Pietenpol-Archive.digest.vol-mx
September 17, 2013 - October 02, 2013
Kind Regards,
Dave Thursby
(Simi Valley, CA)
Subject: | Re: change of emails |
http://www.matronics.com/subscribe/
On 9/17/2013 11:45 AM, Dortch, Steven D MAJ MIL USA NGB wrote:
> UNCLASSIFIED
> OK, It is time. The Army has changed my email and I am going to jump ship. How
> do I unsubscribe with this email and resubscribe with my new email?
> Blue Skies,
> Steve D
> UNCLASSIFIED
Awesome! Another California Pietenpol builder.
Chris
Sacramento, Ca
Westcoastpiet.com
_____
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of David
Sent: Tuesday, September 17, 2013 11:15 AM
Subject: Pietenpol-List: First Post
Hi All,
I am new to the list and just want to say Hi!
I received my plans from Andrew yesterday and am getting as much info as
possible.
One thing I did notice was that the balance info on the plans indicates one
side is heavier than the other. I don't recall which side and by how much,
but I thought it interesting in light of the thread on this topic.
Anyway, enough for now.
Kind Regards,
Dave Thursby
(Simi Valley, CA)
From: | "Douwe Blumberg" <douweblumberg(at)earthlink.net> |
I've also noticed my plane weighs unequally fore and aft. the tail is
heavier than the nose
Subject: | Re: coaming and sharp edges |
At a high velocity impact any hard object (your head) impacting a very narrow edge
with very low surface area will make that edge cut through plastic , rubber
or any soft material.
The best thing to do is to gave that edge more surface area like hemming it (folding
it back on itself) or cover the edge with an small diameter aluminum tube
to increase the surface area. A material it will not cut through. This will
allow the material in back of the edge to act as a crumble zone an absorb the
energy.
The padding over it will help too. Best to sit in your plane belted in and see
were the danger areas are by moving your body as if your were in a crash. Then
you will have a good idea of what areas your head and body may contact thus adding
some protection there.
Just my thoughts ~ WF2
http://forums.matronics.com/viewtopic.php?p=408780#408780
Subject: | round tube wing struts |
Hello folks, to vary a question about the subject.
I am going to use round tubes for the wing struts, of course I search and read
everything I can, the replace option for the streaming ones used in the Piet are
round tube with OD = 1 3/4" and 1.2 mm wall thikness (I do not remember where
I found this). now the question is other, I was looking the photo attached
here and I plan to do something like that, but something is not very clear, as
I see in the strut is an .. aluminium? block, and a bolt holding it.. just one
bolt?. .. of what diameter? A4 or A5?... the other question is how long is the
inside piece? is this piece threaded?.. and the diameter of the D2 bolt ? (i
do not know how to name it)..
Thank you in advance
Mario Giacummo
Photos here: http://goo.gl/wh7M4
Little Blog : http://vgmk1.blogspot.com
http://forums.matronics.com/viewtopic.php?p=408783#408783
http://forums.matronics.com//files/lower_strut_fork_end_002_108_693.jpg
Dave=2C
There is a nice group of west coast Piet folks=2C most current builders=2C
a great support group. There is an annual gathering and fly in at Frazier
lake air park the first saturday in June each year. a great place to get in
formation and fellowship. Welcome to the group=2C looking forward to your
participation.
Vic
Tulare Ca NX414MV
Subject: RE: Pietenpol-List: First Post
Date: Tue=2C 17 Sep 2013 22:38:16 -0700
Chris
Sacramento=2C Ca
Westcoastpiet.com
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis
Sent: Tuesday=2C September 17=2C 2013 11:15 AM
Hi All=2C
I received my plans from Andrew yesterday and am getting as much info as po
ssible.
side is heavier than the other. I don=92t recall which side and by how muc
h=2C but I thought it interesting in light of the thread on this topic.
Anyway=2C enough for now.
Kind Regards=2C
Dave Thursby
(Simi Valley=2C CA)
href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro
From: | "AircamperN11MS" <Scott.liefeld(at)lacity.org> |
Welcome Dave,
I have a piet in Lancaster and there are a few others near by. You are welcome
to come up and see mine anytime you wish. There is a lot of knowledge within
this group.
