Pietenpol-Archive.digest.vol-nd
December 21, 2013 - January 21, 2014
Subject: | Re: Extended Fuselage Question |
Thanks Gary.
Additional clarification. I am looking for the longitudinal (front to back?) location
of the "struts". I understand the length, as you mentioned.
I have spent several hours comparing the two fuselage drawings and am certain I
am missing something. I don' want to "guess" on the location of these key elements.
Grant Ziebell
Savannah, TN
http://forums.matronics.com/viewtopic.php?p=415971#415971
Headed to the airport now...I'll get back to you tonight, unless someone
else beats me to it...
Gary Boothe
NX308MB
-----Original Message-----
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of GrantZ
Sent: Saturday, December 21, 2013 6:22 AM
Subject: Pietenpol-List: Re: Extended Fuselage Question
Thanks Gary.
back?) location of the "struts". I understand the length, as you mentioned.
certain I am missing something. I don' want to "guess" on the location of
these key elements.
Grant Ziebell
Savannah, TN
Grant
Now i see!
The front ash cross member is centered where the 2nd and 3rd
(from the front) vertical struts on the fuse sides meet at the lower longeron-
The second bay back (front cockpit) dimension (fore to aft) I
believe is the same for the short and long fuse
so you can use the 1933 plans for the placement of the rear ash piece-
Those plans show a distance of 27.5" center to center
Hope that didn't make it more confusing!
Earl Brown
I may not have gone where I intended to go, but I think I have ended up where I
intended to be.
http://forums.matronics.com/viewtopic.php?p=415980#415980
From: | "Douwe Blumberg" <douweblumberg(at)earthlink.net> |
Subject: | cold weather flights |
I think 34 degrees was the lowest for me.
After about twenty minutes I'm ready to land. Those chemical heat packets
help a lot in gloves and waistband.
The plane sure performs nicely at those temps!!
Douwe
Grant
This is a somewhat frequent question when building the long fuselage. To
figure out where to put the cross braces between the two fuselage side for
the long fuselage you need to consult the short fuselage plans.
The cross braces go at the same cluster joint as the short. The distance
isn't too critical. Just put them at the center of the cluster. One thing
to make sure is the ash cross members need to be the same distance apart as
the distance between the spars. You might find that this puts the rear ash
member at about the center of the rear seat even though it is shown on the
front of the seat on the plans. Several builders, myself included, have
added a second piece behind the seat so our wing fittings are in the correct
location.
Long fuselage, front ash piece location
http://westcoastpiet.com/images/Chris%20Tracy/images/98.jpg
Here is the rear ash piece.
http://westcoastpiet.com/images/Chris%20Tracy/images/P1030326.JPG
Chris T.
Sacramento, Ca
Westcoastpiet.com
Thanks Gary.
these key elements.
Grant Ziebell
Savannah, TN
my friend has an extended fuse and his is 24 at the cockpit across. he said that
the fuse is lengthened but not widened. we have no way of confirming if his
was built to plans. we did measure it. gary will have you his answer later..
if his is like my friends the u can almost bet it should be 24 inches
jim
http://forums.matronics.com/viewtopic.php?p=415995#415995
im confused to. I thought we were here like yourself get to get tips and get help
with building. instead i get 12 e mails on what to wear when its cold outside.
I think the subject should be st uck to but no one asked me. stay with this
site and filter out all of the bull shit. there is good info but also lots
of bs that should be handled off site with personal e mails. one thing I have
learned is stay with the plan, call pietenpol if you have questions and u will
have plenty of them and work on the project every day.
jim hyde
http://forums.matronics.com/viewtopic.php?p=415996#415996
Thought the question had been answered twice so far-
Didn't realize the question had changed to how wide is the fuselage
Earl Brown
intended to be.
http://forums.matronics.com/viewtopic.php?p=416004#416004
From: | "Jack Phillips" <jack(at)bedfordlandings.com> |
Grant,
I remember having the same problem when I built my fuselage, but don't
remember the solution. As I recall, the information is really all there on
the drawings but sometimes you have to look at several different sheets to
get all the dimensions.
I'll have to dig my plans out tomorrow and go over them to see what I did.
I think I just made sure the top and bottom pieces were in line with the
verticals in the fuselage sides.
