Pietenpol-Archive.digest.vol-nh
March 06, 2014 - March 15, 2014
      http://forums.matronics.com/viewtopic.php?p=419861#419861
      http://forums.matronics.com//files/dyno_runa_1percent20small_894.jpg
Subject: Re: Egad!! The Top Curmudgeon has abdicated!
Date: Mar 06, 2014
Headed north tomorrow to pick up a mortister, I'll look into that! The guy I'm going with is too scared to drive across the lake... maybe I could talk him into a voyage even kids will take. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419864#419864 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: jeep engine
Date: Mar 06, 2014
Hey, It is important to know exactly what prop you're spinning when you do your static tests to help ascertain what she's doing. I'd be very interested in hearing the results of the static tests, and what prop it is spinning Sounds interesting. Douwe ________________________________________________________________________________
Date: Mar 06, 2014
Subject: Re: Piet Wings for Sale + Other Parts
Brian Durham,=0AThe Cavalier, That is Stan McLeod design isn't it?- All w ood low wing x-country machine?- I have some old newsletters for the cava lier from the 60, and 70's.- Contact me of list if you want.=0A-=0AShad =0A=0A=0A________________________________=0AFrom: Tim White <aa5flyer@gmail .com>=0ATo: "pietenpol-list(at)matronics.com" =0ASent: Wednesday, March 5, 2014 9:34 PM=0ASubject: Re: Pietenpol-List: Pi et Wings for Sale + Other Parts=0A=0A=0A--> Pietenpol-List message posted b y: Tim White =0A=0AI need instruments.- Are any avail able?=0A=0ATim White=0A=0A=0A> On Mar 5, 2014, at 2:34 PM, "N219BR" =0A> =0A> Hi All,=0A> =0A> I acquired a Piet that's taking up valuable space right now. I'm looking at parting it out. I have an A-65 mount/cowl, 3 piece wings, cub gear, fittings, and 1.5 Corvai r cores, plus lots of assorted odds and ends. =0A> =0A> The back end was st icking out of an open hangar here in Washington State, so you can imagine w hat the vert/and aft end fuse looks like.=0A> =0A> Let me know what you nee d, and I'll send pictures. I'm looking at trying to get a Cavalier SA102.5 in the air so, I'd be interested any trades to help me toward that end. Alw ays willing to help another piet get in the air! I'll be driving to San Die go in April if anybody along the way needs something.=0A> =0A> Thanks,=0A> =0A> Brian Durham=0A> lake Stevens, WA=0A> =0A> --------=0A> Brian Durham =0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http://forum s.matronics.com/viewtopic.php?p=419837#419837=0A> =0A> =0A> =0A> =0A> =0A ======================== ________________________________________________________________________________
Date: Mar 06, 2014
From: santiago morete <moretesantiago(at)yahoo.com.ar>
Subject: Rv: Scimitar propeller drawings
=0A=0A=0A=0A=0AHi everyone!=0A=0A=0A=0AOscar, the crankshaft in the model A is centered to the fuselage,-but many of the engine components are on th e port side (camshaft, valves, oil pump etc), so the engine block is not sy mmetrical to the crankshaft axle. I think that's the main reason why Dan's and model A powered Piets are heavier on the port side (add to that the int ake manifold, carburator, exhausts, throttle controls, etc)-=0ASaludos! =0A=0ASantiago ________________________________________________________________________________
Date: Mar 06, 2014
Yes, but his clever logo is only on the right side.surely that would offset it.:-0 Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of santiago morete Sent: Thursday, March 06, 2014 8:19 AM Subject: Pietenpol-List: Rv: Scimitar propeller drawings Hi everyone! Oscar, the crankshaft in the model A is centered to the fuselage, but many of the engine components are on the port side (camshaft, valves, oil pump etc), so the engine block is not symmetrical to the crankshaft axle. I think that's the main reason why Dan's and model A powered Piets are heavier on the port side (add to that the intake manifold, carburator, exhausts, throttle controls, etc) Saludos! Santiago ________________________________________________________________________________
Date: Mar 06, 2014
Brian, I would be interested in the cub if it can be shipped reasonably to Tennessee. Price? I will understand if the shipping thing is too much of a hassle. Thanks Grant Ziebell Savannah, TN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419872#419872 ________________________________________________________________________________
Date: Mar 06, 2014
Subject: Re: jeep engine
The engine sounds great. If it runs good and does what you want, I would put it on and go with it. I am not advising you to change anything but during a boring meeting I did the following internet search found the following ideas to "hop up" a Go-Devil engine: Airflow is one of the "easier" ways to get more HP: Burns dual carb intake with dual Solexes. Supersonic intake. Make a Dual Intake. (not sure if this will help an aircraft engine as much as a hot rod) "Any good welding shop should be able to fabricate dual intakes for you. All you really need is a manifold flange, a 90 degree tube, and a matching carb flange. Two of those and you have dual carbs. Compression: There was a "High altitude" version of this engine with higher compression of 7 to 1. The Supersonic cylinder head (Script looks great and you up the compression ratio a little bit and http://mightymo.org/public_html/images/AdobeFiles/L_Hd_Perf.pdf Clifford Performance makes a header for the Go-Devil. http://www.cliffordperformance.net/Merc ... _Code=J258<http://www.cliffordperformance.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Code=57-0432&Category_Code=J258> Or just shave the head a bit. Also: A decent camshaft with proper timing and lift, and machine the block for removable cam bearings. Consider a gear type camshaft drive You can upgraded the ignition system to a Pertronix setup using 12volts. Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 06, 2014
Subject: Hello again
In the past, as publisher of the BPA News, I thought it inappropriate to actively participate in Matt's Matronics Pietenpol discussion group. Now is the time for me to again become a participant. Doc Mosher ________________________________________________________________________________
Date: Mar 06, 2014
Doc, Your participation is eagerly awaited, and would have most likely been accepted when you were publisher. Surely , you have noted that the position of Top Curmudgeon appears to now be a shared position...maybe of some interest to you? ;-) Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Doc Mosher Sent: Thursday, March 06, 2014 1:41 PM Subject: Pietenpol-List: Hello again In the past, as publisher of the BPA News, I thought it inappropriate to actively participate in Matt's Matronics Pietenpol discussion group. Now is the time for me to again become a participant. Doc Mosher ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: Re: Hello again
Date: Mar 06, 2014
Well if you're going to bring in the Pro from Dover... -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/6/14 4:50 PM, "Gary Boothe" wrote: > >Doc, > >Your participation is eagerly awaited, and would have most likely been >accepted when you were publisher. Surely , you have noted that the >position >of Top Curmudgeon appears to now be a shared position...maybe of some >interest to you? ;-) > >Gary Boothe >NX308MB > > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Doc Mosher >Sent: Thursday, March 06, 2014 1:41 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: Hello again > > >In the past, as publisher of the BPA News, I thought it inappropriate to >actively participate in Matt's Matronics Pietenpol discussion group. Now >is >the time for me to again become a participant. > >Doc Mosher > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: Doc Mosher--- on the Pietenpol List
Date: Mar 06, 2014
Welcome back Doc and nice of you to 'hang around' with us again! How IS that GN-1 coming along anyway? :))) I heard you and Larry Williams were building one....... Mike C! ________________________________________________________________________________
Date: Mar 06, 2014
Subject: Re: my Uncle Tony talks about how to swing a compass...and
then
Actually I have used JET A. Kerosene. Blue Skies, Steve D On Tue, Mar 4, 2014 at 6:31 AM, Jack Phillips wrote: > jack(at)bedfordlandings.com> > > That reminds me, Oscar - you don't have to buy that expensive compass > fluid. > It is nothing more than lighter fluid, like the old Zippo lighters used. > Gulflite charcoal lighter fluid works just fine for much lower cost. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags > Sent: Monday, March 03, 2014 10:29 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: my Uncle Tony talks about how to swing a > compass...and then > > > Thank you, Mikee, but this time I already knew how to do what needed to be > done. I assume that you posted this for the benefit of others who might > not > know the correct procedure. A certain [UNCLASSIFIED] friend of mine comes > to mind ;o) > > And my thanks to Ben Charvet for pointing out to me that I can save the > cost > of buying a brass screwdriver by taking an old key and > filing/grinding/shaping it into a screwdriver suitable for adjusting the > compensator screws on the instrument. A true Pietenpoler. > > In preparation for conducting this precision operation, I bought a bottle > of > Templeton Rye, should my whiskey compass require topping up. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419748#419748 > > ________________________________________________________________________________
Subject: Re: Doc Mosher--- on the Pietenpol List
Date: Mar 06, 2014
Welcome back Doc! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419892#419892 ________________________________________________________________________________
Date: Mar 06, 2014
Doc we welcome you back with open arms! Sent from my iPad Jack Textor > On Mar 6, 2014, at 3:40 PM, Doc Mosher wrote: > > > In the past, as publisher of the BPA News, I thought it inappropriate to actively > participate in Matt's Matronics Pietenpol discussion group. Now is the time for > me to again become a participant. > > Doc Mosher > > > > > ________________________________________________________________________________
Date: Mar 07, 2014
Welcome back Doc. Was wondering if we would hear from you and Dee again. Cheers, Jim Boyer =C2- ________________________________________________________________________________
Date: Mar 07, 2014
Subject: Piet parts for sale
Brian, I am interested in your cowl. Please give me your phone # in a direct reply and let's discuss. Do you have a nose bowl as well? Also, do you have diagonal cabanes (from top motor mount to wing attach points)? Tim in central TX ================== Subject: Pietenpol-List: Piet Wings for Sale + Other Parts From: "N219BR" <briankdurham(at)gmail.com> Hi All, I acquired a Piet that's taking up valuable space right now. I'm looking at parting it out. I have an A-65 mount/cowl, 3 piece wings, cub gear, fittings, and 1.5 Corvair cores, plus lots of assorted odds and ends. ________________________________________________________________________________
Date: Mar 07, 2014
Welcome back Doc! I was wondering what you and Dee were going to do going f orward. Glad to have you here. Dan Helsper Puryear, TN -----Original Message----- From: Doc Mosher <docshop(at)tds.net> Sent: Thu, Mar 6, 2014 3:41 pm Subject: Pietenpol-List: Hello again In the past, as publisher of the BPA News, I thought it inappropriate to actively participate in Matt's Matronics Pietenpol discussion group. Now is the time for me to again become a participant. Doc Mosher ________________________________________________________________________________
Subject: Board of Crumudgeons- encouragement from my wife
Date: Mar 07, 2014
The other day, as were doing our usual routine of sipping morning coffee an d browsing the internet, I happened to mentioned to my wife that I was cont emplating applying for a position on the new Board. She asked what the qual ifications were in order to serve. During the course of this conversation, I explained that one of the duties would be to shame people. She pondered f or a moment... exclaiming...."you're good at that"..... Dan Helsper Puryear, TN ________________________________________________________________________________
Date: Mar 07, 2014
Not sure why you felt it would have been inappropriate for you, as publisher of the BPA News, to participate in discussions in this group. Nonetheless, welcome back, Doc. Let 'er rip. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419911#419911 ________________________________________________________________________________
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Mar 07, 2014
Welcome back Doc, it will be good to read some of your words again. Cheers, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419912#419912 ________________________________________________________________________________
Subject: Re: Board of Crumudgeons- encouragement from my wife
Date: Mar 07, 2014
Well Dan, That sounded like an acceptance speech to me. Have fun with it. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419913#419913 ________________________________________________________________________________
then
Date: Mar 07, 2014
I'm probably going to get another lashing by Mr. Hyde for keeping the compass thread alive, but I thought I would mention that the regs consider "topping off" or refilling the compass in a certified aircraft to be a repair that can legally only be done by a Certified Repair Station, and only the manufacturer's recommended and STC'd compass fluid can be used. In experimentals, anything goes but I have read that the use of kerosene or Jet A can cause the compass markings to fade to yellow over time. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419920#419920 ________________________________________________________________________________
Date: Mar 07, 2014
then
"regs consider "topping off" or refilling the compass in a certified aircraft to be a repair that can legally only be done by a Certified Repair Station" Oscar, this helps me understand why for the past couple decades the mechanics that have worked on my certified plane have not wanted to bother with the compass when it got low on fluid, instead telling me it was something I could easily do by buying a kit from ASC. Kept their hands clean. Kept the compass topped up. Now that I think about it, I think it is getting low once again. On my Piet, I'm using a sealed marine compass, but don't tell anyone. Ken On Fri, Mar 7, 2014 at 9:44 AM, taildrags wrote: > > I'm probably going to get another lashing by Mr. Hyde for keeping the > compass thread alive, but I thought I would mention that the regs consider > "topping off" or refilling the compass in a certified aircraft to be a > repair that can legally only be done by a Certified Repair Station, and > only the manufacturer's recommended and STC'd compass fluid can be used. > > In experimentals, anything goes but I have read that the use of kerosene > or Jet A can cause the compass markings to fade to yellow over time. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419920#419920 > > ________________________________________________________________________________
Subject: Re: Corvair engine core
Date: Mar 07, 2014
There are a few corvair specific yards here in az. Also craigslist in Phoenix az has a few around 150. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419945#419945 ________________________________________________________________________________
Subject: Fuselage Width
Date: Mar 07, 2014
I am about to join the two sides of my fuselage together. I found the width dimensions in the orginal plans but not for the extended fuselage (supplementary plans). How did you all determine what they are? John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419958#419958 Attachments: http://forums.matronics.com//files/fusesides_722.jpg ________________________________________________________________________________
Date: Mar 07, 2014
He only changed the length, and the location of the uprights and diag's. Width stayed the same. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of john francis Sent: Friday, March 07, 2014 5:00 PM Subject: Pietenpol-List: Fuselage Width --> I am about to join the two sides of my fuselage together. I found the width dimensions in the orginal plans but not for the extended fuselage (supplementary plans). How did you all determine what they are? John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419958#419958 Attachments: http://forums.matronics.com//files/fusesides_722.jpg ________________________________________________________________________________
Subject: Re: Fuselage Width
Date: Mar 07, 2014
Thanks Gary, Ill look at that in the morning. Im in for the night. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419960#419960 ________________________________________________________________________________
Date: Mar 07, 2014
...but you are right, no width dimension is given on the supplemental... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of john francis Sent: Friday, March 07, 2014 5:14 PM Subject: Pietenpol-List: Re: Fuselage Width --> Thanks Gary, Ill look at that in the morning. Im in for the night. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419960#419960 ________________________________________________________________________________
Subject: Which one?
Date: Mar 07, 2014
It's time to get serious and I could use some advice. How many different sets of plans are there for piets? I have the set published originally in the flying and glider manual. Are these different from the ones available from the pietenpol family? What about those available from St. Croix? How about the biplane version? Any input would be very appreciated Glen Sent from my iPhone ________________________________________________________________________________
Subject: Which one?
Date: Mar 07, 2014
There is only one Pietenpol...get the plans from the Pietenpol family. They will have updates available not in the Flying and Glider Manual. Anything else is not a Pietenpol. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of glenschweizer(at)yahoo.com Sent: Friday, March 07, 2014 7:23 PM Subject: Pietenpol-List: Which one? It's time to get serious and I could use some advice. How many different sets of plans are there for piets? I have the set published originally in the flying and glider manual. Are these different from the ones available from the pietenpol family? What about those available from St. Croix? How about the biplane version? Any input would be very appreciated Glen Sent from my iPhone ________________________________________________________________________________
Subject: Re: Willys jeep pietenpol engine maybe?
Date: Mar 08, 2014
According to the Flying and Glider Piet article the Ford A weighs 244lb. According to this Wikipedia article the Willys weighs in at 470 lb! We just told a certain propmaker that he couldn't use his VW engine because it's too small and revs too high. It's 2500cc. The Willys is 2200cc. The c-65 is 2830cc and the Corvair starts at 2700cc. The Ford is a wopping 3400cc! and 128 ft-lb torque. The c65 has 148lb torque. The little Willys? 114 ft-lb. The Corvair appears to be 155 but at 2800 rpm. So, perusing the above, in direct drive, will the Willys be able to pull it off? I think nostalgia is colouring perceptions here. Nothing wrong with nostalgia but as Mark Twain said; "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." But; "Life is trying things to see if they work." (Ray Bradbury) OK, I'll stop now. Bad Clif A crank is a very elegant device. It's small, it's strong, it's lightweight, energy efficient and it makes revolutions. E F Schumacher > > By the way, I found a dyno simulation for the L134 engine that produced > the power and torque curves in the graph that I've attached. It may be > possible to make this work, just looking at the curves. At "normal" prop > speeds of 2200-2300 RPM, the power looks to be about 36-37HP (solid red > curve). Run it up to 2400-2500 and it climbs into the 40-42HP range, > which is comparable to the Ford "A" engine. Run it at 3000 RPM with a > ground-adjustable 68" Warp Drive like the Corvair uses and it might put > out 50HP. > > The dry weight of the engine is given in the Willys specs as 365 lbs. but > people on the Jeep CJ chat sites say it weighs about the same as a > small-block Chevy. The Ford A engine weighs about the same, I think... > specs that I found show weight of engine and transmission to be 475, so > the engine alone should be about the same weight as the Willys. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419861#419861 > > > Attachments: > > http://forums.matronics.com//files/dyno_runa_1percent20small_894.jpg > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > ________________________________________________________________________________
Subject: Re: Which one?
Date: Mar 08, 2014
Glen, Mr. Boothe is correct. This is a great way to start. Listen to all advise b ut be careful to evaluate where it is coming from. While I was building I g ave the advise from the fellows who had built and flown their airplanes the heaviest weighting. Like anything else, there is no substitute for experie nce. Bi-plane version? No such thing. This is not a Pietenpol. I can just hear t he report from the Board of Curmudgeons now ..... Dan Helsper Puryear, TN -----Original Message----- From: glenschweizer <glenschweizer(at)yahoo.com> Sent: Fri, Mar 7, 2014 9:23 pm Subject: Pietenpol-List: Which one? It's time to get serious and I could use some advice. How many different s ets of plans are there for piets? I have the set published originally in the f lying and glider manual. Are these different from the ones available from the pietenpol family? What about those available from St. Croix? How about th e biplane version? Any input would be very appreciated Glen Sent from my iPhone ________________________________________________________________________________
Subject: advice on how to fix an error
Date: Mar 08, 2014
I am laying out the sides of my fuselage and realized this morning that I made an error. On the left side interior, I accidentally glued a small gusset to the first joint behind the pilot's seat. Now I realize that I am supposed to put a long gusset that extends all the way from the joint at the base of the rear seat back to that joint. What do you think I should do? Should I try to sand that whole gusset off and replace it? Does that long gusset add structural strength there? Seeking advice? Thanks -------- Joe Pringle Atlanta, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419974#419974 ________________________________________________________________________________
Subject: Re: advice on how to fix an error
Date: Mar 08, 2014
Hi Joe What kind of glue did you use? If t-88 then you're in luck. Simply heat the gusset with your covering iron. When it's too hot to touch , it will peel off like a post it note. When you are done, consider carefully what you just learned about epoxy. Sent from my iPhone > On Mar 8, 2014, at 6:08 AM, "pringljo" wrote: > > > I am laying out the sides of my fuselage and realized this morning that I made an error. On the left side interior, I accidentally glued a small gusset to the first joint behind the pilot's seat. Now I realize that I am supposed to put a long gusset that extends all the way from the joint at the base of the rear seat back to that joint. > > What do you think I should do? Should I try to sand that whole gusset off and replace it? Does that long gusset add structural strength there? > > Seeking advice? Thanks > > -------- > Joe Pringle > Atlanta, GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419974#419974 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 08, 2014
The gusset IS the strength of the joint. There is no strength in the end-gr ain joint without the gusset. Repair it now and be worry-free later. Lorenzo > Subject: Pietenpol-List: advice on how to fix an error > From: joseph.pringle(at)gmail.com > Date: Sat=2C 8 Mar 2014 06:08:39 -0800 > To: pietenpol-list(at)matronics.com > m> > > I am laying out the sides of my fuselage and realized this morning that I made an error. On the left side interior=2C I accidentally glued a small g usset to the first joint behind the pilot's seat. Now I realize that I am s upposed to put a long gusset that extends all the way from the joint at the base of the rear seat back to that joint. > > What do you think I should do? Should I try to sand that whole gusset off and replace it? Does that long gusset add structural strength there? > > Seeking advice? Thanks > > -------- > Joe Pringle > Atlanta=2C GA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419974#419974 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 08, 2014
From: Charles Burkholder <born2fly(at)abcmailbox.net>
wow. I never knew you could do that with T-88. Good to know Charles B On 3/8/2014 9:35 AM, glenschweizer(at)yahoo.com wrote: > > Hi Joe > What kind of glue did you use? If t-88 then you're in luck. Simply heat the gusset with your covering iron. When it's too hot to touch , it will peel off like a post it note. > When you are done, consider carefully what you just learned about epoxy. > Sent from my iPhone > >> On Mar 8, 2014, at 6:08 AM, "pringljo" wrote: >> >> >> I am laying out the sides of my fuselage and realized this morning that I made an error. On the left side interior, I accidentally glued a small gusset to the first joint behind the pilot's seat. Now I realize that I am supposed to put a long gusset that extends all the way from the joint at the base of the rear seat back to that joint. >> >> What do you think I should do? Should I try to sand that whole gusset off and replace it? Does that long gusset add structural strength there? >> >> Seeking advice? Thanks >> >> -------- >> Joe Pringle >> Atlanta, GA >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=419974#419974 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 08, 2014
I would remove the small gusset and replace it with what is called out in the plans. When we rebuilt our fuselage, we found that removing the old gussets ranged from easy (which is bad because it suggests poor gluing in the original build) to difficult. So I don't know how are this will be to do cleanly. I, too, was unaware of the hit trick. My only concern there is that the rest of the joint may be weakened, but since the gusset really is what provides the strength, then this isn't that much of a concern. I'm happy to drop by and look at what you have (I don't think I live that far away). It's not like I'm an expert, but I have had to do similar operations on my Piet. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/8/14 10:18 AM, "Charles Burkholder" wrote: > > >wow. I never knew you could do that with T-88. Good to know >Charles B >On 3/8/2014 9:35 AM, glenschweizer(at)yahoo.com wrote: >> >> Hi Joe >> What kind of glue did you use? If t-88 then you're in luck. Simply >>heat the gusset with your covering iron. When it's too hot to touch , it >>will peel off like a post it note. >> When you are done, consider carefully what you just learned about epoxy. >> Sent from my iPhone >> >>> On Mar 8, 2014, at 6:08 AM, "pringljo" >>>wrote: >>> >>> >>> >>> I am laying out the sides of my fuselage and realized this morning >>>that I made an error. On the left side interior, I accidentally glued a >>>small gusset to the first joint behind the pilot's seat. Now I realize >>>that I am supposed to put a long gusset that extends all the way from >>>the joint at the base of the rear seat back to that joint. >>> >>> What do you think I should do? Should I try to sand that whole gusset >>>off and replace it? Does that long gusset add structural strength there? >>> >>> Seeking advice? Thanks >>> >>> -------- >>> Joe Pringle >>> Atlanta, GA >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=419974#419974 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Which one?
Date: Mar 08, 2014
This is a misleading answer and not correct. For example there are four "Pietenpol" fuselages There are two from the 1931 flying and glider magazine - a wood one and a s teel one. There is a 1933 improved version with steel gear and there is a 1966 fuselage for the corvair engine. there are at least three engine mounts. The suggestion that something is not a Pietenpol would have upset Bernie Pi etenpol and he was nothing like that protective.. He was an experimenter an d tried all kinds of things. The Air Camper has used more engines than like ly any other aircraft type. So those protective of the Pietenpol name are really counter productive to the idea of this blog and "experimental" aircraft in my opinion. Brian > From: gboothe5(at)comcast.net > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Which one? > Date: Fri=2C 7 Mar 2014 19:44:49 -0800 > > > > There is only one Pietenpol...get the plans from the Pietenpol family. Th ey > will have updates available not in the Flying and Glider Manual. Anything > else is not a Pietenpol. > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > glenschweizer(at)yahoo.com > Sent: Friday=2C March 07=2C 2014 7:23 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Which one? > > > It's time to get serious and I could use some advice. How many different > sets of plans are there for piets? I have the set published originally i n > the flying and glider manual. Are these different from the ones availabl e > from the pietenpol family? What about those available from St. Croix? H ow > about the biplane version? Any input would be very appreciated > Glen > > Sent from my iPhone > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 08, 2014
I know that 2200 cc will fly a Pietenpol because I just had a ride in one i n New Zealand. It needed 3000 rpm to get enough power and was an overhead valve engine. It was from a Toyota Hilux. As for weight=2C published weights are usually misleading. As for your general points=2C they are valid questions and worthy of consid eration. Brian > From: cdawson5854(at)shaw.ca > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? > Date: Sat=2C 8 Mar 2014 01:50:16 -0800 > > > According to the Flying and Glider Piet article the Ford > A weighs 244lb. > According to this Wikipedia article the Willys weighs > in at 470 lb! > We just told a certain propmaker that he couldn't use > his VW engine because it's too small and revs too high. > It's 2500cc. The Willys is 2200cc. > The c-65 is 2830cc and the Corvair starts at 2700cc. > The Ford is a wopping 3400cc! and 128 ft-lb torque. > The c65 has 148lb torque. The little Willys? 114 ft-lb. > The Corvair appears to be 155 but at 2800 rpm. > > So=2C perusing the above=2C in direct drive=2C will the Willys > be able to pull it off? > > I think nostalgia is colouring perceptions here. > Nothing wrong with nostalgia but as Mark Twain said=3B > "It ain't what you don't know that gets you into trouble. > It's what you know for sure that just ain't so." > > But=3B > "Life is trying things to see if they work." (Ray Bradbury) > > OK=2C I'll stop now. > > Bad Clif > > A crank is a very elegant device. It's small=2C > it's strong=2C it's lightweight=2C energy efficient > and it makes revolutions. > E F Schumacher > > > > > > By the way=2C I found a dyno simulation for the L134 engine that produc ed > > the power and torque curves in the graph that I've attached. It may be > > possible to make this work=2C just looking at the curves. At "normal" prop > > speeds of 2200-2300 RPM=2C the power looks to be about 36-37HP (solid r ed > > curve). Run it up to 2400-2500 and it climbs into the 40-42HP range=2C > > which is comparable to the Ford "A" engine. Run it at 3000 RPM with a > > ground-adjustable 68" Warp Drive like the Corvair uses and it might put > > out 50HP. > > > > The dry weight of the engine is given in the Willys specs as 365 lbs. b ut > > people on the Jeep CJ chat sites say it weighs about the same as a > > small-block Chevy. The Ford A engine weighs about the same=2C I think. .. > > specs that I found show weight of engine and transmission to be 475=2C so > > the engine alone should be about the same weight as the Willys. > > > > -------- > > Oscar Zuniga > > Medford=2C OR > > Air Camper NX41CC "=3BScout"=3B > > A75 power > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=419861#419861 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/dyno_runa_1percent20small_894.jpg > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: whoa, I got to fly!!
