williams ps. Trying to get to Blakesburg, IA and Brodhead for the antique/grass roots fly-ins in the next couple of weeks. Anyone else??? ________________________________________________________________________________
Subject: Re: Dynamic balancing ?
Date: Aug 19, 2013
Dan I like your balancer. One thing I can add though from my own experience is that the CG of the prop is not on the top surface, it is inside 'somewhere close' to one half the thickness of the hub. If you machine a plug that fits the bore of the prop shaft hole, then you can lower the fulcrum point into the bore of the prop shaft hole in the prop. The balancer becomes way more sensitive. You can also make different plugs to fit different props if needed. You want to get close to the 3D CG point, slightly above it. If below obviously it will never balance. Rather than relying on the bubble level, simply get a length of clear plastic tubing and clamp it to the table on each side by the propeller tips. Add water to the tube till the level is adjacent to the prop tip. Gravity is a harsh mistress but in this case she gives us a super accurate reference line. If you want to involve children as a learning experience, get them to add the water with food coloring, they'll have fun and learn something at the same time! Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407033#407033 ________________________________________________________________________________
Subject: Re: T.C. is back
Date: Aug 19, 2013
Hi Larry I am glad your back. I am going with wifee to AAA on Labor Day Weekend. I hope to see you there. Dick N. ----- Original Message ----- From: Lawrence Williams To: Pietlist Sent: Monday, August 19, 2013 8:27 AM Subject: Pietenpol-List: T.C. is back Mr. Helsper et al, It is true, I Larry Williams (aka. Top Curmudgeon) have returned to actively scanning the daily digest ;ever vigilant for some poor soul who inadvertently posts a question that has been answered 500 times in the past 6 months or asks something so off-base that his ability to build a true flying machine is doubtful. (for those....well, we banish them to Belize!) As I have been on sabbatical, I have come closer to being "one with the sky" and have therefore gained a sense of clarity, charity and compassion. As a result, the fiery barbs from my keyboard will likely be much more infrequent and less harsh than what was the norm in days gone by. Not by any means nice, just gentler............maybe. Larry (TC) Williams ps. Trying to get to Blakesburg, IA and Brodhead for the antique/grass roots fly-ins in the next couple of weeks. Anyone else??? ________________________________________________________________________________
Date: Aug 19, 2013
Dick you flying or driving? Haven't been there for 3 or 4 years. May try and rearrange my schedule to attend via motorhome... Sent from my iPad Jack Textor On Aug 19, 2013, at 11:19 AM, "Dick N" wrote: > Hi Larry > I am glad your back. I am going with wifee to AAA on Labor Day Weekend. I hope to see you there. > Dick N. > ----- Original Message ----- > From: Lawrence Williams > To: Pietlist > Sent: Monday, August 19, 2013 8:27 AM > Subject: Pietenpol-List: T.C. is back > > Mr. Helsper et al, > > It is true, I Larry Williams (aka. Top Curmudgeon) have returned to active ly scanning the daily digest ;ever vigilant for some poor soul who inadverte ntly posts a question that has been answered 500 times in the past 6 months o r asks something so off-base that his ability to build a true flying machine is doubtful. (for those....well, we banish them to Belize!) > > As I have been on sabbatical, I have come closer to being "one with the sk y" and have therefore gained a sense of clarity, charity and compassion. As a result, the fiery barbs from my keyboard will likely be much more infrequen t and less harsh than what was the norm in days gone by. Not by any means ni ce, just gentler............maybe. > > Larry (TC) Williams > > ps. Trying to get to Blakesburg, IA and Brodhead for the antique/grass roo ts fly-ins in the next couple of weeks. Anyone else??? > > > href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matr onics.com/Navigator?Pietenpol-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 19, 2013
Joe, Yes good point about trying to lower the fulcrum point. This would give a m ore accurate reading. Dan Helsper Puryear, TN -----Original Message----- From: scudrun <jstreet(at)uwaterloo.ca> Sent: Mon, Aug 19, 2013 9:57 am Subject: Pietenpol-List: Re: Dynamic balancing ? Dan I like your balancer. One thing I can add though from my own experienc e is that the CG of the prop is not on the top surface, it is inside 'somewhere close' to one half the thickness of the hub. If you machine a plug that f its the bore of the prop shaft hole, then you can lower the fulcrum point into the bore of the prop shaft hole in the prop. The balancer becomes way more sensitive. You can also make different plugs to fit different props if nee ded. You want to get close to the 3D CG point, slightly above it. If below obvi ously it will never balance. Rather than relying on the bubble level, simply get a length of clear plastic tubing and clamp it to the table on each side by th e propeller tips. Add water to the tube till the level is adjacent to the pr op tip. Gravity is a harsh mistress but in this case she gives us a super acc urate reference line. If you want to involve children as a learning experience, g et them to add the water with food coloring, they'll h! ave fun and learn something at the same time! Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407033#407033 ________________________________________________________________________________
Date: Aug 19, 2013
Thank God. Now I don't have to be quite as vigilante while scanning the lis t posts! Dan Helsper Puryear, TN -----Original Message----- From: Lawrence Williams <lnawms(at)yahoo.com> Sent: Mon, Aug 19, 2013 8:28 am Subject: Pietenpol-List: T.C. is back Mr. Helsper et al, It is true, I Larry Williams (aka. Top Curmudgeon) have returned to activel y scanning the daily digest ;ever vigilant for some poor soul who inadverte ntly posts a question that has been answered 500 times in the past 6 months or asks something so off-base that his ability to build a true flying mach ine is doubtful. (for those....well, we banish them to Belize!) As I have been on sabbatical, I have come closer to being "one with the sky " and have therefore gained a sense of clarity, charity and compassion. As a result, the fiery barbs from my keyboard will likely be much more infrequ ent and less harsh than what was the norm in days gone by. Not by any means nice, just gentler............maybe. Larry (TC) Williams ps. Trying to get to Blakesburg, IA and Brodhead for the antique/grass root s fly-ins in the next couple of weeks. Anyone else??? ________________________________________________________________________________
Date: Aug 19, 2013
Hi Jack I am taking my camper we will be in the SW campground. I hope you can make it also. Dick N. ----- Original Message ----- From: Jack To: pietenpol-list(at)matronics.com Sent: Monday, August 19, 2013 12:10 PM Subject: Re: Pietenpol-List: T.C. is back Dick you flying or driving? Haven't been there for 3 or 4 years. May try and rearrange my schedule to attend via motorhome... Sent from my iPad Jack Textor On Aug 19, 2013, at 11:19 AM, "Dick N" wrote: Hi Larry I am glad your back. I am going with wifee to AAA on Labor Day Weekend. I hope to see you there. Dick N. ----- Original Message ----- From: Lawrence Williams To: Pietlist Sent: Monday, August 19, 2013 8:27 AM Subject: Pietenpol-List: T.C. is back Mr. Helsper et al, It is true, I Larry Williams (aka. Top Curmudgeon) have returned to actively scanning the daily digest ;ever vigilant for some poor soul who inadvertently posts a question that has been answered 500 times in the past 6 months or asks something so off-base that his ability to build a true flying machine is doubtful. (for those....well, we banish them to Belize!) As I have been on sabbatical, I have come closer to being "one with the sky" and have therefore gained a sense of clarity, charity and compassion. As a result, the fiery barbs from my keyboard will likely be much more infrequent and less harsh than what was the norm in days gone by. Not by any means nice, just gentler............maybe. Larry (TC) Williams ps. Trying to get to Blakesburg, IA and Brodhead for the antique/grass roots fly-ins in the next couple of weeks. Anyone else??? href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.mat ronics.com/Navigator?Pietenpol-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: ELT wanted
Date: Aug 19, 2013
Inspecting my Narco ELT-10 for annual=2C I find that the battery has create d corrosion that has damaged the printed circuit board and battery connecto r=2C so it's now junk. I do not want to spend the money on a "real" 406 MH z ELT so I'm looking for an old standard 121.5 MHz ELT like my Narco or the thousands of other yellow and orange ELTs that used to be in every Cessna and Piper out there. If someone has one they would like to sell or if they can refer me to a shop or individual that may have one=2C let me know (off line). Oscar Zuniga Air Camper NX41CC "Scout" Medford=2C OR ________________________________________________________________________________
From: "Dortch, Steven D MAJ MIL USA NGB" <steven.d.dortch(at)us.army.mil>
Date: Aug 19, 2013
Subject: Re: ELT wanted
UNCLASSIFIED Before you buy. Sure consider the ones that use the coppertop D cell batteries rather than the custom (expensive) batteries. Steve On 08/19/13, Oscar Zuniga wrote: > > > > Inspecting my Narco ELT-10 for annual, I find that the battery has created corrosion that has damaged the printed circuit board and battery connector, so it's now junk. I do not want to spend the money on a "real" 406 MHz ELT so I'm looking for an old standard 121.5 MHz ELT like my Narco or the thousands of other yellow and orange ELTs that used to be in every Cessna and Piper out there. If someone has one they would like to sell or if they can refer me to a shop or individual that may have one, let me know (offline). > > Oscar Zuniga > Air Camper NX41CC "Scout" > Medford, OR > > > UNCLASSIFIED ________________________________________________________________________________
Date: Aug 19, 2013
ELT's are famous for that, I always take ours apart at the annual and clean it and put a little no-ox grease- or corrosion prevention compound on th e batts to try to prevent that.=0A-=0AShad=0A =0A=0A_____________________ ___________=0A From: "Dortch, Steven D MAJ MIL USA NGB" <steven.d.dortch@us .army.mil>=0ATo: pietenpol-list(at)matronics.com =0ASent: Monday, August 19, 2 013 3:50 PM=0ASubject: Re: Pietenpol-List: ELT wanted =0A =0A=0A--> Pieten pol-List message posted by: "Dortch, Steven D MAJ MIL USA NGB" =0A=0AUNCLASSIFIED=0ABefore you buy. Sure consider the one s that use the coppertop D cell batteries rather than the custom (expensive ) batteries.=0A=0ASteve =0A=0AOn 08/19/13, Oscar Zuniga wrote:=0A> =0A> =0A > =0A> Inspecting my Narco ELT-10 for annual, I find that the battery has c reated corrosion that has damaged the printed circuit board and battery con nector, so it's now junk. I do not want to spend the money on a "real" 406 MHz ELT so I'm looking for an old standard 121.5 MHz ELT like my Narco or t he thousands of other yellow and orange ELTs that used to be in every Cessn a and Piper out there. If someone has one they would like to sell or if the y can refer me to a shop or individual that may have one, let me know (offl ine).=0A> =0A> Oscar Zuniga=0A> Air Camper NX41CC "Scout"=0A> Medford, OR == ________________________________________________________________________________
Date: Aug 19, 2013
[UNCLASSIFIED] Steve: even the "custom" batteries for a standard ELT are less cost than the cheapest 406 MHz ELT, so I'm not going to be too picky at this point. I just need one for annual condx inspection. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407060#407060 ________________________________________________________________________________
building?
Date: Aug 20, 2013
If you don't mind me asking, where did you get the rough cut spruce? Thanks, Todd Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407102#407102 ________________________________________________________________________________
Date: Aug 20, 2013
building? I bought most of mine from Public Lumber and some from McCormick Lumber.- It appears both websites have changed are are now not as user friendly as they were when I used them. I would imagine a phone call will get you what you are after.=0A-=0AAt the time, I was able to pick and choose widths an d thickness along with length. I believe I bought 1" X 8" X 6' and made all my capstrip for the ribs. As time went on I bought various sizes-to cut up-what was needed for the current stage of building.- Shipping was not too bad, otherwise I would have tried something else. (all UPS or FedEx.) - =0A-=0AIt is also nice to cut your own because you can get the most o ut of the stock...if you plan well prior to cutting.=0A-=0A-=0A=0AMicha el Perez=0APietenpol HINT Videos=0AKaretaker Aero=0Awww.karetakeraero.com =0A=0A=0A> ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Aug 20, 2013
Oscar, Are there any aircraft salvage yards near you? You could get a previously enjoyed or tested one from a place like that. A lot of airplanes get salvaged that haven't had severe accidents. Ground loops come to mind. Perhaps Wentworth aircraft or someone near you will have one. Just get in touch with our friend "Google". He can help you out. Good luck, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407114#407114 ________________________________________________________________________________
From: "Sanders, Andrew P" <andrew.p.sanders(at)boeing.com>
Date: Aug 20, 2013
Oscar: I have a spare Narco ELT-10 that you are welcome to for the price of shippi ng. If that is acceptable to you, send me your "Snail Mail" address off list. I will be at the hangar this weekend and will dig it out then. Also, would you like it "heavy" (with a recently expired battery) or "light " (without). Regards, Andrew C-177 "Cardinal" N2206Y w/180 hp & CS. From: Oscar Zuniga <taildrags(at)hotmail.com<mailto:taildrags(at)hotmail.co m>> Subject: Pietenpol-List: ELT wanted Inspecting my Narco ELT-10 for annual=2C I find that the battery ha s create d corrosion that has damaged the printed circuit board and battery co nnecto r=2C so it's now junk. I do not want to spend the money on a "real " 406 MH z ELT so I'm looking for an old standard 121.5 MHz ELT like my Narco or the thousands of other yellow and orange ELTs that used to be in every C essna and Piper out there. If someone has one they would like to sell or i f they can refer me to a shop or individual that may have one=2C let me k now (off line). Oscar Zuniga Air Camper NX41CC "Scout" Medford=2C OR ________________________________________________________________________________
building?