My wife grew up in Simi and went to Royal High. In fact she is going down today
to visit with her mother.
Welcome aboard and enjoy the flight,
Scott Liefeld
Flying N11MS since March 1972
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=408785#408785
Subject: | Re: round tube wing struts |
Mario,
I hope this helps. You might have to fix the links if they were broken onto multiple
lines.
I beleive what you are looking at is from Don Helsper. D2 is a J-3 cub WING STRUT
ADJUSTMENT FORK
FAA/PMA'd. J-3 & PA-11. Replacement for 13770-00. Includes bolt, nut, cotter pin
& jam nut. Measures 5/16" bolt hole. Measures 7/16" x 20 thread NF3.
It can be seen here
http://www.aircraftspruce.com/catalog/appages/strutadjfbsets1.php?clickkey=394462
The insert in the aluminum strut is a part from McMaster carr. It is either 7075
or 6061 aluminum stock that is flat on each side
This next paragraph is a post on this forum from dan Helsper and explains the insert.
quote...
Larry Williams has been flying his airplane with the aluminum Skytech struts for
years now. These are the same ones I put on my airplane. Advantage is less weight.
If you don't want to attempt welding these (which I didn't) you have to
insert and attach the end fittings with AN bolts. I used 7075 aluminum rectangular
bar stock for the end fittings McMaster Carr Supply # 9055K13 $48.38 for
3 lineal feet. Worked great.
Dan Helsper
Poplar Grove, IL.
Bob 'Early Builder' Dewenter
Dayton OH
http://forums.matronics.com/viewtopic.php?p=408786#408786
From: | "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov> |
Subject: | a neat idea from John Egan |
I had the pleasure of catching up with Pietenpol builder John Egan during t
he Piet fly-in at Brodhead and he's not
only making good progress in his shop but passing along good ideas like thi
s one by submitting them to Sport Aviation
where this one appeared in the August, 2013 issue. My Uncle Tony Bingeli
s would be proud John........
Mike C. in Ohio
Vic-
For the West Coast fly-in, the first Saturday in June 2014 is the 7th. Is that
the correct date for Frazier Lake? I want to make it next year for sure. It's
about 430 miles for me and Scout... a long day, probably 3 intermediate fuel
stops and 4 hops that I'll make on Friday the 6th so as to have the full day
there on Saturday. If I get hung up in weather, I may need to make it part-way
on Friday and then arrive sometime mid-morning on Saturday.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power
http://forums.matronics.com/viewtopic.php?p=408793#408793
From: | "Bill Church" <billspiet(at)sympatico.ca> |
Mario,
I assume you are talking about using chro-moly steel (4130) round tube, and not aluminum tube. The streamline tubing in the photo is an extruded aluminum shape. It is not recommended to weld aluminum that is to be used as a structural member, as it can significantly weaken the metal in the weld zone. That is the reason why there is an aluminum block inside, secured with bolts. When using steel, you have the advantage of being able to weld without compromising the strength of the tube. For the inner threaded part, you can purchase wing strut barrels http://www.aircraftspruce.com/catalog/appages/strutadjfbsets3.php?clickkey=3621
(Aircraft Spruce part no 05-05900), which can be welded into the ends of your steel
tube struts.
One point to consider, when using round tubes for your struts is that they will
create a lot of drag. Round struts really are not aerodynamically "clean".
You should give serious thought about adding some kind of fairings to streamline
the tubes.
Hope that helps.
Bill C.
http://forums.matronics.com/viewtopic.php?p=408807#408807
From: | Mario Giacummo <mario.giacummo(at)gmail.com> |
Bill, thank you for your response, I know about the drag, so I am going to
do this http://vgmk1.blogspot.com/search?q=aerodinamisacion
and of course, steel tube, I do not know what by the moment, I do not want
to repeat things about availability of anything here. anything in its
moment.
Thank you very much, regards.
Mario Giacummo
2013/9/18 Bill Church
> Mario,
> your steel tube struts.
> will create a lot of drag. Round struts really are not aerodynamically
> "clean". You should give serious thought about adding some kind of
> fairings to streamline the tubes.