Here's a picture showing them:
Basically, if you put in the cross pieces that define the cockpit (and I
think those dimensions are given on the plans), then pull the longerons
together at the tail, the sides will form a fourth order polynomial curve
that the wood naturally wants to hold. I think I just cut the cross pieces
to fit that curve. Whatever, it looks right.
Be very careful to make sure you have everything lined up perfectly.. I
used plumb bobs and pipe clamps as shown in the picture below. The fuselage
is upside down, resting on the upper longerons, with the plumb bobs aligning
the center of the bottom cross braces with the center of the top cross
braces (I had a centerline drawn on the table as well). You can see some of
the strings used to pull on various parts of the lower longerons to keep
everything in alignment. As Tony Bingelis says, building an airplane is
basically a series of alignment exercises.
Don't give up on this website. There's a wealth of good information here,
but some of us that built their planes a decade or so ago are busy with
other projects now.
Good luck!
Jack Phillips
NX899JP
Smith Mountain Lake, Virginia
Sent: Saturday, December 21, 2013 8:38 AM
Additional info re my question: I am looking for the dimensions to position
the pieces ( BP calls them struts on the plans) which go between the left
and right fuselage sides as well as the ash reinforcements.
Dimensions are given on the standard fuselage plans but are omitted on the
improved/extended fuselage plans.
Grant Ziebell
Savannah, TN
http://forums.matronics.com/viewtopic.php?p=415967#415967
Grant,
Not sure if you got the answers you were looking for yet. Although my Piet
is built and flying, I am in no way an expert, such as a person like Chris
Tracy. I'm sure there are others, but I know of no-one who has studied the
plans longer and more intently, along with lots of peripheral stuff!
In no way do I wish to appear cavalier, but I just followed plans...mixed
with some s.w.a.g. and a little of my own interpretation....but I never was
stumped by needed information! My long fuselage plans are only marked, "*
Corrected 9-22-94...", and the attached is a snippet. This gives locations
for the uprights. I merely referred to the original drawings for the
x-members.
Best of luck to you! Please do not be put off by negative comments about
this list. Admittedly, one may have to ask a question more than once...or
ask a different way.
Anyone who says this list is not helpful is full of CRAP!!
Gary Boothe
NX308MB
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe
Sent: Saturday, December 21, 2013 6:59 AM
Subject: RE: Pietenpol-List: Re: Extended Fuselage Question
Gary Boothe
NX308MB
Thanks Gary.
these key elements.
Grant Ziebell
Savannah, TN
From: | John Fastnaught <fastnaught(at)windstream.net> |
I'm about to assemble the airframe before covering and am curious about cable tension.
Do we use 43.13 tensions or is their something special on the cables?
Jack
N144JF
Ford powered
Chris,
Great answer. Just the info I needed to "break the code"!!
Grant Ziebell
Savannah, TN
http://forums.matronics.com/viewtopic.php?p=416033#416033
i just finished making both wings and center section.. i have one extra rib left
over and have been working on it all day to make me a girlfriend. i heard that
some dude did it many years ago...does anyone have a set of plans. tomorrow
is sunday and i have to take the day to rest.
http://forums.matronics.com/viewtopic.php?p=416034#416034
Subject: | Re: one extra rib |
From: | "jarheadpilot82" <jarheadpilot82(at)hotmail.com> |
"Eve"n a guy like you can throw a little humor out there. [Laughing]
Have a nice day of rest.
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=416036#416036
You must be a fighter pilot. They all think they're God :-)
Jack Phillips
NX899JP
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Braniff1966
Sent: Sunday, December 22, 2013 12:04 AM
Subject: Pietenpol-List: one extra rib
left over and have been working on it all day to make me a girlfriend. i
heard that some dude did it many years ago...does anyone have a set of
plans. tomorrow is sunday and i have to take the day to rest.
Control cables, drag and anti-drag wires, flying wires or bracing wires?
Jack Phillips
NX899JP
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John
Fastnaught
Sent: Saturday, December 21, 2013 10:35 PM
Subject: Pietenpol-List: Cable tension
cable tension. Do we use 43.13 tensions or is their something special on the
cables?