Date: Aug 20, 2013
I started building in a winter month also. I did all the metal fittings and assemblies first so I didn't have to worry about my cold basement causing problems with glue setting up. I only had to heat a very small space to get them all cut out and welded up. When it warmed up I started in on other smaller stuff like rudders, elevators, wing ribs and whatever I could store in my garage. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407127#407127 ________________________________________________________________________________
Date: Aug 20, 2013
Andrew=2C if Oscar doesn't want it I will take it. My Piet is not as far a long as his but I will need an ELT eventually. If Oscar doesn't want it=2C send it "light" to: CN Campbelll=2C 604 Cordova Court=2C Salisbury=2C NC 28146. Don't know how you want to handle the shipping expenses. If you send it pr epaid=2C I will reimburse you. Thanks=2C Chuck From: andrew.p.sanders(at)boeing.com Subject: Pietenpol-List: Re: ELT wanted Date: Tue=2C 20 Aug 2013 16:43:42 +0000 =0A =0A =0A =0A =0A =0A =0A =0A =0A Oscar:=0A =0A I have a spare Narco ELT-10 that you are welcome to for the price of shippi ng.=0A =0A If that is acceptable to you=2C send me your =93Snail Mail=94 address off l ist. I will be at the hangar this weekend and will dig it out then.=0A =0A Also=2C would you like it =93heavy=94 (with a recently expired battery) or =93light=94 (without).=0A =0A Regards=2C=0A Andrew=0A =0A C-177 =93Cardinal=94=0A N2206Y w/180 hp & CS.=0A =0A From: Oscar Zuniga <taildrags(at)hotmail.com>=0A Subject: Pietenpol-List: ELT wanted=0A =0A Inspecting my Narco ELT-10 for annual=2C I find that the battery has crea te=0A d corrosion that has damaged the printed circuit board and battery connecto =0A r=2C so it's now junk. I do not want to spend the money on a "real" 406 MH=0A z ELT so I'm looking for an old standard 121.5 MHz ELT like my Narco or the =0A thousands of other yellow and orange ELTs that used to be in every Cessna =0A and Piper out there. If someone has one they would like to sell or if they =0A can refer me to a shop or individual that may have one=2C let me know (o ff=0A line).=0A =0A =0A Oscar Zuniga=0A =0A Air Camper NX41CC "Scout"=0A =0A Medford=2C OR =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Aug 20, 2013
building?
I still have several fittings that I made in advance hanging above my workbench that I had to remake after finding the finished sizes of many glued/welded parts were different than plans. Wife wants me to make windchimes out of them. Would wait on making fittings until you need them to hold something together. rh On Tue, Aug 20, 2013 at 3:26 PM, jammer wrote: > > I started building in a winter month also. I did all the metal fittings > and assemblies first so I didn't have to worry about my cold basement > causing problems with glue setting up. I only had to heat a very small > space to get them all cut out and welded up. When it warmed up I started > in on other smaller stuff like rudders, elevators, wing ribs and whatever I > could store in my garage. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407127#407127 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Aug 20, 2013
btw - just finished my airworthiness last Saturday and yes the DAR did ask to see my ELT. Didn't care if it worked or even had batteries in it. I got it off ebay for $19 + $50 shipping, from Aukland NZ. rh On Tue, Aug 20, 2013 at 3:34 PM, Chuck Campbell wro te: > Andrew, if Oscar doesn't want it I will take it. My Piet is not as far > along as his but I will need an ELT eventually. If Oscar doesn't want it , > send it "light" to: > CN Campbelll, 604 Cordova Court, Salisbury, NC 28146. > > Don't know how you want to handle the shipping expenses. If you send it > prepaid, I will reimburse you. Thanks, Chuck > ------------------------------ > From: andrew.p.sanders(at)boeing.com > To: taildrags(at)hotmail.com > Subject: Pietenpol-List: Re: ELT wanted > Date: Tue, 20 Aug 2013 16:43:42 +0000 > > Oscar: > > I have a spare Narco ELT-10 that you are welcome to for the price of > shipping. > > If that is acceptable to you, send me your =93Snail Mail=94 address off l ist. > I will be at the hangar this weekend and will dig it out then. > > Also, would you like it =93heavy=94 (with a recently expired battery) or > =93light=94 (without). > > Regards, > Andrew > > C-177 =93Cardinal=94 > N2206Y w/180 hp & CS. > > From: Oscar Zuniga <*taildrags(at)hotmail.com* <taildrags(at)hotmail.com>> > Subject: Pietenpol-List: ELT wanted > > Inspecting my Narco ELT-10 for annual=2C I find that the battery has cr eate > d corrosion that has damaged the printed circuit board and battery connec to > r=2C so it's now junk. I do not want to spend the money on a "real" 40 6 MH > z ELT so I'm looking for an old standard 121.5 MHz ELT like my Narco or t he > thousands of other yellow and orange ELTs that used to be in every Cessn a > and Piper out there. If someone has one they would like to sell or if th ey > can refer me to a shop or individual that may have one=2C let me know (off > line). > > > Oscar Zuniga > > Air Camper NX41CC "Scout" > > Medford=2C OR > > > * > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ===========http://forums.matronics.com > ========== > ="_blank">http://www.matronics.com/contribution > ========== > * > > * > =========== =========== =========== =========== > * > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: NX626E
Date: Aug 20, 2013
Hello good people! You better all grab your courage everybody because this is flying weather. Now Im talking about the best 20 minutes of your life. When you die and St. Peter asks you, Hey, when were you happiest down there? Youre gonna say well, it was okay the day that I got married and I didnt much mind the day I first fell in love but seeing the sky in my own Pietenpol Air Camper that I built myself well sir that beats them all. NX626E flew for the first time August 20th, 2013 (Video proof forthcoming) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407132#407132 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 20, 2013
Whoa-! That is the best news I've heard all day! Congratulations on a successful first flight, but you'll need to post a lot more detail than that! "Experimental Two-Six Echo, low pass and victory roll approved; cleared to land!" -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407133#407133 ________________________________________________________________________________
Date: Aug 20, 2013
Larry, I hope to be at both Blakesburg and Brodhead this year. Rick Schreiber Valparaiso, in Sent from my iPad On Aug 19, 2013, at 8:27 AM, Lawrence Williams wrote: > Mr. Helsper et al, > > It is true, I Larry Williams (aka. Top Curmudgeon) have returned to active ly scanning the daily digest ;ever vigilant for some poor soul who inadverte ntly posts a question that has been answered 500 times in the past 6 months o r asks something so off-base that his ability to build a true flying machine is doubtful. (for those....well, we banish them to Belize!) > > As I have been on sabbatical, I have come closer to being "one with the sk y" and have therefore gained a sense of clarity, charity and compassion. As a result, the fiery barbs from my keyboard will likely be much more infrequen t and less harsh than what was the norm in days gone by. Not by any means ni ce, just gentler............maybe. > > Larry (TC) Williams > > ps. Trying to get to Blakesburg, IA and Brodhead for the antique/grass roo ts fly-ins in the next couple of weeks. Anyone else??? > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 20, 2013
Congratulations Bill!! Can't wait to see the vid!! Dan Helsper Puryear, TN -----Original Message----- From: BYD <billsayre(at)ymail.com> Sent: Tue, Aug 20, 2013 6:00 pm Subject: Pietenpol-List: NX626E Hello good people! You better all grab your courage everybody because this is flying weather. Now I=C3=A2=C2=C2=99m talking about the best 20 minutes of your life. When you die and St. Peter asks you, =C3=A2=C2=C2=9CHey, when were you h appiest down there?=C3=A2=C2=C2=9D You=C3=A2=C2=C2=99re gonna say =C3=A2=C2=C2 =93 well, it was okay the day that I got married =C3=A2=C2=C2=93 and I didn=C3=A2=C2=C2=99t much mind the day I first fell in love =C3=A2=C2=C2=93 but seeing the sky in my own Pietenpol Air Camper that I built myself =C3=A2=C2=C2=93 well sir =C3=A2=C2=C2=93 that beats them all. NX626E flew for the first time August 20th, 2013 (Video proof forthcoming) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407132#407132 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 20, 2013
I fly a GN-1 constructed by someone else, but now you're making me want to build a Piet... Congratz! -------- L.Metzel KLNC A65-8 N2308C AN Hardware Airframe 712TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407138#407138 ________________________________________________________________________________
Date: Aug 20, 2013
Subject: Re: NX626E
Congratulations Bill!! Glad to hear of your success. On Tue, Aug 20, 2013 at 5:59 PM, BYD wrote: > > Hello good people! > > You better all grab your courage everybody because this is flying weather . > Now I=92m talking about the best 20 minutes of your life. > > When you die and St. Peter asks you, =93Hey, when were you happiest down > there?=94 You=92re gonna say ' well, it was okay the day that I got mar ried ' > and I didn=92t much mind the day I first fell in love ' but seeing the sky in > my own Pietenpol Air Camper that I built myself ' well sir ' that bea ts > them all. > > NX626E flew for the first time August 20th, 2013 > (Video proof forthcoming) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407132#407132 > > =========== =========== =========== =========== > > -- Greg Bacon Prairie Home, MO NX114D(Mountain Piet) ________________________________________________________________________________
building?
Date: Aug 20, 2013
I have an experience to share with you guys. Once I was in a remote place, my signal in my phone got jammed, i thought the problem would be with my service provider. After coming back home i gave black and blues to my customer care highlighting my issue. They pleaded me saying that the problem is not with them. Then i browsed through the search engine regarding my issue, i got a remedy for my cell phone, there i came to know the problem called signal jamming that is experienced in most cell phones. They have a product called cell phone jammer (http://www.jammerall.com/categories/Cell-Phone-Jammers/) could be very useful to get rid of these problems. Check out the details here cell phone jammer and hope this information would be beneficial. Hope that u would pass this information to all your friends, so that they too would benefited, Stay safe, Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407143#407143 ________________________________________________________________________________
building?
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Aug 20, 2013
Folks, I have emailed Matt Dralle about this most recent post. Apparently the scammers and sellers have descended on this forum. I though Matt would want to know. Hopefully, he can block this guy, so we don't have to put up with these type posts. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407146#407146 ________________________________________________________________________________
building?
Date: Aug 20, 2013
Folks, I have emailed Matt Dralle about this most recent post. Apparently the scammers and sellers have descended on this forum. I though Matt would want to know. Hopefully, he can block this guy, so we don't have to put up with these type posts. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407147#407147 ________________________________________________________________________________
building?