> Hope that helps.
> Bill C.
Subject: | New Engine to replace Corvair |
My new engine showed up today to replace the Corvair I was originally going to
install.
John Francis
http://forums.matronics.com/viewtopic.php?p=408819#408819
http://forums.matronics.com//files/image_1135018178_353.jpg
Subject: | Re: New Engine to replace Corvair |
That should help your CG problem!
Jack Textor
install.
> John Francis
Thanks everyone for the kind welcome.
We will be sure to check out the gathering in June next year.
I am working on the Bingelis books on eBay, and have been trying to acquire
a Corvair engine. This will be a long term project for the kids and I
(there's 5 of them) and we are also building a 1/5 scale RC model as well.
One initial question about wood - I have read that Douglas Fir can be used
as an alternative to Spruce. Is this a reasonable assumption? If so, can
someone point me towards a suitable source, preferably on the West Coast?
To foster some enthusiasm with the kids I'd like to get a few wing ribs done
- even if they end up on the wall as decoration - and I'm prepared to use
the construction of these as a learning and bonding experience (pun
intended).
Thanks again, Dave
-----Original Message-----
AircamperN11MS
Sent: Wednesday, September 18, 2013 8:13 AM
Subject: Pietenpol-List: Re: First Post
Welcome Dave,
welcome to come up and see mine anytime you wish. There is a lot of
knowledge within this group.
today to visit with her mother.
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
And should swing a nice long prop.
> Sent from my iPad
> Jack Textor
to install.
>> John Francis
Oscar,- Yes the gathering will be on the 7th this coming year.-- If y
ou get hung up with weather or decide to do it in two days there are a few
Pietenpol people from Northern California who came this year and will proba
bly come again.- Perhaps you could meet up with one or some of them and h
ead down together.- =0A=0A-I'm looking forward to meeting you, and Scou
t, in person at the gathering!=0A=0AMike Groah=0A=0A=0A=0A=0A______________
__________________=0A From: taildrags <taildrags(at)hotmail.com>=0ATo: pietenp
ol-list(at)matronics.com =0ASent: Wednesday, September 18, 2013 11:39 AM=0ASub
ject: Pietenpol-List: Re: First Post=0A =0A=0A--> Pietenpol-List message po
sted by: "taildrags" =0A=0AVic-=0A=0AFor the West Co
ast fly-in, the first Saturday in June 2014 is the 7th.- Is that the corr
ect date for Frazier Lake?- I want to make it next year for sure.- It's
el stops and 4 hops that I'll make on Friday the 6th so as to have the full
day there on Saturday.- If I get hung up in weather, I may need to make
it part-way on Friday and then arrive sometime mid-morning on Saturday.=0A
=0A--------=0AOscar Zuniga=0AMedford, OR=0AAir Camper NX41CC "Scout&qu
ot;=0AA75 power=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://foru
Dave,
Welcome! My Piet is in Lincoln (LHM), just northeast of Sacramento. It is
built mostly with Poplar, some of which I purchased from my local big box
aircraft supply store (Lowe's); but the longer pieces were purchased from a
local hardwood and flooring store. It's easiest when you can find a local
supplier and hand pick your pieces. Chances are, you could even go to your
local lumber supply, tell them you want clear, vertical grain boards (don't
say it's for an airplane), and they will be able to get it for you.
AC43.13 allows Doug Fir as a direct substitute, even allowing for lesser
dimensions as the wood is stronger than spruce. Contact me off list, if you
wish to discuss suitable grain. Gboothe5(at)comcast.net.
Gary Boothe
NX308MB
Sent: Wednesday, September 18, 2013 6:33 PM
Subject: RE: Pietenpol-List: Re: First Post
intended).
Thanks again, Dave
AircamperN11MS
Welcome Dave,
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
I just sprayed a mouthful of scotch (it's 4pm here...) when this post opened up!
Kinda expecting a engine debate starter, wondering if I was gonna see a pic
of a ford or a continental... Nicely done!
So you gonna change the gear too?
http://forums.matronics.com/viewtopic.php?p=408837#408837
Hey Dave,
Rather than spending a bunch of time searching ebay for the Bingelis books, why
don't you just order the set from EAA? $90 for all four books. Brand new.