Jack
N144JF
Ford powered
Subject: | Fuel Lines and Cabanes |
I have attached a link to an interesting and very informative couple of blog posts
written by William Wynne and posted on his FlyCorvair.net website. This is
good information for all of us builders and owners-
http://flycorvair.net/2013/12/19/pietenpol-fuel-lines-and-cabanes/
http://flycorvair.net/2013/12/20/fuel-lines-and-cabanes-part-2/
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=416048#416048
Subject: | Re: Cable tension |
Actually all the cables but for now the control cables.
Jack
> Jack Phillips
> NX899JP
> From: owner-pietenpol-list-server(at)matronics.com
> Fastnaught
> To: Pietenpol List
> cables?
> Jack
> N144JF
> Ford powered
> Sent from my iPad
Be careful what you wish for!
Adam said he didn't have anyone to talk to. God said that He was going to make
Adam a companion and that it would be a woman. He said, "This pretty lady will
gather food for you, she will cook for you, and when you discover clothing, she
will wash it for you. She will always agree with every decision you make and
she will not nag you, and will always be the first to admit she was wrong when
you've had a disagreement. She will praise you! She will bear your children
and never ask you to get up in the middle of the night to take care of them.
"She will NEVER have a headache and will freely give you love and passion whenever
you need it."
Adam asked God, "What will a woman like this cost?" God replied, "An arm and a
leg." Then Adam asked, "What can I get for a rib?" Of course the rest is history......................
John Francis
http://forums.matronics.com/viewtopic.php?p=416052#416052
Subject: | Re: Fuel Lines and Cabanes |
great post. I have the braided stainless fuel line on the shelf and plan to use
it. my cabanes are made and have been installed fitted and removed. I was sort
of proud that I had all of this done. I now have to modify them and weld them
in. this will be a loss in time but well worth it.. at 70 I have to weigh
construction time against time remaining...my career spans 55 years and this is
my last square to fill except for the extra rib project ..I hope to improve
on the prototype.
my big question is why did this thoughtful fellow hit the ground so hard..
I wish we had more posts like this. im not inclined to modify this project but
this is necessary.
http://forums.matronics.com/viewtopic.php?p=416059#416059
if you are a glass cockpit guy consider looking at the ntsb site recorded hearing
on the asiana accident. watch dave mckennys portion group three. he is my human
factors chairman
http://forums.matronics.com/viewtopic.php?p=416060#416060
Jim,
Two words. Carburetor Ice.
Here is a link to a story on his website describing the circumstances as well as
information to help others avoid the same situation.
http://flycorvair.com/carbice.html
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=416062#416062
I'm taking advantage of some downtime during Annual by adding a trim tab that can
be controlled from the flight deck. Of course, my AI/DAR will have to approve
it for a sign-off w/said Annual..
I bought a $26 cable from Spruce that locks in any position w/quarter turn of t-handle.
My diabolical plan is to mount it under seat (near right knee). I thought
about the electric trim servo method, but I like staying in the stone age
(no electrics). I will attempt to attach some fotos to this post. I am up for
suggestions/ideas.. if there might be a simpler method out there...
I thought about the bungie/string technique that I've seen on here, but prefer
a "secondary" control, in the event I lose all hydraulics.
KLNC
A65-8
N2308C
AN Hardware
Airframe 724TT
W72CK-42 Sensenich
Standard Factory GN-1
http://forums.matronics.com/viewtopic.php?p=416064#416064
http://forums.matronics.com//files/tab1_438.jpg
http://forums.matronics.com//files/tab2_572.jpg
http://forums.matronics.com//files/tab3_558.jpg
http://forums.matronics.com//files/tab4_105.jpg
may I ask what ur plane weighs and what type of fabric and paint process.. if the
trim works ill try one to
http://forums.matronics.com/viewtopic.php?p=416068#416068
Thank you, I was looking at the NTSB report, it is amazing the different st
ory from the pilot and co-pilot, pilot: negotiated landing, on impacted pla
ne caught fire,, Owner: from 80 feet plane spun in and caught fire, very in
teresting, gary=0A=0A=0A=0A________________________________=0AFrom: jarhead
pilot82 =0ATo: pietenpol-list(at)matronics.com =0A
Sent: Sunday, December 22, 2013 1:44 PM=0ASubject: Pietenpol-List: Re: Fuel
lot82" =0A=0AJim,=0A=0ATwo words. Carburetor Ic
e.=0A=0AHere is a link to a story on his website describing the circumstanc
es as well as information to help others avoid the same situation.=0A=0Ahtt
p://flycorvair.com/carbice.html=0A=0A--------=0ASemper Fi,=0A=0ATerry Hand
=0AAthens, GA=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums
Control cables need to have no slack, but not be so tight as to put undue
stress on the control surfaces (which are wood). Having said that, you will
find due to the unique geometry of the elevator control system that it is
impossible to keep the up and down cables tight at all time..
As in many things Pietenpol related, you just have to exercise your own
judgement.
For the bracing wires, again you don't want slack, and opposing cables
should have approximately the same tension. The easiest way to determine
this is to pluck them like a guitar string and see if you get about the same
note (Thummmm) from them. If you have a tensiometer, fine. Go ahead and
use it, but it is probably not necessary.
Of course, such tensioning methods for the flying wires and bracing wires
are to give a starting point. It may be necessary to tighten or loosen one
slightly to move a flying surface in such a way as to get the airplane "in
rig". That's why they need to be adjustable.
Jack Phillips
NX899JP
Fastnaught
Sent: Sunday, December 22, 2013 10:34 AM
Subject: Re: Pietenpol-List: Cable tension
Jack
> Jack Phillips
> NX899JP
> Fastnaught
> To: Pietenpol List
the
> cables?
> Jack
> N144JF
> Ford powered
> Sent from my iPad
I wanted to eat a little crow here. I made a snide remark about the list while
replying to another question. it seems I had asked nearly the same question
a few days earlier and although 70 or so folks read my question no one answered.
I admire all these builders here and im gonna need some help on this
journey I don't want to be considered un-gratefull. Please accept my apology
I don't want to be a bad egg.
http://forums.matronics.com/viewtopic.php?p=416084#416084
Apology accepted. There's a lot of good info available here, but as Ryan
Mueller commented, many of the questions being raised have been answered
many times over the last 16 years, and people get tired of answering them
again, when the questions and answers are available in the archives.
And most of the questions can be abswered by just reading Tony Bingelis'
books and actually thinking about the problem and coming up with a solution,
instead of immediately asking someone else how they solved the problem. To
be honest, most of the fun I had bulding my Pietenpol was coming up with
solutions to these problems.
Jack Phillips
NX899JP
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aviken
Sent: Sunday, December 22, 2013 9:35 PM
Subject: Pietenpol-List: apology
while replying to another question. it seems I had asked nearly the same
question a few days earlier and although 70 or so folks read my question
no one answered. I admire all these builders here and im gonna need some
help on this journey I don't want to be considered un-gratefull. Please
accept my apology I don't want to be a bad egg.
680lbs, stitts polyfiber sys, automobile imron paint on fuse only
KLNC
A65-8
N2308C
AN Hardware
Airframe 724TT
W72CK-42 Sensenich
http://forums.matronics.com/viewtopic.php?p=416088#416088
thanks for the info. please let me know how the trim works. my fuse and tail are
finished.. now would be the right time to add a trim.. also I have read that
the piet with a ford a weighs about 695 I would have guessed yours would have
been a good bit less. thanks for the info. im using an a65 and the same prop
jim
http://forums.matronics.com/viewtopic.php?p=416090#416090
..will do.
KLNC
A65-8
N2308C
AN Hardware
Airframe 724TT
W72CK-42 Sensenich
http://forums.matronics.com/viewtopic.php?p=416093#416093
... Adam was a cheap bastard.
LOL,
WF2
http://forums.matronics.com/viewtopic.php?p=416102#416102
From: | "Bill Church" <billspiet(at)sympatico.ca> |
im confused. I thought we were here to get tips and get help with building. instead
i get an email about glass cockpits and ntsb reports. I think the subject
should be st uck to but no one asked me. stay with this site and filter out
all of the bs. there is good info but also lots of bs that should be handled off
human factors chairman
http://forums.matronics.com/viewtopic.php?p=416104#416104
...btw, that part # for that T-handle cable is 05-15200 at Spruce if you're interested
in the same cable...$26. It's 12' in length. Just cut it to fit.