Date: Aug 20, 2013
Folks, I have emailed Matt Dralle about this most recent post. Apparently the scammers and sellers have descended on this forum. I though Matt would want to know. Hopefully, he can block this guy, so we don't have to put up with these type posts. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407145#407145 ________________________________________________________________________________
Subject: NX626E
Date: Aug 21, 2013
Bill very good news, congratulations! Jack Textor Des Moines, IA -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of BYD Sent: Tuesday, August 20, 2013 5:59 PM Subject: Pietenpol-List: NX626E Hello good people! You better all grab your courage everybody because this is flying weather. Now Im talking about the best 20 minutes of your life. When you die and St. Peter asks you, Hey, when were you happiest down there? Youre gonna say well, it was okay the day that I got married and I didnt much mind the day I first fell in love but seeing the sky in my own Pietenpol Air Camper that I built myself well sir that beats them all. NX626E flew for the first time August 20th, 2013 (Video proof forthcoming) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407132#407132 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Bill's flight
Date: Aug 21, 2013
CONGRATS BILL!! Well done! Send video link asap, we can't wait to see it!! Can you remind me of the details of your plane? Engine, gear, etc? Douwe ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
Congrats!! WE NEED PICTURES!! -------- NX321LR ON THE FINAL PUSH!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407152#407152 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
So very cool. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407153#407153 ________________________________________________________________________________
Subject: Re: Bill's flight
Date: Aug 21, 2013
There is info on N626E here: http://www.aviationdb.com/Aviation/Aircraft/6/N626E.shtm Looks like a Ford powered Piet, but no idea if it's got Cub style gear, Jenny style gear, or a hand-carved prop ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407158#407158 ________________________________________________________________________________
Date: Aug 21, 2013
Thanks to everyone who responded, and particularly to Andrew, who made a most generous offer. I'll be taking him up on it. At the last condx inspection on my airplane, the A&P not only checked for the presence of the ELT, he checked the date on the battery and also tested the unit to see if we got a warble on 121.5 MHz. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407160#407160 ________________________________________________________________________________
Date: Aug 21, 2013
Subject: Re: NX626E
Great work Bill, I will be right behind you in probably a month in NX6819Z. rick h On Tue, Aug 20, 2013 at 4:59 PM, BYD wrote: > > Hello good people! > > You better all grab your courage everybody because this is flying weather . > Now I=92m talking about the best 20 minutes of your life. > > When you die and St. Peter asks you, =93Hey, when were you happiest down > there?=94 You=92re gonna say ' well, it was okay the day that I got mar ried ' > and I didn=92t much mind the day I first fell in love ' but seeing the sky in > my own Pietenpol Air Camper that I built myself ' well sir ' that bea ts > them all. > > NX626E flew for the first time August 20th, 2013 > (Video proof forthcoming) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407132#407132 > > =========== =========== =========== =========== > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
Oscar, You have a good A&P. He did the ELT inspection correctly. Part of the inspection now is that you have to manually (Simulated accident), set it off to make sure it works and that part of the test is documented in the log books. Hang on to that A&P if you can. Andrew did you good. Keep him as a friend too. :) -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407162#407162 ________________________________________________________________________________
Date: Aug 21, 2013
Oscar, You have a good A&P. He did the ELT inspection correctly. Part of the inspection now is that you have to manually (Simulated accident), set it off to make sure it works and that part of the test is documented in the log books. Hang on to that A&P if you can. Andrew did you good. Keep him as a friend too. :) -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407163#407163 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
OPPS, Wrong thread on previous post. Sorry guys -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407164#407164 ________________________________________________________________________________
Date: Aug 21, 2013
Subject: Re: NX626E
How do you test an ELT? Drop it on the floor and see if it goes off? rick h On Wed, Aug 21, 2013 at 10:38 AM, AircamperN11MS wrote: > Scott.liefeld(at)lacity.org> > > Oscar, > > You have a good A&P. He did the ELT inspection correctly. Part of the > inspection now is that you have to manually (Simulated accident), set it > off to make sure it works and that part of the test is documented in the > log books. Hang on to that A&P if you can. > > Andrew did you good. Keep him as a friend too. :) > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407162#407162 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Aug 21, 2013
I'll just flat go out here and put in a plug for the A&P who did the last annual on my airplane: he is Mark Julicher, and he's based at Bulverde Airpark, north of San Antonio. Super nice guy, really knows these older airplanes and knows fabric. Actually, the prior annual was conducted by A&P Jeff Scott of Los Alamos, who also checked the ELT. Jeff is another one who knows these old airplanes, and he really knows his Continental engines. Embarrassingly, two of the earlier annuals that were done on my airplane were done by an air maintenance shop in Laredo, TX... and I don't believe the ELT was part of the check done. I sure paid a lot for some of the things that that shop "fixed" (more like UN-fixed) on the airplane. They do NOT know experimentals and they do NOT know older airplanes unless they are certified or have multiple engines. Off soapbox now. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407175#407175 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
Send to me.I do free testing on every landing! Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland Sent: Wednesday, August 21, 2013 11:23 AM Subject: Re: Pietenpol-List: Re: NX626E How do you test an ELT? Drop it on the floor and see if it goes off? rick h On Wed, Aug 21, 2013 at 10:38 AM, AircamperN11MS wrote: Oscar, You have a good A&P. He did the ELT inspection correctly. Part of the inspection now is that you have to manually (Simulated accident), set it off to make sure it works and that part of the test is documented in the log books. Hang on to that A&P if you can. Andrew did you good. Keep him as a friend too. :) -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407162#407162 ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: Re: NX626E
From: "M. Zeke Zechini" <marcus.zechini(at)gmail.com>
Date: Aug 21, 2013
Yes...watched my A&P, IA do it during my condx Sent from my iPad On Aug 21, 2013, at 6:54 PM, "Gary Boothe" wrote: > Send to meI do free testing on every landing! > > Gary Boothe > NX308MB > > From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-li st-server(at)matronics.com] On Behalf Of Rick Holland > Sent: Wednesday, August 21, 2013 11:23 AM > To: pietenpol-list > Subject: Re: Pietenpol-List: Re: NX626E > > How do you test an ELT? Drop it on the floor and see if it goes off? > > rick h > > > On Wed, Aug 21, 2013 at 10:38 AM, AircamperN11MS wrote: ty.org> > > Oscar, > > You have a good A&P. He did the ELT inspection correctly. Part of the in spection now is that you have to manually (Simulated accident), set it off t o make sure it works and that part of the test is documented in the log book s. Hang on to that A&P if you can. > > Andrew did you good. Keep him as a friend too. :) > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407162#407162 > > > > > > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > > -- > Rick Holland > Castle Rock, Colorado > NX6819Z > > > > > http://www.matronics.com/Navigator?Pietenpol-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
I don't trust you Gary. When I test mine I just hold it with one hand and smack it into the palm of my other hand. Kind of like clapping. Doesn't take much. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407180#407180 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
I tried that, but I keep missing the other hand... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of AircamperN11MS Sent: Wednesday, August 21, 2013 4:29 PM Subject: Pietenpol-List: Re: NX626E --> I don't trust you Gary. When I test mine I just hold it with one hand and smack it into the palm of my other hand. Kind of like clapping. Doesn't take much. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407180#407180 ________________________________________________________________________________
Date: Aug 21, 2013
Since we are on the subject of ELTs. I am fortunate to have an old Dorne & Margolin DM ELT5-2 that is without batteries that I hope to use. It says on the case to use only alkaline D-size batteries. There are two free wires inside the enclosure (+/-). Does anyone know how the batteries are aligned (parallel/series) to make it work? I've searched the net but can't find anything for that ELT. Any suggestions other than to send it to Gary for testing. [Wink] -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407182#407182 Attachments: http://forums.matronics.com//files/photo_11_145.jpg ________________________________________________________________________________
Subject: MERFI Fly-In
Date: Aug 21, 2013
Any Pietenpols planning to go to the MERFI fly-in in Urbana, OH this weekend? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407183#407183 ________________________________________________________________________________
Date: Aug 21, 2013
Consider yourself lucky...I would have charged for those wires... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of curtdm(at)gmail.com Sent: Wednesday, August 21, 2013 5:21 PM Subject: Pietenpol-List: Re: ELT wanted --> Since we are on the subject of ELTs. I am fortunate to have an old Dorne & Margolin DM ELT5-2 that is without batteries that I hope to use. It says on the case to use only alkaline D-size batteries. There are two free wires inside the enclosure (+/-). Does anyone know how the batteries are aligned (parallel/series) to make it work? I've searched the net but can't find anything for that ELT. Any suggestions other than to send it to Gary for testing. [Wink] -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407182#407182 Attachments: http://forums.matronics.com//files/photo_11_145.jpg ________________________________________________________________________________
Subject: Re: MERFI Fly-In
Date: Aug 21, 2013
Me likely Steve On Aug 21, 2013, at 8:38 PM, "John Francis" wrote: > > Any Pietenpols planning to go to the MERFI fly-in in Urbana, OH this weekend? > > -------- > John Francis > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407183#407183 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 21, 2013
"free wires"... get it? ;o) Curt, a little more info is required. If you know how many D-cells the case can hold, we can figure it out. D-cells are 1.5V apiece and these clusters are usually wired with the batteries in series, so you could have 1.5, 3, 4.5, 6, 7.5, 9, 10.5, 12, or 13.5 volts... or more. However, nine D-cells to give 13.5 volts makes a pretty hefty battery pack and I doubt that it would have held more. The battery pack for my Narco ELT-10 is essentially nine stacked and potted D-cells to give 13.5V, which coincides with the nominal 14V DC of many aircraft power systems. The radio with battery pack feels like a chunk of lead or a brick... the specs say it's 3.9 lbs. The red and black wires that are "free" (no extra "charge", get it?) can be snipped clean, stripped, and a connector attached so you can fabricate a battery enclosure with a mating connector. The batteries would join in a "nose to tail" daisy-chain for a series connection. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407191#407191 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 21, 2013
Gary is on a roll ;o) My ELT has a 3-position switch on it... OFF-ARMED-ON. I merely switch it to the ON position to test, trusting that the momentum-actuated mechanism inside the gadget will do the same in the event of a sudden stop. I don't really expect it to do anything to save my life or help anybody locate my suddenly-stopped airplane though. The Narco ELT-10 is designed to be removable from the aircraft and used by the pilot or pax as a hand-held locator transmitter. It has a built-in antenna for that purpose, and the assumption is that it can be removed from the wreckage (ugh!) and taken to a safe and secure place away from the scene where searchers can zero in on the occupants and not a tangle of wood and fabric that may be down in a forest or ravine. Or in Belize. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407192#407192 ________________________________________________________________________________
Subject: Wing rIb components quick and easy
Date: Aug 22, 2013
I can attest to what others have said about how easy it is to quickly craft both the wing rib gussets and rib members. The included photo has a lot in it. My wing rib jig is loaded with the first set of components. It is now surrounded by 32 sets of 10 rib members. There are 900+ gussets in the plastic tubs and bags (5 different sizes / shapes). The gussets took a 24"x48" sheet of 1/16" aircraft grade ply and about 6 hours spread over 3 nights. I used a table saw, chop saw and metal sheers. It was very easy to make them. I got home early from a trip yesterday and felt it was a good time to cut the rib components. The 32 sets of 10 rib members took 3 hours. If anyone out there is fretting these tasks, stop now. -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407205#407205 Attachments: http://forums.matronics.com//files/dsc00127_medium_969.jpg ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: being found
Date: Aug 22, 2013
With all this talk about ELT's I have to post that during my airworthiness inspection no mention of an ELT was ever made and from day one I never installed one nor 15 years later have one. I'm s ure it would be prudent to carry one but I've just never done it but then again I don't fly over mountains or rugged terrain. I figure they'll just see the smoke and drive toward it. ________________________________________________________________________________
Subject: Re: being found
Date: Aug 22, 2013
I am not planning on installing an ELT either. Its not required during the 40 hour test period. Less weight. less cost. I will not be flying over mountains either. Planning on using a GPS SPOT like device however for CC flights. Cell or land line phone check ins with someone will also help. -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407208#407208 ________________________________________________________________________________
Date: Aug 22, 2013
It's hard to predict what is important to an inspector. Like Mike, my FAA inspector had no interest in seeing the ELT (although I have one mounted), nor was he concerned that the word 'EXPERIMENTAL' was not written on the side of the forward cockpit (he only wanted to see a placard on the forward panel with the word 'EXPERIMENTAL' somewhere on the placard), but.... He was dead set that I safety all the hose clamps! That's not a reg, either. A year later, at a presentation he did at our EAA chapter, he again mentioned safetying hose clamps! I didn't mind...it didn't take long. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bdewenter Sent: Thursday, August 22, 2013 6:56 AM Subject: Pietenpol-List: Re: being found --> I am not planning on installing an ELT either. Its not required during the 40 hour test period. Less weight. less cost. I will not be flying over mountains either. Planning on using a GPS SPOT like device however for CC flights. Cell or land line phone check ins with someone will also help. -------- Bob 'Early Builder' Dewenter Dayton OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407208#407208 ________________________________________________________________________________
Subject: Re: Wing rIb components quick and easy
Date: Aug 22, 2013
Nice job Bob! After building the jig and making the first rib, the work of building the rest of the ribs will become easy and rewarding. As I work on the hand carving on the wing tips and finishing the ailerons, I dream of those lackadaisical days of building wing ribs. Spent two hours last night in the simulator with Russ. He disabled all the gauges but what I would have in my Piet then put me into some tough situations. Most enlightening was flying into clouds and maintaining altitude and level wings with just the altimeter and magnetic compass. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407210#407210 ________________________________________________________________________________
Date: Aug 22, 2013