One stop shopping. One shipping charge.
http://www.shopeaa.com/bingelissetof4.aspx
Bill C.
http://forums.matronics.com/viewtopic.php?p=408839#408839
I'm glad you got the aluminum valve covers!
Barry
Nx973bp
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Francis
Sent: Wednesday, September 18, 2013 8:40 PM
Subject: Pietenpol-List: New Engine to replace Corvair
to install.
John Francis
Just how big would a Pietenpol need to be to wear this engine? I'm sure someone
on this list is smart enough to scale this and even provide dimensions. Yes
this is a challenge. Would I fly it? Heck yes!!!! Would we use a couple of
old Ferris Wheels for the main wheels?
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=408844#408844
on this list is smart enough to scale this and even provide dimensions. Yes this
is a challenge. Would I fly it? Heck yes!!!! Would we use a couple of old
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=408845#408845
David=3B
It sounds like you got your questions answered (about wood selection). Mea
nwhile=2C if you have kids involved and you want to start with something ta
ngible=2C I'll reiterate something that I posted earlier (probably before y
ou joined the list): consider building a quickie fuselage mock-up out of lu
mber scraps or inexpensive hardware-store materials. All you need is the s
ection from the firewall to the pilot's seat back. It will give you a grea
t feel for the geometry and ergonomics of the Piet cockpit=2C and it's some
thing that the kids can help assemble and then climb all over without worry
ing about damaging it. If you later want to hang it from a tree limb and m
ake it into a swing=2C that's fine too. No need to measure or cut to the n
earest 1/32"... nothing is critical.
You should be able to find some inexpensive lumber and plywood and then whi
p together the mock-up with a brad gun=2C stapler=2C or drywall screws in a
jiffy. Won't even require glue joints=2C although you could use Gorilla o
r wood glue and really make it sturdy.
Latex paint=2C of course =3Bo)
Oscar Zuniga
Medford=2C OR
A75 power
Opps, Still had the other thread on my mind while looking at this one. Bad Scott
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=408846#408846
...and the hp will be similar.
> Barry
> Nx973bp
> To: pietenpol-list(at)matronics.com
> to install.
> John Francis
Hi Dave,
Welcome to the West Coast Piet Group. Yes and I have my Piet made entirely out
of Doug Fir except for plywood sheeting.
Jim Boyer
Santa Rosa, CA
PS My Piet has yet to fly; hopefully this year though.
The mock fuselage is a great idea, your kids will like helping you with it
and they can play with it after, they used mine for a sled in the winter.
rick
On Thu, Sep 19, 2013 at 9:33 AM, Oscar Zuniga wrote:
> David;
> Meanwhile, if you have kids involved and you want to start with something
> tangible, I'll reiterate something that I posted earlier (probably before
> you joined the list): consider building a quickie fuselage mock-up out of
> lumber scraps or inexpensive hardware-store materials. All you need is the
> section from the firewall to the pilot's seat back. It will give you a
> great feel for the geometry and ergonomics of the Piet cockpit, and it's
> something that the kids can help assemble and then climb all over without
> worrying about damaging it. If you later want to hang it from a tree limb
> and make it into a swing, that's fine too. No need to measure or cut to
> the nearest 1/32"... nothing is critical.
> whip together the mock-up with a brad gun, stapler, or drywall screws in a
> jiffy. Won't even require glue joints, although you could use Gorilla or
> Latex paint, of course ;o)
> Oscar Zuniga
> Medford, OR
> A75 power
Rick Holland
Castle Rock, Colorado
NX6819Z
Great photo, Rick!! The thing even has a wing centersection!
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=408860#408860
That one will never sell for what he has as a minimum bid ($9600). There are several
complete, flying Piets and GN-1s out there for that much or less.
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=408862#408862
Good luck to the seller.
Like Oscar suggested, for only a few dollars more, one could buy Doc Mosher's very
nice, well-built, flying Piet. Just sayin'...
Go to Barnstormers.com, and search "Pietenpol".
