Pietenpol-Archive.digest.vol-my
October 02, 2013 - October 14, 2013
      white card stock to a least get some idea of what the color is.
      > Rick Schreiber
      > NX478RS
Date: Oct 02, 2013
Subject: Re: Scott or Maule tail Wheel
From: "bradandlinda tds.net" <bradandlinda(at)tds.net>
A thought on tail wheel/rudder spring tension adjustment. The springs should be adjusted so that wheel response should be matched with aerodynamic rudder response. For example, if the springs are too tight, during a crosswind take off the small amount of rudder pressure required to maintain runway centerline will not be enough to maintain heading with rudder alone, and the airplane will weather vane into the wind as the tail lifts off. Worse yet, on landing with correct amount of aerodynamic rudder, as the wheel touches down, the plane will veer sharply in the direction of the rudder input, and be very squirrley on the roll-out. Can you say ground loop? Brad Williams On Tue, Oct 1, 2013 at 6:20 PM, Dick N wrote: > > Guys > Don't use the inflatable tail wheel, I did use it and I replaced the inner > tube every other month. I just ordered a solid tail wheel. > Dick N. > > ----- Original Message ----- From: "taildrags" <taildrags(at)hotmail.com> > To: > Sent: Monday, September 30, 2013 11:30 PM > Subject: Pietenpol-List: Re: Scott or Maule tail Wheel > > >> >> Jim; >> >> A couple of observations on the solid 6" Scott vs. the pneumatic 8" >> tailwheel. First, weight. Most Piets tend to be tail-heavy, and according >> to the Aircraft Spruce shipping weights, there is more than a 2 lb >> difference between the 2000 and the 3200. That's a lot. Second, aircraft >> angle in the 3-point attitude. The Piet's FC10 airfoil can still be >> producing lift with 5.00 or 6.00 mains and a big tailwheel. The original >> configuration is with a tailskid, which put the tail down lower. The people >> who are flying with spoked wheels and a tailskid probably have the plane >> nearer to a full-stall in the 3-point attitude than airplanes like mine, >> and that gives you the slowest landing speed and the shortest landing roll. >> Lastly, you should try taxiing a Piet with the 6" solid Scott on grass or >> pavement. It will turn on a dime. Matter of fact, I have thought of >> changing the spring tension on the tailwheel on mine to reduce the >> sensitivity just a bit, although I do like to hav! >> e the ability to make it go precisely where I want it to go. Now I'll >> wait to hear from those who may be using the larger tailwheel to see if >> I've missed an even better deal than I have with the solid 6". >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=409532#409532> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: Re: ***FIRST FLIGHT ****
Date: Oct 02, 2013
Man Chris, what a GREAT report and accomplishment for both you and your tes t pilot. That guy did a great job flying and landing it even with the engi ne misses. Love the sound of the engine and looks of it and the overal pl ane is downright gorgeous. Way to go fella--nicely done! Mike C. in Ohio ________________________________________________________________________________
Date: Oct 02, 2013
Thanks Mike, I have to say your video which was the first thing I bought when I started this project and it gave me inspiration the whole time. Everytime I would get tired of the project, I would watch parts of your video and get all fired up again.....so seeing this project finished is partially because of your plane and video!! So thanks Man! [quote="michael.d.cuy(at)nasa.gov"]Man Chris, what a GREAT report and accomplishment for both you and your test pilot. That guy did a great job flying and landing it even with the engine misses. Love the sound of the engine and looks of it and the overal plane is downright gorgeous. Way to go fella--nicely done! Mike C. in Ohio > [b] -------- NX321LR ON THE FINAL PUSH!! Mitsubishi Powered Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=409695#409695 ________________________________________________________________________________
Subject: Re: Newbie Arkansas builder
Date: Oct 02, 2013
Just noticed I was asked a question in one of the replys of my previous post. I said I was big in size... well here's my best description. at last years pilot physical I stood 5 ft 10 in. tall and weighed 230 lbs... it is true I am sporting a little un-needed weight , might be a good inspiration to loose about 30 during the build. But in reality im not a big guy , just Arkansas stocky. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409696#409696 ________________________________________________________________________________
Subject: I'm honored!
Date: Oct 02, 2013
Wow Chris, that is truly and honor to hear that my video partially helped y ou to keep going on your project and FINISH it! I cannot believe how man y people have told me they've enjoyed that video and it really was develope d as a one-time, one builder (John Ficklin in Florida) project as John aske d me help him out. I had no idea the video would go to all parts of Europe , South Africa, Hawaii, Alaska, and Australia. You cats are crazy! H ere I was hoping the video tape would help put your wives to sleep early so you could go back out into the shop or basment and keep working until Jay Leno came on! I have to say that getting a ride in and seeing Frank Pavliga's Sky Gypsy b ack in the 80's changed my whole mindset about what kind of flying and plan e that I wanted. I thought I wanted a go-fast, closed cockpit. Frank's ride to me launched me into old-time aviation. I bought an Aeroncan Cham p with a church buddy Joe Tomasic in 1989 for $3,500 each and learned how t o fly tailwheel airplanes. Once Joe and I started flying the Aeronca with the door off I could NOT get enough of that open air feeling and view. (especially during takeoff and landing.) Once I had enough tailwheel time Frank was gracious enough to let me fly his Sky Gypsy and that sealed the deal. The Aeronca was sold wh en Joe retired and moved to Arizona an the Piet project got underway and I' ve never looked back. Fifteeen years later that sturdy, sturdy, and trusty little friend sitting in the hangar has never disapointed me and has given myself and many others great joy (and terror!:) over the years and still continues to do so. The second half of your adventure (like Rick Holland's) has just gotten sta rted Chris and we're thrilled for you! You've joined a very small group o f builders who actually made it to the finish line and how you're already o ff on the starting line of the most aviation fun you'll ever have! Mike C. in Ohio ________________________________________________________________________________
Date: Oct 02, 2013
One other good thing about building an airplane is it can help you with your motivation to stay on a diet plus maintaining good health in general if you are worried about keeping your medical. rh On Wed, Oct 2, 2013 at 11:40 AM, aviken wrote: > > Just noticed I was asked a question in one of the replys of my previous > post. I said I was big in size... well here's my best description. at > last years pilot physical I stood 5 ft 10 in. tall and weighed 230 lbs... > it is true I am sporting a little un-needed weight , might be a good > inspiration to loose about 30 during the build. But in reality im not a big > guy , just Arkansas stocky. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409696#409696 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Oct 02, 2013
Subject: Re: Poly fiber issues
On 10/1/2013 5:30 PM, taildrags wrote: > > Rick; I can empathize with you... I searched high and low for a match for the yellow on Scout and got pretty close with some, but the Poly-Tone yellow (which, it turns out, is almost exactly the same yellow as is used on highway centerline stripes) was always just a little different from what I was finding. > > I would go around the retail distributor and cut right to the source... Poly Fiber in Riverside, CA. I would be greatly surprised if they weren't willing and able to send you some actual color swatches of the paints that you are interested in. And in fact, I have a daughter living in Carlsbad and family in Fallbrook, not too far from Riverside, and if you needed to have someone go by Poly Fiber to pick up swatches and mail them to you, I'll bet that could be arranged too. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409619#409619 > > Thanks Oscar, I will get in touch with them and see what I can find out. The yellow I am looking for is just an organish yellow. I am trying to simulate, or at least get a little closer to the color of weathered fabric planes finished with orange shellac. I have a copy of Sport Aviation from 1987 with a picture of Ken Hyde's Grand Champion Jenny. Eventhough this was a new restoration, it was finished with clear dope, then orange shellac. The final color is what I would like to get closer to, yet still use a certified topcoat. I have attached a copy of the Jenny photo. Rick Schreiber ________________________________________________________________________________
Date: Oct 02, 2013
On 10/1/2013 6:35 PM, g. doe wrote: > Rick, sorry to hear about this, I have several shades of yellow left > over for different jobs, be glad to send them to you, I am sure the > labels are still clear, gary in Kennesaw, GA. > > Gary, Thanks for the response. I just sent out an email to the list trying to show what color I am looking for. What colors of Poly tone yellow do you have? Just a dab of the paint on white card stock would be all that is necessary for me. Rick Schreiber ________________________________________________________________________________
Subject: Re: I'm honored!
Date: Oct 02, 2013
Great comments Mike. For me, I also often put on your tape for inspiration...... Believe it or not I am looking fwd to the rainy fall ans winter here in Seattle - for some wonderful, warm days in the workshop....! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409704#409704 ________________________________________________________________________________
Subject: Pietenpol RC Model
Date: Oct 02, 2013
Hi all, As I mentioned previously I am building a 1:4.5 RC scale model of a Piet before building the 1:1 scale model. To this effect I am looking for some spruce offcuts. If anyone has a handful of 1x1s about 4 feet in length they want to sell, please let me know off-list. These can be the reject pieces you didn't use in your 1:1 Piet. Thanks in advance, Dave ________________________________________________________________________________
Date: Oct 02, 2013
Jake; Now that is one beautiful, graceful fuselage. Nice work. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409714#409714 ________________________________________________________________________________
Date: Oct 02, 2013
Subject: Re: Pietenpol RC Model
Also, Aircraft Spruce sells spruce cuttoffs - http://www.aircraftspruce.com/catalog/wppages/bargainbag_spruce.php On Wed, Oct 2, 2013 at 2:22 PM, David wrote: > Hi all, **** > > ** ** > > As I mentioned previously I am building a 1:4.5 RC scale model of a Piet > before building the 1:1 scale model.**** > > ** ** > > To this effect I am looking for some spruce offcuts. If anyone has a > handful of 1x1s about 4 feet in length they want to sell, please let me > know off-list. These can be the reject pieces you didn=92t use in your 1: 1 > Piet.**** > > ** ** > > Thanks in advance, Dave**** > > * > =========== =========== =========== =========== > * > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: first little step
Date: Oct 02, 2013
finally got started and built one half of my work table. Why is I can figure in my head how many 2x4's I will need , then find out I need twice as many! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409725#409725 ________________________________________________________________________________
Subject: ###Second Flight####
Date: Oct 02, 2013
The second flight went much smoother and incident free....I adjusted the mixture control to about midway towards lean and wired it in place....did several static pulls and it sounded really good and smooth. We took off and flew around the patch for about 15 min problem free and very smooth running.!!! So we are real close to getting the bugs worked out. I am looking for advice as far as amount of force needed to keep the nose up. I think I may have made a mistake by making the center lift struts equal length with the riblett airfoil hence not giving me enough incidence. Has anyone else have a nose heavy situation and how did you fix it? Anyone put shims in the horizontal stabilizer ? -------- NX321LR ON THE FINAL PUSH!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409726#409726 ________________________________________________________________________________
Subject: Re: ###Second Flight####
Date: Oct 02, 2013
Chris, we? Congratulations on some outstanding work! Sent from my iPad Jack Textor On Oct 2, 2013, at 7:38 PM, "Chris Rusch" wrote: > > The second flight went much smoother and incident free....I adjusted the mixture control to about midway towards lean and wired it in place....did several static pulls and it sounded really good and smooth. We took off and flew around the patch for about 15 min problem free and very smooth running.!!! So we are real close to getting the bugs worked out. > I am looking for advice as far as amount of force needed to keep the nose up. I think I may have made a mistake by making the center lift struts equal length with the riblett airfoil hence not giving me enough incidence. Has anyone else have a nose heavy situation and how did you fix it? Anyone put shims in the horizontal stabilizer ? > > -------- > NX321LR > ON THE FINAL PUSH!! > Mitsubishi Powered > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409726#409726 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 02, 2013
"We"meaning me on the ground watching my test pilot having all the fun....it's a joint effort! -------- NX321LR ON THE FINAL PUSH!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409731#409731 ________________________________________________________________________________
Date: Oct 02, 2013
Chris; first of all, you need to change your signature line. It still says "On The Final Push". Second, the need to hold back stick is unusual in these airplanes... usually they are tail heavy. Most of the posts that you'll find in the archives talk about *adding* incidence to the horizontal stabilizer, not *decreasing* incidence. You're breaking new ground here with the Riblett airfoil and equal-length cabanes. Ideally, of course, you would increase the wing incidence by lengthening the front cabanes a smidgen. However, that would probably be a major effort and would probably also involve the lift struts, unless you have threaded fork ends on them that would permit you to lengthen the front struts to accommodate more wing incidence. You could probably play with the horizontal tail, but I don't think it will be too easy at this point either. You could add more nose-up biasing trim on the elevator, but that will increase drag and won't address the real issue, which sounds like not enough wing incidence. I'll have to go back to look at P.F. Beck's testing of the Riblett to see what he says about how they set it. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409738#409738 ________________________________________________________________________________
Date: Oct 02, 2013
Center lift struts? You mean the cabanes? On Wed, Oct 2, 2013 at 6:38 PM, Chris Rusch wrote: > rmdinfo(at)rmdbenders.com> > > The second flight went much smoother and incident free....I adjusted the > mixture control to about midway towards lean and wired it in place....did > several static pulls and it sounded really good and smooth. We took off and > flew around the patch for about 15 min problem free and very smooth > running.!!! So we are real close to getting the bugs worked out. > I am looking for advice as far as amount of force needed to keep the nose > up. I think I may have made a mistake by making the center lift struts > equal length with the riblett airfoil hence not giving me enough incidence. > Has anyone else have a nose heavy situation and how did you fix it? Anyone > put shims in the horizontal stabilizer ? > > -------- > NX321LR > ON THE FINAL PUSH!! > Mitsubishi Powered > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409726#409726 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Oct 02, 2013
Chris Where in the range is your CG for these test flights? On Wed, Oct 2, 2013 at 8:41 PM, taildrags wrote: > > Chris; first of all, you need to change your signature line. It still > says "On The Final Push". Second, the need to hold back stick is unusual > in these airplanes... usually they are tail heavy. Most of the posts that > you'll find in the archives talk about *adding* incidence to the horizontal > stabilizer, not *decreasing* incidence. You're breaking new ground here > with the Riblett airfoil and equal-length cabanes. > > Ideally, of course, you would increase the wing incidence by lengthening > the front cabanes a smidgen. However, that would probably be a major > effort and would probably also involve the lift struts, unless you have > threaded fork ends on them that would permit you to lengthen the front > struts to accommodate more wing incidence. You could probably play with > the horizontal tail, but I don't think it will be too easy at this point > either. You could add more nose-up biasing trim on the elevator, but that > will increase drag and won't address the real issue, which sounds like not > enough wing incidence. I'll have to go back to look at P.F. Beck's testing > of the Riblett to see what he says about how they set it. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409738#409738 > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Oct 03, 2013
FYI The CG is at 15.6 from leading edge for these flights -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409755#409755 ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Oct 03, 2013
Chris, First off, Congats on the second flight. Secondly, It sounds like you are describing a nose heavy airplane. I looked again at the video's you posted. The plane looks to be flying in a level attitude. It also looks like your wing is moved back a little. I would perform another W&B to determine exactly where it is with the pilot who is currently flying it. Then recalculate the W&B with you as pilot. The man fling it right now doesn't look to be very big. A twenty pound heavier pilot would probably correct the problem you are describing. Try putting rocks in the pilots pockets without him looking and see if he comes back and tells you that the plane is fine now. Happy Landings, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409756#409756 ________________________________________________________________________________
Date: Oct 03, 2013
Here is a video from last night.....pretty uneventful which is good!! http://youtu.be/WpnyU_sC85A -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409765#409765 ________________________________________________________________________________
Date: Oct 03, 2013
Congratulations Chris. Looks and sounds great. The sputtering just adds a 'period realism' hahaha Seriously though I'm glad it was nothing more than that. It is nerve wracking flying something that doesn't have a bunch of hours behind it to give you some reassurance. I just completed my first couple of hours after a total engine rebuild, and watching your video gave me the willies for a second time. Many happy hours of flying to you. Joe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409767#409767 ________________________________________________________________________________
Date: Oct 03, 2013
Chris: How was the air speed ? When I add power the stick pressure changes, I tried equal lengths on cabanes and ended up to be universal , attached a bungee from the seat to the stick with a slide and lock. problem solved. She still flies well at 78 MPH. Or 68 MPH. Congratulations Pieti Lowell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409783#409783 ________________________________________________________________________________
Date: Oct 03, 2013
Airspeed was 70ish mph -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409784#409784 ________________________________________________________________________________
Date: Oct 03, 2013
Hi Dick, I read you post about spring tension with great interest.... Still being a newbie with my Piet ... I find that I am the situation you describe in your post. Doing calm wind full power takeoffs on pavement, - the Piet tracks true. But the moment the tail starts flying - the Piet wants to veer right -- takes a lot of left rudder to get it back on track. I associate that with P-Factor generated by my O-200. Does this sound right? Wheel landings on calm wind days seem to be the same process in reverse. I wheel in at 60 with 1200 rpm. Once the wheels are planted - i slowly back off on the power and allow the tail to just come down on its on. However - the moment the tail wheel touches - its the rudder dance. I stressed 'calm wind days' as I am not ready for cross winds in the Piet just yet. Looking at my tail wheel (see attached) I don't have a castering tail wheel - so I am not sure that spring tension is my problem? Are your comments based on the spring tension with a castering tail wheel? I read up on tail wheel castering on a few other forums ... seems there are a number of pilots that take the springs/cables off and free-wheel using brakes to steer. Anybody free wheeling with their Piet's? -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409797#409797 Attachments: http://forums.matronics.com//files/n687mb_tail_wheel_3619_627.jpg ________________________________________________________________________________
Date: Oct 03, 2013
Jim Yes that sounds pretty true, the one thing to check is are your rudder and tail wheel aligned when the plane is sitting on the ground. The other thing to check is the wing trim, bring the tail up to level and you take a digital level and measure the angle at the cabane struts on both sides then check at the wing tips make sure that the readings are .5 degrees less than at the base. Next question, yes I have a castoring tail wheel it is a spring type, I think the springs are very important. Dick N. ----- Original Message ----- From: "Fun2av8" <iflyga(at)fun2av8.com> Sent: Thursday, October 03, 2013 8:48 PM Subject: Pietenpol-List: Re: Scott or Maule tail Wheel > > Hi Dick, > > I read you post about spring tension with great interest.... > > Still being a newbie with my Piet ... I find that I am the situation you > describe in your post. Doing calm wind full power takeoffs on > avement, - the Piet tracks true. But the moment the tail starts flying - > the Piet wants to veer right -- takes a lot of left rudder to get it back > on track. I associate that with P-Factor generated by my O-200. Does this > sound right? > > Wheel landings on calm wind days seem to be the same process in reverse. > I wheel in at 60 with 1200 rpm. Once the wheels are planted - i slowly > back off on the power and allow the tail to just come down on its on. > However - the moment the tail wheel touches - its the rudder dance. > > I stressed 'calm wind days' as I am not ready for cross winds in the Piet > just yet. > > Looking at my tail wheel (see attached) I don't have a castering tail > wheel - so I am not sure that spring tension is my problem? > > Are your comments based on the spring tension with a castering tail wheel? > > I read up on tail wheel castering on a few other forums ... seems there > are a number of pilots that take the springs/cables off and free-wheel > using brakes to steer. > > Anybody free wheeling with their Piet's? > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper, VA KCJR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409797#409797 > > > Attachments: > > http://forums.matronics.com//files/n687mb_tail_wheel_3619_627.jpg > > > ________________________________________________________________________________
Date: Oct 04, 2013
Subject: Re: bungees
Have you checked your wheels for toe out? Had a Cessna 150 that was slightly tow in after a tire change. Push it back into the hangar and it squatted, pull it out and it stood up tall. I think my project may be very slightly toe in. seems to do the same thing. Blue Skies, Steve D On Mon, Sep 30, 2013 at 7:48 PM, GNflyer wrote: > > well I made another fun flight in my GN-1 this afternoon about 45 minutes > before dark. followed by the smoothest landing I have even made in it. > (could be partly due to a very weak bungee on the right side. by the time I > turned at the hangar and shut down the leg was splayed out pretty bad. I > had thought I would go to coil springs on them but as the time to fly just > has not been that much and I feel pretty comfortable with the Cub gear as > it is. I just need to find the lowest price but timely delivery source and > get some in and change them.having never done it I am not at all sure what > I need.I seem to remember 1080? as a strength rating but that may have been > on my old Tri-pacer I used to have.any good recommendations? I looked up > Chief aircraft and have ordered from them in the past but figured this > would be a good place to ask first. thanks. Raymond > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409519#409519 > > ________________________________________________________________________________
Date: Oct 04, 2013
Jim, What you are describing regarding take offs and landings is exactly how it should feel. The airplane is doing what it is supposed to do. There is nothing to fix. I hate to see you spend a bunch of time trying to fix something that is not broken. That said, get someone who is familiar with flying piets or cubs to to verify that the airplane is fine. If there is something truly wrong then he should be able to head you in the proper direction. The airspeeds you are giving are fast also. I suspect that either the indicator is not reading correctly or you are just landing it too fast. Have you gone out and done any slow flight work or stalls with the plane. See what airspeed it indicates when it stalls power off. If you are uncomfortable with doing that, I again say have someone else fly it for input. That airplane has been flying for many years. it is hard for me to believe that it as poor handling qualities. I am not trying to sound a rough on you, but I don't want to see you spend time fixing something that is not broken. Worse yet, have you change something while experimenting and hurt yourself or the plane. Very respectfully, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409826#409826 ________________________________________________________________________________
Date: Oct 04, 2013
Chief aircraft is where I get my bungee's from. Is there anything in your logbook that indicates a part number for you? There are a lot of different sizes to choose from. Mine seem to last 3 to 4 years. Then they start sagging. Good luck find the proper ones. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409828#409828 ________________________________________________________________________________
Date: Oct 04, 2013
there definitely is a little. I tried to correct it while I was finishing up assembling the gear on the fuse early on. did get it better but it does have some. I have always figured a little toe out is preferable to toe In on a conventional gear. but the bungees are definitely failing. after removing the strut t was very evident that the outer one had several places tat are shrunken in a lot under the wrapping have new ones coming now from A/S and hope in the next couple days to get a tool rigged up to install them. D.J. had them put on several years ago and they sat in the Arizona heat quite a while before I bought the project and I have had it at least 6 or 7 years or more. it is amazing how time passes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409829#409829 ________________________________________________________________________________
Date: Oct 04, 2013
Sounds like you are on the right track. You are correct about the toe out. The wheels should either be straight or a little toed out. If toed in the plane will ground loop very easily. Not a good thing. Let us know how it goes. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409830#409830 ________________________________________________________________________________
Date: Oct 04, 2013
Going without tailwheel control cables is not unheard of, I believe the new SuperStol is designed that way, ground steering only with rudder and brakes - http://justaircraft.com/page.php?45. Have no idea how a Piet behaves without the cables. rh On Thu, Oct 3, 2013 at 7:48 PM, Fun2av8 wrote: > > Hi Dick, > > I read you post about spring tension with great interest.... > > Still being a newbie with my Piet ... I find that I am the situation you > describe in your post. Doing calm wind full power takeoffs on pavement, - > the Piet tracks true. But the moment the tail starts flying - the Piet > wants to veer right -- takes a lot of left rudder to get it back on track. > I associate that with P-Factor generated by my O-200. Does this sound > right? > > Wheel landings on calm wind days seem to be the same process in reverse. > I wheel in at 60 with 1200 rpm. Once the wheels are planted - i slowly > back off on the power and allow the tail to just come down on its on. > However - the moment the tail wheel touches - its the rudder dance. > > I stressed 'calm wind days' as I am not ready for cross winds in the Piet > just yet. > > Looking at my tail wheel (see attached) I don't have a castering tail > wheel - so I am not sure that spring tension is my problem? > > Are your comments based on the spring tension with a castering tail wheel? > > I read up on tail wheel castering on a few other forums ... seems there > are a number of pilots that take the springs/cables off and free-wheel > using brakes to steer. > > Anybody free wheeling with their Piet's? > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper, VA KCJR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409797#409797 > > > Attachments: > > http://forums.matronics.com//files/n687mb_tail_wheel_3619_627.jpg > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Oct 04, 2013
Since you are building an RC version of your Piet - I thought you might get a kick out of my RC Piet. The RC Piet is from Stevens Aero and was built by Paul Stamison. Mr. Jin Woo provided the decals. The front and rear cockpit instruments in the model match the ones in my Piet -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409841#409841 Attachments: http://forums.matronics.com//files/rc_mr_sam_with_n687mb_3661_258.jpg http://forums.matronics.com//files/rc_mr_sam_with_n687mb_3663_417.jpg http://forums.matronics.com//files/rc_mr_sam_with_n687mb_3661_418.jpg http://forums.matronics.com//files/rc_mr_sam_with_n687mb_3661_186.jpg http://forums.matronics.com//files/rc_mr_sam_with_n687mb_3658_198.jpg ________________________________________________________________________________
Date: Oct 04, 2013
Chris; With the standard CG envelope being 15"-20" aft of wing leading edge, flying it with the CG at 15.6" aft is definitely going to be nose heavy. My airplane has a 16 gallon fuel tank in the nose and when I'm flying solo with full fuel, I have to hold some back stick too. Where is the fuel tank in Two One Lima Romeo? If it's in the nose and you're doing test flights with full fuel, you might try draining off half the tank and flying it again. And unless it is requiring considerable back stick to hold it straight & level, or you have a wing centersection fuel tank, it doesn't sound like you have any big adjustments to make. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409846#409846 ________________________________________________________________________________
Date: Oct 04, 2013
Subject: Higher Useful Load
Hey everyone! I've been a lurker on this mailing list for a long time, but haven't really said much. I'm considering building a Pietenpol and the only thing holding me back at this point is the useful load. It seems the average useful load is about 450 lbs. I'd REALLY like to get 500-550 useful. I'll be using an O-200 to power mine. Has anyone designed a slightly larger wing or some-such to allow for a higher useful load? Thanks! John ________________________________________________________________________________
Subject: Re: Higher Useful Load
Date: Oct 04, 2013
John; It's not just a matter of getting enough lift and thrust to get the airplane to fly at a higher gross weight. The design loading for the wing spars, wing attach fittings and bolts, lift struts, strut attachment fittings and bolts, landing gear, and other things are affected by an increase in weight. If you think about it, the Normal Category load limit is +3.8G so if you increase the gross weight by 100 lbs, the stresses have to be analyzed for 3.8 times that (actually, 1.9 times that for each wing since there are 2 wings). Not that it can't be done, but you've got to look at the whole picture and not just adding more wing area or engine thrust to get the additional weight off the ground. This topic has come up fairly often, given that most people today are a little larger in weight and stature than Mr. Pietenpol was. In my case it's not a factor since I'm 5'-9" and weigh about 152 in summer clothes, but I think I'm the exception. In fact, my airplane (empty weight 633) is right at gross with full fuel and two FAA-standard people aboard (175 lbs apiece). I haven't heard a lot of excitement on this list about structurally and aerodynamically analyzing the Air Camper and re-engineering it for a higher gross weight. It is what it is. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409853#409853 ________________________________________________________________________________
Date: Oct 04, 2013
> Not that it can't be done, but you've got to look at the whole picture and not just adding more wing area or engine thrust to get the additional weight off the ground. Your correct here and very good advise. Unfortunately people do what you are saying without any total engineering being looked at. Lots of Piet's flying around that way with increased loads on the total airframe lowering the safety factor, without know what it is. I would assume some are under the 3.8G's limits ..... and the limits are there for a reason. Build a Piet as a Piet. If you what it to do something different, look for an other design. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409859#409859 ________________________________________________________________________________
From: "A Future Pilot" <afuturepilotis(at)gmail.com>
Date: Oct 04, 2013
OK, so redesigning it is out...but is the published useful load accurate for an O-200? About what useful load can I expect, since I'm assuming I'll have more than what I'd have with a Model A. Doing some searching through this list, I've seen people talk about 1250 or so gross with an O-200. Is that realistic? Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409864#409864 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Oct 04, 2013
John, I think that you are looking at this backwards. You seem to be asking, "If I add an O-200, how much more can I add?" I think the better question is, "My aircraft can be comfortably be registered and operated with a gross weight of X. What are the best practices that I can use to build light as safely possible in order to leave me as much useful load as possible." The design weight is set for all the reasons previously discussed. So instead of asking how much you can add, figure out what your empty weight will be, then your useful load is left. It seems to me that often people like the Pietenpol, but want to change it to do or be X, Y, or Z on their desires list. There are many great designs out there, and if the Piet cannot quite give you what you want, then keep looking. You will be much happier in the end. My $.02 -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409869#409869 ________________________________________________________________________________
Date: Oct 04, 2013
58tl has an O200 and has a gross weight of 1320. Yes it does get off the ground, and yes carrying a little more speed on approach feels fine. Steve > On Oct 4, 2013, at 3:45 PM, "A Future Pilot" wrote: > > > OK, so redesigning it is out...but is the published useful load accurate for an O-200? About what useful load can I expect, since I'm assuming I'll have more than what I'd have with a Model A. Doing some searching through this list, I've seen people talk about 1250 or so gross with an O-200. Is that realistic? > > Thanks! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409864#409864 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 04, 2013
hi guys & gals, i looked at the video and i noticed that the elevator did not have the usual 3 to 4 degree droop typical of piets in flight, in fact it was pointed up 2 or 3 degrees. so going back and looking at my notes it shows that the riblet airfoil calls for a 1" longer cabane in front. however, the riblet has the same 2 degree angle of incidence in relation to the top longeron as the standard piet airfoil.on account of the fact that the riblet front spar is 1 inch lower than the rear in relation to the chord line. so, chris' piet has 1 degree less than called for in the plans. ergo, all things being more or less equal from the standpoint of the air blowing over the plane the horizontal stabilizer is one degree off in relation to the wing. the riblet airfoil has almost the same pitching moment as the piet airfoil so it should trim up the same.anyway thats my 5 cents. ________________________________________________________________________________
Date: Oct 04, 2013
Thanks everyone! I think my initial question wasn't really what I meant to be asking. The way I should have worded it is "What is the highest gross weight that the pietenpol can safely operate with when using an O-200 engine. Also, are there any wing or other section redesigns that would be beneficial." So, with that in mind, would y'all say that an empty weight of around 750 (or hopefully less) is reasonable, and a gross weight of about 1250 is safe with an O-200? I plan on building as light as possible (including using a steel tube fuselage), but other than just building light, there aren't any modifications to the original design that are recommended? (I have looked at Keri-Anne's modifications. I think I may go with the no-gap ailerons and steerable tail wheel. Have any of you had experience with those?) Thanks again everyone! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409874#409874 ________________________________________________________________________________
Date: Oct 04, 2013
John, Leave off the "with an O-200" and your question is more accurate, in my opinion. The question should be "what is the max gross weight allowed, and what is a reasonable empty weight." period. Whether or not it is an O-200, a Rotec, am A-65, a Model T or any other engine is more a factor in Weight and Balance computations. Too heavy an engine and is placement is going to affect the CG and thus the flyability of your final product even if your airplane is within a weight range. $.02 more. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409875#409875 ________________________________________________________________________________
Date: Oct 04, 2013
John, Leave off the "with an O-200" and your question is more accurate, in my opinion. The question should be "what is the max gross weight allowed, and what is a reasonable empty weight." period. Whether or not it is an O-200, a Rotec, am A-65, a Model T or any other engine is more a factor in Weight and Balance computations. Too heavy an engine and is placement is going to affect the CG and thus the flyability of your final product even if your airplane is within a weight range. $.02 more. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409876#409876 ________________________________________________________________________________
Date: Oct 04, 2013
If by "no-gap ailerons" you mean installing the ailerons using full-span piano hinges, my guess is that the majority of Piets that are being constructed today are using that method and a good number of flying Piets have them as well. My airplane has them. I think everyone agrees that they improve control responsiveness. Same for your question about steerable tailwheels. I think I can safely say that tail skids are in the minority and fixed or free-castoring tailwheels are too. Having the tailwheel steerable improves ground handling but it does add an extra set of cables and control horns to the tail of the airplane. Cutting into your useful load ;o) -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409883#409883 ________________________________________________________________________________
Date: Oct 04, 2013
I checkef the tail wheel alignment against the rudder and found that the tail wheel is around 3 degrees off center. Looking at how far it is off explained those nasty little side trips that the Pete wants to take when the tail wheel touches down. I need to put turnbuckles on the cables that attach to the tail wheel so I can center the tail wheel. -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409888#409888 ________________________________________________________________________________
Date: Oct 05, 2013
Let's assume that your plane is strong and won't break, So structural matters aside: Increased weight decreases the speed (not angle) at which your aircraft stalls. The stall speed increases incrementally once a certain weight is passed. Add to increased weight, an aft CG and the increase in stall speed in a bank, and you can have a stall speed that is close to the speed you turn base! On the extreme end of this is envelope, a very overloaded aircraft cruses just a few knots above the stall speed. Altitude also affects this. Thus the U2 flight envelope at altitude was cruse and top speed were within 2-4 knots of stall speed. Y'all be careful out there. Steve D On Fri, Oct 4, 2013 at 12:26 PM, taildrags wrote: > > John; > > It's not just a matter of getting enough lift and thrust to get the > airplane to fly at a higher gross weight. The design loading for the wing > spars, wing attach fittings and bolts, lift struts, strut attachment > fittings and bolts, landing gear, and other things are affected by an > increase in weight. If you think about it, the Normal Category load limit > is +3.8G so if you increase the gross weight by 100 lbs, the stresses have > to be analyzed for 3.8 times that (actually, 1.9 times that for each wing > since there are 2 wings). Not that it can't be done, but you've got to > look at the whole picture and not just adding more wing area or engine > thrust to get the additional weight off the ground. > > This topic has come up fairly often, given that most people today are a > little larger in weight and stature than Mr. Pietenpol was. In my case > it's not a factor since I'm 5'-9" and weigh about 152 in summer clothes, > but I think I'm the exception. In fact, my airplane (empty weight 633) is > right at gross with full fuel and two FAA-standard people aboard (175 lbs > apiece). I haven't heard a lot of excitement on this list about > structurally and aerodynamically analyzing the Air Camper and > re-engineering it for a higher gross weight. It is what it is. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409853#409853 > > ________________________________________________________________________________
Date: Oct 05, 2013
As a builder you are the person who states the gross weight. I would not list over 1320 pounds to stay in the Light sport category. But your official gross weight decision is your decision. The experienced and long considered conventional wisdom of the Pietenpol community is that somewhere around 1230-1280 pounds is the limit. I have not done the math to a flaw but I think my useful load is around 550 pounds. Minus fuel will allow me to carry fuel and two of pax and stuff. If I fill the main tank I am OK but when I fill the wing tank as well, I have to get skinnier passengers. The easiest way for me to be able to carry a passenger is to lose weight. I plan on losing about 16 more pounds to get to 180. That will allow more forward CG and for larger passengers. Blue Skies, Steve D. On Fri, Oct 4, 2013 at 11:05 AM, John Ackerman wrote: > Hey everyone! > > I've been a lurker on this mailing list for a long time, but haven't > really said much. I'm considering building a Pietenpol and the only thing > holding me back at this point is the useful load. It seems the average > useful load is about 450 lbs. I'd REALLY like to get 500-550 useful. I'll > be using an O-200 to power mine. Has anyone designed a slightly larger wing > or some-such to allow for a higher useful load? > > Thanks! > John > > * > > * > > ________________________________________________________________________________
Date: Oct 05, 2013
@nightmare I meant climb performance and stall speed, not maximum structural limitations. I realized that that's probably where the confusion was coming from. So it sounds like 1250 gross is safe, and if I build to 750 or lighter, that'll give me a solid 500 pounds useful load, which should be plenty! Thank you all for your help! Now I just gotta save up some money to buy the plans :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409926#409926 ________________________________________________________________________________
Subject: Re: Engine Selection
Date: Oct 05, 2013
Just today I heard of someone with an O-320 on theirs here in KY. I was told he had done a lot of modifications to it to allow for that. I'm not sure if he's on this mailing list, or if any of you have heard anything about it. But generally a Corvair or O-200 is about as big as makes sense for a Pietenpol. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409930#409930 ________________________________________________________________________________
Date: Oct 06, 2013
Got my cords in from A/S in 3 days from the day I called ill they were in the mailbox. sure can't complain there. used a modified version of the EAA video where they used an engine hoist ad rope to stretch them.except I have a tall hi-lift farm jack. clamped the base to my work bench and tacked a lug to the table right in front of it's base and pinned the bottom end to it with a 3/8 bolt and ran a rope to the bungee and jacked it up till either the rope would break or I could pry he cord over the lugs. load tested some old ropes that way till I got them all on. after clamping the top end of the strut in my vise it didn't take too long to pull the rope back out from between the logs and cord.actually went fairly well and no blood spilled. nice change from many of my projects.now to finish replacing the leaking oil pan and change out oil coolers and see what progress I have made. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409939#409939 ________________________________________________________________________________
Subject: Re: Mr Sam - Pietenpol N687MB
Date: Oct 06, 2013
Weight & Balance Data ============== Does anyone have a CG Envelope diagram for a Piet? -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409943#409943 Attachments: http://forums.matronics.com//files/sample_wandb_graph_107.png ________________________________________________________________________________
Date: Oct 06, 2013
Aux Fuel Tank ======== Is anyone using an portable auxiliary fuel tank? I fly with a bunch of cubs to go get a $100 hamburger. The Cubs I fly with carry more than 13 gals of fuel and as far as I can tell - burn less per hour than I do. I get a little nervous when the gas gauge gets down to 1/4 tank. I think a simple answer might be a portable aux tank in the front seat that would hold an additional 7-10 gallons . My IA says the installation would be a simple gravity feed as long as the Aux tank was higher than the carburetor. Anyone done this? -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409944#409944 ________________________________________________________________________________
From: =?utf-8?B?dG1icmFudEBtc24uY29t?= <tmbrant(at)msn.com>
Subject: =?utf-8?B?Q2VudGVyIHNlY3Rpb24gaGFsZiBtb29u?
Date: Oct 06, 2013
V29uZGVyaW5nIGlmIGFueW9uZSBoYXMgYW55IHBob3RvcyBvZiB0aGUgYnVpbGQgdXAgb2YgdGhl IGNlbnRlciBzZWN0aW9uIGN1dG91dCAoaGFsZiBtb29uKS4gIEknbSBhYm91dCB0byBkbyB0aGlz IGJ1dCBoYXZpbmcgdHJvdWJsZSB2aXN1YWxpemluZyB0aGUgcHJvY2Vzcy4KClRoYW5rcywKClRv bSBCLgoKU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgUGhvbmU ________________________________________________________________________________
Subject: Center section half moon
Date: Oct 06, 2013
Several of Mike Cuy's http://westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy.htm Several of Gary Boothe's http://westcoastpiet.com/images/Gary%20Boothe/wing.htm Jack Textor too http://westcoastpiet.com/images/Jack%20Textor/wing.htm Rick Holland as well http://westcoastpiet.com/images/Rick%20Holland/pictures.htm There are more but I don't have time to search for them Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of tmbrant(at)msn.com Sent: Sunday, October 06, 2013 11:34 AM Subject: Pietenpol-List: Center section half moon Wondering if anyone has any photos of the build up of the center section cutout (half moon). I'm about to do this but having trouble visualizing the process. Thanks, Tom B. Sent from my Verizon Wireless Phone =EF=BD~=EF=BD=03 ________________________________________________________________________________
Date: Oct 06, 2013
Future Pilot, The best way to increase your useful load is to build lighter. If you constantly think about how to build it lighter throughout the build, you'll be able to lift whoever you put in there. Mine came in at 626lbs. It could have been lighter and I know where my extra weight is but there's nothing I can do about it now. I have an A-65 and have probably flown with a passenger on 500-600 flights. I' ve never felt concerned on climbout. I've had passengers up to about 260lbs. Don't know that a much larger person could be shoehorned in the front. What I have noticed is with a larger passenger the bottom seems to drop out a little quicker on landing. It doesn't seem to really like the higher weights. That's why the best way to increase useful load is to build light and not focus so much on higher horsepower. Larger engines seem to add more weight than just the engine itself. Larger fuel tank, maybe another fuel tank, starter, generator, adding more stuff because you think it's okay since you have a larger engine, etc. Just try to build a Piet for what it is, a beautifully light, simple, and graceful early 1930's design. You will not be disappointed! Absolutely love mine!! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409961#409961 ________________________________________________________________________________
Subject: Progress on SkyScout...
Date: Oct 06, 2013
> From: Ray Krause <raykrause(at)frontiernet.net> > Date: October 6, 2013 at 1:14:37 > Gary, > > Here are a few photos of the fuselage and mount jig. It's on the gears, th e tank is in place and the firewalls are ready. Notice the mechanical toe br akes! Just like the big boys, don't know how they will work? The tail wheel i s a copy of the Sonex setup. Uses 1/2" titanium rod. Pretty light. I may ha ve to re-make the wheel castor to raise the tail a few more inches. All cont rol cables have been run and seem to work correctly. Gear springs may have t o be reduced in length, depending on what happens when the motor and the res t of the garbage is added. > > When I finish the motor mount, I will have to work on the panel. No electr ic wiring required! I will work on the A-65 this winter. > > Thanks, > > Ray Sent from my iPad ________________________________________________________________________________
Subject: Re: Center section half moon
Date: Oct 06, 2013
Hi Tom Do you want to see mine, its at my hangar. Dick N. ----- Original Message ----- From: tmbrant(at)msn.com To: pietenpol-list(at)matronics.com Sent: Sunday, October 06, 2013 1:34 PM Subject: Pietenpol-List: Center section half moon Wondering if anyone has any photos of the build up of the center section cutout (half moon). I'm about to do this but having trouble visualizing the process. Thanks, Tom B. Sent from my Verizon Wireless Phone =EF=BD~=EF=BD=03 ________________________________________________________________________________
Date: Oct 07, 2013
Doing a moon cutout reduces wing area, hence why Bernie used the center flap. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409982#409982 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Oct 07, 2013
But it does increase visibility, particularly during tight turns... Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of womenfly2 Sent: Monday, October 07, 2013 7:12 AM Subject: Pietenpol-List: Re: Center section half moon Doing a moon cutout reduces wing area, hence why Bernie used the center flap. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409982#409982 ________________________________________________________________________________
Subject: Re: Progress on SkyScout...
Date: Oct 07, 2013
Wow Ray! That is so cool. I love it. I've been wondering how your projec t is going. It looks really great. Mike Groah Sent from my iPad > On Oct 6, 2013, at 7:45 PM, Ray Krause wrote: > > > >> From: Ray Krause <raykrause(at)frontiernet.net> >> Date: October 6, 2013 at 1:14:37 > >> Gary, >> >> Here are a few photos of the fuselage and mount jig. It's on the gears, t he tank is in place and the firewalls are ready. Notice the mechanical toe b rakes! Just like the big boys, don't know how they will work? The tail wheel is a copy of the Sonex setup. Uses 1/2" titanium rod. Pretty light. I may h ave to re-make the wheel castor to raise the tail a few more inches. All con trol cables have been run and seem to work correctly. Gear springs may have t o be reduced in length, depending on what happens when the motor and the res t of the garbage is added. >> >> When I finish the motor mount, I will have to work on the panel. No elect ric wiring required! I will work on the A-65 this winter. >> >> Thanks, >> >> Ray > > > > > > > > > > > > > > Sent from my iPad ________________________________________________________________________________
Date: Oct 07, 2013
Tom...and anyone else whom may be interested...I just updated my website an d have an all new, more user friendly photo gallery with added pictures. In there, you can go to the CENTER SECTION album and look at how I made my C. S. cut out.- The filler material for the cut out, the blocks that you wil l see,-is balsa wood . These were-thinner pieces laminated together and then cut to fit.- The rest of the cutout is made with spruce and plywood .=0A=0AIf God is your co-pilot...switch seats.=0AMichael Perez=0APietenpol HINT Videos=0AKaretaker Aero=0Awww.karetakeraero.com ________________________________________________________________________________
Date: Oct 07, 2013
Jim; I have thought about creating that W&B envelope diagram for my airplane. You must realize, though, that unlike certified aircraft which are all alike, experimentals are all different and one envelope diagram will not serve for all. On the matter of aux tanks, you might consider a temporary setup rather than a fixed aux tank and piping, which would permanently add to your empty weight. There are many different configurations of blow-molded plastic fuel tanks for boats (for example), and you could secure one in the front cockpit for longer flights or extra margin. The rubber tubing with a squeeze bulb could be used to hand-transfer fuel from the aux tank up to the main tank. Most of those molded fuel tanks for boats hold enough to add about an hour of flight time. Just a thought. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409997#409997 ________________________________________________________________________________
Date: Oct 07, 2013
The Fuel Tank is in the wing and no aux tank at all. I am going to shim the horizontal stab up in the rear 1/4" and see how tha affects the flying characteristics. Thanks for all of the suggestions! taildrags wrote: > Chris; > > With the standard CG envelope being 15"-20" aft of wing leading edge, flying it with the CG at 15.6" aft is definitely going to be nose heavy. My airplane has a 16 gallon fuel tank in the nose and when I'm flying solo with full fuel, I have to hold some back stick too. Where is the fuel tank in Two One Lima Romeo? If it's in the nose and you're doing test flights with full fuel, you might try draining off half the tank and flying it again. And unless it is requiring considerable back stick to hold it straight & level, or you have a wing centersection fuel tank, it doesn't sound like you have any big adjustments to make. -------- NX321LR Now test flying!! Mitsubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=409998#409998 ________________________________________________________________________________
Date: Oct 07, 2013
Note that mine is a hybrid flop, a flop with a cutout, best (or worst) of both worlds. rh On Sun, Oct 6, 2013 at 1:05 PM, Chris wrote: > ** > > Several of Mike Cuy's > > http://westcoastpiet.com/images/Mike%20Cuy%20A-65%20Piet/mike_cuy.htm > > Several of Gary Boothe's > > http://westcoastpiet.com/images/Gary%20Boothe/wing.htm > > Jack Textor too > > ***http://westcoastpiet.com/images/Jack%20Textor/wing.htm* > > Rick Holland as well > > http://westcoastpiet.com/images/Rick%20Holland/pictures.htm > > > There are more but I don't have time to search for them > > Chris > Sacramento, Ca > Westcoastpiet.com > > > ------------------------------ > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *tmbrant(at)msn.com > *Sent:* Sunday, October 06, 2013 11:34 AM > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: Center section half moon > > Wondering if anyone has any photos of the build up of the center section > cutout (half moon). I'm about to do this but having trouble visualizing > the process. > > Thanks, > > Tom B. > > Sent from my Verizon Wireless Phone > > =EF=BD~=EF=BD > > * > =========== =========== =========== =========== > * > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
From: "skipgadd(at)earthlink.net" <skipgadd(at)earthlink.net>
Subject: Felix For Sale
Date: Oct 07, 2013
Hi all, It is time to sell my GN1/Piet. I have had the privilege of owning and flying Felix the GN1 since 2006 and over 200 hours. The highlight of course was 2009 when we flew to Brodhead and OSH and back to WV, 2 up. I am getting closer to completion of my Piet (started in 1990) and need the space as I am only a step or 2 away from attaching the wings for rigging. I love flying the Grega, much more than the Chief, and hate to see it go, but it is time. It has an A65, aircraft time and SMHO is 485 or so as I fly when I can. It was certified 1998, completed by Felix Quast(Dick N's distant cousin) The project was started back in the 60's or 70's, not by Felix. Felix has the Piet type wing not a Cub wing. It flys just like a Piet. Cruz is 68mph, stall something under 40mph. It has a standard Cub cowl tank and a 4gal wing tank, which I use only for cross country flying. It has a tow hook type release used to hand prop, than release from cockpit, PF Beck gave me. It has been real handy to have close by when I am trying to figure out something on my project and I have used several ideas from Felix on my Piet. After flying it for a couple years I decided I agree with Jack P, that the cut out center section is a good thing for viability and worth the small loss of lift. Will go back up on Barnstormers shortly, $12,000. Email or call with questions. H 304 275-3787 C 304 483-8342 Skip skipgadd(at)earthlink.net EarthLink Revolves Around You. ________________________________________________________________________________
Subject: How straight is straight?
Date: Oct 07, 2013
I recently bought some rough cut spruce to build my spars out of. I ran them through my table saw to try and get a good straight edge on them, and I don't think my results are adequate. If I lay all the planks on top of each other, and look down the long edge, I find that they are not perfectly aligned. there are variations of up to 1/8 (maybe slightly less) inch from one edge to the other. It could be that each board is off by a 1/16th, or some variation/combination of that. In other words, the edge is slightly wavy. It's imperceptible to the naked eye if you just look at each board individually. This is on a board that is 16 feet long. My question is whether I need to find some larger professional woodworking facility to help me fix these boards, or if this is acceptable variation? -------- Joe Pringle Atlanta, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410001#410001 ________________________________________________________________________________
Date: Oct 07, 2013
Subject: Re: Felix For Sale
Hi Skip, I love seeing that white scarf of yours trailing behind. I remember seeing a picture of it streaming out behind when you were parked; did you have a w ire in it? Cheers, Jim B. =C2- ________________________________________________________________________________
Subject: Re: How straight is straight?
Date: Oct 07, 2013
If a board does not have a finished edge to begin with as you have seem running it through a table saw will not give a perfect edge. One way is to attach a straight edge to the board being cut so it rides the fence then rip it. This is very important that the edge be true before ripping pieces from it. Or one would run the edge on a joiner first to true the edge before sawing ripping it. But joiners are expensive. If you want to do it yourself go an purchase a block plane, the longer the plane face the truer the edge will be that you are planing. Watch this: you want a plane that size. Good luck, learn and have fun, WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410005#410005 ________________________________________________________________________________
Date: Oct 07, 2013
Flap works as an air-brake too. Can't do that with a moon cut-out. LOL! -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410006#410006 ________________________________________________________________________________
Subject: Re: One bladed propeller
Date: Oct 07, 2013
Seen it fly at Sentimental Journey this year. They did a demo flight comparing a standard prop J-3 to an Everal Prop J-3. Everal prop was hard to beat! Climbed faster at a more AOA, faster in level flight. Great idea, but was not practical for every day flying. Cool video! WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410007#410007 ________________________________________________________________________________
Date: Oct 07, 2013
Thanks Keri Ann. Someone recommended that I get a 16 foot board with a known straight edge, lay it on top of my piece and use a Pattern bit on my router. That seems like it might be an easy solution also. I'll post the results -------- Joe Pringle Atlanta, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410008#410008 ________________________________________________________________________________
Date: Oct 07, 2013
womenfly2 wrote: > Sounds like you are okay to use with a 1/16 to 1/8 out of flatness. The jig will help with the straightness, just block it up good. After its all glued-up you will be fine. > > If a board does not have a finished edge to begin with as you have seem running it through a table saw will not give a perfect edge. One way is to attach a straight edge to the board being cut so it rides the fence then rip it. This is very important that the edge be true before ripping pieces from it. > > Or one would run the edge on a joiner first to true the edge before ripping more pieces form it. But joiners are expensive, specially if you only need it a few times. > > If you want to do it yourself go an purchase a block plane, the longer the plane face the truer the edge will be that you are planing. One does not need expensive tools to do this. > > With a hand surface plane: > With a table saw, you get the idea: > > You would want a plane at least that size with a razor sharp cutting blade. > > Good luck, learn and have fun, > WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410010#410010 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: wing center section cutout
Date: Oct 07, 2013
Can't say enough for the wing center section cutout with the hand-hold I bu ilt into mine. It makes getting in and out really easy plus I can stand up in the seat and easily reach my center section luggage area to load/unload . As Jack Phillips pointed out the upward visibility in turns (especially in and around the traffic pattern) is really increased with the cutout. I figured if so many of the biplane types (Jenny, Stearman, Waco) had cutou ts with handholds, it probably is a good idea. Just like a little dihedral. When debating flat wing or dihedral, Forrest Barber said "heck,....birds have dihedral, that's a good enough reason for me." Me too. Mike C. ________________________________________________________________________________