Bob and Mike, What does Uncle Tony say about that???? Just kidding, but, The FAA will say you are not legal Mike. After phase 1 testing you (Bob and Mike) are required to have one in your plane. The only exception would be if the plane is a single seater. I agree that we really don't need them with all the other tracking devices and phones available to us these days. If the FAA changed the rules to include this centuries technologies the manufacturers would throw a fit. How would they stay in business without our money??? Anyway, I hate to see you get in trouble with the FAA someday (during a ramp check) because you don't have one so I figured I would rant a little. Look at the FAR's and you will see what I am talking about. Anyway, just have fun and fly. BTW, Last year while I was going through all the paperwork that is required to be carried in my plane to be legal, I discovered that I had the wrong "Operating Limitations" in the plane and flew it that way for 20 years. I was never ramp checked and never was in trouble for it. But, it was an eye opener. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407211#407211 ________________________________________________________________________________
Date: Aug 22, 2013
You are so right about the regulations Scott and gosh, no wonder Uncle Tony didn't include me in his will......no ELT! I'd better get busy and saf ety wire all my hose clamps too before I fly out to California to visit Gary and the Westcoast Piet bunch. :) We have a great FAA inspector here locally and while he and his wife were a t a little private air strip get-together a few years ago my friend Bill Kl osz and I razzed the daylights out of this guy because he didn't have a compass correction card. We were ramp c hecking the FAA guy. Thank goodness we have some fair-minded and reasonab le Feds around here but you make a good point--they are all different and they all could hang a ny one of us on any given day! Mike C. [cid:image001.jpg(at)01CE9F2C.40FB9510] ________________________________________________________________________________
Date: Aug 22, 2013
NX92GB may be there, Dad might fly over.- If I am not working on my wings I will try to bum a ride over with my neighbor.=0A-=0AShad =0A =0A=0A___ _____________________________=0A From: John Francis <Mrkringles(at)msn.com>=0A M=0ASubject: Pietenpol-List: MERFI Fly-In=0A =0A=0A--> Pietenpol-List mess age posted by: "John Francis" =0A=0AAny Pietenpols plan ning to go to the MERFI fly-in in Urbana, OH this weekend?=0A=0A--------=0A John Francis=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums. ============== ________________________________________________________________________________
Date: Aug 22, 2013
Subject: Covering systems
Pietsters, Is it legal (??..perhaps the wrong term) to cover parts of the plane, say the wings and tail surfaces, with the Polyfiber system and then cover the fuselage with the Stewart system? Seems like I remember reading somewhere that you can't mix systems on the same plane. Thanks, John Franklin Prairie Aire 4TA0 Needville, TX ________________________________________________________________________________
Date: Aug 22, 2013
From: "H. Marvin Haught Jr. " <handainc(at)madisoncounty.net>
Subject: Re: Covering systems
Only if you are doing a certificated airplane. That said, if you are doing a repair, then Stewart Systems is approved to repair any other certified system. M. Haught Aircraft Fabric & Finishes LLC. On 8/22/2013 11:48 AM, John Franklin wrote: > > Pietsters, > > Is it legal (??..perhaps the wrong term) to cover parts of the plane, say the wings and tail surfaces, with the Polyfiber system and then cover the fuselage with the Stewart system? Seems like I remember reading somewhere that you can't mix systems on the same plane. > > Thanks, > John Franklin > Prairie Aire 4TA0 > Needville, TX > > ________________________________________________________________________________
Date: Aug 22, 2013
Subject: Re: being found (OT about getting away with stuff)
Guys, The enforcement of all FAA rules is pretty hit and miss in the small plane arens I think. When I bought my one off homebuilt from the original builder he told me the whole story of how he built it out of wood based on a popular metal plane of the time including a V tail but the mixing control was maladjusted on his first flight and he crashed. The plane was rebuilt with a bigger engine and standard tail form and flown for many years afterward. What I didn't realize was that the original Op Lims stated that "any major changes invalidate the airworthiness certificate". Being as it was subject to two major changes the AW cert was totally invalid and had been for the many years it flew. When I discovered this I decided to get it straightened out. As a result I spent several months corresponding with the FAA, DAR and DER but finally obtained a new airworthiness certificate and am in the process of flying off the 40 hours of Phase 1 (if the stupid weather would ever cooperate). My point is, if someone can fly an airplane for 20 years with an invalid airworthiness cert. what else are people getting away with on a daily basis? Whatever they are "getting away with" it surely doesn't seem to impact GA safety too much and kinda makes me question the whole need for all this bureaucracy. 3rd class medical is a perfect example. Lots of people are flying without medicals yet the accident rate hasn't gone through the roof. In my opinion you should only need a medical if you are flying commercially i.e. someone is paying you. That is just one example, all these ADs and mandatory ADSB would be another. Is it really going to enhance safety? How many GA midair collisions were there last year? ________________________________________________________________________________
Date: Aug 22, 2013
Mixing is called "experimenting" on an experimental. -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407226#407226 ________________________________________________________________________________
Date: Aug 22, 2013
I think what he pretend to do is not mixin. Mix is cover one wing with one system and the otherone with other.. may be this could be bad.. but the fuselage?.. May be I saw bad, but there isn't one with a rotor engine wichi the fuse look like playwood covered?.. is it plywood, isn't it? ;o) Mario Giacummo 2013/8/22 curtdm(at)gmail.com > curtdm(at)gmail.com> > > Mixing is called "experimenting" on an experimental. > > -------- > Curt Merdan > Flower Mound, TX > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407226#407226 > > ________________________________________________________________________________
Date: Aug 22, 2013
My inspector asked me to add the two inch "EXPERIMENTAL" letters in my cockpit. But he said he didn't care if I removed them from "that beautiful woodwork" after the AW is issued. rh On Thu, Aug 22, 2013 at 8:20 AM, Gary Boothe wrote: > > It's hard to predict what is important to an inspector. Like Mike, my FAA > inspector had no interest in seeing the ELT (although I have one mounted), > nor was he concerned that the word 'EXPERIMENTAL' was not written on the > side of the forward cockpit (he only wanted to see a placard on the forward > panel with the word 'EXPERIMENTAL' somewhere on the placard), but.... > > He was dead set that I safety all the hose clamps! That's not a reg, > either. > A year later, at a presentation he did at our EAA chapter, he again > mentioned safetying hose clamps! I didn't mind...it didn't take long. > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of bdewenter > Sent: Thursday, August 22, 2013 6:56 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: being found > > --> > > I am not planning on installing an ELT either. Its not required during the > 40 hour test period. Less weight. less cost. I will not be flying over > mountains either. Planning on using a GPS SPOT like device however for CC > flights. Cell or land line phone check ins with someone will also help. > > -------- > Bob 'Early Builder' Dewenter > Dayton OH > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407208#407208 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Aug 22, 2013
This is a huge bucket of worms that is practically impossible to intelligently discuss! Believe me, I'm NOT a huge fan of government intervention (with the exception being I'm ok with them outlawing straight headed fasteners...). However, when you spend much time in a third world environment, you get a little more alright with it. But then you spend some time in Europe and wonder what if we go THAT far?! I think the real answer lies reasonable interpretation. In your case, what's the point of flying off 40hrs? You did the right thing in getting things straightened out, and they punish you (in effect). If more reasonable interpretation and enforcement were to be the norm, people would indeed be more inclined to try and follow the rules. To that end, and how I've always looked at this stuff, I believe I just do the best I can to be safe first, and follow the "rules" second. When I'm knowingly violating something and get caught, I simply fess up and take the punishment like an adult. Overall, I'm way ahead of the game despite getting caught for a few things rather than have just not done so much because it really isn't feasible to do it all PERFECTLY legally. It's kind of funny, I've thought a lot about this ELT thing. I believe what I'll do (I hope big brother isn't watching...) is move the ELT I do own over to whatever I'm getting registered, and keep moving it around to where ever I need it at the time to be as legal as possible, but probably not gonna miss a flight somewhere, sometime, just because it isn't in there, ya know? I do always make it a practice for someone to know where I am and when, and will take appropriate action should something go wrong. I believe that is safer than relying on aging equipment and technology anyway. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407231#407231 ________________________________________________________________________________
Date: Aug 22, 2013
What is meant by mixing the processes, is that you do not want to repair Poly fiber with the stewart process or visa-versa. The glues for each process are not compatible. This is how Stewart Wittman was killed in his Tailwind. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407232#407232 ________________________________________________________________________________
Date: Aug 22, 2013
Tools; there are more people who do the "musical chairs" thing than you think. I know a guy who collects antique and rare motorcycles. He has one set of license plates that he keeps current and he puts them on whichever of the bikes he takes out of his barn to go ride. Ridiculous to keep tags on his 18-20 bikes when he can only ride one at a time. As long as he doesn't break any traffic rules or do something stupid to get him pulled over, nobody is the wiser. We should start a trading pool like with the fish scales. One ELT stays current and legal and we mail it to the next guy who is up for annual inspection. After he passes, he mails it to the next person and so on. Each user pays a few bucks so there is money to replace the battery every 2 years ;o) Just hope you don't get "ramped"... -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407235#407235 ________________________________________________________________________________
Date: Aug 22, 2013
It was Steve (not Stewart) Wittman who was killed because he mixed systems on the same flying surface, which came apart in flight. Both Steve and his wife were killed. There's nothing absolutely wrong with using different systems on different components of the airplane. But you sure would need to be able to keep perfect track for any later repairs, both by you and anyone else that ever purchased the plane. Using a single system would prevent errors of mixing systems in later repairs that could prove fatal. On Thu, Aug 22, 2013 at 11:35 AM, AircamperN11MS wrote: > Scott.liefeld(at)lacity.org> > > What is meant by mixing the processes, is that you do not want to repair > Poly fiber with the stewart process or visa-versa. The glues for each > process are not compatible. This is how Stewart Wittman was killed in his > Tailwind. > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407232#407232 > > ________________________________________________________________________________
From: "H. Marvin Haught" <handainc(at)madisoncounty.net>
Date: Aug 22, 2013
You are absolutely wrong! Stewart Systems is approved for repairs on all other certified systems, including Poly Fiber! What you say is correct about any of the other covering systems - none are approved to repair the other. But Stewart's is an approved repair for all other covering systems. M. Haught Aircraft Fabric & Finishes, LLC On Aug 22, 2013, at 12:35 PM, AircamperN11MS wrote: > > What is meant by mixing the processes, is that you do not want to repair Poly fiber with the stewart process or visa-versa. The glues for each process are not compatible. This is how Stewart Wittman was killed in his Tailwind. > > -------- > Scott Liefeld > Flying N11MS since March 1972 > Steel Tube > C-85-12 > Wire Wheels > Brodhead in 1996 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407232#407232 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 22, 2013
Your right it was Steve. I guess I had Stewert on my brain. Perhaps it is OK to repair Poly Fiber with Stewert Systems, but you won't find me doing it on my plane. Call me old school if you you want. No mixing for me thank you. My 3 cents, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407246#407246 ________________________________________________________________________________
Date: Aug 22, 2013
I just sat in a fabric covering class at Oshkosh that was taught by John Goldenbaum of Poly Fiber and he stated what Scott said about not mixing components of one system with components of another system. Is there somewhere on the Stewart Systems website or publications that says it is compatible with all other systems? Nothing personal Mr. Haught. It is just the "trust, but verify" part of how I like to look at these types of discussions when someone vehemently tells someone else that he is wrong about something that could kill you when flying. If you can find that and post a link, I am sure that it would be a help to all of us. Thanks. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407247#407247 ________________________________________________________________________________
Date: Aug 22, 2013
Okay, I stand corrected. Nevertheless, I'm still not going to mix systems on the same airplane. I've got Stits on my Pacer and Stewart on my Piet. I'm going to keep it that way, unless one or the other is fully re-covered. On Thu, Aug 22, 2013 at 12:21 PM, H. Marvin Haught < handainc(at)madisoncounty.net> wrote: > handainc(at)madisoncounty.net> > > You are absolutely wrong! Stewart Systems is approved for repairs on all > other certified systems, including Poly Fiber! What you say is correct > about any of the other covering systems - none are approved to repair the > other. But Stewart's is an approved repair for all other covering systems. > > M. Haught > Aircraft Fabric & Finishes, LLC > > > On Aug 22, 2013, at 12:35 PM, AircamperN11MS wrote: > > Scott.liefeld(at)lacity.org> > > > > What is meant by mixing the processes, is that you do not want to repair > Poly fiber with the stewart process or visa-versa. The glues for each > process are not compatible. This is how Stewart Wittman was killed in his > Tailwind. > > > > -------- > > Scott Liefeld > > Flying N11MS since March 1972 > > Steel Tube > > C-85-12 > > Wire Wheels > > Brodhead in 1996 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=407232#407232 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 22, 2013
Hello Ken, > It was Steve (not Stewart) Wittman who was killed because he mixed > systems on the same flying surface, which came apart in flight. IIRC, there was a report many years ago on Sport Aviation. I cannot remember every single word, but the long and the short of it is that the flying surface was covered with Stits Poly-Fiber, and was not a problem of mixed materials but wrong covering techniques. Steve applied the fabric using the cotton method i.e. he put the cement on the wood, let it dry, laid the fabric and brushed the cement over the fabric, assuming that the cement would have run through the thickness of the fabric and onto the underlying dried cement, softening it. It didn't, or at least it did for but a very small percentage of the glued surface, because the polyester fabric has no affinity with nitrate cement like cotton has. This was the comment of Mr. Ray Stits himself, who pointed straight at his covering manual, where he stated that his fabric should be applied immediately over a fresh hand of nitrate cement, and another should be put on immediately on the external surface, in a wet-on-wet fashion, so every fiber becomes, in fact, completely encapsulated with cement. SeeYa, Andrea ________________________________________________________________________________
Date: Aug 22, 2013
Subject: Sad, sad, sad news :-(
Hello guys, Just in from AvWeb: http://www.avweb.com/avwebflash/news/EAA-Founder-Paul-Poberezny-Dies-At-91220479-1.html?ET=avweb:e2614:220628a:&st=email I have that eerie feeling that our world isn't going to be the same anymore... SeeYa! Andrea ________________________________________________________________________________
Date: Aug 22, 2013