PIETENPOL AirCamper Neenah WI
PIETENPOL AIRCAMPER NEENAH WI $11,000 FLY RIGHT NOW Cont.65, Silver/blue, TT
75hrs incl engine overhaul. AHNC. Let's talk. Doc Mosher--920-727-1534 Contact
Donald A. Mosher - OSHKOSH AIR ASSOCIATES, Owner - located Neenah, WI USA
Telephone: 920-740-4350 . 920-727-1534 . Posted September 10, 2013
Bill C.
http://forums.matronics.com/viewtopic.php?p=408864#408864
That's great! I think I could attach it to some ropes and let it hang from a
tree and the younger ones would love it.
I picked up the Engines book and the Construction Techniques books for $3
each on eBay. I have a very limited budget for this project. Not limited in
absolute amount as such, but "limited" as in it's a drip feed system :-)
Thanks again, Dave
_____
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Holland
Sent: Thursday, September 19, 2013 9:52 AM
Subject: Re: Pietenpol-List: First Post
rick
David;
and make it into a swing, that's fine too. No need to measure or cut to the
You should be able to find some inexpensive lumber and plywood and then whip
together the mock-up with a brad gun, stapler, or drywall screws in a jiffy.
Won't even require glue joints, although you could use Gorilla or wood glue
Oscar Zuniga
Medford, OR
A75 power
" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
Rick Holland
NX6819Z
Mine has round steel struts....is there an easier way to streamline them? I'm lazy
http://forums.matronics.com/viewtopic.php?p=408874#408874
From: | John Greenlee <jmgreenlee(at)sbcglobal.net> |
Hello Good People,
A friend recently purchased a Piet project. It had previously had a Corvair.
He wants to install a Continental.
He wants to buy a mount. Or buy/borrow a jig. Or know the magic dimensions for
mounting Continental. Drawing maybe. If you got stuff to sell contact me offline.
Advice is also appreciated.
Ezra Stiles
I used balsa. I was able to find a source with 3/4" thick pieces. I laminated pairs
of those together then routed out a cove for the steel tube. It was an easy
project to shave the balsa into a streamlined shape. Key was buying a cheap
razor blade plane at the local hobby shop for 5 bucks or so. Regular planes don't
like balsa. Some varnish and then covered with fabric. Was easy and a lot
cheaper than buying streamlined.
lazy :?
There used to be an extruded plastic streamline tubing material that was made to
slide over round tubing and the ultralight guys used it for this very purpose.
I acquired some a number of years ago and it was test-flown on the prototype
Flying Squirrel, where it proved to be of some benefit in drag reduction and
cruise. I'll try to find out where I got it, but I want to say that it was
through Carlson or Sky-Tek.
Slipping some plastic extrusions over your round tubing struts and then securing
it in place is just about as simple and inexpensive as you're going to get.
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=408878#408878
Subject: | Streamline plastic fairings |
Hi.
Some information at:
http://www.uflyit.com/streamline_fairings.htm
http://www.ultralightnews.ca/streamlinedfairings/1.html
http://chrusion.com/BJ7/Streamline/fairings.html
I used these fairings on my cabanes and U/C legs.
Just slit them around trail edge with a Xacto type knife and slid over, fixing
with small aluminium brackets.
In truth not sure how much it improve things as the aircraft was well beyond a
brick aerodynamically regarding parasite drag.
Made me feel better!
Gerry
From: | "Jack Phillips" <jack(at)bedfordlandings.com> |
Which Continental? The Pietenpol supplemental plan set has plans for a
mount for an A65 Continental. If he's installing a C85, C90 or O-200 I
think the mounts are different than for an A65, but I'm not sure of that.
Jack Phillips
NX899JP
Smith Mountain Lake, Virginia
Greenlee
Sent: Thursday, September 19, 2013 11:24 PM
Subject: Pietenpol-List: Cont mount
Hello Good People,
Corvair. He wants to install a Continental.
for mounting Continental. Drawing maybe. If you got stuff to sell contact
me offline. Advice is also appreciated.
Ezra Stiles
Mount locations are the same for all series of the small Continental engines including
A, C, and O-200.
A common recommendation is to make the mount 2" longer than the plans show for
W&B issues. A Google search will confirm mount dimensions.