Date: Oct 07, 2013
Could you not use a steel stud as a guide? I think they are pretty straight. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410019#410019 ________________________________________________________________________________
Date: Oct 07, 2013
Subject: Re: wing center section cutout
Agree, whether you 'flop' or not I also highly recommend the grab handle, mine is exposed when I open the flop. rick h On Mon, Oct 7, 2013 at 1:41 PM, Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC] wrote: > Can't say enough for the wing center section cutout with the hand-hold I > built into mine. It makes getting in and out really easy plus I can stand > up in the seat and easily reach my center section luggage area to > load/unload. As Jack Phillips pointed out the upward visibility in turns > (especially in and around the traffic pattern) is really increased with the > cutout. > > I figured if so many of the biplane types (Jenny, Stearman, Waco) had > cutouts with handholds, it probably is a good idea. > > > Just like a little dihedral. When debating flat wing or dihedral, > Forrest Barber said "heck,....birds have dihedral, that's a good enough > reason for me." Me too. > > > Mike C. > > > * > > * > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Date: Oct 07, 2013
Great thoughts on the Aux Fuel tank idea. I want a portable solution as opposed to a permanent installation. I am going to take your suggestion and investigate marine fuel tanks (red hold 6-10 gallons). I want to also look into an electrical fuel pump squeezing the fuel bulb to pump that much gas up to my main would be a lot of effort. As for the envelope I hear what you are saying on the envelope although Piets are basically the same they are all individually different given wheel configuration, engine choices, etc. I need to do more research to learn how to create the envelope I do think I have the data. -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410022#410022 ________________________________________________________________________________
Subject: Re: Mr Sam (N687MB) - Scott Tail Wheel
Date: Oct 07, 2013
Update on the tail wheel... pulled one link out of the chain between the thimble and the spring. Brought the wheel in to perfect alignment. This temporary ... I am going to replace the chain links (looks like something you would buy at Ace Hardware) with turnbuckles. That way I can adjust both sides and then safety wire them into place. -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410023#410023 ________________________________________________________________________________
Date: Oct 07, 2013
Excellent idea, Oscar! Just screw in on the ends... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Monday, October 07, 2013 2:03 PM Subject: Pietenpol-List: Re: How straight is straight? --> Could you not use a steel stud as a guide? I think they are pretty straight. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410019#410019 ________________________________________________________________________________
Date: Oct 07, 2013
RGljaywNCg0KVGhhdCB3b3VsZCBiZSBncmVhdC4gIEFjdHVhbGx5LCBJIGNvdWxkIGJyaW5nIG15 IENDIHVwIHRvbyBhcyBJJ2QgbGlrZSB5b3VyIGZlZWRiYWNrIG9uIHRoZSBkZXNpZ24gSSd2ZSB1 c2VkIHRvIG1ha2UgaXQgYSA0Jy0wIiBjZW50ZXIgc2VjdGlvbi4gIExldCdzIHRyeSB0byBmaWd1 cmUgYSB0aW1lIG91dCBvbiB0aGUgd2Vla2VuZCBpZiB0aGF0IHdpbGwgd29yay4gIE15IHdlZWsg aXMgYnVyaWVkLg0KDQpUb20gQi4NCg0KRnJvbTogaG9yenBvb2xAZ29sZGVuZ2F0ZS5uZXQNClRv OiBwaWV0ZW5wb2wtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUGlldGVucG9sLUxp c3Q6IENlbnRlciBzZWN0aW9uIGhhbGYgbW9vbg0KRGF0ZTogU3VuLCA2IE9jdCAyMDEzIDIzOjIx OjExIC0wNTAwDQoNCgoKCgoKCgpIaSBUb20gCkRvIHlvdSB3YW50IHRvIHNlZSBtaW5lLCBpdHMg YXQgbXkgCmhhbmdhci4KRGljayBOLgoKICAtLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0tIAog IEZyb206IAogIHRtYnJhbnRAbXNuLmNvbSAKICAKICBUbzogcGlldGVucG9sLWxpc3RAbWF0cm9u aWNzLmNvbSAKICAKICBTZW50OiBTdW5kYXksIE9jdG9iZXIgMDYsIDIwMTMgMTozNCAKICBQTQog IFN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBDZW50ZXIgc2VjdGlvbiAKICBoYWxmIG1vb24KICAN CldvbmRlcmluZyBpZiBhbnlvbmUgaGFzIGFueSBwaG90b3Mgb2YgdGhlIGJ1aWxkIHVwIG9mIHRo ZSAKICBjZW50ZXIgc2VjdGlvbiBjdXRvdXQgKGhhbGYgbW9vbikuICBJJ20gYWJvdXQgdG8gZG8g dGhpcyBidXQgaGF2aW5nIAogIHRyb3VibGUgdmlzdWFsaXppbmcgdGhlIHByb2Nlc3MuDQoNClRo YW5rcywNCg0KVG9tIEIuDQoNClNlbnQgZnJvbSAKICBteSBWZXJpem9uIFdpcmVsZXNzIFBob25l DQoNCu+/vX7vv70DCgoKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVucG9sLUxpc3Qg RW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0 b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4v U3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3Nl LCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0g ICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdApf LT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBT YW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0K Xy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAg ICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAt TWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09CgogCQkgCSAgIAkJICA ________________________________________________________________________________
Date: Oct 07, 2013
yeah=2C I guess I waffled a bit on whether i'd do the flop or a cutout and this is where I've ended up too. I like the Hybrid flop/cutout idea too=2C but it's too late for me to do that. Cutout it is. Tom B. > From: jack(at)bedfordlandings.com > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Re: Center section half moon > Date: Mon=2C 7 Oct 2013 07:33:30 -0400 > gs.com> > > But it does increase visibility=2C particularly during tight turns... > > Jack Phillips > NX899JP > Smith Mountain Lake=2C Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of womenfly2 > Sent: Monday=2C October 07=2C 2013 7:12 AM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: Center section half moon > > > > Doing a moon cutout reduces wing area=2C hence why Bernie used the center > flap. > > -------- > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=409982#409982 > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: strut attachment
Date: Oct 07, 2013
Looking at the screen shot=2C some of you smart engineer types might be abl e to help me on this one.. I'm using the Carlson Aircraft aluminum struts (small) and using the 3/4" x 3/4" alum. bar attachment like Larry Williams. I'm wondering on the spar attachements at the center section=2C do I need to do the double "U" bracket as shown in "B" or couldn't I just reorientat e the strut attach bolt so it's parallel with the spar attach bolts as show n in "A". I don't see how there'd be a difference but I'm no engineer and would love to hear feedback. I'm not trying to change it just to change it =2C I just have very little welding experience so I'm paying to have it don e - IE=2C the least I can give him the better. FYI - model is not to scale. Tom B. From: tom.brant(at)amec.com Date: Mon=2C 7 Oct 2013 13:36:56 -0400 Subject: strut attachment Capture=0A =0A The information contained in this e-mail is intended only for the individu al or entity to whom it is addressed. =0A Its contents (including any attachments) may contain confidential and/or pr ivileged information. =0A If you are not an intended recipient you must not use=2C disclose=2C dissem inate=2C copy or print its contents. =0A If you receive this e-mail in error=2C please notify the sender by reply e- mail and delete and destroy the message. =0A iVBORw0KGgoAAAANSUhEUgAABE8AAAL9CAYAAADacEhTAAAAAXNSR0IArs4c6QAAAARnQU1BAACx jwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAHatSURBVHhe7d3LjmRbehfweAQkeAskBp4xQkIg MWUEDJAfAEG3MJdqLgKbAcgSLluWkWUbQ3PkCchUn3NcjZGxZFqyZDOxB2AMPIIfIonIS1VkVEbE vnzr8q31s5Ty6XMyI/Ze67cu3z9Xxj4cDocHX9qAgf0GfuzHfuzhx3/8x29+/cmf/MnD0q/v/MT3 Hv78X/grb36d/tvS1xnt+37zN//rw0/+q597OP3/iHv7/d//Hw+/+7u/+/ha0a99fn2/9Vv/7eGn f/5XHv7lz/1KyHW/vPaf/kt/b/fr/cL3f/3hb37vF3a/ztL++O+/8zsP/+Kn/tnDd77zdx6+94/+ ycM//N4/fvjud7/78J2//bcefvu3f2v1dfzSr314+Kt/92cf/uxf++cPf+ov/sTDn/nLf//hz/2N n3r46//g5x9+7dd/4+br3Ruzp3Ftftw/P2pDbcgAAwwwwAADAxjQiQN0os19ByFgdHiytBD1fcsD KW2lrS4NCE/sAewBGGCAAQYYYICBhQY01MKGElB0EFD03FfCE4W5cCafAeGJPUDP64pr45MBBhhg gIGuDHR1MQIKAUVaA8KTfIWzsEOfCU/sAWxKGWCAAQYYYICBhQY01MKGSlvUu786xk/hiS9twMB4 BsyhdeZQ7aydGWCAAQYYYKBzAzqo8w4S2jiNwwADDDDAAAMMMMAAAwwwwEBbA8IT4QkDDDDAAAMM MMAAAwwwwAADDDBww4DGMUAYYIABBhhggAEGGGCAAQYYYIAB4Unb4z2OV2l/BhhggAEGGGCAAQYY YIABBvIakCxJFxlggAEGGGCAAQYYYIABBhhggAEnT/KmW5JJfccAAwwwwAADDDDAAAMMMMBAWwOS JekiAwwwwAADDDDAAAMMMMAAAwww4ORJ24RKQqj9GWCAAQYYYIABBhhggAEGGMhrQLIkXWSAAQYY YIABBhhggAEGGGCAAQacPMmbbkkm9R0DDDDAAAMMMMAAAwwwwAADbQ1IlqSLDDDAAAMMMMAAAwww wAADDDDAwFsG3r17dwquNI42YIABBhhggAEGGGCAAQYYYIABBl4MnAKTl6+vvnpsF42jDRhggAEG GGCAAQYYYIABBhhgYG4Dl4HJKTR5+RKeCI/83RwDDDDAAAMMMMAAAwwwwAADUxq4FZgITwyKKQeF FHnuFFn/638GGGCAAQYYYIABBhg4D0tO/3wekNz6ZydPBCmCFAYYYIABBhhggAEGGGCAAQaGNbD0 dInwxCAYdhBIjiXHDDDAAAMMMMAAAwwwwAADlwYiAhN/tiNMEaYwwAADDDDAAAMMMMAAAwwwMJSB 6MBEeGKADDVApMxSZgYYYIABBhhggAEGGGBgTgMlA5Pz1/aZJ4IUQQoDDDDAAAMMMMAAAwwwwAAD aQyUCkwuP0z2/fvDw8uX8MQASTNAJMlzJsn6Xb8zwAADDDDAAAMMMMBAjcDkPCy5/GfhifBEeMIA AwwwwAADDDDAAAMMMMBAVwa2PlJ4yaOHz1/7VmDi5IlB0dWgkCJLkRlggAEGGGCAAQYYYIABBkqd LjkFKlsCE+GJ8ER4wgADDDDAAAMMMMAAAwwwwEBzAz0HJsITA6T5AJEqS5UZYIABBhhggAEGGGCA gTkNZAlMhCfCE+EJAwwwwAADDDDAAAMMMMAAA9UMlApMbj0hZ+nnmSz5Ph8Ya7BUGyxS5TlTZf2u 3xlggAEGGGCAAQYYmNNAjcBkSfAR8T3CE+GJ8IQBBhhggAEGGGCAAQYYYICB3QZ6e0JORGjy8hrC EwNk9wCRIs+ZIut3/c4AAwwwwAADDDDAAAOlTpdEPCFHeCLwEHgwwAADDDDAAAMMMMAAAwww0MTA LIGJD4w1wJoMMKm0VJoBBhhggAEGGGCAAQYYyGlgxsBEeCI8EZ4wwAADDDDAAAMMMMAAAwwwcNPA 7IGJ8MQAMUkywAADDDDAAAMMMMAAAwww8IWBUoFJrUcKR37OifDEADFJMsAAAwwwwAADDDDAAAMM MPBooEZgUirUqPW6nrZjsJgwGWCAAQYYYIABBhhggAEGJjIw8iOFS4UpwpOJBogPZsr5wUz6Tb8x wAADDDDAAAMMMMDAXgOlTpf09khh4YmQQxLMAAMMMMAAAwwwwAADDDDAwGIDApPDQ1SY4uSJgbd4 4O1NOv28tJwBBhhggAEGGGCAAQYYKGtAYBIXmPjAWIGJwIQBBhhggAEGGGCAAQYYYGAQA6UCk+xP yIk6dXJ6HSdPBhks0tuy6a321b4MMMAAAwwwwAADDDDQk4EagUlk+JD9tYQnwhNpMwMMMMAAAwww wAADDDDAQOcGPCGnzJ/jLA11hCedD5Cekk3XImlngAEGGGCAAQYYYIABBuoZKHW6ZJYn5CwNRpZ8 n/BEeCJhZoABBhhggAEGGGCAAQYY6MSAwKTtCZNrQYrwpJMBIr2tl95qa23NAAMMMMAAAwwwwAAD PRkQmPQZmHjajsBEqswAAwwwwAADDDDAAAMMMNDQgMCk/8BEeNJwgPSUbroWaTsDDDDAAAMMMMAA AwwwUM9AqcDEI4XLBzH+bEeQIm1mgAEGGGCAAQYYYIABBhgoZKBGYLLkA099z76ARXhSaIBIb+ul t9paWzPAAAMMMMAAAwwwwEAvBjxSeF9I0WvIIzwRnkiYGWCAAQYYYIABBhhggAEGdhgodbrEI4X7 CWKEJzsGSC/JpuuQsjPAAAMMMMAAAwwwwAADdQ0ITPoJNmqcVhGeCE8kzAwwwAADDDDAAAMMMMAA AwsMCEzmCkw8bWfBoJDa1k1ttbf2ZoABBhhggAEGGGCAgR4NlApMPCEnVxDj5IkgRcLMAAMMMMAA AwwwwAADDDBwZqBGYFLjT028R1xAIzwxSZokGWCAAQYYYIABBhhggIGpDXhCTlzIMGpgIzwxSU49 SfZ4LNA1Oa7KAAMMMMAAAwwwwEB5A6VOl3hCzphBjPBEeCI8YYABBhhggAEGGGCAAQamMCAwGTPY qHHaRXhikpxikpTcl0/utbE2ZoABBhhggAEGGOjRgMBEYBIRrghPhCfCEwYYYIABBhhggAEGGGBg KAMCE4FJRGDiUcUmxqEmxh7Tbdfkty4MMMAAAwwwwAADDNQ1UCow8UhhQcwpRHHyRJAiSGGAAQYY YIABBhhggAEGUhqoEZhEn2DwejnDGOGJSTLlJCnFr5via2/tzQADDDDAAAMMMNCDAY8Uzhk8jBAY CU+EJ8ITBhhggAEGGGCAAQYYYKBbA6VOl3iksCBmTagjPDFJdjtJ9pBsuwa/YWGAAQYYYIABBhhg oL4BgYlgY02wUeN7hSfCE+EJAwwwwAADDDDAAAMMMNDcgMBEYFIjBNn6HsITk2TzSVKSXz/J1+ba nAEGGGCAAQYYYKAHA6UCE0/IEcRsDUmu/ZzwRHgiPGGAAQYYYIABBhhggAEGqhmoEZhEF85eTxgj PDFJVpske0i2XYPfsDDAAAMMMMAAAwwwUNeAJ+QIHkYIn4QnwhPhCQMMMMAAAwwwwAADDDAQaqDU 6RJPyBHEtApihCcmydBJUopfN8XX3tqbAQYYYIABBhhgoBcDAhPBRqtgo8b7Ck+EJ8ITBhhggAEG GGCAAQYYYGCTAYGJwKRGcNHDewhPTJKbJsle0m3X4TctDDDAAAMMMMAAAwzUNSAwEZj0EGbUvgbh ifBEeMIAAwwwwAADDDDAAAMM3DRQKjDxSGFBTO0QZOv7CU9MkhZKBhhggAEGGGCAAQYYYOALAzUC k62FrJ8TutQ2IDwxSVooGWCAAQYYYIABBhhggIEHjxQWSNQOJDK9n/DEJGmhZIABBhhggAEGGGCA gUkNlDpd4pHCgphMwciSaxWeTDpJ+lCtuh+qpb21NwMMMMAAAwwwwEAvBgQmgo0lYYHvee1EeCI8 8VsGBhhggAEGGGCAAQYYGNyAwERgIgzZZ0B4Mvgk2Uu67Tr8poUBBhhggAEGGGCAgboGSgUmnpCz rwgXYuRsP+GJ8MRvGRhggAEGGGCAAQYYYGAQAzUCE8V/zuJfv+3rN+HJIJOkFL9uiq+9tTcDDDDA AAMMMMBADwY8IWdfQSxQ0H5LDQhPhCd+y8AAAwwwwAADDDDAAAOJDJQ6XeIJOYKEpUHCjN8nPEk0 SfaQbLsGv2FhgAEGGGCAAQYYYKC+AYGJYGPGwKKnexaeCE/8loEBBhhggAEGGGCAAQY6NCAwEZj0 FB7Mfi3Ckw4nSUl+/SRfm2tzBhhggAEGGGCAgR4MCEwEJrOHFL3ev/BEeOK3DAwwwAADDDDAAAMM MNDQQKnAxCOFBTG9BhEZr0t40nCS7CHZdg1+w8IAAwwwwAADDDDAQH0DNQKTjAWqaxb49GpAeCI8 8VsGBhhggAEGGGCAAQYYKGzAI4WFAr2GAq5rmU3hSeFJUopfP8XX5tqcAQYYYIABBhhgoAcDpU6X eKTwsmJXKKCdIg0IT4QnfsvAAAMMMMAAAwwwwAADQQYEJgr2yILda/XjSXgSNEn2kGy7Br9hYYAB BhhggAEGGGCgvgGBST8FrrBBX5QyIDwRnvgtAwMMMMAAAwwwwAADDKw0UCow8YQcxX+p4t/r7rMl PFk5SUry6yf52lybM8AAAwwwwAADDPRgoEZgosDdV+BqP+1XyoDwRHjitwwMMMAAAwwwwAADDDDw hgFPyFGIlyrEvW4+W8ITC6WFkgEGGGCAAQYYYIABBp4NlDpd4gk5+YplAYc+OzcgPLFQWigZYIAB BhhggAEGGJjagMBEkSwoYeCeAeGJhXLqhbKHv511Df6GmwEGGGCAAQYYqG9AYKJYvlcs+++MOHki MBGYMMAAAwwwwAADDDAwnQGBiWJYIMLAVgNOnlg0p1s0/Wan/m92tLk2Z4ABBhhggIFWBkoFJh4p rAjfWoT7uZx2hCfCE+EJAwwwwAADDDDAAANDGagRmCiAcxbA+k2/bTUgPLFQDrVQtvqNhvf12zQG GGCAAQYYYKCdAY8UVhBvLYj9HDtLDQhPhCfCEwYYYIABBhhggAEG0hkodbrEI4UV00uLad83lxXh iYUy3ULptzrtfquj7bU9AwwwwAADDLQ0IDCZq1gVTujvngwIT4QnwhMGGGCAAQYYYIABBro1IDBR QPdUQLuWeT0KTyyU3S6ULX+r4b39Vo0BBhhggAEGGGhnoFRg4gk58xa+JUOPS1en/13y/bx2G8fC E+GJ8IQBBhhggAEGGGCAgeYGagQmis42Redo7f5WWPLy7w6H9w/CkzGdCU8slM0XSr/VafdbHW2v 7RlggAEGGGCglQFPyBmzwBwtKHm5n3Ovh8NXjwHJeWByCk1evoQnY9oWnghPhCcMMMAAAwwwwAAD DFQxUOp0iSfkjFms9hDEfA5IbgcmwpPxDQpPLJRVFspWv9Hwvn6bxgADDDDAAAMMtDUgMBm/qOwh 5Ch1DSe/h8PHx1Mm5wHJrX928mRM88IT4YnwhAEGGGCAAQYYYICBUAMCkzGLx1IBRc+vKzxh+cWn 8MRCGbpQ+s1O29/saH/tzwADDDDAAAOtDAhMFJk9hyBbr014wrXwRGgiNGGAAQYYYIABBhhgYJeB UoGJRworWLeGHdE/JzxhUXhiody1ULb6jYb39ds0BhhggAEGGGCgrYEagUl0Aez1FMBbDQhP2BGe CE+EJwwwwAADDDDAAAMM3DXgkcKKx63Bwwg/JzzhX3hioby7UPqtTtvf6mh/7c8AAwwwwAADrQyU Ol3ikcIK0WyBivCEWeGJ8ER4wgADDDDAAAMMMMDAJwMCE0VitmCjxvUKT4wL4YmF0maJAQYYYIAB BhhgYHIDAhOFYY0AIvN7CE+MEeHJ5AtlqyOg3tfxYwYYYIABBhhgoK2BUoGJJ+QoMjOHJNeuXXjC tfBEeOI3TQwwwAADDDDAAAOTGKgRmIxYOLsnhbPwhAHhySQLpd/stP3NjvbX/gwwwAADDDDQwoAn 5Cj4BD8xBoQnMe04gsfjXG5B0wYMMMAAAwwwwAADDGQ3UOp0iSfkKB5HKHy33oPwhH8nT4RGjuky wAADDDDAAAMMJDcgMFHYbQ0F/NwyO8KTZe00gycnT5IvmNl/Q+L6/ZaPAQYYYIABBhhYZ0Bgopib oVDt5R6FJ8abkydCE79pYoABBhhggAEGGEhiQGCigOslTJjtOoQnxp7wJMlC6Tcx634To720FwMM MMAAAwyMYqBUYOKRworB2QKQPfcrPDFehCfCE79pYoABBhhggAEGGOjMQI3AZE8h6WcVkrMZuBWe vIzXw+H9cS79/HX697O10+j3++SgswXD9fhtEQMMMMAAAwwwwMAsBjxSWBgxetGZ/f6uhSefg5Of fHj6HuFJ9r6+vP7z+fl5TbI4z7I4u0/WGWCAAQYYYICB9gZKnS7xSGFBzGjFaw/3cy88eev0iZMn OcfiZZj9xnrZfgGxiOsDBhhggAEGGGCAgZENCExyFlM9FO+uoa2de+HJ4fCHTp68b9tHe8bIG6dL bv05q4V65IXavfHNAAMMMMAAAwy0MSAwyVtQ7SnG/OxY/X4rPDkc/vhYaP8f4Umy8GRlYHIeprRZ TCzi2p0BBhhggAEGGGBgNAOlAhNPyBmrIBew5OnPeydPLj/v5PTZJ/5sp7/+3RGYCE9GW6jdj80n AwwwwAADDDDQxkCNwESx3V8xpk/m6JN7T9u5fNKO8KQfF0GBifDE5qLN5kK7a3cGGGCAAQYYyG7A E3L6KY4EGPqitIFb4clbwYnwpK3JAoGJ8CT7ou36bTwZYIABBhhggIF6BkqdLvGEnLaFVunC2+vn 71/hSd99uOAJObc+AHbtf6u36FjgtTUDDDDAAAMMMMBAFgMCk76LJsGE/qlhQHjSn7PCp0s8bSfL Iu06bSgZYIABBhhggIF2BgQm/RVKNQpk76HfrxkQnvRho2Fg4s92bErabUq0vbZngAEGGGCAgZ4M CEz6KI4EGPqhRwPCk3YuOwlMhCc9LdiuxQaSAQYYYIABBhioa6BUYOKRwu0KrR4Lb9eU34PwpG4f dhiYCE9sUOpuULS39maAAQYYYICB1gZqBCaK5bqFlvbW3qUNCE/KG+s8MBGetF68vb8NJAMMMMAA AwwwUNaARwqXL3pKF65eXx+2NiA8KWMwUWAiPLFZKbtZ0b7alwEGGGCAAQZaGCh1usQjhcsUUK0L Y++vX+8ZEJ7EGKn8SOG1jyBe+v0W9hYLu/fkjgEGGGCAAQYYiDEgMIkpbu4Vkf67dp7RgPBku/uk p0s8qtjmJGZzoh21IwMMMMAAAwz0YEBgsr2gmbEAds+8bDUgPFlnZ8DAxJ/t9LDouwabTwYYYIAB BhhgYLmBUoGJJ+SsK462FqF+TjtnNCA8ue928MBEeGKjsnyjoq20FQMMMMAAAwy0MlAjMMlY0Lnm +wWdNtJGEQaEJ287migwEZ602gB4X5tPBhhggAEGGGDgugFPyFHwRhS8XoOjKAPCk8+WJg1MhCc2 LTauDDDAAAMMMMBAHwZKnS7xhBwFdFQB7XXmtTR7eCIwebVO9rFo2rzoBwYYYIABBhhgYB4DApN5 i1FBhL7PZGC28GSQRwovffTw2u+bZ5G2IdPXDDDAAAMMMMBAOwMCE0VzpqLZtfJ6MjBDeOJ0yeJ1 cfE3rk1lfP9B29qgMsAAAwwwwMDcBgQmClAhBAOZDYwanghMNq3Nm35IMCIYYYABBhhggAEGGHjT QKnAxCOFFeGZi3DXntPvSOGJwGR39rH7BWycbJwYYIABBhhggIHJDdQITBSfOYtP/abfMhu4F548 /ff3r75O/66XexaYhOYdoS9m4zT5xsnRbOOJAQYYYICBOQx4pLCCuJfi0HWwWNLArfDk6b999/lz UT4HKK3DE4FJsXW42AsLUgQpDDDAAAMMMMDAQAZKnS7xSGHFb8ni12vztcfAtfDky6fStAtPPCGn WqZR7Y1sngbaPPmtonHDAAMMMMDAHAYEJgrPPYWnn+Unu4F74cnh8PtNTp44XdJkDW7ypoIUQQoD DDDAAAMMMNCpAYGJgjd7wev6GY4ycD88+b/VwhOBSfPsovkF2Dh1unHyG0VjgwEGGGCAgXkMlApM PCFHERtVxHodlloYuBWeHA5/cKxl/1fR8ERg0tU63NXFCFIEKQwwwAADDDDAQCUDNQKTFsWO91Rk M8BAlIF7Hxhb4mk7ApNuM4puL8zGqdLGyW8VjQEGGGCAAQbmMSAwUVRGFZVeh6UZDNx7VPHlY4pP /3vL03YEJinW4RQXKUgRpDDAAAMMMMAAAxsMeKSwAneGAtc9cl7KQMnwRGCSLotId8E2Ths2Tn6j yDkDDDDAAAPzGCh1usQjhRWopQpUr8tWrwYiwxOPFE6/Dqe/AWGKMIUBBhhggAEGpjcgMFF89lp8 ui42MxvYG544XTJU3jDUzUy/cfJbRZ4ZYIABBhiYx4DARFGauSh17fxmMLA1PHmZn63JQ63JQ92M 8MRvHhlggAEGGGBgaAOlAhOPFFbIZihkXSOntQ1sDU+EJkPmDEPe1NCbJgORWQYYYIABBuYyUCMw qV2QeD9FMAMMZDCwJjzxJzrDr83D36AgxW8gGWCAAQYYYCCVAU/IUVRmKCpdI6czGLgVnnz5AbDv j2vN06OK/ZJjyJxhyJuC1SaZAQYYYIABBlIZKHW6xBNyFLgzFLjukfNSBi7Dk9enS57Ckssv4cmw GcOwN5ZqwySZ5JABBhhggIH5DAhMFHylCj6vyxYD2w1cnihZGpj4s53h1/Hhb1CI4jePDDDAAAMM MNCNAYHJ9oJGMajtGGCglIHXwcfH5z+9efkTnM//+/yUye2fUWcP+EshnTpgp3azQdS2xhcDDDDA AAOHx034y9fpz2giv85fu1RR4XUVrAwwMKKBy/DjcPh4rKOevp7+9ObL8GT5z1j/B1z/deqAnSo8 8RtWBhhggAEGGhsoFZh4pLAidsQi1j1xXcvArfDjWniy5WfUmEPmDEPelA1j4w2jycK4YoABBhiY 0UCNwKRWgeF9FLMMMDCKgaXhx62TJ+f/7do/vz6tYh8w4D5Apw7YqcIj4REDDDDAAAMVDHiksOJy lOLSfbA8moEtgYnwRDZwJxvQQMITBhhggAEGGGBgqYFSp0s8UljxOlrx6n6YrmngMsx+mdNfHjW8 5OTIrT/bWfLzTp4Mv5cY/gb95q3Cb96Wbjh9n/HGAAMMMJDRgMBEEVizCPRevDGwzMCSRwNHhCeH r7569cHfL+97GagIT4bf4wx/g8IT4QkDDDDAAAMMrDYgMFlWvCjytBMDDNQ0sCQwOQ/po8KTU4By +XV52kV4Mny2MPwNrt4sZfyNmGvmmAEGGGCAgf0GSgUmnpCjuKxZXHov3kYzsDYwqRWevHUi5fPj jfevSdb17tqwuwsSdvjtIAMMMMAAAwxUM1AjMBmtkHE/inMGGChtYE9gUjo8eXVt798/HJ6/nDwZ PlsY/garbb4kgywxwAADDDDQvwFPyFH0lS76vD5jDGwzEBWYlAhPrgUmL8HJ6f8LT/rfA+zcpw1/ g8ITv71kgAEGGGBgcgOlTpd4Qs62Aklhqd0YYOBk4NoTcnYWuK/W/IjPPHl8jbMTJtf+WXgyfLYw /A3aME++YY6cfL2W+YIBBhjIY0BgojhToDPAQH8GSpwuubU2R4QnS4ITJ0/y7A927OWmuEkBigCF AQYYYICBCQwITPorlBSv+oQBBmoHJuF/trPg1InwZIpcYYqbtGGeYMO8I0Hkgw8GGGAgsQGBicJM cc4AA/0ZaBmYCE/U+IVqQw1bqGFtxBNvxJkwLzDAAAN9GygVmHikcH8FmKJYnzCQx0AvgYnwpO81 PPEeS8Mm7jwBjYCGAQYYYGAaAzUCE0VaniJNX+krBvow0GNgIjxR4xeq8TVsoYadZjOr/YwhBhhg gIESBjxSuI/CSIGqHxhg4NJA74GJ8MS+pMS+5PiaGlYbMMAAAwwwwEAfBkqdLvFIYcWfAIABBrYb qPFI4VLrsKft9LG+l+rfyq+rMSs3uBMpAjsGGGCAAQbODAhMthc0ikFtxwADpQxkOl2y5VHFr+/v 43Fdfv31FLq8f3j8/562Y9/ytG8RnmgDBhhggAEGGKhrQGCi4CtV8HldthjYbmCUwOTen+08BSM/ 8xiMvHwJT+ruA5LuuzRS0o6T/gn+GGCAAQZSGSgVmHhCzvZCSZGp7RhgYMTAZEl48ik0+cVffDpd 4uRJqj1FoxpeeNKo4eFU9DDAAAMMDG+gRmCi+FP8McAAA+sMjB6YLAlPDodffgpNfvVXhSf2Y0v3 Y8IT4QkDDDDAAAMMxBjwhJx1BYyCT3sxwEAtAzMFJsvCk39/LJi/7892BCdLgxOfeWKzHLNZ1o7a kQEGGJjXQKnTJZ6Qo6isVVR6H9ZGNJD5CTmRe4prT9vxgbHz7lt2+NJoOxpvTUrle6WaDDDAAAPD GBCYKDZHLDbdE9fZDcx6umTL03YuP+PEZ57IBRbkAhppQSMNs9l1r7wzwAADDGw1IDBRWGYvLF0/ wyMaEJjcXtevnTwRntgPbdgPabQNjSZM8dtjBhhggIEpDAhMFJsjFpvuievsBgQmy2tY4cnytlIX 322ru98wxeYQFA4YYIABBhh4MlAqMPFIYQVr9oLV9TPc0oDAZNs+RXiyrd3sid5sN40JBgMMMMAA A7MbqBGYtCw6vLeilwEGMhoQmOzfnwhP9rfh7Huks/vXmDAwwAADDDAwmwGPFFZIZiwkXTO3MxgQ mMTuSYQnse05237p4n415uQA/FmWz21ggAEGJjFQ6nSJRworaGcoaN0j56UMeKRw2XpUeFK2fSer pTXmZB2uSJqkSOLa3MYAAyU/v0RgopAsVUh6XbZmMOB0Sb01WnhSr60n2HtqzAk6WWAiMGGAAQYm MuCEieJzhuLTPXKezYDApE3dKTxp0+6D1tgac9COVShNVCgxbB5jgIFSgYkn5ChQsxWorpfZngwI TNqvz8KT9n0w0D5VYw7UmQITgQkDDDAwkYEagUlPRYhrURQzwEAGAwKTvupL4Ulf/ZG89taYyTtQ oTRRocSq+YqBuQ14Qo7CMUPh6Bo5ndGAwKTf9bl2ePJiwZ6tXxM7+mbImxIoCBQYYIABBoYwUOp0 iQ98VeDOWOC6Z+6jDHhCTp4asnZ4sqMwH2LfMvj954E/eEcYLAo9BhhggIFHAwITBV5Uged1WGIg zoDTJTnrxi+Dro/Htfb+11Po8v5xTT68f7/o6+lncraT617Ub4u+CQKDgAEGGGCAgYIGBCZxBY5i UVsywECUAYHJOLXiY7Dx8eOrX1DcOpUiPBmn7wODIY0S2JgKi4KFhX4yVhlgYDQDAhMFXlSB53VY YiDOgMBkvP3Gp88hOYYnpwDl/OvyZMpLoPLKwYqTJ06fjOfnbP859M0JM4QZDDDAAANdGSgVmHik cFzhpAjVlgzMZ0BgMmZN+Ck0+erpT2Ivg5Nr//s8bFn9ZzvP7yVEGdLUkDfV1UZ5tN+Uuh9jhgEG GFhnoEZgotibr9jT5/qcgX0GBCbr1rJsa/9jeHEMMl6+1oQnlydT1nzmyfn7MjacseFuSHDit8wM MMAAA00NXJ4COT3ZJurr/LUVTvsKJ+2n/RiYz4Bido7a7zI4OQUotcKTww8/f/D7ZXjjNEp6f+lv oOkGOVsC63p5Z4ABBsoYKHW6xCOF5yvuFPT6nIE4A5dhtjWwzBrYW7u2Dk9OAcp5iOI0yjDuhrkR IYrfNDPAAAMMVDUgMIkrcBSL2pIBBqIMOF2ivjuFOeefd3L+pztrT6Cs/syT5+DkJUC5DFKcRknt M/XFV90k95aouh52GWCAgfoGBCYKvKgCz+uwxECcAYFJ/fWw+z3Ifzy2yX++HaK8cvPGk3heHm28 5jNPLkOTayGK0ygpzaa8aKGJ3y4zwAADDFQzUCowuTxOrpCKK6S0pbZkYHwDAhN13M0A5zk8OXzz 5Z/Q3DqVcrk2f/reBY8rfgxErpw8eevfvzL8/OG2n97PPq/aPm9FEGjQrWisHjvQNZlYGGCAgQIG agQmirvxizt9rI8ZiDUgMFG7La7dLsKTl88gOXx7bMNToPL151Mp1wKTa6dDbn7/ivDkPFC5DHRY 79J6lxelEChQCCyeaLw3fwwwMKGBy41Q1NNxfOBrbOGkENWeDMxnQBGpXttUx1wLT37jc3hy+MHz U3g+HP/dla9bQcmtwOOtn1tyKsVplK69d31xCpgJC5hNk6N2MlYYYGCDgVKnSwQm8xV3Cnp9zkCc gcui095QvbbJwJLw5BiYPJ4uuRGeLPlvSwKWpd/z1mmUlxMwgsTmY6H5Bdjwb9jwb5pAvA9rDDDA wKdP3z9tQCJPlwhM4gonRai2ZGA+A4pCNVl4fXPjM08e/2zneOrkFIxEhCdLApaX91oaolz97BWf jdJyP2+ghg9UxUlL0N6bPwYY+MKAEybzFWKKb33OQP8GBCbqsKJ12Fl48hiQ/OyxvY9fn/7UpkF4 siRkWRKuvPW448d7tAcs3QYGLWQMMMAAA+MZEJj0XzgpbvURA/MZEJiMt952u4e6CE9e2Ts+lvjl xEnNkydLwpMl33PzA2sFKCUDFAO42wEPfkn4XpsvBgY0UCowudykKPjmK/j0uT5nYLsBgYl6q0m9 dXny5N8c++GXjl//9uz0SeU/21kSjOz5nk+nagbc4zUx9GU7GsyddIRCziBngAEGNhioEZgomrYX TdpO2zEwpwGBiRqreY31xmeePP65y/eFJ837ZsN+r5NrNrA76QhFU95BpO/0HQMVDVyeAon80Nfz 11bwzVnw6Xf9zsB2AwITdVVXddWVp+30/pknTp50PY66vjgFScWCpKvJzn2zzwADZwZKnS7xhJzt RZICU9sxwMBlmG0vqa7qysC9RxV3+oGxwpOux1HXF6d4UEAywAADkxoQmCjMFOcMMNCfAadL1E5d BSS39kjCE3vo+D20CSDNBBDf+QaUNmWAga4MCEz6K5QUr/qEAQYEJuqllPWS8KSrPV5KQz4w1uQ3 CFyTgaKfgUEMlApMPCFHwafoZ4CB7QYEJmqG9DWD8MReOX6vbGJIPzHEozDQtCkDDBQ1UCMwUTRt L5q0nbZjYE4DAhN10VB1kfCk6F5uKCvL9/0miUk73mBaPki0lbZiYKcBT8iZsxBTgOt3Bvo3IDBR Cw1bCwlP7F937l/fGBsmjGEnjHgsBqA2ZYCBxQZKnS7xhJz+izEFsz5ioF8DnpCj9pmm9hGeLN6z TWNi/z7eBAILAwwwwECMAYFJvwWTYlbfMDCvAadLYtY4e4Vk7Sg8EZ7sD0su2zDZIIhvAKi0KQMM MLDDgMBk3oJMMa7vGejXgMBEjTN92CM8sb/dsb+9Mn5MLNNPLPGoDFRtysDgBgQm/RZMill9w8C8 BgQm6hp1zZkB4Yn9ePx+3CRjkmGAAQYYuG+gVGDikcLzFnqKfH3PwH4DApP765c1ftI2Ep4IT4Qn kw7++I43mLQpAwzcNVAjMFE87S+etKE2ZGAuAwIT9YBAaIEB4cndfR5HCxy9rhdW/4BOUHAxwAAD gxrwSOG5CjAFt/5mII8BgYmaRaG70oDwxH49fr++EmH8BehUbcoAAww0NFDqdIlHCucpyhTQ+oqB /gx4pLAaRViy04DwxP46fn+9E2X8BelkbcoAAwwUNiAw6a9QUrzqEwYYcLpEXSIwCTQgPLGfjt9P BwKNvzgdrk0ZYICBIAMCE4WZ4pwBBvozIDBRiwhMChkQnthDB+2hz8ZoIazxF6rztSkDDDCw0kCp wMQTcvorwBTF+oSBPAYEJuoPgUkFA8IT++aV++YF47IC3PiLBkGbMsAAA1cM1AhMFGl5ijR9pa8Y 6MOAwETNsaAws7eJ3N8KT3iK9PT0WiYybcAAAwxkNuAJOX0URgpU/cAAA5cGBCb2F5n3F+mvXXgi PInPOkxq6SeGeBQGmjZloHMDpU6XeEKO4k8AwAAD2w14Qo66Ql3RkQHhif18/H6+I+DxNweMNmWA gWEMCEy2FzSKQW3HAAOlDDhdopYQmHRqQHgyzB64ozHWKXYFH+wMMMDAg8BEwVeq4PO6bDGw3YDA RP3QUTFnv3htvyg8YSO+ljD5mfwYYICBngwITLYXNIpBbccAA6UMCEzsFXraK7iWBR6FJ8IT4cmC gRLfSOBpUwYYKGqgVGDikcIKyVKFpNdlawYDAhP7biFFYgPCk6J710nHRuIBoZgzIBhgILGBGoHJ DMWNe1TEM8BApAGBidpg0qJwvD2l8GS8Pm2/7zdBmiAZYICBGgY8UliBF1ngeS2eGIgzIDCxD6ix D/AelZ0JT4Qn8WFLZcTxNwCFNmWAgW4NlDpd4pHCcUWTAlRbMjCfAY8Utv8XZExgQHjS7f448fib YOAoLA0cBhioaEBgMl8hpvjW5wz0b8DpEnv+xAWbfdyWfZzwhJstbm7/jInURMoAAwzsNSAw6b9w UtzqIwbmMyAwsb7vXd/9fGJDwhPhifAk8QCO7zwDQpsy0NBAqcDEE3LmK/AU9fqcgTgDAhN7ZYEH A48GhCfqhPg6weAywTLAAANLDdQITBRRcUWUttSWDMxhQGBiHV+6jvu+iawIT4QnwpOJBnx8ZxtA 2pSBlQY8IWeOwkuBrZ8ZyGdAYGJPLAhh4KYB4Yl9/8p9/4I5xaBb0EjgxcPTptq0WwOlTpd4Qk6+ 4kxBrc8Y6MeAJ+TYs9uzM7DKgPCk2732qn7sq2YyCBN3ngHR12DSH4n7Q2DST4GkWNUXDDDwYsDp Evt0+3QGNhsQnqhN4msTA3LzgIzvDMC1KQMVDQhMFGiKdAYY6M+AwMTe3N6cgRADwhN1RXxdYXCG DM74joFdmzJQwIDApL9CSfGqTxhgQGBiP24/zkC4AeGJWiK+ljBQwwdqfCeBr00Z2GGgVGDikcIK PkU/AwxsNyAwsQe3B2egqAHhifphR/1wxaZBW3TQxneYQaBNGVhgoEZgomjaXjRpO23HwJwGBCb2 3fbdDFQzIDxRMyyoGVZ6NIBXNhiE8Qi1qTbdbcAjhecsxBTg+p2B/g0ITOy17bUZaGJAeLJ7f92k 3/quiwxmKBhgIKeBUqdLPFK4/2JMwayPGOjXgEcK51xT7YX023AGhCfCk/ggxkQx3EQRj8TA06bd GBCY9FswKWb1DQPzGnC6xH7afpqB7gwIT7rZv3dnY3ttZ6AP1JkGyPaBoO06bjuBybwFmWJc3zPQ rwGBiT20PTQDXRsQnqhv4usbg77rQR/f4QaRNk1hoFRg4gk5/RZiimR9w0D/BgQm9s32zQykMSA8 SbHnT+PpqYY0AWgDBhjow0CNwERx1n9xpo/0EQN9GRCY9LFG2qvoBwZWGhCeCE/is46VCOMvQKdq UwYmNeAJOX0VSApW/cEAAy8GBCb2xwp1BtIbEJ6oseJrLBND+okhHoWBpk2LGSh1usQTchR9Cn8G GNhuwBNy7IfthxkYzoDwpNh+fjgry2s/E8XEnW9ALR8o2mpHWwlMthc0ikFtxwADpQw4XWIPbA/M wNAGhCfqlx31y5WxYdIYetKIB2MQatNFBgQmCr5SBZ/XZYuB7QYEJva99r0MTGNAeLJozz6Nh5ga zgQCDAMMxBgQmGwvaBSD2o4BBkoZEJjErHH2CtqRgWQGhCfCk5jA5Lwdkw2C+AaASpsysMNAqcDE I4UVkqUKSa/L1gwGBCb2twp9BqY3IDxR4+yocfzZTnzjAalNpzRQIzCZobhxj4p4BhiINCAwUSxP Xyzbl065L73qXnjCQ/ycYKGx0DDAwG0DHimswIss8LwWTwzEGRCY2MPYwzDAwBUDwhPhifDEBGmC ZKCGgVKnSzxSOK5oUoBqSwbmM+CRwvYANfYA3oOzIQwIT4QnwhOT2RCTWTxkk0NAmwpM5ivEFN/6 nIH+DThdYu9n78cAAxsMCE/URwH10cXY2wAx/iJ0rDZloJEBgUn/hZPiVh8xMJ8BgYn9qWKZAQZ2 GhCeqK/i66udKOMvSCdrUwYKGygVmHhCznwFnqJenzMQZ0BgYk+qWGaAgUADwhM1VXxNFQg0/uJ0 uDZlIMhAjcBEERVXRGlLbcnAHAYEJvahimUGGChkQHiijgqqo87GaCGs8Req87UpAysMeELOHIWX Als/M5DPgMDE3lOxzAADFQwIT9ROK2qnhWOyAtz4iwZBmzLwhoFSp0s8ISdfcaag1mcM9GVAYGK/ uXBjbn9jj8tAlAHhCUtRlj6/jsXMYsZAZgMCk74KJAWr/mCAgZMBjxS2t8i8t3Dt/A5hQHgiPBGe mMyGmMziIU81OQhMFGcKdAYY6M+A0yX2aPZoDDDQkQHhyVT1UaWx1xFwBTXgDFw1IDDpr1BSvOoT BhgQmNhHVtqw2yPaIzKw1oDwhJm1Zu5/v0XPosdArwZKBSYeKazgU/QzwMB2AwIT+4Ze9w2ui00G zgwIT4Qn98OQtW1kkjHJMNCTgRqBiaJpe9Gk7bQdA3MaEJjYK/S0V3AtPDKwwIDwZG0w4Pvvhy0L 4N1/EQ2tjRjYaMAjhecsxBTg+p2B/g0ITOwRFagMMJDYgPBEfbaxPrsx7hMPiPjGAEybVjFQ6nSJ Rwr3X4wpmPURA/0a8IQce0KFMgMMDGRAeFKlrplszAw0QBT+BkjHBgQm/RZMill9w8C8BpwusQ+c bONvr9jxXpHF4PlIeGK8x4/3YKTxF6jTtWlaAwKTeQsyxbi+Z6BfAwITez9FKgMMTGBAeJK2hup4 fE4wcIQPBk5FA6UCE0/I6bcQUyTrGwb6NyAwsd/reDNun1Zxn8bBRHOB8MTcEj+3TDSA4hsPSG36 aKBGYKI4678400f6iIG+DAhM7PEUygwwMLEB4YlaNb5WnXhAxTcmoJO0qSfk9FUgKVj1BwMMvBgQ mNjXKZYZYICBRwPCE7VpfG1qcJlgGVhioNTpEk/IUfQp/BlgYJ8BgYl1fMk67ns4YWAyA8IT4Ynw ZLJBH9/hBtGKNhWY7CtoFITajwEGShjwSGF7IUUwAwwwcNfAvfDk62Mbfnj68/vT/x/h62V9vNs2 K+ohr/VqrBl4QDBwbkBgotgrUex5Ta4Y2GfA6RJrtf0aAwwwsMqA8MQvzeNDIoNw1SCM7wCoO2hT gcm+okZRqP0YYKCEAYGJPZo9GgMMMLDZgPBEnRlfZxqQmwdkfGcAXrFNSwUmHimsiCxRRHpNrmYx IDCxL7MvY4ABBkIMCE/UlvG1pcEZMjjjOwb2Am1aIzCZpcBxn4p5BhiIMiAwsRezF2OAAQbCDQhP 1JPx9aSBGj5Q4zsJ/I1t6pHCiruo4s7rsMRArAGBif2X/RcDDDBQ1IDwRA25sYa84dKgLTpo4zvM ILjTpqVOl3ikcGzhpBDVngzMZcATcuy37LcYYICBqgaEJ+rG+FrcIK46iOM70KA4tqnAZK4iTNGt vxnIYcDpEnsseywGGGCgmQHhiToxvvY2oJsN6PjOnGqACExyFE+KXP3EwFwGBCb2VfZVDDDAQBcG hCdT1YaVzBnclRoa3oCwSGAyVxGm6NbfDOQwIDCxl7KXYoABBrozIDxRfwbUnxeuDfTuBnp8J6ce OKUCE48UzlGUKZ71EwN9GhCY2D/ZPzHAAANdGxCepK4BO7Vl0HfaMVNjrxGYKMj6LMj0i35hoF8D AhN7JnsmBhhgII0B4cnU9WQhpyaAQg0L64oTNB4p3G+xpJDVNwzMbUBgYp9kn8QAAwykNCA8UY+u qEcXGjcZLGwo+ILxlTpd4pHCcxd6Cn39z8A+Ax4pbF9kX8QAAwwMYUB4on4Nrl+P48LkoA3qGRCY 7CtqFIXajwEGShhwuqTeOmjPoa0ZYICBSgaEJ8KT+KyjEt74C4chSZsKTBR7JYo9r8kVA/sMCEzs fxRwDDDAwNAGhCfq5fh62aQx9KQRD2bVILw8/n3636c/q9n65Qk5+4olxab2Y2BuAwITex57HgYY YGAaA8KTVXXbNC721ccmEFDKGTht1D9+PLz6WvvhsOffr/Cbu/DT//qfgfUGBCbl1jj7B23LAAMM dGxAeCI82ReUvNV+HYOPv1mAKrfpW+HJvTDF6ZL1xZGC8n6bvbjSVvfbShvlbyOBib2Ngo4BBhiY 3oDwRO0bX/uaWKafWOJRfRqoS8KTyzDl9L9PP6eAy1/Ate7D1wXkV4+uhChctXZZ4v09Icdexl6G AQYYYODCgPBEeBJf55poTDTlDAhPFKolCsVbr3krMDkc3h8XkffCufdc1nZZ4v2cLim3dtkXaFsG GGBgAAPCE+GJ8GSAgRzfid0ODOGJIrVE0Xj5mksCk5fgRHjCZA2Tpd5DYGIPoKBjgAEGGFhoQHjS bY2Y2PBCfBMV/Ik7s7sBIjxRqJYqIk+v+9bTnE7/7jwoeeuf/VkYlyVdRr+2wMQ+xb6EAQYYYGCD AeFJd7XhAI43QBSkgLjQgPBEkRpdSJ6/3lNQ8vExRLkXmDh5wmJJi9GvLTCxNxlgg2mvtHCvpK+N dwYKGRCemIfj5+FCWOMvVOcnbFPhiYI1uqgUnjBV0lTL1xaY2I8ooBhggAEGAg0IT9TP8fVzIND4 i9PhydtUeKLQLVmMOnnCV0lfNV5bYGIPolBigAEGGChkQHiilo6vpQthjb9QnZ+wTYUnituSBajw hK+Svkq8tkcK23MokhhggAEGKhkQnqif4+vnSnjjLxyGBG0qPFHclihAX15TeMJXSV9Rr+10iX2G QokBBhhgoIEB4Yl6Ob5ebgA5/ibA6LRNhSeK26gC9K3XEZ7wVdLXntcWmNhbKJQYYIABBhobEJ6o keNr5Mao428Iko7aVHiiuN1TgN77WeEJX/eM1PzvAhP7CYUSAwwwwEBHBoQn6uL4urgj4PE3B0zj NhWeKG5LFq/CE75K+lry2gITewiFEgMMMMBApwaEJ2rh+Fq4U+zxNwpPgzYVnihulxSgW79HeMLX Vjt7fk5gYt+gUGKAAQYYSGBAeKL+ja9/E8CPv2mQKrWp8ERxu6dIvfezwhO+7hmJ+O+ekGOfoEhi gAEGGEhoQHii5o2veRMOhPhGAKtQmwpPFLcRxeu11xCe8FXKl9Ml9gYKJQYYYICB5AaEJ2rc+Bo3 +aCIbxDIAttUeKK4LVXcnl5XeMJXpC+Bif2AQokBBhhgYCADwhN1bWBd+zw3DDRA4hsHuJ1tKjxR 3EYWt5evJTzha68vgYk9gEKJAQYYYGBQA8ITtezOWvaNuWHQwRLfUPBtaFPhieJ2b3F76+eFJ3xt 8SUwse4rlBhggAEGJjAgPFG/bqhf78wNEwyc+EYDcWGbCk8Ut1uK26U/Izzha42Vl9DEhtm6zwAD DDDAwAQGhCdq1oU164r5YIKBE99oIC5sU+GJ4nZpcbvl+4QnfN07mSQwscav2BBZ2xeu7drUuGKA gRQGhCfWtfh1zeBPMfjjO77KYBKeKG63hCJLf0Z4wte5FY8Utp5bzxlggAEGGPhkQHhSpd6bbMwZ YJN1eNVBJDxR3C4NQrZ8363w5PXnWrw/uv/8dfpvW97Pz/Tn2eeXWMOt4QwwwAADDLxpQHhSte6b ZBwabJN0dJPBIzzpr9gcKQBYEp4cDj/z/Ehj4ckofS8wsW5btxlggAEGGLhrQHjSpP672y9J/6Li +b4MvME7uOmgEZ4IT0oW7NfCk9O//73fO81tP3oMTp6+T3hSsi9Kv7bAxFptrWaAAQYYYGCVAeFJ 0zpwVV/lCVQMwkE7tovBIjwRnpQsqm+FJ0//7f8dv/5IePI+p0OBifXZ+swAAwwwwMBmA8KTLurB zf3XZ6BiQA7WoV0NEuFJzqK1ZOAR+dr3w5P//UVwcjqB4jNP+nUpMLEmW5MZYIABBhgIMSA86aou DOnT9oGKwTlIR3Y5OIQn/RapkSFGq9da8pknl3+yIzzpy6Qn5FiDrcEMMMAAAwwUMSA86bI+LNLX 9UIVgzV5B3Y9KIQnfRWqrUKOUu/rUcU5fTldYt217jLAAAMMMFDcgPCk6zqxeP+XCVQM3KQdl2Iw CE9yFrelwo7o1xWe5PElMLHWWmsZYIABBhioakB4kqJerGpif6BiECfrsFSDQHiSp7iNDjZqvJ7w pG9fAhPrq/WVAQYYYICBZgaEJ6nqxmZO1gUqBnSSjkqJX3jSd3FbI+Ao+R7Ck/58CUysqdZUBhhg gAEGujAgPElZP3Zh53qgYnB33kGp0QtP+ituS4YZtV9beNKHL4GJddQ6ygADDDDAQHcGhCep68ju PD0FKga6NihnQHjSR3FbO9So9X7Ck3a+BCbl5k1rkrZlgAEGGGAgwIDwRHgSn3UEwIy/KB09SJsK T9oVt7UCjJbvIzyp58sjha2VNvIMMMAAAwykMiA8UVPH19QmgVSTQDyAooNKeFKvuG0ZYrR6b+FJ WV9Ol1gfrY8MMMAAAwykNSA8KVrnpXWxr542IUza8VUGk/CkbHHbKrTo5X2FJ/G+BCbWRGsiAwww wAADQxgQnlSp94awsjxQMTlM1uFVB5HwJL647SW46OE6hCcxvgQm1kHrIAMMMMAAA8MZEJ5UrfuG 8/N2oGKimKSjmwwe4UlMcdtDUNHjNQhPtvsSmFj7rH0MMMAAAwwMbUB40qT+G9rU4DcHzPIjSEXa SniyvbjtMazo7ZqEJ+t8CUxskq35DDDAAAMMTGNAeFKkvpvGj5MnJsva2IUn64rb3sKJ3q9HeHLb lyfkmPNrz/nejzkGGGCAgW4MCE+EJ/EHCQzwbgZ4fOc2HzDCE+FJyQBGePKlL6dLrGnWNAYYYIAB Bhg4GhCeNK8FB3RochmwU7sZKMIT4YnwpLwBgYl1zDrGAAMMMMAAAxcGhCfd1IQD2TTRDNSZ3Q0Q 4Un5wrlkONH7a8988kRgYu2ydjHAAAMMMMDADQPCk+5qwwG8mnQG6MRuB4bwRHhSMoCZLTwRmFiv rFcMMMAAAwwwsNCA8KTbGjGx4YX4Bvw8jsSdlmYgCE+EJ8KTfQYEJtYoaxUDDDDAAAMMbDAgPElT MybyvQGiIAXEhQaEJ/sK55LBwwivPerJE4GJdSnRJsJ6uHA91KfGNQMMMFDZgPDEGh2/RldGHH8D UHTcpsIT4UnJkGaU8MQjha1DNtQMMMAAAwwwEGxAeKJOjq+Tg5HGX6BOT9ymwhPhScvw5CWUOBze H+eRz1+nf1/yupa8ttMl1h6bZAYYYIABBhgoaEB4oo6Or6MLgo2/WACStanwRHiyJEjY+j23Tp48 /befPn7904enf24fnghMrDc2yQwwwAADDDBQyYDwRO0cXztXwht/4TAkaFPhifBkazCy5OeuhSeX fwbTMjwRmFhjbJIZYIABBhhgoIEB4Yl6Ob5ebgA5/ibA6LRNhSfCkyUhyNbvuReeHA7/8zg3/EH1 kycCE+uKTTIDDDDAAAMMNDYgPFEjx9fIjVHH3xAkHbWp8ER4sjUYWfJz98OTP/4iODn9+U6JzzwR mFhLbJIZYIABBhhgoCMDwhN1cXxd3BHw+JsDpnGbCk+EJ0tCkK3fc/8zT35ULDzxhBxrhw0yAwww wAADDHRs4Fp48u3xmr85fn19/PpweNorHv//CF+fH5bQcb80rk93jlkNu7MBBTQ3BoDwRHiyNRhZ 8nP3HlV8+VknLx8au/XkidMl1gvrBQMMMMAAAwwkMSA8UafGBzVJ8MffOEwV2lR4IjxZEoJs/Z57 4cnlI4q3hCcCE2uETTIDDDDAAAMMJDQgPFHvxte7CQdCfCOAVahNhSfCk63ByJKfKxWeCEysCzbJ DDDAAAMMMJDcgPBEjRtf4yYfFPENAllgmwpPhCdLQpCt3xMZnghMrAU2yQwwwAADDDAwkAHhibo2 sK59nhsGGiDxjQPczjYVnghPtgYjS35ub3giMDH/2yQzwAADDDDAwKAGhCdq2Z217Btzw6CDJb6h 4NvQpsIT4cmSEGTr9+wJT55+1vynDRhggAEGGGCAgSENCE/sdeP3+iaLISeLeCibBp/wRHiyNRhZ 8nN7whPj3tzPAAMMMMAAAwwMbEB4sql+MyZujomBB0wnAcLMAIUnwpMlIcjW7xGemL9nnl/dO/8M MMAAAwzcMCA8EZ7E5wEmHZNOOQPCE+HJ1mBkyc8JT8qNXfOitmWAAQYYYICB1AaEJ8IT4YlJLNMk JjwRniwJQbZ+j/DEfJhpPnStvDLAAAMMMFDRwJLw5AeHh8f95IfjdQ3w9fIwBM6KOSv2wpKu+KQr XZsKT4QnW4ORaz93/oQc4Yn52+aAAQYYYIABBhh404DwJF3tmGAsG2wJOiktfOGJ8CQiPHn9SOH3 T78hOIaTwhPzt/mbAQYYYIABBhgQnjydnHHypPhYKP4GaQt/E/F+G8IT4cmW8OTL0yXvj/PI5y/h yf6xaX7ThgwwwAADDDAwtAEnT9Th8X8JYtIYetKIB7NqEApPhCdLw5PL0yXnYcnlPwtPzNvmbQYY YIABBhhg4KYB4cmqus14WjSeFn2Thm8cQmTFLDwRntwKT+6dMLkWoAhPzNtZ50TXzS4DDDDAAAOV DAhP1PDxNXwlvPEXDkOCNhWeCE8uw5PXJ0y2fW6J8MS8bePJAAMMMMAAAww4efL0WScvXz7zpPiY KP4GQo4EIUepxUd4Ijw5hSeXgcm5t6Uf+vrqNb766uwDsT4+f3Ds689FWfJnP6Xce13rCgMMMMAA Awww0NiAkyfq8Pg6vDHq+BuCpKM2FZ7MG57cCkyWhCdf/EnPMTA5XHwtDV6ufWaKTY35nwEGGGCA AQYYGNSA8ERdHF8XDzpY4hsKvg1tKjyZKzxZGphcC08uT5dchiXCE/O1DS4DDDDAAAMMMLDIgPBE /bqhfr1jy+BbNPjiG34KzMKTscOTLz/wdf18cn565NPfab5xyuStIMXJk/Xtbb7TZgwwwAADDDAw hQHhyRT1ZmXLJo/KDT4VYuHJeOHJltMlt8bYqwDk48eHw/HrMpR5/B5/tjPV3GFetjYzwAADDDDA wC4DwhN7x/gDEAblrkEZ3yFDIReejBGeRAcmVz/z5Dk8OQUol19vBSpOnpi/zd8MMMAAAwwwwMCb BoQnQ9WVnYxzg62TjhgSt/Akb3hSMjDZEp5cC1QOB0/bMYdZxxhggAEGGGCAgQsDwpMh68vGzk00 jTtgaNTCk1zhSa3ARHhi3jXvMsAAAwwwwAADRQ0IT4auM4vauf7XJQZto4afArPwpP/wpEVgIjwx 75p3GWCAAQYYYICBogaEJ1PUm0UNfRmiGLSVG3wqxMKT/sKTiCfkRI6Ztz4w9q0/0fFnO+bqSHde iycGGGCAAQYGNyA8marurDSeBx80PtC16aARnvQRnrQ+XXJrMhOemIMrLXZN50L3yDkDDDDAAAOV DQhP7H3is4DKiONvAIqO21R40i486Tkw8Wc75l0bSAYYYIABBhhgoKgB4Yk6Ob5ONmiLDtr4Dks1 CIQndcOTLIGJ8MS8a95lgAEGGGCAAQaKGhCepKobi1qIq8kN2iQdlRK/8KR8eJIxMKkVnry0zeHw /jh+Pn89/amQuU8bMMAAAwwwwAADwxoQntjvxu/3TRjDThjxWFYPQOFJmfAke2BSIzx5Ckj+9fHr Jx+e/ll4Yq6z3jHAAAMMMMDANAaEJ6trt2lsbK+TTSCQlDMgPIkLT0YKTEqHJ49hyY9+9BiavHX6 xMmTcmPefKptGWCAAQYYYKALA8IT4cn2kORa2xncXQzu+I7tYrAIT7aHJ709UrjUOCnxtJ3Pgckf HcfBHzp5Muj8Usqk17UvYIABBhhgYAADwpMu6sHBxtIAA0Nh0O3AEJ6sC09GPV1ya9IsG5788RfB yenPd5w8Me8PtpB3uwZoZ2ONAQYYYKCZAeGJ/UF8TmBANxvQ8Z3Z3QARntwPT2YMTEr/2c5LQOID Y83v5ncGGGCAAQYYmNSA8KS72nCAsTjpYJoguOgBp/Dk7fBk9sCkRnhy+YQdHxhrru9hTnQNHDLA AAMMMFDJgPBEeBJf81fCG3/hMCRoU+HJ5/BEYPL2XFPiz3ZuBSf+bMecb9PKAAMMMMAAAxMYEJ6o l+Pr5QkGTnyjgbiwTWcPTwQm9+cX4cn9NrLB00YMMMAAAwwwwMBKA8ITNevCmnXF2FqJMP4CdOrA bTpbeDLLE3JWTDB3x7fwxBwc6clr8cQAAwwwwAADjwaEJ3f34cbK6rGy+gd0wsBhR/QAmiE8cbpk 3xwiPNnXftFj1uvpDwYYYIABBhgYwoDwRN0eX7ebHIaYHOJhhAy2UcMTgUncvCE8iWtLc5m2ZIAB BhhggAEGng0IT0LqOZ5ezSkmGCDKGRgpPBGYlHEiPCnTruY17coAAwwwwAADUxsQnghP4g8YmFSm nlTiQb0apNnDE4FJ+flBeFK+jc1x2pgBBhhggAEGpjMgPBGexNe6JpLpJpJ4RFcHZsbwRGBSd04Q ntRtb/Od9maAAQYYYICBKQwIT4Qn8XWvyWOKySMezqLBmCU8EZi0mweEJ+3a3tyn7RlggAEGGGBg WAPCk0X12rD9X6b+NWEAU85Ar+GJRwqX6/O140l40k9frO0736/vGGCAAQYYYKBbA8IT4Ul8gGLA dzvg4zu7+gDqKTxxuqTPsS486bNfzIv6hQEGGGCAAQZSGxCeVK/9UntZVnubFCbo5GYDp3V4IjDp f3wLT/rvI3OkPmKAAQYYYICBdAaEJ81qwHRWlgUnp/Y0EWiDcgZahCcCk3L9WWKsvOqvjx8fDiu+ XgUvh/fHCe3218t7lbgPr5nLnf7SXwwwwAADDAxuQHgiPInPOgYfNPENBuGKNq0VnghM8o/jxyBk RXBy+t4l4Qkb+W3Y3OpDBhhggAEGGFhtQHiibl1Rty70ZSAubCj4NuB7KVw/fjw8rPk6/dz794eb X4riscZuZHjyysb742mU49dT0DJWm7kf/ckAAwwwwAADDFwxIDyx943f+5twTDjlDVw+3eZekHIt PBGYlO+r2uNh75/tXNp6DEmeA5Pz/8/OeHZqW/V+DDHAAAMMMJDIgPBEeCI8STRg4ztrmAHwVsF7 Hqi8hCeX32fBGsf/p88f+ep4T8evzSdP3ghKroUnp/d5eS+ffzKOJfOCvmSAAQYYYICBLwwIT4ap HTsa3wZaR50xNfA3TxAIoIY08RiUPAcZ54HGps88WRGeXAY250GKecBawAADDDDAAAMMDGRAeDJk HdF4jA40QBTaBggDKQxchiefQo0tHxi7Ijw5/PA43x2/Xv0Jj9MoKcw0Xii1kbmVAQYYYICBbAaE J8zGmxWe2JQzwEBdA63Dk5cQ5TxIOT8J40966now/rQ3AwwwwAADDIQbEJ4IT4QnJpbwiSUelYGq Te8auPknNAtPoFz7cNirn3nyfPLkPDxxGsWcak5lgAEGGGCAgQENCE/u7se5X+1+9Q/oBIUxAwzs N/CfjnPPh/t/QvPFhwafBSuR4YnTKNYCGwgGGGCAAQYYGMiA8GT/fl3Nc9mGAw0QnWuAMJDHwHN4 cvj2OAf9l+PXx9dByhehyRufTbL0McWnkyiPQcuNkydOo1gLbJgZYIABBhhgYCADwpM8dUGeGm6g AZKn0UHWVwxcCU8ew5Rvjl9fPz+++Hg65fKEyluhycvnqFz7b68+JHZliHLvQ2ZttKwjDDDAAAMM MMBAZwaEJ+qN+JqzM+TxNwiNNmWgRwOX4cnzU3A+hSc/eB2enAKUe1+LgpPjCZZF37fg81HOH7Ps Q2atJTbNDDDAAAMMMNCRAeGJGii+BuoIePzNAaNNGejVQIHw5F64EnmCxWkUa4cNMgMMMMAAAwx0 bEB4og6Kr4M6Bh9/swBpUwZ6MXAWnnzx+SbHP9k5bDh5siQ8WfI9S06m3PrTodOJlFd/JtRLm7sO 458BBhhggAEGZjEgPGE93rrwRGLMAAMNDNwITx4/v+T5STxLwo4W37MkYLn8sx7OGjiLXzRtRLQp AwwwwAADGQwITziNd2ozq6BhgIEGBi7Ck8PPH6/hFz6f2Og9PFkS2Lz5NKD4SdzCqE0ZYIABBhhg gIFLA8ITJuLnhQZFU/xNgKFNGchm4DI8+eXjXPTvxgpPzgMWHyhrrRHSMsAAAwwwwEBFA8IT9VF8 fVQRcPzFA6FNGchq4DI8+Q/Huej7nwOUEU6eCE+sLzbJDDDAAAMMMNDIgPBEnRRfJzXCHH8jcGhT BjIZuHjazqsPWD1+WKzwxNxss8kAAwwwwAADDGw2IDxRG8XXRgbk5gEZ3xmAa9N5DNx6VPHpaTud f2Dsks88cfLE+mJ9YYABBhhggIFGBoQn89QV9WrIRpjr3SA02pqBHg0IT7js0aVr4pIBBhhggIEx DAhPxujHvsaj8EQazAADDQwITyxofS2G+kN/MMAAAwwwMJIB4QnP8Z4bFE3xNwGGNmUgmwHhCbPZ zLpeZhlggAEGGMhjQHiSp6/yjCvhiVMHDDDQwIDwxIKWZ6HUV/qKAQYYYICBbAaEJ8zGm21QNMXf BBjalIFsBoQnzGYz63qZZYABBhhgII8B4UmevsozroQnTh0wwEADA8ITC1qehVJf6SsGGGCAAQay GRCeMBtvtkHRFH8TYGhTBrIZEJ4wm82s62WWAQYYYICBPAaEJ3n6Ks+4Ep44dcAAAw0MCE8saHkW Sn2lrxhggAEGGMhmQHjCbLzZBkVT/E2AoU0ZyGZAeMJsNrOul1kGGGCAAQbyGBCe5OmrPONKeOLU AQMMNDAgPLGg5Vko9ZW+YoABBhhgIJsB4Qmz8WYbFE3xNwGGNmUgmwHhCbPZzLpeZhlggAEGGMhj QHiSp6/yjCvhiVMHDDDQwIDwxIKWZ6HUV/qKAQYYYICBbAaEJ8zGm21QNMXfBBjalIFsBoQnzGYz 63qZZYABBhhgII8B4UmevsozroQnTh0wwEADA8ITC1qehVJf6SsGGGCAAQYSGXj37t3DQXjCbLzZ BkVT/E2AoU0ZyGZAeMJsNrOul1kGGGCAAQZSGBCeqPEL/XJcwxZq2BQTi3vnv5kB4Yk5wgaUAQYY YIABBhgoZOAUoDyGKN8c9/s/fPp6/N/fHv/59O++Pn794PnffTj+8wBfn+65UJs2qxv6uR/FIwQM MNDAgPDEZqmfhVBf6AsGGGCAAQYGNfASKHwKFoQnrG+33qBo2n6xOlrbMTCKAeEJy6NYdh8sM8AA AwwwkMLAZZDyKVAZ4NTJ6eSMkyfFs43ib5BiIDl5wAEDlQ0IT8yNNpoMMMAAAwwwwEBjA9cClfN/ n+VPeoQnxeuZ4m9gQmg8IQgFGO/SgPDE3GhuZIABBhhggAEGEhjIErAIT4rXfcXfwISQYELosrjW bmOPHeHJ2P1r/OpfBhhggAEGGJjIQA8Bi/CkeLZR/A1MGhNNGkIY42mxAeGJudHcyAADDDDAAAMM TGSgdMAiPCleixV/AxPCRBPC4sJZmxgXwhMGzAMMMMAAAwwwwAADrwwsCVgeH7n8xofcCk+KZxvF 38CEYEJggIEvDQhPjAvjggEGGGCAAQYYuGHg4cr/+YXt5yfrvBW2aJ9iGUexFzYRWAwYYOC6AeGJ 8WF8MMAAAwwwwAADFwauBSa3/r2wQE1fyYCGrtTQJkaLIwPnBoQnPJgTGGCAAQYYYGB6A1vCkiU/ o8ZT5xcwoFELNOr0k6A2Na7uGhCemCdsmBlggAEGGGBgWgNLApDI77m7N2VxWosrbCjyVjQWUCYV BqIMCE9YirLkdVhigAEGGGAgtYHIkGTJa6n/ZAAbDWi4jQ2XeoJyz9w3NyA8MYfY6DLAAAMMMMAA A28YWBKARH1P8z2xMZBpDCgiDRgGGGhgQHiSaaFwrTY2DDDAAAMMMNDUQFRY4oNnG+z7xxk7Gk/h zAADDQwIT5puQJhvYH6cjQO7+pIBBhhgoAsDpQMV+yX7pQsDGsSgYICBBgaEJ11sOthvYN+Gm30G GGCAAQaKGogIVeyR7JHeMKBRDAwGGGhgQHhSdNPAdAPTNsJMM8AAAwww0L0Bf7Zjj7Rjn6zxdjRe 95ODe+O7WwPCE/OHDSYDDDDAAAMMMMAAA3kMKC67LS7zIDLg9dV6A8KT9W3GmTZjgAEGGGCAgQYG Iv4M5q3XUIepxZMZ0GHJOsyC0WDBYKTAPCE8MZaNZQYYYIABBhjozkCpoGTr69qHF9iHG3dbx53O MCAZYKCBAeHJ1knbz1nwGWCAAQYYYCDMwNZQo8XP2bM32LMba+djTQcYhAww0MCA8CRs08NvA782 EvwywAADDCQ00CLwKPGe9j72Po0MaPhGDW/BSbjgsBI4XwhPzAHmAAYYYIABBhgoaqBEcNHba9qf B+7Pjcd741FjG3AMMNDAgPDk3uTsv1vAGWCAAQYYYGC1gdLhRsS+OfoaI67JazSoB/KNb41koDDA QAMDwpPVmyFOGzjNt6hzpc8YYICBCQ1EhxHnr1dj/7H3+mtco/ewDzsa0AjagAEGGhgQntjcWn8Y YIABBhhgYLOBvYHDtZ9vvS/ecl8R1/zyvhGv5TUa1BZ15pJhb2zzRAQ7EwxUMCA8MUfVWeS0s3Zm gAEGGBjGwJZg4d7P9LjvvXfNl//98h7W/vyW7++x3VxT8Rqm+BsMM1nByAoDgQaEJ+ZGm3kGGGCA AQYYuGtgS2F/72d63tPeu/YM/73n9nVtu+qZXT98d7DrHO3LAANvGhCemD9tmBlggAEGGGDgTQMl AoIMe/IS9936NTO0u2tcXK8t/kaTu8mdAQbiDAhP4tqSS23JAAMMMMBAagMlCvwsBXGJe+/1NbP0 ieu8mpEIT+BggIEGBoQnqTd5xkyDMaMwMmYYYICBoQyUKPCzrM8l7n3Ja95qnyU/H/k9WfrKdb7a 89kAAsEAAw0MCE+G2gAaQw3GkCLKGGKAAQZSGogswG+9Vo9rc8l7L32/Ja699DV7/fD9WfgLppzE wOKAgcoGhCfmSpt+BhhggAEGJjZQohi/95q197v3rmfPf699L+fvt+e6z3+25T147021z6YfMtFP PNEbaMZMiAHhiXnUPMoAAwwwwAADrwxEFeVLXydkT3fRh0vfe+33lbjWiNdcex+X3x9xDV6jWn1W 7Y0sDhYHBhj4bEB4YjwYDwwwwAADDDBw18De4nztz28pxNe+x5Lv33IdLX5myb3c+54W1+09N+Ug m37o7iDXGdqVAQZuGhCemEdtmBlggAEGGEhsoNUJgnuFeIn//taertb79F5T7G2H3u/P9fnAWAtV 4oXKAB4klBGemIfMQwwwwAADDCQzsLZQrrVvXXtdPX1/rTYq8T5727HENXnNorVS0Re3ICRbEAw2 46GaAeGJ+dH8yAADDDDAQAIDewvkFidUoq85+vWq7TcL+Ypoj+xtMOn1KxYn7XiLdaHJlKeFc4rw xBg0BhlggAEGGOjUQERxvPQ1au0dl15Pqe+rdZ+l3ieyXUpdo9ddWIdsn3eKv4FFYXvnaDttN66B W+HJN8d56cPh4d27d4//f4Sv07083g/T2oABBhhggIE0BiIL5iWvVXOfsOR6or+n5v1FvFfk/Udc j9donl00v4A0kyesrDAQaEB4Yu5TPDDAAAMMMJDMQGQxfe+1Wuw7711T9H9vcY/33nOGe7zXBv77 1ZonsBhKNvlBoe8ZaGhAeGLDbM1ggAEGGGBgAAPRxfZbr9dyz1rj/s7fo8W9Rt9ji3vwnlXqmipv YmEYYGEwII2VUAPCE/OieZEBBhhggIEBDUQX4rOHKaf7D92DPpsr0U8lrtNrdlWDdXUxRQYGcPqY gQ4NCE/MdwNumM01Hc41nJlrGGCgIwORBXtPa07kfS15ra33vuS1137P1mvxcyn3DCkv2iLQ0SJg 4BtDmwwIT8xj5jEGGGCAAQYYeDSw9P827bkatPHS+4n8vmttE/keL6+VpR9cZ3idFv6CFoEGE5SB wXE6A8ITc6W5kgEGGGCAAQamMVAixKj1mun22cZVqXGl6DQYGGCggQHhSalJ3evaMDDAAAMMMMBA CgO1wo8t76M+aFAf9D9uNYqBwQADDQwIT1JsaoyNBmOj/40Du/qIAQYYYKCIgS0hR+TP2PfY99wx oIEMEgYYaGBAeFJk08FyA8s20CwzwAADDDBQzEBkONLbk4vs29Lt29JdcLGBCS8LDFQ0IDwxl9lo MsAAAwwwwAADKw1EhCn2/BX3/Cv7t/O+0XCdd5AJdawBpz9f+lN4woKxzQADDDDAAAMMBBhYEqio +dT9AQY0YkAjmvQCJj39MNlYFJ6YN8wbDDDAAAMMMMBAAQMeKTxZXVHA0JXaVMMq2hlgoIEB4YnN Ur2FTltrawYYYIABBhhggIG9BhoUTTptb6f5eYbyGxCe5O9D41AfMsAAAwwwwAADDMxjQHji1AED DDQwIDyx0M6z0Oprfc0AAwwwwAADDOQ30KBoyt9o4OtDBvYaEJ4wtNeQn2eIAQYYYIABBhhgoJ4B 4YlTBwww0MCA8MRCV2+h09bamgEGGGCAAQYYYGCvgQZFk07b22l+nqH8BoQn+fvQONSHDDDAAAMM MMAAA/MYEJ44dcAAAw0MCE8stPMstPpaXzPAAAMMMMAAA/kNNCia8jca+PqQgb0GhCcM7TXk5xli gAEGGGCAAQYYqGdAeOLUAQMMNDAgPLHQ1VvotLW2ZoABBhhggAEGGNhroEHRpNP2dpqfZyi/AeFJ /j40DvUhAwwwwAADDDDAwDwGhCdOHTDAQAMDwhML7TwLrb7W1wwwwAADDDDAQH4DDYqm/I0Gvj5k YK8B4QlDew35eYYYYIABBhhggAEG6hkQnjh1wAADDQwITyx09RY6ba2tGWCAAQYYYIABBvYaaFA0 6bS9nebnGcpv4F548oPDw7t37x4OH45z1ABfp3t5vB92tQEDDDDAAAMMMMAAAxkNCE8UMwww0MCA 8CTjguGabXQYYIABBhhggAEGZjXQoGiCbVZs7pv9zwaEJ8aD8cAAAwwwwAADDDDAQB4DwhOnDhhg oIEB4YmFMs9Cqa/0FQMMMMAAAwwwwECDokmjG3gMMCA8YcA8wAADDDDAAAMMMMBAHgPCE6cOGGCg gQHhiYUyz0Kpr/QVAwwwwAADDDDAQIOiSaMbeAwwIDxhwDzAAAMMMMAAAwwwwEAeA8ITpw4YYKCB AeGJhTLPQqmv9BUDDDDAAAMMMMBAg6JJoxt4DDAgPGHAPMAAAwwwwAADDDDAQB4DwhOnDhhgoIEB 4YmFMs9Cqa/0FQMMMMAAAwwwwECDokmjG3gMMCA8YcA8wAADDDDAAAMMMMBAHgPCE6cOGGCggQHh iYUyz0Kpr/QVAwwwwAADDDDAQIOiSaMbeAwwIDxhwDzAAAMMMMAAAwwwwEAeA8ITpw4YYKCBAeGJ hTLPQqmv9BUDDDDAAAMMMMBAg6JJoxt4DDAgPGHAPMAAAwwwwAADDDDAQB4DwhOnDhhgoIEB4YmF Ms9Cqa/0FQMMMMAAAwwwwECDokmjG3gMMCA8YcA8wAADDDDAAAMMMMBAHgPCE6cOGGCggQHhiYUy z0Kpr/QVAwwwwAADDDDAQIOiSaMbeAwwIDxhwDzAAAMMMMAAAwwwwEAeA8ITpw4YYKCBAeGJhTLP Qqmv9BUDDDDAAAMMMMBAg6JJoxt4DDAgPGHAPMAAAwwwwAADDDDAQB4DwhOnDhhgoIEB4YmFMs9C qa/0FQMMMMAAAwwwwECDokmjG3gMMCA8YcA8wAADDDDAAAMMMMBAHgPCE6cOGGCggQHhiYUyz0Kp r/QVAwwwwAADDDDAQIOiSaMbeAwwIDxhwDzAAAMMMMAAAwwwwEAeA8ITpw4YYKCBAeGJhTLPQqmv 9BUDDDDAAAMMMMBAg6JJoxt4DDAgPGHAPMAAAwwwwAADDDDAQB4DwhOnDhhgoIEB4YmFMs9Cqa/0 FQMMMMAAAwwwwECDokmjG3gMMCA8YcA8wAADDDDAAAMMMMBAHgPCE6cOGGCggQHhiYUyz0Kpr/QV AwwwwAADDDDAQIOiSaMbeAwwIDxhwDzAAAMMMMAAAwwwwEAeA8ITpw4YYKCBAeGJhTLPQqmv9BUD DDDAAAMMMMBAg6JJoxt4DDAgPGHAPMAAAwwwwAADDDDAQB4DwhOnDhhgoIGBy/Dk4+Hh3bt3D4dv j9fyzfHrB8//+8Pxnwf4Ot3b4/3lWRxcq75igAEGGGCAAQYYYOCzgQZFE4AAMsCA8IQB8wADDDDA AAMMMMAAA3kMCE/8JpgBBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAAD DDDAAAMM5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMM MMAAAwzkMSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwww wAADDOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDA AAMM5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMMMMAA AwzkMSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwwwwAAD DOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDAAAMM 5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMMMMAAAwzk MSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwwwwAADDOQx IDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDAAAMM5DEg PHHqgAEGGhi4F558fXh49+7dw+HD8doG+Drdy+P95FkcXKu+YoABBhhggAEGGGDgs4EGRROAADLA gPCEAfMAAwwwwAADDDDAAAN5DAhP/CaYAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwAD whMGzAMMMMAAAwwwwAADDOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPC EwbMAwwwwAADDDDAAAMM5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8IT BswDDDDAAAMMMMAAAwzkMSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMG zAMMMMAAAwwwwAADDOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbM AwwwwAADDDDAAAMM5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswD DDDAAAMMMMAAAwzkMSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMM MMAAAwwwwAADDOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwww wAADDDDAAAMM5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDA AAMMMMAAAwzkMSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAA AwwwwAADDOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAAD DDDAAAMM5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMM MMAAAwzkMSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwww wAADDOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDA AAMM5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMMMMAA AwzkMSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwwwwAAD DOQxIDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDAAAMM 5DEgPHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMMMMAAAwzk MSA8ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwwwwAADDOQx IDxx6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDAAAMM5DEg PHHqgAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMMMMAAAwzkMSA8 ceqAAQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwwwwAADDOQxIDxx 6oABBhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDAAAMM5DEgPHHq gAEGGhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMMMMAAAwzkMSA8ceqA AQYaGBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwwwwAADDOQxIDxx6oAB BhoYEJ5YKPMslPpKXzHAAAMMMMAAAww0KJo0uoHHAAPCEwbMAwwwwAADDDDAAAMM5DEgPHHqgAEG GhgQnlgo8yyU+kpfMcAAAwwwwAADDDQomjS6gccAA8ITBswDDDDAAAMMMMAAAwzkMSA8ceqAAQYa GBCeWCjzLJT6Sl8xwAADDDDAAAMMNCiaNLqBxwADwhMGzAMMMMAAAwwwwAADDOQxIDxx6oABBhoY OA9Pfnh8/4+Hh3fv3j0cvj3+8zfHr6+f//eH4z8P8HW6t8f7y7M4uFZ9xQADDDDAAAMMMMDAZwMN iiYAAWSAAeEJA+YBBhhggAEGGGCAAQbyGBCe+E0wAww0MCA8sVDmWSj1lb5igAEGGGCAAQYYaFA0 aXQDjwEGhCcMmAcYYIABBhhggAEGGMhjQHji1AEDDDQwIDyxUOZZKPWVvmKAAQYYYIABBhhoUDRp dAOPAQaEJwyYBxhggAEGGGCAAQYYyGNAeOLUAQMMNDAgPLFQ5lko9ZW+YoABBhhggAEGGGhQNGl0 A48BBoQnDJgHGGCAAQYYYIABBhjIY0B44tQBAww0MCA8sVDmWSj1lb5igAEGGGCAAQYYaFA0aXQD jwEGhCcMmAcYYIABBhhggAEGGMhjQHji1AEDDDQwIDyxUOZZKPWVvmKAAQYYYIABBhhoUDRpdAOP AQaEJwyYBxhggAEGGGCAAQYYyGNAeOLUAQMMNDAgPLFQ5lko9ZW+YoABBhhggAEGGGhQNGl0A48B BoQnDJgHGGCAAQYYYIABBhjIY0B44tQBAww0MCA8sVDmWSj1lb5igAEGGGCAAQYYaFA0aXQDjwEG hCcMmAcYYIABBhhggAEGGMhjQHji1AEDDDQwIDyxUOZZKPWVvmKAAQYYYIABBhhoUDRpdAOPAQaE JwyYBxhggAEGGGCAAQYYyGNAeOLUAQMMNDAgPLFQ5lko9ZW+YoABBhhggAEGGGhQNGl0A48BBoQn DJgHGGCAAQYYYIABBhjIY0B44tQBAww0MCA8sVDmWSj1lb5igAEGGGCAAQYYaFA0aXQDjwEGhCcM mAcYYIABBhhggAEGGMhjQHji1AEDDDQwIDyxUOZZKPWVvmKAAQYYYIABBhhoUDRpdAOPAQaEJwyY BxhggAEGGGCAAQYYyGNAeOLUAQMMNDAgPLFQ5lko9ZW+YoABBhhggAEGGGhQNGl0A48BBoQnDJgH GGCAAQYYYIABBhjIY0B44tQBAww0MCA8sVDmWSj1lb5igAEGGGCAAQYYaFA0aXQDjwEGhCcMmAcY YIABBhhggAEGGMhjQHji1AEDDDQwIDyxUOZZKPWVvmKAAQYYYIABBhhoUDRpdAOPAQaEJwyYBxhg gAEGGGCAAQYYyGNAeOLUAQMM1DXw7t27h4PwxEKZZ6HUV/qKAQYYYIABBhhgoG7RpEjV3gwwIDxh wDzAAAMMMMAAAwwwwEAyAzosWYdJPCWe6Q0IT8y75l0GGGCAAQYYYIABBpIZ0GHJOix94ay9jbmT gVOA8hiifHtsjx8evz4+/bvH//3N8evr5//94fjPA3x9ul/hnzmMAQYYYIABBhhggIGMBhRyinkG GGhn4CVUeBWmCE8yLiau2SaIAQYYYIABBhhgYGQD7YomBau2Z4CBcwOXQcr5/85++sTJE9bNdwww wAADDDDAAAOpDaS++JFTLfcmtWXgzMCtYCVDyCI8sdbYLDHAAAMMMMAAAwykNpD64hWXAgYGGHhl YEnI0uIUi/DEWmOzxAADDDDAAAMMMJDaQOqLVzgrnBlgYLWBFgGL8MRaY7PEAAMMMMAAAwwwkNpA 6otfXTTBqr8ZYGCJgeiARXjC3RJ3vocTBhhggAEGGGCgWwPdXphgxIkCBhjo2sCagEV4Yq2xEWKA AQYYYIABBhhIbSD1xXddWBkYbI1q4OH5/0a9v8j7+uJRzAIx8zYDDDDAAAMMMMAAAxkNKHAjCyWv xdOoBl4Ck3v/f9T7d1/GNgMMMMAAAwwwwAADUxuY+uYzpl2uWUpbzcC9oGTJf7fAmGMZYIABBhhg gAEGGGBgAAM6cYBOrFZMa6vxx8uSQGTv93A0viN9rI8ZYIABBhhggAEGBjOgQwfrUEGKkym7DOwN Rtb+vPFnDmaAAQYYYIABBhhggIEEBnRSgk7aVQy7P8b3GFgbhuz5/j3X6Wc5Z4ABBhhggAEGGGCA gYIGNG7BxhV6OAUypIE9AcmanzU2zc8MMMAAAwwwwAADDDDQiQEd0UlHDFlka9s5xteaQGTr97I0 hyX9rJ8ZYIABBhhggAEGOjWgYzrtGGGKUyvpDWwNSm79nPFqzmaAAQYYYIABBhhggIEGBjR6g0ZP XxRrM+Nmj4Etocqe9/OzvDLAAAMMMMAAAwwwwMBOAxpwZwMKQpwQYSDQwHmwYmyanxlggAEGGGCA AQYYYKATAzqik45QgAcW4PrUuGaAAQYYYIABBhhggAEGGAg0oDEDG1MAIgBhgAEGGGCAAQYYYIAB BhhgYDwDwhPhCQMMMMAAAwwwwAADDDDAAAMMMHDDgMYxQBhggAEGGGCAAQYYYIABBhhggAHhyXhH hhwDS96nnjhjYrY4M8AAAwwwwAADDDDAQBoDaS5UWJA8LDApHLbkJbt+Rpub3xhggAEGGGCAAQYY YICBEAMhLyLYEGwwcMXArvSj8g+bVM2HDDDAAAMMMMAAAwwwwMCbBsAAg4ESBirnHk3erkS7eU3j kQEGGGCAAQYYYIABBjo0oFM67BSnOAY6ydMk1ej0TY018y0DDDDAAAMMMMAAAwwkNaDjknacgCVZ wLI3z3jL6d7X7P3njU3zMwMMMMAAAwwwwAADDHRiQEd00hHCkGRhyFY3EYHF2veOeM8Mr7G2XXy/ +Z8BBhhggAEGGGCAAQYWGtBQCxtKuDFJuFHLQ0QYEX2tEdeU6TWi28/rWU8YYIABBhhggAEGGBjW wLA3JuwQdqQwEBU21J6ko6470+vUbmPvZ31igAEGGGCAAQYYYKAbA91cSIpCF1xeShmIChFKXd/e 1426v0yvs7fN/Lz5hgEGGGCAAQYYYICBbgx0cyHCEydFGDgaiPq/XibZqPvJ/Dq99IXrsN4xwAAD DDDAAAMMMLDZwOYfVOgKOxgobCAiMGgxOUZc98tr3Lv+yPeKfK171+2/W3sYYIABBhhggAEGGEhl INXFKtYLF+sGb5/jIaqoL9W/Ude3NDDZeh/R13n5eluvy8/1Oe70i35hgAEGGGCAAQYYODOgMQwI BrIYiCr+I+436lpOrxNxPdGvseT+ot/T65mLGGCAAQYYYIABBhjo1kC3F9ZlQQVyv15uFbuj9duS wn7J96xtlyWvufR71r637+937OkbfcMAAwwwwAADDDAwgQGdPEEnDxtELS3U3/q+Efp9z/2f/+yt toh6j15PmIzgwD1YxxhggAEGGGCAAQYYKG6g+BsMW7jDWd9OZCE/UqAS1S4vpqNeT2BSf4yYl7Q5 AwwwwAADDDDAAANFDBR5UYGJD3YNNxBZ0C95rYwTzpL7qvE9GdvONVsLGGCAAQYYYIABBhhg4IYB jWOA5DRQIwQo/fSXUvZqtk3WNirV9l4353yi3/QbAwwwwAADDDDAwB0DGsggGcNAzcAgk5mS7ZKp HVzrGONcP+pHBhhggAEGGGCAgUYGNHyjhg//sxb38aXlksFBthMXUW3BmTmTAQYYYIABBhhggAEG JjSg0yfs9KmDm6gQIesHzkbdv3Fj7mSAAQYYYIABBhhggIGJDOjsiTp76tBkST/vCRaWvH5P37Pn Xi9/tqf7ci3mdAYYYIABBhhggAEGGChgQKMWaFQhxWBPG8p6ymSJbSGKOXCJE9/DCQMMMMAAAwww wMDkBgCYHICgZ7CgZ6tnIYq5cKsdP8cOAwwwwAADDDDAwAQGdPIEnSwgEZAsNiBEMSeaExlggAEG GGCAAQYYYOALA1BAwQADbxsQpBgbxgYDDDDAAAMMMMAAAww8GgBBGzDAwG0DQhRjxBhhgAEGGGCA AQYYYGByAwBMDmDxn3NoJ2NFiMKAeYABBhhggAEGGGCAgUkN6PhJO15o4tTVZgN7QxRjzrzLAAMM MMAAAwwwwAADyQzosGQdtrngdZ+sRxtYE6JEv7fX45kBBhhggAEGGGCAAQYqGtDYFRtb8OG0x5AG roUoxpb5lQEGGGCAAQYYYIABBgYxoCMH6cghi3J9k2t8nkIUfZarz/SX/mKAAQYYYIABBhhgYJGB Rd+kIHJiggEGGGCAAQYYYIABBhhggAEGZjUgPJGyMcAAAwwwwAADDDDAAAMMMMAAAzcMaBwDhAEG GGCAAQYYYIABBhhggAEGGBCeOFo169Eq980+AwwwwAADDDDAAAMMMMDAXgOSJekiAwwwwAADDDDA AAMMMMAAAwww4OSJlG1vyubnGWKAAQYYYIABBhhggAEGGJjVgGRJusgAAwwwwAADDDDAAAMMMMAA Aww4eSIdnDUddN/sM8AAAwwwwAADDDDAAAMM7DUgWZIuMsAAAwwwwAADDDDAAAMMMMAAA06eSNn2 pmx+niEGGGCAAQYYYIABBhhggIFZDUiWpIsMMMAAAwwwwAADDDDAAAMMMMCAkyfSwVnTQffNPgMM MMAAAwwwwAADDDDAwF4DkiXpIgMMMMAAAwwwwAADDDDAAAMMMODkiZRtb8rm5xligAEGGGCAAQYY YIABBhiY1YBkSbrIAAMMMMAAAwwwwAADDDDAAAMMOHkiHZw1HXTf7DPAAAMMMMAAAwwwwAADDOw1 IFmSLjLAAAMMMMAAAwwwwAADDDDAAANOnkjZ9qZsfp4hBhhggAEGGGCAAQYYYICBWQ1IlqSLDDDA AAMMMMAAAwwwwAADDDDAgJMn0sFZ00H3zT4DDDDAAAMMMMAAAwwwwMBeA5Il6SIDDDDAAAMMMMAA AwwwwAADDDDg5ImUbW/K5ucZYoABBhhggAEGGGCAAQYYmNWAZEm6yAADDDDAAAMMMMAAAwwwwAAD DDh5Ih2cNR103+wzwAADDDDAAAMMMMAAAwzsNSBZki4ywAADDDDAAAMMMMAAAwwwwAADTp5I2fam bH6eIQYYYIABBhhggAEGGGCAgVkNSJakiwwwwAADDDDAAAMMMMAAAwwwwICTJ9LBWdNB980+Awww wAADDDDAAAMMMMDAXgOSJekiAwwwwAADDDDAAAMMMMAAAwww4OSJlG1vyubnGWKAAQYYYIABBhhg gAEGGJjVgGRJusgAAwwwwAADDDDAAAMMMMAAAww4eSIdnDUddN/sM8AAAwwwwAADDDDAAAMM7DUg WZIuMsAAAwwwwAADDDDAAAMMMMAAA06eSNn2pmx+niEGGGCAAQYYYIABBhhggIFZDUiWpIsMMMAA AwwwwAADDDDAAAMMMMCAkyfSwVnTQffNPgMMMMAAAwwwwAADDDDAwF4DkiXpIgMMMMAAAwwwwAAD DDDAAAMMMODkiZRtb8rm5xligAEGGGCAAQYYYIABBhiY1YBkSbrIAAMMMMAAAwwwwAADDDDAAAMM OHkiHZw1HXTf7DPAAAMMMMAAAwwwwAADDOwy8P8BTEN7YmWLCPIAAAAASUVORK5CYII ________________________________________________________________________________
Subject: Re: Progress on SkyScout...
Date: Oct 07, 2013
Thanks, Mike. Sorry I missed seeing everyone at the West Piet FLYIN this su mmer. Maybe next year. Please let me know if you folks have any informal gat hering. Hope to see you sometime, Ray Krause Sent from my iPad > On Oct 7, 2013, at 6:29 AM, Michael Groah wrote: > > Wow Ray! That is so cool. I love it. I've been wondering how your proj ect is going. It looks really great. > > Mike Groah > > > Sent from my iPad > >> On Oct 6, 2013, at 7:45 PM, Ray Krause wrote: >> >> >> >>> From: Ray Krause <raykrause(at)frontiernet.net> >>> Date: October 6, 2013 at 1:14:37 >> >>> Gary, >>> >>> Here are a few photos of the fuselage and mount jig. It's on the gears, t he tank is in place and the firewalls are ready. Notice the mechanical toe b rakes! Just like the big boys, don't know how they will work? The tail wheel is a copy of the Sonex setup. Uses 1/2" titanium rod. Pretty light. I may h ave to re-make the wheel castor to raise the tail a few more inches. All con trol cables have been run and seem to work correctly. Gear springs may have t o be reduced in length, depending on what happens when the motor and the res t of the garbage is added. >>> >>> When I finish the motor mount, I will have to work on the panel. No elec tric wiring required! I will work on the A-65 this winter. >>> >>> Thanks, >>> >>> Ray >> >> >> >> >> >> >> >> >> >> >> >> >> >> Sent from my iPad > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: Center section half moon
Date: Oct 07, 2013
Tom No problem call me when you get time. I will be helping Bob Poore for a couple of days but I will be clear after that. It is at my hangar at Cryystal. Dick N 651-638-0793 ----- Original Message ----- From: TOM MICHELLE BRANT To: pietenpol-list(at)matronics.com Sent: Monday, October 07, 2013 7:00 PM Subject: RE: Pietenpol-List: Center section half moon Dick, That would be great. Actually, I could bring my CC up too as I'd like your feedback on the design I've used to make it a 4'-0" center section. Let's try to figure a time out on the weekend if that will work. My week is buried. Tom B. ------------------------------------------------------------------------- ----- From: horzpool(at)goldengate.net To: pietenpol-list(at)matronics.com Subject: Re: Pietenpol-List: Center section half moon Date: Sun, 6 Oct 2013 23:21:11 -0500 Hi Tom Do you want to see mine, its at my hangar. Dick N. ----- Original Message ----- From: tmbrant(at)msn.com To: pietenpol-list(at)matronics.com Sent: Sunday, October 06, 2013 1:34 PM Subject: Pietenpol-List: Center section half moon Wondering if anyone has any photos of the build up of the center section cutout (half moon). I'm about to do this but having trouble visualizing the process. Thanks, Tom B. Sent from my Verizon Wireless Phone =EF=BD~=EF=BD=03 =EF=BD=EF=BD~=EF=BD=EF=BD,=03g=EF=BD=EF=BD ________________________________________________________________________________
From: "skipgadd(at)earthlink.net" <skipgadd(at)earthlink.net>
Date: Oct 07, 2013
Hi Jim, Thanks, No, no wire. I do tie the scarf through the coat hangar loop in the jacket so it doesn't pull on my neck. Skip ----- Original Message ----- From: Jim Boyer Sent: 10/7/2013 1:09:50 PM Subject: Re: Pietenpol-List: Felix For Sale Hi Skip, I love seeing that white scarf of yours trailing behind. I remember seeing a picture of it streaming out behind when you were parked; did you have a wire in it? Cheers, Jim B. ________________________________________________________________________________
Subject: Re: strut attachment
Date: Oct 07, 2013
If you need to change the position of your wing - and almost EVERYONE needs to - in order to correct your cg location, you need to use your "B" method. Hopefully, you can visualize the parallelogram that "B" provides, which will allow for the cabane struts to be moved fore and back. With the sketch shown in "A," what happens is that the front and rear cabanes will be locked into a fixed relationship. What they need is to be free to act as hinges in the front / rear swing directions. Follow the plans... -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410045#410045 ________________________________________________________________________________
Subject: step
Date: Oct 07, 2013
Back in September, Douwe wrote- > It just makes it easier. Now I wish I had installed one for the front pit too. A step for the front 'pit is very simple and easy. It adds virtually no weight and points straight ahead, so it adds no drag. Take a look at the port side gear leg, aft member, in the top two photos here: http://www.flysquirrel.net/piets/CorkyPiet.html There is a short stub of tubing welded to the aft member of the gear leg vee, maybe 3" long, with a closed end. I use that little step every single time I need to get anywhere into the front 'pit and it works perfectly. Now, if you're getting out of the cockpit, you really can't see where to place your foot to get on it, but if someone is helping they can guide your foot onto it. Getting into the cockpit is infinitely easier by using that little step. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410047#410047 ________________________________________________________________________________
Date: Oct 08, 2013
WF2, Why was it not practical for everyday flying? Granted it is a more complex prop and would be more expensive to build. It would require more thought to make sure it was installed correctly. Once installed and setup, it has all the advantages of an adjustable prop without the additonal hardware and complexity. What are the wear issues? On my other list there is an aerodynamacyst and he has explaned the advantages of one blade. But quite simply, it is easier to build a two bladed fixed prop. On my Vtail it has a two bladed 88 inch prop. This is more efficient than the later and shorter 84 inch prop. Newer models have IO 550s (300HP) that all have 3 blade props. The 3 blade is less efficient, but shorter (less ground strikes) and quieter. Besides it looks "sexier". For a given HP about 1000 to 1300 RPM with a big bladed prop (fewer blades is better) is the most efficient. However, most engines make their HP at higher RPM. On Mon, Oct 7, 2013 at 12:42 PM, womenfly2 wrote: > > Seen it fly at Sentimental Journey this year. They did a demo flight > comparing a standard prop J-3 to an Everal Prop J-3. Everal prop was hard > to beat! > > Climbed faster at a more AOA, faster in level flight. Great idea, but was > not practical for every day flying. > > Cool video! > WF2 > > -------- > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410007#410007 > > ________________________________________________________________________________
Subject: Re: One bladed propeller
Date: Oct 08, 2013
wouldn't a one bladed prop side load the crankshaft/bearing? Putting a bend ing moment at the hub that isn't there with a two or more bladed design. The trailing blades don't get the clean air the leading blade had. Steve > On Oct 8, 2013, at 10:08 AM, Steven Dortch wro te: > > WF2, Why was it not practical for everyday flying? > > Granted it is a more complex prop and would be more expensive to build. I t would require more thought to make sure it was installed correctly. > Once installed and setup, it has all the advantages of an adjustable prop w ithout the additonal hardware and complexity. > > What are the wear issues? > > On my other list there is an aerodynamacyst and he has explaned the advant ages of one blade. But quite simply, it is easier to build a two bladed fixe d prop. > > On my Vtail it has a two bladed 88 inch prop. This is more efficient than the later and shorter 84 inch prop. Newer models have IO 550s (300HP) that a ll have 3 blade props. The 3 blade is less efficient, but shorter (less grou nd strikes) and quieter. Besides it looks "sexier". > > For a given HP about 1000 to 1300 RPM with a big bladed prop (fewer blades is better) is the most efficient. However, most engines make their HP at hi gher RPM. > >> On Mon, Oct 7, 2013 at 12:42 PM, womenfly2 wrote : > >> >> Seen it fly at Sentimental Journey this year. They did a demo flight comp aring a standard prop J-3 to an Everal Prop J-3. Everal prop was hard to bea t! >> >> Climbed faster at a more AOA, faster in level flight. Great idea, but was not practical for every day flying. >> >> Cool video! >> WF2 >> >> -------- >> >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=410007#410007 >> s List Un/Subscription, >> www.matronics.com/Navigator?Pietenpol-List" target="_blank">http://www. matronics.com/Navigator?Pietenpol-List >> ronics.com/" target="_blank">http://forums.matronics.com >> Matt Dralle, List Admin. >> ==== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Oct 08, 2013
Single bladed props were used in the 50s for control line racing models for this exact reason. I recall that the efficiency of a single bladed prop is only matched by contra-rotating props, but I could be wrong on that. Like most things. :-) _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Steve Emo Sent: Tuesday, October 08, 2013 8:08 AM Subject: Re: Pietenpol-List: Re: One bladed propeller wouldn't a one bladed prop side load the crankshaft/bearing? Putting a bending moment at the hub that isn't there with a two or more bladed design. The trailing blades don't get the clean air the leading blade had. Steve On Oct 8, 2013, at 10:08 AM, Steven Dortch wrote: WF2, Why was it not practical for everyday flying? Granted it is a more complex prop and would be more expensive to build. It would require more thought to make sure it was installed correctly. Once installed and setup, it has all the advantages of an adjustable prop without the additonal hardware and complexity. What are the wear issues? On my other list there is an aerodynamacyst and he has explaned the advantages of one blade. But quite simply, it is easier to build a two bladed fixed prop. On my Vtail it has a two bladed 88 inch prop. This is more efficient than the later and shorter 84 inch prop. Newer models have IO 550s (300HP) that all have 3 blade props. The 3 blade is less efficient, but shorter (less ground strikes) and quieter. Besides it looks "sexier". For a given HP about 1000 to 1300 RPM with a big bladed prop (fewer blades is better) is the most efficient. However, most engines make their HP at higher RPM. On Mon, Oct 7, 2013 at 12:42 PM, womenfly2 wrote: Seen it fly at Sentimental Journey this year. They did a demo flight comparing a standard prop J-3 to an Everal Prop J-3. Everal prop was hard to beat! Climbed faster at a more AOA, faster in level flight. Great idea, but was not practical for every day flying. Cool video! WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410007#410007 s List Un/Subscription, www.matronics.com/Navigator?Pietenpol-List" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ronics.com/" target="_blank">http://forums.matronics.com Matt Dralle, List Admin. ==== ________________________________________________________________________________
Date: Oct 08, 2013
Steve, You're quite correct that a hard-mounted one-blade prop would put significan t bending moments into the shaft...shades of crank-snapping Corvairs. You may not have noticed in the video that the one-blade prop is free to mov e fore and aft about an axis through the hub. This eliminates all the bendin g moments that a hard-mounted one-blade would produce. Mike Hardaway Scratched on an iPad with blunt instruments. On Oct 8, 2013, at 8:08 AM, Steve Emo wrote: > wouldn't a one bladed prop side load the crankshaft/bearing? Putting a be nding moment at the hub that isn't there with a two or more bladed design. > > The trailing blades don't get the clean air the leading blade had. > > Steve > > On Oct 8, 2013, at 10:08 AM, Steven Dortch wro te: > >> WF2, Why was it not practical for everyday flying? >> >> Granted it is a more complex prop and would be more expensive to build. I t would require more thought to make sure it was installed correctly. >> Once installed and setup, it has all the advantages of an adjustable prop without the additonal hardware and complexity. >> >> What are the wear issues? >> >> On my other list there is an aerodynamacyst and he has explaned the advan tages of one blade. But quite simply, it is easier to build a two bladed fix ed prop. >> >> On my Vtail it has a two bladed 88 inch prop. This is more efficient tha n the later and shorter 84 inch prop. Newer models have IO 550s (300HP) that all have 3 blade props. The 3 blade is less efficient, but shorter (less gr ound strikes) and quieter. Besides it looks "sexier". >> >> For a given HP about 1000 to 1300 RPM with a big bladed prop (fewer blade s is better) is the most efficient. However, most engines make their HP at h igher RPM. >> >> On Mon, Oct 7, 2013 at 12:42 PM, womenfly2 wrote : m> >>> >>> Seen it fly at Sentimental Journey this year. They did a demo flight com paring a standard prop J-3 to an Everal Prop J-3. Everal prop was hard to be at! >>> >>> Climbed faster at a more AOA, faster in level flight. Great idea, but wa s not practical for every day flying. >>> >>> Cool video! >>> WF2 >>> >>> -------- >>> >>> >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=410007#410007 >>> s List Un/Subscription, >>> www.matronics.com/Navigator?Pietenpol-List" target="_blank">http://www .matronics.com/Navigator?Pietenpol-List >>> ronics.com/" target="_blank">http://forums.matronics.com >>> Matt Dralle, List Admin. >>> ==== > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Oct 08, 2013
good catch - forgot about that feature. > Subject: Pietenpol-List: Re: strut attachment > From: tkreiner(at)gmail.com > Date: Mon=2C 7 Oct 2013 20:25:29 -0700 > To: pietenpol-list(at)matronics.com > > > If you need to change the position of your wing - and almost EVERYONE nee ds to - in order to correct your cg location=2C you need to use your "B" me thod. > > Hopefully=2C you can visualize the parallelogram that "B" provides=2C whi ch will allow for the cabane struts to be moved fore and back. > > With the sketch shown in "A=2C" what happens is that the front and rear c abanes will be locked into a fixed relationship. What they need is to be f ree to act as hinges in the front / rear swing directions. > > Follow the plans... > > -------- > Tom Kreiner > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410045#410045 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Need email
Date: Oct 08, 2013
Can someone give me Malcolm Morrison's email address? Thanks. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Oct 08, 2013
Subject: Re: Need email
Dan, this may be what you are looking for: gliderx5(at)comcast.net. On Tue, Oct 8, 2013 at 11:24 AM, wrote: > Can someone give me Malcolm Morrison's email address? Thanks. > > Dan Helsper > Puryear, TN > > * > > * > > ________________________________________________________________________________
Subject: Re: Mr Sam - Pietenpol N687MB
Date: Oct 08, 2013
Weight & Balance (WB) / Datum / Center of Gravity (CG) ====================================== Perhaps I am just having too much fun over thinking this...... I would like to figure this out for my piece of mind. Attached below for N687MB are: W&B Spreadsheet W&B Arm Chart (screen shot) W&B Calculations (screen shot) Snap shots of Page 1 of the 1933 plans that hint that the Datum is actually 7.5 inches ahead of the leading edge. Center of Gravity Can someone figure out where I went wrong in the spreadsheet? The Weight/Arm/Moment table says CG is at 17.7 aft of the datum. The long hand calculations / Percent of Wing Chord says the CG is at 15.2 inches aft of the datum. I can't find the error that is causing the 2.5 inch difference. Datum I read posts that say the Datum is the leading edge of the Wing. My question right now is based on the attached snap shots of my 1933 plans for N687MB. I can find no notes any where on the plans that says that Datum is the LE. However, in the snap shots of page 1 - there is vertical line 7.5" ahead of the LE and a penciled in note that says its 9.5 inches ahead of the LE. Could this line be the Datum? I am hoping someday soon I will be able to talk with Mr. Brusilow, the builder, and ask him. [/u] -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410086#410086 Attachments: http://forums.matronics.com//files/n687mb__1933_plans__main_wheel_cl_aft_of_datum_759.jpg http://forums.matronics.com//files/n687mb__1933_plans__pg_1__datum__386.jpg http://forums.matronics.com//files/n687mb__1933_plans__wing_aft_of_datum_108.jpg http://forums.matronics.com//files/n687mb__1933_plans__ident_box__496.jpg http://forums.matronics.com//files/n687mb_wandb_detailed_calculations_600.png http://forums.matronics.com//files/n687mb_wandb_arm_measurements_345.png http://forums.matronics.com//files/pietenpol_wandb_profile_final_ver_1_679.xls ________________________________________________________________________________
Subject: Re: How straight is straight?