KLNC
A65-8
N2308C
AN Hardware
Airframe 724TT
W72CK-42 Sensenich
http://forums.matronics.com/viewtopic.php?p=416120#416120
Subject: | Re: Cold Flights |
From: | "AircamperN11MS" <Scott.liefeld(at)lacity.org> |
Hello Pieters,
I find it very interesting to read about how we are using our birds. Most would
consider them fair weather airplanes and to some that is all they are. I for
one do like the occasional cold flight. Mostly when flying over a fresh snow fall.
One flight in particular my wife and I flew over some pine covered mountains
about 100' above the trees after a heavy snow fall. Very pretty flight, the
engine and prop noise knocked the snow from the tree branches as we flew by.
The flight was so beautiful that we forgot that we were even cold. Try it if
you ever get the chance.
Happy holidays to all and congratulations to all who made first flights in 2013.
Scott Liefeld
Flying N11MS since March 1972
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=416123#416123
Thank you all for the huge laugh this morning. It took me a minute to digest the
first question.
Scott Liefeld
Steel Tube
C-85-12
Wire Wheels
Brodhead in 1996
http://forums.matronics.com/viewtopic.php?p=416125#416125
I hate to waste anything ...a tree even ifs its only a spruce had to give its
life for that to make that rib :-)
http://forums.matronics.com/viewtopic.php?p=416131#416131
From: | Steven Dortch <steven.d.dortch(at)gmail.com> |
I now try look at uncle Tony's books and then do a quick search through the
archives. But often I need the question answered my way. I have posted
questions and got no answers so I restate the question from a different.
> solution,
> Jack Phillips
> NX899JP
Oops, dog hit the keyboard, Really!
angle. Sometimes I am then given good directions to Uncle Tony or the list.
Don't Stop asking.
On Mon, Dec 23, 2013 at 11:01 AM, Steven Dortch
> the archives. But often I need the question answered my way. I have posted
>> solution,
>> To
>> Jack Phillips
>> NX899JP
>> some
From: | Michael Perez <speedbrake(at)sbcglobal.net> |
No apology required, although I do appreciate you doing so.
I do not believe that Matt has put any type of question asking restriction or repeated
question asking space usage restriction on his, (this) site, so I am one
that feels it is OK to ask away! Those whom do not wish to answer the same
question over and over do not need to do so.
Most people get the "See Tony's books" or "check the archives" answers just because
as new people arrive here, they may not know such tools exist.
If God is your co-pilot...switch seats.
Michael Perez
Pietenpol HINT Videos
Karetaker Aero
www.karetakeraero.com
Subject: | Arrow Fest III...sorta... |
As some of you may know, I usually take a chunk of time off around the holidays
to dedicate to a major build on my plane. This year, I do not have as much to
build, (a good thing) but I still have a lofty goal in mind. I would like to
wrap up work on my engine cooling inlets, (eye brows, eye lashes, eye sore...)
of my own design and also finish the engine cowling and exhaust heat muff. Maybe
even get some of these items painted. Today is my last day of work until the
21st. Even with some family commitments here and there, I hope to get a lot
done.
I would also like to take time to do a write up or two for the newsletter and maybe
another HINT video, but the above will be the priority.
All in due time...
Michael Perez
Karetaker Aero
Merry Christmas from the Big Piet Builders (Georgia)
Barry
NX973BP
Considering the time of year, very much ON subject!=0A-=0AMerry Christmas
!-=0A=0AIf God is your co-pilot...switch seats.=0AMichael Perez=0APietenp
ol HINT Videos=0AKaretaker Aero=0Ahttp://www.karetakeraero.com/
Christmas came just in time, with a strong hint to my daughter I think uncle Tony's
books will be under the tree, yipppeee
http://forums.matronics.com/viewtopic.php?p=416150#416150
TriScout:
Why would anyone need to approve anything that you do to your experimental aircraft
if it's already registered and airworthy? If you have it installed by the
time the annual condition inspection is conducted, it will be inspected like
any other part of the aircraft, but you don't need approval or sign-off on it.