It should not surprise anyone that any manufacturer would advise to use their own products for repairs, for many reasons, not the least of which are those that would come from their Legal Dept concerning warranties. Still, as Mr. Haught correctly stated, Stewart Systems offers their products as a patching process for any solvent based system, as stated in their 'Procedures Manual,' under "Repairing Fabric": " REPAIRING FABRIC Always refer to FAA Advisory Circular AC 43.13-1B Chapter 2 before repairing any fabric damage. This advisory circular spells out in detail how particular injuries to the aircraft fabric are to be repaired. Repairing fabric damage with STEWART SYSTEMS method is a relatively simple and easy process. In the case of a fabric puncture, the area must be thoroughly cleaned with STEWART SYSTEMS EkoClean Heavy Duty Cleaner (E670) to remove any waxes, silicones, or contaminates which might be present. If the topcoat is STEWART SYSTEMS Waterborne Catalyzed EkoPoly you just need to scuff sand an area 2 around the damaged area before patching. If you are unsure of the topcoat or you know it is something other than STEWART SYSTEMS Waterborne Catalyzed EkoPoly Top Coat, you must sand down to the EkoFill coat 2 around the damaged area or to bare fabric if repairing a solvent based system. Next glue your patch on the sanded area using EkoBond glue and allow to dry. Heat shrink the fabric ONLY over the open hole under the patch. Finish Iron the patch edges at 250F. Apply EkoFill to desired thickness, sand and spray matching top coat. Stewart Systems is FAA approved for repairing any certified covering system." Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of jarheadpilot82 Sent: Thursday, August 22, 2013 12:15 PM Subject: Pietenpol-List: Re: Covering systems --> I just sat in a fabric covering class at Oshkosh that was taught by John Goldenbaum of Poly Fiber and he stated what Scott said about not mixing components of one system with components of another system. Is there somewhere on the Stewart Systems website or publications that says it is compatible with all other systems? Nothing personal Mr. Haught. It is just the "trust, but verify" part of how I like to look at these types of discussions when someone vehemently tells someone else that he is wrong about something that could kill you when flying. If you can find that and post a link, I am sure that it would be a help to all of us. Thanks. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407247#407247 ________________________________________________________________________________
Date: Aug 22, 2013
Andrea, thanks for the clarification, though it only reinforces the point that mixing covering systems (which is more than just the products) can be dangerous. Each system calls out particular processes by which the products are to be combined. Keeping all of that straight is the major reason for using one and only system on a particular airplane. Cheers, Ken On Thu, Aug 22, 2013 at 1:42 PM, Andrea Vavassori wrote: > andrea(at)modelberg.it> > > Hello Ken, > > > It was Steve (not Stewart) Wittman who was killed because he mixed > > systems on the same flying surface, which came apart in flight. > > IIRC, there was a report many years ago on Sport Aviation. I cannot > remember every single word, but the long and the short of it is that > the flying surface was covered with Stits Poly-Fiber, and was not a > problem of mixed materials but wrong covering techniques. Steve > applied the fabric using the cotton method i.e. he put the cement > on the wood, let it dry, laid the fabric and brushed the cement over > the fabric, assuming that the cement would have run through the > thickness of the fabric and onto the underlying dried cement, > softening it. It didn't, or at least it did for but a very small > percentage of the glued surface, because the polyester fabric has no > affinity with nitrate cement like cotton has. This was the comment of > Mr. Ray Stits himself, who pointed straight at his covering manual, > where he stated that his fabric should be applied immediately over a > fresh hand of nitrate cement, and another should be put on > immediately on the external surface, in a wet-on-wet fashion, so every > fiber becomes, in fact, completely encapsulated with cement. > > SeeYa, > > Andrea > > ________________________________________________________________________________
Date: Aug 22, 2013
Thanks, Gary.... you are right on target! And the real point in this topic is that you should be careful in "mixing" systems, such as using one brand fabric sealer over another systems glue, etc. which may have been what caused problems in the instance of Steve Whitman. Some products may not be compatible with others. That is why Stewart's got certification for repair of other systems. Being water based glue and Sealer (EkoFill) and waterborne paint, there are no incompatibility issues. But if you do decide to repair another system with Stewart's, be advised that it is necessary to clean the area to be repaired very thoroughly because fish eye can be a huge problem. I scrub the area with TSP and a scotchbrite pad, rinse and then scrub with the Stewart's cleaner. I follow that, after it dries with a wipe of isopropyl alcohol. Waterborne paints are very intolerant of contaminates. M. Haught 8/22/2013 2:48 PM, Gary Boothe wrote: > > It should not surprise anyone that any manufacturer would advise to use > their own products for repairs, for many reasons, not the least of which are > those that would come from their Legal Dept concerning warranties. Still, as > Mr. Haught correctly stated, Stewart Systems offers their products as a > patching process for any solvent based system, as stated in their > 'Procedures Manual,' under "Repairing Fabric": > > " REPAIRING FABRIC > Always refer to FAA Advisory Circular AC 43.13-1B Chapter 2 before repairing > any fabric damage. This advisory circular spells out in detail how > particular injuries to the aircraft fabric are to be repaired. > Repairing fabric damage with STEWART SYSTEMS method is a relatively simple > and easy process. In the case of a fabric puncture, the area must be > thoroughly cleaned with STEWART SYSTEMS EkoClean Heavy Duty Cleaner (E670) > to remove any waxes, silicones, or contaminates which might be present. If > the topcoat is STEWART SYSTEMS Waterborne Catalyzed EkoPoly you just need to > scuff sand an area 2 around the damaged area before patching. If you are > unsure of the topcoat or you know it is something other than STEWART SYSTEMS > Waterborne Catalyzed EkoPoly Top Coat, you must sand down to the EkoFill > coat 2 around the damaged area or to bare fabric if repairing a solvent > based system. Next glue your patch on the sanded area using EkoBond glue and > allow to dry. Heat shrink the fabric ONLY over the open hole under the > patch. Finish Iron the patch edges at 250F. Apply EkoFill to desired > thickness, sand and spray matching top coat. Stewart Systems is FAA approved > for repairing any certified covering system." > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > jarheadpilot82 > Sent: Thursday, August 22, 2013 12:15 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Covering systems > > --> > > I just sat in a fabric covering class at Oshkosh that was taught by John > Goldenbaum of Poly Fiber and he stated what Scott said about not mixing > components of one system with components of another system. > > Is there somewhere on the Stewart Systems website or publications that says > it is compatible with all other systems? Nothing personal Mr. Haught. It is > just the "trust, but verify" part of how I like to look at these types of > discussions when someone vehemently tells someone else that he is wrong > about something that could kill you when flying. > > If you can find that and post a link, I am sure that it would be a help to > all of us. Thanks. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407247#407247 > > ________________________________________________________________________________
Date: Aug 22, 2013
There is a great disturbance in the force. RIP Paul Barry -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Andrea Vavassori Sent: Thursday, August 22, 2013 3:44 PM Subject: Pietenpol-List: Sad, sad, sad news :-( --> Hello guys, Just in from AvWeb: http://www.avweb.com/avwebflash/news/EAA-Founder-Paul-Poberezny-Dies-At-9122 0479-1.html?ET=avweb:e2614:220628a:&st=email I have that eerie feeling that our world isn't going to be the same anymore... SeeYa! Andrea ________________________________________________________________________________
Date: Aug 22, 2013
I totally agree about "mixing" systems. I do not mix components and as Andrea brought out, make SURE I have the manual of any system that I am using on hand so that I use the proper techniques of application for that system. Gary quoted the data exactly in a prior post, and copied the manual exactly. "" REPAIRING FABRIC Always refer to FAA Advisory Circular AC 43.13-1B Chapter 2 before repairing any fabric damage. This advisory circular spells out in detail how particular injuries to the aircraft fabric are to be repaired. Repairing fabric damage with STEWART SYSTEMS method is a relatively simple and easy process. In the case of a fabric puncture, the area must be thoroughly cleaned with STEWART SYSTEMS EkoClean Heavy Duty Cleaner (E670) to remove any waxes, silicones, or contaminates which might be present. If the topcoat is STEWART SYSTEMS Waterborne Catalyzed EkoPoly you just need to scuff sand an area 2 around the damaged area before patching. If you are unsure of the topcoat or you know it is something other than STEWART SYSTEMS Waterborne Catalyzed EkoPoly Top Coat, you must sand down to the EkoFill coat 2 around the damaged area or to bare fabric if repairing a solvent based system. Next glue your patch on the sanded area using EkoBond glue and allow to dry. Heat shrink the fabric ONLY over the open hole under the patch. Finish Iron the patch edges at 250F. Apply EkoFill to desired thickness, sand and spray matching top coat. Stewart Systems is FAA approved for repairing any certified covering system." That excerpt is on Page 1 of Section 16 in the Stewart Instruction Manual. It can be found at http://www.stewartsystems.aero/support.aspx By the way, I am a distributor for both Stewarts and SuperFlite, and I don't think I was vehement at all, just speaking from a knowledge of fact. And I have contributed here in the interest of safety and accuracy of information. That benefits all of us. Additionally, I did not intend to say it is compatible with all other systems as in mixing components, but it IS compatible in repairing all other systems if the repair is completed as described above. M. Haught Aircraft Fabric & Finishes, LLC On Aug 22, 2013, at 2:14 PM, jarheadpilot82 wrote: > > I just sat in a fabric covering class at Oshkosh that was taught by John Goldenbaum of Poly Fiber and he stated what Scott said about not mixing components of one system with components of another system. > > Is there somewhere on the Stewart Systems website or publications that says it is compatible with all other systems? Nothing personal Mr. Haught. It is just the "trust, but verify" part of how I like to look at these types of discussions when someone vehemently tells someone else that he is wrong about something that could kill you when flying. > > If you can find that and post a link, I am sure that it would be a help to all of us. Thanks. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407247#407247 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 22, 2013
For certified aircraft both Polyfiber and Stewarts processes are approved, but does anybody know where the processes really start and end? With Polyfiber you prep the frame, glue with polytac, stitch, tape with pol ybrush, spray 2 coats of polybrush, 3 coats of polyspray, and an undetermin ed number of color coats (polytone or aerothane). It's interesting that the manual says they "recommend" polytone or areothane, it does not say "requi re" which leads me to believe that other paints may be substituted. If the color coats are not part of the "system", then what about the polyspray or the polybrush? Neither attach the fabric to the frame so as long as the pol ytac/polybrush system of gluing and taping are followed (or Stewarts ecobon d) the fabric should remain attached. Everything else is UV protection, wea ve filling, and decoration. I realize that I'm trying to reason my way into a conclusion on a matter dictated by the FAA, but I am curious on what def ines the "process". Anyone know for sure? Malcolm ----- Original Message ----- From: "H. Marvin Haught Jr." <handainc(at)madisoncounty.net> Sent: Thursday, August 22, 2013 4:02:39 PM Subject: Re: Pietenpol-List: Re: Covering systems isoncounty.net> Thanks, Gary.... you are right on target! And the real point in this topic is that you should be careful in "mixing" systems, such as using one brand fabric sealer over another systems glue, etc. which may have been what caused problems in the instance of Steve Whitman. Some products may not be compatible with others. That is why Stewart's got certification for repair of other systems. Being water based glue and Sealer (EkoFill) and waterborne paint, there are no incompatibility issues. But if you do decide to repair another system with Stewart's, be advised that it is necessary to clean the area to be repaired very thoroughly because fish eye can be a huge problem. I scrub the area with TSP and a scotchbrite pad, rinse and then scrub with the Stewart's cleaner. I follow that, after it dries with a wipe of isopropyl alcohol. Waterborne paints are very intolerant of contaminates. M. Haught 8/22/2013 2:48 PM, Gary Boothe wrote: > > > It should not surprise anyone that any manufacturer would advise to use > their own products for repairs, for many reasons, not the least of which are > those that would come from their Legal Dept concerning warranties. Still, as > Mr. Haught correctly stated, Stewart Systems offers their products as a > patching process for any solvent based system, as stated in their > 'Procedures Manual,' under "Repairing Fabric": > > " REPAIRING FABRIC > Always refer to FAA Advisory Circular AC 43.13-1B Chapter 2 before repair ing > any fabric damage. This advisory circular spells out in detail how > particular injuries to the aircraft fabric are to be repaired. > Repairing fabric damage with STEWART SYSTEMS method is a relatively simpl e > and easy process. In the case of a fabric puncture, the area must be > thoroughly cleaned with STEWART SYSTEMS EkoClean Heavy Duty Cleaner (E670 ) > to remove any waxes, silicones, or contaminates which might be present. I f > the topcoat is STEWART SYSTEMS Waterborne Catalyzed EkoPoly you just need to > scuff sand an area 2=9D around the damaged area before patching. If you are > unsure of the topcoat or you know it is something other than STEWART SYST EMS > Waterborne Catalyzed EkoPoly Top Coat, you must sand down to the EkoFill > coat 2=9D around the damaged area or to bare fabric if repairing a solvent > based system. Next glue your patch on the sanded area using EkoBond glue and > allow to dry. Heat shrink the fabric ONLY over the open hole under the > patch. Finish Iron the patch edges at 250=C2=B0F. Apply EkoFill to desire d > thickness, sand and spray matching top coat. Stewart Systems is FAA appro ved > for repairing any certified covering system." > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > jarheadpilot82 > Sent: Thursday, August 22, 2013 12:15 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Covering systems > > --> > > I just sat in a fabric covering class at Oshkosh that was taught by John > Goldenbaum of Poly Fiber and he stated what Scott said about not mixing > components of one system with components of another system. > > Is there somewhere on the Stewart Systems website or publications that sa ys > it is compatible with all other systems? Nothing personal Mr. Haught. It is > just the "trust, but verify" part of how I like to look at these types of > discussions when someone vehemently tells someone else that he is wrong > about something that could kill you when flying. > > If you can find that and post a link, I am sure that it would be a help t o > all of us. Thanks. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407247#407247 > > > > > > > > > > > > > > > =========== =========== =========== =========== ________________________________________________________________________________
Date: Aug 22, 2013