Date: Oct 08, 2013
When you come across a question like this it's always reassuring to recall where the original came from. You're worrying about a dimension that probably wouldn't have bothered the original builder in the 30's who was laying out dimensions on a wood floor and using equipment of the era. Don't lower your personal standards but don't get caught up in the mind-set that you can't build an 80 year old design unless you have a CNC machine to cut the pieces. A piet ain't a Saturn 5!![/list] -------- L.V.Williams XCG, XCMR,EPP USHPA, EAA, AMA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410090#410090 ________________________________________________________________________________
Date: Oct 08, 2013
Jim; the "mystery vertical line" is, of course, the plane of the firewall. It's a very handy and uniform place from which to measure other things (such as the axle or the wing). It can also be used as the datum for doing your W&B but so can anything else that you choose. Some people use the very front of the prop hub, simply so that all moment arms are measured in the same direction from that point and all moments are clockwise and positive (no subtracting of moments). It is useful to have the wing leading edge as the datum because that's the reference that we typically refer the acceptable range of CG location to, and it's also what most people use. If you keep your + and - signs correct for moment arms that are forward and aft of the datum, the math is pretty simple and it all works out. I have not checked through your calculations to see where things may have gone amiss, but I'll be happy to do so this evening when I have some time. Math errors are common in W&B calculations. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410101#410101 ________________________________________________________________________________
Date: Oct 08, 2013
Which one of these denotes "Top Curmudgeon"? -------- L.V.Williams XCG, XCMR,EPP USHPA, EAA, AMA Dan Helsper Puryear, TN -----Original Message----- From: Larry Williams <lnawms(at)yahoo.com> Sent: Tue, Oct 8, 2013 6:19 pm Subject: Pietenpol-List: Re: How straight is straight? When you come across a question like this it's always reassuring to recall where the original came from. You're worrying about a dimension that probably wou ldn't have bothered the original builder in the 30's who was laying out dimension s on a wood floor and using equipment of the era. Don't lower your personal stan dards but don't get caught up in the mind-set that you can't build an 80 year old design unless you have a CNC machine to cut the pieces. A piet ain't a Satu rn 5!![/list] -------- L.V.Williams XCG, XCMR,EPP USHPA, EAA, AMA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410090#410090 ________________________________________________________________________________
Date: Oct 08, 2013
Hi Jim, Was looking at your figures and one thing I had a question about is your empty weight. Your figures are showing the mains at 176 and 178 and the tailwheel at 20 lbs. This gives an empty weight of 374 lbs. I haven't built a Piet, but have built a Rans S-6 and Rans S-12, so perhaps this could be a "little light"? Would like to see some empty weights from the other builders. Just my $.02 and certainly not throwing any stones. John Weber On Oct 8, 2013, at 3:25 PM, "Fun2av8" wrote: > > Weight & Balance (WB) / Datum / Center of Gravity (CG) > ====================================== > Perhaps I am just having too much fun over thinking this...... I would like to figure this out for my piece of mind. > > Attached below for N687MB are: > W&B Spreadsheet > W&B Arm Chart (screen shot) > W&B Calculations (screen shot) > Snap shots of Page 1 of the 1933 plans that hint that the Datum is actually 7.5 inches ahead of the leading edge. > > Center of Gravity > Can someone figure out where I went wrong in the spreadsheet? The Weight/Arm/Moment table says CG is at 17.7 aft of the datum. The long hand calculations / Percent of Wing Chord says the CG is at 15.2 inches aft of the datum. I can't find the error that is causing the 2.5 inch difference. > > Datum > I read posts that say the Datum is the leading edge of the Wing. My question right now is based on the attached snap shots of my 1933 plans for N687MB. I can find no notes any where on the plans that says that Datum is the LE. > > However, in the snap shots of page 1 - there is vertical line 7.5" ahead of the LE and a penciled in note that says its 9.5 inches ahead of the LE. Could this line be the Datum? > > I am hoping someday soon I will be able to talk with Mr. Brusilow, the builder, and ask him. > > > [/u] > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper, VA KCJR > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410086#410086 > > > > > Attachments: > > http://forums.matronics.com//files/n687mb__1933_plans__main_wheel_cl_aft_of_datum_759.jpg > http://forums.matronics.com//files/n687mb__1933_plans__pg_1__datum__386.jpg > http://forums.matronics.com//files/n687mb__1933_plans__wing_aft_of_datum_108.jpg > http://forums.matronics.com//files/n687mb__1933_plans__ident_box__496.jpg > http://forums.matronics.com//files/n687mb_wandb_detailed_calculations_600.png > http://forums.matronics.com//files/n687mb_wandb_arm_measurements_345.png > http://forums.matronics.com//files/pietenpol_wandb_profile_final_ver_1_679.xls > > > > > > > ________________________________________________________________________________
Date: Oct 08, 2013
You are absolutely right about the weights . I just took the weights off the sheet provided to me at the time of sale and plugged them in. The light just didnt go off that these were really under stated. I just checked an archive and found that a Piet with the long fuse and an 0-200 should come in at about 775 pounds empty weight. Nice catch. -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410105#410105 ________________________________________________________________________________
Date: Oct 08, 2013
Hi Oscar, Thanks for chiming in. I do understand that the Datum can be anything the builder wants it to be including some point in space beyond the hub - why some would is beyond me. But the FAA W&B book says its possible. Since I didn't build Mr. Sam and at the moment can't get in touch with the builder - what do i do now? The airplane flies fine and probably could just accept that and life goes on. But, I just one of those guys who just has to know for my own piece of mind. Just for fun, I did this crap for flights in my Maule. Hows this for a theoretical approach to the problem. Could one put the Piet on a fulcrum (a heavily padded saw horse) and just find the empty weight balance point and call that the CG point. Then, put in a pilot and a full load of fuel and rebalance the Piet. That would be the approximate aft limit of the CG. Then put in a passenger and once again re-balance the Piet. Could one call that the forward limit of the CG? Then could one measure from the empty weight CG to the Leading edge and call that the Initial datum measurement? From there just re-measure everything. Then, how would one prove this using conventional W&B / CG calculations? Or, maybe I should just go flying ......javascript:emoticon('[Laughing]') taildrags wrote: > Jim; the "mystery vertical line" is, of course, the plane of the firewall. It's a very handy and uniform place from which to measure other things (such as the axle or the wing). It can also be used as the datum for doing your W&B but so can anything else that you choose. Some people use the very front of the prop hub, simply so that all moment arms are measured in the same direction from that point and all moments are clockwise and positive (no subtracting of moments). It is useful to have the wing leading edge as the datum because that's the reference that we typically refer the acceptable range of CG location to, and it's also what most people use. If you keep your + and - signs correct for moment arms that are forward and aft of the datum, the math is pretty simple and it all works out. > > I have not checked through your calculations to see where things may have gone amiss, but I'll be happy to do so this evening when I have some time. Math errors are common in W&B calculations. [Laughing] -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410106#410106 ________________________________________________________________________________
Date: Oct 08, 2013
Larry, your words of wisdom make me feel much better about the precision (not) work I did tonight. At times I far exceed the quality of Mr. Waterman (he made my plane.) at other times I feel like a gorilla with a BFR. Blue Skies, Steve D. On Tue, Oct 8, 2013 at 2:52 PM, Larry Williams wrote: > > When you come across a question like this it's always reassuring to recall > where the original came from. You're worrying about a dimension that > probably wouldn't have bothered the original builder in the 30's who was > laying out dimensions on a wood floor and using equipment of the era. Don't > lower your personal standards but don't get caught up in the mind-set that > you can't build an 80 year old design unless you have a CNC machine to cut > the pieces. A piet ain't a Saturn 5!![/list] > > -------- > L.V.Williams > XCG, XCMR,EPP > USHPA, EAA, AMA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410090#410090 > > ________________________________________________________________________________
Date: Oct 08, 2013
For my "real" plane I carry several example W&Bs with me. Then I can simply reference them Probably not as important on Most Piets, but perhaps for some. Examples I would do are. Tanks full, Pilot only. Main (front) tank full, Pilot only. Aux tank full. Pilot only. Tanks empty Pilot only. Tanks full, pilot and front Pax. Front tank, pilot and pax Tanks empty pilot and front Pax. I would also figure out how where you go past the aft CG. IE with the front tank empty how big can the back seater be? Where do you go past Forward CG? How skinny can the pilot be with the front tank full? Don't forget, If you carry a full craftsman took kitl in the box behind your rear seat it should be included, As well as the full set of Clydesdale horseshoes you carry in the custom storage bag hung under the engine. Once you have figured out these calculations you will have a very good feel for what (and who) you can carry. Y'all be careful out there. Steve D Far Forward CG and the plane gets more twitchy, far back CG and the plane responds sluggishly. On Tue, Oct 8, 2013 at 4:58 PM, taildrags wrote: > > Jim; the "mystery vertical line" is, of course, the plane of the firewall. > It's a very handy and uniform place from which to measure other things > (such as the axle or the wing). It can also be used as the datum for doing > your W&B but so can anything else that you choose. Some people use the > very front of the prop hub, simply so that all moment arms are measured in > the same direction from that point and all moments are clockwise and > positive (no subtracting of moments). It is useful to have the wing > leading edge as the datum because that's the reference that we typically > refer the acceptable range of CG location to, and it's also what most > people use. If you keep your + and - signs correct for moment arms that > are forward and aft of the datum, the math is pretty simple and it all > works out. > > I have not checked through your calculations to see where things may have > gone amiss, but I'll be happy to do so this evening when I have some time. > Math errors are common in W&B calculations. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410101#410101 > > ________________________________________________________________________________
Date: Oct 08, 2013
Jim; Do you keep your plane in a hangar? If so, this can be pretty easy and you won't be in any hurry to get it done. Since the airplane is flying, you don't have to worry about getting it done any certain time and you can do it in two sessions. You could probably do it all yourself, but it's far easier with two people. In one session you'll be measuring things and in the second session you'll be weighing the airplane. Get some tape (painter's tape is fine and it comes off your hangar floor easily, but anything else will do), plus a length of nice strong twine and a plumb bob or anything heavy that you can tie to the end of the twine. A point on the end of it just helps you get closer on your measurements but it can be a big lag bolt or anything similar if you don't have a plumb bob. Get a Sharpie to mark on the tape, plus a piece of paper and pencil to write down your measurements. Then get a steel measuring tape that's at least 20 or 25 ft. long and you're ready. With the airplane out of the hangar (or in it... doesn't matter but it's easier to do if you don't have to crawl around under the airplane), lay a straight stripe of tape on the floor, in line with the nose and tail of the airplane and close to where you usually park the airplane and you know the wings and tail will clear everything. Next, lay a second stripe of tape across the first to form a cross, and try to get it so it falls more or less where your tires will sit when you roll the plane in to line up with the first stripe. Before you roll the plane in though, check to make sure the second stripe is at right angles to the first. You can do this a number of ways but you have twine and a measuring tape, so you can always just pick a number (like 4 ft.) and make a mark on each tape stripe that distance away from where they cross. Then measure the distances diagonally between the marks to make sure they are the same. Pick up the cross tape and adjust it if need be to get it square to the other stripe. Now roll the airplane in, lining it up on the long stripe. Guide the tailwheel down the stripe till the mains roll right onto the cross stripe. You may need to roll it back and forth a bit till the tailwheel is on the stripe and a plumb line dropped from the propeller hub drops right onto the tape. If the main axles are also right over the cross stripe, chock the mains and you're ready to start measuring. There are a lot of interesting measurements that you can take with this setup that don't have much to do with weight and balance, but they can be useful at other times. I won't worry with those now. You'll need a sawhorse or ladder, or you could also use a rope or hoist slung from your hangar roof, but you've got to raise the tail till the fuselage is in the straight and level position. A rope and pulley could be the best way to do this, but blocking up the tail with boxes or a sawhorse can do it too, as long as you can get the fuselage level and steady, and as long as you can drop a plumb line from the center of the tailwheel to the floor. Setting the tailwheel up on a stand won't usually let you do this. And watch it when you're raising the tail, since some aircraft get a little light on the tail in the level attitude, and can go on their nose if you overshoot. Get an accurate level and put it on the straightest section of fuselage longeron that you have easy access to. Usually that will be right inside the rear cockpit, the top longerons. A bubble level will do, but if you have one of those "angle finder" gizmos or a digital level, that's best. If you do it carefully and slowly, you'll only ever have to do this once. Airplane is level. Axles are directly over the cross tape, nose and tailwheel are directly over the longitudinal tape. Wheels are chocked. Now it's just a matter of taking your plumb line and measuring tape and getting the important measurements. The biggie is that leading edge, since it's your datum. Pick a side of the airplane that you want to work on and you can take all the measurements on that side. It doesn't matter which. Let the plumb line drape over the wing so the plumb bob goes down to the floor from the leading edge. Let the plumb bob stop swinging, then put down a piece of tape with a nice clear mark right where the plumb bob points. Now you can measure anything you want or need. Drop a line from the face of the firewall and measure aft to the leading edge. Measure from the leading edge mark back to the line that the landing gear make. Drop your plumb line from the center of the tailwheel and measure from the landing gear tape back to where the tailwheel plumb bob drops. And, as long as you've got everything set up, you can measure from the face of the prop hub to the firewall, you can measure the track (distance between contact patches of the two mains, you can measure from the firewall to the tailpost to determine which of the various Air Camper fuselage lengths you have, you can put your angle finder on the wing cabanes and determine if they are inclined and if so, by how much (usually measured at the top where the cabanes attach to the underside of the wing, and measured in inches aft of vertical). With these measurements, you can determine all the other moment arms once you do the weighing because you have determined the locations of the three weighing points and their positions relative to the leading edge, which is the datum. All of the laying out and measuring can be done in about an hour, if you have help and have the few simple tools that are needed. The weighing is next, and you could move right on to it if you have the scales available. With some prior planning, you could also do the whole thing in one process by setting the airplane up on the scales and doing the weighing and measuring all at one shot. Let's say you're doing it in two phases, so now the tape and marks are all off your hangar floor and you're not measuring anything this time... only reading scales. You'll want to pick a day when it's not too windy. You'd be surprised what even a breeze or gust will do to the reading on a digital scale when it flows around an airplane. So, get the best scales you have available but even if you decide to go with digital bathroom scales, at least make the two that you use on the mains identical. they have to go up to at least about 400 pounds. The one for the tailwheel can be smaller, but if all three are identical, even better. I used digital electronic race car scales for weighing my airplane, but Mr. Pietenpol very likely didn't have any of those and his airplanes flew just fine. Roll the mains onto two of the scales using ramps. Easier with two people. Raise the tail to the level position again, but this time you can use a small table, tool chest, or other stable platform to put the tailwheel right on the scale with the fuselage leveled using your angle finder or level to get it nice and level. In the best case, you will have drained all fuel out of the airplane so you get an empty weight. You can fool with draining the gascolator, but it's not a big deal. I would weigh it with the normal operating level of oil in the engine and make note of that. Make sure you've taken handheld radio, water bottle, knee board, headsets, spare parts and tools, fuzzy dice, and any other loose items out of the cockpits and stowage areas. Remember, it's "basic EMPTY weight". Read the scales and record the weights. Left main, right main, tailwheel. Those are important numbers and they should be something like in the 300s for the mains and less than 30 for the tail. Now to determine the moment arms for fuel, passenger, and pilot. I'll describe the situation for a fuel tank in the nose. With the airplane still level and on the scales, take a KNOWN quantity of fuel, something reasonable like 5 or 6 gallons, and pour all of it into the fuel tank. Replace the tank cap. Read all three scales again and write down the numbers. Later, you can go back and reverse-calculate the fuel moment arms by knowing those three weights and the amount of weight of fuel that you added. You will then know the fuel moment arm, which should never change unless you make changes in the tank location. To determine the passenger and pilot moment arms, find a volunteer and get their weight. Don't let them guess at their weight... have them weigh themselves either before you use the scales for the plane weighing, or on another set of scales. Have them climb into each cockpit slowly and carefully, make sure nothing moves on the scales, and record the weights in both configurations. Again, later on you can reverse-calculate the moment arm distances for passenger and pilot if you know what the person's weight was and what the new readings are on your scales. You're done in the hangar. Probably another hour to do the weighing, but if you did it carefully and remembered to record all the numbers, you'll never have to do it again. You can do all of the above on a rainy or wintry day when you don't have anything else to do, and of course you can work out the formulas and W&B diagrams later on when you're at home and comfortable. That should do it. No mystery vertical lines, and everything you have will be useful at one time or another. I probably missed something along the line, but I'm sure someone will chime in if I have. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410118#410118 ________________________________________________________________________________
Date: Oct 09, 2013
Y'all might check with your local EAA chapter. Chapter 35 has a calibrated set of scaled used only for weight and balance on aircraft. For $25 you get to use the scales, AND the guy who manages them for the club is the best asset. He has done this many times and will walk you through this. Blue Skies, Steve D On Tue, Oct 8, 2013 at 11:03 PM, taildrags wrote: > > Jim; > > Do you keep your plane in a hangar? If so, this can be pretty easy and > you won't be in any hurry to get it done. Since the airplane is flying, > you don't have to worry about getting it done any certain time and you can > do it in two sessions. You could probably do it all yourself, but it's far > easier with two people. In one session you'll be measuring things and in > the second session you'll be weighing the airplane. > > Get some tape (painter's tape is fine and it comes off your hangar floor > easily, but anything else will do), plus a length of nice strong twine and > a plumb bob or anything heavy that you can tie to the end of the twine. A > point on the end of it just helps you get closer on your measurements but > it can be a big lag bolt or anything similar if you don't have a plumb bob. > Get a Sharpie to mark on the tape, plus a piece of paper and pencil to > write down your measurements. Then get a steel measuring tape that's at > least 20 or 25 ft. long and you're ready. > > With the airplane out of the hangar (or in it... doesn't matter but it's > easier to do if you don't have to crawl around under the airplane), lay a > straight stripe of tape on the floor, in line with the nose and tail of the > airplane and close to where you usually park the airplane and you know the > wings and tail will clear everything. Next, lay a second stripe of tape > across the first to form a cross, and try to get it so it falls more or > less where your tires will sit when you roll the plane in to line up with > the first stripe. Before you roll the plane in though, check to make sure > the second stripe is at right angles to the first. You can do this a > number of ways but you have twine and a measuring tape, so you can always > just pick a number (like 4 ft.) and make a mark on each tape stripe that > distance away from where they cross. Then measure the distances diagonally > between the marks to make sure they are the same. Pick up the cross tape > and adjust it if need be to ge! > t it square to the other stripe. > > Now roll the airplane in, lining it up on the long stripe. Guide the > tailwheel down the stripe till the mains roll right onto the cross stripe. > You may need to roll it back and forth a bit till the tailwheel is on the > stripe and a plumb line dropped from the propeller hub drops right onto the > tape. If the main axles are also right over the cross stripe, chock the > mains and you're ready to start measuring. There are a lot of interesting > measurements that you can take with this setup that don't have much to do > with weight and balance, but they can be useful at other times. I won't > worry with those now. > > You'll need a sawhorse or ladder, or you could also use a rope or hoist > slung from your hangar roof, but you've got to raise the tail till the > fuselage is in the straight and level position. A rope and pulley could be > the best way to do this, but blocking up the tail with boxes or a sawhorse > can do it too, as long as you can get the fuselage level and steady, and as > long as you can drop a plumb line from the center of the tailwheel to the > floor. Setting the tailwheel up on a stand won't usually let you do this. > And watch it when you're raising the tail, since some aircraft get a > little light on the tail in the level attitude, and can go on their nose if > you overshoot. Get an accurate level and put it on the straightest section > of fuselage longeron that you have easy access to. Usually that will be > right inside the rear cockpit, the top longerons. A bubble level will do, > but if you have one of those "angle finder" gizmos or a digital level, > that's best. If you do it ca! > refully and slowly, you'll only ever have to do this once. > > Airplane is level. Axles are directly over the cross tape, nose and > tailwheel are directly over the longitudinal tape. Wheels are chocked. > > Now it's just a matter of taking your plumb line and measuring tape and > getting the important measurements. The biggie is that leading edge, since > it's your datum. Pick a side of the airplane that you want to work on and > you can take all the measurements on that side. It doesn't matter which. > Let the plumb line drape over the wing so the plumb bob goes down to the > floor from the leading edge. Let the plumb bob stop swinging, then put > down a piece of tape with a nice clear mark right where the plumb bob > points. Now you can measure anything you want or need. Drop a line from > the face of the firewall and measure aft to the leading edge. Measure from > the leading edge mark back to the line that the landing gear make. Drop > your plumb line from the center of the tailwheel and measure from the > landing gear tape back to where the tailwheel plumb bob drops. And, as > long as you've got everything set up, you can measure from the face of the > prop hub to the firewall, you can m! > easure the track (distance between contact patches of the two mains, you > can measure from the firewall to the tailpost to determine which of the > various Air Camper fuselage lengths you have, you can put your angle finder > on the wing cabanes and determine if they are inclined and if so, by how > much (usually measured at the top where the cabanes attach to the underside > of the wing, and measured in inches aft of vertical). > > With these measurements, you can determine all the other moment arms once > you do the weighing because you have determined the locations of the three > weighing points and their positions relative to the leading edge, which is > the datum. All of the laying out and measuring can be done in about an > hour, if you have help and have the few simple tools that are needed. > > The weighing is next, and you could move right on to it if you have the > scales available. With some prior planning, you could also do the whole > thing in one process by setting the airplane up on the scales and doing the > weighing and measuring all at one shot. Let's say you're doing it in two > phases, so now the tape and marks are all off your hangar floor and you're > not measuring anything this time... only reading scales. > > You'll want to pick a day when it's not too windy. You'd be surprised > what even a breeze or gust will do to the reading on a digital scale when > it flows around an airplane. So, get the best scales you have available > but even if you decide to go with digital bathroom scales, at least make > the two that you use on the mains identical. they have to go up to at > least about 400 pounds. The one for the tailwheel can be smaller, but if > all three are identical, even better. I used digital electronic race car > scales for weighing my airplane, but Mr. Pietenpol very likely didn't have > any of those and his airplanes flew just fine. > > Roll the mains onto two of the scales using ramps. Easier with two > people. Raise the tail to the level position again, but this time you can > use a small table, tool chest, or other stable platform to put the > tailwheel right on the scale with the fuselage leveled using your angle > finder or level to get it nice and level. In the best case, you will have > drained all fuel out of the airplane so you get an empty weight. You can > fool with draining the gascolator, but it's not a big deal. I would weigh > it with the normal operating level of oil in the engine and make note of > that. Make sure you've taken handheld radio, water bottle, knee board, > headsets, spare parts and tools, fuzzy dice, and any other loose items out > of the cockpits and stowage areas. Remember, it's "basic EMPTY weight". > > Read the scales and record the weights. Left main, right main, tailwheel. > Those are important numbers and they should be something like in the 300s > for the mains and less than 30 for the tail. > > Now to determine the moment arms for fuel, passenger, and pilot. I'll > describe the situation for a fuel tank in the nose. With the airplane > still level and on the scales, take a KNOWN quantity of fuel, something > reasonable like 5 or 6 gallons, and pour all of it into the fuel tank. > Replace the tank cap. Read all three scales again and write down the > numbers. Later, you can go back and reverse-calculate the fuel moment arms > by knowing those three weights and the amount of weight of fuel that you > added. You will then know the fuel moment arm, which should never change > unless you make changes in the tank location. > > To determine the passenger and pilot moment arms, find a volunteer and get > their weight. Don't let them guess at their weight... have them weigh > themselves either before you use the scales for the plane weighing, or on > another set of scales. Have them climb into each cockpit slowly and > carefully, make sure nothing moves on the scales, and record the weights in > both configurations. Again, later on you can reverse-calculate the moment > arm distances for passenger and pilot if you know what the person's weight > was and what the new readings are on your scales. > > You're done in the hangar. Probably another hour to do the weighing, but > if you did it carefully and remembered to record all the numbers, you'll > never have to do it again. You can do all of the above on a rainy or > wintry day when you don't have anything else to do, and of course you can > work out the formulas and W&B diagrams later on when you're at home and > comfortable. > > That should do it. No mystery vertical lines, and everything you have > will be useful at one time or another. I probably missed something along > the line, but I'm sure someone will chime in if I have. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410118#410118 > > ________________________________________________________________________________
Date: Oct 09, 2013
Jim, EAA 186 has scales. I want to borrow, too. Zeke On Oct 9, 2013 7:04 AM, "Steven Dortch" wrote: > Y'all might check with your local EAA chapter. Chapter 35 has a calibrated > set of scaled used only for weight and balance on aircraft. For $25 you get > to use the scales, AND the guy who manages them for the club is the best > asset. He has done this many times and will walk you through this. > > Blue Skies, > Steve D > > > On Tue, Oct 8, 2013 at 11:03 PM, taildrags wrote: > >> >> Jim; >> >> Do you keep your plane in a hangar? If so, this can be pretty easy and >> you won't be in any hurry to get it done. Since the airplane is flying, >> you don't have to worry about getting it done any certain time and you can >> do it in two sessions. You could probably do it all yourself, but it's far >> easier with two people. In one session you'll be measuring things and in >> the second session you'll be weighing the airplane. >> >> Get some tape (painter's tape is fine and it comes off your hangar floor >> easily, but anything else will do), plus a length of nice strong twine and >> a plumb bob or anything heavy that you can tie to the end of the twine. A >> point on the end of it just helps you get closer on your measurements but >> it can be a big lag bolt or anything similar if you don't have a plumb bob. >> Get a Sharpie to mark on the tape, plus a piece of paper and pencil to >> write down your measurements. Then get a steel measuring tape that's at >> least 20 or 25 ft. long and you're ready. >> >> With the airplane out of the hangar (or in it... doesn't matter but it's >> easier to do if you don't have to crawl around under the airplane), lay a >> straight stripe of tape on the floor, in line with the nose and tail of the >> airplane and close to where you usually park the airplane and you know the >> wings and tail will clear everything. Next, lay a second stripe of tape >> across the first to form a cross, and try to get it so it falls more or >> less where your tires will sit when you roll the plane in to line up with >> the first stripe. Before you roll the plane in though, check to make sure >> the second stripe is at right angles to the first. You can do this a >> number of ways but you have twine and a measuring tape, so you can always >> just pick a number (like 4 ft.) and make a mark on each tape stripe that >> distance away from where they cross. Then measure the distances diagonally >> between the marks to make sure they are the same. Pick up the cross tape >> and adjust it if need be to ge! >> t it square to the other stripe. >> >> Now roll the airplane in, lining it up on the long stripe. Guide the >> tailwheel down the stripe till the mains roll right onto the cross stripe. >> You may need to roll it back and forth a bit till the tailwheel is on the >> stripe and a plumb line dropped from the propeller hub drops right onto the >> tape. If the main axles are also right over the cross stripe, chock the >> mains and you're ready to start measuring. There are a lot of interesting >> measurements that you can take with this setup that don't have much to do >> with weight and balance, but they can be useful at other times. I won't >> worry with those now. >> >> You'll need a sawhorse or ladder, or you could also use a rope or hoist >> slung from your hangar roof, but you've got to raise the tail till the >> fuselage is in the straight and level position. A rope and pulley could be >> the best way to do this, but blocking up the tail with boxes or a sawhorse >> can do it too, as long as you can get the fuselage level and steady, and as >> long as you can drop a plumb line from the center of the tailwheel to the >> floor. Setting the tailwheel up on a stand won't usually let you do this. >> And watch it when you're raising the tail, since some aircraft get a >> little light on the tail in the level attitude, and can go on their nose if >> you overshoot. Get an accurate level and put it on the straightest section >> of fuselage longeron that you have easy access to. Usually that will be >> right inside the rear cockpit, the top longerons. A bubble level will do, >> but if you have one of those "angle finder" gizmos or a digital level, >> that's best. If you do it ca! >> refully and slowly, you'll only ever have to do this once. >> >> Airplane is level. Axles are directly over the cross tape, nose and >> tailwheel are directly over the longitudinal tape. Wheels are chocked. >> >> Now it's just a matter of taking your plumb line and measuring tape and >> getting the important measurements. The biggie is that leading edge, since >> it's your datum. Pick a side of the airplane that you want to work on and >> you can take all the measurements on that side. It doesn't matter which. >> Let the plumb line drape over the wing so the plumb bob goes down to the >> floor from the leading edge. Let the plumb bob stop swinging, then put >> down a piece of tape with a nice clear mark right where the plumb bob >> points. Now you can measure anything you want or need. Drop a line from >> the face of the firewall and measure aft to the leading edge. Measure from >> the leading edge mark back to the line that the landing gear make. Drop >> your plumb line from the center of the tailwheel and measure from the >> landing gear tape back to where the tailwheel plumb bob drops. And, as >> long as you've got everything set up, you can measure from the face of the >> prop hub to the firewall, you can m! >> easure the track (distance between contact patches of the two mains, you >> can measure from the firewall to the tailpost to determine which of the >> various Air Camper fuselage lengths you have, you can put your angle finder >> on the wing cabanes and determine if they are inclined and if so, by how >> much (usually measured at the top where the cabanes attach to the underside >> of the wing, and measured in inches aft of vertical). >> >> With these measurements, you can determine all the other moment arms once >> you do the weighing because you have determined the locations of the three >> weighing points and their positions relative to the leading edge, which is >> the datum. All of the laying out and measuring can be done in about an >> hour, if you have help and have the few simple tools that are needed. >> >> The weighing is next, and you could move right on to it if you have the >> scales available. With some prior planning, you could also do the whole >> thing in one process by setting the airplane up on the scales and doing the >> weighing and measuring all at one shot. Let's say you're doing it in two >> phases, so now the tape and marks are all off your hangar floor and you're >> not measuring anything this time... only reading scales. >> >> You'll want to pick a day when it's not too windy. You'd be surprised >> what even a breeze or gust will do to the reading on a digital scale when >> it flows around an airplane. So, get the best scales you have available >> but even if you decide to go with digital bathroom scales, at least make >> the two that you use on the mains identical. they have to go up to at >> least about 400 pounds. The one for the tailwheel can be smaller, but if >> all three are identical, even better. I used digital electronic race car >> scales for weighing my airplane, but Mr. Pietenpol very likely didn't have >> any of those and his airplanes flew just fine. >> >> Roll the mains onto two of the scales using ramps. Easier with two >> people. Raise the tail to the level position again, but this time you can >> use a small table, tool chest, or other stable platform to put the >> tailwheel right on the scale with the fuselage leveled using your angle >> finder or level to get it nice and level. In the best case, you will have >> drained all fuel out of the airplane so you get an empty weight. You can >> fool with draining the gascolator, but it's not a big deal. I would weigh >> it with the normal operating level of oil in the engine and make note of >> that. Make sure you've taken handheld radio, water bottle, knee board, >> headsets, spare parts and tools, fuzzy dice, and any other loose items out >> of the cockpits and stowage areas. Remember, it's "basic EMPTY weight". >> >> Read the scales and record the weights. Left main, right main, >> tailwheel. Those are important numbers and they should be something like >> in the 300s for the mains and less than 30 for the tail. >> >> Now to determine the moment arms for fuel, passenger, and pilot. I'll >> describe the situation for a fuel tank in the nose. With the airplane >> still level and on the scales, take a KNOWN quantity of fuel, something >> reasonable like 5 or 6 gallons, and pour all of it into the fuel tank. >> Replace the tank cap. Read all three scales again and write down the >> numbers. Later, you can go back and reverse-calculate the fuel moment arms >> by knowing those three weights and the amount of weight of fuel that you >> added. You will then know the fuel moment arm, which should never change >> unless you make changes in the tank location. >> >> To determine the passenger and pilot moment arms, find a volunteer and >> get their weight. Don't let them guess at their weight... have them weigh >> themselves either before you use the scales for the plane weighing, or on >> another set of scales. Have them climb into each cockpit slowly and >> carefully, make sure nothing moves on the scales, and record the weights in >> both configurations. Again, later on you can reverse-calculate the moment >> arm distances for passenger and pilot if you know what the person's weight >> was and what the new readings are on your scales. >> >> You're done in the hangar. Probably another hour to do the weighing, but >> if you did it carefully and remembered to record all the numbers, you'll >> never have to do it again. You can do all of the above on a rainy or >> wintry day when you don't have anything else to do, and of course you can >> work out the formulas and W&B diagrams later on when you're at home and >> comfortable. >> >> That should do it. No mystery vertical lines, and everything you have >> will be useful at one time or another. I probably missed something along >> the line, but I'm sure someone will chime in if I have. >> >> -------- >> Oscar Zuniga >> Medford, OR >> Air Camper NX41CC "Scout" >> A75 power >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=410118#410118 >> >> >> >> >> >> >> >> ========== >> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > * > > ________________________________________________________________________________
Subject: Corvair College 27, Nov 8 - 10, Barnwell, SC
Date: Oct 09, 2013
Well worth attending. https://corvaircollege.wufoo.com/forms/corvair-college-27-registration/ -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410128#410128 ________________________________________________________________________________
Date: Oct 09, 2013
Mike, You are partly correct. Everel (the prop maker) states that the centrifugal effect cancels out the bending moment and this blade not only moves but it also bends and that is where most of the bending moment occurs. (is this true of a more simple non pivoting blade?) The main reason that the Everel prop pivots is that it makes it an "automatic variable pitch type" prop. Basically when the aircraft is moving slower (TO and climb) the prop goes to fine pitch for max RPM. As the aircraft speeds up (cruise) the prop goes to coarse pitch for lower RPM and faster cruise. Here is a link that describes it very well. http://www.ultraligero.net/Cursos/varios/helice_de_una_pala.pdf IMHOBIKIAR The true efficiency of the Everel prop is in it's ability to "pivot", thus making it varaiable pitch. Some hombuilt fixed props claim to do the same with the materiels that they use. Basically the prop flexes based upon air load. These are made for the speedy homebuilts like the lancair and glassair. Would a two bladed prop be built where both blades could mechanically pivot like the Everel single blade? Blue Skies, Steve D On Tue, Oct 8, 2013 at 11:26 AM, Bkemike wrote: > Steve, > You're quite correct that a hard-mounted one-blade prop would put > significant bending moments into the shaft...shades of crank-snapping > Corvairs. > You may not have noticed in the video that the one-blade prop is free to > move fore and aft about an axis through the hub. This eliminates all the > bending moments that a hard-mounted one-blade would produce. > Mike Hardaway > > Scratched on an iPad with blunt instruments. > > > On Oct 8, 2013, at 8:08 AM, Steve Emo wrote: > > wouldn't a one bladed prop side load the crankshaft/bearing? Putting a > bending moment at the hub that isn't there with a two or more bladed > design. > > The trailing blades don't get the clean air the leading blade had. > > Steve > > On Oct 8, 2013, at 10:08 AM, Steven Dortch > wrote: > > WF2, Why was it not practical for everyday flying? > > Granted it is a more complex prop and would be more expensive to build. > It would require more thought to make sure it was installed correctly. > Once installed and setup, it has all the advantages of an adjustable prop > without the additonal hardware and complexity. > > What are the wear issues? > > On my other list there is an aerodynamacyst and he has explaned the > advantages of one blade. But quite simply, it is easier to build a two > bladed fixed prop. > > On my Vtail it has a two bladed 88 inch prop. This is more efficient than > the later and shorter 84 inch prop. Newer models have IO 550s (300HP) that > all have 3 blade props. The 3 blade is less efficient, but shorter (less > ground strikes) and quieter. Besides it looks "sexier". > > For a given HP about 1000 to 1300 RPM with a big bladed prop (fewer blades > is better) is the most efficient. However, most engines make their HP at > higher RPM. > > On Mon, Oct 7, 2013 at 12:42 PM, womenfly2 wrote: > >> > >> >> Seen it fly at Sentimental Journey this year. They did a demo flight >> comparing a standard prop J-3 to an Everal Prop J-3. Everal prop was hard >> to beat! >> >> Climbed faster at a more AOA, faster in level flight. Great idea, but was >> not practical for every day flying. >> >> Cool video! >> WF2 >> >> -------- >> >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=410007#410007 >> s List Un/Subscription, >> www.matronics.com/Navigator?Pietenpol-List" target="_blank"> >> http://www.matronics.com/Navigator?Pietenpol-List >> ronics.com/" target="_blank">http://forums.matronics.com >> Matt Dralle, List Admin. >> ==== >> >> >> >> > * > > * > > * > > D============================================ > npol-List"">http://www.matronics.com/Navigator?Pietenpol-List > D============================================ > //forums.matronics.com > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > * > > * > > * > > ________________________________________________________________________________
Subject: Re: Engine out.. again
Date: Oct 09, 2013
I added some baffling to my carb heat muff. .. welded to the exhaust pipe. Now I have a 55 rise in temp from ambient. So I was seeing 120 in the inlet yesterday. It made the mixture a bit rich. I'm going to run more and adjust the carb. Anybody else know how much heat your making? Jeff Faith Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410136#410136 ________________________________________________________________________________
Subject: Re: Felix For Sale
Date: Oct 09, 2013
I tethered a piece of an old t-shirt to the cockpit combing w/a leather shoe lace.. http://youtu.be/fpkbuFpHOfo -------- KLNC A65-8 N2308C AN Hardware Airframe 724TT W72CK-42 Sensenich Standard Factory GN-1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410141#410141 ________________________________________________________________________________
Date: Oct 09, 2013
Jeff; I'm not sure if you saw the carb icing probability graph that Gerry Holland posted, but the temperature scale of the graph ends at 40*C, or 104*F. In fact, the colored part of the graph (where icing is possible) doesn't even extend beyond about 38*C or 100*F. It sounds like you've got a robust carb heat setup now. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410147#410147 ________________________________________________________________________________
Date: Oct 09, 2013
Hey Guys, As I sit out at the hangar (KCJR) it is a kinda miserable day all cloudy and its drizzling. Gotta tell ya just dont care! The Culpeper Air Fest is this coming Saturday. The war birds are starting to arrive. Many are getting in their formation practice. Rumor has it we will have over 60 Texans on the ramp and in the air on Saturday. Im throwing a Hangar Party all day (if your local send me an email -- come on down !!!). With all this talk about W&B, CG, Datum lines, and other such elusive mysteries, I kinda feel like weve been around the barn and down the rabbit hole a bunch of times. Some really great info and thoughts came out of all of this. I totally lost focus on what started this. What started this ruckus was the discussions about upgrading my tail wheel from the roller skate to an 8 Scott 3200. There were thoughts on both sides pro and con. What stuck with me is that the Scott 3200 weighs 6 pounds and the roller skate weights less than a pound. Then there were thoughts expressed that Piets are typically tail heavy any way and that adding 5 pounds more to the tail would be a big deal. So I figured Id just do the math and see what the calculated effect of this additional weight would be with respect to the CG. I knew that the Datum was key to all of this Then it was off to the races . Measuring stations and compiling data. I got so wrapped up (Yes, I was having lots of fun!) in the process that I lost sight of the goal. OMG I was up till ODark-Thirty still crunching numbers. Thankfully my PC does an automatic shutdown forced me to go to bed. Lots of folks chimed in with their Piet specific CG data. No two Piets had the same data. The CG ranges were interesting. But, since no two Piets are built exactly alike it just makes sense that the CG data would be different. The Datum is arbitrary the Builder decides where he or she wants it to be . For most Piets, but not all Piets - the Datum is the LE of the Wing. It turns out that that might NOT be the case for my Piet. Page 1 of the plans used to build Mr. Sam say that there is a mystery vertical line 9 ahead of the LE. The Wing, Struts, and main gear are situated based on a specific distance from this line. But thenIm guessing that this mystery line is the Datum. No one wrote Datum and drew an arrow to this line. So technically . I still dont know. As I mentioned before It was off to the races logic and reason be damned Im gonna prove where my CG is Well if you look at the previous posts and attachments you can see I had a lot of fun creating spreadsheets with pictures and arrows all over the place just like Alices Restaurant. Oscar must be a lot like me . I suspect he has a few pictures with arrows as well. His detailed instructions on how to do the measure and weigh the Piet are incredibly well written and spot on! Im gonna do just that. I even ordered two 550 pound bathroom scales for less than $80 with shipping. So with all of this hurry scurry and rustling of papers, quivers, and arrows . I still dont know what the mathematical impact of adding 5 pounds to the tail will be. I suppose I could just tie a 5 pound rock to the tail and ask Chuck if he wants to go flying Wouldnt that be a hoot. Truth: Mr. Sam flies well. I dont have any nose or tail heavy issues. Life is good. Gonna go watch the war birds fly. I wonder.If I took off would they join up on me in formation? Ha Ha Ha . Fat chance! P.S. Gonna go with the Scott 2000 ...... No Sweat!!! -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410157#410157 ________________________________________________________________________________
Date: Oct 09, 2013