Date: Mar 08, 2014
Guess what my Piet did today? It actually got to fly!!! It's been two months since I squeezed in a flight between the weather. 58 degrees and sunny with a tiny crosswind. Had patrolled the front for thirty minutes but the skies were clear of the Hun so returned to base and made two pretty nice landings on the asphalt. It was a good day. Keep building!! Douwe ________________________________________________________________________________
Date: Mar 08, 2014
Wow. That gusset popped off in about 60 seconds. Thanks. -------- Joe Pringle Atlanta, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419981#419981 ________________________________________________________________________________
Date: Mar 08, 2014
Subject: Instrument mounting hint
Just saw this on the Bonanza list. One setup for instruments is to angle the top of the artificial horizon to ensure it is level in flight. A side effect is that angling the instrument toward the pilot can help eliminate glare on the glass face. One instrument is available straight or with the top angled 8 degrees. What do y'all think. Is glare a problem in your piets? or is this a solution looking for a problem? Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 08, 2014
Subject: PLB App
Here is a personal locator app for android GPS equipped phones and tablets. https://play.google.com/store/apps/details?id=com.sygem.android.trackme A cheap solution. Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 08, 2014
My idea on instruments is Jim Hammonds approach on his Hatz. A single knife switch on his dash labelled on and off. Burt Rutan's rule on the Voyager was if you throw an accessory up and it co mes down it is too heavy to go on the aircraft Then there is the adage - If it ain't there if can't break I know your question was about angles and not about an artificial horizon b ut I can't help myself Angling the dashboard might be an idea=2C not the instruments. Date: Sat=2C 8 Mar 2014 11:36:38 -0600 Subject: Pietenpol-List: Instrument mounting hint From: steven.d.dortch(at)gmail.com Just saw this on the Bonanza list. One setup for instruments is to angle the top of the artificial horizon to ensure it is level in flight. A side effect is that angling the instrument toward the pilot can help elim inate glare on the glass face. =0A One instrument is available straight or with the top angled 8 degrees. What do y'all think. Is glare a problem in your piets? or is this a solutio n looking for a problem? Blue Skies=2C =0A Steve D =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Mar 08, 2014
Subject: Re: Instrument mounting hint
Correct Brian, I don't want to add any unneeded instrument to my plane. Just to be clear, I was not advocating for an artificial horizon, But wanting to discuss the reflective glare on the few instrument panels I do have. Some Bonanza owners have done the tilt by putting washers under their instruments until it is just right. Some have tilted the instrument panel (using washers) Blue Skies, Steve D On Sat, Mar 8, 2014 at 12:19 PM, Brian Kenney wrote: > My idea on instruments is Jim Hammonds approach on his Hatz. A single > knife switch on his dash labelled on and off. > > Burt Rutan's rule on the Voyager was if you throw an accessory up and it > comes down it is too heavy to go on the aircraft > > Then there is the adage - If it ain't there if can't break > > I know your question was about angles and not about an artificial horizon > but I can't help myself > > Angling the dashboard might be an idea, not the instruments. > > ------------------------------ > Date: Sat, 8 Mar 2014 11:36:38 -0600 > Subject: Pietenpol-List: Instrument mounting hint > From: steven.d.dortch(at)gmail.com > To: pietenpol-list(at)matronics.com > > > Just saw this on the Bonanza list. > > One setup for instruments is to angle the top of the artificial horizon to > ensure it is level in flight. > > A side effect is that angling the instrument toward the pilot can help > eliminate glare on the glass face. > > One instrument is available straight or with the top angled 8 degrees. > > What do y'all think. Is glare a problem in your piets? or is this a > solution looking for a problem? > > Blue Skies, > > Steve D > > * > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > ="_blank">http://www.matronics.com/contribution > ========== > > * > > * > > > * > > ________________________________________________________________________________
Subject: Honda CB350 wheel modification directions
Date: Mar 08, 2014
I hope this works it is my first attempt to post a file As requested here is my notes on modifying the wheels used on my airplane -------- Brian Kenney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419992#419992 Attachments: http://forums.matronics.com//files/wheel_mod_801.docx ________________________________________________________________________________
Date: Mar 08, 2014
Mine are not angled and they are not a problem. Date: Sat=2C 8 Mar 2014 12:29:46 -0600 Subject: Re: Pietenpol-List: Instrument mounting hint From: steven.d.dortch(at)gmail.com Correct Brian=2C I don't want to add any unneeded instrument to my plane. Just to be clear=2C I was not advocating for an artificial horizon=2C But w anting to discuss the reflective glare on the few instrument panels I do ha ve. =0A Some Bonanza owners have done the tilt by putting washers under their instr uments until it is just right. Some have tilted the instrument panel (using washers) Blue Skies=2C Steve D =0A On Sat=2C Mar 8=2C 2014 at 12:19 PM=2C Brian Kenney wrote: =0A =0A =0A =0A My idea on instruments is Jim Hammonds approach on his Hatz. A single knife switch on his dash labelled on and off. Burt Rutan's rule on the Voyager was if you throw an accessory up and it co mes down it is too heavy to go on the aircraft =0A Then there is the adage - If it ain't there if can't break I know your question was about angles and not about an artificial horizon b ut I can't help myself Angling the dashboard might be an idea=2C not the instruments. =0A Date: Sat=2C 8 Mar 2014 11:36:38 -0600 Subject: Pietenpol-List: Instrument mounting hint From: steven.d.dortch(at)gmail.com Just saw this on the Bonanza list. One setup for instruments is to angle the top of the artificial horizon to ensure it is level in flight. A side effect is that angling the instrument toward the pilot can help elim inate glare on the glass face. =0A =0A One instrument is available straight or with the top angled 8 degrees. What do y'all think. Is glare a problem in your piets? or is this a solutio n looking for a problem? Blue Skies=2C =0A =0A Steve D =0A =0A =0A =0A st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List=0A http://forums.matronics.com=0A ="_blank">http://www.matronics.com/contribution=0A =0A =0A =0A =0A =0A " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List=0A tp://forums.matronics.com=0A _blank">http://www.matronics.com/contribution=0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Mar 08, 2014
Subject: Re: Honda CB350 wheel modification directions
Brian, it did load well. I could open it. Is this for the Piper cub style gear? Blue Skies, Steve D On Sat, Mar 8, 2014 at 12:32 PM, Brian C-FAUK wrote: > > > > I hope this works it is my first attempt to post a file > > As requested here is my notes on modifying the wheels used on my airplane > > -------- > Brian Kenney > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419992#419992 > > > Attachments: > > http://forums.matronics.com//files/wheel_mod_801.docx > > ________________________________________________________________________________
Date: Mar 08, 2014
Thanks for this post. I am in the process of doing this. Your techniques wi ll be valuable to me. Lorenzo > Subject: Pietenpol-List: Honda CB350 wheel modification directions > From: brian.kenney(at)live.ca > Date: Sat=2C 8 Mar 2014 10:32:06 -0800 > To: pietenpol-list(at)matronics.com > a> > > I hope this works it is my first attempt to post a file > > As requested here is my notes on modifying the wheels used on my airplane > > -------- > Brian Kenney > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419992#419992 > > > > > Attachments: > > http://forums.matronics.com//files/wheel_mod_801.docx > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 08, 2014
The wheels I have are on the wood straight axle gear. they are now 27 years y oung. . Sent from my iPad > On Mar 8, 2014, at 1:49 PM, "Steven Dortch" wr ote: > > Brian, it did load well. I could open it. > > Is this for the Piper cub style gear? > > Blue Skies, > Steve D > > >> On Sat, Mar 8, 2014 at 12:32 PM, Brian C-FAUK wrot e: a> >> >> I hope this works it is my first attempt to post a file >> >> As requested here is my notes on modifying the wheels used on my airplane >> >> -------- >> Brian Kenney >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=419992#419992 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/wheel_mod_801.docx >> >> >> >> >> ========== >> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 08, 2014
I will be doing it again for I friend. I will take some pictures as I go. Sent from my iPad > On Mar 8, 2014, at 2:14 PM, "larharris2 Harris" wrote : > > Thanks for this post. I am in the process of doing this. Your techniques w ill be valuable to me. > > Lorenzo > > > > > Subject: Pietenpol-List: Honda CB350 wheel modification directions > > From: brian.kenney(at)live.ca > > Date: Sat, 8 Mar 2014 10:32:06 -0800 > > To: pietenpol-list(at)matronics.com > > ca> > > > > I hope this works it is my first attempt to post a file > > > > As requested here is my notes on modifying the wheels used on my airplan e > > > > -------- > > Brian Kenney > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=419992#419992 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/wheel_mod_801.docx= Archive Search & Download, 7-Day Browse, Chat, FAQ, > &g= --> http://www.matronics.com/Navigator?Pietenpol-List > > ======================== > > > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 08, 2014
Gauges are not angled on NX18235 and glare is no problem. Other than glanci ng at the oil temp and pressure once in awhile I rarely look at them. Greg C. ----- Original Message ----- From: Steven Dortch To: pietenpol-list(at)matronics.com Sent: Saturday, March 08, 2014 11:36 AM Subject: Pietenpol-List: Instrument mounting hint Just saw this on the Bonanza list. One setup for instruments is to angle the top of the artificial horizon t o ensure it is level in flight. A side effect is that angling the instrument toward the pilot can help el iminate glare on the glass face. One instrument is available straight or with the top angled 8 degrees. What do y'all think. Is glare a problem in your piets? or is this a solut ion looking for a problem? Blue Skies, Steve D --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Mar 08, 2014
Subject: Re: Pietenpol-List Digest: 22 Msgs - 03/07/14
You subscribed yourself, you need to remove yourself: http://www.matronics.com/subscribe/ On Sat, Mar 8, 2014 at 1:13 PM, Ellen wrote: > > Please remove this email address from your distribution. Second request. > > Sent from my iPhone ________________________________________________________________________________
Date: Mar 08, 2014
Your writeup says that you got the idea from a photo on WestCoastPiet. Any idea of the name of the listing=2C since photos are categorized by name of the owner/builder? I think I may need all the photo reference I can get. Th anks. Lorenzo Subject: Re: Pietenpol-List: Honda CB350 wheel modification directions From: brian.kenney(at)live.ca Date: Sat=2C 8 Mar 2014 14:40:45 -0500 I will be doing it again for I friend. I will take some pictures as I go. ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Mar 08, 2014
I think that somebody already suggested that the published wt. for the Wileys included the transmission, which, of course, would not be included. On Mar 8, 2014, at 11:00 AM, Brian Kenney wrote: > I know that 2200 cc will fly a Pietenpol because I just had a ride > in one in New Zealand. > It needed 3000 rpm to get enough power and was an overhead valve > engine. It was from a Toyota Hilux. > > As for weight, published weights are usually misleading. > > As for your general points, they are valid questions and worthy of > consideration. > > Brian > > > From: cdawson5854(at)shaw.ca > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? > > Date: Sat, 8 Mar 2014 01:50:16 -0800 > > > > > > > > According to the Flying and Glider Piet article the Ford > > A weighs 244lb. > > According to this Wikipedia article the Willys weighs > > in at 470 lb! > > We just told a certain propmaker that he couldn't use > > his VW engine because it's too small and revs too high. > > It's 2500cc. The Willys is 2200cc. > > The c-65 is 2830cc and the Corvair starts at 2700cc. > > The Ford is a wopping 3400cc! and 128 ft-lb torque. > > The c65 has 148lb torque. The little Willys? 114 ft-lb. > > The Corvair appears to be 155 but at 2800 rpm. > > > > So, perusing the above, in direct drive, will the Willys > > be able to pull it off? > > > > I think nostalgia is colouring perceptions here. > > Nothing wrong with nostalgia but as Mark Twain said; > > "It ain't what you don't know that gets you into trouble. > > It's what you know for sure that just ain't so." > > > > But; > > "Life is trying things to see if they work." (Ray Bradbury) > > > > OK, I'll stop now. > > > > Bad Clif > > > > A crank is a very elegant device. It's small, > > it's strong, it's lightweight, energy efficient > > and it makes revolutions. > > E F Schumacher > > > > > > > > > > By the way, I found a dyno simulation for the L134 engine that > produced > > > the power and torque curves in the graph that I've attached. It > may be > > > possible to make this work, just looking at the curves. At > "normal" prop > > > speeds of 2200-2300 RPM, the power looks to be about 36-37HP > (solid red > > > curve). Run it up to 2400-2500 and it climbs into the 40-42HP > range, > > > which is comparable to the Ford "A" engine. Run it at 3000 RPM > with a > > > ground-adjustable 68" Warp Drive like the Corvair uses and it > might put > > > out 50HP. > > > > > > The dry weight of the engine is given in the Willys specs as 365 > lbs. but > > > people on the Jeep CJ chat sites say it weighs about the same as a > > > small-block Chevy. The Ford A engine weighs about the same, I > think... > > > specs that I found show weight of engine and transmission to be > 475, so > > > the engine alone should be about the same weight as the Willys. > > > > > > -------- > > > Oscar Zuniga > > > Medford, OR > > > Air Camper NX41CC "Scout" > > > A75 power > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=419861#419861 > > > > > > > > > > > > > > > Attachments: > > > > > > http://forums.matronics.com//files/dyno_runa_1percent20small_894.jpg > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > > No virus found in this message. > > > Checked b===================== > >====== > > > > > > > > ________________________________________________________________________________
Date: Mar 08, 2014
No not a photo on West Coast Piet but a Piet from the west coast. It was i n a magazine and the owner was from the S.F. area and the registration was something like N113 but that is all from memory. I probably still have the article. From: larharris2(at)msn.com Subject: RE: Pietenpol-List: Honda CB350 wheel modification directions Date: Sat=2C 8 Mar 2014 16:43:34 -0500 =0A =0A =0A Your writeup says that you got the idea from a photo on WestCoastPiet. Any idea of the name of the listing=2C since photos are categorized by name of the owner/builder? I think I may need all the photo reference I can get. Th anks. Lorenzo Subject: Re: Pietenpol-List: Honda CB350 wheel modification directions From: brian.kenney(at)live.ca Date: Sat=2C 8 Mar 2014 14:40:45 -0500 I will be doing it again for I friend. I will take some pictures as I go. =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Old BPA newsletters
Date: Mar 08, 2014
This is an idea for discussion. I have a large binder of Buckeye Pietenpol Newsletters. I would like to see them scanned and put somewhere on the net for public access. There is a lot of timeless information in them. I would be willing to do some or all of the work to do this but I have no idea the best way to do this and what the reaction would be if I did it. Your comments are welcome. Perhaps this has already been discussed. -------- Brian Kenney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420012#420012 ________________________________________________________________________________
Date: Mar 08, 2014
I found a picture of the airplane - It is N3133 From: brian.kenney(at)live.ca Subject: RE: Pietenpol-List: Honda CB350 wheel modification directions Date: Sat=2C 8 Mar 2014 16:56:53 -0500 =0A =0A =0A No not a photo on West Coast Piet but a Piet from the west coast. It was i n a magazine and the owner was from the S.F. area and the registration was something like N113 but that is all from memory. I probably still have the article. From: larharris2(at)msn.com Subject: RE: Pietenpol-List: Honda CB350 wheel modification directions Date: Sat=2C 8 Mar 2014 16:43:34 -0500 =0A =0A =0A Your writeup says that you got the idea from a photo on WestCoastPiet. Any idea of the name of the listing=2C since photos are categorized by name of the owner/builder? I think I may need all the photo reference I can get. Th anks. Lorenzo Subject: Re: Pietenpol-List: Honda CB350 wheel modification directions From: brian.kenney(at)live.ca Date: Sat=2C 8 Mar 2014 14:40:45 -0500 I will be doing it again for I friend. I will take some pictures as I go. =0A =0A =0A =0A ============0A st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List=0A ============0A http://forums.matronics.com=0A ============0A ="_blank">http://www.matronics.com/contribution=0A ============0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Re: Old BPA newsletters
Date: Mar 08, 2014
This has been hashed over many times in the past. Grant McClaren, a past publisher of the BPA News, won't allow this type of copying. It's too bad, but he feels that he was done wrong by the Piet community some years ago & asserts his copyright rights. Kip Gardner On Mar 8, 2014, at 5:04 PM, Brian C-FAUK wrote: > > > > This is an idea for discussion. I have a large binder of Buckeye > Pietenpol Newsletters. I would like to see them scanned and put > somewhere on the net for public access. There is a lot of timeless > information in them. I would be willing to do some or all of the > work to do this but I have no idea the best way to do this and what > the reaction would be if I did it. Your comments are welcome. > > Perhaps this has already been discussed. > > -------- > Brian Kenney > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > ________________________________________________________________________________
Date: Mar 08, 2014
For anyone interested, attached are a few photos of what the finished product looks like. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420015#420015 Attachments: http://forums.matronics.com//files/20060617_112_120.jpg http://forums.matronics.com//files/20060617_113_578.jpg http://forums.matronics.com//files/20070616_062_184.jpg http://forums.matronics.com//files/20070616_063_857.jpg http://forums.matronics.com//files/20070616_066_108.jpg ________________________________________________________________________________
Date: Mar 08, 2014
I am all in favor of this. I have an incomplete set I would be willing to c ontribute to the effort. Lorenzo > Subject: Pietenpol-List: Old BPA newsletters > From: brian.kenney(at)live.ca > Date: Sat=2C 8 Mar 2014 14:04:34 -0800 > To: pietenpol-list(at)matronics.com > a> > > This is an idea for discussion. I have a large binder of Buckeye Pietenpo l Newsletters. I would like to see them scanned and put somewhere on the ne t for public access. There is a lot of timeless information in them. I wou ld be willing to do some or all of the work to do this but I have no idea t he best way to do this and what the reaction would be if I did it. Your com ments are welcome. > > Perhaps this has already been discussed. > > -------- > Brian Kenney > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 08, 2014
Are the rights owned by him personally? Or by the BPA? Lorenzo > From: kipandbeth(at)earthlink.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Old BPA newsletters > Date: Sat=2C 8 Mar 2014 17:34:35 -0500 > rthlink.net> > > This has been hashed over many times in the past. Grant McClaren=2C a > past publisher of the BPA News=2C won't allow this type of copying. > It's too bad=2C but he feels that he was done wrong by the Piet > community some years ago & asserts his copyright rights. > > Kip Gardner > > On Mar 8=2C 2014=2C at 5:04 PM=2C Brian C-FAUK wrote: > .ca > > > > > > > This is an idea for discussion. I have a large binder of Buckeye > > Pietenpol Newsletters. I would like to see them scanned and put > > somewhere on the net for public access. There is a lot of timeless > > information in them. I would be willing to do some or all of the > > work to do this but I have no idea the best way to do this and what > > the reaction would be if I did it. Your comments are welcome. > > > > Perhaps this has already been discussed. > > > > -------- > > Brian Kenney > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Speaking of Doc...
Date: Mar 08, 2014
William Wynne has a nice article on flycorvair.net about Doc. Here's the link: http://flycorvair.net/2014/03/08/pietenpol-weight-and-balance-article-source/ Welcome back, Doc! -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420018#420018 ________________________________________________________________________________
Date: Mar 08, 2014
Thank you. Very helpful. Lorenzo > Subject: Pietenpol-List: Re: Honda CB350 wheel modification directions > From: billspiet(at)sympatico.ca > Date: Sat=2C 8 Mar 2014 14:37:43 -0800 > To: pietenpol-list(at)matronics.com > ca> > > For anyone interested=2C attached are a few photos of what the finished p roduct looks like. > > Bill C. > ________________________________________________________________________________
Date: Mar 08, 2014
As I said, this has all been discussed before, it's in the archives. He asserts the rights to all the issues that were published by him, he essentially WAS the BPA at the time, and copyright law is pretty clear that he can assert those rights. I have no idea how Frank Pavliga would feel about the copying of the issues published when his Dad was the editor. Kip Gardner On Mar 8, 2014, at 5:52 PM, larharris2 Harris wrote: > Are the rights owned by him personally? Or by the BPA? > > Lorenzo > > > > From: kipandbeth(at)earthlink.net > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: Old BPA newsletters > > Date: Sat, 8 Mar 2014 17:34:35 -0500 > > > > > > > > This has been hashed over many times in the past. Grant McClaren, a > > past publisher of the BPA News, won't allow this type of copying. > > It's too bad, but he feels that he was done wrong by the Piet > > community some years ago & asserts his copyright rights. > > > > Kip Gardner > > > > On Mar 8, 2014, at 5:04 PM, Brian C-FAUK wrote: > > > > > > > > > > > > This is an idea for discussion. I have a large binder of Buckeye > > > Pietenpol Newsletters. I would like to see them scanned and put > > > somewhere on the net for public access. There is a lot of timeless > > > information in them. I would be willing to do some or all of the > > > work to do this but I have no idea the best way to do this and > what > > > the reaction would be if I did it. Your comments are welcome. > > > > > > Perhaps this has already been discussed. > > > > > > -------- > > > Brian Kenney > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 08, 2014
Can copyrights for a nonprofit org member communications be owned by an indi vidual or does that belong to the org? Sent from my iPhone > On Mar 8, 2014, at 2:52 PM, larharris2 Harris wrote: > > Are the rights owned by him personally? Or by the BPA? > > Lorenzo > > > > > From: kipandbeth(at)earthlink.net > > To: pietenpol-list(at)matronics.com > > Subject: Re: Pietenpol-List: Old BPA newsletters > > Date: Sat, 8 Mar 2014 17:34:35 -0500 > > arthlink.net> > > > > This has been hashed over many times in the past. Grant McClaren, a > > past publisher of the BPA News, won't allow this type of copying. > > It's too bad, but he feels that he was done wrong by the Piet > > community some years ago & asserts his copyright rights. > > > > Kip Gardner > > > > On Mar 8, 2014, at 5:04 PM, Brian C-FAUK wrote: > > e.ca > > > > > > > > > > This is an idea for discussion. I have a large binder of Buckeye > > > Pietenpol Newsletters. I would like to see them scanned and put > > > somewhere on the net for public access. There is a lot of timeless > > > information in them. I would be willing to do some or all of the > > > work to do this but I have no idea the best way to do this and what > > > the reaction would be if I did it. Your comments are welcome. > > > > > > Perhaps this has already been discussed. > > > > > > -------- > > > Brian Kenney > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 08, 2014
Brian, They do it with a fish scale, so why not this? Maybe it would be possible to loan your binder out so others can see the old newsletters. When one builder finishes, it gets sent to the next, and so on. There may be a discussion in the archives about copyrights.However, there is nothing that says I, or any other builder, can't read your copies. If you are interested, let me know off-line, and I would be happy to assist in any way I can. I just want to be in the queue. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420023#420023 ________________________________________________________________________________
Date: Mar 08, 2014
OK So it was a solution looking for a Problem that was not there. It is bad here so the garage is dark. We are having "South Texas Snow" aka Drizzle all day. Thanks Guys, Steve D On Sat, Mar 8, 2014 at 2:10 PM, Greg Cardinal wrote: > Gauges are not angled on NX18235 and glare is no problem. Other than > glancing at the oil temp and pressure once in awhile I rarely look at them. > > Greg C. > > ----- Original Message ----- > *From:* Steven Dortch > *To:* pietenpol-list(at)matronics.com > *Sent:* Saturday, March 08, 2014 11:36 AM > *Subject:* Pietenpol-List: Instrument mounting hint > > Just saw this on the Bonanza list. > > One setup for instruments is to angle the top of the artificial horizon to > ensure it is level in flight. > > A side effect is that angling the instrument toward the pilot can help > eliminate glare on the glass face. > > One instrument is available straight or with the top angled 8 degrees. > > What do y'all think. Is glare a problem in your piets? or is this a > solution looking for a problem? > > Blue Skies, > > Steve D > > * > > ">http://www.matronics.com/Navigator?Pietenpol-List > ics.com <http://ics.com> > .matronics.com/contribution <http://matronics.com/contribution> > > * > > > ------------------------------ > <http://www.avast.com/> > > This email is free from viruses and malware because avast! Antivirus<http://www.avast.com/>protection is active. > > ________________________________________________________________________________
Date: Mar 08, 2014
If those are the lost issues, Dan Halsper is your man. Entrusted with only the most secret of secret documents and informational treasures. you need to be talking to Dan the man! Please make sure you tell him that I sent you John In a message dated 3/8/2014 5:49:33 P.M. Eastern Standard Time, larharris2(at)msn.com writes: I am all in favor of this. I have an incomplete set I would be willing to contribute to the effort. Lorenzo > Subject: Pietenpol-List: Old BPA newsletters > From: brian.kenney(at)live.ca > Date: Sat, 8 Mar 2014 14:04:34 -0800 > To: pietenpol-list(at)matronics.com > > --> Pietenpol-List message posted by: "Brian C-FAUK" > > This is an idea for discussion. I have a large binder of Buckeye Pietenpol Newsletters. I would like to see them scanned and put somewhere on the net for public access. There is a lot of timeless information in them. I would be willing to do some or all of the work to do this but I have no idea the best way to do this and what the reaction would be if I did it. Your comments are welcome. > > Perhaps this has already been discussed. > > -------- > Brian Kenney > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > >====================== &g====== > > > ________________________________________________________________________________
Date: Mar 08, 2014
Ok let's not debate the ownership of the old newsletters I would still like input on how to download information that is available w ith permission for access by others. Is this blog the best way to do it or is there a better way? Brian From: kipandbeth(at)earthlink.net Subject: Re: Pietenpol-List: Old BPA newsletters Date: Sat=2C 8 Mar 2014 18:04:30 -0500 As I said=2C this has all been discussed before=2C it's in the archives. H e asserts the rights to all the issues that were published by him=2C he ess entially WAS the BPA at the time=2C and copyright law is pretty clear that he can assert those rights. I have no idea how Frank Pavliga would feel ab out the copying of the issues published when his Dad was the editor. Kip Gardner On Mar 8=2C 2014=2C at 5:52 PM=2C larharris2 Harris wrote:Are the rights ow ned by him personally? Or by the BPA? Lorenzo > From: kipandbeth(at)earthlink.net > To: pietenpol-list(at)matronics.com > Subject: Re: Pietenpol-List: Old BPA newsletters > Date: Sat=2C 8 Mar 2014 17:34:35 -0500 > rthlink.net> > > This has been hashed over many times in the past. Grant McClaren=2C a > past publisher of the BPA News=2C won't allow this type of copying. > It's too bad=2C but he feels that he was done wrong by the Piet > community some years ago & asserts his copyright rights. > > Kip Gardner > > On Mar 8=2C 2014=2C at 5:04 PM=2C Brian C-FAUK wrote: > .ca > > > > > > > This is an idea for discussion. I have a large binder of Buckeye > > Pietenpol Newsletters. I would like to see them scanned and put > > somewhere on the net for public access. There is a lot of timeless > > information in them. I would be willing to do some or all of the > > work to do this but I have no idea the best way to do this and what > > the reaction would be if I did it. Your comments are welcome. > > > > Perhaps this has already been discussed. > > > > -------- > > Brian Kenney > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > > > > > > > > > > > > > > > > > > =0A =0A href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List=0A href="http://forums.matronics.com">http://forums.matronics.com=0A href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution=0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Mar 08, 2014
There are also International Pietenpol Association newsletters out there from before the time the AAA took over the organization. I have some that I would be happy to contribute. Darrel Jones Sonoma, CA On 3/8/2014 2:49 PM, larharris2 Harris wrote: > I am all in favor of this. I have an incomplete set I would be willing > to contribute to the effort. > > Lorenzo > > > > Subject: Pietenpol-List: Old BPA newsletters > > From: brian.kenney(at)live.ca > > Date: Sat, 8 Mar 2014 14:04:34 -0800 > > To: pietenpol-list(at)matronics.com > > > > > > > This is an idea for discussion. I have a large binder of Buckeye > Pietenpol Newsletters. I would like to see them scanned and put > somewhere on the net for public access. There is a lot of timeless > information in them. I would be willing to do some or all of the work > to do this but I have no idea the best way to do this and what the > reaction would be if I did it. Your comments are welcome. > > > > Perhaps this has already been discussed. > > > > -------- > > Brian Kenney > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > > > > > > > > > >====================== > &g====== > > > > > > > * > > > * ________________________________________________________________________________
Date: Mar 08, 2014
Here is what I propose, if the 2 of you are willing to share. I am willing to pay the postage to get both sets of newsletters together. I will pay to send them to my address. I will then pay the postage to get them to the next guy. When he is done, then he pays to mail it on to the next guy, etc, etc. By doing it that way, nobody reimburses anybody for postage, they just pay to send it on. Lest you think I am being pushy to be the first in line, that is why I am willing to pay for postage to me as well as from me to the next guy. I am also willing to collect the names and addresses of those builders interested in being a part of the mobile library. Let us know if you think that would work. But thanks for considering the possibility of sharing your newsletters. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420028#420028 ________________________________________________________________________________
Date: Mar 08, 2014
Who runs the BPA and has the right to OK the publication? Perhaps they would be posted in a Members only area. (Members Only jacket required) With my next paycheck I am joining the BPA. Blue Skies, Steve D On Sat, Mar 8, 2014 at 6:18 PM, Darrel Jones wrote: > There are also International Pietenpol Association newsletters out there > from before the time the AAA took over the organization. I have some that I > would be happy to contribute. > > Darrel Jones > Sonoma, CA > > On 3/8/2014 2:49 PM, larharris2 Harris wrote: > > I am all in favor of this. I have an incomplete set I would be willing to > contribute to the effort. > > Lorenzo > > > > Subject: Pietenpol-List: Old BPA newsletters > > From: brian.kenney(at)live.ca > > Date: Sat, 8 Mar 2014 14:04:34 -0800 > > To: pietenpol-list(at)matronics.com > > > > > > > This is an idea for discussion. I have a large binder of Buckeye > Pietenpol Newsletters. I would like to see them scanned and put somewhere > on the net for public access. There is a lot of timeless information in > them. I would be willing to do some or all of the work to do this but I > have no idea the best way to do this and what the reaction would be if I > did it. Your comments are welcome. > > > > Perhaps this has already been discussed. > > > > -------- > > Brian Kenney > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=420012#420012 > > > > > > > > > > > > > > > >====================== > &g====== > > > > > > > > > * > > > * > > ________________________________________________________________________________
Subject: Which one?