It all depends upon how the STC is worded, and how different regions of the FAA interpret both their standards and the particular STC. Recently a local AI wanted to cover a certified airplane with Stewarts, but the customer wanted a solvent based paint. =46rom what I understand, the FAA interpreted the EkoFill as the finish coat as the fabric was protected and sealed from contaminates, deterioration and UV. I made the point with him that the Stewart STC is completed only by the waterborne topcoat. But apparently, it was approved and signed off. I do not believe that situation was entirely legal, but it is signed off and flying. Since I have not seen the actual documentation, I can't verify the story, but throw it out as an example. I also know of a Pitts Special that was recovered by a large shop. I do not know what brand of fabric or if any "system" was used, but I think it was basically PolyFiber, and painted with a Dupont Topcoat with a flex additive. I don't know how that sort of a thing gets done, legally. And again, I have not be able to verify the facts, but that was what the owner told me. I believe that generally, the STC is interpreted as being a complete system through paint, and that any substitutions are not legal nor permitted. And I doubt that any of the companies would warranty a cover job if there are any deviations from the "system" which also includes application techniques. I know that Stewart's and SuperFlite will not honor a warranty claim unless the whole system used. To me, even a Piet is too much of an investment, even if only in time and effort, to risk having to recover it in a short period of time by using any questionable covering practices. Normally, I don't think safety would be involved, but the example of Steve Whitman shows that even errors in application techniques could possibly kill you. The short answer is that the process is the STC, which includes the application manual for each of the different systems. M. Haught On Aug 22, 2013, at 4:39 PM, gliderx5(at)comcast.net wrote: > For certified aircraft both Polyfiber and Stewarts processes are approved, but does anybody know where the processes really start and end? > > With Polyfiber you prep the frame, glue with polytac, stitch, tape with polybrush, spray 2 coats of polybrush, 3 coats of polyspray, and an undetermined number of color coats (polytone or aerothane). It's interesting that the manual says they "recommend" polytone or areothane, it does not say "require" which leads me to believe that other paints may be substituted. If the color coats are not part of the "system", then what about the polyspray or the polybrush? Neither attach the fabric to the frame so as long as the polytac/polybrush system of gluing and taping are followed (or Stewarts ecobond) the fabric should remain attached. Everything else is UV protection, weave filling, and decoration. I realize that I'm trying to reason my way into a conclusion on a matter dictated by the FAA, but I am curious on what defines the "process". Anyone know for sure? > > Malcolm > > From: "H. Marvin Haught Jr." <handainc(at)madisoncounty.net> > To: pietenpol-list(at)matronics.com > Sent: Thursday, August 22, 2013 4:02:39 PM > Subject: Re: Pietenpol-List: Re: Covering systems > > > Thanks, Gary.... you are right on target! And the real point in this > topic is that you should be careful in "mixing" systems, such as using > one brand fabric sealer over another systems glue, etc. which may have > been what caused problems in the instance of Steve Whitman. Some > products may not be compatible with others. That is why Stewart's got > certification for repair of other systems. Being water based glue and > Sealer (EkoFill) and waterborne paint, there are no incompatibility > issues. But if you do decide to repair another system with Stewart's, be > advised that it is necessary to clean the area to be repaired very > thoroughly because fish eye can be a huge problem. I scrub the area with > TSP and a scotchbrite pad, rinse and then scrub with the Stewart's > cleaner. I follow that, after it dries with a wipe of isopropyl alcohol. > Waterborne paints are very intolerant of contaminates. > > M. Haught > > > 8/22/2013 2:48 PM, Gary Boothe wrote: > > > > It should not surprise anyone that any manufacturer would advise to use > > their own products for repairs, for many reasons, not the least of which are > > those that would come from their Legal Dept concerning warranties. Still, as > > Mr. Haught correctly stated, Stewart Systems offers their products as a > > patching process for any solvent based system, as stated in their > > 'Procedures Manual,' under "Repairing Fabric": > > > > " REPAIRING FABRIC > > Always refer to FAA Advisory Circular AC 43.13-1B Chapter 2 before repairing > > any fabric damage. This advisory circular spells out in detail how > > particular injuries to the aircraft fabric are to be repaired. > > Repairing fabric damage with STEWART SYSTEMS method is a relatively simple > > and easy process. In the case of a fabric puncture, the area must be > > thoroughly cleaned with STEWART SYSTEMS EkoClean Heavy Duty Cleaner (E670) > > to remove any waxes, silicones, or contaminates which might be present. If > > the topcoat is STEWART SYSTEMS Waterborne Catalyzed EkoPoly you just need to > > scuff sand an area 2=94 around the damaged area before patching. If you are > > unsure of the topcoat or you know it is something other than STEWART SYSTEMS > > Waterborne Catalyzed EkoPoly Top Coat, you must sand down to the EkoFill > > coat 2=94 around the damaged area or to bare fabric if repairing a solvent > > based system. Next glue your patch on the sanded area using EkoBond glue and > > allow to dry. Heat shrink the fabric ONLY over the open hole under the > > patch. Finish Iron the patch edges at 250=B0F. Apply EkoFill to desired > > thickness, sand and spray matching top coat. Stewart Systems is FAA approved > > for repairing any certified covering system." > > > > Gary Boothe > > NX308MB > > > > > > -----Original Message----- > > From: owner-pietenpol-list-server(at)matronics.com > > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > > jarheadpilot82 > > Sent: Thursday, August 22, 2013 12:15 PM > > To: pietenpol-list(at)matronics.com > > Subject: Pietenpol-List: Re: Covering systems > > > > --> > > > > I just sat in a fabric covering class at Oshkosh that was taught by John > > Goldenbaum of Poly Fiber and he stated what Scott said about not mixing > > components of one system with components of another system. > > > > Is there somewhere on the Stewart Systems website or publications that says > > it is compatible with all other systems? Nothing personal Mr. Haught. It is > > just the "trust, but verify" part of how I like to look at these types of > > discussions when someone vehemently tells someone else that he is wrong > > about something that could kill you when flying. > > > > If you can find that and post a link, I am sure that it would be a help to > > all of us. Thanks. > > > > -------- > > Semper Fi, > > > > Terry Hand > > Athens, GA > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=407247#407247 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > <; &nb================ == > > > > > > > ________________________________________________________________________________
Date: Aug 22, 2013
Tools what are straight headed fasteners? Sent from my iPad Jack Textor On Aug 22, 2013, at 12:33 PM, "tools" wrote: > > This is a huge bucket of worms that is practically impossible to intelligently discuss! > > Believe me, I'm NOT a huge fan of government intervention (with the exception being I'm ok with them outlawing straight headed fasteners...). However, when you spend much time in a third world environment, you get a little more alright with it. > > But then you spend some time in Europe and wonder what if we go THAT far?! > > I think the real answer lies reasonable interpretation. In your case, what's the point of flying off 40hrs? You did the right thing in getting things straightened out, and they punish you (in effect). If more reasonable interpretation and enforcement were to be the norm, people would indeed be more inclined to try and follow the rules. > > To that end, and how I've always looked at this stuff, I believe I just do the best I can to be safe first, and follow the "rules" second. When I'm knowingly violating something and get caught, I simply fess up and take the punishment like an adult. Overall, I'm way ahead of the game despite getting caught for a few things rather than have just not done so much because it really isn't feasible to do it all PERFECTLY legally. > > It's kind of funny, I've thought a lot about this ELT thing. I believe what I'll do (I hope big brother isn't watching...) is move the ELT I do own over to whatever I'm getting registered, and keep moving it around to where ever I need it at the time to be as legal as possible, but probably not gonna miss a flight somewhere, sometime, just because it isn't in there, ya know? > > I do always make it a practice for someone to know where I am and when, and will take appropriate action should something go wrong. I believe that is safer than relying on aging equipment and technology anyway. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407231#407231 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 22, 2013
Just to prove Im not a four flusher heres the photographic proof I said would be coming.... http://youtu.be/0y4PnKwikvM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407283#407283 ________________________________________________________________________________
Date: Aug 22, 2013
Jeez I think I just figured it out! As opposed to phillips correct... Sent from my iPad Jack Textor On Aug 22, 2013, at 7:11 PM, Jack wrote: > > Tools what are straight headed fasteners? > > Sent from my iPad > Jack Textor > > On Aug 22, 2013, at 12:33 PM, "tools" wrote: > >> >> This is a huge bucket of worms that is practically impossible to intelligently discuss! >> >> Believe me, I'm NOT a huge fan of government intervention (with the exception being I'm ok with them outlawing straight headed fasteners...). However, when you spend much time in a third world environment, you get a little more alright with it. >> >> But then you spend some time in Europe and wonder what if we go THAT far?! >> >> I think the real answer lies reasonable interpretation. In your case, what's the point of flying off 40hrs? You did the right thing in getting things straightened out, and they punish you (in effect). If more reasonable interpretation and enforcement were to be the norm, people would indeed be more inclined to try and follow the rules. >> >> To that end, and how I've always looked at this stuff, I believe I just do the best I can to be safe first, and follow the "rules" second. When I'm knowingly violating something and get caught, I simply fess up and take the punishment like an adult. Overall, I'm way ahead of the game despite getting caught for a few things rather than have just not done so much because it really isn't feasible to do it all PERFECTLY legally. >> >> It's kind of funny, I've thought a lot about this ELT thing. I believe what I'll do (I hope big brother isn't watching...) is move the ELT I do own over to whatever I'm getting registered, and keep moving it around to where ever I need it at the time to be as legal as possible, but probably not gonna miss a flight somewhere, sometime, just because it isn't in there, ya know? >> >> I do always make it a practice for someone to know where I am and when, and will take appropriate action should something go wrong. I believe that is safer than relying on aging equipment and technology anyway. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=407231#407231 > > > > > ________________________________________________________________________________
Date: Aug 22, 2013
Yep, that's them. These days, just have no use for them... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407287#407287 ________________________________________________________________________________
Date: Aug 23, 2013
I found the answer to my question on the polyfiber site Since 2001, the FAA has required that fabric covered aircraft (at least the fabric parts) be painted only with topcoat paints tested and approved on a n STC. Use of any other topcoat paint will void the STC and airworthiness o f the aircraft. Up to 2001, the STC's "ended with the silver", and any type paint was legal to use. This is no longer true. Over the years, increased use of brittle automotive or industrial paints caused enough cracking and d elamination to cause the FAA to rethink approving untested topcoat paints o ver fabric. Failed topcoat paints expose polyester fabric to sunlight and U V damage. As of the latest revision of the Poly Fiber STC Procedure Manual (revision 21, September 2006), only the following topcoat paints are approv ed on the Poly Fiber STC: Poly Tone, Aerothane, or Randolph Ranthane. All t hree of these paints have long service lives over fabric as well as an FAA Parts Manufacturing Authority (PMA), which allows their application on cert ified aircraft. For instance, a J-3 Cub must have only Poly Tone, Aerothane or Ranthane over the fabric parts, but you could use enamel or anything el se over the struts, cowl, fairings, etc. The keyword is FABRIC. Experimenta l aircraft are not bound by these rules, however, we do recommend using pro ducts with known track records on fabric components. Malcolm ----- Original Message ----- From: "H. Marvin Haught" <handainc(at)madisoncounty.net> Sent: Thursday, August 22, 2013 6:22:25 PM Subject: Re: Pietenpol-List: Re: Covering systems It all depends upon how the STC is worded, and how different regions of the FAA interpret both their standards and the particular STC. Recently a loca l AI wanted to cover a certified airplane with Stewarts, but the customer w anted a solvent based paint. From what I understand, the FAA interpreted th e EkoFill as the finish coat as the fabric was protected and sealed from co ntaminates, deterioration and UV. I made the point with him that the Stewar t STC is completed only by the waterborne topcoat. But apparently, it was a pproved and signed off. I do not believe that situation was entirely legal, but it is signed off and flying. Since I have not seen the actual document ation, I can't verify the story, but throw it out as an example. I also know of a Pitts Special that was recovered by a large shop. I do not know what brand of fabric or if any "system" was used, but I think it was basically PolyFiber, and painted with a Dupont Topcoat with a flex additive . I don't know how that sort of a thing gets done, legally. And again, I ha ve not be able to verify the facts, but that was what the owner told me. I believe that generally, the STC is interpreted as being a complete system through paint, and that any substitutions are not legal nor permitted. And I doubt that any of the companies would warranty a cover job if there are any deviations from the "system" which also includes application techniques . I know that Stewart's and SuperFlite will not honor a warranty claim unle ss the whole system used. To me, even a Piet is too much of an investment, even if only in time and effort, to risk having to recover it in a short pe riod of time by using any questionable covering practices. Normally, I don' t think safety would be involved, but the example of Steve Whitman shows th at even errors in application techniques could possibly kill you. The short answer is that the process is the STC, which includes the applica tion manual for each of the different systems. M. Haught On Aug 22, 2013, at 4:39 PM, gliderx5(at)comcast.net wrote: For certified aircraft both Polyfiber and Stewarts processes are approved, but does anybody know where the processes really start and end? With Polyfiber you prep the frame, glue with polytac, stitch, tape with pol ybrush, spray 2 coats of polybrush, 3 coats of polyspray, and an undetermin ed number of color coats (polytone or aerothane). It's interesting that the manual says they "recommend" polytone or areothane, it does not say "requi re" which leads me to believe that other paints may be substituted. If the color coats are not part of the "system", then what about the polyspray or the polybrush? Neither attach the fabric to the frame so as long as the pol ytac/polybrush system of gluing and taping are followed (or Stewarts ecobon d) the fabric should remain attached. Everything else is UV protection, wea ve filling, and decoration. I realize that I'm trying to reason my way into a conclusion on a matter dictated by the FAA, but I am curious on what def ines the "process". Anyone know for sure? Malcolm ----- Original Message ----- From: "H. Marvin Haught Jr." < handainc(at)madisoncounty.net > Sent: Thursday, August 22, 2013 4:02:39 PM Subject: Re: Pietenpol-List: Re: Covering systems isoncounty.net> Thanks, Gary.... you are right on target! And the real point in this topic is that you should be careful in "mixing" systems, such as using one brand fabric sealer over another systems glue, etc. which may have been what caused problems in the instance of Steve Whitman. Some products may not be compatible with others. That is why Stewart's got certification for repair of other systems. Being water based glue and Sealer (EkoFill) and waterborne paint, there are no incompatibility issues. But if you do decide to repair another system with Stewart's, be advised that it is necessary to clean the area to be repaired very thoroughly because fish eye can be a huge problem. I scrub the area with TSP and a scotchbrite pad, rinse and then scrub with the Stewart's cleaner. I follow that, after it dries with a wipe of isopropyl alcohol. Waterborne paints are very intolerant of contaminates. M. Haught 8/22/2013 2:48 PM, Gary Boothe wrote: > > > It should not surprise anyone that any manufacturer would advise to use > their own products for repairs, for many reasons, not the least of which are > those that would come from their Legal Dept concerning warranties. Still, as > Mr. Haught correctly stated, Stewart Systems offers their products as a > patching process for any solvent based system, as stated in their > 'Procedures Manual,' under "Repairing Fabric": > > " REPAIRING FABRIC > Always refer to FAA Advisory Circular AC 43.13-1B Chapter 2 before repair ing > any fabric damage. This advisory circular spells out in detail how > particular injuries to the aircraft fabric are to be repaired. > Repairing fabric damage with STEWART SYSTEMS method is a relatively simpl e > and easy process. In the case of a fabric puncture, the area must be > thoroughly cleaned with STEWART SYSTEMS EkoClean Heavy Duty Cleaner (E670 ) > to remove any waxes, silicones, or contaminates which might be present. I f > the topcoat is STEWART SYSTEMS Waterborne Catalyzed EkoPoly you just need to > scuff sand an area 2=9D around the damaged area before patching. If you are > unsure of the topcoat or you know it is something other than STEWART SYST EMS > Waterborne Catalyzed EkoPoly Top Coat, you must sand down to the EkoFill > coat 2=9D around the damaged area or to bare fabric if repairing a solvent > based system. Next glue your patch on the sanded area using EkoBond glue and > allow to dry. Heat shrink the fabric ONLY over the open hole under the > patch. Finish Iron the patch edges at 250=C2=B0F. Apply EkoFill to desire d > thickness, sand and spray matching top coat. Stewart Systems is FAA appro ved > for repairing any certified covering system." > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > jarheadpilot82 > Sent: Thursday, August 22, 2013 12:15 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Covering systems > > --> > > I just sat in a fabric covering class at Oshkosh that was taught by John > Goldenbaum of Poly Fiber and he stated what Scott said about not mixing > components of one system with components of another system. > > Is there somewhere on the Stewart Systems website or publications that sa ys > it is compatible with all other systems? Nothing personal Mr. Haught. It is > just the "trust, but verify" part of how I like to look at these types of > discussions when someone vehemently tells someone else that he is wrong > about something that could kill you when flying. > > If you can find that and post a link, I am sure that it would be a help t o > all of us. Thanks. > > -------- > Semper Fi, > > Terry Hand > Athens, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407247#407247 > > > > > > > > > > > > > > > <; &nb=================== href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List href="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution === ________________________________________________________________________________