Jim In regards to your mysterious 9.5 inches ahead of the wing on page 1 of your plans. Measure the distance from the firewall to the bracket that holds the lower end of the front cabain strut. If Mr. Sam is a long fuselage it should be about 16.25 inches, if its a short fuselage it would be about 14.25 inches. Im guessing you may find Mike added 2 inches to the nose of the fuselage to help the weight and balance. Chris -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410163#410163 ________________________________________________________________________________
Date: Oct 09, 2013
Good luck, Jim! FYI...I just changed my tailwheel design. Old tailwheel, with BHP A frame, weighed about 4 lbs. New set up, with spring and 6" wheel weighs 9 lbs. The math says that CG changed little. Gary Boothe NX308MB Sent from my iPhone > On Oct 9, 2013, at 1:05 PM, "Fun2av8" wrote: > > > Hey Guys, > > As I sit out at the hangar (KCJR) it is a kinda miserable day all cloudy and its drizzling. Gotta tell ya just dont care! The Culpeper Air Fest is this coming Saturday. The war birds are starting to arrive. Many are getting in their formation practice. Rumor has it we will have over 60 Texans on the ramp and in the air on Saturday. Im throwing a Hangar Party all day (if your local send me an email -- come on down !!!). > > With all this talk about W&B, CG, Datum lines, and other such elusive mysteries, I kinda feel like weve been around the barn and down the rabbit hole a bunch of times. Some really great info and thoughts came out of all of this. > > I totally lost focus on what started this. What started this ruckus was the discussions about upgrading my tail wheel from the roller skate to an 8 Scott 3200. There were thoughts on both sides pro and con. What stuck with me is that the Scott 3200 weighs 6 pounds and the roller skate weights less than a pound. Then there were thoughts expressed that Piets are typically tail heavy any way and that adding 5 pounds more to the tail would be a big deal. > > So I figured Id just do the math and see what the calculated effect of this additional weight would be with respect to the CG. I knew that the Datum was key to all of this > > Then it was off to the races . Measuring stations and compiling data. I got so wrapped up (Yes, I was having lots of fun!) in the process that I lost sight of the goal. OMG I was up till ODark-Thirty still crunching numbers. Thankfully my PC does an automatic shutdown forced me to go to bed. > > Lots of folks chimed in with their Piet specific CG data. No two Piets had the same data. The CG ranges were interesting. But, since no two Piets are built exactly alike it just makes sense that the CG data would be different. > > The Datum is arbitrary the Builder decides where he or she wants it to be . For most Piets, but not all Piets - the Datum is the LE of the Wing. It turns out that that might NOT be the case for my Piet. Page 1 of the plans used to build Mr. Sam say that there is a mystery vertical line 9 ahead of the LE. The Wing, Struts, and main gear are situated based on a specific distance from this line. But thenIm guessing that this mystery line is the Datum. No one wrote Datum and drew an arrow to this line. So technically . I still dont know. > > As I mentioned before It was off to the races logic and reason be damned Im gonna prove where my CG is Well if you look at the previous posts and attachments you can see I had a lot of fun creating spreadsheets with pictures and arrows all over the place just like Alices Restaurant. Oscar must be a lot like me . I suspect he has a few pictures with arrows as well. His detailed instructions on how to do the measure and weigh the Piet are incredibly well written and spot on! Im gonna do just that. I even ordered two 550 pound bathroom scales for less than $80 with shipping. > > So with all of this hurry scurry and rustling of papers, quivers, and arrows . I still dont know what the mathematical impact of adding 5 pounds to the tail will be. I suppose I could just tie a 5 pound rock to the tail and ask Chuck if he wants to go flying Wouldnt that be a hoot. > > Truth: Mr. Sam flies well. I dont have any nose or tail heavy issues. Life is good. Gonna go watch the war birds fly. I wonder.If I took off would they join up on me in formation? Ha Ha Ha . Fat chance! > > P.S. Gonna go with the Scott 2000 ...... No Sweat!!! > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper, VA KCJR > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410157#410157 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 09, 2013
Subject: webinar
Just finished listening to the webinair on painting with Latex. paint. the presenter was really good. Just a good old boy who followed along with how he did it. I got a lot of good tips from it and am about ready to start. After I finish some other projects. Blue Skies, Steve D ________________________________________________________________________________
Subject: Re: Mr Sam - Pietenpol N687MB
Date: Oct 09, 2013
Thanks Gary.....Glad to hear it !!!! -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410180#410180 ________________________________________________________________________________
Subject: Progress report
Date: Oct 09, 2013
Well friends, Here is a progress report that I hope is some inspiration for the rest of yo u builders. I just finished the brush coats of primer on one of my wings tod ay. I still need to do the other wing half, which I hope to finish tomorrow. All of the rest of the airframe is finished through the brushed primer coat s. I plan on starting the final finish spray painting in the next week or so. Rick Schreiber, NX478RS Valparaiso, IN Sent from my iPad
Date: Oct 09, 2013
Mr Michael Brusilow - Mr Sam =================== Does anyone remember what User ID Mike used to sign on the forum? I've searched all posts for N687MB, , Mr Sam, and Brusilow. I only come with stuff I've posted. Chris says he remembers posts when Mike was building Mr. Sam. Those would be pure gold to read. Jim -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410184#410184 ________________________________________________________________________________
Date: Oct 09, 2013
Success !!!! I Googled Mike and found a link to the Matronics Archives. Did a search on N687MB and found a gold mine! :-) Jim -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410185#410185 ________________________________________________________________________________
Subject: Re: steel tube fuselage tacked
Date: Oct 09, 2013
Paul; it's looking nice. Do you plan to bead-blast and powder coat it after you get all the fittings and tabs installed, or will you just go with primer and/or paint? I don't know about powder coating but it seems to me that if you need to add a tab or fitting after you've powder-coated, you won't be able to get the same finish on the added parts that you have on the powder-coated rest of the thing. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410193#410193 ________________________________________________________________________________
Subject: Re: webinar
Date: Oct 09, 2013
[UNCLASSIFIED] Steve- was the latex paint webinar by Malcolm Morrison? I've got to view that one. I've heard good things about it. I recall the red paint job that you, Steve & Freda Jones put on your old Chevy Suburban in the blazing Texas heat. I think the paint was curing as soon as it left the spray nozzle, so it's no surprise that the Suburban didn't end up looking exactly like a Ferrari. It also might have helped if the masking tape would have come off before the Texas sun permanently attached the adhesive to your chrome trim ;o) It sure looked like y'all had fun painting that day though. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410194#410194 ________________________________________________________________________________
Subject: Re: Progress report
Date: Oct 09, 2013
Rick; beautiful! Very nice work, smooth, and it must be immensely satisfying to see it nearing the point of assembling everything into a real airplane. Just as food for thought, and looking at where you have reinforcements added for inspection covers, take a look at where NX41CC has them. I don't endorse these locations, and there are a bunch of them on my airplane, but just think about places you may want to be able to get to or inspect in the future. Take a look here: http://www.flysquirrel.net/piets/repairs/inspection.html With the handheld inspection cameras that are available nowadays, some of these inspection covers can certainly be dispensed with. However, I recently got myself one of the Harbor Freight cheapie ones (limited coverage due to relatively short length of camera probe) and was a bit surprised to find that I couldn't exactly maneuver it down through the wing as easily as I thought I would be able to. Rib gussets and rib lacing presented quite an obstacle course for the little "camera on a snake" to weave through. In any case, you can always add a reinforcing ring and inspection cover if you need one later. Oh, and pay no attention to the fact that the centersection flop droops below the trailing edge of the wing in the last photo on the webpage linked above. I have since added a solid stop to make sure that the TE of the flop lines up with the TE of the main wings. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410195#410195 ________________________________________________________________________________
Date: Oct 10, 2013
Congratulation Rick. A long road coming close to fruition. Very exciting fo r you amigo. Thanks for sharing this. Dan Helsper Puryear, TN -----Original Message----- From: Rick <lmforge(at)earthlink.net> Sent: Wed, Oct 9, 2013 9:38 pm Subject: Pietenpol-List: Progress report Well friends, Here is a progress report that I hope is some inspiration for the rest of y ou builders. I just finished the brush coats of primer on one of my wings toda y. I still need to do the other wing half, which I hope to finish tomorrow. All of the rest of the airframe is finished through the brushed primer coats. I plan on starting the final finish spray painting in the next week or so. Rick Schreiber, NX478RS Valparaiso, IN Sent from my iPad
      3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
      3D
      t">http://www.matronics.com/Navigator?Pietenpol-List>
      3D
      nics.com
      3D
      3D
Date: Oct 10, 2013
The presentation was very well presented and educational. I enjoyed watch it. Good see alternatives like this, helps bring down the cost of HB. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410202#410202 ________________________________________________________________________________
Subject: Re: Mr Sam (N687MB) - Scott Tail Wheel
Date: Oct 10, 2013
Has anyone had experience with Matco Tail Wheels ? I'm thinking about either: Tthe 6" solid rubber composite tail wheel $170 overall height is 9.71 inches & weighs 4.75 pounds. The 6" Pneumatic $199. Overall height is 9.71 inches. This assembly with pneumatic tire, tube, and wheel weighs 4.75 pounds. They are single arm as opposed to double arm which seems to be more durable and stable. But technology has advanced a lot. My concern is that with a single arm if will tend to lean to the side. Thoughts http://www.matcomfg.com/CANTILEVEREDTAILWHEELASSEMBLIESSINGLEARMFORK-tp2-69.html -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410217#410217 Attachments: http://forums.matronics.com//files/matco_6_inch_solid_tail_wheel_dollar180_130.jpg http://forums.matronics.com//files/matco_6_inch_pneumatic_tail_wheel_dollar200_907.jpg ________________________________________________________________________________
Date: Oct 10, 2013
Looking good, Rick. Cheers, Ken On Wed, Oct 9, 2013 at 8:34 PM, Rick wrote: > Well friends, > Here is a progress report that I hope is some inspiration for the rest of > you builders. I just finished the brush coats of primer on one of my wings > today. I still need to do the other wing half, which I hope to finish > tomorrow. All of the rest of the airframe is finished through the brushed > primer coats. > > I plan on starting the final finish spray painting in the next week or so. > > Rick Schreiber, > NX478RS > Valparaiso, IN > > > Sent from my iPad >
      > http://forums.matronics.com>
      > http://www.matronics.com/contribution>
Subject: A-65 tachometer cable
Date: Oct 10, 2013
Does any one have a good tach cable for the A-65, probably about 4' long? ACS seems to have them, but it is hard to determine if they will fit the A-65. Another question: the tach I have is non-recording but I have a Hobbs meter with two leads ( it has only 14 hrs on it), can it be used without an electrical system, no battery planned? Does the oil pressure sensor somehow send a micro voltage? Maybe I should just get a recording tach! But I like the looks of the old one! Thanks, Ray Krause SkyScout, motor mount done, working on the panel Sent from my iPad ________________________________________________________________________________
Date: Oct 10, 2013
Jim, Please stop referring to the "Mystery line" on your plans. There is no mystery. It's called a firewall. I believe your plane has the "long" fuselage. The photo clips that you posted are from the drawings for the "standard" fuselage (from the 1933 Improved Air Camper plans). The basic dimensions for the long fuselage were provided on a supplementary plan sheet, drawn up in the 1960's. However, there isn't a version of the drawing in your photo that applies to the long fuselage, so it's VERY likely that the builder of your plane just wrote in pencil, the dimensions that applied to his (your) plane. The distance from the firewall to the wing leading edge very well may be different from the number on your plans, as the wing may have been shifted to get the CG to fall in the acceptable range. Bill C. Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=410220#410220 ________________________________________________________________________________
Subject: Archive searches
Date: Oct 10, 2013
TIP: When searching the archives for previous posts, there are two methods. The first is accessed through the Forum: http://forums.matronics.com/search.php The problem is that this method will only give results that were posted after the Forum was up and running (2006). Previous to the introduction of the Forums, the List operated using a different format. Those messages are all stored in the old archive, which is also searchable, and contains MANY more results than the Forum archive. Access the old archive here: http://www.matronics.com/search/ Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410225#410225 ________________________________________________________________________________
Subject: Aviation Maintenance Technician Handbook
Date: Oct 10, 2013
I recently discovered the book "Aviation Maintenance Technician Handbook - Airframe" published by the FAA in 2012. I think it has some helpful information on construction that might be of interest to new and tosome long time builders (me). Also, the graphic are much better than what I have seen in other FAA publications. Best of all you can download it for FREE off of their website. http://www.faa.gov/regulations_policies/handbooks_manuals/aircraft/amt_airframe_handbook/ Chris -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410228#410228 ________________________________________________________________________________
Date: Oct 10, 2013
Subject: Re: A-65 tachometer cable
Its been a few years, but I ordered my tach cable from ACS. I also ordered the right angle drive to simplify installation. The right angle drive enables you to use a clockwise or counter-clockwise tachometer. I bought one with a built in recording hour meter. For oil pressure it would probably be best to use a mechanical gauge, which involves running a simple tube from the engine to the gauge. I used automotive oil pressure and temp gauges and they don't use any electricity. Ben Charvet NX866BC 189 hours after the flight this morning On 10/10/2013 11:49 AM, Ray Krause wrote: > > Does any one have a good tach cable for the A-65, probably about 4' long? ACS seems to have them, but it is hard to determine if they will fit the A-65. > > Another question: the tach I have is non-recording but I have a Hobbs meter with two leads ( it has only 14 hrs on it), can it be used without an electrical system, no battery planned? Does the oil pressure sensor somehow send a micro voltage? Maybe I should just get a recording tach! But I like the looks of the old one! > > Thanks, > > Ray Krause > SkyScout, motor mount done, working on the panel > > Sent from my iPad > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: W&B simplified------
Date: Oct 10, 2013
Thank you Bill C. for pointing out that the mystery line is the datum and i f I can futher point out that my Uncle Tony suggests in his book series tha t it is so much less confusing to use the nose of the airplane as the datum-- -that way all of your moment arms are + positive numbers and there isn't any confusion with negative distances from the datum as when you use the fi rewall. I used the nose of my airplane for the datum and doing the W&B as described by Tony Bingelis was a very straightforward deal, even for a guy like me who struggled with math. (well okay....at least how to correctly score a bowling game) Mike C. ________________________________________________________________________________
Date: Oct 10, 2013
Bill! Thank for pointing that out. I shoulda figured that out...duh! Thanks to a tip from Zeke, I googled Michael Brusilow and stumbled upon the Matronics Archives that has all his posts. Been reading them for hours. Learned so much about my Piet. Yes, it is the long fuse. Yes, the wings were shifted back 3.5". And the CG is 14.5 inches aft of the LE. And now I know what those 4 holes in the front cockpit floorboard are for. Color me a happy camper! -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410235#410235 ________________________________________________________________________________
Date: Oct 10, 2013
Oscar yes it was Malcolm Morrison, The only thing he did not cover much was painting with a sponge roller. With Valspar tractor paing you should never: paint in the sun, wind or on a grassy or dirty surface. We painted my old Suburban on the grass in the ditch beside my hangar, on a 104 degree day in a 10-15 mph breeze. It was red, just not shiny. The paint has turned black somewhat and is peeling off in some places. I sold that old truck to a coworker. He has put Big new shiny rims with big tires, replaced the exhaust, rear axle, steering box, power stearing system, radiator, had the AC worked over, replaced all fluids and most seals, had the interior detailed, shocks all the way around, and drives it today. He is a doctor and likes the rough appearance and so won't paint it. It will live forever. Blue Skies, Steve D On Wed, Oct 9, 2013 at 11:46 PM, taildrags wrote: > > [UNCLASSIFIED] Steve- was the latex paint webinar by Malcolm Morrison? > I've got to view that one. I've heard good things about it. > > I recall the red paint job that you, Steve & Freda Jones put on your old > Chevy Suburban in the blazing Texas heat. I think the paint was curing as > soon as it left the spray nozzle, so it's no surprise that the Suburban > didn't end up looking exactly like a Ferrari. It also might have helped if > the masking tape would have come off before the Texas sun permanently > attached the adhesive to your chrome trim ;o) It sure looked like y'all > had fun painting that day though. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410194#410194 > > ________________________________________________________________________________
Date: Oct 10, 2013
Thanks, Ben. I think I will just call ACS and see what they recommend for my set up. And thanks for the help with the oil pressure. I will have it all solved today, I hope! Ray Krause Sent from my iPad > On Oct 10, 2013, at 10:58 AM, Ben Charvet wrote: > > > Its been a few years, but I ordered my tach cable from ACS. I also ordered the right angle drive to simplify installation. The right angle drive enables you to use a clockwise or counter-clockwise tachometer. I bought one with a built in recording hour meter. For oil pressure it would probably be best to use a mechanical gauge, which involves running a simple tube from the engine to the gauge. I used automotive oil pressure and temp gauges and they don't use any electricity. > > Ben Charvet > NX866BC > 189 hours after the flight this morning > >> On 10/10/2013 11:49 AM, Ray Krause wrote: >> >> Does any one have a good tach cable for the A-65, probably about 4' long? ACS seems to have them, but it is hard to determine if they will fit the A-65. >> >> Another question: the tach I have is non-recording but I have a Hobbs meter with two leads ( it has only 14 hrs on it), can it be used without an electrical system, no battery planned? Does the oil pressure sensor somehow send a micro voltage? Maybe I should just get a recording tach! But I like the looks of the old one! >> >> Thanks, >> >> Ray Krause >> SkyScout, motor mount done, working on the panel >> >> Sent from my iPad > > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > > > > > ________________________________________________________________________________
Date: Oct 10, 2013
Hi Jim, I am using the Matco solid tail wheel on miss le Bec . 550 hours with no problems Randy Bush NX294RB Sent from my iPhone On Oct 10, 2013, at 9:59 AM, "Fun2av8" wrote: > > Has anyone had experience with Matco Tail Wheels ? > > I'm thinking about either: > > Tthe 6" solid rubber composite tail wheel $170 overall height is 9.71 inches & weighs 4.75 pounds. > > The 6" Pneumatic $199. Overall height is 9.71 inches. This assembly with pneumatic tire, tube, and wheel weighs 4.75 pounds. > > They are single arm as opposed to double arm which seems to be more durable and stable. But technology has advanced a lot. My concern is that with a single arm if will tend to lean to the side. > > Thoughts > > > http://www.matcomfg.com/CANTILEVEREDTAILWHEELASSEMBLIESSINGLEARMFORK-tp2-69.html > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper, VA KCJR > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410217#410217 > > > > > Attachments: > > http://forums.matronics.com//files/matco_6_inch_solid_tail_wheel_dollar180_130.jpg > http://forums.matronics.com//files/matco_6_inch_pneumatic_tail_wheel_dollar200_907.jpg > > > > > > > ________________________________________________________________________________
Subject: FWIW - Please dont reply to Messages using Quote
Date: Oct 10, 2013
I Know... I Know ... Its not my place to say this.....BUT !!!! In the interest of easy to read threads ... Please do not use the QUOTE button at the bottom of each post withing the thread. When you do Matronics copies the original post and dumps it below your response in your post. This sometimes makes the replies really long and there is no point. Please, Please use the REPLY POST button at the top and bottom of the thread. The posts are chronological.... No reason to repost the context that you are replying to. I Know... I Know ... Its not my place to say this.....BUT !!!! -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410265#410265 ________________________________________________________________________________
Date: Oct 10, 2013
Ben can you expand on how a right angle drive can work with both? I have a C85 and a counterclockwise tach. Thanks! Sent from my iPad Jack Textor On Oct 10, 2013, at 12:58 PM, Ben Charvet wrote: > > Its been a few years, but I ordered my tach cable from ACS. I also ordered the right angle drive to simplify installation. The right angle drive enables you to use a clockwise or counter-clockwise tachometer. I bought one with a built in recording hour meter. For oil pressure it would probably be best to use a mechanical gauge, which involves running a simple tube from the engine to the gauge. I used automotive oil pressure and temp gauges and they don't use any electricity. > > Ben Charvet > NX866BC > 189 hours after the flight this morning > > On 10/10/2013 11:49 AM, Ray Krause wrote: >> >> Does any one have a good tach cable for the A-65, probably about 4' long? ACS seems to have them, but it is hard to determine if they will fit the A-65. >> >> Another question: the tach I have is non-recording but I have a Hobbs meter with two leads ( it has only 14 hrs on it), can it be used without an electrical system, no battery planned? Does the oil pressure sensor somehow send a micro voltage? Maybe I should just get a recording tach! But I like the looks of the old one! >> >> Thanks, >> >> Ray Krause >> SkyScout, motor mount done, working on the panel >> >> Sent from my iPad > > > -- > Ben Charvet, PharmD > Staff Pharmacist > Parrish Medical center > > > > > ________________________________________________________________________________
Subject: new BPA Newsletter editor
Date: Oct 10, 2013
I got my new BPA Newsletter in the mail the other day (lots of good stuff in there, by the way), and I see that John Hofmann has stepped up as the new editor, beginning with the January 2014 issue. Perfect timing, kicking off the 85th anniversary year of the Piet. John will, of course, be succeeding Doc and Dee Mosher, who have raised that baby with loving care and kept it interesting and timely. I look forward to every issue. My favorite article in the latest issue is "A Brodhead Odyssey", Douwe Blumberg's narrative about his and Marci's trip to Brodhead 2013. Since I will probably not live to make that flight myself, I really enjoyed Douwe's story and the encouraging things that he found at old-timey airports along the way. Great reading. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410283#410283 ________________________________________________________________________________
Subject: Re: new BPA Newsletter editor
Date: Oct 10, 2013
PS, also in the current issue is the logo for the 2013 Brodhead event, which is really nice. If anyone knows how I can get in touch with Pat Weeden to find out more about the logo and possibly use the graphic for an art project that I have in mind, I would appreciate it. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410284#410284 ________________________________________________________________________________
Subject: Re: W&B simplified------
Date: Oct 10, 2013
Bowling scoring as applied to airplanes: if you have a good landing you get two additional tries :-) -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410286#410286 ________________________________________________________________________________
Subject: AC Move and address change
Date: Oct 11, 2013
Oscar's mention of the newsletter reminded me to change my address with Doc And Hoff. 2400 South 14th St, West Des Moines, IA. We love the house and acreage although the move is horrible. Moving the fuselage and wings this morning. Will have about 3 thousand square foot shop in the lower level and about a 300 foot drive to mess with the Piet. Quite a change from the old family room. Will post some shots when I get caught up. Sent from my iPad Jack Textor ________________________________________________________________________________
Date: Oct 11, 2013
Thanks Randy. That really boosts my confidence in the single arm tail wheel! -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410309#410309 ________________________________________________________________________________
Date: Oct 11, 2013
Jack, I bought one of these right angle drives for my A-65. Where the engine cables comes in to it, there is a barrel with the cable receiving threads on one side and a threaded cap on the other. It can be rotation reversed by swapping the threaded cap and cable receiving threads. It flops the gearing around so it spins the other way. A look at Aircraft Spruce's web page may make it a bit clearer to understand. http://www.aircraftspruce.com/catalog/inpages/tachdrives1.php -------- David Gallagher Zodiac 601 XL-B: flying, 250+ hours now Next project under construction: Finish my father's Aircamper Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410313#410313 ________________________________________________________________________________
From: "skipgadd(at)earthlink.net" <skipgadd(at)earthlink.net>
Date: Oct 11, 2013
Oscar, I think (webmasterATeaa.org) is Pat Weeden, or his brother. If not they can probably get you in touch with him. Skip > [Original Message] > From: taildrags <taildrags(at)hotmail.com> > To: > Date: 10/10/2013 11:39:45 PM > Subject: Pietenpol-List: Re: new BPA Newsletter editor > > > PS, also in the current issue is the logo for the 2013 Brodhead event, which is really nice. If anyone knows how I can get in touch with Pat Weeden to find out more about the logo and possibly use the graphic for an art project that I have in mind, I would appreciate it. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410284#410284 > > ________________________________________________________________________________
Date: Oct 11, 2013
Oscar, Make that (webmasterATeaa431.org) Skip > [Original Message] > From: taildrags <taildrags(at)hotmail.com> > To: > Date: 10/10/2013 11:39:45 PM > Subject: Pietenpol-List: Re: new BPA Newsletter editor > > > PS, also in the current issue is the logo for the 2013 Brodhead event, which is really nice. If anyone knows how I can get in touch with Pat Weeden to find out more about the logo and possibly use the graphic for an art project that I have in mind, I would appreciate it. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410284#410284 > > ________________________________________________________________________________
Date: Oct 11, 2013
Subject: Engine Gauges For Sale
Ray's post about tach. cables and engine gauges remonded me that I have thr ee, brand new gauges for sale. Oil press. and temp. and a mechanical tach. with hour meter. The two oil gauges are electrical. All are brand new and c ome complete in original boxes.- Email me if interested.=0A=0A=0A=0AIf Go d is your co-pilot...switch seats.=0AMichael Perez=0APietenpol HINT Videos =0AKaretaker Aero=0Ahttp://www.karetakeraero.com/ ________________________________________________________________________________
Date: Oct 11, 2013
Skip; thanks. I got an almost immediate response from Pat at the address you mentioned. His brother Bill is the artist who created the Brodhead 2013 logo and I'm getting in touch with him. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410335#410335 ________________________________________________________________________________
Subject: Re: Aviation Maintenance Technician Handbook
Date: Oct 12, 2013
Excellent resource Chris thanks! Sent from my iPad Jack Textor On Oct 10, 2013, at 12:24 PM, "Catdesigns" wrote: > > I recently discovered the book "Aviation Maintenance Technician Handbook - Airframe" published by the FAA in 2012. I think it has some helpful information on construction that might be of interest to new and tosome long time builders (me). Also, the graphic are much better than what I have seen in other FAA publications. Best of all you can download it for FREE off of their website. > > http://www.faa.gov/regulations_policies/handbooks_manuals/aircraft/amt_airframe_handbook/ > > Chris > > -------- > Chris > Sacramento, CA > WestCoastPiet.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410228#410228 > > > > > > > > > > ________________________________________________________________________________
Subject: Brusilow is on Facebook---for Jim McWhorter
Date: Oct 12, 2013
Jim-- I would think if you could just talk with the builder of your plane y ou'd be better off in the long run. If you're on FB you could message him here: https://www.facebook.com/#!/mic hael.brusilow?fref=ts (he's even got photos of your plane on there when it had a Model A Ford eng ine.) He's in his 90's....retired OBGYN. Perhaps he can give you his e-mail and or phone so you can hear about your plane directly from the builder without searching anywhere else. Mike C. ________________________________________________________________________________
Date: Oct 12, 2013
Subject: Aileron control cable routing
Gentlemen and Oscar, I am looking at where the aileron cables were on my plane. They were routed from the horns on the stick, crossing each other to a pulley mounted on the sdiewalls. Then they are routed straight up behind the instrument panel and to the wing root. The plans are not clear and photos I have seen don't seem to have this feature. They look like they simply cross each other and go straight up through the back side of the instrument panel. Opinions? Blue Skies, Steve D. ________________________________________________________________________________
Date: Oct 12, 2013
Subject: Re: Aileron control cable routing
Steve Mine go from the horns on the control stick directly to a pulley on the rear spar (crossing just below the instrument panel). Sounds like you have an extra set of pulleys between the stick and spar. rick h On Sat, Oct 12, 2013 at 4:32 PM, Steven Dortch wrote: > Gentlemen and Oscar, I am looking at where the aileron cables were on my > plane. They were routed from the horns on the stick, crossing each other to > a pulley mounted on the sdiewalls. Then they are routed straight up behind > the instrument panel and to the wing root. > > The plans are not clear and photos I have seen don't seem to have this > feature. They look like they simply cross each other and go straight up > through the back side of the instrument panel. > > Opinions? > > Blue Skies, > Steve D. > > * > > * > > -- Rick Holland Castle Rock, Colorado NX6819Z ________________________________________________________________________________
Subject: Re: Brusilow is on Facebook---for Jim McWhorter
Date: Oct 12, 2013
Thank's Mike. I found him on FB and have sent him a friend request. -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410419#410419 ________________________________________________________________________________
Date: Oct 12, 2013
There IS a reason for the datum to be forward of the aircraft. This is particularly true for transport category. Most are swept wing so leading edge of the wing is meaningless. Same with other commonly used GA ones like firewall, prop flange and so on. Since location of the datum is completely arbitrary, most big aircraft use a point in front of the plane. That way, all of the arms are positive and the math is slightly simpler when changing things like radomes that might be forward of, say, a front bulkhead datum. FWIW, the original Piper factory paperwork for our J-3 shows TWO datums -- the leading edge of the wing and the prop flange, though most people use the leading edge. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410420#410420 ________________________________________________________________________________
Subject: Steel tube Pietenpol for sale $1800
Date: Oct 12, 2013
> Hello everyone > > I am selling my PIETENPOL project > > Here are the details > > I purchased the project from Don Morris in Missouri in September 2011 And f rom my understanding built the wings landing gear center section fuel tank a nd control hardware he was given the airplane project from a guy in the mid 9 0s by the name of Brent Brown who started the project in the 80s and Did mos t most of the welding on the fuselage > > Steel tube fuselage > Steel landing gear with spring suspension > Steerable tail wheel > Matco wheels and brakes > Piper Struts designed to be at an V for less drag > Aluminum Turtledeck > Control cables and hardware > Instruments is already in instrument panel > Wings are mostly done > No logs > > serious inquiries please > > $1800.00 > > I can load and ship for extra cost > > First person with the money gets it > > > > > > > Bryce Reid > 405-226-3625 > Oklahoma City > 1 mile from KPWA
Date: Oct 13, 2013
Gentlemen (and Steve)- It sounds like with additional pulleys to divert the aileron control cables to the insides of the cabin, there may be more room (depth) for instruments in the instrument panel. Other than that, I can't imagine why it was done. It can't hurt, though. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410426#410426 ________________________________________________________________________________
Date: Oct 13, 2013
Post Construction Rear Cockpit Step ======================== I got a bit of a small problem and need some help. I am somewhat disabled due to a service connected aircraft accident. This makes it difficult to get into/out of the Piet. I have to literally put one leg in the cockpit and then hop up on to the fuse behind the pilot seat (do so ever so carefully), and then slide down into the seat. Getting out is, well to be honest, kinda funny to watch (so I've been told). I just sorta hang one leg over the side and grab on to the strut and kinda do a controlled bail out. I've looked at maybe doing the toe cut-out .... looks like a really really bad idea. Has anyone attached any kind of a step to the bottom of the Fuse below the pilot's seat? In my mind (keep in mind I'm not a builder) it just sounds easy to do. But, I am pretty sure its not simple. Can it be done? Any suggestions. One thing is for sure - I have to figure something out or one day for sure, I'm gonna break something. PS. one guy suggested I carry a step ladder.....yeah, like I got someplace to stow a step ladder after I am in the cockpit. Maybe a rope ladder ..... javascript:emoticon(':D') :D -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410427#410427 ________________________________________________________________________________
Date: Oct 13, 2013
With cabanes tilted back, full forward stick can contact the cables. Like Oscar says..."can't hurt..." Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Sunday, October 13, 2013 11:17 AM Subject: Pietenpol-List: Re: Aileron control cable routing --> Gentlemen (and Steve)- It sounds like with additional pulleys to divert the aileron control cables to the insides of the cabin, there may be more room (depth) for instruments in the instrument panel. Other than that, I can't imagine why it was done. It can't hurt, though. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410426#410426 ________________________________________________________________________________
Date: Oct 13, 2013
Jim, I have a recollection from over 40 years ago of watching Frank Tallman drop into the cockpit of a Grumman Duck. Not to minimize your injury, though, as it wouldn't take much to make it difficult to squeeze into a Piet! There must be 50 ways to make a step! Well, maybe a half dozen or so...but you will need access to the bottom framing, just behind the seat. If you don't already have a panel there, now would be a great time to make one. Good stuff to inspect under there... I have a step, and cannot imagine not having one. Yours may end up looking a little more like an afterthought, but I'll bet you could come up with some good ideas. See what you have for access, and go from there.... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Fun2av8 Sent: Sunday, October 13, 2013 11:18 AM Subject: Pietenpol-List: Re: Mr Sam - Pietenpol N687MB Post Construction Rear Cockpit Step ======================== I got a bit of a small problem and need some help. I am somewhat disabled due to a service connected aircraft accident. This makes it difficult to get into/out of the Piet. I have to literally put one leg in the cockpit and then hop up on to the fuse behind the pilot seat (do so ever so carefully), and then slide down into the seat. Getting out is, well to be honest, kinda funny to watch (so I've been told). I just sorta hang one leg over the side and grab on to the strut and kinda do a controlled bail out. I've looked at maybe doing the toe cut-out .... looks like a really really bad idea. Has anyone attached any kind of a step to the bottom of the Fuse below the pilot's seat? In my mind (keep in mind I'm not a builder) it just sounds easy to do. But, I am pretty sure its not simple. Can it be done? Any suggestions. One thing is for sure - I have to figure something out or one day for sure, I'm gonna break something. PS. one guy suggested I carry a step ladder.....yeah, like I got someplace to stow a step ladder after I am in the cockpit. Maybe a rope ladder ..... javascript:emoticon(':D') :D -------- Jim McWhorter N687MB (New Owner) Culpeper, VA KCJR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=410427#410427 ________________________________________________________________________________
Date: Oct 14, 2013
Subject: Post Construction Rear Cockpit Step
Jim, I don't know when/if my project will ever fly, but among the first things I did after buying the project from Corky was to add not one, but TWO steps on the port side for the pilot's cockpit. I have a bad left knee and a bad right foot, the agility of a statue, etc., so I need help. My current PC has no drivers for my old camera and the PC that has the drivers and my pix is sick with a bad power supply.... so I will try to describe: The lower and REAR step (for the right foot) is behind the seat. A steel vertical (streamline tubing) is supported by upper and lower longerons and pilot seatback frame. An "L" is effected by a smaller tube welded to it. This tube runs aft. That smaller tube running aft is level with the ground when the plane is parked, so the foot rests on it. The FRONT step is attached to the front of the seat, the part you sit on. A tube goes all the way from left to right, for full support, and extends about 6 inches out the port side. This tube attaches to several wooden frame members, vertical and horizontal. On the outside of the plane is a sleeve of airstream tubing that slips over this tube. A clever guy might find ways to build these so they extend and retract to cut down drag in flight. I went for simple and robust. A further couple of accommodations to my physical limits are a stainless handle to grab that is affixed to the turtledeck. The right hand grabs it as the left hand grabs the left rear cabane. As you state, my purpose is to hoist myself up onto the "saddle" of the turtledeck, then slide into the cockpit. This means the front of the turtledeck must be strong enough to support full body weight, so it might need to be beefed up a bit. Finally there is a faux headrest to affix the shoulder harness high enough to avoid spinal compression in an accident. I say "faux" because it is well behind the pilot's head, 6 or more inches back on the turledeck. This leaves room for the "saddle" right behind the seat. This may be clear as mud. If I get my camera and old PC linked again, I will send pix. We also can talk if you wish, to clarify. Let me know. Tim in central TX ________________________________________________________________________________
Date: Oct 14, 2013
Jim =2C the GN-1 plans shows a retractable step. There are two pieces of s teel tubing ( one=2C the step=2C slides inside the other which is fastened to the bottom of the fuselage under the rear seat.) There are two straps w elded to the outside tube which straps are also bolted to the inside of the fuselage bottom. The step has a flat plate welded over the outside end of the step to keep it from sliding back into the holder. the other end of t he step has a bolt through it to prevent the step from coming out of the tu be when you pull it out for use. I have the plans here somewhere and if I can find them I'll send them on to you. Chuck > Subject: Pietenpol-List: Re: Mr Sam - Pietenpol N687MB > From: iflyga(at)fun2av8.com > Date: Sun=2C 13 Oct 2013 11:18:29 -0700 > To: pietenpol-list(at)matronics.com > > > Post Construction Rear Cockpit Step > ======================== > I got a bit of a small problem and need some help. > > I am somewhat disabled due to a service connected aircraft accident. Thi s makes it difficult to get into/out of the Piet. I have to literally put one leg in the cockpit and then hop up on to the fuse behind the pilot seat (do so ever so carefully)=2C and then slide down into the seat. > > Getting out is=2C well to be honest=2C kinda funny to watch (so I've been told). I just sorta hang one leg over the side and grab on to the strut a nd kinda do a controlled bail out. > > I've looked at maybe doing the toe cut-out .... looks like a really reall y bad idea. > > Has anyone attached any kind of a step to the bottom of the Fuse below th e pilot's seat? In my mind (keep in mind I'm not a builder) it just sounds easy to do. But=2C I am pretty sure its not simple. Can it be done? Any suggestions. > > One thing is for sure - I have to figure something out or one day for sur e=2C I'm gonna break something. > > PS. one guy suggested I carry a step ladder.....yeah=2C like I got somep lace to stow a step ladder after I am in the cockpit. Maybe a rope ladder ..... javascript:emoticon(':D') > > > > > :D > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper=2C VA KCJR > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410427#410427 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Oct 14, 2013
Subject: Re: Post Construction Rear Cockpit Step
Jim, my step set up may be a little more complex than what you are looking to do, just because it is retractable and required some machining.- This method also requires you have full access to the area under the pilot seat as well.=0A-=0AThe pictures attached will show how it is made. The combin ation of the slot on one tube and the screw location on the other tube dict ate how far out the step slides and also keep it flush with the outside of the fuselage when retracted.- My step pulls out-4". -(I can take a pi cture of the assembly on the finished fuselage if you wish.) You will note that there are two mounting blocks. When weight is applied to the step, pre ssure is applied to the fuselage longeron. I added a piece of 1/16" plywood on the longeron under the tube so that the tube, over time, would not dig into the soft spruce. The second block attaches the assembly to a fuselage cross member. If you look close, the very end of the tube, inside the fusel age, is-wedged under a seat cross member. The weight applied to the step will try to lift the opposite end, so I arranged the assembly to butt under an existing, strong seat support.- There isn't any/much force on the-t wo attaching blocks themselves. Again, any place the tube comes in contact with the sof t spruce, I added plywood.- (I also recommend-doing this for any screw/ bolt holes through out the entire aircraft.)- I am not a fan of having ho les, screws, bolts, etc. going into the longerons, so I epoxied the attachi ng blocks into place. The fuselage plywood side acts as the gusset for the block mounted on the longeron. =0ABe sure to leave enough tube/step stickin g out to allow for the thickness of the fuselage plywood side, fabric, stre tchers, etc. =0A-=0AI plan on making a simple cover to cover the end of t he tube in flight, but if it makes some sort of cool turbo/whistling sound through the air, I may just leave it.- 8^[ )=0A=0AIf God is your co-pilot ...switch seats.=0AMichael Perez=0APietenpol HINT Videos=0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: Oct 14, 2013
Jim, What Gary said, access is the key. My Grega has an external step, basically there is a longeron size stick glued on the top of the bottom longeron under the seat and the step is attached to it. The step is .125 aluminum. I am doing a similar step on my Piet project. Can send more pictures if you want. Skip > [Original Message] > From: Fun2av8 <iflyga(at)fun2av8.com> > To: > Date: 10/13/2013 2:20:36 PM > Subject: Pietenpol-List: Re: Mr Sam - Pietenpol N687MB > > > Post Construction Rear Cockpit Step > ======================== > I got a bit of a small problem and need some help. > > I am somewhat disabled due to a service connected aircraft accident. This makes it difficult to get into/out of the Piet. I have to literally put one leg in the cockpit and then hop up on to the fuse behind the pilot seat (do so ever so carefully), and then slide down into the seat. > > Getting out is, well to be honest, kinda funny to watch (so I've been told). I just sorta hang one leg over the side and grab on to the strut and kinda do a controlled bail out. > > I've looked at maybe doing the toe cut-out .... looks like a really really bad idea. > > Has anyone attached any kind of a step to the bottom of the Fuse below the pilot's seat? In my mind (keep in mind I'm not a builder) it just sounds easy to do. But, I am pretty sure its not simple. Can it be done? Any suggestions. > > One thing is for sure - I have to figure something out or one day for sure, I'm gonna break something. > > PS. one guy suggested I carry a step ladder.....yeah, like I got someplace to stow a step ladder after I am in the cockpit. Maybe a rope ladder ..... javascript:emoticon(':D') > > > :D > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper, VA KCJR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410427#410427 > > ________________________________________________________________________________
Date: Oct 14, 2013