> Jack Phillips
> NX899JP
Adrian M
Winnipeg, MB
Canada
http://forums.matronics.com/viewtopic.php?p=408888#408888
Gerry=3B
Yes=2C that is exactly the stuff. Extruded plastic sleeves that slip on ov
er round tubing. The Flying Squirrel has two sizes of wing strut tubing=2C
main and drag=2C so there are four struts and they are roughly the same le
ngth as the ones on the Piet. In testing=2C the prototype picked up 5-7 MP
H in top speed after adding the streamline sleeves over the round 4130 stee
l struts. That seems to agree with the claims made on the ultralight websi
tes that you provided links to.
Oscar Zuniga
Medford=2C OR
A75 power
Subject: | question for Oscar |
Oscar,
You've got a Pietenpol Aircamper that was built by Corky yes? You've got a
brand new A75 engine on that beauty but you call it a 'Scout' ? Is that
just a nickname since Scouts are all
single place Pietenpols. Just curious.
Also give us an update please! You're planning all of these cool trips for
next year but are you making progress in getting NX41CC back together?
You have got to be chomping at the bit
to fly her again. Sorry for being so nosey but more flying stories please!
Mike C. in Ohio
From: | Michael Perez <speedbrake(at)sbcglobal.net> |
Subject: | Renter's Insurance |
The time has come where I need to look into acquiring renter's insurance. I
would like some feedback on what organizations I should look into, ones I
should avoid, questions I should ask, answers I should receive, etc.- Tha
nks for your input.=0A=0A=0AIf God is your co-pilot...switch seats.=0AMicha
el Perez=0APietenpol HINT Videos=0AKaretaker Aero=0Awww.karetakeraero.com
Subject: | Re: Renter's Insurance |
From: | Steven Dortch <steven.d.dortch(at)gmail.com> |
Renters insurance for your plane, self, Car, House?
Steve D
> insurance. I would like some feedback on what organizations I should look
> into, ones I should avoid, questions I should ask, answers I should
> receive, etc. Thanks for your input.
> Michael Perez
> Karetaker Aero
Subject: | Re: Streamline plastic fairings |
Dave Rogers, the gentleman/aerodynamacist who answered about the prop
scallops, says round protrusions from aircraft (antennas or struts) are
very draggy. A round antenna has much more drag than a Blade antenna, even
though they have the same thickness. This is due to the turbulance created.
(remember you put them on so that they cut through the air, not
sideways.) Based on that, streamlining of struts and wires should add to
speed.
Be careful you may get so much speed that you cruse at VNE!
Blue Skies,
Steve "Unclassified" D
Michael,
What a coincidence, I just started flying again yesterday after getting my PPL
back in the '70's. I rented an LSA Tecnam (similar to a Cessna 150) and went
with a CFI. All went well but he did tell me that I would have to have renters'
insurance plus buy my own headset. Those are both new requirements for an
old-timer like me. Anyway, I got a quote from Avenco for about $200-$250 per
year and a glance at the EAA website showed their prices to be about the same.
Of course you can buy more liability for more $$. I'll probably go with EAA
as I'm a member and like to support them.
John Franklin
Prairie Aire 4TA0
Needville, TX
Sent: Sep 20, 2013 11:47 AM
Subject: Pietenpol-List: Renter's Insurance
The time has come where I need to look into acquiring renter's insurance. I would
like some feedback on what organizations I should look into, ones I should
avoid, questions I should ask, answers I should receive, etc. Thanks for your
input.
Michael Perez
Karetaker Aero
dont you saw this video?
http://www.youtube.com/watch?feature=youtube_gdata_player&v=ftq8jTQ8ANE
El 20/09/2013 14:00, "Steven Dortch" escribi=F3
speed.
Blue Skies,
Regarding the drag induced by round tubing, and the benefits of streamlining, check
out this article.
http://forums.matronics.com/viewtopic.php?t=50119&highlight=streamline
Bill C.
http://forums.matronics.com/viewtopic.php?p=408904#408904
From: | Ray Krause <raykrause(at)frontiernet.net> |
Do you think the 2" longer mount would apply to the Skyscout (single place Pietenpol),
too? Seems to me that it would. I would rather have some extra weight
out front than deal with the CG by moving the cabane struts back as my only option.