Date: Mar 08, 2014
Glen, The attached picture, taken today just before a flight with Lee Graybill and his Baby Ace, is of a Pietenpol. not a GN-1 Aircamper. or a re-designed St. Croix Pietenpol Aircamper. It is a long fuselage, corvair powered Piet.all variations available only through the Pietenpol family. Since you asked specifically about Pietenpols, my answer was not intended to be a commentary on the variations of this fine airplane, nor an analysis of what Mr. Pietenpol represented in the world of experimental aviation. FYI - Today's flight was with two 200 lb crew members! Good luck with your decision. Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Brian Kenney Sent: Saturday, March 08, 2014 7:31 AM Subject: RE: Pietenpol-List: Which one? This is a misleading answer and not correct. For example there are four "Pietenpol" fuselages There are two from the 1931 flying and glider magazine - a wood one and a steel one. There is a 1933 improved version with steel gear and there is a 1966 fuselage for the corvair engine. there are at least three engine mounts. The suggestion that something is not a Pietenpol would have upset Bernie Pietenpol and he was nothing like that protective.. He was an experimenter and tried all kinds of things. The Air Camper has used more engines than likely any other aircraft type. So those protective of the Pietenpol name are really counter productive to the idea of this blog and "experimental" aircraft in my opinion. Brian > From: gboothe5(at)comcast.net > To: pietenpol-list(at)matronics.com > Subject: RE: Pietenpol-List: Which one? > Date: Fri, 7 Mar 2014 19:44:49 -0800 > > > There is only one Pietenpol...get the plans from the Pietenpol family. They > will have updates available not in the Flying and Glider Manual. Anything > else is not a Pietenpol. > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of > glenschweizer(at)yahoo.com > Sent: Friday, March 07, 2014 7:23 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Which one? > > > It's time to get serious and I could use some advice. How many different > sets of plans are there for piets? I have the set published originally in > the flying and glider manual. Are these different from the ones available > from the pietenpol family? What about those available from St. Croix? How > about the biplane version? Any input would be very appreciated > Glen > > Sent from my iPhone > > > > ============ > > > ________________________________________________________________________________
Date: Mar 09, 2014
Your right, In researching further another site turned up that didn't the first time. They say the go devil engine itself weighs 148 lb. That NZ Piet, was it operating with or without a reduction unit? Jim Malley's Piet has a 98hp Ford Fiesta in it but with a psru. Clif ----- Original Message ----- From: Brian Kenney To: pietenpol-list(at)matronics.com Sent: Saturday, March 08, 2014 8:00 AM Subject: RE: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? I know that 2200 cc will fly a Pietenpol because I just had a ride in one in New Zealand. It needed 3000 rpm to get enough power and was an overhead valve engine. It was from a Toyota Hilux. As for weight, published weights are usually misleading. As for your general points, they are valid questions and worthy of consideration. Brian > > According to the Flying and Glider Piet article the Ford > A weighs 244lb. > According to this Wikipedia article the Willys weighs > in at 470 lb! > We just told a certain propmaker that he couldn't use > his VW engine because it's too small and revs too high. > It's 2500cc. The Willys is 2200cc. > The c-65 is 2830cc and the Corvair starts at 2700cc. > The Ford is a wopping 3400cc! and 128 ft-lb torque. > The c65 has 148lb torque. The little Willys? 114 ft-lb. > The Corvair appears to be 155 but at 2800 rpm. > > So, perusing the above, in direct drive, will the Willys > be able to pull it off? > Bad Clif ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: CB350 wheels
Date: Mar 09, 2014
Hey Bill, Out of curiosity, how do those brakes hold and over the last 27 years, how often would you guess you've had to replace the pads, if at all? Douwe ________________________________________________________________________________
Date: Mar 09, 2014
I have never replaced the pads and used the old ones that came with the whe els. I only recently adjusted the cable for the first time after over 25 ye ars.. I am using only one of the two shoes in each wheel. I use the leadin g shoe only ( the one that self energizes). I can lock the wheels on grass and have pulled the tail off the ground on payment but only under extreme b reaking. They won't really hold under full throttle but that doesn't mean t hey are not good as they really shorten the roll and are I think they are the perfect balance. They worked out great and I lucked out with the set u p. From: douweblumberg(at)earthlink.net Subject: Pietenpol-List: CB350 wheels Date: Sun=2C 9 Mar 2014 04:48:03 -0400 =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Hey Bill=2C=0A =0A =0A =0A Out of curiosity=2C how do those brakes hold and over the last=0A 27 years=2C how often would you guess you=92ve had to replace the pads=2C i f at=0A all?=0A =0A =0A =0A Douwe=0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Re: Willys jeep pietenpol engine maybe?
Date: Mar 09, 2014
It is direct drive. The guy that did it has three of them in different type s of airplanes and there are two others on Air Campers down under. I saw on e but didn't get to talk to the owner who was out of town. From: cdawson5854(at)shaw.ca Subject: Re: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? Date: Sun=2C 9 Mar 2014 00:39:19 -0800 =0A =0A =0A =0A =0A =0A =0A Your right=2C In researching further another =0A site=0A turned up that didn't the first time. They =0A say=0A the go devil engine itself weighs 148 =0A lb.=0A =0A That NZ Piet=2C was it operating with or =0A without=0A a reduction unit? =0A =0A Jim Malley's Piet has a 98hp Ford Fiesta =0A in=0A it but with a psru.=0A =0A Clif=0A =0A =0A =0A ----- Original Message ----- =0A From: =0A Brian =0A Kenney =0A To: pietenpol-list(at)matronics.com =0A =0A Sent: Saturday=2C March 08=2C 2014 8:00 =0A AM=0A Subject: RE: Pietenpol-List: Re: Willys =0A jeep pietenpol engine maybe?=0A =0A I know that 2200 cc will fly a Pietenpol because I just had a =0A ride in one in New Zealand. It needed 3000 rpm to get enough power and was =0A an overhead valve engine. It was from a Toyota Hilux. As for =0A weight=2C published weights are usually misleading. As for your =0A general points=2C they are valid questions and worthy of consideration. =0A Brian =0A > > According to the Flying and Glider Piet article the =0A Ford > A weighs 244lb. > According to this Wikipedia article the =0A Willys weighs > in at 470 lb! > We just told a certain propmaker =0A that he couldn't use > his VW engine because it's too small and revs too =0A high. > It's 2500cc. The Willys is 2200cc. > The c-65 is 2830cc =0A and the Corvair starts at 2700cc. > The Ford is a wopping 3400cc! and =0A 128 ft-lb torque. > The c65 has 148lb torque. The little Willys? 114 =0A ft-lb. > The Corvair appears to be 155 but at 2800 rpm. > > =0A So=2C perusing the above=2C in direct drive=2C will the Willys > be able to =0A pull it off? > Bad Clif =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Mar 09, 2014
By the way Clif I believe that a model A engine in a Piet produces more pow er than the rated horsepower stated by Ford. I think it is at least 50 hors epower or perhaps a little more. This is due to better breathing and perha ps the aluminum head. It has to produce more because of the way it performs . Some folks that have used higher rpm likely have even more but it is alwa ys the power versus reliability trade-off to consider. That 200 cu in is ha rd to beat. From: brian.kenney(at)live.ca Subject: RE: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? Date: Sun=2C 9 Mar 2014 07:16:19 -0400 =0A =0A =0A It is direct drive. The guy that did it has three of them in different type s of airplanes and there are two others on Air Campers down under. I saw on e but didn't get to talk to the owner who was out of town. From: cdawson5854(at)shaw.ca Subject: Re: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? Date: Sun=2C 9 Mar 2014 00:39:19 -0800 =0A =0A =0A =0A =0A =0A =0A Your right=2C In researching further another =0A site=0A turned up that didn't the first time. They =0A say=0A the go devil engine itself weighs 148 =0A lb.=0A =0A That NZ Piet=2C was it operating with or =0A without=0A a reduction unit? =0A =0A Jim Malley's Piet has a 98hp Ford Fiesta =0A in=0A it but with a psru.=0A =0A Clif=0A =0A =0A =0A ----- Original Message ----- =0A From: =0A Brian =0A Kenney =0A To: pietenpol-list(at)matronics.com =0A =0A Sent: Saturday=2C March 08=2C 2014 8:00 =0A AM=0A Subject: RE: Pietenpol-List: Re: Willys =0A jeep pietenpol engine maybe?=0A =0A I know that 2200 cc will fly a Pietenpol because I just had a =0A ride in one in New Zealand. It needed 3000 rpm to get enough power and was =0A an overhead valve engine. It was from a Toyota Hilux. As for =0A weight=2C published weights are usually misleading. As for your =0A general points=2C they are valid questions and worthy of consideration. =0A Brian =0A > > According to the Flying and Glider Piet article the =0A Ford > A weighs 244lb. > According to this Wikipedia article the =0A Willys weighs > in at 470 lb! > We just told a certain propmaker =0A that he couldn't use > his VW engine because it's too small and revs too =0A high. > It's 2500cc. The Willys is 2200cc. > The c-65 is 2830cc =0A and the Corvair starts at 2700cc. > The Ford is a wopping 3400cc! and =0A 128 ft-lb torque. > The c65 has 148lb torque. The little Willys? 114 =0A ft-lb. > The Corvair appears to be 155 but at 2800 rpm. > > =0A So=2C perusing the above=2C in direct drive=2C will the Willys > be able to =0A pull it off? > Bad Clif =0A =0A =0A =0A =0A ============0A st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List=0A ============0A http://forums.matronics.com=0A ============0A ="_blank">http://www.matronics.com/contribution=0A ============0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Re: Which one?
Date: Mar 09, 2014
Glen, As mentioned, there are the original Pietenpol Air Camper plans, that were published in the 1932 Flying and Glider magazine, and which you have a copy of. Then there are the plans available from the Pietenpol family. http://community.pressenter.net/~apietenp/BHPietenpolAndSonsAirCamperAircraftPurchasePlans.html In addition to these, there were a couple of different sets of plans for "modernized" versions of the Air Camper that were sold. One set was the St. Croix Air Camper, and the other was the Grega GN-1 Aircamper. Neither of these are available for sale anymore. While some have built their aircraft strictly from the Flying and Glider plans, I believe it would be a real challenge to do so, since the reprints are so small, and are simply lacking some details. My recommendation would be to obtain a set of the plans from the Pietenpol family, to complement the Flying and Glider plans. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420038#420038 ________________________________________________________________________________
Date: Mar 09, 2014
Bill, Just to muddy the water. I have a Pietenpol With plans that were modified by Grega. But it is not a Grega! It is a Pietenpol fuselage with mods that later became the Grega wing. I think. It is just enough hybrid that I cannot firmly tell you where the Grega mods definitely begin or end. Blue Skies, Steve D Pietenpol Air-Camper On Sun, Mar 9, 2014 at 11:39 AM, Bill Church wrote: > billspiet(at)sympatico.ca> > > Glen, > As mentioned, there are the original Pietenpol Air Camper plans, that were > published in the 1932 Flying and Glider magazine, and which you have a copy > of. Then there are the plans available from the Pietenpol family. > > http://community.pressenter.net/~apietenp/BHPietenpolAndSonsAirCamperAircraftPurchasePlans.html > > In addition to these, there were a couple of different sets of plans for > "modernized" versions of the Air Camper that were sold. One set was the > St. Croix Air Camper, and the other was the Grega GN-1 Aircamper. Neither > of these are available for sale anymore. > > While some have built their aircraft strictly from the Flying and Glider > plans, I believe it would be a real challenge to do so, since the reprints > are so small, and are simply lacking some details. My recommendation would > be to obtain a set of the plans from the Pietenpol family, to complement > the Flying and Glider plans. > > Bill C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420038#420038 > > ________________________________________________________________________________
Date: Mar 09, 2014
a 134 cu in jeep engine sans manifolds and sans flywheel weighs #245 pounds with iron head according to the scale in my friends milk barn however, i would be carefull to compare it to the oft quoted weight of #241 lbs with magneto for the model A because i know none of you guys has actually done it. just my two cents ________________________________________________________________________________
Date: Mar 09, 2014
Then, there's this, from Grant MacLaren, circa 1999: Like many other modifications to an airplane's design -- one change requires many other changes. If a "new" biplane is designed, it will be just that -- a new design. It should not carry the name "Pietenpol." Pietenpols forever! -=Grant MacLaren=- Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Steven Dortch Sent: Sunday, March 09, 2014 10:56 AM Subject: Re: Pietenpol-List: Re: Which one? Bill, Just to muddy the water. I have a Pietenpol With plans that were modified by Grega. But it is not a Grega! It is a Pietenpol fuselage with mods that later became the Grega wing. I think. It is just enough hybrid that I cannot firmly tell you where the Grega mods definitely begin or end. Blue Skies, Steve D Pietenpol Air-Camper On Sun, Mar 9, 2014 at 11:39 AM, Bill Church wrote: Glen, As mentioned, there are the original Pietenpol Air Camper plans, that were published in the 1932 Flying and Glider magazine, and which you have a copy of. Then there are the plans available from the Pietenpol family. http://community.pressenter.net/~apietenp/BHPietenpolAndSonsAirCamperAircraf tPurchasePlans.html In addition to these, there were a couple of different sets of plans for "modernized" versions of the Air Camper that were sold. One set was the St. Croix Air Camper, and the other was the Grega GN-1 Aircamper. Neither of these are available for sale anymore. While some have built their aircraft strictly from the Flying and Glider plans, I believe it would be a real challenge to do so, since the reprints are so small, and are simply lacking some details. My recommendation would be to obtain a set of the plans from the Pietenpol family, to complement the Flying and Glider plans. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420038#420038 ========== st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Mar 09, 2014
Kenny, I watched the Youtube clip several times, and I think you are doing something pretty neat. I have been a life long fan of flatheads, Grace and I have a little collection in the hangar. I read all the notes, and for my 2 cents, I think that you have a power plant that will work within limitations, (just as all engines do). I was headed over to my neighbors with the scale, but Mr. Mdw, covered this, and effectively showed both the weight is comparable to a Ford, and also how unreliable internet data can be. I think most people miss that there are both L-134's and OHV F-134's. Scale in a milk barn always beats the internet for useful data, Clif listed the displacements and rpm ranges of several engines, and to it I would like to add the consideration of compression ratio. We have been testing this for a year, back to back, same airframe, etc, and it is surprising the difference between 8.0 and 10.25 to one. The relationship holds true with most engines. I am sure that an O-200 with 8:1 and OHV can be tuned to make more power at any given rpm than a 200 cid Ford. Displacement alone is an incomplete picture. On 'tight' motors: If everything else is set right, it is ring drag on the surface finish of the bores that makes it hard to prop. In my experience, 10 hours of ground runs at 50-60% power has the same smoothing effect as one takeoff and climb to 3,000' at wot. 280 finish on bores is better than 220, but it is time at wot that helps. An optical tach like a Proptach 2545 and a ground adjustable prop are a good 'comparative' Dyno. Get the prop in the test range, check the static rpm, make the change and compare rpm. I have loaner WD props, (in both rotations), glad to send one to you for testing. If Oz's chart is good, targeting 3000 rpm instead of 2500 will buy you a 28% hp increase. The loss of prop efficiency will be in the single digits, and you will have a large net thrust increase. Test this with the loaner prop, you will become convinced. You will have plenty of people tell you it will/won't work. Their belief is based on stories, and since every Pietenpol is a 'snowflake' unto itself, much of the commentary does not apply. You should be able to use The Ford weight and Balance data we collected. My website tells how to get this directly from Doc Mosher. I do not think the success of Fords is because they make 'more than 50 hp' The W&B tests showed that the Ford guys build lighter planes than many A-65 guys. The Ford guys also use better matched props on average. They go into their build knowing they don't have weight or power to waste. It is the opposite attitude of a guy who thinks 'I have a light motor, I don't have to care'. Last thought: There will never be any psru that will be as light, reliable nor as cheap as a 12 pound, $500 new turbocharger. I am not kidding, they are very easy to plumb on flatheads, they don't stress engines, they function as mufflers, and 134 cid at 36" MAP is 200 cid of airflow. Look up the turbo testing on my webpage, email me direct or call anytime.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420053#420053 ________________________________________________________________________________
Date: Mar 09, 2014
Compression ratio increases can be impractical in a L head because cross se ction area reduction as the head gets shaved. The engine breathes less (int ake and exhaust) as the area get smaller. Therefore the more practical way to increase power is to compress the intake charge by super or turbo chargi ng as William suggests. Turbocharging has one danger in that hot exhaust ge ts compressed too and therefore the consequences of an exhaust leak increas e as a result. Just thoughts to ponder. > Subject: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? > From: WilliamTCA(at)aol.com > Date: Sun=2C 9 Mar 2014 14:48:54 -0700 > To: pietenpol-list(at)matronics.com > > > > Kenny=2C > I watched the Youtube clip several times=2C and I think you are doing so mething pretty neat. I have been a life long fan of flatheads=2C Grace and I have a little collection in the hangar. > > I read all the notes=2C and for my 2 cents=2C I think that you have a pow er plant that will work within limitations=2C (just as all engines do). I w as headed over to my neighbors with the scale=2C but Mr. Mdw=2C covered thi s=2C and effectively showed both the weight is comparable to a Ford=2C and also how unreliable internet data can be. I think most people miss that the re are both L-134's and OHV F-134's. Scale in a milk barn always beats the internet for useful data=2C > > Clif listed the displacements and rpm ranges of several engines=2C and to it I would like to add the consideration of compression ratio. We have bee n testing this for a year=2C back to back=2C same airframe=2C etc=2C and it is surprising the difference between 8.0 and 10.25 to one. The relationshi p holds true with most engines. I am sure that an O-200 with 8:1 and OHV ca n be tuned to make more power at any given rpm than a 200 cid Ford. Displac ement alone is an incomplete picture. > > On 'tight' motors: If everything else is set right=2C it is ring drag on the surface finish of the bores that makes it hard to prop. In my experienc e=2C 10 hours of ground runs at 50-60% power has the same smoothing effect as one takeoff and climb to 3=2C000' at wot. 280 finish on bores is better than 220=2C but it is time at wot that helps. > > An optical tach like a Proptach 2545 and a ground adjustable prop are a g ood 'comparative' Dyno. Get the prop in the test range=2C check the static rpm=2C make the change and compare rpm. I have loaner WD props=2C (in both rotations)=2C glad to send one to you for testing. > > If Oz's chart is good=2C targeting 3000 rpm instead of 2500 will buy you a 28% hp increase. The loss of prop efficiency will be in the single digits =2C and you will have a large net thrust increase. Test this with the loane r prop=2C you will become convinced. > > You will have plenty of people tell you it will/won't work. Their belief is based on stories=2C and since every Pietenpol is a 'snowflake' unto itse lf=2C much of the commentary does not apply. You should be able to use The Ford weight and Balance data we collected. My website tells how to get this directly from Doc Mosher. > > I do not think the success of Fords is because they make 'more than 50 hp ' The W&B tests showed that the Ford guys build lighter planes than many A -65 guys. The Ford guys also use better matched props on average. They go i nto their build knowing they don't have weight or power to waste. It is the opposite attitude of a guy who thinks 'I have a light motor=2C I don't hav e to care'. > > Last thought: There will never be any psru that will be as light=2C relia ble nor as cheap as a 12 pound=2C $500 new turbocharger. I am not kidding =2C they are very easy to plumb on flatheads=2C they don't stress engines =2C they function as mufflers=2C and 134 cid at 36" MAP is 200 cid of airfl ow. Look up the turbo testing on my webpage=2C email me direct or call anyt ime.-ww. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420053#420053 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 09, 2014
Amen. Dan Helsper Puryear, TN cc: Board of Curmudgeons -----Original Message----- From: Gary Boothe <gboothe5(at)comcast.net> Sent: Sun, Mar 9, 2014 1:28 pm Subject: RE: Pietenpol-List: Re: Which one? Then, there=99s this, from Grant MacLaren, circa 1999: Like many other modifications to an airplane's design -- one change requires many other changes. If a "new" biplane is designed, it will be jus t that -- a new design. It should not carry the name "Pietenpol." Pietenpols forever! -=Grant MacLaren=- Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Steven Dortch Sent: Sunday, March 09, 2014 10:56 AM Subject: Re: Pietenpol-List: Re: Which one? Bill, Just to muddy the water. I have a Pietenpol With plans that were modi fied by Grega. But it is not a Grega! It is a Pietenpol fuselage with mods that later became the Grega wing. I think. It is just enough hybrid that I cannot firmly tell you where the Grega mods definitely begin or end. Blue Skies, Steve D Pietenpol Air-Camper On Sun, Mar 9, 2014 at 11:39 AM, Bill Church wrote : > Glen, As mentioned, there are the original Pietenpol Air Camper plans, that were published in the 1932 Flying and Glider magazine, and which you have a copy of. Then there are the plans available from the Pietenpol family. http://community.pressenter.net/~apietenp/BHPietenpolAndSonsAirCamperAircra ftPurchasePlans.html In addition to these, there were a couple of different sets of plans for "m odernized" versions of the Air Camper that were sold. One set was the St. Croix Air Camper, and the other was the Grega GN-1 Aircamper. Neither of these are available for sale anymore. While some have built their aircraft strictly from the Flying and Glider pl ans, I believe it would be a real challenge to do so, since the reprints ar e so small, and are simply lacking some details. My recommendation would b e to obtain a set of the plans from the Pietenpol family, to complement th e Flying and Glider plans. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420038#420038 st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?Pietenpol-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 09, 2014
Brian, You are correct on the limits of compression increase on flatheads. The point I was trying to make is that Kenny's HP per cubic inch at 6.5:1 should be better than the Ford HP per cubic inch at 4.25 to 5.25:l. The limits for increasing on the Jeep may be higher still, as it has a wildly under square bore and stroke ratio. Manifolds on flatheads are on the same side and short, good for compact turbo installation. The exhaust pressure is less than you may suspect, the energy of the exhaust gasses is primarily heat. In an enclosed compartment always a concern, especially with a lot of joints, but I was kind of picturing it out in the slipstream. I am pretty sure someone brought a turbocharged Piet to Brodhead in the last decade, but I can't remember who it was. Part of the reason why I am optimistic about Kenny's project is thinking about A-37 and A-40 Continentals. They are flatheads also, they have less cubic inches. They are maybe 80 pounds lighter, but they did fly a lot of stuff like J-3s on floats with light people.-ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420056#420056 ________________________________________________________________________________
Date: Mar 09, 2014
Steve, Not sure I follow. You have a set of Pietenpol plans that John Grega modified? And your fuselage was modified to become a wing? :) There are a lot of homebuilts out there that were begun from a set of plans, and got modified along the way. For instance, from looking at old photos, back in the 60's it seemed to be a popular modification to add spill plates to the tips of Pietenpol wings. Since the practice did not continue, one can likely deduce that the modification did not improve performance. Likewise, it is also clear that the mod did not improve appearance either. It is pretty common with this design for buiilders to make changes. Some changes are very subtle, and others are not so subtle. it is quite possible that the original builder of your plane started with a set od Pietenpol plans, and incorporated selected details borrowed from the Grega plans. Bill C. > Bill, Just to muddy the water. I have a Pietenpol With plans that were modified by Grega. But it is not a Grega! It is a Pietenpol fuselage with mods that later became the Grega wing. I think. It is just enough hybrid that I cannot firmly tell you where the Grega mods definitely begin or end. > > Blue Skies, > > Steve D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420057#420057 ________________________________________________________________________________
Date: Mar 09, 2014