I would make a logbook entry in the airframe log to document the change. The
caveat is that you must decide whether adding the trim tab constitutes a "major
change" or not. Here's the definition from 14 CFR 21.93:
A minor change is one that has no appreciable effect on the weight, balance, structural
strength, reliability, operational characteristics, or other characteristics
affecting the airworthiness of the product. All other changes are major
changes.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power
http://forums.matronics.com/viewtopic.php?p=416152#416152
Well, from the West Coast builders to you Piet folks on the East Coast, best wishes
for a joyful and blessed Christmas! And just out of curiosity, do you east
coast and southern Pieters consider Sun 'n' Fun as your unofficial Piet gathering?
I guess it's 'only' 840 miles from Atlanta to Brodhead, but that's more
of a stretch than the 454 miles from Atlanta to Lakeland so I figured it was
the best opportunity for Piets to gather down there, or possibly the 460 miles
to the Lee Bottom Flying Field in Hanover, IN.
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=416153#416153
Subject: | Re: Arrow Fest III...sorta... |
Mike;
Good for you, planning to maximize your available build time over the holidays.
One thing I might mention about fabricating your cowl is that you should of
course try removing and reinstalling the cowling with everything installed on
the engine, before the cowling is painted. My setup is with the usual top and
bottom halves of the cowling joined by piano hinges to make either half removable
without disturbing the other half by pulling the hinge pins, and that's a
good thing. The removable top half makes servicing the top plugs, mags, harnesses,
oil screen, and other stuff pretty easy, and it comes off readily. It's
the bottom half that causes the problems, and it needs to come off when you
have to get to the carb, air box, oil sump, lower plugs, or anything else "down
under".
My bottom half is in three pieces (four, actually)... the bottom and two sides,
also joined with piano hinges but without removable pins, fixed to half of the
nose piece. Picture here:
http://www.flysquirrel.net/piets/CEA_Piet04.jpg
The fact that the lower cowling is in several pieces with hinges allows it to be
flexed and maneuvered, but the problem is the exhaust stacks, which contact
the cowling pieces as I maneuver it to clear the air filter and carb heat box,
which scratches the paint on the lower cowling. There's not really much to be
done about it other than having a helper around when you pull the cowlings (rarely
the case), or wrapping the stacks with soft rags or towels before pulling
the cowling, or just not caring too much if you get minor paint scratches (which
is my case with Scout, since I just shoot some Rustoleum Ford Implement
Blue on things from time to time). You'll see from the picture that the stacks
are usually fabricated tucked in to the sides of the cowling, which helps with
streamlining but means you have to sneak past them with the cowling. By all
means do some test-fitting with everything in place before you paint, or you
may end up crying when you get some scratches. Scout has long since forgiven
me for scratches, and now doesn't even grumble unless I break or bend something
;o)
Oscar Zuniga
Medford, OR
A75 power
http://forums.matronics.com/viewtopic.php?p=416154#416154
this is a big change... having another set of eyes is always a plus. even if not
required... synergy is always a good plan. hopefully you will get good input
from this group. my thought is that adding a moving flight control is possibly
a major change. there are folks that do know and it aint me :D so I guess im
wasting your time [Embarassed]
http://forums.matronics.com/viewtopic.php?p=416155#416155
From: | Chuck Campbell <cncampbell(at)outlook.com> |
Jack=2C whatdaya mean -- "think". We are. Chuck
> From: jack(at)bedfordlandings.com
> Subject: RE: Pietenpol-List: one extra rib
> Date: Sun=2C 22 Dec 2013 06:44:02 -0500
gs.com>
> Jack Phillips
> NX899JP
> Smith Mountain Lake=2C Virginia
66
> Sent: Sunday=2C December 22=2C 2013 12:04 AM
ib
Subject: | Ford Model A for sale on eBay |
Just passing it along.
http://www.ebay.com/itm/Aircraft-Ford-Model-A-Engine-w-New-Watson-Propeller-Zero-Time-Since-Rebuild-/310826432120?forcerrptr=true&hash=item485eb2f678&item=310826432120&pt=Motors_Aircraft
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=416162#416162
Since I've flown my Pietenpol to Brodhead 5 times, and Oshkosh 3 times, but
only once to Sun 'n'Fun, I wouldn't consider it my unofficial Pietenpol
gathering.
I'm planning to fly it to Triple Tree next summer. That's probably the best
grass-roots fly-in this side of the Appalachians.