Subject: Re: NX626E
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Aug 22, 2013
Bill, an amazing video. Looks like old hat to you. Fantastic job. Now I have a big question to ask of you. Can I copy your parking brake system or do you have a patent on it? I could pay you a royalty. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407291#407291 ________________________________________________________________________________
Date: Aug 22, 2013
Mike: I agree. I do not have one, nor do I ever plan on having one......practical ly speaking, (not in the vocabulary of logically thinking men....:.read: FA A policy-maker's), it is not necessary to install one of these morfadite co ntraptions, in this type of airplane, in my opinion. Dan Helsper Puryear, TN -----Original Message----- From: Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] (GRC-RXD0)[Vantage Partners, LLC] Sent: Thu, Aug 22, 2013 3:15 pm Subject: Pietenpol-List: being found With all this talk about ELT=99s I have to post that during my airwor thiness inspection no mention of an ELT was ever made and from day one I never installed one nor 15 years later have one. I =99m sure it would be prudent to carry one but I=99ve just never done it but then again I don=99t fly over mountains or rugged t errain. I figure they=99ll just see the smoke and drive toward it. ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 22, 2013
Fantastic, Bill!! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of BYD Sent: Thursday, August 22, 2013 5:18 PM Subject: Pietenpol-List: Re: NX626E Just to prove Im not a four flusher heres the photographic proof I said would be coming.... http://youtu.be/0y4PnKwikvM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407283#407283 ________________________________________________________________________________
From: "Dortch, Steven D MAJ MIL USA NGB" <steven.d.dortch(at)us.army.mil>
Date: Aug 22, 2013
Subject: Re: Fwd: Re: Fwd: Propeller Pictures
UNCLASSIFIED Michael Perez and other Pietenfolk, Below is the answer on why you should leave scallops in your prop. The expert is Dave Rogers. He is a professor of aerodynamics at a little boating school in Annapolis, Maryland. He owns and flies Bonanzas and loves most everything that flies. Blue Skies, Steve D -------- Original Message -------- From: dfr Date: Aug 22, 2013 7:19:46 PM Subject: Re: Fwd: Propeller Pictures > G'day Steve, > > Leave the scallops. The experimental evidence (?) suggests that the propeller > is more efficient with the scallops. The likely reason is that the scallops > transition the boundary layer from laminar to turbulent. The turbulent boundary > layer then stays attached longer which results in more lift (thrust). > > A propeller is nothing more than a wing spinning in a circle. I suspect that > the Reynolds number is quite low, hence the turbulent boundary layer is better. > > There is a direct analogy with some towing tank studies done on a small sailboat > rudder. The drag on the rudder was actually lower with a slightly rough finish, than with > an ultra smooth finish for the same reason. > > On the other hand, if you don't like the results you can always strip it, sand it > and refinish it. It is harder to do the reverse . > > Dave Rogers > > On 8/22/2013 6:42 PM, Dortch, Steven D MAJ MIL USA NGB wrote: > >UNCLASSIFIED Dr. Dave, As you know I am finishing the restoration on a Pietenpol Air camper. > >A gentleman on the Pietenpol list posted this with the attached photos. The question is "Do > >the scallops help or hurt the prop efficiency? " I told him I would ask you as a recognized > >aerodynamics expert. > > > >"I received my CloudCars propeller yesterday. It is a 76 X 38 all maple scimitar that I > >ordered not finished...which saved me some money and allows me to finish, stain, paint, > >varnish as I want. As shipped, it weighs 10#. With it was a note from Jay Anderson to call > >him for some finishing tips. During our conversation, he told me that they seem to get better > >performance from the props. that are left with the "scallops" intact as opposed to the > >propellers that are sanded smooth. He also recommended that the "fields", (fiberglass covered > >tips) stay intact. Sounded like most people don't like the rough, patch-work look of them and > >try to fill/sand smooth. These fields form a nice, hard edge around the wood that should also > >be left intact. My plan was to sand the propeller smooth and make it as slick as I could. > >After our 40 min. conversation, I am now going to leave the prop. as shipped. Jay said some > >MILD sanding is fine to prep. it for it's first coat of protection, (paint, ! varnish, > >stain...) but nothing more than that is needed. MILD sanding between coats is also OK, but > >keep it to a minimum." > > > >In other words "is it better to leave the "scallops" or is that an Old Pilots Tale? > > > >Blue Skies, Steve D. UNCLASSIFIED > > -- > David F. Rogers, PhD, ATP > Professor of Aerospace Engineering (Emeritus) > Annapolis, MD > > Rogers Aerospace Engineering & Consulting > Annapolis, MD > Over 50 years of experience > www.nar-associates.com > 410 271 1968 (c) UNCLASSIFIED ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 22, 2013
Outstanding! Very good looking airplane! -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407297#407297 ________________________________________________________________________________
Date: Aug 22, 2013
Steve, there was no answer below your post about leaving the scallops on wood props. Perhaps you forgot to add the attachment(s)? -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407301#407301 ________________________________________________________________________________
Subject: Re: Covering systems
Date: Aug 22, 2013
Wow, look what one word lead to. >From the original question posed, I never even thought about mixing the different chemicals or repairing using different systems. I don't think John did either. Just using different processes for different parts of the airplane. Why one would, I don't know. Can they? I don't see why not. -------- Curt Merdan Flower Mound, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407302#407302 ________________________________________________________________________________
Date: Aug 23, 2013
Subject: Re: NX626E
Very nice Bill; enjoyed seeing your video and I like your paint job too. Cheers, Jim B. ________________________________________________________________________________
Date: Aug 22, 2013
UNCLASSIFIED Billy, Did it come through below? Michael Perez and other Pietenfolk, Below is the answer on why you should leave scallops in your prop. The expert is Dave Rogers. He is a professor of aerodynamics at a little boating school in Annapolis, Maryland. He owns and flies Bonanzas and loves most everything that flies. Blue Skies, Steve D -------- Original Message -------- From: dfr Date: Aug 22, 2013 7:19:46 PM Subject: Re: Fwd: Propeller Pictures > G'day Steve, > > Leave the scallops. The experimental evidence (?) suggests that the propeller > is more efficient with the scallops. The likely reason is that the scallops > transition the boundary layer from laminar to turbulent. The turbulent boundary > layer then stays attached longer which results in more lift (thrust). > > A propeller is nothing more than a wing spinning in a circle. I suspect that > the Reynolds number is quite low, hence the turbulent boundary layer is better. > > There is a direct analogy with some towing tank studies done on a small sailboat > rudder. The drag on the rudder was actually lower with a slightly rough finish, than with > an ultra smooth finish for the same reason. > > On the other hand, if you don't like the results you can always strip it, sand it > and refinish it. It is harder to do the reverse . > > Dave Rogers > > On 8/22/2013 6:42 PM, Dortch, Steven D MAJ MIL USA NGB wrote: > >UNCLASSIFIED Dr. Dave, As you know I am finishing the restoration on a Pietenpol Air camper. > >A gentleman on the Pietenpol list posted this with the attached photos. The question is "Do > >the scallops help or hurt the prop efficiency? " I told him I would ask you as a recognized > >aerodynamics expert. > > > >"I received my CloudCars propeller yesterday. It is a 76 X 38 all maple scimitar that I > >ordered not finished...which saved me some money and allows me to finish, stain, paint, > >varnish as I want. As shipped, it weighs 10#. With it was a note from Jay Anderson to call > >him for some finishing tips. During our conversation, he told me that they seem to get better > >performance from the props. that are left with the "scallops" intact as opposed to the > >propellers that are sanded smooth. He also recommended that the "fields", (fiberglass covered > >tips) stay intact. Sounded like most people don't like the rough, patch-work look of them and > >try to fill/sand smooth. These fields form a nice, hard edge around the wood that should also > >be left intact. My plan was to sand the propeller smooth and make it as slick as I could. > >After our 40 min. conversation, I am now going to leave the prop. as shipped. Jay said some > >MILD sanding is fine to prep. it for it's first coat of protection, (paint, ! varnish, > >stain...) but nothing more than that is needed. MILD sanding between coats is also OK, but > >keep it to a minimum." > > > >In other words "is it better to leave the "scallops" or is that an Old Pilots Tale? > > > >Blue Skies, Steve D. UNCLASSIFIED > > -- > David F. Rogers, PhD, ATP > Professor of Aerospace Engineering (Emeritus) > Annapolis, MD > > Rogers Aerospace Engineering & Consulting > Annapolis, MD > Over 50 years of experience > www.nar-associates.com > 410 271 1968 (c) UNCLASSIFIED ________________________________________________________________________________
Date: Aug 22, 2013
Still nothing, Steve. -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407311#407311 ________________________________________________________________________________
Date: Aug 23, 2013
Steve, thank you and Dave for the intell. below. I always like to get multi ple inputs on matters that I am not sure of one way or another. (The mixing of covering products/techniques is another good thread...) I know here at work we, (not myself personally) have done some work with boundary layers a nd their advantage to flying surfaces, so what I am hearing seems to ring t rue.=0A=0AI am finished with my propeller, I applied the last coat of varni sh yesterday. I did, in fact, leave it as shipped. As Dave mentioned, I fig ured worst case, I could sand it all down smooth as glass later if needed.. .sounds like I won't.=0A=0AAs some of you may know, I also was not concerne d with the "glass" like finish on the entire AC; the whole thing is painted by brush.- Perhaps that slightly "textured" surface will actually help p erformance on some small scale...=0A=0ANext up is the dimple tape all aroun d all of the exposed round tube and maybe the LE of the streamline tube.- (I kid...)=0A=0AThanks again.=0A=0A=0A-=0AMichael Perez=0APietenpol HINT Videos=0AKaretaker Aero=0Awww.karetakeraero.com=0A=0A=0A=0A>______________ __________________=0A>=0A>- =0A>> G'day Steve,=0A>> =0A>> Leave the scall ops. The experimental evidence (?) suggests that the propeller=0A>> is more efficient with the scallops. The likely reason is that the scallops=0A>> t ransition the boundary layer from laminar to turbulent. The turbulent bound ary=0A>> layer then stays attached longer which results in more lift (thrus t).=0A>> =0A>> A propeller is nothing more than a wing spinning in a circle . I suspect that=0A>> the Reynolds number is quite low, hence the turbulent boundary layer is better.=0A>> =0A>> There is a direct analogy with some t owing tank studies done on a small sailboat=0A>> rudder. The drag on the ru dder was actually lower with a slightly rough finish, than with=0A>> an ult ra smooth finish for the same reason.=0A>> =0A>> On the other hand, if you don't like the results you can always strip it, sand it=0A>> and refinish i t. It is harder to do the reverse .=0A>> =0A>> Dave Rogers=0A>> =0A>> On 8/22/2013 6:42 PM, Dortch, Steven D MAJ MIL USA NGB wrote:=0A>> >UNCLASSIF IED Dr. Dave, As you know I am finishing the restoration on a Pietenpol Air camper.=0A>> >A gentleman on the Pietenpol list posted this with the attac hed photos. The question is "Do=0A>> >the scallops help or hurt the prop ef ficiency? " I told him I would ask you as a recognized=0A>> >aerodynamics e xpert.=0A>=0A> ________________________________________________________________________________
Date: Aug 23, 2013
UNCLASSIFIED Did anyone else get it? It comes back to me complete. On 08/23/13, Billy McCaskill wrote: > > Still nothing, Steve. > > -------- > Billy McCaskill > Baker, LA > tail section almost done, starting on ribs soon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407311#407311 > > > > > > > UNCLASSIFIED ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Aug 23, 2013
I got it, and it made perfect sense. It's the same principle as putting dimples on golf balls to make the boundary layer transition from Laminar to Turbulent flow. It used to be that all golf balls were smooth, but some golfers discovered that an old, cut up ball with dings and gouges would travel further than a new smooth ball. Wind tunnel testing confirmed it and the manufacturers starting putting dimples on golf balls. Check out: http://entertainment.howstuffworks.com/sports/golf/basics/question37.htm Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Dortch, Steven D MAJ MIL USA NGB Sent: Friday, August 23, 2013 7:05 AM Subject: Re: Pietenpol-List: Fwd: Re: Fwd: Propeller Pictures UNCLASSIFIED Did anyone else get it? It comes back to me complete. On 08/23/13, Billy McCaskill wrote: > > Still nothing, Steve. > > -------- > Billy McCaskill > Baker, LA > tail section almost done, starting on ribs soon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407311#407311 > > > > > > > UNCLASSIFIED ________________________________________________________________________________
Date: Aug 23, 2013
UNCLASSIFIED Micheal, sounds like your plane will be a speed demon. Are ready to compete in the low and really slow experimental division at Reno? Perhaps you should step up to unlimited! ;+} Blue Skies, Steve D On 08/23/13, Michael Perez wrote: > > > > Steve, thank you and Dave for the intell. below. I always like to get multiple inputs on matters that I am not sure of one way or another. (The mixing of covering products/techniques is another good thread...) I know here at work we, (not myself personally) have done some work with boundary layers and their advantage to flying surfaces, so what I am hearing seems to ring true. > > I am finished with my propeller, I applied the last coat of varnish yesterday. I did, in fact, leave it as shipped. As Dave mentioned, I figured worst case, I could sand it all down smooth as glass later if needed...sounds like I won't. > > As some of you may know, I also was not concerned with the "glass" like finish on the entire AC; the whole thing is painted by brush. Perhaps that slightly "textured" surface will actually help performance on some small scale... > > Next up is the dimple tape all around all of the exposed round tube and maybe the LE of the streamline tube. (I kid...) > > Thanks again. > > > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > > > > > > > > G'day Steve, > > > > > > Leave the scallops. The experimental evidence (?) suggests that the propeller > > > is more efficient with the scallops. The likely reason is that the scallops > > > transition the boundary layer from laminar to turbulent. The turbulent boundary > > > layer then stays attached longer which results in more lift (thrust). > > > > > > A propeller is nothing more than a wing spinning in a circle. I suspect that > > > the Reynolds number is quite low, hence the turbulent boundary layer is better. > > > > > > There is a direct analogy with some towing tank studies done on a small sailboat > > > rudder. The drag on the rudder was actually lower with a slightly rough finish, than with > > > an ultra smooth finish for the same reason. > > > > > > On the other hand, if you don't like the results you can always strip it, sand it > > > and refinish it. It is harder to do the reverse . > > > > > > Dave Rogers > > > > > > On 8/22/2013 6:42 PM, Dortch, Steven D MAJ MIL USA NGB wrote: > > > >UNCLASSIFIED Dr. Dave, As you know I am finishing the restoration on a Pietenpol Air camper. > > > >A gentleman on the Pietenpol list posted this with the attached photos. The question is "Do > > > >the scallops help or hurt the prop efficiency? " I told him I would ask you as a recognized > > > >aerodynamics expert. > > > > > > > > > > > > > UNCLASSIFIED ________________________________________________________________________________