Bill, *The logbook on my Piet says it is a "Pietenpol aircamper......in accordance with the original drawings as amended by John w. Grega to include...." forward section of the fuselage is extended 6 inches for the different motor (Grega drawing). Wing built in 3 sections *( *the air foil looks like a Pietenpol)with a 9.5 gallon gas tank in upper wing. also the Right gear is J3 cub. Left gear was fabricated to match (a Grega idea). * *The Fuselage follows the Pietenpol plans by Orrin Hoopman. The bolts attaching the Cabanes to the Fuselage runs right to left like the Pietenpol plans. The bolts attaching the cabanes to the wing run from front to rear and attach a 3 piece wing with a wing tank, A la Grega. . * *Sorry if I don't get to join the club. But everyone already calls me a Bastard;+}* *Blue Skies,* *Steve D.* On Sun, Mar 9, 2014 at 6:39 PM, Bill Church wrote: > billspiet(at)sympatico.ca> > > Steve, > Not sure I follow. You have a set of Pietenpol plans that John Grega > modified? And your fuselage was modified to become a wing? :) > There are a lot of homebuilts out there that were begun from a set of > plans, and got modified along the way. For instance, from looking at old > photos, back in the 60's it seemed to be a popular modification to add > spill plates to the tips of Pietenpol wings. Since the practice did not > continue, one can likely deduce that the modification did not improve > performance. Likewise, it is also clear that the mod did not improve > appearance either. It is pretty common with this design for buiilders to > make changes. Some changes are very subtle, and others are not so subtle. > it is quite possible that the original builder of your plane started with > a set od Pietenpol plans, and incorporated selected details borrowed from > the Grega plans. > > Bill C. > > > > Bill, Just to muddy the water. I have a Pietenpol With plans that were > modified by Grega. But it is not a Grega! It is a Pietenpol fuselage with > mods that later became the Grega wing. I think. It is just enough hybrid > that I cannot firmly tell you where the Grega mods definitely begin or end. > > > > Blue Skies, > > > > Steve D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420057#420057 > > ________________________________________________________________________________
Date: Mar 09, 2014
So, Steve, it sounds like you have an example of what I was referring to - A plane built using the Pietenpol plans, with selected modifications (in this case, borrowed from the GN-1). Good that the original builder chose to retain the original fuselage design , as the Grega modifications (added plywood sheathing unnecessarily added weight to the aft fuselage structure. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420059#420059 ________________________________________________________________________________
Date: Mar 09, 2014
Steve; I think you can run two quick DNA tests to check for paternity. 1. Can the angle of the cabanes be changed; i.e., if there were no cabane brace struts or cables, can the wing physically be pivoted forward or aft by changing the angle of the cabanes? If the answer is 'no', Mr. Pietenpol is not the father. 2. Do the landing gear leg attach points meet the lower longerons at the wing strut attach points, both forward and aft? If the answer is 'no', Mr. Pietenpol is not the father. If you're still holding out a thread of hope, you can try one last check but it's not definitive: are the tailwheel control cables connected to the bottom of the rudder using brackets on the rudder rather than running forward to the rudder bar? Grega connected them in that fashion but others have used the same method in the interest of eliminating a second set of control cables the length of the empennage. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420060#420060 ________________________________________________________________________________
Date: Mar 09, 2014
Biggest drawback to the Grega mod is that the wing cannot be moved fore and aft to help with CG. The Three piece wing makes it handy to work on here in the garage. I like the Wing tank as well. It is what I have. Several of the old pilots at 8T8 say who have flown it say it flies really well. Blue Skies Steve D. On Sun, Mar 9, 2014 at 8:06 PM, Bill Church wrote: > billspiet(at)sympatico.ca> > > So, Steve, it sounds like you have an example of what I was referring to - > A plane built using the Pietenpol plans, with selected modifications (in > this case, borrowed from the GN-1). Good that the original builder chose > to retain the original fuselage design , as the Grega modifications (added > plywood sheathing unnecessarily added weight to the aft fuselage structure. > > Bill C. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420059#420059 > > ________________________________________________________________________________
Date: Mar 09, 2014
1. Can the angle of the cabanes be changed; i.e., if there were no cabane brace struts or cables, can the wing physically be pivoted forward or aft by changing the angle of the cabanes? If the answer is 'no', Mr. Pietenpol is not the father. NO, but the bottoms would pivot fore and aft. the tops pivot port and starboard. Hybrid. 2. Do the landing gear leg attach points meet the lower longerons at the wing strut attach points, both forward and aft? If the answer is 'no', Mr. Pietenpol is not the father. YES, They do. but the Logbook confesses that they are Cub gear. 3. Are the tailwheel control cables connected to the bottom of the rudder using brackets on the rudder rather than running forward to the rudder bar? NO, the cables go to the rudder on top. There was no steering on the tailwheel until John K put it on. It now has a Cessna tailwheel and we still have to finish putting in Pulleys and such to complete the tail steering. Blue Skies, Steve D On Sun, Mar 9, 2014 at 8:14 PM, taildrags wrote: > > Steve; > > I think you can run two quick DNA tests to check for paternity. > > 1. Can the angle of the cabanes be changed; i.e., if there were no cabane > brace struts or cables, can the wing physically be pivoted forward or aft > by changing the angle of the cabanes? If the answer is 'no', Mr. Pietenpol > is not the father. > > 2. Do the landing gear leg attach points meet the lower longerons at the > wing strut attach points, both forward and aft? If the answer is 'no', Mr. > Pietenpol is not the father. > > If you're still holding out a thread of hope, you can try one last check > but it's not definitive: are the tailwheel control cables connected to the > bottom of the rudder using brackets on the rudder rather than running > forward to the rudder bar? Grega connected them in that fashion but others > have used the same method in the interest of eliminating a second set of > control cables the length of the empennage. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420060#420060 > > ________________________________________________________________________________
Date: Mar 09, 2014
I think Frank L. from the Milwaukee area put a turbo or supercharger on hi s Funk? engine. You are probably correct that the exhaust pressure may not be that high but there is still the concern that the exhaust piping and fla nges need to be made carefully as most factory turbos are piped with alloy tubing and rightfully so. I personally would not want to fly in a turbo eng ine aircraft in a tight cowled aircraft with homemade exhaust piping and m aybe not even with factory piping because a crack could/would mean a fire. That is just my fear limitation. Flat heads are not that much of a penalty on a slow turning engines and why auto engines don't need overhead cams in direct drive applications on airp lanes. The point I was making that to go more power the right direction is to pressurize the intake not to modify it internally. Don't take my comments as a challenge to your knowledge but really to vali date what you said and to educate others that might not be so acquainted w ith the all the limitations. I confess that I don't know much about the engine in question. What will th e increased rpm and/or power do to the bottom engine or to the breathing of the engine? I think it has a chance=2C the question more relates to wheth er the end result is a one or two seater. > Subject: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? > From: WilliamTCA(at)aol.com > Date: Sun=2C 9 Mar 2014 16:38:56 -0700 > To: pietenpol-list(at)matronics.com > > > > Brian=2C > You are correct on the limits of compression increase on flatheads. The p oint I was trying to make is that Kenny's HP per cubic inch at 6.5:1 should be better than the Ford HP per cubic inch at 4.25 to 5.25:l. The limits f or increasing on the Jeep may be higher still=2C as it has a wildly under s quare bore and stroke ratio. > > Manifolds on flatheads are on the same side and short=2C good for compact turbo installation. The exhaust pressure is less than you may suspect=2C t he energy of the exhaust gasses is primarily heat. In an enclosed compartme nt always a concern=2C especially with a lot of joints=2C but I was kind of picturing it out in the slipstream. I am pretty sure someone brought a tur bocharged Piet to Brodhead in the last decade=2C but I can't remember who i t was. > > Part of the reason why I am optimistic about Kenny's project is thinking about A-37 and A-40 Continentals. They are flatheads also=2C they have less cubic inches. They are maybe 80 pounds lighter=2C but they did fly a lot o f stuff like J-3s on floats with light people.-ww > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420056#420056 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 09, 2014
This is my take on this debate. Anyone that is building an aircraft like th e one we are all interested has much in common. Debating on the originality of a particular design is counter productive as all it does is subdivide a small group into even smaller groups. I hate when people appear to act sup erior because they think they are more authentic or more pure. I know it is human nature but it is stupid. We should embrace all that is Pietenpol-lik e and in doing so we are all better off and that allows us to educate all i n all the ways of doing this and let them decide what is the best way to d o something rather than being shamed into like it is some form of Victorian racism. Come on people don't be so judgemental=2C Bernie Pietenpol certai nly wasn't! I might be reading this wrong and that might not be the intention but if I am taking it that way than so are others! Date: Sun=2C 9 Mar 2014 20:32:10 -0500 Subject: Re: Pietenpol-List: Re: Which one? From: steven.d.dortch(at)gmail.com 1. Can the angle of the cabanes be changed=3B i.e.=2C if there were no =0A cabane brace struts or cables=2C can the wing physically be pivoted =0A forward or aft by changing the angle of the cabanes? If the answer is =0A 'no'=2C Mr. Pietenpol is not the father. NO=2C but the bottoms would pivot fore and aft. the tops pivot port and sta rboard. Hybrid. 2. Do the landing gear leg attach points meet the lower longerons at the=0A wing strut attach points=2C both forward and aft? If the answer is 'no' =2C=0A Mr. Pietenpol is not the father. YES=2C They do. but the Logbook confesses that they are Cub gear. 3. Are the tailwheel control cables connected to the bottom of the rudder =0A using brackets on the rudder rather than running forward to the rudder =0A bar? NO=2C the cables go to the rudder on top. There was no steering on the tail wheel until John K put it on. It now has a Cessna tailwheel and we still ha ve to finish putting in Pulleys and such to complete the tail steering. =0A Blue Skies=2C Steve D =0A On Sun=2C Mar 9=2C 2014 at 8:14 PM=2C taildrags wro te: =0A =0A =0A =0A Steve=3B =0A =0A I think you can run two quick DNA tests to check for paternity. =0A =0A 1. Can the angle of the cabanes be changed=3B i.e.=2C if there were no caba ne brace struts or cables=2C can the wing physically be pivoted forward or aft by changing the angle of the cabanes? If the answer is 'no'=2C Mr. Pie tenpol is not the father. =0A =0A =0A 2. Do the landing gear leg attach points meet the lower longerons at the wi ng strut attach points=2C both forward and aft? If the answer is 'no'=2C M r. Pietenpol is not the father. =0A =0A If you're still holding out a thread of hope=2C you can try one last check but it's not definitive: are the tailwheel control cables connected to the bottom of the rudder using brackets on the rudder rather than running forwa rd to the rudder bar? Grega connected them in that fashion but others have used the same method in the interest of eliminating a second set of contro l cables the length of the empennage. =0A =0A =0A -------- =0A Oscar Zuniga =0A Medford=2C OR =0A Air Camper NX41CC "Scout" =0A A75 power =0A =0A =0A =0A =0A Read this topic online here: =0A =0A http://forums.matronics.com/viewtopic.php?p=420060#420060 =0A =0A =0A =0A =0A =0A =0A =0A =0A st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List =0A =0A http://forums.matronics.com =0A =0A le=2C List Admin. =0A ="_blank">http://www.matronics.com/contribution =0A =0A =0A =0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Subject: Re: Fuselage Width
Date: Mar 09, 2014
Tomorrow it may get to 60 degrees here. I am hoping to begin to glue the fuse sides together. I looked at a lot of pictures on westcoastpiet and it appears people start all over the place. I think the front two connectors are not put into place because of the addition of the engine mount later? Some add the 3/8's plywood floor before adding the additional connectors while others add the connectors first then lay the flooring on top. What should I not do when connecting the fuselage together that would cause problems later? Thanks, John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420065#420065 ________________________________________________________________________________
Date: Mar 09, 2014
One "hot" setup on a Go-Devil Jeep (circa 1960) was Dual carbs compression raised to 7.5 to 1 with Hickey Head bored to 141 cubic inches. reground camshaft with proper timing and lift, and improved headers (20-25% HP increase) These mods were available at one time (1970s) but I am not sure you could find them now. Blue Skies, Steve On Sun, Mar 9, 2014 at 8:36 PM, Brian Kenney wrote: > I think Frank L. from the Milwaukee area put a turbo or supercharger on > his Funk? engine. You are probably correct that the exhaust pressure may > not be that high but there is still the concern that the exhaust piping and > flanges need to be made carefully as most factory turbos are piped with > alloy tubing and rightfully so. I personally would not want to fly in a > turbo engine aircraft in a tight cowled aircraft with homemade exhaust > piping and maybe not even with factory piping because a crack could/would > mean a fire. That is just my fear limitation. > > Flat heads are not that much of a penalty on a slow turning engines and > why auto engines don't need overhead cams in direct drive applications on > airplanes. The point I was making that to go more power the right direction > is to pressurize the intake not to modify it internally. > > Don't take my comments as a challenge to your knowledge but really to > validate what you said and to educate others that might not be so > acquainted with the all the limitations. > > I confess that I don't know much about the engine in question. What will > the increased rpm and/or power do to the bottom engine or to the breathing > of the engine? I think it has a chance, the question more relates to > whether the end result is a one or two seater. > > > > Subject: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? > > From: WilliamTCA(at)aol.com > > Date: Sun, 9 Mar 2014 16:38:56 -0700 > > > To: pietenpol-list(at)matronics.com > > > WilliamTCA(at)aol.com> > > > > Brian, > > You are correct on the limits of compression increase on flatheads. The > point I was trying to make is that Kenny's HP per cubic inch at 6.5:1 > should be better than the Ford HP per cubic inch at 4.25 to 5.25:l. The > limits for increasing on the Jeep may be higher still, as it has a wildly > under square bore and stroke ratio. > > > > Manifolds on flatheads are on the same side and short, good for compact > turbo installation. The exhaust pressure is less than you may suspect, the > energy of the exhaust gasses is primarily heat. In an enclosed compartment > always a concern, especially with a lot of joints, but I was kind of > picturing it out in the slipstream. I am pretty sure someone brought a > turbocharged Piet to Brodhead in the last decade, but I can't remember who > it was. > > > > Part of the reason why I am optimistic about Kenny's project is thinking > about A-37 and A-40 Continentals. They are flatheads also, they have less > cubic inches. They are maybe 80 pounds lighter, but they did fly a lot of > stuff like J-3s on floats with light people.-ww > > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=420056#420056 > > > > > > > > > > > > ============= > > > > > > > > * > > > * > > ________________________________________________________________________________
Subject: DNA analysis please
From: "M. Zeke Zechini" <marcus.zechini(at)gmail.com>
Date: Mar 09, 2014
I think I have GN-1. The wings are clipped Cub (aluminum ribs). Was built by Bob Odegaard in 1991. Started life with A65, now has C-85-12. Still swingin g same 74x41 McCauley. Will try to get it to Brodhed this year. About to replace Cub legs, as I am covering a new set. Certainly am enjoying flying it! Sent from my iPad
Date: Mar 09, 2014
Just to clear the Air, I am not taking any of this personally. This Pietenpol Air-Camper (I use a dash since it is a bastard according to Oscar;+}) was built from the mid 1960s and flew in 1975. It flew for about 20 years and by all accounts flew quite well. It is going to be resurrected. My apologies to the Piet Purists, but I am not going to Go back and rebuilt the cabanes, wing and struts to make this legitimate. Oscar has seen this plane and his memory must be shorter than his.....Grandmother. I guess at any Pietenpol gathering I will have to land on the back runway and will have to use the back door to get something to eat. But I am OK with that. I guess I am like that bastard cousin that just won't go away =) Blue Skies, Steve D On Sun, Mar 9, 2014 at 8:52 PM, Brian Kenney wrote: > This is my take on this debate. Anyone that is building an aircraft like > the one we are all interested has much in common. Debating on the > originality of a particular design is counter productive as all it does is > subdivide a small group into even smaller groups. I hate when people appear > to act superior because they think they are more authentic or more pure. I > know it is human nature but it is stupid. We should embrace all that is > Pietenpol-like and in doing so we are all better off and that allows us to > educate all in all the ways of doing this and let them decide what is the > best way to do something rather than being shamed into like it is some form > of Victorian racism. Come on people don't be so judgemental, Bernie > Pietenpol certainly wasn't! > > I might be reading this wrong and that might not be the intention but if I > am taking it that way than so are others! > > > ------------------------------ > Date: Sun, 9 Mar 2014 20:32:10 -0500 > Subject: Re: Pietenpol-List: Re: Which one? > From: steven.d.dortch(at)gmail.com > To: pietenpol-list(at)matronics.com > > > 1. Can the angle of the cabanes be changed; i.e., if there were no cabane > brace struts or cables, can the wing physically be pivoted forward or aft > by changing the angle of the cabanes? If the answer is 'no', Mr. Pietenpol > is not the father. > > NO, but the bottoms would pivot fore and aft. the tops pivot port and > starboard. Hybrid. > > 2. Do the landing gear leg attach points meet the lower longerons at the > wing strut attach points, both forward and aft? If the answer is 'no', Mr. > Pietenpol is not the father. > > YES, They do. but the Logbook confesses that they are Cub gear. > > 3. Are the tailwheel control cables connected to the bottom of the rudder > using brackets on the rudder rather than running forward to the rudder > bar? > > NO, the cables go to the rudder on top. There was no steering on the > tailwheel until John K put it on. It now has a Cessna tailwheel and we > still have to finish putting in Pulleys and such to complete the tail > steering. > > Blue Skies, > Steve D > > > On Sun, Mar 9, 2014 at 8:14 PM, taildrags wrote: > > > Steve; > > I think you can run two quick DNA tests to check for paternity. > > 1. Can the angle of the cabanes be changed; i.e., if there were no cabane > brace struts or cables, can the wing physically be pivoted forward or aft > by changing the angle of the cabanes? If the answer is 'no', Mr. Pietenpol > is not the father. > > 2. Do the landing gear leg attach points meet the lower longerons at the > wing strut attach points, both forward and aft? If the answer is 'no', Mr. > Pietenpol is not the father. > > If you're still holding out a thread of hope, you can try one last check > but it's not definitive: are the tailwheel control cables connected to the > bottom of the rudder using brackets on the rudder rather than running > forward to the rudder bar? Grega connected them in that fashion but others > have used the same method in the interest of eliminating a second set of > control cables the length of the empennage. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420060#420060 > > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > ========== > st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List > ========== > http://forums.matronics.com > ========== > ="_blank">http://www.matronics.com/contribution > ========== > > * > > * > > > * > > ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: Re: DNA analysis please
Date: Mar 10, 2014
Looks like a Piet to me. When you're flying it, what does it look like from the cockpit. If it looks like, feels like, and flies like fun, then I call it fun. That's MY test=85 ;) -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine From: "M. Zeke Zechini" <marcus.zechini(at)gmail.com<mailto:marcus.zechini(at)gma il.com>> >" > Date: Sunday, March 9, 2014 9:05 PM etenpol-list(at)matronics.com> Subject: Pietenpol-List: DNA analysis please I think I have GN-1. The wings are clipped Cub (aluminum ribs). Was built b y Bob Odegaard in 1991. Started life with A65, now has C-85-12. Still swing ing same 74x41 McCauley. Will try to get it to Brodhed this year. About to replace Cub legs, as I am covering a new set. Certainly am enjoyin g flying it! [cid:e1842e0b-fc5f-47a7-a304-ef9006fcef05(at)Enterprise.emory.net] ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 09, 2014
Looks neat. My only complaint is it gets fuzzy when I zoom in. What advantage to covering the legs? Less drag or just looks? Steve On Sun, Mar 9, 2014 at 9:05 PM, M. Zeke Zechini wrote: > > I think I have GN-1. The wings are clipped Cub (aluminum ribs). Was built > by Bob Odegaard in 1991. Started life with A65, now has C-85-12. Still > swinging same 74x41 McCauley. Will try to get it to Brodhed this year. > About to replace Cub legs, as I am covering a new set. Certainly am > enjoying flying it! > > > Sent from my iPad >
      > http://www.matronics.com/Navigator?Pietenpol-List>
      > http://forums.matronics.com>
      > http://www.matronics.com/contribution>
Date: Mar 09, 2014
Russian GAZ (a Soviet Competitor to the post WWII jeep) is still being made and uses a 4 calendar diesel with a supercharger. I saw them in Iraq. Everything on them broke but the tough little engine, tranny brakes and steering. Blue Skies, Steve D On Sun, Mar 9, 2014 at 9:01 PM, Steven Dortch wrote: > One "hot" setup on a Go-Devil Jeep (circa 1960) was > > Dual carbs > > compression raised to 7.5 to 1 with Hickey Head > > bored to 141 cubic inches. > > reground camshaft with proper timing and lift, > > and improved headers (20-25% HP increase) > > > These mods were available at one time (1970s) but I am not sure you could > find them now. > > > Blue Skies, > > Steve > > > On Sun, Mar 9, 2014 at 8:36 PM, Brian Kenney wrote: > >> I think Frank L. from the Milwaukee area put a turbo or supercharger on >> his Funk? engine. You are probably correct that the exhaust pressure may >> not be that high but there is still the concern that the exhaust piping and >> flanges need to be made carefully as most factory turbos are piped with >> alloy tubing and rightfully so. I personally would not want to fly in a >> turbo engine aircraft in a tight cowled aircraft with homemade exhaust >> piping and maybe not even with factory piping because a crack could/would >> mean a fire. That is just my fear limitation. >> >> Flat heads are not that much of a penalty on a slow turning engines and >> why auto engines don't need overhead cams in direct drive applications on >> airplanes. The point I was making that to go more power the right direction >> is to pressurize the intake not to modify it internally. >> >> Don't take my comments as a challenge to your knowledge but really to >> validate what you said and to educate others that might not be so >> acquainted with the all the limitations. >> >> I confess that I don't know much about the engine in question. What will >> the increased rpm and/or power do to the bottom engine or to the breathing >> of the engine? I think it has a chance, the question more relates to >> whether the end result is a one or two seater. >> >> >> >> > Subject: Pietenpol-List: Re: Willys jeep pietenpol engine maybe? >> > From: WilliamTCA(at)aol.com >> > Date: Sun, 9 Mar 2014 16:38:56 -0700 >> >> > To: pietenpol-list(at)matronics.com >> > >> WilliamTCA(at)aol.com> >> > >> > Brian, >> > You are correct on the limits of compression increase on flatheads. The >> point I was trying to make is that Kenny's HP per cubic inch at 6.5:1 >> should be better than the Ford HP per cubic inch at 4.25 to 5.25:l. The >> limits for increasing on the Jeep may be higher still, as it has a wildly >> under square bore and stroke ratio. >> > >> > Manifolds on flatheads are on the same side and short, good for compact >> turbo installation. The exhaust pressure is less than you may suspect, the >> energy of the exhaust gasses is primarily heat. In an enclosed compartment >> always a concern, especially with a lot of joints, but I was kind of >> picturing it out in the slipstream. I am pretty sure someone brought a >> turbocharged Piet to Brodhead in the last decade, but I can't remember who >> it was. >> > >> > Part of the reason why I am optimistic about Kenny's project is >> thinking about A-37 and A-40 Continentals. They are flatheads also, they >> have less cubic inches. They are maybe 80 pounds lighter, but they did fly >> a lot of stuff like J-3s on floats with light people.-ww >> >> > >> > >> > >> > >> > Read this topic online here: >> > >> >
http://forums.matronics.com/viewtopic.php?p=420056#420056 >> > >> > >> > >> > >> > >> > ============= >> > >> > >> > >> >> * >> >> >> * >> >> > ________________________________________________________________________________
Date: Mar 09, 2014
Subject: Re: Vasek's production of Historic Propellers
Vasic, just a thot. The Russians made a copy of the Ford Model AA truck. It used a Ford model a Engine. They made 985,000 of them up until 1950. perhaps you could find one of them. Steve D On Mon, Mar 3, 2014 at 11:45 AM, Vasek wrote: > > Thank you for the nice words, I very appreciate it. I can post photos of > some of our interesting projects if you wish. We will have a four-blade > propeller from R.E.8 soon in the "old style" and a big beautiful Chauvier e > prop from D.H.1. > > > > Perhaps your Piet should have some styling to remind us of a pre WWII > Avia or Letov. > > > It definitely could have! Do you have any suggestions? > > > > Are there any old Waltor Minor engines floating around? they are > somewhat comparable to at Contental O200 while about 30 pounds heavier. > > > Yes, I think that I could find some, but I have a feedback from a guy who > had GN-1 that the Walter was too weak. He replaced it with Subaru with a > reduction drive. > > > > There is no reason that you could not break into the Prop or > construction business. > > > The question is, would people be interested in these carved propellers? I > mean, airworthy? Such a prop would be at least three times more expensive > than it is now. > > -------- > My production of WW1 propellers, trophies and constructions: > =88=BC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=419726#419726 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 09, 2014
Subject: Re: Piet parts for sale