Hope this comes through. Having a bit of trouble attaching the sketch to t he E-mail. > Subject: Pietenpol-List: Re: Mr Sam - Pietenpol N687MB > From: iflyga(at)fun2av8.com > Date: Sun=2C 13 Oct 2013 11:18:29 -0700 > To: pietenpol-list(at)matronics.com > > > Post Construction Rear Cockpit Step > ======================== > I got a bit of a small problem and need some help. > > I am somewhat disabled due to a service connected aircraft accident. Thi s makes it difficult to get into/out of the Piet. I have to literally put one leg in the cockpit and then hop up on to the fuse behind the pilot seat (do so ever so carefully)=2C and then slide down into the seat. > > Getting out is=2C well to be honest=2C kinda funny to watch (so I've been told). I just sorta hang one leg over the side and grab on to the strut a nd kinda do a controlled bail out. > > I've looked at maybe doing the toe cut-out .... looks like a really reall y bad idea. > > Has anyone attached any kind of a step to the bottom of the Fuse below th e pilot's seat? In my mind (keep in mind I'm not a builder) it just sounds easy to do. But=2C I am pretty sure its not simple. Can it be done? Any suggestions. > > One thing is for sure - I have to figure something out or one day for sur e=2C I'm gonna break something. > > PS. one guy suggested I carry a step ladder.....yeah=2C like I got somep lace to stow a step ladder after I am in the cockpit. Maybe a rope ladder ..... javascript:emoticon(':D') > > > > > :D > > -------- > Jim McWhorter > N687MB (New Owner) > Culpeper=2C VA KCJR > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=410427#410427 > > > > > > > =========== =========== =========== =========== > > > /9j/4AAQSkZJRgABAAEBLAEsAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/2wCE AAkGBwgHBgkIBwgKCgkLDhgPDg0NDh0VFhEYIh4kJCIeISEmKzcuJig0KSEhMEEwNDk6PT49JS5D SEM8SDc8PTsBCgoKDgwOHA8PHDsnISc7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7Ozs7 Ozs7Ozs7Ozs7Ozs7Ozs7O//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEB AQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYS QVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5 usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIDJ0JrwMBEQACEQEDEQH/ 2gAMAwEAAhEDEQA/APbqYxaQhaADOKACgAoAKACgA7UALQAUAJQAUALQAUAJQAtABQAUAFABQAUA FABQAUAFAB0oAKACgAoASgBaACgBKACgBaACgBKAFoASgBaAEoAKAFoAKACgAoAKAEoAWgAoASgB aACgBKACgBTQAlABQAUAFAC0AJQAUAFABQAUALQAUAFABQAUAFABQAlAC0AJQAUAFAC0AFACUAFA BQAUALQAlAC0AJQAUAFABQAUAFABQAUAFABQAUALQAUAJQAUAFABQAUALQAUAJQAUAFABQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFAC0AIaACgBaAEoAKAFoASgBaAEoAKACgAoAKAFoADQAlABQAtA BQAUAFABQAlABQAUAFABQAUAFABQAUAFABQAjfdP0oA5/wAJbwtzvU5Mh5Jz3p3uO+h0NIQUAFAB QAUAFABQAUAFABQAjHCk+1AFeyfzEyMAelMbLNIQUAFABQAUALQAlABQAUALQAUAJQAUAFAC0AJQ AtACUAFAFeSadb2KJbfdAyndLvHynsMUh2LFMQUAFABQAUAFAC0AJQAUAFABQAUAFAC0AJQAUAFA BQAUAFABQAUAFAC0AJQAUAFACigBKACgAoAKACgAoAKACgBaACgBD04oARW3DigBaACgAoAKACgA oAKACgBaAEoAKACgAoAKAFoABQAUAJQAUALQAUAFAB2oASgBRQAlAC0AJQAUAFABQAUAFABQAdKA CgAoAKACgAoAKACgAoAKACgBaACgBKAFoAKAEoAWgBKAFoAKACgAoASgBaACgBKACgAoAKACgAoA KACgAoAKAD6UAFABQAUAFABQAlMYUhBQAtABQAUAFABQAUAFAC0AFACEZoAWgAoASgBTQACgAoAK AEoAWgBKAFoAKAEoAWgBKACgBaACgBKAFoASgBaACgBKAFoASgBaACgBKACgBaAEoAKAFoAKAEoA WgAoASgAoAWgBKAFoAKAEoAKAFoASgAoAKACgAoAWgBKAFoASgBRQAUAFACUAFABQAUAFABQAUAF ABQAUAFABQAUAFABQAUALQAUAFABQAlABQAUALQAlABQAtABQAUAFACUALQAUAFACUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAUALQAlABQAUAHSgAoAWgAoAKACgBKACgAoAKACgBaAEoAKAFoAKA CgBKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBD0oAwvCsYSK4K52tK3B5xzTd+o2jepCCg AoAKACgAoAKACgAoAKAEYZUg9xQBR0soFaJGB2fw46Cmxl+kIKACgAoAKACgBaAEoAWgBKACgAoA KACgBaAEoAWgAoASgAwO/agBaACgAoASgBRQAlABQAtABQAlAC0AAoASgBaAEoAKACgAoAKACgAo AKAFoASgAoAKACgAoAWgBKAFoAKAEoAKACgAoAWgAoASgAoAWgAoASgAoAWgAoASgBaAEoAWgBKA CgAoAKACgAoAWgBKAFoASgBaAEoAKACgAoAKACgBaAEoAKAFoASgAoAKACgBaACgBKACgAoAKACg AoAKACgAoAWgBKACgAoAKAFoAKAEoAWgAoAKAEoAWgBKACgAoAKACgAoAKAFoASgAoAKACgAoAKA CgAoAKAEFABQAtABQAUAFABQAUAFAC0AJQAtABQAUAFABQAUAFABQAUAJQAtABQAUAFACUALQAUA AoAKACgBKACgBaACgAoAKACgAoAKACgAoAKACgBKACgBaAEoAWgBKAFoAKACgAoAKAAUAJQAUAFA C0AFACUAFABQAUARXNxDax+ZO4RM4yaEmw2MDU/Eb2t6YohG0WBhue9XZLcLqw6HxCMjzZYMj7yD rj1zRyiukX01y0ZCcncOoGDilyhcamvWZYq7beM0coXJINZs5/uSDrjr0o5GNMtC8gLYEinseelK wr9CQTRnPzDj3pWGPBGODQAtACUALQA1shSR1oArWF9Fexs0RPynDfWm1YC1SAKAFoASgAoAKACg AoAWgBKADvjFAC0AJQAtACUAFABQAUALQAUAJQAUALQAlABQAUAFABQAUAFABQAUAFABQAtACUAF ABQAtACUAFABQAtACUAFABQAUAFABQAUAFABQAtACUAFAC9qAEoAKAFoAKAEoAWgAoAKAEoAKAFo ASgAoAKACgAoAKACgAoAKACgAoAKACgAoAQ/dIoAw/CSFLOVdpXEh4PXr1psexu/SkIKACgAoAKA CgAoAKACgAoAQ/dOPSgCrp4wpyBn+9QUy30oJCgBaACgBKACgAoAKACgBaACgBKACgAoAKACgBaA EoAKACgBaACgBKACgBaACgAoASgBaAEoAKADpQAtACUAFABQAUAFABQAvagBKACgBaAEoAKAFoAK AEoAWgBKAFoASgAoAWgAoASgAoAKAFoAKAEoAWgAoASgAoAKACgBaACgAoAKAEoAKACgBaAEoAKA FoAKAEoAUUAJQAtABQAlAC0AJQAUALQAlABQAtACUAFABQAUALQACgBKACgAoAKACgAoAWgAoASg AoAKAFoASgBaAEoAWgBKAFoAKACgBKAFoAKACgAoAKACgBKAFoAKACgBKACgBaAEoAMUAFAC0ANF ABQAtABQAUAFABQAUAFAC0AFACUALQAUAFABQAUAFABQAUAJQAtABQAlACigAoAKACgAoAKACgAo AKACgBKAFoAKACgAoAKAI5JY4lLSOqgdcmiwEI1C0LqgmXcRkCnZgWRSAWgAoASgBaACgAoAKACg AoAKACgAoAKACgBKAFoASgAoAKACgAoAKAMzxHaG7010UElTng4P4UmBl6Lb2Wp2b2d1BGfKxx0c fWqkuo9tC8fDGlFVD2+7ZyMsal3YXMv+zrOxunPkA7pNrJ3YHuKpRE2kazeHNKlQg2ww3OQTU6jT sQHwlpW0qqSLznIc9aabQXXYjk8J2xX5biXIGAW5xRzSWzDTsUf+ESvbclrXUN+Puq4IzTVSQuWI XNh4lhih8qVJtjfMkb7Mj8etP2ndDshBqniGBlD2bEDPBXP60c0AUWNn8VXsON0KBl5b5GIYe3vT 07A4ssDxLI0g+QjaQGTHK56E0aCsyzHrV3dedFDZSlkGAwHysaWg0u5b0CwubaIyXeEkf/lkn3Vq QZr0CCgAoAWgBKACgBaAEoAKACgBaAEoAKAEckLx1oBDImLA7hg0MbJKBB0FABQAUAHagAoAWgAo AKAEoAKACgBTQAlABQAtACUAFABQAUAFABQAUAFABQAUALQAUAJQAUALQAlABQAUAFABQAUALQAl ABQAtACUAFABQAtACUALQAUAJQAUAFAC0AJQAUAFABQAUAFABQAUAFABQAUAFABQAUAB6GgDI8OK VtpdwG5pGbrzTYGvSAKACgAoAKACgAoAKACgAoARuFPHagCC16ZznIoKZYoJCgAoAWgBKAFoASgA oAKAFoAKAEoAKACgAoAWgBKACgBaAEoAKACgAoAWgBKACgAoAWgBKACgAoAWgAoASgBaAEoAWgBK ACgAoAWgBKACgBRQAUAFACUAL0oASgBaACgBKACgAoAWgAoASgBaACgAoAKAEoAKAF7UAJQAtABQ AUAFACUALQAUAFABQAlAC0AJQAtABQAUAFAAKACgBKACgAoAWgBKAFoASgAoAKACgAoAKACgAoAK AFoASgAoAKACgBaACgAoASgBaACgAoAKAEoAWgBKACgBaAEoAKAFoASgBaAEoAKAFoAKACgAoASg BaACgAoAKADpQAlABQAtADaACgBaACgAoAKACgAoAKAFoAKACgBKAFoAKACgAoAKACgAoAKACgAo AKACgAoAKAEoAU0AJQAtABQAUAFABQAUAJQAtABQBU1K6+yWrOv3zwv+NAGDbWNzqMzNIwCkfPJk nJqm9LDWxYudCS2jaeGaQugyBjJzSTfUatsWtEv/ADx5Txujhc/N3PehiNekIKACgAoASgBaACgB KAF6UAFABQAUAFABQAUAFACUAHSgBaACgBKACgA68dqAOWvYW0S/W4iD+S/U9dze9WnfcPQ6K1u4 bqMPC4NS1YDJ8QxL58EmwEng5oih30NXT3WSyiZG3Lt60mrCuWKACgAoAKACgBCinqo/KlZAN8uJ STtQZ68daLDuOACjgAfSmIWgBaAEoAKACgAoAKACgAoAKACgAoAKAFoAawypGaAGQqRk0DZLQISg BaACgBKACgBaAEoAWgBKACgBaAEoAKAFoASgAoAKAFoASgAoAKAFoASgBaAEoAKACgBaAE+lABQA UALQAlAC0AFACUALQAUAFACUAKaAEoAUUAFABQAUAFACUALQAUAFACUAFABQAUAFABQAUAFABQAU ALQAlABQAUAB6GgDN0VRtnYckyH5vWmxs0qQgoAKAFoASgAoAKACgAoAKAEb7pxwcUAVrPzCPnAU DoAaY2WqQgoAWgBKACgAoAKACgAoAKAFoASgAoAKACgAoAKACgAoAKACgAoAKAFoASgAoAU0AFAB QAlABQAUAFABQAUAFAC0AFACUAFABQAUALQAlAC0AJQAUAFAC0AFABQAUAJQAUALQAUAFACUAL2o AKAE6UAFAC0AJQAUALQAdKACgAoASgAoAKAFoASgBaAEoAWgAoAKAEoAWgAoASgBaAEoAKAFoAKA CgAoASgAoAKACgAoAWgBKAF6UAJQAtACUAFABQAUALQAlABQAUAFAC0AFACUAFABQAUAFABQAtAB QAUAJQAtABQAlAC0AJQAtABQAlAC0AFABQAUAFAAaACgBtABQAtABQAUAFABQAUAFAC0AFABQAUA FABQAUAFABQAUAFABQAUAFAB2oAKAEoAWgAoAKACgBKACgAoAKACgAoAWgBKACgDl/E97LBJKoG7 Me1F28D1Jqo2BorWmo6lFEFhhcQ7AFYR/Ln2NNyV9h8r3NNdeV4pVkiOQMZI4J70rITTKuimH7eI o0O8Hduz2oewzqKkQUALQAUAFABQAUAJQAtABQAUAFABQAGgBKAFoASgBaAEoAKAFoASgAoAjnhj njaOZAyEcg0mBhPoM9irf2RPt+bKrKxIT1A+tNNp6hZXuINPvb54m1KaNfKYZVTnNNvsireZvW8U cEKxwjCKMAUiSSgBaAEoAKACgAoAwvEkjxvCGCeS3AY9Q3bFXB2A1rO5S5gV1IzjkZzipasBPSAK AFoASgBaAEoAWgBKACgBaAAUAFABQAUAJQAi9KAFoAKACgAoAKAFoASgBaAEoAKAFoASgBRQAUAJ QAUAFAC0AJQAUAFABQAUAFABQAtACUAFABQAUAFABQAUAFABQAc5oAWgBKAFoAKACgAoASgBaACg AoAKAEoAWgBKAFoASgAoAWgANACUALQAlABQAUALQAUAFACHigAoAKAA9DQBm6KgT7Tg8eYcKBwB TY2aVIQUAFABQAUAFAC9KAEoAKACgAbG05oAq2Ufl7sMdpPANMbLVIQtABQAlAC0AJQAUAFABQAt ABQAlABQAtACUALQAlAC0AJQAUAFABQAUALQAlAC0AJQAUAFABQAUAFABQAUAFABQAtACdO1ABQA UAFAC0AJQAUAFABQAUALQAlABQAUAFABQAvSgBKACgBRQAUAFABQAUAFACUALQAlAC0AJQAUAFAC 0AJQAUAFAC0AFACUAFABQAtACUAFABQAtACUAFAC9qACgAoAKACgAoASgAoAKAFoAKAEoAWgBKAC gAoAKACgAoAKAFoAKACgAoAKAEoAKACgAoAKACgBaACgAoASgBaAEoAKACgAoAKAFoASgAoAKAFo AKACgAoASgBaAGc0wFoAWkAUAFABQAUAFABQAtABQAUAFACUALQAUAFABQAUAJQAtABQAUAFABQA UAFABQAUAFABQAUAJQAtAB3oAKACgAoASgDE122jlcIwwsykO2cHAHamNF7R/JWxjhgLFIlCgt1p WsIlnsba4z5sKtn2oHdokighh/1UarxjIFArklAC0AFABQAUAJQAtABQAUAFABQAUAFAAKAEoAWg BKAIZbuCJ1R5FDN0GaaTAin1GCFCQTI3ZEGSaVgIo9Xt2dQ2U3DPzEcH0p27DsX1YMoZTkHoRSEL QAUAVtRlmgtJJLcKZFGRu6UIErmHHe6tf22+1t42kwR8z7Bn37inddB2sNtdD1N1Sa5uooZscxxZ KqfqetPnYWS0JrBtZtLsw3UYmRjxIvC//Wo5k9AsW9Uu7q1vIPLkiWEn5lYHLDvj0xSVrCsakbrI gdCCp6Gk1YB1ABQAm9dxXIzQAtAGV4l0+bUtMa3tiFlLDDH+H3o2GjM0PQNR02SNZbpHQdWXvT5m FkjqKQgoAKACgAoAWgBKACgAoAKACgBaACgBKACgBBQAtABQAUAFAC0AFABQAUAFABQAUAFACUAF AC0AJQAUAFABQAUAH0oAKACgAoAKACgBG4GRQAtABQAUAFABQAUAFABQAUAFAC0AFABQAlABQAUA FABQAUALQAUAFACUAFAC0AFABQAlAC0AJQAUAFABQAtACUAFABQAUAFAAaAKtgEAk2H+I544zTY2 WqQgoAKACgBaAEoAKAFoASgAoAZMcRPz2oBFXTX3JjccjqCelNjLtIQUAFABQAUAFABQAUALQAlA BQAtABQAUAJQAtACUAFABQAUAFABQAUAFABQAUAFABQAtACUAFABQAUALQAUAJQAtACUAFAC0AJQ AUAFABQAUALQAlABQAUAFABQAUALQAlABQAUALQAlABQAooAKAEoAWgAoASgBaAEoAKAFoAKACgA oAKAEoAWgAoASgAoAWgBKACgBaACgBKAFoADQAlABQAtACUAFAC0AJQAUAFAC0AFACUALQAlABQA UALQAlAC0AJQAUALQAUAJQAUAFAC0AJQAUAFAC9KACgBKACgAoAKACgAoAKACgAoAKACgAoAWgBK AFoABQAlABQAlABQAtABQAUAFABQAUAFAC0AHagAoASgBaACgAoASgBaACgAoAKAEoAWgAoAKACg BKAFoAKACgAoAKAEoAKAFoAKACgBi78ndjHagB1AFLWLf7RZOFOGXkGmgRFoxWNDCWGfyJoG0aVI QUAFAC0AJQAtABQAUAFACUAFABQAUAFAC0AFABQAlAGZrk0scUawvtYnn1xTQGPbaaLqZjDcbX3f vO+6m2x2NSPQIV+9PMeMcNip5pdw0Fj8PWKziZldyCCAzcZHtRdhc1sY6UCCgAoAZLIkSF5CAo65 oAxrkWlvdCe3k2T43FR3FNDYWuvREBJcFgPmIPSq5SbmpBe20/EUqtgZ4NS4tD32K9/b/wBpQ7VU psO5HYdT9KSa6FWtuZ1peTae5juy7BcL0+6O1Ve6Jd0b0M0cyBo2BB9KmwD6AMDWvMs7oXW9irDC gdj/AI1SGaem3ZntlabCN060n5CLC3ELPsWVCw7Z5pWYElAC0AJQAUAFAC0AJQAUALQAUAJQAtAC Z5xQAtACUAHSgBF6UALQAUALQAUAFABQAUAFACUAFAC0AJQAUAFABQAtACUAKaAEoAKACgAoAKAF oASgAoAR+FoQAOgoAWgAoAKACgAoAWgBKAFoASgBaAEoAWgAoASgAoAKACgBaACgAoASgBelACUA FABQAtABQAlABQAUALQAlAC0AJQAUAFAB0oAKACgCtZ/flx93dwaY2WaQgoAKACgAoAWgBKACgAo AWgBko/dPxnjp60AUdHgaKJmcEO5zgnoPSgbNCgQUAFAC0AJQAUAFAC0AAoAKAEoAKACgAoAWgBK AFoAKAEoAWgAoASgBaAEoAWgAoASgAoAKACgA54oAWgBKAFoAKAEoAKACgBaAEoAKACgAoAKACgA oAKACgAoAKACgAoAKACgAoAKACgAoAKAFoASgBaAEoAKAFoAKACgAoASgBaACgAoAKAEoAWgAoAK ACgBKACgAoAWgBKACgBaACgBKACgBaACgAoASgBaACgAoASgBaACgBKAFoASgBaAEoAKACgAoAWg AoASgAoAKAFoASgAoAWgBKACgBaACgBKACgAoAKACgAoAKACgAoAKACgBaAEoAKACgAoAWgBtABQ AtABQAUAFABQAUAHagAoAWgAoAKACgAoAKACgAoAKACgBKAFoAKACgAoAKAEoAKACgBaACgAoASg BaACgAoAKAEoAWgBrKGUqehGKAOdt/OtZ7hY9oKrtj3ckHtTbHYowa/qdjdyrq6rswNi4C5P1qm4 vZCaaOotL2G6RSjruP8ADmps0BapAFABQAlAC0AJQAtACUAFAC0AFABQAUAJQAtACUAZWtRB5YCX K5yuccVSYFfT5orOWTzWJHUY5AFFm0GxuI6OoZGDA9CDU2AWkAtMAoASgDE1DS9RvLpm+2otueFQ KeB/jTUmkFkOXw9b7maWSRmZdpwaTbYWSHTeHbGVFU+YMdw3Jpaj0E03w7aabcia3eXgcKTkU7sL o2KBFa9sobxNsowR0YdRQBgtY6np0rNbgyxkAZTqMd8U1LuhtaaMeNWvmQRGMiUnqEPGOx96LoOV kV3c3t1B/wAekrdsbSOfWjmQWZg2huZtQWCQshyQpGQSarnfQOU1V07VrSTfKA8WeJA3zL7mk5ic ext6Bd3FzGWuGUh/mQD0pMZr0hC0AFABQAUAFABQAUABoASgBaACgAoASgAoAQcChgLQAUALQAUA JQAUAFAC0AFABQAlABQAUALQAnSgBaAEoAWgBKAFoASgAoAKACgAoAKAA0AHagAoAKACgAoAWgBK AFoAKAEoAWgAoASgBaAEoAKACgAoAWgAoAKACgAoAKAEoAKACgAoAWgAoAKACgBKAFoASgAoAKAF oASgAoArWZ++oOcMfwpjZZpCCgAoAKAF7UAJQAUAFABQAUAI4BRgemKARDa9CRnFA2T0CCgAoAWg AoASgBaACgBKACgBaACgAoASgBaACgAoAKACgAoAKAEoAKAFoASgBaACgAoASgAoAKACgBaAEoAW gBKACgBaACgAoASgBaAEoAKACgAoAKAFoAKAEoAKACgAoAKAFoASgAoAKAFoAKACgBKAFoAKAAUA FACUALQAUAJQAUALQAUAJQAUALQAlABQAUALQAUAJQAUALQAlABQAtACUAFAC0AJQAtACUAFABQA UAFAC0AFACUALQAlABQAUAFABQAUAFABQAUAFABQAUAFAC0AJQAUAFABQAtACUAFABQAUAFABQAU AFABQAUALQAlABQAUAFAC0ANoAKAFoAKACgAoAKACgAoAWgAoAKACgAoAKACgAoASgBRQAUAFABQ AUAFABQAlAC0AFABQAlAC0AFABQAUAFABQAUAFACUAFAGNcp/wATQtGy8YDKOo96fQZoXthaX8YS 7gSUDkbh0qbAnYwrrRZrF1l04NIo/wCWe7BH0qubuFuw2DxJJbyeRc28mU4Jbg0/dfULNHSwSrNE sighT0yMVIh9AC0AJQAtAAKACgAoAKAEoAKAFoAKACgBKAGSxRyrtlUMuc4NALQxb61ism3QugGT +7PJOe30qkMpf2gUu1KDyXz84A+U46U9ALMPiaEsyu0XycOA/wAwPpihxJujdhmSZcoee49KhjJK ACgAoAKACgAoAKAFoASgAoAKAOe1yDyL2O6VkQDk+pNNIfQ3YWEsKN13KKWwjnb2D+zdSURb0glJ kAXoGHUfjVJ9BvU6SJ1kjV1PBGakQ+gBKAFoASgAoAWgAoAKAEoAWgBKAFoAQdKACgBBQwFoAKAF oAKACgAoAQUALQAUAFABQAdqAEoAKAFoASgBaACgBKACgAoAKACgAoAKACgBG6UAAoAWgAoAKACg AoAX2oASgBaACgAoASgAoAKAF6UAJQAUAFAC0AFABQAUAFABQAlABQAtAAKAEoAWgAoAKAEoAKAC gBaACgAoAKAEPQ0AVrRstL8wPzdu1NjZZpCFoASgAoAKACgAoAKACgAoAbLjynBIAx1PagEQWe4D YcFQOCO9MbLVIQlABQAtACUAFABQAUAL9KAEoAWgAoAKAEoAWgAoAKACgBKAFoAKADpQAUAFABQA lAC0AFACUAFAC0AJQAUAFABQAUALQAUAJQAUAFABQAtABQAlAC0AJQAUAFAC0AFACUAFAC0AJQAU ALQAlAC0AFACUALQAlABQAtACUAFAC0AFABQAlAC0AFACUAFABQAtABQAlAC0AFABQAUAJQAUAFA BQAtACUALQAUAJQAUAFABQAUAFACmgBKAFoASgAoAKACgAoAWgBKACgAoAWgBKACgBaAEoAKACgA oAKACgAoAKACgAoAKACgAoAKACgAoAKAFoASgAoAWgBKACgBKACgBaACgAoAKACgAoAKACgBTQAU AFACUAFABQAtACUALQAUAFABQAUAFABQAUAFACUALQAUAFABQAUAJQAUALQAUAFABQAlAGBJDdDW 5GSNijFecYAHrmmmOxv0hC0ARS28MpzJEjEeopWHckGBwO1MQUALQAUAFACUAFABQAtACUAFAC0A JQAUAFAEF7P9mtnkGMjpmhAcxcedLJ5rEK/+yOc+9XfpYZqw6PaMQxkfzGUZG79am7Ajn8K6bOxe WMMxxliBk496mw7o1rOzhsohHbptWmST0AYuoSa1HqIFtCj2jAAEEZU9yc/0o5kh2Ll/YvqFmsUk 7wPkEtGe9O9thaGYNL1e1XdFfLcOM4DArn68nNPn7odkKmr3NsJI9RhKlMfODgGkmmFmi5a6xDLd /Z/MViTgFfWny6XEalSAUAFABQAUAZuvwxy2B8zA2sDk9qENEulbk0+ISnpxn27UxEGtSK1uNn7w qclVPOKFoNEmjTGaBz2DcD0FDEaFIAoAWgBKACgAoAKAFoAKACgBKACgAoADwKAAdKACgAoAWgAo ADQAlABQAtABQAUAFABQAUAFACUAFAC0AJQAUAFAC0AJQAUAFABQAtADWoAXtQAUAFABQAtABQAl AB0oAKAFoAKACgBKAFoAKACgAoAKAEoAWgAoASgBaACgBKACgBaACgAoASgBRQAlACmgBKACgAoA KACgBaAEoAgtgFLIoxg0DZPQIKACgBaAEoAKACgAoAKACgBsoHlsCOMc0ICtYH5Bhwy4+XjFAy3Q IKACgAoAKAFoASgAoAXpQAUAJQAtACUALQAlABQAUALQAUAFACUALQAUAFACUALQAlAC0AJQAtAB QAdqAEoAKAFoABQAlAC0AJQAUAFABQAUAFAC0AH0oASgBRQAUAFACUALQAlABQAUALQAUAFACUAL QAlAC0ABoASgBaACgAoAKAEoAWgBKACgAoAKAFoAKACgAoASgBaAEoAWgAoASgBaACgAoASgAoAW gBKACgAoAWgBKAFoAKAE6UAFABQAtABQAlABQApoASgAoAXpQAlABQAUAFABQAUAFABQAtABQAUA JQAUALQAUAFACUAFABQAUAFABQAUAFABQAUALQAlACUAFAC0AFABQAUAFABQAUAFAC0AFABQACgA oASgAoAWgAoAKACgAoAKACgBKAFoASgAoAWgAoAKACgAoASgAoAWgAoASgBaACgBKACgAoAKACgA oAWgAFABQAUAFACUAFAC0AFABQAlABQAUANlClDvGQOaAOW1K+SaeSO1KJhDudl61otBsijllY28 qsFaJAN+7Oad+wWLU2sXttkeWGC+vOajTYTNfS9QN9HlojGw/EUmkFi/SAKACgBaAGSRpKpWRQyn qCKA2KkOlWMFwJ4bZEkHQjtSHcu0xBQAUALQAlADJYklTZIoZcg4PtQCOY8UahewXcdtbQnDAFSB kD1NUmkOxFpsX2yeVL47UbgA/wBD2ptvoCSOnsLSCyt1htxhOuc5JPqagRYoAWgAoASgBaAEoAKA FoAKAEoAOlABQAUAB6cUAIPagBaACgBaACgAoASgBTQAUAFABQAdqACgBKAFoASgAoAKAFoAKAGq qrnaAMnPFAC0AFABQAUAFABQA1zigBGk2Mi7GIbjIHA+tGgWH0AFABQAUAFABQAtACUAFAC0AFAC UALQAUAFABQAUAFABQAUAFABQAUAJQAtACUAFAC0AJQAtAB0oASgAoAKAFoAKAEoAKACgCC1XYHH fdQNligQlABQAUALQAlAC0AJQAUAFAEdwdtvIfRTQgIdPIMCbemOKBstUCCgAoAWgAoAKAEoAKAC gAoAWgAoAKAEoAKACgBelABQAUAJQAgOc8YxQAtAC0AFABQAUAJQAUAFABQAUAFABQAUAFAC0AJQ AtABQAlABQAUALQAUAJ0oAWgBKACgBaACgBKAFoASgAoAKACgBaAEoAWgAoASgBaACgBKAFoAKAC gAoAKACgBKAFoASgAoAKAF7UAJQAUALQAlAC0AFABQAUAFABQAUAFABQAlABQAUALQAlABQAUAFA BQAUAFABQAtACUALQAUAJQAUALQAUAHSgBKAAkKpJOABkmgARgyhlOVIyDQAtACUAFAC0AJQAUAF ABQAUAFAC0AJQAUAFABQAUALQAlABQAUALQAlABQAlABQAtABQAUAFABQAUAFAC0AFACUALQAlAB QAUALQAUAFABQAdqAEoAWgAoAKAEoAKAFoAKAEoAKAFoAKACgAoAKAEoAWgBKACgAoAWgAoASgAo AWgAoASgBaAEoAoK9x9pIOGG7HHYUyjQpEhQAlABQAtACUALQAlADZFLIVU7T60AihFo9usryTfv WbIORxj6UNjv2J10+1VNiRBV68UBchk0aykl8wxnJGCM8H8KL6WC5dhhigQJCgRR2FIRJTAKAEoA ybrX7SBGdcuqkgkdiKpRFcp23iu1ljhdoyglbau49abgugXOiUggEdDUDFoASgAoAKAGzP5UTvjO 0E4oAwZtT1KdcWdrw3G7H3aq8UPlY2RdaKMTwQAAAo/Gk5IdipP5+HaWMwtuCsWXr7inFrYRd8Pa i0p8na3lhiFY0MVzoKkBaACgAoAKACgAoASgBaAEoAKAFoAKAEPSgBF6UALQAtABQAdqAEoAKAFo AKAEoAWgAoAKACgBKAFoASgAoAWgAoAKAEoAUUAJQAUAFABQA1+lCGhwoEFACigBKACgAoAKACgB aACgBKAFoAKACgBKAFoASgBaACgAoAKAEoAWgBKACgBaACgBKAFoASgAoAKAFNACUAFABQAvagBK ACgAoAggbM0gC8DHzetA2T0CFoASgAoAKAFoASgAoAWgBKAI7ltlvI3TCk0ICrpRXyiEZ2RvmBYY 602Nl+kISgBaACgAoASgAoAWgBKACgAoAKAFoAKACgAoASgAoAWgBKAAUALQAUAFABQAlABQAUAL QAlAAKAFoASgBaACgAoASgAoAU0AJQAUAL2oAOlACUAFABQAtABQAGgBKACgBaAEoAKACgBaACgA oASgAoAWgAoAKACgBKAFoAKAEoAWgBKACgAoAWgAoASgAoAKACgAoAKACgAoAWgBKAFoASgBaACg BKACgBk3miM+QFL9gxwKAH0ALQAlABQAUAFABQAtACUAFABQAtABQAUAJQAUAFAC0AJQAUABAIII 4NAAAFAAGAOgoAKAFoASgAoAWgAoAKACgBKACgAoAWgAoAKAEoAKACgAoAWgBKACgAoAKAEoAKAF oAKACgAoAKACgAoAWgAoAKACgBKACgAoAWgAoAKACgAoAKACgAoASgBaACgAoAKACgAoAKAEoAKA FoASgBaAEoAWgAoAKACgBKACgAoAWgBKACgBaAEoAyHZU1CQI4fJGR3SmUasZyikntSJH0AFAB0o ASgAoAKACgAoAb5ibtm4bvSgBrzxI21nUNjO3POKdgK6anavIESQk/TpRYXoWwQRkHNIYtABQBX1 C5jtLSSab7oHrjNNIDkbO00eac3UD7zneI5GPP8AjVNS6juuhtWiaTqcgZrWNZouACAD9QKhwS2H zM3AAOB0FBIUAFABQAUAFAAAB0GKACgAKgjBAxSAhhtLeCRpIolRm6kCmFyagBaAEoAKAFoAKAEo AKAFoAKACgBKACgANACDpQA6gBKAFoASgAoAWgBKACgAoAWgBKACgBaAEoAKACgAoAKAFoASgAoA KACgAoAKACgBkjBQM96ECHjpQAUAFABQAUAFABQAUAFABQAUAFABQAtABQAUAFABQAlAC0AFABQA lAC0AFABQAlABQAtABQAlAC0AFABQAUAFABQAlAC0AIehoAr2z5lkUptK9/WgbLFAgoAWgAoAKAE oAKAFoABQAUAMlG6Jx6igCCxUhNxGMjoOlA2WaBC9KACgAoASgAoAKAFoASgBaACgAoASgBaAEoA WgAoAKAEoAKACgBaACgAoAKACgAoASgBaAEoAKAAcAd6AFoAKAEoAWgAoASgAoAKACgAoAKACgAo AWgBKAFoASgBaACgAoASgAoAKACgBaAEoAKAFoAKACgAoAKACgAoASgAoAWgBKAFoAKACgAoASgA oAKAFoAKACgAoAKAEoAWgBKACgBaAEoAKACgAoAKAAH2IoAKACgBaACgBKACgAoAWgAoAKACgAoA KACgBKACgBaACgAFACUALQAUAJQAUAFAC0AJQAtACUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA lAC0AFABQAUAFABQAUAB6UAFAC0AFACUAFAC0AFABQAUAFABQAUAFABQAlAC0AFABQAUAFABQAUA FABQAUAJQAtABQAUAJQBDdXUNpH5k7hVppN7APjlWQZX0zSAeCCMjpQAtACUAFABQAtACUALQAUA ZOsKYmWZAAADvbFND6FjSGT7IqoynHPFEvMRdpAFAC0AFACUAH0oAKAK2oFxCpjYrhssR6UIaOab UPs9yZllWRmyWAyMemPWtErk+g/S7CW8zciQK8vzSZJJHtUuT2KJmhlsPOjcZYr8rdQwz/OlfXUL WWhoaTOUIt3XaT90+tDF0NWkAUAQ3kXnWske1WyvAbpStcaObtNJsLw+XPGYrgDkoelO1tRlefQt W0qRrjSjFdtvBCycEL6U+d9RWOn0trtrNDfKiTHkqvQe1Ju+wi3QAtACUAFABQAtABQAUAJQAtAB QAlABQAtABQAlAC0AJQAtACUALQAUAIelACIABxmhgOoASgBaACgBKAFoAKACgBKAFoAKACgAoAS gAoAKACgAoAKACgBaAEoAKACgANABQAyRTtO1sHtmgY8ZGPSgQUAFABQAUAMij8vd8xbc2ee1IbZ JTEFACDntigAoAKAFFABQAlAC0AFACUAFAC0AFABQAUAJQAtABQAUAFACUALQAlABQAUAFAC0AJQ AUAFABQAtACUAVbLl5iM43d6BstUCCgAoAWgBKAFoAKAEoAWgBKAGy8Rt9KARHbBVQIh4UYpjZNS ELQAlAC0AJQAUAL2oASgBaACgBKAFoASgBaACgBKAF7UAFABQAUAJ0oAKACgAoAWgAoASgBaACgA oASgAoAKAFoASgBaAEoAKAFoATpQAtABQAlAC0AJQAUALQAUAFACUAFABQAUAFAC0AJQAtABQAUA FACUAFAC0AJQAUALQAUAFACUAFABQAUALQAUAFAB0oAKACgBKACgBaACgBKACgAoAWgBKACgBaAE oAWgBKACgAoAKAFoASgAoAWgAoASgBTQAlABQAUALQAUAJQAUALQAUAFACUALQAUAFACUAFABQAU AFAC0AJQAUALQAlAC0AJQAUAFABQAUAFABQAUAFACUAFABQAtABQAUAFABQAUAFAC0AFACUAKaAC gAoASgAoAKAFoAKACgAoASgBaACgAoASgAoAWgBKAFoASgBaACgAoAKACgBOlAEV1AtxA8TjIIoW gGRptxNFcyR3AYbSFyae4+huUhC0AFACUAFAC0AFABQAUAZXiCSWK1DQEB89TTVhowtIa5ijVWLF zliEGBiqv3BGtb6s5hDZ3YYg5GOlJpCLkepxMPmKgYzwaVh2J4LyKb7posIsUgCgBTQAlAFecMSy E/Iw69xTGjn7+wRnj81AyA4R14x7/Wna49i7YTi0PluF92B7ChoWhY1PyLux8wSqNvIJ/lSV0GxQ 0u7ZpVKR5jA2jYPem1Z2YJ3OiqRBQANwCQOaAOO1PWjZaiwezZdjcvsIDCqTT0uNpo09I8S2t9hM /MRnOOBTcCTdVlYZUg1AxaACgBaACgAFADWZUUsxAA6k0ARi5hzt8xQfc9aLMCUEHoQaAFoASgBT QAGgAoASgBaACgAoASgAoAKACgAoADQAL0oAXpQAUAJQAUAFAC0AFABQAlABQAtACUAFABQAUAFA BQAUAFABQAUAGaACgAoAPpQAUANY+tAx1Ag79KACgAoAOlABQAUALQAUAFABQAUAFACUAKKACgBK AFoASgAoAWgAoAKACgBKAFoAKAEoAKACgAoAWgBKAFoASgBelAB2oASgBaAEoAr2ud0mT34oGyxQ IWgAoASgBaAEoAXpQAlAC0ABoAZMMxMOmRQCI7ddoAPDY5x0pjZPSEFABQAlAC0AFABQAlABQAtA BQAUABoASgAoAKACgBaAEoAUUAJQAUAL9KACgBKAFoATpQAUALQAlAC0AJQAUAFABQAtAAKACgBK ACgBaACgBKAFoASgBaAEoAKADpQAUAFABQAUALQAUAFABQAlABQAUALQAUAJQAUALQAlABQAtACU ALQAlABQAUAFABQAUAFABQAtACUAFAC9qAEoAKACgAoAKACgAoAXtQAlABQAUALQAlABQAtACUAK aAEoAWgBKACgAoAWgAoAKACgAoAKACgBKAFoAKAEoAKACgBaAEoAWgBKAFoAKAEoAKACgAoAKAFo ASgAoAKACgBaAEoAKAEoAKAFoAKACgAoAKACgAoAWgAoATpQAUALQAUAFACUALQAlABQAtABQAUA FABQAUAJQAtABQAUAFABQAlAC0AFABQAlAC0AJQAUAYusWuy4S5T+IgNkZGaaeg+hD/b0lvL5Btm kI/iBxn6UaCZq2uowXUhSM/MBnmhoEWx7UgCgBaACgAoASgAoApaspNmSuNysCM0IEUNKCDEbp8z klj602M0H0y2K7VXavoOlLYLlS40NZITHDKYyTncBzRew7li008wSAlhgDgAd/U07iNCpEJTAKAF oAhukLxZH3l5GKBoyo5VF59nO+ReoH931qmtB6El3pZZ2mt3ALLjGOtSIzza37RpB5JDkBdx6KM1 TYWNbTdKhs3aUIBK3XBOKm4O3Q0KBBQAUANlijlUrKiup6gjNJgjmtd8M6fcuDBN9huHIwydwO2K cbx2HfuWfDmn32ns6XOordw/w8cj0qnK+4tLaG9UgLQAlABQBBfTi2tnl2liBwB3NCA4W2u9SvL5 beMuwfO8O2B7datyFY2V8KzNiSXUH87uQOPoKlzZVkGjTXenzzW95OCN3yBuCKbuxHUKQygjvUgF ABQAtABQAUAFABQAUAFABQAUAJQAUAHagABoAKACgAoAM4oAKAFoASgBaACgAoAKAGLIrMwU5KHB 9qB2sPoEJQAtACUAFABQAUAFABQAUAFABQAUAFADWwMZOKAFIPGDjFAC0AFABQAUAFABQAUAFAC0 AFABQAUAFACUALQAlAC0AFABQAUAJQAtACUALQAUAJQAtABQAlAC0ABoASgBRQAUAFABQAlAC0AF AFa2jjSaVkzuY/N9aBss0CCgBKAFoASgBaACgBKAFoAKAGS8Rt9KARDaEsu5vvGgbLFAgoAWgAoA KACgBKACgBaACgBKACgAoAKAFoAKACgAoASgBaACgBKAFoAKACgAoAKACgBKAFoAKACgAoAKACgA oAKACgAoAKACgBKAFoASgBaACgBKACgAoAKAFoASgBaAEoAWgAoASgBaACgBKAFoAKACgBKAFoAK AEoAWgBKAFoASgAoAKACgAoAWgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoASgAoAKAFoASg AoAWgAoASgAoAKACgAoAKAFoAKACgAoAKACgAoAKACgBKAFoASgAoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgBaAEoAKAEoAKAFoAKACgAoAKACgAPSgAoAWgAoAKACgAoAKAEoAWgAoASgBaACgAoA KAEoAWgBKACgAoAWgAoASgBaACgBKAFoAKACgBBQAUAVtRg+0WcsYyDjIx60XsBz9lZ2905tr9yz n7nOCPoRVXfQexYvdDuVkWSyl3bAMKTtJP1qeZgNm1K/05v9KUNuHHGAPxqlbqDRe0vXLbUZPLjI D/3c0OIjWqQEoAKACgBaAK2oOEtJCSMgZAJpoDEspPtDGd5RiNuMDim0NHRjkA1IgoAKACgAoAKA FFACdqAMPUI/KlLM5TqCQQMimhuwQa8ikrJAViAG11YEEVTihMm/t+1IO1XLgfdpcohIdfgkfYYp FbHApNWGjWRg6BgDgjvSAUkKMk4FABQBk6zrcWnkRBHaRjjIHC+9VFXEYVhptzrrNNPcyLbg/Iw+ 9nvj2pubWiHZdS1LYSaA8U8M80kQOGDH73saSk9mx2XQ6W2nS4hWWM5VhkVL0ESUAFABQBl62s8s YijjkMZ+8yYz+VNNLqMwNQ0+a0kW4ZMBRjPb8fenF66A3odLpN4Lu2X++AM0mhFDxXY+dZG5jz5k WDkHtQtxl3RLhJ7NAshkKqMk+9DVhGjSAKACgAoAKACgBKACgBaAEoAKACgAoAKAEFAC0AHSgAoA KAFoASgBaAEoAWgBKAFpAQW1sluZShJMjlzn1oSsVKVyamSHFABQAUAFABQAUAFABQAUAFABQAUA FADX7UAh1AB9KACgAoAKACgAoAKACgAoAKACgAoAWgBKAFoAKACgAoAKAEoAKACgBaACgA7UAFAB QAUAFABQAUAFACUAFABQAtAAaAD6UAJ2oAgt/wDWyN0zx9aBssUCCgBKAFoAKACgBKACgAoAWgCO f/VNg4460AiKyZHj3RkkH1oGyzQISgBaACgBKACgBaAEoAWgAoAKACgBKACgAoAWgAoAKACgAFAB QAlABQAtABQAUAFABQAUAFACUALQAlAC0AFABQAlAC0AJQAtABQAUAJQAUAFAC0AJQAUAFABQAtA CUAFAC0AJQAUAFAC0AFABQAUAFACUALQAlAC9qACgBKACgBaACgBKAFoAKACgAoAKAEoAKAFoASg BaAEoAWgAoAKACgAoAKAEoAKAFoASgBaAExQAEgdeKACgBaACgANACUAFAC0AFABQAlABQAtABQA lABQAUAFAC0AFABQAUAHSgAoAKACgBKACgAoAKACgAoAKACgBaAEoAWgBKACgBaACgBtABQAtABQ AUAFABQAUAFAC0AFACUALQAlAC9KACgAoAKACgBKAFoAKACgAoAKACgAoASgBaACgBKAFoASgAoA WgBKAFoASgAoAWgBCMjHagDmJnW11QO4CbH2Djn8PrVdAOnHSpAjngjuImimQOjDBB70gTsR2tja 2gC20CR4GPlFCVguWKYC0AJQAUAVtRlnhtWa1i8yXgAenvQFrmKoeW6kW/XzGH3SRgfQCq5lsilG zMqyDWMsyqH2sxLc469sU76COgtb5441DHJ2ZCsMfrSdhGnDcRzfcYdM8GpAloAWgBKACgAoAKAO b1uCS4vcxW5lIXacn+VWmrDGW2g3TRsJjGgONoXsKm49OpdXw9ASxldiWGDjikmxFjTtEtLADy97 sDnLtmhthc0qBBQAUAcv4ysJSIr6zGJ0O0n2pp2Dc0PDE0P9mRwphWTORnqepP60O26DXqad1GJb d02B+OFPekNGL4euCs8lq6NHIMkox6c03qDVjoKQhKAFoASgBk0STxNHIAVYYoA5i4W50m48xdwQ YVT1DCqT6MbXYvz61bzWTANtlY7QCpxmnyisO8PJIv2jfnaCAPT8KgZtUCEoAiupjbwtIIpJSP4I xkmjTqNK+hIhJUFlKk9j2oELQAtABQAlAC0AFACUAFABQAUAFABQAUAFAC0AFACUALQAUAFACUAL QAlABQAtACUAFABQAUAFABQAUAFABQAUAFABQA2QA4zQgHUAFADXBZWUMVJHUdRQAqgqoBJbA6nv QAtABQAUAFABQAUAFAAKACgBaAEoAKAFoASgAoAKAFoAKACgAoAKACgAoASgBaACgAoAKAEoAKAF oASgBaACgAoASgCvadXz2Y8UDZY70CFoAKACgAoAKAEoAKACgAoAgvmKWcrKMkLQgG2BQxL5fTAO B2psbLVIQlAC0AFACUALQAlAC0AFACUALQAlABQAtABQAUAFABQAUAJQAUAFAC0AAoAKAEoAKAFo AKAEoAO9ABQAUAFAC0AFACUALQAlABQAtABQAUAJQAtABQAlABQAUAFABQAtABQAUAFACUALQACg AoASgBaACgAoAKACgAoAKAEoAKAFoASgAoAKAFoAKACgAoASgBe1ABQAlABQAtABQAUAFABQAUAF ACUALQAUAFACUALQAlAC0AJQAtAAKACgAoAKAEoAKAFoASgAoAKAFoASgBaACgBKACgBaAEoAKAC gAoAKAFoASgAoAKAFoAKACgBKAFoAKACgAoAKACgAoAbQAUALQAUAFABQAUAFABQAtABQAUAJQAU ALQAlABQAtABQAlACigAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBKACgBaACgBKAOf1vSbm81 KGaBsRjBbp1FNDN9AVQA9QKQivqM7W1nJKg5WhAQaZqH2zO6MxkjIBptWA0aQBQAUAFABQAmB6Cg Dl73RLq51SKSRiYxn5kOCBnge9F2thm1NpymELFhXC7ckZyKLsLmPP5+n3m8osalMkL0NUn0BovW WpIpCszFSedxyVzRYRsVIBQBXvbn7LDuABc8KD0zQgM/TdSu7udEkgVFAIfBzz7U3ZAbB6UgMmWW RrtVjw0athsdRTGakX3BgYpCY6gAoAWgBKACgCK5t47mFoZhlG684pAc5e6DJpz/AGnSd5x8zITz n2q1KwNX2LWm69HOitMxV1+SRSMEH6U3HsK9tCC1miuPEG61ccZ3YXnHpUvQo6akIKAEoAKAFoAY 8ayKVkUMp7EUBsUH0a0dwSGCA5EeflzQO5oIiou1AFA7CgQtAC0AFABQAlAC0AFACUAFAC0AFACU AFABQAUAFAC0AJQAtACUALQAUAJQAUAFAC0AFACUAFABQAUAFABQAUAFABQAUAFABQAUAFADX6rz ihDHZoENfcFJQAt2BOKAHDpz1oAKACgAoAOlABQAtACUALQAnQUAFAC0AFACUAFAC0AFACUALQAU AHSgBKAFoAKACgAoAKACgBKAFoASgBaAEoAKACgBaAEoAKAK1qP30xwAC1A2WqBAKAEJA6nFAC9K AEoAKAFoASgBaAEoAhvU8y0lQEjKkcUIEVtJhWCJgpzuOSSe9NjZoUhCUALQAd6ACgBKAFoAKAEo AWgBKACgAoAKAFFABQAUAFABQAdqAEoAKACgBaAEoAWgAoASgAoAWgBKAFoAKACgAoASgAoAWgAo ASgBaACgBKAFoAKACgAoAKAEoAWgAoASgAoAKAFoASgBaACgAoAKACgBKAFoAKAEoAKACgAoAWgA oAKACgBKACgAoAKACgBaACgAoAKACgBKACgBaACgAoASgBaAEoAKACgAoAWgAoAKACgAoAKACgAo ASgAoAWgBKACgBaAEoAKAFoAKACgBKACgBaAEoAKACgAoAKACgBelACUAFABQAtABQAlAC0AJQAU AKKAEoAKACgBaAG0AB+tAC0AFABQAUAFABQAUALQAUAFABQAUAJQAtABQAUAFACUAFAC0AFACUAL QAUAFABQAUAFABQAUAFAB2oAKAAUAJQAtACUALQAUAJQAZoAbLGssbRuMqwwRQGxz9kVt9RfdgMH KgY7evtVdBnRdqkQUAFAC0AJQAUAZ11rEFtklWZVPJHQe9NRCxYS/tWVWE6fN0BPJo5WBSudQt7p XtkBORg8dKLNAUdMszc3TNhlgRduCMbqew7HSAYGB2qRBQBjazvluVRdwWNdzEdvSqQadSLRHzfS Dd8oQKBjGfUmlp0Q9TePQ0hHOSlzfgbm+VuABhs1XQZt6fIJbZXBPJPXr1pMRYpAFABQAUAUdcvW 0/TJrhB8yjC9OD601uJmTpg1i+s0u4tRQCRRhWjBH6UOVnsCj5ls6hf2Lot/beYjHHmxdB7n0oVm O3Yj1DTLDVrNru33BiCQ8fG4j+dTblY730J/DkFpHYRtaoA2MM3Un61TEa1IBaACgBKACgAoAKAC gAoAWgBKAFoASgAoAWgAoASgBaAEoAKACgAoAB0oAKACgAoAKAFoAKAEoAKACgAoAWgAoASgAoAK ACgAoAKACgAoAKACgAoAKACgAoAguFDNHzgg5poaJqQhaACgA9qACgAoAWgBKAFoAKACgAoAKAEo AWgBKAFoATpQAUAL2oAO1ABQAlABQAUAFAC0AAoAKACgAoAKACgAoASgAoAOlAC0AFACUAVrTZ5k 2zqG+agbLNAgoARlVsblB2nIz2NAXFoAWgBKAFoASgBaAEoAjuCBA5YlRg5I7UAivpq+Wjxg8KcA +vFDAuUAFAB0oAKAFoAKAEoAUUAFACUAFAC0AFABQAlABQAUAFAC0AJigBaAE70ALQAlAC0AJQAU AFAC0AFABQAlABQAtABQAUAHSgAoAKACgAoAKACgAoAKACgBKAFoASgBaAEoAKACgAoAKAFoASgB aAEoAWgBOKAFoAKACgAoAKACgAoASgBelABQAUAFABQAlAC0AJQAUAFAC0AJQAtABQAUAFABQAUA FABQAUAFABQAUAFACUAFABQAUAFABQAtACUALQAUAFABQAlABQAUALQAlABQAooAKAEoAWgAoAKA CgBKACgBaACgAoASgBaACgBKACgAoAKAFoASgAoAWgBKAEoAWgAoAKACgAoAKACgA7UALQAUAFAB QAUAFABQAUAFABQAUAFABQAUAJQAtABQAUAFABQAdqACgAoAKAAUAJQAUALQAdqAEoAMUALQBWv4 nmspo4iRIyEKQcc0LQF5nM22p32lwul3bsdjgEnJz9Paq51LcOVrY39P1W2vQdjAMOxocbAY2sCW DVt8PCyKGz2pIZ0VlMs9skiPvBH3sYzQ1YRPSAKAEoAWgBG+6aEBxV+0sNxJF8371sANwMelUtdh lNg6yE79rg8Hb93/AOtR6ILdy1a6pHBJLK3+tJAHycLTsnqB0Om6t9pfy2jRAOMg9aTQGtUiCgDD 11GjvIJh5pRht2o2Mntn2pphr0MS0v7i21G5ht51JjIBLxna+ewPtVJeQ3c6ywZ3iLyS72I5UDG2 pBnPz3xivotqlXlYht4/rVJIWxo6dfW9pFIsjnbuJDY4P0pWAvjU7PAzMoz60uUVywk0bHCuM4zj NKwx/FABQBR1uyGoaZNb8biMqT2NAIx/AlwG097TbsMDEYJ5ptWC503bBpAIFVFwAAo9KErAY2gN Gk1xFDGEiLFlwfem1ZAbVIBaAEoAKAFoAKAEoAKACgAoAKACgAoAKACgAoAKAFoASgAFABQAHgZo Aan3aGA6gAoAKAFoAKACgBKAFoAOlACUALQAUAJQAUAFABQAUAFABQAUAFABQAUAFABQAUAQzMQ6 AAnn8qY0TUhBQAUAFABQAUAFAC0AFACUALQAUAJQAUAFAC0AFABQAlABQAtACe1AC0AFABQAUAFA CUAFABQAtACUALQAUAJQAUAFAC0AFABQBXgGJZMYxmgbJ6BBQAUAFAC0AFABQAUAJQAUARXRxbyE DPynj1oBFbSiSkpMfl/N0/CmwZepALQAUAFACUAFAC0AFABQAlAC0AJ0oAKAFoAKAEoAKAFoAKAC gAoASgAAwAB2oAWgAoAKAEGaAFoAKAEoAKAFoASgAoAWgAoAKACgAoAKACgAoAKACgAoAKACgBKA FNACUALQAUAFACUAFABQAtACUAFAC0AJQAUALQAlAC0AFABQAlAC0AFACUALQAUAJQAUALQAlAC0 AFACUAFAC0AFABQAlAC0AFABQAUAJQAtAB0oAKACgAoASgAoAWgAoASgBaACgBKAFoAKAAUAFABQ AUAFABQAUAAoASgBRQAUAJQAtABQAlAC0AJQAtABQAlAC0AFACUAFABQAUALQAUAJQAUAFACUALQ AUAFABQAUAFABQAUALQAUAFABQAUAFACUALQAUAFABQAUAJQAtABQAUAHSgAoAKACgA6UAJQAtAB QAUAFABQAGgAoAKAEoAKAFFAEckUcq7ZEDD0IpBexkXHh2Bh+4do+c7e1Ne7sPQyrnStXQRov73a CPvDA9/Wm5BZG74ftrm2sQt2f3hOaTYrGlmgBaAEoAKACgDIuIFN25cgnG5AR3HpTKLu+3Nsssir tI7j9KVhXIJNNtLsEyQKp6Y9qLWHewy20ux0594PzdVDH+QoSE3c01dWGVOaBC0AUtYiMli5ThlG aENHKrZhpreQyDy9xfax6MByRVWa0GzZTUY1/wBJTCZO1i55IHt60WvsJswZLmS61CRriIEFv3a5 6DHU0MC1YaRe3KOZTEoI+5np70uZ9gshX0C9YFZ0VwBj5TwfejnHoQrYahCu2QSLgFQ60+cXKSxz X0DpklGbCnrxS50xWZuaBeT3duzzNuw5UcYwBQx2NakI5Ke3TQdekvIiViuz8wJ43f0px3sDZ1UM iyxq6dDSasAy8/49ZeQBtPWhAjD8PTCXUbhhGq/KFHHYVTVhnR1IhKACgAoAKAFoAKAEoAWgAoAS gBaAEoAKACgBaACgAoASgAoAKAGyHahoBCRHKAmhgx9AC0AJQAtAB0oASgBaAEoAKACgAoAKAFoA KAAUAJQAUAFABQAtACUAFABQAUAFABQBBOyrJGG9eOaBonoEFABQAd+tABQAUAFAC0AFABQAlAC0 AFACUAFABQAUAFAC0AFACUAFABQAtABQAlABQAUALQAlAC0AFACUAFAB3xQAUAFABQAUAFAFe3x5 0mARzzQNligQUAFABQAUALQAlABQAUALQBFcnbBI2CcDOKECGWpypOMZ7UDZPQIWgBKACgAoAKAF oASgBaACgAoASgBaAEoAKACgAoAKAFoASgBaACgAoASgAoAKACgAoAKAFoAKACgBKACgAoAWgAoA SgBaACgAoAKACgAoAKACgANACUALQAdKACgANACUALQAlAC0AJQAtACUALQAUAFABQAUAFABQAlA C0AJQAUAFABQAtABQAUAFACUAFAC0AFACUAFAC0AFABQAlAC0AFABQAUAFABQAUAFACUALQAUAFA BQAUAFACUAL0oASgAoAWgAoAKACgAoAKACgAoASgBaACgAoASgAoAKAFoAKAEoAWgAoAKACgAoAK ACgBKACgBaAEoAWgAFACUAFABQAUAFABQAUAFABQAtABQAUAFABQAGgBKAFoAKAEoAKACgBelABQ AUAFABQAUAJQAUAFAC0AFABQAUAJQAUALQAfSgBKAFoASgBaAGyOkSM8jBUUZJPagClHrGnyEeXd Iapwa3E3Yuo6uMowI9qmwxaACgBaACgAoASgDJ1WXyJ0yCS/3fb1pjHrf2lxbPGkybtvR+KfLYNw 0qRtqhmDDoCO9DAn1C1E8ZbYHZQcCpQJlPR7gRgQMFUjjGeapoLGzUiEIBBBGQe1AHJ69aPaRSlC iqWBUlcnH92mnoP0MBLqedRFbRPJ8/yttJqm0kFm9TSTRrqC7BmclQpLDHWp57dAt2NO0u1s5yyA ZZOQzY5q7XA37e6inHyMCRwcetRYViekBFLbxygblXIORxQFxYYUgUhBjJyaQElMCjrNguoWTwkf Nj5T0IpDRg6LqbaZKbPUZHVRhIiw4P8A9etH72yE1Yt+ItetYrWS3gfzJ2GNq9aFG2rEtXoO8Kab LaWiTXJJldc/N1Ge1S5XHaxv0gFoAKAEoAKACgAoAWgBKACgBaAEoAKACgAoAWgBKAFNABQAlABQ A2T7hzQgQkPCAUMGPoAKACgBaACgAoAKACgBKAFoAKAEoAKADpQAtACUAFABQAUAFABQAUAFABQA UAFAEM6qZEyvIPBx0oGiegQUAJQAUAFAC0AFABQAUAFABQAUAJQAtACUAFAC0AFABQAUAJQAUAFA C0AJQAUAFAC0AJQAUAFAC0AJQAUAFABQAUAFABQAUAVbcobu4CsdwxuHpxTewy1SEFABQApoASgA oAKACgAoAKAIrsK1tIHbaCOvpQgQlqCEBJ5wM0DZPQISgBaAEoAWgBOlABQAtABQAlABQAtACUAF ABQAUALQAUAFABQAUAJQAUAKaADpQAlAC0AFABQAlAC0AJQAUAFAC0AFABQAlAC0AFABQAUAFABQ AUAJnnFAC0AFABQAlAC0AFABQAUAFABQAUAFABQAUAFABQAUAFAAaACgAoAKACgAoABQAUAFABQA lAC0AFABQAlAC0AFACUALQAUAFACUAFAC0AFACUAFABQAvagBKACgAoAKAFoAKAEoAUUAFABQAUA FACUALQAUAFABQAUAFABQAlACmgBKACgAoAWgBKACgAoAKACgBRQAlABQAtABQAUAJQAtACUALQA UAFADaAFoAKACgAoAKACgAoAKACgBaACgAoAKACgAoAKACgAoAKACgBKAFoAKACgAoAOlACUAFAB QAtABQAUAFABQAUAFABQAUAJQAUALQBx+vPLf6r9hJxBvVWHPcc57EValaOgramv/wAI1p/kpGqM oUdQetRqupVyl/pOkTCMhpEySH/vD0P0qk77hbsdBbTLPEHU8GpYmTUAFABQAlAAcHg0AQXdutzF sYlfcdqAMP8Asb7JM0ryNKp/v9BTTY7FSzvzDK0MHzkMSGPRT6GrVnqxJHVxyLLGGVgcjtWYbHPJ KWurjykVZEbAyvPuc1Q76nQwndEpznI6+tSIfQBFcW0NwAJ4w4HTNFgTHRQxQriKNUHoBikFyvqF r9oQMrFXUEZ9QaYGE8ccJIkXzFC4Vyudx9aY15E7RhXklhklDKBvGeD6UJuwb7Fn+0Z1PyhSgABJ Bwp9DRoJqxoxXUTgAsFbGcZpBYnFABQAUAVNQ0y01GLy7uEOOo9RSC5WsPD+mWMhkhtwXzkM53Ef TNK3UdzVqhCUALQAUAJQAUAHPagBaAEoAKACgAoAKACgAoAKAFoAKACgAoASgAoAbIMrihAJD9zF DGx9AgoAKACgAoAWgBKAFoASgAoAKACgAoAWgBKAFoASgAoAKACgAoAKACgAoAKACgCvPIqTRISA XPGT1pjRYpCCgAoAKACgAoAKAFoAKACgBKAFoAKAEoAKACgAoAKACgAoAWgAoASgBaAEoAWgBKAF oAKACgBKACgAoAKACgBaAEoAKACgAoArWvMkh3hzuxwOlBTLNBIUALQAUAFACUALQAlABQAUAV9Q /wCPOQYzx0oQ0OtMeSuARx360AyagQtABQAlAC0AJQAtACUAFABQAUAFAC0AFABQAlAC0AFABQAU AJQAUALQAUAJQAtABQAUAFACUAFABQAtABQACgBKAFoAKAE6UAFAC0AFACUAFAC0AFACUALQAUAJ QAUAFAC0AFABQAlAC0AJQAtACUALQAUAFACUALQAUAFACUAFABQAUALQAUAJQAUALQAUAJQAtACU ALQAlABQAtABQAlAC0AJQAUALQAUAJQAUAFAC0AJQAtACUAFABQAtABQAUAJQAtABQAGgAoAKACg AoASgAoAWgAoASgBaAEoAWgAoAKAEoAWgAoAKACgAoAKACgAoASgBaACgBKACgAoASgBaACgAoAK ACgAoAKACgBaACgAoAKACgAoAKAEoAWgAoAKACgAoAKACgANABQAUAFABQAlAC0AFACUALQAUAFA BQAUAJQAtABQAlAHL+ItHvLrUEntAdvB+9gAimpWGktxbTXLwTtbSpDvT5Tzwre5qnZ7E+ppasiX ektIXAdF3goc5x2FTsNWKnhu7kkmeIriPbuBB6H0psdtDoTUiEoAWgBKACgAJwMntQAnDD1oAybz S28xpLTADfeTpTTsO5SVr20ZwoI2DkKuFNPmTE0zPg+1vd7PLefzWLMVf5cdqHKwctzsYUEcSoBj AqQH0AFABQAEhRk4FAFVLS0+0M6Kok6kA0ajJpIIpAQyCgLlWWx3RGLgxn8DTuFyC5hj3bZISdo4 cDGPxpDHNLLGdkTK4K8BiQSfrTuDHpdTpGjTqEbHzKOefY96BWJBesufNiPtt5oCxYjnR+mQfSlY LEgYHoaBC0AFABQAUAJQAUALQAlABQAUAFABQAUAFABQAUALQAlAC0AJQAtACUAQ3Ugij3H6UIEN sHV7ZDGcr60MDI8QX8qq9pDHJlwMOOnvVKy1CzM2yurm3RoriSTygMEclvqDTclcfL2JZPtBWbMj lFx5ZDHPPQU1LsChcltZ7kSQxGdndQWfL4x/jSbDlROXuRGxF3IXQ8gDr70rglYiXULn7iyyDGMk rz+FF0DViZ7u9EgIn2xqSPnABP1o0FYhOrXKYLyZbOMLTsFtCVdUufM++SrdPlA2+1LQdhZNRuSr RCURyEkbiAdtFkDXYZ/adwCsZuF3AdQB85p2S1El0EGsXRKYQDAIbnqfpQkmMmfVpY2BOHj2DG3G c96WgAurtJHG67gcHeuPypaAA1ggxLk5xhxjv2p6CGf2pcoGEjfPuwAoHShWCzRLNrEscgQBePvZ HIoSuMR9acFGCrsIO72P1quWwgXV5W5LxohP3tpOKmwFpL2Ulm3R+XnCkdaQ0MfVMSBEwc9KdgAa qDMY9yAjqp60WAk/tJPmO7bjsRSsA5dRTBDMN3UD+8PaiwaDTqic7cEL944osAp1KMxhkdR3+YYo sBVvZhcXdltQ8OGz/hT2BG1UiFNABQAlABQAtACUAFAC0AJQAUAFAC0AFACUAFAC0AFACUAFABQA UALQAlABQAUAFABQAUAFABQAUAFABQAtAB2oASgAoAKACgCtbL+/lYNjnG3GKY2WaQgoAKACgAoA WgBKACgBaAEoAraiWWzkMeN2OM0AhumtI0Xz8e1AFygAoASgAoAWgBKAFoAKAEoAWgBKACgAoAWg BKACgAoAWgBKACgAoAWgA6UAFACUAFAC0AAoASgAoAKAFoAKACgAoAKAEFAC0AFACUALQAUAJQAt ABQAdqACgBKACgBaACgAoAKACgAoAKACgBKAFoAKACgBKAFoAKACgAoAKACgBKAFoASgAoAKAFoA PpQAlAC0AJQAtABQAUAJQAUAAAGcDrQAtACUALQAUAFACUAFAC0AFABQAlAC0AFACUAHtQAUALQA UAFACUAKaAEoAKACgAoAKAFoAKACgAoASgAoAKAFoAKACgAoASgAoAKACgBTQAUAFABQAUAFACUA LQAUAFABQA2gBaACgAoAKACgAoAKAA0ALQAUAFABQAUAJQAUAFAC0AFABQAlAC0AFABQAUAFABQA lAC0ABoAKACgBKAFoAKACgAoAKACgAoASgDn2l1OK8l/erMoblFGMDt+lU2uw7GnbajFK2xvkbpg 96VhDr3T4LyF0dQpfqwHNJaDuYy+GNi7TfOxxwT2+gouw0NfTdNh0+PEZLMRyx70XAvUCEoAKACg AoAztZ1BbSLYGCuwzk9hTSAy7PWWgG24JeRucMQOPaqsmOzNQavAuxZAVduq+lJRvqhPQsx3lvLk CRcgZIPGKXKwJo/Lx+7249qVrAOoAO9AC0AJQBm60rsibSVRclyOuPpTQWOeVLm0dprWVyXXJ3L9 0D2p31C2p0Ojamt/ESvO04J9/Sk1YdnuaVIQfWgBjxRuMMoxQFxv2dOOBx09qB3ImtDkmN8Z9eaA uVWSeJmMkihF5DAYNMY6RXjzJGzZ75FAWJvOkVx8y7T09TQKxL9p2nDrj0wc5osFga8t0kEbyBGP QNxmjlYicEEZBpAFABQAUAFABQAHjmgAoAKACgAoAKACgAoAXtQAlABQAtACUAVNTA+yMSDx6U0N EGgBv7PUufmJJPpQ9wNEojfeUH8KQrjHghcfPGp+ooHceFUdABQIaYYyclFz0zigd2L5aDoo/KgV wMUZ6ovHtQFxGijYbWRSPQigLh5MY6RqPwoC4htoSmwxJt9MUDuxPs0G3b5SY9MUBcjGn2aspFtH lPunb0pBdj3tIH6xL+VFguyNtPtWUKYlwOmB0phcG062KhfL4AwMUBciOj2ZBwhUnGWB5OKAuD6R aP8AwsDnPDUahcj/ALEt9pTe+wnJGefzod2F0SLpNqEKsGZT2JpBcRdHtVXZ85XPTcead2F0WEsY I23KmDjA9qAuMfTbZ23FTn2OKAuRPpFu8gc7we/PX60XYXF/smDbgs55yOelAXJmsYWyWBzjGaAu O+yxgADGAMAYoC5VuNNlmAQXRSPPICDJH1oC426KwXdtEu1VJAC4poLmnSELQAUAJQAUALQAUAJQ AtACUAFAC0AJQAtAAKACgAoAKAEoAKACgAoAWgAoAKAEoAKACgBaACgBO9ABQAUAFABQAUAFABQA UAFAFKwdmkmWTIlViG9MdsfhTY2XaQgoAPpQAUAFABQAUAFAC0AJQBV1MBrN1LBc4GT2poEPslEc CqG3Y70mNk9AgoAKAF7UAJQAUALQAlABQAtABQAUAFACUAFABQAtACUALQAlAC0AFACUAKKACgAo AKAEoAKAFFABQAUAFABQAlABQAtACUALQAlABQAtABQAUAJQAtACUALQAlABQAtABQAUAFACUAFA C0AJQAtABQAUAFABQAlAC0AJQAtABQAUAFACUAFABQAtABQAUAFACUALQAUAFABQAlABQAUALQAU AFABQAlAC0AFABQAlABQAUALQAlAC0AJQAUALQAUAAoASgBaAEoAKACgAoAKAFoAKAEoAKAFoASg BaAEoAKAFoASgAoAWgBKACgBaAEoAKACgAoAKACgBaAEoADxQAlAC0AFABQAUAFABQAUAHagAoAW gAoASgBaACgBKAFoAKACgAoAKACgBKAFoAKACgAoAKACgAoAKACgBKAFoAKACgAoAKACgAoASgDM 1ZjbyRXCx7v4WxTVhoRohJEJ7cKCOSnvRYdzIudW1GUvFBFsbICEHAJPbNXogsaL2mqSQK5eNZsc pnv9ahMNCDSNSninFpdqS27BJOSp9Kbs9RHRVIhKACgBaACgCOWGKUYljVx7jNKw07EE+n2k6bZI EOBgHHI+lFguzMvLeyiilxcMGTAz1wewq7NhcymhkUyP5+4Fd+CcDcKd5Ca0HS3dzb+SxYlmP7xV bk/QUXQI6TT52ljG7OMcE96gC7QAlABQBm60Y1h3TLmIDJ5xTQ07FGFBJC4hj3NsznHJPsfagaK9 yjQTROjIJI8bgmcfjTvZWQjfsbyK6j/dyI7AfNtNJqwizSAKACgAoAKAEKKw5ANAXI2t4mPK0DuM NpGFwq+4BNAXIZYw3zOhyinHGcUDIwsoCFJQq9ScUwJ455EiDSlRQKxJ9qUMF2nJ545oCw8XEXB3 gZ45pWESUAFABQAUAFABQAUAFABQAUALQAlABQAUAFAFPVhmybgEgg4NCATRgRp8ecZOTwfenLcC 7SAKACgAoAKAFoAKAEoAKAFoAKAEoAWgAoASgAoAKQBTAKAFoASgAoAKACgAoAKAMy4b/ibxKY1K 7clu4oGjToEFABQAUAFABQAUAGRnFAC0AFABQAUAFACUALQAlAC0AFABQAlABQAtABQAUAJQAUAF ABQAUAFABQAUAFABQAUALQAlABQAUAFAFLTwyy3IYf8ALQkH2psbLtIQtACUAFAC0AFACUAFABQA tAFXUghspRI+xSOtNX6AhmmSb4MHaGXjikxsuUCCgAoAKAFoAKAEoAWgAoAKAEoAKACgAoAKAAcU ALQAUAFACUAFABQAUALQAUAFABQAUAFABQAUAJQAUALQAUAJQAtACUAFABQAtABQAlAC0AFABQAU AJQAtACUALQAlABQAooAKACgBKACgBaAEoAWgAoASgBaACgAoAKACgBKAFoAKACgAoAKAEoAKACg BaACgANADJHEaF24AoBITzU3BCwDHoM80BYkoAKAA0AFABQAlAC0AFAB0oAKAEoAXtQAlABQAUAF ABQAUALQAlABQAUAFABQAUALQAUAFABQAUAFABQAUAFABQAUAFACUAFABQAUAFAC0AHagA7UAFAB QAUAFACUAFABQAUALQAlABQAUAFABQAUAFABQAdqACgAoAWgAoAKACgAoAKACgAoAKACgAFABQAl AC0AFABQAGgAoAKACgAoAKACgBAQelAC0AFACUALQAlAC0AVNSMK2b/aGKxnjI65oV+gIo6RfW7E RCVWZxnG3HSqaC9zM8QRNZX63C7dj44Jxg0K70Qabs6Wzm8+2STjJHODkZqWDMfxBaKjC6jyGfhg vc9jTiD1L2jXX2iBo+phwhbP3uOtDS6AaFIBaACgAoAKAM7VriSNUjiHLnn6UxpGNHYvcyiSdTDC fTk7qbbBKzNaPR4lkSQzSNtXaAcY/Kk2w0H/ANj2jMWYMzepPf1pXYXsXIYI4M+UuM9aBEtACUAF AGPrsrK0YTbx1BGc5ql2GkM0N1gVkeXK4yC3bPWhi2LNzFAxllhZSSP3gz7cHFLUGZMMM0VwlzAq gIu1tny7h7iqb0GldHQ2dytzECPvDqPSosJk9ABQAUAFABQAUAFAC0AMaJTnjBPcUBcqCzdZd/m7 lH8JGKB3I3t2iOVB44AXo3+FA7jxmSMhh5fGcHtTAhimudu+LDgHBA6Y9qPULFh77y13PE45wR6D 1oshWJUu4XkMavyBmiwiZSCODSAWgAoAKACgAoAWgAoASgBaAEoAKAKWrLm1Py5xyfpTQBoqbNPi APBGR7UgJ7W5iu4BNbtujJIzjHIOD+ooasBNSAWmAlABQAUAFABQAUAFAC0AFACUAFAC0AJQAUAL QAgoAWgBKAFoASgAoAKACgDIuj/xOoVDDO3O2q6DRr1IgoAKAFoASgAoADQA0oDIrY5A60rajHUx BQAtABQAdqADtQAUAFACUAFABQAUALQAlABQAUALQAUAJQAUAFABQAUAFAC0AJQAUAFABQAUAFAB QBXtCS82U2Ycj6+9A2WaBCUAKaACgAoAKAEoAKACgAoAo61t/s6UMAQcfzpoCTTYzHBhuW7mkxst UCCgAoAKAFoAKACgBKACgAoAWgBKAFoAKAEoAU0AJQAUAFAC0AFACUAFABQAtACUAFABQAtABQAU AJQAUAFABQAtABQAUAFACUAFAC0AJQAtABQAUAJQAtABQAUAFABQAUAJQAUALQAUAJQAtABQAUAJ QAtABQAUAFAAKACgAoAKACgANABQAUAFABQAUABoAOlABQA1lV1KsAQeCDSauCdhkVvDCcxRqpxj PtSUUthuTe5LVCG5O/G04x1oAWgAoAWgAoAKAEoAWgAoASgAoAKACgBaACgBKACgAoAWgAoASgBa ACgAoASgBaAEoAKACgBaACgAoASgBaACgBKAFoASgBaAEoAKACgBaAEoAKAFoAKAEoAKACgBaACg A6UANoAWgAoAKACgAoAKACgAoAWgBKAFoAKACgBKACgBTQAlAC0AFABQAUAFABQAUAFACUALQBTu ruWG4jhis5pt/wB51KhUHvk0rxvZspRui3TJFoAKACgBKAIbe1gtd32eJI95y20YyaBuTe5PQISg AoAWgBKACgBksSTRmORQynqDQBx2uafc6VdPdWhZ4ZMBQeSrZ6D2ppjauW1uTcxG11OE7Rj5DnIP sTQ7MNVubmmy2whEVvH5KqMhCMcUMTK3iCUmwZVU53DacZoQ9ir4St5okuZZYwqysCDtwW9zTlJP YNToKkQAgjIoAKACgBaAMTXJYobmF5hyASvOM1UU3sO9iOOXCrLMHBVvlHpmktdgWpqxhprYqX2s RnI5xSAqQymG9MJIQKvf+KmBpowdQw6UhC0AFAC0ARSwRyj51BPr6UDTsYEulyWYkaGQtvzlQ3X3 qrvqFiusrtHKYyGUY80Ox3HHanqKxELjbIj226PcCMsMgfWlqOzua2jNaqFmLBZnG0jdnOO+KGmB rRzxSAFJFIPTmpaEP3L2YfnQABlPAYfnQAblzjcKAFoAKAFoASgApALTAKAGlQeoFADGhUqAvy46 YoHcjktwxUlQ+B3phcg8tSrZEkO1t3PQ0hsDORjyGUs2eSeM/SmBMlyBGhlIyepHSkKxMkscn3GB oEPoAKACgBaAEoAWgBKACgAoAz9Zl8uBV5G7jI/lQhrQm0xla1DJnbnv1oYMtAAdOKSVhBTAWgBK AFoAKACgAoASgBaACgBKAFoAKAEoAWgBKACgAB5NABQAUAFABQAUAFABQBkXJjGtREnD4xz0/wD1 01sUjYpEiHpxQAUALQAUAFACUALQAlAC0AFACUAFAC0AJQAUAFABQAUALQAUAJQAUALQAh6cUAFA BQAUAFABQAUAFAC0AJQAUAFABQAUAFABQBStpwb2SNiwfnapHYHrTGy7SEFAC0AJQAUAKKAEoAKA FoASgCjrRQWJ8w4BZe2e9NbgieydZLdWU8dKTGyxQIO1ABQAUAFABQAlABQAUALQAUAJQAtACUAF ABQAtACUAFAAxwpIBOOwoAByAelABQAUAFAC0AFABQAUAFABQAUAFACUALQAUAFACUAFAC9qACgB KACgBaAEoAKAFoAKAEoAKACgBaACgAoASgAoAWgBKACgAoAWgBKACgBaACgA7UAJQAtABQAUAJQA tABQAlAC0AFABQAUAFABQAUAFACUALQAUAJQAtABQAlABQAUALQAlABQAUAFABQAUAFABQAUALQA UAJQAtACUALQAUAFACUALQAUAAoASgBaACgBKAF6UAJQAUALQAnSgBaACgAoAKACgBKACgAoAXtQ AlABQAUALQAUAJQAlAC0AFABQAUAFABQAUAFAC0AFACUALQAdKAEoAWgAoAKAEoAMj8qAF7UAFAB QAUAFABQAdKACgAoAKACgA7UAFACUALQAlAC0AAoASgBaACgAoAQgHqOlAEVxbQ3KbJkDLQF7GZd aFG5zbyGLAwBT5mO5HFBqi3KRNHGbYEc55Wi6D5m4OBikIWgA6UAJQAtACUAVryyiusNJuyowMGg F5mZ5TLEYHMiEgknrjHSmU7ItWBRDwPnxyfUetAbhq8aqEnwmVPfqfYUIRNZTGT+EhSOPTPehgy5 SEFABQAHocUAcwfPeYC4G5wdyYb7oqgW5oiOK4LJJExyfmOMUiipJaxyylEDw4JVuM5o1QCW2nzi Y7j8iD5NowRmi4rdSvJp150SMnbJn5l6j65p3sgcUPisL+IlSv3s8jOPxo5g5EV7eDWIH+fBkH8W MjmjnXVByFgW1+4dSCHccdePxpJhyo37CKSK2UTH96QN2DkZobBlikIWgAoASgBaAEoAKACgAoAC PWgCB7SFtxCBWbqw60DuRNauD8jKFzyuODTC41InVidpjCDoOjCgYvnyJswoZT1OelILEy3URUMW 2g+tOwmrE4II4pCCgAoAWgAoASgAoAzdbZEhQsu454FNK4D9FUrZDJzkkihu4F+kAUALQAlAC0AF ABQAlABQAUALQAlAC0AJQAtABQAUAFACUAFAC0AFACUALQAlABQBlXEK/wBtwyE/eXGPcUxmtSEJ QAUAFABQAUAFABQAtABQAUAAoASgAoAKAFoAKAEoAWgAoAKAEoAWgAoASgAoAKACgAoAKACgAoAK AFoASgAoAKACgAoAKAKtn5ZllZG3NuIPtTY2WqQgoAKACgAoAKACgAoAKACgCpqkixWbMyhhkDBo Q0PsCDbrjH4UCZYoAKACgAoAKACgBaAEoAKACgBaAEoAWgBKAFoASgAoAWgAoASgBaACgBKACgBa ACgAoASgBaAEoAKAFoAKACgBKACgBaACgA+lABQAlABQAUALQAUAFABQAUAFABQAlAC0AFACUAFA CigAoAKACgBKAFNABQAlABQAUALQAUAFABQAUAFABQAlAC0AJQAUALQAUAFABQAlAC0AFABQAUAJ QAtABQAlAC0AFACUALQAlAC0AFACUALQAUAFACUAFAC0AJQAtACUAFABQAvSgAoATv1oAWgBKAFo AKAEoAWgBKACgBaACgAoASgAoAKACgAoAKAFoASgAoAKAFFACUALQAlACUALQAUAFABQAUAFABQA UALQAlAC0AFABQAUAFABQAUAFABQAUAFABQAlAC0AFABQAlAC0AFAAaACgAoAKACgAoAO1ACUAGB nPegAoAWgBKACgBaAEoAKAFoASgBaAEoAWgAoAKAKeoWgnjOAd3t3oGrbMwyY7O6xAkgdGy25uTn tj0q0u4PyLV/qEctr5OV3sMr3AxS5WAaHuJWViwU5AHbP0pBY3aQgoAWgBKAMW/iKXTgqMSD5Wx+ lFxvYXTZfNh2Eybg2PeqY0SahMkKguGOeMDr+FJIHoWrDZhim7JAJyentQxMt0hBSAKYBQAUALQA UAFABQAlAC0AJQAtABQAUAJQAUAGKAGNChBHTNA7lV7V1UiHGByu7tQO5HvEDhVkIYjuc4PYYpho WILks2yRcEDlu2fSkKxZ4x7UCCgAoAWgBKAM3W5UWFYScNJnAxmmu4yxpi7LRVypx6UmItUAFAC0 AFABQAUAFACUAFAC0AFACUAFAC0AFABQAUAFACUALQAUAJQAtABQAUAJQBjzXCnxBHCAuUTLZ96d tBmxSELQAlABQAUAFABQAvagAoAKAEoAKAFNACUAFABQAUAFABQAtABQAUAJQAUAFABQAUAFABQA UAFABQAUAFABQAUAFABQAUAFAFe2VFd9o5JyTQNlmgQlABQAUALQAlAC0AFACUAFAFfUDttixAIB BOelA0LZMWhBJz70AyegQUALQAlABQAUAFAC0AFABQAlAC96ACgBKAFoAKAEoAKACgBaACgANACU AFAC0AAoAKAEoAWgAoAKACgBKACgBaAEoAWgAoAKACgBKACgAoAWgAoAKACgAoAKACgBKACgBaAA UABoASgBelABQAGgAoAKACgAoASgBaAEoAWgAoAKACgAoAKACgBKACgAoAU0AJQAtABQAUAJQAtA CUALQAGgBKACgAoAWgAoAKACgAoASgAoAWgBKAFoAKACgANABQAUAFABQAUABoAKACgBKAFoAKAC gBKAFoAKACgAoASgAoAWgAoAKACgAoASgBaACgAoASgBaAEoAWgBKACgBKAFoAKACgAoAKACgAoA O3NAC0AJQAvSgAoAKACgAoAKAEoArWENzAjpd3RuWLsyuUCbVJ4XA649aGBaoASgBaAAUAFABQAl ABQAtABQAUAFACUAFAC0AJQAUAFABQAtABQAlAC0AJQAUAFAC0AFACUALQAUAJQAUANlkSJC8jbV HU0AZcmsbt4t1X5RnMjY/SqtYQ21voby4MVxAASg/eY4Pt7UnFIpMtHSbIyK7RZK/dGeBSC5QE8h Z0g+RvMxgr2z/hT2BG4gwgFIQtADGmjViu75gMkDrRYLDlZWGVOaAK19CtxCyZw68qfQ0DRiQu8D MMKDJycHB3CqtbYdyG5uLi4kR9u1kbAz91fc0XsSdHZWyW8fyjluTipGyxQIKACgBaAEoAKACgBa AEoAKAEBB6EHFAri0DCgAxQAUAFABQAUAFABQBDLbQykFlG4HOfegadiCWEhx5mWBPB7CmPQSC42 NsdhnPbsD0oCxepEhQAtACUAY2vlFaJpE3KFOADg5qogW9H3m0DueWPA9B6UmNl6kIKAFoAKAEoA WgAoASgBaACgBKACgBaAEoAKAFoASgAoAKAFoASgAoAKAFoASgBaAMOZBJ4kjwF+RMt6j0p9Bm3S EFABQAUALQAlABQAtACUAFAC0AFACHigBaACgAoASgBaAEoAKAFoASgBaAEoAKACgAoAQkhlG0nP f0oAdQAlABQAUAFABQAUAFABQAUAFAAehoAq2m7zZQXyM8DHSgbLVAgoAKAFoASgAoAUUAJQAtAC UAVtRBNo+FLewoAktgBEAOlA2S0CCgAoAKACgAoAU0AJQAtABQAUAFACUALQAUAFAAKACgBKAFoA KACgBKAFoATvQAtACUAFABQAtABQAUAFACUAFAC0AFABQAUAFABQAUAJQAtABQAUAJQAtABQAlAC 0AFACUALQAUAFABQAxGcu4K4UY2n1oDoPNACUALQAUAJQAUAFABQAtABQAlAC0AFABQAUAAoAKAC gAoASgBaACgAoAKACgAoAKAEoAKAFoAKAEoAKACgAoAKAFoASgAoAKAFoASgAoAKACgBaAEoAWgB KAFoASgBaAEoAKAFoASgAoAKACgBaAEoAWgBKACgAoAWgAoASgAoAKAFoASgBaAEoAO9ABQAtACU AJQAtABQAUAFABQAUAFABQAUALQACgAoAKACgAoAKACgAoASgAoAWgAoAKACgBKAFoATFAC0AFAB QACgBKAFoAKACgBKAFoAKAEOeMUALQAUAFABQAlAC0AJQAUALQBDdSmGBpFGSKEBzg1uSK83Suxj GQ+TgCrsB0VpcLcRK4G0kZxUNWAzdaE28sCBEqYCnoxNNDsM0y1sntyHXc8hz+8HOfb2pt6hsVr2 IW904AMceMfL/F+FNWA1bW882weQ5DoDkMMGk1qJGZp6BpYC53TMeRnlaBpnR1IhKAKt1AGlV8UB ZMpi5mtmaRopDuwCPSqKaFuLuIvKrBh0GOlKwbFbzLe41B7ZmVOjbh39qGuoupp29jbxuXX5iTnk 8flSAt0CCgBaAEoAKACgBaACgBKACgBkzbIyc4xQNGHBfGMSlHwVcsBjd5gNVbUGyddVkEsZkXy0 dM4YYIoS7CLVtqSysUZNrA44bOaHGwWLQnQ8A89MVIWY4SITgMM0BYdQAUAFABQAUAFAAcAc9KAM 27RIZkdcfvHwxPP4Uyrmin3BSJFoAKACgDJ17yyqiXGwKxJPamkNFnSMfY4yowCoIxSYMu0CFoAS gBaAEoAWgA7UAJQAUALQAlABQAtACUALQAlABQAUALQAUAIQMgntQAUAFABQAvagBKAMSSMf8JGr M3BUYGcYOKYG3SAKACgAoAKACgBaACgBKAFoAKACgBKACgAoAWgAoASgAoAWgBKAFoASgAoAU0AJ QAUAFABQAUAFABQAUAFABQAUALQAlAC0AJQBQ00Dzbj5TxIfmNNjZfpCCgAoAKADnPtQAUAFABQA UAFAFTVXKWbEHBJA/WhAS2u3yxsI98etA2TUCFoAKACgAoASgAoAKACgAoAWgBKACgBe1ACUALQA UAFABQAUAJQAtABQAGgBKACgBaAEoAKACgAoAWgAoASgAoAKAFoAKAEoAKACgBaACgBKAFoAKACg BKACgBaAEoAKACgBaACgAoAKACgAoAKAEoAWgBKAFoAKACgBKAFoASgBaAEoAWgBKACgBaACgAoA KACgA6UAHagAoAKACgAoASgAoAWgAoAKAEoAWgAoASgBaACgBKACgAoAKAFoAKACgBKAFoASgBaA CgA6UAFABQAlAC0AFACUAFAC0ANVgw4oAdQAlAC0AFACUALQAUAFACUALQAUAFACUAFABQAtABQA UANoAKAEZ1XG5guemaAsOBoAKACgAoAKADtQAvagBKAFoAKAEoAKAFoAKAEoAKAFoAKACgCu8/lS Krn7xwKY7FikIKACgAoAKAEoAWgAoABQAlAC0AJQAUAL2oAKACgBKACgAoAWgBhkUPszzQA6gAoA KAFoAKAGuoZCpGQaAOc1G3jYPKR5ew4xjlj607Fb6D7OQ27LKYyrFdqjklvemJm06JeW+GXqMjPa p2BaGctt9kkIX5lA3AMTn8Kd2x3G3U0cttuuFw4GQxH3R+FFuwimL4CwMg2TBpMFg2VI7Gn5MSt0 NDRo1ldrggFgfTp9KTVgNekAlACMu5Sp6EY4oAzHtrmKYsnzqFwvPXHTNBSMfUIp7d1nnSTbn7o5 2n696aFbqSRD941xHm3Zl6AZ3H1waOg27IsxTSQQhj984yVHX60dQLkeohFUFjISMkkYxRYRoxuJ I1cdCMikIdQAtACUAFABQAUAFAC0AJigCrJp1q8gkEQRx/EnH8qNegXuQS6WG3lZWLPxlhnA64FO 47lOTT5MhRAVO75XRunuad+w3qPjeSMx7wyqMgkgncaV7bhYRD9mlBllUs5OE6E+mKerAlS4lkCt FjzBlTuOOfp3pPQncRNRuFWMPDIc8FyMD60aFWLC3bJvMhb5BkjHb2p6CsAvyrBGALscjA4A+vrR YNBy3wwNwIz0OMUrBYVbh2zgHjigdhwbeo+bIHf1NFwESF5Hy+VjXjZjqfWgGW6RIUAFAC0AZPiB R5EZ3YO71xmmlcaJtDx/Z8YXGBkdc4pMGX6BC0AJQAUAFACA8kYIx3oAWgBaAEoAKACgBaAEoAWg AoASgBaAEoAWgBKAAgHrQAUAFABn5tuDQAUALQBk7v8AidPkjjCr+VMfQ1aQgoAKACgBaACgBKAF oASgBaAEoAKAFFACUAFAC0AHagBKAFoASgAoAKACgAoAKACgBaAEIyKACgBe1ACUAFABQAUAFABQ AUAFABQAtAFOyiEU04zyzlqBst0CCgAoAKACgAoAKACgAoAKAKeq+ULT99t2bh9760eQ0SWLxyQ7 4cbSe1N6AyxSEFAC0AJQAvSgBKAFoASgBe1ACUAFAC0AFABQAUAJQAtABQAUAJQAtACUAFAC0AFA BQAUAJQAtABQAlABQAUAFAC0AFABQAUAFABQAUAFACUALQAlAC0AFABQAlAC0AJQAtABQAUAFABQ AlACmgAoAKAEoAKAFoAKACgAoAKACgAoASgBaAEoAKACgBaACgBKACgAoAWgBKAFoAKACgAoAKAC gBKACgAoAKACgAoAWgAoASgAoAKAFoASgBaAEoAOlAC9qAEoAWgAoASgBaACgBKAFoAKACgA6UAF ABQAlABQAtABQAUAFABQAUAFABQAlABQAUAFABQAUAFABQAtADaAFoAjmginULMgYA5GexoGpOOx J0oEFABQAUAFAB2oAKACgAoAWgAoAKACgAoAKACgAoAKACgCjfym3IfaxGR0GaaKRNZzGVCG4dTg ikSyxQAUAHegAoAKAEoAKAFoABQAlABQAUALQAUAJQAtACUALQAlAFDUJBA8blflJ5amh3L6ngUh C0AJQAUALQAlAGPrUHzxyHhCcdO5ppjQWdnLLZKtzJmdAQhHGB2NA9h0bvaS5csE2n5ccsaNBWLM E0ep2rgxyxEHayuuCppX7C1Rkarpt8qN9nAmRj0U7SKfNYdkcza6bMlw0COI0Vx8vPy+tVzuw7HY abeRW9x9jAOzkgkf1pWuQbAlQ4ww5qbDHUAQXtz9kt2m8tn2kZVevWgDDjvJY9dM/wBoke3nG3bs +RQBwQexz1q32Dle5o65G01kNhOFcMcelQhobZutyitJCrgnbnGCv1p2GW2s49u2P5BjH4UhXIrf TY4JmcHIbsR0oC5eACgAdBQIWgAoASgABGSMjI7UAFACc7u2MUgFpgLQAlABQAY5zQAUABAPWgCG W1hkILoCR0JoHdjZrOKVSCgznINAXIpbVgu2JT9WbgfhQO40wCOXz2bJ24Yt0ApgPSFJAjblaM8j 0NAXHG23OreYdo7YoC5KIVXPzNyfXpSFceI0HRRQK46gAoAKACgAoAztZOEi+QNyetAE+mIUtFVg B9KGNlqgQUAFAC0AJQAUAFABQAjKGGD0pWAWmAUAFABQAtABQAlABQAUALQAlABQAUAFABQAUAFA GNHvbxDPlVMShcHuDimM2aQhaAEoAKACgAoAKAFoAKAEoAKAFoASgAoAKAFoAKAEoAKAFoAKACgB KACgAoAWgBKACgAoAWgAoASgAoAKACgAoAKACgAoAKAILbGW+YMcnn09qBsnoEFABQAUAFABQAUA FABQAUAVNTdI7RpJF3KpBxjNCV9BoNMGLbhQqkkge1AMt0CCgBaAEoAWgBKACgBaACgBKAFoASgA oAKACgBaACgBKACgAoAWgBKACgBaACgAoAKAEoAKACgAoAWgANACUAFABQAUALQAlABQAtACUALQ AUAFACUAFABQAtABQAUAFABQAUAFABQAUAJQAUALQAUAFACUAFAC0AJQAtACUALQAUAFABQAlAC0 AFABQAUAFABQAUAFABQAUAFABQAUAFABQAlABQAUAQX9u9zaSQRytCzjG9eoo22An6DFAC0AFABQ AlAC0AFABQAUAJQAUAFAC0AFABQAlABQAtACUALQAUAJQAUALQAUAJQAtAAaACgAoASgAoAWgBKA FoADQAlAC0AJQAUALQAUAFABQA2gAoAWgAoAKACgAoAKACgAoAKAFoASgBaACgAoAKAEoAWgBKAF oASgCC7HyBgTwce1A0ZlnMLa8YP/AMtG2MR/e7UwbNqkIWgBKACgAoAKAFoASgAoAKACgAoAKACg ApAFMCC6vba0Um4mVMDPJppMWwy31G1uAhilU7ug70+VoZaqQM/VvKKIs4OwEHr3ppDRejIaNWHQ jNIQ+gBKAMm+8QWVnN5JLySBtrBFztPvVcvcLFu01CG6bajDd1pONgLE80dvH5kzbUBAz9TikCVy vqkH2izePBJ6jHWhaDRkWN3t1OMn7si7Cc9MdvzqraC0Nm9thcQso4Y96laDTM+G4eG4VZJJAF4O /p9c1W+wbbmvG6yIHXoelSIgubGC4OWXDYxuHWgDHvdBnJjNtMSQedx7dqd+g9CbTdJnjuI57lhu TPQ9abkw2NupENljWVCjjIPagNjJe0uUO0yJlmPO3jH0pplBHcTeW9vKjOwQlnGFC0aE69RAqwDz Yf8AVfLnYec5oKRsAjGc8UiQ3L/eFAC0ALQAlABQAYoAWgAoASgA+lABQAtAB0oASgAoAKAEJAIB zycdKAFoAQqCCCOD1FAEMlsrRmMEohGPlOMfSjYdyK1tTaoU82aVR0MjZIp3fUNFsPjlJUsN2ASM EUAO887o/l4egB3nxA7S3IpBYkBFAhaACgAoAz9bUPaBSOrDHNNASaQ26xjO3aOcUMbLlIQUAFAB QAUAFABQAUAFAC0AZ2q6gLOEFSu4nbgtg5ppAUI3upWeVt4Vx64H4U2x2Ej1AxREedtcZL9TtoCx ctdUDcOd2ON4HFKwGhFNHKMr29aQiSgBaACgBKAFoASgAoAKACgAoAKAMcJjXSwY4PJB9cdqd9Bm xSELQAlABQAtABQAlABQAtABQAlABQAUAFABQAdKACgAoAKAGyllQlF3N2FA1vqOoEFABQAtABQA lABQAUAFAC0AFACUAHOT6dqACgAoAKAFoASgBTQAUAVLVNk8/B5bNA2WqBBQAUAFABQAtABQAlAB QAUAVNVGbGQZIzjGPrTW40PsQFtlUEnHXNJgyxQIKACgBaACgBKAFoABQAlACmgAoASgAoAKAFoA SgAoAWgAoASgAoAKACgAoAWgBKAFoAKACgBKAFoAKAEoAKAFoASgAoAWgBKACgBaAEoAKACgAoAK ACgBaACgBKAFoASgBaAEoAWgBKACgAoAWgAoASgBaAEoAXpQAUAICD07UAFAC0AJQAtABQAUAJQA UAFAC0AJQAtABQACgAoAKACgAoAKACgAoAKAEoAKAFoASgBaACgAoASgAoAXtQAUAFACUAFABQAU AFABQAtABQAlAC0AFABQAlABQAUALQAlAC0AJ0oAKAFoASgBfpQAUAFABQAUAJQAtACUALQAlAC0 AJQAUALQA2gBaACgAoAKACgAoAKACgAoAWgA6UAJQAUAFAC0AJQAtACUAFABQAtADJE3oVPegDm9 TjI3cAyk8EfKcjvVFG7ptyLmzjcMC20BsetJklnpSAa0iL951H40WAoXWtWlvGHLg5z7VSiwY7Sb /wDtCIyrgxk/KRSegGhSASgAoAWgAoAKAEoAKAFoAZLIsUbSSHaijJPoKAM1dctWfC5xjgnufar5 BXMnUmgvr9lkACbQwYnqMf0pLawJlHVdFu9Lsnu9OvHZDjcRyQvr7ikpNPUfKrWRoeHPEkd5J5Fx I3mnhcrgH3FU12Fcv6zcEXUKLsIU7sEUkhmvF/q1+lSBg+Iru/sZUkt2bym64XOPWqi11C2hr6fe JdwK68Ejp/Wk0JGXrmmJue+hiVpMfMMfrSuUihZ3RjMVwFCIeDGnUH1+lVp0D1OqwsseHAZWHQ1L DYdQI5fWbdbbUI1VNsMh3cDAXHX6VSGaukais8PlytiRB1JHzD1pO3QVmVdSlgCSfZ5o3kLZA3g7 T9KpJ7sL9jR0+beg+7gjjH61A+hcoELQAlABQAUARXMImiZM4OOG9DQBlbXdDFK8bP8AcPBBOOtN lIhkKWjeTGpaMLh17U0mBc3zfZljk5ycfL2WkJIpxfvZA4ZQkZyig43Y759aLhZbm1bTCVMgk47k YzQInpAFACUAFAC0AJQAUAFABQAUAKKAEoAKAFoASgAoAKACgAoARkVhyKAuRG3XcGH3h0z2oHcG jkP93rnigLjXDgEYz7mmMC8oXhOMZ60gsMjvPlQumN3v0pisTfaYS5TzBuAyRRYLGfrjKVSPCkkE jJpq4ixo8bR2EYcgnrx2qWN7l2gQvSgBKAF6UAJkdqACgAoAKACgDO1W+a2i2wj943Q+lUkBBZ6a 07pc34DMOVQ84PrUjNcqCMEDFAiKS0t5AweJCG68daAuUZ9NMSH7KSBnO0U7lXuUDP5VxJE4chR6 Yx/9enuKxp6ZO+TBM2/HKtnOfakKxoUgCgAoAKACgAoAKAD8KAFoASgDHjvVfWngjHKnDYHtTtZD NikIKACgA9qAAUALQA0nbQA6gAoAKAEoAKAFoAKAEoAWgBKACgBaACgAoASgBaAEoAWgBKAFoAKA EoAWgAoASgAoAKACgBaAEoAKACgAoAq2zZupgDwDzn1oGW6BCUAFABQAtACUAFABQAUALQBV1B0j ti8jYUEfj7U0NCadKJbfcFCckbQc4oYMt0hCUALQAlABQAUALQAUAFABQAlABQAUALQAUAFACUAF AC0AJQAUAFABQAUAFAC0AFABQAUAJQAtACUAFAC9qAEoAKAFoAKAEoAKACgAoAKACgAoAKACgBaA EoAKAFoAKACgAoASgBaAEoAWgAoAKAEoAKAFoAKACgBKACgBaACgBKAFoASgAoAKACgAoAWgAoAK ACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoASgBaACgBKAFoAKACgAoAKADtQAUAFACUAL2 oASgAPTpQAUAGaAFoASgAoAWgAoABQAUAFACUAFAC0AJQAUAFAC0AFABQAlABQAtABQAUANoAKAC gBaACgAoAKACgAoAKAFoASgAoAWgAoASgAoAWgBKAI7i4itY/MncIg7mhJvYCi+uWOzdHJ5nsKv2 bAhXXUdh5cY2k9S1HJYCnca3ctcFIAoUAnpnNFkgasZ95cnzPOeQxOehAzuPpR0sNJEdhqc0XEbu WlGAGTHNMVrFhjrF2qiGCdC3LOWwPyNS5JD5WW7fQ712DXMqrkDhTnFLnYWRYh8PRpOJZ5PNCnO3 bSb01DQ24okhQJEoVR2AxQIfQAlAC0ABoASgBTQAlABQAUAUNcEn9lzeT94YPTOeaFoBz9tpser2 hyxjlbPlyKOV96b8hrzMTVrLV9Ekjlu1juLdckzIuAB6EdvrVKo3olYFHrc7Dwxetfaeu5MxEfIx GMiplYXmjmvENlHZatEYAIWQ7lcjgA9h+NC0WgS1NnUHkuIbaVl+ZVAGDyW96aHY6CzJNrFu4O0Z 5qRDriCO4haKZQyN1BoA5p7S70Sdnt3DwynAB6JjpTT6D0Nmw1SK7VVbCsVz14NNxsIxdQSGHVJf KPDKF8tRge9CHc6e3XbBGuMYUcVLEPoAiuLeK4TZMgZaARRm01IYAtlEq7ecY6n3p3GcNc6XdD55 v9FuXk3FxwoX6HvTU+qFy2Wpq2t7cWLDEyysi7SVORkngmne+4rM6CHWlaNCUXd/EN2PqaXKM0Le 7hnOI3BOM9aTTQFikAlABQAtAGfeWwWVpo96s/DFTRcaMmdoIGDSLJljsBc9R601p1B6LY0tPBlw 3mMe3PGAKAQ3UYPJkRgE+zscSAjp7j0oQIfZoIv9W7ODz8x5ouUaQPFIgKACgBaAEoAWgAoASgBa AEoAWgAoASgAyKACgAoAKACgBaAEoAKACgAoAQqDQBXuLKKcjeM7eV9j60XHcXyCOW5OMHjrQO5g 600kbIgUoI1OH789KoXkXtLuPItY47glGAxj1NDDQv294ku7BBw2OD+tKwWJRPEePMXPTrSsLYeG UjIIxQBDezCCAyNnaOuO1NDRRsrpGQSJJuVujbs0NdGM0YZRIgPQkUmSSUAFAEd1IIbeSRgSFGeK ECMTRiLl4TJAY1UMY1fkjmmx9DfpCCgAoAKAK19bLPCwztPqKARjecbSUSscLG2ANvUetPoVudCr BlDDoRmkSLQAUAFABQAtACUAFABQAUAY9uf+JzOBsznnA5HFPoM2KQgoAWgBKACgAoAKAAUALQAU AFACUAFAC0AJQAUAFABQAUAFAC9KAEoAKACgBaAEoAKAFoAKACgAoASgAoAKACgAoAWgBKACgAoA z9OObq8GRgS46e1NjZoUhC0AJQAUAFACmgBKACgAoAKAKWsY+wSbj6dvenHcaF0kEWSZAH0oYMu0 hCUAFABQAtACUALQAlAC0AHagBKACgBaACgAoABQAGgBKACgAoAWgBKACgAoAKACgBaAEoAKAFoA O1AB0oASgBaAEoAWgBKACgAoAKACgAFABQAUAFAC0AHSgAoAKAAUAFABQAUAJQAtABQAUAFABQAl AC0AJQAtACUAFABQAtACUAFABQAtABQAlABQAUAFABQAUAFAC0AFABQAUAFACUAFACigBKAFoAKA A0AJQAUAFABQAtABQAlABQAUALQAUAFABQAUAJQAUALQAUAFABQAlABQAtABQAlABQAtABQAUAFA CUAFABjigAoAKAFoASgBaACgAoAKAEoAWgAoAKAG0AFAC0AFABQAUAFABQAUAFABQAUALQAnSgBa ACgAFABQAUAY+s6KdUkRjdyxIo+6vSndrYehFZeGLS23F5ZpWfGdzcUtR3Reh0exhBCQjnnk5oDm ZajgiiULHGqqOwFKwm2R3NlBcQmNo1HcHH3T60WC5yt1bfZ5pYXkOF4QdzmtNw0N7w/dtNZrFMcz RDDH1qWI1KQBQAtABQAUAFABQAUAJQAtACUAFADZkEkToRkMCKAOZ0K3vrfUmV4JFgBIyen1puSK t1OndFdCjqGUjBBHBqSdgRFjUKihVHAAGAKLBc53xR57XNqkVq0iHO5gu7j0p3itxpPoVPs09ppq vqH7uTdlWVs49Mj6Vd77DdjprAg2seOgFQSSMzLOoAJUjk+lAD2VXUqygqeoNIDGn8Pwq5lsdsT/ AN1hlf8A61Vd9Rqw+w0NIJRPdN5so6DsKTdw22NegQUAFABQA10Rxh0Vh7jNJpAQGwtCjL9njCt1 AXGaLD5mRSaZCWZ0GGK7cdqNAuc80EenTMgDSkP0jyApPQfWtE2K51luZDAhmAEmPmA6VAElACUA LQBDdQieBozkZ6EdQaAMDUogFtxKz4xjc3Un0NUNmtpcqtCEUEbRjpSaBlq4iE0Dxn+IY+lIRiW0 4WaSIysZE4ZCp5x3FMrY27d98eaRLJaACgAoAO1ACUALQAUAJQAUAFABQAtACY9qACgAoAKACgAo AKACgAoAKACgAoAKAMjXlY+WyNyoOFx196asMdpEQm08MeHYnL45aiVrju0WHsmK43DJ6kcEj3pX C5Cto0dysmC5wQ5bp+ApgRxrNEVRplyzYAbj8hQA0Xdx84R4nU5xleOOtN6bisZ7xywalHHHsEEs e4kDHlkeo96OgDYr9IriJf3mIwSecZOetV8wvY2IdYtpHCMW55DY4qeURoJNG5wrDPpU2Aqaxc/Z rXcMEn+HGd3tTSuHUh0SOSNX8xFVeCu09M9qGBqUgCgAoAKACgDn9WgEzSxxfJsI5Hc/T0p7bFI3 bfHkpt6YFIlj6ACgAoAXtQAlABQAtACUAFAGfC6f2lMq7dwxnAp2GaFIQUAFABQAUAFABQAUALQA lABQAtACUALQAlAC0AJQAUAAoAWgAoAKAEoAWgBKACgBaACgAoAKAEoAXtQAlABQAtACUAFABQAt ACUAVLRVSecAkszZb06UxlukIKACgAoAKAFoAKAEoAWgBKAK2pf8ej846UIaH2f+oXAwPSgGT0CC gAFACUAFABQAUAKKAEoAU0AFACUALQAlAC0AIBjigAoAKAFoASgAoARs/wAPrQCI7aAW6FRJI5Jy S7ZNJJ9Rt3JqYhKACgBaAEoAKAF6UAJQAtABQAUAJQAtABQAlAC0AJQAtACUALQAlAC0AJQAtACU AFABQAtACUALQAUAFACUALQAUAFABQAUAJQAUALQAlABQAUAFABQAUALQAUAFABQAUAFACUAFAC0 AFACUALQAlAC0AFABQAUAFACUALQAUAJQAvSgAoASgBaACgBKAFoAKAEoAKAFoAKACgBKAFoAKAC gAoAKACgBKACgAoAKACgAoAKACgBaAEoAKACgBaAEoAKACgANABmgBaAEoAWgAFABQAUANoAWgAo AKACgAoAKACgAoAWgBKACgBaACgAoAKACgANABQAlABQAUAFABQBka7ZSylbi32ZUYfcM8e1O49e hiQ3Rsb4SI4XaMv8v319RTbFqzqPtsb2YurcGVCMqB3qbBYrf2kwjV5F8o9CpHO70NPQEn1H2upB 5vInUJIO4OVNFh2NGkIKACgANACUAFAC0AJQAUAHSgBaAEoAWgAoAyfEUKy2a7lLfMBjdjrTQ0Sa IWW38sk7UO1Qeox60MGXpxIYmELBZOxI4pbCKB1iCMhJwySYyRjpVKN9gehONRtW27JkO7pz1o5W K6GxajC0hRyq/wB1s5DChxsCZcVlYBlIIPcVIx1ABQAlABQAtACUAN8tASQi5JznFAXHUALQAlAC 0AJQBi66sYZBMuVY5U9waaHcdpEzmby1U+Tj5T6UNiNikBh3QRdUlDDJYAjB+7QPY0tOkMsTMU2D dge49abBlukIKACgBKAFoADQAUAFABQAlAC0AJQAUAFAC0ABoAKAEoAKACgAHHfNABQAUAFABQBi +J3nS0DQBSMHIJxVRaQ9Cfw6jx6TF5j7ycnP1pS3EadIAoAa0aNgsoJHI46UrBco3stvZMxwBuGW UD+lUkFzOKZ8ySAo4cbSTwQKrTqNWMq7triSbc6eYBgLnuKLoLFO3iuUuni8qUouSvA+apckHKdL ocMdyizvA6GJztLZ5pt+YWsS+I9hgjWRsAuMc857UkBZ0QMLPLx+WxY5Gc/jSYi/QAUAFAC0AJQB jarbFLg3EKgSPhGJbHFO47XRZ0eQ7JLckt5Rxu9aGI0KQBQAUAFABQAUAFABQAtAGVahhqc4aTcd 3C+gpjNSkIWgBKACgAoAKADv7UAFABQAtACUAHQUAFAC0AFACUAFABQAUALQAlABQAooAKACgBKA CgAoAKACgAoAKACgBaAEoAKACgAoAKACgCnbv/pkqDGF6+tOw2XKQhaAEoAWgAoASgAoAKACgAoA p6qQtmdwBGQP1oQ07aklgGW2QOMMOvNAMsUCCgAoAKACgBaACgAFACUALQAUAFABQAUABoASgBaA EoAWgBO9ABQAUAFABz+FAC0AFACUAFAC0AJQAtACUALQAlABQAtABQAUAJQAUALQAUAFACUAFAC0 AFACUALQAlAC0AJQAtABQAlABQAtABQAUAFACUAFABQAtABQAlAC0AJQAUALQAlAC0AJQApoAKAC gAoAKACgAoAKACgAoAKACgAoASgBaACgAoAKAEoAWgAoAKAEoAKAFoASgBaACgAoAKAEoAWgBKAF oASgBaAEoAWgBBQAUAAoAWgBKAFoAKACgAoAKAEoAKACgAoAKACgAoAjmi82MruZc91ODSd+g07D IGuXkk86JI4xwmGyT7mhO+6BpdGTimIKAFoAKACgAoAbQAUALQAUAFABQAUAFABQAUAFABQAtABQ AlABQAUALQAlABQAtACUAFAB0oACMjBoA53UrDyZfkU8j5HJ4+hp3G7MNHuJre+FrIY8SDcU6bfp 603qrg0kb8kUcoAkRWxyMjpU3Ec9Ks9rcSjbt3HCnHUetVuO6NrTbpbu1V1bJHDcY5pNWEW6QCUA LQAUAJQAtACUAFAC0AFABQAlABQBBfJG9pIJcBQM5Pb3o2A57w5cCS8Mcdx5mCS2D1q5aISZ1FQM oajpNvfqwk3IzDBZODQ7hoZC+EFikLQahOgxgKVBpqTRV12IbjwteboxDqG5OA+8Y49sU1NoWh0e n2ps7YQ+YzgdN3YelS23uLToWqAEoAKAFoAKACgAoASgAoAWgAoASgCO4t47hNkq5AORQAkFtDbq qxoAE4HtRcCWgCiLAi9kn3gq/YjkUD0LkUaxIEToKBD6ACgAoASgAoAKACgBaACgAoAKADpQAUAF ABQAUABoAKAEoAKACgAoAKACgAoAxvE5P2IRxoGlbpx0HenFJ7gWdBJbSoMjBC4PGKTA0KACgAoA z77SILu5S5JZJlG3I6EehFAEI0dgXXz/AN26gbdtO4ySPRolbJldl/u9qV2Fy7DbRQfcUA9M96BX JenSgDnfENxDKRCqgS9VcrkjHoKpKw7aGro6bNPiXfvIHJxik9RF2kAUAFAC0AJQBT1WLzLRsNtK 8j60IZU8PAiOT5icnuc802I16QC0AJQAUAFABQAUAFABQBl2odtWmZyBjp6kUxmpSELQAlAEalxK Q2Np+7gfzpD6ElMQd6ACgBaAEoAKACgAoAKAFoASgAoAWgBPpQAUALQAgII46UAFABQAUAFAB3oA KACgAoAWgAoASgAoAWgBKAF7UAJQAtACUAL2oAoWyEX02WDZORjt7UD6F6gQtACUAFABQAUAFAC0 AJQAUAVNUbbbjEYfLDg0BsS2knmw7tpHsRQxsmoELQAlABQAUAFABQAUAFABQAtACUAFAC0AFABQ AUAFABQAlAC0AFABQAlABQAUAFAC0AJQAtACUAKKACgAoAKACgAoAKACgAFABQAUAFABQAUAFABQ AlAC0AFACUAFAC0AFACUALQAUAJQAtABQAlABQAUALQAUAFACUAFABQAUALQAUAJQAtABQAlAC0A FACUALQAlAC0AFABQAUAFABQAlAC0AFABQAUAFABQAUAFACUAFAC0AFABQAUAJQAtABQAlAC0AJQ AUALQAUAFACUAJj5s0AKBjvQAUAIzbRnB/CgBQeKAELKGC5GT0FAC0AFAC0AJQAtACUALQAlABQA tACUAFAC0AFACUALQAUANoAKAFoAKACgAoAKACgAoAKACgAoAKACgBaACgBKACgBRQAUAGKAEoAD xQA2NxIuVoAJHEUbSNnaoycCgDmbjxGftIUorW5+9xkqPcVfKgV+hZsrjSpZ47pVywHyOeg+npSd MHNGvDe280YkjkG0+vFJxa0AzdeVcLNENzYKtg9qEh36DPDLArKwJYvjJxgU2I3akBaACgAoAKAC gAoAKAEoAU0AFABQAUAMljWWNo3GUYYI9RRsBXsdNs9PDfZIFj3/AHiOppWHctUxC0AFABQAlAC0 AHagAFABQAUAFABQAUAJQAUALQAUAFACUALQAlAC0AFABQAUAFACUAFAC0AFABQAUAFABQAUAFAB QAlAC0AJQAUAFABQAUAFABQAUAc/4qu/sqxE4298fex7VUUD2L3h+TzdPDc4LHGaTA0qQBQAUAFA BQAUAFAAehxQBx10JZVcSM8jI5yCecCr3d+g9NTT0u/czwxgErIuNo7Y7n3pOwehvVIgoAKACgAo Az9ZP+jAZIAOSM9famhoj0AIbd2QMGLYbPr6UmI1KACgAoAKACgAoAKACgAoA5zTLiMa9NGxHmSM +Apz09fSra0GdHUCCgAoAKACgAoAbnLYU9OtADqAFoASgAoAKACgAOcHbwaACgAoAKADFABQAtAC UALQAUAJQAUAFABQAUAFABQAUAFABQAooAKACgBKACgBaAEoAo2kapeT7Tn5tx55FNjL1IQUALQA UAJQAUALQAlABQAUAU9VjL2uUzvRgy4prQF2H6auyzjHzdP4jk0gLNAC9KAEoAKACgBaAEoAWgAo AKAEoAWgBKAFoAKACgBKAFoAKACgBKACgBaAEoAKAACgBaAEoAWgBKAFoAKAEoAKAFoADQAUAFAB QAUAFABQAUAFABQAlABQAtACUAFABQAUAFAC0AFACUAFABQAtACUAFABQAUALQAUAJQAUALQAUAJ QAtABQAlAC0AHSgAoAKACgAoAKACgBKACgBaACgAoAKACgBKAFoASgAoAWgAoASgAoAWgAoASgBa ACgAoAKACgAoABQAUAFABQAlAC0AFACUALQAlABQAUAMwx3h/unoQe1IZS1Gxi1Oxa3jmMa54aM8 rionHmWhUZcruyexj8i3EAaZxF8u+Xkn396qN0rN3JZZqhBQAUAFACde+BQBXvYJZ1QQXLQFWBO0 D5h6VMk+jKi0t0WRVEhQAUALQAUAJQAUALQAlABQAlAC0AFABQAUAFABQAUAFABQAUALQAlABQAU AFABQAUALQAUAJQA2SRYoy7kBV5JoA5ufxRuuo4raFirZwT/ABY/lV8qW4C/2wiyRyWyuq7v3i4z u+lFkM6RTuUH1FQIzZ9BspXZ1Voyxydhxk0rMdzOuvDBlU7bjkH5eMY9uKak1sGjIpdIvbZIwhZ1 XjCdR6YqlPyAadNv7tNjRPH82CGfAA9eKXN2Hsb2nabBYD90oBxjikJl2gQtABQAlAC0AFACUALQ AUAFABQAUAFABQAUAFACUALQAUAJQAUALQAUAJQAtABQAlAC0AJQAUALQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABQAUABoASgBaACgAoASgBaACgBKACgAoAKACgAoAKAOe8XIj26DnzMHaF6/wD6 qaQGh4fVV0uIKGA9+tK1gNGgAoAKACgBaAEoAWgBKAKt3ao+ZAgJA5HTP40DMiyuhbxeYiK2Onyk FuegqmtQ1sbVtdQ3KBo3Ge655U+hpNWET0gCgAoAB0oAwNR819T8vzCN+Ag6gDvVdBpG3bQrBCsa DAFSJklAB0oAKAFoASgAoAKACgAoA5nTkki8SSb4wqPv2kdz6mnpYbOmpCCgAoAKADjpQA2QlUJG c47daWwISE5TP5mhDeg+mIKAGySJGu5zgDvQNIMgrvT5sjigB1AhaAEoAWgBKACgAoAWgBKACgBa AEoAKACgAoAKACgAOB14oAKACgAoAKACgAoAKACgAoAKACgCpbKovLkgnJI/DimxlukIKACgAoAK ACgAoAKAFoASgCtqAJgwoOc9qBofZgLAqjoOKAZNQIWgBKACgAoAKAFoASgBaAEoAWgAoAKACgBK AFoASgAoAWgAoASgAoAKACgAoAWgAoAKACgAoAKAA0AJQAtABQAUAFACUAFABQAUAFABQAtABQAC gAoAKAEoAWgBKACgAoAKAFoASgBaACgAoASgBaACgBKACgBaAEoAKACgBaAEoAU0AJQAUAFABQAt AAKACgAoASgAoAWgAoABQAUAFABQAlAC0AFACUAKaAEoAXtQAlAC0AFACUALQAUAFACUAFAC0AFA BQAUAFABQAUAFABQAlABQAtABQAUAM2fPvyemMZ4oAq/Zm8t1lLMGPKp8uRWaTRd0WHWUMjRkYHB U9/fNW79CVYdKrPE6o5jYggMBkqfWmJFfTYZ7WziguZjO6DBlbq/uaSu9xu3Qnndo4ZHjQuyqSEB xuPpQJLU4tNZ8SnVbG3vbaG1S6mDeWg3skYHIJ6Vh7ZvpY6HTildHb10HOGOelIApgLQAlABQAUA LQAUAJQAUAFACUAFAC0AFABQAUAFABQAGgBaACgANABQAlABQAUALQAlAC0AFABQBHPDHPEY5V3I eopBsZ50Gw84yrGVY9cGmO5CPD8X2vzzMxGMbcCl5BdGyo2gAdqYgoAKAGmRAcF1B9M0WAcCD0Io AKAA/XFAC0AFABQAUAJQAtABQAUAFABQAGgAoAKACgBKAFoAKAEoAUUAFABQAUAJQAtAB0oAKACg BKAFoAKAEoAKAFoAKACgBDQAtACUALQAUAFACUAFACmgAoAKACgAoAKACgAoAKACgBKACgAoAKAC gCGa5hh/1jgfjTsBWj1ezk3ASjeoyUJ5FPkYrocNTttpJfbgZwaXKPfYp6lFYaltl+1BGh53q2OP Q07NDRZ02e2jtUjS5WUjqQc8mk0wZd86P++BxmlYVhBPETgSKT7GizAXzY/76/nRYBfNTHDD8KLA gMiKMlgKADzY8Z3j86LANaeJclnVQOuTinYBsd1BIm9JVK5xkGizAessbDh1wfelYCjfwlwDBIiE HcCR096pDvoZ6o0VwrkCQluShxj/AGqAsnqX11WJHaN8tsOMjuaLCJxqNuCwkbYVxw1JJgSNeW6h T5q4Y4GOc0WYFW71JBmG2IMx4UnpRYLFLRNO/eG9uGZpGOQSabbHokbuR61IhcigAyPWgAyAM5oA Mj1FABketABketABketABx60AJx60AULXS4ba8a582V3OcB2yFz6U22xl8kDvSERXFzDbIHmkCg9 Pei1xN2FhniniEsThkPcU2rAiA30acfwgfezxxRYoWC4Dgu7BQMk88e1DQOw77dbZwJR/Q0WEOa6 iRSzEgAZ6UgsMS8gfMizr5ajnPGKfKx9BTewoNxckE8YGf5Ugt2HS3ltFgSSoCRkKTyfwp8oiP7f agjbIGJ4wvNHKwHC+h25yfYHgmlYBUvIX4DDPpTsAxtStUVWaQAN0560crAebyIKrZ4PSiwDRfQl tozn6UWHYl+0JnHtmlYLDTdRLt3HBPY0WCwi3kLbtrD5TgjNOwWFlu4osbs80rBYRryJSoz97pTs FhVukZNyAt7CiwWEe8ROCMH0zSsFhy3Kt0B/GgLDDeICwx054PFArALxGUMg3DOPpRYdhXulUgYP J4p2AGu0Vwp7jj3osFga7jXAbGW6D1osFhFvIy2wnDkZxRYLEbXsiyEfZyVA67hzSBqw6G+WUMRG 4A9adgsPa6VRzjPYZ60rBYZ9sIl2bF2gHJ3dPwp2HyjhdrztGTjgZ5osKwq3JYfcxQFhr3RVlCqC CcE54FAWFa9jUgYYktjiiwrEkdxHIcKwyDjFKwWJc0AVLRibmcEHAIwfX6Uxst80hBQAUAFABQAU AFABQAUALQBS1V2igR0OMOMj1oQ0S2S7YB827POfWgGT0CCgBaAEoAWgBKACgAoAWgBKAFoASgAo AWgAoAKACgAoAKACgAoAKACgAoAKACgAoASgAoAWgAoAKACgAoASgBaACgAoAKAEoAKACgAoAWgB KAFoADQAUAJQAUAFABQAtABQAlABQAtACUAFABQAUALQAUAJQAUAFABQAUALQAUAFABQAUAFABQA UAJQAtABQAUAFABQAUAJQAtABQAUAFABQAUAFACUALQAUAFABQAUAFABQAlAC0AJQAUALQAlABQA tACdqAAHgZGDQAUALQAUAFABQAUAFACUAMaVFcIW+bGcUr2HZkf2uLzliyQ7dARS51ew+R2uWKok KAGSRpIAHUHByM9jQF7DqAGmNGdXKjcvQ+lS4ptMd7aD6oQlAC0AJQAtACUALQAUAFACUALQAlAC d85oAKAFoAKACgAoAKACgAoAKACgAoAWgAoASgBTQAUAFABQAdKACgBKAFoAKACgClqV0LeHAZQ5 HANAIyLSS9vV8v5jEThudv61XNbYdiYaddJu/dqc8Z3dBS5gshgiubfzI3LKg+YEGncLF3TtREvy TNls8Hbik0FjUpCCgBKACgBaACgAoAKACgAoAKACgAoAKAEoAWgBOlAC0AFABQAUAFABQAUAJQAt ABQAUAJQAtABQAlAC0ABoAKADpQAlAC0AJQAtABQAUAFIChbiePU5xPMGSVQ0SAdAOv8xQuppJxc FYv0zMBQAUAJQAUALQAUAFACUAFAC0AJQAUAFABQBxWrSfbNZkgu5vIgiJ3L3YdsntV2dtAdiaLw 08MglhCTb+59Pr3qblaE/wDYk6K6RwIBngg8kUXQbbMs/wBiETFoolTgZbd978KNguiZtDQRN5B8 p3OSRSTsFxI9IkG1XClec/MTxRcNBDoccboYw52qR9/FPmYaEUmhuHVlO7jB3Hp+NPmYWiSDTJxE EQGMKMABzik2+gaPcSPS5VzkMcnn5qQKyGjRG8ogySFie5xxTuLREcemTNI7SJPheAC2d1F9B2RM NHDxBSHC53bf50XCyK0enTxyAMjCBGPDHnH1p8wrIbJpbwSbo0uJOSMbiRg96HJj5UNnsJREyzQz uegKj/Ci9g5ew230VnidtkgYjq3U+nFDdwsK2jTneJopHVgBkNz+FJyfcLLoRjTbmNV/0eU7G4+Y 8CnztC5Q+xXNtPI8iyyHGUULnNHN3BRJoYrhnMkkV1sznYTijmSVh2aLK2148oaUy+WeCuTkUuYV h6w3/lld7pkkDqTijmHYYLa+MLRlpmL/AHu3HpT5hNIfbxXMVvIGaXPbncRildjSGiG6U5fziHOA 2eV96LhZbiRJLHL9yVj33Z5+lF2Fuw5beZBIu+4zIc4LHAH17UczEooatmbUSqvmmPcMID09xTux 2REIZIy7IbrD8F85YAUc192Fl2CMyEKsUk4HVm9TRcGtSOMXEs6EllQqcMSRzQ21oLlRS1S/8lor aTzSF+9tb9fpTUvMVjE8TWPiC9ktf7GlU/LtZJTz9RU+0a3Vw9nbY6Hw3pmu2Oitb3c+24kORtAI T1P40Oe2g1Huxs+kajBqX2oSSPaMpzCDgA98CpvLuVoy/awyTbpI0kQ4CsGbAb0Iq76WFoV54ZUm 8rzVeRTnAP3U9+wouDTLltZTzxlt6MrDAkD5x7UarQVo2I5dJuCqRCMbQclgeSaOaw0wk0zUdgFu wimT7rs+Vx3BFHM0KyKKaDqlxf8AnXywNtzsfdyo9KnmfRDsu5ffR7v7O6W8kUMu4EHJOaLgrdSR NHuWP76Rc8Enr0p3FZEw0qRpD5wjKHk461PkKyGvpM5G39zsByoxjFN2HZCppkibyyo/ogPei7BJ DI9JufLXe0asTlsEkD2p8wrIe+kSNtzKhIPPy4OPrRzMaSHDTrrzizNC6443CjmDQItIaIs6lNx9 uKOZsNNiMaLcMx8y5XaWyAqkEfjRzeVgLR0z5WxLh2Ocmkw9AfTXbIE20cDigdxkumSyOSZ1C8dF 5GKAuhX0yaSJo3u2wT1AwcUXFoRw6RLFEsYuc7TkHbQGhINK5bdMwB5GOxouDsxw0vClRczbT78/ nRdoLobHpWzrcOfT2p3YaE7WQIA8w8Dj2oC5CulYYsZ5C2MZzRcNELFpZX/XXMsh/L8KQaFkWqhd u47cYx7UBcrNpMZdHErgp93vijULkv8AZ0W4tvkyTng4ouwuhF05BKZC7lsYoC5LHaqkYTexIGMn rQFyB9NQxGNZZArfe560BcpNpsts7SeYJVx8quec0/IPQoXF62yJTDhidrkcsfYVWi1Cx0lmrLbq Gz06HqPrUAynp6Xy6neG5MH2Y48rZncPrTb8gZp0hBQAUAFABQAUAFABQAtACUAUNaYLZ5Jx8w5x 0prcEWLEAWse05GKQMn6UAFAC0AJQAtACUAFABQAtABQAUAJQAtACUAFABQAtACUALQAUAFABQAU AJQAUAGecYNAC0AFABQAUAFAAKACgBKAFoAKAEoAWgBKAFoASgAoAWgAoAKAEoAKAFoAKACgBKAC gBaAA0AJQAtACUALQAlAC0AJQAUAL2oAKAEoAWgBKAFNABQAUAJQAtABQAUAJQAUALQAlAC0AFAB QAUAFABQAUAFABQAUAFABQAlAC0AJ3oAXpQAUAFACUAFAC0AFABQAUAFABQAUAJQAUAFABQAhXOC c0ALjFAC0AJQAUAFAC0AFACUAHFAC0AJQAZwcUAFAC0AFACUALQAlABQAtACUAFAC0AJQAUALQA2 gBaACgAoAKACgAoAKACgBaACgBKAFoASgAoAKAFoAKACgAoAKACgAoAKACgCGa3hmIMsatjpkUBc kVQvQAUABZRwWGaLARzJFPGyNggigaujlri4NtcOI1MYVwAvfPr9Kr1HY6uBt8KNzyAeakkkoASg BaACgAoASgAoAWgAoASgBaACgAoASgBaAEoAWgAoAOlABQAUAFABQAlAC0AFACdBQAtABQAUAFAB QAlABkbgO5oAWgAoAKACgAoAKACgAoAY0asysR8yfdPpSGnbQfTEFABQAlAC0AFACUALQAUAFABQ AUAFACUAFAHB+I/DGp6lr3mR3qpaTDEwVcEgdB70czWyHypna2Vv9ltY7dTlY1Cg0CJ6ACgAoAKA CgAoAKACgAoAKACgBssaSxtHIoZHBVlPcGkwK2n2bWMS26SvJAudu88oOyj1A9+afqBcoASgAoAK ACgAoAKAFoASgAoAKACgA+lAARQAYxQAm1f7ooAa0aNwyAgdMigdxrww45iQjHPy0rBdlO/lMUqJ FErPjIyuNv41SSGjQH3RzSJBl3DFAEawIqbMcZzQO4kttFKHyoDONpYDnFS4JjUmippliNKt5UL7 oslwAOR61NOLgrFSlzPQvowdFdc4YZHGK0M9h1AB0oATAznAzSsAv0pgFACHIHAzQA1pUQoHZULn ABPU+lA7D/agQUAFABQAUAFABQAUAFABQAUAJjrQAY56UALQAUAFABQAUAFABQAUAFACMisMMoI9 6AGJBEjbljQN6gc0Bck6UAVLaQNdzIAOACSD+lNjZbpCCgAxQAUAFABQAUAFAC0AJQBQ1nH2ZfmC kOMEimhosWOPsse3OMd6QmT0ALQAUAIVBx7UAFABQAUAFABQAUAFABQAtABQAUAFAAKACgBKACgB aAEoAWgBKAFoAKAEoAKAFoAKACgAoAKACgBKAFoAKAEoAKAFoAKACgAoAKAEoAKACgAoAKAFoASg BaACgAoASgAoAKAFoASgBaAEoAWgBKAFoAKACgAoASgBaACgBKAFoAKAEoAWgAoAKAEoAWgAoASg BaAEoAWgAoAKACgAoAKAEoAWgAoASgAoAKACgBaACgAoAKACgAoABQAUAFABQAUAFABQAUAFABQA UAJQAtACUALQAUAAoAKACgAoASgAoAKAFoAKAEoAWgAoASgBelAB0oAKACgAoAbQAUALQAUAFABQ AUAFABQAtAAKAEoAWgAoAKACgBKAFoAKACgAoAKAEoAWgAoAKAMjWJ747rfT/LVyAS7H7o+lUtNQ sZVvpmsQP58kgk77Q2T9aXM3uPl8yRLXV5ZdsiYReVOcU+bsNou2uiN5olvJfNbOSCKnUWi2NoDA AHSgQtABQAUAFACUALQAlAC0AFABQAlAC0AFABQAlAC0AFABQAUAJQAUALQAUAJQAtABQAUAFACU ALQAUAFACUAFAC0AFACDPegBaACgAoAKAEoAKAAcUALQAUAFABQAUAFACUALQAUAFACUALQAGgBK AK7kGdQGAb0x1pjLFIQUgCmAUAFABQAUAFACigBKAD+VABQAUAFABQAUALQAlAC0AJQAUAFABQAU AFABQAdOgoAKACgAoAgNyBeLb9yu6iwE9AFO+jaRlVTx1oKRbHCgCgkWgAoAryziCRUKMQx+92FS 5JOxSjdXLFUSFABQAUAFACMwRSx6Dk0AJG4kQOuQD6jBoDYd7UART20NwqrNGGCsGXPYjvUuKluN Sa2JaoQUAFABQAUAFABQAUAFAC0AJQAUAFABQAUAFABQAUAFABQAUAFABzk0AAoAKAKVoNt7cgYx kNx9Kb2Gy7SEFABQAtACUAL9KAEoAWgAoAKAM7WkL26ddquGbHXFNDRasyGt0KjC44pAyagQUALQ AUAFABQAUAJQAtABQAUAFABQAlAC0AJQAUAFAC0AJQAvSgAoAKACgAoASgBaACgBKAFNABQAlAC0 AFABQAUAFABQAUAJQAtABQAUAJQAUALQAUAFABQAlAC0AFABQAUAFACUALQAUAJQAUALQAUAJQAv SgAoAKACgBKAFoAKAEoAWgAoAKACgAoAKACgAoASgAHQZ60ALQAUAFACUALQAUAJQAUALQAUAJQA UAFABQAUALQAUAFABQAUAFAAaAAUAFACUALQAlAC0AJQAUALQAUAJQAUALQAlABQAtACUALQAlAB QAUALQAUAFABQAlABQAUAFAC0AJQAUAFACUALQAUAFABQAUAFAC0AJQAUAFAC0AJQAtABQAUAFAC UALQAUAFABQAUAFABQAUAZGsoI3E+QAy7TnuewqogJpN2ykRTABW+6c9D6UMDXqQCgDOvtZtLQEF wzdOOmfSqUWwG2msQzMVkATH8Wflz9aHGwrs0x04qRi0AJQAooAKACgAoAKACgBrEKpJzx6UAKOl ABQAtAAaADpQAlABQAUALQAUAFACUAFAC0AFABQAUAFABQAlABQAtACUAFAC0AJQAtABQAUAFABQ AUAFACUALQAUAJQAtABQAUAJQAtABQAGgAoAKAEoArEKLobhyehoK6FmgkWgDO1W+ey8orHuVj8x z0poC1ZlmtkZzlmGemKTBk1ABQAUAFABQAUALQAlABQAtACDPOfwoAWgAoASgBaAE70AFABQAtAC UAFABQAUAFABQAUAY9vcb9enjABAUfN6Y7VXQDY61IFDUnER3dwueuM4pjTLkbq8KyL90gEUhD6A CgBgCuSSM9uRStcY+mIKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAWgBKACgAIoAKAGu23Hyk5P agEOoAPagBqSI+djA7Tg47GgLWHUAFABQAUAFABQAtACYoAKAKNrt+3XBDjeSAV9MCm9h2LxwKQg oAKACgAoAKACgAoAWgAoAztcQvY4DYG4ZpoEizZDbaxjbt46A0gJ6AF7UAJQAtABQAlABQAUALQA lAC0AFABQAUAJjmgAoAKACgAoAKAFoASgAoAKAFoAKACgBKACgAoAWgAoASgBaAEoAWgAoAKACgB KAFoAKACgAoASgBaACgAoASgAoAKAFoAKAEoAWgAoASgBaAEoAKAFoASgBaACgBKAFoAKACgAoAS gAoAKAF6UAFABQAlABQAUAFABQAUALQAlAC0AFACUALQAUAFABQAUAFABQAUAFACUALQAUAFABQA lAC0AFABQAlAC0AFACUALQAUAFABQAUAFABQAUAFABQAUAJQAUAFABQAUALQAGgAoAO1ABQAlABQ AUALQAUAFABQA2gAoAWgAoAKACgAoAKAA0AFAC0AJQAUALQAUAFACUALQAUAJQAtACUALQAUAFAA KAK99D59s64BI5GfWi9gRy00TRi2fzQ0qsZFAydx7ZxWibDodTYXBubSOVkKMw+ZT2NZgZ2v3Mgi WC3k2O/Vh2poLkFnosV5Yo10TvcZ3Lx+NDY9EU72yk0+VCrE/LjIH3vqKE7dANLSb4Rf6PcShjkb H6Bs9hTaEbNSAtACUALQAUAFACUAFABQAtACUALQAlAC0AFACUALQAlAC0AJQAUALQAlAC0AFABQ AlAC0AFABQAUAFABQAUAFABQAUAFABQAUAJQAtACUALQAUAFABQAlAC9qADtQAUAJQAUALQAUAJQ BWLEXYVgNvY+9BXQs0EiFlUgE43cD3oAz9ZWRoohHj74zkZpp2Gi9AMRAcfhSEx9ABQAtACUALQA hGaACgBaAEoAKAFoAKAEoAKACgBaACgBKAFoASgAoAWgBKACgAoAKAMi0tbdtYmnWLEydWB65p9C mzXBB6GkSZeqRmS5RFjbcy4EnYe1NMaNKIbY1HoKQh1ACMDxtOOaQIWmAUAJtGaAF5oAKACgA7UA FABQAUAFABQAUAFABQAUAFABQAUAFABQAUAISRjAzQAtADHZ1xtTI780h2HLjGQMZ5oENeRQduee w9aG7DSCJiyBmUqT2PahO6B6DsndjjAoELTAKAA8UAHagAHTFABSAypbadrwy221FxgNjLKe9N3t ZFJLqai5AHf3oJFoAKAFoASgAoAKACgAoAKAKuprm1Jwvy84NCCw+xG22QZ6AU2DJ6QC0AFABQAU AJQAUAKaAEoAWgAoASgBaACgAoAKACgBKACgAoAXpQAUAJQAUALQAlAC0AJQAtABQAlABQAtABQA lAC0AFACUAKaAEoAWgAoAKAEoAKAFoAKACgAoASgAoAXtQAUAJQAUAFABQAUALQAUAFABQAUAJQA UALQAUAJQAUALQAUAJQAtABQAlABQAUAL2oASgBaACgAoAKAAUAFABQAUAJQAtACUAFABQAtACUA FABQAUAFAC0AFACUALQAUAJQAtABQAlAC0AJQAtABQAUAJQAtABQAUAJQAtABQAUAJQAUAFABQAt ABQAUAFACUALQAlACmgBKAF7UAJQAvSgBtABQAtABQAUAFABQAUAFABQAv0oASgAoAWgBKACgBaA CgAoAKACgANABQAUAFABQAUAYmt2qonnRxj8BQtB3K+h3jpcMkyFI2GFJPGR6VTswsMvGYSy7oz5 ecndzjPpSWoHQ26hII1X7oUYpCC4gjuIzHIuQf0oBaHLalB9lkjjkQnyX3xMO9O1y0dHpt39rtw5 AVs4Kg9KTt0ILdABQAUAFACUAFABQAtABQAlABQAUALQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAJQAtABQAUAFABQAUAFABQAUAJQAtABQAlAC9KACgAoASgBaAEoAKAFoASgAoAWgBKAK4XN 0x5wMfSmMs0hEMtuks8MrFswklQDxkjHIo1C5FfA5jwBgHOScYoGieIgxgjpQIf3xQAtACUAFABQ AUALQAUAFAAKACgBKACgBaAEoAKQBTAKAFoAKACgBKADIoAb5iD+IUWCwx7mGMgNIgJ7ZppMNiCT VLKMfNOmScAZ6mnysChZ3VvDcTTl2Ac55NId0WV1exjjZlbaAckYp8rFfuVH1qzcvKJCT0CetHKx 3sbVvIJYVdRgEdKkQ+gAoAKACgAoATbyeTzQAtABQAUAFAAOOlABQAGgBaACgBKAFoASgAoAWgBK ACgBGz2oAWgBCcCgBsb741cDqKAtYfQAUAMaJGcMy/MOQalxV7ju9h9UIKACgAAxQAUAFABQAe+K AKKSO14QGxGvBUeppjLqYC4AIA9aSExaACgBRQAlABQAUAFABQAooAp6lIY4MquT29qaGh2nFms4 2kADEZOKQi1QAlAC0AISAOTigDM1HVUt1wuQpOPM7fhVqIXQ7Rrua5jfzgeOhPf1qWBo0gCgBaAE oAKACgAoAKAFoAKAD6UAJQAUAFABQAUAFABQAUAFAC0AFACUAFABQAUAFAB0oAKACgBaACgAoAKA CgBKAFoAKAEbJGAcUgEACjAoAdTAKAEoAWgBKAFoAKAGjduOcbe1ADqACgBKAFoASgAoAWgBKACg BaAEoAKAFoAKACgAoAKAEoAWgBKAFoASgBaAEoAKAFoAKACgBKACgBaAEoAWgAoASgBRQAUAJQAt ABQAnSgAoAKAFoAKAEoAKAFoAKAEoAU0AJQAUAKaACgAoAKAEoAWgAoABQAUAFABQAlACmgBKACg BaAEoAKAFoAKACgBKACgBaACgAoASgBaAEoASgBaACgAoAKACgAoAKACgBaAEoAKACgAPFAC0AFA BQAUAFABQAUAFACUALQAUAFACUARXVutzC0b5wfSkBzj27LOsUmFkGcM44B9vWrvoVYoG8cSi0RP NmkYBuPfrT0SuSr3O2QYRQeoFQAjuFIz09aAMbXZg9spTGM4OTjHvT2HbQd4cDmOVmjCjOMj+I0N p7AzZpCCgBaACgBKAFoAKACgAoASgAoAWgAoASgAoAKAFoAKACgAoAKAEoAXpQAlAC0AFABQAUAF ABQAUAFABQAUAFABQAlAC0AFACUALQAlAC0AFACUAFAC0AJQAUAFABQAtABQBXv2mS0kNsP3uOPa hAcWZ9Ukl3tDceYhJVlHbNVzpaXBLyNKHWblYwzhg3cMpJzQ2htWJ4tbnEZd06jIwDxQ0gSY608R iX5GibcByxGAafKIkutXtZFQuhcKR270uUa03NCxuopIB84+h4pNCZb3L6ikAuR2IoAKADIHU0AV 2vbZSQZkyOvPSnZgQzarbxqrKd4boR0osBH/AG1aeaqK689ycfzp8jDQF1yyZmUSr8pxnPBNHKwE bW7VYi5dQPr2pWDUj/4SGyChmbap6H1osASa/brGzBTx03cZp8gXE/ttWYeVGWTGd2aHEBG1tdzK oHHQ+vtRyjYQ60rDYzDzMZ+6eKVgsQP4kjDsImjcIcHtVWRI9vEltlFQqWboCcUlHqMB4ijaYRog YgZba2cU+VILoauvszMYodyD+8dpBpWQ7CPrF25Xyrdhx0Knk0LlBxZXs7nVl+ZoJiWY5LZIH4UO UegJMl+2akIiXjmLqc8Jw1Fx26DZLvU3KqkU6A4JOz9KOZBZk6w6pJv3Apls8MOlK4rIDo1w6fPI N3cbjQpMLIVPDw3Fprl2z2FF2Gg8eGrMAqXkK4+UE9KE2F7FXTtOtmnntOdkfykevvQ7juWrrQYG SNLfCqvBDcjFIQwaRZJchTGQR0IPWixVzbijWJAiDAFBA8UAJQAUAFABQAtABQAlACEgYBOM9KAF oAKACgAoAWgAoAKAEoAKACgAoAKACgDOur1I7krliwHC5wv400MuwSeZEr4xkZpCH59aAFoAKACg AoAKAA0AFABQAUAFABigAoAqQH/SpQQO3SmMt0hBQAtAAKAEoAWgBKAFoASgBRQBm62yLHB5i7h5 n3c47U0NOxctECW6KB0FIGS0CI5Z4oV3O2BQBQudVVG2wgNx19KqwGZcXt5cXUUcSGX5t21eBii6 QWY+PQ7i4Eq37qIWO4BetK/YEaenmIzN5bdFxj+tDHc0aQhKACgAoAKACgBTQAlAC0AFABQAlABQ AUALQAUAJQAUANKAyB8nIGMZ4oAdQAUAFABQAUAFAC0AJQAjKDjI6UAOoASgBaACgAoASgBTQAlA C0AJQAUAFAC0AFACUAKaACgAoAKACgBKADpQAtACUALQAlABQAtABQAUAFABQAlABQAUAFABQAUA LQAlABQAUALQAUAJQAtABQAUAHagBKAFFABQAUAJQAtACUAFABQAUAFACmgAoAKAEoAKACgBaACg AoAKACgBKAFoAKACgBKACgBaAEoAWgBKACgAoAKAFoASgAoAKACgAoAKACgAoAWgBKAFoAKAEoAW gBKAFoASgBKAFoAKACgAoAKACgAoAKAFoASgAoAWgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg CKaCKdQsqBgOme1AEcVjbRNuSFQ3rikO7LNMQhAPUUAUm0mxaR3e3Vy/XdyPyo30Y7lxVVFCooVR wAKBDqAEoAWgAoAKACgBKAFoASgAyM4B5oAWgBKAFoAKAEoAUUAJQAtABQAUAJQAtABQAUAJQAtA BQAlAC0AFABQAlABQAtAAKACgAoAKAEoAKAFoAKAEoAKAFoASgBaACgBKAFoAKACgAoAjmwIzmhA ipZo6ztnpt9aBslRla5kG3lTjOKALG0YxgYoENMMZGDGpB9qVguZWq2NoPLPlqm5gCV4JFUrjuNf RFeNik7ZbgZ6Ckm0PQZ/ZN3AqmCcEjgqTgGnzMVkNi0++h+Xqn90N3/wp8z6jshywauI32soPVRn 9KXN5Bp3IIdL1adibmcQDdk4cvkelHO+wuVFuLw9AMfaJGm/vZGM0rsLotx6TZRgBYBgHIyaQXJP 7Nst242sRI6Er0pcqDmYHTbIkE20XH+zTsguIumWSElbdORjGOKYXY7+z7Pj/RouOnyilZBdh/Z9 ptK/Z49p7YosFyRLaCP7kKL9Fphdj9i/3R+VKwhdq/3R+VFgGmGI9Y1/Klyod2NNtATkwxkjplRT SsF2ILS3VtywRhsYyFFFkF2PEUa9I1GPaiwXH49qYgoAKACgAoAKACgAoA57R5T/AMJBfwl/Vgv4 1XQZ0NSIz/NkOoNEYxsHIYUxmhSELQAlABQAUAFACigBKACgBaAEoAKAFoASgBaAEoAKAFoAKACg BKACgA6UAcxqexbkeSyqGYg54Gc81S1K2Ojttgt4xGRs2jGOmKlkseSAPpQAD2FAC0AFABQAUAFA BQAUALQAlABQAUAVLRStxMdwOcYHcUxst0hBQAtABQAlAC0AJQAtACUAFAGfrS/6OsgUMyt0PvTj uCK41QqiLGiqAMnOeBTshsg+1XV4mVEgG7hlGVxT0Q7eQsWl3UyK7sI2J5zzge1TzC0Rdi0eBSTM zS85welK7C5ejjSMYRAo9hQK4y73fZ2CfePAoBGdprkX5jZcYTAP0607DNikISgBaACgBKAFoAO1 ABQAlABQAUALQAUAFABQAlABQAUAFABQAUAAPpQAUALQAUAFABQAlAC0AFABQAlAC0AJQAUAHGcU AFABQAtACUALQAlAC0AJQAtACUALQAUAJQAtACUAFABQAUAFAC0AFABQAlAC0AJQAUAKaACgAoAS gBaACgBKACgBaACgBKACgBaACgAoASgBRQAGgA7UAJQAtABQAUAJQAtACUAFABQAtABQAlABQAtA AKACgAoASgBaACgBKAFoAQcUAFAC0AJQAUAFABQAUALQAUAFACUAFAC0AJQAUAFAC0AJQAUAFAC0 AFABQAUAFACUAJQAtABQAUAFABQAUAFABQAtABQAUAFABQAUAFACUALQAlAC0AFABQAlAC0AFABQ AlAC0AFABQAUAFACUgCmAtABQAUAJQAtACUAFABQAtACUAFAC0AFABQAUAFAB2oASgBaACgAoAKA CgBKAFoAKACgAoADQAUAFABQAUAFACUALQAUAFACUALQAUAJQAUALQAlABQAUAFABQAUALQAUAFA EVwcRmhDRS0qNkklLNuz0yOaLg/Isrxcvhjz2xQBZoEIQexxQBma1KsSRbwNrNg+o96cR3sXLFla 2RkGFPSk9AZPQIKACkAUwCgAoAKACgAoAWgBKACgAoAKACgAoAKACgAoAKACgAoAWgBKACgAoArW 9jDbzyTIDvkOSTQO5ZoEU1AW9c7T8+PpQV0LlBIUABoAbGrLncxbJzz29qQMdTAKACgBaAEoAKAC gAoAKACgAoAKACgAoAKACgAoAKACgDmNaVXldmX7p/h4zTsNtI6C0w1rEwHBUGlYRPQAUAHSgBaA CgAoASgAoAKAFoAKAEoAKAKVqW+3ThlAGByO9MbLtIQUALQAUAJQAtABQAlABQAUAVNSz5IAxz1y KENC2sMLQRsVVjtHzYoYXLQAHAGBQIKACgApAMlGY2HqKYIzrRZvtoV5BtRc7QuM0ymatIkSgBaA CgAoASgBaACgAoAKACgAoAKAAUAFACUALQAlAC0AFACYoAAMUAFAC0AFACUAFAC0AFABQAUAFACU ALQAUAISB14oAaMhsDkfXmgY768UCCgBaAEoAWgBKAFoASgBaACgBKAFoAKACgAoAKACgBKAFoAK AEoAWgBKACgBaACgAoAKAEoAWgBKACgAoAKAFoASgBaAA0AJQAtABQAlAC0AFABQAUAFABQAUAFA BQAlABQAUAKaAEoAWgAoASgBaAEoAKAFoASgBaACgBKAFoAKAEoAUUAFACUAFAC0AJQAUAFABQAU AKaAEoAWgBKAFoASgBaAEoAWgBKAFoABQAUANoAKAFoAKACgAoAKACgAoAKACgBaACgBKACgBaAC gAoABQAUAFABQAUABoAKACgAoADQAlAC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUA FAAaACgAoASgBaACgBKAFoAKAEoAWgAoAKAEoAWgBKAFoAKAEoAKAFoAKACgBKACgBaACgBKAFoA KACgAoASgBaAEoAUUAFADJHWNcscCgDMi1iC8n+yokquQTkrwMe9VZDQaW4M8gV2b+QpMLWLSr/p zMJOo5XPSkHQt0CCgCreWMd20bO7qUzjafX1o1tZAiyiBFCqMAUALQAUAFAC0AJQAUALQAUAJQAt ABQAlABQAUAFABQAUAFABQAUAFABQAtACUAFABQAUAFAFdci4YA8UyixSJEbIU7RkgcCgEV3SZ2g dBsUHcyk/pUtvoUrFmqJCgBRQAlABQAUAFABQAUAFABQAUAR3E8dtC80zbUQZJoAhsdQtr4MbWUO F603FoC1SAKAKuoXf2OAyBdzdl9aEgRBomqrqts0oj8tlbaVzTaS2A0aQBQBy2vRM0uWIY5yoDYP 4imM6HT8/YoclT8o6dKTEWKACgBRQAlABQAUAFABQAtABQAUAFABQBTt2Bu5QVwQOuaBlygQnSgA oAWgBKAFoAKAEoAKACgDO1yZILZHdiF3gdfWmgLlpjyF2nIHApAyWgAoAKACgCO4IERDEgH0oGij p0iS3Lsgbp1am0Ns0qRItACUAFABQAtACUAFABQAtACUAFAC0AJQAtABQAdqAEoAWgAoAKACgAoA SgAoAWgBKAFoASgAoAWgBKACgAoAWgBDQAYoAjEKrGEDNgHuc5pW0sO+pIAB0piCgAoAUUAJQAtA CUAFAC0AFABQAlAC0AFACdqACgBaACgAoAKACgAoAKACgBKACgBaACgBKAFoASgBaACgBKACgBaA CgBKACgBaAE+lAC0AJQAUALQAlABQAUAFABQAUAFABQAUALQAlABQAUALQAUAFACUALQAlAC0AFA CUALQAlABQAUAFABQAUAKaACgBKACgAoAKACgBaAEoAKACgBaACgBKACgBaAEoAKAEoAWgAoAKAC gAoAKACgAoAXtQAlABQAUALQAlAC0AJQAtABQAUAJQAtABQAlAC9qACgAoAKACgAoAO1ACUAFAC0 AJQAtABQAUAFABQAUAFABQAUAJQAUAFABQAtACUAFAC0ABoAKACgAoAKACgBKAFoAKACgBKACgBa ACgAoASgBaACgANACUAFAC0AFACUALQAUAFABQAlAC0AJQAUAFABQBBeD90ecUDRkaWYTcy8t5m3 GCOnrVDtqOhdYriLDoy7gG2+p4FAuhoJtN82JBuA5XFKwdC5SEFABQAUgCmAUAFAC0AJQAtABQAl ABQAtACUALQAlABQAUAFAC0AJQAUAFABQAEgDJOAKAAEHlSCPagAoAKACgAoAKAKyFhcOG6E/Lim UWaRIUAFABQAtACd/agAoAKACgAoAKACgAoAKACgCK4gS4iMcoyp7UAc3c6bLp26W3V1Gf8Almx4 570J8pVr6Ii1nX9QsrHz0A+XAZVjJar0Js2XtN8VWN3bB3bZJ/cznP0ocGCIdR1myvLZYJswyuCU JP3D701F7oNUZFtdGynjkt7n5+NyseH96En1DyO0s7uO6TK8N3U9ahqwFntSA5jVtj3THaTKR0PS qWgzc0xVSwgVE2AL09KliLYoAKACgAoAKACgAoAKACgBaAEoAKACgCjaR7NQuWyCpAxxjHrTuMvU hC0AJQAtACUAFABQAUAFABQBleI136fj/aHbNNAi/ZgrboCeg6+tJjZNQIKACgAoAgvQph+dioHO RQhooaIqeZMUJIOMZ6iqYNWNepEFAAKACgAoAKACgBKACgBaAEoAKACgAoAKAFoASgAoAKAFoASg AoAKAFoASgBaACgBKAFoAKAEoAKAFoASgAoAKACgAoAKAFoASgAoAKAFoAKAEoAKAFoAKACgA6UA FABQAlAC0AFABQAUAFABQAlABQAtACUALQAlABQAUAFAC0AJQAUAFAC0AFABQAlAC0AJQAtABQAU AFACUAFAC0AMXfufdt25+XHX8aAHUAFABQAtABQAlAC0AJQAUAFAC0AFABQAUAFABQAGgAoAKACg AoAKAEoAWgBKAFoAKAEoAKACgAoAKAFoAKACgAoAKAEoAXtQAlABQAtABQA2gAoAWgAoAKACgAoA KACgAoAKACgBaAEoAKAFoADQAUAFABQAUAJQAtABQAUAFACUALQAlAC0AFABQAlAC0AFACUALQAl AC0AFACUALQAUAFABQACgAoAKAEoAWgAoASgAoAKACgAoAWgBKAFoAKACgAoASgBaACgBKAFoAKA CgBKAFoAKAEoAKACgAoAKAFoASgBaAEoAKAFoASgBaACgCvejNs+Bk44FAIw7QO10kiECVl+YY4q 2OxYtGzqOPJGDySeqmpA04gBdSHgn+VIOhYoEFABQAUAFABQAtABQAUAJQAUALQAlACOgfGc8HIw cUALQAUAFABQAUAFAC0AJQAUAFABQBFcjdA67QcjGD0oQIzNKvoUVodmwoxXCnIFU0Mv/bE3BVVj 7jpU2Cw8XK4OVK4OOaAsK06KpY9B6c0WFYrWF4biSRWUgA8Gmx2L1IRThQC9lOefTPSgroXKCQoA KACgAoAKAFoASgAoAKACgAoAKACgAoAKAAgEYIoAjaGNgRsHIweKLDuc9N4XSG4EuntHEoz8rLwM 9cVKVtB6Msz6BDcRplQjr1K96od1sZ1zol0tsEwhw3ynb0pfIVuxmmS+09xIC6+WPur2H41opdHs JrqaEXie6VFLxKy464IP40/d6BZ2MpNTkv5JYslec8/wDvzS9BancaXPDLZxiCQOFUDNS1YC5SAK ACgBaAEoAWgBKACgAoAKACgAoAKAK8X/AB8ueeR0NAyxQIKAFoASkAtMAoASkAUwCgAoAzNeP+io gIDO4Az60IC7aY+zR7TkY60MGTUAFABQAUAVdSbZbMR1HQetCGipoRBE+OeR82ME02I1aQBQAUAF ABQAUALQAUAJQAUALQAlACigAoAKACgBKAFoAKAEoAWgBKACgBaACgAoAKAEoAWgBKACgAoAWgBK ACgAoAOc0AFABQAtACUAFABQAUAFABjFABQAvagBKAFFABQAUAFABQAUAAoAKAA0AJQAtABQAlAC mgBKACgBaACgBKAFoASgAoAWgAFACUALQAlAC0AJQAtABQAGgAoAKAEoAWgAoASgAoAWgBKACgBa ACgBKAFoASgBaAEoAWgBKAFoASgBaAEoAWgAoASgBaAEoAKAFoAKACgAoASgAoAKAFoASgBaAEoA KAFoASgAoAWgBKAFoASgAoASgAoAWgAoAKACgAoAKACgAoAWgA7UAJQAtACUALQAGgBKAFoAKACg AoAKACgBKAFoASgAoAXtQAUAFACUALQAm4eooAKAFoAKACgAoASgBaACgAoASgBaACgAoASgAoAK ACgBaAEoAWgAoAKACgBKAFNAB0oAKAEoAKAFoASgAoAWgAoAKAAUAJQAtABQAUAFABQAlAC0AJQA tABQAUAFABQAUAJQBHcKXhdR1xxQCOdmJjvgRJyOoxj8qr0KLtplr1CkbKAMA54PrxSAvQoReyvj rxz/AEoF0LdIQUAFAC0AJQAUAFABQAtABQAlABQAUALQAlABQAUAFABQAUAFABQAtACUAFAEdyu+ CRckZUjihAcrpWn3N4ss24K6Ns6kA49feqbaHbubVtps0IKGQFDyQPWlcBq6VKOHn3rnPI60rsE7 Ey2DpGwV1VyT8wp3Hcg0i3lRXZ3ydx6HNNu4jXXOOeKkRWiYG4kAH3TyaYyzkZxmkIKACgAoAWgA oASgAoAKACgAoAKACgAoAQsF6kCgBDIijLMAPeiwEZuYwM54Bp2AQXURIG7GTgZ4yaLAOLxhecAE /nRYZWgvt11JbvC6bRkMRwRS0CxcDowyGBoEQz2dvOuJYwR+VFh3ZXexsYwQ0YIIwR1osFzMEGny l4VUKhOC3TBp8tgujT0/TINPLPE5y33vSkr7AWWu4lUkNnb1xRYViKa/jRC0fzY449fSiwyOW+kQ FliYqBngdfWnoFiNNaifIVTuA4Hr7U+Wwi4t3GeDw2M471I7EnnxAZLAUCATxsSFYNjriiwCCdCc Z6deaLDsH2mMAEngnGaAsPWRGHB60CsOoAKACgCtbvvuJDgDAABzyaBss0CCgA6UARyXEMZAeRVJ 7E0WAYbuHOA4J+tOwEB1W2BQZYljgbRmiwAur2LDImAw2w5GMGnysCzFcQyqDG4IJwD60rNAS0gC gDL1+OJreNpd2UfIK9RTQ0aFsQYEIUKMdB2pAySgQtACUAFAFTUseTgybM9zTQ07FbQxsE6HGQ2c jvmkK9zVoASgAFABQAUALQAUAJQAUAFAC0AJQAUAFABQAtABQAUAJQAtACUALQAUAFABQAUAFABQ AlAC0AFABQAlAC0AJQAUALQAUAJQAUAFAC0AJQAtACUALQAlAC0AJQAUAFABQAtACdqAFoAKAEoA WgAoAKAEoAWgAoAO1ACUAFABQAtABQAUAJQAUAFAC0AFABQAUAFABQAUAFACUAFAC0AFABQAlAC0 AJQAtAAaACgAoAKACgAoAKAEoAWgAoASgAoAWgAoAO1ABQAUAJQAUAFABQAUAFABQAUAFABQAtAB QAlABQAUAFAC0AJQAUAFAC0AJQAUAJTAKQC0AFABQAUAFABQAUALQAlAC0AFABQAlAC0AFABQAUA FABQAdKACgAoAKACgAoAKACgAoAa7KilnIVQMkntQBRuNWtovMVSXdF3AL0P40+UDEi1qTVZ2t4C 6YHz9gD6Zp6LYLu4o+0W2VmmCKuQCGzuPoadxmtpV6JmaNpw7dlxytJok06kYUALQAUAFACUALQA UAJQAtACUALQAlAC0AFABQAUABoAKAEoAKAFoAKACgBKAFoASgBaAEoAWgBKAFoABQAUAFABQAUA JQAtABQAUAFABQAlABQAUALQAlAC0AJQAUABoA524C+Z8sfzeZz9KY7FvTPMe5MjLgAbf/rihjsW bYk6hcjYcZGGz7UhWL1AgoAKACgBaACgBKAFoASgAoAWgBKAFoASgAoAXpQAlABQAtACUAFAC0AJ QAUAFAEdznyH29ccYoBFDRfL/fGFQqluRnPPemwNOkAUAB6UAZukqQZGUYR2Jx6c0ymaVIkqQ5W8 mBIwcEUDJ/KAlZwBlgAT9KVtQvoNhJJdGiZNpwDnqPWhPoNkik4O8AEHtQhB5icfMOadhDsigAoA KADv7UAFABQAwyp6g84oAa06r2NA7EIu96B1Bweg9aYWA5k2ne6kHO0fyoGIiyMDlNo9Cc5oDQf9 mJJBPynse1IV0D2aSFjJzn9PpQFxg0+Mfe+bnP40BcQWIwQxyOgyTQO4v2Z1AxIQAMeuaAuVpbOX y/ld8EEMT1+oo1QKxQS7ubeeOFz5y/dVlYncfQ/Sq9RdSxKl0wB29eBzzmpBLUxmTZcvHKrnaM49 CKasL5G3bRST2agu+7bjC89fWhspWL0diojUNgsOpPei4tCZLaOMbVXjOaQEixov3VAoFcgbT7Vt xESqzHO5Rg5oHdkUemrFuMcrq7HLN60Bcc1kzYPm4YdwvWgLiCyIBBIIbk7eKAuho0/Z9wrjdnpS C477CckiTAJ5GKdw0IJLW7jRVilG0HJPfHoKdwshsUt0sB+8xXkYTHHvRe4WHLfSIUXa75PJIxt9 qdkBK+pxRnDMm7ONuec0KIWK9vqERuH2pluxXoRStYCeTU1Q4UBj6Kc80WCxTk1W5V4x9nfeScoo 6/jRoFhUS/vJCZN0UeeFB7fWm32C2hP/AGQGLGSQkN1HpSuGiHppg+6+1owflB7e9IdxV0mBd+0k bzlgO9AXKdxoAZ2aCQJuOcYoC6Yn2B4PLWVXfPLeX90H+lAddCqpvnlaNJbiIMerAnA9qq/UnlJJ 31K1U4mdlB4+XJI9Saaa6odjOvNZeFxud3QdeMnNHqSkOXXdQEIkEUmz0AGTSvEdmOh8SXjxuUik DZ6SpjFF4iUZFyx8RTSeYJY42ZT67aLDL6a5bmPewx2wDmjlCw5NYjKZZCD6ZpWFczdT1eaOWQXN vGLVEDgq25mPoR2ppDvYNL1mCG0MhjCB23bM8qKLdguzROtwlEaKNnDdxwBSatuBFJr8QaRY43JT 14z9KfKF0S2+tW0ziEkxyNwM+tDiBHevLb3KMQ59GB4x7igeho2U/wBogEnGehxSasInpAFABQAU AFABQAUAFABQAtABQAlAC0AFACUALQAlABQAUALQAUAFACUALQAUAFACUALQAdqACgAoASgBaACg BKACgBaAEoAKACgAoAWgBKACgAoAKAFoAKACgAoAKACgBKAFoAKAEoAKAFoAKACgBKAFoASgAoAK AFoAKAEoAKAFoASgBaACgBKAFoAKAEoAWgAoAKACgAoAKACgAoASgBe1ACUAFABQAUALQAlABQAU AFABQAtABQAlABQAtABQAlABQAUALQAlABQAUAFABQAUALQAlABQAUAFABQAUAFABQAtACUAFACU wCkAtABQAUAFABQAUAFAC0AFACUALQAlABQAtABQAUAFACUALQAUAFACUAFABQAtABQACgAoAz9a hlnszFDJsDHDH2oTsNHPQaJNcyyBGQwhcA7upquZodkjZTRjHCsccqqQMEhOtSF0MbSJANqrEwI5 yO9O4XJdJ0k2b+fPIGnIwdowMUriduhq0CFoAKAEoAWgBKAFoABQAlABQAtABQAlAC0AFABQAlAB QAUAFABQAtACUALQAUAFABQAlABQAtACUAFABQAtACUAFABQAUALQACgAoASgBaACgAoAKACgBKA CgAoAKAA8A0Ac2CjXzqY3XncMcim9htal7QpJJlkkc8FsBf7uKGBcgDG6lyc4PakHQtUCCgCtezm FUKqGJPTOKaGiwmdgzSExaACgAoAKAFoAQUALQAlABQAtACUAFABQAUAFABQAUAFABQAUALQBFcf 6iTnHynn0oQGfoBU2xK+vzcY5psZqUhBQAHoaAM7Sjtik2kbNx202Mtx3CueOnqOlILECttupGY4 HGKALW844GaLBYMuegoAY0Tt1f8ADFFwuM8lxJuyQMYx1FA9CMrOEIG1XLHHGR+NMBoM4yGXnA5z 3/woCwkjzo0ZVOrAMQ2cCgLA9zJ5jRpnjvRdBYav2vex3rsx8oPU0XQWJts/3cCgCRLcrjDfKO2O 9ILj1hUMW7mgVx3koMfKOKAuPwKBBQAUAFABQAUAFACMMgj1oA5jVrWaObfG2Hi+dVUcEHqad+47 G5pdwbq0SRguegI70SVmIoa4v2aVLgDiQ7CAOc+tCY0T6BMslu6qu0K1DEalIAoAKACgAoAKACgA oAKACgAoAY0SN1FAXIZLC2kUh4lIJz0oHcrW6RJfmFYlUBMjAp6D1LIsIMglBkHIpCuTrGifdUCk K47p0pgFABQAUAFABQAUAU9Winms2ituHbjOegoQ0YVzoxtrZpWEfmMANpPT3HvTQ9Dcsre3eBHE Cj5ccjJpWsJ6Ek+n2k6MskCEN14waQczRD/Y1h5AhFuoTOeOp/GnsFwOkWeQfL6dMGjULiNpFuzE gkAjGPSgL33M3VtGhSAkbm3kBsnAAp7hZMqeG9LSYT/aIiPLbCs3O7/PpRcS90220aHGEdlOcjPO Palew7ojGhwpv2OzB+zdvpQF0RLoSq7SIQHYYx2z60ajui5qcbm12r98rjIpoVrlPw5LMzXSTHIB Ur+VIRt0AFABQAtABQAlABQAUAFAC0AJ0oAWgAoASgAoAWgBKAFoAKAEoAWgAoAKACgAoAKAE6UA FABQAtABQAUAJQAtACUALQAUAJQAUAFABQAvSgAoAKAEoAKACgAoAKAFoAKAEoAWgBKACgAoAWgA oAKADpQAg56UAFABQAUALQAlAC0AJQAUAFABQAUALQAUAJQAUALQAUAFABQAUAFACUAFABQAtACU AFAC0AJQAUAFABQAUALQAh6UAFAC0AFACUALQAUAFACUAFAC0AJQAUAFAC0AFACUALQAlAC0AJQA UAFAC0AJQAUAFAC0AJQAtADaAFoASgBaACgAoAKACgA7UALQAlAC0AFABQAUAJQAUALQAlABQAUA LQAlABQAtACDpQAtABQAdKACgBkq7kIwD9aAMuA/Z7qNVwuc7hjk/jTQzWpCCgAoAKAFpAFABTAS gBaACgAoASgAoAKAFoAKACgAoAKAEoAKACgBaACgAoASgBaAEoAKACgAoAWgBKACgBaAEoAWgBKA FoAKAEoAKACgAoAKACgAoAKACgAoAKAAfyoAKAFoAa3Q0Ac48hOosNj7gMDHAYU+hW5PoxMd84O9 Q4wFPQYpvYRowbft021ueCRUh0LlAgoAztTmWKaIP0+8fU+1NDRfiOY1PrSEx1ABQAtABQAlABQA tACUALQAUAJQAUAFABQAUAFABQAUAFABQAUAR3B2wSH0U0AZPhpdsMxWVpEZyQD/AA+1Uxm1UiCg CO4fyoJJCpIVScCkBmaBNHcRu0aFEbkqT0NU9B3NFrZGXac7fQHFILkUcaidlLbsHODQMt4AoJCg AoAKACgBNoznFAXE2DsBQAbFByAKAFx6YoANygE5HFADGmRcdcH2osOwxblSxXacjrRYLEqsG6Gi wh1ABQAUAFABQAUAFABQBR1O2WaMsPvdDjuKY12Oe0u5bR7h45DPJFK/yrj5UHfFPfQWxs6zcxtZ rtZdzHgE0kgDw7EsVs6hduGxQ2ug2zWpCCgAoAKAI8urHOSp/SgZT1aTUhAF0uOMyNnLyHhPw70b dASRW0q81MW5GqxQiUHgxnqPUinfyG4lxL44RmhkCN3x0HuKLITRZSZHXcM4pWEOEiN0YccUWCw7 IoAKACgCnCCNQlGwbSoIOeaYy5SEGaAELBepAoAaZYx1cfnRYBGniX7zgUWHYhlv4Y88kkHGAOaL BYbcX6QHDKcnp707BYhm1MoF2RhgepzwKaSCwi6nIQP9GYdMgmloFiC/1ryIQse3z26AgkD3osL0 MfUdVuJIraGYbsn5pAvVuwx2qnZbBsbljq1oluqXEyRyLgMDwB/9ak4sV0aqsrqGUgqeQR3qRi0g CmAUAVb9VaAh+R6U0NGd4bIjWaEy7mDZx0oYM26QgoAKAMbxFMQiRIH3feBUdx0FNaAkP8Pb3ged k2byOP50MDWpAFABQAtABQAlAC0AFABQAUAJQAtABQAUAFABQAUAFAB0oAKACgAoAKACgAoAKACg BKAFoASgBaAEoAKAFoAKACgAoASgAoAWgAoASgAoADQAUAFABQAtABQAUAJQAtACUAFABQAUAFAC 0AJQAUAAoAU0AJQAUAFAC0AFABQAlAC0AJQAUALQAUAFACUAFABQAtABQAlAC0AJQAtACUALQACg AoASgAoAPpQAtACUAFAC0AJQAUALQAUAFABQAlAC0AFABQAlABQAUAFAC0AJQAUALQAUAAoAKAEo AKAFFACUAFAC0AJQAUAFACUAFAC0AFABQAUAFABQAUALQAlAB9KACgBaAEoAWgBKAFoASgBaACgA oAKACgBKAAcCgAoAWgBKAFoAKAMzVEZB5iBj3IBxQNDoNTi/s5ruSOSNE6qRzTtdiaKi+Io2nCrb StCeki4P5im0l1FqWxq9sGYTCSHAzl17UcvYZagu7e4RXhlVlboR3pOLQiXcvqKQx1ABQAUAFACd +lAC0AJQAtABQAUAFABQAUAFACUAFABQAtACUAFAC0AJQAUALQAlABQAtACUALQAUAAoAKAEoAKA CgBaAEoAWgBKACgAoAKACgAoAKAFoASgAoAKAEZQylT0IoA5C20n7JqUksN48qvIf3cjZCfSneXU ttGm9qf7ShmV2BGCVHSnfSwmasGwXEuwYOcmkIsUhBQBmatFvkifOAnJx1PtRsNF20njubaOWI5R hxQxMmoAKACgAoAKAFoASgBaACgAoASgAoAKACgAoAKACgAoAKACgApAQXrrHaSs+AoU5zTAzfDL q9tLtVk+fofT2pvQZs0hC0AMkQPGyHOGGDigDK0DQINDM4t5pnWUg7ZGzt+lF292PTojXoEZqXEM F9PvbGcHNPUZfSWNxuVgR60rCH5HrQAUAFADXkRMb2C54GT1oAaZ4wcZ5osOwyS5CR7tpx2oCxi3 etzfaWgjUJGP+Wo559KeiERxaw72oMkgQrJsOO49aduwFpNQjkhHlSK+3uPvfhRZjuTpfW7dSyt2 BosHMRyzWyW5Al2knOcdDQkFx1vcxSsrqzcDBIHGaNh37FuG5dolZkIJHIJ5FSKxYSVHzg9KAsPo EFABQAdKAI2mRcjk49BRYdio15M+fLj2gHv1xTHYZxFgM5y3VmOaB2MqbFx5odl3wsRhepp7K5L0 KyaVc3Mgad0iiDZVickj+lHN0Cx1NokcUQRXDNjk+vvUgT0CCgBGYKCT0FAFZ72MKSgZjjIGMUbA ivJPKFbndgBgoPJFMrYTzZAQX3JGw3bs9PYiiwCRGZI9nkYGcrnkkUaBqOgnhkEhmjETHgn+9QDd hkiiN1mjmfYvyiMngmhMCWOL7QPNAjO7rnqCOtAXJDaEOWzzjAx2ouK47yZN24u2B/D60XDQR45t h8tirHue1FwKVv5zXjAzFwsfXGOc0XHYvKkpUdd+MHsDQBHPbXLgCO4aLnkqAf50XC4Lp+JRK0jM wGMHpSuK442KuSX6egoC477FHgAAAKMDA5FAXJvJTBB5z1JoC437NDt2lMj3oC4qW8KKFSNQB0GK AuJNbo8ZXYP8aATM2PSI/PR3jOcHLE5PsKB3tsQ+I7aCO2i2kxszbBgcH6046Be5BJor/ZgUVHyP mGOSPakg0AxX1vbn7Os6LghUHOwev1quZCsRwXWqkItwsiO/TsOKOddg1LaX2oneBA74HJwBS0HY er38kYbbIpHb1ougsR363pR8oY1YZZge9F+wGfp0N0LiaGMkMMMOgOKNOhNrl15r+3Zi+4FiMtjO Pw9KfMh28yafU7mFNrRu+Tjeg4+tLQSRo6dPPPDunhMXpk8mk7dAsTvBG5yygkHOaBp2Hoqou1AA B2FAhaAFoASgBaACgBKAFoAKAEoAWgBKACgAoAKAFoAKAEoAWgBKACgAoAWgAoASgBaACgBKACgA oAKACgAoAKAFoAKACgAoASgAoAKAFoAO1ACUAGPagCKQ+UAS3U4FA0rjwCB1+b1NAhQCM80ALQAU AFAC0AMaREZVZgGc4UetAWHDigAoAKACgAoAKACgAoAKACgBaACgBKAFoASgAoAWgAoAKACgBKAC gBaAEoAOlABQAooAKAEoAKACgBaAE6UAFABQAUALQAlAAKAFNACUAFABQAtACUALQAUAFABQAUAF ACUALQAUAJQAUAFABQAtACUAFABQAUAFABQAUALQAlABQAUAFABQAUAJQAUALQAUAFABQAUAQ3cU ssYEFwYHBzuCg59uaWo1bqTduaYgoAKAFoASgBaACgAoAKAEoAWgAoAKACgAoAKAEoAWgAoAKACg BKAFoAr30Xm2zqBkjkUAjAiQTzmO4UmBxgqWPOKoo1I9GsVXMEfl5H8JqdhXKsmhyKxMVy756+Zz Tu+oJIrpp97FNuW3RiOm48U+YLkv2G4+79lG0tk4fFLmA27ZDHCqt1A9aQiWgBKACgAoAKAFoAKA CgAoAKAENAC0AFACUALQAlABQAUAFABQAUAFACigAoAKAEoAKACgAoAWgBKAFoAKACgAoAT6UAFA BQAUAFAC0AJQAUAAoAKACgAoAKACgDAu4We5/doP3bbsdOO9O42Jd6jZl42kbypFOAW4UfWqSfQL mvbEmeQEAEY6d6gGWaBBQBla0Lr939mi8wMQCPxpoa10L1nax2iOsWQrtu29lJ64pAyegQUAFABQ AUALQAlABQAtABQAUAFABQAlABQAUAFAB6e1ABQAUAFAEF/H5lnKmM5HSgEZ+hDEtxt5Ut1psbNe kIWgBKACgAoA5+ezuLie6U4XkGNvencqw6C0u4WIDM7bRgEfL+dDYiTkAPLHKqqCdvOc0XGOYybk nWORWx8wBzii4D1a5MkYjYjk7t4+9RdBYlEUmBtDnnGW7e4oAVLGZUbNyS56krx+VK4rosLaooA7 g5zQFyu+k2bOzCPYzHLbeMmgLjG0a2OeD0wPagLkI8PwAja7BR2HFCuguE2gQSog3FWQcMOtF2Fx yaHED+8mdlxjFAXLtnYwWUZSFcA8nJzmkFySWCOVcEfiKYXK/kyxIcsGPXPb8qBkYe5RQFO4j5ue Dj0poOVIFursgFkEYPRSMkfWh2CwrT3BZ8D5Nvy4HOaWgrCRpcyMrS4xyCM9KYFhIGZcSEgA9AaQ XJ9iqRhRj19KAK2qMyWhKYzkDnpTEcvpkS3lzexmYmZMOFj4A9QfWqYy/bp5TvDJI4WT7yhegx2N Tcdi7HaTICvmvJHnhs/NihsVkB/tFEdIlVnX7pc9aObyCw6K4u9peTudoVV6epouh2Y4tcFWKbmc cDjjH+NFwsWEtnIUyPnAHbmkK5YSJExhRwMA98UCHbR3AoAMD0oAjkgR12kYFAXIlso0UKgXAORl c4p3GTxRiJdq+uaQmPoAKACgDPtUH9ozsBtIXGM9fen0GaFIQUAFABQAUAFABQAUAGKACgDI8R20 c1vC8uf3Ugbg00PoaVowe3RgBgjtSEVtT1FLAJlC5Y9B1A9aaQFDTLzVryYPLBHHBuI5HOB3pXXQ LNbm7igAoAhvFDW0ildwI6ChAjE0WMQatKhB3eWBn1qgOhwO9SAYHoKACgAoAKACgBaAEoAKAFoA SgAoAWgBKAFoAKACgBKAFNACUALQAUAFABQAlAC9qACgAoAKACgA7UAJQAUAFAC/SgBKACgAoAKA CgAoAKAFoASgBaAEoAKAFoASgAoAKACgAoAKACgAoAhh81pZvOC7Vf8Ad8c4x/jSG7JaE1MQUALQ AlABQAUAFABQAtABQAlAC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAlAC0AFAAaACgAoAKAEoA KAFoASgBaAEoAKAFoAKACgAoAKAEoAWgBKAFoASgBaACgBKAFoASgBaACgBKACgAoAKAFoASgBaA EoAWgAoAKAEoAWgAoASgBRQA2gBaACgAoAKACgAoAKACgAoAKACgBaACgAoAKACgAoAKACgAoAKA DpQAUAFABQAUAFACUAFABQAUAY+sW5WVJxyB2PQU0xlnSLpZ4Cu8GRT8y+lDVgL9IQtACUALQAUA JQAtACUAFAC0AFACUALQAUAFABQAlABQAooAKACgBKACgBaAEoAKACgAoAWgAoASgAoAKAFFACUA Zes3F8lzp1vp4UedP++ZhnbGBk/nwKL26FJdTVoJEoAWgBoAUYUYFAC0AFABQAtACUAFABQAUAR3 FxHbRGSZgqigDPi120dhuDohOA5HH4+lOy6AagIIBB4pAFACMwRSzHCgZJ9KAOO1+/3KZ4JxsLYA B5I9q0tZgylosTX13ym+BMBhJySaiWug4nZWcTRXEoLLjjAA6D0obBl2kIKACgAoAKACgAoAKAFo ABQAUAFABQAlABQAdKAE3DdtyN3XFAC0AFABQAUAFABQAtACUAMn4hft8poBGJ4c3efcfMWXPBPW mwN6pAKYBQAUAFAFRFxcO23aS3bvTKLdIkMCgA+lABQAUAFABQAUAFAFWXUbSK5FvJMolP8ADnmn yvcC0CCAQeDSAKAKeoXAg25YqOScDOfamhk1o/mRbgcqeR9KTBk1AgIHcUAJtAOcCgBcDPSgAoAK ACgDM15yliVyPnOBkcZpoZj6EywXYeBUImb5yD2ofmBsapZecPNX7y+npSW9w0DTZZIz5Eikr2bP T2psGadIQcUAHSgAoAKACgAoAKACgAoAKACgAoAoWgP9pXZYDgKN2Kb2GX6QgoAKACgAoAKACgAo AKACgDL19lFvFGzxp5j7cvTSGi7YrstkXIIUYBHSkDJWjjZtzIpIGMkUhXHCmAUAFADJhmNgcjjq KARz9nJ9n1dY952kleepzVDbOjqRBQAUAFABQAUAFAC0AJQAtABQAlAC0AFABQAUAJQAUALQAlAC 0AFACUALQAlAC0AFABQAUAFACUALQAUAFACUAFABQAUAFABQAUALQAlABQAtABQAUAJQAUAFABQA UAFABQAUAFABQAtABQAUAJQAUALQAUAJQAUALQAlAC0AFABQAUAJQAtABQAUAFABQAlAC0AFAAaA EoAWgAoAKAEoAKACgBaAEoAWgAoASgAoAWgAoASgAoAWgAoAO1ACUAFAC0AFABQAUABoAKAA0AJQ AtAAaAEoAKACgAoAWgBKACgBaACgBKACgAoAKACgAoAKAEpgFIBaACgAoAKACgAoAKACgBaAEoAW gAoAKACgBKACgBaAEoAKACgBaAAUAJQAtACUALQAUAJQAtACUAMmjWaNo26EYoBaHOyzf2dfojKy JnaHx1+vtVIZvWd3DdoxhfOw7WHoanYRYoAKACgAoADQAUAJQAtACUALQAUAFABQAUAHegAoAKAD pQAlABQAUAFAC0AJQAtACUALQAlABQAHjoKAFoASgAoAKAI2jY3CSA/KFII+uP8ACgY/Pz42npnP agQtAC0AFACMwUZYgD1NABQAUAFAC0AFABQAlAFe9s47yLy5VBHoelCGnY5q9sPsP7sMVG4YJ5yP SqTYGlp94LSNEk5iZtuc/dP+FFhGoby2UkGdAQM4zS5WK5j6vrNrNZyRW8rnP8SCnyjTOUadLqdb eACR0fKs3GM03oCZ12m2kNsqQwooy2XIP8VTYu5qxALcP6mkS9iegQUAFABQAtABQAlABQAtABQA UAFABQAlABQAUAG0A5xz60AFAC9qAEoAKACgAoAKACkAjfdNMDl9MfGvOqK6xrnIx0PpVDsaR1uP 7XJAi7vLPzEdhRyiNKC4imRWRgdwyMGpsBKSFBPpQBBb3Uc8auvAPY9qdh2J6Qijbu730ylfkXGD 70xsvUhBQAUAFABQAUAFABQAUAY+s6eJCJ0TMi87gOaBodo17KyLBchvM9SMU3boDRrUhGPr0m0D L4QDkAc5qkMtaNIHsk29PTHSpYi9QAtACUAFABQAtACUAMmjWWMo6hh6EUAcvJZ+TIJrdvLWSU70 2/db29qauU7GzZx3Ez+ZLIrQdU9aGIhvo/s5wsTkOeqnGwUaDuW9LuhPGyc7ojt5PJoZJdpAFABj tQAYoAKACgAoAKACgAHFABQAUAUrZP8AiZXT84wo5NAy7QIKACgAoAKACgAoAKACgAoAxfFDOLaG ONFYvJySM7R6007AalkoS1iGMfKMjGKQE1ABQAUAFACMBtIPSgDkryFW1GO4aN98LZTBwTzTQHXD kZpAFABQAUAFABQAUAFABQAUALQAUAFABQAlAC0AFABQAlABQAtABQAUAJQAtABQAUAJQAtABQAl AC0AJQAUALQAdqAEoAWgAoASgAoAWgANACUAFAC0AJQAtABQAUAFACUAFABQAUAFABQAUALQAGgB KACgAoAWgBKACgBaACgBKAFoAKACgAoASgAoAXtQAUAFABQAlAC0AFABQAUAFABQAUAFABQAUAFA CUALQAUAFACUAGKACgBaACgAoASgBaACgBKACgBaACgAoAKACgBKAFoASgBaACgAoASgAoAKAFoA SgAoAWgBKACgBaAEoAKACgBKACgBaACgAoAKACgAoAKACgBaACgAoAKAAUAJQAooAKACgAoAKACg AoASgBaACgAoAKACgAoAKAEoAWgCte2UN4qiXIKnIZTg0J2GnYLOygslYW8YUucse7H1NArlmgAo AKACgAoASgAoAKAFoASgBaACgBKAFoAKAA0AJQAtACUALQAlABQAUAFABQAtABQAUAJQAUALQAlA BQAUAFABQAtABQAUAJj16UAFABQApoASgBaACgAoASgCKe3juF2yoD6e1A07GHNoTpcmaJi3B43Y H5UJsNNzMZD5jmQFZFOF3EdPSrDbQq7Qt80ccoQlCX4+6KSS2DqHh/R2toVluLaSCSeRsLIwLHHR jj1qU1vFgk1ozp9KXMoUIoRASdp/i9TTA0IuLmTHT696QdCegQjMqKWYhVUZJPagCvb3sM1uJt6q pOOWFNxAsggjIOR7UgCgAoAKACgAoAKACgAoAWgAoAKACgAoASgAoAUUAJQAUAFABQAUABzg469q AOMiububXkUNhVnMciocbv8A6wqr2Gamo6JJky2bFmz90tjA9Af8aV2g0M8G4sH3CFx/C4PehNBY tS6jcNaNn92mMbyCKd10Bljw+PNQsFKpwxyc80SDobtSIzLYhdTlOWy3BB7Uxs06QgoAKACgAoAK ACgAoAKAEYBgVoAw7uOYSmNcpk/ez2pjZo2N0Zi0cqhWXpz96hiMnX5issmPu7AOlMfQ1NG/48U+ TaehqRF6gAoAKAFoASgAoAKACgDO1SxSZTJ82eOh6e9CKRSsp/7NO2STfFI+FYnP/wCqnqxM0byS OS3ZklAKjNFgRS0AsZJSx69RQwNqpEFMAoAKACgAoAKACgBaACgBKAFoAq26YuZ29SMUDZZoEFAB QAUAFABQAtABQBHMZBG3khS/bd0pDVuosSssaq7bmA5OOppg7X0MvxDuMEShTgty392mgRpW277P Hu67RmkDJKBBQAUALQAlAHLaxC/251RzGo+diO9MDpoDmGM/7IpAPoAKACgAoAKAFoAKAEFAC0AJ QAtABQAUAJQAUALQAh4oABQAUALQAlAC0AJQAtABQAUAFABQAUAJQAUAFAC0AJ3oAKAFoASgAoAW gAoASgBaAEoAKAFoAKAD6UAJQAtABQAlACigAoAKACgBKAFoASgAoAUUAJQAtABQAUAJQAtAAKAE oAKACgAoAWgAoAKAEoAKACgBaACgAoAKAEoAWgAoASgAoAWgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKACgAoAKACgAoAKACgBKAFoAKAA0AJQAtABQAUAFACUALQAlAC0AJQAUAFABQAtACU AFABQAUAFABQAUAFABQAUAFABQAUAFAC0AJQAtABQAUAFAAaACgANACUAFABQAUAHFAC0AFACUAF ABQAUALQAUAFABQAlAC0AFAFWyvVvGuAkM8fkSmImVNocjuvqPelddAaa3LNMAoAWgAoAKACgAoA KACgAoAKACgBKACgAoAKACgAoAWgAoAKACgAoASgAoAKACgA6D6UAUn1S3SVUJPzdD2p8o7EqXtu 3SQdM8+lFmTcd9qg258wUWHYBdwFS3mLtHfNFgEe8hT/AJaL7c0WAFu4G+7KhPpuFHKwFNwoGRgn OMA0WGkRR38LjIYZ7jPIotYQ2TUoEI2/OM4JXHy/WnygB1O237I5FY98HpS5bAhTfxhSzSIoFFh2 sQf2tEbw24ZcYyH7E+lPl0FoOe/JiVlIJY4GD1x6Uh2IlvxuC72POGyOhoCxDLfO8ixrIV+bHSmH oc9qtxNJJtjmj35wisvUj1NPYLGzo2k5YTzq20j5t+Msf8KjqHQv6uCJEwnAU4IPOfT6UIEGgKvk M4ABJwcd6cgLsP8Ax8yY7Ug6FigRDeW6XdpNbSZ2SoUbHoRigDgD4Q1m2SG288XFtE42kNhjz1P4 U/aND5Ud7Y2/2W2WLjjnik3cGWaBCUALQAlAFdbVlvGuPtExDDHlEjYPcCjUenYsUCCgAoAWgAoA KACgAoAKADpQAlABQAUAFABQAUAFAGdBpYi1Ka7aTcGO5E242nHNIDRpgV792hs5po4fOkjQssY6 sQOlAHDN4m1C/tmglthaykcpKmM//qqvd6CtJbnVeGXlex/fKA3qKTt0Ga9SBn23zajOS+cYGCOl MZoUCCgA46UAFABQAtACUALQAlABQBWu7UTsrDhl70bAcpfpJpcjTs9xIfMztRdxHvV83cduwy9v kvNywtI0shA24xjNFlYR1+nw/Z7KGL+6gH1qGBYoAWgAoASgBaAEoAKAFoASgCnc2W8Ns288hWHA NA7mT/wj87zjfcDyepAHOfb2puT6CSSNy2tktowqDnue5pATUAFABQAtACUALQAlABQAtACUALQA lAEMRzPIMMCOPY0DJqBC0AJQAtABQAUAJQAtABQAlAGT4i3eTBsOCsgb8B60IDUibdGrYxkdKAHU AFABQAUAFAHN+JYoopDMw+Z0I4PJ9qaGbWlEtptsSrKfLHDdelJiLVAC0ABoASgAoAKAFoAKACgA oASgBaAEoAKAF7UAFABQAUAFABQAlAC0AFABQAUAFACUAFAC0AFACUALQAUAFABQAlABQAv0oASg BaACgAoAKACgBKACgAoAWgAoASgAoAWgBKACgBaACgAoADQAlABQAUAFAC0AFABQAUAJQAUALQAU AJjmgAoAKACgBaAEoAWgAoAKAEoAWgBKAFoASgBaAEoAKACgAoAWgBKAF6UAFABQAUAFABQAUAFA BQAUAJQAtABQAUAJQApoASgBaACgAoAKACgBKAFoAKACgAoASgAoAWgAoASgAoAKACgAoAKACgBK AFoAKACgAoAKACgAoAD04oAKAFoASgBaACgBKAFoASgBaACgAoAKADpQAlAC0AFACUALQA0KqsWA AJ6n1oC46gAoAKAEoAWgBAQehBx6UAFABQAE7Rk0AH0oAWgBKACgBaACgAoAKAEoAKACgBaACgAo ASgAoAKACgAoAKACgAoAKAFoAKACgBKAFoASgAoAWgBKQEdwxVOASc0wRmvpMVxJlmbap4HpTu0U MOjtGp8llJxjHQfWi7FoJ/ZFwSJPPVZdm0nGaFIBq6TeMEWW5RY1PIVPvUX8hk40ddzEyAf3cKOK LhdId/Y6blbzeQMH5RzSTC5JFpqxSErK+zoE7CgVyM6OmWIfBbknb3oQXBNFgQH5myfvEd6B3Jf7 LtfKMartz1I6mktNg5h4063DBtpJAx1piuNOlWm3b5ZAznrSDmHf2baby/kjJGKYXJDZwMQzRgkc AmgLmLrjASiDycRdeP4zTWgGZ4fsXutTeW4UbQuT7+1JgtEdmoCgBRgDoKBGTrX/ACzZXx823bjr TQybQxi0Yc5DkGhgyeABbqUfxE5/CkHQtUCCgAoAKAFoASgAoAWgBKAFoAKAEoAWgAoAKACgBKAF oASgAoAWgBKACgAoAKACgAoAKACgDO1q2t2sLiSSGNmCE5Yf1oQ7kXhrb/Z+6MYRmyOc5GKbEa1I DLsYhFqdyQTiTkZ9e9AzUoEFABgZzjmgBaAEoAKACgAoAKACgBssiQoXkYKo7mgDmtW1QTO32OIk gFWkzjIqtg1KGn2Ls3nSruVv9nb+tCdti9jYj1CW13rHHJPGp64xsHpS06kM2reUTQrIBgMM4pAS 0AFABQAUAFACUALQAlAFe8u4rOMPNnBOAAKaV2BVi1q2eZYiGRycYbt70+XS4GkKkAoAKAFNACUA FABQAUAFAC0AJQAUAFAFWH/j+mO7oANuelMZapCCgBaAEoAWgBKACgAoAKACgDP1g4jXsDkdM/pQ A57+3toMZBaMAFB1GaaiDKN3rciFfs6Jz2bk/pT0CzI01q7MrH7I7RjAAQZo93oOzIF13UBvP2ZT z8v+FCsDRYh16TK+bC2DwcD7ppaCSfUR9ecYZU+U8fcOc07IdjO1XVpLiWEJbSvtDFiqcf8A66Xu 9WCT7HT6WCNPt8gglAcHtSYmWqAF7UAFABQAdKAEoAWgAoAKACgBKACgBaACgAoAKAEoAWgBKAF6 UAFACUALQAUAFAAKACgAoAKACgBPpQAUALQAUAFABQAUAFABQAUAFABQAUAFABQAGgBKAFoAKACg BKACgAOOlAC0AFABQAUAFABQAUAJQAtABQAUAJQAtABQAlAC0AFACUALQAUAFABQAlAC0AJQAtAB QAlAC0AJQAtABQAlABQAUAKKACgAoAKACgAoAKAEoAUUAJ0oAWgAoASgBaACgAoAKACgAoASgAoA KAFoAKAEoAUUAJQAUAFAC0AFACUAFABQAUAFABQAtABQAlABQAlAC0AFABQAUAFABQAUAFABQAUA FAC0AJQAUALQAUAFABQAUABoAKACgAoABQAUAJQAUALQAUAFABQAUARpFHG7uihWf72O9A229Cq+ rWEdy1s91GJlxlc9Krkdrk3RaWWNsbXU9+tTYBJiPL6/lQUiraXGxdsxCDqoJ6CnYT0HTapZwoWe YYHpzRysNhtlqsF5O8MSuCozlhwfpQ0GpepALQAGgAoASgAoAWgBKACgBaACgAoAKACgBKACgAoA WgAoAKAEoAWgAoASgBaACgBKAFoAKAK8syrIV5+UfNx0pjQ63RVVin8TE0mDJaQgpgFABQAUAFAB QAtACUAFAC0AJQAUAZWr2ElydyLvGPu5xii76DRPo9mbK0COF3nk4HT2ouDZeoEZF7vkn4XBQEhh 2oKJNALNayM235nz8tNiZejGJGPvQDJaQgoAKACgBaAEoAWgAoASgBaAEoAKAFoABQAUAFABQAUA FABQAGgAoAKAEoAKACgBaACgBKAM/wAQHGj3OAPu9x701uBX8MR+XYthQo3dB9KJAbFIDPsdn2y4 CsrOGy3tmmxt6GhSELQAlABQAUAFABQAUAFABQBWvrQXaojMVUHJx3ouBWtNFs7RtyR7m9zRqO/Y 0GjRk2Mi7fTFArkIsoBIz7TluozwaB3LAAUYAwB6UCCgAoAWgAoASgAoAWgBKAKepadFqMYSZnAH TacUegaGW2lC0gy2HdT8sjHnHvTu+o9ti/pU8gH2e4bMgGV55IoYmaNIAoAKACgBaAEoAKACgAoA KACgBaAKsODdynCbhgZHX8aBlmgQUALQAlAC0AJQAUAFABQAUAZeuFdsIL7W38HmmhospZ28h8x0 DMecnvSC5OsMSABY1AHtQK4/av8AdFADfKjznYPyoHdiGCI5+Qc+1AXY37Jb/wDPJfyoC7HLBEgw saj8KLhdkg46UCCgBaACgAoAKACgANABQAlABQAUALQAUAFABQAlAC0AFACUAFAC0AFABQAUAFAB QAUAFABQAUAJQAtABQAUAFACUALQAUAJQAtABQACgAoAKACgAoAKACgBKACgBaAD6UAFABQAlAC0 AJQAtACUAFAC0AJQAtABQAUAJQAUAGKACgBaACgAoASgAoAWgAoAKACgAoATpQAtABQAUAJQAtAC UALQAUAFABQAlAAKAFoASgBe1ABQAdKACgAoASgAoAWgAoAKACgAoAKAEoAKAFoADQAUAFACUALQ AUAFACUAFAC0AJQAUAFABQAUALQAlABQAUAFABQAUAFABQAUAFABQAUAFAC0AFABQAlAC0AFABQA lAC0AFABQAUAFABQAlAC0AFACUAFAC0AFABQAlADJ4vOheIkgMMZFAI5hfCYtZXlgZZmcknzfem9 dy01Yjt9E1CGVi/zHH3g3WjnYrIaumaoTKrQlE/gO/JX3p8zFyruZ62txBcsbhmYJyVc8lqak2gt Y3bHSBdxb2nZRnDKq9D9al3DQ19P02209CIE5J5Y9TSBsu0CEoAKACgBaAEoAKAFoAKADtQAUAFA BQAUAJQAUALQAUAFABQAUAFACUAFABQAdKAFoAKAEoAqMoSZyMhRyRnqaY0WYxhFHtSEOoAKACgA oAKACgBaAEoAKACgAoAWgBKACgAoAKAMG+LJOwyVhL4JHX6Ux2LWgFfs8uwAKJDihiZfiYGVx6Gk NktAgoAa7hOtADh0zQAUAFAC0AFACUALQAUAJQAtABQAUAFABQAlABQAUALQAUAFABQAdqAEoAKA CgAoAqaoQLGXJwNtNDRHoqhdPTaMA84xQwL9IRl6ShS8vied0mc5/Smxs1KQgoAKAFoAKACgBKAF oAKAEoAKQBTAKACgAoAKAFoADQAh4FAHOXHigR3XlJbErsZwSeuKtRXcWpPD4kt3gSUxtgj5gvJB 9PelyjLw1a0yoL4LdBSsA77XCJctMo45GelOwyVLy3csFlU7eDzSsIbM8E8JUurKeODSsNOxkwny bxZEkVgrbME8gUw0N+kIKACgBaAEoAKACgBaAEoAKACgBRQBUg2m9nIAzgA4oGW6BCYoAKACgAoA KAFoASgAoAKAMnXyoWEFgvPf0poDSthtgTpnHY0gJKACgAoAKAFoASgBaACgAoAKACgAoASgBaAC gAoASgBaAEoAWgAoAKAEoAUUAFABQAlABQAtABQAUAFABQAGgAFABQAUAFABQAUAJQAUALQAUAFA CUALQAUAJQAUALQAUAFABQAUAFABQAUAJQAtACUALQAUAFABQAUAJQAnXpQAtABQAtABQAlABQAt ABQAlABQAUAFABQAtABQAUAFABQAnFAC0AFABQAlAC0AFABQAlABQAUALQAUAFACUALQAUAFABQA lABQAtABQAlAC0AFABQAlAC9KACgAoAKACgAoAKACgAoASgAoAKACgBaACgBKACgBaACgBKACgAo ASgBaACgAoAKACgAoAKACgAoAKAFoASgBaACgAoAKACgBKAFoAKACgAoAKAEoAWgAoASgBaACgBK AFoAQUALQAlAGRf+IbO0YRq3mSZxtB5quUPIryeJoYlO6MGReq56e+afKBm6nqVveTbHzAGQlmxy eO1FrbBcm0/W4NNsIreEmc84ZsjP6cmizk9QLP8Abtw8i4EES7csHzkUrIS7D7DxNDPceRMuOceY AQv60NAb9SMKACgBaACgAoASgBaACgBKACgBaACgAoAKACgBKACgAoAWgBKACgBaACgAoAKACgAo Ao3KkOGHChhn3plIujgUiRaACgAoASgAoAKACgAoAKACgA/GgAoAKAD3oAKACgDJ1W3Uzo5DMpBy o6ZprYaINGure3P2dd2+V8gZzTaEzXjYGZwAOOM1I3sTUCCgCpeDEsZH/wBegpFsdBQSFAC0AFAC UAL0oASgAoAWgBKACgBaAEoAWgAoASgAoAWgBKACgAoAWgAoASgAoAXtQBleJJjBpUjjjkA/TNNA L4fl87T1fPWhgaLjOAaECM/Tm/4mF4ozgEduKBmlUiCmAtABQAlABQAUAFAC0AFABQAlAC0AJQAU AFABQAtACHkYoAzV0SxU7jDvbnk9eaCuYQ6LbKWMICA9gOlArlV/D6m7EyyLhfugihN7BoVptFkh WUm4IDnI54ou2NJMq7Tzk/OeoHXAqibIayk5XzAFb+IccUaoCGRZo3Z1nVSeAB2/+vRqKx2Ni26z hJOcqOakZP8ASgAoAWgAoAKAEoAWgBKAFNABQAUAV4EQTSsowWPNAyxQIKAEoAKACgBaAEoAWgBK ACgDn/EyCa5sYyqt85YA9ePSqi7Ab0f+rXtxUgOoAKACgAoAWgBKACgAoAKACgBaAEoAWgBKAFoA SgBaACgAoABQAlAC0AFACUALQAUAJQAUALQAUAFABQAlABQAtACUALQAUAFABQAUAJQAtABQAUAF ABQAlACigBKAFoAKACgAoASgAoAWgAoAKACgBKAFoAKACgBKAFoATvQAUAFABQAUAFABQAUALQAU AJQAtABQAUAFABQAUAFABQAUAJQADgUAFABQAtABQAUAFACUAFAAc9qACgBaACgBKAFoAKACgAoA KACgBKACgBaACgAoAKACgAoAKACgAoAKACgAoAKAEoAWgAoASgAoAKACgAoAWgBKACgBaAEoAKAC gAoAKACgAoAKACgAoAKACgAoAKAFoAKACgAoAKAEoACASPagBaAEoAWgAoAKACgAoAKACgAoADQA UAFABQAUANkXfGy5K5GMjqKAOVv9OeAySNF5hjAHmSfxD/Gmh6dC5YW2n6hCEePEgHQ9/cUmh3sX JdGgYFjnd0Bx0pWC5GuhQqQQ7DA9uad2LQjg8OW8EpkjdiTnO4A0teo7oltdAtYZRLJmVwc89M07 iv2NagQUAFAC0AJQAtACUAFAFe7vrazQtcTImPU801FsDIfxGr7vIiZVA+8/GTT5UFjKk8U3QJyg UA44FVaImmP/ALfvPtK4fKhfu7MljSdgs+5JN4huoFQoiAYywfNLQLMsQ+JS0QkaNdpOM5xj8KfK mOxJda8oiCrMIpzggYyvXuaLWFfsbGnXX2u0SU4DdGx0zUsZZpALQAUAFACUAFAC0AJQAUAFABQA UAZ1w2+58hwQMggqcUyjRpEhQAtABQAUAJQAtACUAFABQAUAFAC0AFACUAFABQBV1BA0AzIYwDk4 OMj0poaM7Slje6M6IEXkKB6fWhqwGlbnM0hKkfNgH1oBljIHU0hCkgd6AKt4FZ4xzuByCDQNFoHi gQUAGR6igA4FABQAUAGRmgBaACgBKAFoASgAoAKAFoASgAoAKACgAoAKACgAoAOKAD8aADPvQBna 9DNc6XKloA0nBA9cGk0CKPhC2vbW2uI75GU+Z8hPcYp3uO1jbnYRxl/ShCRnaVIzSPKUOZT8xHIB FNjNWkIKACgAoAbKXWNjEgdwPlUnAJ+tACpu2KXADY5AOcGgB1ABQAlAC0AJQAUAFABQAUAFABQA UAFABQAUAFAAQCMGgCpNp0ErMxXDEYyKB3K39i24J2EqD1FFwvYemj24H7ws/wBTQFzQRQihUACg YApCFpgFABQAtACUAFABQAtABQAlABQBDEFE8mOp5PNAyagQUAL0oASgAoAKACgAoAKACgDI1pVN 3Ysxwqsc8ZpoaNZPuikxC0AFABQAUAFABQAUAKKACgBKAFoASgAoAWgAoASgAx3oAWgBKAFFABQA lAC0AFABQAUAFAAKACgAoAKAEoAKAFoASgAoAWgBKAFoAKACgBKAFoAKAEAxQAooAKAEoAWgAoAS gBaAEoAKACgAoAWgAoAKACgAoASgAoAWgBKACgAoAWgAoASgAoAWgAoASgAoAWgAoAKACgAoAOlA BQAUAFABQAUAFABQAlAC0AFACUAFABQAUAFAC0AJQAtACUAFABQAUALQAUAJQAtABQAlAC0AFABQ AUAFAAaAEoAWgAoAKACgAoAKAEoAKACgBaAEoAMA9e1ABQAUALQAUAJQAtACUAFACUALQAUAFABQ AUAFABQAUAFABQAtABQAlABQAtABQA0soYKSAT0HrRYB1ABQAlAC0AFABQAlAC0AFAB0oAKAEoAW gAoASgBaAEoAiuoFuIijZ/CgEzBeKS0vVmjG1FXATrtNUtimb8EyzRhkPapJJaACgBKAFoASgAoA KACgBaAEOByaAMXXNSkt8R2zDJXPHXPaqVuoGDZaXd30vnPvk9fN4H/16TY7WOlTRoOPNJb1UcA0 guWl06zQALbRYH+zSsg5mRtpVkzBvIVSBjK8UW1uF2NbSLMweSEwuMeuKYXIm0SD5tjsM9iARSC5 zGsWxtySt1CB5ojX5QSDnqar5COm8OpLHZsspUkN1XofehgzVpAFAC0AAoAKACgBKAFoASgBqOWd 1KMoXoT0P0oHYfQITtQBnjEl0nLB42xkjgj2pjNCkIWgBKACgAoAWgAoASgBaAA0AJQAUAFABQAU AFABQBz2v/bWl2o7xw9PlTP45p3Q7GfY/IkStcvGxbHA65/lVNgzUjW4a7kSN22oeFzU3Vh6lqRL tEzHjJxlcZxQAsgusMFYKPUrk0gKZlmklUMwDLxgetO4EyR3pAIl+c/wkcfWi6GNdNSeNlHl5HQ8 g0X8hWI2S+SPBkRJNvBYkgmnddQsSQG9eA/6REX2ghgucfhRfyAsEzowyCVakAhjlEgG6QpnO5T+ houFkROl0VB3uM5yQPmA9KLhZCtJKhRYpXbB+bjk/wD1qAFeG9YMnnsD1BC/pQKxVSHUooZFEhGM AEjJz7UJhyoVIL6JiTdykqPmBXOfpTcvIfKEC3dwMpcToAdwLrz9Kdx2IxHqVrHJtmml3njPb3Hp RzIVkTB73y3cM7Oy7VBU4HvSugsQyNdOiJmRlxkuMjDfhRzdgtYjZNXSbcZm+z4AXqSaOfyFypLc dEt+Y5GhuH452spH86d/ISQ+Oe4aApM0q7Bksy4z9KV09h8o6Nb6ZWjNx5ZzgkDkDtRoCVtiLdq0 Th2k3hRtEe08+5o5vILMC9+hBJfeTjYAdo9waOYdmROb9VALzBmJAcKSCPWjnt0CzQq3Nz5iqlwD sUAhlPPrTbt0FuAluXlVfMLI+RncRmi9heRLK9yLYbRnsck54qeYdtCHbMZEmUyRH/nm5JBajm7A oiiXUkZ3EflnO4xgnAHrmnfTYLEVxLdM0cjyttJIDK/r/KndhyjbKLUftmftDywq33WclSKTkwUb 6nQ6TCkKSCMKFZs4XoKkGX6BBQAUALQAUAFABQAlAC0AFABQAlABQAUALQAUAFABQAUAJQAUAFAB QAUAFABQAUALQAlABQAUALQAUAFACUALQAUAFAFeEnz5F7D2oGyxQIBQAlABQAtABQAlABQAUAFA GXq8Ur3Nm0ThQjHfuGRgigaRprwooELQAUALQAlABQAUAFABQAtACUALQAUAFABQAlAC0AFACUAF ABQAUALQAlAC0AFACUALQAUAAoAKACgAoAKACgAoAKACgAoAKACgAoASgBaACgAoAKAEoAWgBKAC gBaACgBKAFoASgBaACgAoASgBaAEoAWgAoAKACgAoAKACgAoAKACgBKACgBaACgBKAFoASgBaACg AoASgAoAWgBKACgBaACgBKAFoASgBaAEoAWgBksscMZeZ1RB1ZjgChK+iAdQAUAFAC0AJQAtABQA UAJQAtABQAlAC0AFABQACgAoAKACgBKACgBaAEoAWgAoAKAEoAWgBKAFoASgAoAWgAoAKACgBKAC gAoAWgA6UANoAWgAoAKADIBxnrQAUAFABQAUAFABQAtABQAUAHSgBKAFoAQqCQSBkdDSsAtMAoAK ACgAoAKAIk87zm3hBF/Dg80utrBYlpgFABQAlABQAtABQAUAJQAUAFAGdq1uuzz84C/fHqKaGjmt O1e8gklkaNBAH2bgenpmrbTE0zbttcLNskiyF+86HipaSEXE1W3Jw2V6frS5RvQtC5g2k+YoA65P SlYB0U0cwzE6sPUGhqwD6ACgBaACgBKAM/Wb1rSAeVsMhYDDHAx3ppAYlnam+uiwIORh2HO32pvQ aOpijWKNY0GFUYAqRBKHMTCJgjkfKxGcGkNW6lXT1vo49l+8UpHR0GM/UUJsqfK/hLlMgKACgDKv dBtbyQs2UBIJCjqfWkO5pQQpBGI4xhRTESUAJQAUALQAUAJQAvSgBKACgAoAWgBDQBmiSX+0FTZt iJ4OR6UDNKgQtACUAFABQAUALQAnSgBaAEoAKACgAoAKACgAoAKAGTY8tt2MY79KARzUkUZiljRg HWTKkc/5FXqimb9n93kYfuM5qWDLNIkKAKF/GrSxbQPMzkE9KLFIvDoKCRaAAjPBFACBV7KAaQXF wKYBQAUAJsXdu2jPTOKVguLQAUwCgAoAKADA9KAAADoKACgAwPSgBCAeoFABgelAC4HpQAfhQAY9 qAE2Ln7o/KlZBcNi/wB0flRYLhtX0FMAx7UAG0dcCgBGijbIZFOfUUh3EWNI1wiqoHYCmK5S0cho 5GGfmcnkYpsZo0hBQAlAC0AJQAtABQAUAIeKAD6UALQAUAFABQAlABQAUALQAUAFACUAR3EwghaQ 9ug9aAMSS51G4M6ony442noKrQdhLW6u7Ld57l0/2u59qE+YErbmtaX0VwmR8rdCD60mrCsWqQBQ AUAL2oASgAoAKACgBaAEoAWgBKAFoAqxAC9l5bO0HHagb2LNAgoAKAFoASgAoAKACgBaACgChqLx rLEjuUL8D3oHsW4STGpbGfagQ+gBaAEoAKACgBaACgBKAFoASgAoAWgBD0460AFABQAtAAaAEoAK AFNABQAUAJQAtABQAUAJQAtACUAFAC0AFABQAGgAFABQAUAJQAUALQAUAFABQAlABQAUALQAdKAD tQAlAC0AFABQAGgBKACgBaACgAoASgANABQAtABQAUAFABQAUAFACUALQAUAFABQAlAC0AJQAtAB QAUAFABQAlABQAUALQAlAC0AFABQAUAFABQAlAEc8EVzEYp41kjJBKsMg4ORSavowTtqiSmAUALQ AUAJQAtABQAlAC0AFABQAUAJQAtABQAUAFABQAlAC9KAEoAWgAoAKACgBKACgBaAEoAKACgBe1AC UAFAC0AJQAUALQAUAFACUAFABQAUAFABgZzQAUAFABQAUAFAC0AFABQAlAC0AFABQAlAC0AFABQA UAFABQAlAC0AFABQAUAFABQAUAFACUAFABQAEAjBGRQBha1Y7QJIV+83Ix8v400Mr6PYxSLKgYLM uRx796HcAOj3dukcUSpKN26SQ9SaL9Q0toRy6TqMzbFCrGOCGbIajnYWNnSdOaxT95JucjGB0FFw djRpCCgANACUAI7BELMcKoyTQBymoTG9LyZaSInKrnGB2qulhq50GlWcVpbL5SkFwCxY81Ii5QAt AEcsixqWPYZwKAGwTxzpvjbIoAloAKAFoAKACgBKACgAoAWgAoAiNxCs625lQTMpZUzyQO+KLASU ALQAlAC0AJQBlyENcxyBMBJAN3rTK17GpSJCgBaACgBKAFFABQAUAFACUAFABQAUAFABQAUAFAAe mKAOb1BzbyS7wFPUcYBBpobNbSx/o4OCD3zQwL1IQUAU7kj7QgYEjPGD/OgpFwdKCQoAKACgAoAK ACgBGO0dM80ALQAUAFABQAtAAaAEoAKACgAoAKACgAoAKACgAoAKACgAoAWgBD0oAoaazl5t+Qd3 3ccCmNl+kIWgBKAFoASgBsjFELBS2Ow60AkKjBlDDOD6jFANWHUAUr2Z0AUFAM85/limMmsihtka NdqtzgjpSYiagAoAMj1FABQBXuLyG2kRJmC7+lNJsCx1HFIAoAWgAoAO1ABQBU1Rc2UnTAGTxkj6 e9CBGRo03lXbIxwGxj+lV0Gbk9vHMpDKPrUhcx57Dy5EiDlRgsTjjPrTuO1yxpuo71jSQHBJVWP9 aBGrSEFABQAooAKAEoAKACgBaACgAoAKAKkJIvZkPZQR+OaYy1SEFAC0AJQAtACUAFABQAvSgBKA MvWJHSaARqu7rk9ce1NDRpRf6teMcdKQmPoASgBaAGsWGNoB55yegoAdQAlAC0AFABQAlAC0AJQA UAFAC0AFAB3oAKACgAoAKAEoAKACgBaACgAoAKACgAoADQAlAC0AJQAtACUALQAUAJQAtACUAL2o ASgBelABQAlAC0AJQAtACUALQAUAFACUAFABQAtACUAFAC9KAEoAWgAoASgBaAEoAKAFoASgAoAK AFoAKACgAoASgAoAWgBKACgBaACgBKACgBaACgBKACgAoAWgBKACgAoAWgBOlAB0oAKAFoASgAoA KAFoAKAEoAU0AJQAtACUALQAUAFABQAUAJQAtABQAlABQAUALQAlABQAUAFABQAUALQAUAFACUAL QAlABQAtACUAFABQAUAFABQAUAFABQAUAB6UAFAC0AFABQAUAFABQAlAC0ABoATpQAtABQAUAFAB QAUAJQAUAFABQAtABQAUAFAB0oAKACgBsiB0KnoaAOdvIntnVlYo6ybhgdvrVIbXYj1HxPJDNHHB BgHklx1HpTUUSX7PXY5QftEfl8blIOdwpcoXNOG6hmAMcgOam1hk1ACUALQAGgDO1yUx6dMFLAsp 5XGQKcRq3U5rQrW9muRbyRSR2QwygnOR70+bzHZI7UAAADoKkkWgAoAikiLMGVsccjHWgaZkzCSJ lMaiBwxCg9G96aHYv2V6k6KJCFl7rQ0SW6QBQAtABQAlABQAUAFABQBRn02OXVrXUdxWSBHTA/iD Y/wpFKWli9TJCgBaAEoAO1AGPI43RxvuI84HcOgOelMo2KRItABQAlABQAtABQAlAC0AJQAUAFAC 0AFACUAFABSAKAI5IIpSDJGr46ZFMd7DLZdpYBhgHgDtQDJ6BBQBl6nIkM8TOoIZ1AyaaGalIQUA FABQAUAFADJvMEZ8kDf23dBQA4A4G45I644BoAWgAoAKACgBaAEoAKACgAoAKACgBaAEoAKACgAo AKACgA6UANjkSQZQggHHFADqAKGmmTfOJFC/PwAc0DZfoELQAhzxjFAC0AJQAUAFAC0AZOqxstxH Kke47SM5wPahDKUGsTwQS+ZCZCnKsTgN7CnZdRNDv7WvJ5MQqsSsuUB5Jo0Cwxo9YkVAztg9elO6 HYa1vfxktKZSDxhecmi4WtqTRR3rxOyTTo3o6/yo9R2HLBfyBY5F8zDdW4wD/WkK3Q2beLyYlj3M 2O5pCZJQAvSgAoASgAoACMgigDnpo5Irphv2Kg+Z2HWmM3oXDxqynII7UhCugcYJPHPFAGPdW08R JYl1J+QqBlae47Ethfssz210UVkAIx3FFhGr9KQBQAUALQAUAFABQAlABQAtACUAVbdWF7OxOVIG PamMtUhC0AFACUAFABQAUAFABQAUAY2vN/pFsiswc5KYGcmmho2E+4v0pCFoAKACgBaAEJxQAUAL QAUAFABQAUAFABQAUAFABQAUAFACUALQAlABQAtABQAUAFACUAFAC0AJQAtABQAUAJQAUAFAC0AJ QAUAKKAEoAWgAoASgBaACgBKACgBaAEoAKAFoASgBaACgAoAKAEoAWgBKAFoAKAEoAKACgBaAEoA WgAoAKACgBKACgBaAEoAU0AJQAtACUALQAlAC0AJQAUAFAC0AJQAtABQAlABQAtACUALQAUAJQAU AKKACgAoAKACgAoAKAEoAWgBKACgBaAEoAWgAoASgBaACgBKAFoASgAoAWgAoASgAoAWgBKAFoAS gBaAEoAWgAoASgBaAEoAWgBKAEoAWgAoAKACgAoAKACgANABQAtABQAUAFABQAUAFABQAlAC0AJQ ApoAKAEoAKACgBe1ABQAUAFABQAUAFACUALQAlABQBhXXiOCHVVskz8rbZGI6E+lUo6C1NK/thdw gxhCw5GelTsUjI1W3Q2gjuMI6AAOFH3vSna42VTYS3EKzWcUbGMbGU5Ugj+dPRadBGY11PbXnlSI 8ZYDdkHBPsacX0QNG/a6yWVkRlZlHBPQ460cork1hrhu7oQrCVye/XHrSsh2Zt1IhDnjBoAr3djB dshmUkp0IOKA2Jo41jGFFAMdQAtACUALQBXu7dZ4iCuSBwKENOxzTJjJPmRNGM49x6Vdx2ZuaZqc d3+7PyygZwe9JxsSaFSAUAKKAEoAKACgAoAKAFoASgAoAWgBKACgDElEjXQ2uPK8zcMDvnoaq9hm 3UiCgAoAKAFFACUAFABQAUAFABQAUALQAlABQAUAFABQAGgCGABWYY570DZNQIKAIXtYXnWd0y6j AJ7UBcmoAKACgAoAhvDci3P2MR+cSMeZnaOeTx7Uthq19SVc7RuIJ7kUxC0ALQAlAC0AJQAUAFAC 0AJQAtACUAFABQApoASgBaAEoAKACgAoAZLH5iMrEhSMHHFAFfTVCwYT7oOB6/jTY2W+1IRk6QVk nuChRkVuCp7+lNjua9IQlABQAtACUAFAC0AJQAjosi4YZFAFYadagFfKBUnO09KB3Jo7eGLHlxKu OBgdKAbbJKBBQAUAFAC0AFABQAUAJQAUAGQOtAGLrCwzZaO5RSBhwT2/pVDVitpOorbGWGVmPTbn 1+tDQF641lIk4jbd79KLIRUl1G4mby3iwjEFStGgzPm0uSS+aTzHRJCSqvzj2FLmYcp02mpJFAEl z8vAJOSaXqDLVAgoAWgBKACgBaACgBKACgBaAK0ePtchDknaAV9KY+hYpCCgAoAWgBKACgAoAKAF FACUAZOu5VrdhEXbJAYHlTTQ0akeRGu7rjmkIdQAUALQAlABQAUAFAC0AJQAUAFAC0AJQAUALQAU AAoAKACgBKACgAoAKACgAoAWgBKAFoASgBaAEoAKACgAoAKAFoAKAEoAKAFoASgAoAWgAoAKAEoA WgAoAKAEoAKAFoAKACgBKACgBaACgAoASgBaACgBKAFFAB0oAKACgAoAKACgAoASgBaAEoAWgAoA SgBelACUALQAUAJQAUAFAC0AFABQAlAC0AJQAUALQAUAJQAUAFABQAtACUALQAUAJQAUALQAlAC0 AJQAtABQAUAFACUALQAUAFABQAUAFACUALQAlABQAUALQAUAJQAtACUALQAlABQAUAFAC0AJQAUA JQAtABQAUAFABQAUAFAAelABQAtABQAUAJQAtABQAUAFABQAUAJQAUALQAlAC0AJQAtABQAUAFAC UAFAC0AFACUALQAlAHI69opjImDM53DYfT1zTTtqinqrIl0TWGt3ktLmIDaNyleNwqtGrkbaGtqp Wewkmt9sm0cgc/5NTbuNFPRLkJLHCiMEdd2HPzZ7mqa0C5J4jgJRZVQucgYH9aldh30I9Lgt7rzI JYCrhc7sYI9qGrbAmzXtrG3tuY4xu/vHrSuK5YoAWgBKAFoAKAEoAKADj1oAa8iRqWdgAO5NCQGN qV5aTW4mjnAdQdoYdfwqooe2hkWcNzJcNggjC7Tghhz1pXFY7IdBmkAvagBKACgAoAWgBKAFoASg BaACgAoAKAEoAxLh4/OYbQ6B/mAbGGz3p2GbgpCE6UAFABQAUAFAC0AFABQAmKAFoASgAoAKAA5w duM0AFABQAUAFAFe1LbnDf3j3oGyxQIKACgAoAKACgAoAKADpQAUAFABQAtACUAFABQAUAFABQAU ALQAlAC0AJQAUAFABQAUAFIBG+6aYFLSCfIcEoSHP3abAvHoaQGbo0UcQmCLtYud2OhoGzSoEFAB QAUAFAC0AJQAUAAoAWgBKACgAoAKACgBaACgAoAKAEoAbI2xGbBOBnAoA5w2esy3fnB9ofn5jwB2 GKfN0GklqXI9EEiq1zt80nLFe5pX7DuhF0ECUt9obBbOAuPwo2C6LyaZaI27y9xxj5uaBXLSqqgB VAA6YHSlYQpRWxlQfwpgLQAUAFABQAtABQAUAJQAtACUALQBAjZuXGOMdcUD6E1AgoAKACgAoAWg AoAKACgBKAMjX5hGIFwclwaaGjWT7gpCYtABQAtABQAUAFABQAUAIAAMAYoAKACgAoAKACgBaACg AoASgBaAEoAWgBKAFoAKACgAoAKAEoAWgAoAKAEoAKAFoASgBaACgBKACgAoAKACgBaACgAoAKAE oAWgAoAKACgAoAKACgAoAKACgAoASgBaACgBKAFoAKACgAoASgBaACgAoAKACgBKAFoAKACgAoAK ACgAoAKACgAoAKAEoAWgBKAFoAKAEoAKACgAoAWgBKAFFABQAlAC0AFACUAFABQAtABQAUAFABQA lAC0AFACUAFAC0AFACUALQAUAFACUALQAlABQAUALQAlABQAUAFAC9qACgBKAFoAKACgBKAEoAWg AoAKACgAoAKACgAoAWgAoAKAEoAWgBKACgBaACgA+lABQAUAFACUAFABQAtABQAUAFABQAh4oAKA FoASgBaACgAoAa6q6lWAKnqDQBhahowWECBd6qSQD1X/AOtTT7lJmRHPNpwMse1kziQZyB+FVddQ NCwexS7WaaT97jKlD8vPbFDi2LnXQ0NVuLe4sJIo503HA4b3pWaFp1MnwwjtfMUlk2w5Vx2b0obA 6upAKAFoASgBaAEoAKAOe1q93ypAS0WD1I4+tXHyGUYrq7hct85YcMCc8dsUXuItWrSXSiMROVLZ w7c59celK6Ww7F1NIMrl5wsZ/wBg1IGnFbxRMXRBvPBbvQK5NQAlABQADpQAUAFABQAUAFABQAtA CUALQAlAGBqKql3Ms8f7qTaQe2R7015AbdtKs0KSIcqw4pNWAkoAbvGdpODQA6gAoAKACgAoAKAF