Date: Aug 23, 2013
I received the reply via. email. It appears that it is not going through th e web list, so I kept it on the bottom of my reply back. That reply, with t he intel. from Dave, are on the web list now.=0A=0A=0A-=0AMichael Perez =0APietenpol HINT Videos=0AKaretaker Aero=0Awww.karetakeraero.com=0A=0A=0A =0A>________________________________=0A> From: "Dortch, Steven D MAJ MIL US A NGB" =0A>To: pietenpol-list(at)matronics.com =0A>Sent: Friday, August 23, 2013 7:05 AM=0A>Subject: Re: Pietenpol-List: F wd: Re: Fwd: Propeller Pictures =0A> =0A>=0A>--> Pietenpol-List message pos ted by: "Dortch, Steven D MAJ MIL USA NGB" =0A >=0A>UNCLASSIFIED=0A>Did anyone else get it? It comes back to me complete. =0A>=0A>On 08/23/13, Billy McCaskill- wrote:=0A>> --> Pietenpol-List mess age posted by: "Billy McCaskill" =0A>> =0A>> Still nothing, Steve.=0A>> =0A>> --------=0A>> Billy McCaskill=0A>> Baker, LA=0A>> tail s ection almost done, starting on ribs soon=0A>> =0A>> =0A>> =0A>> =0A>> Read this topic online here:=0A>> =0A>> http://forums.matronics.com/viewtopic.p hp?p=407311#407311=0A>> =0A>> =0A>> =0A>> =0A>> =0A>> =0A>> =0A>UNCLASSIF ====0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Aug 23, 2013
Subject: Re: NX626E
Muy bueeeno!!! Felicitaciones!!! Mario Giacummo 2013/8/22 BYD > > Just to prove I=92m not a four flusher ' here=92s the photographic proo f I > said would be coming.... > > http://youtu.be/0y4PnKwikvM > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407283#407283 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Aug 23, 2013
Subject: Re: NX626E
Congratulations Bill!- Very nice plane and video. Go Pro I am guessing? =0A=0AMichael Perez=0A=0APietenpol HINT Videos=0AKaretaker Aero=0Awww.karet akeraero.com ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: Bill Sayre's First Flight NX626E
Date: Aug 23, 2013
Fantastic video Bill and what a smooth touch you have on the stick. Your Stinson 108 and Boredom Fighter flying hours showed up clearly on your video. I like how you touched down and af ter you decelerated you lifted up in your seat and let out a big exhale. Many of us know that feel so well! I still get that on gusty crosswind days after landing and seeing that the whole plane is still intact. Great job, beaut iful plane, and now let the real fun begin. PS-why didn't you wait for a gusty, windy, lousy day for your first flight like so many seem to do? You picked a picture-perfect weather slot! Uncle Tony would be super-proud of you! Mike C. PSS-did you powder your beard just to make you look more experienced? :) ________________________________________________________________________________
Date: Aug 23, 2013
Subject: Re: NX626E
Way to go Bill. First flight over water yet. You 'da man! Stinemetze ________________________________________________________________________________
Subject: Re: being found (OT about getting away with stuff)
Date: Aug 23, 2013
Considering R.R's comments=2C I have a comment. I have been flying since 1 942. have somewhere in the neighbor hood of 10=2C000 hours in Military and General Aviation aircraft. Have been into a bunch of airports -- large and small -- have been tied down on a bunch of flight lines -- and=2C get this =2C I HAVE NEVER BEEN RAMP CHECKED. I'm sure all the GA aircraft I flew we re properly certificated=2C but the FAA didn't know that. I agree with R. R. -- we don't need the FAA with all their stupid regulations that don't me an anything. If I ever get ramp checked I might change my mind. C PS. I think I will finish my Piet and go fly it without bothering with all the unnecessary paper work. I DIDN'T SAY I WAS GOING TO DO THAT -- JUST T HAT I'M THINKING ABOUT IT. > Date: Thu=2C 22 Aug 2013 12:56:28 -0400 > From: r.r.hall(at)cox.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: being found (OT about getting away with stuff) > > > Guys=2C > > The enforcement of all FAA rules is pretty hit and miss in the small plan e arens I think. When I bought my one off homebuilt from the original build er he told me the whole story of how he built it out of wood based on a pop ular metal plane of the time including a V tail but the mixing control was maladjusted on his first flight and he crashed. The plane was rebuilt with a bigger engine and standard tail form and flown for many years afterward. What I didn't realize was that the original Op Lims stated that "any major changes invalidate the airworthiness certificate". Being as it was subject to two major changes the AW cert was totally invalid and had been for the m any years it flew. When I discovered this I decided to get it straightened out. As a result I spent several months corresponding with the FAA=2C DAR and DER but finally obtained a new airworthiness certificate and am in the process of flying off the 40 hours of Phase 1 (if the stupid weather would ever cooperate). ! > My point is=2C if someone can fly an airplane for 20 years with an inval id airworthiness cert. what else are people getting away with on a daily ba sis? Whatever they are "getting away with" it surely doesn't seem to impact GA safety too much and kinda makes me question the whole need for all this bureaucracy. 3rd class medical is a perfect example. Lots of people are fl ying without medicals yet the accident rate hasn't gone through the roof. I n my opinion you should only need a medical if you are flying commercially i.e. someone is paying you. That is just one example=2C all these ADs and m andatory ADSB would be another. Is it really going to enhance safety? How m any GA midair collisions were there last year? > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Covering systems
Date: Aug 23, 2013
Who would know? Chuck > Date: Thu=2C 22 Aug 2013 11:48:22 -0500 > From: jbfjr(at)peoplepc.com > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Covering systems > > > Pietsters=2C > > Is it legal (??..perhaps the wrong term) to cover parts of the plane=2C s ay the wings and tail surfaces=2C with the Polyfiber system and then cover the fuselage with the Stewart system? Seems like I remember reading somewh ere that you can't mix systems on the same plane. > > Thanks=2C > John Franklin > Prairie Aire 4TA0 > Needville=2C TX > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 23, 2013
Way to go Bill - great inspiration....!!!! Bernard would be very pleased. THANKS for posting the video.................................. Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407360#407360 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 23, 2013
Way too cool! That was quite an adventurous flight for the FIRST FLIGHT! You are an inspiration. Thanks, Ray Krause SkyScout in progress Sent from my iPad On Aug 22, 2013, at 5:18 PM, "BYD" wrote: > > Just to prove Im not a four flusher heres the photographic proof I said would be coming.... > > http://youtu.be/0y4PnKwikvM > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407283#407283 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 23, 2013
Very cool! Congratulations Bill, very nice job -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407370#407370 ________________________________________________________________________________
Subject: Re: Bill Sayre's First Flight NX626E
Date: Aug 23, 2013
My beard was a darker shade when I started this project!!! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407373#407373 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 23, 2013
AircamperN11MS wrote: > Can I copy your parking brake system or do you have a patent on it? I could pay you a royalty. It has been suggested that I draw up plans for that system, but I just can't seem to find the time. If you can figure out the complexities, you welcome to use it - just be advised that there are no warranties and you assume all liabilities. Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407375#407375 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 23, 2013
Thanks Bill. I'll give it a try this weekend. Hope it doesn't throw off my W&B. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407378#407378 ________________________________________________________________________________
Date: Aug 23, 2013
The explanation showed up in the email digest this morning, but wasn't showing up on the forum. Odd. -------- Billy McCaskill Baker, LA tail section almost done, starting on ribs soon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407380#407380 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 23, 2013
> "speedbrake(at)sbcglobal.n"] > Congratulations Bill! Very nice plane and video. Go Pro I am guessing? > > Michael Perez Drift Innovation HD720 Has built in screen (for aiming/setting up) and rotatable lens so if the camera is at an angle you can still get a level shot. Well under $100 new in box at Amazon. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407388#407388 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 23, 2013
Sent from my iPad On Aug 23, 2013, at 12:58 PM, "BYD" wrote: > > > ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 24, 2013
I just had a chance to view the video. Now I see what the patented parking brake looks like! Super nice flight Bill, and the landing could not have been better. I must say, the prop sure does stop suddenly when you shutdown the engine. Must be that 12:1 compression ;o) I don't think I've ever seen a setup where the cabanes are braced with the X-wires on one side and a brace tube on the other. Makes perfect sense since the passenger always boards from the port side, but still a little unusual. Congratulations again! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407414#407414 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 25, 2013
Hi Oscar, The patented parking brake came to me when I was wondering how to secure the ship at a location that didnt offer someplace to tie the tail. It occurred to me that Id have ropes to tie the plane down and I could use them for double-duty like you see in the video. You have seen the cabane support system I used before go back and look at N2431 that I used to own and youll recognize it. After a discussion with Vi Kapler where he mentioned that just the cross-wires alone made for a flexing wing, I decided to replicate that feature. And although I am running a high-compression head (for a Model-A), I think the sudden stop is more a factor of a newly broken-in engine. I imagine both factor in. Thanks for the compliments, and now that youre on the west coast again, maybe well meet at a function in between our locations! Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407458#407458 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 25, 2013
Bill; I'd be curious to hear more about the flexing wing discussion. I'm not sure how that translates back to the cabanes and their bracing. Next July I plan to fly Scout to the event at Arlington that used to be the Northwest fly-in. That is, if I survive the West Coast fly-in down to Frazier Lake next June ;o) In January 2014 I will have officially entered early geezerhood... eligible for Social Security ;o) I will reward myself with some x-c flying in 2014. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407460#407460 ________________________________________________________________________________
Subject: Control system bearings
Date: Aug 25, 2013
What are people using for bearings in the control system. For the torque tube I thought some 1" .049 tube would work but seems a bit loose. Could machine something down from a thicker tube or look into a buyout part. Curious what others are using. Tom B. ________________________________________________________________________________
From: "skipgadd(at)earthlink.net" <skipgadd(at)earthlink.net>
Date: Aug 25, 2013
Tom, .058 is the magic size. The ID of any size will fit the OD of the next smaller size. Skip > [Original Message] > From: TOM MICHELLE BRANT <tmbrant(at)msn.com> > To: pietenpol-list(at)matronics.com > Date: 8/25/2013 4:21:05 PM > Subject: Pietenpol-List: Control system bearings > > > What are people using for bearings in the control system. For the torque tube I thought some 1" .049 tube would work but seems a bit loose. Could machine something down from a thicker tube or look into a buyout part. Curious what others are using. > > Tom B. > > ________________________________________________________________________________
Date: Aug 25, 2013
Subject: Cowling reinstall
UNCLASSIFIED Gentlemen and Oscar, I have started working on the cowling. When Attached, the bottom cowling (chin) attaches easily. But the portion around the prop looks like it is sticking too far forward and will interfere with the prop right around where the prop bolts are. It does not improve when I add the top portion of the cowling. The design appears to me that it needs to be back enough to put small Rclips to attach the top to the bottom next to the prop. It is also tight against the air filter and seems not square to the filter. Any Ideas before a take a BFH to it to hammer it into shape? Blue Skies, Steve D UNCLASSIFIED ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 25, 2013
Cool. I just entered geezerhood myself and can relate that its fine. As far as the flexing wing discussion, Vi related that with just the cross bracing for the cabanes, he felt the fuselage in a sense could yaw while the wing continues straight (my description not his). I suppose in turns but dont remember him saying that. He did mention that at first it could be a little unnerving. Myself, Ive pretty much stayed away from Arlington since it grew into the third largest aviation event in the nation. Its part of that geezerhood mentality. The more pages an event has in its NOTAM, the less likely I am to attend. Ill try to pay attention if you come up and maybe intercept you at a fuel stop or something. Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407476#407476 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 25, 2013
Bill, Where are you located "in the West"? Ray Krause SkyScout in progress Colusa, CA Sent from my iPad On Aug 25, 2013, at 7:20 PM, "BYD" wrote: > > Cool. I just entered geezerhood myself and can relate that its fine. As far as the flexing wing discussion, Vi related that with just the cross bracing for the cabanes, he felt the fuselage in a sense could yaw while the wing continues straight (my description not his). I suppose in turns but dont remember him saying that. He did mention that at first it could be a little unnerving. > > Myself, Ive pretty much stayed away from Arlington since it grew into the third largest aviation event in the nation. Its part of that geezerhood mentality. The more pages an event has in its NOTAM, the less likely I am to attend. Ill try to pay attention if you come up and maybe intercept you at a fuel stop or something. > > Bill > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407476#407476 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Cowling reinstall
Date: Aug 25, 2013
Steve (and gentlemen)- Put down the BFH. Sit and listen. When I first installed (re-installed) the cowlings on Scout, I had the same experience as you did. The bottom half went on quite well (after I weaseled and scooched and prayed it into place around the exhaust stacks, filter, and air box), and I secured it to the four bosses that attach it to the firewall so that it would not move. Then I started with the top half. I can take some pictures of the setup on Scout, and in fact I'm pretty sure that I already have some if I can find them, but the front of the cowling sits pretty close to the back of the prop bolts and all those whirling things. Not so close that they rub, but pretty close just the same. My top and bottom halves are fastened together at the front with about 3 PK screws and Tinnerman nuts on each side of the hole where the prop flange shaft comes through, so they aren't going anywhere. I'm thinking pictures may be quite useful here, so I'll see what I've got. Do not employ the BFH; we are craftsmen, not cavemen. At any rate, only employ the BFH when the hangar doors are closed and Tech Counselors cannot observe your actions. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407479#407479 ________________________________________________________________________________
Subject: Re: NX626E
Date: Aug 25, 2013
>From what I find on the FAA aircraft registry database, Bill is based in Gig Harbor, WA. He can probably see Tacoma across the narrows to the east. Bill, I would be perfectly happy to skip the big event at Arlington and just visit with friends instead. It would probably be cheaper, and undoubtedly less stressful ;o) I have a friend over on the Oly Pen in Port Angeles with his own strip, my friend Kyle Rash is over on Rosario Strait in Anacortes, and I have so many other friends up in Washington state that I'd like to visit (including Jake Schultz in Bellevue)-! You're talking me out of trying to go to a big fly-in and have fun instead. Good for you! Pietenpols forever! -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407480#407480
August 15, 2013 - August 25, 2013
Pietenpol-Archive.digest.vol-mv