I forgot to answer your second question. Which is yes I do have the diagonal bracing. ~Brian Durham 425-971-5968 On Mar 7, 2014 12:57 AM, "Timothy Willis" wrote: > Brian, > > I am interested in your cowl. Please give me your phone # in a direct > reply and let's discuss. Do you have a nose bowl as well? > > Also, do you have diagonal cabanes (from top motor mount to wing attach > points)? > > Tim in central TX > ================== > > Subject: Pietenpol-List: Piet Wings for Sale + Other Parts > From: "N219BR" <briankdurham(at)gmail.com> > > Hi All, > > I acquired a Piet that's taking up valuable space right now. I'm looking > at parting > it out. I have an A-65 mount/cowl, 3 piece wings, cub gear, fittings, and > 1.5 Corvair cores, plus lots of assorted odds and ends. > > * > > > * > > ________________________________________________________________________________
Date: Mar 09, 2014
Hi Tim, Seems to be a lot of Piet builders in Texas. I don't have the metal eyebrows that mount to the engine. What I have is the nose bowl and top cowl...or at least that's what I think it is, now that I think of it is made of a heavy fabric material. But it has piano hinge on the sides. I'll get some better pictures and perhaps you can help me identify it. Here's some pictures I currently have. My phone number is 425-971-5968. ~Brian Durham 425-971-5968 On Mar 7, 2014 12:57 AM, "Timothy Willis" wrote: > Brian, > > I am interested in your cowl. Please give me your phone # in a direct > reply and let's discuss. Do you have a nose bowl as well? > > Also, do you have diagonal cabanes (from top motor mount to wing attach > points)? > > Tim in central TX > ================== > > Subject: Pietenpol-List: Piet Wings for Sale + Other Parts > From: "N219BR" <briankdurham(at)gmail.com> > > Hi All, > > I acquired a Piet that's taking up valuable space right now. I'm looking > at parting > it out. I have an A-65 mount/cowl, 3 piece wings, cub gear, fittings, and > 1.5 Corvair cores, plus lots of assorted odds and ends. > > * > > > * > > ________________________________________________________________________________
Subject: Re: Corvair engine core
Date: Mar 09, 2014
Bill, Glad you are headed to Corvair college #29. If you have not landed an engine core yet, here is a tool that you may not have seen before. In 10 minutes of looking with it I found this lead 155 miles from your house in Greenville SC: 1966 4 door corvair, auto matic, for parts or restore, cant text pictures 864-915-6395 The site is http://www.searchtempest.com/. (You can find it by goggling "Search Tempest Craigslist") It is a search engine that looks on all the Craigslists for you in any specified radius from your home zip code. I have used it to find all kinds of stuff, I have found it more productive than Ebay or Corsa. Email me privately if you have not found a core before the college.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420075#420075 ________________________________________________________________________________
Date: Mar 09, 2014
The landing gear/lower wing strut fittings look like GN-1 fittings. The rear landing gear attachment is forward of the rear cabain which is common on a GN-1 but not on the Pietenpol. What is not typical of a GN-1 is the rear wing strut attaching to the rear gear location. I'm guessing that this makes your wing struts are not parallel. Mr. Grega recommended using a Cub wing and landing gear on the GN-1. The attachment for the rudder cables are below the stabilizer which is where the GN-1 mounting point is. Most of the other differences between a GN-1 and a Pietenpol are in the metal fittings and the fully sheeted fuselage. Both of which cannot be seen in the picture. My guess though is this is a GN-1. This whole conversation about TRUE Pietenpols comes up frequently. I think what really irritates the purists is to call all the various look-a-likes a Pietenpol. Be true to the design and call it a GN-1 which is inspired by the Pietenpol. But in the end it really doesn't matter what it is as long as you like it. And it sounds like you do. Chris -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of M. Zeke Zechini Sent: Sunday, March 09, 2014 7:05 PM Subject: Pietenpol-List: DNA analysis please I think I have GN-1. The wings are clipped Cub (aluminum ribs). Was built by Bob Odegaard in 1991. Started life with A65, now has C-85-12. Still swinging same 74x41 McCauley. Will try to get it to Brodhed this year. About to replace Cub legs, as I am covering a new set. Certainly am enjoying flying it! ________________________________________________________________________________
Date: Mar 10, 2014
I do enjoy!! I noticed a lot of Piets have brace from firewall to top of front cabane. I do not, AND I have a passenger door. I will have to see where GN-1s differ in extra plywood & check mine. I have a set of plans. I have a extra rib from Michael Brusilow's Mr. Sam. Just may build one day. Need to be retired, though. -Zeke On Mon, Mar 10, 2014 at 12:26 AM, Chris wrote: > > The landing gear/lower wing strut fittings look like GN-1 fittings. The > rear landing gear attachment is forward of the rear cabain which is common > on a GN-1 but not on the Pietenpol. What is not typical of a GN-1 is the > rear wing strut attaching to the rear gear location. I'm guessing that this > makes your wing struts are not parallel. Mr. Grega recommended using a Cub > wing and landing gear on the GN-1. The attachment for the rudder cables are > below the stabilizer which is where the GN-1 mounting point is. Most of > the > other differences between a GN-1 and a Pietenpol are in the metal fittings > and the fully sheeted fuselage. Both of which cannot be seen in the > picture. My guess though is this is a GN-1. > > This whole conversation about TRUE Pietenpols comes up frequently. I think > what really irritates the purists is to call all the various look-a-likes a > Pietenpol. Be true to the design and call it a GN-1 which is inspired by > the > Pietenpol. But in the end it really doesn't matter what it is as long as > you like it. And it sounds like you do. > > Chris > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of M. Zeke > Zechini > Sent: Sunday, March 09, 2014 7:05 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: DNA analysis please > > > I think I have GN-1. The wings are clipped Cub (aluminum ribs). Was built > by > Bob Odegaard in 1991. Started life with A65, now has C-85-12. Still > swinging > same 74x41 McCauley. Will try to get it to Brodhed this year. > About to replace Cub legs, as I am covering a new set. Certainly am > enjoying > flying it! > > ________________________________________________________________________________
Subject: Re: Fuselage Width....Curmudeon/purist alert...scramble
to fill power vacuum
Date: Mar 10, 2014
John, Before you make a mistake you might regret forever, please check the plans, which call for 7/32" floor thickness. 3/8" would be overkill and add unnec essary weight. I myself would never deviate from the plans (unless the chan ges were really necessary or cool-looking) used 1/4" since that is what was available. There seems to be a real power vacuum on this list since the "resignation". I am sure it will all be sorted out in due time. Applications for the Boar d of Curmudgeons are still being accepted. But, in the end, the purists wil l prevail, as they rightly always do. Dan Helsper Puryear, TN -----Original Message----- From: john francis <Mrkringles(at)msn.com> Sent: Sun, Mar 9, 2014 9:00 pm Subject: Pietenpol-List: Re: Fuselage Width Tomorrow it may get to 60 degrees here. I am hoping to begin to glue the fu se sides together. I looked at a lot of pictures on westcoastpiet and it appe ars people start all over the place. I think the front two connectors are not put into place because of the addition of the engine mount later? Some add the 3/8's plywood floor before adding the additional connectors while others ad d the connectors first then lay the flooring on top. What should I not do when connecting the fuselage together that would cause problems later? Thanks, John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420065#420065 ________________________________________________________________________________
to fill
Date: Mar 10, 2014
Dan, Thank you very much for the Curmudgeon Alert. I would absolutely agree with you. Stick with 7/32" or the more common 1/4". I do, however, have a purist confession to make. I built my fuselage while I was in college. A friend gave me a fantastic deal on space in his hangar so I was able to build. When I got to the point of adding the floor to the fuselage I was really scraping pennies. I searched around and actually found a plywood importer in Baltimore that dealt with aircraft plywood at a great price. So I skipped classes one day and left at 4:00am on the 16 hour roundtrip drive to Baltimore in my old beat up Ford Escort. When I finally arrived (this was pre GPS and internet days) I went to the dock to pick up my beautiful sheet of 1/4" 4' x 8' mahogany plywood only to find that it was 3/8"! Well since I had spent the next several weeks of food money and rent on gas and plywood I couldn't possibly imagine wasting the trip. I went back to my car and did a quick calculation and found that by making the floor out of 3/8", I'd add about 5lbs to my Piet. After thinking it over for a while I decided it was worth it. So I tied the sheet of plywood to the roof and watched it slap my Escort for the next 8 hours. It only slid off once, while on the beltway around Washington D.C. Amazingly it wasn't damaged! So.... I now have to live with a 626 lb. Piet instead of a 621lb. Piet. Was the 5 lbs. worth it? Absolutely! I got to go back home and glue my floor on... and tell the story! Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420083#420083 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: crisp and clean Pietenpol purity...
Date: Mar 10, 2014
My $.02 on the whole purity issue is this. (not that anyone really cares) My hat is off, big time, to anyone with the gumption to finish a scratch-built stick and fabric airplane and actually FLY it successfully. It takes a unique person to accomplish such a goal, and there are fewer and fewer of them around in this country. I AM all about being smart in your decisions and modifications, but I still must respect the person the person's perseverance who actually finishes a plane EVEN if it's filled with bone-headed "improvements" and flies like crap and becomes a "Barnstormers.com queen". They weren't wise, but they actually DID something pretty hard to do. I don't respect their "common sense" but I certainly can respect the fact that they finished it. Just because of simple historicity, I think a plane should be labeled accurately. A Grega is a Grega, a Pietenpol is a Pietenpol, a combination of both is an "unnamed experimental" inspired by both. I do think we can start sounding pretty silly when we can't call a Pietenpol and Pietenpol because it uses motorcycle wheels rather than original Jenny wheels, or ply leading edges rather than oatmeal box cardboard scrounged from the dump at midnight. Douwe ________________________________________________________________________________
Date: Mar 10, 2014
Subject: Re: Which one?
"...This is my take on-this-debate. Anyone that is building an aircraft like the one we are all interested has much in common. Debating on the =0A originality of a particular design is counter productive as all it does =0A is subdivide a small group into-even smaller groups. I hate when people =0Aappear to act superior because they think they are more authentic or =0A more pure. I know it is human nature but it is stupid. We should embrace al l that is Pietenpol-like and in doing so we are all better off and =0Athat allows us to educate all in-all the ways--of doing this and let =0Ath em decide what is the best way to do something rather than being =0Ashamed into like it is some form of Victorian racism. Come on- people =0Adon't b e so judgemental, Bernie Pietenpol certainly wasn't!=0A-=0AI might be rea ding this wrong and that might not be the intention but if I am taking it t hat way than so are others!..."=0A=0A=0A=0AAmen.=0A-=0A=0AIf God is your co-pilot...switch seats.=0AMichael Perez=0APietenpol HINT Videos=0AKaretake r Aero=0Awww.karetakeraero.com=0A ________________________________________________________________________________
Date: Mar 10, 2014
Subject: Re: crisp and clean Pietenpol purity...
Douwe, I care! Blue Skies, Steve D Pieten-Grega Air-Camper ________________________________________________________________________________
Date: Mar 10, 2014
Michael, how about at any Piet gathering we line them up starting with an origional build by Mr. Pietenpol and as they change from his 1929 design we push them further down the line. At least until they start to look like Flybabys! Just having fun. I plan on calling mine a Pietenpol Air-Camper with Grega like "improvements" (I did that just to prod people) and flying it anyhow. I guess I will have to park in the back 40 where they drink Pabst Blue Ribbon and moonshine. Blue Skies, Steve D ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Mar 10, 2014
Hear, Hear, Douwe! I agree. As Larry Williams (ex Top Curmudgeon) once begrudgingly admitted "We're all Snowflakes!" Now enough discussion on this. If you have a flying Pietenpol (of whatever persuasion) go fly it now that the weather is finally becoming spring-like. If you are building one, then get into your shop and make some sawdust! I'm going to spend the day dragging all the crap that has accumulated in my hangar out of the way so I can get the Piet out and fly it today. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Monday, March 10, 2014 9:45 AM Subject: Pietenpol-List: crisp and clean Pietenpol purity... My $.02 on the whole purity issue is this. (not that anyone really cares) My hat is off, big time, to anyone with the gumption to finish a scratch-built stick and fabric airplane and actually FLY it successfully. It takes a unique person to accomplish such a goal, and there are fewer and fewer of them around in this country. I AM all about being smart in your decisions and modifications, but I still must respect the person the person's perseverance who actually finishes a plane EVEN if it's filled with bone-headed "improvements" and flies like crap and becomes a "Barnstormers.com queen". They weren't wise, but they actually DID something pretty hard to do. I don't respect their "common sense" but I certainly can respect the fact that they finished it. Just because of simple historicity, I think a plane should be labeled accurately. A Grega is a Grega, a Pietenpol is a Pietenpol, a combination of both is an "unnamed experimental" inspired by both. I do think we can start sounding pretty silly when we can't call a Pietenpol and Pietenpol because it uses motorcycle wheels rather than original Jenny wheels, or ply leading edges rather than oatmeal box cardboard scrounged from the dump at midnight. Douwe ________________________________________________________________________________
Date: Mar 10, 2014
Steve: I like PBR. Wil make room for some in front cockpit. G.O.B from Virginny, Zeke On Mon, Mar 10, 2014 at 10:37 AM, Steven Dortch wrote: > Michael, how about at any Piet gathering we line them up starting with an > origional build by Mr. Pietenpol and as they change from his 1929 design we > push them further down the line. At least until they start to look like > Flybabys! > > Just having fun. I plan on calling mine a Pietenpol Air-Camper with Grega > like "improvements" (I did that just to prod people) and flying it anyhow. > I guess I will have to park in the back 40 where they drink Pabst Blue > Ribbon and moonshine. > > Blue Skies, > Steve D > > * > > > * > > ________________________________________________________________________________
Date: Mar 10, 2014
Well said Douwe. How about those of us who elected to widen the fuselage ,or a different tail wheel. It still looks like a Piet and you can,t tell the 2 inch wider fiuse by looking at it. Gardiner Sent from my iPad On Mar 10, 2014, at 9:44 AM, "Douwe Blumberg" w rote: > My $.02 on the whole purity issue is this (not that anyone really cares) > > My hat is off, big time, to anyone with the gumption to finish a scratch-b uilt stick and fabric airplane and actually FLY it successfully. It takes a unique person to accomplish such a goal, and there are fewer and fewer of t hem around in this country. > > I AM all about being smart in your decisions and modifications, but I stil l must respect the person the person=99s perseverance who actually fin ishes a plane EVEN if it=99s filled with bone-headed =9Cimprovem ents=9D and flies like crap and becomes a =9CBarnstormers.com qu een=9D. They weren=99t wise, but they actually DID something pr etty hard to do. I don=99t respect their =9Ccommon sense=9D but I certainly can respect the fact that they finished it. > > Just because of simple historicity, I think a plane should be labeled accu rately. A Grega is a Grega, a Pietenpol is a Pietenpol, a combination of bo th is an =9Cunnamed experimental=9D inspired by both. > > I do think we can start sounding pretty silly when we can=99t call a Pietenpol and Pietenpol because it uses motorcycle wheels rather than origi nal Jenny wheels, or ply leading edges rather than oatmeal box cardboard scr ounged from the dump at midnight > > Douwe > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 10, 2014
Douwe, I admire your plane, your art and your thoughts. Let me add $.01 to the comments on people being persistent enough to finish a plane. To finish a plane, it is a requirement that a builder not listen to all the people who tell him he will fail or is doing things wrong. In a 6 year build this might mean ignoring several hundred people, mostly obviously playing the role of 'Eeyore', but others who pose as' friendly' advisors. Ignore every one of them, keep working, and the plane will get done. Is this the definition of successful homebuilding? I say it isn't. Completing the plane isn't success, learning is. A guy who listens to no one learns nothing and often creates the poor flying hangar queen you mention. His completed plane might be a rarity, but the mindset of not being willing to consider anything that might evolve one's views is quite common today. My definition of success is the guy who finishes the plane, ignores the 98% of the people who are negative, but learns from 4 or 5 trusted advisors who get him to consider things that make his plane far better than it would have been. This guy not only has a good flying plane, has learned a lot, he also has trusted friends and is in a position to share something. The actual rarity in society is not the bullheaded man who will not stop, it is the man wise enough to listen, examine evidence, and change his perspective if it improves what he is making. The biggest between a poor plane for sale on barnstormers with 2 hours on it and a great one sitting at Brodhead with 500 hours on the tach is mostly in the mindset of the builder. Both planes are made of roughly the same quantity of wood, metal and fabric, and the likely took about the same effort to build. The difference is mostly in what the builder was willing to learn. The barnstormer plane, and the dozens like it that were never completed are not a good use of materials nor human time. They are not art either. If I want art, I can study and be moved by the work of Douwe or Felix de Weldon.-ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420099#420099 ________________________________________________________________________________
Subject: Steel-tube fuselage update - landing gear
Date: Mar 10, 2014
Hello good Piet-ple, It was a LONG weekend in the shop and I thought I'd post a few photos of the progress. I am making the steel-tube Piet with the "improved" landing gear. I have jigged the axles and vee in place for the welder who will stop over on March 21st. I had seen some photos of landing gear that were made with a somewhat different cluster joint where the axle meets the vee. This allows me to use a conduit pipe to hold the axles in line while they are welded. I marked the location of the "fishmouth" cutout, drilled a series of small holes, then cut between the dots to remove the metal. I cleaned it up with an angle grinder until the axles fit. It was a long several days to get all these parts jigged and cut/fit - yet it's a nice feeling of satisfaction now that this step has been completed. Hope you all are doing well...... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420106#420106 Attachments: http://forums.matronics.com//files/landing_gear_a_856.jpg http://forums.matronics.com//files/landing_gear_b_189.jpg http://forums.matronics.com//files/landing_gear_c_696.jpg http://forums.matronics.com//files/landing_gear_d_470.jpg http://forums.matronics.com//files/landing_gear_e_702.jpg ________________________________________________________________________________
Subject: Re: Steel-tube fuselage update - landing gear
Date: Mar 10, 2014
Wow! Very nice work! -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420110#420110 ________________________________________________________________________________
Date: Mar 10, 2014
Looks really nice, Jake Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aerocarjake Sent: Monday, March 10, 2014 2:08 PM Subject: Pietenpol-List: Steel-tube fuselage update - landing gear Hello good Piet-ple, It was a LONG weekend in the shop and I thought I'd post a few photos of the progress. I am making the steel-tube Piet with the "improved" landing gear. I have jigged the axles and vee in place for the welder who will stop over on March 21st. I had seen some photos of landing gear that were made with a somewhat different cluster joint where the axle meets the vee. This allows me to use a conduit pipe to hold the axles in line while they are welded. I marked the location of the "fishmouth" cutout, drilled a series of small holes, then cut between the dots to remove the metal. I cleaned it up with an angle grinder until the axles fit. It was a long several days to get all these parts jigged and cut/fit - yet it's a nice feeling of satisfaction now that this step has been completed. Hope you all are doing well...... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420106#420106 Attachments: http://forums.matronics.com//files/landing_gear_a_856.jpg http://forums.matronics.com//files/landing_gear_b_189.jpg http://forums.matronics.com//files/landing_gear_c_696.jpg http://forums.matronics.com//files/landing_gear_d_470.jpg http://forums.matronics.com//files/landing_gear_e_702.jpg ________________________________________________________________________________
Date: Mar 10, 2014
Jake, You have a very nice looking fuselage, it certainly will make for a stout plane. Your photos caught my eye because I have Terry Hand's fuselage in my hangar getting the same task done. Terry's fuselage looks to be a pretty close clone of yours. It is hard to tell anything exact in a picture, but Terry's is a short fuselage right out of the F&G manual. I wanted to point out that during the Weight and Balance project we took the exact axle location of each plane. Most builders had given little thought to axle location, combining 1930s axle location with modern powerful brakes. In the article series we spent some effort to show that BHP's planes with brakes moved the axle well forward, to within 1/2" of the leading edge. His only later comment was that 0 to 3" behind the leading edge with the plane level was a good range. If you would like to get copies of the info before finish welding, read: http://flycorvair.net/2014/03/08/pietenpol-weight-and-balance-article-source/ Terry's plane came with a set of legs that would have put the axle 7.5" behind the leading edge. As he is planning on using 6x6 Cleveland hyd. drums off a Pacer, I opted to cut up the legs and scrap them, building new ones that moved the axle to BHP's recommended zone for Piets with brakes. Terry's gear is being finished with this kind of spring: http://flycorvair.net/2012/10/27/new-die-spring-landing-gear-on-a-pietenpol-10-a-m-4-p-m/ The data from the W&B project showed the reason why more Piets with strong brakes and aft axles don't end up on their backs: Many of the same planes have terrible aft CG conditions. At this point, your plane can easily have everything correct, there isn't any reason to have it other than BHP intended. Although I have seen the plans work countless times, most welding detail design manuals have better ways to attach the small thick wall tubes for the bolts to the main tubes. Look at AC-43-13 and particularly the EAA book on welding. They involve a better load path into the main tube. Powerful brakes and paved runways put a load on the attachments not envisioned in 1930.-ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420112#420112 ________________________________________________________________________________
Date: Mar 10, 2014
Thanks WW.... I met you briefly at OSH w/ Terry. He has been out to see my project several times. I did move the axles 3 1/2 inches forward because of your w&b articles. Sure would not want to do that as a retrofit later. I plan to have a bracket at the base of the bee at the axle which I have seen versions of on other similar birds. Thanks for the suggestions. I'll do some more research. I'd like my gear to be stout for any eventual "less than ideal" landings - ha! Thx..... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420113#420113 ________________________________________________________________________________
Date: Mar 10, 2014
Just went out and took a look at mine. The gear looks plenty forward. Cessna 120/140s had a metal strap modification to move the landing gear forward about 5 inches or so. It looked strange but dramatically reduced the noseover rate. Some would tweak the landing gear forward about 3 inches I have heard that on Stearman Biplanes they replace the stock brakes with Jeep (Yes WWII or CJ5) brakes. They were inefficient and as a result lowered the rate of noseovers. Blue Skies, Steve D On Mon, Mar 10, 2014 at 7:52 PM, aerocarjake wrote: > > > > Thanks WW.... I met you briefly at OSH w/ Terry. He has been out to see my > project several times. I did move the axles 3 1/2 inches forward because of > your w&b articles. Sure would not want to do that as a retrofit later. I > plan to have a bracket at the base of the bee at the axle which I have seen > versions of on other similar birds. > > Thanks for the suggestions. I'll do some more research. > > I'd like my gear to be stout for any eventual "less than ideal" landings - > ha! > > Thx..... > > -------- > Jake Schultz - curator, > Newport Way Air Museum (OK, it's just my home) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420113#420113 > > -- Blue Skies, Steve D ________________________________________________________________________________
to fill
Date: Mar 10, 2014
Sometimes : as they say , even a blind hog will find an acorn . Well I guess I found my acorn. I fretted about my sheet of 7/32 ply that I had paid a huge sum of dough for only to see that most builders use 1/4 on the floor. I finally said ,"the hell with it" and used it anyway. Now I find I am in good stead with powers of Curmudeondum. What a nice discovery! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420120#420120 ________________________________________________________________________________
Subject: looking to trade for a Pietenpol
Date: Mar 10, 2014
If you happen to have a flying Piet in the southern California area (or wit hin a few hundred miles of it) and want to trade for an LSA Pulsar 1 projec t that isn't flying yet but is fairly complete=2C you can check out this li nk: http://www.contactmagazine.com/Classifieds/Pulsar-1.html Oscar Zuniga Air Camper NX41CC "Scout" Medford=2C OR ________________________________________________________________________________
Subject: Re: Speaking of Doc...