Ray Krause
SkyScout now on its gear, installing the fuel tank.
including A, C, and O-200.
>> Jack Phillips
>> NX899JP
> Adrian M
> Winnipeg, MB
> Canada
From: | "Charles Burkholder" <born2fly(at)abcmailbox.net> |
I have a renters insurance policy from avemco back from my flight
training. I pay $370 yr for minimum liability and $25,000 hull coverage.
I'm surprised at all they cover but they cover pretty much everything
with it. Taildraggers, low-time pilots etc
www.avemco.com/NonOwned/Features.aspx
CB
----- Original Message -----
Sent: Friday, September 20, 2013 12:47 PM
look into, ones I should avoid, questions I should ask, answers I should
Michael Perez
Karetaker Aero
It would need a prop carved out of a 2000 year old redwood, and Paul Bunyan
to carve it!( or a scaled up Dan Helsper)=0A-=0AShad=0A=0A=0A___________
_____________________=0AFrom: AircamperN11MS <Scott.liefeld(at)lacity.org>=0AT
o: pietenpol-list(at)matronics.com =0ASent: Thursday, September 19, 2013 11:31
AM=0ASubject: Pietenpol-List: Re: New Engine to replace Corvair=0A=0A=0A--
org>=0A=0AJust how big would a Pietenpol need to be to wear this engine? I'
m sure someone on this list is smart enough to scale this and even provide
dimensions. Yes this is a challenge. Would I fly it? Heck yes!!!! Would we
use a couple of old Ferris Wheels for the main wheels?=0A=0A--------=0AScot
t Liefeld=0AFlying N11MS since March 1972=0ASteel Tube=0AC-85-12=0AWire Whe
els=0ABrodhead in 1996=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp
://forums.matronics.com/viewtopic.php?p=408845#408845=0A=0A=0A=0A=0A=0A
Preferable to use to use the less effective method to resolve a CG
issue, eh?
Remember, lengthening the mount 2" only moves the weight of the engine
forward relative to datum. Moving the wing back 2" moves the weight of
the engine and the entire fuselage (and it's contents) forward. More
bang for your buck, less ant-eater.
Ryan
option.
> Thanks,
> Ray Krause
> Sent from my iPad
>>> Jack Phillips
>>> NX899JP
>> Adrian M
>> Winnipeg, MB
>> Canada
what about making a set of spacer spools between the firewall and mount to get
the same thing done if you ended up needing the weight shift? I realize that
would not necessarily mean the cowl would still work but it could allow for some
trial offset of thrust as well without a lot of extra work except longer bolt
to do some weighing.Raymond
http://forums.matronics.com/viewtopic.php?p=408912#408912
Ryan,
Your ant-eater comment really hit home! I have seen this on other Pietenpol planes
and don't really like it. Guess I will just follow the mount plans I received
with the Piet plans. Guess I could always figure a work-around if needs be.
Ray
PS. Somewhere I saw a picture of a Scout with an extended mount. If I can find
it, I will try to send it out.
> On Sep 20, 2013, at 3:31 PM, Ryan Mueller wrote:
> Preferable to use to use the less effective method to resolve a CG issue, eh?
> Remember, lengthening the mount 2" only moves the weight of the engine forward
relative to datum. Moving the wing back 2" moves the weight of the engine and
the entire fuselage (and it's contents) forward. More bang for your buck, less
ant-eater.
> Ryan
option.
>> Thanks,
>> Ray Krause
>> Sent from my iPad
for W&B issues. A Google search will confirm mount dimensions.
>>>> Jack Phillips
>>>> NX899JP
>>> Adrian M
>>> Winnipeg, MB
>>> Canada
This could be a viable work-around if I end up needing it.
Ray Krause
some trial offset of thrust as well without a lot of extra work except longer
bolt to do some weighing.Raymond
Subject: | =?utf-8?Q?4.jpg_640=C3=97480_pixels? |
Ryan,
This email may not work. But here is a picture of a loooong motor mount for
a heavy Cont engine.
Ray Krause
http://westcoastpiet.com/images/Sky%20Scout/images/4.jpg