oASgAoAKACgAzQACgAoAKACgCrZspaUL2c5+tDGy1QIKACgAoAKACgAoAKACgBaAEoAWgBKACgAo AKAFoASgAoAKAFoASgAoAKAFoASgAoAMc5xzQAEZoAjnbZBIw7KT0oAq6TuFrgqoOc8DBpsbLp+6 aQjP0jZiTy5S43HquP8A9dNjZo0hBQAUAFABQAUAFAC0AJQAUAFAB9KACgBaAEoAKAFoASgAoAWg BKACgAoAKACgAoAKACgAoAKACgAoAKACgBaACgBKACgCtbmQ3MwccA/Lj0oGyzQIKACgAoAKAFoA KACgAoASgDL1eIPNDiVI5AeMjOaaGkaUR3RqfakIdQAUAFAC0AJQAUAKKACgAoASgAoAKAFNACUA LQAlABQAUALQAUAJQAtABQAUAJQAUAFABQAUAFAC0AJQAUAFABQAtACUALQAUAJQAUALQAUAFABQ AlABQAtAAKACgAoAKACgAoASgBaAEoAWgBKAFoAKAEoAKACgBaACgAoAKACgAoASgBaACgAoASgA oAKAFoAKACgAoASgBaACgAoASgBaAEoAWgAoAKAEoAWgBKACgBaACgAoAKACgBKAFoAKACgBKAFF ABQAUAFABQAUAFABQAUAFABQAlABQAtABQAUAFABQAlABQAUAFABQAUAFAC0AJQAUALQAUAFADaA FoAKACgAoAKACgAoAKAFoAKACgAoASgAoABnJyeO1AC0AJQAtABQAlABQAtABQAUAFABQAUAJQAU ALQAlABQAooAKACgAoASgBpdVIBYZPagCtcadbzMXCBJCMbgKB3MeXwyqSyTWsjLM+Mtux+nShNr RA9RJfD08s5/fhYpB+8bo+fai9tg03N2ztIrOLy4h9SeppCJ6YBQAUAFABQAUAFAEVxbQ3KbJ41Y e/akCdihc6QrkNDIQw5AbpTux3KTiW1kIlR94ywcHAIpgWo7+aBws5U5A+U8Fc0bgzWRw65U0hDq AEoAKAK95a/akRfPmh2tuzE20n2PtS16DVuqJxn8KYhaACgAoAWgAoASgAoAKACgDP1e282AkFgC RuCrkmmhlfSJ9k7W7SArztB4Ix7U3d6g7GxUiM/UnFs6zbeWGwN/dPrTQdNC5byCWFXHcUgJMUAH fFABQAUAFABQAUAFAB/WgBKADNAC/pQAfSgAoAKAKGmEl5idxyxIJ9PSgbL9AgoAKAFoASgAoAKA ELKCFJAJ6D1oAdQAUAJQAUAFABQAUAFABQAUAFABQAUALQAUAFACUAFABQAUAFAEVz/x7yYP8JoB FbSSGty+4MzH5sU2MunofpSEZmjEsZCDlQxH402M1KQgoAKACgBaAEoAKACgAoAKACgAoAKAFoAS gAoAWgBKAFoASgAoAKACgAoAKACgAoAKACgAoAKAFoASgAoAKAFNACUALQBWjK/a3wpDDqc9fwpj sWKQgoAKACgBaAEoAKAFoAKACgDK1SQJdwBvuYJOOTTSKRoxZ8tc+lIlklABQAUAJQAUALQAUAFA BQAlABQAUAFABQAtACUAFAC0AFABQAUAJQAtACUAFABQAtABQAlAC0AJQAUAFAC0AFABQAUAFABQ AlABQAtACUALQAlABQAUAFAC0AJQAtACUALQAUAFACUAFAC0AFABQAUAFABQAlABQAtABQAUABoA KAIrmZbeIyMrsAQMIMnk4oGld2RJQIKAF6UAFACUAFAC0AJQAtABQAUAFABQAUAFABQAlAC0AFAB QAlAC0AFABQAUAFACUAFABQAtACUAFABgZzQAUALQAUAFABQAUAFABQAUAFABQAUAFABQAUAIKAF oAKAEoAWgBKAFoAKACgBKAFoAKAEoAWgAoAKAEoASgAoAWgAoAKACgAoATaM5xQAtABQAooAKACg AoAKAEoAU0AFACUAFAC0AFABQAUAJQAtABQAlABQAtABQAUAFABQAlABQAUAVr951iC2ykuxxkY+ WgDmra21I3M0lwjIpbdk5zxVNsrktqixHqV8gCh8nOBkZzT0JsWDq11CN0hgdCBg8rtPcGlZbDt2 F/4SERLmeHgDkqc8/SjlQkrlqDXbKV9nmbW96OUC/DPFOm6F1cDjg9KlqwElABQAtACUAFABQA2R lVCWOBigDNTWoXJEccjbeTx2quUCP+145lYT2x8voSeRn0o5baiTM/UmDHfbzBOgAPJGKaKNHQSz GdjIWU4z161LBqxr0hBQAtACUAFAC0AJQAtACUAFABQAUAFABQAGgCCOzgicyImHY5JPWgdyegRW 1GEzWUqRj59pK/Wga31KHh6VharFITuHXPY+lF7lTilsbFBAUAHSgAoAKACgBaAG55FABQAtACYo ARiFGaAF3Dj3oAWgAoAz9MfM10uwriQ4PY02NmhSEFABQAUAKKACgBKAG+WokMmPmIxn2pBfoPpg FABQAlABQAtACUAFABQAUAGecYoAKAFoAKACgBKAFoAKAEoAKACgCK7cx2srDGVUnnpQgRV0dUFo GTkscsfU02Nl4kYNIRmaLndMSwOWzwf84psZqUhBQAUAFABQAUAFAC0AFACUAFAEN3P9mt3m8tnC ckL1xQNK5KpDKGU5B5BoEABBPOfSgBaAFoASgAoAKACgBaAEoAKACgAoAKACgAoAKACgAoAKACgA oAKACgAoAKAK0SBb2Rgpyw5amPoWaQhaAEoAKACgAoAWgAoAKACgDF8QuI/JfftwemOT+NVFAa0B BhQjOCB1qQY+gAoAKAFoAO1ACUALQAlABQAUALQAlABQAUAFABQAUALQAUAFACUALQAUAJQAtACU AFAC0AJQAUALQAUAJQAUALQAUAJQAUAFABQAUAFAC0AJQAtACUAFAC0AJQAUAFABQAUAFABQAtAC UALQAUAFABQAUAFABQAUAFABQAUAFACUAFABQAUAFABQAtABQAlAC0AFABQAlABQAtACUALQAlAC 0AJQAUALQAlABQAUAFABQAUAFAC0AJQAUALQAUAFABQAUAFABQAUAJQAtABQAUAFACUAFAC0AJQA tACUAFABQAUALQAlABQAtACUAFABQAtABQAdKACgAoASgBKACgBaACgAoAKACgAoADQAUALQAUAJ QAE4GcflQAtABQAUAFABQAUAFABQAUAJQAtABQAUAJQAtABQAUAFACUALQAUAJQAUAFABQAmxSMb Rj6UrAQmytmUqYEweDxTHcpzaFZSHKoUP+zSC5z+sQw2MbrFh5FbIKDn6YqwNvw3ZzW9u0s/yyTY LLjGKm4M2KBBQAUAFABQAUAVb60N0qqJCgB5x3ouBnxeHo40CG5lYBt2TjNF2PTsTf2PhxidtinI GKLhcdFo8YkLzSNJnsegoC6NCONYkCIMKO1IQ6mAUAFABQAUAGRu29+tABQAtACUAFABQAUAFABQ AjbsfLj8aAFoAKACgDn2jkttWfyGxkZwV4HtTvZWKSN9TlQfWkSLQAtABQAlABQAUAJgZ4NAByOl AC0AFABx3FADW2hST2oAdQAUAUNMh8mS5yzFmkJ59KBsv0CCgBCcECgB1ABQAlAC0AFACUAFAC0A JQAUALQAlABnt3oABQAUAFABQAtACUAFAC0AFACUALQAlABQBXv+LKb3QihAiLRwy6fEGKlgMHHS hjZcboaBGJ4cc3CTMQQofK9qbGtEblIQjusaFnYKo7mgNgV1YZVgRQAuR6igAyB3AoAMjPUUAG4e ooAMj1FABkeooAQOjfdYHHHBosAu4eooAQ7SCCRQAi7UVVXAAGAKAHZosAZHqKLAGR6igBNy5xkZ 9KAE3puC7hn0zQAu9M43DP1oAN6j+IUAAZScAjNADWljXO51G3rk0AKrq33WB+lAAzovVgPxoADI gbaWG4jOM0AKHXswoANy9ARQABl/vD86AFBHY0AFABQAUALQAlABQAUAHSgAoArpu+1sOwHWmV0L FIkKACgAoAKACgBaAEoAWgBKAMvWkEj2yvIFUvwO5PamNGmgwij2pCFoAKACgBaACgBKAFoASgAo AKAFoAKAEoAWgAoASgAoAKACgBaACgAoAKACgAoADQAUAJQAUALQAlABQAUALQAlAC0AFACUAL2o ASgBaAEoAKACgBaACgBKAFoASgAoAKAFoASgBaAEoAWgAoAKADtQAlAC0AFABQAUAJQAtABQAlAC 0AFABQAUAJQAtABQAlAC0AFABQAUAFABQAUAFABQAlAC0AJQAUAFABQAtABQAUAJQAtACUAFAC0A JQAUALQAlAC0AFACUALQAUAFABQAUAFACUALQAUAFACUAFAC0AFABQAlABQAUAFAC0AFACUAFAC0 AFACUAFAC0AFABQA2gBaACgAoAKACgAoAKACgA70ALQAUAFACUAFAC0AFAAKACgAoAKAEAx070AL QAUAFACUALQAdKACgBKACgAoAKACgAoAWgAoASgAoAKAM281yws22vLufphBmqUGK5kav4mG9YLB gS3UgZP0p25dw62G6Lp0LXztesPNUhgpbOTSd2VojqxjAx0qRBQAUAFABQAUAFABQAUAFABQAUAF ABQAAYAHagAoAKACgAoAKACgBaACgBKACgAoAKACgAoAKAMDxDEFvLabkeYDGxDY96qLDQ1dOJFu sZkEhQY3CkwLXFIAoAWgCOOQOWCg4U4yRjNA2rD6BBQAUAFABQAUAGKACgAoAKAKOm7C9yyEk+aQ RnpTdxsvdKQgoAgmk2yAE4FA0T0CCgAoAKACgAoAKAFoASgAoAWgBKACgBRQAGgAoAKAEoAKACgA oAWgBKACgAoAKAK9/kWM+M52H+VAEOigf2bCV7rnpimwZdb7p+lIDN0Fi9uxOM57DApvQbNOkIyt dSaRYEhXPzZJ/ujHXHemnYaRm2tvdKUTdKikFS5HBPbNPmCxNLa3gUqCyNu4ZBz+HoKE7BYjFpdp IGd5c7TwRuH/AOuhsaVhxS7CLJF5pzyAOx9T/hRddRpWJvKlnjVZkk2qdxAXBJpX7BZCS6fcyxhm G/HIUnke1F7bE2QyO1uLRVig8yMMMscZyfSi/cdl0JvIk2IFVwU+b5eM/wD16ExJCLFfqMIMo/JL cke1DkFgC3JflWyU2gqvf3NO4WI4NPvTFsaUgMufUqe4B9KTmwcUJ9gnSVG824LoAvBO0inzMFEY ba6t1zarIJH5ZmO6jn7gojmt9SdMFfugBRnGff2oTXYGugGy1HzmkaNQDwoVyTj3NF7BbUmmspVi xbja3U88j8aV2OyE8m7VlKq/mnhmOMYouFiP7HeKQIXYBvvt6UXYcqIbuyv2kVkuCEVcMBwfrT5r CcUOXTpZTA5YvtGCetLmY7JCT2F/5kghlkEYHygDHNLmYcqZBaaZeIJlkdlR2yMgk5qudvcLIYum XUMoMly2zOGOO3rmhTeyFyotQ2d2srLHcyFFP93jBpcwcqII7WS1diGl+XJJbJ3CnztjcSeO1uCX IYLEy/eXOSfShyYuVD44tQhIG8YX+EnrRzILWH5v0UZcF+pCHIFK67DsSQz6hudZHUEDCjHX3p3Q WHKNTVQZJDIO2MA/WkmFiWDULsf622JA4JH6YodugrakseqA7g8MisoyVxzikJE8N7DKobJTIzhx iiwNWJ1kRvusPzosAFkPy7hk9s0AMgkV94DZ2nB9qGNkUTILtxuO89j2oAtUCCgAoAWgBKACgBaA EoAKACgDH12IvPasnVCTj+tNMaNaP/VrnrikIfQAUAFABQAlAC0AFACUAFAC0AJQAUALQAlABQAU AFAC0AJQAtABQAUAFABQAlAC0AJQAUAFABQAtACUALQAlABQAUALQAUAJQAtACUAFAC0AJQAUALQ AUAJQAtABQAlAC0AJQAUAFAC0AFABQAUAJQAtABQAUAFABQAUAJQAtABQAlAC0AFACUALQAlAC0A FABQAUAFABQAlAC0AJQAUAFAC0AJQAUAFABQAUALQAUAJQAUAFABQAtABQAUAFABQAUAFABQAUAJ QAUAFAC0AJQAtABQAUAFACUAFAC0AFACUAFAC0AJQAtABQAlABQAUAFACmgBKAFoATpQAtACUAJQ Ac0ALQAUAFABQAUAFABQAUALQAUAFABQAUAFABQAlABQAtABQAUAFABQAUAJQAtABQAlABQAUANe VEUsWGBQBQutTEcO+AI53YwT2p2AWK+JldZHjwuPun1osBoAgjIpAFAB0oAKACgCvqDtHZymMHdt wMdqF5gcf/ZVxeSSW4nRUkw53D5s+gqm+yHYnbQ3gjXbb4wclj1pKyHqVGEwjkil4LMQrqCCPaqW gcrIbPU9SsYHELqwz8rN3x1GPWm5LZoizNLR/Fdze3XkfZzJjk/Lt/LPWk1HYaTOvU5APrUALQAU AFABQAUAFABQBWvL2K0Qlslv7o60WAxzrhNzhiyR46Bf61dgQ5L+5t4wwlEyhsbXHJHsaWgWNm1u I7qESRHIPUeh9KnYCagAoAKACgBaAEoAKACgBaACgBKAFoASgAoAKAIreVpd4aMoUYrz39xSuNqx m+JCI7aKUhTtfGD71SELoToFkjjfdj5s/Whqw2a1IQUAFABQAUAFABQAUAFABQAh4oAWgAoAKAKV hGY55sAbCxINMbLtIQUAUb3i4iGPvHFA0XulAgoAO9ABQAUAFABQAUAFABQAUAFABQAUALQAUAFA BQAlABQAUAFABQAUAFABQBBev5drKwHRSaEAzTM/Yo8lDx/B0psbLLfdP0pCMzQFSO0KRhgFPehj NSgQUAFABQAUAGAKACgAoAKACgApAFMAoAKACgAoAKACgAoAKAE2g9hQAo46UgCmAUAJtA4wMUAL gDpSANoPUCmA3y0xjaMemKAF2r6CgACKpJCgE9aAuG1c5wM0AG0egoATYvoKAuRG0jLsxHzMME98 U7juMeyRkZezDBpBcjGnqrBkwrBcZHrRcdyKPSk+cyDLnhWBOVHtTuwuXreBLaIRxjgdzyTSZLIo Aftcu/ZkH5cdce9DH0LVAgoAKACgAoAKAFoASgAoAKAMnVBIbyIRkNlSNnce9NPQaNK3UxwRoeSq gE0hMkoAKACgBaACgAoAKAEoAWgBKACgBRQAUAJQAUAFABQAtABQAUAJQAUALQAUAFABQAlAC0AF ABQBDBcJM8yIHBiba25SATjPHrQFmS0ALQAlABQAtACUALQAlAC0ABoABQAUAJQAtACUALQAUAFA BQAlAC0AJQAtABQAUAFACUALQAUABoAKAEoAWgAoAKACgBKACgBaACgAoAKADtQAlAC0AFACUALQ AUAFACUAFAC0AFABQAlAC0AFACUALQAlAC0AJQAtABQAUAFABQAUAFABQAUAFABQAlABQAUALQAn SgBaACgAoAOlABQAUAJQAUALQAlABQAtABQAlABQAUAFAC0AFACUALQAlAC0AFABQAlACUAFAC0A FABQAUAFABQAUALQAUAFACUAFAC0AFABQAUAFACUAFABQAtABQAlAC0AFACUAFADJ5o7eJpZW2oo yTRYDnLvXprlimnQmSPBG9Tzn2qnaO4JN7EMemateTLJcKkS/wC9yD6470nLsCVi3H4aYSpI19Jw clQvBpc0h6FWbTrjT7wbHRonIKbuCfUGmtdwsXtJvHhlaKZiUY/Xa2f5U3qLU3akAoAKACgBkwUx lXXKt8pH1oBGFqsEtvOs0ahYwMFlPNNMdjWsLnzoE3ja+O/ehoVirrTzLbyC1t45plAZUbjcfTNJ aDs+hBbWVhq1qJRbyW7H78ZG0q3uKPQNty7ZaVa2aoIkJKdGY80rBcve2aYgoAKACgAoAKAFoArX 9x9mgLBlVzwu7vTSuF0mYNpFLqmot5xkjjhAYg8biTnFNu2iHodEIIlUqI02nqMVIrlO+sYyjPFE pY9fYe1NDTuZdtPNZThBggDkZ+99Ke4WOhglWaJZE6GpEPoAKAF6UAJQAUAFABQAUAFABQAUAFAA eBzxQAxJA7Oq5+Q4JoG1YfQIp6vGsunTBhnC7hx0IoQ0Y2iMkE6J5jSMx6qD39atoPQ6WoEFABQA UAFABQAUAFABQAUAFABQAUAFAFSwDBpdwIO44z6Z4pjZcpCEoAqXAb7QjI2NvXnqKClsW6CQoAKA CgBaAEoAKAF7UAJQAtABQAlABQAUAFAC0AISF6mgBaACgAoAKAEoAKACgAoAKAK+ogGymBxjbzmg BumArYxDI6cY6UMGWW4Un2oAzNAlaW03kYGT7U2NmpSEFABQAUAFABQAUAFABQAUAFABQAUAFABQ AUAFABQAUAFABQAUAFABQAUAFABQAUALQAlABQAUAFABQAUAFABQAUAUbfcNTuR/BhT+NA+hfoEJ QAUALQAlABQAUAFABQAUAYWvvcRahYvED5eSH2jnFNDNxPuD6UhC0AFABQAUAFAC0AJQAtABQAlA C0AJQAtACUAFABQAtABQAlABQAUALQAUAFABQAlAC0AJQAtABQAUAFABQAlAC0AFABQAUAJQACgA oAKACgAoAKACgBaACgAoAKAEoAKACgBaACgAoAKACgAoAKACgAoASgBaACgAoAKACgBKAFoAKAEo AWgAoAKACgAoASgAoAWgAoAKACgBKAFoAKACgBKACgAoAKAFoAKAEoAKACgAoAWgBKAFoAO9AAaA DpQAUAJQAtACUALQAUAJQAUAFAC0AFABQAlAC0AFABQAlABQApoAKACgBKACgAoAWgBKACgAoAKA FoASgBaACgBtABQAtABQAUAFABQAUAFABQAtACUAFAC0AJQAUAFABQAUALQAlABQAtABQAUAFACU AFAC0AYnikM1j5f/ACzYEN78U1pqFjH8PSxaTbJYTpsaHBRx6Gmk3uPY6u3uFkUAsN2OcdKkLE/b igRV+yvKkkd3Isyk5T5dpWl6lNrojFkh+xXEyvgh1zn3q9xG5YTCe2R13YxjnvSYizSASgAoAKAI 7iITRFG6HtQBzuJluJIYppIoo2+XavT1FNMfU1J5EvrNnizvXqB1Bo1QIz9O1Roi5uwyANtxjr70 7J7CtY6HOVyvPHFSBy+pm7g1GCeeVlT5iV7AenFVFt6IOVI2tIvjeQDzBtlUfMKTQF+kAYoAWgBK ACgDM16zmu7TbAzBhnhev4U07BYwbe8uLW4S1KziMRjdyNxJ9/rVRsPXY1k1YYMW4RzbeA/QH3pW AsW+qJ5X74hnH93jP0FDiIpXoWR1eHbtY59GX2NNO2wb6lvw7cCe1kAQpskKkE55qZAatIAoAKAC gAoAKACgAoAKACgAoAKAIL5oktnadA6rztIzk9qEgRXsNSguBgsiODgrnvTcQLkUgkBK5GCRyPSk Nqwy7BNtMB12HH5UIRzWiSR/aLdxINzZ79auw15HV1AgoAKACgAoAWgAoASgAoAKACgAoAKACgCh pTu/nE52byE3cHGaGNl+gQUAULokXcaqBvOOT6UykX6RIUAFABQAUAFABQAtACUAFAC0AJQAUAFA BQAtACUAFABQAtACUAFAC0AJQAUAFAFPWJEi0y4kk+6qZ5OKAHaXIsthC6fdKjpTYFlvunFIDN0Q v5Tq7ltrYpjtY06QgoAKAFoASgAoAWgBKACgAoAWgBKACgAoAKACgAoAKACgAoAKACgAoAKACgAo AWgBKACgAoAWgBKAFoAKAEoAKACgAoArIp+3yMRgbQAfWgfQtUCEoAKAFoAKAEoAWgBKACgAoAy9 WXfc265PXsfemhmoBgAUhBjnNABQAUALQAUAJQAUAFAC0AJQAtABQAUAFACUAFABQAtABQAUAJQA tACUALQAUAJQAUALQAlABQAZ5xQAUALQAUAFABQAlAC0AFACUALQAlABQAtABQAlAC0AJQAtABQA lABQAUAFABQAUALQAUAFABQAlAC0AFABQAUAFABQAUAFACUAKKACgAoAKAEFAC0AJQAtABQAUAFA BQAUAFABQAUAFABQAlAC0AFAAKAEoAWgBKACgAoAKACgAoAKAFoAKACgBKACgAoAWgAoAKACgBKA FNACUALQA1jj86AFoAKACgAoAKACgAoAWgBDxQAtABQAUAJQAtABQAlABQAUALQAUANoAKAFoAKA CgAoAPpQAUAFABQAUAFABQAUALQAlABQAtABQAlAC0AJQAZGSAeRQAUALQAUAFACUALQBDdW8d1A 0MoyrUAY0+lTSzM1wsZVMbGXv7EU2/IaSRSmi1CwYyTfNEOy9/b2p3C1ti1b67E0eTuVxxszT5QL zarCI1y6ktxhTzmlyhsY11LJqN4NibipA2jt9aewkdPawi3gWMduv1qAZLQAUAFABQAUAZ2sW5a2 eeFGaZV4UH71NOwdLHI2cur294n2T9/LJkuZPlVEHb61bloNxZNc3UrxLIkRlYkhwx+6aBNvoamj a8m9YLnEaYAUk85pON9gNW/SC+tXVGV2A4wamw0czY3a2N/EgLIWfoehHpVdA1R2w6VAhe1ACUAL QAlABQBVn061nJZ48E9xxQBHJpNnK+6aPzCMAbj0oHcrXGihcvaMFcKQN/OKAKi6TfyNGs7rsLbp D3HsKdwN22t0to9idyST6mpBslpiCgAoAKACgAoAKACgAoAKACgAoAzNfH+iIx3bFcFselNbgZtj HFIkq7j9/jHXPam11K9TftZA8eO68HNSSOuP+PeXt8p/lQBzGhRg3KrhWjXABI5yKbQ7nV0hBQAU AFABQAUALQAUAJQAUALQAUAJQAUAVLINHJIjBskltx6HmgbLdAgoAoXK79Qh5Py84oKRfoJCgAoA KACgAoAKACgAoAKAFoASgAoAKAFoAKACgAoASgBaACgBKACgAoAMDOaACgBsiJKhSRAyHqGGQaA2 FRVRQqABR0AoAHOEY+goAyvD0wmt3YR7AGIptDNakIKACgAoAWgBKACgAoAKACgAoAKACgAoAKAF oASgBaAEoAKAFNACUALQAlAC0AFABQAUAJQAUAFAC0AFACUALQAlABQAtAFSE5vZvmBwB9RQMtUC CgAoAKACgAoAWgAoASgAoAyNYZheWqhDhmADZ6HNNBbqa46CkAtACUAFAC0AFACUAFAC0AFABQAU AJQAtACUAFABQAUAFABQAtACUAFAC0AFABQAUAFABQAlABQAUALQAUAFABQAUAFABQAUAFABQAUA FACUAFABQAtAAKAEoAXtQAUAFABQAlAC0AFACUALQAlABQAUALQAUAFACUALQAUAFABQAUAFABQA UAFACUALQA053AAcdzQA6gAoAKAEoAWgAoAKAEoAKAFoAKAEoAKAFoASgBaACgBBQAtACUAFAC0A FABQAUAFACUAFAC0AJQAfSgBaACgAoAKACgAoASkAHtTAWgAoASgAoAKACgBe1ABQAlAC9qAEoAW gAoAO1ACUAFABQAtABQAUANoAWgAoAKACgAoAKACgAoAKACgBaACgAoASgBaAEoAWgBKAFoADQAU AJQAtABQAlAC0AJQAtADJZFiRnY4CjJoCxj/ANsyvM5iWMQhcjdkEn/CqsIvWt/FcAhxsIH8WMGk 4j9BtzpNlcLhoEU9mUYIqfQfMylcaDaD5nmdR6k1V2PmHfaYrUstpEnyry5PJotoJspTas906pHK Y3Byyqc4qkkgTNjSryS4hxcqEmBPA7j1qWIvUgCgAoAKACgCvdWcdym1sr7rxQNMpW+ixxI6+a53 HPXrQO6Of1Tw5Ms+6KNpccoQcDPvVKbQblqG0uNOhUSOWc8qX6p9Kd7h5FW30y6v9TM0Ui+WhDBm 7HvxUy3FY7RRhQD1ApCHUAJQAtACUAFABQBG88MbBXlRWPYnFFmA7zEyBvXkZxmiwCh1P8Q/OiwC 0AFABQAUALQAlABQAUAFABQAUAFABQAyaMSRMhAwR3oBHOrEwn+eXZMSVODjntxVDL+mSSxSeVKM 5P3s0hsu6i5Szl2kbipC59aESjI8NReZunL52krjGOabY+h0FSIKACgAoAXtQAlACIcj0PcUALQA UAFABQAUAFABQBS01mPmq2RtYjrmmxsu0hBQBQkUvqCkdY+2eOfWmMv0hBQAUALQAlAC0AJQAUAF AC9qAEoAKAFoASgBaAEoAKACgAoAWgAoASgAoAKACgAoAKACgBG+6fpQBl+Hhi1bB3DccE9xTYzV pCCgAoAKACgBe9ACUAFABQAUALQAUAJQAtACUAFAC0AJQAtACUAFAC0AFACUAFABQAtABQAlABQA tACUAFABQAUAFABQAUAVIVZL+bgBGAP40D6FugQUAFABQAUAFABQAUALQAlAGXqXmfb7dVXcvoeM H1pjVjUHQUhBQAUALQAUAJQAUAFABzQAAYzyaACgQUDFoAKAEoAKAFoASgAoAKACgBaAA0AJQAtA BQAUAFABQAUAJQApoAPpQAUAJQAtACUALQAUAFABQAlABQAtACUAFABQAtABQAlAC0AJQAtABQAU AJQAtABQAUAFABQAlABQAtABQAUAFAAKACgAoAKACgBKAFoAKAEoAX6UAFABQAUAFAAaACgAoAKA CgAoASgAoAWgAoASgBaACgAoAKAEoAKAFoASgBaAEoAWgAoAKACgBKAFoASgAoAWgAoAKACgBKAF oAaw5UenNADhQAlAC0AFABQAlABQAUAFAC0ABoASgAoAWgAoASgBaAEoAWgAoAbQAUALQAUAFABQ AUAFABQAtABQAUAJQAUAFACigAoAKAEoAWgAoAKACgAoAKACgAoAKACgCpqO5YDIoB2/wnoaENHO LYm4WbzHdPQO2QD/AIVTb6AOgmntdsFxF8hxhiANo/qDTunsN6G7ZXSl3iZgWXqB0FTYRnalJLPd rEiBnGerYXb/AI09gLFjolskX7z94T154pNsdxuqaJbvG8tqnkS4yTGMbqV33F6mXpF6kDxpNIUc vsRSD1+vvVXbFsdaCCMipAKACgBaACgBKACgAoAq31p9pXGenO09CaLjTOfiun0y4kaZdgyBnqPe q3E9DqI3WSNZF6MMipAfQAlABQAtABQIZIpaNlQ7WIwD6UIZyWo6deq7zvA77FxvB3E/hVcw7djN jvbqWR1aLeUAAJ4yPTHaquK1izHqvkyLGLZ1HRt2cg0kBafWrmKPyACpB+9nJIo8xeRYTWpzGZS3 ykgcdKBluHXVDIkwUFhkEGk4iuizHqJ83D7AjLuXPelYZKNTg2BjkZ6DuaOViuiUXsBQPvAGcc0W DYetzAwysqEZx1pWGSBl7MKAFyPWgBkc0cufLdW2nBwehoasA/vigAoAKACgDK1i2JYTBFK4wSFy wPtTTH5GVZXu/U1ViAijJbvmq6C0JdbvZLxhBYfMYyCSPel8I0rm1ptoLO2CAksfmYn1qQZboEFA BQAtACUAFABQAUAFACmgBKAILqOeTy1glEa7sucZJHoPSkVFpbk/TpQSFMCjpw2PMpI3Fi3B7UMb L1AgFAGfJtXVV4OWWmBoUgCgAoAKAFoASgAoAWgAoASgBe1ACUALQAUAJQAtACUALQAlABQAUAFA BQAUAFABQAc5oAKAEb7pHtQBnaI6+S8SEERnHFNjZpUhBQAUAFABQAUALQAlADEhjRy4HzHuTSsF x9MBaAEoAKACgAoAWgBKACgAoAKACgBaACgBKACgAoAKAFoASgAoAKAFoASgAoAWgBKACgBaAKsU ga9lTBBQDJ+tAyzQIKACgAoAKACgA70AFABQAooAyNVk2aharxgnp3poZqrwoApCFoAKAFoASgBa ACgBKACgBaACgBKAFoASgAoAUUAFACUAFAC0AJQAUAFABQAtACUALQAdKACgAoASgAoAKAFoAKAE oAWgAoAKACgAoADQAlAC0AJQAUALQAUAJQAUAFABQAUAFAC0AJQAUALQAlABQAUAFAC0AFABQAUA JQAUALQAlAC0AJQAUAFAC0AJQAooASgBaACgAoAKACgAoASgBaAEoAKAFoAKACgAoAKACgAoASgB aAEoAWgAoAKACgAoAKAEoAKACgAoAKACgAoAKACgBaACgBKAAdcmgBaACgAoASgAoAKACgAoADQA UAFABQAUAFAC0AJQAtACUALQAUANoAWgAoAKACgAoAKACgAoAXtQAUAFABQAUAFABQAUAFABQAlA BQAtACUALQAlAC0ABoASgAoAR1DqVYZBoAwLlYoZZYJFA4+Uk45qii1C0F5ELafCyqvynHIHShoR lS2txpl4CuH3cgk4FCdwJHlhSXCA4dPlHbPcZ9KbVxXNbQ53ntWZyfvHHGBj2qWNmjikI5fULCAa skiFUCnv2c9CPQ01cexuaQJBZKJQd2T1+tEmm7oRcpAFABQAUAFAC0AFABQBheJrQyxI6gbSdrHH IHrQkMTwzeOyyWkpP7o4QngkVTFobtSAUALQAlABSAKYBQBVuNPt5mDlArjoQKVh3MS/sbiz3SrG kwchW44696tO+jAjQ2kcL+daK21syANnaPaiwrmwmmafLbgRQqI2GRtqWVdoifw/Ztzlw/8Afzk0 MFIjudAUx4tJvLYDqwzT5mLRmdJoOpjJWSFueBvIo52CSHX2l6hBC7QQrcEL9wEDd7c0+ZdQsUEN 5FD++0yYcjcNnAP4Uc8X1Ek77DDd3ke+WG2nXDcsUYZ/Slzp9S+VhealfMGXbOyjqyxkAj+tNzSF yvsbnh0PjJiYKRnzCuMmp5ritbob2BnOOfWgQtABQAUARXMqQxFnxj3oSA5YQ28lszRSFJGI4I9T /KqtZjujW0mCGzUuX8yRzjd0H4Uh+hrqQehpEi0gCmAUAFABQAUAL0oAKAEoAKACgAoAKACgChpY j/esgBJY5bGO9MbL9IQUAZd1PEmsW8bZ3kcYFPoFzUpAFAC0AFACUALQAUAFABQAlAC0AFABQAUA FABQAUAFABQAGgBKAIpZmjkVfJdkIyZARhfrzmmkO2hIjo6h42DKehByKWxKdx1AxKAFoASgAoAR /uNjrigDL8PqFt34GS2TximxmtSEJQApoASgAoAKACgAoAKACgBaAEyM4zzQAtABQAlABQAUALQA UAFABQAlABQAtACUAFAC0AFACUAFABQApoASgAoAKACgAoAKAKVp/wAf118oHI57nimMu0hBQAUA FABQAtABQAlABQAGgDM1Qwi7tzJuyvIAPWmho01+6MjFIQUALQAlAC0AJQAUALQAUAFABQAlABQA UALQAUAJQAUAFAC0AFAAaAEoAWgAoAKACgBKACgBaAEChSSB160AFABQAUALQAlABQAtABQAUAFA BQAUAJQAUALQAlAC0AJQAUAFAAD7UAFABQAUALQAUAFAB0oAKACgBKAFFACUAFABQAtABQAUAFAB QAUAJQAtAB2oAKACgAoAKACgAoAKACgAoAKACgAoASgAoAMgdaAFoAKAEoAWgA6UAJQAtACUAFAC 0AJQAtACUAFAC0AFACUAFABQAUAFABQAUAFAC0AFACUAFAC0AFACUAFABQAtABQAlABQAUAFABQA tABQAlABQAtABQAlACUAFAC0AFABQAUAFABQAUALQAUAJQAUAFAC0AFACUAFABQAtACUALQAlABQ AtACUAFAC0AFABQBXurSG6XEqA46EjpQC0KFtp08VyVdgYBhlfv9DTuBpTwRXERjmQMh7GpBaHP6 hot4hh+xOHCyFvmOCAe1NOw9Db061+x2qxZy3VvrQ2ItUAU7nTba5lEkqEsCDwfSgadi2BgYHFAg oAKACgBaAM7WoJZ7dRHvIU7iqnGfSnF2dwRANSntFQ3seYyACV6qfcU2kx2LI1ex8oSmbCnnoaXK yW0iRdSs2+5OjdOh6Zo5RjpJbaZDG0sZzxjPeizC9jmbcvb+I1VnXA+XHqPWi3YZ11IQUAFABQAU ALQBDPcwW+POlVM9ATTUW9gIn1G0jzvlAAGcnpRYCL+1bV/KX5t0pwqsuDT5QTXQwr4xQ3T+RypY q2T09RQkDNzRVVbP92xKFiVz2FS2Nmh9KBBQAUALQAlABQAYoAKACgAoAKACgChrETSW6bE37WyR 7UIaM21tLe4mYPHJHtGxTnkg9sU7W2Amm024tocQMJEXnaRzii4hNMv2d0BySWwTt5x707BrsblS AUAFABQAUALQAlABQAUALQAUAFACUAHagCjpUZQSliMsx+UdF9qbGy/SEIM85oAzm0iF9WGoOzl1 GFUngUXYaGjQAUALQAlAC0AFABQAUAJQAtACUALQAUAFAB0oASgBaACgBKAFoASgAoAigtoLbd9n iSPccsFGMn1oB6u5LQAUAFAEc8giiLHoKEA9TlQaACQ4RiOwoAzdB5tSxHzEnJ9abGadIQgzuIx8 uODmgB1ACUAFAC0AJQAtABQAlABQAySJXIY5DDoQcGlbsA5V2qFGePU0wHUAJQAUAFABQAUALQAU AJQAtAAKAEoAWgAoAPpQAlAC0AJQAtACUALQAUAJQAUAFAFW3/4+5/mJGeAR0oG9i1QIKAFoAKAE oAKAFoAKAEoAKAMfVkP22FlG1iAFb3zVIZsDoM9akQUAFAC0AJQAtABQAlABQAAhvukH6UALQAlA C9qADvQAlAC0AFABQAlABQAUAFABQAtABQAlAC0AFACUALQAhOMe9ABQAgRVYsFALdT60ALQAtAC UAFACmgBKAFoADQAUAFACUALQAUAFACUALQAUAFABQAlAC0AFABQAUAJQApoASgBRQAUAJQAtABQ AUAFACUAL0oABQAUAFACUALQAUAFABQAlAC0AFABQAlAC0AFAAKAEoAWgAoAKAEIB4IzQAUALQAU AJQAtABQAUAFABQAUAFABQAUAFABQAUAFACUALQAUAFABQAUAFABQAUAFABQAUAFABQAlABQAtAB QAlAC0AHSgAoAKACgAoASgBaAEoAKAFoASgAoAKACgAoAKACgAoADQAtABQAlAC0AJQAUALQAUAF ABQAUAFABQAUAJQAtABQAlABQAUAFABQBT1DUrewQGZjk9ABmmo3Agi1R3nK/ZW8nYGEgYHn0xRY FqSjUWdA8drMR3zgY/Wiy7jaYDU4v3RKkLIcK2RRYQ6PUYWZkYMjLnINFgF/tG2wfmYYGeVPSiwB /aNtiNgx2ucA+n1osBbpAFAC0AJQAUAQz2sM/wDrFzQNOxmvoYV5DbTtGjjlMZA98UXYOzIH8Pt0 R48HqSvNCdh6FWfR5bZvNwhGcAIOvHc1XMLQw5oLuHUYXgdsRSbwpXp7e9DkK19Eeg2sjSwJIylG YZIIwRUgS0AFACUAFABQBx+r+H9U1C8aRJFjUt1L9eeoo5mth6FpPDl0zHzbhAp7AE0czsFkS/8A COPj/j8Oc5BKZx7UczQaFi28OWkTI0jSSbOik4H5UNtg2jYRVRQqgKB2FIQtMBe1ACUAFABQAUAF AC0AJQAHgZPagDGl1xfOaOJTtUkFsd6dg+RIurKwTLCPccDdRZBsOkvke1lLcgDt1osMy49Qh83a Q+/gk5wW+lFhXLN7rL/cRNilc7t2DmnZAN0qzae6N3G3l25bOzpuIpXY7dToKQgoAWgBMUAGMUAL QAlAC0AFABQAlABQAUAB6GgCjpTq0cmzO0uSM02Nl+kISgBaACgBKACgBaACgAoAKAEoAWgBKAFo AKACgAoAKACgAoASgBaACgA7UAJQAtACUALQAlAFbUHVLfLEDJwM+tAImgJMSbuDigGOf7jfSgDN 0EqbZgo/i5NNgadIAoAXtQAlABQAUALQAUAFABQAlABQAUAFABQAUAFAC0AJQAUAKKACgAoASgAo AKAFoASgAoAKACgBaACgBKAFoAQ8UAJn2NAC0AVrf/j4nI3cnv06dqBvYs0CFoASgAoAKACgBaAE oAWgANAGTqskUd3AS+JBgD2BNUkF7GqOgqQCgBaAEoAXtQAUAFABQA1gGUg9DxQBV03TbTTImiso vLRm3EZJ5/GpjGxc6kp6yLdUQFAC0AJQAUALQAlAC0AJQAtACUALQAUAJQAUAFABQAUALQAUAFAB QAlAC0AJQAUAFAC0AFABQAlABQAtABQAlABQAUALQAUAJQAtACUAFABQAvagAoAKAEoAKAFoAKAE oAWgAoAKACgAoAKACgAoAKAEoAWgAoADQAlABQAUALQAUAJQAUALQAlAC0AJQAtACUALQAUAFABQ AlACigAoAKACgANABQAUAFACUAFABQAtABQACgAoAKACgANABQAlABQAtABQAUAFABQAUAFABQAU AJQAtABQAUAFAAaAEoAWgBKACgBaACgBKAFoAbQAtABQAUAFABQAUAFABQAUALQAUAFABQAlAC0A HSgAoAKAE5zjHFAC0AFACUALQAGgAoAKACgAoAKAEoAx7zQUnkeSG5lhdzk45/nTux6CR6JIin/T G3HuFAo5mGg99LuOQt0zIf4WouBCdL1Dco+0w7R32fd+lF/IBj6VqAZGDwuV656mhMRXubfXCI1i iiwflbLdBRzJdBljTtMvFnxdRxLApyADmi43Y36RIUALQAlABQAtABQAUAFAEP2WASmXyl3nvigd 2S0CFoAKAEoAKAFoASgAoAWgBKACgBaACgBKAFoASgBaAEoAKACgAoAgeztnDK0CfN1460h3ZDLp VlIMNbr9e9O4XK39gwL9yWVfxzRdhddjFl04HViluXkOcYJ+6B1NNMZvNotoU+ZN0gH3z1zSFcrx 3BtrkJtUDhQufTvTsNm0DkA0iQoAKACgAoAKAFFABQAlABQAtABQAlAAeAaAKOmAESMuQCxOPSmy mXqRItACUAFABQAtABQAlABQAUALQAlABnnFAC0AFABQAUAFABQAUAFACUALQAdKAEFABQAUAFAB QBT1WJZbYKW2/MCD70AWouI1+lACTDMLj1U0AijoYVbNdh45yPemwNGkAUAFABQAdqACgBaADtQA lAC0AFACUALQAUAFACUAFABQAtACUALQAUAFABQAUAFACUAFABQAtABQAlABQAtACUALQAlAC0AU 7Vv9MuECsFXHJ6E98UDLdAgoAWgAoAKAEoAKACgBaAE6UAYmr8arbbUDgj5h+NMZtr90UhBQAtAB QAlABQAUAKKAEoAKACgAoAKACgAoAKACgBaAEoAWgBKACgAoAKACgBaAA0AFABQAlAC0AFABQAlA BQAUAFABQAtABQAUAFABQAlAC0AFACUAFAC0AJQAUAFAC0AJQAUAFAC0AFABQAUAJQAtABQAUAHS gAoAKACgAoAKACgAoAKACgBKACgAoAWgAoASgAoAWgAoAKAEoAWgAoADQAUAFABQAUAFABQAUAFA BQAlAC0AJQAtABQACgAoAKADpQAlABQAtACUALQAUAFACUAL2oAKAEoAWgAoAKACgAoAKACgAoAK ACgAoASgBaACgAoASgAoAWgBKACgBKAFoAKACgAoACcDJ4oAKACgAoAWgAoAKACgAoAKACgAoAKA CgAoAKACgAoAKAEoAWgAoASgBaACgAoAKACgBDnBxQBSNxL53yISuM9cfnTG0WopFkXI/L0pCH0A LQAUABoASgAoAKACgBaAEoAKAFoAKAEoAKAFoAKAEoAU0AJQAvSgAoAKAEoAWgAoADQAlABQAUAF ABQAUAFABQAUANWNIyzKoXPJIHWgCgNZtncpAwkZchgD0IqnFoDIjkubnUHMscRWXoiHJA9zQxq5 0yKERVHQCpEOoAWgAoASgBaAEoAKACgBaAEoAKAFoAQ9DQBR0vdskBIIDkDFNjL9IQUAFACUAFAC 0AFACUALQAUAJQAtACUAFAC0AJQAtABQAlAC0AJQAtABQAUAIBjgUALQAGgBKACgChrKlrVQg+fe Np9DTQIuRZEa5POOaQCTlhC5QZYKcCgDO0Alrc5xnPUd6BmrQIKAFoASgAoAWgAoAKACgA7UAFAB QAlAAKAFoAKAEoAWgBKACgAoAUUAFABQAlABQAUAFABQAUALQAlABQAtACUALQAUAJQBXj3i6kBA CYBHNMZYpCCgBelABQAlABQAtABQAUAFAGPq4JvIDvwAemOh9afQaRrjoKQhaAEoAKACgAoAKAFo ASgAoAKACgAoAKACgBaAEoAKAFNAAaAEoAWgBKACgAoAXtQAlABQAtABQAlABQAtAB9KACgAoAKA CgAoADQAUAFAB0oAKACgAoASgAoAKAFoASgAoAKAFoASgAoAWgAoAKACgAoAKACgAoAKADpQAUAF ABQAUAFABQAUAFACUALQAGgAoAKACgAoAKAEoAWgAoASgBaAEoAKAFoAKACgAoAKAEoAWgAoAKAC gAoAKACgAoAKAEoAWgBKACgBaACgAoAKACgAoASgBaACgAoASgBaAEoAWgAoASgAoAKACgBaACgA oAKAEoAWgAoAKACgAoASgAoAKACgAoAKACgAoAKACgAoAKACgAoABk54IxQAtACDigBaACgAoASg BaACgBKAFoASgBaACgAoAKAEoAKADpQAZoAzdVgjOHOVLDaWHAH1poaQyylMUvl75M5xsbGfc/Sg PI1aQhaACgAoATigBaACgAoASgBaACgAoAKAEoAWgCK4nit03SsFFCQCWtzFdR+ZCwYZwfY+lFrA S0gFpgFACduKAEQMEAY7mA5OMZoAWgAoAWgAoAKAEoAWgAoAKACgAoAKAEoADnHHWgCK5iaa3eNJ GjZhgMvUULQDDi8K28WWE0hkOSSOMk0XY7p7kNnFLY3gV4nJHylj6etVoB0Vq/mR7gcjPHNSJktA BQAUALQAlAC0AJQAooAKAEoAXtQAUAIehoAzNEZikylgQHOMdAKbGzTpCCgBaACgBKAFoAKAEoAW gAoASgBaACgAoAKAEoAWgBKAFoAKACgBKACgBe1ACUALQAlABQAUAUtTmSGOPf0ZwKaAtRDEagHt SBiT/wCok5A+U8mgDI8Jhxp7eZj756DFNjeht0hBQAUALQAUAFACUALQAUAFACUAFABQAUALQAlA BQAtABQAUAJQAtACUALQAdKACgBKACgAoAKACgBaAEoAKACgAoAWgBKAKcHOoTkk5wAKALtABQAU AJQAtABQAUAFABQAlAGXqDKt4jE4wQM5/pTQ0ag6CkIWgBKAFoASgAoAKACgBaACgAoASgAoAWgB KAFoAKAEoAKAFoASgAoAKACgBaACgBKAFFABQAUAJQAUALQAUABoASgBaAEoAKAFoAKACgAoAKAE oAKACgBaAEoAKACgAoAWgBKAFoAKACgAoAKACgAoAKACgAoAKACgBKACgBaACgAoAKACgAoASgBa AEoAWgAoAKAEoAWgBKAFoAKACgBKACgBaACgAoASgBaACgAoASgBaAEoAWgAoAKAEoAKAFoASgAo AWgAoAKAD6UAFABQACgAoASgBaAEoAWgBKAFoASgBaAEoAWgAoAKADpQAUAJQAUAFAC0AFABQAlA C0AFADaAFoAKACgAoAKACgAoAKAFoAKACgBKAFoASgBaAEoAXpQAUAFACUALQAlABQAtACUALQAU AJQAUAITtBPpQBm3WqGDAKKpPT5smqSAydQvRdwSxzFxH1XaCM/jTvbYZHDMYUi2PJHGFDDbjr05 o5l1EWH1LEJiuW8yHkMwPX0JosDaKVnqlvJM0cUzwSR5YKzZBHpR5jvbcuLrMrgeTIoY9iwwKNBX 7k0GtGW1BD/OOCeOvrS0uCaG/wBqB44yJGGAR9/hvenyjIl1D7Tt8uduMq4P8VGzFbsWdFa5knJZ ZVjxwXHGPak5Jjs0b1SIWgBOlAGKviK3bUhahNsXOZmbAyO2Krl0EbQIIBByD0IqRi0AFABQAlAB QBy3jTzSYljZMFSNvc1UdBGh4TiMOlAMpBJyc9zSbKasbVIQUAAoAKACgBKACgAoAWgBKAFoAKAE YkDgUAUlvtshikA3r94DtRYdi4jBlBU8GgQtABQAUANkbYuT0oApX2qRWFoZ7jjHAA7mqSuOxSh1 xnAZo1Ve+TzT5UIh1W9+3LGls7qqt823+L2pfCBsaZbm2so42GG6kemam4Mt0AFABQAGgBKACgBa AEoAKACgAoAKABuhoAo6VEkMTRo275iSabGy9SEGe1ABkAgZ5NABQAUAFAC0AJQAtACUALQAUAFA CUALQAlAC0AFABQAlAC0AJQAtABQAUAFABQAlAC0AZuuqrWikgfK4PNNDReiIaNWBGCKQht1n7LL tHOw4/KgDK8LKRZyMzEuX+YEY28Dimxm1SELQAUAFACUALQAlAC0AJQAUAFAC0AJQAUAFAC0AFAB QAUANZgoyfpQAtAC0AFABQAUAFACUALQAlABQAUALQAlABQAUAFABQAUAV0K/aXwMN3pj6FmkISg AoAKACgBaACgAoASgAoAxtU3rqEZhQMxA+U9D9afQZsLnaM9e9IQtABQAtABQAlABQAUAFABQAtA CUALQAlABQAtABQAUAJQAUAFABmgAoAKAFoASgAoAWgBKACgBaAEoAKACgAoAKACgAoAWgAoASgA oAKACgAoAWgANACUALQAlABQAvagAoAKACgBKACgBaAEoAWgBKAFoAKACgAoASgAoAWgANABQAlA C0AJQAUALQAUAJQAtAAaAEoAWgAoAKACgAoAKAEoAKAFoAKACgAoAKAEoAKACgAoAWgAoAQ8UAFA C0AFABQAUAJQAtABQAUAJQAtACUAL0oAKACgAoAKAEoAKACgAoAWgBKAF7UAJQAUALQAUAJQAtAB QAUAFABQACgAoAKAG0ALQAUAFABQAUAFABQAUALQAUAJQAtACUALQAUAFABQAUAFABQAUAFACUAF ABQAtABQAUAFACUAN8tOuxePalYLi7FxjaMemKLAYHiK80+1Nvb3Fs0jTvtXYudv+0atJLUd7Edp Np00yRXlpHGSmI3b+IdwR2ocLoOZrcsaxodjKBdpAiyxj7w4GPeo5ew730ZRt7eyWVBcW8ZgdcH5 cjPv6Vdh7bG8mlWCbdtrEAowPl6CosTzMlSztozlII1x6KKLBdkiwxqSVjUE9SBRZBdklMQlABQA ki70ZckZGMigDj7vQ3t5maZfMhx94D9TRcaQ/T9XmsWVJFM6H7xB+6O2KvRrUVjo7fUba4AKORnp kYqbA9C0GU9CD9KVgFoAMgdTQBlXmv2VtG7K+8o2wgA8Gq5GK5zsNvceINQadXHlqR8xGMD2FS2U l3O2jQRoqKMADAoEOoAKACgAoAKAEoAKAM/VNSNlsWOJpHY44GcUadQsVTe30sgWGCQbv7y4Aouh 2ZHNqV7bSZmhYRY64707oLMIdeDsMvGR14BHFOwCXWvtB8qrGz7gOvb1oSXUT8jNTX7tGYGNmO4q p9fwobiGr2N2ZWltEu2iAnQcZ9PeloNaEumzMQI5U2SYzgHOR60gZfoEFACBjvK7SABw3Y0AKRni gDPktkkkZJ0Vk/un19aNyh76ZayYOzbjuvFIVx1rptrakNFH8w7k5piuW6AFoAKAEoAKAE5z2xQA 6gAoAKAEoAWgAoASgBG+6aAKOkbDCzISQTihqw2X6BBQBVYkXq4J6c0D6FqgQtACUAFABQAtABQA UAAoASgBaAEoAWgBKACgBaACgAoAKACgAoAQ+1ABQAUAL2oASgDM18O1oixg5aRRx2FC0A0IV8uJ FzwoxQAkzbYXb0UmgClobRtabo2DAnJwOhptWBmjSAWgAoASgBaAEoAWgAoAKACgAoASgAoAKACg BaACgAoAKAEIB4NAC0AFABQAUAFABQAUAJQAtACUAFAC0AJQAUAFABQAtACUAUYGQ6hMAG38Zz0H 0pjL1IQtABQAUAJQAtACUALQAUAFAGTfx5v1kABAUZBOO/amUtjVHSkSLQAlABQAUALQAlAC0AJQ AUAFABQAUALQAlACigAoASgAoAWgBKACgAoAKAFoASgBaAEoAKACgAoAKAFNACUAFAC0AJQAtACU ALQAlABQAUALQAUAFABQAlAC0ABoAKAEoAKACgAoAWgBKACgAoAWgAoASgBaACgAoAiuLeK5j8uZ dy5B64wRQNNrYk6dKBBQAtABQAUAJQAUAFAC0AFACUAFABQAUAL9KAEoAWgBKAFoAKACgAoAKAEo AKACgAoAKAFoAKAEoAWgAoAKAEoAWgAoASgAoAWgAoAKACgAoAKAEoAWgAoASgBaACgAoAKACgAo ASgAoAKAFoASgAoAWgAoAKACgAoASgAoAKACgBaAG0AFAC0AFABQAUAFABQAUAFABQAnzbwcjbjp 3zQA6gAoAKACgAoAKACgAoASgBaACgAoAOlABQAlAC9KACgAoAKACgBKAM3UdHhvSXDFJMYB9M0a odznrvSLq35Kl1QYUu3bufrT5tQ5b7FjTtVgthHbK0zRnhvM+YD157AVW+7FotLEb3VzFeCKNoVt wDuAOQSTwadvIbtbU6ewkeWzieUfORz/AI1mIsUALQAUAFABQAUANZQylWAIPY0gMy50WFpWmtsR SEYPHB/CqT6Fcxj3OmXttCrRqzOGIJHYdqamkDVyrFb6hDDt23SnJO4E9abn5hy9iKNtdljcNduq g5RQp3477j3pe0RPLIuQWuo3ThPNkZQMMzDGaOe/qHKaCeHEMimWTdGCG2Ed6i7HobdtbxWsQigQ Ig7ChCbuSUwCgAoAKACgAoAKAA0AGB6UAFAAQD1FAEZghb70SEfSlZDuznvE+kQ+Sk8EYG1xuReN wodyk09yzpRt4ZkidcmRcxu2D9QDTtchJmpqBxZTYznYcYHNNDRm6AHdWd42BHDOT1P0oYbG3SEJ QAUAFAFW9UriZPvDgj1oGiW3feuMjI6j0oBk1AiOVzGm4Iz8gYX3PWgB9ABQAtABQAlAC0AFABQA UAHSgBKACgBG4U/SgCho/wDqmxnBOeRjmgbNCgQUAUyGOoAdgM0D6FygQtACUAFAC0AFACUALQAl ABQAtABQAlABQAtABQAUAFACUAFABQAUAFAC0AJQAUAVNRyYkVSQS45AzihDRaT7ooYiO5IFtKTn AQ9PpQBQ8PBRYKULEHn5qGM1KBBQAtABQAUAJQAUALQAlAC0AJQAtABQAUAFACUAFAC0AFABQAUA JQAtABQAUAJQAUAFAC0AJQAtACUAFABQAUAFAC0AFAFG3KrqE67huJzjv0pj6F2kIWgBKAFoAKAE oAKAFoAKAEoAybyMHVFMsilAoKoafQpGsKRItABQAUAJQAUAFAC0AJx2oAKAFoAKACgBKACgBaAE oAWgAoAKAEoAKAFoASgBaAEoAWgBKACgAoAWgAoASgBaACgAoAKACgBKACgAoAWgAoAKAEoAKAFo AKAEoAKACgAoAKAFoASgAoAWgBKACgAoAWgBKAFoASgBaACgAoASgAoAWgBKAFoAKAEoAWgBKACg A6UAKKAEoAWgA7UAJQAtAAaACgAoASgBRQAUAFABQAGgAoASgBaAEFABQAtABQAGgAoAKAEoAXpQ AlAC0AHSgBKAFoASgBaACgAoASgAoAWgAoASgBe1ABQAlABQAdKACgBaACgBKAFoAKAEoAKAFoAB QAUAJQAUAJQAtABQAUAFABQAUAFAAaAFoASgAHvQAUAFAC0AFACUALQAfSgAoAKACgAoAKAAUAJQ AtACUAFAC0AJQAtABQAlAAQD1FIDPvNItrhCFQIevA4/KjYdymnh2JroTXD7go4VRtppvoO5uKAo AAwBQSFABQAUALQAlABQAUAFABQAUAGAOwoAMCgAoAKACgBe1ACUALQAlABQAtACUALQAlABQAUA RXMCXMLROODQBzktre6a24RyXEKEsNgGR/hTUl1C3YLSS71FBK8rWsbggs3X8KG9dB27nQWNtHa2 6xwksvXJOcn1pCLFABQAm9ckbhkdaLANaWNSAzAE9KLBYhnniYGMkZPrTHsVLS4jjdirqFHVemB6 0WC5oiWMjhh+dKwiI3cYm8rnd296dgLFIBaAEoAWgBKAFoASgAoAKAFoASgAoACOCKAM7RuIpF8w uFYgE02M0aQgoAz5WU6lGCXBHTHQ0yuhoUiQoAKAFoAOlABQAlAC0AFABQAdKACgBKAFoAKAEoAK ACgAoAWgBKADpQAUAFAC0AJQBn61JPFBE0ETSHzBuC9cU0NF6LPlrkYOOlIRHekrZzFeoQ4/KhAi roRzp8Z4z3xQNmhQIKACgBaACgBKAFoASgBaAEoAKAFoAKACgAoAKAEFAC0AJQAtACUAFABQAtAB QAlABQAUALQAlABQAtACUAFAC0AJQAUAFAFGD5dUnGPvKDn6U+g7aF6kIKACgAoAWgAoAKACgAoA SgDHv4z/AGorKhPyDnHA5pjSNdfuikIWgAoAKAFoAKAEoAKAEVQgwgAoAWgAoAXtQAlABQAUAFAC 0AJQAUALQAUAFACUALQAlABQAUALQAlAC0AJQAUAFABQAUAFAC0AFACUALQAUAFABQAUAFABQAUA FACUAFABQAUAFAC0AJQAUAFAC0AFAAKACgAoAKACgAoAKAEoAWgBKAFoASgAoAWgBKAFoAO1ACUA L0oADQAUAJQAtABQAUAFACUAFABQAUALQAlABQAtACUAFABQAtACUAFABQAtABQAUAJQAtABQAUA FABQAdKACgAoAKAEoAKAFNABQAUAFABQAUAFABQAUAJQAUAFAC0AFABQAUAJQAtABQAlABQAtADa ACgBaACgAoAKACgAoAKAFoASgBaAEoAWgAoAKACgAoAKAEoAWgAoAKACgAoAKACgAoAKACgBO9AC 0AFABQAlABQAtACE4xxQAtACUAFAC0AJQAUAFABQAtABQAUAJQAtACUALQAlABQAUALQAlAC0AFA BQAlABQAUAFADdylioIyOozRYCpfWJmQmB/Kk/Q0DuZlhqLwu9tKNpQ7S59fTFVYXqb6HcoNSAtA GT9guo5pChQq7FjyQTTuPQhGn3u0IFj25OcuTRzMCpeadfRxRnbG82QqLuP+elHNYcYp6FHUoWtZ j5y4kcgYBPOfSmm9xNGnbadcvhwhToeW4P8AXNJykHKkatpY+XIZpTmTsM5C0gLtAgoAWgAoAKAE oAWgAoASgBRQAUAFACHoaAKenRiMS7SPmcnA7U2NlykIWgDNmWT+1IiDhOh+lMroaNIkKACgAoAK AFoASgBTQAlAC0AAoAKAEoAKACgBaACgBKACgAoAKACgAoAO9AC0AJQAUAFAEF8StnMVGSEOM/Sh AVNBZmsF39aANLnPTigAoAKACgAoAKACgAoAKACgAoAKACgBaACgBKACgAoAXpQAlAC0AFACUAFA C0AJQAUALQAlAC0AFABQAUAFABQAlABQAUAU4G3X84B+7j+VPoMudKQhaACgBKAFoAKACgAoASgA oAx7tiurqUYbioBU+nf8KY0bA6CkIKACgAoAUUAFACUAFAC0AJQAtAB0oASgBaAEoAKACgBaAEoA KACgBe1ACUAFABQAUAFABQAUAFABQAUALQAlABQAUAFABQAtACUAFAC0AJQAUAFAC9qAEoAWgBKA CgAoAWgBKACgBaAEoAWgAoASgAoAWgAoAKAEoAKACgAoAKACgAoAWgBKAFoASgBRQAlAC0AJQAtA BQAUAJQAUAFAC0AJQAUAFAC0AFABQAlABQAUAJmgAzQAc0AFAC0AFAC0AJQAUALQAlAC0AJQAtAB QAdqACgAoAKAEoAWgAoAKAEoAWgBKACgAoAKAFoAKAEoAKACgBaACgAoASgBaAEoAWgBKAFoAbQA tABQAUAFABQAUAFAB9KAF7UAFACUALQAGgAoAKAE79KAF6UAFABQAlAC0ABoASgBfpQAUAJQAUAL QAUAFABQAUAFABQAlAC0AFABQAlABQAUAFABQAtACUALQAlAC96AEoAKAFNABQAGgBKAFoASgBCw DBSeT0FAC0ALQAUAFACUAFAFDWrqS1tMwjLsdo5poRmaDJMY2nmYGVvft702ykjoVO5QakRi65CY pRcRKuT94Y6mmgNLT5TJbqW2hsdB0FDBlmkAUAFABQBTvdOiu5Y5HJBT0oGmXAMDFAgoAKACgAoA KACgBaACgBKAFoASgBaAE7+1ACMPlIoApaTt8p/LChNxxg5psbL9IQlAFKbi9hCtjJOQR147Uyuh dpEhQAUAFAC0AFACUAFAC0AJQAtACYORzxQAUAFAC0AFACY5zmgBaACgBKAFoAKACgAoASgAoAKA CgCG8KraTF+F2nNCAr6LsFkgjzgdc+tDAvUALQAnegAoAWgAoAKACgBKAFoAKAEoAKAFoASgBaAE oAKACgAoAKACgBaACgBKACgAoAWgBKAF6UAJQAtACUAFABQAtABQAUAU4Mi9lDYGTkY70DLdAgoA KACgAoAWgBKAFoAKAEoAw9VIGqxYOSQAeM4FNPoNK5tr90fSkIWgAoAWgBKACgAoAWgAoAKAEoAK ACgAoAWgBKACgBaAEoAKAFoASgAoAKACgAoAKAFoAKAEoAKACgAoAWgAoASgAoAKAFoAKAEoAKAF oATPJHpQAUAFAAeBQA0thgMcHvQA+gBKACgAPFABQAtACUALQAUAFABQAnSgBaAEoAWgAoAKACgB KAFoAKADpQAUAJQAvSgBKAFoASgAoAKACgBe9ACUALQAUAFABQAlABQAtABQAUAFABQAlAC0AJgU ALQAlABQAUAFABQAUAFAC0AFACUAFABQAtABQAlAC0AFABQAUAFABQAUAFACe1AC0AFACUAFAC0A JQAtABQAUAJQAUALQAlAC0AFABQAlACUAFAC0AFABQAUAFABQAHgUAFAC0AJQAD3oAWgANABQAUA FAAKAEoAWgAoAKAEoAWgAoAKAI4w67w5yM/L9KAJKACgBKAFoAKACgBKACgBelACUAA96ACgAoAK ACgAoAWgBKAFoASgBaAEoAKACgAoAKACgAoAKAKgMN5KZLe6y8YKHYQdvr9DxTs0MtjgYzmkIKAF oAKACgBKAK2oWou7ZoycEcqfQ0AjHsiUuDFJGFyvULT0H1NizcEbBk4HOOgpAytrxC2yZ4+frTQI m0whrcMvQ96TEXKACgBaAEoAKACgAoAWgBKACgAoAKACgBaACgBKACgAoAKAEb7p9MUAVNM2eUVi ULGD8oFDGy7QIKAKTDdfoNpwgznPFMroXaRIUAFABQAUAFABQAUAJQAUALQAUAJQAUAFAC0AFACU ALQAlABQAUALQAlABQAUAFACDjNAEGojNhOM4+Q0ICHRk2WEeCCDyMU2Nl6kIKAFoAKAEoAKAFoA KACgAoASgBaACgBKACgAoAKACgBaAEoAKACgAoAKACgAoAKAFoASgBaACgBKACgAoAWgBKAFoASg CnGoXUpOeq5xRYZcoEFAC0AFACUAFABQAUAFABQBi358rVUPTdjJJqkh3NkHgVIh1AAaACgAoASg BelACUAFAC0AJQAtAAKAEoAKACgAoAWgBKAFoAKACgBKACgAoAKACgAoAKAFFABQAUAFAB0oASgB aACgAoASgAoAKACgAoAKAFoAKACgAoAKAEoAKACgBaAEoAKACgBaACgAoAKACgBKACgBaACgAoAS gAoAWgAoAKAEoAKAFoAKACgAoASgAoACQOtABQAtABQAUAFACUALQAUAFAB0oAKACgANACUAFAC0 AJQAUAFABQAUAFAC0AJQAUAFAC0AFAB0oAKAEoAKAFoAKACgAoAKADvQAUAJgZzQAUAFABQAtACU AFABQAtACUAFABQAtABQAUAFABQAUANoAWgAoAKACgAoAKACgAoAKACgAoAKAFoASgBaACgAoAKA CgBKAFoASgBaAE5z14oAKAFoAKAEoAWgAoASgBaAEoAWgBrMFH8qAFHTpigAoAKACgAoAKACgBaA EoAKADgUAJuGcUWAWgDO1LVBaOIol3y8ZB4AFNLuBYtruOYhVYE4zxRYCS6R3gdY2w2ODSQFO1u/ L2QytmTH50x2NBTkZFIQtABQAUAAAHQYoAKACgAoAKACgAoAKAMjVrAgPc228vjDID1FCDdWKOma rFbo6SlgQc4INVuP1HajdNfzxizBl2LzGOmT6/hQ/d3BeRvWkC29ukS/wipES0AFABQAUAFABQAt ACUALQAlABQAUAB6g5NABQAUAFABQAAYGBQAUAIfumgCnpk6zLJ5aFUQ7QSMZpsbLtIQUAVeftJG Mgng+lMroW6RIlAC0AAoAKACgAoAKACgBKAFoASgAoAKACgBaACgAoASgAoAKACgAoAKACgAoAKA CgCG8YLaysTgBTQCK+isjWEZjII9RTasNl+kIKACgAoAKAA0AFABQAlAC0AFABQAlAC0AJQAtACU ALQAUAJQAUAFABQAtACUAFAC0AJQAUAFABQAUAFABQAE4xx1oAKACgAoAqRsx1CX5RtAAz3osPoW 6BC0AFACUAFABQAUALQAUAJQBh6pFFNq9q+GMkPQA8c+1AzcHQUCFoASgBaACgBKACgBaACgBKAC gBaAEoAKACgAoAKAFoABQAlAAKAFoAKACgBKACgBaAEoAWgBKACgAoAKACgAoAWgBKAFoASgAoAK ACgBaACgAoASgBaAEoAWgAoAKAEoAWgBKAFoAKACgAoAKACgAoASgBaACgBKAFoAKACgAoAKACgB KACgBaAEoAKACgAoAWgAoAKACgBKAFoAKAEoAWgAoASgBaAEoAWgAoAKAEoAKACgBP0oAWgAoAKA FoASgAoAKACgBaACgBKAFoAKAEoAXpQAlABQAtABQAUAFABQAUAFACUALQAUAFACUAFAC0AJQAUA FAC0AJQAtABQAUANoAWgAoAKACgAoAKACgAoAKAFoAKAEoAWgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoASgBaAEoAWgBKACgAoAU0AFABQAUAFACUAFABQAUAMmVmiYJ97HFCBHOCaeO5I80t5 Z5XdyT6VY0rm9Z3AuY89PbvUCHXVtHcRMjr94de9F7AYtuZLCQxupKZxvPHPrVblG7G4ccdRU2Fa xl6pFJCfMgBA9euDTQ76E1hcMjrDcOC7Dg9j9KBM0Scc0hBQA10DrhicZzwcUAOoAKACgAoArX17 DZRb5WGf4V7t9KAKUeuRuGJhdVHTPf8AwqrLuIsx6jDKcJk4GWzxilYY7+0bbJBkAxRYB/2222s3 nR7VGSd3SjlYbHNahd2F95jy2+wRt8rg/e9zVW8xp9x2hGKG4LWuNjDJx0NJsDqkbcgI71IhaACg AoAKAK9/cC2tnk3KGx8u7uaaQIoWt7cebAXbdG4IYnAwaeg7Gq0gVAw5BIAxUiWpHPcJEQCeSelC GSqcjNAhaACgAoAKACgAoAKAFoASgAoAa/3G+lAFDRHDW7bQOGptWGzRpCCgCnExN0y5GQeaZXQu UiRaACgBKAFoAKACgBKACgAoAKACgBaACgBKAFoAKAEoAKACgAoAKACgBaAEoAQDBPJ+lIBskgR0 XB+Y0wH0AVtSO2wuCACRGcA9OlCBFfQARpcJbG4jJx602NmjSEFAC0AFACUAFABQAtABQAUAJQAt ACUALQAlABQAUAFABQAtACUALQAUAJQAUALQAlABQAUAFAC0AJQAUAFAC0AJQAtACUAUoQ39oT8j HHH4Ux9C7SEFABQAtAAaAEoAKACgAoAKAMTUiY9WhMaNk9T2oGjbHQUCCgAoAWgBKACgBaACgBKA CgAoAKACgAoAKACgBaAEoAKACgAoAKACgBaAEoAKAFoASgAoAKACgAoAWgBKAFoASgAoAWgAoASg AoAKACgBaAEoAKAFoABQAlAC0AFABQAlAC0AJQAtABQAUAFACUALQAUAFABQAUAFABQAlABQAUAL QAlABQAUAFAC0AJQAUAFAC0AFAAaACgAoAKACgAoAKAEoAKAFNACUALQAUAFABQAhoASgBaAFoAK ACgBKAFoAKAEoAKAFoAKAEoAKACgBaAEoAKAFoAKAEoAKAFoASgBaACgBKACgAoAKAFoAKACgBKA CgBaACgAoAKACgBtABQAtABQAUAFABQAUANdgg5zigEKrBgCpBHtQAtABQAUAFAADxQAUALQAUAF ABQAlAC0AFACUAFAC0AFACUALQAlABQAvagAoASgAJA60AFABQAUAFABQAUAFABQAtACUgGo4cEr ng45BFMLWHUAZer2eUaaFCX7hev1oQ7lDSS0cnLbZAMgsPvr3zVNBY6HeoQMSADU2EZ+qWrS7Xj2 lQPmB/nTQypod800kyOpHlHAB44+lNh5GnfxfaLNwnXHBqVoBzYnxMCWLRp8wP8Adx15q9heZ1Vv Mk8CSxnKuMg1GwElABQAUAFABQAUARXFtBcrtniVx7jpQNO2xSudDsp9x2tGxx80bYNF30YXK7eH Yfl8u6uE25GQ3Wi8urC67CDw5FtKG5mMeOmefzou+4adihqfhuCC1Mkc0m1V2lS3GKpSl3C0exZ0 jSLV4YtzPII1wpJxu+tTK47jtQs4rFGMEflp99X7Bh60IW6NHRpGksULtluc02IvUgCgAoAWgDO1 q18+3VxuzCd4Vf4uKE7AQLHC9kkzx/NEBnjmm9Ci7ZFwXUjCZytAmVLw+Ve72Tl04544pIaL9q+9 OufehiZNQIKACgBaACgBKACgAoAWgAoAa3CknpigDP0OLy7Z2xtLuWx6U2NmjSEFAFONR9qfjHOc evvQUXaCRKACgBaACgBKAFFACUAFAC0AJQAtABQAUAJQAUALQAlABQAUAFABQAtABQAlABQBBMf3 qKOpGaBonoEV9RUtYzhepQ4oBDNLXZZRKV2naMj0NA2W6BAO9AC0AJQAtABQAlAC0AJQAtABQAUA FABQAlAC0AJQAtACUAFABQAUAFABQAtABQAUAFACdKAFoASgAoAKACgBaAEoAKACgCmE26luDEBl 5X1NMfQu0hCUALQAnbigAoAWgBKACgAoAKAMHW5wmqWiBW3D5twGfbFUtgN4dBUgLQAnOfagBaAE oAKAFoASgAoAKACgBelABQAlABQAUALQAlAC0AJQAtACUALQAlABQAtABQAlABQApoAKAEoAKACg BaACgBKAFoASgAoAKACgBaACgAoAKACgAoASgAoAWgBKAFoASgBaACgAoAKACgAoASgBTQAUAIKA CgAoAKACgAoAKACgAoAWgBKAFFABQAUAJQAtABQAUAJQAtACUALQAUAJQAtABQAlAC0AJQAtACUA LQAdKAEoAKACgBaAEoAWgAoAKAEoAWgAoASgBaACgBKAFoASgAoAWgBKAFoAKACgAoAKACgAoASg AoAWgBKAFoAKACgAoASgAoAKAFoASgBaAG0AFAC0AFABQAUAFABQAHpigAACjAGBSSsAUwCgAoAW gAoAKACgAoASgBaACgBKAFoASgBaACgBKACgAoAKACgAoAWgAoASkAjMFGWIA96YDDPGIzJuyq9S OaLAOjkSRQyNkEZoAdQAUAFAC0ANZ1XqQKLAMS4hdWZZUIT7xB6fWnZgPR1kUPGwZT0I6GkDVhaA CgAx2oA57Ul+y3BKxttznIPP1FNDKWrRatcJGsCkxKN28Pjj0xTU+UOW43T9YaOQxXJeMLwd/ING jDUkuLhY5beaBojNISAqnHHrTSEauk30bM0WEQZ4AP60mguZmvqtjI1xIwFu3II/h9c0kugNGnoV 4kqCFduzbuQhs59abVgNepAKACgAoAKACgAoAKACgAoAZPEs8LxOPlYYoAw9GdrR5LRixER+XPpm n0Haxo6yf9Acj86VgItCZWtgqgjbwc02DNOkIKACgAoAQjcpHrQBlREwzSwyrgAYDMfvCgaDTXZJ /KBfy8nG4d6p6jZY1YAW4kJICnB/GkhLQdpuVi8pmDMoB4GMA0mDLlAgoAKACgBaACgAoASgAoAK AGv9xuM8UAZ3h8BbIgKVO45+tN6jZp0hBQBRt1lW8kJHydATTGXqQgoAKADPOKAFoAKACgA7UAAo AKAEoAKACgAoAKACgBaACgBKACgAoAWgA70AFABQAlAFK+d1ngWMHLZ5xwPrTQ0XR0FIRV1UsunX JQZYRnA/ChAiHQXeTTIZJOHZeabGzQpCAd6ACgBaACgAoAKACgBKAF7UAFACUAFABQAtACUAFABQ AUALQAlABQAUALQAlAC0AAoAKACgAoAKACgAoATpQAUALQAlABQBRbe9/wDKCNhGfQjFAy9QIKAF oAKAEoAKAFoASgAoAKAMTVht1OOQozKiAgKe+aaGjbHQUhBQAUALQAlABQAUAFABQAUAFABQAUAF ABQAUAFAC0AJQAtACUAFABQAUAFABQAtABQAUAFABQAUAJQAUALQAlAC0AFACUAFABQAUAFABQAU AFABQAY/SgAoAKACgBaAEoAWgBKACgAoAXtQAUAFABQAGgBKACgAoAKAFoASgAoAWgBKAFoAKACg AoAKACgBKACgAoAWgAoAKAEoAUUAFACUAFAC0AFACUAKaAEoAWgAoAKAEoAKACgBaACgAoASgAoA KAFoASgBaACgBKACgAoAWgAoASgBaACgBKACgAoAKAFoATHNABQAUAFAC0AJQAtABQAlACigBKAC gAoAUUAFADaACgBaACgAoAKACgAoADQAtACUAFAC9qACgAoAKACgAoAO1ABQAUAJQAUAGRnAIyO1 AC0AFACUAFABQAUALQAUAJQAUAR3DtHEWjXLdAKECRzGowXM9vEl5dEkSb/kXhh2/KrjNrYdrGlD YPI32i3u2BIB2noT9O1JsS0Ems5UmMjPKowG/dMQA30pcz7jaTLMF+yEJcqEGPvE9TRYT0NBHVxl CCPalYBaAKGo6gLZGEY3Pj8BTSHYyLmzvLmNrnLbiASpJ4/3aOaw2iqLIMpa4mlYDHmJjAI9aUlz rlHF8ruddEqpGqxgKoHAFJRUVZENjqYC0AJQBQ1mFXspH2bmVTgUD6WMPw/rH2vUYrSM7gsRLkA4 +lW0B0U9hbTtueJS3c461nYEzDv/AAsrs01jL5UyqQmemf6UXa2CyZkW2j6tbqd0b9TvYEZPsPaq VS4OPYL6e7aJoJ4iIR8qqUP+TRdMFGSLvhmC5+0wnyGhjhBGduAwNHNpYXLY6+kAUALQAlAC0AJQ AUALQAUAJQAUAZ95Zn7SLyHlwu1lJ4NCY7mNfXiLZNY+ZJL5hwRj5lHpVLzFa2huaRam0skQ/ex+ Q7CpAu0AFAATgZPSgBgmiyB5i89OaLAPHtQBnapavIBNCBvH3ge4ppjINIOJpJJyTI3yjByAKbYW Zf1FlWzctjAqUgRDpKjYzqpXPUHrQDL9AhaAEoAKACgAoAKACgAoAWgBrfdOPSgDP0Vy9u4PGHNN jNGkIWgDPhb/AImLxnnA3cmnYdy/SEFAC0AJQAUALQAlABQAtACUAKaAEoAXpQAlABQAUALQAGgB KAFoASgAoAKACgAoAKAKN3Ky3sKAgLgk5FNDReFIRW1If6BcYXPyHihAV9BLHT0BxgcDFNgaNIBa ACgAoAKAEoAKACgAoAWgAoASgBaACgBKACgAoAKAFoASgBaACgBKAFoAKACgAoAKAEoAWgBKACgA oAKAFoAKAEoAKAKQlB1Ex7uQOmKY+hdpCFoAKACgBKACgBaAEoAKACgDG1Jgmpws6kj5fp1pjSNm kIKAFoAKACgAoAKACgAoAKAEoAKACgAoAKACgAoAKAFoAKACgBKACgAoAKACgAoAKACgBaAEoAWg AoAKACgBKAFoAKAEoAKAFoASgAoAKAFoAKAEoAKAFoASgAoAKAFoAKAEoAWgAoAOlACUAFABQAUA FABQAtACUAFABQAtABQAUAFACUALQAUAFACUALQAlAC9qAEoAWgBKACgBaACgBKACgAoAKACgBaA EoAKACgBaAEoAKACgAoAWgAoASgBaACgBKAF6UAFABQAlABQAUALQAUAJQAtABQAlAC0AFABQAlA BQAtABQAlABQAtACUAFABQAUAFABQAtABQAlACUAFAC0AFABQAUAFABQAUALQAlAC0AJQAtACUAL QAUAFABQAUAFABQAlACBFDlwo3EYJ9qAHUAFABQAUAJQAtABQAlAC0AJQAHBGDQBn6ta+bbjYThO Qo457c0J2HuVrKeSzIW8liC7cbu5PvVbga8bpLGGUgqRUiMu60sAO8TM4c7mQ8/lRdj0Kttcz28r ieQb2O7aByB6VS1AvXmp7LfdAu6RuAp60rBYi01Xu2eS4UDgBlx1NDHexrEfKVHFIk5icSRTNE7s xz6Z496oe2p0VmxNugJGQO1SxWJqAFoASgAIBGCOKAK2y00+MuEjhXuQAKEuw2+5FFqkMk/kn5W6 0+XqTdF1WVhlSCKQxcUABUHqBSAOlMAoAWgBKACgBaAEoAKACgBrOqnBPPpRYCrDqUErMihtynBG OadgLQkQ8AjOKVgFO0jBI5oAgFrarN5vlRiT+9jmiw7skeeNASzBQOpPaiwrEikEAg5B6GgAoAra hDNPaPFbuqOwxkjNCdgOe+wanAoEiiQp825ec+1Up9xpdiK31C5guNm54wBnY33fypqwNNG1Hq6b f3jKTgdKVhEFzKIr1RbBQD8zH0+goSKMi41aSaYwOr8sNqKeDRolcnW51djCYbcA/ePJqRssUCCg AoAKACgAoAKACgAoAKAEfhW+lAFDRlC27YAALEgU2M0PrSEFAGTa2M41i4upjiIH90M+3OaLhZGt 9KACgAFAC0AJQAUAFABQAUAFABQAd+lAC0AJQAUAFABQAUAFABQAUAFABQAtACUALQBm6kzi4hCY 5600NGgv3RSEVdWDHTLoIGLGM4C9elCGhNIUJp8AGMbB0+lNgy5SEFAC0AJQAtACUALQAlAC0AFA CUAFABQAtABQAlABQAtABQAlABQAUALQAUAJQAUAFABQAUAFABQAUALQAUAJQAtACUAFAFKM/wDE xlO3GABmgfQu0CCgBaACgBCM9yKACgAoAWgBKACgDI1FYmv4lkaQMzDbtbgY/wAafQd7GvSELQAU AFACUALQAUAJQAtACUAFABQAUAFABQAtABQAUAJQAtABQAUAFABQAUAFABQAlAC0AFACUAFAC0AF ABQAlAC0AFACUAFAC0AJQAUAFABQAtABQAlAC0AFAAaACgBKACgAoAKACgAoAKAFoAKACgBBQApo AKACgAoAKAEoAWgAoAKACgAoAKACgBKAFoASgAoAWgAoASgAoAKAFoAKACgAoAKAEoAWgBKAFoAS gAoAKACgBaACgBKACgBaACgAoAKAEoAWgAoASgAoAXpQAUAJQAtABQAlAC0AJQAtABQAlABQAUAL QAUAFACUAFABQAUALQAUAJQAtABQAlACUAFAC0AFABQAUAFABQAGgBe1ACUAFABQAtABQAlABQAU AHfFAC0AJQAUAFAC0AFACUAFABQAUAFAC0AJQAUAFABQAjKGBVhkelAGZqNkmfMwTngnP3R607se g2yY22yIyrtBIBLZzTtcDQS6ifaA6hmzgHjOKVmIoazJaxKryLuk/hCnk0JDvYyFtrm4BlBm3AnO Oq+gp81h2RLaaktspRgRcMcHcTzQSXU1kx5EoUhSMknHFFgKNzeia+YJGSHOzcjZHsRQ9AN/TYZI LOOOVmLjruOTUgWaACgAoAKAKWrRs9rxt2g5YMM5FA0c8bBoS01v0x0ammNlrS9SWOSXbu2jGUJz g1W4m+5vvcRpbvPuBRFLEjtiptrYRg2/iJ7i6KRiMR7cruyC1XyoVzUTU42Ukqw2nB9jUtWC6LcM 8Uyho3BGO1JqwySkAUAFABQAtACUABztO3r2oAx10u7km825vMMTkiMYH0p3HoVLnQrqLdNZ3BeT BJVuC349qSYaEEsWqQIuI5fMIAGPmA+tPmCwyOfV5VCi0kHlkkgjAb05ockHK7EyJrV6u2SDyARj dvwRRzLoFu46Pw/eNeBru6M0OMHLH8gKFOVwSSOkRBGiovAUYFITFoAKACgCGe1guBiaNW98UDvY z5dDg8nZEzAjoTz+FGo7oq2Wi7i8hmaOUnbJt649Kd2LQlutKggIlBdmyCSetT5j0NmHPlLu649c 0yWOoAU0AJQAUALQAlABQAtABQAlADZv9U/GeDxQCKekqY7UIylWHUGmNl6kIKACgAoAKACgAoAK AFoASgAoAKACgA6UALQAUAJQAUAFAC0AJQAUAFABQAUALQAUAJQAUAZmpt5d9akKGL5Q84xTQ0aY GAKQilrRcaTdGLO8RkgChOwEfh/J0m33LhtgJGe9NgaNIBaACgAoASgANABQAv0oAKACgBKACgBa AEoAWgBKACgAoAKACgBaACgAoAKACgBKAFoASgBaACgBKAFoAKAEoAKACgBaAEoAoRndqkoYcKBt zTGX6QgoAKACgAoAKACgAoAKACgDH1BQmoRyOcksoQDt9aYzYHQUhBQAUALQAUAFABQAUAFABQAl ABQAUALQAUAFACUAFABQAUALQAUAFABQAlABQAtACUAFABQAUAFABQAUALQAlAC0AFACUALQAlAC 0AFACUAFABQAooAKAEoAWgBKAFoASgBaACgBKAFoAKACgAoASgBaAEoAWgAoAKADtQAUAJQAtABQ AlABQAtABQAUAJQAtABQAlABQAtABQAUAJQAUAFAC0AFACUALQACgAoASgAoAWgBKAD86AFoASgA oAU0AAoASgBaACgBKAFoAKACgAoASgBaACgAoAKAEoAWgAoAKACgAoAKACgBKAFoAKACgA6UAFAC UALQAUAFACUALQAUANoAKAFoAKACgAoAKACgAoAXtQAlABQAUALQACgAoAKACgBKACgBaACgA6UA FACUAFAC0AJQAtABQAlABQAUAFABQAUARXIzH0z2oQ0ZxsxKpRWXcOV56YoHsUJ7G9E4/dlogOOc nNNMPQYmkXdzPH9qX5OpwcBfpRfsTax0lvCsEYRcn3NIGxstrBKcyRIT64pDTZVk0azkYmRCwJzg niiwXHW+k2NrO08MCq57+n09KLBcvUxBQAUAFABSARlDKVPQ0wMO7SSxkBXp5gYcfw+lNFGVr81p bxNPbsiPu3bRwHP4VauhC6dqsYsgdrslwcMsfT3I96GrgizZwWV4VEkJLfcDAYZRUWsC06Fu50EJ A32NyX6gSN1P1ouGhk38t5bpALhTCN2AoHHvx3q0waNjStZEkZFwwIH8QHb3FTa70QkbYIIyOhqQ CgBaAEoABQAYoAKACgAoAKQBTAKACgAoAKACgAoAKAM6CYQXEyurhRzuI4P0p6DZWi1AXuoG1SOT IGWz0UU2lYEbQGBgdqkQUALQAlABQAUAFABQAUAFABQA2TiNvpQCKGh7jZ7nfcSxpsfQ0u1IQUAF AB2oASgBaACgAoAKAEoAWgAoASgAoAKAFoASgBaAE9qACgBaAEoAKACgAoAWgAoASgAoAzr/AAL2 EnBwMAdwfWmho0B0GKQitqv/ACDbnAB/dngn2oQEOhFjpcBYANtwcGm9ANCkAUALQAUAJQAtABQA UAFABQAUAFABQAlABQAtACUAFAC0AJQAUAFAC0AFACUAFABQAooASgBRQAlABQAUAFABQAUAFABQ BRbb/aajeen3QO/1pjL1IQUAFAB0oAKACgAoAKACgAoAxNVAXUoJOMYAfPTGf51S2GbY6CpEFABQ AtACUAFABQAtABQAlABQAUALQAUAFABQAUAJQAtABQAlAC0AJQAUAFAC0AJQAtACUAFABQAtACUA FAC0AJQAtABQAlAC0AFACUALQAlABQAUALQAlABQAvSgBKAFFABQAlAC0AFABQAUAJQAtACUALQA lAC0AFABQAdKACgBOlAC0AFACUALQAUAFABQAlAC0AFACUALQAUAFACUAFAC0AJQAtACUAHSgBaA EoAKACgAoAKACgAxigAoAKACgAoAKAFFACUAFABQAUAFABQAtABQAUAFABQAlABQAvegBKACgAoA WgAoAKACgAoAKACgAoASgAoAWgBKAFoAKAEoAWgBtABQAtABQAUAFABQAUABoAKACgBaACgBKAFF ABQAgzzn8KAFoAOlABQAUAJQAtABQAUAFABQAUAFACUALQACgBKAFoASgBaAI5lDxsp7igEZdlJu ZdjBSjHIK8kelGhbNZTkAjoaCBaACgAoAKACgAoAWgBKACgBaACgCC7gFxA0ZJGRwRQBxcem28k8 huDJFOpI+Y5H5U9R6IS6sJtM/wBKmB8pCCvl/MuT3I9aal3E1pczotQuobmSI3YIPzFicFx71V+i Q2rLU6PSfFAltovtERXPyhtwOfxo5U9ibmib2G+hkSVEeIjGM4OfWpcUNO2pzN7ZS6dMsqnNtJ8v yHBI70ou2g3Y6rQ7jfGYfM3hQCvqo9CackxGpUgFABQAUAFABQAtACUAFAAx2gmgABz0oAKACgAo AKACgAoAwfEAXz4v9IMZ4yvamr9B2Ltg9vCr7CWfPzv6mhoC8kyNjB60rCsPoAKACgAoAKACgBaA CgBKACgBHwEJPTHNAFHRxCLY+Ru27jyfWmxl+kIKAFoADQAlAC0AFACGgAoAKACgA+lAC0AFACUA HegBaACgAoAKAEoAKAFoAKAEoAWgBKACgAoAyNWRn1C12FhjlvQimnYaNdfuikIqauM6bc/7hoQE Ogbv7LgLNk4psDRpAFABQAtACUALQAUAFABQAUAFABQAUAJQAtABQAlAC0AFABQAUAFACUALQAUA FABQAUAJQAtACUAFAC0AJQAtACUAFABQBVCqL0ncNx7Ux9C3SEJQAiMHXIyPqKA2FoAKAFoASgAo AKACgDnNZl36xDFj7pXGR8uT/WqQ0jox0FSIKAFoAKACgAoAKACgBKAFoASgAoAWgAoASgBaACgB KACgBTQAlAC9KACgBKACgBaACgBKAFoAKAEoAKACgBaACgAoASgAoAWgAoAKAEoAKAFoASgAoAWg BKACgAoAKACgAoAWgAoAKACgBKAFoASgAoAUUAFAAKACgA6UAJQAtABQAUAJQAUAFAC0AFABQAlA C0AJQAYoAWgAoAKACgBKACgAoAKAFoAKACgAoAKACgAoAKAE7UAFABQAUAFAC0AJQAUALQAlAC0A FABQAUAFABQAUAJQAtACUAFAC0AJQAtACUALQAlABQAtACUAFABQAUALQAUAFABQAUAFACUAFACU AFAC0AFABQAUAFABQAUAFACigAoAKADpQAlABQADpQAUAFAC0AAoAO9ABQAUAJQAUAFAC0AJQAtA CUALQAUAJQAtABQAUAZeowFZEdI/lzklTgincpDrC6DSNErqyoOeec0WEaORnGeaQgoA53xBqk8d wLOGCQg9SpwTVKyHZlfT9SuoxtO5R12vyad0xF6LXcPtdRx1OccUWuBsQTpMCUzx6ioaAkoAKACg AoAWgAoAoX2mwXOX8seaOhzjNA7mbYRTRE2EtpKYjn5zyoHpTeq1GmyK+8I21xIvlERRDhlA5I9D Uu4i9D4b02C2jgiiKCM5UqxBBoBu5TufD8kEjXFpduTjG1/SnzMejMa7imhWWK6ZpGZjsRTyR6rV J6e8FrbHReF7Oa1swZo/L3DhCcn8aliNugQlABQACgAoAKACgAoACQoJPAFAFNNQhkmEabmznJA4 FOwWJOY5Bz8rdDQMlSQMSPSkFh9AgoAWgBCcdaACgDIv9HmubhpVuiM9FYZA+lF2PQjt9FuYY9jX xfP3iVxmi7FZF+xsfszM8krSO3c8ACi4adC4aACgAoAWgBKAFoASgAoAPagAAxQA2THlsD0xQBR0 Ug2uV4GeBQNmhQIKADNABQAUAFAC0AFABQAUAJQAtACUAFABQAUAFABQAtABQAlAC0AFABQAUAFA CUAFABQBn3jf6ai7lXgHn600NGgOgpCKOtyGLSrlxjITuKEAmhndYIQML2psC/SAWgAoAKACgAoA KACgAoAKAEoAKACgAoAKACgAoAUUAFACUALQAlAC0AFACUAKaACgAoATvQAtACUAFAC0AFACUALQ AlABQBS5GoncvGPlNA+hdoELQAnSgAoAWgBKAFoAKACgAoAw9RiEms24IVlADFT256imtho26Qha AEoAKACgAoAKAFoASgAoAWgAoASgBaAEoAKACgBaAEoAWgAoAKACgBKACgBaAEoAWgBKACgAoAU0 AJQAUAFAC0AFACUAFABQAUAFABQAtACUAFABQAUAFABQAtACUAFABQAUAFABQAUAFABQAtACUALQ AUAFABQAUAJQAtABQAUAJQAUAFAC0AFABQAUAFABQAUAFAB0oASgBaACgAoAKAEoAWgBKACgAoAW gBKACgAoAO9ABQAUALQAgoAWgBKACgAoAWgAoAKACgAoAKACgAoAKAEoAKACgBaAEoAKAFoASgAo AWgAoAKACgAoASgAoAKAFoAKACgAoAKAG0ALQAUAFABQAUAFABQAHgUAFABQAc59qACgAoAWgBKA FoAKAEoAWgBKACgBaAEoAKAFoAKAEoAXtQACgAoABQAlAC0AJQAtACUANljWWMxuMq3WgDD1GCWy kkuYCSAvKnAH1zTW+g7lTRtTeORluYmjkc5Cl8gD2qmr7BtodPG6yKGU/wD1qgRn67bmWzLx43xn PTtRr0AoaXhnWOSNCq8Zfrz6VTRQ/VtJRUlkgBw/JX0pasRFp9zEu0OdixEKWJOWPbin0uGyOiU5 AI6VIh1AAaAEoAKAFoAKAEoARiFGWIA96AGfaIcE+YuB3zTsBICCAQeDSAZ5Ue/fsXd645pDuPpi CgBaAEoAKACgAoAKACgCG9iaa0ljRtrMpAI7UAc5ZP8AZGAnc7SCFP8AeqtXsM2dLk862KMBgdCP SkwIH82G6jhDc7s5HXHvQM1x0FIkKACgBCucc9KAElkSFC8jBVHehK+wBFIkqB42BU96LAOpAFMA oAWgAoAKACgBKAF7UAFABQAlADZv9U/b5TQCKOh4+wrtIKkkgimwNCkAjHapPoKAKemySSKTKRv5 yB0oGy7QIKACgAoAKACgA70ALQAlAC0AJQAUAFABQAtABQAlABQAtABQAUAJQAUAFABQAUAZGp2l 2+pwT26qY1GGz1607jRrikIpa0nmaXcptByvQ0bAGjDbp0K8cLjihjZdoEFAC9qAEoAKACgAoAWg BKAFoAKAEoAKAFoASgBaACgBKAFoASgBaACgAoASgBaAEoAU0AFABQAlAC0AJQAUALQAUAFACUAF AFc7vtgwRtxyKB9CzQIKACgAoASgBaACgAoASgAoAydQ+TU4WBXLgD5s8c0x9DWpCF7UAJQAtABQ AUAFACUALQAlABQAUAFAC0AFABQAUAJQAtABQAlABQAUAFABQAdqACgBaAEoAWgBKACgAoAKACgB aAEoAKACgAoAUUAFABQAlABQAUALQAlABQAtABQAlABQBH58X2j7PvHm7d+32zjNFgsS0AJQAUAF ABQAtABQAlABQAvSgAoASgAoAKAFoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoABQAUAFABQAU AJQAtACUALQAUAJQAUAKaAEoAWgAFACUALQAUAFACUALQAlABQAtABQAUAFABQAUAFACUAFAC0AF ABQAlAC0AJQAUAFAC0AJQAtABQAUAFABQAUAJQAtABQAUANoAWgAoAKACgAoAKACgAPvQAdqAFoA SgBTQAUAJQAUAFAC0AFABQAdKACgBKACgBaAEoAKACgBaACgAoAKAEoAKAFoADQAUAJQAjKrqVYA g9QaAMPWNNRT58UO4j9B7UK5W5FaXz2l0EZWEcg/yarRg73ubxKTwsBhlYEGpJOYjaSKedInSM54 LHOzH86u2mo9NjqVBaMbupHNQI53UrNYr15sEk/NyeB707sb1NnS5RLaKQ+/HBbHWkxbFygAoASg AoAWgBKAFoAwPEcF/dSxQWMBdcHc5cKq/wD16alYdu5Hb6ZeWIJLl+BnHIP4U3JvcLdibS9UJhl8 7C+S+0j1+lDQeptRurqCpqRDqAFoASgBaAEoAKACgAoAbJGsi7WLAdflJH8qL2BOw+gDktY81NXk ijiPl7Q4YrkLnrV8ySG7lnTLtLJSZXCxKDge/tRYVyxp8L3t1LdSFgpOFI4yPapb7D2No5BGAMd6 QhaACgBaAMHxPFM0ccisREnJAHeqi+gWRX0i9NvKIQ6OuAXGe/tTeu4eoXmsu08/lljHGcAocEUW sFh2k6jGrx7pJAHByXy2eeOaGtQOjHtUAFABQAUALQAlAC0AHagBKACgBH+6fpQBn6DEIbBVGOpy AOnNNjNGkIiumCW0rE4AUnNAFfTAohBQ5UjOaBsu0CCgAoAKAFoADQAlABQAUAFAAOelAAaADtQA UAFAC0AJQAtABQAUAJQAUAFAC0AFACUAFABQBn68AdIuR6r/AFpoCXS08uzjHH3R0pMbLdAgoAKA CgBaACgBKAFoAKAEoAWgAoAKAEoAKACgAoAWgAoAKACgAoAKACgAoADQAUAFABQAlAC0AJQAUALQ AlAC0AFACUAVin+nB93O3GKB9CzQIKAFoASgAoAWgAoAKACgBKAMnVoBJe27ggOhBGT1pj6GsOlI QtABQAlAC0AFABQAdKAEoAKAFoAKACgBKAFoAKACgBKAFoAKAEoAWgBKAFNABQAUAHSgBKAFoAKA CgAoASgBaAEoAKACgBaAEoAWgAoASgBaACgBKAFoAKAEoAKACgAoAKAFoAaERXZwo3NwT60rdQv0 FpgFABQAUAFABQAtACUALQAlABQAvSgBKAFoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg BKAFoASgBaAEoAKACgAoAWgAoAKAEoAKACgBaAEoAWgBKAFoASgAoAWgAoAKAEoAWgAoAKACgAoA SgAoAKAFoASgBaACgAoAKAEoAWgBKAFoAKACgAoAKACgAoAKACgBKAEoAWgAoAKACgAoAKACgAPv QAtABQAUAJQAtABQAUAFABQAUAJQAtAAaACgAoAKACgBD7UAFAC0AFABQAUAFABQAx5FRkVsgucD igB9ACUALQAlAAQCCD0oAxdU0l5FZrcgjg7O/wBKpMpMoXMmo2Z8uKFmQdNhxn/69HMuorE2j6LL Hdi7lY7X+d1cHIb29qXMFkjo6QirfWwnCfIGwe/agaJ4IlhjCIAAPSgRJQAlAC0AIzBRljgCgApA FMAoAKACkBnX2mRy7pIxsckMcdyKeo9zMstRFvctDIx4+ZAvVhV20E3bQ37aYTwrIBjPUelQBLQA UAFABQAUAFABQAUAFAEF3aRXSbZV/EUAU4dCtI2JbdIP7rn5R+FLXqO9tjSUBVAUAAdAKYhaACgA oAKAEYAghhkHtSA5PUbZrHVfNhhhjiC7ge5rSNtitSbRjHc3s0aqsiHJYngrUslMh1CzfTp2CMfL YfJkk0Rctga7HR6ZK01lG0mN+OcdKGBapAB5oAWgBKACgAoAWgBKACgBsgBRgemKARS0VdtigBJA yBn602Mv0hEF8dtnMcKcKeG6GhAQaUd0O4gDIHA6U2Nl6kIKACgAoAKACgAIyKAAUAFAC0AFADXQ OpVhweooBOwtABQAtACUALQAlAC0AJQAvagBKACgAoAKACgBaAEoAo646xaTcu4yFQ0IEJorM2nQ tIu1yoyM5psC/SAKACgBaACgAoAKACgAoASgAoAWgAoAKACgAoAKACgAoASgBaAEoAWgANABQAUA FABQAlAC0AJQAUAFABQAtACUAFABQBULAaiFbAJXK4HJ+tPoPoW6QgoAWgAoASgBaACgAoAKAEoA yrwxPehm3F4mAxj1poaNUUhAfagAoAKACgAoAKACgAoAOlAC0AJQAUALQAUAJQAtACUALQAUAJQA tABQAUABoAKAEoAKAA8UALQAUAFABQAUAFABQAlAC0AJQAUAFAC0AJQAUALQAlAC0AFABQAlABQA UALQAlAC0AFACUALQAlAC0AJQAUALQAUAFAAaAEoAKAFoAOlACUAFAC0AJQAUALQAUAFAAaACgAo ASgBaACgAoASgBaACgBKACgAoAKAFoASgBfpQAlABQAUAFAC0AJQAtACUAFAC0AJQAtABQAlABQA tABQAUAFACUALQAlABQAtACUAFABQAtACUALQAUAJQAUALQAUAFABQAlABQAe1ABQAUAJQAtABQA UAFABQAUAFABQAtABQAlAC0AFABQAGgAoAKAEoAWgAoAKADpQAUAJQAtABQAlAC9KACgAoAKACgA oASgBaAEoAWgAoASgCCe7ggyHcAjt3ppNgRfbomcqV+UHG4kYJo5R2LCTxsCcjA6n0pBaxIDQIWg AoASgAoAWgCK6DmBxFjfjjNAFK2vwEVpsqSQhz61VrjZo1IgoAWgDm/Euvy6c7QW0TM+0fMEJxmq XKtwa0Mm08R6go/fFexw45x/ntT0b0J5Wh2o6klzLDPBEonwc46sPSiyWrLu3oangqS6ns5ri7t5 ICz4VZBg4FRzJ7Cs1udHQAtACUAFABQAtABQAlABQBS1PUYbCIl3Acj5e/NNRuBlf8JDINqCHdJj L7c4HvVWQ7WLFrrRmZiFUxggccEUrCNeCZJ4xImcH1FS9AJKAEoAKADGM4oAxtStmvgnzMHhb+E8 kHrQ7o0jYv6fY29lGRbpjfyzHqfrSIHXtqt1FtOM+pp2BOwtnbR2kIij6dT9aBMnoAWgBKACgBaA CgBKACgAoAbLxG3bihAinozb7JW49OKbGXqQivf/APHjPkZ/dn+VC3Ar6MHW2RW5XYMe3sabG0aF IQtACUAKKAEoAKAAUALQAUAFABQAUAFAB9KAEoAKACgAoAKACgAoAKACgAoAWgBKACgApAUNdIGk 3IZdwKYI+tMA0Qn7BGCDwMDPei1gL9ABQAUAFABQAUALQAlABQAtAAaAEoAWgAoASgBaAEoAWgAo ASgBaAEoAKACgBaACgAoAKAEoAWgAoAKACgAoAOlACUAFABQBSEh/tJo8ZGAc+lMfQu0hBQAooAK AEoAXpQAUAFACUAFAGTeEf2nGQRuUcg00UjWHQUiRaACgAoAKACgAoASgAoAKACgBaACgAoAKACg BKAFoASgBaACgAoAKAEoAWgAoASgAoAWgAoAKACgBKACgBaAEoAKACgAoAWgBKAFoAKACgBKAFoA KACgBKAFoAKAEoAKACgBaADpQAUAFABQAlAC0AJQAUAFAC0AJQAUAFAC0AFABQAUAFABQAUAFACU ALQAUAAoAKACgAFABQAUAFABQAUAJQAUAFABQAtABQAUAJQAUAFABQAUAFAC0AFACUALQAUAFABQ AlABQAtABQAlAC0AFABQAUAJQAUAFAC0AJQAtABQAlABQAUALQAUAFABQAUAJQAtABQAlABQAlAB QAtABQAUAFABQAUAFAC0AFABQAlAC0AFABQAUAFABQAUAFABQAUAJQAUALQAUAJQAUAFAC0AFABQ AlABQAd+tAC0AJQAtAGTrF4wSS2tmAl25JJx+VUl1E0NtdJ3oHu5nckcAHpUtsrQmfRrZmLbpAx7 7qfMwuRTWs1uoVCZEYYbdRcFYfaXp2YlATHAHb86bVg62L8E6TJujYHscdjUtCsSUAFABQAtABQB z+q2wt7oygMyS8Yz90+1NNj3NDSbkzQlJG3Oh6+ooYWL9IQUABAPYUgImtoHzuhQ59Vosh3ZFHpt lFJ5kdrEr/3tvNFg5mWqYgoAKACgBaACgAoASgAoAKAI2gjaTzDGpfpkjtSsFxJWhhXdJtQE4yaF ELmfqNjbSqzwusU2M8HAb6inZoZDpF75l0IQ56fdPbHpVNCNupAKACgAoAz7mVorsJsXDjg56mmU Xd6hQWIFIkjS8gkOEkBOcYp2sBPSAKAFoAKAEoAKACgAoAKAFoAiuf8Aj3kxwdpxQCKehM7abEZG Vmx1AxTYM0KQFfUeLGc+iGhAiDSuIwWZd7KDgelMbL9IQUAFABQAtABQAlABQAUAFABQAUAFABQA tACUAL3oASgAoAWgBKAFoASgAoAKACgAoAKAKGvYGj3Wc42HpQtwDQ4xHpkAVsgrnNA2aFAhKACg BaACgBKAFoASgAoAKACgBaACgBKAFoAKAEoAKACgAoAKAFoAKAEoAKAFoAKACgAoASgAoAWgAoAS gBaACgBKACkBTjjVdRlcL8zgZPtVDtoXKQgoAKAFoAKAEoAKACgAoAWgDH1QmO8jkT7y4+71600M 1x0pCFoASgAoAWgAoADQAlACigAoAKACgAoAKACgAoAKAEoAKAFoAKAEoAKAFoASgAoAKAFoAKAE oAWgBKAFoASgBaAEoAWgBKACgAoAWgBKACgAoAKAFoAKAEoAKACgBaACgBKACgAoAKACgAoAWgBK ACgAoAWgAoAKACgAoAKACgAoASgBaACgAoASgBaACgAoASgBaAEoAWgBKACgBaACgAoASgBaACgA 7UAJQAtACUALQAlABQAUAL2oAKACgAoASgBaACgAoAKAEoAWgBKACgBaACgAoAKACgBKACgBaACg AoASgBaAEoAKACgBaACgAoASgBaACgAoAO1ACUALQAUANoAWgBKAFoAKACgAoAKACgBaACgAoASg BelACUAKaAEoAWgAoABQAUAFABQAUAFABQAUAFABQAUAFABQAdKACgBKACgBaAEoAWgDmZV86/YM y5YnCH+dVZ7jsdIoAUAdAKkQtABQBSvNOhmQlUAftigdykrtabUM0SBV+cDqfwqldg9CVdYRNgmX apOCc9KOVsTNUdM1IC9qAEoAKAIL22W6gaNuv8J9DQCOesWeynld8+bHwy9ttXqx2sblpqtjdxl4 LhCAcHPGD+NJwaJLasrcqQR7VNgFoGFABQAUAFAB0oAKADvigAoAWgAoAKAEoAKAMbXdMvr90Nrf GGNesePvH60Xa2Cxz09tfp8l7IYZVb5JsEqfY1fO+iCxu+GrZI0aWV99wWI3dB+AqW7jN2kIWgDn 9c1KSKcQwSOu0fNsX+vaqWgWIG1jzElJeRcY2YHT3NMDKv76W6lQy+cEA+ViMAH1ouug3F2Ltva6 hNahYN5bfyS2BilzWFymlZaPOJopbuQZjORtPX2NLmY3Y3KQgoAKACgBaACgBKACgBTQAUARXG7y JNmN204zQBR0BZEsFSXOR3Pemxs0ulIRBf8A/HlNxn5TQgRV0pDGzoTyFBI9DTY2aNIQtACUALQA UAFACUAFABQAUALQAUAJQAUAFABQAtACUAFABQAtABQAlABQAUAFABQAUAZniTP9iXQVgpKgZP1F C3As6Yuy0jXbtwo4xjtQNlqgQUAFABQAUALQAlABQAtABQAUAJQAtABQAUAFABQAUAFABQAUAFAC UAFABQAtABQAUAHegAoAKAEoAWgBKAFoASgAoAKAKqAG+dgzEgYI7CgZaoEIGJYjacDv60ALQAdK ACgBaAA0AJQAtABQBh385/teOAttXgjjrVW0Gjb7VIgoAWgA6UAJQAUALQAUAFABQAlAC0AJQAtA BQAUAJQAtABQAUAFACUAFABQAUAFABQAUAFAC0AFACUAFAC0AAoASgAoAKAFoASgBaACgAoASgBa AEoAKACgAoAKAFoASgBaACgBKAF7UAJQAUAFAC0AJQAUALQAUAFABQAlABQAtABQAlAC0AFABQAU AJQAUALQAUAFACUAFAC0AIaACgBaAEoAWgAoASgBaACgAoASgAoAKACgAoAKAFoAKAEoAWgBKAFo AKACgBKAFoASgAoAWgAoAKAEoAWgAoAKAEoAWgBKACgBaAEoAWgAoASgBaACgBKAFoAKACgAoASg AoAKAEoAKAFoAKACgAoAKACgAoAWgAoASgAoAWgAoAKACgAoAKAEoAWgAoABQAUAJQAtABQAUAHS gAoASgBelACUAFABQAUALQAUAFAHO3Ris7+Vw2Pb0z1xTS6jLEWrLDbwRbDucYUk8D6+lO3clJLR Cpq04kcvCPIXjeM0WGlctW2pxTsgwUL9AetJoC4siMMo6kexpWArXn2ZkcSBGYLkjviiw72MTTbc XpRPLHlRvkgdR6Zpth01OmpCCgAoAKACgDmPGMV1GI7m0bb2b5cimnZg1dHJ3ljqGrS28on+zTBM KoHDfUU+eS+EXLcuQ6Tf2AjJaRZkbmRCQrH6UKq2PksXode1SKR1mlYufugxfLQmrXsKzNWDxBcZ AeFWHTd0zRo3YEmSL4lHIa0Y4xna1PlQX7GlDq1rKASxT/eGMVLiMvKQyhlOQehFIAoAKAAjIIoA KACgAoAKACgAoAKAI7m3iuYminQMh7GgDIS3axu2wVI2/KCfvU9wNe3lMsKuV2k9QaQEtAEbxRvk OinPXIosFyOOzt487IUXPXjrSsPmZW1qItp7mNF3r0yOlOyBNmfp99LDaYSMyFBhiTgZ9qphYvaV qbXlurzQmKTJBUn9aTt0El3NFWDDI6UgHUABoASgAoAUUAJQAUAFABQBDeHFpMc7fkPPpxQgK2iM xsYg7h22glgKb3Av0gIb0A2cwJwNp59KEBS0hHV5C5JJAB56+9MbNOkIKACgBaACgBKACgAoAKAF oAO1ACUAFAC0AFABQAlABQAUALQAlABQAUAFABQAUAM3fvMZ/CgY+gRQ14H+yp9oG7Axnp1FCAn0 8sbSMuQW2jd9aGDLFAC96AEoAWgBKACgAoAKACgAoAWgAoAKAEoAKACgBaAEoAWgBKACgAoAKACg BaACgBKACgAoAKAFoASgBaACgAoASgAoAKAKIEP9psVU+bjkg9RTH0L1IQUALQAUAJQAtABQAg6U AKKAEoAybqM/2xFKxGwLgD3p9Bo1qQhaACgBKAFoAKACgAoAKACgAoAKACgBKACgBaACgAoASgAo AWgAoAKACgAoASgAoAWgAoAKACgAoASgAoAWgBKACgBaAEoAWgAoASgAoAWgAoAKAEoAKACgAoAK