Date: Mar 10, 2014
Kevin, here is one of my favorite moments with Doc: At Oshkosh 10 or 12 years ago, we are trying to drive in through the inner gate, but we don't have the right pass. Doc is at the wheel of his old Taurus wagon, and he tells me this will not be a problem. As we are in line, Doc explains that getting past the guards is a complex equation of speed, proximity and the right wave. You must drive in fast enough they will not stop you, but not so fast to alarm them; you must drive close enough to them that they are more concerned about taking a step back than getting a look for your pass; and you have to wave just so, so they feel socially obligated to return it, but you don't make solid eye contact. Each of these must be adjusted for the individual guards on hand taking in to account their age and fitness, the time of day, weather, angle of the sun, etc. With our particular point of entry the magic combination was about 12mph and 16 inches to the guard. Doc waved just so, and the woman awkwardly waved as she was stepping back, The two other guards waved as if some VIP they should have known just drove past. Doc looked straight ahead and we drove right in. When we were clear by 50 yards, Doc looked over at me with a smile and said just like Alec Guinness, "These aren't the droids your looking for." -ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420124#420124 ________________________________________________________________________________
Date: Mar 11, 2014
to fill
However, you cannot now park on the front row at the gatherings.! ;+} Blue Skies, Steve D On Mon, Mar 10, 2014 at 11:16 PM, aviken wrote: > > Sometimes : as they say , even a blind hog will find an acorn . Well I > guess I found my acorn. I fretted about my sheet of 7/32 ply that I had > paid a huge sum of dough for only to see that most builders use 1/4 on the > floor. I finally said ,"the hell with it" and used it anyway. Now I find I > am in good stead with powers of Curmudeondum. What a nice discovery! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420120#420120 > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 11, 2014
Yeah, he's the Jedi master. I look forward to having him control my mind at Brodhead this year. You had a link in your post, William, giving Doc's aviation background/biography. He's an impressive guy. -------- Kevin "Axel" Purtee Rebuilding NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420136#420136 ________________________________________________________________________________
to fill
Date: Mar 11, 2014
danhelsper(at)aol.com wrote: > John, > > Before you make a mistake you might regret forever, please check the plans, which call for 7/32" floor thickness. 3/8" would be overkill and add unnecessary weight. I myself would never deviate from the plans (unless the changes were really necessary or cool-looking) used 1/4" since that is what was available. > > There seems to be a real power vacuum on this list since the "resignation". I am sure it will all be sorted out in due time. Applications for the Board of Curmudgeons are still being accepted. But, in the end, the purists will prevail, as they rightly always do. > > Dan Helsper > Puryear, TN > > My bad. It was a long day and I have the 1/4 plywood in my shop. Dont even have a piece of 3/8th so I would of caught that. > > > > > -- -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420138#420138 ________________________________________________________________________________
Subject: Cross Braces
Date: Mar 11, 2014
I cant find these two cross braces on the plans. Can anyone enlighten me as to why they are there? -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420145#420145 Attachments: http://forums.matronics.com//files/image_2_204.jpeg ________________________________________________________________________________
Subject: Re: Cross Braces
Date: Mar 11, 2014
John look at the plan sheet labeled Drawing No. 1. (upper right corner) There are some detail drawings in the lower right corner of this sheet. Look at the one for the fire wall. You will see the upper one is for the engine tray and the lower is to back up the firewall to floor joint. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420150#420150 ________________________________________________________________________________
Date: Mar 11, 2014
Woops, I see you have two lower braces. I'm guessing the builder added another one because the lower one interferes with the lower engine mount fittings and has to be trimmed short of the side. This is what some would call a builder improvement............. but is likely not needed. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420152#420152 ________________________________________________________________________________
Subject: Took Jack's advice
Date: Mar 11, 2014
Hey all, I took Jack=92s advice and went flying today! Beautiful day, but windy. Coming right down the runway most of the time with the occasional odd gust. Decided to do five take offs and landings and call it a day. I=92m on a long asphalt runway so I=92d land right on the threshold, then get airborne again and land, so I could squeeze two in. All went well. One time, a gust got under a wing and that was great practice as I applied power and got things straightened out. So as Jack said, go fly or go make sawdust!! (in your Pietenpol, your Grega, your =BE scale Graham Lee Neurport, your 7/8th scale SE5, your RV whatever, or whatever you fly!! Go have fun!!!) Douwe ________________________________________________________________________________
Subject: my new article, need input
Date: Mar 11, 2014
Hey, Don't know if John'll publish it, but I feel compelled to write an article for the newsletter. Now that I've got a year-and-a-half of flying on Re-PIET, I thought I'd write an article about things I did that I like, things I did that I don't like and things I wish I had done. I know I asked this on the list a few years ago, but would you guys who are flying send me a list of things you like, don't like or wish you had done?? You can put it on the list or send them to me personally. I think this could be a handy thing for those still building. Thanks! Douwe douweblumberg(at)earthlink.net ________________________________________________________________________________
Subject: Re: my new article, need input
Date: Mar 11, 2014
What a great idea. A compilation of snowflakes! Really looking forward to i t. I'm currently putting together a bill of materials based on plans in Fly ing and Glider Manual. Thanks to all for the insjght regarding my "which one" question. The l ast thing I wanted to do was to cause controversy. Sorry to hit such a touc hy subject. I have decided that when I build, it will be kept as close to o riginal(later versions)as possible using modern covering and AN hardware. T his is as very time proven airplane you cant argue with success. Sent from my iPhone > On Mar 11, 2014, at 6:44 PM, "Douwe Blumberg" wrote: > > Hey, > > Don=99t know if John=99ll publish it, but I feel compelled to w rite an article for the newsletter. Now that I=99ve got a year-and-a- half of flying on Re-PIET, I thought I=99d write an article about thin gs I did that I like, things I did that I don=99t like and things I wi sh I had done. > > I know I asked this on the list a few years ago, but would you guys who ar e flying send me a list of things you like, don=99t like or wish you h ad done?? You can put it on the list or send them to me personally. I thin k this could be a handy thing for those still building. > > Thanks! > > Douwe > > douweblumberg(at)earthlink.net > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 12, 2014
It occurs to me that since it appears that that the only plans set currentl y available for sale new is for a 'real' Pietenpol, the whole issue is de f acto a nothing-burger. As to currently flying Piets and Piet-like-flying objects (PLFO?) - run whu t ya brung, as far as I'm concerned. And to the purists, please recall that almost an entire generation of curre nt Brodhead and Piet aficionados got their first (and sometimes only) Piet or PLFO ride with Kim Strickland in his ' gasp! ' Grega. Ah yes, it was a simpler time=85we held hands and sang kumbaya by the light of the campfire ' or around steaks at Flynn's. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine From: "glenschweizer(at)yahoo.com<mailto:glenschweizer(at)yahoo.com>" <glenschwei zer(at)yahoo.com> >" > Date: Tuesday, March 11, 2014 11:28 PM etenpol-list(at)matronics.com> Subject: Re: Pietenpol-List: my new article, need input What a great idea. A compilation of snowflakes! Really looking forward to it. I'm currently putting together a bill of materials based on plans in Flying and Glider Manual. Thanks to all for the insjght regarding my "which one" question. The last thing I wanted to do was to cause controversy. Sorry to hit such a t ouchy subject. I have decided that when I build, it will be kept as close to original(later versions)as possible using modern covering and AN hardwar e. This is as very time proven airplane you cant argue with success. Sent from my iPhone On Mar 11, 2014, at 6:44 PM, "Douwe Blumberg" > wrote: Hey, Don=92t know if John=92ll publish it, but I feel compelled to write an arti cle for the newsletter. Now that I=92ve got a year-and-a-half of flying on Re-PIET, I thought I=92d write an article about things I did that I like, things I did that I don=92t like and things I wish I had done. I know I asked this on the list a few years ago, but would you guys who are flying send me a list of things you like, don=92t like or wish you had don e?? You can put it on the list or send them to me personally. I think thi s could be a handy thing for those still building. Thanks! Douwe douweblumberg(at)earthlink.net D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D npol-List"">http://www.matronics.com/Navigator?Pietenpol-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 12, 2014
Oops, the little gray cells are getting worn ' It was Ken Stricker, not S trickland, who hopped all those rides in a Grega. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine From: "glenschweizer(at)yahoo.com<mailto:glenschweizer(at)yahoo.com>" <glenschwei zer(at)yahoo.com> >" > Date: Tuesday, March 11, 2014 11:28 PM etenpol-list(at)matronics.com> Subject: Re: Pietenpol-List: my new article, need input What a great idea. A compilation of snowflakes! Really looking forward to it. I'm currently putting together a bill of materials based on plans in Flying and Glider Manual. Thanks to all for the insjght regarding my "which one" question. The last thing I wanted to do was to cause controversy. Sorry to hit such a t ouchy subject. I have decided that when I build, it will be kept as close to original(later versions)as possible using modern covering and AN hardwar e. This is as very time proven airplane you cant argue with success. Sent from my iPhone On Mar 11, 2014, at 6:44 PM, "Douwe Blumberg" > wrote: Hey, Don=92t know if John=92ll publish it, but I feel compelled to write an arti cle for the newsletter. Now that I=92ve got a year-and-a-half of flying on Re-PIET, I thought I=92d write an article about things I did that I like, things I did that I don=92t like and things I wish I had done. I know I asked this on the list a few years ago, but would you guys who are flying send me a list of things you like, don=92t like or wish you had don e?? You can put it on the list or send them to me personally. I think thi s could be a handy thing for those still building. Thanks! Douwe douweblumberg(at)earthlink.net D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D npol-List"">http://www.matronics.com/Navigator?Pietenpol-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 12, 2014
Glen, just a thot, Have you thought about Oratex? it advertises in the flying mags. It is precolored cloth that does not need painting. It is UV resistant and better than Icecream. The website implies that it makes childbirth a pleasure and conception a miracle. If you used it you simply pick your color fabric and cover the plane. Just a thot, Mine is already covered. Blue Skies, Steve D On Tue, Mar 11, 2014 at 11:28 PM, wrote: > What a great idea. A compilation of snowflakes! Really looking forward > to it. I'm currently putting together a bill of materials based on plans > in Flying and Glider Manual. > Thanks to all for the insjght regarding my "which one" question. > The last thing I wanted to do was to cause controversy. Sorry to hit such > a touchy subject. I have decided that when I build, it will be kept as > close to original(later versions)as possible using modern covering and AN > hardware. This is as very time proven airplane you cant argue with success. > Sent from my iPhone > > On Mar 11, 2014, at 6:44 PM, "Douwe Blumberg" > wrote: > > Hey, > > > Don't know if John'll publish it, but I feel compelled to write an article > for the newsletter. Now that I've got a year-and-a-half of flying on > Re-PIET, I thought I'd write an article about things I did that I like, > things I did that I don't like and things I wish I had done. > > > I know I asked this on the list a few years ago, but would you guys who > are flying send me a list of things you like, don't like or wish you had > done?? You can put it on the list or send them to me personally. I think > this could be a handy thing for those still building. > > > Thanks! > > > Douwe > > > douweblumberg(at)earthlink.net > > * > > D============================================ > npol-List"">http://www.matronics.com/Navigator?Pietenpol-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > > * > > * > > > * > > -- Blue Skies, Steve D ________________________________________________________________________________
Date: Mar 11, 2014
I have barely heard of Oratex. Can't be better than my ice cream ! My gela to is damned good too. I will look into it. Does it get rib stitched? I w as thinking on the lines of Dacron and (gulp,here we go again) latex.oh no I said the L word. Back in my ultra lite days I had real good luck with it i t was quite repairable held up great in Nevada sun looked really good(like p oly tone). And cheap. I hope that the curmudgeons don't curse me but the t hought of using dope hasn't occurred to me since the seventies. Way to flam mable for my liking. Have you used the Oratex System? Could actually be co st effective will check it out. Thanks Sent from my iPhone > On Mar 11, 2014, at 10:01 PM, Steven Dortch wr ote: > > Glen, just a thot, Have you thought about Oratex? it advertises in the fly ing mags. It is precolored cloth that does not need painting. It is UV resis tant and better than Icecream. > > The website implies that it makes childbirth a pleasure and conception a m iracle. > > If you used it you simply pick your color fabric and cover the plane. > > Just a thot, Mine is already covered. > Blue Skies, > Steve D > > >> On Tue, Mar 11, 2014 at 11:28 PM, wrote: >> What a great idea. A compilation of snowflakes! Really looking forward t o it. I'm currently putting together a bill of materials based on plans in Flying and Glider Manual. >> Thanks to all for the insjght regarding my "which one" question. T he last thing I wanted to do was to cause controversy. Sorry to hit such a t ouchy subject. I have decided that when I build, it will be kept as close t o original(later versions)as possible using modern covering and AN hardware. This is as very time proven airplane you cant argue with success. >> Sent from my iPhone >> >>> On Mar 11, 2014, at 6:44 PM, "Douwe Blumberg" wrote: >>> >>> Hey, >>> >>> >>> >>> Don=99t know if John=99ll publish it, but I feel compelled t o write an article for the newsletter. Now that I=99ve got a year-and -a-half of flying on Re-PIET, I thought I=99d write an article about t hings I did that I like, things I did that I don=99t like and things I wish I had done. >>> >>> >>> >>> I know I asked this on the list a few years ago, but would you guys who a re flying send me a list of things you like, don=99t like or wish you h ad done?? You can put it on the list or send them to me personally. I thin k this could be a handy thing for those still building. >>> >>> >>> >>> Thanks! >>> >>> >>> >>> Douwe >>> >>> >>> >>> douweblumberg(at)earthlink.net >>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> npol-List"">http://www.matronics.com/Navigator?Pietenpol-List >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> //forums.matronics.com >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> ot;">http://www.matronics.com/contribution >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> >> >> >> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > > -- > Blue Skies, > Steve D > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Pietenpol refrence page
Date: Mar 11, 2014
Pieten-people, If builders and fans have not had a chance to see it, I have a single page on my main site where all of our Piet and BHP stories are collected. It is at this link: http://flycorvair.net/2013/11/28/corvair-pietenpol-reference-page/ It is not all Corvair stuff, it has information on the life and influence of BHP, Cabanes and fuel lines, Weight and Balance, mount construction, landing gear design, props, cooling, box spars, etc. There are 34 separate stories there, a few hundred photos. I like Corvairs, but I am not a zealot about them. I am glad to provide information to any builder, I don't care what has or will power his plane. I have many happy hours behind All manner of Continentals and Lycomings, Radials from PW, Warner, Wright and the Russians, even Olds and Chevy V-8s....(But never a Rotax 912)... We even own a Schweizer 1-26 that has no motor at all. If you are a Continental or Ford guy our two webpages still have info you can use. http://www.flycorvair.com/ has pages on carbs, thrust and HP testing, FI and props. http://flycorvair.net/ has nearly 500 stories, many on instrumentation, wiring, flight tests, books and more. Plenty of things to learn there, even if we have nothing for you to buy.-ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420168#420168 ________________________________________________________________________________
Date: Mar 12, 2014
It appears to be a lot lighter too. Another "Simplicate and add lightness." possibility. Maybe even close to helium filled ping pong balls. Clif The one thing I am most afraid of is a new idea. Chairman Mao I have barely heard of Oratex. Can't be better than my ice cream ! My gelato is damned good too. Thanks Sent from my iPhone ________________________________________________________________________________
Date: Mar 12, 2014
See the "shelf" detail under "constructional view of front of fuselage". It calls for an 1 1/4" x 1 1/2" Ash top motor mount bearing brace and a 3/4" square Spruce lower floor board brace. Sorry for the picture size, but it better to read at this scale. Enjoy the journey! .... WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420173#420173 ________________________________________________________________________________
Date: Mar 12, 2014
Thanks for the responses and I do see them on the prints. However, with a Corvair engine, I believe these are modified because of the mounts. I just need to know how. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420174#420174 ________________________________________________________________________________
Date: Mar 12, 2014
You did not mention Corvair engine. ;) WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420176#420176 ________________________________________________________________________________
Date: Mar 12, 2014
John, The corvair doesn't change much, if anything, especially if you use the WW mount. One thing I am very glad I did (stole the idea from Jim Boyer), was to glue some "firewall placement dowels" in the x-piece supports (that's why they are longer than plans). That piece of plywood must have come off and on at least 100 times! After final attachment, just cut the dowels flush and install the firewall metal. If you don't have a forward fuel tank, you can use the x-piece as a support for a forward baggage. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of john francis Sent: Wednesday, March 12, 2014 4:55 AM Subject: Pietenpol-List: Re: Cross Braces --> Thanks for the responses and I do see them on the prints. However, with a Corvair engine, I believe these are modified because of the mounts. I just need to know how. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420174#420174 ________________________________________________________________________________
Date: Mar 12, 2014
Gary, Thanks, the picture explains a lot. Did you build the top crosspiece as the plans suggest and notch it to fit around the front strut? That I cant see in the picture. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420179#420179 Attachments: http://forums.matronics.com//files/crosspiece_147.jpg ________________________________________________________________________________
Date: Mar 12, 2014
Helium works good in tires Sent from my iPhone > On Mar 12, 2014, at 12:39 AM, "Clif Dawson" wrote: > > It appears to be a lot lighter too. > > Another "Simplicate and add lightness." > possibility. > > Maybe even close to helium filled ping pong > balls. > > Clif > > The one thing I am most afraid of is a new idea. > Chairman Mao > I have barely heard of Oratex. Can't be better than my ice cream ! My ge lato is damned good too. Thanks > > Sent from my iPhone > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 12, 2014
No. that is done as extra support for the Model A engine. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of john francis Sent: Wednesday, March 12, 2014 5:45 AM Subject: Pietenpol-List: Re: Cross Braces --> Gary, Thanks, the picture explains a lot. Did you build the top crosspiece as the plans suggest and notch it to fit around the front strut? That I cant see in the picture. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420179#420179 Attachments: http://forums.matronics.com//files/crosspiece_147.jpg ________________________________________________________________________________
From: "Boatright, Jeffrey" <jeffboatright(at)emory.edu>
Subject: Re: Pietenpol refrence page
Date: Mar 12, 2014
Thanks for the resource, William! -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/12/14 2:20 AM, "William Wynne" wrote: > >Pieten-people, > >If builders and fans have not had a chance to see it, I have a single >page on my main site where all of our Piet and BHP stories are collected. >It is at this link: > >http://flycorvair.net/2013/11/28/corvair-pietenpol-reference-page/ > >It is not all Corvair stuff, it has information on the life and influence >of BHP, Cabanes and fuel lines, Weight and Balance, mount construction, >landing gear design, props, cooling, box spars, etc. There are 34 >separate stories there, a few hundred photos. > >I like Corvairs, but I am not a zealot about them. I am glad to provide >information to any builder, I don't care what has or will power his >plane. I have many happy hours behind All manner of Continentals and >Lycomings, Radials from PW, Warner, Wright and the Russians, even Olds >and Chevy V-8s....(But never a Rotax 912)... We even own a Schweizer >1-26 that has no motor at all. > >If you are a Continental or Ford guy our two webpages still have info you >can use. http://www.flycorvair.com/ has pages on carbs, thrust and HP >testing, FI and props. http://flycorvair.net/ has nearly 500 stories, >many on instrumentation, wiring, flight tests, books and more. Plenty of >things to learn there, even if we have nothing for you to buy.-ww > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=420168#420168 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 12, 2014
John, To add to what Gary and others have said; As pointed out, the strength of the cross brace in the original plans is because it is the aft end of the motor mount bearers. This was common in the'20s, look at how an OX-5 is in a jenny (it is kind of imbedded in the fuselage but it is on bearers) Fast forward to the 1960s and look at BHP's original Corvair mount. At first glance it is an odd structural design, but looking at it, the purpose emerges as a retrofit to existing fuselage construction. It has two large steel main tubes that are taking the function of the ash bearers. BHP's Corvair mount is also tied into the cross brace that forms the bottom of the shelf. The mounts we build today are different. Here is a view of one of our mounts on the same airframe, Mark Chouinard's, that was used as your original picture: http://flycorvair.net/2013/10/17/pietenpol-mount-on-airframe/ On a modern build, the cross brace has much lower load on it, and it can be made light, as in Gary's photos. However, I want everyone to understand that the plywood firewall must now go all the way to the top of the upper longerons (or higher) because it stabilizes them against the slight load they get pulling them together. I have flown a modern mount on our Piet with a low firewall and shelf (Our plane was originally Ford powered) without thinking about it much, but I went back later and raised the firewall to full height and put a 1"x1" cross brace on it just below the top longerons to stiffen it . Gary's plane has the thrust line in the stock location, which also mimics the Ford installation. This is required on a BHP Corvair conversion, because he retained the blower fan. A modern electric start Corvair can have the thrust line moved up 3" without getting into the top cowl. This was tested on our Piet in 1999. The modern mounts we make in our fixture all come this way. I have hand built a few with the original low line for guys like Bob Lester, who was trying to fit an original cowl, but all the ones you see on projects like Mark Chouinard's, Kevin Purtee's, Dave Aldrich's, Jim Boyer's and Terry Hand's are all high thrust line mounts. There is some pretty good photos covering thrust lines and axle location at this link: http://flycorvair.net/2012/11/08/pietenpol-products-motor-mounts-gear-and-instalation-components/ -ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420193#420193 ________________________________________________________________________________
Date: Mar 12, 2014
Thanks William, nice to have you on the list. John -------- John Francis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420196#420196 ________________________________________________________________________________
Date: Mar 12, 2014
Picture of Mark Chouinard Piet and his Corvair motor mount ... may help. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420199#420199 ________________________________________________________________________________
Date: Mar 12, 2014
Picture of Mark Chouinard Piet and his Corvair motor mount ... may help. Your braces almost look the same. WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420200#420200 ________________________________________________________________________________
Date: Mar 12, 2014
Another 'aha' moment for me! Looking at the pix of Pieten-Vairs, I now see the difference between the thrust line using the BHP engine mount and the modern mount. Essentially, if the Corvair valve covers are more or less in line with the top longerons, it's a modern mount. If they are below it, then it's a BHP mount (designed to accommodate the top blower). I have a BHP mount sitting in my hangar and will have to take a closer look at it next time I'm out there. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420201#420201 ________________________________________________________________________________
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com>
Date: Mar 12, 2014
Steve, I am, indeed, thinking about Oratex. I think it looks good and is a strong as you know what. Contact Lars at betteraircraftfabric.com and he will send a free sample in the color(s) you want. I know it is not Irish linen. Or even Dacron, but it is an interesting product. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420203#420203 ________________________________________________________________________________
Date: Mar 12, 2014
Subject: Welding Question
Hey Pietsters, Is it OK to weld a stainless steel bolt to a 4130 bushing using TIG with stainless 316 filler rod? This is for the Contrex tach sensor bracket that WW recommends. Thanks, John Franklin GN-1 / Corvair 164cid Prairie Aire 4TA0 Needville, TX ________________________________________________________________________________
Subject: It's been 85 years, ya know....
Date: Mar 12, 2014
Just kicking around and idea.... In '09, for the 80th anniversary of the "Air Camper" several of us flew as a group to Oshkosh. We made a humble little statement that Pietenpols and their builders are alive and well. Overall it was a success and created a lot of memories for a lot of people. I also believe it kick started several builds. I think any design that has endured like the Pietenpol design has deserves to be recognized at least every 5 years. Any interest out there in doing something similar to what we did in '09? It was also done in '99 and '89. Maybe it's a little premature to think about doing it again, but every 10 years just seems like a long time to put together a little Oshkosh celebration. What has worked in the past has been to congregate at Brodhead for the regular Piet fly-in then gather together and fly en mass to Oshkosh on Sunday morning. There would have to be lots of cooperation with the OSH tower and EAA folks. They'd have to want to recognize the 85th Year Anniversary to make it really cool. In the past we've had a few "ins" when it came to dealing with those folks. What do all the flyers or organizers think about this? I sure had a Piet-load of fun in '09. Besides one of my sweet kids dropped and broke my mug that I got for flying in there. I need to get another one... Don Emch NX899DE P.S. It's okay to shoot the idea down... won't hurt my feelings. :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420212#420212 ________________________________________________________________________________
Date: Mar 12, 2014
Great idea. I wish I had mine ready to participate. Not until next year. Pe rhaps I will be able to attend the 90th . . . Lorenzo > Subject: Pietenpol-List: It's been 85 years=2C ya know.... > From: EmchAir(at)aol.com > Date: Wed=2C 12 Mar 2014 12:02:51 -0700 > To: pietenpol-list(at)matronics.com > > > Just kicking around and idea.... > > In '09=2C for the 80th anniversary of the "Air Camper" several of us flew as a group to Oshkosh. We made a humble little statement that Pietenpols and their builders are alive and well. Overall it was a success and create d a lot of memories for a lot of people. I also believe it kick started se veral builds. I think any design that has endured like the Pietenpol desig n has deserves to be recognized at least every 5 years. > > Any interest out there in doing something similar to what we did in '09? It was also done in '99 and '89. Maybe it's a little premature to think a bout doing it again=2C but every 10 years just seems like a long time to pu t together a little Oshkosh celebration. What has worked in the past has b een to congregate at Brodhead for the regular Piet fly-in then gather toget her and fly en mass to Oshkosh on Sunday morning. There would have to be l ots of cooperation with the OSH tower and EAA folks. They'd have to want t o recognize the 85th Year Anniversary to make it really cool. In the past we've had a few "ins" when it came to dealing with those folks. > > What do all the flyers or organizers think about this? I sure had a Piet -load of fun in '09. Besides one of my sweet kids dropped and broke my mug that I got for flying in there. I need to get another one... > > Don Emch > NX899DE > > P.S. It's okay to shoot the idea down... won't hurt my feelings. :) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420212#420212 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: It's been 85 years, ya know....