Jack Phillips
NX899JP
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags
Sent: Monday, December 23, 2013 11:57 PM
Subject: Pietenpol-List: Re: Off Subject
wishes for a joyful and blessed Christmas! And just out of curiosity, do
you east coast and southern Pieters consider Sun 'n' Fun as your unofficial
Piet gathering? I guess it's 'only' 840 miles from Atlanta to Brodhead, but
that's more of a stretch than the 454 miles from Atlanta to Lakeland so I
figured it was the best opportunity for Piets to gather down there, or
possibly the 460 miles to the Lee Bottom Flying Field in Hanover, IN.
Oscar Zuniga
Medford, OR
A75 power
Thanks for the reply Oscar. I am actually burning HINT videos and won't be
looking at the picture link you sent quite yet.- I have Mike C's. cowling
templates, but my setup is quite a bit different from his and the template
s won't do me much good...looks like I will be starting from scratch.=0A-
=0AI have straight stacks for the exhaust and it appears they will be well
outside the engine cowling itself. Once I am finished with my cooling intak
es, I will go back to making the aerodynamic fairings/heat muff for the exh
aust.- I have one cooling intake complete...just finished it about an hou
r ago...and I think it came out great!- Well, technically it is not finis
hed...I still need to replace all the screws holding it together with rivet
s and nut plates. How well it actually performs, as with everything else, i
s yet to be seen. Once the exhaust is complete, I will move on to figuring
out how to fabricate the engine cowling, get it to fit around everything an
d still be user friendly on the various aspects you pointed out in your pos
t.=0A-=0AScratched paint...I've had my cooling inlets made and re-made I
don't know how many times and probably 3X that amount installed and removed
from the engine. Surprised I have paint still on the engine at all!- Tha
t cool weathered/scratched/used look just as character... (I'm-talking ab
out the plane.)=0A-=0AIf God is your co-pilot...switch seats.=0AMichael P
erez=0APietenpol HINT Videos=0AKaretaker Aero=0Ahttp://www.karetakeraero.co
m/
...all valid points. I always leave things up to my AI/DAR. Since he signs the
books, it's his dept. Last annual, he said I needed an ELT, so I ordered the new
406 model ($588) w/in an hour of his suggestion.
braniff is right... I figure an extra set of eyes can't hurt. When I tried for
the Annual this year, it was a no-go. My machine is currently grounded until he
finds the time to help change the rubber push rod housing bushings. There are
no leaks, but the bushings are showing cracks (see picture). He will not sign
it off until we get the new ones on. We'll have to pull the cylinders to get
to them. He's tough on mx, and I approve this message.
KLNC
A65-8
N2308C
AN Hardware
Airframe 724TT
W72CK-42 Sensenich
http://forums.matronics.com/viewtopic.php?p=416167#416167
http://forums.matronics.com//files/photo_11_556.jpg
I wanted to take a few close up shots of my propeller as finished- and po
st them before I forgot.=0A-=0AThe first is of the front side and the sec
ond is the back, engine side.-=0A=0AIf God is your co-pilot...switch seat
s.=0AMichael Perez=0APietenpol HINT Videos=0AKaretaker Aero=0Awww.karetaker
aero.com
That would be great to see some Piets at Triple Tree. Their were hundreds of planes
this year and only one Piet that I saw. It was a very nice steel tube plane,
white and blue with Mickey and Minnie on the tail. I hung around it for a
while hoping to meet the owner but never did.
Merry Christmas everyone,
Keith Goff
> gathering.
> But never di
> Jack Phillips
> NX899JP
> Oscar Zuniga
> Medford, OR
> A75 power
Neat! ... I'll run that by my mechanic. Thx for the info
KLNC
A65-8
N2308C
AN Hardware
Airframe 724TT
W72CK-42 Sensenich
http://forums.matronics.com/viewtopic.php?p=416180#416180
I believe the cylinders will still need to be removed initally to remove th
e old tubes. Yes?-I have a second engine that I will rebuild someday and
I will be looking into making this change for that one.=0A=0AIf God is your
co-pilot...switch seats.=0AMichael Perez=0APietenpol HINT Videos=0AKaretak
Subject: | Uncle Tony's Books |
Oscar,
Now can we be friends again?
Gary