AFoASgBaACgAoAKADpQAlABQAUALQAUAFABQAUAJQAUAFAC0AFACUALQAUAJQAUAFABQAtABQAlA BQAUALQAUAFABQAUAAoAKAEoAWgAoASgAoAKACgAoAKAFoASgBaACgA6UAJQAtABQAUAJQAtABQA lAC0AFACUALQAUAJQAtACUAFAC0AJQAUAFABQAtACUAFAC0AJQAtACUAFABQAUAFACUAFAC0AFAB QAUAFABQAUAFAC0AJQAUAFAC0AFABQAUAFABQAUAFACUAFAC0AFABQAUAFABQAUAFACUALQAlAC0 AFABQAlAFO9023vMmRfmIxkUDuZ58PRKxZG91B7H1ouwViWHRFiDfvWyygEDoPpTUmguinPZXtvO rZaZyTiRRjaOwNCaGvIj8u/8uNFEpBO4sFIOafNYLE8ekTXc4uJ5HXJG5WHYelLmDY3Le3jto9kK 7R1+tSlYTdyWmIKAEoAWgAoAjmiSaNo3GVIxQC0OOuYW0y9NsMqqjfG2evNUnfcdrbHS6TdG7tv3 wXzUOD7+9JoRceGNxteNSPpU2C5XbTLNjkwID6jijbYd2VptBsnDbFKMe4J69uKFoFyCHw8kThvt D/e3MMDk96rmYXRtIixoqKMKowBSELQAUALQAlABQAUAFABQAUAZ2taj/Z9v8mPNf7gPSml3EVbP XQ8my5j2DIAcHg07dh+Q/XLi3awbey7hyoz1pJMNCfw/k6ZE5Z23DILdaGFjRpALQAlAEdyoe3kU ruBU8etAIwNPlKyRRRuGR3w8bDlaq2hRoala7IhJEPunnnoKSETWdwjBFVs7h69KAZdqRBTAKACg AoAKACgAoAKAIrsE2soXrsOKEBW0ZSmnxhuuKctwZepAV9RBNjOAcEoaEBR0TG9ggG3YvOe9NjZr UhC0AFACUALQAlABQAUAFABQAUALQAUAFABQAUAFACUAFABQAUAFABQAtACUAFAFBN41aX5gVKjA 70+hXQv0iTO8Q8aPc9QcDBHbkULQaJdJRo7GMOctjk460MGXKBBQAtABQAlABQAUALQAUAFACUAF AC0AJQAUAFAC0AJQAtABQAUAFACUAFAC0ABoASgBaAEoAWgBKAFoASgAoAKACgAoAKAKkaFdQlcd GAzQPoW6BBQAUAFABQAUAFACigBKAFoAyrhI31P5yAUUEZp2GjUpCCgAoAWgAoAKAEoAWgA6UAJQ AtABQAUAJQAUALQAGgAoAKAEoAOlABQAtACUAFABQAUAFABQAooAKAEoAKAFoAKACgAoAKACgAoA KACgAoASgAoAXtQAUAFACUAFAC9qAEoAWgAoAKACgBKACgAFAC0AFABQAUAFACUAFABQAtACUAFA C0AJQAvagBKAFoASgAoAWgAoAPpQAUAJQAUALQAUAJQAUAKaAAUAFABQAlABQAUAFABQAUAFAC0A FACUALQAUAFABQAUAJQAUAFAC0AFACUALQAUAJQAUALQAUAJQAUAFABQAUALQAlAC0AJQAUAFAC0 AFACUAFAC0AFACUALQA2gAoAWgAoAKACgAoAKACgBaACgAoASgBAwI4oAdQAlAC0AFABQAlAACGA KkEHoRQAtABQAlABQAUALQAlAC0AJQAUALQAUAAoAKACgBKACgAoAMUAFABQAUAFAC0AJQAUALQA lAC0AFABQBn61Zi6snwoMiDcvHX2oH5HLabqBtnhutkiKCRMuOce+attPqDTW6O3Rg6Ky/dIyKgQ tAC0AJQAUAFAC96AEoAKAFoAKAEoAKACgBkkUcq7ZUVh7igLmbJoVsxco8iljnrkCgdyJPDlsLjz XllZcYKFuDRqF0jZRFRQiAKqjAA7UCFoAWgAoASgCvFZwQStMikNz36fSgdzm5dekeaUBj5edu0r 0zVWQiXw8ZJrjc8hMcbHGR/KhjsdRUiEoAKAFoAKAEGcngY7UAFAC0ABoAhuyVtZSoyQhwKEBBpH /HjFkEHHQ0MGXKAIL7P2Kfb97YcY+lCAo6DIHh4PzBRu4xzTY+hrUhCUALQAlABQAUAFABQAUALQ AUAFACUALQAlAC0AJQAUAFABQAtABQAUAJQAUAFAFEyKNRK8bgMcdfxpjL1IRR1tEfS51cMVI6Ke etCAl0/AtI9pYjA+91oGyzQIKACgAoAWgAoASgAoAWgBKAFoAKAEoAWgBKAFoAKAEoAKAFoAKACg AoAKAEoAWgBKAFoAKAEoAKACgAoAKACgAoAKACgCnGrjUJT/AAEDqehoH0LlAgoAWgBKACgAoAKA CgBaACgDHu9zaoFRR9z5iR1HpTGa46CkIKAFoAKAEoAKAFoAKAEoAWgAoAKAAUAFABQAUAJQAtAB QAUAJQAtABQAlABQAUAFAC0AFABQAGgBKAFoAKAEoAKACgAoAWgAoAKAEoAWgBKAFoASgBaACgBK ACgAoAWgBKAFoASgBaACgANACUAFAC9KAEoAKAFoAKACgBKACgAoAKACgAoAKACgBTQAlABQAtAC UAFABQAUAFABQAUALQAlAC0AJQAUAFABQAtACUAFABQAUAAoAKQC0wEoAKACgBaACgBKAFoAKAEo AWgAoAKAEoAWgAoASgBaACgAoASgBaAEoAWgAoAKAEoAKACgBaACgAoAKACgAoASgAoAWgBtAC0A JQAtABQAUAFABQAUAFABQAY5zn8KAFoATjtQAUALQAUAJQAd8UAH16UAAAAwBgUgFpgJQAtACUAF ABQAUAFAB0FAC0AFABQAUAJQAtACUALQAUAFACUALQAlABQAUAFAFbUrsWNlJcFd20cChAc3ceJb rdHEkQzIwG5ewqvdCzOk08TC3Bncsx9e1JgWqQBQAlABQBiXnh5Lu63vOwhzkoByfx9KLjubSKFU KOwxQIdQAhoAKACgAoAWgAoASgAoAWgAoASgAoAKACgAoAKAFoASgBaAEoAKAIJbO2lBElvGwPXK 0h3aMvC6fd+QsYWOT7u3oKpDubSnKg0iR1ACUAFAB36UAFAABjpQAtACUARXWfs0mDg7TzQBBpRY 2Me4nIGKGBcoAiusi2lwcHaefwoQGdokrSZBxgL17mmx9DWpCCgA70AFAC0AFACUAFABQAUAFABQ AtABQAUAFACUALQAmOKAFoAKAEoAWgAoASgAoAzkh2arLKrKS4AK4wQAKY+ho0hFLWcDTpSc4GCc fWmtwH6bMlxarJH0ND0C9y1SAKACgAoAKACgAoAKACgBaACgBKACgAoAKACgAoAUUAJQAtABQAUA JQAtABQAlABQAUAFABQAUAFABQAUAFAC0AJQAUAVf+Yhwf4cEUD6FqgQUAHSgAoAWgBKACgBaAEo AWgDIu941RfKbBI+YHoBTK6GsOlIkKACgAoAKAFoASgBaACgAoAKACgAoAKACgBKACgBaACgBKAF oASgBaACgBKACgAoAWgBKAFoAKAEoAKAFoAKACgBKAFoAKAAUAFACUAFAC0AJQAUAFABQAUALQAl ABQAtABQACgBKACgAoAKACgAoAKAFoASgBaAEoAKACgAoAKAFoASgA6UAFABQAUALQAUAJQAtACU AFAC0AFACUAFACigAoASgBaACgAoASgAoAKACgANABQAUgFpgJQAtACUALQAUAJQAUAFABQAUALQ AUAFABQAUAFABQAUAJQAvSgBKAFoAKACgAoAKAEoAKACgBaAEoAKACgAoAWgBKACgBKACgAoAWgA oAKACgAoADQAUAFAC0AFABQAhHIOTxQAUAFABQAUALQAUAJQA1yVQlV3Edh3oAdQAUAFABQAtACU AFABQAtABQAlABQAtABQAlABQAUAFABQAUAFABQAUANmiSaNo5VDIwwQaQJ2KdtpNlayO8UIy+Mg 8igZf6UxBQAlAC0AFACUAFABQAUAFAC0AFACUAFABQAjBuNpA554oAWgAoAKACgAoAKACgAoAKAC gBaAEoAbK4ijZ26KM0IDnpvEDM5RR5Sg4LdTn0xV2QirdXk15dQJGfNZjtO0bSoPc0NWKsdYi7EV fQYqBC0AFABQAUAFAC0AFACUAQ3oJs5gOuw/yoW4EOkbhp8IcYYLg02DLlIBk2BE+4ZGDkUAUdLG 0LyBuGQB6dqBs0aBBQAUALQAlABQAUALQAUAFABQAUAJQAv0oAKACgBKACgAoAKAFoAKAEoAKACg AoAzlUNqshDHcoHA9KYzRpCMzxJ/yBrjnHT+YpoCbRlCadCAu35elIbdy7QIKACgAoAKACgBaAEo AKACgAoABQAUALQAlABQAUAFABQAUALQAlABQAUAKKAEoAKAFoASgAoAWgBKACgAoAKACgAoAKAK AJGrNgcbRzQMv0CFNACUAFABQAtACUAFAC0AJQBkXjKuqxqyjaw655z9KdtBmuOBSEFABQAtABQA UAFABQAUAJQAtABQAUAFACUAFABQAUAFAC0AFABQAlAC0AFABQAGgAoASgBTQAUAFACUAFAC0AFA BQAUAJQAtABQAUAJQAiOroHRgynkEd6AFoAKAFoASgAoAWgBKAFoAKACgBKAFoAKAEoAWgBKACgB aAAUAJQAtACUALQAnegBaAEoAKACgBaACgBKAAACgAoAWgBKACgAoAKAFoASgBaACgAoAO1ACUAF AC0AFACUAFABQAUAFABQAUAFAC0AFACUAFABQAtABQAlABQAUAL2oAOlABQAlABQAtABQAUAFABQ AlAC0AFABQAlAC0AFACUALQAUAJQAUALQAUAJQAtABQA2gAoAWgBCAetAC0AFABQAUABoAWgBKAC gBRQAlAC0AFABQAUAJQAtACUALQAUAJQAtABQAUAFABQAUAHSgAoAKAEoAMUALQAUAFACUAFAC0A FAAKACgAoASgBaAEoAWgBKAFoAKACgBKAFoAKACgAoADQAUAFABQAUAFACdBmgBaAEoAKACgBaAE oAKACgAoAWgBKAAjIIPSgCm2mWRH+oQc7sjjmlYfMxbTT7W2cyxRjzD/ABnk0WC5bpiFoASgAoAK AFoASgAoAKAIbzi0m4z8h4oQFbRJPM09G3A9qctxsv0hDZRmJx6g0AZWi4KpuVw0eVGRTY3sa9IQ tACUAFABQAUALQAUAFABQAUAJQAUAFAC9qAEoAKACgAoAKACgAoAKACgAoAKAKKs39ouu0DABz60 yuhepEmb4jQvo1wASpABBHqDTQFjS8/YICwwSgOKQFqgAoAKAF7UAJQAtACUAFABQAUAFAB70AFA BQAUAFABQAUAKKACgAoASgAoAWgBKACgBaAEoAWgAoAKAEoAKACgAoAWgAoASgCiHX+1mRT82wEi gZeoEFABQAUAFABQAUAFAC0AJQBz92oOruxOFyoJJ4FVfoHU6AVIBQAUALQAUAHSgAoASgAoAKAF 6UAJQAtACUALQAUAFACHgUAMikWVdyHIoB6ElACUALQAUAJQAcUALQAUAFABQAUAFACUAFABQAtA BQAUAFACUALQAlABQAUAAGBgcCgAoAWgAoASgBaACgANABQAUAJQAUAFAC0AAoAKACgAoASgAoAW gAoASgAoAKAFoASgAoAKAFoAKAEoAWgBKAFoAKACgAoASgBaAEoAKAFoAKAEoAKAFoASgAoAKACg AoAKACgAoAKACgBaACgAoAKACgAoASgBaAEoAWgAoAKACgAoAKACgAoASgAoAUUAFABQAUAJQAUA FABQAUALQAGgBKACgBe1AB2oASgAoAKAEoAKADFABgCgBaACgAoAKACgAoAWgAoAOlACUAA6UALQ AUAFACd8d6AAUALQAlAC0AFACUAFAC0AFABQAUAJQAUALQAUAFACUALQAUAJQAtACUALQAlAC0AF ABQAUAJQAUALQAUAFABQAlADWLh1CqNv8RJ6UBpYdQAtAAaACgAoAKAEoAWgAoASgBaAEoAKACgA oAKACgAoAKACgAoADwOBQBy+papeXEslvbRKVVuz4OKvRbhZvYv6Pfs6pE4G0Dr3GOxpPyCxsggg EdKkAoAKACgAoAKACgAoAKAIbwN9ll2fe2nFCBEOkb10+ISABwOcCh+QFygBG+6aAMvRlKq+WYnz GBJ5zTGatIQUAKKAEoAWgAoAKAEoAKACgAoAKACgBaACgAoASgBaAEoAKACgAoAXpQAlAC0AJQBm Ml4dYyIwLfb98HrTuM06QijreRpsu0kZxnHpmnHcCey/49IuSflHUYpMCegAoAKACgAoAKACgAoA KACgBaAEoAWgBKACgAoAKACgBe1ACUAFABQApoADQAUAJQAUALQAlABQAUAFABQAUAFABQAtACUA ZheX+3RGmPLEeXO38hmmPoadIQUAFABQAvagBMc0AFABQAtACUAc7fyPFraq0LeXIR8+Mj8qpWGj oqkQtABQAlACigAoAKAEoAWgAoASgAoAWgBKACgBaACgBDQAiqFGFGKAFoAWgAoASgBaAEoAWgAo AKACgAoAKACgAoASgBaACgAoAKACgBKACgBaACgBKAFoAKACgBKAFoASgBaAEoAKAFoAKACgAoAS gBaACgAoASgAoAKACgAoAWgAoAKACgAoASgBaAEoAWgAoAKAEoAWgBKAFoAKAEoAWgAoAKAEoAKA FoASgBaAEoAKAFoASgAoAKACgAoAKAFoASgBaACgBKACgAoAKAFoAKAA0AFABQAUAJQAUALQAUAF ACUALQAUAFABQAlABQAUALQAlABQAtABQAlABQAUAFAC0ANoAKAFoAKACgAoAKACgAoAWgBKACgA oAKAAUALQAUAJQAUAGOc0AFAC0AFABQAlABQAUAFABQAtABQAlAC0AHSgAoAKACgBKACgBaAEoAW gAoAKAE6UAFABQBTub5YW2qpYnuB0p2HYtRgiNdxye9IQ+gBKACgBaAEoAKAFoAKACgBKACgBaAC gAoASgAoAKACgBaAEoAbJIsa7nYAD1oAgiv7WVyiTIWHbNNxaAsggjg0gFoAKAExzQAUAR3G/wCz yeWoZ9p2gnAJoBHIaXbxLrCtJC6SKQDtPGfeqb00YzXv7cW8+5HIjnbpnAB70kBpafIj26hD8qja PwoYFqkIKACgAoAKACgAoAKAIL4sLSUocELwaECGaYytaIUJI9fWhgWqACgDL0h9894ATiOYqRjG DTew2alIQtABQAlABQAUAFAC0ABoAKAEoAWgBKAFoAKAEoAWgBKACgAoAWgBKAFoASgAFABQAUgC mBl+JZWh0mR0OCGXtn+IU1uBb04s1qrMynPTb0pMCzSAKYC0AJQAUAFABQAtACUAFAC0AFACUALQ AlABQAUAFABQAUAFABQAUAFABQAUAFAC0AFACUALQAlABQAUAFABQAtACUAZkwxrUJ3MMr0Xv9af QDTpAFABQAUAFAC0AFABQAlABQBiT/8AIcJLH7o2gn+lV0C5tjpUgLQAUAFABQAlABQAtABQAUAJ QAooASgBaACgBKACgAoAWgBOlABQAUALQAUAJQAtABQAlABQAtACUALQAUAFABQAUAJQAUAFABQA UAFABQAUALQAUAFABQAlABQAtABQAUAFABQAUAFABQAlAC0AFAAaACgAFABQAUAJQAtACUALQAUA FABQAUAFABQAlAC0AFABQAUAJQAUAFABQAtACUAFAB0oAWgBKACgAoAWgAoASgANABQAUALQAlAC 0AJQAUAFABQAUAFABQAtABQAlABQAUALQAlAC0AFABQAUAFACUAFABQAUAFABQAtABQAUAHagBKA CgAoAWgBKACgBKYwoEFIBaAAUAFABQAUAHagAoAKAFoASgAGcc9aAFoASgAoAWgBKACgAPbFAC0A FACUAHTHFABQAUAL0oAKACgAoAKACgAoAKAEoAKACgBaAEoAWgBKACgAoAKACgDJ1y/aCMwxBg5H 3gM4qkAum6cqv58jSEcFUds7TSbGa1IQUAFABQAlABQAtACUALQAlABQAUALQAlABQAtACd6ACgA oAKACgDH1sPM6wAfLwxOaadhoSLRY4lElq4344yOM9zRew7le3nurMkRSJJDGf3gkJBH0+lVe+4W N+NxIgdTwRnioJH0AJQAtACUAc7rlsIZleGMjzc/MBkZoTSY7XBL+KfStjxMjJwoJyc461bS3EvM seHJAYmUEkjk5GMVLGbVIQUAFABQAUAFABQAUAQXxIs5iOoQ0IEQ6P8A8eEYJyR1oY2XaBC0AJjH SgBaAEoAKAFoAKAEoAKACgA6UAFABQAUALQAfSgBKACgAoAKAFoAKAEoAKACgAoAUUAJSAKYBQBl eJo2k0iVVYq25eR16igC1paLHYxopbAH8XWhgW6ACgAoAWgAoATpQAtACUAFAC0AJQAtABQAUAJQ AUALQAUAIc56cUALQAlABQAUAFABQAUAFABQAtACUAFABQAdKACgBaACgBKACgDMBb+3G6lQgx7U DNSgQUAJQAUAFAC0AJQAtACUAFAGLcwJ/bHmk54BGOv0pjNodBSELQAUAFABQAUAJQAvSgBKAFoA SgAoAWgBKACgBaACgAoAKAEoAWgAoASgAoAWgBKAFoAKACgBKACgAoAWgAoASgBaACgAoAKAEoAK AFoASgAoAKAFoASgAoAKACgAoAKACgAoAKAFoASgAoAWgAoASgBaAEoAKAFoASgBaACgAoASgAoA KACgAoAKACgAoAKACgAoAKACgBaAEoAKACgAoAKACgAoAKACgAoAKACgAoAKAEoAWgAoAKACgAoA KACgBaAEoAKACgBaACgBKAFoASgAoAWgBKAFoAKAA0AJQAUAFABQAtABQAlABQAv0oASgAoAKACg BaAEoAWgBKAE70xgKBBSAWgAoAKACgAoAO3FAC0AJQAUALQAUAFAAaAEoAWgBKAFoAKAEoAWgAoA O1ABQAUAJQAtABQAUAFABQAlAC0AJQAUAFAC0AJQAUAFABQBU1S4a1s3kj+90H1ppXAqaVqBlXdK wRemG9fahoL+RqgjGRzSAwJJy0k/llWZiSOMkdqbKTN6MbY1GMcdKRI6gBaAEoAWgBKAFoATjOKA FoASgAoAWgBKAFFABQAUAFABQAlABQAUAFAGZrTCIRyYJPTAOP8AIppDTI9P1SEWsfmkLzjg/rT5 RBqiQ3tp9ohblM9uSKVrDQaDcqYFhQ71A4YDj6UNAa9IQUAFABQA0gSIVdeDxg0AZ1xpKnBtyEOe uKLsenUk0qxeySTzZPMkdslvQelO4Mv0hBQAUAFAC0AJQAUAFAFbUmVLCcucAIec4poER6OVNjGY ydp9RihjZdpCCgAoAKACgAoAKACgAoAKACgAoAWgAoAKACgAoAKACgAoASgAoAWgBKACgAoAO1AB QAUAMDfvCPSgB9AGZ4jZ00qQxnDZUAntzTW4F2zVkto1bGQB070gZKpJHIwfSgBaAFoAKACgBKAC gAoAKACgBaAA0AJQAUAFAC0AJQAtABQAlABQAUAFABQAtACUAFABQAUAFABQAUAFABQAUALQAUAJ QBRJK6oAFHI5PWgfQvUCCgAoAKAFoAKAEoAKACgAoAxL2RhqKo394bcD+dUloBt1IC0AFACUALQA UAJQAUALQAlABQAtABQAUAFABQAlABQAUALQAUAFACUAFABQAUALQAlAC0AFABQAlACigAoASgBa AEoAWgAoADQAUAFABQAlABQAtACUAHSgAoAKACgAoAKAFoAKACgBKACgBaAEoAWgBKACgAoAWgBK AFoAO1ACUAKKAEoAKAFFABQAUAJQAUALQAUAFACUAFABQAUALQAlAC9KAEoAWgBKAFoASgAoAKAF oASgAoAKACgBaAEoAKACgAoAKAFoAKAEoAKAF6UAFACUAFAC0AJQAUALQAlAC0AJQAUAFAC0AJQA tABQAUAFABQAlACmgBKACgBaAEoAKAFoAb9KACgAoAWgAoAKACgAoAO1AB9aACgAoAKACgBaACgA oAKAEoAWgAoAKAE6UALQAUAJQAtABQAUAJQAtABQAlABQAUALQAUAJQBW0+K6igYX06zSs7NlVwF GeAPoKBu3Qs0CFoAKAEoAbJGsiFXAIPY0Ajl76yl02UtCCkZbO/OR9PaqTvoVa5bivUhtXQSgEqc B2+YsfSnuL1KWlx7tTijWZO7MqNmh6BodZUCFoAKAAUAJQAtACUAG0ZBxyOM0ALQAUAFACUALQAl ABQAUAFABQAUAAoAKACkBh+JNGfUUE8Uj+ZGMCLPDDPIppjRg2UMUkgtyTDJE20I7YIz/SqQXszR IvY2KLMJMErlAePrRe3QVuxR0++ubCYs+Rb/ADZ3DG0/1oUlsDTNdPEqpH/pMLBwRwvQj1FPlTHa xcGu2hZ1UklDg0uUQ7+2rM7QJFyenNHKwK7eIbcziGIMzk4AAPJo5QRsISUBYAH0qQHUAFABQAUA FAC0AFADJU8yNk3Mu4YypwRQCHAYAFABQBW1NVawnV87ShzihAtCvoEbRaZEGLE+rdcUMbNGgQUA LQAUAJQAUAFAC0AFACUALQACgAoAKACgAoAKACgAoASgAoAKACgAoAKACgAoAKACgCusmbkpkZ69 eaYyxSEZXibP9kSEY+8vX601uBoWmfs6bgQcCkBLQAUALQAlABQAUALQAlABigAoAKACgAoAKACg AoAKAFoASgBaAEoAKACgAoAKACgAoAKACgAoAKAFoASgAoAWgAoAKAEoAzQT/bJHTK/nTA0qQBQA tABQAlAC9qAEoAWgBKACgDFba2tOzByVwo6AU9Bpm1SEIwJBAO0+tAC0ALQAUAFAAaACgAoAKAEo AWgAoAKAEoAKAFoAKACgBKAFoAKAEoAWgBKAFFABQAlAC0AJQAUALQAlABQAtABQAlAC0AFABQAn SgBaACgBKAFoASgBelABQAUAFAAaACgBKAFoASgAoAKAFoAKACgBKACgAoAWgAoAKACgBKAFoASg BaAEoAWgAoAKACgBKAFoAKACgBKAFoAKAEoAKACgAoAKACgAoAKAF7UAJQAUAFABQAUAFAC9qACg AoAKAEoAWgAoAKACgAoASgBe1ABQAUAFACUALQAlABQAtABQAUAFABQAlABQAtAB2oAKAEoAKAFo ATFABQAUAL2oAKAEoAWgBtABQAUALQAUAFABQAUAB6UAAGKACgAoAKACgAoAKADBoAWgBOlAC0AF ABQAUAFABQAUAJQAtACUALQAUAFABQAUAFABQAlABQAUAFABQAUALQAUAMkRJEKSKGU9QRQBzWt6 f9lty6GI7mwPkwQPT3qk3sDS3Rm6NILaTfIgMkQ288EZ709HqB1NlqcFyrlH3BOGOMYpOLQbl0TR k43DNTYCSgAoASgBaACgAoAKAEoAKAFoAKAEoAWgBKACgBaAEoAKADpQAUAFAGfqelW15+9aJfPT lXA5pWsNPoUdNXyp48yNtboDwcjsasNjcaONhhkU/UVAXKk2lWEjFpLZCSMdKYXZWbw9p5OVjKZ/ utjNJ3C49NA05HD+RlvUk09QuXIrO2h/1cKLj2pWC7JwMDimIKACgAoAKAFoASgAoAKACgAoAq6o dthP8uflIxTQEWiKy6bEJBhsdCc0PUPQv0gCgAoAKAFoAKAEoAKAFoASgAoAWgANACUALQAlABQA tACUAFABQAUAFAC0AJQAUAFABQAUAZlm+dTuAMYzjpzn/Cn0GadIRna+QNMkJQtgqcA4700CLdm7 PbI7LtJGcZzikBNQAUAFABQAUAFABQAUAFAC0AJQAtACUAFAC0AJQAtACd6AFoASgAoAKACgAoAK ACgAoAKACgAoAKACgAoAKACgAoAKACgDMeArrSTvK5DLhUB4HFMDTpAFAC0AJQAUAFABQAUAFABQ Bzc+DrbISxcupxn7o7VXQep0aFiuXXafTOakQtAAfagBaAEoAKAFFABQAlABQAUAFABQAUAFAC0A JQAtABQAUAHagBKACgAoAKAFFABQAUAFABQAUAFABQAUAFACUALQAUAFABQAUAJQAUAFAC0AJQAU ALQAUAJQAUAFAC0AFABQAUAJQAUAFAC0AFABQAUAJQAUALQAlAC0AJQAUALQAUAFACUAFABQAtAC UALQAUAJQAtACUAFAC0AJQAUALQAlABQAtACUAFABQAUALQAlABQAtACUALQAUAFAB2oAKACgAoA KACgAoAKAEoAWgBKAFoAKADpQAlAC0AFACUALQAUAJQAUAFABQAUAFAC0AFABQAUAFACUAFAC0AN pjCgBaQgoAKACgAoAKAA9KACgAoAKACgAoAKACgAoAKACgAoAWgAoASgBaACgAoAKACgAoAKAEoA KAFoAaqlQfmLEnPNACigBaAEoAWgBKACgAoAKACgBTQAlAHMa5f5unQA/uhtVMcsT6VSSAu6TpzS WZa+jCTM2Rt6gdqm99SrtCz6TKjE2bKA4w2ev1p3sIXTrG6hYiU8FgzMWyTj0ouJJI2KQC0AJQAt ABQAlABQAtACUALQAUAFACUAFABQAUALQAUAFACUALQAlAGHrUgtJ0dG2yODsGOAfeqQXNi33eRH v+9gZ+tSBJQAUAFABQAUAFABQAUAFABQAUALQAUAJQAUAVtSVmsJ1RirFTggZoAj0ZdmnxLu3EDB NNgy7SAKAIRMpuDFn5hzimMmpCCgAoAWgBKACgAoAWgBKACgAoAWgBKACgAoAKAFNACUAFABQAUA LQAlABQAUAFAGNZSr/bU8RPzkE4p20GbNIRn67GsumyIwbBI+79aaaQFiwwLVAoIXHGaQ2WKBBQA UAFAC0AJQAtACUAFABQAUAFAC0AJQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAC0AFACU AFABQAUAFAFEqP7V3gneEAxnjFA7KxeoEFABQAUAFAC0AJQAUAFAC0AcwsfmeJpmPRGGQx46daq+ gzpqkQtACUALQAUAFABQAUAFABQAlAC0AJQAUAFABQAtACUALQAlABQAUAFABQAUALQAlACmgBKA CgBaACgBKACgBaAEoAWgBKAFoAKACgAoAKAEoAKAFoASgAoAWgBKACgAoAWgBKAFoAKAEoAWgBKA CgAoAKACgBfpQAlABQAtACUALQAlAC0AFABQAlABQAUALQAlABQAUALQAUAHSgBKACgBaACgAoAS gBaAEoAKAFoASgBaAEoAKACgBaACgAoAKACgAoAKAEoAWgAoAKAEoAWgBKAFoASgBaACgBKACgAo AKAF7UAHagAoASgAoAKAFoAKACgBKAFoASgAoAKAFoAKACgBtMYUAFIQtABQAUAFABQAh4BoAUUA FAC0AJQAUAFAC9KAEoAKACgBEOVBwV9j2oAdQAUAMYPvXaVCc7gRyaAHUALQAUAFACUAFABQAtAA aACgBKAFoAKACgAoAKAGtu42468/SgB1ACUAFAC0ARXKSPA6wsFcjAJ7UAZUegxGRWnYvsbIp3Y7 6GyBjpSEFABSAKYBQAtABQAlABQBEs264eIRvhACXIwufQetAWJaACgAoAWgBKACgAoAKAFoASgA oAKACgAoAo6vqCadamUgsx4VR1ppXA4u41e61GSIgPvQ4DKPlYZptroJXO8tJllhUjg45U9RUtDJ qACgAoAKACgAoAKACgAoAKACgAoAKACgAoAr6hu+wz7M7thxQtAKugY/s6MDHHXHHNNgaVIAoAqI Ct6542ntjvQPoXKBCUAFABQAtACUAKKAEoAKAFoAKACgBKADpQAtACUAFABQAtABQAlABQAUAFAB QAUAZsLwvqrCOMb1B3Pn+lOw+hpUhGdrqs1mAr7PnGfcelNOwIs6e++1QgYGMAUmBYoAKAFoAKAE oAKACgAoAKACgAoAKAFoAKACgBKACgAoAKACgAoAKACgAoAKAFoASgBaAEoAKACgAoAKACgAoAKA CgBaAM6YFdUi3AFGHHqDQGpoUALQAlABQAUAAoAWgBKACgAoA5tyG16RBy24D2HGaroM6SpEKaAE oAWgBKAFoASgBaACgAoASgAoAKACgAoAKACgAoAKAFoAKACgBKACgAoAKACgBelACUALQAdqAEoA KAFoASgBaACgAoAKACgAoAKACgAoAKACgBKAFoASgAoAWgAoASgAoAKAFoAKACgBKACgBaAA0AFA BQAlABQAtABQAlAC0AFACUALQAUAFABQAUAJQAUALQAlABQAtABQAUAFABQAUAJQAtACUAFABQAU ALQAlABQAUALQAUAFABQAlABQAUAFAC0AFACUALQAlAC0AFABQAUAJQAtACUALQAlABQAUAFABQA UAFAC0AFABQAUAFACUAFABQAUAFACigBtMYUAFIQtABQAUAFABQAHpQAtABQAlABQAtABQAUAJQA UAFABQAUAFABQAUAMmZ1idokDuBlVJxk0APGdoyMGgAoAKAFoAKACgBKAFoAKAEoAKACgAoAKACg AoAKACgAoAKACgAoAQlgQAM+vtQAtIApgFABQAtABQAlAC0AFACUALQAUAJQAtACUALQAUAJQAUA FABQAUAZWvWBuoRNEMyx9v7w9KENGXp5gDvp8yxrbumRyBtPtT0FfUlF49jcxQLm4Zgd7g46dKaQ 27HSDoKkQUAFABQAUAFABQAtABQAUAFABQAUAJQAUAQX3FnMSSuFJyKAK2hlmsRI+MyMW4psGaFI AoAqrxfNluo4WmPoWqQgoAKAFFABQAlAC0AFACUALQAUAFABQAlAC0AFACUAFABQAtABQAlABQAU AFABQBl2UZXUJXDZDE5GOn40DZqUCM3XlJscrkFXBznpTiBasChtIzGcqRwcYpDZYoEFAC0AJQAU AFABQAUAFAC0AJQAUAFABQAvagBKAFoAKACgBKACgAoAKACgAoAKACgAoAKACgAoAWgBKACgBaAC gAoASgCiQG1QEZBQc5HB/wDr0+g7F6kIKACgBaAEoAUUAJQAUAFABQBy1wB/wlDxs3LFGQKOnHOa q2gzqakQtACUAFABQAUALQAUAFACUAFAC0AJQAtACUAFABQAtACUAFABQAUAFABQAtACUAFABQAU AFAC0AJQAtACUALQAUAFABQAUAFACUALQAUABoASgAoAKAFoATFABQAUAFABQAUALQAlABQApoAS gAoAKACgAoAKACgBaAEoAKACgBaAEoAKACgAoAWgBKACgAoAKACgAoAKAFoASgBaACgAoAKAEoAK ACgAoAWgBKACgBaAEoAPwoAKACgBaAEoAWgBKAFoADQAlAAelABQAtAAaAEoAWgAoAKACgAoAKAC gAoASgAoAKACgBaACgBKAFoAKACgBKAFoAO1ACUALQAUAJ0oASmMKACkIWgAoAKACgAoADQAtABQ AlABQAUALQAlABQAUAFABQAUAFABQBRurlbaR90jscA7OP0poZPZTmeIMQAfSkInoAWgBKACgAoA WgBBnn9KAFoAKACgAoAKAEoAWgBKACgBaAEoAbJIkQ3O2B0osAI6yIGQ5U9DQJO+o6gYUAFAGfJq sSzmGNS7L1xVculwL6OrjKEEVIDqACgBKAFoASgAoAKACgAoAKAFoAKAEoAKAFoAKACgBKAFoASg CK7kMVu7L97HHHegEYc+mnUIFkiEKyH7ysOn0xT22G9Rtn4em+1RzXc21YuFWM/eHoaV5Bojo+lA goAKACgAoAKACgAoAKAFoAKAEoAKACgAoAhuzttZSMcKeo4oBEGkMWslyoH06U2BdpAHNAFctGbs DA8wDj1xTH0LFIQtACUALQAlABQAtABQAUAJQAUAFAC0AFABQAlABQAUALQAlAC0AJQAUAFABQAU AZVht+3yBFwQTuwcg5NMbNWkIy/EC5tEOWCiQE4poC/ap5cCKBgAUgZLQAUAFAC0AJQAUAKaAEoA KACgAoAKACgBelABQAUAJQAtACUAFABQAUAFABQAUAFABQAUAFABQAtACUAFABQAvagBKAA+1ABQ BRkbGoLmVVyQAhHJ+lO2g7F+kISgAoAKAFoASgBaACgBKACgDDfYfEm4fKRGATjr/wDWqraDRuVI goAKAFoASgBaAEoAWgAoASgBaACgBKACgBaACgAoASgAoAWgAoASgBaAEoAKAFoAKAEoAXpQAUAJ QAooAKAEoAKAFoAKACgAoAKACgAoAKADtQAlAC0AFACUALQAlAC0AJQAUAFAC0AFACUALQAlABzQ AUAFABQAtACUAFAC0AFABQAlABQAUAFAC0AJQAUAFABQAUAFAC0AHSgBKAFoASgAoAKACgAoAWgB KAFoASgBaACgAoASgA70ALQAlABQAUALQAlACmgBKACgAoAUUAFABQAUAFAAaAEoAKAFoASgBaAE oAWgBKACgAoAWgA7UAJQAtABQAUAFABQAUAJQAtABQAUANpjCgApCCgBaACgAoAKAENADqACgAoA SgAoAKACgAoAWgBBn1oAKAAnAzQBA97bIAzTxhScZzxmnZiuT0hlHVY8xq4QEg4z6UFIpaFmEzK8 mctjBOcGqYrG3UCAjggHHvTAjtllSFVnkEkg4LgYz+FAElAC0AJQAUALQAmRnANAC0AJQAtACUAF ABQAtABQAlAGdrduZoEkUEtE24AZ/pTTa2GhumSuJGj81HjAGeeQ3cUMNDTpCCgAYZUjJGe4oA5n VNOlhuDMRujPIZRytOL1GSaTeyxJjYChPzOW/WqaQep0CMHAIqBDqACgA6ck0AR+dH/fHFFgsSA8 ZFAC0AJQAtAB2oASgBaAEoAKAFoAKAEoAWgBKACgCK5h85Au9kIOQRQBiT/a9M2pB80QOXbGc+9U n3HbsaMWooMic4I5yBxilysWhdjkSRcocgUgHUAFABQAUANMiKSC6ggZPPQUAZVzrkUbHyArqrbS S2Mn29ver5O4F2xvVuhggK+M4BzmpasBapAFABQAUALQAlABQBBenFnOR2Q/yoQIraEpTT0BGCeT TYM0KQBQBWTb9sIIGQOtAyzQIKACgAoAKAFoAKACgBKAFoAKAEBBGVIPagBaAA0AFABQAlAC0AJQ AUAFAC0AJQAUAFABQBi6cynVpht2OAcgHg80x3NqkIyPE+7+z0EblXMq7SB700HQ07di0SkjnHNI GSUAFABQAUAFABQAtACUAFABQAUAFABQAUAFABQAUAFAC0AFABQAlABQAooAKAEoAKACgAoAKACg AoAKADFAC0AJQAUAFAGZeBP7Ut93Ujj/AGf/ANdA0adAgoAKACgBaAEoAWgAoASgAoAwPNP/AAkM kSOjYwSD1HFPoM36QhaAEoAKACgBaAEoAKAFoAKACgBKACgBaACgAoAKACgAoASgAoAWgAoAOlAC UALQAlAC0AFACUAFABQAtABQAlAC0AFABQAUAFABQAlAC0AFABQAUAFABQAUAJQAUAFAC0AFABQA UAFABQAlAC0AFACUAFAC0ABoASgAoAWgBKACgBaACgAoAKAEoAWgBKAFoAKACgBKACgBaAA0AFAB QAlACmgAoASgAoAKAFoAKAEoAKACgAoAKAFoAKACgBKACgAoAKAFoAO1ACUALQAUAFABQAUAJQAU AFAC0AFABQAlAC0AFACUALQAUAFABQAlAC0AFABQAUAFABQAUAFADaYwoAKQhaACgAoAKACgAoAK AFoASgAoAWgBKACgAoAKACgBaAOf8U3VxFbMsDhFK9c8k1SGkU3spV09JJlTy5UUuhPSpu2HKbWj uAjwksWXnk54PTFN33Bl6ZBJGykUhI5wRCN5JUyzCXJPfHpTuUdHDIJYlcdxmkSPoAKAFoAQ57UA KaAEoAKAISCJcBTjGc0xj4ZA65yMjrikwY+gQUALQAlABQAtABQAlACMMqRQBzOp28kN48j5VWTh ox0NVF9CjU0a/FxCsT7vMQAFm6N9KJWvoSadSAUABAIwaAOa8QQ2+nxiRPvO/wAqZxirirg3oR6P enK7JNhI/wBW7Zz9KHboG25v2V6lyGU4WROGWpY7ElxcxWyF5WAApJCMW61OeZ2SEYRjtXAzk1aV h2ILgT21xHHOpKHA4PBpLULG5p0qvGyq+7YcdelJqwtOhbpALQAn0oAWgAoASgBaAEFABQAtACUA LQAlABQBBfCY2kotgDKRgZOKARztlp2rLIySXAORlnJ6+1PmY+VImk8MvPjzr2UDHKg0rsNFsbll apZ26QxkkL3PU0CuT0AFABQAUAcbq0s1lq7m7lwkpJXYDwvTmtFLSwOxNpFtYtBsuo2keVtwlJzs 9Oe1S0CZLpIkt9WjhVt0RDDIOfejZWGdPUiCgAoAKACgAoAKAK+o/wDHjN/uEcUICPSWLWUZJB7c DFNjZcpCCgDPiZhqsq8lSAee30pjNCkIKACgBaACgAoASgBaACgAoAKAGqqrwoAHXigBaACgBaAA 0AJQAUAKKACgBKACgAoAKACgAoAydPQpfyDy12jP7zueaYzWpCM/WgTbJtwGDgjI4poaLVp/qF+l ITJqACgAoAKAFoASgBaAEoAKACgBaAEoAKACgBaACgAoAKACgBKAF7UAFACUAFABQAUAFABQAUAF ABQAUAFABQAUAFABQAUAZt1HG2qQSE5aPggH16UDNKgQUAFABQAUALQAlABQAUAFAHOglPFDqsag SAcjPYd6d+gzoqQgoAKACgAoAKACgAoAKACgAoAKACgBaACgAoAKAEoAKAF6UAFACUALQAlAC0AF ABQAUAJQAUALQAUAJQAUALQAlAC0AFABQAUAFACUALQAlABQAtACUALQAUAJQAtACUAFABQAtABQ ACgAoAKACgBKACgBaACgBKACgBaACgBKAFoAKAEoAKAFoASgBaAEoAKACgBaACgAoASgAoAWgBDn HHWgAoAWgBKACgAoAWgAoASgAoAB70AFABQAUALQAlAC0AJQAtAAaAEoAKADpQAUALQACgAoAKAC gBKAFoAKACgAoASgAoAWgBKACgBaACgAoAKACgA7UAFABQAUAJQAtABQAUANpjCgApCFoAKACgAo AKAA0ALQAlABQAUAFABQAtABQAlADd6eZ5e4b8Z255xRYB1AGVrFpG6s5WMtKNh3/wBPemhogsGJ szZzBf3fCsxzkU2G5VhlkiuvvuFRwPY0egHTCpEYOsjyZ0bcoycYPp6U0O5f0WTfaYwRtJHNDEaF IBoYHOD060AOoASgBaACgBAMZ96AGTEqu4DOKAKcUqxXEanGZR2p2Gy/SELQAUAJQAUAFABQAUAF AEF5bLcwMh4JHB9KEwOcbzLLeJdyhX2hV+answd73sa+m6kkh8mT5SMBSe/4+tNoRp1IwoAyfEGn rd22/aCU/lQBkQ2kXkfP5cRA/dk8/XHr9KaVtirIet0YP3QhDjZndnaR6VVmTsMt47nUZthk2wNh mL9qJDR0tpZw2qYjXnuTWdgbItUt/Nt8qPnU5qk7CM/TPMi1AIEXBHznPT0+tGlg0N6kAlABQAtA BQAUAFACUAFABQAUAFABQAUAFAGfdssF/DJznBHtin0GX1IZQR0NIQtABQAUAFABQBm6xbxzeV5n TPehLqUiuLKZESW3jWQMPmVjg0XB2JNL0+aO7lurpI0YjCIn8I70XuJmtQIKAG5feAFGzHJzzn6U AOxQAUAFABQBX1BillMy9QpoQDdNQpZoCSSRnmmwZapAFAFCEj+0XXLE4z04HtTGX6QgoAKAFoAK ACgANABQAUAFAAaACgBKAFoASgBaACgANABQAUAFACUALQAUAJQAjDIxQBhaJHfxajcC5gKQn7rF up9qd0UzepEmdriGS2jQS+WTIPx9qa8gLNgZDaRmUYfuCMUmBZoASgAoAKAFoASgBaACgAoASgAo AWgBKAFoAKACgANABQAdKACgAoASgAoAKACgAoAKACgAoAKACgA4oAKACgAoAKACgAoAzbjYdZgV VbftLMQOCO2afQfQ0qQgoAKACgAoAWgBKACgAoAKAMERyDxEzgExnqX4wcfw00xm9SEFABQAtABQ AlABQAUAFABQAtABQAUAJQAUAFAC9KACgAoAKAEoAWgAoAKACgBO9ABQAUAFABQAUAFABQAUAFAC 0AFABQAdKACgAoAKAA0AFACUALQAlAC0AFACUAFABmgBaACgAoAQ0ALQAUAFACUALQAUAFACUAFA C0AJQAUAFABQAtABQAUAFABQAUAFABQAUAAoAKADtQAUAJQAtABQAlABQAUAFAC0AFABQAlABQAt ACUAFABQAtACUALQAlAC0AFABQAlAC0ANy3mY2jZjrnnP0oAWgAoAWgAoASgBaACgAoAKAEoAKAC gBaAEoAKACgAoAWgBKACgAoAWgBKAFoASgBaAEoAWgBtMYUAFIQtABQAUAFABQAUALQAUAFACUAF ABQAUAFABQAm0BicDJ70rALTAjuIUnhaOQZDUIFoc3c+daXaKF+WLIUkZwKa7FMoW0lxeXe2Hje3 IBwSO5Bqr22EdsowoHoKgRka4CzIqMAw+amhlnRw/kF2PDHIXHSkwZfoEGB1oAKACgAoAKACgAIy CD0oAw5JJ4ZGNyIPMR/3ZU4+U/1pjZsW8nmRK3TIpCJKAFoASgAoAKACgAoAWgBKAILq2S4jKtwe xHY0DTOce3lspUiuNqq3O9R1PrTTCxqWN00O1XbzI2/jGTzTYrLoawII4qQAgEYNAGDqmjknz7d2 DB85H8I7002tik0Yl3p6396pSOV3UBCquQCPU0Xa2ZPKmXJ9Ml06FsuRAp4JOcj0NOLY+VdC5Z6p LGMO/BGcv2Pp9KbswHS6r5u9GYFAQpC8Zz0qWCsW9DsjbRs0ke1iepJJPv7UrvqGxqUCFoAKACgA oAKACgBKAFoAKAEoAKACkAhYL1OKYCCRD0dfzosBU1GKOaLdlSUBPXoKY0V9Lv0KxQOw34xwabQj VqQCgBfpQBGJF8wpnkdaLAPoAgu0SWBlbnHIGcc0WGhmnyF4mUoE2NgAHPFNiZZY7VJ9KQDIpkkZ lU/MvUUWAkoAWgAoAKAEoAKAK2pBjYTBcZ200CGaU4ks0KtnHBoY2XKQgoAowEi+cZKr/dPf3plF 6kSFAC0AFABQAUAFABQAgGBigBaACgBKAFoAKACgAoASgBaACgAoAKACgBKAFoASgBaAEoAKAM/X GKWYKpubeABTQ0W7UEW6A5Bx3OTSBktAgoAKAFoASgAoAKAFoAKAEoAKACgAoAKACgAoAKACgAoA XpQAlABQAUAFABQAUAFABQAUAFABQAUAHegBe1ACUAFABQAUAZ8jBdYXqGMeB7in0GaFIQUAL0oA SgAoAKAFoAKAEoAKAOdmbzfE0KySKUjJwvIIOKroB0VSAUAFAC0AFACUAKaACgAoASgBaAEoAWgB KACgBRQAGgBKAFoAOlAB0FABQAlABQAtABQAUAFABQAUAJQAUAFABQAtABQAUAFACUAFAC0AFABQ AlAC0AJQAUAFABQAtABQAlABQAtABQAUAJQAUAFABQAUAFACigAoASgAoAWgAoASgBaAEoAKAFoA KAEoAKAFoAKACgAoAKACgAoAKACgBKAFoAKAEoAKAFoASgBaAEoAKAFoASgAFAC0AFACUAFAC0AJ QAUAFABQAUAFABQAtABQAUAFACUALQAUAFABQAUAJQAUALQAlAC0AFABQAUAH0oAKACgAoAKACgA oAKAEoASgAoAKAFoAKACgAoAKAA0AFABQApoASgAoAKAFoAKACgBKACgAoAxtdmswDHI588LkKpx xTSGZNtMVZZIVCsv3QO9VoFmbVnrEbQubllDocHaDScRGVeXsl/OphQKCdgyOce9D0Ha50Wn2/2W 0SI9R1qRFigBaACgBKACgAoARmVPvHFACgg9KAMXXbRXYSBMtj72elNMpFnSrhWAiB5Cg0NWEzRp CCgAoAKACgAoAKACgAoAKAIri3jnUCRehyD6GgLmBd209hMHXLgsWyDgfjVJ9GNeQtjqskStLORt BwyZyV96NHsI3La7huQfJbOPbFJqwrk+M8EUhjVRE+6oH0FACsoYFWAKnqDSApS6VayE/IVyckA0 7sdyeCzht1wiDPcnqaAuT0CFoASgAoAWgBKAFoAKACgBKACgAoAKACgCOeISoVJI9xQCOfutFvC6 NA6DaecHG73p8zK0GPpF8qlI3dFPUqRyafM+oKyMS5jvLO8eO5YgBMg7cbqd77KwmjWguNYlijMB kZQg+bAOTRzR6oDe0yC5RTLeSlpGA+XoF/CpbAvVIitc27uQ8JVX9x1oGmUJYryEOx8yQk8bfT6V VwtfYxr9b+VHllglQBsDC9vX6U+ZLYOWVyHS76cNLKJXBztEY9Ka1Eka39pTODHAGeUDICnOfrSt bcaNbTrX7OjSOD5svzPnt7VINlugQUAFABQAUAFAFTVcDTrgkkYQnNNAR6I4fTo2ClcjoRg0MC/S AKAM+3Vl1KQuOq/KfamUzQpEi0AJQAtACUALQAUAFABQAUAFABQAUAFABQAlAC0AJQAtABQAUAJQ AUAFABQAUAFABQBQ1dVeGJWcIpkGSRTQIuQkeUuOmOKQMfQAUALQAUAJQAUAFABQAtABQAlABQAU AFABQAUALQAUAJQAtACUAFABQAtABQAlABQAtABQAlABQAUAFABQAUAFAC0AJQBSlDjUotvCsOTj 07ZoAvUAJ3xQAUAFABQAUALQAlABQAUAc3bwr/wkdwxIOXzgHpxVPVDOkqRBQAUAKaACgBKAFoAK AD6UAFACUAFAC0AJQAUAFAC0AFABQAUAFABQAUAJQAtABQAUAFAB0oAKACgBKACgBaACgAoASgAo AWgAoAKACgAoASgBaACgBKACgBaAA0AJQAtABQAlABQAUAFABQAUAFABQAUALQAlABQAUAFABQAU AFAC0AJQAUAFAC0AJQAdKAFoASgBaACgAoAKAEoAKAFoAKAEoAWgBKACgBTQAUAFABQAlABQAUAF AC0AJQAUAFABQAtABQAUAJQAUALQAUAFABQAlABQAUALQAlABQAtACUALQAUAJQAUALQAlAC0AJQ AtABQAUAAoAKACgBKAFoAbQAUAFAC0AFABQAUAFABQAtACUAFACmgBKAFoAKAEoAKAFoASgAoAxt esFn2T7fuD5sDkigZgz2RXzAJZxHsCgqvTPpVJ2HbyHBTEyh90gYEZ6E46/jTW4jpNJgtIo/3CsH PXectUNWBmjQIWgBKAFoASgBaAIbmTy4WYde1AGHPcTvNKqLIy5GHzlR/wDXqtFuUi/pjOGY+b5s TchieQfShiLGooj2xMjFVHJI7VNgRl2EOydpUYhe2e9MZuo25FYdxSJFoAKACgAoAWgBKACgDAvN VmXUnhC/uUGAAeWNWkhpEdjrzQyLDdxEREDY27LfQ0+VWumJm9HcwyAlJUOOTz0qLMBzvEFJdl2j rk9KVmGxl3mmW95G09mY/MYfK45FPVMaZjLdSwXRWeKQNGMFgdvPt7VXMnogfobtnqakbJiDgA71 PGPek4iZpqQwBB4NSAUAFABQAUALQAUAJQAtABQAUAFABQAUAFABQAnORjpQAtABQAlABQBn61ZC 6ttwUmSPlQO/qKBp2M/wxcfPLbYcADcAwqml0EdBUgFABQAUABoA5iOyWz13Y8ZZZDiM4zx1OaFZ IfmdKiImdihc9cCkK46mAUAHSgBaAEoAKACgCpqm/wDs+fYoY7TwaaAbo5LWERJBPfFD3GXaQgoA pxoRqTsTxsGBQMuUCFoASgAoAWgAoAKACgAoAKACgAoASgBaACgBKACgAoAWgBKAFoAO1ACUAFAB QAUAFABQBna4cWagg8uBwM0AXLQYt0BOeOtAEtABQAUAFABQAUAKKAEoAXpQAlABQAUALQAUAJQA UALQAUAJQAUAFABQAtABQAlABQAUAFABQAUAFABQAUAFABQAUAFABQBnMXOsgBXChB1Pyn6VXQDR qQCgAoAKACgAoAKACgAoAWgDBVy2vEISFDncMdTj1psdmbtIQUAFAC0AFACUALQAlAC0AFABQAlA C0AHSgAoAKACgBKACgBaACgAoASgBaAEoAWgAoAKAEoAWgBKACgBaACgAoAKACgAoABQAUAFABQA lABQAtABQAlAC0AJQAtACUAFAC0AFABQAlABQAtACUAFAABQAtACUALQAlABQApoABQAlAC0AFAB QAlABQAUAFAC0AFACUAFABQAUAFABQAUALQAlAC0AFACUAFABQAtABQAUAFACUAFAC0AJQAtACUA FABQAtACUAFABQAtABQAlAC0AJQAtABQAlABQAtACUAFABQAtABQAlABQAUALQAUAFABQAlAC0AJ QAUALQAlAC0ANoAKACgBaACgAoAKACgAoAWgAoAKACgBKAFoASgAoAjnnjgQvKcAfnRYCFb+EkK2 5CezDFOwFhZEbgMPzpWAXI7EUAI6h1KnFAI5qTNvPIMq8kYwkKnlvc1SVx3WxojTIZ0NxGNryryp PAPt6UrjKixzaYrLGUBY4UM3G6qvcDQstR34jnIWXpzxn6VNhWNEEEZByKQhaACgBKAAUARXQYwP szuxxj1oQIybFWWWSPKgYGc8c9yR0p6LYq5NFuSVwnIdsgHjkUDLjlZLSUP9zBBwO1BNtTNttoUe VEMNzknmm0NdjWtWJiHy7QOAKliZLQIKAFoASgBaAEoAKAOf16yi85H/AHibiTuTsfU00UilcafM SLiPdKdoARR/OncTXYi8vVAUUW29i3zfLgAUc0dh8hb3akB5zQKqoOnU8etD5QsQtqF0pRjH5eW3 ZXOD7cU1yrQWpuxLDqlmrSqN3QkDkGoaBNozLrSzYqpiLSRs+WB7/wCAp30sA+yuvKwYXOQcNET9 7PcU7AbcE6yrnBU/3W4NS0LYmoASgBaAEoAWgBKACgAoAWgAoASgBaACgAoAKACgBKAIrmeO2iMk pwoIGcUJXAlBBAI6UAFAFWzsILMuYVO5+pJyaLvqO5aoEFABQAUAFADWjQurlRuXofSgB1ABQAUA FABQAUAFABQBU1UZ0+frwucDvQtAE0kAWEWBtHpQNlygQUAVkDfbnOxgoX73Y0aAWaACgAoAWgAo ASgBaACgBKAFoAKAEoAKACgBaAEoAWgAoASgAoAKAFoASgBaACgBKACgAoAqalGskAV843A8HFCG iW0BWEA0CZNQIKBi0AFACUAFAC0AFACUAFAC0AJQAUAFABQAUAFABQAtACUALQAGgBKAFoAKACgA oASgBaACgAoASgAoAKAFoAKAEoAKAM6eM/2zbyhmwEYEZ4oA0aACgAoABQAUAFABQAUAFABQBhgt /wAJCFA2R4bdz948YqugzcqRBQAtACUAFABQAUALQAUAFACUAFAC0AJQAtABQAlAC0AFACUAFAC0 AFACUAFAC0AFABQAUAJQAUAFAC0AFABQAUAFACUALQAUAJQAtACUAFAC0AFABQAlABQAUAFABQAU AFABQAUAFAC0AFACUAFABQAUAL2oASgAoAWgAoAKACgAoAKAEoAWgBKAFFACUALQAUAJQAtACUAF AC0AFABQAUAFACUAFABQAtABQAlAAKAFoASgAoAWgBKACgBaACgBKACgAoAWgBKACgBaAEoAWgBK AFoASgAoAKAFoAKACgBKAFoAKACgAoASgAoAKACgBaAEoAWgAoASgBaACgBKAE+lABQAUALQAUAF ABQAUAFAC0AFACUALQAlAC0AFABQBBc2sNyAJV5HQg4IovYDNu9FLtmCUhMY2E/rTuMz5bHUILoP BE2wcfI33hTUugWKvlXpkd2trlfKfAJzjB9MdaOfsxOLJEvbu3l/eb/LA43Hv6U73CxXurq4MjXC KjSNHnbjHH1oDUvaZrU0MIW6VQpGU28nHv707XAsz61aS71mjEsa9wOanlBMyby+SOWOVMlWXCIc 4B+tUhtWNnQbqUKsMiyNG33Xb1qZCNypAhu7j7NEH8qSUlgoWMZPJ/lQCRNQAUAIcHIzzQBhXdmR N88nyIfvL1JPZqq5Vrk7zW8SJEJsMVKgfxUW6gXdPz9mw+c9MHqKTEzMCeQGOQoUkoWJHGe/qaNW NmrYuJIPMXo3Q+tDEyxSEFABQAUAFAC0AFAFe/jaS1kVBl8cUIDD0mU2+93l3Kh/eD+5nt71WoWs dHUgGB6DmgClPplvNcLOdyuBjg8H8KGBYt7eK2UrCu0E5P1oAlODwaAMu+0aKYtJb/u5fY4//VQt B37mVvubG4SS68wQ/cOOTn1qrpjs1sa1tqRfcSoESnAO7JPuR2oaEX4Z45kDRMGUjINJqwiSpAKY C0AFACUALQAlABQAtACUAFABQAUAFABQBS1W3kuLbbCRlTnBGc0LQCKzvUhiSG5kUOCEwB0Pbinu O1zSzgZpCKFvq9pczNHCzNtOC20gU3FoDndRvvEb+LrOGyaH+xiwZmjXLEd9x+vpT5ktGhWbeh2I IIyDUjCgAoAKACgBaAEoAKACgAoAKACgAoAr6iAbKYHPKkcHFADNK2/Yo9pyPWhgW6ACgAoAKACg BaAEoAWgAoAKAEoAWgAoASgBe1ACUAFAC0AFABQAlABQAUALQAlABQAUAFABQAUAFAGbrbSKlv5b cGUBl/vD0poaLtqGWBd67T6ZzikJk1ACUALQAlAC0AFACUALQAlAC0AJQAUAKaACgBKADpQAUALQ AlAC0AJQAtABQAlABQAUAFAC9qAEoAWgBKACgBaAEoAWgBKAFoASgCnIyjUYxnnbjHpQBcoAKAFN ACUAFAC0AFACUAFABQBhybY9YxL/AMtH+QZ54HXFV0HY3KkQdqACgBaAEoAKAFoASgAoAWgAoAKA EoAKACgBaACgAoAO1ACUAFAC0AJQAtACUALQAUAFABQAlABQAUAFAC0AFACUALQAlAC0AFABQAlA BQAtACUAFAC0AJQAtACUAFAC0AJQAUAFAC0AJQAtACUAFABQAUAFAC0AJQAUAL0oAO1ABQAUAJQA tACUALQAGgBOlABQAUALQAlABQAtABQAUAFABQAUAFACUALQAlAC0AFABQAUABoASgAoAKAFoASg AOeMUALQAlAC0AFAAaACgAoAKACgAoABQAUAFABQAUAFABQAlAC0AJQAtABQAUAJQAtABQAUAFAC UALQAlABQAtACUAFACUAFABQAtABQAUAFABQAyaQRRlyGIHZRk0B6ElACUAFAC9qAEoAKACgBaAC gAoAKAEoAQqp6qDSaAp6hYQz2zKsShgpAIHSmh3uc+sMEF5FH5Q2JhWOeBTsmF9dDok02zXOyBFz 1wKmwXYjabalGCRKrFcBsdKAuZAR7bUY4z5mFIO8Hj0wBV9Cjo6kgWgBKACgAoAr3USkbzxxyc4o Q0Y9rFAkk5SGR9zZ3Mfvn0Gabb6jubFi0TW4MKlAScqeoPfNDWpJkXDR7pI5ZWZA3zZ/pTsVoaml LssYxgjrgH0zUiZboEFABQAUAIjbsjBBBxzQAtABQAUAcuz/AGfUJCke9GYqRjgmq2Hc6OzlE9tF KBjcoOPSpESngcD8KAEZlVcsQo9TQAtABQAUARzwRzriRQR2oC9jIm0lofOkt9gZkxuwd2PSi5Wh mzyz6dHCwLRI5ABC56+1UmhWOntDIYQZRhqkViagDKu9YEWu2elQCNpJVaSUl8FFA4wO5Jp20uBr UgAUAJQAUAFACigAoAKACgAoASgBaAEoAzNYsy8f2i33LKgJOwcsP6007BvoVbbWQ6xW9xHIm9cG Vex/pTshoisNMS4eRzLMoc7tp9/SjVDdi22mPaxObWQn5cEN1NSguJpl5ObvyHgxGVyG6fpVO1hN GxUiCgAoAKAFFACUAFABQAUAFABQAUAUtYYJps7EEgLQlcCLw8SdLiZixLZPIxihgzSoAKACgAoA KACgBaACgBKAFoAKAEoAWgAoAKAEoAKAF7UAFACUALQAlAC0AHagBKAFoASgAoADxQBFBN5ob5Sp BxyKAaJaAKGsMEhhLA481eR2poNi5D/qx1pDY+gQtABQAlAC0AJQAtABQAUAFACUALQAUAJQAUAL QAdKACgAoASgAoAKACgBaACgBKAFoAKAEoAKACgBaAEoAKACgBaAEoAKAKEqEatDJgYKFcnt9Ka2 DQv0gCgAoAKACgAoAKACgBaACgDnUdH8Ssj5SVAWX5fvD61XQZ0NSIKAFoASgAoAKACgBTQAUAFA BQAlABQAUALQAlABQAtABQAUAFABQAUAJQAUAFAC0AJQAUALQAlAC0AAoAKACgAoASgBaAEoAKAF NACUALQAUAFABQAUABoASgBTQAlAC0AJQAtACUAFABQAtABQAlABQAUALQAlABQAUAFAC0AFABQA UAJQAUAFABQAUAFAC0AFABQAlAC0AFACUALQAUAFABQAlABQAUAFABQAUAFAB0oAKACgAoAKACgA oAKAFoASgBaACgBKAFoASgBaACgAoAKACgBKAFFABQAlAC0AJQAtABQAlAC0AFACUALQAUAFACUA FABQAUAL2oASgBaAG0AFAAKACgBaACgAoAKAA9KAFoASgAoAWgBKAFoAKACgAoAKACgBKACgCvd3 kVoB5m4k9AozTSA5XUdTkW7kaKCTZKwCccZH96jTYpRe5sx65HFGouYpFIO3OKbWtkT10NaCZJ03 xnIqWgF8tNwbaMjvSC46mAUAGcUAGRQAUABAIwRkUAULqzZd0tuCXxwu7GPp70DuUYL5YYCWdvMQ cgrg/jTQynGkl35ccY2Bdxkc9T70N9hHS26COFEDbtoAz60hEgzjnrQAUAFABQAUAFAAOtABQBzm pxtHqeHJ2OMjaelNbA7Gpodyl1p6PErKgJVd3U470MC/SAPrQAUAFABQAUAFADWijYgsikjoSKAH UAFAGEuhsfFzay4i8tbfy0AHzFs8k/hxU9S7rlsbtUQLQAlAC0AFABQAlABQAtACUAFABQAUAFAH N6xaCylluEDiOXlmzwp9PxpxdhkmjPLLfR7Wby44cNnue1NsRvsMqQemKkDnNBhMmpSzJKWhiJQZ PUdvpTkN6dDpaQhKACgBaAEoAKACgAoAKACgAoAKAKer/wDINuDgnCE4B5oQbEehBf7MiKFiDyNx oYepoUAFABQAUAFAC0AJQAtABQAUAJQAUALQAUAJQAtABQAUAFABQAUAJQAUALQAUAJQAUAFACN9 0/SgCrp7blbJGRwQO1A2W6BGfrSK8EYZsfOCOKaAs2RY26b3Vyf4l6GkBPQAUAFAC0AJQAUALQAU AFACUALQAUAFABQAUAFABQAUAFACUALQAUAFABQAlACmgAoAKACgBKACgAoAKAFoASgAoAKACgCh PuGqQNtypBGSOnFPoPoX6QgoAKAFoASgBaACgBKAFoASgDHJzrBCsVKnJGOtVbQZsVIgoABQAUAF AC0AJQAtACUAFABQAtABQAlABQAUAFABQAtABQAlABQAtACUAFAC9KACgAoAKACgAoAKAEoAKACg AoAWgBKACgBTQAlABQAtACUALQAn0oAKACgBaAEoAKACgAoAWgBKAFoAKACgAoASgAoAKACgAoAK ACgBaACgAoAKACgAoADQAUAJQAUAFABQAtABQAlAC0AFABQAUAFABQAUAJQAtACUAFABQAUAFABQ AUAFABQAtACUALQAlABQAtABQAUAFACUALQAUAJQAtACUAFACigAoAKACgAoAKAAUAJQAUAFABQA tACUAFAC0AFACUAFABQAtACUAFACUxhQAUhBQAtAB3oAKACgA7UAFABQAUAFABQAtABQAUAFABQA lABQAUAZs+jW9xdG5laQvjGQ2MCi7HdFhdNtFi8vyV2kYOepoC7K91pgxvjy+0YWNulAXMq2dbOR 5rYbjuAKknn1HtiqvpqDOkhlSZA8TBlPQipasIeRxQADjigDNvjcKyhA/JJyvI+lNMZRt7i43xvM ro/Iwx/XFO66Ds9i7bXDJCwWfz3QfxcE0mK2o1tQuTE6xRxtcLj5d3GKdkFiaLUN2Ay/N3C84pWC zGzzWcoKvGH7MAKLDVym1/BDIUiSOJcnGBkEAU7A7lzTZreQmSP7xGOmOKXkJo0aQgoAKACgBe1A BQAlABQBn3mlxXN0s5Hz9Dz1H0oGmXYY1hjCIAAOwoEPoAKACgAoAKAAnHPYUAVoL+2nk8uOVS3Y Z5P4VTi1qBZqQCgAoAKACgBaACgBKAFoASgAoAM80AFAC0AJQAtABQAlADZI0kQpIoZT1BGRQA2K CKEERRqgP90YoAe67lKgkZHUUAV7GxhsYjHAp5O5iepNAFmgBaACgAoASgAoAKAF7UAJQAUAFABQ BX1BUa0kWQHYRzgc4oQIbpePsaYG1ew9qGDLVABQAUAFABQAUAFABQAvagBKACgBaAEoAWgAoASg AoAKACgBaAEoAKAFoAKACgBKAFoASgBG+6aAM/SOkhJGSx/Kmxs0aQjM14usMDI+0iUcevtTQF+3 XZCihQuB0HakBLQAUAJQAUAFAC9KAEoAKACgAoAWgAoASgBaACgBKAFoAKACgAoAKACgAoAKAEoA U0AFABQAUAJQAUAFAC0AJQAUAFABQAUAUrmXytQt18wASZGz1prYZdpCFoASgAoAKAFoASgAoAKA CgDFwra7nfyoPyg/TrVW0K0NqpJCgBaACgAoAKAAUAFACUAFABQAtACUALQAlABQAUAFAC0AJQAt ACUAFABQAtABQAUAFACUALQAUAJQAUALQAUAJjHSgAoAWgAoASgAoAKAFoAKAEoAKACgAoAWgAoA SgAoAKAFoAOlABQAUAFACUAFAC0AJQAd6ACgAoAKACgBaACgBKAFoAKACgBKACgBaAEoAKAFoAKA CgAoAOlABQAUABoAKACgAoAKACgAoASgBaACgBKACgAoAKACgBaAEoAKAFoAKACgBKAFoAOlABQA UAFAAKAEoAKAFoAKAA0AJQAtABQAlABQAtABQAlAC9qACgBKAFoAKAEoAKAFoAKACgBKAEpjCgAp CFoAKACgAoAKAA0AFABQAUAFABQAtACUAFABQAUAFAApyM0AFAASAMngUAVoNQtLjf5FxHIE4Yq2 QKbi1uJNPYf9qt9wUTx7icAbhzRYZk65DiRHJwhBFCv0GO8P3EKxrao5ZgOfTPpTkhG1UgFABQBH LbxS/fQE+vegLkSWFtGSY4wpJySPWgdyMaZApypZflx1oC5BNps+4NbXRTHXcM07juijfQSWqtmf fI2CwVecetO4EEdhPLCkxAClTzik2Fi1p4ljWPDCOMDlSpyx9KL9hG+DkA0hBQAUAFABQAtAAaAE JC9TigBaAEoAWgBKACgAoAKAKmqR3Etk8do22VuM5wcd+aa0YI5y1sW0qcNLbySytyJA3QemKem9 xnT2tys6kDO5eDkYpCJ6kAJAGScAUwOd03WrjWPEV1BYvF/ZliAryqQxmkI6D0ApvTQdjoqQhaAE oAKACgBaAEoAKACgAoAKACgBaAEoAKACgAoAKAFoASgAoAKADpQAUAFABQAUAFABQAUAVNWz/Z05 AY4XOB1NNARaA/m6XC+CMg8HtzSYGhQAUAFABQAUAFABQAUAFAC0AJQAUALQAlABQAUAFAAKAFoA SgBe1ACUALQAlABQAUAFABQAj/cP0oAp6cgUuwBG7t2pjLtIRQ1dDJHAqHD+aCD6U0NF2PPlikJj qAFoAKAEoAKAFoAKAEoAKAFoAKACgAoAKACgAoAKACgBKACgBaACgBKACgAoAWgAoASgAoAKACgB elACUAFABQAUAFABQBl3qxtq9mrKxcAnjoPrT6D0NSkIKACgBaAEoAKACgAoAKACgDGZE/t8bs5Z crxjkU+gzZpCCgAoAWgBKACgBaACgBKAFoAKAEoAKAFoASgBaAEoAKACgAoAKAFoASgAoAWgAoAS gBaACgAoAKAEoAKAFoAKACgBKACgBaAEoAKACgAoAKACgBaACgAoASgAoAWgBKAFoASgAoAWgBKA FoASgAoAKACgAoAKACgAoAKACgAoAKAFoAKAEoAWgAoAKAEoAKAFoAKACgAoAKAA0AFABQAUAAoA QnAyaAFoAKAEoAKAFoASgAoAKADvQAUAH0oAWgAoAKACgBKAFoAKACgBKAFoASgBaAEoAKAFoASg AoAKAFoAKACgAoASgAoAXtQAUAJQAUAFABQAUAFABQAUAFABQAUAJTGFABSELQAUAFABQAUAFAC0 AJQAUAFABQAtACUALQAUAFACUAGMUAIx2qWPYUAY/wBsa9nltZVCxFcEexqrAtHqVz4b8pj9lmVI u0e3AqVoP1Kl3o95bSq0arKmdxdRgrT5vILGfrBv4bSSK2juJ50+ZH25z7Cnzpbhyvoanguz1MWy XWrKIpiDmMLg596nmvsKzW51FABQAUAFABQAUAHegDH1Wxe5uT5beXuTk+uD0p3Y1Yu27LcWjRsr JjKsueRilYDG1G4WwikUw3E2SNoTlgPb2FUrbtj16G9Zyia3SQEnI78UmrEk1IAoAKACgBsYdQQ7 BjnjAxxQDHUAYfiWaa1EU0e4r0+XsaaaAv6Tdi8s0kyN2PmAOcUNAXaQBQAUAAoAKACgAoAiuYfO iKg7T2bHSgaMfFxb6gpKlo15Jz7daroBtQyrNGGXv+lSJoo+InjTRrpZN2HjKAKpJJPA4FGxUU29 B+i6bZ6XYpBYW0duhG5lVcZPcn3pJJbBJtvUvUyRaAEoAKAFoAKACgAoASgAoAWgBKACgAoAWgAo AqaldtZWxlWMyY7ZxTSAraRftcs4kkRix3KFOdo9M05KwGnUgLQA09RzjFAC0AGKACgAoAKACgAo AKACgCrqYzYzD/ZoGhukII9PiVTuAHBoYPQuUCCgBaACgBKACgBaACgAoAKACgBKAFoASgAoAKAF oAKACgAoAKAEoAKAFoAKAEoAKAFoAa+QjY9KAKmmFzETJ6nH0oGy5SEZ2tBjFFtIUbsEnsKpaDRc tMfZo9pGMUgZLQIWgAoAKAEoAKAFoAQnAoAKACgAoAWgBKACgAoAKAFoAKACgBKAFoASgAoAWgBK AFoAKAEoAKACgAoAKACgAoAKACgAoAKAM66z/a1tgLwD9aYzRpCCgBaAEoAKACgAoAWgBKACgDGR 1bW2HO5TxzxTHY2aQgoAWgBKACgAoAWgAoAKACgBKAFoAKAEoAKAFoAKAEoAKACgAoAWgAoASgBa ACgAoASgBaACgAoAOlACUALQAUAJQAUAFAC0AJQAUALQAlABQAtACUAFABQAtACUAFAC0AJQAUAF AC0AJQAtABQAlABQAUAFABQAUAFAC0AJQAUALQAUAJQAtABQAUAFABQAlABQAtABQAUAFABQAUAJ QAtABQAlAC0AJQAUAFABQAtACUAFAB/KgAoAKAFoAKAEoAWgBKAFoAKACgAoABQAUAFABQAUAJQA vSgBKAFoASgAoAWgAoASgBaACgAoAKACgBKACgBaACgAoAOlABQAlABQAlMYUAFIQtABQAUAFABQ AGgBaAEoAKACgAoAWgBKACgAoAWgBKAFoATqKAMO7hSO7YMNiMCC3XHoapDsatlIJLdfmDEDGali J6ADAoAKACgAoAWgBKAFoAOlACUAVr9N0QbcV2nOQMmmBVhuSk2ZPuMMn2oGypcKv2hkV2D4yoHO famhmjpayJCVZVVB90Dr75pMTLtIQUAFABQBWnv4IJxC7Ycrux7U0hdbE6sjgOpBHY0hlfU7UXlh Nbn+NePrQgMTwncybp4JYRHtYKMdDiqYHS1IBQAUAFABQAUAFACNu2nZjPbNAFW9haWAsDscDrQh oztOmMMoaQrgtswoPB/wqtwNwYxxUiEUYGCc+9AC0AFABQAUAFABQAUAFABQAtACUAFABQAtACUA FAFbUbc3FsyBVb1Vu/tTTsNGFpzRxsFSL7I8b5MYGWPtT06A/M6SNw6gipEx1IBaYCUAFABQAUAF ABQAUAFABQBU1R3SxlaPG4DvTQBpIxYx/Pu6kmhgW6QBQAZ7d6ACgBaACgBOlAC0AJQAtABQAd6A CgBKACgBaACgAoAKACgBKACgAoAWgAoASgAoAKAEf7jZ9KAKemIkaOqPuGfxFA2XaBFLVV/co2QA jAnIyKBos2wAhXHA7UAySgQUAFABQAUAFABQAUALQAlABQAtABQAlAC0AFABQAlABQAUAFAC0AJQ AtACUAFABQAUAFABQAUAFABQAUAFABQAUAFAFCcFtUhw2NikkUxl+kIKACgAoAKAFoAKACgBKAFo AxoV3alMw5USenOaYzYpCFoASgAoAKAFoAKACgBKAFoASgAoAKACgAoAKACgAoAKAFoASgAoAKAF oAKACgBKAFoASgAoAUUAFABQAUAFABQAlAC0AJQAUAFABQAUAFABmgAoAKACgAoAKAFoASgAoAKA CgAoAKAFoASgBaAEoAKACgAoAKACgAoAWgAoAKAEoAWgAoAKACgAoASgAoAKAFFABQAlAC0AFABQ AUAFACUALQAUAFACUALQAlABQAtACUAFABQAUAFAC0AFACUALQAUAJQAUAFAC0AFABQAUAFABQAU AJQAUALQAxWYswZCoB4OetAD6ACgAoASgAoAKACgBaAE70ALQACgBKAFoAKACgBKACgBKYwoAKQh aACgAoAKACgBG4U0AKucDNABQAUAFABQAUALQAGgAoAKAEoAKACgDJ1u3RtsjAgN8hwevoKaGivo NwEuZIG3AkDCkfdxTYM36kQlAC0AJQAgLbyCAFxwc9aAFIyMUAFABQAUAFABQBnXmnu7brcoMYIU jAzRcZWTTrySd5HZYQ3BCn9RTuGhrQReTEqbi2O570hEtACUAFABQBwsq3Wp6tdSbFjljb5MjkqD 29avmtoOxv6LqKNGUZuN23pyD70mgNupEcpBL9i8TTQMnyM+5SB1yKodjq6kQtACUALQAlABQAUA FABQBmanaquZ1HA5KjgH60IYaXemQiGRSG27h6Yqml0EadSAUALQAUAJQAUAFABQAtABQAlABQAU ALQAlABQAUAFAFO7s1kkEyRxlwedw60DTEt5XSTa5ByT04xTGy7SJCgBaAEoAKACgAoAKACgAoAU 0AZ+tqrae6s20ZHP40IET6eMWkYIxxQxssUCDvQBStpJDf3CORtXG0e1N7DLtIQUAFAC0AFABQAU AFACUAKaACgBKACgAoAKACgBaAEoAWgAoASgBaAEoAKACgBH+63Qcd6ARU04hldsANnBxQNlygRl eIZVitYw2fmfAHrTiNGhaH/Rojz90daTES0AFABQAtACUAFABQAtACUAKKAEoAKACgBaAEoAKAFo AKAEoAWgAoAKACgAoASgAoAKACgBaAEoAKAFoASgAoAKAFoASgAoAo3BT+07YE4cBiMdxTGXqQgo AKACgAoAB7UAKaAEoAKACgDJiDDVHjRW5O9mzxj0p2Kua1IkWgAoASgAoAKACgAoAKACgAoAKACg AoAKACgAoAKACgAoAKACgAoAWgBKACgAoAWgBKACgAoAKAFoASgBaAEoAWgAoASgBaAEoAPwoAKA FoASgAoAKACgBaAEoAKACgAoAKACgBaAEoAWgBKACgAoAKACgAoAKACgAoAKACgBaAEoAKAFoAKA CgAoAKAEoAKAFoAKACgBKAFoAKACgAoASgAoAKACgBaACgBKACgAoAKADvQAUAFABQAtACUALQAU AJQAUALQAUAFABQAUAFABQAUAFACUALQAlAC0AFABQAUAJQAtACUALQAUAJ6UALQAUAFAAKAEoAK AFoAKAGimMKACkIWgAoAKACgAoAQ9KAFoAKAFoAKACgBKAFoAKAEoAKAIpbmCEhZZkQn1OKfK2BH /aFn83+kR/L15o5WK6Q6G9tpiwjnRivUA9KOVgMmubSRTG08WT0+YUcrGmc6cw3omjZdqEguxJ3U 9dhs6PT7n7VarKUKE5BU+opNW2EWePWkAUAGR6igAoAKACgAoAKAKeoXhtiqKBkgksTgAf1ppAQr fSlwu6LPXPqP8aLDsTW18JSwZCpU9uQaLBYmW4RlyQy+xHIosFiRJFfgH3pWFYdQAtAB2oASgDmE I03WbgmHG98qT0INPQofexy212VgjKidt5Y8j3BpprqB0FuWMY3DkVImc5qCt/wkuQ+35FKZHG70 qkCOn7VIgoAAMDAoAKAGySLEheQ7VHU0AOoAWgBKACgBGUOu1gCD2oA5vURd2F15scbvCv3So7el UmnoP0NyxuftMQYrsbuuelSxFmgA+lABQAUAFABQAvagBKACgBaAEoAWgBKAFoASgAoAKAFoAqXd urBnIBHoaBphYzM6FHRgycE44P0psGi1SEFABQAUAFABQAUAFABQAUAUtXGbB+A3Tg/WgB+mOZLK NiQSfSgC1QAUAZ8JkGrSrtAjKdQO/wBaBmhQIKAAjNAC0AJQAUAFABQAtABQAUAJQAtACUAFAC0A FACUAFAC0AFABQAlABQAUAR3GPIkyARt5BoAr6ajRxlSOBjFA2XKBGN4kRnjtljfDeZkD+9TQGrb jbAg74pAySgAoAKAFoASgBaAEoAWgAoAKAEoAWgAoASgAoAKAFoAKAEoAKACgBaACgBKACgAoAKA CgAoAKACgBaACgAoASgAoAKACgDMu40fV7U5G9Ace4pjRp0hBQAUAFABQAAY6UALQAUAJQAUAYEZ k/4SDPmKF5UAd/UUx2N+kIKACgBaACgBKACgBaACgBKACgAoAKACgAoAWgAoASgAoAKACgAoAKAC gBaAEoAWgAoAKACgBKAFoASgBaAEoAKAF6UAJQAUALQAlAC0AJQAUAFAC0AFABQAUAJQAtACUAFA BQAUAFABQAUAFAC0AJQAUAFABQAUAFABQAtACUALQAlABQAtABQAUAFACUAFAC0AJQAUALQAlAC0 AFABQAGgBKAA5Ix0oAOlAC0AFACUALQAUAJQAUAFABQAUAFABQAUAFABQAUALQAlAC0AJQAtABQA lAC0AFACUAFABQAUALQAUAJQAUALQAlAC0AJQAtABQAUAFABQAUAFABQAlAC0ANpgFABSAKAFoAK QBTAKAEJwKAHUAFABQAlABQAUAFABQAUAQ3onNs4tdvm9snAoBHLP4d1N7syvJEyH+Hccj8aHN9g SSK6eGL+KYkYKnIOHxnPc01NlJJER0rWrXzBDGxVhg4wSabqLqLlG/YNSDx+fbk7Vz8sZ4NTcOQg u0udi5LbwfuFCvNVz+QWCzvL3y2jhExkB+b5jkH6U+YFGxdV9SigC+cylTlV2HkelLmTHy2J3utR Ee6QkAA/KQct7U00DiO0O31K5lEkrGJIyMcEfhScrhax19SSFABQBFLKUdVC5B6+1A0hIXdnbdwo PFAMkkjSQYkUMPcUCKUmlQsu1MjHTnpQO5TNhexf6tsqfvANz+FO+gaDJI7mKPzXeRHzyCRihMCx pMF1HPI1wQQeRzkj2obG9jW6UiQoAWgBPSgDJ8SW5lsTIq5MfUeo7046Ma7GbJdQvparvdpI8EIe pqndO4mW9N1CGC3kzITtGST0z3pNAUtP/wCJjrPnsQUA3DHY+tD2sNHVVIgoAKACgAoAKACgAoAK ACgCveSxRqiSvsMrbEP+12oQXMeG5+y3TszpkHbJzzx0q7NoGbsUiyxh4zlTUMB9ABQAUAFABQAU AFABQAtABQAUAJQAUAFAC0AJQAUABGRigDOlMlvIiiQkluh7imMvROsi5BB+lIQ+kAtMBKACgAoA KAFoASgAoAoa2gk0yZdwXI4JOKEA7RVCabCAMACgC7QAUAU4C32+QFcDHXPWmNlykIWgAoASgBaA CgAoASgAoAKAFoASgBaACgAoASgAoAWgBKAFoASgAAwOtABQAtACUAMnAMLg4xjvQNFbTS21w7Dc MfLnoO1AMuUCMfxFKsa2isMl5cDnGMA01YDVgbfAjeoBpAPoARWySPSiwC0AFABQAUAFABQAUAFA BQAtACUALQAlABQAUAFABQAtACUALQAlABQAUAFABQAUAFABQAUAHFABkDkmgAyPWgAoATev94UW CwhkRerCiwDfPjyRuGfSiwWMuWRZPEVsEkDBIjwOcZqtkM2KkQUAFACmgBKACgAoAWgAoASgDnUx Hr5LsS7yEfKMhRjjNMZ0dIQlABQAtAAaACgBKACgAoAKACgBaAEoAKACgAoAKACgAoAWgBKACgAo AKACgAoAKACgAoAKACgAoAWgAoASgAoAWgBKACgBaAEoAKACgAoAKACgAoAWgAoAKACgBKAFoASg BaAEoAKACgAoAKACgAoAKACgAoAKACgBaACgAoAKACgANABQAUAFACUAFABQAtABQAUAFABQAlAC 0AFABQAUAFABQAUAAoAKAEoAKAFoASgAoAKACgAoAKACgAoAKACgBaACgA+lABQAlABQAtACUALQ AlAC0AFABQAlAC9qAEoAWgA6UAJQAtACUAKKACgAoAKAEoAKAFoASgBRQA2mAUAFIAoAWgAoAKAC gA+tAC0AJQAUAHSgBaAEoAKAFoASgAoAKACgAoAKAK1/aLeWzRNweqt3B9aBo5SbfaagjL2I3AcE kU0LU6yxuVvbWOdUZA38LjBFDVgLGB6UgDpQAUAFABQAjDjgAn3pALTAKAGmRAwUkAnp70AOoAin MbRsr4IxzRYaCF4iq7CPmGR707AS0hBQAUAFACOquhV1BUjBB6UAcbqVnY3E8iWczRybsYzn8qu0 rDutixaaHFNtD3j/ACDBVRtz9an3rDsjpbW2itYgkI4Hc9TUpWEyamIKACgBaAEoAKACgAoAKACg CO4giuYWhnjV42GCppAnbYzbzSbVLYeRDsMa4BUnP/16oq9yHTbmW2ZI5YyIzxnBoYjc+lIQUAFA BQAUAFAC0AJQAtABQAUAFABQAUAJQAtACUAFAEF1bCcDDMjL0K/yoGnYrWp8mQgMCC3zDptNMbNA EEAjpSJCgAoAKAFoATpQAUAFABQBR1oqumylgSMdqADQ3L6VbM3Xbjpim9wL1IAoAz7cBNTkA43L ux/WgbNCkIKYBQAUALQAlAC0AFACUAFAC0AFACUALQAUAJQAtABQAdKACgAoAKAEoAKACgBsv+qb 6UAinpfzI8hH3j949xTGy9SEY3iMlfsbKseRIfmc4CjHNNAjWgIMKEYxtHTpSBj+1AGFeXJ087Hm lGW4KqD+HrVJDZDcX12+3yVkVgdwOOCKFYS1L66g7KuEcZ6txgUtBobZ6hKcq5WY5OGUYz7U9LhY lGpMJ/JeBs5AyCMUrLuJ7k/2+HGfm2+u04pWCw5L23cArKME4B9/Sm4tAAvYDn5xwcUWBCfboQNz NtGcfjSASW+jjOSCVxkMKAEfUYVKrn5iM4p2AR9TtkCHd9/pgUWAF1GJlVugJxyQMUJARtq9upOW HHvT5QI11mBg4U/MntwaOUPIkbVoQqEHcXHC9KVgIRq4PnFNp8psMAemelOwDU1yITrFIcEjr059 KLAPbWELhYwCD0JaiwEb6wSpNuobsM9c/SiwxItRnERd/mbOAo70aCHHU7hZF3pGqMcBS3I/GiyA e2qYZwq7goxx2P8AhSsMiGr4mEbKdp5z607ASHUQJB+9DK33QowQPekMrrqU5K+WVdj0VuATTJ1A 312JSJJEXPRV5xRoMl/tfkqPm4+Uj+96UWQCfbJFJQOWwPvMOjelJtDSZEb9lkWJvOMrDoBgA0XQ reQ03FyGaNhJ87cL0wPY079gJFe7kij2JKjAlWDD73pSugSsLJBerGeZWcYYBcflTuhiGHUpF3uG DtxhT90UuYViG/ttWVGSwOJGwd7AYo5u4uW2xSbSdZvLpbi9by/JwY0hfGT3z6ihVHtsO1uppXFj qRgLQMizdee/tQml0HoUNOt7y31m188bGdSXVcY+tPm00FY62pEFABQAUAFABQAUAFABnnFABQBh I0I8QMrcOeVC9/rTKN2kSFABQAtACUAFAC0AFACUAFABQAtABQAUAJQAUAFABQAUAFABQAUAFABQ AUAFABQAtABQAlABQAUAFABQAtACUAFABQAUAFABQAUAFABQAvagAoAKACgAoAKACgBKACgAoAKA CgBaACgBKACgAoAKACgAoAKAFoASgBaAEoAKAFoAKAEoAWgANABQAUAJQAUAFAC0AJQAtACUAFAC 0AFACUAFAC0AJQAUAFABQAUALQAlABQAUAKaAEoAKAFoAKACgAoAKACgAoAKACgAoAKACgBKAFoA SgAoAKAFoAKACgBKAFoAKACgAoAKAEoAKAFoAKACgAFABQAlAC0ANpjCgApCFoAKACgAoAKAA0AL QAUAFACUAFAC0AFABQAUAFABQAlABmgBaAEoA5LxZaTpKktvD5iswLHPT2qk7D6Gl4ZW7jS4juU/ d7g0bZ65HIpNp7A1Y3KQhKAFoASgBaAEoAKAGyglPl6igEY87y+c0ku1VX5l4zz9e1Mplua5kl08 vbj95jBB420CsZ6+fJaxCNyQynK55+tPQY+P7RbGOJ8tvHXGMe2aXQLGja3Ib5WOD0xQIt0hBQAU AFAHLQaTG186RsY3VydxGc+1UyixdWV9bAtD8wHOVP8AShNdhWH6Zq7NN5EzLlRye9Fk9UL1N4EE AjoakAoAWgAoASgAByMjpQAUAFABQAUAFABQBm31vKGZo2GwjoT0poe5LYXSy/uwVIUdj0PpQ0DR dpCCgAoAKACgAoAOlAC0AFACUALQAlABQAUAFABQAUAKaAKGoRldsqjKA/vB3x60DQ6wmU5i8xWI PAHpTaAuUhBQAUAFABQAUALQAlAFDWwx0yby87gMjBoQBoOP7Jt8En5eSwwc02BfpAFAFKGNv7Rl kJG3aAtAy7QIKAFoASgAoAWgBKACgAoAKAFFABQAlACigAoAKACgAoASgBaAEoAKACgAoAWgBkqe ZGyZK7hjI7UAVNMsmso3RpC4LZUk9qLgXaAMzX4/NtUXarfP/EMgU1YEX7cAQRgdAopASfSgDi3m uX1S7triMN8+6Lac9O/tVaD8ieK7K6hBFFBIZN+GJz83rzRoCTOs2qRgqMemKkQz7PF2jUduBQO5 AdNtiW+U5Y5PJ5ouFxj6Yh8vZLInl52jOetFwIhpGFC/aZcA57UXY7oVdJRV2hyBnNNNoQraPAVA 3P8Ae3ZzyaV2FyT+zY95cO30PSgLkf8AZEJYMZJCQMdaLsLhFo9vEpUFsnvRdhcP7GtcjK5A6CjU Liro1koZREMNjP4UBclXTrVTlYQv04zQF2RJo1kjhkjwMEY6jmhaBccdIsthXyBg0BcP7KtRGqCM YUk88nmgfMA0izVgwi5HvQK5P9itv+eKD8KAuyMabahdoQ4ByOaAuPSxt0JxGDn15pBcf9mhznyl zjGcUwuwFtAP+WSevSgLsPs0H/PJPXpQK5JsX+6OPagBPLQ9UX8qAuBijJyUX8qB3HbR6CgQYHpQ AYHpQAUAFABQAvSgBKACgChdof7TtGUf3gT7YpgX6QBQAtACUALQAUAFACUALQAlAGBbqw8S3Drt IYBTnsPagZ0FAgNACUAFAC0AJQAUAFABQAUAFAC0AFABQAlABQAUAFABQAUAFAC0AJQAUAFABQAU AFABQAUAFAC0AJ2oAKACgAoAKACgBaAEoAKACgBaACgAoAKACgAoAKAEoAWgBKACgAoAKACgBaAC gBKACgAoAKACgAoAKAF7UAJQAUAFAC0AJQAUAFABQAtACUAKKACgAoASgBaAEoAWgBKACgBTQAlA C0AJQAUALQAlAC0AFABQAUAJQAUAFAC0AJQAtABQAlACmgAoAKAEoAWgAoAKAEoAWgANABQAUAJQ AUALQAlAC0AFACUAFAC0AJQAUALQAlABQAtACUAFACigAoAKACgBtMYUAFIQtABQAUAFABQAGgBa AEoAWgAoAKACgBKAFoASgBaACgBKAFoAKAEoAQqD1ANIBQMdKYC0AFACUAFACmgAoAQqDjPY5oAW gDO1CB1j3QHBDZ56CgpEMUy4bzV2SEAMMYB9MUwIZpgkSnZ5MIzu9RR1E2asJW5to324yMjPakGx kTQS2zyRgnLt8rE9B6gU9B+hrWMheAZYMy8EikJks8yQQvLK21EGSfQUJCMy3163nGVHy9Q2RjH9 KpxsBaTUIXGc4+tKwGRe3kMOpIV3Dcd7EEYp9B3aNB9YgDADO3GS3pRYDnbq8trrUpntImSRBlto 6+/HSi6WwLU3vD12ZoWjII2gEUmI16kBaYCUAFABQA1ZA4bYeVOD7GgB1ABQAUAFABQA2RA6FT0N AJnPXW+xlmEChIx87ZU5b6GqRXoblncC5hV9pU46GpJtYnoAKACgAoAKAFoASgAoAWgBKAFoASgB aACgBKACgBaAEPPB70AY93FJamMI+xN+QVXn6Yporc1IJRIo9cdKRLJKACgAoAKACgAoAKAKWrLu snG5Rjn5uM00AmisW02EkjPPT60MC9SAKAKtuF+0ybSM9xTKZapEhQAUAFABQAUAFABQAUALQAUA JQAUALQAUAJQAUAFAC0AJQAUAFABQAUAFABQAUAFAGN4l+aGCPdgO/Iz1GKqI0a0KqkKKgwoUACp EPoA5i0CDxZOnyklCcrz+dNjZ0yIsahUUKB0ApCFoAKACgAoAWgBKACgAoAKQBTAKQBTAKACgAoA KAFoASgAoAKACgAoAKACgBelACUAFABQAtACUAFABQAUAFABQBQu1ZtStT0Vcn8aaHYv0hBQAUAF ABQAUAFABQAdKACgDEtQv/CQXDdMDHC9fxpjNukIKACgAoAWgAoAKAEoAKAFoASgAoAKAFFABQAU ABoAKAEoAXtQAlABQAUAFABQAUALQAlABQAUALQAlABQAUAFABQAUAFACmgBKACgBaACgAoAKACg AoASgBaAEoAWgAoAKAEoAWgAoAKACgBKAF7UAJQAUALQAlABQADPegBaACgBKACgBaAEoAKAFoAK AEoAKAFoAKACgAoASgBaAEoAKAFoAKACgBO1AAOg7UAFAC0AFACUAFABQAUAFABQAtACUAFABQAt AB2oAKACgAoAKACgAoAKAEoAKACgBaACgBKACgBaAEoAXtQAlAC0AFACUAFABQAUALQAUAFABQAC gBKACgAoASmAUAB9qQC0AFABQAUAFAAaACgBaAEoAKAFNACUAFAC0AJQAUALQAUAFABQAlABQAUA FAC0AAoASgBaAEoAKAFoATqOQKAKU9ptLPCGYMcsmepoKTM7+z57hplIljBfOHOVYU7iNyJBHGqD ooxSEyvdRbpFYDoDklc8UykGnW/2eDbuJ544oYmWJYkmjaKVQyMMEHvSEZcvh6wK4hi8o+q0Idyq /hstIW+1sB2+WnzPYNCjrfh2RLVZYZnkaPjbjoPWjme4WQ7w/p0V7ag3NvcQOnU5wGocr7MNjobb TrO2DiGBFLjDHHJqUrBcy9EgEer3mEZVT5FJPBFU2HTY36QhaACgBKACgBAAM7QBk5NAC0AFAC0A JQAUAByMYH1oAq6ha/aYCqsUb1Hf2oGjLF8tldokwIAG0Adh71SVx2N1SGGV6GpJFoAWgBBQAUAF AC0AJQAUAFABQAvagBKACgAoAWgBKACgBkqCRCpH0oBGVbSiFzJICm0fP65+lMrbQ10YMoZehpEi 0AFABQAUAFABQBT1Vo0sXaXGB/OmhofYFfscbKByM8DrStYGWaBBQBTt3Q30yr94AZ5pjLlIQUAF ABQAUALQAlABQAUAFAC0AFACUAFAC0AFACUALQAlAC0AFABQAUAJQAUAFABQAUAZWuwxzC33Oqsr Egnr05xT1GkaUP8AqkPtSEPoA5uxaNfFUvXzHjb2yAadwOkpAFABQAUAFABQAtACUAFABQAtACUA FABQAUALQAUAFACUAFABQAUAFABQAtACUAFAC0AJQAUAFABQAUALQAUAJQBm3ZB1a3UISVGSSeBT GkzTpCCgAoAKAA0AFACUAFAC0AFAGIgZNccsxw3QevtTGbVIQUAFABQAtAAaAEoAKAFoABQAlABQ AtACUALQAlAC0AJQAUALQAlABQAUAFABQAUALQAlABQAUAFAC0AJQAUAFABQAUAFABQAtACUAFAC 0ABoASgAoAKACgAoAKACgAoAKACgAoAKAFoAKAEoAKACgAoAUUAJQAUALQAlAC0AFACUALQAUAJQ AtACUALQAUAFABQAUAFACUAFABQAUALQAlABQAtACUAFABQAtABQAlABQAvagBM4oAKACgBaACgA oAKACgBKACgAoAKAFoAKACgBKACgBe1ACUAFAC0AFACUAFAC0AJQAUALQAlAC0AFABQAUAFABQAU AFACUALQAUANpgFABSAKAFoAKACgAoAKACgBRQAUAHSgBKAFoADQAUAJQAtACUAFACmgAoAKAEoA KACgAoAKAFoASgBaAEoAKACgAoAhublLdcnJY/dUdTQFimb1pD5W9YpcH5euPemMjh1CSOJ2uCHj U48xf8KdgH2eqLPMiRxP5b8K/Y0rWA06QgoAKAA0AGMdBQBTuILjzN8MuExypGeaLjRU0zUBJNLG 67XD7SMd6prsDNepEFABQAtACUAFABQAUALQAlABQAtACUAZmpaesrGUZ6YKjvQhplfSZ1tSbXJ2 h8fO2SDVWE9DbqQCgBaAEoAKACgAoAWgBKACgAoAWgBOlABQAUALQAlABQBBPArN5gUbgME46ihD TKtnM8LmCb+H+I9x602DNGkIKACgAoAKACgDP13H9nOvGWIAyM04jH6QpGnxBgMj04obEXaQBQBQ t1xqtywP8KjGMCn0GX6Qg+lAC0AJQAUAFABQACgAoAKAFoASgAoAWgAoASgAoAWgAoAKAEoAKACg AoAKACgAoAKAMjXhmW1AHJLYz0HSmho1YxiNR7UhDqAOcskH/CVTblJIQlSOgqr6AdHUgLQAlABQ AtABQAUAJQAUAFABQAtACUALQAUAJQAUALQAlABQAUAFABQAUAFABQAUALQAlAC0AJQAtACUAFAC 0AJQBl6hMqalboFbee4GQR6U1sNI1KQhaAEoAKAFoASgAoAXtQAlABQBiGFYdbwSW8z58k9D6Cnc Zt0hC0AJQAUAFABQAUAFABQAUALQAlAC0AJQAtAAKAEoAKAFoASgBaAEoAKACgAoAKACgAoAKACg BaACgAoASgAoAKACgAoAUUAFACUAL0oAKAEoAWgBKACgAoAKACgAoAKAFoASgAoAXtQAdKAEoAWg AoASgAoAWgBKACgBe9ABQAUAAoAKACgAoASgAoAKACgAoAWgBKACgBaAEoAKAF7UAFABQAUAFABQ AUAJQAtACUAFABQAUAFAB7UAFAC0AFACUALQAUAJQAUALQAUAJQAtACUALQAUAJQAUAFAC0AFACU AKaAEoAKAFoAKACgAoASgAoAKAFoASgAoAWgBKAFoAKACgBtMYUAFIQtABQAUAFABQAGgAoAU0AF ACUALQAUAFABQAUAID14xQAUALQAlABQAUAFAC9KAEoAWgAoAKACgAoAKAEoAKAGTP5UTyYJ2jOB QBliOe6YO8gC4JAH+e1MaRaGnWz4eWJWfGNw70guTCzgG/EY+cAN74o2C4tvbRWybIlwM5/GkImp gIxCKWY4A6k0ACsrjKnIpbhawtMAoA5PVPFgs9XlsAMOnTIyKuKVhX1GaBFJqF79sncxEENjpvND l0RR19QIKAFoAKAEoAKACgAoAKAFoASgAoAKADjpQBh6jaeTcNOSPLfHbJz6U7j9CXSdTaZmhuOq nAfpn2pvyCxr1IgoAWgBKACgAoAKACgAoAKACgAoAKACgAoAKACgApAZmrwvhHjjLLnDY61Q0WbG 4WWIA5Uj+FutDQMtUhGdq+qJpyDKsWb7vGRTSAdo9+b+BmdQrKccUNWAv0gCgDK8SK39msyDLKw7 44poaJ9GQppsCl2fC9WHNIReoAKAKtuM3UzZORxQUy1QSFABQAUAFABQAtACUAFAC0AFABQAUAFA BQAlABQAtABQAlABQAUALQAlABQAUAFIApgYniVnjNpIrbVDkE4poDaT7g+lIBaAObsIwfGFzKhP NvhsHjOf51TvYDpKkAoAKACgAoAKAFoASgAoAKAFoASgBaACgBKACgAoAKAA8UAFABQAUAFABQAt ACUAFABQAtABQAUAJQAUAFABQAUAZV5IW1mGEM4GzPHTNPSw0atIQUAFABQAUAFAC0AFACUAFAGJ Esn9uO8hVgG2g/3RimM26QgoAKACgBaAEoAKACgAoAKACgBaACgBKACgAoAKACgBaACgBKAFoASg AoAKACgAoAKAFoASgAoAKAFoAKAEoAKACgAoAKAFoASgAoAKACgBaACgAoASgAoAWgAoAKAEoAKA CgBaACgBKAFoAKACgBKACgAoAKAFoAKACgBKAFoAKACgAoADQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFACUAFABQAUAFABQAtACUAFABQACgAoAUUAJQAtAAaAEoAWgAoAKAEoAKACgBaAEoAKAFoAK AEoAKAFoASgAoAWgA6UAAoASgAoAKACgAoAWgAoAKAEoAKAFoAKACgBtMYUAFIQtABQAUAFABQAU ALQAUAFABQAlAC0AJQAtABQAUAFACUALQAhIHUigBaACgANACUAFAC0AJQAUAFAAKACgAoAKAK7Q CJtyYA/lQO5UfU4reLeVcrnaGA4JqrAy3HeQsQMlSV3YIqbBYsAg9KBBQAUAHSgAoAKAKl3ptpdh vOhQuR9/HzfnSsO5iPZSaLKHQl4QuEb+4au9wN6wuVubZJEOeOalqwiyaAEoAWgBKACgAoAKAFoA SgAoAKACgAoAbJGkqFJFDKexoAwLy3+w3ActIy7gV+X5V+tNMLFzSdVWdzaz8TrnHow9abj1A1ak AoAKACgAoAKACgAoAKACgBaAEoAKAD8KADpQAUAFADZEEiMjdGGDQBjXKS2L+bGAdq7AzHj2yKpM Zq2lwlxCrp6DPtSasIpazaiRUn5ynBHUYPtQhozfDzpBezRxq6Rt2POT60eQ2dLSJCgChrRC2R9N w7UIESaS27ToCAQNvQ9abAt0gCgDOsvNOo3ZZWWIYAyOp9qdxtGjSEFABQAUAFAB0oAWgBKACgBe lACUAFAC0AFABQAUAFABQAUAFACUAFABQAUAFADZW2RswGcDpQBHa3AuI9w69xQBNQBh+KVfybdk IXEmCW6Yqot9ANuP7i454qQFoA5vRdq+Jb9c/MYwcfjVMbOkqRBQAUAFAC0AJQAUAFAC0AJQAUAF AC0AJQAtACUALQAlABQAUAFABQAUALQAUAFABQAUAJQAUAFAC0AFACUAFABQBk3ihddtXDjcyFdn t1zT6DNakIKAFoAKAEoAWgBKACgAoAKAMdFA1l97EH+AHoadijYpEi0AJQAtABQAlABQAUAFAC0A JQAtACUAFABQAUAFAC0AJQAtABQAlABQAUAFABQAtACUAFABQAtACUALQAUAFACUAFACbvn27T0z ntQAtABQAvSgBKACgAoAWgBKACgBe1ACUALQAUAJQAtACUAFAC0AFAAKACgBKAFoAKAEoAKACgBa AEoAKACgAoAKACgBaACgAoAO1ABQAUAFABQAUAJQAtABQAGgAoASgBaAEoAWgAoAKAEoAKAFoASg AoAQ0ALQAUAFAC0AJQAUALQAUAFAAaACgBKACgAoAWgAoAKACgAoAKACgBKAFoASgBaACgBKAFoA SgAoAWgAoASgAoAWgAoAKAEoAWgBtABTAKQC0AFABQAUAFABQAtACUAFABQAUALQAUAFABQAUAFA BQBXvHlSL90uSeD60AjKkstRgiaWG43sy/MrDJB9qrm7oaiuhFFrAjuVtZDKlw4wo28A+pzQlfYH c24phICrjBHB9D9KloLEqKEUKvQUkrCFpgFABQAtABQAlABQAUAFABQBm6sL7axsgGyuAM4wfWi6 QzNk0/UTa2wVVyDl4zjg/Wq5l2BD5YtTYOn2fPGUO4Aj2zRdDNjT4pobcLcPvk7mpbJLPtQAYx0o AKACgBrusY3OQB6mhAYOo649vqz2artVIw+71J/SqSQakL65BLZXEdw0cmFxx3J6cU3ELkngsObB 3bKqWxt7Z71MmFjoqQBQAUAFABQACgBaACgBKACgAoAKACgBTQBHNEk0ZjkGVPWgDCntGTUduHCn lZPT8ad7DL9jeuZDbXJ/eDlXAwGFNrqgsaNSIKACgBaAEoAKACgAoAKACgAoAUUAJQAUAI4JRgrb SRwfSgBIldYkWR97gYZsYyfXFADqAKl+9s0bRTsuT0XPJNNK40Ube4Fq/Uqn/LRW52+4NO1wNOUC 5tXWM/fQgGp2DY4nUbh9Li+0t8s0fysynPtxVoGtTsNIvotR06G6hfcrjk9ORwf1qWrMlFreu7bk ZPQUrDMrxMzJp3y78lh93rTQy7pYxp1uOfuCkxFqgAoAKACgAoAWgBKAFoASgAoAKACgAoAWgBKA CgBaAEoAWgBCQoyeAKAImuIlYJvXcRkDPWiwCG5hGcuAR2zzTsHkO8+PGd1ILDvNTgbhz0osALLG 3RhRYLCCVCMhgR7GiwCmRAcFhRYBd6jqwosFivdzxiFl5ywwKY9htgqRoSrKxbklelFgZa3KO4pC M3XBG8CByCuclfWnYaNGHiJPoKQh1AHP6OpGu3hYruC4BC4yM03YbOgpCCgBaAEoAKAFoAKAEoAW gAoASgAoAWgAoAKAEoAKACgBaAEoAKACgAoAWgBKACgAoAWgBKAFoASgBaAEoAWgBKACgDIuZNni K3QH78RyPoafQDXpAFABQAUALQAlABQAUAFABQBhWUk0uqSCX5XQnCng7c0xm7SEFABQAUALQA1m Cgk9BQBTj1KOSYoI5Ao/jI4zTsC1LtIAoAKACgAoAKACgAoAKACgAoAWgAoAKACgBKACgAoAKAFo ASgBaAEoAKAFoAKAEoAWgBKACgAoAWgBKAFoADQAdqAEoAKAFoASgAoAWgBKAFFAAaACgAoAKACg AoAKAEoAKACgAoAKACgAoAKAFoAKACgBKAFoAKACgAoAKACgBKAFoAKACgAoAKACgAoABQAUAAoA SgAoAWgBKAFoASgAoAWgAoAKAG0ALQAtACUAFABQAtABQAUAFACUAFAC0AFABQAUAFABQAlABQAt ABQAUAFACUAFABQAUAFABQAUAFAC0AFABQAUAFABQAlABQA0Uxi0hBQAtABQAUAFABQAUALQAUAJ QAtABQAUAFACUAFAC0AFACUABAIxQAAYGKAMzV2sHQxXMyxuRgMD8y+9HKO9kVI91k6JcPuhUgJI 3T2P1qkFrGraXSys0ZYF07joaTEWaQCO6xqWdgqjuTigBqzRsFKyKQ3Qg9aAH0ALQAUAJQAooASg AOe3FABQAUAFABQAtAB9KAEoAMUAI6CRGRhwRg0AZ8Mdvdh7e6iSR4ztO5eSOxodh3aI/wDhHNLL Oxtgd5BYEnHFLVBzGmkaxIEjUKo6ADpTEPoAKACgAoAKAEoAKACgA79eKAFoASgAoAKACgAoAhub dLiPa/bkH0oAyrvTGW4SUcqpyGBOUp3fQZZjvfs4JuJFZCflxyaAsaKOrqGU5FIQtABQAUAFABQA UAFABQAUAFABQAUAFABQAUAc/rEc9rI1zbrnbyc8/U079Ble2ctu32qu5IYhDwR+NO4XLu+ZGmXz HhCru5AxQBT1azt/KDHiKXkALlt9SGhJ4Z3C1uvKnyZPnWJ+qNjB/DpRs7A0VJtVmUqttEZLiNwH QnqR1qrrcWr0NTX5BJpkcoX+IHBOMe1JAadgwezhYLtBQED0pDZPQIKACgAoAKACgAoAKACgA4FA BkeooAQMp6EcUAJ5i4yGGKAAOp6MKAGvMiNtJ59KLAQSajbxqx8xPlOD83SnygM/tGNiwjKkLjLE 4GfSiw7Ia94skhjjlwRzlf5UWCxAdUVQPmJKkBgadgIriae6LR25MisO3AH40XsARaRPiMiRUA52 kZwfalzaD0JZNJlcf6xN3Xdg5/nSu0LQY2m3sTYhlj8s9eCD+FPm8gQiWeoiWYyLbsjDCbSQR9aH LpYdvMjWzvyQs0SMByGVzwaLhoTwQ3yxhHt0yerCTpQFxJBdicCW1Z4+i7GHy+9F0BBCL1llLo8j qcKG9/ei6Ac9jex2rIkilWGCshJou3uCtYZZ211DF+7KFAeArEcelO/kJGlBDMQN749B1wKkeiRX 1REh+znbvKkgM3IH1p3J2NWMYjUe1IB1AHPaarL4nvCu542T72cgH0FPUpnQ0iQoAKACgBaAEoAK ACgAoAKACgAoAKACgAoAKAFoAKADtQAlABQAUAFABQAUAFABQAUAFABQAUAFABQAtACUALQBi343 eIrFSpAKMQ3uO1MDZpAFABQAUAFAC0AJQAUAFABQBycTxWGvMplkVFZizM24HPOPaqUdBm1Z61b3 JIHy4JGSwxQ42EXI7qKQgKSCemRU2Ad50f8AeFFh2GvdQR53yAY60WFYo3WsRp5giBIjGSR/hTsF jNhub27m3oszBuOeFA9Kd0NJ2JFtFgfbKyux6bSeD70vQaR0KfcH0pEi0AFABQAUAFABQAUALQAl ABQAUAFABQAtABQAUAJQAtABQAUAFACUAFABQAUALQAdqACgAoABQAlAC0AFABQAUAFACUAFAC0A JQAUALQAlABQAtACUAFAC0AJQAUAFABQAUAFAC0AJQAUAFABQAUALQAlABQAtAB2oASgBaACgAoA SgAoAWgBKAFoASgAoAWgAoAKAEoAKAFoAKAEoAKACgBRQAUAFACfjQAUALQACgBKACgBaACgAoAK
October 02, 2013 - October 14, 2013
Pietenpol-Archive.digest.vol-my