Date: Mar 12, 2014
I have been slowly getting all my systems in place to finally fly my Piet up to Brodhead. I am on the fence about OSH, but if others want to go in a gaggle, I'm in! As to cooperation with OSH organizers, I'd love to see it. At one point the powers that be were wringing their hands about declining numbers of "antique" planes attending. I pointed out to them that they cannot expect antique planes to flock to a venue that forces them to operate with modern strictures such as hard-surface runways and ignoring crosswinds. Our planes and their cohorts were designed at a time when most "airports" were simply open fields. All landings were done into the wind and on grass. I can land on hard surfaces, but for what we are all about, the obvious choice is Pioneer Airfield. Also, wouldn't it be cool to have a bunch of Piets parked around Bernard's old hangar? Those comments were sent in '09, after some kerfuffles with the Piets being forced to land on hard surfaces in challenging winds. So far I haven't gotten a response. -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/12/14 3:02 PM, "Don Emch" wrote: > >Just kicking around and idea.... > >In '09, for the 80th anniversary of the "Air Camper" several of us flew >as a group to Oshkosh. We made a humble little statement that Pietenpols >and their builders are alive and well. Overall it was a success and >created a lot of memories for a lot of people. I also believe it kick >started several builds. I think any design that has endured like the >Pietenpol design has deserves to be recognized at least every 5 years. > >Any interest out there in doing something similar to what we did in '09? >It was also done in '99 and '89. Maybe it's a little premature to think >about doing it again, but every 10 years just seems like a long time to >put together a little Oshkosh celebration. What has worked in the past >has been to congregate at Brodhead for the regular Piet fly-in then >gather together and fly en mass to Oshkosh on Sunday morning. There >would have to be lots of cooperation with the OSH tower and EAA folks. >They'd have to want to recognize the 85th Year Anniversary to make it >really cool. In the past we've had a few "ins" when it came to dealing >with those folks. > >What do all the flyers or organizers think about this? I sure had a >Piet-load of fun in '09. Besides one of my sweet kids dropped and broke >my mug that I got for flying in there. I need to get another one... > >Don Emch >NX899DE > >P.S. It's okay to shoot the idea down... won't hurt my feelings. :) > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=420212#420212 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 12, 2014
Jeff, I landed on the hard surface with a stupid stiff crosswind at OSH that year. many of the guys in the gaggle lined up on the runway and then in the last hundred feet or so just side stepped over and landed on the grass beside the runway. As far as I know nothing was ever said to them. Flying in there in a gaggle does ease a little of the stress and might be a good opportunity for those wanting to get their chance to go to the big show. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420219#420219 ________________________________________________________________________________
Date: Mar 12, 2014
I would love to do that! Hoping to have mine done for the 90th Tho' -------- Earl Brown I may not have gone where I intended to go, but I think I have ended up where I intended to be. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420221#420221 ________________________________________________________________________________
Date: Mar 12, 2014
I've got a few in's with Oshkosh organizers, would be happy to do what I can. Piet's hangar is probably out do to Kidventure, which takes Pioneer field out with it. An EARLY arrival is probably the best plan, weather and traffic wise. Would be happy to host an evening event here in Oshkosh in the firehouse. I've got a great meeting area that could easily hold 20 to 30 people, and if there's more, I'll just open the whole place. For folks that fly in, we could set a meeting place and I'll pick up as many as I can in the old 1929 LaFrance fire truck! If there were at least 5 or 6 planes, I imagine we could try to get them together, would be fun to have a old Ford car or truck parked with them! The EAA has an old T, would work if nothing else pans out. I could probably get the EAA's displays out of Bernie's hangar to put with the airplanes for the public's viewing pleasure, would make it more formal looking as a group. I'd even be happy to get a beer going for the event that we could tap that evening. What's the consensus on style? The firehouse is located at 6th and Main, probably two miles or so from the field. Half a dozen great bars and restaurants within walking distance. Google "Brooklyn Firehouse Oshkosh" to see it and find some pictures (from the real estate add, think they're still online) of the venue. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420222#420222 ________________________________________________________________________________
Date: Mar 12, 2014
As far as having an "in", and not to put anybody on the spot, but remember the story about Doc Mosher driving right past the gate guard to get in at OSH? What if Doc leads the gaggle? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420223#420223 ________________________________________________________________________________
Date: Mar 12, 2014
Boy, that sounds like a gaggle of even better ideas! One thing about OSH - you're never more than two blocks from a bar, once you get off the field. ;) As to the other, having been involved in organizing large conventions, I know that every decision is a compromise. But, it sure seems like a huge waste of Pioneer Airfield to have the helicopters and Kidventure shut it down to most other uses. Kidventure, if it's still held in a big tent, could really be anywhere there's a large field (like the OTHER side of the museum, or even in the big, old exhibits building that apparently isn't being used at all this year). And, obviously, helicopters can operate almost anywhere. I know, I know, there are probably a lot of domino effects that result in the current set up, but talk about a natural for antique planes. I don't really grock the purpose of Pioneer Airfield if it's not used at the association's premier event to promote...pioneering aviation! -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/12/14 4:07 PM, "tools" wrote: > >I've got a few in's with Oshkosh organizers, would be happy to do what I >can. > >Piet's hangar is probably out do to Kidventure, which takes Pioneer field >out with it. > >An EARLY arrival is probably the best plan, weather and traffic wise. >Would be happy to host an evening event here in Oshkosh in the firehouse. > I've got a great meeting area that could easily hold 20 to 30 people, >and if there's more, I'll just open the whole place. For folks that fly >in, we could set a meeting place and I'll pick up as many as I can in the >old 1929 LaFrance fire truck! > >If there were at least 5 or 6 planes, I imagine we could try to get them >together, would be fun to have a old Ford car or truck parked with them! >The EAA has an old T, would work if nothing else pans out. I could >probably get the EAA's displays out of Bernie's hangar to put with the >airplanes for the public's viewing pleasure, would make it more formal >looking as a group. > >I'd even be happy to get a beer going for the event that we could tap >that evening. What's the consensus on style? > >The firehouse is located at 6th and Main, probably two miles or so from >the field. Half a dozen great bars and restaurants within walking >distance. Google "Brooklyn Firehouse Oshkosh" to see it and find some >pictures (from the real estate add, think they're still online) of the >venue. > >Tools > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=420222#420222 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 12, 2014
In '09 we went the formal route and the EAA folks were involved in organizing the gaggle coming in and they promoted it in literature ahead of time. I'd be happy to organize something if I had the right people to talk to at OSH. The last time Bill Rewey was a key organizer and did a lot of the talking to EAA. That worked out really well. If we think we have enough interest I could go a step further and contact the EAA. but we'd have to have some real interest from the flyers. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420228#420228 ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" <michael.d.cuy(at)nasa.gov>
Subject: 85 years
Date: Mar 12, 2014
Between John Hoffman and Doc Mosher they have all the contacts at EAA any g roup could ever want to organize a gathering. I was involved with the 70 th & 80th gatherings and really the only thing you need is to confirm with EAA that they'll rese rve a place for everyone to park and a date and time of arrival. I have found that flying into Oshkosh is safer and more organized than any local flying I do at uncontrolled fiel ds by a long shot as a group or flying the Ripon/Fisk arrival. Don Emch gave a perfect option for landing on grass too next to the paved runways. Mike C. Ohio ________________________________________________________________________________
Date: Mar 12, 2014
If I can make to Brodhead, then I'm willing to commit to Oshkosh. I realize the former is the big "if" for a guy from Atlanta, but what can I say? The good Lord willing and the crick don't rise... -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/12/14 4:38 PM, "Don Emch" wrote: > >In '09 we went the formal route and the EAA folks were involved in >organizing the gaggle coming in and they promoted it in literature ahead >of time. I'd be happy to organize something if I had the right people to >talk to at OSH. The last time Bill Rewey was a key organizer and did a >lot of the talking to EAA. That worked out really well. If we think we >have enough interest I could go a step further and contact the EAA. but >we'd have to have some real interest from the flyers. > >Don Emch >NX899DE > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=420228#420228 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Re: 85 years
Date: Mar 12, 2014
You guys are making it tough for me to concentrate here at work! Now I'm ju st reading emails and trying to convince myself that nobody will notice if I sneak out to the airport for a quick evening flight=85 -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine From: <Cuy>, "LLC]" <michael.d.cuy(at)nasa.gov<mailto:michael.d.cuy(at)nasa.gov>> >" > Date: Wednesday, March 12, 2014 3:45 PM etenpol-list(at)matronics.com> Subject: Pietenpol-List: 85 years Between John Hoffman and Doc Mosher they have all the contacts at EAA any g roup could ever want to organize a gathering. I was involved with the 70 th & 80th gatherings and really the only thing you need is to confirm with EAA that they=92ll re serve a place for everyone to park and a date and time of arrival. I ha ve found that flying into Oshkosh is safer and more organized than any local flying I do at uncontrolled fiel ds by a long shot as a group or flying the Ripon/Fisk arrival. Don Emch gave a perfect option for landing on grass too next to the paved runways. Mike C. Ohio ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Re: Welding Question
Date: Mar 12, 2014
Use 309 http://www.lincolnelectric.com/en-us/support/welding-how-to/Pages/filler-met al-detail.aspx Sent from my iPhone On Mar 12, 2014, at 1:47 PM, John Franklin wrote: > > Hey Pietsters, > > Is it OK to weld a stainless steel bolt to a 4130 bushing using TIG with s tainless 316 filler rod? This is for the Contrex tach sensor bracket that W W recommends. > > Thanks, > John Franklin > GN-1 / Corvair 164cid > Prairie Aire 4TA0 > Needville, TX > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Mar 12, 2014
I like Tools' idea of a Piet fest at his place. Could be a good time for a bunch of Pietenpol guys. Leinenkugels for all my friends! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420239#420239 ________________________________________________________________________________
Date: Mar 12, 2014
Leiny's? I was gonna MAKE a keg... not the store bought stuff... Though Leiny's is good! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420247#420247 ________________________________________________________________________________
Date: Mar 12, 2014
Leiny's or "tooly's", I am in there, either way! -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420248#420248 ________________________________________________________________________________
Date: Mar 12, 2014
Pietenpolers, Two cents on a group fly in to Oshkosh: Last year we had a 'Corvair power' row reserved at Oshkosh. One of the best things about it was the EAA put it right behind my booth, which backed up right on the homebuilt flight line. Randy Bush's 500 hr Pietenpol was within 25' feet of my tent. This year my space is #616, in the same spot. While you could park the Piets anywhere between Warbirds and Aeroshell square, consider for a minute requesting a row behind my booth. While most companies just do business 9-5, we tend to run our place as a social operations base 6am-12pm. We have cookouts two nights, but all week we have electricity, shade, lawn chairs, coolers, food, tools, mechanics, welders, valuables storage, books, beach umbrellas, ground transportation, spare tie downs, water, computers, Cordless screwdrivers, emergency cash, a primo gate pass, a gas grill, Folding tables, funnels, heaters, an air-conditioner, tarps, beer, a service dog available for petting, a coffee pot, more beer and a trailer to hide in during rainstorms. The Weseman's are right next to us, and they bring even more stuff. Sovereign countries have started protracted wars with less equipment than we bring to Oshkosh. Having the row behind us allows us to keep an eye on planes. Last year during a squall we went out and doubled up everyone's tie downs. I can bring up stuff from Brodhead on Sunday that you may not want in the plane. A row near the Arch can mean not having a place to sit and every bottle of water setting you back $6. Our booth at Oshkosh basically costs $3,000 for the week, and our approach is to get every dollars worth of fun out of it. If it isn't forbidden in the fine print, we do it, If it is forbidden, I claim I never saw it, If I am reminded that I was reprimanded for doing it last year, I point out continuous exposure to 100LL causes amnesia. Mike, Mr.Tools or whomever would like to lead, my input is to get Charlie Becker and Doc Mosher in the loop, they are Luke and Obwan, and always have the right person to call to make things go smoothly. At Oshkosh, the force is with them. -ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420249#420249 ________________________________________________________________________________
Subject: West Coast Piet fly-in 2014
Date: Mar 12, 2014
So... is there an info page=2C or a "host"=2C or a common point of contact for the Frazier Lake event=2C or is this list the meeting place? I'm start ing to get a little more excited about the event since it has really starte d to be spring around here. We're supposed to be into the 70s for highs th is weekend and the days this week have been just beautiful. The pireps fro m you Pieters who have already ventured out of the hangar have also gotten my blood stirring. Just two things left to do before I fill the tank and pull the prop on Scou t=2C and those should happen this weekend. I've got my engine oil all read y for the oil change once I warm up the engine=2C and I dug out the headset and tangle of cords that goes with it. I'm on a controlled field=2C so fo r the past year or so I've had my little Icom IC-A23 on tower frequency any time I'm in the hangar so I can pick up the chatter and figure out what's w hat. Today I checked with the A&P who's going to do the condition inspecti on on the airplane and he's ready when Scout is. This will not be his firs t condition inspection on an Air Camper=2C but we'll see what he thinks whe n he peeks up Scout's skirt. I can already smell that engine exhaust as I run up the engine and taxi test to see how it handles with the Matco tailwh eel. So it's about 12 weeks till the fly-in. I'll need at least two more weeks to get odds and ends wrapped up=2C then another week for the inspection and another week to clear up squawks=2C so that leaves 8 weeks to get in the a ir and get comfortable before I run the Siskiyou Summit headed south. I've been reading up on how to fly a good test card to determine Vx and Vy and I want to do that during that time=2C too. I need to scale it back to Piet proportions though... most test cards out there are for planes that can cl imb thousands of feet in a reasonable amount of time=2C and they don't even start their test programs till they get to about 3000'. I would burn an a fternoon and a tank of fuel trying to do that! They also recommend using a stopwatch for the timed climbs. I'm going to use an hourglass =3Bo) I also need to make a 'For Sale' sign to hang on the plane at Frazier Lake. That's the plan=2C anyway. Oscar Zuniga Medford=2C OR Air Camper NX41CC "Scout" A75 power=2C Tennessee Props 72x36 prop ________________________________________________________________________________
Date: Mar 13, 2014
A service dog that fetches beer for me from someone else's cooler? Schuh-weet -- I'm there! Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine Sent from an iPad with a spelling problem > On Mar 12, 2014, at 11:38 PM, "William Wynne" wrote: > > > Pietenpolers, > > Two cents on a group fly in to Oshkosh: > > Last year we had a 'Corvair power' row reserved at Oshkosh. One of the best things about it was the EAA put it right behind my booth, which backed up right on the homebuilt flight line. Randy Bush's 500 hr Pietenpol was within 25' feet of my tent. This year my space is #616, in the same spot. While you could park the Piets anywhere between Warbirds and Aeroshell square, consider for a minute requesting a row behind my booth. > > While most companies just do business 9-5, we tend to run our place as a social operations base 6am-12pm. We have cookouts two nights, but all week we have electricity, shade, lawn chairs, coolers, food, tools, mechanics, welders, valuables storage, books, beach umbrellas, ground transportation, spare tie downs, water, computers, Cordless screwdrivers, emergency cash, a primo gate pass, a gas grill, Folding tables, funnels, heaters, an air-conditioner, tarps, beer, a service dog available for petting, a coffee pot, more beer and a trailer to hide in during rainstorms. The Weseman's are right next to us, and they bring even more stuff. Sovereign countries have started protracted wars with less equipment than we bring to Oshkosh. > > Having the row behind us allows us to keep an eye on planes. Last year during a squall we went out and doubled up everyone's tie downs. I can bring up stuff from Brodhead on Sunday that you may not want in the plane. A row near the Arch can mean not having a place to sit and every bottle of water setting you back $6. Our booth at Oshkosh basically costs $3,000 for the week, and our approach is to get every dollars worth of fun out of it. If it isn't forbidden in the fine print, we do it, If it is forbidden, I claim I never saw it, If I am reminded that I was reprimanded for doing it last year, I point out continuous exposure to 100LL causes amnesia. > > Mike, Mr.Tools or whomever would like to lead, my input is to get Charlie Becker and Doc Mosher in the loop, they are Luke and Obwan, and always have the right person to call to make things go smoothly. At Oshkosh, the force is with them. -ww > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420249#420249 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Date: Mar 12, 2014
Oscar Mike Groah is the point man for the fly-in. I heard from him the other day and he is working on this year's flyer. I'm sure info will be out soon. But really all you need to know is the date and where. That's about all there is to the details. Is a very low key affair. Chris T. Sacramento, Ca Westcoastpiet.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Wednesday, March 12, 2014 9:25 PM Subject: Pietenpol-List: West Coast Piet fly-in 2014 So... is there an info page, or a "host", or a common point of contact for the Frazier Lake event, or is this list the meeting place? I'm starting to get a little more excited about the event since it has really started to be spring around here. We're supposed to be into the 70s for highs this weekend and the days this week have been just beautiful. The pireps from you Pieters who have already ventured out of the hangar have also gotten my blood stirring. Just two things left to do before I fill the tank and pull the prop on Scout, and those should happen this weekend. I've got my engine oil all ready for the oil change once I warm up the engine, and I dug out the headset and tangle of cords that goes with it. I'm on a controlled field, so for the past year or so I've had my little Icom IC-A23 on tower frequency anytime I'm in the hangar so I can pick up the chatter and figure out what's what. Today I checked with the A&P who's going to do the condition inspection on the airplane and he's ready when Scout is. This will not be his first condition inspection on an Air Camper, but we'll see what he thinks when he peeks up Scout's skirt. I can already smell that engine exhaust as I run up the engine and taxi test to see how it handles with the Matco tailwheel. So it's about 12 weeks till the fly-in. I'll need at least two more weeks to get odds and ends wrapped up, then another week for the inspection and another week to clear up squawks, so that leaves 8 weeks to get in the air and get comfortable before I run the Siskiyou Summit headed south. I've been reading up on how to fly a good test card to determine Vx and Vy and I want to do that during that time, too. I need to scale it back to Piet proportions though... most test cards out there are for planes that can climb thousands of feet in a reasonable amount of time, and they don't even start their test programs till they get to about 3000'. I would burn an afternoon and a tank of fuel trying to do that! They also recommend using a stopwatch for the timed climbs. I'm going to use an hourglass ;o) I also need to make a 'For Sale' sign to hang on the plane at Frazier Lake. That's the plan, anyway. Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power, Tennessee Props 72x36 prop ________________________________________________________________________________
Date: Mar 13, 2014
Agreed, ER309L is you beat best for SS and 4130. If God is your co-pilot...switch seats. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: West Coast Piet fly-in 2014
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: Mar 13, 2014
Oscar, I also heard from Mike G last night. He was confirming the final details for the flyer. PIREP from Lancaster CA. I gave a couple of rides over the past weekend. On Saturday I took David Tracy, (yes Chris, your brother) and we flew for an hour or so with a bunch of fun stuff mixed in. dropping in on unsuspecting friends and such. It was great fun. then Sunday I took up another Dave and we flew for about 0.8 hours. Just flying around, no landing anywhere since he was so heavy. He admitted to 244lbs. He filled the whole front cockpit. He is the heaviest person I have taken for a ride. It was about 70 degrees out and my airfield is at 2347 MSL. The poor plane needed about 99% power to remain aloft. I think the next flight will just be me so I can remember what a joy it is to fly as a single seat plane. Gotta do that every now and then. Oscar, once you get to flying it again you may reconsider selling. Don't be surprised if you do. Cheers everyone and go flying, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420268#420268 ________________________________________________________________________________
From: "Jack Phillips" <jack(at)bedfordlandings.com>
Date: Mar 13, 2014
That's a nice offer, William. It would be great to have all the Pietenpols in a row on the flight line. Another contact that might be helpful is Jeff Gaulden, who usually handles homebuilt parking. He's a Pietenpol builder. In 2011 (the last time I flew my Piet to OSH), he parked me right by the "Brown Arch" leading to the flightline. I managed to take advantage of such a spot when Paul Poberezny showed up to present an award. After his presentation, I asked if he would autograph my airplane. He replied "I don't autograph airplanes. Which one is it?" I pointed it out to him and he smiled and said, "I'll autograph a Pietenpol". One of the proudest moments of my life. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of William Wynne Sent: Wednesday, March 12, 2014 11:36 PM Subject: Pietenpol-List: Re: 85 years Pietenpolers, Two cents on a group fly in to Oshkosh: Last year we had a 'Corvair power' row reserved at Oshkosh. One of the best things about it was the EAA put it right behind my booth, which backed up right on the homebuilt flight line. Randy Bush's 500 hr Pietenpol was within 25' feet of my tent. This year my space is #616, in the same spot. While you could park the Piets anywhere between Warbirds and Aeroshell square, consider for a minute requesting a row behind my booth. While most companies just do business 9-5, we tend to run our place as a social operations base 6am-12pm. We have cookouts two nights, but all week we have electricity, shade, lawn chairs, coolers, food, tools, mechanics, welders, valuables storage, books, beach umbrellas, ground transportation, spare tie downs, water, computers, Cordless screwdrivers, emergency cash, a primo gate pass, a gas grill, Folding tables, funnels, heaters, an air-conditioner, tarps, beer, a service dog available for petting, a coffee pot, more beer and a trailer to hide in during rainstorms. The Weseman's are right next to us, and they bring even more stuff. Sovereign countries have started protracted wars with less equipment than we bring to Oshkosh. Having the row behind us allows us to keep an eye on planes. Last year during a squall we went out and doubled up everyone's tie downs. I can bring up stuff from Brodhead on Sunday that you may not want in the plane. A row near the Arch can mean not having a place to sit and every bottle of water setting you back $6. Our booth at Oshkosh basically costs $3,000 for the week, and our approach is to get every dollars worth of fun out of it. If it isn't forbidden in the fine print, we do it, If it is forbidden, I claim I never saw it, If I am reminded that I was reprimanded for doing it last year, I point out continuous exposure to 100LL causes amnesia. Mike, Mr.Tools or whomever would like to lead, my input is to get Charlie Becker and Doc Mosher in the loop, they are Luke and Obwan, and always have the right person to call to make things go smoothly. At Oshkosh, the force is with them. -ww Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420249#420249 ________________________________________________________________________________
Date: Mar 13, 2014
Jeff, He is not quite that kind of a dog, he is much more likely to sit in your lap and help you finish your coffee when your not looking. He is very quiet at airshows, and most people never see him, but people who love animals pick him up on their radar, and spend a few minutes petting him. He is a stand in for companions left at home for a week. Many of these people are not Corvair nor experimental builders, just flyers and dog people. At Oshkosh 2013 a fantastically beautiful woman, reminiscent of Raquel Welch in '100 rifles' came in the booth and asked to pet the dog. She was dressed more for a day at the beach than one at a trade show. She sat in a chair with him and held him against her chest for 20 or 30 minutes while her husband was checking out turboprops at Dimetech. She rocked him and sang him a soft song. A bunch of Corvair guys on the other side of the tent had a hard time keeping mechanical trains of thought going. One of them finally said "In my next life I am coming back as a small dog." A friend of ours from California questioned he is a real 'service dog' and I showed him the paper work that originated with Grace's country doctor in our small FL town, stating the dog was anxiety relief. He scoffed, but I pointed out that the government in his home state of California has spent 10 years prescribing regulating and distributing marijuana to people for ailments like low self esteem. Our dog is a lot less harmful than that. To see pictures of Brodhead 2013 and our booth and plane row last year, get a look at this link: http://flycorvair.net/2013/08/12/brodhead-oshkosh-and-beyond-2013/ -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420271#420271 ________________________________________________________________________________
Subject: Pietenpol article---Smithsonian Air & Space Magazine from
2010
Date: Mar 13, 2014
Since winter has a tight grip on many of us still, here's a little armchair reading for those who might not have seen this article by the late and wonderful gentle man and aviation author Marshall Lumsden. http://www.airspacemag.com/history-of-flight/the-pride-of-cherry-grove-1044 0619/?no-ist [cid:image002.png(at)01CF3EA1.B273E430] [cid:image003.jpg(at)01CF3EA1.B273E430] ________________________________________________________________________________
Date: Mar 13, 2014
You mention beer twice and sang the Navy mantra (better to beg forgiveness...). I'm in! Let me know if I can help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420274#420274 ________________________________________________________________________________
Date: Mar 13, 2014
William, That sounds great. Thanks for the offer to set up a ground support! At this point we are starting to get the ball rolling with some of the EAA folks to find out about doing a mass arrival. Again, the only way it would really work is if we actually have a "mass". I wonder if the EAA might be willing to either set up a tent or loan out some of their Piet stuff for William's area and there could be a Pietenpol display. Maybe we could corral a couple of knowledgable volunteers to stand post for a few shifts to spread the Pietenpol cheer. Just some ideas.... Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420277#420277 ________________________________________________________________________________
Date: Mar 13, 2014
I won't flying in a Pietenpol, but I will be flying in midweek for 3 days or so. Happy to help in any way. Just let me know. -------- Semper Fi, Terry Hand Athens, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420278#420278 ________________________________________________________________________________
Date: Mar 13, 2014
Service dogs are one of the best ideas going, IMO. My mom's neighbor has a service dog for many needs and it has changed her life. Never heard of a dog drinking coffee (beer yes, but not coffee). I guess it makes him that much more human! Does he fly with guys? -- Jeffrey H. Boatright, PhD, FARVO Associate Professor of Ophthalmology Emory University School of Medicine On 3/13/14 9:42 AM, "William Wynne" wrote: > >Jeff, > >He is not quite that kind of a dog, he is much more likely to sit in your >lap and help you finish your coffee when your not looking. He is very >quiet at airshows, and most people never see him, but people who love >animals pick him up on their radar, and spend a few minutes petting him. >He is a stand in for companions left at home for a week. Many of these >people are not Corvair nor experimental builders, just flyers and dog >people. > >At Oshkosh 2013 a fantastically beautiful woman, reminiscent of Raquel >Welch in '100 rifles' came in the booth and asked to pet the dog. She was >dressed more for a day at the beach than one at a trade show. She sat in >a chair with him and held him against her chest for 20 or 30 minutes >while her husband was checking out turboprops at Dimetech. She rocked him >and sang him a soft song. A bunch of Corvair guys on the other side of >the tent had a hard time keeping mechanical trains of thought going. One >of them finally said "In my next life I am coming back as a small dog." > >A friend of ours from California questioned he is a real 'service dog' >and I showed him the paper work that originated with Grace's country >doctor in our small FL town, stating the dog was anxiety relief. He >scoffed, but I pointed out that the government in his home state of >California has spent 10 years prescribing regulating and distributing >marijuana to people for ailments like low self esteem. Our dog is a lot >less harmful than that. > >To see pictures of Brodhead 2013 and our booth and plane row last year, >get a look at this link: > >http://flycorvair.net/2013/08/12/brodhead-oshkosh-and-beyond-2013/ -ww. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=420271#420271 > > ________________________________ This e-mail message (including any attachments) is for the sole use of the intended recipient(s) and may contain confidential and privileged information. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message (including any attachments) is strictly prohibited. If you have received this message in error, please contact the sender by reply e-mail message and destroy all copies of the original message (including attachments). ________________________________________________________________________________
Subject: Re: Pietenpol article---Smithsonian Air & Space Magazine
from 20
Date: Mar 13, 2014
Great article Mike regards -------- Mario Giacummo Photos here: http://goo.gl/wh7M4 Little Blog : http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420281#420281 ________________________________________________________________________________
Date: Mar 13, 2014
Jeff, Yes, the dog is a Java Junkie, but it isn't on his approved list so he steals it from unattended mugs. You can see his first plane flight at this link: http://www.flycorvair.com/hangar0109.html Don, My experience is that the EAA will support most ideas that don't absorb manpower, which they are short of during Oshkosh. A big part of getting their support is explaining that this isn't something for the 10 guys flying in in their planes, but it is a gathering point to have many people from the Pietenpol community make Oshkosh a specific destination this year. Food for thought: Rather than bringing the EAA's Piet artifacts to the flight line, How about a visit to the Pietenpol hangar? We could pick one evening and have a group photo there, and perhaps we could get inside the rope access. I personally would love to spend a few hours sitting in that hangar, looking at marks on the workbench and walls. I would like to get a lot of detail photos of BHP's plane there, and the hangar. Someone should start a dialog with the EAA about how the Pietenpol community can maintain and improve that hangar, the display, and its contents. Spring and fall weekend work parties? You have a lot better chance of getting permission to land at pioneer airport then. You can ask Doc Mosher for more details, he is well versed in operations at Pioneer airport. In speaking with Doc the other day, we both spent a lot of time on the idea that now 85 years later, near 100% of the people involved with the plane and the legacy of the man arrived in the second half of the 85 years. This means that someone, or in most cases, a chain of someones, people we are too late to thank personally, preserved "Pietenpols" for each of us to 'discover.' Getting your plane done and flying it is the best way to preserve the chain, add another strong link. But there are also many other ways, and not every one of them has to be the titanic effort that Doc and Dee put into the news letter and developing 'the Packet.' There are lots of smaller, good things that people do all the time. If we can weave some of these together at the Hangar at Pioneer airport, good. The structure sits on EAA property, but it doesn't belong to them. It is actually owned by every person who ever unrolled a set of Pietenpol plans at his kitchen table and quietly said to himself "I must build this.....' -ww. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420284#420284 ________________________________________________________________________________
Date: Mar 13, 2014
As Chris and Scott stated I should have the flyer emailed and snail mailed out today or Friday.- I don't know why it's taken me so long this year. T hings have just been busy I guess.- =0A=0AAs just a quick piece of info t he basic details of the event are:=0A=0ADate:- Saturday June 7, 2014=0ALo cation:- Frazier Lake Airpark- 1C9 (near Hollister CA)=0A=0AOur host is Charlie Miller who is based at Frazier Lake.- =0A=0AMore to come in the coming days!=0A=0AMike Groah=0ATulare CA =0A414MV=0A=0A=0A=0A=0A=0AOn Thurs day, March 13, 2014 6:18 AM, AircamperN11MS wrot eld(at)lacity.org>=0A=0AOscar,=0A=0AI also heard from Mike G last night.- He was confirming the final details for the flyer.- =0A=0APIREP from Lancas ter CA.- I gave a couple of rides over the past weekend.- On Saturday I took David Tracy, (yes Chris, your brother) and we flew for an hour or so with a bunch of fun stuff mixed in. dropping in on unsuspecting friends and such.- It was great fun. then Sunday I took up another Dave and we flew for about 0.8 hours.- Just flying around, no landing anywhere since he wa s so heavy.- He admitted to 244lbs.- He filled the whole front cockpit. - He is the heaviest person I have taken for a ride.- It was about 70 d egrees out and my airfield is at 2347 MSL.- The poor plane needed about 9 9% power to remain aloft.- I think the next flight will just be me so I c an remember what a joy it is to fly as a single seat plane.- Gotta do tha t every now and then. =0A=0AOscar, once you get to flying it again you may reconsider selling.- Don't be surprised if you do.- =0A=0ACheers everyo ne and go flying,=0A=0A--------=0AScott Liefeld=0AFlying N11MS since March 1972=0ASteel Tube=0AC-85-12=0AWire Wheels=0ABrodhead in 1996=0A=0A=0A=0A=0A Read this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php - - - - - - - - - - - - - -Matt Dralle, List Admi ===== ________________________________________________________________________________
Date: Mar 13, 2014
Well said, William. Besides having several other airplane and engine projects that I need to get busy on, part of the reason why I have decided to sell my Air Camper is to "preserve Pietenpols for someone else to discover". I see so many wannabes and lurkers on these lists with little more than a set of plans and a head full of dreams. It is almost beyond their grasp to imagine that they could somehow hold down a job, raise a family, pay the bills, and still glue sticks together into the shape of an airplane in the garage. They can scarcely afford to pay for their flight reviews and airman medicals, if they even have those yet. Renting a spam can just to go fly over some pretty countryside for an hour can set them back more than they pay for gas to drive to work, pick up and drop off the kids, buy groceries, and all the rest of it. Flying may be out of their grasp for many decades to come, if they even hold on to the dream that long. I want to find that one person who has the dream, and take them for a ride in my airplane. I'll know if it's the right person, the right fit. One of the best Piet pictures I have is one that I got from Don Emch, and it says everything that needs to be said about this. I never get tired of looking at this picture. See attached. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420286#420286 Attachments: http://forums.matronics.com//files/done_piet2_197.jpg ________________________________________________________________________________
Date: Mar 13, 2014
I can get the stuff from Piet's hangar for display. We can also most likely go there for a group thingy, but from about 9 to 4, it's CLOBBERED with Kidventure, that at this point, ain't gonna change I doubt. They have quite a lot of momentum that prevents an entire change of venue at one time. Like most of airventure, it's volunteer based. I volunteered last year at Kid Venture as well, and it's a different sort of thing. Rather formal and proceduralized partially in the name of protecting kids. They got all upset with my son (who volunteered there as well) because he was wearing the WRONG volunteer shirt... both were given to him at the same time, and same place and were both red. The lettering was different... I'm telling ya, it ain't likely we're gonna get that whole thing to change, and it probably shouldn't although I REALLY think the area could be WAY better utilized. I just had no idea how big of an event the kid venture thing was until I worked over there. I also volunteer during the flying season flying out of Pioneer field. Getting permission to land there is a simple matter of getting an approval from Sean Elliot. However, NO flying other than helos during airventure. I do NOT know anything about the ultralight area, but it does have some appeal to a Piet in terms of an arrival. Different lower, slower, pattern. It's a venue where rides could possibly be given DURING airventure. I gotta say, from an observer's standpoint, those guys look like they're having FUN FUN FUN sun up to sun down. However, don't know about the feasibility of getting a plane from WW's place to there and back sort of thing, which pretty much relegates the Piets to displays for the main event. If anyone does know much about that area (and I think Greg Cardinal does), would love to hear about that. Back to Bernie's hangar. Since I work for Jim Casper, who runs Pioneer, I'd be happy to get the keys and arrange a behind the scenes tour of his hangar. I'm in there all summer long and I gotta say it's a GREAT resource as I build parts for my Piet with that only a few feet away. We'd probably have to do it after Kid Venture closes for the day, which is about when the airshow for the day starts, around 4. A group photo would be cool. Just got a call back from Jim, Dan owns most of Pioneer during Air Venture (he runs Kid Venture...) and he'll check with him and let me know for sure. So hopefully that'll be arranged in the next couple days. The hangar is open during the day, but I think after hours would be better as a private showing. Kinda hard for us to be behind the ropes will a million kids come to and fro... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420290#420290 ________________________________________________________________________________
Date: Mar 13, 2014
Oscar, that's the best way - taking someone up in your Pietenpol and "hooking" them on it. Several years ago, I got an email from a Lurker on the list who lived in Raleigh (where I lived at the time), asking if he could meet me at the airport and take a look at my Pietenpol. I readily agreed to meet him the following Saturday morning. When we got to the airport I could tell from his questions that he was seriously interested in building a Pietenpol. We took plenty of time looking at the plane and I answered many questions. Then I suggested we go for a ride. It was one of those mornings you dream about. 100 mile visibility, no wind and air smooth as glass. We took off from Sanford, NC (KTTA) and headed north, over Jordan Lake. I let him fly it, and that was all it took. His name is Chuck Borsuk and he is now nearing completion of one of the nicest Pietenpols I've ever seen. When he finishes his and flies it to Brodhead for the first time, I'll feel that I've had a small hand in helping to pass on the legacy. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of taildrags Sent: Thursday, March 13, 2014 1:07 PM Subject: Pietenpol-List: Re: 85 years Well said, William. Besides having several other airplane and engine projects that I need to get busy on, part of the reason why I have decided to sell my Air Camper is to "preserve Pietenpols for someone else to discover". I see so many wannabes and lurkers on these lists with little more than a set of plans and a head full of dreams. It is almost beyond their grasp to imagine that they could somehow hold down a job, raise a family, pay the bills, and still glue sticks together into the shape of an airplane in the garage. They can scarcely afford to pay for their flight reviews and airman medicals, if they even have those yet. Renting a spam can just to go fly over some pretty countryside for an hour can set them back more than they pay for gas to drive to work, pick up and drop off the kids, buy groceries, and all the rest of it. Flying may be out of their grasp for many decades to come, if they even hold on to the dream that long. I want to find that one person who has the dream, and take them for a ride in my airplane. I'll know if it's the right person, the right fit. One of the best Piet pictures I have is one that I got from Don Emch, and it says everything that needs to be said about this. I never get tired of looking at this picture. See attached. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420286#420286 Attachments: http://forums.matronics.com//files/done_piet2_197.jpg ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Date: Mar 13, 2014
Said pic taken at Barber Airport, Alliance, OH, one of the 'greats' in grassroots aviation. Kip Gardner On Mar 13, 2014, at 1:06 PM, taildrags wrote: > > > > Well said, William. Besides having several other airplane and > engine projects that I need to get busy on, part of the reason why I > have decided to sell my Air Camper is to "preserve Pietenpols for > someone else to discover". I see so many wannabes and lurkers on > these lists with little more than a set of plans and a head full of > dreams. It is almost beyond their grasp to imagine that they could > somehow hold down a job, raise a family, pay the bills, and still > glue sticks together into the shape of an airplane in the garage. > They can scarcely afford to pay for their flight reviews and airman > medicals, if they even have those yet. Renting a spam can just to > go fly over some pretty countryside for an hour can set them back > more than they pay for gas to drive to work, pick up and drop off > the kids, buy groceries, and all the rest of it. Flying may be out > of their grasp for many decades to come, if they even hold on to the > dream that long. > > I want to find that one person who has the dream, and take them for > a ride in my airplane. I'll know if it's the right person, the > right fit. One of the best Piet pictures I have is one that I got > from Don Emch, and it says everything that needs to be said about > this. I never get tired of looking at this picture. See attached. > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420286#420286 > > > Attachments: > > http://forums.matronics.com//files/done_piet2_197.jpg > > ________________________________________________________________________________
Date: Mar 13, 2014
Mr. Nightmare, Your observation of the missing link of the Beer-Funnel-Hose 'fire triangle' reveals you to be a bit of a pyromaniac, no? Wonderful, we have more of your kind in our camp. I myself have long been the designated driver at airshows, but was once a member in good standing of the congregation who faithfully tithe 10% of their income to the church of Anheuser-Busch. I could once recite the entire 1896 A.E. Housman poem "Terrance, this is stupid stuff" which includes the observation: "And malt does more than Milton can To justify God's ways to man. Ale, man, ale's the stuff to drink For fellows whom it hurts to think." We will be holding Corvair College #29 in Leesburg FL in two weeks; Our local host is an old friend who flew my Piet with me to Brodhead 2000. Arnold is the same man who was the local host of Corvair College#17 in 2010, a bit of a pyromaniac himself. You can see photos of #17 at this link: http://www.flycorvair.com/cc17.html Although we built and ran 20 engines, In the middle the photos show kegs of beer, a bon fire big enough to melt 10 corroded Corvair cases and a late night skeet contest with 12 gauges. Our feelings were hurt when several magazines refused the story, one editor writing back to say that I was the only person in aviation promoting the Alcohol-Firearms and Aircraft combination. My protests that I grew up with Pappy Boyington as a hero and that the editor had the critical sequence reversed, fell on deaf ears. Nightmare, be forewarned, Arnold and his gang could be at Oshkosh, and if you bring that hose, I cannot guarantee Walt-Disney behavior from our people. -ww ------------------------------------------------ PS: Only Colleges at Arnolds are like this, The ones hosted by Pietenpol Southern gentleman extraordinaire P.F. Beck and crew in SC are classy and refined. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420301#420301 ________________________________________________________________________________
from 20
Date: Mar 13, 2014
Watching the photographs of the piets the sentence that said something like "there are not two equals Piets"... look where the control cables come out in the first two Piets.. mine's are like the second one. ;o) regards. -------- Mario Giacummo Photos here: http://goo.gl/wh7M4 Little Blog : http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420302#420302 ________________________________________________________________________________
from 20
Date: Mar 13, 2014
Mario, You have a good eye. The blue airplane belongs to a friend of mine. It is a Grega GN-1. The second plane is a Piet. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420310#420310 ________________________________________________________________________________
Subject: SNF
Date: Mar 13, 2014
Hey all I just want to let all of you dreamers know I am busy cutting up bulkheads for two sets of floats Dave Aldrich and I are going to build in the Wood Workshop at Sun n Fun on April 1-6 this year. If anyone wants to stop by and help or just BS we will be working some long days on this project. Dick N ________________________________________________________________________________
from 20
Date: Mar 13, 2014
Scott: is it just me, or is the gap between the vertical stab and the rudder on Aircamper One-Six-Charlie-Bravo pretty wide? It looks wider than most. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420313#420313 ________________________________________________________________________________
from 20
Date: Mar 13, 2014
Oscar, Dad has a GN-1 also and the gap in his rudder looks a lot like the one you see. I think it is just one of those Grega trademarks. Dad put in foam gap seals on the rudder and elevator. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420314#420314 ________________________________________________________________________________
Subject: Re: SNF
Date: Mar 13, 2014
Oh... that's just mean. DETAILS! Piet floats? Wood floats? That just might entice me down there! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420315#420315 ________________________________________________________________________________
Subject: Re: SNF
Date: Mar 13, 2014
Dick; I'm very interested! Please take pictures of the floats during the construction and I'll be happy to put them up on a website for myself and others to learn from. If these are the straight MukTuk-style floats, the plans leave it up to the builder to determine various things such as the locations for the strut/leg mounting pads, type and style of water rudder, rudder control cables, and a few other things. When I got my plans years ago, there weren't many prefab rudders available but nowadays there seem to be some that can be adapted from kayaks and other such craft. The MukTuk float plans are scaled up or down depending on the required displacement. Are the ones you'll be building scaled for the Air Camper's displacement? -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420316#420316 ________________________________________________________________________________
Subject: Re: SNF
Date: Mar 13, 2014
Oscar and Mike Yes these are the Muk Tuk floats. I will take a pic at least everyday, I will add one extra bulkhead and I have a lot to figure out yet.. Dick N. ----- Original Message ----- From: "taildrags" <taildrags(at)hotmail.com> Sent: Thursday, March 13, 2014 10:12 PM Subject: Pietenpol-List: Re: SNF > > Dick; I'm very interested! Please take pictures of the floats during the > construction and I'll be happy to put them up on a website for myself and > others to learn from. If these are the straight MukTuk-style floats, the > plans leave it up to the builder to determine various things such as the > locations for the strut/leg mounting pads, type and style of water rudder, > rudder control cables, and a few other things. When I got my plans years > ago, there weren't many prefab rudders available but nowadays there seem > to be some that can be adapted from kayaks and other such craft. > > The MukTuk float plans are scaled up or down depending on the required > displacement. Are the ones you'll be building scaled for the Air Camper's > displacement? > > -------- > Oscar Zuniga > Medford, OR > Air Camper NX41CC "Scout" > A75 power > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420316#420316 > > > ________________________________________________________________________________
Subject: Support the General Aviation Pilot Protection Act
Date: Mar 13, 2014
Please sign this petition=2C post it to your FB page=2C then send it to eve ry pilot you know!!! http://govt.eaa.org/14781/support-general-aviation-pilot-protection-act/?m =4503281 Oscar Zuniga Medford=2C OR Air Camper NX41CC "Scout" A75 power ________________________________________________________________________________
Date: Mar 13, 2014
Thanks for a great article. Joe Motis On Thu, Mar 13, 2014 at 3:22 PM, William Wynne wrote: > > Mr. Nightmare, > > Your observation of the missing link of the Beer-Funnel-Hose 'fire > triangle' reveals you to be a bit of a pyromaniac, no? Wonderful, we have > more of your kind in our camp. I myself have long been the designated > driver at airshows, but was once a member in good standing of the > congregation who faithfully tithe 10% of their income to the church of > Anheuser-Busch. I could once recite the entire 1896 A.E. Housman poem > "Terrance, this is stupid stuff" which includes the observation: > > "And malt does more than Milton can > To justify God's ways to man. > Ale, man, ale's the stuff to drink > For fellows whom it hurts to think." > > We will be holding Corvair College #29 in Leesburg FL in two weeks; Our > local host is an old friend who flew my Piet with me to Brodhead 2000. > Arnold is the same man who was the local host of Corvair College#17 in > 2010, a bit of a pyromaniac himself. You can see photos of #17 at this link: > > http://www.flycorvair.com/cc17.html > > Although we built and ran 20 engines, In the middle the photos show kegs > of beer, a bon fire big enough to melt 10 corroded Corvair cases and a late > night skeet contest with 12 gauges. Our feelings were hurt when several > magazines refused the story, one editor writing back to say that I was the > only person in aviation promoting the Alcohol-Firearms and Aircraft > combination. My protests that I grew up with Pappy Boyington as a hero and > that the editor had the critical sequence reversed, fell on deaf ears. > > Nightmare, be forewarned, Arnold and his gang could be at Oshkosh, and if > you bring that hose, I cannot guarantee Walt-Disney behavior from our > people. -ww > > ------------------------------------------------ > > PS: Only Colleges at Arnolds are like this, The ones hosted by Pietenpol > Southern gentleman extraordinaire P.F. Beck and crew in SC are classy and > refined. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420301#420301 > > ________________________________________________________________________________
Subject: Re: SNF
Date: Mar 13, 2014
Dick; probably everything you still need to figure out can be deduced by studying the attached photo. You'll get close enough, anyway. Water taxiing is all about where the step in the floats is placed relative to the CG, and the rest is pretty much figuring out the geometry of the mounting hardware. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420324#420324 Attachments: http://forums.matronics.com//files/bush_float_planes_153.jpg ________________________________________________________________________________
Date: Mar 14, 2014
Chris, David has been fun to hang with. He is very interested in the people, their stories/history and all airplanes, Antiques/Homebuilts and otherwise. It will be great to have him at our airport. I think I still owe you a ride. I don't remember you going up with me last year. We'll get you up this time. See you in June, -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420333#420333 ________________________________________________________________________________
Date: Mar 14, 2014
Subject: Re: SNF
Sure be careful, in the flying and glider magazine one guy rolled his plane over into the water twice because he placed the floats in the wrong place. Blue skies Steve D ________________________________________________________________________________
Subject: Steel Nails and Bulkhead discoloration
Date: Mar 14, 2014
Hi Piet builders, Got a generic wooden plane question for y'all. I have an airframe that steel nails were used to attach a bulkhead to the fuselage framing. The glue joints look good; but, I have discoloration everywhere he put the steel nails. (Note he did end up going to brass, but about half the structure he used steel). Is this something some of you have seen in the past? If so, what are your thoughts? Remove and replace, or seal and monitor? Thanks, Brian Durham -------- Brian Durham Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420346#420346 ________________________________________________________________________________
Subject: corvair engine serial numbers
Date: Mar 14, 2014
Guys I found three motors for sale, the numbers on the block are as follows: To702ZH T0205YR T0 605RB Can anyone tell me if any of these motors will work for a WW conversion? Thanks Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420347#420347 ________________________________________________________________________________
Date: Mar 14, 2014
Subject: Re: corvair engine serial numbers
Bill, Here's a good place to start: http://www.angelfire.com/ca4/CorvAIRCRAFT/EngineID.htm John F. -----Original Message----- >From: Bill R <brcapper(at)gmail.com> >Sent: Mar 14, 2014 2:07 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: corvair engine serial numbers > > >Guys >I found three motors for sale, the numbers on the block are as follows: >To702ZH >T0205YR >T0 605RB >Can anyone tell me if any of these motors will work for a WW conversion? >Thanks >Bill > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=420347#420347 > > ________________________________________________________________________________
Subject: "Hooking them in"
Date: Mar 14, 2014
Thanks Jack for the kind words and the ride. Not sure I can live up to them! Too much pressure!! Here are a few updated pictures. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420350#420350 Attachments: http://forums.matronics.com//files/2014_03_14_134439_800x598_655.jpg http://forums.matronics.com//files/2014_03_14_135140_800x598_114.jpg http://forums.matronics.com//files/2014_03_14_134303_800x598_209.jpg http://forums.matronics.com//files/2014_03_14_135047_800x598_344.jpg http://forums.matronics.com//files/2014_03_14_135032_800x598_151.jpg ________________________________________________________________________________
Date: Mar 14, 2014
Scott Closest I came to a ride in your plane was this, http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0512.JPG I realized Sunday morning as you were getting ready to leave that I forgot to get a ride. Sure sucked to be left standing on the ground as everyone flies away. I guess I need to build faster. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420352#420352 ________________________________________________________________________________
Date: Mar 14, 2014
ZH = '64 95HP powerglide YR = '60-'63 turbo RB = '65-'68 manual, 140HP There are more suitable candidates than any of these. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420354#420354 ________________________________________________________________________________
Date: Mar 14, 2014
Nice! Love the wood struts! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of cjborsuk Sent: Friday, March 14, 2014 12:49 PM Subject: Pietenpol-List: "Hooking them in" Thanks Jack for the kind words and the ride. Not sure I can live up to them! Too much pressure!! Here are a few updated pictures. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420350#420350 Attachments: http://forums.matronics.com//files/2014_03_14_134439_800x598_655.jpg http://forums.matronics.com//files/2014_03_14_135140_800x598_114.jpg http://forums.matronics.com//files/2014_03_14_134303_800x598_209.jpg http://forums.matronics.com//files/2014_03_14_135047_800x598_344.jpg http://forums.matronics.com//files/2014_03_14_135032_800x598_151.jpg ________________________________________________________________________________
Date: Mar 14, 2014
Hopefully, that's a pic of two Piets climbing out...not maintaining alt! Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Catdesigns Sent: Friday, March 14, 2014 12:57 PM Subject: Pietenpol-List: Re: West Coast Piet fly-in 2014 Scott Closest I came to a ride in your plane was this, http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0512.JPG I realized Sunday morning as you were getting ready to leave that I forgot to get a ride. Sure sucked to be left standing on the ground as everyone flies away. I guess I need to build faster. -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420352#420352 ________________________________________________________________________________
Subject: Re: "Hooking them in"
Date: Mar 14, 2014
Chuck, It's gonna be a sweet flyer. I can tell just by the looks of it! Dan Helsper Puryear, TN -----Original Message----- From: cjborsuk <cjborsuk(at)yahoo.com> Sent: Fri, Mar 14, 2014 2:54 pm Subject: Pietenpol-List: "Hooking them in" Thanks Jack for the kind words and the ride. Not sure I can live up to them ! Too much pressure!! Here are a few updated pictures. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420350#420350 Attachments: http://forums.matronics.com//files/2014_03_14_134439_800x598_655.jpg http://forums.matronics.com//files/2014_03_14_135140_800x598_114.jpg http://forums.matronics.com//files/2014_03_14_134303_800x598_209.jpg http://forums.matronics.com//files/2014_03_14_135047_800x598_344.jpg http://forums.matronics.com//files/2014_03_14_135032_800x598_151.jpg ________________________________________________________________________________
Date: Mar 14, 2014
Looks really nice, Chuck. Looks like you're about at the 90% done, 90% to go stage. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of cjborsuk Sent: Friday, March 14, 2014 3:49 PM Subject: Pietenpol-List: "Hooking them in" Thanks Jack for the kind words and the ride. Not sure I can live up to them! Too much pressure!! Here are a few updated pictures. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420350#420350 Attachments: http://forums.matronics.com//files/2014_03_14_134439_800x598_655.jpg http://forums.matronics.com//files/2014_03_14_135140_800x598_114.jpg http://forums.matronics.com//files/2014_03_14_134303_800x598_209.jpg http://forums.matronics.com//files/2014_03_14_135047_800x598_344.jpg http://forums.matronics.com//files/2014_03_14_135032_800x598_151.jpg ________________________________________________________________________________
Date: Mar 14, 2014
Yes Gary during climb out. You trying to start something???? Smart guy :) -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420361#420361 ________________________________________________________________________________
Subject: Re: Steel Nails and Bulkhead discoloration
Date: Mar 14, 2014
Brian, The nails don't provided any structural strength. Some guys remove all the nails for a small weight savings. Some just leave them in. Since you live in a damp area I would go ahead and remove all that you can then sand the ugly off and reseal. I would hate to have a nail head rust off then Polk through the fabric. I'm not sure there is really a right answer to your question. Just personal preference. My 3 cents. Good luck. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420363#420363 ________________________________________________________________________________
Date: Mar 14, 2014
Gary, Are you going to Woodland tomorrow? Ray Sent from my iPad > On Mar 14, 2014, at 3:23 PM, "Gary Boothe" wrote: > > > Hopefully, that's a pic of two Piets climbing out...not maintaining alt! > > Gary Boothe > NX308MB > > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Catdesigns > Sent: Friday, March 14, 2014 12:57 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: West Coast Piet fly-in 2014 > > > Scott > > Closest I came to a ride in your plane was this, > http://www.westcoastpiet.com/images/WCP_2013_Gathering/IMG_0512.JPG > > I realized Sunday morning as you were getting ready to leave that I forgot > to get a ride. > > Sure sucked to be left standing on the ground as everyone flies away. I > guess I need to build faster. > > -------- > Chris > Sacramento, CA > WestCoastPiet.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420352#420352 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 15, 2014
If you are confident the wood is sound I wouldn't worry too much about it. If you don't like the stain and want to get rid of it you can get a two part wood bleach by Kleen Strip that will remove the rust stains and make the wood look new again. I've used it on spruce and it works wonders. Just be sure to use rubber gloves as it your skin too! :-/ Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420365#420365 ________________________________________________________________________________
Subject: Re: 85 years
Date: Mar 15, 2014
Oscar, I can't believe that picture was taken eight years ago! I've since added a fourth kid to the fleet. My daughter in the front seat is now nearly 5' 10" tall. The others are on their way to that too. I've been very blessed to be able to do this hobby while raising my family. They've been involved all along the way. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420366#420366 ________________________________________________________________________________
Date: Mar 15, 2014
If the structure is sound, just leave it alone. The nails and stain will not hurt anything. Adding compounds to remove stain can damage the wood fibers. I think the staining with some varnish applied over them will give it an antique look. You can always paint. Move forward, not backwards ;) WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420367#420367 ________________________________________________________________________________
Subject: Re: SNF
Date: Mar 15, 2014
Try Zenair Floats @ WF2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420368#420368 ________________________________________________________________________________
Date: Mar 15, 2014
From: "Charles N. Campbell" <charlescampbell1924(at)gmail.com>
William, your dog looks suspiciously like my dog, Pippa. She is half Bijon and half Maltese. They call it a new breed called Maltachon. Incidentally, I have a Corvair type question for you. If OK I will ask it here. I put a 5th bearing on my engine but had already mounted the rear section. I then put on a high volume oil pump. In one of your posts you mentioned that with the larger pump you need to drill a larger hole somewhere in the rear section which I can't do without disassembling the engine. Should I use the high volume pump without the larger hole or revert to the standard pump? Chuck On Thu, Mar 13, 2014 at 12:31 PM, William Wynne wrote: > > Jeff, > > Yes, the dog is a Java Junkie, but it isn't on his approved list so he > steals it from unattended mugs. You can see his first plane flight at this > link: > > http://www.flycorvair.com/hangar0109.html > > Don, >
March 06, 2014 - March 15, 2014
Pietenpol-Archive.digest.vol-nh
